AeroElectric-Archive.digest.vol-ah
July 30, 2001 - September 15, 2001
True
>My battery box is in the standard RV-6 location, just behind the firewall with
a 4 ft. total run to the starter. The conduit to the battery contactor is only
12" long, the positive battery lead ends there while the negative lead continues
on to the firewall ground block.
Okay . . . I think you're going to be in good shape.
( "The Wright brothers flew right through the )
( smoke screen of impossibility." )
( Charles F. Kettering )
http://www.aeroelectric.com
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Hi guys,
I've a lurker here for a few weeks, as I try to learn what these egyptian notations
mean on schematics.
As a "newbie" I would like to thank Bob for incredible level of assistance
that he provides here.
Warren.
Subject: | Re: Antenna/strobe interference |
As one data point, a local RV-8 is flying with wingtip strobes and comm
antennas, no interference. I did take the time to shield the leads from the
(in wing) strobe power supply to the strobe elements, routing the lead as
far away from the antenna as space allowed.
Side note - so far the observed coverage from the wing tip comm antennas has
been good.
Carl Froehlich
RV-8A (systems install)
Vienna, VA
----- Original Message -----
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Sent: Monday, July 30, 2001 1:17 PM
Subject: AeroElectric-List: Re: Antenna/strobe interference
> >Thanks for the prompt reply and I found more information upon rereading
my
> >'Connection #9 late last night.
> >I wasn't going to bother with VOR at all-what with all the mountains
ringing
> >us here in Vancouver-the antenna was going to be a comm.
> >Sounds like it won't work .
> I'd get on the RV-list and see what other folk's
> experiences have been. The noise levels may be
> acceptable to most users. In any case, I'd go ahead
> and try it. The worst thing that happens is that you
> have to add a fuselage mounted antenna at a later date.
> Bob . . .
From: | "jayeandscott" <jayeandscott(at)home.com> |
Thanks-I'll give it a try.
From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com>
Sent: Monday, July 30, 2001 10:17 AM
my
ringing
> Bob . . .
Thanks Carl- sounds encouraging!
Sent: Monday, July 30, 2001 10:47 AM
Subject: Re: AeroElectric-List: Re: Antenna/strobe interference
the
has
> been good.
> Carl Froehlich
> Vienna, VA
> To:
> my
> ringing
> > Bob . . .
Good Afternoon Bob,
Thank you for your help on this and all the other help you have given me on
my RV4 project! I installed the 270-030A choke and it cut the noise by 80 to
90 percent. The supplied capacitor does not have a + or - on it. It has a
bar with two zeros on it and arrows. Need help here! One end has a
indentation around it. Am I correct that one end goes to the wire and the
other end to ground?
Best regards,
Bruce Bell
Lubbock, Texas
Sent: Monday, July 30, 2001 11:23 AM
Subject: AeroElectric-List: Re: Radio Noise
> >Good Evening Bob,
> >Want to get your thumbs up on this! After I powered up the "4" with your
> >power supply I started checking things out. The Val Com 760 radio has a
loud
> >hum or noise in it. Volume control made no difference on intensity. Fuses
> >were pulled till I found the RMI Encoder and RMI Monitor both produced
the
> >noise. A call to Val Com and their Bob suggested a Radio Shack choke #
> >270-030A in the power line would do the job. I haven't done that yet,
just
> >wanted your input.
> >Best regards,
> >Bruce Bell
> >Lubbock, Texas
> >AOA has a woman in it. Talks to me every time I turn on the master
switch!
> Hmmmm . . . I'm disappointed that the VAL Com product is
> vulnerable to this. Sounds like they didn't do their homework.
> Try the choke (and the capacitor that comes with the kit).
> Put the choke in series with the power coming into the radio
> and the capacitor in parallel with the power on the radio side
> of the choke . . the capacitor is polarity sensitive so observe
> it's markings.
> Let me know how this works.
> Bob . . .
>Good Afternoon Bob,
>Best regards,
>Bruce Bell
the bar with the arrows probably points to the
end of the capacitor that simply terminates the
leadwire in the center of the aluminum can. Often
times the arrow has (-) signs printed on it. This
will be ground.
The (+) end of the capacitor will be insulated from
the aluminum can and will have some sort of obviously
non-aluminum material around it. Often this is a black,
hard paper, sometimes an plastic like epoxy seal.
>Hi guys,
notations mean on schematics.
>Cheers,
>Warren.
I'm working on revision 10 to the AeroElectric Connection. Chapter
1 is the BIG project . . . it's being updated to include information
on schematic symbols and the components they represent. Looking to go
to press about end of August.
In the mean time, check your local library for electronics experimenter's
and hobbyist publications. Amateur Radio Handbooks by the American Radio
Relay League and Radio Society of Great Britain are often found on
library shelves and would be good resources. This kind of information
is almost always found in Chapter 1.
Are you building an airplane?
Subject: | This new email format is a loser |
I notice that we now get email that do not identify them selves in to from
or subject as relating to this forum. This makes it difficult to filter them
into the right folder.
Why the change?
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert
L. Nuckolls, III
Sent: Monday, July 30, 2001 10:18 AM
>Thanks for the prompt reply and I found more information upon rereading my
ringing
I have purchased a Sonerai IIL that I am rebuilding the engine on, and in the
process, finding "situations"
in the electrical side of things that don't look very good even to my untrained
eye. Anticipate redoing most if
not all of the wiring. Have learned a great deal by burglarizing the advice that
comes by here. Thanks again.
Warren
> Bob . . .
>Bob,
the process, finding "situations"
>Cheers,
>Warren
Check the down-loadable materials at www.aeroelectric.com
Given the relative size and complexity of your
project, I can suggest that a fresh start wouldn't
be out of line. What engine goes in your airplane?
Subject: | Re: This new email format is a loser |
>Why the change?
I'm not aware of any change. Arrivals to my email application
look just like they did from the beginning. How long has the
"new" format been plaguing you? Do you have another e-mail
application you can try to see if it's something local to your
computer?
Mine filter just fine - what change are you referring to? I've not noticed any.
Reading this thread has stimulated my curiosity. I also have a ValCom
760 and now have a loud (more of a scream than wine) when I switch on the
alternator. I never noticed it when using my handheld as my main com
unit. I thought well it could be a lot of things as it is a homebuilt and
many people have had a hand in it somewhere. While I can do just about
anything, I am not good at doing anything and it could well be my fault.
However the radio is quite when the alternator switch is off. I have not
tried plugging the headset directly into the aircraft jacks and bypassing
the Flight Com portable to see if it still present but I have a gut
feeling it is not the intercom. I am wondering if there could be a
similar solution to solving the scream in my ears.
Also would like to know if others using the ValCom are generating a lot
of heat from the radio, and should I force cool it?
Jim
Wittman Tailwind
Subject: | Negative Battery Cable |
I'm building an RV8A and need to place the battery behind the rear
baggage compt for weight and balance. The starter relay and master relay are
mounted on the battery box. I'm running #2AWG to starter & #6AWG to main
buss/ alternator.
Unless you give me some very good reasons for not doing so; I'm planning
on using a short piece of #2AWG from the batt neg to a fuselodge stringer
and let the fuse be the neg lead.
That much aluminum should equal a #0000 welding cable.
I did this 7 years ago on the Avid I built and haven't had a speck of
trouble even though Sae4130 isn't near as good of conductor as aluminum.
Most of the people building RV's are running separate ground cable and
even separate grounds all the way out to wingtip nav lights.
What are your thoughts on the matter?
Thanks, Esten Spears,
Subject: | Val Com 760 Noise |
Good morning Bob,
Installed the capacitor as instructed. Results are, with RMI encoder and
Monitor off, no noise. With both units on a little noise. This is about 95
percent better than before the Radio Shack kit #270-030A Filter kit was
installed. The Encoder makes a little more noise than the Monitor. 760
volume control makes no difference on the noise. Remains the same with
volume set high or low. The test conditions are- power is supplied with your
power supply, in my garage and through the 403mc intercom. With the engine
running and the four exhaust pipes banging at my feet I don't think I will
hear the radio noise. But from a purist of view the noise is still there!
Best regards,
Bruce Bell
Lubbock, Texas
Smoke test in progress!
Subject: | Val Com 760 Radio Noise |
Just had a conversation with Ron at RMI. He ran me through the procedure to
turn off the back lighting on the RMI Encoder and Monitor. That was causing
the noise in the head set. He said I needed to run the audio input from the
Encoder and Monitor directly to head phone jack. I ran it to the 403mc aux
pin. He said his units are set up to drive the audio directly to the head
phone jacks. So things are starting to come together. You got to love this
list!
Haven't shot myself yet!
Bruce Bell
Lubbock, Texas
Subject: | Re: Val Com 760 Noise |
>Good morning Bob,
Did you do the "lantern battery" test? Did the noise go away
completely then? It would be interesting to see if the noises
go away when the perpetrators are powered by lantern battery
and the 760 is running from the bus. Also, when doing the
lantern battery test, make sure the power ground for the device
being tested is still hooked to your panel ground. Just for grins,
it would also be interesting to know if another 270-030 kit installed
on the noisemakers would finally get the noise down to inaudible.
Sorry if I seem to be creating a big science project for you . . .
not many builders take advantage of ground power supplies
to find out how good or bad their systems really are with respect
to inter-system noise effects.
I'm glad that the improvement was profound . . . but I'm disappointed
that the the three products are so incompatible . . . either the
Encoder and Monitor put out too much noise or the 760 is too sensitive
to noise . . . or both. It's a pretty funky deal when customers
have to go to such lengths to accommodate the manufacturer's shortcomings.
You're probably right in that the remaining noise will become insignificant
when the engine is running. If it's any consolation, there are some
damned expensive heavy iron that suffer similar situations that
have been deemed "insignificant" after the engines are started.
An interesting data point . . . when combined with Mr. Bell's experience,
it reinforces a notion that perhaps the ValCom radio is the more
guilty appliance. You might try the Radio Shack 270-030 filter
on your radio and see what transpires.
This radio is all solid state and should draw less than 200 mA in
the receive mode. This is about 3 watts dissipation inside
the radio . . . it shouldn't need cooling.
Are there any other ValCom users out there with noise experiences
to share?
From: | "Clifford Begnaud" <shoeless(at)barefootpilot.com> |
> to share?
> Bob . . .
Yup, my val com 760 picks up noise from the ignition and the strobles. I
have a Rotax 912 in a model 5 Kitfox. I also get noise from the intercom. I
may try the filter you mentioned. Strangely, the noise is intermittent.
Sometimes it's almost non existant, but most of the time it's there.
Cliff
> to share?
Also, I am building the RMI engine monitor - anyone else report noise from it?
Gary Liming
I was thinking maybe the lights that display the frequencies was
generating the heat, is that possible? If so is it nothing to worry
about? No complaints from ATC yet.
To reiterate though, once I toggle off the alternator the scream goes
away. I will ad the filter and see what happens.
Jim
writes:
> experience,
> lot
> to share?
> Bob . . .
From: | "Harley, Ageless Wings" <Harley(at)AgelessWings.com> |
>>Are there any other ValCom users out there with noise experiences to
share?<<
On the other hand, are there any out there who feel that the Val Com 760 is
the way to go? I am at the point in my Long Ez project to start installing
the avionics and instruments that have been quietly waiting on a shelf for
the last 15 years. Somehow, I don't think my old, 360 channel, tube filled
Narco 12A is going to hack it!
I've been checking out the Val Com 760 in the Spruce catalog because of it's
price and size, and also possibly the Micro Air 2-1/4 inch model.
The Val Com appears to be an 8 watt, single display unit, while the Micro
Air is a 7 watt, dual display.
Any comments?
Harley
http://www.AgelessWings.com
Using RMI Uencoder and Engine analizer with great results! Harmon Rocket N540RM
> > to share?
> Gary Liming
>share?<<
>Any comments?
The MicroAir is only a 4watt radio but it doesn't matter.
See:
http://www.aeroelectric.com/Catalog/avionics/760vhf.html
We've sold about a dozen of these radios but I suspect only
about half are flying yet. Of those who are using them, I've
had no reported noise issues. The next time I get into
the EMC lab at RAC, I'm going to run the noisy-bus test
on this radio for myself and see how well Microair did
their homework.
Thanks for the quick reply, Bob...
Didn't realize you sold the Micro Air until after I read your reply!
And that recommendation from Jim Weir is probably the best selling
point...after all, his antenna is currently buried in my winglet
Well, the Micro Air is smaller, lighter and has more features, but is the
extra $200 more than the Val Com worth those extra features? Or, conversely,
is it a "you pay for what you get" with the noise problem that some are
currently seeing with the Val Com an example?
>>I'm going to run the noisy-bus test on this radio for myself <<
I'll be waiting for your report, meanwhile, I'm searching the cushions for
coins!
Harley
Subject: | Re: RE: Radio Noise |
*** Just curious,
What is the noisy-bus test? Back when I was programming railroad
equipment for fun & profit, we had two basic noise tests:
* The engineer had a CB radio with a rubber duck antenna at the end
of a four-foot coax. He'd stick that sucker inside our unit, transmit,
and poke around for RF on the traces.
* He also had a relay wired up to turn itself off. It would buzz like
a banshee. There was also a capacitor in there to make it ring more.
It may seem primitive, but he created some of the cleanest, most reliable
electronics I ever saw. The pulses looked like out of a textbook.
- Jerry Kaidor ( jerry(at)tr2.com )
I am very happy with the service from ValCom people and very happy with
the ability of the com itself. I suggest buying the intercom module,
frequency hold and harness. I did my own and cost twice as much in
frustration and time.
just an opinion mindya
Jim
writes:
> to
> share?<<
> 760 is
> installing
> shelf for
> filled
> of it's
> Micro
> Any comments?
> Harley
Hi Bob
Placed an order for the book & CD on July 1. No major rush other than
personal impatience; I'll wait for the latest to save an update. I seem
unable to email you from work or home; with an immediate bounce "destination
mail server refused to accept it."
Peter Eedy
pecch(at)ozemail.com.au
Griffith. NSW. Australia.
Sent: Tuesday, July 31, 2001 10:39 AM
Subject: AeroElectric-List: Re: Assistance
>>Lots of good stuff clipped.
> Bob . . .
Mornin', Jim...
the ability of the com itself.<<
Thanks for the advice...I did a little inet searching yesterday, including
Val Com's web site, and found that a lot of people are using them and not
saying much about it...I guess that means that they've had no problems with
them...or they are just sitting on a shelf somewhere! Seem to be more of
them around than the Micro Air, too. I've seen prices on them as low as
$400 new, and $250 used.
Still looking for coins under the cushions here!
Harley
Subject: | marker beacon receiver |
I wanted to install a marker beacon antenna with in my fiberglass
wingtip. Using foil tape what would be an apprropriate length. I have a
58" chord to work with (RV series).
Thanks Rob
Hi All,
Seeing that I started this thread please let me make a couple of comments.
1. I picked the Val Com 760 as I have been using one in my A35 Bonanza for
the past 12 years with out any problems and the price is right.
2. My conversations with Val Com have been very helpful and they are quick
to say "send it back and we will fix it". Warranty starts when the power is
first turned on, not date of sale. Customer service is excellent! Would I
buy another? Yes!
3. RMI is a customer service operation. Ron and his Girl Friday have always
helped me and solved any problems I have had. From the start Ron said to
connect the audio out puts directly to the headphone jack. I did not do
this, but will. When I do I will make a report. Ron talked me through the
procedures to turn the back lighting off. Read the manuals it is in there!
Would I buy RMI again? Yes!
4. Bob Nuckolls has to be a Saint to hang in there with some of the
questions I have asked him. He does this in his spare time! Thank you Bob
for all your help.
Back to the RV4.
Bruce Bell
Lubbock, Texas
Subject: | Re: marker beacon receiver |
Rob,
The equation for a 1/4 wavelength antenna is:
Length (ft) = 234/frequency(MHZ)
For MB (75 MHZ) this gives length of 3.12ft. This is an approximation
for a thin antenna in free space. For a fat (in this case foil tape) the
actual resonant length for 75 MHZ will be shorter, perhaps 5-10% or so. How
you mount it will also affect the resonant frequency. If there is
capacitive coupling to the rest of the plane, this will also make the
antenna too long for the desired frequency.
The easiest thing to do is mount a 3ft or so long length in the wing
tip, feed it from a connector attached (shield grounded) to the outermost
rib. The antenna attaches to the center pin on the outboard side of this
bulkhead BNC connector. Use an SWR analyzer if you can borrow one and
measure the actual resonant frequency. If too low, trim a 1/4" or so off at
a time until you are close to 75MHZ.
For practical installations, this is not a critical antenna. MBs
radiate a relatively huge amount of energy straight up. A not so perfect
antenna should fill the function as well as a finely tuned one. Don't worry
if you can't find an SWR analyzer, make the antenna and see if it works.
Carl Froehlich
Vienna, VA
Sent: Thursday, August 02, 2001 9:19 AM
Subject: AeroElectric-List: marker beacon receiver
> Bob,
> Thanks Rob
I have installed one of Bob's Microair units in my Nesmith Cougar, replacing
an older but very noisy radio. Bob also supplies a prewired harness which
was easy to install.
The result is one of the quietest small aircraft radios that I have ever
used. The built in Microair intercom is also very good when used with a
press to talk switch.
The only shortcoming that I can see is that it would be nice if the radio
had a built in aux input for music.
Its a great little radio
Thanks Bob
Jim Corner
> See:
> their homework.
> Bob . . .
Does anyone know anything about their transponder yet?
~Warren
Subject: | impulse couplings |
I have impulse couplings on both mags, and am wondering how to wire my ACS A-510-2
ignition
switch. The instructions say to use a jumper on the right mag terminal when the
left has impulse
coupling. It looks like this jumper grounds the right mag when "Start" is selected,
and all I
need to do is leave the jumper off to have both mags active when starting. Is
this correct?
Thanks.
http://phonecard.yahoo.com/
Subject: | Rotax 912 Regulator |
I'm running a 912 in my kitfox and noticed some strange behavior lately. The
voltmeter will show low voltage as if the alternator were not working then
suddenly the voltage will go up to normal and I'll start hearing the normal
whine in the headset. It will run a while then go low voltage again. It just
continues to do this off and on during a flight, though it has kept the
battery charged.
Does this sound like a bad regulator? How can I test this or fix it?
thanks,
Cliff
Subject: | Re: impulse couplings |
ignition
left has impulse
and all I
this correct?
>Thanks.
If you have impulse couplers on both mags, you don't use the
kill-during-start jumper for the right mag.
Subject: | Re: Rotax 912 Regulator |
>battery charged.
>thanks,
>Cliff
I'd sure check over the wiring . . .you may have an
intermittent connection. As I recall, that regulator
is potted and not repairable.
>Rob,
Marker beacon signals are HUGE . . . you're passing right over
a 5 watt transmitter with a gain antenna pointed straight up.
A wet string would probably pick up this signal. I've had
a number of builders with plastic (glass and epoxy - NOT grahite)
airplanes simply plug a 40" piece of wire into the antenna jack
on the marker beacon receiver and tape it to the inside of the
fuselage in a way that routes it as much as possible from other
wiring or conductive components.
One builder mounted his receiver in the tailcone behind the
seat and ran his 40" piece of wire aft down the side, above
flight control cables. He say's it worked really well. Carl's
advice is well given . . . give it a try and see what works.
I wouldn't go so far as to run a feedline out to a wingtip.
This is much more complicated than it needs to be.
>Thanks Bob
>Jim Corner
I've got the parts laying on the bench for a do-it-yerself
audio isolation amplifier that will combine several radios,
stereo audio and warning tones into your headset system.
I'll use the "cladboarding" technique described in an article
http://www.aeroelectric.com/articles/cladboard/cladboard.html
and using a diagram similar to:
http://www.aeroelectric.com/articles/audio/760v4.pdf
Maybe I can get to it this weekend and put instructions
up on the website.
Subject: | Re: Microair Transponder |
>~Warren
I have an open PO with my distributor for 3 of these little
critters as soon as they're in-country. . . .
Will post available notice on this list and on my website.
Subject: | Re: Radio Noise & New Article on Website |
>*** Just curious,
Both of these techniques are excellent first-look
activities to flush out potential problems. Similar
tests have been recommended many venues for years.
I've just formalized a Aero-Electric List post on DO-160
to my website. You can get this document at:
http://www.aeroelectric.com/articles/do160.html
The "noisy bus" test I'll do on the Microair will be to inject
square wave stress into the 14v power lead with an amplitude and
frequency curve recommended by DO-160. Another test will use the
"buzzing relay" stress you've described above.
Subject: | Tiny tach for lycomings |
Has anyone successfully used the Micro-1000 electronic tach from Aircraft Spruce
on a Lycoming
O-320? I have one and it doesn't work. I am trying to find out if it is defective
or
incompatible in some way. I have a call in to the manufacturer, Design Technology,
but have not
heard back from them yet.
Thanks.
>> to share?
>> Bob . . .
>Cliff
Hmmmm . . . the intermittent feature is interesting. Does
the volume knob on the radio make any difference in the
amount of noise you hear or is it there even with the
volume turned all the way down?
Subject: | Re: marker beacon receiver - part II |
I see I missed getting the metal airplane case covered
on marker beacon antennas . . .
If you have a metal airplane it's worth trying an antenna
under a fiberglas wingtip. I think I'd use an antenna
analyzer to optimize it. Due to close poximity of
metal wing and tip-rib close out, the 40" of wire
won't even be close.
Run the coax shield to ground at the tip rib. Extend
the center conductor on a piece of cardboard, plexiglas,
fiberglas sheet, or some other suitable "shelf" bolted
to the tip rib and shaped so that it fits inside the tip
fairing. This will let you tune the antenna while the fairing
is removed and get it real close to optimum. You'll find that
installing the tip fairing will make the antenna too long
due to loading effects of wiring to lights on tip. It might
take several installation and removal cycles of the tip
to do a final trim of the marker beacon antenna's length.
Bob. . .
Subject: | WEEKEND SEMINAR - Racine, WI 2 WEEKS! |
The next weekend seminar we're presenting starts two
weeks from tomorrow, August 18, in Racine, WI.
Dee and I will be driving from Wichita and we'd
like a chance to meet many of you and talk about your
project.
We're meeting on the John H. Batten airport. Some
of you may be able to fly in daily and join us for
some down and dirty electro-speak. See:
http://www.aeroelectric.com/Racine.html
for times, location and local hotel information.
[...description of tweeking and pruning...]
*** Gee, if this wasn't a highly critical aircraft application, I'd be
tempted to try a nonresonant voltage probe antenna feeding an emitter
follower that would drive the MB receiver input. No peaking, no tweeking...
Subject: | WEEKEND SEMINAR - Need list server relay |
I used o participate in about a dozen list-server
activities but he e-mail burden became too much.
Matt Dralle graciously offered relief with his support
of the Aero-Electric List. I would sincerely appreciate
it if the folks who frequent the Aero-Electric List
could relay the following information to other amateur
built airplane list-servers on which they participate:
Thanks!
----- Electrical Systems Weekend Seminar -----------
project.
Subject: | New Article on Website |
Hi Bob, and List,
On your new entry for the DO-160 (thanks a bunch, especially for the link
to RTCA) on your website, you write:
>The solid state power distribution assembly for a new target I'm working
on is ALL d-sub >connectors in spite of the fact that three outputs are
rated at over 20A continuous and one
>input is rated for 40A continuous. There are ways to make this work that
allow you to take
>advantage of a wide variety of relatively low cost connectors and tools
with military qualified
>pins at the critical junctures in the connector.
I could use some simple guidance here - assuming one correctly applied pin
on both sides of the connector, how much current can I safely pass through
one of them before needing to split the power connection between two
pins? or Three? or Four? Why not keep power on good ole AMP/Molex
connectors?
Gary Liming
From: Andrew Larkin <aj_larkin(at)yahoo.com> Subject: AeroElectric-List:
electronic tach from Aircraft Spruce on a Lycoming
is defective or
Technology, but have not
Thanks.
Andrew,
I had purchased a Micro-1000 tachometer from Aircraft Spruce and ended
up
returning it when I found a tach from Van's aircraft. The Van's tach is
more appropriately marked for the Lycoming O-320. Van's tach is also
available with a 12" extension cable so that you can mount the signal
generator on the firewall if necessary. You can check it out on their
web site. It is a very nice looking 2 1/4" instrument and less expensive
than the Micro-1000. Van's also has a line of 2 1/4" gauges that are
full sweep electrical gauges. I would have used all of his gauges had I
seen them before purchasing another brand. I would try to return the
Micro-1000 assuming that you have not beat it up.
I buy almost exclusively from Aircraft Spruce and Specialty. While I have
had some minor problems, their customer service has been excellent and
whenever I have had a problem they always bent over backwards to correct
any issues. As always, you must be an informed consumer. Their company
also supports and sponsors many aviation activities and I believe in
supporting them as a show of appreciation for their commitment to
general and experimental aviation.
Good luck,
Rick D.
Murphy Rebel N754SM
The
normal
just
> battery charged.
> thanks,
> Cliff
I had a very similar problem with my 582 powered Kitfox. After replacing
the Voltage regulator with no results, I finally traced the problem to the
Voltmeter itself, and the strange headset noises disappeared. The odd thing
was that whenever I connected my portable voltmeter in paroled the problem
would never appear. I finally reasoned that with the voltage deviations
(down to about 8 volts) that I was getting and a battery in the circuit
there had to be a serious short in the wiring (not evident) or the voltmeter
was the problem.
Good luck
Jim Corner
From: | Graham Singleton <grasingleton(at)avnet.co.uk> |
Subject: | Re: New Article on Website |
> >input is rated for 40A continuous. There are ways to make this work ,
>Gary Liming
I used to think that splitting power connections was not good practice
because if one line/connector fails you would not know about it until the
remaining connectors started to overheat. Is this wrong?
Graham
Subject: | Re: D-subs versus others . . . |
For the target project, I derated D-sub pins to 4A. For larger
current requirements, I parallel whatever is necessary to keep
individual pin loading to 4A or less. To parallel two pins,
you need to swamp out the small variation in resistance from
pin to pin. It's seldom satisfactory, for example, to simply
short an array of pins together at the back of the connector
and expect current through the array to distribute evenly
across the array.
Taking a cue from past tasks where I needed to parallel multiple
transistors in a power control circuit (we added small value ballast
resistors in series with the emitter lead of each transistor) I
reasoned that we can short all the pins together at the connector
on one half (in this case the etched circuit board side). For
the mating connector, each pin gets a 22AWG wire about 10"
long. The array of wires is joined to a common butt-splice.
The other side of the butt splice carries on with the size
of wire appropriate for the circuit's total current.
The approximately 10 milliohms of wire resistance offered by
each pigtail has the same effect as the ballast resistors
in an array of paralleled transistors. Tiny variations in
resistance from pin-to-pin a insignificant compared to the
value of the ballast resistance.
>connectors?
The D-sub connector is compact. You can get very high
quality gold plated pins for them. They're easily worked
with low cost tools . . . even if you use the machined
pins. The AMP Mate-n-Lock and Molex connectors don't
come in right angle PC mount versions. Their contact
density is much lower than the D-sub. I don't think you
can get them in greater numbers than 12 contacts per
plug/socket.
If you're building a product where you'd like to mix
high current (10A+) wires in with small signal wires,
the AMP/MOLEX solutions will either have you paralleling
conductors in the small pins -OR- having to upsize the
connector just because you have one or two wires out
of the total that carry heavy current.
The D-sub solution offers a fair selection of connector
sizes (9, 15, 25, 37, 50) and a large range of connector
configurations that let you deal seamlessly with
panel mount, ecb mount and cable mounted versions.
You can easily intermix micro-amp signal and control
with some rather hefty power wiring with a single
technology.
There are some new circular connectors from AMP that
use the same pins as the D-sub . . . these too might
be considered for similar treatment . . . I'm not
sure if AMP offers any ECB mount versions yet . . . and
it's unlikely that there will ever be a right-angle
ECB version.
All things considered, in spite of the ugly hole you
have to cut to mount a D-sub, the availability of
low cost, high quality pins and inexpensive tooling
combine to make them attractive for a broad
range of applications.
Not sure that wouldn't do just fine. You could transorb protect
the transistor. Why don't you check this out and feed me the
results for an article we can publish.
Another option is a tuned ferrite rod antenna. I think there
were a number of commercial products that provided a reduced
volume antenna for marker beacon receivers using this
technology. You could house it in a small bubble on
the bottom of the fuselage or hide it in a wingtip.
Another interesting antenna I've seen is a "u-channel"
of aluminum about 10" long inside the fuselage that peers
out through a fiberglas window in the fuselage lower
skin. The channel is closed at both ends and has a center
conductor grounded to an end plate at one end and
tuned to 75 MHz with a capacitor at the other end. A hairpin
loop couples this open sided cavity to a coax feedline
that drives the receiver.
This kind of antenna would be easy to flush mount on
a metal airplane's fuselage or simply mount facing down
on the inside of a plastic fuselage.
>>Gary Liming
This has been the standard saw . . . but let's suppose you
have four bolts holding the spar-stub on your wing to the
carry-thru. How do we know when one of them is not carrying
it's intended load?
There are lots of places where we depend on reasonable care
and workmanship to insure that a single point of failure
isn't going to happen. I don't see any difference between
multiple load paths in structure and multiple load paths
in wires. Know what you're trying to accomplish and do
it right.
The most flack I've fielded on this notion was from folks
worried about putting multiple strands of wire into a butt
splice. In one case, I'm putting 7 strands of 22AWG into
a butt splice. I showed them how to strip the ends of the
bundle. Wrap a rubber band around the bundle very tight so
as to prevent slippage of individual strands. Then, I pointed
the ends of the strands at the observer and asked? I you had
not just witnessed that these wires came from 7 strands of
22AWG, how would you know by looking at the end that it wasn't
a single strand of, say a single 10AWG?"
The answer was, of course, "no way I can know."
"Okay, once we put these wires into a splice and put the
gas-tight squash on it . . . and no strands were allowed
to slip, what's the likelihood that any one strand isn't
properly connected? Let's go a step further, tug on each
of the 7 strands and see if you can pull them out without
breaking the wire."
After that, it was simply a matter of using the right tool
to install D-sub pins on other ends and push them into
a connector.
Then I asked, "Has anyone ever seen a properly installed
wire on a D-sub loaded to 4A or less cause failure in the
mated pins?"
"Nope" was the answer there too.
Bottom line was that all the "what-if" concerns were
washed away with knowledge of the task and the craftsmanship
to do it. Hmmm . . . suppose we depend on the same skills
to install wing and prop bolts?
Subject: | Old-style knobs? |
Does anyone have a source for knobs like these used on an old Century I
autopilot?
http://mira.sbw.org/CIGuts/pages/frontviewclose.htm
Sorry I don't know the shaft diameter, but it's pretty standard. It uses
an allen head set screw.
I've looked through the Digikey catalog, and everything seems to have an
index pointer of some sort, either a physical pointer or a painted line. We
just need a plain knurled knob.
Thanks.
> it's intended load?
> Bob . . .
Thanks for that response,Bob. Sounds like good clear thinking to me.
Graham
Subject: | Re: Old-style knobs? |
>autopilot?
Are you wanting to imprint the top surface like
the a/p knobs? There were few standards in these
mechanisms. In order that a product meet government
requirements for "conformity" even when it didn't
matter, there was little value in seeking or
using off-the-shelf products like knobs. Since you
were better off making your own knobs, there was no
driver to adhere to any conventions.
A clever fellow with a lathe can make these for you.
His knurling tool may not have the same pitch so you'd
want him to make a complete set so that they match.
You might also find some knobs that are close enough
to be modified to fit. Can you get an o.d., length
and shaft diameter?
Does anyone have a good source for thermocouples and other temperature
sensors? I've been inspired by Bob Nuckolls and Jim Weir to attempt my
own temperature measurement system. It may not work but maybe I'll learn
something in the process.
Ray Cole
"Are you wanting to imprint the top surface like the a/p knobs?"
Those are decals in the original. I figured we could make some up with a
laser printer.
"Can you get an o.d., length and shaft diameter?"
I'll try to get that information.
I'd much rather find something off the shelf, even if it isn't a perfect
match, than to fabricate something.
From: | "Rob Housman" <ROB-HOUSMAN(at)worldnet.att.net> |
Subject: | Re: Thermocouples |
For thermocouples and information on how to use them check out
http://www.omega.com/
Best regards,
Rob Housman
Europa XS Tri-Gear
90% complete, 90% to go
Sent: Sunday, August 05, 2001 11:43 AM
Subject: AeroElectric-List: Thermocouples
> Ray Cole
> autopilot?
*** Sure,
You can buy them from Century. http://www.centuryflight.com. I think
they're about $30 each.
Once upon a time, I needed a nonstandard OBS knob - it had to stick out
past a panel overlay on my Cessna 170. Making it was a piece of cake on my
Sherline lathe. The "OBS" on the front was hard though. I opted to have it
engraved. $40. I also had to buy a knurl for $60. Bingo, your basic $100
knob.
Hindsight being 20/20, I might have chosen to laser print
it mirror image onto a transparency, and then glue the transparency to the
front of the knob ( which I would have faced off with an inset ). But it
would have been a really bad mismatch for all the other knobs.
Another problem with knobs is paint. Given what they go through, they
should really be dull black anodized. More $$.
From: | Robert McCallum <robert.mccallum2(at)sympatico.ca> |
>sensors?
>Ray Cole
Ray;
We buy temperature sensors for the machinery we build from a company
called Pyromation Inc. Don't know if they have what you want but their
web site is; http://www.pyromation.com/altindex.html
Bob McC
The Matronics website is back up. Congrats to Matt
for his perseverance in the face of adversity.
This is a test message to ping the list-server
Subject: | Question on Note 11, Appendix Z |
My printed version (rev 9) appears to have an incomplete note 11 in appendix
Z. The note ends with: "Otherwise, ". I checked the online version and
found the same thing. Can you elaborate?
I have a 40 amp ND alternator with internal regulator on my Aero Sport Power
IO-320 and your OV module. I'm trying to determine if I should get your 4
terminal continuous duty contactor (S701-1) and wire it per Figure Z-14.
This alternator came with a plug with a green and yellow pigtail. I'm not
sure which is the F terminal or what the other one is for.
Chris Heitman
Dousman WI
RV-9A N94ME (reserved)
wiring
http://www.execpc.com/~cjh/rv9a.html
Subject: | Re: Question on Note 11, Appendix Z |
Chris,
I also have an IO-320 from Aero Sport Power with the 40 amp ND alternator
hanging proudly on the nose of my RV-6. I forget which color wire is the Field
, but the other one is for a cockpit light to indicate an alternator failure.
Look in the paperwork that came with your engine. There should be a piece of
paper with a diagram of the plug on it that identifies each wire. I don't have
the cockpit light wired on mine, since I have an engine monitor that alarms for
low voltage. If you can't find the diagram, I will look it up for you tonight.
Take care,
Danny Kight
Anderson, SC
RV-6 N722DK (reserved)
almost ready for paint
C J Heitman on 08/28/2001 11:19:48 AM
Please respond to aeroelectric-list(at)matronics.com
cc:
Subject: AeroElectric-List: Question on Note 11, Appendix Z
Chris Heitman
Dousman WI
wiring
From: | Bob & Rita Falstad <RandBFalstad(at)compuserve.com> |
Subject: | Landing/Taxi Light & Dimming Circuit for GlaStar |
Folks,
I'm starting the panel for a GlaStar. I believe most GlaStar builders put
the landing/taxi light in the cowl. I'd like to put the Duckworks (RV)
landing/taxi lights in the leading edges. Does anyone know how I can
contact the Duckworks guy? I need to know if the plexiglass can be
re-heated and re-formed to match the contour of the GlaStar's leading edge.
Maybe he's even got a kit that will fit a GlaStar. Also, we've closed our
wings and I'm wondering if any GlaStar builders out there have strung any
wire through the leading edge after the wing is done. Our flexible wiring
conduit is full of wires for wingtip nav and strobe lights and wires for
heated pitot tube.
The panel will have a mix of incandescent lights (Westberg Mfg Co/Westach
engine instruments) and the UMA electroluminescent light bezels (flight
instruments). The avionics are a Garmin GNC250XL GPS/Comm and GTX320
transponder with their own internal lighting. Any ideas how to hook up a
dimmer circuit to keep the lighting intensity relatively constant among the
different lighting types? Do I need to use separate dimming circuits?
Thanks in advance.
(I apologize if a little of this is off topic.)
Subject: | Re: Landing/Taxi Light & Dimming Circuit for GlaStar |
According to the listing on the RV Yeller Pages, Duckworks can be e-mailed at:
jwentz@columbia-center.org
Look at Gary VanMortel's RV Yeller Pages at
http://www.sound.net/~hartmann/yelrpage.htm
Hope that helps.
Best Regards,
Mark Julicher
Bob & Rita Falstad wrote:
> Folks,
> heated pitot tube.
> Thanks in advance.
> Bob
Don can be reached at: DUCKWORKS (DON WENTZ) 503-543-2298
jwentz@columbia-center.org RV LANDING LIGHT KITS
Ed Perry
eperry(at)san.rr.com
From: Bob & Rita Falstad <RandBFalstad(at)compuserve.com>
Sent: Tuesday, August 28, 2001 6:36 PM
Subject: AeroElectric-List: Landing/Taxi Light & Dimming Circuit for GlaStar
> Folks,
edge.
our
> heated pitot tube.
the
> Thanks in advance.
> Bob
Hi Bob;
Save your money. Trace the profile of your wing onto paper & take it into
a
glass shop. They will make you lenses from plexi or lexan - cheap. Go to any
auto shop and buy a set of cheap driving lights and a set of 100 watt bulbs
as well as a couple of headlight adjuster screws & springs. Disassemble the
light and discard everything but the reflector. Cut a hole in a square of
aluminium the same size as the reflector to seat into it (lip of reflector
larger than hole). Now fit alum sheet/reflector into wing with adjuster
screws securing it. There is a few more details, but if can build a plane,
you can probably figure it out.
I ordered 2 lights with my RV-9 wing kit at $75usd each (almost $300 cdn
after taxes & exchange) and almost shit when I seen what I got for that.
When I installed them I was very disappointed with the aiming design, so I
made my own. I then bought the 100w bulbs. So I ended up with a set of $300
dollar lenses & reflectors. Another local builder just built his own for
$38.
S. Todd Bartrim
13B RV-9
C-FSTB (reserved)
Fuselage
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bob &
> Rita Falstad
> Sent: August 28, 2001 6:37 PM
> To: AeroElectric List
> GlaStar
> Folks,
> leading edge.
> closed our
> heated pitot tube.
> among the
> Thanks in advance.
> Bob
I can echo the advice from Mr. Bartrim. I built the landing lights for my RV-6
in a similar manner. J.C. Whitney offers plain round 3" reflectors that take an
H-3 halogen bulb for about $3 each. I got 100 watt H-3 bulbs from them also,
but at $7 each, it would be slightly cheaper to get them at the local auto parts
store. The most intimidating part, forming the lenses, turned out to be a piece
of cake. I used 1/16" lexan and heated it with my wife's 1600 watt hairdryer.
It bends easily after you warm it up good. The mounting brackets for the
reflectors are made from scrap sheet and angle aluminum. Total cost for both my
landing lights was about $30.
Good luck,
Danny Kight
Anderson, SC
RV-6
Haywire on 08/29/2001 09:03:16 AM
cc:
Subject: RE: AeroElectric-List: Landing/Taxi Light & Dimming Circuit for
GlaStar
Hi Bob;
into a
$38.
S. Todd Bartrim
13B RV-9
C-FSTB (reserved)
Fuselage
Subject: | re: Dimming Circuit for GlaStar |
I may be so. I advise builders to "make room" for up to
4 separate dimmer potentiometers when they are building
up a new panel. For the outset, install only one DIM14-15
dimmer and hook all instruments to the same dimmer. As
you gain experience with how your system performs, you
MAY want to add additional controls . . . some circuits
are sufficiently low power to use the DIM14-5 dimmer.
If there is room on the panel for more controls adjacent
to the first one, any controls you add later will look like
they belong there as opposed to be scattered all over the
panel.
>Chris,
>Take care,
>Danny Kight
>Anderson, SC
>To: aeroelectric-list cc:
>Bob,
That was the result of a last minute plan to add
ov protection data for internally regulated alternators
to the book . . . but it fell in a crack. The drawing that
will be added to Rev 10 of the book can be had at:
http://www.aeroelectric.com/articles/bleadov.pdf
One lead is for control of the alternator (it does
not directly supply field power . . hence cannot
be depended on for ov control). The other will be
for the automotive version of an alternator failure
warning lite. Recommend you ignore this lead and
have some form of ACTIVE NOTIFICATION OF LOW VOLTAGE
that flashes a light when the bus drops below 13.0
volts.
< Hell, there are no rules here-- we're >
< trying to accomplish something. >
< Thomas A. Edison >
From: | "Paul Messinger" <paulm(at)tenforward.com> |
Well the same old problem I had months ago came back. The .pdf file never
completes proper downloading and cannot be saved or printed (or viewed
completely). It also hangs up acrobat and forced shutdown is the only
apparent solution.
Again this is the ONLY list server that has EVER caused me problems with.pdf
files. (Running acrobat v5). Also going to the main web site and trying to
drop down to the subject page results in "page not available".
In the past others have also noted problems of this kind.
I respectfully request that www.aeroelectric.com have usable links to the
referenced files as I have never had a problem using that route to .pdf
files.
Paul
L. Nuckolls, III
Sent: Wednesday, August 29, 2001 9:27 AM
Subject: AeroElectric-List: Re: Question on Note 11, Appendix Z
I couldn't get that one to work either.
Terry
> apparent solution.
From: | William Mills <courierboy(at)earthlink.net> |
Info for diagnostic purposes:
It works fine (very fast) with my set-up -
Macintosh OS-9 and Acrobat reader 4.0.
>Terry
> > apparent solution.
Works perfectly on my computer also using Acrobat 5
Bob McC
> completely).
From: | "Ronnie Brown" <rolandbrown(at)sprintmail.com> |
I was able to open it by downloading (right click and save as) to my hard drive.
Then
open it locally with Acrobat 5.0.
There is a splash screen that Acrobat opens asking if you want to check their internet
site for updates. Unfortunately, the locked up screen won't allow you to see the
splash
screen (try pressing Alt+Tab to get to the splash screen). If you can get to this
splash
screen and uncheck the option, then it stops hanging the Acrobat screen up.
I guess you get what you pay for when you get stuff free. (;>(
From: | "Paul A. Franz, P.E." <paul(at)eucleides.com> |
Paul,
I don't have the problem that you're having but I would like to see if I
can help somehow. Did you see the message that suggested something about
checking for updates on Acrobat Reader as a splash screen?
Once in a while when I select a .pdf for viewing, after waiting for what
seems to be long enough, downloading appears to be complete but the screen
is blank. I just click (in Netscape) reload and the .PDF immediately
displays. Odd behavior.
Would you like me to just e-mail that .PDF to see if you have a problem
with it when you load it directly into Acrobat Reader rather than loading
it into the Acrobat Reader plugin?
I wonder if this is one of the .pdf's that Bob created with version 4 of
the Acrobat Writer?
Heck, I'll take a gamble and just attach it to this e-mail.
At 11:11 AM 8/29/2001Paul Messinger sez:
>apparent solution.
>files.
>Paul
>L. Nuckolls, III
>To: aeroelectric-list(at)matronics.com
** L I N U X ** .~. Paul A. Franz, P.E. Engineering Software
The Choice /V\ Blackdog Software Network Consulting and Sales
of the GNU /( )\ <http://blackdog.bellevue.wa.us/> Custom Web Services
Generation
(425) 641-8202, (425) 641-1773 FAX Internet FAX
>apparent solution.
Seems to work fine for me. I am using Acrobat Reader 5.0.1 dated 3/27/2001.
I also tried it with version 4.0 and that was fine too.
I wonder if you have the latest version installed but the plugin for that
version only installed in the browser you're not using. Maybe it got
installed in Netscape and you use IE or vice versa. That would be more
difficult to detect since you don't find that in help, about like the main
application.
Generation
Can anyone tell me the function of two terminals on a Narco AT-150
transponder?
One is term. 3 the "common".
The other is term. 5 the "enable'.
Also, Bob, do you sell a crimper of HD-22 terminals? The ones used in hi
density D-subs.
Steve
Subject: | Re: AT-150 pinout |
>transponder?
>density D-subs.
>Thanks,
>Steve
Take a peek at this page:
http://www.russellw.com/manuals/narco_at150/2electrical.htm
Terminal 3 in this drawing is definitely one of two
power grounds for the transponder/encoder-digitizer system.
Pin 5 is a signal common for the digitizer. Pins 15 and
1 are normally ignored these days . . . you only hook them
up if you have DME (Dinosaur Measuring Estimator) . . .
I've used the tool we sell for 20AWG pins to also install
the 22AWG HD pins. You may find that the crimp is a tad too
close to the end of the wire grip barrel . . . you can pull
the pin out a few thousandths of an inch before closing the
handles.
Subject: | RE: .pdf woes . . . |
>apparent solution.
>files.
>Paul
I'm mystified as to why this is happening. I just checked
the logs on my website and there have been between 80 and
100 thousand downloads of .pdf files from my site over the
past year or so. I've received perhaps a dozen notes from
folks having problems and MOST of those were accommodated
the .pdf using the latest version of Reader.
I believe the last time this discussion came up, I was
able to "fix" a few problems (even some problems exhibited
a later version of Acrobat . . . However, given that my
website has about 80 .pdf files . . . some of which no longer
enjoy availability of original documents . . . the task
to re-compile all of them promises to be a 15-20 hour
effort.
I really wish I had the magic wand to wave and make everybody's
problems go away but I know just enough about these applications
to make reasonable use of them. Given how far behind I am
on other tasks, it doesn't make much sense for me to spend
a lot of time flogging it.
I will do this. If anyone is having intractable problems
with Adobe files downloaded from our website, I'll be glad
to mail a gratis CD rom of the website materials along with
a bunch of other goodies. Just let me know.
n.com>
>I have read ( and enjoyed) most of your articles on the web. The articles
>have been a great help with many things.
>A question about FAA AC 43.13. In the wiring section the publication
>instructs that all wires be identified and goes on to specify where and how
>often. If I do not comply when wiring my radios, is there a problem?
>Curtis
The only government documents that apply to amateur
built aircraft are parts 61 and 91. All others
are offered as reference texts for ideas on how
to do SOME things . . . The electrical section of
AC43.13 is pretty sad . . . I'd like to do an
AeroElectric version of that document to weed
out all the BS.
If you mark ANY wires, do it for your convenience
only. If you want to wire the whole airplane with
white, un-marked wire, you're certainly free to do
it.
Subject: | OV protection for built-in regulator |
Bob Nuckolls wrote:
>>"The drawing that will be added to Rev 10 of the book can be had at:
>> http://www.aeroelectric.com/articles/bleadov.pdf "
Thanks for the link. The above schematic shows an 80 amp fuse between the
two contactors. My contactors will be next to each other on the firewall and
I am assuming that a short (<6") lead won't need protection. If I use 6AWG
wire for the approx. 3 foot lead from the OV contactor to the B terminal of
my 40amp alternator, can I use a 10AWG fusible link at the contactor end
instead of a large 80 amp fuse? It would be separated from other wires and
protected with sleeving or heatshrink tubing.
Chris Heitman
RV-9A
I do not think its a problem with your files. I believe its a seldom seen
compatibility betweeen MS SW and your server SW. This time a couple of
reports of problems. The .pdf file its self has never been the problem; its
a strange case of the handshake failing during downloading. When the file is
sent an an attachment its just fine.
Not worth the effort as last time lots of time was spent and no solution was
really found. Usually someone else on the list simply attached it and sends
it to me and the others having problems.
However as the latest version of MS SW no longer supports some plug ins and
netscape sites, the problems are likely to increase on the internet. I have
already run into MS only web sites where netscape will not work at all.
Thanks again for all you are doing for safer electrical systems.
BTW: I have run into a couple of cases where certified aircraft have had NO
engine Case to fush ground strap. In one case this causes the ammeter to
cycle with the pulsing beacon light. The owner said this was normal :-).
The other case resulted in the throttle cable carrying starter current and
welding its self to a fixed position. Fortunately in idle position.
Paul
L. Nuckolls, III
Sent: Thursday, August 30, 2001 8:57 AM
Subject: AeroElectric-List: RE: .pdf woes . . .
>apparent solution.
with.pdf
>files.
>Paul
effort.
Subject: | Re: RE: .pdf woes . . . |
The site may be set up with a timeout on how long a page takes to display.
This will cause a truncate of the file if the person is using a slow
connection or the document is too large.
A web download is not a guarantee of successful file transfer. All that is
happening is the web server is attempting to pass the string to the browser
(the string is the pdf file). There is no guarantee of success.
-Dan
Sent: Thursday, August 30, 2001 11:56 AM
> >apparent solution.
with.pdf
to
> >files.
> >Paul
> effort.
> Bob . . .
Subject: | System Voltage (auto) |
Listers,
I was going to put this on before the list went down and spaced it.
(just so happy not to have the withdrawal shakes any more)
According to several of the automotive trade journals the O.E.M.'s are
proceeding with the advancement and implementation of a 42 volt
electrical system.( some as soon as 2003 models) This is due in part to
the fact that equipment and component requirements on today's cars have
"maxed out" the capacity of the current 12 Volt systems.
With new federal mileage requirements just around the corner and with
very stiff penalties for non-compliance, the auto makers are looking at
weight reduction and engine horsepower conservation. The new
"standardized" 42 Volt systems will allow wiring size to be greatly
reduced (reducing weight and component size) as well as allowing for
electrically driven power steering, air conditioning, water pumps, etc.,
and a more stabilized and expanded management system.(horse power
conservation)
With builders always concerned with the weight factor of components,
this may be a God send. Some proto-types of the "new style" alternator
are the size of a coffee cup and produce gobs of amps and weight half
that of a ND. Batteries, starters, alternators all sound like they will
be reduced to about half the size and weight of current 12 volt
counterparts and have twice the potential.
Just something to think about.
Jim D. N708JD
RV-7A
Subject: | Re: OV protection for built-in regulator |
>Bob,
It's not between the two contactors . . . it's in series
with the alternator output. This fuse is in lieu of
the fat breaker normally found on the panel of most
SE Aircraft . . . the poorest place in the airplane to
tie the nosiest device in the airplane.
This is too fat a feeder for fusible link technology.
Please use the fuse.
Subject: | You're building the best to have ever flown . . . |
Thank you Paul . . . My pleasure.
Just got a call this morning from a fellow who was on
second flight of his LAIV, got a curl of smoke from
behind the panel, popped the alternator field breaker,
popped the alternator main breaker. Made a safe
landing 100 miles from home base. Test pilot went
home (1600 miles away) . . . now he wants to
band-aid the system sufficiently to allow the test
pilot to come back and check him out in the airplane.
Now I need to decide how deeply I want to get involved
in helping resurrect this aircraft . . . it could
easily evolve into a lose-lose situation. It would have
been SOOOOooooooo easy to do it right the first time.
Keep up the good work folks! The future of little airplanes
as we've come to know them is in OUR hands . . .
Good answer, Dan. I have a very slow connection and have been having
troubles with that one file. I upgraded to Adobe 5.0 and that didn't change
anything. I downloaded Bob's Appendix Z as a test, but I always get timed
out before I can print the last few pages. At this point, I think that's
probably my problem. We will see if it is solved when they hook my cable
modem up, hopefully yet this week.
Thanks.
Terry
Sent: Thursday, August 30, 2001 9:49 AM
Subject: Re: AeroElectric-List: RE: .pdf woes . . .
browser
> -Dan
In place of the 80 amp fuse, B & C recommended a C905-40 current limiter
with # 8 AWG wire between the alternator and the starter contactor. Do you
think this is an equally good solution?
Joel Harding
From: | "Andrew Seefried" <seefried(at)oberon.ark.com> |
To R Falstad, Have you seen the Glastar drop in molded panel blank from
Aerotronics.com ?
Subject: | Re: System Voltage (auto) |
>Listers,
Yes. Maxed out for ENERGY that can be generated and transferred
from the prime mover (engine driven alternator) to some place
where the energy is needed. And, it is true that in some cases,
the ceiling can be lifted by raising the system voltage. For example,
you can run a B&C L-40 or L-60 alternator in either a 14 or 28
volt system. The later requires a special regulator to limit
field voltage to 15 volts - HOWEVER, the minimum speed for regulation
and minimum speeds for full output go up. Not a problem on Lycoming
installations 'cause we got that nice fat ring gear pulley and
a relatively small alternator pulley.
An L-60 alternator with the special regulator puts out twice
the voltage at the same current for a 2x increase in energy
and no increase in weight . . . more efficient? No, for each
watt coming out, you gotta have a corresponding quantity of
h.p. going in . . . all we gained here was a weight savings.
Now, all things constant except for voltage, batteries
come in so many watt-hours per pound of stuff . . . in
most cases the "stuff" is lead, acid and water. Your 24v
battery may have smaller CELLS but you need twice as many.
All things being equal, to carry around the same number of
watt-hours, you're going to have about the same weight of
battery.
Starter motors tend to come in h.p. per pound . . . unless
you drastically change the technology. It's true that highly
geared, brushless d.c. motors could make one hell-of-a starter
motor with a lot less weight . . . but in the low volumes
needed for an aircraft market, not too many folk would want
to spend $1,000 for a starter just to save 3-4 pounds.
Yes, wire weight does go down . . . and in a B-52 which had
500+ miles of wire in it, the difference in wire weights
to utilize 28V vs. 14V is substantial . . . hundreds of
pounds no doubt. But suppose the weight of wire in your
airplane goes to ZERO . . . how many pounds are you going
to save? I've not pulled all the wire out of a small airplane
to weigh it . . . but I'll bet an RV-6 wires up with less than
5 pounds of wire.
Weight and size may go down a little with high volume brushless
designs . . . but the only way they'll make production and
marketing sense is when the components are manufactured in
the millions per year . . . not unusual numbers for cars.
>conservation)
Here's where the automotive guys hit the energy ceiling for
electrical systems. Their requirements for piping watts
around the vehicle on wires is going UP . . . our requirements
have been going steadily down with plenty of opportunities out
there for further improvements yet.
For example. When we replace a 10# sucker system with a 4#
alternator on the vacuum pump drive pad, we drive down parts
count, installation costs, and costs of ownership and get a
7# weight savings to boot. If you have two engine driven
power sources, the need to size a battery for extended
alternator-out-operations goes away . . . there are 2-pound
batteries out there capable of cranking an engine. Gee,
were down another 13 pounds for a total of 20.
The 42-volt system is just three times the present 14-volt
system. If a 2X, 28-volt system doesn't make any sense for
our market, what compelling argument is there for a 3X
system?
Maybe . . . some years down the road . . . and after millions
of the products have already been on the road, we might
find reason to consider an integrated pump/compressor
assembly for an automotive air-conditioner attractive
for a relatively small airplane . . . but would the
availability of a compact air-conditioner component offset
all the expense of converting to 42-v for the rest of
the system?
Without a doubt, advances in automotive technologies
have always run far out in front of anything that government
has seen fit to bless for little airplanes. I expect to
see some truly amazing things coming out of Detroit over
the next ten years . . . and indeed, once the technology
matures (nothing like 10-30 millions cars on the road to
drive maturity), we may see some applicable fallout.
However, the benefits to automobiles will far outweigh
any benefits to airplanes. Over-all system energy requirements
and efficiencies of our machines are pushing the limits
of pistons that jump up and down in their holes to drive
big air thrashers on the front that pushes an aerodynamic
shape that isn't going to get a whole lot better.
Right now, we can cut about 20# off the contemporary
electrical system. The lightweight starter may go down to
5 pounds. The alternator may go down to 4 pounds for
an additional 5-6 pounds over what we can do right now.
The biggest thing in our favor is that we're figuring
out how to do the job with less electrical watts while
the acknowledged goal of the car guys is to "live cleaner
(and simpler) with electricity" . . . their requirements
are going up. It may be that the smallest alternator you
can pull off a 2010 Ford puts out 3000 watts . . . small
for it's output but perhaps bigger than the 500W alternator
we have today that already puts out more energy than we use.
If you're looking forward to air conditioning in your
RV . . . there may be some exciting things coming over
the hill. In the mean time, there's still a lot we can
do with the technology that's already off-the-shelf.
Time will tell . . .
>Thanks.
>Terry
Terry, try downloading to hard drive and THEN opening
the file with Adobe Reader. This technique has made
a substantial difference with most folks problems
surrounding .pdf files.
Right-click the link and give it a pathway. Wait until
the download is complete before you open Reader to
view it.
>Bob,
>Joel Harding
Don't know what this is. I'm going up to B&C
in the morning. I'll find out what they're recommending
and the rational for the substitution.
> view it.
> Bob . . .
That worked. Thanks Bob.
Terry
From: | "David Swartzendruber" <dswartzendruber(at)earthlink.net> |
Although the homebuilders are decreasing their requirements for watts, spam
cans continue to do what they always have, add more goodies, add more
weight, and more watts required. The benefits of 42V may be more attractive
to the certified folks. I know of work being done as we speak to STC a
140A, 28V alternator on a Cessna 206 to run air conditioning and other
goodies.
Wichita
Waiting for the RV-10
----- Original Message -----
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Sent: Thursday, August 30, 2001 4:59 PM
Subject: AeroElectric-List: Re: System Voltage (auto)
> >Listers,
> battery.
> 5 pounds of wire.
> >conservation)
> system?
> the system?
> Bob . . .
Subject: | Switches for duel alternators |
I have an all electric 6A with a LD-40 and SD-8. Would there be any benefit
to wiring the switch that puts the SD-8 on line so that the LD-40 is cut off
at the same time so that they can not be both sending juice to the essential
bus at the same time? If so, how is this wired and what switches would you
use?
Also, do you recommend putting a cover over the switch that turns on the
SD-8 and the switch that turns on "battery only" essential bus power? Or,
perhaops using one of those switches that have to be pulled on to be turned
on?
Ross
Subject: | Re: Switches for duel alternators |
>Bob,
>use?
No, there is no harm to having both alternators on line
at the same time. "Interlocking" is more complex and offers
single points of failure for both alternators.
>on?
The All Electric Airplane on a Budget concept has been pretty
well thrashed with respect to failure modes. If you can
find a way to increase reliability by taking some things
OUT (reduced parts count) or if you perceive a failure mode
that needs the attention of redesign, let's talk about it.
For the moment, there are no changes I can recommend.
( "The Wright brothers flew right through the )
( smoke screen of impossibility." )
( Charles F. Kettering )
Subject: | Alternative B-lead fuse . . . |
>>Bob,
>>Joel Harding
Just got off the phone with folks at B&C . . . they're now
stocking the ANL series current limiters (a cross between
a fat fuse and fusible link) for another program. Their
p/n for the 40A limiter is C905-40. I agree with them
that this is a good substitute for the in-line fuse
we've been selling for some years. We've agreed to change
the offering in B&C catalog on my website.
Subject: | Re: Alternative B-lead fuse . . . |
I'm obviously missing something, here. But is a 40A current limiter
equal to an 80A fuse?
Boyd
RV-Super 6
314 hrs
"Robert L. Nuckolls, III" wrote:
> >>Bob,
> >>Joel Harding
> Bob . . .
Subject: | Alternator Hook Up |
(Posting for a friend and AeroElectric Connection Subscriber)
Questions relate to connecting a Mitsubishi alternator to voltage
regulator (Van's)
The connection (four prong) on back of Mazda alternator (from ancient
Ford Courier) is labeled: E N A & F. The plug (removed from the
vehicle) has no wire at "A", a black wire with yellow tracer at "N", a
white wire with black tracer at "F", a plain white wire at "E". "F" it
seems reasonable to assume, connects the field to the regulator. There
is a post with screw next to the plug which appears to be a ground, and
is connected internally to "E" and also "F" (both show 5 ohms
resistance).
1. Is "F" the field wire?
2. Should either of the other wires be connected anywhere?
The voltage regulator is connected by a shielded wire from alternator
switch in cockpit, and a second wire to the alternator field (at "F").
Dick Sipp
Along with my VM-1000, came a small jar of Nokorode regular paste flux.
This is specified for use with the solder joints on the d-sub plug
containing the inputs from the EGT & CHT thermocouples. Vision Microsystems
specifies that the pins and crimping tools be washed with water after
soldering. Zink chloride is mentioned on the label.
Now that I know that this stuff is "not for electronics use" as specified on
the label, how should I clean, or treat my kit audio panel on which I used
some of this? (I have a supply of your favorite $.88 disc brake cleaner.)
Tom Barnes
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Subject: | Re: flux cleanup |
Lacquer thinner works great. Use a tooth brush and compressed air. That's
what Ron from Rocky Mountain recommends.
Paul Besing
RV-6A N197AB Arizona
Flying
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Sent: Sunday, September 02, 2001 5:32 PM
Subject: AeroElectric-List: flux cleanup
> Bob,
Microsystems
on
> Thanks,
> Tom Barnes
Well, kinda sorta . . .
Recall that the 80A fuse is FAST and it was selected as
a good compromise for ALL alternators 60A and below.
The ANL series current limiters are like fusible links
and not subject to tripping out under small overloads
like the fuse.
I've just posted an article on the topic which you're
all welcome to read at:
http://www.aeroelectric.com/articles/anl/anlvsjjs.html
>Bob,
>Thanks,
> Tom Barnes
Yuk! I'm astounded that Ron would supply this material
with his kit. I'm mystified as to why it's needed. Perhaps
to put thermocouple wires into the solder cups? I've never
tried using an extra active flux to see if it will allow
me to use tin-lead solder on thermocouples. I generally
use machined crimp pins on the thermocouple wire or coat
the tips of the wires with silver solder before using
tin-lead solder to attach them to solder cups.
The $.88 cleaner is lacquer-thinner in a spray can. I think
it would do a pretty good job of getting all the nasty stuff
off. Are the crimp pins machined (solid brass barrels) or
sheet metal open barrel? If they're open barrel, I can
understand why he would want to add solder . . . thermocouple
wires are harder than copper/brass . . . hard to get a reliable
grip with the sheet metal pins. Machined pins can be substituted
in the same connector and eliminate the need for solder and
flux all together.
From: | "John & Teresa Huft" <widgeon92L(at)email.msn.com> |
Bob-
Lets say I have a 60A alternator, and a 60A ANL. And, lets say I let the
battery run down, and so the alternator is actually producing 60 Amps, to
charge the battery and run the other stuff. What is the voltage drop across
the ANL? Is this a heat-operated device?
Thanks, John
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L.
Nuckolls, III
Sent: Monday, September 03, 2001 12:24 AM
Subject: AeroElectric-List: Re: Alternative B-lead fuse . . .
like the fuse.
Subject: | Re: Grounding question |
>I am building an RV6 and have already installed the Vans location for the battery
and engine ground studs per Vans on the firewall in front of the battery with
the Vans supplied 8" #2 cable from the battery neg. I recently purchased
your single point ground block and wanted to put that nearer to the instrument
panel for instrument grounds and run an approximately 20" ground strap or #2
cable to the already installed firewall stud. 1) Am I compromising anything
doing this?, 2) Will this be an adequate grounding system?
Local ground for the battery is fine . . . but the ground block should
be on the firewall so that it shares the ground stud with battery (-)
connection and the crankcase jumper. What you propose
would work but it's not the way the system was designed for optimum
performance . . . the idea is to bring everything together insofar
as it's possible to a single point on the firewall.
What you propose will probably work and it will be an improvement
over what's flying around in most certified ships today. A remotely
mounted ground block should be isolated from local ground . . . mount
it on a piece of wood or phenolic . . . a fat ground strap is not
necessary . . . #10 wire would be big enough to connect it to the
firewall.
Hi Bob,
Checking out the electrical system on my RV4 I have ran into something I can
not figure out. My 4 is basically wired per your Figure Z-11. Two batteries
and two battery buses. A continuity test, with the wires disconnected from
the buses, I get continuity from the battery contactor to the main battery
bus wire. Touch the probe to the aux battery bus no continuity. Ok so far
I think? With the probe connected to the aux battery connector and the aux
battery bus wire I get continuity but I also get continuity touching the
main battery bus wire? This I don't understand. It looks like this should
not happen. Your help please!
Best regards,Bruce Bell
Lubbock, Texas
Subject: | Panel switches and circuit breaker requirements |
I am trying to putt the final touch to the design of my panel and would
appreciate your comments. This is an IFR "all electric" single battery
concept (Figure Z-8, Aeroelectric Connection) with a 40A ND with internal
regulator backed up with a B&C SD-8 alternator and s704-1 relay. Crowbar OV
protection is used on each.
Regarding the ELECTRICAL charging and power BUS distribution switches and
circuit breakers, this is my understanding:
1) 5A circuit breakers will be mounted on the panel for each alternator
and it is this breaker that will trip, if and when the crowbar OV module
activates. And also, one could use the primary alternator's CB to
momentarily reset the alternator while leaving the main battery switch ON.
2) There will be one toggle switch to turn on/off the SD-8 alternator,
and another independent switch (e-bus alternate feed) to supply power to the
essential bus should the MAIN BAT switch be turned OFF. Based on this, the
use of the AUX ALT does not limit you to using only those items wired to the
the ESSENTIAL BUS. It would be appropriate to put the two switches side by
side as it seems they would normally be used together.
3) If the MAIN BAT was turned OFF, and the AUX ALT turned ON, the SD-8
would charge the battery.
4) By manipulating a combination of switches and circuit breakers, one
could substitute the use of the SD-8 in place of the primary alternator
while using the MAIN bus. Of course, the battery would probably drain if it
was left in this state.
First, am I right with these statements and can you think of any switches or
circuit breakers that I've overlooked? The way I see it, these are the ONLY
circuit breakers on the panel.
Secondly, what acronyms do you typically use for labeling these circuit
breakers and switches on the panel?
I surely appreciate your comments.
Tom Barnes
Subject: | RE: Alternative B-lead fuse . . . |
>Bob-
>Thanks, John
It's just a fuse . . . albeit with different thermal
characteristics than the JJS and certainly different
than circuit breakers. It operates based upon an
Amps(squared) * Seconds constant just like a breaker, fuse
or even a piece of wire . . . yes, it's heat build
up that ultimately melts it open.
Don't know what the installed resistance is so I can
only guess at the voltage drop . . . but it's going
to be insignificant . . . less than 100 millivolts.
Subject: | Re: Panel switches and circuit breaker requirements |
>Bob,
Alternators do not require "resetting" . . . further, if you
use the S700-2-10 progressive transfer switch as a DC POWER
MASTER, the first position turns on battery only, the second position
brings up the alternator. The alternator can be shut off any time
and still leave the battery on line.
No problem with that. There is no harm in having ALL switches on
at the same time. There is only advantage in selectively closing
switched depending on the nature of the failure. Some have asked if
they can run the main and aux alternators together for some "added
capacity" and the answer is yes . . . can't imagine why you would
ever need to do this but it can be done.
Yes . . . and run goodies on the e-bus should the alternate feed
switch happen to be closed also.
Correct . . . but the drain on the battery would be reduced
by the approximately 10Amps that the SD-8 will deliver. If you
were close to the intended destination and wanted to leave the
main bus up for the approach, there's not a thing wrong with
adding the SD-8 output to extend the battery life.
Correct, only two breakers are advised. I'd call them MAIN ALT and AUX ALT
My pleasure sir. . .
From: | Ken Harrill <KHarrill(at)osa.state.sc.us> |
Bob and others,
My VM-1000 is installed and I did not clean anything after soldering. I
guess I just missed the part about washing with water after soldering. Just
how important is this? I would have a very difficult time doing a "clean
up" now.
Ken Harrill
RV-6, paint
Sent: Sunday, September 02, 2001 8:32 PM
Tom Barnes
Subject: | internally regulated OV protection |
Thread-Topic: AeroElectric-List: Re: Panel switches and circuit breaker requirements
Thread-Index: AcE07Ak0vfBp2C83Tm+fTCxIqxKfZAAaBkGQ
From: | "Bob Japundza" <Bob.Japundza(at)realmed.com> |
Last winter I switched from an externally regulated alternator in my
RV-6 to the nippondenso alternator with internal regulator sold by
Niagara air parts. So far I've been very pleased with it. I removed my
OV protection circuit and external regulator, with intentions to install
the OV circuit protection for internally regulated alternators. I was
looking over niagara's website over the weekend and read the new
instructions for their alternator kit. It says: "In the case of an
internal failure resulting in an over voltage, the alternator is
designed to shut itself down." Do you think and external OV circuit is
still desirable in this case?
Bob Japundza
RV-6 N244BJ O-360C/S flying 205 hours
Subject: | Re: internally regulated OV protection |
>Bob,
>Bob Japundza
I'd like to believe them . . . but I doubt that they
designed the regulator and they cannot provide a schematic
of the regulator they use so that anyone else can do a
failure mode effects analysis. I've seen the data on
a number of smart chips for alternator voltage regulators
that do indeed have an ov shutdown capability on board.
Problem is that the shutdown works ONLY if the chip itself
isn't toast . . . and if the high power pass transistor
that the chip controls gets toasted, then the chip can't
do anything about it.
The technology is out there to put proper ov protection inside
an alternator along with a perfectly good regulator. If I could
get my hands on all data needed to evaluate the effectiveness
of their claim, then perhaps I can endorse it.
When battery stores call their latest offerings "gel-cells",
I am reluctant to take the advertising hype or word of any
sales type at face value until I can understand how their
system works and have the same faith in it that they do.
Subject: | RE: flux cleanup |
>Bob and others,
>up" now.
Did you use the paste flux? Do I understand correctly that
the past flux is useful for soldering thermocouple wires
directly into the solder-cup, d-sub connector?
If there are flux residues left behind, this WILL
enhance both magnitude and rate of corrosion. Now,
if this is limited to thermocouple leads only, perhaps
the system can stand a lot of fuzzy stuff. Thermocouples
are very low impedance circuits not easily upset by
stray corrosion induced leakage. If the connector
shares other signals with the thermocouples, I think
it would be worth your effort to dismount the connector,
remove the backshell, place it in the middle of an old
towel to catch the liquid and then rinse it out well
with the spray carb cleaner (lacquer thinner in a can).
Subject: | Re: IFR Europa Panel |
>Hello Bob,
>Saw your letter regarding electric vs. vacuum power for attitude gyros etc.
>Am contemplating building a Europa but would want to be able to do light IFR
>(around Florida). Do you know of an all electric set-up that would work with
>the little rotax and provide a safe level of redundancy ? What about battery
>back-up for the attitude gyro in case of engine failure ? I'm just a dumb
>airline pilot (good at breaking things) so please keep your answers simple.
>Thanks for any help,
>Randy Palma
Let's do a load analysis. You've got about 18 amps available
from the Rotax 912 alternator. Let's throw 2.5 amps each at
electric gyros and save another 5A for battery charging.
This leaves you a budget of 8A to run other things. If you're
"IFR" . . . in a cloud, you don't need exterior lights so
the 8A left over should run about everything you need to run
except pitot heat. You could run strobes only during times
that folk MIGHT be able to see you (intermittent obscuration
in haze and hangy-downs) . . . so I could see this working.
The gyros might not take that much . . . and given the really
good directional data you get out of GPS, you could probably
do very nicely without a DG in warm-weather cloud busting.
Doesn't Rotax offer a 40amp Nippondenso alternator option belt driven off
the prop flange? That would give you dual systems and plenty of power.
Weight penalty though.
Wichita
not building yet
I've been noticing a lot of advertising on the Microair Transponder
again. Have they released it for sale yet?
Last time I talked to them I was told it would be a few months. It's
been a few months!
If you haven't got them yet, please put me down for one. Really like
the 760 comm.
Jim D. N708JD
Subject: | Subject: Mag Switch Ground Question |
I searched the active search engine but found nothing directly related to question,
although I am sure I read something very close on the list..... I have two
drawings. One drawing is from the ACS starter switch wiring diagram and the
other drawing is your Appendix Z general wiring diagram which I wired my RV-4
after. The ground lug on the mag(s) is connected to the wire sheath on the special
wire(ground woven wire around a center insulated wire). On the other end
at the ACS switch do I connect the ground sheath(from both mag wires) to the "G"
lug on the ACS switch also ??
There are a variety of methodologies for wiring the mags
suggested over the years . . . ALL are functional in terms
of controlling the ignition system. Several themes have
problems with respect to noise mitigation and potential for
damage to wiring at a future date:
I also have a local ground wire going from the ACS ground lug to a local ground.
LOTS of certified ships are wired this way . . . This means that
your shields are grounded to the airframe at both ends. The engine
end gets grounded through the crankcase-to-firewall jumper, the switch
end gets grounded to panel structure. This puts a conductive pathway
in parallel with the crankcase to firewall jumper and reduces the
effectiveness of the shields as mechanisms to reduce propagation of
p-lead noise.
The hazard to wiring comes from future maintenance errors wherein
the crankcase to firewall ground strap is inadvertently left disconnected
but you attempt to crank the engine. The starter tries to find a ground
through the p-lead shields (or any other shielded wires to the engine
that are similarly mis-used) and the several hundred amps burns up the
shielded wires and damages any wires bundled with them. Had a mechanic
at our airport do this twice on two different airplanes!
Is this correct or do I float the ACS end of these grounds ?? The wiring diagrams
seem at odds here.
Wired as shown in Figure Z and other drawings I've produced, the
system functions as intended. I've had a couple of builders reduce
or eliminate magneto noise in their radios by disconnecting the
local ground at the switch. Wiring in this manner also prevents
the shields from being called upon to do duty for which they are
not designed and causing damage to the airplane.
Also, I did a first engine start tonight and I have a dead mag. When the switch
is placed on the "L" position the engine quits. It runs on the "R" position and
the "both" position. I got some tracing to do here.....I have a standard left
mag impulse coupling (goes clank when I spin the prop...) Any suggestions on
tracing the bug ? The timing seems spot on on 25 degrees on both mags...one
firing a slight prop bump from the other when I use the buzz box.
Just because the mag times doesn't mean it's a good mag. Try
disconnecting the p-lead right at the left mag, start the
engine and see if it runs on "L" position (R-mag grounded).
If so, the problem is in the wiring. If the engine quits,
the mag is bad.
( There are many hypotheses in science which are wrong. )
( That's perfectly all right; they're the aperture to )
( finding out what's right. )
( -Carl Sagan- )
Subject: | Re: Micorair Transponder |
>Bob,
>been a few months!
>the 760 comm.
>Jim D. N708JD
I have a standing order for three of them as soon as
they arrive stateside. I think they'll sell for $1200
with a harness (like I sell for the 760VHF). I can also
probably bundle them with an encoder for a tad less than
you would pay for it elsewhere and have the encoder
wired up too.
They keep telling me (a few more weeks) every time
I call. I think they're being delivered to Australian
customers first.
If you'd like to put one (or the combo) on order,
you could place an order on my website and put your
desires into the comments box.
>Wichita
>not building yet
I'd forgotten about that . . .
I've seen some of those installations but didn't know
if it was a Rotax or aftermarket product.
The folks at Europa have told me that although that alternator will fit the
engine it will not fit inside of the Europa XS cowl.
Best regards,
Rob Housman
Europa XS Tri-Gear
(airframe complete, FF and panel not started)
Irvine, CA
Sent: Wednesday, September 05, 2001 6:30 AM
Subject: AeroElectric-List: Re: IFR Europa Panel
> >Wichita
> >not building yet
> Bob . . .
Do you or any of the listers know of anyone other than ASC that carries
Bob Archer Antennas for conductive aircraft(RV's)? Really don't want to
deal with those guys if I can keep from it.(bad experiences in the
past). Really wish I could find a Comm. ant. to fit inside the V.S. of
the 7. (vertical to vertical/ horizontal to horizontal)
Another question I've been meaning to ask, what kind of interference
will there be, if any, from mounting the Archer Comm. and Nav. Ant. in
tips having strobes? I figure everything for the strobes will have to
be shielded, correct? Looking at using a remote power supply for them
mounted in the Fuselage.
Checked the archives but, no joy so far.
Jim D. N708JD
Try Jim Ayers Less_Drag(at)juno.com
Ross Mickey
Thread-Topic: AeroElectric-List: Antennas
Thread-Index: AcE2RDhXYezuWA2sR+6iCel0s7LjkAAAg58w
From: | "David Glauser" <david.glauser(at)xpsystems.com> |
You can buy them directly from Bob Archer:
Bob Archer
21818 Ocean Ave.
Torrance, CA 90503
310-316-8796
David
> From: Jim Duckett [mailto:perfeng(at)3rivers.net]
> Sent: Wednesday, September 05, 2001 12:48
> Subject: AeroElectric-List: Antennas
> Bob,
> that carries
> don't want to
> the V.S. of
> Nav. Ant. in
> will have to
> for them
> Jim D. N708JD
Contact Bob directly! bobsantennas(at)earthlink.com
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Sent: Wednesday, September 05, 2001 2:48 PM
Jim D. N708JD
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Jim: I bought my Archer Antenna for the VOR Wing tip mount on my RV6-A right
from Bob himself!
Tom in
Ohio
Sent: Wednesday, September 05, 2001 3:48 PM
> Bob,
> Jim D. N708JD
The Rotax add-on alternator is simple to fit and works well, offering redundancy
to the built-in generator. It calls for a simple modification to the exhaust
system to provide clearance, and some ingenuity to carry through the wiring to
the electric prop (if fitted). Really recommend it.
Subject: | Re: electrical noise |
>Dear Bob, I installed my Microair 760 and it works great. The only
>problem is a very noisey turn coordinator. The reason I know this is the
>problem, is because it is the only gyro instrument on the panel. If
>there is a filter that you sell for this application please send it
>along with the bill. Any installation suggestions please include those
>too. Thanks again for all your help.
go to radio shack and get a 270-030 noise filter kit.
try a temporary wiring job with the choke in series
with the +14 volt lead to the turn coordinator. Wire
the capacitor from +14 to ground on the BUS side of
the choke.
See:
http://www.aeroelectric.com/articles/noisfltr.pdf
Subject: | Line Noise Filter |
Hi Bob,
Interested in the noise problem. The 270-030 noise filter kit I got from RS
didn't look anything like your sketch. It had two wires out of it and a
capacitor. From your sketch does the capacitor go in the noisy device ground
wire? Totally confused!
Best regards,
Bruce Bell
Lubbock, Texas
System check with the power on(batteries) seems to be ok. I get two
different voltages on the battery buss but still wonder about the continuity
check!
Subject: | Line noise filter |
Hi Bob,
After more study I have it figured out! I just didn't tie both ground points
together. They both go to your forest of ground tabs.
Bruce Bell
Lubbock, Texas
Subject: | Re: Line noise filter |
>Hi Bob,
>Regards,
>Bruce Bell
>Lubbock, Texas
There's a better way. I'm packing to leave in the morning
for a weekend seminar in Orlando . . . can't do it
tonight. However, when I get back I'll do a Shop Notes
on how to use the Radio Shack 270-030 filter kit to
assemble an effective small noise filter with a minimum
of hassles.
We've barely got enough folks signed up for this
program to break even. Some people bought airline
tickets (including me) to attend this presentation
so canceling the program is out of the question.
If any of you have been planning to attend one
of our programs "someday" and you live in FL . . .
now would be an excellent time to do it!
See:
http://www.aeroelectric.com/Orlando.html
Subject: | Mag Switch Ground Question |
Another benefit of toggle switches is for electronic ignition. The "On"
position for a mag is really open to break the ground circuit, while the
"On" for electronic ignition (e.g. Lightspeed) is closed to provide power to
the unit. This is dirt simple to wire with toggles, just turn the switch
upside down or use the other contacts on an SPDT. Not so simple with a key
switch.
Greg Young
> Let me add my two cents worth here: over the last 6
> months I've seen this question asked over and over...
> it seems everybody has trouble with these key
> switches. At my own airport several of the
> homebuilders have had the same problems. May I ask
> why is everybody so determined to use these stupid,
> expensive switches? You don't really think the lack
> of a key is going to stop someone from stealing your
> plane, do you? Remember, all a thief has to do is
> reach under the panel, cut the wires, and the mags are
> now HOT. A flip of the prop and your plane is gone.
> I'd like to suggest a MUCH easier setup... two toggle
> switches (one for each mag) and a push button for the
> starter. Absolutely dirt simple to wire up, and
> cheaper than a key switch. And, judging by the number
> of busted key switches I've seen, much more reliable
> too. This is how my Cessna 310 is wired, from the
> factory, and it works great. Yes, it takes up
> SLIGHTLY more room on the panel than a key switch, but
> it's worth the trade. I've converted two Long-EZ's to
> this setup, and both owners are very happy.
> Just my opinion....
> Bill
> Lancaster, CA
From: | "John Anderson" <janderson412(at)hotmail.com> |
And - if one switch falls to bits you haven't lost the lot like you would if the
key sw frizzles
-J-
Reply-To: aeroelectric-list(at)matronics.com
To:
Subject: RE: AeroElectric-List: Mag Switch Ground Question
Date: Fri, 7 Sep 2001 10:03:57 -0500
-- AeroElectric-List message posted by: "Greg Young" <GYOUNG@CS-SOL.COM>
switch.
Greg Young
-- AeroElectric-List message posted by: Bill Irvine
Just my opinion....
Lancaster, CA
Subject: | Re: Mag Switch Ground Question |
OK, now you've done it!! I'm confused again. I thought that with a typical
installation, with an impulse coupling on the left mag, you want the right
mag p-lead grounded during starting.
Bruce
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Cy
Galley
Sent: Saturday, September 08, 2001 9:36 AM
Subject: Re: AeroElectric-List: Re: Mag Switch Ground Question
Would the switch be a ON-OFF-(ON) where it the left listed would ground the
mag, middle would disconnect the mag, right momentary to turn on the starter
and the mag would still be dis-connected. Sounds like it would work well.
Regarding the use of a combination mag/start toggle switch, one thing that might
be considered is the possibility of engaging the starter accidentally while the
engine is running during mag checks, in flight trouble shooting etc. No idea
what degree of damage could occur if this happened. For this reason I may elect
to locate the starter button in a more remote location. This might also prevent
accidentally turning the prop when rummaging around the cockpit on the ground,
or when someone else if poking around in your plane (like a thief, maybe?)
Remember the floor-mounted starter contactor switch on early cars? (before my
time, but I've seen 'em) Using something like this would eliminate the
starter contactor and reduce the length of the cable run, provided it was hard
to hit accidentally. Just a thought...
Anyone know the consequences of firing the starter with the engine running?
From the PossumWorks in TN
Mark RV-6A fuse
re:
Doesn't sound so hot when I do it in my Toyota. On a scale of good to bad, I
imagine it's bad.
I used two Aeroelectric 2-3 switches for the mags, along with a starter
button. Wired it up so the starter can ONLY engage with the left mag on
(starter will not operate with both mags off or both mags on).
If that ain't foolproof enough, add a hidden idiot in the canopy/thief kill
switch too.
Rob Acker (RV-6)
> thing that might
> etc.
We've all done it - well I have anyway. Not to different to the effect when the
engine starts, the starter gear is flung clear of the ring gear. Not the end
of the world but wouln't want to make a habit of it. IMHO
-J-
Date: Sat, 08 Sep 2001 13:41:11 -0500
-- AeroElectric-List message posted by: ripsteel(at)edge.net (Mark Phillips)
Mark RV-6A fuse
It certainly never does them any good as a tooth can be chipped, which
almost always happens, when the starter gear collides with the fast-moving
ring gear. However, the Prestolite starter is reasonably protected in that
as soon as the gear hits the starter gear it is spun back into a retracted
position and it will stay there. The new starters with a positive
engagement don't fare quite as well as the solenoid forces engagement. Then
the over-running clutch allows the gear to spin freely - but at about a
jillion rpm. Everyone has heard someone do it to a car engine (I've never
done it myself, mind you!) and I've never seen one fail - that time, anyway.
Subject: | Re: Orlando Seminar |
Hi Bob. Wouldn't you know it! After all the farting around we did to try and
get a seminar in Florida I gotta leave for New Hampshire tonight!! (Sunday)
Well, someday It'll happen. Good luck.
Dave Goff
St Augustine, FL
PS- Anything ever happen with getting the Aux Battery Mang Modules made? I
still certainly need one. One of these days I'm just going to call you and
figure out the "problems" I have with determining my harness. It's too
confusing for me to write it as a question for the aerolist.
Subject: | Re: Mag Switch Ground question |
>Granted, I'm a bit of nut on building systems that are
>easy to maintain, but to me it seems so logical to
>have ONE switch perform ONE function. And Mark
>Phillips made a good point about possibly hitting the
>START position when doing a mag check. It's probably
>not very likely, but still... it's not something you
>would want to do often.
I'm inclined to agree with this philosophy.
I'm changing my design to include a dedicated start switch.
Thanks guys, I needed that -
RANS Courier/912uls in progress
Castro Valley, Ca (SF bay area)
Subject: | Wiring s704-1 disconnect relay |
List,
I'm trying to wire the disconnect relay for my SD-8 PM alternator and
use a crowbar OV protection device. Does the crowbar device replace the
need for a diode (1N4005) as illustrated in Bob's picture of the S704-1 on
his web site? If I still need to use the diode, then do I buy new terminals
or is there a trick to getting three conductors into those little holes in
the terminals provided?
Tom Barnes -6 "all electric" and lots to learn.
Subject: | Roll your own crowbar |
List,
I have the components to make a couple crowbar ov modules and I'm
wondering if I should assemble it using a general purpose pc board or make
it as compact as possible and perhaps make it air tight the way Bob does
his. I've never done anything without a board. Any tips would be
appreciated.
Tom Barnes -6
Subject: | Re: Roll your own crowbar |
>List,
>appreciated.
>Thanks,
> Tom Barnes -6
Obviously, etched circuit boards and enclosures have a mechanical
role in assisting the fabricator during assembly and providing
some measure of robustness and protection when the device is
installed for service.
From a functional perspective, the circuit will work if
you simply tack solder the parts together in a little
"spider web" of components . . . electrons are not choosy
about what kind of house they live in, given them contiguous
pathways through the various components and the circuit will
function as intended . . . EXCEPTION . . . some
have devices warm up enough to require heatsinking.
Housing here is important to the device but not the electrons
who will still be happy to do their assigned tasks until the
overheated component becomes toast.
In my website article on cladboarding, I suggested a means
for wrapping a fairly robust exterior around a somewhat
chaotic collection of soldered together parts and after
functionality was confirmed, immobilizing the components
with foam-in-place potting. Once the potting is set up
and the lid is in place, nobody knows and nobody cares
what the thing looks like inside as long as functionality
and longevity are assured..
The prototypes of the OV module were built with
leaded components by simply wiring them together with
the shortest possible leads and the most compact and
reasonably organize manner I could devise. After functionality
was assured, I used Shoo-Goo adhesive to coat the components
and immobilize them. Sometimes you need to put on several
thin coats and allow to dry between . . . it's a little
time consuming but it's not your hammer-n-tongs time . . .
you can be doing other useful things while the glue
is setting up.
I'm getting ready to post a Shop Notes article on
wiring and packaging a low current noise filter
using the radio shack 270-030 filter kit. I'll
show you how to use good ol' Shoo-Goo to hold
this critter together. The pictures are all done.
Maybe I'll get the text hammered out this evening.
Will post a note here on the list when it's done.
Subject: | Re: Wiring s704-1 disconnect relay |
>List,
>his web site?
You can leave the diode off if you wish. The energy
stored in the coil of the S704-1 relay is small compared
to its heftier cousins and doesn't represent much of
a threat to switch life . . . If you wanted to use
the diode, install the ov module further upstream
at the breaker or switch . . . it just needs to pull
the feedline to ground anywhere downstream of the circuit
breaker . . . it doesn't have to be right across the
coil terminals at the relay.
( -Carl Sagan- )
We had a pretty good discussion about these kinds of things
at our weekend seminar in Orlando last Saturday. It came up
during some questions about the value of level-locking switches
and putting spring loaded guards over switches to prevent
idle, inadvertent operation.
If you wire a pair of 2-5 switches (prefered) or a 2-3 and
2-5 combination to provide starter control in combination
with control of the left mag and interlock so that the
starter can't run with the right mag off, then inadvertent
starter operation can't happen after the engine is running
and you have both mags on.
Inadvertent operation can be all but impossible by
careful layout of switch panels. For single rows of switches
put engine controls at far left end thusly
boost pump (opt)
R-mag
L-mag/start
boost
dc power master
aux battery master (opt)
pitot heat (opt)
taxi light
landing light (wig-wag opt)
nav lites
strobe lights
There is a buffer of switches between the switches
you operate in flight and the ones you generally don't
operate in flight . . . switches in the buffer zone
have no evil consequences for getting the wrong one.
If you do a two-row installation, put the first
7 swithes on top, put the rest in the row below.
Now you have even more isolation between the two
classes of switch.
It's noisy and it will put shiny places on the
gear teeth where there were none before but it's
not a formula for instant death of the parts.
It's such a very rare event and so easy to make
more rare that I don't think it's worth much time
and intellectual capital to think about it much.
One builder was worried about his airplane sitting
at an airshow where one would like to let folks (especially
little ones) sit in the cockpit. Here is a real case
where un-observed cases of switchitis present possiblity
of real hazard . . . if it's MY airplane on static
display for the benefit of hyper active future pilots
or not-too-bright-never-will-be-a-pilots the BATTERY
IS DISCONNECTED before anybody gets into the seat.
Subject: | Switch wiring for electronic ignition....was Mag Switch |
Ground Question
What switching do you recommend for the following.
Right mag replaced with an electronic ignition that will be used to start in
normal operation.
Left mag remains the same with an impulse coupling for emergency starts
I was planning on switching the elec ignition with a switch and the mag with
a switch and using a starter button. Should these be wired so that the
starter can NOT be engaged if both of these switches is on? If so, how is
this done?
The switch layout I was thinking of using is
Battery master
Electronic ignition
fuel pump/primer
starter button
right mag
space
position lights/strobes
landing lights
on a different part of the panel
essential bus
Ross Mickey
6A all electric
I lost the key to a rental while on a long cross country
a few years back. Side doors were locked but baggage
door was not. Got in through baggage door. Reached
behind panel and wiggled p-leads to break them off
the switch, propped the airplane and brought it home.
. . . and we have a guarded push button for those
who gravitate toward that solution.
See
http://www.aeroelectric.com/Catalog/switch/switch.html#s895-1
and figure Z9 in your book or
http://www.aeroelectric.com/errata/R9Z_0400.pdf
Subject: | Re: Switch wiring for electronic ignition.. |
>normal operation.
>this done?
>Battery master
>Electronic ignition
>fuel pump/primer
>starter button
>right mag
>space
>landing lights
>essential bus
When using toggle switches, you can easily switch between
magneto and electronic ignition operation by simply moving
one wire on the ignition switch. The two pole ON-ON
switch has contacts that are closed in the up position
(for electronic) and contacts that are closed in the
down position (for mags) . . . in this case you
want to use 2-3 switches and the push button.
I would not change my recommendations as to positioning
of the switches with respect to each other.
Subject: | Crimping Big Wires |
Ok,
now that we've beaten the mag switch question to
death, how is everyone attaching terminals to the big
wires...the 2, 4 and 6 gauge wires? Is everybody
soldering them on per Electric Bob's suggestion, or is
there a very large crimper out there that I don't know
about? I've seen these teminals crimped on with
vise-grips, crushed in a vise, even smashed with a
hammer against a concrete floor, and the results were
as hideous as they sound.
Personally, I would rather crimp; it's easier to do on
the plane than soldering, and that's how we did it on
the B-2, with some very large and VERY expensive
crimpers. So, I've designed and will soon make a
large and inexpensive crimper that will do this job.
My question to you all is: would anybody be
interested in buying one of these crimpers? Should I
have the machine shop make some extras? I'm not sure
what the price will be, hopefully not over $100. But
the more crimpers I order, the cheaper they will be.
So please, everybody speak up and let me know what you
think. Is this a good idea or not?
Bill Irvine
C-310
Lancaster, CA
Subject: | Re: Crimping Big Wires |
Bill,
There are inexpensive crimpers out there under $25. I borrowed one from a
friend he found it at the local NAPA auto parts store. The crimper was made
for large terminals, had a V notch where the terminal and wire were placed.
Then there is a spring loaded die that slid down into the V notch. Hit the
die with a hammer until the mark on the die was even with the size of the
wire marked on the side of the V and job done. Got all that.
Al
Sent: Monday, September 10, 2001 9:00 PM
Subject: AeroElectric-List: Crimping Big Wires
> Ok,
> Bill Irvine
> C-310
> Lancaster, CA
I soldered them as per Bob. It is very easy. The only thing that takes any
finesse is not getting to much solder in the joint.
Ross
> Ok,
> Bill Irvine
> C-310
> Lancaster, CA
I have found that a Nicopress cable crimper works very well on 2, 4, 6,& 8 ga
lugs
I just marked the wires, stripped them, and took them down to a local FBO.
They crimped them for free.
Paul Besing
Flying
Sent: Monday, September 10, 2001 9:24 PM
Subject: Re: AeroElectric-List: Crimping Big Wires
> Bill,
made
placed.
> Al
> From: "Bill Irvine" <wgirvine(at)yahoo.com>
> To:
> > Ok,
> > Bill Irvine
> > C-310
> > Lancaster, CA
>Bill Irvine
>C-310
>Lancaster, CA
Hi Bill -
If I were doing lots of crimps I'd say count me in, won't be though
so thank you for the offer.
All the best -
Bill Mills
RANS Courier in progress
Castro Valley, Ca.
Listers,
Anyone have a simple circuit for wig - wagging the landing lights?
I'm just about to wire up the ignition on my Subaru EA 81 T (Kitfox 5).
Dual primary with an MSD coil switcher. Should I use carbon or wire HT leads.
With wire is radio supression a problem?
Hey John...
Check out the wig-wag circuit I have in my -8A...
http://vondane.com/rv8a/wiring/dwg/HTML/n8vd_wdwg_r4_frame.htm - DWG3 -
Landing Light Circuit...
-Bill VonDane
Colorado Springs, CO
RV-8A - N8VD - Finish
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of John
Anderson
Sent: Tuesday, September 11, 2001 5:11 AM
Subject: AeroElectric-List: Wig-Wag circuit
Listers,
We stock the "Brute Hammer Crimper"
http://www.terminaltown.com/Pages/Page21.html
It is a good, inexpensive tool.
Gaylen Lerohl
Sent: Monday, September 10, 2001 23:24
> Bill,
made
placed.
> Al
> To:
> > Ok,
save 5% -
Subject: | Re: Wig-Wag circuit |
--- John Anderson wrote:
Listers,
> lights?
Check out
http://aeroelectric.com/articles.html
and scroll to
Wig-Wag collision avoidance systems . . .
and take your pick!
Mike Thompson
Austin, TX
-6 N140RV (Reserved)
Firewall Forward
>Listers,
There are 4 options shown in diagrams listed at:
http://www.aeroelectric.com/articles.html
and per a reader request, I'm working on a 5th which
I hope to get around to one of these days.
Bob . ..
Subject: | MY WORST FEARS HAVE COME TO PASS . . . |
I have wondered for years how long it was going to
take before those who would commit the ultimate
assaults upon liberty of world citizens would
discover the potential of the airplane as a weapon
of terror.
It's amazed me that a Long-Ez load of ugly
cargo hasn't been guided through a window
in the White House before this.
This horrible and very sad day for thousands of
our citizens is going to change a lot of things
and none of them are going to be pleasant or
welcomed.
The gimme-whiner crowd in Florida are STILL
trying to get a toe hold on the notion that
Bush stole the election . . . but I think we
can count our lucky stars that he is in the
White House . . . would anyone feel better if
if Al Gore was working this problem?
Given the scope of this action against the
US today, it is likely that families we know
will be touched directly by events of this
terrible day . . . all we can do is hug
and cry with them and hope that our leadership
has the will, skill and support to do the
best that can be done . . .
Yes.
It's Bush's whole "We're Americans and Fuck you!" attitude that brought this
about. He has repeatedly thumbed his nose at the international community,
escalated the arms race with both China and Russia, and then spent 2 of his
6 months in office on vacation. He is the ultimate lazy ass, moronic
Resident.
In just a few weeks in office, he single-handedly lost the slimmest of
majorities in the Senate by acting as if the Republican's majority was
overwhelming and secure. This horrific act not only happened on his watch,
but was largely brought about by his laziness, his ignorance, and his
arrogance.
Now, try to stick to a topic you know something about -- i.e., aviation.
Asbestos suit on -- flame away....
Jim Ivey
Subject: | Re: MY WORST FEARS HAVE COME TO PASS |
Please...let us not use this list to vent our frustration and anger. Do it
elsewhere....Please.
Ross
Sent: Tuesday, September 11, 2001 8:50 AM
Subject: RE: AeroElectric-List: MY WORST FEARS HAVE COME TO PASS . . .
> Yes.
this
his
> Resident.
watch,
> arrogance.
> Jim Ivey
From: | "Steven DiNieri" <capsteve(at)adelphia.net> |
Hmmm.. I was under the impression that semi-intelligent people frequented
this list. Guess not!!
Jim, would you be from FL by any chance??
Steven DiNieri
Niagara Falls, New York
RV-6A, P28A-160
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of James D.
Ivey
Sent: Tuesday, September 11, 2001 11:51 AM
Yes.
Resident.
arrogance.
Jim Ivey
Subject: | Re: MY WORST FEARS HAVE COME TO |
PASS . . .
i agree
The people who orchestrated these events would like nothing better than to
have Americans pointing fingers at each other. Lets not give them that
pleasure on this list.
I think it is times like this that you all need to pull together, rather
than talk politics.
There are far better forums to discuss these issues. How about we leave
this list to aviation electrical discussions?
My thoughts and prayers are with those touched by this tragedy.
Kevin Horton
Ottawa, Canada (but in Wichita today)
>Steven DiNieri
>RV-6A, P28A-160
>Ivey
>Yes.
>Resident.
>arrogance.
>Jim Ivey
Subject: | Re: MY WORST FEARS HAVE COME TO PASS . . . |
don't know if Jim is from FL. or not! It doesn't make any difference, I
hail from NY / NJ...now living in FL and I beleive he does make a few
valid points. The man who's in the job..... we just have to hope he'll do
what's necessary. Nuff said....let's look for a better forum for these
comments. Now back to Europa Traffic.
Harold Kovac
>about. Now, try to stick to a topic you know something about -- i.e.,
>aviation.
You spew this hate filled garbage and you have the gall to lecture Mr.
Nuckolls about staying on topic on his newsgroup?
Your quote in your first sentence pretty much sums up what I think of your
response.
No regards to you.
Tom Velvick
Jim Ivey,
You have reveiled who you really are.
I think what is on topic in response to the attack is what effect it will
have on aviation. I didn't think of Bob's idea that it could have been a
homebuilt that was used - if that were the case, I doubt if I would ever be
able to fly the plane I am building. I wonder what restrictions I will
have as it is.
It may be off topic, but my heart goes out to those who've lost loved ones.
Gary Liming
>Dear Bob,
>I am sending this reply only to you. You may decide for yourself
>whether to post it on the AeroElectric-List.
>I am appalled by the "gimme-whiner" paragraph of your message.
>Regardless of one's political leanings, do you honestly believe that
>this is the appropriate time to offer such political commentary? Given
>your considerable education and life experience, could you not think of
>any other words of encouragement or support to offer to the families of
>the victims of this horrible tragedy?
>While I may still admire your knowledge of all things electrical, sadly
>I have lost all respect for you as a man.
>Mark Milgrom
I don't think I offered anything that was not
in sympathy or support of those who suffered
most this day. I also regret that whatever
respect you had for me was based upon so fragile
a foundation.
I will confess to some weaknesses of the moment . . .
I've had a few personally tragic moments in
my own life but nothing that could prepare me
for this. Whatever statements I made with a
political bent (but then EVERYTHING we say
is political in one forum or another) was
based on the lead article of the latest issue
of Time . . . in spite a large majority
of credible recounts say Bush won it fair and
square (confirmed by none other than the
chairman of DNC on television), there are
people still trying to make the President's
job harder by printing articles intended to
discredit his position.
Now in the midst of all the artificial rhetoric
he has to take on one of the hardest tasks since
Pearl Harbor. What he does over the next few
weeks can have consequences that can commit us
to an still larger investment of our nation's
personal and material capital.
In retrospect, my choice of pejoratives was poor.
The misery being dished out on the President
probably has more to do with a national effort
to capitalize on the a situation in Florida
than upon the people of Florida . . . my sincere
apologies for insulting the sensibilities of
my friends in Florida . . . or anywhere else
for that matter.
I'm going to be off-list for a few days.
I suggest you take your own advice, Jim, except you probably don't know
anything about aviation either. I've never seen such a crude, and
unwarranted attack as you have spewed out on this list. I think you should
apologize to Bob and the list, and in the future either restrain yourself or
go elsewhere.
Joel Harding
Come on guys, Even lawyers and rabid dogs have a right to their opinions,
even if they are obnoxious Jerks and are dead wrong!
From: | "Paul A. Franz, P.E." <paul(at)eucleides.com> |
Subject: | Informative leadership. |
At 04:23 PM 9/11/2001LRE2(at)aol.com sez:
Our President's leadership is becoming apparent. Here is a report from CNN:
<http://www.cnn.com/2001/US/09/11/white.house/>
** L I N U X ** .~. Paul A. Franz, P.E. Engineering Software
The Choice /V\ Blackdog Software Network Consulting and Sales
of the GNU /( )\ <http://blackdog.bellevue.wa.us/> Custom Web Services
Generation
(425) 641-8202, (425) 641-1773 FAX Internet FAX
From: | "Warren D. Shoun" <wbnb(at)earthlink.net> |
Guys,
If I may, as a former participant in one of these heated internet debates, I
would offer the opinion that the only victim here will be the usefulness of this
site. Let it go, or we may also lose the benefit of the shared wisdom here.
~Warren
It appeared to me that you left the rv-list, and quit selling electrical
items on your website after negative posts about not having a secure
server, etc. I also know that you have a full time job and have better
things to do than spend your time helping strangers on the net build
electrically better airplanes, but you do. I hope these recent negative
posts both personal and public dont affect your presence on the web. You
are the one authoritative person I can turn too when I have electrical
questions and your help is sincerely appreciated. I have seen over and
over where the most qualified people decide it isn't worth the hassle and
quit sharing their knowledge over the net. My apologies to everyone
including Mr. Ivey for contributing to this thread.
Tom Velvick
Peoria, AZ
N9233A rv-4
N188KJ rv-6a wiring
Thank you kindly Bill.
John A.
To:
Subject: RE: AeroElectric-List: Wig-Wag circuit
Date: Tue, 11 Sep 2001 05:42:27 -0600
-- AeroElectric-List message posted by: "Bill VonDane"
Hey John...
-Bill VonDane
Anderson
-- AeroElectric-List message posted by: "John Anderson"
Listers,
From: | "Daryl Hooke" <hooked(at)netspace.net.au> |
Ladies and Gentlemen,=0D
=0D
As an observer from the other side of the world, I awoke to the disbelief of
the horrific incidents inflicted upon America. I, and I would think all
Australians, offer my sympathy to all Americans on this very sad day.=0D
=0D
I understand the emotions suffered and that feelings are running high. I'm
dissapointed that this forum was used to personally attack some members,
exposing all other members to the comments. =0D
Is it not possible for personal comments to be directed straight to each
recipient rather than through the forum?=0D
=0D
Any response to this Email should be sent direct to me at hooked@netspace
net.au=0D
=0D
Again my sympathy to all.....I am deeply shocked by the events of the day=2E=0D
=0D
Daryl Hooke=0D
PARADISE BEACH=0D
AUSTRALIA=0D
From: | "Leonard Garceau" <lhgcpg(at)westriv.com> |
Sent: Tuesday, September 11, 2001 4:05 PM
Subject: AeroElectric-List: Re: MY WORST FEARS HAVE COME TO PASS . . .
> >Dear Bob,
> >Mark Milgrom
Dear Mark,
I have argued many an hour the politics of the nation. But to say you have
lost all respect for a man because of his opinion is your loss and not his.
Narrow minded people who condem others for their opinions are the ones who
seem to cause more problems. Who is not to be respected? I think we should
all be repected! It's a sad day when we US citzens can't repect each others
views after all this is a free country
Bob, I'm sorry for the personal attacks on you. You haven't attacked these
people personally and they should not be attacking you. Please don't let a
few narrow minded people stop you from helping us.
Leonard
From: | "STEVEN A BOOSKA" <boos1(at)ix.netcom.com> |
Subject: | scanner temp spike |
I have a JPS Classic scanner in my Grumman Tiger. Last flight I did a normal
runup, entered the runway and noticed the EGT on #1 had gone form the usual
1200 degrees to 1940! The normal peak is about 1450+. The engine was smooth.
The CHTs for all cylinders, including no.1 were the normal 330 or so. I
taxied back to the hanger (5 minutes) and the temp persisted. I shut the
engine down, inspected the engine, and all seemed normal.
Several hours later, after the engine had cooled, I repeated the test. No 1
started 100 degrees higher, 200, and spiked to 1770. At that point it
stabilized. A few minutes lated it went suddenly down to the normal 1200 and
stayed there for the rest of the taxi.
I called JPI and they said that the only possible engine problem would be
some form of detonation which would show on the CHT at hte same time. Since
nothing had they thought I had some electrical interference somewhere that
the wire from the probe was picking up.Possible from a strobe.
How can this be traced and solved?
Steve
From: | Robert McCallum <robert.mccallum2(at)sympatico.ca> |
RV list
Subject: | Thoughts and Condolences |
To our southern neighbours;
The thoughts, prayers and condolences of all Canadians are with you on
this black memorable day.
Bob McC
Toronto Canada
Subject: | Re: scanner temp spike |
test
Tell you what.
Now that I've gotten home and have been able to watch the satellite reports for
a couple
of hours, I'd say it's no real big deal. The worst part was being at work after
they
shut down all outside communications. You wouldn't believe the disinformation
that was
flying. You'd think we (and the rest of the free world) were under attack. It
was only
four planes. And only two could be flown to it's target. The one bound for the
pentagon ended up short, and the other that went down outside Pittsburgh never
made it
close. I'd like to think there were some heroes on that one, or the terrorist
pilot was
just incompetent.
If you have been watching the coverage, I've been giving the BBC the biggest chance
to
prove themselves, but the CBC (Canadian) comes out the clear winner. The locals
just
care about themselves.
Bernie C.
> =0D
> As an observer from the other side of the world, I awoke to the disbelief> of
> =0D
> I understand the emotions suffered and that feelings are running high. I> 'm
> =0D
> net.au=0D
> =0D
> Again my sympathy to all.....I am deeply shocked by the events of the day> =2E=0D
> =0D
> Daryl Hooke=0D
> PARADISE BEACH=0D
> AUSTRALIA=0D
Subject: | Re: Thoughts and Condolences |
Thanks to all supporters in other countries around the world. I think it
could be so easy for people from other nations to turn their head and not
get involved. The compassion that has been shown from listers in many
countries really shows that no matter where one is from, there is always a
common bond when it comes to humanity. (at least from rational, caring, and
supportive individuals from these nations)
Paul Besing
From: "Robert McCallum" <robert.mccallum2(at)sympatico.ca>
Sent: Tuesday, September 11, 2001 9:43 PM
Subject: AeroElectric-List: Thoughts and Condolences
> Bob McC
> Toronto Canada
Our thoughts are with you all.
Gilles Thesee
MCR 4 S project
France
Bernie, rather bizzare comments. I work directly across the street from the Pentagon,
I saw the destruction yesterday and have already been over this morning.
They may have hit short but still did a terrific amount of damage. We need
make sure the families of the thousands of dead and wounded know it's no bid
deal. That will be a comforting thought for them.
Rick McBride
LTC, USA
Jim,
What we are talking about is you! Your choice of words, mean spirited
slandering of those who do not believe as you do, and apparent lack of
character. The use of a national tragedy to restate your political belief is
reprehensible. YES, you have revealed who you really are.
Subject: | Re: AeroElectric-List Digest: 35 Msgs - 09/11/01 |
> Hey John...
> -Bill VonDane
Nice site, Bill:
With the mechanical flasher, do you notice any radio noise issues?
Ron
I suspect even Al Gore wouldn't feel better... Let alone the rest of us...
I agree with you completely.
Ron
> Jim Ivey
Jim:
This list is for pretty much whatever Bob wants it to be about.
The fact that the discussion here is even worth reading is because Bob
volunteers so much
of his time and expertise to make it so. Although I agree with him
completely, even if I didn't, I'd just skip over what I didn't like, and
read what I came here for.
The future of our country's way of life is important enough to all of us to
allow Bob a little latitude, for something he feels strongly about.
I suggest that if his opinions, electrical or political, bother you, you
refrain from damaging your sensitive little synapses by not reading them.
I'll do that for your future messages, which offend me. Can you do the
same?
Ron
All the wailing and gnashing of teeth is unwarranted as to any replys
unsympathetic to Bob's unnecessary political comment...gloating over the
last election... That is history, and whoever is in the White House is
going to rely on the CIA,and other intellegence agencys advice for any
response or action. Hard Left or Right is not needed now. we all need to
be middle of the road, THE SAME ROAD. Lets have no more name calling, and
concern ourselves with how can we help.
Harold Kovac, a Floridian, not happy with the way the last election was
run, but life must go on.
> > apparent lack of
> > political belief is
> Every word of that accurately describes Bob's original off-topic post.
Well lets just piss Bob off so that he pulls the mail list. That will
show everybody. Yeh, that's it, lets really piss Bob off. (what is the
smiley for childish behavior?)
Steve Eberhart
Fabricating RV-7 tail parts in my motel room, don't tell housekeeping,
N14SE reserved
One test is worth a thousand expert opinions but a thousand opinions are
easier to get. --plagiarized from an unknown author
"RV list"
From: | Graham Singleton <grasingleton(at)avnet.co.uk> |
>Paul Besing
I second that. The free world all know that the black 11th will affect the
whole world.
An unconsidered violent response is probably what the evil ones who
perpetrated this atrocity wanted to achieve. It is to be hoped that the big
guys in the military are careful and accurate when they do respond. If they
punish the wrong people the results will be bad for us all.
I do hope that Bob hasn't been driven away by the ill considered political
remarks carelessly thrown around. That too would help the evil ones to
achieve their goal which it appears is to create chaos in the free world.
Graham (UK )
Jim,
Only in your twisted unthinking perception. Bob was not vulgar, nor did he
attack you. The writer who said this is his house and you are a guest was
right on. Your demeanor, regardless of your limited ability to express your
self in a civilized manner, should merit an immediate invitation to leave the
premises. So please take your ATTITUDE and get out.
From: | "L. Mark Thomassons" <lmttmt(at)wwdb.org> |
I made him the same offer some time ago and his reply to me was simply "Fuck
Off!" Be ready for the same treatment, it seems to be his only method of
communication.
L. Mark Thomasson
lmttmt(at)wwdb.org
"Any fool can criticize, condemn and complain,
and most fools do. But it takes character and
self-control to be understanding and forgiving."
Dale Carnegie
----- Original Message -----
Sent: Wednesday, September 12, 2001 1:48 PM
Subject: Re: AeroElectric-List: MY WORST FEARS HAVE COME TO PASS . . .
> Jim,
your
the
The twit Jim cannot understand plain english, nor express himself without
four letter words. Therefore, I believe any attempt at a rational
communication with this limited person is not possible. My vote is for
expulsion of this abnormal thinker from the list.
From: | William Mills <courierboy(at)earthlink.net> |
>Bob N.,
>If you're reading this, could you please block any further messages from
>"Lord Jim" from being posted to the list? Better yet, since this IS a
>democracy (for the time being), let's all vote!!!
>I vote NO MORE MESSAGES FROM JIM.
I vote we ALL stay on the list and change the subject.
Before Sept 11 all of us email pugilists got along fine.
Now we're like kids playing "got you last".
This is an incredible tragedy we've witnessed, and it's effects are
evident on this list.
Buck up lads, let's move on. We're pissing in the wind . . .
Bill Mills
(hope I'll get to fly it someday in good ol' U.S. airspace)
>. It's Bob's house. He's
>allowed to act how he wants. We're guests, so let's behave accordingly.
>Chris
Agree
from across the Atlantic.
Graham
How 'bout we just save this space for electrical systems debates. Bob can
spout anything he wants, as long as I (and you) can sponge off his
generosity on this e-list and get my bird finished. I still have several
systems to work out in my project. If Bob dumps this list, a bunch of you
will be getting hate mail from several members.
Dave Goff
St Augustine, FL
Thorp T-18 (most wiring completed)
Check your thermocouple. If your instrument is configured for an
upscale burnout then an open in the thermocouple or the wire will be
displayed as a max temp. You may have a connection or T/C that opens
when it gets hot and expands.
Vince Welch
Sent: Wednesday, September 12, 2001 12:33 AM
Subject: AeroElectric-List: scanner temp spike
a normal
the usual
was smooth.
so. I
shut the
test. No 1
it
1200 and
would be
time. Since
somewhere that
> Steve
Ron...
Tha flasher is electronic... I am not flying yet, but another builder here
has the same thing in his -8 and should be flying this month... I will let
you know how his works...
-Bill
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Ronald
A. Cox
Sent: Wednesday, September 12, 2001 10:24 AM
Subject: AeroElectric-List: Re: AeroElectric-List Digest: 35 Msgs -
09/11/01
> Hey John...
> -Bill VonDane
Nice site, Bill:
Ron
From: | "Andrew Seefried" <seefried(at)oberon.ark.com> |
I, for one, sincerely appreciate all the very informative electrical
info on this list and in the Aeroelectric book. It has made possible
the systematic and accurate wiring of my project. I sincerely hope to
learn more from here in the future.
Andrew, - completing Glasair III, west coast, Canada.
First Lady Eleanor Roosevelt was in a local Washington DC bookstore on one
occasion. A man came into the bookstore and made a comment to the clerk at
the front of the store. "Who is that ugly women over there reading?" Of
course the Clerk knew who Eleanor was and since she was close enough to the
front of the store, the clerk was concerned that Mrs. Roosevelt had heard
the comment. The clerk apologizing for the man was amazed at Eleanor's lack
of response to this uncouth statement. When asked, The First Lady responded
" I did not give him permission to offend me" My point? Think about it! The
Banks Brothers, Bruce (Bob we appreciate your efforts here and respect yours
and others opinions)
Bob: (publish this at your pleasure)
First, let me say what disbelief met the tragic events of
yesterday and what terrible consequences were visitted on the workers of
lower Manhattan and the Pentagon. I know I am joined by fellow Canadians in
sending condolences to you and your countrymen.
That you might wax rhetorical on future events is understandable
given the effect these travesties will no doubt have on personal flight and
on our hobby.
I hope you will ignore the crudities flung at you in a
particularly political moment. Please do not let it have an effect on the
net. If it's any solace, we say, "In America, the people hate the
government. In Canada, the government hates the people".
KIndest regards,
Ferg Europa #A064
P.S: Am I the only one getting quote marks from JAnderson with bags of
"" in them?
Bill,
I have a very effective AMP heavy crimper for the 6, 4, 2 & 0 crimps I
use in the shop. i paid $129 for it. Compound action unit gives the
proper square sgaped crimp. The nicopress units give an oval sahped
crimp and would not measure up to the terminal manufacture's recommende
finished crimp dimensions.
On the issues from the last post. I hope Bob hangs there with all of us.
I really care very little what anyone's political opinions are when we
are not in a political arena and generally ignore them in this type
forum. The bashings in the last digest were in very bad taste. I
personnaly am not offended by anyone's political beliefs however there
is a certain decorem that should be followed here. I see two parties
using unneccessary fowl language that do need to apoligize to this list
so at least the air may be cleared.
Wes K
I do hope you good folk are keeping true to the subject line as any message with
the above subject I automaticly delete. I'd hate to miss good electical black
magic.
Kind wish to all.
"Bill VonDane" wrote.
An automotive type Bill?
Thanks Bob, how will version 5 differ.
John A.
----Original Message Follows----
From: "Robert L. Nuckolls, III" <NUCKOLLS(at)AEROELECTRIC.COM>
Subject: AeroElectric-List: Re: Wig-Wag circuit
Date: Tue, 11 Sep 2001 08:16:31 -0500
-- AeroElectric-List message posted by: "Robert L. Nuckolls, III"
Listers,
Bob . ..
5 x 5
To:
Subject: Re: AeroElectric-List: scanner temp spike
Date: Tue, 11 Sep 2001 21:49:11 -0700
-- AeroElectric-List message posted by: "SBooska"
test
Subject: | Re: 11SEPTEMBER2001 |
----------snip-----------------
>KIndest regards,
>Ferg Europa #A064
>"" in them?
You are not alone!
I'm deleting John's messages because the HTML(?) baloney is such a mess.
Bernie,
No big deal? Are you on Crack? Did you tune in a Spielberg movie on
HBO or something?
I'm so glad you have the ability to live such a sheltered life that you
can displace yourself from the magnitude of these events.
Jim Duckett, Captain GFFD
Subject: | AeroElectric web site . . . |
Well Lads -
I just tried to gain access to the AEC web site and - no joy.
Hopefully it's just down temporarily.
I dearly hope that the recent "unpleasantness" on this list has not
cost us the greatest single asset we homebuilders ever had.
P.S.
I first discovered the "Canadian Commentary/Tribute To The United
States" (which is now making the email rounds) on Bob's web site.
He's a most generous and interesting cat, and if I never get to hear
from him again it'll be a pity.
Hey guys, give me a steer here, I only seem to be having this problem with the
list replise??
I've been into options and turned off the .. ies. I'm on a hot mail system so perhaps
that's it?
Did anyone get my request about wire veres carbon HT leads or was it all gibrish?
If this ain't better I'll get a couple of flags!
John A.
Subject: Re: AeroElectric-List: 11SEPTEMBER2001
Date: Thu, 13 Sep 2001 01:14:35 -0600
-- AeroElectric-List message posted by: William Mills
KIndest regards,
Ferg Europa #A064
" in them?
You are not alone!
I agree with the proposal to block any further rantings by this idiot Ivey.
He has no finesse and abuses this medium and those of us who appreciate it.
but after all, he is a lawyer, and a Floridian to boot!
Subject: | RE: AeroElectric-List Digest: 30 Msgs - 09/12/01 |
Now we're like kids playing "got you last".<<
Well said. I have a concern - I have been listening to the proposed
"restrictions" on airline travel that I predict will cripple the industry
(Midway Airlines is already on the verge of bankruptcy, it seems). It would
seem that General Aviation is coming out unscathed, but what if our
fearless(?) leaders don't see it that way. What will our wonderful free
skies be like next year? I'll bet it will be forever different - and not
better. We need to work together to keep our freedoms and not let one
disaster take them away.
Gary Casey
Lancair ES that I hope to fly one day
I have opted for a Wilksch diesel. It is inverted inline 3cyl with
turbo-compressor which can use both diesel and turbo fuel. The reasons are:
1 I believe that the industry (perhaps at government urging) will abandon
highoctane product within ten years. There are indications rumbling already;
2 Diesel fuel carries more energy per unit volume than 100LL;
3 Compression-ignition negates a usual ignition system and its
complications;
4 Thus much ignition-caused signal noise is eliminated;
5 Carburettors disappear with all their complex settings;
6 Similarly carb icing is gone;
7 An inline inverted form of engine in my case allows for a 2-inch higher
prop centreline which in turn allows for a 2-inch larger prop with a 1-inch
greater prop clearance;
8 Diesels are considered reliable, and predominate north of 60;
9 Two-stroke diesels are more efficient in fuel use;
10 Narrower width may give better frontal efficiency;
11 Diesel may make use of turbofuel availablity (increasing);
12 Metallurgy has lightened diesel design;
13 Graham reports the tested unit is smooth as a 6-cyl gas equivalent;
14 Diesel runs more coolly (especially with turbo exhaust) than gas;
15 Ghoulish as it may seem, I prefer diesel dripping (higher flashpoint)
after a prang;
16 Diesels don't need speed reducers - they run at prop speeds:
17 No need for spark plug continuous replacement;
18 see 9 above - Kinder to the environment;
19 see 9 above - less concern over Carbon Monoxide infiltration.
There are three major disadvantages as I see it:
1 You can smell a diesel leak from the other shore;
2 Diesel fuel injectors are notoriously susceptible to water, or aerated
fuel;
3 Weight penalties mean less gas with passengers, but the wife can only
stand 2-1/2 hours anyway.
In spite of my decision, I invite rebuttal, debate or help whencever it
comes.
Cheers, Ferg Europa #A064
From: | Tom Hutchison <thutchis(at)umesd.k12.or.us> |
Subject: | Re: AeroElectric-List Digest: 30 Msgs - 09/12/01 |
EVERYONE!
PLEASE take your politics somewhere else. There are lots of forums dedicated to
political topics where everyone can vent their views and frustrations. Can't
we just talk about aircraft electrical systems.
PLEASE!!!
Tom
Subject: | Multimeter useage |
I have one of Bob's multimeters and now I have to figure our how to use it.
The instructions say to plug the leads into the right hole, turn the dial to
the proper setting, place the leads in the propoer place and read the
display.....not very helpful. I have figured out how to measure
voltage...just place the leads in line but I have no clue how to measure
resistance or actual amerage being used by something. How do you do this.
For example, there is no data with my facet puel pump and i would like to
know how many amps it draws so i can input this into my load analysis.
Ross
RV6A
Subject: | Use of computer power supply |
I have a 200 watt filtered power supply from a an old computer. It says the
yellow wires output 12 volts. Can I use this power for my bench testing?
Can I hook it directly to a 12 volt 4.5 amp battery I am using for portable
power to charge it....attended of course?
Ross Mickey
RV6A
Subject: | Keeping our Freedom |
...well said, and I think one of the best ways to do something about it is
to support EAA and AOPA, not to mention a lot of other worthy organizations
that support general aviation.
Pat Hatch
RV-4, N17PH @ VRB, 700 hours TT
O-320, Hartzell C/S
RV-6, Finish Kit
O-360, Hartzell C/S
Sent: Thursday, September 13, 2001 9:04 AM
Subject: AeroElectric-List: RE: AeroElectric-List Digest: 30 Msgs - 09/12/01
would
> Gary Casey
From: | "Terry Watson" <terrywatson3(at)home.com> |
I'm no expert here, but here's what I think you need to do, IF your are
using Outlook Express:
Go to the TOOLS menu, then OPTIONS, then the SEND tab. Down at the bottom,
you need to select PLAIN TEXT instead of HTML in two places. If you are not
in Outlook Express, you still need to get to plain text instead of HTML.
Anyone who knows what they are doing here please chime in.
Terry
From: "John Anderson" <janderson412(at)hotmail.com>
Sent: Thursday, September 13, 2001 2:20 AM
with the list replise??
Subject: | Re: Multimeter useage |
E=IR If I remember. Measure any 2 and you can figure the 3rd. Measure your
Voltage which is approximately 14 volts. Measure the resistance of your pump
without being powered. The calculated Current will be 14 divided by the
resistance.
Sent: Thursday, September 13, 2001 9:40 AM
Subject: AeroElectric-List: Multimeter useage
Ross
RV6A
The DC resistance of a non-running motor will not reflect the motor's
resistance while running. To measure current draw either use a low range
clamp on amp meter on the power lead (most people don't have access to one
of these), or use a very low ohm resistor (1/2 ohm or so) in series with the
power lead. Measure the voltage drop across the resistor with the motor
running to calculate the current draw. For example, a one volt drop across
the resistor would equate to a 2 amp pump current draw (V=I*R). This is
exactly how your amp meter works when using a battery shunt. The lower the
resistor value, the more accurate the measurement as the lower voltage drop
will have less affect on the running motor. The value selected is limited
by your meter's ability to measure small voltages.
Resistive loads can be estimated by measuring the DC resistance (lights,
pitot heat, etc.) but these will also change from start up to run
conditions. For example, the pitot heat element's resistance increases as
it gets hot (increased resistance equates to decrease current draw).
Carl Froehlich
RV-8A (move to the hanger next month)
Vienna, VA
Sent: Thursday, September 13, 2001 12:47 PM
Subject: Re: AeroElectric-List: Multimeter useage
your
pump
> resistance.
> From: "Ross" <rmickey(at)ix.netcom.com>
> To:
it.
to
> Thanks,
> Ross
> RV6A
From: | "Rob Housman" <ROB-HOUSMAN(at)worldnet.att.net> |
Good advice, to measure only voltage and resistance and calculate amperage.
Simpler yet, assume that you know the voltage is 14 volts in you aircraft.
You measure voltage as the difference in "potential" between any two points
in a circuit, so the power must be turned on. Measure voltage by placing
one lead (probe) on each side of the load. The simplest example is checking
battery voltage by putting the red probe on the plus terminal and the black
on the negative. Use the same scheme for any device in the circuit, but you
can substitute any ground wire or terminal for the negative side of the
battery. Some multimeters can automatically sense polarity making it
unnecessary for you to pay attention to the placement of the black and red
leads.
Resistance is likewise measured by putting one probe (polarity is not
important) on each side of the device being checked, but if the device is
installed in a circuit you may be measuring the circuit's resistance so it
is usually necessary to remove the device from the circuit in order to
measure resistance correctly. Avoid checking resistance in a "live" circuit
because you may feed power to the ohmmeter.
Measuring amps can be a bit tricky because the circuit must be operating in
order to make the measurement making it essential to exercise care about
where you put the probes. Be aware that the meter movement is measuring
voltage even when measuring amps. How so? The multimeter includes an
internal shunt when operating as an ammeter, and this shunt is very low
resistance, so low that we might as well call it a short circuit, which is
exactly what you will have if you insert the ammeter into the circuit
incorrectly. This makes mistakes rather exciting if the voltage is higher,
as it is in household circuits. The meter measures the voltage drop across
the shunt, magically calculates volts divided by ohms (the known resistance
of the shunt) and reports the result as current (amps). Remember that to
measure amps directly (as opposed to calculating amps from Ohm's law) the
meter must be in series with the load. That is, you must open one lead in
the circuit and insert the meter across the "gap" you opened. Any attempt
to measure amps the same way you would measure volts will create a short
circuit. Zap! A blown fuse or tripped breaker is the result of this
mistake, accompanied by sparks at higher voltages.
Best regards,
Rob Housman
Europa XS Tri-Gear
Irvine, CA
Sent: Thursday, September 13, 2001 9:47 AM
your
pump
> resistance.
> To:
it.
to
> Thanks,
> Ross
> RV6A
From: | "Scott Pittman" <SPITTMAN(at)mediaone.net> |
A friend sent me this link this morning. It is an Amazon.com site for
making donations to the Red Cross.
It is a immediate and effective way to help the folks in DC and New York.
Over one million has been donated
since I contributed at 9AM. We can all help.
http://www.amazon.com/paypage/PKAXFNQH7EKCX
Scott Pittman
RV-4
FT. Lauderdale, Fla.
Why not do as the Chinese do, Block internet sites, and then maybe we can
have a nice book burning ala the Nazis. Lets get real and leave politics
out of this mess. Now we should pull together and stop butting heads( or
Mouths )All the political criticisms are not needed now. ENOUGH ALREADY.
Harold Kovac
Fergus, in the disadvantages list you forgot vibration and torsional vibs.
IMHO a 3 cylinder engine is bad for T/vibration and a diesel would offer big challenges
in this area.
John A.
To: "engines"
Subject: AeroElectric-List: Diesels?
Date: Thu, 13 Sep 2001 10:11:23 -0400
-- AeroElectric-List message posted by: "Fergus Kyle"
complications;
after a prang;
fuel;
comes.
>big challenges in this area.
>John A.
I did a very short first flight with this engine, up to 10 feet than down
again, it was a foggy day and Mark Wilksch was desperate to fly in the old
millennium. (don't ask me why know) The engine was very smooth, much
smoother than a Lyconental, more like a straight Six. It has a separate
balance shaft. Lots of torque too,
Graham
"Mark Langford \(Deere PM alternator\)" ,
"plugsup/flyrotary" ,
"rotary engine e-mail list" ,
"RV-list" ,
"Mike Wills"
Subject: | Permanent magnet Alternators (more, bigger John Deere |
models than the 20 amp previously reported)
Ref: 28 Nov 00 posting of info on John Deere 20 amp permanent magnet
alternator in Mark Langford's KR-2; Mike Wills' e-mail to flyrotary list
on Dec 21, 00 re same info.
I visited my local John Deere dealer last April to try to identify all
PM alternators - only did half the job.
Returned today and found them not busy so was able to get the following
info (no cost, no weight - they lost their internet link before we got
the cost; haven't found a place to get the weight info yet):
20 amp As reported in above refs
(http://home.hiwaay.net/~langford/corvair/dynamo.html) P/N AM877557,
regulator AM101406; 4 lbs.
(used on model 670 lawn tractor - any x70 model)
35 amp (almost double) Same device, with internal changes, P/N AM877957
- uses same regulator, AM101406; 4 lbs?
(same lawn tractor?)
55 amps P/N AL81436, regulator P/N AL65077 (flat pack on back of
alternator body, typical)
(used on 6400L and 6500L tractors. L "lights"
for running at night)
85 amps P/N AL81437, regulator P/N AL65077 - has overvoltage protection
[NOTE: same p/n as 55 amp above]
& P/N AL78690, regulator P/N AL______(forgot to get p/n -
is listed as part for 6400 series tractor) - NO overvoltage protection.
(used on 6400 series tractors)
As far as we could tell by a check of all tractor models, all the other
tractors use standard alternators with no separate regulator listed,
implying they have internal regulators and are not PM alternators.
I will be checking further to get weights and prices of alternators and
their associated regulators.
David Carter
RV-6 QB (wiring external lights - 1st electrical work on the airplane)
Nederland, Texas
Dave,
Did you happen to spy any manufactures tag on the dynamo and regulator?
From dealing with anything painted green or having a deer on it, I know
it's generally half again in price to what we can get it for from other
suppliers. I do know that Deere does make some of their own stuff now
but, like with the ND alternator, most of their electrical is bid out.
As an example a Leach-Neville 130 A alternator lists for @ $450.00 from
J.D.. We buy them direct for @ $160.00
Just wondering....?
On a simular note, I've been toying with the idea of trying to mount the
"Fly-Ring" alternator from a Briggs & Stratton industrial and see if I
can make it work. The magnets (field) are in a ring and mount to the
flywheel and the armature is stationary. 35 Amps and weighs @4 pounds
too. Works great on their industrial engines.
Jim Duckett RV-7A N708JD
Bob:
This has happened twice today and once yesterday.
One was address from my memory list and one double-poked from
your website.
Cheers Ferg
from tomts12.bellnexxia.net [209.226.175.56]
----- The following addresses had transient non-fatal errors -----
----- Transcript of session follows -----
... Deferred: No route to host
Warning: message still undelivered after 4 hours
Will keep trying until message is 5 days old"
Sent: Thursday, September 13, 2001 8:27 PM
Subject: AeroElectric-List: Dynamo
> Dave,
> J.D.. We buy them direct for @ $160.00 > Just wondering....?
Jim,
1) I didn't see any hardware; was just copying basic info off a computer
screen. Will let you know when I find out.
2) About using the flywheel to generate electricity - don't see why that
isn't done more; it would eliminate the belt drive for a critical accessory.
David
Subject: | Re: Failure to contact |
nuckolls@aeroel..........
Word up is that Bob had some trouble with his website/ISP and is using a
different email address for the time being. Since I know how he feels (!)
I thought I'd pass on his temporary address. It is:
nuckolls(at)kscable.com
He's on the aeroelectric-list, so I'm sure he'll speak up for himself at
some point.
FYI
At 08:31 PM 9/13/01 Thursday, you wrote:
>Bob:
>your website.
>Cheers Ferg
Great minds discuss ideas,
Average minds discuss events,
Small minds discuss people...
Regarding permanent magnet alternators:
As far as I know there are three ways to regulate the voltage:
1. Use the battery. In other words, don't regulate it at all and hope the
battery will tolerate the overcharging that usually happens. A lot of small
engines use this method. Cheap and simple, but not workable for variable
loads.
2. Use a "parallel" regulator that shorts out the output when the battery
voltage is high enough. Wastes a lot of energy and creates current
pulsations and transients. Some of the medium-output systems use this, like
in smaller outboard motors. Creates EMI problems. The high heat
dissipation in the regulator limits its use to maybe 5 or 10 amps output.
3. Use a "series" regulator that opens the output when the battery voltage
is high enough. This is quite efficient, but creates large voltage
transients on the alternator side and large current fluctuations on the
battery side. Creates big EMI problems. The voltages in the alternator can
be in the hundreds of volts. This has been used on big outboard motors up
to maybe 30 amps.
None of the above methods seem to be particularly attractive for aircraft
use, but the light weight and good efficiency of the PM alternator make it
tempting. Any comments?
Gary Casey
Lancair ES
Subject: | RE: AeroElectric-List Digest: 33 Msgs - 09/13/01 |
>>In spite of my decision, I invite rebuttal, debate or help<<
I agree with your evaluation - the 2-stroke diesel has a lot to offer. The
3-cylinder is a natural for a 2-stroke because of the relative timing of the
exhaust pulses. The in-line is a good, strong arrangement compared to a
horizontally opposed engine with its flimsy crankshaft. I don't know the
details of this engine, but I assume it is piston-ported, which cuts down on
the height (depth, I guess as it is inverted). The crank is short and
stiff, so torsional resonant frequencies should be no problem, except maybe
for the prop. The torsional pulsation frequency is the same as for a
6-cylinder 4-stroke engine so it should be relatively smooth - but not as
smooth as a gasoline engine. HOWEVER:
1. The cylinder pressures will be almost twice that of a gasoline engine.
Weight of the structure is THE problem.
2. A 3 cylinder engine has a relatively large primary pitching couple. You
either have to live with the vibration, try to use soft mounts to isolate
it, or add a balance shaft at an even bigger weight penalty.
4. Durability is a problem for the piston and rings where they go over the
exhaust port. Oil consumption is an issue, but not much of one.
5. Fuel consumption will be higher than for a 4-stroke diesel engine (ask
Detroit Diesel) and not that far removed from a lean-running gasoline engine
as measured in pounds. Diesel fuel is heavier than gasoline so you can get
more pounds in a given size tank.
6. A highly-boosted engine, necessary for good power/weight, will have a
low compression ratio, making starting difficult. Needs a big starter and a
big battery, adding more weight.
Good luck. One of these days we will have a good diesel light aircraft
engine.
HOLD EVERYTHING! DIESEL? ISN'T THAT ANTI-ELECTRIC? THIS SHOULD BE IN THE
ENGINE LIST!
Gary Casey
Diesel buff from way back
Lancair ES
> see why that
> critical accessory.
> David
Check out the engines at
http://www.jabiru.net.au
They apparently use magnets on the flywheel for both the ignition and the
alternator.
Subject: | Re: RE: Wilksch diesel |
slightly off topic (only electric bits are the heater plugs and alternator)
but I thought it might be of interest: this is a piece I wrote for a car
magazine last year.
the Wilksch diesel aircraft engine.
The majority of piston aircraft engines are so archaic it would make any
automotive engineer choke on his beer before falling on the ground in
hysterics. Pushrod operated valve trains, magneto ignition, updraft
carburettors, complicated (and expensive when you get it wrong) handling
regimes - but they are stone reliable, pounding away for hour after hour,
burning copious amounts of the only leaded fuel left in the world.
Fuel is the driving force behind the next generation of reciprocation
internal combustion aircraft engines. The end is clearly in sight - if a
little way off yet - for gasoline fuelled engines. On the other hand, JetA1
Avtur - kerosene, diesel, heating oil are all part of the same family - is
already more widely available throughout the world, and has far better
potential in terms of producing it from renewable resources: all those
yellow fields of rapeseed that you pass is an excellent raw material for
biodiesel.
Diesels run lean all the time - this and the high compression ratios are the
reason that they are so efficient - Whereas large air-cooled aircraft
engines have to run rich, wasting fuel for nothing more than cooling. They
truly are the last dinosaurs of the petrol engine age, and long overdue for
retirement to a museum.
The race is on for the next generation of light aircraft engines - up to
around 400 bhp, where gas turbine engines become cost effective. The
aircraft engine heavyweights - Continental and Lycoming - have entered the
fray , as have Renault, but they are concentrating on the 200+ bhp market.
A plethora of smaller (and much nimbler) firms are also in the race and
leading the pack is Wilksch Airmotive. Led by an ex- Cosworth engineer
called Mark Wilksch, he may be the front man and the public face, but he is
at pains to point out that he is part of a team: Keith Duckworth and Mike
Costin may have been the public face of Cosworth, but Ben Rood was an
integral and essential part of the team, pioneering innovative production
techniques. At Wilksch Airmotive, Martin Long - also ex- Cosworth -
displays the same talents and is responsible for detail drawing, assembly,
and testing. He's a perfect foil for Wilksch.. There are various other
people involved such as Phil Franklin, a very experienced diesel engine
engineer, but most noteworthy is Mike Costin himself: he clearly considers
Wilksch to be something of a protg and in turn is considered to be a
valuable technical sounding board, with an encyclopaedic knowledge of
problems and solutions. "A very wide ranging mind." Is Costin's verdict of
Wilksch.
The production prototype Wilksch is an inverted in line 3 cylinder engine,
rather like a DH Gypsy (Tiger Moth) engine in configuration, although the
resemblance from then on is purely superficial. It can be extended to an in
line 4 (or even 200 bhp 5) cylinder engine: a 160 hp four is planned,
although there is a possibility that it may end up as a conventional flat
four, with a 260 hp flat 6 under consideration as well. There is also the
promise that significantly more powerful versions of each engine will also
be available as development progresses, an intercooler equipped version of
the triple being targeted for a reliable 150 bhp.
The basic operating principal is 2 stroke, although any similarity to your
lawnmower or even a microlight engine is minimal: the cylinders are force
fed (more on that later) with full circumference inlet ports, but the
exhaust is via multiple poppet valves. An under head cam operates the valves
at engine speed through a low maintenance valve train. With no crankcase
induction, the "bottom end" (or is it top?) is a pressure fed wet sump
set-up like most 4 strokes, removing any threat of an oily exhaust or the
need for troublesome needle roller small ends. The sump is effectively the
cam cover, so the bits that suffer the highest start up stresses are
permanently bathed in oil. Poor cam and follower start up lubrication is a
bugbear on many aircraft engines, and often precipitates premature
overhauls. Surprisingly, considering the number of inverted in line engines
produced over the years, this is the first wet sump equipped type: Wilksch
quite happily accedes that almost everything in the engine has been done
before, but not, as he points out, in this particular combination. In fact
there are several innovations - the wet sump being just one - that marks the
engine out as being a clever bit of design.
The crankshaft and con-rods look astonishingly beefy: Truck sized journals
(I kid you not) belie the relatively light weight of the crank, courtesy of
hollow main and crank pins. Currently tipping the scales at 110kg, when the
bugs are ironed out of the prototype and the final patterns are produced, it
should be 10% lighter. The piston rod connection is interesting in that
rather than employ conventional gudgeon pins, a ball end is formed on the
end of the rod and captured by a spherical bearing clipped into the piston:
In practice, the piston turns randomly whilst it's running. This has the
effect of spreading the wear over the entire skirt of the piston, rather
than a line contact perpendicular to the connecting pin. It also means that
there's no possibility of oil leaking past the bores after shut-down with a
smoky start to follow: the amount of oil floating around the system during
operation is considerably less than required to fill up three pistons. Built
into the bottom end are a pair of contra rotating balance shafts - which
double up as the cam and fuel pump drives: with twice as many power pulses
per crank rotation as a 4 stroke, the engine is inherently smooth anyway - a
3 cylinder feels like a 6 - but defeating the secondary out of balance
forces makes it incredibly smooth, with positive consequences for pilot
fatigue and airframe components life.
The induction system is fairly conventional up to a point: the fuel
injection system is standard technology, with the air side taken care of by
a simple turbocharger: no wastegate is fitted, the turbo being closely
matched to the engine's needs: as you climb higher, the faster the turbo
spins to maintain manifold pressure. The fuel injection pump has been
developed by Wilksch from existing automotive rotary pump technology. The
only electric bits are a starter, alternator and glow plugs, in the
interests of reliability.
Where it does diverge from the norm is a special supercharger is also fitted
to the system. Known as a Stosic blower, a driven 2 lobe screw turns a 3
lobe screw in a figure of eight housing: it consumes next to no power when
the turbocharger takes over. For all but starting and descent operations
(throttle shut, engine being driven by the prop) the turbo will maintain
enough manifold pressure to keep the fires alight, but in those specific
circumstances, it does need positive pressure for reliable operation.
It's interesting that the performance figures quoted are quite conservative:
Indeed, power itself isn't a problem - the limiting factors are piston
cooling (where a large percentage of the testing has been concentrated on)
and durability. From the operators point of view, operating costs and
maintenance requirements will be very much lower. In Europe at least - where
avtur costs about 1/3rd that of Avgas - both total and direct operating
costs will be substantially cheaper: Wilksch calculates that a 115 hp
Lycoming - as fitted to Cessna 152's - costs nearly 24/hour, based on
purchase price and fuel costs. The comparable figure for the Wilksch diesel
is 9/hour.
Wilksch are currently the front runners in the fastest expanding sector of
the market - around the 100 hp+ level: all of the heavy competition is at
200 bhp and above. The engine combines the best of 2 and 4 stroke
technology, and has been designed using up to the minute tools including FEA
(Finite Element Analysis) computer modelling. The chances of a Wilksch
finding its way into car isn't likely - but the technology, in terms of the
piston/rod, and the blower, is a fair bet. A couple of automotive engine
design bureaux are experimenting with 2 stroke diesel technology, the
limiting barrier being gudgeon pin (and thence piston) distortion - the
Wilksch solution being just the job. The blower offers better efficiency at
a lower cost than current technology which is still based mainly on Rootes
blower type designs. It's not often that aviation piston engine technology
trickles down to the automotive world - it's usually the other way round.
Captions:
Engine schematic sequence:
(1) Scavenge
Piston uncovers inlet ports and fresh charge purges remaining hot exhaust
gas from the cylinder. The "uniflow scavenging" ports also impart controlled
swirl to the incoming air, assisting in the following combustion
(2) Compression
Exhaust valves close, and compression starts as soon as the inlet ports are
covered. Port size means that the piston rings do not need pegging.
(3) Combustion/ power
At the critical moment, fuel is injected and spontaneously ignites: Swirl
and turbulence ensures good combustion - which continues some way down the
power stroke, typical of a diesel.
(4) Exhaust
Exhaust valves open, and a sonic wave of energy recharges the turbocharger
turbine spinning at 100,000 rpm. Cylinder pressure drops to around that of
the air plenum just before the ports open.
The prototype 3 cylinder Wilksch in a Europa kitplane is the cutting edge of
light aircraft technology. Able to take off and land from farmer's fields,
it will cruise at altitude at nearly 200 mph with a fuel consumption
approaching 50 mpg. That puts the South of France around 3 hours away for a
fuel cost of around a tenner each return for 2 people.
Engine installation: the cooling system is part of the engine -not an added
on accessory. Engine operation is akin to that of a car - unlike most
aircraft engines, with mixture and propeller controls, carb heat and
primers, and complicated operating procedures.
The blower screws: unlike Eaton superchargers which require gearing
together, the male (2 lobe) drives the female (3 lobe) with very low losses.
The very clever rotor geometry has been optimised by world renowned screw
compressor expert Nikola Stosic, and the blower developed and jointly
patented by Wilksch and London City University. Delivering a constant
volume of air according to rpm, the in-line turbocharger boosts the manifold
pressure according to demand.
The spherical bearing piston connection - a 4 stroke piston in this case.
Cheap to produce and exhibiting superior service life, it may become a
standard fitment on a wide variety of engines.
From: | "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> |
Subject: | Re: Failure to contact nuckolls |
>some point.
I've been out of contact for a few days. Our server got hacked
followed in close sequence with some hardware issues. The
website is back on the air as is our e-mail pop server at
aeroelectric.com.
I received a data dump on list activity for the past few
days . . . I'd like to clear up some misconceptions I've
noted.
This is not "my" list . . . it belongs to Matt and exists
at his pleasure and benevolence as do all other lists on
his equipment. I (nor do any of the rest of us) have a
right to be her but rather a privilege that is graciously
afforded us at little or no expense. The name was chosen in
order to capitalize on what ever name recognition my work
has developed over the years to accurately describe the
flavor of discussions found here. Should some untimely
hazard befall me, I would sincerely hope this list
continues under the tutelage of those who have studied
with us to advance our art and craft. I've learned more
about building airplanes working on amateur built machines
than I ever did from my activities at the factories.
In fact, a task before me in the next few weeks is to
take some of the concepts developed on homebuilts to
the managers of some certified aircraft programs to see
if they can grasp an understanding of the vision we have
all developed here.
In notes on the list and sent to me directly, there are
some who believe that I abandoned my list activities of
about a year ago due to pressure from some who were upset
that I did not have a secure website and other issues.
The facts are that I was subscribed to about 10 different
list servers wherein the messages concerning things I
could help with were probably 10-20% of the traffic.
I found myself spending too much time searching out
issues in my field of study from a dump of 200-300 messages
per day. Whittling down the task to a single service was
a simple move to improve the efficiency of application
of my time.
It was an expensive move in that all of the other lists were
a powerful promotional tool for my weekend seminar activities.
The last three programs barely broke even for attendance. This
problem combined with what promises to be a nightmarish (and
undoubtedly more expensive) experience to travel around
the country puts the seminar programs under careful evaluation
for return on investment.
Another misconception is that I got out of the parts
business because of the hassles from disgruntled
customers. In fact, the business got too big. If I
was going to continue my education with activities
on the heavy iron, publishing and list server discussions,
something had to give. While a super way to generate cash
flow, I'm not cut out to be a merchant and Dee is busy
working on her doctorate . . . the best course of
action was to transfer our amateur airplane builder
parts support to someone who was already in that business.
Hence, the transfer of our parts business to B&C last
January.
I've had a generous and heartwarming outpouring of support
from many via direct email. Most were worried about
me taking a beating and giving up. Nobody needs to worry
on that regard. Like the inimitable Mrs. Roosevelt spoken
of earlier this week, there are very few people who have
my permission to intimidate or insult me.
In light of the past week's events, I have identified
a couple of urgent tasks that I'm going to concentrate
on . . . thought I would be done by now but not yet.
My regular e-mail service
is up and running . . . I'll be moving my AeroElectric
List activity back to that address . . . and I'll keep
all of the list-server messages wherein I can offer
constructive responses. To quote another figure from
our country's past: "I shall return".
As I understand it, this is the design of the Jabiru engine alternators, which
output 25 amps. (this is for the 8 cyl, not sure for the 4's & 6's) Very slick,
mounted directly to the rear of the crank. A belt-drive alternator is an accessory,
producing 50 amps.
From the PossumWorks
Mark
I am trying to get a deeper understanding of the reasons why you decided on
using circuit breakers in your Z-8 arcitecure. Some questions.
1) For the 5 amp CB in the SD-8 wiring. Why didn't you use a fuselink or
wire into a fused slot of the battery bus instead of taking up panel space
for a 5 amp CB?
2) For the master switch. Why not use a 2-10 switch wiring the 1-2-3
between the battery contactor and ground and the 4-5-6 positions between a
fused slot in the main bus and the voltage regulator? The switch would then
be OFF-Battery Only-Battery and Alternator.
Ross
all electric 6A
From: | "John Anderson" <janderson412(at)hotmail.com> |
WELL said Bob.
John A.
From: "Robert L. Nuckolls, III" <NUCKOLLS(at)KSCABLE.COM>
Subject: AeroElectric-List: Re: Failure to contact nuckolls
Date: Fri, 14 Sep 2001 06:55:27 -0500
-- AeroElectric-List message posted by: Matt Dralle
"aeroelectric-list"
Subject: | magnet ring 20 amp internal alternator |
Hello, Great Plains Aircraft,
Some of us home-builders are considering permanent magnet alternators.
E-mail replies today pointed us to several engines using alternators on
the flywheel for 20 to 30 amps for engine electrical power. You were
one company mentioned that is already doing this. Checked your web
site just now to see what you had on your internal alternator.
I'm planning to use a Mazda RX-7 rotary engine (the 13B two rotor
engine). The flywheel turns a bit faster than most piston engines,
i.e., we are cruising around 5400 RPM, see 6000 to 6500 RPM at full
throttle. That is nearly double what the VW engines turn.
If your alternator hardware could be appropriately mounted to the
automatic transmission flex plate (flywheel) that we use, do you think
your particular hardware would stand up to the higher centrifugal loads
associated with the higher RPM?
- If the higher RPM is a problem, then perhaps we could consider
mounting the alternator on the PSRU.
Other than higher RPM, can you see any obvious reasons why your hardware
could not be used on a different engine?
David Carter
Nederland, Texas
"plugsup/flyrotary"
Subject: | Ring magnet alternator-on-flywheel |
For Aeroelectric and plugsup/flyrotary list:
Steve at Great Plains just called back and gave me info on his
alternator: At his website, http://www.greatplainsas.com/pg26.ht you
will find pictures of the flywhee, magnet ring, and the alternator
stator windings that sit stationary inside the rotating magnet ring.
Other things are also shown in the picture. (see diehl.jpg attachment
from the website)
His alternator stator is integrated into the Diehl assessory case which
bolts on back (flywheel end) of the VW engine in a tractor configuration
aircraft. Prop is driven off the other end (where generator pulley used
to be).
- Magnet ring is about 5" diameter (if my notes are correct ) and
is mounted to flywheel by 4 1/4" bolts. He said any flywheel (or Mazda
13B flex plate) would need to be 1/4 inch thick to have appropriate
strength for mounting. The stator is mounted to inside of Diehl
accessory case and fits inside the magnet ring. The magnet and stator
parts are about 1 or 1 1/4 inch thick and accessory case is about 1.5"
thick (measured from face of flywheel).
- Said more/bigger staor windings would be needed for more than 20
amps. (Jabiru only puts out 14 amps; 20 is the most he is aware of by
any other system.)
From his web page: "We introduced the moulded ceramic based Magnet Ring
for the 20 AMP internal alternator. This state of the art magnet ring
eliminated the problem associated with steel caps coming loose off
magnet rings as was sold by other VW conversion companies. "
For us 13B users, which has a PSRU attached over the flywheel, I'm not
sure how much room is available for such an alternator.
- I understand that Tracy Crook's PSRU is "open" so that
flywheel/flexplate is visible and it would be simple for wires to access
that area.
- Tracy, is there room - or could room be made - for this or a
re-packaged alternator to be bolted to the flexplate?
The objective would be to have enough electrical power for at least the
efi and electronic ignition. Thus, we would no longer be dependent on a
belt driven alternator and back-up battery for critical engine
functions.
There would still be a need for a belt driven alternator for current
needed in excess of 20 amps for comm-nav, landing lights, external nav &
strobe lights, etc.
David Carter
Subject: | Re: Ring magnet alternator-on-flywheel |
Go To
http://www.compufire.com
and check out the ring alternators there, for another option.
Warren.
>David
It is,
The Rotax 912/4 series of engines use it. Only gives about 18 amps though
but it works. As a matter of interest, we put the AC though a transformer
and got 400 cycle at the right voltage to drive an A/H . The frequency
varies with rpm but it didn't seem to be a problem.
Graham
aeroelectric-list(at)matronics.com, avionics-list(at)matronics.com,
rv4-list(at)matronics.com, rv6-list(at)matronics.com, tailwind-list(at)matronics.com,
pietenpol-list(at)matronics.com
Subject: | Printing Labels on Wire... |
Hello Listers,
I've been pondering the impending electrical wiring of the 'ol RV-4 and
it occurred to me that at some point in my 10-year building process someone
showed me a nifty wire labeler that would allow you to put most any
gauge of wire in one side and pull it completely through. The labeler
would repeatedly print a string of text along the wire from one end to the
other. I have no idea now where I saw this labeler or what it was
called. Does anyone have any insight on this device?
Thanks!
RV-4 / #1763 / N442RV
Subject: | Re: Avionics-List: Printing Labels on Wire... |
They are thermal printers. I don't remember who makes them but it might be Allen
Avionics. Try eBay.
-John
Matt Dralle wrote:
> --> Avionics-List message posted by: dralle(at)matronics.com (Matt Dralle)
> Hello Listers,
> Thanks!
> Matt Dralle
Subject: | Re: Printing Labels on Wire... |
Listers:
An inexpensive method is illustrated in our "How to" pages:
http://www.terminaltown.com/Pages/Page94.html. If you don't have a high
temp heat gun an open flame works well too. I like to set a candle on the
bench so I can use both hands to maneuver the wire. You might want to
practice on some scrap first, especially if you are using wire insulated
with material other than Tefzel.
Gaylen Lerohl
Sent: Friday, September 14, 2001 19:06
Subject: AeroElectric-List: Printing Labels on Wire...
Dralle)
> Hello Listers,
someone
> Thanks!
> Matt Dralle
Matt,
My company uses a device as you described. It uses a tiny laser to write on
the wire as it is pulled through. It is not a very large device. I'm sorry I
don't know the name ot mfg.
Best Regards,
Mark Julicher
taylorcraft list
Matt Dralle wrote:
> Hello Listers,
> Thanks!
> Matt Dralle
"plugsup/flyrotary"
Subject: | Motorcycle PM alternators on flywheel |
Charging Systems
July 30, 2001 - September 15, 2001
AeroElectric-Archive.digest.vol-ah
