AeroElectric-Archive.digest.vol-ao
January 19, 2002 - February 14, 2002
><< I've been renting airplanes for over 20 years and I've
> lost track of the numbers of airplanes I've climbed into
> that still had all the radios ON from the last shutdown.
> The only radio failures I've ever experienced
> were things that simply died while in operation and never
> associated with a noteworthy electrical event such as
> engine start, landing or flap operation, or system shutdown.
>So, I guess this begs the question: "Does an Avionics Master make any sense""
> If the radios can be left on, the an avionics master is wasted time and
>money, not to mention a single point for failure.
I've written about this extensively. I was at Cessna when
the avionics master switch was born. What we really knew
about the physics of what was killing radios was pretty
sad. Further, ALL electronics have become at least 10x more
robust than the puny germanium transistors of 1968.
The avionics master switch was conceived for the wrong
reasons in 1960's and persists more as an homage to tradition
than for any basis in fact.
In the past, when I've encountered a devoted disciple of
tradition who was still preaching the Gospel of Spikes
and Gremlins, I would ask them to explain the physics behind
their doctrine. To date, nobody has been willing to even
discuss the physics . . .
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
Subject: | Re: Seperate Gyro master switch??? |
I've been telling people about the bogus beliefs behind the avionics master
for years. Usually falls on deaf ears.
Gary
From: | William Mills <courierboy(at)earthlink.net> |
>Gary
Seems like the avionics master switch today serves the same purpose
as the "magic" feather that Walt Disney's "Dumbo" thought he needed
for flight.
Once Dumbo let go of THAT notion he flew just fine without it.
Walt Disney wouldn't steer us wrong now would he? ;-)
Bill Mills
(don't know how to measure spikes, so I've signed-on with Bob, Matt
and you guys)
RANS Courier in progress
SF bay area
Hi Gary,
I just need to be sure. In my Tiger, which has no master avionics switch,
is it okay just to leave the radio switches in the on position all the time?
Thansk,
Ned
----- Original Message -----
Subject: Re: AeroElectric-List: Re: Seperate Gyro master switch???
master
> Gary
http://www.matronics.com/browselist/aeroelectric-list
Subject: | Battery "Master" switch |
With all the recent discussion about avionics masters, key switches, a/c security,
etc. I would like to throw out to the assembled 'listers this possible alternative
for your learned critique:
Replace the master switch AND contactor with a manually operated battery disconnect
switch mounted just out of sight, yet near at hand, perhaps just under the center
of
the panel. Switches such as this, used by the ground-racing set, (possibly only
for
emergencies?) can be found in Summits catalog, for example. They list one for
$19.95 (SUM-G1432- no specs. given) up to one by Flaming River (FLA-FR1003-2, 250
amps continuous, 25K for 5 sec. and waterproof, for a whopping $82.95). It would
seem there are switches available somewhere in between these, although I haven't
seen
them (haven't looked much, neither!), nor do I know if they have multiple contacts,
are spring-loaded for fast operation, have useful duty-ratings, or are difficult
to
operate.
Use of such a thing would:
1. be simpler (less failure points- I'm sure switch/contactor is dead reliable,
but...)
2. no current draw (contactor coil draw is "only" a few amps, but amps is amps!)
3. produce no heat (good or bad, depending on where you live?!)
4. be fairly difficult for a potential thief to find, as if this would help here...
5. pretty much make sure nothing happened if someone was pokin' around in your
plane,
provided you remember to shut it off (connect a "ding-ding" key-in-switch noisemaker)
Any experience, thoughts etc.- just don't tell me it's a stupid idea, I'd like
to
know why...
From the Possumworks in TN
Mark Phillips, RV-6A in progress...
From: | Robert McCallum <robert.mccallum2(at)sympatico.ca> |
Subject: | Re: Battery "Master" switch |
Mark;
Having some experience with these switches in race cars I can give some small amount
of insight.
These switches are mandatory in most racing classes as an emergency cut-off. They
are used by rescue
workers in the case of accident to reduce the possibility of fire due to shorted
wiring.
!: Yes they are simpler IF the main battery cable is passing by the area where
you intend to mount
the switch anyway. Otherwise you have to run the full size battery cable to and
from this switch
location. This additional LIVE wiring is contrary to the purpose of a master contactor
which is to
eliminate as much live wiring as possible when it is off. This also applies even
if the main cable
runs past the proposed switch mounting area if the battery is not close by as the
wiring from
battery to switch will remain live with the switch off. As far as failure is concerned
please see
down side comments below.
2: This is true and a good thing. (many race cars are a dead loss electrical system
with no charging
capability)
3: True. (although no matter where you live waste heat energy is generally a bad
thing)
4: True, many European cars (even Rolls Royce) used to have one of these switches
installed adjacent
to the trunk mounted battery as a crude but effective form of theft protection.
A thief without
knowledge of this switch trying to cross wire the ignition to steal the vehicle
would find no
current available.
5: True, when working on a vehicle with one of these switches installed it is common
practice to
turn off the battery switch to avoid potential "surprises"
6: They are generally quite easy to operate as most are intended as an emergency
cut-off. They are,
for the most part, designed to turn off a shorted battery and thus have very high
interrupting
ratings. The duty cycle is continuous. Many have auxiliary contacts designed to
turn off such things
as alternators which can be self sustaining if the battery is simply disconnected
from the system.
They usually have spring applied contacts so that as the contacts wear spring pressure
compensates
and maintains a consistent contact pressure.
Now the down side. These switches, in my experience, are often the cause of a "dead"
vehicle. In the
street vehicles referred to above corrosion was often the culprit and in the race
cars vibration was
deadly for these switches. I have first hand knowledge of Lucas (prince of darkness)
brand which
were extremely vulnerable to vibration related problems and Bosch brand which,
while much better,
seemed susceptible to burned contacts and also eventually suffered vibration failure.
All of the
switches used in these cars were rated at 200 amps or greater but remember that
cranking your
starter can draw significant current especially when power is being supplied by
a modern RG battery
and it's cold outside. I would imagine that if you paid enough for a good aircraft
quality brand of
one of these devices you might get satisfactory service but, from experience, I'd
be cautious. (As
always you get what you pay for. Don't buy the $9.95 "special")
Bob McC
of
for
250
seen
to
> operate.
> but...)
plane,
to
> know why...
> _-
Mark,
I have been thinking of using the Flaming Rivers Battery disconnect switch
for my Pulsar. The switch I have been looking at is in the Summit catalog
and has a remote mounted handle and extension. The switch could be mounted
on the firewall next to the battery and the remote handle in the cockpit.
This would eliminate the ~1 amp drain for the contactor. My Jabiru engine
alternator only puts out 15 amps so every amp I can save is good.
I hadn't thought of the additional security the switch provides. That is a
good idea.
-ned
Subject: AeroElectric-List: Battery "Master" switch
security,
alternative
disconnect
center of
(possibly only for
one for
(FLA-FR1003-2, 250
It would
haven't seen
contacts,
difficult to
> operate.
reliable,
> but...)
amps!)
help here...
your plane,
noisemaker)
like to
> know why...
In a message dated 1/19/02 10:48:40 AM, nthomas(at)mmcable.com writes:
<< Hi Gary,
Thansk,
Ned >>
I have, and do from time to time. Being taught to turn things on after
engine start and off prior to shutdown though is a habit that is hard to
break. I have been flying a Tiger with an Avionics Master and I usually
leave the master on and turn on and shut down equipment as if it weren't
there.
Gary
Ok, here's about 2 years of actual experience. I bought one of that kind of
switch (red removable key) for about $8 from a Sun'n'Fun outdoor vendor.
As I have my battery mounted just in front of the main spar, I mounted the switch
right on the battery plus terminal within easy reach.
Hasn't failed me yet. Of course I turn it on before hitting the starter switch.
I
don't think these switches are designed to switch that kind of starter current
on
and off, but are able to handle them when already turned on.
It is real convenient and reassuring to know that when you turn it off there is
no power anywhere in the plane: not under the instrument panel, no hot starter
wire when working on the engine near the starter, and so on.
Finn
RV-3 Mazda 13-B rotary powered. 200 hours+
Ned Thomas wrote:
> Mark,
> good idea.
> -ned
Sign Up for NetZero Platinum Today
Only $9.95 per month!
http://my.netzero.net/s/signup?r=platinum&refcd=PT97
Subject: | biasing landing, taxi lights |
In reading some material about the life giving effect of keeping a small
current through bulb filaments when not in use, I was thinking about
adding a resistor from master switch to light switch biasing a small
amount of current through the bulb when the light is off and master
switch is on. Is this an idea that may extend the life of these lamps?
Dave Ford
RV6
From: | "Wayne McMullen" <cmcmullen(at)attbi.com> |
Subject: | Re: biasing landing, taxi lights |
The shock to the filament is the initial current surge, while the element is
cold. A gradual increase of turn-on current is the best. I have used this
technique, a bias current, in other applications. But then we were switching
the bulb on and off at a rapid rate.
Wayne
Subject: AeroElectric-List: biasing landing, taxi lights
> Bob,
> Dave Ford
> RV6
I understand that one of the features of the Control Vision switch panels is
that it will turn the landing light on slowly. They call it "soft start."
Also, as I recall, the Lo Presti "Boom Beam" ramps up the voltage to give a
"Soft Start" to their bulb. Lo Presti's is really neat, except for the
price. It only draws 3 amps and last 5000 hours and is much brighter.
Check it out:
http://www.speedmods.com/boom_beam.htm
http://www.controlvision.com/frame.cfm?link=avionics.htm
-ned
Subject: Re: AeroElectric-List: biasing landing, taxi lights
is
switching
> Wayne
> From: "David Ford" <dford(at)michweb.net>
> To:
> > Bob,
> > Dave Ford
> > RV6
>Bob,
The notion of a "keep warm" circuit for large incandescent lamps
is discussed in detail in the AeroElectric Connection. A resistor
that bypasses a small amount of current around a switch that
controls the lamps will keep the filament from achieving ambient
temperature will hold the lamp at some useful point above its
normal cold resistance.
Consider a 55W halogen headlamp for a car. I just went
to the bench and gathered the following data: Theoretical
inrush from room temperature was calculated assuming
10 feet of 20 and 16 AWG wire (10 and 4 milliohms per
foot respectively) in the power feedpath from a 14.0
volt bus.
E I R W Irush(16) Irush(20)
.014 .05 .28 .001 43.8 36.8
.030 .1 .3 .003 41.2 35.0
.046 .15 .31 .007 40.0 34.1
.064 .2 .32 .013 38.8 33.3
.080 .25 .32 .020 38.8 33.3
.100 .3 .33 .030 37.8 32.5
.144 .4 .36 .058 35.0 30.4
.210 .5 .42 .105 30.4 26.9
.295 .6 .49 .177 26.4 23.7
.427 .7 .61 .300 21.5 19.7
.700 .8 .88 .560 15.2 14.3
1.08 .9 1.20 .970 11.3 13.1
1.49 1.0 1.49 1.49 9.2 8.8
The general rule of thumb for keepwarm power has
be 1 to 3% of the lamp's full power rating. Note
that with 1.5 volts at 1.0A applied to the lamp
(1.5W or 2.7%) the inrush current falls to something
on the order of 2x the normal 4A running current.
Now, here's the rub. To get 1A of current to
flow from a 14v bus into a 1.5 ohm lamp you
need a resistor (14.0-1.5)/1 = 12.5 ohms.
This resistor will dissipate 1.5 x 12.5
18.8 watts. It will run pretty toasty and
consume as much energy as that required to run
two to four navigation receivers.
The neatest way to do it is install a DC to DC
converter with an output of 3.3 volts (common
computer part) and use diodes from the output
side to supply about 2.6 volts to every heavy
incandescent lamp circuit (landing, taxi
nav lights). DC to DC converters can be 85%
efficient. Assuming 2A to taxi, 2A to landing,
and 1A to nav lights you'll need 16.5 watts
of keepwarm power. Assuming reasonable efficiency
of the DC to DC converter . . . we'll only dump
about 6 watts of heat out for the whole keepwarm
system compared to 18.8 watts for JUST the
landing light when a resistor is used.
Another problem: DC-DC converters are strong
potential noise generators. Intended for use
with computers with strong immunity to radio
frequency noise, they MAY not work well in
airplanes without adding filtering and
RF tight enclosures.
On a related topic:
There's some popular hype associated with several
companies that offer wig-wag systems wherein they
claim that inrush current limiting supplied
standard with their products greatly enhances
bulb life in the wig-wag mode.
To investigate this claim, I put a data recorder
on the same 55W headlamp and cycled it at .5 second
on, .5 second off and observed the peak current
each time the lamp was re-energized. It turns out
that there is so much mass in the lamp's filament
that it doesn't have a chance to cool below the
3% power temperature . . . in fact, at .5 second
cycling, it didn't fall below the 10% power temperature
between cycles. Inrush was about 7A. When I increased
the timing to 1 second on 1 second off, the inrush
went up to about 8A.
Police cars use the wig-wags on their headlamps
and get hundreds of hours of service from the
bulbs without benefit of extra inrush current
limiting. The feature certainly does no harm
but it adds parts count and cost to the product
without adding demonstrable value.
Bottom line:
RF interference issues coupled with the expense
(about $50) for a DC to DC converter, the whole
thing looses it's luster if you consider using
automotive halogen lamps in lieu of FAA certified
tractor headlights designed and still manufactured
to their 1950's specifications.
If it were my airplane, I'd make every
effort to use low cost, modern lamps for
exterior lighting which are demonstrably
better performers than the products we all grew up
with. Keepwarm is EASY to add later . . . run
the GOOD lamps barefoot for a time and see if
it's REALLY worth your time, effort and dollars
to add a keepwarm system.
While you're getting an airplane ready for
first flight, there are things much more worthy
of time and attention than lamp-life.
From: | "Paul Messinger" <paulm(at)tenforward.com> |
Another GREAT!!!! reply.
Paul
original post:
(rest deleted for space conservation)
>Check it out:
The Lo Presti adaptation of the high pressure discharge
lamps used on many automobiles to aircraft has made it
possible to get a LOT of light for not much power on
a small airplane. However, there are a couple of things
to consider for these lamps.
(1) their color temperature is very high . . . very
nearly matching the color of clear blue sky. As a result,
they provide almost no visual perception differential
as recognition lights in the daytime when you are
silhouetted against clear sky. We tried this lamp
on the AGATE Bonanza at Raytheon . . . pilots were
amazed that tower operators couldn't see them 5 miles
out on a clear day when it was a sure bet that the
lumens being tossed out the front of the airplane
was 5x more than for the lamps they took off!
(2) while certainly more reliable by virtue of a very
long service life, inclusion of a bizillion-hour lamp
doesn't make your landing light system as failure-proof
as the lamp itself. The parts count for the high pressure
lamp system is higher and the amount of wiring, circuit
breakers, terminals and switches is the same as for
incandescent lamps. If spotting an obstruction 1/2 mile
down the runway is your real goal, then perhaps the
modern lighting system is for you. If having a high order
of probability of available light for a comfortable
arrival after dark is the goal, it's hard to beat the
an automotive halogen in each wing . . . one
aimed for taxi, the other for landing but backing each other
up as totally independent systems. Another useful thing
to consider is use of a high/low beam headlamp and
wiring your landing light up with a 2-10 progressive
transfer switch to provide a backup filament in the same
lamp assembly.
If you'd like to include some extra help on inrush current
control, check out the devices in the lower righthand
corner of page 597 of the Digikey catalog:
http://info.digikey.com/T021/V5/597-599.pdf
The Digikey KC015L-ND inrush limiter in series with
a 55W halogen lamp will ADD 5.0 ohms to the cold
resistance of the lamp circuit. This would give you
an inrush limit on the order of 2.6 amps! The device
adds a warm resistance of about .11 ohms for a voltage
drop of about .5 volts in normal operation.
I used similar device in the taxi light circuit of
the Gates-Piaggio GP-180 about 18 years ago. Worked fine.
NOTE > > > > > This is a temperature dependent device.
It needs to heat up to do it's job. Further, it has the
disadvantage of solid wire leads designed to be installed
on an etched circuit board like a disk ceramic capacitor.
The first time the guys out in experimental tried to mount
this thing in the taxi light fixture, they heat-sinked
the thing to the fixture by virtue of a mounting intended
to offset the fragile nature of solid leads.
Because the thing couldn't heat up in a few seconds to
protect itself, the taxi light wouldn't come on full bright
and the inrush limiter would smoke. They burned up three
or four of the things before they called over for help.
I wound up building an assembly in a small metal electronics
enclosure. Brought the solid leads out to nice terminals
on the enclosure and supported the device in a little
nest of fiberglas.
These are a one-cycle per 5-10 minutes sort of thing.
When you turn the lamp off, it takes some time for the
gizmo to cool off in order to get the benefits of inrush
limiting for the next cycle. Again, bottom line is that
if we'd been mounting a really GOOD lamp on the nosegear
back then, I probably wouldn't have messed with the inrush
limiter.
Ned,
The HID 'boom beam' has no filiment. It is a gasious discharge (plasma)
light. That's the reason it lasts 5000 hours.
Bruce
Subject: | re: Avionics master switch??? |
><< Hi Gary,
>Thansk,
>Ned >>
>there.
>Gary
One of the things we've come to understand
about switches in airplanes over the years is
that they don't get used often enough. Many
an on/off switch on a radio became flakey because
the avionics master switch made it unnecessary
to operate the power switch on the radio. Switches
that get cycled from time to time stay in better
shape than switches that never move.
As part of a pre-flight checklist, some builders
cycle EVERY switch on the panel . . . if you
make it a habit of using the panel mounted switch
to energize each radio at start up and de-energize
at shut down, it's far less likely that the switch
contacts will become so corroded that they begin
to loose connection.
A friend of mine used to let me fly his C150 if
I paid for fuel. It featured the super-elcheapo
plastic rocker switches (about 40 cents as I recall).
The FIRST switch to fail in nearly 30 years of
service was the dome light switch . . . very low
current stress and low usage.
Pitot heat and landing light switches were working
fine.
Subject: | Several questions regarding alternators, regulators, |
grounding and
shielding (Pretty Long!)
I hope these topics hasn't been covered to death already, I tried to
read as much of every pertinent chapter and article as I could, but
between that and the manuals for individual items (Rocky Mountain Engine
Monitor, especially), I am still confused regarding grounding, shielding
and other nefarious things electrical (despite having 90% of a EE degree
and 10 years electronics manufacturing experience)...
Background: Velocity RG aircraft, with factory-recommended automotive
alternator and LR-3B about to be wired in, along with some elements of
ControlVision's auto-resettable fuse board, 1 mag + 1 electronic
ignition, 1 vacuum system (although will probably change to all-electric
with backup alternator some day), Navaid wing-leveler...
I am also using dual-side-sticks with Infinity grips, so I need quite a
few relays to handle the current of roll trim, pitch trim, landing
light, strobes, etc... I am therefore designing my own circuitboard to
hold the relays, fastening all except two connections (Bat and Gnd) to
be the Fast-On variety of electrical connection (and a 15-pin DB-type
connector for each stick grip's wiring). The board will be 1/8" FR4
material, as used in high-vibration automotive environment.
My questions are legion, I will try to be quick and to the point.
1) I would like to use the small DIP-style relays from DigiKey, able to
handle 12A or 16A on the contacts. Should these be sufficient? (Before
you say it, yes this will save me time, but more importantly - space. A
neighbor's Velocity had enormous headaches trying to find places to put
all the relays and the dozens of Fast-on connectors needed for them (not
to mention troubleshooting them later), which I will avoid. Hopefully.)
2) I already have an automotive alternator installed, as recommended by
the factory, and currently operating reliably on many Velocities. It is
a 60-Amp model with internal regulator. I could get a different
alternator without internal regulator, but so far can only find ones up
to 50-Amp that use the same mounting method. Can the LR-3B be used with
my current alternator, without disabling the internal regulator?
3) I currently have (2) 4-ga av-wire for the starting circuit (why 2
wires? - long story) from the starter contactor up front (near the
battery), and a separate 8-ga from the alternator back to the main bus
up front. Without relocating the starter contactor with the engine in
back end running a short B-lead from the alternator to it, is there any
anti-alternator noise benefit to terminating the 8-ga wire at the
battery bus in the nose near the battery and running another (10-ga or
8-ga) from the battery to the main-bus in the cabin, rather than
terminating at the main-bus and/or battery-bus inside the cabin
directly?
4) I originally had planned a 3/4" copper conduit as a plane-length
ground, and to carry wiring from the engine to the panel and nose areas
(wires from the hell-hole take another route), but the number/size of
wires quickly outgrew the space, and I was concerned that I was
introducing two additional bolt connections at each end of the conduit -
so I took it out and went to a single 15-foot 2-ga ground cable, from
the battery direct to the engine. If I put the conduit back in, what
kind of wires should be placed inside the conduit, for maximum
electrical noise avoidance effect?
5) Related to #4 above, I noticed while preparing to wire the Rocky
Mountain engine monitor, that it calls for (9) 2-wire
twisted-pair-plus-shield, and (3) 3-wire(2-twisted)-plus-shield cables.
This makes the bundle enormous. Even the simple spst-switch-closure
alarm circuits call for 2-wire-twisted-plus-shield wire, and that seems
like huge overkill to me. What is a reasonable solution for switches
(assuming I do not use the conduit method)? 2-wire shielded (no twist)?
Single-conductor shielded, with shield as ground return?
Single-conductor shielded, with common ground? what about sensors such
as OilP, OilT, FuelP, MAP, Shadin fuel flow transducer, what kind of
shielding is typically necessary for those (the Velocity wiring guru
didn't recommend *any* shielding for these)? I know that the fuel pump
and strobe power really should have 2-twisted-wire-plus-shield, but what
about electronic ignition? (Also, I know the mag wire must be single
wire shielded, and the Alt-Field wire probably as well, although the
LR3B literature implies this may not be necessary.)
(I am sorry to inflict upon you this flood of queries, but I get so many
different answers from different people..)
6) Related to #5 above, if I do go back to the conduit idea for
grounding, what are the best wires to run inside? The noisy ones (field,
alt B-lead, fuel-pump power, strobe power, electronic ignition?) to keep
the noise in, or the other ones (sensors, switches, etc) to keep the
noise out? In either case, what sensors can probably do without the
shield and/or shield separate from ground return, and/or twisted wiring?
I would ask you these questions on the phone (probably lots faster to
answer on the phone than by typing), but perhaps there are more
questions out there like these from others, that could all be answered
at once... unfortunately, it will probably lead to more questions!
Thanks very much for all your answers here, and for your availability to
consult, in some strange way it makes paying the $500 or $1000 I will
likely pay in the future easier, as I have already received so much in
return with your advice here....
-John R.
(P.S.: Perhaps the time savings are illusory as you say, but I still
like the Control Vision board idea... I am adding indicators for every
protected circuit near the load or switch controlling the load, so that
I know which item is going wrong. If I do indeed find little benefit
from the board, I do still have the fuseblocks I got from you so long
ago, so I can use those if necessary (maybe for
battery-bus/essential-bus items?)
Subject: | Re: Several questions . . . |
>Bob,
If you have ONE d-sub connector on the board then I wouldn't
mix-match d-sub terminations =AND= fast-ons. Fast-on
tabs are difficult to add to an etched circuit board and
take up much more room than a d-sub. Run everything through
d-subs. 1/8" board material is overkill. 1/16" will be
fine.
If they have contact ratings sufficient to control the
load, they'll be fine . . . but ditch the fast-ons.
No . . . you can add external ov protection to an alternator
with built in regulator. See:
http://209.134.106.21/articles/crowbar.pdf
http://209.134.106.21/articles/bleadov.pdf
>directly?
Not much . . . probably not worth the effort. If it were
my airplane, I'd move the starter contactor back onto the
firewall.
Don't put the conduit in. Use wire and run all wires from
cabin to engine along the same pathway in the same bundle.
When you strike out on pathways not mapped by the manufacturer's
instructions, one assumes that he/she understands the system's
design as well or better than the guy who built it. Given the
level of understanding of many folk in the certified-iron world
these days, it's not unusual for a manufacturer to understand
little about some aspects of his own product . . . however,
unless you have made a detailed analysis of the circuitry and
deduced for yourself what is and is not useful to do, you
nor I have any basis for making a logical decision about how
we might deviate from the instructions.
Understand . . .
IF you use conduit, ALL wires run inside. If the conduit is not
already installed, don't install it but run all wires together
in same bundle and shield as called out by the manufacturer's
instructions.
No problem. . .
>Thanks,
>-John R.
Not trying to be obtuse here . . . but once you stick other products
into the equation, the mix and match of techniques and architectures
becomes a difficult thing to rationalize. If you need a battery bus,
obviously, the fuseblock will do the job as it's not part of the
Control Vision system . . . but these sorts of decisions kind of
hang you out on a limb . . . neither I nor Control Vision would
be 100% comfortable with recommendations when the outcome has
features over which we have no control.
Let me know how you feel about it a year from now . . . or after
you have made any major changes to architecture like the all-electric
cockpit . . .
Subject: | Re: Fwd: Re: FAR 23.1353 and airworthiness tests for batteries |
>Date: Mon, 21 Jan 2002 08:46:54 -0600
>To: Schmeelkpg(at)aol.com
>From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
>Subject: Re: FAR 23.1353 and airworthiness tests for batteries
>>Bob, I attended your presentation on March 14-15, 1998, at Manassas Airport
in Virginia. You probably remember me. I was the one in the brown leather jacket
in the back row who never said anything.
>>Anyway, I did pay attention to what you said, and I came away with the thought
that an RG battery was better than a flooded cell battery for a variety of reasons.
So when we needed a new battery for our 1968 Mooney M20F a few months
ago, I recommended to the other five owners of the plane that we get an RG battery
to replace it. We got the battery, but one of the owners noticed that the
documentation with it (a Gill G35S) implied that the battery could not be considered
airworthy unless we tested it to a load of 30 amps for 80 percent of
30 minutes (24 minutes) to see if it still read more that 10.5 volts. (I found
the same documentation at the Gill web site after searching for a while. Concorde
has a similar requirement.)
>>The other owner contacted a maintenance shop that said the test would take two
hours. The shop's labor fee is $60 per hour. The other owner also contacted
AOPA and was told that since the literature said it was an annual requirement,
it would have to be done at every annual or the plane would not be airworthy.
The other owner had never seen a test like this before, and he thought that
we should go back to a flooded cell battery at the one-year point because testing
the RG battery would be too expensive.
> The paragraph in question:
>(h) In the event of a complete loss of the primary electrical power
>generating system, the battery must be capable of providing at least 30
>minutes of electrical power to those loads that are essential to continued
>safe flight and landing. The 30 minute time period includes the time needed
>for the pilots to recognize the loss of generated power and take appropriate
>load shedding action.
> Keep in mind that Part 23 is a design requirement. The paragraph says
> "must be capable of" . . . this means that when the original type certificate
> holder or the holder of a supplemental type certificate proposed the battery
> for inclusion on the aircraft, they must show by test or analysis that the
> battery meets its intended purposes.
> No document that is produced by any manufacturer is a regulation nor does
> it carry the force of a regulation. When periodic capacity checks are
> mandated they will be described in an official document specific to
> the airplane under the heading "Conditions for Continued Airworthiness".
> The words that describe the test and how often it is done have to be
> part of the maintenance manual published by the manufacturer -or-
> included in the STC obtained by the manufacturer of the product
> being retrofitted to the airplane.
> The recommendations you are referring to are cover their ass
> weasel words. For example, when I sell my LV monitor/voltammeter
> kit, the instructions say something like, "we recommend you
> check the calibration of this instrument every annual and
> using the following procedure." Most won't bother. But should
> someone come back years from now complaining that my gizmo
> was way out of calibration, I can ask, "Did you do the recommended
> calibration procedure last annual?"
> You are required to do a capacity check only if it's described
> in detail in the STC paperwork along with a pass-fail criteria.
> In this case, the test would become part of the airframe's
> official requirements by supplementing the factory documents.
> If you were using this airplane in some kind of flight for
> hire operation, there may be OPERATIONAL requirements under
> Part 121, 135, etc. that required periodic capacity checks
> but I don't suppose the airplane will be used that way.
>>I knew enough about batteries from your course to know that you recommend a capacity
check along the lines in the Gill literature, but not necessarily at the
80 percent level. I found in FAR 23.1353 that in 1996 the FAA had added paragraph
(h) with a seeming requirement for a capacity check, though the requirement
apparently pertains to all storage batteries, including flooded cell batteries,
and to "those loads that are essential to continued safe flight and landing,"
rather than 30 amps. I contacted Gill, Concorde, AOPA, Mooney, the FAA,
and two shops to find out if the FAR actually required a capacity check.
I got a wide range of opinions, none of them in agreement, from all but the FAA,
which sent me an e-mail thanking me for my comments on airport security in
the wake of the September 11 events.
>>I recognize that you do electricity, not FARs, but I hope you can help me. I
know that a capacity check is wise, but is it an airworthiness requirement?
If it is a requirement, who determines the amperage load used in the check --
the FAA, the battery manufacturer, the aircraft manufacturer, the owner/operator,
or someone else? In your opinion, what is the best and safest way to conduct
the check?
> All good questions to which the answers are benign because
> the requirement doesn't exist. Unless specified otherwise
> in the POH, "loads that are essential to continued
> safe flight and landing" need to be determined by those
> who operate the airplane. See chapter 17 of my book which
> you can download at:
> http://209.134.106.21/articles/Rev9/ch17-9.pdf
> You need to determine for you OWN gratification how
> much stuff can be shut off in order to leave only those
> things active that you NEED for comfortable continuation
> of flight. For my money, the 30 minute requirement
> in FAR 23.1353 is BS . . . you should be confident
> that fuel is the only limit to endurance on your airplane
> and you should know (1) how to shed loads to conserve
> en route energy usage until airport is in sight and
> (2) whether the battery capacity you have on board will
> cut the mustard. It's really EASY to do in a homebuilt
> but not impossible on certified iron.
>>I might note that neither of the shops knew about the check, and I doubt that
any of the general aviation aircraft at the two fields have ever had the check
performed. I got opinions from Gill, Concorde, and AOPA that were less than
professional, leaving me in doubt that anyone understands the 1996 amendment
to FAR 23.1353, if they even saw it.
> A repair shop is not required to KNOW the design
> regulations for an airplane beyond a rudimentary knowledge
> of what they should do or not do to avoid compromising
> some feature in an airplane upon which they are hammering.
> EVERYTHING the mechanic is supposed to know comes right
> out of the OPERATING documents . . . 100 hour inspection
> checklists, overhaul manuals, service manuals, etc.
> Since the periodic capacity check has never showed up
> in a manual they had to follow, it's understandable that
> they wouldn't know anything about it.
>>If you don't want to dabble in interpretation of the FARs, can you at least give
me the name and number of a person to contact at the FAA who can understand
that this is a legitimate question about electrical systems that affects all
of general aviation?
> Like the IRS and other organizations we've grown to
> know and love, the FAA's front line grunts that answer
> telephones are endowed with no more ability for
> intuitive, logical thought than folks dragged in
> off the street. Call 10 different people and I'll bet
> you get at least 5 different answers.
> Bob . . .
Subject: | Re: "How to safeguard your avionics" |
>>On their "safeguard your avionics" page,
>>http://www.aea.net/R1/Secure/guide2.pdf
>On this page they say to make sure the airframe static wicks and grounding
>straps are in good condition. Are static wicks necessary in slower
>(<200mph) aircraft? With respect to avionics, how do they help? If they
>are needed, how do you go about determining position and quantity?
Static wicks are a performance issue . . . not a safeguard
issue. Depending on paint, speed and atmospheric conditions
you can build a static charge on the airplane that will begin
to bleed off in random fashion with so much local current in
the discharge that it creates an interfering noise in receivers.
There are no 100% rules for the numbers and placements of
static wicks. Further, static wick performance can vary widely
from manufacturer to manufacturer . . . for awhile at Raytheon,
we had to do receiving inspection on every wick that came in the
door to insure a minimum performance level. The ultimate
solution for number and placement of wicks on some RAC/Beechcraft
products was hard won after a lot of cut-n-try flight
testing.
By-and-large, don't worry about them until you find that you
need them. Flying in snow, is the most difficult situation
to endure. If your radios are still receiving well then you
will not need them. If the prop tips start glowing blue and you
get little fuzzy lighting streamers around the edges of the
windscreen, then it's a pretty sure bet that you've got a
problem that can probably be helped by installing wicks.
Subject: | Molex Type Connector Question |
Bob or other knowledgeable person: I am planning my RV-6 slider instrument
panel to be removable for service and I am considering the use of Molex
connectors to facilitate separation of the wire bundles between the panel
mounted switches, lights and instruments and the fuse blocks and all the
other stuff mounted behind the panel. My wiring scheme is basically per
Figure Z-11. I would use the detent lock style connectors with receptacles
mounted in the subpanel and free hanging plugs. I have the following
questions and will appreciate any helpful comments and suggestions:
1. Are these connectors acceptable for experimental aircraft use?
2. Is this a reasonable plan?
3. Are there any "gotchus" I should know about?
Thanks in advance and for your continued good natured support of people with
dumb questions like this.
Harry Crosby
Pleasanton, California
RV-6, starting wiring.
Subject: | Re: Molex Type Connector Question |
> instrument
> Molex
> panel
> the
> per
> receptacles
> people with
> Harry Crosby
Harry:
I am using Molex style Amp connectors exclusive in my airplane. So
far, no problems but the airplane is only 4 years old and has only
flown 1,000+ hours. It has only been to to the Arctic Circle once,
coast to coast 5 times, to the highest airport in North America, and
also to the lowest.
There were no wire splices used in construction of my airplane. Molex
style connectors were used in their place. One thing I did was to have
as few connections as possible. Every connection is a potential
failure point. With that said, only add connectors where needed. My
harness stays with the airplane. (RV-6 slider) The switches are
removable from the panel and the radio stack stays in the airplane.
The instruments all come out individually and the panel is removable
but no wires come with it.
Can one work on a panel like I describe above? Yes. I removed my
Apollo GPS 360 and KX-125 and replaced them with SL-30, GX-60, ACU,
MD200-306 indicator, NavAid, new vacuum regulator, new vacuum filters,
new vacuum lines, and a new SigmaTek AI with 8 degree tilt. The vacuum
system was in the airplane but was time to clean or replace the lines
and filters. Suction regulator was one of three items that was
installed used in the airplane. I now only have one used item left as
two out of three have failed.
I sold the GPS last week. Need to advertise the KX-125 and sell it.
If you use Molex style connectors, purchase extra contacts along with
the contact removal tool. There are several different size contacts
and several different styles that are not interchangeable. I prefer to
use in line or in harness connectors instead of having a receptacle
mounted in a piece of metal. It is extra work to install the
receptacle into a mount. Do it if you think it is worth the extra
work.
Gary A. Sobek
1,002.9+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
Yes, the Molex connectors are acceptable.
But, I'd recommend the Amphenol plastic Circular Connectors. (do a search on
these at www.digi-key.com)
They don't cost much more than the Molex connectors and they have a very
positive twist lock feature.
I wired my Velocity instrument panel using the Molex's before someone showed
me the Circular Connectors. I replaced them and am very happy with the
change.
Subject: AeroElectric-List: Molex Type Connector Question
instrument
receptacles
with
> Harry Crosby
>change.
I agree. If you need multi-pin connectors, the circular
plastic Tyco/AMP connectors are much easier to work with than
the Waldom/Molex and they use superior contact materials.
See page 146 of the Digikey Catalog at:
http://info.digikey.com/T021/V5/145-147.pdf
The Series 1 connectors use formed pins capable of
more current than the Series 2. Series 1 pins can
be installed with the B&C's BCT-1 crimp tool.
http://www.aeroelectric.com/Catalog/tools/tools.html#bct-1
My personal favorites are the Series 2 that use
the same machined (or formed) pins as D-sub
connectors. You can install and remove these pins
with the same tools as D-subs. B&C RCT-3 crimp
tool at:
http://www.aeroelectric.com/Catalog/tools/tools.html#rct-3
and DSE-1 extraction tool at:
http://www.aeroelectric.com/Catalog/tools/tools.html#dse-1
A typical Series 1 connector can be viewed at:
http://catalog.tycoelectronics.com/TE/docs/pdf/9/14/167419.pdf
A Series 2 is at:
http://catalog.tycoelectronics.com/TE/docs/pdf/1/30/215031.pdf
The Waldom/Molex connectors are the same genre' as AMP Mate-n-Locks.
They've been used on automotive -AND- aircraft for over 35 years.
I like to minimize the use of connectors where ever possible. Every
connector adds three new joints to every wire. Would a wire bundle
with say 12" of slack in it let you pull a panel down and tie it
out of the way without using a connector?
Nothing real serious. Minimize parts count and labor when you can
but if a connector is really necessary to your goals, consider
the circular plastic connectors cited in a couple of other
posts to the list. They offer gold plated contacts and superior
low cost tooling for very little additional cost.
(o o)
Subject: | Re: current limiter in b-lead |
Your new Fig. Z-22 shows an ANL current limiter in the b-lead when using a
Skytec starter. I assume this wire run would only go from the alternator to
the built-in starter solinoid and thus be fairly short.(Reference your fig.
Z-14, rev.8)
Would the circuit protection still be necessary and if so at which end to
protect which device/length of wire?
Yeah . . . we're concerned about shorted diodes
in the alternator . . . here the source of power
that blows the fuse is the battery.
Without a PM starter system doesn't your circuit protection get put near the
normal starter solenoid?
Yes, because the b-lead needs protection from battery.
With the PM starter, the b-lead is so short (rear of alternator
to fat terminal on starter) that it's more a matter of mechanical
convenience as to how the fuse is installed. For this application,
I think I'd stay with the fast JJN/JJS series fuses covered with
heat shrink . . . this combo is a bit easier to work with in the
small space and closer quarters behind the starter and alternator.
< Throughout history, poverty is the normal condition >
< of man. Advances which permit this norm to be >
< exceeded -- here and there, now and then -- are the >
< work of an extremely small minority, frequently >
< despised, often condemned, and almost always opposed>
< by all right-thinking people. Whenever this tiny >
< minority is kept from creating, or (as sometimes >
< happens) is driven out of a society, the people then>
< slip back into abject poverty. >
< This is known as "bad luck". >
< -Lazarus Long- >
From: | "Jim Robinson" <jbr(at)hitechnetworks.net> |
I have a SkyTek starter that was given to me and is good condition.
Is this a PM starter? What special conditions are necessary with
this starter? I was going to use a B&C starter but couldn't pass up
the deal.
Jim
Subject: | Dumb Vacuum Pump Question |
I'm looking at the Rapco vacuum system kit from Spruce and I see I have to
specify whether I want a 215 CC pump or a 216 CW pump. Would some kind soul
take pity and tell me which I need for an O-360 A1A, and why. Please no
lectures about the merits of all electric, all of life requires trade offs.
Harry Crosby
RV-6, finish kit stuff
Subject: | Re: Dumb Vacuum Pump Question |
In a message dated 1/26/2002 2:28:51 PM Pacific Standard Time, HCRV6(at)aol.com
writes:
<< I'm looking at the Rapco vacuum system kit from Spruce and I see I have to
Harry Crosby
RV-6, finish kit stuff >>
You want a 215CC because it turns counterclockwise, which is what you need
for your Lycoming. You may have an older style 211CC on there now.
Cliff A&P/IA
Subject: | Two Infinity grips - only one active at a time |
Bob and others,
I have two Infinity grips and I want to be able to perform certain
functions from (only) one or the other. I plan to put a toggle switch
on the panel to control the "Infinity in command".
I found a wiring diagram in the archives and built a box with two
relays to control my flaps and it works fine on the bench in single
(Infinity) grip mode. Can you explain how I can accomplish this?
Thanks in advance,
Tom Barnes -6 wiring
Subject: | Re: Two Infinity grips - only one active at a time |
>Bob and others,
>Thanks in advance,
Without knowing how many total circuits run through your
stick grip switches and how they vary in function (pull
up to bus, pull down to ground, logic level signals
to black boxes, etc) I can say that the worst case scenario
involves an umpteen pole, double throw switch to transfer
each switching function back and forth between grips where
the number umpteen represents the total number of switched
functions.
On some aircraft I've worked on, we designed "pilot priority"
circuits such that if any single function is being
commanded by both pilot and copilot controls, the pilot's
controls had priority over the copilot's. Kind of slick
as bells and whistle go but in my not so humble opinion,
not very elegant.
The added complexity of such systems adds failure modes
and doesn't add much in the way of safety or convenience.
When two people are likely to have their hands on the
controls, it's a foregone and preflight briefed conclusion
that "I HAVE THE AIRPLANE!" is the other guy's clue to
drop what he is doing and let loose. The likelihood of
having to use this tool very often is rare.
Having said that, if you'd want to fax drawings of
all the switches and circuits, I could sketch out
the necessary goodies and wiring to do the job . . .
If it were my airplane, I'd budget the time
and dollars need for this effort toward a better
looking paint job . . .
(o o)
Thanks for your input. The man that sells the Infinity grip has
led me to believe it was as simple as a "single switch" but in the same
breath, he said he was not a techie and didn't know exactly how to do
it.
Because my panel has already been designed and cut and labeled
for the switch, I will plan to limit the switch to just the flap up and
flap down functions and next week will fax to you the schematic.
Thanks again,
Tom Barnes
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
Subject: AeroElectric-List: Re: Two Infinity grips - only one active at
a time
>Bob and others,
>Thanks in advance,
functions.
not very elegant.
(o o)
Subject: | RE: Two Infinity grips - only one active at a time |
>Bob,
>it.
There is a scenario where a single switch might get it. You need
to arrange for ALL of the controlled devices to become activated
by means of a switch closure to ground. This means that if you have
6 functions in the stick grip, there would be 6 wires plus a ground
that would interface the switch to the system. In this case, a simple
single pole, double throw switch could be used to complete the
ground to one or the other grip but not both.
Subject: | Battery management module or isolation |
Browing the archive, I read about an individual who
had an alternator failure on one flight. It was
shorted and the breaker did not trip (in a Cessna).
The battery went dead in seconds but he was able to
land safely because he was using old technology, not
the new stuff that depends on electricity.
This made me think about the dual-battery setup...
with the two contactors closed, I could see the two
batteries going dead the same way as he experienced.
And then, I read Bob's article "WHAT'S ALL THIS
BATTERY ISOLATOR STUFF ANYHOW"?
Figure 2 presents a configuration with a battery
management module which would open the aux battery
contactor immediately on alternator failure.
Would this module really prevent damaging (or
draining) the second battery in an alternator short
situation where the fuse or breaker did achieve its
duty?
Bob, is this a module commercially available either
from you or other sources?
As an alternative, a friend is using a DC to DC
converter to constantly charge his aux battery. The
input of the converter is 9 to 75 volts and the output
is 15 volts then regulated to 14v. The battery is not
normally feeding the bus, but it can help during
starting, thanks to an additional starter contactor.
I can see that with his setup, the aux battery would
be completely isolated from any main bus or alternator
failure during operations.
Any opinion on that?
Thanks!
Michel
Michel Therrien CH601-HD
http://pages.infinit.net/mthobby
http://mthobby.pcperfect.com/ch601
Subject: | fuel line support -6A |
I'm routing the fuel line from the tank to the selector valve in a 6A.
According to the AC413.13 book that's long enough to require a support
(16" run is the limit). Affixing a clamp to the smaller gear weldment
tubes would work, but I certainly don't want to drill any holes in those
tubes.
Does any one know of a good way to attach an adel clamp (or other clamp)
to the gear weldment without drilling any holes in the weldment's tube?
Or perhaps there's a better place to attach a support?
Tom Sargent.
Subject: | Re: RE: Two Infinity grips - only one active at a |
time
Hold on guys! Most switches are "Break/Make" which means that the GND will be
removed for a split
second before the other sides control grip, switches, GNDs kick in. And, what
if the switches on
the other grip are not set the same??? I think it is a bit more complicated than
you first think.
Tom...
"Robert L. Nuckolls, III" wrote:
> >Bob,
> >it.
> Bob . . .
Subject: | Re: fuel line support -6A |
Perhaps you could put one adel clamp around the gear mount tube, then another
around the gas line adjusted so the holes in the two clamps coincide, insert one
screw through both, and voila', instant support. Not really sure if this is
acceptable practice, but it would be a "support"!
From the PossumWorks
Mark -6A fuse
> tubes.
> Tom Sargent.
From: | "Vincent Welch" <welchvincent(at)hotmail.com> |
On the -8A Van shows a -12 adel clamp around the gear leg weldment attached
by a #8 screw and nut to a -6 adel clamp. The -6 is used to support the
fuel line.
Vince Welch
RV-8A Finish Kit
>From: tom sargent <sarg314(at)earthlink.net>
>Reply-To: aeroelectric-list(at)matronics.com
>Subject: AeroElectric-List: fuel line support -6A
>Date: Sun, 27 Jan 2002 14:33:18 -0700
>tubes.
>Tom Sargent.
Subject: | Re: RE: Two Infinity grips - only one |
active at a time
removed for a split
if the switches on
you first think.
>Tom...
What is the scenario wherein you perceive the momentary
ground interruption to be a problem?
Subject: | Re: RE: Two Infinity grips - only one active at |
atime
Hiya Mr. Bob,
Mr. Tom wrote he wanted to "perform certain functions" and that he had "built a
box with two relays to
control my flaps". What I am saying is that he has a lot of variables going and
with out knowing types
of relays (like you said (pull up or pulled down)) and switches (to +12v or to
GND) he is using for
whatever, my best guess is a single switch will not cut it.
And what if he has his flaps switch set on one control and not on the other and
then flips "the switch"
on short final? Again, too many variables.
Tom...
Check out my Home Web Page at:
http://home.pacbell.net/tsled
be removed for a split
if the switches on
than you first think.
> >Tom...
> Bob . . .
Subject: | Re: Battery management module or isolation |
If his battery had any snort left, it would
have tripped the breaker. Here's a classic case
where the battery was run years past operational
failure . . .
Not if you maintain your system with the most
rudimentary of battery change out protocols.
>duty?
Sure . . . but (1) if you have any active notification
of alternator failure, maintain the battery such that
it gets replaced either (a) when capacity drops below
that required to keep the e-bus running 3-4 hours
or (b) new one every year in main slot, move main battery
to aux slot.
For my money, one battery and two alternators is head
and shoulders above any of the alternatives. See
the article for All Electric Airplane on a Budget.
No, I've had so few requests for them, I've not
been able to justify the time and expense of
bringing it to production. I'm working on a do-it-
yerself gizmo that you can build with Radio Shack
parts.
To complicated, too expensive, too heavy . . .
we can do better than this. Your questions
and concerns at the outset of this discussion
were based upon a series of events wherein the
owner/operator of the airplane either didn't
understand or didn't care about how the system
worked and allowed it to degrade to a condition
I haven't seen a shorted alternator diode in over
20 years . . . Don't think B&C has seen one
ever on their ND reworks. The airplane cited in
the opening paragraph probably still had the 1960's
style, Ford junk alternator (for which there are
several STC'd diode replacements that promise to
be more robust) and a poorly maintained, flooded-
cell battery.
These are interesting stories but only from the
perspective of how sad the technology and technical
acumen of the certified world stacks the odds
against comfortable completion of flight
when something breaks.
Latest AOPA pilot has yet another similar story.
I believe the folks who participate in this list
agree with me that we're building the finest airplanes
to have ever flown. Further, I think we share a goal
of removing the word EMERGENCY from the lexicon of
our speech about electrical systems. Our mission
is NOT to figure out how to deal with the problem
of the past when they happen on our new airplanes.
The mission is to understand how they happened in the
paste and design both the system and the pilot's
understanding so that they DON'T happen again in
the future.
Yep . . . you got it.
Double ty-wraps work also.
Subject: Re: AeroElectric-List: fuel line support -6A
another
one
Mark -6A fuse
> tubes.
> Tom Sargent.
Double Ty-Raps are not an acceptable method. Hoses ty-rapped to engine mounts
have been known to saw thru the steel mount due to oil and grit along with
vibration. The adel to adel clamp method as outlined by Mark is standard aircraft
methodology -Steve
> From: "Mark Phillips" <ripsteel(at)edge.net>
> To:
> another
> one
> Mark -6A fuse
> > tubes.
> > Tom Sargent.
> the GND will be removed for a split
> in. And, what if the switches on
> complicated than you first think.
> Tom...
That's exactly what you'd want.
Let's say pilot has flaps up set, and copilot has flaps down set.
The toggle is set to pilot side and flaps start going up.
If the switch is flipped, and it's a break-before-make switch, there's an
open circuit (no electricity flows) for an instant as the pilot's switch is
cut out and the copilot's switch is cut in. Flaps start going down.
If the toggle is a make-before-break, then there's an instant where the
flaps motor is getting an "up" command from the pilot at the same time it's
getting a "down" command from the copilot. Depending on how this is wired,
it's very likely this results in a dead short to the power supply. A Very
Bad Thing.
I think that a break-before-make is what you'd want here.
Ultimately, the solution is not to have duplicate controls. With one flaps
switch on the center console, there's no doubt in anyone's mind which switch
is commanding, and no possibility of confusion.
And it's simpler and has fewer parts that could break and therefore fewer
failure modes.
Oops! I think I'm becoming a "disciple of Bob" here!
-Matt
It is always amazing to me how the unique failure, the once in several
lifetimes event, the fluke that happens under very unusual circumstances
evokes a solution that will in all probability screw up conventional
protections against "normal" failures. These schemes become complex, heavy,
expensive, and for what? Something that the normal flyer will never
experience in a 1000 years. Something that probably no one else has
experienced.
When one does the research, many of these unique happenings turn out to be
an "urban legend," the figment of a vivid imagination. Just because it was
published on the internet DOESN'T make it true. Always think of K.I.S.S.
until the aberration goes away.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Always looking for articles for the Experimenter
Subject: AeroElectric-List: Re: Battery management module or isolation
failure . . .
>duty?
to aux slot.
parts.
cell battery.
the future.
Subject: | Re: Two Infinity grips - only one active at atime |
>Hiya Mr. Bob,
a box with two relays to
Oh . . okay, that's what I'd told him earlier when
I'd asked to see the schematic for what he wanted to
control. I don't really like the idea for the switch
for the reasons you mentioned . . . and others. We'll
see if we can figure out a way to make it as surprise-
proof as possible.
>> Tom...
>Bad Thing.
>failure modes.
Bless you my son . . . . I'm still agonizing over whether or
not to help this thing move forward. Trim systems NEED to
be accessible to both pilots and they should not be so fast
that inadvertent operation is a hair-raising event. Further,
being momentary push-to-command-motion systems, there's no
way to leave a trim system in a condition that becomes
and unhappy surprise to the other pilot.
I've had a number of builders wanting to put starter
push buttons and flaps on the stick . . . if it's pilot's
stick only it might not be so bad but having these
controls on two sticks give one pause . . .
I've got something between 1500-2000 hours and I can't imagine
ever wanting to have such easy access to anything other than
trim, intercom PTT, radio PTT, and maybe xponder ident and
frequency flip flop . . . and even the last two are very
low on the convenience list and high on the list of nuisance-
inadvertent operations.
(o o)
>experienced.
Agreed! My personal favorite came into being when the
FAA became alarmed at the number of battery fires in airplanes
fitted with Ni-Cad batteries. These critters have a negative
temperature coefficient for ideal charging voltage. Further,
they will readily accept a whole lot of amps of recharge current
from the starter generator on a turbine engine. Without
going into a lot of details about the root cause of the
battery fires, it's sufficient to say that in any airplane
with any battery the #1 task of the voltage regulator is
to take care of a battery.
Instead of mandating a voltage regulator with current and
temperature sensing to anticipate and prevent battery overheat
and subsequent fires, the wisdom of the moment called for
adding a panel mounted readout of battery temperature and
additions to the POH instructing the pilot how to manage
battery overheating situations.
We increased system complexity, cost and added to pilot
workload when the technology to do the elegant thing
was laying on the ground to be picked up and applied
in a manner that was totally transparent to the pilot.
Subject: | transfer switch; and dual batteries |
on 1/28/02 02:51, AeroElectric-List Digest Server at
RE: "What happens when the transfer switch is thrown and the other pilot's
switch is set differently...." The DC-9's I used to fly had an autopilot
transfer switch. Many cups of coffee were spilled when the pilot-flying
would be about to leave the flight deck... and would give the 'you have
control' signal. If the co-pilot failed to coordinate his heading bug to the
current aircraft heading before the autopilot inputs were passed to his
side, some sudden and surprising roll-rates were triggered! fwiw
Last summer during my aircraft's test flying program, I experienced a
failure of the drive/belt/pulley on my alternator while at an 'away'
airport. I have an CAM100 (Honda auto conversion) with dual electronic
ignition system, so I had to consider carefully if flight home without the
alternator was a go or no-go item.
My electrical system is patterned after Bob's 'dual RGB battery' system
(with some mods for to the electronic ignition). I was able to keep Batt2,
that feeds the ignition system, in isolation (i.e. master switchs OFF), and
use the ESS BUS supply switch to connect Batt1 directly to the essential
items required for flight.
I had a pretty good idea of how long Batt2 could keep my engine running
(i.e. much much longer than the ten minute flight home), and I could use the
radios, etc. with no fear of ever killing my engine due to running down the
battery.)
It was just a short flight (which was good because even though I KNEW it was
supposed to work like this, I'd never tested it before!) but it did prove
the concept of having an alternator failure in flight, and being able to
confidently finish the flight.
So, thanks to Bob's design idea, I was able to safely ferry my aircraft home
and avoid expensive taxis/hassels/repairs away from home base. Thanks again,
Bob.
(The only 'addition' I think I'll make from this experience, is to add a way
to read Batt2 voltage independantly - just to give me a warm feeling that
it's holding as expected ;-)
Grant Corriveau
Montreal
Zodiac 601hds/CAM100
C-GHTF
www.theWingStayedON.ca
Subject: | 2 stick grips, 1 flap switch |
In case the abject logic of Bob's (and others') didn't put
'paid' to the account, why don't we note the number of airliners with two
flap switches, one for each flyer. I've never seen one.
Now mebbe we could look at the B47 (tandem pilot seats) but
five'll get you ten it was an interlinked mechanical lever, just like the
Harvard (T6).
Ferg
diesel Europa
From: | "Nancy and Walter Shipley" <wshipley(at)esper.com> |
Subject: | Fried OV spike supression diode |
Bob, when I did my initial engine start yesterday, a puff of white smoke
rose from the spike supression diode on my ov contactor. When I checked, I
found the diode cracked and white residue on the contactor. Obviously, I
had a spike in voltage, but why?
To give you some background, I have an RV8A with an IO-360 engine, an
Odyssey PC 625 RG battery (17ah), a nippon dinso alternator with built-in
voltage regulator, and I wired in your OV contactor per your schematic
entitled "OV PROTECTION FOR BUILT-IN REGULATOR."
During this initial engine start, the engine ran quite rough. I don't know
if this is related to the diode frying or whether it's due to improper
ignition timing or ???
Any input you have will be greatly appreciated..............
Walt Shipley
P.S. I will need another spike supression diode to install once the problem
is solved, can I get that from you?
Subject: | RE: a few questions for you |
>I ordered 2 of your S704-1 relays. How do I wire those? They have 2 'On'
>connectors, 2 'Com' connectors and one unlabeled connector.
The little terminals are for the coil of the relay. These are
interchangeable. The fat terminals are for the switched contacts
and they too are interchangeable. If you want to add a diode across
the coil terminals for spike suppression (not a bit issue but
easy to do too) you can install a 1N400x diode (from radio
shack) as shown on
http://209.134.106.21/articles/s704inst.jpg
>I also have one of the B&C OV protection devices (LR3B-14). I noticed in
>the wiring instructions that there is a temperature probe connection for the
>battery. Is this available as an option? If not, is there a thermometer
>inside the unit that regulates the voltage presented to the battery? In
>other words, should the OV protection unit be located in the same climate
>(in the cockpit) as the battery? I wrote once before about this but my
>question wasn't very clear - still on a vertical learning curve.
There is an optional battery temperature probe available for
the LR3B series regulators. Unless you plan to spend
hours cruising at the rarified altitudes wherein you
might cold soak a battery while trying to charge it,
you don't need this option.
>Do you have any suggestions about a limit switch to limit the flap up
>circuit on an RV? I noticed several pictures of limit switches in the
>switch section of the 'connection, but don't see anything on the web site.
Just the up-limit? . . . or do you need one for down too.
Take a look at a radio shack 275-017 . . . these are
pretty small but they would work. There's a little larger
switch you can see at
http://209.134.106.21/BasicSwitches.jpg
and order from Digikey at http://www.digikey.com
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Subject: | My Infinity grip set up |
I have two Infinity grips in my RV-6A. On both sticks I have trim, flaps,
and PTT. I can say that it is invaluable to have these controls on the
stick. While in the pattern or on short final, it is VERY nice to just keep
your hand on the throttle, and hand on the stick. With a movement of the
the thumb, I can activate more flaps if I'm too fast, and minute trim
adjustments are just dandy. If I were to do it again, I would defiinately
put the flaps on the stick.
On to the passneger stick. I'm tossed up here. I have flaps and trim on
that stick as well. My 5 year old daughter rides with me and has never hit
the switches. She knows not to, so it's not an issue. Every person I take
flying I do the passenger brief, and let them know what the controls do. It
has not been a problem. I let other pilots fly my airplane, but not land
it. So far, I haven't had a pilot in the right seat that I felt comfortable
enough with to allow to land the airplane. Most RV pilots would be flying
their own airplane, so they aren't in mine. It would be nice to have in the
event I became unconcious and had a pilot in the right seat. Or, if I had a
qualified pilot with me who would like to land the airplane.
So, in retrospect, I think I would still have installed it on both sticks.
Next time, I think I will for safety purposes a disconnect switch on the
panel that renders the buttons useless. Yes, it is added complexity, but
since I only have flaps, trim, and PTT on the stick, it isn't critical. One
could land the plane without these controls on the stick. The only thing
they would have to do is reach over and push my push to talk for
communications.
For the other switches, I wouldn't use them. To complicated, and don't
really need anything else. Engine start is useless in my opinion. You only
turn your key or push your start button once, so it's not a convenience for
in flight purposes. Flip flop might work, but usually when I do my flip
flop, I have just changed freqs on the radio anyway, so my hand is at the
radio, and I could hit the flip flop. Autopilot disconnect would be cool,
but I have yet to use my Navaid, so I don't know if it is worth it or not.
Lights/strobes? Nah. Again, you usually only hit this switch one time, so
flight convenience is not an issue.
My $.02.
Paul Besing
RV-6A N197AB Arizona
First Flight 22 July 01
Kitlog Pro Builder's Log Software
http://www.kitlog.com
----- Original Message -----
Subject: AeroElectric-List: RE: Two Infinity grips - only one active at a
time
> >> Tom...
is
it's
wired,
Very
> >Bad Thing.
flaps
switch
> >failure modes.
> Bob . . .
> (o o)
> ===========o00o=(_)=o00o=========
> < Go ahead, make my day . . . >
> < show me where I'm wrong. >
http://www.matronics.com/browselist/aeroelectric-list
From: | "nknobil(at)gwi.net" <nknobil(at)gwi.net> |
Would there be a problem in jumping the COM terminal to one of the little terminals
in order to supply power to the coil and run the other to a switch between
in and GROUND?
Thankful for your input, as always,
Nick Knobil
RV-8 N80549
Bowdoinham, Maine
Original Message:
From: Robert L. Nuckolls, III nuckolls(at)aeroelectric.com
Date: Mon, 28 Jan 2002 08:38:12 -0600
Subject: AeroElectric-List: RE: a few questions for you
shack) as shown on
Subject: | Re: Fried OV spike supression diode |
Sounds more like the diode was wired backwards.
The two symptoms are unrelated. I am concerned about other
wiring issues. Normally, if this diode is reversed, it
pops the alternator field circuit breaker without hurting
the diode.
You need to check the wiring associated with this circuit
closely.
>Walt Shipley
You can get it quicker from Radio Shack cat# 276-1141 (two in
a blister pack for about $1) . . . or I can throw some
in an envelope for you.
check the photo at:
http://www.aeroelectric.com/Catalog/switch/s701-1l.jpg
Note orientation of banded end of the diode.
(o o)
From: | William Mills <courierboy(at)earthlink.net> |
Subject: | Re: My Infinity grip set up |
Paul -
Wouldn't the passenger's headset need to be plugged-in to the pilot's
side jacks for this to work?
>----------snip----------
>The only thing they would have to do is reach over and push my push
>to talk for
>communications.
>Paul Besing
I have two Infinity grips installed on my Express and have duplicated the
functions on both. The other day the flap switch did not work on the pilot
side and just for grins I reached over and the co-pilots worked. Very
grateful for reduntency in this case. I also have flip/flop, trim, PTT, A/P
disconnect.
Have a GREAT day!!!
Subject: AeroElectric-List: My Infinity grip set up
keep
take
It
comfortable
the
a
One
> communications.
only
for
so
> My $.02.
> Paul Besing
> To:
> time
> > >> Tom...
an
switch
> is
> it's
> wired,
> Very
> > >Bad Thing.
> flaps
> switch
fewer
> > >failure modes.
> > Bob . . .
> > (o o)
From: | "Arnold de Brie" <ajdbrie(at)interestate.nl> |
Hello everyone
Does anybody know if it is possible to connect two GPS receivers, a King
89B and a Skyforce, to the same antenna?
Is it necessary to use a special splitter or can one use just a BNC
T-connector?
Thanks in advance
Arnold de Brie RV8
The Netherland
From: | Ken Harrill <KHarrill(at)osa.state.sc.us> |
Tom,
I attached a small piece of angle to the "spar-floor board reinforcement
angle", and mounted an adel clamp to it.
Ken Harrill
RV-6 final assembly
From: tom sargent [mailto:sarg314(at)earthlink.net]
tubes.
Tom Sargent.
Bob, I said I wired up my OV protection circuit per your diagram, but today
I found I didn't EXACTLY do that. I bought a contactor from you ( same as
the one shown in s701-11.jpg). I wired the contactor in without noticing
the jumper running from the small terminal on the left of the contactor to
the large terminal labled "from battery" -
your diagram for the OV protection doesn't show this jumper, so I assume I
should have removed it? Anyway, I discovered today that this jumper was
completely burned off - all that was left were the ring terminals.
I also bought a couple of the Radio Shack diodes cat # 276-1141 as you
suggested, but I'm wondering if I have the correct item. They're called
"epoxy rectifiers" and they look different from the diode you supplied with
the contactor. They are small ball shaped gizmos, grey on one side and
black on the other. Are they suitable and which way do they go on the
contactor?
Thanks for getting back, and thanks for tolerating my ignorance...........
Walt
> From: Robert L. Nuckolls, III <nuckolls(at)aeroelectric.com>
> Subject: Re: AeroElectric-List: Fried OV spike supression diode
> Date: Monday, January 28, 2002 12:06 PM
I
built-in
know
> the diode.
> closely.
> >Walt Shipley
problem
> check the photo at:
> Bob . . .
> (o o)
From: | "Curt Reimer" <cgreimer(at)mb.sympatico.ca> |
Subject: | Re: You Have Control |
> control' signal.
This must be an airline pilot thing. I was taught to say "you have control"
and the other pilot says "I have control", but alas I've never flown the
line. What is the signal?
I see what you're saying but if the sight of the Captain leaving the flight
deck was'nt a clear enough signal that it's "his airplane" then he's got
serious "comunication" problems ! ; - ) Chris .
From: | "Brian & Debi Shannon" <wings(at)theshannons.net> |
Subject: | RE: AeroElectric-List Digest: 19 Msgs - 01/27/02 |
What's up with the aeroelectric.com website.....It seems to have
disappeared tonight?!?!? Is this a temporary problem?
Subject: | Radio Shack Rotary Switch for CHT & EGT |
Is it possible to use a rotary switch from Radio Shack
to switch the signals from the probes to Vans CHT &
EGT gauges?
Does the wire have to be thermocouple wire all the way
to the switch or can you use regular aircraft wire to
carry the signal from the probe?
Dan DeNeal
Wiring RV6a
Subject: | Stifling technology |
Your statement struck home for me here!
"""""""These are interesting stories but only from the
the future.
Bob . . .""""""""""""""""""
I have worked at maintaining certified airframes since 1966. I too feel
we should learn and benefit from our past. Unfortunately the FAA doesn't
support this idea. They prefer we all have an opportunity to die at the
controls of 50 year old technology. Their lack of central control over
rule interpretation and their fear of legal suits has made them useless
in todays environment. I am ready to surrender my A&P / IA (license to
obey the Moses of aviation) and join some group, somewhere that might be
interested in flying safety through advanced knowlege and the
application of some COMMON SENSE to the aeroplane.
You will ask why I feel this way? Well last week I got a call from the
FSDO that had my field approval request for replacing a prestolite
alternator system on a Beech A23-24 with B&C's 40 amp unit and voltage
regulator lying on their desk. They wanted to let me know they could not
approve it. When I asked why I got a string of three answers,
1-We won't make a field approval on a change which has an equivalent
change available as a commercial STC. (I read STC holder's wallet being
protected by the FAA here)
2-Why don't you ask B&C to PMA or STC their system. (I read STC
holder's wallet being protected by the FAA here also)
3-I don't want to expose myself to legal liability here. (FAA now
acknowleges that they have a fear of being sued).
Your tax dollar at work!!!! Heck no. Bureacracy, laziness, poor
leadership, inadequate training and many other problems, Yes!! Well you
can't fight city hall, so I'll just pack it in and crawl in a hole like
they do. There goes a tremendous love of aviation and a tremendous
amount of contempt for our government which no longer works for the
people but instead work for themselves.
Wes Knettle
Subject: | Fuel line support |
" Double ty-wraps work also. "
Try to avoid using these on metal tubing. When left there for years
gathering grit and oil they will actually saw thru aluminum and 4130
steel tubing. This is especially true in areas of high vibration and
wind movement. In my 30 + years I have found severely chaffed tubing
more often since the advent of popularity for the nylon wire ties then I
ever found from the old AN742 clamps getting loose occasionally and
chaffing tubing. The proper size ADEL rubber lined clamp will go a long
way to preventing this. Of course it still requires a good look at each
periodic inspection.
Wes K
Wisconsin
Subject: | Re: Fuel line support |
Thank You Wes -Steve
> Wes K
> Wisconsin
Subject: | Not airline alone |
"This must be an airline pilot thing. I was taught to say "you have control"
line. What is the signal?"
You have it right, but not just airline - it's an aviation
thing. Introduced at Flying Training schools so that the instructor can be
sure the student isn't fighting the controls. In airliners, the pilots are
within sight of one another (unlike fore-aft trainers) but THEN they say it
because they're not talking to each other, they're talking to the tape -
gives lawyers extra income.
Happy Motoring
Ferg
diesel Europa
Subject: | Re: GPS antenna splitter? |
>Hello everyone
>T-connector?
>Thanks in advance
>Arnold de Brie RV8
>The Netherland
I looked through my catalogs . . . don't find any
GPS splitters but intuitively, I don't see why they
cannot be made to work. Problem is that a GPS signal
is very, Very, VERY weak . . . and a splitter has
losses of its own stacked on top of the fact that only
half of the power coming in can be coupled to each
receiver.
I wouldn't use a splitter unless I was also using
an amplified antenna. This has a downside in that
you have a single active device with powered components
that drives both receivers . . . single point of failure
for both GPS receivers.
If it were my airplane, I'd have separate antennas
for each receiver to protect the integrity of the
dual receiver installation.
Yeah . . . I know, all those antennas look ugly
but let's not forget the mess that Piper got into
when they sacrificed electrical integrity and
performance to save a few ounces by using aluminum
battery cables on their fleet of single engine
products. Small improvements in one aspect of
the product's design can have significant effect
on the performance of other systems.
I catch a lot of flack from guys wanting to build
show planes totally devoid of ugly whiskers when
I remind them that the best PERFORMING antennas
are independent, full sized and as clear as possible
of obstructions. I recall a C-210 I saw coming
down the assembly line in 1968 with dual
nav coms, dual ADF, DME, HF (trailing wire
antenna out the tail cone) and Transponder
installations. This airplane really looked like
it needed a shave. However, if any of those radios
didn't perform to greatest potential, it WASN'T
because we compromised the antenna installations.
Dual GPS receivers can offer a lot of confidence
in probability of comfortable execution and
completion of any flight . . . consider doing
everything practical to avoid compromising
the performance and reliability.
Subject: | Re: Stifling technology |
A similar problem was solve on the Aeronca list when the local FSDO refused
to approve the use of a C-85-8F because the STC was for an C-85 without the
F.
What does the "F" stand for? It is the flanged crank instead of the Taper
shaft crank. Continental says its is the same engine, but the FSDO would not
budge.
They took the paper work to a different FSDO and it was approved. The owner
is now happily flying it.
You might check with B&C to see where they have had success with a field
approval and have the paperwork sent it from there for approval. Some one
the list might just volunteer to shepard the paper like happened on the
Aeronca list.
Subject: AeroElectric-List: Stifling technology
the future.
Wes Knettle
Subject: | Re: AeroElectric Server Outage |
>Bob,
Paul tells me that his connectivity went down and when
he tried to get help, the various institutions involved
all claimed, "must be the other guy's problem."
Folks who went home at 5 p.m. were unavailable to
continue the discussion until this morning . . . but the
system came alive before he could talk to anyone. Wonder
if the REAL culprit will come forward and explain what
was wrong . . .
(o o)
Subject: | Rough running engine - Was: Fried OV spike supression |
diode
01/29/2002 11:52:57 AM
Walt,
You may have a different problem, but here's my recent experience for what
it's worth.
A couple of weeks ago, I cranked up my IO-320 (160 HP w/ Bendix injection
system) for the first time and it also ran rough as a cob. Even though the
engine was run on a test bench at Aero Sport Power (Bart LaLonde) the idle
mixture must be adjusted for your particular prop load. Mine was way too
rich - to the point that the engine would not even run at idle with the
mixture knob full forward. Pulling the knob out about halfway made it purr
like a kitten, so I leaned out the idle mixture on the fuel servo, and now
it runs like it's supposed to.
The idle mixture is controlled by the length of the linkage between the
butterfly control arm and the idle mixture control arm. The little "Star"
turnbuckle (held in place by a spring) is turned in or out to change the
linkage length and consequently the idle mixture. It has no effect on the
high speed mixture, which is controlled by the mixture knob (attached to
the arm on the other side of the servo). I'd be happy to send you a copy
of the Bendix service manual if you could use it.
Danny Kight
Anderson, SC
RV-6 - hope to make the first flight this weekend!!!!!
Subject: | Re: Radio Shack Rotary Switch for CHT & EGT |
>EGT gauges?
Check out the article at:
http://209.134.106.21/articles/excerpt.pdf
. . . and then see if you still have any questions.
(o o)
Subject: | Re: Not airline alone |
>Cheers,
Read a book many years ago wherein an instructor pilot of WWI
era talked about his experiences with students. A light
tap on the shoulder of the guy in the front seat said,
"you have the airplane" . . . a robust smack on the back
of his head said, "it's MY airplane."
Wes...
I'll be sorry if you leave the aviation field as I think you are a valued
member with a treasure-chest of knowledge, but I am glad that you have come
to see the truth about the FAA... they are truly useless and serve no one
except those who pay kickbacks.
David J. Spencer
Beech Super III
djs(at)Group54.com
> Bob,
> the future.
> Wes Knettle
Subject: | Re: Rough running engine - Was: Fried OV spike supression |
diode
Now this is something I hadn't even considered. This engine came off an
RV6A with a two blade prince prop, and I'm using a three blade catto prop.
I'll give this a whirl...
Thanks, man, I appreciate the input.
Walt
> From: Daniel H Kight <kightd@basf-corp.com>
> Subject: AeroElectric-List: Rough running engine - Was: Fried OV spike
supression diode
> Date: Tuesday, January 29, 2002 6:52 AM
> Walt,
what
> it's worth.
the
idle
purr
now
"Star"
the
> Danny Kight
> Anderson, SC
know
When I learned to fly in the Army Air Corp. during W.W.II, the signal the
instructor always used to indicate transfer of control of the airplane was a
violent side to side shaking of the stick. Harley
From: | "Clark, Thomas IFC" <Tom.Clark(at)utcfuelcells.com> |
Electric list,
I am interested in hearing about grounding using the airframe verses using a
separate ground back to the battery. I have a -8 with a battery in the back
and was planning on using an airframe ground but am having second thoughts
due the pre-priming of all the airframe parts. All feedback is welcome. I do
have a instrument ground bus up front with a #14 wire back to the battery
but for nav lights, landing lights and the starter I was going to rely on
the airframe for a ground.
Tom Clark
-8 Fastback
Clark, get yourself a bonding brush. When you see it you'll understand the principal.
It looks like a
counterbore but with a short stainless steel wire brush where the cutter would
be. If you solid rivet the
one hole after using it, you'll have a very reliable ground for the life of the
airframe. This is how it's
done on production aluminum aircraft and the brush is used again to attach the
various components and
ground straps where needed. -Steve
"Clark, Thomas IFC" wrote:
> Electric list,
Asked my old man about it - he flew for 44 years - and he said that in his
early days, some captains would growl "sit on your hands and don't touch
nothin' but your ***..." Not exactly CRM, but reckons he never had a
problem!
Also mentioned that when he was an instructor on Tiger Moths during the
early part of the war, they used a communications system called a gosport
tube - one end was a megaphone over the instructors mouth, feeding a pair of
tubes clamped to the student pilot's ears. Reckoned that worked pretty well,
and was much appreciated by both parties as it was difficult to deliver a
smack on the head past the windshield.
Miles
> >Cheers,
control"
be
are
it
> Bob . . .
diode
Danny, since getting your earlier message, I retimed the engine, then
cranked 'er up again. Ran much smoother, but only when I had the cockpit
mixture control about half rich. Next, I played with the star shaped dealie
and shure enough, the engine ran much better. I still need to play with
the star some more, but thanks to you I'm heading in the right direction.
I will take you up on your offer of the Bendix Service Manual. Can you send
it via email? If not, my address is:
Walt Shipley
116 Tanasi Dr
Loudon, TN 37774
By the way where is Anderson, SC? We lived in Camden for a while many
years ago.....
Thanks again. Hope you get your bird flying and everything goes well.
Walt
supression diode
> Walt,
what
> it's worth.
the
idle
purr
now
"Star"
the
> Danny Kight
> Anderson, SC
know
Subject: | Re: GPS antenna location |
>A recent post to the aeroelectric list asked about a splitter for dual
>GPS antennas. The honorable Mr. Nuckolls says this may be problematic
>and preferred 2 separate antennas(ae?) Are those of you who have
>located these on the glare-shield or under the cowling satisfied with
>the results?
When I run my infamous dual-gps-for-under-$200 system, both
hand-helds are setting in front of me with their butts
Velcro'd to the top of the glare shield and the uppermost
forward corner laying against the windshield and held in
place with a small dollop of windshield sealant (black,
somewhat sticky putty).
In the high wing aircraft I fly, view of the sky behind
the wings has to be compromised. I don't know HOW much
compromise is present and the radios perform well from
this location. If you're considering antennas inside the
cockpit on a canopy aircraft, I have to believe they'll
work equal to or better than what I've enjoyed to date.
(o o)
Subject: | RE: Airframe grounds |
>Electric list,
In a nutshell, components NOT directly associated with
the instrument panel can be grounded locally.
If you don't have it already, I suggest you acquire a copy
of the AeroElectric Connection and check the chapters on
grounding and noise.
A metal airplane assembled with rivets cannot have components
insulated from each other. No matter how much primer you may
have used . . . the forces exerted by a rivet swelling to
fill the hole is far more than any paint can stand up to.
Ditch the #14 wire . . . it adds nothing but weight to your
airplane.
When attaching HEAVY current feeders to the airframe, pick
the heaviest structural material you can drill a hole in
without compromising structural integrity (for example,
be cautious about where and how big holes in a spar might
be). Clean the area around the hole equal to the diameter
of a washer sized to the fastener. In the case of a battery
ground, use a minimum 10-32 threaded fastener . . . 1/4-28
is better. Torque the 10-32 fastener 20-25 in-lb, torque
1/4-28 fastener 50-70 in-lb. These torque values will
enhance the probability of achieving a gas-tight joint
between the wire terminal and the airframe. After the
bolt is tightened, it wouldn't hurt to spray the connection
with primer.
Gizmos with lighter wire like pitot heat, landing and taxi
lights, nav-lights and strobe power supply can also use
local grounds . . . use 8-32 minimum hardware torqued to
12-15 in-lb and cover with primer.
The starter and alternator get ground via the crankcase.
No special attention is necessary. You should have
a nice flexible bonding jumper between a hefty bolt on
the crankcase and the firewall ground block. Except for
the outlying gizmos described above, everything else
should ground to the firewall ground bus with each device
enjoying its own ground wire.
Taking these simple steps will provide joint integrity
that will last the lifetime of the airplane.
Subject: | "you have control" |
"Read a book many years ago wherein an instructor pilot of WWI era talked
about his experiences with students. A light tap on the shoulder of the guy
in the front seat said, "you have the airplane" . . . a robust smack on the
back of his head said, "it's MY airplane." Bob . . ."
I soloed on a Harvard (T-6). The rear (instructor) joystick comes out and
stows for soloing from the front seat. Many a fellow stoogent came away from
early dual with a bump on the back of his head where the instructor had
taken ot the stick and prodded said head through the rollover structure. One
of our guys was big, gregarious and macho. He put up with this insolent
prodding for a while and then lost it on the next occurence. Knowing the
instructor was without a joystick, he rolled the plane over and then jinked
the pitch, thumping the boss's pumpkin all over the rear cockpit. He came
back and landed and said "one word, and you'll never make it to the
Officers' Mess". He wasn't there next day. Apparently he wasn't suited to
flight. Somehow I felt we lost a great fighter pilot.
From: | Frank and Dorothy <frankv(at)infogen.net.nz> |
Subject: | Re: "you have control" |
Dunno if its true, but this hoary old legend dates from the WW2 era...
Apparently, in the Tiger Moth the rear stick is also removable. And a
certain air force instructor, to demonstrate his faith in his student's
ability would ostentatiously drop his stick over the side. One enterprising
student, knowing that this was coming up, secreted a spare stick in the
front cockpit. When the instructor dropped his stick over the side, the
student bellowed "If you say so, Sir!" and dropped the spare stick over the
side too.
No mention of whether this student got his wings or not.
Frank.
Subject: | Electrical installation -- friendly neighbors? |
I just read the Chapter 16 on noise... euh... on
"Electromagnetic Compability" and I did not find an
answer I was looking for.
I intend to install the battery contactors behind the
passenger seat of my plane... but I have other gizmos
there as well.
On the right side is mounted the Strobe power supply
and ELT transmitter. I mounted the Navaid servo on
the left side.
Can I install the contactors and battery bus fuse
blocs near the strobe power supply? Or would I be
better off installing those on the other side of the
plane?
I'm now trying to put more stuff on the right side to
balance everything I've put on the left side (from a
weight distribution stand point).
See
http://mthobby.pcperfect.com/ch601/images/Dcp01219.jpg
for where it the electrical system would be located.
I would make the channel holding the strobe pwr supply
wider and fix both contactors and fuse blocs on the
channel.
Thx.
Michel
Subject: | Re: Electrical installation -- friendly |
neighbors?
>there as well.
I presume that since you use the plural form of
contactor that you have two batteries and a contactor
for each. I further presume that both batteries are
back there next to their respective contactors.
>the left side.
>plane?
Shortest practical connections are best. The
feed wire between hot side of battery contactor
and battery bus blocks would ideally be 6" or
less. These parts are not vulnerable to noise
from components located nearby.
Lateral weight distribution of fuselage
mounted items is not a big deal in single
engine airplanes from a perspective of
handling qualities. If you have wing tanks,
differences in fuel load from side to side
will have a much more profound effect which
may prompt the installation of electric roll
trim.
>See
>channel.
Where are the batteries with respect to the
contactors?
(o o)
Subject: | Re: Alternator warning light |
>Bob,
> I am looking for a simple circuit that will cause a light to come on when
the alternator stops charging, similar to the L lead function in automotive voltage
regulators (my aircraft regulator has no L lead). Do you know of one?
Sure. Go to our website at http://www.aeroelectric.com
Click on:
"Article Reprints, Newsgroup Threads, CAD Drawing Downloads"
Under the section on How To Articles click on:
"Click here for the schematic on a do it yourself low voltage monitor."
This device is the very best way to get timely active
notification of any charging system failure that renders the
alternator incapable of carrying ship's electrical loads.
All of the parts are available from Digikey for about $10.00
I recommend you avoid any of the automotive approaches for
driving an idiot light. First, without having a schematic of
how the sensor works, I can't tell if it will catch all
failures . . . Second, the proposed circuit will nicely drive
a high intensity red led that's small enough to mount right
in front of you on the panel where you cannot miss it . . .
it flashes too. . .
(o o)
*** Looks like a straightforward circuit. A bit too complex to get my FSDO
to sign it off on a field approval, though.
Wonder how hard it would be to build it really - REALLY - small. And
stick it onto the back of a cigarette lighter plug? And since the cig
lighter socket isn't really in the direct scan - stick on a REALLY bright
LED? I seem to remember that a 555 can source 200mA or so...
- Jerry Kaidor ( jerry(at)tr2.com )
Bob - Have you a LED solution to the standard filament lamp? Obviously
the life of a LED is better, not to mention heat dissipation, power
consumption and mechanical strength.
Mike Gray
>Bob,
on when the alternator stops charging, similar to the L lead function in
automotive voltage regulators (my aircraft regulator has no L lead). Do
you know of one?
Mike,
All you need to convert any incandescent circuit to an LED, is a
current-limiting resistor in series - and LEDs exist that even have them
built-in.
For instance, go to
<http://www.digikey.com/scripts/us/dksus.dll?KeywordSearch> and look up
"160-1046".
23 cents is all it costs! You can also get little panel-mount LED
holders, they're pretty cheap too, I've got tons of extras I've had
laying around here for years that I'll never use (if you ever come
through MLB, stop by), but you may as well include them in your order
from DK, they're pretty cheap too.
-John R.
> Mike Gray
> >Bob,
> you know of one?
Subject: | spike eating diodes again |
1/30/2002
Hello Bob, It appears that a significant portion of the questions that you
receive deal with the spike suppression diodes. You have my understanding and
sympathy if you feel that we acolytes are beating a dead horse, but still I'd
like to give that poor beast a few more whacks.
I have gleaned two fundamentals regarding connecting the spike suppression
diodes from your teaching:
1) The diode goes across the coil of the contactor.
2) The cathode end of the diode (the one with the bar in the diagrams and the
one with the stripe / bar / darkening on the diode itself) connects to the
positive end of the contactor coil.
Now I'd like to describe a local circuit diagram:
A) Envision a three terminal battery master contactor. One contactor large
terminal is connected by heavy AWG wire to the plus terminal of the battery.
This same contactor terminal is also connected internally to one end of the
contactor coil inside the contactor.
B) The other large terminal on the battery master contactor is connected by
heavy AWG wire to the input side of the airplane's starter contactor.
C) The one small terminal on the side of the battery master contactor is
connected internally to the opposite end of the contactor coil from A) above.
This small terminal is also connected externally by wire to the battery
master switch. When the battery master switch is closed it completes a
circuit to ground, current then flows through the contactor coil and the
contactor coil magnetic force moves the slug which closes the contact points
between the two large terminals.
D) The circuit diagram in question has a spike suppression diode connected
from the small terminal of the master battery contactor directly to ground.
The cathode (bar) end of the diode is on the terminal end of this connection
to ground.
Now the local circuit described in A) through D) above appears to me to
violate the two criteria given in 1) and 2) above because the diode is not
across the coil and the cathode (bar) end of the diode is attatched to the
negative end instead of the positive end of the coil. I am further concerned
because it appears to me that the plus terminal of the battery is constantly
connected to ground through the contactor coil wire and the diode.
So here are my questions:
AA) Will the circuit described in A) through D) above provide proper spike
suppression protection for the battery master switch?
BB) If the circuit described in A) through D) above will not provide proper
spike protection what connection of the diode and small terminal will provide
the proper protection?
CC) Will the circuit described in A) through D) above have any adverse
affects on the intended or desired circuit operation?
Separate, but related question: Of these two diodes listed below which one is
preferred for spike suppression and why?
DD) Type 1N5400, Cat No 276-1141, 3 Amp, 200 Amp Surge, 50 Peak Inverse
Voltage.
EE) Type 1N4001, Cat No 276-1101, 1 Amp, 30 Amp Surge, 50 Peak Inverse
Voltage.
Many thanks for your continuing help for your wandering troops.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
The LEDs I supply with my LVM-14 are very bright with the
circuit shown. Yes, you could easily build this into a
cigar lighter plug and then orient the LED so that it
shines right at your face . . . you'll see it.
If it were my Cessna, I'd put it in anyhow and just
not tell them about it.
Subject: | Re: Electrical installation -- friendly neighbors? |
Thanks Bob for the answers!
--- "Robert L. Nuckolls, III" >
> contactors?
This is a good question. My answer is somewhere in
the tail. I mean that exact location will be
determined when I do an initial weight and balance. I
am pretty sure it will be behind the contactors
location.
The location I'm planning for the contactors is
interesting to me because it allows me to install most
of the electrical system even though I don't know
exactly where the batteries will be. It is also a
location that will make maintenance and fixes really
easy. I won't need to work through a small access
panel. I'm planning to use aviation cable from
contactor to starter and welding cable from batteries
to contactors.
However, I will most certainly exceed desireable
distances between the batteries and the contactors. I
rationalize that the risks associciated with physical
damages are much less in the tail than they are on a
firewall electrical installation.
I am very open to critiques and comments. So please
do not hesitate to put me back on the right path if
required.
Michel
Greetings... I recently put new brushes in my starter. While it was
apart, I cleaned up the commutator and made sure the slots were free
of any buildup or debris. I noticed during the next two or three
starts, that the starter was spinning the engine significantly
faster than it did before, which I attributed to the clean
commutator, possibly harder brush material. This seemed like a Good
Thing... The next start, the engine spun for about a second, then
the starter went quiet.
Upon disassembly, I found the braided copper cable to the 'hot' brush
had cleanly parted near to where it was connected to a tab on the
post. It had clearly heated up and burned through like a fusible
link. I looked very carefully for any signs of a short, but couldn't
see any. I did notice that the part of the commutator where the
brushes ride had gone quit dark in colour already.
Any ideas what might have caused this? Should I be looking the
armature as a possible culprit? Or maybe the 3rd party brushes were
just not heavy enough? They seemed identical to the originals...
FWIW, this is a light-weight starter for a Rotax 582.
Thanks for any enlightenment here...
Regards, J.
flying: Zenair STOL CH701/582 C-IGGY , >150 hrs.
building: Sonex #325, engine undecided, probably Jabiru 3300/6/120hp
| J. Davis, M.Sc. (comp_sci) | email: jd(at)uwo.ca |
| SysMgr, research programmer | voice: (519) 646 6100 x64166 |
| Lawson Research Institute | fax: (519) 646 6135 |
| London, Ontario | lriweb.sjhc.london.on.ca/~jd |
If you spend any time administering Windows NT, you're far too
familiar with the Blue Screen of Death (BSOD) ...
- "MSDN Flash" email newsletter
Subject: | Re: spike eating diodes again |
>1/30/2002
Hmmm . . . if he's still twitching, whack away . . .
Yes
Correct
Correct so far . . .
>to ground.
I presume your talking about somebody else's wiring diagram.
What you describe is a situation similar to an airworthiness
directive issued against the classic OFF-L-R-BOTH-START keyswitch
offered by Aircraft Spruce and others. The AD was INTENDED to
replace starter switch contacts badly burned by the inductive
effects of the starter contactor and add a diode for the
purported task of mitigating the inductive kick from the
contactor and improved on switch contact longevity. The AD
calls for putting a diode ACROSS THE SWITCH contacts.
Take a peek at:
http://www.aeroelectric.com/nodiode.jpg
Here's an oscilloscope trace of the inductive kick across
a contactor coil when no diode is present. I had to rig
a very fast switching mechanism so that contact spreading
velocity was too high for a fire to form between the
opening contacts . . .
Voltage across the coil rises quickly reaching more than
300 volts in about 300 microseconds.
Take a peek at:
http://www.aeroelectric.com/doncoil.jpg
Here you see how the diode stops the intensive
negative going swing of the inductive spike because
electron flow of the spike puts the diode in a FORWARD
conducting mode.
Now look at:
http://www.aeroelectric.com/donswtch.jpg
Here, the diode is across the switch, just like the
FAA says you should do it. Note that the collapsing
field in the contactor coil is taking the terminal
negative, just like it did in the first picture you
looked at . . . this puts the diode in a REVERSE
current mode . . . no current flows.
Note in this figure how we can see where the fire
lights up between the poor switch contacts. We can
also see where the fire finally goes out after about
1.2 milliseconds. The remaining field collapse still
takes the spike to over 300 volts.
The situation you describe is the same as for the
starter contactor example shown in the figures above.
The diode is in the WRONG place to do its job. Your
perceptions and suspicions are well founded with the
exception of the last sentence. Note that with a diode
across the battery master switch contacts and with
the switch open, the small terminal of the contactor
coil rises to battery voltage. This puts the diode
in a reverse bias mode and no current flows.
No . . .
None . . . ya gotta put a BIG terminal on one end of the diode
and tie it to the battery side of the contactor . . . I.E. get
the diode properly wired across the coil.
Battery contactors don't store a lot of energy. Likelihood
of experiencing observable wear and tear on the battery master
is problematical . . . intermittent duty starter contactors
draw a LOT more current and store more energy, hence the
situation that brought the FAA cavalry galloping over the
hill to save us from an enemy they didn't understand.
>Voltage.
>Voltage.
Take you pick . . . ANY diode does the job with respect to
physics of the task. The electrical stresses on a diode in this
application are tiny. I PREFER the 1N540x series diodes because
they have bigger leads and a mechanically more robust design.
You can see how we put the diodes on in.
http://www.aeroelectric.com/Catalog/switch/s701-2.jpg
Note these diodes ARE the 1N540x series devices. You can
get these from Radio Shack in blister paks of two diodes
for about $1.
The starter contactor shown at . . .
http://www.aeroelectric.com/Catalog/switch/s702-1l.jpg
. . . doesn't have a visible diode . . . the contactors
we buy have the diode already built in.
My pleasure.
"I've got tons of extras I've had laying around here for years that I'll
never use "
John:
They should have been lying around for years. If they've been
laying, no wonder there are tons.
Good idea!
Ferg
A064
That doesn't make any sense - if you want to stop contact arcing, you
put a _capacitor_ across the contacts, not a diode... you put the diode
across the coil to clamp the reverse EMF. This is SOP, no, required
engineering practice - and the FAA doesn't know about it?!?
BTW, _is_ a capacitor across the switch a good idea? I don't think it's
really necessary if you've got the clamping diode, but I guess it
wouldn't hurt (unless you consider it another "point of failure" item
where the risk outweighs the benefit).
Anyway, thanks for pointing out the obvious about the diode, I'll have
to check mine (it's got an external diode wired across two contacts,
I'll have to check which ones)... I had assumed it would be wired
correctly across the coil not the switch...
-John R.
Subject: | Re: naughty LEDs |
Ooooh, you got me! I cringe every time I see the "loose/lose" thing, I
need to keep an eye on the "lie/lay" thing too!
-John
P.S.: The digiKey part number for the afore-mentioned panel-LED-mount is
MP52-ND.
> never use "
> John:
> Good idea!
> Ferg
>> contactors?
>location.
>required.
Not a problem. You obviously UNDERSTAND what
the recommendations are and why. You're making
a considered deviation from the recommendations
based on risk assessment for which you are
willing to accept responsibility.
The only time I have a problem is when someone
is being driven by hangar tales and advice
from people who embrace tradition and myth
more closely than physics and understanding.
Drive on sir . . . your prospects for a long
and enjoyable relationship with your project
are bright.
(o o)
terminals in order to supply power to the coil and run the other to a switch
between in and GROUND?
Nick Knobil
RV-8 N80549
Bowdoinham, Maine
Original Message:
shack) as shown on
the
A capacitor across the coil behaves like the capacitor across
the points in the tried and well worn Kettering ignition system
we drove for about 70 years. Here the task was to mitigate arcing
at the points WITHOUT restraining the magnitude of the voltage
swing. All the capacitor does is give the voltage rise a shallower
slope so that the points (slow, cam operated) have a chance to
open and break the arc . . . from that point on, the field
continues to collapse in the coil and you get the full effect
of that collapse at the coil's secondary winding when the spark
lights the fire in a cylinder.
A capacitor COULD have a similar beneficial effect for switch
contacts. In fact, if you use a capacitor and resistor in
series (so that the capacitor doesn't dump high inrush to the
switch contacts as they close) you could very readily protect
the contacts on switch that controls a battery or starter
contactor. This is discussed in detail in chapter 6 of the
AeroElectric Connection.
Reverse or counter EMF is that voltage generated by the RISE of
magnetic field in the coil that causes coil current to ramp up in the
classic mirror image of an R*C curve except in this case it's
an L/R curve. The diode is not a participant in the routing
of current flow while the switch is closed/closing and the
current is rising. Counter EMF in magnetic circuits is always
less than applied voltage.
The diode only goes to work when the circuit is broken and
the collapsing magnetic field is trying to maintain current
the energized current flow. This isn't counter EMF but an
unrestrained forward EMF that works hard (300+ volts!).
Unless routed off to do harmless work by warming up
some diodes and wire, will start a fire across the switch
contacts and burn away some metal. The photos I published
show that this effect is achieved in grand style with
a diode across the contactor's coil.
Perhaps somebody in the FAA understands this but I've
never met them. Whoever did the AD on the ACS keyswitch
obviously didn't understand it either.
Don't need the cap if you have the diode. The cap and series
resistor are bigger and more expensive than a diode and
the diode is much easier to install and mechanically more robust.
Once the diode is in place, there's nothing for the capacitor
to do. Back before I fully understood these things, I thought
it would be cool to make the points in my '57 Chevy last forever
by putting a diode across the coil. Sure 'nuf . . . no arcing . .
but the engine didn't run either.
That's when I built my first transistorized Kettering system
with a rewound GM coil and a three 2N174 germanium power
transistors. Point current dropped to 1 amp purely resistive
and the capacitor went away. The problem then became one of
keeping the points working good. When the fire went away,
the natural ability to burn away oil film went away too.
A brand new set of points would get flaky and had to be
cleaned periodically because the o-ring in my distributor
shaft wasn't keeping the greasy stuff out of the points
compartment. Not all that glitters is gold . . .
You got it. . .
Subject: | Re: starter brushes |
Hmmm . . . how many total brushes are in your starter . . .
four perhaps? If it has four brushes, perhaps one brush
of a pair was not making good contact. This can make the
remaining set work much harder.
A happy commutator is a sort of light walnut brown in
color.
It's a little difficult to formulate a hypothesis wihtout
knowing more about the motor. Four brushes or two? Permanent
magnet field or wound with wire?
Do you have access to a starter current ammeter . . automotive
supply stores sell a device that reads the magnetic field around
the starter power cable without having to break into the cable.
(o o)
*** Not exactly. If I remember correctly, the capacitor and the ignition
coil form a resonant circuit, producing high-amplitude oscillations at the
primary of around 10 kHz during spark discharge. Take the capacitor out,
the engine will run very poorly - if at all. So it's not just there to
protect the points.
We learned the "minus-minus-minus" rule: if the MINUS point is MINUS
metal, then the condenser is MINUS capacity. And vice versa too. Too much
capacity would move metal in the other direction.
>protect the points.
sameo, sameo . . . with the capacitor out the coil collapse
rate was a function of it's self resonant frequency . . .
much higher than with a capacitor added. Voltage rate of
rise would be so fast that a fire would form between the
points that never went out until stored energy in the coil
was used up. . . . energy stored in the coil would be
expended burning points and none made it to the spark
plug. If you add too much capacity, rate of rise is
slowed too much (resonant frequency too low) and
spark performance suffered.
"Protecting the points" and maximizing the energy fed to
the spark plug were hand-in-hand benefits of choosing
the right size capacitor for the task.
(o o)
Just two brushes, each is about 10mm x 8mm. Permanent magnet. Its
essentially the kind of starter you'd find on a motorcycle or
snowmobile. No solenoid, just a remotely mounted relay which sends
the full load from the 12V12A 'gel' battery to the post connected to
the hot brush. The other brush goes to ground. The starter mounting
bolts go through rubber grommets, so it has a ground strap to the
engine, and the strap was installed and presumably well grounded to
both sided. That's about it...
I realize it'll be tough to post-mortem, just wondered what might
account for the significantly faster RPM and subsequent failure of
the brush lead, all else being equal...
I'm sure I could borrow one...
Thanks for your time.
Regards, J.
I thought Pauly Shore was the end of civilization - until I saw
Chris Farley, who made Pauly Shore look like Laurence Olivier.
-- Harlan Ellison
Subject: | Re: Electrical system question |
>Hello,
>I have an RV-4 that has a 35 amp alternator installed. The ammeter
>fluctuates all the time even with all electrical equipment turned off. I had
>the alternator tested and it works as advertised. I replaced the voltage
>regulator and still have the same problem.
What do you mean my "fluctuates" . . . does the ammeter
simply deflect toward discharge and sits motionless at some
reading or does it wiggle around? How large are the
excursions? Are we talking about a reading on the order
of 2-3 amps or is it larger?
I presume further that you're talking about a minus-0-plus
battery ammeter.
(o o)
From: | "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> |
Subject: | Heated Pitot Wireing |
List, Does it make a difference which wire I use for the ground on a
Gretz Heated Pitot?
Thanks, Tom in Ohio
Subject: | Re: Heated Pitot Wireing |
>Gretz Heated Pitot?
> Thanks, Tom in Ohio
No, the pitot heater is not polarity sensitive. Be advised
that this critter is rated for about 8A continuous draw but
will PEAK at over 15A for several seconds during initial
turn on. If you're using fuseblocks, I recommend a 20A fuse
and 14AWG wire. If your using circuit breakers, a 15A breaker
and 14AWG wire.
(o o)
Subject: | Electrical system comments |
The following link provides a description and diagram of my electrical
system as it now stands. Any comments, thoughts and criticisms gladly
accepted:
http://www.total.net/~grantc/pages/ArtTechnical/Electrical
Thanks!
Grant Corriveau
Montreal
C-GHTF
It might sound redundant, but it's not hard to damage the braid as it comes
out of the terminal. It could have been done installing the brush, since
there is usually not quite enough lead length to do it without straining the
lead. A few broken strands will concentrate the current in the remaining
strands and one thing "leads" to another. That doesn't explain the "higher
rpm" though, which I missed on your earlier post. That could be caused by
the magnets becoming demagnetized, possibly by impacts during assembly or
disassembly (never subject permanent magnets to impact loads, although I'm
not sure how susceptible ferrite magnets are to this trauma). finally, the
unit could have been put together with the brush holder rotated slightly out
of position, which could also cause the problem. Timing of the brushes is
very important. A final remote possibility is that while cleaning the
commutator you inadvertently pushed metal into the plastic insulator between
segments, causing a short between segments. In theory, only solvent should
be used to clean the gaps between commutator segments.
Gary Casey
not a EE, that's for sure
From: | "gretz aero" <warrengretz(at)gretzaero.com> |
Hello Tom and the List,
It does not make any difference at all as to which electrical pin of the
heated pitot tube is ground.
Warren Gretz
Gretz Aero
http://www.gretzaero.com
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: AeroElectric-List: Heated Pitot Wireing
> Gretz Heated Pitot?
> Thanks, Tom in Ohio
From: | "Jim Robinson" <jbr(at)hitechnetworks.net> |
Subject: | Re: aeroelectric web site |
Is your web site down? I need to order some wire.
Jim
Subject: | GPS antenna connector |
My GPS antenna has a screw on type female end. My coax cable has a BNC
female end. How do I connect the two? Is there some fancy male/male
TNC/BNC connector?
Ross Mickey
RV6A
From: | "James E. Clark" <jclark(at)conterra.com> |
Yes, there is such a "cable". One came with our antenna and is about 6-8"
long.
Seemed to have been a "stock" cable as opposed to one that was custome made.
James
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Ross
Subject: AeroElectric-List: GPS antenna connector
TNC/BNC connector?
Ross Mickey
RV6A
Is email taking over your day? Manage your time with eMailBoss.
Try it free! http://www.eMailBoss.com
Subject: | Re: GPS antenna connector |
What antenna do you have. Mine came with the GX-60 I bought.
Ross
Subject: RE: AeroElectric-List: GPS antenna connector
> long.
made.
> James
> To: aeroelectric-list(at)matronics.com
> TNC/BNC connector?
> Ross Mickey
> RV6A
Subject: | Re: Electrical system comments |
Hi Grant
Thanks for putting your electrical diagram online.
at
http://www.total.net/~grantc/Images/ElectSchem.gif
First a question...
What is the diode on the field exciter wire on the alternator do?
Now a comment.
Consider if something should happen to the keyswitch or its wireing
feed.
The motor would stop because of no fuel and spark. If you were
fast and could throw the emergency igniton switch before the
engine quit turning you would be ok. I say before the engine
quit turning because if the keyswitch was bad you could not
use it to crank the engine for a restart. So your dual ign and
fuel pumps with their dual power sources would not do you
any good if you can't use the starter for a restart.
Belt redrive engines stop pretty fast when they are shut down.
If you were at altitude you may airstart the engine (big maybe).
Our redrive auto engines are not good for airstarting and staying
within vne.
If you have a 9-1 compression ratio it handprops like 18-1
with the 2-1 redrive.
Possibly a cure would be to leave the emergency ignition
switch closed when flying. That way if there ever was a problem
in the key switch circuitry the engine would stay running and
you would not need to use the starter.
Just a thought. I could have missed something. I am just
learning all this wireing stuff.
Jim Pollard
ch601hds
ea-81
not wired yet
>accepted:
>Thanks!
>Grant Corriveau
>Montreal
>C-GHTF
From: | Jaye and Scott Jackson <jayeandscott(at)shaw.ca> |
Do you have the white and red, split master/alternator switch? If you do,
this is one case where you get what you pay for. Even a T-210 comes with
this garbage and the ammeter in the one we owned used to dance rythmically
accompanied by a simple tune in our headphones. It was just high-resistance
in the switch contacts. Changing it fixed it right up....
Scott In Vancouver
From: "Robert L. Nuckolls, III" <nuckolls(at)aeroelectric.com>
Subject: AeroElectric-List: Re: Electrical system question
> >Hello,
had
> battery ammeter.
> Bob . . .
> (o o)
Hi Grant,
I fly an "All Electric" Mazda Rotary in my RV-6A. There clearly a
number of ways to provide for "redundancy" to better ensure continued
operation.
Not knowing what your power load is its hard to tell, but I might suggest
raising the 20 amp fuse on battery 2 to 30 amps. My two fuel pumps (I have
both on during take off and landing) draws 5-7 amps each (and they are one
of the lower current ones I could find), but that adds up to 10-14 amps. My
boost pump on for take off and landing draws around 2 amps. Throwing in
the intermittent igntion and that is probably another 4 amps average, if you
have fuel injectors probably in the same range of 4 amps and you find your
self up to 20-24 amps fairly quickly not counting any other current drains.
Yes, I know the circuit breaker/fuse is there to protect the wire not the
components, but if the fuse won't stand the load then you could have bigger
problems than heated wiring.
My design approach was to have the minimum number of components between my
batteries (I have two, one functions as a back up) and my critical systems -
fuel and ignition. I have these critical components wired to a bus with
only a circuit breaker and switch between them. I have two fuel pumps and
two independent ignition systems (Mazda Wankel rotary comes that way stock)
each with their own circuit breaker. So only a DC rated high amperage, high
quality (expensive) toggle switch and the circuit breaker is between my
critical component and power.
Now to show you how annal retentive I can be, I worried about the high
quality switches failing or the circuit breakers failing - hopefully
unlikely as they are rated for 10s of thousands of cycles. But, still I
fretted. So I hooked up a wire straight from the battery bus to the critical
component by passing switches and existing circuit breakers. This wire has a
40 amp circuit breaker in it that is normally open. However, if I push it
in then power is routed around the switches and circuit breakers directly to
the critical componets. It works, push it in and you can shut off all the
switches and pull their indiviudal circuit breakers and the engine keeps
running. The battery bus is tied to each of my two batteries through its
own 40 amp circuit breaker. Each battery is connected to the charging
circuit through the normal relay. That way should a battery malfunction
(short), I can disconnect it from the battery bus by pulling the defective
battery's circuit breaker or opening the relay.
A battery management circuit enables me to bring the aux battery on-line
manually, automatically (sensing its charge voltage) or it can be isolated
from the rest of the circuit. The main battery can be isolated by shutting
off the master switch.
So far I have 125 hours flying this arrangement with no problem. Of course
every component you add is one that weighs more and one that can fail and
there is certainly more than one way of doing it.
FWIW
Ed Anderson
Rv-6A N494BW Rotary Powered
Subject: Re: AeroElectric-List: Electrical system comments
> Hi Grant
> at
> First a question...
> Now a comment.
> feed.
> within vne.
> Jim Pollard
> ch601hds
> ea-81
> not wired yet
> >accepted:
> >Thanks!
> >Grant Corriveau
> >Montreal
> >C-GHTF
Subject: | Re: AeroElectric-List Digest: 9 Msgs - 02/02/02 |
This prevents the alternator relay from becoming latched ON once the
alternator is functioning. The overvoltage protection setup requires that
this relay must switch OFF whenever the ov protection cb opens. But the
alternator 'backfeeds' once it starts working, so I added the diode to block
this.
> Now a comment.
> feed.
This is why I routinely put the 'emer ignition' switch ON for takeoff and
landing and low-level flight. But your concerns are valid. I'm just not sure
how to achieve the same level of self-sufficiency as a magneto system when
using electronic ignition. I wonder if I could introduce a self-latching
relay of sorts that would protect the ignition bus, but would stay unpowered
on the ground while parked...a kill switch?). My key switch does have an
'accessory' position to the left of 'OFF' that isn't being used. Maybe I
could arrange to make this a 'kill' setting that unpowers this 'emer
ignition relay'... I would also want something to warn me if my ignition
feed primary system has failed...
You've got me thinking (again!)... how to make it reliable and SIMPLE and
familiar! Thanks!? ;-)
> within vne.
I haven't tested this yet... but I find that it's not too hard to pull the
engine through a compression cycle on the ground. Thanks for the advice -
I'll keep you posted as I would like to see what happens in flight (at a
safe altitude - over an airfield! -- of course).
Grant Corriveau
Montreal
Zodiac 601hds/CAM100
C-GHTF
www.theWingStayedON.ca
Is there a place where I can find specifications for "MS" part numbers?
As an example, I have some MS25041 PRESS-TO-TEST INDICATORs and I would
like to see if there is an electrical socket that fits the three (3) pin
connection, rather than soldering wires to the pins.
Thanks in advance,
Tom Barnes -6 electrical
Don't exactly recall.
It came with the reconditioned KMD-150. It was manucatured for King by
Comant (**I think**).
My main point was that you should in fact be able to find the cable rather
easily.
James
Subject: Re: AeroElectric-List: GPS antenna connector
Ross
> long.
made.
> James
> TNC/BNC connector?
> Ross Mickey
> RV6A
Subject: | How to take a Magellan GPS 315A apart |
Anybody successfully taken a GPS 315 apart? If so, how?
Mine finally stopped working. Probably a bad connection between antenna and receiver,
as software works fine. I've already cleared memory and even uploaded latest firmware
and re-initialized, of course. In the past it would occasionally and intermittently
loose signal from all satellites. This happened more and more frequently over the
last
year to the point where it doesn't see any permanently.
I'm sure I'll get a bunch of responses along the lines of which GPS I should use,
how
to re-initialize it, etc., etc., but all I want to know is:
How does one open it up?
Finn
Sign Up for NetZero Platinum Today
Only $9.95 per month!
http://my.netzero.net/s/signup?r=platinum&refcd=PT97
Subject: | Re: AeroElectric-List Digest: 5 Msgs - 02/03/02 |
> operation.
> Ed Anderson
Hi Ed,
Thanks for that description. It sounds that in principle you've come to
similar conclusions as I have. I'll check that 20 amp breaker (I think that
the diagram might be outdated - I may have already upgraded that...).
One other possibility I've looked at in place of the breaker is a fuselink
ala Bob Nuckolls and GMC etc...as this is apparently even less trouble-prone
than a fuse.
I also found some CBs that fit into my automotive style fuse holders, that
automatically reset after a short circuit/overload condition once the
condition is removed. I thought this would be handy, but haven't implemented
them yet because Bob Nuckolls suggests that they aren't very good quality
breakers, and that this goes against the philosophy that we don't really
want to reset circuits in flight if they've shutdown for a reason...
So, I'm going to continue looking into some sort of transparent
'self-contained' backup system to that ignition bus...
Grant Corriveau
Montreal
C-GHTF
Subject: AeroElectric-List: Re: AeroElectric-List Digest: 5 Msgs - 02/03/02
> > operation.
> > Ed Anderson
> Hi Ed,
that
trouble-prone
> than a fuse.
implemented
> Grant Corriveau
> Montreal
> C-GHTF
Hi Grant,
Yes, I think Bob provides a great service with his
list/webpage/products/advice. The only thing I am not quite in syn with Bob
on, although I understand his argument, is the use of fuses. I flew too
many hours in military aircraft where you could get a temporary overload
which would pop a circuit breaker and you could push it back in and keep
operating (sometimes). I do agree with Bob that you pay a premium for a top
quality circuit breaker and anything less is questionable.
The only place is use fuses is in the power circuit for my engine
instruments. I've only had one fail and I might have shorted a terminal
with a screw driver and did not notice until later.
Looks like you have a sound electrical design - the main thing is making
certain that you take into consideration all? possible failure modes and
their effect on the rest of the electrical system.
By the way a fellow Canadian by name of Yvon Cournoyer is flying a rotary
powered Zenith CH-200, I think he is in your neck of the woods, but not
certain. Might be worthwhile comparing notes.
Yvon Cournoyer
E-mail Address(es):
geryvon(at)videotron.ca
By the way, great web page. Enjoyed your 1st flight videos
Ed
From: | "Leonard Garceau" <lhgcpg(at)westriv.com> |
Subject: | computer program |
I want to do a schematic drawing of my aircraft wiring. Does anyone know of
a computer program that is used for aircraft wiring or related wiring
harnesses that will work?
Have a good one,
Leonard
Subject: | Re: computer program |
In a message dated 2/4/02 8:54:28 PM Eastern Standard Time,
lhgcpg(at)westriv.com writes:
<< I want to do a schematic drawing of my aircraft wiring. Does anyone know
of
I did mine with Microsoft Publisher. It probably took more time then a
program specifically for that purpose but work for me. It has been easy to
change and update.
Dale Ensing
RV-6A
02/05/2002 08:30:00 AM
Walt,
I put the Bendix manual in the mail to you this morning. Sorry, the
drawings that show the internal fuel circuits are not very clear, but my
original is also a photocopy.
Take care,
Danny Kight
P.S. Here's a photo of my RV-6 just prior to the first flight on
Saturday!!!
(See attached file: Danny's RV-6.jpg)
From: | Charles Brame <charleyb(at)earthlink.net> |
Subject: | Taxi light question |
I plan to have a standard landing light set up in my RV-6A. The lights
will be mounted in the wing tips and I plan to have a wigwag system.
What I have not figured out is a taxi light.
Do I need a taxi light in addition to the two landing lights? If so, how
does one wire it up?
Can I use one of the landing lights as a taxi light? How will that
affect the wigwag system?
RV-6A N11CB (res)
San Antonio
From: | Mark Steitle <msteitle(at)mail.utexas.edu> |
>The Sept. '99 issue of Nuts-N-Volts had an article on using Powerpoint to
>create your own symbols for doing schematics. I think they still have
>back issues available at http://www.nutsvolts.com/toc_Pages/sep99toc.htm.
POWERPOINTING YOUR PROJECTS =97 PART 1 - Steve Daniels
Learn how to use Microsoft=92s PowerPoint for creating a personalized
=93palette=94 of schematic symbols and a =93toolkit=94 for creating PC board drawings.
If you don't want to order the back issue, it shouldn't be too hard to
figure out on your own.
Mark Steitle
Lancair ES
>of
http://www.matronics.com/browselist/aeroelectric-list
From: | "Clifford Begnaud" <shoeless(at)barefootpilot.com> |
You can download a demo version of Intellicad from this web site:
http://www.cadopia.com/
This cad program is compatible with autocad and is very powerful. You can
then get some predrawn schematics from Electric Bob at www.aeroelectric.com
he even has files with all the symbols needed to do your drawing.
Cliff
know
> of
> of
*** I use TurboCad V7 for schematics. Works great. If you check out
www.turbocad.com - somewhere deep in the site, there is a 2D cad program for
free. 2D is all you need for schematics....
From: | "Andrew Seefried" <seefried(at)telus.net> |
Leonard,
I use Microsoft Visio - is CAD compatible - demo version available for $10 -
amazing capability.
Andrew Seefried
Subject: | www.aeroelectric.com |
Looks like Bob's web site is down. Does anyone have another web site
that has a list of his schedule classes? I assume that Bob is still in
business.
There are several builders in the SoCAL area that are intereted and I
have recommend his class to them.
EAA Tech Counselor
Gary A. Sobek
1,002.9+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
http://greetings.yahoo.com
I also used Visio and it worked great for me. Used it for my panel too.
Gary K.
----- Original Message -----
Subject: AeroElectric-List: program
> Leonard,
$10 -
> amazing capability.
> Andrew Seefried
From: | "Nancy and Walter Shipley" <wshipley(at)esper.com> |
Subject: | Re: Bendix manual02/05/2002 08:30:00 AM |
Thanks a bunch, Danny. Maybe someday when my -8A is flying I can come down
and see you.
I'm fairly familiar with your part of SC. I visited Chandelle Estates
fly-in community about a year ago, and I seriously considered moving there,
but my wife wasn't happy with the idea of leaving TN. Since then we have
bought a lot in a fly-in community near Greenville, TN, which is about 75
miles E of Knoxville. Hope to move there in the near future.
Thanks again for the manual......I owe you one, man. If you're ever up this
way and need a place to stay, let me know.
Walt
> Subject: AeroElectric-List: Bendix manual02/05/2002 08:30:00 AM
> Date: Tuesday, February 05, 2002 8:29 AM
> Walt,
> Take care,
> Danny Kight
> Saturday!!!
Subject: | A challenge for Electric Bob.... ;-) |
on 2/5/02 02:51, AeroElectric-List Digest Server at
Many of us have learned a lot about 'electifying' our aircraft from Bob, his
book and his website. But I think there's something missing...the diagrams
assume that the engine will be a standard aircraft type with magnetos and a
mechanical fuel pump.
One of the reasons automotive engines are becoming more popular, is similar
to one of Bob's main complaints with 'certified' electrical systems (i.e.
locked into old technology). Perhaps he can be convinced to take on the
challenge and provide some circuit designs with auto conversions in mind...
1/ We're usually using an automotive alternator (hey - it came with the
engine!). He publishes an overvoltage protection circuit for this kind of
internally-regulated system. Are there any other particularities that need
to be addressed?
2/ With electric fuel pumps exclusively, we have the same need for
maintaining the fuel pressure.
3/ Without mags, we need an extremely reliable electrical supply for the
ignition system, preferably with redundancy equal to or better than mags.
4/ How can we wire up electronic ignition (especially dual systems), to have
simple, familiar operations with maximum safety in the event of electrical
problems?
Can Bob's philosophy which features the 'Essential' bus to make alternator
failures a 'non-event', be expanded to include these key items?. Can he
(will he) also come up with an overall design that meets the specific needs
of us auto-conversion engine operators??? ;-)
(Is he 'listening'.... ??)
Grant Corriveau
Montreal
C-GHTF
Subject: | circuit breakers |
I was wondering about using 7.5 amp circuit breakers (since I already
have them) in place of the 5 amp called for in the alternator field
circuit and the SD-8 relay circuit. Is this an acceptable change?
Dave Ford
RV6
From: | Livingston John W Civ ASC/ENFD <John.Livingston(at)wpafb.af.mil> |
Grant,
Bob's work doesn't assume standard aircraft engines with magnetos. Far from
it. He specifically addresses: electronic ignition, electric fuel pumps, etc.
Look a little closer.
Subject: AeroElectric-List: A challenge for Electric Bob.... ;-)
to be addressed?
problems?
Grant Corriveau
Montreal
C-GHTF
From: | "James Stone" <jandkstone(at)hotmail.com> |
I checked out the Visio website and the $10 version is only active on your
computer for 30 days, did you find that a reality? Do you then have to
shell out 500 bucks to buy the software?
Jim
>From: "Gary K" <flyink(at)efortress.com>
>Reply-To: aeroelectric-list(at)matronics.com
>To:
>Subject: Re: AeroElectric-List: program
>Date: Tue, 5 Feb 2002 18:36:53 -0500
>Gary K.
>From: Andrew Seefried <seefried(at)telus.net>
>To:
> > Leonard,
>$10 -
> > amazing capability.
> > Andrew Seefried
Hey all,
Try Eagle from www.cadsoft.de.
It's a program for schematic capture and circuit board layout, but you can
use just the schematic capture part. It's quite a nice package, and the
freeware version has surprisingly few limitations.
-Matt
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of James
> Stone
> Sent: Thursday, February 07, 2002 9:10 AM
> active on your
> Jim
> >To:
> >Gary K.
> >To:
> > > Leonard,
> >$10 -
> > > amazing capability.
> > > Andrew Seefried
*** Yes and no.
Check out the list of new features in the current software. Decide if
you need them. If not, go buy a downrev one on Ebay. Much cheaper!
Try www.turbocad.com they have a free 2 D package. I used Turbocad Version
6 to do all of my wiring, panel layouts (printed out the layouts to cut my
panel - worked wonderfully!)
Ronnie Brown
your
> *** Yes and no.
From: | "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> |
Subject: | Temporary e-mail address . . . |
I've moved my working e-mail address for the AeroElectric-List
so that I can get back into the conversations. No news on
the server yet . . .
Private e-mails to me should be sent to nuckolls(at)kscable.com
( "The whole of science is nothing more )
( than a refinement of everyday )
( thinking." Albert Einstein )
From: | "Piers Herbert" <piers.herbert(at)ntlworld.com> |
Subject: | Battery contactor |
Hi,
I have not posted to this list before. I am planning to start a RV8 soon.
I was wondering if anybody has used a batery contactor which might be better
or more reliable than the standard kind in the Vans / Aircraft spruce
catalogues.
A search of the internet came up with this one which claims a hold in
current of just 0.13 amps.
http://www.kilovac.com/ciitech/documents/doc_1280.html
I don't know if this would be suitable or worth the money. Price is quoted
at $69.
Piers
From: | "David Swartzendruber" <dswartzendruber(at)earthlink.net> |
This relay may end up in a design I'm doing right now. It's interesting
how the "economizer" makes the relay work on 12 or 24V systems and backs
off on the coil current after closing to allow their claim of .13amps.
If you energize the relay with a variable power supply, you can watch
the current from the power supply go down as you increase the voltage.
It will handle 500 amps for 100 seconds at 85C, 200 amps continuous at
85C, and 250 amps continuous at 50C, so starting your engine should be
no problem for it. If you don't need the relay right away, I may be
able to sell you one at a lower price because I'll be buying them in
larger quantities if I end up selecting this relay.
Wichita
> [mailto:owner-aeroelectric-list-server(at)matronics.com] On
> Behalf Of Piers Herbert
> Sent: Thursday, February 07, 2002 4:35 PM
> Subject: AeroElectric-List: Battery contactor
> Hi,
> a RV8 soon.
> might be better or more reliable than the standard kind in
> the Vans / Aircraft spruce catalogues.
> hold in current of just 0.13 amps.
> Price is quoted at $69.
> Piers
> Search Engine:
> http://www.matronics.com/search
> Jim
I already had Visio at work, didn't realize it was so expensive.
Gary K.
> > Jim
>Gary K.
Getting into the conversation late . . . what kind of
tasks are you considering for Visio?
> Bob . . .
Bob, here's the original email below-
Leonard,
$10 -
amazing capability.
Andrew Seefri
I cn't seem to get to the visio site at MSN's main site. Does anyone
have the site URL handy?
Wes K
> > Bob . . .
Download http://209.134.106.21/CAD/cad.pdf
and http://209.134.106.21/CAD/cad.exe
and http://209.134.106.21/CAD/cad.txt
This is an older version of IntelliCAD which used
to be available from their website at no cost by simply
registering. This program will open and edit the
drawing files which are also downloadable from my
website at:
http://209.134.106.21/articles/seminar.exe
and
http://209.134.106.21/articles/wirebook.exe
The drawings you'll find in these files will
probably represent 80-90% of the work necessary
to do your own page-per-system wirebook. You
can pick and chose from the various pages
to assemble a document that is easily modified
to match what you want do do.
want to do.
TEMPORARY WEBSITE ADDRESS:
>Leonard,
>$10 -
>amazing capability.
>Andrew Seefri
>Wes K
P.S. Visio as a CAD program sucks big time. I use it to import
images from other CAD programs into windows applications but
as a tool for crafting original documents, it's seriously
lacking . . .
> lacking . . .
> Bob . . .
Bob's right... but on the other hand, Visio was never intended to BE a CAD
program.
Folks, there are plenty of schematic drawing packages out there. Most of
'em have limited freeware versions. I use CADSoft Eagle, which has a steep
learning curve but is kinda nice once you get the swing of things. (You
have to control it both with mouse movements AND a command line, at the same
time, for instance.) Keep searching the net and you'll find some. Try
WinDraft by Ivex, or Eagle by CADSoft, or go to some Printed Circuit Board
manufaturer's sites for more links.
-Matt
Just wanted to let the list know that I have been using the freebie
TurboCAD with Bob's drawings and it works just fine. They give you the 2D
version so that you'll like it and upgrade to the 3D version, but the 2D
version is complete and works fine. The program is compatible with AutoCAD
and several other formats.
They are at http://www.turbocad.com
Also, I made up a bunch of full size instrument panel templates that may
be printed and cut out and laid on the actual panel for a feel for how
they all fit together, if anyone wants them, send me an email.
> website at:
> and
> want to do.
> Bob . . .
I'm working on a Mac and cannot utilize an "EXE" file. Could you
provide a link to a "ZIP" file as well? I already have a CAD program
- just need the seminar & wirebook files.
Jim Burley
> and
> want to do.
> Bob . . .
Try CircuitMaker Student version. It's free and it works for what you want
to do.
http://www.microcode.com/downloads/student.htm
R
Yeah, but it limits you to 50 "devices" in the student version. It's not
really supposed to be used as a CAD program, but as a way of analyzing
circuits.
> rswan19(at)comcast.net
> Sent: February 8, 2002 2:26 PM
> Subject: Re: AeroElectric-List: Re: program
> what you want
> to do.
> R
What are you building a Space Shuttle? I don't think you would need more
than 50 devices in a homebuilt.
R
>circuits.
I think circuitmaker is a program designed to assist
in the design of etched circuit boards. You draw the
schematic in a specialized drawing application that
ports directly to an etched circuit board layout
program.
For airplane wiring diagrams you need a real CAD program
like ProCAD, IntelliCAD, AutoCAD, etc.
Here, the "devices" being referred to are things like integrated
circuits, resistors, sockets, etc. The try-it-to-see-if-you-like-
it programs are generally crippled in some way . . . like limited
number of devices . . . or you're prevented from outputing data
to any kind of file or printer to transport fabrication data, etc.
Interestingly enough, the last time I did a full up wirebook on a
relatively simple, single engine airplane, the reference designator
list ended up with over 100 "devices" . . .
>Bob,
Okay, try http://209.134.106.21/articles/Cad_Dwgs.zip
Check this out:
http://www.advancedmsinc.com/creator/index.htm
You can download a free demo, but the schematic package is only $99, so
it's not too expensive to get the real deal. (I forget what part is
crippled, I think it's limited to 255 devices or you can't print or
something like that). It really does work well, I bought the full-on
$1000 professional electronic
schematic-capture/pcboard-layout/auto-router package that is now only
about $500, and I don't mind the extra $$$, it costs so much less and
does everything the $10,000 Futurenet/Redicad Tango etc packages do.
-John R.
> Bob . . .
I just opened the CAD files with TURBOCAD LT which is a free program.
Jerry Latimer
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com>
Subject: AeroElectric-List: Re: program
> > > Bob . . .
of
> website at:
> and
> want to do.
> Bob . . .
I'm working on connecting up my EFIS/One from Blue Mountain Avionics
into my existing airplane. I'm looking for a special switch (or
suggestions), connecting my EGT/CHT sensors to the system. The EFIS has
6 inputs for thermocouples, and I have a 6 cylinder Lyc. So I was gonna
put my 3 hottest cylinders, both EGT & CHT (for a total of 6 inputs),
and then use a (and this is where I need the help), a 6 way (6PDT on-on
switch - if there is such a thing). Then I would switch from my 3
hottest cylinders, which I want to monitor most of the time, and to
check the others as needed.
If anyone has a better suggestion, let me know. By the way, I've seen
Bob's thermocouple information in Chap 14 of the current Aeroelectric
Connection.
Thanks.
Craig
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Subject: | Re: CHT EGT Switch |
Call Ron at Rocky Mountain Insturment. He has a 6 way switch that allows
you to have one input into your your unit, but switch between all cylinders
both CHT and EGT. You could connect as many as you like to the switch.
Paul Besing
RV-6A N197AB Arizona
First Flight 22 July 01
Kitlog Pro Builder's Log Software
http://www.kitlog.com
> Connection.
> Thanks.
> Craig
The 6 way switch is a Westach unit. So check on prices
as they vary from retailers.
Dave Mullins
Nashua, New Hampshire
http://n323xl.iwarp.com
> Paul Besing
> From: "Craig Snively" <craigsn(at)hotmail.com>
> To:
> > Connection.
> > Thanks.
> > Craig
Subject: | CADD for schematics |
Visual CADD, the successor to Generic CADD, is pretty good for
schematics, as far as CADD programs go. [Some of you may remember, Generic
CADD sold for 99 bucks and it was so good, AutoCAD bought the company and
then shut it down. Too much competition.]
For serious schematic work, however, dedicated schematic programs are
far better. I'm still using an ancient DOS version of Tango (from Excel),
but the integrated schematic plus printed circuit board and autorouting
program cost me $2600 quite a few years ago. Prices now are much higher.
Jim Cameron
Lancair ES N143ES
Subject: | Toggle Switch Hole Drilling |
For what it's worth.
One of Lectric Bob's Shop Notes addresses Toggle Switch Installation.
His suggestion for cutting a hole for the body is to use a 15/32"
spotfacer fitted with a 1/8" pilot drill. I am sure that this tool
works well.
However, in calling one major tool company I found that technical person
was not familiar with spotfacers. A call to a local tool supplier
located a source of 15/32" spotfacers for about $30. The same supplier
had a Black & Decker 15/32" "Bullet Drill" for $8.95 (marked down from
$12). The bullet drill has a 15/32" body with a cutting end that looks
very much like the spotfacer's in Bob's photo. It has an integral pilot
about 5/32". I tried it on the .060 aluminum of the instrument panel at
about 600 rpm in my drill press. It cuts like a gem making a very clean
hole an creating a minimal burr.
Richard Dudley
-6A (N331RD reserved)
finish kit
Subject: | Mechanics of panel design |
I'm building a Jabiru J400, 4 seat high wing plane. The manual section
for the instrument panel is not yet ready, but I may wish to modify what
they have to make a panel that is easy to work on. For example, it
could be made in 3 removable sections. I don't know details of panel
construction, such as the creation of a subpanel layer to allow mounting
cable tiedowns without putting holes in the visible panel. Or, how to
mount things: slide out box, vs removable whole panel, etc. Anyone have
a source of design information here? I don't want to reinvent the
wheel, and want to borrow some ideas fom other panel designs. I would
appreciate reference to books or magazine articles or web sites.
Jim Foerster
Subject: | Re: Toggle Switch Hole Drilling |
Black & Decker Bullet drill bits are available from Avery Tools. Shown on
page 29 of their catalog. Website www.avaerytools.com
Harley Beard RV-6A
Harley,
Thanks for your comments.
The drills on page 29 of Avery catalog (as shown in the drawings at the
top of the page) are the common type of drills with the tapered tip. The
drill that I described has a smaller diameter pilot and the cutting
surface of the body is concave so that its outer edges cut before the
inner part. The result is that when the outer edges of the drill break
through, it leaves a "washer" of the cut metal.
Richard Dudley
> Harley Beard RV-6A
I just thought I'd add my 2 cents worth. The easiest way I've found for
drilling the multitdue of toggle switch, circuit breaker, intercom knobs,
dimmer pot, etc.. holes is to use a plain ole' UINIBIT. Its so much quicker
that chucking up a new bit for every size, and does equally good of job on
the holes.
Just my opinion. The unibit is the single most usefull bit for building a
metal plane.
Stein Bruch
RV6, Minneapolis,
Almost ready for hgr.
Richard Dudley
Subject: AeroElectric-List: Toggle Switch Hole Drilling
works well.
Richard Dudley
finish kit
It's available at Sears too. They may not have the 15/32 size, but most
Ace Hardware stores do. Probably True-Value too.
-John R.
James Stone wrote:
> Thanks for the info Richard,
> I've never seen what you describe at the local hardware store and assumed
> you had not either and that was why you were sharing your discovery with us.
> Thanks again, I'm heading for the web site now.
> Jim
In a message dated 2/10/2002 4:28:20 PM Pacific Standard Time,
rhdudley(at)att.net writes:
<< I agree about the usefulness of the Unibit in cutting holes in aluminum
sheet. However, I have not seen one that is sized to 15/32". If the hole
size can be cut with the Uinbit, I'd use it.
RHDudley
I have a Unibit with a max. diameter of 1/2" that has steps every 1/32". The
larger size Unibits are stepped every 1/16".
Cliff
>Can anyone tell me where the dimmer leads on my avionics go? Is it to
>power via a dimmer bus or to ground via a dimmer? Or somewhere else?
>Richard Dudley
>-6A finish
Dimmer leads are power inputs from an adjustable voltage source
such as a rheostat or more modern, solid state dimmers like those
on our website.
Bob:
What is going on with your website. I am trying to order parts .... been
unable to get the site to come up for days??????
Len Leggette, RV-8A
Greensboro, N.C. N910LL (res)
Hooking up systems
From: | "Schemmel, Grant" <Grant.Schemmel(at)utmc.aeroflex.com> |
Subject: | Used equipment question |
I have a question for the list, that I hope someone out there can answer: Does
anybody have experience with how you go about judging the appraised value of
a wrecked aircraft?
I am looking towards my next project, and was thinking that the best way to get
most of the expensive pieces in one swoop would be to bid on something that's
up for salvage. Don't have a clue though (since I've not done this before) as
to how you go about putting a value on one. There was a good article in the
Feb Sport Aviation about it, but the author didn't say how to do the valuation.
Appreciate any tips,
Thanks!
Grant Schemmel
ch601hds w/ o-200
>Bob:
>Len Leggette, RV-8A
>Hooking up systems
The main site is down. Click on the temporary
cite address below and you can get access to the
files. You won't be able to automatically mail an
order . . . fill out the form, and print it. Then
fax to B&C at 316.283.7400 or you can call in an
order to 316.283.8000 (ask for Todd).
From: | Glenn Rainey <nimbusaviation(at)yahoo.com> |
Subject: | Battery contactors |
Triggered by a recent posting with quite a nifty
high-spec contactor - I am left wondering if there are
any really LIGHTWEIGHT devices out there - this one
was almost a pound weight ...
any pointers chaps?
Cheers
Glenn
LEZ (Scotland)
Get a No. 1 Unibit, it one goes up to 1/2 in. by 1/32 increments, including
15/32.
Harry Crosby
Pleasanton, California
RV-6, finish kit stuff
Richard Dudley wrote:
> Jim,
> Here is some more information that may be of help.
> Another builder once showed me some drills which he called "pilot
> drills). I thought they might be the same as my bullet drill. I just
> talked with him. His description, that the cutting face is concave is
> the same as my 15/32 drill. He checked the package. His are Black &
> Decker. They use both the Bullet Drill and Pilot Drill names. It looks
> as thought the generic name is Pilot Drill. He said that he has seen
> them at both Home Depot and Loew's and that he would expect to find them
> also at woodworking stores.
*** I just saw them at the Harbor Freight retail store in Newark, CA.
Subject: | Re: CADD for schematics |
Since no one is mantioning anything open source, I will.
Xfig is a wonderful simple drawing program. Comes with
components for drawing schematics (physical and symbol).
Outputs in most of the common formats (CGM imports into
word, embedded postscript, bitmap graphics formats). It
comes with most Linux distributions.
Best of all it is free (as in beer and speach).
http://www.xfig.org
> Jim Cameron
> Lancair ES N143ES
Subject: | Re: Battery contactors |
>any pointers chaps?
The only lighter alternative might be a manually
operated switch. I have had a number of builders
adapt race-car and/or marine battery switches to
their airplanes. One can fabricate a mechanical
push-pull rod or perhaps a Bowden control on a
bellcrank to make the switch easily accessable
from the pilot's seat.
< Our main website is down. Click on >
< http://209.134.106.21 for access >
< to the files. You won't be able >
< to automatically mail an order . . >
< Fill out the form, and print it. >\
< Fax to B&C at 316.283.7400 or you >
< can call in an order to >
< 316.283.8000 and ask for Todd >
Thanks, Bob.
RHDudley
> >Richard Dudley
> >-6A finish
> on our website.
> Bob . . .
Subject: | Aeroelectric article Detailing How to build a jack |
for a handheld
A few months ago there was an excellent article at the Aeroelectric
connection showing how to build a jack for a handheld to use the
aircraft com antennae. I was wanting to build this tomorrow but cannot
find the article on the temp web site. Does anyone know how I can find
the article?
I wanted to go to Radio Shack and buy the jack. Does anyone know what
jack was used? I think it was the type that has a switch that is
normally closed that opens when the jack inserts. What is this type of
jack called?
Thank you,
ned
connection showing how to build a jack for a handheld to use the aircraft
com antennae. I was wanting to build this tomorrow but cannot find the
article on the temp web site. Does anyone know how I can find the article?
I wanted to go to Radio Shack and buy the jack. Does anyone know what jack
was used? I think it was the type that has a switch that is normally closed
that opens when the jack inserts. What is this type of jack called?
Thank you,
ned
for a handheld
Thank you,
ned
Subject: | Re: Aeroelectric article Detailing How to build a jack |
for a handheld
Suggest you read Jim Weirs' article "Build a $2 cockpit antenna diplexer for
your handheld" page 53, March 2002 Kitplanes Magazine. He uses a Radio
Shack plug 274-288 and a jack 274-248.
Lonnie Benson
Building a Murphy Rebel
Subject: AeroElectric-List: Aeroelectric article Detailing How to build a
jack for a handheld
Subject: | panel accessory power jack |
(coming thick and fast these questions) - looking for
a consensus on the *best* [safe,secure,etc etc] panel
socket for power to run a handheld device like GPS or
whatever off ships power. What do the pundits
recommend ? (not that nasty automotive socket). And
yes, I hate to have trailing power cables in the
cockpit, but just occasionally...... :>
cheers
Glenn Rainey
LEZ, Scotland UK
Subject: | Re: panel accessory power jack |
In a message dated 2/12/2002 6:08:37 AM Pacific Standard Time,
nimbusaviation(at)yahoo.com writes:
<< (coming thick and fast these questions) - looking for
whatever off ships power. >>
I'm interested in the same thing.
Cliff
Subject: | Re: Handheld Antenna Jack |
>Thank you,
>ned
The piece was uploaded to both servers but I neglected
to get it listed in the index of articles. Goto
http://209.134.106.21/articles.html and find the first
item in the How To list . . .
Thanks for the heads-up . . .
for a
handheld
>Lonnie Benson
In the interest of concise speech, there ARE devices called
duplexers, diplexers, circulators and couplers that allow
multiple devices to share an antenna. The panel mounted
jack is not such a device. It's simply a receptacle that
connects your hand held to the antenna when the plug is
inserted. It also features a switch contact that automatically
disconnects the panel mounted radio from the antenna when
the plug is inserted. This is the same kind of functionality
that disconnects the hand-held's speaker when you plug in
headphones, etc.
The parts in Jim's article are the same as those suggested
in http://209.134.106.21/articles.html
Is anyone familiar with the connector that airlines are using to provide
12V power at the passenger seats? Cessna is using this same connector
to provide a 12V power jack in the new singles. Radio Shack used to
make an adapter that converted it to a standard cigarette lighter type
plug.
Wichita
> cheers
> Glenn Rainey
> LEZ, Scotland UK
Subject: | Re: Aeroelectric article Detailing How to build |
Thanks Bob! I'm out to Radio Shack to buy the parts.
ned
Subject: AeroElectric-List: Re: Aeroelectric article Detailing How to build
for
> >Lonnie Benson
> headphones, etc.
> Bob . . .
I hesitate to call out any specific pair of connectors
as they would be but one of hundreds of possibilities
suited to this task but here are some options to consider:
Radio Shack 274-346 panel mounted RCA Phono jack
to connect to power source and a RS 42-2370 (3'
wire with plug already on one end and bare wires
to accept a connector that fits your radio).
Radio Shack 274-002/274-001 mated pair
Radio Shack 274-1576/274-1573 mated pair.
A panel mounted BNC female connector (our
S605BF) could provide a place to plug a
BNC male (Our S605CM). I've installed these
connectors on shielded wire (Our S906-1-22).
The wire is smaller than coax so you need to fill
the open voids with 5-minute epoxy on the cable
male. You can solder a single strand to the center
conductor on the panel mounted female, seat the pin
and fill the back side with epoxy. The connector then
finds "ground" through its mounting.
There are LOTS of ways to do this. Go to your
local parts supply store and let your imagination
work on what ever you find hanging on the racks.
How about a small power supply connecter such as is used to charge your
handheld radio.
A common size might be a 2.5mm. Switchcraft makes a whole line including
plugs and panel jacks. The 712 line of plugs and 760 series of jacks would
work. Try p/n SC1051-ND & SC1052-ND in Digikey. (p.151 , catalog T011)
P/ N SC1148-ND even has a locking ring. This is just like the connection
that Headsets Inc. uses on the batterypower supply for their ANL headset
battery supplies.
The disadvantage to any of these is that specific power cables would need to
be made for your GPS, handheld etc. but thay are small and lightweight.
Stan Blanton
RV-6
From: | William Mills <courierboy(at)earthlink.net> |
Subject: | Re: Aeroelectric article Detailing How to |
And we saw it HERE first! . . . hmmm
> Bob . . .
Subject: | Internally regulated alternator |
First of all, thanks for sending the aeroelectric connection.
I am planning to install a Wilksch engine which uses a Denso alternator (I
think the number is JA188IR) with an internal regulator.
The scheme for adding OV protection to an internally regulated alternator
(Z-24) shows an alternator OV disconnect contactor.
Is the contactor nescessary when adding OV protection to this alternator,
and if so could you explain why it is not sufficient for the crowbar module
just to short the field circuit to gound?
Piers Herbert
Was just looking at stuff like this over the last few days.
And yes, 2.5mm [ID] is a common size. Another one of the "common" sizes
(available at more than one store ;-) ) was the 5.5mm/2.1mm [OD/ID]
combination. {Note that you want to be careful and get the OD/ID pairing
right on this.}
Was able to locate both the plug and the jack as well as a plug with 6ft of
wire and bare ends to connect to whatever you wanted on the other end.
As Bob mentioned, the combinations are endless, so make sure you pick a pair
that is "easy to find".
There are three of us here that are going to use the 5.5mm/2.1. Might just
as well have used the 5.5/2.5 but one of my buddies had alredy gone with
"2.1" **AND** I was able to find the stuff mentioned above.
Hope this rambling helps in some way.
James
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Stan
Blanton
Subject: Re: AeroElectric-List: panel accessory power jack
handheld radio.
battery supplies.
Stan Blanton
RV-6
Subject: | Handheld COM Antenna jack |
Where can we find the 0.010" brass material specified
in Bob's article to make the housing for the jack?
Michel Therrien CH601-HD
http://pages.infinit.net/mthobby
http://mthobby.pcperfect.com/ch601
Subject: | Re: Handheld COM Antenna jack |
Hobby stores that carry R/C planes usually have some small sheet brass
pieces available. You could try there.
Gary Liming
Ace Hardware (and probably many other hardware stores) have a little
hobbyist section with sheet, rod and tube stock of stainless, brass and
aluminum... good for all kinds of little jobs!
-John
Subject: | Re: Internally regulated alternator |
>Bob,
One COULD build a crowbar module that was hefty enough
to open the alternator b-lead fuse . . . but it's a lot
bigger device than the little critter we sell. Further,
if your system suffers from any nuisance trips, you don't
want to be replacing that fuse very often . . . of course
you could put a breaker there . . . but that forces the
electronics in the crowbar module to get bigger yet.
What you suggest is technically possible but fraught
with practical hazards.
I hate the automotive style "cigarette lighter" plug as well, however many
items that you will want to plug in use less than 12 volts. Most new devices
locate the power transformer inside the plug, so if you clip this off and
put on your new plug you will have the incorrect voltage to your expensive
device.
I'd really like to improve on this antiquated power receptacle for my
plane, but I really don't have the time or inclination to rewire every
adapter cord for every accessory.
Maybe Bob could design a variable voltage power supply plug with all the
built in safeguards to prevent frying our "gizmos". How 'bout it Bob? heh,
heh...... pleeeaasee
S. Todd Bartrim
13B rotary powered
RV-9 (finish kit)
C-FSTB (reserved)
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert
> L. Nuckolls, III
> Sent: February 12, 2002 7:25 AM
> III"
> Bob . . .
From: | "Robert E. Falstad" <RandBFalstad(at)compuserve.com> |
for a
handheld
Message text written by INTERNET:aeroelectric-list(at)matronics.com
>: AeroElectric-List: Aeroelectric article Detailing How to build a jack
for a handheld<
Ned,
The March '02 issue of Kitplanes has an article on this exact topic by Jim
Weir, Bob's colleague? competitor? (friendly, I hope!).
Jim calls out Radio Shack P/N 274-288 (plug) and P/N 274-248 (jack).
> however many
>device.
> all the
>S. Todd Bartrim
>13B rotary powered
>RV-9 (finish kit)
>C-FSTB (reserved)
funny you should mention that. I JUST e-mailed off the artwork on
a prototype order for new dimmer boards. These boards have pads
on the layout to accept surface mounted potentiometers. When the
'bugs' are worked out, the dimmer line will be expanded to include
two-voltage fixed regulators useful for things like two-speed trim
controllers. Of course, one could use a single channel of the same
device to provide a regulated, filtered source of voltage lower than
the 14V bus to power any accessories that need the lower voltage.
These critters will be offered by B&C in the same range of sizes
as the current dimmers and will physically LOOK the same. Only
the parts on the boards and the wiring will be different.
Should have boards back next Monday and we'll stuff a few up
for bench testing.
Subject: | Re: Your Phone Call |
>Bob, I have been unable to get your website and didn't know which of us
>had the
>problem. By the above note, you do. I would assume that in a week or less
>you'll be back in business. If longer, please let me know.
>One specific question. I took your seminar at Manassas several years ago.
>I'm only know getting into the details of wiring. In reviewing your book I
>find that all the sample diagrams include words to the effect that the
>battery master and the alternator field should come on together. I can't
>find in the book nor do I remember you discussing this. Why should they
>come on together when the engine isn't even running?
Back in the days of generators, you could have either generator,
battery or both switches ON or OFF in any combination. When alternators
came along, we discovered that you should not allow most alternators to
try to run without a battery on line. Here was where the split
rocker was born . . . battery ON/alternator OFF - OK. Battery ON/
Alternator ON - OK. Battery OFF/Alternator is forced OFF too.
Before I had a source of inexpensive toggles with progressive
transfer contacts, I reasoned that there was no particular advantage
in trying to avoid turning the alternator on before starting the
engine. Modern RG batteries didn't care and neither did the alternator.
Hence, all the early power distribution diagrams show two pole,
single throw switch to control both alternator and battery together.
In years since, we've located and now stock the S700-2-10 switch that
will let you mimic the functionality of the split rocker but in a
switch that looks like it belongs on the panel with the rest of
the switches.
If you have an revision 8 or later book, check out free upgrades
that you may download at
You will note that all of the later power distribution diagrams
suggest the use of the S700-2-10 switch which you can acquire
at:
http://209.134.106.21/Catalog/BCcatalog.html
>Another question comes to mind. I believe that you and B&C sell only female
>PDIG fastons. I would like to find some male ones but have not. Can you
>tell me a source? I want to use them as disconnects at the wing root for
>wires in the wing. Is that considered satisfactory or bad?
I have male PIDG style connectors I ordered in to look at. They DO
have metallic insulation support. They're a Waldom-Molex part. I'm writing
up a short article about them that will be published on the website.
I don't recommend them. The knife splices are far superior for this
task. In the mean time take a peek at:
http://209.134.106.21/articles/KnifeSplice/KnifeSplice1.jpg
http://209.134.106.21/articles/KnifeSplice/KnifeSplice2.jpg
http://209.134.106.21/articles/KnifeSplice/FastOnMale.jpg
If you really want the male fast-ons, I'm going to sell the ones
that I have for what I've got in them. A bag of 20 pieces
is $10 each postage paid. I have red and blue sizes.
Subject: | Re: How to build a jack for a handheld |
>Ned,
Sure . . . I've known Jim for at least 15 years and we've traded
ideas on a number of projects and topics. In fact, I've quoted
a piece of his at:
http://209.134.106.21/Catalog/avionics/weir_760.html
Bob or anyone: Can someone explain or refer me to any source of information
that would explain ANLs and how they work. Thanks.
Harry Crosby
Subject: | Re: ANL Question |
>Harry Crosby
Sure. Take a peek at the new articles listed in the
What's New box at the top of this page:
From: | Frank and Dorothy <frankv(at)infogen.net.nz> |
Subject: | Power bus in wing? |
Hi all,
I'd appreciate any comments anyone has on this idea...
I'm going to have a wig-wag landing light flasher in my RV6. To do that,
I'm going to need to use a couple of high-current transistors to actually
turn the light on/off. I figured that these might as well go out at the tip
near the lights themselves and save some heavy-current wiring. And then I
thought that the same technique could be used for turning on/off nav lights
and strobes. In the tip, would be a little power-distribution board and the
strobe power supply. The power distribution board would be supplied by a
single heavy-duty (I guess about 10 amps if all the lights are on) 14.4V
power cable, and have several low-current inputs to turn on/off
high-current transistors. Maybe relays might be OK for the nav lights and
strobes, since these don't need to be turned on/off very often.
Question: Is this a reasonable scheme?
I can see a couple of negatives:
* Single point of failure. But all I'd be losing would be the lights on
one
side. In the end, none of them is essential.
* More complexity. More things to go wrong. But electronics is pretty
reliable nowadays, especially solid-state stuff.
* More expensive. Or would it be? Less wire needed.
* The main bus wire would be sized and fused to carry a lot of current.
If
that shorted, it could be very bad. Especially if there was a bit of fuel
around.
* Probably need fuses in the wingtip to protect the wiring between the
power distribution board and the lights. If one of these blew, it would be
a pain to replace.
Some positives:
* Lighter. But maybe only by a few ounces.
* Easy to add other devices in the wingtip. But what else would you want
out there?
* More efficient power distribution. But power losses through distribution
are pretty minimal anyway.
* An interesting project. This alone might outweigh a few of the negatives
Another interesting possibility would be to distribute the power using AC.
I know of a research project where power is distributed round a boat at
100V, 10KHz AC. Each device has a small rectifier to convert back to 12V. I
was told that, there being no common 'Ground', there can't be short circuits.
Frank.
From: | "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> |
Subject: | Re: Power bus in wing? |
From: "Frank and Dorothy" <frankv(at)infogen.net.nz>
Subject: AeroElectric-List: Power bus in wing?
Why not just use Bob Haan's wig-wag system?
Gordon Comfort
N363GC
>Hi all,
Why not have each circuit get its own power feed. The solid state
relay is fine but this doesn't necessarily mean that you need to
generate any single point failures.
>lights on one
Wire is still cheaper than electro-goodies. Remote switching
may be particularly attractive if, for example, you would like
to use miniature switches to do the input work and keep strong
magnetic fields off the panel.
>current. If
>around.
Yes . . . this wire WOULD be an extension of ship's power distribution
bus . . . methinks it better to keep this compact (i.e. fuse blocks).
>a pain to replace.
Not if you let each system enjoy separately protected circuits at the
bus.
>Some positives:
Or heavier by a few ounces . . . depends on how you mount your electronics.
In any case, it's a wash for weight.
>want
>out there?
Can't think of a thing.
>distribution
Debatable . . .
>negatives :-)
Hmmmmm . . . I'd really like to see the architecture on this one.
I cannot visualize the advantage.
Subject: | Main server back up |
Our main server is back up, sorta. You can access the pages
like always but there are still details to work out for the
scripts that handle order forms. Will let you all know when it's
fully functional again.
Sorry, I was not thinking of a crowbar in the B lead. I was just trying to
understand why the internally regulated alternator (Z-24) needs a contactor
whereas the externally regulated one (Z-23) does not. If the crowbar trips
the field breaker would this not stop the alternator output (Denso
alternator)?
Piers
>To:
What I'm talking about is essentially Bob's system, reconfigured a little,
and with a couple of extras.
Incidentally, Bob's system works out quite expensive for me here in NZ. For
about a third of Bob's price, I bought a light flasher kit from Dick Smith
(about the equivalent of your radio Shack, I think). It flashes two 50W
lights alternately, with an adjustable flash rate.
Frank.
Just wondered what your thoughts are on substituting 7.5 amp breakers
for the 5 amp field breakers for the main and SD8 alternators since I
already have a couple of 7.5 breakers on hand.
Dave Ford
>alternator)?
>Regards,
>Piers
January 19, 2002 - February 14, 2002
AeroElectric-Archive.digest.vol-ao
