AeroElectric-Archive.digest.vol-aq
February 27, 2002 - March 13, 2002
>BTW, yesterday I had a long talk with my local FSDO
>airworthiness inspector about a simple and safe
>modification I want to make to a customer's Mooney...
>sigh. As they say, "Arguing with an inspector is like
>wrestling with a pig in the mud; after awhile you
>realize they both enjoy it."
>My next airplane will be a homebuilt.
My opening comments at weekend seminars
include the statement that the amateur built
aircraft industry is putting out the finest
airplanes to have ever flown. Of course,
I have to follow up with the reasoning that
when we find that something needs to be changed
either to fix it or to make it perform better,
it can happen today without waiting on the
blessings of anybody . . .
If you want to hose something up, get government
to regulate/manage it.
From: | William Mills <courierboy(at)earthlink.net> |
Subject: | Re: Microair radio & xpdr amp requirements |
> I'll be
> offering a kit of transponder, prewired harness and
> ACK encoder for a package price.
> Bob . . .
Yes, please do!
Bill Mills
From: | "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> |
Subject: | Re: Wig-Wag - FOLLOW-UP |
>Follow-up, follow-up
>Bob,
>In going through all the switch combinations, I discovered one anomaly
>that I'd rather avoid. It is an unlikely combination but still possible.
>Here is the logic table:
>Switches Lights
>Taxi Landing Taxi Landing
>Down Down Off Off
>Down Mid Wig Wag
>Down UP Off On
>Mid Down Off Off
>Mid Mid Wig Wag
>Mid Up Off On
>Up Down On Off
>Up Mid On off - relay rapid chatter
>Up Up On On
>It is the rapid chatter (much faster than wig-wag rate) of relay that
>concerns me. The switch positions are not normal but are possible.
>Knowing the circuitry of the controller, is there some alternative
>wiring I might try?
Try moving the brown and yellow wires over to join
the red . . . i.e. all three wires on one connection.
Earlier, I removed the yellow-brown combination from the switch and it
had no effect.
I joined the yellow-brow combination with the red wire and the logic
table remains the same.
RHD
> >Bob,
> >Switches Lights
> >Down Down Off Off
> >Down Mid Wig Wag
> >Down UP Off On
> >Mid Down Off Off
> >Mid Mid Wig Wag
> >Mid Up Off On
> >Up Down On Off
> >Up Up On On
> >wiring I might try?
> Bob . . .
Subject: | ElectrONic AH and DG? |
Hello group,
I would like to have gyros or equivalent in my plane,
but I have not found simple electronic gyros yet.
At one end of the scale, I found a device which
connects to a PDA so you see attitude information on
the PDA's screen.
At the other end, I found integrated engine
instruments, attitude, altitude, airspeed,
temperature, direction, gps and whatever you can
imagine.
Will there be any device available to simply replace
mechanic AH and DG in a unit of similar size?
Thanks for your insight.
Michel Therrien CH601-HD
http://pages.infinit.net/mthobby
http://mthobby.pcperfect.com/ch601
http://greetings.yahoo.com
There are a couple of possibilities out there, Blue Mountain Avionics
makes one called the EFIS/Lite -
(http://www.bluemountainavionics.com/efislite/about.html) and the
Dynon EFIS-10. at http://www.dynondevelopment.com/
Bothof them have some features you describe, although they are not
simple electronic gyros. And they are pricey.
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
Michel Therrien
Subject: AeroElectric-List: ElectrONic AH and DG?
Hello group,
the PDA's screen.
imagine.
http://www.matronics.com/browselist/aeroelectric-list
Subject: | Constant discharge on the battery |
Hi Everyone,
I am currently flying a SuperCub and have been having trouble with the
charging system. The AMP meter shows a constant discharge and the
battery keeps going dead. We have replaced the Generator, Battery,
generator circuit breaker, and voltage regulator with no success. What
am I missing here? The AMPS gauge is a negative - zero - positive
readout. There is no Volts gauge. Whatelse should I be looking at?
Thank You,
Ed Perry
eperry(at)san.rr.com
Subject: | Re: ElectrONic AH and DG? |
yes . . . but probably not this year . . . but
certainly within say 5 years. the technology
is here. it just needs to be applied in enough
OTHER consumer products to drive the prices down
to levels practical for our use. I've got
a 3-axis laser gyro on my bench right now
that's going to replace iron gyros in several
of our targets at RAC. We've built our last
iron gyro stabilized product. . . . and it's
only about $4,000 per axis. It was $10,000
per axis the last time we considered it for
a target upgrade . . . about 6 years ago.
It's probably more than what you're looking for but take a look at
www.dynondevelopment.com Their product, soon to be released includes about
10 things in an EFIS display.
----- Original Message -----
> Hello group,
> the PDA's screen.
> imagine.
Subject: | Re: speed reduction |
>Bob, Do you have a schematic for a speed reduction device for the trim
>servos that I can build or is it something that I have to buy such as
>the Governor Mk III is a speed reduction and switch multiplexer for the
>MAC Trim series of aircraft trim servos from Matronics?
You can use an LM317 regulator from Radio Shack to
build an adjustable power supply that will provide
the necessary, lower voltage for slower operation.
Are you talking about MAC linear actuators? These
only draw a few hundred milliamps and can be
easily controlled by the smallest plastic
device (LM317T).
You can find data on the device along with
hookup info at:
http://www.national.com/ds/LM/LM117.pdf
Matt's product is another alternative.
Also, in a few weeks, the B&C catalog on
our website will offer the full range of dimmers
as two channel, adjustable power conditioners.
You can see a prototype of the 1.5A controller
at:
http://209.134.106.21/temp/apc15-14a.jpg
and
http://209.134.106.21/temp/apc15-14b.jpg
A closeup view of the board is found at
http://209.134.106.21/temp/apc15-14c.jpg
In the closeup view you can see the two
potentiometers that set output voltage.
These can be used as a two-channel controller
where one might need hi and low speed trim
speed adjustment. It can also be used
as a single channel device to provide
clean, regulated power to accessories
that require some voltage less than 14v
to operate.
These will probably sell for the same
price as their dimmer counterparts . . .
the two surface mounted potentiometers
on the power conditioner cost about the
same as the panel mounted potentiometer
and knob for the dimmer.
When the products are being offered for
sale, you'll be able to download
a copy of the installation instructions
which will show how to hook it up for
the various tasks.
>Bob,
>had no effect.
When I developed the wiring diagrams posted
on my website, I had examples of the Galls products
to test on the bench and make sure that it
would work as advertised. If you'll send me your
flasher, I'll figure out what needs to be done
to make it work in your airplane.
Ship it to 6936 Bainbridge Road, Wichita, KS
67226-1008
Subject: | Re: Microair Xpndr |
>Somebody at Becker told me they got approval for their
>ATC-4401 just last week. As it was the case for the
>Microair unit, approval for the Becker unit was
>delayed many months. Becker mentioned they're going
>to ship transponders within 3 weeks... of course, I
>will decide if I believe that in 4 weeks :-)
>Perhaps something happened at the FAA so they have
>time to put stamps on documents...?
I think the FAA is all through torturing Microair
on this product . . . I think it's the FCC taking
their turn.
>Hi Bob,
> Another question for you...on fig. Z-14 on the main power bus, you show
>mostly fuses and then there's a 5A CB for the ALT FIELD. Why the CB instead
>of a fuse? Sounds like it makes sense, but I'm curious to hear the real
>rationale!
The alternator system shuts down by means of a crowbar
ov module that will deliberately short the field
supply line to ground - expecting the upstream fault
protection to open up and remove power from the alternator.
Don't want to do this with fuses. Crowbar OV modules can
be nuisance tripped so this is the one place where I
use a circuit breaker.
> Also you have a CB for the hyd pump...This seems to make sense
>too, since there isn't actually an on-off switch for the pump and it would
>be nice to have "override" control. Is this the rationale for the hyd pump
>CB? Are there any other systems that you would think would be nice to have
>this control over, ie use a CB over a fuse even tough you are going
>primarily with fuses?
I drew that before B&C was handling the ANL limiters. I wasn't
intending that to be any kind of controller . . . the pump motor
has a high inrush and the JJS/JJN type fuses were inappropriate
to protecting this kind of feeder. The ANLs are just the ticket.
Even if you use a breaker for the pump, I wouldn't put it on
the panel . . . one of the goals of clean system design
is to keep those kind of current carrying conductors away
from the panel. I did have one Glasair builder mount his
pump circuit breaker low on the right side kick panel so
he could reach it if he stuck a contactor. This should be
a rare event and if it happens, you can treat it just like
an alternator out event. Kill the main bus to shut off
the pump. Continue to intended destination and turn the
main bus on long enough to cycle the gear . . . or leave
it off and use the primary gear extension system (the manual
one that ALWAYS works) to lower the gear.
>Also how exactly do you wire the CB off the fuse block? Your diagram only
>shows the CB connected to the fuse block, ie no connecting wire from the
>fuse block to the CB???
Opps . . . that should be drawn like the alternator field breaker
in figure Z-11 . . . a fusible link at the fuseblock extends the
bus up to a breaker mounted beside the DC POWER MASTER switch.
Need to fix that!
Subject: | Re: Constant discharge on the battery |
>Hi Everyone,
>Thank You,
>Ed Perry
It's always better to get out the voltmeter
and find out what's broke before pulling it
off airplane. If all the parts you put in
are known good parts then there must be
a wiring problem or a failure in other parts
like the generator switch. Is the voltage
regulator getting power through the breaker
to the B or BAT terminal? What is the voltage
on the generator's field terminal when the
switches are all on with the engine running
vis-a-vis engine stopped?
Do you have a diagram as to how the airplane
is wired? Have you considered putting a B&C
L-40 alternator on to replace the generator?
This has been done perhaps a hundred times
on Super Cubs with one time field approval.
Do you have a friendly local FSDO that would
help you with paperwork?
From: | "Paul Besing" <azpilot(at)extremezone.com> |
Wire guage? If you wire guage is too light, it won't carry the current
through. Have you chased the voltage? See where it is showing live voltage
and how much? If you put a volt meter on your battery while the engine is
running, you should get about 14 volts or so.
Paul Besing
RV-6A N197AB Arizona
First Flight 22 July 01
Kitlog Pro Builder's Log Software
http://www.kitlog.com
Subject: AeroElectric-List: Constant discharge on the battery
> Hi Everyone,
> Thank You,
> Ed Perry
> Hello group,
> the PDA's screen.
In addition to those already mentioned, Sigma Tek, at last year's Oshkosh
(oops Air Venture), was showing prototypes for direct electronic
replacements of the attitude and directional gyros. No information on price
or availability was provided.
Dick Sipp
N250DS
Subject: | Electrical System Instrumentation |
Hi Bob,
A little background:
I have had your book and have been reading the list for several months now.
I have been through the book once and back to sections a few times. I absorb
more and more with each revisit. I am still functioning at a basic level in
the area of electronics, but am reasonably adept at figuring out what is
going on and what is intended if I take it slowly and one step at a time.
I am putting together a Murphy Super Rebel and am a month or so away from
starting the Engine Installation/ Panel and Wiring. The majority of the
panel goodies have been selected and on hand. I am trying to wrap up
instrumentation for the 9 cyl 400 HP M-14PF Radial.
Randy my partner and I have decided to go with your "All electric on a
budget" system. Single Battery. We have a Skytronics 50 Amp. alternator and
their regulator (haven't analyzed its features if any yet). and plan to
install either a B&C 8 or 20 amp alternator on the vacuum pump pad. In the
other two aircraft I have owned, one I built, a CH701 STOL amphib, I have
only had a voltmeter to monitor the electrical system. In both cases they
where digital and I found the information provided adequate to assess the
health of the systems, neither has had any problems to date.
My question for you concerns instrumentation for the electrical system of
the SR.
I know I want a digital voltmeter and I would like it to be a 2.25 round.
Both Electronics International and Davtron make such an animal and both can
be toggled between Volts and Amps. A Davtron Model, the M475VAA has dual
shunts and can read voltage and two current flows. It can measure alternator
output and charge and discharge of the battery. It has a three position
toggle switch. Volts/ +,- Battery Amps/Alternator amps.
I would appreciate your thoughts on the direction I should take on
electrical system instrumentation given the availability of the above
instruments and the usefulness of the information they provide.
Thanks in Advance.
Don Boardman
& Partner
Randy Bowers
SR3500#130 "The Muskie" M-14PF Aerocet 3400 Amphibs Rome, NY
Two things. There is generally a switch on the field. There should be 12
volts on the field terminal of your regulator with the master turned on. If
not there might be a blown fuse in that wire. The other thing that you must
do is flash the field of a "new" generator to give the field enough
magnetism to generate.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Hi Everyone,
Thank You,
Ed Perry
From: | Frank and Dorothy <frankv(at)infogen.net.nz> |
Subject: | Re: Microair radio & xpdr amp |
requirements
> > >I've heard the Microair xpdr is now available in the US for sale. Do
> > >you have a price for it and what are the amps for each unit?
>Saw it here in New Zealand. Asking price was NZ$2800, which should
>translate to about US$1200, give or take a couple of hundred.
Found the pamphlet on it today -- draws 0.5A whilst transmitting, 80mA
while receiving.
Frank.
I am going with the Dynon EFIS. http://www.dynondevelopment.com/
There is also the EFIS/Lite from Blue Mountain Avionics.
http://bluemountainavionics.com/
Ross Mickey
RV6A
> Hello group,
> the PDA's screen.
> imagine.
From: | "Piers Herbert" <piers.herbert(at)ntlworld.com> |
I note you can also get a LM217 which is similar but specified for a wider
temperature range (sub freezing). Would there be any point in using the
wider temperature version, I suppose I might want to fly after the machine
had been in sub freezing temperatures over night, but then as the thing
generates heat it would warm up quickly. Is the LM317 compatible with DO
160, or is this not something we need to be concerned about?
Piers
Subject: | Re: toggle switch failure modes? |
Bob, I'm not saying that your published architecture with the diodes
falls short in any way. Just wondered why the function couldn't be
replaced by a single toggle switch....not much savings, but it would be
lower parts count and probably save a few bucks and an ounce or
two.....one less thing to mount....no voltage drop (yeah, I know, not a
problem to have a 0.7 volt drop). Just seems to me that it would work
just as well with a toggle switch and even though the switch could break,
it's not likely to do so unless actuated.....which means it would break
when you need it most and at that point it wouldn't be much different
than using the diode / toggle combo (i.e. the toggle could also break
when you need the ESS bus...). So in the spirit of your statement on
your website inviting peer review and comment on the wiring diagrams, I
just wondered realistically if there's a toggle switch failure mode that
would create a *statistically meaningful* problem in this scenario?
I'll probably just put the diodes in....not a big deal....just don't see
a compelling advantage....
--Mark
_______
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com>
Subject: Re: AeroElectric-List: toggle switch failure modes?
>Bob,
>A couple days ago I posted a question about using a DPDT toggle switch
for
>the ESS bus, using it to replace the diode function you show on your
>schematics. I didn't get a direct response but your response to another
>post using a similar idea was that there are some good reasons to use
the
>diodes and that using a single switch results in a single point of
failure.
>A couple questions: first of all, what other advantages are there to
>using the diodes besides their obvious function of keeping the current
on
>the ESS bus from feeding back into the main bus?
No moving parts. Never seen one fail in service in an
airplane.
>Second, what kind of failure modes does a toggle switch have? I don't
>know what it looks like inside....in a DPDT switch, can it break such
that
>neither position can make contact? Can the contacts in BOTH positions
>weld together? Etc?
Let's back up a bit. What don't you like about what you
see in the wiring diagrams? Have you read and understand
the failure tolerant design philosophy described in chapter
17 of the AeroElectric Connection? Where do you perceive
that the diagrams published miss the mark?
I'm not trying to avoid your questions I'm curious as
to how the published architectures fall short.
> Bob, would these devices be acceptable replacements for the remoted fuse. Sure
would be
> nice to keep everything in the fuseblock. -Steve
> http://order.waytekwire.com/CGI-BIN/LANSAWEB?WEBEVENT+L2370635A7F820100748E044+M36+ENG
> Need to fix that!
> Bob . . .
Ed:
If you have a generator and not an alternator, you must polarize it at the
voltage reg. when replacing parts before it will operate properly.
Steve
Springfield Auto Parts Co., Inc.
> fuse. Sure would be
I'm not particularly impressed with the little circuit breakers
masquerading as fuses. Besides, one of the goals of using
compact, prefabricated fuse blocks is to get them off the
panel . . . and preferably out of reach. Since the ALT FIELD
breaker might be subject to nuisance tripping, it's best left
on the panel . . . like right next to the DC POWER MASTER.
I show the S700-2-10 switch used for DC POWER MASTER to get
the progressive OFF/BAT/BAT-ALT operation on one switch. The
times that one wants to operate battery only are usually limited
to ground maintenance operations. One could use the S700-2-3
switch to simply bring battery and alternator on and off together
and pull the ALT FIELD breaker for battery only ground ops.
The S700-2-5 is a much less expensive switch.
> > Need to fix that!
> > Bob . . .
TEMPORARY WEBSITE ADDRESS:
We're probably splitting frog hairs . . . it's your
airplane and you have to be comfortable with it. I
can tell you that power distribution steering diodes
are very commonly used on aircraft from King Airs on
up and are much preferred to any mechanical substitute
for overall system reliability.
Anything that moves generally has 1/100th the reliability
rating of it's solid-state counterpart. I did the first
electronic speed controlled pitch trim to fly on the
Lears about 20 years ago. When I did the MTBF studies
the 50-60 piece collection of electronics showed a
calculated MTBF in thousands of hours. When I factored
in the super quality, hermetically sealed mill-spec
auto-disconnect relay, the numbers fell to under
1000 hours.
Nobody on the certified side of aviation will use
a mechanical device in favor of a sold state one.
None of these concerns are significant in the situation we are
contemplating.
Subject: | Aft battery cranking power |
I'm thinking about installing the battery in my RV-8A in the aft location (behind
baggage compartment) for CG reasons. However I'd like to use the smaller Odyssey
battery instead of the big Concorde battery, and I'm wondering if the longer
wire run would significantly impact starting capability? Assuming 250 A
cranking current for a Skytech starter, and using 14 feet of #2 wire vs. only
about 4 feet of #4 wire (for firewall battery location), my calculations using
the published resistance values for #2 and #4 wire shows that there would be
a .55 V drop on the long #2 run vs. a .25 V drop on the short #4 run. But my
question is whether or not this is a meaningful, noticeable difference? Should
I plan on using the bigger capacity battery because cranking may take longer
with the aft location?
--Mark Navratil
Cedar Rapids, Iowa
RV-8A finish kit stuff....
Subject: | Re: Aeroelectric connection vs. CD Rom |
If it is the battery that should be easy to check....but didn't the battery
get drained when he had the big battery installed under the seat? I think I
remember it that way. Let me know if I can help....
Off to work,
Ed Perry
Subject: Re: AeroElectric-List: Aeroelectric connection vs. CD Rom
> >Can someone describe the difference between the Aeroelectric connection
> >and the CD ROM? Is there a .pdf of the book on the CD, or is the CD
> >supplemental information?
> The CD is a mirror of the wbsite . . . if you have a slow
> internet connnection and then it's probably a good deal to
> get the ROM so you don't have to download all the articles.
> Further the CD Rom has a copy of AC43-13b and ammendments on
> it plus other data like fars. It includes a working copy
> of a CAD program that will open, edit and print all of our
> downloadable wirebook drawings.
> The CD will have updates to the 'Connection but not
> a complete book.
> Bob . . .
Subject: | Polarized Connectors. |
I sent the following message while I believe your site was down. Since I have
received no answer I'll submit my question again.
Would these Radio Shack polarized connectors be suitable for wing root
disconnects? (p/n 274-151 male, 274-154 female at $.99 each) They are rated
at 20 amps and cannot be connected the wrong way, and as the name says are
interlocked.
Harley Beard RV-6A finish kit.
Subject: | LR3B-14 Voltage Regulator |
In a message dated 02/22/2002 2:52:43 AM Eastern Standard Time, "Robert L.
Nuckolls, III" writes:
<<.....skip..... one of the requirements I had for configuring the output
stage was that the warning lamp should illuminate IF power were entirely
removed from the regulator.....skip...... >>
2/28/2002
Hello Bob, The statement above that you wrote puzzles me.
I went out to my airplane (still under construction) turned on my battery
master and plugged in my battery charger to bring bus voltage above the point
where the low voltage warning light would no longer flash.
I then pulled the CB providing bus sense (and power source) to pin 3 of the
LR3B-14 voltage regulator. The low voltage level light did not start to
flash. Your statement above implied to me that it should flash.
Is something wrong? Many thanks for your help.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
The Galls controller is in on its way to you by priority mail.
Richard Dudley
> >Bob,
> >had no effect.
> 67226-1008
> Bob . . .
From: | "W T Bartlett" <wtbartlett(at)Prodigy.net> |
I have trouble understanding. The model airplane people sell single axis
,solid state, Gyros for less than $70, and these have to differentiate
between heavy control input and lighter input. Buy three and mount them at
90 deg. to each other and they will hold heading, altitude, and roll. Now we
are up to $210 for a three axis autopilot. These are not directly usable by
us because they require a radio control transmitter and receiver, less than
$100 ( guess you could make a little box for the receiver and carry a
transmitter with you) and they would be simpler if they were just hooked up
to a display and servos. For $150 you can get a two axis autopilot that
receives GPS and holds attitude and heading. They have other gyros that can
distinguish between sky and ground (IR) and will right an out of control
plane (also less than $150. Why is it that people who can build airplanes
can't adapt these products? All the above products weigh less than 2 oz.
Most of the trim servos are modified model airplane servos.
What's the problem?
Bill N7WB
> Subject: Re: AeroElectric-List: ElectrONic AH and DG?
> Bob . . .
A lotta people try these in robots, they ain't very constant.
CPU's like basic stamps have servo signal inputs and outputs
so they are very easy to connect to computers.
Remember an RC plane going 30-80MPH won't be going in a straight
line for for more than a few minutes.
Robots and our real airplanes we want to hold heading, altitude
for maybe hours.
The RC gyros just aren't up to the task. The mechanical ones
precis, and the electronic ones drift. They can be correlated
to other instruments (PNI makes a flux gate compass for about $80
motorola and others have pressure sensors for less than $100) and
it could be done, just not easy.
> What's the problem?
> Bill N7WB
Subject: | Re: Aft battery cranking power |
From: | Denis Walsh <deniswalsh(at)earthlink.net> |
I've used both the concorde25 AH and the odyssey 17AH batts on my O-360
engine. The Odyssey cranks better, but theoretically has less reserve
power.
DLW
> (behind baggage compartment) for CG reasons. However I'd like to use the
> smaller Odyssey battery instead of the big Concorde battery, and I'm wondering
> if the longer wire run would significantly impact starting capability?
> Assuming 250 A cranking current for a Skytech starter, and using 14 feet of #2
> wire vs. only about 4 feet of #4 wire (for firewall battery location), my
> calculations using the published resistance values for #2 and #4 wire shows
> that there would be a .55 V drop on the long #2 run vs. a .25 V drop on the
> short #4 run. But my question is whether or not this is a meaningful,
> noticeable difference? Should I plan on using the bigger capacity battery
> because cranking may take longer with the aft location?
> Thanks,
> --Mark Navratil
> Cedar Rapids, Iowa
>What's the problem?
I have some of these that I've been playing with.
The problem is drift rate. While you're controlling
a model airplane, you responding with control inputs
based on what you SEE the model doing. Drift rates
on the order of as much as 4-5 degrees per minute
would still afford a ton of inertial stability
for controlling the model. Drift rates on this
order are okay for navigation too . . . when you
have GPS data to provide once per second updates
of true course and speed.
The gyros used in both model airplanes and modern
AH/DG replacements are not stable platforms like
iron gyros. They're just rate sensors . . . so to
know where up and north are, you have to initialize
the system and then integrate rate with time to
deduce new heading and whether or not you are
straight and level . . . drift rates on the order
of .1 degree/minute are desirable . . . not easy
with a $75 hummer suitable for model helicopter
stabilization.
That $12K gizmo on my bench right now is laser-ring
gyro that has drift rates on the order of .5 to 1 degree
per minute . . . we use GPS enhancement to wash
out drift. Further, this vehicle's total flight
time is less than 3 minutes so we can live with
and work with the drifts.
Subject: | Re: LR3B-14 Voltage Regulator |
>2/28/2002
No, it should be on steady . . . and probably dimmer than
normal brightness but it doesn't flash.
>Bob,
Very good.
>wondering if the longer wire run would significantly impact starting
>capability? Assuming 250 A cranking current for a Skytech starter, and
>using 14 feet of #2 wire vs. only about 4 feet of #4 wire (for firewall
>battery location), my calculations using the published resistance values
>for #2 and #4 wire shows that there would be a .55 V drop on the long #2
>run vs. a .25 V drop on the short #4 run. But my question is whether or
>not this is a meaningful, noticeable difference? Should I plan on using
>the bigger capacity battery because cranking may take longer with the aft
>location?
No, I got a number of RV-8 builders flying with 17 a.h.
batteries, 2AWG feeders and enjoying excellent cranking
performance.
Subject: | Electrical Sys Instrumentation Ans Found. |
Hi Bob,
Got into the archives for the first time today and see that my question on
system instrumentation has been extensively covered. Sorry I didn't get to
the archives earlier ... new at this list game.
I went to your site looking for a description of the VLM-14 Volt/Ammeter but
could not find it.
Help.
Don Boardman
& Partner
Randy Bowers
Tom -
Who is PNI, and how may they be contacted?
Harley Beard, RV-6A finishing
From: | "Richard D. Fogerson" <rickf(at)velocitus.net> |
Subject: | Bob - I need help in selecting electrical system |
Hi Bob,
I've read about electrical system options until I'm suffering from data
overload. Unless you can suggest a better way, I will try to eat this
elephant a bite at a time in a few e-mails.
Let's say you were building a day (no lights), VFR only, crosscountry
RV3. Modest power req'ts:
RMI encoder (.15 amps)
Engine Monitor (.15 amps)
Navaid (.3 to 3.6 amps)
2 X E.I. (1.5 amps)
GPS (.25 amps)
Other standard electrical stuff like Microair radio & xpdr, contactors,
and boost pump.
Would you go with:
1) One annually replaced RG battery
2) Two RG batteries of equal size where oldest is replaced annually or
3) Two RG batteries of unequal size where both are replaced every one or
two years.
and what size(s) would it/they be?
Thanks Bob,
Rick Fogerson
Fuselage soon
Boise, ID
x
Try www.pnicorp.com for info on the company. Formerly called Precision
Navigation, Inc.
> Tom -
Subject: | Re: Electrical Sys Instrumentation Ans |
Found.
>Hi Bob,
>could not find it.
There are two catalog index/order forms on our website. One
for the stuff I sell as AEC and one for B&C who has taken
over the stuff I used to sell.
Each order form is also the index for descriptions
of products. Note that on catalog page
http://www.aeroelectric.com/Catalog/AECcatalog.html
about 2/3rds of way down the page, you find a listing
for the VLM-14 . . . clicking on the underlined portion
of the listing will link you to:
http://www.aeroelectric.com/Catalog/instrmnt/instrmnt.html
which is the description of the product. Same same for the
B&C order form. Filling out these forms and hitting submit
at the bottom sends the order to different mailboxes.
>power.
It's not just theory but fact . . . "reserve power" or capacity
is only loosely related to "cranking amps" or (more properly)
internal impedance. I can show you 1.5 a.h. batteries that will
dump out more than 1000 amps. A 12v array of these cells weighs
about 2#. On the other hand, there are 35 a.h. batteries weighing
in at over 30# that won't dump more than 400 . . .
Performance in the three tasks of batteries: (1) start (2) regulate
and (3) standby power can be independently tweaked by design
of the battery. Regulation is dead-nuts simple . . . any battery
will do. The need for capacity is a function of how you've
architectured your system . . . if you have two engine driven
power sources, you don't need a lot of capacity. This leaves
only engine cranking performance which can vary considerably
from brand to brand of battery in the same size.
The Odyssey batteries are descendant from the original RG
jelly-roll batteries patented by Gates about 30 years ago.
They are renowned for their very low cell impedance.
Subject: | Re: Polarized Connectors. |
>Bob,
>interlocked.
There are a gob of products out there that are fairly
suitable to this task. The only down side of ALL of them
is their 7-strand, automotive wire with PVC insulation.
Overlooking this relatively minor flaw one can press them
into wing disconnect duty with techniques show as follows:
http://209.134.106.21/articles/wingwire/con1.jpg
http://209.134.106.21/articles/wingwire/con2.jpg
http://209.134.106.21/articles/wingwire/con3.jpg
http://209.134.106.21/articles/wingwire/con4.jpg
Haven't had time to do the Shop Notes for this
piece but the pictures are up . . .
Subject: | Re: I need help in selecting electrical system |
>Hi Bob,
>2 X E.I. (1.5 amps)
>GPS (.25 amps)
>and boost pump.
>Would you go with:
>two years.
For this kind of service I'd go with Figure Z-11, 40A alternator
and an 17 a.h. battery replaced every two years or so. I presume
you ARE going to carry hand held backups like a GPS310 and
JHP-520 so in a daytime cross country environment it's not
critical that ANYTHING on the panel be working. Given the
demonstrated reliability of modern alternators and batteries,
I'd keep it light, simple and low cost. Z-11 is the ticket.
If you have a vacuum pump pad open now or in the future,
upgrade by adding the SD-8 alternator and replace the
battery when it finally won't crank the engine any more.
I found these Neutrik "speakon" connectors in the Maplin catalogue (UK). I
suppose they would be available in the US as well. There are chassis sockets
and line plugs, 20A continuous rated - could be suitable?
http://www.neutrik.com/content/products/products_group.asp?id=204_54361
Piers
From: | Jaye and Scott Jackson <jayeandscott(at)shaw.ca> |
Subject: | Grounding strobe power pack |
Bob:
I have located the strobe power pack just behind the back wall of the baggage
compartment and was wondering if it might cause any noise-related problems if
I were to ground the ground lead right there instead of running a wire all the
way back to the firewall "forest of tabs" that I've used for everything else
up to this point.
Scott in Vancouver
Subject: | Lightweight starters... |
I'm a bit confused about the lightweight starters currently available. It was
my understanding and general impression that most RV builders were getting the
Skytech starter because it was the lightest, best all-around starter. But I've
heard a few less than positive things about Skytech's track record recently.
I looked at the Magnaflite starter, which appears to be a new motor bolted
on to the old "Bendix drive"....it's roughly comparable in price to a Skytech,
is 0.1 pounds lighter, and makes the claim that it has more torque than "any
other lightweight starter out there". I haven't looked at the B&C unit but if
I recall correctly it was heavier and more expensive than the Skytech. So, is
the Skytech getting a lot of use simply because Vans sells it (both separately
and on their new Lycomings) or is there something I'm missing?
--Mark Navratil
Cedar Rapids, Iowa
Subject: | Re: Grounding strobe power pack |
>Bob:
> baggage compartment and was wondering if it might cause any noise-related
> problems if I were to ground the ground lead right there instead of
> running a wire all the way back to the firewall "forest of tabs" that
> I've used for everything else up to this point.
>Thanks,
>Scott in Vancouver
No, landing lights, taxi lights, strobe power supplies, and pitot
heaters can get local grounds. IF, in the relatively rare case
you do get some noise from the strobe supply, it's a 99.5% bet that
it's conducted noise that is easily filtered at the power supply.
Subject: | Re: Lightweight starters... |
> available. It was my understanding and general impression that most
> RV builders were getting the Skytech starter because it was the
> lightest, best all-around starter. But I've heard a few less than
> positive things about Skytech's track record recently. I looked at
> the Magnaflite starter, which appears to be a new motor bolted on to
> Skytech, is 0.1 pounds lighter, and makes the claim that it has more
> torque than "any other lightweight starter out there". I haven't
> looked at the B&C unit but if I recall correctly it was heavier and
> more expensive than the Skytech. So, is the Skytech getting a lot of
> use simply because Vans sells it (both separately and on their new
> Thanks,
> --Mark Navratil
> Cedar Rapids, Iowa
Mark:
The SkyTec is the start that is on the new Lycoming and was one of the
first to hit the market with a good price. At about 4 years and 950
hours, I had the solenoid go out. That was a $37 part that came to
around $43 delivered. My fried Paul Rosales had his go out at about
750-800 hours. I know of one other that had the selonid go out.
The SkyTec starts my engine typically with 3 blades or less. I am
using Bendix mags and only one has an impulse coupling.
Gary A. Sobek
1,010.4+ Flying Hours So. CA, USA
http://SoCAL_WVAF.tripod.com
>was my understanding and general impression that most RV builders were
>getting the Skytech starter because it was the lightest, best all-around
>starter. But I've heard a few less than positive things about Skytech's
>track record recently. I looked at the Magnaflite starter, which appears
>to be a new motor bolted on to the old "Bendix drive"....it's roughly
>comparable in price to a Skytech, is 0.1 pounds lighter, and makes the
>claim that it has more torque than "any other lightweight starter out
>there". I haven't looked at the B&C unit but if I recall correctly it was
>heavier and more expensive than the Skytech. So, is the Skytech getting a
>lot of use simply because Vans sells it (both separately and on their new
B&C produced the first successful lightweight starter
design. It's been STCd for longer than I care to remember
and enjoys strong user support. Robinson Helicopter
has used nothing but B&C starters for about 15 years
and they're very happy with the decision.
B&C has participated in dozens of conversations with
Lycoming and Continental about supplying volume
quantities to support their engine production.
In every case (until a few months ago) both Lyc
and Cont thought they could do better. Lyc
has gone through several iterations of sub-
contracted and outside starters (including
Skytech) over the past 10 years. None have
matched the performance and reliability of
the B&C starter. Continental tested a B&C
starter on their new IO-240 and pronounced
the starter "indestructible" after 5000
starts in the test cell. Then they proceeded
to attempt a clone of the B&C design which
proved to be a poor business decision.
Seems their clone has dropped too much metal
in too many engines. I belive they're
currently negotiating with B&C for the
starter they tested.
Virtually all competition to the B&C starters
use PM motors . . . lighter, cheaper and
easier to build. I was involved in Bill's
deliberations to consider offering a PM
motor version of his design. After several
months of consideration, we agreed that
it would add no performance value. PM
motors have some performance downside
. . . most notability the higher inrush
current and steeper current vs. RPM
curves characteristic of a parallel
wound motor. Bill was unwilling to give
up superior system integration issues
and elected to stay with the wound field
design.
Further, B&C designs use all ball
bearing construction and no plastic
structural parts or gears. B&C starter
pinion gears are directly engaged with
the ring gear by a solenoid.
Many folks report satisfactory performance
from other starters. In the bigger picture,
B&C's track record with Robinson stands
in sharp contrast with attempts by both
Lyc and Cont to do better for less money.
Yeah, the B&C starters are more expensive
but they've got more stuff in 'em and they're
harder to build. I'll suggest that trials in
the marketplace have proven B&C starters to
be good value.
Some further clarification, the GPS I'm leaning toward is the Skymap II from
Bendix King that is charged by the aircraft electrical system but has NiCad
battery backup so it is not a problem. However, I want to use the Microair
comm and xpdr (don't like handhelds) and I forgot to mention that the
alternator/regulator will be B&C but the starter will have to be Skytech
(for unrelated reasons).
Does this change your recommendation to something else?
> >Hi Bob,
> >2 X E.I. (1.5 amps)
> >GPS (.25 amps)
> >and boost pump.
> >Would you go with:
> >two years.
> Bob . . .
How inconvenient does it become to practice manual gear extension procedures if
the
breaker is WAY out of the way and not a pull out type? I remember from my Arrow
check-out time either the instructor or myself using that feature alot.
Bernie C.
"Robert L. Nuckolls, III" wrote:
> >Hi Bob,
> Bob . . .
Subject: | Re: Alternator windings |
My modern (2001) Toyota alternator does this. Probably ND.
Bernie C.
> . . . adding two more diodes to the
> rectifier array will increase output by as much
> as 10%.
> Bob . . .
Subject: | spark ign. question |
Here is a question that I have been wondering about for 20
years. Many times I have had a motor that was hard to start
due to fouled plugs or flooded plugs or low battery.Often pulling a spark
plug wire off the plug and leaving a gap between the wire
and the plug somehow makes the spark more powerfull.
The engine will often fire and start on that cylinder and if
it a multi-cylinder engine the others may catch. Sometimes
the engine will quit when the gap is removed. I learned this
on an old triumph motorcycle and have done it on lawnmowers
and golfcarts, electronic and points ignitions. I know it works
and is not just my imagination.
So anyone got an electrical explanation for this? My guess
is that the coil discharge is held back by the gap. When it
finally jumps it is a bit shorter duration but more intense??
Here is the airplane content
I used this technique to get a zenair soob running while
setting up the carb. It was way too rich and fouled the
plugs bad. We were only ground running so did not want to ruin
more than one set of plugs while setting the carb.
thanks
Jim Pollard
ch601hds
ea81
From: | "David Swartzendruber" <dswartzendruber(at)earthlink.net> |
Yes, the new Lycoming engines from Van's come with a Sky-Tec starter,
but that is only because Van's has spec'd the engine that way from
Lycoming. The Magnaflite is now the standard starter at Lycoming. All
their test cells use Magnaflite starters. When you're buying as many
starters as Lycoming does, it's hard to pay the price for a B&C. As
individuals, choosing an expensive starter only has to be a one time
event.
Wichita
> Mark:
> one of the first to hit the market with a good price. At
> about 4 years and 950 hours, I had the solenoid go out. That
> was a $37 part that came to around $43 delivered. My fried
Subject: | battery cranking power |
Are these available at reasonable cost yet? Saw one at OSK a few years
ago then never heard anything more. I had hoped to mount one beside the
starter. Lighter than running a heavy wire from the battery. It would
also reduce the total battery weight since I'm carrying two alternators
anyway.
Ken
>about 2#.
From: | Robert McCallum <robert.mccallum2(at)sympatico.ca> |
Subject: | Re: spark ign. question |
What happens with a fouled plug (or a plug with too little gap) is that there is
a low resistance
path for the electricity to follow and therefore the spark occurs at a lower voltage.
This low
voltage spark is less intense and contains less energy than if a higher resistance
path is
established thus causing a higher voltage to build up before flash over. This higher
voltage causes
a more intense higher energy spark. This is the theory employed by resistor spark
plugs or
"intensifier gap" spark plugs used in many cars. A low voltage spark jumping a
few thousandths of an
inch gap in a switch is a relatively low energy spark and causes very little damage.
The spark
across a normal spark plug gap of .025 to .100 inches requires a few thousand volts
and fairly
rapidly burns away the electrodes requiring plug replacement regularly. A bolt
of lightening jumps a
very large gap, requires millions of volts and causes instantaneous mass destruction.
The amount of
damage or wear is a rough measure of the energy in the spark A higher energy spark
imparts more
energy to the mixture in the cylinder and hence results in easier starting.
Very simplified explanation, but basically what goes on.
Bob McC
> thanks
> Jim Pollard
> ch601hds
> ea81
Subject: | Re: battery cranking power |
>anyway.
>Ken
Hmmmm . . . they WERE . . sorta. I just tried to log onto
their website at boldertmf.com and the site failed to come
up. These folks had been working on a miniature version of
the jelly-roll cell in a 1.5 a.h. configuration. I've been
following them loosely for several years. I've had samples
of the cells to play with. When new, they performed very
well but they were having service life problems.
Bolder produced a product call Secure Start which I've seen
stores in the past. It sold for about $100 and had an array
of cells in a 12v battery along with built in wall charger,
flashlight and big battery clips to hook to your dead
car battery for a dead-battery resurrection.
Seems they've dropped out of sight. Okay, the next contender
would be the folks who do the Startstick. See:
http://www.startstick.com/Products.html
most of their 12 products are bigger in capacity . . . 10 a.h.
or so is advertised. However here's an interesting item:
http://www.startstick.com/Products.html#UltraStartRed
This is a 4.4#, 5 a.h. product that claims starting
current capability. Don't know anything about these guys.
I'll order some samples one of these days. They
use prismatic cell construction (stacked plates) as
opposed to the jelly-roll cell . . .
To date, the most and only successful jelly-roll
cells with any track record are the Hawker 2 a.h.
cells and the Optima 25 a.h. products (both originally
Gates). Guess the Bolder folks have tossed in the
towel.
Startstick is the next one to watch.
>procedures if the
>Arrow
Turn the E-BUS ALT FEED - ON, DC POWER MASTER - OFF and
lower the gear with the manual system.
>Bob,
Yes. New battery every two years max . . . or every
annual just for the hell of it. If you don't mind
running a capacity check every 6 months or so after
the first year, then keep the battery until it drops
below 4 hours sustained e-bus loads.
How does fouling a plug trash it? I used to clean
and re-gap my plugs regularly . . . on old engines,
it wasn't uncommon to find one with more crud on it
than the others but 15 seconds in the plug cleaner
made it indistinguishable from the others.
I've hear of this "trick" before but I'm at a loss
to explain it. Adding to the total spark gap length
can only raise the path resistance which makes the
event shorter in time.
Here's an interesting thing about spark plugs:
In 1956 my friend's dad had a '56 Chevy with "power pack" V-8 engine and
stick shift - awesome performer. One weekend the engine is missing so 3 of
us teenage experts start troubleshooting.
First thing we do is check the plugs - and cleaned them. No help. Then
took 6 good plugs out of my non-missing 1954 Ford 6 cyl and put them in the
V-8 - no help. We had spark at wires and tops of plugs, so ignition system
was OK. Seemed to be getting gas OK. Sooo, looks really serious - we start
shopping for a place to pull the heads and do a valve job (no, we didn't do
a compression check - ignorant).
Well, some kind soul stopped us and had us buy 8 new plugs - fixed the
problem.
Only thing I figure is that spark plugs that worked in my 7.6 to 1
compression ratio Ford 6 wouldn't fire under the higher pressures in the
10.5 to 1 V-8. Subsequent life experience confirmed that higher compression
requires better/different plugs than what will work in a low compression
engine.
Cleaning? I used to clean my plugs in the Ford, and later, a VW, at 10,000
miles, then replace at 20,000. Cleaning at 20,000 didn't help them work
correctly. What deteriorates? Not visible to the naked eye. Must be
"spark plug black magic" - until there's some "physics" involved.
David Carter
Bob said,
> Bob . . .
True, but the higher resistance means the energy has to build to a higher level
before it jumps the
gap. This greater energy being dissipated across the plug gap creates a hotter
spark although as you
state the duration of the spark may be shorter. If the fire starts within this
time frame you're
away. If not, then the "trick" didn't work this time, but it often does. If you
think of an
ignition coil (or Mag) as being similar to a large capacitor charging up until
the energy is
released by the fact that the voltage built high enough to jump a spark gap, then
the larger the gap
the more energy is stored before the spark jumps and the more energy is released
in the resultant
spark
Bob McC
> Bob . . .
Is anybody here flying using one of these electronic
compasses?
See:
http://www.pnicorp.com/compass-products-and-digital-compasses/v550-digital-vehicle-compass.html
--- Lonnie Benson wrote:
> Benson"
> Navigation, Inc.
> From: <Hebeard2(at)aol.com>
> To:
> DG?
> Hebeard2(at)aol.com
> > Tom -
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
> aeroelectric-list(at)matronics.com
> http://www.matronics.com/subscription
> http://www.matronics.com/photoshare
> http://www.matronics.com/search
http://sports.yahoo.com
Subject: | Alternator B-lead fuse question |
I found an in-line fuse holder with 50 and 60 amps
plug-in fuses this morning.
Is this good for our application in place of a Current
Limiter limiter?
See: http://mthobby.pcperfect.com/dcp01418.jpg
Michel
>compasses?
>See:
Nice looking device, but I'm not using one.
What I am doing is a research project using 3D magnetometers as part of an
attitude sensing system. The primary intent isn't for use in aircraft, but,
as you might guess, that is a constant consideration. It's possible that
combining this with 3D rate gyros might result in a relatively cheap
electronic AH or DG.
Frank.
>level before it jumps the
>hotter spark although as you
>this time frame you're
>If you think of an
>until the energy is
>gap, then the larger the gap
>released in the resultant
>spark
Hmmm . . . my physics book says energy stored on a capacitor
is joules (watt seconds) = volts squared times capacitance
divided by 2. Hence a 100 uF capacitor charged to
300 volts stores 4.5 joules of energy. An inductor's
storage is amps squared times inductance divided by
two . . . If memory serves me correctly, my ol' Chevy
spark coil primary was about 10 millihenries charged
to 2A for a potential energy storage of 20 millijoules.
When we rewound them for transistor ignition, we'd
pull off the primary and wind it back on with half the
turns and double the wire. Half turns gave us 2.5
millihenries of inductance but we would charge it with
about 10 amps for a storage of 125 millijoules of
energy.
All other things being constant and irrespective
of whether the system is inductive or capacitive
storage, adding a spark gap in series with the
gap in the plug would simply allow a fixed
amount of energy to be dissipated in two places
instead of one. I'm having trouble figuring out
how adding the second gap outside the cylinder
improves performance for the gap inside.
Subject: | Re: Alternator B-lead fuse question |
>Limiter limiter?
We talked about this a few weeks ago. While
these holders will indeed mount the larger
70A cousins to the ATC fuses, they're pre-wired
with 10AWG wire. I wouldn't use them with any
alternator larger than 40A.
The one I have appears to be wired with no 8 wire.
This said, is it OK?
Discussing this, I also saw another in-line fuse
holder which supports large tubular fuses. It is a
heavy plastic two-parts tube in which you insert the
fuse and you screw one part into the other. That was
the first time I saw one for big fuses like that
(about 1/4" or 5/16" in diameter). The wire with that
one is definitively a no 8 as it is written on it
(with a PVC jacket). Would this be good?
--- "Robert L. Nuckolls, III"
wrote:
> Nuckolls, III"
> Therrien
> Current
> >Limiter limiter?
> Bob . . .
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
Bob, in a distributor-less system it may make sense that the fouled plug may load
down the
coil so it's never allowed to build up to full voltage. If you create an extra
gap, it will
build up to full voltage and probably result in a higher voltage across the fouled
plug.
Finn
> Bob . . .
Sign Up for NetZero Platinum Today
Only $9.95 per month!
http://my.netzero.net/s/signup?r=platinum&refcd=PT97
With the following information you supplied.
device (LM317T).
hookup info at:
I downloaded this information, purchased the LM317T regulator and proceeded
to build the speed reducer, since I only need a reduced speed I only
installed a 130 ohm resistor from pin 3 to pin 2. On the bench this gave me
about 10.5 volts output. The problem is that by putting this device in line
it is only good for one direction as it does not work with the current flow
reversed. So I just tried a 10 ohm resistor in line and it also reduced the
voltage from 14.5 to around 10.5 on the bench. At this point I installed
this resistor in line on my planes MAC servo and did not see and differance
in acutation time.
Looking for comments and Help
I ran my servo on a 9v teeny battery during testing and I couldn't tell
much difference either. So I suspect you need to be down at some lower
voltage to cut speed at least in half which is what I think most folks want.
My suggestion is to fly and try. I think faster is better. When I roll out
on final, it is too slow. When I am at high cruise it is a little quick but
easily manageable. Hence I have never fiddled with it. To me the only
challenge was to learn the tenth of a second "blip" it takes to trim at
cruise. On the other hand I love gadgets, and someday may put a two
position micro switch in just so my guest pilots can play with it.
DLW
> From: "John Harlow" <jharlow(at)onearrow.net>
> Reply-To: aeroelectric-list(at)matronics.com
> Date: Sat, 2 Mar 2002 19:49:05 -0500
> To:
> Subject: Re: AeroElectric-List: Re: speed reduction
> device (LM317T).
> hookup info at:
> in acutation time.
> John
The rational is then: Even if you lose your only alternator, you shut down
the main bus and maintain the essential bus, and still operate the 2 EI's,
radio, xpdr, and RMI encoder (flt instruments) off the well maintained
and/or tested 17 ah battery. It should get you at least 2 to 3 hrs flying
time.
And, if one really wanted a little more insurance, you could install a small
aux battery to run the EI's but probably not necessary. Does that about
cover it?
One other point, Jeff Rose says there is a brief 8 amp surge for each EI
when first turned on, should the fuse be increased from 3 to 10 amps and the
wire from 20 to 16 AWG?
Thanks, Bob
Rick Fogerson
> >Bob,
from
NiCad
Microair
> Bob . . .
"All other things being constant and irrespective
instead of one.=A0 I'm having trouble figuring out
=A0 Bob"
I have always known that a wet/fouled plug will sometimes begin to fire as
you pull off the wire a little to open up an additional gap at the plug cap.
Is it possible that a wet/fouled plug is more likely to just short out the
current up inside the electrode of the plug when the applied voltage is
great, but when you reduce the voltage a little, it will jump the gap at the
tip instead?
John Z.
Your physics books are no doubt correct, but those formulas are based on a specific
voltage, a
specific inductance, a specific capacitance etc. all constant values.
That's just the point, all other things are not constant and the amount of energy
available is not
fixed. The voltage in an ignition system rises to the point where it "jumps the
gap" at which point
it is effectively shorted to ground and the energy stops building and is dissipated.
The voltage is
not constant if you change the spark gap therefore the charge is not constant and
therefore the
energy is not constant. The larger gap requires the voltage to build to a higher
value before it
"jumps the gap" making more energy available. In some automotive electronic ignition
systems which
are capable of generating 50 to 60,000 volts but only "normally" require 12 to
15,000 to fire the
plugs there are warnings not to run the engine with plug wires removed because
without the proper
discharge gap in the circuit you can build voltages sufficient to breakdown the
insulation in the
coil and/or plug wires. Larger gap equates to higher available voltage which equates
to higher
available energy. If you can convince this energy to find it's way into your cylinder
at the right
time it "may" fire that fouled or worn plug. The extra gap has been proven to work
by many people.
Sometimes accidentally and sometimes intentionally as in "booster gap" spark plugs
which do seem to
fire mixtures that ordinary plugs won't with no other changes to the ignition system.
All of the above explains (??? maybe) why modern cars run larger spark gaps to
create hotter sparks
(more energy) to help burn the fuel more completely to reduce emissions. Reducing
the spark gap
results in a demonstrably lower voltage at the plug, less efficient combustion
and greater emissions
without making any other changes.
Bob McC
> energy.
> Bob . . .
Subject: | Pin numbers of S700-2-10 on Z-23 & Z-24 |
Regarding figures Z-23 and Z-24, is there a typo on the pin numbers
for the S700-2-10 switch? I looked through the archives and couldn't
find any mention of errors, so if it's correct, please explain what's
different that reverses the pin 2 and pin 5 logic between these drawings
and Z-13.
Tom Barnes
>may load down the
>extra gap, it will
>the fouled plug.
I guess I'm having trouble defining fouled. Are
we talking about contamination that bridges the
plug's gap? Or just a lot of crud that coats
things but leaves some smaller gap?
If the gap is filled, then it seems the task
is to put enough energy into the offending
material to burn it away. If we're talking about
jumping a smaller gap, then it seems the task
is still to put enough energy into the now shorter
spark to get the fuel-air mixture to ignite
anyhow.
The later case seems the easiest . . . if the
gap is completely filled, then the plug is effectively
shorted and the energy required to clear it has to
be several orders of magnitude greater than what
it takes to simply generate a spark.
For a given pressure, mix of gasses and availability
of sharp edges to induce sparking at the lowest
possible voltage, then we could expect a plug
to take more voltage to produce a useful spark
in the first place . . . but with a reduced gap,
the sustaining voltage may be lower than for a
wider, clean gap. An inductive coil storage
ignition system tends to deliver energy in a constant
current mode . . . so once a spark establishes
across a reduced quality gap, the low sustaining
voltage times the constant current results in less
energy delivered to combustible gasses.
I'm trying to figure out the physics that says
if we provide an external spark gap (which takes
voltage to ionize and energy to sustain) that
the energy for the internal spark gaps goes up
as a result. Not seeing how that works just
yet.
Bob. . .
If it is indeed #8 you could go up to 50A alternator.
Have you counted the strands of wire and measured
one of them with a micrometer? Or . . . is it marked
8AWG? Where did you find this product?
The automotive super-audio guys have a whole line
of fuseholders that mount and wire large glass
cartridge fuses. The ones I've seen depend on
tension set up in the threaded end caps of a
plastic housing to capture the fuse inside.
Just not the makings for long-life, gas-tight
joints. Also, the ones I saw use setscrews to
attach wires to the conductive end caps.
Okay for audio systems in cars and wiring
up junction boxes for houses but not practiced
in airplanes anywhere I've seen.
Subject: | Re: I need help in selecting electrical |
system
>time.
exactly
>cover it?
I think so
no . . . 20AWG wire takes hundreds of amps for several
seconds to burn it. If you find that the inrush is
popping the 3A fuse, then with 20AWG you can upsize
it to 7A . . . but I don't think the 3A fuse is
going to give you any problems.
Are you planning a vacuum system?
Subject: | Laptop power in the cockpit |
Bob:
This is probably a question you've answered before... but I can't read
all the messages here!
Needed: Power for my laptop in the cockpit.
While flying from Kona to SFO today, I found my new HP Pavilion (N5420)
laptop lithium battery is good for less than 45 minutes. Its a new computer,
so this is really disappointing.
Getting down on my hands and knees, I found the typical Boeing outlets..
one labeled 28VDC and the other 115VAC. Now.. from past experience I'm darn
sure that 115VAC is 400 HZ, and I'm guessing it will fry the 115v adapter
that came with the computer. That adapter says its smart enough to handle
and convert 100-240 volts, 50-60 HZ. Out put is 19vDC, 3.16 amps. I'd guess
my computer could survive on most any DC input of perhaps 12v to 20 volts,
but I'm not so sure it could handle 28V DC.
The airline used to provide first class and business class (I dunno, maybe
coach, too?) with 15 volt power outlets, but has recently deactivated all of
them. Something about they had a spark or a fire in some plane.. Poor
passengers that appear with the appropriate cords, cables, etc that they
bought thinking we'd give them 15 volts at their seats!
Nonetheless, I go back and see folks still using their laptops on battery
power 8 to 12 hours into a flight! I don't know how they do this!
Two questions: Where can I buy a plug that will plug into that 28VDC
outlet in the typical Boeing cockpit? It looks like a round receptacle,
about 1.2 inches in diameter, with one prong vertical and the other
semi-circular opposite the straight one. It looks like this: | ) with a
circle around it. I guess the idea is to keep someone from plugging a normal
110vac plug into it by mistake.
Second question: Without knowing how many amps my computer draws, how can I
select a resistor to step down the voltage from 28vDC to about 15 -19 volts
DC so my computer can handle it? Is there an easy way to step down 28 v DC
to 15-19 vDC with some simple circuitry, without knowing how much current (or
how much resistance) the using component will draw or offer?
I'm not so sure a laptop will operate on 12 volts, but perhaps it
could. In that case, I was contemplating one of the devices sold to step down
aircraft 28 volt systems to 12 volts for use with 12 volt avioncis and
radios. Would that be wise?
Dan Eikleberry
Las Vegas
> marked
> 8AWG?
It is not marked. It must have hundreds of tiny
strands and it has a vinyl insulation. It fits a no 8
butt splice just well and with insulation removed it
appears to be the same diameter as my no 8 tefzel wire
(but much more flexible). The strands are not tinned.
Local electronic part surplus store. They had only a
few left in a box.
> the
> was
> that
> line
Thanks!
Michel Therrien CH601-HD
http://pages.infinit.net/mthobby
http://mthobby.pcperfect.com/ch601
" I guess I'm having trouble defining fouled. Are
> Neither, the secondary gap only helps when there is liquid contamination (oil,
gas,
> combustion by-products) between the center electrode, insulator and outer shell
(ground).
> It's not the spark energy that cleans out this contamination, it's the fact that
once the
> cylinder starts firing the spark plug electrode temperature gets high enough
to vaporize
> and oxidize the liquid contaminants.
> anyhow.
> yet.
> The resistance of the contamination is low enough that spark never reaches the
ionization
> voltage, but not so low that it merely shorts out and conducts the eventual spark
the
> secondary gap allowed. The trick is to allow the spark to reach a voltage high
enough to
> ionize the gap(s); then there must be enough energy in the spark pulse to deal
with the two
> parallel resistances--the contamination and the ionized air gap. Obviously if
the
> contamination resistance is too low or the total spark energy too low then a
spark of
> enough energy to ignite the charge will not occur.
Toronto, Canada
> yet.
*** How about this: The crud across the plug is not a short - it is
a resistor. This resistor kills the Q of the spark coil, so the voltage
never builds properly. The extra gap keeps the resistor off the spark coil
until the voltage has already built.
I *have* seen this effect - fouled cylinder, not firing. Pull the wire
off the distributor, make a big zappy spark - cylinder fires!
WRT the gap eating energy: the Kettering ignition system AFAIK, behaves
like a current source. I've seen it on an ignition scope: disconnect the
plug, voltage rises to 50-60kV. A spark gap OTOH acts like a voltage
regulator ( VR ) tube. It's VR value depends on the width of the gap AND on
the material filling the gap. The higher the gas pressure, the greater
the voltage. Stomp on the gas, the voltage goes up - because the cylinder
pressures go up, the VR value goes up, and the current source raises its
output voltage.
This is also why a marginal ignition system will idle fine, and hiccup
when you drive up a hill. At idle, the plugs are regulating the output of
the ignition system to a low voltage, and everything works. You stomp on
the gas, the cylinder compression rises, the ignition voltage rises, the
voltage goes up, and _ZAP_ something shorts out, maybe a carbon track on the
distributor cap. Stumble!
SO: As long as the sum of the plug voltage and gap voltage is smaller
than the compliance of the rest of the ignition, the plug will fire.
HOWEVER: this is hard on the coil and distributor, since higher voltages
are impressed on them.
- Jerry Kaidor ( jerry(at)tr2.com )
Maybe I can add something to this. I think you've simplified the
explanation a little bit too much. Yes, a "fouled" plug is one in which
deposits on the insulator become conductive and offer a parallel path for
the current to ground. The spark is made in a "Kettering" ignition system
by building up current in a coil and then interrupting the current. A coil
has inductance, which means that it doesn't like to change current.
Interrupting the current causes the voltage across the secondary terminals
to rise, but not instantaneously (I know, I'm guilty of over-simplifying as
well). As the voltage at the spark plug rises the current can flow through
the parallel resistance path essentially bleeding energy from the coil
before it has a chance to reach the voltage required to jump the gap and no
spark will occur. It's not a "weak" spark that prevents ignition, it is no
spark. If some cylinders can fire and start the engine the magneto will be
spun faster, creating more energy and maybe be able to overcome the fouling.
Granted, there is a fine line where there is just enough energy in the coil
to jump the gap, but not enough to sustain the arc and in that case it may
light a fire and may not - it depends on how close to correct the air/fuel
ratio is right at the gap.
Gary Casey
gaps to create hotter sparks
Reducing the spark gap
combustion and greater emissions
> Bob McC
Interesting... A few years ago I ran a 728i BMW beater ($600 bought me 5
years and 200,000 miles) and other than oil changes, I rarely did anything
to it, but I did log mileage/fuel. At about 75,000 miles after I bought it,
(190,000 on the clock) it developed a high speed misfire - last 10% of the
rpm: the problem turned out to be the plugs - the side electrodes had all
but gone, and the center electrode had eroded below the insulator..... (I
still have one of the plugs!) - putting a new set in cured the misfire, but
changed the fuel consumption from 16.1 (imp) mpg to 15.7 mpg.
I now drive a diesel - not as fast, doesn't handle as well, but averages
47mpg and you can get wing struts inside. If you want to know why, calculate
200,000 miles @ 16 mpg X about $3.50 gallon....
Miles McC
Subject: | Wig-wag with only landing lights |
I do not plan to use taxi light(s) on my (tail wheel) RV-6,
so my panel is designed for a single switch (OFF-FLASH-LANDING).
Following the recent thread about the Gall's FS039, I ordered one. I
have an S700-2-10 switch (and two Radio Shack 30A relays if necessary),
planned for this function. I have downloaded the drawings from your
web site regarding the wigwag but I'm can't seem to integrate what I
need. I'm now questioning whether or not the 2-10 switch is suited for
my application. Your comments will be appreciated.
Tom Barnes
From: | Miller Robert <rmiller3(at)earthlink.net> |
Subject: | Re: Laptop power in the cockpit |
> I generally get about 5 hours from my Apple iBook battery.
Robert
In 1903, Sir Oliver J. Lodge and his son, Alec, patented the "spark
intensifier".
As I understand it, this technique is still used in some turbine
engine igniters.
This was studied by the Nat. Bureau of Standards during the 1920s.
They developed a set of curves to show how the use of a spark intensifier
gap would help overcome the failure of ignition due to electrical leakage at
the spark plugs.
Apparently, if the plug insulation is degraded by deposits or other
crud, then the magneto may never build up enough voltage to strike the
spark. Adding the external spark gap in series at a well insulated point in
the circuit, causes a build up in potential (from capacitance in the
insulated wiring harness?) at the gap... which "fires" and thus, also causes
enough voltage to strike an arc at the plug.
All of this described in the book, "Spark and Flames" a history
of ignition in internal combustion engines, by Crawford MacKend.
energy.
Bob . . .<<
http://www.matronics.com/browselist/aeroelectric-list
From: | "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> |
>Bob:
I think your battery is bad out of the box . . . I have had several
Pavilions and currently use the 3410 in a variety of portable
computing and data acquisition tasks. The 3410 came with a lithium
battery but it's recommended replacement from HP is a Ni-MH technology.
Many if not most line operated power supplies for laptops
run the incoming AC directly into a rectifier and couldn't
care less about frequency. Also, if the outlets are provided
for passenger use with their laptops, I wouldn't bet that
there isn't a separate, 115VAC, 60Hz power supply to these
outlets . . . the LAST thing the airline would want is
a story about having trashed a bunch of first-class
passenger's toys.
Look into a Ni-Mh drop-in replacement. If your computer is new,
they might give you this battery on warranty . . . 45 min
service life is useless.
For use on airplanes, I have a 28v to 19 volt step-down regulator
built on one of our linear dimmer frames. For 14 volt aircraft,
I use a switch-mode step-up power supply to give me the 19
volts from the aircraft power.
Couldn't tell you without seeing it.
> can I
Resistors are a bad idea but a regulator with some smarts
like
http://209.134.106.21/temp/apc15-14a.jpg
http://209.134.106.21/temp/apc15-14b.jpg
http://209.134.106.21/temp/apc15-14c.jpg
would do the job . . . or you can use switch-mode step
down regulator that would dissipate less heat and
probably be a bit smaller.
I've had some 19v rated laptops run on 12 but they
wouldn't charge the on-board battery when supplied with
12v . . . suggest one of our power conditioners
or a switch-mode step-down tailored to your task.
>Dan Eikleberry
>Las Vegas
> > marked
> > 8AWG?
>few left in a box.
Interesting! Sounds like a cut above the auto-parts-
store products. Any brand name on it? If it was a
surplus store, they'll have no idea as to orignal
source. Wouldn't mind having one to look at and
evaluate for suitability. Perhaps I can track down
the folks who make it.
Subject: | Re: AeroElectric-List Digest: 26 Msgs - 03/02/02 |
> yet.
Time to display ignorance again. Could the extra gap outside cause the
spark to occur delayed -- and possibly delayed just enough to actually
happen at a better time for the engine to actually get running?
No clue how much longer it would take for a spark to occur, but it's
just a thought.
I could easily see this with a lawn mower -- where the mower doesn't have
a delayed spark system like we have when we start our airplane engines.
Normally the spark fires something short of top dead center. But when
starting, we want the start to occur after TDC by some amount.
-Joe
Subject: | Re: Electrical System Instrumentation |
>Hi Bob,
>I am putting together a Murphy Super Rebel and am a month or so away from
>starting the Engine Installation/ Panel and Wiring. The majority of the
>panel goodies have been selected and on hand. I am trying to wrap up
>instrumentation for the 9 cyl 400 HP M-14PF Radial.
>the SR.
I highly recommend external shunt ammeters for two reasons (1) they
keep high current leads out of the cockpit and (2) they can be used
to monitor more than one current by means of an ammeter selector
switch and multiple shunts. I'd go with the Davtron but put the
shunts in each of the two alternator output leads . . . if you
have a good voltmeter then a battery ammeter is less than useful
compared to the pair of alternator loadmeter functions.
requirements
> > > I'll be
> > > offering a kit of transponder, prewired harness and
> > > ACK encoder for a package price.
> > > Bob . . .
>...and if you could sweeten the deal even more by (figuratively!) tossing
>in the com
>radio, harness, antenna & maybe even an intercom, I'll seriously consider
>sending ya
>a check- plug&play- yeah, that's the ticket!
I'll work on it. Eagerly awaiting arrival of
the first units.
Subject: | Re: Wig-wag with only landing lights |
>Bob,
I didn't like the FS039 because it had a switch on the front.
That's why my published drawings show the FS033. If I were
going to use a Galls wig-wag I'd use the 033 and wire
it per
http://209.134.106.21/articles/gallsww.pdf
. . . I've got the 039 in hand and will see if I
can deduce a way to use it but I don't recommend
it.
If you're going to have two lights, are both on
for landing?
> >If you think of an
> >until the energy is
> >spark
> energy.
I'm no electrical engineer; however, I believe that if a spark plug is
wet or fouled, there is a relatively low resistance path through the
contaminants if the voltage buildup is slow. By having an outside gap,
when the spark crosses the gap, it builds much faster than directly from
the coil. This is one of the reasons that the capacitive discharge
conversions would usually out perform the ketering (SP?) counterpart. It
just has less time to flow through the contaminants.
Dennis
Dennis Golden
Golden Consulting Services, Inc.
No brand name, not even a logo. I'm gonna send you the
one I have... To which one of your three addresses do
I ship?
wrote:
> Nuckolls, III"
> Therrien
> measured
> > > marked
> > > 8AWG?
> no 8
> it
> wire
> tinned.
> a
> >few left in a box.
> auto-parts-
> a
> down
> Bob . . .
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
>engine.
I recall my friendly local service station had a spark plug
cleaning and testing bench. One first cleaned the plug with
compressed air driven blasting compound. He then screws
the plug into a chamber with a window in it so you can
see the spark gap. A Ford buzzer-coil type ignition was
attached to the plug to spark it while pressure in the
chamber was raised with shop air. A plug that wouldn't
fire at less than 120 psi was rejected.
No magic. Look the center electrode of a new plug and you'll
see that its crown is sharp edged and flat. A worn plug
is rounded off and has no sharp edges. Sparks like to jump
from sharp edges. One could restore sharp edges on both
the center and ground electrodes with suitable tools but
the "remanufactured" plug was shorter and therefore ran
cooler than factory new specs.
When I was a kid, you could buy "remanufactured" plugs
for about 1/3rd the cost of new. Close examination would
show that they were simply cleaned and re-sharpened.
Subject: | Re: speed reduction |
>in acutation time.
Reversing the motor requires that you reverse
it's leadwires. One lead is + extend, the other is
+ retract. Regulation of voltage for the purpose
of controlling speed needs to be done before the
switch that controls direction, i.e. your
speed control needs to look like a bus having some
reduced voltage . . . it goes in the line between
the aircraft bus and the trim switch.
If 10 ohms of resistance produces a 3.0 volt drop,
then your motor is drawing 0.3 amps or 300 milliamps.
Motors used in most actuators are permanent magnet
devices who's speed is roughly proportional to applied
voltage. The motor has no way of knowing if the
voltage is reduced via resistor or adjustable regulator.
With the regulator, the voltage is constant irrespective
of motor current (changes with load on the actuator).
With a simple series resistor speed control, the
speed regulation with motor load is poor because as
the motor slows due to increasing load, the current
goes up. Voltage drop increases across the fixed
resistor causing the motor to slow down still more.
Control of trim speed is a common problem on a lot
of airplanes. The wider the speed range btween cruise
and approach to landing, the worse the problem. You want
runaway speeds to be limited in cruise so you deliberately
reduce motor supply voltage until trim action is so benign
that the pilot can perceive and react to it fast enough
to prevent problems. This makes for a system that runs
too slow during the approach phase.
To the best of my knowledge I designed the first tightly
regulated trim speed controllers for bizjets that first
flew on the Lear Model 55 prototype about 1980. The system
had two speeds, one about 4 times faster than the other
for use in takeoff/approach and cruise phases of flight.
Our soon to be offered Adjustable Power Conditioners were
fitted with two potentiometers so that one might have
independently controlled high and low speed settings.
The transfer from low to high speed operation might
be controlled by a microswitch on the flaps that select
low speed operation when flaps are fully retracted and
high speed as soon as the flaps come off the up-stop.
Without knowing about this servo (therefore excusing me from any
responsibility for my comments whatsoever), I'm wondering if perhaps pulse
width modulation is the proper way to slow this guy down?
Pulse width modulation is just another item in the
bag of tricks that allows the motor speed to be
controlled with a switch that is duty cycle
switched (that's how I did it on the Lear).
The motor doesn't care. If you need only one reduced
speed and motor current is stable, the a resistor
might do. If you need to have a stable voltage source
irrespective of motor load changes, then something
like what you are building (like our APC) works better.
If you want to close the loop on motor speed control
and hold it very constant over wide ranges of bus
voltage and motor load, then more smarts and duty
cycle switching is attractive.
The trim actuator won't care which one you use.
What about those ammeters that use a "current sense" transducer - the ones
that look like a donut that you pass the main cable through and the current
is measured indirectly via the induced magnetic field - do you have any
experience with those?
Gary Liming
> Bob,
>intensifier".
>engine igniters.
>the spark plugs.
Checked our local library online catalogs and couldn't come
up with a copy. Wasn't this the pre-cursor to the Bendix
Shower of Sparks system popular on some of bigger engines?
What have you been up to George? Haven't heard from you
in many a moon . . .
From: | "William Bernard" <billbernard(at)worldnet.att.net> |
\"Leo Dougherty\""
Subject: | Audio Flight Avionics |
Does anyone have any information about the Canadian company Audio Flight
Avionics and its product the AV-10?
I have a friend with one of these in a Glasstar. The unit worked well until
about a month ago when at least one chip went up in smoke, literally. A
replacement chip was found and installed and the unit came back to life,
but the parameters are way off. (Cylinder Head Temp is 1450 degrees sitting
in the hangar with the engine off and snow blowing around outside.)
The company is apparently no longer in existence, and to make it worse, the
identification has been ground off of all the chips except the one from
which the smoke escaped.
If there was some way to contact the maker, or to obtain service
instructions, or a detailed description of the parts used, the unit might
be salvageable.
Any help would be appreciated.
Thanks in advance
Tyndar press. Whatever that is.
Lib of Congress number 97-90492.
I don't think it really has much to do with the shower of sparks.
And it doesn't appear to have much use except as a novelty and in the noted
area of the jet engine igniter.
Also, I suspect a dual gap system would be a real joy in the RF noise
area!!!
I've been busy... see www.engineteststand.com
Very much like your mail list page. You do good work!
Subject: | Re: Pin numbers of S700-2-10 on Z-23 & Z-24 |
>Bob,
Good eye. I thought I'd caught all those. Numbering shown
in figures Z-23 and Z-24 are incorrect. I got wrapped around
a manufacturing differences axle a few years ago when I discovered
that my S700-2-10 switches were assembled opposite the Microswitch
equivalents. Note the view of switch in Figure 11-11 versus
switch view in Z-16. The columns are switched. Figure 11-11 is
Microswitch; figure Z-16 is S700-2-10. I had published some
variations on switch terminal numbering based on switches I
was holding in my hand at the time not realizing there were
two configurations. Sooooo . . . you've found a couple of
artifacts in my wiring symbols that represent confusing
times.
I determined that the schematics could be left constant
with respect to terminal numbers if I simply pointed out
the difference between the two switches. I illustrated
the S700-2-10 right on the drawing. The Microswitch product
has reversed column numbers molded into the plastic
switch housing.
I've marked the switches in Figures Z-23/24 for correction.
Thanks!
Regarding whether one or two lights are lit for landing, without
any other input, I suppose my answer would be to use two lights. Is
there something to be gained by using just one? I have cut only one
wing for the light at this point. If it wasn't for the fact that my
panel has been engraved for the "FLASH", I'd consider just the one light
but now, the panel plus the safety issue of the wigwag, I prefer to cut
the other hole and have two lights. What are your thoughts?
Tom
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
Subject: Re: AeroElectric-List: Wig-wag with only landing lights
>Bob,
RV-6,
it per
it.
for landing?
>I ship?
Three? I've got only one. 6936 Bainbridge Road,
Wichita, KS 67226-1008. Where did you see two
others? My website front page? Those three in
the yellow box are companies often mistaken for
me . . . my address is in the upper right corner
of the page.
I appreciate your effort on this. It would be
nice to identify a source for inclusion in
our website catalog. I'll return the sample
to you after I've had a chance to look at it.
>area!!!
Searched for the publisher and didn't turn up anything.
Could you photocopy a few pages of description and any
figures that come with it? I'd like to see it.
Damn George, you got more expensive toys than I do! As
you well know, it takes good and sometimes expensive
toys to do the best work. How far is your facility
from the Ada airport?
Thank you sir!
>Bob,
Those are hall effect transducers. These are described in
the book on page 7-15. They work fine. Rocky Mountain and
others use them for current measurement. They're electronic
devices with some drift and calibration issues. They're also
not as rugged as a shunt. I use them routinely for flight
test instrumentation where I can push a pin out of a plug,
run the wire through the sensor and put the pin back in the
plug.
Here's a link to a company that makes several sizes that
I keep handy for my quick-n-dirty instrumentation
tasks:
http://www.west.net/~escor/
Sure,
Want a fax or scanned images ?
Our facility is .... ON the Ada, Airport. About 150 yards SW of the gas
pumps. Two hangars -- Hangar "A" and a big WWII Quonset hangar with the
Carl Goulet Memorial Engine Test Stand next to it.
Come down anytime. Would love to show you around. I think you would find
the engine instrumentation for the test stand to be fascinating. One can
learn more about an internal combustion engine in an hour sitting there,
watching the computer screen as the engine is put through its paces, than in
half a lifetime doing anything else.
Any time. Weekends are fine, I'm almost always here. Call ahead.
Regards, George
From: Robert L. Nuckolls, III [mailto:nuckolls(at)kscable.com]
Subject: AeroElectric-List: RE: Ignition -
>area!!!
Thank you sir!
I'm not going to have a vacuum pump. That means I could install an SD-8
Alternator right? Since you've raised the issue, assuming that's what you
meant, I can't get real excited about it. Let me tell you why and you make
my day and tell me where I'm wrong. It's another piece of hardware to
maintain/malfunction, it has weight, and isn't cheap ($430 + $65 for ov
protection).
You wrote on the list on 2/24 that the SD-8 "comes with a regulator that
needs a
battery but it may be possible to build one that isn't". Also, "hard to
controll output efficiently and power generation not efficient". I don't
get a warm a feeling from that. Seems to me, if I wanted more
reliability, it would be easier, cheaper, possibe? to install a second
battery. Besides,
did I mention I am using a B&C L-40 Alternator and regulator which is bullet
proof and most likely will never fail. Where have I gone wrong?
Rick Fogerson
RV3 fuselage soon
Boise, ID
down
EI's,
> >time.
> exactly
small
> >cover it?
> I think so
> Bob . . .
From: | "Don Eaves" <doneaves(at)midsouth.rr.com> |
Subject: | Re: Audio Flight Avionics |
Try this email address:
afatechsupport(at)home.com
His name is Peter Rummell
Don Eaves
----- Original Message -----
From: "William Bernard" <billbernard(at)worldnet.att.net>
Subject: AeroElectric-List: Audio Flight Avionics
until
sitting
the
> be salvageable.
> Thanks in advance
Also Try this email address: wedgie(at)interlog.com
Don Eaves
until
sitting
the
> be salvageable.
> Thanks in advance
From: | "Annette Coulter" <coulter(at)alaska.net> |
> > folks want.
> (Yep, your parts count just went way up, too.)
> -Matt
Matt -
I think so to. I have been watching this thread and I suspect that lowering
the voltage on a shunt dc motor just lowers the available torque - doesn't
necessarily change the unloaded speed. The only speed drop one gets is from
the reduced available torque. PM field dc motors look like a shunt dc motor
with a fixed field voltage (also current and flux). As I recall, changing
the speed on a requires a change in the field - which one can't do with a PM
field. So the only way to lower the speed and keep the torque up is to use
a PWM power supply.
Don't hold me to this cause I have not yet done my homework and I don't deal
with dc motor very often. Next week i'll be at work and will dig out some
references.
carl
Bob and Dan,
I have personal experience using the 115 V 400 Hz power in Boeing and
Douglas airplanes. I have never seen a problem. These outlets aren't
normally supplied to passengers, but the crew routinely use them to run
and/or charge their various electronics including laptops. I have used it
myself on 3 or 4 different computers with no ill effect.
Russ Werner
Maui
Wow,
Proves it - if you are patient (wait 50 years), and ask questions and listen
to others, you can eventually get answers to some of life's interesting
questions. Thanks, Bob. Even though it started off talking about lawn
mower engines, this has been a fun "thread".
David Carter
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com>
Subject: AeroElectric-List: Re: spark ign. question
compression
> >engine.
10,000
> Bob . . .
Subject: | Re: Where can I get |
In a message dated 2/24/02 8:55:05 PM Eastern Standard Time,
khorton(at)cyberus.ca writes:
> I've just installed a Grand Rapids EIS 4000 engine monitor. They
> provide Fast-Ons to connect the EGT and CHT thermocouples to the
> wires going into the monitor. The wires to the monitor are
> theromcouple wire, matching the wire coming from the thermocouples.
> Why are Fast-Ons a bad idea? Does a bit of corrosion at the
> interface between the male and female Fast-Ons eventually screw up
> the accuracy?
> What should be used instead of Fast-Ons? I'd like something that is
> removable, so I can simply unplug rather than pulling the probes if
> I ever need to pull the engine.
> Thanks,
> Kevin Horton
I guess I missed your reply to Kevin's question. Could you repeat your
answer?
Dale Ensing
Subject: | Guitar switch suitable for electric flaps ? |
Hi Bob and all,
What would you think of the use of a 5 position lever rotary switch for our
electric flaps motors ?
The setups I've seen use conventionnal rotary switches and a cranked lever
on the shaft to provide a positive locking effect for each flap position.
Nevertheless the whole device is rather bulky behind the panel.
Any advice about using a switch such as this one ?
http://www.electro-nc.com/e2_m.pdf
Any suggestions ?
Thank you
Gilles
France
I'm looking for a source of relays similar to the S704-1 sold by on Bob's
web site. See:
http://www.aeroelectric.com/Catalog/switch/switch.html#s704-1
I'm looking for a couple of 12v, 4 amp relays that use Fast-On tabs. I
need one that is normally open, single pole, and one that is normally
closed, double pole.
I've searched a few web sites, but haven't found anything similar. Can
anyone point me at a vendor?
Kevin Horton RV-8 (engine installation & electrics)
khorton(at)cyberus.ca (613) 821-7862 (home)
Ottawa, Canada (613) 952-4319 (work)
http://eccentrix.com/misc/rv8/
Subject: | Re: relay source? |
>web site. See:
The S704 has normally closed contact so it can be used
as a normally closed. Radio Shack's 900-2394 is a similar
product.
I'm not aware of any double pole products in this type
of package.
If all you need is 4A, take a look at Radio Shack's 275-214
(4PDT - 5A) and 275-218 (DPDT - 10A) products. These may
have extra poles for your task but they are easily ignored.
These have tabs that can probably be wired using narrow fast-ons.
I'd have to measure the tabs to be sure.
>Sure,
Okay. Need to get my yearly trek to George and Becki Orndorff's hangar
scheduled. If I recall correctly, you're only about 35 miles off
of I35. We'll drive to the seminar presentation. I've also got a
flying trip to Orndorff's in the works. Either one might be
an opportunity to stop by. We'll see what works.
Subject: | RE: George Braly - Ignition info from book |
>Sure,
Opps. . . forgot this in earlier post. Let's see
how faxes come through. 316.685.8617
Subject: | Re: Guitar switch suitable for electric flaps ? |
><Gilles.Thesee@ac-grenoble.fr>
> Hi Bob and all,
I presume you're interested in having the switch
provide input for 5 positions of flaps. Cessna
did the most practical "servoed" flap control
system for small aircraft.
They rigged a Bowden control cable between the
flap mechanism and the flap switch assembly.
Microswitches that operate the flap motor are
mounted on a plate that is rotated under a
cam that's operated by the flap control
handle.
Moving the handle would depress one of the
two switches which causes the flap motor to
run. As the flap moves, the switch plate
is moved to follow the command cam until
the operated switch is released and the flaps
stop.
This arrangement gives you basically infinite
number of flap positions although the
handle is fitted with a couple or three
detents.
See if you can find a Cessna single engine
airplane fitted with this system. A local
maintenance shop should be able to show you
a parts catalog and maintenance manual description
of the system.
The switch you've cited COULD be used as
you suggest but it takes some intervening
electronics to make it work.
Most flap systems are so benign with respect to
effect and handling qualities that the notion
of more than up, half, down positions doesn't
seem very useful. The nice thing about a totally
manual system with a spring loaded, center off
switch is that you still have infinite number of
flap positions and a reliable, SIMPLE, low parts
count system.
From: | "Richard D. Fogerson" <rickf(at)velocitus.net> |
Subject: | AFP Fuel Injection Boost Pump |
A couple of questions Bob,
I was talking to AFP today and they recommend a 10 amp fuse and 20 AWG
for their FI boost pump because it has a 7 amp surge at start and a 5
amp continuous power requirement. Your Z11 has 3 amp and 22 AWG. Sould
I upgrade this to 7 and 20?
Also, I want to put either a 3 amp CB switch or a toggle switch
someplace hidden to prevent engine start, say on the line between the
Battery Contactor solenoid terminal and the Battery/Alternator Master
Switch. What do you think of location and switch preference?
Thanks, Rick Fogerson
RV3 Fuselage
Boise, ID
Subject: | Re: motor speed control |
> > > folks want.
> > -Matt
>Matt -
>a PWM power supply.
A PM or (shunt wound motor with fixed field) is very sensitive to
applied voltage . . . in fact, motor speed is almost directly
proportional to applied voltage. If you'd like to dig into
the details of motor performance, here is one of dozens of
good links on the subjet;
http://www.pittmannet.com/pdf/220000ALL.pdf
Torque is directly proportional to armature current.
Armature current is equal to applied voltage minus
counter emf (directly proportional to speed) divided
by motor resistance . . . usually a very low number.
A pm motor has an counter emf constant, let's say
our sample motor is 4 volts per thousand RPM. Let's
assume further that the motor has an resistance
of .5 ohms. Sooooo . . . if we lock the shaft
(zero rpm) and put 14 volts to the motor, we
can expect a stall current of 14/0.5 or 28
amps. This would also be very close to the
inrush current for getting this motor started.
Okay, turn the shaft loose and let's suppose
we measure a no-load current of 1.0 amp.
We know that 1 amp drops 0.5 volt across the
internal resistance so counter-emf must
be 13.5 volts. The no load speed is, therefore,
13.5/4 = 3.375 KRPM. Now, let's have our
motor drive the flaps down and we measure
a max current of say 6 amps. Okay, 6A times
0.5 ohms says counter emf is now 14 - 3 or
11 volts. 11/4 = 2.75 KRPM.
Now, let's drop the bus to 10 volts. The flaps
are going to take the same TORQUE to lower
irrespective of how fast you drive them. So,
to maintain the same current (and 3.0
volts of I*R drop) the counter emf MUST
drop to 10 - 3 or 7.0 volts. The new
flap motor speed is 7/4 = 1.75 KRPM.
The motor is doing the same work but at
1.75/2.75 = 63% of the full bus voltage
speed. Want a motor that has better speed
regulation? Try the same calculations using
0.2 ohms resistance with the same counter
emf factor.
Bottom line is that a motor's speed can be
controlled by ANY means that adjusts it's
perceived applied voltage. Duty cycle
(or pulse width modulation) switching
is no different than turning down the
knob on a power supply.
Subject: | Instrument Lighting |
Is there a preferred architecture for instrument lighting?
In a given panel, there may be a combination of many small incandescent
lamps in instruments while for those without internal lamps, there are
several alternatives such as post lights or even inserts between the
instrument and the panel. In addition, modern avionics such as UPS and
Garmin have dimmer imput that apparently monitors the dimmer buss and
responds as the voltage of the buss is changed. These units are
programmable for the "offset" and "slope" of the response.
There may be as many as twenty or more lamps and/or dimmer accesses that
could be in parallel.
Among the questions I have are:
1. Should these all be in parallel with the wiring protected by a single
fuse, loosing all if a short occurs in one and the problem of
troubleshooting to isolate the offending circuit. Or should they each be
fused , a cumbersome prospect: or possibly use in-line fuses on each?
Or, should some sort of priority "zoning" be used with each zone having
its own fuse?
2. The other aspect of all these lights is the physical connection of
all the wires or zoned paralleling of wires. I can imagine using many
butt splices and bundling leads from nearby instruments and tying
together the butt splices and eventually arriving at the buss.
I would appreciate your objective views on how to approach this.
Thanks in advance,
Richard Dudley
-6A finishing
N331RD (reserved)
Subject: | another spark ign. question |
Thanks for all the emails about my spark gap question!!
Really great stuff. I understand it much better now.
Here is another question that probably has a more
obvious answer I have wondered about for a while.
You get a spark when the points open and the magnetic
field collapses due to the magnetic lines of force moving
through the secondary coil.
So why don't you also get a spark when the points first
close and the magnetic field is forming. It seems like
it should be moving through the secondary at this time
also only the other way ..expanding?
Subject: | Re: another spark ign. question |
**** Well, you do. But it's not as strong. The voltage induced in
a coil is proportional to the rate of change of the magnetic flux. And
the flux collapses faster than it builds.
Not only that, but the voltage pulse on point *making* is the opposite
polarity from the pulse when the *break*. And the sparkplug is constructed
to prefer the breaking polarity.
Huh? What difference does it make to the plug what polarity the voltage
is? Well, it turns out that it's easier to pull electrons off something
sharp and pointy than off something broad and rounded. In fact, it's
possible to use a spark gap as a RECTIFIER for high voltage AC.
Back in my misspent youth, I had access to a neat book called "The Boy
Electrician" or somesuch. One project in "The Boy Electrician" was to build
a Geiger counter. ( I think the book dated from the 50's, and there was
some interest in atomic energy at that time ). The Geiger tube required
a source of high voltage DC, which was ( as I remember ) supplied by a Model
T spark coil feeding an adjustable spark gap with one pointy electrode, and
one round electrode. The gap would spark only when the pointy electrode was
negative.
( The same book showed how to make an Xray tube, which I assume could
supply atomic radiation to be counted by the Geiger counter. Scary stuff,
from a modern prospective ).
Bob, thank you for yor response.
Objet : AeroElectric-List: Re: Guitar switch suitable for electric flaps ?
In fact, what we'd like is "up", "takeoff", "normal landing" and "short
landing". The double slotted fowler flaps are very powerful past the 35/40
down position. Very steep approaches are possible with the "full down"
position.
> detents.
The Cessna arrangement is nice and simple , but the kit manufacturer
supplies the servo device with a linear pot and limit switches as a
standard.
> count system.
Agreed. In a next project, I'll consider using this type of setup or maybe
the Cessna device. What we like with the fixed position system is the
"switch and forget" functionnality.
Thanks for your advice,
Gilles
France
>standard.
If the feedback potentiometer is built in, then
the hardest part of a servoed flap system
is done. Did they include any kind
of sample electronics?
Further, if you go automatic servo positioning,
have you considered the hazards for electronics
failure where you get un-commanded flap motion?
You might want to consider two switches. One
to drive flaps up and down with center being
spring loaded off. Then a second switch to
select the three flap extension positions. The
servo amplifier would be active only in the
extend operation causing flaps to stop at the
desired location while holding the command
switch down. Holding the command switch up
will simply drive flaps to their full up position.
This system would be incapable of simple electronics
failure that would produce un-commanded motion.
Also, the Cessna style mechanical feedback could
still be applicable to your project . . . the
potentiometer would still be used to drive
a flap position indicator.
Reactive components like inductors and capacitors
have dynamic time constants described by:
T = RC for capacitance and T = L/R for inductance.
When the points open in an ignition coil, R is infinite
(paralleled by the capacitor across the points) so the
coil field collapses at a rate determined by the resonant
frequency of the coil/capacitor combination which is
F = 1 / (2*pi*squareroot(LC)). When the points close,
there is a dead short across the capacitor and the source
impdedance of the charging current is low. Here the
T=L/R time constant prevails wherein T is very long
compared to the points open model. Voltage output from
the coil in this phase is quite low . . . probably too
weak to establish any kind of arc
From: | "Piers Herbert" <piers.herbert(at)ntlworld.com> |
Garry K was kind enough to send me a copy of the flap control schematic by
Mike Palmer which appeared in the December 1999 Kitplanes magazine.
This scheme uses a linear pot and a LM324 (quad op amp chip). However I
decided this was unsuitable for flap control on the grounds of its active
failure modes.
Any of several wires loose could result in uncommanded travel.
This is also a potential problem with a stick grip flap or trim control
scheme if the relays are controlled via the ground side. A chaffed wire
could cause uncommanded travel.
I have a diagram for the three position system used on the Scottish Aviation
Bulldog. This uses four microswitches operated progressively by a cam. Two
switches are required to define the intermediate position with a small dead
band between them. As far as I can see this scheme has no active failure
modes. Any wire loose or chaffed would not cause uncommanded travel. The
relays are controlled via the positive side. As the scheme stands it has has
only the one breaker. Therefore thicker wire would have to be used
throughout. I could use thinner wire for the control part if the cirucit if
this part of the circuit was supplied via its own fuse. The scheme also
specifies two four pole dual throw relays, using two poles in each relay for
the motor reversing circuit and also feding each relay coil via a NC pole on
the other relay. I do not understand why it was done this way since the
motor reversing circuit can be done with one pole (dual throw) per relay so
you would need two poles per relay at most.
For three positions I could use a 2-10 toggle switch. I suppose you could
extend this scheme to four positions with the guitar switch but that would
require six microswitches.
Piers.
Subject: | LR3B-14 Voltage Reg Function |
In a message dated 02/22/2002 2:52:43 AM Eastern Standard Time, "Robert L.
Nuckolls, III" writes:
>.....skip..... one of the requirements I had for configuring the output
>stage was that the warning lamp should illuminate IF power were entirely
>removed from the regulator.....skip......
In a message dated 02/28/2002 "Robert L.
> No, it should be on steady . . . and probably dimmer than
> normal brightness but it doesn't flash.
3/5/2002
Hello Bob, Can I please have another bite at this apple? I agree with the
above with some clarification / amplification and then a comment and two
questions:
Clarification:
1) With bus voltage above the level at which the LVWL would be activated:
2) If electrical power is removed from pin 3 of the regulator, but continues
to be provided to pin 6 via the alternator switch and alternator circuit
breaker the LVWL will flash at its normal brightness.
3) If electrical power is removed from both pin 3 and pin 6 the LVWL will
burn steadily at a dim level. (As you say above).
3) above by the opening of the CB feeding pin 3 and that same CB is being
used to provide power to the LVWL then the light will not illuminate in any
fashion and no warning will be given.
Question: Does it not make sense then that if one wants to take advantage of
the warning capabilities of the regulator in instances 2) and 3) above that
one should power the LVWL from a CB other than the CB feeding bus voltage
sense to pin 3?
Yet your diagrams and the instructions from B&C provided with the LR3B-14 say
to use the same CB for both the LVWL and feeding pin 3.
Question: Can you explain?
Many thanks.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
Subject: | Re: Instrument Lighting |
>Bob,
My least favorite task on the GP-180 program at Learjet
was to architecture the panel dimming control system. The
airplane had a broad mix of incandescent, plasma, led,
fluorescent, and EL lighting on the panel.
Pilots who fly $multimillion$ airplanes like all the
illumination to move up and down together on whatever
control is used to set intensity. The end result for
that airplane was a couple of dimming controllers with
individual, programmable outputs that could be tailored
to the lighting technology they powered. These things
cost over $1500 each in 1983.
I advise builders to make space for at least 4 dimmer
potentiometers in their panel. At the outset, install
only one and hook all the dimming loads to a single
dimmer.
It will be months after the airplane flies that you
will begin to have a sense of what lighted items need
different or special attention. If you need to add
more controls, you'll be able to do it in a manner
that makes them look like they belong there. If you
carve your dimmer panel into stone and need to add
controls later . . . well . . .
The alternative is to spend a LOT of time with a
blackout blanket over the canopy working on the dimming
system in the shop . . . If it were my airplane,
I'd concentrate on getting it flying. Save the
enhancements for winter time projects when you
can't fly much anyhow.
>its own fuse?
This isn't done . . . common shorts during production
caused a LOT of damage to dimmers at Beechcraft on the Bonanza
and Baron lines about 25 years ago. I designed a short-proof
dimmer that would simply shut down when overloaded. Once all
the shorts are fixed, the dimmer would operate normally.
Our dimmers are similarly short proof.
You can use a D-sub connector to build a minibus immediately
adjacent to the instruments being lighted. Fixture wires can
be brought to this common point close by the instruments so that
an array of many lights can be neatly wired and powered through
a single dimmed power and ground wire running from the panel
to the dimmer. See:
http://209.134.106.21/articles/minibus/minibus.html
*** The GNS430 is programmable for either following a lighting buss, or
working off a photocell in its faceplate. In my Sundowner, I was unable
to make it do anything sensible in terms of following the dimmer bus.
Here's the deal: during the day, you want the radio at full brightness,
otherwise you can't see it. You don't care about the rest of the lamps.
During the night, you want the radio's brightness set way down, outherwise
it overpowers the rest of the panel - not to mention your own night vision.
But you want the rest of the lights set to some reasonable brightness.
The radio almost wants to be "brightness inverted" with respect to all
the instruments, post lights, etc. I punted and set it to work off its
photocell. But I think it really deserves its own brightness pot. Phew,
I'd have to do a 337, get a field approval, and modify the FMS for the
radio.... Hmm, what if I mounted a post light next to the photocell? :)
Subject: | Re: LR3B-14 Voltage Reg Function |
>3/5/2002
>questions:
>Clarification:
>sense to pin 3?
Power to pin 3 is just a sense lead and has very little
current flowing in it . . . a few tens of milliamps as
I recall. Likelihood of this breaker/fuse opening is
very remote. Mechanical failure of some kind is the
most probable cause. If this concerns you, you can move + source
for the lamp to any other handy point.
Just a question about how your dimmers work in terms of dissipating
power. What exactly does the heat sink do? Is it dissipating extra
energy when the dimmer is turned down, or up?? (excuse my excessive
ignorance...) One of the things I'm wondering on the subject of panel
dimming is do I need a panel lights On/Off switch (more clutter and an
extra failure point) or can I just wire up the dimmer to the lights and
during the day turn the dimmer all the way down to minimize power draw
from it?
--Mark Navratil
Cedar Rapids, Iowa
RV-8A finish kit stuff...
----- Message d'origine -----
De : "Robert L. Nuckolls, III"
Envoy : mardi 5 mars 2002 14:32
Bob and Piers,
Thank you for your messages.
Now I realize I have to dig deeper into that servo system before making
decisions.
We'll call the kit manufacturer to get thir schematics.
thanks again,
Gilles
Subject: | Re: dimmer question |
>Bob,
>from it?
In the early days of panel illumination, power to the
lamps was controlled by simple rheostat . . . a panel
mounted, knob adjustable power resistor. Full clockwise
rotation reduced the resistance to zero and the lamps
were fully illuminated. Rotation CCW increased resistance
and intensity goes down. Simple and at that time, not
terribly expensive because rheostats were common catalog
items in many sizes.
The problem with rheostats are several fold. First, they
DO get hot . . . energy that is not fed to lamps is used
up in the rheostat and shed in the form of heat. The
rheostat's total resistance needed to be adjusted to
accommodate the number of lamps in the circuit. Often,
there was no ideal catalog item so compromises were
made in performance. In some cases, aircraft companies
designed and ordered special rheostats with features
not available off-the-shelf. The price went up.
The dimmers we sell are "smart rheostats" . . . they
still dump off unneeded eneregy in the form of heat.
However, instead of being constant resistance devices
they are constant voltage devices with the smarts to
hold output constant based on control knob position
and irrespective of bus voltage fluctuations. Anohter
advantage of the current design is that heat is
dumped off remote from the panel control. Further,
the panel control can now be a miniature potentiometer
. . . much more panel friendly.
I recall riding in a Cessna 310 one night where the
panel around two dimmer rheostats (each about 3" in
diameter and 1.5" deep behind panel) ran so hot that
you could not hold your finger on the panel material
around the knob. The two rheostats used up about
20 square inches of panel space . . . now we can put
each control pot in less than 1 square inch of space
and heat comes off the panel.
When the lamps are turned all the way up, very little
power is dissipated in the dimmer assembly (max amps
times about 1 volt drop = low watts). When the lamps are
turned all the way down we have a little more energy
dumped (minimum amps times 10 volts of drop = a bit
more power). Maximum heat is generated when the lamps
are at some medium intensity where there is significant
current at about 7-8 volts of drop = most watts).
The dimmers we sell are designed to stop dimming when
the lamps are just above dull red glow . . . and
emitting least usable amount of light. This happens
at about 4 volts. If we took the control all the way
down to minimum for the dimmer regulator, there would
a significant amount of control rotation that produced
no visible changes in light output . . . poor design.
The power consumed by the dimmer system at minimum
intensity is very small compared to the output of
your alternator. Life of bulbs at 4 volts is measured
in centuries . . . so adding a switch to control them
is of no practical benefit.
Having said all that, it's important to note that even
at minimum intensity operation, your full up a Christmas
display of panel lighting can be large compared to the
energy it takes to run really useful things like radios.
This is why we recommend the e-bus be loaded with
single lamp illumination sources like our map light
or a single flood lamp in the overhead. It's possible
to SEE quite well with very little energy devoted to
panel illumination.
Subject: | Re: Guitar switch suitable for electric |
flaps ?
>Bob and Piers,
>decisions.
>thanks again,
>Gilles
Could you ask them to fax a copy to me too? 316.685.8617
If we're all looking at the same piece of paper, we're in
a better position to evaluate the design.
Subject: | Re: AFP Fuel Injection Boost Pump |
10A fuse is inappropriate for 20AWG wire . . your suggestion
for 7A fuse and 20AWG is well considered.
This has been well thrashed on the list with perhaps
a half dozen "solutions" offered and considered.
My personal opinion is that most of our fears in
this regard are ill-founded. In most cases where
security is required (like an air show flight line)
you may well be required to unhook a battery terminal.
Anything you want to do to is probably as useful
as anything suggested here on the list.
Subject: | Re: Guitar switch suitable for electric flaps |
> >Bob and Piers,
> >decisions.
> >thanks again,
> >Gilles
> Bob . . .
Will do.
Gilles
Subject: | Vans tach sender |
Anybody know how Vans tach sender works (the one that plugs into the tach drive
on the accessory case and is then wired up to their tach gauge)? I'm wondering
if it is a frequency generator of some sort that might be compatible with the
Grand Rapids EIS 4000 engine monitor (which is designed to pick up pulses from
a mag P lead). I asked Vans about it and haven't received any response.
I'd rather use a pickup off the tach drive so that I don't have to depend on one
ignition source or the other to get rpm (or use a switch between the two mags
when doing a mag check).
--Mark Navratil
Cedar Rapids, Iowa
Subject: | 115V 400Hz power |
on 3/5/02 02:51, AeroElectric-List Digest Server at
aeroelectric-list-digest(at)matronics.com wrote:
> From: "Russ Werner" <russ(at)maui.net>
> Subject: Re: AeroElectric-List: Re: Laptop power in the cockpit
> Bob and Dan,
> Russ Werner
> Maui
When Airbus discovered that flight crews and others (i.e. pax in the
washrooms) were using these plugs for laptop computers, they issued a 'Do
not do this' bulletin, citing dangers of overheating, fire and explosion of
the battery chargers/converters due to the difference in Hz. I'm not an
expert in this stuff at all, so I just pass it on as food for thought.
Grant
Subject: | Re: 115V 400Hz power |
*** You're probably getting away with it because of the current design of
computer power adaptors: they don't have 60Hz power transformers anymore.
Instead, they rectify the AC and use it to drive a high-frequency
oscillator. The output of the oscillator is goes through a toroidal
transformer ( which can be small & light because of the high frequency ).
The intent is to make the supplies small and light. The side effect is to
make the 400 Hz not matter.
Subject: | Avionics cooling requirements |
I have a Garmin GNS430 and GTX327 which each has a nipple
for air, which leads me to think maybe it is required. (Above the 430 is
a small audio panel). For the sake of argument, let's say I want to
ALWAYS have a fan ON when the avionics are ON. Two questions: 1) how
much volume is needed and can volume be translated to electrical power?
2) Does it matter if the volume is forced in, or pulled out (suction)?
If suction would work, I would want to use the exhaust in
place of a windshield defroster blower; see any problems with this? I
live in the North, but have to plan for some trips to Texas and Florida.
I will appreciate your comments.
Tom Barnes -6 electrical
Subject: | Re: Avionics cooling requirements |
I have the GNS 430 and a King KT-76C transponder that require air cooling. I
have installed the Ameri-KingAK-920 cooling fan. It comes on with the
avionics switch and has worked great for the last 2 yrs. I live in Florida
and would not be without some source of cooling.
Robert, did you get the fax on the spark "enhancer" ?
>area!!!
Thank you sir!
system
>protection).
Yeah but it weighs only 3.5#, has a very long life. If you have an
electrically dependent engine, I'd rather have two alternators
than two batteries . . especially if they are B&C alternators.
A second 17 a.h. battery weighs 15+ pounds and needs periodic
replacement. The second alternation weighs 1/5 that of the battery
and will run gizmos to the tune of it's full output as long as
the engine is turning.
>needs a
>battery.
Cheaper initially . . . but I think the cost of ownership
over 5-10 years is lower and the airplane is 12# lighter.
03/07/2002 08:35:48 AM
Bob: I have a V166 Ford regulator. I also have a 60 amp alternator
from Mark L. There are three wires coming out of the reg.
1) field
2) ground
3) staitor
Do I use the staitor wire? I have the connectors A & S on the reg.
tied together with the positive side of the crowbar to my
master/battery switch. I know the f term on the reg is for the field.
The ground will go to the engine ground.
Also I'm planning on using #4 welding cable for my battery
connections ( from B&C). Is this alright or should I be using #2
BRUCE UVANNI
RV6A FWF / Panel
BUVANNI(at)US.IBM.COM
PHONE: (802) 769-2822
Subject: | Re: Ford Regulator |
>1) field
>2) ground
>3) staitor
The "S" terminal is one of the power input pins to the
regulator and needs to be jumpered to the "A" terminal.
Ground is make to the regulator's case. Mount the regulator on
the firewall and this connnection is covered. "F" does
indeed go to the alternator's field terminal. See
Figure Z-23 of
http://209.134.106.21/articles/Rev9/ch10-9.pdf
If your battery is in front of the airplane, #4 will
suffice for all fat wires. If your battery is behind the
seat, use 2AWG to bring the heavy current forward . . .
#4 soft jumpers are still fine for the battery connnections.
Yes. Thank you. I've .pdf'd the pertinent pages and
I'm going to publish them for enlightenment of the
group. I STILL don't understand the physics of what's
happening.
Subject: | Re: Ford Regulator -OOPS! WRONG LINK |
> >1) field
> >2) ground
> >3) staitor
> Figure Z-23 of
Sorry 'bout that. Clicked on the wrong link to
paste to my last reply. The REAL link is:
http://209.134.106.21/articles/Rev10/z10.pdf
Subject: | Re: Vans tach sender |
>drive on the accessory case and is then wired up to their tach
>gauge)? I'm wondering if it is a frequency generator of some sort that
>might be compatible with the Grand Rapids EIS 4000 engine monitor (which
>is designed to pick up pulses from a mag P lead). I asked Vans about it
>and haven't received any response. I'd rather use a pickup off the tach
>drive so that I don't have to depend on one ignition source or the other
>to get rpm (or use a switch between the two mags when doing a mag check).
It's probably specific to the instrument that uses
it's signal. I've designed several variations on this
same theme that are in no way interchangeable with each
other. It MIGHT work but you'd have to have some detailed
design from both companies to see if you can do some
practical interface . . . but odds are against you.
Why not "depend" on a single source? In the relatively
rare case that the single mag driving the monitor
fails or needs to be shut off . . . how does this
affect your probability of comfortable termination
of that flight? Tachometers are among the least
useful instruments on the panel and wings don't
fall off if the tach craps.
Subject: | Airline power sources |
LONG message about Airline Power Sources!
OK... I thought we were finished with the topic of airline cockpit power
sources, computers, GPS, and other things that pilots like to plug in... .
but apparently not! (Fine with me, because I never got a satisfactory answer
to my original questions anyway!)
Russ Werner of Maui writes: <<< I have personal experience using the 115 V
400 Hz power in Boeing and Douglas airplanes. I have never seen a problem.
These outlets aren't normally supplied to passengers, but the crew routinely
use them to run and/or charge their various electronics including laptops. I
have used it myself on 3 or 4 different computers with no ill effect.>>>
My comment: Glad to hear it, Russ. But... I distinctly remember from my
USAF days during the Viet Nam war that we were all warned not to plug normal
115v devices into aircraft 400hz outlets, even though they 'looked' like a
house outlet, because 400 hz would 'fry' most anything not built for it. In
particular, they showed us photos of those rechargeable flashlights all
pilots were buying at the time, (white, rectangular case, about 5 inches
long, had both a red and a white bulb in the end, little reversible 115v plug
used for recharging the ni-cad battery inside). Pilots, especially on
C-130s, would try to recharge them using 400 hz outlets -- with disastrous
results. The photos showed how this action resulted in melted flashlights at
best, and I think an inflight fire at worst.
Therefore, I'm quite leary of using most 115v 60hz devices in a cockpit,
but do understand that most of the modern day computer power adapters have
been built with the flexibility to handle almost anything. I know the modern
Sony and HP laptops come with a power adapter that is labled to handle
100v-250v, 50/60 hz input. That's a wide variety, and to think no matter
what, it puts out 19 volts for your laptop! But.... it didn't say 50-400hz.
I wish it would. I'd feel more comfortable.
Jerry Kaidor writes: <<< You're probably getting away with it because of
the current design of computer power adaptors: they don't have 60Hz power
transformers anymore. Instead, they rectify the AC and use it to drive a
high-frequency oscillator. The output of the oscillator is goes through a
toroidal transformer ( which can be small & light because of the high
frequency ). The intent is to make the supplies small and light. The side
effect is to make the 400 Hz not matter.>>>
OK... So this is lighter (and more adaptable) than a heavy wire-wound
transformer /rectifier in the first place! At least I feel more comfortable
using one of these modern laptop power supplies on 400 hz input! But I'd
like to use someone else's, not my own!
Grant Corriveau wrote: <<>>
Well, I'm certainly not an expert on this either, just looking for good
advice, but I am an airline Captain for a 'major airline' (can't really say
the name, but it begins with a big letter "U" and has been associated with
phrases like "friendly skies" and "Rising" which meant absolutely nothing to
anyone, so they dropped it and we currently have no catchy phrase, motto, or
brand association).
As for outlets, my airline no longer has any working 115v 60hz outlets in
the lavatories that I'm aware of. Those that remain have been deactivated,
whether they are labled that way or not. Even the new Boeing 777 HAS a nice
power supply that creates 115v 60 Hz located behind every lavatory mirror
(yeah, you can take a peek -- theres a secret button you push up, loacted
just under the mirror / paper towel dispenser), but my airline chose not to
have the outlets installed in the mirror base. The power goes to a dead end.
But.. you WILL find a 115v 400 hz outlet in darn near EVERY airliner
somewhere near door 1L (one, Left). Look around. Its usually near the floor
sometimes on the door frame, sometimes below the flight attendant jumpseat,
sometimes in the galley. The purpose of this is to provide power for certain
tools used during interior installation, or for certain Boeing test
equipment, (the outlet in the cockpit is primarily for this purpose); or more
common... the purpose in the cabin is to provide power for specially built
vacuum cleaners designed to operate on 115v 400hz. You don't see these very
often these days... The last one's I saw were in Hong Kong. Airline carpets
in the USA are filthy these days...
I have seen passengers try to plug their computers into these cabin
utility 400hz outlets. Usually, the flight attendants discourage them, but
on long flights (say 14 hours to Sydney or Hong Kong), some passengers talk
their way into using them. I've also seen passengers leave computers plugged
into the 'shaver outlets' in the lavatories, back when they used to work.
I'm not sure those outlets had the current flow ability to charge a computer,
however. What uses more... a shaver or a computer power supply?
Most of those outlets don't really look like a house outlet-- the aircraft
version is a rounded outlet, and I think the intent is you plug in and rotate
the plug a tiny bit to the right to lock it in. But a straight prong,
non-polarized, 115v 60 hz plug will fit if you try. Therefore, you could
plug a computer into one.
Computer power at airline seats: Both Delta and United (perhaps others)
came up with a great idea to provide passengers (at least first class, maybe
business class as well) with a 15 volt outlet at their seats a couple years
ago. They failed to decided upon a common outlet, so passengers had to buy
two different models or an interchangeable plug for their cords. Radio Shack
sold them. The airlines also failed to take advantage of the market -- they
could (and should) have sold them at the gate prior to boarding!
Sadly, United (not sure about Delta), has begun DE-activating all these
15 volt outlets, at least on the 777, and probably the 767 and 747-400
aircraft as well, citing some sparks or a fire somewhere on a plane as the
reason. The power supply is still in the closet somewhere, and there is a
master power switch there, too, but most don't work anymore. Too bad.. This
was a terrific sales idea that the passengers really liked. They complain
bitterly each day as they discover the plane has outlets -- but they don't
work.
I'm also wondering why the airlines chose 15 volts when all the Sony, HP,
and Compaq computers I've seen like to see 19 volts? Sure, they operate on
11.6 volt internal batteries, but as Bob Knuckolls pointed out, they don't
get a charge if you try to operate on 12 volts input. Perhaps 15 volts is
enough, but why not 19 volts in the first place?
28VDC outlets: The Boeing cockpits all have a 28VDC outlet, with a round
outlet. The plug that goes into it has to have one straight prong, and one
curved one, shaped like a parenthesis ) . I.e., it looks like this: | ) .
(Sorry this is getting SO LONG.. but there is lots to cover here!) Bob
answered my question with a couple of URLs that took me to some nice photos
of devices that looked like some ICs on a heat sink, but no information on
how or where to buy one, nor the circuit to build one.
That's one of them. An 'adjustable power conditioner'.
That's pretty big for what I need! And I would need the circuit for that
thing anyway.
If I could find the correct plug, I could wire it to a small device that
takes in 28vdc and outputs 19vdc for a computer!
WHERE could I find a device that does just that? Converts 28vdc to 19vdc,
no matter what the load on the user end? And, could I get one that doesn't
care too much what the input voltage is? I'd like to get one that takes in
12vdc-28vdc and puts out a constant 19vdc!
What does that look like? Is it nice a small and lightweight so I can carry
it on every trip? I could also use it on my computer in my car!
Sorry this got so long... but I STILL need the answer: I'm reluctant to
plug anything that's labeled 50/60hz input into a 400hz outlet, so I want to
go with the 28VDC source. How can I do that, what do I need, and where can I
get it?
Dan Eikleberry
Las Vegas
Subject: | Re: Airline power sources |
> LONG (interesting) message about Airline Power Sources!
[----------snip----------]
*** Not too hard. A simple circuit with a "three terminal regulator" will
do it. But making it small and light will be hard. Here's why:
Suppose your laptop wants an amp at 19V - this seems typical. The three
terminal regulator will accurately drop the 28V to 19V by inserting a
sort of dynamicly adjusting resistor (actually transistor ) in line with
the current. This resistor will generate heat. How much heat? P ( power )
equals E ( voltage ) times I(current). E here is the voltage DROP across
the regulator. 28V - 19V = 9 volts. Current is an amp. Power is 9V times
1 amp, or 9 Watts. So you'll need a heat sink, which porks up the package
somewhat, although 9 watts isn't all THAT much.
You might be able to
minimize the heatsink requirements by putting a series diode string before
the input to the 3-terminal regulator. Each diode drops .7 volts. You
should really have 5 volts of head room for the regulator, which means you
want a minimum of 24 volts at its input. If you know what the minimum
voltage output of the socket is, you subtract 24 volts from that, divide by
.7V per diode, and then you come up with how many diodes to put in the
string. If you tweek the design for 5V headroom, then your regulator only
has to dissipate 5 watts instead of 9.
*** This is harder. It can be done. You have to design a switching
regulator, which is somewhat outside the "do-it-yourself" level of
complexity. If you see a market for this, I have a friend who is expert
at designing switching power supplies, and who could use some consulting
work....
- Jerry Kaidor ( jerry(at)tr2.com )
19vdc,
doesn't
in
carry
Sounds like our old friend LM317 to me.
At least that should work off the 28v supply. It won't step up though.
To step up dc I suppose you would need an inverter - transformer - rectifier
set up?
Piers
Subject: | Re: S704-1 starter run-onrelay for PM starter |
>Hi Bob,
>In Fig Z-22 there is a fix for "run-on" in PM starters like Sky-Tec.
>The description says it buffers the panel mounted start button from very
>high inrush currents. Is that another way of saying it protects the
>starter button?
Sure . .
>I presume you still get the in-rush and need to start the prop spinning
>and get past the high in-rush period before turning on the EI's to
>prevent the possibility of kick-back.
No . . . this shouldn't be an issue. The relay's primary task
is to protect the starter switch while providing positive
disconnect of the built-in starter contactor at starter release
so that you don't get delayed dis-engagement due to generator
action of the starter motor as it spins down. The inrush
currents being considered here are associated only with
characteristics of the contactor. See:
http://209.134.106.21/articles/strtctr.pdf
Subject: | mounting inline components |
I have a couple of places where I would like to add in-line components -
one place is for a diode to drop the voltage slightly, another is to add
resistors. I there a good way to add them in-line without the bulk of a
barrier strip with screw friction connections? The connections I am
talking about is to join stranded wires to solid wire component leads, or
just solid leads to solid leads. I was thinking about maybe a knife
connector on the leads and stranded wire, along with a high temp plastic
strip inside the shrink wrap for some added strength. Any better ideas?
Gary Liming
From: | "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> |
Subject: | Re: mounting inline components |
Where do you need to drop a voltage just 0.6 volts and why?
You really have my curiosity stoked here . . .
For small components like that, I cut the leads on the component
to about .25" long. Strip .25" of 22 or 20AWG leadwire and solder
to component with a simple lap joint. Use small heatshrink over
each joint and then two layers of heatshrink over the whole assembly
including the joints.
I you can find some heavy, internal melting wall heatshink
for the outer layer, a single overall layer of shrink will
suffice.
I am putting camera mounts in the wings, and the camera is designed for 12
volts, and the manufacturer suggested putting a couple of diodes in series
in front of the camera power to drop the 14v down a bit, which made sense
to me. The nominal current draw is 180 ma, so heat is not a
problem. Pictures of the mount and the camera fixture are on the
instrument and wings pages of www.liming.org/ch801.
> suffice.
Ok, will do. And thanks.
Gary Liming
From: | Graham Singleton <grasingleton(at)avnet.co.uk> |
>--Mark Navratil
I can make a guess that it might be what used to be referred to as a tacho
generator. Simply a DC generator the voltage of which depends only on rpm.
I have an old one in a box somewhere in my shop. There used to be a Carr
(?) tacho that worked the same way. It had a nice 270 degree display.
Graham
Subject: | Switch numbering |
I'd just like to confirm switch numbering. Some of your drawings show
Microswitch toggle switches while others show your S700-2-XX switches.
It appears that the numbering differs between the two sources.
I have concluded that the numbering (with the keyway up viewed from the
back) is 1-2-3 bottom to top on the left and 4-5-6 bottom to top on the
right for the S700-2-XX and for the Microswitch the left and right
numbering is interchanged or 1-2-3 bottom to top on the right and 4-5-6
bottom to top on the left.
Is this correct?
Thanks in advance.
Richard Dudley
-6A finishing
N331RD reserved
There has been a continuing thread about both errors in the tachometer
and effects of RF on the tachometer and manifold pressure gauge. I have
read several posts reporting tachometer errors and indicator changes
when transmitters are keyed.
My question is: Does anyone with these instruments have good results?
Has the tachometer been calibrated and found within reasonable
tolerances (+-10%?)? Has anyone's installation been immune to RF. That
is unaffected when your transmitter is keyed?
Richard Dudley
-6A finishing
N331RD reserved
> >--Mark Navratil
> Graham
Subject: | in-line components |
I've done that, but usually I, after soldering as described above, double
the leads back over the component on opposite sides. This creates an "S"
configuration with the component itself providing the structure and the
separation of the exposed leads. Then the whole thing is shrink-wrapped.
Gary Casey
Subject: | Re: in-line components |
>< to about .25" long. Strip .25" of 22 or 20AWG leadwire and solder
> including the joints.>>
Good idea!
Subject: | Re: Switch numbering |
>Bob,
>Is this correct?
Another builder asked about this a short time ago. Here's
the exchange . . .
>Bob,
> Regarding figures Z-23 and Z-24, is there a typo on the pin numbers
>for the S700-2-10 switch? I looked through the archives and couldn't
>find any mention of errors, so if it's correct, please explain what's
>different that reverses the pin 2 and pin 5 logic between these drawings
artifacts in my wiring symbols that represent two switches
with swapped functionality from side to side.
switch housing.
Thanks!
Interesting. If the cameras are THAT sensitive to input voltage,
you might want to consider some form of low-dropout regulator.
Your bus voltage can be anything from 13.8 to 14.6 volts and
still be okay for operating the rest of the airplane. National
makes a low-dropout regulator that works down to 0.5 volts
of headroom. See: http://www.national.com/ds/LM/LM2940.pdf
> >--Mark Navratil
These can come in ALL flavors depending on the tachometer technology
chosen by the people who designed the tach. I've built perhaps a dozen
tachometer systems with "senders" that ranged from a (1) simple reed switch
mounted in close proximity to a spinning magnet to (2) a hall-effect
sensor that watches a dozen tiny bar magnets fly by to (3) variable
reluctance pickup that watches gear teeth in a gear box, to etc, etc.
There's no such thing as a standard tach transducer. It's unlikely
that the signal from Van's tach would come even close to interfacing
to the EIS4000 . . . magneto's put out two signal cycles per engine
revolution. To make a tach work smoothly, you want as many pulses
per revolution as possible . . . working with so few as 2/rev
is tricky and why many magneto based tachs have problems.
If an interface were to be designed for this task, I'd probably
use what is called a phase-locked loop oscillator and frequency
multiplier to make the 2/rev mag output match whatever the EIS4000
expects to see. I could build sufficient inertia and filtering
into the interface to make the most skittish digital display
settle down. Whatever the answer to this problem, it is not
simple.
+/- 1% is a better goal . . . in fact, with modern technologies,
0.1% is easily attained. A very common problem with many of these
products is the lack of understanding and/or willingness of their
producers to address rudimentary aircraft systems interface problems.
Airplanes carry VHF and UHF signal sources that can upset
otherwise well behaved electronics.
Over the years, I've probably made a dozen offers to companies
to assist in making their products more bullet proof. These
offers are generally triggered by some builder's effort to make
the accessory perform well in his airplane. To date, not
one company has taken me up on an offer of free assistance
and many of you are still plagued with having to do their
homework for them.
I've suggested many times on this list and others that
product performance SHOULD be marketplace driven. It matters
not what the manufacturer's sales hype claims nor what
blessings from Washington have been bestowed on the device.
You folks have the ultimate ability to make purveyors of
poor merchandise toe the line. It shouldn't matter
how many "satisfied customers" the manufacturer claims . . .
if it's not working in YOUR airplane, it's HIS
problem and he should either make it work or give you
your money back.
Again, if any of you encounter system integration problems
with a product and the manufacturer's tech support is having
you fiddle with lots of changes or additions to the
system that were NOT covered in his installation manual
or advertising brochures, feel free to give them my
e-mail address. I'd really like to see all this stuff
work right out of the box . . but if it doesn't and
they won't make the effort to fix it right . . . then
you guys need to pass the word and hit the turkeys
in their bottom line.
>John
The safest thing for ANY manufacturer or systems integrator
to advise is, "If the critter has a cooling air inlet, blow
into it."
Without proper instrumentation on the item's hot spots inside,
you have no way to evaluate whether or not your particular
set of radios are having heating problems. My distributor
lists a variety of avionics cooling blowers with 1 to 5
hose connections ranging from $125 to $250.
Subject: | Re: Thermocouple Switches |
> > the accuracy?
> > Thanks,
> > Kevin Horton
>Bob,
>answer?
>Dale Ensing
Hadn't answered it yet. I've been trying to come up
with an answer he's going to like but I'm not sure
that's possible.
I guess EIS has been using fast-ons in their thermocouple
leads for years . . and if they're still doing it, I
must assume the customers are happy with how the system
is working.
IF I were to tackle this task on my airplane, here's how
I'd do it:
Hopefully the thermocouple wires are 20AWG or smaller.
I'd use D-sub connectors with machined pins to make
the interface with individual probes and a harness that
brings all temperature data into the cabin.
The harness needs to be fabricated from the same
kind of thermocouple wire as the probe (type J or K).
I'd bring the bundle to a small enclosure mounting
a two pole, x-position switch for the purpose of
selecting one-of-x thermocouples for display.
Use another d-sub connector at the rear of the enclosure
to bring the probe bundle into the switch and carry the
thermocouple signal away to the instrument.
The interior of the switch box can be wired with
ordinary copper . . . when both sides of the
thermocouple lead are treated with the same
"interfering influence", the errors cancel out.
Thermocouple wire is used to take the signal
from the switch box to the instrument.
http://38.254.60.87/embrace/IMAGES/PDF/f-45-50.pdf
Grayhill has a suitable, miniature switch that you
can view at the above link.
This isn't an "easy" answer . . . it's a 2-4 hour
project to assemble and wire it.
In most schematics, there is a large CB/fuse that protects the B-lead off
the Alternator. I can't figure out how to wire a CB without bringing a big
wire up to the instrument panel. So, is the protection needed or will the
crowbar OV relay suffice? Where can I get an inline fuse that will work?
And, how do you wire that to a big 4AWG wire?
Thanks.
Keith
RV-6 finish
Denver
> http://209.134.106.21/temp/apc15-14b.jpg
>thing anyway.
When I posted those links, I thought I mentioned that the
photos were of prototype devices about to be included on our
website catalog and mentioned further that they would be
priced about the same as dimmers of the same size.
Data on a suitable device and info on wiring it can
be found in:
http://www.national.com/ds/LM/LM150.pdf
diagram is in upper left corner of page 7.
The prototype device I illustrated is actually
SMALLER than what you need. I have an HP
laptop that runs from a 19v, 2A power supply.
I ran the battery down and then plugged a
bench supply into the external DC power jack.
The computer draws just over 2A just to charge
the battery and the draw stayed over 1A for
about 30 minutes. When I turned the computer
on, the current draw went back up to 2A and
stayed there until the battery finished charging.
Then, depending on whether or not drives were
spinning, the computer would draw between .8
and 1.8 amps.
If you're going to toss away 9 volts at 2A
you need to dump 18 watts. The little
heatsink in:
will not let you do that continuously for
very long.
a heatsink capable of taking care of this
dissipation is shown at:
http://209.134.106.21/temp/MVC-008X.JPG
This is also possible but probably beyond the scope of
amateur workbench construction. It requires a special
wound transformer and a handfull of electro-goodies.
>get it?
If you have a 115vac outlet available, it's probably okay wiht your
laptop power supply. Drop by an avionics shop and see if they'll
let you power the supply from their 115vac/400Hz bench supply.
Hold it in your hand and if it's no warmer in 15 minutes than
it would be plugged into the wall, it's okay. My HP powersupply
runs happily on 400Hz.
I think most laptops are going to be in the 2-3 amp range
at 19v. . . . more than 9 watts to dump
But you still have to get rid of a total of 18w . . . whether
it's with resistors, diodes or transistors, all of those goodies
are going to dump out BTU's in trade for watts. The heat
has to go somewhere. The best thing to do with it is dump to
some device designed to maximize dissipation of the heat
to surrounding atmosphere . . . i.e. something with fins
or perhaps a fan on it. A totally enclosed, three-terminal
circuit could perhaps be smaller by using forced air from
a small fan . . . a tiny amount of air movement can have a
profound effect on heatsink requirements. There are some
really cute little fans out there used inside computers.
>> > the accuracy?
>> > Thanks,
>> > Kevin Horton
>>Bob,
>>answer?
>>Dale Ensing
> that's possible.
> is working.
> I'd do it:
> Bob . . .
Hmm. I getting very confused. My original question was in regard to
using Fast-Ons to join thermocouple wires with the wires going into
my EIS 4000. Now Bob is talking about switches. The EIS 4000
doesn't use any switches, as all thermocouple wires go into the unit,
and it can display data from all cylinders at once.
The wires from the Fast-Ons to the EIS 4000 are thermocouple wires,
i.e. type J or K as appropriate. Looking at one wire, I see the
following interfaces in order:
Type J wire from thermocouple to male Fast-On tab;
male Fast-On tab to female Fast-On tab;
female Fast-On tab to Type J wire;
Type J wire to male D-sub pin;
male D-sub pin to female D-sub pin (connector attached to the back of
the EIS). I can't tell what kind of wire is used from here on in.
The parts I'm worried about are those associated with the Fast-On
tabs. Everytime we have an interface with dissimilar metals, we'll
create a voltage. The voltages at the two interfaces between the
Type J wire and the Fast-On tabs will cancel each other out, assuming
both interfaces are the same temperature. So I don't see how using
Fast-On tabs creates a problem, but I'm certainly no expert, so I
could have this all messed up.
Kevin Horton
Keith,
The crowbar protects against overVOLTAGE.
The CB protects against overCURRENT.
They're not interchangable.
But I'm sure Bob will elaborate on that. :)
-Matt
> bringing a big
> or will the
> Thanks.
Subject: | Re: Thermocouple Switch for Blue Mountain EFIS |
Kevin Says:
Bob Says:
I can see why. I'd been mulling over an answer to an earlier
question by Craig that started something of a tread on thermocouples.
I got several questions stirred together in the reply which
I have split out as follows:
Craig Asked:
I'm working on connecting up my EFIS/One from Blue Mountain Avionics
into my existing airplane. I'm looking for a special switch (or
suggestions), connecting my EGT/CHT sensors to the system. The EFIS has
6 inputs for thermocouples, and I have a 6 cylinder Lyc. So I was gonna
put my 3 hottest cylinders, both EGT & CHT (for a total of 6 inputs),
and then use a (and this is where I need the help), a 6 way (6PDT on-on
switch - if there is such a thing). Then I would switch from my 3
hottest cylinders, which I want to monitor most of the time, and to
check the others as needed.
If anyone has a better suggestion, let me know. By the way, I've seen
Bob's thermocouple information in Chap 14 of the current Aeroelectric
Connection.
I'd do it:
Put the 2 hottest cylinder CHT/EGT thermocouples onto
2 fixed inputs which uses up 4 of the total.
Run the other pair of inputs to a 4-pole, 4-position
such that thermocouple PAIRS for the other 4 cylinders
can be switched to the "roving" inputs to the EFIS.
can purchase from Digikey
goto: http://www.digikey.com and enter
71BD30-02-2-AJN as the part number to search.
This switch has two decks of two poles each for
a total of 4 poles. It has an adjustable stop
so that you can limit the throw to 4 positions.
Subject: | Re: Thermocouple and fast-ons |
Kevin says:
Bob says: I see how I got it muddied up. There were a couple
of thermocouple questions I was treating as a thread. I've
split them apart and we'll work with Kevin's question.
Kevin,
My concern with fast-ons is based on the relative harness
of the two materials. Thermocouple wire is quite hard compared
to the terminal that's grabbing it and trying to get a gas-tight
joint. I prefer the machined pins found available for D-subs
and other multi-pin connectors for their 4-quadrant grip
on the wire.
EIS has been using the fast-ons for years and I must presume
they're getting satisfactory service . . . so I'd advise
that you follow their instructions and truck on.
>Bob,
>Thanks.
Have you looked over the articles on our website at
http://www.aeroelectric.com ???
All of these questions and many more are answerable
for the downloading time . . . You might also
consider acquiring a copy of The AeroElectric
Connection which can be ordered from the same
website. If you have a slow internet connection,
you can get a mirror image of the website on a
CD ROM that will save a lot of download time.
Take a peek too at the range of tools and materials
available from both website catalogs at
http://www.aeroelectric.com/Catalog/AECcatalog.html
and
http://www.aeroelectric.com/Catalog/BCcatalog.html
The descriptive literature for these products are
a good education as to what's available and how
they are used.
Thanks for the suggestion Bob. I like this idea best of all that I've
seen so far.
Craig
> I'd do it:
From: | "Gabriel A Ferrer" <ferrergm(at)bellsouth.net> |
Subject: | B&C's LR3 Voltage Regulator |
I bought the B&C LR3 Voltage Regulator. The following installation
instruction was included:
"Be sure to use a 5 amp circuit breaker on pin 6 of the regulator.
Connecting pin 6 directly to the bus or using so called "solid-state
breakers (PTC thermistors) will damage the regulator if there is an
overvoltage trip"
My RV6 electrical installation includes Control Vision's ExpBus. It has
a 5 amp "polyfuse" (thermal breaker) in series with the wire going to
pin 6.
1. Will this create a problem for the voltage regulator?
2. If yes to 1: will installing a 5 amp in line fuse in series with the
polyfuse correct the problem?
3. If no to 2: what do you recommend? (too late to return the ExpBus)
Gabe A Ferrer (RV6, working on installing electrical system)
Cell: 561 758 8894
Voice or Fax: 561 622 0960
Email: ferrergm(at)bellsouth.net
Yes, I have a copy of the AeroElectric Connection. I also checked your
website and didn't find any specifics. I must have missed it.
Keith
> Connection
Subject: | Re: B&C's LR3 Voltage Regulator |
Gabe,
I also have the EXP buss and when I discovered the same information re the 5
amp fuse, I called B&C and they informed me include a 5 amp CB in series.
The EXP buss always has a residual voltage going through it and must have
the power shut down for it to reset. B&C also told me that the mechanical CB
is quicker and they wanted it installed for warranty reasons.
Have a GREAT day!!!
----- Original Message -----
From: "Gabriel A Ferrer" <ferrergm(at)bellsouth.net>
Subject: AeroElectric-List: B&C's LR3 Voltage Regulator
> overvoltage trip"
> pin 6.
> Cell: 561 758 8894
http://www.matronics.com/browselist/aeroelectric-list
From: | "Daniel Pelletier" <pelletie1(at)hotmail.com> |
Subject: | starter contactor |
Hi Bob,
I'm confused again. I've yet a solenoid right on my starter. Some guys told
me that I don't need starter contactor in that case and I've just to bring
the battery cable (from Battery contactor) right on the big starter's stud
and to plug the solenoid connection right on the start's pole of the
ignition switch. Is that true.
In the wiring's diagram, I saw that the main buss is wiring from the starter
contactor. Where did I take my feed if I have not starter contactor, on the
starter stud?
Thanks for help.
Daniel Pelletier
601 HDS
Wiring
http://messenger.msn.fr
>Bob,
>Thanks.
http://www.aeroelectric.com?
There are no specifics to your questions by title of the
article but it's all in there. For example:
In Note 9 of Appendix Z (which I observe should be Note 10
to match the drawings) we talk about getting the b-lead feeder
out the cockpit. In the chapter on noise, we discuss the value
of keeping FAT wires (carry large currents and have strong,
noisy magnetic fields around them) away from SKINNY wires
(that carry radio and instrumentation signals). In all of our
published power distribution diagrams, we show the alternator
b-lead tied to the hot side of the starter contactor on
the firewall. In Figures 17-1, 17-2 and associated text
we discuss the rational for putting b-lead protection out
on the firwall . . . whether fuse or circuit breaker - it
doesn't matter.
The current recommendation is illustrated at:
http://www.aeroelectric.com/Catalog/ckrtprot/ckrtprot.html#bleadfuse
and offered for sale at:
Articles at:
http://209.134.106.21/articles/big_term.pdf
http://209.134.106.21/articles/rules/review.html
http://209.134.106.21/articles/terminal.pdf
speak to various issues and techniques surrounding
soldered and crimped terminals including big fellers
for fat wires to go on your battery master and
starter contactors.
>overvoltage trip"
>pin 6.
I've not taken the time to run any tests using the crowbar
OV protection system with Polyswitches . . . The fault current
that flows in the milliseconds after a OV condition is detected
can be as high as 300 amps. This causes the 5A breaker to open
right smartly. It is possible that the Polyswitch time delays
are sufficiently longer under these conditions to put etched
circuit board traces inside the LR3 regulator at risk.
Yes, this is the most conservative approach to avoiding
future problems.
Subject: | RE: starter contactor |
>Hi Bob,
You CAN use built in contactors included on MOST starters but
you may not want to. See:
If you DO use a built in contactor and the starter is a
wound field device (like B&C) then you can make your
starter engagement switch last a whole lot longer
by adding a buffer relay as shown in Figure Z-22 of
the AeroElectric Connection. If you have a PM motor
starter (like Skytech) then the buffer relay is
REQUIRED to prevent starter run-on and to protect
the starter switch's condtacts.
>In the wirings diagram, I saw that the main buss is wiring from the starter
>starter stud?
Of the switched side of the battery contactor . . . but if
it were my airplane, it would have an auxiliary contactor
like our 702-1 that has no heavy inrush currents, draws
about 4 amps while energized, has built-in arc suppression
diode on coil and provides a hand location on firewall for
power distribution and b-lead feeds when the battery is
located remotely from the engine.
See:
http://www.aeroelectric.com/Catalog/switch/switch.html#s702-1
Subject: | fast ons for thermocouple wiring |
In a message dated 03/10/2002 2:53:27 AM Eastern Standard Time,
khorton(at)cyberus.ca writes:
<< ....skip..... Hmm. I getting very confused. My original question was in
regard to
could have this all messed up. Kevin Horton >>
3/10/2002
Hello Kevin (and Bob), I think that Bob has now responded and sorted out any
switch confusion, but I'd like to pursue this subject a bit further. What I'm
going to describe is how Vision Microsystems Inc. handles their thermocouple
inputs. It might give some confidence to what you are doing or uncover some
subtle aspect of this subject that is of value.
With the VMS system I got 4 EGT and 4 CHT thermocouples already lead wired
with appropriate K and J wires that terminated in 1/4 inch wide male / female
push-ons. (I'm using the generic term "push-on" here because Fast On is a
proprietory AMP name and the distinction may be important to some people).
VMS provides more J and K wire for transition and some Thomas and Betts fully
insulated push-ons that just get crimped onto the transition wire for
connecting to the push-on on the end of the lead wire coming from the
thermocouple. (I declined to use the provided T&B push-ons and purchased
fully insulated Molex Avi Krimp push-ons because the Avi Krimp push-ons have
the additional metal wire insulation crimping support and the T&B's did not).
The J and K transition wires then go to a 25 pin D sub connector (in the
newer version of the VMS DPU (Data Processing Unit) which plugs into the DPU.
The D sub connector has stamped pins and the the transition wires are both
crimped and soldered to these pins.
VMS makes a big deal of the fact that one must use the special soldering flux
that they supply. I quote: "Apply NOKORODE flux to these leads, otherwise the
solder will not bond to the wire properly. NOTE:Read caution statements and
direction on container before use)". NOKORODE Regular Paste Flux is made by
Rectorseal in Houston TX. It contains zinc chloride, but no lead. It is
described as "Not for electronics use.....". It needs to be washed off with
water after soldering.
It is a little puzzling to me as to why the wires must be soldered to the D
sub pins, but just crimping them to the push-ons on the other end is OK. It
would not be possible to solder to the push ons that VMS provided or the ones
that I used because of the insulation. Also I believe that the push-ons on
the end of the thermocouple lead wires were soldered on by the factory that
produced the thermocouples and the leads. (I can't easily check because the
leads are now all covered up in wire looms.)
This crimp only versus crimp plus soldering at the push-on junction would
seem to create an asymmetry and generate some erroneous signal. Maybe some
expert reading this can explain away my concern.
The output from the DPU to the LCD VMS guages is via ribbon cable.
So, with the exception of the soldering bit, it looks like you are doing what
VMS considers good practice. You might want to call VMS up (ask for Dave) and
discuss the pin soldering issue. Their number is 360-714-8203. Yes, I know
that you are not using their product, but they have always been very generous
in educating me.
Good luck.
PS: The thermocouple leads in the Westach (800-400-7024) catalog are
terminated with push-on connectors. They make the statement that thermocouple
leads (which are offered in a variety of lengths) should not be cut. But they
also show patch (transition) cables leading to the instruments which may be
shortened or lengthened. The catalog doesn't say anything specific about
connecting patch cables to the instruments. Maybe a phone call to them would
be educational. Please share what you learn with the rest of us. Thanks.
Subject: | Re: EGT/CHT channel scanner was Re: AeroElectric-List: |
>snipped
> I'd do it:
What you suggest seems like a more elegant version of what RMI suggests
for monitoring multiple CHT/EGTs on their Micro Monitor. I have a Micro
Monitor (got it used at a very good price). This solution works, however,
it does not allow maximum use of one very useful feature available in
nearly every engine monitoring system.... the out of limit alarm. These
alarm features, allow the pilot to keep his head outside the aircraft. With
the alarm, I know that I don't HAVE to watch the EGTs and CHTs during
cruise flight. The alarm will warn me if a cylinder starts running to hot
(or cold).
My Micro Monitor only allows me to monitor one EGT and one CHT at a time.
Even with a rotary switch, I can only monitor one cylinder at a time
(usually the hottest one). I feel that there is a weak point in the use of
a rotary switch to view the other cylinders. I am forced to choose between
constantly operating the rotary switch to check the other cylinders. This
defeats the whole purpose of the engine monitor: allowing me to concentrate
on watching for traffic. The other choice is to leave the rotary switch
positioned on the hottest cylinder with occasional checks of the other
cylinders (Every 5-10 minutes).
I would like to install an electronic switching and scanning device
between the 4 CHT & 4 EGT probes of my engine and the 2 inputs of my engine
monitor. A device that would scan each channel for a predetermined amount
(adjustable?) of time, then repeat for the next three channels. This would
allow the alarm to catch any fault much sooner than I would catch it.
A vacuum leak in one intake runner or a partially clogged fuel injector
could easily cause the mixture to go lean. Thus a normally cool cylinder
would start running hot. A bad ignition wire or plug would cause the
effective timing (running with only one spark source) to retard. This would
also cause a rise in CHT and/or EGT temps on the effected cylinder(s).
While these are not "everyday" occurrences, at $20,000+ for a new engine,
I hate to take unnecessary chances. Is such a module commercially
available? Could one be built reasonably?
Charlie Kuss
RV-8A fuselage
Boca Raton, Fl.
My EIS 4000 manual says it can handle 1, 1.5, 2, 3, 4, 5, 6, 7, 8, or 9
pulses per revolution.
A friend of mine has an RV6 with a tach pulse generator that he bought from
Aircraft Spruce which plugs into the tachometer cable connection on the
engine that interfaces with his EIS.
Ronnie Brown
Subject: | Contactor confusion |
Hi Bob: I have a B&C master contactor and a four terminal starter
contactor of the type that has two small terminals labeled "S" and "I."
After rereading your book and several of your articles I got curious about
the internal connections on these devises and started checking with my
multimeter and found that I measure essentially zero resistance through the
coils of both devises where your book and related articles says there should
be somewhere between 4 and 15 ohms (all diodes and connections removed). Can
you help me understand what is going on here? Both devises pull in properly
when I apply 12 volts across the coil terminals.
Also, what is the "I" terminal on the starter contactor connected to? Van's
suggested wiring diagram shows an optional lightweight starter hookup that
has a jumper from the "I" terminal on the contactor to the starter solinoid.
Any idea what that is for (I am using your Z-1, now Z-11 wiring but am unsure
how to treat the Sky-Tec starter on my new engine)? Thanks for you
continuing support and patience with these probably dumb questions.
Harry Crosby
Pleasanton, California
RV-6, wiring
Subject: | PVC insulation - EIS 4000 |
I've just started the installation of a Grand Rapids EIS 4000 engine
monitor in my RV-8. I had assumed that all the wiring would have
aircraft quality tefzel installation, but I just learned that the
harness going into the unit have PVC insulation.
So now I have some thinking to do. First I must decide how much of
the wiring I will replace, and then I must convince the Canadian
inspector of the correctness of my plan. I'll contact the inspector
as soon as I have done my thinking and have a convincing story. If
he is going to insist on a major rewiring I would rather know now
before I get too deep into this.
I need to acquire some knowledge on PVC insulation. I assume there
are three potential issues:
1. Noxious fumes if the insulation is overheated (yes, I agree that
no wires in a properly designed and installed electrical system
should ever overheat. However, we still read about the occasional
electrical smoke or fire incident, even on type certificated
aircraft);
2. Abrasion resistance not as good as tefzel insulation; and
3. Shorter life than tefzel insulation.
Tackling these issues in order:
1. I assume that PVC insulation on some wires is OK, as not all wires
are at risk of getting hot. I could use PVC insulation as long as
the wires in question are routed well clear of the exhaust system,
handle low voltage/low power signals (i.e. CHT and EGT extension
wires) and are not in the same bundle as wires with power sources.
Are these criteria reasonable?
2. Assuming the wires in question are well secured and cannot chafe
against anything, are there any other abrasion issues to worry about?
3. How does the life of PVC insulation compare to tefzel? What
failure modes should I expect as the wire ages? What warning signs
should I look for?
Thanks for your assistance,
Kevin Horton RV-8 (installing engine)
Ottawa, Canada
http://eccentrix.com/misc/rv8/rv8.html
Subject: | Re: PVC insulation - EIS 4000 |
Kevin,
I would say that you should talk to the EIS people. They have been very
helpful to me. I am sure you are not the first to try a Canadian
installation of their system, maybe they know the answers. You should
definitely at least send them a copy of your e-mail to the group with your
concerns.
Good luck,
Ed Perry
eperry(at)san.rr.com
Subject: AeroElectric-List: PVC insulation - EIS 4000
> aircraft);
> should I look for?
> Ottawa, Canada
I'm sorry but PVC just isn't acceptable in aircraft period. The amount of
money you might save is insignificant when you consider the PVC will crack
and possible shortout. This will overheat it. Yes, you can get it in colors
but simple wire markers work just as well.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Always looking for articles for the Experimenter
aircraft);
should I look for?
Ottawa, Canada
Subject: | Thermocouple connections |
I think there is too much worrying going on about TC connections. In the
old days we used meters for temperature read-outs that were sensitive to
circuit resistance, but these days the interface is a very high impedance
electronic one. If the pair of connections is at the same temperature the
error in reading should be very small, in my experience. In other words, if
you connect the positive TC wire to a copper wire at the same location that
the negative one is connected it will cancel out the TC effect of the
connection. But if the positive one is connected, say, in the engine
compartment and the negative goes into the cockpit before it changes to
copper you can expect an error in reading roughly in the amount of the
difference in temperature. I can't see where on flux will have an effect
compared to another - or even crimped compared to soldered.
Gary Casey
<a 5 amp "polyfuse" (thermal breaker) in series with the wire going to
>pin 6.
circuit board traces inside the LR3 regulator at risk.>>
Maybe I can help. The "Polyfuse" is an NTC device designed to have a very
steep temperature curve. It is not a fuse as such, but is more correctly
called a "current limiter." I use a Raychem Polyswitch to protect a .5 amp
power supply against overload and the one I picked will limit at .35 amps
at -40C and .11 amps at 85C so you can see there is a wide variation of the
current limiting vs temperature. After tripping it will dissipate 1.1 watts
at 25C, which means that it will continue to pass about .09 amps at 12 volts
WITH A DEAD SHORT IN THE SYSTEM. It will not open, but will go from, in
this case, a resistance of 4.8 ohms in the "conducting" mode to about 133
ohms with a dead short applied.
Gary Casey
Subject: | Re: Contactor confusion |
The diodes shouldn't make any difference when measureing these
devices with a multi-meter. What kind of multi-meter are you using?
Some of the lower cost, analog devices don't have a good low ohms
capability. For example, I have an old "pocket" mulitmeter that
reads 1000 ohms at midscale on the lowest resistance setting.
This means that 4-ohms and 15-ohms would look like zero ohms
on the instrument.
The "I" terminal is essentially a second power output terminal
that becomes hot when the contactor is energized.
See http://www.aeroelectric.com/Catalog/switch/switch.html#s702-1
and http://www.aeroelectric.com/Catalog/switch/S702Wire.jpg
The "I" terminal was used on automobiles to boost ignition
coil primary current during cranking. This terminal could
very well be used as Van suggests . . . it will serve the
same function as the starter-run-on buffer relay shown in
figure Z-22 of the book . . . The "I" terminal has been used
by some builders to drive a STARTER ENGAGED light on the
panel.
TEMPORARY WEBSITE ADDRESS:
Subject: | Alternator Problem |
Hi All,
I just had a problem with my alternator and discovered the bracket holding
it on was broken. In disassembling it I notice what I thought was a ground
wire to the shielding was broken and not making contact.
After reassembling I noticed the shielding(on the ground wire) was not
grounded on the other side so I left it off. Now I noticed when I first was
having a problem that my alternator was discharging. Well after replacing
the bracket and reattaching the wires(hopefully correctly), I am still
discharging. Before I remove the alternator and take it to be tested, do you
think I could have replaced the two small wires incorrectly on the
alternator? Could what I thought was a ground wire to the shielding been
something else?
Thanks for your help.
Shelby Smith
In a message dated 3/11/02 5:39:53 AM Pacific Standard Time,
nuckolls(at)kscable.com writes:
<< What kind of multi-meter are you using? Some of the lower cost, analog
devices don't have a good low ohms capability. For example, I have an old
"pocket" mulitmeter that reads 1000 ohms at midscale on the lowest resistance
setting. >>
Thanks Bob. And I have an old Micronta (Radio Shack) multimeter that
"should" read 10 ohms midscale on the lowest setting. When I checked the
resistance of a diode in the forward direction I read about 4 ohms. Does
that sound about right?
Harry Crosby
RV-6, wiring
Subject: | help with a welen strobe???? |
Can anyone tell me were to find a schematic for a Whelen comet flash strobe.
This unit flashes once and stops working; What was found after opening is a
powered
component. It looks like it might have been a ressistor, but not sure.....
its wire
does not stick up as high as a diode close by, so i need help to get this
unit back into the air.
I can't even find a bad unit to buy to see what this part was.
If anyone can help please let me know.
thanks
jerrym(at)nsc.com
Subject: | Re: help with a welen strobe???? |
What powersupply is that (what model exactly)?
Can you take a picture of the component's location?
Perhaps I could open mine and try to identify it for
you.
Michel
--- Jerry Morris wrote:
> Morris"
> powered
> its wire
> part was.
> thanks
> jerrym(at)nsc.com
> Forum -
> Contributions of
> any other form
> latest messages.
> other List members.
> aeroelectric-list(at)matronics.com
> http://www.matronics.com/subscription
> http://www.matronics.com/photoshare
> http://www.matronics.com/search
Michel Therrien CH601-HD
http://pages.infinit.net/mthobby
http://mthobby.pcperfect.com/ch601
Not only that, with ageing it will release hydrogen chloride vapour which
causes corrosion.
Graham
From: | "Richard D. Fogerson" <rickf(at)velocitus.net> |
Subject: | Contactors, Current Limiters on Z22 |
Hi Bob,
Just a few quick questions:
1) Do all the Z diagrams use S704-1 for starter contactors and S701-1
for Battery Contactors?
2) Z-22 (Permanent Magnet "run-on") says "size B-lead ANL limiter to
Alternator and AWG to match". For a B&C 40 amp would that be ANL 60 and
6 AWG?
Subject: | Re: Contactors, Current Limiters on Z22 |
>Hi Bob,
Yes. However, we call out those numbers as minimum-effort
acquisitions of two of many parts suited to the task.
>6 AWG?
We needed to upsize earlier JJS/JJN series fuses with respect
to their alternators because of very fast response of the
fuses. ANL limiters are much more robust as described
in . . .
http://209.134.106.21/articles/anl/anlvsjjs.html
. . . and are picked with ratings closer to the output
of alternator. Therefore a 40A alternator gets an ANL40,
the 60A alternator gets an ANL60
>setting. >>
When you put an ohmmeter across a diode, keep in mind
that you're really measuring a voltage drop. The true
resistance of a diode is very low . . . generally on the
order of tens of milliohms. The "resistance" reading
for a diode will vary somewhat from meter to meter but
the reading cited in your case is not unreasonable.
I'm surprised that this instrument doesn't seem to
measure the resistance of the contactor coils.
Subject: | Re: Alternator Problem |
>Hi All,
>something else?
Improper connection of shields should make no difference
with respect to proper alternator operation. In fact,
the notion that alternator installations benefit from
any form of shielding is a myth perpetrated by Cessna's
ADF installations of the 1960's and perpetuated into
tens of thousands of other airplance since.
You need to troubleshoot your alternator installation
per Note 8 of http://209.134.106.21/articles/Rev10/z10.pdf
I understand how they work. What I've not investigated
are the time constants for their operation. There's
an I(squared)*T constant for fuses and breakers that
describe dynamic behavior of a protective device. What
I cannot assert now is whether or not the crowbar
OV system as it presently exists in our products will
live and work happily with the Polyswitch anyone chooses
to use in their off-the-shelf wiring product.
By-in-large, I can find no redeeming pre-wired switch
panels with or without Polyswitches . . . careful
analysis of cost and time to install shows that these
products do not live up to their advertising hype.
Many of my builders are wiring their complete airplane,
wire, contactors, switches, terminals, fuseblocks, etc
for less than the cost of a pre-wired product and in
the same amount of time. See:
http://209.134.106.21/articles/xpbusthd.html
http://209.134.106.21/articles/expbusad.html
anyone interested in more data on Polyswitches
can check . . .
http://www.circuitprotection.com/litbrochures/shortformcatalog.pdf
Subject: | Cessna Split Master Switch |
To the list;
New subscriber...first post.
Question: Can a Cessna Split Master Switch
(S1994) handle up to 20 AMPS? I would like to run a
wire from my voltage regulator through the switch so
I could isolate my stator from the entire system
should it fail.
TIA,
Jack Lockamy
Sonex #300
Camarillo, CA.
www.jacklockamy.com
>aircraft);
>should I look for?
These questions generally produce lots of response . . .
Had we been building airplanes in 1890, wires would be
insulated with tar and hemp. Then cotton covered rubber
could have come along and everyone with new wire to sell
would pour forth with all the evils of the past and
extoll virtues of the present.
In 1960 we were wiring airplanes with nylon jacketed
PVC . . . the best we knew how to do then. Pretty soon,
here comes Teflon . . MUCH better in many respects but
not without it's own evils . . . very toxic out-gassing
when overheated. Then comes Tefzel . . . lower temps
than Teflon, more rugged and not quite so toxic. Then
comes Kynar . . . I had to beat vendors off with clubs
while working the GP-180 project at Learjet in 1983 . . .
my airplane was going to be "hundreds of pounds overweight"
if I didn't champion the new latest and greatest.
Looking back, many of the airplanes I rent are wired
with nylon over PVC wires. They're 30+ years old
and the wires are still flexible and insulations are
intact. Wires under the cowl are in pretty good shape
too . . . because they've probably been replaced a number
of times over the years . . .
Further, we've read where the very thin, very tough
Kynar insulation has a degradation mode that may have
precipitated the cabin fire in an airplane over the
North Atlantic a few years back.
Here are some brief tech data sheets on PVC
and Tefzel.
http://www.endura.com/material1.htm#7
http://www.endura.com/material1.htm#37
Bottom line is that I wouldn't loose any sleep over
PVC instrumentation wires in the cockpit. Probability
of future difficulties with the wire any time in the
next 30 years is remote. Further, the outcome of some
problem being markedly influenced by the the fact that
the wire is covered in Tefzel as opposed to PVC
is even more remote.
PVC under the cowl is easy to observe and apply
maintenance as required. Probability of an
uncomfortable situation arising out of an
instrumentation loss is remote.
So, your real problem is how to deal with a
bureaucrat primed to pay homage to the latest
approved mantra. You're on your own there my
friend. My advice has to be based on an understanding
of physics and observations of history. Bureaucrats
are not renowned for their ability to exercise
those skills.
None the less, I would lean on EIS with great
enthusiasm to upgrade their product. It's
not an expensive thing to do . . . they've
just been lazy.
Subject: | Re: Cessna Split Master Switch |
>To the list;
>should it fail.
Better to wire it per Figure Z-16 of
The infamous split-rocker has the same guts
in it as switches offered at:
http://www.aeroelectric.com/Catalog/switch/switch.html#switch
Suggest you review additional links on this
page about features of these switches.
By-in-large, the switches shouldn't be used
for loads exceeding 10A, 100W landing lights
and pitot heaters are only 8A . . .
Subject: | Re: Thermocouple connections |
><D-sub pins, but just crimping them to the push-ons on the other end is OK. It
>ones
>leads are now all covered up in wire looms.)>>
Don't know where "solder" was even mentioned much less recommended.
You can't soft-solder thermocouple wires. You can silver-solder them
but this is useful only for joining wires or making a thermocouple
out of bulk wire. See:
http://209.134.106.21/articles/excerpt.pdf
I prefer d-sub connectors for thermocouples using the MACHINED
crimp on pins which grab the wire in a four-quadrant munch. These
pins are always gold plated.
>connection.
Not true. The location of a copper to thermocouple junction defines
the system's "cold" junction. If one KNOWS what the temperature
of that junction IS and allows for in in system calibration, it's
entirely satisfactory. See view B of figure 14-10 in the article
cited above.
The switching technique I described in the earlier post puts
a pair of opposing "cold" junctions in series to accomplish
the cancellation you've alluded to above . . . but they have
to come in opposing pairs.
One can only "worry" about thermocouples if one doesn't understand
thermocouples. It's true that modern thermocouple instruments
are LESS sensitive to loop resistance of the thermocouple
but there are things that introduce significant errors
that are EASY to avoid.
Got a box on my workbench right now that's going to go back
into a Beechjet for some temperature studies on a pitot-heat
deicing system. Two sets of d-sub pins in each thermocouple
loop.
Here's another example of how copper-clad can be used to
fabricate custom enclosures:
http://209.134.106.21/temp/MVC-036X.JPG
Here's a view of the serially interrogated
data acquisition modules . . . these cost about
$50 each off the internet:
http://209.134.106.21/temp/MVC-037X.JPG
Here's how the electronics are mounted on a hefty
aluminum plate that also mounts a couple of heaters
to keep the interior of the box about 10 degrees
C.
http://209.134.106.21/temp/MVC-039X.JPG
Here are the thermocouple data conversion chips
that take care of cold-junction compensation
and give me a nice 10 mV/Degree C output
signal. Note connector in foreground
terminates 12 pairs of thermocouple wire
that extends TC data right up to the chips:
http://209.134.106.21/temp/MVC-041X.JPG
You guys with laptops can use this relatively
simple data acquisition technique to go find
out whats REALLY happening under the cowl.
Thanks for the reply Bob. I will review the .pdf
document you referenced/linked.
Would you mind taking a look at my DRAFT electrical
diagram to see if I have any potential problem
areas? My diagram can be found on the lower left
side of my homepage (see www.jacklockamy.com).
It is a .pdf file also.
I have started running some of the wire and would
like a second or third opinion if anyone cares to
comment or provide suggestions. In places where I
changed from 14 AWG to 8 AWG on the same run....I
changed it all to 8 AWG (haven't updated drawing
yet.)
TIA,
Jack Lockamy
Camarillo, CA.
www.jacklockamy.com
> >To the list;
> >should it fail.
> Bob . . .
I was just about to hookup my two 55W landing lights to a relay coming off
off a 2-10 switch.
Am I safe to assume from the above statement, that I could wire the 9.2A
(@12v) load directly to a switch and be okay (likewise for my 7.4A nav and
8A pitot tube loads)? I'd like to reduce parts count as much as possible
without affecting safety.
Thanks, Rob (RV-6).
Subject: | Re: Thermocouple connections - PostScript |
Forgot to mention . . . look closely at how the
thermocouple wires drop onto the etched circuit
board adjacent to the integrated circuits in the
foreground . . . I crimped male d-sub pins onto
the wires and then soldered the PIN to the board.
Except for silver-soldered thermocouples on the
far end of each circuit, all joining of thermocouple
wires are d-sub pin crimps . . . When I
calibrated this system against an ice bath,
individual T/C chips had errors of
as much as 3 degrees C which was were washed out
in correction values entered into the data
acquisition program. The thermcouple wiring
errors were less than 0.5 degrees C in spite
of the fact that each circuit had 18 joints
between the thermocouple and the instrumentation
chip.
Here's a link to that photo again:
>>aircraft);
>>should I look for?
> and Tefzel.
> those skills.
> just been lazy.
> Bob . . .
Thanks for the info and advice.
I've decided I will replace the power input wire, and the one that
provides 5v output to one of my senders. I'm comfortable leaving the
other PVC stuff alone.
I'll contact the folks who run the organization that does the
official inspections up here to see what their policy is. Then I'll
contact the local inspector. If I can't convince them to allow PVC
on instrumentation wires, I'll redo the rest of the harnesses.
I contacted Grand Rapids, and Greg offered to redo the harness with
the wire of my choice if I want. I may still go down that road,
which would leave PVC on only the thermocouple wires. I haven't
managed to find a supplier of tefzel insulated thermocouple wires yet.
Take care,
Kevin Horton RV-8 (installing engine & electrics)
Ottawa, Canada
> > just been lazy.
> > Bob . . .
>Bob,
Okay . . . at least GR is now aware of the problems
that some of their customers are experiencing. I hope
they move to fix the product line and not just your
harness (should that become necessary).
Goto
http://www.omega.com/toc_asp/subsectionSC.asp?subsection=H06&book=Temperature
down the page you will find type J and type K duplex
thermocouple wire listed.
Your looking for TT-K-## or TT-J-## where ## is the wire
gage. I use a lot of TT-K-20 and TT-J-20 in solid wire.
It's my favorite for use with the 20AWG d-sub connectors.
You can build a part number consisting of "TT" for teflon over
teflon, "J" or "K" for the kind of thermocouple and then
a length value.
For example, 25' of TT-K-20 is $31 plus shipping. You can
select a part number, add it to a shopping cart and buy
the stuff right on line.
OMEGA is a good company to do business with.
From: | "Werner Schneider" <WernerSchneider(at)compuserve.com> |
Subject: | Combining Insight gem and Rocky Mountains engine Monitor |
Hello Bob,
you're very helpfull comments in this list are very well appreciated. I hope
you can give me also some advice.
I plan to use a RKYM engine monitor, now what I dont like is, that I can
monitor one pair of temp only. I got a Insight Gem603 monitor (which a
friend just fixed). My idea is now, to use both instruments together.
-I have no sensors yet, can I use the sensors from RKYM also for the
Insight?
-is there a electronic available, which I could integrate between the
Gem and
RYM which would change the pair of sensor every say 30 sec? This would
allow a logging of engine data on all cylinders.
-Is there any problem to run two instruments with one set of sensors?
-Any opinion about this approach and RKYM?
Many thanks for your help and your book is worth any cent!
Werner (Glastar final assembly)
Subject: | soldering thermocouple wire |
In a message dated 03/13/2002 2:52:39 AM Eastern Standard Time,
<< Don't know where "solder" was even mentioned much less recommended.
out of bulk wire.......skip..... >>
3/13/2002
Hello Again Bob, Soldering thermocouple wires was brought up in my responding
posting to Kevin Horton (repeated below) wherein I quoted instructions from
Vision Microsystems about soldering type J and K wires to stamped pins for
their engine instrumentation system. You are now confirming that even this
soldering has no value or effect?
Also it would appear that push-on connectors when properly crimped and
polarized would function the same as the connectors shown in Figure 14-13 of
The Aeroelectric Connection. Thanks.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
Subj: fast ons for thermocouple wiring
Date: 03/10/2002
regard to
February 27, 2002 - March 13, 2002
AeroElectric-Archive.digest.vol-aq
