AeroElectric-Archive.digest.vol-av
April 28, 2002 - May 13, 2002
Date: Apr 28, 2002
Subject: who can work on what on experimental aircraft
In a message dated 04/27/2002 2:52:14 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "Cy Galley" Date: Apr 28, 2002
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com>
Subject: Re: Racemate alternator
> >I am looking at using a Racemate alternator (www.racemate.com) on my >autoconversion aircraft engine. This utilizes a concentric alternator within >the high performance water-pump - a neat and space-saving arrangement used by >the Team-38 autoconversion.. Does anyone know of a failure mode for an >alternator that might cause it to freeze solid and thus take out the >water-pump with it? That's pretty slick! What you see is an adaptation of the same technology used in the B&C SD-8 and 200G PM alternators into the pulley of a water pump. Since there are no moving or wearing parts unique to the alternator, this modification to the pump does not increase the likelihood of wear-related failure. There are magnets on the inside surface of the pulley that COULD come loose and jam the pulley IF it were not for the fact that centrifugal force pushes the magnets away from the pole pieces while the pulley is turning. I see very little risk for having modified the pump in this manner. My browser was unable to access the descriptive literature on this product. Do you know how many amps the alternator will produce? Bob . . . ________________________________________________________________________________
Date: Apr 28, 2002
Subject: Re: Lightspeed wiring . . .
> > > >Bob > I have a question regarding the starter contactor S702-1. Can a >continous duty contactor S701-1 be used in this role? In my >configuration it woul make a much cleaner installation. > >Jim Robinson Folks have done it but you're almost certain to suffer the sticking starter contactor syndrome . . . Starter contactors are specifically designed for this service. Bob . . . ________________________________________________________________________________
Date: Apr 28, 2002
From: "James B. Robinson" <jbr(at)hitechnetworks.net>
Subject: Re: contactor
-----Original Message----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Date: Sun, 28 Apr 2002 12:37:30 -0500 Subject: Re: AeroElectric-List: Re: Lightspeed wiring . . . > > > > > > > > > >Bob > > I have a question regarding the starter contactor S702-1. Can a > >continous duty contactor S701-1 be used in this role? In my > >configuration it woul make a much cleaner installation. > > > >Jim Robinson > > Folks have done it but you're almost certain to suffer > the sticking starter contactor syndrome . . . Starter > contactors are specifically designed for this service. > > Bob . . . Thanks Bob I'll make the correct part function in its specific role. Jim Robinson ________________________________________________________________________________
Date: Apr 28, 2002
Thankyou for your usual erudite response, Bob. Very reassuring. The alternator comes as a single unit, delivering 35A, or a twin unit, delivering 50A total. Employs double belts for redundancy. Cleans up the accessory end of the engine and avoids having to use mounting brackets with their potential for failure. Ken Melvin. ________________________________________________________________________________
Subject: Re: who can work on what on experimental aircraft
Date: Apr 28, 2002
You are correct! But I think that if you fly IFR, some of the instruments must be certified. I could be and am probably wrong but I know you have to have a static and transponder check even if you are VFR for class C. Do you think that a certified instrument tech will certify your non-standard instrument? You can do it yourself on a homebuilt, but you have to buy a certified standard to do the checking so it is cheaper to have it done by an approved repair station. At least it was explained that way to me. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: who can work on what on experimental aircraft In a message dated 04/27/2002 2:52:14 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "Cy Galley" http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: Charging one of two dual batteries
Date: Apr 28, 2002
About a week ago there was a discussion of charging the AUX battery in a two battery all electronic system. If Figure Z-4 is used for the charging system and the Aux battery drains for some unknown reason, then you must be able to get to the aux battery with a charger to bring it back on line. A worse scenario is that I fly into a field with no service and the grandson turns on either the aux or main master (I would never fail to follow the shutdown procedure) and one battery is discharged. In that situation, I could start the engine with one battery, but never recharge the dead battery! To remedy this possibility, why not make the aux and main contactors look just like the crossover contactor with the three diodes. Then if either battery will start the engine, the alternators will charge the dead battery once the engine is running. The dead battery will not pull the good battery down before the engine starts because it will not draw current until its input voltage is about 13.5V, which only happens after the engine has started. Even if the pilot did not know one battery was dead, started the engine with the normal procedure, the aux master would turn on and the alternator/regulator would probably begin charging the dead battery as soon as the engine started even if the pilot opened the cross-contactor. If the pilot noticed the low voltage light, he would probably leave the cross-over closed for 5-10 minutes to charge the battery with both alternators to insure the battery had enough energy to maintain the regulator function, then turn the cross-over off. Am I missing something? Gene Long ________________________________________________________________________________
Date: Apr 28, 2002
> >Thankyou for your usual erudite response, Bob. Very reassuring. The >alternator comes as a single unit, delivering 35A, or a twin unit, delivering >50A total. Employs double belts for redundancy. Cleans up the accessory end >of the engine and avoids having to use mounting brackets with their potential >for failure. Ken Melvin. I'll keep checking back on their website. I was unable to get past the front page earlier today. I'd be interested in getting copies of any technical data on their products if you do put your hands on it. Bob . . . ________________________________________________________________________________
From: "Richard D. Fogerson" <rickf(at)velocitus.net>
Subject: Re: Antenna Questions from Aeroelectric Book
Date: Apr 28, 2002
Sorry, I messed up. I should have said the wire from the Battery Contactor solenoid to the Master Switch that grounds the solenoid and closes the Bat Con switch. Rick > >5) One last question on another topic. With dual ignition and dual > >batteries in the back, I want to put a hidden switch on the line from > >main bat/con solenoid to the voltage regulator. What would work best, a > >toggle switch, toggle switch with fuse, re-settable cb, or cb switch? > > I'm not visualizing what wire you're talking > about. I'm not aware of any wire that runs from the battery > contactors directly to the voltage regulator. What would > be the function of the switch? > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Apr 29, 2002
Subject: Re: Charging one of two dual batteries
> > >About a week ago there was a discussion of charging the AUX battery in a two >battery all electronic system. If Figure Z-4 is used for the charging system >and the Aux battery drains for some unknown reason, then you must be able to >get to the aux battery with a charger to bring it back on line. > >A worse scenario is that I fly into a field with no service and the grandson >turns on either the aux or main master (I would never fail to follow the >shutdown procedure) and one battery is discharged. In that situation, I >could start the engine with one battery, but never recharge the dead >battery! How do you walk away from an airplane that has a nice, bright, LOW VOLTS light flashing at you? >To remedy this possibility, why not make the aux and main contactors look >just like the crossover contactor with the three diodes. Then if either >battery will start the engine, the alternators will charge the dead battery >once the engine is running. You could do that. >The dead battery will not pull the good battery down before the engine >starts because it will not draw current until its input voltage is about >13.5V, which only happens after the engine has started. Dead batteries don't pull down good batteries . . . the watt-seconds of energy that transfers on initial connection is quite small compared to the capacity of the good battery. The good battery will deliver energy at 12.5 or below, the discharged battery needs 13.0 and higher to take on any significant charge. >Even if the pilot did not know one battery was dead, started the engine with >the normal procedure, the aux master would turn on and the >alternator/regulator would probably begin charging the dead battery as soon >as the engine started even if the pilot opened the cross-contactor. If the >pilot noticed the low voltage light, he would probably leave the cross-over >closed for 5-10 minutes to charge the battery with both alternators to >insure the battery had enough energy to maintain the regulator function, >then turn the cross-over off. Don't need a third contactor . . . just use 4-terminal, continuous duty contactors like our S702-2 (two diodes drive the [+] side of the coil from both the battery and the bus side of each battery master). The battery contactor can then be closed using either the battery or whatever is on the bus from the other battery. Bob . . . ________________________________________________________________________________
Date: Apr 29, 2002
Subject: who can do what to an experimental aircraft
In a message dated 04/29/2002 2:52:50 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "Cy Galley" From: "Cy Galley" <cgalley(at)qcbc.org>
Subject: Re: who can do what to an experimental aircraft
Date: Apr 29, 2002
You are still right, but I NEVER said that what I wrote about pertained to experimental. I just pointed out the weirdness of the FAA regs. ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: who can do what to an experimental aircraft In a message dated 04/29/2002 2:52:50 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "Cy Galley" http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: hand held question
Date: Apr 30, 2002
22, 2000) at 04/30/2002 10:43:31 AM In your reply below, do the zeners go from the + input to ground? Thanks, Larry Dodge RV16LD >I have made the sin of shutting off the battrey master before shutting >the engine (912 Rotax). my handheld transceiver................................. If I were going to tie any hand helds into ship's power, I would probably use a Radio Shack 270-030 noise filter downstream of a small fuse (1A) and then put a couple of 1N4745, glass zener diodes across the output feeding the radio. .............................. Bob . . . ________________________________________________________________________________
Subject: Starter solenoid
Date: Apr 30, 2002
Hi All, I've heard about starter solenoids wich have a diode included against electric arcs. It seems they are very different from the convential STANCOR contactor that we can buy and find everywhere. Does anybody know a trademark name for this type of product and where I can purchase one of it ? Thanks for your help. Vincent. France ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Space shuttle electric power system design
I recently discovered this NASA website containing fascinating information about the space shuttle: http://www.shuttlepresskit.com/STS-105/scom.htm Of particular interest to this list is the document http://www.shuttlepresskit.com/scom/28.pdf which describes (starting on page 20) the shuttle's electrical system. Adobe Acrobat is required to view these documents. Enjoy. Mark Milgrom ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Apr 30, 2002
I've used solenoids with diodes included that are made by Kissling, a German Company. They'll set you back quite a bit more than the $14 solenoids from Aircraft Spruce. David Swartzendruber Wichita > Hi All, > > I've heard about starter solenoids wich have a diode included > against electric arcs. It seems they are very different from > the convential STANCOR contactor that we can buy and find everywhere. > > Does anybody know a trademark name for this type of product > and where I can purchase one of it ? > > Thanks for your help. > > Vincent. > France > ________________________________________________________________________________
From: "Peter Laurence" <plaurence(at)worldnet.att.net>
Subject: Frustrated
Date: Apr 30, 2002
Please forgive me for using this forum for a soapbox. But, I need to vent. I decided to tackle Jim Weir's dimmer circuit that was published in Kitplanes. I need some clarification on a subject and sent him an email. His response was (take my course ans find out. Recently, I tryed to get so some information on another item pertaining to the dimmer . With no respnse I sent him several emails. Subsequently, I snail mailed him a cad drawing I had done for a circuit board for this dimmer asking for an evauation with a willingness to pay for his consultation time.I even enclosed a self addressed envelope. I realize that Mr. Weir is probable a busy person running a business. However, If he chooses to take on a column in Kitplanes, he should demonstrate some responsibilty to his readers. ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Re: Frustrated
> > > >Please forgive me for using this forum for a soapbox. But, I need to vent. >I decided to tackle Jim Weir's dimmer circuit that was published in >Kitplanes. I need some clarification on a subject and sent him an email. His >response was (take my course ans find out. Recently, I tryed to get so some >information on another item pertaining to the dimmer . With no respnse I >sent him several emails. Subsequently, I snail mailed him a cad drawing I >had done for a circuit board for this dimmer asking for an evauation with a >willingness to pay for his consultation time.I even enclosed a self >addressed envelope. > >I realize that Mr. Weir is probable a busy person running a business. >However, If he chooses to take on a column in Kitplanes, he should >demonstrate some responsibilty to his readers. If one chooses to be a simple disseminator of information, "responsibility" can certainly be limited to making sure the presentation is accurate. It matters not that the data appears in an encyclopedia, magazine article or web-page. However, if one chooses to be a teacher, then responsibilities are broader. A teacher wants to know that the information is understood and offers extra effort as needed to advance understanding. The greatest joy a teacher can experience is to see the successful application of knowledge to the benefit of those who have applied themselves and were willing to learn. I am not familiar with the article you cited. Is it accessible from the 'net? If not, can you e-mail or fax me a copy. Let's see if we can run this confusion =AND= frustration to ground. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Re: Starter solenoid - Internal diodes
> >Hi All, > >I've heard about starter solenoids wich have a diode included >against electric arcs. It seems they are very different from the convential >STANCOR contactor that we can buy and find everywhere. > >Does anybody know a trademark name for this type of product and where >I can purchase one of it ? > >Thanks for your help. > >Vincent. >France It's a toss up. Many of the off-the-shelf automotive contactors I've researched have a diode installed. If they do, they'll be marked on the box or somewhere on the device that a diode is included. The S702-1 contactor offered from our website does include the built in diode. If you have an automotive contactor that is not so marked, then it's easy to take advantage of the superior characteristics of the product by adding your own diode. A 1N5400 series device (3A, 50V or more) is just fine. Radio Shack sells them here in states for about $1.25 in a package of 2 diodes. These are the same diodes we include externally on our S701-1 contactors which you can see at: http://www.aeroelectric.com/Catalog/switch/s701-1l.jpg I'd go to the car-parts store and look at all the offerings of starter contactors. If they look like: http://www.aeroelectric.com/Catalog/switch/s702-1l.jpg . . . then check the box and/or markings on the base of the device to see if the word "diode" is mentioned. If you find one so marked, fine and dandy. If you can't find one at the first store, I'm not sure I'd spend much time looking . . . adding the diode is cheap and easy. Bob . . . ________________________________________________________________________________
Subject: Re: ignition system noise
Date: Apr 30, 2002
Bob, Sorry, I wasn't very clear in my message. I was wondering about the possibility of substitution of wire normally used for ignition p-leads in place of his RF coax cable. It seemed you had issues with the use of coax as a shielded wire for non-RF uses. Russ ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: ignition system noise > > > > >Just a thought, but how about the shielded wire normally used for wiring > >mags? > > > >Russ > > I'm sorry, I don't understand the question. . . > we were talking about perceived value of adding > capacitors to the input power of CDI ignitions > and using RF grade coax as shielded wire. I'm > not sure what you're asking here. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Apr 30, 2002
> >Bob, > >Sorry, I wasn't very clear in my message. I was wondering about the >possibility of substitution of wire normally used for ignition p-leads in >place of his RF coax cable. It seemed you had issues with the use of coax >as a shielded wire for non-RF uses. I can see no reason why a modern (Tefzel and cousins) shielded wire cannot be used in this application. Since the black box is fitted with BNC connectors, your biggest problem is to find a BNC connector for smaller shielded wire -AND- a tool to install them. It might be more trouble to find substitute materials and tooling than it is to simply go with RG-400 coax . . . this gets you around the problems everyone is reporting with the easy-to-melt RG-58 and you'll be able to readily obtain matching connectors and tooling. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Re: hand held question
> >In your reply below, do the zeners go from the + input to ground? > >Thanks, > >Larry Dodge >RV16LD > > > >I have made the sin of shutting off the battrey master before shutting > >the engine (912 Rotax). my handheld >transceiver................................. > > If I were going to tie any hand helds into ship's power, > I would probably use a Radio Shack 270-030 noise filter > downstream of a small fuse (1A) and then put a couple > of 1N4745, glass zener diodes across the output feeding > the radio. > > .............................. I used to have a schematic of this filter . . . it was published on my website some years ago but I've lost it. Let's see if I can be lucid with words: 207-030 inductor goes in series with the power to the radio. Capacitor from the kit goes from the downstream (radio) side of inductor to power ground. Observe polarity markings on capacitor. I'd put two zeners across the capacitor to serve as sacrificial crowbar ov protection . . . one would do in most cases but their cheap and the second one doesn't hurt and would stand in for the first if it should fracture. The banded end of the zener goes to the (+) side of the capacitor. ________________________________________________________________________________
Subject: Hidden Switch Question Rephrased
Date: Apr 30, 2002
> Sorry, I messed up. I should have said the wire from the Battery Contactor > solenoid to the Master Switch that grounds the solenoid and closes the Bat > Con switch. > Rick > > > >5) One last question on another topic. With dual ignition and dual > > >batteries in the back, I want to put a hidden switch on the line from > > >main bat/con solenoid to the voltage regulator. What would work best, a > > >toggle switch, toggle switch with fuse, re-settable cb, or cb switch? > > > > I'm not visualizing what wire you're talking > > about. I'm not aware of any wire that runs from the battery > > contactors directly to the voltage regulator. What would > > be the function of the switch? > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Altimeter certification
The discussion on who can work on instruments for an experimental aircraft raises the following question: If I build my own glass cockpit display and use a digital readout of a certified altitude encoder to display altitude (corrected for altimeter setting): - Can I find someone to sign off an altimeter check on it? - Am I legal to fly IFR? My assumption on both is yes, but it appears to be a fuzzy area. I could not get a straight answer from the FAA people at Oshkosh booths last year. The answer I got was I would have to talk to the certification people in the FAA (which did not make sense to me, since they worry about certified aircraft). Tony Cann ________________________________________________________________________________
Subject: Weak radio transmission
Date: Apr 30, 2002
I have a Icom panel mount radio, reception is poor on the ground, fair in the air. When flying at cruise 150 MPH, receiver and transmitter are bearly readable with no transmission over 5 miles or so. Slow down enter the pattern receiver is better transmitter is still weak but readable. Where do I begin? Are there things I can do or is it time to visit the radio shop? Al ======================================================================= http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Re: Weak radio transmission
> >I have a Icom panel mount radio, reception is poor on the ground, fair in >the air. When flying at cruise 150 MPH, receiver and transmitter are bearly >readable with no transmission over 5 miles or so. Slow down enter the >pattern receiver is better transmitter is still weak but readable. >Where do I begin? Are there things I can do or is it time to visit the radio >shop? >Al I'd start with checking the antenna and coax cable connections. Run end to end continuity checks on the coax center conductor and shield . . . and make sure they're not shorted to each other. Is this a new condition or always been this way? I'd put some kind of performance analysis device on the antenna. I keep one of these things around for checking out antennas and transmission lines: http://www.mfjenterprises.com/products.php?prodid=MFJ-259B If you're not inclined to add such a critter to your toolbox, then a trip to the shop for a quick look-see at the antenna with their test equipment would be in order. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2002
Subject: Re: Hidden Switch Question Rephrased
> Hidden switch? I presume this is for some form of security function . . . the kind of switch is immaterial . . . > > Sorry, I messed up. I should have said the wire from the Battery >Contactor > > solenoid to the Master Switch that grounds the solenoid and closes the Bat > > Con switch. > > Rick > > > > > >5) One last question on another topic. With dual ignition and dual > > > >batteries in the back, I want to put a hidden switch on the line from > > > >main bat/con solenoid to the voltage regulator. What would work best, a > > > >toggle switch, toggle switch with fuse, re-settable cb, or cb switch? > > > > > > I'm not visualizing what wire you're talking > > > about. I'm not aware of any wire that runs from the battery > > > contactors directly to the voltage regulator. What would > > > be the function of the switch Bob . . . ________________________________________________________________________________
Date: May 01, 2002
message posted by: "Peter Laurence" > > > Please forgive me for using this forum for a soapbox. But, I need to vent. > I decided to tackle Jim Weir's dimmer circuit that was published in > Kitplanes. I need some clarification on a subject and sent him an email. His > response was (take my course ans find out. Recently, I tryed to get so some > information on another item pertaining to the dimmer . With no respnse I > sent him several emails. Subsequently, I snail mailed him a cad drawing I > had done for a circuit board for this dimmer asking for an evauation with a > willingness to pay for his consultation time.I even enclosed a self > addressed envelope. > > I realize that Mr. Weir is probable a busy person running a business. > However, If he chooses to take on a column in Kitplanes, he should > demonstrate some responsibilty to his readers. I'm not surprised: I had a similar run-in with Mr Weir over the question of burying a copper tape antenna in the wing of my Europa specifically for a handheld nav/com - although he did reply (post a message on alt.rec.homebuilt and I might answer - he never did) The truth of the matter is that you have to make a judgement call on the confidence you have on the information in magazines (and elsewhere - like the 'net) - it's the reason I decided not to renew my EAA membership: the only benefit I get is the magazine (I live in England) and there were too many stories that I felt were inaccurate, or missed the point, or were just plain wrong... (as detailed by Bob in the past) As it happens, I believe Jim Weir's info is fairly solid, but as he's pretty much unapproachable, it's sometimes not that useful when you want to tailor something specifically to your needs or wishes - in direct contrast to Bob and the aeroelectric list. I'm probably interested in about 5% of the traffic on this list, but the participants are clearly a clever lot and throw up all sorts of questions (and answers) that you never thought to ask - as well as catch Bob out occasionally! The fact that he sticks his hand up right away and will issue a correction to all by return gives me 100% confidence in the information here. The philosophy, wiring architecture, and most of the components for the electrical system of my Europa are pure aeroelectric connection. Miles Miles McCallum Technical editor, FLYER magazine www.flyer.co.uk ________________________________________________________________________________
Subject: Re: remote vs. local strobe supply?
Date: May 01, 2002
Please forgive me for using this forum for a soapbox. But, I need to vent. I decided to tackle Jim Weir's dimmer circuit that was published in Kitplanes. I need some clarification on a subject and sent him an email. His response was (take my course ans find out. Recently, I tryed to get so some information on another item pertaining to the dimmer . With no respnse I sent him several emails. Subsequently, I snail mailed him a cad drawing I had done for a circuit board for this dimmer asking for an evauation with a willingness to pay for his consultation time.I even enclosed a self addressed envelope. I realize that Mr. Weir is probable a busy person running a business. However, If he chooses to take on a column in Kitplanes, he should demonstrate some responsibilty to his readers. Sorry for this abrupt end--A glitch- to continue; I have sent Bob Nuckolls several emails in the past and he has answered every one of them. I have also called him by telephone. He has always been willing to talk and answer my not so astute questions. He is always been helpful and gracious OK I'm done. Peter Laurence > ________________________________________________________________________________
Date: May 01, 2002
Subject: 3-terminal contactor for alternator disconnect?
Bob: Confusion Abounds-- I have a OVM-14 to use with a 40 amp internal regulated alternator. I also have a 70-111226 master relay with 3 leads. Can I use this relay in the system??? If so please help me with the wiring. (I am aware of the S701-1 relay, but I have the master relay) You need a 4-terminal contactor like the one shown on our website to do this task . . . The contactor needs to energize by pulling-up-to bus as opposed to pulling down to ground. Another question??? If the OVM-14 is connected, as is done with an external regulator, to the IG lead to the alternator--this should "kick out" the alternator in an overvoltage condition. The OVM-14 would go to ground, thus the 5 amp breaker would see the ground and trip? Or is this NOT the way to go???? Of course the alternator is still in the circuit--is it possible that the alternator can still produce power if the IG has no voltage to it??? There are probably failure modes within the altenrator that will allow the machine to produce uncontrolled output in spite of having removed +12 v from the IG lead. This is why we have to add the external contactor. Bob . . . ________________________________________________________________________________
Date: May 01, 2002
Subject: Re: Space shuttle electric power system design
> > >I recently discovered this NASA website containing fascinating >information about the space shuttle: > > http://www.shuttlepresskit.com/STS-105/scom.htm > >Of particular interest to this list is the document >http://www.shuttlepresskit.com/scom/28.pdf which describes (starting on >page 20) the shuttle's electrical system. > >Adobe Acrobat is required to view these documents. Enjoy. Thanks for the heads-up on this one. I've captured the document for future reference . . . some of those distribution control panels look like a mis-positioned switch looking for someplace to liven up someone's day . . . Bob . . . ________________________________________________________________________________
Date: May 01, 2002
Subject: IFR Cert
In a message dated 05/01/2002 2:52:28 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com writes: "The discussion on who can work on instruments for an experimental aircraft raises the following question: If I build my own glass cockpit display and use a digital readout of a certified altitude encoder to display altitude (corrected for altimeter setting): - Can I find someone to sign off an altimeter check on it? - Am I legal to fly IFR? My assumption on both is yes, but it appears to be a fuzzy area. I could not get a straight answer from the FAA people at Oshkosh booths last year. The answer I got was I would have to talk to the certification people in the FAA (which did not make sense to me, since they worry about certified aircraft). Tony Cann" 5/1/2002 Hello Tony, Yes there may be a bit of fuzz on your situation and maybe a significant technical problem. 1) You are probably wasting your time asking hypothetical questions of most FAA employees about experimental aircraft. The only blood that flows through their brain is standard type certificated aircraft blood. It is not necessarily their fault. Their regulations, their orders, and their training are created / conducted by lawyers and bureaucrats who usually think only in terms of standard type certificated aircraft. It is difficult for them (and for us) to remember and try to figure out which regulations apply to experimental aircraft and which ones don't. Unfortunately each individual Part of the regulations do not make clear their coverage or exclusions. 2) Whether or not you will get your IFR cert can only be answered by the person / agency who conducts the tests required by the FARs on your airplane. Appendix E to Part 43 specifies the tests and criteria that your equipment must meet. Will your equipment meet those criteria? If you know that it will not even before you go to the tester then you are on a futile mission. 3) Question: I'm not an electronicly oriented person, but I'm under the impression that encoders only put out digital altitude (actually flight level) information in 100 foot intervals. Does this mean that your cockpit read out will also only be in 100 foot intervals? If so, you can see by the tables and other info in Appendix E to FAR Part 43 that the equipment will not meet the testing criteria since many of the tolerances are much less than 100 feet. 4) The general rule of thumb (can be found in some FAA pubs, but I can't find it in any FAR) is that an altimeter that shows greater than a 75 foot error on the ground before flight is not considered reliable. Friction tolerance in Table III of Appendix E to Part 43 is plus or minus 70 feet up to 5,000 feet. I'd appreciate your (and anyone else's) response to the above. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Rotax912ULS Alternator?
Date: May 01, 2002
Bob, Received your book and WOW its a wealth of knowledge. Since I have not received my engine (Rotax 912ULS) for our Skystar Kitfox Lite2. I was wondering if you knew the Alternator configuration that comes standard. I have been able to find from their web page that it is a 40A alternator, but is it a permanent Magnet type with built in regulator, or can I use your Alternator controller as the regulator on this Rotax engine. I will be using the main bus/essential bus system as outlined in you book. Thanks for creating a book that is easy to understand and also your great Web Page that is chuck full of how-to aviation stuff. Thanks for your reply in advance In Las Vegas The Banks Brothers Bruce ________________________________________________________________________________
Date: May 01, 2002
Subject: Special buy on dimmer rheostats
We've picked up a small quantity of dimming rheostats that are similar to the devices used for single-lamp panel dimming in the overhead of many Cessna single engine aircraft. Check it out on http://www.aeroelectric.com/Catalog/AECcatalog.html Bob . . . ________________________________________________________________________________
Subject: Switch Physical Dimensions?
Date: May 01, 2002
Bob, Can you please provide the physical dimensions for the S700 series of switches, or a location to find the dimensions? I'm interested in space required behind the panel as well as how "full-size bat-handle actuators" compare to bat-handle actuators of typical (Potter & Brumfield) switch-breakers? Thanks, Roy Thoma ________________________________________________________________________________
Date: May 01, 2002
> >Can you please provide the physical dimensions for the S700 series of >switches, or a location to find the dimensions? http://www.aeroelectric.com/Catalog/switch/s700dwg.jpg > I'm interested in space >required behind the panel as well as how "full-size bat-handle >actuators" compare to bat-handle actuators of typical (Potter & >Brumfield) switch-breakers? Uggghhh! please don't use switch-breakers . . . Bob. . . ________________________________________________________________________________
Date: May 01, 2002
Subject: Re: Rotax912ULS Alternator?
> >Bob, > >Received your book and WOW its a wealth of knowledge. Since I have not >received my engine (Rotax 912ULS) for our Skystar Kitfox Lite2. I was >wondering if you knew the Alternator configuration that comes standard. I >have been able to find from their web page that it is a 40A alternator, but >is it a permanent Magnet type with built in regulator, or can I use your >Alternator controller as the regulator on this Rotax engine. I will be >using the main bus/essential bus system as outlined in you book. >Thanks for creating a book that is easy to understand and also your great >Web Page that is chuck full of how-to aviation stuff. Thank you for the kind words. I'm pleased that you are pleased with your purchase. The power distribution diagram and alternator wiring depicted in Figure Z-16 is applicable to the 250 watt PM alternator. I downloaded a data sheet at: http://www.kodiakbs.com/engines/datasheets/912S.pdf This publication clearly shows a small, probably Nipon Denso alternator belt driven from a pulley behind the prop flange. I suspect this is an optional feature. If you choose to buy this feature (assuming it fits under your cowl) then wiring diagram Z-13 would be more appropriate and allow you to run both alternators with the 250 W machine backing up the larger one. Bob . . . ________________________________________________________________________________
Date: May 01, 2002
Bruce, Bob is correct that the standard PM alternator for the Rotax 912ULS is 250W (18A nominal). Rotax and other offer a belt driven 40A alternator as an option. The optional alternator I have came from Aircarft Sales and Parts in Vernon B.C. Canada. Ph (250) 549-1102. email asap(at)junction.net. [I have no affiliation with ASAP and bought my alternator from one of the large Rotax distributors.] The after market optional alternators appear to be much less expensive than the Rotax option. It MAY be possible to get all the parts of a second alternator kit EXCEPT the (internally regulated) alternator and then order the B&C alternator which requires the external regulator. Bob: I'm having a difficult time choosing between using a battery contactor (as in Z-16) or not (as in Z-17). What's the criteria for including the battery contactor? [I'm building an Zenair 601HDS with a Rotax 912S. All electric, night and IFR legal, optional 40A ND alternator in addition to the 18A Rotax Dynamo. Single Nav/GPS/Com, xponder, and intercom, Voltmeter/Loadmeter, integrated Engine Instrument System, and capacitive fuel gauges. 85% done. 50% to go.] Thanks for your contributions to this community. Regards, Roy Thoma ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Rotax912ULS Alternator? > > > > >Bob, > > > >Received your book and WOW its a wealth of knowledge. Since I have not > >received my engine (Rotax 912ULS) for our Skystar Kitfox Lite2. I was > >wondering if you knew the Alternator configuration that comes standard. I > >have been able to find from their web page that it is a 40A alternator, but > >is it a permanent Magnet type with built in regulator, or can I use your > >Alternator controller as the regulator on this Rotax engine. I will be > >using the main bus/essential bus system as outlined in you book. > >Thanks for creating a book that is easy to understand and also your great > >Web Page that is chuck full of how-to aviation stuff. > > Thank you for the kind words. I'm pleased that you are > pleased with your purchase. The power distribution diagram > and alternator wiring depicted in Figure Z-16 is applicable > to the 250 watt PM alternator. I downloaded a data sheet > at: > > http://www.kodiakbs.com/engines/datasheets/912S.pdf > > > This publication clearly shows a small, probably Nipon Denso > alternator belt driven from a pulley behind the prop flange. > I suspect this is an optional feature. > > If you choose to buy this feature (assuming it fits under > your cowl) then wiring diagram Z-13 would be more appropriate > and allow you to run both alternators with the 250 W > machine backing up the larger one. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Re: IFR Cert
Date: May 01, 2002
BAKEROCB(at)aol.com wrote: > > 1) You are probably wasting your time asking hypothetical questions of most > FAA employees about experimental aircraft. The only blood that flows through > their brain is standard type certificated aircraft blood. It is not *** Which brings up a historical something I've been wondering about: * How and when did the US government get into the business of "certificating" aircraft? Was it a particular horrific accident? What was the first airplane to be "certificated"? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 01, 2002
THIS IS SPAM GET ME OFF THIS. NOW ----- Original Message ----- From: <jerry(at)tr2.com> Subject: Re: AeroElectric-List: IFR Cert > > BAKEROCB(at)aol.com wrote: > > > > 1) You are probably wasting your time asking hypothetical questions of most > > FAA employees about experimental aircraft. The only blood that flows through > > their brain is standard type certificated aircraft blood. It is not > > *** Which brings up a historical something I've been wondering about: > > * How and when did the US government get into the business of > "certificating" aircraft? Was it a particular horrific accident? What > was the first airplane to be "certificated"? > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 01, 2002
Subject: Re: Switch Physical Dimensions?
Dear Bob: Could you elaborate on this? At first thought, a toggle switch that is also a circuit breaker seems attractive. What am I missing? Thanks. Robert Miller "Robert L. Nuckolls, III" wrote: > Uggghhh! please don't use switch-breakers . . . > > Bob. . . > > ________________________________________________________________________________
Date: May 01, 2002
Hi Bob, As you suggested , I did the continuity check first and that was the problem. The center conductor had a wisker that missed the pin and was shorting. Thank You for your help, not only for this question but all the questions of mine that others have asked and you have answered. Al "Moose" N526AP (19 hrs) ________________________________________________________________________________
Date: May 01, 2002
> >BAKEROCB(at)aol.com wrote: > > > > 1) You are probably wasting your time asking hypothetical questions of > most > > FAA employees about experimental aircraft. The only blood that flows > through > > their brain is standard type certificated aircraft blood. It is not > >*** Which brings up a historical something I've been wondering about: > > * How and when did the US government get into the business of > "certificating" aircraft? Was it a particular horrific accident? What > was the first airplane to be "certificated"? http://www.faa.gov/apa/history/briefhistory.htm tells us that, "The Air Commerce Act of May 20, 1926, was the cornerstone of the Federal government's regulation of civil aviation. The Act charged the Secretary of Commerce with fostering air commerce, issuing and enforcing air traffic rules, licensing pilots, certificating aircraft, establishing airways, and operating and maintaining aids to air navigation." http://users.mfi.net//~stearman/airshow/model4.html This website talks about the first airplane to be certified with a 300 hp P/W Wasp engine. This was in 1926. Since 1926 was the year that the Air Commerce Act One can presume there were earlier instances of "certification" Here's a piece that speaks to the Civil Aeronautics Act of 1938 that created the CAA. The piece says, "Until that time, numerous government agencies and departments had a hand in aviation policy." http://www.air-transport.org/public/publications/display1.asp?nid=961 Bob . . . ________________________________________________________________________________
Subject: Radio difficulties
Date: May 01, 2002
Bob Nuckolls reply to Al and Deb Paxhia (regarding radio trouble): "I'd put some kind of performance analysis device on the antenna. I keep one of these things around for checking out antennas and transmission lines: http://www.mfjenterprises.com/products.php?prodid=MFJ-259B If you're not inclined to add such a critter to your toolbox, then a trip to the shop for a quick look-see at the antenna with their test equipment would be in order." ... quite agree that 95% of radio troubles stem from poor or neglected coaxial cable fittings. However, one warning: read the instructions of the MFJ259B Verrry carefully - and you will note that it must only measure the antenna and system - no signal on the radio. Many make the mistake of 'trying' the transmitter with the 259 still attached. MFJ will be glad to fix it for $100 or more...................... I have one for our Amateur Radio club, but I use it on their systems because of the ease with which they 'blow'. Not to put radio techs out of work, but your local Ham Radio club probably has someone who might be inclined to chase up your troubles. www.arrl.org, "find on this site" - "Clubs". Ferg Kyle Europa A064 ________________________________________________________________________________
Subject: Questions on last chapter of Aeroelectric Book
Date: May 01, 2002
Hi Bob, I finished reading the book and have questions on items 2 and 3 from page 16-16: Item 2) - you talk about a brass stud in the firewall to connect the negative terminal of the battery to the engine crankcase. Is this for composite airplanes only or metal ones too? Item 3) - You say to run "DC power & control around the left side of the cockpit". My RV3 will have two batteries in back but the trim cable and throttle and mixture quadrant are on the left side. I think I heard somewhere that power wires should not be run on the same side of fuselage as these flight controlcables for some electrical reason???? Even if that is not the case, it would be harder to run the wires and not conflict with the control cables. What do you think? ________________________________________________________________________________
Subject: Yuasa battery
Date: May 01, 2002
Hi Bob, The Yuasa NP 12-12 battery looks like just the ticket for my day VFR only RV3 (dual ignition, dual batteries in the back, B&C alternator, regulator, and alternator) with modest electrical needs. It only weighs 8.8 lbs, has dimensions of only 5.9 X 3.9 X 3.8 inches, and has a 12 Ahr capacity. Their small size and weight is great for having two in back. Their 2 X 12 Ahr capacity would give plenty of cranking and flying capacity with 24 Ahr total. And their cost of only $47 each makes changing out one each year easy to take! Tell me there's nothing wrong with it! Thanks, Rick Fogerson RV3 fuselage Boise, ID ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: sec: unclassified - MAINTAINING IFR SYSTEMS
Date: May 02, 2002
Folks, There has been talk about maintenance of instruments for IFR use. Some useful references are: FAR 91.411, 91.413, Part 43 Appendixes D and E. If you are the manufacturer of the aircraft you are one of the eligible persons to do test and maintenance, subject I suppose to skill and equipment. Here in Australia, which usually calls up FAR as references, experimental aircraft do not have to have certified instruments, but do need to meet the accuracy and maintenance requirements in them. Some manufacturers are refusing to certify to a TSO or FAR, but do build and test to the FAR or TSO. They can market the product cheaper by passing product liability on to the aircraft manufacturer, who is us. Hence price reductions of 30% or more, due to the absence of product liability insurance. The make the product test data available so you and the inspectors can be satisfied the equipment meets the mandated IFR accuracy requirements, even though not formally certified. The following data is drawn from a Kitplanes article about calibrating ASIs, which can be done with a simple water manometer. I do not know where the accuracy requirement for ASI is in the FAR. The table below is from the article, which quoted prime source as AN 05-10-24. The date of the Kitplanes article is not visible in the photocopy I have. I hope this data helps someone, somewhere. David Francis,Canberra, Australia, VH-ZEE Knots Water InchesMPH Knots Water In PSI 50 1.63 50 43 1.26 0.042 60 2.35 70 60 2.47 0.084 70 3.21 90 77 4.09 0.139 80 4.19 110 95 6.11 0.207 90 5.31 130 112 8.53 0.29 100 6.56 150 129 11.4 0.388 110 7.95 120 9.48 130 11.14 140 12.94 150 14.87 160 16.95 170 19.17 180 21.54 190 24.05 200 26.71 210 29.51 220 32.47 230 35.58 240 38.84 250 42.27 ____ ----- Original Message ----- From: "Mark C. Milgrom" <milgrom(at)earthlink.net> Subject: AeroElectric-List: Space shuttle electric power system design > > I recently discovered this NASA website containing fascinating > information about the space shuttle: > > http://www.shuttlepresskit.com/STS-105/scom.htm > > Of particular interest to this list is the document > http://www.shuttlepresskit.com/scom/28.pdf which describes (starting on > page 20) the shuttle's electrical system. > > _____________________________________________________________________ From: Tony Cann <tony.cann(at)sun.com> Subject: AeroElectric-List: Altimeter certification The discussion on who can work on instruments for an experimental aircraft raises the following question: If I build my own glass cockpit display and use a digital readout of a certified altitude encoder to display altitude (corrected for altimeter setting): - Can I find someone to sign off an altimeter check on it? - Am I legal to fly IFR? My assumption on both is yes, but it appears to be a fuzzy area. I could not get a straight answer from the FAA people at Oshkosh booths last year. The answer I got was I would have to talk to the certification people in the FAA (which did not make sense to me, since they worry about certified aircraft). Tony Cann ____ From: "Al & Deb Paxhia" <paxhia2(at)attbi.com> Subject: AeroElectric-List: Weak radio transmission - ======================================================================= http://www.matronics.com/browselist/aeroelectric-list > > ____ ________________________________________________________________________________
Date: May 02, 2002
Subject: Re: Yuasa battery
> > >Hi Bob, >The Yuasa NP 12-12 battery looks like just the ticket for my day VFR >only RV3 (dual ignition, dual batteries in the back, B&C alternator, >regulator, and alternator) with modest electrical needs. > >It only weighs 8.8 lbs, has dimensions of only 5.9 X 3.9 X 3.8 inches, >and has a 12 Ahr capacity. Their small size and weight is great for >having two in back. Their 2 X 12 Ahr capacity would give plenty of >cranking and flying capacity with 24 Ahr total. And their cost of only >$47 each makes changing out one each year easy to take! > >Tell me there's nothing wrong with it! Click on : http://www.batteryweb.com/yuasa.cfm . . . and then click on the linked terminals callouts for any battery with an "F1" terminal. The F1 style is a .187" faston tab that is far shy of that required to deliver hundreds of amps of cranking current. The smallest common battery with "NB" or "HP" style terminals is the NP18-12B which is functionally interchangeable with a dozen brands offering the same style and capacity of battery. Bob . . . ________________________________________________________________________________
Date: May 02, 2002
Subject: Re: Switch-breakers . . .
> > >Dear Bob: > >Could you elaborate on this? At first thought, a toggle switch that is >also a circuit >breaker seems attractive. What am I missing? >Thanks. >Robert Miller > >"Robert L. Nuckolls, III" wrote: > > > Uggghhh! please don't use switch-breakers . . . > > > > Bob. . . Circuit protection is used to tap a bus and distribute power to a useful location. If you have a row of switch-breakers on the panel, now you've created a bus behind the panel that is probably in addition to the ones already a part of fuse blocks. If you're using breakers throughout the system, then the inclusion of switch-breakers forces you to fabricate a bus on the right side for the non-switching breakers and another bus on the left side for all the switch breakers. Fuseblocks keep the busses off the panel and provide you with an convenient, compact, low parts count, bolt-on alternative to the high parts count, costly, laborious and real estate hungry breaker panels. See also http://209.134.106.21/articles/fuseorcb.html It's not that a switch-breaker is an inherently evil device . . . but its use forces design issues counter productive to the fabrication of low cost, failure tolerant, easy to maintain systems. Bob . . . ________________________________________________________________________________
Date: May 02, 2002
Subject: Re: Questions on last chapter of Aeroelectric Book
> > >Hi Bob, >I finished reading the book and have questions on items 2 and 3 from >page 16-16: > >Item 2) - you talk about a brass stud in the firewall to connect the >negative terminal of the battery to the engine crankcase. Is this for >composite airplanes only or metal ones too? Metal too . . . but with rear mounted batteries in a metal airplane, you can ground the batteries to structure locally -OR- run a battery ground to the firewall stud. >Item 3) - You say to run "DC power & control around the left side of the >cockpit". My RV3 will have two batteries in back but the trim cable and >throttle and mixture quadrant are on the left side. I think I heard >somewhere that power wires should not be run on the same side of >fuselage as these flight controlcables for some electrical reason???? >Even if that is not the case, it would be harder to run the wires and >not conflict with the control cables. What do you think? > Don't know why anyone would say this. Wires, controls, plumbing and black boxes have lived in close proximity to each other in the confined spaces of airplanes for years. There are mechanical considerations for installation that are observed to prevent interference with each others functions but I can think of no practical reason why one take pains to avoid sharing spaces. Note 3 suggests that power and signal wiring not share spaces for noise-mitigation . . . but failure to observe this is not an automatic guarantee of noise problems either. It's just something easy to do on initial installation that eliminates a hard-to-track-down-and-fix possibility should a noise problem arise later. Bob . . . ________________________________________________________________________________
Date: May 02, 2002
Subject: Yak electrics
Hello all ! Can anyone explain the generator system of the Yak 50/52 to me ? It is the original russian design. I am a Yak 50 operator in Germany. thanks Henning DE Bremen / Germany ________________________________________________________________________________
Subject: Altitude tolerance
Date: May 02, 2002
"4) The general rule of thumb (can be found in some FAA pubs, but I can't find it in any FAR) is that an altimeter that shows greater than a 75 foot error on the ground before flight is not considered reliable. Friction tolerance in Table III of Appendix E to Part 43 is plus or minus 70 feet up to 5,000 feet." We were given this reason years ago why we must demonstrate handflying transports within 50 feet of required altitude - to allow for 50% error in handling. The idiots didn't specify the time interval, so most instructors used to skip anything longer than about 10 seconds at 37,000 feet. It finally died. Imagine losing capability for twelve hours. Ferg Kyle Europa A064 ________________________________________________________________________________
Date: May 02, 2002
Subject: Re: Yak electrics
> >Hello all ! > >Can anyone explain the generator system of the Yak 50/52 to me ? >It is the original russian design. >I am a Yak 50 operator in Germany. > >thanks > >Henning DE >Bremen / Germany Not sure of what your question is. The operation of generators as a power source for a vehicle of any type is a rudimentary technology. Any number of tutorials on automotive generators would explain the theory, operation and practical maintenance in detail. Is there some feature of the Yak 50 system unique to the aircraft? One would have to have a copy of the wiring diagrams (which I do not have) to address these kinds of questions. Bob . . . ________________________________________________________________________________
Date: May 02, 2002
Well Robert, thanks for your response, but yes, the Yak system is a kind of special ( at least to me ). For example, there is a voltage regulator wich I hav not jet seen. You maybe know it as a carbon pile regulator. This is 1950`electrics, and completely unknown to germans. And so the story goes on and on. As far as I can tell, and I am pretty familiar with electrics, this system is completely diferent from anything i have seen. The basics may be the same, but thats it ! Russian technology..... Any help is welcome ! Henning DE Bremen/Germany ________________________________________________________________________________
Date: May 02, 2002
H30Damm(at)aol.com wrote: > > > Well Robert, > thanks for your response, but yes, the Yak system is a kind of special ( at least to me ). > For example, there is a voltage regulator wich I hav not jet seen. You maybe know it as a carbon pile regulator. This is 1950`electrics, and completely unknown to germans. > And so the story goes on and on. As far as I can tell, and I am pretty familiar with electrics, this system is completely diferent from anything i have seen. > The basics may be the same, but thats it ! > Russian technology..... > > Any help is welcome ! *** If it helps, I can read Russian.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Pullable Breaker
Date: May 02, 2002
Just received a pullable 5A Potter & Brumfield cb from Van's. It doesn't visibly pop when overloaded...can't see the white band that I see when pulled manually. It works, i.e. it breaks the circuit, but without any visual indication. Is that normal? jb ________________________________________________________________________________
Date: May 02, 2002
Subject: Screws vs Fastons
Hi Guys, Just saw this posting on the Cessna Cardinal List. Good example of why Bob likes those Fastons. From: robert patterson <cardinalflyer(at)attbi.com> Subject: intermittent flaps Rick, Take a look at the back of the flaps circuit breaker too - my flaps became intermittent/non-op a couple of summers ago, I tracked it down to a loose screw on the back of the circuit breaker - tighten up the others while you're under there too! Bob Patterson N34634, '73FG, 9B1 (Marlboro, MA) Regards, Don Boardman SR3500#130 "The Muskie" M-14PF Aerocet 3500 amphibs, Rome, NY ________________________________________________________________________________
Date: May 02, 2002
Subject: Re: Pullable Breaker
> >Just received a pullable 5A Potter & Brumfield cb from Van's. It doesn't >visibly pop when overloaded...can't see the white band that I see when >pulled manually. It works, i.e. it breaks the circuit, but without any >visual indication. Is that normal? > >jb Hmmm . . . not for any breaker I've ever seen. After it breaks, I presume you can reset it by pushing on the button . . . how much travel does it have before the contacts close? Bob . . . ________________________________________________________________________________
Subject: RE: Pullable Breaker
Date: May 02, 2002
More on this question: I tested this breaker by connecting two jumpers (the colored wire, alligator clip, radio shack type) from the breaker terminals to the battery terminals. This smoked the wires and I don't remember if the breaker popped that time. Now there was no continuity in those jumper wires so I tried another pair. This time the wires held and the results were as described in my first post. The breaker tripped but not visibly. The breaker was reset by pulling it open and pushing it back down. This was repeated several times and it tripped every time. When I tried to remove the screws from the breaker terminals, one was so tight that I over torqued it and bent the terminal and cracked the case. Evidently it welded when I smoked the wires. When I took the case apart I was expecting to see a coil/moving metal core mechanism. No such thing...it had one terminal connected to a metal strip (bi-metallic?), so it was thermal, not magnetic. Following Bob's architecture, this was the only breaker I planned to use and it is for the alternator field. I should read the section on the crowbar overvoltage circuit again, but doesn't it short the field wire to ground, and isn't the breaker supposed to open in milliseconds? Lots of questions. Faulty breaker? Too many amps for the breaker? Can that type of breaker really open in milliseconds? jb -----Original Message----- From: John Brick [mailto:jbrick(at)wolfenet.com] Subject: Pullable Breaker Just received a pullable 5A Potter & Brumfield cb from Van's. It doesn't visibly pop when overloaded...can't see the white band that I see when pulled manually. It works, i.e. it breaks the circuit, but without any visual indication. Is that normal? jb ________________________________________________________________________________
Subject: Re: RE: Pullable Breaker
Date: May 02, 2002
I unsuscribed from this spam and I am still getting it. WHAT IS WRONG WITH THIS PICTURE. ----- Original Message ----- From: "John Brick" <jbrick(at)wolfenet.com> Subject: AeroElectric-List: RE: Pullable Breaker > > More on this question: I tested this breaker by connecting two jumpers (the > colored wire, alligator clip, radio shack type) from the breaker terminals > to the battery terminals. This smoked the wires and I don't remember if the > breaker popped that time. Now there was no continuity in those jumper wires > so I tried another pair. This time the wires held and the results were as > described in my first post. The breaker tripped but not visibly. The breaker > was reset by pulling it open and pushing it back down. This was repeated > several times and it tripped every time. > > When I tried to remove the screws from the breaker terminals, one was so > tight that I over torqued it and bent the terminal and cracked the case. > Evidently it welded when I smoked the wires. When I took the case apart I > was expecting to see a coil/moving metal core mechanism. No such thing...it > had one terminal connected to a metal strip (bi-metallic?), so it was > thermal, not magnetic. > > Following Bob's architecture, this was the only breaker I planned to use and > it is for the alternator field. I should read the section on the crowbar > overvoltage circuit again, but doesn't it short the field wire to ground, > and isn't the breaker supposed to open in milliseconds? > > Lots of questions. Faulty breaker? Too many amps for the breaker? Can that > type of breaker really open in milliseconds? > > jb > > -----Original Message----- > From: John Brick [mailto:jbrick(at)wolfenet.com] > To: aeroelectric-list(at)matronics.com > Subject: Pullable Breaker > > > Just received a pullable 5A Potter & Brumfield cb from Van's. It doesn't > visibly pop when overloaded...can't see the white band that I see when > pulled manually. It works, i.e. it breaks the circuit, but without any > visual indication. Is that normal? > > jb > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 03, 2002
Subject: For: 2000 PC PARTS
> > >I unsuscribed from this spam and I am still getting it. WHAT IS WRONG WITH >THIS PICTURE. Dear 2000 PC PARTS - Only people with 2000 Macintosh parts can unsubscribe. Seriously, scroll to the bottom of this note and click on "UN/SUBSCRIBE". Better yet have some patience and stick around - Bob and the listers will make it well worth your while in education, products, and support. Good luck in either case - Bill ________________________________________________________________________________
Date: May 03, 2002
> >Well Robert, >thanks for your response, but yes, the Yak system is a kind of special ( >at least to me ). >For example, there is a voltage regulator wich I hav not jet seen. You >maybe know it as a carbon pile regulator. This is 1950`electrics, and >completely unknown to germans. >And so the story goes on and on. As far as I can tell, and I am pretty >familiar with electrics, this system is completely diferent from anything >i have seen. >The basics may be the same, but thats it ! >Russian technology..... > >Any help is welcome ! Carbon pile regulators were among the first successful devices used for voltage and current control of DC machines. Early electric street cars used large carbon pile resistors to adjust current delivered to the traction motors. Even today, if one wants a variable power resistor capable of great wattage, the carbon pile is #1 choice. I use them in several alternator test stands that I've built. The "carbon pile" is a stack of disks or plates of carbon with contacts at each end. Resistance of the stack is varied by adjusting pressure on the stack . . . usually, the motion is quite small . . . the stack's total length changes very little with pressure. This characteristic yields an opportunity to build a sort of mechanical amplifier wherein voltage impressed across a coil of wire becomes a current that produces magnetic force that manifests itself in a variable resistance of considerable current handling capabilities. You can stack up the carbon disks with a constant tension supplied by a spring and hook the stack in series with field supply to a generator (or alternator). Absent any outside influence, the resistance of the stack is low and output from the machine is high. Now, arrange a coil of wire to tug on a magnetic armature such that increasing current decreases force on the stack, voila! Negative feedback that tends to stabilize the system. Adjust the mechanical positions and forces of the parts so that the desired bus voltage falls somewhere near the middle of the devices control slope and you have a regulator with no moving/wearing parts of any consequence. Here's a link to a page that shows a schematic of a carbon pile regulated generator. A tad more complex than the systems used on vehicles but representative of an application for this technology. http://www.gotopcs.net/stones.html In my never very humble opinion, a rather elegant solution. One can find carbon pile regulators still in service in older turbine and piston aircraft here in US as well. I don't Here's a link to a discussion of the M14 engine and accessories . . . a cousin if not sibling to the engine in your airplane. http://www.alltheweb.com/go/2/H/web/http/fred.abramson.com/m14p.htm Carbon pile resistors are still used in modern products, mostly battery testers and variable loads for test bench uses. Here are some examples: http://bach-simpson.com/iprod01.htm http://www.autometer.com/test/specifications/sb5sp.htm Folks in aviation still repair these devices. See: http://www.alltheweb.com/go/1/H/web/http/www.montagar.com/~patj/ebjagabi12.htm http://www.asapavionics.com/component_repair.htm These are but a few of the hits I got on www.google.com for a search on "carbon pile". Troubleshooting the system is just the same as for any other regulator. The generator field current needs to be controlled in response to variations in bus voltage and output current from the machine. Techniques for isolating a faulty component in the generator/regulator system are the same no matter what kind of regulator is is used. By-in-large, as long as the system is mechanically intact (no broken wires, burned switches, burned commutators or seized bearings, etc.) then system instability or adjustment problems is almost always attributable to a need for regulator overhaul. Bob . . . ________________________________________________________________________________
Date: May 03, 2002
> >More on this question: I tested this breaker by connecting two jumpers (the >colored wire, alligator clip, radio shack type) from the breaker terminals >to the battery terminals. This smoked the wires and I don't remember if the >breaker popped that time. Now there was no continuity in those jumper wires >so I tried another pair. This time the wires held and the results were as >described in my first post. The breaker tripped but not visibly. The breaker >was reset by pulling it open and pushing it back down. This was repeated >several times and it tripped every time. > >When I tried to remove the screws from the breaker terminals, one was so >tight that I over torqued it and bent the terminal and cracked the case. >Evidently it welded when I smoked the wires. When I took the case apart I >was expecting to see a coil/moving metal core mechanism. No such thing...it >had one terminal connected to a metal strip (bi-metallic?), so it was >thermal, not magnetic. Magnetic breakers are $100 devices . . . very rare. >Following Bob's architecture, this was the only breaker I planned to use and >it is for the alternator field. I should read the section on the crowbar >overvoltage circuit again, but doesn't it short the field wire to ground, >and isn't the breaker supposed to open in milliseconds? Yup, when wired into an airplane with a big battery to feed the bus, fault currents that flow in the crowbar can be as much as 300 amps . . .the breaker opens right smartly under this kind of stess. >Lots of questions. Faulty breaker? Too many amps for the breaker? Can that >type of breaker really open in milliseconds? The breaker you have must be defective . . although some of the mechanical characteristics you describe lead one to question design and quality as well. I'd recommend you pick up a Klixon or Mechanical Products 5A miniature breaker from B&C. Bob . . . ________________________________________________________________________________
Date: May 03, 2002
Subject: Spam, spam, who's got the spam?
> > >I unsuscribed from this spam and I am still getting it. WHAT IS WRONG WITH >THIS PICTURE. Forgive me sir but the only spam on this list is a product of your lack of understanding of how list servers work and what it takes to have your wishes accommodated. It certainly won't happen with mud slinging and YELLING at people who have no control over the cause of your distress. There must be some problem with the way your e-mail address is batched with the server's list of subscribers that will require the personal attention of the man who so graciously offers the space on his computers to service the needs of others at NO CHARGE. I suggest simple, polite note to the person listed at the top of the subscribe page as list administrator . . . "Matt Dralle" . . . . explaining that you have been unsuccessful in effecting an automatic un-subscribe to this service. Would he please take some time out of his busy day to open the data file to search for and manually and delete the offending entry? Matt's a nice guy and tries to be very helpful so you be nice too . . . I think he'll be pleased to accommodate you forthwith . . . Bob . . . ________________________________________________________________________________
Date: May 03, 2002
Subject: Magnetos
Bob, In a recent reply you recommended keeping your mags and using each one of them with an electronic ignition until they need overhauling, then going dual E.I. The mags that came with my engine are Bendix Shower of Sparks 200 series. I'm planning on using your electric airplane on a budget schematic and I thought if I just used the E. I. for starting I could forget about the vibrator. So....do you see any pitfalls and would you still make the same recommendation???? Also, do you have any of those faston connectors left? Thanks for your service to the homebuilt community. Joel Harding ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: May 03, 2002
The problem with the generator and carbon pile regulator on the M14P engines is that they are big and heavy. B&C makes a small lightweight, permanent magnet alternator for that engine that is a fraction of the weight. It is a cousin to the SD-8 and I believe it delivers around 10 amps. David Swartzendruber Wichita ________________________________________________________________________________
Date: May 03, 2002
Well Bob, thanks a lot ! You really helped me understanding the whole lot. I tried Google to on that subject, but i did not found what you did. Actually I think the fault does not lie in the Voltage regulator but in the differntial relay, but thats another story. Only today i got a publication on aviation electrics from Jeppesen. I guess we can sort problems out now. Thanks again Henning ________________________________________________________________________________
Date: May 03, 2002
Subject: Re: Magnetos
> >Bob, >In a recent reply you recommended keeping your mags and using each one of >them with an electronic ignition until they need overhauling, then going >dual E.I. The mags that came with my engine are Bendix Shower of Sparks 200 >series. I'm planning on using your electric airplane on a budget schematic >and I thought if I just used the E. I. for starting I could forget about the >vibrator. So....do you see any pitfalls and would you still make the same >recommendation???? Sounds good to me. >Also, do you have any of those faston connectors left? Which ones? The shrouded males? Yup. Put your order in . . . >Thanks for your service to the homebuilt community. You're welcome. Bob . . . ________________________________________________________________________________
Date: May 03, 2002
There is a big capability difference between the original electrical system and what the b&c can produce. The original is rated at something like 107A and 28V which gives about 3kW. I guess the russian instrumentation (and radios) were pretty power hungry - Apparently the Yak18 (and probably others) had a very nice (but large and heavy) non-tumbling AI in it. I can only imagine what they were using for radios. Can you say vacuum tube? Not quite like the surface mount stuff we have today. Rugged though. If you can get along with something less than a 3kW power budget (I know, that means you'll have to get an extension cord to run the welder... ) then going to something from b&c would be a lot lighter. Matt- ----- Original Message ----- From: "David Swartzendruber" <dswartzendruber(at)earthlink.net> Date: Friday, May 3, 2002 9:19 am Subject: RE: AeroElectric-List: Re: Yak electrics > > The problem with the generator and carbon pile regulator on the M14P > engines is that they are big and heavy. B&C makes a small > lightweight,permanent magnet alternator for that engine that is a > fraction of the > weight. It is a cousin to the SD-8 and I believe it delivers > around 10 > amps. > > David Swartzendruber > Wichita > ________________________________________________________________________________
Date: May 03, 2002
Robert L. Nuckolls, III wrote: > > Carbon pile regulators [...] > > In my never very humble opinion, a rather elegant > solution. *** Wow! That _is_ elegant. I wouldn't be at all surprised to find such on locomotives - there's a LOT of electrical power involved with those, especially with reactive braking. Another elegant regulator I once saw: There was this high-current "semi-regulated" power supply for charging telephone central office batteries. It had a power transformer with an extra winding. A small amplifier pumped DC into the extra winding. This DC would saturate the transformer, and the output voltage would dip. If it dipped too far, you pumped in less DC. If it didn't dip enough, you pumped in more DC.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Hand tool battery charging - Little off Topic
Date: May 03, 2002
Hi gang, I use a cordless drill quite a bit while building my Pulsar. It seems that if I put the battery in the frig or freezer that I get a better charge on the NICAD battery pack. Is there any reason not to do this? Thanks, Ned ________________________________________________________________________________
Date: May 03, 2002
> >So what about a situation where you need to control a dozen things with >On-Off toggle switches? Fuse blocks are great, but if I have to put in a >fuse block AND then run the wires to a console with toggle switches, and >then to the item to be powered....wouldn't it end up being more time, >money, and weight than just installing the switch-breakers? I like fuse >blocks and they have some good merits but I'm still trying to decide if >there's an advantage (or even a disadvantage) to using them in this case. Everything that needs a switch gets a switch, everything needs circuit protection and gets it whether it's a breaker or fuse. >One of my dilemma's (that leads to the fuse/toggle vs. breaker-switch >question) is an ongoing concern over the ability to kill power to some >individual item in the panel in the case of malfunction/smoke from a >single piece of equipment. Perhaps I'm just paranoid after my experience >(in the archives) where the transponder started smoking and wouldn't quit >by just turning it off. Even though it was day VFR, the ability to pull >the breaker was very useful. My dad who's a career GA pilot has also >related experiences where for one reason or another it was nice to be able >to break power to a piece of equipment using something other than it's own >on-off switch. Another example if my memory serves correctly is the >Swissair MD-ll that went down off the east coast a few years back...seems >they had an electrical fire that did NOT blow the breaker/fuse, and the >entire aircraft was lost (I think it was in the cabin entertainment >system, which may not be built to the same standard as !the cockpit >avionics, but was probly as robust as the sport aviation stuff in my >panel). Examples in the panel on my RV-8A are planned pieces of equipment >like the turn coordinator, the EIS-4000 engine monitor (has no On-off >switch built in) and perhaps the Dynon unit as well...not sure if it has >an on-off function but even if it does it's probly a software operated >function and not a mechanical disconnect. Same goes for my GPS...it has a >"soft" on-off switch. I want to be able to shut down these pieces of >equipment during flight...either because they are acting erratically >(which can create an annoyance at best or a dangerous display of >misleading information at worst) or because they smoke without blowing the >fuse, etc. Sure you can kill the master if something's burning up, but if >that something is on the essential bus of my all-electric airplane and >it's an IFR dark and stormy night, I'm dead.... why? some component putting out bad smells and smoke from inside a black box may be an uncomfortable experience but it's not hazardous. If it's on the e-bus, let 'er burn . . . it will either stop in a few minutes or pop the fuse. These cases are very rare . . . >I know, I know...if I just design and wire it right and use good equipment >and all that, I don't have to worry about this scenario, right? I'm still >looking for a logical way to come to grips with the potential failure >modes and their consequences, and am not completely convinced that >inaccessible fuse blocks are the *safest* answer. Maybe the most >reliable, inexpensive, and simple....but the safest??? > >If anybody can put my mind at ease with a factual explanation of why my >safety concerns are unfounded, I would welcome the input. If you're worried about these kinds of problems, it's better that you address all the worries rather than build the airplane to anyone else's philosophy . . . the only cure for worry is to weigh probability of an event and potential hazards against the notion of adding complexity and pilot workload in an already busy situation. About 200,000 Cessnas and Pipers were built with breakers that you can't pull . . . if pull-ability were a big issue, why no proliferation of STC's to replace the breakers? My friend George Orndorff likes to have his builders build breaker panels using Airpax rocker-switch/breakers. His builders have LOTS of CONTROL over EVERYTHING . . . but at a price of dollars, labor and panel space to install and the risks of encouraging pilots to become systems failure analysts at inconvenient or already stressful times. Bob . . . ________________________________________________________________________________
Date: May 03, 2002
Subject: Re: 1 amp noise filter
Bob and others, I think the schematic for this, minus the two diodes, is on Bob's web site. Somewhere Bob had mentioned that he thought he had done a schematic and could not find this info. http://209.134.106.21/articles/noisfltr.pdf Visual instructions at: http://209.134.106.21/articles/filter/filter.html Good Luck and thanks to all who contribute here. Rick D. Murphy Rebel N754SM Hudson, MA From: Steven Kay <skay(at)optonline.net> Subject: Re: AeroElectric-List: Re: Bendix King Handheld KX99 Bob, I'd like to see a schematic to be sure of the configuration when you can find the time. Sounds like cheap inssurance for the goodies in the flight bag. -Steve "Robert L. Nuckolls, III" wrote: > > > If I were going to tie any hand helds into ship's power, > I would probably use a Radio Shack 270-030 noise filter > downstream of a small fuse (1A) and then put a couple > of 1N4745, glass zener diodes across the output feeding > the radio. > > The filter will take off the short duration gremlins > that most radios don't care about. The zeners would function > like the crowbar ov protection system used on the Grummans > some years back . . . ov conditions of long duration would > fail the diode shorted (without allowing the output > to rise above 16 volts) and open the fuse. > > Bob . . . > ________________________________________________________________________________
Date: May 04, 2002
> >Well Bob, >thanks a lot ! >You really helped me understanding the whole lot. >I tried Google to on that subject, but i did not found what you did. >Actually I think the fault does not lie in the Voltage regulator but in >the differntial relay, but thats another story. >Only today i got a publication on aviation electrics from Jeppesen. >I guess we can sort problems out now. >Thanks again The reverse current cutout or differential relay is another little piece of black magic . . . If you find that this critter is bad and not replaceable, there are ways to (1) replace the relay with a fat diode or (2) build a little forward voltage, reverse current sense module to drive a plain-vanilla contactor to do the same job. Bob . . . ________________________________________________________________________________
Subject: 2SI rectifier meltdown
Date: May 03, 2002
Bob, A friend of mine has a 2SI 35hp 2stroke engine (in his Aerolite 103 with a lighting coil, with a rectifier to charge his battery. (hasn't charged it yet) He keeps burning them up. (the rectifier that is) He was told that he had to have a load of at least 1 amp. if he did not have this load, could that be causing his rectifier problems. What is the best way to charge a battery with this small electrical system. The only thing he is powering is the starter. Electric Flaps and Strobe light. Thanks in advance for your help. The Banks Brothers Bruce (in Las Vegas NV) We have your book if you have any reference we need to look at. ________________________________________________________________________________
Date: May 04, 2002
Subject: Re: 2SI rectifier meltdown
> >Bob, >A friend of mine has a 2SI 35hp 2stroke engine (in his Aerolite 103 with a >lighting coil, with a rectifier to charge his battery. (hasn't charged it >yet) He keeps burning them up. (the rectifier that is) He was told that he >had to have a load of at least 1 amp. if he did not have this load, could >that be causing his rectifier problems. What is the best way to charge a >battery with this small electrical system. The only thing he is powering is >the starter. Electric Flaps and Strobe light. Thanks in advance for your >help. The Banks Brothers Bruce (in Las Vegas NV) We have your book if you >have any reference we need to look at. I am skeptical of the need to have a load to prevent rectifier/regulator destruction . . . a minimum load is commonly necessary to keep the voltage regulation setpoint within reasonable bounds. The simple act of placing a battery across the rectifier/ regulator's output (especially a discharged battery) should be more than enough load to insure regulation performance. These regulators are pretty generic. I think I'd try a regulator from B&C . . . they have one that goes on their SD-8, 10A alternator that's proven to be rather robust . . you can give Todd a call at 1.316.283.8000 and order one. Does the airplane have a voltmeter in it? Did you get any voltage readings on the system during periods of operation before the regulator craps? How long does the regulator last? Is it mounted on metal with at least 30 square inches of exposed surface? I suspect the critter is getting too hot an melting it's bitty brains out. Bob . . . ________________________________________________________________________________
Subject: Switches
Date: May 04, 2002
I would like to replace the set of toggle switches on the over head panel in my Exec90 with lighted pushbutton switches. That would make it easier to see at dark and anytime as it's difficult to see which switch is what. Anyway, I have a problem because the pushbutton switches are rated at 2 amps while the current toggles are rated at 10 to 15 amps. I could just replace them with more toggles but I would like the upgrade. I had considered using relays but I worry about the extra drain (about 100ma per relay with at least 6 relays). Any suggestions would be greatly appreciated. Thanks. ________________________________________________________________________________
Date: May 04, 2002
Subject: Re: Switches
Depends on what they are driving. If they are simple things, like a motor or lights, you could use a transistor (or FET) instead of a relay. ASCII Art below (fixed fonts are best). push button /------- Load ---+ | / | --- B |/ C V +-. .-------VVV--------| GND | 1K |\ E | \ V | gnd +power Transistor must be rated for the load, TIP-32's and TIP-42's are probably adequate for 3-6Amps. If you are running higher, then I would look into FET's. I am not a big fan of relay's either. They seem so old fashioned. If you subscribe to the smoke theory* of electronics, then they are scarey. *electronics run on smoke, let the smoke out, and they quit working. P Fischer wrote: > > I would like to replace the set of toggle switches on the over head > panel in my Exec90 with lighted pushbutton switches. That would make it > easier to see at dark and anytime as it's difficult to see which switch > is what. Anyway, I have a problem because the pushbutton switches are > rated at 2 amps while the current toggles are rated at 10 to 15 amps. I > could just replace them with more toggles but I would like the upgrade. > I had considered using relays but I worry about the extra drain (about > 100ma per relay with at least 6 relays). Any suggestions would be > greatly appreciated. Thanks. ________________________________________________________________________________
Date: May 05, 2002
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Switch-breakers . . . >I want to be able to shut down these pieces of >equipment during flight...either because they are acting erratically >(which can create an annoyance at best or a dangerous display of >misleading information at worst) or because they smoke without blowing the >fuse, etc. Sure you can kill the master if something's burning up, but if >that something is on the essential bus of my all-electric airplane and >it's an IFR dark and stormy night, I'm dead.... why? some component putting out bad smells and smoke from inside a black box may be an uncomfortable experience but it's not hazardous. If it's on the e-bus, let 'er burn . . . it will either stop in a few minutes or pop the fuse. These cases are very rare . . . I agree it is very rare, but I'm not sure I completely agree about it being non-hazardous....if it's a quick 'poof' with a mild odor (which is common when something blows a fuse) that's no big deal, but if it lasts much longer than that (30 sec or more), acrid electrical smoke can become overpowering very quickly. Not to mention the rather distracting psychological factor involved that something in the airplane with you is on fire and you can't just jump out. At least that was my experience in the two situations I can remember being in a vehicle with electrical stuff smoking (one in an airplane, the other in a car...but that's another story...). It's amazing how far away the ground seems even at 1000' agl on a clear sunny day when you can't breathe (and yes, the vents were open, but I was ready to knock the window out and stick my head into the slipstream for a breath.....I would have done it in the 172, but it's a bit more complicated in an RV....). >I know, I know...if I just design and wire it right and use good equipment >and all that, I don't have to worry about this scenario, right? I'm still >looking for a logical way to come to grips with the potential failure >modes and their consequences, and am not completely convinced that >inaccessible fuse blocks are the *safest* answer. Maybe the most >reliable, inexpensive, and simple....but the safest??? > >If anybody can put my mind at ease with a factual explanation of why my >safety concerns are unfounded, I would welcome the input. If you're worried about these kinds of problems, it's better that you address all the worries rather than build the airplane to anyone else's philosophy . . . the only cure for worry is to weigh probability of an event and potential hazards against the notion of adding complexity and pilot workload in an already busy situation Agreed, but what I'm really trying to get at is a way to understand if there's a REASON to be worried or not. As you pointed out, the situations I'm describing ARE very rare, but in aircraft design we also need to consider the potential impact of even very rare events. If they are not hazardous as you maintain, it's a moot point. But if a rare event can be catastrophic when it occurs, and there's a reasonable method of eliminating the risk (adding a toggle switch or pullable/switchable breaker), this would seem prudent to me. One of the problems with some (most?) spam can designs is that they group multiple pieces of equipment on a single breaker for space savings, cost, etc. I think this may have contributed to the situation I experienced where a piece of equipment was making smoke but not popping the breaker....it was drawing enough current to smoke something but because the breaker was sized to handle much larger loads, it did not pop (this is just a theory and I can't recall the details of what other components--if any--were on the same breaker....). At any rate this particular issue can be eliminated by using fuseblocks because individual fuses can be more readily assigned to each component, and therefore each fuse can also be sized more closely to the equipment's true power requirements. Question is this: say my Grand Rapids EIS-4000 (on the Essential Bus) only needs a 1 amp fuse because it's max current requirement is something like .25 Amps. Is it physically impossible for a unit to produce smoke for more than a second or two using less than the 1 amp required to blow the fuse? What about a piece of equipment that has higher power requirements (3 or 5 amp fuse)? If the physics of creating smoke from any type of internal problem imaginable dictates that the current required to do so MUST be greater than the properly sized fuse, then I rest my case and will sleep well at night knowing that my equipment can't possibly create more than a little puff before being extinguished by the circuit protection. And I'll leave the needless extra toggle switches out of my airplane.... About 200,000 Cessnas and Pipers were built with breakers that you can't pull . . . if pull-ability were a big issue, why no proliferation of STC's to replace the breakers? True....and I can't say how many people have experienced problems where they needed to pull a breaker and couldn't....it's possible that in most cases (however rare) where this situation was encountered, the master was simply shut off killing all things electrical. In most spam cans, no big deal really.....in the worst case scenario you pull out the flashlight on your dark 'n' stormy night and shine it on you vacuum gyros : ) Not so simple if your attitude information is electric and on the same bus as the smoke-generator.... Thanks for the input, --Mark Navratil Cedar Rapids, Iowa RV-8A finish kit.... ________________________________________________________________________________
Subject: annunciator panel
Date: May 05, 2002
I'm looking for a control circuit for an annunciator panel. Anyone know where I can find one? Thanks. ________________________________________________________________________________
Date: May 05, 2002
> Another example if my memory serves correctly is the Swissair MD-ll that went >down off the east coast a few years back...seems they had an electrical fire >that did NOT blow the breaker/fuse, and the entire aircraft was lost (I think >it was in the cabin entertainment system, which may not be built to the same >standard..... Mark, Since I fly DC-10s, I paid some attention to this accident and I'm pretty sure that the final report blames a short in a map reading light in the overhead panel that ignited some type of mylar insulation, which then sustained the fire. I remember there was an FAA directive to change to a different type of insulation. I think the only time you'll really have life threatening situations, is when some other surrounding material is ignited by the electrical fireworks. I hope this will ease your mind a little. Joel Harding Larkspur, CO Connecting the engine. ________________________________________________________________________________
From: "Steve Richard" <steve(at)oasissolutions.com>
Subject: Battery charging
Date: May 05, 2002
I have 2 12v Gill RG batteries in my airplane (a Mooney Rocket conversion, M20K). The batteries are in parallel, 12 volt system. I would like to use a standard auto battery charger to recharge or boost the batteries per the service instructions. I would like to charge them in the airplane (since removing them is incredibly difficult) using the ground power adapter / jumper cables. What is wrong or good about this picture? Steve Richard steve(at)oasissolutions.com ________________________________________________________________________________
Date: May 05, 2002
Subject: re: OV Protection
Bob, I'm a subscriber to your book and am wiring my RV6 the "Nuckolls Way" but I have a couple of quick questions. My engine is coming from AeroSport Power with a 40 amp alternator with an internal regulator, and I am going to add the overvoltage protection as shown in your book. In figure Z-24 you show a (2-10) switch as a OFF/BAT/ALT switch in which you could close the battery contactor without closing the alternator OV disconnect contactor. I found another diagram on your site that shows the circuit with a (2-3) switch and a "Important" note that the battery and alternator should come on and off at the same time. Is this a revision, and if so, what was the reason for it? Either 2-3 or 2-10 can be used. The 2-3 simply brings altenrator and battery on and off together and you pull the alt field breaker to kill the alternator for ground ops with where the engine isn't running. The 2-10 allows you independent but interlocked operation of battery and alternator. Bottom is both OFF, mid positon is BATtery, upper postion is BATtery/ALTernator. Either alternative is entirely satisfactory . . . just depends on how fancy you want to get. One other question about wiring one mag and one electronic ignition. Figure Z-27 shows wiring to have the right electronic ignition disabled while starting on the left (impulse coupler) mag. In the second paragraph under note 2, page Z-5 you say that the electronic system on the right side should be left on for start. Which is the best way to wire it? Depends on what the supplier of your electronic ignition says. If they recommend that it be on for starting -AND- the magneto is impulse coupled then either or both systems can be on during cranking and no interlocking of the ignition switches with starter control is necessary. However, if you have a magneto that is NOT impulse coupled, I'd take some pains to make sure that the starter cannot be engaged while this magneto is ON. Thanks for a great book, I'm pleased that you're finding it a good value! Bob . . . ________________________________________________________________________________
Date: May 06, 2002
Subject: Tiptoe through the cobwebs . . .
> >Robert L. Nuckolls, III wrote: > > > > Carbon pile regulators >[...] > > > > In my never very humble opinion, a rather elegant > > solution. > >*** Wow! That _is_ elegant. I wouldn't be at all surprised to find such >on locomotives - there's a LOT of electrical power involved with those, >especially with reactive braking. > > Another elegant regulator I once saw: > > There was this high-current "semi-regulated" power supply for charging >telephone central office batteries. It had a power transformer with an >extra winding. A small amplifier pumped DC into the extra winding. This >DC would saturate the transformer, and the output voltage would dip. If it >dipped too far, you pumped in less DC. If it didn't dip enough, you pumped >in more DC.... Sounds like you may be talking about "saturable core reactor" regulation. This was the non-silicon forerunner to the silicon controlled rectifier. Here's a schematic for a three-phase ac/dc power supply using saturable core reactors just ahead of the rectifiers. http://209.134.106.21/temp/705scrps.pdf I suspect what you saw at the telephone company was pretty close to the same thing . . . perhaps single phase as opposed to 3 phase . . . This is a VERY mature technology . . . I taught saturable core reactors for a time at a Navy E-tech school at Great Lakes NTB in N. Chicago, IL. SatCore controlled power supplies were very common aboard ships from about the first time they installed AC power generation and distribution systems. It's STILL a good technology. Here's one of many companies that still use it in new product. http://www.warnerpower.com/industrial_power_conversion/powersupplies.html If you want to see something REALLY elegant, take a peek at http://www.tpub.com/neets/book5/15k.htm this page describes a critter called the "Amplidyne" . . . basically an electromechanical, power operational amplifier. Push-pull 6L6's would drive a field winding to the tune of +/- 100 milliamperes at 300 volts. A really fat motor would spin the shaft to the tune of several horsepower and the Amplidyne would respond to input from the vacuum tubes by producing +/- 300 VDC at many amps. The system I taught at GLakes was about a 20A machine that ran the radar antenna servo motor at the top of the mast. Haven't thought about saturable cores and Amplidynes in years. . . Bob . . . ________________________________________________________________________________
Subject: Trashing aviators
Date: May 06, 2002
"If this is true, there is sure as hell no substitute for a "real" airline pilot. Notice how the article tries to pass off the Boeing Test Pilots as "airline transport pilots." No way... if true, these guys were just 500 hour junior corporate jockeys with less than NO savvy about REAL flying!" Let's not fill these pages with ignorant bias. The two jobs (test and airline) are entirely different. EACH takes its toll on the other. One takes intense interest on minutiae and requires concentration on one or two details at a time. Accurate control for short periods is a necessity. I would be tempted to place naval fighter jocks nearer the first category. The airline pilot does not need to concentrate on one detail or another, but to be steadfast and keep a larger picture in perspective. He must do the same (bone-chilling) routine over and over with unwavering regularity for the sake of the 'load'. The two jobs are so dissimilar as to require special talent to divert from one to the other. I've seen test pilots at the top of their trade screw up a simple trip through lack of training and practice. ....and woe betide the poor airline driver who who attempts test flying without the background. Those who deride one or the other have usually done neither. Ferg Kyle Europa A064 ________________________________________________________________________________
Date: May 06, 2002
Subject: Re: annunciator panel
> >I'm looking for a control circuit for an annunciator panel. >Anyone know where I can find one? Thanks. I'm not aware of any generic and/or off-the-shelf "control circuit" for annunciation. You need to make a list of all critters about which you wish to be notified and describe the sensor that detects the event. Ordinary events signaled by switch closures simply supply +14 or ground to a lamp circuit. Some parameters like low bus voltage, temperatures, pressures, etc. may require some additional intelligence to convert the analog parameter to a discrete output that will drive a lamp. Virtually every annunciator system is custom to the the application. Bob . . . ________________________________________________________________________________
Date: May 06, 2002
> >One of the problems with some (most?) spam can designs is that they group >multiple pieces of equipment on a single breaker for space savings, cost, >etc. I think this may have contributed to the situation I experienced >where a piece of equipment was making smoke but not popping the >breaker....it was drawing enough current to smoke something but because >the breaker was sized to handle much larger loads, it did not pop (this >is just a theory and I can't recall the details of what other >components--if any--were on the same breaker....). At any rate this >particular issue can be eliminated by using fuseblocks because individual >fuses can be more readily assigned to each component, and therefore each >fuse can also be sized more closely to the equipment's true power >requirements. Most airplanes left the factory with one gizmo, one breaker. VERY few systems (and they are generally tiny-draws) will share a circuit protection device on an as-delivered airplane. It's so damnably difficult to do the right thing on a certified ship that future modifications will tend to go in with less than elegant architecture . . . >Question is this: say my Grand Rapids EIS-4000 (on the Essential Bus) >only needs a 1 amp fuse because it's max current requirement is something >like .25 Amps. Is it physically impossible for a unit to produce smoke >for more than a second or two using less than the 1 amp required to blow >the fuse? What about a piece of equipment that has higher power >requirements (3 or 5 amp fuse)? If the physics of creating smoke from >any type of internal problem imaginable dictates that the current >required to do so MUST be greater than the properly sized fuse, then I >rest my case and will sleep well at night knowing that my equipment can't >possibly create more than a little puff before being extinguished by the >circuit protection. And I'll leave the needless extra toggle switches >out of my airplane.... You can create smoke and NOT open a 1A fuse or breaker . . . under the right conditions. Obviously, the unrestrained power is limited to 14 watts total . . . but this amount of energy shed from some itty-bitty device inside a black box is toast. Fuses protect wire, only wire, and never anything but wire . . . if there is a compelling need to protect some piece of equipment, you do it differently. I designed time limited, constant current controllers for the landing gear on a LAIVP that used an actuator per landing gear. This was to prevent what could be nearly instantaneous destruction of a motor and/or mechanism should a limit switch fail and the system drive to hard stops. > About 200,000 Cessnas and Pipers were built with breakers that you > can't pull . . . if pull-ability were a big issue, why no >proliferation > of STC's to replace the breakers? > >True....and I can't say how many people have experienced problems where >they needed to pull a breaker and couldn't....it's possible that in most >cases (however rare) where this situation was encountered, the master was >simply shut off killing all things electrical. In most spam cans, no big >deal really.....in the worst case scenario you pull out the flashlight on >your dark 'n' stormy night and shine it on you vacuum gyros : ) Not so >simple if your attitude information is electric and on the same bus as >the smoke-generator... It's going to be on either the main bus or the e-bus. If it's on the main bus, you can shut that down. Things on the e-bus are limited by design philosophy to things that have very low probability of emitting hazardous vapors/smoke. I'd drive the attitude gyro from the e-bus and d-gyro from the main bus. Actually, if it were my airplane, I'd probably not have any gyros . . . I'd put in two wing-levelers capable of drilling precision, GPS guided holes in the sky. Bob . . . ________________________________________________________________________________
Date: May 06, 2002
Subject: Re: Hand tool battery charging
> >Hi gang, > >I use a cordless drill quite a bit while building my Pulsar. It seems that >if I put the battery in the frig or freezer that I get a better charge on >the NICAD battery pack. Is there any reason not to do this? I am unable to put a physical rational to support your observation . . . but it certainly wont hurt anything. Bob . . . ________________________________________________________________________________
Date: May 06, 2002
I just figured that the charger senses the resistance of the battery and shuts down the charging at a preset resistance. I assume that if the battery is kept cold the resistance is lowered and thus the battery recieves more charging. Seems to work with my cell phones as well. Does this not make logic? ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Hand tool battery charging > > > > >Hi gang, > > > >I use a cordless drill quite a bit while building my Pulsar. It seems that > >if I put the battery in the frig or freezer that I get a better charge on > >the NICAD battery pack. Is there any reason not to do this? > > > I am unable to put a physical rational to support > your observation . . . but it certainly wont hurt > anything. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 06, 2002
Many battery packs have a temperature sensor that will shut it down if the charge is too long or too high that heats up the battery. At least I have found them in laptop battery packs. Starting with a cooler sensor might delay this. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Hand tool battery charging > >Hi gang, > >I use a cordless drill quite a bit while building my Pulsar. It seems that >if I put the battery in the frig or freezer that I get a better charge on >the NICAD battery pack. Is there any reason not to do this? I am unable to put a physical rational to support your observation . . . but it certainly wont hurt anything. Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
From: "Mark D. Dickens" <mddickens(at)mindspring.com>
Subject: Nav Antenna Question
Date: May 06, 2002
Bob, would it be possible to use two bent whip COM antennas mounted horizontally on the tail as VOR/LOC/GS antennas? I see that Comant sells blade style antennas with a signal combiner, but this set up is very expensive, so I'm trying to come up with something I can hide under my horizontal stab (RV-8) on either side that costs a lot less. Thanks! Mark Dickens Highlands Ranch, CO RV-8 Fuse ________________________________________________________________________________
Subject: Re: Tiptoe through the cobwebs . . .
Date: May 06, 2002
Robert L. Nuckolls, III wrote: > > http://www.tpub.com/neets/book5/15k.htm > > this page describes a critter called the "Amplidyne" . . . basically *** Woo hoo! Kind of like a dynamotor only with active field control. Back when I was doing railroad software, one of our suppliers was a maker of LARGE lightning suppressors. They had had a problem with testing their suppressors: the power pulses involved was so large that they would affect the city power grid for blocks around. So they acquired a surplus generation unit from a hydroelectric generation plant and drove it with a large electric motor. Zaps for test were derived off the output of the generator, and the inertia of the motor kept the instantaneous load off the city grid. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: TSO'd or not?
Date: May 06, 2002
22, 2000) at 05/06/2002 04:32:33 PM I am building an RV-6 and wish to have IFR capability. What components, avionics, and/or instruments need to be TSO'd? Larry Dodge ________________________________________________________________________________
Date: May 06, 2002
One things I started thinking about, is silly checklists. In the Beech, and Cessna's I have flown, there is the checklist item "make sure the CB's are all in" (paraphrasing). So pilot A goes out flying, maybe at night or something, a circuit breaker pops, and doesn't notice it. Walks in the FBO turns in the key, and goes out for a beer after a successful adventure. Pilot B shows up the next day, the CB is poped out, so, just like the check list says, mashes in said popped CB. Flys around VFR day, no big deal. Now that I am thinking about it, I hope I'll at least think about that popped CB before taking flight. It is a reminder that something is amiss (or at least a mechanic might have been looking at something?). It won't be a wrote, checklist item anymore. ________________________________________________________________________________
Date: May 06, 2002
Jim Franz has an annunciator package with lights and processor. You might give him a call. He is the one that sells the AOA. I don't have his number here, but he is in all the publications. A real nice guy to deal with. Jim Robinson > > > > > >I'm looking for a control circuit for an annunciator panel. > >Anyone know where I can find one? Thanks. > > > I'm not aware of any generic and/or off-the-shelf > "control circuit" for annunciation. You need to make > a list of all critters about which you wish to be > notified and describe the sensor that detects the > event. Ordinary events signaled by switch closures > simply supply +14 or ground to a lamp circuit. Some > parameters like low bus voltage, temperatures, > pressures, etc. may require some additional intelligence > to convert the analog parameter to a discrete output > that will drive a lamp. > > Virtually every annunciator system is custom to the > the application. > > Bob . . . > > > advertising on the Matronics Forums. > members. > http://www.matronics.com/ > > > ________________________________________________________________________________
Date: May 07, 2002
Try www.proscanavionics.com. They displayed their systems at the recent Twin Cities RV Forum. Alex Peterson Maple Grove, MN RV6-A N66AP 140 hours > > > > > >I'm looking for a control circuit for an annunciator panel. Anyone > > >know where I can find one? Thanks. > > > > > > I'm not aware of any generic and/or off-the-shelf > > "control circuit" for annunciation. You need to make > > a list of all critters about which you wish to be > > notified and describe the sensor that detects the > > event. Ordinary events signaled by switch closures > > simply supply +14 or ground to a lamp circuit. Some > > parameters like low bus voltage, temperatures, > > pressures, etc. may require some additional intelligence > > to convert the analog parameter to a discrete output > > that will drive a lamp. > > > > Virtually every annunciator system is custom to the > > the application. > > > > Bob . . . > > ________________________________________________________________________________
Date: May 07, 2002
Subject: Re: Nav Antenna Question
> > >Bob, would it be possible to use two bent whip COM antennas mounted >horizontally on the tail as VOR/LOC/GS antennas? I see that Comant sells >blade style antennas with a signal combiner, but this set up is very >expensive, so I'm trying to come up with something I can hide under my >horizontal stab (RV-8) on either side that costs a lot less. The generic, tail mounted mouse-whiskers antennas common to light aircraft of the 50's and 60's would do just fine. It would be difficult to make a pair of comm antennas interface with the coax feedline as a single antenna. You might try using comm antennas as standalone, dual antennas. The second leg of a "dipole" formed by the second whisker adds only marginally to total performance. You can still use the coupler to get GS info off one of the antennas. Bob . . . ________________________________________________________________________________
Date: May 07, 2002
Subject: Re: Hand tool battery charging (cold batteries)
> >Many battery packs have a temperature sensor that will shut it down if the >charge is too long or too high that heats up the battery. At least I have >found them in laptop battery packs. Starting with a cooler sensor might >delay this. This sounds logical. Bob . . . ________________________________________________________________________________
Date: May 07, 2002
I've been hoping to see one come along too. But the pickings are thin. So here's my wish list: I want to be able to assemble an enunciator panel that exactly matches my needs. There should be different sized trays into which I can insert pre labelled switch-lamps. The lamps should flash ( and maybe sound an alarm ) if a parameter is exceeded and then I should be able to acknowledge the alarm by pressing the lamp. It would then continue to glow solid until the out of limit parameter was fixed. Trays should come in 3, 4,5,6 etc sizes, with a base control unit. The best alternative is the EIS in my opinion, except not analog. I want the best of both worlds. Any takers? ChrisH -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex Peterson Subject: RE: AeroElectric-List: Re: annunciator panel --> Try www.proscanavionics.com. They displayed their systems at the recent Twin Cities RV Forum. Alex Peterson Maple Grove, MN RV6-A N66AP 140 hours > > > > > >I'm looking for a control circuit for an annunciator panel. Anyone > > >know where I can find one? Thanks. > > > > > > I'm not aware of any generic and/or off-the-shelf > > "control circuit" for annunciation. You need to make > > a list of all critters about which you wish to be > > notified and describe the sensor that detects the > > event. Ordinary events signaled by switch closures > > simply supply +14 or ground to a lamp circuit. Some > > parameters like low bus voltage, temperatures, > > pressures, etc. may require some additional intelligence > > to convert the analog parameter to a discrete output > > that will drive a lamp. > > > > Virtually every annunciator system is custom to the > > the application. > > > > Bob . . . > > = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: May 07, 2002
> >I just figured that the charger senses the resistance of the battery and >shuts down the charging at a preset resistance. I assume that if the >battery is kept cold the resistance is lowered and thus the battery recieves >more charging. > >Seems to work with my cell phones as well. > > >Does this not make logic? Measurement of internal impedance could be a factor in some of the new smart chargers with microprocessor control . . . many small appliance batteries also have microprocessors in them to compute total energy transfered during charge and discharge cycles in order to maximize battery performance. Bob . . . ________________________________________________________________________________
Date: May 07, 2002
I was thinking of building such a beast as I got closer to that point... A few analog inputs with adjustable alarm setpoints, an audible alarm, flashing lights... All I'd need is a PIC chip and some A/D converters and some time. But I know that I know just enough to be dangerous, so I haven't really done and concrete design on it. > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Chris > Horsten > Sent: Tuesday, May 07, 2002 8:47 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > I've been hoping to see one come along too. But the pickings are thin. > So here's my wish list: > > I want to be able to assemble an enunciator panel that exactly matches > my needs. There should be different sized trays into which I can insert > pre labelled switch-lamps. The lamps should flash ( and maybe sound an > alarm ) if a parameter is exceeded and then I should be able to > acknowledge the alarm by pressing the lamp. It would then continue to > glow solid until the out of limit parameter was fixed. Trays should come > in 3, 4,5,6 etc sizes, with a base control unit. The best alternative is > the EIS in my opinion, except not analog. I want the best of both > worlds. > > Any takers? > ChrisH > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex > Peterson > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Re: annunciator panel > > > --> > > Try www.proscanavionics.com. They displayed their systems at the recent > Twin Cities RV Forum. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 140 hours > > > > > > > > >I'm looking for a control circuit for an annunciator panel. Anyone > > > >know where I can find one? Thanks. > > > > > > > > > I'm not aware of any generic and/or off-the-shelf > > > "control circuit" for annunciation. You need to make > > > a list of all critters about which you wish to be > > > notified and describe the sensor that detects the > > > event. Ordinary events signaled by switch closures > > > simply supply +14 or ground to a lamp circuit. Some > > > parameters like low bus voltage, temperatures, > > > pressures, etc. may require some additional intelligence > > > to convert the analog parameter to a discrete output > > > that will drive a lamp. > > > > > > Virtually every annunciator system is custom to the > > > the application. > > > > > > Bob . . . > > > > > ________________________________________________________________________________
Date: May 07, 2002
Thank you all for your input. I see there's quite a bit of interest. I am pleasantly surprised at this. It would be nice if we collectively could design a control circuit. Personally, I don't think it would be very difficult but it sure could be alot of fun. Proscan avionics has a beauty but $2500 bucks for about $150 bucks in parts seems a bit excessive. I have already bought the annunciator lights. Honeywell makes them. They are rectangular about one inch by a quarter of an inch with two leds. This allows you to split the light and, if wanted, have two annunciations per annunciator unit. I bought them from a company called REM electronics. They're located in Ohio I think. These little lights a bit pricey but not to bad. If you don't want fancy annunciator lights most any led will suffice. The big thing is designing a circuit. Lets say everyone wants the same basic stuff, over voltage alert, low oil pressure, pitot heat, fuel, fuel pump, cyl head temp, landing gear, (in my case I would like rotorhead speed). We could compile a list and start to figure out a circuit. Each circuit needs filtering, seperation from the other circuits, a way to be sure the signal is valid etc. Any ideas would be greatly appreciated. I'll try to throw something together and maybe we can get Bob to nurse us along since he's the expert and I sure have never done anything like this before. Sure sounds like fun though. Thanks to you all. "Matthew Mucker" wrote: > > I was thinking of building such a beast as I got closer to that point... > > A few analog inputs with adjustable alarm setpoints, an audible alarm, > flashing lights... > > All I'd need is a PIC chip and some A/D converters and some time. But I > know that I know just enough to be dangerous, so I haven't really done and > concrete design on it. > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Chris > > Horsten > > Sent: Tuesday, May 07, 2002 8:47 AM > > To: aeroelectric-list(at)matronics.com > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > > > > > I've been hoping to see one come along too. But the pickings are thin. > > So here's my wish list: > > > > I want to be able to assemble an enunciator panel that exactly matches > > my needs. There should be different sized trays into which I can insert > > pre labelled switch-lamps. The lamps should flash ( and maybe sound an > > alarm ) if a parameter is exceeded and then I should be able to > > acknowledge the alarm by pressing the lamp. It would then continue to > > glow solid until the out of limit parameter was fixed. Trays should come > > in 3, 4,5,6 etc sizes, with a base control unit. The best alternative is > > the EIS in my opinion, except not analog. I want the best of both > > worlds. > > > > Any takers? > > ChrisH > > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex > > Peterson > > To: aeroelectric-list(at)matronics.com > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > --> > > > > Try www.proscanavionics.com. They displayed their systems at the recent > > Twin Cities RV Forum. > > > > Alex Peterson > > Maple Grove, MN > > RV6-A N66AP 140 hours > > > > > > > > > > > >I'm looking for a control circuit for an annunciator panel. Anyone > > > > >know where I can find one? Thanks. > > > > > > > > > > > > I'm not aware of any generic and/or off-the-shelf > > > > "control circuit" for annunciation. You need to make > > > > a list of all critters about which you wish to be > > > > notified and describe the sensor that detects the > > > > event. Ordinary events signaled by switch closures > > > > simply supply +14 or ground to a lamp circuit. Some > > > > parameters like low bus voltage, temperatures, > > > > pressures, etc. may require some additional intelligence > > > > to convert the analog parameter to a discrete output > > > > that will drive a lamp. > > > > > > > > Virtually every annunciator system is custom to the > > > > the application. > > > > > > > > Bob . . . > > > > > > > > > > > _- ======================================================================= > _- ======================================================================= messages. > _- ======================================================================= http://www.matronics.com/browselist/aeroelectric-list > _- ======================================================================= > > ________________________________________________________________________________
Date: May 07, 2002
> >Thank you all for your input. I see there's quite a bit of interest. I >am pleasantly surprised at this. It would be nice if we collectively >could design a control circuit. Personally, I don't think it would be >very difficult but it sure could be alot of fun. Proscan avionics has >a beauty but $2500 bucks for about $150 bucks in parts seems a bit >excessive. I have already bought the annunciator lights. Honeywell >makes them. They are rectangular about one inch by a quarter of an >inch with two leds. This allows you to split the light and, if wanted, >have two annunciations per annunciator unit. I bought them from a >company called REM electronics. They're located in Ohio I think. These >little lights a bit pricey but not to bad. If you don't want fancy >annunciator lights most any led will suffice. The big thing is >designing a circuit. Lets say everyone wants the same basic stuff, >over voltage alert, . . . don't need ov annunciation but you do need lv warning. Got the sensor and instructions coming on line in a few days. > low oil pressure, This is just a switch that operates a light > pitot heat, This is a current sensor you can make with a few turns of wire around a reed switch that operates a light. > fuel, low fuel warning? floats holding magnets can close a reed switch to light a light at calibrated level in tank. Optical liquid level sensor mounted at desired level in tank can sense low fuel. Either can light a light. > fuel pump, Pressure switch on output side of pump? > cyl head temp, Never seen a warning for cyl-hd temp in an airplane but it's not hard. AD596 thermocouple conditioner configured to light a light at a calibrated temperature value is pretty easy to do. > landing gear, Lights on still more switches > (in my case I would like rotorhead speed). We >could compile a list and start to figure out a circuit. Each circuit >needs filtering, seperation from the other circuits, a way to be sure >the signal is valid etc. Any ideas would be greatly appreciated. I'll >try to throw something together and maybe we can get Bob to nurse us Except for cyl-hd temp and lv warn, every function described is the simple lighting of a light based on a switch closure. LV warn sensor is readily available. Cyl-hd temp, if one really wants one isn't difficult to gin up either. All=in=all, not much to design or build . . . Bob . . . ________________________________________________________________________________
Date: May 07, 2002
Robert L. Nuckolls, III wrote: > > > much to design or build . . . > *** Here's where I start getting serious "homebuilt envy". I don't want a fancy panel full of blinking lights. I want one BIG RED (idiot) LIGHT that means "there is a problem". This big red light would be in my immediate scan. It would be driven by a little processor that would have sensors for everything that could conceivably be a problem. As long as that light's off, I can concentrate on flying the plane. When the light goes on, I look at all the other stuff. Maybe include a voice annunciator ( or just Morse Code for us poor hams ) to say why the light went on. But the main thing is that when all's ok, it's OFF, and I just have this one item to scan to verify that. The processor could have subtle logic to decide whether something's OK or not. "If this input blips less than 1ms less than 20 times, that's OK..." "If this input is LOW and that one's HIGH, we've got trouble..." "If the bus voltage is trending low and yet we have high RPMs..." - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 07, 2002
Thanks, Bob. What got me thinking about this was Comant's blade antenna. Somehow they're combining the signals from both blades. I assume (dangerous word, I know) that their "signal combiner" is different from a traditional diplexer, thus my question. Are you familiar with how the signal combiner works? Thanks for your time on this! Mark ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Nav Antenna Question > > > > > > >Bob, would it be possible to use two bent whip COM antennas mounted > >horizontally on the tail as VOR/LOC/GS antennas? I see that Comant sells > >blade style antennas with a signal combiner, but this set up is very > >expensive, so I'm trying to come up with something I can hide under my > >horizontal stab (RV-8) on either side that costs a lot less. > > > The generic, tail mounted mouse-whiskers antennas > common to light aircraft of the 50's and 60's would > do just fine. It would be difficult to make a pair > of comm antennas interface with the coax feedline > as a single antenna. You might try using comm > antennas as standalone, dual antennas. The second > leg of a "dipole" formed by the second whisker adds > only marginally to total performance. > > You can still use the coupler to get GS info off > one of the antennas. > > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 07, 2002
Send me some of the details and I can design the circuits. Wayne ----- Original Message ----- From: <ptf(at)execpc.com> Subject: Re: RE: AeroElectric-List: Re: annunciator panel > > Thank you all for your input. I see there's quite a bit of interest. I > am pleasantly surprised at this. It would be nice if we collectively > could design a control circuit. Personally, I don't think it would be > very difficult but it sure could be alot of fun. Proscan avionics has > a beauty but $2500 bucks for about $150 bucks in parts seems a bit > excessive. I have already bought the annunciator lights. Honeywell > makes them. They are rectangular about one inch by a quarter of an > inch with two leds. This allows you to split the light and, if wanted, > have two annunciations per annunciator unit. I bought them from a > company called REM electronics. They're located in Ohio I think. These > little lights a bit pricey but not to bad. If you don't want fancy > annunciator lights most any led will suffice. The big thing is > designing a circuit. Lets say everyone wants the same basic stuff, > over voltage alert, low oil pressure, pitot heat, fuel, fuel pump, cyl > head temp, landing gear, (in my case I would like rotorhead speed). We > could compile a list and start to figure out a circuit. Each circuit > needs filtering, seperation from the other circuits, a way to be sure > the signal is valid etc. Any ideas would be greatly appreciated. I'll > try to throw something together and maybe we can get Bob to nurse us > along since he's the expert and I sure have never done anything like > this before. Sure sounds like fun though. Thanks to you all. > > > "Matthew Mucker" wrote: > > > > > I was thinking of building such a beast as I got closer to that > point... > > > > A few analog inputs with adjustable alarm setpoints, an audible > alarm, > > flashing lights... > > > > All I'd need is a PIC chip and some A/D converters and some time. > But I > > know that I know just enough to be dangerous, so I haven't really > done and > > concrete design on it. > > > > > -----Original Message----- > > > From: owner-aeroelectric-list-server(at)matronics.com > > > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Chris > > > Horsten > > > Sent: Tuesday, May 07, 2002 8:47 AM > > > To: aeroelectric-list(at)matronics.com > > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > > > > > > > > > > I've been hoping to see one come along too. But the pickings are > thin. > > > So here's my wish list: > > > > > > I want to be able to assemble an enunciator panel that exactly > matches > > > my needs. There should be different sized trays into which I can > insert > > > pre labelled switch-lamps. The lamps should flash ( and maybe > sound an > > > alarm ) if a parameter is exceeded and then I should be able to > > > acknowledge the alarm by pressing the lamp. It would then continue > to > > > glow solid until the out of limit parameter was fixed. Trays > should come > > > in 3, 4,5,6 etc sizes, with a base control unit. The best > alternative is > > > the EIS in my opinion, except not analog. I want the best of both > > > worlds. > > > > > > Any takers? > > > ChrisH > > > > > > -----Original Message----- > > > From: owner-aeroelectric-list-server(at)matronics.com > > > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Alex > > > Peterson > > > To: aeroelectric-list(at)matronics.com > > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > > > > --> > > > > > > Try www.proscanavionics.com. They displayed their systems at the > recent > > > Twin Cities RV Forum. > > > > > > Alex Peterson > > > Maple Grove, MN > > > RV6-A N66AP 140 hours > > > > > > > > > > > > > > >I'm looking for a control circuit for an annunciator panel. > Anyone > > > > > >know where I can find one? Thanks. > > > > > > > > > > > > > > > I'm not aware of any generic and/or off-the-shelf > > > > > "control circuit" for annunciation. You need to make > > > > > a list of all critters about which you wish to be > > > > > notified and describe the sensor that detects the > > > > > event. Ordinary events signaled by switch closures > > > > > simply supply +14 or ground to a lamp circuit. Some > > > > > parameters like low bus voltage, temperatures, > > > > > pressures, etc. may require some additional intelligence > > > > > to convert the analog parameter to a discrete output > > > > > that will drive a lamp. > > > > > > > > > > Virtually every annunciator system is custom to the > > > > > the application. > > > > > > > > > > Bob . . . > > > > > > > > > > > > > > > > > _- > ======================================================================= > > _- > ======================================================================= > messages. > > _- > ======================================================================= > > _- > ======================================================================= > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - RV6 - IFR STANDARDS
Date: May 08, 2002
Larry, I am building an RV7 to an IFR standard. My understanding is as follows: a. alitmeter and ASI need to meet TSO standards. b. comm radios need to meet TSO standards, and most do. c. nav radios and indicators need to meet TSO. d. GPS need to meet TSO C129, but you need to select the sub category carefully. e. I am not sure, but if you use an efis then I think it needs to meet extra TSO requirements for redundancy and reliability. EFIS One might be a safe bet. Some useful references are: FAR 91.411, 91.413, Part 43 Appendixes D and E, there are others too. The engine, alternator and battery driving an all electric IFR plane do not have to meet any TSO, but they better be good. Pay particular attention to redundancy, you will need it one dark night. As a minimum you should consider two alternators, one battery. David Francis, VH-ZEE, Canberra, Australia I am building an RV-6 and wish to have IFR capability. What components, avionics, and/or instruments need to be TSO'd? Larry Dodge - > _ ________________________________________________________________________________
Date: May 07, 2002
You're talking about the Grand Rapids EIS. It's a nice system and now has a fuel flow option. One dummy light. If you want to feel like your in a 777 then individual lights are the order of the day. Either way, if someone designs it, homebuilders will buy it. Chris H -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jerry(at)tr2.com Subject: Re: AeroElectric-List: Re: annunciator panel Robert L. Nuckolls, III wrote: > > --> > > much to design or build . . . > *** Here's where I start getting serious "homebuilt envy". I don't want a fancy panel full of blinking lights. I want one BIG RED (idiot) LIGHT that means "there is a problem". This big red light would be in my immediate scan. It would be driven by a little processor that would have sensors for everything that could conceivably be a problem. As long as that light's off, I can concentrate on flying the plane. When the light goes on, I look at all the other stuff. Maybe include a voice annunciator ( or just Morse Code for us poor hams ) to say why the light went on. But the main thing is that when all's ok, it's OFF, and I just have this one item to scan to verify that. The processor could have subtle logic to decide whether something's OK or not. "If this input blips less than 1ms less than 20 times, that's OK..." "If this input is LOW and that one's HIGH, we've got trouble..." "If the bus voltage is trending low and yet we have high RPMs..." - Jerry Kaidor ( jerry(at)tr2.com ) = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: May 07, 2002
Wayne I think what I want and maybe others too is to have analog style gauges and dummy lights to go with them. I like the idea of a caution light that stays on until an exceeded parameter is corrected. I have not read it yet, but in this months SPORT AVIATION, there is an article about a trike and it has a nice looking enunciator panel, minus the gauges I think. I don't know too much about it except that you almost need to have two of every gauge? Else how does an analog or electric gauge trigger a light and keep it lit while it is out of limit? Chris H -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wayne McMullen Subject: Re: RE: AeroElectric-List: Re: annunciator panel --> Send me some of the details and I can design the circuits. Wayne ----- Original Message ----- From: <ptf(at)execpc.com> Subject: Re: RE: AeroElectric-List: Re: annunciator panel > > Thank you all for your input. I see there's quite a bit of interest. I > am pleasantly surprised at this. It would be nice if we collectively > could design a control circuit. Personally, I don't think it would be > very difficult but it sure could be alot of fun. Proscan avionics has > a beauty but $2500 bucks for about $150 bucks in parts seems a bit > excessive. I have already bought the annunciator lights. Honeywell > makes them. They are rectangular about one inch by a quarter of an > inch with two leds. This allows you to split the light and, if wanted, > have two annunciations per annunciator unit. I bought them from a > company called REM electronics. They're located in Ohio I think. These > little lights a bit pricey but not to bad. If you don't want fancy > annunciator lights most any led will suffice. The big thing is > designing a circuit. Lets say everyone wants the same basic stuff, > over voltage alert, low oil pressure, pitot heat, fuel, fuel pump, cyl > head temp, landing gear, (in my case I would like rotorhead speed). We > could compile a list and start to figure out a circuit. Each circuit > needs filtering, seperation from the other circuits, a way to be sure > the signal is valid etc. Any ideas would be greatly appreciated. I'll > try to throw something together and maybe we can get Bob to nurse us > along since he's the expert and I sure have never done anything like > this before. Sure sounds like fun though. Thanks to you all. > > > "Matthew Mucker" wrote: > > > > > I was thinking of building such a beast as I got closer to that > point... > > > > A few analog inputs with adjustable alarm setpoints, an audible > alarm, > > flashing lights... > > > > All I'd need is a PIC chip and some A/D converters and some time. > But I > > know that I know just enough to be dangerous, so I haven't really > done and > > concrete design on it. > > > > > -----Original Message----- > > > From: owner-aeroelectric-list-server(at)matronics.com > > > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Chris > > > Horsten > > > Sent: Tuesday, May 07, 2002 8:47 AM > > > To: aeroelectric-list(at)matronics.com > > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > > > > > > > > > > I've been hoping to see one come along too. But the pickings are > thin. > > > So here's my wish list: > > > > > > I want to be able to assemble an enunciator panel that exactly > matches > > > my needs. There should be different sized trays into which I can > insert > > > pre labelled switch-lamps. The lamps should flash ( and maybe > sound an > > > alarm ) if a parameter is exceeded and then I should be able to > > > acknowledge the alarm by pressing the lamp. It would then continue > to > > > glow solid until the out of limit parameter was fixed. Trays > should come > > > in 3, 4,5,6 etc sizes, with a base control unit. The best > alternative is > > > the EIS in my opinion, except not analog. I want the best of both > > > worlds. > > > > > > Any takers? > > > ChrisH > > > > > > -----Original Message----- > > > From: owner-aeroelectric-list-server(at)matronics.com > > > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Alex > > > Peterson > > > To: aeroelectric-list(at)matronics.com > > > Subject: RE: AeroElectric-List: Re: annunciator panel > > > > > > > > > --> > > > > > > Try www.proscanavionics.com. They displayed their systems at the > recent > > > Twin Cities RV Forum. > > > > > > Alex Peterson > > > Maple Grove, MN > > > RV6-A N66AP 140 hours > > > > > > > > > > > > > > >I'm looking for a control circuit for an annunciator panel. > Anyone > > > > > >know where I can find one? Thanks. > > > > > > > > > > > > > > > I'm not aware of any generic and/or off-the-shelf > > > > > "control circuit" for annunciation. You need to make > > > > > a list of all critters about which you wish to be > > > > > notified and describe the sensor that detects the > > > > > event. Ordinary events signaled by switch closures > > > > > simply supply +14 or ground to a lamp circuit. Some > > > > > parameters like low bus voltage, temperatures, > > > > > pressures, etc. may require some additional intelligence > > > > > to convert the analog parameter to a discrete output > > > > > that will drive a lamp. > > > > > > > > > > Virtually every annunciator system is custom to the > > > > > the application. > > > > > > > > > > Bob . . . > > > > > > > > > > > > > > > > > _- > ====================================================================== > > > _- > ====================================================================== > > messages. > > _- > ====================================================================== > > > _- > ====================================================================== > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: May 07, 2002
Subject: Re: SEC: UNCLASSIFIED - RV6 - IFR STANDARDS
> My understanding is as follows: > > a. alitmeter and ASI need to meet TSO standards. If you read FAR 91.411, it says the TSO "are to be considered tested and inspected as of the date of their manufacture". So two years out, they don't and would be subject to standard pitot static tests, just like non-TSO'd ones. ________________________________________________________________________________
Date: May 07, 2002
Did anyone look at "Proprietary Software Systems" Jim Franz has the hi intensity led's displays and the whole unit is very competitively priced. His Email is lfranz(at)compuserve.com or his phone # is 612 474-4154. It appears to be a very nice package. Jim Robinson Glasair 79R > > > I've been hoping to see one come along too. But the pickings are thin. So > here's my wish list: > > I want to be able to assemble an enunciator panel that exactly matches my > needs. There should be different sized trays into which I can insert pre > labelled switch-lamps. The lamps should flash ( and maybe sound an alarm ) > if a parameter is exceeded and then I should be able to acknowledge the > alarm by pressing the lamp. It would then continue to glow solid until the > out of limit parameter was fixed. Trays should come in 3, 4,5,6 etc sizes, > with a base control unit. The best alternative is the EIS in my opinion, > except not analog. I want the best of both worlds. > > Any takers? > ChrisH > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex > Peterson To: aeroelectric-list(at)matronics.com Subject: RE: > AeroElectric-List: Re: annunciator panel > > > --> > > Try www.proscanavionics.com. They displayed their systems at the recent > Twin Cities RV Forum. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 140 hours > > > > > > > > >I'm looking for a control circuit for an annunciator panel. Anyone > > > >know where I can find one? Thanks. > > > > > > > > > I'm not aware of any generic and/or off-the-shelf > > > "control circuit" for annunciation. You need to make > > > a list of all critters about which you wish to be > > > notified and describe the sensor that detects the > > > event. Ordinary events signaled by switch closures > > > simply supply +14 or ground to a lamp circuit. Some > > > parameters like low bus voltage, temperatures, > > > pressures, etc. may require some additional intelligence > > > to convert the analog parameter to a discrete output > > > that will drive a lamp. > > > > > > Virtually every annunciator system is custom to the > > > the application. > > > > > > Bob . . . > > > > > > > > > > advertising on the Matronics Forums. > members. > http://www.matronics.com/ > > > > > > > ________________________________________________________________________________
Date: May 08, 2002
Thanks Bob. You input is much appreciated. Actually, I had designed a circuit a year ago for my plane but then made the mistake of taking helicopter lessons. Now my plane morphed into a helicopter so the panel was put on hold. I thought I could use a "crow bar" type circuit to trigger the enunciators lights with some filtering built in much like your crowbar circuit for taking out an out-of-control alternator. Or perhaps something as simple as a 3904 transistor used to isolate the enunciators from the source of the signal via filtering. A series of these circuits, one for each ennunciation, could be tied into a relay that could be used to test the lamps simultaneously. An addition circuit would be required for a master warning. Thought maybe some TTL would work for this or a programmable chip. . Please post your ideas. I'm sure there's a better way then this. Thanks. ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: annunciator panel > > > > >Thank you all for your input. I see there's quite a bit of interest. I > >am pleasantly surprised at this. It would be nice if we collectively > >could design a control circuit. Personally, I don't think it would be > >very difficult but it sure could be alot of fun. Proscan avionics has > >a beauty but $2500 bucks for about $150 bucks in parts seems a bit > >excessive. I have already bought the annunciator lights. Honeywell > >makes them. They are rectangular about one inch by a quarter of an > >inch with two leds. This allows you to split the light and, if wanted, > >have two annunciations per annunciator unit. I bought them from a > >company called REM electronics. They're located in Ohio I think. These > >little lights a bit pricey but not to bad. If you don't want fancy > >annunciator lights most any led will suffice. The big thing is > >designing a circuit. Lets say everyone wants the same basic stuff, > >over voltage alert, . . . > > don't need ov annunciation but you do need lv warning. Got > the sensor and instructions coming on line in a few days. > > > low oil pressure, > > This is just a switch that operates a light > > > pitot heat, > > This is a current sensor you can make with a few turns > of wire around a reed switch that operates a light. > > > fuel, > > low fuel warning? floats holding magnets can close a > reed switch to light a light at calibrated level in tank. > Optical liquid level sensor mounted at desired level > in tank can sense low fuel. Either can light a light. > > > > fuel pump, > > Pressure switch on output side of pump? > > > > cyl head temp, > > Never seen a warning for cyl-hd temp in an airplane > but it's not hard. AD596 thermocouple conditioner > configured to light a light at a calibrated temperature > value is pretty easy to do. > > > > landing gear, > > Lights on still more switches > > > (in my case I would like rotorhead speed). We > >could compile a list and start to figure out a circuit. Each circuit > >needs filtering, seperation from the other circuits, a way to be sure > >the signal is valid etc. Any ideas would be greatly appreciated. I'll > >try to throw something together and maybe we can get Bob to nurse us > > > Except for cyl-hd temp and lv warn, every function described > is the simple lighting of a light based on a switch closure. > LV warn sensor is readily available. Cyl-hd temp, if one really > wants one isn't difficult to gin up either. All=in=all, not > much to design or build . . . > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: base antenna
Date: May 08, 2002
05/08/2002 10:40:08 AM Hey Bob: two quick question. I have an old radio that I'd like to set up in my hanger to listen to air traffic over head. 1) is there a way to build a cheap easy antenna that I can put on the roof for better reception? 2) can I use radio shack coax cable I a left over form a TV antenna install to run between the radio and antenna? Thanks BRUCE UVANNI RV6A FWF & Panel BUVANNI(at)US.IBM.COM ________________________________________________________________________________
Date: May 08, 2002
> > >Thanks, Bob. What got me thinking about this was Comant's blade antenna. >Somehow they're combining the signals from both blades. I assume (dangerous >word, I know) that their "signal combiner" is different from a traditional >diplexer, thus my question. Are you familiar with how the signal combiner >works? > >Thanks for your time on this! The "signal combiner" may indeed be a simple power mixer that would work similarly to feed two receivers from a single antenna. The black-magic part of the installation involves cutting feedlines between combiner antennas and combiner so that the radiation pattern (or reception pattern) produced is what is expected. Without looking at typical patterns, I'm not sure whether they work for and accept strong reception of the nose and tail and let it fall on the sides or some other rational. Bottom line is that you are certainly free to try anything and go fly it. Tune in a distant station and fly a 360 turn while observing whether or not you get deep and wide nulls in the reception pattern. If you find something that's acceptable to you, tell us all about it. Bob . . . ________________________________________________________________________________
Date: May 08, 2002
Subject: TSO Requirements
In a message dated 05/08/2002 2:52:29 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <> writes: " Larry, I am building an RV7 to an IFR standard. My understanding is as follows: a. alitmeter and ASI need to meet TSO standards. b. comm radios need to meet TSO standards, and most do. c. nav radios and indicators need to meet TSO. d. GPS need to meet TSO C129, but you need to select the sub category carefully. e. I am not sure, but if you use an efis then I think it needs to meet extra TSO requirements for redundancy and reliability. EFIS One might be a safe bet. Some useful references are: FAR 91.411, 91.413, Part 43 Appendixes D and E, there are others too. The engine, alternator and battery driving an all electric IFR plane do not have to meet any TSO, but they better be good. Pay particular attention to redundancy, you will need it one dark night. As a minimum you should consider two alternators, one battery. David Francis, VH-ZEE, Canberra, Australia" AeroElectric-List message posted by: lhdodge1(at)mmm.com << I am building an RV-6 and wish to have IFR capability. What components, avionics, and/or instruments need to be TSO'd? Larry Dodge >> 5/8/2002 Hello David, I disagree with your understanding and believe that it falls into the category of hearsay, gossip, and rumor. We ought to strive to do better than that in this forum. I assume that even though you are writing from Australia that you are answering for IFR operations in the USA because you cited US Federal Aviation Regulations. Is that correct? If that is the case then what is required is in the US FAR's. Since those Regulations are readily availabe in the public domain then one should be able to cite the specific regulation that says in just so many words that "No one may fly under IFR in US controlled airspace unless their XXXXXX equipment meets the requirements of TSO YYYYYY." I'm not aware of one single Regulation that reads like that. Case in point: Even FAR 91.207 regarding ELT's doesn't say that one must have a new ELT that meets some specific TSO. Just that 1) The ELT must be approved and in operable condition, and 2) An ELT that meets the old TSO may not be used for new installations after June 21, 1995. The fact is that much of the equipment available to us as amateur builders of experimental aircraft is TSO'd and 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: May 08, 2002
Subject: Re: Switch Breakers
> >Mark, in Cedar Rapids wrote... > >"...Another example if my memory serves correctly is the Swissair MD-ll >that went down off the east coast a few years back...seems they had an >electrical fire that did NOT blow the breaker/fuse, and the entire >aircraft was lost (I think it was in the cabin entertainment system, >which may not be built to the same standard as the cockpit avionics, but >was probably as robust as the sport aviation stuff in my panel)." > >As an American Airlines MD-11 First Officer at the time Swissair crashed >off the coast of Newfoundland, I was keenly interested in the event (for >obvious reasons). When the dust settled and the investigation was >complete, it was part of the official findings that the crew could >easily have reached a suitable airfield with the time remaining, but >opted to loiter while trying to troubleshoot. This decision was >tragically fatal for hundreds of people and should be remembered for all >time by all who fly airplanes. > >Designing your electrical system to be safe is great, but let's not >forget the big picture. Nobody will ever second-guess your decision to >LAND and then troubleshoot, but doing it in reverse order may have >deadly consequences. I seem to recall that the incident cited was ultimately blamed on a wire bundle fire which ignited insulation. The situation got worse with more rapidity than the crew anticipated and they blew away get-on-the-ground- quick time with a combination of troubleshooting efforts and other distractions. If I'm recalling this incorrectly, perhaps someone on the list can enlighten me. If my recollection is correct, then outcome of this situation would have been no different had fuses, breakers or switch-breakers been in service on the faulted wiring . . . you can have a high resistance fault that is also high energy output that does not draw sufficient current to trip the protection. Much more common in 28 and 115 volt systems than in 14 volt systems. The likelihood of this condition existing in your homebuilt is extremely remote and still . . . rather than try to isolated and troubleshoot the problem, I'd shut the whole system down and do hand-held nav/comm to some comfortable arrival spot. If you'd like to keep a turn coordinator running, you could arrange to power it from the battery bus via a miniature toggle switch mounted next to the instrument. Odds are greater that, the t/c is going to go t/u at some point in the future due to corrosion of the switch than the odds you'll need to run the t/c during a total blackout of the panel due to smoke in the cockpit. Bob . . . ________________________________________________________________________________
Date: May 08, 2002
Subject: Re: Switch breakers
> > >One things I started thinking about, is silly checklists. >In the Beech, and Cessna's I have flown, there is the >checklist item "make sure the CB's are all in" (paraphrasing). > >So pilot A goes out flying, maybe at night or something, >a circuit breaker pops, and doesn't notice it. Walks in >the FBO turns in the key, and goes out for a beer after >a successful adventure. > >Pilot B shows up the next day, the CB is poped out, so, >just like the check list says, mashes in said popped CB. >Flys around VFR day, no big deal. > > >Now that I am thinking about it, I hope I'll at least >think about that popped CB before taking flight. It is >a reminder that something is amiss (or at least a mechanic >might have been looking at something?). It won't be >a wrote, checklist item anymore. I wrote a checklist for our company Bonanza a few years back that called for testing the OPERATION of everything that could be conducted and observed from the pilot's seat. It was insufficient to see that the breaker was IN and simply assume that the piece of equipment powered from that breaker was going to work. Our shutdown checklist also included a check of the breaker panel. If a breaker was found OUT, a tye-wrap was to be placed around the extended breaker-button and a squawk sheet cut on the pad of duplicate squawk tickets keep in the map-case along with a supply of miniature tie-wraps. A pullout copy of the squawk sheet was left at the desk for routing to the appropriate mechanic. Anyone who came out to the airplane later could look in the squawk book and see what items had been worked since he last flew and what items were still open. I don't recall that anyone ever elected to fly with a breaker tied off. I was never presented the situation myself. I can imagine that if a tied breaker were for some accessory I didn't need, I might go ahead and use the airplane anyhow . . . the bottom line was that there was a system to check for operation as part of preflight, alert others as to potential problems both from a maintenance and operational perspective, and a system to track fixes. Whether you have a fuse panel or breaker panel, it is incumbent upon the pilot to see that all the things necessary and/or desirable for today's mission are functional before takeoff irrespective of the condition of a breaker or fuse. If something is found not to work, an informed decision is possible as to whether or not the mission gets scrubbed for maintenance. Bob . . . ________________________________________________________________________________
Subject: Re: TSO Requirements
Date: May 08, 2002
BAKEROCB(at)aol.com wrote: > > b. comm radios need to meet TSO standards, and most do. *** Don't think so. The King KX-170(A,B), possibly the most popular general aviation navcom ever made, is not TSO'd. They also made a TSO'd version, the KX-175. I've never seen a KX-175 installed in an airplane! - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 08, 2002
Wayne McMullen wrote: > > > Does any know whart TSO means? > "Technical Standard Order". Often, they just reference an industry document of some sort. For example, the TSO for VSI's references an SAE ( Society of Automotive Engineers ) document. ( I found this out when I wanted a 2 1/4 inch VSI for an old airplane with a small panel. I was investigating buying a non-TSO'd instrument and just testing it myself. ) - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: May 08, 2002
It sounds like what you want is similar to the setup in an F-14. There is a large yellow light right in front of the pilot that says "Master Caution" and illuminates on any problem. You just push it in to reset it and then glance down to the side to see which trouble light is lit. The ones on the side panel stay lit. It shouldn't be too hard to rig such an animal and I plan to put one in my RV-8A. I am building an all electric aircraft and figure a few instances of signal conditioning or level shifting with several OR gatesshould take care of most of it. Sourcing the light panel with the custom lettering will be the hardest part. I can't see spending more than a couple hundred for this. Bill Christie, RV8A, Phoenix ----- Original Message ----- From: <jerry(at)tr2.com> Subject: Re: AeroElectric-List: Re: annunciator panel > > Robert L. Nuckolls, III wrote: > > > > > > much to design or build . . . > > > > *** Here's where I start getting serious "homebuilt envy". I don't want a > fancy panel full of blinking lights. I want one BIG RED (idiot) LIGHT > that means "there is a problem". This big red light would be in my > immediate scan. It would be driven by a little processor that would have > sensors for everything that could conceivably be a problem. As long as > that light's off, I can concentrate on flying the plane. When the light > goes on, I look at all the other stuff. Maybe include a voice annunciator > ( or just Morse Code for us poor hams ) to say why the light went on. But > the main thing is that when all's ok, it's OFF, and I just have this one > item to scan to verify that. > > The processor could have subtle logic to decide whether something's OK > or not. > "If this input blips less than 1ms less than 20 times, that's OK..." > "If this input is LOW and that one's HIGH, we've got trouble..." > "If the bus voltage is trending low and yet we have high RPMs..." > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 08, 2002
Subject: TSO Requirements 2
In a message dated 05/08/2002 2:52:29 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <> writes: " Larry, I am building an RV7 to an IFR standard. My understanding is as follows: a. alitmeter and ASI need to meet TSO standards. b. comm radios need to meet TSO standards, and most do. c. nav radios and indicators need to meet TSO. d. GPS need to meet TSO C129, but you need to select the sub category carefully. e. I am not sure, but if you use an efis then I think it needs to meet extra TSO requirements for redundancy and reliability. EFIS One might be a safe bet. Some useful references are: FAR 91.411, 91.413, Part 43 Appendixes D and E, there are others too. The ......skip.......... David Francis, VH-ZEE, Canberra, Australia" AeroElectric-List message posted by: lhdodge1(at)mmm.com << I am building an RV-6 and wish to have IFR capability. What components, avionics, and/or instruments need to be TSO'd? Larry Dodge >> 5/8/2002 Hello David, I disagree with your understanding and believe that it falls into the category of hearsay, gossip, and rumor. We ought to strive to do better than that in this forum. I assume that even though you are writing from Australia that you are answering for IFR operations in the USA because you cited US Federal Aviation Regulations. Is that correct? If that is the case then what is required is in the US FAR's. Since those Regulations are readily availabe in the public domain then one should be able to cite the specific regulation that says in just so many words that "No one may fly under IFR in US controlled airspace unless their XXXXXX equipment meets the requirements of TSO YYYYYY." I'm not aware of one single Regulation that reads like that. Case in point: Even FAR 91.207 regarding ELT's doesn't say that one must have a ELT that meets some specific new TSO. Just that 1) The ELT must be approved and in operable condition, and 2) An ELT that meets the old TSO may not be used for new installations after June 21, 1995. The fact is that much of the equipment available to us as amateur builders of experimental aircraft is TSO'd and (Oops, sorry about that. I got interrupted and distracted by the secretary of war and inadvertently sent this before it was ready. Let me continue) we can often benefit from choosing such equipment even though we are not required to. Again the issue of what is required / recommended by the Regulations and Advisory Circulars for standard type certificated aircraft and what is mandated by regulations for amateur built experimental aircraft are: 1) In many cases quite different, and 2) Not readily apparent unless one studies the Regulations / AC's in detail. Case in point: AC No. 20-138 Subject: "Airworthiness Approval of GPS Navigation Equipment For Use As A VFR and IFR Supplemental Navigation System". This AC describes a burdensome process to obtain such approval and refers to TSO C129. But buried within the AC is this paragraph "8.a. Application process. Operators wishing to obtain approval of Class A( ) GPS equipment for IFR operations may do so via the type certificate (TC) or supplemental type certificate (STC) process." Neither of these processes pertain to amateur built experimental aircraft. In passing please let me make two additional points about TSO's: A) Many TSO's had a "Deviations" paragraph that says in effect that the FAA has provisions for using alternate or equivalent means of compliance with the TSO's criteria and applicants can go that route with a demonstration of equivalence. B) I stopped maintaining a library of TSO's quite a while ago because every one seemed to be just two or three pages long that didn't say anything. But they included a list of a bunch of references such as RTCA, ARINC, SAE, DOT, etc, etc, documents. Without all the numerous references the TSO were mostly useless when it came to technical information. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Re: TSO Requirements 2
Date: May 09, 2002
I did some checking on TSOed equipment. My certified Bellanca does NOT have any TSOed equipment. Surprised? Shouldn't be as TSOs only started in 1947 and is NOT the only way to get appliances that are approved for flight. Here is Joe Norris' EAA peer re-viewed statement... "Equipment does not need to be manufactured to a TSO, even for IFR flight. A TSO (Technical Standard Order) is a guideline issued by FAA for the manufacture of a component. It is a method of compliance with the regulations regarding performance and accuracy, and as such can be used by a manufacturer to streamline the approval process for a particular component. A TSO is not THE ONLY means of compliance. In fact, so long as the equipment in your aircraft meets the requirements spelled out in FAR 91.205 (as required by your operating limitations) and can be proven (through flight or ground testing) to perform within the required tolerances, you're good to go. TSOs are relatively new." (They were first set-up in 1947 and heavily revised in 1980.) "There are literally hundreds of aircraft flying today, both type certificated and experimental, that don't have a single TSOed radio or instrument installed. TSOs were developed to aid in the manufacturing of aviation products, not as an approval for installation. Hope this helps. Let me know if you have further questions. Joe Norris EAA Aviation Information Services EAA Aviation Center, Oshkosh, WI 888-322-4636, extension 6806 jnorris(at)eaa.org We are pleased to provide this info as an EAA membership benefit. To ensure that this service continues, renew your membership or join EAA today by calling 800-843-3612 or 920-426-5912. Visit EAA on the web at http://www.eaa.org/" If you would like to look at the history of TSO by the FAA go to ... http://av-info.faa.gov/tso/Histry/hist96.htm which also has some information on the application of TSOs. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: TSO Requirements 2 In a message dated 05/08/2002 2:52:29 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <> writes: " Larry, I am building an RV7 to an IFR standard. My understanding is as follows: a. alitmeter and ASI need to meet TSO standards. b. comm radios need to meet TSO standards, and most do. c. nav radios and indicators need to meet TSO. d. GPS need to meet TSO C129, but you need to select the sub category carefully. e. I am not sure, but if you use an efis then I think it needs to meet extra TSO requirements for redundancy and reliability. EFIS One might be a safe bet. Some useful references are: FAR 91.411, 91.413, Part 43 Appendixes D and E, there are others too. The ......skip.......... David Francis, VH-ZEE, Canberra, Australia" AeroElectric-List message posted by: lhdodge1(at)mmm.com << I am building an RV-6 and wish to have IFR capability. What components, avionics, and/or instruments need to be TSO'd? Larry Dodge >> 5/8/2002 Hello David, I disagree with your understanding and believe that it falls into the category of hearsay, gossip, and rumor. We ought to strive to do better than that in this forum. I assume that even though you are writing from Australia that you are answering for IFR operations in the USA because you cited US Federal Aviation Regulations. Is that correct? If that is the case then what is required is in the US FAR's. Since those Regulations are readily availabe in the public domain then one should be able to cite the specific regulation that says in just so many words that "No one may fly under IFR in US controlled airspace unless their XXXXXX equipment meets the requirements of TSO YYYYYY." I'm not aware of one single Regulation that reads like that. Case in point: Even FAR 91.207 regarding ELT's doesn't say that one must have a ELT that meets some specific new TSO. Just that 1) The ELT must be approved and in operable condition, and 2) An ELT that meets the old TSO may not be used for new installations after June 21, 1995. The fact is that much of the equipment available to us as amateur builders of experimental aircraft is TSO'd and (Oops, sorry about that. I got interrupted and distracted by the secretary of war and inadvertently sent this before it was ready. Let me continue) we can often benefit from choosing such equipment even though we are not required to. Again the issue of what is required / recommended by the Regulations and Advisory Circulars for standard type certificated aircraft and what is mandated by regulations for amateur built experimental aircraft are: 1) In many cases quite different, and 2) Not readily apparent unless one studies the Regulations / AC's in detail. Case in point: AC No. 20-138 Subject: "Airworthiness Approval of GPS Navigation Equipment For Use As A VFR and IFR Supplemental Navigation System". This AC describes a burdensome process to obtain such approval and refers to TSO C129. But buried within the AC is this paragraph "8.a. Application process. Operators wishing to obtain approval of Class A( ) GPS equipment for IFR operations may do so via the type certificate (TC) or supplemental type certificate (STC) process." Neither of these processes pertain to amateur built experimental aircraft. In passing please let me make two additional points about TSO's: A) Many TSO's had a "Deviations" paragraph that says in effect that the FAA has provisions for using alternate or equivalent means of compliance with the TSO's criteria and applicants can go that route with a demonstration of equivalence. B) I stopped maintaining a library of TSO's quite a while ago because every one seemed to be just two or three pages long that didn't say anything. But they included a list of a bunch of references such as RTCA, ARINC, SAE, DOT, etc, etc, documents. Without all the numerous references the TSO were mostly useless when it came to technical information. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: May 09, 2002
Subject: TSO standards
In a message dated 05/09/2002 2:52:24 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <> writes: << BAKEROCB(at)aol.com wrote: b. comm radios need to meet TSO standards, and most do. *** Don't think so. The King KX-170(A,B), possibly the most popular general aviation navcom ever made, is not TSO'd. They also made a TSO'd version, the KX-175. I've never seen a KX-175 installed in an airplane! Jerry Kaidor ( jerry(at)tr2.com ) >> 5/9/2002 Hello Jerry, I appreciate your efforts to inform us and I further appreciate your efforts to edit postings so that we don't have to wade through extraneous material. But in your editing please take care to get the right person attributed to the right material. What you quoted above is an extract from some other person's posting within my posting and my position is exactly the opposite of what you included above. Thank you. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: May 09, 2002
Subject: Pins-outs needed for Apollo GX 65 and KX-170B + advice
RV-6A owner asked me to install a new intercom and get radios working on his newly-purchased 6A with a history of Avionics problems. Request suggestions on how to approach install of new intercom along with tie in to these two radios. Thanks! Vern ________________________________________________________________________________
Subject: Swissair and fire
Date: May 09, 2002
Cheers. The accident report is not complete in that the final cause must be somewqhat conjectural, due to the destruction aspects. " I seem to recall that the incident cited was ultimately blamed on a wire bundle fire which ignited insulation. The situation got worse with more rapidity than the crew anticipated and they blew away get-on-the-ground-quick time with a combination of troubleshooting efforts and other distractions. If I'm recalling this incorrectly, perhaps someone on the list can enlighten me." This is essentialy the conclusion reached. The extensive use of kapton insulation brought about discovery that (a) time, (b) moisture and (c) vibration caused the insulation to produce tiny cracks. These created the occasional trip of C/Bs over time. The great danger was in the re-saetting of the c/b, fuse, etc (no matter which). With the resurgence of power small but very hot (1200deg) sparks brought the insulation well above its specs and it became explosive. This has been demonstrated to destroy accompanying bundled circuits or to bring other materials to high temperature - in fact a video in the USN labs shows it blowing a steel plate in two. "If my recollection is correct, then outcome of this situation would have been no different had fuses, breakers or switch-breakers been in service on the faulted wiring . . . you can have a high resistance fault that is also high energy output that does not draw sufficient current to trip the protection. Much more common in 28 and 115 volt systems than in 14 volt systems." Quite agree. The greatest effect seems to have been visitted on USN F-18s operating off carriers in tropical waters (see above), which accelerated the effects. These provided earlier warnings, but by then makers had used the wire in a number of major carriers - mine included. the saving grace may be that few are wet, or vibrate. The entertainment system installed in the DC10 (or MD-something) used this wire, and the burn patterns point to it as an early cause. "The likelihood of this condition existing in your homebuilt is extremely remote and still . . . rather than try to isolate and troubleshoot the problem, I'd shut the whole system down and do hand-held nav/comm to some comfortable arrival spot." Exactly. Don't ever reset a C/B unless you KNOW why it safely popped. The details of the slow reaction of the crew was in line with airline procedure, in that it appears the F/O wanted to land overweight, the Captain insisted on detailed procedures as laid down. Usual procedure in the event of "smoke of unknown origin" was to shut off most of the various sections of the electrical system to establish reduction of smoke, then rebuild the system bit by bit until only the faulty section is left off. If I'd known then what I know now............Who are we.............etc.etc.? Ferg Europa A064 ________________________________________________________________________________
Date: May 09, 2002
Subject: Annunciators
Okay guys, I guess I'll spill the beans. I've been working on a series of annunciators, just the light part, and they are pretty close to being done. They are LED based, sunlight readable, dead-front, available in red, green, and yellow, and can be matrix stacked in any x-y configuration. Physical size is 1w x 0.375h x 1d, a little rectangular box. The legend area essentially covers the entire front face. They should be priced at a point that would make then attractive to the homebuilt crowd. Each annunciator has a master caution output so it can activate the master caution annunciator (on your glareshield or somewhere noticeable). Of course you only want to light that for "bad" stuff. Each annunciator also has a "lamp test" terminal so you can hook up a lamp test push-button that lights all of the indicators at once. This is sort of questionable for LED based indicators, but who doesn't like to see all the pretty lights light up? The annunciators activate on a "ground" input, but an inverter module is available for input signals that go "high" for the desired annunciation condition. I also have a vibrating module, sort of like a pager, that could be slaved to the master caution also. I find that if you place this in the seat cushion just under your thigh, it really gets your attention. One thing that has delayed me a bit is getting the packaging figured out so I don't have a bunch of tooling costs. I've got some prototypes of what I think will be a good solution just about ready. The latest idea for ordering would be to order the color and a legend from a standard set. If more than one annunciator is ordered, the customer will provide the layout desired and they will be configured and wired up prior to shipping. This is mostly because the bussed connectors (power, master caution and lamp test) are not something the average builder would have the tooling for. The sensor input is a standard tab. Custom legends could be accomodated, but there would be some addtional costs for the art charges etc. What do you think? Do these have market potential? Years ago I also designed something I called a "Pilot's Associate". It took in analog voltages and allowed you to set alarm thresholds, high and/or low. It was designed to drive a set of annunciators (idiot lights). I tabled it when my RV-4 project went into hibernation. So, I guess great minds think alike. Mike ________________________________________________________________________________
Date: May 09, 2002
> > >RV-6A owner asked me to install a new intercom and get radios working on >his newly-purchased 6A with a history of Avionics problems. >Request suggestions on how to approach install of new intercom along with >tie in to these two radios. Thanks! Vern What kinds of "problems" were experienced? I would start by taking out the entire system and go back in with my own wiring that connects bench-tested black boxes. Bob . . . ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: Your book, and welding cable for ground
I"m building a GIII. Have all engine electrics from B&C. Will have about 10 ft of battery cable to starter, and various busses. You mentioned welding cable for battery ground. Could it be used for all wiring calling for no. 2 cable? Or should I order no. 2 AC cable instead? Given the total cost of building this machine and the market value when completed, I think I'd go for 22759 wire for all the connections . . . but welding cable can be used too. It's about 15% heavier. Love your book, but I'm still an electical putz. ABy the way, I'm planning an all electric plane. Am using B&C 60 amp alt, and the 8 amp dynamo, all with the recommended regulators and overvoltage stuff. Does one of your book's diagrams cover what I should be shooting for, for redundancy? Why 60A? Have you done a load analysis that shows you need this kind of capacity. How about a 40A machine and used the $saved$ to buy aircraft wire for the fat feeders? The quest for "redundancy" has to be satisfied by an analysis of how you intend to use your airplane and what you consider to be the minimum equipment needed to do the most complex mission. Bob . . . -------------------------------------------- | People are far more willing to pay | | for being amused than for anything else. | | -Thomas Edison- | -------------------------------------------- ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: subminiature connector
Hey Bob, I just ordered your book today and was browsing your web site. I was looking for a connector for the MAC servos. I saw the one you made from Radio shack but couldn't find it on their web site. Do you have a part number or better yet, a better connector. Surely their must be a 6 pin connector out their that will do the job. The connectors I used were the 276-1537 and 276-1538 which you can find on the website under wire-cable-hardware & tools/connectors/miscellaneous or by entering the part numbers in the search box. The connectors are stocked by all the stores. I was very pleased to find a product I have been looking for, the gooseneck map lite. I ordered one of those today also. Thanks for the help, and the great discussions on the Electric list, I'm pleased that you find it useful. Bob . . . ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: Over voltage circuit
A while back I ordered an over voltage circuit from AeroElectric Connection in KS. In reading the material shipped with the order I noted that the circuit is one time use, whereas it protects the VR by opening up the circuit when an over voltage condition is sensed. From what I read the circuit is a one time use. Am I wrong in my understanding? No, when it triggers due to ov condition, it puts a dead short downstream of your alternator field control breaker and causes it to open up as it would be expected to do with any other fault on the line. The breaker can be reset and the ov module can be expected to perform its assigned task many, many times. In discussion with another builder he advises that he is using a circuit that energizes a relay when an over voltage condition is sensed. Are you familiar with this device? This is a technology used in decades past as the best we knew how to do in 1975 . . . I've designed and presided over the manufacture of tens of thousands of "OV Relays". We went to crowbar ov protection in all of B&C's alternator controller products about 1985. The OVM-14 crowbar module was introduced to the market about 7 years ago. Over 700 have been sold and I presume most are by now in service. The reason this comes up is that on Saturday I had my first engine start (Rotax 914) but did not have any charging of the battery. On advise of a knowledgeable friend I used a Cessna split switch that turned on and off the alternator separate from the battery. Information in the installation manual states that the circuit I had that switch inserted must not be opened else an over voltage condition will occur which will fail the VR if a 22K MFD capacitor is not installed. I had a 22K MFD cap installed but it apparently did not protect the circuit from the over voltage condition. Of course there's always the possibility that I got a bad VR from the start. Whatever the situation is, it would not have happened had I had I at least had the over voltage circuit, I purchased, in place. I cannot advise as to the validity of advice given without seeing the schematic. Are you familure with the Rotax charging system enough to explain the reason for the over voltage situation that might have occurred on my engine when the Alternator circuit was opened. I should add that this circuit, that I had the switch in is fused. If that fuse were to fail the VR would fail. Again the 22K MFD cap was suppose to "protect" from the over voltage. Drop me a copy of how your airplane is wired and I'll see if I can deduce the cause of your problem. The 22K mFd capacitor is there for noise filtering and no other purpose. It CANNOT protect against an overvoltage condition brought on by regulator failure. It MIGHT mitigate an ov condition due to regulator instability and in particular under light loads. Suggest you study Figure Z-16 of a Revision 10 issue of the AeroElectric Connection and consider wiring your airplane as illustrated therein. If you don't have the book, you can download the chapter at: http://209.134.106.21/articles/Rev10/z10.pdf I'll comment on the probable cause of your problem after I see the wiring diagram. Bob . . . ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: May 09, 2002
For a 6 pin connector, look at the DTM06-6SA Plug and DTM04-6PA Receptacle available at www.laddinc.com. David Swartzendruber Wichita > > Hey Bob, > > I was looking for a connector for the MAC servos. I saw the one > you made from > Radio shack but couldn't find it on their web site. Do you > have a part > number or better yet, a better connector. Surely their must > be a 6 pin > connector out their that will do the job. > ________________________________________________________________________________
Subject: Re: TSO standards
Date: May 09, 2002
BAKEROCB(at)aol.com wrote: > the right material. What you quoted above is an extract from some other > person's posting within my posting and my position is exactly the opposite of > what you included above. > *** Sorry about that! - Jerry ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: annunciator panel
Autometer makes a product called the Tri-Alert. It is a black box that takes a signal from 3 of it's gauges(individually) and allows you to set the desired trip point for whatever you are monitoring. Upon hitting the set point it will give a 12 volt output that you can use hook up to a light and/or an alarm. I put one in and am monitoring for low oil pressure, high oil temp and low voltage. The box allows you to select whether you monitor high or low limits. I don't know if it will work with other manufacturer's gauges (electrical senders). It costs about $75.00 and I got it from Jeg's racing equipment. Good luck, Rick D ________________________________________________________________________________
Date: May 09, 2002
Subject: Nav Antenna Question
Bob is right, one com antenna will serve for the Nav, Loc, and GS with a diplexer, or you can use one com for the Nav & Loc, and the other for the GS . In the RV series you don't have to put them externally on the tail, put them in the wingtips. I have used this system on two airplanes and it works fine. I hate to see an experimental airplane loaded up with external antennas. The only two that need to be external is the transponder and the com. The com antenna in the wingtip will also work as a com, but at a reduced range. For whatever its worth. Frank even for ________________________________________________________________________________
Subject: Re: Nav Antenna Question
Date: May 09, 2002
On the subject of diplexers, is it okay to not use all of the outputs on the diplexer? I have one that is designed to run 2 VOR/LOC receivers and 2 GS receivers and I only have one of each. Any problem with capping off the extra jacks? Russ ----- Original Message ----- From: <FSmith9890(at)aol.com> Subject: AeroElectric-List: Nav Antenna Question > > Bob is right, one com antenna will serve for the Nav, Loc, and GS with a > diplexer, or you can use one com for the Nav & Loc, and the other for the GS > . In the RV series you don't have to put them externally on the tail, put > them in the wingtips. I have used this system on two airplanes and it works > fine. I hate to see an experimental airplane loaded up with external > antennas. The only two that need to be external is the transponder and the > com. The com antenna in the wingtip will also work as a com, but at a > reduced range. For whatever its worth. Frank > > > even for > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 09, 2002
Russ Werner wrote: > > On the subject of diplexers, is it okay to not use all of the outputs on the > diplexer? I have one that is designed to run 2 VOR/LOC receivers and 2 GS > receivers and I only have one of each. Any problem with capping off the > extra jacks? > *** I suspect that it is OK, but you have to cap them off with 50-ohm loads. These are just a connector with a 50-ohm resistor built in. Or you can make your own. The resistor would go from the center pin to the outside of the connector. This will make the splitter "think" that the receivers it was designed to drive, are actually connected. Also, 75-ohm terminators are really common in high-tech surplus, because Ethernet used to use them. Probably work fine.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: SEC: UNCLASSFIIED - IFR REQUIREMENTS
Date: May 10, 2002
Hello David, I disagree with your understanding and believe that it falls into the category of hearsay, gossip, and rumor. We ought to strive to do better than that in this forum. 'OC' Baker Yep, some of these threads get exciting. Hullo OC, yes I write from Australia. The connection is that, like many countries, our regulator calls up the FAR for airworthiness certification matters. So I get to read the FARs at bedtime too. Not relevant, but I lived & flew in the US for two years, great fun. The picture for IFR in an experimental looks like this: AC 20.27 para 7 says a special airworthiness certificate may be issued, with any operational limitations the inspector thinks wise. The limitations are expressed in Order 8130.2, which in turn calls up FAR 91.205, mandatory instruments & radios. Where a FAR says an approved gadget is required, guidance as to what they are likely to approve will generally be found in a TSO. They may also approve other satisfactory equipment if convinced its safe. So the lowest risk way to avoid any operating limitations for phase 2 listed in the special certificate of airworthiness is to have equipment that performs closely to a TSO, which is not hard, particularly for nav radios, they are freely available. Have fun, David Francis -----Original Message----- > ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: Yak electrics
> >There is a big capability difference between the original electrical >system and what the b&c can produce. The original is rated at something >like 107A and 28V which gives about 3kW. I guess the russian >instrumentation (and radios) were pretty power hungry - Apparently the >Yak18 (and probably others) had a very nice (but large and heavy) >non-tumbling AI in it. I can only imagine what they were using for >radios. Can you say vacuum tube? Not quite like the surface mount >stuff we have today. Rugged though. > >If you can get along with something less than a 3kW power budget (I >know, that means you'll have to get an extension cord to run the >welder... ) then going to something from b&c would be a lot lighter. You might call Bill at 316.283.8000 and talk to him about his customer experience with the smaller PM alternators on this genre' of airplane. I know there are quite a number of these aircraft flying day/vfr with Bill's very light alternator replacing the flame-throwing pig generator. He would be in a better position to evaluate your needs against his experience and products. Bob . . . ________________________________________________________________________________
Date: May 09, 2002
Subject: Re: base antenna
> > >Hey Bob: two quick question. >I have an old radio that I'd like to set up in my hanger to >listen to air traffic over head. >1) is there a way to build a cheap easy antenna that I can put on the roof >for >better reception? Sure . . . see http://www.sadona.com/news/ant_jpole2.html Multiply all dimensions shown by 1.15 to make it work best in aircraft band. >2) can I use radio shack coax cable I a left over form a TV antenna install >to >run between the radio and antenna? This will work but it may be messy to get good connections if it's an aluminum foil shield. RG-58 (real cheap from Radio Shack) might be easier to work with. Bob . . . ________________________________________________________________________________
Subject: ammeter
Date: May 10, 2002
22, 2000) at 05/10/2002 09:02:42 AM A am planning to install an ammeter in my RV-6 panel. Which circuit should be monitored - alternator or battery? Regards, Larry Dodge ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: Switch for dimming light
Bob I am using the LR-3 alternator controlers for my Glasair, per Figure Z-4. I seem to remember a thread awhile ago that the lamp output to the warning lamp needed something to work with a LED. I couldn't find the reference. Is there any problem using LED's instead of regular light bulbs? Jim Robinson Glasair 79R ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: ammeter
> >A am planning to install an ammeter in my RV-6 panel. Which circuit should >be monitored - alternator or battery? It's not a question of "should" . . . eithe one yields certain useful information. If you're going to subscribe to one of the power distribution philosophies outlined in the 'Connection, then a battery ammeter is very difficult to implement . . . alternator loadmeter is easy. In either case, please do plan on active notification of low voltage (bus below 13.0 volts). Ammeters and voltmeters are diagnostic instruments . . . the flashing light is your first line of defense against the dark-panel- syndrome. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: Battery charging
I have 2 12v Gill RG batteries in my airplane (a Mooney Rocket conversion, M20K). The batteries are in parallel, 12 volt system. Why two batteries in parallel versus one big one? I would like to use a standard auto battery charger to recharge or boost the batteries per the service instructions. I would like to charge them in the airplane (since removing them is incredibly difficult) using the ground power adapter / jumper cables. What is wrong or good about this picture? No problem I can see. Many owner/operators have provided some remote access to the batteries accessed by come conveniently located connector. Would recommend a 5A fuse at the battery be used to protect this always hot wire between batteries and charging connector. This would of course, limit the output of your charger to less than 5A . . . probably okay for most little battery maintainers. If your batteries are flooded cell products, how about putting an RG battery in there and not have to worry about an external battery charging connection. If you don't run off and leave the master switch on, you can about guarantee that the RG battery will be there when you need it - without benefit of external charging support. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Date: Thursday, May 9, 2002 8:46 pm Subject: AeroElectric-List: Re: base antenna > >2) can I use radio shack coax cable I a left over form a TV > antenna install > >to > >run between the radio and antenna? > > This will work but it may be messy to get good > connections if it's an aluminum foil shield. RG-58 > (real cheap from Radio Shack) might be easier to work > with. > If you want to transmit with your base station, won't you get pretty high SWR's with 75ohm tv cable? I think you could recieve just fine, but I'll bet you won't be able to talk to very distant aircraft. I am pretty sure the com radios are 50ohm output? Regards, Matt Prather ________________________________________________________________________________
Date: May 10, 2002
Subject: IFR Avionics requirements
I have been searching for FAR information which stipulates the avionics requirements for IFR navigation. I am only interested in locating the appropriate section which identifies the NECESSARY NAVIGATION RADIOS required for IFR flight. I understand that somewhere in the FARs it mentions something about only needing equipment for the type of navigation and approaches which are required for a particular flight. The issue is...... I want to set up a light IFR RV7A to punch through overcasts when necessary..... That=B9s it, no real weather stuff to speak of. I seem to remember that 1 VOR was the minimum, and that GPS alone could not be approved as sole source IFR. I would like to set up a minimum IFR RV with GPS only as my sole source of navigation and for non-precision approaches. I do not want to include the outdated VOR in my panel. Is this going to be possible? Are the rules different in any way for experimental aircraft flying under IFR. Can someone answer my question properly or refer me to the FARs which are applicable to my question. Thank you. Victor S. ________________________________________________________________________________
Date: May 10, 2002
Subject: NavAid autopilot available
I have a new, never installed NavAid AP1 and a crank S2 servo. I've had it about 3 months, I've changed my mind and I'm going to use an S-Tek. The new price is $1300 but they have a 6 month backlog. If anyone here wants one now, I'll sell this for the same price. ________________________________________________________________________________
From: "Steve Richard" <steve(at)oasissolutions.com>
Date: May 10, 2002
Thanks for the info. I'm not sure why they chose 2 batteries over one, especially since they put both of them in a big box that has to be hoisted into the tail of the aircraft. Maybe because they are standard and can be eaily ordered? Steve -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: Battery charging I have 2 12v Gill RG batteries in my airplane (a Mooney Rocket conversion, M20K). The batteries are in parallel, 12 volt system. Why two batteries in parallel versus one big one? I would like to use a standard auto battery charger to recharge or boost the batteries per the service instructions. I would like to charge them in the airplane (since removing them is incredibly difficult) using the ground power adapter / jumper cables. What is wrong or good about this picture? No problem I can see. Many owner/operators have provided some remote access to the batteries accessed by come conveniently located connector. Would recommend a 5A fuse at the battery be used to protect this always hot wire between batteries and charging connector. This would of course, limit the output of your charger to less than 5A . . . probably okay for most little battery maintainers. If your batteries are flooded cell products, how about putting an RG battery in there and not have to worry about an external battery charging connection. If you don't run off and leave the master switch on, you can about guarantee that the RG battery will be there when you need it - without benefit of external charging support. Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: May 10, 2002
It might have something to do with weight and balance. Check your W&B to see if you can use a different battery. You may need the weight in that location. FAA is rather particular about even the brand of battery that you are legally permitted to use. I presume that your airplane configuration was created by STC. To change the configuration from the STC takes a 337 with field inspection. FSDO might even want you to run it past engineering. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Steve Richard" <steve(at)oasissolutions.com> Subject: RE: AeroElectric-List: Re: Battery charging Thanks for the info. I'm not sure why they chose 2 batteries over one, especially since they put both of them in a big box that has to be hoisted into the tail of the aircraft. Maybe because they are standard and can be eaily ordered? Steve -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: Battery charging I have 2 12v Gill RG batteries in my airplane (a Mooney Rocket conversion, M20K). The batteries are in parallel, 12 volt system. Why two batteries in parallel versus one big one? I would like to use a standard auto battery charger to recharge or boost the batteries per the service instructions. I would like to charge them in the airplane (since removing them is incredibly difficult) using the ground power adapter / jumper cables. What is wrong or good about this picture? No problem I can see. Many owner/operators have provided some remote access to the batteries accessed by come conveniently located connector. Would recommend a 5A fuse at the battery be used to protect this always hot wire between batteries and charging connector. This would of course, limit the output of your charger to less than 5A . . . probably okay for most little battery maintainers. If your batteries are flooded cell products, how about putting an RG battery in there and not have to worry about an external battery charging connection. If you don't run off and leave the master switch on, you can about guarantee that the RG battery will be there when you need it - without benefit of external charging support. Bob . . . http://www.matronics.com/browselist/aeroelectric-list http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: May 10, 2002
> > >----- Original Message ----- >From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> >Date: Thursday, May 9, 2002 8:46 pm >Subject: AeroElectric-List: Re: base antenna > > > > >2) can I use radio shack coax cable I a left over form a TV > > antenna install > > >to > > >run between the radio and antenna? > > > > This will work but it may be messy to get good > > connections if it's an aluminum foil shield. RG-58 > > (real cheap from Radio Shack) might be easier to work > > with. > > > >If you want to transmit with your base station, won't you >get pretty high SWR's with 75ohm tv cable? I think you could >recieve just fine, but I'll bet you won't be able to talk to >very distant aircraft. I am pretty sure the com radios are >50ohm output? True . . but he said he wanted to simply LISTEN which is the only thing he can legally do with that radio. Either coax would work fine for listening and while the SWR would be high with 75 ohm coax, he would probably not notice any degradation of performance should he choose to talk to someone too . . . Bob . . . ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: IFR Avionics requirements
> > >I have been searching for FAR information which stipulates the avionics >requirements for IFR navigation. I am only interested in locating the >appropriate section which identifies the NECESSARY NAVIGATION RADIOS >required for IFR flight. I understand that somewhere in the FARs it mention>s >something about only needing equipment for the type of navigation and >approaches which are required for a particular flight. > >The issue is...... I want to set up a light IFR RV7A to punch through >overcasts when necessary..... That=B9s it, no real weather stuff to speak of. >I seem to remember that 1 VOR was the minimum, and that GPS alone could not >be approved as sole source IFR. I would like to set up a minimum IFR RV with >GPS only as my sole source of navigation and for non-precision approaches. >I do not want to include the outdated VOR in my panel. Is this going to be >possible? Are the rules different in any way for experimental aircraft >flying under IFR. > >Can someone answer my question properly or refer me to the FARs which are >applicable to my question. Don't recall the specific FAR and I'm not sure I've read it. My instructors taught that I could fly IFR for any mission where the airplane was properly equipped for the task using the nav-aids approved for the task. For example, if you plan to do an ILS approach at the other end, then you need ILS equipment. If you plan a VOR approach at the other end, you need a VOR . . . etc. Many an IFR flight was launched and completed with only an ADF and/or VOR receiver and gyros. If all you want to do is punch through cloud layers, then no ground based nav aids are needed to safely complete the mission. ATC will tell you to climb/descend on a heading and report reaching VMC. This can be safely accomplished with radio communications contact, transponder and whatever means you have on board to hold an accurate heading. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
regardless of what anyone says, a VOR is not required to take off and punch through the clouds. Get an approach approved GPS, moving map, and CDI and you are legal to fly any non-precision approach / IFR flight in the US. ________________________________________________________________________________
Date: May 10, 2002
snip I would like to set up a minimum IFR RV with > GPS only as my sole source of navigation and for non-precision approaches. snip > > Can someone answer my question properly or refer me to the FARs which are > applicable to my question. > > Thank you. > > Victor S. > Victor, The archives have a lot on this subject but I think Mike Robertson(FAA) made the best reference which was to AIM 1-1-21.b.1(b) which says you have to have something else besides the GPS. I think this is because GPS units are not yet "approved' for "primary" means of navigation. Stan Blanton RV-6 ________________________________________________________________________________
Date: May 10, 2002
Thank you for the info, looks like I won't have to install the VOR after all. One day when the GPS (non-VOR) based precision approach is available I can perhaps upgrade my panel. For now I was hoping to install The following avionics in my panel for very light IFR flight....... UPSAT.....GX 50 with CDI UPSAT.....SL40 UPSAT.....SL70 with encoder On to the next step...... Victor S. ________________________________________________________________________________
Date: May 10, 2002
In a message dated 05/10/2002 2:52:17 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <>writes: << ....skip...... Where a FAR says an approved gadget is required, guidance as to what they are likely to approve will generally be found in a TSO. They may also approve other satisfactory equipment if convinced its safe. So the lowest risk way to avoid any operating limitations for phase 2 listed in the special certificate of airworthiness is to have equipment that performs closely to a TSO, which is not hard, particularly for nav radios, they are freely available. >> 5/10/2002 Hello David, Your point is well taken. The FAA Inspector or the DAR (Designated Airworthiness Representative) has significant judgemental powers at the time of the initial inspection. If the inspector chooses to insist on a TSO'd piece of equipment even though one is not required by Regulations then the builder is faced with a choice of: 1) Going over the Inspector's head up the bureaucratic chain of command in an attempt to get a more favorable decision (some times not a wise move), or 2) Meeting the Inspector's requirements. If the builder can determine in advance what may be required by an Inspector at the time of the inspection, even if it is something not mandated by Regulation, and build accordingly, he can save himself some grief. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: May 10, 2002
> >Thanks Bob. You input is much appreciated. Actually, I had designed a >circuit a year ago for my plane but then made the mistake of taking >helicopter lessons. Now my plane morphed into a helicopter so the panel was >put on hold. I thought I could use a "crow bar" type circuit to trigger the >enunciators lights with some filtering built in much like your crowbar >circuit for taking out an out-of-control alternator. Or perhaps something as >simple as a 3904 transistor used to isolate the enunciators from the source >of the signal via filtering. A series of these circuits, one for each >ennunciation, could be tied into a relay that could be used to test the >lamps simultaneously. An addition circuit would be required for a master >warning. Thought maybe some TTL would work for this or a programmable chip. >. Please post your ideas. I'm sure there's a better way then this. Thanks. You're shoveling a lot of sand before you have identified what holes need to be filled. Make a list of every parameter you want to monitor and define the sensor that will supply the data. Ordinary switches and voltages applied to a system will drive annunciator lights directly. Filters, transistors, etc are not needed. Somewhere on the list you will want to monitor some analog signals that will require some kind of signal conditioning . . . but this is "sand" that cannot be defined until the "holes" are defined. Make a list. Define the sensors. Define behavior of the annunciation. Is it sufficient to have the light ON only during a monitored event or do you want the light to latch ON if the monitored parameter drops into the caution range only momentarily, etc, etc. Picking all the little electro-goodies to accomplish the various tasks is easy. You can save a lot of time and back-tracking if the tasks are fully described and understood before you start worrying about what parts are needed. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
Subject: Latching (?) Relays
Hi Bob, I am a homebuilder with a degree in electronic engineering and just completed my Q200 homebuilt. I have designed and built many low-power analog and digital circuits over the years and figure I have a good grasp of how relays work and how you use them. However, while wiring my Q200 I encountered a problem with relays latching on even when current to the coil was removed and was hoping you might be able to shed some light on what was happening. 1) Master relay - mounted in tail of aircraft next to battery. #4 wire running forward to panel. One side of relay coil connected to battery +12V, other side runs forward to master switch where it is switched to ground. Ground and power wires were accidentally shorted at firewall (ends of bolts touching conductor). I didn't check for a short before turning on the master. I noticed within a couple of seconds that something wasn't right. Immediately shutoff the master - but didn't hear a click. Smoke started coming from #4 power and ground cables. Almost had a heart attack. After about a minute I finally managed to cut the power cable to prevent a fire. I assumed the master relay contacts had been fused closed but when I checked it appeared to work completely normally. I fixed the short, double-checked the wiring, replaced the relay and have been using the circuit fine for the last 20 hours. So why did the relay not turn off when power was removed from the relay coil? I assumed the relay was at fault until I encountered a similar situation with the starter solenoid. 2) Starter solenoid wired in the normal way - +12V comes from start terminal on magneto switch to relay coil, other side of coil goes to ground. I had a temporary, very poor, connection to the battery. Turned the mag switch to start, the B&C starter began turning the engine over very, very, very slowly. It was obvious there was not enough voltage so I switched the mag switch to off but the starter kept turning the engine. It continued for about 30 seconds until I disconnected the battery. Again, I double-checked the wiring, fixed the battery connection and have been using the system fine for the last 20 hour So my question is: how is possible for a relay to stay energized like this? Is it possible the electric fields around the power cables due to the high currents hold the relay on even when power to the coil is removed? Until I figure this one out I carry wirecutters with me in the cockpit! Hope you can shed some light on this puzzle. It would be useful to know what parts are being used as battery and starter contactors. If I were to make a wild-assed-guess, both your battery and starter contactors look like this . . . http://www.aeroelectric.com/Catalog/switch/s701-1l.jpg These critters are designed to carry hundreds of amps but only switch about 70A. Your first event was probably a light "welding" of the battery contactor when it was closed into a hard fault. The second event was a similar event precipitated by the use of a continuous duty contactor as a starter contactor. Contactors suitable for starter control look like . . . http://www.aeroelectric.com/Catalog/switch/s702-1l.jpg This is a special breed of cat designed to SWITCH hundreds of amps without sticking. It's an intermittent duty device with very high contact pressure. I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . | Stupidity cannot be cured with money, or through education, | | or by legislation. Stupidity is not a sin, the victim can't | | help being stupid. But stupidity is the only universal | | capital crime; the sentence is death, there is no appeal, | | and execution is carried out automatically and without pity. | | -Lazarus Long- | ________________________________________________________________________________
Date: May 10, 2002
In a message dated 05/09/2002 6:42:47 PM Eastern Daylight Time, FSmith9890(at)aol.com writes: > In the RV series you don't have to put them externally on the tail, put > them in the wingtips. I have used this system on two airplanes and it > works > fine. I hate to see an experimental airplane loaded up with external > antennas. The only two that need to be external is the transponder and > the > com. The com antenna in the wingtip will also work as a com, but at a > reduced range. Well, we'll just see about that! I have installed a transponder antenna in my right wheel pant on the RV-6A, behind the baffle. When my crimper and RG-400 get here from Bob's web store, and my transponder gets out of the shop (it got rainwater in it and died a slow kilo-voltage death by toasting), I will plumb it up and let everyone know how it works. I have retained my oily bell-mounted antenna for comparison purposes for the time being. Later, I plan to do the same type of experiment with the comm whip antennas versus wintgtip mount Archer-design (gamma-matched quarter wave) at both 122 and 146 MHz. Given the speed I tinker at, look for results in early 2004! Bill B ________________________________________________________________________________
Date: May 10, 2002
In a message dated 05/10/2002 10:35:39 AM Eastern Daylight Time, mprather(at)spro.net writes: > If you want to transmit with your base station, won't you > get pretty high SWR's with 75ohm tv cable? I think you could > recieve just fine, but I'll bet you won't be able to talk to > very distant aircraft. I am pretty sure the com radios are > 50ohm output? > With a 50 ohm antenna, it raises your minimum achievable VSWR to 1.5, I think. No big deal. In fact, if you choose an odd multiple of quarter wavelengths of the 75 ohm coax, and place a 100 ohm antenna (for example, full-wave square loop) at the far end, the transmitter will see 50 ohms, for a perfect match. Magic! -Bill B ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: Switches
> >I would like to replace the set of toggle switches on the over head >panel in my Exec90 with lighted pushbutton switches. That would make it >easier to see at dark and anytime as it's difficult to see which switch >is what. Anyway, I have a problem because the pushbutton switches are >rated at 2 amps while the current toggles are rated at 10 to 15 amps. I >could just replace them with more toggles but I would like the upgrade. >I had considered using relays but I worry about the extra drain (about >100ma per relay with at least 6 relays). Any suggestions would be >greatly appreciated. Thanks. The total additional draw of relays used to boost the capability of your switches is insignificant in terms of system loading. Our soon to be released solid state relays will require only 10-15 mA for control and will have no moving contacts . . . but the plain-vanilla relays like our S704-1 can be used as well and without concern for the power needed to close the relay . . . it is quite small in the grand scheme of things. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
Subject: Re: Driving LED annunciator with LR3 Controller
> > >Bob > >I am using the LR-3 alternator controlers for my Glasair, per Figure >Z-4. I seem to remember a thread awhile ago that the lamp output >to the warning lamp needed something to work with a LED. I >couldn't find the reference. Is there any problem using LED's >instead of regular light bulbs? Yes. First, you need a resistor to "fool" the LR-3 into thinking that a regulator lamp is still there. Use a 220 ohm, 1 watt resistor. Then, hook your LED lamp fixture (and any resistor needed to ballast the LED) in parallel with the 220 ohm resistor. Bob . . . ________________________________________________________________________________
Date: May 10, 2002
Yeah, but the AIM is NOT regulatory. > snip > I would like to set up a minimum IFR RV with > > GPS only as my sole source of navigation and for non-precision approaches. > > snip > > > > Can someone answer my question properly or refer me to the FARs which are > > applicable to my question. > The archives have a lot on this subject but I think Mike Robertson(FAA) made > the best reference which was to AIM 1-1-21.b.1(b) which says you have to > have something else besides the GPS. I think this is because GPS units are > not yet "approved' for "primary" means of navigation. > ________________________________________________________________________________
Date: May 10, 2002
I took this issue up with my local avionics shop and was told that there was no way I was going to be able to get a GPS approved for approaches without a VOR and annunciator also installed. An approach approved GPS is not legal to use for an approach (according to the avionics tech) until a ton of paperwork is signed off on by the FAA including test flying and the tech's signature declaring that it performs as it is supposed to. They offered to do the paperwork for somewhere around $1k. Ed Holyoke -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Aucountry(at)aol.com Subject: Re: AeroElectric-List: IFR Avionics requirements regardless of what anyone says, a VOR is not required to take off and punch through the clouds. Get an approach approved GPS, moving map, and CDI and you are legal to fly any non-precision approach / IFR flight in the US. = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: May 10, 2002
it is really appalling how the FAA and the avionics shops have made the wonderful world of GPS so complicated. GPS's take all of the guess work out of navigating. Yet, there are next to no standards for installing an ADF system, no tests, no certifications, just a sign off by the avionics tech. Yet, the ADF is just as likely to point at your left wing's strobe, or require you to shut down your alternator so it can find the station you are tuned to. And all it does is tell you approximately what direction it is. Not how far away it is. Great way to shoot an approach while in the klag. Something wrong with this picture?????? By the way the AC 120-38 (ADVISORY Circular) is good reading and will help you understand what the avionics tech is saying has to be done to get a panel mounted GPS installed and certified. Unfortunately the FSDO's have taken this ADVISORY circular and made it the REGULATION for proper installation of a GPS. Which has probably been very effective in ensuring that only 25% of the potential GPS systems have been installed - the other 75% (or more, never got installed because of the extra $1000 required to do the paper work - and then there are the other shops that don't even want to go there because of the hassle from their local FSDO inspectors). Really unfortunate! > I took this issue up with my local avionics shop and was told that there > was no way I was going to be able to get a GPS approved for approaches > without a VOR and annunciator also installed. An approach approved GPS > is not legal to use for an approach (according to the avionics tech) > until a ton of paperwork is signed off on by the FAA including test > flying and the tech's signature declaring that it performs as it is > supposed to. They offered to do the paperwork for somewhere around $1k. > > Ed Holyoke > ________________________________________________________________________________
Date: May 10, 2002
There are some who have the opinion that if you're flying an experimental airplane, you don't need an FAA signoff to make your GPS IFR legal. You, if you desire, can do the flight tests, radio interference tests, and sign off the log book. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ronnie Brown Subject: Re: AeroElectric-List: IFR Avionics requirements it is really appalling how the FAA and the avionics shops have made the wonderful world of GPS so complicated. GPS's take all of the guess work out of navigating. Yet, there are next to no standards for installing an ADF system, no tests, no certifications, just a sign off by the avionics tech. Yet, the ADF is just as likely to point at your left wing's strobe, or require you to shut down your alternator so it can find the station you are tuned to. And all it does is tell you approximately what direction it is. Not how far away it is. Great way to shoot an approach while in the klag. Something wrong with this picture?????? By the way the AC 120-38 (ADVISORY Circular) is good reading and will help you understand what the avionics tech is saying has to be done to get a panel mounted GPS installed and certified. Unfortunately the FSDO's have taken this ADVISORY circular and made it the REGULATION for proper installation of a GPS. Which has probably been very effective in ensuring that only 25% of the potential GPS systems have been installed - the other 75% (or more, never got installed because of the extra $1000 required to do the paper work - and then there are the other shops that don't even want to go there because of the hassle from their local FSDO inspectors). Really unfortunate! ________________________________________________________________________________
Date: May 11, 2002
Ed Holyoke wrote: > > > I took this issue up with my local avionics shop and was told that there > was no way I was going to be able to get a GPS approved for approaches > without a VOR and annunciator also installed. An approach approved GPS > is not legal to use for an approach (according to the avionics tech) > until a ton of paperwork is signed off on by the FAA including *** The "ton" of FAA paperwork is * A 337 for the initial installation of the GPS. This is the same as you would do for any radio. * An FMS ( Flight Manual Supplement ) for the GPS. The mfgr should supply a sample, but it needs to be customized for your particular airplane. * A second 337 for the IFR approval of the GPS. The reason for two 337's is the flight test: with only one 337 for the entire installation, you or the shop would have to flight test an unairworthy airplane. Bad for insurance. A few years ago, this was all a big deal. But now the FSDOs and shops should pretty well have it down to a science. I installed my own GPS, did my own paperwork, and got it signed off by my IA ( for the first 337 ) and a Repair Station ( for the second ). The hardest part of the whole deal was finding the Repair Station to sign off on the second 337: a busy avionics shop has very little interest in taking on liability for work they didn't do. OTOH, shops usually aren't very enthusiastic about doing paperwork, and it just *might* be possible to get one to do the physical work - you do the paperwork - they sign. How to do the paperwork? March right down to the FSDO and ask... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net>
Subject: Easy Battery Ammeter
Date: May 11, 2002
Grand Rapids is now offering Hall Effect sensors, to measure current, for their EIS. The current sensor is very easy to install. They look like a doughnought and you just run the wire, in which you wish to measure the current, through its middle. Gabe A Ferrer ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Subject: Re: Easy Battery Ammeter
Date: May 11, 2002
Is this unit for DC voltage? Who can I contact at Grand Rapids? Wayne ----- Original Message ----- From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net> Subject: AeroElectric-List: Easy Battery Ammeter > > > Grand Rapids is now offering Hall Effect sensors, to measure current, for > their EIS. > > The current sensor is very easy to install. They look like a doughnought and > you just run the wire, in which you wish to measure the current, through its > middle. > > Gabe A Ferrer > ferrergm(at)bellsouth.net > Cell: 561 758 8894 > Night or FAX: 561 622 0960 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 11, 2002
The reliably of modern electronic (GPS) would make any experimental aircraft usable for IFR. My concern is keeping the engine running with all that water in the air. Wayne ----- Original Message ----- From: "Ronnie Brown" <romott(at)adelphia.net> Subject: Re: AeroElectric-List: IFR Avionics requirements > > it is really appalling how the FAA and the avionics shops have made the > wonderful world of GPS so complicated. GPS's take all of the guess work out > of navigating. > > Yet, there are next to no standards for installing an ADF system, no tests, > no certifications, just a sign off by the avionics tech. Yet, the ADF is > just as likely to point at your left wing's strobe, or require you to shut > down your alternator so it can find the station you are tuned to. And all it > does is tell you approximately what direction it is. Not how far away it > is. Great way to shoot an approach while in the klag. Something wrong with > this picture?????? > > By the way the AC 120-38 (ADVISORY Circular) is good reading and will help > you understand what the avionics tech is saying has to be done to get a > panel mounted GPS installed and certified. Unfortunately the FSDO's have > taken this ADVISORY circular and made it the REGULATION for proper > installation of a GPS. Which has probably been very effective in ensuring > that only 25% of the potential GPS systems have been installed - the other > 75% (or more, never got installed because of the extra $1000 required to do > the paper work - and then there are the other shops that don't even want to > go there because of the hassle from their local FSDO inspectors). > > Really unfortunate! > > > > I took this issue up with my local avionics shop and was told that there > > was no way I was going to be able to get a GPS approved for approaches > > without a VOR and annunciator also installed. An approach approved GPS > > is not legal to use for an approach (according to the avionics tech) > > until a ton of paperwork is signed off on by the FAA including test > > flying and the tech's signature declaring that it performs as it is > > supposed to. They offered to do the paperwork for somewhere around $1k. > > > > Ed Holyoke > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 11, 2002
Subject: Re: AML switches and LEDs
>Bob > >This may be a stupid question but, on an AML34FBA4AC01 rocker >switch does it matter how the connections are placed. It has only >two connections (actually 2 pairs). Is there a preference as to >which of the fast on post is the hot lead? No. By-in-large, switches and light bulbs do not have a preference for which terminal is "hot" . . . Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: May 11, 2002
Subject: lasar ignition noise
I have a new engine on an rv-8 using the lasar ignition. The ignition operates normally but I am hearing spark noise through the headsets at idle only when receiving, transmissions are clear. When the engine is ran up to say 1500, the added wind, engine and increased frequency of the spark noise makes it hard to hear individual snaps (becomes more of a buzz). I had the local avionics shop connect a box to the antenna cable and send tones to the com and that all checks out fine, so it had to be the antenna. We connected another antenna but on the top side of the plane with the same results. I then called Bob and ran this by him. On his suggestion I then went and cut the "blue" and "green" lasar wires (to L and R on the switch) which made the mags hot all the time with neglegable results. I have called unison several times, vision micro, and the antenna mfg in addition to Bob. We have went through making sure there are no ground loops in the heatset jacks, no bad ignition leads or plugs, lasar and start switch both grounded at firewall. Through all this it is believed that it is simply radiated and being picked up by the antenna. This is somehting that will not prevent me from flying (inspection this tues.) and may not even hear it in the air, but it would be nice to figure this out. any suggestions? John Link rv-8 ________________________________________________________________________________
Date: May 11, 2002
Subject: Re: lasar ignition noise
May or may not be applicable to the LASAR, but when I had the same problem with a Klaus ignition it was fixed by using automotive resistive spark plug wires. > >I have a new engine on an rv-8 using the lasar ignition. The ignition >operates normally but I am hearing spark noise through the headsets at idle >only when receiving, transmissions are clear. When the engine is ran up to >say 1500, the added wind, engine and increased frequency of the spark noise >makes it hard to hear individual snaps (becomes more of a buzz). > >I had the local avionics shop connect a box to the antenna cable and send >tones to the com and that all checks out fine, so it had to be the antenna. >We connected another antenna but on the top side of the plane with the same >results. I then called Bob and ran this by him. On his suggestion I then went >and cut the "blue" and "green" lasar wires (to L and R on the switch) which >made the mags hot all the time with neglegable results. > >I have called unison several times, vision micro, and the antenna mfg in >addition to Bob. We have went through making sure there are no ground loops >in the heatset jacks, no bad ignition leads or plugs, lasar and start switch >both grounded at firewall. >Through all this it is believed that it is simply radiated and being picked >up by the antenna. This is somehting that will not prevent me from flying >(inspection this tues.) and may not even hear it in the air, but it would be >nice to figure this out. > >any suggestions? >John Link >rv-8 > > ________________________________________________________________________________
Subject: welding relays
Date: May 11, 2002
>>I noticed within a couple of seconds that something wasn't right. Immediately shutoff the master - but didn't hear a click. Smoke started coming from #4 power and ground cables. Almost had a heart attack. After about a minute I finally managed to cut the power cable to prevent a fire.<< Once a long time ago in a galaxy far away I remember that the design rules was to size the battery cable so that if there were a dead short the battery would go dead before the wire would catch on fire. Any other wires were protected by fusible links. I'm sure, by looking at newer cars, that this rule has been often ignored, but it made sense to me. Looks like a #4 wire isn't big enough to protect against that failure mode. And relays welding closed with a high-current short is not an uncommon occurrence. Gary Casey ES project ________________________________________________________________________________
Date: May 11, 2002
Subject: Re: welding relays
> > >>I noticed within a couple of seconds that something wasn't right. >Immediately shutoff the master - but didn't hear a click. Smoke started >coming from #4 power and ground cables. Almost had a heart attack. After >about a minute I finally managed to cut the power cable to prevent a fire.<< > > Once a long time ago in a galaxy far away I remember that the design rules > was to size the battery cable so that if there were a dead short the > battery > would go dead before the wire would catch on fire. Any other wires were > protected by fusible links. I'm sure, by looking at newer cars, that this > rule has been often ignored, but it made sense to me. Looks like a #4 wire > isn't big enough to protect against that failure mode. And relays welding > closed with a high-current short is not an uncommon occurrence. Hadn't heard of that one. Back in the hey-day of soggy-out-of-the-box flooded batteries, this might have been a practical thing to do but today's 25 a.h., RG batteries are capable of 1200A fault current or better. Besides, a hard fault through sufficiently fat wires on a flooded battery may not precipitate a fire but geysers of hot, acid laden water are only slightly more appealing than a wire-fire. Of course, one has the option of installing current limiters like http://www.aeroelectric.com/Catalog/ckrtprot/anl.jpg . . . These are available in some really fat sizes for folks that are worried about it. Keep in mind that the first event cited in this discussion was a fault generated by a wiring error. The second event was probably due to soggy battery. It's unusual for the same system to suffer both events so closely spaced . . . and had the wiring error not occurred, it would have been a single-event story. Hard, uncontrolled faults in battery feed wires are very rare. I've never encountered one in a single engine aircraft personally and I've never read of one either. That doesn't mean that it hasn't happened but since this is a core technology feature of a 40+ year career, I think it's safe to say that likelihood of having either (1) a hard fault downstream of a stuck battery contactor or (2) a stuck starter contactor paired with a stuck battery contactor is very low. Bob . . . ________________________________________________________________________________
Subject: Jabiru 3300 dual alternator control
Date: May 11, 2002
Bob, Bruce Banks asked about the Rotax 912 system, and you noted that this has an optional 40 amp belt driven alternator in addition to the standard 20 amp PM alternator. You recommended diagram Z13 for dual alternators in this situation. My situation is similar, but not identical. The Jabiru 3300 has a robust flywheel mounted PM alternator that should be bulletproof, almost identical to the SD8--but of course that hard working regulator might fail. I plan to add a B&C SD20 alternator to the spline fitting on the crankshaft. Tim at B&C assures me that this will give 20 amps at 2750 rpm in a 14 volt system. I would like to run both alternators simultaneously, as they are each about the same capacity and could give a total of 40 amps. Would it be reasonable to substitute the B&C SB1B-14 regulator for the LR3 listed on Z13, and then have both units on simultaneously? I would fuselink the SD20 output and probably connect it to the battery side of the battery contactor. I worry about overvoltage protection from both systems being on in parallel. Could, for example, the PM alternator trigger the OV system and then bring down both paralleled alternators? I don't think it would, but I'm not fully certain how the SB1B works. The SB1B is a standby controller. The SB1B should keep field current at zero unless a low bus voltage is detected. Thus, I speculate that it would not be set to crowbar the field circuit of the SD20 and blow the field fuse. This is of some general interest, as the Jabiru system is getting popular, and those of us who want all electric systems with redundancy could use this alternative. My power budget may not require both alternators on simultaneously, but this system has the advantage of automatic switching from PM alternator to SD20 if the PM fails, and is thus one less item to distract the pilot. In other words, it works like the dual alternator diagram in fig. 17-8 of the 'Connection. My plane is a Jabiru J400 with Blue Mountain EFIS (4amps), transponder, one NAV/COMM, one COMM, strobes (7 amps), positions lights (6amps) and an autopilot which may suck considerable power at times. In the future I may need pitot heat. I will use all of your recommended systems: fast-on wiring, NylaFlow conduit, battery bus, essential bus, main bus, single point ground, fuses, and voltage and current monitor. The one battery, two alternator system looks like a winner. Jim Foerster ________________________________________________________________________________
Date: May 11, 2002
Subject: IFR Equipment Required
In a message dated 05/11/2002 2:52:38 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com writes (slightly edited): << I have been searching for FAR information which stipulates the avionics requirements for IFR navigation. I am only interested in locating the appropriate section which identifies the NECESSARY NAVIGATION RADIOS required for IFR flight. I understand that somewhere in the FARs it mentions something about only needing equipment for the type of navigation and approaches which are required for a particular flight. The issue is...... I want to set up a light IFR RV7A to punch through overcasts when necessary..... That's it, no real weather stuff to speak of. I seem to remember that 1 VOR was the minimum, and that GPS alone could not be approved as sole source IFR. I would like to set up a minimum IFR RV with GPS only as my sole source of navigation and for non-precision approaches. (1) I do not want to include the outdated VOR in my panel. Is this going to be possible? (2) Are the rules different in any way for experimental aircraft flying under IFR. (3) Can someone answer my question properly or refer me to the FARs which are applicable to my question. >> 5/11/2002 Hello Victor, Thank you for opening this can of worms. I doubt that we'll all agree and come to some common specific answers, but it should be fun (and maybe a bit educational to try). I've inserted some numbers into your posting above in front of each individual question in order to make answering them easier. Lets start with number (3). What FAR Section pertains? Your basic reference is FAR Section 91.205. This Section identifies all of the equipment and instruments needed for VFR, VFR Night, and IFR flight for standard category US airworthiness certificated aircraft. Does that mean that Section 91.205 doesn't apply at all to amateur built experimental aircraft and those experimental aircraft get to have whatever they want? Not at all because the Operating Limitations that are issued at the time of certification of your amateur built experimental aircraft will require the aircraft to meet the appropriate requirements of Section 91.205 depending upon the capability that you are seeking and the equipment that you are providing for your aircraft. Question (2): Once your amateur built experimental aircraft gets into phase two (after the initial flight restrictions are flown off) and you file IFR and take off with your properly equipped aircraft in accordance with your Operation Limitations you should expect to be treated just like any standard type certificated aircraft in the ATC system and you should be capable of operating IFR like any standard type certificated aircraft. Question (1): Can get by with no VHF (VOR) navigation equipment? My answer is a question --Why? Our present national navigation system is built around VOR stations. It will be that way for many, many, many more years to come -- maybe through out our entire flying career. If you have both GPS and VHFnavigation capability in your aircraft you have some backup / alternate flexibility. (I flew for many years with a single navigation capability (TACAN only) in high performance aircraft -- having no back up really sucks). Sure, other posters have told you that no VHF navigation capability is "legal". I don't know how they intend to prove that, but you can bet the first time some ATC controller starts out to help you do what you want to do and he includes some VOR requirement and you tell him "Unable" what you may very likely hear in return is "Well then, I'm unable also". My recommendation: In your other posting you indicated that you were planning on putting in a UPSAT SL-40 VHF Comm. Why not put in a UPSAT SL-30 VHF NavComm instead? It is an extremely capable piece of equipment (can handle two VOR station signals at the same time for intersection capability). If you connect it to the external CDI that you are planning in such a fashion that you can switch the external CDI feed from either the GPS or the VHF Nav you will have a very flexible and capable system. Now about "light IFR" and "punching through". I don't want to get up on my soap box in this posting, but please let me make two philosophical observations: A) Many pilots have busted their ass in attempts to just "punch through" (either going up or down) what was supposed to be "just a layer". B) The phrase "Light IFR" is a lot like the phrase "a little bit pregnant". 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Re: IFR Equipment Required
Date: May 11, 2002
I must agree. If you go IFR, be prepared to go FULL IFR.You could vectored to a hold or some other IFR trap. Wayne ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: IFR Equipment Required > > In a message dated 05/11/2002 2:52:38 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com writes > (slightly edited): > > << I have been searching for FAR information which stipulates the avionics > requirements for IFR navigation. I am only interested in locating the > appropriate section which identifies the NECESSARY NAVIGATION RADIOS > required for IFR flight. I understand that somewhere in the FARs it mentions > something about only needing equipment for the type of navigation and > approaches which are required for a particular flight. > > The issue is...... I want to set up a light IFR RV7A to punch through > overcasts when necessary..... That's it, no real weather stuff to speak of. > I seem to remember that 1 VOR was the minimum, and that GPS alone could not > be approved as sole source IFR. I would like to set up a minimum IFR RV with > GPS only as my sole source of navigation and for non-precision approaches. > (1) I do not want to include the outdated VOR in my panel. Is this going to > be > possible? (2) Are the rules different in any way for experimental aircraft > flying under IFR. (3) Can someone answer my question properly or refer me to > the FARs which are applicable to my question. >> > > 5/11/2002 > > Hello Victor, Thank you for opening this can of worms. I doubt that we'll all > agree and come to some common specific answers, but it should be fun (and > maybe a bit educational to try). > > I've inserted some numbers into your posting above in front of each > individual question in order to make answering them easier. > > Lets start with number (3). What FAR Section pertains? Your basic reference > is FAR Section 91.205. This Section identifies all of the equipment and > instruments needed for VFR, VFR Night, and IFR flight for standard category > US airworthiness certificated aircraft. Does that mean that Section 91.205 > doesn't apply at all to amateur built experimental aircraft and those > experimental aircraft get to have whatever they want? > > Not at all because the Operating Limitations that are issued at the time of > certification of your amateur built experimental aircraft will require the > aircraft to meet the appropriate requirements of Section 91.205 depending > upon the capability that you are seeking and the equipment that you are > providing for your aircraft. > > Question (2): Once your amateur built experimental aircraft gets into phase > two (after the initial flight restrictions are flown off) and you file IFR > and take off with your properly equipped aircraft in accordance with your > Operation Limitations you should expect to be treated just like any standard > type certificated aircraft in the ATC system and you should be capable of > operating IFR like any standard type certificated aircraft. > > Question (1): Can get by with no VHF (VOR) navigation equipment? My answer is > a question --Why? Our present national navigation system is built around VOR > stations. It will be that way for many, many, many more years to come -- > maybe through out our entire flying career. If you have both GPS and > VHFnavigation capability in your aircraft you have some backup / alternate > flexibility. (I flew for many years with a single navigation capability > (TACAN only) in high performance aircraft -- having no back up really sucks). > > Sure, other posters have told you that no VHF navigation capability is > "legal". I don't know how they intend to prove that, but you can bet the > first time some ATC controller starts out to help you do what you want to do > and he includes some VOR requirement and you tell him "Unable" what you may > very likely hear in return is "Well then, I'm unable also". > > My recommendation: In your other posting you indicated that you were planning > on putting in a UPSAT SL-40 VHF Comm. Why not put in a UPSAT SL-30 VHF > NavComm instead? It is an extremely capable piece of equipment (can handle > two VOR station signals at the same time for intersection capability). If you > connect it to the external CDI that you are planning in such a fashion that > you can switch the external CDI feed from either the GPS or the VHF Nav you > will have a very flexible and capable system. > > Now about "light IFR" and "punching through". I don't want to get up on my > soap box in this posting, but please let me make two philosophical > observations: > > A) Many pilots have busted their ass in attempts to just "punch through" > (either going up or down) what was supposed to be "just a layer". > > B) The phrase "Light IFR" is a lot like the phrase "a little bit pregnant". > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 11, 2002
Bob, Bruce Banks asked about the Rotax 912 system, and you noted that this has an optional 40 amp belt driven alternator in addition to the standard 20 amp PM alternator. You recommended diagram Z13 for dual alternators in this situation. My situation is similar, but not identical. The Jabiru 3300 has a robust flywheel mounted PM alternator that should be bulletproof, almost identical to the SD8--but of course that hard working regulator might fail. I plan to add a B&C SD20 alternator to the spline fitting on the crankshaft. Tim at B&C assures me that this will give 20 amps at 2750 rpm in a 14 volt system. I would like to run both alternators simultaneously, as they are each about the same capacity and could give a total of 40 amps. Would it be reasonable to substitute the B&C SB1B-14 regulator for the LR3 listed on Z13, and then have both units on simultaneously? I would fuselink the SD20 output and probably connect it to the battery side of the battery contactor. I worry about overvoltage protection from both systems being on in parallel. Could, for example, the PM alternator trigger the OV system and then bring down both paralleled alternators? I don't think it would, but I'm not fully certain how the SB1B works. The SB1B is a standby controller. The SB1B should keep field current at zero unless a low bus voltage is detected. Thus, I speculate that it would not be set to crowbar the field circuit of the SD20 and blow the field fuse. This is of some general interest, as the Jabiru system is getting popular, and those of us who want all electric systems with redundancy could use this alternative. My power budget may not require both alternators on simultaneously, but this system has the advantage of automatic switching from PM alternator to SD20 if the PM fails, and is thus one less item to distract the pilot. In other words, it works like the dual alternator diagram in fig. 17-8 of the 'Connection. My plane is a Jabiru J400 with Blue Mountain EFIS (4amps), transponder, one NAV/COMM, one COMM, strobes (7 amps), position lights (6amps) and an autopilot which may suck considerable power at times. In the future I may need pitot heat. I will use all of your recommended systems: fast-on wiring, NylaFlow conduit, battery bus, essential bus, main bus, single point ground, fuses, and voltage and current monitor. The one battery, two alternator system looks like a winner if I can get reliable control. Jim Foerster ________________________________________________________________________________
Subject: PM alternator upgrade for reliability
Date: May 11, 2002
Bob, While designing a second alternator for my Jabiru 3300, it occurred to me that the major failure mode for a permanent magnet (PM) is regulator failure. Unlike a field regulator which controls at most 5 amps, the poor PM regulator must pass the whole output. For the Rotax, this is 18 amps, for the Jabiru about 20. Since the Rotax, Jabiru, and SD-8 all have the permanent magnets mounted such that centrifugal force just presses them into a seat, they can't fly out. The coils are fixed with no sliding contacts. The Rotax and Jabiru alternators are part of the flywheel, so there is no drive system to fail. Given these facts, would a backup regulator be as good as a whole separate PM alternator? Three S704-1 relays could switch the two coil leads and the output lead. A fourth relay might be needed for the second OV circuit: the first OV relay would automatically switch to the backup regulator. Before committing this to copper, a failure analysis should be done, and I don't have any field experience to back up the above line of reasoning. What do think, Bob? Could this become another Z diagram? Cheaper and lighter and simpler than a separate alternator. Jim Foerster ________________________________________________________________________________
Date: May 12, 2002
In a message dated 5/11/02 06:17:29 PM, BAKEROCB(at)aol.com writes: << Sure, other posters have told you that no VHF navigation capability is "legal". I don't know how they intend to prove that, but you can bet the first time some ATC controller starts out to help you do what you want to do and he includes some VOR requirement and you tell him "Unable" what you may very likely hear in return is "Well then, I'm unable also". >> Well, actually, the GPS he proposes will fly to any VOR just as easily as it would any other fix. Punching in nearest VOR and direct to will reset the GPS to fly to that station (target). There is no legal requirement to use any ground based stations unless that is what you have in your plane. No one ever said not having a backup nav aid was smart thinking. he asked if he could fly IFR with a GPS only. The answer is yes. ________________________________________________________________________________
Date: May 12, 2002
Subject: Question re: "basic" kit of essential tools/supplies
Hi, Bob, Just curious...for those of us who are inexperienced in dealing with things electrical...would it be worth your time and $$ to put together and sell a basic kit of the tools (crimper, soldering tool, solder, and the most-used sizes of wire, connectors, splices, etc)? I mention this because I'm building an RV-6, and it would have been useful for me to have had some of those items (especially the basic tools) to do things like the wiring in my fuel tank for the capacitance fuel senders, and (coming up) the landing lights...not to mention the Bob Archer VOR antenna that I'm planning on putting in the wingtip...just a thought, might be useful for us novices who aren't sure what they need. Semper Fi John RV-6 (left wing) ________________________________________________________________________________
Date: May 12, 2002
While I do agree with the intent of the below that IFR flight ops be taken quite seriously, I would suggest that the statement that the VOR network will be around for "many, many, many more years" may be incorrect. With all the money that has been spent by the US govt. on GPS, with more money going into "GPS II", there are efforts underway to realize some of the advertised dollar savings. One avenue being explored by the FAA (and other govts) is the possibility of using GPS for enroute navigation and shutting down the VOR network. Lots of money is also being spent on enhanced GPS landing systems (do a web search on LAAS and WAAS for more) which would allow most (or all) ILS systems to be shutdown as well. Yes, there are technical problems, but the costs savings available through eliminating VOR and ILS ground equipment, maintenance personnel, flight checking, etc. are big enough to keep this effort going. Plus there are operational advantages such as being able to provide a precision approach capability at most any location where one feels like doing the survey work. The timetable of when to close down the existing VOR/ILS network is a highly political thing when there is a big installed base of current users but it will happen sometime. As more and more users start installing and using GPS and discovering the operational advantages, the decision will get easier. Back up and redundancy options are part of the equation too and have not been overlooked. Jim Oke Winnipeg, MB (Did enough single TACAN IFR myself to learn not to like it...) ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: IFR Equipment Required > > In a message dated 05/11/2002 2:52:38 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com writes > (slightly edited): > > << I have been searching for FAR information which stipulates the avionics > requirements for IFR navigation. I am only interested in locating the > appropriate section which identifies the NECESSARY NAVIGATION RADIOS > required for IFR flight. I understand that somewhere in the FARs it mentions > something about only needing equipment for the type of navigation and > approaches which are required for a particular flight. > > The issue is...... I want to set up a light IFR RV7A to punch through > overcasts when necessary..... That's it, no real weather stuff to speak of. > I seem to remember that 1 VOR was the minimum, and that GPS alone could not > be approved as sole source IFR. I would like to set up a minimum IFR RV with > GPS only as my sole source of navigation and for non-precision approaches. > (1) I do not want to include the outdated VOR in my panel. Is this going to > be > possible? (2) Are the rules different in any way for experimental aircraft > flying under IFR. (3) Can someone answer my question properly or refer me to > the FARs which are applicable to my question. >> > > 5/11/2002 > > Hello Victor, Thank you for opening this can of worms. I doubt that we'll all > agree and come to some common specific answers, but it should be fun (and > maybe a bit educational to try). > > I've inserted some numbers into your posting above in front of each > individual question in order to make answering them easier. > > Lets start with number (3). What FAR Section pertains? Your basic reference > is FAR Section 91.205. This Section identifies all of the equipment and > instruments needed for VFR, VFR Night, and IFR flight for standard category > US airworthiness certificated aircraft. Does that mean that Section 91.205 > doesn't apply at all to amateur built experimental aircraft and those > experimental aircraft get to have whatever they want? > > Not at all because the Operating Limitations that are issued at the time of > certification of your amateur built experimental aircraft will require the > aircraft to meet the appropriate requirements of Section 91.205 depending > upon the capability that you are seeking and the equipment that you are > providing for your aircraft. > > Question (2): Once your amateur built experimental aircraft gets into phase > two (after the initial flight restrictions are flown off) and you file IFR > and take off with your properly equipped aircraft in accordance with your > Operation Limitations you should expect to be treated just like any standard > type certificated aircraft in the ATC system and you should be capable of > operating IFR like any standard type certificated aircraft. > > Question (1): Can get by with no VHF (VOR) navigation equipment? My answer is > a question --Why? Our present national navigation system is built around VOR > stations. It will be that way for many, many, many more years to come -- > maybe through out our entire flying career. If you have both GPS and > VHFnavigation capability in your aircraft you have some backup / alternate > flexibility. (I flew for many years with a single navigation capability > (TACAN only) in high performance aircraft -- having no back up really sucks). > > Sure, other posters have told you that no VHF navigation capability is > "legal". I don't know how they intend to prove that, but you can bet the > first time some ATC controller starts out to help you do what you want to do > and he includes some VOR requirement and you tell him "Unable" what you may > very likely hear in return is "Well then, I'm unable also". > > My recommendation: In your other posting you indicated that you were planning > on putting in a UPSAT SL-40 VHF Comm. Why not put in a UPSAT SL-30 VHF > NavComm instead? It is an extremely capable piece of equipment (can handle > two VOR station signals at the same time for intersection capability). If you > connect it to the external CDI that you are planning in such a fashion that > you can switch the external CDI feed from either the GPS or the VHF Nav you > will have a very flexible and capable system. > > Now about "light IFR" and "punching through". I don't want to get up on my > soap box in this posting, but please let me make two philosophical > observations: > > A) Many pilots have busted their ass in attempts to just "punch through" > (either going up or down) what was supposed to be "just a layer". > > B) The phrase "Light IFR" is a lot like the phrase "a little bit pregnant". > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Easy Battery Ammeter. Where to Get Sensor.
Date: May 12, 2002
Contact Grand Rapids Technologies at 616 583 8000. Ask for Gregg. The sensor works on DC. Gabe A Ferrer ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Subject: Re: Easy Battery Ammeter. Where to Get Sensor.
Date: May 12, 2002
Thanks for the reply. Wayne ----- Original Message ----- From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net> Subject: AeroElectric-List: Easy Battery Ammeter. Where to Get Sensor. > > Contact Grand Rapids Technologies at 616 583 8000. Ask for Gregg. > > The sensor works on DC. > > Gabe A Ferrer > ferrergm(at)bellsouth.net > Cell: 561 758 8894 > Night or FAX: 561 622 0960 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 12, 2002
This discussion makes a strong case for a mechanical disconnect switch instead of an electrical master battery solonoid. Here is some advise that I hope will help others. I often see people ask a question, then stating that they had seen it before and cannot find it again. I have done the same thing. In an attempt to catalog the info where I might be able to find it, I copy what I find is interesting and anything that I think will be needed in the future and paste it to a WORD document and save it under an appropriate alphabetical folder within my electrical folder. Good luck, Rick D. > > >>I noticed within a couple of seconds that something wasn't right. >Immediately shutoff the master - but didn't hear a click. Smoke started >coming from #4 power and ground cables. Almost had a heart attack. After >about a minute I finally managed to cut the power cable to prevent a fire.<< > > Once a long time ago in a galaxy far away I remember that the design rules > was to size the battery cable so that if there were a dead short the > battery > would go dead before the wire would catch on fire. Any other wires were > protected by fusible links. I'm sure, by looking at newer cars, that this > rule has been often ignored, but it made sense to me. Looks like a #4 wire > isn't big enough to protect against that failure mode. And relays welding > closed with a high-current short is not an uncommon occurrence. Hadn't heard of that one. Back in the hey-day of soggy-out-of-the-box flooded batteries, this might have been a practical thing to do but today's 25 a.h., RG batteries are capable of 1200A fault current or better. Besides, a hard fault through sufficiently fat wires on a flooded battery may not precipitate a fire but geysers of hot, acid laden water are only slightly more appealing than a wire-fire. Of course, one has the option of installing current limiters like http://www.aeroelectric.com/Catalog/ckrtprot/anl.jpg . . . These are available in some really fat sizes for folks that are worried about it. Keep in mind that the first event cited in this discussion was a fault generated by a wiring error. The second event was probably due to soggy battery. It's unusual for the same system to suffer both events so closely spaced . . . and had the wiring error not occurred, it would have been a single-event story. Hard, uncontrolled faults in battery feed wires are very rare. I've never encountered one in a single engine aircraft personally and I've never read of one either. That doesn't mean that it hasn't happened but since this is a core technology feature of a 40+ year career, I think it's safe to say that likelihood of having either (1) a hard fault downstream of a stuck battery contactor or (2) a stuck starter contactor paired with a stuck battery contactor is very low. Bob . . . ________________________________________________________________________________
Date: May 12, 2002
From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com>
Subject: Re: IFR equipment required
> > >Victor & Bob, I am deep into wiring (Keeping the smoke inside thanks to >this great list) and have been told by the locale FAA Inspector that my >plane will meet minimal IFR Standards at least by my Ohio Inspector. > I have a Garmin 430, Apollo SL-30 & Garmin 327 Transponder. I won't >be using an external VOR Head (SL-30 has a built in needle) and as these 2 >radios are approach certified. The sure death of VOR Navigation in the >future, should I believe make this a non-issue with most DARS & FAA >Inspectors. > Thanks Bob for letting us talk a little about Avionics on your >list. It's not my list, it's YOUR list. Any discussion in search of truth and/or the elegant solution is well within the Matt's charter for the activities he hosts on his servers. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: May 12, 2002
> > This discussion makes a strong case for a mechanical disconnect > switch instead of an >electrical master battery solonoid. How so a STRONG case? We might just as well have been discussing prop bolt failures, wing strut failures or any other event for which the probability is small but not ZERO. Let us take care lest we worry small probabilities into STRONG cases with a resulting waste of intellectual resources, time and dollars that INCREASES weight, parts count and burdens a pilot with more things to worry about and be prepared to react to. Before we can call this a STRONG case, I'll suggest some research into all of the dark-n-stormy night stories and service difficulty reports published over a substantial chunk of years would be in order. I've not read them all but I've read a lot. I've also gathered a lot of observations on other DC powered vehicles over the years. Welding of contactors is very rare and most often induced by operational errors. I've not experienced it even once in my lifetime. >Here is some advise that I hope will help others. I often see people ask a >question, then >stating that they had seen it before and cannot find it again. I have done >the same thing. In >an attempt to catalog the info where I might be able to find it, I copy >what I find is >interesting and anything that I think will be needed in the future and >paste it to a WORD >document and save it under an appropriate alphabetical folder within my >electrical folder. >Good luck, I'd like to think that we're all here to improve on the odds of comfortable and enjoyable use of these machines though considered discussion of the physics as opposed to hoping for "luck" . . . Bob . . . ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: "basic" kit of essential tools/supplies
> >Hi, Bob, > >Just curious...for those of us who are inexperienced in dealing with >things electrical...would >it be worth your time and $$ to put together and sell a basic kit of the >tools (crimper, >soldering tool, solder, and the most-used sizes of wire, connectors, >splices, etc)? I mention >this because I'm building an RV-6, and it would have been useful for me to >have had some of >those items (especially the basic tools) to do things like the wiring in >my fuel tank for the >capacitance fuel senders, and (coming up) the landing lights...not to >mention the Bob Archer >VOR antenna that I'm planning on putting in the wingtip...just a thought, >might be useful for >us novices who aren't sure what they need. > >Semper Fi >John >RV-6 (left wing) I'll suggest that some time browsing through our website catalog will produce results very close to what you're asking for. Unlike catalogs of folks who are in the tools business, our catalog was developed based upon a need to practice techniques and skills described right here on the AeroElectric List and others in which I've participated over the years. If you have NO tools whatsoever, then you would not be wasting your dollars to simply acquire one of everything we offer. There are no duplications of capabilities across the spectrum of tools offered and there is very low probability that you will not find several instances where each of these tools will be needed in the completion of your project. Obviously, we did not choose to offer additional tools commonly available elsewhere. You're going to need screwdrivers, wrenches, pliers, wire cutters and strippers, etc. But you can get these pretty much as needed and when needed from local suppliers. The things we choose to offer from our website are those items you won't find at Sears. Just for grins, I dug out the toolbox I developed for my grab-it-and-run tasks at work. The toolbox is about 4" x 10" x 3" and fits in my briefcase. With the items it contains, I have successfully tackled a lot of tasks. The box contains: Propane powered soldering iron Propane powered heat gun (Of course, propane powered tools were chosen for their size and portability, plug-in-the-wall devices are more suited for daily shop activities) Small diagonal cutters (Craftsman - you ARE going to break them some time, Sears will replace for free which makes them a bargain) Cheap wire strippers Small needle nose pliers (Craftsman again . . .) Extraction tools for D-sub and MS34xx series connector pins Hex wrench set (type that folds up like pocket knife) X-acto knife (one that I built that holds spare bladed in handle) Xcellite tool set of slot and phillips screwdrivers and nutdrivers through 3/8" Open/box wrenches for 3/8, 7/16, 1/2" Odd assortment of male/female pins for connectors cited above. RCT-3 D-sub crimp tool Solder and solder wick Cheap, super slim volt/ohmmeter from Radio Shack . . . a rudimentary instrument at best but capable of measuring and deducing problems that a wet finger won't do. Add to this list the extra compliment of crimp tools from our website and I think you'll find that the majority of wiring tasks for your airplane are immanently doable. Bob . . . ________________________________________________________________________________
Date: May 12, 2002
Subject: RW 162f Electrical system
Bob and anyone who can help: I am building a Rotorway 162f helicopter which has two FADEC computers that run the engine and electronic ignition. I have several questions about the electrical system which seems to be designed rather poorly. I wish I could upload a schematic or diagram so you could take a look at it but instead I'll try and describe it instead. It seems to be a simple system with basically two buses: The "essential buss" has: 2 Fadec's 2 Fuel pumps 2 Ignition modules Each Fadec has it's own 20 amp fuse One of each fuel pump and ignition module are paired together off of a 15 amp fuse. The buss is supplied by two wires (seem like 12 awg but can't be sure) that run from the battery through two 30 amp fuses. It is also supplied directly from the alternator by one of two b-lead wires, the second of which goes directly to the 12v battery. They are both protected by 30 amp inline fuses at the alternator. There is no battery contactor or switch. The second buss is interesting because: In addition to the avionics and instrument power leading from it, they have an alternator field switch coming off a 7.5 amp fuse that also supplies the avionics. The starter relay and key switch also come off this bus through a 7.5 amp fuse that it shares with the instrument power tap. This buss is supplied with power from the battery only through a third 30 amp fuse. The alternator was an upgrade when I purchased their lighting kit from a 30 amp to a 54 amp. It doesn't seem to have included larger wire for the b leads, one looks like 10 or 12 awg and the second is smaller, maybe 14 or 16 awg. I intend to put a landing light, nav and strobes and instrument lights and B/C dimmer on the second buss. There will also be a Garmin 250xl GPS/Comm and 327 xnpdr off that buss. The kit comes with a wiring harness that just plugs together so I'm a little hesitant to mess around with it, but I'm at the stage where I can modify it with out too much trouble. I'd like to change it to match the schematic for a light acft that's in your book but don't want to add any weight. My questions are these: Why all the duplicate paths from battery to busses, and alternator to bus and battery? If one side of the 30 amp supply from battery shorts or overloads, wouldn't it just blow the other supply side too? Same with the alternator B-leads. I want to replace all the fuses with breakers. I don't like having components sharing fuses, especially the fuel pumps and ignition modules. Should I also put the alt field on the essential bus? How about the starter relay? I bought a B/C crowbar OV device and plan to install it as well. All the wiring diagrams in your book show the alternator going to the contactor and then to the busses. Does the essential buss require the two 30 amp battery feeds plus the alternator feed? I would like add a contactor for the battery and a battery master switch. I picked up an 80 amp continuous duty relay from the local autoparts store (Eclin STS 80?) that I thought was a copy of the ones I've seen on other aircraft and thought I'd add the diode as per Bob's book. Will this work? I also want to replace the two small wires with one larger cable from the alternator to the output side of the contactor and eliminate the direct line to the first buss. Would that be smart or would it cause other problems? If there were a problem with the battery or contactor, the direct feed from the alternator would still power the FADEC's. What wire size would be appropriate for a 54 amp output? Should I put a fusable link to protect it? Since this engine requires power to run the FADECs and ignition, what is the minimum voltage the contactor requires to stay open? If the alternator dies, will low voltage open the relay and kill the engine? I think the factory told me that the FADEC's require 10v minimum. Am I adding a source of failure when there was none to begin with? A strobe power pack requires 7.5 amps, landing light 8 amps, nav and instrument power and lights, radio and xnpdr consume (?). Will this overload the second buss with only 30 amp protection? Thanks in advance for any suggestions Vince Ackerman ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: PM alternator upgrade for reliability
> > >Bob, > While designing a second alternator for my Jabiru 3300, it occurred >to me that the major failure mode for a permanent magnet (PM) is >regulator failure. Unlike a field regulator which controls at most 5 >amps, the poor PM regulator must pass the whole output. For the Rotax, >this is 18 amps, for the Jabiru about 20. Since the Rotax, Jabiru, and >SD-8 all have the permanent magnets mounted such that centrifugal force >just presses them into a seat, they can't fly out. The coils are fixed >with no sliding contacts. The Rotax and Jabiru alternators are part of >the flywheel, so there is no drive system to fail. Given these facts, >would a backup regulator be as good as a whole separate PM alternator? Excellent question. To provide a good answer, we would have to consider the field history on the existing rectifier/regulator assemblies. I do recall a lot of unhappy discussion about the Rotax 912 regulator on Kitfox and Pulsar lists in years past but I've not heard much lately (of course I don't participate on those lists any more either . . . ) Does anyone have any current insight to offer on these products? > >Three S704-1 relays could switch the two coil leads and the output lead. > A fourth relay might be needed for the second OV circuit: the first OV >relay would automatically switch to the backup regulator. Before >committing this to copper, a failure analysis should be done, and I >don't have any field experience to back up the above line of reasoning. Here's the rub . . . as a general rule, relays are considered to have the greatest negative impact on MTBF of any system. Now, that's not to say that inclusion of relays makes system failure a frequent certainty but given that the rectifier regulator is all solid state, and has no relays, adding very many relays to the system might have a more negative impact on total system reliability than could be offset by having two regulators. Given the weight and size of the regulator, I think I would rather hang my hat on the concept of having an e-bus powered with enough capacity to get me comfortably on the ground at airport of intended destination. This is something that we do ANYHOW and makes whatever else you do with respect to alternator system reliability a mute point. As long as you have a good e-bus/battery combo, then it wouldn't add a lot of risk to try backing up the main regulator with a relay-switched alternate . . . it just MIGHT perform as desired but there is risk that the whole alternator system has become less reliable due to inclusion of relays that are common to both systems. We already have one relay in the output of both a Rotax and SD-8 system for control and to implement OV protection. (I'm toying with a ROBUST crowbar OV design that would be able to pry open a 20A breaker . . . but I'm still stuck with the problem of control . . . don't have anything more elegant to propose than the OVM-14 and S704-1 combo . . . yet . . .) The neat thing about an SD-8 or SD-20 backup alternator is that they stand totally alone from the main system and not run except when needed so that parts are not subject to failures driven by service stress. > >What do think, Bob? Could this become another Z diagram? Cheaper and >lighter and simpler than a separate alternator. Is it? The SD-8 weighs in at about 4 pounds installed. How much does a Rotax rectifier/regulator weigh? How much does it cost? Much less than an SD-8? Excellent questions worthy of good critical review. . . Bob . . . ________________________________________________________________________________
Date: May 12, 2002
Basically I think that "OC" is on the money here. Your opinion may vary. Two specific comments: 1. I still remember my IFR instructor drilling into my head that ... "you are either IFR or VFR and never both. If you are IFR be prepared to do EVERYTHING IFR...". Basically I took it as once I request IFR services and enter the system, I must be prepared to do all the "basic" things that ATC asks of me unless I have an emergency. I do understand though the need at times to "bust through" what is a **KNOWN** light layer of fog etc. The decision is yours of course. 2. In our RV6 that is being built as a *VFR* plane, it has the King KMD 150 moving map display (NOT IFR) and the UPSAT SL40 (comm only). But, it is wired so that in the future a) the SL40 can be slid out and replaced with the SL30 (tray and harnesses in for SL30), b) the CDI out of the KMD 150, which is brought to an accessible terminal block and from there to the NAVAID autopilot, can be easily connected to a CDI if we decide to put one in the "reserved" hole for same. In the future the CDI out of the SL30 can either replace the KMD 150 CDI out or be added via a switch for a "legit" IFR setup. In this setup, we will have VOR/Localizer/ILS approaches potentially available to us. The moving map GPS would be a visual aid in this scenario. You might want to consider something similar. The added cost is the delta between the SL40 and the SL30 plus a CDI. If you want to be in the system, it may well be worth the $2-3K. James [stuff deleted ...] > Question (2): Once your amateur built experimental aircraft gets > into phase > two (after the initial flight restrictions are flown off) and you > file IFR > and take off with your properly equipped aircraft in accordance with your > Operation Limitations you should expect to be treated just like > any standard > type certificated aircraft in the ATC system and you should be capable of > operating IFR like any standard type certificated aircraft. > [stuff deleted ...] > Sure, other posters have told you that no VHF navigation capability is > "legal". I don't know how they intend to prove that, but you can bet the > first time some ATC controller starts out to help you do what you > want to do > and he includes some VOR requirement and you tell him "Unable" > what you may > very likely hear in return is "Well then, I'm unable also". > > My recommendation: In your other posting you indicated that you > were planning > on putting in a UPSAT SL-40 VHF Comm. Why not put in a UPSAT SL-30 VHF > NavComm instead? It is an extremely capable piece of equipment > (can handle > two VOR station signals at the same time for intersection > capability). If you > connect it to the external CDI that you are planning in such a > fashion that > you can switch the external CDI feed from either the GPS or the > VHF Nav you > will have a very flexible and capable system. > > Now about "light IFR" and "punching through". I don't want to get > up on my > soap box in this posting, but please let me make two philosophical > observations: > > A) Many pilots have busted their ass in attempts to just "punch through" > (either going up or down) what was supposed to be "just a layer". > > B) The phrase "Light IFR" is a lot like the phrase "a little bit > pregnant". > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Subject: Handheld power conditioning
Date: May 12, 2002
Hello Bob, after going through the seminar wirebook I've found Page V25, is this exactly describing what you mention below? Unfortunately we have no seminars over here in Europe where we could gain from your knowledge. Should the whole setup be placed in a special metal case? I'm planing to have three such ports available on my panel, should I separate them each in one case or can they be put on one printboard. What does the note exactly mean? Many thanks for your feedback Werner (still many decisions to do electrical wise) ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls(at)kscable.com> Subject: AeroElectric-List: Re: Bendix King Handheld KX99 > > > > > > >To > >I have made the sin of shutting off the battrey master before shutting > >the engine (912 Rotax). my handheld transceiver KX-99 (Bendix King) > ...................... > > > If I were going to tie any hand helds into ship's power, > I would probably use a Radio Shack 270-030 noise filter > downstream of a small fuse (1A) and then put a couple > of 1N4745, glass zener diodes across the output feeding > the radio. ________________________________________________________________________________
Date: May 12, 2002
> >While I do agree with the intent of the below that IFR flight ops be taken >quite seriously, I would suggest that the statement that the VOR network >will be around for "many, many, many more years" may be incorrect. > >With all the money that has been spent by the US govt. on GPS, with more >money going into "GPS II", there are efforts underway to realize some of the >advertised dollar savings. One avenue being explored by the FAA (and other >govts) is the possibility of using GPS for enroute navigation and shutting >down the VOR network. Lots of money is also being spent on enhanced GPS >landing systems (do a web search on LAAS and WAAS for more) which would >allow most (or all) ILS systems to be shutdown as well. > >Yes, there are technical problems, but the costs savings available through >eliminating VOR and ILS ground equipment, maintenance personnel, flight >checking, etc. are big enough to keep this effort going. Plus there are >operational advantages such as being able to provide a precision approach >capability at most any location where one feels like doing the survey work. >The timetable of when to close down the existing VOR/ILS network is a highly >political thing when there is a big installed base of current users but it >will happen sometime. As more and more users start installing and using GPS >and discovering the operational advantages, the decision will get easier. >Back up and redundancy options are part of the equation too and have not >been overlooked. From the manufacturing side of the issue, we KNOW that VOR, ILS, ADF and GS technologies have far outlasted their practical usefulness and persist only due to the lethargic, uninspired and unmotivated pleasure of government. We were told over a decade ago that ground based VOR and ADF facilities were going to be phased out by attrition . . .as they crapped out, they would not be repaired. Yeah . . . right. In the mean time, great committees assigned guardianship of our futures plod ever onward, oblivious of the fact that the value of their deliberations is inversely proportional to the square of the number of people working the task. The Coast Guard has been navigating with one meter precision over our nation's waterways using GPS navigation for many years . . . they pressed some old low frequency beacon technology into service to provide wide area dissemination of GPS error data to boats over a decade ago. Hmmm . . . they obviously screwed up . . . not enough committees . . . they just went out and did it. You and I, out there working with what we can buy off the shelf today are better equipped to evaluate what we can do as a matter of routine than is the most dedicated of public servants. It's all well and good to seek out "approved", "certified", or "TSO'd" equipment and installations but NONE of this guarantees diddly-squat with respect to the outcome of any venture into an IFR situation. Plenty of faithfully blessed systems operated by qualified pilots bite the big rock every year. Bottom line is that it's really up to all of YOU to decide what can comfortably navigated based on evaluation of equipment you have and your skill to use it. When you're over the top in the sun and want to penetrate down to 600' ceilings below, the person from whom you request a clearance isn't going to ask you if all your goodies are blessed and whether or not you have the foggiest notion of what you're doing. They have every right to expect that you wouldn't ask for that clearance if you were not PERSONALLY confident of the outcome. Just because all the stuff in your panel is when you need it. If you've flown that ADF or other non-precision approach into your home field a dozen times VFR using a couple of Walmart hand-held GPS receivers for reference, what critically thinking scientist would think you were better off flying that approach with the 30 year old radio on the panel? And if you DO use those Walmart hand helds, the guy watching you on radar may think you're the most skilled ADF pilot he's ever seen! How many string-straight, 20kt crosswind ADF approaches do you supposed he's witnessed? Yeah, we gotta cross the T(s) and dot the I(s) to get shed of bureaucratic attention - just to gain admittance to the party. However, I'm not sure I'd purchase front row tickets when the ones up in the nose-bleed section are cheaper. After the bureaucrats smile and go away, I'll suggest you are better off becoming good at what you understand, can demonstrate that works and is more reliable because you might have bought a number of el' cheapo flight aids instead of one gold-plated one. Yeah, roll it up in a ball and the bureaucrats will be all over the wreckage. But what difference does it make then as to the various blessings your stuff had or didn't have? You set out to exercise an extraordinary skill that placed certain demands on you and your equipment. For what ever reason, the pieces just didn't fall into place . . . the NTSB report will chronicle YOUR screw-up in black and white for all of us to read for decades hence. I'll suggest that gold-plated, holy-watered hardware doesn't do much to improve the odds. Being a good scientist, understanding the capabilities and limits of the tools you are crafting and being practiced in their operation will go a LONG way into improving your odds and enjoyment of the machine you're building. Government is pre-disposed to believe only they understand the science which you are "qualified" to use only because you read their book, took their course, passed their test every 6 months and saluted all their rules. I'm not suggesting those things don't help . . . and certainly hundreds of thousands of us have lived to tell the tales of life in in that environment. However, NONE of their requirements are based on your demonstrated UNDERSTANDING of the science involved. Your participation on this list and others says you're at least interested in knowing and understanding the science. Good science is good science, whether it happens in your cockpit, here on this list, or in some meeting room in Washington. Experience suggests that the best science may happen any place but Washington. Bob . . . ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: Jabiru 3300 dual alternator control
> > >Bob, > Bruce Banks asked about the Rotax 912 system, and you noted that >this has an optional 40 amp belt driven alternator in addition to the >standard 20 amp PM alternator. You recommended diagram Z13 for dual >alternators in this situation. My situation is similar, but not >identical. The Jabiru 3300 has a robust flywheel mounted PM alternator >that should be bulletproof, almost identical to the SD8--but of course >that hard working regulator might fail. I plan to add a B&C SD20 >alternator to the spline fitting on the crankshaft. Tim at B&C assures >me that this will give 20 amps at 2750 rpm in a 14 volt system. Oops! That 20A output at "2750" rpm is based on gearing offered at the vacuum pump pad of most aircraft engines. The alternator needs to turn about 4,000 rpm to get you 20A. On a Lycoming with about 1:1.3 pad ratio, the 20A statement at 2750 propeller RPM is accurate. > I would >like to run both alternators simultaneously, as they are each about the >same capacity and could give a total of 40 amps. Would it be reasonable >to substitute the B&C SB1B-14 regulator for the LR3 listed on Z13, and >then have both units on simultaneously? I would fuselink the SD20 >output and probably connect it to the battery side of the battery >contactor. What's the advantage of simultaneous operation to a single bus? I'd think I'd rather have independent operation to separate busses even if one of the batteries were quite small . . . just big enough to stabilize the alternator. > I worry about overvoltage protection from both systems being on in >parallel. Could, for example, the PM alternator trigger the OV system >and then bring down both paralleled alternators? I don't think it >would, but I'm not fully certain how the SB1B works. The SB1B is a >standby controller. The SB1B should keep field current at zero unless a >low bus voltage is detected. Thus, I speculate that it would not be set >to crowbar the field circuit of the SD20 and blow the field fuse. This >is of some general interest, as the Jabiru system is getting popular, >and those of us who want all electric systems with redundancy could use >this alternative. The SB1 has selective trip meaning that it wouldn't take the SD-20 off line unless it detects that the SD-20 is in fact the source of the OV condition. Okay, suppose you were running a light load and the PM alternator goes out in OV trip but no warning lights come on because the loads are well within the capability of the remaining alternator. In this case, you wouldn't use the SB-1 but the LS-1 which has low voltage warning feature. Then, selective trip for OV isn't a big deal. > My power budget may not require both alternators on simultaneously, >but this system has the advantage of automatic switching from PM >alternator to SD20 if the PM fails, and is thus one less item to >distract the pilot. In other words, it works like the dual alternator >diagram in fig. 17-8 of the 'Connection. My plane is a Jabiru J400 with >Blue Mountain EFIS (4amps), transponder, one NAV/COMM, one COMM, strobes >(7 amps), position lights (6amps) and an autopilot which may suck >considerable power at times. In the future I may need pitot heat. I >will use all of your recommended systems: fast-on wiring, NylaFlow >conduit, battery bus, essential bus, main bus, single point ground, >fuses, and voltage and current monitor. The one battery, two alternator >system looks like a winner if I can get reliable control. You could do this but you'll want to add active notification of low voltage should the main alternator fail -AND- the standby alternator becomes overloaded. The SB1 regulator has a light that illuminates to tell you that the SB alternator has picked up some load which could have this light illuminated under NORMAL operations. You would want to add LV warning also to assure you that irrespective of the combination of operating alternators, loads on the bus are being supported. It's a toss-up for one or two busses. Either will work for you. I like the failure notification and isolation of dual busses better. If you used a tiny battery on the aux alternator, then you don't need a fat cross-feed contactor because the aux battery would not be expected to aid cranking. A smaller S704-1 relay or perhaps just a breaker to push in for effecting interconnection of the two systems would suffice. The biggest hurdle you may have to mount is the gearing of the SD-20 to get reasonable output. Any way you could belt drive a 40A ND machine for LOTS of good output? Bob . . . ________________________________________________________________________________
Date: May 12, 2002
Subject: IFR by GPS only
In a message dated 05/12/2002 2:52:29 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com <> writes: << Well, actually, the GPS he proposes will fly to any VOR just as easily as it would any other fix. Punching in nearest VOR and direct to will reset the GPS to fly to that station (target). There is no legal requirement to use any ground based stations unless that is what you have in your plane. No one ever said not having a backup nav aid was smart thinking. he asked if he could fly IFR with a GPS only. The answer is yes.>> 5/12/2002 Hello Aucountry, His exact question was "I would like to set up a minimum IFR RV with GPS only as my sole source of navigation and for non-precision approaches. I do not want to include the outdated VOR in my panel. Is this going to be possible?" So you may be right. A simple one word answer of "Yes" may meet legal, regulatory, and theoretical requirements. But in reading the entire context of his posting I think that he was owed a bit more. The word "possible" to me meant that he wanted to have safe and practical subsequent IFR operations after initial certification. Can we do this if it is not too far off topic? Could we have a little survey? Can we please hear from any pilot builders who have: 1a) Successfully certified their amateur built experimental aircraft in the USA for IFR operations with only a GPS installed in their aircraft, and 1b) Subsequently flown that aircraft IFR in IMC in the USA and are satisfied with their configuration. 2) Attempted to certify their amateur built experimental aircraft for IFR operations in the USA with only a GPS installed in the aircraft and were denied their IFR approval. First hand pilot builder inputs only please, no "heard it from a friend of a friend" 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? PS: Your words "just as easily" bring to mind the many words being written currently in the aviation press about how difficult people are finding it to manipulate their GPS's and fly (particularly in IMC) at the same time. Sometimes the scarcest commodities in the cockpit are eyeballs and finger tips. Flying single pilot IFR in IMC and manipulating a GPS consumes a lot of both. Rod Machado wrote recently about how the requirement to manipulate a GPS was adversely impacting safe flight by the pilot involved. He suggested that GPS should stand for Give it to the Person Sitting next to you. ________________________________________________________________________________
Subject: Re: RW 162f Electrical system
Date: May 12, 2002
Hi Bob, Appears we have another rotorway driver here that is not all to happy with the wiring scheme on these ships. Any suggestions? P.S. Vince, I have an Exec 90. The wiring is inadequate. One other serious problem, the electronic ignition FAILS if the voltage drops below 9.6 volts. Just like that no engine! And, there's no provision to for warn the driver other than a real good preflight.... and there is no backup. We need some sort of fail safe provision in case the voltage goes way down all at once. Any suggestions? ----- Original Message ----- From: "Vince Ackerman" <vack(at)teleport.com> Subject: AeroElectric-List: RW 162f Electrical system > > Bob and anyone who can help: > > I am building a Rotorway 162f helicopter which has two FADEC computers that > run the engine and electronic ignition. I have several questions about the > electrical system which seems to be designed rather poorly. I wish I could > upload a schematic or diagram so you could take a look at it but instead > I'll try and describe it instead. > > > It seems to be a simple system with basically two buses: > > > The "essential buss" has: > > 2 Fadec's > 2 Fuel pumps > 2 Ignition modules > > Each Fadec has it's own 20 amp fuse > One of each fuel pump and ignition module are paired together off of a 15 > amp fuse. > > The buss is supplied by two wires (seem like 12 awg but can't be sure) that > run from the battery through two 30 amp fuses. > > It is also supplied directly from the alternator by one of two b-lead wires, > the second of which goes directly to the 12v battery. They are both > protected by 30 amp inline fuses at the alternator. > > There is no battery contactor or switch. > > > The second buss is interesting because: > > In addition to the avionics and instrument power leading from it, they have > an alternator field switch coming off a 7.5 amp fuse that also supplies the > avionics. > > The starter relay and key switch also come off this bus through a 7.5 amp > fuse that it shares with the instrument power tap. > > This buss is supplied with power from the battery only through a third 30 > amp fuse. > > > The alternator was an upgrade when I purchased their lighting kit from a 30 > amp to a 54 amp. It doesn't seem to have included larger wire for the b > leads, one looks like 10 or 12 awg and the second is smaller, maybe 14 or 16 > awg. > > I intend to put a landing light, nav and strobes and instrument lights and > B/C dimmer on the second buss. There will also be a Garmin 250xl GPS/Comm > and 327 xnpdr off that buss. > > The kit comes with a wiring harness that just plugs together so I'm a little > hesitant to mess around with it, but I'm at the stage where I can modify it > with out too much trouble. I'd like to change it to match the schematic for > a light acft that's in your book but don't want to add any weight. > > My questions are these: > > Why all the duplicate paths from battery to busses, and alternator to bus > and battery? If one side of the 30 amp supply from battery shorts or > overloads, wouldn't it just blow the other supply side too? Same with the > alternator B-leads. > > > I want to replace all the fuses with breakers. I don't like having > components sharing fuses, especially the fuel pumps and ignition modules. > Should I also put the alt field on the essential bus? How about the starter > relay? I bought a B/C crowbar OV device and plan to install it as well. > > All the wiring diagrams in your book show the alternator going to the > contactor and then to the busses. Does the essential buss require the two 30 > amp battery feeds plus the alternator feed? > > I would like add a contactor for the battery and a battery master switch. I > picked up an 80 amp continuous duty relay from the local autoparts store > (Eclin STS 80?) that I thought was a copy of the ones I've seen on other > aircraft and thought I'd add the diode as per Bob's book. Will this work? > > I also want to replace the two small wires with one larger cable from the > alternator to the output side of the contactor and eliminate the direct line > to the first buss. Would that be smart or would it cause other problems? If > there were a problem with the battery or contactor, the direct feed from the > alternator would still power the FADEC's. What wire size would be > appropriate for a 54 amp output? Should I put a fusable link to protect it? > > Since this engine requires power to run the FADECs and ignition, what is the > minimum voltage the contactor requires to stay open? If the alternator dies, > will low voltage open the relay and kill the engine? I think the factory > told me that the FADEC's require 10v minimum. Am I adding a source of > failure when there was none to begin with? > > A strobe power pack requires 7.5 amps, landing light 8 amps, nav and > instrument power and lights, radio and xnpdr consume (?). Will this overload > the second buss with only 30 amp protection? > > > Thanks in advance for any suggestions > > > Vince Ackerman > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: welding relays
>Electric Bob wrote: > Let us take care lest we worry small probabilities into STRONG > cases with a resulting waste of intellectual resources, time and > dollars that INCREASES weight, parts count and burdens a pilot with more > things to worry about and be prepared to react to. Most of us could better ensure a long life by watching what we eat - fat, salt, sugar etc. Play the odds, guys. If it tastes good, spit it out. hal ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: IFR by GPS only
Let me be the first to respond to the survey. My answer is : "Sort of." Unfortunately my plane was certified five years ago and the boilerplate has changed; however, my Operating Limitations said (paraphrased since I dont have it with me). "Approved for night VFR and IFR, when properly equipped." I was delighted to have that statement and I hope they have not changed it. My only piece of navigation equipment was (and still is) a KLX 135A GPS/Com. I have not ever filed IFR in it, since I have no current IFR rating; however I believe it to be possible to do so, providing the plan requested was within the capability of the installed equipment. As a post script, I share the observation that manipulating the GPS for precise navigation is a complex task. Watching most pilots I fly with trying to work their GPS, us a frightening thing. Believe me I spent many many hours both in flight and on the ground, training with this jewel to be able to master it. And it is one of the most intuitive and user friendly ones. DLW > From: BAKEROCB(at)aol.com Reply-To: aeroelectric-list(at)matronics.com Date: Sun, 12 > AeroElectric-List: IFR by GPS only > > > In a message dated 05/12/2002 2:52:29 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com <> writes: > > << Well, actually, the GPS he proposes will fly to any VOR just as easily as > it would any other fix. Punching in nearest VOR and direct to will reset the > GPS to fly to that station (target). There is no legal requirement to use any > ground based stations unless that is what you have in your plane. > > No one ever said not having a backup nav aid was smart thinking. he asked if > he could fly IFR with a GPS only. The answer is yes.>> > > 5/12/2002 > > Hello Aucountry, His exact question was "I would like to set up a minimum IFR > RV with GPS only as my sole source of navigation and for non-precision > approaches. I do not want to include the outdated VOR in my panel. Is this > going to be possible?" > > So you may be right. A simple one word answer of "Yes" may meet legal, > regulatory, and theoretical requirements. But in reading the entire context of > his posting I think that he was owed a bit more. The word "possible" to me > meant that he wanted to have safe and practical subsequent IFR operations > after initial certification. > > Can we do this if it is not too far off topic? Could we have a little survey? > Can we please hear from any pilot builders who have: > > 1a) Successfully certified their amateur built experimental aircraft in the > USA for IFR operations with only a GPS installed in their aircraft, and > > 1b) Subsequently flown that aircraft IFR in IMC in the USA and are satisfied > with their configuration. > > 2) Attempted to certify their amateur built experimental aircraft for IFR > operations in the USA with only a GPS installed in the aircraft and were > denied their IFR approval. > > First hand pilot builder inputs only please, no "heard it from a friend of a > friend" > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > PS: Your words "just as easily" bring to mind the many words being written > currently in the aviation press about how difficult people are finding it to > manipulate their GPS's and fly (particularly in IMC) at the same time. > Sometimes the scarcest commodities in the cockpit are eyeballs and finger > tips. Flying single pilot IFR in IMC and manipulating a GPS consumes a lot of > both. > > Rod Machado wrote recently about how the requirement to manipulate a GPS was > adversely impacting safe flight by the pilot involved. He suggested that GPS > should stand for Give it to the Person Sitting next to you. > ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: IFR Equipment Required
Handheld GPS for IFR...is it legal? While NDB, DME, RNAV, ILS and GPS approaches my may brilliantly performed using a handheld GPS, one had better have the "equipment appropriate to the facilities to be used" on board. RIght? I always remember the motto "SKIN, TIN, TICKET" and I add HOUSE. If I have an accident while flying an NDB approach without an ADF receiver I suspect that even if I save my skin, my ticket and possibly my home will be in jeopardy. FAA will scoff up my ticket and lawyers will take everything else while my insurance man shakes his head and smiles. K. H. (Hal) Kempthorne RV6-a N7HK flying! Paso Robles, CA ________________________________________________________________________________
Date: May 12, 2002
I have an Apollo SL60 and MAP 360 in our 172. It is not approach certified which means the damned thing isn't "automatically" sequencing waypoints for you. From a human factors perspective, it is dangerous to automatically change things like the next waypoint (especially since the FAA system has too many variables - published, versus vectors, versus multiple approaches to the same runway). With the Apollo, I choose the next waypoint and it DOESN'T CHANGE until I select the next one. I use it in conjunction with the FAA blessed LOC/GS indicators. I can shoot a whole lot more accurate approach when I monitor the GPS and the ILS-CDI than when I just use the CDI alone. Oh and the FAA mandated GPS CDI is totally useless - another lamebrained piece of gear added to satisfy the old farts who are used to chasing CDI needles and are confounded by computers and smart display systems. Using a GPS requires practice and study. You can't jump in the plane and fly in the klag then try to learn how to use it!!! And yes it is more complicated than a ILS/CDI and VOR radio, but it GIVES YOU SO MUCH MORE INFORMATION AND SITUATIONAL AWARENESS - NO CONTEST! ________________________________________________________________________________
Date: May 12, 2002
Subject: Your password
--- StripMime Report -- processed MIME parts --- multipart/alternative text/html audio/x-midi application/octet-stream --- StripMime Errors --- A message with no text/plain section was received. The entire body of the message was removed. Please resend the email using plaintext formatting --- ________________________________________________________________________________
Date: May 12, 2002
Subject: Re: push to test?
Bob In the Z-4 diagram that I am using. The warning lights will light when the Xfeed/starter is pressed to start or Xfeed position and the lamp on the LR-3 will light at start do to low voltage. Am I correct in this thinking? I therefore would not need a press to test button for these lights. Jim Robinson Glasair 79R ________________________________________________________________________________
Subject: Jabiru 3300 dual alternator control
Date: May 12, 2002
Bob wrote: "Oops! That 20A output at "2750" rpm is based on gearing offered at the vacuum pump pad of most aircraft engines. The alternator (SD20) needs to turn about 4,000 rpm to get you 20A. On a Lycoming with about 1:1.3 pad ratio, the 20A statement at 2750 propeller RPM is accurate." The reason I chose the SD20 was because of the perfect fit to the spline on the crankshaft. I know that the table of shaft rpm vs. output listed with the SD20 drawing says that at 3000 rpm, the output is 12 amps. There is no lower rpm listed to interpolate to 2750 rpm. What I failed to consider was that this output is for 28 volts: no mention of this on the chart. Tim at B&C pointed out that at 14 volts the output could be much greater at 2750 rpm. He claimed 20 amps. Additionally, the Jabiru engine is rated at 120 HP at 3300 rpm, so in an emergency, the engine could be run faster for more amps. The prop might not allow 3300 rpm, but 3000 should be possible. Even with 12 amps, this is more than the SD8 which gives 6.8 amps at 3000, and 5.7 amps at 2750. My essential bus [EFIS/ONE, SL70 xponder, SL30 NavComm] totals 5.1 amps until I transmit on the radio. If the output of the SD20 is under 8 or 10 amps at 2750, then I would be better off with the SD8. At some point, the field current of 5 amps gets significant. I know that a belt driven ND alternator would give 40+ amps, but I'm not up to adding the belt drive. This dual bus system with the EFIS/ONE do-everything is already more work than the standard instrument panel, and blazes new ground. I prefer electrical challenges to mechanical! Let me know if you think I would be better off exchanging the SD20 for an SD8. Your advice to all of us is much appreciated. Jim Foerster Jabiru J400/Jabiru 3300 engine/ 20% done. ________________________________________________________________________________
Subject: Longer handles for PIDG crimper
Date: May 13, 2002
If you are struggling to complete the crimp with the bargain priced RCT-1, which does a great crimp, consider lengthening the handles. It is quite easy. I took 8 inches of 1/2 inch thinwall copper conduit, the same stuff used for making a J comm antenna per Jim Weir's design, and found that it formed onto the tool perfectly. Remove the red plastic grips by using two screwdrivers to pry each side. Then tap the 8 inches of tubing over each tang. If you want to use an end cap, put it on before you tap, and solder it afterwards. Cut the copper tubing to whatever length is most comfortable, but 8 inches should be plenty. The BNC crimper, RCT-2, seems to have the same design and could also be so modified. Jim Foerster ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: sec: unclassified : IFR AVIONICS AGAIN
Date: May 13, 2002
Victor asked if he could use GPS only in US airspace as a lighweight IFR kit. I found guidance in AC 90.94, para 3c which states very clearly that you can only use GPS in US airspace in IFR conditions when you also have a terrestrial navaid fitted and serviceable. This is an advisory circular but it has commanding language on this point. I suspect para 3c is a flow down from a more mandatory requirement in the operational regs somewhere. The GPS installation should follow guidance in AC120-138 (elsewhere incorrectly quoted as 120-38, which talks about ozone). I am having internet problems and cannot read AC120-138 to check it. I have a suspicion that the reason GPS is still not trusted in comparison with old technolgy VOR/ADF systems is that the satellite signal is very very weak. The GPS reciever identifies the satellite signal by some very clever signal processing. The problem seems to be that when conducting an approach over an electronically noisy site, like a big city, stray strong electronic emissions on the right frequency can simply overpower the clever GPS processing and cause inaccurate readouts - a bit like an ADF at sunset you might say. Hope this helps, David Francis, VH-ZEE ________________________________________________________________________________
From: "David A. Leonard" <dleonar1(at)maine.rr.com>
Subject: IFR GPS Manipulation
Date: May 13, 2002
This thread on GPS manipulation is especially interesting to me. I fly a 72 Bellanca Vking, and it has a complement of old VORS and an ADF, and a single axis autopilot. I also have an older Garmin GPS 95 on the yoke, and a new Garmin Colormap 295 up on the passengers side glare shield (due to panel real estate) I just got through a 2 hr instrumanet recurrency ride, and got a lecture on not spending so much time pushing buttons on the GPS. I never took the older unit out as it seems to work well, and it is in my scan. The instructor's observation, as well as mine, was the the old unit, with the complete telephone keypad, is very fast to program identifiers in, the new one is slow and requires a lot of busy work. It has a toggle rocker swithch, and takes a while to get alpha characters input. The database is big. It seems as though this is a case of the simpler technology reducing the workload. If you are cleared to NOXXIS beacon, on the old GPS you just key in the letters, there are enough buttons,each button is three characters.. hit "abc" and you get "B", if you need "c" you hit the right arrow, left arrow for "A"... hit go to, and bam, there's your bearing and range. The new one requires much toggleing and attention.. The new GPS has much more information, frequencies, airport information, etc, and the moving map is a wonderful piece of situational awareness. It seems at it's highest use as a moving map, which is entirely automatic.. turn it on and it graphically displays your position. It is also a heck of a radio guide,, "nearest" will get you the closest ten Airports, or Navaid, or ARTCC frequency.. It is an incredibly useful tool, but it takes almost as much attention as perusing a book.. not what you need to be doing while setting for a hold entry to an instrument approach! My headings seem to wander if I don't have the AP running while diddling the unit. My procedure for IFR with this setup is now, when cleared to a fix, key it into the Garmin 95xl (this is 1995 technology, with a database, still updatable). Assume the heading, this can be done in 20 seconds. Then stabilize the plane, and get the autopilot heading corresponding with the GPS ground track. At this point I start setting up the VORs. Only then can I fool with the 295. Usually the destination airport is set up as the active waypoint, if you want you can pre-program your filed route on the ground. This is very handy as you can see all the intersections, navaids, airports etc. scrolling by on the map, without doing any programming. When the immediate work is done, and you settle into your enroute mode, you can then fool with the fancy GPS. On an approach I set the 95XL for the outer marker, which is usually an NDB(LOM). The ADF went south in the middle of one of my approaches.. I was happy I had the GPS doing its thing! ADF's don't really give much time to react..the GPS is really nice for knowing just how far you are outside the outer marker, as the range information is right there. Once you are on the ILS, you simply watch the ground track on that GPS, keep it on the ILS inbound course, and it will keep the ILS needle pretty much glued in the center.. very helpful with crosswinds on final. The whole time the Garmin 295 is simply set on the moving map page, with the "Track up" mode on. It is really helpful to be able to see the outer marker, and the airport ahead of you. It is also very nice on a radar vector approach to be able to see exactly when you will intercept the localizer, graphically..it gives you al lot of warning as to when the needle is going to start moving, and how far out the controller is aiming you. On the missed the map is very nice for seeing your course to re-intercept. Anyway, these are just my observations, I actually have a hard time keeping IFR current without annual instrument recurrency rides with an instructor. Though it is important to know all of the instrument techniques, I personally only fly ILS approaches...(well I prefer visuals).. I figure that if that is all the scheduled carriers are allowed to fly, with pilots that do it every day, then how can I hope to be more proficient then those guys.. I really like the vertical guidance and Radar vectors..it just seems safer, and there are a lot of ILS approaches available. I'm also one of those 1000 foot AGL minimum people..I just feel like its too hard to practice enough to be current flying to those 200 foot agl minimums as a pilot who doesn't practice at least weekly. That being said, I sure like using the IFR system for any kind of x-country work. And here I sit,new Charts and Rating in hand looking at the weather system, with a huge low centered around Columbus, OH, and my trip scrubbed..thunderstorms, low ceilings, high winds.icing.the front goes from there to Maine where I am.. who needs to be blundering around in a little single engine airplane .... It looks like a good office day.. Dave Leonard N77FE ________________________________________________________________________________
Date: May 13, 2002
I agree that the satellites would be pretty tough to disable by anyone other than the US government. However (sorry if this seems black helicopter-ish), it would be possible (likely?) that our guys disable GPS satellites for tactical reasons - like they don't want someone else using them because they might pose a threat to our own assets (in the form of weapons guidance). I think it somewhat less likely that functioning GPS would provide a threat to us on our home turf (the bad guys have to get the weps onto the continent first - not impossible, but maybe less probable). With that assumption in mind, does anyone have any idea whether GPS can effectively be selectively disabled (over a region or continent)? I suspect that if this capability exists, the US government would choose this option rather than disrupting peaceful users outside the scope of the perceived threat. Matt Prather ----- Original Message ----- From: "Cy Galley" <cgalley(at)qcbc.org> Date: Monday, May 13, 2002 9:01 am Subject: Re: AeroElectric-List: IFR Equipment Required > > But VORs are not guarded. In rural areas they are back away from > the roads > so it is a long walk in. But destroying one is no different than > when the > government takes it out of service for maintenance. > > At present, it is very difficult to hit any satellite as one has to > launch a ________________________________________________________________________________
Date: May 13, 2002
Subject: Re: IFR GPS Manipulation
In a message dated 5/13/02 08:25:02 AM, dleonar1(at)maine.rr.com writes: << If you are cleared to NOXXIS beacon, on the old GPS you just key in the letters, there are enough buttons,each button is three characters.. hit "abc" and you get "B", if you need "c" you hit the right arrow, left arrow for "A"... hit go to, and bam, there's your bearing and range. The new one requires much toggleing and attention.. >> yes, but if you had a "Real" GPS, built in, you could punch "nrst" twice to get the intersections, then select which one you wanted to fly to (usually the one in the window already), then direct to. Your map would point right to the intersection. If you had an approach GPS, it would overlay a course for you to fly on the map window. ________________________________________________________________________________
Date: May 13, 2002
In a message dated 5/13/02 08:30:01 AM, mprather(at)spro.net writes: << With that assumption in mind, does anyone have any idea whether GPS can effectively be selectively disabled (over a region or continent)? I suspect that if this capability exists, the US government would choose this option rather than disrupting peaceful users outside the scope of the perceived threat. >> Yes, the GPS can have it's accuracy altered, or completely turned off, in areas as small as a few hundred square miles. ________________________________________________________________________________
Date: May 13, 2002
Subject: Re: Low Voltage Warning Light
> >When the LR-3 regulator senses low voltage and illuminates the low >voltage warning light, can the light be shut off by pulling the field >breaker (or opening the Alternator switch if you have one)? In a single >alternator system it would be nice to be able to extinguish the light >after you recognize the low voltage situation.... No . . . in fact, the light is designed to illuminate when ALL power is removed from the regulator to annunciate the fact should a problem arise with either or both supply leads to the regulator. The usual technique for turning the light OFF is to kill the main bus and go to e-bus until airport is in sight and then bring the main bus back up if necessary to complete the flight. This minimizes the amount of time one works with the distractions of the lamp flashing. If you want to switch it off you'll need to add a switch to the bulb supply . . . or just unscrew the fixture. You might also consider a dimmable lamp fixture. Bob . . . ________________________________________________________________________________
Date: May 13, 2002
> > >Bob > >In the Z-4 diagram that I am using. The warning lights will light >when the Xfeed/starter is pressed to start or Xfeed position and the >lamp on the LR-3 will light at start do to low voltage. Am I correct >in this thinking? I therefore would not need a press to test button >for these lights. Correct. ________________________________________________________________________________
Date: May 13, 2002
David A. Leonard wrote: > > > The instructor's observation, as well as mine, was the the old unit, with > the complete telephone keypad, is very fast to program identifiers in, the > new one is slow and requires a lot of busy work. It has a toggle rocker > swithch, and takes a while to get alpha characters input. The database is > big. > [...] > > If you are cleared to NOXXIS beacon, on the old GPS you just key in the > letters, there are enough buttons,each button is three characters.. hit > "abc" and you get "B", if you need "c" you hit the right arrow, left arrow > for "A"... hit go to, and bam, there's your bearing and range. The new one > requires much toggleing and attention.. > *** This sounds like a *natural* for voice recognition. Imagine, you press a button on your yoke, and say "Direct Noxxis". A little screen pops up on your GPS with a list of closest matches ( in order of probability: the "Noxxis" that's 5 NM away is more probable than the "Nockit" that's 500 NM away ). You select the right one - whole thing just two or three button presses. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: IFR Equipment Required
Date: May 13, 2002
> In a message dated 5/13/02 08:30:01 AM, mprather(at)spro.net writes: > > << With that assumption in mind, does anyone have any idea whether GPS > can effectively be selectively disabled (over a region or continent)? > I suspect that if this capability exists, the US government would > choose this option rather than disrupting peaceful users outside > the scope of the perceived threat. >> > > Yes, the GPS can have it's accuracy altered, or completely turned off, in > areas as small as a few hundred square miles. > I believe that this demonstrated functionality was a primary reason the government gave when they turned off selective availability a few years ago. I guess they were certain they could turn on SA in some geographical regions when necessary and not affect accuracy in the US. Of course, the govt has never guaranteed us that SA will never be turned on again. ________________________________________________________________________________
Date: May 13, 2002
Subject: Re: Nav Antenna Question
I'm pretty sure that ethernet was 50 ohms, but cable tv is 70-75 ohms. I picked up a 50 ohm terminating resistor with a BNC connector on it at radio shack for 2 or three USD. As long as you're not transmitting INTO it, this is more like what you are looking for. Bernie C. jerry(at)tr2.com wrote: > > > Russ Werner wrote: > > > > On the subject of diplexers, is it okay to not use all of the outputs on the > > diplexer? I have one that is designed to run 2 VOR/LOC receivers and 2 GS > > receivers and I only have one of each. Any problem with capping off the > > extra jacks? > > > *** I suspect that it is OK, but you have to cap them off with 50-ohm loads. > These are just a connector with a 50-ohm resistor built in. Or you can make > your own. The resistor would go from the center pin to the outside of the > connector. This will make the splitter "think" that the receivers it was > designed to drive, are actually connected. > > Also, 75-ohm terminators are really common in high-tech surplus, > because Ethernet used to use them. Probably work fine.... > ________________________________________________________________________________
Subject: Re: IFR GPS Manipulation during Approach
Date: May 13, 2002
Actually, on the Apollo SL60, all I have to do is press nearest, change the list from airports, VORs, NDBs, or intersections and then check to make sure that what I want is the closest (most of the time it is!), then hit the direct to button. Really easy, even when bouncing around in the last parts of the approach. ________________________________________________________________________________
From: "Walter S. Fellows" <fellowsw(at)mondexkorea.com>
Date: May 14, 2002
It can be jammed as well -- there was an incident near Albany NY where an army unit had put a jamming unit in the warehouse and left it on. The location was on one of the major flight paths into NYC and it was causing the airline traffic flying on autopilot to veer of course when it passed by. > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Francis, CMDR David > Sent: Monday, May 13, 2002 3:09 PM > To: 'aeroelectric-list(at)matronics.com' > Subject: AeroElectric-List: sec: unclassified : IFR AVIONICS AGAIN > > > > Victor asked if he could use GPS only in US airspace as a lighweight IFR > kit. > > I found guidance in AC 90.94, para 3c which states very clearly that you > can > only use GPS in US airspace in IFR conditions when you also have a > terrestrial navaid fitted and serviceable. This is an advisory circular > but > it has commanding language on this point. I suspect para 3c is a flow down > from a more mandatory requirement in the operational regs somewhere. > > The GPS installation should follow guidance in AC120-138 (elsewhere > incorrectly quoted as 120-38, which talks about ozone). I am having > internet > problems and cannot read AC120-138 to check it. > > I have a suspicion that the reason GPS is still not trusted in comparison > with old technolgy VOR/ADF systems is that the satellite signal is very > very > weak. The GPS reciever identifies the satellite signal by some very clever > signal processing. The problem seems to be that when conducting an > approach > over an electronically noisy site, like a big city, stray strong > electronic > emissions on the right frequency can simply overpower the clever GPS > processing and cause inaccurate readouts - a bit like an ADF at sunset you > might say. > > Hope this helps, David Francis, VH-ZEE > >
April 28, 2002 - May 13, 2002
AeroElectric-Archive.digest.vol-av
