AeroElectric-Archive.digest.vol-az
June 27, 2002 - July 24, 2002
Date: Jun 27, 2002
Subject: Re: Fuses vs. Breakers exchange - names withheld
In a message dated 6/27/02 04:35:04 AM, mtherr(at)yahoo.com writes: << http://mthobby.pcperfect.com/ch601/daypict.jpg >> you can do that in a homebuilt. What about certified. I'm talking about a Grumman Tiger. The fuses are on the front panel where you can get to them. I personally wouldn't care for a panel that swings down. I'd rather be able to reach a stable panel in flight that isn't flopping around. ________________________________________________________________________________
Date: Jun 27, 2002
But why do we need to be able to reach the panel in flight? --- Aucountry(at)aol.com wrote: > down. I'd rather be able > to reach a stable panel in flight that isn't > flopping around. ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby ________________________________________________________________________________
Date: Jun 27, 2002
In a message dated 6/27/02 09:02:25 AM, mtherr(at)yahoo.com writes: << But why do we need to be able to reach the panel in flight? >> just in case a fuse blows. Coming out of Cammillo one night, it was a little bumpy, I turned on the nav lights and panel lights. I usually like to keep it fairly dark inside. When I went to read a map, I cranked up the panel lights and everythng went totally dark. Fues blown. Hmmm. I turned down the panel lights, replaced the fuse, and tried it again. Lights worked good right up to the max lighting. I replaced the fuse again, and went with partial lighting for the rest of the flight. Nothing worng with the circuit. The rheostat was grounding on the primer line and blowing the fuse at full on. Easy to see when laying on my back under the panel. On another occasion, the landing light fuse would blow after about 40 seconds. This occurred a number of times. I still don't know why. It was a 10 amp fuse. Knowing this, I was able to land, at night, using the landing light until the fuse blew. After landing, i replaced the fuse, While taxing to parking, I would use the landing light intermittently to see where I was going. Again, each time I over used the light, the fuse would blow, easy to replace. A circuit breaker would have been nice. Point is, if a fuse blows, I want to be able to replace it in flight. ________________________________________________________________________________
Date: Jun 27, 2002
I asked because I can acknowledge it is easy to see when a breaker pops off, but not a fuse. As for the panel lighting problem... I'll have panel lights and flood lights (which also illuminate the panel) on two different circuits... of course, I'll also have a battery powered light. For the landing light problem... I'll have two circuits for landing and taxi lights. But according with regulations, landing/taxi are not required unless this is a commercial flight (or is it unless you carry passengers?). You get the idea... I feel that the plane functions do not depend on any single circuit and if a circuit goes, I prefer to look at it once on the ground. The one exception to that is the alternator circuit which will have an OV protection module with a panel circuit breaker (on the field circuit). I am debating in my mind whether I'd like to get a breaker on the normal feed to the e-Bus just to become confident that the loading do not exceed my design load in practice (so I am confident I would not blow the fuse from the battery bus when I run only on the e-bus). Michel --- Aucountry(at)aol.com wrote: > Aucountry(at)aol.com > Coming out of Cammillo one night, it was a little > bumpy, I turned on the nav > lights and panel lights. I usually like to keep it > fairly dark inside. When .... ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby ________________________________________________________________________________
withheld
Date: Jun 27, 2002
If somethings is shorting (rheostat) while in flight, I am not too excited about being able to replace the fuse that powers it. You don't find something like a rheostat shorting to part of the fuel system to be a problem with a circuit? The airplane PROBABLY won't blow up.... I think the idea is to design a fault tolerant system for all missions on which the plane may embark. In the 'dark and (maybe) stormy' scenario that you describe, the system could have been more fault tolerant be allowing you to switch on your alternate source of light, be it through a different circuit wired into the plane (to power a flood?), or one of the flashlights that you carry. Carrying two is a good idea. Working on my electrical system while flying at night is not one of the better ways for me to maintain situational awareness, in my opinion. As Bob has pointed out in the past, if you are flying something that is already certified, you are likely stuck with a system NOT designed to be fault tolerant. In that case, I can understand the need to be able to accomplish repairs while underway, though it doesn't make me happy. Turning up the flood to read a chart shouldn't make 'everything' go dark in a well designed system. You can pull over to the side while in your car. That's less convenient in an airplane. Matt Prather. ----- Original Message ----- From: Aucountry(at)aol.com Date: Thursday, June 27, 2002 10:25 am Subject: Re: AeroElectric-List: Fuses vs. Breakers exchange - names withheld > > > In a message dated 6/27/02 09:02:25 AM, mtherr(at)yahoo.com writes: > > << But why do we need to be able to reach the panel in flight? >> > > just in case a fuse blows. > > Coming out of Cammillo one night, it was a little bumpy, I turned > on the nav > lights and panel lights. I usually like to keep it fairly dark > inside. When > I went to read a map, I cranked up the panel lights and everythng > went > totally dark. Fues blown. Hmmm. I turned down the panel lights, > replaced > the fuse, and tried it again. Lights worked good right up to the > max > lighting. I replaced the fuse again, and went with partial > lighting for the > rest of the flight. Nothing worng with the circuit. The rheostat > was > grounding on the primer line and blowing the fuse at full on. Easy > to see > when laying on my back under the panel. > > On another occasion, the landing light fuse would blow after about > 40 > seconds. This occurred a number of times. I still don't know why. > It was a > 10 amp fuse. Knowing this, I was able to land, at night, using the > landing > light until the fuse blew. After landing, i replaced the fuse, > While taxing > to parking, I would use the landing light intermittently to see > where I was > going. Again, each time I over used the light, the fuse would > blow, easy to > replace. A circuit breaker would have been nice. > > Point is, if a fuse blows, I want to be able to replace it in flight. > > ________________________________________________________________________________
Date: Jun 27, 2002
Subject: Re: RV-List: Blue Mountain
The PCFlightsystems iPAQ based PCEFIS and EPANEL appear to be direct competitors to the BlueMountain system- The EPANEL would be a single source failure item but the PCEFIS could be (according to the mfgr.) used on duplicate iPAQ's, one for EFIS and one for GPS mapping, switchable between them for some redundancy, at least for the display. Their website shows such a configuration. See: http://pcflightsystems.com/ Has anyone here investigated these or have any actual flight experience with them? I am considering using these (two iPAQ's) with a separate engine monitor, airspeed indicator and altimeter plus separate fuel gauges in my VFR panel with handheld backup (com & GPS) of course... From the PossumWorks Mark - panel planning Michael Stephan wrote: > Single point failure is something to consider, especially if it happens > during a flight. ________________________________________________________________________________
Subject: Fuses vs. Breakers exchange - nameswithheld
Date: Jun 27, 2002
Interesting discussion. I like the dual alt/dual batt electrical system for ultimate fault tolerance. I agree with many of you that the pilot should be FLYING while airborne and should save the MAINTENANCE until on the ground. A properly designed system will allow you to continue the flight without the NEED to change any fuses or reset any cb's. I swerve slightly however, and come down on the side of the cb in the cockpit simply for pilot awareness. The popped cb tells me exactly what the problem is so I can continue the flight COMFORTABLY with that knowledge. Incidentally, I would NEVER put cb's on my instrument panel! What a colossal waste of precious space. Mine will be mounted along the kick panels next to my legs and angled so that the white band of a popped cb as well as its label will be easily seen with a quick glance. I'm new to the list, but have enjoyed all of your comments & suggestions thoroughly! Thanks. Jon Hults -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of mprather(at)spro.net Subject: Re: AeroElectric-List: Fuses vs. Breakers exchange - nameswithheld If somethings is shorting (rheostat) while in flight, I am not too excited about being able to replace the fuse that powers it. You don't find something like a rheostat shorting to part of the fuel system to be a problem with a circuit? The airplane PROBABLY won't blow up.... I think the idea is to design a fault tolerant system for all missions on which the plane may embark. In the 'dark and (maybe) stormy' scenario that you describe, the system could have been more fault tolerant be allowing you to switch on your alternate source of light, be it through a different circuit wired into the plane (to power a flood?), or one of the flashlights that you carry. Carrying two is a good idea. Working on my electrical system while flying at night is not one of the better ways for me to maintain situational awareness, in my opinion. As Bob has pointed out in the past, if you are flying something that is already certified, you are likely stuck with a system NOT designed to be fault tolerant. In that case, I can understand the need to be able to accomplish repairs while underway, though it doesn't make me happy. Turning up the flood to read a chart shouldn't make 'everything' go dark in a well designed system. You can pull over to the side while in your car. That's less convenient in an airplane. Matt Prather. = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Jun 27, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >In a message dated 6/27/02 04:35:04 AM, mtherr(at)yahoo.com writes: > ><< http://mthobby.pcperfect.com/ch601/daypict.jpg >> > >you can do that in a homebuilt. What about certified. I'm talking about a >Grumman Tiger. The fuses are on the front panel where you can get to them. >I personally wouldn't care for a panel that swings down. I'd rather be able >to reach a stable panel in flight that isn't flopping around. Got a reader in Florida working on a Grumman refurbish that will feature the fuseblocks, e-bus, dual alt, etc. His goal is to put it in under a Form 337 field approval. Will let everyone know how it works out, if it works out. There's no scientific reason for it not to but . . . well . . . . 'nuf said. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jun 27, 2002
> > >In a message dated 6/27/02 09:02:25 AM, mtherr(at)yahoo.com writes: > ><< But why do we need to be able to reach the panel in flight? >> > >just in case a fuse blows. >On another occasion, the landing light fuse would blow after about 40 >seconds. This occurred a number of times. I still don't know why. It was a >10 amp fuse. Knowing this, I was able to land, at night, using the landing >light until the fuse blew. After landing, i replaced the fuse, While taxing >to parking, I would use the landing light intermittently to see where I was >going. Again, each time I over used the light, the fuse would blow, easy to >replace. A circuit breaker would have been nice. > >Point is, if a fuse blows, I want to be able to replace it in flight. Wouldn't it be better to fix the reason it is blowing? And what are you going to do when the light bulb burns out? They always do it just when you first turn them on . . . just before you need it. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2002
> >I asked because I can acknowledge it is easy to see >when a breaker pops off, but not a fuse. When passive failures (fuse doesn't pop) outnumber active failures (fuse pops) then what is the relative value of having a fuse or breaker be able to annunciate the fact that the system is dead due to overload? The system is just as useless either way. >As for the panel lighting problem... I'll have panel >lights and flood lights (which also illuminate the >panel) on two different circuits... of course, I'll >also have a battery powered light. Plan B backs up Plan A . . . good design not found on most certified ships. >For the landing light problem... I'll have two >circuits for landing and taxi lights. But according >with regulations, landing/taxi are not required unless >this is a commercial flight (or is it unless you carry >passengers?). But what are YOUR requirements? If you intend to have lighting useful for landing at night irrespective of the condition of any single, forward shining lamp, then two systems are dictated. Many of my builders have used hi/lo beam automotive headlight lamps so that there is a spare filament in each fixture . . . even if the second one doesn't point exactly the right direction, it's a whole lot better than no light. >You get the idea... I feel that the plane functions do >not depend on any single circuit and if a circuit >goes, I prefer to look at it once on the ground. The >one exception to that is the alternator circuit which >will have an OV protection module with a panel circuit >breaker (on the field circuit). > >I am debating in my mind whether I'd like to get a >breaker on the normal feed to the e-Bus just to become >confident that the loading do not exceed my design >load in practice (so I am confident I would not blow >the fuse from the battery bus when I run only on the >e-bus). Don't understand . . . are you concerned that the diode may fail? This is tested on every pre-flight. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2002
Subject: RE: Fuses vs. Breakers exchange
> > >Interesting discussion. I like the dual alt/dual batt electrical system >for ultimate fault tolerance. I agree with many of you that the pilot >should be FLYING while airborne and should save the MAINTENANCE until on >the ground. A properly designed system will allow you to continue the >flight without the NEED to change any fuses or reset any cb's. > >I swerve slightly however, and come down on the side of the cb in the >cockpit simply for pilot awareness. The popped cb tells me exactly what >the problem is so I can continue the flight COMFORTABLY with that >knowledge. Spent the whole day today in a "Red Team" meeting where a good customer with a lot of airplanes has his shorts in a bunch. Seems a low-rate but persistent nuisance trip of a warning system will sometimes result in a scrubbed mission or putting an airplane down away from home field. In the later case, passengers and crew of the afflicted airplane have to by commercial tickets. Technicians and other pilots have to fly commercial to recover the airplane. I've participated in hundreds of problem-solving efforts over the years involving systems that draw everything from milliamps to hundreds of amps from ship's power. I've witnessed gawd-awful burned up motors, contactors and power supplies. There have been plenty of microprocessors that wandered off to la-la land. I cannot remember one case where the problem to be solved first made its presence known by popping a breaker. The ones that popped breakers were fixed by the mechanics (they found the shorted wire or hard-fault failed component). The problems that don't pop breakers (aside from wires that came loose) are often the hardest to fix and they greatly outnumber problems that do pop breakers. This is the way most radios fail and it always means a trip to the shop. I am mystified by any notion of comfort to be derived from knowing or not knowing that a fuse/breaker is open or not open. Many of our new designs on the big ships use remotely controlled breakers driven by flight systems management computers. When a system mis-behaves, we light a lamp anyhow to tell a pilot the thing isn't working. He doesn't know and couldn't care less as to why. We don't have to annunciate "AFT COMPRESSOR RCB OPEN" . . . his pax are already telling him, "it's hot back here!" Popped breakers were not mentioned in today's meeting either but I have taken notice of an delta-p switch built and certified with 30 year old, very process sensitive technology. Few people have the skill and patience to make this product work well today. It's time to do a simpler, no-moving parts upgrade . . . just like swapping out all those breakers and a bizillion threaded fasteners and lock-washers for the little plug-in block of plastic with only one part . . . and it doesn't move. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2002
Subject: Re: RE: Fuses vs. Breakers exchange
>.Many of our > new designs on the big ships use remotely controlled > breakers driven by flight systems management > computers. When a system mis-behaves, we > light a lamp anyhow to tell a pilot the thing isn't > working. He doesn't know and couldn't care less > as to why I'm told the C-130-J has a virtual breaker system controlled by a touch screen LCD. One of the virtual breakers powers the screen itself. When you "pull" that breaker the plane is down till you reload the operating system. ________________________________________________________________________________
Subject: Audio panel
Date: Jun 27, 2002
Hello Rob, You might want to look at rst-engr.com for their audio panel. It is cheap, a kit, and allows all those neat things at 20 percent of the price of a UPS or King panel. It is priced well with the marker beacon built in. A recent conversation with Jim Weir he stated that the latest circuit board is coming out in time for Oshkosh and builds in half the time. Just my 2 cents. Kev << Do I really need the cost/failure point/complexity of an audio panel? Suggestions from the guru, Bob), and the collective wisdom of the list will be much appreciated. >> I've asked myself this same question a number of times. In todays GA airplanes, there really isn't much need for DME, ADF, 3 Navs, 3 Coms, AUX, or a host of the bells and whistles included in the lasted audio panels from Garmin, UPS, etc. What I need most is a 4-place intercom (doesn't need to be stero) that has marker beacon, and 2 coms. Maybe 1 Nav. I don't really care if the copilot can talk on one freq, while I talk on the other one either. ________________________________________________________________________________
Date: Jun 27, 2002
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Fuses vs. Breakers exchange --> > > >Interesting discussion. I like the dual alt/dual batt electrical system >for ultimate fault tolerance. I agree with many of you that the pilot >should be FLYING while airborne and should save the MAINTENANCE until >on the ground. A properly designed system will allow you to continue >the flight without the NEED to change any fuses or reset any cb's. > >I swerve slightly however, and come down on the side of the cb in the >cockpit simply for pilot awareness. The popped cb tells me exactly >what the problem is so I can continue the flight COMFORTABLY with that >knowledge. I am mystified by any notion of comfort to be derived from knowing or not knowing that a fuse/breaker is open or not open. Many of our new designs on the big ships use remotely controlled breakers driven by flight systems management computers. When a system mis-behaves, we light a lamp anyhow to tell a pilot the thing isn't working. He doesn't know and couldn't care less as to why. We don't have to annunciate "AFT COMPRESSOR RCB OPEN" . . . his pax are already telling him, "it's hot back here!" Popped breakers were not mentioned in today's meeting either but I have taken notice of an delta-p switch built and certified with 30 year old, very process sensitive technology. Few people have the skill and patience to make this product work well today. It's time to do a simpler, no-moving parts upgrade . . . just like swapping out all those breakers and a bizillion threaded fasteners and lock-washers for the little plug-in block of plastic with only one part . . . and it doesn't move. Bob . . . OK Bob, fuse or cb.....my only point was that IF you get a failure/malfunction that DOES pop the breaker or blow the fuse, I'd like to be able to physically SEE which one it was. Also, if you could see the fuse box or cb panel from the cockpit and they were all still intact, wouldn't you at least know more than you did before about the failure? ...and wouldn't that be of some value? (...like whether the offending circuit still has power). Jon = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Jun 27, 2002
> OK Bob, fuse or cb.....my only point was that IF you get a > failure/malfunction that DOES pop the breaker or blow the fuse, I'd like > to be able to physically SEE which one it was. Just out of interest, I bought a interesting set of fuses at an automotive store. Each fuse has an LED which glows when the fuse is blown. John Slade Cozy IV ________________________________________________________________________________
Date: Jun 27, 2002
John, Still early days for me, I took Bob's seminar last weekend in Watsonville and it was excellent so I've started lurking here just to figure out what the issues are I should be thinking about when I come to plan my panel. I'm already sold on the idea of fuses vs CBs however it could be helpful to know that a fuse has blown and the LEDs could help. Do you recall the manufacturer or store where you got them? Thanks, Tony ----- Original Message ----- From: "John Slade" <sladerj(at)bellsouth.net> Subject: RE: AeroElectric-List: RE: Fuses vs. Breakers exchange > > > OK Bob, fuse or cb.....my only point was that IF you get a > > failure/malfunction that DOES pop the breaker or blow the fuse, I'd like > > to be able to physically SEE which one it was. > Just out of interest, I bought a interesting set of fuses at an automotive > store. Each fuse has an LED which glows when the fuse is blown. > John Slade > Cozy IV > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jun 27, 2002
Auto Zone carries them here. R ----- Original Message ----- From: "Tony Babb" <tonybabb(at)alejandra.net> Subject: Re: AeroElectric-List: RE: Fuses vs. Breakers exchange > > John, > > Still early days for me, I took Bob's seminar last weekend in Watsonville > and it was excellent so I've started lurking here just to figure out what > the issues are I should be thinking about when I come to plan my panel. > > I'm already sold on the idea of fuses vs CBs however it could be helpful to > know that a fuse has blown and the LEDs could help. Do you recall the > manufacturer or store where you got them? > > Thanks, > > Tony > ----- Original Message ----- > From: "John Slade" <sladerj(at)bellsouth.net> > To: > Subject: RE: AeroElectric-List: RE: Fuses vs. Breakers exchange > > > > > > > > OK Bob, fuse or cb.....my only point was that IF you get a > > > failure/malfunction that DOES pop the breaker or blow the fuse, I'd like > > > to be able to physically SEE which one it was. > > Just out of interest, I bought a interesting set of fuses at an automotive > > store. Each fuse has an LED which glows when the fuse is blown. > > John Slade > > Cozy IV > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Torx, schmorx
Date: Jun 27, 2002
Cheers, 'OC', Your message reads, in part: "Some background: Recently a fellow builder in a posting to a web based group that I belong to expressed his complete disgust with Phillips drive screws. I responded that there were superior alternatives such as hex socket, Torx, and Torx Plus drive screws that were being used in modern aerospace vehicles, but that it was very difficult to find and expensive to buy such screws in small quantities for our use." Actually it was me. I had just stripped another @#$% & Philips head screw, attempting to loosen it, and sent out a very calming and soothing flamer to all and sundry complaining that Henry Ford wanted control of the fabulous Robertson screw ("square-drive", to the teenager who writes the catalog descriptions) of 1908. Since it originated in Milton Ontario - about ten miles away - is superior in every way to the @$% Philips and is easily the best-automated screw to be driven to say nothing of cheeeap to produce, the venting of my spleen had a most rehabilitating effect. However, the subsequent stream of conciousness which followed, began to diverge to Torx, and several other attempts to simulate the Robertson. This tended to complicate a very simple point. When Henry couldn't power the factory away from an equally self-impressed Robertson, Henry dropped the idea and adopted Harry Philips' inferior design and the pressured War department made it the darling of the forces by specifying for the Army Air Force as the build up to war in the late 1930's began. Thus the Philips (@#$% ) became an "army-navy" AN part number and the Robertson forgotten. My only rant was that it cost thousands of man-hours of wasted energy in substituting the @#$% & for the Prince of Screws. As a result, Philiups died rich, Robertson blundered into obscurity and the Milton plant closed when an American company bought the rights and produces millions Of R'son screws today mainly for the Canadian market. Mark my words, the R'son is coming your way, and its qualities are superior in every way. It is much cheaper, better formed, can be hoisted onto work by its driver, produces more torque than any but the most sophisticated device, and can be unscrewed without fail. I defy anyone to install a slotted or P'head downward with one hand. For those who doubt my words, please contact the History channel for a one-hour program regarding the story of this simple, elegant invention. Best of intentions, ferg Europa A064 ________________________________________________________________________________
Date: Jun 27, 2002
> > > >.Many of our > > new designs on the big ships use remotely controlled > > breakers driven by flight systems management > > computers. When a system mis-behaves, we > > light a lamp anyhow to tell a pilot the thing isn't > > working. He doesn't know and couldn't care less > > as to why > >I'm told the C-130-J has a virtual breaker system controlled by a touch >screen LCD. One of the virtual breakers powers the screen itself. When >you "pull" that breaker the plane is down till you reload the operating >system. Software by Microsoft no doubt . . . Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jun 27, 2002
> > >OK Bob, fuse or cb.....my only point was that IF you get a >failure/malfunction that DOES pop the breaker or blow the fuse, I'd like >to be able to physically SEE which one it was. Also, if you could see >the fuse box or cb panel from the cockpit and they were all still >intact, wouldn't you at least know more than you did before about the >failure? ...and wouldn't that be of some value? (...like whether the >offending circuit still has power). > >Jon How does that information help you as a pilot to do your best at comfortable completion of that particular flight? The first indication that anyone gets for a malfunction is that some expected event didn't happen when a switch was moved, perhaps the flag drops on an indicator, or the thing just quietly dies (like comm radios . . . I've had them quit and it took some time to realize that I wasn't hearing anyone for a long time when the frequency HAD been pretty busy earlier). Once you've deduced that some equipment item is not working, of what value is it to know anything about why? If that's a really handy piece of equipment, you've undoubtedly got a backup. In any case, life trundles on without it until you're in a position to really do something about it. Bob . . . ________________________________________________________________________________
Date: Jun 27, 2002
Subject: Re: Van's ammeter FYI
Robert L. Nuckolls, III wrote: > > >> >>hi listers, >>I found out the hard way, and by good luck, that what seems to be the >>logical way to wire up this meter dosn't work. >> >>I am using the main bus/essential bus scheme promoted by Bob Nuckolls. >>The two busses are connected by a big diode. These are electronic gauges >>and get a power and ground in addition to the sense pin(s). It seems >>logical to power the gauges, including the ammeter, from the essential >>bus but this dosn't work for the ammeter, the meter will show a huge >>discharge. Moving the ammeter power lead to the main bus will fix it. >> >>I think that the problem is that the 1 volt drop across the diode causes >>the sense pins to be at a higher voltage than the power source which >>boggles the circuit. >> > > Hmmm . . . is there any place on the net I can see the installation > schematic for this product? Or can you fax me a copy? > > Bob . . . > > It's nothing fancy. +12 on the "I" pin, ground on the "G" pin and the "+" and "-" pins go to the shunt. The shunt is only a few millivolts below the battery voltage and the essential bus is one diode drop below the battery voltage. So if the "I" pin is on the essential bus it is below the shunt voltage. On the main bus it is above the shunt voltage. Jim Bean > > > > > > ________________________________________________________________________________
Date: Jun 27, 2002
Subject: Re: Torx, schmorx
I grow entirely weary of the ongoing diatribes about peoples inability to drive a simple screw. For seventy years, the military has build and maintained aircraft with Phillips screws. Yes, it does require the dexterity of an 18 yr old conscripted PFC mechanic. Perhaps that is too much to ask. I submit that there are far more important issues to address. ________________________________________________________________________________
Date: Jun 28, 2002
> Auto Zone carries them here. Right. That's where I got them. John Slade ________________________________________________________________________________
Date: Jun 27, 2002
Subject: Re: Keeping things simple.
> > >On Thursday, June 27, 2002, at 12:08 AM, richard(at)riley.net wrote: > > > I've already got the 2 place intercom that I need. I just need switches > > to > > xmit on com 1 or 2, and listen to com 1, com 2 and nav. Anybody got a > > diagram I can use? > > > >Richard--I assume you're using a UPS sl-30. I really think -that- one >radio will do everything you want without external switches. The ability >to monitor the standby frequency effectively gives you the functionality >(in single pilot ops anyway) of two comm radios. > >You can obviously monitor the nav side, but with the radio's ability to >decode and display the identifier, you don't need to do that except to >listen to flight service on the VOR (Realistically, with widespread AWOS >and Flightwatch, when was the last time you actually used the nav audio >except to identify a station...on a checkride). > >There isn't AFAIK anything to listen to on GPS so you don't need to >monitor that. > >Take the money you had budgeted for a second comm and audio panel and >spend it on a "tuck and roll" upholstery job in TJ. You're right, with the SL30 decoding NAV I don't need to listen to it, but I already have both the SL30 and a GX60, so I'm at least going to have to be able to pick Xmit 1 or 2. I'm figuring on the GX as primary com since it interfaces so nicely with it's database. ________________________________________________________________________________
Subject: Keeping it simple, revisited
Date: Jun 28, 2002
Richard, > You have a UPS-SL30 and GX60, and need two switched inputs, as well as music > capability, and four place intercom. The PS Engineering PMA4000 is small, > can fit in a 2.5 inch hole or use a rectangular faceplate, and has an > excellent squelch system. It will automute the music fed into it during > radio transmission. Eastern Avionics has them for $675, and you may be able > to find it cheaper. This would be a small, neat installation that does > everything that you want. > Jim Foerster ________________________________________________________________________________
From: "Walter S. Fellows" <fellowsw(at)mondexkorea.com>
Subject: CBs vs Breakers
Date: Jun 28, 2002
I generally agree with the thread on leaving the troubleshooting to the ground. However I can remember several times in my 210 when I was going a little too fast and extended the flaps which caused the breaker to pop. You know what the problem is, slow down, reset the breaker and extend the flaps the remainder of the way. It is probably a similar situation for gear extension in a Lancair IV or Stallion. So, I lean on the side of CBs in view (maybe with a little head twisting) in the kick panels (z-14, dual bus, dual battery, dual alternator, dual cb panels, one panel on each side of the airplane, replace one battery each annual). My $.02. Walter Fellows ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Re: CBs vs Breakers
Date: Jun 28, 2002
Walter's comments: 1. I generally agree with the thread on leaving the troubleshooting to the ground.... 2. I can remember several times in my 210 when I was going a little too fast and extended the flaps which caused the breaker to pop. You know what the problem is, slow down, reset the breaker and extend the flaps the remainder of the way.... No problem with Walter's first comment above. The logic of Bob's design philosophy is that maintenance items are handled at the destination. I have a problem with Walter's second statement. He did not have equipment problems. He had a problem with piloting technique. Since it was so easy to reset the breaker he did not have to face the recurring problem of excessive approach speeds. It was so quick that he didn't even have to think about it - so he didn't. With modern designs and modern equipment a failed circuit requires contemplation (on the ground). There was a good article in Sport Aviation recently. It suggested that we fly occasionally with a friend whereby you alternate PIC duties on each leg of the trip. The thesis was that you will be a better pilot due to the basic competitive nature of people. The author used the analogy of golfing with a friend - where winning shouldn't matter. ________________________________________________________________________________
Date: Jun 28, 2002
Several issues--- I have had several fuses in cars and electronic devices that fatigue fractured. I can't believe this is a rare occurrence. I can't say CBs are better, but fuses have their own problems. Perhaps anti-vibration mounting for fuses should be considered. CBs are made in many varieties. The best ones to use are electro-hydraulic (NOT thermal). They double as switches, of course. This can make the wiring much simpler which makes up for their increased weight. The on-off cycle ratings are now about the same as regular switches. Some cute things can be built easily into the CB such as alarms and blinking lamps on trip. Eric M. Jones (Glastar #5540) ________________________________________________________________________________
Date: Jun 28, 2002
I think vibration should be a consideration for mounting anything in an airplane. Four cylinder aircraft engines are especially bad as far as vibration. And survivability of systems should some part of the engine/propellor come apart should also at least be considered. They guys that race o-200 safety cable the engine to the airframe because their propellors are prone to failure with the blad twist and RPM that they run. Pointing out that fuses are susceptible to vibration damage is a interesting, as they seem like they might be pretty immune. Have you had failures with ATC (blade) style fuses, or just the glass tube type? Matt Prather. ----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Date: Friday, June 28, 2002 12:03 pm Subject: AeroElectric-List: Re: CBs vs Breakers > > Several issues--- > > I have had several fuses in cars and electronic devices that fatigue > fractured. I can't believe this is a rare occurrence. I can't say CBs > are better, but fuses have their own problems. Perhaps anti-vibration > mounting for fuses should be considered. > > CBs are made in many varieties. The best ones to use are > electro-hydraulic (NOT thermal). They double as switches, of course. > This can make the wiring much simpler which makes up for their > increasedweight. The on-off cycle ratings are now about the same as > regularswitches. Some cute things can be built easily into the CB > such as > alarms and blinking lamps on trip. > > Eric M. Jones (Glastar #5540) > > > _- > - The AeroElectric-List Email Forum - > _- > !! NEW !! > _- > List Related Information > _- > ======================================================================= > > > > > ________________________________________________________________________________
Date: Jun 28, 2002
Eric, You tantalize us - tell us more about the "electro-hydraulic" CBs and source(s), please. David Carter ----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Subject: AeroElectric-List: Re: CBs vs Breakers > > Several issues--- > > I have had several fuses in cars and electronic devices that fatigue > fractured. I can't believe this is a rare occurrence. I can't say CBs > are better, but fuses have their own problems. Perhaps anti-vibration > mounting for fuses should be considered. > > CBs are made in many varieties. The best ones to use are > electro-hydraulic (NOT thermal). They double as switches, of course. > This can make the wiring much simpler which makes up for their increased > weight. The on-off cycle ratings are now about the same as regular > switches. Some cute things can be built easily into the CB such as > alarms and blinking lamps on trip. > > Eric M. Jones (Glastar #5540) ________________________________________________________________________________
Date: Jun 29, 2002
You are quite right about the problem being bad piloting technique. Is there a pilot around who has never suffered a bout of bad piloting technique? So is the penalty a no flaps or partial flaps landing? No big deal because we a trained to do that but what if your intended airport has short runways.?. Do you really want to divert to another airport as a result to be as slave to some principle of design? I have heard Bob say many times that you have to practically consider each situation instead of slavishly follow a rule or principal. As for the flying pilot non flying pilot approach, I have been riding in the cockpit of a 777 on approach when the alarm bell went off. Of course there was a fp and nfp. It came from trying to extend flaps while the spoilers were deployed. Bad pilot technique. Sure. Big problem, no because of Boeing's design. Several airline pilots confessed to me that they have done the same thing. An electric flap system or electric gear system should be protected by a breaker within reach of the pilot. Or there should be some other method for dealing with this problem. Walter Fellows > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells > Sent: Friday, June 28, 2002 9:36 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: CBs vs Breakers > > > > Walter's comments: > 1. I generally agree with the thread on leaving the troubleshooting to > the > ground.... > 2. I can remember several times in my 210 when I was going a little too > fast and extended the flaps which caused the breaker to pop. You know > what > the problem is, slow down, reset the breaker and extend the flaps the > remainder of the way.... > > No problem with Walter's first comment above. The logic of Bob's design > philosophy is that maintenance items are handled at the destination. > > I have a problem with Walter's second statement. He did not have > equipment > problems. He had a problem with piloting technique. Since it was so easy > to reset the breaker he did not have to face the recurring problem of > excessive approach speeds. It was so quick that he didn't even have to > think about it - so he didn't. With modern designs and modern equipment a > failed circuit requires contemplation (on the ground). > > There was a good article in Sport Aviation recently. It suggested that we > fly occasionally with a friend whereby you alternate PIC duties on each > leg > of the trip. The thesis was that you will be a better pilot due to the > basic competitive nature of people. The author used the analogy of golfing > with a friend - where winning shouldn't matter. > > > = > = > = http://www.matronics.com/browselist/aeroelectric- > list > = > > ________________________________________________________________________________
Date: Jun 28, 2002
Shouldn't there be a way to torque limit a flap motor without making it blow its circuit protection (like a window motor)? The main circuit protection (breaker or fuse) certainly can protect the device that it powers, but it should maybe more protect the wire that connects to it. I think I have read Bob reference a thermal limiter that is self "automatic?" So maybe the scenario should be that the system is designed with a fuse large enough to support the current load that the device it powers can safely demand for ultimate circuit protection, and a current limiter in the motor system. Then if you are a little ham-fisted with the flap application the system does a soft shutdown for a moment until it cools off (hopefully allowing you to contemplate your actions for a moment), and then you get a chance to try again. If you are really persisten then the flaps just don't get lowered because the device stays in its current limiter mode. If you have a shorting failure in the motor, controller, or wire, then its blows a fuse, you stop making sparks with it by trying to reset it repeatedly, and you don't get to make more fireworks with it again until you make a landing somewhere and can get to the fuse panel. I suppose you could wire an anunciator to the limiter to indicate when its in limiter mode so that you can know when you will have more success. Probably won't find something like this on a C210 any time soon... Does anyone know whether the C210 flap breaker was designed to protect the structure?? There are lots of other things you could do that would overstress the airframe... If you need more reliability - ie its impractical to design a redundant wing flap mechanism, then maybe the thing should be mechanical to start with. I could imagine that might be a consideration if you operate in Alaska where long, smooth, no flapper landing strips might be further away than your mission endurance. The idea of trading off PIC duties is a good one. I have a buddy who flies with me and isn't current, and I think I am going to get on him about this so we can get sharper. Matt Prather. ----- Original Message ----- From: "Walter S. Fellows" <fellowsw(at)mondexkorea.com> Date: Friday, June 28, 2002 5:29 pm Subject: RE: AeroElectric-List: CBs vs Breakers > > You are quite right about the problem being bad piloting technique. Is > there a pilot around who has never suffered a bout of bad piloting > technique? So is the penalty a no flaps or partial flaps landing? > No big > deal because we a trained to do that but what if your intended airport > has short runways.?. Do you really want to divert to another > airport as > a result to be as slave to some principle of design? I have heard Bob > say many times that you have to practically consider each situation > instead of slavishly follow a rule or principal. > > As for the flying pilot non flying pilot approach, I have been > riding in > the cockpit of a 777 on approach when the alarm bell went off. Of > coursethere was a fp and nfp. It came from trying to extend flaps > while the > spoilers were deployed. Bad pilot technique. Sure. Big problem, no > because of Boeing's design. Several airline pilots confessed to me > thatthey have done the same thing. > > An electric flap system or electric gear system should be protected > by a > breaker within reach of the pilot. Or there should be some other > methodfor dealing with this problem. > > Walter Fellows > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > > aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Kells > > Sent: Friday, June 28, 2002 9:36 PM > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: CBs vs Breakers > > > > > > > > Walter's comments: > > 1. I generally agree with the thread on leaving the > troubleshootingto > > the > > ground.... > > 2. I can remember several times in my 210 when I was going a > littletoo > > fast and extended the flaps which caused the breaker to pop. You > know> what > > the problem is, slow down, reset the breaker and extend the flaps > the> remainder of the way.... > > > > No problem with Walter's first comment above. The logic of Bob's > design > > philosophy is that maintenance items are handled at the destination. > > > > I have a problem with Walter's second statement. He did not have > > equipment > > problems. He had a problem with piloting technique. Since it > was so > easy > > to reset the breaker he did not have to face the recurring > problem of > > excessive approach speeds. It was so quick that he didn't even have > to > > think about it - so he didn't. With modern designs and modern > equipment a > > failed circuit requires contemplation (on the ground). > > > > There was a good article in Sport Aviation recently. It suggested > that we > > fly occasionally with a friend whereby you alternate PIC duties on > each > > leg > > of the trip. The thesis was that you will be a better pilot due to > the > > basic competitive nature of people. The author used the analogy of > golfing > > with a friend - where winning shouldn't matter. > > > > > > > > > > > > ________________________________________________________________________________
Date: Jun 28, 2002
Subject: Re: Keeping it simple, revisited
> > >Richard, > > You have a UPS-SL30 and GX60, and need two switched inputs, as well as >music > > capability, and four place intercom. The PS Engineering PMA4000 is >small, > > can fit in a 2.5 inch hole or use a rectangular faceplate, and has an > > excellent squelch system. It will automute the music fed into it >during > > radio transmission. Eastern Avionics has them for $675, and you may >be able > > to find it cheaper. This would be a small, neat installation that >does > > everything that you want. > > Jim Foerster I only have 2 seats, and I already have a DRE 244e. It has a terrific music mute and squelch. So I'm back to... Someone have a circuit diagram of how to use a couple of toggle switches to control 2 radios in and out? ________________________________________________________________________________
Date: Jun 28, 2002
I think one factor that has not been mentioned is that each and every one of you have experience with the automotive fuses that are proposed (not the glass ones, but the ATO blade type) in the cars we drive. When was the last time you had a fuse blow on your lights or radios, unless you were fooling around with the wiring, or you had a poor trailer hookup? Everybody likes to give their experience stories - well, mine is that I've driven several internal combustion cars on bad roads (vibration prone) for a long, long time (more than I can remember) with zero blade fuse failures. Do you even bother to carry spare fuses in your car? Has it ever really been a problem? Some might, but the folks I know seem to share the same experience as me. If you do the MATH you won't have nuisance trips. I say this because for a while I was enamored with polyfuses (you can search the archives for the email exchanges) because they don't even need to be replaced, but really, if they are properly chosen, neither do fuses unless your equipment fails. They only protect the wires against much more expensive equipment going haywire. What if the expensive equipment does actually fail - which perhaps has a MTBF of 2,000 hours? Then, you get to put in a new $1.00 fuse with your $500-$2000 and up failed piece of equipment. I resisted for a while, but the fuse blocks and a conservative approach on sizing them means I wont be worried about the failure of a fuse, but the failure of some of the other components, the most unreliable of which is always the pilot by several orders of magnitude. Gary Liming ________________________________________________________________________________
Date: Jun 28, 2002
I did not realize reading Bob's text how compact a blade fuse installation can be. This evening, I wired my fuse panel and I am pretty impressed with the number of wires coming out of it! See: http://mthobby.pcperfect.com/ch601/daypict.jpg 22 circuits, main bus feed, ess bus feed and alternator field (not yet connected). All on a panel 10"X6" that will take 0"X0" of instrument panel space. Michel ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby ________________________________________________________________________________
Subject: Subject: CBs vs Breakers
Date: Jun 29, 2002
Cheers, My $0.02 refers to Ernest Kells's message on the subject today. I suggest a second reading as it is the wisest bit of advice seen in a while. Airline experience is often a 'behaviour revision' endeavour because of one airline company's attitude toward a procedure. The battle becomes a contest between thoise who build and those who operate aircraft. Ernest hit the nail on the head IMHO. A 'rescue' procedure creates the tendency to be tested regularly rather than avoiding the need for rescue in the first place. His analogy to golf (tennis, etc) is pure logic. Two heads are better than one is the basis for having a buddy look over your work in building, too. FWIW, Ferg Europa A064 ________________________________________________________________________________
From: "Brian & Debi Shannon" <wings(at)theshannons.net>
Subject: GNS 430 Current Draw
Date: Jun 29, 2002
Hi All, Does anyone know the approximate current draw for the Garmin GNS 430 or 530...trying to do a load analysis and haven't found any info on their website or in the online users manual! Also - is there anyone out there planning on going with EFIS/One and trying to put it on an SD-8 powered essential bus? Just curious what others have come up with....I know Greg @ BM says it'll draw 4A without the AP, probably 8A w/ AP...doesn't leave much room for many other items (w/out using the battery) if you're down to only the SD-8. Thanks! --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Subject: Starter Solenoid Orientation
Date: Jun 29, 2002
Should the starter solenoid be oriented upside-down in the event of a solenoid spring failure, so that it will fail in the open position?I understand that I can de-energize the starter solenoid by turning off the master solenoid but I want the extra safety. Also,should the master solenoid switch be mounted in the upright position or can it be positioned on its side? Jeff Laishes ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Re: GNS 430 Current Draw
Brian, I've measured the current draw of my GNS 430 of the combined Nav and Com lines at 2.13 amps on a 12 volt supply. Regards, Richard Dudley -6A panel, N331RD reserved Brian & Debi Shannon wrote: > > > Hi All, > > Does anyone know the approximate current draw for the Garmin GNS 430 or > 530...trying to do a load analysis and haven't found any info on their > website or in the online users manual! > > Also - is there anyone out there planning on going with EFIS/One and trying > to put it on an SD-8 powered essential bus? Just curious what others have > come up with....I know Greg @ BM says it'll draw 4A without the AP, probably > 8A w/ AP...doesn't leave much room for many other items (w/out using the > battery) if you're down to only the SD-8. > > Thanks! > --- > Checked by AVG anti-virus system (http://www.grisoft.com). > ________________________________________________________________________________
From: "Stephen Johnson" <spjohnsn(at)ix.netcom.com>
Date: Jun 29, 2002
The GNS 430 installation manual with all sorts of good stuff is available on the web site. Go to the customer support section and go down the page to installation manuals. Steve Johnson ----- Original Message ----- From: "Brian & Debi Shannon" <wings(at)theshannons.net> Subject: AeroElectric-List: GNS 430 Current Draw > > Hi All, > > Does anyone know the approximate current draw for the Garmin GNS 430 or > 530...trying to do a load analysis and haven't found any info on their > website or in the online users manual! > > Also - is there anyone out there planning on going with EFIS/One and trying > to put it on an SD-8 powered essential bus? Just curious what others have > come up with....I know Greg @ BM says it'll draw 4A without the AP, probably > 8A w/ AP...doesn't leave much room for many other items (w/out using the > battery) if you're down to only the SD-8. > > > Thanks! > --- > Checked by AVG anti-virus system (http://www.grisoft.com). > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jun 29, 2002
Walter, Fergus and others: Thanks to Fergus for the positive feedback, and to Walter for assuming that my comments were only meant to be constructive - not a slam. The article referred to below is published in the May Sport Aviation (Gerry Twombly, Page 128). Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete > There was a good article in Sport Aviation recently. It suggested that we > fly occasionally with a friend whereby you alternate PIC duties on each leg > of the trip. The thesis was that you will be a better pilot due to the > basic competitive nature of people. The author used the analogy of golfing > with a friend - where winning shouldn't matter. ________________________________________________________________________________
Subject: CB vs Fuses
Date: Jun 29, 2002
My bad experiences with fuses have been the old ceramics from European autos and 5 X 20 glass fuses (also European). I believe the ACT blade types are superior....but hey...there's still no switch. I'll probably have a few fuses in places where I don't also need a separate switch. I also have used self-resetting solid state fuses; these should be carefully applied. Electrohydraulic-Magnetic circuit breakers are best for operating in difficult environments and packed panels. They don't heat load and nuisance trip. They are small and have rockers or toggles and lots of features. These are going into my Glastar. http://www.pocosales.com/ or http://www.cbibreakers.com/ look up CBI Hy-Mag B-frame circuit breakers. http://www.etacbe.com/n_america/e-t-a/etacbeframeset.html check model series 8330 Regards. Eric M. Jones ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Torx, schmorx 2
In a message dated 06/28/2002 2:53:30 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com LRE2(at)aol.com writes: 6/29/2002 Hello LRE2, I apologize for pursuing the off topic subject of specialty screws in this forum after it was initially raised by Fergus Kyle (he wants credit). I have this tendency to want to solve problems when people raise them. My wife often accuses me of this -- it turns out that she frequently wants just sympathy rather than a solution to her latest complaint / problem. But I am an incurable solution provider. Please let me make 5 points: 1) Your comment about the dexterity of young junior enlisted men in manipulating Phillips drive screws was particularly poignant to me. That is how I started out -- as a 17 year old enlisted airplane mechanic in the US Navy over 52 years ago in 1950. And many's the Phillips screw that I have turned in those intervening years. I miss those days, but not the Phillips drive screws. 2) And yes, my physical skills served me very well in those golden days of youth, but some how as time has passed the physical challenge of a problem has faded a bit in appeal and the mental challenge has come to the fore. Some times I find it much better to use my brain rather than my (limited) brawn to solve problems these days. 3) Aerospace has indeed found it desirable / necessary to move beyond the Phillips drive screw. Many, many alternatives have been developed through the years by different people in an attempt to develop the "perfect screw drive". (And the search continues -- Torx Plus being one of the more recent examples). I won't even begin to list all of the others here, but the hex socket and the Torx seem to be two of the most common ones used on modern aerospace vehicles. If the big boys are using something better than the Phillips drive, why shouldn't we amateur experimental builders be also willing to move forward? Don't we even claim to be on the leading edge at times? 4) Simple screw? -- surely you jest. As an Aerounautical Engineer (a subspecialty in structures), an A&P mechanic (and a pilot of some 40 years plus) I assure you that there is nothing simple about aerospace fasteners. They literally hold our vehicles together -- is there a more fundamental function in the pilot's list of desires than that his vehicle not fall apart while in use? There are even federal laws about the pedigree and accountability of aerospace fasteners. 'Nuff said. 5) As for more important issues to address in one of these forums, over 50 fellow builders have contacted John Fleisher at Micro Fasteners expressing a desire to obtain some of the specialty screws that we have been discussing. I submit that to those 50 plus builders, and more to come, that this subject reached a level of importance that directly affected the bulding of their aircraft. Isn't that why we are all communicating with each other? Regards from a fellow builder. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Torx, schmorx 1
In a message dated 06/28/2002 2:53:30 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "Fergus Kyle" writes: 6/29/2002 Hello Ferg, Yep, I was keenly aware that it was you that raised this issue in this forum, but I wasn't sure that you would want to remind eveyone and claim "credit" so I obfuscated that fact. Sorry. I am willing to give you complete credit, and to thank you because I feel that some benefit has flowed. Ferg, my renewed search for a better screw drive in a stainless steel 100 degree flat head counter sink configuration was not in any way intended to denigrate the Robertson drive, or products from Canada (I greatly loved flying the Katana DA20-C1). But I looked at both what modern aerospace vehicles were using and what was reasonably available in drive bit inserts and the conclusion was either hex socket or Torx. Since the hex sockets were pretty small in the number 8 flathead 100 degree countersink screws that I had previously bought (at great expense) I opted for the Torx drive. (Actually I feel that Torx Plus is superior, but again availability is minimal). So there we have it. As over 50 fellow builders have responded to John Fleisher at Micro Fasteners indicating a desire for such screws he is in the process of procuring some number 8-32 5/8 inch long Torx drive 100 degree counter sink flat head SS screws and will maybe procure some other sizes. If you feel that the Robertson drive screw's time has arrived why don't you pursue getting some made up in the configurations and material that fellow builders could use? A word of caution -- it has taken me over four years of searching and struggle to reach this point and I'm still not sure that the Torx drive is going to be a satisfactory replacement for the Phillips drive. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? PS: I would be careful about using the term "Prince of Screws" in referring to the Roberston drive because there is a screw drive already in existence called the Prince. It was very similar to the Phillips and was easily confused. It now has fallen out of favor and is not readily found. PPS: There is a screw square drive remarkably similar to the Robertson called SCRULOX. Maybe it is just another name for a Robertson drive. I don't know anything about its pedigree. Insert bits can be obtained from SNAP-ON. ________________________________________________________________________________
Date: Jun 29, 2002
Be advised that that number should increase when transmitting. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Dudley Subject: Re: AeroElectric-List: GNS 430 Current Draw Brian, I've measured the current draw of my GNS 430 of the combined Nav and Com lines at 2.13 amps on a 12 volt supply. Regards, Richard Dudley -6A panel, N331RD reserved Brian & Debi Shannon wrote: > > > Hi All, > > Does anyone know the approximate current draw for the Garmin GNS 430 or > 530...trying to do a load analysis and haven't found any info on their > website or in the online users manual! > > Also - is there anyone out there planning on going with EFIS/One and trying > to put it on an SD-8 powered essential bus? Just curious what others have > come up with....I know Greg @ BM says it'll draw 4A without the AP, probably > 8A w/ AP...doesn't leave much room for many other items (w/out using the > battery) if you're down to only the SD-8. > > Thanks! > --- > Checked by AVG anti-virus system (http://www.grisoft.com). > = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Jun 29, 2002
Buy the SD-20. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian & Debi Shannon Subject: AeroElectric-List: GNS 430 Current Draw Hi All, Does anyone know the approximate current draw for the Garmin GNS 430 or 530...trying to do a load analysis and haven't found any info on their website or in the online users manual! Also - is there anyone out there planning on going with EFIS/One and trying to put it on an SD-8 powered essential bus? Just curious what others have come up with....I know Greg @ BM says it'll draw 4A without the AP, probably 8A w/ AP...doesn't leave much room for many other items (w/out using the battery) if you're down to only the SD-8. Thanks! --- Checked by AVG anti-virus system (http://www.grisoft.com). = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Re: Torx, schmorx 1
>PS: I would be careful about using the term "Prince of Screws" in referring >to the Roberston drive because there is a screw drive already in existence >called the Prince. It was very similar to the Phillips and was easily >confused. It now has fallen out of favor and is not readily found. Was that the screws that are similar to phillips, except that the 4 legs are offset slightly? ________________________________________________________________________________
Date: Jun 29, 2002
OC & Ferg, I haven't seen a description of the diffence between Torx & Torx Plus. Also, having never seen a Torx of any type, nor a Robertson, could you give us a brief description of what these fasteners and drive bits look like? Probably a web page link with pictures would be worth a thousand words. David Carter ----- Original Message ----- From: <BAKEROCB(at)aol.com> Subject: AeroElectric-List: Torx, schmorx 1 > > In a message dated 06/28/2002 2:53:30 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com "Fergus Kyle" writes: > > fellow builder in a posting to a web based group that I belong to expressed > his complete disgust with Phillips drive screws. I responded that there were > superior alternatives such as hex socket, Torx, and Torx Plus drive screws > that were being used in modern aerospace vehicles, but that it was very > difficult to find and expensive to > buy such screws in small quantities for our use." Actually it was me.> > > 6/29/2002 > > Hello Ferg, Yep, I was keenly aware that it was you that raised this issue in > this forum, but I wasn't sure that you would want to remind eveyone and claim > "credit" so I obfuscated that fact. Sorry. > > I am willing to give you complete credit, and to thank you because I feel > that some benefit has flowed. > > > Ferg, my renewed search for a better screw drive in a stainless steel 100 > degree flat head counter sink configuration was not in any way intended to > denigrate the Robertson drive, or products from Canada (I greatly loved > flying the Katana DA20-C1). > > But I looked at both what modern aerospace vehicles were using and what was > reasonably available in drive bit inserts and the conclusion was either hex > socket or Torx. Since the hex sockets were pretty small in the number 8 > flathead 100 degree countersink screws that I had previously bought (at great > expense) I opted for the Torx drive. (Actually I feel that Torx Plus is > superior, but again availability is minimal). > > So there we have it. As over 50 fellow builders have responded to John > Fleisher at Micro Fasteners indicating a desire for such screws he is in the > process of procuring some number 8-32 5/8 inch long Torx drive 100 degree > counter sink flat head SS screws and will maybe procure some other sizes. > > If you feel that the Robertson drive screw's time has arrived why don't you > pursue getting some made up in the configurations and material that fellow > builders could use? A word of caution -- it has taken me over four years of > searching and struggle to reach this point and I'm still not sure that the > Torx drive is going to be a satisfactory replacement for the Phillips drive. > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > PS: I would be careful about using the term "Prince of Screws" in referring > to the Roberston drive because there is a screw drive already in existence > called the Prince. It was very similar to the Phillips and was easily > confused. It now has fallen out of favor and is not readily found. > > PPS: There is a screw square drive remarkably similar to the Robertson called > SCRULOX. Maybe it is just another name for a Robertson drive. I don't know > anything about its pedigree. Insert bits can be obtained from SNAP-ON. > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jun 29, 2002
Here is a web page that illustrates seven types of screw heads: www.msbuilder.com/tool/msscrew.htm Terry > > Also, having never seen a Torx of any type, nor a Robertson, could you give > us a brief description of what these fasteners and drive bits look like? > Probably a web page link with pictures would be worth a thousand words. > ________________________________________________________________________________
Date: Jun 29, 2002
Snip... So there we have it. As over 50 fellow builders have responded to John Fleisher at Micro Fasteners indicating a desire for such screws he is in the process of procuring some number 8-32 5/8 inch long Torx drive 100 degree counter sink flat head SS screws and will maybe procure some other sizes. Is this www.microfasteners.com ? How do I get on his list. These things might be ideal to replace the **#@ing cowls screws I keep stripping. John Slade Cozy IV ________________________________________________________________________________
Date: Jun 29, 2002
Subject: RE: GNS 430 Current Draw
> >Be advised that that number should increase when transmitting. Transient loads for transmitters are generally ignored in the load analysis for sizing alternators and batteries. Transmitter energy requirements are generally under 1% of the total system requirements and are therefore not a factor. ________________________________________________________________________________
Date: Jun 29, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Terry Watson wrote: > > > Here is a web page that illustrates seven types of screw heads: > www.msbuilder.com/tool/msscrew.htm > If you include the 'http://' in the web address, it will allow most users to simply click on the address & go to the page listed. ________________________________________________________________________________
Date: Jun 29, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> >Brian, >I've measured the current draw of my GNS 430 of the combined Nav and Com >lines at 2.13 amps on a 12 volt supply. Good data point! Thanks! Bob . . . ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Re: Starter Solenoid Orientation - Myths and magic
> > > >Should the starter solenoid be oriented upside-down in the event of a >solenoid spring failure, so that it will fail in the open position? I >understand that I can de-energize the starter solenoid by turning off the >master solenoid but I want the extra safety. Also,should the master solenoid >switch be mounted in the upright position or can it be positioned on its >side? > > Jeff Laishes The myths surrounding supposed failure modes of contactors including the hazards of g-loading due to airborne maneuvers are rampant in the wild. I've not been able to track down a single case of hard data that backed up any of the stories about spring failure or aerobatic g-loading being any cause for concern. I was at OSH one year when a story went around about somebody's starter contactor closing during an airshow performance causing lots of damage to starter and ring gear. The popular story was that the pilot's daring-do produced the necessary acceleration to close the contacts and weld them. In fact, the contacts probably welded on initial startup and the pilot either didn't notice or had no obvious indications of the event via panel instrumentation. Your starter contactor should be of this variety: http://www.aeroelectric.com/Catalog/switch/s702-1l.jpg These generally mount on the firewall with the terminals facing forward. G-loading that would produce inadvertent closure of the contacts would occur only if you hit the ground, tail first, at mucho feet per second . . . if you do hit the ground in this attitude, starter contactor closure is the least of your concerns. Battery contactors are normally closed for the duration of the flight. In this condition, the spring is fully compressed and magnetic forces keeping the contactor closed are at their highest - impossible to open with aero dynamic loads. Unless you plan to fly some high-g maneuvers during battery only ops with an e-bus alternate feed bypassing an OPEN battery contactor, concerns for mounting the battery contactor in some magical position are also invalid. Cursory looks at actuator mass and spring rates in the various contactors we sell show that g-loads capable of effecting contactor performance just don't happen in light aircraft. Bob . . . ________________________________________________________________________________
Date: Jun 29, 2002
Subject: Re: CB vs Fuses
> >My bad experiences with fuses have been the old ceramics from European >autos and 5 X 20 glass fuses (also European). I believe the ACT blade >types are superior....but hey...there's still no switch. I'll probably >have a few fuses in places where I don't also need a separate switch. I >also have used self-resetting solid state fuses; these should be >carefully applied. The only fuses I've seen that succumbed to vibration were the glass and ceramic cartridge devices in the smaller ratings and of the fast-blow variety. The fusible portion of the device was so fine in the 3A or smaller sizes that they would part the solder joint under the end cap with severe vibration. This is why you didn't see a cartridge fuse of less than 5A used in very many places on airplanes. The plastic fuses in all sizes are not so afflicted. Electrohydraulic-Magnetic circuit breakers are best for operating in >difficult environments and packed panels. They don't heat load and >nuisance trip. They are small and have rockers or toggles and lots of >features. These are going into my Glastar. > >http://www.pocosales.com/ or http://www.cbibreakers.com/ look up CBI >Hy-Mag B-frame circuit breakers. > >http://www.etacbe.com/n_america/e-t-a/etacbeframeset.html check model >series 8330 These are indeed fine circuit breakers . . . we've looked at breakers with similar performance characteristics in certified aircraft for years . . . but only in special cases where the extra fast response of magnetically tripped breakers was found useful or necessary . . . They are used less than 1% of the time in the GA fleet. To state they are "best" for your application implies an increased risk of problems by using any lesser product. I'll suggest that 50 years of experience in the GA fleet has demonstrated that this is not the case. I don't recommend fuses as "better" than breakers for the purpose of protecting the wires but I would say that they are equal to breakers in this regard at a fraction of the cost. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jun 29, 2002
Subject: RE: CBs vs Breakers
> >I did not realize reading Bob's text how compact a >blade fuse installation can be. This evening, I wired >my fuse panel and I am pretty impressed with the >number of wires coming out of it! See: > >http://mthobby.pcperfect.com/ch601/daypict.jpg > >22 circuits, main bus feed, ess bus feed and >alternator field (not yet connected). All on a panel >10"X6" that will take 0"X0" of instrument panel space. Nice job on dressing those bundles! Bob . . . ________________________________________________________________________________
Subject: Re: Two alternator, one or two battery systems
Date: Jun 30, 2002
Bob, OK, I will use the Z-14 style of electrical system. Both the Jabiru PM flywheel alternator and the B&C SD20 are 20 amp units. The SD20 will have the B&C LR3C-14 regulator and the Jabiru will have the Jabiru provided regulator. I will add overvoltage protection with the OVM-14 and the s704-1 relay for the PM alternator. The main battery is an Odessey 17 amp hour unit with internal resistance of 7 milliohms (I confirmed this cranking the engine on the stand.) The small battery is a Panasonic 5 amp-hour unit with fast-on tabs. There is no diagram in the connection for this permutation of components, but I can manage with some thought. The hardest part will be learning to use the software to redo the drawings! Questions: 1. Will one VLM-14 system work, or do I need the VSM-14KIT as well? The B&C voltage regulator will indicate if the SD20 has failed, so the VLM-14 could monitor the PM alternator. Furthermore, since each alternator has its own 20 amp shunt, the DPDT switch shown on the last page of the instruction manual could allow manual selection for the loadmeter. However, to switch the voltmeter independently of current, I could use a single pole, double throw switch. Pin 8, the normal input for the voltmeter, would be switched between the main bus and the aux bus. I do wish to monitor field voltage on the SD20 at times, so the pushbutton to test field voltage on the SD20 is still needed. Any problems so far? This arrangement means that the PM alternator drives the main bus with the 17 amp-hr battery. This bus will be protected from voltage spikes from the starter by the VLM-14. It will be used mainly for lights and strobes. The avionics will be on the aux buss which is driven by the SD20 and stabilized by the 5 amp-hr battery. With the crossfeed relay activated only for failure of either alternator, the avionics will never see any noise or spikes from the starter. 2. I have a source of relay sockets used in automobiles which fit an s704 relay clone. There will be at least three of these used: small battery contactor, PM overvoltage relay, and crossfeed relay. If a relay sockets were used for these, the opportunity to misconnect a relay in the future is eliminated. Do you see a problem with this? 3. You suggested either a s704 crossfeed relay, or even a 20 amp circuit breaker. I happen to have one of these breakers, so what is the better choice? The chance of either bus shorting to ground is low given the fuses everywhere. The relay allows me to use an annunciator light driven by the switch. A plain SPST switch would be simplest, and given the low current involved, might be the most justified. 4. I plan to put the current shunt in the ground lead of the PM alternator. Then, no 24 gauge fuse links are needed, as the wires to the ammeter are a ground potential. See Z-13 Jim Foerster J400/3300 ________________________________________________________________________________
Date: Jun 30, 2002
Subject: Actual Loads
Bob, In evaluating the real current loads in various operating conditions, I have measured current draw for each of the radios and instruments that I have. There are a few items that I do not have data for and cannot readily measure until everything is installed and operating. Referring to your Z-11 schematic, what continuous (or average)current do you expect in the line from the Main Power Bus to the pin 6 of the Alternator Controller: and for the Lo V Warn to pin 5 of the Controller? Thanks in advance. Richard Dudley ________________________________________________________________________________
Subject: GNS430 serial input from Rocky Mtn Encoder
Date: Jun 30, 2002
Anyone used the serial output from a Rocky Mountain Encoder to the serial input on a Garmin 430 rather than the encoder grey code? If so, I'm curious what protocol you used. Russ Werner HR II ________________________________________________________________________________
Date: Jun 30, 2002
Subject: Re: Actual Loads
> >Bob, > >In evaluating the real current loads in various operating conditions, I >have measured current draw for each of the radios and instruments that I >have. There are a few items that I do not have data for and cannot >readily measure until everything is installed and operating. > >Referring to your Z-11 schematic, what continuous (or average)current >do you expect in the line from the Main Power Bus to the pin 6 of the >Alternator Controller: and for the Lo V Warn to pin 5 of the Controller? Pin 6 is field supply. Since the B&C alternators are originally rated as 40 or 60A devices with the field powered up internally, they will become 43 and 63A devices with the field supplied externally. If you're using any other brand of EXTERNALLY excited alternator, then figure on a max of 3A going into pin 6 on the regulator which will happen under the very rare cases of maxed out alternator performance due to loading, low RPM or both. Under normal conditions, a B&C with the supplied pulley and typical loads for VFR/IFR flight, field current will be 1 to 1.5 amps. Pin 5 is a sense lead that draws about 50 milliamps as I recall. Bob . . . ________________________________________________________________________________
Date: Jun 30, 2002
> > An electric flap system or electric gear system should be protected > by a breaker within reach of the pilot. Or there should be some other > method for dealing with this problem. Let's size the "problem" . . . suppose you find that flaps stop deploying when airload induced current values exceed the value of the circuit protection long enough to trip the device. Flaps are already out with considerable surface to the wind . . . else the protection wouldn't have operated. What is the risk to the planned landing? I'll suggest none. The difference in landing performance between say 2/3 deployed and fully deployed flaps would be difficult to deduce by observation. The real risk is for some of the older Cessnas with their 40-degree flap extensions. What happens if you've got the boards out and have to do a go-around. There were conditions on some models that committed you to put the wheels on the ground after dropping below some minimum height above the ground. I think there was an AD put out against the 150's to change maximum flap travel to 30 degrees after these aircraft experienced a rash of unhappy go-around attempts. > >Shouldn't there be a way to torque limit a flap motor without making >it blow its circuit protection (like a window motor)? The main circuit >protection (breaker or fuse) certainly can protect the device that it >powers, but it should maybe more protect the wire that connects to it. >I think I have read Bob reference a thermal limiter that is self >"automatic?" In the best of all worlds, yes. Modern brushless motors often build stall current limitations into their controllers but even this value may be several times the normal running current of the system such that prolonged operation (tenths of seconds to seconds) at over-normal levels may open the circuit protection. This is particularly probable with permanent magnet or shunt wound motors that exhibit sharp rise in current draw as load increases as compared with the softer behavior of a series wound motor. >So maybe the scenario should be that the system is designed with a >fuse large enough to support the current load that the device it powers >can safely demand for ultimate circuit protection, and a current limiter >in the motor system. Then if you are a little ham-fisted with the flap >application the system does a soft shutdown for a moment until it >cools off (hopefully allowing you to contemplate your actions for a >moment), and then you get a chance to try again. The overload situation has to be pretty short lived. White arc speeds are for fully deployed flaps. By the time they're half way out, drag is going up rapidly and the airplane slows down quickly. I've expedited descent to the end of the runway and started extending flaps at over-the-arc speeds while holding level flight. As soon as the needle touches the top of the white arc, push the nose down to stay at the top while the flaps continue to deploy. Unless one has the power up -and- nose pushed over it seems that it would be difficult to stay at speeds above the white arc after the flaps were deployed by half or more (except the American AA-1 Yankee . . . flaps were a waste of parts and labor to install on that airplane). > If you are really >persisten then the flaps just don't get lowered because the device stays >in its current limiter mode. If you have a shorting failure in the >motor, controller, or wire, then its blows a fuse, you stop making >sparks with it by trying to reset it repeatedly, and you don't get to >make more fireworks with it again until you make a landing somewhere and >can get to the fuse panel. I suppose you could wire an anunciator to >the limiter to indicate when its in limiter mode so that you can know >when you will have more success. I built a set of active current limiters to go in series with each motor of a landing gear retraction system for a Lancair IVP. These are designed to limit torque to values capable of operating the gear but prevent transient spikes of startup AND the possibility of damaging a gearbox if the system jams or drives past limit switches. These are not difficult to build but they do drive up parts count. I think I would make SURE that the flap system supply was robust enough to stay powered up for all but hard fault conditions. If just-over-the-white-arc airspeeds are likely to trip the protection, it's simply too light. On homebuilts, we modify to correct such faults of design. Certified ships are another matter. >Probably won't find something like this on a C210 any time soon... Does >anyone know whether the C210 flap breaker was designed to protect the >structure?? There are lots of other things you could do that would >overstress the airframe... We ran some tests way back when that deliberately drove the flaps on a Cessna into mechanical stops. I don't recall now which model it was but I recall that the event didn't permanently deform anything. The actuators at that time had end-of-travel, overrun limiters on the ball screw and the flaps were supposedly rigged so that the motor couldn't jam things even if the limit switch failed to halt the motor . . . the ball screw traveller simply reached the end of the stroke and uncoupled. The real overload threat was extension of flaps at high airspeeds. I think there was a 30kt headroom value for the top of the white arc for design strength . . . I can call out to Cessna and confirm that value. These instances are of short duration unless one is pushing the nose down to maintain over-speed while the flaps come out. >If you need more reliability - ie its impractical to design a redundant >wing flap mechanism, then maybe the thing should be mechanical to start >with. I could imagine that might be a consideration if you operate in >Alaska where long, smooth, no flapper landing strips might be further >away than your mission endurance. Electric flaps of the PM motor/ball-screw variety have been installed on tens of thousands of airplanes for over 40 years. I've not researched the service difficulty reports on this system so I cannot attest to qualities "pure as the driven snow." However, personal observation over the years shows that this flap system deployment technology is at least very low on the list of concerns. Having said all this assumes that everything was working as-designed. Most breakers take something on the order of 5-30 seconds to open with a 200% overload. There is reason to check the breaker in a flap system that tripped due to "aerodynamic overload" . . . All in all, one should KNOW how the airplane is going to behave with flaps deployed at any setting. If you can't extract yourself from a rejected landing with full flaps under all conditions, it might pay to never extend flaps to full until your comfortable arrival is assured. Popped fuses are not the ONLY way flaps might become immobile. . . Bob . . . ________________________________________________________________________________
Date: Jun 30, 2002
Bob, Thanks for your reply. I have an additional related question: (I plan on using a B&C 60 A alternator and the LR-3 controller.) In Z-11 from the main bus you show a AWG 22 fusible link, 18 AWG wire to and from the switch, have a 5 A Circuit breaker in the line between the Bat/Alt switch and pin 6 of the controller and an AWG 20 wire from pin 4 of the controller to the field of the alternator. Would you explain the rationale for that combination. Do you expect the fusible link to fail in a shorter time than it takes the breaker to respond if there is a failure at the controller or the alternator? Regards, Richard Dudley Robert L. Nuckolls, III wrote: > > > > > >Bob, > > > >In evaluating the real current loads in various operating conditions, I > >have measured current draw for each of the radios and instruments that I > >have. There are a few items that I do not have data for and cannot > >readily measure until everything is installed and operating. > > > >Referring to your Z-11 schematic, what continuous (or average)current > >do you expect in the line from the Main Power Bus to the pin 6 of the > >Alternator Controller: and for the Lo V Warn to pin 5 of the Controller? > > Pin 6 is field supply. Since the B&C alternators are originally > rated as 40 or 60A devices with the field powered up internally, > they will become 43 and 63A devices with the field supplied > externally. If you're using any other brand of EXTERNALLY > excited alternator, then figure on a max of 3A going into > pin 6 on the regulator which will happen under the very rare > cases of maxed out alternator performance due to loading, low > RPM or both. Under normal conditions, a B&C with the supplied > pulley and typical loads for VFR/IFR flight, field current > will be 1 to 1.5 amps. > > Pin 5 is a sense lead that draws about 50 milliamps as I > recall. > > Bob . . . > ________________________________________________________________________________
Date: Jun 30, 2002
> Anyone used the serial output from a Rocky Mountain Encoder to the > serial input on a Garmin 430 rather than the encoder grey code? If so, I'm > curious what protocol you used. I have set the uEncoder output to: SHAdZ and the Garmin GNS-430 GPS input on Channel 1 to: Shadin-fadc - Serial air data and fuel flow information from Shadin 9628XX-X Fuel/Air Data Computer and it works fine on the ground (it transmits IALT; PALT; DALT; TALT; IAS; TAS; OAT; TAT; InHg and Hdg [magnetic heading from the remote compass] every second or so.) Ulrich (all electric IFR CH801) ________________________________________________________________________________
Date: Jun 30, 2002
Subject: Torx Schmorx 3
AeroElectric-List message posted by: "David Carter" "OC & Ferg, I haven't seen a description of the diffence between Torx & Torx Plus. Also, having never seen a Torx of any type, nor a Robertson, could you give us a brief description of what these fasteners and drive bits look like? Probably a web page link with pictures would be worth a thousand words. David Carter" 6/30/2002 Hello David, The URL <> will give you pictures of the Robertson (square) and the Torx (six lobe) drives. The difference between the Torx and the Torx Plus is more subtle. You can go to this web site to check it out <<http://www.camcar.textron.com/torxplus/>>. Ask for literature to get the precise picture. Some comments: 1) Torx Plus is relatively new and both fasteners and drivers may be hard to come by. 2) There is a constant ongoing struggle. A screw drive configuration that works good on a high speed automated assembly line may not be too good when it gets out in the field and vice versa. 3) Don't confuse either Torx or Torx Plus with Torx-Set. They are quite different. 4) A printed tool catalog like Jensen <> has good pictures of many different screw drives. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Re: GNS430 serial input from Rocky Mtn Encoder
Date: Jun 30, 2002
Ulrich, Fantastic. Thanks for the great information. What can the 430 do with all that information? Is it able to give you wind and drift information? If so, how far down the menus to get that displayed? I don't have the compass module for my Rocky Mountain, but I may get it if the 430 can make good use of it! Aloha, Russ Harmon Rocket II ----- Original Message ----- From: <ulf3(at)juno.com> Subject: AeroElectric-List: GNS430 serial input from Rocky Mtn Encoder > > > > Anyone used the serial output from a Rocky Mountain Encoder to the > > serial input on a Garmin 430 rather than the encoder grey code? If so, > I'm > > curious what protocol you used. > > > I have set the uEncoder output to: > > SHAdZ > > and the Garmin GNS-430 GPS input on Channel 1 to: > > Shadin-fadc - Serial air data and fuel flow information from Shadin > 9628XX-X Fuel/Air Data Computer > > and it works fine on the ground (it transmits IALT; PALT; DALT; TALT; > IAS; TAS; OAT; TAT; InHg > and Hdg [magnetic heading from the remote compass] every second or so.) > > > Ulrich > (all electric IFR CH801) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jun 30, 2002
> > > > >Brian, > >I've measured the current draw of my GNS 430 of the combined Nav and Com > >lines at 2.13 amps on a 12 volt supply. I'm not familiar with these units, but don't their displays have backlighting? I'd guess that at full brightness the current draw would be considerably higher. Finn ________________________________________________________________________________
Date: Jul 01, 2002
Finn, There is a photocell that adjusts the brightness of the display on the GNS 430. The display becomes brightest when the ambient light is high and dimmest when the ambient light is low. The measurement that I reported (2.13 A) was in a lighted room. Shining a flashlight on the photocell made no difference suggesting that the room illumination was enough to take the display to its brightest. If I cover the photocell to simulate dark conditions, the current draw declines to 1.7 A. Regards, Richard Dudley Finn Lassen wrote: > > > > > > > > > >Brian, > > >I've measured the current draw of my GNS 430 of the combined Nav and Com > > >lines at 2.13 amps on a 12 volt supply. > > I'm not familiar with these units, but don't their displays have > backlighting? I'd guess that > at full brightness the current draw would be considerably higher. > > Finn > ________________________________________________________________________________
Subject: Re: RE: Fuses vs. Breakers exchange
Date: Jul 01, 2002
----- Original Message ----- From: "John Slade" <sladerj(at)bellsouth.net> Subject: RE: AeroElectric-List: RE: Fuses vs. Breakers exchange > > > OK Bob, fuse or cb.....my only point was that IF you get a > > failure/malfunction that DOES pop the breaker or blow the fuse, I'd like > > to be able to physically SEE which one it was. > Just out of interest, I bought a interesting set of fuses at an automotive > store. Each fuse has an LED which glows when the fuse is blown. > John Slade > Cozy IV > We use a similar device at work and there are a couple of things to bear in mind on these LED blown fuse indicators. First they only work if there is a load downstream of the fuse that is capable of lighting the LED. If you have a blown fuse on the landing light circuit it will only light up the blown fuse indicator if the switch is on and the filiment is good. They can also make troubleshooting a little confusing from time to time since the LED in the fuse will carry the voltage through it. I have spent too much time over the years chasing a problem that turned out to be a blown fuse because I put a voltmeter on the circuit, read the proper voltage and carried on looking for something else when all along it was a blown fuse. Well, the LED wasn't on and I had voltage downstream, it must not be the fuse, right? but it was. I'm not trying to discourage the use of these things I just want everybody to know the rest of the story. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) http://www.myrv7.com Fuselage Airplanes never win battles with the ground. The best the airplane can hope for is a draw. > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Blown fuses
Date: Jul 01, 2002
I had a 1982 Dodge Challenger ( a Mitsubishi in disguise) which used blade type fuses and had a slider switch and light attached to the fuse block. When the key was on you could slowly move the slider through each fuse position and it would light. The same thing could be done on these aircraft systems with a rotary switch (yes I know most of them are junk) and an LED. By using a current limiting resistor for the LED at the load side of each fuse the "monitoring circuit" is protected from shorting the load and blowing the fuse. Not much current flows through a 1K resistor. FWIW Kev..RV7 wings arrive tomorrow! OK Bob, fuse or cb.....my only point was that IF you get a > > > failure/malfunction that DOES pop the breaker or blow the fuse, I'd like > > > to be able to physically SEE which one it was. > > Just out of interest, I bought a interesting set of fuses at an automotive > > store. Each fuse has an LED which glows when the fuse is blown. > > John Slade > > Cozy IV ________________________________________________________________________________
Date: Jul 01, 2002
Subject: Re: Blown fuses
> >I had a 1982 Dodge Challenger ( a Mitsubishi in disguise) which used >blade type fuses and had a slider switch and light attached to the fuse >block. When the key was on you could slowly move the slider through >each fuse position and it would light. > >The same thing could be done on these aircraft systems with a rotary >switch (yes I know most of them are junk) and an LED. By using a >current limiting resistor for the LED at the load side of each fuse the >"monitoring circuit" is protected from shorting the load and blowing the >fuse. Not much current flows through a 1K resistor. If we do our homework, the likelihood of ever having to replace a fuse is very low for the lifetime of the airplane. If one has a voltmeter, it's really easy to probe the downstream side of the fuse to see if it's blown . . . since we're trouble shooting a system with known problems, our wirebook notes on which fuse powers that system should take us right to the fuse in question. If one doesn't have a voltmeter, we're not ready to troubleshoot the system anyhow and self annunciating fuses and fuse holders won't make the task much easier. Bob . . . ________________________________________________________________________________
Date: Jul 01, 2002
Ulrich, Do you have your Rocky Mountain Encoder (grey code heading to transponder) output connected to the 430 as well or just using the serial data line out/in? Russ ________________________________________________________________________________
Subject: RE: AeroElectric-List Digest: 5 Msgs - 07/01/02
Date: Jul 02, 2002
Hi folks, I've been sitting on the sidelines reading the traffic, and picking up some good information along the way. Here's a comment that a friend, who is a Cessna dealer mentioned to me when he visited my Pulsar (almost done) My use of blade fuses. He mentioned that Cessna is using these type fuses in area and has had a problem with vibration causing the fuses to come loose. A service bulletin was sent out advising persons to apply a small dab of RTV on the head of the fuse, enough to hold it to the fuse block yet not enough to inhibit its removal. Using Bob's fuse blocks, I've found that it takes a hefty push to insert and a good tug to remove so I don't think this would be an issue but this comment made to me bares mentioning. Bernie Berger N914BB(res) ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: terminal strip for fastons
Date: Jul 02, 2002
Bob - do you sell a terminal strip for fastons? I cant find them on your web site. I think since I will have to make a joint at the wing root this is my choice method. Assuming a joint (which I know you dislike) anything against this? Thanks, Steve. ________________________________________________________________________________
Subject: Help ( A little off topic )
Date: Jul 02, 2002
All - I found a bargain at a garage sale .. It's a turn and bank gyro produced by Honeywell. It's in good shape ( from the outside) now I'm wondering if I should use it. The placard reads : MFR Part 00-205C4 / Serial # 156 / Series 5 and at the bottom in very small lettering it says Cessna. Does anyone know of this model? Is it 24v or 12v? I would like to know the pin out for this. Any leads or suggestion are greatly appreciated. Thank you in advance. Peter Ferguson N601PK Zodiac 601 "Metal Firecracker" ________________________________________________________________________________
From: "Harley, Ageless Wings" <Harley(at)AgelessWings.com>
Date: Jul 03, 2002
Mornin', Peter... >>a turn and bank gyro produced by Honeywell. It's in good shape ( from the outside) now I'm wondering if I should use it. The placard reads : MFR Part 00-205C4 / Serial # 156 / Series 5 and at the bottom in very small lettering it says Cessna. Does anyone know of this model? Is it 24v or 12v? I would like to know the pin out for this. Any leads or suggestion are greatly appreciated.<< I went to the Honeywell Avionics website, but they require pre approved access to their support section. Wasn't difficult to request it, but it may be awhile before I get approval. Meanwhile, I found this link on the site that may be of help. It provides: "a variety of service publications in support of Honeywell's avionics, including Technical Newsletters, Service Bulletins, and Component Maintenance Manuals" It also sources several names, snail mail addresses and email addresses for customer aid and service. http://www.cas.honeywell.com/cs/publications.htm Hope this helps Harley ________________________________________________________________________________
Date: Jul 03, 2002
Subject: Re: terminal strip for fastons
> > >Bob - do you sell a terminal strip for fastons? I cant find them on your web >site. I think since I will have to make a joint at the wing root this is my >choice method. Assuming a joint (which I know you dislike) anything against >this? How about this? http://209.134.106.21/articles/wingwire/wingwire.html Bob . . . ________________________________________________________________________________
Date: Jul 03, 2002
Bob - thanks for that. I wonder why there is not such a thing as a faston terminal strip. Thanks again, Steve. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: terminal strip for fastons > > >Bob - do you sell a terminal strip for fastons? I cant find them on your web >site. I think since I will have to make a joint at the wing root this is my >choice method. Assuming a joint (which I know you dislike) anything against >this? How about this? http://209.134.106.21/articles/wingwire/wingwire.html Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Jul 03, 2002
----snip--- > I wonder why there is not such a thing as a faston > terminal strip. Thanks again, Steve. They do, I have one in my hand. It's 12 circuits and says "WECO 401" on it. Couldn't tell you where it came from, but I might could find out. R ________________________________________________________________________________
Date: Jul 03, 2002
Don't know how old that terminal strip is Bob but the old Western Electric Company used WECO on a lot of their stuff. Bill Lamb ----- Original Message ----- From: "RSwanson" <rswan19(at)comcast.net> Subject: Re: AeroElectric-List: Re: terminal strip for fastons > > ----snip--- > > I wonder why there is not such a thing as a faston > > terminal strip. Thanks again, Steve. > > They do, I have one in my hand. It's 12 circuits and says "WECO 401" on > it. Couldn't tell you where it came from, but I might could find out. > R > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 03, 2002
Greetings, WECO is a Canadian company. They make over 10,000 different terminal blocks. Check out www.weco.ca Bruce -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RSwanson Subject: Re: AeroElectric-List: Re: terminal strip for fastons ----snip--- > I wonder why there is not such a thing as a faston > terminal strip. Thanks again, Steve. They do, I have one in my hand. It's 12 circuits and says "WECO 401" on it. Couldn't tell you where it came from, but I might could find out. R = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Help With Alternator
Date: Jul 03, 2002
I am starting to look at acquiring overvoltage protection for my alternator. Perhaps I am too early. However, I need some info on my alternator. Can one of you help? I have a Electrosystem ALX-8421LS. The data plate is marked 12V. No Amps are specified. I can find NO documentation on this alternator (Prestolite???). I can only find an ALX-8421 which is 24 volts and 70 Amps (no LS suffix). Questions: Can I assume that my ALX-8421LS is a 12Volt, roughly 35 Amp alternator? Can I assume that there is NO built-in regulator? Should I slam it? note: I can use the forward weight (w&b). It only has 150 hours on it. It is a klunker - but half the volts and half the amps probably means a similar weight. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete ________________________________________________________________________________
Date: Jul 04, 2002
Subject: Velcro
Bob, You have mentioned in earlier posts about securing RG batteries with Velcro, avoiding the need for the weight of conventional battery boxes. Do you have any additional information about the Velcro suitable for this application? I'd be interested in any details about specific materials, dimensions, securing methods and sources of supply. Thanks in advance. Richard Dudley ________________________________________________________________________________
Subject: What is the easiest CAD program for my wirebook?
Date: Jul 04, 2002
The predrawn diagrams in the 'Connection are great, but I need to modify and combine several of the "Z" diagrams. Does anyone have an opinion which of the two affordable CAD programs are easier to learn? TurboCAD or Intellicad? I intend to buy the program as the free versions seem to have less in the way of tutorial and ease of use. At least that is what the web sites suggest. Thanks for any insight you might have. Jim Foerster J400 ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Subject: Re: What is the easiest CAD program for my wirebook?
Date: Jul 05, 2002
Hello Jim, I'm using the free version of Intellicad and I'm happy with it. I had to printout the several hundred pages of docu to be able to work with it, but for the diags so far it works very well. Werner ----- Original Message ----- From: "James Foerster" <jmfpublic(at)attbi.com> Subject: AeroElectric-List: What is the easiest CAD program for my wirebook? > > The predrawn diagrams in the 'Connection are great, but I need to modify > and combine several of the "Z" diagrams. Does anyone have an opinion > which of the two affordable CAD programs are easier to learn? TurboCAD > or Intellicad? I intend to buy the program as the free versions seem to > have less in the way of tutorial and ease of use. At least that is what > the web sites suggest. > Thanks for any insight you might have. > > Jim Foerster J400 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 05, 2002
James I used the Turbo Cad 2d which is downloadable for free from their website. It is more than adequate for modifying Bob's Z diagrams. Some of the features available in the 3D version aren't available in the 2D demo but it wasn't much of a problem. The help documentation that comes with the program is all one needs. Bill Rounds N159RV finish. Electrical done James Foerster wrote: > >The predrawn diagrams in the 'Connection are great, but I need to modify >and combine several of the "Z" diagrams. Does anyone have an opinion >which of the two affordable CAD programs are easier to learn? TurboCAD >or Intellicad? I intend to buy the program as the free versions seem to >have less in the way of tutorial and ease of use. At least that is what >the web sites suggest. >Thanks for any insight you might have. > >Jim Foerster J400 > > ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Ball vario
I have a Ball vario model 600 and when I key the mike it goes full deflection down. I tried with my handheld near by, does the same thing. A problem or just something you live with. Anyway to stop it? Thanks in advance, R ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Oil Pressure switch rating
Bob Do you happen to know what the current carrying capacity is of the oil pressure switch B & C sells. Am contemplating using it to switch on the Navaid wing leveler since they seem insistent on not having it on during start up. Would probably need 7 amps tops going thru the normally open set of contacts. Thanks Bill Rounds N159RV ________________________________________________________________________________
Date: Jul 05, 2002
I did the same as others and tried out all the free versions from various websites etc, in the end I liked TurboCad the best as it was similar to how other windows programs worked. However there are some features missing from the free version (like blocks and other advanced drawing tools) So I cruized over to ebay and was able to pickup and older version in the sealed box for $20. It works great and I have used it for panel layout and wiring diagrams. - Andy Karmy RV9A - Finishing ---------- Original Message ---------------------------------- From: "James Foerster" <jmfpublic(at)attbi.com> Date: Thu, 4 Jul 2002 23:11:38 -0700 > >The predrawn diagrams in the 'Connection are great, but I need to modify >and combine several of the "Z" diagrams. Does anyone have an opinion >which of the two affordable CAD programs are easier to learn? TurboCAD >or Intellicad? I intend to buy the program as the free versions seem to >have less in the way of tutorial and ease of use. At least that is what >the web sites suggest. >Thanks for any insight you might have. > >Jim Foerster J400 > > ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re: Help With Alternator
Slam it! ----- Original Message ----- From: "Ernest Kells" <ernest.kells(at)sympatico.ca> Subject: AeroElectric-List: Help With Alternator > > I am starting to look at acquiring overvoltage protection for my alternator. > Perhaps I am too early. However, I need some info on my alternator. Can > one of you help? > > I have a Electrosystem ALX-8421LS. The data plate is marked 12V. No Amps > are specified. I can find NO documentation on this alternator > (Prestolite???). I can only find an ALX-8421 which is 24 volts and 70 Amps > (no LS suffix). > > Questions: > Can I assume that my ALX-8421LS is a 12Volt, roughly 35 Amp alternator? > Can I assume that there is NO built-in regulator? > Should I slam it? note: I can use the forward weight (w&b). It only has 150 > hours on it. It is a klunker - but half the volts and half the amps > probably means a similar weight. > > Thanks for any help. > Ernest Kells - RV-9A O235-N2C, Wood Prop > Finish Kit 20% Complete > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Steve Richard" <steve(at)oasissolutions.com>
Date: Jul 05, 2002
Has anyone tried CircuitMaker (student version) at http://www.microcode.com/downloads/student.htm or Visio? Steve Richard -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Andy Karmy Subject: Re: AeroElectric-List: What is the easiest CAD program for my wirebook? I did the same as others and tried out all the free versions from various websites etc, in the end I liked TurboCad the best as it was similar to how other windows programs worked. However there are some features missing from the free version (like blocks and other advanced drawing tools) So I cruized over to ebay and was able to pickup and older version in the sealed box for $20. It works great and I have used it for panel layout and wiring diagrams. - Andy Karmy RV9A - Finishing ---------- Original Message ---------------------------------- From: "James Foerster" <jmfpublic(at)attbi.com> Date: Thu, 4 Jul 2002 23:11:38 -0700 > >The predrawn diagrams in the 'Connection are great, but I need to modify >and combine several of the "Z" diagrams. Does anyone have an opinion >which of the two affordable CAD programs are easier to learn? TurboCAD >or Intellicad? I intend to buy the program as the free versions seem to >have less in the way of tutorial and ease of use. At least that is what >the web sites suggest. >Thanks for any insight you might have. > >Jim Foerster J400 > > http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
ebook?
Date: Jul 05, 2002
Hi Steve; Circuit maker is meant for "testing" of circuit designs. It will produce nice schematic drawings, but this is not it's intended use. Unfortunately the student version is limited to 50 devices. A "device" consists of fuses, switches, etc. so it does not take long before all 50 are used up. If you are using it for a few separate, simple circuit drawings, it will work, but anything more complex or an overview of your system would require the full version which is very $$$$$$$. S. Todd Bartrim 13B rotary powered RV-9endurance (finish kit) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm > -----Original Message----- > From: Steve Richard [SMTP:steve(at)oasissolutions.com] > Sent: Friday, July 05, 2002 10:50 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: What is the easiest CAD program for > my wirebook? > > > > Has anyone tried CircuitMaker (student version) at > > http://www.microcode.com/downloads/student.htm > > or Visio? > > Steve Richard > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Andy > Karmy > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: What is the easiest CAD program for my > wirebook? > > > > I did the same as others and tried out all the free versions from various > websites etc, in the end I liked TurboCad the best as it was similar to > how > other windows programs worked. However there are some features missing > from > the free version (like blocks and other advanced drawing tools) So I > cruized > over to ebay and was able to pickup and older version in the sealed box > for > $20. It works great and I have used it for panel layout and wiring > diagrams. > > - Andy Karmy > RV9A - Finishing > > ---------- Original Message ---------------------------------- > From: "James Foerster" <jmfpublic(at)attbi.com> > Date: Thu, 4 Jul 2002 23:11:38 -0700 > > > > > >The predrawn diagrams in the 'Connection are great, but I need to modify > >and combine several of the "Z" diagrams. Does anyone have an opinion > >which of the two affordable CAD programs are easier to learn? TurboCAD > >or Intellicad? I intend to buy the program as the free versions seem to > >have less in the way of tutorial and ease of use. At least that is what > >the web sites suggest. > >Thanks for any insight you might have. > > > >Jim Foerster J400 > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 05, 2002
ebook? Well, that was a much more polite answer than the one I got when I suggested it several months ago. R ----- Original Message ----- From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> Subject: RE: AeroElectric-List: What is the easiest CAD program for my wir ebook? > > Hi Steve; > Circuit maker is meant for "testing" of circuit designs. It will > produce nice schematic drawings, but this is not it's intended use. > Unfortunately the student version is limited to 50 devices. A "device" > consists of fuses, switches, etc. so it does not take long before all 50 are > used up. If you are using it for a few separate, simple circuit drawings, it > will work, but anything more complex or an overview of your system would > require the full version which is very $$$$$$$. > > S. Todd Bartrim > 13B rotary powered > RV-9endurance (finish kit) > C-FSTB (reserved) > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > -----Original Message----- > > From: Steve Richard [SMTP:steve(at)oasissolutions.com] > > Sent: Friday, July 05, 2002 10:50 AM > > To: aeroelectric-list(at)matronics.com > > Subject: RE: AeroElectric-List: What is the easiest CAD program for > > my wirebook? > > > > > > > > Has anyone tried CircuitMaker (student version) at > > > > http://www.microcode.com/downloads/student.htm > > > > or Visio? > > > > Steve Richard > > > > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Andy > > Karmy > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: What is the easiest CAD program for my > > wirebook? > > > > > > > > I did the same as others and tried out all the free versions from various > > websites etc, in the end I liked TurboCad the best as it was similar to > > how > > other windows programs worked. However there are some features missing > > from > > the free version (like blocks and other advanced drawing tools) So I > > cruized > > over to ebay and was able to pickup and older version in the sealed box > > for > > $20. It works great and I have used it for panel layout and wiring > > diagrams. > > > > - Andy Karmy > > RV9A - Finishing > > > > ---------- Original Message ---------------------------------- > > From: "James Foerster" <jmfpublic(at)attbi.com> > > Date: Thu, 4 Jul 2002 23:11:38 -0700 > > > > > > > > > >The predrawn diagrams in the 'Connection are great, but I need to modify > > >and combine several of the "Z" diagrams. Does anyone have an opinion > > >which of the two affordable CAD programs are easier to learn? TurboCAD > > >or Intellicad? I intend to buy the program as the free versions seem to > > >have less in the way of tutorial and ease of use. At least that is what > > >the web sites suggest. > > >Thanks for any insight you might have. > > > > > >Jim Foerster J400 > > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Re:
> From: "Ernest Kells" <ernest.kells(at)sympatico.ca> > Subject: AeroElectric-List: Help With Alternator > > > I am starting to look at acquiring overvoltage protection for my > alternator.Perhaps I am too early. However, I need some info on > my alternator. Can > one of you help? > > I have a Electrosystem ALX-8421LS. The data plate is marked 12V. > No Amps > are specified. I can find NO documentation on this alternator > (Prestolite???). I can only find an ALX-8421 which is 24 volts > and 70 Amps > (no LS suffix). ******************************* Try these two web sites: http://www.lycoming.textron.com/support/service_publications/service_ins tructions_recent/SI1154J.pdf http://www.kellyaerospace.com/2002cd/Catalogs/PriceBook_ESI.pdf They both act like it is 12V, 70A. carl ________________________________________________________________________________
Date: Jul 05, 2002
> From: "Ernest Kells" <ernest.kells(at)sympatico.ca> > Subject: AeroElectric-List: Help With Alternator > > > I am starting to look at acquiring overvoltage protection for my > alternator.Perhaps I am too early. However, I need some info on > my alternator. Can > one of you help? > > I have a Electrosystem ALX-8421LS. The data plate is marked 12V. > No Amps > are specified. I can find NO documentation on this alternator > (Prestolite???). I can only find an ALX-8421 which is 24 volts > and 70 Amps > (no LS suffix). ********************************************** Just out of curosity, did you buy this from Wayne Riggs? There was an almost identical post on the Glastar net quite a while back. carl ________________________________________________________________________________
Date: Jul 05, 2002
Subject: Four New Email Lists At Matronics!!
Dear Listers, I've just added four new email Lists to the current lineup at Matronics. These new lists include: KRNet: krnet-List(at)matronics.com The RANS KR1 and KR2 Series Cub: cub-List(at)matronics.com The Piper J-3 Cub RV10: rv10-List(at)matronics.com The New 4-place RV from Van's! Europa: europa(at)matronics.com The Slick European Composite All the usual features are available with the new Lists including the search engine, archive download, 7-day List browse, and PhotoShare! To sign up for any or all of the new lists, please go to the List Subscription page and put in your email address and select the Lists of your choice. The URL for the Subscription page is: http://www.matronics.com/subscibe Don't forget that its your posts that generate traffic on the respective Lists! Post an introduction and a description of your project or dreams! Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 05, 2002
Subject: [With Good URL This Time!] Four New Email Lists At
Matronics!! [Typo in the subscribe page URL last time - SORRY! -Matt] Dear Listers, I've just added four new email Lists to the current lineup at Matronics. These new lists include: KRNet: krnet-List(at)matronics.com The RANS KR1 and KR2 Series Cub: cub-List(at)matronics.com The Piper J-3 Cub RV10: rv10-List(at)matronics.com The New 4-place RV from Van's! Europa: europa(at)matronics.com The Slick European Composite All the usual features are available with the new Lists including the search engine, archive download, 7-day List browse, and PhotoShare! To sign up for any or all of the new lists, please go to the List Subscription page and put in your email address and select the Lists of your choice. The URL for the Subscription page is: http://www.matronics.com/subscribe Don't forget that its your posts that generate traffic on the respective Lists! Post an introduction and a description of your project or dreams! Best regards, Matt Dralle Matronics Email List Admin. Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
From: "dswartzendruber(at)earthlink.net" <dswartzendruber(at)earthlink.net>
Date: Jul 06, 2002
I can find out what it is for you on Monday. David Swartzendruber Wichita >I have a Electrosystem ALX-8421LS. The data plate is marked 12V. No Amps >are specified. I can find NO documentation on this alternator >(Prestolite???). I can only find an ALX-8421 which is 24 volts and 70 Amps >(no LS suffix). > >Questions: >Can I assume that my ALX-8421LS is a 12Volt, roughly 35 Amp alternator? >Can I assume that there is NO built-in regulator? >Ernest Kells - RV-9A O235-N2C, Wood Prop > Finish Kit 20% Complete ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 4 Msgs - 07/04/02
Date: Jul 06, 2002
Hi Ernest, It looks as if you have the 24V Prestilote unit but visit this site http://www.2aps.com/esi_alt.htm, they have a lot of data on all alternators and I am sure you will find yours there. ________________________________________________________________________________
Date: Jul 06, 2002
Ernest, Found what I was looking for :
http://www.kellyaerospace.com/2002cd/Catalogs/PriceBook_ESI.pdfand click on product information in left window to see how alternator designations work ________________________________________________________________________________
Date: Jul 06, 2002
I have a Prestolite ALU-8421 which I was advised was 24v when purchasing my engine. It has 50 hours since new. Others on this list have said this is at least 70 amp. If anyone would like this, with voltage regulator and 24v. Light weight starter, let me know. I won't be using it. Lots of production plane using these. Marty in Brentwood TN -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of dswartzendruber(at)earthlink.net Subject: RE: AeroElectric-List: Help With Alternator --> I can find out what it is for you on Monday. David Swartzendruber Wichita >I have a Electrosystem ALX-8421LS. The data plate is marked 12V. No >Amps are specified. I can find NO documentation on this alternator >(Prestolite???). I can only find an ALX-8421 which is 24 volts and 70 >Amps (no LS suffix). > >Questions: >Can I assume that my ALX-8421LS is a 12Volt, roughly 35 Amp alternator? >Can I assume that there is NO built-in regulator? Ernest Kells - RV-9A >O235-N2C, Wood Prop Finish Kit 20% Complete = = =
Date: Jul 06, 2002
Subject: Re: Oil Pressure switch rating
> >Bob > >Do you happen to know what the current carrying capacity is of the oil >pressure switch B & C sells. Am contemplating using it to switch on the >Navaid wing leveler since they seem insistent on not having it on during >start up. Would probably need 7 amps tops going thru the normally open >set of contacts. I doubt that the draw is even that heavy. Are you really sure you want to do this with an oil pressure switch? First, I am skeptical that your electrical system is going to have any characteristics that are unfriendly to their electronics. Those oil pressure switches are not the most whippy switch I ever opened up . . . wouldn't mind using them for the classic tasks of driving an hour-meter, etc. but I don't think I'd run any really USEFUL accessory through them. If you really want to shut something off for any part of the flight operations, it's really hard to beat a switch on the panel. I've written the folks at Navaid several asking them to be more explicit on what parts of their product is at risk and offered free assistance in hardening up their circuitry. Never heard back from them. Sooo . . . odds are that they don't KNOW what parts are vulnerable and/or they don't KNOW what systems in the airplane are potential antagonists. They're simply repeating the decades old mantra that strives to shield 'delicate' electronics from 'nasty' gremlins . . . both of which don't exist. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2002
> > >Bob - thanks for that. I wonder why there is not such a thing as a faston >terminal strip. Thanks again, Steve. I think there are . . . I used to build them by mounting double tab male fast-ons on single row barrier strips and I've seen a number of commercial products. I note that others on the list have identified at least one manufacturer (WECO) . . . there have to be dozens. I'm just not familar with any. Bob . . . ________________________________________________________________________________
Date: Jul 06, 2002
wrote: >The guy would designed the Navaid is longer flying the friendly skies with us(aircraft >accident IIRC). I went to visit the Navaid "factory" some time ago and I do not recommend >that anyone using a Navaid do that. It's analagous to liking hot dogs or sandwich meat--you >really don't want to know how they're made. The Navaid folks just assemble the product >according to their instructions. They can do basic electronic trouble-shooting/diagnostics, >and give information off of their stat sheet, but that's about it. Where is the 'factory' ? (no I don't intend to go, but my hanger-mate with one might want to, despite your cautions; I guess he can handle the mystery-meat process). Also, does anyone recall who the original designer was? TIA ________________________________________________________________________________
Date: Jul 06, 2002
641 North Market Street Chattanooga, TN Be advised that there are two Market Streets (one in the "new" downtown section and another across the river) in Chattanooga and the "factory" looks like a house and the numbers aren't very visible from the street. Garfield Willis wrote: > > wrote: > > >The guy would designed the Navaid is longer flying the friendly skies with us(aircraft > >accident IIRC). I went to visit the Navaid "factory" some time ago and I do not recommend > >that anyone using a Navaid do that. It's analagous to liking hot dogs or sandwich meat--you > >really don't want to know how they're made. The Navaid folks just assemble the product > >according to their instructions. They can do basic electronic trouble-shooting/diagnostics, > >and give information off of their stat sheet, but that's about it. > > Where is the 'factory' ? (no I don't intend to go, but my hanger-mate > with one might want to, despite your cautions; I guess he can handle the > mystery-meat process). > > Also, does anyone recall who the original designer was? > > TIA > ________________________________________________________________________________
Date: Jul 06, 2002
> >Also, does anyone recall who the original designer was? > Doug Spears. Died in a Mustang II that crashed on takeoff ________________________________________________________________________________
From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net>
Subject: Coax Cable Routing
Date: Jul 06, 2002
Could someone please advise: Should coax cable for communication antenna be routed together with electrical wires? Would the electrical cables interfere with transmitting or receiving? The electrical cables are: flap motor power, nav, tail and taxi lights, fuel level, strobe power (14 volts, not the high side) and push to talk. Thanks in advance. Gabe A Ferrer (RV6 "final wiring" (when will it end?)) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Date: Jul 07, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Coax Cable Routing
> > >Could someone please advise: >Should coax cable for communication antenna be routed together with >electrical wires? They can be . . . >Would the electrical cables interfere with transmitting or receiving? >The electrical cables are: flap motor power, nav, tail and taxi lights, fuel >level, strobe power (14 volts, not the high side) and push to talk. >Thanks in advance. No . . . Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 07, 2002
Subject: microphone wiring
>Bob, > I've watched your posts on the RV-List, found them informative > and helpful. Your AeroElectric Connection book has been very helpful in > planning and wiring my RV-6. The bird flies like a dream, and so far > I've been able to keep the smoke in the wires. > > Thus far, I've not been able to find a good source of information > on the care and wiring of nav-com and intercoms. My plane is equipped > with an old King KX170B, Microair 720, with a Sigtronics SPA 400 > intercom. I have interconnected them with a simple switching arrangement > that allows selecting comm1 (King), comm 2, (MicroAir), both (audio > only), nav (audio for ident). > > My problem is, I've describe my circuitry to a good A&P, and I > think I've improperly wired the switches for comm selection. > > I've used a DPDT miniature toggle to switch the Mic audio and > Headset audio to either comm1, or comm 2, with a SPST miniature toggle to > either connect or remain open across the headset audio switch lugs of the > DPDT switch. The configuration works, and communications are clear, > according to all reports I've received during the last year. > > My A&P tells me that I should have also included the transmitter > key line in the switch, using a 3PDT switch, so as to key up the proper > transmitter. My gut tells me he's right, but now I'm curious to know why > the simpler circuit I've used hasn't caused problems during the last > year. Many times I've had both radios tuned to the same frequency, and > keying the mike has never created the squeal normally associated with two > transmitters using the same frequency at the same time. In fact, the > radio not selected will receive the information transmitted by the > other. I've used a hand-held radio to double check, and can not detect > any keying of the transmitter section of the non-selected radio when the > PTT switch is keyed, and I know that the transmit key line is connected > to both radios directly. > > What am I missing? > If you have confirmed that the non-selected transmitter is indeed passive then you're probably okay. I'm at a loss to explain why you are not having problems . . . the standard practice since day one has been to switch both mic-audio and PTT lines for the selected transmitter. The only thing I can think of is that some modern transmitters I've seen don't need the PTT line to make the transfer from receive to transmit. Microphones should break both the PTT and Mic-Audio lines when the PTT button is relaxed. This allows different microphones to share the same input to the transmitter without interfering with each other. Many modern amateur transmitters sense the microphone power current draw when a microphone is connected to the audio circuit via the PTT switch and use this to deduce the need to transfer from receive to transmit. I suspect that other manufacturers may be doing the same thing - which makes the separate PTT control lead unnecessary for those radios. Bob . . . -------------------------------------------- | People are far more willing to pay | | for being amused than for anything else. | | -Thomas Edison- | -------------------------------------------- Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 07, 2002
Greetings, Again I'd like to remind list users that a simple Google search of a part number will typically surprise and please you with the results. A quick Google search of this part number brought up the manufacturer's home page along with product details and a description of what each letter of the model number represents. Why ask the list when it is easier and quicker to do it yourself. In this case, ten characters typed into Google provides immediate results versus having to type a message to the list and hoping that someone does the research for you. Bruce -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of emrath Subject: RE: AeroElectric-List: Help With Alternator I have a Prestolite ALU-8421 which I was advised was 24v when purchasing my engine. It has 50 hours since new. Others on this list have said this is at least 70 amp. If anyone would like this, with voltage regulator and 24v. Light weight starter, let me know. I won't be using it. Lots of production plane using these. Marty in Brentwood TN -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of dswartzendruber(at)earthlink.net Subject: RE: AeroElectric-List: Help With Alternator --> I can find out what it is for you on Monday. David Swartzendruber Wichita >I have a Electrosystem ALX-8421LS. The data plate is marked 12V. No >Amps are specified. I can find NO documentation on this alternator >(Prestolite???). I can only find an ALX-8421 which is 24 volts and 70 >Amps (no LS suffix). > >Questions: >Can I assume that my ALX-8421LS is a 12Volt, roughly 35 Amp alternator? >Can I assume that there is NO built-in regulator? Ernest Kells - RV-9A >O235-N2C, Wood Prop Finish Kit 20% Complete = = = http://www.matronics.com/browselist/aeroelectric-list = = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Jul 07, 2002
Subject: RE: Help With Alternator
> > >Greetings, > >Again I'd like to remind list users that a simple Google search of a >part number will typically surprise and please you with the results. > >A quick Google search of this part number brought up the manufacturer's >home page along with product details and a description of what each >letter of the model number represents. > >Why ask the list when it is easier and quicker to do it yourself. In >this case, ten characters typed into Google provides immediate results >versus having to type a message to the list and hoping that someone does >the research for you. Agreed . . . to a point. When someone conducts a successful search on the 'net for any information that might be useful to others, it's helpful to let the list members know about both the question, answer and the method by which you found it. Bob . . . ________________________________________________________________________________
Date: Jul 07, 2002
Subject: Re Flightcom 403 intercom problems
Bob and other helpful people, Got the Flightcom 403 Intercom and the wiring must be goofed up because the sidetone isn't working (have a Apollo SL40), the volume controls won't affect the radio, and the auxilary inputs are very distorted and low volume. the intercomm volume also won't adjust the aux. volume either. Bob, you posted a 403mc wiring diagram about a year ago, 403mc.pdf which isn't on line anymore. Do you still have that diagram, maybe that woul be a good place to start. I'm ready to scrap the current harness and start over. If anyone else has some suggestions they would be appreciated. Bill Rounds N159RV thought I was done with the electrical. ________________________________________________________________________________
Subject: Source of 100 mv current shunts
Date: Jul 07, 2002
Bob, or anyone, It was mentioned in the 'Connection I believe that a 100 mv shunt for 100 amps is better than a 50 mv at 50 amps because the first one has a higher power rating. If the shunt is in the battery ground connection, starter current flows through it. I need an 20 amp range shunt, and at 50 mv this is 2.5 milliohms. With the starter drawing 200 amps or better, power is I squared R, or 10 watts. A 100 mv 40 amp shunt would be better, but I can't seem to find one on Google, Allied catalog, or Mouser. An alternative would be a Hall effect transducer. Does B&C still sell these? Jim Foerster ________________________________________________________________________________
Subject: Alternator Brushes-early failure
Date: Jul 07, 2002
Bob I have a 1975-1979 Honda civic alternator rated at 40 amps using a 3.25" dia pulley on my RV 6 that experienced early brush failure (400 hrs. tach time). I disassembled and inspected slip rings. Slip rings looked good so I gave them a highly polished finish using 600 grit aluminum oxide cloth on my lathe and reassembled using new brushes from the local auto parts store. I suspect I am experiencing brush failure once again (600 hrs. tach time) no charging at extremely heavy loads (40 plus amps). Is their a better quality brush available or what else could lead to early brush failure? John Stevenson N312SV ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Re Flightcom 403 intercom problems
> >Bob and other helpful people, > >Got the Flightcom 403 Intercom and the wiring must be goofed up because >the sidetone isn't working (have a Apollo SL40), the volume controls >won't affect the radio, and the auxilary inputs are very distorted and >low volume. the intercomm volume also won't adjust the aux. volume >either. > >Bob, you posted a 403mc wiring diagram about a year ago, 403mc.pdf which >isn't on line anymore. Do you still have that diagram, maybe that woul >be a good place to start. I'm ready to scrap the current harness and >start over. If anyone else has some suggestions they would be appreciated. Here's what I found in my archives on the 403mc series products . . . http://216.55.140.222/temp/403-403dManual.pdf http://216.55.140.222/temp/403mcManual.pdf http://216.55.140.222/temp/fc403mc.pdf Bob . . . ________________________________________________________________________________
Subject: SPST Switches
Date: Jul 08, 2002
Bob, or someone: I was ordering some of Bob's stuff this morning. I am completely following his philosophy and equipment, where possible. It is imbedded with some elegant logic. One problem. I am planning to use 9 ON-OFF switches in the panel, basically for everything except flap actuation and trim actions. The concept is positive control - no ambiguity. I.E: the taxi light is ON or it is OFF - simplicity is the ultimate sophistication. However, I notice that Bob does not list this type of switch. I really don't want an ON-OFF-ON switch (a centre position) for binary situations. I could possibly be talked into an ON-OFF-(ON) for the boost pump. This surprised me. I was thinking about a switch like AN3021-2 (MS35058-22). Am I missing something here ? ? One anomaly: I have installed a Cessna Start switch (read today's article on PropWash for possible big brother implications to GA operators not taking sufficient precautions to prevent theft). I guess someone may want to steal my little RV-9A to splat it against a few thousand tons of concrete and steel. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 20% Complete ________________________________________________________________________________
Subject: Re: SPST Switches
Date: Jul 08, 2002
Ernest Kells wrote: > > > One problem. I am planning to use 9 ON-OFF switches in the panel, basically > for everything except flap actuation and trim actions. The concept is > positive control - no ambiguity. I.E: the taxi light is ON or it is OFF - > simplicity is the ultimate sophistication. However, I notice that Bob does > not list this type of switch. I really don't want an ON-OFF-ON switch (a > centre position) for binary situations. I could possibly be talked into an > ON-OFF-(ON) for the boost pump. > *** This is something I find endlessly annoying in my Sundowner. A row of toggle switches - some of them are binary, some of them trinary. You can't just run your hand across the switches and know they're all off. Or ON, for that matter. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jul 08, 2002
>I was ordering some of Bob's stuff this morning. I am completely following >his philosophy and equipment, where possible. It is imbedded with some >elegant logic. > >One problem. I am planning to use 9 ON-OFF switches in the panel, basically >for everything except flap actuation and trim actions. The concept is >positive control - no ambiguity. I.E: the taxi light is ON or it is OFF - >simplicity is the ultimate sophistication. However, I notice that Bob does >not list this type of switch. I really don't want an ON-OFF-ON switch (a >centre position) for binary situations. I could possibly be talked into an >ON-OFF-(ON) for the boost pump. Take a look at chapter 8 in the book. The switches we sell offer every combination you might need but not necessarily a switch that is LIMITED to any particular task. Our S700-1-3 switch is a single pole, double throw switch with the capability of being an ON-ON function. It becomes an ON-OFF function when you don't hook up the other "on" to anything. >This surprised me. I was thinking about a switch like AN3021-2 >(MS35058-22). Am I missing something here ? ? > >One anomaly: I have installed a Cessna Start switch (read today's article >on PropWash for possible big brother implications to GA operators not taking >sufficient precautions to prevent theft). I guess someone may want to steal >my little RV to splat it against a few thousand tons of concrete and >steel. Fear is the biggest tool anyone has to bend you to their will irrespective of the logic or infringements upon your rights. A keyed mag switch is a minor inconvenience if someone wants to steal your airplane. I once brought a rental airplane home after I had lost the key. Didn't even need any tools. With my bare fingers, I was able to wiggle the terminals on the back of the switch until they broke off. I propped the engine and replaced the terminals when I got home. Most mags are accessible trough oil check doors. A pair of dikes will get both mags hot in a second or two. Twin engine airplanes of ALL types do not have key-switches . . . gee, if one is looking for a really BIG hammer, a KingAir would make a much bigger mess than an RV . . . A hardened chain and lock on the prop hub IS theft prevention. A key-switch is not. Common folks. If you used the time you spent watching talking heads on TV working on your airplane instead, you'll be much happier with the result. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 08, 2002
> >Ernest Kells wrote: > > > > > > One problem. I am planning to use 9 ON-OFF switches in the panel, > basically > > for everything except flap actuation and trim actions. The concept is > > positive control - no ambiguity. I.E: the taxi light is ON or it is OFF - > > simplicity is the ultimate sophistication. However, I notice that Bob does > > not list this type of switch. I really don't want an ON-OFF-ON switch (a > > centre position) for binary situations. I could possibly be talked into an > > ON-OFF-(ON) for the boost pump. > > >*** This is something I find endlessly annoying in my Sundowner. A row of >toggle switches - some of them are binary, some of them trinary. You can't >just run your hand across the switches and know they're all off. Or ON, >for that matter. Which ones are not OFF when the full down is selected? Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Alternator Brushes-early failure
> >Bob > >I have a 1975-1979 Honda civic alternator rated at 40 amps using a 3.25" >dia pulley on my RV 6 that experienced early brush failure (400 hrs. >tach time). I disassembled and inspected slip rings. Slip rings looked >good so I gave them a highly polished finish using 600 grit aluminum >oxide cloth on my lathe and reassembled using new brushes from the local >auto parts store. I suspect I am experiencing brush failure once again >(600 hrs. tach time) no charging at extremely heavy loads (40 plus >amps). Is their a better quality brush available or what else could lead >to early brush failure? Does it charge under lighter loads? Have you measured the voltage to the field while in operation? With light loads at cruise RPM, field voltage can go down below 2 volts with a properly working alternator. With one diode open, the voltage never goes below 2 volts and the alternator becomes unable to carry full loads. 600 grit abrasive on a slip ring surface is only slightly better than 100 grit. Slip rings need to be diamond tool cut. You can polish with fine steel wool using very light pressure and a slow turning speed in the lathe. The finish you're trying to achieve is on the order of 100 micro-inches of roughness or better. 600 grit has a spacing of 1670 micro- inches and even the scratches are all parallel to the direction of rotation, they'll work pretty hard on the brush surface. What brand is this alternator? If not an ND, have you considered a junk-yard takeoff? The ND alternator with 100,000 miles on it is a better alternator than many other new/overhauled offerings. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Source of 100 mv current shunts
> > >Bob, or anyone, > It was mentioned in the 'Connection I believe that a 100 mv shunt >for 100 amps is better than a 50 mv at 50 amps because the first one has >a higher power rating. If the shunt is in the battery ground >connection, starter current flows through it. I need an 20 amp range >shunt, and at 50 mv this is 2.5 milliohms. With the starter drawing 200 >amps or better, power is I squared R, or 10 watts. A 100 mv 40 amp >shunt would be better, but I can't seem to find one on Google, Allied >catalog, or Mouser. > An alternative would be a Hall effect transducer. Does B&C still >sell these? The electrical system instrumentation chapter is going to be revised with next revision. The idea of putting a shunt in the battery lead was a weak attempt to satisfy the desire to have a minus-0-plus style battery ammeter. In years since I published that section, the error of my ways have been fully exposed. Consider using one of the power distribution diagrams from appendix Z as published. The battery ammeter is not a superior indicator system and it has a lot of system design problems. VM1000 and others have hall effect sensors that you may easily use as a battery ammeter if you so choose. Wouldn't do it that way on my airplane. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Robert L. Nuckolls, III wrote: > > > > ON-OFF-(ON) for the boost pump. > > > > >*** This is something I find endlessly annoying in my Sundowner. A row of > >toggle switches - some of them are binary, some of them trinary. You can't > >just run your hand across the switches and know they're all off. Or ON, > >for that matter. > > Which ones are not OFF when the full down is selected? > *** Offhand, the rotating-beacon/strobe switch. OFF is in the middle for this one. Full down is "beacons and strobe both". Also, the landing/taxi light switch. Up is landing, down is taxi, off is in the middle. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Jul 08, 2002
David Swartzendruber Kelly Aerospace Aerospace Engineering Division 316-755-3097 The VM1000 will not show negative current. They intend for their current sensor to be used to sense alternator current only. If you use it as a battery ammeter, battery discharge will be shown as zero. I haven't demonstrated this to myself, but that is what the guys at Vision Microsystems told me. David Swartzendruber Wichita > > VM1000 and others have hall effect sensors that you > may easily use as a battery ammeter if you so choose. > Wouldn't do it that way on my airplane. > > Bob . . . > ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Comparing apples and oranges . . .
http://209.134.106.21/temp/Apples_and_Oranges.pdf Hmmm . . . wonder how prunes and watermelons compare . . . Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Generator problem
I know this is off topic... off - list actually... but if someone could give me a few pointers I'd appreciate it. I have a 5kw aux power unit in my boat that has started acting up. It will put out 120 volts for about 20 minutes and then the voltage will drop to just 8 -10 or less, just slightly off the bottom of the meter. There aren't any other indications and repeated attempts at restarting the generator and putting it on line show no voltage. After a few days it will once again work fine for a while. What sort of things can I check to figure out what has gone bad? The little engine that powers it seems to run fine, just no output. Thanks, Vince Ackerman ________________________________________________________________________________
Date: Jul 08, 2002
> >Robert L. Nuckolls, III wrote: > > > > > > ON-OFF-(ON) for the boost pump. > > > > > > >*** This is something I find endlessly annoying in my Sundowner. A row of > > >toggle switches - some of them are binary, some of them trinary. You > can't > > >just run your hand across the switches and know they're all off. Or ON, > > >for that matter. > > > > Which ones are not OFF when the full down is selected? > > >*** Offhand, the rotating-beacon/strobe switch. OFF is in the middle for >this one. Full down is "beacons and strobe both". Also, the landing/taxi >light switch. Up is landing, down is taxi, off is in the middle. Interesting. I've got several hundred hours in a Sundowner and I didn't recall that. I don't think they'd get that certified these days. Of course, that airplane was certified under kinder, gentler rules . . . Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: Generator problem
> >I know this is off topic... off - list actually... but if someone could >give me a few pointers I'd appreciate it. I have a 5kw aux power unit in my >boat that has started acting up. It will put out 120 volts for about 20 >minutes and then the voltage will drop to just 8 -10 or less, just slightly >off the bottom of the meter. There aren't any other indications and repeated >attempts at restarting the generator and putting it on line show no voltage. >After a few days it will once again work fine for a while. > >What sort of things can I check to figure out what has gone bad? The little >engine that powers it seems to run fine, just no output. Depending on the age of this machine, it probably has slip rings and brushes. Does it have a lot of time on it? Do you have a service manual for it? Is there a "black box" associated with it that might be a regulator for the alternator? If you can identify wires from a black box that might carry field excitation voltage to the alternator, some voltage measurements during a brownout would be helpful. If the field voltage goes up as the output voltage falls, then I'd look into brush problems. Otherwise, it's most likely a regulator problem. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Thanks, Bob. I will drop the idea of measuring current through the battery. It would only be useful if there were a way to integrate the current to estimate watt-hours lost from the battery capacity. As it is, tracking the voltage on the busses should be good enough. Above 12.5 volts, no battery draw. This will save me some trouble. Jim Foerster J400--building ________________________________________________________________________________
Date: Jul 08, 2002
Robert L. Nuckolls, III wrote: > > > Which ones are not OFF when the full down is selected? > > > > >*** Offhand, the rotating-beacon/strobe switch. OFF is in the middle for > >this one. Full down is "beacons and strobe both". Also, the landing/taxi > >light switch. Up is landing, down is taxi, off is in the middle. > > Interesting. I've got several hundred hours in a Sundowner > and I didn't recall that. I don't think they'd get that > certified these days. Of course, that airplane was certified > under kinder, gentler rules . . . > *** In 1974. Do you think there'd be any hope of getting an OFF-ON-ON arrangement approved through the 337 process? Do such switches eist? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jul 08, 2002
Section 11 in the 'Connection shows a number of ideas for hooking up OFF-ON-ON DPDT S700-2-10. It is an interesting read because in a couple examples, he hooks the supply to what one normally expects is the output to achieve some interesting logic. Tom Barnes -6 all electric, budget shot. ----- Original Message ----- From: <jerry(at)tr2.com> Subject: Re: AeroElectric-List: Re: SPST Switches > > Robert L. Nuckolls, III wrote: > > > > Which ones are not OFF when the full down is selected? > > > > > > >*** Offhand, the rotating-beacon/strobe switch. OFF is in the middle for > > >this one. Full down is "beacons and strobe both". Also, the landing/taxi > > >light switch. Up is landing, down is taxi, off is in the middle. > > > > Interesting. I've got several hundred hours in a Sundowner > > and I didn't recall that. I don't think they'd get that > > certified these days. Of course, that airplane was certified > > under kinder, gentler rules . . . > > > *** In 1974. > > Do you think there'd be any hope of getting an OFF-ON-ON arrangement > approved through the 337 process? Do such switches eist? > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED RE: BATTERY SWITCHES
Date: Jul 09, 2002
G'day Bob, I am planning on having two alternators, a main and standby. To ensure that both do not operate at the same time I propose to control them through a single three position switch marked Off-Main Alt-Standby Alt. Does this need to be an exotic break-before-make, or make before break, switch, or will a simple toggle do? I thought a toggle would function as a break then make switch, with any microsecond delay with no alternator power being taken up by my very well maintained RG battery, which would give the cockpit toys a nice ride? Thanks for your help, David Francis VH-ZEE ________________________________________________________________________________
Date: Jul 08, 2002
> >Robert L. Nuckolls, III wrote: > > > > Which ones are not OFF when the full down is selected? > > > > > > >*** Offhand, the rotating-beacon/strobe switch. OFF is in the middle for > > >this one. Full down is "beacons and strobe both". Also, the landing/taxi > > >light switch. Up is landing, down is taxi, off is in the middle. > > > > Interesting. I've got several hundred hours in a Sundowner > > and I didn't recall that. I don't think they'd get that > > certified these days. Of course, that airplane was certified > > under kinder, gentler rules . . . > > >*** In 1974. > > Do you think there'd be any hope of getting an OFF-ON-ON arrangement >approved through the 337 process? Do such switches eist? they exist. the stumbling block may be if they exist in the same style as the original switches. I could check the specification control drawings for the switches used on the Sundowner at RAC. Will have to wait until next week. I'm in a meeting at the wrong facility all day tomorrow and then I'll be off the rest of the week to the Lancair facility. I'm doing a custom seminar for their troops. What you're needing is a switch with the same functionality as our S700-2-10. This switch has a progressive transfer that would bring the strobe on in the mid position and make the beacon wait until the switch was full up. Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Re: SEC: UNCLASSIFIED RE: BATTERY SWITCHES
> > >G'day Bob, >I am planning on having two alternators, a main and standby. To ensure that >both do not operate at the same time I propose to control them through a >single three position switch marked Off-Main Alt-Standby Alt. > >Does this need to be an exotic break-before-make, or make before break, >switch, or will a simple toggle do? > >I thought a toggle would function as a break then make switch, with any >microsecond delay with no alternator power being taken up by my very well >maintained RG battery, which would give the cockpit toys a nice ride? You want to AVOID making any part common to both systems. For example, if your single selector switch broke an over-center spring, you could end up with BOTH alternators down. Why make this complicated? It doesn't hurt anything if both alternators are on at the same time. See figure Z-12 in . . . http://216.55.140.222/articles/Rev10/z10.pdf Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 08, 2002
> > >Thanks, Bob. I will drop the idea of measuring current through the >battery. It would only be useful if there were a way to integrate the >current to estimate watt-hours lost from the battery capacity. As it >is, tracking the voltage on the busses should be good enough. Above >12.5 volts, no battery draw. > This will save me some trouble. Obviously, if you WANT to track watt-seconds of energy transfer into and out of the battery, you'll need a bi-polar current sensor of reasonable accuracy. The hall effect sensor is the way to go. See http://www.powell.com/hallfect.html http://content.honeywell.com/sensing/prodinfo/current/ These are VERY accurate http://catalog.sensing.honeywell.com/ss.asp?FAM=current&FT_2148=21829 This critter is less expensive but you need to add your own amplifier. http://catalog.sensing.honeywell.com/datasheet.asp?PN=CSLA1CD&FAM=current&P=21830 Further, the easiest thing to do might indeed be the 100mv shunt rated for starter current surges. One of these could be beefy enough to take 200A for short times. http://www.deltecco.com/WO2-100MV-DC.html Bob . . . ________________________________________________________________________________
Date: Jul 08, 2002
Subject: velcro for battery boxes
In a message dated 07/05/2002 2:55:43 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com Richard Dudley writes: " Bob, You have mentioned in earlier posts about securing RG batteries with Velcro, avoiding the need for the weight of conventional battery boxes. Do you have any additional information about the Velcro suitable for this application? I'd be interested in any details about specific materials, dimensions, securing methods and sources of supply. Thanks in advance. Richard Dudley" 7/8/2002 Hello Richard, I haven't seen any other replies so please let me take a shot at this. I have secured my B&C RG battery with a combination of aluminum angles, thin plywood, and velcro. It is not really a battery box per se, but maybe more of a battery cage since I made no attempt to seal it, drain it, or vent it in any way. The aluminum angles are secured to the inside fuselage bottom in the baggage compartment with layers of fiberglass and epoxy. The cage is sized to fit my specific battery. There are slots cut into the aluminum angles such that two inch wide velcro strips purchased at a local fabric store can be threaded through the slots. Two pieces of thin plywood shield both the top of the battery and the forward face so that any wire connections cannot come into contact with any baggage. (The inboard side, the outboard side, and the back are shielded by aircraft structure). There are either slots or notches at appropriate places in the plywood pieces that the velcro strips either go through are are held in by tension. The velcro is fastened by threading a loop piece of velcro through one aluminum angle and a hook piece of velcro through the other opposite aluminum angle. By facing the velcro hooks and loops in the proper manner and bringing the free ends up over the piece of plywood on the top and then mashing them together one can form a complete loop with four layers of velcro cloth connecting together across the top of the battery. Two of these velcro loops run fore and aft and one runs crosswise. It Makes a total of 12 strips of cloth running across the top of the battery. The direction of pull across the top and the 90 degree bend going down the sides make it almost impossible for the velcro hooks and loops to separate -- the nylon cloth strips would have to fail in tension before the hooks and loops would separate. It is light, simple, fairly inexpensive, and strong. Seems to fill my needs. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: Jul 08, 2002
Subject: microphone gain & MicroAir 760 radio
The Microair 760 manual talks about adjusting the microphone gain for use in noisy environments, but there don't seem to be any controls on the radio for this. Anyone know how this works? Do some headsets have such a control on them? While we're on the subject, I'm having a problem with my Flightcom 403mc intercom. I can hear the radio loud & clear, but the intercom itself is extremely quiet. I can just barely hear my passenger talking, even with the intercom volume turned way up. The passenger has the same problem hearing me. Any ideas? http://sbc.yahoo.com ________________________________________________________________________________
Date: Jul 08, 2002
Subject: Ignition Noise in the Audio
I need a little help thinking this through: I am getting excessive ignition noise audible in my comm radio, a Microair 760. It takes about 80% of the available squelch to cover the noise when no one is transmitting. My plastic airplane has an O-200. It has 2 Bendix S4 mags on it, and no alternator (radio from battery only). I noticed that a handheld radio also picks up a lot of ignition noise from the engine when held near the airplane, so I think my Microair is probably not the culprit. I notice that when only one mag is powering the engine things get a little quieter (requiring only about 65% of the available squelch). It doesn't seem to matter which mag, though one mag makes a slightly different sound than the other. The only thing I have tried so far is to pull the p-leads from both mags and run the engine. 95% of the noise is still there. This makes me think that I am getting the noise directly from the mags themselves, or probably more likely the ignition harness. I have heard of people using filter capacitors on mags. Do I need one of these? Or, alternately, I think my ignition harness is of the sheilded type, but its old. Do their sheilding properties diminish with age? Or if I had one broken shield on each harness, would this also cause this kind of problem? How can I be sure that I have a shielded harness? My wires have a greenish braided covering with threaded ends... Thanks for any info anyone may provide! Matt Prather VariEze N34RD ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: microphone gain & MicroAir 760 radio
> >The Microair 760 manual talks about adjusting the microphone gain for use >in noisy environments, >but there don't seem to be any controls on the radio for this. Anyone >know how this works? Do >some headsets have such a control on them? I'm totally mystified as to why anyone would adjust a gain to compensate for noisy environment . . . the end product of received signal intelligibility is a function of signal to noise ratio. Adjusting system gain has an equal effect upon both signal (voice) and noise. If you have a problem with perceived background noise in your signal as others hear you, you need a better microphone. Some do much a much better job than others at attenuating ambient noise with respect to your voice. >While we're on the subject, I'm having a problem with my Flightcom 403mc >intercom. I can hear the >radio loud & clear, but the intercom itself is extremely quiet. I can >just barely hear my >passenger talking, even with the intercom volume turned way up. The >passenger has the same >problem hearing me. Any ideas? This IS a gain problem within the intercom. The procedure is to first set up the gains on your intercom and headsets such that you can speak to each other comfortably. THEN adjust the volume on the radio so that it too is at the desired level. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: Ignition Noise in the Audio
> >I need a little help thinking this through: > >I am getting excessive ignition noise audible in my comm radio, a >Microair 760. It >takes about 80% of the available squelch to cover the noise when no one is >transmitting. My plastic airplane has an O-200. It has 2 Bendix S4 >mags on it, >and no alternator (radio from battery only). I noticed that a handheld >radio also >picks up a lot of ignition noise from the engine when held near the >airplane, so I >think my Microair is probably not the culprit. I notice that when only >one mag is >powering the engine things get a little quieter (requiring only about >65% of the >available squelch). It doesn't seem to matter which mag, though one mag >makes >a slightly different sound than the other. > >The only thing I have tried so far is to pull the p-leads from both mags >and run the >engine. 95% of the noise is still there. This makes me think that I am >getting the noise >directly from the mags themselves, or probably more likely the ignition >harness. I have >heard of people using filter capacitors on mags. Do I need one of >these? Or, alternately, >I think my ignition harness is of the sheilded type, but its old. Do >their sheilding properties >diminish with age? Or if I had one broken shield on each harness, would >this also cause >this kind of problem? How can I be sure that I have a shielded harness? > My wires have >a greenish braided covering with threaded ends... Used to fly a Cub with a C-85 engine that was about the loudest ignition noise source I'd ever seen. Radios of any kind were all but totally overwhelmed. Capacitors on the p-leads are not helpful. The problem lies totally within the plug harnesses and to a lesser extent with magneto design (if they are plastic cap mags). Bob . . . ________________________________________________________________________________
Subject: How to wire a GPS/NAV Indicator
Date: Jul 09, 2002
I would be grateful if any of the experienced builders on the list could advise how to wire a single VOR display (KI-206) to both a GPS (KLN-35) and Nav (KNS-80). I have a relay (Advanced Electronics RSU-21 originally for Loran/nav) and have the appropriate pinouts. Wiring this, the control switch (GPS/NAV) and the WAYPT and MSG lights is no problem, however I'm not sure if I have to switch or ground the stator connections from the KNS-80 to the KI-206 while the GPS (which uses only FROM,TO,Left,Right) is used. Since the relay unit includes both relay and CMOS switching I am assuming I should use the relay connections for the display as a failsafe. (I think of the NAV as the failsafe as this would allow an ILS/glideslope approach if the relay unit failed and the weather closed in.) The CMOS could switch the LED indicators giving the added benefit that if the relay unit went down neither the NAV or GPS LED would light. Does my logic make sense? Any further suggestions? Mike Gray ________________________________________________________________________________
Date: Jul 08, 2002
Hello, Bob and others: Thanks to everyone for their response. Per Bob's email I will go with the S700-1-3, wiring the one side. Two comments: First, I understand Jerry's comments regarding the collage of switches on his Sundowner. I can live with the above solution, but I would prefer the ON OFF scenario. Binary. Not sometimes the switch is off in the centre, sometimes in the down position. I was going to get the coloured booties (red, white blue and green) to organize and colour-code the functions. This is similar to the flight controls. On a go-around do you do push in the throttle, pull out the mixture, er was that push or pull the prop, carb heat ? ? boost pump ?? A complicated solution must have some major benefit to offset simplicity and consistancy. Second, Bob's comments about the usefulness of the Cessna start switch is well known. He is right on all counts. However, when some thief crashes my plane into a schoolyard full of kids will the lawyers make certain that Bob's logic is perfectly understandable to all the jurors. Thanks again for everyone's help. ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: SPST Switches > Fear is the biggest tool anyone has to bend you to their > will irrespective of the logic or infringements upon > your rights. A keyed mag switch is a minor inconvenience > if someone wants to steal your airplane. I once brought > a rental airplane home after I had lost the key. Didn't > even need any tools. With my bare fingers, I was able > to wiggle the terminals on the back of the switch until > they broke off. I propped the engine and replaced the > terminals when I got home. Most mags are accessible > trough oil check doors. A pair of dikes will get both > mags hot in a second or two. Twin engine airplanes of > ALL types do not have key-switches . . . gee, if one > is looking for a really BIG hammer, a KingAir would > make a much bigger mess than an RV . . . > > A hardened chain and lock on the prop hub IS theft > prevention. A key-switch is not. > > Common folks. If you used the time you spent watching > talking heads on TV working on your airplane instead, > you'll be much happier with the result. > > Bob . . . > > |-------------------------------------------------------| > | Too often we enjoy the comfort of opinion without the | > | discomfort of thought. ~ John F. Kennedy | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: velcro for battery boxes
Thanks for your reply OC! I was beginning to think that I was the only one who received my post on the list. The general idea is attractive. I was hoping to avoid having to "invent" details that others had already worked out. Regards, Richard Dudley BAKEROCB(at)aol.com wrote: > > > In a message dated 07/05/2002 2:55:43 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com Richard Dudley > writes: > > " Bob, You have mentioned in earlier posts about securing RG batteries with > Velcro, avoiding the need for the weight of conventional battery boxes. > Do you have any additional information about the Velcro suitable for > this application? I'd be interested in any details about specific > materials, dimensions, securing methods and sources of supply. > Thanks in advance. Richard Dudley" > > 7/8/2002 > > Hello Richard, I haven't seen any other replies so please let me take a shot > at this. I have secured my B&C RG battery with a combination of aluminum > angles, thin plywood, and velcro. > > It is not really a battery box per se, but maybe more of a battery cage since > I made no attempt to seal it, drain it, or vent it in any way. The aluminum > angles are secured to the inside fuselage bottom in the baggage compartment > with layers of fiberglass and epoxy. The cage is sized to fit my specific > battery. > > There are slots cut into the aluminum angles such that two inch wide velcro > strips purchased at a local fabric store can be threaded through the slots. > Two pieces of thin plywood shield both the top of the battery and the > forward face so that any wire connections cannot come into contact with any > baggage. (The inboard side, the outboard side, and the back are shielded by > aircraft structure). > > There are either slots or notches at appropriate places in the plywood pieces > that the velcro strips either go through are are held in by tension. The > velcro is fastened by threading a loop piece of velcro through one aluminum > angle and a hook piece of velcro through the other opposite aluminum angle. > By facing the velcro hooks and loops in the proper manner and bringing the > free ends up over the piece of plywood on the top and then mashing them > together one can form a complete loop with four layers of velcro cloth > connecting together across the top of the battery. > > Two of these velcro loops run fore and aft and one runs crosswise. It Makes a > total of 12 strips of cloth running across the top of the battery. > > The direction of pull across the top and the 90 degree bend going down the > sides make it almost impossible for the velcro hooks and loops to separate -- > the nylon cloth strips would have to fail in tension before the hooks and > loops would separate. > > It is light, simple, fairly inexpensive, and strong. Seems to fill my needs. > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > ________________________________________________________________________________
Date: Jul 09, 2002
> I was beginning to think that I was the only one who received my post on > the list. > The general idea is attractive. I was hoping to avoid having to "invent" > details that others had already worked out. I have another perspective, having just installed duel batteries on my Cozy IV. Per Cozy plans, I wrapped the lower part of the battery in duct tape and did a small layup onto the spar and an inch up the sides of the battery. After cure, this forms a perfect tray. Next I'll add an aluminum strap bolted to the firewall. This is the way we epoxy types do it. John Slade Cozy IV http:/kgarden.com/cozy ________________________________________________________________________________
Date: Jul 09, 2002
Thanks for the reply, John. Regards, Richard Dudley -6A Panel John Slade wrote: > > > > I was beginning to think that I was the only one who received my post on > > the list. > > The general idea is attractive. I was hoping to avoid having to "invent" > > details that others had already worked out. > > I have another perspective, having just installed duel batteries on my Cozy > IV. > Per Cozy plans, I wrapped the lower part of the battery in duct tape and did > a small layup onto the spar and an inch up the sides of the battery. After > cure, this forms a perfect tray. Next I'll add an aluminum strap bolted to > the firewall. This is the way we epoxy types do it. > John Slade > Cozy IV http:/kgarden.com/cozy > ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Re: How to wire a GPS/NAV Indicator
> >I would be grateful if any of the experienced builders on the list could >advise how to wire a single VOR display (KI-206) to both a GPS (KLN-35) >and Nav (KNS-80). > >I have a relay (Advanced Electronics RSU-21 originally for Loran/nav) >and have the appropriate pinouts. Wiring this, the control switch >(GPS/NAV) and the WAYPT and MSG lights is no problem, however I'm not >sure if I have to switch or ground the stator connections from the >KNS-80 to the KI-206 while the GPS (which uses only FROM,TO,Left,Right) >is used. > >Since the relay unit includes both relay and CMOS switching I am >assuming I should use the relay connections for the display as a >failsafe. (I think of the NAV as the failsafe as this would allow an >ILS/glideslope approach if the relay unit failed and the weather closed >in.) The CMOS could switch the LED indicators giving the added benefit >that if the relay unit went down neither the NAV or GPS LED would light. > >Does my logic make sense? Any further suggestions? I'd have to study the manuals for the various components. I did a switch-box design B&C a few years back that would make a King vor combo share the obs/cdi indicator with several brands of gps receivers. We did ALL of the switching between radios and indicator on dry relay contacts to avoid any issues with leakages, on-resistance, silicon sneak paths, etc. I'm not sure what your options are with respect to cmos switching . . . Any connections not shared by the indicator to a given radio are simply left unconnected. Don't ground them or otherwise terminate them unless you have installation instructions that specifically tell you otherwise. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2002
> >In a message dated 07/05/2002 2:55:43 AM Eastern Daylight Time, >aeroelectric-list-digest(at)matronics.com Richard Dudley >writes: > >" Bob, You have mentioned in earlier posts about securing RG batteries with > Velcro, avoiding the need for the weight of conventional battery boxes. > Do you have any additional information about the Velcro suitable for > this application? I'd be interested in any details about specific > materials, dimensions, securing methods and sources of supply. > Thanks in advance. Richard Dudley" I've got a field trip planned to several stores to see if I can find 1" webbing with 6" or longer, mating velcro strips SEWN on. This combo has a tensile strength of better than 200#. Two strips would qualify as adequate restraint for a battery mounted behind you in an airplane. For any other technique, make sure what you do will resist 300-400# pull on a rapidly decelerating mass of lead and plastic. I seem to recall that one of amateur-built aviation's famous got creamed in the back of the head with a toolbox a while back. Batteries aren't any friendlier. Batteries mounted forward of the passengers and crew are not so critical. RV's with the battery against the firewall poses no big crash threat that can be mitigated by heavy restraints. Some have argued a reduction in fire hazard by putting rubber booties over exposed hardware but belive me, those booties will be no barrier to crash driven shorts finding their way to the nuts and bolts. If your airplane gets so bent up that there is risk of shorting out the hot wire between battery (+) and the battery contactor, it's unlikely that your body will care much. Bob . . . ________________________________________________________________________________
Date: Jul 09, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: microphone gain (dissenting opinion)
"Robert L. Nuckolls, III" wrote: > > > > > >The Microair 760 manual talks about adjusting the microphone gain for use > >in noisy environments, > >but there don't seem to be any controls on the radio for this. Anyone > >know how this works? Do > >some headsets have such a control on them? > > I'm totally mystified as to why anyone would adjust a gain > to compensate for noisy environment . . . the end product of > received signal intelligibility is a function of signal to > noise ratio. Adjusting system gain has an equal effect upon > both signal (voice) and noise. If you have a problem with > perceived background noise in your signal as others hear > you, you need a better microphone. Some do much a much > better job than others at attenuating ambient noise with > respect to your voice. > snipped Bob, I hate to disagree with someone of your knowledge & experience, but I feel that an expanded perspective might be in order. There can be some justification for Microair's instructions because gain can actually affect overall signal to noise. Some observations are in order. This stuff is a lot easier to demonstrate than describe, so bare with me. Consider first that any amplification system has a limited maximum output. At some level of ambient noise, plus signal (voice), all multiplied times the gain of the system, you will drive the system into distortion. Signal to noise just got a lot worse than measured specs for the system. If you reduce the system gain, you can now position the mic closer to your mouth and speak louder as well. You have just improved the overall signal to noise ratio by raising the input signal level relative to the input noise level. So, while the previous statements were technically correct, this is 'the rest of the story.' re: adjusting mic gain. Many electret condenser mics used in today's headsets have gain controls included in the mic module. These mic modules include a preamplifier stage to raise the level of the low-output condenser mic element to traditional dynamic mic levels to match the rather loose 'standard' signal level expected by a/c radios. The points about system gain apply to this single stage of gain as well. Lightspeed told me to lower the mic gain on my 15XL's when I had a problem with intermittant noise in the headsets. I hope this is useful info. Charlie audio engineer in another life Slobovia Outernational Airport Pocahontas MS (Yes, there is a story behind the name.) ________________________________________________________________________________
Date: Jul 09, 2002
Subject: Reading Battery Amperage
In a message dated 07/09/2002 2:52:47 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com "David Swartzendruber" dswartzendruber(at)earthlink.net writes: "The VM1000 will not show negative current. They intend for their current sensor to be used to sense alternator current only. If you use it as a battery ammeter, battery discharge will be shown as zero. I haven't demonstrated this to myself, but that is what the guys at Vision Microsystems told me" . David Swartzendruber 7/9/2002 Hello David, I have a VM1000 system installed in my airplane under construction and I find what you were told to be a bit puzzling. My amperage transducer is installed on the alternator output (B cable) per VM instructions. Here is how their instructions for installing the amperage transducer read: "Route the wire which originates from the alternator output (usuallly marked 'BAT' INTO the circuit board side and OUT the sensor (round black device) side. See Figure 11: Amps Transducer Orientation. If properly installed, the AMPS readout will increase as more electrical loads are turned on and the alternator is active Shielded alternator wire is OK". My opinion is that anytime a wire running through the transducer has current flowing into the circuit board side and out the sensor side of the transducer as designed there will be an appropriate amperage reading on the VM1000 display. I also think that if one chose to run one of the battery cables through the transducer, instead of the alternator out cable, and placed the transducer on the "correct" battery cable with the "proper" orientation that the VM1000 system would then show the amperage flowing through that cable. Would that not then be battery amperage? I also opine that if one installs the transducer "backwards" on any wire then very likely there will be a zero or no reading of amperage on the VM1000 display. What do you think? Can you confirm the above with Vision Microsystems? 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Re: Reading Battery Amperage
Date: Jul 09, 2002
"OC", Everything you say agrees with what I understand about the VM1000. The difference between measuring alternator current and battery current is that alternator current is always in the same direction, while battery current can be in either direction. Since the VM1000 will only measure current in one direction, it's not so great for battery current. David Swartzendruber Wichita > 7/9/2002 > > Hello David, I have a VM1000 system installed in my airplane under > construction and I find what you were told to be a bit puzzling. > > My amperage transducer is installed on the alternator output (B cable) per VM > instructions. Here is how their instructions for installing the amperage > transducer read: "Route the wire which originates from the alternator output > (usuallly marked 'BAT' INTO the circuit board side and OUT the sensor (round > black device) side. See Figure 11: Amps Transducer Orientation. If properly > installed, the AMPS readout will increase as more electrical loads are turned > on and the alternator is active Shielded alternator wire is OK". > > My opinion is that anytime a wire running through the transducer has current > flowing into the circuit board side and out the sensor side of the transducer > as designed there will be an appropriate amperage reading on the VM1000 > display. > > I also think that if one chose to run one of the battery cables through the > transducer, instead of the alternator out cable, and placed the transducer on > the "correct" battery cable with the "proper" orientation that the VM1000 > system would then show the amperage flowing through that cable. Would that > not then be battery amperage? > > I also opine that if one installs the transducer "backwards" on any wire then > very likely there will be a zero or no reading of amperage on the VM1000 > display. > > What do you think? Can you confirm the above with Vision Microsystems? > > 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? > > dswartzendruber(at)earthlink.net writes: "The VM1000 will not show negative > current. They intend for their > current sensor to be used to sense alternator current only. If you use > it as a battery ammeter, battery discharge will be shown as zero. I > haven't demonstrated this to myself, but that is what the guys at Vision > Microsystems told me" . David Swartzendruber > ________________________________________________________________________________
Date: Jul 10, 2002
Subject: microphone gain (dissenting opinion)
Bob, Charlie: Thanks for the info. I think it's probably a moot point because neither my radio nor my headsets seem to have gain controls anyway. Does anyone know where they are located on the Microair 760, David Clark H10-13X, or H10-13.4? ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: Re: terminal strip for fastons
Date: Jul 10, 2002
R & Bruce - thanks for that! I have found the WECO site. I had a quick look last night. The 401 indeed looks useful. It was late last night when I saw it and need to work out the dimensions etc but it looks as though it could be just the job. Thanks again, Steve. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RSwanson Subject: Re: AeroElectric-List: Re: terminal strip for fastons ----snip--- > I wonder why there is not such a thing as a faston > terminal strip. Thanks again, Steve. They do, I have one in my hand. It's 12 circuits and says "WECO 401" on it. Couldn't tell you where it came from, but I might could find out. R http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Date: Jul 10, 2002
Hi Steve, I too looked at the web site but I got the feeling that they only catered for commercial quantities. Is that correct, or can I buy small amounts ? Paul, Europa 363 ----- Original Message ----- From: "Steve Sampson" <SSampson.SLN21(at)london.edu> Subject: RE: AeroElectric-List: Re: terminal strip for fastons > > R & Bruce - thanks for that! I have found the WECO site. I had a quick look > last night. The 401 indeed looks useful. It was late last night when I saw > it and need to work out the dimensions etc but it looks as though it could > be just the job. > > Thanks again, Steve. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RSwanson > Sent: 03 July 2002 22:33 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: terminal strip for fastons > > > ----snip--- > > I wonder why there is not such a thing as a faston > > terminal strip. Thanks again, Steve. > > They do, I have one in my hand. It's 12 circuits and says "WECO 401" on > it. Couldn't tell you where it came from, but I might could find out. > R > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 11, 2002
Subject: Re: AeroElectric-List Digest: 3 Msgs - 07/10/02
> From: "Steve Sampson" <SSampson.SLN21(at)london.edu> > Subject: RE: AeroElectric-List: Re: terminal strip for fastons > R & Bruce - thanks for that! I have found the WECO site. I had a quick look > last night. The 401 indeed looks useful. It was late last night when I saw > it and need to work out the dimensions etc but it looks as though it could > be just the job. Steve check out this site: http://www.great-atlantic1.com I was looking at the printed catalog and they offer regular terminal blocks and straight or 45deg faston type strips that mount on the terminal blocks. Goto electrical, terminal blocks. James ________________________________________________________________________________
From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net>
Subject: L-40 Alternator
Date: Jul 12, 2002
Bob: Should the B&C L-40 Alternator be grounded to the single point ground (forest of tabs)? The instructions that came with it do not address grounding. Thanks Gabe A Ferrer (RV6) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Subject: L-40 Alternator Cooling
Date: Jul 12, 2002
Bob: Should blast air be used to cool the B&C L-40 Alternator? If so, where should it be aimed at? It looks as if the L-40 incorporates an internal fan. Is this sufficient for cooling? Thanks Gabe A Ferrer (RV6) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Subject: teflon spray
Date: Jul 12, 2002
I'm trying to find a teflon spray which I have been told to by Continental to obtain locally and have not been able to find it. Does anyone know of a source for this? Dave Ford ________________________________________________________________________________
Subject: Re: L-40 Alternator
Date: Jul 12, 2002
I grounded my B&C to a universal ground tab welded to the engine mount. I have no dedicated blast tube to the alternator. So far after some 300 hours of operation, things are working well. Wayne ----- Original Message ----- From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net> Subject: AeroElectric-List: L-40 Alternator > > Bob: > > Should the B&C L-40 Alternator be grounded to the single point ground > (forest of tabs)? > > The instructions that came with it do not address grounding. > > Thanks > > Gabe A Ferrer (RV6) > ferrergm(at)bellsouth.net > Cell: 561 758 8894 > Night or FAX: 561 622 0960 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 12, 2002
Subject: Re: teflon spray
Several years ago I bought teflon lubricant for my bicycle at a bike shop. John ----- Original Message ----- From: "Dave Ford" <dford(at)michweb.net> Subject: AeroElectric-List: teflon spray > > I'm trying to find a teflon spray which I have been told to by > Continental to obtain locally and have not been able to find it. Does > anyone know of a source for this? > > Dave Ford > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Jim & Jeanette Oberst" <joberst@cox-internet.com>
Date: Jul 12, 2002
You can also get teflon spray lubricant at any sporting goods store... it's used to lubricate exercise treadmills. Jim Oberst ----- Original Message ----- From: "John & Amy Eckel" <eckel1(at)comcast.net> Subject: Re: AeroElectric-List: teflon spray > > Several years ago I bought teflon lubricant for my bicycle at > a bike shop. > > John > ----- Original Message ----- > From: "Dave Ford" <dford(at)michweb.net> > To: "aeroelectric-list" > Subject: AeroElectric-List: teflon spray > > > > > > I'm trying to find a teflon spray which I have been told to by > > Continental to obtain locally and have not been able to find it. Does > > anyone know of a source for this? > > > > Dave Ford > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 12, 2002
Paul - Yes I was concerned about that too. I don't know is the answer. James - thanks for your suggestion. I will take a look. Steve. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Paul McAllister Subject: Re: AeroElectric-List: Re: terminal strip for fastons Hi Steve, I too looked at the web site but I got the feeling that they only catered for commercial quantities. Is that correct, or can I buy small amounts ? Paul, Europa 363 ----- Original Message ----- From: "Steve Sampson" <SSampson.SLN21(at)london.edu> Subject: RE: AeroElectric-List: Re: terminal strip for fastons > > R & Bruce - thanks for that! I have found the WECO site. I had a quick look > last night. The 401 indeed looks useful. It was late last night when I saw > it and need to work out the dimensions etc but it looks as though it could > be just the job. > > Thanks again, Steve. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of RSwanson > Sent: 03 July 2002 22:33 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: terminal strip for fastons > > > ----snip--- > > I wonder why there is not such a thing as a faston > > terminal strip. Thanks again, Steve. > > They do, I have one in my hand. It's 12 circuits and says "WECO 401" on > it. Couldn't tell you where it came from, but I might could find out. > R > > http://www.matronics.com/browselist/aeroelectric-list > > http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
From: "Daniel Pelletier" <pelletie1(at)hotmail.com>
Subject: wiring nippo denso alternator
Date: Jul 13, 2002
Hi Bob, I read chapter 4 of your book and have some understanding problems for my wiring. I've a ND alternator with a "B" output for Battery but no "F" or "G" output. I've a green socket with two wire, a Black one with a with stripe and a White one with a green stripe. Someone wrote 1G near the Black one and "L" near the White one. I've too a Delco Remy voltage regulator whit three output Bat - Arm and Fld, I have also your Over voltage device. I gonna have a dual ignition (paul mesinger's modification of my Nippo Denso distributor. I'm unable to find a plan to wire that device. Your help would be appreciate. Daniel Pelletier 601HDS/W/Soob http://www.hotmail.com/fr ________________________________________________________________________________
Date: Jul 13, 2002
The power unit doesn't have a lot of time on it, it's seldom used. I don't have a service manual. The whole thing is encased in a metal box which is somewhat hard to get to, but I'll look for the regulator and try and find a way to check the voltage Thanks Vince on 7/8/02 12:01 PM, Robert L. Nuckolls, III at bob.nuckolls(at)cox.net wrote: >> >> I know this is off topic... off - list actually... but if someone could >> give me a few pointers I'd appreciate it. I have a 5kw aux power unit in my >> boat that has started acting up. It will put out 120 volts for about 20 >> minutes and then the voltage will drop to just 8 -10 or less, just slightly >> off the bottom of the meter. There aren't any other indications and repeated >> attempts at restarting the generator and putting it on line show no voltage. >> After a few days it will once again work fine for a while. >> >> What sort of things can I check to figure out what has gone bad? The little >> engine that powers it seems to run fine, just no output. > > Depending on the age of this machine, it probably > has slip rings and brushes. Does it have a lot of time > on it? Do you have a service manual for it? Is there > a "black box" associated with it that might be a > regulator for the alternator? If you can identify > wires from a black box that might carry field excitation > voltage to the alternator, some voltage measurements > during a brownout would be helpful. If the field > voltage goes up as the output voltage falls, then > I'd look into brush problems. Otherwise, it's most > likely a regulator problem. > > Bob . . . > > ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 8 Msgs - 07/12/02
Date: Jul 13, 2002
I got some from a sporting goods store for the bed on a treadmill. Might try that. It says, "for fishing reels, etc." in addition to the myriad other uses. Ron > From: "Dave Ford" <dford(at)michweb.net> > Subject: AeroElectric-List: teflon spray > > > I'm trying to find a teflon spray which I have been told to by > Continental to obtain locally and have not been able to find it. Does > anyone know of a source for this? > > Dave Ford ________________________________________________________________________________
Date: Jul 15, 2002
Subject: nd part number to make model chart
It would be nice to have an ND (Nippondenso) alternator part number to year make model chart and vice versa. I have worked the net pretty hard and have not found one. Has anyone found a conversion chart like that? It would be handy in many ways. Barry Pote RV9a chevy powered, finish kit ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: L-40 Alternator Cooling
> > >Bob: > >Should blast air be used to cool the B&C L-40 Alternator? If so, where >should it be aimed at? > >It looks as if the L-40 incorporates an internal fan. Is this sufficient for >cooling? > >Thanks > >Gabe A Ferrer (RV6) >ferrergm(at)bellsouth.net >Cell: 561 758 8894 >Night or FAX: 561 622 0960 It has always distressed me to some degree that nobody I'm aware of has ever done a temperature survey on any of the B&C alternator installations to see if they're subject to temperature induced overstress as installed. These alternators are demonstrating exemplary service life but very few installations are heavily loaded. The average vfr day load on a lightplane is under 10 a, vfr nite is under 20 and ifr is under 30. If anyone were interested in doing some real critical cooling tests on their alternator, I'd be pleased to assist. For the moment, all we can say is that overstressed or not, the little buggers are hanging in very well in the field. Bob . . . ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: L-40 Alternator grounding
> > >Bob: > >Should the B&C L-40 Alternator be grounded to the single point ground >(forest of tabs)? > >The instructions that came with it do not address grounding. > >Thanks > >Gabe A Ferrer (RV6) >ferrergm(at)bellsouth.net >Cell: 561 758 8894 >Night or FAX: 561 622 0960 The alternator and starter both get their grounds though the crankcase. There is no value in adding any form of extra ground to either of these devices. There should be a hefty ground strap from crankcase to firewall ground block. Bob . . . ________________________________________________________________________________
Date: Jul 15, 2002
> >I grounded my B&C to a universal ground tab welded to the engine mount. I >have no dedicated blast tube to the alternator. So far after some 300 hours >of operation, things are working well. >Wayne Engine mounts should be dedicated to holding engines on the airplane and completely independent of the electrical system. A ground strap from crankcase to firewall ground stud by-passes the engine mount as a component of the electrical system and eliminates any need to install bond straps across the engine mount biscuits and lets the engine mount do what it does best without having to be concerned about both electrical and mechanical integrity of the various joints. Bob . . . ________________________________________________________________________________
Date: Jul 15, 2002
----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: L-40 Alternator > > > > >I grounded my B&C to a universal ground tab welded to the engine mount. I > >have no dedicated blast tube to the alternator. So far after some 300 hours > >of operation, things are working well. > >Wayne > > Engine mounts should be dedicated to holding > engines on the airplane and completely independent > of the electrical system. > > A ground strap from crankcase to firewall ground > stud by-passes the engine mount as a component > of the electrical system and eliminates any need > to install bond straps across the engine mount > biscuits and lets the engine mount do what it > does best without having to be concerned about both > electrical and mechanical integrity of the various > joints. > > > Bob . . . My installation is as follows: a ground strap from the (-) side of the battery goes to a top engine case bolt. The other end of this bolt is another ground strap that goes to a tab welded to the engine mount. The engine mount is bolted to the firewall at 5 locations, with the bolts extending through the firewall and through airframe stringers, thereby supplying ground to the airframe. On another tab on the engine mount several other ground lines to ground from shielded wires, such as the alternator, etc. My plane is an aluminum MustangII. It was my assumption that the engine, engine mount and airframe should all be at the same ground state. As stated, I have had no problems except with the gaud awful standard aircraft starter and alternator. Wayne > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: wiring nippo denso alternator
> > > >Hi Bob, > >I read chapter 4 of your book and have some understanding problems for my >wiring. I've a ND alternator with a "B" output for Battery but no "F" or >"G" output. I've a green socket with two wire, a Black one with a with >stripe and a White one with a green stripe. Someone wrote 1G near the Black >one and "L" near the White one. if you have a stock ND alternator, it has a built in regulator and cannot use the external regulator. >I've too a Delco Remy voltage regulator whit three output Bat - Arm and Fld, >I have also your Over voltage device. I gonna have a dual ignition (paul >mesinger's modification of my Nippo Denso distributor. I'm unable to find a >plan to wire that device. lost you here. don't know about a ND distributor. you can use the ND alternator in combination with the ov module and an alternator b-lead disconnect contactor as shown in figure Z-24 of the AeroElectric Connection. if you don't have a book you can download appendix Z from my website. use the IG (black) wire as a field control input. ignore the white lead. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Check out :Dual alt.
Click here: http://www.kellyaerospace.com/index.htm/test/VoltageReg.pdf http://www.kellyaerospace.com/index.htm/test/VoltageReg.pdf The above is an article from Aviation Maintenance Technology magazine about dual alt. and volt. reg, Steve ________________________________________________________________________________
Date: Jul 15, 2002
Subject: one wire racing alternators
I have seen many 'racing, 1 wire' alternators in hot rod catalogs. What is a '1 wire' alternator and how does it fit into our systems and how does it hookup, with regards to for OV etc, per Bob's book? Or will it work at all? Barry Pote RV9a chevy powered ________________________________________________________________________________
Subject: Re: one wire racing alternators
Date: Jul 15, 2002
There are several pieces of information relevant to these guys in Bob's book, as well as in the matronics archive. Send me an email offline if you have trouble finding them. The '1 wire' alternators are internally regulated. This allows all of the normal alternator wiring to be hidden within the case - so they actually do have all of the normal wires... just hidden. They are fantastic from the standpoint of ease of installation - hook it to the battery, a switched lead to the battery, and away you go. However, they aren't as easy to shut down should the runaway regulator failure mode happen. They require a contactor to disconnect them from their heavy current connection to the battery. Once you count the wiring to the contactor, I'm not sure you are really ahead of the game. Bob, you made a mention of these guys in the archive: "There are probably failure modes within the altenrator that will allow the machine to produce uncontrolled output in spite of having removed +12 v from the IG lead. This is why we have to add the external contactor." This mentions just disconnecting the IG lead. Is there any different effect from connection the IG to ground, instead of just floating it? I guess what I am asking is whether the IG lead connects to the FLD lead in some way. Matt Prather. ----- Original Message ----- From: barry pote <barrypote(at)comcast.net> Date: Monday, July 15, 2002 3:16 pm Subject: AeroElectric-List: one wire racing alternators > > I have seen many 'racing, 1 wire' alternators in hot rod catalogs. > > What is a '1 wire' alternator and how does it fit into our systems and > how does it hookup, with regards to for OV etc, per Bob's book? > > Or will it work at all? > > Barry Pote RV9a chevy powered > > > _- ________________________________________________________________________________
Date: Jul 15, 2002
Bob, Nevermind. I just found the answer to my question... In the archive: "One lead is for control of the alternator (it does not directly supply field power . . hence cannot be depended on for ov control). The other will be for the automotive version of an alternator failure warning lite. Recommend you ignore this lead and have some form of ACTIVE NOTIFICATION OF LOW VOLTAGE that flashes a light when the bus drops below 13.0 volts." I guess I should follow my own advice! Matt Prather ----- Original Message ----- From: mprather(at)spro.net Date: Monday, July 15, 2002 3:43 pm Subject: Re: AeroElectric-List: one wire racing alternators > > There are several pieces of information relevant to these guys in > Bob's book, as well as in the matronics archive. Send me an email > offline if you have trouble finding them. > > The '1 wire' alternators are internally regulated. This allows > all of the normal alternator wiring to be hidden within the case - > so they actually do have all of the normal wires... just hidden. They > are fantastic from the standpoint of ease of installation - hook it > to the battery, a switched lead to the battery, and away you go. > However, they aren't as easy to shut down should the runaway regulator > failure mode happen. They require a contactor to disconnect them > from their heavy current connection to the battery. Once you count > the wiring to the contactor, I'm not sure you are really ahead of the > game. > > Bob, you made a mention of these guys in the archive: > > "There are probably failure modes within the altenrator > that will allow the machine to produce uncontrolled output > in spite of having removed +12 v from the IG lead. This > is why we have to add the external contactor." > > This mentions just disconnecting the IG lead. Is there any different > effect from connection the IG to ground, instead of just floating > it? I > guess what I am asking is whether the IG lead connects to the FLD lead ________________________________________________________________________________
Subject: Re: 1 wire
Date: Jul 15, 2002
The 1-wire alternators are certainly internally regulated (I realize that isn't what you asked). I grouped all of the internally regulated alternators with the 1-wire units, however, because they have the same fundamental safety problem - no way to control the field current from the outside. I hadn't really thought about whether the the overvoltage protection scheme Bob has for the internally regulated units will work on the 1-wire units.... After snooping around I have found my source of uncertainty - The common one-wire units are GM converted altenators. These are the ones I have converted - from a stock internally regulated unit. The trick is to just get the right internal regulator and then hook a jumper to the battery lead - providing continuous excitation. Here is a link to a description of the process: http://mightymo.org/Proj_OneWire.html And that's what I did. Based on everything I have seen on the net it looks like all of the advertised 1-wire units are GM (or derivative). I don't see any advantage to using one of them over a standard GM alternator - which I think are generally pretty junky compared to the ND units anyway... I think the 1-wire units are attractive to someone who wants to wire a hotrod and doesn't want to figure anything out. I apologize for providing a muddled response before. Matt Prather ----- Original Message ----- From: barry pote <barrypote(at)comcast.net> Date: Monday, July 15, 2002 4:34 pm Subject: 1 wire > Hi Matt, > > thanks for the reply. I have Bob's book and and don't remember any > words about '1 wire' alternators. But what you mention sounds like the > PM alternators he talks about. No? > > I recently looked at alternators in the archive, but did not look > for '1 > wire ' ones. > > Matt, are all internally regulated alternators one wire? > > I already bought the parts from BOB for an internally regulated > alternator. I will be using some kind of Nippondenso, internally > regulated model. > > But the '1 wire terminology in the catalogs, threw me. > Barry Pote RV9a > > ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: AeroElectric- AeroElectric Connection book
Hello. I have been following along with the great information being dispensed on this list. I finally ordered the AeroElectric book and CD about a month ago and wondered how long it takes to get them in the mail? Dennis~ Seattle ________________________________________________________________________________
Subject: L40 Alternator Cooling Test
Date: Jul 15, 2002
Bob: I'd be glad to run a cooling test on the alternator. HOWEVER, I'm about 4 months away from flying. I have made provisions to have a spare temperature port in my Grand Rapids Engine Information System. I'll be able to attach the temperature sensor most anywhere in the engine compartment. I'll get in contact with you after my first flight. Thanks. Gabe A Ferrer ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: Check out Dual alt.
> > Click >here: http://www.kellyaerospace.com/index.htm/test/VoltageReg.pdf > >http://www.kellyaerospace.com/index.htm/test/VoltageReg.pdf > >The above is an article from Aviation Maintenance Technology magazine about >dual alt. and volt. reg, The system described here parallels two alternators onto a single bus with features that make the alternators share the total load. If one has two identical alternators that run full time, why not make the system TRULY redundant and have two batteries too? In most cases, the second alternator can be a smaller, auxiliary machine of smaller capacity that doesn't have to run full time like the diagrams showing an SD-20 or SD-8 installation. In these cases paralleling is not necessary or even useful. I've designed systems like this for the Cessna and Beech light twins . . . all they do is make the pilot "feel-good" because the two loadmeters always read the same . . . pretty expensive and complicated just for "feel-good" Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 15, 2002
Subject: Re: AeroElectric Connection book
> >Hello. I have been following along with the great information being >dispensed on this list. I finally ordered the AeroElectric book and CD about >a month ago and wondered how long it takes to get them in the mail? > >Dennis~ >Seattle > How did you order the book? I've searched the primary and backup order archives for orders to both B&C and AeroElectric Connection. Can't find an order with your name or e-mail address attached to it. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Alternator and Overvoltage Protection
Date: Jul 16, 2002
Bob, I know this is slightly off topic but I would appreciate an answer if possible. Having just blown up one expensive car battery through a runaway alternator I would like to include overvoltage protection in my car using the B&C supplied unit (A quick aside on B&C - Possibly the best service I have ever got from a US company - I ordered last Friday and my package was delivered at 8:30 Monday -- to TOKYO, JAPAN - Well done) Am I correct in assuming that I require the alt. relay with an internally regulated alternator? Or would putting a 5A fuse in the field cable with the OVM device attached to the alternator/ground work as in OVM installation drawing, blowing the fuse if overvoltage. Does a standard alternator continue to output if the +ve volts are removed from the field connection? Is there any reason this circuit would not work with a 105A alternator? ________________________________________________________________________________
Date: Jul 16, 2002
> > >"Robert L. Nuckolls, III" wrote: > > > > > > > > > > > >The Microair 760 manual talks about adjusting the microphone gain for use > > >in noisy environments, > > >but there don't seem to be any controls on the radio for this. Anyone > > >know how this works? Do > > >some headsets have such a control on them? > > > > I'm totally mystified as to why anyone would adjust a gain > > to compensate for noisy environment . . . the end product of > > received signal intelligibility is a function of signal to > > noise ratio. Adjusting system gain has an equal effect upon > > both signal (voice) and noise. If you have a problem with > > perceived background noise in your signal as others hear > > you, you need a better microphone. Some do much a much > > better job than others at attenuating ambient noise with > > respect to your voice. > > >snipped > >Bob, > >I hate to disagree with someone of your knowledge & >experience, but I feel that an expanded perspective might be >in order. > >There can be some justification for Microair's instructions >because gain can actually affect overall signal to noise. >Some observations are in order. This stuff is a lot easier >to demonstrate than describe, so bare with me. > >Consider first that any amplification system has a limited >maximum output. At some level of ambient noise, plus signal >(voice), all multiplied times the gain of the system, you >will drive the system into distortion. Signal to noise just >got a lot worse than measured specs for the system. If you >reduce the system gain, you can now position the mic closer >to your mouth and speak louder as well. You have just >improved the overall signal to noise ratio by raising the >input signal level relative to the input noise level. You've inserted a new variable. If one has overwhelmed the system's dynamic range, then too much overall gain will indeed overdrive the system adding to the apparent noise. >So, while the previous statements were technically correct, >this is 'the rest of the story.' > >re: adjusting mic gain. Many electret condenser mics used in >today's headsets have gain controls included in the mic >module. These mic modules include a preamplifier stage to >raise the level of the low-output condenser mic element to >traditional dynamic mic levels to match the rather loose >'standard' signal level expected by a/c radios. The points >about system gain apply to this single stage of gain as >well. > Lightspeed told me to lower the mic gain on my 15XL's >when I had a problem with intermittant noise in the >headsets. What was the intermittent "noise" . . . squelch breaking, feedback, ????? There can be numerous reasons that reducing gain can improve behavior of a system without changing the signal to noise ratio of the adjusted system. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2002
Subject: Re: Alternator and Overvoltage Protection
> >Bob, I know this is slightly off topic but I would appreciate an answer >if possible. > >Having just blown up one expensive car battery through a runaway >alternator I would like to include overvoltage protection in my car >using the B&C supplied unit > >(A quick aside on B&C - Possibly the best service I have ever got from a >US company - I ordered last Friday and my package was delivered at 8:30 >Monday -- to TOKYO, JAPAN - Well done) > >Am I correct in assuming that I require the alt. relay with an >internally regulated alternator? Or would putting a 5A fuse in the field >cable with the OVM device attached to the alternator/ground work as in >OVM installation drawing, blowing the fuse if overvoltage. Does a >standard alternator continue to output if the +ve volts are removed from >the field connection? Most internally regulated alternators do not use the + control lead to power the field. There are failure modes internal to the regulator circuitry that will not shut down a runaway alternator. >Is there any reason this circuit would not work with a 105A alternator? Should work just fine with either a fuse or circuit breaker for the crowbar module to work against. You may want to use a larger contactor than the S701-1 device shown in our catalog. This is nominally a 50A device for switching service that will carry hundreds of amps intermittently for cranking. I've not had any experience with it in a system that could run long term loads greater than 50A. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Date: Jul 16, 2002
It took Bob all of two days to get my order to Michigan... Denny ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: AeroElectric Connection book > > > > >Hello. I have been following along with the great information being > >dispensed on this list. I finally ordered the AeroElectric book and CD about > >a month ago and wondered how long it takes to get them in the mail? > > > >Dennis~ > >Seattle > > > > How did you order the book? I've searched the primary and > backup order archives for orders to both B&C and AeroElectric > Connection. Can't find an order with your name or e-mail > address attached to it. > > > Bob . . . > > |-------------------------------------------------------| > | Too often we enjoy the comfort of opinion without the | > | discomfort of thought. ~ John F. Kennedy | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Transponder Noise in Intercom
Date: Jul 16, 2002
When I turn on my transponder (used AT-50) I hear a continuous tone through the intercom. Around 2 or 3Khz I'd guess. Sounds like a fairly clean sinusoid, but I haven't scoped it. It begins as soon as the transponder switch is moved to standby and stays until the unit is switched off. The level is not high, and may not be noticable with the engine running but it's certainly annoying on the ground. I am using the AeroElectric single point ground system for the avionics and all audio runs are shielded. Any ideas on how I might fix this? Filter the intercom and/or transponder + lead? Curt ________________________________________________________________________________
Date: Jul 16, 2002
Subject: Re: Transponder Noise in Intercom
> > >When I turn on my transponder (used AT-50) I hear a continuous tone through >the intercom. Around 2 or 3Khz I'd guess. Sounds like a fairly clean >sinusoid, but I haven't scoped it. It begins as soon as the transponder >switch is moved to standby and stays until the unit is switched off. The >level is not high, and may not be noticable with the engine running but it's >certainly annoying on the ground. I am using the AeroElectric single point >ground system for the avionics and all audio runs are shielded. Any ideas on >how I might fix this? Filter the intercom and/or transponder + lead? Do you have a copy of the 'Connection? You need to check out chapter 16 and go through some rudimentary isolation checks to see what mode of propagation is bringing noise outside your transponder and into your intercom. It could be magnetic noise coupled between black boxes or adjacent wiring. It could be conducted noise transferring across the common 14v power system. Only after the propagation mode is discovered can you properly craft a means for breaking that coupling mode. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2002
Subject: Sec 1223 Power Supply
Hi Bob, I purchased a Samlex SEC 1223 DC power supply as per your recommend a while back. Just getting around to using it. The Manual says: "DO NOT CONNECT THE POWER SUPPLY TO THE AC POWER SOURCE WHILE MAKING CONNECTIONS" Does this mean that I need to have all connections I wish to power made and then when all is ready plug the power supply in? If so it seems an awkward way to have to work. I would appreciate your comments, Regards, Don Boardman & Partner Randy Bowers Moose #130 "The Beast" M-14PF 400HP Aerocet 3500 amphibs Rome, NY ________________________________________________________________________________
Date: Jul 17, 2002
Subject: Re: Sec 1223 Power Supply
> >Hi Bob, > >I purchased a Samlex SEC 1223 DC power supply as per your recommend a while >back. Just getting around to using it. The Manual says: > >"DO NOT CONNECT THE POWER SUPPLY TO THE AC POWER SOURCE WHILE MAKING >CONNECTIONS" > >Does this mean that I need to have all connections I wish to power made and >then when all is ready plug the power supply in? > >If so it seems an awkward way to have to work. Agreed. That sounds like boilerplate from some bureaucrat's notion of warnings and cautions to put on every product to hold the lawyers at bay . . . I'd ignore it. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2002
Subject: Starter and Battery contactor diodes
I have read through everything I can on your web site. It's all been a great education for me. I thank you very much. I have one question that I have been unable to answer; What is the rating or size of the diodes used on the starter and battery contactors? About any diode you can find 1A or greater, 50V or greater will do. I prefer the 3A devices sold by Radio Shack and others because they are mechanically more robust than the 1A devices . . . easier to use. Bob . . . -------------------------------------------- | People are far more willing to pay | | for being amused than for anything else. | | -Thomas Edison- | -------------------------------------------- ________________________________________________________________________________
Date: Jul 17, 2002
Subject: Re: Ball vario
> >I have a Ball vario model 600 and when I key the mike it goes full >deflection down. I tried with my handheld near by, does the same thing. A >problem or just something you live with. Anyway to stop it? >Thanks in advance, >R This is a classic RF interference problem especially common to instruments not intended for installation on airplanes intended to carry the usual compliment of electronics. You'll need to talk to Ball and see if they have any recommendations. How is this powered? If you have long wires coming out the back to a battery in the airplane, you might try powering up with dry cells located as close as possible to the rear of the instrument. If this improves the situation, then perhaps a filter in the power leads will do it. Bob . . . ________________________________________________________________________________
Date: Jul 17, 2002
> > >When I turn on my transponder (used AT-50) I hear a continuous tone through >the intercom.............. >Any ideas on >how I might fix this? Turn on the engine.? :-) K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Jul 17, 2002
> When I turn on my transponder (used AT-50) I hear a continuous tone through > >the intercom.............. > >Any ideas on > >how I might fix this? > Here's what I did: replace aging Narco AT-50 with newer model AT-150, so as not to have to rewire or replace tray. Ignore advice from others to spend extra $ on Garmin model with slide-in Narco adapter for lazy types like myself, because that costs more. Fly with undependable transponder that has bad reputation for drifting out of frerquency specs for a couple years. Get small quantity of rainwater in the stack and eventually fry the high voltage power supply on the circuit board (remember, you opted to stay with vacuum tube technology in favor of robust, solid state gear that operates at 13.8 volts, to save money.) Have technician make unsuccessful attempt to repair burnt components over a period of 6 months, to save still more money (versus factory service). Final step: come to senses, shell out the $1200 to John Stark for the Garmin GTX-320A and fly happy again :-) This may not fix your problem, since my adventure never started out with a noise problem, but I'll bet you end up somewhere close to where I did :-) Narco is junk. Use it for a door stop or paperweight. Post script: I am happy to report, in case anyone is interested, that my experiment with concealing a quarter-wave whip antenna for the transponder inside the aft compartment of the new 2-pc RV main gear wheelpant (attached to a horizontal aluminum ground plane behind the aft bulkhead of the wheelpant, fed by coax run inside the gear leg fairing) is a success. The installation performs well, with no obvious shielding from the nearby wheel and axle, and looks to be weathertight and drag-free. The 14 foot coax run is more than the 8.8 feet of RG-400 allowed in the installation manual, but the attenuation does not seem to make ATC unhappy. The ground plane is mounted in the widest part of the aft wheelpant compartment, and is cut to fit the contours snugly, in a trapezoidal shape. Dimensions are nearly a quarter wave from the radiating element in all directions. The antenna is hung vertically downward from the middle of the ground plane, as if on the belly of the plane. Regards, -Bill B RV-6A - gradually removing unstreamlined objects from the exterior airframe ________________________________________________________________________________
Date: Jul 17, 2002
I agree with the Narco junk assessment. The Narco transponder in my MustangII last exactly 11 months after putting in service, but had over 13 months since purchase. Narco won't even respond to my letters and phone calls. Cost $700 to replace magnetron tube (7 years ago). Replaced with a King a year later, and it's been transponding without a problem since. Wayne ----- Original Message ----- From: <SportAV8R(at)aol.com> Subject: Re: AeroElectric-List: Transponder Noise in Intercom > > > > When I turn on my transponder (used AT-50) I hear a continuous tone through > > >the intercom.............. > > >Any ideas on > > >how I might fix this? > > > > Here's what I did: replace aging Narco AT-50 with newer model AT-150, so as > not to have to rewire or replace tray. Ignore advice from others to spend > extra $ on Garmin model with slide-in Narco adapter for lazy types like > myself, because that costs more. Fly with undependable transponder that has > bad reputation for drifting out of frerquency specs for a couple years. Get > small quantity of rainwater in the stack and eventually fry the high voltage > power supply on the circuit board (remember, you opted to stay with vacuum > tube technology in favor of robust, solid state gear that operates at 13.8 > volts, to save money.) Have technician make unsuccessful attempt to repair > burnt components over a period of 6 months, to save still more money (versus > factory service). > > Final step: come to senses, shell out the $1200 to John Stark for the Garmin > GTX-320A and fly happy again :-) > > This may not fix your problem, since my adventure never started out with a > noise problem, but I'll bet you end up somewhere close to where I did :-) > Narco is junk. Use it for a door stop or paperweight. > > Post script: I am happy to report, in case anyone is interested, that my > experiment with concealing a quarter-wave whip antenna for the transponder > inside the aft compartment of the new 2-pc RV main gear wheelpant (attached > to a horizontal aluminum ground plane behind the aft bulkhead of the > wheelpant, fed by coax run inside the gear leg fairing) is a success. The > installation performs well, with no obvious shielding from the nearby wheel > and axle, and looks to be weathertight and drag-free. The 14 foot coax run > is more than the 8.8 feet of RG-400 allowed in the installation manual, but > the attenuation does not seem to make ATC unhappy. The ground plane is > mounted in the widest part of the aft wheelpant compartment, and is cut to > fit the contours snugly, in a trapezoidal shape. Dimensions are nearly a > quarter wave from the radiating element in all directions. The antenna is > hung vertically downward from the middle of the ground plane, as if on the > belly of the plane. > > Regards, > > -Bill B > RV-6A - gradually removing unstreamlined objects from the exterior airframe > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 17, 2002
>Narco is junk. Use it for a door stop or paperweight. Those Narco transponders are - antiques! I have actually done pretty well with Narco radios in the past. They are less money up front. My Deb has all Narco digital stuff and has not been serviced in ten years! I especially like the VOR indicators for their parallel movements. Currently, the Mk12 digital sometimes doesn't go to the selected frequency in one area and Narco say this is a $200 fix. You have to send it in but, on the other hand, you don't have a guy in there working on it with a hammer. Promptly on buying my Deb ( did I mention that it is for sale?) I bought a new Narco txp. I complained that it seemed to move in the panel. Several years later I looked and saw that they had "stabilized" it by stuffing a hunk of vacuum hose between it and the airframe! Not so much incompetence as dishonesty. I think they had the duty sweeper do the work. I did see him installing on another aircraft. Yes, a certified avionics shop. My RV has only an Icom radio, a Skyforce GPS and a Garmin 327(?) transponder which is great. I consider the txp the most important box in the panel. With only a GPS, you can't communicate. With only a comm, ATC can't help locate you and guide you to safety. Forget DF steers. I wouldn't buy a King txp with Garmin around. Way back, I flew a Bonanza with two old MK12 Narcos - 'digital' then meant 'fingers'. We needed three, however, because both radios failed on long flights. I haven't had a comm failure since. Go ahead and archive this as it will only cost about a tenth of a cent. K. H. (Hal) Kempthorne RV6-a N7HK flying! PRB (El Paso de Robles, CA) ________________________________________________________________________________
From: "David A. Leonard" <dleonar1(at)maine.rr.com>
Subject: Low Voltage indicator light/Relay
Date: Jul 17, 2002
List, Theis question is from Bellanca Vking group. the Vikings have a low voltage indicator annunciator light(push to test, dimming type. they are somehow driven by a relay and a fused wire to the alternator. Apparently the relay is NLA and I was wondering if there was an easy way to retrofit a similar but different system? I believe it is a 6v relay but I'm not sure. Here is the post>> Just got off the phone with Duane at Millers. The relay (255KM5D) is no longer available anywhere. He tells me that what they do is take out the 1 amp fuse by the alternator and disable the red warning light system. There is no other way to fix the problem. So if that is the only fix..... this is the cheapest repair that I have ever had. >> Thanks, Dave Leonard ________________________________________________________________________________
Subject: Re: Low Voltage indicator light/Relay
Date: Jul 18, 2002
My question is... Why is a 6 volt relay in a 12 volt system? Wouldn't that almost insure failure by burning? Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com We support Aeroncas ----- Original Message ----- From: "David A. Leonard" <dleonar1(at)maine.rr.com> Subject: AeroElectric-List: Low Voltage indicator light/Relay List, Theis question is from Bellanca Vking group. the Vikings have a low voltage indicator annunciator light(push to test, dimming type. they are somehow driven by a relay and a fused wire to the alternator. Apparently the relay is NLA and I was wondering if there was an easy way to retrofit a similar but different system? I believe it is a 6v relay but I'm not sure. Here is the post>> Just got off the phone with Duane at Millers. The relay (255KM5D) is no longer available anywhere. He tells me that what they do is take out the 1 amp fuse by the alternator and disable the red warning light system. There is no other way to fix the problem. So if that is the only fix..... this is the cheapest repair that I have ever had. >> Thanks, Dave Leonard http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: NARCO
Date: Jul 18, 2002
Cheers, In the bad old days, deH Vampires (Canada's first jet fighter - and wooden at that) were 'equipped' with NARCO homers (ADFs) called "Bird-dog". Picture a 20-year-old in his 4th jet trip (no 2seat trainers then), snaking through 30,000 feet of cloud only to pop out on top with not a single buddy in sight. No transponder, and wood. Defense radar couldn't 'paint'. Stooged about for 30 minutes then began panicking about terra firma. Reliable old 'BirdDog' couldn't read my home beacon, so dialled up a 50,000W broadcast station about 15 miles from base. Made up a descent diagram from scratch and told GCA I'd pass through their beam in 5 minutes. They caught me, lost me, caught me again and vectored me to final GCA in 200 feet of blizzard. Ran out of fuel on the runway. My left kneecap danced on my leg for an hour. Good old NARCO. Ferg Europa A064 ________________________________________________________________________________
Date: Jul 18, 2002
Subject: Re: nd part number to make model chart
Barry, ND is to Japan what AC-Delco is to the U.S. They are the primary electrical supplier for O.E.Ms in Japan, Korea, China and starting to be primary in some U.S. productions (due to Corperate agreements and buy-outs). Anyway, there is cross-overs, of a sort, with the primary O.E.M. users part numbers to ND and back but, it generally isn'y availible to the public per say. The internal parts are pretty much the same for each "Class" of part but, like with AC-Delco (G.M.) there are 38 alternators listed just for Chevrolet in 1998 for example (some 56 for the entire G.M. production). Some will interchange (just an extra bolt hole or mounting tab), while others have a completely different case mounting. Probably the easiest to do is find a primary user (Mazda, Toyota, etc.) that uses the case class and output size that your looking for and just stay with that. I went with a ND alt. for a Geo Metro with A/C. 50 Amps, internally regulated, installed B&C O/V protection and crowbarred it. Yea, I know, no vibrator box hanging on the firewall but, it works for hundreds of thousands of vehicles without O/V protection. Anyway, I would go with G.M (Geo) or Toyota applications. Geo because some of the ND numbers cross to AC-D and Toyota because They adopt most of NDs numbers directly. You might try contacting some of the automotive elctrical rebuilder supply W.D.s and see if they have what your looking for as far as a true crossover. Next best thing that I've found is Echlin's Alternator and Starter User's Guide (NAPA). It has Year, Make, Model, Case Class, Output, and some connection pictures. Hope this helps... Jim Duckett, Packing for OSH barry pote wrote: > >It would be nice to have an ND (Nippondenso) alternator part number to >year make model chart and vice versa. > >I have worked the net pretty hard and have not found one. > >Has anyone found a conversion chart like that? > >It would be handy in many ways. > >Barry Pote RV9a chevy powered, finish kit > > ============================ > > ________________________________________________________________________________
Date: Jul 18, 2002
> >My question is... Why is a 6 volt relay in a 12 volt system? Wouldn't that >almost insure failure by burning? I suspect this relay runs from the center-tap of a y-connected stator winding. The output voltage from the center tap is about 1/2 the system voltage. This feature of some alternators (called an "aux terminal") has been used on many airplanes of years past to drive a low-voltage sensor module or relay to monitor instances where this output goes to zero (meaning alternator is turn off or failed). This is equal to the idiot light system used on many cars of era as well. >List, > >Theis question is from Bellanca Vking group. the Vikings have a low voltage >indicator annunciator light(push to test, dimming type. they are somehow >driven by a relay and a fused wire to the alternator. Apparently the relay >is NLA and I was wondering if there was an easy way to retrofit a similar >but different system? > >I believe it is a 6v relay but I'm not sure. > >Here is the post>> >Just got off the phone with Duane at Millers. The relay (255KM5D) is no >longer available anywhere. He tells me that what they do is take out the >1 amp fuse by the alternator and disable the red warning light system. >There is no other way to fix the problem. So if that is the only >fix..... this is the cheapest repair that I have ever had. Dave. Depending on how sanitary you want to be with respect to regulations, you can substitute about any 6v relay for this device . . . problem is that since 6v DC vehicle systems are so old, DC relays of this rating are increasingly hard to come by. The electronics world uses some 5v relays that might be adaptable but these are designed to solder to etched circuit boards and difficult to adapt to your application. If it were MY airplane, I'd build a low-voltage monitor set to trip at 13.0 volts like the one described by schematic http://209.134.106.21/articles/lvwarn/9021-610.pdf If you'd like to drive the same lamp fixture, it would take an output buffer transistor to boost the LED output drive of this circuit sufficiently to drive the lamp in your stock fixture. This would preserve the look of the panel and provide a much more useful indication. > >> > >Thanks, Dave Leonard > > >http://www.matronics.com/browselist/aeroelectric-list > > Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Re: NARCO
Date: Jul 19, 2002
Glad it worked out, and good thinking for a 20 year old... You must have been pushing on those rudder pedals pretty hard, Ferg... Nervous, eh wot... Cheers ... Denny ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Subject: AeroElectric-List: NARCO > > Cheers, > In the bad old days, deH Vampires (Canada's first jet fighter - > and wooden at that) were 'equipped' with NARCO homers (ADFs) called > "Bird-dog". > Picture a 20-year-old in his 4th jet trip (no 2seat trainers > then), snaking through 30,000 feet of cloud only to pop out on top with not > a single buddy in sight. No transponder, and wood. Defense radar couldn't > 'paint'. Stooged about for 30 minutes then began panicking about terra > firma. Reliable old 'BirdDog' couldn't read my home beacon, so dialled up a > 50,000W broadcast station about 15 miles from base. Made up a descent > diagram from scratch and told GCA I'd pass through their beam in 5 minutes. > They caught me, lost me, caught me again and vectored me to final GCA in 200 > feet of blizzard. Ran out of fuel on the runway. > My left kneecap danced on my leg for an hour. > Good old NARCO. > Ferg > Europa A064 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Pilot Priority Relay Assembly
Date: Jul 19, 2002
Bob: I am beginning the electrical wiring for my plane. Reviewing your wiring diagrams, I find most of them will serve my purpose very well. On the yaw and pitch trim diagrams, there is a pilot priority relay assy. Is there an assembly I can purchase from someone or do I have to custom build this unit? A purchased assembly would be a whole lot easier than laying out a PC board and doing the assembly! Thanks for your help, Eugene Long Lancair Super ES glong2(at)netzero.net ------------------------------------------- Introducing NetZero Long Distance Unlimited Long Distance only $29.95/ month! Sign Up Today! www.netzerolongdistance.com ________________________________________________________________________________
Date: Jul 19, 2002
Subject: Re: Pilot Priority Relay Assembly
Bob - I am looking at the same sheets from your Lancair IV wire book. I looks like one relay can suffice for both trim axes. Correct? I would also prefer to have roll and pitch on the coolie switch rather than yaw and pitch. Any comments about how to change the sheets to reflect this? Many Thanks, John Schroeder glong2 wrote: > > Bob: > > On the yaw and pitch trim diagrams, there is a pilot priority relay assy. Is > there an assembly I can purchase from someone or do I have to custom build > this unit? A purchased assembly would be a whole lot easier than laying out > a PC board and doing the assembly! > > Thanks for your help, > > Eugene Long > ________________________________________________________________________________
Date: Jul 19, 2002
I believe that Matt Dralle's company Matronics (yes, the guy that hosts this mailing list for us for FREE) has such a product. See if http://www.matronics.com/governor/index.htm is close enough for you: it apparently uses a "first come/first served" model rather than pilot priority. -Matt > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of glong2 > Sent: Friday, July 19, 2002 4:02 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Pilot Priority Relay Assembly > > > Bob: > > I am beginning the electrical wiring for my plane. Reviewing your wiring > diagrams, I find most of them will serve my purpose very well. > > On the yaw and pitch trim diagrams, there is a pilot priority > relay assy. Is > there an assembly I can purchase from someone or do I have to custom build > this unit? A purchased assembly would be a whole lot easier than > laying out > a PC board and doing the assembly! > > Thanks for your help, > > Eugene Long > Lancair Super ES > glong2(at)netzero.net > > ------------------------------------------- > Introducing NetZero Long Distance > Unlimited Long Distance only $29.95/ month! > Sign Up Today! www.netzerolongdistance.com > > http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: Tone generator
Date: Jul 19, 2002
Does anyone have a *simple* schematic for a tone generator? I am putting EI fuel gages (both quantity and fuel flow). EI has one wire that supplies a ground when one of the LED's light to alert you of an action, whether it be a warning or simply a timer. I was thinking about hooking that wire to a tone generator and using it as a "master caution". I know they have such a thing, as EI sells them, but they are a little pricey, considering it's an "extra". Anyway, I figured that it can't be too tough of a circuit to build. Thanks, Keith Hughes RV-6, Denver ________________________________________________________________________________
Subject: Re: Tone generator
Date: Jul 19, 2002
Keith Hughes wrote: > > > Does anyone have a *simple* schematic for a tone generator? *** Piece O'cake. Do a google search for "LM555" and simple but robust tone oscillators will be presented to you. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jul 20, 2002
You can go to Radio Shack and buy a buzzer or beeper that has the circuitry built in. Those things just have two wires: power and ground. Apply power, and beeps come out. Maybe a few more bucks than rolling your own, but a heckuva lot easier. I went to www.radioshack.com and did a search on "buzzer" and came up with 30 hits, many of 'em work on 12VDC. I clicked on one at random and it was $5. (cat #273-066) -Matt > Does anyone have a *simple* schematic for a tone generator? I am > putting EI > fuel gages (both quantity and fuel flow). EI has one wire that supplies a > ground when one of the LED's light to alert you of an action, > whether it be > a warning or simply a timer. I was thinking about hooking that wire to a > tone generator and using it as a "master caution". I know they > have such a > thing, as EI sells them, but they are a little pricey, considering it's an > "extra". Anyway, I figured that it can't be too tough of a circuit to > build. ________________________________________________________________________________
Date: Jul 20, 2002
> > Does anyone have a *simple* schematic for a tone generator? I am > > putting EI fuel gages (both quantity and fuel flow). Who is EI? I'm looking for capacitence senders and gauges that cost less than $300. Any recommendations? John Slade ________________________________________________________________________________
Date: Jul 20, 2002
Subject: Re: Tone generator capacitance sender
John Slade wrote: > > > > > Does anyone have a *simple* schematic for a tone generator? I am > > > putting EI fuel gages (both quantity and fuel flow). > Who is EI? I'm looking for capacitence senders and gauges that cost less > than $300. Any recommendations? > John Slade John: Actually, they're not too hard to build yourself. I did some experiments and plan to build one. A flat plat capacitor about the size of your hand hooked into a NE555 oscillator circuit varies the frequency quite a bit. The capacitance is from a few hundred PF to 600 or so. Jim Weir wrote an article about a similar design about 3 years ago in kit planes. -- Tom Sargent. ________________________________________________________________________________
Date: Jul 20, 2002
EI is Electronics International. They are located in Oregon and have a website: http://www.buy-ei.com/ John > Who is EI? I'm looking for capacitence senders and gauges that cost less > than $300. Any recommendations? > John Slade > > _ ________________________________________________________________________________
Date: Jul 21, 2002
Subject: RG Battery failure (but not in airplane)
I found yesterday following a power failure at home that my RF 12V 7A alarm system battery was dead. Not only dead, but also damaged. See picture: http://pages.infinit.net/mthobby/batterie.jpg That battery was about 7 or 8 years old. Alarm system mfg mandates battery change after 5 year. I believe that there is a constant floating charge applied to the battery in this application, but I did not know that such failure could happen. The nice thing is that it did not leak at all. Any comments? ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://health.yahoo.com ________________________________________________________________________________
From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Solid facts about "imported" electric horizons ?
Date: Jul 22, 2002
Hi, all Anyone around here has feedback from "imported" electric horizons like those from AS ? Of course I know the general opinion, you get what you pay for, etc. But the only feedback I can remember from the last time this subject was discussed here is a conversation about a failed RC Allen gyro, and their strange sense of warranty. Has anyone here bought an imported electric gyro, and is satisfied (or dissatisfied) with it ? Or does someone know of someone who did ? Electric horizons are so expensive I'd like to thoroughly ponder the pros and cons, and get solid information about those instruments before buying. Our project is primarily for VFR. Any facts or comments welcome, Thanks Gilles ________________________________________________________________________________
Date: Jul 22, 2002
Subject: Re: RG Battery failure (but not in airplane)
Michel, I have worked with this type of battery for the last 15 or more years. They have been used in the application of UPS (uninterruptible power supply) back up batteries, computer system stand by batteries, fire alarm system stand by batteries and security alarm system stand by batteries. The failure and damage that your photo shows seems to be typical of what I have found over the years. I have used a life expectancy of 3 to 5 years as a rule of thumb to keep them reliable. In aviation, as Bob suggests, maybe it should be more like 1 or 2 years. I have found 3 common failure modes in the work I have done with them. 1. They will not recover from a deep discharge. After deep discharge, they will over heat, swell, and split open (as your photo shows) during attempt to recharge. 2. A good, fully charged unit will over heat and fail as above if anything more than a true "float" voltage is applied. 3. If a new or fully charged unit is not float charged during storage, it will sulfate and go bad in less than a year just sitting on the shelf. Too finicky for our use? They will not leak corrosive electrolyte on our pretty birds. This is the single best feature in my book. I think they are great as long as we take care not to overcharge them, deep discharge them or let them sit too long in storage. I won't be buying my battery until I am ready to crank the engine for the first time. John P. Marzluf Columbus, Ohio Kitfox Outback, (out back in the garage) ________________________________________________________________________________
Date: Jul 22, 2002
From: John Mireley <glcompair(at)mireley.tcimet.net>
Subject: electronic capacitance fuel gauge senders
> Who is EI? I'm looking for capacitence senders and gauges that cost less > than $300. Any recommendations? > John Slade http://www.recreationalmobility.com/Product/Airframe_Accessories/Instruments/Falcon/fuel_gauges.asp Recreational Mobility, 12 or 24 inch bendable senders $70 I've not used these. If you decide to use them, please let me know how they work out. -- John Mireley Great Lakes Comp Air 5020 U.S. 20 West Angola, IN 46703 FAX/Voice Mail - 5173323127 Internet - http://198.109.164.162/glcompair ________________________________________________________________________________
Subject: Re: electronic capacitance fuel gauge senders
Date: Jul 22, 2002
doesn't Spruce or Wicks have Westach capacitance senders and gauges for under $300? last I looked it was about $100/sender and less for the dual gauge. I heard that they work fine. Gary K. ----- Original Message ----- From: "John Mireley" <glcompair(at)mireley.tcimet.net> Subject: AeroElectric-List: electronic capacitance fuel gauge senders > > > > Who is EI? I'm looking for capacitence senders and gauges that cost less > > than $300. Any recommendations? > > John Slade > > http://www.recreationalmobility.com/Product/Airframe_Accessories/Instruments /Falcon/fuel_gauges.asp > > > Recreational Mobility, 12 or 24 inch bendable senders $70 > I've not used these. If you decide to use them, please > let me know how they work out. > > > -- > John Mireley > Great Lakes Comp Air > 5020 U.S. 20 West > Angola, IN 46703 > FAX/Voice Mail - 5173323127 > Internet - http://198.109.164.162/glcompair > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 22, 2002
Subject: Re: Solid facts about "imported" electric
horizons ?
FWIW: I originally ordered one of the import AIs from AS thinking that a grand should get you something fairly decent. It did not work out of the box and some seven months and $700 later I finally got the RC Allen unit as a replacement. About seven hours on it so far and it is doing fine. Bob -- > From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr> > Reply-To: aeroelectric-list(at)matronics.com > Date: Mon, 22 Jul 2002 00:47:17 +0200 > To: > Subject: AeroElectric-List: Solid facts about "imported" electric horizons ? > > <Gilles.Thesee@ac-grenoble.fr> > > Hi, all > > Anyone around here has feedback from "imported" electric horizons like those > from AS ? > Of course I know the general opinion, you get what you pay for, etc. > But the only feedback I can remember from the last time this subject was > discussed here is a conversation about a failed RC Allen gyro, and their > strange sense of warranty. > Has anyone here bought an imported electric gyro, and is satisfied (or > dissatisfied) with it ? > Or does someone know of someone who did ? > Electric horizons are so expensive I'd like to thoroughly ponder the pros > and cons, and get solid information about those instruments before buying. > Our project is primarily for VFR. > > Any facts or comments welcome, > > Thanks > Gilles > > ________________________________________________________________________________
Date: Jul 22, 2002
Subject: Feed the ignition bus from both batts simultaneously?
Gday.. I didn't find this specifically in the archives - so here goes: I feed my dual-channel electronic ignition box, and dual coils, and main fuel pumps from the 'key' bus. This bus MUST be powered to keep the engine running. So, of course I want this bus to be as reliable as possible. 1/ Can I feed it directly from both of my two batteries (RGB - ala Aeroelectric connection) with a diode assembly in each feed to isolate the batteries from one another? 2/ Would these feeds be good candidates for fuselinks instead of fuses/cbs to ensure high reliability? Thanks, -- Grant Corriveau Montreal Zodiac 601hds/CAM100 C-GHTF www.theWingStayedON.ca ________________________________________________________________________________
Subject: Re: Solid facts about "imported" electric horizons
Date: Jul 22, 2002
----- Message d'origine ----- De : "Bob & Karen Risch" : Envoy : lundi 22 juillet 2002 19:25 Objet : Re: AeroElectric-List: Solid facts about "imported" electric horizons ? > > FWIW: > I originally ordered one of the import AIs from AS thinking that a grand > should get you something fairly decent. It did not work out of the box and > some seven months and $700 later I finally got the RC Allen unit as a > replacement. About seven hours on it so far and it is doing fine. > > Bob > -- > > > > From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr> > > Reply-To: aeroelectric-list(at)matronics.com > > Date: Mon, 22 Jul 2002 00:47:17 +0200 > > To: > > Subject: AeroElectric-List: Solid facts about "imported" electric horizons ? Bob, Thanks for the input. Gilles ________________________________________________________________________________
Date: Jul 22, 2002
The current probes have 0-5V DC output so many different displays are possible. Paul ----- Original Message ----- From: "Gary K" <flyink(at)efortress.com> Subject: Re: AeroElectric-List: electronic capacitance fuel gauge senders > > doesn't Spruce or Wicks have Westach capacitance senders and gauges for > under $300? last I looked it was about $100/sender and less for the dual > gauge. I heard that they work fine. > > Gary K. > > ----- Original Message ----- > From: "John Mireley" <glcompair(at)mireley.tcimet.net> > To: > Subject: AeroElectric-List: electronic capacitance fuel gauge senders > > > > > > > > > > Who is EI? I'm looking for capacitence senders and gauges that cost less > > > than $300. Any recommendations? > > > John Slade > > > > > http://www.recreationalmobility.com/Product/Airframe_Accessories/Instruments > /Falcon/fuel_gauges.asp > > > > > > Recreational Mobility, 12 or 24 inch bendable senders $70 > > I've not used these. If you decide to use them, please > > let me know how they work out. > > > > > > -- > > John Mireley > > Great Lakes Comp Air > > 5020 U.S. 20 West > > Angola, IN 46703 > > FAX/Voice Mail - 5173323127 > > Internet - http://198.109.164.162/glcompair > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 22, 2002
In a message dated 7/22/2002 6:09:43 AM Pacific Daylight Time, glcompair(at)mireley.tcimet.net writes: > Recreational Mobility, 12 or 24 inch bendable senders $70 > I've not used these. If you decide to use them, please > let me know how they work out. > Think these are the same units sold by Westach Instruments; may even be manufactured by them. Considered using them myself, but not yet, so would be interested in any experience with these as well. doug ________________________________________________________________________________
Date: Jul 22, 2002
> >I found yesterday following a power failure at home >that my RF 12V 7A alarm system battery was dead. Not >only dead, but also damaged. See picture: > >http://pages.infinit.net/mthobby/batterie.jpg > >That battery was about 7 or 8 years old. Alarm system >mfg mandates battery change after 5 year. I believe >that there is a constant floating charge applied to >the battery in this application, but I did not know >that such failure could happen. > >The nice thing is that it did not leak at all. After you replace the battery, measure voltage at the battery terminals while the "charger" is on and after several days. The closest I ever came to hurting someone really bad happened about 25 years ago. I designed a refrigeration failure alarm system for those semi-portable, outdoor cooler/freezer units you see behind Burger King, etc. This thing was housed in a super heavy duty, sealed enclosure to take the worst any weather could inflict. A bell on the outside and a flashing red light on top would annunciate power and/or refrigeration failure. Backup battery power was one of the first prismatic RG batteries to show up on the market. One night, a local user of the product went out to his cooler and hit the press-to-test switch. A few minutes later, he called the service department to complain that his alarm system "disappeared" . . . The following morning, the techs showed up in my office with the run-away alarm box. It had puffed up like a blow fish (NEMA-4 enclosure held up very nicely) and was kind of beat up. Seems the battery charger failed (insufficient heat sinking) and put the super- push of electrons into the battery. It out-gassed with what must have been pretty much ideal ratio of H2 to O2. When the guy hit the switch, the contents ignited and the rocket-thrust of gasses out the conduit fitting on the back pulled the lag screws out of the cooler frame and the whole box launched across the parking lot. Had the box been mounted at head-level or lower, there would have been great risk to anyone standing in front of the enclosure. As it was, the surprised burger-flipper heard a loud whoosh and the box simply disappeared. A re-design of the charger -AND- appropriate ventilation holes precluded a future event. I've oft marveled at my lucky stars since. Bob . . . ________________________________________________________________________________
Date: Jul 22, 2002
Subject: Re: Feed the ignition bus from both batts simultaneously?
> >Gday.. > >I didn't find this specifically in the archives - so here goes: > >I feed my dual-channel electronic ignition box, and dual coils, and main >fuel pumps from the 'key' bus. This bus MUST be powered to keep the engine >running. So, of course I want this bus to be as reliable as possible. > >1/ Can I feed it directly from both of my two batteries (RGB - ala >Aeroelectric connection) with a diode assembly in each feed to isolate the >batteries from one another? If you have two batteries, then I'd recommend two battery busses. Distribute half your ignition and fuel pumps between the two busses. Use individual toggle switches to control each device. A 6-slot fuse-block on each battery generally gives you enough power sources for engine and other misc devices that want either continuous or most reliability power sources. Each battery needs it's own "contactor" a-la Figure Z-30. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Subject: RG Battery Standard charging
Date: Jul 22, 2002
Bob, Using your wiring methods Is there really any need to worry about overcharging these Batteries (ie Recumbent Gas) Thanks Bruce Banks in Las Vegas ________________________________________________________________________________
Date: Jul 22, 2002
Subject: Re: L40 Alternator Cooling Test
> > >Bob: > >I'd be glad to run a cooling test on the alternator. > >HOWEVER, I'm about 4 months away from flying. > >I have made provisions to have a spare temperature port in my Grand Rapids >Engine Information System. > >I'll be able to attach the temperature sensor most anywhere in the engine >compartment. > >I'll get in contact with you after my first flight. Sounds like a plan. What is the temperature sensor technology? Thermocouple? What Kind? Bob . . . ________________________________________________________________________________
Date: Jul 23, 2002
----- Original Message ----- Subject: Re: AeroElectric-List: electronic capacitance fuel gauge senders : : In a message dated 7/22/2002 : glcompair(at)mireley.tcimet.net writes: : Think these are the same units sold by Westach Instruments; may even be : manufactured by them. Considered using them myself, but not yet, so would be : interested in any experience with these as well. : doug Have used a Westach, unit purchased from ACS, for 3 yrs. No problems. Londt ======================================================================= http://www.matronics.com/browselist/aeroelectric-list : : : : : : ________________________________________________________________________________
Date: Jul 23, 2002
From: "Paul A. Franz, P.E." <paul(at)eucleides.com>
senders At 05:06 AM 7/22/2002John Mireley sez: > > Who is EI? I'm looking for capacitence senders and gauges that cost less > > than $300. Any recommendations? > > John Slade > > ><http://www.recreationalmobility.com/Product/Airframe_Accessories/Instruments/Falcon/fuel_gauges.asp> > > >Recreational Mobility, 12 or 24 inch bendable senders $70 >I've not used these. If you decide to use them, please >let me know how they work out. Floats type senders came with my kit. Looks like something from JC Whitney. The problem is that the floats can only move about 4 total inches of travel and they are an inch and a half in diameter so the touch the top before they could float to full and when all the way against the bottom of the leaning tank it is still a third full. So I would like to use the capacitive type senders referenced above too. I'd have to use the longer ones - 24". Is there any problem with them rattling in a near empty tank? Can I use my existing gauges? Can this setup be calibrated to match the actual fuel amount given that there is not a linear relationship between depth and amount of fuel? Any drawbacks to their use? Like fire hazard, calibration difficulty? Anybody out there using them? Paul Franz PAF Consulting Engineers | 427 - 140th Ave NE (425)641-8202 voice | Bellevue, WA 98005 (425)641-1773 fax | <http://blackdog.bellevue.wa.us/> ________________________________________________________________________________
Date: Jul 23, 2002
Paul - Check out Westach at: http://www.frostalarm.com/cat/p35.html It will answer some of these questions - see 800 number at page bottom. Bill Mills RANS Courier in progress (sight tube fuel quantity indicating system with Horizon fuel flow meter) SF bay area, Calif. > >---------snip------------- >Floats type senders came with my kit. Looks like something from JC Whitney. >The problem is that the floats can only move about 4 total inches of travel >and they are an inch and a half in diameter so the touch the top before >they could float to full and when all the way against the bottom of the >leaning tank it is still a third full. So I would like to use the >capacitive type senders referenced above too. > >I'd have to use the longer ones - 24". Is there any problem with them >rattling in a near empty tank? > >Can I use my existing gauges? > >Can this setup be calibrated to match the actual fuel amount given that >there is not a linear relationship between depth and amount of fuel? > >Any drawbacks to their use? Like fire hazard, calibration difficulty? >Anybody out there using them? > > >Paul Franz > >PAF Consulting Engineers | 427 - 140th Ave NE >(425)641-8202 voice | Bellevue, WA 98005 >(425)641-1773 fax | > <http://blackdog.bellevue.wa.us/> > > ________________________________________________________________________________
Date: Jul 23, 2002
> Check out Westach at: http://www.frostalarm.com/cat/p35.html > It will answer some of these questions - see 800 number at page bottom. Interesting - this is the one that Blue Mountain (EFIS-1) links to from their web page. I guess that clinches it. John Slade ________________________________________________________________________________
Date: Jul 23, 2002
Subject: Re: RG Battery Standard charging
> >Bob, > >Using your wiring methods Is there really any need to worry about >overcharging these Batteries (ie Recumbent Gas) Thanks Bruce Banks in Las >Vegas It's not hard to degrade a battery's performance by either over or under charging. This is true irrespective of the battery technology. All other things being equal, RG batteries tend to be more robust with respect to slight overcharge (15.0 volts or so) as it affects life and with respect to severe overcharge as it affects hazardous behavior (the critters go "psssst" and it's all over). RG batteries have fewer "worries" in that they are less likely to become an explosion hazard if the battery box is ventilated or simply replaced with an open tray. They are also incapable of leaking nasty stuff that eats up your airplane. Yes, you can smoke an RG battery or any other battery by overcharging it. It's not difficult to avoid overcharge damage and if it does happen, likelihood of severe consequences is nil. Bob . . . ________________________________________________________________________________
Subject: Aircraft chargers
Date: Jul 23, 2002
Are chargers for aircraft of higher voltage than the standard auto chargers?? Seems I recall reading about this sometime ago. Wayne ________________________________________________________________________________
Subject: Wire size confusion
Date: Jul 23, 2002
Bob, I'm wiring my position lights and nav lights. Each bulb has a resistance of 10 ohms, so it'll draw 1.4 amps at 12v. The wires for both left and right nav & position will go back to the same switch and fuse, so I have a total of 5.6 amps draw when everything is on. If I understand "the book" correctly, I need to supply each item on the same circuit with the same size wire, so I need 20AWG wire to each item. Am I on the right track? Regards, John Slade > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > William Mills > Sent: Tuesday, July 23, 2002 9:40 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: electronic capacitance fuel gauge > senders > > > > > Paul - > > Check out Westach at: http://www.frostalarm.com/cat/p35.html > It will answer some of these questions - see 800 number at page bottom. > > Bill Mills > RANS Courier in progress > (sight tube fuel quantity indicating system with Horizon fuel flow meter) > SF bay area, Calif. > > > > >---------snip------------- > >Floats type senders came with my kit. Looks like something from > JC Whitney. > >The problem is that the floats can only move about 4 total > inches of travel > >and they are an inch and a half in diameter so the touch the top before > >they could float to full and when all the way against the bottom of the > >leaning tank it is still a third full. So I would like to use the > >capacitive type senders referenced above too. > > > >I'd have to use the longer ones - 24". Is there any problem with them > >rattling in a near empty tank? > > > >Can I use my existing gauges? > > > >Can this setup be calibrated to match the actual fuel amount given that > >there is not a linear relationship between depth and amount of fuel? > > > >Any drawbacks to their use? Like fire hazard, calibration difficulty? > >Anybody out there using them? > > > > > >Paul Franz > > > >PAF Consulting Engineers | 427 - 140th Ave NE > >(425)641-8202 voice | Bellevue, WA 98005 > >(425)641-1773 fax | > > <http://blackdog.bellevue.wa.us/> > > > > > > ________________________________________________________________________________
Date: Jul 23, 2002
Subject: Re: Wire size confusion
> >Bob, >I'm wiring my position lights and nav lights. >Each bulb has a resistance of 10 ohms, so it'll draw 1.4 amps at 12v. >The wires for both left and right nav & position will go back to the same >switch and fuse, so I have a total of 5.6 amps draw when everything is on. >If I understand "the book" correctly, I need to supply each item on the same >circuit with the same size wire, so I need 20AWG wire to each item. Am I on >the right track? Yes. Nav lights I've worked with in past draw 2 amps each on 14v system for a total of 6A. This means that the entire system has to be wired such that the wiring attached to a 7A fuse or breaker is not at risk. This translates to 20AWG wire or larger. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2002
Subject: Re: Aircraft chargers
> >Are chargers for aircraft of higher voltage than the standard auto >chargers?? Seems I recall reading about this sometime ago. >Wayne Can't imagine why. Bob . . . ________________________________________________________________________________
Date: Jul 23, 2002
Subject: Heads-up on Blue Mountain
Recently did a factory seminar for our friends at Lancair out in Redmond, OR. They've been trying to work with the folks at Blue Mountain Avionics . . . http://www.bluemountainavionics.com/ As of the date of my trip to Lancair (July 15), the folks at Lancair had yet to see a set of working hardware. They'd unsucessfully tried to install several versions of hardware. Just a heads up for folks on the list. I sincerely wish Blue Mountain well in their efforts but be advised that it's a good idea to talk to several satisfied customers of a product before you plunk down kilobucks. If I hear anything from Lancair, I'll post it here. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 23, 2002
Robert L. Nuckolls, III wrote: > > > > > >Are chargers for aircraft of higher voltage than the standard auto > >chargers?? Seems I recall reading about this sometime ago. > >Wayne > > Can't imagine why. > *** 28V Cessnas? Also, this reminds me of a really interesting article I found on the Internet - nothing to do with airplanes, everything to do with charging voltage of batteries: http://www.landiss.com/battery.htm - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jul 23, 2002
Subject: Re: Heads-up on Blue Mountain
>Bob: I talked to a major supplier of custom panels at Arlington who has had a similar experience to Lancair's. Hope they get it working, I'd like to use it. >Just a heads up for folks on the list. I sincerely wish Blue >Mountain well in their efforts but be advised that it's a good idea >to talk to several satisfied customers of a product before you plunk >down kilobucks. -- John ________________________________________________________________________________
Date: Jul 23, 2002
> >Bob, > >I'm wiring my position lights and nav lights. > >Each bulb has a resistance of 10 ohms, so it'll draw 1.4 amps at 12v. > >The wires for both left and right nav & position will go back to the same > >switch and fuse, so I have a total of 5.6 amps draw when > everything is on. > >If I understand "the book" correctly, I need to supply each item > on the same > >circuit with the same size wire, so I need 20AWG wire to each > item. Am I on > >the right track? > > > Yes. Nav lights I've worked with in past draw 2 amps each > on 14v system for a total of 6A. This means that the entire > system has to be wired such that the wiring attached to a > 7A fuse or breaker is not at risk. This translates to 20AWG > wire or larger. > > Bob . . . OK, thanks. One follow-on question if I may.... I can't see any reason why I'd want nav lights off and position lights on, or vice versa, so can I splice these wires up at the fitting and just run one feed, or is that a no-no? John Slade, Cozy IV ________________________________________________________________________________
Date: Jul 23, 2002
There are two sides to every story, and it's interesting to read the other side as well. This is all available on the Blue Mountain website. Sometimes it's hard to figure out which side is telling the truth, but I personnally will be very cautious when dealing with Lancair from now on (ya, right - like I'm shopping for a IVP). But if half of what Greg said about Lancair is true, then when I do hit the lottery I'll skip right over them and get a Maverick jet or something else instead ;<}. I have an EFIS/Lite mounted in my panel ready to go. Not flying yet, but I'm impressed with what I got and what I paid for it. If there are some bugs, I'm confident they will be worked out to everyone's satisfaction. Bad press on the internet spreads fast and can be pretty ruthless. Bob's comments were very diplomatic as usual and simply cautionary verses derogatory (and I agree, everyone should do their homework), but I just had to add a comment in support of BMA because I know they are working hard to get an affordable state-of-the-art instrument out to other homebuilders. I was waiting for the new MicroAir stuff and the Dynon and gave up on both because they were making delivery promises they couldn't keep, but I'm sure they will also work as advertised after initial development and delivery problems. I guess that's just what it's like to be the first customers in the experimental market. Happy building and safe flying, Gary K. ________________________________________________________________________________
Date: Jul 23, 2002
Maybe it was in connection with aircraft voltage regulators vice auto regulators of 12 years ago. That was the time I was installing my electrics in my MustangII. Seems from the article in the link below, auto batteries are using more advanced technology then a decade or more ago so the standard chargers have the same task as aircraft. Anyway thanks for the info. BTW, I have used Concord batteries and the usual aircraft starter and alternator with nothing but the usual failures (two Concord lead-acid batteries in 3 years). Since talking to Sean Tucker circa 1994, I have gone to B&C EE battery, starter, regulator and alternator. The first 30 AH B&C was still going strong after 8 years and 500 hours. I felt that battery has served well and installed a new one, although it was still spinning my O-360 easily. Good stuff that B ask Sean Tucker. I remember when he could hardly get his 400 HP + Lycoming spinning at all. Wayne ----- Original Message ----- From: <jerry(at)tr2.com> Subject: Re: AeroElectric-List: Re: Aircraft chargers > > Robert L. Nuckolls, III wrote: > > > > > > > > > >Are chargers for aircraft of higher voltage than the standard auto > > >chargers?? Seems I recall reading about this sometime ago. > > >Wayne > > > > Can't imagine why. > > > *** 28V Cessnas? > > Also, this reminds me of a really interesting article I found on the > Internet - nothing to do with airplanes, everything to do with > charging voltage of batteries: > > http://www.landiss.com/battery.htm > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Jul 23, 2002
senders John, As previously mentioned, Jim Weir designed a module to allow capacitance senders to be used with standard (ie cheap) resistive style gauges. I've installed the capacitance senders in both fuel tanks of my RV-8A. A friend of mine is currently building a pair of Jim Weir's modules for me. Feel free to contact me off list at chaskuss(at)bellsouth.net for more info. Charlie Kuss >> Who is EI? I'm looking for capacitence senders and gauges that cost less than $300. Any recommendations? >> John Slade ________________________________________________________________________________
Date: Jul 23, 2002
At 08:23 AM 7/23/2002Robert L. Nuckolls, III sez: > Yes, you can smoke an RG battery or any other battery > by overcharging it. It's not difficult to avoid > overcharge damage and if it does happen, likelihood > of severe consequences is nil. > > Bob . . . My old Cherokee 160 had a generator not an alternator and I went through batteries like crazy and smoked radios in the panel more than once. I discovered they voltage regulator had to be replaced. using a Piper Part it was pretty pricey and would only last a while. Taking them apart I discovered the field contacts were welded closed. One time it overheated the generator so much it slung the solder out of it. I took it to an Auto-Electric shop and they refurbished it for a small fraction of the cost of getting a rebuilt one. Eventually I found another voltage regulator that would last longer just by looking at the shape of the case to match the mounting holes. It was for a John Deere combine. They were a fraction of the cost but still didn't last more than a year. 1) Was it legal for me (not an A&P) to remove the generator and have it repaired at an Auto-Electric shop? How about using the John Deere part which worked better but still wasn't a solution? 2) Why did the field points weld closed every few hours? 3) If I could have installed your crowbar OV protection back then, would that have solved the problem? Or is there more to the picture? BTW, even though the battery cables going to the starter were huge, it always seemed to be marginal whether it would turn over when cold. Would have to hit the starter button a couple of times to get it to start to spin over. One time at an airport, got a jump with 24 volts and boy did it start quickly. Since the battery usually had one totally bad cell from the overcharging I got used to hand starting that Cherokee as a matter of course. Paul Franz PAF Consulting Engineers | 427 - 140th Ave NE (425)641-8202 voice | Bellevue, WA 98005 (425)641-1773 fax | <http://blackdog.bellevue.wa.us/> ________________________________________________________________________________
Subject: SD-8 in dual battery configuration
Date: Jul 23, 2002
Bob, I am using your Z-13 and Z-25 drawings for a dual battery configuration. A main battery for all components and FADEC primary supply buss, a 7amp battery for Ess. and FADEC secondary buss. My question concerns a "what if" I were to leave a switch on for example in ground testing ESS buss or left on FADEC power and ended up discharging 7 amp battery. There is no way to bring the SD-8 "on line" as power for the relay comes via the discharged battery. So the question is to get the SD-8 on line to charge the backup battery, should I use a switch to temporarily bypass the relay, or another relay to crossfeed the main battery/alternator to charge the backup battery? Dave Ford RV6 ________________________________________________________________________________
Date: Jul 24, 2002
Paul A. Franz, P.E. wrote: > > 1) Was it legal for me (not an A&P) to remove the generator and have it > repaired at an Auto-Electric shop? *** No. It wouldn't even be legal for you to remove it and have it repaired by an FAA repair station. You would need to have it signed off by an A&P or IA. How about using the John Deere part > which worked better but still wasn't a solution? > *** Nope. > BTW, even though the battery cables going to the starter were huge, it > always seemed to be marginal whether it would turn over when cold. Would > have to hit the starter button a couple of times to get it to start to spin > over. One time at an airport, got a jump with 24 volts and boy did it start > quickly. *** Aluminum battery cables? Seems to me that Piper was using aluminum cables... People used to replace them with copper, there are approved kits for that. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Jul 24, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > > > > Bob . . . >OK, thanks. One follow-on question if I may.... >I can't see any reason why I'd want nav lights off and position lights on, >or vice versa, so can I splice these wires up at the fitting and just run >one feed, or is that a no-no? >John Slade, Cozy IV You lost me. Which are the 'nav' and which are the 'position' lights? Around here the terms are interchangeable in referring to the red, white and green lights at the corners of the airframe. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2002
> >I can't see any reason why I'd want nav lights off and position > lights on, > >or vice versa, so can I splice these wires up at the fitting and just run > >one feed, or is that a no-no? > >John Slade, Cozy IV > > You lost me. Which are the 'nav' and which are the 'position' > lights? Around here the terms are interchangeable in referring > to the red, white and green lights at the corners of the airframe. > Ah. By "Nav" lights I mean the red and green. By "Position" lights I mean the white rearward facing lights. You're talking about the fittings. I'm talking about the individual bulbs which each have a wire coming out of the fitting. I guess I should just splice these together at or inside the fitting. John Slade ________________________________________________________________________________
Date: Jul 24, 2002
> > >At 08:23 AM 7/23/2002Robert L. Nuckolls, III sez: > > Yes, you can smoke an RG battery or any other battery > > by overcharging it. It's not difficult to avoid > > overcharge damage and if it does happen, likelihood > > of severe consequences is nil. > > > > Bob . . . > >My old Cherokee 160 had a generator not an alternator and I went through >batteries like crazy and smoked radios in the panel more than once. I >discovered they voltage regulator had to be replaced. using a Piper Part it >was pretty pricey and would only last a while. Taking them apart I >discovered the field contacts were welded closed. One time it overheated >the generator so much it slung the solder out of it. I took it to an >Auto-Electric shop and they refurbished it for a small fraction of the cost >of getting a rebuilt one. Eventually I found another voltage regulator that >would last longer just by looking at the shape of the case to match the >mounting holes. It was for a John Deere combine. They were a fraction of >the cost but still didn't last more than a year. > >1) Was it legal for me (not an A&P) to remove the generator and have it >repaired at an Auto-Electric shop? How about using the John Deere part >which worked better but still wasn't a solution? No, but a whole LOT of folks used to do just that. >2) Why did the field points weld closed every few hours? Relatively poor quality of regulator or perhaps the generator had a shorted field winding that caused it to draw excessive current. >3) If I could have installed your crowbar OV protection back then, would >that have solved the problem? Or is there more to the picture? The crowbar ovm combined with a relay to open the generator's field winding during an ov condition would help avoid the consequences of an ov condition. >BTW, even though the battery cables going to the starter were huge, it >always seemed to be marginal whether it would turn over when cold. Would >have to hit the starter button a couple of times to get it to start to spin >over. One time at an airport, got a jump with 24 volts and boy did it start >quickly. Yup, used to crank 6v cars from 12v cars and got similar results . . . obviously, a condition that has to be limited in terms of how long you leave things connected up! >Since the battery usually had one totally bad cell from the overcharging I >got used to hand starting that Cherokee as a matter of course. Yeah, my mom had a straight-8 Pontiac with a 6v system that WOULD NOT start for a combination of reasons in very cold weather. Worked out a combination of heat lamps on battery, carb and fuel pump plus battery trickle charger to keep the ol beast primed for a 0-degree start the next day. Those were not the GOOD Ol's DAYS! >Paul Franz My articles archive server went dark last night and e-mail to the hardware guy bounced as well (might be network problem). Thought I'd load the articles back onto Dr. Teeth but found that pipe plugged too. Got a reading for me? Bob . . . ________________________________________________________________________________
Date: Jul 24, 2002
> > There are two sides to every story, and it's interesting to read the other >side as well. This is all available on the Blue Mountain website. >Sometimes it's hard to figure out which side is telling the truth, but I >personnally will be very cautious when dealing with Lancair from now on (ya, >right - like I'm shopping for a IVP). But if half of what Greg said about >Lancair is true, then when I do hit the lottery I'll skip right over them >and get a Maverick jet or something else instead ;<}. The division of Lancair I was referring to is their avionics assembly and builder assistance center. I spent the better part of three days working with a capable and attentive staff who took time off from their tasks of assembling instrument panels for builders to attend my seminar. There were about a dozen panels under construction that ranged from 30 to 100K dollars. The impression I got working with these folks was that they are always looking for ways to give more value to their customers. They've assembled a lot of glass cockpit installations. My impression was that they would be delighted to offer a $10K EFIS to their customers if they can credibly recommend it. A question that comes to mind about your comment is why they would they lie to me? I was told that someone from BMA was in their shop personally at least once and that they had tried to install a BMA system in an airframe several times. It demonstrated serious bugs in behavior when the sensor system was put into motion. Some of the Lancair folks monitor this list. If anyone there would care to give us a factual narrative of their experience with BMA, I'm sure we'd like to hear it. > I have an EFIS/Lite mounted in my panel ready to go. Not flying yet, but >I'm impressed with what I got and what I paid for it. If there are some >bugs, I'm confident they will be worked out to everyone's satisfaction. > Bad press on the internet spreads fast and can be pretty ruthless. >Bob's comments were very diplomatic as usual and simply cautionary verses >derogatory (and I agree, everyone should do their homework), but I just had >to add a comment in support of BMA because I know they are working hard to >get an affordable state-of-the-art instrument out to other homebuilders. Can't comment because I don't know the details of their operation. I do recall dozens of folks "working hard" out of a building on Newton, KS airport for a number of years while Jim Bede drummed up support for his idea of what the future of amateur built airplanes ought to look like. > I was waiting for the new MicroAir stuff and the Dynon and gave up on both >because they were making delivery promises they couldn't keep, but I'm sure >they will also work as advertised after initial development and delivery >problems. Yup, and I'm about to take them down off my website catalog because I'm weary of making excuses to folks who want to buy them. Of the several dozens of radios I've delivered, all seem to be pleased with their purchase but that still doesn't offset my discomfort with dangling a carrot that (for the moment) cannot be reached . . . > I guess that's just what it's like to be the first customers in >the experimental market. True. It's like buying stocks. If you go on faith, you act based upon who's writings and oratory you find most attractive. I'd prefer to build an activity based on a track record of customers who believe they got good value for what they received. Like a company's long term demonstrated commitment to good value AND profitability, a customer's words have more value than the supplier's words when it comes to separating me from my money. It's true that SOMEBODY has to be the first customer. For myself, before I plunked down that kind of cash for any of the first few articles, it would really be nice to see it flying and get a pilot report from somebody who knows what their doing when evaluating a new product. I'd also like to see how well the thing is put together inside. I don't know if BMA has published any pilot reports but they have invested in a lot of advertising and have a booth at OSH . . . been there, done that, it takes a lot of cash. For a fraction of what they've spent in promotion, they could hire a credible reviewer to put sturdy legs under their sales effort. Before one of our customers took delivery of a new Premier, we had about 1,000 hours of FLIGHT experience with the machine and in spite of that effort, we're still chasing bugs from systems. But the first airplane didn't get delivered until we were as confident as we could be that the airplane wasn't going to produce really unhappy and perhaps lethal surprises. I know that BMA doesn't have to be CERTIFIED but that doesn't relieve them of a responsibility for having the same confidences in their product's ability to perform as if it WERE certified. Call it "bad press" if you wish but if you find that my facts are in error, I'd be pleased to know about it. Errors not withstanding, the facts shared with me to date suggest caution. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2002
> A question that comes to > mind about your comment is why they would they lie to me? How about higher profit margins on higher priced equipment? > I was told that someone from BMA was in their shop personally Bob, Have you read Greg Richter's description of what occured during that and other visits? If not, I think you should, as should anyone giving this Lancair commentary any credence. See http://www.bluemountainavionics.com/discus/messages/1/85.html?1027448310 and scroll down to Greg's comments. Having read both sides of the story, my personal reaction is that there's some very deliberate corporate politics going on here. Bob, presuming that you don't have an axe to grind either way I'd very much like to read YOUR evaluation of the Blue Mountain EFIS box. In the meantime, I'm saving up for one. > It's true that SOMEBODY has to be the first customer. Its my understand that Blue Mountain has shipped over 100 units. I think they're well past the first customer situation. > Call it "bad press" if you wish but if you find that > my facts are in error, I'd be pleased to know about it. You havent mentioned any FACTS, Bob. Just relayed second hand comments from one of the parties. My 2c John Slade ________________________________________________________________________________
Date: Jul 24, 2002
Subject: Re: RE: Re: Wire size confusion
> > > >I can't see any reason why I'd want nav lights off and position > > lights on, > > >or vice versa, so can I splice these wires up at the fitting and just run > > >one feed, or is that a no-no? > > >John Slade, Cozy IV > > > > You lost me. Which are the 'nav' and which are the 'position' > > lights? Around here the terms are interchangeable in referring > > to the red, white and green lights at the corners of the airframe. > > >Ah. By "Nav" lights I mean the red and green. By "Position" lights I mean >the white rearward facing lights. You're talking about the fittings. I'm >talking about the individual bulbs which each have a wire coming out of the >fitting. I guess I should just splice these together at or inside the >fitting. >John Slade Interesting. I've never heard that distinction made before. Anywho, around here we tie all the lights together on one circuit and power them up through about a 7A fuse/breaker with 20AWG or larger wire. Butt splices at any convenient place is okay . . . or, you can put three 20AWG wires into a single blue terminal for attachment to the switch. If it were my airplane, I would bring all three wires right up to the switch. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2002
Subject: Re: SD-8 in dual battery configuration
> >Bob, > >I am using your Z-13 and Z-25 drawings for a dual battery configuration. >A main battery for all components and FADEC primary supply buss, a 7amp >battery for Ess. and FADEC secondary buss. My question concerns a "what >if" I were to leave a switch on for example in ground testing ESS buss >or left on FADEC power and ended up discharging 7 amp battery. Any time I do extended maintenance on an airplane that calls for closing a battery contactor, I hook a ground power supply to the system. The task of being a mechanic is not much different than being a pilot . . . many of the same hazards exist but the results are usually less lethal. Why anyone would do any extended ground ops battery-only is like taking off with low fuel. > There is >no way to bring the SD-8 "on line" as power for the relay comes via the >discharged battery. So the question is to get the SD-8 on line to >charge the backup battery, should I use a switch to temporarily bypass >the relay, or another relay to crossfeed the main battery/alternator to >charge the backup battery? If you're going to have two alternators and two batteries, then an architecture more like Z-14 is in order. I've had several folks express an interest in this combination. The major points are that the aux battery could be small (7A is fine), crossfeed relay and battery relays can downsize to 30A plastic relays like our S704-1, and you get the ability to put either or both batteries on line to bring up either alternator. I'd also suggest a ground power connection even if it's only rated for 20A or so. This lets you connect a product like http://www.samlexamerica.com/samlexhome.htm . . . and avoid both wear, tear and risk of deep-discharging your battery(s). By the way, has your FADEC been tested for ability to stay on line during brownout expected during normal cranking? So systems go brain-dead during cranking and need independent battery support during start up. Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Jul 24, 2002
> > > >I can't see any reason why I'd want nav lights off and position > > > lights on, > > > >or vice versa, so can I splice these wires up at the fitting > and just run > > > >one feed, or is that a no-no? > > > >John Slade, Cozy IV > > > > > > You lost me. Which are the 'nav' and which are the 'position' > > > lights? Around here the terms are interchangeable in referring > > > to the red, white and green lights at the corners of the airframe. > > > > >Ah. By "Nav" lights I mean the red and green. By "Position" lights I mean > >the white rearward facing lights. You're talking about the fittings. I'm > >talking about the individual bulbs which each have a wire coming > out of the > >fitting. I guess I should just splice these together at or inside the > >fitting. > >John Slade > > > Interesting. I've never heard that distinction made before. > Anywho, around here we tie all the lights together on one > circuit and power them up through about a 7A fuse/breaker > with 20AWG or larger wire. > > Butt splices at any convenient place is okay . . . or, > you can put three 20AWG wires into a single blue terminal > for attachment to the switch. > If it were my airplane, I > would bring all three wires right up to the switch. > > Bob . . . Hmmm. Thats what I'm doing, but I'm left wondering... why am I doing this? So I can still have some lights if one circuit fails? ________________________________________________________________________________
Date: Jul 24, 2002
> > > Also, this reminds me of a really interesting article I found on the >Internet - nothing to do with airplanes, everything to do with >charging voltage of batteries: > > http://www.landiss.com/battery.htm Nice link. Pretty much accurate too. But keep in mind that all he is talking about here are flooded batteries . . . even if they are of the so called "maintenance free" type. The site also give you links to a ton of other info from manufacturers. Thanks for the heads up Jerry! ________________________________________________________________________________
Date: Jul 24, 2002
June 27, 2002 - July 24, 2002
AeroElectric-Archive.digest.vol-az
