AeroElectric-Archive.digest.vol-bf
October 04, 2002 - October 17, 2002
      >DIRECT send mails with attachement)!
      >So please, everybody connected to the Internet using MS operating systems
      >and MS mailing programm you NEED a virus scanner and have to update at least
      >ONCE A WEEK your virus definition! This will cost you around 50 bucks a
      >year, that is nothing compared to an infected computer and the hassel to
      >clean and set it up new (or it is about one hour flying a year).
          Grisoft.com has a shareware virus checker that is VERY effective.
          Our computers stay logged on 24 hours a day and the AVG system
          does a complete scan of our systems every day in the wee hours
          of the morning. It updates the virus data automatically too.
          If you have a dial-up connection or don't want to leave your
          computer on all the time, you can manually update the virus data
          at first log-on of the day. It just takes a few seconds.
          I get about a dozen attacks a day against nuckolls(at)aeroelectric.com
          AVG catches and quarantines them all. We also use Eudora e-mail
          which has not been a popular target for attacks (although the
          latest and greatest (Bugbear) does know how to search for e-mail
          addresses from Eudora's address book.
          I also get another dozen notices per day for mail that was
          "undeliverable" due to virus laden attachments. These
          are invariably from the mail servers for people I don't even
          know and have never communicated with. This means there are
          virus propagation programs out there that know how to pretend
          they are YOU in hopes that the recipient will unwittingly
          launch an attachment that arrives in your name.
          Good protection is free, e-mail programs with lower orders of
          risk are free and wary policies for the opening of
          ANY attachment makes good sense. Your service provider probably
          has disk space available to you for the crafting and posting
          of your own webpage. Even if you don't need or want a webpage,
          it is worth your trouble to learn how to upload files to that
          disk space and give others links on how to access it.
          I almost never send files as attachments to e-mails. I
          prefer to place them on my server and then give the recipient
          a link to download it.  If anything shows up in your
          mailbox with my name on it with an attachment of any kind,
          don't open it unless we've communicated about the file in
          advance and you KNOW what it contains.
Date: Oct 04, 2002
Subject: Bright-Dim switch
FWIW as more LED's illuminate they will dim more and more when run through a commom dimming resistor. I once put a dimmer on a tachometer that used 30 LED's for analog as well as 3 seven segment digital LED's. IIRC what worked well there was a 4049 ? ic that pulsed the supply current continually at perhaps 100 Hz when the other panel lights were dimmed (did not have full system voltage). Then one miniature cheap volume control varied the duty cycle of the power supplying all the LED's and dimmed them. Total cost of less than $2., the brightness did not vary depending on how many were lit, and nothing to even get warm. Don't know if this would lead to any electrical noise problems in an aircraft. Ken > Bob, > > I'm trying to figure out the best way to make a bright-dim switch for > multiple LED's in my panel driven by different circuits. My initial > thought was to run the ground for all the LED's through the toggle such > that in the Bright position, it would go directly to ground and in the > Dim position, it would go through an additional resistor to dim the > LED's. But this of course won't provide consistent results because the > amount of voltage drop across the dimming resistor would depend upon how > many of the LED circuits were turned On. > > Wondering if it would work to use a zener diode in place of the resistor > to provide a constant voltage drop for consistent dimming regardless of > how many LED's are on?? Is there a better or simpler scheme for a > Bright/Dim switch that I'm missing? > > Thanks, > > --Mark Navratil ________________________________________________________________________________
From: "Ted Hultzapple" <thultzap(at)rochester.rr.com>
Subject: Cheap Batteries
Date: Oct 04, 2002
I just got a 17a.h. battery from MECI http://www.meci.com/default.asp?mode=getitems&category=618 Part # 140-0094 I plan to use it while building and see if it will crank the engine when the time comes. Ted ________________________________________________________________________________
Date: Oct 04, 2002
From: "William Yamokoski" <yamokosk(at)lmc.cc.mi.us>
Subject: Radio Noise
Hi Folks, Enough of these complicated problems....time to get back to basics! No one has asked a beginner question in entirely too long a time. Here's mine. I have the MicroAir 760 radio, Flightcom intercom, Telex headset in my Subaru-powered Glastar. With engine off every thing is clear as a bell in the headset. Turn on the engine and I hear a pronounced clicking sound that gets faster or slower with engine rpm. The engine has its own computer. A source wire for engine rpm leads out of the computer and is connected to the Grand Rapids Engine information system tachometer function. All alternator goodies are firewall forward except for the 5A circuit breaker for the alternator and the overvoltage protection module, as per Bob's drawing for overvoltage protection for internally regulated alternators. Com antenna mounted in vertical stabilizer, antenna wire is a yellow, "triple-shielded" type supplied with the airplane kit. People listening to me broadcast say there is pronounced background noise and that transmission appears to break up. So...any ideas on this? I greatly appreciate your thoughts and suggestions. Bill Yamokoski ________________________________________________________________________________
Date: Oct 04, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Trim & autopilot Relay / Schematic
> >I'm using two MAC Stick grips model G7 and am wondering which relay to use >so that both grips can have full control of elevator/aileron trim. > >Is there a schematic schematic for this? Here is a compendium of pitch trim relay drawings from various past projects. You can mix/match features shown in here to get what you need. http://216.55.140.222/temp/PitchTrim.pdf Any spdt relay good for 1A or more will work in these circuits. If you want speed control, one of our dimmers can be modified to mount a potentiometer for speed control adjustment or you can use the dimmer drawings published at http://216.55.140.222/temp/DimFab.pdf to craft your own speed controller. >Also, each grip will have a switch that I want to disconnect the power to >the autopilot servos & control unit. The autopilot & servos draw a maximum >of 5 amps. This will probably need a relay also? > >What relay would be recommended for this? Here's a drawing from a past project that shows how to take a spring loaded, center off switch and tie it to a disconnect relay with a latching circuit to give you push-to-engage, push-to- disengage action from the stick grip switch. See: http://216.55.140.222/temp/AP_Disconnect.pdf Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: Radio Noise
> > >Hi Folks, > Enough of these complicated problems....time to get back to > basics! No one has asked a beginner question in entirely too long a > time. Here's mine. > I have the MicroAir 760 radio, Flightcom intercom, Telex headset in > my Subaru-powered Glastar. With engine off every thing is clear as a > bell in the headset. Turn on the engine and I hear a pronounced > clicking sound that gets faster or slower with engine rpm. The engine > has its own computer. A source wire for engine rpm leads out of the > computer and is connected to the Grand Rapids Engine information system > tachometer function. All alternator goodies are firewall forward except > for the 5A circuit breaker for the alternator and the overvoltage > protection module, as per Bob's drawing for overvoltage protection for > internally regulated alternators. Com antenna mounted in vertical > stabilizer, antenna wire is a yellow, "triple-shielded" type supplied > with the airplane kit. People listening to me broadcast say there is > pronounced background noise and that transmission appears to break > up. So...any ideas on this? I greatly appreciate your thoughts and suggest! Have you reviewed chapter 16 and mapped out a plan of attack for determining (1) source of noise (2) victim and (3) propagation mode? Bob . . . ________________________________________________________________________________
Date: Oct 04, 2002
What is the reason to use the momentary switch [(on) -(on)] and circuitry to actuate the relay as opposed to a simple [on-off] switch? - Jim > > >Also, each grip will have a switch that I want to disconnect the power to > >the autopilot servos & control unit. The autopilot & servos draw a maximum > >of 5 amps. This will probably need a relay also? > > > >What relay would be recommended for this? > > Here's a drawing from a past project that shows > how to take a spring loaded, center off switch > and tie it to a disconnect relay with a latching > circuit to give you push-to-engage, push-to- > disengage action from the stick grip switch. > > See: http://216.55.140.222/temp/AP_Disconnect.pdf > > > Bob . . . > ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: DPDT relay?
Why dpdt? Because you can accomplish the task with one relay instead of two, which I should think would be both lighter and less expensive. And I believe there are dpdt relays that use fast-ons. My question worded a different way would be "why not a dpdt?" Is there a DISadvantage to making it simpler, lighter and cheaper?? --Mark Navratil Cedar Rapids, Iowa RV-8A N2D canopy skirts... From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: DPDT relay? > >Bob, > >Have you ever considered offering a DPDT relay in your catalog to >complement the SPDT S704-1? You mention on your website that the S704-1 >is good for use with flaps and trim systems, but if I understand it >correctly, I will need TWO of these relays for the flaps and two for each >trim axis (I'm using the coolie hat on the Infinity stick grip for trim). > This means for flaps and two trim axis I need 6 relays (at $60), whereas >with DPDT relays I could get by with only 3 (and probably less $$) for >these functions, right? > >I know I can get DPDT relays at Radio Shack and other places but I >thought I'd ask you first....seems that other folks could use them also >and it would be nice to have some with the same kind of connectors that >the S704-1 has... Why dpdt? See: http://www.aeroelectric.com/temp/flaps.pdf The S704-1 a bit of a hog for trim but they have the distinct advantage of using fast-on connections. The diagram shown above will work with any PM motor system and best yet, it puts a dead short across the motor when both relays are relaxed. This has the effect of dynamically braking the motor and minimizes coast. ________________________________________________________________________________
Date: Oct 04, 2002
> >What is the reason to use the momentary switch [(on) -(on)] and circuitry to >actuate the relay as opposed to a simple [on-off] switch? > >- Jim You could do this. I prefer the two position latched-unlatched configuration. This keeps the a/p from coming ON with aircraft power if the stick switch were left ON. Further, the momentary ground for actuation lets you parallel multiple sources for control. Some builders want a push-it once for disconnect of all motor driven flight control surfaces . . . so you add more poles to the relay and let it control pitch and roll trim power too. This is the way most bizjets operate. Hitting a Wheel Master Disconnect button stops all electrically driven surface motion. If it were my airplane, I'd probably put the ENGAGE button on the panel and use only a DISENGAGE button on the stick. I can duplicate the DISENGAGE button on the other stick. The momentary two-position latch circuit gives you lots of options that the simple ON-OFF doesn't. Bob . . . ________________________________________________________________________________
Subject: Group LED dimmer
Date: Oct 04, 2002
Mark, The sustained brightness from an LED is determined from its DC rating - there is a maximum given. Thus all your LED lamps are fixed in maximum brightness by the current flow at prescribed voltage. However, one can 'fool' the eyes by turning on and off the LED at a rate (above 30-40 time per second) imperceptible to the human eye. At the same time the average current flow may be reduced and thus equally to the LEDs, by reducing the on/off ratio with a timer chip. Jim Weir in KitPlanes expounded on this a while back. You might want to consult him. Ferg ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: Zener diode OV protection for alternators
I am in the process of the final installation of a Nippon-Dienso(sp?) 60 amp alternator in my LongEZ. I want to use the poor-man's Zener diode/fuse combination for my overvoltage protection. Bob Nuckolls has described this installation. All my Zener knowledge somehow blew out the window when I retired and I can't decide which way the Zener should go in branched to ground after the fuse and whether I need to put a resistor in parallel with it. When I measure the resistance of the Zener, of course, one polarity is a low resistance and the other polarity is open circuit. Which end should I connect to the B+ voltage?? This is the only piece of information that is currently keeping me on the ground. I presume you're referring to an alternator with a built in regulator. Adding ov protection to this machine requires more than a simple shutdown of the control line in an ov condition. See figure Z-24 of the power distribution diagrams at http://www.aeroelectric.com/articles/Rev10/z10.pdf The zener/fuse ov protection was indeed certified in some models of Grummans . . . I wouldn't recommend this technique when it's so easy to do much better. See: http://www.aeroelectric.com/articles/crowbar.pdf If you do use a zener, it MUST be a 1 watt glass device (1N4745A) and it MUST be used in conjunction with a real fuse - NOT a circuit breaker. The banded end of the zener is equal to the yellow lead of the crowbar ov module depicted in Figure Z-24 Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 04, 2002
> >Why dpdt? Because you can accomplish the task with one relay instead of >two, which I should think would be both lighter and less expensive. And I >believe there are dpdt relays that use fast-ons. > >My question worded a different way would be "why not a dpdt?" Is there a >DISadvantage to making it simpler, lighter and cheaper?? But does the single relay version put a short across the motor when you release the run command? Does the single relay version isolate what might be a very low power command switch from having to carry motor current? Bob . . . ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: Location of bus and contactor for rear-mounted
batteries. > > >In Figure Z-14, there are 6" or shorter wires > >recommended between the Battery / Battery Contactor / > >Battery Bus. Does this mean that the Battery Bus > >must be a maximum of 12" from the battery? Where > >are most people mounting their Battery & Bus (in an RV). > > >>Battery busses should be right next to the battery as > >>should their respective contactors. This is why those > >>leads are flagged as having the shortest practical > >>length. > >Those of us building the Lancair Super ES are generally stuck with putting >the battery in the back of the plane for weight and balance >reasons. Where do you recommend putting the battery contactor and battery >bus in that situation? What modifications, if any, would you make to Z14? Battery busses and battery contactors mount as close as practical to their respective battery. Not sure what you mean about modifications to Z-14 . . . if you want to do a single battery installation, then perhaps figure Z-12 is appropriate. This is the architecture used in most certified ships that are getting an SD-20 installation. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2002
Subject: Re: Cheap sources for RG batteries?
> >17 AH RGs usually run about $15.00. > > RG batteries do have an excellent shelf life but > it's not infinite. I've seen ads for batteries > "removed from service" that are "tested good". > These are fine for many applications where the > user doesn't really care what the true capacity > of the battery is. The last I saw at that price were new Powersonics. -- John ________________________________________________________________________________
Date: Oct 04, 2002
Hi Bob - Where can I download this as a .DWG file. I'd like to add it to my wirebook for the Lancair ES. Jim Pack wrote: > > > > See: http://216.55.140.222/temp/AP_Disconnect.pdf > > > > > > Bob . . . ________________________________________________________________________________
Date: Oct 04, 2002
Hi Bob - Same with these drawings, could I get them in .DWG files for AutoCad. Many thanks again, John Schroeder > Here is a compendium of pitch trim relay drawings from > various past projects. You can mix/match features shown > in here to get what you need. > > http://216.55.140.222/temp/PitchTrim.pdf > > Any spdt relay good for 1A or more will work in these > circuits. ________________________________________________________________________________
Date: Oct 04, 2002
batteries >Battery busses should be right next to the battery as >should their respective contactors. This is why those >leads are flagged as having the shortest practical >length. > >>Those of us building the Lancair Super ES are generally stuck with >>putting the battery in the back of the plane for weight and balance >>reasons. Where do you recommend putting the battery contactor and >>battery bus in that situation? What modifications, if any, would you >>make to Z14? > Battery busses and battery contactors mount as close as > practical to their respective battery. > Not sure what you mean about modifications to Z-14 . . . if > you want to do a single battery installation, then perhaps > figure Z-12 is appropriate. This is the architecture used > in most certified ships that are getting an SD-20 installation. > Bob . . . I'm actually doing a dual battery with one large and one small battery (Z14 with the S704-1s for small battery contactor and crossfeed). The large battery must go in the back, while the small battery will go up front. Are you suggesting that the battery contactor and bus for the large battery should go in back by the large battery? Following Z14, that would mean running three fat wires from back to front (wires from contactor to crossfeed, and battery to ground) instead of two fat wires if the contactor were in front. It also means running all wires off the large battery bus from back to front. Is that the recommended course? Or should I just run two fat wires from the battery in back to its contactor and ground in the front. Need help here. Thanks. ________________________________________________________________________________
Date: Oct 04, 2002
> > > >17 AH RGs usually run about $15.00. > > > > RG batteries do have an excellent shelf life but > > it's not infinite. I've seen ads for batteries > > "removed from service" that are "tested good". > > These are fine for many applications where the > > user doesn't really care what the true capacity > > of the battery is. > >The last I saw at that price were new Powersonics. That's a bargain. That's basically an out-the-door- of-the-factory price. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2002
> > >Hi Bob - > >Same with these drawings, could I get them in .DWG files for AutoCad. > >Many thanks again, Go get http://216.55.140.222/temp/pitchtrim.zip ________________________________________________________________________________
Date: Oct 05, 2002
From: "Paul A. Franz, P.E." <paul(at)eucleides.com>
At 08:13 PM 10/4/2002Robert L. Nuckolls, III sez: > > > > > > > >17 AH RGs usually run about $15.00. > > > > > > RG batteries do have an excellent shelf life but > > > it's not infinite. I've seen ads for batteries > > > "removed from service" that are "tested good". > > > These are fine for many applications where the > > > user doesn't really care what the true capacity > > > of the battery is. > > > >The last I saw at that price were new Powersonics. > > That's a bargain. That's basically an out-the-door- > of-the-factory price. > > Bob . . . I posted my research on pricing I did a couple months ago. $49.95 includes shipping from Les Schwab. 5 year warranty. Schwab is one of the best if not the best place to get tires, batteries and brakes in the West. So considering Bob's plan of discarding these batteries every two years, you'd get 60% prorated credit on the next battery so that makes these $20 for two years. Provided they aren't still good in two years. I posted this info. Bob added more on other models but my research was done with the specs that Bob published for size, weight and current. Date: Mon, 19 Aug 2002 00:03:32 -0700 From: "Paul A. Franz, P.E." <paul(at)eucleides.com> Subject: Re: AeroElectric-List: Re: Wheelchair Battery ? Status: At 11:51 AM 8/18/2002Robert L. Nuckolls, III sez: > Did a little poking around on the 'net . . . the ES18-12 > didn't sound like a Sonnenschein part number (Bill used to > handle a Sonnenschein Gel-Cell and we had some occasion to > tippy-toe through the Sonnenschein catalogs). The Les Scwab buyer (there's only one) looked this up in his catalog. He faxed me the page of photos for the Sonnenschein Batteries. Each battery in the photos has the name "Powerfit" clearly written in raised letters on the case. Can't see what the small writing says though. I posted this fax <http://www.eucleides.com/fax00005.tif>. You can phone Jamie at Schwab HQ (514)416-5132 and talk to him as I did. He said this was a Sonnenschein battery. > A search > on ES18-12 seems to attribute this part number to a company > called "Global". Here's a website in the UK that illustrates > the ES18-12 as a direct replacement for several other brands: > >http://www.upssystems.uk.com/acatalog/The_UPS_Store_High_Quality_Pattern_Replacements_2.html > > Did a search on Global and ES18-12 and got only 6 hits > NONE of which revealed to me who "Global" is . . . I did some searching too and it looks like Global and Yuasa are synonyms. <http://www.vds.de/en/daten/verzeichnisse/pest/pest1107414c0.htm#7381> They have an ES 18-12. One branded Rocket and the other branded Global. > I suspect this is a re-branded battery. This is not > to suggest that it's a "bad" battery . . . lots > of perfectly reputable folks buy good stuff from other > folks and re-brand it (not the least of which are my > friends up in Newton, KS). Look at this nice book of specs for Powerfit batteries. <http://www.exidenetworkpower.co.uk/mainpages/downloads.html> Looks like it might also be an Exide battery. But I see that the Powerfit ES18-12 photo from the fax I was sent has the Sonnenshein rising sun symbol just as do all other Sonnenshein batteries have in the upper left corner. > So, the battery you have discovered is indeed a member > of a family of batteries of this size and price class > that is equivalent to Sonnenschein F312/15.0GH5; A512/16.0G5 > RS Dryfit 595-081; Powersonic PS12170; Panasonic LCR12V17CP; > LCR1215P(a); Hitachi HP15-12; Global ES18-12; Fulmen 12015; > Fiamm FG21803 and undoubtedly others. Paul Franz PAF Consulting Engineers | 427 - 140th Ave NE (425)641-8202 voice | Bellevue, WA 98005 (425)641-1773 fax | <http://blackdog.bellevue.wa.us/> ________________________________________________________________________________
Date: Oct 05, 2002
batteries > > >Battery busses should be right next to the battery as > >should their respective contactors. This is why those > >leads are flagged as having the shortest practical > >length. > > > >>Those of us building the Lancair Super ES are generally stuck with > >>putting the battery in the back of the plane for weight and balance > >>reasons. Where do you recommend putting the battery contactor and > >>battery bus in that situation? What modifications, if any, would you > >>make to Z14? > > > Battery busses and battery contactors mount as close as > > practical to their respective battery. > > > Not sure what you mean about modifications to Z-14 . . . if > > you want to do a single battery installation, then perhaps > > figure Z-12 is appropriate. This is the architecture used > > in most certified ships that are getting an SD-20 installation. > > > Bob . . . > >I'm actually doing a dual battery with one large and one small battery (Z14 >with the S704-1s for small battery contactor and crossfeed). The large >battery must go in the back, while the small battery will go up front. Are >you suggesting that the battery contactor and bus for the large battery >should go in back by the large battery? Following Z14, that would mean >running three fat wires from back to front (wires from contactor to >crossfeed, and battery to ground) instead of two fat wires if the contactor >were in front. The crossfeed contactor can be anywhere most convenient wiring. This is often on the firewall 'cause both your main bus, aux bus and starter contactors can use handy places to grab a fatwire feed. Battery contactors are next to batteries and battery busses are next to batteries. > It also means running all wires off the large battery bus >from back to front. Yes. How many are there? Battery busses seldom have more than 4-5 feeds and they're small wires. This leaves you two fat wires + feeds going to the back. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Phone Interface
Date: Oct 05, 2002
I have a Motorolla Satellite Phone 9505 that I want to Wire up a Hands free interface to the headset. The phone has a 3 connector plug for a personal hands free. Mike, earphone and a common ground I assume. How easy would it be to wire a plug that would let me plug in the headset. Is there any special thing that I need to do re Impedances? Any other hints Thanks Bob. Ian - Always be connected to your Messenger Friends ________________________________________________________________________________
Date: Oct 05, 2002
Subject: Batter Switch
Goto http://store.summitracing.com and search on SUM-G1432 This switch sells for $20 and is sufficiently rated to serve as a battery disconnect switch in a light aircraft. I've had several builders replace the finger operated lever on similar switches with a belcrank arm. An auto parts choke/throttle control kit was adapted to the bell crank and mounted on the panel to provide a push-pull master battery switch. This is especially suited to airplanes with small or no alternator where you don't want to throw away an amp of keep-closed power and also don't want to buy the much more expensive, low-holding current contactors. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 05, 2002
Yes, the single DPDT relay version will isolate a very low power command switch from having to carry motor current, just like the two SPDT relay version. No, it will not put a short across the motor when you release the switch. I suppose for applications that benefit from this, the two-relay version would be the way to go. But for my RV setup, the only thing that would be sensitive enough to matter would be pitch trim, and I'm using a flap-activated microswitch to source power from a speed reducer to slow down the trim motor considerably when flaps are up....so I really doubt it would make any observable difference in my setup. There are some people using a Radio Shack DPDT relay (#275-218 for $7.99 with socket #275-220 for $2.49) to accomplish flap and trim functions with a single relay for each motor. Contacts rated 15 A @ 125 VAC. Someone put a schematic online and I printed it out but lost the link to it. The main thing I don't like about it is that I don't think this Radio Shack relay uses Fast-on connectors...the base has solder tabs which might accept Fast-ons but it still makes mounting more difficult compared to a relay with a flange that accepts two screws.... Bob do you know if the supplier that you get your SPDT relay from might have a DPDT relay that uses Fast-ons? I'll check my Mouser and Digikey catalogs and let you know if I find something.... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D canopy skirts... _______ From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: DPDT relay? > >Why dpdt? Because you can accomplish the task with one relay instead of >two, which I should think would be both lighter and less expensive. And I >believe there are dpdt relays that use fast-ons. > >My question worded a different way would be "why not a dpdt?" Is there a >DISadvantage to making it simpler, lighter and cheaper?? But does the single relay version put a short across the motor when you release the run command? Does the single relay version isolate what might be a very low power command switch from having to carry motor current? Bob . . . ________________________________________________________________________________
Date: Oct 05, 2002
Subject: Two Speed Trim Servo
Bob, How would I wire a SPST grip mounted [on-on] switch to switch between a fast and a slow elevator trim speed using the Matronics Gov MkIII and the MAC Trim Servo? - Jim ________________________________________________________________________________
Date: Oct 05, 2002
Sorry, there are a couple of optional switches: SPDT [on-on] SPDT [on-off-on] SPDT [(on)-off-(on)] So, restated, how would I wire one of the above switches in the G207 grip to switch between a fast and a slow elevator trim speed using the Matronics Gov MkIII and the MAC Trim Servo? - Jim ________________________________________________________________________________
Subject: Re: Two Speed Trim Servo
Date: Oct 05, 2002
I've got a set-up that uses a pair of radio shack relays and a switch to detect my flap position. It automatically switches to high speed whenever my flaps are off of their "UP" stop. It uses two matronics governors and the mac servo. ----- Original Message ----- From: "Jim Pack" <jpack(at)igs3.com> Subject: AeroElectric-List: Two Speed Trim Servo > > Sorry, there are a couple of optional switches: > > SPDT [on-on] > SPDT [on-off-on] > SPDT [(on)-off-(on)] > > So, restated, how would I wire one of the above switches in the G207 grip to > switch between a fast and a slow elevator trim speed using the Matronics Gov > MkIII and the MAC Trim Servo? > > - Jim > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 05, 2002
How are they wired together? Where do you bypass the Matronics Governors? - Jim ----- Original Message ----- From: "Ralph E. Capen" <recapen(at)earthlink.net> Subject: Re: AeroElectric-List: Two Speed Trim Servo > > I've got a set-up that uses a pair of radio shack relays and a switch to > detect my flap position. It automatically switches to high speed whenever > my flaps are off of their "UP" stop. It uses two matronics governors and > the mac servo. > > ----- Original Message ----- > From: "Jim Pack" <jpack(at)igs3.com> > To: > Subject: AeroElectric-List: Two Speed Trim Servo > > > > > > Sorry, there are a couple of optional switches: > > > > SPDT [on-on] > > SPDT [on-off-on] > > SPDT [(on)-off-(on)] > > > > So, restated, how would I wire one of the above switches in the G207 grip > to > > switch between a fast and a slow elevator trim speed using the Matronics > Gov > > MkIII and the MAC Trim Servo? > > > > - Jim > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 05, 2002
Jim, The flap switch activates the two four pole double throw relays. The 4PDT relays switch between one governor with a "low" speed setting and another governor with a "high" speed setting. This keeps all of the governors' safety features intact while allowing two speeds (discrete - non variable). I have patents currently pending...contact me directly...my intent is not to market or sell - just prevent others from making money from my idea...! Ralph Capen ----- Original Message ----- From: "Jim Pack" <jpack(at)igs3.com> Subject: Re: AeroElectric-List: Two Speed Trim Servo > > How are they wired together? Where do you bypass the Matronics Governors? > > - Jim > ----- Original Message ----- > From: "Ralph E. Capen" <recapen(at)earthlink.net> > To: > Subject: Re: AeroElectric-List: Two Speed Trim Servo > > > > > > > I've got a set-up that uses a pair of radio shack relays and a switch to > > detect my flap position. It automatically switches to high speed whenever > > my flaps are off of their "UP" stop. It uses two matronics governors and > > the mac servo. > > > > ----- Original Message ----- > > From: "Jim Pack" <jpack(at)igs3.com> > > To: > > Subject: AeroElectric-List: Two Speed Trim Servo > > > > > > > > > > Sorry, there are a couple of optional switches: > > > > > > SPDT [on-on] > > > SPDT [on-off-on] > > > SPDT [(on)-off-(on)] > > > > > > So, restated, how would I wire one of the above switches in the G207 > grip > > to > > > switch between a fast and a slow elevator trim speed using the Matronics > > Gov > > > MkIII and the MAC Trim Servo? > > > > > > - Jim > > > > > > > > > > > > > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 05, 2002
> >Bob, > >How would I wire a SPST grip mounted [on-on] switch to switch between a fast >and a slow elevator trim speed using the Matronics Gov MkIII and the MAC >Trim Servo? > >- Jim Why would you want to do this on the stick grip? How about using flap position (flaps not fully up gets you high speed trim)? This is the way we did it on the Lears about 20 years ago. Eliminates one piloting task. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 05, 2002
> > >I've got a set-up that uses a pair of radio shack relays and a switch to >detect my flap position. It automatically switches to high speed whenever >my flaps are off of their "UP" stop. It uses two matronics governors and >the mac servo. Why two governors? Do you need to slow the trim system down from it's full-voltage condition even in the approach phase of flight? Most of the homebuilts I've seen only need to slow it down and control pitch trim in the cruising flight mode. The technique is illustrated on page 2 of http://216.55.140.222/temp/PitchTrim.pdf If you need to regulate both the flaps up and flaps down trim speeds, a second potentiometer on a single voltage regulator will give you this capability without having to add a second controller. Bob . . . ________________________________________________________________________________
Date: Oct 05, 2002
> > >Jim, > >The flap switch activates the two four pole double throw relays. The 4PDT >relays switch between one governor with a "low" speed setting and another >governor with a "high" speed setting. This keeps all of the governors' >safety features intact while allowing two speeds (discrete - non variable). Sounds pretty complicated. Page 2 of http://216.55.140.222/temp/PitchTrim.pdf shows a way to do it with one, single pole, two position switch. >I have patents currently pending...contact me directly...my intent is not to >market or sell - just prevent others from making money from my idea...! Before let a patent attorney soak you for much money, be sure to investigate "prior art" for systems already out there. There's been so much work done in this area that's already in service that you may be at risk of spending a lot of money only to find out that what you have is not patentable. Or your technique varies so slightly from other techniques and control philosophies as to have make the patent very weak. It's been my observation on patents that unless you are trying to protect a rudimentary feature of core physics that makes your product unique, the act of getting a patent is not very useful. The technology rolls along so fast that techniques for doing things become obsolete long before the patent runs out. Finally, holding a patent makes you LIABLE for defending it. Suppose you do have a patent and you perceive that its "protection" has been challenged. You are obligated to mount a defense or risk loosing it. I recall one case where the holder of a violated patent waited until his perceived "damages" mounted to a value that justified paying an attorney to go after the violator. When the judge found out that the plaintiff knew of the violation for several years before filling suit, he booted the case out of court. Patents are good things to have some times but the vast majority of patents issued are so weak -or- imposing upon the holder as to be virtually useless in a rapidly evolving technology. And, as is always the case, only the lawyers on BOTH sides get paid their standard fees whether you win or not. Locks on doors only keep honest people honest. In the case of both locks and patents, dishonorable people are seldom dissuaded by them. The risk is high that a patent may cost you more than you bargained for and in ways you never anticipated. Bob . . . ________________________________________________________________________________
Date: Oct 05, 2002
Bob, I already had the second governor so this was much simpler for me...I built a mount for the relays and the governors and wired them all together...test harness and all. I'm not big on the understanding of voltage regulators and potentiometers (yet) as implemented in a circuit...the intent was to keep the safety features inherent in the governor and allow me to ground select the two speed settings. I do know of a couple of folks that are not using full speed in "flaps-down" mode - just faster speed. Thanks for your input...as always, you show me more things to learn about, and I'm not the only one that is thankfull for that! Ralph Capen <> > >my flaps are off of their "UP" stop. It uses two matronics governors and > >the mac servo. > > > Why two governors? Do you need to slow the trim system down > from it's full-voltage condition even in the approach phase > of flight? ________________________________________________________________________________
Date: Oct 05, 2002
Bob, More thanks... I did all of the paperwork myself so I'm not out any attorneys fees. You're probably correct that it is not really new - or special. I will check out the listing that you pointed me to to see a different way to do it! Ralph ________________________________________________________________________________
Date: Oct 05, 2002
Subject: RE: Phone Interface
> >I have a Motorolla Satellite Phone 9505 that I want to Wire up a Hands >free interface to the headset. > >The phone has a 3 connector plug for a personal hands free. Mike, >earphone and a common ground I assume. > >How easy would it be to wire a plug that would let me plug in the >headset. > >Is there any special thing that I need to do re Impedances? I've not had an occasion to dig into the interface characteristics of cell phones. Given that different brands of phones seem to require different earphone/mic accessories implies that they can be different from brand to brand. What you need to do is a bench measurement of the voltages and impedances of the circuits while a "qualified" accessory is plugged into the telephone and then strive to duplicate those characteristics in a new system. Bob . . . ________________________________________________________________________________
Date: Oct 05, 2002
Subject: DIY two speed trim system
I've modified one of the previously published pitch trim drawings to include a two speed system based on flap position. I believe this system has all the operational features of the Matronics trim controller system with the addition of two, independently set trim speeds and connections for a switch on the flap linkage. See: http://216.55.140.222/temp/trim6.pdf The latest dimmer boards from B&C have provisions for assembling this trim controller module. I haven't fed them the assembly data yet but I suspect the costs will be the same as for a DIM5-14 dimming controller. Parts values are given in the drawing so one could do the whole thing in house if you wish. The relays are not critical. The MAC servos only draw about 100 mA. Any 12v relay you want to use would be fine. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 05, 2002
Subject: Re: DIY two speed trim system
What specific switch would you suggest for the "depressed when flaps full up" switch? Has anyone rigged this type of setup & has pictures of the physical installation? - Jim ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: DIY two speed trim system > > I've modified one of the previously published pitch trim > drawings to include a two speed system based on flap > position. > > I believe this system has all the operational features > of the Matronics trim controller system with the addition of > two, independently set trim speeds and connections for > a switch on the flap linkage. > > See: http://216.55.140.222/temp/trim6.pdf > > The latest dimmer boards from B&C have provisions for > assembling this trim controller module. I haven't fed them > the assembly data yet but I suspect the costs will be > the same as for a DIM5-14 dimming controller. > > Parts values are given in the drawing so one could do > the whole thing in house if you wish. The relays are > not critical. The MAC servos only draw about 100 mA. > Any 12v relay you want to use would be fine. > > Bob . . . > > |-------------------------------------------------------| > | My interest is in the future, because I'm going to | > | spend the rest of my life there. -C.F. Kettering- | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Re: Promotion of Bobs CD
Date: Oct 05, 2002
Bob, Thoroughly enjoyed your program at the Tandem Wing Fly-In at Coffey County Airport, but I have one correction. The Jabiru was mounted on Wayne Ulvestad's Dragonfly (not a Quickie). Wayne earned the "Best Overall Dragonfly" award at the fly-in. He has one beautiful plane. Jeff ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Promotion of Bobs CD > > > > >I have to add a general promotion too. I just finished all of my wiring and > >I can't thank Bob enough. Everything was pretty straightforward after > >reading his book, making the drawings from his CAD files and ordering all > >the right stuff from his website. It came out great and everytime I > >stripped, crimped and plugged another wire onto either the ground block or > >fuse blocks I was thinking of how much I owe Bob if I ever see him around. > >What a great system. Love that master toggle too. > > > >You are providing an incredible service to homebuilders Bob, thanks a > >million! (That's about how many hours it would have taken if I tried it > >without your help.) > > I'm very pleased that you find this activity useful. > > Spent yesterday at the tandem wing fly-in on the Burlington > KS airport. These guys have no factory support. I've never met > a more inquisitive and ambitious bunch of builders. They're > looking at all kinds of engine options, electrical system > options and whatever they decide to do, there are few if > any suppliers of bolt-on-and-fly hardware. > > Got to look over a Jabiru engine installed in a Quickie. > The American aircraft engine manufacturer's ought to keep > scale models of this engine on everybody's desk to remind > them what an aircraft engine CAN be . . . > > See http://www.jabiru.co.za/engines_pictures.htm > > http://www.zenithair.com/zodiac/xl/3300.html > > The installation was so much smaller and lighter than > contemporary engines in the Quickies that the installer > had to move a shorter engine forward under a new cowl > to get the CG back in the right place. The end result > being enough engine to firewall clearance to make this > space attractive as a forward baggage compartment. > > No castings. EVERYTHING appears to be NC machined > from solid hunks of metal. Not only a work of art > but a stout and practical alternative to the 1940's > technology that heads up the vast majority of US > certified aircraft. > > Yet another example of what can happen when you > figure out a way to do it without government's > assistance and oversight. > > Bob . . . > > > >Gary K. > >Pelican PL w/Stratus Subaru > >Newport, R.I. > > > > > > Bob . . . > > |-------------------------------------------------------| > | There is a great difference between knowing and | > | understanding: you can know a lot about something and | > | not really understand it. -C.F. Kettering- | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 06, 2002
Oops...I take back my first statement....the single DPDT relay will NOT isolate the command switch from carrying motor current. The schematic I have doesn't clearly show the internal workings of the relay, so I looked up the relay schematic on Radio Shack's website and sure enough, the circuit works such that the command switch provides the motor power ground. With my Infinity stick grip the switches are rated at 8 amps so I think this would still work ok for flaps and trim, but if someone is using a switch rated at only one or two amps the DPDT solution would not work... On a seperate note, I looked through the relays in my Mouser catalog and there are several flange-mount, DPDT relays that use Fast-Ons. They are available with 15-30 Amp ratings and are in the $9-10 range. I also noticed there were several SPDT relays that use Fast-Ons and they were all between $3 and $4 apiece. Perhaps they are inferior quality to the ones Bob sells for $10?? Anyway since they cost less than half what the DPDT relays cost, I may just go ahead and order eight of them (two each for flaps, pitch trim, roll trim, and taxi/landing lights). It will probably add a few ounces, but will save me a few bucks and give me the benefits of motor braking and less stress on the command switch....for what little those features may be worth in my set-up... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D canopy skirts.... Yes, the single DPDT relay version will isolate a very low power command switch from having to carry motor current, just like the two SPDT relay version. No, it will not put a short across the motor when you release the switch. I suppose for applications that benefit from this, the two-relay version would be the way to go. But for my RV setup, the only thing that would be sensitive enough to matter would be pitch trim, and I'm using a flap-activated microswitch to source power from a speed reducer to slow down the trim motor considerably when flaps are up....so I really doubt it would make any observable difference in my setup. There are some people using a Radio Shack DPDT relay (#275-218 for $7.99 with socket #275-220 for $2.49) to accomplish flap and trim functions with a single relay for each motor. Contacts rated 15 A @ 125 VAC. Someone put a schematic online and I printed it out but lost the link to it. The main thing I don't like about it is that I don't think this Radio Shack relay uses Fast-on connectors...the base has solder tabs which might accept Fast-ons but it still makes mounting more difficult compared to a relay with a flange that accepts two screws.... Bob do you know if the supplier that you get your SPDT relay from might have a DPDT relay that uses Fast-ons? I'll check my Mouser and Digikey catalogs and let you know if I find something.... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D canopy skirts... _______ From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: DPDT relay? > >Why dpdt? Because you can accomplish the task with one relay instead of >two, which I should think would be both lighter and less expensive. And I >believe there are dpdt relays that use fast-ons. > >My question worded a different way would be "why not a dpdt?" Is there a >DISadvantage to making it simpler, lighter and cheaper?? But does the single relay version put a short across the motor when you release the run command? Does the single relay version isolate what might be a very low power command switch from having to carry motor current? Bob . . . ________________________________________________________________________________
Subject: trim speed control
Date: Oct 06, 2002
<detect my flap position. It automatically switches to high speed whenever >my flaps are off of their "UP" stop. It uses two matronics governors and >the mac servo.>> I assume these "governors" provide a constant voltage output, but what about a simple series resistor? I realize it won't regulate the trim speed to as constant a value as a voltage control, but it is very simple. A flap-actuated switch could then just bypass the resistor. Another thing that I have seen used is a time delay that runs the trim slow for maybe a second and then goes into high speed. What's the consensus on something like that? Gary Casey ES project ________________________________________________________________________________
Subject: XM radio
Date: Oct 06, 2002
Has anyone looked into the use of an XM radio receiver for cruising tunes? Was wondering what the receiver frequency band would be & if a GPS antenna could be split to feed the input? Dave Ford ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: trim speed control
> >< >detect my flap position. It automatically switches to high speed whenever > >my flaps are off of their "UP" stop. It uses two matronics governors and > >the mac servo.>> > >I assume these "governors" provide a constant voltage output, but what about >a simple series resistor? I realize it won't regulate the trim speed to as >constant a value as a voltage control, but it is very simple. A >flap-actuated switch could then just bypass the resistor. Another thing >that I have seen used is a time delay that runs the trim slow for maybe a >second and then goes into high speed. What's the consensus on something >like that? It's been done and some people have found it satisfactory. Given the very low mechanical efficiency of the MAC servos, their current draw is relatively constant over a range of loads. Active voltage control just increases the stability of the system for changes both in aerodynamic loads and bus voltages. To meet FAA requirements on larger airplanes, it was necessary to use tach feedback on the motors and actually servo the motor's speed. The trim speed controller using a modified dimmer is about half way between a speed feedback servo and the simple resistor. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Wire identification
Can someone point me to a reference that deciphers the mil spec labeling on wire? I would like to look up gauge and insulation type from the numbering for a given wire number. Thanks, Gary Liming ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: Wire identification
> > >Can someone point me to a reference that deciphers the mil spec labeling on >wire? I would like to look up gauge and insulation type from the numbering >for a given wire number. See if you can find what you need at: http://stinet.dtic.mil/str/dodiss4_fields.html Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: XM radio
> >Has anyone looked into the use of an XM radio receiver for cruising >tunes? Was wondering what the receiver frequency band would be & if a GPS >antenna could be split to feed the input? I'm using one in my car, it's set up for rack-out rack-in to the airplane GPS antennas are not suitable, but the dedicated XM antennas aren't expensive Look at EBAY to buy the XM unit. They're cheaper there than anywhere else. There are two basic schemes for XM output. One goes into your intercom. The other goes into the antenna of an FM radio. Be sure you know which one you're getting. We used it on our honeymoon, driving around northern California. I only cut out when we were in tunnels. It should be great in the air. ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: single DPDT relay?
> >Oops...I take back my first statement....the single DPDT relay will NOT >isolate the command switch from carrying motor current. The schematic I >have doesn't clearly show the internal workings of the relay, so I looked >up the relay schematic on Radio Shack's website and sure enough, the >circuit works such that the command switch provides the motor power >ground. With my Infinity stick grip the switches are rated at 8 amps so >I think this would still work ok for flaps and trim, but if someone is >using a switch rated at only one or two amps the DPDT solution would not >work... Okay. You had me going there. I've been suffering a slight case of brain-strain trying to figure out how to do it with one DPDT and not run power through the control switch as well. There's yet another variation on the theme wherein one doesn't want to use the itty-bitty stick-grip switches and opts for panel mounted toggle switches. Here's a case where the progressive transfer type switch with momentary action both sides of center [DPDT (on)-on-(on)] works well. See http://216.55.140.222/temp/flaps2.pdf Obviously, these configurations work equally well with any PM motor positioning system be it flaps, trim, cowl flaps, canopy, etc. >On a seperate note, I looked through the relays in my Mouser catalog and >there are several flange-mount, DPDT relays that use Fast-Ons. They are >available with 15-30 Amp ratings and are in the $9-10 range. I also >noticed there were several SPDT relays that use Fast-Ons and they were >all between $3 and $4 apiece. Perhaps they are inferior quality to the >ones Bob sells for $10?? Anyway since they cost less than half what the >DPDT relays cost, I may just go ahead and order eight of them (two each >for flaps, pitch trim, roll trim, and taxi/landing lights). It will >probably add a few ounces, but will save me a few bucks and give me the >benefits of motor braking and less stress on the command switch....for >what little those features may be worth in my set-up... Those will probably work for you just fine. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2002
> >What specific switch would you suggest for the "depressed when flaps full >up" switch? See: http://216.55.140.222/temp/BasicSwitches.jpg and http://info.digikey.com/T023/V5/0770-0771.pdf >Has anyone rigged this type of setup & has pictures of the physical >installation? If anyone DOES have a working instllation and can share pictures I can post, I'd like to hear from them . . . Bob . . . ________________________________________________________________________________
Date: Oct 06, 2002
Subject: We nearly got hosed . . .
Catching up on a pile of unread mail this afternoon and ran across this tidbit in AOPA Pilot. You can see an online equivalent of the piece at http://www.aopa.org/whatsnew/newsitems/2002/02-3-041x.html?PF Seems the FAA came very close to banning all "non-certified" EFB "electronic flight bag" devices from the cockpit unless sprinkled with appropriate holy water. See the advisory circular below which outlines in detail, the interests assigned to a plethora of organizations within the FAA. http://www.aopa.org/whatsnew/newsitems/2002/ac120-76.doc Had the "benefits" of government interest defined in the above document been realized for our class of cockpit, most current suppliers of useful equipment would throw in the towel. The ones that stayed the course would have to multiply their prices 3x to 10x. Advancement of their products and ability to try new things would no longer be driven by new technologies but by the designers ability to get government "permission" . . . Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: We nearly got hosed . . .
In a message dated 10/6/02 4:46:03 PM Central Daylight Time, bob.nuckolls(at)cox.net writes: > The ones that stayed the course would have to > multiply their prices 3x to 10x. Advancement of their > products and ability to try new things would no longer be > driven by new technologies but by the designers ability > to get government "permission" . . . > Good Evening Bob, I know this is a bit off topic, but I couldn't agree more. May I add that standardization will always stifle innovation? I know our industry constantly cries out for more and more standardization. People want all GPSs to operate the same. Nobody wants to be required to learn anything different when jumping from airplane to airplane, but if we allow the government to set standards as to how things are to be done, nobody will ever be able to make any improvements. The whole beauty of our entire system is that we are free. Free to try and free to fail. Let the market set the standards. People will build what people will buy. Sorry for the soap box oratory. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Seawind
I'm in the process of building a Seawind. For those who don't know, it's a seaplane. I've been monitoring this site for a while now and find it very interesting and informative. I need some help in determining how to setup my electrical system. Thesystem will be all electric using two B & C alternators and regulators. It will also have two batteries. The plane will also be full IFR with auto pilot. What opinions do you all have on what should be on the essential buss and the main buss. Thank you Tom Saccio ________________________________________________________________________________
Subject: XM radio
Date: Oct 06, 2002
Both serius and xm radio use terk brand antennas. They have two leads feeding the receiver; one is satellite and the other terrestrial. They use ground transmitters for areas such as large cities where line of site (to the satellite) is hard to maintain. They are relatively cheap, 79$ with a 30$ rebate. (www.terk.com) Steve capsteve(at)adelphia.net N221RV RV-6A Subject: AeroElectric-List: XM radio Has anyone looked into the use of an XM radio receiver for cruising tunes? Was wondering what the receiver frequency band would be & if a GPS antenna could be split to feed the input? Dave Ford ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Two-color LED and the LR-3?
Bob, I'm wiring my airplane, mostly taking your advice and thank you very much by the way... But I'm wondering if it's possible for the voltage light on the LR-3 controller to instead run to a two-color LED? Ideally, I'd like it to light up green when the alternator is doing its thing, and red when it isn't. ________________________________________________________________________________
Date: Oct 06, 2002
Subject: Re: Two-color LED and the LR-3?
> > > Bob, > > I'm wiring my airplane, mostly taking your advice and thank you very >much by the way... > But I'm wondering if it's possible for the voltage light on the LR-3 > controller to instead run to a two-color LED? Ideally, I'd like it to >light up green when the alternator is doing its thing, and red when it >isn't. A bit tough. The circuit flashes too. With a red/green led, you would get an alternating red/green during a low voltage condition . . . and I'm not sure we could get things to bias up properly to make sure that the red light would be illuminated during a power-down of the LR-3. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2002
I spoke with the XM folks a while back and they said there was no buffering of the signal so I could expect to have the music drop out when rolling the airplane (or flying under bridges!). Too bad. Russ ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Date: Oct 07, 2002
The Wright brothers patented their Flyer, and then spent the rest of their productive lives and every penny they could scrape up 'trying' to protect their patents, in court... They did not make even one further advance in aeronautics after getting their patents... Curtiss replaced the wing warping with ailerons, and changed from a canard planform to a conventional planform and simply powered around them,... The other airplane manufacturers ignored the Wrights patents and began producing airplanes, and the world went on... Bob's advice is right on the mark... I will add to that advice, if you have something useful, forget the patents, publish it with your name attached and insist that anyone using it or manufacturing it for sale use your name in the future... Fame will be a far greater reward than making ATLA affluent.. Denny ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Two Speed Trim Servo > > > > > > >Jim, > > > >I have patents currently pending...contact me directly...my intent is not to > >market or sell - just prevent others from making money from my idea...! > > Before let a patent attorney soak you for much money, > be sure to investigate "prior art" for systems already > out there. There's been so much work done in this ________________________________________________________________________________
Date: Oct 07, 2002
Subject: Re: Seawind
> >I'm in the process of building a Seawind. For those who don't know, it's a >seaplane. I've been monitoring this site for a while now and find it very >interesting and informative. I need some help in determining how to setup my >electrical system. Thesystem will be all electric using two B & C alternators >and regulators. It will also have two batteries. The plane will also be full >IFR with auto pilot. What opinions do you all have on what should be on the >essential buss and the main buss. Tom, it would be easier to evaluate you're project if you listed all the things you plan to put in your airplane and how, based on your present understanding, which bus you would use to power them up . . . Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 07, 2002
From: "William Yamokoski" <yamokosk(at)lmc.cc.mi.us>
Hi Bob, You mean to tell me that the book not only tells me how to set up my electrical system, it also helps me diagnose my screw-ups??? Such a deal! The DAR is coming on Sunday so I won't be digging into it just yet, but thanlks very much for pointing me in the right direction. I know there has been a thread on promoting your products and I stand fully behind that concept. Everyone who asks about my electrical system hears your name and is told to get the durned book. Next step for me is to read it :) Thanks. Bill Yamokoski, watching the ammeter swing from 12:00 to 6:00 when the radio mike is keyed. ________________________________________________________________________________
Subject: Insulating washers
Date: Oct 07, 2002
Hi Bob, What is the requirement for insulating washers on the Mic and HS jacks? The Val Com doesn't show any requirement but would it help or not? Best regards, Bruce Bell Lubbock, Texas RV4 # 2888 ________________________________________________________________________________
Date: Oct 07, 2002
Subject: Terminal Boots?
What is the convention / need for terminal boots on the fat wires we have firewall forward? I see these nifty little rubber boots to put over the connections, however in my case (wiring per Z11) I have 2 or 3 connections on the posts of the master contactor & starter contactor so it's not clear to me how I would use one of those rubber terminal boots. Is this something I need, or if everything is tied up and clear of the connection points can they be left open? - Andy Karmy RV9A - Seattle WA Finished my AWG2 leads (just like the comic books show)... ________________________________________________________________________________
Date: Oct 07, 2002
> What is the convention / need for terminal boots on the fat wires > we have firewall forward? Even I know this one. They're used to hide the mess we made of the insulation while soldering with a blow torch! John Slade Cozy IV ________________________________________________________________________________
Date: Oct 07, 2002
> > > > > > > >Can someone point me to a reference that deciphers the mil spec labeling on > >wire? I would like to look up gauge and insulation type from the numbering > >for a given wire number. > > > See if you can find what you need at: > > http://stinet.dtic.mil/str/dodiss4_fields.html I didn't have any luck finding a hit on either a wire number or documents that had wire numbers in them. There were a couple of hits on documents that looked close, but the document wasn't included in the description. Am I missing something? Thanks, Gary Liming ________________________________________________________________________________
Date: Oct 07, 2002
Don't know whether they support sat phones but for a cellphone connection to your headeset/intercom check out http://www.cellset.com/Aviationitems.html Dave -----Original Message----- From: Ian Scott [mailto:jabiru22(at)yahoo.com.au] Subject: RE: AeroElectric-List: Phone Interface I have a Motorolla Satellite Phone 9505 that I want to Wire up a Hands free interface to the headset. The phone has a 3 connector plug for a personal hands free. Mike, earphone and a common ground I assume. How easy would it be to wire a plug that would let me plug in the headset. Is there any special thing that I need to do re Impedances? Any other hints Thanks Bob. Ian ________________________________________________________________________________
Date: Oct 07, 2002
> > >Can someone point me to a reference that deciphers the mil spec > labeling on > > >wire? I would like to look up gauge and insulation type from the > numbering > > >for a given wire number. > > > > > > See if you can find what you need at: > > > > http://stinet.dtic.mil/str/dodiss4_fields.html > >I didn't have any luck finding a hit on either a wire number or documents >that had wire numbers in them. There were a couple of hits on documents >that looked close, but the document wasn't included in the >description. Am I missing something? What numbers are you looking for? Bob . . . ________________________________________________________________________________
Date: Oct 07, 2002
Subject: Re: Insulating washers
> >Hi Bob, >What is the requirement for insulating washers on the Mic and HS jacks? The >Val Com doesn't show any requirement but would it help or not? >Best regards, >Bruce Bell >Lubbock, Texas >RV4 # 2888 Quoting from Chapter 16 . . . "Microphone and headset jacks are common victims of ground loops. A very few millivolts of noise can be easily detected either in the headphones or impressed upon your outgoing signal while speaking on the radio. In metal airplanes, use insulating washers to prevent the mounting bushings of headset and microphone jacks from making contact with the airframe. All audio system grounds should terminate at the audio system's distribu- tion amplifier . . . usually the intercom system. Then, a single ground wire from the audio system should join all other avionics grounds at the panel equipment ground block." See also description for the insulating washers at http://www.aeroelectric.com/Catalog/wiring/wiring.html#s890-1 Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 07, 2002
Subject: RE: Terminal Boots?
> > > What is the convention / need for terminal boots on the fat wires > > we have firewall forward? >Even I know this one. They're used to hide the mess we made of the >insulation while soldering with a blow torch! >John Slade >Cozy IV Gee John, turn down the heat a little. I use the smallest stable flame I can get from the standard hardware store variety torch and apply heat only to the terminal . . . it's possible to get the joint to flow with nary a hint of scorch on the insulation. If you do get some discoloration and/or pull-back, some double wall heat shrink like we use on our battery jumpers is more secure than booties. See. . . http://www.aeroelectric.com/Catalog/wiring/sbl.jpg Booties are primarily intended as shields over otherwise exposed electrical terminals to prevent inadvertent contact and possible shorts. We use them all over the spam cans. See . . . http://www.aeroelectric.com/Catalog/wiring/25171-2S.jpg You can help them stay in place by putting a tye-wrap or string tie around the barrel of the boot. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2002
Subject: Re: Terminal Boots?
> >What is the convention / need for terminal boots on the fat wires we have >firewall forward? > >I see these nifty little rubber boots to put over the connections, however >in my case (wiring per Z11) I have 2 or 3 connections on the posts of the >master contactor & starter contactor so it's not clear to me how I would >use one of those rubber terminal boots. > >Is this something I need, or if everything is tied up and clear of the >connection points can they be left open? Tens of thousands of airplanes are flying sans booties yet electrical problems for lack of boots isn't very high on the list of probable causes. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2002
> > A bit tough. The circuit flashes too. With a red/green > led, you would get an alternating red/green during a > low voltage condition . . . and I'm not sure we could get > things to bias up properly to make sure that the red light > would be illuminated during a power-down of the LR-3. > > Bob . . . > Hmm. Well, a flashing warning light, even if it's red/green, isn't so bad. Provided it'll light up green when everything is good. Odd behavior at shutdown I'm not too concerned about. ________________________________________________________________________________
Date: Oct 07, 2002
> >I spoke with the XM folks a while back and they said there was no buffering >of the signal so I could expect to have the music drop out when rolling the >airplane (or flying under bridges!). Too bad. Weird. There is buffering, about 5 seconds worth. It won't cut out under bridges, but will in tunnels. I think the only way you'll get it to cut out in an airplane is flying inverted. :) ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: RE: Terminal Boots?
> > Booties are primarily intended as shields over otherwise > exposed electrical terminals to prevent inadvertent > contact and possible shorts. We use them all over the > spam cans. See . . . > > http://www.aeroelectric.com/Catalog/wiring/25171-2S.jpg So, this is my primary question... What is a person to do if you have 2 or 3 lugs under those connections? How can the boots be attached in that configuration? - Andy ________________________________________________________________________________
Date: Oct 08, 2002
They can't... Suggest a simple rubber flap screwed to the firewall and hanging over the lug to prevent accidental contact with a wrench, etc... Denny ----- Original Message ----- From: "Andy Karmy" <andy(at)karmy.com> Subject: Re: AeroElectric-List: RE: Terminal Boots? > > > > > Booties are primarily intended as shields over otherwise > > exposed electrical terminals to prevent inadvertent > > contact and possible shorts. We use them all over the > > spam cans. See . . . > > > > http://www.aeroelectric.com/Catalog/wiring/25171-2S.jpg > > So, this is my primary question... What is a person to do if you have 2 or 3 lugs under those connections? How can the boots be attached in that configuration? > > - Andy > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 08, 2002
In a message dated 10/8/02 12:58:03 AM Central Daylight Time, andy(at)karmy.com writes: > So, this is my primary question... What is a person to do if you have 2 or 3 > lugs under those connections? How can the boots be attached in that > configuration? > > - Andy > Good Morning Andy, I like to use the booties, don't know that they are really needed most of the time though. In the case which you mention, I just run the two, three or four wires through the Bootie before putting it all together. So far, that has worked well for me, but it does sometimes take creative thought to get the lugs to lay close enough for everything to fit together and look nice. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Alternator Blast tube
Hi all Have the Van's alternator with the external regulator. It doesn,t have a fan so am wondering where the cooling air from the blast tube should be directed. Front or back of the unit. Also is there a particular location on the magneto that should be the focus of the blast tube. Bill Rounds RV-9A Finishing the baffle ________________________________________________________________________________
Date: Oct 08, 2002
> > > > > > Booties are primarily intended as shields over otherwise > > exposed electrical terminals to prevent inadvertent > > contact and possible shorts. We use them all over the > > spam cans. See . . . > > > > http://www.aeroelectric.com/Catalog/wiring/25171-2S.jpg > >So, this is my primary question... What is a person to do if you have 2 or >3 lugs under those connections? How can the boots be attached in that >configuration? Generally can't. At least for multiple fat wires. You can sometimes get one fat wire and a couple of skinny ones to share the same boot but it can get crowded under the end-cap. Lots of situations in certified and OBAM ships call for multiple wires to a large threaded post. These are generally left open. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2002
> > > > > > A bit tough. The circuit flashes too. With a red/green > > led, you would get an alternating red/green during a > > low voltage condition . . . and I'm not sure we could get > > things to bias up properly to make sure that the red light > > would be illuminated during a power-down of the LR-3. > > > > Bob . . . > > > > > Hmm. Well, a flashing warning light, even if it's red/green, isn't >so bad. Provided it'll light up green when everything is good. > Odd behavior at shutdown I'm not too concerned about. See http://www.aeroelectric.com/temp/Bicolor_LED.pdf ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: Alternator Blast tube
> >Hi all > >Have the Van's alternator with the external regulator. It doesn,t have >a fan so am wondering where the cooling air from the blast tube should >be directed. Front or back of the unit. Also is there a particular >location on the magneto that should be the focus of the blast tube. Have there been temperature studies done to show that blast cooling for these items is necessary? I don't recall having seen any cooling on mags for an RV and although some folks have cooled the alternator, I don't recall anyone taking any real data that shows it's needed. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2002
Subject: relay ratings
If a double pole relay is rated at 30 amps, is this 30 amps per contact? I've looked at the spec sheets for several relays like this and it appears to mean 30 A per contact (for a total relay current capacity of 60 A) but it's not absolutely clear... I'm planning on controlling two 100 W lights on my RV-8A from my Infinity stick grip. I was looking at using two independent relays to accomplish this, but most single pole relays are rated at 15 A, and if I recall correctly it's good to use switches with a 20 A rating to handle the inrush current of the lights. Does this rule of thumb apply to relays too, or only toggle switches? Would it be better to use a DPDT relay rated 30 A, assuming that this is 30 A per contact, instead of two SPDT relays rated 15 A? (Yes I know this means both lights are on or off at the same time, and this is ok with me...). Thanks for the endless wisdom... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing but never finished... ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Dimming question, again...
Guys, I never really received a direct answer addressing my proposed use of a zener diode for my bright/dim switch question a few days ago, so here goes one more time: I have 3 LED indicators that I want to be ON when power is applied to some piece of equipment. I want to use a toggle switch to provide a bright/dim function for these LED's. My proposal to keep things simple is to run the ground for the LED's through the bright/dim switch. When in the Bright position, the switch will tie straight to ground. When in Dim position, the switch will go to ground via a zener diode of TBD voltage. The theory is that since the zener has a constant voltage across it with varying current, it will provide consistent dimming values to all three LED's regardless of whether one, two or all three are ON. Does this make sense, or is there a simpler, better, cheaper way to accomplish this? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: Dimming question, again...
In a message dated 10/8/02 1:18:59 PM Central Daylight Time, czechsix(at)juno.com writes: > When in the Bright position, the switch will tie straight to ground. When > in Dim position, the switch will go to ground via a zener diode of TBD > voltage. The theory is that since the zener has a constant voltage across > it with varying current, it will provide consistent dimming values to all > three LED's regardless of whether one, two or all three are ON. > Good Afternoon Mark, I am no expert and can't give advice as to what is best, but I did use a Zener to accomplish the dimming function on the four lights that were required for annunciation on my IFR GPS installation. The panel mount GPS unit supplies the ground for the various lights that are required. When they need to be on, they are grounded through that set. I put a Zener diode of an appropriate voltage in the power feed with a SPST switch to short out the Zener when I want them bright. Been working like a charm for the last eleven years! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 08, 2002
Bob, I made a list and tried to break it down as to what goes where. Here it is: Main Bus: Taxi lights, Strobe, Landing lights, Position lights, Panel lights, Over head lights Auto pilot, Vor, HSI Fuel boast pump, Right & Left fuel transfer pump, Bilge pump Pitot heat, Cooling fan, Stall warning, Flaps, Hobbs meter Electric trim for Ailerons, Rudder and Stablizer Landing gear, Hydraulic pressure gauge Essential Bus: Altimiter, Rate of climb, Air speed indicator, AI, Turn and slip indicator Directional gyro, GPS( full IFR UPS stack), Nav-Com, Transponder, Audio panel Goose neck light, Amp and Volt meter, Annunciator light, Clock and Timer Primary fuel pump, Quad fuel gauges Turn cordinator I will also have an EM 1000 to monitor the engine. I know that this is not complete but I hope that it is enough to get me started in the right direction. Thanks Bob. Tom ________________________________________________________________________________
Date: Oct 08, 2002
From: Phil Hildebrand <phildebrand(at)pritchardindustrial.com>
Subject: Annunciator
Does anyone know where I could source a good looking annunciator for my panel. Something with about 5 lights and a dim switch, etc. Philip Hildebrand, Lancair Super ES, Canada Email: phildebrand(at)pritchardindustrial.com ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: Annunciator
Why don't you roll your own? You can have a sign manufacture engrave the plastic subpanel, light it up with a fiberoptic ribbon, and connect it to a small relay board. If this sounds intersting, let me know, I can provide the source for all of the aformentioned items. Just did this on a Velocity XL Peter ----- Original Message ----- From: "Phil Hildebrand" <phildebrand(at)pritchardindustrial.com> Subject: AeroElectric-List: Annunciator > > Does anyone know where I could source a good looking > annunciator for my panel. Something with about 5 lights and a dim > switch, etc. > > > Philip Hildebrand, Lancair Super ES, Canada > Email: phildebrand(at)pritchardindustrial.com > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 08, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
czechsix(at)juno.com wrote: > > > Guys, I never really received a direct answer addressing my proposed use of a zener diode for my bright/dim switch question a few days ago, so here goes one more time: > > I have 3 LED indicators that I want to be ON when power is applied to some piece of equipment. I want to use a toggle switch to provide a bright/dim function for these LED's. My proposal to keep things simple is to run the ground for the LED's through the bright/dim switch. When in the Bright position, the switch will tie straight to ground. When in Dim position, the switch will go to ground via a zener diode of TBD voltage. The theory is that since the zener has a constant voltage across it with varying current, it will provide consistent dimming values to all three LED's regardless of whether one, two or all three are ON. > > Does this make sense, or is there a simpler, better, cheaper way to accomplish this? > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing... > Mark, With incandescent lamps, your idea will work fine, but LED's don't respond well to varying the voltage. Most variable intensity LED's happen by using pulsed DC & varying the pulse width (duty cycle) of the pulsed voltage. The perceived brightness changes with the 'on-time' of the LED. Unfortunately, it's a lot more complicated than adding a zener diode. Charlie ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: Annuciator
>> Does anyone know where I could source a good looking >> annunciator for my panel. Something with about 5 lights and a dim >> switch, etc. >Why don't you roll your own? >You can have a sign manufacture engrave the plastic subpanel, light it up >with a fiberoptic ribbon, and connect it to a small relay board. > >If this sounds intersting, let me know, I can provide the source for all >of the aformentioned items. Just did this on a Velocity XL > >Peter Peter, Phillip I am also building a Lancair ES and looking for a small, "annunciator solution." I am building my own panel. Roll your own sounds great, if I can get a little guidance. I'll have two B&C regulators that have annunciator lights that come with the units (which I may convert to LEDs), and thought that I might add some lights on the panel near the regulator lights. I was thinking about simply putting in a couple of lights to indicate when the boost pump and cross feed are on and let it go at that. The two extra lights would be simple indicators of whether a switch is on or off. But I was thinking it might also be nice to annunciate low fuel pressure in the field of view along with these other lights. But being a rookie at this stuff, I don't really have a clue how to do that. (It was a leap for me to figure out how to wire a light simply to indicate when a switch is on!) I would appreciate any thoughts you have. There are some good solutions out there (e.g., Proprietary Software), but as my panel grows, my budget shrinks. Besides, a custom annunciator sounds more fun. Dan O'Brien Lancair Super ES ________________________________________________________________________________
From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net>
Subject: Insulating Wahsers for Music Jacks
Date: Oct 08, 2002
Bob or anyone, please: Do you know where to get 1/4 inch hole insulating washers for a music jack? Gabe A Ferrer (RV6, N2GX reserved, SE Florida) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Date: Oct 08, 2002
Subject: Re: Insulating Wahsers for Music Jacks
> > >Bob or anyone, please: > >Do you know where to get 1/4 inch hole insulating washers for a music jack? How many do you need. Allied Electronics catalogs packages of 100 for about $4.00 per pkg. It's a Keystone Electronics p/n 4711. The matching flat washer is p/n 3178 also from keystone. Allied doesn't catalog this one. If you just need a few, try http://www.keyelco.com They might sample you a few. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Gabe and Marisol Ferrer wrote: > Bob or anyone, please: > > Do you know where to get 1/4 inch hole insulating washers for a music jack? > > Gabe A Ferrer (RV6, N2GX reserved, SE Florida) You might try Newark electronics part #50N867 at this site. http://www.newark.com/search/searchPage.jsp?focus=0 -- Bob McC ________________________________________________________________________________
Date: Oct 08, 2002
Mark, That arrangement should work fine, just make sure your Zener is rated high enough current to light (dimmly) all three LEDs. This shouldn't be a problem, since you will likely only need a few milliamps each. Since the LED is really a diode, the voltage drop across it will be constant ( about 0.8V if I remember right), regardless of the current. Of course the current will determine the intensity of the LEDs. Each LED will need a series resistor of a value determined by the current rating of the LED and the highest system voltage you expect to see. With an LED rated at 20 mA full bright, say (14V - 0.8V)/20mA 660 Ohms or, erring on the high side, around 720 ohms or so. Now if you need 5 mA for the dim current, your 720 ohm will drop (720 *.005) 3.6V. Thus 14V - 0.8V - 3.6V 9.6V zener would give you the current you want (assuming the led currents above are correct - but they're probably not!). Todd -----Original Message----- From: czechsix(at)juno.com Subject: AeroElectric-List: Dimming question, again... Guys, I never really received a direct answer addressing my proposed use of a zener diode for my bright/dim switch question a few days ago, so here goes one more time: I have 3 LED indicators that I want to be ON when power is applied to some piece of equipment. I want to use a toggle switch to provide a bright/dim function for these LED's. My proposal to keep things simple is to run the ground for the LED's through the bright/dim switch. When in the Bright position, the switch will tie straight to ground. When in Dim position, the switch will go to ground via a zener diode of TBD voltage. The theory is that since the zener has a constant voltage across it with varying current, it will provide consistent dimming values to all three LED's regardless of whether one, two or all three are ON. Does this make sense, or is there a simpler, better, cheaper way to accomplish this? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... eJ8+IjICAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcAGAAAAElQTS5NaWNy b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEkAYAAAIAAAEAAAAQAAAAAwAAMAIAAAAL AA8OAAAAAAIB/w8BAAAAXQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGFlcm9lbGVjdHJpYy1s aXN0QG1hdHJvbmljcy5jb20AU01UUABhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tAAAA AB4AAjABAAAABQAAAFNNVFAAAAAAHgADMAEAAAAgAAAAYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9u aWNzLmNvbQADABUMAQAAAAMA/g8GAAAAHgABMAEAAAAiAAAAJ2Flcm9lbGVjdHJpYy1saXN0QG1h dHJvbmljcy5jb20nAAAAAgELMAEAAAAlAAAAU01UUDpBRVJPRUxFQ1RSSUMtTElTVEBNQVRST05J Q1MuQ09NAAAAAAMAADkAAAAACwBAOgEAAAAeAPZfAQAAACAAAABhZXJvZWxlY3RyaWMtbGlzdEBt YXRyb25pY3MuY29tAAIB918BAAAAXQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGFlcm9lbGVj dHJpYy1saXN0QG1hdHJvbmljcy5jb20AU01UUABhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3Mu Y29tAAAAAAMA/V8BAAAAAwD/XwAAAAACAfYPAQAAAAQAAAAAAAAC+XsBBIABADIAAABSRTogQWVy b0VsZWN0cmljLUxpc3Q6IERpbW1pbmcgcXVlc3Rpb24sIGFnYWluLi4uAPkQAQWAAwAOAAAA0gcK AAgAFQAmADAAAgBYAQEggAMADgAAANIHCgAIABUAGQA1AAIAUAEBCYABACEAAAAxNzIyRTNDNjAy REJENjExQkIzRDAwQzA5NUVDMTc5QgAoBwEDkAYAhAsAACEAAAALAAIAAQAAAAsAIwAAAAAAAwAm AAAAAAALACkAAAAAAAMALgAAAAAAAwA2AAAAAABAADkAIFbe/jxvwgEeAHAAAQAAADIAAABSRTog QWVyb0VsZWN0cmljLUxpc3Q6IERpbW1pbmcgcXVlc3Rpb24sIGFnYWluLi4uAAAAAgFxAAEAAAAW AAAAAcJvPP7exuMiGNsCEda7PQDAlewXmwAAHgAeDAEAAAAFAAAAU01UUAAAAAAeAB8MAQAAABQA AAB0aG91Z0BhdHRnbG9iYWwubmV0AAMABhCuDUYqAwAHENwKAAAeAAgQAQAAAGUAAABNQVJLLFRI QVRBUlJBTkdFTUVOVFNIT1VMRFdPUktGSU5FLEpVU1RNQUtFU1VSRVlPVVJaRU5FUklTUkFURURI SUdIRU5PVUdIQ1VSUkVOVFRPTElHSFQoRElNTUxZKUFMTFRIAAAAAAIBCRABAAAATwgAAEsIAADn DwAATFpGdWYfbFg/AAoBAwH3AqQD4wIAY2jBCsBzZXQwIAcTAoNDAFAO5nBycTIP5n0TCoAIyCA7 CW8yNTVLAoAKgXYIkHdrC4Bk2jQMYGMAUAsDYwBBC2DAbmcxMDMzC6YF0LkKwGssCqIKhAqAVA9w awVACsByFfFlB4ACMCCEc2gIYGxkIHcFsAhrIGYLgGUsIGrMdXMFQADAa2UZAAhwZRqweQhhIFoJ 8ASQIBUEACAYcHQJgCBoabhnaCAJ8AhgHIFjCHDDCXAY4XRvIGwccQVAhChkB3BtbHkpGEASbAMg dGgJ0SBMRXBEcy4gGAAb0RkUbkonBUBiGrBhIBEwb88CYBiwGhAAkG5jGwMZcN8DEAMgHdAaoB6A IAIgIsHXGfAcMSDgZgfRbSJBBzCUbXAEIGUA0GguF0r+UyGjHwAfQxvDJJAe0CLQ3yDgHkAEcRoQ JgJ2BvABkLcYoCcwA2BwGEAFAG8EEf5pBUAiMyCxBaAAgAGQGOEWKBhABuB1BUAwLjjiVhvAZiBJ JqEHgAbQtxuhBRAd8SkaEAlwZwsReyFABBFvK1AmAh0lH6BP/ytQBaAIcA+gLXoiJAEAHCB+ciPw GfAl8wuAHCAAgXT3ItEtZB9kRSShJjMiMyNF/w+gCIEmkgCQGlAFsS1RIODedgdAClAv+BlgYiLQ Lvr7HAELgGcxeRhAFNAl8xxieweQGPF5GlAYsCfnIfJlXHhwBZAdgw+gZR+gV38pMByQA5EmQhwE GCEWwW2+QRnAGUApkSwjIXFhItAoKDE0KyAtKuMpL0MB0DyxPSA2Ng/QT/RobS0xchoQBJAFEDcy /wOgOFYhgSdyCsAIYDghAcGXIuA/hBkAbx+gTm8H4PcrQSHyI0M1PKMFsSYCHkG/HRYaEBsjQgUv pSiCKEICYCouMDA1HqA/EDPYLjZWH6IaQCA+CD4x60fyPwE5SYJ6G4MZgBlCeGdpdiHULvoh8yoz Yf0EEHUwUTdAJgIhQBlgHSX/BCAqkUsRCsApwh1BOoE+QOZiKsEmAXknGvEhAgGg4SMSb3QhKSTb DIIfsN8EcAsxUZkLAx3QMz9AFZGfAUAhARwgOoAQdDE2PjD9VYJPLCELgAdABdAtESgxP1WDF0ZU lFRhCxNUlmktzT4ANAFAHdAxOEeADMGrWSNSYEYDYToMg2IP0M5jSjAPYACQeEAaMBzA/i4FoDlg F0VSYAZgAjBat7JUClBzZD3AGhBPOoCzISAboTA4GhAB0DARYOQxOlVRUE1cZ1KAWrc6YQSQbyKw OnEFEGMt+x3QGlBAAMBhkAIgYbAfkGNcIVxodWJqOnFat0EVYSFFYWZMNEE6IET7HlE3InFd0TcQ AiBBcSzA/QuALmcwVy9YOlPkC7YXU/1VgD5kjxphVnQg8CjwHCLPNgBloFtPF0pHdTkgGhC/K3AZ 8EsQLAEmxE9RZUsBryNyHkBPUwBxdxuhYVKg9zQRIZE3QG0i0CEBbEEcMf8aQBqwNKNKNCdDRENy UT009i9E0gPhdDJxZkYjhV4B+U5hZ28hcR2wJhAa8XdA/weRAiAasARgGvE3EAeAWrDvF1krcA9w SxEzJjQU0GGw/xggBbAEIB8AGCErcEyDHaH5ILFPThlwJhADoGxAcWL5G9FhcAtQCJA4MTrBA3Dv UGEIkCHBLVFlZkAFIBjCnx+ge7lzEiDgHaBnZyFA/3V2HaEhARRwdDEg4HTZPODfIbB2M0RVLsEf YScfkQXQ73JmVjEdoRqgZSigHwA3Ib8f8QdwC1AwwXtRHbByQcD/JfMJwEGzRFaEgx7yHNMmArt0 33/BV3zSC4Al80IsI/9sMikwZpMmAnWFIjM3EBqx/2GQC3Ad8h2hiASLKWXBjH9/jYh3QI7oJ+AH MHN9LVFU/kImYCf1f8EYACXjBbAi0P+HIhgSIZQmAko0D3BOYSnY/yf2KMo7UTTwlZA3IkUXKTb/ ggYp4jRBGNIeQjciNPOHM38ey4khLKx8wSYBNIEZ8nS/GYBCgh7ITuJ8kCTbRHgS/4ZBBCAahDER GgEFsZXDd8L/M4GGwz/RILACQKUCD2AkkO86YEpxPcGdUmNcIX3BGRDlorM/F01ua27wF0pVgL8W 8geweiA28glQF1NDCYC9CsFSfaBBQG7yQxBhF0SQUlYtODzATjImYB8Z0achNyFnORdoXy09/68f sC+xP7JPsnCul3/QtC6/PkCVEmqvMkAAwAMRRgWw/00QPjCzih/DRFG3QR/ibED/AIB4oRlgGNFw 0SLBiVoIUP8CMAUQT8FmkS0ys4prdSvS9YTCWQhgJzMDb2I64SCg/wBwG5JxoEJzAHAi0Z+TRFHv YvWz5C1RcMZkb2E3EHID/0B1FvBiVbcEH5Cun8U/xk8nx1+y37PiISEHsEVXP8mxs4qMEEMQhFJl cyBV/y7BGyNxYFJgPTDLMkRxHbC/FHJNZBwRa5jEGbQhUBkg/R2hUw9xeRB/0NAjIPDP0v9OYYhC AxAHkZlTv/S828Q/39Sf1a/Wv8h/vHlSIrAcE7xJbsBSNwECILONUGxRH1ZWy8FhH2Ivs7pVTi8A U1VCU0NSSUIGRcvBHgB0cDovL6p34OAu3csvGtBiBPT/2p/PveBv4XfRBNAys43LHO/kn+F3zMTd ci/cr7ONBmD7CsAycUUWABnhZaDov+GH3+0Ds40HEA9gSwFz6HLoj9/hWe0S8QKzjWtzUzphBpDf 3UDtz/Kp6w+znE/Sd/Ez//Wv4YYYsLbR3XLzvrsb9Y//4Wgp4btHs43DJ/FE/j/hhv/TnwT/Bg8H H9ffCO+uKxQxAgALYAADABAQAAAAAAMAERAAAAAAAwCAEP////9AAAcwYEoQMTtvwgFAAAgwYEoQ MTtvwgELAACACCAGAAAAAADAAAAAAAAARgAAAAADhQAAAAAAAAMAAoAIIAYAAAAAAMAAAAAAAABG AAAAABCFAAAAAAAAAwAFgAggBgAAAAAAwAAAAAAAAEYAAAAAUoUAALcNAAADAAmACCAGAAAAAADA AAAAAAAARgAAAAABhQAAAAAAAB4AE4AIIAYAAAAAAMAAAAAAAABGAAAAAFSFAAABAAAABAAAADgu MAALABeACCAGAAAAAADAAAAAAAAARgAAAAAOhQAAAAAAAAMAGIAIIAYAAAAAAMAAAAAAAABGAAAA ABGFAAAAAAAAAwAagAggBgAAAAAAwAAAAAAAAEYAAAAAGIUAAAAAAAAeACmACCAGAAAAAADAAAAA AAAARgAAAAA2hQAAAQAAAAEAAAAAAAAAHgAqgAggBgAAAAAAwAAAAAAAAEYAAAAAN4UAAAEAAAAB AAAAAAAAAB4AK4AIIAYAAAAAAMAAAAAAAABGAAAAADiFAAABAAAAAQAAAAAAAAAeAD0AAQAAAAUA AABSRTogAAAAAAMADTT9NwAAan8 ________________________________________________________________________________
Date: Oct 08, 2002
Gabe and Marisol Ferrer wrote: > > > Bob or anyone, please: > > Do you know where to get 1/4 inch hole insulating washers for a music jack? > > Gabe A Ferrer (RV6, N2GX reserved, SE Florida) > ferrergm(at)bellsouth.net > Cell: 561 758 8894 > Night or FAX: 561 622 0960 > http://www.switchcraft.com/ & look up their 1/4" audio phone jacks. P/N s1028 & s1029 insulating washers are needed. Unfortunately, they can't be found using the site's search engine. Go to a well equipped electronics supply house that handles Switchcraft brand connectors & ask for them by name & #. If you haven't bought your jacks yet, you can use their enclosed style SERIES MN-11* Hi-D JAX which has a threaded nylon (insulated) mounting bushing. Charlie ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Oct 08, 2002
----- Original Message ----- From: "Bill Rounds" <wrounds(at)ix.netcom.com> Subject: AeroElectric-List: Alternator Blast tube > > Hi all > > Have the Van's alternator with the external regulator. It doesn,t have > a fan so am wondering where the cooling air from the blast tube should > be directed. Front or back of the unit. Also is there a particular > location on the magneto that should be the focus of the blast tube. Bill: Many moons ago, when Van was using an alternator like unto the Pelican unit, there were failures (both on Van's RV-4 and others) attributed to lack of cooling. Van even drilled a hole in the side of the alternator case and piped air to it from the upper plenum. When I was setting up my -4, I had one of the same units. It too, had the fan removed. Bill Bainbridge sent me a pulley with fan which I use to this day. The only explanation for the fan removal that I could find was the vague notion that the air movement inside the cowl might tend to fight with the fan. It was suggested that the diodes in the back of the alternator could fail if overheated and so I built a shroud for the back side of the unit and piped air to it from the front engine cooling baffle. This works in concert with the fan. The alternator is still OK after nine years. I have no proof that what I did was necessary. Gordon Comfort N363GC ________________________________________________________________________________
Date: Oct 08, 2002
Bob, You're probably right that there isn't any temperature studies on the need for blast air for the alternator and mag. It may be another old wives tale akin to needing shielded cable for the alternator field. On the other hand, most if not all of the RV webmasters such as Sam Buchanan used blast air on the Alt. and Mags . In addition, the homebuilding guru, Tony Bingelis recommends it and Vans has them on their demo aircraft. It seems to me that I saw some anecdotal data somewhere that temperatures can exceed 300 degrees F in some parts of the uncooled cowling area. Do you think any of the above means anything. I don't have enough practical knowledge to separate the wheat from the chaff on this one. At any rate if we wanted to cool the alternator would one want to cool the forward or aft face. It seem to me that those ND alternators have diodes in the back end. Would they be vulnerable to overheating? Bill Rounds Robert L. Nuckolls, III wrote: > > >> >>Hi all >> >>Have the Van's alternator with the external regulator. It doesn,t have >>a fan so am wondering where the cooling air from the blast tube should >>be directed. Front or back of the unit. Also is there a particular >>location on the magneto that should be the focus of the blast tube. >> > > > Have there been temperature studies done to show that > blast cooling for these items is necessary? I don't > recall having seen any cooling on mags for an RV and > although some folks have cooled the alternator, I don't > recall anyone taking any real data that shows it's > needed. > > Bob . . . > > ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSFIED - SWITCH QUERY
Date: Oct 09, 2002
Bob, I am designing my first electrical circuits - managed to get confused between the headroom required by fuses and switches so I re-read Ch11 of the Connection, and am attempting to use the following table from Ch 11 of AC43.13 to size switches for basic services. Still confused! Switch Derating Factors Sys Volts Load Type Derating factor 12 Lamp 5 12 Relay 2 12 Heater 1 12 Motor 2 Would you be kind enough to clarify the switch ratings of your S700 series switches. The only reference to their rating I can find is at the end of the article Switch Ratings- What's it all Mean? which generically quotes 7 amps, but does not specify tungsten, inductive or resistive. For example, for my 55 watt 4.6 amp landing light the table suggests a whopping 23 amp DC switch rating. Presumably because of the inrush. But the computed fuse will be 7 amp, so will the fuse blow when the switch goes to work? Some of my loads are pitot heat (constant resistance) 8 amps, position lights, 6A, strobe power supply 7A, taxi light 4.6A. Please confirm your S700 series switches are suitable for each of these loads. Additionally, in Z12 and Z13 the essential bus alternate feed is shown as a switch, but supports some fairly hefty combined loads on the e-bus, well over 7A. At what total load point would you suggest upgrading from your S700 series switch to a relay? Mine will be a complex IFR equipment fit with attendant heavy electrical loads. Appreciate your advice, and I very much enjoy sitting down to my daily electrical lesson on the List. David Francis, Canberra, Australia, VH-ZEE Email: David.Francis(at)defence.gov.au ________________________________________________________________________________
Date: Oct 09, 2002
I have a RV6 with my alternator blast tube aimed at the front. No problems to compared to aiming it from behind. I have been running it for three years 300 hrs trouble free, but I wonder if that is really necessary given that the temps in my car bonnet/hood are not much cooler. Come to think of it I also wonder if the 4inch pulley is also necessary to slow down the alt revs. Albert ________________________________________________________________________________
Date: Oct 09, 2002
For those who want to build their own annunciator lights, the nicest system I have seen uses 1.5in by 3/8 in bar lights, which have two 12 volt bulbs, draw 180 ma, and have stacking tongue and groove slots so that they can be stacked horizontally, vertically, or variations of these. A colored plastic sheet with lettering can be run through your laser printer to make whatever lable you want, and because the lighted area is 1.5 by 1/4, the lable can have 6 to 10 letters. The lamps glow at a medium intensity, suggesting that they should be good for thousands of hours. The price? 20 cents each, 15 cents for 10 or more. I got 30 of them. see http://www.mpja.com/product.asp?product5072+LA for the picture. These use 0.187 faston tabs. Jim Foerster ________________________________________________________________________________
Subject: Hall effect Ammeter - Magneto ignition current
Date: Oct 09, 2002
I have two questions for you : - Does anyone have a commendable reference for a good (and reliable) Hall effect ammeter sensor with an unipolar power supply (+12V ) ? The only one I found with unipolar power supply is from Honeywell and looks like very small and fragile... (CS Series). I red here and there thing's about "micro switch" sensor, but can't find it. - I would like to use toggle switches for my ignition circuit and I would like to know what is the real value of the current from the primary circuit of a Bendix magneto when you ground it? Does anyone have measured it once ? Thank you for your help. Vincent. France ________________________________________________________________________________
Date: Oct 09, 2002
> >Bob, > >You're probably right that there isn't any temperature studies on the >need for blast air for the alternator and mag. It may be another old >wives tale akin to needing shielded cable for the alternator field. On >the other hand, most if not all of the RV webmasters such as Sam >Buchanan used blast air on the Alt. and Mags . In addition, the >homebuilding guru, Tony Bingelis recommends it and Vans has them on >their demo aircraft. It seems to me that I saw some anecdotal data > somewhere that temperatures can exceed 300 degrees F in some parts of >the uncooled cowling area. Yup, anecdotal. It's sad that the same folks who KNOW that we need to know, understand and observe other performance limits on the airframe like Vne, stall, gross weight, density altitude, etc toss around other numbers on the same machines as if they were also important but haven't a clue as to what's really going on. > Do you think any of the above means anything. > I don't have enough practical knowledge to separate the wheat from the >chaff on this one. At any rate if we wanted to cool the alternator >would one want to cool the forward or aft face. It seem to me that >those ND alternators have diodes in the back end. Would they be >vulnerable to overheating? Might be. Never had the opportunity to go find out so I can't tell you. >Bill Rounds It's pretty easy to find out for sure. Thermocouple reading instruments are relatively cheap . . . A really good Fluke digital T/C readout is under $100 http://www.tequipment.net/FlukePriceList.html The worst case temps for most airplanes is a best angle climb on hot day. An alternator would be tested with everything electrical turned on. If you were REALLY going to see if the alternator could be loaded to max capacity, you would fabricate and install a temporary load of some kind that could be used to fully load the machine. The alternator is concerned with stator winding and diode array temperatures. Diodes are not always easy to get at without disassembling the alternator but you can slip a miniature T/C into the windings of most alternators without disassembly. Magnetos, of course, are easy to T/C . . . a dab of durable epoxy will hold a T/C to the outside of the case. If anyone is willing to go do some real studies on these issues and publish the results, the could go down in the annals of OBAM aviation as somebody who really KNEW what they were talking about. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: SWITCH QUERY
> > > >Bob, >I am designing my first electrical circuits - managed to get confused >between the headroom required by fuses and switches so I re-read Ch11 of the >Connection, and am attempting to use the following table from Ch 11 of >AC43.13 to size switches for basic services. Still confused! > >Switch Derating Factors >Sys Volts Load Type Derating factor >12 Lamp 5 >12 Relay 2 >12 Heater 1 >12 Motor 2 > > >Would you be kind enough to clarify the switch ratings of your S700 series >switches. The only reference to their rating I can find is at the end of the >article Switch Ratings- What's it all Mean? which generically quotes 7 amps, >but does not specify tungsten, inductive or resistive. > >For example, for my 55 watt 4.6 amp landing light the table suggests a >whopping 23 amp DC switch rating. Presumably because of the inrush. But the >computed fuse will be 7 amp, so will the fuse blow when the switch goes to >work? > >Some of my loads are pitot heat (constant resistance) 8 amps, position >lights, 6A, strobe power supply 7A, taxi light 4.6A. Please confirm your >S700 series switches are suitable for each of these loads. > >Additionally, in Z12 and Z13 the essential bus alternate feed is shown as a >switch, but supports some fairly hefty combined loads on the e-bus, well >over 7A. At what total load point would you suggest upgrading from your >S700 series switch to a relay? Mine will be a complex IFR equipment fit with >attendant heavy electrical loads. > >Appreciate your advice, and I very much enjoy sitting down to my daily >electrical lesson on the List. Have you read http://www.aeroelectric.com/articles/swtchrat.pdf You may be spending far too much time worrying about this. Our switches are suitable for about any of the common loads in your airplane. It isn't like we're trying to get 10,000 to 50,000 cycles out of these switches. It's more like 10-15 years which probably won't exceed 1,000 cycles on the most used switch and perhaps a few dozen cycles on the least used. Take the wire rating table in Figure 8-3 as guide for fuse sizes. 30 to 100% headroom is no big deal for most circuits you just want them large enough that there are no nuisance trips of the circuit protection. The ringer is pitot heat. This heater draws a lot of inrush (cold) current for perhaps 5-10 seconds after turn-on. Run 14AWG and 15A fuse for the 8A device. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2002
> > >I have a RV6 with my alternator blast tube aimed at the front. No problems >to compared to aiming it from behind. I have been running it for three years >300 hrs trouble free, but I wonder if that is really necessary given that >the temps in my car bonnet/hood are not much cooler. Come to think of it I >also wonder if the 4inch pulley is also necessary to slow down the alt revs. >Albert the oversized pulley was deemed useful by some folks to "prevent overspeeding" and thereby increasing bearing life. Bearing life has proven to be more a factor of rotor balance than a function of speed. This is why B&C balances their rotors to about 10x tighter specs than factory-new. Leaving the pulley factory stock gets you more output at idle/taxi RPMs, increases cooling and increases cowl clearance on come aircraft. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2002
> > > >----- Original Message ----- >From: "Bill Rounds" <wrounds(at)ix.netcom.com> >Subject: AeroElectric-List: Alternator Blast tube > > > > > > > Hi all > > > > Have the Van's alternator with the external regulator. It doesn,t have > > a fan so am wondering where the cooling air from the blast tube should > > be directed. Front or back of the unit. Also is there a particular > > location on the magneto that should be the focus of the blast tube. > >Bill: Many moons ago, when Van was using an alternator like unto the >Pelican unit, there were failures (both on Van's RV-4 and others) attributed >to lack of cooling. Van even drilled a hole in the side of the alternator >case and piped air to it from the upper plenum. When I was setting up >my -4, I had one of the same units. It too, had the fan removed. Bill >Bainbridge sent me a pulley with fan which I use to this day. The only >explanation for the fan removal that I could find was the vague notion that >the air movement inside the cowl might tend to fight with the fan. It was >suggested that the diodes in the back of the alternator could fail if >overheated and so I built a shroud for the back side of the unit and piped >air to it from the front engine cooling baffle. This works in concert with >the fan. The alternator is still OK after nine years. I have no proof that >what I did was necessary. Hey Gordon, long time no hear from you. Of course that's mostly my fault. We may find a good reason to get back to OSH one of these years. A common anecdote flying around about alternator fans way back when was the notion that on airplane engines, the alternator runs "backwards" and therefore, the models fitted with fans would be better off having the fan removed and cooling replaced with a blast tube. If anyone had bothered to study the physics of centrifugal fans they would have discovered that turning that particular design "backwards" results in only a slight loss of air flow for a given speed. Removing the fans was NOT a good thing to do. Even if the fans were left on, pundits of the time opined that slowing the alternator down with a larger pulley was advisable . . .which only served to further cripple fan operation. Modern alternators are cooled with internal fans so we don't have an opportunity to hose them up by taking the fans off. Bob . . . ________________________________________________________________________________
Subject: Inline mike and headset plugs
Date: Oct 09, 2002
I am looking for a source of inline male & female mike and speaker plugs for an aviation headset (part of the phone interface project) Ian http://www.sold.com.au - SOLD.com.au - Find yourself a bargain! ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: Hall effect Ammeter - Magneto ignition current
> >I have two questions for you : > >- Does anyone have a commendable reference for a good (and reliable) >Hall effect ammeter sensor with an unipolar power supply (+12V ) ? >The only one I found with unipolar power supply is from Honeywell >and looks like very small and fragile... (CS Series). >I red here and there thing's about "micro switch" sensor, but can't find it. Microswitch and Honeywell are one in the same company http://content.honeywell.com/sensing/prodinfo/current/ Did a quick websearch and came up with http://www.wattco.net/tstitems/halleffect.pdf http://www.crmagnetics.com/newprod/ProductView.asp?ProdName=CR5210 and http://www.west.net/~escor/ >- I would like to use toggle switches for my ignition circuit and I would >like to know >what is the real value of the current from the primary circuit of a >Bendix magneto when you ground it? >Does anyone have measured it once ? I've taken a whack at it. It's not much and due to the pulsed nature that lasts only a very short time, it's difficult to put an RMS value on it. I think I recall seeing peak currents on the order of 2-3 Amps. >Thank you for your help. > > >Vincent. >France > > Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Switch ratings
Date: Oct 09, 2002
I've been reading the list for some time now trying to absorb what I will need to know - but now I am about to start and have a really simple question to which I haven't seen the answer. I am putting some "microswitches" in the flap mechanism that will switch the motor current directly. It looks like the motor has a stall current of about 4-5 amps. Catalogs usually list current ratings at every voltage except 12, it seems. Question is, how does one convert the typical 120-volt AC rating to a 12-volt DC inductive load? I'm assuming a 15-amp AC switch will have the capacity for a 5-amp DC load. Correct? Then I found some switches that had a Mil-spec rating - the cost went from about $4 each to about $25 each. What's the difference? Gary Casey ES ________________________________________________________________________________
Subject: Current capacity
Date: Oct 09, 2002
Bob, I've positioned my battery and contactors so that they can be connected short, shrink wrapped lengths of your B&C brass bus bar stock. Any idea of the AWG equivelent of this brass stock? Should I double it up? On a similar note, I notice that drawing 11a shows 18AWG for the starter contactor, but 22 awg for the other contactors. Why is this? John Slade Cozy IV ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: Current capacity
> >Bob, >I've positioned my battery and contactors so that they can be connected >short, shrink wrapped lengths of your B&C brass bus bar stock. Any idea of >the AWG equivelent of this brass stock? Should I double it up? Single layer will be fine. >On a similar note, I notice that drawing 11a shows 18AWG for the starter >contactor, but 22 awg for the other contactors. Why is this? Starter contactors draw about 5X the current Bob . . . ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: Switch ratings
> >I've been reading the list for some time now trying to absorb what I will >need to know - but now I am about to start and have a really simple question >to which I haven't seen the answer. I am putting some "microswitches" in >the flap mechanism that will switch the motor current directly. It looks >like the motor has a stall current of about 4-5 amps. Catalogs usually list >current ratings at every voltage except 12, it seems. Question is, how does >one convert the typical 120-volt AC rating to a 12-volt DC inductive load? >I'm assuming a 15-amp AC switch will have the capacity for a 5-amp DC load. >Correct? Then I found some switches that had a Mil-spec rating - the cost >went from about $4 each to about $25 each. What's the difference? Not much. See http://www.aeroelectric.com/articles/swtchrat.pdf About any switch you buy with thickness of 0.4" x 1.0" x 0.6" (Microswitch V3 series) or larger will be just fine. Given the VERY infrequent and low duty cycle of switches in airplanes, "ratings" that speak of life in the tens of thousands of operations are close to meaningless. As I point out in the article above, 117 VAC ratings compare very favorably with 14 VDC capability. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Strobes
I'm reeling at the cost of buying these things from the standard aero suppliers for my canard A/C. I've bought some samples at auto parts stores with a plan to roll-my-own, but they all seem so dim. Also re-packaging them for wing-tip installation is an issue. Has anyone come up with a BRIGHT solution for building your own strobes? Thanks Neil Clayton Cozy MkIV #493 ________________________________________________________________________________
Date: Oct 09, 2002
current sensors - http://www.ampsense.com/ I got the AMP200's and PRO50 installed but not running yet. Gary K. ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Hall effect Ammeter - Magneto ignition current > > > > >I have two questions for you : > > > >- Does anyone have a commendable reference for a good (and reliable) > >Hall effect ammeter sensor with an unipolar power supply (+12V ) ? > >The only one I found with unipolar power supply is from Honeywell > >and looks like very small and fragile... (CS Series). > >I red here and there thing's about "micro switch" sensor, but can't find it. > > > Microswitch and Honeywell are one in the same company > > http://content.honeywell.com/sensing/prodinfo/current/ > > > Did a quick websearch and came up with > > http://www.wattco.net/tstitems/halleffect.pdf > > http://www.crmagnetics.com/newprod/ProductView.asp?ProdName=CR5210 > > and > > http://www.west.net/~escor/ > > > >- I would like to use toggle switches for my ignition circuit and I would > >like to know > >what is the real value of the current from the primary circuit of a > >Bendix magneto when you ground it? > >Does anyone have measured it once ? > > I've taken a whack at it. It's not much and due to the pulsed > nature that lasts only a very short time, it's difficult to put an > RMS value on it. I think I recall seeing peak currents on the order of > 2-3 Amps. > > > >Thank you for your help. > > > > > >Vincent. > >France > > > > > > Bob . . . > > |-------------------------------------------------------| > | My interest is in the future, because I'm going to | > | spend the rest of my life there. -C.F. Kettering- | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Subject: Vaccum Pump Removal
Date: Oct 09, 2002
Since I am using the all-electric approach to building I plan to remove and sell my vaccum pump. I have an O-235 N2C engine. I will need to install a cover plate and gasket on the accessory pad in place of the vaccum pump. Does anyone know where I can buy one already made? I haven't seen anything in my regular catalogues. I really don't want to make a plate for this. The engine and everything on it is still "certified" - so far. Thanks for any help. Ernest Kells - RV-9A O235-N2C, Wood Prop Finish Kit 70% Complete ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: Strobes
> >I'm reeling at the cost of buying these things from the standard aero >suppliers for my canard A/C. I've bought some samples at auto parts stores >with a plan to roll-my-own, but they all seem so dim. Also re-packaging >them for wing-tip installation is an issue. > >Has anyone come up with a BRIGHT solution for building your own strobes? You seem willing to get shed of the strangle-hold that certified aviation strobe suppliers have on the market. That being the case, then there's no reason to build your self when there are so many capable suppliers of product equal to or better than certified for less dollars. Did some websearching and had thousands of hits for suppliers/manufacturers of vehicular warning strobe systems. Here's just a small sample. http://www.strobes-r-us.com/strobes-r-us_021.htm http://www.strobes-r-us.com/strobes-r-us_025.htm http://www.galls.com/shop/viewProductDetail.jsp?item=GR006 http://www.galls.com/shop/viewProductDetail.jsp?item=GR061 http://www.angelfire.com/biz5/ies/606pakset1.JPG http://www.acornproducts.com/specials/January_2002_Specials/Undercover_Specials_Content.htm http://www.strobe.com/products/xpak.htm Talk to the folks that make them. You're looking for systems that put 20 joules or more energy into EACH flash to be on a par with systems sprinkled with Washington holy water. The hard part is mounting some of these critters as the supplied lamp assemblies are designed to fit inside user supplied fixtures. But some creative glass and epoxy, sheet metal or machine work should yield useful alternatives . . . Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Re: Vaccum Pump Removal
> > >Since I am using the all-electric approach to building I plan to remove and >sell my vaccum pump. I have an O-235 N2C engine. I will need to install a >cover plate and gasket on the accessory pad in place of the vaccum pump. >Does anyone know where I can buy one already made? I haven't seen anything >in my regular catalogues. I really don't want to make a plate for this. >The engine and everything on it is still "certified" - so far. >Thanks for any help. Why aren't you "plugging" that hole with another alternator? Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 09, 2002
I got a couple of strobe kits from Great Plains Aircraft. I think they are really some kind of Heathkit type of kit that Great Plains re-labels. I built two strobes - one works, I need to order another bulb. I potted them with micro slurry for vibration. I have not yet tried mounting them. They are not all that bright, but I will use them if nothing better comes along. Sam ----- Original Message ----- From: "Neil Clayton" <harvey4(at)earthlink.net> Subject: AeroElectric-List: Strobes > > I'm reeling at the cost of buying these things from the standard aero > suppliers for my canard A/C. I've bought some samples at auto parts stores > with a plan to roll-my-own, but they all seem so dim. Also re-packaging > them for wing-tip installation is an issue. > > Has anyone come up with a BRIGHT solution for building your own strobes? > > Thanks > Neil Clayton > Cozy MkIV #493 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Re: Hall Effect Ammeter ...
Date: Oct 09, 2002
I bought two Hall Effect sensors from Grand Rapids Technology www.Hometown.AOL.com/EngInfoSys I installed one on my backup power system and one on the primary. They run from a 4.8 VDC source. Call Gregg at Grand Rapids, 616 583 8000. I'm sure he'll be glad to discuss with you the sensor's details. I haven't flown yet, but it looks like they are working in the hangar. Gabe A Ferrer (RV6, N2GX reserved, SE Florida) ferrergm(at)bellsouth.net Cell: 561 758 8894 Night or FAX: 561 622 0960 ________________________________________________________________________________
Date: Oct 09, 2002
I messed with it for a while, and got fristrated. If you search on e-bay, there are various auto (police, emergency) strobe systems available for pretty cheap. Just search "strobe" there will be a buncha hits. It seems there are one or two places that have stores and 5 or 6 systems at a time for sale, so they are new. (usually $60-240 for the powersupply with some bulbs). The frustrating thing, is the darn wing tip fittings. Like you, my Cozy isn't too conducive to mounting the bulbs anywhere but the tips. They'll cost about $300 for the pair. Neil Clayton wrote: > > I'm reeling at the cost of buying these things from the standard aero > suppliers for my canard A/C. I've bought some samples at auto parts stores > with a plan to roll-my-own, but they all seem so dim. Also re-packaging > them for wing-tip installation is an issue. > > Has anyone come up with a BRIGHT solution for building your own strobes? > ________________________________________________________________________________
Date: Oct 09, 2002
There are certainly much cheaper power supplies that you can use with the aeroflash or whelen strobe tubes if you don't want to build a custom mount. I chose to use the Nova Electronics XPAK 904 - this is one of the links Bob posted: http://www.strobe.com/products/xpak.htm The 904 has bascially the same specs as the whelen cometflash 413 that drives three strobe heads. I purchased my 904 from http://www.strobesnmore.com for $159 dollars compared to $350+ for the whelen unit. There's detailed information in the RV-List archives, just search on XPAK. I hooked it up to my Whelen lighting units and they're extremely bright! It exceeds the 20 Joules per flash requirment that Bob mentions. Todd Houg RV-9A - fuselage -----Original Message----- From: Robert L. Nuckolls, III Subject: AeroElectric-List: Re: Strobes > >I'm reeling at the cost of buying these things from the standard aero >suppliers for my canard A/C. I've bought some samples at auto parts stores >with a plan to roll-my-own, but they all seem so dim. Also re-packaging >them for wing-tip installation is an issue. > >Has anyone come up with a BRIGHT solution for building your own strobes? You seem willing to get shed of the strangle-hold that certified aviation strobe suppliers have on the market. That being the case, then there's no reason to build your self when there are so many capable suppliers of product equal to or better than certified for less dollars. Did some websearching and had thousands of hits for suppliers/manufacturers of vehicular warning strobe systems. Here's just a small sample. http://www.strobes-r-us.com/strobes-r-us_021.htm http://www.strobes-r-us.com/strobes-r-us_025.htm http://www.galls.com/shop/viewProductDetail.jsp?itemGR006 http://www.galls.com/shop/viewProductDetail.jsp?itemGR061 http://www.angelfire.com/biz5/ies/606pakset1.JPG http://www.acornproducts.com/specials/January_2002_Specials/Undercover_Specials_Content.htm http://www.strobe.com/products/xpak.htm Talk to the folks that make them. You're looking for systems that put 20 joules or more energy into EACH flash to be on a par with systems sprinkled with Washington holy water. The hard part is mounting some of these critters as the supplied lamp assemblies are designed to fit inside user supplied fixtures. But some creative glass and epoxy, sheet metal or machine work should yield useful alternatives . . . Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| eJ8+IhMCAQaQCAAEAAAAAAABAAEAAQeQBgAIAAAA5AQAAAAAAADoAAEIgAcAGAAAAElQTS5NaWNy b3NvZnQgTWFpbC5Ob3RlADEIAQ2ABAACAAAAAgACAAEEkAYAAAIAAAEAAAAQAAAAAwAAMAIAAAAL AA8OAAAAAAIB/w8BAAAAXQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGFlcm9lbGVjdHJpYy1s aXN0QG1hdHJvbmljcy5jb20AU01UUABhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3MuY29tAAAA AB4AAjABAAAABQAAAFNNVFAAAAAAHgADMAEAAAAgAAAAYWVyb2VsZWN0cmljLWxpc3RAbWF0cm9u aWNzLmNvbQADABUMAQAAAAMA/g8GAAAAHgABMAEAAAAiAAAAJ2Flcm9lbGVjdHJpYy1saXN0QG1h dHJvbmljcy5jb20nAAAAAgELMAEAAAAlAAAAU01UUDpBRVJPRUxFQ1RSSUMtTElTVEBNQVRST05J Q1MuQ09NAAAAAAMAADkAAAAACwBAOgEAAAAeAPZfAQAAACAAAABhZXJvZWxlY3RyaWMtbGlzdEBt YXRyb25pY3MuY29tAAIB918BAAAAXQAAAAAAAACBKx+kvqMQGZ1uAN0BD1QCAAAAAGFlcm9lbGVj dHJpYy1saXN0QG1hdHJvbmljcy5jb20AU01UUABhZXJvZWxlY3RyaWMtbGlzdEBtYXRyb25pY3Mu Y29tAAAAAAMA/V8BAAAAAwD/XwAAAAACAfYPAQAAAAQAAAAAAAAC+XsBBIABACMAAABSRTogQWVy b0VsZWN0cmljLUxpc3Q6IFJlOiBTdHJvYmVzALkLAQWAAwAOAAAA0gcKAAkAFQAxABIAAwBHAQEg gAMADgAAANIHCgAJABUAJwAeAAMASQEBCYABACEAAAA3ODk5MTA4NENDREJENjExQkIzRDAwQzA5 NUVDMTc5QgA9BwEDkAYAcA0AACEAAAALAAIAAQAAAAsAIwAAAAAAAwAmAAAAAAALACkAAAAAAAMA LgAAAAAAAwA2AAAAAABAADkAQIDqoAdwwgEeAHAAAQAAACMAAABSRTogQWVyb0VsZWN0cmljLUxp c3Q6IFJlOiBTdHJvYmVzAAACAXEAAQAAABYAAAABwnAHoOqEEJl628wR1rs9AMCV7BebAAAeAB4M AQAAAAUAAABTTVRQAAAAAB4AHwwBAAAAFAAAAHRob3VnQGF0dGdsb2JhbC5uZXQAAwAGEPySGcsD AAcQpQ0AAB4ACBABAAAAZQAAAFRIRVJFQVJFQ0VSVEFJTkxZTVVDSENIRUFQRVJQT1dFUlNVUFBM SUVTVEhBVFlPVUNBTlVTRVdJVEhUSEVBRVJPRkxBU0hPUldIRUxFTlNUUk9CRVRVQkVTSUZZT1VE T05UV0EAAAAAAgEJEAEAAABJCgAARQoAAGEUAABMWkZ1jdVCsT8ACgEDAfcCpAPjAgBjaMEKwHNl dDAgBxMCg0MAUA7mcHJxMg/mfRMKgAjIIDsJbzI1NUsCgAqBdgiQd2sLgGTaNAxgYwBQCwNjAEEL YEBuZzEwMzMLpiBkVGgEkGUgCsAXMGOHBJABkAuAbHkgbRUQJmgXgBcAYXAEkCBwxG93GNFzdXAL UAiQ7QQgdA9wBUB5CGAXgAOR+nUPoCAD8BnwGeEXMQSQtG9mC2BzGGAFsXcXAFZsCfAZUHQDYGIX MHRedR0QBCAGkBozZAIgJw0FQHcAcAVAdG8gYnp1AxBkF0AXgBrAHsBtRxggCGACMC4gSRhxb48a 0R7BGsIbUk5vdh9QWkUckGMc4QMAYwQgWABQQUsgOTA0IP4tGeEEAB2QBCACIBcwG8DTG0MZoG5r BCBCHQAY8Xsc0AmAOgqiCoQLMBmgMy42AUAVoA/QaAJAcDqoLy93J1AuHNQuBaAcbS8RMARwFRB0 cy/SeAqway4m4G0liCXFrxbiItMPcAQgYhvwYwcx8xgBG1JzYQeAGVAYwCJhPysBG1IcZSgBD7Ab 1DQx6jMZ5GQFEHYZwwnRHMbpGJFkcyAycAhwD2EPoH0fMG0YECLiA1Im3weQbh8EYAlwJ/IxsAWx JDE1/jkeASuQD4EtkgqxMSEeweAkMzUwKzPDLPkgAPcbECAwFvMnBCABABfBHJDPHzALgDPRAMB0 aQIgOFHhG0NSVi1MBAAFQArA4w9gLwIsIGofgRlQGKCfMNEjsSKDIDIggG9rODJvBUAZcB6yMVFX HHQZoGd7MhALgGc24yyhFNAbQnnSJxchZXgc4GUHgBgB9mIFED3hISBABUA/cBeQ9wmALNQWwUoI YByQBCAYwvsb1AlwcR8AOKAJ8B6hGgL/JNJDIjjhMGApWwGRFuAEcDUfMEgIYGdE+TmROUHNIxFm GsELYGdlJYUVon8lnyahCqADYCVAIgAQdDH2NiMQSuJPQCELgAdABdD/B5AsEEfASuNIhkn0ScEL E8FJ9mktMTQ0AUAZoHgxODABQAzQToMk8Eb3A2ElcAySYg/QCAAdEAAg1CBMIDBOFRBrNHE6gf5J UeAK4wqBJPAGYAIwUBeGVwmAI9BzZGF5OpDGTyIAULIgMDk6kAHQIjARYDg6MjRAUE1/UidFoFAX G5IcgSIBIlAt+xmgHNBAOLEiJCfyUigdUPZqIfFQF0EboSHUV5E5wuo6B/BlW4BTMtRMj02a7yZE C7ZIk0rgPlpvBUAHgddL8iUFHuB5W4AiUK9RtIgiIDwG4GIublFVWkAFoHhjwA+wPilaQbEFQDA1 Ok6AVYEgFiDoLzkvVPMtIvBPEDqQ7RpCd0nyJXU+X19gb2F1awfAAxFDC2B5HsADoDzjD3EvEHk0 QDsRGfAkcvNkmW1GSScfwAnRJHE+ML8aERtSBaA54SQBHvB5PhL/G1EhEz4RBCAxwyvTAZAU0P8q MhuSaBUZZTSxM9IxURqB0SoyQS9DIDEnLxAe4P9GATIQGVAtsSwCC1AHkRoR/GF1HsEKsT6BH5EJ cFxF/j4bAx9QC1E5MR7QA2ArkOotMVAtGRBuOpAe8G8D/xgQK4E68T+wdXEeAAdwIDD+QVGgeNFM IAqwUWBHsD4R32gVG1EztAPwFgAtONA80P8LgHGxNIE41D6SI4EZYCfg/W1cSCsBAHAaQCPRLaI8 soF4BUJSSUdIVHVx/wpAONMz0h7zPhIaQQXAeXFZHMVzPyleCoAghhFZ/xpRepMD8CuQcBMe0EfA OuG/FwAfMCQFHNEV8RyQLSCA/x8hGfKFuBeSBpAIkB8xFHD/OMQc1XL4D3B04TjxG1IAwP5yPFAg IIW4FvAaER0QcBW/GnEPoDqQG1E5MzeDbnuS/xvwjOIe1YW4g+NHgR2wHGH/j+UXQ3rhA4Fz4gqw AmCL2f+FuCQBKEU/YELgS5EewYMi/w+wJUA2IgORilgz0YW4QeHPN7E0dESLhhJEaR8wdYP9GSBi OwRusz7BD3A+0ghg/ywQFNAjoR2wI1A+gZjbcvfyLwOBdWYA0B1ACXA0sf8kAS8QI1AfcDSRHmEE oD4SqxzUnql5JTFtMGFIN3T7OrMfUHMAwHpideNEjEiT4TIfcy1yLRrAJ/OnKnpfVRAxKR6mf6eP qJc1O6k/JvhnK4GrlSCAcC+VFHJQKFREN+MuaixgRj8bED+wPUdSTxA2760/rk+vX7BvNkh5qhsV 8QeSoUMAJ+RiaXo1L3UZsS8mcDYo4Q+hqSBK3FBHtf+3BQWhbihGq6Q3LHEHMSiwSp/xCsB5X+lU 8l9TvFZVFNAEkAWg9S8Qcr2XXwhQAjBDMaz/3yb/KA8pHo4yB0BrHrIbUv8CEMRgGdUAwDxQG0J7 MYZR/z8yCQA8QD4SmNqjFRnkMLD7BUAWwWpBxHOiM1E/YCPQPHJnGBALgB7AhbdFQfxDSEJVHsKM w3hRoWIbEn/IFixgBRAkkDgiGwKFt1f/G/E+EWuiiSEYEB5wl6Gabv8qcg9xHzB20iOCH+Oh03WS /yQEGtEFAZeSLKcZZZGYC2D/NQAssQ+gBtAZoxdSAQAAkP5nI9A1U05Q0nEAgQEAGrK/GUeRmE5Q P4CgYTBhQnnR/3WDBQAYoDjQdOGI4NaRPqP6ZRkAeFQBh9GHoS3BB0D/hbdzogDQcMEa4QWwxHCz of9B0B8wcAAcgB8wGsFHYAMg/wdAl6FLgNvCBCAgMOFxpV/fhgOGECTS4X/i5HxK4+VP++Zf5258 5DsF0MqTFxE54f8jYjk0R2CgUnmhBZB2gBrR+W4yZ2+HJeTC6IwsYT7E70Kxb4QxURmgZiEjM2GG EuotdJBGIDBLl4N9guyuH+dv8v/0D+g5KVpfLT3/9r/3z/jf+e/6EPY34uT7yr8jICpyaM8hwADA AxFGBbD+dR/ATHX7hBbwI2Ez0f7h/yNhLGBEUTNR3JFEIQlwK6P/A2B1MRtDv3IFEHnBREIj8f/7 KmmVBtBzUe+hxmJ6YSPQ976heoIrIW7KURdAncIGwf+UIUoAFwEzwilF+4QkAXsQ/xLwloEwQL6h ONDYoD4hjOX+TVgm/qREdvafDT8OTw9fxfrdIUBwTkVXEVH7KppCIiB3GtFbRCBVGtH/g+OcAUAB EtI2IR7Qs/IkJG/QcWm4C7n7wVAggB7BU/9r8VuxF7SWIBdyPpROUEHi/4GjB5QEewvfHD8dTx5f EB9vBBlboBWiciBJOHj7LVA/b3JLxRNhVv9YD/taVU5AL1NVQlNDgiBC/kUTYcDpJWuoIFmAK1DU QP5wIi8XTigPKRcYpBfS+y3fErwsPykXFGQlEi8kT/st+1KwOyNFfFDe0VuAMF8pJ/s7E/stQTol MBIwLyj5nFPfOLH7LQRzvaNOUGM1bzpJ+zKv+zxPGhc40z1PKSbNsP+wcSUSO14Cuz0vKQi7MALY //stCsc45EXfKSYbP0yfTa+vTr8ff1CP4ht9XJAAUwAAAAADABAQAAAAAAMAERAAAAAAAwCAEP// //9AAAcwwHkhQgZwwgFAAAgwwHkhQgZwwgELAACACCAGAAAAAADAAAAAAAAARgAAAAADhQAAAAAA AAMAAoAIIAYAAAAAAMAAAAAAAABGAAAAABCFAAAAAAAAAwAFgAggBgAAAAAAwAAAAAAAAEYAAAAA UoUAALcNAAADAAmACCAGAAAAAADAAAAAAAAARgAAAAABhQAAAAAAAB4AE4AIIAYAAAAAAMAAAAAA AABGAAAAAFSFAAABAAAABAAAADguMAALABeACCAGAAAAAADAAAAAAAAARgAAAAAOhQAAAAAAAAMA GIAIIAYAAAAAAMAAAAAAAABGAAAAABGFAAAAAAAAAwAagAggBgAAAAAAwAAAAAAAAEYAAAAAGIUA AAAAAAAeACmACCAGAAAAAADAAAAAAAAARgAAAAA2hQAAAQAAAAEAAAAAAAAAHgAqgAggBgAAAAAA wAAAAAAAAEYAAAAAN4UAAAEAAAABAAAAAAAAAB4AK4AIIAYAAAAAAMAAAAAAAABGAAAAADiFAAAB AAAAAQAAAAAAAAAeAD0AAQAAAAUAAABSRTogAAAAAAMADTT9NwAAUUU ________________________________________________________________________________
Date: Oct 09, 2002
Gabe, I have a 40 amp alternator and an SD-8 backup alternator. Greg at Grand Rapids advised me to purchase just one hall effect current sensor and run both B-leads through it. I don't anticipate ever running both alternators at the same time so the single current sensor should be sufficient for my system. Chris Heitman Dousman WI RV-9A N94ME (reserved) http://my.execpc.com/~cjh/rv9a.html -----Original Message----- I bought two Hall Effect sensors from Grand Rapids Technology. I installed one on my backup power system and one on the primary. --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Date: Oct 09, 2002
Subject: Two-color LED and the LR-3?
Phreeeow! Now that's a true act of kindness. Many, many thanks. > > > See http://www.aeroelectric.com/temp/Bicolor_LED.pdf > > ________________________________________________________________________________
Subject: Strobes
Date: Oct 10, 2002
> I messed with it for a while, and got fristrated. Me too. I made the White Plains strobes. As was said, they work (both in my case :), but then you still have to figure out how and where to fit them, and you still need the fittings. I struggled with this one for two years before buckling under and getting the Aeroflash units. There's about $30 worth of cheap looking parts in the whole package, but they work well and they're much cheaper than the Whelands. John Slade Cozy IV http://kgarden.com/cozy ________________________________________________________________________________
Date: Oct 10, 2002
> current sensors - http://www.ampsense.com/ > I got the AMP200's and PRO50 installed but not running yet. These look nice, and inexpensive too. What gauge did you use? John Slade ________________________________________________________________________________
Date: Oct 10, 2002
I was wondering wghat the advantages to using Hall Effect ammeter sensors are? Is it to get the big leads out of the cockpit? Thanks Ned ----- Original Message ----- From: "Gabe and Marisol Ferrer" <ferrergm(at)bellsouth.net> Subject: AeroElectric-List: Re: Hall Effect Ammeter ... > > I bought two Hall Effect sensors from Grand Rapids Technology > www.Hometown.AOL.com/EngInfoSys > > I installed one on my backup power system and one on the primary. > > They run from a 4.8 VDC source. > > Call Gregg at Grand Rapids, 616 583 8000. I'm sure he'll be glad to discuss > with you the sensor's details. > > I haven't flown yet, but it looks like they are working in the hangar. > > Gabe A Ferrer (RV6, N2GX reserved, SE Florida) > ferrergm(at)bellsouth.net > Cell: 561 758 8894 > Night or FAX: 561 622 0960 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 10, 2002
I don't think that the Bi-color Led's are wired that way (maybe there is one out there though) all of the ones that I have seen have 3 leads- an input for each of the led elements, and a ground- the led shown looks to be designed specifically for polarity sensing- is there such a thing? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Erik Anderson Subject: AeroElectric-List: Two-color LED and the LR-3? Phreeeow! Now that's a true act of kindness. Many, many thanks. > > > See http://www.aeroelectric.com/temp/Bicolor_LED.pdf > > http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 10, 2002
> > >I was wondering wghat the advantages to using Hall Effect ammeter sensors >are? Is it to get the big leads out of the cockpit? >Thanks >Ned No, you can get the fat wires out with either a shunt or a hall effect sensor. Hall-sensors do not require breaking into the lead wire to measure the current that flows in it. You can also use the hall-sensor to measure the current in more than one wire wherein the sensor sees the algebraic sum of all the currents. Not much application for this in airplanes but there is ONE two-wire opportunity. You can run the b-lead for both the main and aux alternators through the sensor and it will read either alternator or the sum of both should they both happen to be on and delivering power. This comes with a price. Hall-sensors have very tiny output signals that need amplification by circuitry having stable characteristics. Higher parts count, lower overall reliability and perhaps some loss of accuracy (not a big issue for alternator loadmeters). Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 10, 2002
Subject: RE: Hall Effect Ammeter ...
> >Gabe, > >I have a 40 amp alternator and an SD-8 backup alternator. Greg at Grand >Rapids advised me to purchase just one hall effect current sensor and run >both B-leads through it. I don't anticipate ever running both alternators at >the same time so the single current sensor should be sufficient for my >system. That will work. See my post of a few minutes ago. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2002
> >There are certainly much cheaper power supplies that you can use with the >aeroflash or whelen strobe tubes if you don't want to build a custom >mount. I chose to use the Nova Electronics XPAK 904 - this is one of the >links Bob posted: >http://www.strobe.com/products/xpak.htm > >The 904 has bascially the same specs as the whelen cometflash 413 that >drives three strobe heads. I purchased my 904 from >http://www.strobesnmore.com for $159 dollars compared to $350+ for the >whelen unit. There's detailed information in the RV-List archives, just >search on XPAK. I hooked it up to my Whelen lighting units and they're >extremely bright! It exceeds the 20 Joules per flash requirment that Bob >mentions. Good data points! Thank you. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2002
Subject: Re: Alternator Blast tube
Guess I will volunteer to be the guinea pig for testing without blast tubes. My A&P thinks they are not needed so I am not putting them in. If I have premature failures I will post them. Len Leggette RV-8A N901LL (res) Greensboro, N.C. Flying Saturday !! ________________________________________________________________________________
Date: Oct 10, 2002
> > >I got a couple of strobe kits from Great Plains Aircraft. I think they are >really some kind of Heathkit type of kit that Great Plains re-labels. I >built two strobes - one works, I need to order another bulb. I potted them >with micro slurry for vibration. I have not yet tried mounting them. > >They are not all that bright, but I will use them if nothing better comes >along. Chapter on lighting speaks to sizing the capability of a strobe. Potential energy per flash is capacitance x volts(squared) divided by two. Any strobe you assemble can be easily analyze for flash energy by plugging in the numbers. A few years ago, I saw a diagram that I think was published in Sport Aviation way back when. It charged a 20uF capacitor to 300 volts. 20 microfarads X 300 2 divided by 2 comes out to 0.9 Joules per flash. Pretty wimpy. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2002
> > >I don't think that the Bi-color Led's are wired that way (maybe there is one >out there though) all of the ones that I have seen have 3 leads- an input >for each of the led elements, and a ground- the led shown looks to be >designed specifically for polarity sensing- is there such a thing? Yes. see http://www.jiannwa.com.tw/con-20.htm http://www.ledyoung.com.tw/pdf/L-1.PDF These folks seem to be a source for low-quantity off the shelf shipments. http://www.sourceresearch.com/sunled/LXXX58X.cfm The key here is "bi-color" meaning red or green but not both. There are some red-green pairs with a common lead where you can illuminate both leds to get "multi-color" effects. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2002
Subject: Re: Seawind - Rudimenary system planning
> >Bob, I made a list and tried to break it down as to what goes where. Here it >is: Good start. Let's water the seeds of these ideas and see what grows out of them . . . >Main Bus: >Taxi lights, Strobe, Landing lights, Position lights, Panel lights, Over head >lights >Auto pilot, Okay > Vor, VOR? are you talking about the display head? This normally gets all operating power from the radio that drives it. > HSI You might want to put this on the Aux bus. >Fuel boast pump, Right & Left fuel transfer pump, Bilge pump I think I'd put all of these on one of the battery busses. >Pitot heat, Cooling fan, Stall warning, Flaps, okay > Hobbs meter This goes on a battery bus > >Electric trim for Ailerons, Rudder and Stablizer These draw very little current and are very intermittent duty. They could go on the aux bux. >Landing gear, Hydraulic pressure gauge Okay >Essential Bus: I'm wrestling with the word "essential" in the vernacular of airplane-speak. Essential evokes a sense of urgency in the minds of many speakers and listeners. Auxiliary and perhaps "endurance bus" are better phrases. I'd REALLY like to get everyone to sign up to the idea that were NOT going to have any electrical emergencies in our airplanes. >Altimiter, Is this a micro-encoder? Does it need power to operate? > Rate of climb, same question > Air speed indicator, same question >AI, Turn and slip indicator okay >Directional gyro, GPS( full IFR UPS stack), Nav-Com, Transponder, Audio panel >Goose neck light, Amp and Volt meter, Annunciator light, okay > Clock and Timer Battery bus >Primary fuel pump, Battery bus > Quad fuel gauges okay >Turn cordinator covered above "turn and slip" >I will also have an EM 1000 to monitor the engine. Okay >I know that this is not complete but I hope that it is enough to get me >started in the right direction. Thanks Bob. An excellent start! Take this list an re-arrange it as suggested above. Add two battery busses to your deliberations. Do you plan electronic ignition? Put this(ese) on battery busses too. This is a good exercise. Make your list look something like this: Main Battery Bus: #1 Ignition 3A Hobbs 1A . . Main Power Distribution Bus: Main Alternator Field 5A Landing light 10A Pitot heat 15A . . Aux Battery Bus Clock 1A #2 Ignition 3A . . Aux Power Distribution Bus: Aux Alt Field 5A GPS 3A A.H. 3A . . When the list is complete, you'll be able to take Figure Z-14 and begin to size the bus bars (sizes of fuse blocks). Further, each item on the list represents a page in your wire-book-to-be that describes how that system is wired. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2002
Subject: Re: relay ratings
> > >czechsix(at)juno.com wrote: > > > > If a double pole relay is rated at 30 amps, is this 30 amps per contact? > >The contact rating on a relay or switch is per pole. i.e. your double pole >relay is therefore >capable of switching two separate 30 amp circuits. Generally accurate. SOME products like our S704-1 have de-rated contacts for the normally closed side. I think our S704-1 is rated at 30A for n.o. and 20A for normally closed. This is seldom an issue but you should be aware of it. Another point, you CANNOT parallel contacts of a two pole relay and expect to get performance of a relay equivalent to a device rated for twice the current without taking pains to make sure contact pairs SHARE current. This is done with lengths of wire to generate ballasting resistance in the legs of each relay pole. If you are considering anything like this, lets talk. It's generally a better idea to upsize a relay than to stack sets of contacts on top of each other. Bob . . . ________________________________________________________________________________
Subject: Alternator Cooling
Date: Oct 10, 2002
Early inthe "phase 1" testing of my O-360 Glastar I placed a thermocouple right next (within 1/4")to the alternator (a 40 amp BC) and got a temperature reading less than 100 degrees F. The temp did rise a couple ofdegrees from no load to full electrical load but it was not what I considered enough temp to worry about cooling, at no time did I ever see 100 F. The engine baffles that I made look very much like a standard Van's kit. I got the patterns from Tony Bingelis's book on engines. FYI the outside air on the day of testing was 64F. The firewall, at the engine control cable area was 115F and the gascolator which is located about 4" from the Vetterman exhaust pipe was 122F but it's cooled with a 5/8" blast tube and shroud. Charlie Burton ________________________________________________________________________________
Date: Oct 10, 2002
Subject: Magneto & Alternator Temperature Requirements
Yup, anecdotal. It's sad that the same folks who KNOW that we > need to know, understand and observe other performance limits > on the airframe like Vne, stall, gross weight, density altitude, > etc toss around other numbers on the same machines as if they > were also important but haven't a clue as to what's really going > on. There is generally a source for the upper limit temperatures of the mags and the alternator. These limits are published in the engine manufacturer's specifications list. For example, In the case of a Lycoming O-320 or O-360, the maximum permissible temperature must not exceed 360F in the stator slot and stator end turns, 248F in the drive end bearing, and 305F in the positive heat sink. The magneto maximum permissible temperature is 225F in the pole laminations. Usually, both alternators and mags can be purchased from their respective manufacturers with thermocouples already installed (extra cost). Determining the temperature that any accessory is exposed to at any particular operating set of conditions once installed on a given airframe is the responsibility of the airframe manufacturer (spam can or homebuilder). As already mentioned on this list, homebuilders can and probably should instrument, as do the spam can manufacturers, to learn the actual temperature profiles in their specific installations. Slick, (and probably Bendix) mag manufacturers (and probably the alternator manufacturers) will tell you (if you ask) where to locate the temperature sensors for finding the hottest spot if you prefer to instrument your own rather than buy one with the sensor already installed. At least I have found this true in the case of Slick. Jim McCulley ________________________________________________________________________________
From: "David A. Leonard" <dleonar1(at)maine.rr.com>
Subject: Anecdotal Alternator cooling
Date: Oct 10, 2002
Regarding blast cooling to an alternator, my 1988 BMW 735i runs a 100 amp Bosch Unit. BMW saw fit to run a cooling duct to the alternator. The alternator has a ducted rear housing with a connection for a 3.5" plastic duct that runs to behind the front grille. It is a pretty elegant set up. (I had to go open my hood and look at it just now before writing!) I would guess they had a pretty good reason, those German luxury car engineers take life pretty seriously, and it looks like a relatively expensive set up. this alternator has a brush pak-regulator setup that lives in the rear case section, so I guess they are cooling it..it looks like the airflow runs in from the rear, and is sucked out the pulley end by the alternator fan. Anecdotal evidence, but I would be willing to bet somone did some experimenting before engineering in this expense. Dave Leonard My 72 Bellanca alternator(pulley driven aft end of the engine) has blast air to it as well... ________________________________________________________________________________
Date: Oct 10, 2002
Subject: relay contact ratings
One more ignorant question about relay ratings...do the same rules apply to selecting appropriate relay contact ratings as with toggle switches? For example I think Bob recommends a toggle switch rated at 20 A for a 100W landing light due to inrush. Is the same true for relays, or will a 15 A relay provide sufficient service life? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... ________________________________________________________________________________
Date: Oct 10, 2002
Subject: Re: relay contact ratings
> >One more ignorant question about relay ratings...do the same rules apply >to selecting appropriate relay contact ratings as with toggle switches? > >For example I think Bob recommends a toggle switch rated at 20 A for a >100W landing light due to inrush. Is the same true for relays, or will a >15 A relay provide sufficient service life? You need to read the article at: http://www.aeroelectric.com/articles/swtchrat.pdf and then pretty much go buy any switch you want to do any task you want. By-in-large, the life of switches in airplanes has little if anything to do with their ratings. If you find it interesting to worry about ratings, I would not dissuade you from addressing your worries - but I'd rather you didn't worry about them at all. All those "rules" people are fond of citing don't mean much for the machines we're building. Bob . . . ________________________________________________________________________________
Subject: Over Voltage Protection Module
Date: Oct 10, 2002
Hi Bob, Just wondered if the OVM-14 14V Over Voltage Protection Module works okay with PM alternators? I have the VLM 14PM and need to complete this area with OV protection. Should I consider the LR3B-14 Aircraft Alternator Control System as an alternative to OVM -14? I also notice B&C has a new OV unit for PM alternators. IT's nice to have so many things to look at for the job but it makes it hard to decide which way to go.... Thanks. Ned ________________________________________________________________________________
Date: Oct 10, 2002
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
Subject: Re: Magneto & Alternator Temperature Requirements
This might be really easy to do. Go to your local welding supply store and ask for TempliStick(sp?) crayons. They are available in many different temperatures. Just scribble some crayon on the part. If the mark melts, the temp of the crayon has been exceeded. Scott in VAncouver ----- Original Message ----- From: <mcculleyja(at)aol.com> Subject: AeroElectric-List: Magneto & Alternator Temperature Requirements > > > > Yup, anecdotal. It's sad that the same folks who KNOW that we > > need to know, understand and observe other performance limits > > on the airframe like Vne, stall, gross weight, density altitude, > > etc toss around other numbers on the same machines as if they > > were also important but haven't a clue as to what's really going > > on. > > There is generally a source for the upper limit temperatures of the mags and > the alternator. > > These limits are published in the engine manufacturer's specifications list. > For example, In the case of a Lycoming O-320 or O-360, the maximum > permissible temperature must not exceed 360F in the stator slot and stator > end turns, 248F in the drive end bearing, and 305F in the positive heat sink. > > The magneto maximum permissible temperature is 225F in the pole laminations. > Usually, both alternators and mags can be purchased from their respective > manufacturers with thermocouples already installed (extra cost). Determining > the temperature that any accessory is exposed to at any particular operating > set of conditions once installed on a given airframe is the responsibility of > the airframe manufacturer (spam can or homebuilder). As already mentioned on > this list, homebuilders can and probably should instrument, as do the spam > can manufacturers, to learn the actual temperature profiles in their specific > installations. Slick, (and probably Bendix) mag manufacturers (and probably > the alternator manufacturers) will tell you (if you ask) where to locate the > temperature sensors for finding the hottest spot if you prefer to instrument > your own rather than buy one with the sensor already installed. At least I > have found this true in the case of Slick. > > Jim McCulley > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 10, 2002
Subject: pin-out for a king KX-150 VHF
Hello, I am looking for the pin out for a bendix/king kx-150 VHF, the lighting is not working and i suspect it is in the a/c wiring. thanks for the help --------------------------------- Faith Hill - Exclusive Performances, Videos, & more faith.yahoo.com ________________________________________________________________________________
Date: Oct 10, 2002
Hi Bob, Took your advice and reworked my system. Tell me what you think. Main Battery Bus Fuel boast pump, Right & left fuel transfer pump, Bilge pump, Hobbs meter, Primary fuel pump Aux Battery Bus Clock and timer, Electronic ignition system. Not sure what else to add to this bus. Main Power Dist. Bus Taxi lights, Strobe, Landing lights, Position lights, Panel lights, Over head lights, Auto pilot, Pitot heat, Cooling fan, Stall warning, Flaps, Hydrolic pressure gauge, Landing gear, Attitude indicator Aux Power Dist. Bus HSI, Electric trim (ailerons, rudder, Stablizer), Turn and slip indicator, Directional gyro, GPS (full IFR UPS stack), Nav Com, Transponder, Audio panel, Goose neck light, Amp and Volt meter, Annunciator light, Quad fuel gauges, VM 1000 When you told me how to make the list you said to do Main Battery Bus #1 Ignition 3A Hobbs 1A Am I correct in assuming that 3A is the amps that the ignition draws? I'm not sure what the #1 means. Could you please explain? Tom ________________________________________________________________________________
Date: Oct 10, 2002
Subject: off line until Monday
Dee and I are hopping on the big iron bird in the morning headed for Oregon to do a weekend seminar. Will be back on line Monday morning. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 11, 2002
Neil, Try [ http:www.strobeguy.safeshopper.com ]. Read up on the Superpack 906. Save a lot of money. When I first asked my FAA safety man about these over the phone he said I would have to get them field approved. I wasn't happy about that so I met him at a safety meeting and showed him the specs. When he learned it was for an had been in the electrical industry and that that was the industry standard. I have no fear of using these. Your milage may vary. HTH. writes: > > > I'm reeling at the cost of buying these things from the standard > aero > suppliers for my canard A/C. I've bought some samples at auto parts > stores > with a plan to roll-my-own, but they all seem so dim. Also > re-packaging > them for wing-tip installation is an issue. > > Has anyone come up with a BRIGHT solution for building your own > strobes? > > Thanks > Neil Clayton > Cozy MkIV #493 > > > > > messages. > > > > > > > ________________________________________________________________________________
Date: Oct 11, 2002
As an add-on to my last post I'd like to say that the specs also say that these lights put out 80 joules. That would be 23.33 Joules per flash in a set of three. I bought the "Vans, Whelen, Tail light/ strobe combination and the Strobes-n-more pop-in strobes for inside the wing tips. That's got to be an easy install. Pop-in strobes--$24.99 ea., 45 Ft. cable $15.75, three connectors, $5.79, S-pack 906 168.99 Larry Mac Donald > If you search on e-bay, there are various auto (police, emergency) > strobe systems available for pretty cheap. Just search "strobe" > there will be a buncha hits. It seems there are one or two places > that have stores and 5 or 6 systems at a time for sale, so they > are new. (usually $60-240 for the powersupply with some bulbs). > > The frustrating thing, is the darn wing tip fittings. Like you, > my Cozy isn't too conducive to mounting the bulbs anywhere but > the tips. They'll cost about $300 for the pair. Neil Clayton wrote: ________________________________________________________________________________
From: "Ted Hultzapple" <thultzap(at)rochester.rr.com>
Subject: ARC connectors
Date: Oct 11, 2002
Where can I get crimp connectors for an ARC 459A transponder plug. Ted ________________________________________________________________________________
Date: Oct 11, 2002
Subject: FAA Goldmine
pulsar-builders(at)caseyk.org 2/11/2002 Free Government Gold Available -- Well anyway free government information which can be more valuable than gold at times. The FAA has created a CD (compact disc) that contains an unbelievable amount of information and links to even more. I can't / won't begin to describe the information available on this CD -- you must see it for yourself. The title of this CD is "2002 FAA KEY TO THE INTERNET FAA PUBLICATIONS, JUNE 2002" It is much more than a key or a menu -- it contains actual documents and links to more on the internet. It is available free from your local FSDO -- my FSDO was happy to mail me one. Try it, you'll like it. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: Oct 11, 2002
Subject: Re: off line until Monday
BOB: HOPE YOU HAVE FUN IN OREGON. GOT THE WELDING CABLE YOU SUGGESTED. MY IN-LAWS OWN A SCRAP YARD AND AHD A LOT LAYING AROUND, HOWEVER, SINCE THEY LOOK FORWARD TO RIDING IN THE PLANE IN THE FUTURE THEY ORDERED ME 80 FEET AT .60 CENTS A FOOT. SO I TOOK THEM UP ON THAT ONE. KNOWING THAT IT WILL BE BETWEEN 6-9 MONTHS BEFORE I TEST FLY THE PLANE, CAN I GET THE BATTERIES NOW SO I CAN MAKE THE APPROPRIATE MOUNTS? REGARDS, ED SILVANIC ________________________________________________________________________________
Date: Oct 11, 2002
FYI, in case anybody is interested in more info on the XPAK 904, I documented it pretty extensively on the RV-List a couple years ago. Search for "Cometflash on a beer budget". I'm not flying it yet but a friend of mine with an RV-8 is using the same unit, and at the airport the other evening I saw it in operation....and it's VERY BRIGHT. We are using Whelen strobe heads by the way...most strobe heads including Aeroflash cannot handle the 40 joules per head that this unit can put out. My friend is firing only two wingtip strobes, I will be running a tail strobe as well...the unit can fire four strobe heads so it will cover any configuration you want on an airplane... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Strobes > >There are certainly much cheaper power supplies that you can use with the >aeroflash or whelen strobe tubes if you don't want to build a custom >mount. I chose to use the Nova Electronics XPAK 904 - this is one of the >links Bob posted: >http://www.strobe.com/products/xpak.htm > >The 904 has bascially the same specs as the whelen cometflash 413 that >drives three strobe heads. I purchased my 904 from >http://www.strobesnmore.com for $159 dollars compared to $350+ for the >whelen unit. There's detailed information in the RV-List archives, just >search on XPAK. I hooked it up to my Whelen lighting units and they're >extremely bright! It exceeds the 20 Joules per flash requirment that Bob >mentions. Good data points! Thank you. Bob . . . ________________________________________________________________________________
Date: Oct 11, 2002
Just curious, why would you want all the fuel pumps on the battery bus? Is this Seawind set up such that an electric boost pump or primary pump are required at all times due to the high engine location? Will the engine-driven pump not be adequate to keep it running without the elec pumps? I can understand the desire for something like the bilge pump to be on a battery bus, and possibly the transfer pumps (if needed for refueling?), but otherwise wouldn't it be ok to put elec boost pumps on the Ess or Aux busses? I'm planning to have my Lightspeed ignition system running off my battery bus, but my elec boost pump will be on the Ess bus unless there's a compelling reason I'm missing why it should be on my battery bus (RV-8A). --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Seawind - Rudimenary system planning > >Bob, I made a list and tried to break it down as to what goes where. Here it >is: snip >Fuel boast pump, Right & Left fuel transfer pump, Bilge pump I think I'd put all of these on one of the battery busses. >Primary fuel pump, Battery bus ________________________________________________________________________________
Date: Oct 11, 2002
AeroElectric List
Subject: Vacuum Pump Removal
Try any Lycoming parts house. Cover is Lycoming Part # 60430. Gasket is Lycoming Part # 8313 Charlie RV-6A N11CB (Res) San Antonio ----------------------------------- > From: > Subject: AeroElectric-List: Vaccum Pump Removal > > > Since I am using the all-electric approach to building I plan to remove and > sell my vaccum pump. I have an O-235 N2C engine. I will need to install a > cover plate and gasket on the accessory pad in place of the vaccum pump. > Does anyone know where I can buy one already made? I haven't seen anything > in my regular catalogues. I really don't want to make a plate for this. > The engine and everything on it is still "certified" - so far. > Thanks for any help. > Ernest Kells - RV-9A O235-N2C, Wood Prop > Finish Kit 70% Complete > > ________________________________________________________________________________
Date: Oct 11, 2002
AeroElectric List
Just reread your message and saw where you specified an 0235 engine. The info I sent was for an 0-320. They may be the same, but you had better check. My apologies. Charlie RV-6A N11CB (Res) San Antonio ----------------------------------------- > Try any Lycoming parts house. Cover is Lycoming Part # 60430. Gasket is Lycoming Part # 8313 > > Charlie > RV-6A N11CB (Res) > San Antonio > > ----------------------------------- > > > From: > Subject: AeroElectric-List: Vaccum Pump Removal > > > Since I am using the all-electric approach to building I plan to remove and > sell my vaccum pump. I have an O-235 N2C engine. I will need to install a > cover plate and gasket on the accessory pad in place of the vaccum pump. > Does anyone know where I can buy one already made? I haven't seen anything > in my regular catalogues. I really don't want to make a plate for this. > The engine and everything on it is still "certified" - so far. > Thanks for any help. > Ernest Kells - RV-9A O235-N2C, Wood Prop > Finish Kit 70% Complete > > ________________________________________________________________________________
Subject: Battery contactor running temperature
Date: Oct 11, 2002
Hi Bob, I know you're away. This can wait till you get back if no one else chimes in... I was running a few tests this evening, and had the master on for maybe 10 minutes max. A few minutes later I climbed in the back to attach yet another wire and noticed that the battery contactor was hot. Hot enough that I wouldnt want to keep my hand on it for more than a few seconds. Is this normal? John Slade ________________________________________________________________________________
Date: Oct 12, 2002
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Battery contactor running temperature
John Slade wrote: > > > Hi Bob, > I know you're away. This can wait till you get back if no one else chimes > in... > > I was running a few tests this evening, and had the master on for maybe 10 > minutes max. A few minutes later I climbed in the back to attach yet another > wire and noticed that the battery contactor was hot. Hot enough that I > wouldnt want to keep my hand on it for more than a few seconds. Is this > normal? > John Slade > A battery contactor draws in the neighbourhood of one amp. This on a nominal 12 volt system represents approximately 12 watts of power being dissipated by the contactor windings. If you imagine holding onto a 12 watt light bulb while it is illuminated you will realize that yes this represents quite a bit of heat and is therefore normal. -- Bob McC ________________________________________________________________________________
Subject: Wiring Diagram NAT model AA80 intercom
Date: Oct 12, 2002
ANYONE HAVE A WIRING DIAGRAHM FOR A NORTHERN AIRBORNE TECHNOLOGY (NAT) INTERCOM MODEL 80? I COULD SURE USE ONE. TRYING TO HOOK UP A PTT AND HAVING TROUBLE. THANKS, NED ________________________________________________________________________________
Subject: Instrument holes?
Date: Oct 12, 2002
Hello, Could anybody tell me what's the center-to-center distance for the mounting holes for a standard 2.25" instrument? I need to fabricate a blanking plate, and would prefer not to drive to the airport today to measure :). Thanks in advance, - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 12, 2002
From: TSaccio(at)aol.com Date: Thu, 10 Oct 2002 23:36:30 EDT Subject: Re: AeroElectric-List: Re: Seawind - Rudimenary system planning Hi Bob, Took your advice and reworked my system. Tell me what you think. Main Battery Bus Fuel boast pump, Right & left fuel transfer pump, Bilge pump, Hobbs meter, Primary fuel pump Aux Battery Bus Clock and timer, Electronic ignition system. Not sure what else to add to this bus. Main Power Dist. Bus Taxi lights, Strobe, Landing lights, Position lights, Panel lights, Over head lights, Auto pilot, Pitot heat, Cooling fan, Stall warning, Flaps, Hydrolic pressure gauge, Landing gear, Attitude indicator Aux Power Dist. Bus HSI, Electric trim (ailerons, rudder, Stablizer), Turn and slip indicator, Directional gyro, GPS (full IFR UPS stack), Nav Com, Transponder, Audio panel, Goose neck light, Amp and Volt meter, Annunciator light, Quad fuel gauges, VM 1000 When you told me how to make the list you said to do Main Battery Bus #1 Ignition 3A Hobbs 1A Am I correct in assuming that 3A is the amps that the ignition draws? I'm not sure what the #1 means. Could you please explain? Tom Hi Bob, Took your advice and reworked my system. Tell me what you think. Main Battery Bus Fuel boast pump, Right left fuel transfer pump, Bilge pump, Hobbs meter, Primary fuel pump Aux Battery Bus Clock and timer, Electronic ignition system. Not sure what else to add to this bus. Main Power Dist. Bus Taxi lights, Strobe, Landing lights, Position lights, Panel lights, Over head lights, Auto pilot, Pitot heat, Cooling fan, Stall warning, Flaps, Hydrolic pressure gauge, Landing gear, Attitude indicator Aux Power Dist. Bus HSI, Electric trim (ailerons, rudder, Stablizer), Turn and slip indicator, Directional gyro, GPS (full IFR UPS stack), Nav Com, Transponder, Audio panel, Goose neck light, Amp and Volt meter, Annunciator light, Quad fuel gauges, VM 1000 When you told me how to make the list you said to do Main Battery Bus #1 Ignition 3A Hobbs 1A Am I correct in assuming that 3A is the amps that the ignition draws? I'm not sure what the #1 means. Could you please explain? Tom ________________________________________________________________________________
Subject: Heatshrink
Date: Oct 12, 2002
Bob - I bought a grounding cable from your website a couple weeks ago - the one for the engine-to-firewall connection. The ends have some heavy-duty looking heat shrink on them. I'm thinking of using the same thing elsewhere under the cowl. What are the specs of the heatshrink you used, and where can I get some more? Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Subject: Re: Instrument holes?
Date: Oct 12, 2002
Jerry, A 2.25" instrument uses a 2.3125 hole with screw holes 2.625" CTC (.169 drill Diameter). Info is from a Aircraft Spruce catalog. Dave. ----- Original Message ----- From: Jerry Kaidor To: Aeroelectric-List(at)matronics.com Sent: Saturday, October 12, 2002 5:54 PM Subject: AeroElectric-List: Instrument holes? Hello, Could anybody tell me what's the center-to-center distance for the mounting holes for a standard 2.25" instrument? I need to fabricate a blanking plate, and would prefer not to drive to the airport today to measure :). Thanks in advance, - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 13, 2002
Subject: Internally Regulated Alternator Adjustment?
How does one accomplish an "adjustment" of the output voltage of an internally regulated alternator? I fly a homebuilt (I'm not the original builder) that uses an internally regulated Hitachi alternator on a Lycoming. The alternator raises the battery buss to a value between between 14.9 and 15.1 when the engine runs. I'd like to replace the conventional lead-acid battery with a "gel cell" someday and know this is too high (for either type of battery). Thanks, Joe Clarkston, WA ________________________________________________________________________________
Subject: Microair T2000 Transponder
Date: Oct 13, 2002
Hi, Bob! Can you tell me the status of my T2000 order? If you no longer have them available, just say so and I'll go through the Microair website. You were also going to include the encoder, antenna and harness, but that may have fallen through as well. Awaiting your reply off-line. Thanks. Ken Brooks RV-8 Roscoe, IL ________________________________________________________________________________
Subject: For Steve Sampson
Date: Oct 13, 2002
Steve, When I used the 'reply' function to answer your diesel queries, I got the following; " ----- The following addresses had permanent fatal errors ----- SSampson.SLN21(at)london.edu (expanded from: ) ----- Transcript of session follows ----- 550 SSampson.SLN21(at)london.edu... User unknown 550 ... User unknown" So call me again with a suitable return address and will email my earlier reply. Cheers, Ferg ________________________________________________________________________________
From: "Kurt A. Schumacher" <Kurt.Schumacher(at)schumi.ch>
Date: Oct 13, 2002
Ken, I am convinced Microair does the best to fulfill all orders as they got them in. There is a _huge_ demand on the market for the Microair products, Bob will deliver as soon as he will receive your T2000 from Australia. Anybody planning to install Microair products should be advised to order early enough. Microair will no longer deliver direct to end users. -Kurt. Sport Aviation LLC Microair Dealer for Switzerland http://www.sportaviation.ch Webmaster EAS - Experimental Aviation of Switzerland http://www.experimental.ch -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Brooks Subject: AeroElectric-List: Microair T2000 Transponder --> Hi, Bob! Can you tell me the status of my T2000 order? If you no longer have them available, just say so and I'll go through the Microair website. You were also going to include the encoder, antenna and harness, but that may have fallen through as well. Await Ken Brooks RV-8 Roscoe, IL = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 13, 2002
3 weeks ago I called American Avionics in Seattle and they had them in stock. Got it next day. Dave -----Original Message----- From: Kurt A. Schumacher [mailto:Kurt.Schumacher(at)schumi.ch] Subject: RE: AeroElectric-List: Microair T2000 Transponder Ken, I am convinced Microair does the best to fulfill all orders as they got them in. There is a _huge_ demand on the market for the Microair products, Bob will deliver as soon as he will receive your T2000 from Australia. Anybody planning to install Microair products should be advised to order early enough. Microair will no longer deliver direct to end users. -Kurt. Sport Aviation LLC Microair Dealer for Switzerland http://www.sportaviation.ch Webmaster EAS - Experimental Aviation of Switzerland http://www.experimental.ch -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Brooks Subject: AeroElectric-List: Microair T2000 Transponder --> Hi, Bob! Can you tell me the status of my T2000 order? If you no longer have them available, just say so and I'll go through the Microair website. You were also going to include the encoder, antenna and harness, but that may have fallen through as well. Await Ken Brooks RV-8 Roscoe, IL = = = http://www.matronics.com/browselist/aeroelectric-list = http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 13, 2002
Subject: Re: Internally Regulated Alternator
Adjustment? Joe, Unfortunately, the only "adjustment" you can make is to disassemble the alternator and replace that voltage regulator Charlie Kuss > >How does one accomplish an "adjustment" of the output voltage of an >internally regulated alternator? > >I fly a homebuilt (I'm not the original builder) that uses an internally >regulated Hitachi alternator on a Lycoming. The alternator raises the >battery buss to a value between between 14.9 and 15.1 when the engine >runs. I'd like to replace the conventional lead-acid battery with a >"gel cell" someday and know this is too high (for either type of battery). > >Thanks, >Joe >Clarkston, WA > > ________________________________________________________________________________
Date: Oct 13, 2002
Subject: Re: Wiring Diagram NAT model AA80 intercom
> >ANYONE HAVE A WIRING DIAGRAHM FOR A NORTHERN AIRBORNE TECHNOLOGY (NAT) >INTERCOM MODEL 80? > >I COULD SURE USE ONE. TRYING TO HOOK UP A PTT AND HAVING TROUBLE. > >THANKS, >NED I have the installation manual which includes the following models. aa80-001, aa80-020, aa80-060. aa80-062 I can scan it and send it to you if you want it. Jim Pollard Merlin Ont zodiac 601hds ea81 ________________________________________________________________________________
Subject: Spade connectors
Date: Oct 13, 2002
Hi AeroElectric Listers, I am brand new to this list, I hope I am not asking a newbie question that averyone is tired of hearing. I am looking very seriously at using Subaru power for my RV-7 from Eggenfellner Aircraft. They recommend using the EXBUS from control vision. The EXBUS uses automotive type spade connectors and the installation manual for the Eggennfellner package shows them being used in many places. All of the certified aircrarft that I have been involved with used ring terminals with lock wahers and a screw to hold connections together. So my question is this. Are the spade connectors really OK for airplanes? Would you consider using them on an airplane that requires electricity to keep it's engine running? Maybe there are poor quality spade connectors that give them a bad reputation but the ones people put in their experimental airplanes are of much better quality? I appreciate any opinions on this. Randy ________________________________________________________________________________
Date: Oct 13, 2002
In an old Aircraft Spruce catalog shows that the holes are centered on a 2 and 5/8" diameter circle 45 degrees off the vertical. Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com We support Aeroncas ----- Original Message ----- From: "Jerry Kaidor" <jerry(at)tr2.com> Subject: AeroElectric-List: Instrument holes? > > Hello, > > Could anybody tell me what's the center-to-center distance for the > mounting holes for a standard 2.25" instrument? I need to fabricate a > blanking plate, and would prefer not to drive to the airport today to > measure :). > > Thanks in advance, > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 13, 2002
Subject: NAVAID & PTT Diode
Hello friends, For those of you using a Navaid Devices autopilot with a VFR panel (no VOR and only 1 VHF), do you (or should I) connect the optional diode to the PTT switch? I'll be using an Apollo SL-40 COM. Thanks! Michel ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 13, 2002
Subject: Re: Spade connectors
Check Bob's answer at: http://www.aeroelectric.com/articles/faston3.pdf. And the answer is yes. Roger ----- Original Message ----- From: "Randy Crothers" <rnvcrothers(at)attbi.com> Subject: AeroElectric-List: Spade connectors > > Hi AeroElectric Listers, > I am brand new to this list, I hope I am not asking a newbie question > that averyone is tired of hearing. > I am looking very seriously at using Subaru power for my RV-7 from > Eggenfellner Aircraft. They recommend using the EXBUS from control vision. > The EXBUS uses automotive type spade connectors and the installation manual > for the Eggennfellner package shows them being used in many places. > All of the certified aircrarft that I have been involved with used ring > terminals with lock wahers and a screw to hold connections together. So my > question is this. Are the spade connectors really OK for airplanes? Would > you consider using them on an airplane that requires electricity to keep > it's engine running? > Maybe there are poor quality spade connectors that give them a bad > reputation but the ones people put in their experimental airplanes are of > much better quality? > I appreciate any opinions on this. > Randy > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 13, 2002
Thanks Cy! And Ken. And Dave. I did look in the Aircraft Spruce catalog before asking, but now they only have a three-inch kind. I guess they decided it was more beneficial to spend their paper on stuff to sell, rather than on free engineering info. I can't say I blame them - that catalog must cost a MINT to put out. I needed it to make a mounting plate for the remote control for my new ACK ELT - made necessary because the existing ELT in my Sundowner is obsolete, and even its battery is obsolete. In fact, the battery that replaced the original obsolete battery is now obsolete! Since the ELT cannot legally be re-batteried, it must be replaced. Luckily, it's annual time, and almost enough stuff to route the cable needs to come apart anyway. I figured that it would be best to mount the remote control panel in an instrument hole, so as not to bugger up the instrument panel, or ( horror! ) hang the thing on a bracket below. Again, thank you all for the information! - Jerry Kaidor ( jerry(at)tr2.com ) ----- Original Message ----- From: "Cy Galley" <cgalley(at)qcbc.org> Subject: Re: AeroElectric-List: Instrument holes? > > In an old Aircraft Spruce catalog shows that the holes are centered on a 2 > and 5/8" diameter circle 45 degrees off the vertical. > > Cy Galley - Bellanca Champion Club > Newsletter Editor & EAA TC > www.bellanca-championclub.com > We support Aeroncas > > ----- Original Message ----- > From: "Jerry Kaidor" <jerry(at)tr2.com> > To: > Subject: AeroElectric-List: Instrument holes? > > > > > > Hello, > > > > Could anybody tell me what's the center-to-center distance for the > > mounting holes for a standard 2.25" instrument? I need to fabricate a > > blanking plate, and would prefer not to drive to the airport today to > > measure :). > > > > Thanks in advance, > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: Ennuciator
For those of you who asked me about the info for the roll your own ennunciator-- For the engraving: Guillermo Valledor 305-821-3424 valgreencopr.msn.com For the lights:( fiber oprtic ribbon) Ken Whitaker 562-776-9494 fiberlite(at)email.msn for the board Wayne Lanza 561-664-8953 wlanza(at)iu.net Peter Laurence ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: NAVAID & PTT Diode
> > >Hello friends, > >For those of you using a Navaid Devices autopilot with >a VFR panel (no VOR and only 1 VHF), do you (or should >I) connect the optional diode to the PTT switch? > >I'll be using an Apollo SL-40 COM. I'm mystified as to what the Navaid has to do with any wiring to the PTT switch. On who's drawing is the diode mentioned and what notes support the option decision? Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
> >ANYONE HAVE A WIRING DIAGRAHM FOR A NORTHERN AIRBORNE TECHNOLOGY (NAT) >INTERCOM MODEL 80? > >I COULD SURE USE ONE. TRYING TO HOOK UP A PTT AND HAVING TROUBLE. > >THANKS, >NED Here's a copy of the pinout data I have http://www.aeroelectric.com/temp/NAT80.pdf Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: Heatshrink
> >Bob - > >I bought a grounding cable from your website a couple weeks ago - the >one for the engine-to-firewall connection. The ends have some >heavy-duty looking heat shrink on them. I'm thinking of using the same >thing elsewhere under the cowl. What are the specs of the heatshrink >you used, and where can I get some more? Call Todd at B&C and see if he can fix you up. The internal melting wall heat shrink is described at http://www.alphawire.com/pages/125.cfm Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - USING LEDS
Date: Oct 15, 2002
Folks, I am looking at using a couple of LEDs to indicate things like fuel pump on, pitot heat on, maybe low fuel or oil pressure. Most LEDs seem to like 2-5volts. So how do I provide that voltage electrically - a step down device to a 5v mini bus? In line resisters to each? I cant see any advice in the AeroElectric Connection on these aspects. Appreciate any help David Francis, VH-ZEE Email: David.Francis(at)defence.gov.au ________________________________________________________________________________
Date: Oct 14, 2002
"Robert L. Nuckolls, III" wrote: > > > > > > > >Hello friends, > > > >For those of you using a Navaid Devices autopilot with > >a VFR panel (no VOR and only 1 VHF), do you (or should > >I) connect the optional diode to the PTT switch? > > > >I'll be using an Apollo SL-40 COM. > > I'm mystified as to what the Navaid has to do > with any wiring to the PTT switch. On who's > drawing is the diode mentioned and what notes > support the option decision? > > Bob . . . Bob, the diode is intended to momentarily disconnect the servo from the control head (I don't recall if it interrupts power or signal) when the PTT is activated. Apparently there have been some cases where RFI or something upset the servo during radio transmissions. The diode is shown on Navaid's installation diagrams. I included the diode in my Navaid installation even though I have no idea if it is necessary. The only downside of it is when I have allowed the plane to get significantly out of trim due to fuel imbalance; a slight roll will occur when the PTT is used. Sam Buchanan (RV-6, 425 hrs with Navaid) "The RV Journal" http://thervjournal.com ________________________________________________________________________________
Date: Oct 14, 2002
Per the Navaid installation instructions, the diode in series with the PTT switch disengages the Navaid servo when transmitting. I did not do this in my installation and have found this is a problem. Hitting the PTT causes a very pronounce stick bump. I will be putting in this mod the next time I pull the panel. Other than this the Navaid works as advertised. Program the track into the GX-60, turn it on away you go. Carl Froehlich RV-8A (40 hour fly off completed today) Vienna, VA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: NAVAID & PTT Diode > > >Hello friends, > >For those of you using a Navaid Devices autopilot with >a VFR panel (no VOR and only 1 VHF), do you (or should >I) connect the optional diode to the PTT switch? > >I'll be using an Apollo SL-40 COM. I'm mystified as to what the Navaid has to do with any wiring to the PTT switch. On who's drawing is the diode mentioned and what notes support the option decision? Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: Re: Remote Compressor Switch
Date: Oct 14, 2002
This question is a little on the heavy duty side but I suspect someone will know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the garage separate from my shop space. I want to switch it on and off remotely. I ran door bell wire through conduit ahead of time anticipating doing this. Here is what I think I need. Probably a transformer like a door bell uses. A low voltage switch to activate on the remote end. A solenoid activated contactor to handle the above specified load. I tried to find what I needed at Home Depot but no luck. Is this kind of switching only available from industrial type outlets? Am I on the right track here? Thanks for any help, Randy ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: USING LEDS
> > >Folks, >I am looking at using a couple of LEDs to indicate things like fuel pump on, >pitot heat on, maybe low fuel or oil pressure. Most LEDs seem to like >2-5volts. So how do I provide that voltage electrically - a step down device >to a 5v mini bus? In line resisters to each? Red LEDs are about 2v, Whites are almost 4v with other colors in that range. All can be operated with a simple resistor in series to set rated operating current for operation at any voltage greater than the minimum required for the device. See http://www.aeroelectric.com/articles/leds3.pdf Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: Internally Regulated Alternator Adjustment?
> >How does one accomplish an "adjustment" of the output voltage of an >internally regulated alternator? > >I fly a homebuilt (I'm not the original builder) that uses an internally >regulated Hitachi alternator on a Lycoming. The alternator raises the >battery buss to a value between between 14.9 and 15.1 when the engine >runs. I'd like to replace the conventional lead-acid battery with a >"gel cell" someday and know this is too high (for either type of battery). You sure you really want to put a gel-cell battery in your airplane? They're getting pretty rare and don't perform nearly as well as either the flooded or RG (recombinant-gas) batteries. See: http://www.aeroelectric.com/articles/rg_bat.html and http://www.aeroelectric.com/articles/battery.pdf the only fix for the too-high output voltage is to replace the alternator's built-in regulator. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 14, 2002
Sam - I believe that some of the problem here is that "PTT" has taken on too many meanings to be of use as an acronym - at least on this list. One is: Push-To-Talk. Another is: Push-To-Test, and yours is "Push-To-disconnecT. Maybe someone on the list can can come up with a more descriptive acronym for your situation. Mine is "APED": Auto Pilot Emergency Disconnect Cheers, John Schroeder Sam Buchanan wrote: > > > > >For those of you using a Navaid Devices autopilot with > > >a VFR panel (no VOR and only 1 VHF), do you (or should > > >I) connect the optional diode to the PTT switch? > > > ________________________________________________________________________________
Date: Oct 14, 2002
> >Hi Bob, Took your advice and reworked my system. Tell me what you think. > >MAIN BATTERY BUS >Fuel boast pump >Right Fuel transfer pump, >Left Fuel transfer pump >Bilge pump >Hobbs meter, >Primary fuel pump Keep the listing one line per powered device . . we'll add protection sizes to each item later A total of 4 electric fuel pumps? How are they interconnected and how are they used? >AUX BATTERY BUS >Clock and timer >Electronic ignition system. I take it you're planning a single electronic ignition? >MAIN POWER DISTRIBUTION BUS >Taxi lights >Strobe >Landing lights >Position lights >Panel lights >Over head lights Would this be used as a nighttime courtesy light? Maybe it would work better on one of the battery busses so it could be used with the master switches off. > >Auto pilot >Pitot heat >Cooling fan . . . for radios? If so probably should be on same bus as radios. >Stall warning I'd run this from a battery bus >Flaps >Hydrolic pressure gauge Is this an electrically powered instrument? >Landing gear Hydraulic pump? Probably run this right from the main battery contactor through its own ANL current limiter. > Attitude indicator >AUX POWER DISTRIBUTION BUS >HSI >Roll trim >Yaw trim >Pitch Trim >Turn and slip indicator, >Directional gyro A DG in addition to the HSI? >GPS >Nav Com >Transponder >Audio panel >Goose neck light Move this to a battery bus >Volt meter With switch to monitor either bus and either battery >Loadmeter With switch to monitor either alternator. What kind of ammetere would you use here? Does it take 14 VDC to operate? >Annunciator light What gets annunicated? >Quad fuel gauges >VM 1000 The VM1000 has voltmeter/loadmeter capabilities. You may not need the loadmeter and voltmeter cited above. >When you told me how to make the list you said to do >Main Battery Bus >#1 Ignition 3A >Hobbs 1A > >Am I correct in assuming that 3A is the amps that the ignition draws? I'm not >sure what the #1 means. Could you please explain? No, size of the fuse/breaker that will protect the circuit. We're working toward building your first drawing which is the power distribution diagram. Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: pin-out for a king KX-150 VHF
> > >Hello, > >I am looking for the pin out for a bendix/king kx-150 VHF, the lighting is >not working and i suspect it is in the a/c wiring. Sorry, that's not included in my library of drawings. can anyone else help out? Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
Subject: Re: ARC connectors
> > >Where can I get crimp connectors for an ARC 459A transponder plug. >Ted I don't know what style connector that is. Can you e-mail me a photograph? Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 14, 2002
> >BOB: > > HOPE YOU HAVE FUN IN OREGON. GOT THE WELDING CABLE YOU SUGGESTED. MY >IN-LAWS OWN A SCRAP YARD AND AHD A LOT LAYING AROUND, HOWEVER, SINCE THEY >LOOK FORWARD TO RIDING IN THE PLANE IN THE FUTURE THEY ORDERED ME 80 FEET AT >.60 CENTS A FOOT. SO I TOOK THEM UP ON THAT ONE. KNOWING THAT IT WILL BE >BETWEEN 6-9 MONTHS BEFORE I TEST FLY THE PLANE, CAN I GET THE BATTERIES NOW >SO I CAN MAKE THE APPROPRIATE MOUNTS? I wouldn't buy a battery until the day before first flight. Make the trays using dimensions off the batteries. Which batteries are you planning on using? Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
> > >"Robert L. Nuckolls, III" wrote: > > > > > > > > > > > > > > >Hello friends, > > > > > >For those of you using a Navaid Devices autopilot with > > >a VFR panel (no VOR and only 1 VHF), do you (or should > > >I) connect the optional diode to the PTT switch? > > > > > >I'll be using an Apollo SL-40 COM. > > > > I'm mystified as to what the Navaid has to do > > with any wiring to the PTT switch. On who's > > drawing is the diode mentioned and what notes > > support the option decision? > > > > Bob . . . > > >Bob, the diode is intended to momentarily disconnect the servo from the >control head (I don't recall if it interrupts power or signal) when the >PTT is activated. Apparently there have been some cases where RFI or >something upset the servo during radio transmissions. The diode is shown >on Navaid's installation diagrams. > >I included the diode in my Navaid installation even though I have no >idea if it is necessary. The only downside of it is when I have allowed >the plane to get significantly out of trim due to fuel imbalance; a >slight roll will occur when the PTT is used. Interesting! If you can't live with the stress, just shut it off during stress . . . I'm not sure I'd take that approach to solving an RF interference problem but I guess it would work. Bob . . . ________________________________________________________________________________
Date: Oct 14, 2002
> > >This question is a little on the heavy duty side but I suspect someone will >know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the garage >separate from my shop space. I want to switch it on and off remotely. I ran >door bell wire through conduit ahead of time anticipating doing this. > >Here is what I think I need. Probably a transformer like a door bell uses. A >low voltage switch to activate on the remote end. A solenoid activated >contactor to handle the above specified load. I tried to find what I needed >at Home Depot but no luck. Is this kind of switching only available from >industrial type outlets? Am I on the right track here? > >Thanks for any help, >Randy Look up motor starter or contactor on ebay. They are often rated in hp but sometimes in amps. The rating given for the controlling switch part is the "coil voltage". You need one with at least 2 poles for 220 volts so you can switch both wires at the same time. If you get one with 110 or 220 volt coil you will not need a transformer. Make sure your bell wire is rated for that if you do. A in line fuse(S) to protect the wire to your switch would be good also for the higher volt control would be good too. A transformer should be on the same circuit as the compressor is. That way if you shut the breaker off the transformer is off. Or put one of those pieces that lock the separate breakers together in the breaker panel box. Jim Pollard Merlin Ont ch601hds ea81 ________________________________________________________________________________
Subject: Bench PS
Date: Oct 14, 2002
Bob - A couple months ago you recommended a power supply that was on sale at Radio Shack. I got one. It's working great the little I've used it so far. I bet you have a similar device, and a cleaver setup for the wire/probes/clips coming out the back for + and -. I could reinvent the wheel, or just ask for a description of yours. Thanks. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 14, 2002
Bob: I believe you recommended two 17 amp RG batteries? As a recap, I am building the Lancair ES, all electric panel. I will have an IO-520 "D" engine. Engine gauges will be EI, Electronics International, Avionics will be a Garmin Stack--Garman-340 AUD/COM, GNS-530, GNS-430, GTX-327 TRANSPONDER. TruTrak 2 axis A/P. As I have mentioned to you before, I was interested in the BMA EFIS/ONE. Could not get any positive response, however, I am beginning to hear good things about the EFIS/Lite inwhich some folks are using as their Primary PFD. In fact one person has installed it in a YAK doing acro! and loves it. It certainly would look better proportioned using this. It would allow for the standard 3 1/8 instruments to surround it as backup, just like the Airbus I fly. I have written BMA for the dimensions to see how the panel will lay out. What do you think? I will have a list of possible switches for you soon. I am following your conversation about the Seawind build up. Thanks. By the way I have found two electric gyros. Made in 1987, and have been yellow tagged, whatever that means. $600.00 for one $1,000.00 for two, which would fulfill my primary, stby system should the BMA not become a good course of action. What do you think? Regards, Ed Silvanic N823MS ________________________________________________________________________________
Date: Oct 14, 2002
> Unfortunately, the only "adjustment" you can make is to disassemble > the alternator and replace that voltage regulator That's not the answer I wanted to hear, Charlie . Is it possible I've overlooked something in the hookup of the alternator? Other than a "B" lead and ground, it has only two other terminals: "S" and "L". The original builder connected battery voltage (through the alternator switch and "field" CB) to the "S" terminal but the alternator would not start up until engine RPM exceeded 2400 (apparently no field excitation; only residual magnetism). A local automotive electrical shop suggested that the "L" terminal was used for startup by supplying its current through the dashboard's alternator warning light. So I moved the lead from the "S" terminal to the "L" terminal (after inserting a 20-ohm series resistor) and now it starts right up. But could a battery voltage connection to the "S" terminal still be needed? Perhaps with no connection it floats, hence the 15-volts of output. Another thought is to try a well-heatsunk, heavy-duty silicon diode in series with the alternator's "B" lead to drop about 1 volt. Any thoughts on that approach if "Plan A" above doesn't work? -- Joe > From: Charlie Kuss <chaskuss(at)bellsouth.net> > Subject: Re: AeroElectric-List: Internally Regulated Alternator > Adjustment? > > > Joe, > Unfortunately, the only "adjustment" you can make is to disassemble the alternator and replace that voltage regulator > Charlie Kuss > > >> >>How does one accomplish an "adjustment" of the output voltage of an >>internally regulated alternator? >> >>I fly a homebuilt (I'm not the original builder) that uses an internally >>regulated Hitachi alternator on a Lycoming. The alternator raises the >>battery buss to a value between between 14.9 and 15.1 when the engine >>runs. I'd like to replace the conventional lead-acid battery with a >>"gel cell" someday and know this is too high (for either type of battery). >> >>Thanks, >>Joe >>Clarkston, WA ________________________________________________________________________________
Date: Oct 14, 2002
Randy, You don't even need the doorbell wire. I have my compressor mounted in one end of my house, in the shop, and can control it from there, the door to the shop, my garage at the other end of the house or my master bedroom (for when I'm lying in bed and realize I forgot to turn it off). What you need is any X-10 control switch (one or more) and an x-10 220v appliance module. I originally bought mine at www.smarthome.com. Working great for 4 years now. No wires, the switch just sends a code down the ac line in the house and the module picks it up and turns on or off as sent. If you have more questions, let me know. Russ Werner HR II Maui ----- Original Message ----- From: "Randy Crothers" <rnvcrothers(at)attbi.com> Subject: AeroElectric-List: Re: Remote Compressor Switch > > This question is a little on the heavy duty side but I suspect someone will > know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the garage > separate from my shop space. I want to switch it on and off remotely. I ran > door bell wire through conduit ahead of time anticipating doing this. > > Here is what I think I need. Probably a transformer like a door bell uses. A > low voltage switch to activate on the remote end. A solenoid activated > contactor to handle the above specified load. I tried to find what I needed > at Home Depot but no luck. Is this kind of switching only available from > industrial type outlets? Am I on the right track here? > > Thanks for any help, > Randy > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 14, 2002
Thanks Jim, that really helps get me pointed in the right direction. Randy ----- Original Message ----- From: "Jim and Lucy" <jpollard(at)mnsi.net> Subject: Re: AeroElectric-List: Re: Remote Compressor Switch > > > > > > >This question is a little on the heavy duty side but I suspect someone will > >know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the garage > >separate from my shop space. I want to switch it on and off remotely. I ran > >door bell wire through conduit ahead of time anticipating doing this. > > > >Here is what I think I need. Probably a transformer like a door bell uses. A > >low voltage switch to activate on the remote end. A solenoid activated > >contactor to handle the above specified load. I tried to find what I needed > >at Home Depot but no luck. Is this kind of switching only available from > >industrial type outlets? Am I on the right track here? > > > >Thanks for any help, > >Randy > > > Look up motor starter or contactor on ebay. They are often rated in hp but > sometimes > in amps. The rating given for the controlling switch part is the "coil > voltage". You need one > with at least 2 poles for 220 volts so you can switch both wires at the > same time. > If you get one with 110 or 220 volt coil you will not need a transformer. > Make sure > your bell wire is rated for that if you do. A in line fuse(S) to protect > the wire to your > switch would be good also for the higher volt control would be good too. > A transformer should be on the same circuit as the compressor is. That way > if you shut the breaker off the transformer is off. Or put one of those pieces > that lock the separate breakers together in the breaker panel box. > > Jim Pollard > Merlin Ont > ch601hds > ea81 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Date: Oct 15, 2002
Hello Ed, > the BMA EFIS/ONE. Could not get any positive response, however, I am > beginning to hear good things about the EFIS/Lite inwhich some folks are > using as their Primary PFD. In fact one person has installed it in a YAK We had some messages about two month ago, where a user reported, that in a standard rate turn, after 270 deg the gyro just got off the trak, I'm not sure they fixed their problem, but it seems then it was not reliable enough for IFR > found two electric gyros. Made in 1987, and have been yellow tagged, whatever > that means. $600.00 for one $1,000.00 for two, which would fulfill my I have currently a similar thing a RC Allen gyro for 600$, I let it check with an instrument shop, it starts very late (13V), noisy bearings and after removing power stops immediately. They recommend a reconditoning (~700$) which makes it still cheaper then a new one. Kind regards Werner ________________________________________________________________________________
Date: Oct 15, 2002
This could be as complex as building a small power supply using a 7805 voltage regulator, or the simpler way is to just properly size a series resistor. I'm sure Bob has some info somewhere on this subject. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Francis, CMDR David Subject: AeroElectric-List: SEC: UNCLASSIFIED - USING LEDS Folks, I am looking at using a couple of LEDs to indicate things like fuel pump on, pitot heat on, maybe low fuel or oil pressure. Most LEDs seem to like 2-5volts. So how do I provide that voltage electrically - a step down device to a 5v mini bus? In line resisters to each? I cant see any advice in the AeroElectric Connection on these aspects. Appreciate any help David Francis, VH-ZEE Email: David.Francis(at)defence.gov.au = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 15, 2002
You just need a size1 motor starter. Siemens, Allen-Bradley, etc, all make these, and they are used routinely in factories. They have overloads on them to protect the motor in case of overcurrent or single phase, and they have a coil (usually 110vac) that can be controlled remotely like you mention. Bad thing is that they are usually about 150-200 bucks, so I don't know if that is worthwhile to you. If you didn't want the overload protection, you could accomplish the same thing with individual solenoids or relays like we use in our planes, operated by 12vdc. This would work, but require a transformer. There is another methold, although I don't condone it, but I have seen it done more than once in my plant (unfortunately). You can also use a simple light switch (DPST) and run 2 of the three phases through the remote mounted light switch to turn it on and off. One leg will always be hot to the motor, but this will not hurt it, just makes it an electrical hazard if you have to work on it. Again, I don't condone it, but it will work, and will definitely be the cheapest method. May I ask why you want it remote controlled? Maybe there is a simpler solution. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Randy Crothers Subject: AeroElectric-List: Re: Remote Compressor Switch This question is a little on the heavy duty side but I suspect someone will know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the garage separate from my shop space. I want to switch it on and off remotely. I ran door bell wire through conduit ahead of time anticipating doing this. Here is what I think I need. Probably a transformer like a door bell uses. A low voltage switch to activate on the remote end. A solenoid activated contactor to handle the above specified load. I tried to find what I needed at Home Depot but no luck. Is this kind of switching only available from industrial type outlets? Am I on the right track here? Thanks for any help, Randy = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 15, 2002
Subject: Matt Dralle Appreciation Month . . .
Every year about this time, many of us dig into our pockets and send a donation to Matt to help defray the costs of supporting dozens of list-servers offered at basically no cost to anyone who chooses to take advantage of this fantastic service. Being half owner in the 'Connection's server and having barely got my feet wet with learning to set it up and maintain it, I can tell you that Matt's offerings are at least 100x more complex and 10x more expensive than my meager efforts at becoming cyber-wise. I can well appreciate the skill, time and expense it takes to accomplish what he has accomplished on our behalf. Please do a little calculating on what it's worth to you for access to Matt's hardware and programming skills that have kept us all in touch over the last year. Drop a little something in the mail to him - or contact him by the medium of your choice from list below. He can take plastic too. Matt G Dralle Matronics PO Box 347 Livermore, CA 94551 Voice 925-606-1001 Fax 925-606-6281 Email: dralle(at)matronics.com Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 15, 2002
Subject: RE: Remote Compressor Switch
> > >You just need a size1 motor starter. Siemens, Allen-Bradley, etc, all >make these, and they are used routinely in factories. They have >overloads on them to protect the motor in case of overcurrent or single >phase, and they have a coil (usually 110vac) that can be controlled >remotely like you mention. Bad thing is that they are usually about >150-200 bucks, so I don't know if that is worthwhile to you. Here's a couple on e-bay for a lot less than that. Both offerings end soon and neither one has a bid on it at this time. If they don't sell, you can contact the offering party directly using info from these links below. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1775867122 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1774907122 >If you didn't want the overload protection, you could accomplish the >same thing with individual solenoids or relays like we use in our >planes, operated by 12vdc. This would work, but require a transformer. >There is another methold, although I don't condone it, but I have seen >it done more than once in my plant (unfortunately). You can also use a >simple light switch (DPST) and run 2 of the three phases through the >remote mounted light switch to turn it on and off. One leg will always >be hot to the motor, but this will not hurt it, just makes it an >electrical hazard if you have to work on it. Again, I don't condone it, >but it will work, and will definitely be the cheapest method. I think he has a single phase machine . . . the contactors above are 3-pole . . . but he can simply ignore one. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2002
Subject: Re: Bench PS
> >Bob - > >A couple months ago you recommended a power supply that was on sale at >Radio Shack. I got one. It's working great the little I've used it so >far. > >I bet you have a similar device, and a cleaver setup for the >wire/probes/clips coming out the back for + and -. I could reinvent the >wheel, or just ask for a description of yours. When I sold those power supplies for a time, I offered a 10AWG set of extension leads that made it easy to connect the power supply's (+) lead to the alternator b-lead terminal and the (-) lead to handy ground (like crankcase or single point ground block). This allowed the 13.8 volt power supply to pretend like it is an alternator. If you wanted to take the simulation a tad further, configure a 12v relay to control 110 VAC going to the power supply. Disconnect the alternator's field lead and use it to drive the relay's coil. This makes your DC PWR MASTER switch function just as if the engine was running. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2002
Larry Bowen wrote: > I bet you have a similar device, and a cleaver setup for the > wire/probes/clips coming out the back for + and -. I used to use "GR Plugs" for 12V bench distribution. GR plugs are a pair of banana plugs sticking out one end, and a matching pair of jacks on the other end. They can plug into a pair of banana jacks spaced .75 inches. I found a long skinny aluminum chassis, and mounted several pairs of banana jacks on it, all spaced .75, with black ones on the bottom, and red ones on the top. Then wired them all in parallel. The GR plugs can be stacked, so you can plug two or three items into one "jack" ( pair of banana jacks ). Their current capacity is quite high. I have put 20A through a GR plug, and it didn't even warm up! "GR" btw stands for General Radio, which was a test equipment company. Wonder if they're still around? - Jerry Kaidor ( jerry(at)tr2.com ) ----- Original Message ----- From: "Larry Bowen" <Larry(at)BowenAero.com> Subject: AeroElectric-List: Bench PS > > Bob - > > A couple months ago you recommended a power supply that was on sale at > Radio Shack. I got one. It's working great the little I've used it so > far. > > I bet you have a similar device, and a cleaver setup for the > wire/probes/clips coming out the back for + and -. I could reinvent the > wheel, or just ask for a description of yours. > > Thanks. > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 15, 2002
on 10/14/02 6:50 PM, Robert L. Nuckolls, III at bob.nuckolls(at)cox.net wrote: > > >> >> BOB: >> >> HOPE YOU HAVE FUN IN OREGON. GOT THE WELDING CABLE YOU SUGGESTED. MY >> IN-LAWS OWN A SCRAP YARD AND AHD A LOT LAYING AROUND, HOWEVER, SINCE THEY >> LOOK FORWARD TO RIDING IN THE PLANE IN THE FUTURE THEY ORDERED ME 80 FEET AT >> .60 CENTS A FOOT. SO I TOOK THEM UP ON THAT ONE. KNOWING THAT IT WILL BE >> BETWEEN 6-9 MONTHS BEFORE I TEST FLY THE PLANE, CAN I GET THE BATTERIES NOW >> SO I CAN MAKE THE APPROPRIATE MOUNTS? > > > I wouldn't buy a battery until the day before first flight. > Make the trays using dimensions off the batteries. Which batteries > are you planning on using? > > Bob . . . > I have a battery that came with my kit 3 years ago. It is still in the box and never been filled with distilled water. Is there a problem with using it? Should I go buy a new one? Thanks Vince ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 23 Msgs - 10/14/02
Date: Oct 15, 2002
Bob: The Navaid Devices autopilot had some problems with spurious roll inputs in some installations when the radio was transmitting (it's an older design, as you know). The suggestion is in the installation manual (a supplement, I believe) saying that the optional PTT wiring to the autopilot would momentarily interrupt the power to the servo when you transmit, preventing roll excursions during that few seconds. I'm going to pull a wire for it, and see what happens with mine when I fly mine Ron > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > Subject: AeroElectric-List: Re: NAVAID & PTT Diode > > > > > > > >Hello friends, > > > >For those of you using a Navaid Devices autopilot with > >a VFR panel (no VOR and only 1 VHF), do you (or should > >I) connect the optional diode to the PTT switch? > > > >I'll be using an Apollo SL-40 COM. > > I'm mystified as to what the Navaid has to do > with any wiring to the PTT switch. On who's > drawing is the diode mentioned and what notes > support the option decision? > > Bob . . . ________________________________________________________________________________
Date: Oct 15, 2002
> >on 10/14/02 6:50 PM, Robert L. Nuckolls, III at bob.nuckolls(at)cox.net wrote: > > > > > > >> > >> BOB: > >> > >> HOPE YOU HAVE FUN IN OREGON. GOT THE WELDING CABLE YOU SUGGESTED. MY > >> IN-LAWS OWN A SCRAP YARD AND AHD A LOT LAYING AROUND, HOWEVER, SINCE THEY > >> LOOK FORWARD TO RIDING IN THE PLANE IN THE FUTURE THEY ORDERED ME 80 > FEET AT > >> .60 CENTS A FOOT. SO I TOOK THEM UP ON THAT ONE. KNOWING THAT IT WILL BE > >> BETWEEN 6-9 MONTHS BEFORE I TEST FLY THE PLANE, CAN I GET THE > BATTERIES NOW > >> SO I CAN MAKE THE APPROPRIATE MOUNTS? > > > > > > I wouldn't buy a battery until the day before first flight. > > Make the trays using dimensions off the batteries. Which batteries > > are you planning on using? > > > > Bob . . . > > > >I have a battery that came with my kit 3 years ago. It is still in the box >and never been filled with distilled water. Is there a problem with using >it? Should I go buy a new one? If it's still dry, it will probably perform as well as can be expected for a flooded battery. I wouldn't fly one in my airplane. Are you planning one or two batteries? Your original note suggested two. You might use your flooded battery as a test battery but plan on new RG batteries for first flight. |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 15, 2002
Vince Ackerman wrote: > > > on 10/14/02 6:50 PM, Robert L. Nuckolls, III at bob.nuckolls(at)cox.net wrote: > > > > > > >> > >> BOB: > >> > >> HOPE YOU HAVE FUN IN OREGON. GOT THE WELDING CABLE YOU SUGGESTED. MY > >> IN-LAWS OWN A SCRAP YARD AND AHD A LOT LAYING AROUND, HOWEVER, SINCE THEY > >> LOOK FORWARD TO RIDING IN THE PLANE IN THE FUTURE THEY ORDERED ME 80 FEET AT > >> .60 CENTS A FOOT. SO I TOOK THEM UP ON THAT ONE. KNOWING THAT IT WILL BE > >> BETWEEN 6-9 MONTHS BEFORE I TEST FLY THE PLANE, CAN I GET THE BATTERIES NOW > >> SO I CAN MAKE THE APPROPRIATE MOUNTS? > > > > > > I wouldn't buy a battery until the day before first flight. > > Make the trays using dimensions off the batteries. Which batteries > > are you planning on using? > > > > Bob . . . > > > > I have a battery that came with my kit 3 years ago. It is still in the box > and never been filled with distilled water. Is there a problem with using > it? Should I go buy a new one? > > Thanks > > Vince Hi Vance, It is most probably ELECTROLYTE that you have to use to fill your battery. In that case your battery is brand new the moment you add the Electrolyte to it. (electrolyte = a mixture of acid and water) Thats what I did, buy the battery now to have the right dimensions -- fill it when you are ready. Rino > -- ________________________________________________________________________________
Date: Oct 15, 2002
Shannon, thanks for the information. My hangar / shop is under my house, I live on an airpark. My garage and compressor is up on the top side of the property and separate from the house. And if course I have a small leak somewhere! It is nice to have the compressor so far away as I can barely hear it when it turns on but it is a long way to go to turn it off at night when I am done working. So that big compressor keeps cycling all night unless I go out there and turn it off. Last night I did order a few X10 components from Smarthome.com. A little expensive for the 30 AMP controller at $100 but I think it will be worthwhile for me. The X10 is controlled via signals transmitted through the AC wiring. Randy ----- Original Message ----- From: "Shannon Knoepflein" <kycshann(at)kyol.net> Subject: RE: AeroElectric-List: Re: Remote Compressor Switch > > You just need a size1 motor starter. Siemens, Allen-Bradley, etc, all > make these, and they are used routinely in factories. They have > overloads on them to protect the motor in case of overcurrent or single > phase, and they have a coil (usually 110vac) that can be controlled > remotely like you mention. Bad thing is that they are usually about > 150-200 bucks, so I don't know if that is worthwhile to you. > > If you didn't want the overload protection, you could accomplish the > same thing with individual solenoids or relays like we use in our > planes, operated by 12vdc. This would work, but require a transformer. > > There is another methold, although I don't condone it, but I have seen > it done more than once in my plant (unfortunately). You can also use a > simple light switch (DPST) and run 2 of the three phases through the > remote mounted light switch to turn it on and off. One leg will always > be hot to the motor, but this will not hurt it, just makes it an > electrical hazard if you have to work on it. Again, I don't condone it, > but it will work, and will definitely be the cheapest method. > > May I ask why you want it remote controlled? Maybe there is a simpler > solution. > > --- > Shannon Knoepflein <---> kycshann(at)kyol.net > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Randy > Crothers > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Remote Compressor Switch > > > > This question is a little on the heavy duty side but I suspect someone > will > know what I need. I have a 22.5 Amp 230 Volt compressor. It is in the > garage > separate from my shop space. I want to switch it on and off remotely. I > ran > door bell wire through conduit ahead of time anticipating doing this. > > Here is what I think I need. Probably a transformer like a door bell > uses. A > low voltage switch to activate on the remote end. A solenoid activated > contactor to handle the above specified load. I tried to find what I > needed > at Home Depot but no luck. Is this kind of switching only available from > industrial type outlets? Am I on the right track here? > > Thanks for any help, > Randy > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 15, 2002
> >Larry Bowen wrote: > > I bet you have a similar device, and a cleaver setup for the > > wire/probes/clips coming out the back for + and -. > >I used to use "GR Plugs" for 12V bench distribution. GR plugs are a pair of >banana plugs sticking out one end, and a matching pair of jacks on the other >end. They can plug into a pair of banana jacks spaced .75 inches. I found >a long skinny aluminum chassis, and mounted several pairs of banana jacks on >it, all spaced .75, with black ones on the bottom, and red ones on the top. >Then wired them all in parallel. > > The GR plugs can be stacked, so you can plug two or three items into one >"jack" >( pair of banana jacks ). Their current capacity is quite high. I have >put 20A through >a GR plug, and it didn't even warm up! > > "GR" btw stands for General Radio, which was a test equipment company. >Wonder if they're still around? Only a ghost of the original company remains. They got out of the RF business a number of years ago and concentrated on high speed automated test equipment for etched circuit board assembly testing. They sold out that operation a few years back to http://www.teradyne.com/prods/prodserv.html > - Jerry Kaidor ( jerry(at)tr2.com ) > Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 15, 2002
> > >Sam - > >I believe that some of the problem here is that "PTT" has taken on too >many meanings to be of use as an acronym - at least on this list. One >is: Push-To-Talk. Another is: Push-To-Test, and yours is >"Push-To-disconnecT. Maybe someone on the list can can come up with a >more descriptive acronym for your situation. > >Mine is "APED": Auto Pilot Emergency Disconnect Bizjets have buttons called "Wheel Master Disconnects" that shut down all motor driven flight control surfaces (a/p and trim servos) with the press of a single button. There's another button on some aircraft called "Control Wheel Steering" that disconnects autopilot steering for duration of switch depression. Once released, the a/p resumes it's last condition. In this case, a "PTT" input to the autopilot is somewhat analogous to "Control Wheel Steering" in that it temporarily disables the autopilot . . . but for the wrong reasons. Bob . . . |-------------------------------------------------------| | My interest is in the future, because I'm going to | | spend the rest of my life there. -C.F. Kettering- | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 15, 2002
Subject: Re: standing up to be counted. . .
> >Hi Bob, > >This is just the way life is, you know. The inventor of the Xerox copier >was turned down by dozens of non-government corporate bureaucrats. . . . and even after the Xerox process became a runaway success, the same people who were snubbed by the copier marketplace failed to see the future in adapting the technology to laser printers. Even when the laser printer was first brought to life in Xerox's own Palo Alto labs, it was up to other companies to show them how to make $mucho$ with the idea. > The >auto and airplane were derided as silly ideas till they were >demonstrated. The developer of Fed Express got a poor grade for his thesis >outlining the design of the system. > >Railing against bureaucrats is like pissing into the wind, an expression I >learned while growing up in north central Kansas. There was a time when I would agree with that . . . now I think there is an increasing awareness of current trends and predicable futures for some of the paths our leadership has mapped out for us. The Internet is an important feature of this new awareness. Irrespective of whether or not you agree with anything I have to offer, how often do you write your congress-persons? Even when the details of your opinion are mis-understood or mis-filed by the recipient, they are acutely aware of the numbers of folk who are watching and expressing themselves. I write several times a week on various issues, usually at http://www.congress.org/ But if the issue is particularly important to me, the letters go out priority mail. >K. H. (Hal) Kempthorne >RV6-a N7HK flying! >PRB (El Paso de Robles, CA) Bob . . . |-------------------------------------------------------| | Too often we enjoy the comfort of opinion without the | | discomfort of thought. ~ John F. Kennedy | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 15, 2002
To make it even simpler, Radio Shack offers assemblies of red, green, and orange LEDs (276-270, 276-271, 276-272, respectively) that have the resistor installed internally so all are rated at 12VDC (16VDC max). Best regards, Rob Housman Europa XS Tri-Gear A070 Airfarame complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: USING LEDS > > >Folks, >I am looking at using a couple of LEDs to indicate things like fuel pump on, >pitot heat on, maybe low fuel or oil pressure. Most LEDs seem to like >2-5volts. So how do I provide that voltage electrically - a step down device >to a 5v mini bus? In line resisters to each? Red LEDs are about 2v, Whites are almost 4v with other colors in that range. All can be operated with a simple resistor in series to set rated operating current for operation at any voltage greater than the minimum required for the device. See http://www.aeroelectric.com/articles/leds3.pdf Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Subject: Re: Phone Interface
Date: Oct 15, 2002
Ian I've built a few of theses, not a lot of problems. You will need a way of increasing the op from the phone headset, normally less than 100 ohms. There is never enough gain to overcome the cabin noise. Next, a two input mic mixer to combine your headset mic and the phone mic. This can all be assemble into a small project box with connectors that plug into your IC, and a cable going to the phone. This is very similar to the ones seen in the mags except it will work. Good luck Gerry ----- Original Message ----- From: "Ian Scott" <jabiru22(at)yahoo.com.au> Subject: RE: AeroElectric-List: Phone Interface > > I have a Motorolla Satellite Phone 9505 that I want to Wire up a Hands > free interface to the headset. > > The phone has a 3 connector plug for a personal hands free. Mike, > earphone and a common ground I assume. > > How easy would it be to wire a plug that would let me plug in the > headset. > > Is there any special thing that I need to do re Impedances? > > Any other hints > > Thanks Bob. > > Ian > > > - Always be connected to your Messenger Friends > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 15, 2002
Robert L. Nuckolls, III wrote: > > > > > > >Hi Bob, > > > >This is just the way life is, you know. The inventor of the Xerox copier > >was turned down by dozens of non-government corporate bureaucrats. > > . . . and even after the Xerox process became a runaway > success, the same people who were snubbed by the copier > marketplace failed to see the future in adapting the > technology to laser printers. Even when the laser > printer was first brought to life in Xerox's own > Palo Alto labs, it was up to other companies to show > them how to make $mucho$ with the idea. > *** Xerox also invented Ethernet, but did they make any money off it? A couple of guys working for Xerox had the bright idea of doing Ethernet over unshielded twisted pair ( telephone wire ). Xerox didn't want to pursue the idea, so they quit and founded SynOptics - which I joined in 1990. LOTTA money got made on that one.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 16, 2003
At 00:41 16/10/2002, you wrote: > > >This could be as complex as building a small power supply using a 7805 >voltage regulator, or the simpler way is to just properly size a series >resistor. I'm sure Bob has some info somewhere on this subject. By coincidence, I was looking at a Kitplanes article on this just yesterday... came from the September 2000 issue. The short answer is a resistor of at least 600 ohms is right for a single LED in a 14V electrical system. If you have several LEDs is series, the resistor value drops. Frank. ________________________________________________________________________________
Date: Oct 15, 2002
> > >*** Xerox also invented Ethernet, but did they make any money off it? A >couple of guys working for Xerox had the bright idea of doing Ethernet over >unshielded twisted pair ( telephone wire ). Xerox didn't want to pursue the >idea, so they quit and founded SynOptics - which I joined in 1990. LOTTA >money got made on that one.... > > - Jerry Kaidor ( jerry(at)tr2.com ) One of Dee's textbooks for a course she took was "Dealers of Lightning", a history of Xerox PARC based on interviews of the folks that built the division and did a whole lot of things for the first time including windows, personal computers, laser printing, word processing and data base programs, graphics capable of animation displays, digital communication via laser, and probably a dozen other things I don't immediately recall. A fascinating read if you get a chance to put your hands on a copy. Amazon has some used copies for $10. Bob . . . ________________________________________________________________________________
Subject: dual battery switch
Date: Oct 15, 2002
Since I am planning on having dual batteries, I still can't figure out when I would shut down the aux battery master and still keep the main battery master. I would think that if I want the main batter contactor off, I would also want the aux contactor off. If that is the case, could I just have a master switch to turn on/off both the main and aux contactors? I plan on having a switch to drive the e-bus from either the main battery bus or the aux battery bus. This way, on an alternator runaway or over volt trip, I turn on the alt e-feed from one or both of the battery busses and turn off the master switch which would turn off the master/aux contactors. Am I missing something here? Bob --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Date: Oct 15, 2002
> >FWIW, I have a copy of an article entitled "Predicting The Future," given >at the >20th annual meeting of the Stanford Computer Forum by Alan Kay, one of the >founding principals of PARC. His thesis there is that the way to predict the >future is to invent it, as Bob indicates. He talks about a study done by the >railroads just after WWI that showed that airline transportation would >always be >more expensive than that provided by the railroads, with the obvious (and >incorrect) conclusion. > >Bill Steer Found an excerpt from that piece. Did you the whole thing on the 'net anywhere? Bob . . . ________________________________________________________________________________
Date: Oct 15, 2002
Subject: Re: dual battery switch
I coud'nt either.... so I decided to operate both contactors from a single master switch. However, I added to momentary off switches so I can test each contactor individually. The good side is that my system is really simple to use and anyone familiar with the Cessnas will be able to operate my electrical system. I also have the aux inition and the e-bus switches. The negative side is that I have a single point of failure for both contactors (the master switch). However, failure of the switch won't prevent the big ventilator on the nose of the plane to keep the cabin cool (ign and fuel pumps are on battery busses). And I still have the e-bus feed switch separate. Michel PS: I should be able to publish my electrical system drawings soon if I can find time to update my web site. --- Bob Kuc wrote: > > > Since I am planning on having dual batteries, I > still can't figure out when I would shut down the > aux battery master and still keep the main battery > master. I would think that if I want the main > batter contactor off, I would also want the aux > contactor off. If that is the case, could I just > have a master switch to turn on/off both the main > and aux contactors? > ===== ---------------------------- Michel Therrien CH601-HD http://pages.infinit.net/mthobby http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby Faith Hill - Exclusive Performances, Videos & More http://faith.yahoo.com ________________________________________________________________________________
Date: Oct 15, 2002
> >--- Bob Kuc wrote: > > > > > > Since I am planning on having dual batteries, I > > still can't figure out when I would shut down the > > aux battery master and still keep the main battery > > master. I would think that if I want the main > > batter contactor off, I would also want the aux > > contactor off. If that is the case, could I just > > have a master switch to turn on/off both the main > > and aux contactors? > > >I coud'nt either.... so I decided to operate both >contactors from a single master switch. However, I >added to momentary off switches so I can test each >contactor individually. The good side is that my >system is really simple to use and anyone familiar >with the Cessnas will be able to operate my electrical >system. I also have the aux inition and the e-bus >switches. Why would you want to have your year 2002 airplane emulate a year 1960 airplane? By adding the press-to-test switches, your system has become more complex than as-published. If a Cessna driver needs to check out in your airplane, what's so complicated about both switches ON for normal ops and both switches OFF for parking the airplane? It's during alternator failed operations that your airplane is unlike anything pushed out the doors of places where spam is canned. Your guest pilot is going to need a checkout anyhow if he/she is to take advantage of the improvements his Cessna will never have. I can't see how you've gained anything . . . >The negative side is that I have a single point of >failure for both contactors (the master switch). >However, failure of the switch won't prevent the big >ventilator on the nose of the plane to keep the cabin >cool (ign and fuel pumps are on battery busses). And >I still have the e-bus feed switch separate. > >Michel >PS: I should be able to publish my electrical system >drawings soon if I can find time to update my web >site. If one has two batteries then it is presumed that you have truly flight critical equipment that would benefit from separate power sources during alternator-out conditions when maximum endurance is needed from battery only operations. Depending on your particular airplane's equipment I think its most likely that when the alternator quits, you turn off BOTH masters and run in the redundant battery, max endurance mode with engine powered only from aux battery and e-bus only from main battery. When the airport is in sight, the main battery master COULD be turned on to allow showing lights or other tasks driven from the main bus while leaving the aux battery free to keep the engine running irrespective of the outcome for the main battery. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2002
> >Since I am planning on having dual batteries, I still can't figure out >when I would shut down the aux battery master and still keep the main >battery master. I would think that if I want the main batter contactor >off, I would also want the aux contactor off. If that is the case, could >I just have a master switch to turn on/off both the main and aux contactors? > >I plan on having a switch to drive the e-bus from either the main battery >bus or the aux battery bus. This way, on an alternator runaway or over >volt trip, I turn on the alt e-feed from one or both of the battery >busses and turn off the master switch which would turn off the master/aux >contactors. > >Am I missing something here? Why does this need to be more complicated? If you have two batteries, then each battery has a task to itself. I presume you're planning to maintain both batteries so that each is assured of the capacity needed to comfortably complete the flight. IF so, what condition do you anticipate that you'll want to drive the e-bus from the aux battery? The reason for two batteries is to have one shielded from all loads EXCEPT keeping the engine running. Flipping the e-bus to the aux battery would be necessary only if you've exhausted the main battery which means you (1) didn't do your homework and put too much load on it or (2) didn't do your homework and maintain the battery for sufficient endurance to the task. In either case, you don't move the e-bus to the aux battery. This is when you whip out the flight-bag standbys. The last thing I'd do is saddle the aux battery with additional loads. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Strobes - tail assembly
Date: Oct 15, 2002
Bob wrote in a reply to a roll your own strobe question: " Did some websearching and had thousands of hits for suppliers/manufacturers of vehicular warning strobe systems. Here's just a small sample. etc." I have decided to do just this but have the problem of combining the tail light and strobe tube. I don't want to use the Whelen unit since its power output is less than the supply I plan to use and I object to the price. I have been considering making an array of LEDs to surround the the tube but I'm a little unsure as to a) how many at 5000mcd I will need and b) how to power this. Advice will be appreciated. Rob Rob W M Shipley. RV9A fuselage. N919RV resvd. ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: off line until Monday
Bob: Her is a list of some of the equipment I will have concerning how many and what type of toggle switches I should have. Cabin Fan, for a blower that will be ducted into the main stream of the NACA air scoop. Cabin lights which I have 4 individual reading lights that have there own on/off switch, a toggle switch here would be the master control sort of speak. High/Low boost toggle switch, perhaps a 3 way switch, off, low and high. I quess this is required with fuel injected engines. Landing light. Taxi light - left, taxi light -right. I have modified my wing tip position lights to have some Auto Zone high intensity lights for taxi. Nav lights, Strobe lights. Pitot heat. AOA system. Cargo are light. Looking at the Z-12, Switches for the Main DC, Aux DC. I have the ACS ignition switch, reading a lot about electronic ignition; don't really know what the advantage would be to have this. If recommended, can I upgrade later or just wire it up now? Basically, looking at the Z-12, other than the obvious things, i.e., lights, pumps; can you just tell me what toggle switches to order, the wire required and I'll get going. Received my 6,10,and 20 fuse bus boxes today. These I presume are for the + side of power, what do you recommend for a ground bus? I suspect I would need three, firewall, instrument panel, and one back near the batteries where servos, strobe power supply could hook up to. Going to send you some attachments of some of the stuff Lancair makes available to see what you think. Regards, Ed ________________________________________________________________________________
Date: Oct 16, 2002
Bob: Here is the regulator, alternate alternator, bus bar, fasteners. Power distribution grid. What do you think of all this stuff? Regards, ED ________________________________________________________________________________
Date: Oct 16, 2002
> The reason for two batteries is to have one shielded > from all loads EXCEPT keeping the engine running. > Flipping the e-bus to the aux battery would be necessary > only if you've exhausted the main battery which means > you (1) didn't do your homework and put too much > load on it or (2) didn't do your homework and maintain > the battery for sufficient endurance to the task. In either > case, you don't move the e-bus to the aux battery. > > This is when you whip out the flight-bag standbys. > The last thing I'd do is saddle the aux battery with > additional loads. > The thought is more of parts reduction then emulation. If the aux always follows the master, then using the same switch would make it less complicated and reduce your part count by one. Since you don't move the e-bus to the aux, then just having a master switch that controls both contactors and alternate to e-bus switch would be all that is needed. With this assumption, there should also be no need to monitor the voltage level on the aux bus, since it is the same during normal operation, and e-bus is the essential one to monitor. Bob --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Date: Oct 16, 2002
> The thought is more of parts reduction then emulation. If the aux always > follows the master, then using the same switch would make it less > complicated and reduce your part count by one. Would it be a good habit to alternate starting between the batteries? This would give a backup indication of poor battery condition. Just a thought. John Slade Cozy IV ________________________________________________________________________________
Subject: Predicting the Future
Date: Oct 16, 2002
Small note about predictions--in 1967 Keuffel & Esser, the sliderule people, contracted for a sophisticated analysis of technology 1000 years in the future. This study generated glowing predictions of domed cities and even 3D television in 2067, but failed to predict that nobody would need sliderules just 5 years later. Eric M. Jones ________________________________________________________________________________
Date: Oct 16, 2002
on 10/15/02 9:08 AM, Robert L. Nuckolls, III at bob.nuckolls(at)cox.net wrote: > > > >> >> Hi Bob, >> >> This is just the way life is, you know. The inventor of the Xerox copier >> was turned down by dozens of non-government corporate bureaucrats. > > . . . and even after the Xerox process became a runaway > success, the same people who were snubbed by the copier > marketplace failed to see the future in adapting the > technology to laser printers. Even when the laser > printer was first brought to life in Xerox's own > Palo Alto labs, it was up to other companies to show > them how to make $mucho$ with the idea. > > >> The >> auto and airplane were derided as silly ideas till they were Don't forget that Xerox also came up with the Graphical User Interface which was basically copied by Steve Jobs and Steve Wozniak to became the Apple Macintosh (which was subsequently copied by Microsoft to become windows). Vince ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: diode jumper
>Bob.......thanks for the responses. You must have answered my question on >the E-bus isolation diode in the attachment to your response, but for some >reason, I didn't get the attachment.......just the "paperclip." > >The original question was: > >Regarding the e-bus isolation diode: Why not put a jumper between the two >ac signal inputs, so you have two diodes in parallel? Wouldn't that >reduce the voltgage drop across the diode to the e-bus? The voltage drop across a diode is a fairly fixed quantity. It's not like a resistor wherein paralleling two resistors will cut the voltage drop in half. This is known as the "barrier hill potential" junction voltage that is a function of the materials from which the junction is made. For many years after the rise of silicon devices as material of choice for new design, germanium devices continued to be manufactured because their barrier hill potential was on the order of 0.25 volts . . . about a third that of their silicon cousins. Paralleling diodes to increase their current carrying ability is also problematical. One has to match the two diodes carefully to insure that they share the load. In our case, any diode in the bridge rectifier array is able to carry our loads nicely on its own so the other three diodes are just along for the ride. The reason for using the bridge rectifier array is the convenience with which it can be mounted and wired. No other diode product with similar current and voltage ratings is so user friendly. It really bugs some people that there are three diodes left over that don't do anything for us . . . Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: Strobes - tail assembly
> >Bob wrote in a reply to a roll your own strobe question: >" > Did some websearching and had thousands of hits for > suppliers/manufacturers of vehicular warning strobe > systems. Here's just a small sample. > >etc." > >I have decided to do just this but have the problem of combining the tail >light and strobe tube. I don't want to use the Whelen unit since its >power output is less than the supply I plan to use and I object to the >price. I have been considering making an array of LEDs to surround the >the tube but I'm a little unsure as to a) how many at 5000mcd I will need >and b) how to power this. > >Advice will be appreciated. > >Rob >Rob W M Shipley. >RV9A fuselage. N919RV resvd. Whelen has a white LED nav tail light that's TSO'd . . . but not cheap. It's presently being installed on the tail of the Beechjet. The array of LEDs to do this task is something on the order of 50-75 lamps. Whelen uses surface mount lamps on etched circuit boards. They also have to be oriented to achieve the spherical radiation pattern that mimics a light bulb. I think I go with two separate fixtures . . . or switch to the silly but qualified, dual lamp fixtures on the wings and forget the nav light for the tail. Bob . . . ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: Ed's Lancair - System planning
> >Bob: > > Her is a list of some of the equipment I will have concerning how > many >and what type of toggle switches I should have. Cabin Fan, for a blower that >will be ducted into the main stream of the NACA air scoop. Cabin lights which >I have 4 individual reading lights that have there own on/off switch, a >toggle switch here would be the master control sort of speak. High/Low boost >toggle switch, perhaps a 3 way switch, off, low and high. I quess this is >required with fuel injected engines. Landing light. Taxi light - left, taxi >light -right. I have modified my wing tip position lights to have some Auto >Zone high intensity lights for taxi. Nav lights, Strobe lights. Pitot heat. >AOA system. Cargo are light. Looking at the Z-12, Switches for the Main DC, >Aux DC. I have the ACS ignition switch, reading a lot about electronic >ignition; don't really know what the advantage would be to have this. If >recommended, can I upgrade later or just wire it up now? Basically, looking >at the Z-12, other than the obvious things, i.e., lights, pumps; can you just >tell me what toggle switches to order, the wire required and I'll get going. >Received my 6,10,and 20 fuse bus boxes today. These I presume are for the + >side of power, what do you recommend for a ground bus? I suspect I would need >three, firewall, instrument panel, and one back near the batteries where >servos, strobe power supply could hook up to. Going to send you some >attachments of some of the stuff Lancair makes available to see what you >think. Don't send anything yet. First, take the list of things you've cited and organize them based upon the architecture for the power distribution diagram you plan to use. Do the list like we've been working on for Tom's Seawind that has been thrashed to some extent here on the list. Until this list is complete and accurate, you're not ready to order parts. You've got a composite airplane - you'll need a "busy ground bus" . . . I'd use the 48 pin device shown in the website catalog. I'd bring ground for every electrically powered device to this single ground point. Let's get your paperwork finished first. Go through the list postings of the last few days and find a message with the subject Seawind - Rudimentary system planning Start building a list like that for your airplane and post it here on the list with the subject "Ed's Lancair system planning" and lets comb it out on the list. Bob . . . ________________________________________________________________________________
Date: Oct 16, 2002
> >Bob: > > Here is the regulator, alternate alternator, bus bar, fasteners. > Power >distribution grid. What do you think of all this stuff? > >Regards, > >ED I presume you had some attachments to your e-mail response to the list. Be aware that the list server doesn't forward any kind of attachments. I'll arrange to look at them via direct mail when we get your paperwork done. I've also changed the subject line to match what we're talking about so those with an interest/disinterest in this conversation can chose to open the messages or not. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
> > > The reason for two batteries is to have one shielded > > from all loads EXCEPT keeping the engine running. > > Flipping the e-bus to the aux battery would be necessary > > only if you've exhausted the main battery which means > > you (1) didn't do your homework and put too much > > load on it or (2) didn't do your homework and maintain > > the battery for sufficient endurance to the task. In either > > case, you don't move the e-bus to the aux battery. > > > > This is when you whip out the flight-bag standbys. > > The last thing I'd do is saddle the aux battery with > > additional loads. > > > >The thought is more of parts reduction then emulation. If the aux always >follows the master, then using the same switch would make it less >complicated and reduce your part count by one. Since you don't move the >e-bus to the aux, then just having a master switch that controls both >contactors and alternate to e-bus switch would be all that is needed. The AUX does not follow or lead anything. Normal operations for both batteries calls for moving the switches together but in no particular order. >With this assumption, there should also be no need to monitor the voltage >level on the aux bus, since it is the same during normal operation, and >e-bus is the essential one to monitor. I'm lost. Which architecture are you talking about? I thought we were discussing a single alternator, two battery system. Main bus, e-bus, main battery bus, aux battery bus. Now you seem to be discussing something else. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
> > > The thought is more of parts reduction then emulation. If the aux always > > follows the master, then using the same switch would make it less > > complicated and reduce your part count by one. >Would it be a good habit to alternate starting between the batteries? >This would give a backup indication of poor battery condition. >Just a thought. If your main battery is always less than one year old and your aux battery is less than two years old, this should never be a concern . . . but you could certainly do it. I'd always start with both batteries to reduce wear and tear on other system components. The faster the engine starts, the lower the stress on components that get the engine started. Testing of batteries should be a maintenance activity needed only if you're modus operandi calls for periodic capacity checks and replacement on measured conditions. With periodic replacement well inside the battery's expected useful life, testing of any kind is less useful . . . How about doing a one-battery start every oil change? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: Internally Regulated Alternator Adjustment?
>Bob, > >Earlier I wrote: > > > I'd like to replace the conventional lead-acid battery with a > >"gel cell" someday and know this is too high (for either type of > >You responded: > >[snip] > > You sure you really want to put a gel-cell battery in your airplane? > > They're getting pretty rare and don't perform nearly as well as > > either the flooded or RG (recombinant-gas) batteries. See: >[snip] > >You're absolutely right -- RG is what I want. I couldn't remember >the correct name for it; hence the "gel cell" (in quotes). > >And while I have you attention, please let me express my gratitude for >your time and effort on the AeroElectric List. I'm a long-time lurker >and have learned a lot by reading your responses. I figured that was the case. Just rattling your cage a little. I'm trying to get folks to purge the term "gel-cell" from the vernacular of battery-speak unless that's what they're REALLY talking about. Thank you for the kind words. Bob . . . ________________________________________________________________________________
Date: Oct 16, 2002
> >With this assumption, there should also be no need to monitor the voltage > >level on the aux bus, since it is the same during normal operation, and > >e-bus is the essential one to monitor. > > I'm lost. Which architecture are you talking about? I thought > we were discussing a single alternator, two battery system. > Main bus, e-bus, main battery bus, aux battery bus. Now you > seem to be discussing something else. > I am. Right now I am building a system to monitor voltage in the plane. With the alt working, then the whole system will have the same voltage, the voltage from the alternator. However, in an alternator out situation, my volts drop < 13. I would think that I would need to monitor the voltage level to at least down to 10 volts remaining, where I better be on the ground. I am planning on monitoring the voltage level off from the e-bus. Since the aux battery doesn't have as much load on it as the main battery, and the main battery is driving the e-bus, I don't think that I would need to monitor the voltage level on the aux battery bus. Bob --- Checked by AVG anti-virus system (http://www.grisoft.com). ________________________________________________________________________________
Date: Oct 16, 2002
Bob: Excellent advise. Yes, I have kept copies of all the seawind discussion. I will refer to them now and do my homework assignments. I will order the 48 pin ground point. Thanks for your response, I will use your Ed's Lancair-System planning as reference from here on out. Regards, ED N823MS ________________________________________________________________________________
Date: Oct 16, 2002
Bob: OK. I have them ready to go when the time comes. Regards, Ed ________________________________________________________________________________
Date: Oct 16, 2002
Ed - What kind of Lancair are you building? We are building a Super ES (IO-550N) and are looking at Z-14 as the power distribution plan. This system calls for dual alternators and 2 batteries. We'll buy the 20 amp alternator from B&C, along with 2 of the regulators. I've done a lot of work in AutoCAD, drawing relevant circuits for avionics power, adding things to the busses (#1, #2, #1 battery & #2 battery), labeling the diagram and adding equipment numbers to it. I then make an entry in an Excel sheet with the number, nomenclature, where-to-buy, part number (if known), power rating and other information for each piece of electrical gear in the wire book. Regarding the ground busses: We'll have one on the firewall and directly behind it on the cabin side of the firewall will be another 48. Both of these will use two common bolts to bind them together and fasten them to the firewall. A ground strap goes from the firewall ground bus to the engine. Right now, we have one channel of the FADEC (or electronic ignition) on each battery bus. The avionics are on the small (20 amp alternator) bus. If you would like to see what I have, let me know and I'll email the files to you. Looking forward to watching yours "get combed out" on this list. It will be productive for us, too. Cheers, John Schroeder Lancair Super ES > > Bob: > > Excellent advise. Yes, I have kept copies of all the seawind > discussion. ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: Seawind - Rudimenary system planning
Hi Bob, Here is my revised list as per your suggestions: Main Battery Bus: Full boast pump Rt wing fuel transfer pump ( aux tank to main tank ) Left wing fuel transfer pump ( aux tank to main tank ) Transfer pump ( left wing to right wing ) Transfer pump ( right wing to left wing ) Bilge pump Primary fuel pump Hobbs meter Over head curtesy lights Aux Battery Bus: Clock/timer Stall warning Goose neck light Main Power Distribution Bus: Taxi lights Strobe lights Landing lights Position lights Panel lights Auto pilot Flaps Hydraulic pressure pump (needs power) Attitude indicator Pitot Heat Aux Power Distribution Bus: HSI Electronic trim for ( ailerons, rudder, stabilizer) Turn and slip indicator GPS (Full IFR UPS stack) Nav Com Transponder Audio panel Quad fuel gauges Cooling fan for radios VM 1000 There are six fuel pumps. 2 pumps to transfer fuel from aux tanks to main tanks. 2 pumps to transfer fuel from left wing to right wing and vice-versa. 1 pump to bring fuel up to the engine. 1 high altitude pump. There is also the pump that is on the engine. Do you think that all the fuel pumps should be on the same bus? If not which pumps do I put on which bus? I am also told that the altimeter, Rate of climb indicator, and air speed indicator need power to operate and that they have built in encoders. What bus should the be hooked up to? Thanks for your patience, Tom Saccio ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Load meter & Volt Meter
In a dual battery / dual alternator setup, why is it important (or is it important) to have a volt meter and/or ameter for each system if you have the alternator low voltage indicator lights from the LR-3 regulators? If they are important, do they need to be visible all the time or just on runup/problem time? Is it something you should be checking in flight? It appears to me that if the volts are good (as indicated by the low volt warning lights), then the alternators are working (volts & amps should be fine). - Jim ________________________________________________________________________________
Date: Oct 16, 2002
----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Ed's Lancair - System planning > > > > >Bob: > > > > Her is a list of some of the equipment I will have concerning how > > many > >and what type of toggle switches I should have. Cabin Fan, for a blower that > >will be ducted into the main stream of the NACA air scoop. Cabin lights which > >I have 4 individual reading lights that have there own on/off switch, a > >toggle switch here would be the master control sort of speak. High/Low boost > >toggle switch, perhaps a 3 way switch, off, low and high. I quess this is > >required with fuel injected engines. Landing light. Taxi light - left, taxi > >light -right. I have modified my wing tip position lights to have some Auto > >Zone high intensity lights for taxi. Nav lights, Strobe lights. Pitot heat. > >AOA system. Cargo are light. Looking at the Z-12, Switches for the Main DC, > >Aux DC. I have the ACS ignition switch, reading a lot about electronic > >ignition; don't really know what the advantage would be to have this. If > >recommended, can I upgrade later or just wire it up now? Basically, looking > >at the Z-12, other than the obvious things, i.e., lights, pumps; can you just > >tell me what toggle switches to order, the wire required and I'll get going. > >Received my 6,10,and 20 fuse bus boxes today. These I presume are for the + > >side of power, what do you recommend for a ground bus? I suspect I would need > >three, firewall, instrument panel, and one back near the batteries where > >servos, strobe power supply could hook up to. Going to send you some > >attachments of some of the stuff Lancair makes available to see what you > >think. > > Don't send anything yet. First, take the list of things you've cited > and organize them based upon the architecture for the power distribution > diagram you plan to use. Do the list like we've been working on > for Tom's Seawind that has been thrashed to some extent here on the > list. > > Until this list is complete and accurate, you're not ready to order > parts. > > You've got a composite airplane - you'll need a "busy ground > bus" . . . I'd use the 48 pin device shown in the website catalog. > I'd bring ground for every electrically powered device to this > single ground point. > > Let's get your paperwork finished first. Go through the list > postings of the last few days and find a message with the subject > Seawind - Rudimentary system planning > > Start building a list like that for your airplane and post it here > on the list with the subject "Ed's Lancair system planning" and > lets comb it out on the list. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 16, 2002
> > > >With this assumption, there should also be no need to monitor the voltage > > >level on the aux bus, since it is the same during normal operation, and > > >e-bus is the essential one to monitor. > > > > I'm lost. Which architecture are you talking about? I thought > > we were discussing a single alternator, two battery system. > > Main bus, e-bus, main battery bus, aux battery bus. Now you > > seem to be discussing something else. > > >I am. Right now I am building a system to monitor voltage in the plane. >With the alt working, then the whole system will have the same voltage, the >voltage from the alternator. . . . actually not true. E-bus runs about .7 volts lower than main bus. > However, in an alternator out situation, my >volts drop < 13. I would think that I would need to monitor the voltage >level to at least down to 10 volts remaining, where I better be on the >ground. . . . are you saying that you're not SURE that you can run battery-only loads for duration of remaining fuel? What stands in the way of making this a sure thing? Voltmeters and ammeters make for good diagnostic tools (that's why we added the field voltage measurement feature to the Loadmeter/Voltmeter product). By-in-large, one should be able to configure and maintain a system in a manner that lets you fly with confidence having only a low volts warning light as your total electrical system instrumentation. > I am planning on monitoring the voltage level off from the e-bus. >Since the aux battery doesn't have as much load on it as the main battery, >and the main battery is driving the e-bus, I don't think that I would >need to monitor the voltage level on the aux battery bus. Correct. Is this a single-alternator/dual-battery system? The Loadmeter/Voltmeter system we used to sell featured a relay that when energize from the main bus, feeds the voltmeter from the main bus. When the main bus shuts down, the relay drops out and transfers the voltmeter to the e-bus. I think the last time I responded to this thread, we were discussing combining both battery contactors onto a single switch . . . and someone mentions adding press-to-test buttons to allow single battery cranking as a means of pre-flight testing. I was hoping that we agreed there's a valid reason for putting each battery on its own switch. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
> >Bob: > > Excellent advise. Yes, I have kept copies of all the seawind >discussion. I will refer to them now and do my homework assignments. I will >order the 48 pin ground point. Thanks for your response, I will use your Ed's >Lancair-System planning as reference from here on out. Let's get started on yours too. Go ahead and post a first pass at it. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: John's Lancair - System planning
> > >Ed - > >What kind of Lancair are you building? We are building a Super ES >(IO-550N) and are looking at Z-14 as the power distribution plan. This >system calls for dual alternators and 2 batteries. We'll buy the 20 amp >alternator from B&C, along with 2 of the regulators. > >I've done a lot of work in AutoCAD, drawing relevant circuits for >avionics power, adding things to the busses (#1, #2, #1 battery & #2 >battery), labeling the diagram and adding equipment numbers to it. I >then make an entry in an Excel sheet with the number, nomenclature, >where-to-buy, part number (if known), power rating and other information >for each piece of electrical gear in the wire book. Regarding the ground >busses: We'll have one on the firewall and directly behind it on the >cabin side of the firewall will be another 48. Both of these will use >two common bolts to bind them together and fasten them to the firewall. >A ground strap goes from the firewall ground bus to the engine. > >Right now, we have one channel of the FADEC (or electronic ignition) on >each battery bus. The avionics are on the small (20 amp alternator) bus. > >If you would like to see what I have, let me know and I'll email the >files to you. Could you be talked into publishing them? I'd be pleased to post them on my server and link them for general access by anyone interested. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
Subject: Re: Load meter & Volt Meter
> >In a dual battery / dual alternator setup, why is it important (or is it >important) to have a volt meter and/or ameter for each system if you have >the alternator low voltage indicator lights from the LR-3 regulators? > >If they are important, do they need to be visible all the time or just on >runup/problem time? Is it something you should be checking in flight? > >It appears to me that if the volts are good (as indicated by the low volt >warning lights), then the alternators are working (volts & amps should be >fine). > >- Jim . . . an astute observation my friend. Electrical system gages are mostly useful for diagnostics while trouble shooting a system. It's quite practical to consider the low volts warning lights as your primary and only necessary flight instrumentation for the electrical system(s). If the lights are out, cool. If a light is lit, then we should KNOW that we've got enough battery aboard that we'll put the wheels back on the ground without breaking a sweat. Then, if the only measurement tools for fixing the system are those you pull out of your toolbox, I don't see that as a big problem. If the automotive industry had put a calibrated and trustworthy low volts warning light on cars back about 45 years ago, perhaps the "idiot light" might have been named the "smart light". Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 16, 2002
John: Thank you for writing me. Since Lancair has left me in the dark on this part of the building project it was beginning to get a little discouraging. Since I have talked to Bob on the phone and net, I am getting a better big picture. I would love to have anything you have that would help me through this process. Here is a snap shot of where I am now. I acquired kit #59. I have been working on it about a year and a half. I am about to close the left wing; just finished the left flap closeout. Ready to close out the left aileron, however, my hang up there is the wiring of the servo. Some have routed to the inboard, others to the outboard. I am running a plastic tubing for the wire, and I am looking for some simple connectors so as to remove the aileron if necessary. I have the horizontal stab on, the vertical stab, on, half a rudder. I made an inspection plate for the com antenna connections, again running a plastic tube so as to replace faulty wire if need be. Once the left side is done I am sure the right side will go faster. Avionics was, I have just bought a Gagman stack: AUD/COM 340, GNS-530, GNS-430, GTX-327. Will be installing the elevator servo for the TRUTRAK 200 or 250, haven't decided yet. I will also be going dual alt/batt. I am looking at the Z-12 plan. Is that the same as your Z-14? Perhaps I need to be updated. I have version 10 of the Aeroelectric Connection? I am thinking seriously about the BMA EFIS/Lite for my PFD. Talked to them yesterday and they may make the same size HSI. I have heard better news about this item vise the EFIS/ONE. At any rate I will go with all electric gauges that I can find and afford. Any recommendations here? Engine: I just ordered an IO-520 "D", 300hp. I will be going with a rear belt driven 60amp ALT in the rear. I also will be going with the 20amp BC ALT. I do not have AUTOCAD, but I just ordered Bob's CD-ROM. Additionally I bought one 20 fuse box, one 10 fuse box, and a 6 fuse box just for starters. I will be installing the batteries on each side of the elevator idler. Any recommendations? Bob recommended welding cable so I bought 80 feet @ .60 cents a foot. I have just learned from Bob about the 48 ground bus, I like what you did. I am going with toggle switches, and my latest assignment from Bob is to what goes on each bus. There you have it. We have 4 Lancair's here in the Memphis area going on right now. I am the only Super ES. One guy is near completion on his IVP and is going to sell me his cowling, carbon fiber, because he had to modify another one to fit his three intercoolers. I am also getting his box that he made for the cabin blower, since he has now gone with an airconditiong system. Have you installed a cabin blower? I currently work for FedEx, so I will be out for the next few days. I appreciate your time and info, if there is anything that I can do, let me know. Regards, Ed SIlvanic N823MS(at)aol.com (901) 409-7807 ________________________________________________________________________________
Date: Oct 16, 2002
Subject: loadmeter/voltmeter
Speaking of which, Bob, I was planning to use one of your loadmeter/voltmeters in my RV-6 project and was disappointed that you discontinued them. I held off buying one until I was closer to needing it and now they are no more. Are you thinking about selling them again? I'll buy one. Ed Holyoke >Voltmeters and ammeters make for good diagnostic tools (that's why we added the field voltage measurement feature to the Loadmeter/Voltmeter product). By-in-large, one should be able to configure and maintain a system in a manner that lets you fly with confidence having only a low volts warning light as your total electrical system instrumentation. > I am planning on monitoring the voltage level off from the e-bus. >Since the aux battery doesn't have as much load on it as the main battery, >and the main battery is driving the e-bus, I don't think that I would >need to monitor the voltage level on the aux battery bus. Correct. Is this a single-alternator/dual-battery system? The Loadmeter/Voltmeter system we used to sell featured a relay that when energize from the main bus, feeds the voltmeter from the main bus. When the main bus shuts down, the relay drops out and transfers the voltmeter to the e-bus. I think the last time I responded to this thread, we were discussing combining both battery contactors onto a single switch . . . and someone mentions adding press-to-test buttons to allow single battery cranking as a means of pre-flight testing. I was hoping that we agreed there's a valid reason for putting each battery on its own switch. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: Re: loadmeter/voltmeter
Date: Oct 16, 2002
*** Speaking of voltmeters, I was at the auto parts store, and there was a cute little digital voltmeter that plugs into the cigarette lighter socket. I had to have it. Now it lives in my Sundowner. I don't smoke :). - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 17, 2002
Bob: I have selected the following busses based on what I have seen and read. I will admit, however, it was hard not to include avionics bus, ground bus, essential bus, and emergency bus. MAIN POWER DISTRIBUTION BUS: Attitude indicator either as primary or backup. Looking at the EFIS/Lite from BMA which has had better performance than what I have heard about the EFIS/ONE. Nav lights Strobe Taxi light left Landing light Autopilot Electric Flaps Pitot heat AOA system Cabin Fan GNS-530 GTX-327 AUX POWER DISTRIBUTION: Taxi light - right Electric trim: aileron, rudder, elevator Turn coordinator Directional Gyro- possible a future BMA HSI GNS-430 engine gauge- Electronics International- Oil/Temp MAP RPM Ultimate Bar Graph FP-5L, fuel flow/pressure MAIN BATTERY BUS: Amp/Volt gauge Post lighting Fuel boost pump (high) * Ignition #1 Comm panel Cabin lighting Cargo Compartment light AUX BATTERY BUS: Clock Hobbs Meter * Ignition #2 Fuel boost Pump (low) Power Receptacle for Hand Held NAV/COM * Ignition system: I have always have seen MAGS, I'll be honest with you, I don't know much about this other than what is in cars. Have read a lot of past mail about this. My IO-520"D" engine is coming with a new set of MAGS and harness. Should I plan on discarding this? Go with one side on EI or go for both EI? If I stay with MAGS, is it to much trouble to go to EI later? Here is my first pass at this! Regards, Ed Silvanic ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Subject: Re: Predicting the Future
Date: Oct 17, 2002
If predicting the future were possible, we would all be rich.... BTW, I still have, and use now and then, a K&E slide rule, the Rolls Royce Silver Phantom of slip sticks... A log, log, antilog screamer... I might point out that the atomic bomb, the SR71, and lotsa good stuff was designed and engineered on slip sticks.. Denny ----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Subject: AeroElectric-List: Predicting the Future > > Small note about predictions--in 1967 Keuffel & Esser, the sliderule people, > contracted for a sophisticated analysis of technology 1000 years in the future. > This study generated glowing predictions of domed cities and even 3D television in > 2067, but failed to predict that nobody would need sliderules just 5 years later. > > Eric M. Jones > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
"AeroElectric-List Digest Server"
Date: Oct 17, 2002
The higher the current from the power supply, the shorter the useable lifespan of the flash tube... In fact the light output of the strobe head will degrade rapidly, logarithmically even, with increasing current... It may be that with a 25% increase in lumens over nominal the actual lumens of the flash tube after one year of use, will be less than what you would get for many years of use at the recommended power level... TANSTAAFL Denny ----- Original Message ----- From: "Rob W M Shipley" <Rob(at)RobsGlass.com> Subject: AeroElectric-List: Strobes - tail assembly > > Bob wrote in a reply to a roll your own strobe question: > " > Did some websearching and had thousands of hits for > suppliers/manufacturers of vehicular warning strobe > systems. Here's just a small sample. > > etc." > > I have decided to do just this but have the problem of combining the tail light and strobe tube. I don't want to use the Whelen unit since its power output is less than the supply I plan to use and I object to the price. I have been considering making an array of LEDs to surround the the tube but I'm a little unsure as to a) how many at 5000mcd I will need and b) how to power this. > > Advice will be appreciated. > > Rob > Rob W M Shipley. > RV9A fuselage. N919RV resvd. > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 17, 2002
> >*** Speaking of voltmeters, I was at the auto parts store, and there was a >cute little digital voltmeter that plugs into the cigarette lighter socket. >I had to have it. Now it lives in my Sundowner. I don't smoke :). > > - Jerry Kaidor ( jerry(at)tr2.com ) Radio Shack used to offer a bar-graph voltmeter that plugged into the cigar lighter too. Never put my hands on one to see how it was scaled or how accurate it was. Might do that next time I see one. Have you checked the accuracy of your purchase against a good multi-meter? It's getting easier by the year to do accurate voltage measurement and display so accuracy issues should be diminishing . . . but there are some early offerings out there that were off by more than 0.5 volts at 14.0 volts. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 17, 2002
> > >The higher the current from the power supply, the shorter the useable >lifespan of the flash tube... In fact the light output of the strobe head >will degrade rapidly, logarithmically even, with increasing current... It >may be that with a 25% increase in lumens over nominal the actual lumens of >the flash tube after one year of use, will be less than what you would get >for many years of use at the recommended power level... This is true. The life of the strobe tube itself is a function of heating . . . at 20 watt-seconds per flash and 1 flash per second they have to dump 20 watts of heat. For an object this small, this means they run REALLY warm. I've had builders substitute surplus flash tubes into their holy-watered strobe systems only to find that they were good for only 10 hours of operation before their shells were markedly darkened. One builder remarked about 10 years ago that he didn't mind replacing them fairly often 'cause he could get the tubes for about $3.00 each and he'd worked out a means for convenient replacement. His cost-of-ownership was sufficiently enhanced despite the added time-to-maintain. I think one is justified in substituting "high power" strobe heads from the emergency vehicle market into holy-watered strobe systems. Emergency vehicles generally see a lot more operating hours per year than most airplanes and I have to believe successful products offered to that market are relatively robust. Get a photographer's light meter that will read flashguns and take a sample reading of your strobe assembly's output when new. It's time to replace the head when the light output falls by one half (1 f-stop). Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Good, low budget multi-meters
Date: Oct 17, 2002
I am looking for a good quality mutli-meter, without paying Fluke prices. Any suggestions? Thanks in advance! Sam ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Tom's Seawind - Rudimenary system planning
> >Hi Bob, Here is my revised list as per your suggestions: Very good. Lets start working the loads issues. The architecture details need not be carved in stone at this time . . . I think you're 95% of the way there now. You need to put some current draw (not wire or breaker size) figures on each of these items. I'll add a few where I'm sure I've got good numbers. >Main Battery Bus: Main battery contactor 1A >Full boast pump >Rt wing fuel transfer pump ( aux tank to main tank ) >Left wing fuel transfer pump ( aux tank to main tank ) >Transfer pump ( left wing to right wing ) >Transfer pump ( right wing to left wing ) >Bilge pump >Primary fuel pump >Hobbs meter 0.1A >Over head curtesy lights > >Aux Battery Bus: >Clock/timer 0.05A >Stall warning 0.2A (intermittant) >Goose neck light ) 0.1A > >Main Power Distribution Bus: Main battery contactor 1A >Taxi lights >Strobe lights >Landing lights >Position lights 6A >Panel lights >Auto pilot >Flaps 5A (intermittant - just guessing here) >Hydraulic pressure pump (needs power) This guy will move to the main battery through an ANL current limiter. What is your "emergency" gear extension system like? How do you get the gear down with no electrical power? >Attitude indicator >Pitot Heat 8A > >Aux Power Distribution Bus: >HSI >Roll trim Mac Servo? 0.2A (intermittant) >Yaw trim Mac Servo? 0.2A (intermittant) >Pitch trim Mac Servo? 0.2A (intermittant) >Turn and slip indicator 0.3A >GPS (Full IFR UPS stack) >Nav Com (xx/xx receive/intermittant transmit) >Transponder >Audio panel 0.1A >Quad fuel gauges >Cooling fan for radios >VM 1000 > >There are six fuel pumps. 2 pumps to transfer fuel from aux tanks to main >tanks. >2 pumps to transfer fuel from left wing to right wing and vice-versa. >1 pump to bring fuel up to the engine. >1 high altitude pump. >There is also the pump that is on the engine. > >Do you think that all the fuel pumps should be on the same bus? If not which >pumps do I put on which bus? What kind of pumps are these? Fawcet solid state pumps? They don't draw much current. I think I'd like to be able to keep this airplane aloft with the master switches both OFF and still use up all fuel aboard. I'd put the pumps on battery busses, each with it's own fuse. Say half half of them on main battery, half on aux battery. >I am also told that the altimeter, Rate of climb indicator, and air speed >indicator need power to operate and that they have built in encoders. What brand and part numbers are you anticipating in these slots? >What bus should the be hooked up to? > >Thanks for your patience, > >Tom Saccio > No problem. This is a good and necessary exercise that should be the beginning of EVERY electrical system design. At RAC, we try to have all these details worked out before any parts are ordered or aluminum is cut. It can save you a lot of time and avoid the frustration and expense of back-tracking over unforeseen problems later. We have a couple of Lancair guys watching this thread and I hope we'll be posting their deliberations here soon as well. After we've gone through a few of these exercises I think the technique will be obvious to others who are wrestling with their own project planning. ________________________________________________________________________________
Date: Oct 17, 2002
MCM Electronics WWW.mcmelectronics.com has Fluke 110 on sale at $99.00 or for the budget minded they have a TENMA DMM for 29.95 (order #72-2055). I have had excellent service from these folks! -----Original Message----- From: Sam Hoskins [mailto:shoskins(at)globaleyes.net] Subject: AeroElectric-List: Good, low budget multi-meters I am looking for a good quality mutli-meter, without paying Fluke prices. Any suggestions? Thanks in advance! Sam ________________________________________________________________________________
Subject: Re: Good, low budget multi-meters
Date: Oct 17, 2002
Sam Hoskins wrote: > > > I am looking for a good quality mutli-meter, without paying Fluke prices. > > Any suggestions? > *** How about Sears Craftsman? I think Sears is reasonably careful about what they slap Craftsman stickers onto. In general, I've given up on cheap multimeters. They always break for me, YMMV. Well, there is one exception. I have a little credit-card-sized SOAR that has never let me down. Still ticking after ten years. Do an Ebay search for "Fluke Multimeter" - there are LOTS of them. A used Fluke might be your best meter. - Jerry Kaidor ( jerry(at)tr2.com ) > Thanks in advance! > > Sam > > > > > > ________________________________________________________________________________
Subject: z14
Date: Oct 17, 2002
Bob, I'm finishing the details of my electrical system design for my Lancair Legacy, working on the power grid/contactors right now. To refresh you, it is a dual alt/bat sys, similar to your depiction in z14. dual 17ah bats will be behind the seat with the bat and crossfeed contactors there on a power grid, and there will be a starter (and avionics) power grid on the firewall, and there will be a final contactor bank in the aft fuselage where the hyd pump and air conditioning is. I have a couple of questions though: 1) why is the wire from the starter contactor to the starter shown as 2awg, while the wire feeding it from the batteries is only 4awg. Shouldn't the wire from the bat to starter contactor also be 2awg, especially in a situation like this where there is 7-10 feet between the contactors? 2) is there any reason I can't move the shunt to the other side of the contactor to measure amp draw on the bat? Likewise, I will pull the crossfeed and starter feed off before the shunt so there is no drop on it and to eliminate any problems there. If this doesn't make sense, I can include a drawing. Heres basically what I have in mind: B+ 0--O contactor 0--0--0 bat_shunt 0--0--0 alt_shunt 0--0 anl30 0--0 alt | | | | xfeed main cont & bus starter --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 17, 2002
> >Sam Hoskins wrote: > > > > > > > I am looking for a good quality mutli-meter, without paying Fluke prices. > > > > Any suggestions? We've been offering this instrument or close cousins to it for several years with good history . . . http://www.aeroelectric.com/Catalog/tools/tools.html#dmm-2 I've had occasion to use one of these from Radio Shack and I think it's a good value . . . you can also probably find one locally. http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F008%5F002%5F001%5F000&product%5Fid=22%2D811 Bob . . . ________________________________________________________________________________
Date: Oct 17, 2002
Sears has good digital meters reasonable... ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Good, low budget multi-meters > > > > >Sam Hoskins wrote:
October 04, 2002 - October 17, 2002
AeroElectric-Archive.digest.vol-bf
