AeroElectric-Archive.digest.vol-bg
October 17, 2002 - October 24, 2002
      > > > I am looking for a good quality mutli-meter, without paying Fluke
      prices.
      > > > Any suggestions?
      >    We've been offering this instrument or close cousins
      >    to it for several years with good history . . .
      >    http://www.aeroelectric.com/Catalog/tools/tools.html#dmm-2
      >    I've had occasion to use one of these from Radio Shack
      >    and I think it's a good value . . . you can also probably
      >    find one locally.
      http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CT
      LG%5F008%5F002%5F001%5F000&product%5Fid=22%2D811
      >    Bob . . .
      http://www.matronics.com/browselist/aeroelectric-list
Date: Oct 17, 2002
Subject: Ed's Lancair-System Planing
Bob: I plan on using two 17 amp batteries as recommended. What company do you recommend for these batteries? I would like to contact them to acquire the actual dimensions in order to build the platform/trays in the back of my Lancair ES. Thanks, Ed Silvanic ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Re: Seawind - Rudimenary system planning
Hi Bob, Here is the new revised, revised, revised list: Main battery bus: Main battery contactor 1A Hydraulic Pressure pump (Connected through an ANL current limiter) Fuel boast pump Transfer pump (left wing to right wing) Transfer pump (Right wing to left wing) Bilge pump Hobbs meter 0.1A Over head courtesy lights All fuel pumps have independent fuses Aux Battery Bus: Clock timer 0.05A Stall warning 0.2A (intermittent) Goose neck light 0.1A Transfer pump left wing (aux to main tank) Transfer pump right wing (aux to main tank) Primary fuel pump All pumps have independent fuses Main Power Distribution Bus: Main battery contactor 1A Taxi lights Strobe lights Position lights 6A Panel lights Auto pilot Flaps 5A (Intermittent?) Attitude indicator Pitot heat 8A Aux Power Distribution Bus: HSI Roll trim Mac servo 0.2A (intermittent) Yaw trim Mac servo 0.2A (intermittent) Pitch trim Mac servo 0.2A (intermittent) Turn and slip indicator 0.3A GPS (full IFR UPS stack) Nav Com (receive/intermittant transmit) Transponder Audio panel 0.1A Quad fuel gauge Cooling fan for radios VM 1000 As for the fuel pumps, the transfer pumps are Fawcet pumps and the primary and high altitude pumps are Mallory. Emergency gear extension is via hand pump As for the altimeter, rate of climb and airspeed indicator, I do not know the brands or the part numbers for these yet. I will try to sort this out soon. Thanks, Tom Saccio ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Re: John's Lancair - System planning
Hi Bob - I'm flattered and would be pleased to have you put them on your website. As you know, this is always an ongoing work-in-progress and I will also add a MS WORD doc as an amplification of where the project is and what is planned or being massaged. Please let me know where to send the files. The wirebook is in AutoCAD and if needed, I could also add a .DXF file if it would help. Cheers, John Schroeder > > Could you be talked into publishing them? I'd be pleased to post > them on my server and link them for general access by anyone interested. > > Bob . . . ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Dual Alt/ Dual Bat Bus List
Bob, Here is another "Bus" list to review. Any suggestions? Main Bus 1. Main LR-3 OV Sense 2. Main Alt FLD 3. Windshield Defog Fan 4. Electronics cooling Fan 5. AOA Control Box 6. UPSAT - SL 30 - COMM 7. UPSAT - SL 30 - NAV 8. Electric Attitude Indicator 9. Turn & Bank Coordinator 10. Low Oil Pressure / Master on 11. Strobes 12. Starter 13. Electric Trim Indicator 14. Pitot Heat 15. Autopilot Control Unit (CB that can be pulled) 16. Position Lights 17. Landing Light 18. Taxi Light Auxiliary Bus 1. Aux LR-3 OV Sense 2. Aux Alt FLD 3. EFIS 4. EFIS Display 5. GMA 340 Audio Panel 6. GNS 430 comm 7. GNS 430 - Nav 8. GTX 330 Transponder 9. Roll Trim Servo & MkIII Gov. 10. Pitch Trim Servo & MkIII Gov. 11. Annunciator Panel 12. Fuel Boost Pump 13. Fuel Level Sensors Main Battery Bus 1. Primary Electronic Ignition 2. GNS 430 memory 3. SL30 memory 4. Gooseneck Light Pilot Auxiliary Battery Bus 1. Hobbs Meter 2. Gooseneck Light CoPilot 3. Accessory Outlets 4. Auxiliary Power outlets Thanks, Jim ________________________________________________________________________________
Date: Oct 17, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >Hi Bob - > >I'm flattered and would be pleased to have you put them on your website. >As you know, this is always an ongoing work-in-progress and I will also >add a MS WORD doc as an amplification of where the project is and what >is planned or being massaged. > >Please let me know where to send the files. sent them directly to bob.nuckolls(at)cox.net >The wirebook is in AutoCAD and if needed, I could also add a .DXF file >if it would help. Lets look at your planning documentation first. Do I understand you did a spread-sheet/load analysis? Is it an Excel file? Bob . . . ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Re: 17AH battery dimensions
> >Bob: > > I plan on using two 17 amp batteries as recommended. What >company do you recommend for these batteries? I would like to contact them >to acquire the actual dimensions in order to build the platform/trays in the >back of my Lancair ES. How about dowloading: http://www.aeroelectric.com/temp/17AH.pdf Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 17, 2002
Subject: Re: Predicting the Future
In a message dated 10/17/02 8:47:58 AM Eastern Daylight Time, doconnor(at)chartermi.net writes: > BTW, I still have, and use now and then, a K&E slide rule, the Rolls Royce > Silver Phantom of slip sticks... I have a collections of slide rules that I started as people were throwing them away. Don't know if they will ever be worth anything but they are interesting to me. My grown kids had never seen one until recently when I hauled them out. Dale ________________________________________________________________________________
Date: Oct 17, 2002
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
'Kay, I'm really straining my old brain here, and it's just for fun. Didn't K&E stand for Kuenst and Engel? Or am I thinking of K&N? Scott in Vancouver( Hey.look! No capital A) ----- Original Message ----- From: <DWENSING(at)aol.com> Subject: Re: AeroElectric-List: Predicting the Future > > In a message dated 10/17/02 8:47:58 AM Eastern Daylight Time, > doconnor(at)chartermi.net writes: > > > > BTW, I still have, and use now and then, a K&E slide rule, the Rolls Royce > > Silver Phantom of slip sticks... > > I have a collections of slide rules that I started as people were throwing > them away. Don't know if they will ever be worth anything but they are > interesting to me. My grown kids had never seen one until recently when I > hauled them out. > Dale > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 17, 2002
> > >'Kay, I'm really straining my old brain here, and it's just for fun. >Didn't K&E stand for Kuenst and Engel? Or am I thinking of K&N? Keuffel & Esser > > > > > BTW, I still have, and use now and then, a K&E slide rule, the Rolls >Royce > > > Silver Phantom of slip sticks... > > > > I have a collections of slide rules that I started as people were throwing > > them away. Don't know if they will ever be worth anything but they are > > interesting to me. My grown kids had never seen one until recently when I > > hauled them out. Me too. I bill them as the calculator for which batteries and sticking keys are never an issue. Bob . . . ________________________________________________________________________________
Date: Oct 17, 2002
>Eric: It is worse than that. I had a consulting contract for a couple of years with Cubic Optical Systems, who bought K&E's Optical Products Division. They were master craftsmen and technicians, but not too good in the predictions department. TI went to them when they invented the original 4 function electronic calculator. Since every engineer/engineering student in the country had a K&E slide rule and was using K&E graph paper,TI wanted to team and use the K&E name/logo on their calculator. K&E turned them down - thought it might hurt their slide rule business. Guess they were right. I did manage to talk the president out of one of the last of the 6" shirt pocket K&E slide rules in captivity. >Small note about predictions--in 1967 Keuffel & Esser, the sliderule people, >contracted for a sophisticated analysis of technology 1000 years in >the future. >This study generated glowing predictions of domed cities and even 3D >television in >2067, but failed to predict that nobody would need sliderules just 5 >years later. > >Eric M. Jones -- John ________________________________________________________________________________
Date: Oct 18, 2002
I just bought a pair of 17ah RG batteries from http://www.meci.com, part# 140-0094, 15.95 each. Someone posted a link last week with them for 15.95 each, so I jumped on it (thanks whoever posted that link). I bought the pair for use during initial testing and possibly the first year, if they hold up and end up being good quality. Bob says they are pretty much all the same, and these really look good, and have performed well so far, so I tend to agree. The dimensions are about 6.625tall x 7.00wide x 3.00deep. I made my trays out of 2core2 from Lancair. I made them 3.25x7.25 for a 0.25" clearance with a carbon strap that goes over top to hold them in. Pictures are at http://shannon.v8eaters.com/images/lancair/10_2002/ --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of N823ms(at)aol.com Subject: AeroElectric-List: Ed's Lancair-System Planing Bob: I plan on using two 17 amp batteries as recommended. What company do you recommend for these batteries? I would like to contact them to acquire the actual dimensions in order to build the platform/trays in the back of my Lancair ES. Thanks, Ed Silvanic = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: z14
Date: Oct 18, 2002
Bob, (thought this would be simple answers, so it must not have gone through the first time I sent it) I'm finishing the details of my electrical system design for my Lancair Legacy, working on the power grid/contactors right now. To refresh you, it is a dual alt/bat sys, similar to your depiction in z14. dual 17ah bats will be behind the seat with the bat and crossfeed contactors there on a power grid, and there will be a starter (and avionics) power grid on the firewall, and there will be a final contactor bank in the aft fuselage where the hyd pump and air conditioning is. I have a couple of questions though: 1) why is the wire from the starter contactor to the starter shown as 2awg, while the wire feeding it from the batteries is only 4awg. Shouldn't the wire from the bat to starter contactor also be 2awg, especially in a situation like this where there is 7-10 feet between the contactors? 2) is there any reason I can't move the shunt to the other side of the contactor to measure amp draw on the bat? Likewise, I will pull the crossfeed and starter feed off before the shunt so there is no drop on it and to eliminate any problems there. If this doesn't make sense, I can include a drawing. Heres basically what I have in mind: B+ 0--O contr 0--0--0 bat_shunt 0--0--0 alt_shunt 0--0 anl30 0--0 alt | | | | xfeed main cont & bus starter --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Subject: Re: Ed's Lancair-System Planing
Date: Oct 18, 2002
Ed I am building a ES and I used B and C. I also have pictures of the bracket I built. see the link Ron Raby N829R http://www.bandcspecialty.com/ ----- Original Message ----- From: <N823ms(at)aol.com> Subject: AeroElectric-List: Ed's Lancair-System Planing > > Bob: > > I plan on using two 17 amp batteries as recommended. What > company do you recommend for these batteries? I would like to contact them > to acquire the actual dimensions in order to build the platform/trays in the > back of my Lancair ES. > > Thanks, > > Ed Silvanic > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: K&E
Date: Oct 18, 2002
Keuffel und Esser Ferg ________________________________________________________________________________
Subject: s701/2 contactors
Date: Oct 18, 2002
Bob, Working on the layout of my power grids, and was wondering if I could get some dimensions on the s701 and s702 contactors? Also, I assume you strongly suggest using the s702 for the starter versus using another s701? Last, how would the s701 be suited for an avionics relay...I know it would be way overrated, but I'm wondering about its robustness to cycles, compared to your s704 relay or another bosch automotive style relay. I know you strongly discourage avionic switches and relays, but in my case I feel its warranted with the SFS EFIS system, as well as a few other components that don't have power switches....therefore, with it warranted, I want it to be as failproof as possible, so I'm looking for a good relay. Here is an equipment list and its amp draw, protection, location and buss: PROT PANEL PANEL DESCRIPTION AMPS SIZE LABEL GROUP BUS MAIN BUSS Landing Gear Pump 30.00 40 HYD PUMP bulkhead MAIN BUSS Air Cond Compressor Motor 35.00 35 A/C COMP bulkhead MAIN BUSS Air Conditioning Fan Motor 3.00 5 A/C FAN bulkhead MAIN BUSS total 68.00 80 3 Sierra FS screen 5.00 5 EFIS MFD 2 PRI AV MAIN BUSS Avidyne MFD 4.00 4 MOVING MAP PRI AV MAIN BUSS Frantz AOA 0.50 2 AOA PRI AV MAIN BUSS Trutrak Autopilot 1.00 7 AUTO PILOT PRI AV MAIN BUSS BFG Stormscope 0.50 3 STORM SCOPE PRI AV MAIN BUSS Merlin Weather Datalnk 0.75 3 DATA LINK PRI AV MAIN BUSS Garmin GPS/NAV/COMM 0.50 5 NAV/COM 2 PRI AV MAIN BUSS 0.50 2 GPS PRI AV MAIN BUSS total 12.75 31 8 Flaps Motor 5.00 10 FLAP MOTOR PRIMARY MAIN BUSS Speed Brakes 0.25 4 SPEED BRAKE PRIMARY MAIN BUSS Fuel Trans Pump 1.50 5 TRANS PUMP PRIMARY MAIN BUSS Fuel Boost Pump 1.75 10 BOOST PUMP PRIMARY MAIN BUSS Starter, other relays 0.50 7 OTHER RELAY PRIMARY MAIN BUSS Pitot Heat 7.25 10 PITOT HEAT PRIMARY MAIN BUSS Mountain High Oxygen System 0.50 2 O2 SYSTEM PRIMARY MAIN BUSS JPI Slim Line Volt/Amp Disp 0.50 1 VOLT/AMP PRIMARY MAIN BUSS Strobe Lights 2.75 7 STROBES PRIMARY MAIN BUSS Nav Lights 2.75 7 NAV LIGHTS PRIMARY MAIN BUSS Taxi Lights 4.00 7 TAXI LIGHTS PRIMARY MAIN BUSS Land Lights 4.00 7 LAND LIGHTS PRIMARY MAIN BUSS Door Seal 0.50 5 DOOR SEAL PRIMARY MAIN BUSS CD/DVD Player 0.50 2 CD/DVD SYS PRIMARY MAIN BUSS Turn Coordinator 0.75 2 TURN COORD PRIMARY MAIN BUSS Main Voltage Regulator 2.00 5 MAIN V REG PRIMARY MAIN BUSS Warning Lights 0.50 2 WARN LIGHTS PRIMARY MAIN BUSS Dimmable Lighting 1.00 7 PANEL LIGHT PRIMARY MAIN BUSS Cabin Lights 0.25 5 CABIN LIGHT PRIMARY MAIN BATT Power Points 2.00 5 POWER POINT PRIMARY MAIN BATT Ryan TCAD 0.75 5 RYAN TCAD PRIMARY MAIN BUSS total 39.00 115 21 TOTAL MAIN BUSS 119.7 226 32 AUX BUSS Sierra FS screen 5.00 5 EFIS MFD 1 ESS AV AUX BUSS Solid State Attitude Gyro 0.50 5 EFIS AHRS ESS AV AUX BUSS PS Engineering audio panel 0.50 3 AUDIO PANEL ESS AV AUX BUSS Apollo Comm 0.50 5 UPS COM 1 ESS AV AUX BUSS Garmin Transponder 1.50 2 TRAN/ENCODE ESS AV AUX BUSS ??? SPARE ESS AV AUX BUSS total 8.00 20 6 Trim System Motors 1.00 3 TRIM ESS AUX BUSS Aux Voltage Regulator 2.00 5 AUX V REG ESS AUX BUSS Sierra Engine Data Unit & GPS 1.00 5 EAU/GPS ESS AUX BUSS Landing Gear Relays 0.50 2 GEAR RELAYS ESS AUX BUSS Gear Indicator Lights 0.50 1 GEAR LEDS ESS AUX BUSS Attitude Indicator 0.75 2 ATT GYRO ESS AUX BUSS ??? SPARE ESS AUX BUSS total 5.75 18 4 TOTAL AUX BUSS 13.75 38 10 --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 18, 2002
Bob, Working on the layout of my power grids, and was wondering if I could get some dimensions on the s701 and s702 contactors? Also, I assume you strongly suggest using the s702 for the starter versus using another s701? Last, how would the s701 be suited for an avionics relay...I know it would be way overrated, but I'm wondering about its robustness to cycles, compared to your s704 relay or another bosch automotive style relay. I know you strongly discourage avionic switches and relays, but in my case I feel its warranted with the SFS EFIS system, as well as a few other components that don't have power switches....therefore, with it warranted, I want it to be as failproof as possible, so I'm looking for a good relay. Here is an equipment list and its amp draw, protection, location and buss (I have this in spreadsheet form if you'd like to post it): PROT PANEL PANEL DESCRIPTION AMPS SIZE LABEL GROUP BUS MAIN BUSS Landing Gear Pump 30.00 40 HYD PUMP bulkhead MAIN BUSS Air Cond Compressor Motor 35.00 35 A/C COMP bulkhead MAIN BUSS Air Conditioning Fan Motor 3.00 5 A/C FAN bulkhead MAIN BUSS total 68.00 80 3 Sierra FS screen 5.00 5 EFIS MFD 2 PRI AV MAIN BUSS Avidyne MFD 4.00 4 MOVING MAP PRI AV MAIN BUSS Frantz AOA 0.50 2 AOA PRI AV MAIN BUSS Trutrak Autopilot 1.00 7 AUTO PILOT PRI AV MAIN BUSS BFG Stormscope 0.50 3 STORM SCOPE PRI AV MAIN BUSS Merlin Weather Datalnk 0.75 3 DATA LINK PRI AV MAIN BUSS Garmin GPS/NAV/COMM 0.50 5 NAV/COM 2 PRI AV MAIN BUSS 0.50 2 GPS PRI AV MAIN BUSS total 12.75 31 8 Flaps Motor 5.00 10 FLAP MOTOR PRIMARY MAIN BUSS Speed Brakes 0.25 4 SPEED BRAKE PRIMARY MAIN BUSS Fuel Trans Pump 1.50 5 TRANS PUMP PRIMARY MAIN BUSS Fuel Boost Pump 1.75 10 BOOST PUMP PRIMARY MAIN BUSS Starter, other relays 0.50 7 OTHER RELAY PRIMARY MAIN BUSS Pitot Heat 7.25 10 PITOT HEAT PRIMARY MAIN BUSS Mountain High Oxygen System 0.50 2 O2 SYSTEM PRIMARY MAIN BUSS JPI Slim Line Volt/Amp Disp 0.50 1 VOLT/AMP PRIMARY MAIN BUSS Strobe Lights 2.75 7 STROBES PRIMARY MAIN BUSS Nav Lights 2.75 7 NAV LIGHTS PRIMARY MAIN BUSS Taxi Lights 4.00 7 TAXI LIGHTS PRIMARY MAIN BUSS Land Lights 4.00 7 LAND LIGHTS PRIMARY MAIN BUSS Door Seal 0.50 5 DOOR SEAL PRIMARY MAIN BUSS CD/DVD Player 0.50 2 CD/DVD SYS PRIMARY MAIN BUSS Turn Coordinator 0.75 2 TURN COORD PRIMARY MAIN BUSS Main Voltage Regulator 2.00 5 MAIN V REG PRIMARY MAIN BUSS Warning Lights 0.50 2 WARN LIGHTS PRIMARY MAIN BUSS Dimmable Lighting 1.00 7 PANEL LIGHT PRIMARY MAIN BUSS Cabin Lights 0.25 5 CABIN LIGHT PRIMARY MAIN BATT Power Points 2.00 5 POWER POINT PRIMARY MAIN BATT Ryan TCAD 0.75 5 RYAN TCAD PRIMARY MAIN BUSS total 39.00 115 21 TOTAL MAIN BUSS 119.7 226 32 AUX BUSS Sierra FS screen 5.00 5 EFIS MFD 1 ESS AV AUX BUSS Solid State Attitude Gyro 0.50 5 EFIS AHRS ESS AV AUX BUSS PS Engineering audio panel 0.50 3 AUDIO PANEL ESS AV AUX BUSS Apollo Comm 0.50 5 UPS COM 1 ESS AV AUX BUSS Garmin Transponder 1.50 2 TRAN/ENCODE ESS AV AUX BUSS ??? SPARE ESS AV AUX BUSS total 8.00 20 6 Trim System Motors 1.00 3 TRIM ESS AUX BUSS Aux Voltage Regulator 2.00 5 AUX V REG ESS AUX BUSS Sierra Engine Data Unit & GPS 1.00 5 EAU/GPS ESS AUX BUSS Landing Gear Relays 0.50 2 GEAR RELAYS ESS AUX BUSS Gear Indicator Lights 0.50 1 GEAR LEDS ESS AUX BUSS Attitude Indicator 0.75 2 ATT GYRO ESS AUX BUSS ??? SPARE ESS AUX BUSS total 5.75 18 4 TOTAL AUX BUSS 13.75 38 10 --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 18, 2002
Wow, what a mess that turned out, let me try again: DESCRIPTION AMPS MAIN BUS =================================== (bus in bulkhead) Landing Gear Pump 30.00 Air Cond Compressor Motor 35.00 Air Conditioning Fan Motor 3.00 sub 68.00 (pri avionics bus, panel) Sierra FS screen 5.00 Avidyne MFD 4.00 Frantz AOA 0.50 Trutrak Autopilot 1.00 BFG Stormscope 0.50 Merlin Weather Datalnk 0.75 Garmin GPS/NAV/COMM 0.50 0.50 sub 12.75 (main bus in panel) Flaps Motor 5.00 Speed Brakes 0.25 Fuel Trans Pump 1.50 Fuel Boost Pump 1.75 Starter, other relays 0.50 Pitot Heat 7.25 Mountain High Oxygen System 0.50 JPI Slim Line Volt/Amp Disp 0.50 Strobe Lights 2.75 Nav Lights 2.75 Taxi Lights 4.00 Land Lights 4.00 Door Seal 0.50 CD/DVD Player 0.50 Turn Coordinator 0.75 Main Voltage Regulator 2.00 Warning Lights 0.50 Dimmable Lighting 1.00 Cabin Lights 0.25 (batt bus) Power Points 2.00 (batt bus) Ryan TCAD 0.75 sub 39.00 TOTAL MAIN BUS 119.75 AUX BUSS (ess avionics bus, panel) Sierra FS screen 5.00 Solid State Attitude Gyro 0.50 PS Engineering audio panel 0.50 Apollo Comm 0.50 Garmin Transponder 1.50 Spare ??? sub 8.00 (aux buss, panel) Trim System Motors 1.00 Aux Voltage Regulator 2.00 Sierra Engine Data Unit & GPS 1.00 Landing Gear Relays 0.50 Gear Indicator Lights 0.50 Attitude Indicator 0.75 Spare ??? sub 5.75 TOTAL AUX BUSS 13.75 I have this in spreadsheet form if you would like to post it. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Shannon Knoepflein Subject: AeroElectric-List: s701/2 contactors Bob, Working on the layout of my power grids, and was wondering if I could get some dimensions on the s701 and s702 contactors? Also, I assume you strongly suggest using the s702 for the starter versus using another s701? Last, how would the s701 be suited for an avionics relay...I know it would be way overrated, but I'm wondering about its robustness to cycles, compared to your s704 relay or another bosch automotive style relay. I know you strongly discourage avionic switches and relays, but in my case I feel its warranted with the SFS EFIS system, as well as a few other components that don't have power switches....therefore, with it warranted, I want it to be as failproof as possible, so I'm looking for a good relay. Here is an equipment list and its amp draw, protection, location and buss: PROT PANEL PANEL DESCRIPTION AMPS SIZE LABEL GROUP BUS MAIN BUSS Landing Gear Pump 30.00 40 HYD PUMP bulkhead MAIN BUSS Air Cond Compressor Motor 35.00 35 A/C COMP bulkhead MAIN BUSS Air Conditioning Fan Motor 3.00 5 A/C FAN bulkhead MAIN BUSS total 68.00 80 3 Sierra FS screen 5.00 5 EFIS MFD 2 PRI AV MAIN BUSS Avidyne MFD 4.00 4 MOVING MAP PRI AV MAIN BUSS Frantz AOA 0.50 2 AOA PRI AV MAIN BUSS Trutrak Autopilot 1.00 7 AUTO PILOT PRI AV MAIN BUSS BFG Stormscope 0.50 3 STORM SCOPE PRI AV MAIN BUSS Merlin Weather Datalnk 0.75 3 DATA LINK PRI AV MAIN BUSS Garmin GPS/NAV/COMM 0.50 5 NAV/COM 2 PRI AV MAIN BUSS 0.50 2 GPS PRI AV MAIN BUSS total 12.75 31 8 Flaps Motor 5.00 10 FLAP MOTOR PRIMARY MAIN BUSS Speed Brakes 0.25 4 SPEED BRAKE PRIMARY MAIN BUSS Fuel Trans Pump 1.50 5 TRANS PUMP PRIMARY MAIN BUSS Fuel Boost Pump 1.75 10 BOOST PUMP PRIMARY MAIN BUSS Starter, other relays 0.50 7 OTHER RELAY PRIMARY MAIN BUSS Pitot Heat 7.25 10 PITOT HEAT PRIMARY MAIN BUSS Mountain High Oxygen System 0.50 2 O2 SYSTEM PRIMARY MAIN BUSS JPI Slim Line Volt/Amp Disp 0.50 1 VOLT/AMP PRIMARY MAIN BUSS Strobe Lights 2.75 7 STROBES PRIMARY MAIN BUSS Nav Lights 2.75 7 NAV LIGHTS PRIMARY MAIN BUSS Taxi Lights 4.00 7 TAXI LIGHTS PRIMARY MAIN BUSS Land Lights 4.00 7 LAND LIGHTS PRIMARY MAIN BUSS Door Seal 0.50 5 DOOR SEAL PRIMARY MAIN BUSS CD/DVD Player 0.50 2 CD/DVD SYS PRIMARY MAIN BUSS Turn Coordinator 0.75 2 TURN COORD PRIMARY MAIN BUSS Main Voltage Regulator 2.00 5 MAIN V REG PRIMARY MAIN BUSS Warning Lights 0.50 2 WARN LIGHTS PRIMARY MAIN BUSS Dimmable Lighting 1.00 7 PANEL LIGHT PRIMARY MAIN BUSS Cabin Lights 0.25 5 CABIN LIGHT PRIMARY MAIN BATT Power Points 2.00 5 POWER POINT PRIMARY MAIN BATT Ryan TCAD 0.75 5 RYAN TCAD PRIMARY MAIN BUSS total 39.00 115 21 TOTAL MAIN BUSS 119.7 226 32 AUX BUSS Sierra FS screen 5.00 5 EFIS MFD 1 ESS AV AUX BUSS Solid State Attitude Gyro 0.50 5 EFIS AHRS ESS AV AUX BUSS PS Engineering audio panel 0.50 3 AUDIO PANEL ESS AV AUX BUSS Apollo Comm 0.50 5 UPS COM 1 ESS AV AUX BUSS Garmin Transponder 1.50 2 TRAN/ENCODE ESS AV AUX BUSS ??? SPARE ESS AV AUX BUSS total 8.00 20 6 Trim System Motors 1.00 3 TRIM ESS AUX BUSS Aux Voltage Regulator 2.00 5 AUX V REG ESS AUX BUSS Sierra Engine Data Unit & GPS 1.00 5 EAU/GPS ESS AUX BUSS Landing Gear Relays 0.50 2 GEAR RELAYS ESS AUX BUSS Gear Indicator Lights 0.50 1 GEAR LEDS ESS AUX BUSS Attitude Indicator 0.75 2 ATT GYRO ESS AUX BUSS ??? SPARE ESS AUX BUSS total 5.75 18 4 TOTAL AUX BUSS 13.75 38 10 --- Shannon Knoepflein <---> kycshann(at)kyol.net = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 18, 2002
Subject: RE: Portalac battery bargains
> > >I just bought a pair of 17ah RG batteries from http://www.meci.com, >part# 140-0094, 15.95 each. Someone posted a link last week with them >for 15.95 each, so I jumped on it (thanks whoever posted that link). I >bought the pair for use during initial testing and possibly the first >year, if they hold up and end up being good quality. Bob says they are >pretty much all the same, and these really look good, and have performed >well so far, so I tend to agree. Don't know as I would call them "pretty much the same" . . . If one were going to use these batteries in a long-term application where they were regularly called upon to deliver significant amounts of energy (deep discharge cycles) I'm sure you will find significant differences between the low-dollar products and premium products like the Hawkers. Our ability to get adequate performance from about ANY battery hinges on what we're going to call "service life". We can choose to (1) periodic capacity check and change out when remaining capacity no longer serves our minimum endurance needs or (2) do periodic changeouts at intervals so short that the absolute quality of the battery is not significant. Adopting the first technique gives us detailed information about the battery's real capabilities but it takes and investment of time and tools to add yet another activity to the maintenance tasks on our airplanes. We've deduced that "buy-em-cheap-and-change-them-often" offers an equivalent level of reliability for the operation of the airplane without investing in a science project that bares the soul of every battery. I checked out the website cited and note that the company running this service seems to dabble in a bit of everything with no full line of anything. This suggests an operation that deals in industrial surplus. This is not an automatic mark against them or the products they offer. I buy a LOT of components from surplus dealers. I'll suggest this raises a flag of doubt as to how old the batteries may be and how well cared for since new. Were these batteries originally purchased by a company now bankrupt? Did they sit in a hot warehouse for a couple of years while a bankruptcy court set the rules of liquidation? Other companies sell the same battery in the $50-70 range which is at least a suggestion that normal procurement costs of this battery are to high to justify a regular retail price of $16. I'd never heard of the brand offered so I poked around on the 'net and found the company's website at http://www.gsbattery.com/info.html and their specifications for the PE12V17 battery at: http://www.gsbattery.com/sla/pe12v17/pe12v17.html The whole line of Portalac offerings can be viewed at: http://www.gsbattery.com/sla/masterlinecard.htm where you will see that this is not the hottest battery offered in terms of high-rate output (see PX series). However I do note on the spec sheet for the PE12V17, they claim to support 255A for 5 seconds. A pair of batteries in parallel would be good for about 510A for 5 seconds or 225A for longer. All-in-all, if the battery is in good shape, should perform well in a dual battery airplane. Here I learned that the battery is a Japanese import and GS Battery doesn't make them here in the US. This raises yet another flag suggesting that there are extra layers of marketing between you as a user and the original manufacturer. So, it still boils down to a fine example of "caveat emptor" . . . these batteries may well be an excellent value. I'd certainly give them a try but be suspicious/critical. Irrespective of your findings (good or bad) be sure to let everyone on the list hear about it! Bob . . . ________________________________________________________________________________
Date: Oct 18, 2002
I bought them with your exact ideology in mind: buy em cheap and replace them often. I plan to replace them either before the first flight, or after the initial 40 hour testing phase. I got them cheap so I could use them to test everything in the plane. If they will still start it when its time in a couple months, then I'll still use them, and replace them shortly after. If not, I'll replace them before. Either way, I'll post the results. I thought for 30 bucks, I couldn't go wrong to at least try them out and let me test everything. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Portalac battery bargains > > >I just bought a pair of 17ah RG batteries from http://www.meci.com, >part# 140-0094, 15.95 each. Someone posted a link last week with them >for 15.95 each, so I jumped on it (thanks whoever posted that link). I >bought the pair for use during initial testing and possibly the first >year, if they hold up and end up being good quality. Bob says they are >pretty much all the same, and these really look good, and have performed >well so far, so I tend to agree. Don't know as I would call them "pretty much the same" . . . If one were going to use these batteries in a long-term application where they were regularly called upon to deliver significant amounts of energy (deep discharge cycles) I'm sure you will find significant differences between the low-dollar products and premium products like the Hawkers. Our ability to get adequate performance from about ANY battery hinges on what we're going to call "service life". We can choose to (1) periodic capacity check and change out when remaining capacity no longer serves our minimum endurance needs or (2) do periodic changeouts at intervals so short that the absolute quality of the battery is not significant. Adopting the first technique gives us detailed information about the battery's real capabilities but it takes and investment of time and tools to add yet another activity to the maintenance tasks on our airplanes. We've deduced that "buy-em-cheap-and-change-them-often" offers an equivalent level of reliability for the operation of the airplane without investing in a science project that bares the soul of every battery. I checked out the website cited and note that the company running this service seems to dabble in a bit of everything with no full line of anything. This suggests an operation that deals in industrial surplus. This is not an automatic mark against them or the products they offer. I buy a LOT of components from surplus dealers. I'll suggest this raises a flag of doubt as to how old the batteries may be and how well cared for since new. Were these batteries originally purchased by a company now bankrupt? Did they sit in a hot warehouse for a couple of years while a bankruptcy court set the rules of liquidation? Other companies sell the same battery in the $50-70 range which is at least a suggestion that normal procurement costs of this battery are to high to justify a regular retail price of $16. I'd never heard of the brand offered so I poked around on the 'net and found the company's website at http://www.gsbattery.com/info.html and their specifications for the PE12V17 battery at: http://www.gsbattery.com/sla/pe12v17/pe12v17.html The whole line of Portalac offerings can be viewed at: http://www.gsbattery.com/sla/masterlinecard.htm where you will see that this is not the hottest battery offered in terms of high-rate output (see PX series). However I do note on the spec sheet for the PE12V17, they claim to support 255A for 5 seconds. A pair of batteries in parallel would be good for about 510A for 5 seconds or 225A for longer. All-in-all, if the battery is in good shape, should perform well in a dual battery airplane. Here I learned that the battery is a Japanese import and GS Battery doesn't make them here in the US. This raises yet another flag suggesting that there are extra layers of marketing between you as a user and the original manufacturer. So, it still boils down to a fine example of "caveat emptor" . . . these batteries may well be an excellent value. I'd certainly give them a try but be suspicious/critical. Irrespective of your findings (good or bad) be sure to let everyone on the list hear about it! Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Subject: Re: s701/2 contactors
Date: Oct 18, 2002
Shannon, suggest that you peruse the archives as this topic has been covered in depth as to why specific relays are used for starters versus what is used for a continuous contactor... Also, BOb's book goes into detail about this topic.. Cheers ... Denny ----- Original Message ----- From: "Shannon Knoepflein" <kycshann(at)kyol.net> Subject: AeroElectric-List: s701/2 contactors > > Bob, > > Working on the layout of my power grids, and was wondering if I could > get some dimensions on the s701 and s702 contactors? Also, I assume you > strongly suggest using the s702 for the starter versus using another > s701? Last, how would the s701 be suited for an avionics relay...I know > it would be way overrated, but I'm wondering about its robustness to > cycles, compared to your s704 relay or another bosch automotive style > relay. I know you strongly discourage avionic switches and relays, but > in my case I feel its warranted with the SFS EFIS system, as well as a > few other components that don't have power switches....therefore, with > it warranted, I want it to be as failproof as possible, so I'm looking > for a good relay. > > Here is an equipment list and its amp draw, protection, location and > buss: > > PROT PANEL > PANEL > DESCRIPTION AMPS SIZE LABEL > GROUP BUS > > MAIN BUSS > Landing Gear Pump 30.00 40 HYD PUMP > bulkhead MAIN BUSS > Air Cond Compressor Motor 35.00 35 A/C COMP bulkhead > MAIN BUSS > Air Conditioning Fan Motor 3.00 5 A/C FAN bulkhead > MAIN BUSS > total 68.00 80 > 3 > > Sierra FS screen 5.00 5 EFIS MFD 2 > PRI AV MAIN BUSS Avidyne MFD 4.00 4 > MOVING MAP PRI AV MAIN BUSS > Frantz AOA 0.50 2 AOA > PRI AV MAIN BUSS > Trutrak Autopilot 1.00 7 AUTO PILOT > PRI AV MAIN BUSS > BFG Stormscope 0.50 3 STORM SCOPE PRI AV > MAIN BUSS Merlin Weather Datalnk 0.75 3 DATA > LINK PRI AV MAIN BUSS Garmin GPS/NAV/COMM 0.50 5 > NAV/COM 2 PRI AV MAIN BUSS > 0.50 2 GPS > PRI AV MAIN BUSS total 12.75 31 > 8 > > Flaps Motor 5.00 10 FLAP MOTOR > PRIMARY MAIN BUSS > Speed Brakes 0.25 4 SPEED BRAKE PRIMARY > MAIN BUSS > Fuel Trans Pump 1.50 5 TRANS PUMP PRIMARY > MAIN BUSS > Fuel Boost Pump 1.75 10 BOOST PUMP PRIMARY > MAIN BUSS > Starter, other relays 0.50 7 OTHER RELAY PRIMARY > MAIN BUSS > Pitot Heat 7.25 10 PITOT HEAT > PRIMARY MAIN BUSS > Mountain High Oxygen System 0.50 2 O2 SYSTEM PRIMARY > MAIN BUSS > JPI Slim Line Volt/Amp Disp 0.50 1 VOLT/AMP PRIMARY > MAIN BUSS > Strobe Lights 2.75 7 STROBES PRIMARY MAIN > BUSS > Nav Lights 2.75 7 NAV LIGHTS > PRIMARY MAIN BUSS > Taxi Lights 4.00 7 TAXI LIGHTS > PRIMARY MAIN BUSS > Land Lights 4.00 7 LAND LIGHTS > PRIMARY MAIN BUSS > Door Seal 0.50 5 DOOR SEAL > PRIMARY MAIN BUSS > CD/DVD Player 0.50 2 CD/DVD SYS PRIMARY > MAIN BUSS > Turn Coordinator 0.75 2 TURN COORD > PRIMARY MAIN BUSS > Main Voltage Regulator 2.00 5 MAIN V REG PRIMARY > MAIN BUSS > Warning Lights 0.50 2 WARN LIGHTS PRIMARY > MAIN BUSS > Dimmable Lighting 1.00 7 PANEL LIGHT > PRIMARY MAIN BUSS > Cabin Lights 0.25 5 CABIN LIGHT PRIMARY > MAIN BATT > Power Points 2.00 5 POWER POINT PRIMARY > MAIN BATT > Ryan TCAD 0.75 5 RYAN TCAD > PRIMARY MAIN BUSS > total 39.00 115 > 21 > > TOTAL MAIN BUSS 119.7 226 32 > > > AUX BUSS > Sierra FS screen 5.00 5 EFIS MFD 1 > ESS AV AUX BUSS > Solid State Attitude Gyro 0.50 5 EFIS AHRS ESS AV > AUX BUSS > PS Engineering audio panel 0.50 3 AUDIO PANEL ESS AV > AUX BUSS > Apollo Comm 0.50 5 UPS COM 1 > ESS AV AUX BUSS > Garmin Transponder 1.50 2 TRAN/ENCODE ESS AV > AUX BUSS > ??? SPARE > ESS AV AUX BUSS > total 8.00 20 > 6 > > Trim System Motors 1.00 3 TRIM ESS > AUX BUSS > Aux Voltage Regulator 2.00 5 AUX V REG ESS > AUX BUSS > Sierra Engine Data Unit & GPS 1.00 5 EAU/GPS ESS > AUX BUSS > Landing Gear Relays 0.50 2 GEAR RELAYS ESS > AUX BUSS > Gear Indicator Lights 0.50 1 GEAR LEDS ESS > AUX BUSS > Attitude Indicator 0.75 2 ATT GYRO ESS > AUX BUSS > ??? SPARE > ESS AUX BUSS > total 5.75 18 > 4 > > TOTAL AUX BUSS 13.75 38 10 > > --- > Shannon Knoepflein <---> kycshann(at)kyol.net > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 18, 2002
Ron: Thanks for your reply. I really would like to see the pictures of your battery box/tray and bracket. I can't seem to find your link. Went to your design website and B&C, but no luck. What am I doing wrong. On another topic. I am getting ready to closeout the left aileron. How did you route your wires from your Ray Allen servo? I would like to run the wires in a small plastic tubing so as to rerun wire should I need to. This would be from the outboard side of the aileron to the wing tip area, and of course from there through the leading edge 1 inch conduit. Lastly, should I want to replace or inspect the servo I am looking for some connectors. I would also use some connectors so I can remove the aileron as well. Is this too much? Some people have ran there wires toward the inboard side down the trailing edge of the wing. Getting ready to install a cabin blower to the ventilation system from the vertical stab NACA scoop. I have friend that is finishing his IVP, and decided to put in AC, so he's going to let me have his box that he made for the blower. Any recommendations here. Engine. I just ordered an IO-520"D," 300hp, 60amp ALT, rear driven by belt with the starter. Will be doing Bob's Z-14, Dual ALT/BAT system. Considering electronic ignition, however, I have no clue what's out there or the advantages thereof. Are you planning electronic ignition? and if so what do you recommend, and are you going MAG/EI or dual EI. Avionics: Just ordered a Garman stack: 340/GNS-530,GNS-430,GTX-327. Autopilot: TruTrak 200/250? Sorry I asked you so many questions. I am ready to close the left wing. The left flap is closed out, and of course the aileron if I can figure out the right wiring. I have the vertical stab/hrizontal stab, and have a rudder hanging. Target date: Next summer some time. ________________________________________________________________________________
Date: Oct 18, 2002
Thanks, will do. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis O'Connor Subject: Re: AeroElectric-List: s701/2 contactors Shannon, suggest that you peruse the archives as this topic has been covered in depth as to why specific relays are used for starters versus what is used for a continuous contactor... Also, BOb's book goes into detail about this topic.. Cheers ... Denny ----- Original Message ----- From: "Shannon Knoepflein" <kycshann(at)kyol.net> Subject: AeroElectric-List: s701/2 contactors > > Bob, > > Working on the layout of my power grids, and was wondering if I could > get some dimensions on the s701 and s702 contactors? Also, I assume you > strongly suggest using the s702 for the starter versus using another > s701? Last, how would the s701 be suited for an avionics relay...I know > it would be way overrated, but I'm wondering about its robustness to > cycles, compared to your s704 relay or another bosch automotive style > relay. I know you strongly discourage avionic switches and relays, but > in my case I feel its warranted with the SFS EFIS system, as well as a > few other components that don't have power switches....therefore, with > it warranted, I want it to be as failproof as possible, so I'm looking > for a good relay. > > Here is an equipment list and its amp draw, protection, location and > buss: > > PROT PANEL > PANEL > DESCRIPTION AMPS SIZE LABEL > GROUP BUS > > MAIN BUSS > Landing Gear Pump 30.00 40 HYD PUMP > bulkhead MAIN BUSS > Air Cond Compressor Motor 35.00 35 A/C COMP bulkhead > MAIN BUSS > Air Conditioning Fan Motor 3.00 5 A/C FAN bulkhead > MAIN BUSS > total 68.00 80 > 3 > > Sierra FS screen 5.00 5 EFIS MFD 2 > PRI AV MAIN BUSS Avidyne MFD 4.00 4 > MOVING MAP PRI AV MAIN BUSS > Frantz AOA 0.50 2 AOA > PRI AV MAIN BUSS > Trutrak Autopilot 1.00 7 AUTO PILOT > PRI AV MAIN BUSS > BFG Stormscope 0.50 3 STORM SCOPE PRI AV > MAIN BUSS Merlin Weather Datalnk 0.75 3 DATA > LINK PRI AV MAIN BUSS Garmin GPS/NAV/COMM 0.50 5 > NAV/COM 2 PRI AV MAIN BUSS > 0.50 2 GPS > PRI AV MAIN BUSS total 12.75 31 > 8 > > Flaps Motor 5.00 10 FLAP MOTOR > PRIMARY MAIN BUSS > Speed Brakes 0.25 4 SPEED BRAKE PRIMARY > MAIN BUSS > Fuel Trans Pump 1.50 5 TRANS PUMP PRIMARY > MAIN BUSS > Fuel Boost Pump 1.75 10 BOOST PUMP PRIMARY > MAIN BUSS > Starter, other relays 0.50 7 OTHER RELAY PRIMARY > MAIN BUSS > Pitot Heat 7.25 10 PITOT HEAT > PRIMARY MAIN BUSS > Mountain High Oxygen System 0.50 2 O2 SYSTEM PRIMARY > MAIN BUSS > JPI Slim Line Volt/Amp Disp 0.50 1 VOLT/AMP PRIMARY > MAIN BUSS > Strobe Lights 2.75 7 STROBES PRIMARY MAIN > BUSS > Nav Lights 2.75 7 NAV LIGHTS > PRIMARY MAIN BUSS > Taxi Lights 4.00 7 TAXI LIGHTS > PRIMARY MAIN BUSS > Land Lights 4.00 7 LAND LIGHTS > PRIMARY MAIN BUSS > Door Seal 0.50 5 DOOR SEAL > PRIMARY MAIN BUSS > CD/DVD Player 0.50 2 CD/DVD SYS PRIMARY > MAIN BUSS > Turn Coordinator 0.75 2 TURN COORD > PRIMARY MAIN BUSS > Main Voltage Regulator 2.00 5 MAIN V REG PRIMARY > MAIN BUSS > Warning Lights 0.50 2 WARN LIGHTS PRIMARY > MAIN BUSS > Dimmable Lighting 1.00 7 PANEL LIGHT > PRIMARY MAIN BUSS > Cabin Lights 0.25 5 CABIN LIGHT PRIMARY > MAIN BATT > Power Points 2.00 5 POWER POINT PRIMARY > MAIN BATT > Ryan TCAD 0.75 5 RYAN TCAD > PRIMARY MAIN BUSS > total 39.00 115 > 21 > > TOTAL MAIN BUSS 119.7 226 32 > > > AUX BUSS > Sierra FS screen 5.00 5 EFIS MFD 1 > ESS AV AUX BUSS > Solid State Attitude Gyro 0.50 5 EFIS AHRS ESS AV > AUX BUSS > PS Engineering audio panel 0.50 3 AUDIO PANEL ESS AV > AUX BUSS > Apollo Comm 0.50 5 UPS COM 1 > ESS AV AUX BUSS > Garmin Transponder 1.50 2 TRAN/ENCODE ESS AV > AUX BUSS > ??? SPARE > ESS AV AUX BUSS > total 8.00 20 > 6 > > Trim System Motors 1.00 3 TRIM ESS > AUX BUSS > Aux Voltage Regulator 2.00 5 AUX V REG ESS > AUX BUSS > Sierra Engine Data Unit & GPS 1.00 5 EAU/GPS ESS > AUX BUSS > Landing Gear Relays 0.50 2 GEAR RELAYS ESS > AUX BUSS > Gear Indicator Lights 0.50 1 GEAR LEDS ESS > AUX BUSS > Attitude Indicator 0.75 2 ATT GYRO ESS > AUX BUSS > ??? SPARE > ESS AUX BUSS > total 5.75 18 > 4 > > TOTAL AUX BUSS 13.75 38 10 > > --- > Shannon Knoepflein <---> kycshann(at)kyol.net > > http://www.matronics.com/browselist/aeroelectric-list > > = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 18, 2002
> > >I bought them with your exact ideology in mind: buy em cheap and >replace them often. I plan to replace them either before the first >flight, or after the initial 40 hour testing phase. I got them cheap so >I could use them to test everything in the plane. If they will still >start it when its time in a couple months, then I'll still use them, and >replace them shortly after. If not, I'll replace them before. Either >way, I'll post the results. I thought for 30 bucks, I couldn't go wrong >to at least try them out and let me test everything. sounds like a PLAN . . . Bob . . . ________________________________________________________________________________
Subject: Microair T-2000 SFL Transponders
Date: Oct 18, 2002
Hello, -listers! Took Dave's advice and called American Avionics to inquire about Microair T-2000 SFL transponders and the sales guy said they just got 4 in today (Friday, Oct 18) and he had 2 left! I got one of the two remaining and it was quitting time on Friday, so if you call early on Monday (Oct 21), you might get the last of their most recent shipment. Price is $1195.00 U.S. Good luck. Bob, when the one I ordered from you comes in, please give it to the next guy down on the list. Thanks. I would still like your encoder, antenna and harness, however, if I can still get that within a couple of weeks. If that's not possible, I'll go another route. Thanks again. Ken Brooks RV-8 Roscoe, IL -- wishing I owned stock in Microair ________________________________________________________________________________
Subject: American Avionics Sales Dept - was Microair T2000 SFL
Transponder
Date: Oct 18, 2002
Ooops! I was going to include in my previous post, contact info for anyone wishing to talk to American Avionics about a Microair T2000 SFL transponder. Call early Monday, the 21st! It is: American Avionics sales at 1-800-890-5640 Their website is www.americanavionics.com but their link to Microair is inop. Ken Brooks Roscoe, IL ________________________________________________________________________________
Date: Oct 18, 2002
Subject: T Recess Screws
pulsar-builders(at)caseyk.org 10/18/2002 Hello Fellow Builders, Stainless steel, flat head, 100 degree countersink, six lobe recess drive*, screws are now available in the following sizes with Micro Fastener catalog numbers in ( ). 4-40X1/2 (FCMXS0408) T8 recess 6-32X ? (not quite available yet, but soon. Check with John at Micro Fasteners) 8X32-5/8 (FCMXS0810) T15 recess** 10X32-3/4 (FCMXS1112) T20 recess **You may recall that a previous batch of the 8X32 screws had T20 recess drives. These screw heads did not have adequate strength and Micro Fastener is shipping replacement T15 drive 8X32 screws to all who purchased the earlier batch. I'd like to emphasize that these are special configuration screws that are not available elsewhere. Also these screws are intended for use in amateur built experimental aircraft. While these screws were not manufactured to NASM / MS 24694 standards I have personally installation tested the 8X32 size screws and have received a report of strength testing that gives me confidence in using these screws in my aircraft for structural purposes such as fastening aluminum hinges to composite control and flight surfaces. The decision to use these screws and the manner of their use rests with the individual builder. You may contact Micro Fasteners at: 800-892-6917 or email <> web site is <<http://microfasteners.com>> I request that you relay this posting to any group that you may be part of that has members that could be interested in this information. Thank you. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? *PS: While there is no longer a patent in force for Torx drive screws the name Torx is still a registered trademark. So manufacturers are making screws and drive tools entirely compatible with the Torx configuration and various T sizes, but not using the Torx name. ________________________________________________________________________________
Date: Oct 18, 2002
Subject: Re: Internally Regulated Alternator Adjustment?
Answering my own question here: apparently my Hitachi (unknown model nr.) internally regulated alternator requires battery voltage on its "S" terminal to regulate at 14.2 volts. With no connection to "S", its output rises to 15 volts. Perhaps the "S" means "sense". It certainly doesn't mean "start" in the case of this alternator. For alternator starting, I found that some current must be injected into the "L" terminal. With no connection there, my alternator wouldn't come on line below 2400 (engine) RPM. In my installation, I feed it from the same source that feeds the "S" connection but through a 20-ohm resistor. "L" stands for "lamp" terminal -- the idiot light on the dash. In some 70s automotive designs, the lamp supplied the alternator starting current and when the lamp burned out the alternator wouldn't start (except by residual magnetism). Thanks to Charlie Kuss for his suggestions. -- Joe On 10/13/2002 05:59 Joe Dubner wrote: > How does one accomplish an "adjustment" of the output voltage of an > internally regulated alternator? > > I fly a homebuilt (I'm not the original builder) that uses an internally > regulated Hitachi alternator on a Lycoming. The alternator raises the > battery buss to a value between between 14.9 and 15.1 when the engine > runs. I'd like to replace the conventional lead-acid battery with a > "gel cell" someday and know this is too high (for either type of battery). > > Thanks, > Joe > Clarkston, WA > > ________________________________________________________________________________
Date: Oct 18, 2002
Ed - Check Bob's website. He has already done this. Http://209.134.106.21/articles/macservo/macservo.html. We routed the wire per the book - outboard, then back thru the wing in the conduit. You'll need 2 connectors: one to get the aileron off and the other to get the servo out of the aileron. John Schroeder & Ron Szot Lancair Super ES - 2 wings, 2 flaps, 2 ailerons, 2 elevators & H-S. ________________________________________________________________________________
Date: Oct 18, 2002
John: Thanks for the reply. I have the print out of the sub "D" miniature connector. It's 9 pin, and will work great for the elevator and rudder trim servos with a 5 wire connection. Just thought that there maybe something else out there for a two wire connection. Some guys are using the radio control airplane connectors for this servo. Regards, Ed Silvanic N823MS @aol.com ________________________________________________________________________________
Date: Oct 18, 2002
Subject: Re: z14
> > >Bob, (thought this would be simple answers, so it must not have gone >through the first time I sent it) > >I'm finishing the details of my electrical system design for my Lancair >Legacy, working on the power grid/contactors right now. To refresh you, >it is a dual alt/bat sys, similar to your depiction in z14. dual 17ah >bats will be behind the seat with the bat and crossfeed contactors there >on a power grid, and there will be a starter (and avionics) power grid >on the firewall, and there will be a final contactor bank in the aft >fuselage where the hyd pump and air conditioning is. I have a couple of >questions though: I'm not understanding your used of the term "grid" . . . when you say "similar" to Z-14, how is it to be different and why? >1) why is the wire from the starter contactor to the starter shown as >2awg, while the wire feeding it from the batteries is only 4awg. >Shouldn't the wire from the bat to starter contactor also be 2awg, >especially in a situation like this where there is 7-10 feet between the >contactors? The power distribution diagrams are generalizations intended to depict architecture. If your battery(ies) are a long way from the engine, cranking current conductors would be 2AWG. If the battery(ies) are close, 4AWG will suffice. >2) is there any reason I can't move the shunt to the other side of the >contactor to measure amp draw on the bat? Likewise, I will pull the >crossfeed and starter feed off before the shunt so there is no drop on >it and to eliminate any problems there. If this doesn't make sense, I >can include a drawing. Heres basically what I have in mind: > >B+ 0--O contr 0--0--0 bat_shunt 0--0--0 alt_shunt 0--0 anl30 0--0 alt > | | > | | > xfeed main > cont & bus > starter How would the changes give you any advantage? Panel mounted gages are primarily diagnostic instruments. When things are working well, they give no meaningful information. Given the changes you propose, how will they help you (1) know something isn't working and (2) deduce what needs to be fixed? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 18, 2002
>I did manage to talk the president out of one of the last of the 6" >shirt pocket K&E slide rules in captivity. As we're severely off-topic anyway - anyone know any source for a small circluar slide-rule (not an E6B, just a regular log-log sliderule)? I used to have one about 80mm dia that came "free" from Time-Life but it somehow got overheated and is no longer truly circular. I love it for checking relative prices - much faster and more unobtrusive than any of my favourite RPN calculators (just tossing that in to start another red herring :-)). Incidentally, there are good books written about the history of slide rules and I guess they are read by collectors of the same - so there is likely a market - don't throw out any you have. regards Rowland PS I'm in England if you're recommending circular slide-rule suppliers | PFA 16532 EAA 168386 Young Eagles Flight Leader 017623 | Europa builder #435 G-ROWI e-mail ________________________________________________________________________________
Date: Oct 19, 2002
In a message dated 10/19/2002 2:40:40 AM Central Standard Time, rowil(at)clara.net writes: > As we're severely off-topic anyway - anyone know any source for a > small circluar slide-rule (not an E6B, just a regular log-log > sliderule)? I used to have one about 80mm dia that came "free" from > Time-Life but it somehow got overheated and is no longer truly > circular. I love it for checking relative prices - much faster and > more unobtrusive than any of my favourite RPN calculators (just > tossing that in to start another red herring :-)). > Good Morning Rowland, Jeppesen Sanderson makes one that is the size you want and was designed by retired UAL captain Ray Lahr. He designed it primarily to replace the large E6B style aviation calculators. While it is primarily oriented toward aviation use, it should be more than adequate for the use you describe. The calculator is available in three sizes. The smallest will fit easily in the breast pocket of any mens dress shirt. Works great for young people with excellent vision. The next larger size is the one that Ray designed to fit in the shirt pocket of the double pocket military style shirt favored by airline pilots of the fifties. Jepp also makes a larger one that is favored by us old folks. I carried one of the smaller ones in my pocket as a normal part of my dress for thirty years or more, not just when flying, but all of the time. For the last twenty years or so, I have switched to the one that is easier to read with my failing vision. I keep one in the Bonanza and another on my desk. Happy Skies, Old Bob PS United Air Lines and American Airlines both had proprietary calculators that were issued by those respective airlines. Ray Lahr was a young DC-3 copilot and decided he could design a much better one that would not only be smaller and easier to carry, but had a broader capability. Works great! ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Oct 19, 2002
Subject: Re: AeroElectric-List: Predicting the Future > > As we're severely off-topic anyway - anyone know any source for a > small circluar slide-rule (not an E6B, just a regular log-log > sliderule)? I used to have one about 80mm dia that came "free" from > Time-Life but it somehow got overheated and is no longer truly > circular. I love it for checking relative prices - much faster and > more unobtrusive than any of my favourite RPN calculators (just > tossing that in to start another red herring :-)). > PS I'm in England if you're recommending circular slide-rule suppliers RPN? Way to go! Gordon Comfort N363GC ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: Circular Slide Rules
> > > > >I did manage to talk the president out of one of the last of the 6" > >shirt pocket K&E slide rules in captivity. > >As we're severely off-topic anyway - anyone know any source for a >small circluar slide-rule (not an E6B, just a regular log-log >sliderule)? I used to have one about 80mm dia that came "free" from >Time-Life but it somehow got overheated and is no longer truly >circular. I love it for checking relative prices - much faster and >more unobtrusive than any of my favourite RPN calculators (just >tossing that in to start another red herring :-)). http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=723963498 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=724622465 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=724766111 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=724585778 ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: System architecture
> > >Bob, > >Working on the layout of my power grids, and was wondering if I could >get some dimensions on the s701 and s702 contactors? Also, I assume you >strongly suggest using the s702 for the starter versus using another >s701? Last, how would the s701 be suited for an avionics relay...I know >it would be way overrated, but I'm wondering about its robustness to >cycles, compared to your s704 relay or another bosch automotive style >relay. I know you strongly discourage avionic switches and relays, but >in my case I feel its warranted with the SFS EFIS system, as well as a >few other components that don't have power switches....therefore, with >it warranted, I want it to be as failproof as possible, so I'm looking >for a good relay. Review chapter 17 and then revisit why you want/need an "avionics relay" and tell us what it does for you. What facts in the physics of how the SFS EFIS system is built that suggest a need for pampering by the pilot . . . or any other system you intend to install. Are you building a 14 or 28v airplane? Some of the currents you've cited are too low for 14v. Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
RPN - Reverse Polish Notation so named for the Polish gentleman that invented it. ----- Original Message ----- From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com> Subject: Re: AeroElectric-List: Predicting the Future > > Subject: Re: AeroElectric-List: Predicting the Future > > > > > > > As we're severely off-topic anyway - anyone know any source for a > > small circluar slide-rule (not an E6B, just a regular log-log > > sliderule)? I used to have one about 80mm dia that came "free" from > > Time-Life but it somehow got overheated and is no longer truly > > circular. I love it for checking relative prices - much faster and > > more unobtrusive than any of my favourite RPN calculators (just > > tossing that in to start another red herring :-)). > > PS I'm in England if you're recommending circular slide-rule suppliers > > RPN? Way to go! > > Gordon Comfort > N363GC > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 19, 2002
Subject: RE: Architecture and load analysis studies
> > >Wow, what a mess that turned out, let me try again: Okay, this is a good itemized list of what things draw. Now you need to organize these loads into the various phases of flight to deduce the sizes of alternators and batteries needed to support the loads. Electrical Load Analysis is an important first step in electrical system planning on any project, spam-can or OBAM. It not only determines what sizes of energy generation and storage devices you need, but it forces you to make decisions about how the system will be operated in various situations and in particular, how you plan to tolerate failures in the "no sweat" mode. Download this .pdf file. http://216.55.140.222/temp/Load_Analysis.pdf those of you who are using AutoCAD or compatible program to generate your documentation can also download: http://216.55.140.222/temp/load_analysis.dwg The first page of the .pdf file shows an exemplar load analysis for a Europa project sent to me by a reader some months ago. You can see how electrical loads were defined for the various phases of flight. The second page of the .pdf file is a blank form for the generation of your own load analysis. Use a separate page for each bus. You will need up to 2-4 pages for Main Bus, Aux Bus, Main Battery Bus, Aux Batery Bus, and/or E-bus. Fill in values for each load using only the continuous operating load with transient loads being written as an interesting but not terribly significant note as the denominator of a fraction. For example, your nav/com load might be entered as 0.7/5.3 where 700 mA is the continuous running load in receive while the device peaks at 5.3 amps during transmit. Some of you have shared beginnings of this kind of data in spread sheet format. This works too. Which ever format you choose to use, this exercise is an important step in the planning stages of your project. Note that the Europa project (Rotax 914) had running loads that far exceeded the output of the Rotax's 18A alternator. Hence the need to install the 40A second alternator. With addition of second alternator, the All-electric Airplane on a Budget architecture became a no-brainer decision. This airplane ended up with a B&C 40A machine + a very robust 18A PM alternator built into the engine. A very attractive combination. more to come . . . Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Replacing T20 Drive 8X32 Screws
AeroElectric-List message previously posted by: "Larry Bowen" "Is Micro Fastener contacting previous customers about the T20 screws, or do I have to call them? Thanks for your efforts in this regard. Do not archive- Larry Bowen Larry@BowenAero.com http://BowenAero.com" 10/19/2002 Hello Larry and Others, John is in the process of shipping the T15 drive 8X32 replacement screws to everyone that received the T20 drive screws. If you haven't received your replacement screws within a week I recommend that you contact John. I appreciate your kind words. The person who really deserves the thanks is John Fleisher at Micro Fasteners who invested his time and money in this effort even though he had no previous connection to our hobby. The best way to thank John, in my opinion, is to pass the word among fellow builders so that all may be aware of the availability of these unique screws (and also some very useful hex socket drive screws that Micro Fasteners carries). 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Subject: Measuring Load
Date: Oct 19, 2002
While we're talking about loads, I have a dumb question about my multimeter (from B&C). This may be pretty basic, so bare with me. So far, all I've been able to use it for is testing continuity. Last night I wanted to see which was which of two resitors, a 1k and a 470 ohm. I tested each and had no clue what the readings meant. I've since identified the resitors by looking at the packet. Here's the readings: No connection: 200 ohm scale: 62.8 2k ohm scale: .423 20k ohm scale: 1.26 470 ohm resistor 200 ohm scale: 61.6 2k ohm scale: .33 20k ohm scale: .33 1k resistor 200 ohm scale: 62.2 2k ohm scale: .398 20k ohm scale: .55 Direct short 200 ohm scale: 0 2k ohm scale: 0 20k ohm scale: .2 I must have missed this session in the electronics course. Can someone explain the above to me? John Slade ________________________________________________________________________________
Date: Oct 19, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Ed and Shannon's Lancair system planning
MAIN POWER DISTRIBUTION BUS: Attitude indicator either as primary or backup. Looking at the EFIS/Lite from BMA which has had better performance than what I have heard about the EFIS/ONE. Nav lights Strobe Taxi light left Landing light Autopilot (this might go on aux bus) Electric Flaps Pitot heat AOA system (how much current? Perhaps would live well on aux bus) Cabin Fan GNS-530 (Since this has on/off switch, put on aux bus) GTX-327 (ditto) AUX POWER DISTRIBUTION: Taxi light - right (I think I'd run all exterior lighting from the main bus) Yaw trim Pitch trim Roll trim Turn coordinator Directional Gyro- possible a future BMA HSI (if your en-route power generation capabilities with main alternator out call for shedding some flight instrument loads, I'd make it the DG and leave the A.H. on the aux bus. You get excellent course info from GPS which makes the DG the most redundant and least needed of flight instruments) GNS-430 engine gauge- Electronics International- Oil/Temp MAP RPM Ultimate Bar Graph FP-5L, fuel flow/pressure (again, let's get a load analysis based on your aux alternator capability. BTW, for operation during main alternator failure, you can use ALL the aux alternator capability. The head-room rule for having left over power to recharge battery doesn't apply. It may be that some if not all engine instrumentation could be on the main bus for en-route ops. Once you've set up for cruise, the engine instruments don't do much for you. When it's time to descend and prepare for landing, you should have two fully charged batteries waiting in the wings to let you run lots of main-bus stuff during the approach phase. MAIN BATTERY BUS: Amp/Volt gauge Post lighting (with dual alternator/dual battery all instrument lighting can go on the aux bus - depending on load analysis for aux alternator). Fuel boost pump (high) * Ignition #1 Comm panel (this can go on the aux bus) Cabin lighting (consider putting timer on this) Cargo Compartment light (ditto) AUX BATTERY BUS: Clock Hobbs Meter * Ignition #2 Fuel boost Pump (low) Power Receptacle for Hand Held NAV/COM * Ignition system: I have always have seen MAGS, I'll be honest with you, I don't know much about this other than what is in cars. Have read a lot of past mail about this. My IO-520"D" engine is coming with a new set of MAGS and harness. Should I plan on discarding this? Go with one side on EI or go for both EI? If I stay with MAGS, is it to much trouble to go to EI later? Use toggle or rocker switches for ignition systems. These switches readily wire up to accommodate either mags or electronic ignition. You won't get any worthwhile credit for mags if you order the engine without them. Further, 90% of your performance improvement comes with addition of the first electronic ignition. Sooooo . . . if it were my airplane, I'd take one mag off, bag it up with desiccant and put it on the shelf. Put on one electronic ignition. When the first mag dies, put the saved on on. When the second mag dies, replace it with a second electronic ignition. Let's see . . . we've got several designs going at one time here. Shannon sent me a first pass at his loads analysis in Excel . . . how about we work his system in detail and relax on the others for a bit. Shannon, you sent me some drawings that showed some new busses with disconnect switches/relays and some re-arrangements for contactors. If we're going to use your files as a baseline for the on-list demonstration, we need to get the bus-structures and then add more columns to your Excel file to flesh out the load analysis. A question to be resolved is defining the physics behind your decision for altering the Figure Z-14 architecture. If both batteries go in the back, then each battery's contactor and distribution bus would be mounted adjacent to its respective battery. The crossfeed contactor goes on the firewall to provide a means for splitting the battery feeds to the main and aux busses and establishing feedpoints via ANL current limiters to each alternator. The added limiters are not necessary as shown but would be useful for protecting the hydraulic pump and A/C compressor feeds. I'm not suggesting that you need to wire your airplane MY way if you really want to do it different . . . but we'll have to use someone else's airplane as the on-list design study if you believe you have a basis for marching to a different drummer. Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: RE: Architecture and load analysis studies
I'm having difficulty downloading the file http://216.55.140.222/temp/load_analysis.dwg When I try to download, it says the the file doesn't exist. I downloaded the pdf file with no trouble. Has anyone had better luck with this file? Tom Saccio ________________________________________________________________________________
Date: Oct 19, 2002
From: TSaccio(at)aol.com Date: Sat, 19 Oct 2002 15:36:24 EDT Subject: Re: AeroElectric-List: RE: Architecture and load analysis studies I'm having difficulty downloading the file http://216.55.140.222/temp/load_analysis.dwg When I try to download, it says the the file doesn't exist. I downloaded the pdf file with no trouble. Has anyone had better luck with this file? Tom Saccio I'm having difficulty downloading the file http://216.55.140.222/temp/load_analysis.dwg When I try to download, it says the the file doesn't exist. I downloaded the pdf file with no trouble. Has anyone had better luck with this file? Tom Saccio ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: Multimeter Problems
> >While we're talking about loads, I have a dumb question about my multimeter >(from B&C). >This may be pretty basic, so bare with me. So far, all I've been able to use >it for is testing continuity. Last night I wanted to see which was which of >two resitors, a 1k and a 470 ohm. >I tested each and had no clue what the readings meant. I've since identified >the resitors by looking at the packet. > >Here's the readings: > >No connection: >200 ohm scale: 62.8 >2k ohm scale: .423 >20k ohm scale: 1.26 sounds like your meter is broke. If you would be so kind as to return it to me at Bob Nuckolls 6936 Bainbridge Road Wichita, KS 67226 I'll check it out and then make arrangements to get it replaced. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 19, 2002
> >Answering my own question here: apparently my Hitachi (unknown model >nr.) internally regulated alternator requires battery voltage on its "S" >terminal to regulate at 14.2 volts. With no connection to "S", its >output rises to 15 volts. Perhaps the "S" means "sense". It certainly >doesn't mean "start" in the case of this alternator. This usually means "Switch" . . . other alternators will use "IGN" on the terminal with the same function. Sorry I missed asking you how you had connected leads to the back of the alternator when this thread started. I just assumed you had a diagram describing how to use the alternator. The reason the output voltage jumps up should the alternator get started is because there is a one-diode drop in an internal connection between b-lead and the "S" terminal. The regulator thinks it's seeing bus voltage when in fact, there's a .7 volt error that causes the regulator to boost alternator output by that amount. >For alternator starting, I found that some current must be injected into >the "L" terminal. With no connection there, my alternator wouldn't come >on line below 2400 (engine) RPM. In my installation, I feed it from the >same source that feeds the "S" connection but through a 20-ohm resistor. > "L" stands for "lamp" terminal -- the idiot light on the dash. In some >70s automotive designs, the lamp supplied the alternator starting >current and when the lamp burned out the alternator wouldn't start >(except by residual magnetism). Correct. In many early automotive installations, should the alternator warning light bulb burn out, the alternator wouldn't start up. This was a sort of double-whammy against the car owner 'cause he not only lost indication of a failed alternator, the failure of the 50-cent lamp might force failure of the alternator as well. Later cars added a resistor across the bulb to prevent lamp failure from killing the alternator too. 20-ohms is a bit low. During the time that your bus is hot but the alternator is not turning, circuitry inside the regulator is pulling down on that 20 ohm resistor as if it were a lamp. 20 ohms on 12v produces 600 mA of current on a lamp driver transistor sized for perhaps a 100-200 mA lamp. This may not be a bid deal for the transistor but I think you'll find that the alternator comes on line nicely with a 50-75 ohm resistor as well and would certainly reduce risk of overheating the regulator's lamp driver transistor. Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: Architecture and load analysis studies
> > >From: TSaccio(at)aol.com >Date: Sat, 19 Oct 2002 15:36:24 EDT >Subject: Re: AeroElectric-List: RE: Architecture and load analysis studies >To: aeroelectric-list(at)matronics.com > > >I'm having difficulty downloading the file >http://216.55.140.222/temp/load_analysis.dwg When I try to download, it says >the the file doesn't exist. I downloaded the pdf file with no trouble. Has >anyone had better luck with this file? Do you have AutoCAD or some other program capable of editing AutoCAD drawings? If so, RIGHT-click the link and then tell your browser where to store the drawing on your hard drive. THEN you'll be able to open and edit the drawing. It's the original drawing that generated page 2 of the .pdf file and useful only to those who have CAD capabilities. Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
> sounds like your meter is broke. If you would > be so kind as to return it to me at Ahha!. And I thought it was me. What a relief! I'll mail it next week. Thanks. ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Some airplanes were never ment to fly . . .
Just got this note from a friend of mine who was inadvertently sucked into helping resolve a few assembly issues on an amateur built airplane. Seems the builder was offered one of our OV modules but a supposedly learned friend decided he knew how it was supposed to work without reading the instructions. After the alternator ran away and smoked some electro-whizzies in spite of OV "protection", my friend finds himself paddling upstream in the rapids of ignorance with a very short paddle . . . >The builder is making a GlassStar which is now in flyable condition. Big >engine. His "friend" helped him rig the throttle cable. At first turn >over of the engine, it went to full power, ~2900 rpm on a 3 blade >prop. Pulling the throttle all the way out reduced the rpm about 300. I >pointed out the problem, a lever "mechanical advantage" on the carb where >the cable connects. Limited delta length of the "wire", I suggested move >the attach point further in toward the carb to get greater "range". There >was an argument with the "friend". > >A friend of mine spent some time with the builder. His "friend" had >rigged the ailerons so that the "cross over" cable was wound around the >"outgoing" cable, in each wing, two turns each side. Further, the flaps >cable was wound around that. Somehow, it passed FAA inspection that >way. You could put the stick anywhere you wanted, and it would stay >there, with a real high "break loose" force. All of that got straightened >out over 3 days of restringing by my friend. > >I was called in to look at the ELT installation. There was a dashboard >remote switch of the "pull and toggle" variety. Can't change the position >unless you pull out on the "flipper" - prevents accidental actuation on >the remote dashboard switch. It was working in the ON-ON method. Pulled >the switch and noticed that a terminal had been pulled out of the switch >on the wiring side under the dash. Missing a terminal, it was just wired, >for that wire, to the other side (throw). The builder's "friend" had >checked it out for him, and rewired it; the builder said. I rewired the >switch, so there was an OFF, regardless of the ELT "impact switch", and an >ON, regardless of the ELT "impact switch", as well as the center "what >ever the ELT impact switch wants". > >The builder has your files, which I gave him on a disk, my schematic, and >your phone number and your e-mail address. He said that he gave them all >to his "friend", and that the "friend" rewired your OV protection >circuit. He said that there is now a third contactor. He didn't want me >to look at it, even though I volunteered. He said that he isn't going to >contact you.?! > >I have told my friend what I saw, he related the story of the re-rigging >of the flight controls, and suggested that we both stop helping this >fellow, because there might be implications during an inquiry that is >likely in the future. I was just going to suggest that approach. Some airplanes were just not meant to fly and this may indeed be one of them. I think I'd distance myself as far as possible from this accident looking for someplace to happen . . . >I really have to stop helping people. Don't let this one event discourage you. The only thing sadder than good information not shared is good information being ignored. The bell-curve is a fact of nature . . . SOMEBODY has a natural obligation to occupy the lowliest places on the curve. Fortunately most are eliminated from the gene-pool at minimum risk to others. I think it was Igor Sikorsky who was credited with the following observation: "Most early designers of airplanes were also the test pilots. This had the beneficial effect of eliminating bad designers". >Meanwhile, the abstract of my next paper (European GNSS 2003 at Graz >Austria) is on the web at >http://www.gtwn.net/~keith.peshak/GNSS2003.htm I sent a copy to the new >FAA Administrator and the Transportation Secretary. I guess I am getting >a little frustrated. Understand. I'm just wrapping up a 4-year effort trying to fix a $10 problem in a pitch trim actuator that has cost us 10-15 million dollars in warranty claims and untold damage in customer dissatisfaction. The problem has gone on for so long and cost so much money that nobody wants to admit that there was ever a simple solution. Hence, we're about to embark on a development program for a fine new actuator that will cost twice as much (but last the lifetime of the airplane), needs perhaps a $million$ more in development costs and will take two years to get to the field. In the mean time, customers who bought our airplanes in good faith are still getting screwed. When you're dealing with professional bureaucrats, consumer benefits and faith in the logical application of physics are the smallest of driving forces on their considerations. Doesn't matter if it's government or business. All we can do is be good engineers and don't rewrite any laws of physics. If our audience is high enough on the bell curve to perceive the value of what we do, great. You may have to bang on the bell a whole lot before you get the attention of folks in top 10% of the curve. Bob . . . ________________________________________________________________________________
Date: Oct 19, 2002
Thanks Bob I tried what you said and it worked. I used the Cad program I got from you. Tom ________________________________________________________________________________
Subject: Essential Bus (always a good topic)
Date: Oct 19, 2002
Bob, What am I missing? Why not use another diode to feed the essential bus instead of having the E-Bus Alternate Feed Switch? Thanks, Eric M. Jones ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: T Recess Screws
> 10/18/2002 > > Hello Fellow Builders, Stainless steel, flat head, 100 degree > countersink, > six lobe recess drive*, screws are now available in the following > sizes with > Micro Fastener catalog numbers in ( ). ... 'OC', Thanks for taking the lead on the torx screw issue. I purchased some of the first batch of #8's from Micro Fasteners, & expect to use some of the other sizes also. What do you use for pan head replacements? I'd like to use torx, but McMaster Carr only has zinc plated pan head torx, or black oxide torx plus. Have you been able to find cadmium plated, which I believe minimizes dissimilar metal corrosion problems with aluminum? Regards, Chris Good. West Bend, WI RV-6A, flying. -- Get 250 full-color business cards FREE right now! http://businesscards.lycos.com ________________________________________________________________________________
Date: Oct 19, 2002
Subject: Re: Essential Bus (always a good topic)
> >Bob, > >What am I missing? Why not use another diode to feed the essential bus >instead of having the E-Bus Alternate Feed Switch? How would you turn the e-bus off? The alternate feed comes from an always hot battery feed. Also, how would you pre-flight the independent pathways if you didn't have a way to enable them separate from each other? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Re: z14
Date: Oct 20, 2002
The term "grid" refers to my bank of contactors that is mounted near the batteries. This refers specifically to the 2 battery contactors, and the crossfeed contactor. In my system, I plan 3 "grids": 1 in the aft fuselage for the hydraulic pump with up and done contactors, one behind the seat with the 2 battery and 1 crossfeed contactor, and 1 on the firewall with the starter contactor and avionics relays (if necessary). The only difference between my plan and your z14 is the depiction of the switches, and possibly the location of the shunts, and I plan on having an avionics bus (due to SFS EFIS). I am having Lancair build my panel, and they, by standard, use the split bat/alt switch, so that is one difference. I plan to have the avionics switches/relays (against your common practice, I know) for the SFS EFIS computers, the xbow AHRS, and the Merlin datalink...none of which have on/off switches so I can have them off during starting. The other difference was I plan to put dual shunts on each bus, one from the battery side, and one from the alternator side, so I can better see what is occurring in the charging system. This leads into your last question. The reason for my question about the shunts is due to the small voltage drop across them. In your depiction, the shunt is between the starter contactor and the battery ground. Therefore, when the motor is being started, the shunt in another voltage drop that we have to deal with. I realize it is small, but it appears to me that moving it to where I plan (after the starter contactor) would get rid of this voltage drop as seen by the starter, and have no other ill effects. The purpose of having the two shunts is self-explanatory I assume. If I pull the feed for the buss off from in between the two shunts, one shunt will indicate what is coming from the battery (or going to), and the other will indicate what is coming from the alt. This should give a quick indication of whether an alt has failed, or a battery is no longer up to the task. None of this is set in stone at all. I am new to all of this and am just in the planning stage. I'm trying to be as thorough as possible in my planning though, as you suggest in your book. I started with a circuit listing and amp draw in excel. I arranged these on the busses as required, per your suggestions. Then I took your z14 and massaged it for my setup and came up with a basic wiring schematic. I made a couple of changes (switches per Lancair, and shunts), namely the position of the shunts. Before I build the "grids" I would like to discuss it and see if I'm missing something. (BTW, Bob, I sent directly to you an email with 3 attachments, 1) excel circuit list 2) acad modified z14 schematic 3) acad scale drawing of airplane with the beginning of the wires being run in it......please review and the above might make more sense) --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: z14 > > >Bob, (thought this would be simple answers, so it must not have gone >through the first time I sent it) > >I'm finishing the details of my electrical system design for my Lancair >Legacy, working on the power grid/contactors right now. To refresh you, >it is a dual alt/bat sys, similar to your depiction in z14. dual 17ah >bats will be behind the seat with the bat and crossfeed contactors there >on a power grid, and there will be a starter (and avionics) power grid >on the firewall, and there will be a final contactor bank in the aft >fuselage where the hyd pump and air conditioning is. I have a couple of >questions though: I'm not understanding your used of the term "grid" . . . when you say "similar" to Z-14, how is it to be different and why? >1) why is the wire from the starter contactor to the starter shown as >2awg, while the wire feeding it from the batteries is only 4awg. >Shouldn't the wire from the bat to starter contactor also be 2awg, >especially in a situation like this where there is 7-10 feet between the >contactors? The power distribution diagrams are generalizations intended to depict architecture. If your battery(ies) are a long way from the engine, cranking current conductors would be 2AWG. If the battery(ies) are close, 4AWG will suffice. >2) is there any reason I can't move the shunt to the other side of the >contactor to measure amp draw on the bat? Likewise, I will pull the >crossfeed and starter feed off before the shunt so there is no drop on >it and to eliminate any problems there. If this doesn't make sense, I >can include a drawing. Heres basically what I have in mind: > >B+ 0--O contr 0--0--0 bat_shunt 0--0--0 alt_shunt 0--0 anl30 0--0 alt > | | > | | > xfeed main > cont & bus > starter How would the changes give you any advantage? Panel mounted gages are primarily diagnostic instruments. When things are working well, they give no meaningful information. Given the changes you propose, how will they help you (1) know something isn't working and (2) deduce what needs to be fixed? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 20, 2002
I will re-read 17 and get back to you. My initial thoughts are that the SFS as well as the Xbow AHRS and the Merlin Datalink system all have computers in them. The SFS runs on a PC platform running NT I believe. Therefore, low voltage dropouts causing the SFS to re-boot in mid stream of the boot-up cycle does not seem like a good idea to me (or to the people at Lancair). We all know how finicky pc's with MS OS's on them can be, especially during boot-up. I just don't see the need to risk it. Also, the Xbow behaves similarly from my understanding, where it has to "boot-up" and takes some time to "align" itself or whatever.....re-booting it during this time doesn't seem like a good idea either. Same goes with the Merlin. If these units had power switches on them, I would totally agree, and would never even consider an avionics relay/switch....I would just turn them off. However, they don't, so I can't, so I feel it is warranted. Do you disagree? I'd love nothing else than to have the 2 switch spots open back up on my already stuffed panel :) I'm building a 14v plane. Which currents are you concerned with. Some of them were my best guesses. Some of them were obtained from a reference sheet of actual amp draws provided by Brent Regan. If Brents plane is a 28v plane, then I will need to double all the values I got from him. Do you know if his plane is? I hate to bother him with such a trivial question in light of the events last week...I'm sure he has enough to deal with. Thanks for the help. Your expertise and guidance is appreciated more than you realize. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: System architecture > > >Bob, > >Working on the layout of my power grids, and was wondering if I could >get some dimensions on the s701 and s702 contactors? Also, I assume you >strongly suggest using the s702 for the starter versus using another >s701? Last, how would the s701 be suited for an avionics relay...I know >it would be way overrated, but I'm wondering about its robustness to >cycles, compared to your s704 relay or another bosch automotive style >relay. I know you strongly discourage avionic switches and relays, but >in my case I feel its warranted with the SFS EFIS system, as well as a >few other components that don't have power switches....therefore, with >it warranted, I want it to be as failproof as possible, so I'm looking >for a good relay. Review chapter 17 and then revisit why you want/need an "avionics relay" and tell us what it does for you. What facts in the physics of how the SFS EFIS system is built that suggest a need for pampering by the pilot . . . or any other system you intend to install. Are you building a 14 or 28v airplane? Some of the currents you've cited are too low for 14v. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 20, 2002
Bob, I'll gladly make the changes as needed. What I have done so far is just a basic start, planning as much as possible before I start building. Nothing is set in stone. I've used info from you, from Lancair, and from other builders to arrive at what I have so far. I've tried to combine the info and my understanding to build my own system....I didn't want to bother you for every little detail. Obviously, I've made a few mistakes, which I'm sure we'll hammer out here shortly :) As far as my structure goes of the power system, I'm totally open to ideas. I put the xfeed contactor with the batter contactors so I only had to run one large 2awg wire to the front. However, after re-reading your chapter on contactors and wiring, it appears that I could make some changes and have fewer wires to run back to the batteries by putting the crossfeed contactor on the firewall and running the alt feeds to the starter contactor and xfeed contactor respectively. In this case, a pair of 4awg feeds from the p+ and the e+ batteries, and a combined 2awg ground would provide all the needed wiring (and do away with the 4 and 6 gauge feeds from the 70A and 20A alternators all the way to the back). I would still have to run an 8awg wire back for the hyd and a/c systems buss-bar, but this would probably be better. What do you think? With the drawing I sent you, you can basically see where everything is in my plane, and you can tell me where things should be. Now, for the topic of the z14 re-design. I don't really think I've changed anything, except for adding the split alt/bat switches, moving/adding the shunts, and adding the avionics bus/switch/relay. Please give me some pointers as to where to go next and what to do to get my excel spreadsheet and drawings whipped into shape, and I'll do my best to comply ASAP...for the benefit of myself and others. As always, thanks. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Ed and Shannon's Lancair system planning MAIN POWER DISTRIBUTION BUS: Attitude indicator either as primary or backup. Looking at the EFIS/Lite from BMA which has had better performance than what I have heard about the EFIS/ONE. Nav lights Strobe Taxi light left Landing light Autopilot (this might go on aux bus) Electric Flaps Pitot heat AOA system (how much current? Perhaps would live well on aux bus) Cabin Fan GNS-530 (Since this has on/off switch, put on aux bus) GTX-327 (ditto) AUX POWER DISTRIBUTION: Taxi light - right (I think I'd run all exterior lighting from the main bus) Yaw trim Pitch trim Roll trim Turn coordinator Directional Gyro- possible a future BMA HSI (if your en-route power generation capabilities with main alternator out call for shedding some flight instrument loads, I'd make it the DG and leave the A.H. on the aux bus. You get excellent course info from GPS which makes the DG the most redundant and least needed of flight instruments) GNS-430 engine gauge- Electronics International- Oil/Temp MAP RPM Ultimate Bar Graph FP-5L, fuel flow/pressure (again, let's get a load analysis based on your aux alternator capability. BTW, for operation during main alternator failure, you can use ALL the aux alternator capability. The head-room rule for having left over power to recharge battery doesn't apply. It may be that some if not all engine instrumentation could be on the main bus for en-route ops. Once you've set up for cruise, the engine instruments don't do much for you. When it's time to descend and prepare for landing, you should have two fully charged batteries waiting in the wings to let you run lots of main-bus stuff during the approach phase. MAIN BATTERY BUS: Amp/Volt gauge Post lighting (with dual alternator/dual battery all instrument lighting can go on the aux bus - depending on load analysis for aux alternator). Fuel boost pump (high) * Ignition #1 Comm panel (this can go on the aux bus) Cabin lighting (consider putting timer on this) Cargo Compartment light (ditto) AUX BATTERY BUS: Clock Hobbs Meter * Ignition #2 Fuel boost Pump (low) Power Receptacle for Hand Held NAV/COM * Ignition system: I have always have seen MAGS, I'll be honest with you, I don't know much about this other than what is in cars. Have read a lot of past mail about this. My IO-520"D" engine is coming with a new set of MAGS and harness. Should I plan on discarding this? Go with one side on EI or go for both EI? If I stay with MAGS, is it to much trouble to go to EI later? Use toggle or rocker switches for ignition systems. These switches readily wire up to accommodate either mags or electronic ignition. You won't get any worthwhile credit for mags if you order the engine without them. Further, 90% of your performance improvement comes with addition of the first electronic ignition. Sooooo . . . if it were my airplane, I'd take one mag off, bag it up with desiccant and put it on the shelf. Put on one electronic ignition. When the first mag dies, put the saved on on. When the second mag dies, replace it with a second electronic ignition. Let's see . . . we've got several designs going at one time here. Shannon sent me a first pass at his loads analysis in Excel . . . how about we work his system in detail and relax on the others for a bit. Shannon, you sent me some drawings that showed some new busses with disconnect switches/relays and some re-arrangements for contactors. If we're going to use your files as a baseline for the on-list demonstration, we need to get the bus-structures and then add more columns to your Excel file to flesh out the load analysis. A question to be resolved is defining the physics behind your decision for altering the Figure Z-14 architecture. If both batteries go in the back, then each battery's contactor and distribution bus would be mounted adjacent to its respective battery. The crossfeed contactor goes on the firewall to provide a means for splitting the battery feeds to the main and aux busses and establishing feedpoints via ANL current limiters to each alternator. The added limiters are not necessary as shown but would be useful for protecting the hydraulic pump and A/C compressor feeds. I'm not suggesting that you need to wire your airplane MY way if you really want to do it different . . . but we'll have to use someone else's airplane as the on-list design study if you believe you have a basis for marching to a different drummer. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 20, 2002
Subject: RE: Ed and Shannon's Lancair system planning
> > >Bob, > >I'll gladly make the changes as needed. What I have done so far is just >a basic start, planning as much as possible before I start building. >Nothing is set in stone. I've used info from you, from Lancair, and >from other builders to arrive at what I have so far. I've tried to >combine the info and my understanding to build my own system....I didn't >want to bother you for every little detail. Obviously, I've made a few >mistakes, which I'm sure we'll hammer out here shortly :) Please understand what were about here . . . my intent is not to embarrass you or anyone else on the list. I view these exercises as excellent learning tools both for the builders who's airplanes we are discussing -and- those who are listening in and considering their own projects as we go along. It's pretty easy to treat all that's been done before us as a Wall-Mart of choices . . . a huge box of Tinker-Toys from which we can build a new system. Many builders I've worked with over the past 15 years have approached their electrical system configuration task with the mind-set that a "sprinkling of everything" is the best way to make sure all the bases are covered. All they've got to go on is what they've seen in other airplanes and read about in the dark-n-stormy-night stories. If there are any "mistakes" made, they're generally founded in a lack of understanding of details how we want the system to work and what can be gleaned from lessons-learned by observing and ANALYZING the experience of others. It's hard to break the mind-set of traditional airplane- think especially when fears of the unknown jump in to take the place of understanding. >As far as my structure goes of the power system, I'm totally open to >ideas. I put the xfeed contactor with the batter contactors so I only >had to run one large 2awg wire to the front. However, after re-reading >your chapter on contactors and wiring, it appears that I could make some >changes and have fewer wires to run back to the batteries by putting the >crossfeed contactor on the firewall and running the alt feeds to the >starter contactor and xfeed contactor respectively. In this case, a >pair of 4awg feeds from the p+ and the e+ batteries, and a combined 2awg >ground would provide all the needed wiring (and do away with the 4 and 6 >gauge feeds from the 70A and 20A alternators all the way to the back). >I would still have to run an 8awg wire back for the hyd and a/c systems >buss-bar, but this would probably be better. What do you think? With >the drawing I sent you, you can basically see where everything is in my >plane, and you can tell me where things should be. I could certainly TELL you where things should be but I'd rather discuss how things could be and have you and others arrive at a logical conclusion of your own as to how they SHOULD be. >Now, for the topic of the z14 re-design. I don't really think I've >changed anything, except for adding the split alt/bat switches, >moving/adding the shunts, and adding the avionics bus/switch/relay. Okay. You've made a conscious decision to make changes. What is the rational for your suggestions? How do they improve the value of the finished system? >Please give me some pointers as to where to go next and what to do to >get my excel spreadsheet and drawings whipped into shape, and I'll do my >best to comply ASAP...for the benefit of myself and others. Let's add some columns to your spread sheet with headers like those on the .pdf file I published for load analysis. One of the first mistakes folks make when they add up all the numbers is based on the notion that there are normal flight conditions where EVERYTHING is turned on and drawing max load at the same time which is never true. There are a lot of airplanes flying around out there with a too-big alternator, too-big battery and architectures that will lead them up a one-way, dead-end canyon like the "Sparks in the Dark" story I related in Chapter 17. I'm picking on you because you were the first one to share a spread-sheet version of your deliberations. I gotta warn you all folks, he who lets it be known that he has some skill with advanced thinking and planning tools is likely to find himself in the spotlight with our friend Shannon. >As always, thanks. . . . and thank YOU sir for volunteering to stand in the bright lights. This is going to be a good exercise for us all. One of chapters that is yet to be added to the 'Connection deals with load analysis and system architecture planning. My participation in this activity is good review for getting started on that new chapter. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2002
Subject: Re: z14
> > >The term "grid" refers to my bank of contactors that is mounted near the >batteries. This refers specifically to the 2 battery contactors, and >the crossfeed contactor. In my system, I plan 3 "grids": 1 in the aft >fuselage for the hydraulic pump with up and done contactors, one behind >the seat with the 2 battery and 1 crossfeed contactor, and 1 on the >firewall with the starter contactor and avionics relays (if necessary). I think you'll find this a good thing to do . . . but let's whack the load analysis first and then get to discussions on best physical locations for things. >The only difference between my plan and your z14 is the depiction of the >switches, and possibly the location of the shunts, and I plan on having >an avionics bus (due to SFS EFIS). I am having Lancair build my panel, >and they, by standard, use the split bat/alt switch, so that is one >difference. I plan to have the avionics switches/relays (against your >common practice, I know) for the SFS EFIS computers, the xbow AHRS, and >the Merlin datalink...none of which have on/off switches so I can have >them off during starting. The other difference was I plan to put dual >shunts on each bus, one from the battery side, and one from the >alternator side, so I can better see what is occurring in the charging >system. This leads into your last question. > >The reason for my question about the shunts is due to the small voltage >drop across them. In your depiction, the shunt is between the starter >contactor and the battery ground. Therefore, when the motor is being >started, the shunt in another voltage drop that we have to deal with. I >realize it is small, but it appears to me that moving it to where I plan >(after the starter contactor) would get rid of this voltage drop as seen >by the starter, and have no other ill effects. What drawing are you looking at? In the chapter on electrical system instrumentation (written about 10 years ago) I shown a shunt option that put it right in a battery lead so that the builder could use the classic -0+ reading battery ammeter. In more recent times, I've decided that this style of ammeter doesn't tell us anything we cannot deduce from other combinations and putting a shunt in series with a starter is NOT a good idea anyhow. In all of the power distribution diagrams, I show shunts only as LOADMETERs to read the present loading of each alternator and starter current does not flow through this shunt. >The purpose of having the two shunts is self-explanatory I assume. If I >pull the feed for the buss off from in between the two shunts, one shunt >will indicate what is coming from the battery (or going to), and the >other will indicate what is coming from the alt. This should give a >quick indication of whether an alt has failed, or a battery is no longer >up to the task. I think one shunt in each alternator b-lead would suffice. How would you use the information made available by any more shunts? >None of this is set in stone at all. I am new to all of this and am >just in the planning stage. I'm trying to be as thorough as possible in >my planning though, as you suggest in your book. I started with a >circuit listing and amp draw in excel. I arranged these on the busses >as required, per your suggestions. Then I took your z14 and massaged it >for my setup and came up with a basic wiring schematic. I made a couple >of changes (switches per Lancair, and shunts), namely the position of >the shunts. Before I build the "grids" I would like to discuss it and >see if I'm missing something. Sure. Let's start with Z-14 and go through each proposed modification to see how it adds value. I'm not saying that things shouldn't be done to change this drawing but if it IS changed, there should be a foundation in physics and operating convenience for doing so. > > >(BTW, Bob, I sent directly to you an email with 3 attachments, 1) excel >circuit list 2) acad modified z14 schematic 3) acad scale drawing of >airplane with the beginning of the wires being run in it......please >review and the above might make more sense) I got 'em. Let's expand the Excel file to assist in our load analysis deliberations. When we've got that exercise 90% done, we'll shift our focus to architecture and placement. Bob . . . ________________________________________________________________________________
From: "Jeremy Davey" <jeremycrdavey(at)btinternet.com>
Date: Oct 20, 2002
I just wanted to add a word of thanks, too, to all those who are sharing their designs and thinking, and Bob for giving us all knowledge-based assessment of them. I've got to go through this process, probably just after Christmas, and I'm learning a huge amount about the process before I start. I am grateful to everyone who is putting their designs up for Bob's expert critique, and am relishing the ego-free-zone we have here. If only more of the world was like it! Now if only I could work out how to run an all-electric plane off that puny Rotax alternator... Regards, Jeremy Europa XS monowheel G-EZZA Please, no need to archive! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Ed and Shannon's Lancair system planning > > >Bob, > >I'll gladly make the changes as needed. What I have done so far is just >a basic start, planning as much as possible before I start building. >Nothing is set in stone. I've used info from you, from Lancair, and >from other builders to arrive at what I have so far. I've tried to >combine the info and my understanding to build my own system....I didn't >want to bother you for every little detail. Obviously, I've made a few >mistakes, which I'm sure we'll hammer out here shortly :) Please understand what were about here . . . my intent is not to embarrass you or anyone else on the list. I view these exercises as excellent learning tools both for the builders who's airplanes we are discussing -and- those who are listening in and considering their own projects as we go along. It's pretty easy to treat all that's been done before us as a Wall-Mart of choices . . . a huge box of Tinker-Toys from which we can build a new system. Many builders I've worked with over the past 15 years have approached their electrical system configuration task with the mind-set that a "sprinkling of everything" is the best way to make sure all the bases are covered. All they've got to go on is what they've seen in other airplanes and read about in the dark-n-stormy-night stories. If there are any "mistakes" made, they're generally founded in a lack of understanding of details how we want the system to work and what can be gleaned from lessons-learned by observing and ANALYZING the experience of others. It's hard to break the mind-set of traditional airplane- think especially when fears of the unknown jump in to take the place of understanding. >As far as my structure goes of the power system, I'm totally open to >ideas. I put the xfeed contactor with the batter contactors so I only >had to run one large 2awg wire to the front. However, after re-reading >your chapter on contactors and wiring, it appears that I could make some >changes and have fewer wires to run back to the batteries by putting the >crossfeed contactor on the firewall and running the alt feeds to the >starter contactor and xfeed contactor respectively. In this case, a >pair of 4awg feeds from the p+ and the e+ batteries, and a combined 2awg >ground would provide all the needed wiring (and do away with the 4 and 6 >gauge feeds from the 70A and 20A alternators all the way to the back). >I would still have to run an 8awg wire back for the hyd and a/c systems >buss-bar, but this would probably be better. What do you think? With >the drawing I sent you, you can basically see where everything is in my >plane, and you can tell me where things should be. I could certainly TELL you where things should be but I'd rather discuss how things could be and have you and others arrive at a logical conclusion of your own as to how they SHOULD be. >Now, for the topic of the z14 re-design. I don't really think I've >changed anything, except for adding the split alt/bat switches, >moving/adding the shunts, and adding the avionics bus/switch/relay. Okay. You've made a conscious decision to make changes. What is the rational for your suggestions? How do they improve the value of the finished system? >Please give me some pointers as to where to go next and what to do to >get my excel spreadsheet and drawings whipped into shape, and I'll do my >best to comply ASAP...for the benefit of myself and others. Let's add some columns to your spread sheet with headers like those on the .pdf file I published for load analysis. One of the first mistakes folks make when they add up all the numbers is based on the notion that there are normal flight conditions where EVERYTHING is turned on and drawing max load at the same time which is never true. There are a lot of airplanes flying around out there with a too-big alternator, too-big battery and architectures that will lead them up a one-way, dead-end canyon like the "Sparks in the Dark" story I related in Chapter 17. I'm picking on you because you were the first one to share a spread-sheet version of your deliberations. I gotta warn you all folks, he who lets it be known that he has some skill with advanced thinking and planning tools is likely to find himself in the spotlight with our friend Shannon. >As always, thanks. . . . and thank YOU sir for volunteering to stand in the bright lights. This is going to be a good exercise for us all. One of chapters that is yet to be added to the 'Connection deals with load analysis and system architecture planning. My participation in this activity is good review for getting started on that new chapter. Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 20, 2002
Subject: RE: System architecture
> > >I will re-read 17 and get back to you. My initial thoughts are that the >SFS as well as the Xbow AHRS and the Merlin Datalink system all have >computers in them. The SFS runs on a PC platform running NT I believe. >Therefore, low voltage dropouts causing the SFS to re-boot in mid stream >of the boot-up cycle does not seem like a good idea to me (or to the >people at Lancair). We all know how finicky pc's with MS OS's on them >can be, especially during boot-up. I just don't see the need to risk >it. Also, the Xbow behaves similarly from my understanding, where it >has to "boot-up" and takes some time to "align" itself or >whatever.....re-booting it during this time doesn't seem like a good >idea either. Same goes with the Merlin. If these units had power >switches on them, I would totally agree, and would never even consider >an avionics relay/switch....I would just turn them off. However, they >don't, so I can't, so I feel it is warranted. Do you disagree? I'd >love nothing else than to have the 2 switch spots open back up on my >already stuffed panel :) Risks come in two classes. (1) Those that are understood, quantified and accounted for as part of the system design and operation and (2) those that are rumored and not supported with facts from the manufacturer and cause us to do all kinds of things, useful or not, to assuage our worries. Call the folks who make the gizmos in question. Ask them what the stable operation input voltage range is for their products. If it doesn't extend down to 9.0 volts or less, ask them if they ever heard of DO-160? If their system does go into reboot due to brown-out, does it come up reliably and with no adverse consequences? If I had a product that couldn't stay fully awake during engine cranking, it would have a cold-boot routine on a brown-out detector that couldn't care less if it were the first, second or tenth reboot event triggered over the last 60 seconds. There are no excuses for allowing any less stable performance to find its way onto an airplane. System complexities in our automobiles doubles every few years and there are millions of folks out there who expect and receive good operating characteristics on mornings so cold that he battery barely turns the engine over. I've had some discussions with Lancair concerning some FADEC systems now being installed by some of their customers. This piece of ( $%#%$) needs a pampered bus source in order to achieve the minimal functions necessary to get the engine started. In my never so humble opinion, this behavior is inexcusable. I've got some ideas I'll be discussing with them during my next trip out there in January for working around this idiosyncrasy in the FADEC. Let's see if the concerns you've identified are real first. >I'm building a 14v plane. Which currents are you concerned with. Some >of them were my best guesses. Some of them were obtained from a >reference sheet of actual amp draws provided by Brent Regan. If Brents >plane is a 28v plane, then I will need to double all the values I got >from him. Do you know if his plane is? I hate to bother him with such >a trivial question in light of the events last week...I'm sure he has >enough to deal with. What happened to Brent last week? Don't worry about it. It was just a note in passing. I think I saw something less than 6A for position lights. It's not important right now. We need to build a framework for organizing and analyzing all the data before we quibble over the actual sizes of numbers. >Thanks for the help. Your expertise and guidance is appreciated more >than you realize. You're helping me too . . . more than you realize. I'm really stoked by this opportunity to run all the traps here on the List . . . I've done in numerous times in the past on individual OBAM projects and more times than I'd like to recall on spam-cans. Each pass though it refines and cements good ideas . . . being able to share it with the List readers makes this one of the more promising efforts yet. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2002
Subject: T Recess Screws
AeroElectric-List message previously posted by: "Chris Good" " 'OC', Thanks for taking the lead on the torx screw issue. I purchased some of the first batch of #8's from Micro Fasteners, & expect to use some of the other sizes also. What do you use for pan head replacements? I'd like to use torx, but McMaster Carr only has zinc plated pan head torx, or black oxide torx plus. Have you been able to find cadmium plated, which I believe minimizes dissimilar metal corrosion problems with aluminum? Regards, Chris Good. West Bend, WI RV-6A, flying. >> 10/20/2002 Hello Chris, I use hex socket drive pan head stainless steel screws purchased from Micro Fasteners in many different sizes and places in my airplane. None of these uses could be considered "structural". In theory it would be nice to have all hex socket or all six-lobe (Torx) drive screws in the plane for standardization purposes, but the reality is that since the different sized hex socket screws and different sized Torx drive screws require different sized drivers one is forced to have a variety of drive bits on hand regardless of drive preferences or standardization. My solution is found in the Chapman or Mini-Ratchet sets that come with a number of different sizes and types of drive inserts. I'm never at a loss for the right insert bit. If you don't want to go stainless in order to avoid some perceived corrosion conflict with aluminum (which I feel is overrated in our applications) I don't have a good answer. Cadmium plating seems to be favored only within the aerospace industry and their Phillips drive screws. The Textron Camcar catalog doesn't show the specific combination that you want, but that doesn't mean that it doesn't exist someplace. Maybe an extensive internet and telephone search might turn up something. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? PS: I would like to apologize to all the electrophiles reading about screws who are offended / annoyed by this subject appearing on this list. The only excuses that I can offer are that: 1) Somebody else started it (right Fergus?) 2) It is definitely related to our airplane building activities, and 3) Many builders are benefiting. Please be patient with our little side excursion. ________________________________________________________________________________
Date: Oct 20, 2002
Subject: Re: 18 awg fuse link
>Hi, Bob. Your article on fabricating fusible links says to consult you >for situations needing larger links. > >That's me. I am using a 14 awg wire for my essential bus alternate feed, >and have about 6 or 8 amps full load on the bus. (I'm estimating the load >for the Facet boost pump and primer.) > >I was going to use an 18 awg fuse link coming off the bat connection of >the master contactor. > >Whaddaya think? > >Gary Is this the only always hot feed you have from your battery? In other words, I understand that you do not have a battery bus that powers things other than the e-bus alternate feed? If you have a battery bus, consider taking the alternate feedpath off one of the fuse slots with a 10A fuse in it. If your battery is very far away, 14AWG would help mitigate small voltage drops, otherwise, you could drop down to 16AWG. If the alternate feed IS the only always-hot feed, then I'd go on down to 22AWG for the fusible link. You'd be amazed at how robust a piece of 22AWG wire is in a hard fault condition. It will handle your 6-8A full load currents very nicely and keep the "weak link" as weak as practical. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 20, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: influencing your legislators (was Re: standing up to
be counted. . .) "Robert L. Nuckolls, III" wrote: > > > > > >Hi Bob, > > > >This is just the way life is, you know. The inventor of the Xerox copier > >was turned down by dozens of non-government corporate bureaucrats. > > . . . and even after the Xerox process became a runaway > success, the same people who were snubbed by the copier > marketplace failed to see the future in adapting the > technology to laser printers. Even when the laser > printer was first brought to life in Xerox's own > Palo Alto labs, it was up to other companies to show > them how to make $mucho$ with the idea. > > > The > >auto and airplane were derided as silly ideas till they were > >demonstrated. The developer of Fed Express got a poor grade for his thesis > >outlining the design of the system. > > > >Railing against bureaucrats is like pissing into the wind, an expression I > >learned while growing up in north central Kansas. > > There was a time when I would agree with that . . . > now I think there is an increasing awareness of > current trends and predicable futures for some > of the paths our leadership has mapped out for > us. The Internet is an important feature of this > new awareness. > > Irrespective of whether or not you agree with > anything I have to offer, how often do you write > your congress-persons? Even when the details > of your opinion are mis-understood or mis-filed > by the recipient, they are acutely aware of the > numbers of folk who are watching and expressing > themselves. > > I write several times a week on various issues, > usually at http://www.congress.org/ But if > the issue is particularly important to me, the > letters go out priority mail. > > >K. H. (Hal) Kempthorne > >RV6-a N7HK flying! > >PRB (El Paso de Robles, CA) > My wife & I recently participated in a successful grass-roots campaign in support of a bill to fund a particular kind of leukemia research. Here is how we were told to get the word to the right place. In the post 9-11 environment, DC legislators might not receive hard-copy mail for months. Email is so easy to fake an source address that little weight is given emails by the staff. We were told to contact the legislator's staff (local or DC) & obtain the name of the assistant in charge of the field of interest. Then obtain that assistant's fax number in DC. Faxes should include your name, address & if desired, your phone number. This makes it easier for the staff to verify that you are a legitimate voter. A few hundred faxes resulted in our legislator's shift from not even being aware of the bill to being a co-sponsor. Hope this is useful info. Charlie ________________________________________________________________________________
Date: Oct 20, 2002
Tom - I had no problem downloading the .DWG file and pulling it up. John Schroeder > > I'm having difficulty downloading the file > http://216.55.140.222/temp/load_analysis.dwg When I try to download, ________________________________________________________________________________
Date: Oct 20, 2002
Terry - Prints OK in AutoCAD LT 2000. John Schroeder Terry Watson wrote: > > > I downloaded and opened it in AutoCAD 14 three times and each time when I > try print it I get a fatal error and some note about an access violation. > > ________________________________________________________________________________
From: "William Slaughter" <willslau(at)alumni.rice.edu>
Date: Oct 20, 2002
Bob, May I assume that the ($%#%$) FADEC unit you're referring to is the Aerosance unit? I'm installing one in my RV-8 (money has already changed hands), and am planning a 7.2 AH battery/SD-8 alternator as a dedicated power source (pampered buss) for the FADEC. While I certainly agree that this shouldn't be necessary, their unit is currently the only game in town for integrated, computerized fuel and spark management of the sort we are all used to having in our cars. If a pampered buss is what it needs at this time, that's a price I'm willing to pay. I am anxious to hear your thoughts on how to best configure the electrical system to accommodate their unit. While I'm well aware that "It's the pioneers who get the arrows in their backs.", I've been so impressed by the renaissance in automotive performance over the last decade, which has been largely enabled by computerized engine management, that I just can't see building a 21st century aircraft powerplant any other way. So far, everyone I have personally spoken to who has actually installed and flown on of the Aerosance units is very pleased. None of them said it was the path on least resistance, however. While my system architecture will certainly not compare with the complexity of the Lancairs, I've found this thread a very interesting case study. As always, thanks for the time and energy you devote to these very educational exercises. William Slaughter RV-8 N492WS in progress -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: System architecture > > >I will re-read 17 and get back to you. My initial thoughts are that the >SFS as well as the Xbow AHRS and the Merlin Datalink system all have >computers in them. The SFS runs on a PC platform running NT I believe. >Therefore, low voltage dropouts causing the SFS to re-boot in mid stream >of the boot-up cycle does not seem like a good idea to me (or to the >people at Lancair). We all know how finicky pc's with MS OS's on them >can be, especially during boot-up. I just don't see the need to risk >it. Also, the Xbow behaves similarly from my understanding, where it >has to "boot-up" and takes some time to "align" itself or >whatever.....re-booting it during this time doesn't seem like a good >idea either. Same goes with the Merlin. If these units had power >switches on them, I would totally agree, and would never even consider >an avionics relay/switch....I would just turn them off. However, they >don't, so I can't, so I feel it is warranted. Do you disagree? I'd >love nothing else than to have the 2 switch spots open back up on my >already stuffed panel :) Risks come in two classes. (1) Those that are understood, quantified and accounted for as part of the system design and operation and (2) those that are rumored and not supported with facts from the manufacturer and cause us to do all kinds of things, useful or not, to assuage our worries. Call the folks who make the gizmos in question. Ask them what the stable operation input voltage range is for their products. If it doesn't extend down to 9.0 volts or less, ask them if they ever heard of DO-160? If their system does go into reboot due to brown-out, does it come up reliably and with no adverse consequences? If I had a product that couldn't stay fully awake during engine cranking, it would have a cold-boot routine on a brown-out detector that couldn't care less if it were the first, second or tenth reboot event triggered over the last 60 seconds. There are no excuses for allowing any less stable performance to find its way onto an airplane. System complexities in our automobiles doubles every few years and there are millions of folks out there who expect and receive good operating characteristics on mornings so cold that he battery barely turns the engine over. I've had some discussions with Lancair concerning some FADEC systems now being installed by some of their customers. This piece of ( $%#%$) needs a pampered bus source in order to achieve the minimal functions necessary to get the engine started. In my never so humble opinion, this behavior is inexcusable. I've got some ideas I'll be discussing with them during my next trip out there in January for working around this idiosyncrasy in the FADEC. Let's see if the concerns you've identified are real first. >I'm building a 14v plane. Which currents are you concerned with. Some >of them were my best guesses. Some of them were obtained from a >reference sheet of actual amp draws provided by Brent Regan. If Brents >plane is a 28v plane, then I will need to double all the values I got >from him. Do you know if his plane is? I hate to bother him with such >a trivial question in light of the events last week...I'm sure he has >enough to deal with. What happened to Brent last week? Don't worry about it. It was just a note in passing. I think I saw something less than 6A for position lights. It's not important right now. We need to build a framework for organizing and analyzing all the data before we quibble over the actual sizes of numbers. >Thanks for the help. Your expertise and guidance is appreciated more >than you realize. You're helping me too . . . more than you realize. I'm really stoked by this opportunity to run all the traps here on the List . . . I've done in numerous times in the past on individual OBAM projects and more times than I'd like to recall on spam-cans. Each pass though it refines and cements good ideas . . . being able to share it with the List readers makes this one of the more promising efforts yet. Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 20, 2002
Subject: Re: RE: System architecture
William Slaughter wrote: > > > Bob, > May I assume that the ($%#%$) FADEC unit you're referring to is the > Aerosance unit? I'm installing one in my RV-8 (money has already changed > hands), and am planning a 7.2 AH battery/SD-8 alternator as a dedicated > power source (pampered buss) for the FADEC. While I certainly agree that > this shouldn't be necessary, their unit is currently the only game in town > for integrated, computerized fuel and spark management of the sort we are > all used to having in our cars. If a pampered buss is what it needs at this > time, that's a price I'm willing to pay. I am anxious to hear your thoughts > on how to best configure the electrical system to accommodate their unit. > While I'm well aware that "It's the pioneers who get the arrows in their > backs.", I've been so impressed by the renaissance in automotive performance > over the last decade, which has been largely enabled by computerized engine > management, that I just can't see building a 21st century aircraft > powerplant any other way. So far, everyone I have personally spoken to who > has actually installed and flown on of the Aerosance units is very pleased. > None of them said it was the path on least resistance, however. While my > system architecture will certainly not compare with the complexity of the > Lancairs, I've found this thread a very interesting case study. As always, > thanks for the time and energy you devote to these very educational > exercises. > > William Slaughter > RV-8 N492WS in progress > I just looked at their price list. If I could afford that much for ignition & fuel injection, I'd just buy a Sai Marchetti & be done with it. :-) Seriously, If you want similar performance for 1/10 the cost, talk to Tracy Crook at Real World Solutions. He probably has more hours on the unit he designed (flying on an RV-4) than all the Aerosance units combined. He doesn't consider his unit a 'FADEC' because true FADEC gives the computer 'Full Authority' with the pilot only making requests to the computer. The web site lists various alternative engines, but he's currently working with someone installing one on a Lycosaur (software changes). http://www.rotaryaviation.com/eficont.html Charlie ________________________________________________________________________________
From: "Jim & Jeanette Oberst" <joberst@cox-internet.com>
Subject: Strobe "reconditioning"
Date: Oct 20, 2002
I have a Whelen strobe light power supply that I haven't powered up in many years. I have heard that the capacitors in strobe supplies "weaken" after long periods of inactivity, and have to be slowly trained up to normal voltage. Can anyone advise me on how to do this? Jim Oberst ________________________________________________________________________________
Date: Oct 20, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Strobe "reconditioning"
><joberst@cox-internet.com> > >I have a Whelen strobe light power supply that I haven't powered up in many >years. I have heard that the capacitors in strobe supplies "weaken" after >long periods of inactivity, and have to be slowly trained up to normal >voltage. Can anyone advise me on how to do this? Hook up the 14 volt supply leads to a 6v battery. Leave the strobe head(s) disconnected. After 10 hours or so, apply full 12v for another 10 hours. Then you can hook up heads and see how it works. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2002
Check on the Whelen web site. At one time, they said that you should re-form the electrolytic capacitors with about 70% of normal voltage. I even wrote and article about the procedure. The print wasn't even dry when some one wrote me saying that it was no longer necessary; that they had installed better capacitors. So I would check with Whelen. Might even phone them. They might say you need to re-form at a lower voltage or they may say, "just turn them on!" Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Jim & Jeanette Oberst" <joberst@cox-internet.com> Subject: AeroElectric-List: Strobe "reconditioning" <joberst@cox-internet.com> > > I have a Whelen strobe light power supply that I haven't powered up in many > years. I have heard that the capacitors in strobe supplies "weaken" after > long periods of inactivity, and have to be slowly trained up to normal > voltage. Can anyone advise me on how to do this? > > Jim Oberst > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 20, 2002
Subject: Re: Influencing you legislators (was: standing up to
be counted. . .) >My wife & I recently participated in a successful grass-roots campaign in >support of a bill to fund a particular kind of leukemia research. Here is >how we >were told to get the word to the right place. > >In the post 9-11 environment, DC legislators might not receive hard-copy mail >for months. Email is so easy to fake an source address that little weight is >given emails by the staff. We were told to contact the legislator's staff >(local >or DC) & obtain the name of the assistant in charge of the field of interest. >Then obtain that assistant's fax number in DC. Faxes should include your name, >address & if desired, your phone number. This makes it easier for the staff to >verify that you are a legitimate voter. > >A few hundred faxes resulted in our legislator's shift from not even being >aware >of the bill to being a co-sponsor. > >Hope this is useful info. > >Charlie Sure. Every effort one makes to make their communications more focused can't do anything but help. We've moved through many eras starting with the hunter-gatherers, agrarian, craftsman, industrial, and now find ourselves well along in the technological age and on the brink of a new era . . . the information age. Years ago all we had was newspapers and mail. Then came telephone, radio, television, and even fax machines although they were rarely use by ordinary individuals. But now one can send and receive faxes through their computer. It just keeps getting better and better. The Internet is making it very difficult for those who would call themselves our learned leaders to keep a low profile on behavior that went relatively unnoticed for many years behind a snow storm of selective information dissemination by the classic "news" services. Even now, the new technology for sharing information makes it possible for us to have this list-server and share our knowledge on a far greater scale than ever before possible and for very little cost. The Internet has only begun the profound effects on options it offers for new ways to conduct our lives. It's also a powerful tool for spotlighting dishonorable behavior by those who embellish their names with "honorable" and hope we haven't noticed things that would have us believe otherwise. Bob . . . ________________________________________________________________________________
Date: Oct 20, 2002
I went out to the www.whelen.com and the warning is still there.... WARNING: Strobe light power supplies are meant to be used, not to remain in an inactive state. Use them at all times, this will improve their proper functioning. Any strobe light power supply that has been out of service for a long period of time is subject to failure because the electrolytic condenser loses the polarity formation. A strobe light power supply not having been used for one year or longer is vulnerable to failure. If this is the case, it is recommended to start operating the system on a voltage that is reduced by 25 percent for 10 to 15 minutes before putting the power supply into normal service. This will prevent overheating of the condenser while they reform. If the power supply, after a long period of non use, is operated at full voltage immediately, there is an excellent possibility that the condenser will become overheated. ----- Original Message ----- From: "Cy Galley" <cgalley(at)qcbc.org> Subject: Re: AeroElectric-List: Strobe "reconditioning" > > Check on the Whelen web site. At one time, they said that you should > re-form the electrolytic capacitors with about 70% of normal voltage. I even > wrote and article about the procedure. The print wasn't even dry when some > one wrote me saying that it was no longer necessary; that they had installed > better capacitors. So I would check with Whelen. Might even phone them. > They might say you need to re-form at a lower voltage or they may say, "just > turn them on!" > > Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh > > Editor, EAA Safety Programs > cgalley(at)qcbc.org or experimenter(at)eaa.org > > Always looking for articles for the Experimenter > > ----- Original Message ----- > From: "Jim & Jeanette Oberst" <joberst@cox-internet.com> > To: > Subject: AeroElectric-List: Strobe "reconditioning" > > > <joberst@cox-internet.com> > > > > I have a Whelen strobe light power supply that I haven't powered up in > many > > years. I have heard that the capacitors in strobe supplies "weaken" after > > long periods of inactivity, and have to be slowly trained up to normal > > voltage. Can anyone advise me on how to do this? > > > > Jim Oberst > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 20, 2002
Subject: RE: Influencing your suppliers (was: System Architecture)
> > >Bob, >May I assume that the ($%#%$) FADEC unit you're referring to is the >Aerosance unit? I'm installing one in my RV-8 (money has already changed >hands), and am planning a 7.2 AH battery/SD-8 alternator as a dedicated >power source (pampered buss) for the FADEC. While I certainly agree that >this shouldn't be necessary, their unit is currently the only game in town >for integrated, computerized fuel and spark management of the sort we are >all used to having in our cars. If a pampered buss is what it needs at this >time, that's a price I'm willing to pay. I am anxious to hear your thoughts >on how to best configure the electrical system to accommodate their unit. I don't recall now which brand of FADEC I was looking at. I'll update you all when we have a handle on ways to make it work. I'm working on several approaches. The obvious is a separate battery that doesn't get loaded with starter current. This is Lancair's present approach. But if it's a battery that CAN'T help with cranking, then the system gets one BIG battery and one SMALL battery which kind of hoses up the advantages of dual-identical-batteries for maintenance. I'm looking at a couple of hardware approaches that eliminate the need for a high maintenance battery . . . >While I'm well aware that "It's the pioneers who get the arrows in their >backs.", I've been so impressed by the renaissance in automotive performance >over the last decade, which has been largely enabled by computerized engine >management, that I just can't see building a 21st century aircraft >powerplant any other way. So far, everyone I have personally spoken to who >has actually installed and flown on of the Aerosance units is very pleased. I have no doubts that the folks who designed the current offerings were concentrating very hard on performance issues under "normal cruising" conditions. It's almost a dead-nuts given that an all electronic approach will beat the socks off of carbs/n/mags . . . If they had just gone the final step further, taken advantage of about 40 years of experience and took the last step to make sure the weakest link in cranking performance didn't happen in THEIR product. >None of them said it was the path on least resistance, however. While my >system architecture will certainly not compare with the complexity of the >Lancairs, I've found this thread a very interesting case study. As always, >thanks for the time and energy you devote to these very educational >exercises. We'll figure out a way to make them work. That doesn't relieve any of us from obligation as responsible consumers to rag their butts for not doing their homework. I've often suggested that builders stop by the booths of such vendors at OSH and ask lots of questions. Show lots of interest and then pop the biggie . . . "What do I need to do to pamper your system so it will work in my airplane?" When you get the "bad" news, just shake your head sadly and walk away. Tell them you'll check back with them next year. Do this even if you're not particularly interested in owning the thing right now. Now, if you really want the system and you're willing to learn to live with it's shortcomings, go ahead and order it about two weeks after you repeat the same Q&A performance over the phone. I just mentioned in another post that we're acquiring powerful new tools in the age of information. One number every supplier is learning to track is potential lost sales due to poor consumer perceptions. We can make a BIG impression by making them think they're loosing sales due to design and performance shortfalls. We can also make a big impression by letting them know that LOTS of folks are becoming AWARE of their shortfalls. If we don't do this, it's unlikely that the problems will ever be fixed. Bob . . . ________________________________________________________________________________
Date: Oct 21, 2002
At the least, I will modify my AV bus to have a diode in series with the AV switch, and then add an Alternate Feed switch off the battery bus. Unfortunately, there was an accident at Brent's airstrip on Tuesday involving 599L, the Lancair factory IVP, and 3 CFS/SFS employees (Grant, Barry, and Nate. From Aero-News.Net: http://www.aero-news.net/news/sport.cfm?ContentBlockID=6135 I'll get working on modifying the spreadsheet, and we'll go from there. Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: System architecture > > >I will re-read 17 and get back to you. My initial thoughts are that the >SFS as well as the Xbow AHRS and the Merlin Datalink system all have >computers in them. The SFS runs on a PC platform running NT I believe. >Therefore, low voltage dropouts causing the SFS to re-boot in mid stream >of the boot-up cycle does not seem like a good idea to me (or to the >people at Lancair). We all know how finicky pc's with MS OS's on them >can be, especially during boot-up. I just don't see the need to risk >it. Also, the Xbow behaves similarly from my understanding, where it >has to "boot-up" and takes some time to "align" itself or >whatever.....re-booting it during this time doesn't seem like a good >idea either. Same goes with the Merlin. If these units had power >switches on them, I would totally agree, and would never even consider >an avionics relay/switch....I would just turn them off. However, they >don't, so I can't, so I feel it is warranted. Do you disagree? I'd >love nothing else than to have the 2 switch spots open back up on my >already stuffed panel :) Risks come in two classes. (1) Those that are understood, quantified and accounted for as part of the system design and operation and (2) those that are rumored and not supported with facts from the manufacturer and cause us to do all kinds of things, useful or not, to assuage our worries. Call the folks who make the gizmos in question. Ask them what the stable operation input voltage range is for their products. If it doesn't extend down to 9.0 volts or less, ask them if they ever heard of DO-160? If their system does go into reboot due to brown-out, does it come up reliably and with no adverse consequences? If I had a product that couldn't stay fully awake during engine cranking, it would have a cold-boot routine on a brown-out detector that couldn't care less if it were the first, second or tenth reboot event triggered over the last 60 seconds. There are no excuses for allowing any less stable performance to find its way onto an airplane. System complexities in our automobiles doubles every few years and there are millions of folks out there who expect and receive good operating characteristics on mornings so cold that he battery barely turns the engine over. I've had some discussions with Lancair concerning some FADEC systems now being installed by some of their customers. This piece of ( $%#%$) needs a pampered bus source in order to achieve the minimal functions necessary to get the engine started. In my never so humble opinion, this behavior is inexcusable. I've got some ideas I'll be discussing with them during my next trip out there in January for working around this idiosyncrasy in the FADEC. Let's see if the concerns you've identified are real first. >I'm building a 14v plane. Which currents are you concerned with. Some >of them were my best guesses. Some of them were obtained from a >reference sheet of actual amp draws provided by Brent Regan. If Brents >plane is a 28v plane, then I will need to double all the values I got >from him. Do you know if his plane is? I hate to bother him with such >a trivial question in light of the events last week...I'm sure he has >enough to deal with. What happened to Brent last week? Don't worry about it. It was just a note in passing. I think I saw something less than 6A for position lights. It's not important right now. We need to build a framework for organizing and analyzing all the data before we quibble over the actual sizes of numbers. >Thanks for the help. Your expertise and guidance is appreciated more >than you realize. You're helping me too . . . more than you realize. I'm really stoked by this opportunity to run all the traps here on the List . . . I've done in numerous times in the past on individual OBAM projects and more times than I'd like to recall on spam-cans. Each pass though it refines and cements good ideas . . . being able to share it with the List readers makes this one of the more promising efforts yet. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: LongEZ - Rudimenary system planning
Date: Oct 21, 2002
Bob, After attending your seminar in SLC sometime ago, I came home & began the task of planning the electrical system for my Long-EZ. The choice of avionics, instrumentation & etc. was an ongoing tug of war between this, that and the latest. I went to OSH this year with a list & money in hand, my mind set (at least I thought so, but one has to be somewhat flexible) and purchased avionics, engine instruments & some misc goodies. Due to some "lack of performance" on the intended engine instrumentation, I went with the Elec Int'l brand. I got some very good deals & left pleased. Here is what I have tenatively placed on each bus: MAIN BUS: Low voltage wrng Spare (Possible future cabin heat...) Landing lgt Nav & Strobe lgts (2-10 swtch) Intercom & audio (CD/MP3) Elec Int'l Analyzer & Fuel flow instrm'ts Starter Contactor DigiTrak A/P Lndg/Air Brake Nose Gear System AUXILLARY BUS: Rocky Mtn uEncoder SL/30 Com SL/30 Nav & Terra Digital CDI Apollo GX-65 Com-#2 Apollo GX-65 GPS SL/70 Transpdr Spare (future elec AI) Spare (future elec DG) Turn Co-ord Elec Int'l Tach, Oil, & V/A gauges BATTERY BUS: Map & Inst lights/ Gear & Canopy Warn'g System Spare LSE Elect'c Ign Handheld Nav/Com/GPS (Cigarette lghtr plug) Auxillary Bus Fuel Boost/Primer sys Would like to have the Instm't lights & Warning system circuits on the Main buss, how about adding them in with the low voltage circuit? I have worked up most of the numbers for the loads on each, but would appreciate any input thus far. I used AutoCAD & your CD for all of my Elec System drawings & am willing to share what I have to date with those who are interested. Thank you very much, Bob, for the excellent work and time you have devoted to the homebuilder's community. Your efforts have made this a very pleasurable experience for me. Les N69HZ (reserved) ________________________________________________________________________________
Date: Oct 21, 2002
>Hmmm......Okay. You are correct, the Essential Bus is the only "always >hot" thing in the system. > >As a matter of fact I found out how much a 22awg fuse link can stand today. > >I have about half of the wiring done, and hooked up the battery for a >"smoke test." It worked! Quite a nice plume of smoke! It came from your >Overvoltage protection module, and the feed to it was of course the fuse >link you show for the alternator field feed. > >The only thing that was operating at the time was the flap circuit. I >found nothing miswired, and the flaps and Master contactor still work fine >after the smoke. The B-lead contactor was not even hooked up at the >time. I tried it since, and it works too. The fuselink will need to be >replaced.....the insulation got all mushy inside the sleeve. The O/V >module wires are now stuck together, but not really melted. And the heat >shrink shrank lots more. > >I also must assume that the O/V module has departed this world. It was >wired correctly, correct polarity, etc. Was it a bad module? > >I have since hooked up more stuff, and everything works and nothing gets >hot. I didn't change anything (other than adding components) since the >"smoke test." Hmmm . . . did you have a 5A circuit breaker in series with the ov module or JUST the fusible link? The fusible link is to protect a wired EXTENSION of the main bus between the bus feeder and the 5A breaker on the panel. It's not intended to be the protective device that opens when the ov module trips. Send me your OV module and I'll fix it. I'll also see if there was any reason by way of its assembly that caused it to nuisance trip. Do you have enough materials to replace the 22AWG fusible link that burned? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 21, 2002
> > >At the least, I will modify my AV bus to have a diode in series with the >AV switch, and then add an Alternate Feed switch off the battery bus. What is the value to be gained in having a separately switched avionics bus? >Unfortunately, there was an accident at Brent's airstrip on Tuesday >involving 599L, the Lancair factory IVP, and 3 CFS/SFS employees (Grant, >Barry, and Nate. From Aero-News.Net: >http://www.aero-news.net/news/sport.cfm?ContentBlockID=6135 Damn! This is sad. Thanks for the heads-up on the accident. These toys we love so much are anything but "safe" folks. They have whirring propellers that will mince you in a millisecond, they're death traps in a storm, and viciously unforgiving of inattention to operational limits. I had an instrument instructor who once suggested that when on final for any approach you would do well to be thinking, "This may the approach that I'll really get to do a go-around." On short final, we are prone to the mindset that every approach WILL end with a landing. I've ridden with pilots who take their hand off the throttle and fly with both hands on final. Even so, there are some "canyons" from which a graceful exit are not possible including runway edges with drop-offs onto gravel . . . Be careful out there. Bob . . . ________________________________________________________________________________
Subject: Re: Measuring Load
Date: Oct 21, 2002
John Slade wrote: > > > While we're talking about loads, I have a dumb question about my multimeter > (from B&C). > This may be pretty basic, so bare with me. So far, all I've been able to use > it for is testing continuity. Last night I wanted to see which was which of > two resitors, a 1k and a 470 ohm. > I tested each and had no clue what the readings meant. I've since identified > the resitors by looking at the packet. > > Here's the readings: > > No connection: > 200 ohm scale: 62.8 ... The meter is leaky... > 2k ohm scale: .423 ... The meter is leaky... > 20k ohm scale: 1.26 ... The meter is leaky... > *** I believe that digital ohmmeters work by attempting to output a constant current into the test resistance, and measuring the voltage across it. By ohms law Voltage = Current * Resistance. If Current is a known constant, then you can find out Resistance by measuring Voltage. When there is nothing connected to the meter, the internal Current source should raise the Voltage at the test leads as high as it can go - trying to push that constant Current through the air. The meter should measure that Voltage and show "off the scale". An internal leakage path in your meter is shorting out some current, letting the meter read a "resistance" with nothing connected. This "resistance" varies with range setting because the constant current output or voltage full-scale is different. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Re: loadmeter/voltmeter
Date: Oct 21, 2002
Robert L. Nuckolls, III wrote: > > > > > >*** Speaking of voltmeters, I was at the auto parts store, and there was a > >cute little digital voltmeter that plugs into the cigarette lighter socket. > >I had to have it. Now it lives in my Sundowner. I don't smoke :). > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > Radio Shack used to offer a bar-graph voltmeter that plugged into > the cigar lighter too. Never put my hands on one to see how it > was scaled or how accurate it was. Might do that next time I see > one. Have you checked the accuracy of your purchase against a > good multi-meter? It's getting easier by the year to do accurate > voltage measurement and display so accuracy issues should be > diminishing . . . but there are some early offerings out there > that were off by more than 0.5 volts at 14.0 volts. > *** The meter is made by "Vector". It claims to be accurate to .1V. Here's a URL: http://store.yahoo.com/rodi/vec008.html - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Diode
Date: Oct 21, 2002
The use of the Radio Shack #276-1185 is a 25A 50PIV bridge. In the book It is recommended to use only one leg of this device. The reason for this is that it is hard to get a single power diode in a package that is as easy to bolt on and has its own heatsink for any reasonable price. www.allelectronics.com has the same part #FWB250 for $1.75. Almost everybody sells one of these. There are some considerations that should be examined: The 25 Amp is not continuous 25A DC. It is rectified average current. The true DC continuous current is (depending on test method) 12.5 Amps or 17.7. This is derates linearly from 70 degC to 150 degC where the current is zero. The continuous DC current is not specified because the FWB is almost never used this way. Teasing the real data out of the AC published AC data is not easy. Granted, the lower current typical of small airplanes should give no problem, but if the airplane has a lot of accessories on the essential bus, some things should be examined. The power loss through the diode (and the voltage drop) can be critical in emergency situations. At 12.5A the forward voltage drop is 1.1 VDC. This Vf drops off with current. This would be okay at high voltages, but if the alternator has gone kaput this becomes an important waste. I suggest it makes a lot more sense to use a whopping big single Schottky diode for this purpose, for example IR-100BGQ030. It has some great advantages: 1) At 150 degC and 25A it would still work just fine. The RS FWB part would be long dead if pushed it this far. 2) Its forward voltage drop Vf at 25A is less than 0.3 VDC. Downsides? Any comments? Want to buy some? Regards, Eric M. Jones ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Re: 10008 Parrish
>Below is the result of your inquiry. It was submitted by >Rudy Parrish (fly90u(at)hotmail.com) on Monday, October 21, 2002 at 11:14:19 > >Comments/Questions: Could you recommend a charger or charger/analyzer for >use with an RG battery (Concorde). Concorde's instructions require a >constant-potential charger, but I have yet to find one on the market, >short of high-end professional equipment, and none of my acquaintances at >the airport have one either. Is it out of the question to use a constant >amperage charger on this type of battery? First, why do you think you need a charger? An RG battery has a very low, self-discharge rate. Once installed in your airplane, it should perform very nicely as long as the airplane doesn't sit for 6 months at a time. Almost any automotive charger from Wall-Mart, etc that advertises "automatic cutoff" Harbor Freight has one on sale at http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=45005 for $20. After any charger has been attached to your battery for 24 hours, put a voltmeter on the battery terminals and see that the reading does not exceed 14 volts. If you're simply wanting to maintain a battery for long periods of storage, about ANY little "trickle charger" combined with a clock switch can be used to turn the charger on for 30 minutes or so every day. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
From: Livingston John W Civ ASC/ENFD <John.Livingston(at)wpafb.af.mil>
Subject: Diode
Date: Oct 21, 2002
Eric, The way I understand it, the essential bus currents should not be high enough to worry about it, and the diode is not used when the alternator has gone south, a direct feed is then being used from the battery. John -----Original Message----- From: Eric M. Jones [mailto:emjones(at)charter.net] Subject: AeroElectric-List: Diode The use of the Radio Shack #276-1185 is a 25A 50PIV bridge. In the book It is recommended to use only one leg of this device. The reason for this is that it is hard to get a single power diode in a package that is as easy to bolt on and has its own heatsink for any reasonable price. www.allelectronics.com has the same part #FWB250 for $1.75. Almost everybody sells one of these. There are some considerations that should be examined: The 25 Amp is not continuous 25A DC. It is rectified average current. The true DC continuous current is (depending on test method) 12.5 Amps or 17.7. This is derates linearly from 70 degC to 150 degC where the current is zero. The continuous DC current is not specified because the FWB is almost never used this way. Teasing the real data out of the AC published AC data is not easy. Granted, the lower current typical of small airplanes should give no problem, but if the airplane has a lot of accessories on the essential bus, some things should be examined. The power loss through the diode (and the voltage drop) can be critical in emergency situations. At 12.5A the forward voltage drop is 1.1 VDC. This Vf drops off with current. This would be okay at high voltages, but if the alternator has gone kaput this becomes an important waste. I suggest it makes a lot more sense to use a whopping big single Schottky diode for this purpose, for example IR-100BGQ030. It has some great advantages: 1) At 150 degC and 25A it would still work just fine. The RS FWB part would be long dead if pushed it this far. 2) Its forward voltage drop Vf at 25A is less than 0.3 VDC. Downsides? Any comments? Want to buy some? Regards, Eric M. Jones ________________________________________________________________________________
Date: Oct 21, 2002
Bob, Is there a way I can reach you to discuss this instead of typing it all out? I've contacted SFS and Xbow again, and pretty much have been told the same thing again. SFS, Robert, 208.389.9959 Xbow, Dean, 408.965.3300 The xbow is DO-160 for class 23. It takes it about 1 second to boot up, starts sending data, and takes about 60 seconds to calibrate itself to straight and level. They suggest an avionics master, but say it shouldn't require it. SFS is a little different. The certified version from CFS is DO-160 Delta hardware and DO-178 Alpha software. However, the certified version hardware is slightly different than the SFS stuff. The SFS stuff was DO-160 tested, but nothing was really done to correct any of the small problems found (not really sure what was found though)...this stuff was corrected in the hardware of the CFS certified stuff. When the unit sees below 9.5 volts, its shuts down and waits for the voltage to come back up. It has about a 90 second boot cycle. The first 5-6 seconds are done in MSDOS 6.22 where it checks for the cards and whatnot. Then in another 5-6 seconds, it switches over to its proprietary software that does CRC checks, opens files, and gets the unit fired up. This takes another 75-80 seconds, so 90 seconds total. If during the time it is opening a file the voltage drops and it shuts down, it can mess things up. Also, it can loose (fry) the voice annunciation chip. These are the reasons I saw fit for a AV master. With the master, I can protect the SFS. By adding an AV ALT FEED along with a diode in series with the AV MASTER, I can reduce the chance of an AV MASTER switch ruining my day. I realize this is adding parts to fix someone elses problem (SFS), but it seems the only logical way. The SFS basically requires it, or it "could" do nasty things if I timed the start just wrong. Since I'm basically stuck with putting the AV MASTER in, I'll back it up with a diode in line, and an ALT AV FEED. Not the best idea in a perfect world, but the best solution I can see to what I've been given? I'm still working on the load spreadsheet, modifying it for the different phases of flight. I'll be sending it in soon. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: System architecture > > >At the least, I will modify my AV bus to have a diode in series with the >AV switch, and then add an Alternate Feed switch off the battery bus. What is the value to be gained in having a separately switched avionics bus? >Unfortunately, there was an accident at Brent's airstrip on Tuesday >involving 599L, the Lancair factory IVP, and 3 CFS/SFS employees (Grant, >Barry, and Nate. From Aero-News.Net: >http://www.aero-news.net/news/sport.cfm?ContentBlockID=6135 Damn! This is sad. Thanks for the heads-up on the accident. These toys we love so much are anything but "safe" folks. They have whirring propellers that will mince you in a millisecond, they're death traps in a storm, and viciously unforgiving of inattention to operational limits. I had an instrument instructor who once suggested that when on final for any approach you would do well to be thinking, "This may the approach that I'll really get to do a go-around." On short final, we are prone to the mindset that every approach WILL end with a landing. I've ridden with pilots who take their hand off the throttle and fly with both hands on final. Even so, there are some "canyons" from which a graceful exit are not possible including runway edges with drop-offs onto gravel . . . Be careful out there. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Date: Oct 21, 2002
Just a thought if you are planning on a GPS, the Garmin 196 has a voltmeter... I use it to check the generator voltages on my Apache before takeoff... Quicker and more accurate than watching the verrry slow needle on the 45 year old ammeter... Denny ----- Original Message ----- From: <jerry(at)tr2.com> Subject: Re: AeroElectric-List: Re: loadmeter/voltmeter > > Robert L. Nuckolls, III wrote: > > > > > > > > > >*** Speaking of voltmeters, I was at the auto parts store, and there was a > > >cute little digital voltmeter that plugs into the cigarette lighter socket. > > >I had to have it. Now it lives in my Sundowner. I don't smoke :). > > > > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > > > Radio Shack used to offer a bar-graph voltmeter that plugged into > > the cigar lighter too. Never put my hands on one to see how it > > was scaled or how accurate it was. Might do that next time I see > > one. Have you checked the accuracy of your purchase against a > > good multi-meter? It's getting easier by the year to do accurate > > voltage measurement and display so accuracy issues should be > > diminishing . . . but there are some early offerings out there > > that were off by more than 0.5 volts at 14.0 volts. > > > > *** The meter is made by "Vector". It claims to be accurate to .1V. Here's > a URL: > > http://store.yahoo.com/rodi/vec008.html > > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Avionics Switches
Bob, I have read your opinions regarding avionics master switches. If a specific avionics item does not have it's own switch, do you recommend putting one in? It appears to me that if you had redundant avionics (electric AI for example), in an alternator failure situation and wanded to preserve battery, you would want to turn off the redundant instrements unless they were needed. As such, items like an attitude indicator, turn & bank, that do not have thier own internal switch, could justify having one. (not all ganged up on a single master switch for all avionics, just switches for those that don't have thier own.) - Jim ________________________________________________________________________________
Subject: Re: Diode
Date: Oct 21, 2002
Livingston John W Civ ASC/ENFD wrote: > > > The 25 Amp is not continuous 25A DC. It is rectified average current. The > true DC continuous current is (depending on test method) 12.5 Amps or > 17.7. This is derates linearly from 70 degC to 150 degC where the current > is zero. The continuous DC current is not specified because the FWB is > almost never used this way. Teasing the real data out of the AC published > AC data is not easy. > *** Seems to me you should be able to get more out of it since you're not using the other three diodes. Also, a decent heat sink will go a long way to getting full output through the thing. And an airframe can be a VERY decent heatsink. I once built a 20A continuous power supply. I used one of those RS fullwave bridges. I bolted it to a 1/4" aluminum heat spreader that was bolted to a 1/4" aluminum bottom plate ( of the entire supply ). I had a pretty enormous filter capacitor, which tended to make life harder on the rectifiers - because the cap would pull a huge gob of current every time the diodes conducted. A discharged cap looks like a short circuit. I think it would be worth trying out the RS bridge with the desired DC running through it, well heatsinked, and a thermal probe to figure out if it's doing OK. > I suggest it makes a lot more sense to use a whopping big single Schottky > diode for this purpose, for example IR-100BGQ030. It has some great > 2) Its forward voltage drop Vf at 25A is less than 0.3 VDC. *** That's a VERY good point. If you have stuff that's line voltage sensitive, and the alternator is dead, and you're approaching that airport - that extra volt could be the difference between making and not making it.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Re: Diode Bridge Rectifiers vs. Others
> >The use of the Radio Shack #276-1185 is a 25A 50PIV bridge. In the book It >is recommended to use only one leg of this device. The reason for this is >that it is hard to get a single power diode in a package that is as easy >to bolt on and has its own heatsink for any reasonable price. >www.allelectronics.com has the same part #FWB250 for $1.75. Almost >everybody sells one of these. > > >There are some considerations that should be examined: > >The 25 Amp is not continuous 25A DC. It is rectified average current. The >true DC continuous current is (depending on test method) 12.5 Amps or >17.7. This is derates linearly from 70 degC to 150 degC where the current >is zero. The continuous DC current is not specified because the FWB is >almost never used this way. Teasing the real data out of the AC published >AC data is not easy. The folks that publish data sheets and pick ratings for their parts don't seem to talk to each other much. Looking at the data sheet for the 100BGQ030 part from IR we infer that the "100" given in their part number is a "current" rating. Looking at the Major Ratings chart on the data sheet at http://216.55.140.222/temp/100bgq030.pdf we note that a "rectangular waveform average rating" of 100A (180 degree square wave conduction angle) and a DC (RMS) rating of 141 amps. This means that the part-number-rating is NOT the DC rating for the device. Looking at the data sheet for the 25F series devices at http://216.55.140.222/temp/25f.pdf we see that the part number current rating for these devices IS the DC/RMS value. Figures 1 and 2 show how the device needs to be de-rated when the average current flow occurs over decreasing conduction angles while working as a rectifier in AC systems. Let's look at a 35A bridge rectifier from international rectifier. Excepts are published at http://216.55.140.222/temp/36mb.pdf Here again, we see that the part number current rating of 35A is the DC current rating which gets de-rated to 28A for capacitive input filters (conduction angles less than 180 degrees). The 100A Schottky device is seems to be the odd-ball in that it's part number rating is not also the DC rating. >Granted, the lower current typical of small airplanes should give no >problem, but if the airplane has a lot of accessories on the essential >bus, some things should be examined. An e-bus load that even begins to push the ratings of a 25-35A rectifier assembly has waaaayyyyyy too much stuff on it . . . >The power loss through the diode (and the voltage drop) can be critical in >emergency situations. At 12.5A the forward voltage drop is 1.1 VDC. This >Vf drops off with current. This would be okay at high voltages, but if the >alternator has gone kaput this becomes an important waste. How so? The 1.1 volts is a maximum value never experienced in the way we're going to use the part. E-bus loads should be down around 3-6 amps continuous. A 35A device shows a drop on the order of .7 to .8 volts or less at this current level. When you are operating battery only, we EXPECT things on the e-bus to operate directly from the battery with an output voltage range of 12.5 volts (100% charge) down to 10.5 volts (0% charge). When the alternator is operating, the main bus is running over a range of 13.8 to 14.6 volts. Throw away 0.8 volts due to diode drop then you have a 13.0 to 13.6 volt e-bus . . . 0.5 to 1.1 volts more than a battery will ever deliver. When the alternator goes "kaput" . . . the diode is there to PREVENT powering the main bus via the e-bus alternate feed. The e-bus gets powered directly from the battery during alternator out ops. >I suggest it makes a lot more sense to use a whopping big single Schottky >diode for this purpose, for example IR-100BGQ030. It has some great advantages: (Referring to the data sheet cited above) Aside from the fact that this part has about 1/2 the voltage drop (which isn't an issue anyhow) How would we mount this critter? It's designed to be soldered to an etched circuit board. There are lots of diode configurations out there with attractive electrical ratings . . . the diode bridge we've recommended for a number of years now was favored for it's installer friendly configuration. Take a peek at the 25F part. This is a nice part, works good, lasts a long time . . . but it needs to be mounted on some kind of heat-sinking bracket. It needs insulating hardware (usually mica washers and nylon bushing), nuts, washers, terminals and one solder joint to install. The bridge rectifier is about a close to plug-n-play as I've been able to find for this application. >1) At 150 degC and 25A it would still work just fine. The RS FWB >part would be long dead if pushed it this far. > >2) Its forward voltage drop Vf at 25A is less than 0.3 VDC. All the things you've said are true. However, I'll suggest that the recommended devices ARE electrically suited for the intended application and mechanically the most elegant solution available. Bob . . . ________________________________________________________________________________
Subject: ELT control wire?
Date: Oct 21, 2002
Hello, I'm installing an ACK E01 ELT in my Sundowner. ACK supplies a 16-foot extension cable to connect the ELT control panel to the ELT. Given the ELT location in the Sundowner - all the way back in the tail - this is probably not long enough. The ACK manual says that you can use a cable up to 150 feet, but they don't say anything about what kind of cable to use. I figured that using the same as they did, would be pretty safe. Their cable says: E166160 UL ( actually, it's the UL backwards-R+U symbol ) AWM 20251 26AWG 60 degrees C 150V Physically, it's a four-conductor UTP ( telephone ) wire with an ordinary RJ11 crimpon connector at one end, and a FEMALE RJ11 crimp-on socket at the other end. I have not been able to find one of these female crimp-on sockets. I have found a similar cable assembly - with an identical socket - that was 25 feet long. But it has no reassuring verbiage printed on the cable. Well, the female end does say "Made in China" :). Anybody know of a source for the Right Stuff? The UL-blessed cable? The female crimp-on connector? Or will the Wrong Stuff work just fine - assuming that I ohm it out first, because I suspect that the pins might be reversed.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: System Design, Load analysis
Date: Oct 21, 2002
I've finished a rough load analysis. http://shannon.v8eaters.com/images/lancair/airplane_amp_draw.xls I'm not sure I have it all correct (actually, I know I don't), and the results kind of surprise me. It looks like my busses are going to require some more thought about the grouping and whatnot, as my amp draws are higher than I expected on the main bus. I'm open to all suggestions Bob. I planned a 70A main alternator (Kelly Aerospace unit) and a B&C 20A aux. Not sure what to do now. Lots of electronics, lots of amp draw :) --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Subject: Re: System Design, Load analysis
Date: Oct 20, 2002
> > I've finished a rough load analysis. > > http://shannon.v8eaters.com/images/lancair/airplane_amp_draw.xls > snip > --- > Shannon Knoepflein <---> kycshann(at)kyol.net > I like the spreadsheet you've done. I did something similar for my RV-6. I did notice that a number of loads you have such as flaps are transient and of short duration. Perhaps these should not be included when calculating the total amp draw? Stan Blanton RV-6 ________________________________________________________________________________
Date: Oct 21, 2002
I have the same situation and the instructions say to start the unit with the voltage reduced by 50%. I plan to reduce it a bit below that and slowly increase it to condition it to "condition" the electrolytics. Bill Lamb ----- Original Message ----- From: "Jim & Jeanette Oberst" <joberst@cox-internet.com> Subject: AeroElectric-List: Strobe "reconditioning" <joberst@cox-internet.com> > > I have a Whelen strobe light power supply that I haven't powered up in many > years. I have heard that the capacitors in strobe supplies "weaken" after > long periods of inactivity, and have to be slowly trained up to normal > voltage. Can anyone advise me on how to do this? > > Jim Oberst > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 21, 2002
I would think the same goes for speed brakes and landing gear pump. You can draw from the battery for the brief time that they are actuated. Once you have the plane cool, you might want to turn off the compressor while climbing for the additional power, unless it is really hot you also don't need it in cruise and maybe not even in decent. These too are a "maybe" load. Remember, you only "need" about 80% of your total load as alternator capacity. If you exceed that you need to turn stuff off that really isn't necessary. Some energy management. Cy Galley Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org ----- Original Message ----- From: "Stan Blanton" <stanb(at)door.net> Subject: Re: AeroElectric-List: System Design, Load analysis > > > > > I've finished a rough load analysis. > > > > http://shannon.v8eaters.com/images/lancair/airplane_amp_draw.xls > > > snip > > --- > > Shannon Knoepflein <---> kycshann(at)kyol.net > > > > I like the spreadsheet you've done. I did something similar for my RV-6. I > did notice that a number of loads you have such as flaps are transient and > of short duration. Perhaps these should not be included when calculating the > total amp draw? > > Stan Blanton > RV-6 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Re: ELT control wire?
Date: Oct 21, 2002
It's just telephone cable. Not critical by any means. Buy the 25 footer and clip off the male end. Reinstall a new male end where you need it and be sure to swap wires accordingly, as the ELT wires cross enroute while the telephone wires don't. Your ELT won't work properly if you just connect it like a telephone! Making it that simple would be too easy!! When you're finished, get out your sharpie and write "Made in USA"! Russ ----- Original Message ----- > > I'm installing an ACK E01 ELT in my Sundowner. ACK supplies a 16-foot > extension cable to connect the ELT control panel to the ELT. Given the ELT > location in the Sundowner - all the way back in the tail - this is probably > not long enough. > > The ACK manual says that you can use a cable up to 150 feet, but they > don't say anything about what kind of cable to use. I figured that using > the same as they did, would be pretty safe. Their cable says: > > E166160 > UL ( actually, it's the UL backwards-R+U symbol ) > AWM > 20251 > 26AWG > 60 degrees C > 150V > > Physically, it's a four-conductor UTP ( telephone ) wire with an ordinary > RJ11 crimpon connector at one end, and a FEMALE RJ11 crimp-on socket at the > other end. I have not been able to find one of these female crimp-on > sockets. I have found a similar cable assembly - with an identical socket - > that was 25 feet long. But it has no reassuring verbiage printed on the > cable. Well, the female end does say "Made in China" :). > > Anybody know of a source for the Right Stuff? The UL-blessed cable? The > female crimp-on connector? Or will the Wrong Stuff work just fine - > assuming that I ohm it out first, because I suspect that the pins might be > reversed.... > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 21, 2002
> > >I've finished a rough load analysis. > >http://shannon.v8eaters.com/images/lancair/airplane_amp_draw.xls > >I'm not sure I have it all correct (actually, I know I don't), and the >results kind of surprise me. It looks like my busses are going to >require some more thought about the grouping and whatnot, as my amp >draws are higher than I expected on the main bus. I'm open to all >suggestions Bob. I planned a 70A main alternator (Kelly Aerospace unit) >and a B&C 20A aux. Not sure what to do now. Lots of electronics, lots >of amp draw :) See, isn't it a good thing we do this before you buy your alternators? :-) Good piece of work on the spread sheet. Now . . . Drive all the intermittent loads like trim motors, flap motors, landing gear pumps, pump relays, etc to zero. Battery will supply momentary "overload" for these items. (are you going to wig/wag landing and taxi lights?) Add in battery contactors at 0.8A each Add another column after Cruise. Call it IFR Cruise. Change the old Cruise to VFR Cruise. IFR Cruise has no exterior lights and probably no A/C VFR Cruise has exterior lights and no pitot heat. A/C will probably run only during ground ops and during climbout to altitude. Probably not during decent and maybe during taxi. Let's see how this impacts your totals. DAVE S . . . are you watching this? Any suggestions? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Re: Avionics Switches
> >Bob, > >I have read your opinions regarding avionics master switches. > >If a specific avionics item does not have it's own switch, do you recommend >putting one in? It appears to me that if you had redundant avionics >(electric AI for example), in an alternator failure situation and wanded to >preserve battery, you would want to turn off the redundant instrements >unless they were needed. As such, items like an attitude indicator, turn & >bank, that do not have thier own internal switch, could justify having one. >(not all ganged up on a single master switch for all avionics, just switches >for those that don't have thier own.) > >- Jim > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Switchable ammeter shunts
Bob, There are two schools of thought as to the placement of the external ammeter shunt. If placed in the Alternator "B" lead, you can moniter the charging function of the alternator, which is probably the most important function of the ammeter. However, it would be nice to also be able to assess "load". Would it not be feazable to place a second external shunt in the "big wire" line from the battery contactors to the main bus. The connection of each shunt to the ammeter being controlled by a SPDT mini-toggle placed next to the ammeter, so that you could select to assess "charging" or "load". I would envision following the charging function most of the time. The "load" mode would be important largely for ground equipment checks, and in the event of an alternator failure, to assess priorities for power conservation. Thanks LRE FEW Mustang Firewall Forward ________________________________________________________________________________
Date: Oct 20, 2002
> > I have a Whelen strobe light power supply that I haven't powered up in many > years. I have heard that the capacitors in strobe supplies "weaken" after > long periods of inactivity, and have to be slowly trained up to normal > voltage. Can anyone advise me on how to do this? > > Jim Oberst > I spoke with Whelen about this this very subject last week. The person I talked with, Jeff Argersinger, told me that it was only a concern if the unit was one of the older "DF" dual flash units as opposed to the newer "CF" comet flash units. The CF units first appeared in the early to mid 90's. Supposedly the newer units have better capacitors. Stan Blanton RV-6 ________________________________________________________________________________
Date: Oct 21, 2002
I abbreviate this to save space: My comment regarding the Radio Shack device NOT being 25A is only to say "be careful with ratings" FWB and most diodes are never rated for DC continuous. You might not discover your mistake until you were in trouble. Your comment regarding the 100BGQ030 not being 100 Amps---I never said that it was. But it IS specified at 50% squarewave. So that's 50A continuous; (I know that's much more than we need). And to keep the temperature down, rating the device even lower gives it plenty of margin for this job. And a lower loss too. Actually, the 100BGQ030 mounts with two screws, but I have built a little mount for the thing. The RS part WOULD certainly do the job for most airplanes, but I still think the whopping big Schottky diode is a perfect solution for the task at hand. Thanks, Eric M. Jones ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Re: Switchable ammeter shunts
> >Bob, > There are two schools of thought as to the placement of the external >ammeter shunt. If placed in the Alternator "B" lead, you can moniter the >charging function of the alternator, which is probably the most important >function of the ammeter. > However, it would be nice to also be able to assess "load". Would it >not be feazable to place a second external shunt in the "big wire" line from >the battery contactors to the main bus. The connection of each shunt to the >ammeter being controlled by a SPDT mini-toggle placed next to the ammeter, so >that you could select to assess "charging" or "load". I would envision >following the charging function most of the time. The "load" mode would be >important largely for ground equipment checks, and in the event of an >alternator failure, to assess priorities for power conservation. Thanks If you wire the alternator b-lead as shown in the Z-drawings, putting a shunt in the main bus feeder would only show bus loads. This value would be equal to alternator output minus that which the battery is taking on to increase its state of charge. How would another current measurement help you operate and/or debug your airplane? Obviously, we can add shunts and voltmeter taps in lots of places around the system. You need to analyze the time and dollars to add such features against the value of having them. In other words, what failures do you anticipate that are easier to (1) detect in flight and/or (2) troubleshoot and fix because you have this extra data? The way I make these decisions is to write the pilot's operating handbook section that deals with this new feature. Suppose somebody besides you is flying the airplane, under what conditions would this new feature be useful to the pilot and what would you write down as a procedure for interpreting the data and reacting to it? Same thing for pages of a maintenance manual. What kinds of failures will enjoy faster resolution for having installed the feature and how would you instruct a mechanic to use it? If the outcome of this documentation exercise shows some real advantages for having these features, then by all means add them in. Bob . . . Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 21, 2002
> >Speaking of which, Bob, I was planning to use one of your >loadmeter/voltmeters in my RV-6 project and was disappointed that you >discontinued them. I held off buying one until I was closer to needing >it and now they are no more. Are you thinking about selling them again? >I'll buy one. > >Ed Holyoke No plans at the moment. In fact, I opened my mouth too early and offered bare boards for those who wanted to assemble their own clones of this instrument. Because the boards had a couple of mistakes which needed cut-n-paste repairs, I trashed the balance of the boards. I'll see if I can re-lay the boards in ExpressPCB (with the errors fixed) and post the artwork along with all the drawings for assembly. Just need a few spare hours . . . Bob . . . ________________________________________________________________________________
Date: Oct 21, 2002
> >Bob, > >I have read your opinions regarding avionics master switches. > >If a specific avionics item does not have it's own switch, do you recommend >putting one in? It appears to me that if you had redundant avionics >(electric AI for example), in an alternator failure situation and wanded to >preserve battery, you would want to turn off the redundant instrements >unless they were needed. As such, items like an attitude indicator, turn & >bank, that do not have thier own internal switch, could justify having one. >(not all ganged up on a single master switch for all avionics, just switches >for those that don't have thier own.) I started to reply to this earlier and see that I hit the "send" button too soon . . . If you're doing an airplane with an e-bus, then being able to control everything on the bus might have some effect on your options for best endurance. If you've got two engine driven power sources, maybe it doesn't matter whether you can control ALL equipment items powered from the e-bus. If you're going dual-bat/dual-alt, then it's and even smaller issue because of the extra output of the SD-20. I don't like to put multiple electro-whizzies on one switch . . . this generates a single point of failure for all those devices. Whether or not you need to add switches to anything not supplied with switch depends on your system architecture, power generation equipment and a load analysis. The goal is to have no more switches than are absolutely necessary for situations requiring loads to be shed. Bob . . . ________________________________________________________________________________
Date: Oct 21, 2002
Subject: Electric Primer
The A Spruce catalog there is an electric primer that describes a solenoid with a spring and plunger. Does this arrangement replace a traditional type primer the same way - i.e., would the switch be operated the same as in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, then throw the switch again, etc.? So would it be wired as a momentary switch? Also, the electric primer is cheaper by at least half of the traditional ones, and you can leave the primer lines on the other side of the firewall. Seems like a no brainer - is there any reason to use the traditional primer? Gary Liming ________________________________________________________________________________
Date: Oct 21, 2002
Sorry to be so dense. But am I to understand, that with the ammeter shunt in the "B" lead as per the Z diagrams, that in the event of alternator failure, ie charging amps =O, then the ammeter will show the current discharge load on the batteries? That is what I'm looking for. I am fully aware of cost benefit ratios. Many of us deal on a daily basis with life threatening risk. The key is to use preplanning to reduce and or manage risk to as low a level as possible. ________________________________________________________________________________
Date: Oct 22, 2002
From: "Richard V. Reynolds" <rvreynolds(at)macs.net>
Subject: Re: Electric Primer
ACS Electric Solenoid Engine Pimer Valve P/N 05-29823 is an electric valve. You need to tee into the fuel line from the electric boost pump, usually at the engine fuel pump inlet, then to the solenoid primer valve, then to the cylinder(s). Turn the electric boost pump on, then turn the solenoid valve on and fuel flows to the cylinder(s). I used a ON-ON-(ON) switch S700-2-5) from AreoElectric Connection. Richard Reynolds Gary Liming wrote: > > The A Spruce catalog there is an electric primer that describes a solenoid > with a spring and plunger. Does this arrangement replace a traditional > type primer the same way - i.e., would the switch be operated the same as > in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, > then throw the switch again, etc.? So would it be wired as a momentary > switch? Also, the electric primer is cheaper by at least half of the > traditional ones, and you can leave the primer lines on the other side of > the firewall. Seems like a no brainer - is there any reason to use the > traditional primer? > > Gary Liming > ________________________________________________________________________________
Date: Oct 22, 2002
Try molex pn 87031-0413. See there web site at www.molex.com Ron ----- Original Message ----- From: <jerry(at)tr2.com> Subject: AeroElectric-List: ELT control wire? > > Hello, > > I'm installing an ACK E01 ELT in my Sundowner. ACK supplies a 16-foot > extension cable to connect the ELT control panel to the ELT. Given the ELT > location in the Sundowner - all the way back in the tail - this is probably > not long enough. > > The ACK manual says that you can use a cable up to 150 feet, but they > don't say anything about what kind of cable to use. I figured that using > the same as they did, would be pretty safe. Their cable says: > > E166160 > UL ( actually, it's the UL backwards-R+U symbol ) > AWM > 20251 > 26AWG > 60 degrees C > 150V > > Physically, it's a four-conductor UTP ( telephone ) wire with an ordinary > RJ11 crimpon connector at one end, and a FEMALE RJ11 crimp-on socket at the > other end. I have not been able to find one of these female crimp-on > sockets. I have found a similar cable assembly - with an identical socket - > that was 25 feet long. But it has no reassuring verbiage printed on the > cable. Well, the female end does say "Made in China" :). > > Anybody know of a source for the Right Stuff? The UL-blessed cable? The > female crimp-on connector? Or will the Wrong Stuff work just fine - > assuming that I ohm it out first, because I suspect that the pins might be > reversed.... > > - Jerry Kaidor ( jerry(at)tr2.com ) > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Date: Oct 22, 2002
What are you doing with a high wing setup and no electrical fuel pump =(;o(((, I was thinking it is a small fuel pump, now I'm stucked with a valve only =(;o((. Any good idea how to solve this easely? Werner ----- Original Message ----- From: "Richard V. Reynolds" <rvreynolds(at)macs.net> Subject: Re: AeroElectric-List: Electric Primer > > ACS Electric Solenoid Engine Pimer Valve P/N 05-29823 is an electric valve. You > need to tee into the fuel line from the electric boost pump, usually at the > engine fuel pump inlet, then to the solenoid primer valve, then to the > cylinder(s). Turn the electric boost pump on, then turn the solenoid valve on > and fuel flows to the cylinder(s). I used a ON-ON-(ON) switch S700-2-5) from > AreoElectric Connection. > > Richard Reynolds > > Gary Liming wrote: > > > > > The A Spruce catalog there is an electric primer that describes a solenoid > > with a spring and plunger. Does this arrangement replace a traditional > > type primer the same way - i.e., would the switch be operated the same as > > in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, > > then throw the switch again, etc.? So would it be wired as a momentary > > switch? Also, the electric primer is cheaper by at least half of the > > traditional ones, and you can leave the primer lines on the other side of > > the firewall. Seems like a no brainer - is there any reason to use the > > traditional primer? > > > > Gary Liming > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: Solenoid Wire Size
Date: Oct 22, 2002
Dear Bob and list members, One of the biggest variables I've noticed in the various manuals and wiring aids is the wire size called out for the starter contactor. Bob's diagrams have them sensibly small, Bingelis would have fatter wires; my own kit manufacturer recommends 12 ga. for both relays and the field circuits! My question is, what kind of current draw does one typically see to activate the starter solenoid? Many thanks, Jeffrey Steenson ABQ, NM ________________________________________________________________________________
Date: Oct 22, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: RE: System architecture
> > >Bob, > >Is there a way I can reach you to discuss this instead of typing it all >out? I've contacted SFS and Xbow again, and pretty much have been told >the same thing again. > >SFS, Robert, 208.389.9959 >Xbow, Dean, 408.965.3300 > >The xbow is DO-160 for class 23. It takes it about 1 second to boot up, >starts sending data, and takes about 60 seconds to calibrate itself to >straight and level. They suggest an avionics master, but say it >shouldn't require it. Okay! Sound's like they did their homework. >SFS is a little different. The certified version from CFS is DO-160 >Delta hardware and DO-178 Alpha software. However, the certified >version hardware is slightly different than the SFS stuff. The SFS >stuff was DO-160 tested, but nothing was really done to correct any of >the small problems found (not really sure what was found though)...this >stuff was corrected in the hardware of the CFS certified stuff. When >the unit sees below 9.5 volts, its shuts down and waits for the voltage >to come back up. It has about a 90 second boot cycle. The first 5-6 >seconds are done in MSDOS 6.22 where it checks for the cards and >whatnot. Then in another 5-6 seconds, it switches over to its >proprietary software that does CRC checks, opens files, and gets the >unit fired up. This takes another 75-80 seconds, so 90 seconds total. >If during the time it is opening a file the voltage drops and it shuts >down, it can mess things up. Also, it can loose (fry) the voice >annunciation chip. Hmmmm . . . not so good. Does this system boot from mechanical drives? >These are the reasons I saw fit for a AV master. With the master, I can >protect the SFS. By adding an AV ALT FEED along with a diode in series >with the AV MASTER, I can reduce the chance of an AV MASTER switch >ruining my day. I realize this is adding parts to fix someone elses >problem (SFS), but it seems the only logical way. How does this help you? Basically you have an accessory that cannot be in the boot-up process while you crank the engine. You can approach this from one of two ways (1) protect the battery that supplies this system from engine cranking loads or (2) don't turn it on until after the engine is started. Adding another bus with extra switches doesn't help you optimize either of these choices. Z-14 has two independent alternator/battery systems with cross-feed capability. This allows you to get 34 a.h. of cranking performance, from relatively small, inexpensive batteries. You have total independence of each system in normal operating modes and either bus has access to 4 different sources of power should something fail. The benefits of this architecture and opportunities for system reliability and weight savings with greatest attention to simplicity are inarguably solid. How would you operate the switches for the second bus to make the SFS system live comfortably in your airplane? You can . . . (1) shield the aux system from cranking loads and crank with only the main battery in which case the pampered systems can run from the aux bus and come up and down with the bus. This is the simplest approach for numbers of controls on the panel -OR- (2) you can put power switches in series with pampered systems and don't turn them on until after the engine is started. This is sort of what you have with the added bus . . . In the first case, you loose the robust cranking performance of paralleled 17 a.h. batteries and may have to upsize the main battery to offset this loss of performance. To get EQUAL performance, the main battery might have to go up to 32 a.h. and the aux battery reduced to as small as 10 a.h. You loose the simple yearly maintenance of the "musical batteries" game . . . I think the second choice is the more attractive. Don't hose up the advantages of the Z-14 capabilities for the rest of the airplane by being super-accommodating to one piece of equipment that may not belong in an airplane. Just add power control switches for the pampered systems, run them from either bus as dictated by your load analysis results and don't turn them on until after the engine is running. No extra busses or switches needed. No modifications needed to the battery sizing and maintenance. No changes to the relative robustness of an electrical system that folks flying $million$ doctor-killers can only dream about. Bob . . . ________________________________________________________________________________
Date: Oct 22, 2002
Yeah, that would help a lot. Flaps, hyd pump, etc. I'm hoping to stay with the 70A and 20A. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stan Blanton Subject: Re: AeroElectric-List: System Design, Load analysis > > I've finished a rough load analysis. > > http://shannon.v8eaters.com/images/lancair/airplane_amp_draw.xls > snip > --- > Shannon Knoepflein <---> kycshann(at)kyol.net > I like the spreadsheet you've done. I did something similar for my RV-6. I did notice that a number of loads you have such as flaps are transient and of short duration. Perhaps these should not be included when calculating the total amp draw? Stan Blanton RV-6 = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 22, 2002
> > >The A Spruce catalog there is an electric primer that describes a solenoid >with a spring and plunger. Does this arrangement replace a traditional >type primer the same way - i.e., would the switch be operated the same as >in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, >then throw the switch again, etc.? So would it be wired as a momentary >switch? Also, the electric primer is cheaper by at least half of the >traditional ones, and you can leave the primer lines on the other side of >the firewall. Seems like a no brainer - is there any reason to use the >traditional primer? > >Gary Liming Figure Z-1 and Z-11 show how to wire this with a single S700-2-50 switch. The Beech Skipper used this technique and other undoubtedly do too. It would be my choice. Bob . . . ________________________________________________________________________________
Date: Oct 22, 2002
> >Sorry to be so dense. Not a problem. >But am I to understand, that with the ammeter shunt in the "B" lead as >per the Z diagrams, that in the event of alternator failure, ie charging amps >=O, then the ammeter will show the current discharge load on the batteries? >That is what I'm looking for. Why? When the alternator quits and you go into the max endurance mode, how would you use indicated battery drain to make any kind of decision in flight? >I am fully aware of cost benefit ratios. Many of us deal on a daily >basis with life threatening risk. The key is to use preplanning to reduce >and or manage risk to as low a level as possible. Exactly! Battery loads in an alternator out situation is a pre-arranged condition that you've already mapped out in detail as part of the system design and operating procedure. I don't see how instrumenting this parameter adds anything to your in-flight comfort. The critical parameter under battery only ops is voltage. When the voltage is below 11.0 volts, you are nearly out of juice and the battery ammeter would still be showing a value within a few percent of what it was when the battery was fully charged. Bob . . . ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Re: Solenoid Wire Size
> > >Dear Bob and list members, > >One of the biggest variables I've noticed in the various manuals and >wiring aids is the wire size called out for the starter contactor. Bob's >diagrams have them sensibly small, Bingelis would have fatter wires; my >own kit manufacturer recommends 12 ga. for both relays and the field circuits! > >My question is, what kind of current draw does one typically see to >activate the starter solenoid? > >Many thanks, >Jeffrey Steenson >ABQ, NM See http://www.aeroelectric.com/articles/strtctr.pdf Some designers try to mitigate effects of starter solenoid inrush currents using fatter wires to maintain the snappy solenoid engagement with 20+ amps inrush. I prefer to use the B&C approach to always using a good quality starter contactor in series with the starter and wiring the starter's built in solenoid as shown in the Z-drawings. In this case, starter button current is about 4A. You can't do this with PM motor starters so Figure Z-22 becomes an attractive option where starter button current drops to about 100 mA. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 22, 2002
Since there are 2 SFS, one on each buss, the first solution below is not real feasible. The second is what I had in mind with the AV MASTER. I understand what you are saying. Always have. Basically, don't add parts when parts aren't needed. My shortcoming in understanding was that since I figured I had to have the switch for the SFS anyway, I might as well make it a convenience feature too, and add the other avionics behind it. Then, I thought by adding the diode in line, and the ALT AV FEED, I would have a truly backed up system, where it would be easy to shed loads, one switch failure wouldn't ruin my day, etc, etc. Since Z14 is your design, can you step me through a failure analysis of it. Ie, what you would do when an alternator failed, both alts out, a contactor failed, how you would shed load, etc, etc? Then I can fully understand your intentions, and see if I see any way to better tailor it to my needs. With my glass cockpit with redundant SFS displays, 2 gps's, 2 coms, etc, it might serve me well to be able to dump all the loads easily except those required. However, this can likely be accomplished with just careful planning of the 2 busses and what to put where, or it might serve me well to put the ESS stuff on an ESS buss fed by a diode (with ALT FEED) off the MAIN or AUX buss. I think I still need to look at what I have on what buss. I don't think I have this correct yet. I'll be sending another spreadsheet soon. Basically, I still have a lot of decisions to make :( --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: System architecture > > >Bob, > >Is there a way I can reach you to discuss this instead of typing it all >out? I've contacted SFS and Xbow again, and pretty much have been told >the same thing again. > >SFS, Robert, 208.389.9959 >Xbow, Dean, 408.965.3300 > >The xbow is DO-160 for class 23. It takes it about 1 second to boot up, >starts sending data, and takes about 60 seconds to calibrate itself to >straight and level. They suggest an avionics master, but say it >shouldn't require it. Okay! Sound's like they did their homework. >SFS is a little different. The certified version from CFS is DO-160 >Delta hardware and DO-178 Alpha software. However, the certified >version hardware is slightly different than the SFS stuff. The SFS >stuff was DO-160 tested, but nothing was really done to correct any of >the small problems found (not really sure what was found though)...this >stuff was corrected in the hardware of the CFS certified stuff. When >the unit sees below 9.5 volts, its shuts down and waits for the voltage >to come back up. It has about a 90 second boot cycle. The first 5-6 >seconds are done in MSDOS 6.22 where it checks for the cards and >whatnot. Then in another 5-6 seconds, it switches over to its >proprietary software that does CRC checks, opens files, and gets the >unit fired up. This takes another 75-80 seconds, so 90 seconds total. >If during the time it is opening a file the voltage drops and it shuts >down, it can mess things up. Also, it can loose (fry) the voice >annunciation chip. Hmmmm . . . not so good. Does this system boot from mechanical drives? >These are the reasons I saw fit for a AV master. With the master, I can >protect the SFS. By adding an AV ALT FEED along with a diode in series >with the AV MASTER, I can reduce the chance of an AV MASTER switch >ruining my day. I realize this is adding parts to fix someone elses >problem (SFS), but it seems the only logical way. How does this help you? Basically you have an accessory that cannot be in the boot-up process while you crank the engine. You can approach this from one of two ways (1) protect the battery that supplies this system from engine cranking loads or (2) don't turn it on until after the engine is started. Adding another bus with extra switches doesn't help you optimize either of these choices. Z-14 has two independent alternator/battery systems with cross-feed capability. This allows you to get 34 a.h. of cranking performance, from relatively small, inexpensive batteries. You have total independence of each system in normal operating modes and either bus has access to 4 different sources of power should something fail. The benefits of this architecture and opportunities for system reliability and weight savings with greatest attention to simplicity are inarguably solid. How would you operate the switches for the second bus to make the SFS system live comfortably in your airplane? You can . . . (1) shield the aux system from cranking loads and crank with only the main battery in which case the pampered systems can run from the aux bus and come up and down with the bus. This is the simplest approach for numbers of controls on the panel -OR- (2) you can put power switches in series with pampered systems and don't turn them on until after the engine is started. This is sort of what you have with the added bus . . . In the first case, you loose the robust cranking performance of paralleled 17 a.h. batteries and may have to upsize the main battery to offset this loss of performance. To get EQUAL performance, the main battery might have to go up to 32 a.h. and the aux battery reduced to as small as 10 a.h. You loose the simple yearly maintenance of the "musical batteries" game . . . I think the second choice is the more attractive. Don't hose up the advantages of the Z-14 capabilities for the rest of the airplane by being super-accommodating to one piece of equipment that may not belong in an airplane. Just add power control switches for the pampered systems, run them from either bus as dictated by your load analysis results and don't turn them on until after the engine is running. No extra busses or switches needed. No modifications needed to the battery sizing and maintenance. No changes to the relative robustness of an electrical system that folks flying $million$ doctor-killers can only dream about. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 22, 2002
Update at http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_3.xls I moved a couple things to the AUX BUSS (warning and panel dimmable lights). I changed the intermittent loads to 0.00. No, no wig-wag on landing and taxi lights. Both lights are attached to the gear door. The taxi lights will point out to the side more, whereas the landing light will be focused together and up a little. Added IFR Cruise column, and updated it accordingly. I highlighted the components in yellow that I'm not sure I have on the right buss. In an earlier email, I asked Bob to explain the failure mode operation of the z14, so I could better understand and might be able to better place these yellow components. Without sounding crazy, since I have to hide the SFS behind a switch to protect it during starting, I think I would still prefer to create an avionics buss with this switch and a diode, with an alt av feed from before the contactor. This will make it easy to shed load in an alt out situation...turn both batt and alt off, and flip the alt av feed. This will have just the basics on it to get me to a landing location at which point I can turn the batt contactors back on and do flaps, lock the gear for safety (it has a manual dump, so lowering it doesn't require power), etc, etc. Is this really that crazy? To me it adds convenience (all off avionics), protection of the "pampered" SFS, robustness with the alt feed sw, and simplicity during failure modes (turn on alt av feed and then turn both alts and bats off until ready to land). Am I crazy in this thinking? --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Subject: alternator sizing
Date: Oct 22, 2002
After staring at my buss structure and amp loads over lunch, I've determined that I'm probably in trouble with my proposed 70A/20A combo. Especially considering I might attempt to add some sort of de-ice capability in the future. Therefore, I am considering upgrading the 20A aux alternator I had planned to another 70A unit from Kelly Aerospace that mounts on one of the 2 vacuum pads. This will give me more than enough current for my current system, and will provide some room for future expansion. However, is adding a larger alternator like that have any drawbacks, besides the added weight? --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Mic wiring on 760 VHF
>I am wiring a Microair 760 to my experimental (Pitts S1S) and have looked at >your "shop notes" for the Mic Jack wiring. If I'm only wiring a single Mic, >am I correct in assuming the red wire is unused? yes > Also, in your diagram, the >shielding for Mic is shown to be terminated to ground at both ends (radio >connector and jack) but the Microair manual says to only connect the >shielding to ground at the radio end and leave insulated at the mic/ phones >end. I'm new to electrical wiring and don't want to make an expensive >mistake. Any help on the subject would be appreciated, My harness uses the microphone shield AS A GROUND connection for the microphone jack. The jack needs to be insulated from the airframe using non-metalic mounting bracket or washers like http://www.aeroelectric.com/Catalog/wiring/wiring.html#s890-1 you can download our instructions for the Microair 760 installation at: http://216.55.140.222/Catalog/avionics/760imB.pdf Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Starter-engaged Warning
Where would be the best place to insert a "starter-on" warning light? The goal is to let you know if you have a stuck starter or starter contactor. Is there a best spot on the starter to attach a warning light that will let you know it is engaged? Or would you just put it on the starter side of the starter contactor and assume that if the contactor is closed (and the starter button is not pressed), you have a problem. - Jim ________________________________________________________________________________
Date: Oct 22, 2002
A Facet electric fuel pump would solve your problem. AS sells them and you can find them locally at auto parts stores for a few dollars less. R ----- Original Message ----- From: "Werner Schneider" <WernerSchneider(at)compuserve.com> Subject: Re: AeroElectric-List: Electric Primer > > What are you doing with a high wing setup and no electrical fuel pump > =(;o(((, I was thinking it is a small fuel pump, now I'm stucked with a > valve only =(;o((. > > Any good idea how to solve this easely? > > Werner > > ----- Original Message ----- > From: "Richard V. Reynolds" <rvreynolds(at)macs.net> > To: > Subject: Re: AeroElectric-List: Electric Primer > > > > > > > ACS Electric Solenoid Engine Pimer Valve P/N 05-29823 is an electric > valve. You > > need to tee into the fuel line from the electric boost pump, usually at > the > > engine fuel pump inlet, then to the solenoid primer valve, then to the > > cylinder(s). Turn the electric boost pump on, then turn the solenoid valve > on > > and fuel flows to the cylinder(s). I used a ON-ON-(ON) switch S700-2-5) > from > > AreoElectric Connection. > > > > Richard Reynolds > > > > Gary Liming wrote: > > > > > > > > The A Spruce catalog there is an electric primer that describes a > solenoid > > > with a spring and plunger. Does this arrangement replace a traditional > > > type primer the same way - i.e., would the switch be operated the same > as > > > in throw the switch for 2-3 seconds, and one "squirt" is delivered, let > go, > > > then throw the switch again, etc.? So would it be wired as a momentary > > > switch? Also, the electric primer is cheaper by at least half of the > > > traditional ones, and you can leave the primer lines on the other side > of > > > the firewall. Seems like a no brainer - is there any reason to use the > > > traditional primer? > > > > > > Gary Liming > > > > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Re: Starter-engaged Warning
I hooked mine to the "I" terminal on the starter contactor. From what I understand it's energized when the contactor is online. The key is that as long as the starter contactor is off, then the starter is dead. That's why it's there after all... - Andy Karmy RV9A - Wiring ---------- Original Message ---------------------------------- From: "Jim Pack" <jpack(at)igs3.com> Date: Tue, 22 Oct 2002 16:11:08 -0600 > >Where would be the best place to insert a "starter-on" warning light? The >goal is to let you know if you have a stuck starter or starter contactor. >Is there a best spot on the starter to attach a warning light that will let >you know it is engaged? Or would you just put it on the starter side of the >starter contactor and assume that if the contactor is closed (and the >starter button is not pressed), you have a problem. > >- Jim > > ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Re: Mic wiring on 760 VHF
And the harness works with the jacks insulated. I ordered one from Bob some time ago and had no problems installing the 760. R > My harness uses the microphone shield AS A GROUND > connection for the microphone jack. The jack needs > to be insulated from the airframe using non-metalic > mounting bracket or washers like > > http://www.aeroelectric.com/Catalog/wiring/wiring.html#s890-1 > > you can download our instructions for the Microair 760 > installation at: > > http://216.55.140.222/Catalog/avionics/760imB.pdf > > > Bob . . . > > |-------------------------------------------------------| > | The man who does not read good books has no advantage | > | over the man who cannot read them. | > | - Mark Twain | > |-------------------------------------------------------| > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 22, 2002
> Where would be the best place to insert a "starter-on" > warning light? Is it really necessary? Sometimes during hot starts, I leave the starter engaged after the engine begins firing, and it is quite easy to hear the starter gear whining even at a few hundred engine rpm. My starter is a Lamar, maybe others can't be heard. The old carburetted cars often needed to be cranked a little past where they started firing, and I recall the same sound with them. Alex Peterson Maple Grove, MN RV6-A N66AP 215 hours ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Location of the battery contactor and bus
A few weeks ago there was an exchange about the location of the battery bus for rear-mounted batteries (as in my Lancair Super ES). Bob Nuckolls wrote: Battery contactors are next to batteries and battery busses are next to batteries. Question: Why do the battery contactor and battery bus need to go next to the battery? What specifically would be wrong with putting the battery in back and the battery contactor and bus up front, as if the battery were up front? Confession: I am an "acres of breakers" person, though outside of that I am closely following Z-14, possibly with one large and one small battery and smaller relays for the crossfeed and #2 contactor. I had originally planned to put the breakers for the battery bus near the other breakers up front. I am wondering why I should put them in back. I'm watching the ongoing Lancair threads closely, and really apprciate all the help. Thanks. Dan O'Brien Lancair Super ES ________________________________________________________________________________
Date: Oct 22, 2002
> >Where would be the best place to insert a "starter-on" warning light? The >goal is to let you know if you have a stuck starter or starter contactor. >Is there a best spot on the starter to attach a warning light that will let >you know it is engaged? Or would you just put it on the starter side of the >starter contactor and assume that if the contactor is closed (and the >starter button is not pressed), you have a problem. Most automotive starter contactors pressed into aviation duty have an "I" terminal that was used to augment ignition coil current in the early days of 12v cars. This same terminal can be used to drive an indicator light on the panel. You would want to use an in-line fuse or fusible link at the contactor. If your contactor doesn't have this feature, you can simply drive the light from the donwstream side of the starter contactor either at the starter or contactor. Bob . . . ________________________________________________________________________________
Date: Oct 22, 2002
Jim, I have a low voltage light wired to the start solenoid. As long as there is power to the starter solenoid the light is lit. When the voltage is removed from the starter solenoid, the light goes out. Ed Anderson Rv-6A N494BW Rotary Powered eanderson(at)carolina.rr.com ----- Original Message ----- From: "Jim Pack" <jpack(at)igs3.com> Subject: AeroElectric-List: Starter-engaged Warning > > Where would be the best place to insert a "starter-on" warning light? The > goal is to let you know if you have a stuck starter or starter contactor. > Is there a best spot on the starter to attach a warning light that will let > you know it is engaged? Or would you just put it on the starter side of the > starter contactor and assume that if the contactor is closed (and the > starter button is not pressed), you have a problem. > > - Jim > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Electric Solenoid Engine Primer Valve
AeroElectric-List message previously posted by: Gary Liming "The A Spruce catalog there is an electric primer that describes a solenoid with a spring and plunger. Does this arrangement replace a traditional type primer the same way - i.e., would the switch be operated the same as in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, then throw the switch again, etc.? So would it be wired as a momentary switch? Also, the electric primer is cheaper by at least half of the traditional ones, and you can leave the primer lines on the other side of the firewall. Seems like a no brainer - is there any reason to use the traditional primer? Gary Liming" 10/22/2002 Hello Gary, If you read all the words carefully you will see that this device (P/N 05-29823) is an electrically controlled primer valve, not a primer. The normal mechanical primer is a cylindrical pump by which you manually force some fuel into some or all of the cylinder induction areas of the engine. If the aircraft has an electrically driven fuel pump it is possible to plumb it so that the electrically driven fuel pump can supply fuel to the cylinder induction areas. Some means is needed to control when fuel should be permitted to flow to the cylinder induction areas other than just turning the electrically driven fuel pump ON or OFF. The electric solenoid engine primer valve serves this function. If the aircraft doesn't have some source for providing fuel pressure prior to engine start this ON or OFF valve is unable to prime the engine by itself. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: Oct 22, 2002
Subject: Re: Location of the battery bus
> >A few weeks ago there was an exchange about the location of the battery bus >for rear-mounted batteries (as in my Lancair Super ES). Bob Nuckolls wrote: > > Battery contactors are next to batteries and battery busses are > next to >batteries. > >Question: Why do the battery contactor and battery bus need to go next to >the battery? What specifically would be wrong with putting the battery in >back and the battery contactor and bus up front, as if the battery were up >front? Battery busses are always hot. This means you minimize the length of the feeder between the battery (unprotected) to the bus where protected feeders branch off. If you want to mount the bus remotely, then you need to put a relay or contactor in series with the extended feeder and then it's no longer a "battery bus" >Confession: I am an "acres of breakers" person, though outside of that I >am closely following Z-14, possibly with one large and one small battery >and smaller relays for the crossfeed and #2 contactor. I had originally >planned to put the breakers for the battery bus near the other breakers up >front. I am wondering why I should put them in back. The general rule of thumb for crash safety is to have no always hot wires protected at more than 5A . . . and it's REALLY nice if that protection is a 5A or smaller fuse - MUCH faster than a breaker. If the feeder between battery (+) and the battery bus is kept short, this minimizes the length of always-hot, unprotected wire. This can usually be on the order of a few inches when the battery bus is a fuse block adjacent to the battery contactor. If you extend the feeder, then it has much higher fault currents than the recommended design maximum and this calls for addition of another master-switch like control to allow killing that feeder in times of distress. If it were my project and breakers on the panel were still the order of the day for a main and aux bus, the battery busses would still be in the back and fabricated with fuseblocks. >I'm watching the ongoing Lancair threads closely, and really apprciate all >the help. Thanks. >Dan O'Brien >Lancair Super ES Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 22, 2002
I looked at my contactor (purchased from B&C) & it has the "I" terminal along with an "S" terminal. I assume the correct wiring would be to have the "S" terminal hooked to the starter button & power and the "I" terminal to ground with another line from the "I" terminal to the indictor light. The two larger terminals are the starter power contacts that should be fed with 2AWG lines. That all sound correct? Thanks! - Jim ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Starter-engaged Warning > > > > >Where would be the best place to insert a "starter-on" warning light? The > >goal is to let you know if you have a stuck starter or starter contactor. > >Is there a best spot on the starter to attach a warning light that will let > >you know it is engaged? Or would you just put it on the starter side of the > >starter contactor and assume that if the contactor is closed (and the > >starter button is not pressed), you have a problem. > > Most automotive starter contactors pressed into aviation > duty have an "I" terminal that was used to augment > ignition coil current in the early days of 12v cars. > This same terminal can be used to drive an indicator > light on the panel. You would want to use an in-line > fuse or fusible link at the contactor. > > If your contactor doesn't have this feature, you > can simply drive the light from the donwstream side > of the starter contactor either at the starter or > contactor. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - ALTERNATOR OPERATION
Date: Oct 23, 2002
Bob, What is the preferred way of operating Z12 with two uneven sized alternators - both together, which involves really closely matching the voltage regulators, or is it more realistic to just run one at a time, the big one, with the baby on standby? David Francis, VH-ZEE, RV7, Australia Email: David.Francis(at)defence.gov.au ________________________________________________________________________________
Date: Oct 23, 2002
In a message dated 10/22/02 8:35:11 PM Pacific Daylight Time, jpack(at)igs3.com writes: << I assume the correct wiring would be to have the "S" terminal hooked to the starter button & power and the "I" terminal to ground with another line from the "I" terminal to the indictor light. >> I can't speak for the B&C starter contactor but on my start contactor from Van's connecting the "I" terminal to ground would short the battery to ground (briefly, and with considerable smoke) when you engage the start contactor. I believe the correct approach is to run the "I" terminal to the indicator light with a return from the light to ground. On my contactor, the "I" terminal connects to the battery terminals when the contactor is engaged. If I'm wrong I hope somebody straightens me out before I put power on this thing. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Oct 23, 2002
Subject: LED Wiring
Bob, In your LED wiring diagram, you have a 220 ohm resister in both parallel & series with the LED. The 12 volt LED's purchased from RS have only a 220 ohm resister in series with the LED. Why the difference? Do I need to put a resister in parallel with the Radio Shack 12V LED before I use it as a low volts warning light? - Jim ________________________________________________________________________________
Subject: Re: > Re: Electric Primer
Date: Oct 23, 2002
Just a little note: If your throttle linkage is through the firewall and mechanical, and the choke and prop control and maybe a couple other linkages, too; it seems a small thing to use a mechanical primer on the engine side of the firewall so you can hand-prop the bird if you REALLY need to. Eric "An acre of performance is worth the whole world of promise." James Howell ________________________________________________________________________________
Date: Oct 23, 2002
From: "William Yamokoski" <yamokosk(at)lmc.cc.mi.us>
Subject: Electric Gyro question
Hi Folks, Noted something that struck me as unusual. I have Bob's basic 2 battery, one alternator architecture, with main bus and essential bus connected by the four-post diode and by a separate switch for e-bus only operations. When I put the main master switch or aux master switch (or both) on, the electric artificial horizon begins spinning but the "off" flag stays put. When I just turn on the E-Bus Alternate Feed switch, the gyro starts spinning and the "off" flag disappears. What does it take to make that flag disappear? All other devices connected to the essential bus appear to operate normally no matter what switch configuration I use. Is that flag trying to tell me something? Thanks for any ideas on this. Bill Yamokoski, First Flight a week ago, still working on radio noise ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Electric Gyro question
Hi Folks, Forgot to clarify in my first posting that the Art. Horizon is connected to the essential bus. thanks again. Bill Yamokoski ________________________________________________________________________________
Date: Oct 23, 2002
> > >Hi Folks, > Noted something that struck me as unusual. I have Bob's basic 2 > battery, one alternator architecture, with main bus and essential bus > connected by the four-post diode and by a separate switch for e-bus only > operations. When I put the main master switch or aux master switch (or > both) on, the electric artificial horizon begins spinning but the "off" > flag stays put. When I just turn on the E-Bus Alternate Feed switch, > the gyro starts spinning and the "off" flag disappears. What does it > take to make that flag disappear? All other devices connected to the > essential bus appear to operate normally no matter what switch > configuration I use. Is that flag trying to tell me something? Thanks > for any ideas on this. Is your engine running during this test or are you operating battery only? The flag is calibrated to drop at some level of supply voltage below a normal bus voltage. The diode voltage drop in the e-bus normal feed path subtracted from a battery-only voltage level may indeed be too low to raise the flag. If your engine is running and the main bus is above 13.8, then I suspect the flag will raise. The fact that you can close the e-bus alternate feed switch and raise the flag re-enforces this hypothesis. Do you have a voltmeter in the airplane? While the flag is down, what is the voltage reading? Is your voltmeter reading the main bus or the e-bus? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: LED Wiring
> >Bob, > >In your LED wiring diagram, you have a 220 ohm resister in both parallel & >series with the LED. > >The 12 volt LED's purchased from RS have only a 220 ohm resister in series >with the LED. > >Why the difference? Do I need to put a resister in parallel with the Radio >Shack 12V LED before I use it as a low volts warning light? We need to make the LED emulate an incandescent lamp which will NOT illuminate at the very current levels that flow in this annunicator circuit in the OFF state. Without the parallel resistor, the LED glows dimly even when the bus voltage is normal. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 23, 2002
I assume this is with engine off? (ie, no alternator) If so, what you are experiencing is the voltage drop across the diode here, which is sending the flag out. There is a small voltage drop across the diode, and the flag is telling you about a low voltage condition. When you switch on the ESS feed switch, you bypass the diode (and any other voltage drops in the system) and get enough voltage. Start the engine, and the flag will disappear (as long as your charging system is working). --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Yamokoski Subject: AeroElectric-List: Electric Gyro question Hi Folks, Noted something that struck me as unusual. I have Bob's basic 2 battery, one alternator architecture, with main bus and essential bus connected by the four-post diode and by a separate switch for e-bus only operations. When I put the main master switch or aux master switch (or both) on, the electric artificial horizon begins spinning but the "off" flag stays put. When I just turn on the E-Bus Alternate Feed switch, the gyro starts spinning and the "off" flag disappears. What does it take to make that flag disappear? All other devices connected to the essential bus appear to operate normally no matter what switch configuration I use. Is that flag trying to tell me something? Thanks for any ideas on this. Bill Yamokoski, First Flight a week ago, still working on radio noise = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 23, 2002
From: Phil Hildebrand <phildebrand(at)pritchardindustrial.com>
Is the attitude indicator an RC Allan. When I first installed a RC Allan electric attitude indicator in my Mooney as a standby, the low voltage flag would stay on until the engine was running. I contacted RC Allan and they said that the flag setting was too high and that it could be adjusted. It would appear that the units are shipped from the factory with the settings so close to 12 volts that a battery without an alternator would not be enough for the flag to drop. I sent the unit back to the factory and asked them to adjust it to the lowest voltage possible as the unit was for standby and I wanted it to work in the worst case scenario (seized engine, no alternator output). When I got it back I never had any problems. By adding the second bus maybe your voltage increases enough to drop the flag. Have you done an accurate voltage check on both buses? On another note I am wondering what Attitude indicator you actually have as I am looking for an alternative to the RC Allan for my Lancair ES. The Goodrich model is twice the price but based on what I have heard it my be a good buy on the long run? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of William Yamokoski Subject: AeroElectric-List: Electric Gyro question Hi Folks, Noted something that struck me as unusual. I have Bob's basic 2 battery, one alternator architecture, with main bus and essential bus connected by the four-post diode and by a separate switch for e-bus only operations. When I put the main master switch or aux master switch (or both) on, the electric artificial horizon begins spinning but the "off" flag stays put. When I just turn on the E-Bus Alternate Feed switch, the gyro starts spinning and the "off" flag disappears. What does it take to make that flag disappear? All other devices connected to the essential bus appear to operate normally no matter what switch configuration I use. Is that flag trying to tell me something? Thanks for any ideas on this. Bill Yamokoski, First Flight a week ago, still working on radio noise = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 23, 2002
><< I assume the correct wiring would be to have the "S" terminal hooked to the > starter button & power and the "I" terminal to ground with another line from > the "I" terminal to the indictor light. >> > >I can't speak for the B&C starter contactor but on my start contactor from >Van's connecting the "I" terminal to ground would short the battery to ground >(briefly, and with considerable smoke) when you engage the start contactor. >I believe the correct approach is to run the "I" terminal to the indicator >light with a return from the light to ground. On my contactor, the "I" >terminal connects to the battery terminals when the contactor is engaged. If >I'm wrong I hope somebody straightens me out before I put power on this thing. Where did anyone see a wiring diagram that suggests this "I" terminal be connected to anything? The "I" terminal becomes common to both FAT terminals on the contactor when the contactor closes. Connecting this terminal to ground would produce predictable, unpleasant results. I note that only a few of the Z-drawings call out a "case ground" for the lower end of the contactor coil . . . but note that only three connections to on the symbol suggest a terminal-post/nut connection. The lower end comes out the bottom of the symbol to a "firewall ground" . . . Wiring details called out in the catalog listing for this style contactor can be viewed at: http://www.aeroelectric.com/Catalog/switch/S702Wire.jpg I'll do some work on the Z-drawings to amplify these facts. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Z-12 ALTERNATOR OPERATION
> > >Bob, >What is the preferred way of operating Z12 with two uneven sized alternators >- both together, which involves really closely matching the voltage >regulators, or is it more realistic to just run one at a time, the big one, >with the baby on standby? The small alternator is intended for use only when the main alternator is unavailable. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 23, 2002
Bob, In setting up my contactors according to a slight modification of your Z-11, I have put both contactors (main and starter), on the engine side of the firewall. This seemed attractive until I read your comments about battery and battery bus leads. I realized that I have the hot lead (unprotected) from the battery going through the firewall (using a grommet and typical SS firewall shield) to the main contactor. In hindsight, it would have been better to place the main contactor on the inside of the firewall. Of course, I can take it all apart and move the battery contactor to the aft side of the firewall. However, I am wondering is there is another (reasonable) way to recover from this mistake. My question is: is there a reasonable way to add protection for the lead from the battery to the contactor? It would have to tolerate starter current but open under a dead short of the lead to ground. The battery lead will be relatively short since this is an RV-6A and the battery is behind the center of firewall. Richard Dudley RV-6A, firewall forward Robert L. Nuckolls, III wrote: > > > > > >A few weeks ago there was an exchange about the location of the battery bus > >for rear-mounted batteries (as in my Lancair Super ES). Bob Nuckolls wrote: > > > > Battery contactors are next to batteries and battery busses are > > next to > >batteries. > > > >Question: Why do the battery contactor and battery bus need to go next to > >the battery? What specifically would be wrong with putting the battery in > >back and the battery contactor and bus up front, as if the battery were up > >front? > > Battery busses are always hot. This means you minimize the > length of the feeder between the battery (unprotected) to > the bus where protected feeders branch off. If you > want to mount the bus remotely, then you need to put a relay > or contactor in series with the extended feeder and then > it's no longer a "battery bus" > > >Confession: I am an "acres of breakers" person, though outside of that I > >am closely following Z-14, possibly with one large and one small battery > >and smaller relays for the crossfeed and #2 contactor. I had originally > >planned to put the breakers for the battery bus near the other breakers up > >front. I am wondering why I should put them in back. > > The general rule of thumb for crash safety is to have > no always hot wires protected at more than 5A . . . and > it's REALLY nice if that protection is a 5A or smaller > fuse - MUCH faster than a breaker. If the feeder between > battery (+) and the battery bus is kept short, this minimizes > the length of always-hot, unprotected wire. This can usually > be on the order of a few inches when the battery bus is a fuse > block adjacent to the battery contactor. > > If you extend the feeder, then it has much higher fault > currents than the recommended design maximum and this > calls for addition of another master-switch like control > to allow killing that feeder in times of distress. > > If it were my project and breakers on the panel were still > the order of the day for a main and aux bus, the battery > busses would still be in the back and fabricated with > fuseblocks. > > >I'm watching the ongoing Lancair threads closely, and really apprciate all > >the help. Thanks. > >Dan O'Brien > >Lancair Super ES > > Bob . . . > > |-------------------------------------------------------| > | The man who does not read good books has no advantage | > | over the man who cannot read them. | > | - Mark Twain | > |-------------------------------------------------------| > ________________________________________________________________________________
Date: Oct 23, 2002
Date: Oct 23, 2002
Ed, You're one of the few that are actually flying. So, can you hear your starter with the engine running? Or does your headset/exhaust drown out all other sounds? If you can hear the starter whirring away do you really need a warning light to tell you that? Mark Quoting Ed Anderson : > > > Jim, > I have a low voltage light wired to the start solenoid. As long as > there is power to the starter solenoid the light is lit. When the > voltage > is removed from the starter solenoid, the light goes out. > > Ed Anderson > Rv-6A N494BW Rotary Powered > eanderson(at)carolina.rr.com > > ----- Original Message ----- > From: "Jim Pack" <jpack(at)igs3.com> > To: > Subject: AeroElectric-List: Starter-engaged Warning > > > > > > Where would be the best place to insert a "starter-on" warning light? > The > > goal is to let you know if you have a stuck starter or starter > contactor. > > Is there a best spot on the starter to attach a warning light that > will > let > > you know it is engaged? Or would you just put it on the starter side > of > the > > starter contactor and assume that if the contactor is closed (and the > > starter button is not pressed), you have a problem. > > > > - Jim > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Dual Comm Audio Wiring
>Below is the result of your inquiry. It was submitted by >David Domeier (davidd010(at)earthlink.net) on Tuesday, October 22, 2002 at >14:10:28 > >Tuesday, October 22, 2002 > >How can I wire my airplane to use 2 comm radios without >going to the expense of an audio panel? > >David Domeier Sure, see this drawing. http://216.55.140.222/temp/DualCommAudio.pdf I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . | Stupidity cannot be cured with money, or through education, | | or by legislation. Stupidity is not a sin, the victim can't | | help being stupid. But stupidity is the only universal | | capital crime; the sentence is death, there is no appeal, | | and execution is carried out automatically and without pity. | | -Lazarus Long- | ________________________________________________________________________________
Date: Oct 23, 2002
> >Bob, > >In setting up my contactors according to a slight modification of your >Z-11, I have put both contactors (main and starter), on the engine side >of the firewall. This seemed attractive until I read your comments about >battery and battery bus leads. > >I realized that I have the hot lead (unprotected) from the battery going >through the firewall (using a grommet and typical SS firewall shield) to >the main contactor. In hindsight, it would have been better to place the >main contactor on the inside of the firewall. > >Of course, I can take it all apart and move the battery contactor to the >aft side of the firewall. However, I am wondering is there is another >(reasonable) way to recover from this mistake. > >My question is: is there a reasonable way to add protection for the lead >from the battery to the contactor? It would have to tolerate starter >current but open under a dead short of the lead to ground. > >The battery lead will be relatively short since this is an RV-6A and the >battery is behind the center of firewall. This installation was recommended by Vans for years and may still be. The risks are small but certainly not zero. You'd never get this "certified" but then, if you don't fly your airplane into a big pile of rocks, it's not much of an issue. Do good periodic inspection on this penetration to make sure that isolation of the hot wire is not being degraded with age and service and you'll probably be okay. If you ever sell the airplane, make sure the new owner is aware of the recommendation for extra inspection. This is very much out of the ordinary for light aircraft. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Hi Folks, Thanks for the replies. Looks like the diode gets the nod here :) I have a voltage readout in the Grand Rapids engine monitor. That instrument isn't fed by my essential bus so I can't really compare voltages from the main vs. essential busses. If the flag shows up while the engine is on, then I'll worry. My education in electrons continues....... Bill Yamokoski ________________________________________________________________________________
Date: Oct 23, 2002
> >Ed, >You're one of the few that are actually flying. So, can you hear your >starter >with the engine running? Or does your headset/exhaust drown out all other >sounds? If you can hear the starter whirring away do you really need a >warning >light to tell you that? >Mark A bit of history might help here. In the certified world, there are many instances of stuck starter contactors wherein the pilot was unaware of the event and damage was done. MOST of these events were on lower priced single engine aircraft using contactors not well suited for starter control service . . . we won't go into naming names here. Of course, conventional wisdom in the certified world was not to make it easy to improve on the suitability of the contactor by (ughhh!) putting an AUTOMOTIVE device on in place of the junk . . . "I know, let's put a light on the panel to tell the pilot when the contactor sticks! It's easier to add a Band-Aid to a certified ship than it is to fix a problem. In our airplanes, we're using very robust starter contactors so the likelihood of this happening is at least an order of magnitude lower . . . but again, it is not zero. This begs the question, "Will we hear the results of this event and shut things down in time to prevent severe damage?" It also begs the question, "Will we always keep an eye on the light to make sure it goes out when the starter button is released?" We can debate the merits of adding this feature for days but it won't change the facts . . . the chances of a stuck contactor are not zero, the chances of being distracted and being unaware of the event are not zero, and the chances of a warning light going unnoticed are not zero either. Bottom line is that the vast majority of light singles do not have this light and in the grand scheme of things, the certified stuff wears out or breaks far more often than they are destroyed by stuck contactors. It's a real toss up. I probably wouldn't put one on my airplane unless it was included in an annunciator array that shows lots of other good things to know and is certain to be observed more often than some lowly light tucked away somewhere on the panel like the certified ships. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: shielded pair
> >Looking for two pin shielded wire...like the three pin shielded wire >(S906-3-22). I've bought a bunch of the three pin and my wiring for my >radios calls for two pin shielded. I would hate to use three pin with an >unused circuit - just like two single pin shielded...an extra shield. > >Thanks, >Ralph Capen Don't have any in our inventory. It's available from most electronic supply houses but not in tefzel. You'd have to order probably a minimum of 100' to get it in the right stuff from anywhere. It's not a big deal to cut off an unused wire and ignore it. You might check with a local avionics shop and see if they would sell you short pieces. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 23, 2002
Thanks, Bob. I am concluding that it is worth the time and effort to re-work the layout and put the battery contactor inside. Not that I plan to fly into a pile of rocks but with the contactor inside there is less question as well as need to explain. Regards, Richard Dudley Robert L. Nuckolls, III wrote: > > > > > >Bob, > > > >In setting up my contactors according to a slight modification of your > >Z-11, I have put both contactors (main and starter), on the engine side > >of the firewall. This seemed attractive until I read your comments about > >battery and battery bus leads. > > > >I realized that I have the hot lead (unprotected) from the battery going > >through the firewall (using a grommet and typical SS firewall shield) to > >the main contactor. In hindsight, it would have been better to place the > >main contactor on the inside of the firewall. > > > >Of course, I can take it all apart and move the battery contactor to the > >aft side of the firewall. However, I am wondering is there is another > >(reasonable) way to recover from this mistake. > > > >My question is: is there a reasonable way to add protection for the lead > >from the battery to the contactor? It would have to tolerate starter > >current but open under a dead short of the lead to ground. > > > >The battery lead will be relatively short since this is an RV-6A and the > >battery is behind the center of firewall. > > This installation was recommended by Vans for years and may > still be. The risks are small but certainly not zero. You'd > never get this "certified" but then, if you don't fly your > airplane into a big pile of rocks, it's not much of an issue. > Do good periodic inspection on this penetration to make sure > that isolation of the hot wire is not being degraded with age > and service and you'll probably be okay. > > If you ever sell the airplane, make sure the new owner is > aware of the recommendation for extra inspection. This > is very much out of the ordinary for light aircraft. > > Bob . . . > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: LED Dimmer Switch
Bob, I am trying to hook up an LED warning panel for main & aux alternator failure, x-feed on, starter on & low oil pressure warn. I have tried hooking up an LED warning panel using LEDs with parallel & series 220 ohm resters instead of lamps. I used the Zener Diode 1N4745A as the dimmer, but get no ruduction in the LED brightness. Any suggestions on where I am going wrong? - Jim ________________________________________________________________________________
Subject: Loadmeter reappears with alt field voltage
Date: Oct 23, 2002
Bob, and others, Bob has mentioned in a prior post that the transient suppression of the formerly available loadmeter circuit board is not needed. That means that the dual ammeter/voltmeter needs only connection to the shunt(s) used to measure current output from the alternator(s). Westach is now making these meters available, in the 'what's new' section of their site. Bob mentioned that the 13 to 15 volt range was inexplicably done in red in the picture on their web site! I ordered one, and had them change the 13 to 15 volt range to green. There is a six week wait, as they sold out of the first batch. Bob has mentioned how valuable is it to have field voltage available for troubleshooting. One of the problems with the original loadmeter, which is just an ammeter scaled for your particular alternator in %, was that measuring the field voltage from the alternator gave an miscalibrated voltage reading on the voltmeter scale which read roughly 10 to 17 volts. Back home on the ground you could look up the true voltage from a table. With the circuitry of Bob's loadmeter no longer available, this is not an option anyway. However, if you are willing to use the ammeter scale, which reads 0 to 100%, and is linear--no expanded scale issues--you can press this into service by using a spring-loaded double pole switch to shift the loadmeter from the shunt(s) to read the field voltage. When you want to check field voltage, just push the spring-loaded switch and read it from the loadmeter. The appropriate series resistor is easy to calculate. Say you want a 0 to 20 volt scale, so that each 5% marking on the leadmeter was 1 volt. The loadmeter is a 1 ma movement with a 50 millivolt voltage drop at full scale: calculates to 50 ohms. The series resistor would be 20 volts divided by 1 ma, or 20,000 ohms. We can ignore the internal resistance of the meter here. Here is what I'm doing for my two alternators, one of which has a field and the other a permanent magnet. The S200-2-50 switch is on-on-(on). The first position reads current output of alternator 1, the second is alternator 2, and the spring-loaded third position reads voltage from the field circuit on the loadmeter side. If you have one alternator, then a on-(on) DPDT switch would shift the loadmeter from the current reading shunt to the voltage reading resistor from the field circuit. Bob, it might help to put a simple diagram on the 'Connection, so that people who wish to use this feature can do so. I've got the diagram in my head, but I'm afraid the verbal description was opaque. Jim Foerster ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: LED Dimmer Switch
> >Bob, > >I am trying to hook up an LED warning panel for main & aux alternator >failure, x-feed on, starter on & low oil pressure warn. > >I have tried hooking up an LED warning panel using LEDs with parallel & >series 220 ohm resters instead of lamps. I used the Zener Diode 1N4745A as >the dimmer, but get no ruduction in the LED brightness. > >Any suggestions on where I am going wrong? You probably have the zener backwards. It sounds like you've got it wired such that the zener is FORWARD biased wherein the voltage drop is about the same as an ordinary diode . . . 0.7 volts. Reversing the zener causes the voltage drop to increase to the value of the zener's rating. In the case of a 1N4745, the rating is 16 volts. This will drop ALL of your applied voltage and the LED will be dark. Try zeners over the range of 1N4735 (6.2v) to 1N4739 (9.1 volts) to find the one that provides the desired dimming characteristic. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
> >Thanks, Bob. >I am concluding that it is worth the time and effort to re-work the >layout and put the battery contactor inside. Not that I plan to fly into >a pile of rocks but with the contactor inside there is less question as >well as need to explain. Can't argue with that logic . . . Bob . . . ________________________________________________________________________________
Subject: Bob's words of wisdom
Date: Oct 23, 2002
> Bob . . . > > | Stupidity cannot be cured with money, or through education, | > | or by legislation. Stupidity is not a sin, the victim can't | > | help being stupid. But stupidity is the only universal | > | capital crime; the sentence is death, there is no appeal, | > | and execution is carried out automatically and without pity. | > | -Lazarus Long- | > > Hi Bob; I always enjoy reading your memorable quotes on your signature and look forward to next one. I must say though, that this is one the better ones. Thanks and keep 'em coming. ;-) S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm Bob's words of wisdom Bob . . . | Stupidity cannot be cured with money, or through education, | | or by legislation. Stupidity is not a sin, the victim can't | | help being stupid. But stupidity is the only universal | | capital crime; the sentence is death, there is no appeal, | | and execution is carried out automatically and without pity. | | -Lazarus Long- | Hi Bob; I always enjoy reading your memorable quotes on your signature and look forward to next one. I must say though, that this is one the better ones. Thanks and keep 'em coming. ;-) S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm ________________________________________________________________________________
Date: Oct 23, 2002
From: Jaye and Scott Jackson <jayeandscott(at)shaw.ca>
Subject: Re: Bob's words of wisdom
This one caught my eye,too. I wonder if some will think Bob thinks their question is stupid? Or would one have to be stupid to think that? Hmm.. Scott in Vancouver ----- Original Message ----- From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> Subject: AeroElectric-List: Bob's words of wisdom > > > Bob . . . > > > > | Stupidity cannot be cured with money, or through education, | > > | or by legislation. Stupidity is not a sin, the victim can't | > > | help being stupid. But stupidity is the only universal | > > | capital crime; the sentence is death, there is no appeal, | > > | and execution is carried out automatically and without pity. | > > | -Lazarus Long- | > > > > > Hi Bob; > I always enjoy reading your memorable quotes on your signature and > look forward to next one. I must say though, that this is one the better > ones. > Thanks and keep 'em coming. ;-) > > S. Todd Bartrim > Turbo 13B rotary powered > RX-9endurance (FWF) > C-FSTB (reserved) >
http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > Bob's words of wisdom > > > Bob . . . > > > | Stupidity cannot be cured with money, or through education, | > > | or by legislation. Stupidity is not a sin, the victim can't | > > | help being stupid. But stupidity is the only universal | > > | capital crime; the sentence is death, there is no appeal, | > > | and execution is carried out automatically and without pity. | > > | -Lazarus Long- | > > > Hi Bob; > > I always enjoy reading your memorable quotes on your signature and look forward to next one. I must say though, that this is one the better ones. > > > Thanks and keep 'em coming. ;-) > > > S. Todd Bartrim > > Turbo 13B rotary powered > > RX-9endurance (FWF) > > C-FSTB (reserved) > > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Odyssey Battery Question
Anyone know why the Odyssey Battery(#680) has a metal case. Doesn't seem to be removable. Could it be used as a battery box? Thanks. Byron ________________________________________________________________________________
Date: Oct 23, 2002
Bob, Tell them where it comes from. These young guys may not know about the late Robert Heinlein and his great stories and words of wisdom. Terry Watson "There ain't no such thing as a free lunch", (from The Moon is a Harsh Mistress by Robert A Heinlein.) This one caught my eye,too. I wonder if some will think Bob thinks their question is stupid? Or would one have to be stupid to think that? Hmm.. Scott in Vancouver ----- Original Message ----- From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> Subject: AeroElectric-List: Bob's words of wisdom > > > Bob . . . > > > > | Stupidity cannot be cured with money, or through education, | > > | or by legislation. Stupidity is not a sin, the victim can't | > > | help being stupid. But stupidity is the only universal | > > | capital crime; the sentence is death, there is no appeal, | > > | and execution is carried out automatically and without pity. | > > | -Lazarus Long- | > > > > > Hi Bob; > I always enjoy reading your memorable quotes on your signature and > look forward to next one. I must say though, that this is one the better > ones. > Thanks and keep 'em coming. ;-) > > S. Todd Bartrim > Turbo 13B rotary powered > RX-9endurance (FWF) > C-FSTB (reserved) > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > Bob's words of wisdom > > > Bob . . . > > > | Stupidity cannot be cured with money, or through education, | > > | or by legislation. Stupidity is not a sin, the victim can't | > > | help being stupid. But stupidity is the only universal | > > | capital crime; the sentence is death, there is no appeal, | > > | and execution is carried out automatically and without pity. | > > | -Lazarus Long- | > > > Hi Bob; > > I always enjoy reading your memorable quotes on your signature and look forward to next one. I must say though, that this is one the better ones. > > > Thanks and keep 'em coming. ;-) > > > S. Todd Bartrim ________________________________________________________________________________
Date: Oct 23, 2002
Terry Watson wrote: > > > Bob, > > Tell them where it comes from. These young guys may not know about the late > Robert Heinlein and his great stories and words of wisdom. > > Terry Watson > > "There ain't no such thing as a free lunch", (from The Moon is a Harsh > Mistress by Robert A Heinlein.) > *** IMHO Heinlein's best book. The words about insurance companies are alone worth the price of admission. On Heinlein's pay-as-you-go moon, you "buy" life insurance by placing a bet with your bookie. You bet that you'll die that year, he bets you won't, and figures the odds... Well, isn't that what real insurance companies do? Explains a lot.... - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 23, 2002
Or might it cause someone to not ask a question they should have asked for fear of looking stupid? Or is it stupid to fear looking stupid? Bill Lamb Ocklawaha ----- Original Message ----- From: "Jaye and Scott Jackson" <jayeandscott(at)shaw.ca> Subject: Re: AeroElectric-List: Bob's words of wisdom > > This one caught my eye,too. > I wonder if some will think Bob thinks their question is stupid? > Or would one have to be stupid to think that? > Hmm.. > Scott in Vancouver > ----- Original Message ----- > From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> > To: > Subject: AeroElectric-List: Bob's words of wisdom > > > > > > > > Bob . . . > > > > > > | Stupidity cannot be cured with money, or through education, | > > > | or by legislation. Stupidity is not a sin, the victim can't | > > > | help being stupid. But stupidity is the only universal | > > > | capital crime; the sentence is death, there is no appeal, | > > > | and execution is carried out automatically and without pity. | > > > | -Lazarus Long- | > > > > > > > > Hi Bob; > > I always enjoy reading your memorable quotes on your signature and > > look forward to next one. I must say though, that this is one the better > > ones. > > Thanks and keep 'em coming. ;-) > > > > S. Todd Bartrim > > Turbo 13B rotary powered > > RX-9endurance (FWF) > > C-FSTB (reserved) > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > > > > > > > > Bob's words of wisdom > > > > > > Bob . . . > > > > > > | Stupidity cannot be cured with money, or through education, | > > > > | or by legislation. Stupidity is not a sin, the victim can't | > > > > | help being stupid. But stupidity is the only universal | > > > > | capital crime; the sentence is death, there is no appeal, | > > > > | and execution is carried out automatically and without pity. | > > > > | -Lazarus Long- | > > > > > > Hi Bob; > > > > I always enjoy reading your memorable quotes on your signature and look > forward to next one. I must say though, that this is one the better ones. > > > > > > Thanks and keep 'em coming. ;-) > > > > > > S. Todd Bartrim > > > > Turbo 13B rotary powered > > > > RX-9endurance (FWF) > > > > C-FSTB (reserved) > > > > > > TARGET"_blank">http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "Jeremy Davey" <jeremycrdavey(at)btinternet.com>
Date: Oct 24, 2002
Nope. Surely not realising you're stupid is an essential part of being stupid?! For example: 1) People who park their trolleys in supermarkets (US: grocery stores) so that they block the aisle 2) People who drive in the middle lane when the left (US: right) one is empty, not realising they are taking up two lanes (one-side overtaking rule does not apply in US, so this one may be completely meaningless to most of the readers - sorry :-( ) 3) People who walk slowly side-by-side down a narrow pedestrian tunnel on the Tube (US: subway) in the rush-hour not realising everyone is backing up behind them 4) People who really think that how they look is more important than their safety Apologies, I think this thread set me off on my soapbox... Regards, Jeremy Europa XS Monowheel G-EZZA - still making the wings, no electric string in sight yet... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Billie Lamb Subject: Re: AeroElectric-List: Bob's words of wisdom Or might it cause someone to not ask a question they should have asked for fear of looking stupid? Or is it stupid to fear looking stupid? Bill Lamb Ocklawaha ----- Original Message ----- From: "Jaye and Scott Jackson" <jayeandscott(at)shaw.ca> Subject: Re: AeroElectric-List: Bob's words of wisdom > > This one caught my eye,too. > I wonder if some will think Bob thinks their question is stupid? > Or would one have to be stupid to think that? > Hmm.. > Scott in Vancouver > ----- Original Message ----- > From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> > To: > Subject: AeroElectric-List: Bob's words of wisdom > > > > > > > > Bob . . . > > > > > > | Stupidity cannot be cured with money, or through education, | > > > | or by legislation. Stupidity is not a sin, the victim can't | > > > | help being stupid. But stupidity is the only universal | > > > | capital crime; the sentence is death, there is no appeal, | > > > | and execution is carried out automatically and without pity. | > > > | -Lazarus Long- | > > > > > > > > Hi Bob; > > I always enjoy reading your memorable quotes on your signature and > > look forward to next one. I must say though, that this is one the better > > ones. > > Thanks and keep 'em coming. ;-) > > > > S. Todd Bartrim > > Turbo 13B rotary powered > > RX-9endurance (FWF) > > C-FSTB (reserved) > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > > > > > > > > Bob's words of wisdom > > > > > > Bob . . . > > > > > > | Stupidity cannot be cured with money, or through education, | > > > > | or by legislation. Stupidity is not a sin, the victim can't | > > > > | help being stupid. But stupidity is the only universal | > > > > | capital crime; the sentence is death, there is no appeal, | > > > > | and execution is carried out automatically and without pity. | > > > > | -Lazarus Long- | > > > > > > Hi Bob; > > > > I always enjoy reading your memorable quotes on your signature and look > forward to next one. I must say though, that this is one the better ones. > > > > > > Thanks and keep 'em coming. ;-) > > > > > > S. Todd Bartrim > > > > Turbo 13B rotary powered > > > > RX-9endurance (FWF) > > > > C-FSTB (reserved) > > > > > > TARGET"_blank">http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 23, 2002
Byron, I don' know for certain about that model, but the Odyssey line can be had with Metal Jackets - they are used by the motorcycle crowd. Generally the metal jacketed ones are quite a bit more expensive. Regardling use of the metal jacket as a battery box, my guess is that is may not be stressed for the loads it may encounter in an aircraft installations. Ed Anderson ----- Original Message ----- From: <N89BJ(at)aol.com> Subject: Re: AeroElectric-List: Odyssey Battery Question > > Anyone know why the Odyssey Battery(#680) has a metal case. Doesn't seem to > be removable. Could it be used as a battery box? Thanks. > > Byron > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Z-11a, Single ECU
Bob, I am using Z-11a with a single ECU to keep the motor noisy. Not sure of the best way to feed it from either battery buss. Two diodes to prevent cross feed would lower the voltage in an alternator out situation. One double pole switch could be another single point failure. I am thinking about two switches side by side, on-off-on, that have their handles tied together. Up would be normal feed from one battery, center is off, and down would be feed from the other battery. Any thoughts or suggestions from anyone are always welcome. That's what makes this group work so well! Randy ________________________________________________________________________________
Date: Oct 23, 2002
I have tried a couple of Zeners and the 9.1volt with a 220 ohm resister in series with it appears to work for a single LED. However, when I put more than one LED with 220ohm resistors in parallel to the LED then none work. (When I bypass the Zener, they work, but at a dimmer level). Is there some special trick to making multiple LED's dim? - Jim ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: LED Dimmer Switch > > > > >Bob, > > > >I am trying to hook up an LED warning panel for main & aux alternator > >failure, x-feed on, starter on & low oil pressure warn. > > > >I have tried hooking up an LED warning panel using LEDs with parallel & > >series 220 ohm resters instead of lamps. I used the Zener Diode 1N4745A as > >the dimmer, but get no ruduction in the LED brightness. > > > >Any suggestions on where I am going wrong? > > > You probably have the zener backwards. It sounds like > you've got it wired such that the zener is FORWARD > biased wherein the voltage drop is about the same > as an ordinary diode . . . 0.7 volts. > > Reversing the zener causes the voltage drop to > increase to the value of the zener's rating. In > the case of a 1N4745, the rating is 16 volts. > This will drop ALL of your applied voltage and > the LED will be dark. > > Try zeners over the range of 1N4735 (6.2v) to > 1N4739 (9.1 volts) to find the one that provides > the desired dimming characteristic. > > Bob . . . > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 23, 2002
The more recent RV-7 plans show just that. The steel case has a few lightening holes put in it, a couple bracing pieces of angles riveted on, and it is used to hold the battery to the firewall. There is a hold down bar screwed to the top. I like it. > From: "Ed Anderson" <eanderson(at)carolina.rr.com> > Reply-To: aeroelectric-list(at)matronics.com > Date: Wed, 23 Oct 2002 19:44:53 -0400 > To: > Subject: Re: AeroElectric-List: Odyssey Battery Question > > > > Byron, > I don' know for certain about that model, but the Odyssey line can be > had with Metal Jackets - they are used by the motorcycle crowd. Generally > the metal jacketed ones are quite a bit more expensive. Regardling use of > the metal jacket as a battery box, my guess is that is may not be stressed > for the loads it may encounter in an aircraft installations. > > Ed Anderson > ----- Original Message ----- > From: <N89BJ(at)aol.com> > To: > Subject: Re: AeroElectric-List: Odyssey Battery Question > > >> >> Anyone know why the Odyssey Battery(#680) has a metal case. Doesn't seem > to >> be removable. Could it be used as a battery box? Thanks. >> >> Byron >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Oct 23, 2002
> >I have tried a couple of Zeners and the 9.1volt with a 220 ohm resister in >series with it appears to work for a single LED. > >However, when I put more than one LED with 220ohm resistors in parallel to >the LED then none work. (When I bypass the Zener, they work, but at a >dimmer level). > >Is there some special trick to making multiple LED's dim? Each LED needs its own resistor. You cannot parallel LEDs. Further, depending on whether your group of LEDs are pulled up to +14v or pulled down to ground, you need separate dimming control zeners and a two pole switch to handle the full array of annunciator leds. See http://216.55.140.222/temp/LED_Dimming.gif Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Thoughts from folks wiser than most (was: Bob's
words of wisdom) > > > > Bob . . . > > > > | Stupidity cannot be cured with money, or through education, | > > | or by legislation. Stupidity is not a sin, the victim can't | > > | help being stupid. But stupidity is the only universal | > > | capital crime; the sentence is death, there is no appeal, | > > | and execution is carried out automatically and without pity. | > > | -Lazarus Long- | > > > > >Hi Bob; > I always enjoy reading your memorable quotes on your signature and >look forward to next one. I must say though, that this is one the better >ones. > Thanks and keep 'em coming. ;-) I really like the Lazarus Long quotations. Most folks don't know who he wasn't . . . since he is a fictional character of exceedingly long life who turns up in multiple works by Robert Heinlein. I think Bob's alter-ego(s) show up in his most thought-provoking and creative works. Can't decide tho if Lazarus Long or Jubal Hershaw fits the Heinlein model . . . it may be both! Both his fictional and serious works are well worth the effort to acquire and read. One of my favorites since Jr. High. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
> > >This one caught my eye,too. >I wonder if some will think Bob thinks their question is stupid? >Or would one have to be stupid to think that? >Hmm.. Hmmmm . . .yerself. It DOES makes one think a bit . . . no? Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
> >Anyone know why the Odyssey Battery(#680) has a metal case. Doesn't seem to >be removable. Could it be used as a battery box? Thanks. Why do you want a battery box for an RG battery? They are totally unnecessary. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: RE: Heinlein's words of wisdom
> > >Nope. Surely not realising you're stupid is an essential part of being >stupid?! > >For example: > >1) People who park their trolleys in supermarkets (US: grocery stores) so >that they block the aisle >2) People who drive in the middle lane when the left (US: right) one is >empty, not realising they are taking up two lanes (one-side overtaking rule >does not apply in US, so this one may be completely meaningless to most of >the readers - sorry :-( ) >3) People who walk slowly side-by-side down a narrow pedestrian tunnel on >the Tube (US: subway) in the rush-hour not realising everyone is backing up >behind them >4) People who really think that how they look is more important than their >safety > > > >Apologies, I think this thread set me off on my soapbox... > >Regards, >Jeremy I would think Mr. Heinlein would characterize those kinds of behavior as selfishness and uncaring. There are plenty of intelligent people who practice those things. Plenty of intelligent people have serious flashes of stupidity too . . . like strapping one's self into an airplane with nearly empty tanks and a fuel valve you can't reach . . . or not calling for local radar support when you find yourself above an overcast and NOT on an IFR flight plan . . . went down for a "look see" based 500 foot ceilings cite by ATIS. Found the guy wires for a 1500-foot tower. I'm sure that these are the kinds of things to which the honorable Mr. Heinlein was referring. I'm certain he would find the activity on this list most appropriate to a bunch of folks doing their best to enjoy (and survive) in a very unforgiving environment. We're all working hard to avoid walking into a lion's gage naked, unarmed and carrying a dead-chicken in each hand. Bob . . . ________________________________________________________________________________
From: "William T Bartlett" <wtbartlett(at)Prodigy.net>
Subject: Re:List: Electric Primer
Date: Oct 23, 2002
Werner: In your case its easy. Tee off your gascolater out line,put an automotive fuel pump (smallest,cheapest, with between 4 and 15 PSI) on your firewall and adapt the output of the pump to the 1/8th " primer manifold (That little soldered-on Ball fitting is a standard AN fitting, but an 1/8th" ferrule from automotive shop will seal well enough). Activate the pump with a spring loaded on off switch. You just need to learn how many seconds you need to hold your switch down - probably about 2. You will be able to hear that pump click. About three clicks should do it. I have a friend who will buy your valve. Bill N7WB > From: "Werner Schneider" <WernerSchneider(at)compuserve.com> > Subject: Re: AeroElectric-List: Electric Primer > > > What are you doing with a high wing setup and no electrical fuel pump > =(;o(((, I was thinking it is a small fuel pump, now I'm stucked with a > valve only =(;o((. > > Any good idea how to solve this easely? > > Werner > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: More words of wisdom
Bob, I saw this little pearl a few years back. "Hydrogen is the most abundant element in the universe, Stupidity runs a close second." Rick Girard ________________________________________________________________________________
Date: Oct 23, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Jim Pack wrote: > > > Bob, > > I am trying to hook up an LED warning panel for main & aux alternator > failure, x-feed on, starter on & low oil pressure warn. > > I have tried hooking up an LED warning panel using LEDs with parallel & > series 220 ohm resters instead of lamps. I used the Zener Diode 1N4745A as > the dimmer, but get no ruduction in the LED brightness. > > Any suggestions on where I am going wrong? > > - Jim > Jim, LED's don't function like light bulbs. They are diodes that just happen to emit light. It takes a 'threshold' voltage to forward bias or light the diode (varies with the design/color of the LED) and the diode will use a fixed amount of current to be 'converted' to light. The series resistor is sized to supply the needed voltage/current to the LED depending on supply voltage. Less than 'threshold' voltage means that the LED doesn't glow. If the voltage is raised very much above the theshold, current begins to rise (remember it's a diode, not a resistive load) and the excess current destroys the diode. LED 'brightness' is varied by pulsing the DC supply voltage with a varying pulse width. The pulse frequency is high enough that the human eye doesn't notice it, kind of like TV or movie pictures. Constant DC voltage = max brightness; as the 'on' time percentage of the DC voltage decreases, the LED looks dimmer to the human eye. Think about strobe lights from your Disco days. :-) The faster the strobe flashes, the brighter the room looks. LED dimmers are available & plans for building your own are available, but either way you are looking at more money/work/complexity than a zener or reostat to change the voltage. Charlie with apologies to the EE's reading my very rough description of electronic functions. ________________________________________________________________________________
Date: Oct 23, 2002
Thanks, I was putting another resister in parallel with each LED in addition to the series resistor. - Jim > >I have tried a couple of Zeners and the 9.1volt with a 220 ohm resister in > >series with it appears to work for a single LED. > > > >However, when I put more than one LED with 220ohm resistors in parallel to > >the LED then none work. (When I bypass the Zener, they work, but at a > >dimmer level). > > > >Is there some special trick to making multiple LED's dim? > > Each LED needs its own resistor. You cannot parallel > LEDs. Further, depending on whether your group of LEDs > are pulled up to +14v or pulled down to ground, you need > separate dimming control zeners and a two pole switch > to handle the full array of annunciator leds. > > See http://216.55.140.222/temp/LED_Dimming.gif > > > Bob . . . > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Plug for Auto Alternator
I bought a 60 Amp Honda alternator. Fits well and is mechanically attached to the plane, but I need to attach it electrically and the 3-pin plug that normally attaches it to the cars' system is of course not part of the alternator purchase. How can I locate this plug? Thanks Neil Clayton Cozy MkIV #493 ________________________________________________________________________________
Date: Oct 23, 2002
> > >Thanks, I was putting another resister in parallel with each LED in >addition to the series resistor. Oh. That was only necessary for making the LR3 Regulator believe it was driving a light bulb. The LR3 is a pull-down type switch for the LED output. So, if you want to dim this LED along with other LEDs of the pull-down variety, you would put a resistor in parallel ONLY with the LED for the LR3, all others run barefoot. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Loadmeter reappears with alt field voltage
> > >Bob, and others, > Bob has mentioned in a prior post that the transient suppression of > the formerly available loadmeter circuit board is not needed. That means > that the dual ammeter/voltmeter needs only connection to the shunt(s) > used to measure current output from the alternator(s). Westach is now > making these meters available, in the 'what's new' section of their > site. Bob mentioned that the 13 to 15 volt range was inexplicably done > in red in the picture on their web site! I ordered one, and had them > change the 13 to 15 volt range to green. There is a six week wait, as > they sold out of the first batch. Hmmm . . . wonder if the first batch had the wrong colored arc! > Bob has mentioned how valuable is it to have field voltage available > for troubleshooting. One of the problems with the original loadmeter, > which is just an ammeter scaled for your particular alternator in %, was > that measuring the field voltage from the alternator gave an > miscalibrated voltage reading on the voltmeter scale which read roughly > 10 to 17 volts. Not so. See installation data (link below) > Back home on the ground you could look up the true voltage from a > table. With the circuitry of Bob's loadmeter no longer available, this > is not an option anyway. However, if you are willing to use the ammeter > scale, which reads 0 to 100%, and is linear--no expanded scale > issues--you can press this into service by using a spring-loaded double > pole switch to shift the loadmeter from the shunt(s) to read the field > voltage. > When you want to check field voltage, just push the spring-loaded > switch and read it from the loadmeter. The appropriate series resistor > is easy to calculate. Say you want a 0 to 20 volt scale, so that each 5% > marking on the leadmeter was 1 volt. The loadmeter is a 1 ma movement > with a 50 millivolt voltage drop at full scale: calculates to 50 > ohms. The series resistor would be 20 volts divided by 1 ma, or 20,000 > ohms. We can ignore the internal resistance of the meter here. Here's a link for a complete data package on the VLM-14 including installation/operation instructions, schematic-BOM and board layout. http://216.55.140.222/temp/LM-VM_Data.pdf Here's a link to an ExpressPCB artwork file that I belive represents a re-incarnation of the original board minus the original errors. CAUTION . . . check this artwork over for possible new errors before ordering boards. http://216.55.140.222/temp/9021-310-1A.pcb Also, this artwork doesn't represent an optimized layout for size since I took advantage of ExpressPCB's super cheap offer of 3 boards for $62 in four days if you put them on a standard profile . . . which is too big for a optimized layout but still plenty small and about the same size as the originals. > Here is what I'm doing for my two alternators, one of which has a > field and the other a permanent magnet. The S200-2-50 switch is > on-on-(on). The first position reads current output of alternator 1, the > second is alternator 2, and the spring-loaded third position reads > voltage from the field circuit on the loadmeter side. If you have one > alternator, then a on-(on) DPDT switch would shift the loadmeter from the > current reading shunt to the voltage reading resistor from the field circuit. > Bob, it might help to put a simple diagram on the 'Connection, so > that people who wish to use this feature can do so. I've got the diagram > in my head, but I'm afraid the verbal description was opaque. I don't see how you can do this with a two-pole progressive transfer like the 2-50 . . . it should take a 4-pole . . . but never mind now 'cause you can for all practical purposes duplicate the original product right down to the installation manual and instructions. Suggest you evaluate the downloads and see if it gives you a shorter path (with a track record) to success. Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Z-11a, Single ECU
> > >Bob, I am using Z-11a with a single ECU to keep the motor noisy. Not sure >of the best way >to feed it from either battery buss. Two diodes to prevent cross feed would >lower the voltage >in an alternator out situation. One double pole switch could be another >single point failure. >I am thinking about two switches side by side, on-off-on, that have their >handles tied together. >Up would be normal feed from one battery, center is off, and down would be >feed from the >other battery. Any thoughts or suggestions from anyone are always welcome. >That's what >makes this group work so well! I'd run it via fusible link from the aux battery only. This is what a second battery is for . . . provide a totally independent source of power for the engine that is not also loaded with other goodies. If push comes to shove, you can always close both battery contactors and get main battery power to the ECU but if you've got a less-than-two-year-old battery in the aux slot, I can't see this happening. How much current does your ECU draw in cruise? Bob . . . ________________________________________________________________________________
Date: Oct 23, 2002
Bob, I thought the LR3 just grounded the low volt warning light contact when the voltage dropped. So, you're saying that when I hook the LED with a 220ohm resister in parallel & one in series to the LR3, that it will not behave like it does on my breadboard (where I have the other LED's hooked up to the same power bus)? Do I need to run a separate power line to the LR3 indicators separate from the other 6 LED's I have hooked up? Or can they all share the same power line? When I include one LED with a parallel resistor and the others without, on the dim setting (through the zener) only those that do not have a resistor light up. The result is that the LR3 warning light remains dark even when I connect it to ground. If instead of connecting it to ground on the breadboard, it is connected to the LR3, will it work in this configuration? (for example, if in your diagram, one of the LED's had a resister in parallel with the LED and the others didn't, the one with the parallel resistor doesn't do it's job). Sorry for being such a beginner. - Jim > > > >Thanks, I was putting another resister in parallel with each LED in > >addition to the series resistor. > > Oh. That was only necessary for making the LR3 Regulator > believe it was driving a light bulb. The LR3 is a pull-down > type switch for the LED output. So, if you want to dim this > LED along with other LEDs of the pull-down variety, you > would put a resistor in parallel ONLY with the LED for the > LR3, all others run barefoot. > > Bob . . . > ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Plug for Auto Alternator
Neil, I had the same problem. I couldn't find a plug but I eventually used large size spade connectors from NAPA which fit the wire and slide onto the alternator, Then secured the wires with a small adel clamp. --Kent A. Neil Clayton wrote: > > I bought a 60 Amp Honda alternator. Fits well and is mechanically attached > to the plane, but I need to attach it electrically and the 3-pin plug that > normally attaches it to the cars' system is of course not part of the > alternator purchase. How can I locate this plug? > > Thanks > Neil Clayton > Cozy MkIV #493 > ________________________________________________________________________________
Date: Oct 23, 2002
Subject: Re: Electric Solenoid Engine Primer Valve
> >AeroElectric-List message previously posted by: Gary Liming > >"The A Spruce catalog there is an electric primer that describes a solenoid >with a spring and plunger. Does this arrangement replace a traditional >type primer the same way - i.e., would the switch be operated the same as >in throw the switch for 2-3 seconds, and one "squirt" is delivered, let go, >then throw the switch again, etc.? So would it be wired as a momentary >switch? Also, the electric primer is cheaper by at least half of the >traditional ones, and you can leave the primer lines on the other side of >the firewall. Seems like a no brainer - is there any reason to use the >traditional primer? > >10/22/2002 > >Hello Gary, If you read all the words carefully you will see that this device >(P/N 05-29823) is an electrically controlled primer valve, not a primer. >The normal mechanical primer is a cylindrical pump by which you manually >force some fuel into some or all of the cylinder induction areas of the >engine. Hi OC, and others who responded. I left out 'valve' in the first post, sorry. I guess I didn't make myself too clear - let me rephrase the question: I see type cert planes with both boost pump switches and manual (plunger type) primers - Why? I suspect they had a good reason to do that, but I don't see it. Just making sure I am not missing something. Gary Liming ________________________________________________________________________________
Date: Oct 23, 2002
Thanks Denis, If Van says its OK, then I'd go for it. Ed ----- Original Message ----- From: "Denis Walsh" <deniswalsh(at)earthlink.net> Subject: Re: AeroElectric-List: Odyssey Battery Question > > The more recent RV-7 plans show just that. The steel case has a few > lightening holes put in it, a couple bracing pieces of angles riveted on, > and it is used to hold the battery to the firewall. There is a hold down > bar screwed to the top. I like it. > > > From: "Ed Anderson" <eanderson(at)carolina.rr.com> > > Reply-To: aeroelectric-list(at)matronics.com > > Date: Wed, 23 Oct 2002 19:44:53 -0400 > > To: > > Subject: Re: AeroElectric-List: Odyssey Battery Question > > > > > > > > Byron, > > I don' know for certain about that model, but the Odyssey line can be > > had with Metal Jackets - they are used by the motorcycle crowd. Generally > > the metal jacketed ones are quite a bit more expensive. Regardling use of > > the metal jacket as a battery box, my guess is that is may not be stressed > > for the loads it may encounter in an aircraft installations. > > > > Ed Anderson > > ----- Original Message ----- > > From: <N89BJ(at)aol.com> > > To: > > Subject: Re: AeroElectric-List: Odyssey Battery Question > > > > > >> > >> Anyone know why the Odyssey Battery(#680) has a metal case. Doesn't seem > > to > >> be removable. Could it be used as a battery box? Thanks. > >> > >> Byron > >> > >> > >> > >> > > > > > > > > > > > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 23, 2002
This is being reposted in plain text hoping that word wrap will work and it will fit in your browser window. Sorry. Bob, and others, Bob has mentioned in a prior post that the transient suppression of the formerly available loadmeter circuit board is not needed. That means that the dual ammeter/voltmeter needs only connection to the shunt(s) used to measure current output from the alternator(s). Westach is now making these meters available, in the 'what's new' section of their site. Bob mentioned that the 13 to 15 volt range was inexplicably done in red in the picture on their web site! I ordered one, and had them change the 13 to 15 volt range to green. There is a six week wait, as they sold out of the first batch. Bob has mentioned how valuable is it to have field voltage available for troubleshooting. One of the problems with the original loadmeter, which is just an ammeter scaled for your particular alternator in %, was that measuring the field voltage from the alternator gave an miscalibrated voltage reading on the voltmeter scale which read roughly 10 to 17 volts. Back home on the ground you could look up the true voltage from a table. With the circuitry of Bob's loadmeter no longer available, this is not an option anyway. However, if you are willing to use the ammeter scale, which reads 0 to 100%, and is linear--no expanded scale issues--you can press this into service by using a spring-loaded double pole switch to shift the loadmeter from the shunt(s) to read the field voltage. When you want to check field voltage, just push the spring-loaded switch and read it from the loadmeter. The appropriate series resistor is easy to calculate. Say you want a 0 to 20 volt scale, so that each 5% marking on the leadmeter was 1 volt. The loadmeter is a 1 ma movement with a 50 millivolt voltage drop at full scale: calculates to 50 ohms. The series resistor would be 20 volts divided by 1 ma, or 20,000 ohms. We can ignore the internal resistance of the meter here. Here is what I'm doing for my two alternators, one of which has a field and the other a permanent magnet. The S200-2-50 switch is on-on-(on). The first position reads current output of alternator 1, the second is alternator 2, and the spring-loaded third position reads voltage from the field circuit on the loadmeter side. If you have one alternator, then a on-(on) DPDT switch would shift the loadmeter from the current reading shunt to the voltage reading resistor from the field circuit. Bob, it might help to put a simple diagram on the 'Connection, so that people who wish to use this feature can do so. I've got the diagram in my head, but I'm afraid the verbal description was opaque. Jim Foerster ________________________________________________________________________________
Date: Oct 24, 2002
Yikes! That progressive transfer feature of 2-50 switch was *not* what I wanted. What I wanted was a double pole, triple throw toggle, one position spring loaded. This would be for the two alternator situation. Perhaps describing the one alternator design would illustrate the idea more easily. The shunt is in the B lead from the alternator. Two wires come from the shunt and connect to the lower set of fixed contacts on the DPDT switch: call these left and right. The ammeter connects to the switched pair of contacts. With the lower set active, the ammeter reads the current through the shunt. In the other switch postion, which is a momentary spring loaded position, the ammeter positive side is connected to a 20K resistor which goes from the left upper switch contact to the field connection. The right upper contact is grounded, and completes the circuit. The meter is now a voltmeter-0 to 20. And the expanded scale voltmeter? Just connect the minus side to ground, and the positive side to the minus side of the ammeter. It will read the voltage of the shunt 'downstream' side. When the switch is up, to read field voltage, the expanded scale voltmeter will read zero--which is fine, as the field voltage is read only for a brief moment. That is why I wanted a spring loaded toggle. A momentary DPDT push button would also do, but is hard to find with push on terminals. Since the field voltage is of interest only to the owner of the OBAM plane, the brief zero reading on the voltmeter side should cause no concern. Now for the two alternator case. A rotary switch with two poles and three positions would work, but then we lose the push-on connection, and the spring return from reading field voltage. You would not want the meter displaying field voltage all the time because you forgot to reset the switch. I have just found a suitable toggle in the Allied catalog, but it is a solder unit stock # 70-8619 listed as On-On-(On) and DP3T. This is a subminiature unit and could easily mount next to the meter. Pigtails leads could then be connected with the crimp-on knife connects. If you must have standard toggle switches, then use two: one DPDT to select one of two alternator shunts, and the second spring-loaded DPDT On-(On) switch to switch the ammeter between the field voltage resistor-ground pair, and the shunt pair going to the ammeter.
October 17, 2002 - October 24, 2002
AeroElectric-Archive.digest.vol-bg
