AeroElectric-Archive.digest.vol-bh
October 24, 2002 - October 31, 2002
           It appears that this avoids the need for the original board and
      attedant construction.  Fusible links needed from the shunts, of course.
      Jim Foerster
Subject: Z-11a, Single ECU
Date: Oct 24, 2002
> I'd run it via fusible link from the aux battery only. This > is what a second battery is for . . . provide a totally > independent source of power for the engine that is not > also loaded with other goodies. > > If push comes to shove, you can always close both battery > contactors and get main battery power to the ECU I thought both contactors were closed during normal ops? I have the same situation - one ECU and two batteries. I was thinking that for "normal operations" I'd like the fuel pumps and ECU to go and off with the master. This would make for simpler operation, and everything would shut down with the master. Any reason why I couldnt wire the ECU and pumps with a fuseable link to the essential bus on the "normal" side their switch, and a fuseable link to the aux battery bus on the "Emergency" side? If this is "acceptable" practice, which switch type would be best? John Slade Cozy IV ________________________________________________________________________________
Subject: Re: Plug for Auto Alternator
Date: Oct 24, 2002
I also used spade connectors for this too but it's highly recommended to use PIDG double-crimp connectors. The spade connectors from NAPA are probably single-crimp and allow the wire to move and eventually break. You should have a whole pile of different sized PIDG terminals and good PIDG crimpers to wire a plane anyway. Gary K. ----- Original Message ----- From: "Kent/Jackie Ashton" <kjashton(at)vnet.net> Subject: Re: AeroElectric-List: Plug for Auto Alternator > > Neil, I had the same problem. I couldn't find a plug but I eventually used > large size spade connectors from NAPA which fit the wire and slide onto the > alternator, Then secured the wires with a small adel clamp. > --Kent A. > > Neil Clayton wrote: > > > > > I bought a 60 Amp Honda alternator. Fits well and is mechanically attached > > to the plane, but I need to attach it electrically and the 3-pin plug that > > normally attaches it to the cars' system is of course not part of the > > alternator purchase. How can I locate this plug? > > > > Thanks > > Neil Clayton > > Cozy MkIV #493 > > > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Electric Solenoid Engine Primer Valve
In a message dated 10/23/02 11:25:17 PM Central Daylight Time, gary(at)liming.org writes: > I see type cert planes with both boost pump switches and manual (plunger > type) primers - Why? > > I suspect they had a good reason to do that, but I don't see it. Just > making sure I am not missing something. > > Gary Liming > Good Morning Gary, I may have missed part of the point here, but as to the priming function of an electric boost pump, It All Depends on the type of fuel controller system in the aircraft. If it has a basic float type carburetor, the boost pump merely supplies a positive head of pressure to assure adequate flow for the needle valve controlled by the float to control. In that case, an electrically operated valve can be installed so as to bypass the carburetor and send fuel to prime either directly to the cylinder or via a central priming point, usually somewhere down stream of the carburetor. On the other hand, a pressure injection carburetor, such as a PS5C, will flow fuel through the carburetor any time that sufficient pressure is applied. More pressure, more fuel. On those units, no solenoid is need. All you have to do is operate the pump. They same is true for the Continental/Bendix style of constant flow fuel injection systems. Any help? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 24, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> >In a message dated 10/23/02 11:25:17 PM Central Daylight Time, >gary(at)liming.org writes: > > > I see type cert planes with both boost pump switches and manual (plunger > > type) primers - Why? > > > > I suspect they had a good reason to do that, but I don't see it. Just > > making sure I am not missing something. > > > > Gary Liming > > > >Good Morning Gary, > >I may have missed part of the point here, but as to the priming function of >an electric boost pump, It All Depends on the type of fuel controller system >in the aircraft. If it has a basic float type carburetor, the boost pump >merely supplies a positive head of pressure to assure adequate flow for the >needle valve controlled by the float to control. > >In that case, an electrically operated valve can be installed so as to bypass >the carburetor and send fuel to prime either directly to the cylinder or via >a central priming point, usually somewhere down stream of the carburetor. > >On the other hand, a pressure injection carburetor, such as a PS5C, will flow >fuel through the carburetor any time that sufficient pressure is applied. >More pressure, more fuel. On those units, no solenoid is need. All you have >to do is operate the pump. > >They same is true for the Continental/Bendix style of constant flow fuel >injection systems. I wish it were so simple/logical. The 172XP in the late 60's is fuel injected and has a hand primer too . . . Never knew what to do with it. I need to check the POH next time I rent it and see what it suggests. Virtually all low wing, carbureted aircraft I've flown have electric boost pumps and as I recall, all POH checklists call for the pump to be running during takeoff and approach to landing. Low wing fuel injected have boost pumps too, but most don't call to run the pump during any time other than engine priming (which pre-flights the pump) or instances of engine driven pump failure. The Beech Sundowner was carbureted and had a manual primer. The Skipper (designed after the Sundowner with Pug Piper contributing considerable input) had an electric primer, obviously only functional if the boost pump was also running. The Skipper is the only airplane I've flown with an electric primer. The advantages of minimizing the fuel plumbing in the cockpit are obvious but consider an alternative advantage of an electric primer system on an engine with any kind of fuel delivery system. Install a 4-port primer system feed by an electric valve downstream of an electric pump. Put a needle valve in the primer line and calibrate primer fuel flow for 55 to 65% power fuel flows for your particular engine. The primer can be used for its obvious function in pre-flight. Should the engine suffer fuel starvation due to any sort of discontinuity in the normal fuel delivery system, one can pull the mixture to idle cutoff, turn on the primer system and adjust the throttle (now a mixture control) for smoothest running engine. I proposed this to a Long-Ez builder about 12 years ago. He plumbed is primer system to get fuel from the left tank through its own outlet and filter. His fuel management protocol was to switch tanks such that the left tank always as as much or more fuel than the right tank. He tested this system in flight and reported performance as anticipated. How many airplanes flying have DUAL, redundant and totally independent fuel delivery systems? Bob . . . ________________________________________________________________________________
Subject: Lazarus Long and LED Primer
Date: Oct 24, 2002
I was privileged to meet 79 year-old Lazarus Long (AKA Robert A. Heinlein, the "Mark Twain of Sci Fi") in 1987 not too long before he died. He stood about 5 feet-tall, weighed perhaps 90 pounds and walked with a cane. He was impeccably dressed, white haired and dapper. We was still writing and just working on more Lazarus Long. I was amazed he was so tiny; this didn't fit with my idea of him at all. For a great collection of his quotes try: http://www.bobgod.com/writer/lazaruslong.html LED Primer: 1) LEDs will emit light if their voltage is above some small voltage, usually a couple of volts. Incandescent lamps when you think about it, behave the same (but for very different reasons). 2) LEDs lifetimes are nearly infinite if not pushed too hard; there are LEDs that have been on continuously for thirty years and counting. LEDs will be common household lamps in the next few years. Plug-in replacement lamps for most applications are available or easy to craft yourself. They are not extremely efficient (lumens/watt), but they are small, cool, and last almost forever. 3) LEDs are brighter and dimmer depending on the current through them. (Forget pulse-width modulation...that's usually not the way it's done). If you increase the voltage to them, the current through them increases and they get brighter. If you reduce the resistance the same thing happens. Don't exceed the recommended maximum current. Most common LEDs work well at 20 milliamps (or as Bob spells it miliamps). For the mathematically inclined: V(supply)-V(led)R(in series) x I(led). 4) Using LEDs in parallel: Incandescent lamps (and many other things) INCREASE resistance when they're on so the hot lamp gets less of the current. This is good. But LEDs (and many other things) decrease resistance when they're on so all the current wants to go through one LED. This is not good; one LED's current will quickly spiral up, leading to things not working. To prevent this, you only have to give each little LED its own little resistor. 5) If you want to dim parallel LEDs (each of which may be on or off) then it is easiest to change the voltage to the LEDs. Bob's zener+bypass switch or any voltage regulator works well. Regards, Eric M. Jones ________________________________________________________________________________
Subject: Re: ELT control wire?
Date: Oct 24, 2002
Russ Werner wrote: > > > It's just telephone cable. Not critical by any means. Buy the 25 footer > and clip off the male end. Reinstall a new male end where you need it and > be sure to swap wires accordingly, as the ELT wires cross enroute while the > telephone wires don't. *** Thanks Russ. That's what I did. Actually, the 25-footer worked fine as it was wired. I had to snip the connector and crimp on a new one anyway to fish the wire through the floor. - Jerry ________________________________________________________________________________
Date: Oct 24, 2002
Subject: AutoCad
Bob: Watching closely the Z-14 system planning for shannon. Interested in doing the wirebook. Thought I had a program that would read dwg files, but don't. Checked at the store, autocad at 3300.00. Never found autocad lite, but did find turbo autocad at best buy for 99.99. Will this work? ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: AutoCad
Bob: Sorry. Looking for autcad info. Been flying all night. Up in Canada now. Thanks, Ed Silvanic ________________________________________________________________________________
Date: Oct 24, 2002
Subject: RE: Z-11a, Single ECU
> > > I'd run it via fusible link from the aux battery only. This > > is what a second battery is for . . . provide a totally > > independent source of power for the engine that is not > > also loaded with other goodies. > > > > If push comes to shove, you can always close both battery > > contactors and get main battery power to the ECU >I thought both contactors were closed during normal ops? that's right . . . the only time the ECU would be running aux battery only is if the alternator is off line whereupon you separate the batteries to do their respective tasks. >I have the same situation - one ECU and two batteries. I was thinking that >for "normal operations" I'd like the fuel pumps and ECU to go and off with >the master. This would make for simpler operation, and everything would shut >down with the master. Any reason why I couldnt wire the ECU and pumps with a >fuseable link to the essential bus Use a fuse from the e-bus . . . fusible links are special case, single feed protection where very high reliablity is desired and faulting that line has no chance of precipitating problems into the rest of the system. Consider that if you get into a J-3 with NO electrical system and flip the mag switches ON, that engine is ready to run. There no particular reason I can understand why this should change just because we added an electrical system. If it were my airplane, I'd wire all devices needed to support engine operation from battery busses. If I have smoke in the cockpit, all DC PWR MASTER switches can go to OFF and the engine will continue to run. > . . . on the "normal" side their switch, and a >fuseable link to the aux battery bus on the "Emergency" side? If this is >"acceptable" practice, which switch type would be best? "Traditional" practice based on 60 some odd years experience watching the regulated side of aviation where the term ECU might as well be a foreign language. "Traditional" practice masquerades as "acceptable". The truly acceptable practice comes from logic and understanding of component characteristics and the user's desires for system operational features and reliability. The inescapable fact is that the engine of your choice has ONE ECU . . . this is a very complex piece of electronics with a lots of failure modes. If it is your perception that the chance of aux battery failure in your airplane is so far above zero that you consider a multiple-source ECU power switching to be a risk mitigation, and your logic is more compelling than mine then the airplane should be wired as you see fit. Be careful of fusible links . . . these attach only to very low impedance points in the system were a robust battery can be expected to open the link and interrupt only ONE circuit. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Loadmeter reappears with alt field voltage
> > > Yikes! That progressive transfer feature of 2-50 switch was *not* what I >wanted. What I wanted was a double pole, triple throw toggle, one position >spring loaded. This would be for the two alternator situation. Perhaps >describing the one alternator design would illustrate the idea more easily. > The shunt is in the B lead from the alternator. Two wires come from the >shunt and connect to the lower set of fixed contacts on the DPDT switch: >call these left and right. The ammeter connects to the switched pair of >contacts. With the lower set active, the ammeter reads the current through >the shunt. In the other switch postion, which is a momentary spring loaded >position, the ammeter positive side is connected to a 20K resistor which >goes from the left upper switch contact to the field connection. The right >upper contact is grounded, and completes the circuit. The meter is now a >voltmeter-0 to 20. > And the expanded scale voltmeter? Just connect the minus side to >ground, and the positive side to the minus side of the ammeter. It will >read the voltage of the shunt 'downstream' side. When the switch is up, to >read field voltage, the expanded scale voltmeter will read zero--which is >fine, as the field voltage is read only for a brief moment. That is why I >wanted a spring loaded toggle. A momentary DPDT push button would also do, >but is hard to find with push on terminals. Since the field voltage is of >interest only to the owner of the OBAM plane, the brief zero reading on the >voltmeter side should cause no concern. > Now for the two alternator case. A rotary switch with two poles and >three positions would work, but then we lose the push-on connection, and the >spring return from reading field voltage. You would not want the meter >displaying field voltage all the time because you forgot to reset the >switch. I have just found a suitable toggle in the Allied catalog, but it >is a solder unit stock # 70-8619 listed as On-On-(On) and DP3T. This is a >subminiature unit and could easily mount next to the meter. Pigtails leads >could then be connected with the crimp-on knife connects. If you must have >standard toggle switches, then use two: one DPDT to select one of two >alternator shunts, and the second spring-loaded DPDT On-(On) switch to >switch the ammeter between the field voltage resistor-ground pair, and the >shunt pair going to the ammeter. > It appears that this avoids the need for the original board and >attedant construction. Fusible links needed from the shunts, of course. First, before we take hammers-n-saws to the system, let's determine if the data package for duplicating the original product is of use to you. If not, why not? Once we've determined the need to re-arrange things, let's discuss logical ways to do so. One thing I'm not sure you understand about the instrument as-supplied by Westach is that the expanded scale voltmeter side of the instrument is not stand-alone. Westach's offerings at expanded scale instruments were not up to the requirements I placed on my design so I ordered only basic meter movements in the instrument (see specification control drawing for 9021-200-2) and accomplished calibration and scaling on the etched circuit board. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
> > >Neil, I had the same problem. I couldn't find a plug but I eventually used >large size spade connectors from NAPA which fit the wire and slide onto the >alternator, Then secured the wires with a small adel clamp. >--Kent A. Beware of auto parts stores crimp-on terminals. See: http://www.aeroelectric.com/articles/faston3.pdf http://www.aeroelectric.com/articles/terminal.pdf Auto parts stores around here have the "HELP" line of odd-and-ends for automotive hardware that may include replacement mating connectors for various alternators. My personal preference is to use a PIDG Fast-on to go directly to the appropriate terminal using strain relief as suggested in Kent's post. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: LED Dimmer Switch
> >Bob, > >I thought the LR3 just grounded the low volt warning light contact when the >voltage dropped. That's right. In the common vernacular of electro_speak this is a "pull-down" activation of the lamp. >So, you're saying that when I hook the LED with a 220ohm resister in >parallel & one in series to the LR3, that it will not behave like it does on >my breadboard (where I have the other LED's hooked up to the same power >bus)? Do I need to run a separate power line to the LR3 indicators separate >from the other 6 LED's I have hooked up? Or can they all share the same >power line? Since power is in the "pull up side" of the "pull-down" activate lamp, it is possible to run all the LEDs from a single power source as illustrated in my sketch. >When I include one LED with a parallel resistor and the others without, on >the dim setting (through the zener) only those that do not have a resistor >light up. The result is that the LR3 warning light remains dark even when I >connect it to ground. If instead of connecting it to ground on the >breadboard, it is connected to the LR3, will it work in this configuration? Hmmm . . . you're beginning to get a glimpse into the perverseness of behavior of LEDs when you try to treat them like voltage driven devices. A red led has about 2.0 volts across it at all intensities and its light output varies with current. Lets try this for the LR3 wiring: http://216.55.140.222/temp/LED_Dimming2.gif >(for example, if in your diagram, one of the LED's had a resister in >parallel with the LED and the others didn't, the one with the parallel >resistor doesn't do it's job). Yup, the original suggestion wouldn't tolerate dimming. Let's see if this works better. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Odyssey Battery Question
> > >Thanks Denis, > > If Van says its OK, then I'd go for it. If Van or anyone else has a recommendation and can explain it in a logical way that you and I understand and agree, then I'd "go for it" too . . . Any lack of understanding as listeners should raise valid concerns and skepticism about what is being proposed. Van is a nice guy, I'm a nice guy, there are lots of nice guys out there with opinions . . . but don't trust a single one of them to drive important decisions about your airplane unless they also help you understand and agree with the opinion. Unlike working on the certified side, you're allowed to do this . . . Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
In a message dated 10/24/02 9:51:45 AM Central Daylight Time, bob.nuckolls(at)cox.net writes: > I wish it were so simple/logical. Golly Bob, I still think it is simple and logical. All it requires is that you understand the engines fuel delivery system. Float type carburetors need to have a method of getting fuel to the carburetor bowl so that it may be fed to the engine as needed. The level of the fuel in the bowl is controlled by the float needle. High wing airplanes generally have an adequate head of fuel pressure to keep fuel available to the bowl, but there have been a few that have back up engine driven pumps, "just in case" or to provide a higher pressure than the high fuel tank provides. Most aircraft that have engine driven pumps are also provided with a back up electric pump these days, though in days of yore, the back up for the engine driven pump was often a hand operated one. I am not aware of any airplane using a "fuel Injection" system that does not also use an engine driven fuel pump. In some of the simpler systems, such as that used by Continental on most of their current production, the speed of the pump, therefore the pressure available, is one of the determinants of the amount of fuel fed to the engine. The PS5C carburetor is very similar to the type of fuel injection system commonly used on Lycoming engines. It has A, B and C chambers that measure airflow and such to decide how much fuel to feed the engine. The PS5C is referred to by the manufacturer as a Pressure Injection Carburetor. There is no fuel flowing in the "venturi" or fuel control body of the carburetor. It is injected into the airstream as it leaves the carburetor body. Any fuel control system that utilizes that sort of fuel control device will react to a higher pressure by putting more fuel on the fire. Therefore, running an electric pump or wobbling a hand wobble pump will add fuel to the engine. That is how the early versions of the Bonanza and Navion were primed. I assume other engine using the PS5C did likewise. That is why engines that are equipped with fuel injection, or pressure injected carburetors, don't tend to have the standby pumps operated for takeoff or landing. It would add an undesired amount of fuel to the engine. There are exceptions, but they should be covered in the POH. I think you will find that almost all of the aircraft which recommend that the electric standby pump be operated during takeoff and landing will have a float type carburetor. Engines that have some sort of pressure injection will recommend that the pump only be used when needed. That usually means for priming the engine or after the failure of the engine driven pump. It can occasionally be used during high altitude and high temperature conditions. It IS simple and logical. However, it does require that the operator be aware of what type of fuel delivery system is used on the engine being operated. Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 24, 2002
> >Bob: > > Sorry. Looking for autcad info. Been flying all night. Up in Canada >now. > >Thanks, There are 3 cad programs on my CD_Rom that will open, edit, save and print my drawings. You can order from http://www.aeroelectric.com/Catalog/AECcatalog.html I had the CD_ROM on the server for awhile and lots of folks downloaded it . . . drove traffic (read billing) on my server up quite a bit. As soon as I can get my experimental server back on the DSL line (not metered) I'll make the download available again. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
> >Bob: > > Watching closely the Z-14 system planning for shannon. Interested in >doing the wirebook. Thought I had a program that would read dwg files, but >don't. Checked at the store, autocad at 3300.00. Never found autocad lite, >but did find turbo autocad at best buy for 99.99. Will this work? Older versions did. Don't know about the latest. You could contact the supplier on the 'net ad ask about cross-application capabilities of the current version with respect to AutoCAD R14 format of my drawings. Or you can get the CD_Rom at http://www.aeroelectric.com/Catalog/AECcatalog.html which has three CAD programs on it that will work. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
Bob, If the Westach instrument calibration is not good enough so that you used a linear 'bare' movement, then the unit they are selling now, with the expanded scale components already in the meter case, won't work with your board. I already have one of their -30-0+30 ammeter and 7-17 volt dual indicator instruments which looks exactly like their newer model with your scale of 10-15 volts and 'loadmeter' 0 to 100%. What I have has the internal circuitry for the expanded scale, and I would expect that their new unit does, too. (They sell these units for use in boats and cars as well as airplanes) If so, the external circuit board, which is far more flexible and can be calibrated, would not work with their newer unit. We need to talk to them about making the unit without the expanded scale circuitry. Drat--I already ordered my meter from them, and it will probably have the internal expanded scale circuitry. Is there a reasonable way to open up these meters to make direct connection? Jim Foerster ________________________________________________________________________________
Date: Oct 24, 2002
Valve > >In a message dated 10/24/02 9:51:45 AM Central Daylight Time, >bob.nuckolls(at)cox.net writes: > > > I wish it were so simple/logical. > >Golly Bob, I still think it is simple and logical. All it requires is that >you understand the engines fuel delivery system. Didn't disagree with anything you said . . . the "illogical" condition I cited was the presence of a hand operated primer in a certified airplane that left the factory with a fuel-injected engine in it. Bob . . . ________________________________________________________________________________
Subject: Suggested wiring circuits.
Date: Oct 24, 2002
Bob, Why have the voltmeter reading voltage from the essential bus after the diode rather than from the battery bus? Thanks as always for enlightenment. Rob Rob W M Shipley. RV9A fuselage. N919RV resvd. ________________________________________________________________________________
Date: Oct 24, 2002
> > >Bob, > If the Westach instrument calibration is not good enough so that you > used a linear 'bare' movement, then the unit they are selling now, with > the expanded scale components already in the meter case, won't work with > your board. I already have one of their -30-0+30 ammeter and 7-17 volt > dual indicator instruments which looks exactly like their newer model > with your scale of 10-15 volts and 'loadmeter' 0 to 100%. What I have > has the internal circuitry for the expanded scale, and I would expect > that their new unit does, too. Have you seen any specifications for the instrument or did they specifically tell you that it was a stand-alone instrument? > (They sell these units for use in boats and cars as well as > airplanes) If so, the external circuit board, which is far more flexible > and can be calibrated, would not work with their newer unit. We need to > talk to them about making the unit without the expanded scale > circuitry. Drat--I already ordered my meter from them, and it will > probably have the internal expanded scale circuitry. Is there a > reasonable way to open up these meters to make direct ! >connection? I'm lost. I guess we're not talking about the same beast at all. Yes, Westach makes dual pointer instruments with a 7-17 expanded scale, stand-alone voltmeter -AND- a minus-zero-plus ammeter in either 30 or 60 amp full scale ranges. Got one on my bench right now getting torn down for failure analysis. One of our members here on the list let all the smoke out of the second instrument in a row. Need to figure out how and why. Some folks mentioned that the instrument I specified for my VM/LM product was now being offered by Westach and featured in their what's new page at http://www.westach.com/whatsnew.htm This is pretty close to what I was buying from them EXCEPT the normal and battery only operating voltage arcs are the wrong color. I was unable to find any further description of the instrument shown so I don't know if they've gone to the trouble to add their own voltmeter scaling circuitry inside or if the instrument is truly a mis-painted clone of what I originally purchased. Have you had any conversation with them about their newest offering? Suggest you sent a copy of the 9021-200-2 drawing to them and ask if what you're getting meets those specifications. If the instrument IS to that drawing, then we need to talk about whether or not you wish or intend to clone the product I offered. If so, then you'll find all the data necessary to accomplish this task posted as cited earlier. If not, then you're free to deduce any other interface for the instrument you wish. If the Westach offering is NOT equal to the 9021-200-2 instrument, then cloning my original design is no longer an issue. I'm not favorably impressed with the Westach technique for scaling their expanded scale voltmeters . . . I wanted an instrument that could be externally calibrated to compensate for manufacturing variations and ageing effects. This is why I chose the route illustrated in the data package. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
voltage > > One thing I'm not sure you understand about the instrument as-supplied > by Westach is that the expanded scale voltmeter side of the instrument > is not stand-alone. Westach's offerings at expanded scale instruments > were not up to the requirements I placed on my design so I ordered > only basic meter movements in the instrument (see specification > control drawing for 9021-200-2) and accomplished calibration and > scaling on the etched circuit board. Yo Bob: I think that there are enough of us out here in homebuilt land that had planned to use your unit to make it worthwhile offering it again. I designed it into my panel / electrical scheme a couple of years ago and was really disappointed when you discontinued it. Whacha think? -- John ________________________________________________________________________________
From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Battery Management Module
Date: Oct 24, 2002
Bob, The time has come for me to order all the necessary bits and pieces for the Big Wiring. I'd like to order a low voltage/battery management module for our 2 battery project. But I'm afraid I was unable to locate it on your site. May I ask you how I could place an order for this item, along with other pieces of equipment ? thanks in advance, Gilles Thesee MCR4S structure complete ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Fuel Boost or Prime Pumps?
AeroElectric-List message previously posted by: Gary Liming "Hi OC, and others who responded. I left out 'valve' in the first post, sorry. I guess I didn't make myself too clear - let me rephrase the question: I see type cert planes with both boost pump switches and manual (plunger type) primers - Why? I suspect they had a good reason to do that, but I don't see it. Just making sure I am not missing something.Gary Liming" 10/24/2002 Hello Gary, It boils down to the meaning of words, the engine design, and the details of how the fuel system is plumbed. In the case you describe above the aircraft designer / builder felt that he needed an electrically driven fuel boost pump to back up the engine driven fuel pump. But that electrically driven fuel boost pump was not plumbed into the engine priming system in any fashion so the designer / builder also needed a manual priming pump. Things can get a bit confusing as there can be some various combinations and permutations involved. Procedures could call for the electrically driven fuel boost pump to be on during engine cranking, but that doesn't automatically make it into a priming pump. Why did the engine designer / builder include an electrically driven fuel boost pump in his design? Maybe he was concerned with the engine driven fuel pump failing at some point and then the electrically driven fuel boost pump would suppy enough fuel to allow the airplane to be flown safely to a landing point chosen by the pilot. The most critical "some point" that the designer had in mind may have been in the takeoff / landing pattern where the pilot would have little time to react. So why not just have the electrically driven fuel boost pump on at all times in the takeoff / landing pattern? Well it is very possible that if this electrically driven fuel boost pump can supply enough fuel to operate the engine all by itself then when both the engine driven pump and the electrically driven pump are operating the engine may get drowned and quit operating. How to solve that problem? One solution is to have a two stage (high output and low output) electrically driven fuel boost pump. Then the procedure is to operate the electrically driven fuel boost pump in the low output stage at all times in the takeoff / landing pattern so that if the engine driven fuel pump fails at that critical time the engine will still keep running at a lower power setting long enough for the pilot to select the high output stage from the electrically driven fuel boost pump and then fly the airplane safely. There can be other variations on the theme of what constitutes a well designed system and what constitutes acceptable operating procedures (both from a mechanical and from an ergonomic viewpoint). So the precise meaning of words in connection with fuel pumps (valve, boost, prime, transfer*), the type of engine fuel induction system (cabureted or injected), and the plumbing of the fuel system are all critical elements in understanding the design and operating procedures of an aircraft's fuel system. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? *PS: I once listened to a 10 minute conversation that I was not participating in where some of the participants were talking about fuel transfer pumps (that move fuel from tank to tank) and some of the participants were talking about fuel boost pumps. All participants were using just the term "fuel pump" and the conversation was chaotic and useless because of the sloppy terminology. ________________________________________________________________________________
Date: Oct 24, 2002
In a message dated 10/24/02 1:27:57 PM Central Daylight Time, bob.nuckolls(at)cox.net writes: > Didn't disagree with anything you said . . . the "illogical" > condition I cited was the presence of a hand operated primer > in a certified airplane that left the factory with a fuel-injected > engine in it. > > Bob . . . > I agree! It would be nice to know what they had in mind! Happy Skies, Old Bob ________________________________________________________________________________
Subject: buying Radio's
Date: Oct 24, 2002
I am building a Lancair ES and want to put a Garmin or Appolo stack into my plane. I also want to do the wiring. Both companies have a policy that these parts need to be dealer installed. How does everyone get around this problem? Ron Raby N829R ________________________________________________________________________________
Date: Oct 24, 2002
When wiring and ECU: > Use a fuse from the e-bus . . . fusible links are special > case, single feed protection where very high reliablity > is desired and faulting that line has no chance of > precipitating problems into the rest of the system. Not sure I understand this. Surely, the ECU has the highest possible reliability requirements. By the way, this ECU (from RWS aka Tracy Crook) has two feed pins and two independant computers. Apparantly there is a common component inside which limits the redundancy. I'm not sure why. > If it were my airplane, I'd wire all devices > needed to support engine operation from battery > busses. If I have smoke in the cockpit, all DC > PWR MASTER switches can go to OFF and the engine > will continue to run. Of course. I should have known that. BTW - My multi-meter is on the way back. Regards, John Slade Adding the multi dimension control wheels to my panel as we speak. ________________________________________________________________________________
Subject: Re: buying Radio's
Date: Oct 24, 2002
Ron Raby wrote: > > > I am building a Lancair ES and want to put a Garmin or Appolo stack into > my plane. I also want to do the wiring. Both companies have a policy that > these parts need to be dealer installed. How does everyone get around this > problem? > *** I installed a GNS430 in my Sundowner. I got around Garmin's policy by having the selling shop fabricate me a harness for the radio. Then they went on record as the "installing shop". - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 24, 2002
"Robert L. Nuckolls, III" wrote: > Should the engine suffer fuel starvation due to > any sort of discontinuity in the normal fuel > delivery system, one can pull the mixture to idle > cutoff, turn on the primer system and adjust the > throttle (now a mixture control) for smoothest > running engine. Reminds me of a story I read as a young'n about a P-51 pilot whose fuel pump was rendered inop by hostile fire- he nursed it all the way back to merry old England using the primer alone- story said his hand was worn to the bone but he saved his Mustang AND his bacon. Remembering the story, I've often wondered if this may be a feasible backup for a Lyc on a homebuilt, even if plumbed to only 3 cylinders, drawing from the gascolator, bypassing both pumps plus the carb- I picture a firewall-mounted manual pump with an actuator rod extending rearward to within sweating pilots reach- probably won't get much ROC, but maybe the prop wouldn't get visible either. Plus you'd sound like a LeRhone (sp?) rotary as you made the field (silence/pump/brrrrrrump!-silence/pump/brrrrrrump!) Any thoughts? Mark Phillips ________________________________________________________________________________
Date: Oct 24, 2002
Ron: I just bought a Garman stack: Aud/Com 340, GNS-530, GNS-430, and Transponder GTX327. Lancair will allow you to install your own, but Garman pushes to do the harness, then allows you to slide it in and apply your own power sources. I checked around from several sources, and prices varied from 24-29K. I was lucky and got the whole stack for 18,133.00. They did my wire harness for 500.00. This included the wiring between units, i.e. the com panel as well as the wiring between the GNS's. Other leads that will be labeled will be the 4 headset sets, and the leads for power. Believe me the 500.00 is well worth the money, as it will take them 45 days to do. Just had a friend buy a GNS-530 for his Seneca, paid 13K for it plus 2000.00 for installation. All I will have to do is slide it in, connect the antenna, headset jacks, and decide as per Bob's schematic planning as to where each radio gets its power. I will be going what I call a partial EFIS, EFIS/Lite from BMA; so I will have to buy the Garman 106a so I can display, vor, loc, ILS, and GPS tracking. I am beginning to cut/paste instruments pictures on my panel for layout. I will admit, I am little biased, my Lancair ES will look something like the A300 I fly for FedEx. Don't want to make things to confusing, a little standardization won't hurt. Of all the manufacturer's, Garman has been the best to work with when coming to home builts, as far as performance, Appolo I hear is a good choice. Regards, Ed Silvanic Lancair ES N823MS ________________________________________________________________________________
Subject: Re: Starter-engaged Warning
Date: Oct 24, 2002
Bob, Thanks for the excellent explanation of the real purpose of a starter engagement warning light. I sometimes think us airplane types just like lots of knobs and pretty lights. Mark Quoting "Robert L. Nuckolls, III" : > > > > > >Ed, > >You're one of the few that are actually flying. So, can you hear your > > >starter > >with the engine running? Or does your headset/exhaust drown out all > other > >sounds? If you can hear the starter whirring away do you really need a > > >warning > >light to tell you that? > >Mark > > > A bit of history might help here. In the certified world, there > are many instances of stuck starter contactors wherein the > pilot was unaware of the event and damage was done. > > MOST of these events were on lower priced single engine aircraft > using contactors not well suited for starter control service . . . > we won't go into naming names here. Of course, conventional > wisdom in the certified world was not to make it easy to > improve on the suitability of the contactor by (ughhh!) > putting an AUTOMOTIVE device on in place of the junk . . . > "I know, let's put a light on the panel to tell the pilot > when the contactor sticks! > > It's easier to add a Band-Aid to a certified ship than > it is to fix a problem. > > In our airplanes, we're using very robust starter > contactors so the likelihood of this happening is > at least an order of magnitude lower . . . but again, > it is not zero. > > This begs the question, "Will we hear the results of > this event and shut things down in time to prevent severe > damage?" It also begs the question, "Will we always > keep an eye on the light to make sure it goes out > when the starter button is released?" > > We can debate the merits of adding this feature for > days but it won't change the facts . . . the chances > of a stuck contactor are not zero, the chances of > being distracted and being unaware of the event > are not zero, and the chances of a warning light > going unnoticed are not zero either. > > Bottom line is that the vast majority of light > singles do not have this light and in the grand > scheme of things, the certified stuff wears out > or breaks far more often than they are destroyed > by stuck contactors. It's a real toss up. I probably > wouldn't put one on my airplane unless it was included > in an annunciator array that shows lots of other > good things to know and is certain to be observed > more often than some lowly light tucked away somewhere > on the panel like the certified ships. > > Bob . . . > > > > > > > ________________________________________________________________________________
Date: Oct 24, 2002
In a message dated 10/24/02 3:45:37 PM Central Daylight Time, ripsteel(at)edge.net writes: > Remembering the story, I've often wondered if this may be a feasible backup > for a Lyc on a > homebuilt, even if plumbed to only 3 cylinders, drawing from the > gascolator, bypassing both > pumps plus the carb- I picture a firewall-mounted manual pump with an > actuator rod extending > rearward to within sweating pilots reach- probably won't get much ROC, Good Afternoon Mark, Since it appears to be war story time------- About fifty years ago, a friend of mine had an engine failure in his Cessna 170 that was caused by a plugged gascolator screen. After that, he added a T fitting where the fuel line came out of the left fuel tank. He ran that to a small needle valve (the type used to adjust the vacuum for the T&B). From the needle valve he ran it to a small fitting which he had added just at the outflow of the float type carburetor. (He put it in the carburetor body mainly because that was the easiest place to drill a hole and run a tap.) He could shut off the fuel valve, open the needle valve and adjust the fuel to match whatever amount of air was coming through the carburetor. By adjusting both the throttle and the needle valve, anything from full power to idle was possible. Obviously, that will only work on a high wing airplane. On a low wing airplane, you would need a pump of some kind. Electric would be nice, but a hand operated wobble pump is doable. Any of the common old style hand operated fuel pumps would be easier to use than a standard primer. There have been many cases of folks getting an airplane home on primers. Fact is, the Continental Fuel injection system is really not much more than a continuous primer with the fuel mechanically adjusted to provide the proper mix. Unlike the fancier fuel injection systems, such as the PS5C, or the float type carburetors, the throttle body does not measure the airflow at all. There is no balance of pressures or vacuum used at all. I could be wrong, but I think the Continental folks developed their simple system after they noted how many people had managed to get it home on the primer alone. More than one way to skin a cat. As to using the hand wobble pump to keep the airplane airborne, I had an engine pump fail on takeoff in a Bonanza about fifty years ago. It wasn't particularly difficult to keep it running, but it doesn't allow you to do much else in the cockpit. I purchased a standby electric pump to augment the wobble pump as soon as they were made available. Happy Skies, Old Bob ________________________________________________________________________________
Subject: Flap switch
Date: Oct 24, 2002
A few months ago there was a discussion of "set and forget" flap switches that would move the flaps to a pre-set position and stop. I see Van's now has such a switch for RV's. $200.00 http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1035492734-228-216&bro wse=new&product=fps Terry ________________________________________________________________________________
Date: Oct 24, 2002
Ok. So where did you purchase the radios at such a good price? Ron Smith N566U RV8A ________________________________________________________________________________
Date: Oct 24, 2002
Bob, it looks like I will be replicating your original system-which is what I had planned to do in the first place. I'm encouraged to hear that you will be opening up the Westach meter. Looks like I can do the same, replace the faceplate with that terrific meter scale faceplate that you posted, and make direct connection to the meter movement. I'll be happy to build the PC board, and thanks for all the help with this topic. Jim Foerster ________________________________________________________________________________
Date: Oct 24, 2002
> > > > > One thing I'm not sure you understand about the instrument as-supplied > > by Westach is that the expanded scale voltmeter side of the instrument > > is not stand-alone. Westach's offerings at expanded scale instruments > > were not up to the requirements I placed on my design so I ordered > > only basic meter movements in the instrument (see specification > > control drawing for 9021-200-2) and accomplished calibration and > > scaling on the etched circuit board. > >Yo Bob: > >I think that there are enough of us out here in homebuilt land that >had planned to use your unit to make it worthwhile offering it again. > >I designed it into my panel / electrical scheme a couple of years ago >and was really disappointed when you discontinued it. >Whacha think? It's not going to rise from the ashes in our shop. Someone mentioned that Westach was "offering the same instrument" I used to sell. I'll e-mail a copy of the drawing to them and see if this is indeed the case. When I first read that, I was thinking that it would be relatively easy for folks to roll their own based on the data package and artwork I published. I see now how we may have got our signals crossed. I suspect they've added standalone expanded scale voltmeter circuitry . . . external signal conditioners are not generally in their bag of tricks. Maybe I should give them a link to the data package and see if they would want to pick the product up or do their own version. I'll explore that. Bob . . . ________________________________________________________________________________
Subject: system
Date: Oct 24, 2002
Bob, Haven't heard from you for a couple days on the system design exercise we were working on on the list. Obviously, I'm anxious to move forward. I'm not trying to be pushy, but would you mind taking a look at my responses to you and advise me? I've basically decided that your method/advice is what I want to follow (chosen from all the advice out there, ie Lancair, other builders, etc), so until I get some of your great words of wisdom on my project, I'm pretty much in total limbo :) With my project moving half way across the US in just over a week for finish bodywork and paint, limbo is not a good place for me to be, LOL :) Let me know what you come up with. Thanks, as always, for your patience and willingness to educate. --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 24, 2002
Ron, Contact John Stark at: Stark Avionics, Hangar 12, Columbus Metro Airport,Columbus, GA 31909, Phone (706) 324-3770 or 321-1008; email:jts7(at)starband.net. He sells Garmin and Apollo at significant discount. Richard Dudley Ron Raby wrote: > > > I am building a Lancair ES and want to put a Garmin or Appolo stack into my plane. I also want to do the wiring. Both companies have a policy that these parts need to be dealer installed. How does everyone get around this problem? > > Ron Raby > > N829R > ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Voltmeter/Loadmeter project
> > >Bob, it looks like I will be replicating your original system-which is what >I had planned to do in the first place. I'm encouraged to hear that you >will be opening up the Westach meter. The one I am opening is toast. Also, to open these up you have to drill off some tubular rivet tops . . . no really good way to put them back together. Go look at the photos in http://www.aeroelectric.com/temp/Westach >Looks like I can do the same, replace >the faceplate with that terrific meter scale faceplate that you posted, and >make direct connection to the meter movement. I'll be happy to build the PC >board, and thanks for all the help with this topic. Look at http://216.55.140.222/temp/Westach/Westach4.jpg This face plate looks like it may have been mounted before the meter movements were installed cause the needles thread through from opposite sides. If you took those four screws out, do you think you could get the faceplace past the needles without whacking them? I've made LOTS of new faceplates for meters in the past 30 years with the first ones laid out in ink, lettered with Leroy pens and then shot down photographically. Last week I did one in AutoCAD and pasted a laser print right to the scale plate. I don't think I'd tackle one of these things in my shop. Let's see if (1) Westach is interested in taking on the whole product and (2) what a plug-n-play instrument would cost. I wrote them a few minutes ago and forwarded the data package to them. Let's see what they say. Bob . . . ________________________________________________________________________________
From: "Francis, CMDR David" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - LOAD ANALYSIS
Date: Oct 25, 2002
Bob and friends, I have been following the load analysis thread and have done my own, and it is very informative. I am building a RV7 for IFR. The comm/nav radios are included in the two EFIS. I have been undecided between Z12 and Z14. The analysis clarified the decision. Assume Jabiru engine with 20-25 amp alternator plus 40 amp B&C, 2 x batteries. Bus nomenclature is as per Z14, ie. main bus is essential bus. Where there is no value of amperage I either dont know yet or its an intermittent load. This analysis tells me that pitot heat and landing lights need to be used sparingly in some situations like night circuits, IFR approaches, main alternator out. Z14 gives me the best headroom in the worst situations (cruise in cold cloud, night circuits), because I can operate both alternators together, but it is more complex than a modified A12. Either way the standby alternator is heavily loaded when the main one is dead. Appreciate any comments. David Francis, Canberra, Australia <<...OLE_Obj...>> Email: David.Francis(at)cbr.defence.gov.au ________________________________________________________________________________
Date: Oct 24, 2002
> >When wiring and ECU: > > Use a fuse from the e-bus . . . fusible links are special > > case, single feed protection where very high reliablity > > is desired and faulting that line has no chance of > > precipitating problems into the rest of the system. >Not sure I understand this. Surely, the ECU has the highest possible >reliability requirements. You don't want to tie onto the e-bus with a fusible link where the diode normal feedpath and alternate feedpaths are not designed to cleanly open a fusible link. If you use a fusible link in the ECU power path, it should tie right to the battery (+) side of the battery contactor. If you choose to run the ECU from the e-bus, use a breaker or fuse like the rest of the current protection on the bus. >By the way, this ECU (from RWS aka Tracy Crook) has two feed pins and two >independant computers. Apparantly there is a common component inside which >limits the redundancy. I'm not sure why. > > > If it were my airplane, I'd wire all devices > > needed to support engine operation from battery > > busses. If I have smoke in the cockpit, all DC > > PWR MASTER switches can go to OFF and the engine > > will continue to run. What do you mean by two feed pins? Are these separate power inputs for each half of a redundant system? >Of course. I should have known that. > >BTW - My multi-meter is on the way back. Got it today. It's sick. Will talk to Todd at B&C about it tomorrow. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
> >In a message dated 10/24/02 3:45:37 PM Central Daylight Time, >ripsteel(at)edge.net writes: > > > Remembering the story, I've often wondered if this may be a feasible > backup > > for a Lyc on a > > homebuilt, even if plumbed to only 3 cylinders, drawing from the > > gascolator, bypassing both > > pumps plus the carb- I picture a firewall-mounted manual pump with an > > actuator rod extending > > rearward to within sweating pilots reach- probably won't get much ROC, > >Good Afternoon Mark, > >Since it appears to be war story time------- > >About fifty years ago, a friend of mine had an engine failure in his Cessna >170 that was caused by a plugged gascolator screen. > >After that, he added a T fitting where the fuel line came out of the left >fuel tank. He ran that to a small needle valve (the type used to adjust the >vacuum for the T&B). From the needle valve he ran it to a small fitting >which he had added just at the outflow of the float type carburetor. (He put >it in the carburetor body mainly because that was the easiest place to drill >a hole and run a tap.) > > >There have been many cases of folks getting an airplane home on primers. >Fact is, the Continental Fuel injection system is really not much more than a >continuous primer with the fuel mechanically adjusted to provide the proper >mix. Unlike the fancier fuel injection systems, such as the PS5C, or the >float type carburetors, the throttle body does not measure the airflow at >all. There is no balance of pressures or vacuum used at all. > >I could be wrong, but I think the Continental folks developed their simple >system after they noted how many people had managed to get it home on the >primer alone. > >More than one way to skin a cat. At my last weekend seminar I talked to a builder about this system: See: http://216.55.140.222/temp/NoValve.gif He plans to put optical low fuel warning light sensors in each tank at the 5 gal usable point. Another optical sensor in the right tank at 1/2 full will trigger the transfer pump to move fuel from the left tank maintaining the right tank at half full until the left tank's low fuel warning light comes on. Auto transfer is stopped at that point which leaves 5gal in left tank as reserve. When low fuel light comes on in right tank, the transfer optionally resumes to maintain fuel in the right tank at 5 gal until after the left tank is exhausted. If the transfer and/or main delivery scheme becomes disabled for any reason, the nurse-it-down-on-the- primer option is available for not less than 5 gal of capacity for all but the last hour of flight. Three switches. Three solid state pumps. Three level sensors and a handful of electronics parts. No valves and no fittings in the cabin where people sit. Bob . . . ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: system
> > >Bob, > >Haven't heard from you for a couple days on the system design exercise >we were working on on the list. Obviously, I'm anxious to move forward. >I'm not trying to be pushy, but would you mind taking a look at my >responses to you and advise me? I've basically decided that your >method/advice is what I want to follow (chosen from all the advice out >there, ie Lancair, other builders, etc), so until I get some of your >great words of wisdom on my project, I'm pretty much in total limbo :) Sorry. I've been nose-to-the-stone on a RAC project. Need to get a spin-chute controller tested and installed in a Premier by Sunday. Haven't been able to spend as much time on e-mail as usual. >With my project moving half way across the US in just over a week for >finish bodywork and paint, limbo is not a good place for me to be, LOL >:) Let me know what you come up with. Thanks, as always, for your >patience and willingness to educate. We're all learn'n here . . . Consider upsizing the main alternator to 90A. This would take care of your headroom problems on the main bus. If you upsized the aux alternator, then we'd have to move some main-bus loads to the aux bus and I'd rather keep the aux bus as clean as possible. >--- >Shannon Knoepflein <---> kycshann(at)kyol.net > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 24, 2002
Subject: Re: Shannon's Lancair
> > >Bob, > >Haven't heard from you for a couple days on the system design exercise >we were working on on the list. Obviously, I'm anxious to move forward. >I'm not trying to be pushy, but would you mind taking a look at my >responses to you and advise me? I've basically decided that your >method/advice is what I want to follow (chosen from all the advice out >there, ie Lancair, other builders, etc), so until I get some of your >great words of wisdom on my project, I'm pretty much in total limbo :) Sorry. I've been nose-to-the-stone on a RAC project. Need to get a spin-chute controller tested and installed in a Premier by Sunday. Haven't been able to spend as much time on e-mail as usual. >With my project moving half way across the US in just over a week for >finish bodywork and paint, limbo is not a good place for me to be, LOL >:) Let me know what you come up with. Thanks, as always, for your >patience and willingness to educate. We're all learn'n here . . . Consider upsizing the main alternator to 90A. This would take care of your headroom problems on the main bus. If you upsized the aux alternator, then we'd have to move some main-bus loads to the aux bus and I'd rather keep the aux bus as clean as possible. OOPS! Hit the send button accidently again. Here's a sketch of the rear batteries version of Z-14 http://216.55.140.222/temp/DB-DA_PDD.gif We'll have to figure out a way to do some heavy duty battery bus distribution near the batteries on the main battery side to accommodate the ANL's for hydraulics and a/c compressor. Adding a ground bus adjacent to the batteries gives us a place to tie all those fat wires together for ground feeder, battery minus leads and the big motors. You could also ground strobe supply and nav lights back there. With the cross-feed up on the firewall, I think you can see how it becomes the distribution point for fat wires to fan out to the panel and things on the engine. I think I'll do an alternative figure Z-14 for the next revision to show exactly this situation. Let's continue to refine the spread sheet. You'll need to get "hard" numbers from suppliers for those currents in doubt. I think you should plan to MEASURE each of these when the airplane is finished just to make sure the analysis is complete and accurate. If you upsize the main alternator, I think you'll be in good shape. You spoke about adding some heat hot patch on windshield? hot prop? You've got a 40A budget for these things since the a/c and fan will never run during heating season. I'll try to get a look at the latest spread sheet but can't spend too much more time on it tonight. Bob . . . >--- >Shannon Knoepflein <---> kycshann(at)kyol.net > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 24, 2002
In a message dated 10/24/02 10:06:33 PM Central Daylight Time, bob.nuckolls(at)cox.net writes: > Three switches. Three solid state pumps. Three > level sensors and a handful of electronics parts. > No valves and no fittings in the cabin where people > sit. > > Bob . . . > Good Evening Bob, Very Interesting! May I assume this is on a low wing airplane? I guess all the electricity and such scares me a bit, but then, isn't this whole site about having a good sound electrical system? I still think I might consider adding one of those nice little hand wobble pumps that were so ubiquitous back in WWII. And I am the guy who doesn't want to add an ounce of unnecessary weight! Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 25, 2002
> You don't want to tie onto the e-bus with a fusible link > where the diode normal feedpath and alternate feedpaths > are not designed to cleanly open a fusible link. You lost me here. Not hard to do. > If you use a fusible link in the ECU power path, it should > tie right to the battery (+) side of the battery contactor. > If you choose to run the ECU from the e-bus, use a breaker > or fuse like the rest of the current protection on the bus. Tracy recommends no fuse, so maybe direct to the AUX battery is best. > What do you mean by two feed pins? Are these separate > power inputs for each half of a redundant system? I wish. Unfortunately, Tracy tells me, they both go the same point inside. Perhaps its designed for yet to be installed total redundancy. > Got it today. It's sick. Will talk to Todd > at B&C about it tomorrow. Thanks. I'm confused enough without any help from bad meter readings. John Slade ________________________________________________________________________________
Subject: Re: Electric Solenoid Engine Primer Valve
Date: Oct 25, 2002
> He plans to put optical low fuel warning light sensors in... Anyone know where I can get these? John Slade ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Date: Oct 25, 2002
> > Install a 4-port primer system feed by an electric > valve downstream of an electric pump. Put a needle > valve in the primer line and calibrate primer fuel > flow for 55 to 65% power fuel flows for your > particular engine. The primer can be used for its > obvious function in pre-flight. > Hello Bob, that is my intention to do, however I have to tee in a fuel pump for that as my highwing Glastar has no such setup (fuel boost pump) planned, I intend to do that at the gascolator primer port. Question, concerning fuel pump and valve, do you know of anybody selling such parts? Do I also need the valve, as I could go directly for a blocking primer pump?. Many thanks for your help Werner ________________________________________________________________________________
Date: Oct 25, 2002
http://www.ppavionics.com/products.htm They sell it have them in my header tanks for my glastar, work great! Werner ----- Original Message ----- From: "John Slade" <sladerj(at)bellsouth.net> Subject: RE: AeroElectric-List: Re: Electric Solenoid Engine Primer Valve > > > He plans to put optical low fuel warning light sensors in... > Anyone know where I can get these? > John Slade > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 25, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> >In a message dated 10/24/02 10:06:33 PM Central Daylight Time, >bob.nuckolls(at)cox.net writes: > > > Three switches. Three solid state pumps. Three > > level sensors and a handful of electronics parts. > > No valves and no fittings in the cabin where people > > sit. > > > > Bob . . . > > > >Good Evening Bob, > >Very Interesting! > >May I assume this is on a low wing airplane? Yeah. Long-Ez >I guess all the electricity and such scares me a bit, but then, isn't this >whole site about having a good sound electrical system? Yup >I still think I might consider adding one of those nice little hand wobble >pumps that were so ubiquitous back in WWII. And I am the guy who doesn't >want to add an ounce of unnecessary weight! Saw one in a junk box out at RAC a few years back. I think it was the one used in early Bonanzas. Probably just needs o-rings. Interested? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 25, 2002
> > > You don't want to tie onto the e-bus with a fusible link > > where the diode normal feedpath and alternate feedpaths > > are not designed to cleanly open a fusible link. >You lost me here. Not hard to do. See http://216.55.140.222/temp/NoFLink.gif You mentioned tying one of the feeds to your ECU through a fusible link to the e-bus . . . the sketch shows how this is a bad deal. > > If you use a fusible link in the ECU power path, it should > > tie right to the battery (+) side of the battery contactor. > > If you choose to run the ECU from the e-bus, use a breaker > > or fuse like the rest of the current protection on the bus. >Tracy recommends no fuse, so maybe direct to the AUX battery is best. That is essentially what the fusible link to the aux battery does for you. VERY reliable but still keeps that wire from toasting its entire length and taking other wires with it. > > What do you mean by two feed pins? Are these separate > > power inputs for each half of a redundant system? >I wish. Unfortunately, Tracy tells me, they both go the same point inside. >Perhaps its designed for yet to be installed total redundancy. Have him give drop me a note. If there is some desire on his part to effect separate functionality schemes to provide some sort of back up, I'd be pleased to help him with it. The point I was offering in our discussions was that (1) given the easily implemented philosophy for battery maintenance, we'll never suffer an unusable battery and (2) the aux battery is backed up by the main battery by simply turning the master switches back on that there was no value in making the ECU power control switch select from one of two different power sources. This was especially significant given the relative complexities of the ECU itself, worrying about redundant power sources approaching the reliability of wing attach bolts was something of an overkill. Now, if Tracy has a scheme for building independent circuits internal to his product, either one of which will run the engine, THEN supplying these from separate sources begins to make some sense. Bob . . . ________________________________________________________________________________
Date: Oct 25, 2002
> > >http://www.ppavionics.com/products.htm > >They sell it have them in my header tanks for my glastar, work great! The principal upon which these things function was first brought to my attention when I was about 16 years old. Delco batteries were fitted with a special battery cap called "The Delco Eye" . . . it was simply a piece of plastic rod, cut to a 90-degree cone on the far end an mounted to a filler cap. If battery water was low, ambient light entering the cap end of the rod was reflected back causing the cap's center to appear bright - meaning add water. When submerged in liquid, the center was black. I built some sensors using photocells and light bulbs to do some fuel sloshing studies in a Baron about 25 years ago. A few years later, we used the same principal to design and fabricate a whole line of low-liquid level sensors at Electro-Mech that are now used in dozens of places on RAC products. It's solid, no-moving parts, dead-nuts calibration for alerting one to levels in a tank. Bob . . . ________________________________________________________________________________
Date: Oct 25, 2002
Subject: Electric Solenoid Engine Primer Valve
> > > > > > Install a 4-port primer system feed by an electric > > valve downstream of an electric pump. Put a needle > > valve in the primer line and calibrate primer fuel > > flow for 55 to 65% power fuel flows for your > > particular engine. The primer can be used for its > > obvious function in pre-flight. > > >Hello Bob, > >that is my intention to do, however I have to tee in a fuel pump for that >as my highwing Glastar has no such setup (fuel boost pump) planned, I intend >to do that at the gascolator primer port. Question, concerning fuel pump and >valve, do you know of anybody selling such parts? Do I also need the valve, >as I could go directly for a blocking primer pump?. The Fawcet pumps are in-expensive but I think they use reed valves and will free flow if pressurized on the inlet end. You would need the solenoid valve too. ACS has both. You'll also need a needle valve to calibrate the primer fuel flow. These are a pretty common plumbing part in brass. Bob . . . ________________________________________________________________________________
Date: Oct 25, 2002
Subject: Re: Suggested wiring circuits.
> >Bob, >Why have the voltmeter reading voltage from the essential bus after the >diode rather than from the battery bus? >Thanks as always for enlightenment. Depending on your meter, it may draw some small but significant amount of power that would run the battery down if fed from the battery bus. If one want's to steer around doing the mental math of adding diode drop to the reading to know bus voltage, just flip the e-bus alternate feed switch on for a moment. Bob . . . ________________________________________________________________________________
Subject: RE: Z-11a, Single ECU
Date: Oct 25, 2002
> See http://216.55.140.222/temp/NoFLink.gif > a fusible link to the e-bus . . . the sketch shows how this is a bad deal. Thank you. That turned the light on. Obvious when you think about it. Tracy's email is tcrook(at)rotaryaviation.com I'll forward you're note on to him. John Slade ________________________________________________________________________________
Date: Oct 25, 2002
In a message dated 10/25/02 7:36:43 AM Central Daylight Time, bob.nuckolls(at)cox.net writes: > Saw one in a junk box out at RAC a few years back. I think > it was the one used in early Bonanzas. Probably just needs > o-rings. Interested? > > Bob . . . > Good Morning Bob, There is undoubtedly someone with an early Bonanza who would like to have one of those. As you are undoubtedly already aware, The Bonanza hand wobble pumps went through many iterations during the days they were used on production aircraft. All of them were incorporated in a single unit which combined the function of fuel selector valve, fuel strainer and fuel pump in one casting. Very light weight and reduced labor to install. Neat design. Unfortunately, problems surfaced. The handle was on top and was used to pump vertically. It was not the best ergonomic position for pumping. Rotating the handle would change the tank selection. It occasionally happened that the operator would unintentionally rotate the selector valve while pumping for fuel pressure. Sometimes so much that the engine would quit. Also, on the very early ones, sideward loads on the shaft, while pumping, would bend, or even break, the vertical shaft. Beech added a tower to stiffen the structure and changed the tank selection feature such that the handle would only serve to switch tanks when in the very bottom position. They did that by having it sit in a notch when all the way down. You guessed it, they then had trouble with the folks not being able to find the notch when they wanted to switch tanks. On the first ones few iterations, it was possible to put the handle on the shaft in two positions, one hundred and eighty degrees apart. This meant that one would be burning from the left when he/she thought they were on the right. Beech's fix was to issue a Service Letter advising folks to drill and tap the shaft on just one side so that the handle would always be put back on in the correct orientation, provided that the small indexing screw was always replaced. Unfortunately, it wasn't made clear what orientation the valve and handle should be in when the modification was made. That resulted in a situation such that if a unit was installed that had the indexing hole on the opposite side of the shaft from one which had been done the other way, the handle would still point to the wrong tank even when the indexing screw was installed. Actually happened to me once upon a time. The end result of all theses problems was that Beech finally separated the fuel pump function from the valve selection function. They were all still in the same casting, but the pump action used a nice, much more ergonomically correct, stroke on a separate handle that operated the pump through a linkage arrangement. They added a direct and very ordinary fuel selector to the valve. I believe that arrangement was first used on the C35. It stayed in production until the last of the E-series engine equipped aircraft. If the one that you saw was one of those lever operated combination units, please latch onto it and let some of the folks operating older Bonanzas know about it. That lever operated one is a very nice unit. The earlier ones are of interest primarily to those who like to be able to restore antiques to their original configuration. The wobble pump that I would use, if I were to want a manually operated pump, would be one of those which has no function other than being a fuel pump. They were round. Looked about like a large Tuna can. The shaft went into one flat side of the can and the wobbling motion was very comfortable. I believe it was used on the early Beech 18s as well as many other aircraft of the day. It was easy to pump and by controlling the rate of the stroke, fuel pressure could be maintained quite close to the desired number. It was not at all a frantic style effort. Sorry about the rambling. I'll try to stick to electrical stuff from now on! Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 25, 2002
Subject: Re: wobble pumps
> >In a message dated 10/25/02 7:36:43 AM Central Daylight Time, >bob.nuckolls(at)cox.net writes: > > > Saw one in a junk box out at RAC a few years back. I think > > it was the one used in early Bonanzas. Probably just needs > > o-rings. Interested? > > > > Bob . . . > > > >Good Morning Bob, > >There is undoubtedly someone with an early Bonanza who would like to have one >of those. >The wobble pump that I would use, if I were to want a manually operated pump, >would be one of those which has no function other than being a fuel pump. >They were round. Looked about like a large Tuna can. The shaft went into >one flat side of the can and the wobbling motion was very comfortable. I >believe it was used on the early Beech 18s as well as many other aircraft of >the day. It was easy to pump and by controlling the rate of the stroke, fuel >pressure could be maintained quite close to the desired number. It was not >at all a frantic style effort. > >Sorry about the rambling. I'll try to stick to electrical stuff from now on! No problem. If we don't recall and share the history of our art, then it wasn't worth doing! The pump I saw was a stand-alone device. This was years ago . . . we had a big clean-up plant wide a year or so ago. Seems some big-wig walking through the facility was put off by all the "junk" in various boxes and cabinets around the plant. Now everything is clean, uninteresting and sterile. All the rotabins are gone from the experimental flight hangar. You gotta go scrounge parts from the factory bins (which get locked up at night so second shift exp-mechanics are SOL). Experimental can now do anything but experiment. That's why most of the stuff I do for them is out of my shop at home. Bob. . . ________________________________________________________________________________
Date: Oct 25, 2002
Ron: Contact Jeff Smith at 941-358-1404, Navasota Avionics shop in Sarasota, FL. They are a big Bizjet FBO and by Garman stack in volume. Regards, ED ________________________________________________________________________________
Date: Oct 25, 2002
Subject: John Slade's Multimeter Problems
> > > sounds like your meter is broke. If you would > > be so kind as to return it to me at >Ahha!. And I thought it was me. What a relief! >I'll mail it next week. Thanks. The meter was indeed bad. I've spoke with Todd. He is going to send you a new meter. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 25, 2002
Bob: On another note. During bench testing, can I put a voltage/amp gauge on my power supply to monitor volts amp loads as I turn each item on. Ed Silvanic Lancair ES ________________________________________________________________________________
Date: Oct 25, 2002
Subject: Accessory loads testing . . .
> >Bob: > > On another note. During bench testing, can I put a voltage/amp gauge >on my power supply to monitor volts amp loads as I turn each item on. Sure. In fact, I highly recommend it. Open the fuse or circuit breaker for each item and hook your multimeter across the opening in the current mode. Or just hook your multimeter in series with the output from your power supply. Bob . . . ________________________________________________________________________________
Date: Oct 25, 2002
For Garmin stuff talk to John Stark at Stark Avionics, 706-321-1008. He has the best prices I have found and is a heck of a nice guy to deal with. He may also handle Apollo but I've never asked about that. Harry Crosby Pleasanton, California RV-6, electrical stuff ________________________________________________________________________________
Date: Oct 25, 2002
> The meter was indeed bad. > I've spoke with Todd. He is going to send you > a new meter. Thanks, Bob. ________________________________________________________________________________
Date: Oct 25, 2002
Subject: Re: Accessory loads testing . . .
Bob: On another note. You asked me to slow down with Ed's Lancair -System planning, because of two other projects going on. When can I send my next pass? I have my annual check ride on the 9th/10th of next month. I usually slow down two weeks prior to prepare for this two day check ride. I am monitoring the current system planning going on with Shannon and someone else. I am downloading info and creating a sub manual to your Aeroelectric Connection book. I won't be doing any heavy work in the shop on the airplane, however, I can send a few passes through if you have the time. Hopefully this would allow me to begin buying hardware right after my check ride or I can ask for a reserve time to send my next pass after the 10th. What would be best for you? Basically I've been doing my own passes each time you correct/advise on the current projects. My second pass when you see it will look like someone's 10th pass when you get it, but other people would not benefit from seeing the on going changes. Whatever is good for you is OK for me. I just don't want to go too cold on this learning process. Oh, yes, as always thanks for your tip on hooking my voltmeter in series with my power supply to check equipment/bus loads. though I haven't started the panel yet, I am thinking ahead. Regards, Ed Silvanic N823MS Lancair ES ________________________________________________________________________________
Subject: GPS/NAV Illuminated Annunciator
Date: Oct 25, 2002
For all- Was very impressed with the GPS/NAV relay kit, which I purchased from Eric M. Jones. It went together real sweetly, and works as advertised. (Thank you Eric!) What I'm looking for now is one of those impressive looking Illuminated Annunciator switches that has two legends. NAV on the top, and GPS on the bottom. Push the button and it toggles from on to the other. The switching action would of course energize or de-energize the relay. The lights for the legends should probably be routed thru the relay as well, so that the appropriate legend won't light unless the relay did switch. Anyone have any sources for such a switch? Or a Better Idea...? (Planned installation on an RV6 set up for light IFR) Rolf RV6 Old and Slow (and so is the kit) ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Date: Oct 25, 2002
John Stark does handle Apollo as I bought a SL-30 in the stack I bought of him. I have a Garmin 430, Apollo SL-30 & Garmin 327 Transponder prewired by Stark Avionics. Tom in Ohio (Fiberglass City) ----- Original Message ----- From: <HCRV6(at)aol.com> Subject: Re: AeroElectric-List: buying Radio's > > For Garmin stuff talk to John Stark at Stark Avionics, 706-321-1008. He has > the best prices I have found and is a heck of a nice guy to deal with. He > may also handle Apollo but I've never asked about that. > > Harry Crosby > Pleasanton, California > RV-6, electrical stuff > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Subject: fuse link
Date: Oct 26, 2002
Bob, I have a firewall mounted 7ah battery on engine side of firewall tied to SD8 alternator relay. Should I provide a fuse link at the battery terminal protecting the 24" wire going to the relay? Dave Ford RV6 ________________________________________________________________________________
Date: Oct 26, 2002
Subject: Re: fuse link
> >Bob, > >I have a firewall mounted 7ah battery on engine side of firewall tied to >SD8 alternator relay. Should I provide a fuse link at the battery >terminal protecting the 24" wire going to the relay? This small a battery doesn't need a honk'n conctactor. Something like our S704-1 relay would suffice. Can you mount this little puppy closer? If not, put in the fusible link. Your description of the wiring is not clear to me. Are you using one of the z-drawings? Bob . . . ________________________________________________________________________________
Subject: Shopping for supplies....Questions
Date: Oct 26, 2002
Perusing 'lectric Bob's web site for supplies, I find myself with these questions: 1. Soldering wires to a d-sub, or crimping machined pins and pushing them into a d-sub connector -- what's the difference? When do I use one and not the other? 2. On the Tools page, does the BCT-1 also crimp the machine pins? If so, I would have no need to buy both the BCT-1 and the RCT-3, right? C. I see female fast-on spade terminals, but no male counterparts. Why? I was thinking of using this combo for the occasional connection in the airplane. Is it not recommended? Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 26, 2002
Subject: Re: Shopping for supplies....Questions
> >Perusing 'lectric Bob's web site for supplies, I find myself with these >questions: > >1. Soldering wires to a d-sub, or crimping machined pins and pushing >them into a d-sub connector -- what's the difference? When do I use one >and not the other? When the product you're installing comes with a solder-type d-sub and you don't have and/or don't want to change to the other style connector, then you'll have to solder it. Either technique is entirely adequate to the task if done with the right tools, skill and understanding. >2. On the Tools page, does the BCT-1 also crimp the machine pins? If >so, I would have no need to buy both the BCT-1 and the RCT-3, right? The BCT-1 is for open-barrel sheet metal pins as shown on http://216.55.140.222/articles/matenlok/matenlok.html The RCT-3 is for machined pins as shown here http://www.aeroelectric.com/Catalog/connect/connect.html#S604 The crimp-pin d-subs sold in many stores like Radio Shack have the open barrel pins. I use the connector housings from Radio Shack when I need to get some in a hurry or on a weekend and use the machined pins in them . . . but either can be installed in a satisfactory manner. I prefer and usually always use the machined pins in my projects. >C. I see female fast-on spade terminals, but no male counterparts. >Why? I was thinking of using this combo for the occasional connection >in the airplane. Is it not recommended? It's only been recently that anyone offered a male fast-on in the PIDG style (metal liners in the insulation grip). They've been available in plasti-grip for a long time but I wouldn't use these on my airplane. If you want to make a serviceable splice in two wires I would recommend knife splices like this http://www.aeroelectric.com/Catalog/wiring/ksplc2.jpg Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Re: mini connectors
Date: Oct 27, 2002
I sent some pictures to the lists, not sure why it didn't come thru yet on the 'lectric list. I used some Deans R/C model connectors on my MAC grips and thought other people might be interested in using these in tight spots. I included the link below and some ordering information. They are probably available at any hobby shop that carries radio-controlled cars/planes. I mail-ordered mine thru Omni Models 1-800-342-6464. 2-pin F46670 $1.39 3-pin F46671 $1.49 4-pin F46674 $1.85 http://www.matronics.com/photoshare/flyink@efortress.com.10.26.2002/index.ht ml or main page at http://www.matronics.com/photoshare Gary Krysztopik Pelican PL w/Stratus EA-81 subaru 96.438% complete Newport, R.I. ________________________________________________________________________________
Date: Oct 27, 2002
> >I sent some pictures to the lists, not sure why it didn't come thru yet on >the 'lectric list. I used some Deans R/C model connectors on my MAC grips >and thought other people might be interested in using these in tight spots. >I included the link below and some ordering information. They are probably >available at any hobby shop that carries radio-controlled cars/planes. I >mail-ordered mine thru Omni Models 1-800-342-6464. > >2-pin F46670 $1.39 >3-pin F46671 $1.49 >4-pin F46674 $1.85 > >http://www.matronics.com/photoshare/flyink@efortress.com.10.26.2002/index.ht >ml > >or main page at http://www.matronics.com/photoshare > >Gary Krysztopik >Pelican PL w/Stratus EA-81 subaru >96.438% complete >Newport, R.I. Gary, thanks for the heads up on this. Omni Models has a website and a brief search of their offerings turned up some interesting possibilities. Check out: http://www2.omnimodels.com/cgi-bin/woi0001p.pgm?Q=1&I=WSDM3005 This is an example of hundreds of variations on a theme in 0.1" spaced, 0.025" square posted connectors common throughout the electronics industry. With this small spacing and in-line design, they're fairly easy to work with for tight spot, low current applications like the control wheel switch harnesses. Many of these connectors do not positively lock to each other when mated so a piece of suitably sized heatshrink over the mated pairs is in order. Bob . . . ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Re: JPH530 to intercom adapter
>Below is the result of your inquiry. It was submitted by >Randy Garrett (rgarrett7(at)attbi.com) on Sunday, October 27, 2002 at 00:29:09 > >Sunday, October 27, 2002 >Hi Bob ... > >I bought a JRC handheld from you as well as the cigarette lighter >adapter. I would like to hook it into my intercom. I figured the easiest >way was to make a custom cable that plugs into the headset adapter on the >handheld. Would you happen to know what kind of plugs those >are? Hopefully, they are pretty standard. > >BTW, I bought the handheld because it had gotten good reviews. I have >gotten several compliments on how the radio sounds, even though I am still >just using the rubber ducky antenna. I have been intended to connect it >to a real external antenna but it is working so well that I just haven't >gotten around to it. I can easily talk 25-30 miles even though the >mounting is hideous. No telling how well it will do with an actual >antenna (:-) I don't know if you can purchase the loose connectors to mate with the radio but the headset adapter that comes with the radio could be easily adapted to the end of a harness connecting the hand-held to the intercom. My radio is loaned out right now but when I get it back, I'll look at the connectors and see if I can Bob . . . ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Adding stick grip PTT switches
>Below is the result of your inquiry. It was submitted by >dennis leasock (dleasock(at)aol.com) on Sunday, October 27, 2002 at 01:41:50 > >Sunday, October 27, 2002 > Hi Bob >...Quick question, I'm installing a PM-2000 intercom and I want to wire a >PTT switch in the control stick. How do I do that? Thanks for the help. Here's a link to part of the wiring diagram I publish for the 760VHF Microair radio. http://www.aeroelectric.com/articles/audio/760v1.pdf Note that the microphone jacks at the bottom of the page have extended PTT switches scabbed onto the appropriate terminals of each mic jack. These are not vulnerable signal wires so a simple, twisted pair extension works fine. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 27, 2002
Subject: New Technologies
I read in the Oct 21 EETimes about a couple new products that may be useful for our new fangled airplanes. Motorola has a new power switch designed to replace relays in cars. I have used relays, and I really hate 'em. This sounds nice. It is designed to make relay free vehicles. Part number is MC33982 <http://www.eetimes.com/pw/potw/OEG20021018S0046> The other product, is more clever than totally useful, since I don't think it could be adapted to airplanes. Phillpis has a chip that can monitor the tire pressure. It uses the cars keyless entry receiver to read tire pressure, pretty clever, since the receiver is on all the time, and when you are driving it probably does nothing. It may not work for airplanes since most aircraft tires use tubes, but maybe sometime it could be adapted. ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Re: New Technologies
> > >I read in the Oct 21 EETimes about a couple new >products that may be useful for our new fangled >airplanes. > >Motorola has a new power switch designed to replace >relays in cars. I have used relays, and I really hate >'em. This sounds nice. It is designed to make relay >free vehicles. Part number is MC33982 > <http://www.eetimes.com/pw/potw/OEG20021018S0046> > >The other product, is more clever than totally useful, >since I don't think it could be adapted to airplanes. >Phillpis has a chip that can monitor the tire pressure. >It uses the cars keyless entry receiver to read tire >pressure, pretty clever, since the receiver is on all >the time, and when you are driving it probably does >nothing. It may not work for airplanes since most >aircraft tires use tubes, but maybe sometime it >could be adapted. All this stuff is coming down the pike at ever increasing capability. I've participated in a number of solid state relay designs at RAC and have some planned for AEC too. Eric Jones has been massaging some designs he would like to offer to the OBAM industry. I have a couple of his parts on my bench now to look at and hope to hook some of them up to try out yet this weekend. Those of you with a technical bent and a rosin-core smoking habit may like to look over a sampling of the recent offerings from various silicon foundries which I've posted at http://www.aeroelectric.com/NewStuff I'm working with two designs using the Profet smart high side switches for use on certified ships at RAC. A local supplier of custom parts to the aircraft industry here in Wichita has several products certified using the Profet parts. Exciting times ahead. Bob . . . Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Fwd: crimping or solderring - Ongoing thread on another
list Hi Gang, What Bob writes (below) is certainly a factual statement and I don't disagree, *BUT*, my original question was simple and has been referenced by many only in spiritual and oblique references that do not qualify for the "Quantifiable Answer" award. Show me the list of rules"? Who's rules are you interested in? I could sit down and write some. AC43-13 proposes a lot of good "advice" that become "rules" in the hands of enthusiastic bureaucrats. Phil Burger offered us lots of "rules" in his SA article. The statement, "UNDERSTANDING of the physics, and personal responsibility", is certainly relevant to my question and that is why I asked for a reasonable, definitive and irrefutable answer. I am beginning to believe there isn't one, just hyperbola. The "rule" is that 35 + 26 = 61, your consternation seems to arise from having to make a decision as to whether you add it up in your head, use pencil and paper, a scientific calculator, abacus or super-computer to arrive at the answer. It appears that Rick provided the best answer that is available: "AC 43-13 1b Chapter 11 Section 14 Paragraph 11-174 a. Selection of Wire Terminals, "Pre-insulated crimp type ring-tongue terminals are preferred." Okay, call this a "rule" if it makes you feel better . . . There have been too many believable "war stories" that have related to wire failing due to a solder connection, particularly larger ones like the type used on starters and other vibration prone areas of attachment. I must pay attention to these subjective accounts as they convey a certain claim of identifiable truth. What subjective accounts are you referring to? I've never seen a single war story that offered an explanation as to the physics of a failure or a rational engineering or systems approach to keeping it from happening again. Let's take any war story you find "believable" and do a critical analysis of facts cited to see how they add value to our deliberations. Until I can be shown otherwise, my larger connections will be crimped. . . . with tools I hope are calibrated to the task . . . I've seen some pretty creative suggestions for things you mash in a vise, pound with a hammer, or squash with a wrench. NONE of the articles I've read for building and using these tools talked about slicing open finished joints to inspect for "gas tightness" under the microscope. The smaller wires will be soldered only when crimping is not possible. Most, where applicable, will be supported physically near the solder or crimped connection. This is based on the most reliable document to date; the FAA AC 43-13 and AC 65-15 Airframe Handbook. I guess this is what the airlines use. Are you sure? I wouldn't bet on it. Every airframe manufacturer has it's own set of "rules" . . . we have bookshelves of various and sundry process specifications at RAC . . some read sorta like AC43-13, some read sorta like engineering applications manuals from AMP. Most read like the words of people who have been doing something in a successful way for a long time and want to share that knowledge. I'm curious. How has anything I've suggested argued with the documents you've cited above? I'm a bit amused at the notion of calling AC14-13 "the most reliable document to date." When AC43-13 was being updated about 6-7 years ago, the FAA sent a draft copy to Earl Lawrence at EAA asking that it be reviewed by folks within the OBAM community for "gross errors . . . we don't want to get off onto any tangents driven by differences of opinion". They asked for responses in two weeks. Earl sent me the electrical section and asked for a speedy response. I used up the better part of every evening for a week and produced a document detailing about 90 data points where the proposed update to AC43-13 were at best poor practice and in many cases dead wrong. I have a copy of what Earl sent back to the FAA. All totaled, I think EAA members had several hundred "suggestions" for improvement to the document. The update scheduled for two weeks didn't happen for months . . . in fact I think it was over a year. When the revision did hit the streets, many of the suggestions EAA made had been incorporated into the document . . . but far too many did not and new problems were generated in the rewrite. One of these days, I plan to do a "Layman's Guide to the use of AC43-13 Electrical Section" . . . it's going to be a big chore and I'm not looking forward to it. Bottom line is that what you've proposed for your airplane is going be just fine. Should this be carved in stone to make it a set of "rules" . . . are you looking for a consensus suggesting that anyone who decides to do it differently has placed his future in jeopardy? It's precisely this sort of quest for comfort in traditional techniques and/or bureaucratic decision making that has brought certified aviation to the point it is today . . . |---------------------------------------------| | Independence, Kansas . . . your #1 source | | factory fresh, 50-year old airplanes. | |---------------------------------------------| You guys are without a doubt, building the best airplanes to have ever flown . . . Bob . . . --- Checked by AVG anti-virus system (http://www.grisoft.com). Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Re: Fwd: crimping or solderring - Ongoing thread on
another list
Date: Oct 27, 2002
Robert L. Nuckolls, III wrote: > > > It appears that Rick provided the best answer that is available: > "AC 43-13 1b Chapter 11 Section 14 Paragraph 11-174 a. Selection > of Wire Terminals, "Pre-insulated crimp type ring-tongue terminals > are preferred." > > Okay, call this a "rule" if it makes you feel better . . . > *** I had an earnest discussion about this very point with my favorite FSDO inspector. He told me that the FAA "prefers" these connectors because they are very very good for aircraft manufacturers, because ******** They can be applied by untrained personnel. ********** Whereas soldering is a skill that takes a week or so to learn. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
From: "William Slaughter" <willslau(at)alumni.rice.edu>
Subject: Fwd: crimping or soldering - Ongoing thread on
another list
Date: Oct 27, 2002
All, I recently took a couple of guys I know out to lunch in return for electrical connection advice. They work for a local company which makes lots of the "electro-whizzies" that fly on Space Shuttle missions. They use both soldering and crimping (not on the same terminal of course). Crimping is usually specified where the number of identical connections is high, but is subject to rounds of destructive pull tests of sample articles both before and after the production items are done. They use very expensive and frequently calibrated crimping tools. Soldering is simply inspected as part of the normal QC process, and moved on down the line. Gas tightness and proper strain relief are the electrical and mechanical elements of a successful connection. Both can be achieved by a variety of means. William Bottom line is that what you've proposed for your airplane is going be just fine. Should this be carved in stone to make it a set of "rules" . . . are you looking for a consensus suggesting that anyone who decides to do it differently has placed his future in jeopardy? It's precisely this sort of quest for comfort in traditional techniques and/or bureaucratic decision making that has brought certified aviation to the point it is today . . . |---------------------------------------------| | Independence, Kansas . . . your #1 source | | factory fresh, 50-year old airplanes. | |---------------------------------------------| You guys are without a doubt, building the best airplanes to have ever flown . . . Bob . . . --- Checked by AVG anti-virus system (http://www.grisoft.com). Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Re: crimping or solderring
> >Robert L. Nuckolls, III wrote: > > > > > > It appears that Rick provided the best answer that is available: > > "AC 43-13 1b Chapter 11 Section 14 Paragraph 11-174 a. Selection > > of Wire Terminals, "Pre-insulated crimp type ring-tongue terminals > > are preferred." > > > > Okay, call this a "rule" if it makes you feel better . . . > > >*** I had an earnest discussion about this very point with my favorite >FSDO inspector. He told me that the FAA "prefers" these connectors because >they are very very good for aircraft manufacturers, because > > ******** They can be applied by untrained personnel. ********** > > Whereas soldering is a skill that takes a week or so to learn. yup . . . maybe even 8 days . . . Bob . . . ________________________________________________________________________________
From: "Ray P. Stallings" <JetJockey(at)alumni.utexas.net>
Subject: Gear up warning
Date: Oct 27, 2002
Does anyone have plans to make a simple tone generator that can be connected as an aux input to an intercom system to provide a gear up warning? I already have the logic switching for the landing gear up and an external buzzer in place but it is often difficult to hear it when wearing my helmet. Any help is greatly appreciated. I have a PSI PMA-4000 audio panel installed. Regards, Ray ________________________________________________________________________________
Subject: SD-8 & relay
Date: Oct 27, 2002
Bob, I am using Z-25 for wiring the SD-8, S704-1 relay and small battery. The only difference is I am not using the 701 contactor and along with the e-buss feed there is also a FADEC primary power buss off the battery. I guess studying a little further I would have seen there is a fuse link shown from battery to relay, sorry. Dave , > > > >I have a firewall mounted 7ah battery on engine side of firewall tied to > >SD8 alternator relay. Should I provide a fuse link at the battery > >terminal protecting the 24" wire going to the relay? > > This small a battery doesn't need a honk'n conctactor. > Something like our S704-1 relay would suffice. Can you > mount this little puppy closer? If not, put in the > fusible link. > > Your description of the wiring is not clear to me. > Are you using one of the z-drawings? > > Bob . . . > > ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Oct 27, 2002
The BTS555 ProFET is used in the pitot heat controller on the Citation X. David Swartzendruber Wichita > http://www.aeroelectric.com/NewStuff > > I'm working with two designs using the > Profet smart high side switches for use > on certified ships at RAC. A local supplier of > custom parts to the aircraft industry here in > Wichita has several products certified using > the Profet parts. > > Exciting times ahead. > > Bob . . . ________________________________________________________________________________
Subject: Low Voltage Warning & Aux Batt management module
Date: Oct 27, 2002
Bob, Any chance you might make the .DWG file available for the Low Voltage Warning & Aux Batt management Module. I'd like to include it in my wiring documentation for the new plane... Fred Stucklen RV-6A N925RV 2006 Hrs of safe flying! Working on 2'd RV-6A (Slow Build Version) ________________________________________________________________________________
Date: Oct 27, 2002
> > >The BTS555 ProFET is used in the pitot heat controller on the Citation X. Did Benny Lee do that one or someone else? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 27, 2002
Subject: Crimping or soldiering electrical terminals - continued
Thanks for your reply and I do appreciate the time you have spent. No problem. It's what I do . . . *IF* I knew anything about this subject I wouldn't have asked for help with *specifics*. I don't have the time to experiment and see who is right (or wrong). You are generally regarded as a guru in your discipline and I had hoped there would be a "reasonable, definitive and irrefutable answer", Since I have not been shown anything (by anyone), I guess I need to choose what seems to be the safest course of direction. I am not trying to argue or diminish your knowledge on the subject in any form or fashion. I simply need a document that will be an accurate guide and keep me out of trouble. The 43-13 is generally regarded as the "accepted" methodology, not withstanding an heretofore unseen document that would supersede the 43-13 handbook. You mention that you could sit down and write some. Let me tell you that would be welcomed with open arms throughout the experimental community. I have read a lot of what you have wrote and it makes a lot of sense. A document about wiring in an vibrating environment would be a great asset to our community. "To Solder or Not to Solder". Okay. Here are the "rules" by which Bob Nuckolls would wire his own airplane: RULE 1: First choice for joining/terminating any wires up through 22 through 12AWG are PIDG style terminals as described in http://www.aeroelectric.com/articles/terminal.pdf using tools like http://www.aeroelectric.com/Catalog/tools/tools.html#rct-1 or better. --------------------------- RULE 2: Where there is a choice, I would select fast-ons over threaded fasteners in the 22 to 12 AWG range using terminals like http://www.aeroelectric.com/Catalog/wiring/wiring.html#faston with features as explained in http://www.aeroelectric.com/articles/faston3.pdf --------------------------- RULE 3: When I have to live with a treaded fastener then these terminals are in order . . . http://www.aeroelectric.com/Catalog/wiring/wiring.html#s816p ---------------------------- RULE 4: For wires larger than 12AWG, then I would solder and heatshrink joints as described in . . http://www.aeroelectric.com/articles/big_term.pdf Using materials like . . . http://www.aeroelectric.com/Catalog/wiring/s812.jpg which are supplied with double-wall heatshrink for finishing. ------------------------------- RULE 5A: Permanent splicing of single conductors to be accomplished with butt splices like . . . http://www.aeroelectric.com/Catalog/wiring/s816.jpg ------------------------------- RULE 5B: but if it was deemed desirable to break the splice open for future convenience, a knife splice and heat shrink would be used thusly . . . http://www.aeroelectric.com/Catalog/wiring/ksplc2.jpg ------------------------------- RULE 6: When the accessory items are supplied with nylon connectors like AMP Mate-n-Lock or Molex, pins are installed with a tool like . . . http://www.aeroelectric.com/Catalog/tools/tools.html#bct-1 used thusly . . . http://216.55.140.222/articles/matenlok/matenlok.html These connectors would only be used as an accommodation for the use of an accessory that comes with them already installed. They are not my connector style of choice for any other applications. ------------------------------------ RULE 7A: When working with accessories supplied with D-sub connectors, the first choice of mating connectors is the removable pin variety that will accept machined pins like . . http://www.aeroelectric.com/Catalog/connect/connect.html#S604 installed with a tool like http://www.aeroelectric.com/Catalog/tools/tools.html#rct-3 and removed with a tool like . . . http://www.aeroelectric.com/Catalog/tools/tools.html#dse-1 RULE 7B: if for any reason the crimped-pin mating d-sub is not available, then soldering is my second choice using techniques described in . . . http://www.aeroelectric.com/articles/dsubs/d_solder.html and tools like http://www.aeroelectric.com/Catalog/tools/tools.html#s101_1 or better ----------------------------------------- RULE 7C: If options 7A and 7B are not practical, then the lowest order choice for working with d-subs is open barrel crimped pins installed with a tools and techniques like those described in RULE 6. ----------------------------------------- RULE 8: Installation of connectors on coaxial cables to antennas are installed per http://www.aeroelectric.com/articles/bnccrimp.pdf using tool . . http://www.aeroelectric.com/Catalog/tools/tools.html#rct-2 and wire . . . http://www.aeroelectric.com/Catalog/antenna/antenna.html#rg-400 and connectors . . . http://www.aeroelectric.com/Catalog/antenna/antenna.html ------------------------------------------- RULE 9: A single point ground system shall be established behind the instrument panel with sufficient attach points for all accessories in the cockpit area. In deference to RULE 2, a forest-of-fast-on-tabs ground block similar to . . . http://www.aeroelectric.com/Catalog/wiring/wiring.html#gndblk The threaded stud on the ground block assembly would penetrate the firewall and be used to terminate battery (-) leads on either side of firewall and the crankcase ground strap on the engine side of the firewall. In the case of canard pushers with the battery up front, the ground bus would be mounted forward of the instrument panel. If the airplane's firewall is metalic, then a brass bolt and appropriate washers and nuts would be used to provide an engine compartment ground stud and connection of the ground lead to the firewall. A ground strap like . . . http://www.aeroelectric.com/Catalog/wiring/wiring.html#bbs . . . will be used to connect the crankcase to the firewall ground stud. Any ground straps provided around the rubber biscuits of an engine mount will be removed. Engine mounts are for holding engines on airplanes and not use for any part of the electrical system. ------------------------------------------- RULE 10: Tefzel wire used throughout with the exception of cranking circuit fat wires where 4AWG or 2AWG welding cable would be used. An alternative FAT wire could be one of the new copper-clad aluminum wires. These new materials are as solderable and crimpable as pure copper conductors. Caution To get the same electrical performance, you need to use about 2AWG steps larger wire than for copper but the installed wire will still be lighter. Here endeth the reading of the rules. In parallel universes there are differing rules which may well prove to be as useful or perhaps even better than those cited in Bob's universe. Given what Bob has learned up to and including Sunday, October 27, 2003 the rules cited above are his personal choices for practical, solid techniques using moderately priced materials, and tools. Adherence to these rules is likely to produce an electrical system where (1) component wear-out and failure are the sole causes for maintenance and (2) the wiring can be expected to perform as intended over the lifetime of the airplane. ================================================================ Here is how I perceive the question, "When can you use solder on a #2 wire?" Answer, "Well, that depends!". I can't deal with that kind of an answer. Unfortunately that is all I have been getting from our canard community rank and file. Yes, it does depend . . . on only one thing. Whether or not YOU want to solder wires. If any of the rank and file disagree with this, please invite them to bring the facts as they perceive them over to the AeroElectric-List. If I'm unaware of some critical information on the matter, I and several hundred others are intently interested in knowing what it is. This isn't a battle of wills or a turf war. We need to be constantly evolving the art and science of building airplanes based on physics. If I am in error, nobody is more interested in knowing about it than I am. > Let's take any war story you find "believable" and do a > critical analysis of facts cited to see how they add value > to our deliberations. Bob, you are getting picky here, I must have hit a nerve, I didn't mean to. Take my word for it however, there have been recent posts of this and breaking because they were soldered. I just am not going to find them at this time as most were bad work anyway. One fellow e-mailed me and stated a bad crimp is just as bad a bad solder. Hummmmm? Yup, he's right . . . You brought up war stories as having an influence on your deliberations. I've written many times and with extreme disfavor on consideration of what I call "Dark and stormy night" stories as useful data for the design and fabrication of an electrical system. I'll suggest that most of those stories came about due to a lack of understanding on the part of pilots, manufacturers and bureaucrats as to what it takes to produce a reliable flight system. See http://www.aeroelectric.com/articles/Rev9/ch17-9.pdf Our easy-to-achieve goals for having airplanes that stand above the spam-cans is (1) design for failure tolerance and (2) take on the responsibility to learn how to use ANY chosen assembly technique effectively. There will ALWAYS be failures of one kind or another in ANY system. Yeah, you might even burn a soldered terminal off the end of a wire cause you didn't put it on right . . . but you might burn a crimped terminal off too for EXACTLY THE SAME REASON. You mentioned $120.00 for a tool. To me that is not an outrageous price. I'll look into them shortly. I suspect I will need several. Perhaps you could recommend one. Not $120 for A tool but the WHOLE SET of tools . . . see citations in list of rules above. When I amuse my wife she becomes exuberant and happy. I hope I have effected you in the same manner. If you consider that no other document has been offered, except the 43-13, to answer my specific question, I guess it accurately fits the description. All I have seen are several multi page documents, although well written, do not answer my original question regarding solder in the vibrating arena. I've made the statement numerous times and will repeat it here. There is no significant difference in a properly soldered versus properly crimped joint on a wire. Crimping takes specialized tools and less skill; soldering uses very in-expensive tools and takes some practice. I cannot cite any reason for saying that one technique is better than the other with respect to service life in your airplane. > One of these days, I plan to do a "Layman's Guide to > the use of AC43-13 Electrical Section" . . . it's > going to be a big chore and I'm not looking forward to > it. It would appear that it is a badly needed document. Having been inundated with just about every "war story" and Uncle Herbs snake oil remedy for proper wiring, I would personally be relieved to have in my possession such a document. All kidding aside, you should dedicate it to me. I represent the many who don't know but will admit it. I think you're making it more complicated than it needs to be. This is the objection I have for the way the EXP-Bus was sold at OSH last time I was there. A guy behind the counter hands you this whippy assembly that looks really complicated . . . http://www.controlvision.com/pages/avionics_expbus.htm . . .and it only costs $300! You hold the thing in your hand an think, "Damn! I'd NEVER be able to figure out something like this," while the guy behind the counter tells you about all the whippy things it will do and how much "time" it will save. The question you don't know to ask and he doesn't offer is "Does this product offer the simplest, lowest parts count, equal or better performance result at the same or lower cost of ownership." My answer to that question is, "No, it does not." When you pick up an English language dictionary, one finds perhaps 100,000+ words contained therein of which most literate adults use less than two percent of the total. Yet I think we communicate very well. AC43-13 is a similar document. It's a real piece of work and LOOKS important because its got this whippy government agency seal on the cover. Like the EXP-Bus and the dictionary, there are a handful of core facts and features around which 95% of your system will be designed and built and I think I've touched on most of them above. > It's precisely this sort of quest for comfort in > traditional techniques and/or bureaucratic decision > making that has brought certified aviation to the point > it is today . . . > > |---------------------------------------------| > | Independence, Kansas . . . your #1 source | > | factory fresh, 50-year old airplanes. | > |---------------------------------------------| You have a valid point. I only wish my Long will be around as long and respected as the veritable DC-3. No-biggie. Solar UV is going to rot the poor bugger to dust before any of your wiring falls apart. Again, thanks for your time. I do feel honored that someone of your stature has taken the time to try and straighten me out and be a help. Another no-biggie. You've just fallen victim to a veritable blizzard of non-information that provides job-security for certain classes of worker citizens in other aviation venues. You're really better prepared than you think you are but pouring over a document that's 95% floobydust will only make the answers harder to find and understand. Put down your copy of AC43-13 and let's get started on your airplane. If questions come up along the way, you'll get better answers TAILORED to your situation off the list-servers than you'll get out of that document. By the way, my e-mail address at nuckolls(at)aeroelectric.com is going away in a few days. 95% of what arrives there is either spam or virus attacks. Use bob.nuckolls(at)cox.net instead. There's an e-mail generator on the website at http://aeroelectric.com/bob.nuckolls/ that will forward to the Cox account. I'm trying to avoid publishing my direct e-mail address on publicly accessed web pages to keep from getting picked up by so many spam-bots. Better yet, join the AeroElectric-List . . . Bob . . . ________________________________________________________________________________
Date: Oct 28, 2002
> > >I think it's a Cessna design built at Cessna. I betcha it'd blow us away to >know how much that card cost's to replace as a spare part. You got that right . . . but Benny isn't a low-dollar outfit either. He just moves at the speed of light outside the OEM walls while the guys inside haven't broken the sound barrier yet. In any case, it's nice that when folks are getting plugged in to the new parts and making them work for their customers. I hope their design proves to be good value in the field. Bob . . . ________________________________________________________________________________
Subject: system
Date: Oct 28, 2002
Bob, I've considered your suggestion of upsizing the main alt to 90A. However, I am not aware of a unit offered in the mount I need. Also, I'm not entirely sure I have the "correct" things on the PRI and AUX busses anyway, so I'm not sure if moving things around is called for or not. If possible, here is how I'd like to proceed (and proceed I NEED TO DO). I'd like to jointly take a look at my equipment and busses, and see if each component is on the right bus. Then I can go from there as far as alternator requirements for each bus. Can we do that? The spreadsheet is posted at http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_3.xls The components in question are in yellow. I really like the idea of the ESS bus feed off the main busses through a diode (and a switch with NC relay), with an ALT feed switch straight off the battery. I like it so much, that I think I want to create two ESS busses, one off of each the MAIN and AUX bus. My panel is already cut out with 2 switches, so I might as well use them. This will allow me to have a place to put my "pampered" SFS too. I plan to do this behind a N.C. bosch relay, so its failure mode would resort to the buss being on if either the switch or the relay fails. The back up would be the ALT FEED switches. I feel this is warranted due to my need of a "pampered" buss, it adds some convenience features (which are important to me), and it is very well backed up in its failure modes (switch fails:ON, relay coil fails:ON, further backed up by ALT FEED). I realize this is not the minimum parts solution, but it feels right. Thoughts? Another question that I have pondered in an attempt to get the amp draw under control is to switch to a 28 volt system. Can we discuss the merits of this, as I don't recall it being discussed. This would ideally cut most of my amp draws in half (I assume), which should put me back in business. However, it would require a different battery for sure. Are there batteries in the same size as my 17ah 14v ones in a 28V variety? Will I still need 17ah, or will half of that suffice? Will the required starter current go from 200 to 100? Do all of your contactors your sell work on 28V systems? Thanks. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: system > > >Bob, > >Haven't heard from you for a couple days on the system design exercise >we were working on on the list. Obviously, I'm anxious to move forward. >I'm not trying to be pushy, but would you mind taking a look at my >responses to you and advise me? I've basically decided that your >method/advice is what I want to follow (chosen from all the advice out >there, ie Lancair, other builders, etc), so until I get some of your >great words of wisdom on my project, I'm pretty much in total limbo :) Sorry. I've been nose-to-the-stone on a RAC project. Need to get a spin-chute controller tested and installed in a Premier by Sunday. Haven't been able to spend as much time on e-mail as usual. >With my project moving half way across the US in just over a week for >finish bodywork and paint, limbo is not a good place for me to be, LOL >:) Let me know what you come up with. Thanks, as always, for your >patience and willingness to educate. We're all learn'n here . . . Consider upsizing the main alternator to 90A. This would take care of your headroom problems on the main bus. If you upsized the aux alternator, then we'd have to move some main-bus loads to the aux bus and I'd rather keep the aux bus as clean as possible. >--- >Shannon Knoepflein <---> kycshann(at)kyol.net > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: system
Date: Oct 28, 2002
That's a nice spreadsheet, Shannon. Thanks. I think I'll steal it! I have one comment. I'd suggest that you need the AC during decent, depending on where you are. Certainly here in S. Florida you need AC as you decend back into the heat and humidity. John Slade Cozy IV ________________________________________________________________________________
Subject: Test results (& methodology) for NiMH AA digital camera
use
Date: Oct 28, 2002
The table of "usable minutes" of several brand names is interesting. Somewhat related to some testing done by Bob a few months ago re handheld GPS & comm batteries (were those AAA?) http://www.imaging-resource.com/ACCS/BATTS/BATTS.HTM David Carter ________________________________________________________________________________
Subject: Headset/ Mic Jack insulation
Date: Oct 28, 2002
Hello, I wanted to know if the anti rotation tang on my jacks, need to be cut off if I'm using the insulated washers? David L. Hartley 209 983-3318 209 983-3281 Fax 209 929-2649 Pager dhartley(at)aascworld.com ________________________________________________________________________________
Date: Oct 28, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Headset/ Mic Jack insulation
> >Hello, I wanted to know if the anti rotation tang on my jacks, need to be >cut off if I'm using the insulated washers? I think they do . . . You don't want them to "bite" into the washer. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2002
I guess you would lose the "anti rotation" feature then. Does anyone consider that to be an issue, or just snug them up good n tight? David L. Hartley Program Manager Applied Aerospace Structures Corp. 209 983-3318 209 983-3281 Fax 209 929-2649 Pager dhartley(at)aascworld.com -----Original Message----- From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] Subject: Re: AeroElectric-List: Headset/ Mic Jack insulation > >Hello, I wanted to know if the anti rotation tang on my jacks, need to be >cut off if I'm using the insulated washers? I think they do . . . You don't want them to "bite" into the washer. Bob . . . http://www.matronics.com/browselist/aeroelectric-list ________________________________________________________________________________
Date: Oct 28, 2002
Subject: Re: Crimping or soldiering electrical terminals - continued
Bob: Finally recieved your CD-Rom Disk. How do I isolate one of the drawings on the Lancair IV so I can begin my wirebook and get ideas for my Lancair ES. Are we able to print it out by page? Thanks Ed Silvanic ________________________________________________________________________________
Subject: Aux Battery Management Module Availability
Date: Oct 28, 2002
Hi Bob, I've scoured your site and B&C's site looking for your Aux Battery Management Module but can't find it. Is it available?? If so, please point me to the details. Also, I'm trying to figure out how to "size" a Schottky diode. I'm totally lost and would appreciate links regarding this topic. Thanks for all the resources and information that you provide. Also have appreciated your appearances at the Q2/Dragonfly Fly-In in Kansas over the last several years - great presentations! Jon Finley N90MG Q2 - Subaru EJ-22 DD - 440 Hrs. TT - 0 Hrs Engine Apple Valley, Minnesota http://www.FinleyWeb.net/default.asp?id=96 ________________________________________________________________________________
Date: Oct 28, 2002
Subject: Re: Z-11a, Single ECU
Bob, I started this post and have been following it closely between you and John. To answer your question, My current draw is about 4 amps to the ECU. I also have a memory wire that is wired hot all the time that draws very little. I'm not worried about an ECU or Aux battery failure, just my SINGLE toggle switch that provides it power. If I'm going to add a second switch, I would be nice to be able to tap into the second battery. Randy > > > > > > > >Bob, I am using Z-11a with a single ECU to keep the motor noisy. Not sure > >of the best way > >to feed it from either battery buss. Two diodes to prevent cross feed would > >lower the voltage > >in an alternator out situation. One double pole switch could be another > >single point failure. > >I am thinking about two switches side by side, on-off-on, that have their > >handles tied together. > >Up would be normal feed from one battery, center is off, and down would be > >feed from the > >other battery. Any thoughts or suggestions from anyone are always welcome. > >That's what > >makes this group work so well! > > > I'd run it via fusible link from the aux battery only. This > is what a second battery is for . . . provide a totally > independent source of power for the engine that is not > also loaded with other goodies. > > If push comes to shove, you can always close both battery > contactors and get main battery power to the ECU but if > you've got a less-than-two-year-old battery in the aux > slot, I can't see this happening. How much current does > your ECU draw in cruise? > > Bob . . . > > ________________________________________________________________________________
From: "Ray Stallings <from Web-Mail>" <JetJockey(at)alumni.utexas.net>
Subject: Gear Warning Tone
Date: Oct 28, 2002
I posted the following message this weekend which probably explains why I didn't get any responses. I know someone out there knows how to do this, so here goes again: Does anyone have plans to make a simple tone generator that can be connected as an aux input to an intercom system to provide a gear up warning? I already have the logic switching for the landing gear up and an external buzzer in place but it is often difficult to hear it when wearing my helmet. Any help is greatly appreciated. I have a PSE PMA-4000 audio panel installed. Regards, Ray Ray Stallings Email: JetJockey(at)alumni.utexas.net PeoplePC: It's for people. And it's just smart. http://www.peoplepc.com ________________________________________________________________________________
Date: Oct 28, 2002
Subject: $13 volt meter
Date: Oct 28, 2002
> The meter is made by "Vector". It claims to be accurate to .1V. Here's > a URL: > > http://store.yahoo.com/rodi/vec008.html For others who may be interested... Mine came in today. It's a nice little unit and seems to work as advertised. It has high, medium and low voltage LEDs and a backlit LCD display. It's powered from a cigarette lighter socket. I havent had the back off yet, but it has 4 screws. I think the thing can be disassembled and hard wired fairly easily. Moving the LEDs might be a little harder. I also received two $15.95 batteries from http://meci.com/ They're exactly the same size as my $56 panasonic. The terminals look a little less sturdy, but strong enough. I've yet to see how they perform. John Slade ________________________________________________________________________________
Date: Oct 28, 2002
Subject: RE: Headset/ Mic Jack insulation washers
> >I guess you would lose the "anti rotation" feature then. Does anyone >consider that to be an issue, or just snug them up good n tight? If the jacks had to withstand rotary tightening motions in the normal course of usage, their might be some concerns. I've used these parts for years in situations not utilizing the anti-rotation feature . . .doesn't seem to be a problem with a whole lota push'n and pull'n go'n on. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2002
From: Charlie and Tupper England <cengland(at)netdoor.com>
Subject: Re: Gear Warning Tone
"Ray Stallings " wrote: > > > I posted the following message this weekend which > probably explains why I didn't get any responses. I > know someone out there knows how to do this, so here > goes again: > > Does anyone have plans to make a simple tone generator > that can be connected as an aux input to an intercom > system to provide a gear up warning? I already have > the logic switching for the landing gear up and an > external buzzer in place but it is often difficult to > hear it when wearing my helmet. > > Any help is greatly appreciated. I have a PSE PMA-4000 > audio panel installed. > > Regards, > > Ray > > Ray Stallings > Email: JetJockey(at)alumni.utexas.net > PeoplePC: It's for people. And it's just smart. > http://www.peoplepc.com Ray, Saw your post, limited time to research for you right now. Try searching Google for '555 timer ic' & you should find something that will work. You want an oscillator tuned somewhere between 400hz & 3khz. A direct link to the mfgr's web site is http://www.national.com/pf/LM/LM555.html If you haven't found a solution in a few days, email me direct & I'll try a little harder to find you a circuit. Charlie ________________________________________________________________________________
Date: Oct 28, 2002
Subject: RE: Shannon's Lancair system . . .
> > >Bob, > >I've considered your suggestion of upsizing the main alt to 90A. >However, I am not aware of a unit offered in the mount I need. Which engine/alternator combination are you considering? > Also, >I'm not entirely sure I have the "correct" things on the PRI and AUX >busses anyway, so I'm not sure if moving things around is called for or >not. The interesting thing here is that it's not terribly critical at this time. If you arrange your aux and main busses adjacent to each other with spare breakers in the space between them, loads can be easily exchanged between busses as reasons become known in the future. Same thing with main and aux battery busses. If they are in close proximity, loads can be exchanged between these sources as well. The most important part of your load analysis now is to have a good handle on exactly how many total devices need power and what the total loads are. Decisions on exactly where the power comes from can be adjusted. >If possible, here is how I'd like to proceed (and proceed I NEED TO DO). >I'd like to jointly take a look at my equipment and busses, and see if >each component is on the right bus. Then I can go from there as far as >alternator requirements for each bus. Can we do that? The spreadsheet >is posted at > >http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_3.xls > >The components in question are in yellow. > >I really like the idea of the ESS bus feed off the main busses through a >diode (and a switch with NC relay), with an ALT feed switch straight off >the battery. I like it so much, that I think I want to create two ESS >busses, one off of each the MAIN and AUX bus. My panel is already cut >out with 2 switches, so I might as well use them. This will allow me to >have a place to put my "pampered" SFS too. I plan to do this behind a >N.C. bosch relay, so its failure mode would resort to the buss being on >if either the switch or the relay fails. The back up would be the ALT >FEED switches. I feel this is warranted due to my need of a "pampered" >buss, it adds some convenience features (which are important to me), and >it is very well backed up in its failure modes (switch fails:ON, relay >coil fails:ON, further backed up by ALT FEED). I realize this is not >the minimum parts solution, but it feels right. Thoughts? Wouldn't do it if it were my airplane . . . but then it's not my airplane. >Another question that I have pondered in an attempt to get the amp draw >under control is to switch to a 28 volt system. Can we discuss the >merits of this, as I don't recall it being discussed. This would >ideally cut most of my amp draws in half (I assume), which should put me >back in business. It would help . . . > However, it would require a different battery for >sure. Yup . . . and unfortunately there are no commercial RG batteries as practical as the pair of 17 a.h. batteries. Two pairs of 17's is way to big to even consider. > Are there batteries in the same size as my 17ah 14v ones in a 28V >variety? > Will I still need 17ah, or will half of that suffice? You could consider dropping down to pairs of 10-12 ah batteries with a small penalty in weight and a slight gain in total battery energy stored and a pretty hefty boost in price. >Will the required starter current go from 200 to 100? It will be less but not by half. > Do all of your contactors your sell work on 28V systems? We have only 28v dimmers and OV modules. Further, going to 28V shuts you out of anything and everything automotive. Obviously, there are tens of thousands of 28v single engine airplanes flying. If your power budget has become unmanageable on a 14 volt system, then 28 may be your only choice. Bob . . . ________________________________________________________________________________
Date: Oct 28, 2002
Subject: RE: The importance of load analysis.
> >That's a nice spreadsheet, Shannon. Thanks. I think I'll steal it! >I have one comment. I'd suggest that you need the AC during decent, >depending on where you are. Certainly here in S. Florida you need AC as you >decend back into the heat and humidity. >John Slade >Cozy IV Good thought John . . . in fact, everyone on the list should get a copy for reference. The load analysis is a major design tool that becomes increasingly important as system complexity goes up. The load analysis exercise was what raise flags that a 28v system may well be NECESSARY on Shannon's airplane. By doing the analysis first instead of after hardware has been purchased can save one from unhappy discoveries about things that were easily foreseen. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
> > >I posted the following message this weekend which >probably explains why I didn't get any responses. I >know someone out there knows how to do this, so here >goes again: > >Does anyone have plans to make a simple tone generator >that can be connected as an aux input to an intercom >system to provide a gear up warning? I already have >the logic switching for the landing gear up and an >external buzzer in place but it is often difficult to >hear it when wearing my helmet. > >Any help is greatly appreciated. I have a PSE PMA-4000 >audio panel installed. Here's a circuit I used for a customer at Electro-Mech about 25 years ago. http://216.55.140.222/temp/GearWarn.gif It uses one integrated circuit and a few simple components. Output is a 400 Hz tone pulsed at approx 2 times per second. Adjust the value of R to get desired matching volume with other audio sources. Suggest you start with 1K ohm here and adjust as necessary. Less resistance is more volume. Bob . . . ________________________________________________________________________________
Subject: CH701/Battery earth
Date: Oct 29, 2002
Dear Bob, I'm starting the wiring on mt CH701 with Rotax 912s. The a/c is all metal with battery in rear fuselage. 1/ Is it OK to earth the battery locally in the rear fuselage [ the structure is very light ] or would it be better to bring an earth cable all the way forward to the ground bus on the back of the firewall? 2/The Rotax installation manual gives wire sizes in mm squared. Is there a handy conversion table somewhere, mm squared to AWG ? Regards, Shay King. ________________________________________________________________________________
From: "Del Johnson, North Point Solutions, Inc" <del.johnson(at)mindspring.com>
Subject: Fuel State Detector
Date: Oct 29, 2002
Bob, I would like to construct a couple of the fuel detectors, that use a plastic rod. They look like they would be simple to construct and shouldn't cost very much. You mentioned that you have constructed similar devices. I have two questions: 1. Where would you place the light source (infrared) in relation to the light sensor? My first thought would be to drill out a cavity that would house the infrared LED and place the infrared sensor behind the LED. 2. What kind of plastic rod would not react to the various kinds of auto/aviation that it might come in contact with and where can you purchase that material? ________________________________________________________________________________
Date: Oct 29, 2002
> Here's a circuit I used for a customer at Electro-Mech > about 25 years ago. Gee Bob. I wish I knew enough about electronics to build little gizmos like this. I wonder if you would mind using this example to to give me (and others) a shove over the last couple of hurdles into this facinating world. Let me make a start by attempting to interpret the drawing and come up with a shopping list for Radio Shack: 1. Breadboard 2. 100 ohm 1/2 watt resistor 3. Part # IN4742A 4. 10uf capacitor 5. Integrated circuit CD4093 with 14 terminals 6. 1k resistor (for starters) vary as needed for volume 7. .01 uf capacitor 8. 150 ohm resistor 9. .047 uf capacitor 10. 56k ohm resistor 11. 100k resistor 12. 4.7 uf capacitor How'd I do? John Slade ________________________________________________________________________________
Date: Oct 29, 2002
> Bob, I would like to construct a couple of the fuel detectors, that use a... Yes, Bob. Info please. I'd like to build a couple of these too! John Slade PS I built an LED annunciator panel and it went to my head. ________________________________________________________________________________
Date: Oct 29, 2002
With all the considerations, unfortunately, 28V is not really an option for me. Components are already ordered, and not having automotive compatability just won't suffice. 14V it is. My engine is the Continental IO-550N, with one of the AeroSupercharger Solutions vortec superchargers on it. The supercharger is on the co-pilot side, where the alternator usually is. Therefore, the kit comes with a 60A alternator that is mounted on the pilot side to the machined front plate that attaches to the front of the engine that also holds the supercharger. AeroSS has been working with Kelly Aerospace to offer other options. Kelly Aerospace is making a couple of 70A units, but neither is available just yet. One would mount to the front and be belt driven with the supercharger, just like the 60A unit. This is what I planned to use, along with the B&C 20 on a pad. However, this combination is proving to not be up to the task, unfortunately. The other Kelly unit sounds promising though. It is a 70A unit that mounts to the pad on the back of the engine. It is suppose to be available in a couple months. If this unit would materialize, I would strongly consider installing 2 of these units, one on each pad. Then, on my load analysis and buss structure, I would just move the A/C to the AUX BUSS and be done. Also, this would keep a supercharger belt breakage from attempting to ruin my electrical day. Does this sound feasible? As far as my buss structure; I understand your comment about it not being extremely important at this time to have it all worked out. However, to me it is, as I have to get the panel all cut and the labels laser etched on the panel. If I change my mind later, then I have to get the metal re-cut (not likely) or more than likely, I'll just have to live with the changes that won't be properly reflected in the groupings and labels on the panel. A picture of my preliminary panel can be seen at http://shannon.v8eaters.com/images/lancair/Knoepflein-l2k-092002.pdf where you can see the groupings and labels I'm talking about. I want to get this right the first time. It is not right now I know. I've done the 4th go-around on the spreadsheet. I think it's getting closer. It's posted at http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_4.xls Still looking for any and all comments and suggestions. Thanks. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Shannon's Lancair system . . . > > >Bob, > >I've considered your suggestion of upsizing the main alt to 90A. >However, I am not aware of a unit offered in the mount I need. Which engine/alternator combination are you considering? > Also, >I'm not entirely sure I have the "correct" things on the PRI and AUX >busses anyway, so I'm not sure if moving things around is called for or >not. The interesting thing here is that it's not terribly critical at this time. If you arrange your aux and main busses adjacent to each other with spare breakers in the space between them, loads can be easily exchanged between busses as reasons become known in the future. Same thing with main and aux battery busses. If they are in close proximity, loads can be exchanged between these sources as well. The most important part of your load analysis now is to have a good handle on exactly how many total devices need power and what the total loads are. Decisions on exactly where the power comes from can be adjusted. >If possible, here is how I'd like to proceed (and proceed I NEED TO DO). >I'd like to jointly take a look at my equipment and busses, and see if >each component is on the right bus. Then I can go from there as far as >alternator requirements for each bus. Can we do that? The spreadsheet >is posted at > >http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_3.xls > >The components in question are in yellow. > >I really like the idea of the ESS bus feed off the main busses through a >diode (and a switch with NC relay), with an ALT feed switch straight off >the battery. I like it so much, that I think I want to create two ESS >busses, one off of each the MAIN and AUX bus. My panel is already cut >out with 2 switches, so I might as well use them. This will allow me to >have a place to put my "pampered" SFS too. I plan to do this behind a >N.C. bosch relay, so its failure mode would resort to the buss being on >if either the switch or the relay fails. The back up would be the ALT >FEED switches. I feel this is warranted due to my need of a "pampered" >buss, it adds some convenience features (which are important to me), and >it is very well backed up in its failure modes (switch fails:ON, relay >coil fails:ON, further backed up by ALT FEED). I realize this is not >the minimum parts solution, but it feels right. Thoughts? Wouldn't do it if it were my airplane . . . but then it's not my airplane. >Another question that I have pondered in an attempt to get the amp draw >under control is to switch to a 28 volt system. Can we discuss the >merits of this, as I don't recall it being discussed. This would >ideally cut most of my amp draws in half (I assume), which should put me >back in business. It would help . . . > However, it would require a different battery for >sure. Yup . . . and unfortunately there are no commercial RG batteries as practical as the pair of 17 a.h. batteries. Two pairs of 17's is way to big to even consider. > Are there batteries in the same size as my 17ah 14v ones in a 28V >variety? > Will I still need 17ah, or will half of that suffice? You could consider dropping down to pairs of 10-12 ah batteries with a small penalty in weight and a slight gain in total battery energy stored and a pretty hefty boost in price. >Will the required starter current go from 200 to 100? It will be less but not by half. > Do all of your contactors your sell work on 28V systems? We have only 28v dimmers and OV modules. Further, going to 28V shuts you out of anything and everything automotive. Obviously, there are tens of thousands of 28v single engine airplanes flying. If your power budget has become unmanageable on a 14 volt system, then 28 may be your only choice. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: Fuel State Detector
Del, Another and possibly easier approach would be a capacitance sender. Peter > Bob, I would like to construct a couple of the fuel detectors, that use a > plastic rod. They look like they would be simple to construct and shouldn't > cost very much. You mentioned that you have constructed similar devices. > > I have two questions: > > 1. Where would you place the light source (infrared) in relation to the > light sensor? My first thought would be to drill out a cavity that would > house the infrared LED and place the infrared sensor behind the LED. > > 2. What kind of plastic rod would not react to the various kinds of > auto/aviation that it might come in contact with and where can you purchase > that material? > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: 'linearizing' a fuel gauge
Date: Oct 29, 2002
Hi Bob, Our project is to have 240/33 ohm empty to full fuel level senders in the wings. Of course, due to the irregular shape of the wing internal tank, the UMA gauge indication won't match the actual content. For the ends of the scale, there are the built-in zero and full adjustments. But what about the intermediate readings ? I was thinking of an electonic device "correcting" the input, to approximately match the 1/2 and 1/4 marks on the gauge faces. Is such a device easily feasible ? Thanks in advance, Gilles ________________________________________________________________________________
Date: Oct 29, 2002
In a message dated 10/29/02 9:14:49 AM Eastern Standard Time, dr.laurence(at)mbdi.org writes: Or, check out the fuel sensors sold by Aircraft Extras Inc. You can see at www.aircraftextras.com > Another and possibly easier approach would be a capacitance sender. > > Peter > > > Bob, I would like to construct a couple of the fuel detectors, that use a > > plastic rod. They look like they would be simple to construct and > shouldn't > > cost very much. You mentioned that you have constructed similar devices. > > > > I have two questions: > > > > 1. Where would you place the light source (infrared) in relation > to the > > light sensor? My first thought would be to drill out a cavity that would > > house the infrared LED and place the infrared sensor behind the LED. > > > > 2. What kind of plastic rod would not react to the various kinds > of > > auto/aviation that it might come in contact with and where can you > purchase > > that material? > > > ________________________________________________________________________________
Subject: Cheap batteries
Date: Oct 29, 2002
It looks like I got my $15.95 worth! Both these MECI.COM batteries seem unable to take a charge. The charger sits at 1.5 amps and the batteries read 11.2 volts until I give them a tiny bulb to light up, then they drop to 8 volts and the bulb glows dimly. Is there a trick to this, or are they total junk? John Slade ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: 'linearizing' a fuel gauge
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob, > >Our project is to have 240/33 ohm empty to full fuel level senders in the >wings. >Of course, due to the irregular shape of the wing internal tank, the UMA >gauge indication won't match the actual content. >For the ends of the scale, there are the built-in zero and full adjustments. >But what about the intermediate readings ? >I was thinking of an electonic device "correcting" the input, to >approximately match the 1/2 and 1/4 marks on the gauge faces. Is such a >device easily feasible ? You betcha. I use a micro-controller with a built in a/d to read the sensor and convert the reading to true value based on a lookup table built into the software. I've used this basic architecture perhaps a dozen times for various applications over the years. http://216.55.140.222/temp/FuelGage.gif It's becoming easier every day. Here's a nifty new chip from Motorola http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?code=68HC908QT4&nodeId=01M98634 it's supported with low cost development systems and editor-assemblers with lucid, intuitive syntax . . . one of the easiest processors in the world to make work. You can also consider devices like the Basic Stamp from http://www.parallaxinc.com/ This chip set needs an external A/D to make work but it programs in tiny-basic . . . again, very easy to get up and running. Once you've digitized your non-linear data and corrected for sensor and tank geometry, there are LOTS of nice options for dealing with the new linear, accurate data. You can drive an el-cheapo LCD meter with the decimal point set to read out nearest tenth of a gallon out of 199.9 gallons max. You can drive a bar graph display. You can output the data in serial format for communication with other smart electro-whizzies on the panel. Get unhooked from the steam-gages and a whole new world of accuracy, stability and flexibility opens up for you. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: tone generator
alpath.net> >Thanks Bob, > >Is there anything I need to do differently for a 28V >airplane? > >Regards, > >Ray Stallings Increase the 150 ohm resistor to 1500 ohms Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: RE: Fuel State Detector
> > > Bob, I would like to construct a couple of the fuel detectors, that use >a... >Yes, Bob. Info please. I'd like to build a couple of these too! >John Slade > >PS I built an LED annunciator panel and it went to my head. When you can buy them ready to mount for about $40 each, it's not worth the time and trouble to build them. I've designed and built my last optical liquid level sensor. I'd sure look at http://www.ppavionics.com/LFL.htm Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: RE: Gear Warning Tone Generator
> > > Here's a circuit I used for a customer at Electro-Mech > > about 25 years ago. >Gee Bob. I wish I knew enough about electronics to build little gizmos like >this. I wonder if you would mind using this example to to give me (and >others) a shove over the last couple of hurdles into this facinating world. > >Let me make a start by attempting to interpret the drawing and come up with >a shopping list for Radio Shack: > >1. Breadboard >2. 100 ohm 1/2 watt resistor >3. Part # IN4742A >4. 10uf capacitor >5. Integrated circuit CD4093 with 14 terminals >6. 1k resistor (for starters) vary as needed for volume >7. .01 uf capacitor >8. 150 ohm resistor >9. .047 uf capacitor >10. 56k ohm resistor >11. 100k resistor >12. 4.7 uf capacitor > >How'd I do? >John Slade Quite well sir. Good for you! Just to make sure my recollection for parts sizes was in the ballpark I went to the workbench and bread-boarded the circuit as shown . . . http://216.55.140.222/temp/ToneGen.jpg This is an excellent candidate for a clad-board project. See http://www.aeroelectric.com/articles/cladboard/cladboard.html I'd build it up on a flat sheet first or breadboard as in the photo and get it working. Then, build a small box out of ECB material or sheet brass . . . all the parts can be (Ughh!) SOLDERED together. Put a 9-pin d-sub connector on one wall of the box. I'd shoot for about 1" x 2" by 3/4" thick. Assemble your tested circuit inside. Test one more time before you fill with spray-can insulation foam from lumber yard. After foam sets up, trim flush with top of your box and solder a lid on it. Cheap, dirty, and tough as a boot. Works good and lasts a long time. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
>Solutions, Inc" > >Bob, I would like to construct a couple of the fuel detectors, that use a >plastic rod. They look like they would be simple to construct and shouldn't >cost very much. You mentioned that you have constructed similar devices. > >I have two questions: > > 1. Where would you place the light source (infrared) in relation > to the >light sensor? My first thought would be to drill out a cavity that would >house the infrared LED and place the infrared sensor behind the LED. > > 2. What kind of plastic rod would not react to the various kinds of >auto/aviation that it might come in contact with and where can you purchase >that material? If really gotta go off and build one, consider clear polysulphone rod, high intensity red LED (cheap and plentiful) and photodetector of your choice . . . I used to make my own photo-transistors by cutting the top of a metal can device like a 2N2222A and using epoxy to mount the transistor in the back of the sensor assembly. Using 5/8" to 3/4" rod, you can cut a saw slot in one end to divide it in half and put a curtain between the light source and photo transistor. Thin aluminum or brass sheet works. Drill holes so that the photo detector and light source can be mounted either side of the curtain looking toward the sensor end of the rod. cut the rod to desired length and form 90 degree cone on end. Polish cut surfaces to optically clear quality. Devise means for mounting your assembly through the wall of a tank or better yet, put the whole thing inside the tank and bring only wires out. Devise means for exciting the LED (resistor from 5-12 volt source) and watching the photo transistor current (LM311 works well) and use LM311 to drive another LED on panel to indicate when the tip of your sensor is in/out of the liquid. None of this is hard to do, just tedious and lots of process and packaging issues to whip. Wouldn't do it from scratch like this unless there was an overwhelming reason for doing so. There are lots of folks who build them better than I can for a whole lot less money. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > > You betcha. I use a micro-controller with a built in > a/d to read the sensor and convert the reading to true > value based on a lookup table built into the software. > *** And for those who are software-challenged, the same thing can be done entirely in hardware. You take an A/D converter and have it drive a little ROM ( Read Only Memory ). The A/D converter supplies addresses to the ROM. The ROM data outputs go to a D/A converter which drives your meter. The only "programming" to be done is to put the output-voltage words into the ROM. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: Regulated power supply
Bob, or any of you electronically smart guys out there. I found a 10 amp regulated power supply on sale at local Radio Shack for $60. Is that big enough for testing circuitry in my VFR panel? Do have electric AH and Navaid wing leveler. Dale Ensing ________________________________________________________________________________
Date: Oct 29, 2002
Subject: How to do this . . .
Got a note from a reader having trouble dealing with the end of shielded wires getting a clean, compact connection to join the shield with one of the conductors under the shield. Went to the workbench and shot these photos . . . http://www.aeroelectric.com/temp/HowToDoThis Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
> When you can buy them ready to mount for about $40 each, > it's not worth the time and trouble to build them. I've > designed and built my last optical liquid level sensor. > > I'd sure look at http://www.ppavionics.com/LFL.htm > > Bob . . . > Unfortunately they are not very good to do business with. I originally designed my fuel system around one of their products. After I ordered it, he requested that I give him a US shipping address. I pointed out that I didn't live in the US, so what good would that do me? So he refunded my money. I guess he didn't really want to do business after all. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm RE: AeroElectric-List: RE: Fuel State Detector When you can buy them ready to mount for about $40 each, it's not worth the time and trouble to build them. I've designed and built my last optical liquid level sensor. I'd sure look at http://www.ppavionics.com/LFL.htm Bob . . . Unfortunately they are not very good to do business with. I originally designed my fuel system around one of their products. After I ordered it, he requested that I give him a US shipping address. I pointed out that I didn't live in the US, so what good would that do me? So he refunded my money. I guess he didn't really want to do business after all. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm ________________________________________________________________________________
Date: Oct 29, 2002
> >Del, > >Another and possibly easier approach would be a capacitance sender. > >Peter I've fiddled with these a bit . . . they are the technology of choice for linear fuel level measurement and indication but still suffer from linearization problems that beg the use of a micro-controller to straighten out the data. For single point liquid level sensing, it's difficult to beat opto and/or float switch techniques. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Fwd: Simple Light Dimmer?
Bob, I once made a light dimmer from an 2N3055 power transistor, 560 ohm resistor, a 0-5000 ohm pot and a capacitor to stop it from occillating. But, now I don't know how to wire it.(?) I mounted it right on the back of the pot and it works ok in my Long EZ. Do you have a forum or something? Where I can access your stuff. I did find your website. Thanks, John Perry I proposed just the gizmo you're describing to Cessna single engine facilities in 1966. See:
http://216.55.140.222/temp/1966Dimmer.pdf The single engine facility decided it wasn't a good it in the 310/320 series aircraft a few months later. This was the best we knew how to do in 1966. Problems with it then and now is the lack of robustness and the fact that the circuit is not a good voltage regulator. Little bumps in bus voltage will flash the panel lamps. A more modern approach is described at http://216.55.140.222/temp/DimFab.pdf This dimmer is a true output votlage regulator. Further, momentary shorts on the controller's output doesn't send the silicon off to the happy hunting grounds. The 1966 technique was used on MANY production aircraft up through the mid 80's . . . As far as I know, we did the first short circuit proof, true regulating lighting controllers for the Barons and Bonanzas while I worked at Electro-Mech about 1985. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
> >Bob, or any of you electronically smart guys out there. >I found a 10 amp regulated power supply on sale at local Radio Shack for $60. >Is that big enough for testing circuitry in my VFR panel? Do have electric AH >and Navaid wing leveler. >Dale Ensing Sure. You don't need to turn EVERYTHING on at once to test them. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: Cheap batteries
> >It looks like I got my $15.95 worth! >Both these MECI.COM batteries seem unable to take a charge. The charger sits >at 1.5 amps and the batteries read 11.2 volts until I give them a tiny bulb >to light up, then they drop to 8 volts and the bulb glows dimly. Is there a >trick to this, or are they total junk? Doesn't sound good. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
----- Message d'origine ----- De : "Jerry Kaidor" : Envoy : mardi 29 octobre 2002 17:31 Objet : Re: AeroElectric-List: 'linearizing' a fuel gauge > > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > > > > You betcha. I use a micro-controller with a built in > > a/d to read the sensor and convert the reading to true > > value based on a lookup table built into the software. > > > > *** And for those who are software-challenged, the same thing can be done > entirely in > hardware. You take an A/D converter and have it drive a little ROM ( Read > Only Memory ). > The A/D converter supplies addresses to the ROM. The ROM data outputs go to > a D/A converter which drives your meter. > > The only "programming" to be done is to put the output-voltage words into > the ROM. > > - Jerry Kaidor ( > jerry(at)tr2.com ) > > Bob and Jerry, Thank you for your replies. The principle seems clear. Nevertheless I'm afraid I'll need some more guidance to sort everytihing out : which A/D model, which ROM module, how do I hook them up, etc. Of course, when it comes to entering some instructions or values (via my PC ?), I hope I'll succed, but could you give me more detailed info ? Thanks Gilles ________________________________________________________________________________
Date: Oct 29, 2002
> I went to the workbench and bread-boarded the circuit > as shown . . . > > http://216.55.140.222/temp/ToneGen.jpg > Cool! That's just the kind of help I need. Now, one extra little question, if I may.... How do I make it beep intermittently, warble, squeal or otherwise get my attention better than a steady tone? John Slade ________________________________________________________________________________
Date: Oct 29, 2002
> > >With all the considerations, unfortunately, 28V is not really an option >for me. Components are already ordered, and not having automotive >compatability just won't suffice. 14V it is. > >My engine is the Continental IO-550N, with one of the AeroSupercharger >Solutions vortec superchargers on it. The supercharger is on the >co-pilot side, where the alternator usually is. Therefore, the kit >comes with a 60A alternator that is mounted on the pilot side to the >machined front plate that attaches to the front of the engine that also >holds the supercharger. AeroSS has been working with Kelly Aerospace to >offer other options. > >Kelly Aerospace is making a couple of 70A units, but neither is >available just yet. One would mount to the front and be belt driven >with the supercharger, just like the 60A unit. This is what I planned >to use, along with the B&C 20 on a pad. However, this combination is >proving to not be up to the task, unfortunately. The other Kelly unit >sounds promising though. It is a 70A unit that mounts to the pad on the >back of the engine. It is suppose to be available in a couple months. >If this unit would materialize, I would strongly consider installing 2 >of these units, one on each pad. Then, on my load analysis and buss >structure, I would just move the A/C to the AUX BUSS and be done. Also, >this would keep a supercharger belt breakage from attempting to ruin my >electrical day. Does this sound feasible? These are brand new units with no track record. Given what I've observed over the past 40 years efforts of GEAR DRIVING things off of engines that don't rotate smoothly . . . I am cautious and skeptical. The mechanical design problems are formidable. It would be great if they come to pass and have a service life equal to or hopefully MUCH better than most of the certified examples already out there but I'd hate to see your design become DEPENDENT upon their success. >As far as my buss structure; I understand your comment about it not >being extremely important at this time to have it all worked out. >However, to me it is, as I have to get the panel all cut and the labels >laser etched on the panel. If I change my mind later, then I have to >get the metal re-cut (not likely) or more than likely, I'll just have to >live with the changes that won't be properly reflected in the groupings >and labels on the panel. A picture of my preliminary panel can be seen >at >http://shannon.v8eaters.com/images/lancair/Knoepflein-l2k-092002.pdf >where you can see the groupings and labels I'm talking about. The more complex the airplane, the more important it is to design in flexibility. I recommend reverse engraved switch and breaker-panel overlays from Werner Berry http://www.sptpanel.com/instrument_panels.htm . . . with pre-drilled spares holes. Carving your nomenclature into large, hard to change panels pre-supposes you're going to get it exactly right the first time and are betting on never changing it. . . very long odds even when attempted by folks who have been designing airplanes for 40 years. > I want to >get this right the first time. It is not right now I know. > >I've done the 4th go-around on the spreadsheet. I think it's getting >closer. It's posted at >http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_4.xls > >Still looking for any and all comments and suggestions. Thanks. The airplane as you presently perceive it is going to be a truly amazing machine . . . my suggestion to you and other builders is to be cautious of the desire to build a show machine with everything but the kitchen sink. Having lots of toys does not necessarily translate into an equivalent level of flight system reliability. Lost a good friend some years back who was flying a C-210 WITH the kitchen sink. If ever there was an airplane outfitted for robustness against failure in the certified world, this was IT. What he really had was a complex system that added difficulties of understanding and offered few options for sorting good information from bad information. http://216.55.140.222/temp/DEN99FA034.pdf The airplane got away from him once and after recovery, with the adrenaline running 1000% over nominal he had to figure out what broke, and which set of instruments were really giving him the right information and then FLY those instruments. If I were building ANY class airplane in which it was my intent to spend lots of time in clouds, I would have dual, gps guided wing levelers running from independent power sources. This ensures that I have at least one system to keep the dirty side down and pointy end forward while I sorted things out and got my adrenaline levels back down. You've taken on a formidable task and if you have the cash and time, the machine of your dreams will come to pass. Be careful that the snowstorm of bells and whistles doesn't obscure or even hamper your grasp on the minimum equipment needed to comfortably end every flight irrespective of what fails. Every control, every new feature adds to a list of whizzy features that are fun to contemplate with our friends here on the list . . . but each has a dark side effect on our limitations as humans when things are not going well in the cockpit. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: CH701/Battery earth
> >Dear Bob, >I'm starting the wiring on mt CH701 with Rotax 912s. The a/c is all metal >with battery in rear fuselage. > >1/ Is it OK to earth the battery locally in the rear fuselage [ the >structure is very light ] or would it be better to bring an earth cable >all the way forward to the ground bus on the back of the firewall? That would be my choice. >2/The Rotax installation manual gives wire sizes in mm squared. Is there >a handy conversion table somewhere, mm squared to AWG ? 4AWG will suffice for the Rotax's cranking circuit. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
I looks like it would be cheaper and easier to install a capacitance fuel level system with the EIS probes (adjustable at 5 different levels). But this would be too simple. I too am interested in finding a solution to make the 240-33 gauges work. Right now, when empty is empty and full is full, mine shows 1/4 when I have 1/2 of fuel. One friend partly resolved the situation by adjusting the fuel sender arm so it shows full when there is 3/4 of fuel in the tank. But I would have liked to ear that we can solve this with a resistor arrangement or a simple fix. Michel --- Jerry Kaidor wrote: > Kaidor" > > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" > > > > > You betcha. I use a micro-controller with a > built in > > a/d to read the sensor and convert the reading > to true > > value based on a lookup table built into the > software. > > > > *** And for those who are software-challenged, the > same thing can be done > entirely in > hardware. You take an A/D converter and have it > drive a little ROM ( Read > Only Memory ). ===== ---------------------------- Michel Therrien CH601-HD http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby HotJobs - Search new jobs daily now http://hotjobs.yahoo.com/ ________________________________________________________________________________
Date: Oct 29, 2002
Michel, > > I looks like it would be cheaper and easier to install > a capacitance fuel level system with the EIS probes > (adjustable at 5 different levels). > It actually IS a capacitance type probe, that emulates a 240/33 probe. The gauges are UMA analog units. > But this would be too simple. I too am interested in > finding a solution to make the 240-33 gauges work. > Right now, when empty is empty and full is full, mine > shows 1/4 when I have 1/2 of fuel. Hence my posting. > > One friend partly resolved the situation by adjusting > the fuel sender arm so it shows full when there is 3/4 > of fuel in the tank. But I would have liked to ear > that we can solve this with a resistor arrangement or > a simple fix. > The thing looks quite easy to the electronic techies. But I'm unable to find my way in the A/D converter or EPROM stuff. Here is how I seem to understand things : In the principle, you convert your values from analog to digital, make the gizmo issue the correct output according to a table you entered in your EPROM after having filled your tanks bucket by bucket. Then you re-convert the output signal from digital to analog, in order for the gauge to display the correct reading. After some trial and error, one should come out with a reasonably linear indicator. But I'm at at a loss about how one could ACTUALLY accomplish that.... And do you need an extra device to flash the EPROM ? Would a kind guru please help with a detailed step by step ' Fuel gauge linearization for dummies' ? Thanks, Gilles ________________________________________________________________________________
Date: Oct 29, 2002
>The thing looks quite easy to the electronic techies. But I'm unable to find >my way in the A/D converter or EPROM stuff. >Here is how I seem to understand things : >In the principle, you convert your values from analog to digital, make the >gizmo issue the correct output according to a table you entered in your >EPROM after having filled your tanks bucket by bucket. Then you re-convert >the output signal from digital to analog, in order for the gauge to display >the correct reading. that's pretty accurate. >After some trial and error, one should come out with a reasonably linear >indicator. One trial, no error. You hit it right the first time. I fill the tank from a gas pump in .2 gallon increments and record the binary value output by the a/d converter. This technique assumes that for EVERY change in fuel volume there is SOME change in voltage . . . i.e. the float has to be free to move over empty to full. >But I'm at at a loss about how one could ACTUALLY accomplish that.... >And do you need an extra device to flash the EPROM ? Output from the A/D becomes an ADDRESS for the eprom. For each "address" output by the a/d, you have a true gallons value that needs to be programmed into the eprom. Output put from eprom is applied to a d/a which becomes a new analog value for display. I used to have several boards around to program eproms but I'm not even sure where they are now. Haven't needed one in 5 or 6 years. >Would a kind guru please help with a detailed step by step ' Fuel gauge >linearization for dummies' ? I prefer the micro-controllers cause all the stuff is in one chip and they're easily programmed and/or re-programmed from your PC. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 29, 2002
> > > I went to the workbench and bread-boarded the circuit > > as shown . . . > > > > http://216.55.140.222/temp/ToneGen.jpg > > >Cool! That's just the kind of help I need. >Now, one extra little question, if I may.... >How do I make it beep intermittently, warble, squeal or otherwise get my >attention better than a steady tone? >John Slade The schematic I published was used to emulate the intermittent beeping of a gear warning horn on the Bonanzas and Barons. That circuit drives an amplifier and speaker built into the same envelope as the original electro-mechanical warning horns. The circuit constants shown give you about 400 Hz tone beeped two times per second. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
> > When you can buy them ready to mount for about $40 each, > > it's not worth the time and trouble to build them. I've > > designed and built my last optical liquid level sensor. > > > > I'd sure look at http://www.ppavionics.com/LFL.htm > > > > Bob . . . > > > Unfortunately they are not very good to do business with. I >originally designed my fuel system around one of their products. After I >ordered it, he requested that I give him a US shipping address. I pointed >out that I didn't live in the US, so what good would that do me? So he >refunded my money. I guess he didn't really want to do business after all. Just checked his website where I found: "NOTE: Shipping charges shown are for FedEx Ground, within the United States. Non-US customers please email us for shipping costs. For multiple-item purchases, subtract the "shipping credit" from the total." How long ago did you talk to him? Perhaps he has acquired a new view of the world economy since then. These are really small gizmos. They would ship very inexpensively through the mails. If push comes to shove, I'll buy them and ship them to you. Bob. . . ________________________________________________________________________________
Date: Oct 29, 2002
Now I'm confused. Your B&C unit is gear driven also, but it's not prone to the same failures? I don't understand. Are you suggesting to stick with a belt driven unit along with a gear driven unit, over 2 gear driven units? On the panel overlays...Lancair is building my panel. The basic panel will have aluminum inserts with the holes cut. As I understand it, the standard practice is to powdercoat this insert, and then have it laser etched for the labels and whatnot. I've followed the link you provided, but don't understand how this overlay would interface with my inserts. Would it overlay the whole panel in which Lancair wouldn't have to do any laser etching, or would it just overlay parts of it, or would it completely replace what Lancair has already cut? I'm sorry to hear and read about your friend. I understand what you are saying. Building in that robustness and simplicity is what I'm trying to do, as well as make it simple during failure. I've tried to think through every failure and how to handle them. I've tried to be as complete as possible during the planning stages, and that's why I ask so many questions. I could list all the failure modes and my proposed solution, but that would take a while. Your basic Z14 system design is so well thought out and robust, that little else is needed. With the "kitchen sink", as you call it, in my plane, I feel it is important to have an ESS bus linked off of one of the busses so I can quickly shed load and have just the essentials on it. The essentials to me are an attitude indicator (SFS w/ AHRS, and a backup 2" AI), gps, audio panel, com, autopilot, and transponder. Since the SFS is in my list, and since it unfortunately needs to be "pampered", I have to hide it behind a switch. In my experience, a relay is more robust than a switch, so in my design, I'll use a NC relay that is activated by a switch. Switch fails, bus is on. Relay fails, bus is on. Some failure that results in neither of the above working, I'll have an ALT FEED, as outlined in your diagrams. If the SFS didn't have to be "pampered", forget the switch and relay. However, I don't have that option. I could put the switch between the ESS bus and the SFS. However, I like the added feature of just shutting it all off, and feel the NC relay along with the ALT FEED switch adequately backs it up. The basic failure modes are pretty simple: if an alternator goes out, turn it off and use the crossfeed; if a contactor goes out use the crossfeed and possibly the ALT FEED, etc, etc. I think the ultimate failure would be power out engine failure (or both alts), so you have no alts. In this case, in my design I would first turn the ESS ALT FEED on, and then turn both battery contactors and alternator fields off. The remaining equipment that would be running is listed in my spreadsheet and above in my ESS list. I honestly feel I could accomplish this changeover in less than 2 seconds (one switch on, two double switches off) after the problem was realized. This results in an amp draw of 10.75 amps off of the AUX battery. If I understand correctly, this should leave me with 17/10.75=1.6 hours of runtime on the ESS components....all with the flip of 3 switches. Now, with all that said (that was a little look at what is going on in my head), I'd like to hear your personal design. You said that "that is not the way I would do it if it was my plane". So, please tell us how you would do it with the equipment I've selected. I think that would be a very enlightening exercise for all the readers and current system builders to see. Then we can see your thought process and hopefully walk away more educated, smarter, and with safer systems. You've obviously been doing this a lot longer than most of us, so I'm sure we could all benefit from seeing how you'd do it with my equipment. The sheer "kitchen-sinkness" of my equipment list should cover all basis's for any future readers looking for the same guidance. Also, (as if that wasn't enough), I need more info on your proposed dual wing levelers. I assume you mean some sort of autopilot, or are you discussing something else? I plan the trutrak as my primary, but would consider putting something else on the other bus (a much simpler system I assume than a 3axis trutrak?). Would this require another servo on the ailerons? The trutrak gets its gyro info from its own internal gyro (mini fast-resetting AHRS if I understand correctly). Where would the additional wind leveler get its info? Can you recommend a simple wing leveler? As always, thanks for taking the time.... --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Shannon's Lancair system . . . > > >With all the considerations, unfortunately, 28V is not really an option >for me. Components are already ordered, and not having automotive >compatability just won't suffice. 14V it is. > >My engine is the Continental IO-550N, with one of the AeroSupercharger >Solutions vortec superchargers on it. The supercharger is on the >co-pilot side, where the alternator usually is. Therefore, the kit >comes with a 60A alternator that is mounted on the pilot side to the >machined front plate that attaches to the front of the engine that also >holds the supercharger. AeroSS has been working with Kelly Aerospace to >offer other options. > >Kelly Aerospace is making a couple of 70A units, but neither is >available just yet. One would mount to the front and be belt driven >with the supercharger, just like the 60A unit. This is what I planned >to use, along with the B&C 20 on a pad. However, this combination is >proving to not be up to the task, unfortunately. The other Kelly unit >sounds promising though. It is a 70A unit that mounts to the pad on the >back of the engine. It is suppose to be available in a couple months. >If this unit would materialize, I would strongly consider installing 2 >of these units, one on each pad. Then, on my load analysis and buss >structure, I would just move the A/C to the AUX BUSS and be done. Also, >this would keep a supercharger belt breakage from attempting to ruin my >electrical day. Does this sound feasible? These are brand new units with no track record. Given what I've observed over the past 40 years efforts of GEAR DRIVING things off of engines that don't rotate smoothly . . . I am cautious and skeptical. The mechanical design problems are formidable. It would be great if they come to pass and have a service life equal to or hopefully MUCH better than most of the certified examples already out there but I'd hate to see your design become DEPENDENT upon their success. >As far as my buss structure; I understand your comment about it not >being extremely important at this time to have it all worked out. >However, to me it is, as I have to get the panel all cut and the labels >laser etched on the panel. If I change my mind later, then I have to >get the metal re-cut (not likely) or more than likely, I'll just have to >live with the changes that won't be properly reflected in the groupings >and labels on the panel. A picture of my preliminary panel can be seen >at >http://shannon.v8eaters.com/images/lancair/Knoepflein-l2k-092002.pdf >where you can see the groupings and labels I'm talking about. The more complex the airplane, the more important it is to design in flexibility. I recommend reverse engraved switch and breaker-panel overlays from Werner Berry http://www.sptpanel.com/instrument_panels.htm . . . with pre-drilled spares holes. Carving your nomenclature into large, hard to change panels pre-supposes you're going to get it exactly right the first time and are betting on never changing it. . . very long odds even when attempted by folks who have been designing airplanes for 40 years. > I want to >get this right the first time. It is not right now I know. > >I've done the 4th go-around on the spreadsheet. I think it's getting >closer. It's posted at >http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_4.xls > >Still looking for any and all comments and suggestions. Thanks. The airplane as you presently perceive it is going to be a truly amazing machine . . . my suggestion to you and other builders is to be cautious of the desire to build a show machine with everything but the kitchen sink. Having lots of toys does not necessarily translate into an equivalent level of flight system reliability. Lost a good friend some years back who was flying a C-210 WITH the kitchen sink. If ever there was an airplane outfitted for robustness against failure in the certified world, this was IT. What he really had was a complex system that added difficulties of understanding and offered few options for sorting good information from bad information. http://216.55.140.222/temp/DEN99FA034.pdf The airplane got away from him once and after recovery, with the adrenaline running 1000% over nominal he had to figure out what broke, and which set of instruments were really giving him the right information and then FLY those instruments. If I were building ANY class airplane in which it was my intent to spend lots of time in clouds, I would have dual, gps guided wing levelers running from independent power sources. This ensures that I have at least one system to keep the dirty side down and pointy end forward while I sorted things out and got my adrenaline levels back down. You've taken on a formidable task and if you have the cash and time, the machine of your dreams will come to pass. Be careful that the snowstorm of bells and whistles doesn't obscure or even hamper your grasp on the minimum equipment needed to comfortably end every flight irrespective of what fails. Every control, every new feature adds to a list of whizzy features that are fun to contemplate with our friends here on the list . . . but each has a dark side effect on our limitations as humans when things are not going well in the cockpit. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: batt buss
Date: Oct 29, 2002
With a battery buss that has the circuit breakers in the panel, which would you suggest: an appropriately sized ANL current limiter or a fuse at the battery end to protect the 8-10 gauge wire? --- Shannon Knoepflein <---> kycshann(at)kyol.net ________________________________________________________________________________
Date: Oct 29, 2002
That sounds great and simple... so would anyone on this list propose to sell a little black box that would linearize my senders' outputs? I would provide the resistance for various fuel levels of each one of my two probes and that individual would make and program that black box for me. All I'd have to do is to pay for it and install it in my plane. It seems that this could be a very good and viable commercial product. And I think that the same box would work with any resistive fuel senders. How much would that be worth? If it is reasonable, I'm definitively a buyer. Michel > >the correct reading. > > that's pretty accurate. > > >After some trial and error, one should come out > with a reasonably linear > >indicator. > > One trial, no error. You hit it right the first > time. > I fill the tank from a gas pump in .2 gallon > increments > and record the binary value output by the a/d > converter. This > technique assumes that for EVERY change in fuel > volume > there is SOME change in voltage . . . i.e. the > float > has to be free to move over empty to full. > > >But I'm at at a loss about how one could ACTUALLY > accomplish that.... > >And do you need an extra device to flash the EPROM > ? > > Output from the A/D becomes an ADDRESS for the > eprom. > For each "address" output by the a/d, you have a > true > gallons value that needs to be programmed into > the eprom. > Output put from eprom is applied to a d/a which > becomes > a new analog value for display. > > I used to have several boards around to program > eproms > but I'm not even sure where they are now. Haven't > needed > one in 5 or 6 years. > > > >Would a kind guru please help with a detailed step > by step ' Fuel gauge > >linearization for dummies' ? > > I prefer the micro-controllers cause all the > stuff is > in one chip and they're easily programmed and/or > re-programmed from your PC. > ===== ---------------------------- Michel Therrien CH601-HD http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby HotJobs - Search new jobs daily now http://hotjobs.yahoo.com/ ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Oct 29, 2002
I might be persuaded to do such a "black box". It depends a little on how soon everyone would have to have it. My plate is pretty full the rest of this year, but if everyone could wait 4 - 6 months for the end product, I could probably meet that kind of a deadline. David Swartzendruber Wichita > > That sounds great and simple... so would anyone on > this list propose to sell a little black box that > would linearize my senders' outputs? > > I would provide the resistance for various fuel levels > of each one of my two probes and that individual would > make and program that black box for me. All I'd have > to do is to pay for it and install it in my plane. > > It seems that this could be a very good and viable > commercial product. And I think that the same box > would work with any resistive fuel senders. > > How much would that be worth? If it is reasonable, > I'm definitively a buyer. > > Michel > > ________________________________________________________________________________
Date: Oct 29, 2002
Bob, thank you for responding. > > >After some trial and error, one should come out with a reasonably linear > >indicator. > > One trial, no error. You hit it right the first time. > I fill the tank from a gas pump in .2 gallon increments > and record the binary value output by the a/d converter. This > technique assumes that for EVERY change in fuel volume > there is SOME change in voltage . . . i.e. the float > has to be free to move over empty to full. The probe is actually a capacitive device thart emulates a resistive probe. My buddy helped in the liter by liter fuel handling in another more advanced plane. The probe seems to be sufficiently sensitive. > > >But I'm at at a loss about how one could ACTUALLY accomplish that.... > >And do you need an extra device to flash the EPROM ? > > Output from the A/D becomes an ADDRESS for the eprom. > For each "address" output by the a/d, you have a true > gallons value that needs to be programmed into the eprom. Understand. > Output put from eprom is applied to a d/a which becomes > a new analog value for display. OK > > I used to have several boards around to program eproms > but I'm not even sure where they are now. Haven't needed > one in 5 or 6 years. > If we go for an eprom, maybe we'd better ask some electronics teacher in school. > >Would a kind guru please help with a detailed step by step ' Fuel gauge > >linearization for dummies' ? > > I prefer the micro-controllers cause all the stuff is > in one chip and they're easily programmed and/or > re-programmed from your PC. > Micro-controller ? I like the idea. But what's it like ? Any suggestion for a shopping list I could hand to the man behind the counter at the 'Shack or else ? Surely it includes some connecting device, maybe an RS-232 connector I could hook my PC on ? And hopefully a sheet with the basic commands and programming instructions, maybe in assembling language ? Any info will be appreciated. Thanks, Gilles ________________________________________________________________________________
Date: Oct 29, 2002
Tell me what to plan for and I'll be OK. I assume that from my standpoint, I need to plan for installing a small box such as this one: http://mthobby.pcperfect.com/ch601/DCP01829.JPG And it would have similar terminals for the following connections: . +12V . GND . Sender . Fuel Gauge (Sender connection) Would that be it? If yes, it means that it would be really easy to retrofit the system at any time and thus, you can take your time to do it. Michel --- David Swartzendruber wrote: > Swartzendruber" > > I might be persuaded to do such a "black box". It > depends a little on > how soon everyone would have to have it. My plate > is pretty full the > rest of this year, but if everyone could wait 4 - 6 > months for the end > product, I could probably meet that kind of a > deadline. > > David Swartzendruber > Wichita > > > > > That sounds great and simple... so would anyone on > > this list propose to sell a little black box that > > would linearize my senders' outputs? > > > > I would provide the resistance for various fuel > levels > > of each one of my two probes and that individual > would > > make and program that black box for me. All I'd > have > > to do is to pay for it and install it in my plane. > > > > It seems that this could be a very good and viable > > commercial product. And I think that the same box > > would work with any resistive fuel senders. > > > > How much would that be worth? If it is > reasonable, > > I'm definitively a buyer. > > > > Michel > > > > > > > > Forum - > Contributions of > any other form > > latest messages. > other List members. > > aeroelectric-list(at)matronics.com > http://www.matronics.com/subscription > http://www.matronics.com/photoshare > http://www.matronics.com/browselist/aeroelectric-list > http://www.matronics.com/search > http://www.matronics.com/archives > http://www.matronics.com/emaillists > > > > > ===== ---------------------------- Michel Therrien CH601-HD http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby HotJobs - Search new jobs daily now http://hotjobs.yahoo.com/ ________________________________________________________________________________
Date: Oct 29, 2002
> If push comes to shove, I'll buy them and ship them to > you. > > Bob. . . > > Hi Bob; Thanks for the offer, but I've since redesigned that portion of my fuel system and believe I have a better, simpler solution. Something's are blessings in disguise. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm RE: AeroElectric-List: RE: Fuel State Detector If push comes to shove, I'll buy them and ship them to you. Bob. . . Hi Bob; Thanks for the offer, but I've since redesigned that portion of my fuel system and believe I have a better, simpler solution. Something's are blessings in disguise. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm ________________________________________________________________________________
Date: Oct 29, 2002
Subject: RE: 'linearizing' a fuel gauge
> > >I might be persuaded to do such a "black box". It depends a little on >how soon everyone would have to have it. My plate is pretty full the >rest of this year, but if everyone could wait 4 - 6 months for the end >product, I could probably meet that kind of a deadline. Dave, go peek at
http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?code=68HC908QT4&nodeId=01M98634 There's a $19 development system from Digikey search on "M68DEMO908QT4" or a board layout for the development board at: http://e-www.motorola.com/collateral/M68DEMO908QT4MECH.pdf http://e-www.motorola.com/collateral/M68DEMO908QT4SCH.pdf this critter programs in our favorite source code syntax. All of the PC based programming and de-bugging tools are downloadable for free. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Subject: Re: batt buss
> > >With a battery buss that has the circuit breakers in the panel, which >would you suggest: an appropriately sized ANL current limiter or a fuse >at the battery end to protect the 8-10 gauge wire? I presume your talking about extending the battery bus to some place remote from the battery. I cannot recommend doing that nor suggest any techniques that would facilitate that action. Bob . . . ________________________________________________________________________________
Date: Oct 29, 2002
Robert L. Nuckolls, III wrote: > > >Would a kind guru please help with a detailed step by step ' Fuel gauge > >linearization for dummies' ? > > I prefer the micro-controllers cause all the stuff is > in one chip and they're easily programmed and/or > re-programmed from your PC. > *** Actually, so do I. And that Motorola chip that Bob pointed out is nothing short of amazing. Am I to understand that it's an 8-pin DIP with its own ROM, RAM, D/A and timer/PWM unit? Wow. One should be able to use the PWM ( Pulse Width Modulation ) thing as an ersatz analog output. To make the needle swing high, you make the pulse wide. To make the needle swing low, you make the pulse narrow. The program would consist of a little tiny loop: thus: top_of_loop: x = ADC_reading y = conversion_table[ x ] pwm = y goto top_of_loop ...round & round & round she goes... This would probably use a fraction of a percent of the little CPU's power. If there are any I/O pins left, it'd be awful tempting to add a line like this in the middle of the loop somewhere: if( x < 13 ) then light the low-fuel light. The "13" is of course whatever # you judged to mean "low fuel". You could even have multiple lights: if( x < 20 ) then light the no-takeoff light. You could even have it doing periodic tasks totally unrelated to fuel, but that's probably confusing at maintenance time. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 29, 2002
Todd, > fuel system and believe I have a better, simpler solution. >Something's are blessings in disguise. Well? Dont keep us all in suspense. One thought I had was that the capacitance gauge puts out a variable voltage - how hard could it be to have a circuit that switched on an LED at a certain adjustable voltage? ________________________________________________________________________________
Subject: Re: RE: 'linearizing' a fuel gauge
Date: Oct 29, 2002
I just ordered the $19 development system from Digikey. This has got to be about the simplest microcontroller project you could ask for. What is the max number of fuel probes any one airplane will have? I would think that two would be common, (one in each wing). One fuel signal conditioner could "linearize" both fuel probes. The connections would then be: +12V GND Sender1 Sender2 Fuel Gauge 1 Fuel Gauge 2 and as Jerry suggested, you could have Low Fuel Lamp 1 Low Fuel Lamp 2 One 9-pin D-sub could handle it all, and the whole board may fit in the D-Sub Backshell like you've done before Bob. David Swartzendruber Wichita > Dave, go peek at > > http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?code=68HC908QT4&n odeId=01M98634 > > There's a $19 development system from Digikey > search on "M68DEMO908QT4" > > or a board layout for the development board at: > > http://e-www.motorola.com/collateral/M68DEMO908QT4MECH.pdf > http://e-www.motorola.com/collateral/M68DEMO908QT4SCH.pdf > > this critter programs in our favorite source code > syntax. > > All of the PC based programming and de-bugging tools > are downloadable for free. > > Bob . . . > ________________________________________________________________________________
Date: Oct 29, 2002
> > >I just ordered the $19 development system from Digikey. This has got to be >about the simplest microcontroller project you could ask for. What is the >max number of fuel probes any one airplane will have? I would think that >two would be common, (one in each wing). One fuel signal conditioner could >"linearize" both fuel probes. I was wondering about that but I think the pwm timer will only drive one port at a time . . . but at about $3 a chip, who cares if it takes two? >The connections would then be: >+12V >GND >Sender1 >Sender2 >Fuel Gauge 1 >Fuel Gauge 2 >and as Jerry suggested, you could have >Low Fuel Lamp 1 >Low Fuel Lamp 2 > >One 9-pin D-sub could handle it all, and the whole board may fit in the >D-Sub Backshell like you've done before Bob. Funny you should think about that. I think I'd go for the 15-pin d-sub shell just to get the real-estate inside the shell. Or go 9-pin on an open board like http://216.55.140.222/temp/MVC-138X.JPG Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Microair T2000 transponder obsoleted?
Date: Oct 29, 2002
I have heard the Microair T2000 transponder has been obsoleted. Can anyone confirm this and does anyone know how the new model will differ and availability, price, etc. of the new model. Thanks, Rick Fogerson RV3 fuselage near finish Boise, ID ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Subject: Re: RE: Fuel State Detector
Date: Oct 30, 2002
Hello Todd, very strange, I'm located in Switzerland and had no problem at all to order and receive the aux tank switch and the low level warning devices. Everything went very smooth, as I did order for more then one set, I even got some discount without asking for it. Also the advice how to mount them into my header tanks was for free and very much appreciated. So I have a problem to understand what went wrong when you've tried to do business with them. Werner ----- Original Message ----- From: "Bartrim, Todd" <sbartrim(at)mail.canfor.ca> Subject: RE: AeroElectric-List: RE: Fuel State Detector > > > > When you can buy them ready to mount for about $40 each, > > it's not worth the time and trouble to build them. I've > > designed and built my last optical liquid level sensor. > > > > I'd sure look at http://www.ppavionics.com/LFL.htm > > > > Bob . . . > > > Unfortunately they are not very good to do business with. I > originally designed my fuel system around one of their products. After I > ordered it, he requested that I give him a US shipping address. I pointed > out that I didn't live in the US, so what good would that do me? So he > refunded my money. I guess he didn't really want to do business after all. > > S. Todd Bartrim > Turbo 13B rotary powered > RX-9endurance (FWF) > C-FSTB (reserved) > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > > > > > RE: AeroElectric-List: RE: Fuel State Detector > > > When you can buy them ready to mount for about $40 each, > > it's not worth the time and trouble to build them. I've > > designed and built my last optical liquid level sensor. > > > I'd sure look at http://www.ppavionics.com/LFL.htm > > > Bob . . . > > > Unfortunately they are not very good to do business with. I originally designed my fuel system around one of their products. After I ordered it, he requested that I give him a US shipping address. I pointed out that I didn't live in the US, so what good would that do me? So he refunded my money. I guess he didn't really want to do business after all. > > > S. Todd Bartrim > > Turbo 13B rotary powered > > RX-9endurance (FWF) > > C-FSTB (reserved) > > > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 30, 2002
What about recalibrating the markings on the gauge face? Really you guys make something simple so hard. Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gilles.thesee Subject: Re: AeroElectric-List: 'linearizing' a fuel gauge --> <Gilles.Thesee@ac-grenoble.fr> Michel, > > I looks like it would be cheaper and easier to install > a capacitance fuel level system with the EIS probes (adjustable at 5 > different levels). > It actually IS a capacitance type probe, that emulates a 240/33 probe. The gauges are UMA analog units. > But this would be too simple. I too am interested in > finding a solution to make the 240-33 gauges work. > Right now, when empty is empty and full is full, mine > shows 1/4 when I have 1/2 of fuel. Hence my posting. > > One friend partly resolved the situation by adjusting > the fuel sender arm so it shows full when there is 3/4 > of fuel in the tank. But I would have liked to ear > that we can solve this with a resistor arrangement or > a simple fix. > The thing looks quite easy to the electronic techies. But I'm unable to find my way in the A/D converter or EPROM stuff. Here is how I seem to understand things : In the principle, you convert your values from analog to digital, make the gizmo issue the correct output according to a table you entered in your EPROM after having filled your tanks bucket by bucket. Then you re-convert the output signal from digital to analog, in order for the gauge to display the correct reading. After some trial and error, one should come out with a reasonably linear indicator. But I'm at at a loss about how one could ACTUALLY accomplish that.... And do you need an extra device to flash the EPROM ? Would a kind guru please help with a detailed step by step ' Fuel gauge linearization for dummies' ? Thanks, Gilles = = = http://www.matronics.com/browselist/aeroelectric-list = http://www.sold.com.au - SOLD.com.au - Find yourself a bargain! ________________________________________________________________________________
Subject: batt buss
Date: Oct 30, 2002
I don't necessarily want to extend it, but I want to have the CB's in the panel with the rest of them. Therefore, the wire that runs from the battery to the circuit breakers needs protection at the battery end. I was considering a ANL limiter or a fuse, but didn't know which to use. Why is this a problem? Here is the stuff on the bat bus: Door Seal Cabin Lights Dimmable Panel Lighting Power Points Fuel Trans Pump Fuel Boost Pump (High/Low) I want the CB's in the panel mainly for the fuel pump. If the high/low switch fails with the fuel pump stuck on High, it can actually flood the engine and kill it. Therefore, I want to be able to remove power. Why is this a problem? What would you suggest? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: batt buss > > >With a battery buss that has the circuit breakers in the panel, which >would you suggest: an appropriately sized ANL current limiter or a fuse >at the battery end to protect the 8-10 gauge wire? I presume your talking about extending the battery bus to some place remote from the battery. I cannot recommend doing that nor suggest any techniques that would facilitate that action. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
From: "gilles.thesee" <Gilles.Thesee@ac-grenoble.fr>
Date: Oct 30, 2002
----- Message d'origine ----- De : "Ian Scott" : Envoy : mercredi 30 octobre 2002 12:15 Objet : RE: AeroElectric-List: 'linearizing' a fuel gauge > > What about recalibrating the markings on the gauge face? > > Really you guys make something simple so hard. > > Ian > Ian, I wouldn't care to open a brand new guaranted indicator just to change the markings. Besides, when in flight, we often judge the indication just by glancing at the pointers. What about a pointer position right half way between zero and full, but meaning only 1/8 or 1/6th tank ? Or the alarm LED turning on at 1/2 tank ? I'd prefer calibrating the whole system just to have the indicator reasonably reflecting the actual situation inside the tank. It seems to me far easier to install a small calibrating gizmo, PROVIDED someone far more knowledgeable than I am was kind enough to help in the design at a -hopefully- reasonable cost ;-) Cheers Gilles ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Load Analysis
Shannon - I've looked at your load analysis and have a couple of questions regarding how you calculated the loads for some of the equipment. We are also installing a Tru Trak DFC 250 autopilot. The books calls for 1 amp for the controller and 2 amps each for the two servos (pitch & roll). Since one would be using the autopilot for cruise, climb and descent, I would think that the load would be closer to 5 amps than the 1 that you show. The servos work almost constantly, especially in turbulence. For the Garmin 430, you show only .5 amp. The Apollo multi-purpose units have a separate breaker/power source for each purpose. I can't see how .5 amp can cover all of the functions of the Garmin, especially with the display running constantly and the need to transmit frequently on the VHF during IFR flight. You show a footnote that indicates your interest in a PRISM. As I understand the product, they include their "Supplenator" as a mandatory source of power for the system. This is a self exciting alternator that puts out about 40 amps and needs a pad on the engine for mounting. I do not mean to complicate your already difficult problem of putting 10 pounds into a 5 pound paper bag, but if you have some kind of calculation for reducing the nominal values published by the equipment manufacturers, we would appreciate getting a copy. It just seems that the loads you show and plan for are on the lighter side of the fence - and in my experience, the bag always breaks at the wrong time. Bob: If you have some kind of calculation/table of values, we would appreciate getting a copy. We are working on our load analysis and wonder how to calculate steady state values that can be less than those specified by the manufacturers. Many thanks, John ________________________________________________________________________________
Subject: Re: 'linearizing' a fuel gauge
Date: Oct 30, 2002
Avilec do exactly what you want (complete system) -as fitted to various Europas. M ________________________________________________________________________________
Date: Oct 30, 2002
John, You are totally correct on the Tru-trak. I originally only figured 1.0 amp on the load analysis, thinking that the servos would be intermittent and could be pulled from the battery. Now that I think about it, your analysis is probably a lot more accurate. I'll make the change. Also, yesterday I stated that my Tru-trak was a 3 axis when I was asking bob about a wing leverler....this was incorrect, mine is the same as yours, 2 axis. As for the garmin, I was showing it in the RX state. Actually, there are 2 lines for the garmin (it has separate sources too from what I understand), .5 each, so 1.0 total. I'm not sure how to handle the RX versus TX draw in the load analysis, but I agree my numbers are probably on the low side when on TX (probably about 5 amps then?). I'd love to see some hard numbers on the garmin and the Apollo. Once I understand how to account for this, I'll make the changes. Any suggestions? Yes, I realize the PRISM is suppose to have the supplenator. I'm going out to GAMI the middle of November for one of their new engine seminars, so I should have a lot more details at that point. I'm not holding my breath for the system though, and my planning will go on like its not going to be there. The Kelly units I plan are their standard unit with an attached gear drive, so if I do have to use the supplenator, I will just move the one Kelly to be belt driven from the front. That's my plan anyway. Worst case, I won't use a supplenator...afterall, it is my plane :) (nothing is mandatory) I appreciate your thoughts, and your sympathy for my plight. Unfortunately, I have no magic calculations for defying the laws of physics--I just made some mistakes that you pointed out. Do you see any other mistakes, or have any recommendations bus wise, etc? I'm open to all suggestions. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Schroeder Subject: AeroElectric-List: Load Analysis Shannon - I've looked at your load analysis and have a couple of questions regarding how you calculated the loads for some of the equipment. We are also installing a Tru Trak DFC 250 autopilot. The books calls for 1 amp for the controller and 2 amps each for the two servos (pitch & roll). Since one would be using the autopilot for cruise, climb and descent, I would think that the load would be closer to 5 amps than the 1 that you show. The servos work almost constantly, especially in turbulence. For the Garmin 430, you show only .5 amp. The Apollo multi-purpose units have a separate breaker/power source for each purpose. I can't see how .5 amp can cover all of the functions of the Garmin, especially with the display running constantly and the need to transmit frequently on the VHF during IFR flight. You show a footnote that indicates your interest in a PRISM. As I understand the product, they include their "Supplenator" as a mandatory source of power for the system. This is a self exciting alternator that puts out about 40 amps and needs a pad on the engine for mounting. I do not mean to complicate your already difficult problem of putting 10 pounds into a 5 pound paper bag, but if you have some kind of calculation for reducing the nominal values published by the equipment manufacturers, we would appreciate getting a copy. It just seems that the loads you show and plan for are on the lighter side of the fence - and in my experience, the bag always breaks at the wrong time. Bob: If you have some kind of calculation/table of values, we would appreciate getting a copy. We are working on our load analysis and wonder how to calculate steady state values that can be less than those specified by the manufacturers. Many thanks, John = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: Electro-whizzies.....
Date: Oct 30, 2002
Bob, As a longtime disciple I have managed to tag along, acquiring experience and understanding old advice. By way of explanation, I have measured the height of fuel from 1 cm. to the top of the inlet port in litres and have graphed it to reveal a fairly constant relationship in two parts. My interest is in translating the depth of a very convoluted fuel tank into litres etc. However I have been left out to dry on the latest topic, the Motorola micro-controller 68HC908QT4. I went to the page and couldn't understand a thing. I appreciate it's powerful, but it appears that one requires about two hundred pieces of literature to utilize it, few of which seem to escape gibberish in the titling. In addition, they show about five different sizes of 'bug' and refer to such things as 'roadmaps' where there are no roads. Is there a dictionary to translate this into English? I also plumbed the dark recesses of the Basic Stamp (?) without ever breaking the code. Where can I start from scratch to comprehend these barriers? I realise this may be a massive crusade to take a small hand and guide it out of the forest............. From a steamdriven rockbound triode-heater........ Ferg Europa A064 ________________________________________________________________________________
Date: Oct 30, 2002
----- Message d'origine ----- De : "Miles McCallum" : Envoy : mercredi 30 octobre 2002 13:36 Objet : Re: AeroElectric-List: 'linearizing' a fuel gauge > > Avilec do exactly what you want (complete system) -as fitted to various > Europas. > > M > Hi, Found something on Avelec website. But I'm afraid they sell a complete system, with senders and all. We already have the gauges in place, the senders are defined, what we need is linearize the readings. cheers, Gilles ________________________________________________________________________________
Date: Oct 30, 2002
Subject: RE: batt buss
> > >I don't necessarily want to extend it, but I want to have the CB's in >the panel with the rest of them. Therefore, the wire that runs from the >battery to the circuit breakers needs protection at the battery end. I >was considering a ANL limiter or a fuse, but didn't know which to use. >Why is this a problem? > >Here is the stuff on the bat bus: The general rule of thumb for any always hot wire in a certified airplane is 5A or less in the size of it's feeder protection. Battery busses have been classically used to power things that MUST be available whether or not any of the ship's power distribution systems are hot. These would include things like emergency lighting, utility lighting, clocks, radio memories, and in OBAM aircraft, I've suggested that electrically dependent engines should be battery bus powered. I would also avoid the use of breakers because in spite of their current rating, they are capable of delivering 10x to 1000x more energy into a faulted line BEFORE opening than a fuse which is very fast. In the interest of maximizing crashworthiness of the airplane, fuses are preferred. >Door Seal >Cabin Lights >Dimmable Panel Lighting >Power Points >Fuel Trans Pump >Fuel Boost Pump (High/Low) > >I want the CB's in the panel mainly for the fuel pump. If the high/low >switch fails with the fuel pump stuck on High, it can actually flood the >engine and kill it. Therefore, I want to be able to remove power. I've never seen a switch fail in an "ON" position except on that was so badly abused that it welded the contacts closed. This ain't gonna happen on a fuse protected, boost pump circuit. Why is the door seal on the battery? Further, panel lighting can take lots of amps . . . I'd put a gooseneck map light or perhaps a single fixture overhead flood on the battery but not general panel lighting. You've already got the most robust, failure tolerant system to have ever flown in a light airplane. Likelihood of power not being available from either the main bus or aux bus to run necessary things is extremely low. So think of battery busses as supporting things that need to run with the main systems are OFF either by reason of having parked the airplane or deliberately shut off due to smoke in the cockpit to give you a more elbow room to sort out the next step without having the engine quit. In my airplane, battery busses are fuse blocks located adjacent to the battery and fitted with the smallest practical fuse to power the system of interest. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> >What about recalibrating the markings on the gauge face? > >Really you guys make something simple so hard. > >Ian Simple IF: The analog instrument is a style that lends itself to being disassembled and re-scaled . . . The instrument is not a digital readout that shows percent or other kind of fuel quantity . . . --------- I've re-scaled a lot of instruments but I've never been able to make my instrument look just like the rest of the instruments unless I made them all. Putting some kind of electronic data conditioning allows one to re-calibrate the system due to influences of age without having to pull the senders. It also allows one to add features like low fuel warning lights with almost no added cost or effort. My first car was a '41 Pontiac I paid $25 for. My present car is 54 years younger and cost 500 times as much. The fuel gages in BOTH vehicles are !#@$!@#$. EITHER vehicle would have benefited from some circuitry as simple as having a potentiometer to set the zero and full scale readings for the instrument. Jelly-bean micro-controllers add still another opportunity to build OUR airplanes as if they were designed in 2002 instead of 1952. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: RE: Fuel State Detector
> > >One thought I had was that the capacitance gauge puts out a variable >voltage - how hard could it be to have a circuit that switched on an LED at >a certain adjustable voltage? Not difficult. In fact, that's stone simple if you're using a micro-controller to do the signal processing. It's a minor-revision to a circuit like our aux battery management module to operate a light above/below a set voltage level. Schematics have been published on my website. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
----- Message d'origine ----- De : "Robert L. Nuckolls, III" : Envoy : mercredi 30 octobre 2002 05:36 Objet : AeroElectric-List: RE: 'linearizing' a fuel gauge > > > > > > >I just ordered the $19 development system from Digikey. This has got to be > >about the simplest microcontroller project you could ask for. What is the > >max number of fuel probes any one airplane will have? I would think that > >two would be common, (one in each wing). One fuel signal conditioner could > >"linearize" both fuel probes. > > I was wondering about that but I think the pwm timer will > only drive one port at a time . . . but at about $3 a chip, > who cares if it takes two? > > >The connections would then be: > >+12V > >GND > >Sender1 > >Sender2 > >Fuel Gauge 1 > >Fuel Gauge 2 > >and as Jerry suggested, you could have > >Low Fuel Lamp 1 > >Low Fuel Lamp 2 > > > >One 9-pin D-sub could handle it all, and the whole board may fit in the > >D-Sub Backshell like you've done before Bob. > > Funny you should think about that. I think I'd go for > the 15-pin d-sub shell just to get the real-estate inside > the shell. Or go 9-pin on an open board like > http://216.55.140.222/temp/MVC-138X.JPG > > > Bob . . . Bob and all, Here's a link to the fuel-level senders we'll be using http://www.datcon.com/prelease/printelli.htm Cheers, Gilles ________________________________________________________________________________
Subject: Re: Electro-whizzies.....
Date: Oct 30, 2002
Fergus, When I was in college, one of our 2nd year classes was 'Microprocessors.' A super-useful class. We used one of (the many) microcontroller workbooks as the basis for most of the class, and worked through many of the examples in the book with our own, personal Mot HC11 evaluation board. We did lots of projects in both assembly and C, and after finishing the class we were pretty well prepared to use the system to control a small, autonomous robot. I think we could have handled a gas gage too... In order to learn to use one of these little microprocessors, I'd recommend getting one of these project books and working through the examples. I just looked out at amazon.com and found that there were 53 titles under the heading of 'microcontroller.' I liked several of them, including "PIC'n Techniques, PIC Microcontroller Applications Guide." Maybe someone else on the list can recommend their favorite title? If everything in these books seems like jibberish, I'd recommend trying to find a microcontroller, or digital electronics class at your local university. When you buy the cookbook (whichever you choose), you might consider buying the exact project board that the book was written for. This way you can work through the exact examples without getting bogged down in translating from one system to another. These things are really useful machines. All of this talk has gotten me fired up to do a project... Maybe a flight computer with an AoA or something like that. Matt Prather N34RD ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Date: Wednesday, October 30, 2002 7:52 am Subject: AeroElectric-List: Electro-whizzies..... > > Bob, > As a longtime disciple I have managed to tag along, > acquiringexperience and understanding old advice. By way of > explanation, I have > measured the height of fuel from 1 cm. to the top of the inlet port in > litres and have graphed it to reveal a fairly constant relationship > in two > parts. My interest is in translating the depth of a very convoluted > fueltank into litres etc. > However I have been left out to dry on the latest > topic, the > Motorola micro-controller 68HC908QT4. I went to the page and couldn't > understand a thing. I appreciate it's powerful, but it appears that > onerequires about two hundred pieces of literature to utilize it, > few of which > seem to escape gibberish in the titling. > In addition, they show about five different sizes of 'bug' and > refer to such > things as 'roadmaps' where there are no roads. > Is there a dictionary to translate this into English? I > alsoplumbed the dark recesses of the Basic Stamp (?) without ever > breaking the > code. Where can I start from scratch to comprehend these barriers? > I realise > this may be a massive crusade to take a small hand and guide it out > of the > forest............. > From a steamdriven rockbound triode-heater........ > Ferg > Europa A064 > > > _- > ________________________________________________________________________________
Date: Oct 30, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: RE: Shannon's Lancair system . . .
> > >Now I'm confused. Your B&C unit is gear driven also, but it's not prone >to the same failures? I don't understand. It's a 20A machine that uses exactly the same coupling hardware as a popular line of vacuum pumps. Further, it's direct drive. No additional gearing in the power path. While engine's gear train may be rated for the additional horsepower required to produce 70A at the vacuum pump pad, the rotor of such a machine will be heavier -AND- there will need a gear-train inside the alternator to make the rotor run faster . . . this step up gearing would probably be something on the order of 2 to 1 or more . . . inertial effects reflecting back to the engine's gear train -AND- inertial effects on the alternator's own gear train are new and untried conditions. The task has been mounted by a very capable company and I suspect they'll eventually whip all the problems but I'm not sure I would be designing an airplane that depended on those machines to support my first-flight configuration. >Are you suggesting to stick with a belt driven unit along with a gear >driven unit, over 2 gear driven units? A belt driven alternator has no failure modes that will trash an engine. I'd take a belt driven accessory over a gear driven accessory any day. >On the panel overlays...Lancair is building my panel. The basic panel >will have aluminum inserts with the holes cut. As I understand it, the >standard practice is to powdercoat this insert, and then have it laser >etched for the labels and whatnot. I've followed the link you provided, >but don't understand how this overlay would interface with my inserts. >Would it overlay the whole panel in which Lancair wouldn't have to do >any laser etching, or would it just overlay parts of it, or would it >completely replace what Lancair has already cut? They would lay on top of the panel structure. As relatively small, inexpensive overlays, they're easy to change later. >I'm sorry to hear and read about your friend. I understand what you are >saying. Building in that robustness and simplicity is what I'm trying >to do, as well as make it simple during failure. I've tried to think >through every failure and how to handle them. I've tried to be as >complete as possible during the planning stages, and that's why I ask so >many questions. Very good . . . and I'll continue to answer to the best of my abilities or find folks who can. I just get a little uneasy when discussing airplanes with the kinds of features you have proposed. Just trying to assure myself that you are not suffering from poorly supported "delusions of invulnerability" . . . I'd like for you to be around writing about your airplane on this list for many years after first flight . . . >I could list all the failure modes and my proposed solution, but that >would take a while. You don't have to do this for me/us but by all means do it for yourself. The key to survival is having the absolute minimum number of things to observe, interpret and deduce an appropriate action for when things are not going well. Every new feature adds a decision making point that detracts from your duties as pilot. If you can get the electrical emergency procedures page in your POH down to a few paragraphs on one page, then you will have done as well as can be done . . . >The basic failure modes are pretty simple: if an alternator goes out, >turn it off and use the crossfeed; if a contactor goes out use the >crossfeed and possibly the ALT FEED, etc, etc. I think the ultimate >failure would be power out engine failure (or both alts), so you have no >alts. In this case, in my design I would first turn the ESS ALT FEED >on, and then turn both battery contactors and alternator fields off. >The remaining equipment that would be running is listed in my >spreadsheet and above in my ESS list. I honestly feel I could >accomplish this changeover in less than 2 seconds (one switch on, two >double switches off) after the problem was realized. This results in an >amp draw of 10.75 amps off of the AUX battery. If I understand >correctly, this should leave me with 17/10.75=1.6 hours of runtime on >the ESS components....all with the flip of 3 switches. The likelihood of failing two critical components on any single flight is very small . . . in fact we don't even have to consider it in the certification part 23 aircraft. Battery capacity and battery-only operations are not worth spending much time on with a Z-14 configuration. Capacity becomes a cranking performance issue. >Now, with all that said (that was a little look at what is going on in >my head), I'd like to hear your personal design. You said that "that is >not the way I would do it if it was my plane". So, please tell us how >you would do it with the equipment I've selected. . . . thought I did. I published the four-bus sketch last week some time that defined mechanical architecture and in terms of electrical architecture, it's no different than Figure Z-14. The need for pamper-busses is driven by selection of equipment and outside the scope of my advice . . . so I don't think there is much left to decide on your project. I noticed at least one other post where the writer was beginning to comb the nits out of your load analysis and this is a good thing to be doing at this stage. You indicated that your switch and breaker arrangements needed to be carved in stone because of the chosen fabrication technique so it's time to finalize the loads on each bus so the stone-masons can get started. > I think that would be >a very enlightening exercise for all the readers and current system >builders to see. Then we can see your thought process and hopefully >walk away more educated, smarter, and with safer systems. You've >obviously been doing this a lot longer than most of us, so I'm sure we >could all benefit from seeing how you'd do it with my equipment. The >sheer "kitchen-sinkness" of my equipment list should cover all basis's >for any future readers looking for the same guidance. I think we're about there . . . >Also, (as if that wasn't enough), I need more info on your proposed dual >wing levelers. I assume you mean some sort of autopilot, or are you >discussing something else? I plan the trutrak as my primary, but would >consider putting something else on the other bus (a much simpler system >I assume than a 3axis trutrak?). Would this require another servo on >the ailerons? The trutrak gets its gyro info from its own internal gyro >(mini fast-resetting AHRS if I understand correctly). Where would the >additional wind leveler get its info? Can you recommend a simple wing >leveler? Hadn't really thought about it in terms of specific products. My thought processes were occupied with failure mode effects analysis while reading thorough the accident report and trying to put myself in Terry's shoes. It occurred to me that his airplane was very well equipped to the tune of tens of thousands of dollars yet the condition that ultimately forced his undoing was keeping the airplane right side up while trying to figure out which of those killobuck gizmos on the panel were lying to him. Of course, his airplane had to be SAFE in terms some lawyers in Washington could understand so the options available to him were much more expensive than our options. But if it were my OBAM aircraft and I had the desire and budget to cover the panel with toys, it would be no big deal to have something like a 1.5 killobuck Nav-Aid or similar device in each wing as well. Mooney aircraft use to come with a Britian vacuum wing-leveler as STOCK equipment. Further, the wing-leveler was ON all the the time. You could push a button on the wheel to momentarily disconnect it -OR- being vacuum servos, you could simply override the wing-leveler with the wheel and when you turned loose, the airplane returned to level. This feature was credited with saving the buns of more than one Mooney-load of people when the pilot's day was not going well. When Terry's day wasn't going well he didn't have the critical assistance that $1,500 worth of hardware could have provided. Something to consider . . . Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> > >I have heard the Microair T2000 transponder has been obsoleted. Can >anyone confirm this and does anyone know how the new model will differ and >availability, price, etc. of the new model. > >Thanks, Rick Fogerson >RV3 fuselage near finish >Boise, ID Where did you hear this? I've searched the net including Microair's website with nary a mention of this. I note that Microair is now offering harnesses from the factory too. Good move on their part. Now, if they'd just update their installation manuals a bit . . . I'll call the distributor to see if they're arware of any changes but I don't think it's very likely that Microair would be changing a brand new and very popular product so soon after the agonizing task of getting blessings from Washington. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: One chip fuel gage signal conditioner
> >Bob and Jerry, > >Thank you for your replies. The principle seems clear. >Nevertheless I'm afraid I'll need some more guidance to sort everytihing out >: which A/D model, which ROM module, how do I hook them up, etc. >Of course, when it comes to entering some instructions or values (via my PC >?), I hope I'll succed, but could you give me more detailed info ? > >Thanks Let's back off the a/d - prom - d/a approach and see how hard we need to beat up on Dave to do a one-chip design if we help him with it . . . Watch this space . . . Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 30, 2002
> >Tell me what to plan for and I'll be OK. I assume >that from my standpoint, I need to plan for installing >a small box such as this one: > >http://mthobby.pcperfect.com/ch601/DCP01829.JPG > >And it would have similar terminals for the following >connections: > >. +12V >. GND >. Sender >. Fuel Gauge (Sender connection) > >Would that be it? >If yes, it means that it would be really easy to >retrofit the system at any time and thus, you can take >your time to do it. Pretty close. There would probably also be a pull-down signal for a low fuel warning light too. 9-pins is enough. Assembly wouldn't need to be very big. Something like http://216.55.140.222/temp/MVC-138X.JPG except connector would be right angle device. We'll see what tickles Dave's fancy . . . after he's had time to fire up the development system he ordered. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Ferg, Like you I've been lurking for a while, learning as I go. My learning curve is pretty steep but I think this issue was like a vertical brick wall to me too. That makes two little hands.... ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Subject: AeroElectric-List: Electro-whizzies..... > > Bob, > As a longtime disciple I have managed to tag along, acquiring > experience and understanding old advice. By way of explanation, I have > measured the height of fuel from 1 cm. to the top of the inlet port in > litres and have graphed it to reveal a fairly constant relationship in two > parts. My interest is in translating the depth of a very convoluted fuel > tank into litres etc. > However I have been left out to dry on the latest topic, the > Motorola micro-controller 68HC908QT4. I went to the page and couldn't > understand a thing. I appreciate it's powerful, but it appears that one > requires about two hundred pieces of literature to utilize it, few of which > seem to escape gibberish in the titling. > In addition, they show about five different sizes of 'bug' and refer to such > things as 'roadmaps' where there are no roads. > Is there a dictionary to translate this into English? I also > plumbed the dark recesses of the Basic Stamp (?) without ever breaking the > code. Where can I start from scratch to comprehend these barriers? I realise > this may be a massive crusade to take a small hand and guide it out of the > forest............. > >From a steamdriven rockbound triode-heater........ > Ferg > Europa A064 > > http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 30, 2002
Robert L. Nuckolls, III wrote: > > http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?code=68HC908QT4&nodeId=01M98634 > > There's a $19 development system from Digikey > search on "M68DEMO908QT4" > *** Cool! Can this board take a ZIF socket and program chips to stick in something else? Or can it only program the permanently installed one? - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Dual Alternators
Bob: As I study for my annual check ride here, I am still following Shannon's system planning. I have mentioned to you before that I am using a rear belt drive for the Main 60amp alternator, with an Aux B&C 20amp alternator on the vacuum pad. Is this OK? Is there some setup for the Aux alternator to be belt driven as well? Finally figured out how to use your CD-ROM. Have modified the IVP wirebook for my Lancair ES. Knowing that I am fixed gear, and no pressurization, I am eliminate these items off the respected schematics. Kind off going backwards on this, but learning. When can I send you my second pass of Bus loading for Ed's Lancair ES System planning? Thanks, Ed Silvanic N823MS ________________________________________________________________________________
Date: Oct 30, 2002
Subject: RE: Low Voltage Warning & Aux Batt management module
m> >Bob, > > Thanks.... I'm assuming you'll release the .DWG file after that. I'm >trying to put together the schematic documentation for the new plane and >would like to include it....... Oh, if all you need is the schematic in AutoCAD, you can get it http://216.55.140.222/temp/ABMM_Schematic.dwg > I definitely want one. I'm planning a dual battery, single Alternator, >dual electronic ignition system. I haven't started wiring yet, and won't >until I get the first pass of the schematics done. When they are done, I'll >send you a copy. Maybe you can do a quick critique..... Maybe we can publish them for others on the list to join into the conversation. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> >Bob, > As a longtime disciple I have managed to tag along, acquiring >experience and understanding old advice. By way of explanation, I have >measured the height of fuel from 1 cm. to the top of the inlet port in >litres and have graphed it to reveal a fairly constant relationship in two >parts. My interest is in translating the depth of a very convoluted fuel >tank into litres etc. > However I have been left out to dry on the latest topic, the >Motorola micro-controller 68HC908QT4. I went to the page and couldn't >understand a thing. I appreciate it's powerful, but it appears that one >requires about two hundred pieces of literature to utilize it, few of which >seem to escape gibberish in the titling. >In addition, they show about five different sizes of 'bug' and refer to such >things as 'roadmaps' where there are no roads. > Is there a dictionary to translate this into English? I also >plumbed the dark recesses of the Basic Stamp (?) without ever breaking the >code. Where can I start from scratch to comprehend these barriers? I realise >this may be a massive crusade to take a small hand and guide it out of the >forest............. > From a steamdriven rockbound triode-heater........ Ferg, If one had the interest when you and I were knee-high to a grasshopper, an amateur radio handbook combined with some time scrounging around behind the radio-tv repair shop for junkers to strip would get us launched in the hobbyist technology of the day. Today's technology hobbyist has a whole new kind of junk box to dig around in and the books are different too. If you're interested in broadening your horizons, get one of the Stamps-in-Class kits that comes with books, experiments and sample applications. There are hundreds of discussion groups and websites that publish the thoughts and questions of like-minded individuals who have open this new door. Consider a subscription to Nuts and Volts magazine. This publication has become the premier rag encompassing most the modern electronics experimenter venues including communications, processors, software, robotics, lasers, etc. It's easier than it looks. I got my feet wet in micro-processor assembly language about 20 years ago after putting it off for 5 years. Three weeks after purchasing my first development system (AIM-65 for about $1,000) I was writing software I could sell. You can get more powerful development systems today for well under $200 . . . some as low as $19.00! Give it a try . . . it's a blast and quite practical too. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Dual Alternators
> >Bob: > > As I study for my annual check ride here, I am still following >Shannon's system planning. I have mentioned to you before that I am using a >rear belt drive for the Main 60amp alternator, with an Aux B&C 20amp >alternator on the vacuum pad. Is this OK? Sure . . . especially you're using B&C alternators in both slots. >Is there some setup for the Aux >alternator to be belt driven as well? I think you've mis-understood my statements about gear driven accessories. Allow me to clarify . . . The worst performing alternators in the history of the transportation industry are those bolted to gear-drive ports of aircraft engines. Some of the problems are founded on the fact that they're certified and the best-we-knew-how-to-do in 1965. Another problem is that the rotational vibration present in the output torque of a reciprocating engine puts special requirements on gear train design and attention that must be paid to resonances of the rotating masses at the end of the gear train. My skeptical view of ANY new gear-driven product is based on 40 years of observation and sad tales of woe from customers who have had to overhaul a perfectly good running engine because a gear-driven gizmo came apart and dropped itty-bitty pieces of metal in their engine. Risks to the engine for vacuum pump pad driven accessories is VERY LOW . . . this due to the way the spline drive pad protects the engine's interior from any pieces that might come off the accessory if it fails. That takes care of one concern leaving only the other . . . has the product achieved any kind of track record on real engines in real airplanes? I think Kelly has as good a shot as anybody and I hope they pull it off with the first attempt . . . I'd just ask them to prove the products quality on THEIR engine and not on MY engine. > Finally figured out how to use your CD-ROM. Have modified the IVP >wirebook for my Lancair ES. Knowing that I am fixed gear, and no >pressurization, I am eliminate these items off the respected schematics. Kind >off going backwards on this, but learning. That's what it's all about. It's my most sincere wish that participation on this list will pay off in levels of understanding and quality of your finished product that are unmatched anywhere else. > When can I send you my second pass of Bus loading for Ed's Lancair ES >System planning? Can you publish it on a server somewhere so we can all look at look at it? If not, e-mail it to me directly and I'll post it from here. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> >Robert L. Nuckolls, III wrote: > > > > > http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?code=68HC908QT4&nodeId=01M98634 > > > > There's a $19 development system from Digikey > > search on "M68DEMO908QT4" > > >*** Cool! Can this board take a ZIF socket and program chips to stick >in something else? Or can it only program the permanently installed one? If you look at the board photo, there's a second set of dip-8 layout holes that are in parallel with the soldered in chip. You can put a machined pin or zif socket in this slot and cut out the soldered-in chip and you're off and run'n Are you going to get one? Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> > >Found something on Avelec website. But I'm afraid they sell a complete >system, with senders and all. >We already have the gauges in place, the senders are defined, what we need >is linearize the readings. >cheers, > >Gilles Can you deduce the specs for the instruments. Need to know movement resistance and current for full scale. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
> >With a battery buss that has the circuit breakers in the panel, which > >would you suggest: an appropriately sized ANL current limiter or a fuse > >at the battery end to protect the 8-10 gauge wire? > > I presume your talking about extending the battery > bus to some place remote from the battery. I cannot > recommend doing that nor suggest any techniques > that would facilitate that action. > > Bob . . . Bob, How far do you consider "remote" ? Peter http://www.matronics.com/browselist/aeroelectric-list > > ________________________________________________________________________________
Date: Oct 30, 2002
So, I'll take the Door Seal and Panel lighting off (I was considering the reverse etched stuff, but was waiting to hear back from you on my previous post to make a decision.....it appears to draw a VERY low amount of current, even less than the flood light you prescribe). What about the fuel pumps? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: batt buss > > >I don't necessarily want to extend it, but I want to have the CB's in >the panel with the rest of them. Therefore, the wire that runs from the >battery to the circuit breakers needs protection at the battery end. I >was considering a ANL limiter or a fuse, but didn't know which to use. >Why is this a problem? > >Here is the stuff on the bat bus: The general rule of thumb for any always hot wire in a certified airplane is 5A or less in the size of it's feeder protection. Battery busses have been classically used to power things that MUST be available whether or not any of the ship's power distribution systems are hot. These would include things like emergency lighting, utility lighting, clocks, radio memories, and in OBAM aircraft, I've suggested that electrically dependent engines should be battery bus powered. I would also avoid the use of breakers because in spite of their current rating, they are capable of delivering 10x to 1000x more energy into a faulted line BEFORE opening than a fuse which is very fast. In the interest of maximizing crashworthiness of the airplane, fuses are preferred. >Door Seal >Cabin Lights >Dimmable Panel Lighting >Power Points >Fuel Trans Pump >Fuel Boost Pump (High/Low) > >I want the CB's in the panel mainly for the fuel pump. If the high/low >switch fails with the fuel pump stuck on High, it can actually flood the >engine and kill it. Therefore, I want to be able to remove power. I've never seen a switch fail in an "ON" position except on that was so badly abused that it welded the contacts closed. This ain't gonna happen on a fuse protected, boost pump circuit. Why is the door seal on the battery? Further, panel lighting can take lots of amps . . . I'd put a gooseneck map light or perhaps a single fixture overhead flood on the battery but not general panel lighting. You've already got the most robust, failure tolerant system to have ever flown in a light airplane. Likelihood of power not being available from either the main bus or aux bus to run necessary things is extremely low. So think of battery busses as supporting things that need to run with the main systems are OFF either by reason of having parked the airplane or deliberately shut off due to smoke in the cockpit to give you a more elbow room to sort out the next step without having the engine quit. In my airplane, battery busses are fuse blocks located adjacent to the battery and fitted with the smallest practical fuse to power the system of interest. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 30, 2002
I'm not certain, but what you may have heard about was the new radio's & transponder's from X-Air in Australia. IIRC correctly, some of the techies from Microair went over to X-Air to ply their trade after Microair was bought out by Jabiru? Seems they didn't see eye to eye with the new management. X-Air's products look very much like Microair's, but with some improvements that may make the Microair products seem obsolete. As Bob pointed out, since Microair just finished get their "holy water" shower, they are unlikely to improve their product anytime soon. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm RE: AeroElectric-List: Microair T2000 transponder obsoleted? I'm not certain, but what you may have heard about was the new radio's transponder's from X-Air in Australia. IIRC correctly, some of the techies from Microair went over to X-Air to ply their trade after Microair was bought out by Jabiru? Seems they didn't see eye to eye with the new management. X-Air's products look very much like Microair's, but with some improvements that may make the Microair products seem obsolete. As Bob pointed out, since Microair just finished get their holy water shower, they are unlikely to improve their product anytime soon. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm ________________________________________________________________________________
Date: Oct 30, 2002
> Todd, > > fuel system and believe I have a better, simpler solution. > >Something's are blessings in disguise. > Well? Dont keep us all in suspense. > > One thought I had was that the capacitance gauge puts out a variable > voltage - how hard could it be to have a circuit that switched on an LED > at > a certain adjustable voltage? > I had built a fiberglass header tank, with ports for mounting the fuel state detectors which were used to provide a high & low level signal to PPA's "smart switch" which would control the level of the 5usg header tank by controlling 2 transfer pumps from 6 wingtanks. After the PPA deal fell through, I realized that I wasn't entirely comfortable with this system anyway. So due to my recently greatly improved skills at TIG welding aluminum, I decided to build a new tank out of 5052 AL. This tank will be vented only for purging of air, then will be a flow through design. The transfer pumps are still in place, but will function as boost pumps only. The high press FI pumps will draw fuel through the tank. This removes allot of unnecessary electronics from this system. Tank will also have a simple capacitance probe in it connected to a microprocessor which I'm planning on using to display fuel level in my other 6 tanks. I will likely also have an LED low level warning light. I recently bought the "Basic Stamp" Board of Education, in which I'm learning how to build my own "electro-goodies". It's allot simpler than I expected. I will likely use the new Motorola or similar chip to accomplish this task. I realize that this basic stamp could easily handle this, but I would prefer to keep this free for educational purposes. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved)
http://www3.telus.net/haywire/RV-9/C-FSTB.htm RE: AeroElectric-List: RE: Fuel State Detector Todd, fuel system and believe I have a better, simpler solution. Something's are blessings in disguise. Well? Dont keep us all in suspense. One thought I had was that the capacitance gauge puts out a variable voltage - how hard could it be to have a circuit that switched on an LED at a certain adjustable voltage? I had built a fiberglass header tank, with ports for mounting the fuel state detectors which were used to provide a high low level signal to PPA's smart switch which would control the level of the 5usg header tank by controlling 2 transfer pumps from 6 wingtanks. After the PPA deal fell through, I realized that I wasn't entirely comfortable with this system anyway. So due to my recently greatly improved skills at TIG welding aluminum, I decided to build a new tank out of 5052 AL. This tank will be vented only for purging of air, then will be a flow through design. The transfer pumps are still in place, but will function as boost pumps only. The high press FI pumps will draw fuel through the tank. This removes allot of unnecessary electronics from this system. Tank will also have a simple capacitance probe in it connected to a microprocessor which I'm planning on using to display fuel level in my other 6 tanks. I will likely also have an LED low level warning light. I recently bought the Basic Stamp Board of Education, in which I'm learning how to build my own electro-goodies. It's allot simpler than I expected. I will likely use the new Motorola or similar chip to accomplish this task. I realize that this basic stamp could easily handle this, but I would prefer to keep this free for educational purposes. S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm ________________________________________________________________________________
Date: Oct 30, 2002
> very strange, I'm located in Switzerland and had no problem at all to > order > and receive the aux tank switch and the low level warning devices. > Everything went very smooth, as I did order for more then one set, I even > got some discount without asking for it. Also the advice how to mount them > into my header tanks was for free and very much appreciated. > > So I have a problem to understand what went wrong when you've tried to do > business with them. > > Werner > He definitely didn't offer any discount. Maybe he thought he would have to send it via dogsled. Who knows what he was thinking. All I know is that I paid my money and received very rude and inappropriate treatment from someone who is conducting a business. He should take some lessons on customer service from someone like Microfastners or Real World Solutions, both of which have provided me with excellent customer service. (sorry Bob, I haven't yet bought from you (except your book - through the builders bookstore), so I can't truthfully add your name... but I'm sure you would deserve it ;-)) S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) RE: AeroElectric-List: RE: Fuel State Detector very strange, I'm located in Switzerland and had no problem at all to order and receive the aux tank switch and the low level warning devices. Everything went very smooth, as I did order for more then one set, I even got some discount without asking for it. Also the advice how to mount them into my header tanks was for free and very much appreciated. So I have a problem to understand what went wrong when you've tried to do business with them. Werner He definitely didn't offer any discount. Maybe he thought he would have to send it via dogsled. Who knows what he was thinking. All I know is that I paid my money and received very rude and inappropriate treatment from someone who is conducting a business. He should take some lessons on customer service from someone like Microfastners or Real World Solutions, both of which have provided me with excellent customer service. (sorry Bob, I haven't yet bought from you (except your book - through the builders bookstore), so I can't truthfully add your name... but I'm sure you would deserve it ;-)) S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) ________________________________________________________________________________
Date: Oct 30, 2002
----- Message d'origine ----- De : "Robert L. Nuckolls, III" : Envoy : mercredi 30 octobre 2002 20:50 Objet : AeroElectric-List: Re: 'linearizing' a fuel gauge > > > > > > > >Found something on Avelec website. But I'm afraid they sell a complete > >system, with senders and all. > >We already have the gauges in place, the senders are defined, what we need > >is linearize the readings. > >cheers, > > > >Gilles > > > Can you deduce the specs for the instruments. Need to know > movement resistance and current for full scale. > > Bob . . . > Bob and all, The gauges are made by UMA. They are 2"1/4 OPTI-ALERT FUEL QTY 240/30 OHM. I'll conduct some investigation at UMA to get the info. As for the senders, we'll use the ones the kit manufacturer provides. I pasted the wrong URL in my last posting. The correct model is a CGF 3 wire from Centroid Products.
http://www.centroidproducts.com/data.htm Here is an excerp from their website : 'FUEL SENSOR PROBE (Gasoline or Diesel) - The probe is constructed of concentric tubing [....]. The tubes, [.....] acts as a capacitor that has one value in air (empty tank) and changes in value as the fuel level rises inside the probe. The amplifier converts these values to a signal suitable to drive a standard meter or other display device.' I understand it is a classical capacitance sender, except the output emulates that of a 240/33 resistive probe. Thanks for all the help, Cheers Gilles ________________________________________________________________________________
Date: Oct 30, 2002
HI Ferg; I'd just like to echo Bob's advice. I recently bought the Basic Stamp "Board of Education" from Digi-Key (another great company to deal with) then downloaded the "Stamps in Class" curriculum. It quickly introduces you to basic programming and soon you will find yourself experimenting with simple robotics and real world interfaces. I find it interesting and entertaining. Gee, when I was in school, all the techno-nerds used to get beat-up and now.... oh gawd nooooo..... I'm becoming one of them......... just say no to pocket protectors! ;-) S. Todd Bartrim Turbo 13B rotary powered RX-9endurance (FWF) C-FSTB (reserved) http://www3.telus.net/haywire/RV-9/C-FSTB.htm > -----Original Message----- > From: Robert L. Nuckolls, III [SMTP:bob.nuckolls(at)cox.net] > Sent: Wednesday, October 30, 2002 10:12 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Electro-whizzies..... > > > > > > >Bob, > > As a longtime disciple I have managed to tag along, > acquiring > >experience and understanding old advice. By way of explanation, I have > >measured the height of fuel from 1 cm. to the top of the inlet port in > >litres and have graphed it to reveal a fairly constant relationship in > two > >parts. My interest is in translating the depth of a very convoluted fuel > >tank into litres etc. > > > However I have been left out to dry on the latest topic, the > >Motorola micro-controller 68HC908QT4. I went to the page and couldn't > >understand a thing. I appreciate it's powerful, but it appears that one > >requires about two hundred pieces of literature to utilize it, few of > which > >seem to escape gibberish in the titling. > >In addition, they show about five different sizes of 'bug' and refer to > such > >things as 'roadmaps' where there are no roads. > > > Is there a dictionary to translate this into English? I also > >plumbed the dark recesses of the Basic Stamp (?) without ever breaking > the > >code. Where can I start from scratch to comprehend these barriers? I > realise > >this may be a massive crusade to take a small hand and guide it out of > the > >forest............. > > > > From a steamdriven rockbound triode-heater........ > > Ferg, > > If one had the interest when you and I were knee-high to > a grasshopper, an amateur radio handbook combined with > some time scrounging around behind the radio-tv repair > shop for junkers to strip would get us launched in > the hobbyist technology of the day. > > Today's technology hobbyist has a whole new kind of junk > box to dig around in and the books are different too. > If you're interested in broadening your horizons, get > one of the Stamps-in-Class kits that comes with books, > experiments and sample applications. > > There are hundreds of discussion groups and websites > that publish the thoughts and questions of like-minded > individuals who have open this new door. > > Consider a subscription to Nuts and Volts magazine. This > publication has become the premier rag encompassing > most the modern electronics experimenter venues including > communications, processors, software, robotics, lasers, > etc. > > It's easier than it looks. I got my feet wet in > micro-processor assembly language about 20 years ago > after putting it off for 5 years. Three weeks after > purchasing my first development system (AIM-65 for > about $1,000) I was writing software I could sell. > > You can get more powerful development systems today > for well under $200 . . . some as low as $19.00! > > Give it a try . . . it's a blast and quite practical > too. > > Bob . . . > > > > > ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: batt buss
> > > >With a battery buss that has the circuit breakers in the panel, which > > >would you suggest: an appropriately sized ANL current limiter or a fuse > > >at the battery end to protect the 8-10 gauge wire? > > > > I presume your talking about extending the battery > > bus to some place remote from the battery. I cannot > > recommend doing that nor suggest any techniques > > that would facilitate that action. > > > > Bob . . . > >Bob, > >How far do you consider "remote" ? Immediate vicinity. FAA lets us leave 6" of wire "unprotected" . . . obviously, we could probably stretch that a few inches if we needed to. The task is to minimize the risk to adjacent wiring and components and 6" was sort of latched onto about 30 years ago as no-big-deal. In the BIG airplanes, some battery busses ARE feed through ANL limiters or other protective device because it's not uncommon to locate the battery bus several feet away just due to the way these ships are built. This degrades crash-worthiness and I can't see a really good reason to do it in the airplanes we're building. The need to access a fuse panel in an airplane that is NOT going to suffer nuisance trips is very rare. Just like our cars, the vast majority of fuses in a car being hauled to the crusher are the same ones installed by the factory. For our purposes, I'd rather suggest that battery busses be mounted to be as close as practical to the battery that feeds it. We then drop quickly onto low-current, INDIVIDUALLY protected feeders that open in milliseconds with no argument or unnecessary delay. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: AeroElectric-List Digest: Re: Fuel State Detector
> > >Would a kind guru please help with a detailed step by step ' Fuel gauge > > >linearization for dummies' ? > > > > I prefer the micro-controllers cause all the stuff is > > in one chip and they're easily programmed and/or > > re-programmed from your PC. With all the discussion around sophisticated gizmos, didn't anybody think of replacing the scale on the gauge?? Calibrate easily...Color pen or pencil, paper.... real cheap... ;o) Carlos Post your free ad now! http://personals.yahoo.ca ________________________________________________________________________________
Date: Oct 30, 2002
I'm installing a fuse block next to the battery now, 6 position, ordered it from you today. Should I put the fuel pumps on it or not? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: batt buss > > > >With a battery buss that has the circuit breakers in the panel, which > > >would you suggest: an appropriately sized ANL current limiter or a fuse > > >at the battery end to protect the 8-10 gauge wire? > > > > I presume your talking about extending the battery > > bus to some place remote from the battery. I cannot > > recommend doing that nor suggest any techniques > > that would facilitate that action. > > > > Bob . . . > >Bob, > >How far do you consider "remote" ? Immediate vicinity. FAA lets us leave 6" of wire "unprotected" . . . obviously, we could probably stretch that a few inches if we needed to. The task is to minimize the risk to adjacent wiring and components and 6" was sort of latched onto about 30 years ago as no-big-deal. In the BIG airplanes, some battery busses ARE feed through ANL limiters or other protective device because it's not uncommon to locate the battery bus several feet away just due to the way these ships are built. This degrades crash-worthiness and I can't see a really good reason to do it in the airplanes we're building. The need to access a fuse panel in an airplane that is NOT going to suffer nuisance trips is very rare. Just like our cars, the vast majority of fuses in a car being hauled to the crusher are the same ones installed by the factory. For our purposes, I'd rather suggest that battery busses be mounted to be as close as practical to the battery that feeds it. We then drop quickly onto low-current, INDIVIDUALLY protected feeders that open in milliseconds with no argument or unnecessary delay. Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 30, 2002
Robert L. Nuckolls, III wrote: > > > There's a $19 development system from Digikey > > > search on "M68DEMO908QT4" > > > > >*** Cool! Can this board take a ZIF socket and program chips to stick > >in something else? Or can it only program the permanently installed one? > > If you look at the board photo, there's a second set of > dip-8 layout holes that are in parallel with the soldered in > chip. You can put a machined pin or zif socket in this slot > and cut out the soldered-in chip and you're off and run'n > > Are you going to get one? > *** Could be. Although I really REALLY have no money at this time. A big real estate deal, plus ongoing Instrument training is eatin' it all up. Should change mid-November. WRT only having one PWM controller - who needs a PWM controller? You just do it in software.... I'd have a 1-ms or even 500-microsecond interrupt. This would interrupt the main program consisting of... ...a do-nothing loop. Well, maybe that main loop could update the low-limit LEDs. 500-microseconds, that's 2000 times a second. If we do 10 pulses a second ( the meter needle should stay still ), that's 200 interrupt ticks per pulse, or 200 discrete meter needle "levels". The current input for each side would be sampled with the built-in ADC and applied to a table ( one for each side ) which would have the output "level". Each output level would be a "number of ticks for the output to be ON", and a "number of ticks for the output to be OFF". These two numbers would always add up to the total number of ticks per pulse, in our sample case, 200. The interrupt service could also have a state machine for blinking the fuel low LEDs when the fuel got REALLY low. The main loop could also have code that would constantly check the sanity of the interrupt, and reset the processor if the interrupt went awry. I think the chip has a built-in watchdog timer - if the main loop detected that the interrupt was dead ( or in bye-bye-land ), it would just stop kicking the watchdog. It would also have stack check code ( checking for stack overflow ) and any other bulletproofing stuff I could think of. It'd be a piece of cake to have the thing come up from reset in a VERY small fraction of a second. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Dual alternators vs one alternator/dual batteries/Vacuum
pump Bob: Thanks for answering my question about the Aux Alt on the Vacuum pad. Before I get into to it too far, is there a real advantage of a dual Alt/Bat over a single Alt/dual Bat, and a vacuum pump. Coming from the A300 Airbus of many times over protection of several sources, would it not make sense to have another source of power, i.e., vacuum pump vise a total electric plane? This of course is based on not having any type of EFIS on board. Thanks, Ed Silvanic N823MS Lancair ES P.S. I'll be sending you my second pass soon. ________________________________________________________________________________
Subject: Load Analysis
Date: Oct 30, 2002
John, Did a little more research. Garmin 430 is 1.44 amps normal on nav/gps side. The com side is 6.0 when TX, basically nothing when RX. The GTX327 is 15 watts/22watts max, so about 1.5 amps max at 14v. audio panel is 1.5 --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Schroeder Subject: AeroElectric-List: Load Analysis Shannon - I've looked at your load analysis and have a couple of questions regarding how you calculated the loads for some of the equipment. We are also installing a Tru Trak DFC 250 autopilot. The books calls for 1 amp for the controller and 2 amps each for the two servos (pitch & roll). Since one would be using the autopilot for cruise, climb and descent, I would think that the load would be closer to 5 amps than the 1 that you show. The servos work almost constantly, especially in turbulence. For the Garmin 430, you show only .5 amp. The Apollo multi-purpose units have a separate breaker/power source for each purpose. I can't see how .5 amp can cover all of the functions of the Garmin, especially with the display running constantly and the need to transmit frequently on the VHF during IFR flight. You show a footnote that indicates your interest in a PRISM. As I understand the product, they include their "Supplenator" as a mandatory source of power for the system. This is a self exciting alternator that puts out about 40 amps and needs a pad on the engine for mounting. I do not mean to complicate your already difficult problem of putting 10 pounds into a 5 pound paper bag, but if you have some kind of calculation for reducing the nominal values published by the equipment manufacturers, we would appreciate getting a copy. It just seems that the loads you show and plan for are on the lighter side of the fence - and in my experience, the bag always breaks at the wrong time. Bob: If you have some kind of calculation/table of values, we would appreciate getting a copy. We are working on our load analysis and wonder how to calculate steady state values that can be less than those specified by the manufacturers. Many thanks, John = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Subject: Re: Dual alternators vs one alternator/dual
batteries/Vacuum pump
Date: Oct 30, 2002
Ooh boy. You may have opened a can of worms with that line of questioning! Much of the evidence shows that modern alternators have a much longer life, and lower rate of failure than do vacuum pumps. If you are going to keep the airplane for a while, the increased initial cost of electric gyros is outweighed by not having to replace a vacuum pump. Matt Prather N34RD ----- Original Message ----- From: N823ms(at)aol.com Date: Wednesday, October 30, 2002 4:22 pm Subject: AeroElectric-List: Dual alternators vs one alternator/dual batteries/Vacuum pump > > Bob: > > Thanks for answering my question about the Aux Alt on the > Vacuum pad. > Before I get into to it too far, is there a real advantage of a > dual Alt/Bat > over a single Alt/dual Bat, and a vacuum pump. Coming from the A300 > Airbus of > many times over protection of several sources, would it not make > sense to > have another source of power, i.e., vacuum pump vise a total > electric plane? > This of course is based on not having any type of EFIS on board. > > Thanks, > > Ed Silvanic > N823MS > Lancair ES > > P.S. I'll be sending you my second pass soon. > > > _- > - The AeroElectric-List Email Forum - > _- > =======================================================================_-!! NEW !! > _- > List Related Information > _- > ======================================================================= > > > > > ________________________________________________________________________________
From: "Werner Schneider" <WernerSchneider(at)compuserve.com>
Subject: Re: Electric Solenoid Engine Primer Valve
Date: Oct 31, 2002
> >that is my intention to do, however I have to tee in a fuel pump for that > >as my highwing Glastar has no such setup (fuel boost pump) planned, I intend > >to do that at the gascolator primer port. Question, concerning fuel pump and > >valve, do you know of anybody selling such parts? Do I also need the valve, > >as I could go directly for a blocking primer pump?. > > The Fawcet pumps are in-expensive but I think they use > reed valves and will free flow if pressurized on the inlet > end. You would need the solenoid valve too. ACS has both. > > You'll also need a needle valve to calibrate the primer > fuel flow. These are a pretty common plumbing part in brass. > Hello Bob, one last question to this issue, can I put the pump AND the valve on the same switch? I have already a 1-5 switch, so priming on the up position, off in the middle and "fuel injection" on the down position, fuse and wiring would then be the combined load of both, right? Many thanks Werner ________________________________________________________________________________
Date: Oct 30, 2002
I've taken more guidance and made another attempt....a final one I hope. http://shannon.v8eaters.com/images/lancair/airplane_amp_draw_5.xls I made a few more movements (off bat bus, etc), and updated the currents. Any other suggestions? I'm starting to build tomorrow if not? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: RE: Shannon's Lancair system . . . > > >Now I'm confused. Your B&C unit is gear driven also, but it's not prone >to the same failures? I don't understand. It's a 20A machine that uses exactly the same coupling hardware as a popular line of vacuum pumps. Further, it's direct drive. No additional gearing in the power path. While engine's gear train may be rated for the additional horsepower required to produce 70A at the vacuum pump pad, the rotor of such a machine will be heavier -AND- there will need a gear-train inside the alternator to make the rotor run faster . . . this step up gearing would probably be something on the order of 2 to 1 or more . . . inertial effects reflecting back to the engine's gear train -AND- inertial effects on the alternator's own gear train are new and untried conditions. The task has been mounted by a very capable company and I suspect they'll eventually whip all the problems but I'm not sure I would be designing an airplane that depended on those machines to support my first-flight configuration. >Are you suggesting to stick with a belt driven unit along with a gear >driven unit, over 2 gear driven units? A belt driven alternator has no failure modes that will trash an engine. I'd take a belt driven accessory over a gear driven accessory any day. >On the panel overlays...Lancair is building my panel. The basic panel >will have aluminum inserts with the holes cut. As I understand it, the >standard practice is to powdercoat this insert, and then have it laser >etched for the labels and whatnot. I've followed the link you provided, >but don't understand how this overlay would interface with my inserts. >Would it overlay the whole panel in which Lancair wouldn't have to do >any laser etching, or would it just overlay parts of it, or would it >completely replace what Lancair has already cut? They would lay on top of the panel structure. As relatively small, inexpensive overlays, they're easy to change later. >I'm sorry to hear and read about your friend. I understand what you are >saying. Building in that robustness and simplicity is what I'm trying >to do, as well as make it simple during failure. I've tried to think >through every failure and how to handle them. I've tried to be as >complete as possible during the planning stages, and that's why I ask so >many questions. Very good . . . and I'll continue to answer to the best of my abilities or find folks who can. I just get a little uneasy when discussing airplanes with the kinds of features you have proposed. Just trying to assure myself that you are not suffering from poorly supported "delusions of invulnerability" . . . I'd like for you to be around writing about your airplane on this list for many years after first flight . . . >I could list all the failure modes and my proposed solution, but that >would take a while. You don't have to do this for me/us but by all means do it for yourself. The key to survival is having the absolute minimum number of things to observe, interpret and deduce an appropriate action for when things are not going well. Every new feature adds a decision making point that detracts from your duties as pilot. If you can get the electrical emergency procedures page in your POH down to a few paragraphs on one page, then you will have done as well as can be done . . . >The basic failure modes are pretty simple: if an alternator goes out, >turn it off and use the crossfeed; if a contactor goes out use the >crossfeed and possibly the ALT FEED, etc, etc. I think the ultimate >failure would be power out engine failure (or both alts), so you have no >alts. In this case, in my design I would first turn the ESS ALT FEED >on, and then turn both battery contactors and alternator fields off. >The remaining equipment that would be running is listed in my >spreadsheet and above in my ESS list. I honestly feel I could >accomplish this changeover in less than 2 seconds (one switch on, two >double switches off) after the problem was realized. This results in an >amp draw of 10.75 amps off of the AUX battery. If I understand >correctly, this should leave me with 17/10.75=1.6 hours of runtime on >the ESS components....all with the flip of 3 switches. The likelihood of failing two critical components on any single flight is very small . . . in fact we don't even have to consider it in the certification part 23 aircraft. Battery capacity and battery-only operations are not worth spending much time on with a Z-14 configuration. Capacity becomes a cranking performance issue. >Now, with all that said (that was a little look at what is going on in >my head), I'd like to hear your personal design. You said that "that is >not the way I would do it if it was my plane". So, please tell us how >you would do it with the equipment I've selected. . . . thought I did. I published the four-bus sketch last week some time that defined mechanical architecture and in terms of electrical architecture, it's no different than Figure Z-14. The need for pamper-busses is driven by selection of equipment and outside the scope of my advice . . . so I don't think there is much left to decide on your project. I noticed at least one other post where the writer was beginning to comb the nits out of your load analysis and this is a good thing to be doing at this stage. You indicated that your switch and breaker arrangements needed to be carved in stone because of the chosen fabrication technique so it's time to finalize the loads on each bus so the stone-masons can get started. > I think that would be >a very enlightening exercise for all the readers and current system >builders to see. Then we can see your thought process and hopefully >walk away more educated, smarter, and with safer systems. You've >obviously been doing this a lot longer than most of us, so I'm sure we >could all benefit from seeing how you'd do it with my equipment. The >sheer "kitchen-sinkness" of my equipment list should cover all basis's >for any future readers looking for the same guidance. I think we're about there . . . >Also, (as if that wasn't enough), I need more info on your proposed dual >wing levelers. I assume you mean some sort of autopilot, or are you >discussing something else? I plan the trutrak as my primary, but would >consider putting something else on the other bus (a much simpler system >I assume than a 3axis trutrak?). Would this require another servo on >the ailerons? The trutrak gets its gyro info from its own internal gyro >(mini fast-resetting AHRS if I understand correctly). Where would the >additional wind leveler get its info? Can you recommend a simple wing >leveler? Hadn't really thought about it in terms of specific products. My thought processes were occupied with failure mode effects analysis while reading thorough the accident report and trying to put myself in Terry's shoes. It occurred to me that his airplane was very well equipped to the tune of tens of thousands of dollars yet the condition that ultimately forced his undoing was keeping the airplane right side up while trying to figure out which of those killobuck gizmos on the panel were lying to him. Of course, his airplane had to be SAFE in terms some lawyers in Washington could understand so the options available to him were much more expensive than our options. But if it were my OBAM aircraft and I had the desire and budget to cover the panel with toys, it would be no big deal to have something like a 1.5 killobuck Nav-Aid or similar device in each wing as well. Mooney aircraft use to come with a Britian vacuum wing-leveler as STOCK equipment. Further, the wing-leveler was ON all the the time. You could push a button on the wheel to momentarily disconnect it -OR- being vacuum servos, you could simply override the wing-leveler with the wheel and when you turned loose, the airplane returned to level. This feature was credited with saving the buns of more than one Mooney-load of people when the pilot's day was not going well. When Terry's day wasn't going well he didn't have the critical assistance that $1,500 worth of hardware could have provided. Something to consider . . . Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: RE: Shannon's Lancair system . . .
In a message dated 10/29/02 12:02:57 PM Central Standard Time, bob.nuckolls(at)cox.net writes: > If I were building ANY class airplane in which it > was my intent to spend lots of time in clouds, > I would have dual, gps guided wing levelers > running from independent power sources. This > ensures that I have at least one system to keep > the dirty side down and pointy end forward while > I sorted things out and got my adrenaline levels > back down. > Good Evening Bob, I think that would be great! My only question is. If one fails, how do you know which one is the good one? The only way that I am aware of is to revert to some sort of rate based flying. I keep hoping that some of the new solid state attitude devices will become available at a weight and cost that works. In the meantime though, I strongly recommend the installation of two old fashioned needle and ball instruments. Not those abominable pieces of junk known as Turn Coordinators. I think they are very useful as a sensor for an autopilot, but I think they are the reason nobody can fly partial panel these days. I could beat that to death, but I won't. I do recommend the dual T&B because it is so easy to tell which one is telling you the truth. If it wiggles at all, it is telling you enough to save your tail. If it doesn't wiggle, it is no darn good. No voting or analysis required. Also, unlike the Turn Coordinator, it will never tell you a lie. The T&B s still relatively cheap, light weight, non tumbling and very reliable. Until the solid state stuff comes up to speed, I think the T&B is the best bet available. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Load Analysis
Shannon - Thanks for the info. John Shannon Knoepflein wrote: > Did a little more research. Garmin 430 is 1.44 amps normal on nav/gps > side. The com side is 6.0 when TX, basically nothing when RX. The > GTX327 is 15 watts/22watts max, so about 1.5 amps max at 14v. audio > panel is 1.5 > ________________________________________________________________________________
Date: Oct 30, 2002
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: 'linearizing' a fuel gauge
> > > > > Are you going to get one? > > >*** Could be. Although I really REALLY have no money at this time. A big >real estate deal, plus ongoing Instrument training is eatin' it all up. >Should change mid-November. That's only a few weeks away . . . > WRT only having one PWM controller - who needs a PWM controller? You >just do it in software.... PWM controllers are nice if you have a tiny controller and don't want the overhead . . . the a/d has a scan mode too I think . . . once you set it up and turn it on, you just go read an address for latest value assigned to the address. > I'd have a 1-ms or even 500-microsecond interrupt. This would interrupt >the main program consisting of... ...a do-nothing loop. Well, maybe that >main loop could update the low-limit LEDs. 500-microseconds, >that's 2000 times a second. If we do 10 pulses a second ( the meter needle >should stay still ), that's 200 interrupt ticks per pulse, or 200 discrete >meter >needle "levels". that would work > The current input for each side would be sampled with the built-in ADC >and applied to a table ( one for each side ) which would have the output >"level". Each output level would be a "number of ticks for the output to be >ON", and a "number of ticks for the output to be OFF". These two numbers >would always add up to the total number of ticks per pulse, in our sample >case, 200. > > The interrupt service could also have a state machine for blinking the >fuel low LEDs when the fuel got REALLY low. > > The main loop could also have code that would constantly check the sanity >of the interrupt, and reset the processor if the interrupt went awry. I >think the chip has a built-in watchdog timer yes it does . . . > - if the main loop detected >that the interrupt was dead ( or in bye-bye-land ), it would just stop >kicking the watchdog. It would also have stack check code ( checking for >stack overflow ) and any other bulletproofing stuff I could think of. > > It'd be a piece of cake to have the thing come up from reset in a VERY >small fraction of a second. Yup . . . if Dave can't get to it are you going to do it? Bob. . . ________________________________________________________________________________
Date: Oct 30, 2002
> > The Fawcet pumps are in-expensive but I think they use > > reed valves and will free flow if pressurized on the inlet > > end. You would need the solenoid valve too. ACS has both. > > > > You'll also need a needle valve to calibrate the primer > > fuel flow. These are a pretty common plumbing part in brass. > > >Hello Bob, > >one last question to this issue, can I put the pump AND the valve on the >same switch? I have already a 1-5 switch, so priming on the up position, off >in the middle and "fuel injection" on the down position, fuse and wiring >would then be the combined load of both, right? Use a 2-50 wired per figure Z-11. If you wish, you can drive each device from it's own circuit protection. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Oct 30, 2002
> > >I'm installing a fuse block next to the battery now, 6 position, ordered >it from you today. Should I put the fuel pumps on it or not? Does your engine have or do you plan to have electronic ignition in the future? Single or dual electronic ignitions could run from battery bus(es). I noticed both a boost and fuel transfer pumps. How are these used? Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Electric Gyro question
I am having the exact same problem with my RC Allen attitude indicator. My set up is also the same with this instrument on my essential bus. My engine is running and the flag will not go away until I turn on the essential bus switch. The readings on my radio master bus is 13.4 while the reading on my essentail bus is only 12.4. I am getting a big drop through the diode. Bob, what can I do about this? Len Leggette RV-8A N901LL (res) Greensboro, N.C. Flying !! ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Dual gps aided wing levelers . . .
> >In a message dated 10/29/02 12:02:57 PM Central Standard Time, >bob.nuckolls(at)cox.net writes: > > > If I were building ANY class airplane in which it > > was my intent to spend lots of time in clouds, > > I would have dual, gps guided wing levelers > > running from independent power sources. This > > ensures that I have at least one system to keep > > the dirty side down and pointy end forward while > > I sorted things out and got my adrenaline levels > > back down. > > > >Good Evening Bob, > >I think that would be great! My only question is. If one fails, how do you >know which one is the good one? You fly on one and keep the other in reserve. I would use alternate wing levelers on inbound-outbound legs of trip to exercise both. >The only way that I am aware of is to revert to some sort of rate based >flying. The wing levelers are rate based and VERY simple electronically. GPS engines are now well under $100. Each device could have it's own gps receiver and rate sensor. Software would watch cross-track error and turn rate and light a lamp when it is determined that steering commands are not driving loop errors in the right direction. The most probable failures are easy to spot in software and raise the flag. >I keep hoping that some of the new solid state attitude devices will become >available at a weight and cost that works. > >In the meantime though, I strongly recommend the installation of two old >fashioned needle and ball instruments. Not those abominable pieces of junk >known as Turn Coordinators. I think they are very useful as a sensor for an >autopilot, but I think they are the reason nobody can fly partial panel these >days. I could beat that to death, but I won't. The wing levelers do just that . . . the rate sensor is canted off vertical to give some degree of look-ahead for an impending turn. >I do recommend the dual T&B because it is so easy to tell which one is >telling you the truth. If it wiggles at all, it is telling you enough to >save your tail. If it doesn't wiggle, it is no darn good. No voting or >analysis required. Also, unlike the Turn Coordinator, it will never tell you >a lie. > >The T&B s still relatively cheap, light weight, non tumbling and very >reliable. My friend Terry had a working attitude indicator and a working turn coordinator. Flying needle-ball-airspeed with your pucker factor at red-line out is a mixed bag no matter how many working instruments you have of any kind. >Until the solid state stuff comes up to speed, I think the T&B is the best >bet available. The solid state stuff IS up to speed . . . has been for almost ten years. The COST of implementing gps aided wing leveling with precision sky-hole boring has been too high to compete with contemporary, off-the-shelf products. With the availability of low cost rate sensors (about $40) and gps engines (about $60), jelly-bean processors that run at 50 Mhz ($5) there are no more excuses. The technology is laying on the ground and dirt cheap (pun intended). Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Dual alternators vs one alternator/dual batteries/Vacuum
pump > >Ooh boy. You may have opened a can of worms with that line >of questioning! Much of the evidence shows that modern >alternators have a much longer life, and lower rate of >failure than do vacuum pumps. If you are going to keep the >airplane for a while, the increased initial cost of electric >gyros is outweighed by not having to replace a vacuum pump. There are additional advantages in weight savings and enhancements to maintenance efforts when all the plumbing and hoses go away. Electric gyros don't have to run on air that MUST contain particulates that are too small to be captured by the best filter so they tend to run longer between overhauls too . . . Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
Subject: Re: Fuel State Detector
> > > > >Would a kind guru please help with a detailed step by step ' Fuel gauge > > > >linearization for dummies' ? > > > > > > I prefer the micro-controllers cause all the stuff is > > > in one chip and they're easily programmed and/or > > > re-programmed from your PC. > > >With all the discussion around sophisticated gizmos, didn't anybody think of >replacing the scale on the gauge?? >Calibrate easily...Color pen or pencil, paper.... real cheap... Yup, considered that . . . I post comments on that technique earlier today. Bob . . . ________________________________________________________________________________
Date: Oct 30, 2002
In a message dated 10/30/02 9:50:43 PM Central Standard Time, bob.nuckolls(at)cox.net writes: > The solid state stuff IS up to speed . . . has been for almost ten years. > The COST of implementing gps aided wing leveling with precision sky-hole > boring has been too high to compete with contemporary, off-the-shelf > products. With the availability of low cost rate sensors (about $40) and > gps engines (about $60), jelly-bean processors that run at 50 Mhz ($5) > there are no more excuses. The technology is laying on the ground and > dirt cheap (pun intended). > > Bob . . . > Good Evening Bob, All sounds great to me. I am absolutely astounded by what Jim Younkin has done with his stuff. I agree wholeheartedly with you about the need for a full time stabilization system, such as the one used by Mooney. A device like that might have saved JFK jr, provided he had enough awareness to NOT press down the button while holding a death grip on the wheel. I also agree that it is becoming very easy to get way too much equipment in a small airplane. It doesn't make things easier, it makes things harder. Just too much to look at and too much potential for confusion. I still think that if a human being is included in the loop (I have no objection if he/she is not, provided that the reliability is adequate) there is a need for a simple indication that tells whether or not the aircraft is turning. I realize that if the wings are level and all other forces are in balance, the aircraft will not turn, but when we become confused, the one thing that will save our bacon is if we can recognize the turn and get it stopped. I think the old T&B, not a Turn Coordinator will do that best. Stop the turn and you will survive. If electronics can do it reliably, I am all for it. We had far fewer instances of loss of control in the days before we had such heavily loaded cockpits. The worst case we can have is when equipment generates a requirement that we have to vote to see which equipment is giving us the correct information. I hope to see examples of your GPS aided solid state wing leveler soon! Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 30, 2002
> > Yup . . . if Dave can't get to it are you going to do it? > *** Well, I'm not building an airplane, and I think the FAA will get mad at me if I stick something like that in my Sundowner. Although the Sundowner could REALLY use some linearizing help in the fuel gauge department. - Jerry Kaidor ( jerry(at)tr2.com ) ________________________________________________________________________________
Subject: Wiring a fuel injection fuel pump
Date: Oct 30, 2002
Bob, I'm wiring my EFI pumps and trying to decide what gauge wire to use. When running the pumps seem to draw a max of about 1.6 amps (tested with my new multi-meter - thanks). Clearly stamped on the pump casing is "Requires 20 AMP fuse". I'm confused. What gauge wire and what size fuse should I use? Regards, John Slade ________________________________________________________________________________
Subject: RE: Shannon's Lancair system . . .
Date: Oct 31, 2002
I may be mistaken, but I think the solid state stuff is ready. The Trutrak has its own built in gyros from what I understand. They aren't as fancy as the Xbow500 AHRS or anything, as they don't have to be, but they work great from what I hear. Might be something to check out. Which one is the T&B and which one is the Turn coord? I'm not sure I've been alive long enough :) to know the difference. The one I'm planning has the ball, obviously, and then has the flag at the 12oclock position that moves left and right. The one in my 182RG I currently fly has a little airplane that tilts. Which is which, and why is one better than the other? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Subject: Re: AeroElectric-List: RE: Shannon's Lancair system . . . In a message dated 10/29/02 12:02:57 PM Central Standard Time, bob.nuckolls(at)cox.net writes: > If I were building ANY class airplane in which it > was my intent to spend lots of time in clouds, > I would have dual, gps guided wing levelers > running from independent power sources. This > ensures that I have at least one system to keep > the dirty side down and pointy end forward while > I sorted things out and got my adrenaline levels > back down. > Good Evening Bob, I think that would be great! My only question is. If one fails, how do you know which one is the good one? The only way that I am aware of is to revert to some sort of rate based flying. I keep hoping that some of the new solid state attitude devices will become available at a weight and cost that works. In the meantime though, I strongly recommend the installation of two old fashioned needle and ball instruments. Not those abominable pieces of junk known as Turn Coordinators. I think they are very useful as a sensor for an autopilot, but I think they are the reason nobody can fly partial panel these days. I could beat that to death, but I won't. I do recommend the dual T&B because it is so easy to tell which one is telling you the truth. If it wiggles at all, it is telling you enough to save your tail. If it doesn't wiggle, it is no darn good. No voting or analysis required. Also, unlike the Turn Coordinator, it will never tell you a lie. The T&B s still relatively cheap, light weight, non tumbling and very reliable. Until the solid state stuff comes up to speed, I think the T&B is the best bet available. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 31, 2002
I will possibly upgrade to the PRISM electronic ignition in the future, but don't expect it to be ready for some time. The boost pump in inline with the left/right fuel selector and the engine driven pump...it has a lo and hi setting. Its for priming, starting, takeoff and landing. The transfer pump transfers fuel from the center fuel cell I built, to the left wing tank to be used by the normal fuel system. This is an add-on feature I built that holds 11-12 gallons of reserve. It works through a check valve and tees into the left tank fuel return. (http://shannon.v8eaters.com/images/lancair/ 09_2002 and 10_2002). Normal operation is to burn 1.5 hours from the left tank, switch to right, and then transfer center to left. I'm still not sure whether to put these on the bat or regular bus? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Re: batt buss > > >I'm installing a fuse block next to the battery now, 6 position, ordered >it from you today. Should I put the fuel pumps on it or not? Does your engine have or do you plan to have electronic ignition in the future? Single or dual electronic ignitions could run from battery bus(es). I noticed both a boost and fuel transfer pumps. How are these used? Bob . . . = = = http://www.matronics.com/browselist/aeroelectric-list = ________________________________________________________________________________
Date: Oct 31, 2002
Is one of these devices you mentions available at this time Bob? Sounds simple, cheap, and an easy add-on to the other bus. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: AeroElectric-List: Re: Dual gps aided wing levelers . . . > >In a message dated 10/29/02 12:02:57 PM Central Standard Time, >bob.nuckolls(at)cox.net writes: > > > If I were building ANY class airplane in which it > > was my intent to spend lots of time in clouds, > > I would have dual, gps guided wing levelers > > running from independent power sources. This > > ensures that I have at least one system to keep
October 24, 2002 - October 31, 2002
AeroElectric-Archive.digest.vol-bh
