AeroElectric-Archive.digest.vol-bu
March 17, 2003 - March 28, 2003
      > with any experience with this sort of thing and advice on wiring this up?
      > Thanks.
      > Mark Means
      If the circuit closes when the probe rises then the light or whatever will
      come on when there is a good level of oil. I am betting the circuit closes
      when the probe falls down. All ya got to do is feed it 12v to one wire,
      ground the other and the run the light or signaling device in series through
      the 12 v wire. When the circuit is complete, the light comes on, telling you
      the motor is about to make real kool metalflake colors in the oil pan... Ha
      Ha.    Ben Haas. N801BH.  V-8 Ford all aluminum Ford in an 801 Zenith in an
      801 Zenith
Date: Mar 17, 2003
Subject: Re: GM low oil sensor
If I remember correctly, one side if the switch is already grounded to the oil pan. I put a hi-intensity LED in my panel, connected to +12V on one side via a (470 or 4700 ohm?) resistor and the other side of the LED to the wire from the switch. You could get more fancy: one side of a relay coil to +12V and the other side of the coil to the switch. Then use the relay contacts as you see fit to drive a lamp, audible alarm or whatever. Finn Mark Means wrote: > >I have an auto conversion in the works with a low oil sensor which I'm not sure how to hook up to a warning light and hoped someone could offer some advice. I am afraid to route some juice up to it for fear of damage as I can't find out (so far) what the usual input is. > >When unscrewed from the side of the oil pan it looks like a small rod with a small donut on it, with a knob on the end to keep the donut from falling off. The donut is weighted so it hangs in one position. I checked the continuity of the two wires coming out of the base. Moving the donut up and down against the rod opens and closes the circuit. Anyone out there with any experience with this sort of thing and advice on wiring this up? Thanks. > >Mark Means > > > > ________________________________________________________________________________
Date: Mar 17, 2003
Bum advice if one side of the switch is grounded already. Finn Benford2(at)aol.com wrote: > >In a message dated 3/17/2003 9:13:59 AM Mountain Standard Time, >rgvelocity(at)lmf.net writes: > > > > >>When unscrewed from the side of the oil pan it looks like a small rod with >>a small donut on it, with a knob on the end to keep the donut from falling >>off. The donut is weighted so it hangs in one position. I checked the >>continuity of the two wires coming out of the base. Moving the donut up >>and down against the rod opens and closes the circuit. Anyone out there >>with any experience with this sort of thing and advice on wiring this up? >>Thanks. >> >>Mark Means >> >> >> > >If the circuit closes when the probe rises then the light or whatever will >come on when there is a good level of oil. I am betting the circuit closes >when the probe falls down. All ya got to do is feed it 12v to one wire, >ground the other and the run the light or signaling device in series through >the 12 v wire. When the circuit is complete, the light comes on, telling you >the motor is about to make real kool metalflake colors in the oil pan... Ha >Ha. Ben Haas. N801BH. V-8 Ford all aluminum Ford in an 801 Zenith in an >801 Zenith > > > > ________________________________________________________________________________
Date: Mar 17, 2003
Subject: Microair comm and Flightcom 403 intercom wiring
Guys, I'm wiring up a Flightcom 403 intercom to my Microair radio. The intercom wiring diagram seems pretty clear...the only connections it has to the radio are the PTT, headphone, mic, and avionics ground (shown tied to the same ground point as the radio). No problems there. Just wondering about the radio wiring though...does the Mic Ground (also called Mic Lo, pin 2 on the Microair) need to be tied to ground to make the communication with the intercom work, or can it just be left unconnected? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring and fwf... ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Subject: relay switch protection
Date: Mar 17, 2003
Another solution would be to put a transorb across the switch that we wish to protect. An 18V transorb would keep the voltage at a level that the switch can handle, it will allow the relay to open quickly, and if it fails shorted, it's no big deal. The shorted transorb would make you think your switch contacts had stuck shut. There would be nothing needed across the terminals of the relay coil, no unacceptable failure modes, and no increase in parts count. Dave in Wichita ________________________________________________________________________________
Subject: snubbers
Date: Mar 17, 2003
> > > Bob has since stopped recommending the use of MOV's and uses diodes > instead. > > He > > has explained the reasoning before but I can't find my notes on it. > Check > > the > > archives. > > > > I know Bob bailed on recommending MOV's, but like you, I don't > recall > why. No doubt it was one of the many reasons mentioned in this recent > thread. Chris > My recollection is that Bob said the MOV's were harder for people to find. The advantage of the MOV over the diode is that it allows the relay to open more quickly. Bob did some sort of testing that led him to believe that the difference was not significant, so he has been recommending diodes ever since. Dave in Wichita ________________________________________________________________________________
Date: Mar 17, 2003
David Swartzendruber wrote: >Another solution would be to put a transorb across the switch that we >wish to protect. An 18V transorb would keep the voltage at a level that >the switch can handle, it will allow the relay to open quickly, and if >it fails shorted, it's no big deal. The shorted transorb would make you >think your switch contacts had stuck shut. There would be nothing >needed across the terminals of the relay coil, no unacceptable failure >modes, and no increase in parts count. --- Folks, I've probably said enough already (or too much, depending on your own perspective) but I find this whole notion of how switches, avionics and other stuff actually works and should be protected totally lacking in understanding of the physics involved. While most anything COULD work for awhile, I am at a loss to understand why anyone would be interested in defying practices for killing transients for many decades. Diodes are cheap, they work and their failure rate is next to zero. Last message on the subject, I promise. Regards, Steve PS: Transorbs do have their places, this just isn't one of them. By the time the transorb catches any transients, the switch damage has already occurred. I'm surprised someone hasn't suggested thyrectors or diacs... ________________________________________________________________________________
Date: Mar 17, 2003
Subject: Re: relay switch protection
Dave , what is a transorb switch? Can you direct me to a site for more info? Peter ----- Original Message ----- > Another solution would be to put a transorb across the switch that we > wish to protect. An 18V transorb would keep the voltage at a level that > the switch can handle, it will allow the relay to open quickly, and if > it fails shorted, it's no big deal. The shorted transorb would make you > think your switch contacts had stuck shut. There would be nothing > needed across the terminals of the relay coil, no unacceptable failure > modes, and no increase in parts count. > > Dave in Wichita > > ________________________________________________________________________________
Date: Mar 17, 2003
Subject: Re: GM low oil sensor, bum advise
In a message dated 3/17/2003 10:12:25 AM Mountain Standard Time, finnlassen(at)netzero.net writes: > > Bum advice if one side of the switch is grounded already. > > Finn > > Benford2(at)aol.com wrote: > I read that he said there are TWO wires coming off the sensor. Internally grounded units have only ONE wire. ________________________________________________________________________________
Date: Mar 17, 2003
Subject: Archer Comm antenna hookup
I'm hooking up my bob archer comm antenna -the one for the wing tips - I lost the directions? does this sound right - the center coax cable wire goes to the terminal which connects to most of the metal on the antenna -the other antenna terminal seams to be insulated from the rest of the antenna itself - this secound terminal on the antenna just goes to a smaller section of metal which is insulated from the rest of the antenna - i'm assuming this would be the ground? thanks --------------------------------- ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Fw: Dynon Clock power requirements
FYI, passing this along in case it's of interest to anyone else ordering a Dynon EFIS.... --------- Forwarded message ---------- From: "Gillian D'Ancicco" <gillian(at)dynondevelopment.com> Date: Mon, 17 Mar 2003 11:31:09 -0800 Subject: RE: Clock power? Mark, We draw 1 mA typically from the keep alive input. However, we also charge our internal battery from this source if the battery is not fully charged. Thus, if you ran the instrument off its internal battery and never recharged it using the master power, we would draw from the keep alive until our battery was charged. In this case we could draw up to 2 Amp hours off your battery to charge our internal battery. Gillian C. D'Ancicco Business Manager Dynon Avionics Inc. 19501 144th Ave NE Suite C-500 Woodinville, WA 98072 (425)402-4404 Phone (425)984-1751 Fax -----Original Message----- From: czechsix(at)juno.com [mailto:czechsix(at)juno.com] Subject: Clock power? Hi, How much power does the internal clock in the EFIS D-10 use from pin 2 (Keep Alive Clock Power) when the main power is off? Assume it's only a milliamp or so otherwise it could drain the battery over a couple weeks time between flights? Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring....D-10 on order.... ________________________________________________________________________________
Date: Mar 18, 2003
Subject: two computers
This is a very general question and note that my thoughts are the opinion of a builder who has not flown yet. However I'd suggest that high voltage coil joiners can be an excellant solution for the ignition although not really suitable for coil on plugs. Joiners are multiple diode strings that have proven to be very very reliable. If one diode shorts it has no effect. One can always measure the forward voltage drop annually. As long as it does not drop significantly from the 60 volts (approx.) of a new unit, you can be assured that all is well. If one whole diode string shorts, again the engine keeps running. Therefore one can run two otherwise independant ignition units each from its own electrical system (if you are using two electrical systems). Coil joiners get more complex with waste-fire systems since one of each plug pairs operates with reverse polarity, but there are several options. For coil on plugs, I'd consider switching the coil power supply and all the triggers to insure that a shorted driver does not prevent the second system from functioning. Or insure that you can maintain flight with one dead cylinder. Note that a 4 cylinder engine will lose AT LEAST 40% power in an airplane with one dead cylinder due to pumping losses and the other cylinders operating at lower rpm, etc. My own solution for two efi computers is to also feed them from different electrical systems. I then fitted extra injector(s) with a separate filter, fuel rail and regulator for the second system. However the 12 volt feed to the extra injector(s) will normally be switched off (one SPST switch) unless it is required and the primary system is turned off first. To avoid the weight of a third fuel pump it will also require a fuel valve selection to pressurize the second fuel rail on my implementation. Overkill? - probably, but a Megasquirt efi computer is only $110. (check out the web site) and the rest was recycled. Too many auto engine conversions have come out of the sky due to single component failures in ignition and fuel systems. Unlike cars or certified installations built in quantity, these systems are always unique in some aspects and not near as well tested. Without redundancy, unique failure modes will continue to show up, in my opinion. Just last week I heard of a crankshaft sensor failure (in flight) that several people have claimed for years to be as reliable as dirt. It was as reliable as dirt WHEN installed in the factory in a car... Ken > < engines. > I see how you wire two hot busses from 2 batteries to the two computers. > But how do I wire the fuel injectors and the coils to the two separate > batteries? What do you think would work the best? > Thanks, > Leonard>> ________________________________________________________________________________
Subject: Oil level switch
Date: Mar 18, 2003
< If I remember correctly, one side if the switch is already grounded to the oil pan. I put a hi-intensity LED in my panel, connected to +12V on one side via a (470 or 4700 ohm?) resistor and the other side of the LED to the wire from the switch. You could get more fancy: one side of a relay coil to +12V and the other side of the coil to the switch. Then use the relay contacts as you see fit to drive a lamp, audible alarm or whatever.>> Remember that oil level switches in automotive engines are used to check the oil BEFORE starting, not during operation. They are shut off while the engine is running as the oil level will normally drop below the switch level. Even if the switch is mounted low enough to work during operation there is some concern that aeration and turbulence will cause false actuation. If you just wire it to a light, the light may be on all the time the engine is running. Gary Casey ________________________________________________________________________________
Subject: one last contactor diode question
Date: Mar 18, 2003
<> One last question, honest. I heard once somewhere that the starter contactor will be less "vigorous" in opening the contacts with a diode across it and therefore will be slightly more likely to weld than with no diode. In my Cardinal the ignition switch lasted for 30 years without a diode, but the AD was just complied with which resulted in new contacts AND a diode across the starter contactor. hmm.. Gary Casey ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Re: Oil level switch
In a message dated 3/18/2003 7:04:25 AM Mountain Standard Time, glcasey(at)adelphia.net writes: > > > Remember that oil level switches in automotive engines are used to check > the > oil BEFORE starting, not during operation. They are shut off while the > engine is running as the oil level will normally drop below the switch > level. Even if the switch is mounted low enough to work during operation > there is some concern that aeration and turbulence will cause false > actuation. If you just wire it to a light, the light may be on all the > time > the engine is running. > > Gary Casey > Very good point. The oil pressure gauge and light is the one thing ya need to keep an eye on. ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Re: one last contactor diode question
Gary Casey wrote: >One last question, honest. I heard once somewhere that the starter >contactor will be less "vigorous" in opening the contacts with a diode >across it and therefore will be slightly more likely to weld than with no >diode. In my Cardinal the ignition switch lasted for 30 years without a >diode, but the AD was just complied with which resulted in new >contacts AND >a diode across the starter contactor. hmm.. --- Hi Gary, First, I don't mind questions -- I just figured folks were tired of my 'firm' answers on diode suppression stuff. Second, I'll offer two answers. The simple answer is yes, there will be a very small difference with and without the diode which you would only know about if you made lab condition measurements and is of no practical consequence as the time difference is tiny compared to the time line of the total system characteristics. The longer answer is that starter contactors I'm familiar with will store a little more energy than most smaller relays because they have more inductance. As a consequence they are likely to take longer than the typical smaller relays to open. The extra time with any of these is mostly dependent on the inductance of the coil -- and natural resonances due to the combined effects of internal coil and system distributed reactances of the application. The transient frequency produced will be a function of this resonance factor but the coil will attempt to begin oscillation at its natural frequency and at a peak voltage of L(di/dt) caused by the switch's abrupt opening. Note that system dt is heavily influenced by the distributed reactances of the circuit but driven by the switch's opening speed, which for typical switches is relatively slow compared to semiconductor switches. The energy stored in the coil will be determined by L(i 2/2) and will be dissipated as heat in the diode within essentially the first half cycle of the attempted oscillation of the circuit, quenching switch contact arc before it really gets started good. But without knowing the exact parameters involved with typical starter contactors and switches, it is not possible for me to characterize the time delay exactly. All of these factors can be lab condition measured and results determined definitively. My background is with complex systems for military, commercial and industrial systems so my practical experience doesn't encompass very much purely aviation-typical component experience and I would defer to Bob for estimates of times for this in practice. This list is very fortunate to have Bob here with a vast amount of on target practical experience and real professional background and advice. However, I have spent a LOT of time with similar components and would be very much surprised if he disagreed with my statement that the time delay opening a starter contactor with diode suppression is of no practical consequence. Just make sure the diode suppressors are installed with short leads as close to the coil as is practical. Regards, Steve ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Re: AeroElectric-List Digest: 29 Msgs - 03/17/03
> Subject: AeroElectric-List: Microair comm and Flightcom 403 intercom wiring > > I'm wiring up a Flightcom 403 intercom to my Microair radio. The intercom wiring > diagram seems pretty clear...the only connections it has to the radio are the > PTT, headphone, mic, and avionics ground (shown tied to the same ground point > as the radio). No problems there. Just wondering about the radio wiring though...does > the Mic Ground (also called Mic Lo, pin 2 on the Microair) need to > be tied to ground to make the communication with the intercom work, or can it > just be left unconnected? > > Thanks, > > --Mark Navratil It has been my experience that the pins labelled "Mic Lo" on most radios are just internally tied to the radio's "Power Ground" pin. Take an Ohmmeter, and measure the resistance between Pin2 on the MicroAir, and whatever pin is the MicroAir's Power ground pin. If you read a dead short, then you can consider pin 2 to be just another ground connection on the MicroAir. While you are at it, measure between the MicroAir's case and its Power Ground pin. This still leaves open the question of how to connect the "Mic Out" from the intercom to the "Mic Input" of the MicroAir? If you use a shielded wire, the question is what to do with the shield: 1. connect both ends of the shield; one end to Intercom ground, other end to MicroAir Mic LO. 2. Connect the shield to Intercom ground, leave the MicroAir end open. 3. Connect the shield to MicroAir MicLo, leave the intercom end open. 4. Dont bother shielding the Mic line, i.e. use an unshielded wire. Guess what? In 97% of installations, where the power grounds from all of the individual avionics items are short (less than a few feet), and are terminated at a "common" ground terminal, any of the four methods above will work just fine. The mic line audio level is sufficiently high, and is at a low enough impedance, that even shielding is optional (good practise, but optional). Shielding audio lines usually involves keeping RF from the transmitter out of them, and has little to do with preventing capacitive coupling at audio frequencies. In methods 2 thru 4, you are relying on the fact that both the intercom and MicroAir are already connected together through their respective power grounds. The Mic signal return path is through the power wiring via the common ground point. In method 1, you are slightly lowering the ground path resistance by shunting the preexisting ground path with a direct connection between the two units (thru the shield). Practically, with method 1 you may reduce 20mOhms of ground impedance to 10mOhms... In high-quality audio, data aquisition and instrumentation applications, the SigHi-SigLo nomenclature implies an isolated, differential signal pair which is isolated (optically, transformer, differential instrumentation amplifier) from ground. This is done to break "ground loops", and to prevent "common mode" noise from coupling into the desired signals. However, in avionics I have never seen anything but SigLo just being another "GROUND" pin... If the MicroAir MicLo pin is isolated from ground, then only Method 1 above will work, and my hat is off to MicroAir. Mike Mladejovsky (one Czech to another) Gray haired PhDEE Instrumentation Engineer Skylane '1MM Pacer '00Z ________________________________________________________________________________
Date: Mar 18, 2003
Subject: Re: Archer Comm antenna hookup
I got the following from Bob himself - so I guess I had it backwards incase anyone else is interested. Bob writes: You have it just backwards! The center conductor connects to the the insulated little piece of aluminum which spaced from the main part of the antenna forms a capacitor which feeds the rest of the antenna. This devive is called a "Gamma" match. With this device there are enough antenna parameteres that the antenna can be tuned as perfectly as is possible. I'm hooking up my bob archer comm antenna -the one for the wing tips - I lost the directions? does this sound right - the center coax cable wire goes to the terminal which connects to most of the metal on the antenna -the other antenna terminal seams to be insulated from the rest of the antenna itself - this secound terminal on the antenna just goes to a smaller section of metal which is insulated from the rest of the antenna - i'm assuming this would be the ground? thanks --------------------------------- --------------------------------- ________________________________________________________________________________
Date: Mar 18, 2003
Subject: neat site for 0-Rings
check out www.allorings.com -neat site for all your o-ring needs --------------------------------- ________________________________________________________________________________
Subject: Turn coordinator noise
Date: Mar 18, 2003
Dear Bob, I've installed a cheap turn coordinator in my CH701. It's causing noise in the headset when intercom on, or when transmitting. No noise when receiving only. I've looked at some of your suggestions in the archive and will try some of them tommorrow. Is it likely that if I had bought an expensive instrument that it wouldn't cause noise problems? Regards, Shay King. ________________________________________________________________________________
Subject: re: Archer Comm antenna hookup
Date: Mar 18, 2003
From: "David.vonLinsowe" <David.vonLinsowe(at)delphi.com>
I just converted mine to Bob's antenna's. It's the other way around. The center conductor of the coax goes to small section of aluminum. The rest of the antenna is grounded. Also be certain that if you have any lights in the tips that the wires run up the front leg of the antenna. The antennas work great even with the strobes out there flashing away! I picked up 5 1/2 mph on the top end by moving the COM, VOR/GS, marker beacon and transponder antennas out of the breeze Dave RV-6 The need for (more) speed----> From: Julia <wings97302(at)yahoo.com> Subject: AeroElectric-List: Archer Comm antenna hookup I'm hooking up my bob archer comm antenna -the one for the wing tips - I lost the directions? does this sound right - the center coax cable wire goes to the terminal which connects to most of the metal on the antenna -the other antenna terminal seams to be insulated from the rest of the antenna itself - this secound terminal on the antenna just goes to a smaller section of metal which is insulated from the rest of the antenna - i'm assuming this would be the ground? thanks ________________________________________________________________________________
Date: Mar 18, 2003
Well, that is not the case for the Mazda 13-B rotary. I sure would like to know if I have developed an oil leak while airborne. A sensor that doesn't work that way is worthless in my opinion. Finn Gary Casey wrote: > >< > > >If I remember correctly, one side if the switch is already grounded to >the oil pan. >I put a hi-intensity LED in my panel, connected to +12V on one side via >a (470 or 4700 ohm?) resistor and the other side of the LED to the wire >from the switch. > >You could get more fancy: one side of a relay coil to +12V and the other >side of the coil to the switch. >Then use the relay contacts as you see fit to drive a lamp, audible >alarm or whatever.>> > >Remember that oil level switches in automotive engines are used to check the >oil BEFORE starting, not during operation. They are shut off while the >engine is running as the oil level will normally drop below the switch >level. Even if the switch is mounted low enough to work during operation >there is some concern that aeration and turbulence will cause false >actuation. If you just wire it to a light, the light may be on all the time >the engine is running. > >Gary Casey > > ________________________________________________________________________________
Date: Mar 19, 2003
Subject: Re: RG Batteries at UAP/NAPA
FYI I just happened into A UAP/NAPA store the other day looking for the flasher unit to power the landing/taxi light combo and I found that they now carry a complete line of RG Batteries. The line up is marketed to recreational toy like ATV's, jet skies, boats and such. The 18XL is a 300CCA 20ah 18lb beast which measures 12" long 4" wide and 8" in height. The complete "prosport" line is crossed referenced to other RG battery manufacturers. The "good ole boy" (best customer) price was $89Cdn. roughly $60US. When I told my AME about this his eyes just lit up and he said "sounds great stick one in the plane and save the "pink" one for the annual." I love this mechanic. Each time I show him a better way and he's satisfied that it is better, he'll find a legal way to sign it off. BTW the alternating flasher is one used on a school bus and is rated for two sealed beams or a number of bulbs. I'll pick up the flasher unit this week. PeterVC ________________________________________________________________________________
Subject: Re: European hole spacing
Date: Mar 18, 2003
aaah, been there, done that !!. Publishing hard copy for outside of N & S America can be tricky. Generally you'll see two or four ring binders outside the N & S America using A4 paper and generally you'll see 3 ring binders in the US using 8.5 x 11 paper. I know there are exceptions but generally true. Also, don't forget A4 is a little bit longer and a little bit narrower than 8.5 x 11 so may stick out of the binder. If you print from softcopy you have to watch margins etc. FWIW we ended up designing a page size that was a little bit narrower than 8.5 inches and a little bit shorter than A4 (11 inches) so we knew the contents of each page would be the same no matter what size paper was used. Then printed some on A4 with four holes and some on 8.5 x 11 with three holes. The extra trouble and expense is just not worth it unless you have large volumes of print in mind for both markets. ________________________________________________________________________________
Subject: Book review?
Date: Mar 19, 2003
Is anyone familiar with the book "Principles of Avionics?" It's rather pricy and I'd like an opinion before I buy it. It can be found at - http://www.avionics.com/www/books/Principles%20of%20Avionics.htm Regards, Kevin Kinney ________________________________________________________________________________
Date: Mar 19, 2003
Subject: Re: Book review?
In a message dated 3/19/2003 8:47:09 AM Eastern Standard Time, kkinney(at)fuse.net writes: > Is anyone familiar with the book "Principles of Avionics?" It's rather > pricy and I'd like an opinion before I buy it. > > It can be found at - > http://www.avionics.com/www/books/Principles%20of%20Avionics.htm > > > Regards, > Kevin Kinney > > > Hello Kevin, I am not familiar with this book but may like to be. Yes, it is pricey but looking at the table of contents and knowing how much space it would take to cover all of that material in depth, it is cheap. The advertisement does not say how many pages are in the book. I sent two 4.8 cubic foot crates of material home for safe keeping from Millington Tenn. when I went through the US Navy's Avionics "B" Schools in the early seventies. Later, a fire destroyed it all. I had every avionics principal and device known to man documented in that stash of literature. Volumes and volumes of information on changes, new circuits and devices have been compiled since those olden days. GPS was just dawning on a dream come true. If you are just wanting to understand and wire your OBAM bird, Bob Nuckolls has all of the info you need condensed into a cookbook for your reading/wiring enjoyment. It is a superb value for that purpose at less than half the cost of the book you are looking at. (What percentage did you set my sales commission at Bob?) John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Mar 19, 2003
Subject: Running wires next to induction tubes
I've run all my wires and hoses through firesleeve - is it ok to use nylon ties to tie them right onto the intake induction tubes? I wouldnt think they would get very hot - at least not too hot for the firesleeve? thanks --------------------------------- ________________________________________________________________________________
Date: Mar 19, 2003
Subject: Re: Running wires next to induction tubes
In a message dated 3/19/2003 10:19:30 AM Mountain Standard Time, wings97302(at)yahoo.com writes: > > > I've run all my wires and hoses through firesleeve - is it ok to use nylon > ties to tie them right onto the intake induction tubes? I wouldnt think > they would get very hot - at least not too hot for the firesleeve? > > Firesleeve will live ok, the nylon ties will get brittle and break in a few heat cycles though. Ben Haas N801BH. ________________________________________________________________________________
From: David Chalmers <David(at)ctsinternational.com>
Date: Mar 19, 2003
The previous owner and I used nylon tiewraps around the intake tubes of our 0-200 (using downdraft cooling) and didn't have a problem after 300 hours. -----Original Message----- From: Benford2(at)aol.com [mailto:Benford2(at)aol.com] Subject: Re: AeroElectric-List: Running wires next to induction tubes In a message dated 3/19/2003 10:19:30 AM Mountain Standard Time, wings97302(at)yahoo.com writes: > > > I've run all my wires and hoses through firesleeve - is it ok to use nylon > ties to tie them right onto the intake induction tubes? I wouldnt think > they would get very hot - at least not too hot for the firesleeve? > > Firesleeve will live ok, the nylon ties will get brittle and break in a few heat cycles though. Ben Haas N801BH. ________________________________________________________________________________
Date: Mar 19, 2003
Subject: off topic - Skybolt.com - sale - cowl fasteners -
check it out - good deal. if you need cowl fasteners - check out www.skybolt.com they have them on sale down from $457 or so down to $317 total - I just order some. I'm told those hinges break alot - do it right the first time. --------------------------------- ________________________________________________________________________________
From: "Mike Bourget" <falconaviation(at)rogers.com>
Subject: intercom question
Date: Mar 19, 2003
Hi all,,, new to the list putting together a Sal 2.3rd mustang. ready to do wiring now and I have a question. If I use the Icom 200, and I wish to also have a CD player do I need to install an intercom? thanks Mike ________________________________________________________________________________
Date: Mar 19, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Benford2(at)aol.com wrote: > >In a message dated 3/19/2003 10:19:30 AM Mountain Standard Time, >wings97302(at)yahoo.com writes: > > > > >>I've run all my wires and hoses through firesleeve - is it ok to use nylon >>ties to tie them right onto the intake induction tubes? I wouldnt think >>they would get very hot - at least not too hot for the firesleeve? >> >> >> >> > >Firesleeve will live ok, the nylon ties will get brittle and break in a few >heat cycles though. Ben Haas N801BH. > Ties under the cowl of my -4 (several hundred hours & 2 years old when I bought it) were still ok when I sold it 7 years later. Ties made for exterior use (uv protected) should last longer. fwiw, Charlie ________________________________________________________________________________
Date: Mar 20, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: intercom question
> > >Hi all,,, new to the list putting together a Sal 2.3rd mustang. > >ready to do wiring now and I have a question. > >If I use the Icom 200, and I wish to also have a CD player do I need to >install an intercom? Mike, sorry I didn't get back to you sooner on your direct query but Dee and I were out of town since last Friday and where we were going, there wasn't any place to plug a computer into the wall . . . Does the A200 have a true intercom function built in? It's not apparent from the front panel controls in spite of the fact that some of the sales literature I've seen on the net speaks about "intercom capabilities" . . . I suspect this simply means that its headphone output signals are not incompatible with intercom systems. You'll need some form of intercom that features additional audio inputs from other sources like nav receiver, marker beacon, alert tones, etc. in addition to stereo outputs from your music system. This also means that you need to acquire headsets wired for stereo music . . . most are not. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Alternator wiring
>Hi Bob, > >I have purchased your book along with S-704-1 alternator OV relay and the >crowbar overvoltage module. I am building a Skystar Classic IV with a Rotax >912 engine so I am using your diagram Z-15 as a guide. My question is this: Z15??? or Z16 . . .? >On your diagram you have the alternator master circuit wired through the >main power bus and not the essential bus. It seems to me that with this >setup that a failure of the master contactor would result in a shutdown of >the alternator. Is this correct and if so is there any reason not to >attach the >alternator master circuit to the essential bus? The e-bus is generally not needed unless the alternator has failed in which case it allows you to use battery reserves without the burden of the master relay. Depending on how the regulator is configured, the PM alternator on the Rotax may still deliver useful power to the bus with the battery master relay open so battery master relay operation is not necessarily a requirement for alternator operation . . . Even if it is, what kind of flight operations do you anticipate wherein lose of both battery contactor -AND- alternator presents any kind of a tense scenario? Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: 10416 tracy
>Amp meter fluctuation and gear green lights go from bright to dim at low >rpms less that 1000 rpms. Overhauled alternator 60amps with new >belt. Problem was before and after alternator/belt exchange. A related >problem with radio transmission. Low engine rpm transmission is load and >clear. Cruise rpm transmission is not clean but scratchy. Help >Aircraft PA28R-200 1970 >John This problem needs to be trouble shot by someone who understands how the system works and how it behaves when the different components are not working. Too many mechanics troubleshoot by substitution . . . keep replacing things starting with their "best guess" until the problem goes away. The symptoms you cite are suggestive of a regulator problem brought on my increased resistance of wiring and components between the regulator and the bus . . . easy to trouble shoot by someone who understands what he is doing . . . but their may be other deficiencies compounding the problem. It's not a terribly difficult thing to do but it's more than I can lead you through in a quick e-mail response. Do you have a mechanic helping you with this? Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 20, 2003
Subject: D-sub pins substitution?
>Bob, > >Just wanted to thank you for providing all these great resources. I >purchased the AEC book awhile back and it has been a great reference and >educational while building. I'm pleased that you find the investment useful . . . >With the praise out of the way (smile). If you have time for a question >I'd be grateful (and will pay as well - just tell me where to send the check). > >Here goes - I just purchased an UPS/Apollo GX65 COM/GPS unit and it came >with solid barrel connector pins for the DBxx connectors. Since these >require yet another tool that I'll probably never use again I was >wondering your thoughts of the solid pins versus the ones you describe in >your article at >http://www.aeroelectric.com/articles/matenlok/matenlok.html? Since I have >some of the open type pins from left over hobby projects and the crimper >for them as well, it would be really easy to use them. However, if it's >going to come back and bit me, I'll just spend another $90 and buy the >'damn solid pin MS22520 based crimper'. How about a $44 tool at http://www.aeroelectric.com/Catalog/tools/tools.html#rct-3 If it were my airplane, I only use machined pins in the d-sub connectors. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
> >Ok, I see. > >Could have been spectacular though: full battery voltage across a switch >no longer fully submerged in oil. Wonder if the flash would have been >enough to ignite the oil? If it were a little bit of oil in a large volume of air, perhaps. You can't ignite a fuel that doesn't also have the right ratio of oxygen to go along with the ignition event. That's what's so bogus about the official story of root-cause for TWA800 . . . If you've ever done explosion proof testing of products you'll know how DIFFICULT it is to get the right ratio for explosive mixture even when your trying to do it right. Any time the fuel is in great excess compared to oxygen, the system is as inert as a rock. Stuff like gunpowder works anytime because the chemical reaction provides its own oxygen in an otherwise closed environment. It's a really neat thing that gasoline and its cousins make such lousy bombs. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Crossover Warning Light
> >In a message dated 3/17/2003 9:24:38 AM Eastern Standard Time, jpack(at)igs3.com >writes: > > > I would like to put a light on the panel that indicates that the Crossover > > Contactor is on (Dual bat, Dual Alt system). Where should I take the lead > > for the light? > > > > - Jim Figure Z-14 shows just such a light adjacent to the cross-feed contactor control switch. ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: OV Protection
> >I'm in the (very frustrating) process of designing an electrical system >for my first experimental (Kitfox w/ Lyc O-235): > >I'm confused about over voltage protection devices(for alternators): > > I understand that their basic purpose is to protect the electrical > system if the voltage output gets too high, but isn't that the function > of any other type of cirquit protection device (fuses, breakers, fusible > links)? > I'm planning on installing a 35 amp fusible link between the alternator > and the main bus Fusible link? . . . or ANL series current limiter? What size alternator are you using? . . . which power distribution diagram are you basing your system on? > Does that only protect against over-amperage? I saw the 'crow-bar' > type of OV protection devices from B&C on the web site - does that get > installed between the alternator and the fusible link? . . . proper application of the OVM-14 crowbar ov module is described in every appendix Z power distribution diagram where applicable. >Any comments or clarifications would be helpful The first seven paragraphs of chapter 6 speak to what constitutes "over voltage", where it comes from and how and why it needs to be dealt with in a very specific manner . . . Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Radio Recommendations
> >Hello List, > >Thank You (especially Bob Nuckolls) for the responses to my question about >de-rating mini switches a while back......the answers made great sense and >convinced me what a great resource this list is. I will be contributing a >touch of $ to the list soon. > >I am in the process of re-designing the panel for my Kitfox....basically >going to use fuses instead of breakers and changing from a panel mounted >GPS/Com to a comm & a hand held GPS (mainly for economic reasons). Could >You please recommend the Comm & GPS that will give me the best value as >well as the best place to get them? I'm assuming a Terra Comm & Garmin >GPS but recommendations from experienced people will be very helpful. I have been flying exclusively with $100 gps receivers from WalMart now for about 5 years (Garmin GPS310 and close cousins). They do everything I need to do and for a very attractive price. Until this past weekend, I was under the impression that they had problems getting locked onto satellites if you were (1) a long way and/or long time from where the receiver was turned off or (2) moving. Just as an experiment, I held my GPS310 up to the cabin window on an MD80 on way to Seattle last week. The receiver had been turned off weeks ago and 600 miles away. It took the radio less than a minute to figure out where we were (over southern Idaho), how fast we were going (526 mph) and how high we were (31,250'). Truly amazing little machines. Hard to find more bang for the buck. This experiment showed that one doesn't have to have the flight-bag back-up receiver up and running for the duration of the trip. Not planning to replace my stereo 310's any time soon. Will give another one away at my upcoming weekend seminar in Ft. Worth. Bob . . . ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Date: Mar 20, 2003
And the center tank that exploded and burned on the ramp in Bahrain in front of cameras and witnesses was bogus also? (I think it was Bahrain - if not feel free to correct the location) Denny ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > >Ok, I see. > > > >Could have been spectacular though: full battery voltage across a switch > >no longer fully submerged in oil. Wonder if the flash would have been > >enough to ignite the oil? > > If it were a little bit of oil in a large volume > of air, perhaps. You can't ignite a fuel that > doesn't also have the right ratio of oxygen to > go along with the ignition event. That's what's > so bogus about the official story of root-cause > for TWA800 . . . > > If you've ever done explosion proof testing of > products you'll know how DIFFICULT it is to get > the right ratio for explosive mixture even when > your trying to do it right. Any time the fuel > is in great excess compared to oxygen, the system > is as inert as a rock. Stuff like gunpowder works > anytime because the chemical reaction provides > its own oxygen in an otherwise closed environment. > It's a really neat thing that gasoline and its > cousins make such lousy bombs. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re:intercom question
From: "Mike Bourget" <falconaviation(at)rogers.com> >If I use the Icom 200, and I wish to also have a CD player do I >need to install an intercom? Hi Mike: I have tried to drive stereo aviation headsets (LightSpeeds) from a Sony Discman battery-powered CD player without extra amplification, and it almost works, but not quite. The problem is that the lightweight headphones supplied with the Sony are a much lower impedance (~30 Ohms per ear) than aircraft headsets (~150 Ohms per ear). Since the Sony is powered with just two 1.5V alkaline cells, it is only capable of producing about 2.8V peak to peak of audio signal across 30 Ohms, or open circuit. Now 2.8Vp-p is 1Vrms, meaning that the Sony produces P=E 2/R or (1x1)/30 =33mw per ear. If you substitute a 150 Ohm headset, the voltage out of the Sony stays the same, but the power drops to (1x1)/150 = 7mw. This is just not enough to overcom the ambient noise in the cockpit. The level is just too low, even with the volume control on the headsets, and the Sony running wide open. To drive aviation headsets with the Sony, you need a stereo amplifier which is capable of delivering about 30mw to 150 Ohms. By transposing the above equation, we find that it takes E=sqrt(R*P) or sqrt(0.03*150) = 2.1 Vrms, which is 6Vp-p, which means you need a voltage gain of about 3. There are several ways to get the required voltage gain. Use two transformers, roll your own stereo amp, buy a Muse from PS Engineering (http://www.ps-engineering.com), buy a stereo intercom which contains such an amplifier, or buy an expensive panel-mounted stereo audio switching panel. The problem with audio transformers is availability and bulk. You would need 30Ohm to 150Ohm matching transformer with freq response from 30 Hz to >10000 Hz. These are hard to find. Ones that have good low freq respnse would be fairly big, too. Being cheap, I built a little stereo amp using a single IC audio amp chip. It has a freq response which is flat from 10Hz to 10KHz. It has a fixed gain of 3. It will drive four stereo headsets simultaneouly. The audio quality with the noise-cancelling LightSpeed headsets is HiFi. It automatically mutes the music during intercom or ATC radio activity. I haven't written this up in the form of an article for publication, but might be persuaded to do so... Mike Mladejovsky Skylane '1MM Pacer '00Z ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Altitude control
> > > > ><<> I've got plans for > >> a super sensitive, temperature compensated pressure > >> transducer that gives me +/- 20 foot accuracy to > >> 60,000 feet and better than 1% accuracy for pitot > >> pressures to 300 kts. > > > >Does this mean we will be seeing a reasonably accurate, affordable altitude > >control > >device in > >the near future?>> > > > >Pardon me if I don't hold my breath for this one. 20 feet of accuracy at > >60,000 equates to a maximum error of .00098 psi, or 0.007% of full scale, an > >accuracy not attainable by even laboratory grade sensors. At sea level 20 > >feet equates to 0.01 psi or 0.07% of full scale, within reach of high-end > >pressure sensors, but only over a very limited temperature range. I did misquote the spec . . . (which is inexcusable 'cause I wrote it about 8 years ago). Accuracy at altitudes below 20,000 feet was spec'd at 50 feet but the little box easily holds +/- 20 feet for all effects combined. We spec'd accuracy to degrade linearly above 20,000 feet to +/- 1000 feet at 60K . . . the supplier came in at under 300 feet. This isn't a laboratory grade sensor . . . in fact, it's a jelly-bean part that's individually characterized for production variations and temperature effects as part of the normal environmental screening processes. These sensors are not particularly accurate nor are they stable with temperature but they turned out to be quite repeatable. By driving them with a precision constant current source and measuring the voltage drop across the bridge excitation terminals, the sensor becomes its own temperature monitor. Pressure data is, of course, taken off the bridge taps on either side. For altitude control, one can get by with holding current pressure under prevailing conditions with sufficient resolution to meet requirements of the servo model. This used to be done by simply closing off the vent to an aneroid capsule with a valve and then let the capsule drive an lvdt to characterize departures from the pressure captured within the aneroid. That was the technique of choice in 1965 (Cessna Nav-o-Matic 400). Nowadays, one could use a full range absolute sensor with lots of gain (al-la the techniques described above) or a low range differential sensor and capture valve like the ol' Nav-o-Matics. In either case, one could ignore temperature and calibration issues since you're only interested in the short term stability under present conditions. That's what the ez-trim system does as I recall. Bob . . . Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: RE: RG battery mounting positions
> >Hello Gary, > >Seek out the Concord Battery site for one. They sell Certified RG sealed >lead acid batteries for Certified aircraft and have done so for some number >of years now. > >Jim in Kelowna > >----- Original Message ----- >From: <Aucountry(at)aol.com> >To: >Subject: Re: AeroElectric-List: RE: RG battery mounting positions > > > > > > Anyone on this list ever get an RG battery approved in a cerified plane? > > Especially now with the way the FAA is (more) messed up? > > > > Gary B&C has STC's to put several of their battery offerings into certified ships as well. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
> If you've ever done explosion proof testing of > products you'll know how DIFFICULT it is to get > the right ratio for explosive mixture even when > your trying to do it right. Any time the fuel > is in great excess compared to oxygen, the system > is as inert as a rock. Stuff like gunpowder works > anytime because the chemical reaction provides > its own oxygen in an otherwise closed environment. > It's a really neat thing that gasoline and its > cousins make such lousy bombs. > > Bob . . . That's also why its such a challenge to make a fuel efficient carbuerator/ fuel injection system. And why it takes >17kV to make it light, even with the correct mixture. An interesting observation about twa800. Matt- ________________________________________________________________________________
Date: Mar 20, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Figure Z-14
I see everyone referencing Z-this and Z-that.......This is in reference to? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Firewall penetraton for wires
> >In a message dated 3/14/2003 12:58:18 PM Mountain Standard Time, >Hebeard2(at)aol.com writes: > > > > > > > > First of all I couldn't find any stainless steel towel bars, but with the > > help of a sales person I found stainless steel Grab Bars. I couldn't find > > any > > with the stock number given, but they did have quite a selection. Most > were > > > > 1.5" in diameter rather than 1.25". The various stock numbers referred to > > varying finishes available to facilitate good friction when grasping. > There > > > > were some 1.25" diameter in 24" length which cost $33.00. Searching for a > > shorter length, I found an 18" length in 1.5" diameter for $19.96 (Stock # > > 6318, Satin Stainless Steel). Since length means nothing for our purposes, > > and I am cheap, this is the one I bought. I figure the firestop to plug > the > > > > extra .25" wouldn't cost $13.00. Don't get too hung up on stock numbers, > > look > > at the product under Grab Bars. You don't need to use fire-stop putty to fill the excess volume of the larger tubes. Study the pictures posted at http://www.aeroelectric.com/articles/Firewall_Penetration/firewall.html The only place you need any sealing is under the flange were it bolts to the firewall. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Firewall penetraton for wires
> >Hi Harvey, since I was the one with the stainless towel/ grab bar >suggestion, I am supprised you found a salesman in Home depot that knew >what supplies were in their department. If you happen to be a capable >stainless welder you could just use a piece of tubing with a flange >welded to the end. I am squishing mine with the flange on the firewall >side with fire caulking then over filling the interior of the tube and >wire with the same caulking. The caulking is readilly available in >varying temp's. Do I infer that you're not using fire-sleeve with this installation? Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: runaway, self regulated alternators
> > >Bob > >Thanks for the extended reply. > >However its hard to ignore the melted alternator I had in my hands years >ago. That convinced me that an internal failure could keep the voltage low >enough so the shorted current had time to heat things up and one could not >count on the field acting as a fuse. The theory was a diode failure started >things. >Regardless of our differences I personally would never consider a regulator >that could not be controlled fully. Thus no internal regulator with >connections to the "B" lead. Its just not worth the small cost savings. I'm trying to understand the physics supporting your concerns. It is sufficient to "agree to disagree" in politics but we're talking about differing opinions where you suggest my recommendations offer some potential for fire hazard. My premise is that the action of disconnecting a failed alternator from the bus by means of b-lead disconnect contactor allows the alternator output voltage to rise without restraint offered by any loads or battery. Under these conditions, outputs of over 100 volts are easily realized and the resulting current in the field winding will fuse it in seconds. I've seen LOTS of melted alternators also . . . WITH and WITH0UT external regulators. In every case, destruction of the alternator proceeded within constraints offered by system loads and vehicle's battery. The whole idea of the b-lead disconnect is to encourage timely, uneventful self-destruction of the alternator's internals in a manner that mitigates risks demonstrated countless times when the alternator remains connected to the system. Let's be engineers here and dispel lingering doubts on the part of some who read this list. This is an IMPORTANT discussion Paul. The availability of alternators easily modified for external regulation is low. Availability of off-the- car alternators with stellar track records and built in regulators is high. If we're going to take advantage of what SHOULD be a trend toward utilization of commercial off the shelf products, we need to offer our brothers and sisters good reasons and lucid explanations for our recommendations based on the best engineering we know. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Figure Z-14
http://www.aeroelectric.com/Catalog/BCcatalog.html go to the link above and get the aeroconnection book - the 10th addition -it's $30 - it has all the diagrams - and it's good reading - it will open your eyes to many issues involving wiring on airplanes Scott Bilinski <bilinski@kyocera-wireless.com> wrote:--> AeroElectric-List message posted by: Scott Bilinski I see everyone referencing Z-this and Z-that.......This is in reference to? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 --------------------------------- ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: 10415 Ferris
> Bob: >I'm starting to build a Rans S-12S next month. >These question are on fuses. >1. What are the trip characteristics of the 1-15 amp plug-in fuses on your >website? Are they slow-blow, fast-trip, other? They're stock automotive fast blow fuses. >2. I will have one load that will exceed 15A - a MarinePro 250W 12V cabin >heater. Although the thermostat will adjust power consumption as the cabin >heats up, it could initially draw over 20 amps. How would you recommend >that I protect the wiring to it? >Derek A 250 watt heater in a Rans cabin is like trying to heat your garage with a Bic lighter. People have installed electric heaters in airplanes like the Long-Ez . . . had one builder go for a 60A, 28v system in his Ez so he could have sufficient excess watts to use for cabin heat. Even then, the pair of 700 watt heaters were little more than toe warmers. Have you talked with any other Rans owners who have installed this heater in their airplane? The 250 W heater will draw just under 20A, more than the total energy produced by your alternator (I presume you're using a Rotax 912). Believe me, the thermostat on this heater wont shut the heat off before late spring. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
I believe you are referring to a 737 in Manila in May 1990? Although explosive residue was not found, the possibility remains - I read a report where the passenger decking being pushed upwards was claimed to not be consistent with a fuel-tank explosion... but I haven't read much on it, just wanted to mention that the root cause of that one is still debated. No other fuel-tank explosions are known in 80 years of airline recordkeeping, according to the same reports. -John R. Dennis O'Connor wrote: > > And the center tank that exploded and burned on the ramp in Bahrain in front > of cameras and witnesses was bogus also? > (I think it was Bahrain - if not feel free to correct the location) > > Denny > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > > > >> >> > > >>>Ok, I see. >>> >>>Could have been spectacular though: full battery voltage across a switch >>>no longer fully submerged in oil. Wonder if the flash would have been >>>enough to ignite the oil? >> >> If it were a little bit of oil in a large volume >> of air, perhaps. You can't ignite a fuel that >> doesn't also have the right ratio of oxygen to >> go along with the ignition event. That's what's >> so bogus about the official story of root-cause >> for TWA800 . . . >> >> If you've ever done explosion proof testing of >> products you'll know how DIFFICULT it is to get >> the right ratio for explosive mixture even when >> your trying to do it right. Any time the fuel >> is in great excess compared to oxygen, the system >> is as inert as a rock. Stuff like gunpowder works >> anytime because the chemical reaction provides >> its own oxygen in an otherwise closed environment. >> It's a really neat thing that gasoline and its >> cousins make such lousy bombs. >> >> Bob . . . >> >> > > > > > > > > > ________________________________________________________________________________
Date: Mar 20, 2003
Subject: GM low oil sensor, bum advise
Wasn't that in Bangkok? The prime minister was to board the aircraft a couple of hours later. Initial talk was an assassination attempt. Later they said it was the center tank. Ed Holyoke > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis O'Connor > Sent: Thursday, March 20, 2003 8:07 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > And the center tank that exploded and burned on the ramp in Bahrain in > front > of cameras and witnesses was bogus also? > (I think it was Bahrain - if not feel free to correct the location) > > Denny > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > > > > > > > > >Ok, I see. > > > > > >Could have been spectacular though: full battery voltage across a > switch > > >no longer fully submerged in oil. Wonder if the flash would have been > > >enough to ignite the oil? > > > > If it were a little bit of oil in a large volume > > of air, perhaps. You can't ignite a fuel that > > doesn't also have the right ratio of oxygen to > > go along with the ignition event. That's what's > > so bogus about the official story of root-cause > > for TWA800 . . . > > > > If you've ever done explosion proof testing of > > products you'll know how DIFFICULT it is to get > > the right ratio for explosive mixture even when > > your trying to do it right. Any time the fuel > > is in great excess compared to oxygen, the system > > is as inert as a rock. Stuff like gunpowder works > > anytime because the chemical reaction provides > > its own oxygen in an otherwise closed environment. > > It's a really neat thing that gasoline and its > > cousins make such lousy bombs. > > > > Bob . . . > > > > > > > > > > ________________________________________________________________________________
Date: Mar 20, 2003
> > >From: "Mike Bourget" <falconaviation(at)rogers.com> > > >If I use the Icom 200, and I wish to also have a CD player do I > >need to install an intercom? > >Hi Mike: > >I have tried to drive stereo aviation headsets (LightSpeeds) >from a Sony Discman battery-powered CD player without extra >amplification, and it almost works, but not quite. Mike, a lucid and accurate analysis. Thank you for sharing . . . >Being cheap, I built a little stereo amp using a single IC audio >amp chip. It has a freq response which is flat from 10Hz to >10KHz. It has a fixed gain of 3. It will drive four stereo >headsets simultaneouly. The audio quality with the >noise-cancelling LightSpeed headsets is HiFi. It automatically >mutes the music during intercom or ATC radio activity. > >I haven't written this up in the form of an article for >publication, but might be persuaded to do so... I'd be pleased to publish it on aeroelectric.com . . . Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Automation of Alternator Disconnect system
Bob: any ideas on automating the Alternator disconnect system? Like how about if the Voltage crowbar thingy goes off, it would automatically disconnect the alternator contactor and alternator field? this would also turn on a light to let you know you where running only on the battery? What things would you need to consider in an automated system which took care of this alternator field switch and alternator disconnect switch? --------------------------------- ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Electrical Noise in aircraft wiring
I have been reading the aeroelectric forum for a few months. I have noticed that a lot of the discussions have to do with the mechanics of wiring aircraft, i.e crimping vs soldering, wire sizes, ring terminals, etc. Also, there is a lot of discussion about circuit protection, redundency, reliability, spike suppression, etc. Occasionaly, there are a few questions about electrical noise, i.e., shielding, grounding, ground loops, bypassing, filtering, especially where it involves audio, intercoms, mic wiring, audio switching panels, entertainment. Usually, what starts the discussion is something like "how do I get the alternator whine/strobe squeal out of my headphones?" The topic of grounding/shielding is often the least understood, and there is a lot of bad advice that is meted out, here and on other forums. I'll go so far as to say that a lot of avionics vendors, and most avionics installers dont really know what they are doing. I just happened to be poking around at an Intel Microcontroller site, and found the following application note AN-125, which succinctly discusses this topic: http://www.intel.com/design/auto/mcs96/applnots/21031302.PDF "Designing Microcontroller Systems for Electrically Noisy Environments". Read the app note. Study it. There will be a quiz.... Mike Mladejovsky ________________________________________________________________________________
Subject: Too close to my compass?
Date: Mar 20, 2003
I am retrofitting my fiberglass aircraft with a B&C 200G alternator and accompanying regulator & filter capacitor. Space behind the panel is at a premium, and it is very difficult to work down there, close to the firewall. I would like to install the voltage regulator right behind the panel, but this location is about 6" forward of my whiskey compass. Do you think this will present a problem and create magnetic interference? If I had my druthers, I would really like to mount it on the forward side of the firewall, but the installation diagram calls for the aft side of the FW. Any comments? Sam Hoskins Quickie Q-200 ~1,375 hours (Friends don't let friends fly metal airplanes). ________________________________________________________________________________
Date: Mar 20, 2003
Hi Bob, Just started reading your book, Is (fire Sleave) something I have not got to yet? Not familiar with it. Ron Triano -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Firewall penetraton for wires --> >--> > >Hi Harvey, since I was the one with the stainless towel/ grab bar >suggestion, I am supprised you found a salesman in Home depot that knew >what supplies were in their department. If you happen to be a capable >stainless welder you could just use a piece of tubing with a flange >welded to the end. I am squishing mine with the flange on the firewall >side with fire caulking then over filling the interior of the tube and >wire with the same caulking. The caulking is readilly available in >varying temp's. Do I infer that you're not using fire-sleeve with this installation? Bob . . . direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Automation of Alternator Disconnect system
> > >Bob: > >any ideas on automating the Alternator disconnect system? Like how about >if the Voltage crowbar thingy goes off, it would automatically disconnect >the alternator contactor and alternator field? this would also turn on a >light to let you know you where running only on the battery? > >What things would you need to consider in an automated system which took >care of this alternator field switch and alternator disconnect switch? Not sure if I understand your question but I think it's already automated. Within seconds of an ov tripout, the bus voltage drops below 13.0 volts and your low-voltage warning light begins to flash. Not sure what else is needed here . . . Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
><bilinski@kyocera-wireless.com> > >I see everyone referencing Z-this and Z-that.......This is in reference to? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 Appendix Z of the AeroElectric Connection is a growing collection of power distribution diagrams that provide a basis configuring a system to meet your mission needs. Most single engine airplanes produced since the first batteries went on board about 1948 haven't materially advanced in philosophy to this day. The Appendix Z drawings offer a variety of starting points depending on your mission and budget. The drawings are part of the book . . . but since they are updated with every revision to the book, they can also be downloaded as part of the information packages indexed at: http://www.aeroelectric.com/articles.html Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Turn coordinator noise
> >Dear Bob, >I've installed a cheap turn coordinator in my CH701. It's causing noise >in the headset when intercom on, or when transmitting. No noise when >receiving only. I've looked at some of your suggestions in the archive >and will try some of them tommorrow. > >Is it likely that if I had bought an expensive instrument that it wouldn't >cause noise problems? Several people have experienced the same problem over the years and it seems to always involve a Chinese manufactured instrument. Someone on the list promised me the "carcase" of his purchase should it prove to be a noise problem too. I'll see if I can get my friends out at the RFI lab to look at its noise characteristics. It might be possible to craft a modification and/or filter to mitigate the problem. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Contactor Questions
> Bob, need to know which large posts on the S-701-1 OV Disc. The large terminals are interchangeable. The small terminals are also except that the diode polarity determines which terminal gets (+) voltage. >Contactor does the "b" lead from Alt. fasten (Bat post or other post) on >Z-24 11/01? Also, which small post does the "F" and Alt. Fld. 5 Amp wires >(20AWG) fasten to or does it matter?? This contactor has a diode from the >Bat.post to the first small post on the right- horizontally. This post >has two more diodes also - (one to the next small post to the right and >one that fastens to the other large post not identified). If you truly have an S701-1 contactor it should have been sent to you looking like this: http://www.aeroelectric.com/Catalog/switch/s701-1l.jpg Either fat terminal can be wired to the alternator with the other one going to starter contactor. You would REMOVE the red jumper wire visible in on the left side of the picture. Small terminal on right goes to ground, small terminal on left goes to your field switch. What you've described has three diodes and probably looks like this: http://www.aeroelectric.com/Catalog/switch/s701-2.jpg This is the S701-2 contactor supplied with extra diodes to serve as a cross-feed contactor in Z-14. If this is what you have, then remove two diodes wired to each fat terminal and then wire as described for the -1 contactor above. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: exploding Jet-A
><jrourke@allied-computer.com> > >I believe you are referring to a 737 in Manila in May 1990? > >Although explosive residue was not found, the possibility remains - I >read a report where the passenger decking being pushed upwards was >claimed to not be consistent with a fuel-tank explosion... but I haven't >read much on it, just wanted to mention that the root cause of that one >is still debated. > >No other fuel-tank explosions are known in 80 years of airline >recordkeeping, according to the same reports. > >-John R. >Dennis O'Connor wrote: > > > > > And the center tank that exploded and burned on the ramp in Bahrain in > front > > of cameras and witnesses was bogus also? > > (I think it was Bahrain - if not feel free to correct the location) There has been an exhaustive study of public data on the TWA800 incident. I've read quite a bit of it with particular interest discussions illuminated with logic and good physics. Like all such cases, there are plenty of "fog generators" in the discussion including conspiracy theorists and (not the least of which) are agencies of government with competing agendas. The tank in question had to have unusable and/or unused liquid fuel in it. I am mystified as to how the vapor-space in any closed volume with liquid in the bottom, dilutes what would normally be a nearly saturated mixture of fuel/air down to a stoichiometric ratio required for combustion with a high release of energy with any fuel, much less Jet-A. This is but ONE of many questions which I find puzzling. You're free to evaluate for yourself. There are many reasons to be suspicious of the engineering and investigative techniques . . . but be prepared to spend some time looking through the details. check out www.twa800.com http://home.earthlink.net/~neteagle/ Here's but one of many examples of logical, detailed and independent analysis to be found with a bit of websearching . . . http://www.compassionateweb.net/~missiletwa800/mann.htm and as a tip of the iceberg . . . http://www.worldnetdaily.com/news/article.asp?ARTICLE_ID=24075 http://twa800.com/news/Stalcup.htm http://www.flight800.org/sketch.htm http://www.multipull.com/twacasefile/second649.html http://twa800.com/images/exhibit22c_radar.pdf It's a complex puzzle but in the final analysis, only the RIGHT pieces fit together into the real picture. I've found the reasoning of a number of folks to be compelling and in direct contradiction with the officially published accounts. If you feel compelled to learn and/or enjoy putting big puzzles together one could do worse than study what's out there on TWA800. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Grounding
om> >Bob, > > >> Single ground blocks are shipped with with a shorter brass carry >through bolt, washers and nuts for sheet metal firewalls. If in doubt as >you your grounding needs, drop us an e-mail note. > >Getting ready to order some items off your website (what an awesome >resource) and had an electric ground related question. I'm building a >Zodiac 601HDS with a Subaru EA81 (engine mounted up front w/ starter, >low wing, all metal) and will have the battery installed behind the >seats due to weight and balance issues. I'll be running the battery >cables up to the firewall area and need to decide how to deal with the >ground cable. Would it be better to hook it on the cockpit side of the >firewall and attach it to your 24 prong ground plane and then use a >'patch cable' on the engine side of the firewall to the crankcase? The ground block is intended to be used just as you've described. The ideal installation runs (-) lead(s) for battery plus a crankcase ground strap to the single brass bolt through the firewall. All other grounds are best routed to the same block with the exceptions of strobe power supply, landing and taxi lights, pitot heater and nav lights can use local grounds where practical on a metal airframe. >If I understand the grounding and resistance issues properly (as far as >the starter is concerned), it's important to have as little resistance >as possible and having a good ground system is vital to ensure that the >voltage available to the starter is sufficient. Since every attachment >point raises the resistance level I wasn't sure if I should run the >negative side of the battery to the crankcase and then jumper it back to >the 24 prong ground plane or since the airplane is all metal, just run >the ground cable to the crankcase and not worry about the jumper cable. I don't know as it's "vital" . . . just good engineering practice. A couple of hundred thousand airplanes were NOT wired this way and they operate mostly sorta okay . . . but if we know of a better way and it's easy to do, why not? Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Electrical Noise in aircraft wiring
>I just happened to be poking around at an Intel Microcontroller >site, and found the following application note AN-125, which >succinctly discusses this topic: > >http://www.intel.com/design/auto/mcs96/applnots/21031302.PDF > >"Designing Microcontroller Systems for Electrically Noisy >Environments". > >Read the app note. Study it. There will be a quiz.... This is an excellent piece that describes the practical use of a lot of good physics . . . but while many of the principals are common, the applications are not well translated from microprocessor-based-black- box into a how-to-wire-airplanes language. Most noise problems in airplanes come from poor ground architectures. Single point grounding takes care of this. This leaves use with a very few issues that involve radiated or electro-statically coupled noise which are generally pretty easy to predict and avoid in the design phase and easy to fix if discover that we've stubbed our toe at some later time. I don't think I'd recommend the airframe guy spend much time with this piece. But if you've a hanker'n to craft some sort of new black box, it's probably required reading whether your box is processor based or not. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
Subject: Re: Too close to my compass?
> > >I am retrofitting my fiberglass aircraft with a B&C 200G alternator and >accompanying regulator & filter capacitor. Space behind the panel is at a >premium, and it is very difficult to work down there, close to the firewall. > >I would like to install the voltage regulator right behind the panel, but >this location is about 6" forward of my whiskey compass. Do you think this >will present a problem and create magnetic interference? probably >If I had my druthers, I would really like to mount it on the forward side of >the firewall, but the installation diagram calls for the aft side of the FW. it will be okay on the forward side. You need to keep all wiring as far as possible from compass. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2003
> >Hi Bob, Just started reading your book, Is (fire Sleave) something I >have not got to yet? Not familiar with it. > >Ron Triano See http://www.paragonperformance.com/Fire%20Sleeve.html http://www.amstreetrod.com/html/firesleeve.html#desc http://www.chiefaircraft.com/Aircraft/HoseFittings/AeroquipFiresleeve.html Used lots of places under cowl . . . protecting firewall penetrations for wires is but one application. See http://www.aeroelectric.com/articles/Firewall_Penetration/firewall.html Bob . . . ________________________________________________________________________________
Subject: GM low oil sensor redux
Date: Mar 21, 2003
Maybe I missed it in the continuing discussion of fuel tank explosions.... but my original question was whether anyone had any experience with these inductive type switches and knew whether they are designed for direct application of 12volts or something less (I would prefer to not fry it finding out) :) Also, was there a final consensus on the contactor/diode question (bigger diode, TVS, or just say no)? Thanks. Mark ________________________________________________________________________________
Date: Mar 21, 2003
> You need to keep all wiring as far as possible from compass. As a data point on this, I just moved some wires for landing and nav lights which were deflecting the panel mount compass 30 degrees when running past it one inch away. At 3 inches the deflection was barely noticable - maybe 2 degrees. At 6 inches I couldnt see any deflection at all. I moved the wires 18 away. For some reason, a fuel pump wire didnt have any effect, even at 1 inch. John SLade Cozy IV ________________________________________________________________________________
Subject: Re: GM low oil sensor, bum advise
Date: Mar 21, 2003
There was a 'B' in the name somewhere :) Denny ----- Original Message ----- From: "Ed Holyoke" <bicyclop(at)pacbell.net> Subject: RE: AeroElectric-List: GM low oil sensor, bum advise > > Wasn't that in Bangkok? The prime minister was to board the aircraft a > couple of hours later. Initial talk was an assassination attempt. Later > they said it was the center tank. > > Ed Holyoke > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > > aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis O'Connor > > Sent: Thursday, March 20, 2003 8:07 AM > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > > > > > And the center tank that exploded and burned on the ramp in Bahrain in > > front > > of cameras and witnesses was bogus also? > > (I think it was Bahrain - if not feel free to correct the location) > > > > Denny > > ----- Original Message ----- > > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > > To: > > Subject: Re: AeroElectric-List: GM low oil sensor, bum advise > > > > > > > > > > > > > > > > > > >Ok, I see. > > > > > > > >Could have been spectacular though: full battery voltage across a > > switch > > > >no longer fully submerged in oil. Wonder if the flash would have > been > > > >enough to ignite the oil? > > > > > > If it were a little bit of oil in a large volume > > > of air, perhaps. You can't ignite a fuel that > > > doesn't also have the right ratio of oxygen to > > > go along with the ignition event. That's what's > > > so bogus about the official story of root-cause > > > for TWA800 . . . > > > > > > If you've ever done explosion proof testing of > > > products you'll know how DIFFICULT it is to get > > > the right ratio for explosive mixture even when > > > your trying to do it right. Any time the fuel > > > is in great excess compared to oxygen, the system > > > is as inert as a rock. Stuff like gunpowder works > > > anytime because the chemical reaction provides > > > its own oxygen in an otherwise closed environment. > > > It's a really neat thing that gasoline and its > > > cousins make such lousy bombs. > > > > > > Bob . . . > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 21, 2003
Fine Bob... Not wanting to get into a hoohaa over it... In a previous lifetime I happened to hang around the plant engineering department of a small, multinational automobile corporation... One of our perenniel problems was the exploding 55 gallon, steel drum... One in particular I remember was a millwright that managed to blow up a kerosene drum (similar to Jet A) that he was chiseling the top off from, with an airpowered chisel... At that point I issued an absolute ban on reusing 55 gallon drums, which cost us some money but saved a lot more in the long run... Denny ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: exploding Jet-A > > ><jrourke@allied-computer.com> > > > >I believe you are referring to a 737 in Manila in May 1990? > > > >Although explosive residue was not found, the possibility remains - I > >read a report where the passenger decking being pushed upwards was > >claimed to not be consistent with a fuel-tank explosion... but I haven't > >read much on it, just wanted to mention that the root cause of that one > >is still debated. > > > >No other fuel-tank explosions are known in 80 years of airline > >recordkeeping, according to the same reports. > > > >-John R. > > >Dennis O'Connor wrote: > > > > > > > > And the center tank that exploded and burned on the ramp in Bahrain in > > front > > > of cameras and witnesses was bogus also? > > > (I think it was Bahrain - if not feel free to correct the location) > > There has been an exhaustive study of public data on > the TWA800 incident. I've read quite a bit of it with > particular interest discussions illuminated with > logic and good physics. Like all such cases, there > are plenty of "fog generators" in the discussion > including conspiracy theorists and (not the least > of which) are agencies of government with competing > agendas. > > The tank in question had to have unusable and/or > unused liquid fuel in it. I am mystified as to how > the vapor-space in any closed volume with liquid in > the bottom, dilutes what would normally be a nearly > saturated mixture of fuel/air down to a > stoichiometric ratio required for combustion with > a high release of energy with any fuel, much less > Jet-A. This is but ONE of many questions which I > find puzzling. > > You're free to evaluate for yourself. There are > many reasons to be suspicious of the engineering > and investigative techniques . . . but be prepared > to spend some time looking through the details. > > check out www.twa800.com > http://home.earthlink.net/~neteagle/ > > Here's but one of many examples of logical, detailed and > independent analysis to be found with a bit of > websearching . . . > > http://www.compassionateweb.net/~missiletwa800/mann.htm > > and as a tip of the iceberg . . . > > http://www.worldnetdaily.com/news/article.asp?ARTICLE_ID=24075 > http://twa800.com/news/Stalcup.htm > http://www.flight800.org/sketch.htm > http://www.multipull.com/twacasefile/second649.html > http://twa800.com/images/exhibit22c_radar.pdf > > It's a complex puzzle but in the final analysis, only > the RIGHT pieces fit together into the real picture. > I've found the reasoning of a number of folks to > be compelling and in direct contradiction with > the officially published accounts. > > If you feel compelled to learn and/or enjoy putting > big puzzles together one could do worse than study > what's out there on TWA800. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 21, 2003
Subject: Re: GM low oil sensor redux
> >Maybe I missed it in the continuing discussion of fuel tank explosions.... >but my original question was whether anyone had any experience with these >inductive type switches and knew whether they are designed for direct >application of 12volts or something less (I would prefer to not fry it >finding out) :) Don't understand this question. What's an "inductive type" switch? Any switch is limited by it's physical attributes and operating characteristics as described in: http://www.aeroelectric.com/articles/swtchrat.pdf what are the ratings for the device you're considering. When you wrote something about putting 12v directly across the switch, were you saying that you blew it up by having the switch hard-fault a 12v source? What does this switch drive? The best thing is for the switch to close to ground so that only lamp or some small signal current flows in the switch under any conditions, normal or faulted. >Also, was there a final consensus on the contactor/diode question (bigger >diode, TVS, or just say no)? Haven't had time to wade through the threads on contactor spike catchers. Did an article on the subject at: http://www.aeroelectric.com/articles/spikecatcher.pdf . . . the short answer is put a diode across the coil of any inductive device such as a contactor or solenoid. It will improve the life of the switching device. All other concerns for whether or not movs, transorbs, resistors, capacitors, etc, etc should be part of the circuit are either myths or insignificant to the task. Bob . . . ________________________________________________________________________________
Date: Mar 21, 2003
Subject: pin outs
bob I have a KT-78 king transponder. I have a copy of your pin out legend. But I don't understand the circuit column. What do the A1, A2, B2 etc. numbers refer to?? Thanks for answering stupid questions a hundred times I am sure. cary rhodes http://platinum.yahoo.com ________________________________________________________________________________
Date: Mar 21, 2003
Subject: Re: relay switch protection
> >This discussion got started over a shorted battery contactor coil dampening >device and the concern of smoke or fire from an UN-fused circuit wired with >22ga. wire used to supply the ground to the battery contactor. Although very >unlikely, the contactor's coil could short, and again not very likely, the >diode used to dampen the contactor's coil could short. All things >considered, a diode is best for coil dampening performance. Most other >devices will be a source for ringing or not clamp the voltage as low as can >be done with a diode. We really are splitting hairs here though. An MOV >will clamp it at some voltage just over 15 volts -not bad. While a diode >will clamp it at .6 volts -better. I am going to insert a 5A fuse in my >grounding leg at the contactor end of the 22ga. wire to be safe I think. One >could increase the size of the wire to say 16, 12, 10 , etc., and let the >shorted diode or coil become the fuse! I am not concerned about a failure >that results in an open circuit. That will just have to be a failure that >requires picking a spot to land. I just want to be reasonable enough to >protect my ship from smoke in the cockpit. > >Again, this one circuit may be cause for concern only in the very remote >chance that the contactor's coil shorts or the diode punches through. A >simple fuse can set us all at ease. True . . . but take care lest we become "uneasy" about a whole lot of things that are so far down on the ladder of concerns. The scenario you hypothesized, while obviously not ZERO risk, it's tiny compared to the risk of your wing bolts shearing off or your propeller flying away. It's like those articles you read by new journalism graduates who advise that you keep a first aid kit in your car . . . I'll bet those articles have precipitated the sales of bizillions of first aid kits (you can find them in the automotive section of any Walmart). In 40 years of driving a car, I cannot recall a single instance of wishing I'd bought that first aid kit. I've had several instances where "aid" was necessary, but nothing contained in that little tin box was going to be helpful. Let's not load our airplanes up with "little tin boxes" . . . Bob . . . >John P. Marzluf >Columbus, Ohio >Outback, (out back in the garage) > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Subject: Re: pin outs
Date: Mar 21, 2003
Those are the encoder inputs, I believe. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "cary rhodes" <rhodeseng(at)yahoo.com> Subject: AeroElectric-List: pin outs > > bob > > I have a KT-78 king transponder. > > I have a copy of your pin out legend. > > But I don't understand the circuit column. > > What do the A1, A2, B2 etc. numbers refer to?? > > > Thanks for answering stupid questions a hundred times > I am sure. > > cary rhodes > > > http://platinum.yahoo.com > > ________________________________________________________________________________
Date: Mar 21, 2003
But, did it have any liquid fuel in it? If not, the air-fuel mixture could get to a stoichiometric level to support combustion. Plus, in using the air chisel you are introducing an opening through which air can enter, which can certainly allow it to achieve the proper air-fuel ratio for combustion (even if there was alittle liquid in the bottom), AND providing the spark for ignition... baaaad idea! But, a sealed fuel tank does not provide the same scenario as far as I can tell. -John Dennis O'Connor wrote: > > Fine Bob... Not wanting to get into a hoohaa over it... > In a previous lifetime I happened to hang around the plant engineering > department of a small, multinational automobile corporation... One of our > perenniel problems was the exploding 55 gallon, steel drum... One in > particular I remember was a millwright that managed to blow up a kerosene > drum (similar to Jet A) that he was chiseling the top off from, with an > airpowered chisel... At that point I issued an absolute ban on reusing 55 > gallon drums, which cost us some money but saved a lot more in the long > run... > > Denny > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: AeroElectric-List: Re: exploding Jet-A > > > > > > >> >>><jrourke@allied-computer.com> >>> >>>I believe you are referring to a 737 in Manila in May 1990? >>> >>>Although explosive residue was not found, the possibility remains - I >>>read a report where the passenger decking being pushed upwards was >>>claimed to not be consistent with a fuel-tank explosion... but I haven't >>>read much on it, just wanted to mention that the root cause of that one >>>is still debated. >>> >>>No other fuel-tank explosions are known in 80 years of airline >>>recordkeeping, according to the same reports. >>> >>>-John R. >> >>>Dennis O'Connor wrote: >>> >>> >>> >>> >>>>And the center tank that exploded and burned on the ramp in Bahrain in >>> >>>front >>> >>>>of cameras and witnesses was bogus also? >>>>(I think it was Bahrain - if not feel free to correct the location) >>> >> There has been an exhaustive study of public data on >> the TWA800 incident. I've read quite a bit of it with >> particular interest discussions illuminated with >> logic and good physics. Like all such cases, there >> are plenty of "fog generators" in the discussion >> including conspiracy theorists and (not the least >> of which) are agencies of government with competing >> agendas. >> >> The tank in question had to have unusable and/or >> unused liquid fuel in it. I am mystified as to how >> the vapor-space in any closed volume with liquid in >> the bottom, dilutes what would normally be a nearly >> saturated mixture of fuel/air down to a >> stoichiometric ratio required for combustion with >> a high release of energy with any fuel, much less >> Jet-A. This is but ONE of many questions which I >> find puzzling. >> >> You're free to evaluate for yourself. There are >> many reasons to be suspicious of the engineering >> and investigative techniques . . . but be prepared >> to spend some time looking through the details. >> >> check out www.twa800.com >> http://home.earthlink.net/~neteagle/ >> >> Here's but one of many examples of logical, detailed and >> independent analysis to be found with a bit of >> websearching . . . >> >> http://www.compassionateweb.net/~missiletwa800/mann.htm >> >> and as a tip of the iceberg . . . >> >> http://www.worldnetdaily.com/news/article.asp?ARTICLE_ID=24075 >> http://twa800.com/news/Stalcup.htm >> http://www.flight800.org/sketch.htm >> http://www.multipull.com/twacasefile/second649.html >> http://twa800.com/images/exhibit22c_radar.pdf >> >> It's a complex puzzle but in the final analysis, only >> the RIGHT pieces fit together into the real picture. >> I've found the reasoning of a number of folks to >> be compelling and in direct contradiction with >> the officially published accounts. >> >> If you feel compelled to learn and/or enjoy putting >> big puzzles together one could do worse than study >> what's out there on TWA800. >> >> Bob . . . >> >> > > > > > > > > > ________________________________________________________________________________
Date: Mar 21, 2003
I see no point to beating a dead horse. I resent your 'shot' about me not acting like an engineer You simply do not know the extent of my training and experience. I simply am unwilling to present facts based on unproven conjecture and or no longer or never known. There is not always an clear engineering determination of the failure method. Surely you do not mean to infer that the the use of the "B" lead contactor will prevent ALL failures that could cause overheating of the alternator. I did have a shorted out (burned up) alternator, the damage was too large to analyze properly. Several electrical engineers concluded the failure could have been from shorted diodes in the alternator diode module and that produced an internal load that prevented the high voltage that could over current the field and shut the "heat" down. There was no indication of external over loading or external overvoltage. This was many years ago. As a design engineer I have found there is little need to recall why things are not good designs as long as you remember that an approach is not good and there is a better one that is available. As you know one cannot always determine the initial cause of the failure, but when most any assumption can be eliminated by a simple alternative design, simply select the better approach and go on. I would have presented proof if there was any ever determined. The engineers doing the analysis concluded that an internal diode failure could result in a shorted winding that would essentially short the alternator out preventing overvoltage while all the current was used to heat the primary winding that was shorted. Frankly I do not understand your not recognizing that failure mode. Your suggestion that the only failure method would result in an overvoltage and resulting field fusing open is only one failure mode and while it may be the most likely it is not in my experience the only one. In any event I stand by my position that its safer to externally regulate the alternator and is so easy to do. Simply use a different alternator or modify the one you insist using. Small light 40-60 amp alternators are available so why not use them. I disagree good alternators are hard to find. Harder perhaps but they are out there. Also I have looked at many ND alternators and also would not use them in an aircraft. Common yes, simple to modify NO, poor slipring life, very common. Not one found out of dozens from a junk yard had usable sliprings. The position and seal used for slipring protection all flails to varying extent and allowed grit inside and the sliprings were heavily worn down. Why spend the same amount $ for the ND or much more for a converted ND when other brands are similar in size and weight?, and better suited to aircraft use. Not that ND are bad, but I would suggest your comments about stamped sub "D" pins vs machined pins is a similar case. Perhaps the stamped pins are harder to properly use but properly assembled are the additional costs of machined pins worth it? With proper harness support most wiring will outlast the aircraft. I fly a 67 Cessna from time to time and fine the factory wiring and wireing support is the worst example of what seems to work in spite of what good wiring should be. I would not use a ND on my acft. Why spend 30-60K on an acft and save $100 or so on a lesser alternator. I do not intend to keep this thread going with further comments. I think its been beaten too much already. Sorry if I have failed to provide a suitable (to you) reply. Paul > Let's be engineers here and dispel lingering > doubts on the part of some who read this list. This > is an IMPORTANT discussion Paul. The availability > of alternators easily modified for external > regulation is low. Availability of off-the- > car alternators with stellar track records > and built in regulators is high. If we're > going to take advantage of what SHOULD be > a trend toward utilization of commercial off > the shelf products, we need to offer our > brothers and sisters good reasons and lucid > explanations for our recommendations based > on the best engineering we know. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 21, 2003
Those are the data lines for your encoder. ----- Original Message ----- From: "cary rhodes" <rhodeseng(at)yahoo.com> Subject: AeroElectric-List: pin outs > > bob > > I have a KT-78 king transponder. > > I have a copy of your pin out legend. > > But I don't understand the circuit column. > > What do the A1, A2, B2 etc. numbers refer to?? > > > Thanks for answering stupid questions a hundred times > I am sure. > > cary rhodes > > > http://platinum.yahoo.com > > ________________________________________________________________________________
Date: Mar 21, 2003
> > >Fine Bob... Not wanting to get into a hoohaa over it... >In a previous lifetime I happened to hang around the plant engineering >department of a small, multinational automobile corporation... One of our >perenniel problems was the exploding 55 gallon, steel drum... One in >particular I remember was a millwright that managed to blow up a kerosene >drum (similar to Jet A) that he was chiseling the top off from, with an >airpowered chisel... At that point I issued an absolute ban on reusing 55 >gallon drums, which cost us some money but saved a lot more in the long >run... it's a sure bet he thought he was doing a good thing by working on a container that was "empty" . . . when in fact, he would have been better off if it had been half full. A weld shop down the street from me when I was a kid got a guy killed when he put a torch to a tank that had been "washed out" . . . the same weld shop is still there. They flush tanks to be repaired with CO2 now . . . The nose is an excellent safety tool here . . . but if one smokes, perhaps that tool is compromised. If you can smell any remnant of the stuff that used to occupy the volume, you're not through cleaning it -OR- you fill the volume with CO2 before you start working on it. Bob . . . ________________________________________________________________________________
Date: Mar 21, 2003
> > >I see no point to beating a dead horse. > >I resent your 'shot' about me not acting like an engineer You simply do not >know the extent of my training and experience. I simply am unwilling to >present facts based on unproven conjecture and or no longer or never known. >There is not always an clear engineering determination of the failure >method. I said let US be good engineers here . . . perhaps it is I who needs enlightened . . . I have offered data and hypothesis based on what I believe is a logical assimilation of facts. So far, you have voiced only concerns based on some smoked alternators you have experienced/observed. >Surely you do not mean to infer that the the use of the "B" lead contactor >will prevent ALL failures that could cause overheating of the alternator. Of course not, I've seen both internally and externally regulated alternators go up in smoke with severe damage. In every case, the alternators were connected to external loads during the entire destruction sequence. >I did have a shorted out (burned up) alternator, the damage was too large to >analyze properly. Several electrical engineers concluded the failure could >have been from shorted diodes in the alternator diode module and that >produced an internal load that prevented the high voltage that could over >current the field and shut the "heat" down. There was no indication of >external over loading or external overvoltage. >I would have presented proof if there was any ever determined. Proof based on a single case observation is not what's needed here. What I was asking for was a failure modes effects analysis that shows how internal/external alternators stack up with each other in similar failures. > . . . The engineers >doing the analysis concluded that an internal diode failure could result in >a shorted winding that would essentially short the alternator out preventing >overvoltage while all the current was used to heat the primary winding that >was shorted. Frankly I do not understand your not recognizing that failure >mode. The failure modes that produce underage smoking on the part of alternators can happen in both types and yes, without causing an over-voltage condition . . . in fact, EVERY smoked alternator I've pulled seen pulled from the wreckage did NOT participate in an ov event and NONE of them were internally regulated. So my question is, how is an internally regulated machine any more hazardous? >Your suggestion that the only failure method would result in an overvoltage >and resulting field fusing open is only one failure mode and while it may be >the most likely it is not in my experience the only one. I suggested no such thing. Your premise as I understood it said that an internally regulated alternator presents an increased risk of fire because of mutually acknowledged OV failure modes that could not be shut down peaceably from the outside . . . that even when we included the b-lead contactor to protect the rest of the airplane from impending doom, the alternator was still an increased risk because it would operate in what has to be a relatively slow, self destruction mode that would burn things up. I offered that in an ov condition and the alternator unhooked from the ship's systems that (1) the alternator's only load was its own field winding and (2) the output voltage would do what faulted alternators do best and rise to levels over 100 volts and (3) the field winding would last mere seconds with 25+ amps of current flowing in it. >In any event I stand by my position that its safer to externally regulate >the alternator and is so easy to do. Simply use a different alternator or >modify the one you insist using. Small light 40-60 amp alternators are >available so why not use them. I disagree good alternators are hard to find. >Harder perhaps but they are out there. > >I do not intend to keep this thread going with further comments. I think its >been beaten too much already. Sorry if I have failed to provide a suitable >(to you) reply. We're discussing two different failure scenarios one in which no OV condition occurs and one where it does. You offered a opinion for increased hazard due to the way internally regulated alternators are wired and controlled. I thought I'd laid out fact that show an ov condition with an internally regulated but ISOLATED alternator terminates quickly and quietly. Further, all other failures inclined to smoke the machine can happen with EITHER type alternator thus making the extra-ordinary hazard for the off-the-shelf internally regulated alternator difficult to support. Let US be good engineers and figure out where this is wrong. If you have an alternator with burned windings, bad diodes, etc then we're not talking about an ov condition. Should one become aware of the problem, both kinds alternators can be shut down . . . except that the internally regulated alternator has the decided ADVANTAGE of being unhooked from the system via the b-lead contactor. It's unlikely that a pilot will become aware of the problem before the alternator fails irretrievably and disconnects itself via the b-lead fuse or breaker. Now, if the pilot needs to see through an iced-over window now gone cold . . . well . . . I've dug through that pile before. Bob . . . ________________________________________________________________________________
Date: Mar 21, 2003
Subject: off line again . . .
Leaving for Ft. Worth in a few minutes for a couple of days of good airplane-speak with builders in George and Becki's hangar. Back late Sunday night. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 21, 2003
Subject: Re: off line again . . .
Robert L. Nuckolls, III wrote: >Leaving for Ft. Worth in a few minutes for a couple >of days of good airplane-speak with builders in George >and Becki's hangar. Back late Sunday night. Darn! And only a few miles from me! If you're still here, what is the cost and schedule? I'll see if I can make it if at all possible. Thanks, Steve ________________________________________________________________________________
Date: Mar 21, 2003
Steve, Check out the AeroElectric home page, the courses are listed there. Cost is $150 or it was last year when I took it. Highly recommended, best value for $150 I've gotten so far. ----- Original Message ----- From: "Canyon" <steve.canyon(at)verizon.net> Subject: Re: AeroElectric-List: off line again . . . > > Robert L. Nuckolls, III wrote: > >Leaving for Ft. Worth in a few minutes for a couple > >of days of good airplane-speak with builders in George > >and Becki's hangar. Back late Sunday night. > > Darn! And only a few miles from me! If you're still here, what is the > cost and schedule? I'll see if I can make it if at all possible. > > Thanks, > Steve > > ________________________________________________________________________________
Date: Mar 21, 2003
Steve, go to www.aeroelectric.com/seminars/seminars.html ----- Original Message ----- From: "Canyon" <steve.canyon(at)verizon.net> Subject: Re: AeroElectric-List: off line again . . . > > Robert L. Nuckolls, III wrote: > >Leaving for Ft. Worth in a few minutes for a couple > >of days of good airplane-speak with builders in George > >and Becki's hangar. Back late Sunday night. > > Darn! And only a few miles from me! If you're still here, what is the > cost and schedule? I'll see if I can make it if at all possible. > > Thanks, > Steve > > ________________________________________________________________________________
Subject: Re: RE: Microair radio
Date: Mar 21, 2003
Rino, Just incase you never received an answer to your question, try www.xcom760.com. or www.becker-avionics.com. ----- Original Message ----- From: "Rino" <lacombr(at)nbnet.nb.ca> Subject: Re: AeroElectric-List: RE: Microair radio > > Anyone have information about the new radio similar to the Microair. > I am looking for a supplier of this radio > > Rino > > ________________________________________________________________________________
Subject: Seminar
Date: Mar 21, 2003
You Can Fly Them, But Can You Wire Them? What: Weekend seminar presented by The AeroElectric Connection Hosted by the National Capital Area Chapter 186, Experimental Aircraft Association (EAA) When: June 7 0800 - 1700 June 8 0800 - 1200 Where: Manassas, VA at the Manassas Regional Airport (HEF), EAA 186 Chapter House, at the base of the tower Learn the ins and outs of wiring your homebuilt or restoration project airplane. Not building or restoring, then get a general understanding of the aircraft electrical systems. Bob Nuckolls has 40 years of knowledge to share with you. Cost: $150 per person including a copy of Bob's super book The AeroElectric Connection Door Prizes For more information and to register go to the seminar area at http://www.aeroelectric.com/ Also note Bob's satisfaction guarantee. ________________________________________________________________________________
Subject: Call the ball ??
Date: Mar 21, 2003
I have a small problem with my wife. I'm building a Velocity in the garage at home and she who must be obeyed parks her car alongside my Velocity. Recently she's taken to parking very close to the Velocity (her Ford Explorer wheels pass within three inches of the Velocity main gear) even though there is plenty of space on the other side of her car. I've mentioned this a couple of times - big mistake. Sooo I'm thinking I need to do something to provide her with lateral guidance. I should mention there's a wooden frame I built to store the wings along the back wall of the garage so she has to stop before she gets to the storage rack also. Options seem to be: 1) I act as a flagman every time she parks in the garage - not very realistic and probably irritating to her so a non-starter 2) Nail some wood to the floor along the side of the plane and in front of the storage rack so she'll know if she's too close to the plane or the storage rack - a bit crude and I'll probably trip over it when I'm working on the plane - so not a very attractive solution 3) Provide something a bit more sophisticated to provide lateral guidance and tell her when to stop - much more fun !! Seems to me what I need is something like a VASI turned sideways that'll show red if she's too close to the plane and white is she's OK, also a second light - or flash the VASI -when she should stop. I've seen the tennis ball on a string hanging from the roof approach and also seen these laser devices that point down to a spot on the dashboard. neither seems very attractive so I was wondering if anyone has suggestions for either the lateral VASI or stop light approach? I would power it from the garage door opener I'm electronically challenged so the simpler the better, Thanks all ________________________________________________________________________________
Subject: Re: Call the ball ??
Date: Mar 21, 2003
I'd try erecting a cement block wall. I tried the new wife approach and that cost me a Cessna 172. Bill ----- Original Message ----- From: "Tony Babb" <tonybabb(at)alejandra.net> Subject: AeroElectric-List: Call the ball ?? > > I have a small problem with my wife. > > I'm building a Velocity in the garage at home and she who must be obeyed > parks her car alongside my Velocity. Recently she's taken to parking very > close to the Velocity (her Ford Explorer wheels pass within three inches of > the Velocity main gear) even though there is plenty of space on the other > side of her car. I've mentioned this a couple of times - big mistake. Sooo > I'm thinking I need to do something to provide her with lateral guidance. I > should mention there's a wooden frame I built to store the wings along the > back wall of the garage so she has to stop before she gets to the storage > rack also. > > Options seem to be: > > 1) I act as a flagman every time she parks in the garage - not very > realistic and probably irritating to her so a non-starter > 2) Nail some wood to the floor along the side of the plane and in front of > the storage rack so she'll know if she's too close to the plane or the > storage rack - a bit crude and I'll probably trip over it when I'm working > on the plane - so not a very attractive solution > 3) Provide something a bit more sophisticated to provide lateral guidance > and tell her when to stop - much more fun !! > > Seems to me what I need is something like a VASI turned sideways that'll > show red if she's too close to the plane and white is she's OK, also a > second light - or flash the VASI -when she should stop. > > I've seen the tennis ball on a string hanging from the roof approach and > also seen these laser devices that point down to a spot on the dashboard. > neither seems very attractive so I was wondering if anyone has suggestions > for either the lateral VASI or stop light approach? I would power it from > the garage door opener > > I'm electronically challenged so the simpler the better, > > Thanks all > > ________________________________________________________________________________
Date: Mar 21, 2003
> I'm electronically challenged so the simpler the better, Hang an expensive crystal vase containing fresh flowers from a wire on you're side of the garage. Keep the flowers fresh and tell her they're there to greet her every time she returns home. She'll never drive close to the vase. You're plane will be safe, and you'll get a bonus point every time she enters the garage. John Slade ________________________________________________________________________________
Date: Mar 21, 2003
Tony, I have the exact same situation with my dear little lady. We share a two door two car garage with my Kitfox and her Toyota V6 Camry. She backs it in and needs to be positioned a bit to the center so as to have ample room at the left wall of the garage and the left side of her car. I put a tennis ball on a rope in the perfect position for her to back up to. It has four bright LEDs mounted on it that are powered from the door opener's light circuit to annunciate itself in all lighting conditions. When she is on target, the ball hits the high mounted break light in the rear window so that she knows that "docking" is complete. She only drives about five miles to work every day and so to preheat the engine in the winter I have installed a cooling jacket block heater that plugs into a timed outlet to preheat the engine from about 4 AM every morning. This is my attempt to be sure that her engine has a chance to obtain full operating temperature for her short run to work. She thinks I am doing this to give her nearly instant heater output on those cold mornings! J John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Mar 21, 2003
Subject: Infinity Stick Grip - Flap Switch.
Im trying to get my Infinity stick grip order ready since they take 6 weeks or more to get. They also indicate they are busy and dont want to be pestered with questions hence my questions here: On the Flap switch (button #3 in my case), they mention using a "Vertically mounted Toggle Switch [(ON)/OFF/(ON) or ON/OFF/(ON) SDPT] for flaps. Then they mention "Also, we have ON/OFF/ON, ON/ON and ON/OFF Toggle Switches. Note: brackets around the word "ON" [(ON)] in the Toggle Switch descriptions above means that the toggle is momentary in that direction." Later in a description of a standard set up for an aircraft WITH electric Flaps - on switch #3, they say the following: "Flaps ON/OFF/(ON) toggle switch using a limit switch on the UP side, or use a spring loaded-to-center (ON)/OFF/(ON) toggle switch which means youll have to hold the Flap switch UP during a touch-and-go or go-around - - not a good idea. Most dont use this switch (99+%)." Im assuming the one I want is the (ON)/OFF/(ON) one. I dont understand their concern in the paragraph above. I would think with the spring loaded-to-center switch as long as I held it in the ON position, the flaps would move in that direction once I let up on the switch it would return to center and the flaps would stop where they happen to be. Isnt that what I want? Isnt that the way the switch which came with my flap motor is set up? - The one I already have mounted on my instrument panel? I dont want a complicated flap system I just want a motor and an up and down switch can it work that way? Would adding a limit switch be a simple matter of a switch to break the line feeding power to the motor when it runs in the up direction when the flaps get to a certain point? or does it get more complicated than that? Any guidance here would be appreciated. Also what might be the benefits of the ON/OFF/(ON) toggle? Thanks --------------------------------- ________________________________________________________________________________
Date: Mar 22, 2003
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Infinity Stick Grip - Flap Switch.
Julia wrote: > > Im trying to get my Infinity stick grip order ready since they take 6 weeks or more to get. They also indicate they are busy and dont want to be pestered with questions hence my questions here: > > On the Flap switch (button #3 in my case), they mention using a "Vertically mounted Toggle Switch [(ON)/OFF/(ON) or ON/OFF/(ON) SDPT] for flaps. > > Later in a description of a standard set up for an aircraft WITH electric Flaps - on switch #3, they say the following: "Flaps ON/OFF/(ON) toggle switch using a limit switch on the UP side, or use a spring loaded-to-center (ON)/OFF/(ON) toggle switch which means youll have to hold the Flap switch UP during a touch-and-go or go-around - - not a good idea. Most dont use this switch (99+%)." Julia; The idea behind the ON/OFF/(ON) switch combined with an up limit is that when you want "flaps up" you simply flip the switch to the up position and forget it. The flaps run all the way up, then stop on the limit switch fully retracted. In other words in the case of a "go round" you don't have to keep you finger on the switch. (you can still stop them part way if you wish by turning the switch off at the desired position) Flaps "down" is the spring loaded position which you have to hold for operation and motion stops when you let go where ever the flaps may be at that time. -- Bob McC ________________________________________________________________________________
Date: Mar 21, 2003
> > >Any guidance here would be appreciated. Also what might be the benefits of >the ON/OFF/(ON) toggle? I've used ON-OFF-(ON) for years for a speed brake and agree with JD on this (there's very little I agree with him on). If you have to go around, it's very awkward to have to keep pushing the toggle up to get the flaps or brake to retract when you're also flying with that hand. So, by making the up position not momentary, you flick it with your thumb and then forget about it. ________________________________________________________________________________
Date: Mar 21, 2003
The idea is that if you have to go around, or even in general, it's easiest if you can just flip the flap switch up and forget about it. The flaps will go all the way up and stop. In an RV, though (not sure if that's what you're building), the flap motor will run endlessly if you leave it in the up position without a limit switch. There's nothing technically wrong with that (although it could conceivably wear the motor out prematurely), but it just bothers me philosophically. My plan is to install limit swithes for both down and up travel. A down limit switch because I get about 50 degrees of flap travel if I let the motor go until it spins, and the plans call for a maximum of 45 degrees. An up limit switch (NC -- normally closed) because I don't want to mess around with a momentary switch when I raise the flaps. I want to flip the switch up and forget about it. The up limit switch will open the circuit when the flaps reach the full-up position, and the motor will stop spinning. NOTE: the up limit switch will only be in the UP circuit. The down limit switch will only be in the DOWN circuit. If you can live with the momentary up switch thing, then all of this is a non-issue...you don't need any limit switches. Hope this helps, )_( Dan RV-7 N714D (canopy) http://www.rvproject.com ----- Original Message ----- From: "Julia" <wings97302(at)yahoo.com> Subject: AeroElectric-List: Infinity Stick Grip - Flap Switch. > > > Im trying to get my Infinity stick grip order ready since they take 6 weeks or more to get. They also indicate they are busy and dont want to be pestered with questions hence my questions here: > > On the Flap switch (button #3 in my case), they mention using a "Vertically mounted Toggle Switch [(ON)/OFF/(ON) or ON/OFF/(ON) SDPT] for flaps. > > Then they mention "Also, we have ON/OFF/ON, ON/ON and ON/OFF Toggle Switches. Note: brackets around the word "ON" [(ON)] in the Toggle Switch descriptions above means that the toggle is momentary in that direction." > > Later in a description of a standard set up for an aircraft WITH electric Flaps - on switch #3, they say the following: "Flaps ON/OFF/(ON) toggle switch using a limit switch on the UP side, or use a spring loaded-to-center (ON)/OFF/(ON) toggle switch which means youll have to hold the Flap switch UP during a touch-and-go or go-around - - not a good idea. Most dont use this switch (99+%)." > > > Im assuming the one I want is the (ON)/OFF/(ON) one. I dont understand their concern in the paragraph above. I would think with the spring loaded-to-center switch as long as I held it in the ON position, the flaps would move in that direction once I let up on the switch it would return to center and the flaps would stop where they happen to be. Isnt that what I want? Isnt that the way the switch which came with my flap motor is set up? - The one I already have mounted on my instrument panel? > > I dont want a complicated flap system I just want a motor and an up and down switch can it work that way? > > Would adding a limit switch be a simple matter of a switch to break the line feeding power to the motor when it runs in the up direction when the flaps get to a certain point? or does it get more complicated than that? > > Any guidance here would be appreciated. Also what might be the benefits of the ON/OFF/(ON) toggle? > > Thanks > > > --------------------------------- > > ________________________________________________________________________________
Date: Mar 22, 2003
From: "Jim V. Wickert" <JimW_btg(at)compuserve.com>
Hi Julia, For Flap control one question you must ask yourself with the type aircraft are there only two flap positions needed one being in the take off and the other being in the landing positions. If you do not need additional positions for various loading conditions etc. then the simple switch and two limit switch is all you will require. Major question I would have with anyone I am spending my hard earned cash with to purchase their product and there are some options that could be critical to the application and they had the attitude " indicate they are busy and dont want to be pestered with questions", I would question even purchasing from them. Its their product and they should be the expert on its application and want the customer to end up with the proper installation. I would look some where else with that attitude. Maybe we are spoiled from working with Steve Rahm at Vision Aricraft or Bob at Aeroelectric,these guys are the best, but I know there are several other companies in the EXP market that would be very happy to work with you in order to get your business. Just think wha the responce will be if you have a problem with the product quality of functionality????? Jim Wickert Vision #159 ________________________________________________________________________________
Date: Mar 22, 2003
I guess I'm a one percenter. My grip has the momentary up mode. I tested my RV flap, full travel time, on the bench - about 5 seconds. I'm not flying yet so I don't know if that will hold up under load, but it could be even less. Has anyone timed this in flight with a RV? Other aircraft are probably different. I can't imagine a problem moving my thumb 1/2" to hold the flap switch for 5 seconds while manipulating the controls. If I want to bleed off flaps, thumb movement to stop up flaps takes a much larger digital displacement. I also didn't think it was worth the extra complexity of the limit switch. > Most dont use this switch (99+%) > Bob Trumpfheller Building a RV7A in western Colorado ________________________________________________________________________________
Date: Mar 22, 2003
I've had just the opposite experience with Infinity. All the help I wanted and no hurry. > Major question I would have with anyone I am spending my hard earned cash > with to purchase their product and there are some options that could be > critical to the application and they had the attitude " indicate they are > busy and dont want to be pestered with questions", Bob Trumpfheller Building a RV7A in western Colorado ________________________________________________________________________________
Date: Mar 21, 2003
Genius, pure genius.!! > Hang an expensive crystal vase containing fresh flowers from a wire on > you're side of the garage. Keep the flowers fresh and tell her they're there > to greet her every time she returns home. She'll never drive close to the > vase. You're plane will be safe, and you'll get a bonus point every time she > enters the garage. > John Slade ________________________________________________________________________________
Date: Mar 21, 2003
On the other hand, I recently e-mailed some questions and got a response from JD the next day. I've got one of these grips and it is a good product. The switches are all wired up with a nice cable. It makes for a very clean installation. I went with the momentary switch on both up and down for simplicity and so that I wouldn't forget and leave it running. I don't think it would be that hard to solder in a new switch if I hate it that way. I haven't flown it so I'll have to wait and see if I made the right choice. If you don't use the momentary, and you don't like the idea of a limit switch, you could put an indicator light on the panel to remind you to turn it off when you're done with the go around. Ed Holyoke 6qb > > > Hi Julia, > snip > Major question I would have with anyone I am spending my hard earned cash > with to purchase their product and there are some options that could be > critical to the application and they had the attitude " indicate they are > busy and dont want to be pestered with questions", I would question even > purchasing from them. Its their product and they should be the expert on > its application and want the customer to end up with the proper > installation. I would look some where else with that attitude. > ________________________________________________________________________________
Date: Mar 21, 2003
I've got a left handed infinity grip for my throttle, and the cyclic out of an Apache for my stick. I THINK it's enough buttons. > >On the other hand, I recently e-mailed some questions and got a response >from JD the next day. I've got one of these grips and it is a good >product. The switches are all wired up with a nice cable. It makes for a >very clean installation. I went with the momentary switch on both up and >down for simplicity and so that I wouldn't forget and leave it running. >I don't think it would be that hard to solder in a new switch if I hate >it that way. I haven't flown it so I'll have to wait and see if I made >the right choice. > >If you don't use the momentary, and you don't like the idea of a limit >switch, you could put an indicator light on the panel to remind you to >turn it off when you're done with the go around. > >Ed Holyoke >6qb > > > > > > > Hi Julia, > > snip > > > Major question I would have with anyone I am spending my hard earned >cash > > with to purchase their product and there are some options that could >be > > critical to the application and they had the attitude " indicate they >are > > busy and dont want to be pestered with questions", I would question >even > > purchasing from them. Its their product and they should be the expert >on > > its application and want the customer to end up with the proper > > installation. I would look some where else with that attitude. > > > > ________________________________________________________________________________
Date: Mar 22, 2003
> I've had just the opposite experience with Infinity. All the help I > wanted > and no hurry. > Concurrence with this mentioned response about Infinity. Had e-mail and Voice communication with JD and some useful advice regarding my requirements from my UK base. Regards Gerry Gerry Holland mailto://gnholland(at)onetel.com +44 7808 402404 Europa XS 384 G-FIZY The greatest enjoyment from existence is living dangerously.... Friedrich Nietzsche ________________________________________________________________________________
Date: Mar 22, 2003
Your local chandler may be able to provide something suitable -- a navigation light for a yacht may suffice. I'm thinking of the kind that goes on a mast and looks red or green depending on the angle from which it is viewed. Like a PAPI, they swap from one state to another in a very small angular difference. Of course, which way up you would need to mount it would depend on which side the plane is. An alternative approach would be to have a number of LEDs mounted around the inside a can, with a series of slots cut around the can, opposite the LEDs. This would be an inexpensive version of the same thing, whereby the LED for a particular slot would only be viewable from a particular angle. Less expensive yet, how about *two* tennis balls, one hung down for each side of the car? Your good lady wife would simply have to drive between them. You could augment it with a third, directly ahead of the windscreen for the fore and aft positioning. Hope this helps. Nev ----- Original Message ----- From: "Tony Babb" <tonybabb(at)alejandra.net> Subject: AeroElectric-List: Call the ball ?? > > I have a small problem with my wife. > > I'm building a Velocity in the garage at home and she who must be obeyed > parks her car alongside my Velocity. Recently she's taken to parking very > close to the Velocity (her Ford Explorer wheels pass within three inches of > the Velocity main gear) even though there is plenty of space on the other > side of her car. I've mentioned this a couple of times - big mistake. Sooo > I'm thinking I need to do something to provide her with lateral guidance. I > should mention there's a wooden frame I built to store the wings along the > back wall of the garage so she has to stop before she gets to the storage > rack also. > > Options seem to be: > > 1) I act as a flagman every time she parks in the garage - not very > realistic and probably irritating to her so a non-starter > 2) Nail some wood to the floor along the side of the plane and in front of > the storage rack so she'll know if she's too close to the plane or the > storage rack - a bit crude and I'll probably trip over it when I'm working > on the plane - so not a very attractive solution > 3) Provide something a bit more sophisticated to provide lateral guidance > and tell her when to stop - much more fun !! > > Seems to me what I need is something like a VASI turned sideways that'll > show red if she's too close to the plane and white is she's OK, also a > second light - or flash the VASI -when she should stop. > > I've seen the tennis ball on a string hanging from the roof approach and > also seen these laser devices that point down to a spot on the dashboard. > neither seems very attractive so I was wondering if anyone has suggestions > for either the lateral VASI or stop light approach? I would power it from > the garage door opener > > I'm electronically challenged so the simpler the better, > > Thanks all > > ________________________________________________________________________________
Date: Mar 22, 2003
> > >Im trying to get my Infinity stick grip order ready since they take >6 weeks or more to get. They also indicate they are busy and dont >want to be pestered with questions hence my questions here: > >On the Flap switch (button #3 in my case), they mention using a >"Vertically mounted Toggle Switch [(ON)/OFF/(ON) or ON/OFF/(ON) >SDPT] for flaps. > >Then they mention "Also, we have ON/OFF/ON, ON/ON and ON/OFF Toggle >Switches. Note: brackets around the word "ON" [(ON)] in the Toggle >Switch descriptions above means that the toggle is momentary in that >direction." > >Later in a description of a standard set up for an aircraft WITH >electric Flaps - on switch #3, they say the following: "Flaps >ON/OFF/(ON) toggle switch using a limit switch on the UP side, or >use a spring loaded-to-center (ON)/OFF/(ON) toggle switch which >means youll have to hold the Flap switch UP during a touch-and-go or >go-around - - not a good idea. Most dont use this switch (99+%)." > > >Im assuming the one I want is the (ON)/OFF/(ON) one. I dont >understand their concern in the paragraph above. I would think with >the spring loaded-to-center switch as long as I held it in the ON >position, the flaps would move in that direction once I let up on >the switch it would return to center and the flaps would stop where >they happen to be. Isnt that what I want? Isnt that the way the >switch which came with my flap motor is set up? - The one I already >have mounted on my instrument panel? > >I dont want a complicated flap system I just want a motor and an up >and down switch can it work that way? > >Would adding a limit switch be a simple matter of a switch to break >the line feeding power to the motor when it runs in the up >direction when the flaps get to a certain point? or does it get >more complicated than that? > >Any guidance here would be appreciated. Also what might be the >benefits of the ON/OFF/(ON) toggle? > >Thanks My RV is not flying yet, so I don't know if this is relevant or not, but here goes: I'm assuming you have electric pitch trim, using the coolie hat on the stick grip. If so, will you want to be using the pitch trim as the flaps come up during a go-around? Will you have enough fingers to hold a momentary flap switch to the up position and also use the trim? I'm not sure how much the stick forces will change during a go-around, so I'm not sure if you will want to be trimming or not. I pondered putting flap switches on the stick, but eventually decided I didn't want any switches on the stick that could cause a problem if they got inadvertently selected. I'm not sure the flaps are stressed to take an extension at high speed. I put the flap switch on the instrument panel just above the throttle. It is spring loaded in both directions. In a go around, I'll apply the power, then reach up with my index finger and hold the flap switch until they are up. Just my two cents worth, -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Mar 22, 2003
In a message dated 3/22/2003 7:38:22 AM Eastern Standard Time, khorto1537(at)rogers.com writes: > I pondered putting flap switches on the stick, but eventually decided > I didn't want any switches on the stick that could cause a problem if > they got inadvertently selected. I'm not sure the flaps are stressed > to take an extension at high speed. I put the flap switch on the > instrument panel just above the throttle. It is spring loaded in > both directions. In a go around, I'll apply the power, then reach up > with my index finger and hold the flap switch until they are up. > > Just my two cents worth, > -- > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://go.phpwebhosting.com/~khorton/rv8/ > > Kevin, My flaps are manual only on my Kitfox but I wanted to say that I like your safety logic in keeping flap control off the stick. However, why not have your "flaps up" switch position non-spring loaded? You could get too busy in a go around to hold that flaps up switch for the entire travel time needed. The addition of an end switch for the flap motor would be required. John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Mar 22, 2003
In a message dated 3/21/03 11:02:25 PM Central Standard Time, wings97302(at)yahoo.com writes: > Im assuming the one I want is the (ON)/OFF/(ON) one. I dont understand their > concern in the paragraph above. I would think with the spring > loaded-to-center switch as long as I held it in the ON position, the flaps > would move in that direction once I let up on the switch it would return > to center and the flaps would stop where they happen to be. Isnt that what > I want? Isnt that the way the switch which came with my flap motor is set > up? - The one I already have mounted on my instrument panel? > > I dont want a complicated flap system I just want a motor and an up and > down switch can it work that way? > Good Morning wings97302, For what it is worth, my spam can has an ON/OFF/ON switch for the flaps. There are limit switches at both the Up and the Down positions. It was wired that way at the factory as was true for the first 10,178 Bonanzas that were built. I personally find it very useful that way, I can start the flaps down and use that hand for something else while the flaps are in transit. When they get to where I want them, it is easy to flip the switch back to neutral to get them stopped. Back in another life, I flew the Douglas DC-3 and DC-4. Both of those aircraft had their hydraulically actuated flaps set up the same way. We would move the flap lever to the up or down position. Use our hand for doing whatever else needed to be done, then stop the flaps where we wanted them by setting the lever to neutral. Worked fine. By the time the DC-6 and DC-7 came on the scene, the ergonomics guys had decided that we needed something that would keep us stupid pilots from setting the wrong flap by forgetting to neutralize the flap lever. The biggest concern came from the CAA (predecessor to the FAA). Since we had to retract the flaps from the approach or landing flap to a lesser setting for the go around, they wanted a preset position to which the lever could be set. They had no confidence that we aviators could handle it the way it had been done since the DC-3 was first built. Personally, I prefer the way it was originally. That allows an infinite range of positions for the flap, however, the pre-positioning does have an advantage for those aircraft which do have critical flap settings on a go around. For most GA aircraft, the flap desired on a go around is full up. Intermediate settings are generally not required. If the approach is flown at a speed at, or above, the flaps up best rate of climb speed, the flaps can be retracted instantly without any detrimental effect provided the aircraft is rotated as fast as the flaps are retracted. If the aircraft has barn door flaps like the Cessna 180/185 series, a flap motor that runs at a speed that will take five to ten seconds for the flaps to retract will allow adequate time for the aircraft to be accelerated to flaps up best angle of climb speed while the flaps are coming up. I think a momentary flap position switch would be the least desirable of the options available. The ON/OFF/ON is my favorite, though the extra complexity of pre positioned settings may be useful for aircraft with very powerful lift providing flap systems. However, the beauty of a home made aircraft is that you can do it any way YOU like. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Mar 22, 2003
Amen...I'm another one percenter. I originally wanted on the (On)Off(On) flap switch, but let JD talk me out of it when ordering and went with the (On)Off-On instead. He makes a great product but is very opinionated and thinks that what works for him is best for everyone else. Anyway, I regretted it later and ended up ordering replacement switches for two positions, the flaps being one of them....cost me another $25 and the time to replace/resolder the connections. I say get what makes YOU happy. For the RV-8A, I see no problem with the (On)Off(On) switch....I have it mounted on the top left position of the stick grip, operated by my thumb....very easy to hold when pushing the flaps up, and still fly at the same time. I can still hit the PTT with my index finger, and my cockpit is set up for all other functions to be done with my left hand so I don't need to do a bunch of hand-swapping while trying to fly the plane. One other note....the RV climbs so well that you don't even have to get the flaps up to go around under the vast majority of conditions (unless perhaps you're at 10k' density altitude at max gross weight with FP prop perhaps?). I just don't think it's a big deal, and prefer holding the switch until flaps are up to having a limit switch or having to remember half way into the flight that I left the flap motor running. Do what you like and hold your ground when you call JD cuz he'll try to tell you how do do it "right" and it may not be the best for you.... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring and fwf.... From: N67BT(at)aol.com Subject: Re: AeroElectric-List: Infinity Stick Grip - Flap Switch. I guess I'm a one percenter. My grip has the momentary up mode. I tested my RV flap, full travel time, on the bench - about 5 seconds. I'm not flying yet so I don't know if that will hold up under load, but it could be even less. Has anyone timed this in flight with a RV? Other aircraft are probably different. I can't imagine a problem moving my thumb 1/2" to hold the flap switch for 5 seconds while manipulating the controls. If I want to bleed off flaps, thumb movement to stop up flaps takes a much larger digital displacement. I also didn't think it was worth the extra complexity of the limit switch. > Most dont use this switch (99+%) > Bob Trumpfheller Building a RV7A in western Colorado ________________________________________________________________________________
Date: Mar 22, 2003
> >In a message dated 3/22/2003 7:38:22 AM Eastern Standard Time, >khorto1537(at)rogers.com writes: > >> I pondered putting flap switches on the stick, but eventually decided >> I didn't want any switches on the stick that could cause a problem if >> they got inadvertently selected. I'm not sure the flaps are stressed >> to take an extension at high speed. I put the flap switch on the >> instrument panel just above the throttle. It is spring loaded in >> both directions. In a go around, I'll apply the power, then reach up >> with my index finger and hold the flap switch until they are up. >> >> Just my two cents worth, >> -- >> Kevin Horton RV-8 (finishing kit) >> Ottawa, Canada >> http://go.phpwebhosting.com/~khorton/rv8/ >> >> > >Kevin, > >My flaps are manual only on my Kitfox but I wanted to say that I like your >safety logic in keeping flap control off the stick. However, why not have >your "flaps up" switch position non-spring loaded? You could get too busy in >a go around to hold that flaps up switch for the entire travel time needed. >The addition of an end switch for the flap motor would be required. > >John P. Marzluf >Columbus, Ohio >Kitfox Outback (out back in the garage) > I thought about a non-spring loaded flaps up position, but I knew that I would forget to put the switch back to the centre position every once in a while. The motor runs free once it reaches full travel in either direction, so it isn't putting any load on the structure, but I was afraid that it could eventually overheat, as I don't believe it is designed to run continuously. I didn't want the added complexity of limit switches to turn the flap motor off, as parts that aren't installed are cheaper, lighter, more reliable and require less maintenance than parts that are installed. I don't believe that go-arounds in my RV will be so busy that I'll need to let go of the flap switch. The mixture and prop levers will be full forward before landing, I don't have carb heat, and the PTT switch is on the stick, so I don't think my left hand will have much to do during a go-around except push the throttle and take care of the flaps. We each need to do whatever will work for us, and our aircraft. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Mar 22, 2003
In a message dated 3/22/2003 9:09:19 AM Mountain Standard Time, nhulin(at)hotmail.com writes: > > Share? Share the garage? Dodge Caravan, pregnant, heavy snow all winter. > Share they say, Hah. > > From: Janelle, wife of Neil. > > Now thats what I call a GREAT CO-PILOT !!!!!!!! Wait, hold the presses.... Is her Caravan outside or in???????? I can't tell if she is happy or been sweepin snow off the car all winter. ________________________________________________________________________________
Subject: Re: Re: Call the ball ??
Date: Mar 22, 2003
Actually, the car has been outside since the box with the wing kit arrived last summer and took over the "other half" of the garage. There could be some psychological leverage here. If she wants the car back in the garage she is best to encourage me to get out there and build the airplane. The sooner the airplane is finished, the sooner the car gets back in the garage. ...neil (husband of Janelle) > From: Benford2(at)aol.com > Date: Sat Mar 22 - 8:22 AM > >> In a message dated 3/22/2003 9:09:19 AM Mountain Standard Time, >> nhulin(at)hotmail.com writes: >> >> Share? Share the garage? Dodge Caravan, pregnant, heavy snow all winter. >> Share they say, Hah. >> >> From: Janelle, wife of Neil. > Now thats what I call a GREAT CO-PILOT !!!!!!!! Wait, hold the presses.... > Is her Caravan outside or in???????? I can't tell if she is happy or been > sweepin snow off the car all winter. ________________________________________________________________________________
Subject: It mustn't continue..............
Date: Mar 22, 2003
Sorry, but............. it's time to draw its line. "Its" is posessive. "It's" is short for "it is" or "it has". "It's" is short for "it is" or "it has". "It's" is short for "it is" or "it has". "It's" is short for "it is" or "it has". "It's" is short for "it is" or "it has". Ferg A064 ________________________________________________________________________________
Date: Mar 22, 2003
This sounds very familiar to the energy around my project two years ago. I am now building wings in the living room with the stereo tuned to my station as loud and late as I desire. Grocery shopping is a bit of a drag. Like aviation, life is full of trade offs. Ed Tate RV3 Looking for a cook -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of nhulin Subject: AeroElectric-List: Re: Re: Call the ball ?? Actually, the car has been outside since the box with the wing kit arrived last summer and took over the "other half" of the garage. There could be some psychological leverage here. If she wants the car back in the garage she is best to encourage me to get out there and build the airplane. The sooner the airplane is finished, the sooner the car gets back in the garage. ...neil (husband of Janelle) > From: Benford2(at)aol.com > Date: Sat Mar 22 - 8:22 AM > >> In a message dated 3/22/2003 9:09:19 AM Mountain Standard Time, >> nhulin(at)hotmail.com writes: >> >> Share? Share the garage? Dodge Caravan, pregnant, heavy snow all winter. >> Share they say, Hah. >> >> From: Janelle, wife of Neil. > Now thats what I call a GREAT CO-PILOT !!!!!!!! Wait, hold the presses.... > Is her Caravan outside or in???????? I can't tell if she is happy or been > sweepin snow off the car all winter. ________________________________________________________________________________
Subject: Re: It mustn't continue..............
Date: Mar 22, 2003
Amen, I've often wondered what has happened to our educational system. I see non native users with better english skills than some of our native born writers ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Subject: AeroElectric-List: It mustn't continue.............. > > Sorry, but............. it's time to draw its line. > "Its" is posessive. > "It's" is short for "it is" or "it has". > "It's" is short for "it is" or "it has". > "It's" is short for "it is" or "it has". > "It's" is short for "it is" or "it has". > "It's" is short for "it is" or "it has". > > Ferg > A064 > > ________________________________________________________________________________
Date: Mar 22, 2003
Janelle, You're a saint and wonderful role model for the spouses of all homebuilders. Does your husband realize he's the envy of most of the rest of us? ----- Original Message ----- From: "nhulin" <nhulin(at)hotmail.com> Subject: AeroElectric-List: Re: Call the ball ?? > > Share? Share the garage? Dodge Caravan, pregnant, heavy snow all winter. > Share they say, Hah. > >From: Janelle, wife of Neil. ________________________________________________________________________________
Date: Mar 22, 2003
> I see non native users with better english skills than some of our native born > writers And where, exactly, does a "native born" ENGLISH writer come from? John Slade English, and proud of it, but proud also to live in the 'other' land of the free. ________________________________________________________________________________
Date: Mar 22, 2003
Subject: 7-Day Matronics List Browse Enhancement...
Dear Listers, Neil Hulin of the Zenith-List at Matronics wrote to me suggesting I add a "total of available messages" column to the 7-Day List Browse Main page, and it seemed like a great idea! I've made the modifications and I think many will find it extremely helpful as well. Have a look at the following URL: http://www.matronics.com/listbrowse/ Best regards, Matt Dralle Matronics Email List Admin... Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re: 7-Day Matronics List Browse Enhancement...
Date: Mar 22, 2003
This is just Terriffic! "Posts at a glance" Dave ----- Original Message ----- From: Matt Dralle To: dralle(at)matronics.com Sent: Saturday, March 22, 2003 9:57 PM Subject: AeroElectric-List: 7-Day Matronics List Browse Enhancement... Dear Listers, Neil Hulin of the Zenith-List at Matronics wrote to me suggesting I add a "total of available messages" column to the 7-Day List Browse Main page, and it seemed like a great idea! I've made the modifications and I think many will find it extremely helpful as well. Have a look at the following URL: http://www.matronics.com/listbrowse/ Best regards, Matt Dralle Matronics Email List Admin... Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Insurance rates
Date: Mar 22, 2003
"Full coverage $2.498 per year while I am building the kit $400. per year and it would go up when I get the engine." Is there a comma in there? Ferg ________________________________________________________________________________
Date: Mar 22, 2003
Subject: Dimmer Control
I've got B&C's 1.5 AMP dimmer using a heat sink and LM317K they show pins #4,8,7,9 & 5 all go to instrument lights - can I just tie my green instrument light wires all together and then run one wire to just one of these pins on this dimmer control system? thanks --------------------------------- ________________________________________________________________________________
Date: Mar 23, 2003
In this context the US, rarely from some other nation where English is the principal language ----- Original Message ----- From: "John Slade" <sladerj(at)bellsouth.net> Subject: RE: AeroElectric-List: It mustn't continue.............. > > > I see non native users with better english skills than some of our native > born > > writers > > And where, exactly, does a "native born" ENGLISH writer come from? > John Slade > English, and proud of it, but proud also to live in the 'other' land of the > free. > > ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Subject: Re: exploding Jet-A
Date: Mar 23, 2003
It was supposedly dead empty - who knows... I had banned using a torch on drums 18 months before that... He also was supposed to fill it with water before cutting any metal... But if you know anything about millwrights they are long on getting a bigger hammer and short on listening... As far as fuel tanks in aircraft, they are vented or you wouldn't be able to remove the fuel... And, oxygen is one of the most pervasive gases in getting where you don't want it... Just try keeping oxygen out of any container and you will notice that fact... Add heat from the air conditioner pack against the floor of the tank, add an overheated fuel pump that is supposed to be immersed for cooling but isn't, add a spark from wiring running through the tank - fer gawds sake - and you get a boom... Denny ----- Original Message ----- From: "John Rourke" <jrourke@allied-computer.com> Subject: Re: AeroElectric-List: Re: exploding Jet-A <jrourke@allied-computer.com> > > But, did it have any liquid fuel in it? If not, the air-fuel mixture > could get to a stoichiometric level to support combustion. > > Plus, in using the air chisel you are introducing an opening through > which air can enter, which can certainly allow it to achieve the proper > air-fuel ratio for combustion (even if there was alittle liquid in the > bottom), AND providing the spark for ignition... baaaad idea! > > But, a sealed fuel tank does not provide the same scenario as far as I > can tell. > > -John > > > Dennis O'Connor wrote: > > > > Fine Bob... Not wanting to get into a hoohaa over it... > > In a previous lifetime I happened to hang around the plant engineering > > department of a small, multinational automobile corporation... One of our > > perenniel problems was the exploding 55 gallon, steel drum... One in > > particular I remember was a millwright that managed to blow up a kerosene > > drum (similar to Jet A) that he was chiseling the top off from, with an > > airpowered chisel... At that point I issued an absolute ban on reusing 55 > > gallon drums, which cost us some money but saved a lot more in the long > > run... > > > > Denny > > ----- Original Message ----- > > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > > To: > > Subject: AeroElectric-List: Re: exploding Jet-A > > > > > > > > > > > > > >> > >>><jrourke@allied-computer.com> > >>> > >>>I believe you are referring to a 737 in Manila in May 1990? > >>> > >>>Although explosive residue was not found, the possibility remains - I > >>>read a report where the passenger decking being pushed upwards was > >>>claimed to not be consistent with a fuel-tank explosion... but I haven't > >>>read much on it, just wanted to mention that the root cause of that one > >>>is still debated. > >>> > >>>No other fuel-tank explosions are known in 80 years of airline > >>>recordkeeping, according to the same reports. > >>> > >>>-John R. > >> > >>>Dennis O'Connor wrote: > >>> > >>> > >>> > >>> > >>>>And the center tank that exploded and burned on the ramp in Bahrain in > >>> > >>>front > >>> > >>>>of cameras and witnesses was bogus also? > >>>>(I think it was Bahrain - if not feel free to correct the location) > >>> > >> There has been an exhaustive study of public data on > >> the TWA800 incident. I've read quite a bit of it with > >> particular interest discussions illuminated with > >> logic and good physics. Like all such cases, there > >> are plenty of "fog generators" in the discussion > >> including conspiracy theorists and (not the least > >> of which) are agencies of government with competing > >> agendas. > >> > >> The tank in question had to have unusable and/or > >> unused liquid fuel in it. I am mystified as to how > >> the vapor-space in any closed volume with liquid in > >> the bottom, dilutes what would normally be a nearly > >> saturated mixture of fuel/air down to a > >> stoichiometric ratio required for combustion with > >> a high release of energy with any fuel, much less > >> Jet-A. This is but ONE of many questions which I > >> find puzzling. > >> > >> You're free to evaluate for yourself. There are > >> many reasons to be suspicious of the engineering > >> and investigative techniques . . . but be prepared > >> to spend some time looking through the details. > >> > >> check out www.twa800.com > >> http://home.earthlink.net/~neteagle/ > >> > >> Here's but one of many examples of logical, detailed and > >> independent analysis to be found with a bit of > >> websearching . . . > >> > >> http://www.compassionateweb.net/~missiletwa800/mann.htm > >> > >> and as a tip of the iceberg . . . > >> > >> http://www.worldnetdaily.com/news/article.asp?ARTICLE_ID=24075 > >> http://twa800.com/news/Stalcup.htm > >> http://www.flight800.org/sketch.htm > >> http://www.multipull.com/twacasefile/second649.html > >> http://twa800.com/images/exhibit22c_radar.pdf > >> > >> It's a complex puzzle but in the final analysis, only > >> the RIGHT pieces fit together into the real picture. > >> I've found the reasoning of a number of folks to > >> be compelling and in direct contradiction with > >> the officially published accounts. > >> > >> If you feel compelled to learn and/or enjoy putting > >> big puzzles together one could do worse than study > >> what's out there on TWA800. > >> > >> Bob . . . > >> > >> > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: runaway, self regulated alternators//FMEA
Date: Mar 23, 2003
Bob, One last try as I do not seem to have a reply from you that addresses my failure mode (remember, its what I think you say, not what you think you are saying :-) ). The following discussion is generic in nature and does not address specific design details in a real alternator. Alternators have several different internal winding and diode designs and its not reasonable to address them all, nor is it reasonable to assume all will fail in the same way with the same external conditions. For the readers who do not want to get into the details read the final paragraph (s) of conclusions. First, I believe you are saying that disconnecting the "B" lead to a uncontrolled (failed internal regulator in the failed "FULL ON" mode) alternator will result in the alternator's output voltage (with no external load) will rise to around 100V and that will produce some 25 amps thru the 22 G field winding which will fuse open in several seconds and the result is no excess heat and a safe shutdown of the alternator. The "B" lead contactor will open unloading the alternator and prevent external OV. I agree that externally that will happen. Internally I do not agree however. You have a nice theory (that the internal voltage will go to 100V and stay for several seconds while the field winding fuses) but just how does the alternator voltage magically go to 100V and stay there while the field fuses open? What is the internal alternator design (and common to ALL alternator designs as you state the failure mode result is common to all) that limits the voltage to some value below the internal diode voltage failure rating that my failure mode suggests? Consider the following (mostly for the non technical members of the list). The alternator is a current source and is also a current amplifier. IE: IF 1 amp of field current will produce, for example, 15 amps of current to the "B" lead. Then 2 amps of field current will produce 30 amps of "B" lead current etc. The regulator simply looks at the "B" lead VOLTAGE and controls the field current as needed to keep the voltage at the set point of say 14V. If field current control is lost and the field current goes higher than the resulting external current load can handle the output voltage increases until the "B" lead current is externally loaded to the produced current. The alternator voltage will increase as much as needed to keep the field controlled "B" current flowing. If the field current max is 4 amps from the above example the alternator will increase the output voltage as needed until the load is sinking 60 amps. Thus I am saying the "B" lead voltage will rise (and extremely fast) to the point where the load current matches the generated current. If this is 60 amps and the load is suddenly disconnected the voltage rises in a very small fraction of one second to what is needed to load the "B" current. As there is no internal load to handle that 60 amp current, the voltage rises to the point of internal diode failure short(I believe this will be the primary or most common first failure). As the diodes are rated to handle the current there is no fast burning open of the shorted diodes (at least in the short term). Thus the voltage is now controlled by the shorted windings that can handle the current and that drops the generated voltage to an relatively low value and thus there is no 100V and 25 amps thru the field and no 10 seconds to burn out the field and keep the main current thru the shorted windings from producing internal heat. The internal alternator heats up and may burn the field open first or may get really hot as my real experience showed. What fails first at this point depends on the specific alternator design and what additional internal failures happen. Simply stated, a high uncontrolled field current produces a high "B" current that must be loaded to prevent the voltage from rising to what ever voltage is needed to provide the current load. Something will eventually fail. Perhaps it will be the field fusing open and perhaps it will be the diodes failing short or perhaps something else but the internal unloaded voltage will rise until something cuts the field current and or provides the needed load. My contention is the internal unloaded voltage will rise in a few milliseconds (not seconds) to the diode failure point. Then the shorted windings take the current load and produce internal heat. My contention is based on a real failure and the resulting failure analysis of three professional engineers who were employed in a major company's failure analysis engineering department. No specific conclusions could be made due to the extreme damage to the alternator (including charred Field and power windings as well as shorted diodes and partially melted aluminum case). I am ignoring the inductance and resistance etc of the "REAL" circuit as it is a second order effect to my point. For the interested (not really relevant to the discussion in my opinion) The failure was on a LYC powered experimental aircraft with a fuse on the "B" output and a bus OV that opened the 12V to the alternator control. At the time, the owner builder assumed the regulator could not fall such that the field current went on full (this is a widespread belief among auto service people). We were told the OV tripped (opening the 12V supply to the alternator) and the "B" fuse opened (opening the "B" lead). There is no timing or sequence of events available. The builder noted no alternator output from the above indicators and on inspection discovered the alternator smoked and the drive belt heat damaged. Nothing was damaged in the aircraft but then as far as the pilot remembered nothing was on including any avionics so the only external load was the battery. While you have suggested a Failure Modes and Effects (FMEA), I have never seen a proper FMEA on the subject from anyone outside large industry. A proper FMEA on an alternator's failure modes would be long and complex and likely to exceed 100 different failure modes, most of which assessed as very unlikely. Each alternator design would require some part of the FMEA to be unique to that alternator so no common to all FMEA is possible. CONCLUSIONS: I believe the only way to safely shut down an uncontrolled alternator is to stop the field current. As long as there is field current there will be uncontrolled "B" current and uncontrolled current going somewhere. I disagree the runaway voltage will always be controlled to a voltage that is below diode ratings and thus will allow time for the field to burn open from excessive current. One or more shorted diodes can result in greatly reduced internal voltage and thus reduced field current while providing an internal load that creats heat. Its reasonably easy to short out the field externally (bring out a brush lead) with an internally regulated alternator in addition to the "B" lead contactor for those who insist in using such an alternator. Given the many different alternator designs in production there is too many variables to count on the safe internal fusing of the field current. For an External regulated alternator, there is no connection from the "B" to the field and cutting the power to the field (regulator) is simple and does the job in all cases. For the internally regulated alternator its an entirely different case. Here load removal FORCES a second failure (field current removal) to occur before the alternator is 'safe'. This is where we disagree in that I do not agree the field will always fuse open soon enough to prevent overheating of the entire alternator. I am assuming the external load was disconnected at the time of the initial failure. The above referenced partial "expert " failure analysis demonstrated to me that at least in some cases simple load removal was not enough (and frankly none of my peers {experienced electronics engineers} can understand how the removal of the load will result in magically limiting the voltage to less than the internal diode max voltage rating. All felt the voltage would rise and start shorting diodes in well under 1/10 of a second and the resulting voltage would then be clamped at a relative low value which is determined by the specific alternator design and what diode(s) shorted). Considering how simple it is to use an alternator that is easy to convert or needs no conversion (to an external regulator) I feel there is no reason not to do it. As such alternators are available in similar weight,size, and amp ratings there need not be a weight penalty. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: runaway, self regulated alternators > > > > > > ________________________________________________________________________________
Date: Mar 23, 2003
Subject: Infinity Stick Grip - Computer games joystick?!
Hello, all Why not use one of those cool joysticks used for computer games? A whole bunch of switches on them, pre-wired and all, available at the nearest computer store. They are probably very sturdy, to withstand the many hours of game-playing in the hands of teenagers... Did anyone consider one of those? Carlos --- Ed Holyoke wrote: > --> AeroElectric-List message posted by: Ed Holyoke > > On the other hand, I recently e-mailed some questions and got a response > from JD the next day. I've got one of these grips and it is a good > product. The switches are all wired up with a nice cable. It makes for a > very clean installation. I went with the momentary switch on both up and > down for simplicity and so that I wouldn't forget and leave it running. > I don't think it would be that hard to solder in a new switch if I hate > it that way. I haven't flown it so I'll have to wait and see if I made > the right choice. > > If you don't use the momentary, and you don't like the idea of a limit > switch, you could put an indicator light on the panel to remind you to > turn it off when you're done with the go around. > Post your free ad now! http://personals.yahoo.ca ________________________________________________________________________________
Date: Mar 23, 2003
AND THE WINNER IS: For best response to a post. RSwanson (most constructive) Runners-up: Jim Jewell, James Freeman - (least offensive retort) Harry Crosby, LarryRobertHelming - (best spellers) Passing Grade: Keith - 67%, for 'your' & 'you're', but not 'yore' Helming - 67%, for 'their' & 'there', but not 'they're'. It was in 1507 that Martin Waldseemuller (or his collaborator, Matthias Ringman) in their book, "Cosmographiae introductio" suggested that Columbus' new continent be named after Americus Vesputius [Latin book], since both Europa and Asia were named for women. However by 1527, Franciscus Monarchus produced the first known map of the new continents and "America" appears in northern Brazil. Therefore, it must be that the cousins from Britain are actually in conflict with the grammar of Portugal, and not as we note here, those of south-central North America. Next semester will be 'dampening vs. damping'. Ferg PS: apologies to Matt Dralle for Off Topic ________________________________________________________________________________
Date: Mar 23, 2003
joystick?! The best ones, if you go that route, are the Thrustmaster B8 style. In fact, JD's early sticks were injected urethane foam surplus Thrustmasters (I know, I bought a dozen of them). The Thrustmaster "Top Gun" stick is slightly smaller - the same size at JD's - the "Fighter X" is a full size B8. Neither one is made anymore, but you can get them on EBay for about $20. The later Top Guns and all the Fighter Xs have soft neoprene inserts where the checkering is, which is also where your hand contacts the stick. The coolie hat switch they use is the same one JD uses, but the pushbuttons are really too light for aircraft use. It's best to drill them out and replace them. > >Hello, all > >Why not use one of those cool joysticks used for computer games? A whole >bunch of >switches on them, pre-wired and all, available at the nearest computer store. > >They are probably very sturdy, to withstand the many hours of game-playing >in the >hands of teenagers... > >Did anyone consider one of those? > >Carlos > > > --- Ed Holyoke wrote: > --> AeroElectric-List > message posted >by: Ed Holyoke > > > > On the other hand, I recently e-mailed some questions and got a response > > from JD the next day. I've got one of these grips and it is a good > > product. The switches are all wired up with a nice cable. It makes for a > > very clean installation. I went with the momentary switch on both up and > > down for simplicity and so that I wouldn't forget and leave it running. > > I don't think it would be that hard to solder in a new switch if I hate > > it that way. I haven't flown it so I'll have to wait and see if I made > > the right choice. > > > > If you don't use the momentary, and you don't like the idea of a limit > > switch, you could put an indicator light on the panel to remind you to > > turn it off when you're done with the go around. > > > >Post your free ad now! http://personals.yahoo.ca > > ________________________________________________________________________________
Date: Mar 23, 2003
Subject: E-Buss Switch
with bob's wiring diagram for the main buss and e-buss & internal regular Z-xx previously labeled. there is a master switch with Off/Bat/Alt. - positions. there is then an E-Buss switch under normal proceedures you would get in the airplane, turn the master to Alternator - then start up. The E-Buss gets powered from a diode off the main buss - so would you normally leave the E-Buss switch off - untill you had a situation where you had an alternator failure - then you would flip the master switch to Bat. power and turn on the E-Buss. Is that correct? Also, does the OVM module CAUSE the Alternator field to shut off - or does it just allow some of the voltage to go to ground in order to keep the voltage from spiking? Is it the case that you still need to turn the master to Bat or OFF - to get the alternator contactor to shut off? thanks --------------------------------- ________________________________________________________________________________
Date: Mar 23, 2003
Subject: E-Buss - switched vs. non-switched items
I read somewhere that all items run off the E-Buss should have a switch on them - I notice the diagrams call for a turn coordinator to run off the e-buss - there is no switcfh on that. also I have an electric attitude indicator -so I assume that would run off the e-buss as well? are both of these items ok if they don't have an on/off switch on them? if these are ok -how about other low powered items - like instrument lights? thanks --------------------------------- ________________________________________________________________________________
Date: Mar 23, 2003
Subject: Re: Infinity Stick Grip - Computer games joystick?!
Carlos Hi! Someone here in UK has done this very well. Just had to adapt from about 3/4" to 1"+ to fit Joystick. The Aircraft is a very well equipped Europa owned by a X777 Pilot for BA. Regards Gerry Gerry Holland mailto://gnholland(at)onetel.com +44 7808 402404 Europa XS 384 G-FIZY The greatest enjoyment from existence is living dangerously.... Friedrich Nietzsche ________________________________________________________________________________
Date: Mar 23, 2003
Hi Carlos, CH products Manufactures game controls etc. go to http://www.chproducts.com/retail/hi_res_images.html They have a new product for homebuilt aircraft builders that looks to be just what you describe. They are sending information in the mail on request Jim in Kelowna ----- Original Message ----- From: "Carlos Sa" <carlosfsa(at)yahoo.com> Subject: RE: AeroElectric-List: Infinity Stick Grip - Computer games joystick?! > > Hello, all > > Why not use one of those cool joysticks used for computer games? A whole bunch of > switches on them, pre-wired and all, available at the nearest computer store. > > They are probably very sturdy, to withstand the many hours of game-playing in the > hands of teenagers... > > Did anyone consider one of those? > > Carlos > > > --- Ed Holyoke wrote: > --> AeroElectric-List message posted > by: Ed Holyoke > > > > On the other hand, I recently e-mailed some questions and got a response > > from JD the next day. I've got one of these grips and it is a good > > product. The switches are all wired up with a nice cable. It makes for a > > very clean installation. I went with the momentary switch on both up and > > down for simplicity and so that I wouldn't forget and leave it running. > > I don't think it would be that hard to solder in a new switch if I hate > > it that way. I haven't flown it so I'll have to wait and see if I made > > the right choice. > > > > If you don't use the momentary, and you don't like the idea of a limit > > switch, you could put an indicator light on the panel to remind you to > > turn it off when you're done with the go around. > > > > Post your free ad now! http://personals.yahoo.ca > > ________________________________________________________________________________
Date: Mar 23, 2003
Hi Julia, Yes I do. CH Products. They supply both commercial joy sticks for Industrial applications this is where I came accross them and they provide top qulity control sticks for the game industry. They now have a control stick for the Home built aircraft market, with picturers of an installation in both a Lancair and RV. The stick I am going to use is one found in thier retail Gameport section not the USB section of products. They have two sticks that I am now looking into. The Game Stick 3D Right or Left hand with 4 single press buttons and a 4 way hat switch they have them on special now for $39.95 remove the base and the rest is ready to use. This the unit they have installed in the Home built pictures They also have the CH Flight stick that has a few less buttons and again right or left hand also $39.95. I have seen these units and they are good quality. CH Products 970 Park Center Dr. Vista, CA 92083 760-598-2518 www.chproducts.com Go to Retail section Good luck, happy building Jim Wickert Vision #159 ________________________________________________________________________________
Date: Mar 23, 2003
Subject: Re: RE: Microair radio
Thanks Lonnie, I got in touch with www.xcom760.com Lonnie Benson wrote: > Rino, > > Just incase you never received an answer to your question, try > www.xcom760.com. or www.becker-avionics.com. ________________________________________________________________________________
Date: Mar 23, 2003
Julia, In case of alternator failure, you would turn the e-bus on and then turn the master off to save the amp or so that the contactor draws. Depending on how much fuel you've got left, you might even want to turn off some of the stuff on the e-bus to make sure you've got enough battery left for arrival. If the alternator overvolts, the OVM causes the field breaker to blow shutting down the alternator. You should then have a blinking light to warn you of low voltage and follow procedure above. I think that's how it works anyway. Ed Holyoke > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Julia > Sent: Sunday, March 23, 2003 10:13 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: E-Buss Switch > > > > with bob's wiring diagram for the main buss and e-buss & internal regular > Z-xx previously labeled. > > there is a master switch with Off/Bat/Alt. - positions. > > there is then an E-Buss switch > > under normal proceedures you would get in the airplane, turn the master to > Alternator - then start up. The E-Buss gets powered from a diode off the > main buss - so would you normally leave the E-Buss switch off - untill you > had a situation where you had an alternator failure - then you would flip > the master switch to Bat. power and turn on the E-Buss. Is that correct? > > Also, does the OVM module CAUSE the Alternator field to shut off - or does > it just allow some of the voltage to go to ground in order to keep the > voltage from spiking? Is it the case that you still need to turn the > master to Bat or OFF - to get the alternator contactor to shut off? > > thanks > > > --------------------------------- > > > > > > ________________________________________________________________________________
Date: Mar 23, 2003
Subject: GPS antenna location
is it ok to mount the GPS antenna in a wing tip? I was going to mount it under the engine cowl - but the wing tip is relatively empty when compared with under the engine cowl. Also if I had to find another reason, perhhaps it might be argued that if you flew upside down - the reception would be just as good with the wing tip location - whereas it you mounted it under the engine cowl and flew upside down, you'd have the engine blocking the GPS signal? What arguements are there for NOT mounting it in the wing tip? Do strobe signals interfere with GPS at all? I"m using a wing tip COMM antenna in one tip and thought I'd put the GPS in the other tip. My transponder antenna is underneath the seats and my ELT antenna is in the tail - I think that's all the antennas I need. --------------------------------- ________________________________________________________________________________
Date: Mar 23, 2003
Subject: Re: E-Buss Switch
> > >with bob's wiring diagram for the main buss and e-buss & internal >regular Z-xx previously labeled. > >there is a master switch with Off/Bat/Alt. - positions. > >there is then an E-Buss switch > >under normal proceedures you would get in the airplane, turn the >master to Alternator - then start up. The E-Buss gets powered from >a diode off the main buss - so would you normally leave the E-Buss >switch off - untill you had a situation where you had an alternator >failure - then you would flip the master switch to Bat. power and >turn on the E-Buss. Is that correct? 1. I would do a test of the E-Buss switch prior to any flight where this function was important - i.e. an night or IFR flight, assuming your engine is not electrically dependent. If your engine is electrically dependent I would recommend doing a test of the E-Buss switch prior to every flight. The test would basically be: prior to selecting the master switch to ON, select the E-Buss switch to ON and confirm that there is power to the E-Bus. Then select the master switch to ON, and the E-Buss switch to OFF. Once you are close to the airport where you will land, you could power everything else back up if desired by selecting the master to Bat. power. 2. If you had an alternator failure, you would select the E-Buss switch to ON, then select the master switch to OFF. Now your battery is only powering the E-Buss loads, to maximize the electrical endurance. If you left the master to the Bat power position as you suggest the battery is powering everything, and it will run down quicker. This is OK if you are close to the airport where you will land, but you might run the battery to exhaustion otherwise. >Also, does the OVM module CAUSE the Alternator field to shut off - >or does it just allow some of the voltage to go to ground in order >to keep the voltage from spiking? Is it the case that you still >need to turn the master to Bat or OFF - to get the alternator >contactor to shut off? If you have an externally regulated alternator, the OVM shorts out the line to alternator field, causing the field CB to pop. This kills the alternator. If you have an internally regulated alternator, the OVM has to be wired to open a relay in the alternator output, as there is no access to the field power. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net>
Subject: Push to Talk Switch Wiring
Date: Mar 23, 2003
List, I have my Audio Panel PS-4000 wiring harness in place but they didn't make up separate wires for the Push to Talk Buttons? One wire I know is the ground but wouldn't the other wire go to the "Key Wire" on the Microphone jack that the headset plugs into? Thanks for any help as the wiring is just about done. Tom in Ohio ________________________________________________________________________________
Date: Mar 23, 2003
Subject: pre-made wiring harnesses
in case anyone is not interested in doing alot of wiring - check out www.approach-systems.com - they made my harness to go from Transponder to altitude encoder and one from intercom system to COMM radio and wow did that save alot of time. I'm impressed. I never have liked working with those small computer pins. --------------------------------- ________________________________________________________________________________
Date: Mar 23, 2003
Keith... >>By the way...... while we are waaaaaaayyyy off topic...... Is it "nuclear" or "nucular"? << Atomic.... Harley ________________________________________________________________________________
Subject: Re: pre-made wiring harnesses
Date: Mar 23, 2003
You might also want to check into Stark Avionics. John Stark quoted me the absolute lowest prices on all of my avionics (UPSAT stuff), and his prices for wiring harnesses are incredibly inexpensive. Why bother with a "black box" if you don't need to... http://www.mindspring.com/~jts7/index.htm )_( Dan RV-7 N714D (canopy) http://www.rvproject.com ----- Original Message ----- From: "Julia" <wings97302(at)yahoo.com> Subject: AeroElectric-List: pre-made wiring harnesses > > > in case anyone is not interested in doing alot of wiring - check out www.approach-systems.com - they made my harness to go from Transponder to altitude encoder and one from intercom system to COMM radio and wow did that save alot of time. I'm impressed. I never have liked working with those small computer pins. > > > --------------------------------- > > ________________________________________________________________________________
Subject: alternator failure modes
Date: Mar 24, 2003
<> Very interesting discussion from Paul. Just add a couple of points: First, there are some effects which limit the voltage capability of the alternator. The iron in both the field and the stator will saturate at currents not much above the rated currents. Therefore, even thought field current rises with alternator output the flux does not. There also is the effect of the internal capacitance of the stator windings that limit the output, but this might be a small effect. Regardless, as Paul stated, if the output load is removed the stator voltage will rise until limited by something. If the rectifier diodes don't fail the voltage will stabilize at the value limited by the internal resistance/saturation/inductance/capacitance of the alternator. In that case the field winding will likely fail. This is called a "load dump" in the automotive world, but we usually assume it is short lived, generally 10's of milliseconds (just as an aside, for marine usage we would assume that the operator would forget to tighten the battery terminal and the battery connection would repetitively open, causing frequent and repetitive load dumps that would have to be tolerated by the alternator and all electrical components). I think what Paul is suggesting is that it is reasonably probable that at least one diode of one stator phase will short, loading the other phases and pulling down the output voltage enough that the field winding will no longer fuse. I would suggest that it would be very unlikely that 2 phases will short as the current output from the remaining phase would be insufficient to cause a problem. With 2 phases running the output would be 2/3 the rated output, or 40 amps for a 60 amp alternator. Would that be enough to cause a fire? Remember, a simple overheat condition is not a concern, only a safety-of-flight fire. When I first heard of the "meltdown" under discussion I visualized fire and melted aluminum, but apparently it was an internal-to-the-alternator overheat condition, not a safety-related fire. Paul almost had me convinced with his perceptive argument, but now I'm wavering. My plan was to use a dual battery/dual alternator system with equally sized internally-regulated alternators of modest capacity, maybe 35 or 40 amps each. The reason was wiring simplicity and reduced weight. I'm assuming that the lower current capability of the alternators means more benign failure modes - a weak assumption, I'll readily admit. Gary Casey ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Re: E-Buss - switched vs. non-switched items
> > >I read somewhere that all items run off the E-Buss should have a switch on >them - I notice the diagrams call for a turn coordinator to run off the >e-buss - there is no switcfh on that. also I have an electric attitude >indicator -so I assume that would run off the e-buss as well? are both of >these items ok if they don't have an on/off switch on them? > >if these are ok -how about other low powered items - like instrument lights? Items on the endurance bus should include the things you need to get to airport-of-intended-destination-in-sight with the alternator off line. If only these items are on the e-bus, then there's no need for an independent ON/OFF switch. If you have stowaway loads that are not always useful in an alternator out condition, then having some way to shut them off is decidedly useful. Bob . . . ________________________________________________________________________________
Subject: RE: Infinity Stick Grip - Computer games joystick?!
Date: Mar 24, 2003
I am looking at computer joysticks too. Best Buy has these beauties---http://www.saitekusa.com/usa/prod/cyborgold.htm These things must be light and very hard to break...good things for OBAM aircraft. and you can buy a couple for spares just in case. I'd put some quality switches inside and add reinforcement where required, but they are close to perfect now. I'd also mount the thing on an Amphenol connector to detach easily. Not only does this make it easy to work on, but, properly arranged, would make a great anti-theft device. Regards, Eric M. Jones ________________________________________________________________________________
Subject: Re: alternator failure modes
Date: Mar 24, 2003
Good comments. Generally agree with them all. My intent was to keep the real world electronic calcs out of the discussion to make it more informative to the general list readers. I was attempting to point out an alternator failure not addressed by the "B" lead contactor. The peak voltage produced by one alternator (unfailed) that I tested was still working fine at over 200V when I stopped the test. I have been told some alternators have diodes with only 200V typical rating. In any event given the various alternator designs its possible to get very hot and what happens then is unique to the specific installation and surrounding components. The other engineers were not sure how many diodes could fail (they were all failed in the one unit but that could have been a result of the extreme heat). We stopped wondering as it was clear that there were too many variables to worry about when the point was to see if the assumption of a unloaded failed regulator was a condition of concern. Since we concluded it was, the simple and clear solution was to be sure the field was disconnected and an external regulator was a simple fix. The next task was to find an lightweight inexpensive alternator from the auto market for experimental aircraft. Having found one I quit looking. After all why have any risk if there is a simple solution to eliminate it. Perhaps the alternator "you" find with an internal regulator will fail safely and perhaps not. How does anyone know (perhaps only with a test program). With one real world example in hand (some 15 years ago) and expert analysis that concluded the most likely reason for the final burn up was as I have suggested, I decided why take even a very small risk given the simple alternative. Remember the alternator may be very hot to start with and all electronic components running close to their max temperature. The active components including the diodes and regulator electronics are typically rated at much lower temperatures than the wiring/insulation. Another reason to use an externally mounted regulator independent to any decision about my point. I have seen far too many alternators mounted in experimental aircraft where the internal or external alternator cooling fan was reverse to the airflow. The needed analysis is complex specific alternator unique and unneeded if one decided to simply avoid the design. In the case of an electrically dependent aircraft engine I feel there is a need to avoid any known or suspected risk if there is a reasonable solution. Also an external regulator typically is lighter than the "B" lead contactor so there is an additional weight saving. In any event the a regulator failure that results in an over voltage condition is rare and its likely the result self contained. Paul ----- Original Message ----- From: "Gary Casey" <glcasey(at)adelphia.net> Subject: AeroElectric-List: alternator failure modes > > < to > the field and cutting the power to the field (regulator) is simple and does > the job in all cases. > > Considering how simple it is to use an alternator that is easy to convert or > needs no conversion (to an external regulator) I feel there is no reason not > to do it. As such alternators are available in similar weight,size, and amp > ratings there need not be a weight penalty. > > Paul>> > > Very interesting discussion from Paul. Just add a couple of points: First, > there are some effects which limit the voltage capability of the alternator. > The iron in both the field and the stator will saturate at currents not much > above the rated currents. Therefore, even thought field current rises with > alternator output the flux does not. There also is the effect of the > internal capacitance of the stator windings that limit the output, but this > might be a small effect. Regardless, as Paul stated, if the output load is > removed the stator voltage will rise until limited by something. If the > rectifier diodes don't fail the voltage will stabilize at the value limited > by the internal resistance/saturation/inductance/capacitance of the > alternator. In that case the field winding will likely fail. This is > called a "load dump" in the automotive world, but we usually assume it is > short lived, generally 10's of milliseconds (just as an aside, for marine > usage we would assume that the operator would forget to tighten the battery > terminal and the battery connection would repetitively open, causing > frequent and repetitive load dumps that would have to be tolerated by the > alternator and all electrical components). > > I think what Paul is suggesting is that it is reasonably probable that at > least one diode of one stator phase will short, loading the other phases and > pulling down the output voltage enough that the field winding will no longer > fuse. I would suggest that it would be very unlikely that 2 phases will > short as the current output from the remaining phase would be insufficient > to cause a problem. With 2 phases running the output would be 2/3 the > rated output, or 40 amps for a 60 amp alternator. Would that be enough to > cause a fire? Remember, a simple overheat condition is not a concern, only > a safety-of-flight fire. When I first heard of the "meltdown" under > discussion I visualized fire and melted aluminum, but apparently it was an > internal-to-the-alternator overheat condition, not a safety-related fire. > > Paul almost had me convinced with his perceptive argument, but now I'm > wavering. My plan was to use a dual battery/dual alternator system with > equally sized internally-regulated alternators of modest capacity, maybe 35 > or 40 amps each. The reason was wiring simplicity and reduced weight. I'm > assuming that the lower current capability of the alternators means more > benign failure modes - a weak assumption, I'll readily admit. > > Gary Casey > > ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Re: GPS antenna location
> > >is it ok to mount the GPS antenna in a wing tip? I was going to mount it >under the engine cowl - but the wing tip is relatively empty when compared >with under the engine cowl. Also if I had to find another reason, >perhhaps it might be argued that if you flew upside down - the reception >would be just as good with the wing tip location - whereas it you mounted >it under the engine cowl and flew upside down, you'd have the engine >blocking the GPS signal? >What arguements are there for NOT mounting it in the wing tip? Longer coax cable (weakens signal . . . may not be an issue depending on your antenna (amplified or passive). > Do strobe signals interfere with GPS at all? no. >I"m using a wing tip COMM antenna in one tip and thought I'd put the GPS >in the other tip. My transponder antenna is underneath the seats and my >ELT antenna is in the tail - I think that's all the antennas I need. it ought to work. Bob . . . ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Re: E-Bus Switch
> > >with bob's wiring diagram for the main buss and e-buss & internal regular >Z-xx previously labeled. > >there is a master switch with Off/Bat/Alt. - positions. > >there is then an E-Buss switch > >under normal proceedures you would get in the airplane, turn the master to >Alternator - then start up. The E-Buss gets powered from a diode off the >main buss - so would you normally leave the E-Buss switch off - untill you >had a situation where you had an alternator failure - then you would flip >the master switch to Bat. power and turn on the E-Buss. Is that correct? My checklists call for turning the e-bus switch on first, get atis, clearance delivery, and note that nothing on the main bus becomes active. Turn e-bus switch off, conduct normal startup. E-bus switch stays off during normal operations. > > >Also, does the OVM module CAUSE the Alternator field to shut off - or does >it just allow some of the voltage to go to ground in order to keep the >voltage from spiking? Is it the case that you still need to turn the >master to Bat or OFF - to get the alternator contactor to shut off? ov module properly installed shuts down the alternator system and and/or opens contactor with no attention needed by the pilot. Bob . . . ________________________________________________________________________________
Date: Mar 24, 2003
Okay I need some clarification. I am finding it very difficult to find a 40A alternator that is externally regulated for a decent price that I know will fit my plane. I don't want to take an alternator apart and I don't want to build my own brackets. Anyway I have talked myself into getting an internally regulated alternator and putting the B lead contactor in with an OVM like Bob discusses. I don't have a problem with a failed alternator causing the OVM to trip and then the alternator self-distructing as long as it doesn't catch fire. My questions is... If the contactor opens while the alternator is online, will that cause the alternator to leak all of its smoke out? If that is the case then would somebody steer me toward a 40 Amp externally regulated alternator that doesn't cost more than $400. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ________________________________________________________________________________
Date: Mar 24, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: alternator + fire?
From a previous post. " don't have a problem with a failed alternator causing the OVM to trip and then the alternator self-distructing as long asit doesn't catch fire." I know quite a bit aobut cars and have rebuilt numerous Alt's years ago. I have never ran across and Alt that has caught fire. This is really rare right? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 24, 2003
See: http://www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?2X35821 8 scroll down to L-40 boss mount. Bob has said that these are the best available. Ed Holyoke > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Phil Birkelbach > Sent: Monday, March 24, 2003 9:19 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: alternator failure modes > > > > Okay I need some clarification. I am finding it very difficult to find a > 40A alternator that is externally regulated for a decent price that I know > will fit my plane. I don't want to take an alternator apart and I don't > want to build my own brackets. Anyway I have talked myself into getting > an > internally regulated alternator and putting the B lead contactor in with > an > OVM like Bob discusses. I don't have a problem with a failed alternator > causing the OVM to trip and then the alternator self-distructing as long > as > it doesn't catch fire. > > My questions is... If the contactor opens while the alternator is online, > will that cause the alternator to leak all of its smoke out? If that is > the > case then would somebody steer me toward a 40 Amp externally regulated > alternator that doesn't cost more than $400. > > Godspeed, > > Phil Birkelbach - Houston Texas > RV-7 N727WB (Reserved) - Fuselage > http://www.myrv7.com > > > > > > ________________________________________________________________________________
Subject: Re: Call the ball ??
Date: Mar 24, 2003
From: "David Glauser" <david.glauser(at)xpsystems.com>
I've got it even better. I get the entire garage. It was a deal - I wanted the house with the three-car garage. She wanted the smaller house with the two-car garage on a really nice lot. She said if I went for the smaller house I could have the whole garage. Not being a fool, I accepted. dg -----Original Message----- From: Tony Babb [mailto:tonybabb(at)alejandra.net] Subject: Re: AeroElectric-List: Re: Call the ball ?? Janelle, You're a saint and wonderful role model for the spouses of all homebuilders. Does your husband realize he's the envy of most of the rest of us? ----- Original Message ----- From: "nhulin" <nhulin(at)hotmail.com> Subject: AeroElectric-List: Re: Call the ball ?? > > Share? Share the garage? Dodge Caravan, pregnant, heavy snow all winter. > Share they say, Hah. > >From: Janelle, wife of Neil. ________________________________________________________________________________
Date: Mar 24, 2003
> > > Okay I need some clarification. I am finding it very difficult to find a > 40A alternator that is externally regulated for a decent price that I know > will fit my plane. I don't want to take an alternator apart and I don't > want to build my own brackets. Anyway I have talked myself into getting an > internally regulated alternator and putting the B lead contactor in with an > OVM like Bob discusses. I don't have a problem with a failed alternator > causing the OVM to trip and then the alternator self-distructing as long as > it doesn't catch fire. > > My questions is... If the contactor opens while the alternator is online, > will that cause the alternator to leak all of its smoke out? If that is the > case then would somebody steer me toward a 40 Amp externally regulated > alternator that doesn't cost more than $400. > > Godspeed, > > Phil Birkelbach - Houston Texas > RV-7 N727WB (Reserved) - Fuselage > http://www.myrv7.com > > . > I have flight checked this condition several times with my internally regulated alternator, a 40A Denso from Niagra with all brackets etc, for $225. I have a 35A circuit breaker switch in line with the B lead to the main bus. When opened in flight, the alternator loses no smoke. Same with turning off the regulator power. I have my OV protection hooked up to that fellow, but probably should also have the contactor that Bob recommends. I say probably because, I am from Missouri, and haven=B9t been shown the failure mode wherein the field gets goosed by some internal short from the B. P. S. Please don=B9t confuse me with any one who is willing to debate this sort of thing. I am delighted with the value of the niagra product, and its functino and reliability has been great. If I were startign over however, I would have to very carefully consider the B&C which is a giant step up from the =B3out of the box=B2 Denso. ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Motor Glider System Questions
>Bob, >I have entered a subscription to matronics as you suggest. I hope I will be >able navigate the site - an not be plaged by attempts to access my computer >system as you lamented on your site. . . . not sure what your concerns are . . . there are no potential risks to your computer to browse the matronics archives or subscribe to any of their supported lists . . . >I was able to print Z-13 - This was the schematic that I was first drawn to. >The nature of a motorglider flight is motored flight then a transition to >soaring flight - engine off - and the subsequent return for powered flight >for a return home. This poses some interesting battery power conservation >situations. Two batteries has been the main focus. Primarily concern is >the ability to insure adequate power for engine restart. Engine restart is >the #2 absolute requirement after the structural integrity of the airframe. >A send alternator/dynamo has not been considered but is now on the table. What size engine are we talking about? Do you have any current draw values for the starter? >My immediate need is info about determining the length to use in determining >voltage drop. I could not find a clear explanation in 43.13. The >explanation from an on line EAA tech differed from what I believe was on one >of your web articles. I interpret what you said is that the wire length to >use is that from the source , circuit breaker or buss connection, to the >consuming device plus the wire length to a ground connection. 43.13 seems >to indicate that, in an aluminum structure, the resistance drop from the >ground connection to the battery ground to airframe is negligable. Unless you're building a large composite aircraft or a huge aluminum airplane, voltage drops are not a driving consideration for wire size. Table 11-9 in AC43-13 or Figure 8-3 of the 'Connection can be consulted for recommended wires at the various current ratings. Fuses/breakers should be the same size or smaller than the recommended continuous current level. >Another question is the sizing of the main power feed from the battery (aft >baggage compartment) to the the main buss, estimated at 16 feet in my case, >and the power feed to the starter - another 8 feet from the main power buss >to starter relay and on to the starter. I am wondering about installing a >ground conductor from the starter back to the additional engine ground >connection on the firewall and possibly going onto the main ground buss at >the instrument panel. Are we now at 32 feet for voltage drop? What about >extending the ground wire another 16 feet to the battery(ies)? With the battery that far from the engine, make all cranking circuit wires at least 2AWG. Welding cable will work fine. Run braided number from crankcase to firewall ground stud, bring battery (-) to this same stud via 2AWG wire. Let's talk some more about how this airplane is used . . . you may want to consider a dual battery installation. Bob . . . ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Stick Grips
I have a Thrustmaster "Fighter X" and a real stick grip that was referred to (see below) as a "B8". The information about the (my) real stick grip is: GRIP ASSEMBLY,CONT,ACFT,TYPE MC-2 USAF 56C3002 and more #s. The mfg. mark is a "G" in arrow head shaped shield. Their part number is 58765. It is identical to the "Fighter X". in every way except weight and switch force. It has a new Amphenol mil spec connector and stick adapter for a 1.250" o.d. and 1.0" i.d. stick tube. This stick grip was given me for bringing home a disabled (Dual electrical failure) USAF T-38, or was it the only good part left over, whatever. All these years I assumed that it was the stick grip from a T-38/F-5 and maybe some other mil spec flying machines. Can anyone give me the facts on what I have. Is it a valuable antique like me? As for the "Fighter X", do I need driver software to get it to function in the Win or Mac worlds? I picked it up cause it looked a lot like something I used to hold in my right hand a lot. Now if I could find a mil throttle knob with a speed board switch. Thanks in advanced for any information. GG RV-4FB bottom gun ---------------------- The best ones, if you go that route, are the Thrustmaster B8 style. In fact, JD's early sticks were injected urethane foam surplus Thrustmasters (I know, I bought a dozen of them). The Thrustmaster "Top Gun" stick is slightly smaller - the same size at JD's - the "Fighter X" is a full size B8. Neither one is made anymore, but you can get them on EBay for about $20. The later Top Guns and all the Fighter Xs have soft neoprene inserts where the checkering is, which is also where your hand contacts the stick. ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Infinity Grip Selection 2 Rights - or 1 Right and 1
Left???? I'm ordering the Infinity grips -now i'm told I should consider a left and right I was going to order two right grips - since i'm right handed and most people are right handed. what do you all recommend? if I sit in the left seat of my RV7A - the throttle is in the center - would it be bad to hold the stick with my right hand and run the throttle with my left??? The infinity stick conforms to your hand -so you order a left or right hand style - it's not just a round tube. thanks --------------------------------- ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Re: Infinity Grip Selection 2 Rights - or 1
Right and 1 Left???? > > >I'm ordering the Infinity grips -now i'm told I should consider a >left and right > >I was going to order two right grips - since i'm right handed and >most people are right handed. > >what do you all recommend? if I sit in the left seat of my RV7A - >the throttle is in the center - would it be bad to hold the stick >with my right hand and run the throttle with my left??? > >The infinity stick conforms to your hand -so you order a left or >right hand style - it's not just a round tube. > >thanks > You are definitely going to want to hold the throttle in the hand that is on the same side the throttle is. It would not be comfortable to try to cross your left arm across your body to hold the throttle. So, that means you would want a left and right grip for a side-by-side RV, unless you are going to put in a throttle quadrant on the left side of the cockpit. In my opinion, people worry way too much about whether they will be able to fly the aircraft with the "wrong" hand. Sure, it may feel a bit strange for the first few minutes. But by the end of the first flight using your "wrong" hand you'll have forgotten which hand you are using. Just be sure to get enough dual using that hand before your first flight in the RV. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Mar 24, 2003
Subject: Re: Infinity Grip Selection 2 Rights - or 1 Right and
1 Left????
If you are going to the effort and expense of having a custom stick with lots of bells and whistles, with the intent of using them during crucial times of flight, crossing hands doesn't make sense. Picture this: Its a hazy, bumpy day and you are on wide left downwind to a busy airport, talking to the approach controller. He tells you to follow another small experimental which is on an extended right base to the same runway and in the same breath he hands you off to the tower. You need to switch frequencies, continue to fly the airplane through the turbulence, and keep your head outside the cockpit in order to see the airplane you were instructed to follow. At the same time, you are trying to milk off a little more throttle in order to stay behind said traffic. You can have the 'wrong' hand on the stick, and resort to hitting the flipflop on the panel instead of the one on the stick (which you spent extra on). Or, you can twist your left hand across your body to adjust the throttle (which your hand should really stray from for long periods). I think I would choose to fly most of the time with my left hand on the stick, if there's only one throttle in the airplane. That's what you do in a plane with a yolk, and it isn't a problem there. Otherwise, get a second throttle installed onto the left edge of the panel, or plan to fly from the right seat. Crossing over on a custom airplane seems silly. Especially on one that was supposed to be fun to fly. Regards, Matt (who has elevator trim on the wrong side and doesn't like it) Prather- N34RD > > > I'm ordering the Infinity grips -now i'm told I should consider a left > and right > > I was going to order two right grips - since i'm right handed and most > people are right handed. > > what do you all recommend? if I sit in the left seat of my RV7A - the > throttle is in the center - would it be bad to hold the stick with my > right hand and run the throttle with my left??? > > The infinity stick conforms to your hand -so you order a left or right > hand style - it's not just a round tube. > > thanks > > > --------------------------------- > > ________________________________________________________________________________
Date: Mar 24, 2003
List, I Haven't gotten any help on this problem yet? Has anybody faced this one? No help in the archives Thanks, Tom in Ohio ----- Original Message ----- From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> Subject: AeroElectric-List: Push to Talk Switch Wiring > > List, > I have my Audio Panel PS-4000 wiring harness in place but they didn't make up separate wires for the Push to Talk Buttons? > One wire I know is the ground but wouldn't the other wire go to the "Key Wire" on the Microphone jack that the headset plugs into? Thanks for any help as the wiring is just about done. > Tom in Ohio > > ________________________________________________________________________________
Date: Mar 24, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Re: Push to Talk Switch Wiring
Tom & Cathy Ervin wrote: > >List, I Haven't gotten any help on this problem yet? Has anybody faced >this one? No help in the archives > >Thanks, Tom in Ohio >----- Original Message ----- >From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> >To: >Subject: AeroElectric-List: Push to Talk Switch Wiring > > > > >> >> > > > >>List, >> I have my Audio Panel PS-4000 wiring harness in place but they >> >> >didn't make up separate wires for the Push to Talk Buttons? > > >> One wire I know is the ground but wouldn't the other wire go >> >> >to the "Key Wire" on the Microphone jack that the headset plugs into? >Thanks for any help as the wiring is just about done. > > >Tom in Ohio > Hi Tom, Do you mean that the harness has the key wire from the intercom to the radio but not from the mic jack to the intercom? The PTT wire should leave the 'tip' terminal of the mic jack and go to the 'PTT' or 'key' jack on the intercom. There will likely be a PTT terminal on the intecom for the pilot's mic & each passenger's mic. The intercom should have another terminal for a PTT wire leaving the intercom & going to the radio. Does this help? Charlie ________________________________________________________________________________
Date: Mar 24, 2003
In a message dated 3/24/2003 8:00:49 PM Mountain Standard Time, cengland(at)netdoor.com writes: > > >>List, > >> I have my Audio Panel PS-4000 wiring harness in place but > they > >> > >> > >didn't make up separate wires for the Push to Talk Buttons? > > > > > >> One wire I know is the ground but wouldn't the other wire go > >> > >> > >to the "Key Wire" on the Microphone jack that the headset plugs into? > >Thanks for any help as the wiring is just about done. > > > > > >Tom in Ohio > Ya need to contact PS engineering with this problem. They believe no one but themselves are smart enought to do anything. It is kinda hard to believe that a PS harness in incorrect !!!!!!!! Oh, and by the way. Do not tell them this intercom is is a homebuilt. Ben Haas. N801BH. ________________________________________________________________________________
Date: Mar 25, 2003
1 Left????
Hi! With Throttle / Engine Controls to the right/centre then I would strongly recommend using the Left Hand Grip. It may at first feel uncomfortable to 'control' stick with Left Hand but it soon grows on you. For me it felt strange at first after using a 'handlebar type Yoke for a few years.With the Yoke the left hand 'control' felt OK (possible angle of hand grip) but using a stick again did take a little while to get relaxed with. Crossing Arms/Hands to carry out control functions is not a good idea. You could of course duplicate Throttle mechanism and go for additional Left hand Throttle. Regards Gerry On Monday, Mar 24, 2003, at 22:19 Europe/London, Julia wrote: Gerry Holland mailto://gnholland(at)onetel.com +44 7808 402404 Europa XS 384 G-FIZY The greatest enjoyment from existence is living dangerously.... Friedrich Nietzsche ________________________________________________________________________________
Date: Mar 25, 2003
Charlie, I have a "Key Wire" from the audio panel to the jack but.........most harness I have seen also have a wire for the push to talk? I believe I can jump off the jack key wire and accomplish the same thing?? Tom in Ohio ----- Original Message ----- From: "Charlie & Tupper England" <cengland(at)netdoor.com> Subject: Re: Fw: AeroElectric-List: Push to Talk Switch Wiring > > Tom & Cathy Ervin wrote: > > > > >List, I Haven't gotten any help on this problem yet? Has anybody faced > >this one? No help in the archives > > > >Thanks, Tom in Ohio > >----- Original Message ----- > >From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> > >To: > >Subject: AeroElectric-List: Push to Talk Switch Wiring > > > > > > > > > >> > >> > > > > > > > >>List, > >> I have my Audio Panel PS-4000 wiring harness in place but they > >> > >> > >didn't make up separate wires for the Push to Talk Buttons? > > > > > >> One wire I know is the ground but wouldn't the other wire go > >> > >> > >to the "Key Wire" on the Microphone jack that the headset plugs into? > >Thanks for any help as the wiring is just about done. > > > > > >Tom in Ohio > > > Hi Tom, > > Do you mean that the harness has the key wire from the intercom to the > radio but not from the mic jack to the intercom? > > The PTT wire should leave the 'tip' terminal of the mic jack and go to > the 'PTT' or 'key' jack on the intercom. There will likely be a PTT > terminal on the intecom for the pilot's mic & each passenger's mic. The > intercom should have another terminal for a PTT wire leaving the > intercom & going to the radio. > > Does this help? > > Charlie > > ________________________________________________________________________________
Date: Mar 25, 2003
> > >Charlie, I have a "Key Wire" from the audio panel to the jack >but.........most harness I have seen also have a wire for the push to talk? >I believe I can jump off the jack key wire and accomplish the same thing?? This is generally the case. PTT leads to microphones and PTT leads to wheel/stick mounted buttons are one in the same circuit. When only microphone jack PTT wiring is depicted, then additional buttons are wired to the >Tom in Ohio >----- Original Message ----- >From: "Charlie & Tupper England" <cengland(at)netdoor.com> >To: >Subject: Re: Fw: AeroElectric-List: Push to Talk Switch Wiring > > > > > > > Tom & Cathy Ervin wrote: > > > > > > > > >List, I Haven't gotten any help on this problem yet? Has anybody faced > > >this one? No help in the archives > > > > > >Thanks, Tom in Ohio > > >----- Original Message ----- > > >From: "Tom & Cathy Ervin" <tcervin(at)valkyrie.net> > > >To: > > >Subject: AeroElectric-List: Push to Talk Switch Wiring > > > > > > > > > > > > > > >> > > >> > > > > > > > > > > > >>List, > > >> I have my Audio Panel PS-4000 wiring harness in place but >they > > >> > > >> > > >didn't make up separate wires for the Push to Talk Buttons? > > > > > > > > >> One wire I know is the ground but wouldn't the other wire go > > >> > > >> > > >to the "Key Wire" on the Microphone jack that the headset plugs into? > > >Thanks for any help as the wiring is just about done. > > > > > > > > >Tom in Ohio > > > > > Hi Tom, > > > > Do you mean that the harness has the key wire from the intercom to the > > radio but not from the mic jack to the intercom? > > > > The PTT wire should leave the 'tip' terminal of the mic jack and go to > > the 'PTT' or 'key' jack on the intercom. There will likely be a PTT > > terminal on the intecom for the pilot's mic & each passenger's mic. The > > intercom should have another terminal for a PTT wire leaving the > > intercom & going to the radio. > > > > Does this help? > > > > Charlie > > > > > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 25, 2003
> > >Charlie, I have a "Key Wire" from the audio panel to the jack >but.........most harness I have seen also have a wire for the push to talk? >I believe I can jump off the jack key wire and accomplish the same thing?? This is generally the case. PTT leads to microphones and PTT leads to wheel/stick mounted buttons are one in the same circuit. When only microphone jack PTT wiring is depicted, then additional buttons are wired to the (. . . oops, too fast on the keys this morning, launched the message before it was finished) to the microphone jack. See page 11 of http://216.55.140.222/Catalog/avionics/760imB.pdf Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
> >I have flight checked this condition several times with my internally >regulated alternator, a 40A Denso from Niagra with all brackets etc, for >$225. > >I have a 35A circuit breaker switch in line with the B lead to the main bus. >When opened in flight, the alternator loses no smoke. Same with turning off >the regulator power. It would be interesting to get a voltmeter reading on the alternator side of the breaker when it's opened in cruising flight . . . although this DOES pose the risk of diode failure, I believe it to be low. If you've already done this without taking a voltage reading, then the risk is VERY small. > I have my OV protection hooked up to that fellow, but >probably should also have the contactor that Bob recommends. I say probably >because, I am from Missouri, and haven=B9t been shown the failure mode >wherein the field gets goosed by some internal short from the B. I've seen this happen only once . . . about 35 years ago on a Mooney. It was the by-product of poor mechanical design in a low-cost alternator Mooney was trying . . . they abandoned that device for this and other reasons. Given the manner in which modern alternator are assembled mechanically, this is not a concern. >P. S. Please don=B9t confuse me with any one who is willing to debate this >sort of thing. > >I am delighted with the value of the niagra product, and its functino and >reliability has been great. If I were startign over however, I would have >to very carefully consider the B&C which is a giant step up from the =B3out >of the box=B2 Denso. thank you for sharing this data. BTW, the 35 A breaker concerns me . . . a 40A alternator will put out more than 40A when cold. The 60A breaker on most single engine aircraft is DESIGNED to nuisance trip when the stock, 60A alternator is feeling frisky. You might keep an eye open for a 50A breaker to put in that slot when it becomes convenient. Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Re: alternator + fire?
><bilinski@kyocera-wireless.com> > > From a previous post. > >" don't have a problem with a failed alternator causing the OVM to trip and >then the alternator self-distructing as long asit doesn't catch fire." > >I know quite a bit aobut cars and have rebuilt numerous Alt's years ago. I >have never ran across and Alt that has caught fire. This is really rare right? Alternators don't catch fire. They DO burn up windings with liberation of some smelly smoke but they could conceivably eject bits of sparking materials if a wire burns open but they do not burst into sustained flames. Given their locations on engines, the risk of propagating burning debris onto other combustibles under the cowl is zip . . . we take pains to NOT have combustibles under the cowl . . . right? Thousands of airplanes have come down in the history of aviation due to failure of an alternator's ability to power critical items for sustained flight in poorly designed and/or maintained systems . . . I'm aware of no accident where the alternator set the airplane on fire. I'll ask the wreckage-wiennies at RAC if they're ever seen it. I'm certain the answer is going to be "no". Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
Bin watchin' the discussion about failure modes of two-terminal (internally regulated) alternators. I use Prestolite DOFxxxx style alternators, which have four external terminals: Field1, Field2, B (output), and case-ground. As such, they are amenable to external control and shutdown. Because they bring out both field slip-rings, you can even use external high-side (Chrysler), or low-side (Ford, Motorola) Voltage Regulators (VR). OverVoltage Protection (OVP) can be accomplished by interupting the field current path either by using a series switch, or a shunt crowbar which "blows" the field breaker... If I were to use one of the modern two-terminal marvels, I would take it apart to disconnect the internal connection between the B terminal (output) and the internal VR. If I wanted to use the internal VR, I would bring the VR input wire out of the alternator's case so that I could connect an external OVP and a pullable Field Breaker between the B terminal and the internal VR. Alternatively, I would disconnect both the input and output from the internal VR, bring out the wire from the field slip-ring, and revert to my own tried and true external VR and OVP. I made a modification similar to this to the internally regulated alternator in my boat. The goal was to be able to use an external "smart", remote-sensing VR, which is capable of "equalizing" the boat batteries by artifically boosting the charge voltage at my will. It was easy to disassemble the alternator to isolate the internal regulator... Mike Mladejovsky ________________________________________________________________________________
Date: Mar 25, 2003
Subject: starter brushes and burnt alternators
The starter brush dimensions for a Delco-Remy model #1109657 are: .500 x .750 x .250 in. The part numbers are: Standard RX52 Delco D754 Niehoff DR95E I don't know if they are available. They fit industrial and Nash/American starters up to 1951. We also see many burned alternators from cars. Mostly the the diode assy. and reg. in CS130 and CS144 series Delco. (late 1980's and up GM) The B lead connector burns up on the Ford int. reg. alternators quite often, including enough fire to melt other wiring that is close to the alt. Steve Springfield Auto Parts Co., Inc. ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Re: Motor Glider System Questions
> From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > Reply-To: aeroelectric-list(at)matronics.com > Date: Mon, 24 Mar 2003 14:50:50 -0600 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Motor Glider System Questions > > > > >> Bob, >> I have entered a subscription to matronics as you suggest. I hope I will be >> able navigate the site - an not be plaged by attempts to access my computer >> system as you lamented on your site. > > . . . not sure what your concerns are . . . there are no > potential risks to your computer to browse the matronics archives > or subscribe to any of their supported lists . . . Enough said > > >> I was able to print Z-13 - This was the schematic that I was first drawn to. >> The nature of a motorglider flight is motored flight then a transition to >> soaring flight - engine off - and the subsequent return for powered flight >> for a return home. This poses some interesting battery power conservation >> situations. Two batteries has been the main focus. Primarily concern is >> the ability to insure adequate power for engine restart. Engine restart is >> the #2 absolute requirement after the structural integrity of the airframe. >> A send alternator/dynamo has not been considered but is now on the table. > > What size engine are we talking about? Do you have any current > draw values for the starter? I have a Lycoming 150 HP(Low Compression 7:1) with a factory supplied Light Weight Starter. Will get starter information info from data plate if available - project is 1+ hour from home. I have a constant speed propeller with unfeathering accumulator - Hope is to be able to unfeather and "dive start", or at least assist battery start, after motorless soaring flight. The 2 battery installation with manual selection is planned. The only automatic function is the placement of a diode to allow charging of the soaring battery when the engine alternator is on line. I have not planned to parallel the batteries, however another parallel position could easily be added to the manual rotary battery selector switch. The thought is that the "soaring" battery will power the instrumention/radio etc buss to be used for soaring without accessing the engine start battery. While the engine is running, the soaring battery will be charged - a diode is planed to allow charging but not allow discharge of the soaring battery while the engine is running. What happens if one battery-(Soaring) is depleted and it is paralleled with a charged (engine) battery? Have no experience but it does not sound like a good idea to me. Also the hope is to be able to "dive start", if necessary after motorless flight with assist from engine battery as available. > >> My immediate need is info about determining the length to use in determining >> voltage drop. I could not find a clear explanation in 43.13. The >> explanation from an on line EAA tech differed from what I believe was on one >> of your web articles. I interpret what you said is that the wire length to >> use is that from the source , circuit breaker or buss connection, to the >> consuming device plus the wire length to a ground connection. 43.13 seems >> to indicate that, in an aluminum structure, the resistance drop from the >> ground connection to the battery ground to airframe is negligable. > > Unless you're building a large composite aircraft or a huge > aluminum airplane, voltage drops are not a driving consideration > for wire size. Table 11-9 in AC43-13 or Figure 8-3 of the > 'Connection can be consulted for recommended wires at the various > current ratings. Fuses/breakers should be the same size or > smaller than the recommended continuous current level. I am not sure if I am huge - it is a 2 place tandem, all aluminum airframe with a high aspect wing - span 63 feet, fuselage spinner to tail cone 33 feet. Gross weight may approach 2400 pounds. Airframe is 95% complete. Depending to ground wire and/or airframe bond answer (see below) some circuit lengths may have a voltage drop problem - however the few circuits involved could be solved by increasing wire size. > > >> Another question is the sizing of the main power feed from the battery (aft >> baggage compartment) to the the main buss, estimated at 16 feet in my case, >> and the power feed to the starter - another 8 feet from the main power buss >> to starter relay and on to the starter. I am wondering about installing a >> ground conductor from the starter back to the additional engine ground >> connection on the firewall and possibly going onto the main ground buss at >> the instrument panel. Are we now at 32 feet for voltage drop? What about >> extending the ground wire another 16 feet to the battery(ies)? > > With the battery that far from the engine, make all cranking > circuit wires at least 2AWG. Welding cable will work fine. > Run braided number from crankcase to firewall ground stud, > bring battery (-) to this same stud via 2AWG wire. Let's > talk some more about how this airplane is used . . . you > may want to consider a dual battery installation. Would it make sense to bond/jumper all consuming devices to the airframe in addition to a ground wire from each device to a ground buss installed in the #2 ground wire return to the battery? In addition to the firewall and front cockpit ground buss, I planned to put a ground buss at the aft passenger panel, in the #2 ground return to the battery location and connect grounds from the aft PAX panel. Electrical items in the wing would ground in this aft buss. A 2 battery installation is definitely being installed. The mission of the Motorglider is to provide a 2 place aircraft capable of "light IFR" cross country powered flight allowing departure from a city metropolis to an area, where soaring flight is practical, and return. The aircraft is designed to have a glide ratio approaching 30:1. Fuel capacity is 40 gallons, however that amount would not normally be carried. The airframe is a conventional tail dragger with a mechanically retractable main (2 wheel) landing gear. The outer 13 feet wing panels fold over the top and rest on top of the inboard wing. There is adequate power to tow sailplanes, if or when a tow hook is installed. > > Bob . . . Thank You for your input Jerry > > > > > ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Re: Stereo Wirin'
>Question 1: Is this an appropriate method or is there a more functional >way of doing this? Sounds like it ought to work. >The only problem I see it that if you plugged a mono headset into the >STEREO jack, it would short the channel wired to the ring to ground. Even with DC blocking, some folks audio output stages might not like the increased output load. The LM386 will be okay I think. Of course, shorting one headset station's audio output channel to ground would kill them all. >Question 2: Is this a bad thing? Or is the radio protected somehow from >having audio out grounded with no load? I'm going to attempt to "roll >my own" audio isolation amp as shown in the Connection and there is a >10uF capacitor in the audio out- is this critter there to protect the >output from going to ground if it is shorted out? Yes . . . that capacitor is probably undersized . . . don't order parts until I get finished with the prototype. I've got the board stuffed. Will try to get it powered up this evening. . . >I could placard the stereo jack against mono insertion, but this may >make female passengers nervous! I usually put a toggle switch next to the jack to flip between stereo and monaural operation. Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Re: starter brushes and burnt alternators
> > >We also see many burned alternators from cars. >Mostly the the diode assy. and reg. in CS130 and CS144 series Delco. (late >1980's and up GM) >The B lead connector burns up on the Ford int. reg. alternators quite often, >including enough fire to melt other wiring that is close to the alt. Are any of these off-shore manufactured alternators . . . i.e. obviously ND, Mitsubishi, et. als? What's been your experience/observation with ND alternators? Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
> > > What size engine are we talking about? Do you have any current > > draw values for the starter? > >I have a Lycoming 150 HP(Low Compression 7:1) with a factory supplied Light >Weight Starter. Will get starter information info from data plate if >available - project is 1+ hour from home. > >I have a constant speed propeller with unfeathering accumulator - Hope is to >be able to unfeather and "dive start", or at least assist battery start, >after motorless soaring flight. The 2 battery installation with manual >selection is planned. The only automatic function is the placement of a >diode to allow charging of the soaring battery when the engine alternator is >on line. No diode is necessary. A figure Z-11 with a second battery sounds like the cleanest system . . . or Z-13 . . . it's really easy to add the second alternator if you think you'd like to have the second engine driven power source. >I have not planned to parallel the batteries, however another parallel >position could easily be added to the manual rotary battery selector switch. >The thought is that the "soaring" battery will power the instrumention/radio >etc buss to be used for soaring without accessing the engine start battery. >While the engine is running, the soaring battery will be charged - a diode >is planed to allow charging but not allow discharge of the soaring battery >while the engine is running. For Z-11/13 with two batteries, each battery has it's own master switch. Both on for cranking and powered flight. Turn e-bus switch ON and both battery masters off for soaring flight . . . run soaring loads from e-bus (main battery only). >What happens if one battery-(Soaring) is depleted and it is paralleled with >a charged (engine) battery? Have no experience but it does not sound like a >good idea to me. Also the hope is to be able to "dive start", if necessary >after motorless flight with assist from engine battery as available. Doesn't hurt a thing. If main battery is depleted before engine start (have you figured what your soaring loads are?) it represents no big load on the cranking battery when it comes time to start the engine. Just close both battery master switches and hit the starter. With dual, well maintained batteries, the likelihood of EVER having to air-start the engine is zip (unless you've got a less than the best lightweight starter . . . then the risk is slightly greater than zip). >I am not sure if I am huge - it is a 2 place tandem, all aluminum airframe >with a high aspect wing - span 63 feet, fuselage spinner to tail cone 33 >feet. Gross weight may approach 2400 pounds. Airframe is 95% complete. >Depending to ground wire and/or airframe bond answer (see below) some >circuit lengths may have a voltage drop problem - however the few circuits >involved could be solved by increasing wire size. Run 2AWG wire from engine to batteries both ways . . . it will be fine. >Would it make sense to bond/jumper all consuming devices to the airframe in >addition to a ground wire from each device to a ground buss installed in the >#2 ground wire return to the battery? In addition to the firewall and front >cockpit ground buss, I planned to put a ground buss at the aft passenger >panel, in the #2 ground return to the battery location and connect grounds >from the aft PAX panel. Electrical items in the wing would ground in this >aft buss. Airframes hold wings and engine together, wires crank engines and run radios. Except for local grounding of certain remote items like nav lights, strobe power supply, landing/taxi lights and pitot heat, all other stuff is best carried on its own wiring sized to the task. 2AWG fat wires and a pair of 17 a.h. batteries is going to give you excellent cranking performance and reliability. >A 2 battery installation is definitely being installed. > >The mission of the Motorglider is to provide a 2 place aircraft capable of >"light IFR" cross country powered flight allowing departure from a city >metropolis to an area, where soaring flight is practical, and return. The >aircraft is designed to have a glide ratio approaching 30:1. Fuel capacity >is 40 gallons, however that amount would not normally be carried. The >airframe is a conventional tail dragger with a mechanically retractable main >(2 wheel) landing gear. The outer 13 feet wing panels fold over the top and >rest on top of the inboard wing. There is adequate power to tow sailplanes, >if or when a tow hook is installed. Figure Z-11/13 with second battery (Z-30 but no aux battery bus) will probably give you reliability and convenience far better than anything else flying. Bob . . . ________________________________________________________________________________
Date: Mar 25, 2003
Subject: starter considerations with EFIS/one and FADEC
Bob and others: Ive been thinking of solutions to some of the things=A0 we have been discussing concerning voltage drop when starting FADEC engines. Also concern over voltage spikes=A0 or low voltage problems with the EFIS/ONE=A0 during starting.=A0 Here is what I came up with.=A0 Using Z-14 DBDA=A0 Put all avionics one one=20bus. For me I think this will be a avionics bus with quad feed.=A0 One from main=20bus through diode and avionics master switch. Second from Alternate bus through diode and avionics secondary master switch. Master switches are included in case EFIS systems need isolated as Greg Ricktor seems to think they should be. Third and fourth essential feeds from main batt buss and alternate batt buss on one switch that would choose one or the other.=A0 Cross feed contactor will not have starter switch included. Starter switch will be seperate. Here is how I envision it working.=A0 During start up sequence the avionics bus can be feed through the alternative electrical system. So the Efis/One is powered up from that source. Also the FADEC ignition is powered from the Alternate battery. The main battery is used to start the engine The cross feed is kept open at this point so the two electrical systems never affect each other. If you needed both batteries to start you would not turn on avionics bus until engine started. You wouldnt have you oil pressure immediatly but this shouldnt be a common occurance to need both batteries for starting. It seem to me that this allows the Efis/One and the FADEC ing. to be at 12.5 volts continually during engine start-up.=A0 What do you think? ________________________________________________________________________________
Date: Mar 25, 2003
> From: Gerald Giddens <geraldgiddens(at)cox.net> > Reply-To: aeroelectric-list(at)matronics.com > Date: Tue, 25 Mar 2003 11:50:18 -0800 > To: > Subject: Re: AeroElectric-List: Motor Glider System Questions > > > > >> From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> >> Reply-To: aeroelectric-list(at)matronics.com >> Date: Mon, 24 Mar 2003 14:50:50 -0600 >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Motor Glider System Questions >> >> >> >> >>> Bob, >>> I have entered a subscription to matronics as you suggest. I hope I will be >>> able navigate the site - an not be plaged by attempts to access my computer >>> system as you lamented on your site. >> >> . . . not sure what your concerns are . . . there are no >> potential risks to your computer to browse the matronics archives >> or subscribe to any of their supported lists . . . > > Enough said > >> >> >>> I was able to print Z-13 - This was the schematic that I was first drawn to. >>> The nature of a motorglider flight is motored flight then a transition to >>> soaring flight - engine off - and the subsequent return for powered flight >>> for a return home. This poses some interesting battery power conservation >>> situations. Two batteries has been the main focus. Primarily concern is >>> the ability to insure adequate power for engine restart. Engine restart is >>> the #2 absolute requirement after the structural integrity of the airframe. >>> A send alternator/dynamo has not been considered but is now on the table. >> >> What size engine are we talking about? Do you have any current >> draw values for the starter? > > I have a Lycoming 150 HP(Low Compression 7:1) with a factory supplied Light > Weight Starter. Will get starter information info from data plate if > available - project is 1+ hour from home. > > I have a constant speed propeller with unfeathering accumulator - Hope is to > be able to unfeather and "dive start", or at least assist battery start, > after motorless soaring flight. The 2 battery installation with manual > selection is planned. The only automatic function is the placement of a > diode to allow charging of the soaring battery when the engine alternator is > on line. > > I have not planned to parallel the batteries, however another parallel > position could easily be added to the manual rotary battery selector switch. > The thought is that the "soaring" battery will power the instrumention/radio > etc buss to be used for soaring without accessing the engine start battery. > While the engine is running, the soaring battery will be charged - a diode > is planed to allow charging but not allow discharge of the soaring battery > while the engine is running. > > What happens if one battery-(Soaring) is depleted and it is paralleled with > a charged (engine) battery? Have no experience but it does not sound like a > good idea to me. Also the hope is to be able to "dive start", if necessary > after motorless flight with assist from engine battery as available. >> >>> My immediate need is info about determining the length to use in determining >>> voltage drop. I could not find a clear explanation in 43.13. The >>> explanation from an on line EAA tech differed from what I believe was on one >>> of your web articles. I interpret what you said is that the wire length to >>> use is that from the source , circuit breaker or buss connection, to the >>> consuming device plus the wire length to a ground connection. 43.13 seems >>> to indicate that, in an aluminum structure, the resistance drop from the >>> ground connection to the battery ground to airframe is negligable. >> >> Unless you're building a large composite aircraft or a huge >> aluminum airplane, voltage drops are not a driving consideration >> for wire size. Table 11-9 in AC43-13 or Figure 8-3 of the >> 'Connection can be consulted for recommended wires at the various >> current ratings. Fuses/breakers should be the same size or >> smaller than the recommended continuous current level. > > I am not sure if I am huge - it is a 2 place tandem, all aluminum airframe > with a high aspect wing - span 63 feet, fuselage spinner to tail cone 33 > feet. Gross weight may approach 2400 pounds. Airframe is 95% complete. > Depending to ground wire and/or airframe bond answer (see below) some > circuit lengths may have a voltage drop problem - however the few circuits > involved could be solved by increasing wire size. >> >> >>> Another question is the sizing of the main power feed from the battery (aft >>> baggage compartment) to the the main buss, estimated at 16 feet in my case, >>> and the power feed to the starter - another 8 feet from the main power buss >>> to starter relay and on to the starter. I am wondering about installing a >>> ground conductor from the starter back to the additional engine ground >>> connection on the firewall and possibly going onto the main ground buss at >>> the instrument panel. Are we now at 32 feet for voltage drop? What about >>> extending the ground wire another 16 feet to the battery(ies)? >> >> With the battery that far from the engine, make all cranking >> circuit wires at least 2AWG. Welding cable will work fine. >> Run braided number from crankcase to firewall ground stud, >> bring battery (-) to this same stud via 2AWG wire. Let's >> talk some more about how this airplane is used . . . you >> may want to consider a dual battery installation. > > Would it make sense to bond/jumper all consuming devices to the airframe in > addition to a ground wire from each device to a ground buss installed in the > #2 ground wire return to the battery? In addition to the firewall and front > cockpit ground buss, I planned to put a ground buss at the aft passenger > panel, in the #2 ground return to the battery location and connect grounds > from the aft PAX panel. Electrical items in the wing would ground in this > aft buss. > > A 2 battery installation is definitely being installed. > > The mission of the Motorglider is to provide a 2 place aircraft capable of > "light IFR" cross country powered flight allowing departure from a city > metropolis to an area, where soaring flight is practical, and return. The > aircraft is designed to have a glide ratio approaching 30:1. Fuel capacity > is 40 gallons, however that amount would not normally be carried. The > airframe is a conventional tail dragger with a mechanically retractable main > (2 wheel) landing gear. The outer 13 feet wing panels fold over the top and > rest on top of the inboard wing. There is adequate power to tow sailplanes, > if or when a tow hook is installed. > > >> >> Bob . . . > Thank You for your input > Jerry >> >> >> >> >> > > > > > > ________________________________________________________________________________
Date: Mar 25, 2003
Thanks Bob......As always clear, concise information! I have your book also and it has been a great help for this Rookie. Wiring is almost done and the smoke is in the wires so far. Tom in Ohio ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: Fw: AeroElectric-List: Push to Talk Switch Wiring > > > > > > >Charlie, I have a "Key Wire" from the audio panel to the jack > >but.........most harness I have seen also have a wire for the push to talk? > >I believe I can jump off the jack key wire and accomplish the same thing?? > > This is generally the case. PTT leads to microphones and > PTT leads to wheel/stick mounted buttons are one in the > same circuit. When only microphone jack PTT wiring is > depicted, then additional buttons are wired to the > > (. . . oops, too fast on the keys this morning, launched > the message before it was finished) > > to the microphone jack. See page 11 of > http://216.55.140.222/Catalog/avionics/760imB.pdf > > Bob . . . > > ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Hot Little Torch
I was in Radio Shack today and picked up one of their Mini Butane-Powered Soldering Irons - #64-2188 - for $19.99. WOW what a neat tool! I highly recommend getting one of these. I have no patience for waiting for a soldering iron to warm up - I was using a full sized plumbers torch. That worked fine for all but small items like the potentiometer on the light dimmer (no longer a potentiometer) - but this torch is really slick. It comes with a blow torch tip (which I plan to use) and then a soldering tip. The flame is very small and has pin point accuracy - i'm impressed - go get one! --------------------------------- ________________________________________________________________________________
Date: Mar 25, 2003
Subject: Is this a "good" battery for the price?
Hiya Mr. Bob, I found these battries what do you think of the last one, the surplus "HAWKER G13EP" they actually weigh 10.8 Lbs. at: http://surplusev.com/ I got two including shipping to me for $60.oo total ! What do ya think for the price. Tom... ________________________________________________________________________________
From: "Stucklen, Frederic IFC" <Fred.Stucklen(at)UTCFuelCells.com>
Subject: RE: starter considerations with EFIS/one and FADEC
Date: Mar 26, 2003
Tim, This is essentially what I have done with the power to the dual electronic ignition system that I've installed on my new RV-6A. I have a dual battery electrical system. The Aux battery contactor is always open during engine start, thereby assuring that that electronic ignitions always get 12 V, and do not see any voltage spike on the main battery. Once started, the Aux battery will switch onto the bus if it's contact control switch is in the "Auto" position (it also has an "OFF" and an "ON" position...). Also, once the engine is started, oil pressure switches connect each ignition system (via a diode) to both batteries. So even if both battery contactors are turned "OFF", the engine continues to run...... I'll be glad to share this circuit with the list if anybody is interested....... Fred Stucklen RV-6A N926RV Reserved From: TimRhod(at)aol.com Bob and others: Ive been thinking of solutions to some of the things=A0 we have been discussing concerning voltage drop when starting FADEC engines. Also concern over voltage spikes=A0 or low voltage problems with the EFIS/ONE=A0 during starting.=A0 Here is what I came up with.=A0 Using Z-14 DBDA=A0 Put all avionics one one=20bus. from main=20bus through diode and avionics master switch. Second from Alternate bus through diode and avionics secondary master switch. Master switches are included in case EFIS systems need isolated as Greg Ricktor seems to think they should be. Third and fourth essential feeds from main batt buss and alternate batt buss on one switch that would choose one or the other.=A0 Cross feed contactor will not have starter switch included. Starter switch will be seperate. Here is how I envision it working.=A0 During start up sequence the avionics bus can be feed through the alternative electrical system. So the Efis/One is powered up from that source. Also the FADEC ignition is powered from the Alternate battery. The main battery is used to start the engine The cross feed is kept open at this point so the two electrical systems never affect each other. If you needed both batteries to start you would not turn on avionics bus until engine started. You wouldnt have you oil pressure immediatly but this shouldnt be a common occurance to need both batteries for starting. It seem to me that this allows the Efis/One and the FADEC ing. to be at 12.5 volts continually during engine start-up.=A0 What do you think? ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: Is this a "good" battery for the price?
> >Hiya Mr. Bob, > >I found these battries what do you think of the last one, the surplus >"HAWKER G13EP" they actually weigh 10.8 Lbs. at: > >http://surplusev.com/ > >I got two including shipping to me for $60.oo total ! What do ya think for >the price. It's a very good price for this product. I would run capacity tests to make sure they're okay (there is some but a very small risk that 'surplus' inventory is also abused inventory). With this technology, odds are in your favor that they're an excellent buy. Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
From: "William Yamokoski" <yamokosk(at)lmc.cc.mi.us>
Subject: Noise Filter Questions
Hi Folks, I've admitted defeat in my hunt for radio noise, and am putting together one of Bob's noise filters. I'm using the Microair radio and Flightcom 430 intercom. I'm making an assumption that a good choice for the source of the noise is the essential bus to which both devices are independantly connected. I intend to place the filter between the bus and the devices, yellow wire connected to the bus as per Bob's diagrams. If the bus is the source of the noise, it will no doubt be effecting both the radio and the intercom. Can I feed both of these devices from one filter (which would result in both devices being connected to one fuse)or do I need a separate filter for each device? Is there anything to worry about re: physical location of the filter? Thanks for any ideas on this. Oh...one other question...if this filter doesn't help, can I get a volunteer to take me out back and shoot me? Thanks again. Bill Yamokoski, Glastar N4970Y have about 70 hours ________________________________________________________________________________
Date: Mar 26, 2003
Subject: alternator
The only problem we have with burning is the Mitsubishi alt. used on Ford Tempo, Taurus and Thunderbird. The other CS series GM and most other Ford alternators are all american made. The ND alternator is very dependable and generally lasts 100,000 to 150,000 miles. Steve Springfield Auto Parts Co., Inc. ________________________________________________________________________________
From: "Wendell & Jean Durr" <legacy147(at)cableone.net>
Subject: Re: RE: starter considerations with EFIS/one and FADEC
Date: Mar 26, 2003
I for one would be interested in Mr. Stucklen's ideas. ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: Noise Filter Questions
> > >Hi Folks, > I've admitted defeat in my hunt for radio noise, and am putting >together one of Bob's noise filters. I'm using the Microair radio and >Flightcom 430 intercom. I'm making an assumption that a good choice >for the source of the noise is the essential bus to which both devices >are independantly connected. I intend to place the filter between the >bus and the devices, yellow wire connected to the bus as per Bob's >diagrams. If the bus is the source of the noise, it will no doubt be >effecting both the radio and the intercom. Can I feed both of these >devices from one filter (which would result in both devices being >connected to one fuse)or do I need a separate filter for each device? >Is there anything to worry about re: physical location of the filter? >Thanks for any ideas on this. Oh...one other question...if this filter >doesn't help, can I get a volunteer to take me out back and shoot me? >Thanks again. >Bill Yamokoski, Glastar N4970Y have about 70 hours Have you determined that the noise is indeed coming into your affected systems via the 14v bus? What kind of noise are you hearing and what tests have you conducted to determine how it's getting into your radio? Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: Hot Little Torch
> > > I was in Radio Shack today and picked up one of their Mini Butane-Powered > Soldering Irons - #64-2188 - for $19.99. WOW what a neat tool! I highly > recommend getting one of these. I have no patience for waiting for a > soldering iron to warm up - I was using a full sized plumbers torch. That > worked fine for all but small items like the potentiometer on the light dimmer > (no longer a potentiometer) - but this torch is really slick. It comes with a > blow torch tip (which I plan to use) and then a soldering tip. The flame is > very small and has pin point accuracy - i'm impressed - go get one! > > > > Ditto. I bought one after almost being stranded 1500 NM from home with some wires needing solder. Just the thing for the traveling tool kit. Denis ________________________________________________________________________________
Date: Mar 26, 2003
Interesting, as my local junk yard research is the (not good) bin is full of ND alternators where the sliprings are worn out from external dirt. But then I was only looking for small frame alternator to consider. Perhaps its a local issue with dirt?? Paul > > > The only problem we have with burning is the Mitsubishi alt. used on Ford > Tempo, Taurus and Thunderbird. > The other CS series GM and most other Ford alternators are all american made. > The ND alternator is very dependable and generally lasts 100,000 to 150,000 > miles. > > Steve > Springfield Auto Parts Co., Inc. ________________________________________________________________________________
Subject: Fw: Wiring Diagram Questions
Date: Mar 26, 2003
----- Original Message ----- From: Rick Fogerson Subject: Fw: Wiring Diagram Questions Hi Bob, I sent this while you were gone so I'll try again. Rick Fogerson ----- Original Message ----- From: Rick Fogerson Subject: Wiring Diagram Questions Hi Bob, I'm finalizing my wiring diagram and getting ready to order starter, alternator, voltage reg, etc. from B&C. I noticed on Fig Z-11 that a 5A CB is wired between the Bat/Alt Mstr Sw and the Alternator Field terminal. As far as I can tell it is not on any other diagram. Is the CB necessary in my situation and/or under what conditions? I remember on the RV-6 wiring diagram you made for me back in 1996, I had two or three big yellow in-line fuse holders on the firewall among the contactor wires. Sorry, I don't remember exactly what wires, just a bunch of yellow holders in that area. I was just curious why I don't see any in lines on the present diagrams? Last question: B&C sells two push to start sw's. An S895-1 with bare terminals and according to B&C a 501-200-1 with soldiered wires, veristor across the terminals, and potted in back. I'm not familiar with the latter and wanted your opinion of it. Thanks, Rick Fogerson RV3 finish kit Boise, ID ________________________________________________________________________________
Date: Mar 26, 2003
Hi Bob, Thanks for the reply. I was sort of thinking that the filter might function as a very cheap diagnostic device if nothing else. If I insert in between the bus and the radio, and things improve, great. If they don't improve, I've learned something. With the engine off I hear something every time I throw a switch, from a low hum when turning on the gps to a very nice musical chirping when the strobes are turned on. With the engine running, I'm getting a rapid stocatto noise that varies in frequency with engine rpm. When I depress the PTT switch I hear the stocatto noise very loudly. People listening to my transmissions report hearing the same. If nav lights and strobes are off, the stocatto isn't always present, and is less loud when present. I hear others' transmission perfectly fine. I'm using a Subaru engine, which has a computer controlling it. I'm not sure if that can be part of this situation or not. So...can I run two devices off one filter :) Thanks again Bill Yamokoski ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Off Topic - cowl fasteners
Hello Im working to install my engine cowl and I got the Skybolt.com cowl installation kit (on sale now 30% off - and no I don't work for them). I cannot emphasize enough how much I would recommend this kit. I was not looking forward to the cowl at all with this kit it sounds easy. I cut the heck out of my engine baffles to allow my top cowl to fit nicely. I took off my exhaust system. Im going to get the top and bottom cowl to fit together nicely first This I can do on a workbench. Next I will fit the bottom onto the firewall and then the top it sure sounds easy with these fasteners. They certainly are not cheap but I am convinced the finished product will be significantly better. Piano hinge is for pianos. --------------------------------- ________________________________________________________________________________
Date: Mar 26, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Hinge pin/Radio interference
I have heard of situations where a rattling hinge pin can cause radio interference. Is this possible? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Mar 26, 2003
> > >Hi Bob, > Thanks for the reply. I was sort of thinking that the filter might >function as a very cheap diagnostic device if nothing else. If I >insert in between the bus and the radio, and things improve, great. If >they don't improve, I've learned something. Get a couple of 6v lantern batteries (Wallmart will sell you a battery AND a flashlight for less $ than a battery alone) to hook in series for 12v. Run first one, then other then both devices from battery and see what effect it has on your observed interference. IF the noise goes away, you may well be advised to add the filter . . . but I'm skeptical. > With the engine off I hear something every time I throw a switch, >from a low hum when turning on the gps to a very nice musical chirping >when the strobes are turned on. With the engine running, I'm getting a >rapid stocatto noise that varies in frequency with engine rpm. When I >depress the PTT switch I hear the stocatto noise very loudly. People >listening to my transmissions report hearing the same. If nav lights >and strobes are off, the stocatto isn't always present, and is less loud >when present. I hear others' transmission perfectly fine. It's very unusual for one to have such a combination and variety of antagonists. I'm suspecting something in system assembly and/or architecture. Let's do the battery test first. > I'm using a Subaru engine, which has a computer controlling it. >I'm not sure if that can be part of this situation or not. Could be a contributor . . . fuel injectors and fuel pumps have some degree of noise generating ability but the fact that you hear all these other things suggests a more basic problem. The vast majority of airplanes turn out noise free from the get-go if all the rudimentary rules are followed. Let's do some detective work before you break out hammers-n-saws . . . Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
> > > > > > > I was in Radio Shack today and picked up one of their Mini Butane-Powered > > Soldering Irons - #64-2188 - for $19.99. WOW what a neat tool! I highly > > recommend getting one of these. I have no patience for waiting for a > > soldering iron to warm up - I was using a full sized plumbers torch. That > > worked fine for all but small items like the potentiometer on the light > dimmer > > (no longer a potentiometer) - but this torch is really slick. It comes > with a > > blow torch tip (which I plan to use) and then a soldering tip. The > flame is > > very small and has pin point accuracy - i'm impressed - go get one! > > > > > > > > > >Ditto. I bought one after almost being stranded 1500 NM from home with some >wires needing solder. Just the thing for the traveling tool kit. got one in the toolbox at my desk at RAC . . . lets you do things a long way from ac power mains . . . Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: Fw: Wiring Diagram Questions
>Hi Bob, >I sent this while you were gone so I'll try again. >Rick Fogerson >----- Original Message ----- >From: Rick Fogerson >To: aeroelectric-list >Subject: Wiring Diagram Questions > > >Hi Bob, > >I'm finalizing my wiring diagram and getting ready to order starter, >alternator, voltage reg, etc. from B&C. > >I noticed on Fig Z-11 that a 5A CB is wired between the Bat/Alt Mstr Sw >and the Alternator Field terminal. As far as I can tell it is not on any >other diagram. Is the CB necessary in my situation and/or under what >conditions? A circuit breaker is shown for all alternator field/control circuits utilizing crowbar ov protection . . . the crowbar module's proper operation depends on the use of this breaker. It appears on all diagrams. A fuse could be used but since there are system situations that can nuisance trip the crowbar ov protection, this is the one circuit protective device that I recommend be in reach of the pilot. It shows on all of our suggested switch layouts at http://216.55.140.222/articles/switchpanel/swpanel.pdf >I remember on the RV-6 wiring diagram you made for me back in 1996, I had >two or three big yellow in-line fuse holders on the firewall among the >contactor wires. Sorry, I don't remember exactly what wires, just a bunch >of yellow holders in that area. I was just curious why I don't see any in >lines on the present diagrams? Those fuse holders were determined to be too fragile for use in airplanes. I ended up taking most of them back when the customer had problems with 'em. If you NEED a single, in-line fuse consider: http://www.aeroelectric.com/Catalog/ckrtprot/ckrtprot.html#ifh-2 >Last question: B&C sells two push to start sw's. An S895-1 with bare >terminals and according to B&C a 501-200-1 with soldiered wires, veristor >across the terminals, and potted in back. I'm not familiar with the >latter and wanted your opinion of it. Use the first one. It comes with no MOV installed. The MOV's turned out to be a bad idea . . . at least not as good as using a diode across the contactor. The part number with MOV installed is part of an STC'd kit that Bill sells. It should probably be modified but it's so much hassle . . . well, we've all heard that story before. Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: Hinge pin/Radio interference
><bilinski@kyocera-wireless.com> > >I have heard of situations where a rattling hinge pin can cause radio >interference. Is this possible? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 ANY relatively loose joint carrying a current can and will generate some degree of radio noise. Hinges, loose mounting brackets, etc. will do it. Now comes the issue of why does a hinge carry current? In some cases, p-static current is enough to be a detectable problem. I recall reading about a rudder hinge that only caused radio noise at night! Seems that white nav light bulb grounded through hinge which was right next to VOR antenna cat-whiskers on vertical fin cap. A few years ago, a popular myth circulated around the OBAM grapevine about putting bonding straps across all surface hinges on every airplane, including composites. Except for the obvious rudder nav light situation, I doubt the usefulness of this . . . but it sure doesn't hurt anything either. Keeps pink elephants away too . . . Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
Subject: Re: OV warning pin on LR3B-14
Bob, In a previous post you wrote: > It's sorta open collector . . . one of the requirements I had for > configuring the output stage was that the warning lamp should illuminate > IF power were entirely removed from the regulator. To get the output > transistor to turn on using only continuity between the bus and a > warning lamp, I put a resistor from collector to base to create a > level of artificial leakage . . . no problem with .08A lamps but > it will cause problems with LEDs . . . you need to add a pull up > resistor that mimics the current draw of an incandescent lamp. > Try adding 200 ohm, 1 watt resistor between terminals 5 (lamp) > and 3 (lv sense). This should pull up firmly on pin 5 when the > lamp should be off and swamp out the effects of the "leakage" > resistor inside. I understand what you said. However, I would like a little clarification. Like some others, I am using a low current indicator (LED like). Additionally, I would like to be able to test (monitor) my indicator(s) circuit. In order to test my indicator circuits, I plan to use an active low "push-to-test" switch that pulls the various indicator circuits low (0.7V) using diodes to isolate the individual circuits. So, the question comes up; Should I just simply view pin 5 of the LR3B as an NPN transistor with a base to collector resistor? Is there any high side leakage on pin 5? As such, should I assume, during a LV condition with the 200 ohm resistor installed as described above, that pin 5 will not pull all the way to ground if the voltage on pin 3 (OV_SENSE) goes to zero or very low? I've left out exact voltages. Because, I'd expect the value(s) to be dependent upon the transistor's gain and value of the internal collector to base resistor. I don't see any problem with the way LR3 works. It's excellent. I'm just trying to understand and anticipate what I need to make my stuff work properly. Is there any problem with my external indicator and monitoring circuit pulling pin 5 low (open collector low)? Will LR3 continue to "regulate" during such a condition? If things are the way I've tried to describe (clarify), I would think this to be O.K. BTW, I may be glad I found this post. Originally, I was going to feed pin 3 (OV_SENSE) through a 10K resistor. However, it sounds like this would be bad. A 10K resistor obviously won't work with the 200 ohm fix described above. Also, is pin 3 more than just a high impedance voltage sense? If so, how much current draw should I expect on this pin, even if it is only milliamps? The earlier thread was based upon the LR3B-14. Is the same true for the LR3C-14? ________________________________________________________________________________
Date: Mar 26, 2003
> > >Interesting, as my local junk yard research is the (not good) bin is full of >ND alternators where the sliprings are worn out from external dirt. But then >I was only looking for small frame alternator to consider. Perhaps its a >local issue with dirt?? > >Paul This is how I would expect this alternator to fail most often. In spite of small diameter slip rings (very low surface velocity under the brushes) I belive the slip rings are the most vulnerable feature of the design. It's an dry-running, sliding-parts-interface relatively open to operating atmosphere. If the rotors are balanced very carefully to favor bearing life at typical running speeds on a Lycoming, then the demonstrated service life of this alternator as a B&C product is understandable. Return rate on this alternator for reasons other than user induced damage is virtually non-existent. There must be a couple thousand in service since they were introduced at B&C about 12 years ago. (Dave in Wichita, do you ever recall seeing a return for wear-out or failure? I haven't talked with Bill about this issue for several years now . . . the answer was always the same. I'll ask him what the current record is next time I talk to him.) I think the B&C/ND service record stands head and shoulders above the service record of ANY brand alternator on ANY airplane . . . Bob . . . ________________________________________________________________________________
Subject: Re: ... and burnt alternators
Date: Mar 26, 2003
"We also see many burned alternators from cars. Mostly the the diode assy. and reg. in CS130 and CS144 series Delco. (late 1980's and up GM) The B lead connector burns up on the Ford int. reg. alternators quite often, including enough fire to melt other wiring that is close to the alt. Steve Springfield Auto Parts Co., Inc." The CS130 diode block life is so poor in auto service that I carry a spare alternator in the trunk. I now seem to be getting better life with the Transpo DR4000 diode block and a cooling air blast tube (from front of rad). To the lister who wrote that he must use this alternator on his aircraft, note that even though rated at 105 amps, the CS130 gets very hot at only 40 amps output. And, I've seen re-built CS130 alternators sold with a printed warning to never use this alternator with a low battery ... Mike ________________________________________________________________________________
Date: Mar 26, 2003
> >Bob, > >In a previous post you wrote: > > It's sorta open collector . . . one of the requirements I had for > > configuring the output stage was that the warning lamp should >illuminate > > IF power were entirely removed from the regulator. To get the output > > transistor to turn on using only continuity between the bus and a > > warning lamp, I put a resistor from collector to base to create a > > level of artificial leakage . . . no problem with .08A lamps but > > it will cause problems with LEDs . . . you need to add a pull up > > resistor that mimics the current draw of an incandescent lamp. > > Try adding 200 ohm, 1 watt resistor between terminals 5 (lamp) > > and 3 (lv sense). This should pull up firmly on pin 5 when the > > lamp should be off and swamp out the effects of the "leakage" > > resistor inside. > >I understand what you said. However, I would like a little >clarification. > >BTW, I may be glad I found this post. Originally, I was going to feed >pin 3 (OV_SENSE) through a 10K resistor. However, it sounds like this >would be bad. A 10K resistor obviously won't work with the 200 ohm fix >described above. Also, is pin 3 more than just a high impedance voltage >sense? If so, how much current draw should I expect on this pin, even if >it is only milliamps? > >The earlier thread was based upon the LR3B-14. Is the same true for the >LR3C-14? Yes, the lamp driver is the same throughout the product's evolution. But why are you hooking this lamp to a PTT circuit? LEDs never go bad and the light gets tested every preflight when you turn on the battery master. Testing the light as you've proposed only tests the light which is always going to be good . . . turning the alternator off will drop the bus voltage which should get you a warning light in a few seconds . . . this tests the entire LV warning system. Bob . . . ________________________________________________________________________________
Date: Mar 26, 2003
>> >>Bob, >> >>In a previous post you wrote: >> > It's sorta open collector . . . one of the requirements I had for >> > configuring the output stage was that the warning lamp should >>illuminate >> > IF power were entirely removed from the regulator. To get the output >> > transistor to turn on using only continuity between the bus and a >> > warning lamp, I put a resistor from collector to base to create a >> > level of artificial leakage . . . no problem with .08A lamps but >> > it will cause problems with LEDs . . . you need to add a pull up >> > resistor that mimics the current draw of an incandescent lamp. >> > Try adding 200 ohm, 1 watt resistor between terminals 5 (lamp) >> > and 3 (lv sense). This should pull up firmly on pin 5 when the >> > lamp should be off and swamp out the effects of the "leakage" >> > resistor inside. >> >>I understand what you said. However, I would like a little >>clarification. >> > > > > >>BTW, I may be glad I found this post. Originally, I was going to feed >>pin 3 (OV_SENSE) through a 10K resistor. However, it sounds like this >>would be bad. A 10K resistor obviously won't work with the 200 ohm fix >>described above. Also, is pin 3 more than just a high impedance voltage >>sense? If so, how much current draw should I expect on this pin, even if >>it is only milliamps? >> >>The earlier thread was based upon the LR3B-14. Is the same true for the >>LR3C-14? > > Yes, the lamp driver is the same throughout the product's > evolution. But why are you hooking this lamp to a PTT circuit? > LEDs never go bad and the light gets tested every preflight > when you turn on the battery master. Testing the light as you've > proposed only tests the light which is always going to be good > . . . turning the alternator off will drop the bus voltage > which should get you a warning light in a few seconds . . . > this tests the entire LV warning system. > > Bob . . . Yes, I'm aware that LEDs don't burn out and that such a circuit would only be testing the LV LED. (I'm an EE.) However, I do have my reasons for wanting to do this: 1) My annunciators is a cluster of Honeywell AML45 series indicators. In addition to main and aux bus LV warning, there are other items including gear status, motor status, crossfeed, etc. At least two of the circuits have relay circuits that get tested when the PTT is activated. Plus, a portion of the gear wiring gets tested, as well. I could just have the PTT light up only the LEDs that have "testable" circuits. But, from a user (pilot) standpoint, I feel it is better to have a PTT simply light up all indicators. Thus, the pilot does not have to stop and think... "Hum, engine is off.. therefore only this one, that one and that one should be on." Or, "Hum, engine is on... therefore this one, that one and not that one, etc.". I'm just trying to keep the operational chores simple. In other words, no thinking is required. Unless, one of the indicators does NOT light up. 2) My annunciators are also on a high side dimmer circuit that auto adjusts for ambient light. At the same time, you can adjust it manually, as well. Although, I'm tweaking the limit of dimming so they are still somewhat visible in daylight. In any case, I would like to have the PTT for allowing the pilot to verify the dimmer setting. The additional wiring and a few diodes is negligible. I don't see where practical reliability is compromised. A failure of any of the PTT circuits does not present any real hazard to the flight. Most of us are already accustomed to PTT. So, why not have the user interface light all indicators, not just the few that are really being tested beyond the LEDs. Plus, it's a reminder and method to check the warning light dimmer setting. Not necessarily related to the "test" circuit discussed above, but, What is the expected current draw on pin 3 (OV_Sense)? Howard ________________________________________________________________________________
Date: Mar 27, 2003
Bob wrote: > > I usually put a toggle switch next to the jack to flip > > between stereo and monaural operation. Mike wrote: > The instructions for a stereo intercom I use advises to simply leave mono headphone plugs one click out from fully inserted. The only 'down side', I've noticed is selection of OFF or 'radio' on the intercom (or intercom failure) then requires the mono headphone plug to be fully inserted. Another workable solution- thanks! After drawing up the circuit for using a switch as Bob suggests, it appears that not taking care to put the switch in the "stereo" position still allows one channel to short if a mono plug is fully inserted. What I have chosen to do is install both the "transfer circuit" mono jack and a stereo jack, with one of those little spring-loaded covers on the stereo jack labeled with an "S" as a "heads up" to prevent mono insertion. About the same cost/labor/parts count as the switch, but with the possible benefits of being less likely to insert the wrong plug, a bit simpler, and having a flush surface (no protruding toggle, although a slider or rocker switch could be used) Now if I could just decide where to drill these six little holes! Thanks again from The PossumWorks in TN - the A-list rocks! Mark Phillips > > ________________________________________________________________________________
Date: Mar 27, 2003
>Not necessarily related to the "test" circuit discussed above, but, What >is the expected current draw on pin 3 (OV_Sense)? > >Howard As I recall, the drive is capable of pulling down on a lamp rated at 100 mA or better. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
Thank you for your reply. Years ago I spent a lot of time looking for "My Ideal alternator". With an auto engine conversion a reliable electrical system is critical. My question on the ND sliprings was that other small alternators NOT from ND had little or no slipring wear and most had much larger diameter rings. It seems to me the major issue with alternators is application and physical location in autos plus the associated internal regulator that causes one brand and/or another to fail more than another. I understand the B&C ND alternators however have the regulator removed and along with better balance is the reason they are so reliable. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: alternator > > > > > > >Interesting, as my local junk yard research is the (not good) bin is full of > >ND alternators where the sliprings are worn out from external dirt. But then > >I was only looking for small frame alternator to consider. Perhaps its a > >local issue with dirt?? > > > >Paul > > This is how I would expect this alternator to fail most often. > In spite of small diameter slip rings (very low surface velocity > under the brushes) I belive the slip rings are the most > vulnerable feature of the design. It's an dry-running, > sliding-parts-interface relatively open to operating atmosphere. > > If the rotors are balanced very carefully to favor bearing > life at typical running speeds on a Lycoming, then the > demonstrated service life of this alternator as a B&C product > is understandable. > > Return rate on this alternator for reasons other than user > induced damage is virtually non-existent. There must be a couple > thousand in service since they were introduced at B&C about > 12 years ago. > > (Dave in Wichita, do you ever recall seeing a return for > wear-out or failure? I haven't talked with Bill about this > issue for several years now . . . the answer was always > the same. I'll ask him what the current record is next > time I talk to him.) > > I think the B&C/ND service record stands head and shoulders above > the service record of ANY brand alternator on ANY airplane . . . > > Bob . . . > > ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Subject: alternator
Date: Mar 27, 2003
> > (Dave in Wichita, do you ever recall seeing a return for > > wear-out or failure? I haven't talked with Bill about this > > issue for several years now . . . the answer was always > > the same. I'll ask him what the current record is next > > time I talk to him.) > > > > I think the B&C/ND service record stands head and shoulders above > > the service record of ANY brand alternator on ANY airplane . . . > > > > Bob . . . My recollection is that the numbers returned were very small. What the reasons were for the failures in all cases excapes my memory. It seems like we had one that we blamed on the regular high pressure washing by the owner. Dave in Wichita ________________________________________________________________________________
Date: Mar 27, 2003
Subject: alternator
> > > > > > (Dave in Wichita, do you ever recall seeing a return for > > > wear-out or failure? I haven't talked with Bill about this > > > issue for several years now . . . the answer was always > > > the same. I'll ask him what the current record is next > > > time I talk to him.) > > > > > > I think the B&C/ND service record stands head and shoulders above > > > the service record of ANY brand alternator on ANY airplane . . . > > > > > > Bob . . . > >My recollection is that the numbers returned were very small. What the >reasons were for the failures in all cases excapes my memory. It seems >like we had one that we blamed on the regular high pressure washing by >the owner. Yeah, I remember that one. I think he was the Canadian atmospheric research pilot flying a Long-Ez . . . not only did he like to keep things REALLY clean, he managed to mis-understand how the LR-3 works with the alternator and hosed it too. Wanted me to send him a schematic so he could 're-design it to eliminate obvious flaws' . . . I recall some coming back with b-lead terminals burned off due to inadequate security of the nut on the stud. One other I saw had some stator wiring damage from some external accident . . . But you're right, returns were rare and never involved wear-out or gross failure. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
Subject: Re: alternator
> > >Thank you for your reply. > >Years ago I spent a lot of time looking for "My Ideal alternator". With an >auto engine conversion a reliable electrical system is critical. > > My question on the ND sliprings was that other small alternators NOT from >ND had little or no slipring wear and most had much larger diameter rings. > >It seems to me the major issue with alternators is application and physical >location in autos plus the associated internal regulator that causes one >brand and/or another to fail more than another. > >I understand the B&C ND alternators however have the regulator removed and >along with better balance is the reason they are so reliable. Yes, B&C starts with brand new, factory fresh alternators. They open them up and remove the built in regulator. There's also a machining operation to accommodate a mechanical hurdle with making a solid modification to the brush wiring. Rotors are balanced and the whole thing is put back together with Loctite on the threaded fasteners. Service life has mostly to do with balance, re-assembly with attention to detail and robustness of ND's product. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
Subject: Re: lighting dimmers
>Bob, > >I am wiring my Rans with a Rotax 912 using your diagram on pg. Z-15 in the >aeroelectric connection. I have 8 internally lit automotive style engine >gauges, a stereo AM/FM CD player, a KY97 comm. and a KT76 xponder, all with >internal lights. I want to put an overhead flood for the flight instruments >and switches, etc. On page 11-17 you talk about using a 1-3 switch to share >a dimmer unit with two applications. Could I use the B&C dimmer assy. and >have one circuit on all of the aforementioned internal lights and a second >on an overhead flood? If it were my airplane, I think I'd put the panel lighting on a B&C dimmer and put the flood lighting on a single lamp dimmer like http://www.aeroelectric.com/Catalog/SDK-1.jpg and power it from the e-bus. What kind of flood lighting are you considering. LED or incandescent? How much current will it draw? You COULD do as you've suggested but I like the idea of totally independent systems powered from separate busses. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
Bob, What about bonding straps for IFR aircraft that have static wicks? Aren't these installed to protect against fusing the hinges in the case of a lightning strike? With the RV hinge style Heim joint hinge concept, there's not much electrical surface area between the control surface and the fuselage. Fred Stucklen RV-6A N926RV Reserved ANY relatively loose joint carrying a current can and will generate some degree of radio noise. Hinges, loose mounting brackets, etc. will do it. Now comes the issue of why does a hinge carry current? In some cases, p-static current is enough to be a detectable problem. I recall reading about a rudder hinge that only caused radio noise at night! Seems that white nav light bulb grounded through hinge which was right next to VOR antenna cat-whiskers on vertical fin cap. A few years ago, a popular myth circulated around the OBAM grapevine about putting bonding straps across all surface hinges on every airplane, including composites. Except for the obvious rudder nav light situation, I doubt the usefulness of this . . . but it sure doesn't hurt anything either. Keeps pink elephants away too . . . Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
> >Not necessarily related to the "test" circuit discussed above, but, What >>is the expected current draw on pin 3 (OV_Sense)? >> >>Howard > >As I recall, the drive is capable of pulling down >on a lamp rated at 100 mA or better. > >Bob . . . I think you mis-understood the question. This was the 2nd point (question) of the original post. This one is NOT about pin 5 (LAMP). I was asking about pin 3 (the pin also known as "OV_SENSE")? This is the so called SENSE pin. If you don't know the precise value, is the current draw on this pin in the order of microamps, milliamps, or amps? Or, what is the impedance of this input? In other words, disregarding the previously discussed 200 ohm resistor for a moment, is a very low current (<0.1ma) voltage reference adequate for this SENSE pin? Howard ________________________________________________________________________________
Date: Mar 27, 2003
Subject: alt. failures
Mike: You are right. The CS130 alt. are supplied in 85 to 105 amps. It's a small unit for so many amps. The rear bearings are sealed ball bearings that fail often from heat compared to the needle bearings used in the old SI series GM alt. It is recommended not to charge a low battery with the alt., because it causes it to put out max amps for an extended period of time. It therefore overheats the diodes and they fail. The alt. are designed to put back in what you used during starting and to run the vehicle and the accessories. The later GM vehicles use a ducted hose to the rear of the alt. to try to solve some of the overheating. They tend to fail in 40,000 to 60,000 miles. As far as the wear on the ND alt., the slip rings may be worn on some, but they still charge and seem to last two to three times longer than most but not all of the GM's. Steve Springfield Auto Parts Co., Inc. ________________________________________________________________________________
Subject: OVM Circuit Questions
Date: Mar 27, 2003
Bob, I intend to 'Roll my Own' Crowbar OVM. I have a question about the 500 ohm pot. Would it be possible to set this pot and then remove it from the circuit, measure the resistance and replace it with two resistors. I thought this might keep the circuit from drifting over time, due to vibration, heat cycles etc. I just don't know if there is something else that would cause this circuit to drift and necessitate re-calibration from time to time. P.S. I still intend to test the circuit at every condition inspection regardless. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ________________________________________________________________________________
Date: Mar 27, 2003
my floodlight plan is to use a flashlight - I do have the dimmer you mention - but why not run it off the e-bus as well. does it draw that much running the lights down low? I wouldn't think so. "Robert L. Nuckolls, III" wrote:--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" >Bob, > >I am wiring my Rans with a Rotax 912 using your diagram on pg. Z-15 in the >aeroelectric connection. I have 8 internally lit automotive style engine >gauges, a stereo AM/FM CD player, a KY97 comm. and a KT76 xponder, all with >internal lights. I want to put an overhead flood for the flight instruments >and switches, etc. On page 11-17 you talk about using a 1-3 switch to share >a dimmer unit with two applications. Could I use the B&C dimmer assy. and >have one circuit on all of the aforementioned internal lights and a second >on an overhead flood? If it were my airplane, I think I'd put the panel lighting on a B&C dimmer and put the flood lighting on a single lamp dimmer like http://www.aeroelectric.com/Catalog/SDK-1.jpg and power it from the e-bus. What kind of flood lighting are you considering. LED or incandescent? How much current will it draw? You COULD do as you've suggested but I like the idea of totally independent systems powered from separate busses. Bob . . . --------------------------------- ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Ray Allen stick grip wiring questions
Date: Mar 27, 2003
Hi all, Maybe those questions have already been addressed, so please pardon me. Question 1 : In Bob's schematics, the PTT wire is invariably twisted with the corresponding ground wire. In the four button Ray Allen stick grip instructions they show a common ground wire for the PTT wire and the four trim wires. That's one ground for five wires. What should I do ? Twist PTT wire and ground wire all the same ? But then what about the separate routing of the ground wire to the firewall ground bus ? Question 2 : Ray Allen provides 20 ft of 26 AWG wire for the six wires from the grip. Our kit manufacturer uses one multi-conductor shielded wire, the shield playing a role as one of the wires. What would be the best solution ? Thanks, Gilles ________________________________________________________________________________
Date: Mar 27, 2003
Subject: Re: OVM Circuit Questions
> > >Bob, > >I intend to 'Roll my Own' Crowbar OVM. I have a question about the 500 ohm >pot. Would it be possible to set this pot and then remove it from the >circuit, measure the resistance and replace it with two resistors. I >thought this might keep the circuit from drifting over time, due to >vibration, heat cycles etc. I just don't know if there is something else >that would cause this circuit to drift and necessitate re-calibration from >time to time. > >P.S. I still intend to test the circuit at every condition inspection >regardless. I've never had a problem with pots changing setting over time. If consider using multi-turn, screwdriver- adjust pot. These are VERY stable with time and environment. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
> > > > > >Not necessarily related to the "test" circuit discussed above, but, >What > >>is the expected current draw on pin 3 (OV_Sense)? > >> > >>Howard > > > >As I recall, the drive is capable of pulling down > >on a lamp rated at 100 mA or better. > > > >Bob . . . > >I think you mis-understood the question. This was the 2nd point >(question) of the original post. This one is NOT about pin 5 (LAMP). I >was asking about pin 3 (the pin also known as "OV_SENSE")? This is the >so called SENSE pin. If you don't know the precise value, is the current >draw on this pin in the order of microamps, milliamps, or amps? Or, what >is the impedance of this input? In other words, disregarding the >previously discussed 200 ohm resistor for a moment, is a very low >current (<0.1ma) voltage reference adequate for this SENSE pin? Oh, sorry. It's on the order of tens of milliamps but less than 100 as I recall. This pin powers regulator and ov sense electronics. It needs a separate, low impedance connection to the bus. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
> > > > Bob, > > What about bonding straps for IFR aircraft that have static >wicks? Aren't these installed to protect against fusing the hinges in the >case of a lightning strike? With the RV hinge style Heim joint hinge >concept, there's not much electrical surface area between the control >surface and the fuselage. Static wicks are useful only to dissipate p-static from the airplane with many, low-current bleed points each one too quiet to contribute to atmospheric noise in radios. They have no protective role to play in dealing with a lightning strike. Bond straps across hinges would mitigate the welding issue . . . Bob . . . ________________________________________________________________________________
Date: Mar 27, 2003
Subject: Building an E-Buss, Main Buss, fuse block assembly
- my idea Todays Good Idea: I"ve been stewing on how to make my e-buss and main buss and came up with a neat idea. If you are familiar with B&Cs ground blocks, the 24 fast-on tab ones well they have a small hole on one end which would fit right onto the stud on the 10 slot fuse block sold by B&C. The other end contains a large bolt. My plan is to mount the 10-slot fuse block vertically with the ground block on top again the small hole in the bottom of the ground block would go onto the #8 stud off the top of the 10-slot fuse block. The two rectangular pieces would each be mounted vertically tied together with the fuseblock stud. Now make two of these units and let one be the main buss and one be the e-buss. Mount them side by side on quarter inch white plastic board and just bolt the board to another board (you might use 1/8 inch white board here - this just insulates the through bolts which bolt the fast-on tab blocks to the white board from the fuselage) - then bolt it all to the next panel behind the instrument panel. Let the white board hang down below the bottom of this panel so the fuse blocks are a bit easier to get to. One of the vans guys once said he wished he had put a ground block behind the panel. With my plan I will have plenty of fast-on tabs available for any main buss needs, e-buss needs, fused needs, or ground needs all with easy access just behind the panel. Time to hit the sack hopefully I havent lost you here but it sure sounded like a great idea to me. --------------------------------- ________________________________________________________________________________
Date: Mar 28, 2003
Subject: kma 20/kx175
I have a strange problem with the com side of my radio. Perhaps someone on the list can help. When i tune in a com frequency on my #1 radio, (KX-175 mac1700 conversion) in the range of 118.30 to 119.75 I get playback of my voice through my overhead speaker when I don't have it selected on the kma 20. I use a David Clark headset with headsets, inc anc conversion and yoke mounted ptt. This creates a feedback situation that makes my transmissions difficult to hear on the receiving end. When I switch to my second radio, KX 170b with the same frequency, the playback through the speaker doesn't occur and everything is ok, except I have little or no side tone on that radio. This situation on the #1 com does not seem to occur when I tune in higher frequencies beginning in the 120's. Hopefully someone can give me some guidance before I consult with an avionics tech. Best, Mitch Berger ________________________________________________________________________________
Date: Mar 28, 2003
<5.0.0.25.2.20030327110307.01bdaca8(at)pop.central.cox.net> >Thank you , Bob. I think I will use the little "eyeball" cockpit lights (2 >of them) to flood the panel. A/C Spruce and some others carry them. They >are incandescent but I don't know the output. Okay. I think the combination of two eyeball lights may be on the same order of current draw as the single lamp in the one-lamp dimmer kit. So a separate, low cost dimmer control for your floods is feasible . . . the eyeball lights may draw LESS current which means we might need to put a resistor in parallel with the lamps to make them draw ENOUGH current to properly dim with the simple rheostat. So, if you want to go the separate dimmer route, there is a ready solution. If you want to switch two light sets to a single dimmer via switch, that's okay too. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: Building an E-Buss, Main Buss, fuse
block assembly - my idea > > >Todays Good Idea: > >I"ve been stewing on how to make my e-buss and main buss and came up with >a neat idea. > > >If you are familiar with B&Cs ground blocks, the 24 fast-on tab ones well >they have a small hole on one end which would fit right onto the stud on >the 10 slot fuse block sold by B&C. The other end contains a large bolt. > >My plan is to mount the 10-slot fuse block vertically with the ground >block on top again the small hole in the bottom of the ground block would >go onto the #8 stud off the top of the 10-slot fuse block. The two >rectangular pieces would each be mounted vertically tied together with >the fuseblock stud. > >Now make two of these units and let one be the main buss and one be the >e-buss. Mount them side by side on quarter inch white plastic board and >just bolt the board to another board (you might use 1/8 inch white board >here - this just insulates the through bolts which bolt the fast-on tab >blocks to the white board from the fuselage) - then bolt it all to the >next panel behind the instrument panel. Let the white board hang down >below the bottom of this panel so the fuse blocks are a bit easier to get to. > >One of the vans guys once said he wished he had put a ground block behind >the panel. With my plan I will have plenty of fast-on tabs available for >any main buss needs, e-buss needs, fused needs, or ground needs all with >easy access just behind the panel. > >Time to hit the sack hopefully I havent lost you here but it sure >sounded like a great idea to me. I'm lost . . . are you suggesting that the ground blocks be electrically tied to the buss-feed stud on fuse blocks? I'm mystified as to why you would want to do this. Each fuse block IS a bus . . . one fuse block for main bus, one for e-bus, perhaps another for the battery bus. The ground block is central to the whole electrical system and provides ground for virtually everything except a short list of items which can ground locally in ships with metal airframes. Ground blocks are not insulated from the airframe but in fact are tied to the firewall sheet. This is where all grounds come together including crankcase to firewall jumper and battery (-) leads. I don't understand what you are trying to achieve with the alternate configuration described. Bob . . . > > >--------------------------------- > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: kma 20/kx175
> >I have a strange problem with the com side of my >radio. Perhaps someone on the list can help. > >When i tune in a com frequency on my #1 radio, (KX-175 >mac1700 conversion) in the range of 118.30 to 119.75 I >get playback of my voice through my overhead speaker >when I don't have it selected on the kma 20. I use a >David Clark headset with headsets, inc anc conversion >and yoke mounted ptt. This creates a feedback >situation that makes my transmissions difficult to >hear on the receiving end. > >When I switch to my second radio, KX 170b with the >same frequency, the playback through the speaker >doesn't occur and everything is ok, except I have >little or no side tone on that radio. > >This situation on the #1 com does not seem to occur >when I tune in higher frequencies beginning in the >120's. > >Hopefully someone can give me some guidance before I >consult with an avionics tech. This sounds like a radio frequency interference problem. You may be radiating a lot of the problem transceiver's energy into the cockpit. Look for open antenna coax shield connections at both ends for that radio. If you can dummy-load the offending transceiver (dummy load is a combination of resistors designed to make the transmitter THINK it is hooked to a properly operating antenna while in fact, all of its output is being turned into heat), and the problem goes away, it is without a doubt related to degraded feedline or proximity of antenna and audio system is too close. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: Ray Allen stick grip wiring questions
><Gilles.Thesee@ac-grenoble.fr> > >Hi all, > >Maybe those questions have already been addressed, so please pardon me. > >Question 1 : >In Bob's schematics, the PTT wire is invariably twisted with the >corresponding ground wire. In the four button Ray Allen stick grip >instructions they show a common ground wire for the PTT wire and the four >trim wires. >That's one ground for five wires. What should I do ? Twist PTT wire and >ground wire all the same ? But then what about the separate routing of the >ground wire to the firewall ground bus ? I don't like to bundle grounds together . . . breaking one wire kills all associated functions . . . >Question 2 : >Ray Allen provides 20 ft of 26 AWG wire for the six wires from the grip. >Our kit manufacturer uses one multi-conductor shielded wire, the shield >playing a role as one of the wires. >What would be the best solution ? . . . either should be fine but 26 AWG is not a very robust wire for airframe wiring. We're doing the grand experiment with Premier in that some 24AWG wire is used in some bundles . . . up until now, 22AWG was the "smallest wire" rule. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
> > >my floodlight plan is to use a flashlight is it mounted for hand's free operation? > - I do have the dimmer you mention - but why not run it off the e-bus as > well. "E" stands for endurance. Most panel lighting installation draw MUCH more current than what is necessary to light the panel for en route conduct of flight. Further, one would do well to have TWO panel lighting schemes . . . one that wows the air-show judges and one that provides low current, minimal panel lighting for conducing e-bus operations. > does it draw that much running the lights down low? I wouldn't think so. It isn't so much a matter of getting current down as it is having two independent lighting systems. One wire coming loose from your end-all-be-all lighting system leaves you in the dark no matter which bus it's powered from. If the standby system is also very low power, then it's an excellent candidate for being powered by the e-bus. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: cooling fans
>My all-electric liquid-cooled V8 engine has 2 radiators with 20-amp fans, >similar to an auto. The fans are normally required only on the ground; for >extended taxi on really hot days and for 10 minutes after engine shutdown Do these fans really draw 20A or is that just the recommended fuse size? 40A of fans for 10 minutes works out to about 7 a.h. of capacity that needs to be dedicated to post flight cooling operations. > (it has a liquid-cooled turbocharger). I'm thinking of using 20 amp CB > switches for the fans. Wouldn't give you a $1 for a boatload of CB-Switches . . . but whatever floats your boat . . . > (I'm using fuse blocks wherever I can but the biggest plug-in fuse is 15 > amps). > I'd like to be able to (1) turn them on and off with the switch as required, > and (2) turn them on with a timer after shutdown. In cool weather, it might be that a fixed time is longer than necessary. Fans in cars are controlled with thermostats and only run as needed. This seems logical for airplanes too . . . > I have a dual batt, dual alt (120 amp and 20 amp) system. Any ideas for > wiring the fans? Get some REAL operating currents for the fans. I'm skeptical of the 20A figure. What size batteries are you prepared to carry? Why a 120A main alternator? Suggest you join the aeroelectric-list for the conduct of this and similar conversations. It's much better to share with everyone interested than to carry on a limited one-on-one discussion. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Audio Isolation Amplifier
I've spent about as much time on the audio isolation amp project as I can for the moment. Need to catch up on other commitments. In the mean time, folks who would like an advance look at the data package are invited to download . . . http://216.55.140.222/temp/Audio_Prelim.pdf . . . feedback on errors would be welcome. Should be able to put the whole instruction set together for publishing on the website next week. In the mean time, we're headed for the workbench to slave over a hot soldering iron . . . Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: Building an E-Buss, Main Buss, fuse block assembly
- my idea i'm using the fast-on tab ground block just as an extension of the buss on the fuse blocks - not using it as a ground block. This would give me plenty of hook ups for any other non fused power needs. But then I was think - it looks like i want most things fused, so maybe i should just run the wire from the master contactor straight to this main buss fuse block - what do you think?? I do like the idea of mounting it on the white plastic board - so the fuse blocks hang down - this would make it much easier to get at the fuses. This white board might also be a good spot to mount relays and dimmers sytem, etc. I made up a nice battery buss, I had not thought about fuses in that case - does the hour meter need a fuse? does a clock which needs power all the time need a fuse? sounds like I should change that bat. buss out for another fuseblock - what do you think? "Robert L. Nuckolls, III" wrote:--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > >Todays Good Idea: > >I"ve been stewing on how to make my e-buss and main buss and came up with >a neat idea. > > >If you are familiar with B&Cs ground blocks, the 24 fast-on tab ones well >they have a small hole on one end which would fit right onto the stud on >the 10 slot fuse block sold by B&C. The other end contains a large bolt. > >My plan is to mount the 10-slot fuse block vertically with the ground >block on top again the small hole in the bottom of the ground block would >go onto the #8 stud off the top of the 10-slot fuse block. The two >rectangular pieces would each be mounted vertically tied together with >the fuseblock stud. > >Now make two of these units and let one be the main buss and one be the >e-buss. Mount them side by side on quarter inch white plastic board and >just bolt the board to another board (you might use 1/8 inch white board >here - this just insulates the through bolts which bolt the fast-on tab >blocks to the white board from the fuselage) - then bolt it all to the >next panel behind the instrument panel. Let the white board hang down >below the bottom of this panel so the fuse blocks are a bit easier to get to. > >One of the vans guys once said he wished he had put a ground block behind >the panel. With my plan I will have plenty of fast-on tabs available for >any main buss needs, e-buss needs, fused needs, or ground needs all with >easy access just behind the panel. > >Time to hit the sack hopefully I havent lost you here but it sure >sounded like a great idea to me. I'm lost . . . are you suggesting that the ground blocks be electrically tied to the buss-feed stud on fuse blocks? I'm mystified as to why you would want to do this. Each fuse block IS a bus . . . one fuse block for main bus, one for e-bus, perhaps another for the battery bus. The ground block is central to the whole electrical system and provides ground for virtually everything except a short list of items which can ground locally in ships with metal airframes. Ground blocks are not insulated from the airframe but in fact are tied to the firewall sheet. This is where all grounds come together including crankcase to firewall jumper and battery (-) leads. I don't understand what you are trying to achieve with the alternate configuration described. Bob . . . > > >--------------------------------- > > Bob . . . |-------------------------------------------------------| | The man who does not read good books has no advantage | | over the man who cannot read them. | | - Mark Twain | |-------------------------------------------------------| --------------------------------- ________________________________________________________________________________
Subject: Brass hardware
Date: Mar 28, 2003
Bob, What is your experience with using brass studs for conducting electrical current? My question is about potential corrosion problems. Does the stud need to be plated or is unplated acceptable? Dave in Wichita ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Placing headset jacks
AeroElectric-List message posted by: Mark Phillips on placing headset jacks <<.....skip....Now if I could just decide where to drill these six little holes! ....skip...... Mark Phillips >> 3/28/2003 Hello Mark, After 44 years plus of plugging headsets plugs into a wide variety of locations I came to the conclusion that the best location for the pilot's headset jacks (in a side by side seating arrangement) was behind the copilots seat back and the best location for the copilots headset jacks was behind the pilots seatback. In sight and always reachable even when strapped in. No plugs to bump with your knee and no cords lying across your lap. 'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/? ________________________________________________________________________________
Date: Mar 28, 2003
block assembly - my idea > > >i'm using the fast-on tab ground block just as an extension of the buss on >the fuse blocks - not using it as a ground block. This would give me >plenty of hook ups for any other non fused power needs. Name any device you would even want to hook up that is not fused . . . > But then I was think - it looks like i want most things fused, so > maybe i should just run the wire from the master contactor straight to > this main buss fuse block - what do you think?? I do like the idea of > mounting it on the white plastic board - so the fuse blocks hang down - > this would make it much easier to get at the fuses. This white board > might also be a good spot to mount relays and dimmers sytem, etc. EVERYTHING that gets power from a bus uses some form of protection. In our published drawings, distribution from a bus is either via fuse, breaker or in rare cases, fusible links. > > >I made up a nice battery buss, I had not thought about fuses in that case >- does the hour meter need a fuse? does a clock which needs power all >the time need a fuse? sounds like I should change that bat. buss out for >another fuseblock - what do you think? EVERYTHING needs and should get protected . . . Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: Brass hardware
> > >Bob, > >What is your experience with using brass studs for conducting electrical >current? My question is about potential corrosion problems. Does the >stud need to be plated or is unplated acceptable? Haven't had much problem with corrosion . . . pressures at the mated surfaces are high and gas-tight or near gas tight. The studs on White-Rogers (old Stancor-RBM) contactors have always been copper. You may have a customer with a plating requirement for exposed copper alloys. I think Cutler-Hammer contactors have tin plated brass studs. Corrosion resistant materials have higher resistance and tend to be more of a problem than low resistance hardware that might corrode a bit. What's your application? Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
Subject: Re: Placing headset jacks
> >AeroElectric-List message posted by: Mark Phillips on >placing headset jacks > ><<.....skip....Now if I could just decide where to drill these six little >holes! > ....skip...... Mark Phillips >> > >3/28/2003 > >Hello Mark, After 44 years plus of plugging headsets plugs into a wide >variety of locations I came to the conclusion that the best location for the >pilot's headset jacks (in a side by side seating arrangement) was behind the >copilots seat back and the best location for the copilots headset jacks was >behind the pilots seatback. In sight and always reachable even when strapped >in. No plugs to bump with your knee and no cords lying across your lap. Agreed. I was going to suggest above, behind and outboard of the seat. I put some intercom systems in C-150s and moved the mic-headset jacks to small boxes behind the seats. Cords were always out of the way. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2003
- my idea I would certainly think that a booster fuel pump would want a circuit breaker - rather than a fuse - am I right on this one? How about an electric attitude indicator - what's the point of a fuse the pilot cannot replace in flight. The attitude indicator is an important item in IFR - isn't it possible for it to start to fail and cause a surge in power (one which might blow a fuse), but then it keeps running? I know it's not essential for completion of the flight, but I certainly would prefer to have it -and if a fuse blows - i'm absolutely not going to have the item work. Wouldn't this also be the case with my electric turn coordinator?? I don't have my diagrams in front of me right now, but it seems like all of the items on the e-buss would be better suited to ciruit breaker protection rather than a fuse you cannot change in flight? "Robert L. Nuckolls, III" wrote:--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > >i'm using the fast-on tab ground block just as an extension of the buss on >the fuse blocks - not using it as a ground block. This would give me >plenty of hook ups for any other non fused power needs. Name any device you would even want to hook up that is not fused . . . > But then I was think - it looks like i want most things fused, so > maybe i should just run the wire from the master contactor straight to > this main buss fuse block - what do you think?? I do like the idea of > mounting it on the white plastic board - so the fuse blocks hang down - > this would make it much easier to get at the fuses. This white board > might also be a good spot to mount relays and dimmers sytem, etc. EVERYTHING that gets power from a bus uses some form of protection. In our published drawings, distribution from a bus is either via fuse, breaker or in rare cases, fusible links. > > >I made up a nice battery buss, I had not thought about fuses in that case >- does the hour meter need a fuse? does a clock which needs power all >the time need a fuse? sounds like I should change that bat. buss out for >another fuseblock - what do you think? EVERYTHING needs and should get protected . . . Bob . . . --------------------------------- ________________________________________________________________________________
Date: Mar 28, 2003
> >Bob, > > > >What is your experience with using brass studs for conducting electrical > >current? My question is about potential corrosion problems. Does the > >stud need to be plated or is unplated acceptable? > > Haven't had much problem with corrosion . . . pressures > at the mated surfaces are high and gas-tight or near gas > tight. The studs on White-Rogers (old Stancor-RBM) contactors > have always been copper. You may have a customer with > a plating requirement for exposed copper alloys. I think > Cutler-Hammer contactors have tin plated brass studs. > > Corrosion resistant materials have higher resistance > and tend to be more of a problem than low resistance > hardware that might corrode a bit. What's your > application? > > Bob . . .
March 17, 2003 - March 28, 2003
AeroElectric-Archive.digest.vol-bu
