AeroElectric-Archive.digest.vol-by
April 24, 2003 - May 06, 2003
      >     once . . . after talking to my favorite suppliers it
      >     didn't take long to recover my senses.
      >     Bob . . .
Subject:
Date: Apr 24, 2003
04/24/2003 01:02:13 PM Thanks bob, I've sent you an order via your online ordering page. Terry <<<<<<<<<<<<<<,, snip >>>>>>>>>>> My price on this radio is $270 in either the ni-cad or alkaline battery pack version. My personal favorite is the alkaline battery pack . . . I pitched the rechargeable pack for mine a year ago. Can have one shipped direct to you from the distributor yet this week. Bob . . . ************************************************************************* *****************Confidentiality Notice:****************************** ************************************************************************* The information contained in this e-mail message, including any attachments, is intended only for use of the individual or entity named above (addressee). This e-mail may contain information that is privileged, confidential and/or otherwise exempt from disclosure under applicable law. If the reader of this message is not the intended recipient, any disclosure, dissemination, distribution, copying or other use of the communication or its substance is prohibited. If you have received this e-mail in error, please reply to this e-mail indicating you are not the intended recipient and immediately destroy all copies of this e-mail. Receipt by anyone other than the intended recipient is not a waiver of any privileged information. ********************************************************************************** *eSafe scanned this email for viruses, vandals and malicious content* ********************************************************************************** ________________________________________________________________________________
Subject: Belt tension
Date: Apr 24, 2003
I talked to Bill, but didn't really find out a lot. He readily admits he's no expert when it comes to belt tension. What he did know was that he has yet to see one of the front bearings fail in the ND alternator, so that is at least encouraging. He went on to say that he had a consultant from Gates do the calculations when he had it done, and didn't recall much about it. He did recall the bearing was a NSK sealed ball bearing, 46mm OD, 15mm ID, 14mm thick. Any other insight from anyone? Any automotive engineers our there? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: ALT questions > > >Bob, in your alternator design, what belt tension do you recommend? >What belt tension will the bearings tolerate in your alternator? > >I ask because my alternator is belt driven along with my supercharger >from a large pulley behind the spinner on the front of the engine. The >supercharger sits on one side (copilot) and the alternator on the other >(pilot). The pulley is 12", and the belt is 10 rib. See attached pic. >There is an idler/tensioner pulley on each side (see pic). > >What is a good way to calculate the belt tension of this setup and to >figure out if I will alternator bearing problems? The tensioner/idler >pulley is "pulled up tight" by use of a 10-32 screw that screws into a >tapped hole in the very top of the bracket that holds the >tensioner/idler pulley. This screw pushes against the top (of the 2) >bolt that secures the tensioner/idler assembly. This bolt is torqued to >45in-pounds. The belt feels sorta loose, looks like normal automotive >belt tension. Does the force on this bolt/screw directly correspond to >the tension on the belt, so 45in-pounds? Or is it 90 in-pounds as there >are 2 tensioners? > >This late in the day my force diagrams from physics are escaping my >grasp. > >Thanks for the help. Bill Bainbridge would be better for this question. Give him a call at 316.283.8000 and let us know what he says . . . Bob . . . ________________________________________________________________________________
Date: Apr 24, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: Aircraft antenna VS Hand held antenna
If a hand held will pick up the VOR 50 miles out with its own antenna,will there be a improvement inistance if the hand held is hooked up to the aircraft antenna? Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Apr 24, 2003
Subject: Re: Belt tension
Shannon, I've done some work with other kinds of Gates belts (not v-belts). Gates puts excellent information in the technical pages of their belt catalogs, best in the business. Might check their website for pdf versions. Dan ________________________________________________________________________________
Date: Apr 24, 2003
I'm not an automotive engineer but I know how to find things. Try http://www.cptbelts.com/pdf/catalogs/vbelt_all.pdf and go to page 290 to the section titled "V-BELT TENSIONING" to find how to determine the correct tension for your application. See especially Figure 26 on p. 292 for an easy method. Best regards, Rob Housman Europa XS Tri-Gear A070 Airfarame complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Shannon Knoepflein Subject: AeroElectric-List: Belt tension I talked to Bill, but didn't really find out a lot. He readily admits he's no expert when it comes to belt tension. What he did know was that he has yet to see one of the front bearings fail in the ND alternator, so that is at least encouraging. He went on to say that he had a consultant from Gates do the calculations when he had it done, and didn't recall much about it. He did recall the bearing was a NSK sealed ball bearing, 46mm OD, 15mm ID, 14mm thick. Any other insight from anyone? Any automotive engineers our there? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: ALT questions > > >Bob, in your alternator design, what belt tension do you recommend? >What belt tension will the bearings tolerate in your alternator? > >I ask because my alternator is belt driven along with my supercharger >from a large pulley behind the spinner on the front of the engine. The >supercharger sits on one side (copilot) and the alternator on the other >(pilot). The pulley is 12", and the belt is 10 rib. See attached pic. >There is an idler/tensioner pulley on each side (see pic). > >What is a good way to calculate the belt tension of this setup and to >figure out if I will alternator bearing problems? The tensioner/idler >pulley is "pulled up tight" by use of a 10-32 screw that screws into a >tapped hole in the very top of the bracket that holds the >tensioner/idler pulley. This screw pushes against the top (of the 2) >bolt that secures the tensioner/idler assembly. This bolt is torqued to >45in-pounds. The belt feels sorta loose, looks like normal automotive >belt tension. Does the force on this bolt/screw directly correspond to >the tension on the belt, so 45in-pounds? Or is it 90 in-pounds as there >are 2 tensioners? > >This late in the day my force diagrams from physics are escaping my >grasp. > >Thanks for the help. Bill Bainbridge would be better for this question. Give him a call at 316.283.8000 and let us know what he says . . . Bob . . . ________________________________________________________________________________
Date: Apr 24, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Aircraft antenna VS Hand held antenna
><bilinski@kyocera-wireless.com> > >If a hand held will pick up the VOR 50 miles out with its own antenna,will >there be a improvement inistance if the hand held is hooked up to the >aircraft antenna? > > >Scott Bilinski >Eng dept 305 >Phone (858) 657-2536 >Pager (858) 502-5190 > Any antenna will pick up or talk to a facility that it can "see" . . . I've used hand helds in passenger aircraft and experienced amazing performance . . . elevating your antenna to 30K feet can overcome some pretty huge deficiencies in antenna location and capabilities. A rubber duck inside a fuselage is at a disadvantage, especially in high wing all metal light planes. Bubble canopy aircraft are friendlier and especially the glass and plastic variety. But a rubber-duck is a POOR antenna compared with any full sized antenna, especially one mounted on outside of the airframe. If you plan to use a hand held as a "backup" and you want more that to call the tower 5 miles out, then make provisions for hooking it to an external antenna. Bob . . . ________________________________________________________________________________
From: "Dave O'Donnell" <daveodonnell(at)direcway.com>
Date: Apr 24, 2003
Some empirical comments regarding belt tension. My Archer II came with the air conditioner initially. This means that the alternator used the small v-belts (NOT GOOD). I learned the hard way that high tension on the ground would result in a broken belt as the LARGE aluminum pulley on the prop got hot and expanded. Sometimes I would find broken belt strands before failure. Aluminum has a high thermal expansion coefficient. Modern belts do not, do not stretch like the ones of old. If over tightened they tend to break. Non-believers should check tension in the summer after some ramp time, let that big pulley get hot! We all check cold before starting. Tension too loose and the belt would twist in a higher speed descent (short length exposed to intake cooling air) become damaged and break. This got real old fast. Tried everything, what worked was removing the air-con, replacing the alternator pulleys, & belt with the standard size. The std (large) size belt is stiffer, will tolerate the high speed air and it can be run loose enough that expansion of the large pulley on the prop will not result in a broken belt. Truth is, this larger belt would likely bend brackets before breaking. If the belt contact arc (in terms of angle) on the alternator is large the need for tension to achieve drive is greatly diminished. Never have I had a problem with inadequate drive on the alternator. I run the std belt rather loose given my experience. This will directly result in lower bearing loads. Hope some of this helps. Regards Dave O -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Shannon Knoepflein Subject: AeroElectric-List: Belt tension I talked to Bill, but didn't really find out a lot. He readily admits he's no expert when it comes to belt tension. What he did know was that he has yet to see one of the front bearings fail in the ND alternator, so that is at least encouraging. He went on to say that he had a consultant from Gates do the calculations when he had it done, and didn't recall much about it. He did recall the bearing was a NSK sealed ball bearing, 46mm OD, 15mm ID, 14mm thick. Any other insight from anyone? Any automotive engineers our there? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: ALT questions > > >Bob, in your alternator design, what belt tension do you recommend? >What belt tension will the bearings tolerate in your alternator? > >I ask because my alternator is belt driven along with my supercharger >from a large pulley behind the spinner on the front of the engine. The >supercharger sits on one side (copilot) and the alternator on the other >(pilot). The pulley is 12", and the belt is 10 rib. See attached pic. >There is an idler/tensioner pulley on each side (see pic). > >What is a good way to calculate the belt tension of this setup and to >figure out if I will alternator bearing problems? The tensioner/idler >pulley is "pulled up tight" by use of a 10-32 screw that screws into a >tapped hole in the very top of the bracket that holds the >tensioner/idler pulley. This screw pushes against the top (of the 2) >bolt that secures the tensioner/idler assembly. This bolt is torqued to >45in-pounds. The belt feels sorta loose, looks like normal automotive >belt tension. Does the force on this bolt/screw directly correspond to >the tension on the belt, so 45in-pounds? Or is it 90 in-pounds as there >are 2 tensioners? > >This late in the day my force diagrams from physics are escaping my >grasp. > >Thanks for the help. Bill Bainbridge would be better for this question. Give him a call at 316.283.8000 and let us know what he says . . . Bob . . . ________________________________________________________________________________
Date: Apr 24, 2003
Problem is if I let it run too loose, the belt will slip and the supercharger (and alternator) won't turn, which means no power :( (well, less power anyway) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave O'Donnell Subject: RE: AeroElectric-List: Belt tension Some empirical comments regarding belt tension. My Archer II came with the air conditioner initially. This means that the alternator used the small v-belts (NOT GOOD). I learned the hard way that high tension on the ground would result in a broken belt as the LARGE aluminum pulley on the prop got hot and expanded. Sometimes I would find broken belt strands before failure. Aluminum has a high thermal expansion coefficient. Modern belts do not, do not stretch like the ones of old. If over tightened they tend to break. Non-believers should check tension in the summer after some ramp time, let that big pulley get hot! We all check cold before starting. Tension too loose and the belt would twist in a higher speed descent (short length exposed to intake cooling air) become damaged and break. This got real old fast. Tried everything, what worked was removing the air-con, replacing the alternator pulleys, & belt with the standard size. The std (large) size belt is stiffer, will tolerate the high speed air and it can be run loose enough that expansion of the large pulley on the prop will not result in a broken belt. Truth is, this larger belt would likely bend brackets before breaking. If the belt contact arc (in terms of angle) on the alternator is large the need for tension to achieve drive is greatly diminished. Never have I had a problem with inadequate drive on the alternator. I run the std belt rather loose given my experience. This will directly result in lower bearing loads. Hope some of this helps. Regards Dave O -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Shannon Knoepflein Subject: AeroElectric-List: Belt tension I talked to Bill, but didn't really find out a lot. He readily admits he's no expert when it comes to belt tension. What he did know was that he has yet to see one of the front bearings fail in the ND alternator, so that is at least encouraging. He went on to say that he had a consultant from Gates do the calculations when he had it done, and didn't recall much about it. He did recall the bearing was a NSK sealed ball bearing, 46mm OD, 15mm ID, 14mm thick. Any other insight from anyone? Any automotive engineers our there? --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: ALT questions > > >Bob, in your alternator design, what belt tension do you recommend? >What belt tension will the bearings tolerate in your alternator? > >I ask because my alternator is belt driven along with my supercharger >from a large pulley behind the spinner on the front of the engine. The >supercharger sits on one side (copilot) and the alternator on the other >(pilot). The pulley is 12", and the belt is 10 rib. See attached pic. >There is an idler/tensioner pulley on each side (see pic). > >What is a good way to calculate the belt tension of this setup and to >figure out if I will alternator bearing problems? The tensioner/idler >pulley is "pulled up tight" by use of a 10-32 screw that screws into a >tapped hole in the very top of the bracket that holds the >tensioner/idler pulley. This screw pushes against the top (of the 2) >bolt that secures the tensioner/idler assembly. This bolt is torqued to >45in-pounds. The belt feels sorta loose, looks like normal automotive >belt tension. Does the force on this bolt/screw directly correspond to >the tension on the belt, so 45in-pounds? Or is it 90 in-pounds as there >are 2 tensioners? > >This late in the day my force diagrams from physics are escaping my >grasp. > >Thanks for the help. Bill Bainbridge would be better for this question. Give him a call at 316.283.8000 and let us know what he says . . . Bob . . . ________________________________________________________________________________
Subject: Re: Yaesu Aviator Pilot
Date: Apr 24, 2003
At the risk of being confirmed a know-it-not, I seem to recall that the VOR CDI works by detecting the phase between two signals broadcast from the VOR station; 10 degrees phase difference 10 degrees off track. Being able to detect 1 degree of phase error reliably in a quiet environment is a pretty impressive thing ( particularly back in the mid-20th century when this system was invented ) and requires that both the transmitter and receiver conditions be stable for it to work. I wonder if the reason that you can't get a stable signal is because the antenna isn't locked down. Moving the antenna around might change the received phase relationships radically and unpredictably. Have you tried the CDI with the radio hooked in to the plane's VOR antenna, or with the radio duct-taped to the canopy? If it still doesn't work after that, well...have any ICOM portable owners out there had similar problems? Shaun Simpkins ________________________________________________________________________________
Subject: 'Way off topic
Date: Apr 24, 2003
Cheers, Excuse this one off-topic message, but the frustration over SARS here is monstrous. First of all, SARS was imported to Toronto by two travellers from Hong Kong - it did not originate here, nor is there any "outbreak"...... EVERY person connected with these two has been traced and either quarantined as 'suspect' for the requisite 10 days, or hospitalised and treated or released as clear. Of the 7000 people thus affected, 15 or so have died - none under 60 years old or suffering immunity deficiency. All the rest are either absolved of any infection or never were touched by it. All other transmission is by unsuspecting health workers on the job, traced and treated. The incubation period for SARS is 10 days for aperson, 24 hours for an infected surface. ALL this has been pioneered here. There has not been a new infectee for over a week. In Australia, the claim that a Canadian infected a family there has been proven false. The other claim of infection overseas was not a Canadian. Singapore has done a super job in containing its infestation but only by some Draconian measures (by our standards). The abject harm that The WHO has done by including the pioneer city in the contamination of whole provinces of China is proving to be about 12 million dollars a day damage to the city. that will be billions by the time it retracts its asinine warning. The only people seen wearing masks here are either precious dilletantes (those who were too cowardly to fly on 12SEP01) or health workers enroute. If you are looking for terror, watch one billion people over the Pacific. This event is like watching idiots panic when someone shouts "Fire Extinguisher!" There, I can sleep now. ferg Europa A064 ________________________________________________________________________________
From: "ivorphillips" <ivor(at)ivorphillips.flyer.co.uk>
Date: Apr 25, 2003
I brought the Icon A23 from OSH last year expressly for the VOR backup facility, it worked fine on the ground around oskosh but on my first flight in a europa tracking towards Dover VOR I was unable to get a stable signal until about 10 miles out at 3000 ft, On my own Europa I am at present fitting Bob archers wingtip VOR antenna which I am hoping will resolve the problem, Until my plane is flying I cant give a definite answer on the Icom except as a transceiver it is excellent. Ivor phillips europa XS and still building ----- Original Message ----- From: "Shaun Simpkins" <shauns(at)hevanet.com> Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > At the risk of being confirmed a know-it-not, > I seem to recall that the VOR CDI works by detecting the > phase between two signals broadcast from the VOR station; > 10 degrees phase difference 10 degrees off track. Being > able to detect 1 degree of phase error reliably in a quiet > environment is a pretty impressive thing ( particularly back > in the mid-20th century when this system was invented ) > and requires that both the transmitter and receiver conditions > be stable for it to work. > > I wonder if the reason that you can't get a stable signal is > because the antenna isn't locked down. Moving the antenna > around might change the received phase relationships radically > and unpredictably. Have you tried the CDI with the radio hooked > in to the plane's VOR antenna, or with the radio duct-taped to > the canopy? > > If it still doesn't work after that, well...have any ICOM portable > owners out there had similar problems? > > Shaun Simpkins > > ________________________________________________________________________________
Subject: Re: Firewall connector
Date: Apr 25, 2003
> > electrical signal wires, I was hoping to use a mile spec C5015 subtype K > > circular > > bulkhead and mating plug connector for 18 16ga wires. I finally found a > > local stocking distributor here in the former home of several major > > military aircraft manufacturers (Long Island). > > But wait: over $300 for a single mating pair, not including any > > accessories. > > Wow... > > > > Does anyone have any idea about more reasonable sources for firewall > > connectors the AMP CPC (circular plastic connector?) is a plastic copy of the mil spec bendix-type connector and uses the same mil pins. I believe the plastic has a pretty high temp rating. cost is $2-3 and they come in a large variety of sizes. Don't let the price fool you, they work very well and you can get o-rings and strain relief accessories. I think they also accept regular D-sub pins but the mil pins are worth the extra money. They're available from most electrical catalogs (allied, digikey, newark). They're so cheap I got extra ones for test connectors and temporary wire harnesses. A nice way to make a modular system. Of course, the fewer connectors the better for reliability, but in the right places they help in regards to maintainability and upgrades. gary k ________________________________________________________________________________
Date: Apr 25, 2003
> > > > electrical signal wires, I was hoping to use a mile spec C5015 subtype K > > > circular > > > bulkhead and mating plug connector for 18 16ga wires. I finally found a > > > local stocking distributor here in the former home of several major > > > military aircraft manufacturers (Long Island). > > > But wait: over $300 for a single mating pair, not including any > > > accessories. > > > Wow... > > > > > > Does anyone have any idea about more reasonable sources for firewall > > > connectors > >the AMP CPC (circular plastic connector?) is a plastic copy of the mil spec >bendix-type connector and uses the same mil pins. I believe the plastic has >a pretty high temp rating. cost is $2-3 and they come in a large variety of >sizes. Don't let the price fool you, they work very well and you can get >o-rings and strain relief accessories. I think they also accept regular >D-sub pins but the mil pins are worth the extra money. They're available >from most electrical catalogs (allied, digikey, newark). They're so cheap I >got extra ones for test connectors and temporary wire harnesses. A nice way >to make a modular system. Of course, the fewer connectors the better for >reliability, but in the right places they help in regards to maintainability >and upgrades. . . . and should NEVER be used to take wires through a firewall. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 25, 2003
> > >I brought the Icon A23 from OSH last year expressly for the VOR backup >facility, it worked fine on the ground around oskosh but on my first flight >in a europa tracking towards Dover VOR I was unable to get a stable signal >until about 10 miles out at 3000 ft, typical performance for the rubber duck antenna . . . >On my own Europa I am at present fitting Bob archers wingtip VOR antenna >which I am hoping will resolve the problem, >Until my plane is flying I cant give a definite answer on the Icom except >as a transceiver it is excellent. you will see a marked improvement in performance on a full size, external antenna. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2003
In a message dated 04/24/2003 10:55:12 PM Eastern Daylight Time, shauns(at)hevanet.com writes: > I wonder if the reason that you can't get a stable signal is > because the antenna isn't locked down. Moving the antenna > around might change the received phase relationships radically > and unpredictably. Have you tried the CDI with the radio hooked > in to the plane's VOR My experience with the King KX-99 years ago sugests that the problem lies with Yaesu/Vertex engineering and not with the concept of a portable receiver in a noisy environment. This is both surprising and disappointing, since in my ham experience, the Yaesu FT-23R is one of the best handheld FM HT designs ever produced, and is my personal favorite over anything that Kenwood or Icom were offering in its day... Bill B ________________________________________________________________________________
Date: Apr 25, 2003
Ron Triano Quicker one Q-200, 90% Done with 90% to go -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Re: Firewall connector > > > > electrical signal wires, I was hoping to use a mile spec C5015 subtype K > > > circular > > > bulkhead and mating plug connector for 18 16ga wires. I finally found a > > > local stocking distributor here in the former home of several major > > > military aircraft manufacturers (Long Island). > > > But wait: over $300 for a single mating pair, not including any > > > accessories. > > > Wow... > > > > > > Does anyone have any idea about more reasonable sources for firewall > > > connectors > >the AMP CPC (circular plastic connector?) is a plastic copy of the mil spec >bendix-type connector and uses the same mil pins. I believe the plastic has >a pretty high temp rating. cost is $2-3 and they come in a large variety of >sizes. Don't let the price fool you, they work very well and you can get >o-rings and strain relief accessories. I think they also accept regular >D-sub pins but the mil pins are worth the extra money. They're available >from most electrical catalogs (allied, digikey, newark). They're so cheap I >got extra ones for test connectors and temporary wire harnesses. A nice way >to make a modular system. Of course, the fewer connectors the better for >reliability, but in the right places they help in regards to maintainability >and upgrades. . . . and should NEVER be used to take wires through a firewall. Bob . . . Before I would say NEVER, I would like to see some spec on this connector, Don't just not use it because it is plastic, or fibreglass as some have a much better fire ratings than most other materials. Just look at what happened to the space shuttle when a piece broke off. Maybe Bob's never is some electrical reason? Still using my stainless tube with a welded flange and fire caulking. Ron Triano -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 25, 2003
From: Dan&Patty Krueger <pndkrueg(at)infionline.net>
Adolf Wenning , "aeroelectric-list(at)matronics.com" , Al Marretta , Ann & Grey Jewett
Subject: [Fwd: credit reporting info]
From: "Betty Enfinger" <bettyenfinger(at)cox.net> "Larry Spikes" , "Francis Enfinger" , "Mark at Home" < enfinger(at)tampabay.rr.com>, "Lisa Jones" , "Vivian Faircloth" , "Susan Madden" , "Rosie Taylor" , "Prentiss Frazier" , "Patty Krueger" , "Pat Ready" , "Nancy Gressler" , "Marilyn at Work" , "Linda Tillery" , "Jody Webb" , "Joan Highsmith" , "Jill McMahon" , "Helen Gibson" , "Gloria Dawson" , "Gary Wilson" , "Fred Schwenk" , "Carmen Jones" < carmen.jones(at)amsouth.com>, "Barbara Paulin" , "Barbara Allison Hurlbutt" Subject: credit reporting info Date: Tue, 22 Apr 2003 18:26:21 -0500 To All, Very important...Please read... Your Credit: Personal Information goes public Starting July 1st, 2003, the four major credit bureaus in the US (Equifax, Experian, Trans Union, etc.) will be allowed to release credit info, mailing addresses, phone numbers, etc., to ANYONE who requests it. If you do not want to be included in this release of your personal information, you can call 1-888-567-8688. Once the message starts you will want option #2 (even though option #1 refers to this email, push #2) and then option #3. Be sure to listen closely, the first option is only for a two-year period. Make sure you! wait until they prompt for the third option, which opts you out FOREVER. You should receive their paperwork in the mail confirming the "opting out" in less than one week after making the call. PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. Here is the web site: http://www.pirg.org/consumer/credit/bureaus.htm To All, Very important...Please read... Your Credit: Personal Information goes public Starting July 1st, 2003, the four major credit bureaus in the US (Equifax, Experian, Trans Union,etc.) will be allowed to release credit info, mailing addresses, phone numbers, etc., to ANYONE who requests it. If you do not want to be included in this release of your personal information, you can call 1-888-567-8688. Once the message starts you will want option #2 (even though option #1 refers to this email, push #2) and then option #3. Be sure to listen closely, the first option is only for a two-year period. Make sure you! wait until they prompt for the third option, which opts you out FOREVER. You should receive their paperwork in the mail confirmingthe "opting out" in less than one week after making the call. PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. Here is the web site: http://www.pirg.org/consumer/credit/bureaus.htm ________________________________________________________________________________
Date: Apr 25, 2003
In a message dated 04/25/2003 11:05:47 AM Eastern Daylight Time, SportAV8R(at)aol.com writes: > My experience with the King KX-99 years ago sugests that the problem lies > with Yaesu/Vertex engineering Let me add to my own post by saying that the King handheld would read the exact reciprocal of the VOR heading if the bus voltage in my RANS was not reduced to about 12.6 volts by the addition of some series dropping diodes of the 1N4004 variety. I discovered this quirk by accident comparing readings on a familiar VOR using battery vs. ship's mains power, before I ever tried to navigate far from home with it - fortunately! Drop the voltage down to what the KX-99 wanted to see, and SHAZAAM!, the radial display changed 180 degrees to the correct one. -Bill ________________________________________________________________________________
Subject: [Fwd: credit reporting info] HOAX
Date: Apr 25, 2003
THIS IS A HOAX...DO NOT CALL...HERE'S SOME MORE INFO ON IT.. While the phone number and it's purpose are legitimate, the rest of the message is not. The message was started early in 2001 and was the result of someone mixing up two different situations. In 2001, because of implementation of the Gramm-Leach-Bliley Act (also known as the Financial Services Modernization Act) the banking, insurance, and securities industries are now allowed to sell customer information just as the credit bureaus ALREADY did. Congress added a provision to the act requiring that all financial service companies send privacy notices providing a "reasonable opportunity" to opt out of this information-sharing to all their customers by July 1, 2001. The credit bureaus have been able to sell this information, however, they do not and cannot sell any of your information, including your social security number, to "anyone who requests it" as the message says. Under the Fair Credit Reporting Act of 1997, businesses seeking to obtain personal information from credit bureaus must have a "permissible purpose" in order to access credit reports. (Permissible purposes include checking the backgrounds of persons to determine their creditworthiness before selling or renting property to them, extending them loans or credit, or considering them for employment.) This restriction remains in force, it did not change on July 1, and it still applies whether or not you call the number listed. Like I said, someone just managed to mix the two issues up last year, and the information is old anyway. Harley >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >> Dan&Patty Krueger >> Sent: Friday, April 25, 2003 11:38 AM >> To: Martha Beck; Adolf Wenning; aeroelectric-list(at)matronics.com; Al >> Marretta; Ann & Grey Jewett >> Subject: AeroElectric-List: [Fwd: credit reporting info] >> >> >> >> >> >> From: "Betty Enfinger" <bettyenfinger(at)cox.net> >> To: "Mark Snyder" , >> "Larry Spikes" , >> "Francis Enfinger" , >> "Mark at Home" < enfinger(at)tampabay.rr.com>, >> "Lisa Jones" , >> "Vivian Faircloth" , >> "Susan Madden" , >> "Rosie Taylor" , >> "Prentiss Frazier" , >> "Patty Krueger" , >> "Pat Ready" , >> "Nancy Gressler" , >> "Marilyn at Work" , >> "Linda Tillery" , >> "Jody Webb" , >> "Joan Highsmith" , >> "Jill McMahon" , >> "Helen Gibson" , >> "Gloria Dawson" , >> "Gary Wilson" , >> "Fred Schwenk" , >> "Carmen Jones" < carmen.jones(at)amsouth.com>, >> "Barbara Paulin" , >> "Barbara Allison Hurlbutt" >> Subject: credit reporting info >> Date: Tue, 22 Apr 2003 18:26:21 -0500 >> >> >> To All, >> Very important...Please read... >> >> Your Credit: Personal Information goes public Starting July 1st, 2003, >> the four major credit bureaus in the US (Equifax, Experian, Trans Union, >> etc.) will be allowed to release credit info, mailing addresses, phone >> numbers, etc., to ANYONE who requests it. If you do not want to >> be included >> in this release of your personal information, you can call >> 1-888-567-8688. >> Once the message starts you will want option #2 (even though option #1 >> refers to this email, push #2) and then option #3. >> >> Be sure to listen closely, the first option is only for a >> two-year period. >> Make sure you! wait until they prompt for the third option, which opts >> you out FOREVER. You should receive their paperwork in the mail >> confirming >> the "opting out" in less than one week after making the call. >> >> PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. >> >> Here is the web site:
http://www.pirg.org/consumer/credit/bureaus.htm >> >> >> >> >> To All, >> Very important...Please read... >> >> Your Credit: Personal >> Information goes public Starting July 1st, 2003, >> the four major credit >> bureaus in the US (Equifax, Experian, Trans Union,etc.) will be >> allowed to >> release credit info, mailing addresses, phone numbers, etc., to >> ANYONE who >> requests it. If you do not want to be included in this release of your >> personal information, you can call 1-888-567-8688. Once the >> message starts >> you will want option #2 (even though option #1 refers to this >> email, push #2) >> and then option #3. >> >> Be sure to listen closely, the first option is only for a two-year >> period. >> Make sure you! wait until they prompt for the third option, which >> opts >> you out FOREVER. You should receive their paperwork in the mail >> confirmingthe "opting out" in less than one week after making the >> call. >> >> PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND >> FAMILY. >> >> Here is the web site: > href"http://www.pirg.org/consumer/credit/bureaus.htm">http://www. >> pirg.org/consumer/credit/bureaus.htm >> >> >> >> >> >> >> ________________________________________________________________________________
Subject: [Fwd: credit reporting info] HOAX ALERT!!!
Date: Apr 25, 2003
This is a HOAX.. For details go to
http://police2.ucr.edu/hoax.html Best regards, Rob Housman Europa XS Tri-Gear A070 Airfarame complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dan&Patty Krueger Marretta; Ann & Grey Jewett Subject: AeroElectric-List: [Fwd: credit reporting info] From: "Betty Enfinger" <bettyenfinger(at)cox.net> "Larry Spikes" , "Francis Enfinger" , "Mark at Home" < enfinger(at)tampabay.rr.com>, "Lisa Jones" , "Vivian Faircloth" , "Susan Madden" , "Rosie Taylor" , "Prentiss Frazier" , "Patty Krueger" , "Pat Ready" , "Nancy Gressler" , "Marilyn at Work" , "Linda Tillery" , "Jody Webb" , "Joan Highsmith" , "Jill McMahon" , "Helen Gibson" , "Gloria Dawson" , "Gary Wilson" , "Fred Schwenk" , "Carmen Jones" < carmen.jones(at)amsouth.com>, "Barbara Paulin" , "Barbara Allison Hurlbutt" Subject: credit reporting info Date: Tue, 22 Apr 2003 18:26:21 -0500 To All, Very important...Please read... Your Credit: Personal Information goes public Starting July 1st, 2003, the four major credit bureaus in the US (Equifax, Experian, Trans Union, etc.) will be allowed to release credit info, mailing addresses, phone numbers, etc., to ANYONE who requests it. If you do not want to be included in this release of your personal information, you can call 1-888-567-8688. Once the message starts you will want option #2 (even though option #1 refers to this email, push #2) and then option #3. Be sure to listen closely, the first option is only for a two-year period. Make sure you! wait until they prompt for the third option, which opts you out FOREVER. You should receive their paperwork in the mail confirming the "opting out" in less than one week after making the call. PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. Here is the web site: http://www.pirg.org/consumer/credit/bureaus.htm To All, Very important...Please read... Your Credit: Personal Information goes public Starting July 1st, 2003, the four major credit bureaus in the US (Equifax, Experian, Trans Union,etc.) will be allowed to release credit info, mailing addresses, phone numbers, etc., to ANYONE who requests it. If you do not want to be included in this release of your personal information, you can call 1-888-567-8688. Once the message starts you will want option #2 (even though option #1 refers to this email, push #2) and then option #3. Be sure to listen closely, the first option is only for a two-year period. Make sure you! wait until they prompt for the third option, which opts you out FOREVER. You should receive their paperwork in the mail confirmingthe "opting out" in less than one week after making the call. PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. Here is the web site: http://www.pirg.org/co nsumer/credit/bureaus.htm ________________________________________________________________________________
"Adolf Wenning" , "Al Marretta" , "Ann & Grey Jewett"
Subject: Re: [Fwd: credit reporting info]
Date: Apr 25, 2003
This be a hoax ----- Original Message ----- From: "Dan&Patty Krueger" <pndkrueg(at)infionline.net> ; ; "Al Marretta" ; "Ann & Grey Jewett" Subject: AeroElectric-List: [Fwd: credit reporting info] > > > From: "Betty Enfinger" <bettyenfinger(at)cox.net> > To: "Mark Snyder" , > "Larry Spikes" , > "Francis Enfinger" , > "Mark at Home" < enfinger(at)tampabay.rr.com>, > "Lisa Jones" , > "Vivian Faircloth" , > "Susan Madden" , > "Rosie Taylor" , > "Prentiss Frazier" , > "Patty Krueger" , > "Pat Ready" , > "Nancy Gressler" , > "Marilyn at Work" , > "Linda Tillery" , > "Jody Webb" , > "Joan Highsmith" , > "Jill McMahon" , > "Helen Gibson" , > "Gloria Dawson" , > "Gary Wilson" , > "Fred Schwenk" , > "Carmen Jones" < carmen.jones(at)amsouth.com>, > "Barbara Paulin" , > "Barbara Allison Hurlbutt" > Subject: credit reporting info > Date: Tue, 22 Apr 2003 18:26:21 -0500 > > > To All, > Very important...Please read... > > Your Credit: Personal Information goes public Starting July 1st, 2003, > the four major credit bureaus in the US (Equifax, Experian, Trans Union, > etc.) will be allowed to release credit info, mailing addresses, phone > numbers, etc., to ANYONE who requests it. If you do not want to be included > in this release of your personal information, you can call 1-888-567-8688. > Once the message starts you will want option #2 (even though option #1 > refers to this email, push #2) and then option #3. > > Be sure to listen closely, the first option is only for a two-year period. > Make sure you! wait until they prompt for the third option, which opts > you out FOREVER. You should receive their paperwork in the mail confirming > the "opting out" in less than one week after making the call. > > PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. > > Here is the web site:
http://www.pirg.org/consumer/credit/bureaus.htm > > > > > To All, > Very important...Please read... > > Your Credit: Personal > Information goes public Starting July 1st, 2003, > the four major credit > bureaus in the US (Equifax, Experian, Trans Union,etc.) will be allowed to > release credit info, mailing addresses, phone numbers, etc., to ANYONE who > requests it. If you do not want to be included in this release of your > personal information, you can call 1-888-567-8688. Once the message starts > you will want option #2 (even though option #1 refers to this email, push #2) > and then option #3. > > Be sure to listen closely, the first option is only for a two-year > period. > Make sure you! wait until they prompt for the third option, which > opts > you out FOREVER. You should receive their paperwork in the mail > confirmingthe "opting out" in less than one week after making the > call. > > PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND > FAMILY. > > Here is the web site: href"http://www.pirg.org/consumer/credit/bureaus.htm">http://www.pirg.org/co nsumer/credit/bureaus.htm > > ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Subject: Re: [Fwd: credit reporting info] HOAX ALERT!!!
Date: Apr 25, 2003
Those who are so stupid gullible that they believe a breathless announcement that comes as an email that you MUST do this or that to avoid some catastrophe, deserve exactly what they get... Why are we wasting our time on OT crap trying to protect the stupid from themselves? Denny ----- Original Message ----- From: "Rob Housman" <
RobH@hyperion-ef.com> Subject: RE: AeroElectric-List: [Fwd: credit reporting info] HOAX ALERT!!! <RobH@hyperion-ef.com> > > This is a HOAX.. For details go to http://police2.ucr.edu/hoax.html > > > Best regards, > > Rob Housman > Europa XS Tri-Gear A070 > Airfarame complete > Irvine, CA > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dan&Patty > Krueger > To: Martha Beck; Adolf Wenning; aeroelectric-list(at)matronics.com; Al > Marretta; Ann & Grey Jewett > Subject: AeroElectric-List: [Fwd: credit reporting info] > > > > > From: "Betty Enfinger" <bettyenfinger(at)cox.net> > To: "Mark Snyder" , > "Larry Spikes" , > "Francis Enfinger" , > "Mark at Home" < enfinger(at)tampabay.rr.com>, > "Lisa Jones" , > "Vivian Faircloth" , > "Susan Madden" , > "Rosie Taylor" , > "Prentiss Frazier" , > "Patty Krueger" , > "Pat Ready" , > "Nancy Gressler" , > "Marilyn at Work" , > "Linda Tillery" , > "Jody Webb" , > "Joan Highsmith" , > "Jill McMahon" , > "Helen Gibson" , > "Gloria Dawson" , > "Gary Wilson" , > "Fred Schwenk" , > "Carmen Jones" < carmen.jones(at)amsouth.com>, > "Barbara Paulin" , > "Barbara Allison Hurlbutt" > Subject: credit reporting info > Date: Tue, 22 Apr 2003 18:26:21 -0500 > > > To All, > Very important...Please read... > > Your Credit: Personal Information goes public Starting July 1st, 2003, > the four major credit bureaus in the US (Equifax, Experian, Trans Union, > etc.) will be allowed to release credit info, mailing addresses, phone > numbers, etc., to ANYONE who requests it. If you do not want to be included > in this release of your personal information, you can call 1-888-567-8688. > Once the message starts you will want option #2 (even though option #1 > refers to this email, push #2) and then option #3. > > Be sure to listen closely, the first option is only for a two-year period. > Make sure you! wait until they prompt for the third option, which opts > you out FOREVER. You should receive their paperwork in the mail confirming > the "opting out" in less than one week after making the call. > > PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND FAMILY. > > Here is the web site: http://www.pirg.org/consumer/credit/bureaus.htm > > > > > To All, > Very important...Please read... > > Your Credit: Personal > Information goes public Starting July 1st, 2003, > the four major credit > bureaus in the US (Equifax, Experian, Trans Union,etc.) will be allowed to > release credit info, mailing addresses, phone numbers, etc., to ANYONE who > requests it. If you do not want to be included in this release of your > personal information, you can call 1-888-567-8688. Once the message starts > you will want option #2 (even though option #1 refers to this email, push > #2) > and then option #3. > > Be sure to listen closely, the first option is only for a two-year > period. > Make sure you! wait until they prompt for the third option, which > opts > you out FOREVER. You should receive their paperwork in the mail > confirmingthe "opting out" in less than one week after making the > call. > > PASS THIS MESSAGE ON TO ALL IN YOUR ADDRESS BOOK, FRIENDS AND > FAMILY. > > Here is the web site: href"http://www.pirg.org/consumer/credit/bureaus.htm">http://www.pirg.org/co > nsumer/credit/bureaus.htm > > ________________________________________________________________________________
Date: Apr 25, 2003
Where is a picture of Bob Archers Wingtip VOR antenna... I can't see to find it searching the internet. Jeff ----- Original Message ----- From: "ivorphillips" <ivor(at)ivorphillips.flyer.co.uk> Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > I brought the Icon A23 from OSH last year expressly for the VOR backup > facility, it worked fine on the ground around oskosh but on my first flight > in a europa tracking towards Dover VOR I was unable to get a stable signal > until about 10 miles out at 3000 ft, > On my own Europa I am at present fitting Bob archers wingtip VOR antenna > which I am hoping will resolve the problem, > Until my plane is flying I cant give a definite answer on the Icom except > as a transceiver it is excellent. > > Ivor phillips > europa XS and still building > ----- Original Message ----- > From: "Shaun Simpkins" <shauns(at)hevanet.com> > To: > Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > > > > > > At the risk of being confirmed a know-it-not, > > I seem to recall that the VOR CDI works by detecting the > > phase between two signals broadcast from the VOR station; > > 10 degrees phase difference 10 degrees off track. Being > > able to detect 1 degree of phase error reliably in a quiet > > environment is a pretty impressive thing ( particularly back > > in the mid-20th century when this system was invented ) > > and requires that both the transmitter and receiver conditions > > be stable for it to work. > > > > I wonder if the reason that you can't get a stable signal is > > because the antenna isn't locked down. Moving the antenna > > around might change the received phase relationships radically > > and unpredictably. Have you tried the CDI with the radio hooked > > in to the plane's VOR antenna, or with the radio duct-taped to > > the canopy? > > > > If it still doesn't work after that, well...have any ICOM portable > > owners out there had similar problems? > > > > Shaun Simpkins > > > > > > ________________________________________________________________________________
Date: Apr 25, 2003
Subject: Bob Archers Wingtip VOR antenna
Is this what you are looking for?
http://home.hiwaay.net/~sbuc/journal/sportcraft.htm --- Jeffrey wrote: > --> AeroElectric-List message posted by: "Jeffrey" > > Where is a picture of Bob Archers Wingtip VOR antenna... I can't see to find > it searching the internet. > > Jeff > > > Post your free ad now! http://personals.yahoo.ca ________________________________________________________________________________
Date: Apr 25, 2003
I have a picture of it in my construction photos. Go the the F1 Project page, and then go to the final bullet under "wings". It may or may not be what you are looking for, but it shows how I installed the antenna in my wingtip. Randy F1 Rocket http://mywebpages.comcast.net/f1rocket/ ----- Original Message ----- From: Jeffrey <dump(at)relaypoint.net> Date: Friday, April 25, 2003 1:02 pm Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > Where is a picture of Bob Archers Wingtip VOR antenna... I can't > see to find > it searching the internet. > > Jeff > > ----- Original Message ----- > From: "ivorphillips" <ivor(at)ivorphillips.flyer.co.uk> > To: > Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > > > > > > I brought the Icon A23 from OSH last year expressly for the VOR > backup> facility, it worked fine on the ground around oskosh but > on my first > flight > > in a europa tracking towards Dover VOR I was unable to get a > stable signal > > until about 10 miles out at 3000 ft, > > On my own Europa I am at present fitting Bob archers wingtip VOR > antenna> which I am hoping will resolve the problem, > > Until my plane is flying I cant give a definite answer on the > Icom except > > as a transceiver it is excellent. > > > > Ivor phillips > > europa XS and still building > > ----- Original Message ----- > > From: "Shaun Simpkins" <shauns(at)hevanet.com> > > To: > > Subject: Re: AeroElectric-List: Yaesu Aviator Pilot > > > > > > > > > > > > At the risk of being confirmed a know-it-not, > > > I seem to recall that the VOR CDI works by detecting the > > > phase between two signals broadcast from the VOR station; > > > 10 degrees phase difference 10 degrees off track. Being > > > able to detect 1 degree of phase error reliably in a quiet > > > environment is a pretty impressive thing ( particularly back > > > in the mid-20th century when this system was invented ) > > > and requires that both the transmitter and receiver conditions > > > be stable for it to work. > > > > > > I wonder if the reason that you can't get a stable signal is > > > because the antenna isn't locked down. Moving the antenna > > > around might change the received phase relationships radically > > > and unpredictably. Have you tried the CDI with the radio hooked > > > in to the plane's VOR antenna, or with the radio duct-taped to > > > the canopy? > > > > > > If it still doesn't work after that, well...have any ICOM portable > > > owners out there had similar problems? > > > > > > Shaun Simpkins > > > > > > > > > > > > > _- > ======================================================================_- = - The AeroElectric-List Email Forum - > _- > ======================================================================_- = !! NEWish !! > _- > ======================================================================_- = List Related Information > _- > ====================================================================== > > > > ________________________________________________________________________________
Date: Apr 25, 2003
Thanks for your helpful note, Denny. It certainly emphasizes the need for the Delete button. I'm sure we'll all carefully consider your advice the next time you post a note to this list. Bill > > Those who are so stupid gullible that they believe a breathless announcement > that comes as an email that you MUST do this or that to avoid some > catastrophe, deserve exactly what they get... > Why are we wasting our time on OT crap trying to protect the stupid from > themselves? > > Denny ________________________________________________________________________________
Subject: Shunt-parallelled alternators?
Date: Apr 25, 2003
I came across an interesting article the other day: http://www.kellyaerospace.com/articles/VoltageReg.pdf This article shows an aircraft electrical system that's quite different than Bob's diagrams, and I wonder if Bob or others would care to comment. Specifically: 1. The article shows a single electrical bus fed by two alternators. (no essential bus) 2. The article promotes a type of regulator which permits load balancing through a current-sensing circuit in each alternator output and a feedback mechanism that allows the regulators to balance their current outputs. They call this shunt-parallelling and contrast it to field-parallelling, in which no current-sensing is done. 3. Why is this type of regulator and electrical system design desirable? It appears to be most relevant to twin engine aircraft... 4. This seems like an another way of providing automatic system redundancy, with multiple power sources feeding the same bus. If one alternator goes, it can be taken off line, but a reconfiguration of the system isn't necessary to keep operating. An essential bus could be provided, but the Z-14 style electrical system with manual crossfeeds and separated load/power groups would appear to be unnecessary. Just another rumination on trying to achieve a near-zero pilot intervention redundant electrical system, like Cirrus'... Shaun ________________________________________________________________________________
Date: Apr 25, 2003
> >to make a modular system. Of course, the fewer connectors the better for > >reliability, but in the right places they help in regards to >maintainability > >and upgrades. > > . . . and should NEVER be used to take wires through a firewall. > > Bob . . . > > Before I would say NEVER, I would like to see some spec > on this > connector, Don't just not use it because it is plastic, or > fibreglass as some have a much better fire ratings than > most other > materials. Just look at what happened to the space > shuttle when a > piece broke off. Maybe Bob's never is some electrical > reason? Still > using my stainless tube with a welded flange and fire > caulking. > > Ron Triano The CPC connector housings are UL 94V-0 stabilized, heat resistant thermoplastic. This is the fire safety specification for most of the insulating materials used in commercial electronics. Do a websearch on "UL 94V-0" and you'll get tens of thousands of hits. It's been awhile since I looked up the spec but as I recall, the test says it won't sustain combustion on its own and when it melts out of a fueled flame, the dripping matter is not also flaming. The specification says only that this material will not exacerbate a fire, it says nothing about maintaining shape or strength while subjected to fire. Operating temperature ratings of thermoplastics top out about 150 degrees C. They wouldn't last but a minute or two in the fuel-fed flame tests required of all fire wall penetration techniques qualified for use on certified aircraft. Therefore I would say NEVER use these or any other plastic material in a way that might compromise firewall performance unless the manufacturer specifically states that his product has been tested for firewall service. To date, I am aware of no plastic that would qualify and UL 94V-0 is certainly not one of them. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2003
> >Where is a picture of Bob Archers Wingtip VOR antenna... I can't see to find >it searching the internet. > >Jeff http://home.hiwaay.net/~sbuc/journal/sportcraft.htm Bob . . . ________________________________________________________________________________
Subject: Re: Shunt-parallelled alternators?
Date: Apr 25, 2003
This is fine if either alternator in the system is capable of handling full system loads. The beauty of Bob's Endurance buss architecture is that with the flip of a couple of switches you shed all the non-essential electrical loads, without having to think about it. This simplifies a situation that could tend to be stressful. If you lose the primary alternator flip these two switches on and that one off. The load shedding procedure does not have to be written on a checklist because it was designed into the system. The alternative would be that if you lose the primary alternator you would have to turn off all the circuits that you don't need until you get the system to a point where the secondary alternator could keep up. Obviously if either alternator could handle the load then this is a non-issue. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "Shaun Simpkins" <shauns(at)hevanet.com> Subject: AeroElectric-List: Shunt-parallelled alternators? > > I came across an interesting article the other day: > http://www.kellyaerospace.com/articles/VoltageReg.pdf > > This article shows an aircraft electrical system that's quite > different than Bob's diagrams, and I wonder if Bob or others > would care to comment. Specifically: > > 1. The article shows a single electrical bus fed by two alternators. > (no essential bus) > > 2. The article promotes a type of regulator which permits load > balancing through a current-sensing circuit in each alternator > output and a feedback mechanism that allows the regulators > to balance their current outputs. They call this shunt-parallelling > and contrast it to field-parallelling, in which no current-sensing > is done. > > 3. Why is this type of regulator and electrical system design > desirable? It appears to be most relevant to twin engine aircraft... > > 4. This seems like an another way of providing automatic system > redundancy, with multiple power sources feeding the same bus. > If one alternator goes, it can be taken off line, but a reconfiguration of the > system isn't necessary to keep operating. An essential bus > could be provided, but the Z-14 style electrical system with > manual crossfeeds and separated load/power groups would > appear to be unnecessary. > > Just another rumination on trying to achieve a near-zero pilot intervention > redundant electrical system, like Cirrus'... > > Shaun > > ________________________________________________________________________________
Date: Apr 25, 2003
Subject: Comm VS VOR antenna
Comm and VOR antennas are the same right? If the above is correct, would a internal wing tip VOR antenna work better than a VOR/COMM antenna on the belly? Will the VOR internal wing tip antenna work as a COM antenna also? The reason I am asking is that I want to add another antenna for my hand held which will be used mainly for VOR's and secondary as a back up radio. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Apr 25, 2003
> >I came across an interesting article the other day: > http://www.kellyaerospace.com/articles/VoltageReg.pdf > >This article shows an aircraft electrical system that's quite >different than Bob's diagrams, and I wonder if Bob or others >would care to comment. Specifically: > >1. The article shows a single electrical bus fed by two alternators. > (no essential bus) > >2. The article promotes a type of regulator which permits load > balancing through a current-sensing circuit in each alternator > output and a feedback mechanism that allows the regulators > to balance their current outputs. They call this shunt-parallelling > and contrast it to field-parallelling, in which no current-sensing > is done. >3. Why is this type of regulator and electrical system design > desirable? It appears to be most relevant to twin engine aircraft... Yup, it's a Band-Aid on a sorry design that has been flying around in most light twins for 50+ years, first with generators and more recently with alternators using regulators specifically designed for paralleling. I did a design for a regulator paralleling accessory while employed at Electro-Mech more years ago than I care to figure out right now. It too monitored the shunt voltage of each alternator load-meter and tweaked the input to one regulator (slave) to make it track the other (master). This sytem was proposed for the light twins and C-337 at Cessna. We even fiddled with a brass-board of the same system at B&C about ten years ago (remember that one Dave?). Turns out that if you're going to have two alternators, there are far better architectures that allow each to operate independently at what it does best and not irritate a pilot because, "the right alternator is carrying more load than the left one." >4. This seems like an another way of providing automatic system > redundancy, with multiple power sources feeding the same bus. > If one alternator goes, it can be taken off line, but a > reconfiguration of the > system isn't necessary to keep operating. An essential bus > could be provided, but the Z-14 style electrical system with > manual crossfeeds and separated load/power groups would > appear to be unnecessary. But you still have one battery and one battery contactor. Loss of the contactor puts the whole system at risk unless the alternators have been specifically characterized for no-battery operation. >Just another rumination on trying to achieve a near-zero pilot intervention >redundant electrical system, like Cirrus'... I belive Cirrus uses the SD-20 and the standby version of the regulator that goes with it. That system is described in page 17-12 of the 'Connection and illustrated Figure 17-8. I didn't include this option in the Z-drawings because I consider this system to be a Band-Aid that could be pasted into an existing system essentially carved in stone. B&C has a fist full of STC'd kits to put just such a patch on perhaps a dozen airplanes. The Kelly ad promotes a reasonable thing to do to an old airplane that doesn't cost a bizillion dollars. We can do better with our OBAM ships. Bob . . . ________________________________________________________________________________
Date: Apr 25, 2003
Go for it, Bill... ----- Original Message ----- From: "Bill Steer" <bsteer(at)gwi.net> Subject: Re: AeroElectric-List: [Fwd: credit reporting info] HOAX ALERT!!! > > Thanks for your helpful note, Denny. It certainly emphasizes the need for the > Delete button. I'm sure we'll all carefully consider your advice the next time > you post a note to this list. > > Bill > > > > > > > Those who are so stupid gullible that they believe a breathless announcement > > that comes as an email that you MUST do this or that to avoid some > > catastrophe, deserve exactly what they get... > > Why are we wasting our time on OT crap trying to protect the stupid from > > themselves? > > > > Denny > > ________________________________________________________________________________
Subject: Re: autopilot
Date: Apr 25, 2003
From: "David.vonLinsowe" <David.vonLinsowe(at)delphi.com>
> > >Bob, > >I went down to Sun-n-Fun to autopilot shop for my RV-6. I've been doing >research for some time and just needed a little more info before making >the plunge. > >The problem with the Navaid >is the way it will sometimes veer right or left when it's first engaged >then realize it's off course and then correct. The manufacturer knows >of the situation, but doesn't know why it behaves that way. > >I was wondering if you or anyone else out there has come up with a >solution to the problem? the Navaid hasn't been updated in a very long time. As I recall, it's a pure analog servo system. He should be able to fix this problem but for the price, perhaps the idiosyncrasies are forgivable? Bob . . . Thanks Bob, That's the direction I was leaning after SnF. I just wanted to check before I dove into this and reinvented the wheel... Dave RV-6 The need for (more) speed ----> ________________________________________________________________________________
Subject: Re: Comm VS VOR antenna
Date: Apr 25, 2003
No.... The VOR antenna is resonated at a lower frequency than the COM... However, it will work as an emergency antenna for the handheld with some signal loss.... > > Comm and VOR antennas are the same right? > ________________________________________________________________________________
Date: Apr 25, 2003
In a message dated 4/25/03 4:18:37 PM Central Daylight Time, doconnor(at)chartermi.net writes: > No.... The VOR antenna is resonated at a lower frequency than the COM... > However, it will work as an emergency antenna for the handheld with some > signal loss.... > > > > >Comm and VOR antennas are the same right? > Good Afternoon, In addition, the comm signal is transmitted in a vertical mode. The receiving antenna will work best when it is vertical as well. The VOR works in a horizontal plane, Therefore the VOR signal will be best received by an antenna oriented in the horizontal plane. Happy Skies, Old Bob ________________________________________________________________________________
Date: Apr 25, 2003
No VOR is a NAV antenna, Comm is the transmit and receive antenna. Generally a single vertical whip is the comm, two whips horizontal that create a V are the VOR which receives only. Cy Galley - Bellanca Champion Club Newsletter Editor & EAA TC www.bellanca-championclub.com Actively supporting Aeroncas ----- Original Message ----- From: "Scott Bilinski" <bilinski@kyocera-wireless.com> Subject: AeroElectric-List: Comm VS VOR antenna <bilinski@kyocera-wireless.com> > > Comm and VOR antennas are the same right? > > If the above is correct, would a internal wing tip VOR antenna work better > than a VOR/COMM antenna on the belly? > > Will the VOR internal wing tip antenna work as a COM antenna also? > > The reason I am asking is that I want to add another antenna for my hand > held which will be used mainly for VOR's and secondary as a back up radio. > > > Scott Bilinski > Eng dept 305 > Phone (858) 657-2536 > Pager (858) 502-5190 > > ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Date: Apr 26, 2003
Because we are human an care maybe just a little about our RV brothers and sisters who may not be as smart or as informed as some seem to be. James > Why are we wasting our time on OT crap trying to protect the stupid from > themselves? > > ________________________________________________________________________________
Subject: Flightcom 403
Date: Apr 26, 2003
I am about to start my instrument panel and am new to the list. All instruments have been purchased for the 701. Prior to installing I would appreciate comments or experiences with the flightcom 403 intercom and in general UMA instruments. One other slight problem. My aeroflash strobes are installed and wing closed. I have a single 16 ga. positive run to the wing tip with ground at the wing tip. I have followed the shielding discussion and its to late to rewire. Can I do anything at this stage or live with it as is. Do you forsee much interference? One last question. Can I wire my entire panel with 16 ga. wire? Thanks in advance..John Birgiolas ________________________________________________________________________________
Date: Apr 26, 2003
Subject: EGT Gauge
Does anyone know what happens if I use regular copper wires to connect my EGT probe to the gauge. It is impossible to find the required length, proper EGT extension leads for a pusher type engine. I have a Sky Flight EGT Gauge that require a K type probe. Rino Glass Goose C-FZNW 13b turbo ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 28 Msgs - 04/24/03
Date: Apr 26, 2003
04/26/2003 08:47:41 AM It appears to me that you are trading one point of failure (hole in the firewall), for a different point of failure (electrical connection). The question becomes, which point of failure is more likely to fail & which potential failure can be compensated for? I think that I would choose to fabricate the tried and tested fire protection methods and not worry about a newly introduced connection to all of my firewall forward wiring. - Jim Design decisions - thats what makes homebuilding interesting! :-) It seems from my poking around at GA vs. mil airframes, that firewall connectors are the superior engineering design for a long list of reasons, however, the economic reality is that only the military, Airbus, Boeing and Gulfstream, etc., can afford real K-class connectors, so we OBAM folks will continue to use chopped up towel racks. :-( Ira N224xs ________________________________________________________________________________
Subject: EGT Gauge
Date: Apr 26, 2003
Mornin', Rino... Regular copper wire will alter the calibration and range of the sensor if it is a thermocouple. Which I suspect it is because you mentioned that it is a K type probe...there is a K thermocouple. The wires are two dissimilar metals (in the case of the K, Chromal-Alumel). The accuracy of the temperature sensing and range depends on these two specific metals and the fact that they are different. Not only should you use the same metal for the full length of the run, but ALL connectors should also be the same metals. Anywhere that one of these wires touches another type of metal, the calibration will change. As far as finding the wire and connectors, they are available at just about anyplace that sells temperature controls and sensors. A quick search on the internet, using "k thermocouple wire and connectors" as the search term produced over 3,000 hits. I saw rolls of wire offered up to 1000 feet long...that should be long enough! On the other hand, an excellent source, with a good price, for all the connectors, wire, etc that you will need is Omega. I've used them for years. You can find them online here: http://www.omega.com Harley >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Rino >> Sent: Saturday, April 26, 2003 8:27 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: EGT Gauge >> >> >> >> Does anyone know what happens if I use regular copper wires to connect >> my EGT probe to the gauge. >> It is impossible to find the required length, proper EGT extension leads >> for a pusher type engine. >> I have a Sky Flight EGT Gauge that require a K type probe. >> >> Rino >> Glass Goose C-FZNW >> 13b turbo >> >> >> >> >> >> >> ________________________________________________________________________________
Date: Apr 26, 2003
Subject: Re: Flightcom 403
In a message dated 4/26/2003 6:25:53 AM Mountain Daylight Time, jbirgiolas(at)smiletoronto.com writes: > > I am about to start my instrument panel and am new to the list. All > instruments have been purchased for the 701. Prior to installing I would > appreciate comments or experiences with the flightcom 403 intercom and in > general UMA instruments. One other slight problem. My aeroflash strobes > are installed and wing closed. I have a single 16 ga. positive run to the > wing tip with ground at the wing tip. I have followed the shielding > discussion and its to late to rewire. Can I do anything at this stage or > live with it as is. Do you forsee much interference? One last question. > Can I wire my entire panel with 16 ga. wire? Thanks in advance..John > Birgiolas > > If your powerpacks for your strobes are at each tip then there will be little if any interference. I did run separate grounds for all devices in my plane but I don't think using a chassis ground will give ya any problems. I ran as much 16 ga wires also, but you will find that when you build your harnesses 20 - 22 ga stuff will work better for the connectors because there is very little space in the plugs. Also, if you are using the MAC grips you will find that there is no room to play with. The right side of my yoke has a PTT only and that was not bad. The left side uses the 4 function + PTT, that sucker will cause you to call Dr Jack Kevorkian several times when ya try to close the top, and I was using 22 Ga stuff there. If they would have just made it 1/8" taller. !!!!!!!! Ben Haas N801BH. Jackson Hole Wy. ________________________________________________________________________________
From: "John H. Wiegenstein" <johnw(at)hellerwiegenstein.com>
Subject: Feedback on Falcon Gauge Electric TC
Date: Apr 26, 2003
Listers, I recently ordered one of the non-TSO'd electric turn coordinators from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today there is no response to 12V power; no sound, no movement, and the red power failure flag remains visible. Polarity and connections all check out. I've emailed Wultrad and am awaiting their response, but meantime I'm curious what experience others have had with this or other products from this vendor. Seems to me they would have bench tested these before shipping, but perhaps that is one of the steps avoided to save $$$? John H. Wiegenstein Hansville, WA RV-6 S/N 23961 - N727JW (reserved) ________________________________________________________________________________
Date: Apr 26, 2003
Subject: Re: Feedback on Falcon Gauge Electric TC
Have not got my TC gauge yet, but as soon as I do I will give a report. I am also considering there electric AI/DG as a backup to my Dynon EFIS D10. Ed N823MS Lancair ES ________________________________________________________________________________
Date: Apr 26, 2003
hi john In response to your message I removed my falcon electric TC from its box and fired it up, It seems to work ok if a trifle noisy terminal 1 is pos 12 v and terminal 2 neg to ground. the third terminal is left unconnected, I realise that you have probaly wired it up this way, but just checking, regards ivor phillips europa xs ----- Original Message ----- From: "John H. Wiegenstein" <johnw(at)hellerwiegenstein.com> Subject: AeroElectric-List: Feedback on Falcon Gauge Electric TC > > Listers, I recently ordered one of the non-TSO'd electric turn coordinators > from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today there is > no response to 12V power; no sound, no movement, and the red power failure > flag remains visible. Polarity and connections all check out. I've emailed > Wultrad and am awaiting their response, but meantime I'm curious what > experience others have had with this or other products from this vendor. > Seems to me they would have bench tested these before shipping, but perhaps > that is one of the steps avoided to save $$$? > > John H. Wiegenstein > Hansville, WA > RV-6 S/N 23961 - N727JW (reserved) > > ________________________________________________________________________________
Date: Apr 26, 2003
Hi John I also have a Falcon TC and it looks like the wiring instructions are incorrect. Mine was also silent until I put pos voltage to the pin on the right when looking at the aft of the cannon plug and gnd to the inferior pin. It then runs and the flag goes down. Tom Friedland Atascadero, CA EuropaXS -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John H. Wiegenstein Subject: AeroElectric-List: Feedback on Falcon Gauge Electric TC Listers, I recently ordered one of the non-TSO'd electric turn coordinators from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today there is no response to 12V power; no sound, no movement, and the red power failure flag remains visible. Polarity and connections all check out. I've emailed Wultrad and am awaiting their response, but meantime I'm curious what experience others have had with this or other products from this vendor. Seems to me they would have bench tested these before shipping, but perhaps that is one of the steps avoided to save $$$? John H. Wiegenstein Hansville, WA RV-6 S/N 23961 - N727JW (reserved) ________________________________________________________________________________
Date: Apr 26, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: EGT Gauge
> > >Mornin', Rino... > >Regular copper wire will alter the calibration and range of the sensor if it >is a thermocouple. Which I suspect it is because you mentioned that it is a >K type probe...there is a K thermocouple. The wires are two dissimilar >metals (in the case of the K, Chromal-Alumel). The accuracy of the >temperature sensing and range depends on these two specific metals and the >fact that they are different. > >Not only should you use the same metal for the full length of the run, but >ALL connectors should also be the same metals. Anywhere that one of these >wires touches another type of metal, the calibration will change. Actually, connectors can be dissimilar . . . consider that "new" thermocouples are inserted in series opposing such that they cancel each other out. For all but the most demanding precision, you can run thermocouple wire through connectors like d-subs with no ill effects. HOWEVER, I would do this only with machined pins that get one-hell-of-a-grip on the unusually hard wire used for thermocouples . . . open barrel, sheet metal pins are (in my never humble opinion) suited to this task. >As far as finding the wire and connectors, they are available at just about >anyplace that sells temperature controls and sensors. A quick search on the >internet, using "k thermocouple wire and connectors" as the search term >produced over 3,000 hits. I saw rolls of wire offered up to 1000 feet >long...that should be long enough! > >On the other hand, an excellent source, with a good price, for all the >connectors, wire, etc that you will need is Omega. I've used them for >years. > >You can find them online here: http://www.omega.com > >Harley Good answer Harley, thanks for chipping in . . . There is an excerpt from the 'Connection that speaks to this technology at http://www.aeroelectric.com/articles/excerpt.pdf Bob . . . ________________________________________________________________________________
Date: Apr 26, 2003
> Subject: Re: AeroElectric-List: Feedback on Falcon Gauge Electric TC > > > On Saturday, April 26, 2003, at 11:59 AM, John H. Wiegenstein wrote: > >> I'm curious what >> experience others have had with this or other products from this >> vendor. >> > > > I installed one in our AirCam a couple of years ago. I initially had > the same problem, but is somehow fixed itself and the unit has worked > flawlessly since. I installed it without a switch (on any time the > master is on) and we have about 110 hours on it now, which includes > probably 400 engine starts( two engines, average 20-30 minute > flights). > > It is mechanically noisy before the engines are running but otherwise > functions perfectly. > > Although others have reported noise problems with this unit, I don't > hear any noise at all in spite of its location immediately above the > UPS GPS/Comm, and near the intercom. It doesn't even affect the > magnetic compass which sits a couple of inches above it. > > Actually the only operational difficulty we've seen is that the ball > won't always stay centered perfectly in turns. I'm sure if I had a > better gauge, this wouldn't be an issue ;-) > > > James Freeman > > You can see the panel/TC at: > > http://homepage.mac.com/flyeyes/PhotoAlbum6.html ________________________________________________________________________________
Date: Apr 26, 2003
In a message dated 4/26/2003 11:06:08 AM Mountain Daylight Time, johnw(at)hellerwiegenstein.com writes: > > > Listers, I recently ordered one of the non-TSO'd electric turn coordinators > from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today there > is > no response to 12V power; no sound, no movement, and the red power failure > flag remains visible. Polarity and connections all check out. I've emailed > Wultrad and am awaiting their response, but meantime I'm curious what > experience others have had with this or other products from this vendor. > Seems to me they would have bench tested these before shipping, but perhaps > that is one of the steps avoided to save $$$? > > John H. Wiegenstein > Hansville, WA > RV-6 S/N 23961 - N727JW (reserved) > I just got mine last month. I have powered it up and it does spool up nicely altho it is kinda noisy. When I get my radios turned on I will give you guys a report on it. Some people recently have complained that it introduces noise into the radios and if mine does too it will come out and I offered it to Bob to do an autopsy on it and he will post the grizzly details on this list. Ben Haas N801 BH Jackson Hole Wy. ________________________________________________________________________________
Date: Apr 26, 2003
Thanks for filling me in on the perils of shunt-parallelling. I suspected it might be an archaic idea, like so many in the non-OBAM world. > I belive Cirrus uses the SD-20 and the standby version of > the regulator that goes with it. That system is described > in page 17-12 of the 'Connection and illustrated Figure 17-8. > > I didn't include this option in the Z-drawings because > I consider this system to be a Band-Aid that could > be pasted into an existing system essentially > carved in stone. B&C has a fist full of STC'd kits to > put just such a patch on perhaps a dozen airplanes. > Bob, you're referring to the shunt-parallelled system as a "Band Aid", aren't you? The Cirrus system is a 28V dual alternator, dual battery, main+essentials bus design that appears to follow Aeroelectric philosophies closely. It does NOT use a essentials bus alternate feed switch, but has two 2 diode protected feed paths to the essentials bus and to isolate the main bus and alternator from the essential bus and alternator, which regulates 0.75V higher than the main bus to ensure isolation. This theoretically means that the pilot doesn't have to do anything to reconfigure the system after a failure, other that shut off a dead alternator whenever it's convenient. Full annunication tells the pilot what went wrong. This is what I meant by Cirrus' near-zero-pilot-intervention electrical system design. In fact, I don't think the Cirrus system can have an alternate feed switch, since it uses contactors on both batteries, the alternator field enable lines, and the avionics busses ( both main and essential ) to keep heavy and or noisy currents out of panel switches. I suppose this is a subtle disadvantage of the FAA's suggested practice for fire(?) protection Bob recently posted to the list; the ultra-low current mode provided by an essentials bus alternate feed switch isn't an option because it would route battery current directly through the panel. Shaun ________________________________________________________________________________
Subject: Wig wag relay
Date: Apr 26, 2003
In the low cost wig- wag system using automative flasher article, there is mention of a B&C SSF-1 relay or equal. What would be a comparative automotive flasher that I could use? Bob ________________________________________________________________________________
Date: Apr 26, 2003
QC on a product made on mainland China - you gotta be kidding. I had a friend who recently made a tour of some aviation related manufacturing facilities over there. He spotted a Chinese engineering group dissembling and reverse engineering the infamous Mini 500 single seat helicopter. Gonna kill a lot of Chinese helo pilots with that death trap. Bruce -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Benford2(at)aol.com Subject: Re: AeroElectric-List: Feedback on Falcon Gauge Electric TC In a message dated 4/26/2003 11:06:08 AM Mountain Daylight Time, johnw(at)hellerwiegenstein.com writes: > > > Listers, I recently ordered one of the non-TSO'd electric turn coordinators > from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today there > is > no response to 12V power; no sound, no movement, and the red power failure > flag remains visible. Polarity and connections all check out. I've emailed > Wultrad and am awaiting their response, but meantime I'm curious what > experience others have had with this or other products from this vendor. > Seems to me they would have bench tested these before shipping, but perhaps > that is one of the steps avoided to save $$$? > > John H. Wiegenstein > Hansville, WA > RV-6 S/N 23961 - N727JW (reserved) > I just got mine last month. I have powered it up and it does spool up nicely altho it is kinda noisy. When I get my radios turned on I will give you guys a report on it. Some people recently have complained that it introduces noise into the radios and if mine does too it will come out and I offered it to Bob to do an autopsy on it and he will post the grizzly details on this list. Ben Haas N801 BH Jackson Hole Wy. ________________________________________________________________________________
Subject: Re: Falcon Electric TC
Date: Apr 26, 2003
Tom, you were absolutely right. You stated: I also have a Falcon TC and it looks like the wiring instructions are incorrect. Mine was also silent until I put pos voltage to the pin on the right when looking at the aft of the cannon plug and gnd to the inferior pin. It then runs and the flag goes down. I went out, tried this, and voila: power up, flag gone, and (as you said, somewhat noisy) gyro coming to life. I was not ready to try the mix & match connections game, but I'm glad you did. This poses the following question, though: how can a manufacturer be so stupid that it cannot get a simple + and - 12 V wiring diagram (two whole connections!) right in its installation literature? I continue to just be amazed at some of the sorry practice that passes for "aviation quality" work.... Now I can go un-solder and rework the connection and get it right. Thanks for your help - by cc of this email I am passing this on to the "pros" are Falcon Gauge. John H. Wiegenstein Hansville, WA RV-6 S/N 23961 - N727JW (reserved) ________________________________________________________________________________
Subject: wiring question
Date: Apr 26, 2003
I have the AK-350 encoder, an IK2000 engine monitor w/density altitude readout (requiring gray code input, looping out to another device), Garmin GTX327, Garmin GNC300XL. The transponder has a gray code input and 2 RS232 inputs to receive Icarus or Shadin type altitude info. It also has altitude output in Icarus format. The GPS has RS232 inputs to receive (I believe) Icarus or Shadin type info (according to installation manual). It also has a 232 output channel showing aviation type info (serial position, velocity, and navigation data) which I'm not sure where that info is to be used. I am currently thinking that from the encoder to the IK2000 with gray code looping that out to the transponder with a RS232 output going to the GPS unit with altitude info. Does that sound right? Next for the Navaid A/P does it get steering info from the GPS RS232 output NMEA format or from the GPS left/right steering info that would normally go to a Nav Indicator? Do I need the Smart Coupler with this unit? Dave Ford RV6 ________________________________________________________________________________
Date: Apr 26, 2003
It's my understanding that you can buy the Navaid A/P (wing leveler) with the Smart Coupler built in. In that case it will take the serial output from a GPS. If you bought the Navaid A/P without the built-in Smart Couple, then you'll need to buy one from www.porcine.com Another possibility is to use the all solid-state DigiTrak from http://www.trutrakflightsystems.com . It accepts GPS input. -john- john(at)loram.org www.loram.org -----Original Message----- From: Dave Ford [mailto:dford(at)michweb.net] avionics-list(at)matronics.com Subject: AeroElectric-List: wiring question ... Next for the Navaid A/P does it get steering info from the GPS RS232 output NMEA format or from the GPS left/right steering info that would normally go to a Nav Indicator? Do I need the Smart Coupler with this unit? Dave Ford RV6 ________________________________________________________________________________
Date: Apr 26, 2003
Subject: Re: Wig wag relay
> >In the low cost wig- wag system using automative flasher article, there is >mention of a B&C SSF-1 relay or equal. What would be a comparative >automotive flasher that I could use? > >Bob I suspect there are many but I've not researched and verified any specific part numbers. Perhaps someone on the list has taken the time to dig out this information. Bob . . . ________________________________________________________________________________
Date: Apr 27, 2003
I built and tried the other wig wag alternatives using dual 20A continuous relays with the DIY flasher with the lm555. The problem that I have with that circuit is that with no lights turned on I have a rhythmic clicking of the relays going on, so I know that the DIYis producing the proper timing. But as soon as I apply power to the headlights, the relays start working with a twitch and are not rhythmic at all. I have the PB310-nd relays from digi-key. I have used these for my trim. Maybe I should have used z217-nd automotive relays for the headlights instead. Since I have the wiring done, this would be my preferred choice, Would either of these ( z217-nd or the pb310-nd) from digi-key be a replacement for the s704-1 equal? ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Wig wag relay > > > > >In the low cost wig- wag system using automative flasher article, there is > >mention of a B&C SSF-1 relay or equal. What would be a comparative > >automotive flasher that I could use? > > > >Bob > > I suspect there are many but I've not researched and verified > any specific part numbers. Perhaps someone on the list has > taken the time to dig out this information. > > Bob . . . > > ________________________________________________________________________________
Date: Apr 27, 2003
Minus 20dB for cross polarization is part of the signal loss I alluded to... Denny K8DO ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: AeroElectric-List: Comm VS VOR antenna > > In a message dated 4/25/03 4:18:37 PM Central Daylight Time, > doconnor(at)chartermi.net writes: > > > No.... The VOR antenna is resonated at a lower frequency than the COM... > > However, it will work as an emergency antenna for the handheld with some > > signal loss.... > > > > > > > >Comm and VOR antennas are the same right? > > > > Good Afternoon, > > In addition, the comm signal is transmitted in a vertical mode. The > receiving antenna will work best when it is vertical as well. The VOR works > in a horizontal plane, Therefore the VOR signal will be best received by an > antenna oriented in the horizontal plane. > > Happy Skies, > > Old Bob > > ________________________________________________________________________________
Date: Apr 27, 2003
My only comment on using mechanical/thermal relays is that you give up the good feature of the solid state stuff that controls the inrush current on the initial startup and keeps the filament warm between cycles - drastically prolonging bulb life... Denny... ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Wig wag relay > > > > >In the low cost wig- wag system using automative flasher article, there is > >mention of a B&C SSF-1 relay or equal. What would be a comparative > >automotive flasher that I could use? > > > >Bob > > I suspect there are many but I've not researched and verified > any specific part numbers. Perhaps someone on the list has > taken the time to dig out this information. > > Bob . . . > > ________________________________________________________________________________
Date: Apr 27, 2003
Subject: Z Diagrams
I have a question about differences between wiring diagrams Z 11 and Z 13. One has a fuselink and the 5 A field circuit breaker between the main bus and the master switch. The other has the circuit breaker downstream of the master switch. Does it make any difference? Also, I'm planning a small 4 to 5 A. H. battery to back up my #2 electronic ignition. I will probably locate it somewhere near the instrument panel. Would there be a problem grounding it on the firewall ground, when the main battery is grounded locally in the rear fuselage? And the last awe inspiring question of the day is, since there appears to be a large number of ground wires coming off the back of the instrument panel, does it make sense to combine them all and just run one wire to the firewall ground to reduce the size of the wire bundle? Your mission should you decide to accept it, is to provide some much needed clarification, and as always your expertise is much appreciated. Joel Harding ________________________________________________________________________________
Date: Apr 27, 2003
Bob, from your description you may need to do three things... First is that you do not have an adequate series choke and bypass capacitor on the power leads for the 555 allowing noise to get inside... The second is that you are getting voltage sag at the 555 due to the inrush across the filaments... Perhaps a surge capacitor there will help... Any automobile sound shop will have them... Otherwise, you will need a separate power lead from the battery to the 555... And the last is that the transient spike off the relay coil is confusing the 555 and you need a diode across the coil leads and a capacitor to ground there, also... Although I would have expected it to be a problem even with the bulbs turned off, however with transients you cannot predict..... Denny ----- Original Message ----- From: "Bob Kuc" <bkuc1(at)tampabay.rr.com> Subject: Re: AeroElectric-List: Wig wag relay > > I built and tried the other wig wag alternatives using dual 20A continuous > relays with the DIY flasher with the lm555. The problem that I have with > that circuit is that with no lights turned on I have a rhythmic clicking of > the relays going on, so I know that the DIYis producing the proper timing. > But as soon as I apply power to the headlights, the relays start working > with a twitch and are not rhythmic at all. I have the PB310-nd relays from > digi-key. I have used these for my trim. Maybe I should have used z217-nd > automotive relays for the headlights instead. Since I have the wiring done, > this would be my preferred choice, Would either of these ( z217-nd or the > pb310-nd) from digi-key be a replacement for the s704-1 equal? > > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Wig wag relay > > > > > > > > > > > >In the low cost wig- wag system using automative flasher article, there > is > > >mention of a B&C SSF-1 relay or equal. What would be a comparative > > >automotive flasher that I could use? > > > > > >Bob > > > > I suspect there are many but I've not researched and verified > > any specific part numbers. Perhaps someone on the list has > > taken the time to dig out this information. > > > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Apr 27, 2003
Ok, I saw Bob Archer's VOR antenna (asked where to see it in another post, I really like it) now I have another question because of this post. Is it possible that you could create a switch for the BNC connector that hooks your handheld to the COM antenna so that you could switch between the COM and the VOR antennas? Of course without lots of signal loss and noise??? ;) For some reason this just sounds messy. Jeff (RV8 Wings) ----- Original Message ----- From: "Dennis O'Connor" <doconnor(at)chartermi.net> Subject: Re: AeroElectric-List: Comm VS VOR antenna > > Minus 20dB for cross polarization is part of the signal loss I alluded to... > > Denny > K8DO > ----- Original Message ----- > From: <BobsV35B(at)aol.com> > To: > Subject: Re: AeroElectric-List: Comm VS VOR antenna > > > > > > In a message dated 4/25/03 4:18:37 PM Central Daylight Time, > > doconnor(at)chartermi.net writes: > > > > > No.... The VOR antenna is resonated at a lower frequency than the > COM... > > > However, it will work as an emergency antenna for the handheld with some > > > signal loss.... > > > > > > > > > > >Comm and VOR antennas are the same right? > > > > > > > Good Afternoon, > > > > In addition, the comm signal is transmitted in a vertical mode. The > > receiving antenna will work best when it is vertical as well. The VOR > works > > in a horizontal plane, Therefore the VOR signal will be best received by > an > > antenna oriented in the horizontal plane. > > > > Happy Skies, > > > > Old Bob > > > > > > ________________________________________________________________________________
Date: Apr 27, 2003
> >I built and tried the other wig wag alternatives using dual 20A continuous >relays with the DIY flasher with the lm555. The problem that I have with >that circuit is that with no lights turned on I have a rhythmic clicking of >the relays going on, so I know that the DIYis producing the proper timing. >But as soon as I apply power to the headlights, the relays start working >with a twitch and are not rhythmic at all. I have the PB310-nd relays from >digi-key. I have used these for my trim. Maybe I should have used z217-nd >automotive relays for the headlights instead. Since I have the wiring done, >this would be my preferred choice, Would either of these ( z217-nd or the >pb310-nd) from digi-key be a replacement for the s704-1 equal? Which schematic for the 555 flasher are you using? Does it have a capacitor from pin 5 to ground? I neglected this important component on several drawings circulating 'round out there. Not having a 1 uf or so cap from 5 to ground will produce strange behavior like you've described. Bob . . . ________________________________________________________________________________
Date: Apr 28, 2003
Hi bob, where may I find an updated one? Thanks Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Wig wag relay --> >--> > >I built and tried the other wig wag alternatives using dual 20A continuous >relays with the DIY flasher with the lm555. The problem that I have with >that circuit is that with no lights turned on I have a rhythmic >clicking of the relays going on, so I know that the DIYis producing the >proper timing. But as soon as I apply power to the headlights, the >relays start working with a twitch and are not rhythmic at all. I have >the PB310-nd relays from digi-key. I have used these for my trim. >Maybe I should have used z217-nd automotive relays for the headlights instead. Since I have the wiring done, >this would be my preferred choice, Would either of these ( z217-nd or the >pb310-nd) from digi-key be a replacement for the s704-1 equal? Which schematic for the 555 flasher are you using? Does it have a capacitor from pin 5 to ground? I neglected this important component on several drawings circulating 'round out there. Not having a 1 uf or so cap from 5 to ground will produce strange behavior like you've described. Bob . . . direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Apr 27, 2003
Subject: Re: Affordable time-delay
In a message dated 4/27/2003 5:07:16 PM Eastern Standard Time, jon(at)finleyweb.net writes: > Hi all, > > Looking thru the archives it appears that this topic has been discussed > before but I couldn't find a clear answer. > > I am looking for what I think is called an "on-delay timer". My specific > use is to control my low-fuel level light. I have a float type sensor. > The fuel sloshing around causes the light to cycle. I would really like > to install an on-delay timer/relay which requires the input signal to be > "on" for 15 seconds or so (flexible here) before turning on the light. > If the input signal is goes "off" at any point during the countdown, the > timer is reset. > > Doing a web search turns up a ton of products. However; not being much > of an electronic geek, I'm not sure which ones would work. So, if > anyone knows of a product that would do this job (and is terribly > expensive) please forward me some info. I have a 12v system and my low > level light is an LED so don't need much capactity on the circuit. > > Thanks much!! > > Jon Finley > N90MG Q2 - Subaru EJ-22 DD - 440 Hrs. TT - 0 Hrs Engine > Apple Valley, Minnesota > http://www.FinleyWeb.net/default.asp?id=96 > > Hello Jon, I sent Mark Phillips (at the possum works) a couple of general purpose time delay relay modules that I use from time to time in my electronics control business. They are dip switch settable to do many functions, are dual voltage (12 & 24) and they cost less than twenty bucks each. I bread boarded for Mark a configuration that will do just what you are asking. He is using two tanks with a module controlling the low fuel light for each low fuel sensor switch. A count down time delay can be set so that the LED is kept off until the time out is complete. The low fuel sensor must remain in alarm during the entire count down to turn the LED on. A return to normal signal from the low fuel sensor cancels the time out. Both sensor alarm input and completed time delay must be true to turn the light on. He may see this post and chime in to let you know how they are working out for him so far. John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Apr 27, 2003
Bob, I am using the one called AEC_WW2.pdf found in your last .zip file. The drawing has a .1uF cap from pin 5 to ground. I will open my case up to make use that it is to ground. You mentiuone d a 1 uF. Should that be a 1 or a .1 uF cap to ground. > Which schematic for the 555 flasher are you using? Does > it have a capacitor from pin 5 to ground? I neglected this > important component on several drawings circulating 'round > out there. Not having a 1 uf or so cap from 5 to ground > will produce strange behavior like you've described. > > Bob . . . ________________________________________________________________________________
Date: Apr 27, 2003
Subject: Z-14 Questions
Bob: I have been studying the Z-14 duel batt duel alt wiring diagram and have a few questions. 1. Why is the hydraulic pump coming off the main battery contactor as opposed to the main power bus? 2. Why is there a #2AWG between the main battery contactor and the crossfeed contactor when there is only a #4 between crossfeed and aux battery contactor? 3. I am wiring a canard so I have substituted a #2AWG wire for the #4AWG shown between the main battery contactor and the starter contactor per Z-15. Same on the return Ground. Is this correct? 4. Should I also connect the two battery negatives with a #2 or is #4 still ok? 5. Z-15 two different diagrams show the panel ground connected to the #2 AWG ground wire and the other diagram shows the panel ground connected to the battery with a #4AWG. Any difference here or is it just preference? 6. The ground strap from engine to firewall ground calls for a braided strap. Could a #2 welding cable be used here as a substitute? Thanks Tim ________________________________________________________________________________
Date: Apr 27, 2003
Subject: alternative wigwag flashers
>In the low cost wig- wag system using automative flasher article, there is >mention of a B&C SSF-1 relay or equal. What would be a comparative >automotive flasher that I could use? > >Bob I suspect there are many but I've not researched and verified any specific part numbers. Perhaps someone on the list has taken the time to dig out this information. Bob . . . I think I've found one from Grote. It's a school bus electronic alternating flasher #44730. It's marked 6 lamps/side, 12 volt, SAE J945,J590, FMVSS 10B or"8". It has 3 .25 faston males which mate to a generic socket which has 3 8" pigtails for connecting. I haven't tried it yet but the cost was minimal and available from UAP/NAPA. PeterVC ________________________________________________________________________________
Date: Apr 27, 2003
Subject: Camlocks
> For those who have done their cowls with Camlocks instead of hnges, what thickness Al strip did you use for the camlocks to attach to the cowl. Their website shows it done using .063 but that seems like overkill. I was thinking of using .040 or .032, easier to work with and I have it on hand. What do you think? Jeff Point RV-6 FWF Milwaukee WI < I used hinges on the bottom of the the cown and camlocks on the top. I used some of the "scrap" that is included with the kit. I think it is 0.032. Jim Bean RV-8 engine ________________________________________________________________________________
Date: Apr 27, 2003
> >Bob, > >I am using the one called AEC_WW2.pdf found in your last .zip file. The >drawing has a .1uF cap from pin 5 to ground. I will open my case up to >make use that it is to ground. You mentiuone d a 1 uF. Should that be a 1 >or a .1 uF cap to ground. about anything .1 or larger will work . . . if you have .1 uf, that's fine. Bob . . . ________________________________________________________________________________
Date: Apr 27, 2003
I used a Tridon EL 12 flasher (aviation aisle at Kragen) and a generic relay which should be freely available from the same source. This is a type used for ignition de-activation in auto alarm systems. If you ask the guys at your local dealership who prep used cars for sale you'll find they throw these away every day since dealerships don't leave aftermarket alarm systems in used cars. I have offerings from Potter and Brumfield and Siemans both of which have same part number.(W4-45F11). No matter the maker, these will all have pins labelled 85,86,87,87a and 30 and a wiring diagram on the side. They are rated 40/30 amp and have a normally closed and a normally open contact. The circuit works fine although the only issue I've not been able to address is whether or not it will generate any interference with the intercom or radios. A VERY cheap experiment to make however. Good luck. Rob Rob W M Shipley RV9A N919RV Fuselage - now a canoe!!! Subject: Re: AeroElectric-List: Wig wag relay > >In the low cost wig- wag system using automative flasher article, there is >mention of a B&C SSF-1 relay or equal. What would be a comparative >automotive flasher that I could use? > >Bob I suspect there are many but I've not researched and verified any specific part numbers. Perhaps someone on the list has taken the time to dig out this information. Bob . . . ________________________________________________________________________________
Subject: Re: Falcon Gauge Electric TC & Spruce return policy
Date: Apr 27, 2003
I purchased one of these gyros from Spruce a couple of months ago. The first one was using three times the current it should and the RPM was fluctuating. As the RPM went down the current went up, and the RF noise was unacceptable.Spruce replaced it with an equally noisy gyro This one completely wiped out the radio reception in my A/C. I returned this to Spruce also. Spruce will not issue a credit until the manufacture says I did not damage there junk gyro. Mark Delano 6A ----- Original Message ----- From: "Bruce Gray" <Bruce(at)glasair.org> Subject: RE: AeroElectric-List: Feedback on Falcon Gauge Electric TC > > QC on a product made on mainland China - you gotta be kidding. > > I had a friend who recently made a tour of some aviation related > manufacturing facilities over there. He spotted a Chinese engineering > group dissembling and reverse engineering the infamous Mini 500 single > seat helicopter. Gonna kill a lot of Chinese helo pilots with that death > trap. > > Bruce > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Benford2(at)aol.com > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Feedback on Falcon Gauge Electric TC > > > In a message dated 4/26/2003 11:06:08 AM Mountain Daylight Time, > johnw(at)hellerwiegenstein.com writes: > > > > > > > > Listers, I recently ordered one of the non-TSO'd electric turn > coordinators > > from Spruce, mfrd. by Falcon Gauge/Wultrad. In a bench test today > there > > is > > no response to 12V power; no sound, no movement, and the red power > failure > > flag remains visible. Polarity and connections all check out. I've > emailed > > Wultrad and am awaiting their response, but meantime I'm curious what > > experience others have had with this or other products from this > vendor. > > Seems to me they would have bench tested these before shipping, but > perhaps > > that is one of the steps avoided to save $$$? > > > > John H. Wiegenstein > > Hansville, WA > > RV-6 S/N 23961 - N727JW (reserved) > > > > I just got mine last month. I have powered it up and it does spool up > nicely > altho it is kinda noisy. When I get my radios turned on I will give you > guys > a report on it. Some people recently have complained that it introduces > noise > into the radios and if mine does too it will come out and I offered it > to Bob > to do an autopsy on it and he will post the grizzly details on this > list. > > Ben Haas N801 BH Jackson Hole Wy. > > ________________________________________________________________________________
From: "Piers Herbert" <piers.herbert(at)ntlworld.com>
Subject: ANR headset supply
Date: Apr 28, 2003
I would like to have a panel mount supply of 9 V for anr headsets. There are several commercially available from companies like David Clarke or Headsets inc. The question is can I make my own? I could easily make a 9V supply circuit from a 3 pin regulator chip, but would this be suficient? I note that the Headsets inc units contain a dc-dc converter to provide "isolaion". Why is this nescessary? Piers RV-8 ________________________________________________________________________________
Date: Apr 28, 2003
Look up Jim Weir's site... He will show you the best method of having an emergency port to the com antennas... Denny ----- Original Message ----- From: "Jeffrey" <dump(at)relaypoint.net> Subject: Re: AeroElectric-List: Comm VS VOR antenna > > Ok, I saw Bob Archer's VOR antenna (asked where to see it in another post, I > really like it) now I have another question because of this post. > > Is it possible that you could create a switch for the BNC connector that > hooks your handheld to the COM antenna so that you could switch between the > COM and the VOR antennas? Of course without lots of signal loss and > noise??? ;) For some reason this just sounds messy. > > Jeff > (RV8 Wings) > > > ----- Original Message ----- > From: "Dennis O'Connor" <doconnor(at)chartermi.net> > To: > Subject: Re: AeroElectric-List: Comm VS VOR antenna > > > > > > > Minus 20dB for cross polarization is part of the signal loss I alluded > to... > > > > Denny > > K8DO > > ----- Original Message ----- > > From: <BobsV35B(at)aol.com> > > To: > > Subject: Re: AeroElectric-List: Comm VS VOR antenna > > > > > > > > > > In a message dated 4/25/03 4:18:37 PM Central Daylight Time, > > > doconnor(at)chartermi.net writes: > > > > > > > No.... The VOR antenna is resonated at a lower frequency than the > > COM... > > > > However, it will work as an emergency antenna for the handheld with > some > > > > signal loss.... > > > > > > > > > > > > > >Comm and VOR antennas are the same right? > > > > > > > > > > Good Afternoon, > > > > > > In addition, the comm signal is transmitted in a vertical mode. The > > > receiving antenna will work best when it is vertical as well. The VOR > > works > > > in a horizontal plane, Therefore the VOR signal will be best received by > > an > > > antenna oriented in the horizontal plane. > > > > > > Happy Skies, > > > > > > Old Bob > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Re: Z Diagrams
Having encountered total silence, I would like to resubmit this for your consideration. I have a question about differences between wiring diagrams Z 11 and Z 13. One has a fuselink and the 5 A field circuit breaker between the main bus and the master switch. The other has the circuit breaker downstream of the master switch. Does it make any difference one way or the other? Also, I'm planning a small 4 to 5 A. H. battery to back up my #2 electronic ignition. I will probably locate it somewhere near the instrument panel. Would there be a problem grounding it on the firewall ground, when the main battery is grounded locally in the rear fuselage? And the last awe inspiring question of the day is, since there will be a large number of ground wires coming off the back of the instrument panel, does it make sense to combine them all with a multiple tab ground and just run one wire to the firewall ground, to reduce the size of the wire bundle? Joel Harding ________________________________________________________________________________
Date: Apr 28, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
I would look into a flasher unit for a semi tractor trailer. > >In the low cost wig- wag system using automative flasher article, there is >mention of a B&C SSF-1 relay or equal. What would be a comparative >automotive flasher that I could use? > >Bob > > ________________________________________________________________________________
Date: Apr 28, 2003
>I have a question about differences between wiring diagrams Z 11 and Z >13. One has a fuselink and the 5 A field circuit breaker between the >main bus and the master switch. The other has the circuit breaker >downstream of the master switch. Does it make any difference one way >or the other? both figures suggest extending the bus via a vulnerable wire up to the alternator control switch. BOTH systems suggest a 5A breaker in this power lead to accommodate the modus-operandi of crowbar ov protection. Exact location of breaker along the route is not terribly important as long as wires leading up to the breaker are not at risk. Risk is mitigated with the fusible link at the bus. Fusible links are preferred to fuses because they have a very long time constant compared to fuses and breakers . . . so that if the crowbar system operates, only the breaker will open. >Also, I'm planning a small 4 to 5 A. H. battery to back up my #2 >electronic ignition. I will probably locate it somewhere near the >instrument panel. Would there be a problem grounding it on the >firewall ground, when the main battery is grounded locally in the rear >fuselage? Ground it to the single point ground on the firewall. >And the last awe inspiring question of the day is, since there will > be a large number of ground wires coming off the back of the >instrument panel, does it make sense to combine them all with a >multiple tab ground and just run one wire to the firewall ground, to >reduce the size of the wire bundle? No. Every system should have its own ground wire to the single point ground bus . . . else the single point ground is no longer a single point ground. >Joel Harding > > Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Magnet on small access door ?
Date: Apr 28, 2003
Hi Bob and all, A friend proposes to lock a small access door on the top front of the fuselage with a magnet , within one foot or so from the instrument panel. Anyone around have tried this setup ? Are there any chances the compass will be enfluenced by the magnet ? Any workaround ? Thanks in advance, Gilles Thesee ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Re: Z-14 Questions
> >Bob: > I have been studying the Z-14 duel batt duel alt wiring diagram and have a >few questions. >1. Why is the hydraulic pump coming off the main battery contactor as opposed >to the main power bus? Hydraulic pumps take a lot of snort that's not practical to supply from a fuse block, they also generate more noise and it's better to have them drive from shortest practical array of fat wires between pump and battery. >2. Why is there a #2AWG between the main battery contactor and the crossfeed >contactor when there is only a #4 between crossfeed and aux battery >contactor? Keep in mind that these drawings are to suggest ARCHITECTURES. Wire sizes need to be considered for your particular situation. As a general rule of thumb, if batteries are close to engine then ALL fat wires can be 4AWG. If batteries are a long way from engine, then fat wires may want to be 2AWG or even larger as in case of some seaplanes. >3. I am wiring a canard so I have substituted a #2AWG wire for the #4AWG >shown between the main battery contactor and the starter contactor per Z-15. >Same on the return Ground. Is this correct? I presume your batteries are up front. All wiring up front between batteries and all contactors can be 4AWG. The wire feeding the starter and taking ground back to the engine should be 2AWG >4. Should I also connect the two battery negatives with a #2 or is #4 still >ok? 4AWG to single point ground is fine, then run on from ground to engine with 2AWG. >5. Z-15 two different diagrams show the panel ground connected to the #2 AWG >ground wire and the other diagram shows the panel ground connected to the >battery with a #4AWG. Any difference here or is it just preference? Z-15B is not a good idea and will be revised at next revision to bring battery and 2AWG engine grounds together at the ground bus. >6. The ground strap from engine to firewall ground calls for a braided >strap. Could a #2 welding cable be used here as a substitute? sure. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Re: ANR headset supply
> > >I would like to have a panel mount supply of 9 V for anr headsets. There >are several commercially available from companies like David Clarke or >Headsets inc. > >The question is can I make my own? I could easily make a 9V supply circuit >from a 3 pin regulator chip, but would this be suficient? Yes >I note that the Headsets inc units contain a dc-dc converter to provide >"isolaion". Why is this nescessary? it isn't. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Subject: Circuit protection question
Date: Apr 28, 2003
Hi Bob and all, I started the wiring for real last week. No hassles except keeping those wire coils clear. Oh, and a 'crimper elbow' ! Here is my question : We're using some parts supplied by the kit manufacturer for the flaps control and motors. They say they wire with 16 AWG, despite the fact they use a 25 amp breaker. My intention is to use a fuse, and fatter wires. Does it make sense to use 14 AWG wires, since the 25 amp protection is only there for the very momentary inrush current draw ? And do I add a 18 AWG fuselink in case of faulted wire or shorted motor ? Thanks, Gilles Thesee ________________________________________________________________________________
Date: Apr 28, 2003
> about anything .1 or larger will work . . . if you have .1 uf, that's fine. > Ok so I have those caps in place. Now the question is does it matter what kind of caps they should be? A ceramic .1uF is rather small. My 10 uF is a dipped tantalum style, while my .1 uf is larger and I believe a coated one. Maybe I have the wrong type of cap on mine? should I go with the 1000v 1" .1uf cap? I did try the separate lead into the relay and it still acted the same way. Bob ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Z-15?
Bob one point of clairification Is what you are describing below essentially the Z-15 view C Ground system for seaplane? 5. Z-15 two different diagrams show the panel ground connected to the #2 AWG >ground wire and the other diagram shows the panel ground connected to the >battery with a #4AWG.=A0=A0 Any difference here or is it just=A0 preference? =A0 Z-15B is not a good idea and will be revised at next revision =A0 to bring battery and 2AWG engine grounds together at the =A0 ground bus. ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Re: Magnet on small access door ?
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >A friend proposes to lock a small access door on the top front of the >fuselage with a magnet , within one foot or so from the instrument panel. >Anyone around have tried this setup ? Are there any chances the compass will >be enfluenced by the magnet ? >Any workaround ? A properly designed latch could probably work that close to the panel without upsetting the compass. Does he know how to do this? The magnet needs to reside in a magnetic enclosure that minimizes leakage of flux while the door is closed. A steel cup with the same depth as magnet thickness is in order. A piece of steel on the inside of the door should exactly close the cup all around the periphery and should not have a lot of overlap . . . diameter of door shunt is only slightly larger than diameter of cup. In any case, give it a try. It can't do worse than make you figure out something else if it doesn't work. Let us all know how it works out and send pictures. Bob . . . ________________________________________________________________________________
Date: Apr 28, 2003
Why don't you tell your friend to try touch latch, don't need a magnetic. Ron Triano Quicker one Q-200, 90% Done with 90% to go -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Magnet on small access door ? ><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >A friend proposes to lock a small access door on the top front of the >fuselage with a magnet , within one foot or so from the instrument panel. >Anyone around have tried this setup ? Are there any chances the compass will >be enfluenced by the magnet ? >Any workaround ? A properly designed latch could probably work that close to the panel without upsetting the compass. Does he know how to do this? The magnet needs to reside in a magnetic enclosure that minimizes leakage of flux while the door is closed. A steel cup with the same depth as magnet thickness is in order. A piece of steel on the inside of the door should exactly close the cup all around the periphery and should not have a lot of overlap . . . diameter of door shunt is only slightly larger than diameter of cup. In any case, give it a try. It can't do worse than make you figure out something else if it doesn't work. Let us all know how it works out and send pictures. Bob . . . ________________________________________________________________________________
Subject: FYI
Date: Apr 28, 2003
Ebay Item # 2526787231--- 12 Volt Turn & Slip Bank Indicator R.C. Allen ________________________________________________________________________________
Date: Apr 28, 2003
Subject: Quartz Hour Meters on Ebay
see http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26442&item=2413197823 Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 29, 2003
> Why don't you tell your friend to try touch latch, don't need a magnetic. > > Ron Triano Quicker one Q-200, 90% Done with 90% to go > > > A properly designed latch could probably work that > close to the panel without upsetting the compass. Thanks to Bob and Ron. In fact the small door isn't an access door but an aerator. So he wants to open and close it in flight and the touch latch is impractical. Regards, Gilles Thesee ________________________________________________________________________________
Date: Apr 29, 2003
Subject: Re: Blown master fuse
Bob, I guess I just got carried away with the fuse approach vs breakers and failed to see the symbol for the breaker. Before I order a breaker though, what type breaker should I use? A 5a W58 or a combination breaker/switch to use in place of my master switch? If I use the W58 please advise step by step how to wire it and the master switch in, I really want to get it right this time....... Also, I need to place an order with B&C for some other stuff, do you carry the breaker I need? Thanks! Walt Shipley ________________________________________________________________________________
Date: Apr 29, 2003
> >Bob, I guess I just got carried away with the fuse approach vs breakers and >failed to see the symbol for the breaker. Before I order a breaker though, >what type breaker should I use? A 5a W58 or a combination breaker/switch to >use in place of my master switch? Wire it per the drawing. > If I use the W58 please advise step by >step how to wire it and the master switch in, I really want to get it right >this time....... Also, I need to place an order with B&C for some other >stuff, do you carry the breaker I need? Thanks! Any 5A breaker will work. B&C offers a suitable breaker from their website catalog at http://www.bandc.biz This doesn't explain why the crowbar ov system was tripping. Did you find some wiring errors? Bob . . . ________________________________________________________________________________
Date: Apr 29, 2003
> > > about anything .1 or larger will work . . . if you have .1 uf, that's >fine. > > >Ok so I have those caps in place. Now the question is does it matter what >kind of caps they should be? A ceramic .1uF is rather small. My 10 uF is a >dipped tantalum style, while my .1 uf is larger and I believe a coated one. >Maybe I have the wrong type of cap on mine? should I go with the 1000v 1" >.1uf cap? No, the style and voltage are not critical to the operation as long as the voltage rating of the capacitor is equal to or greater than operating voltage. >I did try the separate lead into the relay and it still acted the same way. Hmmm . . . I've built dozens of these. I'm curious as to what's going on here. Can you send me your flasher assembly in the mail to look at? Bob . . . ________________________________________________________________________________
Date: Apr 29, 2003
thanks, Sure. I will attach it all back and send you my relays and stuff up there. It should be in the mail this week-end Could send me yer address? Bob ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Wig wag relay > > > > > > about anything .1 or larger will work . . . if you have .1 uf, that's > >fine. > > > > >Ok so I have those caps in place. Now the question is does it matter what > >kind of caps they should be? A ceramic .1uF is rather small. My 10 uF is a > >dipped tantalum style, while my .1 uf is larger and I believe a coated one. > >Maybe I have the wrong type of cap on mine? should I go with the 1000v 1" > >.1uf cap? > > No, the style and voltage are not critical to > the operation as long as the voltage rating > of the capacitor is equal to or greater than > operating voltage. > > > >I did try the separate lead into the relay and it still acted the same way. > > Hmmm . . . I've built dozens of these. I'm > curious as to what's going on here. Can you send > me your flasher assembly in the mail to look at? > > Bob . . . > > ________________________________________________________________________________
Subject: Surplus comm antenna
Date: Apr 29, 2003
I got what I thought was a good deal on a surplus comm antenna, but I'm not sure now. I can't seem to find any information on the antenna. It's a stainless steel bent whip with a ceramic insulator at the base. The only numbers on the insulator are NS4W4103 and under that CAS. I can't find any specific information on this antenna. The only thing I found was a general statement that this type of antenna is no good above 127MHz. There is also some question of how much airspeed this type of mount can handle (building an RV-8). Any ideas? Thanks ken ________________________________________________________________________________
Date: Apr 29, 2003
> >thanks, > >Sure. I will attach it all back and send you my relays and stuff up there. >It should be in the mail this week-end Could send me yer address? 6936 Bainbridge Road Wichita, KS 67226-1008 ________________________________________________________________________________
Date: Apr 29, 2003
Subject: Simple timer for low fuel warning . . .
What you're looking for is more than a simple timer . . . and a brief look at the replies on this topic didn't pick up on what's needed. A "flicker filter" is easy to implement in a little micro-controller for the lowest parts count . . . but unless you have access to the programming hardware and skills this could a low-return-on-investment approach. A pure discrete component approach is illustrated at: http://216.55.140.222/temp/Flicker_Filter.pdf All the parts are available from Digikey. Timing for turn-on and turn-off response is set by the 470K/22uF resistor/capacitor pairs. The constants shown give you about 11 seconds of delay for uninterrupted switch closure to turn the light on and the same delay of uninterrupted switch opening to turn the light back out. Bob . . . ________________________________________________________________________________
Date: Apr 29, 2003
Subject: Z15B
Bob Could you explain why Z15B is not a good Idea. That particular architecture would work well for the velocity where the #2AWG runs in a duct from firewall through canard bulkhead right to the batteries. A seperate # 4AWG could come from the panel ground block on the panel and to the batteries via a different route. If you dont recommend this then I would have to cut through the duct inside the cabin behind the panel run the #2 wire up to the panel ground presumable on the panel and then back down into the duct to go to the battery. It would be a lot of heavy wire inside the cabin and onto the panel. Is there a better way I'm not seeing? Thanks Tim Z-15B is not a good idea and will be revised at next revision =A0 to bring battery and 2AWG engine grounds together at the =A0 ground bus. ________________________________________________________________________________
Date: Apr 29, 2003
Subject: Re: Surplus comm antenna
> >I got what I thought was a good deal on a surplus comm antenna, but I'm >not sure now. I can't seem to find any information on the antenna. It's >a stainless steel bent whip with a ceramic insulator at the base. The >only numbers on the insulator are NS4W4103 and under that CAS. I can't >find any specific information on this antenna. The only thing I found >was a general statement that this type of antenna is no good above >127MHz. There is also some question of how much airspeed this type of >mount can handle (building an RV-8). Any ideas? > >Thanks > >ken Antennas of this style were used by the thousands when comm transceivers first found their way onto airplanes. We made our own from scratch at Cessna; you can buy the insulators from some specialty houses. One example can be seen at: http://www.surplussales.com/Ceramic.html There's nothing "magic" about this antenna style. I disucss it in the book. It's certainly adequate for your RV-8. Bob . . . ________________________________________________________________________________
Date: Apr 29, 2003
From: "Paul A. Franz, P.E." <paul(at)eucleides.com>
Subject: Re: Radio frequency interferences
At 12:36 AM 4/29/2003kurt schrader sez: >Theoretically right Paul, > >As you said, you need an essential buss and I was >referring to those things that are really essential >when using CB's. I have an electric horizon for >example. I would reset it 1000 times if I had to in >the clouds to keep it and me upright until I got down >or VFR. I have seen this type of argument posed before. Since I am *NOT AN EXPERT* I cannot precisely identify the flaw. But I know just enough to think your response could be flawed. >And my all electric NSI engine ignition will have two >CB's, one of which is hot off the battery buss and the >other off a seperate battery. One even has two wires >going to it for redundancy. Sometimes redundancy introduces complexity that actually reduces reliability. Have you checked out Bob's circuits for OV, dual batteries and it is possible that there should be neither a fuse or CB in portions of the wiring? Remember, I am not qualified, and really don't have the knowledge to argue this well. I am totally relying on Bob's knowledge from a career in the business and he has weighed in the pros and cons of most of these alternatives. There are lots of ways to do things that are acceptable but some of the ways that are commonly done are not good ideas. Bob Nuckolls has a very good way of presenting the information so that you can make choices taking into consideration you preferences. >Neither would be a good item for using a fuse. >Sometimes you just have to have it "now" and you need >to wire for that posibility. I don't put a fuse on >any circuit that, when it dies, I might too. The second battery idea is good. As I recall, there is never a justification for circuit breakers. There is a better way to do the circuit. We should have Bob in the loop here. How about we take this discussion to the AeroElectric list? I'd hear the stuff reviewed again and would learn and you might get some cool ideas too. >I have a 60 amp main buss CB. It has a lot of items >on it and could and should blow from an overload. It is my understanding that it is improperly designed and sized then. Should not be an operational possibility for the overload. >can turn stuff off, like the 10 amp landing light, and >reset it to give me needed items, if I want to. > >On a rescue mission, I once saved 4 F-4's from going >into the ocean by refueling them with a KC-130 that >required over 100 CB resets to keep one engine >running. We shut it down after we refueled the F-4's >and went home on 3 engines. Without that 4th engine >we couldn't get enough speed to refuel them. Bet that had a mess of poor design too! >Remember, engineers design for everything they can >think of (theoretically), but you have to survive what >they didn't think of too (in reality). Engineers are >good, but human. > >We do carry some fuses on our Boeing aircraft, but >they are outnumbered greatly by CB's. Ok, maybe those >are big as a house... :-) You got me on that one. > >Kurt S. Bob N works for Raytheon and can comment on years of commercial practice which is not best practice especially for our experimentals which allow us to use best and current methods and practices with the freedom. Just because it was done on a KC-135 or C-130 doesn't mean it is good, it means it was approved. I'm going to cc: the aeroelectric list with this one and hopefully you'll have a look there too. >--- "Paul A. Franz, P.E." wrote: > > I'm certainly no wiring expert, but I don't think > > Bob Nuckolls would concur > > with you. I believe fuses are the only choice and > > circuit breakers belong > > in your house, not your airplane. If something blows > > a fuse, it should do > > it quickly and protectively. Breakers don't act fast > > enough to protect > > devices, just to prevent fire. > > > > When it comes time to design wiring for your bird, > > have a look at > > <http://aeroelectric.com/>. > > > > You should post your questions directly to the mail > > list for The Aero > > Electric Connection. Subscribe > > <http://www.matronics.com/subscription>. > > > > Fuses vs. Breakers have been debated for years and > > years. Search the > > archives > > <http://www.matronics.com/aeroelectric-list> and I > > think it will > > become apparent that fuses are the only way to go. > > Less cost, higher > > reliability, less weight and panel space. > > > > At 12:43 AM 4/28/2003kurt schrader sez: > > >Michel, > > > > > >You only need circuit breakers instead of fuses for > > >those items that you "need" inflight. Anything > > that > > >you can't do without, you should replace the fuse > > with > > >a CB. That way if the CB pops, you can reset it in > > >flight. If a fuse blows, you have to take the time > > to > > >find the right fuse and replace it while flying. > > > > Only to find that it immediately blows again. If a > > fuse blows or CB pops > > something needs to be fixed before resetting. Since > > fuses are inherently > > less complex, cheaper, faster acting they are the > > appropriate choice for > > all aircraft circuit protection. > > > > Keep in mind, a modern aircraft has a separate > > functioning essential bus too. > > > > > > >Fuses are best for those things that give you no > > cause > > >for worry and allow you to land and replace the > > fuse. > > > > I subscribe to the idea that the essential bus is > > what takes you to the > > safe place to land. > > > > Keep in mind that I am *NOT* an expert in wiring and > > *DO NOT* warrant > > having an authoritative viewpoint. However, Bob > > Nuckolls is probably the > > world's foremost expert on Aero Electrics so you > > should do what he says to > > do as a matter of best practice. > > > > > > >Kurt S. > > > > > >--- Michel Verheughe wrote: > > > > > > > One question though: What do you mean by > > > > CB? I suspect it is not > > > > "Citizen Bands" so it could be "Circuit > > Breaker," is > > > > it? > > > > If so, no, I don't have a CB before the > > regulator. > > > > In fact, I don't have any > > > > CBs but simple fuses as found in automobiles. I > > know > > > > that some microlight > > > > planes have a set of CB on the panel. It looks > > very > > > > neat and it is what I wish > > > > I had. One day I'll rebuild my panel and re-wire > > the > > > > entier plane, that I find > > > > a bit messy now. > > > > > > > > > > > > Cheers, > > > > Michel > >__________________________________ >http://search.yahoo.com Paul Franz PAF Consulting Engineers | 427 - 140th Ave NE (425)641-8202 voice | Bellevue, WA 98005 (425)641-1773 fax | <http://blackdog.bellevue.wa.us/> ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Z15B
Date: Apr 30, 2003
What is Z15B? My book only has Z15. Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Working on Canopy of Finish Kit ----- Original Message ----- From: <TimRhod(at)aol.com> Subject: AeroElectric-List: Z15B > > > Bob Could you explain why Z15B is not a good Idea. That particular > architecture would work well for the velocity where the #2AWG runs in a duct > from firewall through canard bulkhead right to the batteries. A seperate # > 4AWG could come from the panel ground block on the panel and to the batteries > via a different route. If you dont recommend this then I would have to cut > through the duct inside the cabin behind the panel run the #2 wire up to the > panel ground presumable on the panel and then back down into the duct to go > to the battery. It would be a lot of heavy wire inside the cabin and onto the > panel. Is there a better way I'm not seeing? Thanks Tim > > > Z-15B is not a good idea and will be revised at next revision > to bring battery and 2AWG engine grounds together at the > ground bus. > > ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - SOME ELECTRICAL DATA POINTS
Date: Apr 30, 2003
Folks, Its the Australian autumn. A time of year when flying people gather in large flocks to admire and criticise each others planes. So I just had two consecutive weekends looking at homebuilts and then antique planes. Its amazing what you pick up. Three true stories for your entertainment and enlightenment. Some time ago at Adelaide a twin full of charter passengers did a wheels up landing with much damage. The cause - the field power for BOTH alternators ran through ONE relay. Guess which single point of failure had the audacity to fail in flight? By the time they arrived over this major capital city airport they did not have enough battery power to lower the gear or talk to the tower to explain the problem, or get clearances. Imagine the confusion and safety concern for dense airline traffic. Yes it was a Certified aircraft. A Lancair builder told me he just installed a colour GPS and found that every time he hit the PTT all his electronic engine instruments went haywire, and returned to normal on release of PTT. Removed the GPS, problem solved, re-installed it, problem returned. Had an auto electrician spend 4 hrs labour on it, no fix found. He is still flying, and looking for the problem. I had a long ride in a 50 year old de Havilland Chipmunk. It had horrendous noise on the intercom and I remarked that he seemed to have a noisy alternator. He said no its the gyros radiating. These gyros are vacuum powered, but he demonstated it to be true. The noise is independent of the alternator. Amazing. David Francis, RV7 VH-ZEE hammering the fuselage together. ________________________________________________________________________________
Date: Apr 29, 2003
Bob, no I really haven't solved the problem of why the fuse blows (master to alternator/ b lead ov protection contactor). But here is some history; I used your 4 terminal battery contactor, which came with a diode across the two small terminals and another from the large battery terminal to the small terminal on the left. Not realizing that the latter diode should be removed, I wired everything up and when I first started the engine the diode between the two small terminals went up in smoke. I sent you an email at that time and you said to remove the left diode and replace the remaining diode with one from Radio Shack (don't remember the p/n), which I did. I have checked and double checked my wiring against the diagram, have done continuity tests of the alternator to bus wiring (ok) and ran power to the ov contactor bypassing the contactor diode and found the contactor clicks. Would this tell me possibly I have the wrong diode installed ? Please stick with me a little longer.......... Thanks, Walt ________________________________________________________________________________
Subject: Connecting Stereo to RST Intercom
Date: Apr 29, 2003
Hi, I wired a small portable MP3 player to my RST intercom but the volume is low. I thought it might be some kind of impedence problem so I hooked up a small audio transformer from radio shack with the low impedence side to my MP3 player and the high to the intercom. The sound was loud but the MP3 player shuts down (I think it is self protection against shorts). Am I doing this thing right? Has this problem already been solved? I am thinking of adding a resistor to the transformer in the MP3 low impedence side but I don't know what to use. I really want to use the MP3 player since my plane is a Cozy III and space is at a real premium. If you have any suggestions how to fix this I would really apreciate it! Tim ________________________________________________________________________________
Subject: fuel pump on Battery Bus
Date: Apr 29, 2003
In Z-14, what is the rational for putting the fuel pump connected to the "always hot" battery bus? Is there a reason it should not be on one of the switched bus's? - Jim ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Audio Hi-Lo
Gang, Can somebody please tell me about "Audio Hi" and "Audio Lo" connections on radios and intercoms? Why Hi and Lo, what is the difference, what purpose is served, etc? Thanks Dan Horton ________________________________________________________________________________
Subject: The Connection Z-13 questions
Date: Apr 30, 2003
'Letric Bob and the list, I'm configuring my RV-8 as an "all electric plane on a budget". The battery will be aft mounted for weight and balance considerations. I have the following questions. 1) What size current limiter and ammeter shunt is suggested for a 40 amp alternator, Z-13 shows the values for a 60 amp alt. 2) When mounting the battery in the rear of a metal airplane, it was suggested to me by a friend to ground the battery (-) to a local stout longeron, then to reconnect to that same longeron for the firewall ground forest of fast on tabs. I am leaning towards a common ground and running a seperate 2awg wire forward to the firewall to avoid ground loops. Your thoughts? 3) In looking at Z-13, it seems to me that mounting the battery relay up on the firewall, instead of back on the battery mount, it simplifies the connection of the standby alternator to the battery side of the relay if it is firewall mounted, and shouldn't really matter to the battery if it's rear or front mounted, right? As long as the wire leading up to it is sized correctly. 4) I am planning on integrating the lo cost GPU connection from the Connection and for safety mounting the Piper type recepticle in the rear. If my assumption of #3 above is correct and I do mount the battery relay up front on the firewall, would it be OK to connect the output of the GPU solenoid to the battery (+) instead of running another large wire forward to the battery relay? 5) In Z-13, there is a fuse between the Battery bus and the E bus switch and an additional fuseable link between the switch and the e bus. Why both? Thanks for your time. Art Treff ________________________________________________________________________________
Subject: Battery Contactor - Location?
Date: Apr 29, 2003
Doing my wiring diagram in Visio and after spending many hours creating the stencil/shapes I'm almost done. BTW, if there is an easier way (didn't want to learn AutoCAD) to do this, please don't tell me - I've put in way to much work and sometimes ignorance is bliss. Any way, while doing the diagram I started thinking that I'd like to put the battery contactor on or near the firewall. However, my battery is located just behind the seats so I was worried that since I've seen it mentioned that the battery contactor should be within 12 inches or so of the battery that I was violating some golden rule. However, the only reason I could find for placing the contactor so close to the battery was a possible safety issue of having a large current HOT wire running through half the plane. If this is so, how much of safety issue is it? Are there any other reasons for placing the contactor next to the battery? Thanks! Don ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Wiring Help
From: "Edward O'Connor" <edwardoconnor(at)compuserve.com>
I am presently working on my system wiring and having a hard time figuring out how to physically mount some fuse blocks and elect buses in my RV-8. Would appreciate any one who may have some digital pictures of how you installed Bob's back-up Alternator package E-mailing a picture or two. Type A/C doesn't matter. I am specifically interested in the mpunting of the Relay and OV Crowbar and the Capacator etc for the vacume Pad mounted Backup Alt. I'm am basically using the All Ecectric on a budget diagram. Looking for some compact way to do all of this. In addition, the installation of the Bridge Rectifiers diodes Bob sells. What type of heat sinks and where did you get heat sinks if you used them. Reply off line if you like. Thanks. Ed O'Connor/RV-8/Sandy Creek Airpark Panama City FL ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: fuel pump on Battery Bus
> >In Z-14, what is the rational for putting the fuel pump connected to the >"always hot" battery bus? Is there a reason it should not be on one of the >switched bus's? > >- Jim IF your engine is electrically dependent meaning that one or more DC powered systems must be operating to keep the engine running, then it is my suggestion that all such support systems be powered from an always-hot battery bus. When you walk up to a J-3 or Taylorcraft of old and flip the mag switches up, the engine will run and depends on no other powered systems for continued operation. I don't see any reason why the most sophisticated FADEC fitted machine should operate any differently. When you have smoke in the cockpit, you may shut down ALL DC power control switches and the engine continues to run. You have the option reverting to systems-analyst mode and trying to figure out what you CAN operate without having smoke return -or- whip out the hand-helds from the flight bag and concentrate on being a pilot. Whatever choice you make, it is driven by conditions other than stone silence from under the cowl. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: Z15B
> > >What is Z15B? My book only has Z15. Z15 is a two page drawing that has three views, A B and C. Z15 View B suggests that the battery (-) terminal be the tie point of two wires which is in error. The battery (-) lead and ground lead extending to engine compartment aft should come together at a fat brass bolt on the ground block. Bob . . . ________________________________________________________________________________
Subject: Re: Wiring Help
Date: Apr 30, 2003
Hey, please do NOT "reply off line"! I'm close to the same stage and need the info as much as you. David ----- Original Message ----- From: "Edward O'Connor" <edwardoconnor(at)compuserve.com> Subject: AeroElectric-List: Wiring Help > > I am presently working on my system wiring and having a hard time figuring > out how to physically mount some fuse blocks and elect buses in my RV-8. > Would appreciate any one who may have some digital pictures of how you > installed Bob's back-up Alternator package E-mailing a picture or two. Type > A/C doesn't matter. I am specifically interested in the mpunting of the > Relay and OV Crowbar and the Capacator etc for the vacume Pad mounted Backup > Alt. I'm am basically using the All Ecectric on a budget diagram. Looking > for some compact way to do all of this. In addition, the installation of the > Bridge Rectifiers diodes Bob sells. What type of heat sinks and where did > you get heat sinks if you used them. > Reply off line if you like. Thanks. > Ed O'Connor/RV-8/Sandy Creek Airpark > Panama City FL ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: Battery Contactor - Location?
>Any way, while doing the diagram I started thinking that I'd like to put >the battery contactor on or near the firewall. However, my battery is >located just behind the seats so I was worried that since I've seen it >mentioned that the battery contactor should be within 12 inches or so of >the battery that I was violating some golden rule. However, the only >reason I could find for placing the contactor so close to the battery >was a possible safety issue of having a large current HOT wire running >through half the plane. > >If this is so, how much of safety issue is it? Are there any other >reasons for placing the contactor next to the battery? I suppose there are folks who would endeavor to assign qualifiers of magnitude on an answer, e.g. "Running a 10' long always hot battery feeder to a remotely mounted contactor is 15.9 times more likely to set your bunnies on fire in a crash than a feeder that is 1 foot long". Suppose I had a rational for such a statement, would this have any useful meaning for you in making your architecture decision? If I tossed a number out, how would you select a decision-making value? 4.2 times more likely? 7.3 times more likely? It's an intuitive and inarguable fact that minimizing both the number, lengths and potential for high fault currents in always-hot feeders is a "good" thing to do. Bottom line is that you need to evaluate your own perceptions of goodness against perceptions of convenience. I wouldn't do what you propose in my airplane. You wouldn't get it certified in a Cessna either . . . Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
Ed - If you are using the B&C backup alternator, I believe you'll need a regulator. The B&C regulators have crowbar OV built in. > Would appreciate any one who may have some digital pictures of how you > installed Bob's back-up Alternator package E-mailing a picture or two. > Type A/C doesn't matter. I am specifically interested in the mpunting of > the > Relay and OV Crowbar and the Capacator etc for the vacume Pad mounted > Backup Alt. ________________________________________________________________________________
Date: Apr 30, 2003
Thanks for the circuit Bob! I'm a bit lost here. When I search for those part numbers (DigiKey) I get multiple results (CD4093 = 9, IN4148 = 16). I really don't have a clue which ones to order. Does it matter? Do I just pick any one of them and go? Jon "Clueless and Cold in Minneapolis" Finley N90MG Q2 - Subaru EJ-22 DD - 440 Hrs. TT - 0 Hrs Engine Apple Valley, Minnesota http://www.FinleyWeb.net/default.asp?id=96 > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Robert L. Nuckolls, III > Sent: Tuesday, April 29, 2003 2:12 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Simple timer for low fuel warning . . . > > > --> > > What you're looking for is more than a simple timer . . . and > a brief look at the replies on this topic didn't pick up on > what's needed. > > A "flicker filter" is easy to implement in a little > micro-controller for the lowest parts count . . . but unless > you have access to the programming hardware and skills this > could a low-return-on-investment approach. A pure discrete > component approach is illustrated at: > > http://216.55.140.222/temp/Flicker_Filter.pdf > > All the parts are available from Digikey. Timing > for turn-on and turn-off response is set by the > 470K/22uF resistor/capacitor pairs. The constants > shown give you about 11 seconds of delay for uninterrupted > switch closure to turn the light on and the same delay of > uninterrupted switch opening to turn the light back out. > > Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: The Connection Z-13 questions
> > >'Letric Bob and the list, > >I'm configuring my RV-8 as an "all electric plane on a budget". The >battery will be aft mounted for weight and balance considerations. I have >the following questions. > >1) What size current limiter and ammeter shunt is suggested for a 40 amp >alternator, Z-13 shows the values for a 60 amp alt. 40A for both devices. >2) When mounting the battery in the rear of a metal airplane, it was >suggested to me by a friend to ground the battery (-) to a local stout >longeron, then to reconnect to that same longeron for the firewall ground >forest of fast on tabs. I am leaning towards a common ground and running >a seperate 2awg wire forward to the firewall to avoid ground loops. Your >thoughts? Bringing all fat feeders to the common ground point is never a bad decision electrically. It depends on how much one agonizes over the weight of 8' of 2AWG at 4 oz per foot for a total of 2#. History of electrical systems in aviation have suggested that structural parts of the airplane are best designed for holding the airplane together and depending on them for electrical pathways too is problematical. To be sure a couple hundred thousand airplanes HAVE used structural members for electrical tasks but if one is weighing perceptions of relative goodness between two choices, my personal approach would be to keep electrical and structural systems independent of each other as much as practical. I would use local grounds for lights in wings, strobe power supplies and pitot heaters. These are not high current systems and they are neither strong antagonists nor potential victims for noise issues. >3) In looking at Z-13, it seems to me that mounting the battery relay up >on the firewall, instead of back on the battery mount, it simplifies the >connection of the standby alternator to the battery side of the relay if >it is firewall mounted, and shouldn't really matter to the battery if it's >rear or front mounted, right? As long as the wire leading up to it is >sized correctly. See earlier post today on same question . . . Are you going to have a battery bus? If so, you'll need to run some wires back to the battery location to accommodate battery bus powered systems, one more wire for the aux alternator isn't that big of a deal. >4) I am planning on integrating the lo cost GPU connection from the >Connection and for safety mounting the Piper type recepticle in the >rear. If my assumption of #3 above is correct and I do mount the battery >relay up front on the firewall, would it be OK to connect the output of >the GPU solenoid to the battery (+) instead of running another large wire >forward to the battery relay? I wouldn't do that. Battery contactor goes in tail with battery and the ground power contactor can sit right beside the battery contactor. >5) In Z-13, there is a fuse between the Battery bus and the E bus switch >and an additional fuseable link between the switch and the e bus. Why both? The wire between battery bus and e-bus can be powered from EITHER end. The purest would deduce that some form of protection needs to be applied at each end of the feedpath. Since the e-bus alternate feed switch is relatively close to the e-bus, fault risks to the e-bus end are low . . . I'd probably not put a fuse or fuselink in at the e-bus end. I've had some builders assign one of the e-bus fuse slots as an power INPUT connection for the alternate feedpath. If you've got a fuse slot open, this wouldn't be a bad thing to do. You install the same size fuse at the e-bus end as you do for the battery bus end. Bob . . . ________________________________________________________________________________
Subject: Re: RE: E.I. instruments need pampering?
Date: Apr 30, 2003
Hello Bob, I was following this discussion with interest. It seems to have gone quiet now, and I'm wondering if you ever had a satisfactory response from the guys at EI. I'm keen to install the EI engine monitor, but worried about their claim that units have been damaged in normal use. Assuming they are telling the truth, and have had units returned after being damaged, can you suggest a suitable arrangement for filtering the kind of electric surges they discuss, or is it better simply to put the thing on a switched supply, as they suggest? Thanks in anticipation. Kind regards. Neville Kilford ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: RE: E.I. instruments need pampering? > > >Robert L Nukolis III > >Cc: Aeroelectric > > > >Gentlemen: > > > >Electronics International Inc. has been manufacturing aircraft instruments > >for over 20 years and all of our instruments meet and/or exceed the TSO C43a > >standards set by the FAA. The UBG-16 instrument has an operating range of > >7.5 to 30 volts and a 3/10 amp draw. > > > >As in a great number of modern instruments and radios, we are using a fairly > >sophisticated power supply to drive the gas plasma display and the circuit > >boards. Since the aviation industry has not adopted the auto industry > >technique of isolating instruments and accessories from the starting circuit > >during an engine start, there is a possibility of voltage spikes in excess > >of 200 volts through the main bus during the engine start sequence. During > >the start sequence, approximately 100-300 amps is required by the starter. > >This current produces a significantly large magnetic field. When the field > >collapses, a series of voltage pulses (or ringing) will occur on the bus. A > >low battery or an engine that is hard to start can aggravate the situation, > >which is markedly different for each aircraft. > > Is this a condition which is not addressed by the testing > recommendations in DO-160? > > > Over 40 years ago, the > >automotive industry adopted a starter switch that turns off all electrical > >instruments as the key is turned to the start position. The aircraft > >industry adopted the "Radio Bus" or "Avionics Bus" that allows all > >electrical equipment not required during the start sequence to be turned off > >or otherwise isolated. This is the reason for the "pampered avionics bus" > >that is required by Garmin, King, Apollo, STEC, ARNAV, UPS and virtually all > >manufactures of aviation instruments. > > Required or recommended? > > >The "perfectly normal" operating > >condition in a single engine aircraft is well within the UBG-16 operating > >range, but the starting sequence can cause problems for most sophisticated > >electronic instruments. > > I was at Cessna when the avionics master switch was born. This was > in the days of 30v germanium power transistors just finding their > way into the radios of the time. They were indeed fragile > devices. This was before DO-160 came along to guide > us in designing electronics that would withstand > any normal operation of the airplane's electrical system. > Since that time, DO-160 has been through several revisions. > It has been expanded to the extent that we're now advised as to how > to stand off effects of lightning strokes to the airframe. > > > >Electronics International Inc. manufactures over 40 different instruments. > >The UBG-16 is the most complex of the product line and the only one that we > >recommend be isolated from the starting sequence. > > > >Note: If you are operating any sophisticated electrical equipment in your > >aircraft, you need to have a bus that is able to be isolated. > > Please define "sophisticated". Without a doubt I can design > some relatively simple circuits that would be vulnerable to > the stresses of ordinary operation . . . how many and what > kind of parts must be combined before the circuit becomes sophisticated? > > > You can > >simply connect an appropriate switch between the main bus and the breakers > >that drive the selected equipment to allow that equipment to be turned of > >during engine start. > > > >We certainly feel that we are a capable supplier and that there are not any > >shortcomings in the design or fabrication of any of our instruments. If you > >feel that we could improve in one area or another, please feel free to make > >specific constructive suggestions. > > > Can you identify the magnitude, duration and energy content > of the stress that is antagonistic to your products? > May I presume that you've confirmed that the starter > is indeed a source of dangerous stresses and that > the normal course of testing to DO-160 and/or TSO > fails to account for this stress? > > If you can quantify the character of the stress for which > you're unable to guarantee operation, I can be of assistance > in designing an interface suited to protection of > your product. > > > >Thank you, > > > >David Campbell > >Electronics International Inc. > >63296 Powell Butte Highway > >Bend, OR 97701 > >Phone: (541) 318-6060 > >Fax: (541) 318-7575 > >Web: www.Buy-Ei.com > > > Your's truly, > > Bob Nuckolls > > ________________________________________________________________________________
Subject: Makita Battery Charger
Date: Apr 30, 2003
The OCR 3.15 probably stands for over current relay. Maybe the charger is A-OK, maybe the battery has a problem.But if Chris Stones' suggestions don't find a cell problem I have two suggestions: 1) Call a local Makita service center, and maybe (?) they will sell you just the part. Sometime it just depends on who you get to talk to. Ask for the gray-beard. 2) Ebay has 90 Makita battery chargers for sale cheap. Just grab one. Probably cost you less than messing around. Later, Eric M. Jones ________________________________________________________________________________
Date: Apr 30, 2003
Subject: LVWM
Bob- I purchased your LVWM (12 volt) with the incandescent bulb option prior to converting to all LEDs for my annunciator & panel lighting, and would like to use it with the following LED bar module from DigiKey: http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=404&M=MU04-4101 This is an array of 3 superbright LEDs molded into a plastic block. I've have one of the red arrays powered up and intentionally overdriven at 50 mA, measured with a Fluke VOM (180 ohm res, LEDs in series) to determine longevity at an acceptable brightness level. Still fine after a week continuous, but the resistor (1 watt) is running about 150 degrees according to thermographic scanning. My calculations indicate this should actually be a 390 for 20 mA operation, but it is just too dim at that current level. Duty cycle on this array should not be a factor, as I hope to rarely see it lit! Can I simply install this arrangement wired to the appropriate LVWM terminals in place of the incandescent? Also- sorry to nag ya about this, but curious as to progress on the Audio Isolation Amplifier........ Thanks! Mark Phillips - RV-6A - spaghetti on the front burner...... ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: Simple timer for low fuel warning . . .
> > >"Robert L. Nuckolls, III" wrote: >A pure discrete component approach is illustrated at: > > > http://216.55.140.222/temp/Flicker_Filter.pdf > > > > Timing for turn-on and turn-off response is set by the > > 470K/22uF resistor/capacitor pairs. The constants > > shown give you about 11 seconds of delay > > > Bob . . . > > > >The drawing at the location above has 470K/10uF resistor/capacitor >pairs shown. Does the eleven seconds derive from replacing the 470/10 >with 470/22 ? or from the 470/10 as shown in the drawing?? Opps. . . I was laying out a board for this diagram and downsized from 22uF to 10uf to save some cost and boardspace . . . this means that the resistors would have to be INCREASED to about 1 meg to get timing in the 10 second range with 10uF caps. Thanks for the heads up. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
"Jim Younkin" > > >Hello Bob, > >I was following this discussion with interest. It seems to have gone quiet >now, and I'm wondering if you ever had a satisfactory response from the guys >at EI. > >I'm keen to install the EI engine monitor, but worried about their claim that >units have been damaged in normal use. Assuming they are telling the truth, >and have had units returned after being damaged, can you suggest a suitable >arrangement for filtering the kind of electric surges they discuss, or is it >better simply to put the thing on a switched supply, as they suggest? > >Thanks in anticipation. Nope, haven't heard a peep since I my last message to David Campbell on 4/3. I've not heard from Jim Younkin either. It's typical. I've asked dozens of engineers with various manufacturers of avionics to cite a justification for cautionary recommendations about powering their products. In most cases, conversations by e-mail and/or snail-mail just peter out . . . they ignore me an hope I'll go away. I'm working on a letter that I plan to send to every manufacturer of avionics I can find and explain that I'm researching the validity of DO-160 in its current state. If their engineering staff can point out any data which demonstrates that DO-160 testing does NOT adequately account for transients from starters or any other source, would they please share this information. I'm going to write an article to publish the results of this survey that will include any new information I can confirm by repeatable experiment or critical review of a published article. I think it's time to get these folks to either put up or shut up. If DO-160 is inadequate, then there are a whole lot of folks who need to know about it. If DO-160 is adequate, then they need to dump the antiquated dogma crafted in years gone by. There is no excuse for a modern supplier to operate with their head in the sand on this issue. There are no secrets but lots of un-verifiable stories. When the letter goes out, I'll publish the list of folks who got the letter. I'll also solicit suggestions from you folks for suppliers I've missed. All correspondence will be published on my website. After a suitable period of time, I'll see if someone like Light Plane Maintenance is interested in a formal article addressing this issue. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
> >Thanks for the circuit Bob! > >I'm a bit lost here. When I search for those part numbers (DigiKey) I >get multiple results (CD4093 = 9, IN4148 = 16). I really don't have a >clue which ones to order. Does it matter? Do I just pick any one of >them and go? Variations on a part number speak to packages. Some may be surface mount, or rated at different operating temperatures etc. You need to check the part number you're considering against the package you're prepared to work with. I'm working a board layout to use surface mount parts . . . it's going to be quite small. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Small Sealed Batteries
Listers: I am building an all electric Lancair IV and am planning on a single alternator, two same sized sealed battery system ala fig 17-6 in THE BOOK and doing an annual battery rotation. I would like to get the batteries off the firewall (which is already very crowded) and put them in a friendler environment, like under the floor boards. So I am looking for the SMALLEST size (weight is less a concern) battery suitable for the task with greater than 13ahs. I would also like a battery that will be available for a while as I do not want to rebuild a customized battery box each time I need to replace a battery. Right now the best I have found is the Panasonic LC-RD1217 17ah which measures 6.6x7.2x3 inches. Anyone out there know of a smaller alternative? thanks, paul ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Re: Small Sealed Batteries
> >Listers: I am building an all electric Lancair IV and am planning on a >single alternator, two same sized sealed battery system ala fig 17-6 in THE >BOOK and doing an annual battery rotation. I would like to get the batteries >off the firewall (which is already very crowded) and put them in a friendler >environment, like under the floor boards. with a 3" thickness, can you lay a 17 a.h. down on its side and tuck it under the floor? This sounds pretty good to me . . . > So I am looking for the SMALLEST >size (weight is less a concern) battery suitable for the task with greater >than 13ahs. I would also like a battery that will be available for a while >as I do not want to rebuild a customized battery box each time I need to >replace a battery. Why built any battery box . . . these things are happier outside of an enclosure. Strap them down in a tray and let 'em breathe . . . > Right now the best I have found is the Panasonic >LC-RD1217 17ah which measures 6.6x7.2x3 inches. Anyone out there know of a >smaller alternative? thanks, paul The only cranking battery smaller is a 10 a.h. device by B&C that is a unique, single-source product. The 17 a.h. battery you've cited above is made by LOTS of folks. Bob . . . Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Apr 30, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Re: Audio Hi-Lo
DHPHKH(at)aol.com wrote: > >Gang, > Can somebody please tell me about "Audio Hi" and "Audio Lo" connections >on radios and intercoms? Why Hi and Lo, what is the difference, what purpose >is served, etc? > >Thanks >Dan Horton > Typically, 'hi' is the actual signal and 'lo' is the return or 'ground' for that signal. It's possible that manufacturers are avoiding using the term 'ground' because installers with 'a little learning' might assume that since the various 'lo's' are all 'grounds', they can be combined in any convenient fashion. If this is done, the probability of noisy operation with hums, buzzes, etc is greatly increased. Charlie ________________________________________________________________________________
Date: May 01, 2003
> >5) In Z-13, there is a fuse between the Battery bus and the E bus switch > >and an additional fuseable link between the switch and the e bus. Why both? > > The wire between battery bus and e-bus can be powered from EITHER > end. The purest would deduce that some form of protection needs > to be applied at each end of the feedpath. How can e-buss be powered from either direction. The diode Between e-buss and main buss should see to that. Please explain because I'm not understanding. Thanks, Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Working on Canopy of Finish Kit ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: The Connection Z-13 questions > > > > > > >'Letric Bob and the list, > > > >I'm configuring my RV-8 as an "all electric plane on a budget". The > >battery will be aft mounted for weight and balance considerations. I have > >the following questions. > > > >1) What size current limiter and ammeter shunt is suggested for a 40 amp > >alternator, Z-13 shows the values for a 60 amp alt. > > 40A for both devices. > > > >2) When mounting the battery in the rear of a metal airplane, it was > >suggested to me by a friend to ground the battery (-) to a local stout > >longeron, then to reconnect to that same longeron for the firewall ground > >forest of fast on tabs. I am leaning towards a common ground and running > >a seperate 2awg wire forward to the firewall to avoid ground loops. Your > >thoughts? > > Bringing all fat feeders to the common ground point > is never a bad decision electrically. It depends on how > much one agonizes over the weight of 8' of 2AWG at > 4 oz per foot for a total of 2#. > > History of electrical systems in aviation have suggested > that structural parts of the airplane are best designed > for holding the airplane together and depending on them > for electrical pathways too is problematical. To be sure > a couple hundred thousand airplanes HAVE used structural > members for electrical tasks but if one is weighing perceptions > of relative goodness between two choices, my personal > approach would be to keep electrical and structural systems > independent of each other as much as practical. > > I would use local grounds for lights in wings, strobe > power supplies and pitot heaters. These are not high > current systems and they are neither strong antagonists > nor potential victims for noise issues. > > > >3) In looking at Z-13, it seems to me that mounting the battery relay up > >on the firewall, instead of back on the battery mount, it simplifies the > >connection of the standby alternator to the battery side of the relay if > >it is firewall mounted, and shouldn't really matter to the battery if it's > >rear or front mounted, right? As long as the wire leading up to it is > >sized correctly. > > See earlier post today on same question . . . > > Are you going to have a battery bus? If so, you'll need > to run some wires back to the battery location to accommodate > battery bus powered systems, one more wire for the > aux alternator isn't that big of a deal. > > >4) I am planning on integrating the lo cost GPU connection from the > >Connection and for safety mounting the Piper type recepticle in the > >rear. If my assumption of #3 above is correct and I do mount the battery > >relay up front on the firewall, would it be OK to connect the output of > >the GPU solenoid to the battery (+) instead of running another large wire > >forward to the battery relay? > > I wouldn't do that. Battery contactor goes in tail with > battery and the ground power contactor can sit right beside > the battery contactor. > > >5) In Z-13, there is a fuse between the Battery bus and the E bus switch > >and an additional fuseable link between the switch and the e bus. Why both? > > The wire between battery bus and e-bus can be powered from EITHER > end. The purest would deduce that some form of protection needs > to be applied at each end of the feedpath. Since the e-bus alternate > feed switch is relatively close to the e-bus, fault risks to the > e-bus end are low . . . I'd probably not put a fuse or fuselink in > at the e-bus end. I've had some builders assign one of the e-bus > fuse slots as an power INPUT connection for the alternate feedpath. > If you've got a fuse slot open, this wouldn't be a bad thing to > do. You install the same size fuse at the e-bus end as you do for > the battery bus end. > > Bob . . . > > ________________________________________________________________________________
Subject: Hall Sensor Mounting
Date: Apr 30, 2003
Does anyone have any pictures (or good explanations) of how they mounted thier Hall Sensor? It looks like a dangling dounught and I want to make sure it is secured well. - Jim ________________________________________________________________________________
Date: Apr 30, 2003
> > > > >5) In Z-13, there is a fuse between the Battery bus and the E bus >switch > > >and an additional fuseable link between the switch and the e bus. Why >both? > > > > The wire between battery bus and e-bus can be powered from EITHER > > end. The purest would deduce that some form of protection needs > > to be applied at each end of the feedpath. > >How can e-buss be powered from either direction. The diode Between e-buss >and main buss should see to that. > >Please explain because I'm not understanding. The wire that runs from the battery bus through the alternate feed switch and to the e-bus can get power from EITHER the e-bus OR the battery. I.e., sourced from either end. If you're going to protect this wire from ALL potential faults to ground, you put protection in BOTH ends . . . Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
Are you suggesting that putting the batteries behind the seats is a bad idea, because of the long wire runs, or putting the contactors on the firewall with the batteries behind the seat is a bad idea??? A lot of RV-8's with 200 horsepower engines I remember have to put batteries behind the seats for ballast. I don't envy the idea of doing something that is not sound. Jeff (RV-8 Wings) ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Battery Contactor - Location? > > > >Any way, while doing the diagram I started thinking that I'd like to put > >the battery contactor on or near the firewall. However, my battery is > >located just behind the seats so I was worried that since I've seen it > >mentioned that the battery contactor should be within 12 inches or so of > >the battery that I was violating some golden rule. However, the only > >reason I could find for placing the contactor so close to the battery > >was a possible safety issue of having a large current HOT wire running > >through half the plane. > > > >If this is so, how much of safety issue is it? Are there any other > >reasons for placing the contactor next to the battery? > > I suppose there are folks who would endeavor to assign > qualifiers of magnitude on an answer, e.g. "Running > a 10' long always hot battery feeder to a remotely mounted > contactor is 15.9 times more likely to set your bunnies on > fire in a crash than a feeder that is 1 foot long". > Suppose I had a rational for such a statement, would > this have any useful meaning for you in making your > architecture decision? If I tossed a number out, how > would you select a decision-making value? 4.2 times more > likely? 7.3 times more likely? > > It's an intuitive and inarguable fact that minimizing > both the number, lengths and potential for high fault > currents in always-hot feeders is a "good" thing to do. Bottom > line is that you need to evaluate your own perceptions of > goodness against perceptions of convenience. I wouldn't > do what you propose in my airplane. You wouldn't get > it certified in a Cessna either . . . > > Bob . . . > > ________________________________________________________________________________
Date: Apr 30, 2003
The issue as I understand it (and take that for what it's worth) is that you want to avoid long runs of wire from which you cannot remove power. If the battery is behind the seat and the contactor is on the firewall then there is a long wire that is always hot no matter what you do with the master switch. If you put the contactor near the battery then when you turn the master off you simply have a short fat wire that is hot but is easily contained and has less chance of arcing on something and causing a fire during / after a 'not-so-good' landing. If it were me and I had to decide on a battery that was located behind me I would make sure that it was very well secured because I want that thing to stay put if I ever have one of those 'landings.' If it is on the firewall it will be heading away from me if it comes loose, but behind the seat it will be headed for me (or my passenger). Bolt it down solid, use an RG battery that won't spill acid all over you and put the contactor as close as possible to the battery and I can't think of any reason why having it in the back would cause you any grief. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "Jeffrey" <dump(at)relaypoint.net> Subject: Re: AeroElectric-List: Battery Contactor - Location? > > Are you suggesting that putting the batteries behind the seats is a bad > idea, because of the long wire runs, or putting the contactors on the > firewall with the batteries behind the seat is a bad idea??? A lot of > RV-8's with 200 horsepower engines I remember have to put batteries behind > the seats for ballast. > > I don't envy the idea of doing something that is not sound. > > Jeff > (RV-8 Wings) > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Battery Contactor - Location? > > > > > > > > > >Any way, while doing the diagram I started thinking that I'd like to put > > >the battery contactor on or near the firewall. However, my battery is > > >located just behind the seats so I was worried that since I've seen it > > >mentioned that the battery contactor should be within 12 inches or so of > > >the battery that I was violating some golden rule. However, the only > > >reason I could find for placing the contactor so close to the battery > > >was a possible safety issue of having a large current HOT wire running > > >through half the plane. > > > > > >If this is so, how much of safety issue is it? Are there any other > > >reasons for placing the contactor next to the battery? > > > > I suppose there are folks who would endeavor to assign > > qualifiers of magnitude on an answer, e.g. "Running > > a 10' long always hot battery feeder to a remotely mounted > > contactor is 15.9 times more likely to set your bunnies on > > fire in a crash than a feeder that is 1 foot long". > > Suppose I had a rational for such a statement, would > > this have any useful meaning for you in making your > > architecture decision? If I tossed a number out, how > > would you select a decision-making value? 4.2 times more > > likely? 7.3 times more likely? > > > > It's an intuitive and inarguable fact that minimizing > > both the number, lengths and potential for high fault > > currents in always-hot feeders is a "good" thing to do. Bottom > > line is that you need to evaluate your own perceptions of > > goodness against perceptions of convenience. I wouldn't > > do what you propose in my airplane. You wouldn't get > > it certified in a Cessna either . . . > > > > Bob . . . > > > > > > ________________________________________________________________________________
From: Livingston John W Civ ASC/ENFD <John.Livingston(at)wpafb.af.mil>
Date: Apr 30, 2003
As a rule of thumb one should design items in the fuselage to withstand at least 10 forward g's, (I'm not sure what the FAR's currently say) since this is a very survivable load for a well belted pilot. So, for a 20lb battery withstanding 10 g's with a typical safety factor of 1.5, we have a load of 300 lbs. Not hard to do, but very important if you want to walk away from a crash. Same goes for anything in the fuselage, but most importantly for things behind you. John -----Original Message----- From: Phil Birkelbach [mailto:phil(at)petrasoft.net] Subject: Re: AeroElectric-List: Battery Contactor - Location? The issue as I understand it (and take that for what it's worth) is that you want to avoid long runs of wire from which you cannot remove power. If the battery is behind the seat and the contactor is on the firewall then there is a long wire that is always hot no matter what you do with the master switch. If you put the contactor near the battery then when you turn the master off you simply have a short fat wire that is hot but is easily contained and has less chance of arcing on something and causing a fire during / after a 'not-so-good' landing. If it were me and I had to decide on a battery that was located behind me I would make sure that it was very well secured because I want that thing to stay put if I ever have one of those 'landings.' If it is on the firewall it will be heading away from me if it comes loose, but behind the seat it will be headed for me (or my passenger). Bolt it down solid, use an RG battery that won't spill acid all over you and put the contactor as close as possible to the battery and I can't think of any reason why having it in the back would cause you any grief. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "Jeffrey" <dump(at)relaypoint.net> Subject: Re: AeroElectric-List: Battery Contactor - Location? > > Are you suggesting that putting the batteries behind the seats is a bad > idea, because of the long wire runs, or putting the contactors on the > firewall with the batteries behind the seat is a bad idea??? A lot of > RV-8's with 200 horsepower engines I remember have to put batteries behind > the seats for ballast. > > I don't envy the idea of doing something that is not sound. > > Jeff > (RV-8 Wings) > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Battery Contactor - Location? > > > > > > > > > >Any way, while doing the diagram I started thinking that I'd like to put > > >the battery contactor on or near the firewall. However, my battery is > > >located just behind the seats so I was worried that since I've seen it > > >mentioned that the battery contactor should be within 12 inches or so of > > >the battery that I was violating some golden rule. However, the only > > >reason I could find for placing the contactor so close to the battery > > >was a possible safety issue of having a large current HOT wire running > > >through half the plane. > > > > > >If this is so, how much of safety issue is it? Are there any other > > >reasons for placing the contactor next to the battery? > > > > I suppose there are folks who would endeavor to assign > > qualifiers of magnitude on an answer, e.g. "Running > > a 10' long always hot battery feeder to a remotely mounted > > contactor is 15.9 times more likely to set your bunnies on > > fire in a crash than a feeder that is 1 foot long". > > Suppose I had a rational for such a statement, would > > this have any useful meaning for you in making your > > architecture decision? If I tossed a number out, how > > would you select a decision-making value? 4.2 times more > > likely? 7.3 times more likely? > > > > It's an intuitive and inarguable fact that minimizing > > both the number, lengths and potential for high fault > > currents in always-hot feeders is a "good" thing to do. Bottom > > line is that you need to evaluate your own perceptions of > > goodness against perceptions of convenience. I wouldn't > > do what you propose in my airplane. You wouldn't get > > it certified in a Cessna either . . . > > > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Apr 30, 2003
> >Are you suggesting that putting the batteries behind the seats is a bad >idea, because of the long wire runs, or putting the contactors on the >firewall with the batteries behind the seat is a bad idea??? A lot of >RV-8's with 200 horsepower engines I remember have to put batteries behind >the seats for ballast. > >I don't envy the idea of doing something that is not sound. Not at all . . . your question had to do with location of battery contactor. You can mount the battery in any location you like as dictated by volume, weight, available structure to attach and weight/balance issues. Indeed, batteries are found all over light aircraft. A friend of mine has a BD-4 with large engine and constant speed prop . . . his battery is literally inches in front of leading edge of stabilizer. Wherever the battery goes, battery contactor and battery bus are best located nearby for greatest crash safety. Consider also that a 15 pound battery needs to have tie- down good for at least 10x weight or 150 lbs. A couple of 1" web straps with 6" of over-lapped Velcro is a mechanic friendly technique for holding the battery in its tray. Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
<> Which explains why some diagrams show shields connected to "Lo". Thanks Charlie. Dan ________________________________________________________________________________
Date: Apr 30, 2003
Bob, Thanks for the good information and explanation. I definitely appreciate your efforts to not only answer questions but explain the reasons behind the answers. Regards, Don -----Original Message----- From: Phil Birkelbach [mailto:phil(at)petrasoft.net] Subject: Re: AeroElectric-List: Battery Contactor - Location? --> The issue as I understand it (and take that for what it's worth) is that you want to avoid long runs of wire from which you cannot remove power. If the battery is behind the seat and the contactor is on the firewall then there is a long wire that is always hot no matter what you do with the master switch. If you put the contactor near the battery then when you turn the master off you simply have a short fat wire that is hot but is easily contained and has less chance of arcing on something and causing a fire during / after a 'not-so-good' landing. If it were me and I had to decide on a battery that was located behind me I would make sure that it was very well secured because I want that thing to stay put if I ever have one of those 'landings.' If it is on the firewall it will be heading away from me if it comes loose, but behind the seat it will be headed for me (or my passenger). Bolt it down solid, use an RG battery that won't spill acid all over you and put the contactor as close as possible to the battery and I can't think of any reason why having it in the back would cause you any grief. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Fuselage http://www.myrv7.com ----- Original Message ----- From: "Jeffrey" <dump(at)relaypoint.net> Subject: Re: AeroElectric-List: Battery Contactor - Location? > --> > > Are you suggesting that putting the batteries behind the seats is a > bad idea, because of the long wire runs, or putting the contactors on > the firewall with the batteries behind the seat is a bad idea??? A > lot of RV-8's with 200 horsepower engines I remember have to put > batteries behind the seats for ballast. > > I don't envy the idea of doing something that is not sound. > > Jeff > (RV-8 Wings) > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > To: > Subject: Re: AeroElectric-List: Battery Contactor - Location? > > > > > > > > > >Any way, while doing the diagram I started thinking that I'd like > > >to put > > >the battery contactor on or near the firewall. However, my battery > > >is located just behind the seats so I was worried that since I've > > >seen it mentioned that the battery contactor should be within 12 > > >inches or so of > > >the battery that I was violating some golden rule. However, the > > >only reason I could find for placing the contactor so close to the > > >battery was a possible safety issue of having a large current HOT > > >wire running through half the plane. > > > > > >If this is so, how much of safety issue is it? Are there any other > > >reasons for placing the contactor next to the battery? > > > > I suppose there are folks who would endeavor to assign > > qualifiers of magnitude on an answer, e.g. "Running > > a 10' long always hot battery feeder to a remotely mounted > > contactor is 15.9 times more likely to set your bunnies on > > fire in a crash than a feeder that is 1 foot long". > > Suppose I had a rational for such a statement, would > > this have any useful meaning for you in making your > > architecture decision? If I tossed a number out, how > > would you select a decision-making value? 4.2 times more > > likely? 7.3 times more likely? > > > > It's an intuitive and inarguable fact that minimizing > > both the number, lengths and potential for high fault > > currents in always-hot feeders is a "good" thing to do. Bottom > > line is that you need to evaluate your own perceptions of > > goodness against perceptions of convenience. I wouldn't > > do what you propose in my airplane. You wouldn't get > > it certified in a Cessna either . . . > > > > Bob . . . > > > > > > direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Apr 30, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
I must agree that the battery MUST be held in place to with stand I would think at least 15 G's if not 20. The last thing you want is that battery breaking loose during an unfortunate off field landing/crash and then turning into a projectile. > >The issue as I understand it (and take that for what it's worth) is that you >want to avoid long runs of wire from which you cannot remove power. If the >battery is behind the seat and the contactor is on the firewall then there >is a long wire that is always hot no matter what you do with the master >switch. If you put the contactor near the battery then when you turn the >master off you simply have a short fat wire that is hot but is easily >contained and has less chance of arcing on something and causing a fire >during / after a 'not-so-good' landing. > >If it were me and I had to decide on a battery that was located behind me I >would make sure that it was very well secured because I want that thing to >stay put if I ever have one of those 'landings.' If it is on the firewall >it will be heading away from me if it comes loose, but behind the seat it >will be headed for me (or my passenger). Bolt it down solid, use an RG >battery that won't spill acid all over you and put the contactor as close as >possible to the battery and I can't think of any reason why having it in the >back would cause you any grief. > >Godspeed, > >Phil Birkelbach - Houston Texas >RV-7 N727WB (Reserved) - Fuselage >http://www.myrv7.com > >----- Original Message ----- >From: "Jeffrey" <dump(at)relaypoint.net> >To: >Subject: Re: AeroElectric-List: Battery Contactor - Location? > > >> >> Are you suggesting that putting the batteries behind the seats is a bad >> idea, because of the long wire runs, or putting the contactors on the >> firewall with the batteries behind the seat is a bad idea??? A lot of >> RV-8's with 200 horsepower engines I remember have to put batteries behind >> the seats for ballast. >> >> I don't envy the idea of doing something that is not sound. >> >> Jeff >> (RV-8 Wings) >> >> ----- Original Message ----- >> From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> >> To: >> Subject: Re: AeroElectric-List: Battery Contactor - Location? >> >> >> >> > >> > >> > >Any way, while doing the diagram I started thinking that I'd like to >put >> > >the battery contactor on or near the firewall. However, my battery is >> > >located just behind the seats so I was worried that since I've seen it >> > >mentioned that the battery contactor should be within 12 inches or so >of >> > >the battery that I was violating some golden rule. However, the only >> > >reason I could find for placing the contactor so close to the battery >> > >was a possible safety issue of having a large current HOT wire running >> > >through half the plane. >> > > >> > >If this is so, how much of safety issue is it? Are there any other >> > >reasons for placing the contactor next to the battery? >> > >> > I suppose there are folks who would endeavor to assign >> > qualifiers of magnitude on an answer, e.g. "Running >> > a 10' long always hot battery feeder to a remotely mounted >> > contactor is 15.9 times more likely to set your bunnies on >> > fire in a crash than a feeder that is 1 foot long". >> > Suppose I had a rational for such a statement, would >> > this have any useful meaning for you in making your >> > architecture decision? If I tossed a number out, how >> > would you select a decision-making value? 4.2 times more >> > likely? 7.3 times more likely? >> > >> > It's an intuitive and inarguable fact that minimizing >> > both the number, lengths and potential for high fault >> > currents in always-hot feeders is a "good" thing to do. Bottom >> > line is that you need to evaluate your own perceptions of >> > goodness against perceptions of convenience. I wouldn't >> > do what you propose in my airplane. You wouldn't get >> > it certified in a Cessna either . . . >> > >> > Bob . . . >> > >> > >> >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Apr 30, 2003
Subject: Z15B?
Bob Could you explain why Z15B is not a good Idea.=A0=A0=A0 That particular architecture would work well for the velocity where the #2AWG runs in a duct from firewall through canard bulkhead right to the batteries. A seperate # 4AWG could come from the panel ground block on the panel and to the batteries via a different route.=A0 If you dont recommend this then I would have to cut through the duct inside the cabin behind the panel run the #2 wire up to the panel ground presumable on the panel and then back down into the duct to go to the battery. It would be a lot of heavy wire inside the cabin and onto the panel.=A0 Is there a better way I'm not seeing?=A0=A0=A0=A0 Thanks Tim Z-15B is not a good idea and will be revised at next revision =A0 to bring battery and 2AWG engine grounds together at the =A0 ground bus. ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: IEEE guide
Date: Apr 30, 2003
Bob and all, A fellow builder just sent me a CD Rom with a copy of an 'IEEE guide for aircraft electric systems' in pdf format. Most interesting. a few pages missing though. FWIW, Regards Gilles ________________________________________________________________________________
Date: Apr 30, 2003
Jeff - Bob has stated a number of times: Put the battery(ies) in the back if needed for ballast. Or up front (canard) for ballast. Just put the contactor for each battery very near to the battery. Just use 2AWG from the batteries up to the firewall. Might get by with 4AWG if the battery capacity/wire length compute out OK. John Lancair ES wi/ batteries way back in the tail. > Are you suggesting that putting the batteries behind the seats is a bad > idea, because of the long wire runs, or putting the contactors on the > firewall with the batteries behind the seat is a bad idea??? A lot of > RV-8's with 200 horsepower engines I remember have to put batteries > behind > the seats for ballast. > > ________________________________________________________________________________
Subject: Re: RE: E.I. instruments need pampering? "Jim Younkin"
Date: Apr 30, 2003
Excellent plan, Bob. This effort will result in a mixture of good responses and some silence from some corners, but overall, it is bound to generate enough heat and pressure to do some good. I really like your intelligent sense of initiative, responsibility, and integrity. David Carter ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: RE: E.I. instruments need pampering? "Jim Younkin" > > > > > > >Hello Bob, > > > >I was following this discussion with interest. It seems to have gone quiet > >now, and I'm wondering if you ever had a satisfactory response from the guys > >at EI. > > > >I'm keen to install the EI engine monitor, but worried about their claim that > >units have been damaged in normal use. Assuming they are telling the truth, > >and have had units returned after being damaged, can you suggest a suitable > >arrangement for filtering the kind of electric surges they discuss, or is it > >better simply to put the thing on a switched supply, as they suggest? > > > >Thanks in anticipation. > > Nope, haven't heard a peep since I my last message to > David Campbell on 4/3. I've not heard from Jim Younkin either. > > It's typical. I've asked dozens of engineers with various > manufacturers of avionics to cite a justification for > cautionary recommendations about powering their products. > In most cases, conversations by e-mail and/or snail-mail > just peter out . . . they ignore me an hope I'll go away. > > I'm working on a letter that I plan to send to every manufacturer > of avionics I can find and explain that I'm researching the > validity of DO-160 in its current state. If their engineering > staff can point out any data which demonstrates that DO-160 > testing does NOT adequately account for transients from > starters or any other source, would they please share this > information. > > I'm going to write an article to publish the results > of this survey that will include any new information I can > confirm by repeatable experiment or critical review of > a published article. I think it's time to get these folks > to either put up or shut up. If DO-160 is inadequate, then > there are a whole lot of folks who need to know about it. > > If DO-160 is adequate, then they need to dump the antiquated > dogma crafted in years gone by. There is no excuse for > a modern supplier to operate with their head in the sand > on this issue. There are no secrets but lots of un-verifiable > stories. > > When the letter goes out, I'll publish the list of folks > who got the letter. I'll also solicit suggestions from > you folks for suppliers I've missed. All correspondence > will be published on my website. After a suitable period > of time, I'll see if someone like Light Plane Maintenance > is interested in a formal article addressing this issue. > > Bob . . . > ________________________________________________________________________________
Date: Apr 30, 2003
Thanks everyone, that sure is re-assuring. Jeff (RV-8 Wings) ----- Original Message ----- From: "John Schroeder" <jschroeder(at)perigee.net> Subject: Re: AeroElectric-List: Battery Contactor - Location? > > Jeff - > > Bob has stated a number of times: Put the battery(ies) in the back if > needed for ballast. Or up front (canard) for ballast. Just put the > contactor for each battery very near to the battery. Just use 2AWG from the > batteries up to the firewall. Might get by with 4AWG if the battery > capacity/wire length compute out OK. > > John > Lancair ES wi/ batteries way back in the tail. > > > > Are you suggesting that putting the batteries behind the seats is a bad > > idea, because of the long wire runs, or putting the contactors on the > > firewall with the batteries behind the seat is a bad idea??? A lot of > > RV-8's with 200 horsepower engines I remember have to put batteries > > behind > > the seats for ballast. > > > > > > ________________________________________________________________________________
Subject: Simple timer for low fuel warning . . .
Date: Apr 30, 2003
Hi Jon; It's best to pick the cheapest one... It will be easier to explane (pun?) to Pamela ;-) Seriously, there may be some packaging/case differences which you'll want to consider (usually designated by one or more letter following the main part number). In some cases the temperature range over which the part may be used is partly controlled by the packaging. You can go with the most limited temperature range which is often designated 'P' or 'N' for plastic packaging. For hand built stuff it's usually best to use "DIP" (Dual Inline Plastic) packages rather than the tiny surface mount packages. So, using your example; the CD4093B (the 'B' is part of the part number that is often left off these days because the earlier 'A' model is no longer available) in the DIP package/case from Texas Instruments is Digi-Key part number 296-2068-5-ND. The 1N4148 (that's a leading number one (1) not I ('eye')) will be most useful in the axial lead form so use the DO-35 packaging/case. By the way, most all of these components are probably available at your local Radio Shack store where you will be able to fondle them first, before you buy. Then you be able to buy all the other stuff... perf-board or copper-clad, terminal lugs, sockets, bits and pieces of the very small gauge wire, rosin core solder, spaghetti (insulation), ... etc., etc., etc. Regards, -john- -----Original Message----- From: Jon Finley [mailto:jon(at)finleyweb.net] Subject: RE: AeroElectric-List: Simple timer for low fuel warning . . . Thanks for the circuit Bob! I'm a bit lost here. When I search for those part numbers (DigiKey) I get multiple results (CD4093 = 9, IN4148 = 16). I really don't have a clue which ones to order. Does it matter? Do I just pick any one of them and go? Jon "Clueless and Cold in Minneapolis" Finley N90MG Q2 - Subaru EJ-22 DD - 440 Hrs. TT - 0 Hrs Engine Apple Valley, Minnesota http://www.FinleyWeb.net/default.asp?id=96 > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Robert L. Nuckolls, III > Sent: Tuesday, April 29, 2003 2:12 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Simple timer for low fuel warning . . . > > > --> > > What you're looking for is more than a simple timer . . . and > a brief look at the replies on this topic didn't pick up on > what's needed. > > A "flicker filter" is easy to implement in a little > micro-controller for the lowest parts count . . . but unless > you have access to the programming hardware and skills this > could a low-return-on-investment approach. A pure discrete > component approach is illustrated at: > > http://216.55.140.222/temp/Flicker_Filter.pdf > > All the parts are available from Digikey. Timing > for turn-on and turn-off response is set by the > 470K/22uF resistor/capacitor pairs. The constants > shown give you about 11 seconds of delay for uninterrupted > switch closure to turn the light on and the same delay of > uninterrupted switch opening to turn the light back out. > > Bob . . . ________________________________________________________________________________
Date: Apr 30, 2003
><bilinski@kyocera-wireless.com> > >I must agree that the battery MUST be held in place to with stand I would >think at least 15 G's if not 20. The last thing you want is that battery >breaking loose during an unfortunate off field landing/crash and then >turning into a projectile. . . . there used to be a retired highway patrol officer who managed to passed himself off as an expert in accident analysis. After all, in 25+ years of service as a peace officer, he had "investigated" plenty of accidents. I ran across a number of his presentations over the years that I worked in accident analysis with Ken Razak here in Wichita. The officer acquired a nickname in the trade . . . "20G Stackley". No matter how vehicles came together in the various accidents, 20G's would show up in his calculations somewhere on nearly every case . . . it seemed like a good round number, why not make the best of it? When you figure that your airplane weighs about 1000 pounds and has to put 10,000 pounds of retarding force into the mass to produce a 10G slowing acceleration . . . exactly what part of your airplane would you expect to resist with this 10,000 pound force? As it turns out, the crumpling up of metal during a crash has to occur because no part of the airplane can maintain its shape with a 10,000 pound push . . . 20,000 pounds of push are equally un-achievable. For crash safety, DO-160 calls out qualifying your attachment hardware and brackets to 10G and that represents a conservative value . . . the vast majority of airframe structure and internal components are never subjected to anything approaching 10G in a survivable crash. Now, drive your airplane into a mountainside at 200kts and you can count on things seeing a lot more than 10G . . . but it doesn't matter much. In that case, if your battery doesn't kill you, the mountain most certainly will. Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: E.I. instruments need pampering?
>Here again is the copy that we have sent to you, which you claim was never >sent. > > >Mac S. Speed >Electronics International Inc. >63296 Powell Butte Highway >Bend, OR 97701 >Phone: (541) 318-6060 >Fax: (541) 318-7575 >Web: www.Buy-Ei.com > >-----Original Message----- >From: EI Tech Support [mailto:Sales@Buy-Ei.com] >Sent: Monday, April 07, 2003 2:32 PM >To: 'Robert L. Nuckolls, III' >Subject: RE: E.I. instruments need pampering? > >We would like to respond to your questions of Friday- > >1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt to a -22 >volt intermittent transient test for a 28 volt system and a +39 volt to a >-11 volt test for a 12 volt system each with 50 ohm output impedance. In >our opinion this test is not stringent enough for an instrument to survive >on the main bus during an engine start on most aircraft. All of our >instruments can survive transients that are well over the DO-160 >requirement. Mac, I DID receive the note you've copied above. I replied to David's letter the same day with amplifying questions. I found a copy of my reply in my archival files but didn't see that it was actually sent. My apologies, the ball was indeed still in my court. Here's the message I neglected to forward to you on 4/7 . . . ---------- David Campbell's letter and Nuckolls' reply of 4/7/3 --------- >We would like to respond to your questions of Friday- > >1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt to a -22 >volt intermittent transient test for a 28 volt system and a +39 volt to a >-11 volt test for a 12 volt system each with 50 ohm output impedance. In >our opinion this test is not stringent enough for an instrument to survive >on the main bus during an engine start on most aircraft. I am mystified by the numbers cited above. My copy of DO-160D speaks to a +/-300 v capacitively stored spike delivered through an air-core transformer and tailored for a 50-ohm source impedance. 28V system tests call for a +/-600 volt event. What change level is your copy of DO-160? Perhaps I'm out of date. Please cite a basis for your opinion. What is the amplitude, waveform and duration of any transients you have observed and > . . . . . All of our >instruments can survive transients that are well over the DO-160 >requirement. 2). It is our understanding the industry standard for most electronic >aircraft instrument installation is to install on an avionics or radio bus. >We just installed an Apollo GX-60, SL-30, ACU, MX-20, SL-15, Garmin GTX 327, >550/20 encoder, NSD-360 H.S.I. and many other pieces of equipment, and the >install documentation made it clear that these instruments should be >installed on the radio or avionics bus (isolating them from the starting >sequence). It is indeed a "practice" originally promulgated by the notion that the root cause of lots of dead transistors at Cessna and elsewhere was "spikes" from the starter. This was the early days of low voltage, germanium transistors that were showing up in audio and power supply circuits in the current crop of aircraft radios. I cannot attest to studies done elsewhere but at Cessna, there were NO actual spikes captured, quantified and deemed antagonistic to our radios. When we added the avionics master, the problems mostly went away so the "practice" was called a success and we drove happily onward. Nearly 40 years later some folk assume that a "practice" has become a "standard" and that the standard has some foundation in real physics for its existence. I've been designing electronics for aircraft for nearly 40 years and never have I identified transients on the bus that reside outside the DO-160 test envelope. My personal perception is that products tested to DO-160 recommendations do not require extraordinary system architectures or pilot actions to "protect" the product. I.e, the "avionics bus" is a mis-understood and ill- conceived feature in the design of an aircraft electrical system. >3). Our definition of a sophisticated circuit (when referring to power >supplies), is one that would require fly back transformers to drive plasma >displays or TFT backlights, one that uses floating step-up power to allow >top side differential measurement, and high efficiency and charge pump >units. > >4). We know that our instruments can handle input voltage spikes in excess >of +/- 250 volts and over 400 microseconds AC input impedance. This is >approximately 100 times the energy limitation of DO-160 and much better than >other aviation equipment that we have tested. >We feel that the industry needs published data on the voltage spikes >produced during the start sequence for normal aircraft, worst case normal, >abnormal and worst case abnormal. Most manufacturers have solved the >uncertainty by going to a radio or avionics bus that is switched off during >engine start. I infer from this that E.I. believes there are undocumented stresses generated during the normal action of getting the engine started. Further, these stresses have been overlooked by 40 or so years of industry-staffed committees who have participated in the crafting of DO-160 and other documents at RTCA. If such stresses exist in the course of operating an airplane, I could not agree more. Based on EI installation recommendations, I would have assumed that EI has studied and quantified the problem and made an engineering judgment as to whether or not their products could/should be designed to withstand the worst case cranking transients but this appears not to be the case. >We have been producing TSO'd equipment for over 20 years that can survive >the somewhat hostile aircraft electrical environment, but would prefer that >the UBG-16 be operated from a source that is protected from the starting >sequence. > >We are always open to suggestions and new ideas. Thank you for your input. >David Campbell >Electronics International Inc. >63296 Powell Butte Highway >Bend, OR 97701 >Phone: (541) 318-6060 >Fax: (541) 318-7575 >Web: www.Buy-Ei.com Perhaps I can suggest this. Take a scope and go look at the output from the cigar lighter on a car. Set up to + slope trigger at say, 20 volts and then crank the engine. My Tektronix TDS220 could not capture a single transient at ANY horizontal resolution. Tried triggering on - slope at zero volts. Same result. I'd say my GMC van is roughly equal to C-150 for cranking currents and DC system impedance. This is typical of what I've captured on a number of airplanes ranging from C-150 to Beechjets over the past 25 years measured with all manner of scopes, chart recorders and high speed (8,000 samples/second) data acquisition systems, etc. A charter adopted by the AeroElectric Connection is to principals upon which modern electrical systems can be crafted. Our readers would be pleased to know of any data you can add to the knowledge base upon which we will advance the state of our science. Bob . . . (-----------------------------------------) ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( -C. F. Kettering ) (-----------------------------------------) ________________________________________________________________________________
Date: May 01, 2003
Subject: stuff I have on ebay
Quartz hour meter . . . http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2413197823 2-1/4" voltmeter . . . http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26442&item=2413488496 Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: May 01, 2003
> >Hi Jon; It's best to pick the cheapest one... It will be easier to explane >(pun?) to Pamela ;-) > >Seriously, there may be some packaging/case differences which you'll want to >consider (usually designated by one or more letter following the main part >. . . John, thanks for the expanded explanation. I was in a hurry and left an earlier reply somewhat 'short-changed' . . . appreciate the back up! Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: IEEE guide
><Gilles.Thesee@ac-grenoble.fr> > >Bob and all, > >A fellow builder just sent me a CD Rom with a copy of an 'IEEE guide for >aircraft electric systems' in pdf format. >Most interesting. a few pages missing though. > >FWIW, >Regards > >Gilles I'd really like to see it. How bit a file is it? Can you e-mail me a copy or post it to a server somewhere we can download it? Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: 10503 Woodward
>Thursday, May 1, 2003 > >Bob, >I had a voltage regulator which failed closed giving me a very high >reading on the ammeter of my PA28-161. I ended up replacing the voltage >regulator and the alternator as it had failed the resistance test from the >field terminal to ground with only.005 ohms. Now, when I hit the PTT or >mic button, the cabin speaker squeals at very high volume. I disconnected >the speaker and now get some, but not bad, feedback throught the headset >when I hit the PTT. ATC has no problems with my reception. Any thoughts >would be greatly appreciated!! Sounds like you experienced a runaway alternator event that was not brought under control by an over-voltage relay. Do you even HAVE an ov relay? In any case, the only thing I can think of is that some part of your electronics may have been damaged by the event. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: Z15B?
> >Bob Could you explain why Z15B is not a good Idea.=A0=A0=A0 That particular >architecture would work well for the velocity where the #2AWG runs in a duct >from firewall through canard bulkhead right to the batteries. A seperate # >4AWG could come from the panel ground block on the panel and to the batteries >via a different route.=A0 If you dont recommend this then I would have to cut >through the duct inside the cabin behind the panel run the #2 wire up to the >panel ground presumable on the panel and then back down into the duct to go >to the battery. It would be a lot of heavy wire inside the cabin and onto the >panel.=A0 Is there a better way I'm not seeing?=A0=A0=A0=A0 Thanks Tim Z15 View B suggests that the battery (-) terminal be the tie point of two wires which is in error. The battery (-) lead and ground lead extending to engine compartment aft should come together at a fat brass bolt on the ground block. Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: Battery Cables-I need some learnin'.
My Tomahawk has a several large cables under the cylinders to the alternator ,starter and crankcase ground. All of these cables are pretty ugly, oil soaked etc, but seem to work ok. The cables on newer airplanes that Ive looked at appear to have a Tefzel jacket. The ones I have looked to be wrapped with what looks like a large dia thread. Mine look as if the jacket has absorbed oil. Is there a good rule of thumb as to replacement of these older cables? Is welding cable or (welding cable in firesleeve) verboten on production a/c? ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: Battery Cables-I need some learnin'.
> >My Tomahawk has a several large cables under the cylinders to the alternator >,starter and crankcase ground. >All of these cables are pretty ugly, oil soaked etc, but seem to work ok. > >The cables on newer airplanes that Ive looked at appear to have a Tefzel >jacket. The ones I have looked to be wrapped with what looks like a large >dia thread. Mine look as if the jacket has absorbed oil. > >Is there a good rule of thumb as to replacement of these older cables? Is >welding cable or (welding cable in firesleeve) verboten on production a/c? Welding cable would work fine in or out of fire-sleeve but there is a lot of potential for future hassles and really good wire isn't all that expensive. Your airplane may be old enough to have been wired with Mil-W-16878 or similar wire popular before 1980. It may even have cloth over-braid that was famous for soaking up sticky-ugly stuff under the cowl. Depending on how obsessive you and/or your mechanic are about crossing t's and dotting i's, you can fill out lots of paper and generally have no problem with renewing your wiring using modern, Mil-W-22759 wire which is used on the vast majority of GA aircraft for the past 20 years or so. If it were my airplane, I'd just fix 'em and keep on flying. Mil-W-22759/16 (Tefzel) wire, terminals and double-wall heat shrink to dress the ends is readily available from lots of places not the least of which is http://www.aeroelectric.com/Catalog/BCcatalog.html Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: No Audio Panel
Gang, Working on a friend's project. Two coms (430 and Microair), an intercom (PM1000), and no audio panel. Space is getting tight, and no, I didn't do the layout. Looks like it should be possible to tie them together with 5 switched double poles, maybe 2 DPDT and an SPDT, or a 5PDT if available. Nav audio would need another SPDT before the intercom input. Sort of a poor-man's audio panel. Reasonable or dumb? Technical issues? Anybody know where to get a good 5-pole double throw switch? Two switches (a com select and a nav interupt) wouldn't be so bad. Dan ________________________________________________________________________________
Date: May 01, 2003
Subject: Too many wires next to each other???
I'm new to the group, so if this question has been hammered to death already, sorry. Is it OK to run the same ground wire for the flasher power supply, landing light, and nav light? I plan to run those wires in the same conduit out to the wing tip. Am I going to be able to also run an antenna cable for my nav in the same conduit, or will there be too much noise from the strobe power supply. The power supply is at the wing tip so there won't be hi voltage wires next to the antenna cable. Thanks Cam __________________________________ http://search.yahoo.com ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: Too many wires next to each other???
> > >I'm new to the group, so if this question has been >hammered to death already, sorry. > >Is it OK to run the same ground wire for the flasher >power supply, landing light, and nav light? I plan to >run those wires in the same conduit out to the wing >tip. Am I going to be able to also run an antenna >cable for my nav in the same conduit, or will there be >too much noise from the strobe power supply. The >power supply is at the wing tip so there won't be hi >voltage wires next to the antenna cable. run them all together . . . Bob . . . ________________________________________________________________________________
Date: May 01, 2003
Subject: Re: No Audio Panel
I've flown a couple of homebuilts with setups like that. A dpdt to select which radio would transmit with the PTT, and a spst for each radio that you wanted to listen to - often com, com and nav. Sub mini toggles. Don't have a sketch, but I'll bet someone here does. > >Gang, > Working on a friend's project. Two coms (430 and Microair), an > intercom (PM1000), and no audio panel. Space is getting tight, and no, I > didn't do the layout. > > Looks like it should be possible to tie them together with 5 switched > double poles, maybe 2 DPDT and an SPDT, or a 5PDT if available. Nav > audio would need another SPDT before the intercom input. Sort of a > poor-man's audio panel. > > Reasonable or dumb? Technical issues? Anybody know where to get a > good 5-pole double throw switch? Two switches (a com select and a nav > interupt) wouldn't be so bad. > >Dan > > ________________________________________________________________________________
Subject: Audio & intercom make your own.
Date: May 02, 2003
HI Bob and all, I saw a diagram somewhere on your site though I cant font it now, for a roll your own intercom. I intend to make my own form scratch. Features are VOX Music & Sat phone in Compaq Ipaq sound in, Transponder Alt alert in And maybe pilot isolate, Also what sort of signals (peak to peak) and impedance should I expect form (and to) the following devices Personal CD player. Normal aircraft headsets Headset micphone. And what input (and output) voltage and impedance is the Microair 760 expecting, both for mic in and sound out. Thanks in advance Ian ________________________________________________________________________________
Subject: VOR aerial
Date: May 02, 2003
Bob - I hope this doesn't seem like a dumb question but I am new to the homebuilt game - but I have received a "Cat's Whisker" VOR aerial with my Garmin GTX320 and as I am building a composite (Europa) want to mount the aerial behind the rear baggage bulkhead - but 2 problems. 1. Can the aerial face backwards - i.e. the tip of the "V" face tie rudderpost - the plane of the aerial remains horizontal with the aircraft.? 2. The Whelan power unit for the strobes is below (8-10 ins) the aerial between the tips of the aerial - is this a problem? Thanks Mike Toft ________________________________________________________________________________
Date: May 01, 2003
From: Frederic Livesey <fred.livesey(at)zetnet.co.uk>
Subject: UK Wire Gauge
Hi, Here in the UK we use a different method for selecting wire gauge than the USA, does anyone know where I can get a conversion chart. Fred Chester UK ________________________________________________________________________________
Date: May 02, 2003
Subject: Re: UK Wire Gauge
Try Machineries Handbook. I have a copy if you want it looked up. Gimme the specifics. Neil Ex Pat in the USA. At 06:32 AM 5/1/03, you wrote: > > >Hi, Here in the UK we use a different method for selecting wire gauge >than the USA, does anyone know where I can get a conversion chart. >Fred >Chester >UK > > ________________________________________________________________________________
Date: May 02, 2003
Here's an on-line calculator to convert wire gage sizes: http://www.efunda.com/designstandards/gages/wire_forward.cfm However, if you prefer a chart of equivalents go to: http://shopswarf.orcon.net.nz/wiregage.html Best regards, Rob Housman Europa XS Tri-Gear A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Frederic Livesey Subject: AeroElectric-List: UK Wire Gauge Hi, Here in the UK we use a different method for selecting wire gauge than the USA, does anyone know where I can get a conversion chart. Fred Chester UK ________________________________________________________________________________
Date: May 02, 2003
Subject: Re: VOR aerial
> >Bob - I hope this doesn't seem like a dumb question but I am new to the >homebuilt game - but I have received a "Cat's Whisker" VOR aerial with my >Garmin GTX320 and as I am building a composite (Europa) want to mount the >aerial behind the rear baggage bulkhead - but 2 problems. >1. Can the aerial face backwards - i.e. the tip of the "V" face tie >rudderpost - the plane of the aerial remains horizontal with the aircraft.? Yes, the cat-whisker antennas have been mounted both ways on many different aircraft. >2. The Whelan power unit for the strobes is below (8-10 ins) the aerial >between the tips of the aerial - is this a problem? Perhaps but only when you are listening to a VOR station and the only time you'll do this for long periods of time is when the VOR is being used as a remote transmitter for some ground based communications facility or the VOR is a weather broadcast facility . . . pretty rare. I wouldn't worry about it. Bob . . . ________________________________________________________________________________
From: "Vincent Welch" <welchvincent(at)hotmail.com>
Subject: Splitter
Date: May 02, 2003
I read previously that a signal from the NAV antenna can be used for the FM input to an AM/FM/CD. I am installing a wingtip antenna and would like to use a splitter to feed the FM radio. Now for the question. Is there anything special inside of a splitter, by that I mean are all of the outputs the same? I am asking because I need to split the signal going into the VAL INS422 also (need GS and NAV inputs). The splitter that I see in the Spruce catalog is arranged as follows: NAV NAV GS ANT The geometry of my panel indicates that the preferred layout would be: NAV GS NAV ANT (this lower NAV would connect to my FM radio) Can I connect these anyway I like or must the output marked GS go to the GS? I am trying to avoid sharp bends in the coax. Does this make any sense to anyone or am I just babbling? :) Vince Welch RV-8A ________________________________________________________________________________
Date: May 02, 2003
Subject: Re: Audio & intercom make your own.
> >HI Bob and all, > >I saw a diagram somewhere on your site though I cant font it now, for a >roll your own intercom. > >I intend to make my own form scratch. > >Features are VOX >Music & Sat phone in >Compaq Ipaq sound in, >Transponder Alt alert in > >And maybe pilot isolate, > >Also what sort of signals (peak to peak) and impedance should I expect >form (and to) the following devices > >Personal CD player. Contemporary entertainment headsets are lower impedance than aircraft headsets . . . they can range from 8 to 50 ohms but the voltage to drive them will be in the same ballpark as aviation headsets . . . I'd figure on 1v pk-pk to give you a "loud" signal. >Normal aircraft headsets 150 ohms, 2v pk-pk is pretty loud > >Headset micphone. Bias up the microphone from a well filtered, 6v source through 470 ohm resistor. Voice signal levels will be on the order of 1v pk-pk. Bob . . . >And what input (and output) voltage and impedance is the Microair 760 >expecting, both for mic in and sound out. I'd load the headset output with 150 ohms. Dummy load the mic input to the radio with 1K resistor and impress levels no more than 1v pk-pk audio level to the transmitter. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: May 02, 2003
Subject: Re: Splitter
> > > >I read previously that a signal from the NAV antenna can be used for the FM >input to an AM/FM/CD. I am installing a wingtip antenna and would like to >use a splitter to feed the FM radio. > >Now for the question. Is there anything special inside of a splitter, by >that I mean are all of the outputs the same? I am asking because I need to >split the signal going into the VAL INS422 also (need GS and NAV inputs). >The splitter that I see in the Spruce catalog is arranged as follows: > >NAV NAV >GS ANT > >The geometry of my panel indicates that the preferred layout would be: > >NAV GS >NAV ANT (this lower NAV would connect to my FM radio) > >Can I connect these anyway I like or must the output marked GS go to the GS? > I am trying to avoid sharp bends in the coax. >Does this make any sense to anyone or am I just babbling? :) Antenna inputs to automotive entertainment receivers are unique to the application. Their tuners have splitters of a sort to take AM and FM signals to different circuits and account for the fact that AM antennas on cars are terrible antennas and no so bad for FM frequencies. I've heard folks report "satisfactory" performance from their automotive receiver when hooked to various and sundry aviation antennas. The quantified level of performance is problematical but then, when you are 1 mile in the air, a wet string will have some degree of performance that you might well find "satisfactory". Give it a try. It can't do anything worse than be "unsatisfactory" in which case you'll have to do something else. Bob . . . ________________________________________________________________________________
Date: May 02, 2003
Thanks Bob. In relation to the splitter question; I don't know what is inside of a splitter, does the GS output have to go to the GS or is that convient labeling and I can connect the outputs anyway I like? Vince >From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Splitter >Date: Fri, 02 May 2003 11:53:18 -0500 > > > > > > > > > > >I read previously that a signal from the NAV antenna can be used for the >FM > >input to an AM/FM/CD. I am installing a wingtip antenna and would like >to > >use a splitter to feed the FM radio. > > > >Now for the question. Is there anything special inside of a splitter, by > >that I mean are all of the outputs the same? I am asking because I need >to > >split the signal going into the VAL INS422 also (need GS and NAV inputs). > >The splitter that I see in the Spruce catalog is arranged as follows: > > > >NAV NAV > >GS ANT > > > >The geometry of my panel indicates that the preferred layout would be: > > > >NAV GS > >NAV ANT (this lower NAV would connect to my FM radio) > > > >Can I connect these anyway I like or must the output marked GS go to the >GS? > > I am trying to avoid sharp bends in the coax. > > > >Does this make any sense to anyone or am I just babbling? :) > > Antenna inputs to automotive entertainment receivers are unique > to the application. Their tuners have splitters of a sort > to take AM and FM signals to different circuits and account > for the fact that AM antennas on cars are terrible antennas > and no so bad for FM frequencies. I've heard folks report > "satisfactory" performance from their automotive receiver > when hooked to various and sundry aviation antennas. The > quantified level of performance is problematical but then, > when you are 1 mile in the air, a wet string will have some > degree of performance that you might well find "satisfactory". > > Give it a try. It can't do anything worse than be "unsatisfactory" > in which case you'll have to do something else. > > Bob . . . > > ________________________________________________________________________________
Date: May 02, 2003
In a message dated 5/2/03 11:54:45 AM Central Daylight Time, bob.nuckolls(at)cox.net writes: > The > quantified level of performance is problematical but then, > when you are 1 mile in the air, a wet string will have some > degree of performance that you might well find "satisfactory". > > Give it a try. It can't do anything worse than be "unsatisfactory" > in which case you'll have to do something else. Good Afternoon All, For What It's Worth, the early Narco knob tuned receivers had the capability of going on down below the 108 frequency range into the top of the FM band. We often listened to those high end frequency FM stations via the VOR/ILS receiver. Happy Skies, Old Bob ________________________________________________________________________________
Date: May 02, 2003
> > >Thanks Bob. In relation to the splitter question; I don't know what is >inside of a splitter, does the GS output have to go to the GS or is that >convient labeling and I can connect the outputs anyway I like? yes . . . the various outputs are generally frequency band specific . . . they need to drive a receiver unique to the activity of that receiver. Bob . . . ________________________________________________________________________________
Date: May 02, 2003
Subject: RV List 59 msg. digest-5/1
Hi Matt - Is there a problem with getting all 59 msg's - I can 32 and then it jumps to 96 msg, the day before ---- or is it my problem??? ________________________________________________________________________________
Date: May 02, 2003
Subject: UK wire guages
If you are looking for a conversion of AWG to metric sizes try http://mdmetric.com/tech/metricwiregage.htm John Herminghaus ________________________________________________________________________________
Subject: Web Site builder documentation of RV projects - Chris
Good's
Date: May 02, 2003
Chris Good, Thanks for calling attention to your excellent website. I've looked at others (not all, by any means) and have seen others who have posted "some" info on their RV - but your site is absolutely fabulous! Total documentation of anything I could think of to look up. - I highly recommend this web site to anyone building an RV!! Just yesterday I got my courage up again and did the first update/practice on my own primitive website since Nov 2000. I've changed computers since then and had to find and learn how to use a different FTP uploader pgm, and made a new checklist on how to add "daily" (periodic) update pages to the site. Now the wife & I need to learn how to download pictures from our digital camera we bought last Fall and have never downloaded. I am at the stage of creating schematics and wiring diagrams for my RV-6 electrical system, and plan to use IntelliCAD (open architecture clone of, and compatible with, Autocad ), starting off with, and modifying, Bob Nuckoll's drawings and symbols. I noticed your nice wiring info - color, etc. What program did you use to create such elegantly simple and clear graphic info? About your website, did you copy source code from someone else - like I do - and modify it? Or, did you have a professional web site person design it for you? I have the 27 page "NCSA - A Beginner's Guide to HTML" document that I printed off the internet - I use it for my main reference for HTML stuff . I create & edit web documents with Notepad, the simplest text editor. Any tips for us new guys to "web site documentation of our projects"? David Carter http://www.datarecall.net/~dcarter ----- Original Message ----- From: "Chris Good" <chrisjgood(at)lycos.com> Subject: Re: RV-List: Skymap IIIC > --> RV-List message posted by: "Chris Good" > > Bill, > > I have been flying with a Skymap IIIC in my panel for nearly 3 yrs. > The "Systems" section on my website includes a wiring drawing for the Skymap & Navaid, but it's not complicated. Also, there's a photo at the end of the "photo-log" "panel" page. > > Regards, > > Chris Good, > West Bend, WI > RV-6A N86CG 530 hrs flying > http://rv.supermatrix.com ________________________________________________________________________________
From: "Dave O'Donnell" <daveodonnell(at)direcway.com>
Date: May 02, 2003
What is the US wire std? In sheet or tubing BWG (Birmingham Wire Gauge) is the std. So I suspect it is the same in wire. In tubing 16 gauge is 0.065" average wall, normally with a +/- 10% tolerance (ASTM A249 A269, A1016). This means that if you order 16 gauge (0.065" avg) you get 0.058" min. If you order min wall you get min + 18%. How does it work in wire? Regards, Dave O -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Neil Clayton Subject: Re: AeroElectric-List: UK Wire Gauge Try Machineries Handbook. I have a copy if you want it looked up. Gimme the specifics. Neil Ex Pat in the USA. At 06:32 AM 5/1/03, you wrote: > > >Hi, Here in the UK we use a different method for selecting wire gauge >than the USA, does anyone know where I can get a conversion chart. >Fred >Chester >UK > > ________________________________________________________________________________
Date: May 02, 2003
In the US, anything with "Gauge" as a measurement is hopeless to figure out. Tubing, wire, sheet metal, etc. There are pages of "standards", but wire, among other examples, depends on the material. I.e., copper X gauge is different from steel X gauge. Sheet metal same thing - depends on the material and which set of "standards". As I said, utterly hopeless. Alex Peterson Maple Grove, MN RV6-A N66AP 295 hours www.rvforum.org www.usfamily.net/web/alexpeterson > What is the US wire std? In sheet or tubing BWG (Birmingham > Wire Gauge) is the std. So I suspect it is the same in wire. > In tubing 16 gauge is 0.065" average wall, normally with a > +/- 10% tolerance (ASTM A249 A269, A1016). This means that > if you order 16 gauge (0.065" avg) you get 0.058" min. If > you order min wall you get min + 18%. How does it work in wire? > > Regards, > > Dave O ________________________________________________________________________________
Date: May 03, 2003
Thanks Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Audio & intercom make your own. --> >--> > >HI Bob and all, > >I saw a diagram somewhere on your site though I cant font it now, for a >roll your own intercom. > >I intend to make my own form scratch. > >Features are VOX >Music & Sat phone in >Compaq Ipaq sound in, >Transponder Alt alert in > >And maybe pilot isolate, > >Also what sort of signals (peak to peak) and impedance should I expect >form (and to) the following devices > >Personal CD player. Contemporary entertainment headsets are lower impedance than aircraft headsets . . . they can range from 8 to 50 ohms but the voltage to drive them will be in the same ballpark as aviation headsets . . . I'd figure on 1v pk-pk to give you a "loud" signal. >Normal aircraft headsets 150 ohms, 2v pk-pk is pretty loud > >Headset micphone. Bias up the microphone from a well filtered, 6v source through 470 ohm resistor. Voice signal levels will be on the order of 1v pk-pk. Bob . . . >And what input (and output) voltage and impedance is the Microair 760 >expecting, both for mic in and sound out. I'd load the headset output with 150 ohms. Dummy load the mic input to the radio with 1K resistor and impress levels no more than 1v pk-pk audio level to the transmitter. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- direct advertising on the Matronics Forums. ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: Interesting Radio Problem ... Need Help
Date: May 03, 2003
Glacier I was asked to go flying with a friend who is working on his CFI. He had access to a Cessna 150 with a releatively new looking (non-King, non-Cessna [ARC??]) Narco maybe radio. When you power it up, it comes up with 121.5 set so you have to change and toggle to what you want. He mentioned a radio problem so I got my handheld and we checked the radio on the ground. All seemed fine. THE PROBLEM: Since he wanted me to fly I wanted to work the radios as well and when I fired up the plane and did a "radio check", part of the first transmission made it and nothing but carrier thereafter. Several "tests" later showed that: 1. When the plane's engine was NOT running, the radio (transmit) worked 2. When the engine WAS running the radio (transmit) did NOT work 3. Bypassing the intercom and "plugging in direct" had not effect 4. Receive worked in all scenarios THE QUESTION: What could be going on here?? MY THEORIES: 1. The radio's "input" section is getting noise that is interferring with the carrier modulation (but how???) 2. The alternator is REALLY generating some noise (but I don't hear a "whine") 3. There is a really bad grounding problem somewhere (but it RECEIVES just fine) HELP: What do you think could be the culprit?? THanks, James ________________________________________________________________________________
Date: May 03, 2003
Subject: King 520 CDI GS Flag
I just hooked up a King 520 CDI to my Garmin GNC300 Everything works as per the Garmin manual. However the 520 has a GS and GS flag. I left the GS flag pins floating thinking it would retract automatically but it doesn't. I'm only using the Garmin to drive the 520 right now so I would like to retract the GS flag when ever power is applied to the avionics stack. I have two pins, GS+ and GS-, which pin do I pull to ground or common and which do I pull up to 14 volts to get the flag to retract? Do I need to put a resister in line to limit the current? If so does 10K sound about right? Scott ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 15 Msgs - 04/18/03
Date: May 03, 2003
James: Have you tried changing the alternator pulley, or even the one on the engine??? Should boost the output and might be a cheap fix. Ron ----------------------------------------------- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: AeroElectric-List: Power budget Dick's posting has some very IMPORTANT data to make a note of. I have found that our "35 amp" alternator (not B&C) *probably* does 15-17 amps at "lower than cruise" RPMs. So ... when approaching the airport in late afternoon, if I turn on both landing lights, along with strobe and nav, and announce my position, by the time I am on final (if not before), I have a BIG RED "low voltage" light staring me in the face. I can literally see the voltmeter easing toward the lower numbers. So make sure that you get an alternator that really does put out the amperage you need without you having to be turning, say 2500 RPM. James ________________________________________________________________________________
Date: May 03, 2003
----- Message d'origine ----- De : "Robert L. Nuckolls, III" : Envoy : jeudi 1 mai 2003 17:11 Objet : Re: AeroElectric-List: IEEE guide > > ><Gilles.Thesee@ac-grenoble.fr> > > > >Bob and all, > > > >A fellow builder just sent me a CD Rom with a copy of an 'IEEE guide for > >aircraft electric systems' in pdf format. > >Most interesting. a few pages missing though. > > > >FWIW, > >Regards > > > >Gilles > > I'd really like to see it. > > How bit a file is it? Can you e-mail me a copy or post it > to a server somewhere we can download it? > > Bob . . . Bob, No server available at the moment. I'm sending it direct. Gilles ________________________________________________________________________________
Date: May 03, 2003
> I'd really like to see it. > > How bit a file is it? Can you e-mail me a copy or post it > to a server somewhere we can download it? > > Bob . . . Bob, I'm afraid the document is too large for your mail server to accept it : ': message size 9991494 exceeds size limit 5242880 of server mx.east.cox.net[68.1.17.3]' I'll try to place it in a public directory on one of our servers at work. I'll keep you posted. Regards, Gilles ________________________________________________________________________________
Date: May 03, 2003
><Gilles.Thesee@ac-grenoble.fr> > > > > I'd really like to see it. > > > > How bit a file is it? Can you e-mail me a copy or post it > > to a server somewhere we can download it? > > > > Bob . . . > >Bob, >I'm afraid the document is too large for your mail server to accept it : > >': message size 9991494 exceeds size limit 5242880 of > server mx.east.cox.net[68.1.17.3]' > >I'll try to place it in a public directory on one of our servers at work. >I'll keep you posted. try using nuckolls(at)aeroelectric.com That's my server. I don't think we have any limit on it. Bob . . . ________________________________________________________________________________
Subject: Windows viewable sketches (was Todd's Coolant Header
Tank...)
Date: May 03, 2003
Todd ( and/or others on all 3 lists who know how to create "Windows viewable sketches", This is a "builder documentation" and "builder put out sketches for peer review" question/issue. Todd, I looked at your pictures and the color sketch of your coolant system, a .jpg file. Did you do the sketch free hand and scan it? Or, did you use some software product to draw/sketch it? With your .jpg file sketch opened and viewed by my Kodak "Imaging for Windows", I studied the Help document and tried some things, to try to learn how to "draw" - no luck. The drawing toolbar at bottom is greyed out. - I notice at the very top of screen, it says, after the icon for the Imaging viewer software: "Coolant flow system.jpg - Imaging [Read Only]" - Why would it be "Read Only"? Is there a feature like in spreadsheets which can be "locked" to prevent changing critical cells? - Is my "bundled" software one of those damnable "lite" (less features) versions of "real" software? I have Intellicad, an Autocad clone, to create drawings with, but drawings created that way require anyone wanting to view it to have a similar software package, which many do not. - So, I'm looking for a drawing tool other than Intellicad/Autocad that can be viewed by anyone with Windows (and the typical viewers bundled with it). David Carter ----- Original Message ----- From: "Haywire" <haywire(at)telus.net> Subject: [FlyRotary] Coolant header tank & Coolant filler neck thingy??? > Hi Guys; > I've been away at tech school for a few months and am just beginning to get > back to work on my engine. I did fly home every weekend, but just worked on > painting the plane so this is the first I've worked on the engine since > doing coolant flow tests back in December. > In an effort to design the most efficient coolant system possible, I've > built my own header tank. I've drawn a diagram of the system similar to the > diagram provided by Lyn. To finish this tank I need to put a cap on it. I > searched the internet for aluminum filler necks and found some in England, > but while looking through my repair manual I found a pic of a bolt-on > plastic flange mount filler neck. This is shown in the pic "rad cap filler > neck". Can somebody out there tell me if this is just a mount for a filler > cap or if it is for a pressure cap? Can I also get the dimensions of it with > & without the cap. > The "coolantheadertank" pics show how it will be mounted & the "coolant > recovery bottle" pic is an old snowmobile coolant tank modified. Side port > on this tank has been plugged and bottom port has been modified to accept a > 3/8 hose. > Comments, criticism are welcome, but I'd really like the info on the filler > neck thingy, so I can order one tomorrow if it is appropriate. > Thanks > > S. Todd Bartrim > Turbo 13B rotary powered > RV-9endurance (FWF) > C-FSTB > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > "Imagination is more important than Knowledge" > -Albert Einstein > > > --- > ---- > >> Homepage: http://www.flyrotary.com/ > ________________________________________________________________________________
Subject: Oil press warning trouble.
Date: May 03, 2003
Bob, did I do something wrong, or did I get a bad oil pressure switch? I wired my Hobbs and low oil press warning circuit exactly (I think) to your drawing labeled; HOURMETER/OIL P WARN. With the master on, there is no warning indicator. My voltmeter says there is 12.5 V on the oil press switch terminal "S" and about 11.5V on terminal "I". I touched a temporary ground wire to terminal "S" and the light came on. Verdict? Does the switch need to operate a few times to "loosen up". It has never had oil pressure applied to it. Thanks. Sam Hoskins Quickie Q-200 ________________________________________________________________________________
Subject: Re: Pilot Controlled Battery Disconnect -
Date: May 03, 2003
Somebody help me - concerning the 3 drawings Bob gave links to at the bottom of this: Are they a revision to a Z-diagram in AeroElectric Connection? Or, are they something "custom made" just for one particular application? I must have missed the original e-mail traffic and don't know what the first part of the "thread" said. David ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Pilot Controlled Battery Disconnect - > > > > Bob: > > I don't understand how this would work. The relay could only be engaged if > the load was able to provide positive voltage at sufficient current to pull > in the > coil. If the intent here is to pass most of a large current through a > relay instead of > a switch on the panel, shouldn't the relay coil be connected to the bus > side of the > circuit instead of the load side? > Good eye my friend. Got my mouse cord tangled around my > eyeteeth and couldn't see what I was drawing. I'd snatched > some pieces from another drawing and didn't get the details > sifted out. Here's a better crack at it. If you already have > v2.pdf and v3.pdf, they are not changed. Download v1a.pdf > only. > > > > http://216.55.140.222/temp/v1a.pdf > > http://216.55.140.222/temp/v2.pdf > > http://216.55.140.222/temp/v3.pdf > > > Thanks for the heads-up! > > Bob . . . > > ________________________________________________________________________________
Date: May 03, 2003
Subject: Re: RV-List: Web Site builder documentation of RV projects
- Chris Good's David, Thanks for the kind words about my web site. I hope you continue to find it useful. Having initially figured out how to do a few simple things, I just edit the raw html files with additions to the site. The tables are typically MS Excel spreadsheets - Excel has an "export to html" function. The systems section, that includes wiring diagrams, was created as an MS Powerpoint presentation set of slides. Powerpoint has an "export to html" function that creates the pages on the web site. I've used the web site as my main method of documenting my work on the 6A, & I continue to refer to it frequently. Regards, Chris Good West Bend, WI RV-6A N86CG, 530 hrs flying http://rv.supermatrix.com -- On Fri, 2 May 2003 15:41:43 David Carter wrote: >--> RV-List message posted by: "David Carter" > >Chris Good, > >Thanks for calling attention to your excellent website. I've looked at >others (not all, by any means) and have seen others who have posted "some" >info on their RV - but your site is absolutely fabulous! Total >documentation of anything I could think of to look up. > - I highly recommend this web site to anyone building an RV!! > >Just yesterday I got my courage up again and did the first update/practice >on my own primitive website since Nov 2000. I've changed computers since >then and had to find and learn how to use a different FTP uploader pgm, and >made a new checklist on how to add "daily" (periodic) update pages to the >site. > >Now the wife & I need to learn how to download pictures from our digital >camera we bought last Fall and have never downloaded. > >I am at the stage of creating schematics and wiring diagrams for my RV-6 >electrical system, and plan to use IntelliCAD (open architecture clone of, >and compatible with, Autocad ), starting off with, and modifying, Bob >Nuckoll's drawings and symbols. I noticed your nice wiring info - color, >etc. What program did you use to create such elegantly simple and clear >graphic info? > >About your website, did you copy source code from someone else - like I do - >and modify it? Or, did you have a professional web site person design it >for you? I have the 27 page "NCSA - A Beginner's Guide to HTML" document >that I printed off the internet - I use it for my main reference for HTML >stuff . I create & edit web documents with Notepad, the simplest text >editor. Any tips for us new guys to "web site documentation of our >projects"? > >David Carter > http://www.datarecall.net/~dcarter Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Date: May 03, 2003
These are a variation on a theme applicable to ANY of hte Z-drawings where you have loads on the battery bus that require protection at over 7A (5A if certified). Here I've shown the use of mini-contactors or relays located right at the battery bus tap to power high current loads for the engine's electronic controlled ignition and fuel injection. Lower current draw loads 7A and below can be comfortably carried on long leads to the panel switches while higher current loads benefit from a relay. The goal is to minimize the length of an always-hot wire fused at greater than 7A for crash safety. > > > > > > > http://216.55.140.222/temp/v1a.pdf > > > http://216.55.140.222/temp/v2.pdf > > > http://216.55.140.222/temp/v3.pdf > > > > ________________________________________________________________________________
Date: May 04, 2003
Subject: Re: Oil press warning trouble.
> > >Bob, did I do something wrong, or did I get a bad oil pressure switch? > >I wired my Hobbs and low oil press warning circuit exactly (I think) to your >drawing labeled; HOURMETER/OIL P WARN. > >With the master on, there is no warning indicator. > >My voltmeter says there is 12.5 V on the oil press switch terminal "S" and >about 11.5V on terminal "I". > >I touched a temporary ground wire to terminal "S" and the light came on. > >Verdict? > >Does the switch need to operate a few times to "loosen up". It has never >had oil pressure applied to it. > >Thanks. > >Sam Hoskins >Quickie Q-200 Maybe . . . I've had one or two switches returned over the years that would not operate when oil pressure was applied but never any that failed to show continuity with no pressure on it. Can you cycle the switch with (shop air will do) and watch the terminals with an ohmmeter? B&C would be glad to replace the switch if it's being hard to get along with. Bob . . . ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: 1/4 amp fuse ?
Date: May 04, 2003
Hi Bob and all, The instructions for my UMA-Rotax tachometer call for a '1/4 amp inline fuse' between the engine pickup and the instrument. ATC fuses start at 1 amp. What would you suggest to satisfy this requirement ? Do I have to resort to those glass cartridges ? Thanks, Gilles ________________________________________________________________________________
Subject: Re: 1/4 amp fuse ?
Date: May 04, 2003
I had the same problem with my egt/cht unit so I just put a 1 amp fuse at the main bus to protect the wire and left the 1/4 amp glass fuse holder inline. Ugly but don't know how better to do it. Bill Lamb ----- Original Message ----- From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr> Subject: AeroElectric-List: 1/4 amp fuse ? <Gilles.Thesee@ac-grenoble.fr> > > Hi Bob and all, > > The instructions for my UMA-Rotax tachometer call for a '1/4 amp inline > fuse' between the engine pickup and the instrument. > ATC fuses start at 1 amp. What would you suggest to satisfy this requirement > ? Do I have to resort to those glass cartridges ? > > Thanks, > > Gilles > > ________________________________________________________________________________
From: "William Bernard" <billbernard(at)worldnet.att.net>
Subject: Military-style Ground Power Plug
Date: May 04, 2003
I'm installing the military style, three pin ground power plug. I'm using Fighre 4 from Bob's article on ground power plugs as a guide. My question centers around the contactor. I have one with three terminals, two large ones and a single small one. It appears externally similar to the S701-1 contactor otherwise. 1) Do I install a diode from the small terminal to the large terminal on the contactor that will connect to the large center pin of the plug? 2) Will the red wire of the OVM-14 module go to this same terminal? 3) I assume that the black wire of the OVM_14 will go to the small terminal. Correct? 4) The large terminal marked "BAT" will connect to the battery contactor and the unmarked large terminal will connect to the center pin of the plug. Right?? Thanks for the help. Bill ________________________________________________________________________________
Date: May 04, 2003
> >I had the same problem with my egt/cht unit so I just put a 1 amp fuse at >the main bus to protect the wire and left the 1/4 amp glass fuse holder >inline. Ugly but don't know how better to do it. > >Bill Lamb That's about all you can do . . . whoever built that requirement into their design should be tied up with their soldering iron cord and whopped about the head and shoulders with their slide rule. There is NO excuse to make a customer comply with this kind of silliness . . . Bob . . . ________________________________________________________________________________
Date: May 04, 2003
Subject: Re: Military-style Ground Power Plug
> > >I'm installing the military style, three pin ground power plug. I'm using >Fighre 4 from Bob's article on ground power plugs as a guide. My question >centers around the contactor. I have one with three terminals, two large >ones and a single small one. It appears externally similar to the S701-1 >contactor otherwise. > >1) Do I install a diode from the small terminal to the large terminal on >the contactor that will connect to the large center pin of the plug? > >2) Will the red wire of the OVM-14 module go to this same terminal? > >3) I assume that the black wire of the OVM_14 will go to the small >terminal. Correct? > >4) The large terminal marked "BAT" will connect to the battery contactor >and the unmarked large terminal will connect to the center pin of the >plug. Right?? > >Thanks for the help. > >Bill No, a 3-terminal contactor cannot take advantage of the small, sequenced energizing/de-energizing pin in the connector. You need a 4-terminal device so that you have access to both ends of the contactor coil. This is why we stock the 4-terminal device. It can substitute for a 3-terminal contactor as supplied with jumper . . . but will serve in the unique situations requiring 4-terminals by removing the jumper. Bob . . . ________________________________________________________________________________
Date: May 04, 2003
Subject: LEDs
I am looking for the brightest LED annunciator lights that would be viewable in direct sun light. If these devices are not available for direct sunlight, I would like the next best option. A 45 degree viewing angle would be preferred but could accommodate smaller angle as necessary. Hopefully several colors would be available. Source would be 14 Volt and dimmable as dictated by ambient light. Any help would be appreciated Jerry ________________________________________________________________________________
Date: May 04, 2003
Subject: Re: LEDs
> > > I am looking for the brightest LED annunciator lights that would be viewable > in direct sun light. If these devices are not available for direct > sunlight, I would like the next best option. A 45 degree viewing angle > would be preferred but could accommodate smaller angle as necessary. > > Hopefully several colors would be available. Source would be 14 Volt and > dimmable as dictated by ambient light. > > Any help would be appreciated > > Jerry > > I don=B9t know squat about LEDs but can vouch that the one supplied by lectric bob in his LVWM is one very bright light, which will get your attention in the brightest sunlight. I think its flashing helps ? Denis ________________________________________________________________________________
Date: May 04, 2003
> That's my server. I don't think we have any limit on it. > > Bob . . . > > Its probably his email server that is stopping him from sending out a large file. :( Jeff (RV-8 Wings) ________________________________________________________________________________
Date: May 04, 2003
> > > > That's my server. I don't think we have any limit on it. > > > > Bob . . . > > > > > > >Its probably his email server that is stopping him from sending out a large >file. :( > >Jeff No, he got a rejection notice from my cox account. He resent it to my website server and I got the whole document okay. Haven't had time to look it over yet . . . it 114 pages long. Bob . . . ________________________________________________________________________________
Date: May 04, 2003
Subject: Re: LEDs
> > >I am looking for the brightest LED annunciator lights that would be viewable >in direct sun light. If these devices are not available for direct >sunlight, I would like the next best option. A 45 degree viewing angle >would be preferred but could accommodate smaller angle as necessary. > >Hopefully several colors would be available. Source would be 14 Volt and >dimmable as dictated by ambient light. > >Any help would be appreciated See http://www.flamecorp.com/pdf_files/aml_1.pdf page 44 shows some LED custom annunciators. Bob . . . ________________________________________________________________________________
Subject: location of the starter contactor
Date: May 05, 2003
Are there any concerns with mounting the starter contactor remote? Like 20 ft away and going through a 1/4-20 stud on the firewall and then on to the starter? Thanks Ron Raby Lancair ES N829R ________________________________________________________________________________
Date: May 05, 2003
Subject: Re: King 520 CDI GS Flag
> >I just hooked up a King 520 CDI to my Garmin GNC300 > >Everything works as per the Garmin manual. However the 520 has a GS and >GS flag. I left the GS flag pins floating thinking it would retract >automatically but it doesn't. > >I'm only using the Garmin to drive the 520 right now so I would like to >retract the GS flag when ever power is applied to the avionics stack. > >I have two pins, GS+ and GS-, which pin do I pull to ground or common >and which do I pull up to 14 volts to get the flag to retract? Do I >need to put a resister in line to limit the current? If so does 10K >sound about right? Those are meter movement type motors that raise the flags. I don't recall now what current it takes to fully raise one but there is a spec and it's part of the acceptance test procedure for the instrument. Start out with 0.1 ma (100 uA) which is a 150K resistor. Increase by factor of 2x (75k, 36k, 18k, etc) until the flag is out of sight. This empirical procedure will let you sneak up on the right value without endangering the instruments inner works. Alternatively, someone at an avionics shop might be able to tell you the typical flag current . . . I think it's relatively standard throughout the industry. Bob . . . ________________________________________________________________________________
Date: May 05, 2003
Subject: Re: location of the starter contactor
> > >Are there any concerns with mounting the starter contactor remote? >Like 20 ft away and going through a 1/4-20 stud on the firewall and then on >to the starter? > >Thanks > >Ron Raby > >Lancair ES This was discussed in detail about a week ago here on the list. The short answer is "yes, there are concerns." Suggest you check the archives over the past three weeks or so. BTW, 1/4-20 is a tad light for firewall penetrations by fat wires . .. 5/16 is the lightest hardware recommended and it should be brass. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: May 05, 2003
thanks, I will. the 1/4-20 studs were put in by the factory. I will replace them Ron ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: location of the starter contactor > > > > > > >Are there any concerns with mounting the starter contactor remote? > >Like 20 ft away and going through a 1/4-20 stud on the firewall and then on > >to the starter? > > > >Thanks > > > >Ron Raby > > > >Lancair ES > > This was discussed in detail about a week ago here on the > list. The short answer is "yes, there are concerns." > Suggest you check the archives over the past three weeks > or so. > > BTW, 1/4-20 is a tad light for firewall penetrations by > fat wires . .. 5/16 is the lightest hardware recommended > and it should be brass. > > > Bob . . . > > -------------------------------------------- > ( Knowing about a thing is different than ) > ( understanding it. One can know a lot ) > ( and still understand nothing. ) > ( C.F. Kettering ) > -------------------------------------------- > > ________________________________________________________________________________
Tank...)
Date: May 05, 2003
Just about any cad software can open a dxf file for editing, and those same programs can save to that "universal" drawing file format. If your intent is simply to permit others to view your drawings (as opposed to editing them) AutoCad will do the job. Use the help function and the search term "raster file plotter" to find out how to save an AutoCad file as a graphic. The first paragraph in the help window (in AutoCad 2000) is . . . . "Plotting to Raster File Formats The nonsystem raster driver supports several raster file formats, including Windows BMP, CALS, TIFF, PNG, TGA, PCX, and JPEG. The raster driver is most commonly used to plot to files for desktop publishing. " . . . . with further detail to follow. Most of these file types can be opened in Paint. Another scheme that will permit anyone to view your drawings by using the free Adobe Acrobat Reader is for you to use FinePrint to save the file in Adobe Acrobat's pdf format. Go to www.fineprint.com and download the free version of that program. Best regards, Rob Housman A070 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of David Carter Subject: AeroElectric-List: Windows viewable sketches (was Todd's Coolant Header Tank...) Todd ( and/or others on all 3 lists who know how to create "Windows viewable sketches", This is a "builder documentation" and "builder put out sketches for peer review" question/issue. Todd, I looked at your pictures and the color sketch of your coolant system, a .jpg file. Did you do the sketch free hand and scan it? Or, did you use some software product to draw/sketch it? With your .jpg file sketch opened and viewed by my Kodak "Imaging for Windows", I studied the Help document and tried some things, to try to learn how to "draw" - no luck. The drawing toolbar at bottom is greyed out. - I notice at the very top of screen, it says, after the icon for the Imaging viewer software: "Coolant flow system.jpg - Imaging [Read Only]" - Why would it be "Read Only"? Is there a feature like in spreadsheets which can be "locked" to prevent changing critical cells? - Is my "bundled" software one of those damnable "lite" (less features) versions of "real" software? I have Intellicad, an Autocad clone, to create drawings with, but drawings created that way require anyone wanting to view it to have a similar software package, which many do not. - So, I'm looking for a drawing tool other than Intellicad/Autocad that can be viewed by anyone with Windows (and the typical viewers bundled with it). David Carter ----- Original Message ----- From: "Haywire" <haywire(at)telus.net> Subject: [FlyRotary] Coolant header tank & Coolant filler neck thingy??? > Hi Guys; > I've been away at tech school for a few months and am just beginning to get > back to work on my engine. I did fly home every weekend, but just worked on > painting the plane so this is the first I've worked on the engine since > doing coolant flow tests back in December. > In an effort to design the most efficient coolant system possible, I've > built my own header tank. I've drawn a diagram of the system similar to the > diagram provided by Lyn. To finish this tank I need to put a cap on it. I > searched the internet for aluminum filler necks and found some in England, > but while looking through my repair manual I found a pic of a bolt-on > plastic flange mount filler neck. This is shown in the pic "rad cap filler > neck". Can somebody out there tell me if this is just a mount for a filler > cap or if it is for a pressure cap? Can I also get the dimensions of it with > & without the cap. > The "coolantheadertank" pics show how it will be mounted & the "coolant > recovery bottle" pic is an old snowmobile coolant tank modified. Side port > on this tank has been plugged and bottom port has been modified to accept a > 3/8 hose. > Comments, criticism are welcome, but I'd really like the info on the filler > neck thingy, so I can order one tomorrow if it is appropriate. > Thanks > > S. Todd Bartrim > Turbo 13B rotary powered > RV-9endurance (FWF) > C-FSTB > http://www3.telus.net/haywire/RV-9/C-FSTB.htm > > "Imagination is more important than Knowledge" > -Albert Einstein > > > --- > ---- > >> Homepage: http://www.flyrotary.com/ > ________________________________________________________________________________
Date: May 05, 2003
Subject: RE: E.I. instruments need pampering?
>I am sorry I cannot be more helpful on your questions. I think some of the >different voltages that are listed may be due to the fact that the D0-160 >has changed since our instruments were certified. What I have been told is >that our instrument exceeded the TSO requirements at the time the instrument >was certified. > >I am sorry that I will not be able to give a more detailed answer. > > >Mac S. Speed >Electronics International Inc. >63296 Powell Butte Highway >Bend, OR 97701 >Phone: (541) 318-6060 >Fax: (541) 318-7575 >Web: www.Buy-Ei.com Mac, I'm sorry to hear this. I must conclude that Electronic International's proscription for pampering their products on the contemporary equivalent of a protected avionics bus has no basis in physics that you can describe for us. Thank you for taking the time to correspond with me on this important point of engineering. I would encourage E.I. to see that at least one person on your engineering staff become conversant in this regard. It's not very good consumer relations to adopt popular techlore and then promote the mythology by pushing it off onto customers. I'll invite any of E.I.'s tech-folk to join us on the AeroElectric-List which is sponsored by Matt Dralle's server at matronics.com. Anyone can join at no cost by subscribing to the list at http://www.matronics.com/subscribe/ There is another list in addition to the AeroElectric- List that specializes in avionics. You might consider participation in that one also. I believe the AeroElectric-List is unique. We're always looking for new and better ways to get a task done . . . or even take on a new and heretofore undoable task. We have a penchant for comprehending the physics of what we do so that success is not an accident and failure is understood. It's a sharing of knowledge that is not exclusive to the builders of airplanes . . . I would invite your folks as suppliers to the aircraft industry to join us in this endeavor . . . it can only make us all better at what we do. Bob . . . >-----Original Message----- >From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] >Sent: Thursday, May 01, 2003 7:49 AM >To: Mac S. Speed; aeroelectric-list(at)matronics.com >Subject: Re: E.I. instruments need pampering? > > > >Here again is the copy that we have sent to you, which you claim was > >never sent. > > > > > > > >Mac S. Speed > >Electronics International Inc. > >63296 Powell Butte Highway > >Bend, OR 97701 > >Phone: (541) 318-6060 > >Fax: (541) 318-7575 > >Web: www.Buy-Ei.com > > > >-----Original Message----- > >From: EI Tech Support [mailto:Sales@Buy-Ei.com] > >Sent: Monday, April 07, 2003 2:32 PM > >To: 'Robert L. Nuckolls, III' > >Subject: RE: E.I. instruments need pampering? > > > >We would like to respond to your questions of Friday- > > > >1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt to a > >-22 volt intermittent transient test for a 28 volt system and a +39 > >volt to a -11 volt test for a 12 volt system each with 50 ohm output > >impedance. In our opinion this test is not stringent enough for an > >instrument to survive on the main bus during an engine start on most > >aircraft. All of our instruments can survive transients that are well > >over the DO-160 requirement. > > > > Mac, > > I DID receive the note you've copied above. I replied > to David's letter the same day with amplifying questions. > I found a copy of my reply in my archival files but didn't > see that it was actually sent. My apologies, the ball was > indeed still in my court. Here's the message I neglected > to forward to you on 4/7 . . . > > >---------- David Campbell's letter and Nuckolls' reply of 4/7/3 --------- > > > >We would like to respond to your questions of Friday- > > > >1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt to a > >-22 volt intermittent transient test for a 28 volt system and a +39 > >volt to a -11 volt test for a 12 volt system each with 50 ohm output > >impedance. In our opinion this test is not stringent enough for an > >instrument to survive on the main bus during an engine start on most > >aircraft. > > > I am mystified by the numbers cited above. My copy of DO-160D > speaks to a +/-300 v capacitively stored spike delivered through > an air-core transformer and tailored for a 50-ohm source impedance. > 28V system tests call for a +/-600 volt event. What change level > is your copy of DO-160? Perhaps I'm out of date. > > Please cite a basis for your opinion. What is the amplitude, > waveform and duration of any transients you have observed and > identified as originating from the starter? > > > . . . . . All of our > >instruments can survive transients that are well over the DO-160 > >requirement. > > 2). It is our understanding the industry standard for most electronic > >aircraft instrument installation is to install on an avionics or radio > >bus. We just installed an Apollo GX-60, SL-30, ACU, MX-20, SL-15, > >Garmin GTX 327, 550/20 encoder, NSD-360 H.S.I. and many other pieces of > >equipment, and the install documentation made it clear that these > >instruments should be installed on the radio or avionics bus (isolating > >them from the starting sequence). > > It is indeed a "practice" originally promulgated by the notion > that the root cause of lots of dead transistors at Cessna > and elsewhere was "spikes" from the starter. This was the > early days of low voltage, germanium transistors that > were showing up in audio and power supply circuits in the > current crop of aircraft radios. I cannot attest to studies done > elsewhere but at Cessna, there were NO actual spikes captured, > quantified and deemed antagonistic to our radios. When we > added the avionics master, the problems mostly went away > so the "practice" was called a success and we drove happily > onward. > > Nearly 40 years later some folk assume that a "practice" > has become a "standard" and that the standard has some foundation > in real physics for its existence. I've been designing electronics > for aircraft for nearly 40 years and never have I identified > transients on the bus that reside outside the DO-160 > test envelope. > > My personal perception is that products tested to DO-160 > recommendations do not require extraordinary system > architectures or pilot actions to "protect" the product. > I.e, the "avionics bus" is a mis-understood and ill- > conceived feature in the design of an aircraft electrical system. > > >3). Our definition of a sophisticated circuit (when referring to power > >supplies), is one that would require fly back transformers to drive > >plasma displays or TFT backlights, one that uses floating step-up power > >to allow top side differential measurement, and high efficiency and > >charge pump units. > > > >4). We know that our instruments can handle input voltage spikes in > >excess of +/- 250 volts and over 400 microseconds AC input impedance. > >This is approximately 100 times the energy limitation of DO-160 and > >much better than other aviation equipment that we have tested. > > >We feel that the industry needs published data on the voltage spikes > >produced during the start sequence for normal aircraft, worst case > >normal, abnormal and worst case abnormal. Most manufacturers have > >solved the uncertainty by going to a radio or avionics bus that is > >switched off during engine start. > > I infer from this that E.I. believes there are undocumented stresses > generated during the normal action of getting the engine started. > Further, these stresses have been overlooked by 40 or > so years of industry-staffed committees who have participated > in the crafting of DO-160 and other documents at RTCA. > > If such stresses exist in the course of operating an > airplane, I could not agree more. Based on EI installation > recommendations, I would have assumed that EI has > studied and quantified the problem and made an > engineering judgment as to whether or not their products > could/should be designed to withstand the worst case > cranking transients but this appears not to be the case. > > >We have been producing TSO'd equipment for over 20 years that can > >survive the somewhat hostile aircraft electrical environment, but would > >prefer that the UBG-16 be operated from a source that is protected from > >the starting sequence. > > > >We are always open to suggestions and new ideas. Thank you for your > >input. > > > >David Campbell > >Electronics International Inc. > >63296 Powell Butte Highway > >Bend, OR 97701 > >Phone: (541) 318-6060 > >Fax: (541) 318-7575 > >Web: www.Buy-Ei.com > > Perhaps I can suggest this. Take a scope and go look > at the output from the cigar lighter on a car. Set up to > + slope trigger at say, 20 volts and then crank the engine. > My Tektronix TDS220 could not capture a single transient at > ANY horizontal resolution. Tried triggering on - slope > at zero volts. Same result. I'd say my GMC van is roughly > equal to C-150 for cranking currents and DC system impedance. > > This is typical of what I've captured on a number of > airplanes ranging from C-150 to Beechjets over the past > 25 years measured with all manner of scopes, chart > recorders and high speed (8,000 samples/second) > data acquisition systems, etc. > > A charter adopted by the AeroElectric Connection is to > identify, understand, and publish explanations for core > principals upon which modern electrical systems can be > crafted. Our readers would be pleased to know of any data > you can add to the knowledge base upon which we will > advance the state of our science. ________________________________________________________________________________
Date: May 05, 2003
Subject: Re: aircraft microphones
>Hello ! > >I have a problem with the radio of our Antonov 2.We have fitted a King KY 196. >We can recieve well, but transmitting is poor. >I have a feeling that something is wrong with the mic because we tried >several and they all transmit different. I have always regarded all >aircraft mics as of the same design but now i am not so shure about that >anymore. >Can you help me improve my knowledge about aircraft mics ? They are supposed to be interchangeable. There will be subtle differences in how microphones sound to the receiving individual . . . each manufacturer has their own notion of how the frequency response of their product should be tailored. Microphones with and without noise cancelation will sound differently too. For the most part, any modern (younger than 20 years) microphone ought to work just fine with your KY196. What make and model of microphone would you like to use with this radio? Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Subject: Electric T&B noise
Date: May 06, 2003
I powered up my electrics this evening for the first time, and I'm getting a whine from the electric turn coordinator through my headsets. What's my best option to filter this noise out - try to get a filter from a car audio shop? Thanks Dave ________________________________________________________________________________
Subject: CAD help
Date: May 06, 2003
If you have an interest in CAD, please see http://www.tenlinks.com/CAD/products/free/cad.htm. This is a repository of all things in free cad, and add-ons too. Despite many forays into other CAD products, I use DesignCad (not free but cheap). Almost all CAD software does similar things, but if you call tech support for DesignCad...YOU ALMOST ALWAYS GET THROUGH! This says a lot about the company, but it says more about the program because they only have a few people in tech support. Users just don't have many issues. Later, Eric M. Jones "I only regret my economies." Reynolds Price ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: Electric T&B noise
In a message dated 5/5/2003 9:55:34 PM Mountain Daylight Time, dwg(at)iafrica.com writes: > > I powered up my electrics this evening for the first time, and I'm getting > a > whine from the electric turn coordinator through my headsets. What's my > best option to filter this noise out - try to get a filter from a car audio > shop? > > Thanks > Dave > Geez,,,, let us all guess. It is a Wultrad / Falcon T&B ????????? ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: RE: E.I. instruments need pampering?
Bob, Since I was the catalyst for this latest round of skirmishes on the avionics bus, I want you to know how much I appreciate your advocacy for the OBAM community. The energy and commitment you apply to improving the state of the art in aviation electronics is awesome and we all owe you a big debt of gratitude. Joel Harding On Monday, May 5, 2003, at 07:33 PM, Robert L. Nuckolls, III wrote: > > >> I am sorry I cannot be more helpful on your questions. I think some >> of the >> different voltages that are listed may be due to the fact that the >> D0-160 >> has changed since our instruments were certified. What I have been >> told is >> that our instrument exceeded the TSO requirements at the time the >> instrument >> was certified. >> >> I am sorry that I will not be able to give a more detailed answer. >> >> >> Mac S. Speed >> Electronics International Inc. >> 63296 Powell Butte Highway >> Bend, OR 97701 >> Phone: (541) 318-6060 >> Fax: (541) 318-7575 >> Web: www.Buy-Ei.com > > > Mac, > > I'm sorry to hear this. I must conclude that > Electronic International's proscription for pampering > their products on the contemporary equivalent of a > protected avionics bus has no basis in physics > that you can describe for us. > > Thank you for taking the time to correspond with me > on this important point of engineering. I would > encourage E.I. to see that at least one person on > your engineering staff become conversant in this > regard. It's not very good consumer relations to > adopt popular techlore and then promote the > mythology by pushing it off onto customers. > > I'll invite any of E.I.'s tech-folk to join us on > the AeroElectric-List which is sponsored by Matt > Dralle's server at matronics.com. > > Anyone can join at no cost by subscribing to the > list at http://www.matronics.com/subscribe/ > > There is another list in addition to the AeroElectric- > List that specializes in avionics. You might > consider participation in that one also. > > I believe the AeroElectric-List is unique. We're > always looking for new and better ways to get a task > done . . . or even take on a new and heretofore undoable > task. We have a penchant for comprehending > the physics of what we do so that success is > not an accident and failure is understood. > > It's a sharing of knowledge that is not exclusive to > the builders of airplanes . . . I would invite your > folks as suppliers to the aircraft industry to > join us in this endeavor . . . it can only make > us all better at what we do. > > Bob . . . > > >> -----Original Message----- >> From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] >> Sent: Thursday, May 01, 2003 7:49 AM >> To: Mac S. Speed; aeroelectric-list(at)matronics.com >> Subject: Re: E.I. instruments need pampering? >> >> >>> Here again is the copy that we have sent to you, which you claim was >>> never sent. >>> >>> >>> >>> Mac S. Speed >>> Electronics International Inc. >>> 63296 Powell Butte Highway >>> Bend, OR 97701 >>> Phone: (541) 318-6060 >>> Fax: (541) 318-7575 >>> Web: www.Buy-Ei.com >>> >>> -----Original Message----- >>> From: EI Tech Support [mailto:Sales@Buy-Ei.com] >>> Sent: Monday, April 07, 2003 2:32 PM >>> To: 'Robert L. Nuckolls, III' >>> Subject: RE: E.I. instruments need pampering? >>> >>> We would like to respond to your questions of Friday- >>> >>> 1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt >>> to a >>> -22 volt intermittent transient test for a 28 volt system and a +39 >>> volt to a -11 volt test for a 12 volt system each with 50 ohm output >>> impedance. In our opinion this test is not stringent enough for an >>> instrument to survive on the main bus during an engine start on most >>> aircraft. All of our instruments can survive transients that are >>> well >>> over the DO-160 requirement. >> >> >> >> Mac, >> >> I DID receive the note you've copied above. I replied >> to David's letter the same day with amplifying questions. >> I found a copy of my reply in my archival files but didn't >> see that it was actually sent. My apologies, the ball was >> indeed still in my court. Here's the message I neglected >> to forward to you on 4/7 . . . >> >> >> ---------- David Campbell's letter and Nuckolls' reply of 4/7/3 >> --------- >> >> >>> We would like to respond to your questions of Friday- >>> >>> 1). DO-160 Section 17 (Voltage Spike Testing) requires a +78 volt >>> to a >>> -22 volt intermittent transient test for a 28 volt system and a +39 >>> volt to a -11 volt test for a 12 volt system each with 50 ohm output >>> impedance. In our opinion this test is not stringent enough for an >>> instrument to survive on the main bus during an engine start on most >>> aircraft. >> >> >> I am mystified by the numbers cited above. My copy of DO-160D >> speaks to a +/-300 v capacitively stored spike delivered through >> an air-core transformer and tailored for a 50-ohm source >> impedance. >> 28V system tests call for a +/-600 volt event. What change level >> is your copy of DO-160? Perhaps I'm out of date. >> >> Please cite a basis for your opinion. What is the amplitude, >> waveform and duration of any transients you have observed and >> identified as originating from the starter? >> >>> . . . . . All of our >>> instruments can survive transients that are well over the DO-160 >>> requirement. >> >> 2). It is our understanding the industry standard for most >> electronic >>> aircraft instrument installation is to install on an avionics or >>> radio >>> bus. We just installed an Apollo GX-60, SL-30, ACU, MX-20, SL-15, >>> Garmin GTX 327, 550/20 encoder, NSD-360 H.S.I. and many other pieces >>> of >>> equipment, and the install documentation made it clear that these >>> instruments should be installed on the radio or avionics bus >>> (isolating >>> them from the starting sequence). >> >> It is indeed a "practice" originally promulgated by the notion >> that the root cause of lots of dead transistors at Cessna >> and elsewhere was "spikes" from the starter. This was the >> early days of low voltage, germanium transistors that >> were showing up in audio and power supply circuits in the >> current crop of aircraft radios. I cannot attest to studies done >> elsewhere but at Cessna, there were NO actual spikes captured, >> quantified and deemed antagonistic to our radios. When we >> added the avionics master, the problems mostly went away >> so the "practice" was called a success and we drove happily >> onward. >> >> Nearly 40 years later some folk assume that a "practice" >> has become a "standard" and that the standard has some foundation >> in real physics for its existence. I've been designing electronics >> for aircraft for nearly 40 years and never have I identified >> transients on the bus that reside outside the DO-160 >> test envelope. >> >> My personal perception is that products tested to DO-160 >> recommendations do not require extraordinary system >> architectures or pilot actions to "protect" the product. >> I.e, the "avionics bus" is a mis-understood and ill- >> conceived feature in the design of an aircraft electrical system. >> >>> 3). Our definition of a sophisticated circuit (when referring to >>> power >>> supplies), is one that would require fly back transformers to drive >>> plasma displays or TFT backlights, one that uses floating step-up >>> power >>> to allow top side differential measurement, and high efficiency and >>> charge pump units. >>> >>> 4). We know that our instruments can handle input voltage spikes in >>> excess of +/- 250 volts and over 400 microseconds AC input impedance. >>> This is approximately 100 times the energy limitation of DO-160 and >>> much better than other aviation equipment that we have tested. >> >>> We feel that the industry needs published data on the voltage spikes >>> produced during the start sequence for normal aircraft, worst case >>> normal, abnormal and worst case abnormal. Most manufacturers have >>> solved the uncertainty by going to a radio or avionics bus that is >>> switched off during engine start. >> >> I infer from this that E.I. believes there are undocumented >> stresses >> generated during the normal action of getting the engine started. >> Further, these stresses have been overlooked by 40 or >> so years of industry-staffed committees who have participated >> in the crafting of DO-160 and other documents at RTCA. >> >> If such stresses exist in the course of operating an >> airplane, I could not agree more. Based on EI installation >> recommendations, I would have assumed that EI has >> studied and quantified the problem and made an >> engineering judgment as to whether or not their products >> could/should be designed to withstand the worst case >> cranking transients but this appears not to be the case. >> >>> We have been producing TSO'd equipment for over 20 years that can >>> survive the somewhat hostile aircraft electrical environment, but >>> would >>> prefer that the UBG-16 be operated from a source that is protected >>> from >>> the starting sequence. >>> >>> We are always open to suggestions and new ideas. Thank you for your >>> input. >> >> >>> David Campbell >>> Electronics International Inc. >>> 63296 Powell Butte Highway >>> Bend, OR 97701 >>> Phone: (541) 318-6060 >>> Fax: (541) 318-7575 >>> Web: www.Buy-Ei.com >> >> Perhaps I can suggest this. Take a scope and go look >> at the output from the cigar lighter on a car. Set up to >> + slope trigger at say, 20 volts and then crank the engine. >> My Tektronix TDS220 could not capture a single transient at >> ANY horizontal resolution. Tried triggering on - slope >> at zero volts. Same result. I'd say my GMC van is roughly >> equal to C-150 for cranking currents and DC system impedance. >> >> This is typical of what I've captured on a number of >> airplanes ranging from C-150 to Beechjets over the past >> 25 years measured with all manner of scopes, chart >> recorders and high speed (8,000 samples/second) >> data acquisition systems, etc. >> >> A charter adopted by the AeroElectric Connection is to >> identify, understand, and publish explanations for core >> principals upon which modern electrical systems can be >> crafted. Our readers would be pleased to know of any data >> you can add to the knowledge base upon which we will >> advance the state of our science. > > > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > > ________________________________________________________________________________
Date: May 06, 2003
Sounds like another future EFIS D-10 customer in the making. Jim in Kelowna ----- Original Message ----- From: <Benford2(at)aol.com> Subject: Re: AeroElectric-List: Electric T&B noise > > In a message dated 5/5/2003 9:55:34 PM Mountain Daylight Time, > dwg(at)iafrica.com writes: > > > > > > I powered up my electrics this evening for the first time, and I'm getting > > a > > whine from the electric turn coordinator through my headsets. What's my > > best option to filter this noise out - try to get a filter from a car audio > > shop? > > > > Thanks > > Dave > > > > Geez,,,, let us all guess. It is a Wultrad / Falcon T&B ????????? > > ________________________________________________________________________________
From: "shoskins(at)globaleyes.net" <shoskins(at)Globaleyes.net>
Subject: Fuseblock CAD drawings
Date: May 06, 2003
Bob, do you have a link to a CAD version of the fuseblocks? It would be nice for my wirebook. I looked on seminar.dwg and didn't see it there. ________________________________________________________________________________
Date: May 06, 2003
Subject: Galls Flasher circuit
Bob, Is there any way to start with both taxi and landing lights on a 2-10 switch and add the Galls flasher on a separate switch, without adding a lot more complexity ? I looked at your diagrams but couldn't figure out if it would be possible. Joel Harding ________________________________________________________________________________
Date: May 06, 2003
In a message dated 5/6/2003 8:40:34 AM Mountain Daylight Time, cajole76(at)ispwest.com writes: > > Bob, > Since I was the catalyst for this latest round of skirmishes on the > avionics bus, I want you to know how much I appreciate your advocacy > for the OBAM community. The energy and commitment you apply to > improving the state of the art in aviation electronics is awesome and > we all owe you a big debt of gratitude. > > Joel Harding AMEN TO THAT !!!!!!!!!! do not archive Ben Haas N801BH ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: Galls Flasher circuit
Joel- I'm using a 3PDT relay with three separate SPST switches that provides the capability or either or both lights on, and either or both lights flashing. (Galls FS020 flasher) Looks like you could do the same with the 2-10, one other SP switch and the relay. Not sure if this is what you are looking for, but it's fairly simple and straightforward (has to be for me to understand it anyway!) If interested I could send you a dwg. Here's the relay: ( $14.56) http://www.mouser.com/ and search for: 528-3898-12 Catalog page is: http://www.mouser.com//catalog//614/757.pdf It has .25" faston terminals and a mounting bracket built in to the housing, so no socket is required. From the PossumWorks Mark Joel Harding wrote: > > Bob, > Is there any way to start with both taxi and landing lights on a 2-10 > switch and add the Galls flasher on a separate switch, without adding a > lot more complexity ? I looked at your diagrams but couldn't figure > out if it would be possible. > > Joel Harding > ________________________________________________________________________________
Date: May 06, 2003
Subject: Isolation amplifier
Has anyone built Bob's isolation amp? And if so, how well does it work? Ralph --------------------------------- ________________________________________________________________________________
Date: May 06, 2003
Mark, Yes I would be interested in the drawing. What I'm trying to accomplish is a setup that for me would be intuitive, with the 2-10 switch giving me OFF, TAXI, AND TAXI PLUS LANDING LIGHT. Then I would like to turn the flasher on or off with a separate SP switch. If your configuration can accomplish that, then that's what I'm looking for. I can certainly identify with your comment about simple and straightforward. Thanks for the info. Joel Harding On Tuesday, May 6, 2003, at 12:20 PM, Mark Phillips wrote: > > > Joel- I'm using a 3PDT relay with three separate SPST switches that > provides the > capability or either or both lights on, and either or both lights > flashing. > (Galls FS020 flasher) Looks like you could do the same with the 2-10, > one other > SP switch and the relay. Not sure if this is what you are looking > for, but it's > fairly simple and straightforward (has to be for me to understand it > anyway!) > If interested I could send you a dwg. > > Here's the relay: ( $14.56) > http://www.mouser.com/ and search for: 528-3898-12 > > Catalog page is: http://www.mouser.com//catalog//614/757.pdf > > It has .25" faston terminals and a mounting bracket built in to the > housing, so > no socket is required. > > From the PossumWorks > Mark > > Joel Harding wrote: > >> >> >> Bob, >> Is there any way to start with both taxi and landing lights on a 2-10 >> switch and add the Galls flasher on a separate switch, without adding >> a >> lot more complexity ? I looked at your diagrams but couldn't figure >> out if it would be possible. >> >> Joel Harding >> > > > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > > ________________________________________________________________________________
Date: May 06, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
Subject: falcon t&b
So I have a Falcon T & B. This probably means I will have radio noise. How do I fix this when the time comes? It would be much eaisier to "install" the fix now while the panel is out for the last time. Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: May 06, 2003
Subject: Re: Fuseblock CAD drawings
> > >Bob, do you have a link to a CAD version of the fuseblocks? It would be >nice for my wirebook. I looked on seminar.dwg and didn't see it there. For a wirebook, the fuseblock symbol is simply the bus bar with fuses as opposed to breakers. You can configure your bus with either form of circuit protection as needed . . . All of the z-drawings are available from the website in .dwg format and most have the busses set up to depict fuseblocks. . . . or am I misunderstanding your query? Bob . . .
April 24, 2003 - May 06, 2003
AeroElectric-Archive.digest.vol-by
