AeroElectric-Archive.digest.vol-cb
May 26, 2003 - June 10, 2003
      >looking at the contacts selection and there are "30-22AWG" and "24-18AWG"
      >ranges.  Then there are brass, brass gold, brass pre-tin, phosphor bronze,
      >etc.
      >Then there's what Terminal Town sells, and who knows what that stuff is.
      >I've looked on a zillion aircraft builder web sites and sure, everybody says
      >to use Mate-N-Lok connectors.  Ok, would if I could...nobody spells out the
      >specific parts!
         For wires up to and including 20AWG, I'd go for d-subs. MUCH
         better connectors, easier to work with and more compact to boot.
      >SHEEEEESH.
      >Can somebody give me a CLEAR answer about which connectors are ideal for
      >free-hanging applications in aircraft?
      >How about the required tools?  Since these catalogs seem to sell different
      >crimpers for different style connector contacts (yes, the crimper part #s
      >are *different*), I can't tell what's what.
      >Is the BCT-1 a crimp-all-end-all tool?
         I've found that it works on every open barrel pin I've tried it on
         including the full range  mate-n-lock, waldom/molex, and d-subs . . .
         but I used it perhaps once every two years. I seldom design open barrel
         pins into my products and use the tool mostly to service an existing
         connector.
         If you need just one or two, consider the radio shack 274-224 thru
         274-242 connectors. They come in sets with appropriate pins. They
         can be installed with the BCT-1. They are offered in 2 to 12 wires
         per connector. The pins are size in the wire-grip for larger wires
         like 14-18 . . . but you can dike the tabs down to make them suited
         to the smaller wires.
         What you're trying to do is get a joint that looks like figure
         5 in http://www.aeroelectric.com/articles/matenlok/matenlok.html
         The tabs for 20 and 20AWG wire are quite short.
                  ( Knowing about a thing is different than  )
                  ( understanding it. One can know a lot     )
                  ( and still understand nothing.            )
                  (                     C.F. Kettering       )
Date: May 26, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: diodes
> > The diode needs to be rated for 15v or more and be capable > > of carrying the same current that it takes to energize the > > contactor (1 to 5A) for a few milliseconds. About any > > diode rectifier is electrically suited to the task. 1N400x > > series are fine but they are rather small, sometimes glass > > devices that are fragile compared to the 1N540x series > > devices that are always 1/4" diam plastic and 20AWG leads. > > > > If you look at the diodes we supply on the S700 series > > contactors at > > > > http://www.aeroelectric.com/Catalog/switch/s701-1l.jpg > > and http://www.aeroelectric.com/Catalog/switch/s701-2.jpg > > > > . . . you can see how the mechanically more robust > > 3A diodes lend themselves to the task. > > > > ANY diode you can find will work electrically . . . > > chose for convenience of application. > >Sorry to bring this back up, but the vagueness of "ANY diode" has left my >head spinning as I look at page 468 of the Digikey catalog (Sept-Dec 2002). >There's a selection of 1N540x diodes (bridge rectifiers?), the variation >being the "max peak reverse voltage." It ranges from 50V to 1000V. Can I >assume that 50V is sufficient? Is this voltage what you meant by "rated for >15v"? They all cost the same (32 cents), but does "going big" equate to >being conservative? > >Or should I really just throw a dart at the page and choose one that way? >8-) > >I have no clue what any of this means (I am no electrical engineer!), so any >light you can shed is much appreciated. The very best way to get confused is pull down a catalog with too many choices. Go to Radio Shack and ask for a "3A diode". They only stock three numbers: 276-1141, 50-volt; 276-1143, 200-volt; and 276-1144, 400-volt and any of them will work fine. Two in a blister pack for about $1.25 Bob . . . ________________________________________________________________________________
Date: May 26, 2003
Subject: Re: Diodes
> > I would of course defer to Bob Nuckolls on this, BUT I've always >accepted that a diode needs about three times the Reverse Voltage Rating >that it protects. That's in radio work where one seldom encounters excessive >voltage leaps as in aircraft. So, unless corrected, I'll be assuming the 3X >rule when choosing diodes. >Ferg >Europa A064 the 3x rating comes from applications where two diodes are used as a full wave rectifier downstream of a center-tapped secondary. Peak-inverse is 1.5 x RMS and the full-wave center-tap configuration doubles that stress to 3x. A full wave bridge rectifier is pretty happy at only 1.5 x RMS. In our applications, you can't buy a diode rated at less than 50v which is indeed 3x that of 14v system but if you COULD find a 20v diode, it would be fine too. De-rating for ac sine-wave doesn't apply here. Bob . . . ________________________________________________________________________________
Subject: Stick It-Your-Ear Headsets
Date: May 26, 2003
Aviation Consumer recently reviewed the Panther and the Auri-Comm by Quiet Technologies http://www.quiettechnologies.com The Auri-Comm differs from the Panther in that it uses expanding foam inserts ( like industrial ear defenders ) instead of custom molded earpieces, and uses an ultralight boom mike and stereo earpieces instead of the mono earpiece and intra-canal mike of the Panther. It's also cheaper when the cost of the custom molding is included. Aviation Consumer preferred the Auri-Comm over the Panther for several reasons: 0. quieter, less fussy fitting 1. better sound quality, both transmit and receive 2. more comfortable 3. more rugged 4. less sensitive to cord microphonics ( move the cord around and the sound of the movement is transferred directly to your ear ), the seal is not broken when you eat or move you jaw, and the microphone does not pick up body noises like the Panther. I've tried the Quiettechnologies product and agree with Aviation Consumer's opinion. I have not tried the Panther, but I have used custom molded earplugs for industrial noise protection, and have found similar wearability problems with "hard" plugs. I prefer expanding foam plugs, and tests have shown them to be the best at quieting (even better than phones). The problem is that many people can't wear earplugs because of the annoyance factor. An interesting factoid - Quiettechnologies claims that their overall noise reduction is equal to or superior than most ANR headsets, and in general, they're right. I compared them to the much-vaunted Telex 50-D and found this to be true. On the other hand, the new Lightspeed 30G offers better low frequency noise attenuation - where it counts. If you need a lightweight headset, and can stand earplugs, try the Quiet Technologies product. Granted, the boom might droop during really extreme high-G maneuvers... If you want some enlightening reading on the subject, try ANR 101 and 201 on Lightspeed's website http://www.anrheadsets or the E.A.R. corporation's white paper sessions on industrial hearing protection, ANR appropriateness, and limits to noise attenuation by plugs, headsets, or helmets: http://www.aearo.com/html/industrial/tech01.asp#anr Shaun ________________________________________________________________________________
Date: May 26, 2003
Subject: Re: Fuse Block Mounting and Diode Bridge Rectifier
>Below is the result of your inquiry. It was submitted by >John Crate (john.crate(at)jus.gov.on.ca) on Monday, May 26, 2003 at 12:49:04 > >Monday, May 26, 2003 > >John Crate > >, >Email: john.crate(at)jus.gov.on.ca >Comments/Questions: Hi Bob > >A couple of questions. Is there a problem suspending the fuse blocks >upside down under the panel. My plan was to mount them on a platform with >one end hinged to the panel and the other end fastened to the forward >subpanel with zus fastener. This fill allow me to let them them swing >formard for access if needed. Will the wires still be secure with the >faston terminals hanging down? Sure . . . >I need to order a D25 Diode assembly. I ordered a bunch of parts from >B&C, but they were unable to supply the diode. Do I order it directly >from you? No, I don't sell parts any more. You can use a Radio Shack 276-1185 . . . I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . |---------------------------------------------------| | A lie can travel half way around the world while | | the truth is till putting on its shoes . . . | | -Mark Twain- | |---------------------------------------------------| ________________________________________________________________________________
Subject: Z-14
Date: May 26, 2003
I am using a Z-14 wire schematic and have a couple of questions: Is there any scenario where a failure on one bus would require you to turn off the battery for that bus, but not be able to use the crossfeed contactor to power important items on that bus? For example, I have a nav/com on each of the two bus's. The audio panel and transponder is on the Aux Bus. If the Aux bus fails and it switched off, is there any situation that would prohibit me from using power from the Main bus through the crossfeed contactor? Is this something I need to worry about? Second Question: How low can the voltage go, when on battery power only, before you expect to see instrements stop working? - Jim ________________________________________________________________________________
Subject: Re: VERY confused about AMP Mate-N-Lok connectors
Date: May 26, 2003
Thanks much for the response and explanation of this stuff (and also for the response on the diodes). Question...have you ever used a miniature 5-pin DIN connector in an aircraft application? I was thinking it would be ideal as a Ray Allen trim servo 5-wire connector, but I bailed on the idea because of the length of the connector and the lack of a "detent" -- and my being generally unsure about the connector's durability in a high-vibration, possibly high-moisture setting. Just curious if you'd give a thumbs up or down on it. Thanks again, )_( Dan ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: VERY confused about AMP Mate-N-Lok connectors > > > > >I'm sitting here looking at the Digikey & Mouser catalogs, and I'm totally > >confused about AMP Mate-N-Lok connectors. There are Commercial, Universal, > >and Universal II. Each one seems to use a mutually exclusive pin/socket > >type. > > > >Then...ok, let's say I've got 22 AWG wire that needs to be connected. I'm > >looking at the contacts selection and there are "30-22AWG" and "24-18AWG" > >ranges. Then there are brass, brass gold, brass pre-tin, phosphor bronze, > >etc. > > > >Then there's what Terminal Town sells, and who knows what that stuff is. > > > >I've looked on a zillion aircraft builder web sites and sure, everybody says > >to use Mate-N-Lok connectors. Ok, would if I could...nobody spells out the > >specific parts! > > For wires up to and including 20AWG, I'd go for d-subs. MUCH > better connectors, easier to work with and more compact to boot. > > >SHEEEEESH. > > > >Can somebody give me a CLEAR answer about which connectors are ideal for > >free-hanging applications in aircraft? > > > >How about the required tools? Since these catalogs seem to sell different > >crimpers for different style connector contacts (yes, the crimper part #s > >are *different*), I can't tell what's what. > > > >Is the BCT-1 a crimp-all-end-all tool? > > I've found that it works on every open barrel pin I've tried it on > including the full range mate-n-lock, waldom/molex, and d-subs . . . > but I used it perhaps once every two years. I seldom design open barrel > pins into my products and use the tool mostly to service an existing > connector. > > If you need just one or two, consider the radio shack 274-224 thru > 274-242 connectors. They come in sets with appropriate pins. They > can be installed with the BCT-1. They are offered in 2 to 12 wires > per connector. The pins are size in the wire-grip for larger wires > like 14-18 . . . but you can dike the tabs down to make them suited > to the smaller wires. > > What you're trying to do is get a joint that looks like figure > 5 in http://www.aeroelectric.com/articles/matenlok/matenlok.html > > The tabs for 20 and 20AWG wire are quite short. > > Bob . . . > > -------------------------------------------- > ( Knowing about a thing is different than ) > ( understanding it. One can know a lot ) > ( and still understand nothing. ) > ( C.F. Kettering ) > -------------------------------------------- > > ________________________________________________________________________________
Date: May 27, 2003
Subject: Re: Z-14
> >I am using a Z-14 wire schematic and have a couple of questions: > >Is there any scenario where a failure on one bus would require you to turn >off the battery for that bus, but not be able to use the crossfeed contactor >to power important items on that bus? the crossfeed contactor will energize from either bus. Note the pair of diodes that feed the (+) end of contactor coil from opposite busses. >For example, I have a nav/com on each of the two bus's. The audio panel and >transponder is on the Aux Bus. If the Aux bus fails and it switched off, is >there any situation that would prohibit me from using power from the Main >bus through the crossfeed contactor? Is this something I need to worry >about? > >Second Question: >How low can the voltage go, when on battery power only, before you expect to >see instrements stop working? DO-160 calls for useful operation down to 9v, a battery is 95% used up at 10.5 volts so if you're battery only, the 9v figure is somewhat meaningless. Bob . . . ________________________________________________________________________________
Date: May 27, 2003
Subject: Re: DIN connectors?
> >Thanks much for the response and explanation of this stuff (and also for the >response on the diodes). > >Question...have you ever used a miniature 5-pin DIN connector in an aircraft >application? I was thinking it would be ideal as a Ray Allen trim servo >5-wire connector, but I bailed on the idea because of the length of the >connector and the lack of a "detent" -- and my being generally unsure about >the connector's durability in a high-vibration, possibly high-moisture >setting. I considered the miniature DIN connectors when I crafted the comic book at http://www.aeroelectric.com/articles/macservo/macservo.html They're probably okay but much more difficult for the neophyte solder slinger to get a good installation and they're not a great deal smaller than the d-sub illustrated. D-subs are my personal favorites . . I try to make that connector work first before dragging out catalogs for alternatives. Bob . . . ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: XPDR antenna question
Date: May 27, 2003
Hi Bob and all, This is an installation question. I'm intending to install the transponder antenna in the fiber glass fairing below the tail. The ground plane is to be an aluminum cross, with the lateral arms bent to follow the fairing skin, and the antenna in the middle. Are there any drawbacks with this idea ? I posted some picture of the cardboard model at : http://gilles.thesee.free.fr/temp/DSCF1543.JPG http://gilles.thesee.free.fr/temp/DSCF1544.JPG http://gilles.thesee.free.fr/temp/DSCF1545.JPG http://gilles.thesee.free.fr/temp/DSCF1546.JPG Thanks, Gilles ________________________________________________________________________________
Date: May 27, 2003
Subject: Re: RFI and Grounds... Long
Canyon wrote: >1. Is there any such thing as a short circuit? Gone longer than I thought I'd be this weekend. Getting back to the perspective I had hoped to impart here, the short answer is it depends on how short it needs to be. If you are dealing in power circuits it may not be critical to performance that a connection be perfect and pure. Therefore, sometimes just connecting to the right general ground potential can be good enough. OTOH, if you're dealing with small signals, processing millivolts to nanovolts or concerned with measuring or detecting microamps to picoamps, generally speaking, there ain't no such thing as a short circuit. What you may need is as good a connection to a common point as you can figure out how to build and good separation of various return currents. How often does this happen with aircraft? Not often enough to be fearful of it, but I'd bet often enough to require one to be attentive to detail. Example areas in which to be attentive to detail would be with such things as the nav/com and other avionics. You're not likely to get in trouble with the battery mains, alternator circuits and such if you don't mix the return paths of the small signal devices in with these power circuit returns. Ideally you want any current flowing directly to sensitive devices to flow back on the return line as directly to the power source as possible without intervening currents flowing through that same return path from other devices. In fact, this ideal is the basis for GFI devices which have saved many lives in plain old residential power environments. Bob offers a great solution for many with the idea of feeding power through the firewall on a bolt, with avionics returns on the cockpit side and power stuff on the firewall side for the heavier currents. This tends to sort potential errors toward minimum effect. >2. Can two wires occupying the same physical space and carrying equal >currents of opposite polarity radiate energy externally? No, and thinking about that is helpful. If you could accomplish this, then the circuit would neither gather nor emit contaminating external signals. Since it's not physically possible, what's the next best thing? The simple idea is the inspiration for two practical near perfect solutions. First, you can twist two wires evenly with regular, frequent twists and come reasonably close to approximating the two wires occupying the same physical space. To the extent that it's not perfect, it will perform imperfectly. But, for most purposes, this is very effective in the real world as both sides of the circuit are exposed in essentially the same phase and magnitude to both magnetic and electrostatic external signals and the opposite currents in the pair cancel one another. As the wavelengths of AC signals become shorter, the effectiveness is reduced. But there is another way to emulate what we can't really construct -- coax is also inspired by the same simple idea and offers a number of advantages for RF circuits, including our usual VHF and higher frequency signals. There exists even triax and quadrax versions of the same space emulation solutions, similar to the coax for use in specialized areas. So when thinking about how to hook things up for low noise, remember two things: 1: Keep small signal circuits (i.e., RF=typical 1uv or less) paired as close as possible to the ideal of both wires exposed the same way and in the same amount and keep exposure minimized. 2. Always try to return the signal current offered by any avionics (signal) device as directly to the source return as is possible without other intervening currents mixed in with that signal. Almost forgot, shielded twisted pair is often called out in audio and similar applications. The shield is primarily intended for electrostatic decoupling of the wire pair. All you really need to do is hook up one end of that shield to drain off any charge to a proper source return point. A whiteboard would be a lot easier for explaining this kind of thing, but I hope someone finds this useful. Steve ________________________________________________________________________________
Subject: dimmer circuit
Date: May 27, 2003
Perhaps I have put the cart before the horse, but I would like to make a dimmer circuit for my annunciator panel (Which has already been cut into my panel). Is anyone able/willing to suggest a scematic for the dimmer circuit? I have 6 LEDs & a single mini switch that can control it. This is the explanation of how each are proposed to be connected. Label Intent How connected Main Alt Fail Warn of Alt Fail hooked up to the LR3 indicator circuit Aux Alt Fail Warn of Alt Fail hooked up to the LR3 indicator circuit X-Feed On Warn of engaged X-feed Hooked up per Z-14 diagram between posts 5 and 2 on the crossfeed switch. Starter On Warn of stuck starter connected to the I terminal on the Starter Contactor (S702-1) and Ground. Oil Pressure Low Warn of low oil pressure connected to the I terminal on the Oil pressure switch (S710-1) and the Aux Bus Fuse Box. A/P On Warn that A/P is engaged (light out, not engaged) Connected to the Autopilot Control unit power and Ground. Thanks, Jim ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: dimmer circuit
There is a neat dimmer kit you might want to look at with 3 channels (three separate outputs all slaved to a master control) with several other options described in the June 2003 Custom Planes. The kit is also available from A&T Labs at http://www.a-and-t-labs.com/ I have the kit assembled and it looks pretty good - silk screened plated thru holes on the PC board, etc. The price varies as you only have to pay for what features you use. Gary Liming > >Perhaps I have put the cart before the horse, but I would like to make a >dimmer circuit for my annunciator panel (Which has already been cut into my >panel). ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: Diode failures and "Reliable Systems"
> > >Bob responded "excellently" to David Carter's story about a diode failure, >then asked the question at the end: > > > Going back to the 2-cent diode bringing down $millions$ worth of >equipment. How is this anecdote relevant to how a $5 diode > > is bolted to your airplane? > > > > Bob . . . > >David replies: The diode in Z13 that passes Main bus power to E-bus isn't >relevant to the million dollar anecdote - and poses zero threat to my >airplane. > >Since I sent that e-mail, I've engaged my brain a bit more tightly (learning >how to "think like an electron"?) and realized that the switch I proposed - >paralleling around the "failable" diode - "in case it failed" (open), added >NOTHING - it simply duplicated the existing "E-bus switch" in Z-13 - it >would pass power from main bus to e-bus. > - If that diode opened, killing my e-bus radios, etc, I didn't need >the proposed switch - I only needed to close the "E-bus switch" shown in >Z-13 to power the E-bus from the other side (left side) of the Main Battery >Contactor. > >I apologize for being a bit slow at this stuff. It's getting clearer as I >"exercise" my rusty, dusty electron knowledge. Seems like I had "tunnel >vision" on a particular part of the schematic, started "what if'ing", and >lost sight of the "big picture". Not a problem my friend. Please don't succumb to some notion that an apology is in order. I hope that reasons most people have for belonging to this list include giving and receiving assistance in filtering chaff from good stuff. We are surrounded by uncountable sources of unfounded, illogical information. We're all at various stages of practice in the art of organizing our collective basket of simple-ideas into the most efficient designs. May I suggest no useful purpose is served to beat yourself up for loosing sight of simple-ideas in the chaff-storm . . . it happens to all of us. I am certain that my teachers have no feelings of insult nor do they expect any regrets on my part when I benefit from their guiding beams-of-light in the storm. For myself, it's a been a good day when I hit the sack with some new simple-idea in mind that adds to my ability to serve the folks who reward me for my labors. Bob . . . ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: May 28, 2003
Could you be more specific in exactly what kit that is you got from A&T Labs? I have checked their web site and don't find anything that looks like it is a dimmer control. Thanks. Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Working on Canopy of Finish Kit ----- Original Message ----- From: "Gary Liming" <gary(at)liming.org> Subject: Re: AeroElectric-List: dimmer circuit > > > There is a neat dimmer kit you might want to look at with 3 channels (three > separate outputs all slaved to a master control) with several other options > described in the June 2003 Custom Planes. The kit is also available from > A&T Labs at > http://www.a-and-t-labs.com/ > > I have the kit assembled and it looks pretty good - silk screened plated > thru holes on the PC board, etc. The price varies as you only have to pay > for what features you use. > > Gary Liming > > > > >Perhaps I have put the cart before the horse, but I would like to make a > >dimmer circuit for my annunciator panel (Which has already been cut into my > >panel). > > ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: XPDR antenna question
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >This is an installation question. >I'm intending to install the transponder antenna in the fiber glass fairing >below the tail. >The ground plane is to be an aluminum cross, with the lateral arms bent to >follow the fairing skin, and the antenna in the middle. >Are there any drawbacks with this idea ? > >I posted some picture of the cardboard model at : > > >http://gilles.thesee.free.fr/temp/DSCF1543.JPG >http://gilles.thesee.free.fr/temp/DSCF1544.JPG >http://gilles.thesee.free.fr/temp/DSCF1545.JPG >http://gilles.thesee.free.fr/temp/DSCF1546.JPG > >Thanks, > >Gilles When the ground plane cannot be "flat" it is better that departures from flatness deflect away from the antenna, not toward it. Also, if you can keep the radials more disk-like, your radiation pattern will be more uniform. I would start with a round ground plane and then bend some flanges in the disk to conform to inside surfaces for attachment to the airframe. Bob . . . ________________________________________________________________________________
Date: May 28, 2003
Try this link. http://www.a-and-t-labs.com/K11_Dimmer/index.htm Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of LarryRobertHelming Subject: Re: AeroElectric-List: dimmer circuit Could you be more specific in exactly what kit that is you got from A&T Labs? I have checked their web site and don't find anything that looks like it is a dimmer control. Thanks. Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Working on Canopy of Finish Kit ----- Original Message ----- From: "Gary Liming" <gary(at)liming.org> Subject: Re: AeroElectric-List: dimmer circuit > > > There is a neat dimmer kit you might want to look at with 3 channels (three > separate outputs all slaved to a master control) with several other options > described in the June 2003 Custom Planes. The kit is also available from > A&T Labs at > http://www.a-and-t-labs.com/ > > I have the kit assembled and it looks pretty good - silk screened plated > thru holes on the PC board, etc. The price varies as you only have to pay > for what features you use. > > Gary Liming > > > > >Perhaps I have put the cart before the horse, but I would like to make a > >dimmer circuit for my annunciator panel (Which has already been cut into my > >panel). > > ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: KA-25 hummmmmmmmmm . . .
>Below is the result of your inquiry. It was submitted by >Kelly Dossett (Kelly.Dossett(at)wnco.com) on Tuesday, May 27, 2003 at 14:36:55 > >Tuesday, May 27, 2003 > >Kelly Dossett > >, >Email: Kelly.Dossett(at)wnco.com >Comments/Questions: Dear Bob - >I beleive I am lucky to have found your website! Help! > > From a quick review, I was looking for a simple trouble-shooting > guide/advise you may have put together. > >As you guessed, I have a electrical problem on my airplane! > >I have a 1974 Grumman AA-5 "Traveler". Yesterday (27 May 2003) while >flying in the local area, a massive/load electrical "Hummmmmmm" developed. >This "hum" is noted over the speaker, as well as through my headsets/intercom. > >Upon landing and shutdown, I performed some minor troubleshooting. The >"hum" is even noted, just as soon as I flip-on the Master-Switch! >avionics Master-Switch is still in the OFF position) I mean to tell you, >this "hum" is very loud. (the sound is like an electric motor is binding) > >Today, 24 hours later, I have determined, for what it is worth, that if I >un-plug my KA-25 (King Isolation Amp.) the loud "hum" will cease. > >I know you must be "bombarded" with these types of questions. However, if >you might be able to offer ANY ADVISE on how I might be able to better >troubleshoot this problem, I would be so very grateful. > >In layman's terms, what function does the KA-25 serve? >Could this KA-25 unit be my problem? > >Or, do you suspect my problem is elsewhere? > >My many, many thanks! > >Mr. Kelly Dossett >N7167L @ KDTO - Denton Muni >(Just north of Dallas, Texas) The KA-25 is an audio isolation amplifier that combines head-set only outputs from multiple receivers to a single headset feed . . . it also mounts an audio power amplifier to drive the cabin speaker. The audio isolation amplifier may also have an intercom function. It also may process warning tones from other systems. This is why it's common practice to wire the audio system to the main bus so that it will function with the avionics master switch turned off. I suspect something has failed in the KA 25 or it's associated wiring to cause an oscillation (not unlike the feedback you get on some PA systems with poorly placed microphones) except this is a totally electronic phenomenon. You will probably need the assistance of an avionics technician who is more familiar with this system. I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . |---------------------------------------------------| | A lie can travel half way around the world while | | the truth is till putting on its shoes . . . | | -Mark Twain- | |---------------------------------------------------| ________________________________________________________________________________
Date: May 28, 2003
> I would start with a round ground plane > and then bend some flanges in the disk > to conform to inside surfaces for attachment > to the airframe. > > Bob . . . Bob, Thank you for your answer. I'll have another try with a round ground plane. The reason for bending downward was because the top 4 inches of the fairing are lined with carbon fiber. Thus the whole setup could be placed below this conductive limit without bottoming the antenna. Cheers, Gilles ________________________________________________________________________________
From: "Werner Schneider" <wernerschneider(at)compuserve.com>
Subject: Crimp tool metric an AWG
Date: May 28, 2003
Bob and all, I was able to organize here in Switzerland a crimp tool for thicker wire. Problem is, the dies supplied with the pliers is metric, I was able to find a conversion table (thanks to google ) AWG 2 dia 6.54 mm area 33.60 mm2 AWG 6 dia 4.11 mm area 13.30 mm2 The dies I have say 6/10/16/25/35 I believe this is mm2 exactly it says something like 12 KP Cu 25 where the KP seems to be the brand small K lower rear leg extend downwards in something like a half circle. I would prefer to crimp, can I use the 10 die for AWG 6 and the 35 for AWG 2? Is this safe? Any help very much appreciated! Many thanks Werner ________________________________________________________________________________
Date: May 28, 2003
><Gilles.Thesee@ac-grenoble.fr> > > > I would start with a round ground plane > > and then bend some flanges in the disk > > to conform to inside surfaces for attachment > > to the airframe. > > > > Bob . . . > >Bob, > >Thank you for your answer. I'll have another try with a round ground plane. >The reason for bending downward was because the top 4 inches of the fairing >are lined with carbon fiber. Thus the whole setup could be placed below this >conductive limit without bottoming the antenna. Fine, the bent tabs of the ground plane can couple to the carbon fiber . . . this is good. Primary goal is to give the antenna best possible 360 degree line of sight to the horizon. Bob . . . ________________________________________________________________________________
Date: May 28, 2003
> > Fine, the bent tabs of the ground plane can couple to the > carbon fiber . . . this is good. Primary goal is to > give the antenna best possible 360 degree line of sight > to the horizon. > > Bob . . . Bob, It's nice to get instant advice. Does it look better now ? http://gilles.thesee.free.fr/temp/DSCF1550.JPG http://gilles.thesee.free.fr/temp/DSCF1554.JPG http://gilles.thesee.free.fr/temp/DSCF1555.JPG Thanks a lot, Gilles ________________________________________________________________________________
Date: May 28, 2003
><Gilles.Thesee@ac-grenoble.fr> > > > > > > Fine, the bent tabs of the ground plane can couple to the > > carbon fiber . . . this is good. Primary goal is to > > give the antenna best possible 360 degree line of sight > > to the horizon. > > > > Bob . . . > >Bob, >It's nice to get instant advice. > >Does it look better now ? >http://gilles.thesee.free.fr/temp/DSCF1550.JPG >http://gilles.thesee.free.fr/temp/DSCF1554.JPG >http://gilles.thesee.free.fr/temp/DSCF1555.JPG That's it! >Thanks a lot, You're most welcome . . . Bob . . . ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: Crimp tool metric an AWG
> > >Bob and all, > >I was able to organize here in Switzerland a crimp tool for thicker wire. >Problem is, the dies supplied with the pliers is metric, I was able to find >a conversion table (thanks to google ) > >AWG 2 dia 6.54 mm area 33.60 mm2 >AWG 6 dia 4.11 mm area 13.30 mm2 > >The dies I have say 6/10/16/25/35 I believe this is mm2 > >exactly it says something like 12 KP Cu 25 where the KP seems to be the >brand small K lower rear leg extend downwards in something like a half >circle. > >I would prefer to crimp, can I use the 10 die for AWG 6 and the 35 for AWG >2? > >Is this safe? > >Any help very much appreciated! What you have hypothesized about the die sizes seems reasonable. Give it a try. Saw the test terminal in two centered on the wire grip. Sand the sawed end with increasingly finer sand paper until you can distinctly see individual strands (areas of bright copper surrounded by very thin lines of tin plating). The crimp should be totally free of visible voids . . . i.e. the terminal and wire have become one piece of metal. Bob . . . ________________________________________________________________________________
Date: May 28, 2003
Hi Jim- My annunciator panel is not fed with a dimmer, but my panel lights are. (If you have ACAD type stuff, I can send you a copy, if interested) I put one of these little PWM controllers together to use as a panel dimmer and it actually works! It worked great as a motor speed controller (you get a little motor with the kit) and it's rated for 10A, but I removed the motor F/R switch and bought a better quality pot to remote mount on the panel. The one with the kit is OK, just a little twitchy as you change the output. I've had a project board full of LEDs running off it for about a month total, so I suppose it should hold up OK. see: http://mpja.com/productview.asp?product=4057+MD Sixteen bux. I ordered this thing and it arrived as a bunch of parts in a ziplock, so I got to do a little soldering, which was a great confidence builder. They've got a lot of other neat stuff- bought a bunch of LEDs etc, low prices & no, I'm not affiliated! From The PossumWorks Mark Jim Pack wrote: > > Perhaps I have put the cart before the horse, but I would like to make a > dimmer circuit for my annunciator panel (Which has already been cut into my > panel). > > > Is anyone able/willing to suggest a scematic for the dimmer circuit? I have > 6 LEDs & a single mini switch that can control it. > > > This is the explanation of how each are proposed to be connected. > > > Label > Intent > How connected > > Main Alt Fail > Warn of Alt Fail > hooked up to the LR3 indicator circuit > > Aux Alt Fail > Warn of Alt Fail > hooked up to the LR3 indicator circuit > > X-Feed On > Warn of engaged X-feed > Hooked up per Z-14 diagram between posts 5 and 2 on the crossfeed > switch. > > Starter On > Warn of stuck starter > connected to the I terminal on the Starter Contactor (S702-1) and > Ground. > > Oil Pressure Low > Warn of low oil pressure > connected to the I terminal on the Oil pressure switch (S710-1) and the > Aux Bus Fuse Box. > > A/P On > Warn that A/P is engaged (light out, not engaged) > Connected to the Autopilot Control unit power and Ground. > > > Thanks, > > Jim > > > > > > > > ________________________________________________________________________________
Date: May 28, 2003
Subject: Re: Microair Radio-Xpdr Wire Harness
> > >----- Original Message ----- >From: "Rick Fogerson" <rickf(at)cableone.net> >To: >Subject: Re: AeroElectric-List: Fw: Electric Bob - Microair Radio-Xpdr Wire >Harness I can ship tomorrow morning. I have the following data from your last order: Rick Fogerson 7558 W. Hathaway Ct Boise, ID 83703 Country: USA Phone: 208-853-0436 Email: rickf(at)velocitus.net The visa you used ended in -0629 . . . do you want to use this same card? VISA/Mastercard: xxxx-xxxx-xxxx-0629 Expiry: 07/04 Bob . . . ________________________________________________________________________________
Date: May 29, 2003
> > > >Does it look better now ? > >http://gilles.thesee.free.fr/temp/DSCF1550.JPG > >http://gilles.thesee.free.fr/temp/DSCF1554.JPG > >http://gilles.thesee.free.fr/temp/DSCF1555.JPG > > That's it! > Bob, Thanks once more for the knowledge you share with us, and the swiftness of your answers. Regards, Gilles ________________________________________________________________________________
Date: May 29, 2003
> "Robert L. Nuckolls, III" wrote: >> RF goes around corners . . . a radial that is physically >> 1/4 wave length over all still has a low impedance node >> at the base of the antenna if some portion of the end >> takes a 90 degree turn. >> >> "Ground plane" means that you're looking for a zero-ohms >> connection to free space at the end of the transmission >> line for the coax shield connection. If the base impedance >> of a 1/4 wave is on the order of 30 ohms, then 4 radials >> paralleled gives you a 'ground' impedance of about 7 ohms, >> 10 radials would be 3 ohms, etc. One can imagine that >> a disk is made of an infinite number of radials in parallel >> for an ideal 'ground' impedance approaching zero ohms. >> >> Obviously simplistic, there are some additional effects that >> keep us from getting zero but for all practical purposes, >> we can get quite close . . . the overall shape of those 1/4 wave >> radials is not terribly critical. It's length from base of antenna >> to the edge irrespective of shape . . . that's the "magic" of >> a circular ground plane as opposed to a square one . . . square >> gets you 4 radials at the right length and a bunch of others >> too long. Circular makes them all the same length. > >I *think* square - with the dimention a touch undersize - gets you 8 >radials the right length, and an infinite number a little long or a little >short. A hexagon would get you 12 accurate radials, etc. Yup, that's right too . . . >If your diameter is just right, then yes, you have an infinte number of >accurate radials. But what exactly is that diameter? And if you're off >by (say) .125" on a circular ground plane, you have NO accurate >radials. In that case would you be better off with a square or hexagonal one? When you see a vertical antenna with ground plane radials under it perched on top of some tower or building, it's not uncommon to have just 4 radials . . . and as mentioned above, this gives you a "ground impedance" about 1/4th that of the antenna . . . adding more "perfect" radials has a diminishing return on the effort . . . adding 4 more radials only improves on the original 4 by a few percent. Doubling the number again gives you the same percentage improvement. From a power transfer perspective, the guy at the other end would not perceive any improvement in your signal by jumping from 4 to an infinite number of radials. Radiation pattern is also affected by ground plane area and it's shape. You often see radials "drooped" downward. This has two beneficial effects. It raises the matching impedance of the antenna to more nearly equal 50-ohm coax and lowers the radiation angle from approx 45 degrees to some pattern more nearly on the horizon. >Or do I misunderstand - is the 1/4 wave length the minimum, or the optimum? It's "optimum" . . . for a 1/4 wave radial is "tuned" to the frequency of interest. You can get similar performance with 3/4 or any other odd multiples of quarter wave . . and once you're out more than a wavelength or two, you have what's called an "infinite ground plane" wherein actual size variations have no measurable effect on antenna characteristics. Bob . . . ________________________________________________________________________________
Subject: The loss of a horseshoe nail
Date: May 29, 2003
Bob, Off the topic - somewhat. I just couldn't stop sending this - your analogy of the lost horseshoe nail and designing a three-legged horse which could fight is a luxurious and creative one of the best. I don't think we'll ever forget the mental corridor we'll travel in future..................... A milestone. Ferg ________________________________________________________________________________
Subject: King GNS-80
Date: May 29, 2003
Hello all, This may be slightly off topic but there may be others with a similar nagging query... I am collecting instruments and avionics as I construct my RV-8 in an effort to spread the costs over time and to take advantage of "deals" as I come across them. Does anyone have experience with the King KNS-80? This is an all in one unit that incorporates VOR/LOC/GS/DME in one box. From a panel space and installation standpoint it has advantages. From a reliability standpoint it would seem to be a single point failure item. Narco has a similar unit (122 D) with VOR/LOC/GS. OBS/LOC/GS indicators: Is there a standard I/O from receiver to indicator or does each manufacturer have their own signal/data I/O? If they are manufacturer specific is each manufacturer consistent or does each manufacturer have variants within their own product lines? i.e. can I use a Sperry indicator with a King receiver? Antennas... I have followed the discussions on antennas and have decided to go with the Sportcraft VOR/COM wingtip antenna. Can this also be used for the Localizer? I have a Marker Beacon and Transponder antenna. Will I need a separate Glide Slope antenna? I would like to keep the airframe clean i.e. no antennas hanging everywhere. If a separate GS antenna is required can it be mounted inside the fiberglass wingtip? I realize I have posted questions that my require lengthy answers... This is my primary source for aircraft/avionics expertise, and a good one it is! Thanks! Chris Stone RV-8 - wings Slowly drying out in Oregon ________________________________________________________________________________
Date: May 29, 2003
Subject: Re: The loss of a horseshoe nail
> >Bob, > Off the topic - somewhat. > I just couldn't stop sending this - your analogy of the lost >horseshoe nail and designing a three-legged horse which could fight is a >luxurious and creative one of the best. I don't think we'll ever forget the >mental corridor we'll travel in future..................... > A milestone. Thank you for your kind words sir . . . Bob . . . ________________________________________________________________________________
Subject: My Fuel Gauge Design and Linearizing
Date: May 29, 2003
Here's the plan: I have every faith in fuel flow rate but realize the need for fuel gauges. I like the elegance of the capacitive sensors but not their complexity. So how about this-- Put ten tiny tiny tiny 0805 size PTC thermistors on a flex circuit with a Gortex sleeve over it. Arrange these logarithmically so that they can be read-out by a 10-led bar graph. Stuff it through a 1/4" rivnut installed in each tank. On the instrument panel, 10 leds100%, 9 leds70.7%, 8 leds50%, 7 leds35.4%, 6 leds+ 25%, 5 leds17.7%, 4 leds12.5%, 3 leds8.8%, 2 leds6.2%, 1 led4.4%. Use an LM3915 display driver. Greater precision as the fuel is depleted. This makes enormous sense, since no one cares how much they have when they are full of fuel. This also makes up for using the bar graph. Now where does the FAA required "Red radial line marking zero" go? I just don't know. PS- There is one Powerlink 1280 Amp solid state starter battery contactor flying (on a dual battery split system). Seems to be working perfectly. I am making a new run of an updated and improved design. This is still in a test phase, but versions of the new design will be for sale assuming all goes well in the testing. Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net "Nothing is too wonderful to be true." - James Clerk Maxwell, discoverer of electromagnetism "Too much of a good thing can be wonderful." - Mae West, discoverer of personal magnetism ________________________________________________________________________________
Date: May 29, 2003
Subject: Re: Alternator noise on Grumman
>Below is the result of your inquiry. It was submitted by >Fred Hardy (frederick.a.hardy(at)boeing.com) on Wednesday, May 28, 2003 at >11:14:57 > >Wednesday, May 28, 2003 > >Fred Hardy > >, >Email: frederick.a.hardy(at)boeing.com >Comments/Questions: Hi Bob, My '78 Grumman Tiger has a loud whine coming >from the alternator through the headsets. I had the alternator checked at >annual (4/03)and the IA stated the brushes were about 50% worn. Also a new >filter was installed in 2002. The unit charges the battery without any >problems. The alternater is original equipment (25 years/1200 >hours). I've been reading up on this and it seems that I have a bad >diode(s). Should I have the unit totally rebuilt or just have the diodes >replaced? You need to load test the alternator. You can do this with a battery tester before you take it off the airplane. Put a voltmeter on the bus. With engine running at or near 2000 rpm, bring alternator on and increase load on battery up to the rating of the alternator. If you can get more than 1/2 or 2/3rds rating of alternator without drooping the bus to less than 13.0 volts, then your diodes are okay. Did this problem just crop up? Was it after the annual? I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . |---------------------------------------------------| | A lie can travel half way around the world while | | the truth is till putting on its shoes . . . | | -Mark Twain- | |---------------------------------------------------| ________________________________________________________________________________
Date: May 29, 2003
Subject: Re: King GNS-80
On Thursday, May 29, 2003, at 09:49 AM, Chris Stone wrote: > s anyone have experience with the King KNS-80? This is an all in one > unit that incorporates VOR/LOC/GS/DME in one box. From a panel space > and installation standpoint it has advantages. From a reliability > standpoint it would seem to be a single point failure item. > Narco has a similar unit (122 D) with VOR/LOC/GS. I've got over 700 hours behind one. Easy to use, dead reliable. Absolute state of the art...when Jimmy Carter was president. I recently talked to the new owner of my old Navion, and the unit still works flawlessly, but he'sthinking about upgrading. It is, however, an RNAV. Even a cheap GPS sort of makes the RNAV/DME redundant and has more utility. If it's the cheapest way you can get VOR/GS to shoot ILS approaches, and it's a smoking deal, I'd go for it. If you are VFR and just want to navigate, I think the biggest bang for the buck is a Northstar M-1 Loran. About a hundred bucks on e-bay and works great. JFF P.S. It occurs to me that my old Navion is near you, in Washington State. You might look up the registration for 2512T and see if he is ready to make the change. JFF ________________________________________________________________________________
From: "Kevin and Marlys Cocozzoli" <mcocozzoli(at)satx.rr.com>
Subject: RFI
Date: May 29, 2003
Good Evening, I'm having trouble with radio interference in a Glasair III homebuilt I just finished and need some advice on what to look for. I'm not versed in avionics and there's no avionics shop at my airport. I have a UPSAT SL-30 Nav/Comm and SL-15 Audio Panel. The comm radio works fine in ground tests and with the engine running at low RPM I am both transmitting and receiving loud and clear. The problem surfaces when I increase the throttle to take off power. At approximately 2000 RPM my headset fills with static and I hear nothing but this static until I reduce RPM. Then everything's normal again. I was told by the kit maker that it may be the alternator. I pulled the alternator field circuit breaker but this had no effect. I would like to know what else I should look for as I have no idea why the radio would work fine until I advance the throttle. Tower states their not hearing the static so it's purely internal. Thank you very much for any help you can provide. Sincerely, Kevin Cocozzoli 210-666-6713 ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: RFI
Date: May 30, 2003
Are you very familiar with the **digital** setting of the squelch and other items on radio (I and friends have the SL-40). There are certain incantations spelled out in the manual that once done make a lot of sense but when you read the first time may seem a little strange. Suggestion: Take a pilot friend up for a flight and while one of you is flying the plane, the other take the manual and make adjustments with the headsets that you are normally going to use. Of course you could do this on the ground but the noise will be slightly differnt and you will be running your engine for some time at 2000 RPM+ without the benefit of cooling and scenery. Just a thought. James > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin > and Marlys Cocozzoli > Sent: Friday, May 30, 2003 12:12 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: RFI > > > Cocozzoli" > > Good Evening, > > I'm having trouble with radio interference in a Glasair III > homebuilt I just > finished and need some advice on what to look for. I'm not versed in > avionics and there's no avionics shop at my airport. > > I have a UPSAT SL-30 Nav/Comm and SL-15 Audio Panel. The comm radio works > fine in ground tests and with the engine running at low RPM I am both > transmitting and receiving loud and clear. The problem surfaces when I > increase the throttle to take off power. At approximately 2000 RPM my > headset fills with static and I hear nothing but this static > until I reduce > RPM. Then everything's normal again. > > I was told by the kit maker that it may be the alternator. I pulled the > alternator field circuit breaker but this had no effect. I would like to > know what else I should look for as I have no idea why the radio > would work > fine until I advance the throttle. Tower states their not hearing the > static so it's purely internal. > > Thank you very much for any help you can provide. > > Sincerely, > > Kevin Cocozzoli > 210-666-6713 > > ________________________________________________________________________________
Subject: Re: RFI
Date: May 30, 2003
Thanks James, I'll look into the manual. However, since this static starts at 2000 RPM, I obviously can't fly the plane until I get this worked out on the ground. I can't hear anything but static! But I'll check the manual...I should've thought of that. Thanks, Kevin ----- Original Message ----- From: "James E. Clark" <james(at)nextupventures.com> Subject: RE: AeroElectric-List: RFI Are you very familiar with the **digital** setting of the squelch and other items on radio (I and friends have the SL-40). There are certain incantations spelled out in the manual that once done make a lot of sense but when you read the first time may seem a little strange. Suggestion: Take a pilot friend up for a flight and while one of you is flying the plane, the other take the manual and make adjustments with the headsets that you are normally going to use. Of course you could do this on the ground but the noise will be slightly differnt and you will be running your engine for some time at 2000 RPM+ without the benefit of cooling and scenery. Just a thought. James > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin > and Marlys Cocozzoli > Sent: Friday, May 30, 2003 12:12 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: RFI > > > Cocozzoli" > > Good Evening, > > I'm having trouble with radio interference in a Glasair III > homebuilt I just > finished and need some advice on what to look for. I'm not versed in > avionics and there's no avionics shop at my airport. > > I have a UPSAT SL-30 Nav/Comm and SL-15 Audio Panel. The comm radio works > fine in ground tests and with the engine running at low RPM I am both > transmitting and receiving loud and clear. The problem surfaces when I > increase the throttle to take off power. At approximately 2000 RPM my > headset fills with static and I hear nothing but this static > until I reduce > RPM. Then everything's normal again. > > I was told by the kit maker that it may be the alternator. I pulled the > alternator field circuit breaker but this had no effect. I would like to > know what else I should look for as I have no idea why the radio > would work > fine until I advance the throttle. Tower states their not hearing the > static so it's purely internal. > > Thank you very much for any help you can provide. > > Sincerely, > > Kevin Cocozzoli > 210-666-6713 > > ________________________________________________________________________________
Subject: RFI
Date: May 30, 2003
Well, give it a try on the ground with another pilot rev'ing the plane up. Read up and make some minor adjustments BEFORE you start the engine so you have a feel for the process and how to get to the various settings. There are a lot of things you can adjust. Good luck. James > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin > and Marlys Cocozzoli > Sent: Friday, May 30, 2003 2:22 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: RFI > > > Cocozzoli" > > Thanks James, I'll look into the manual. However, since this > static starts > at 2000 RPM, I obviously can't fly the plane until I get this > worked out on > the ground. I can't hear anything but static! But I'll check the > manual...I should've thought of that. > > Thanks, > > Kevin > > ----- Original Message ----- > From: "James E. Clark" <james(at)nextupventures.com> > To: > Subject: RE: AeroElectric-List: RFI > > > > > Are you very familiar with the **digital** setting of the squelch > and other > items on radio (I and friends have the SL-40). There are certain > incantations spelled out in the manual that once done make a lot of sense > but when you read the first time may seem a little strange. > > Suggestion: > > Take a pilot friend up for a flight and while one of you is flying the > plane, the other take the manual and make adjustments with the > headsets that > you are normally going to use. > > Of course you could do this on the ground but the noise will be slightly > differnt and you will be running your engine for some time at 2000 RPM+ > without the benefit of cooling and scenery. > > Just a thought. > > James > > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin > > and Marlys Cocozzoli > > Sent: Friday, May 30, 2003 12:12 AM > > To: aeroelectric-list(at)matronics.com > > Subject: AeroElectric-List: RFI > > > > > > Cocozzoli" > > > > Good Evening, > > > > I'm having trouble with radio interference in a Glasair III > > homebuilt I just > > finished and need some advice on what to look for. I'm not versed in > > avionics and there's no avionics shop at my airport. > > > > I have a UPSAT SL-30 Nav/Comm and SL-15 Audio Panel. The comm > radio works > > fine in ground tests and with the engine running at low RPM I am both > > transmitting and receiving loud and clear. The problem surfaces when I > > increase the throttle to take off power. At approximately 2000 RPM my > > headset fills with static and I hear nothing but this static > > until I reduce > > RPM. Then everything's normal again. > > > > I was told by the kit maker that it may be the alternator. I pulled the > > alternator field circuit breaker but this had no effect. I > would like to > > know what else I should look for as I have no idea why the radio > > would work > > fine until I advance the throttle. Tower states their not hearing the > > static so it's purely internal. > > > > Thank you very much for any help you can provide. > > > > Sincerely, > > > > Kevin Cocozzoli > > 210-666-6713 > > > > > > ________________________________________________________________________________
Subject: ground plane
Date: May 30, 2003
Bob, I've been following the thread about the optimum ground plane for the transponder. What is the optimum diameter for a circular ground plane? I'd like to mount the antenna on a 7" diameter aileron bellcrank access plate on the bottom of the wing of my Glasair. Others have done this, but I'll figure out something else if you think I should. Regards, Troy Scott ________________________________________________________________________________
Subject: Re: ground plane
Date: May 30, 2003
Troy, Here's what Bob said when I asked about this a while ago: If the ground plane is "small" . . . like less than a wavelength at frequency of interest, then it works best if "tuned" . . . i.e. exactly same radius as height of antenna or 5.3" diameter. Hope this helps. Nev ----- Original Message ----- From: "Troy Scott" <tscott@c-gate.net> Subject: AeroElectric-List: ground plane > > Bob, > > I've been following the thread about the optimum ground plane for the transponder. What is the optimum diameter for a circular ground plane? I'd like to mount the antenna on a 7" diameter aileron bellcrank access plate on the bottom of the wing of my Glasair. Others have done this, but I'll figure out something else if you think I should. > > Regards, > Troy Scott > > ________________________________________________________________________________
Date: May 30, 2003
Radius of ground plane disk should be at least the height of the transponder antenna. ----- Original Message ----- From: "Troy Scott" <tscott@c-gate.net> Subject: AeroElectric-List: ground plane > > Bob, > > I've been following the thread about the optimum ground plane for the transponder. What is the optimum diameter for a circular ground plane? I'd like to mount the antenna on a 7" diameter aileron bellcrank access plate on the bottom of the wing of my Glasair. Others have done this, but I'll figure out something else if you think I should. > > Regards, > Troy Scott > > ________________________________________________________________________________
Date: May 30, 2003
From: "William Yamokoski" <yamokosk(at)lmc.cc.mi.us>
Subject: What is that noise anyway?
Hi Folks, Just chiming in on the radio headset static that people are commenting on. I also have a situation where, on idle, there is no noise to speak of. Get up to cruise rpm and the noise/static is very pronounced. Doesn't matter if the intercom is on or off...speak into the microphone and loud static accompanies. I was thinking maybe it was associated with the MicroAir 760, but now we have other radio owners heard from as well. So just what is the source of that static? Is there any reference anyone has so I can read about it? Thanks very much...inquiring minds want to know. Bill Yamokoski ________________________________________________________________________________
Subject: ANL's, Z14 flexibility, and cigarette lighter receptacles...
Date: May 30, 2003
From: "I-Blackler, Wayne R" <wayne.blackler(at)boeing.com>
G'Day Bob, I have a few questions regarding my 'Z-14' system and general installation: a) I have ANL 40 current limiters installed for both the B&C SD-20 and 40A alternators I have installed. Aeroelectric.com states that "the 40 Amp device is suited for all alternators 40A and below". Your Z-14 diagrams show ANL30's, and a Matronics Search revealed that "B&C had 30's to go with the SD-20 alternator".."with the STC'd kits". I'm confused, is my current setup of 2 x ANL40's acceptable? b) I have the main bus (40A) supplied by 4AWG and the aux bus (20A) supplied by 10AWG. Is this acceptable in a crossfeed condition, or would 4AWG give me greater flexibility in a SD-20 failure condition? My understanding is that functionally, the 10AWG is 100% acceptable, but... c) I have 20AWG supplying a cigarette lighter receptacle straight off a hot battery bus. In your experience, is 20AWG (with 7.5A) fuse enough for general use (GPS, small light, small vacuum), or should I increase to 10A? or more perhaps? I have the IA-C23 handheld nav/comm drawing 1.8A during a transmit, and a handheld GPS I'm expecting way less.. What are some of these vacuum accessories drawing? Thanks in advance. Cheers Wayne Blackler ________________________________________________________________________________
Subject: Contactors
Date: May 30, 2003
How are contactors energized? I had always assumed that almost all of them must have a switch to Batt+, but I could be wrong, at least one pilot says that most of them use a switch to ground. What's going on? Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Date: May 30, 2003
Subject: Re: Contactors
Eric, I believe that typically, the master contactor is energized with a switch to ground, while the starter contactor is switched with + voltage, from the switched output of the master contactor. This avoids an always hot wire going to the master switch on the panel. Regards, Chris Good West Bend, WI RV-6A -- --------- Original Message --------- DATE: Fri, 30 May 2003 21:38:41 From: "Eric M. Jones" <emjones(at)charter.net> > >How are contactors energized? I had always assumed that almost all of them must have a switch to Batt+, but I could be wrong, at least one pilot says that most of them use a switch to ground. What's going on? > >Eric M. Jones >www.PerihelionDesign.com >113 Brentwood Drive >Southbridge MA 01550-2705 >Phone (508) 764-2072 >Email: emjones(at)charter.net > > Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail! ________________________________________________________________________________
Date: May 29, 2003
Date: May 30, 2003
Subject: Re: KNS 80
To Chris Stone, I bought a KNS80 for my project Cardinal and am about to put it in, I got a nice yellow tagged unit in great shape for well less that a grand, I've seen them on ebay go from a few hundred dollars (ratty looking) to about $900 real nice looking. Most but NOT ALL HAVE GLIDESLOPE so be sure to check part number and be sure to get the tray, backplate and connectors they can be pricey to find separately. The kns80 I am told uses an "arinc" standard cdi, but it isn't the same as my Narco "arinc". The cdi's are mostly not interchangeable, the King KI206 and KI520 I believe work and the Garmin/Midcontinent I believe work but those usually are pricey on ebay. A collins 350 or 351 work I forget which is the glideslope model. Whan I was looking I was warned to get the "A" model of the Collins as they corrected some problems then. I went with a KI206 indicator with glideslope, it will also work with the garmin gps so when the garmin 430 gets affordable I can use my cdi. That cdi will also work with the Garmin 155xl and 300xl gps. I have been told there are some Cessna/ARC indicators that will also work with the KNS80 and the Garmins but it was difficult getting confirmation. I almost bought an ARC that my avionics guy said would probably work for $90. So if you can get that confirmed you can probably put together a unit real reasonable. The Garmin tech told me that if it works on the King KX 165 or KNS 80 it will work on the Garmin 155/300/430/530 so that might help determine compatability. Something about the resolver being the key factor, I forget. Be sure the cdi has glideslope. I knew nothing about avionics and used the internet, some club sites (this site is new to me) Southeast Aerospace has a nice site that gives specifications but getting confirmation of compatability across manufacturers was difficult since nobody wants to take responsibility. As an avionics newbie that was a problem for me and I just paid for the KING cdi, partly because it can be used on the Garmin later. It's big and heavy and cheap and a cooling fan is I believe recommended. Good luck, Skip Simpson ________________________________________________________________________________
Subject: Re: transponder question
Date: May 31, 2003
Troy, No reason why that shouldn't work, just as long as the transponder antenna can make contact with the aluminium sheet. I've not even the first clue about fibreglassing mind you (mine being a wood plane). I had similar thoughts about putting the transponder antenna on an aluminium access panel underneath the fuselage. I decided against it, preferring to keep the outside of the plane as clean as possible. Also, I would rather an access panel was just that, and could be removed without pulling on the wires, etc. (despite there being an easily-undoable BNC connector). Finally, I'd rather the transponder cable leading up to the aerial would be fixed too, so that it won't flex, and perhaps fracture, in the long term. Perhaps this is overly cautious, but I'd rather leave as little to chance as possible. In the end I just put a little upside-down L-shaped bracket in the fuselage (fixed to one of the uprights that joins the top and bottom longerons), which holds the transponder aerial and ground plane in the correct attitude. Hope this helps. Nev ps. I've sent this reply via the list. ----- Original Message ----- From: Troy Scott To: nkilford(at)etravel.org Sent: Saturday, May 31, 2003 5:03 PM Subject: transponder question Thanks for your response on the Aeroelectric Forum. I need to use the full size 7" access plate for the aileron bellcrank. However, it occurred to me that I could switch to a 7" fiberglass plate with a correctly sized (5.3"? )thin sheet of aluminum bonded to the inside of it. This would serve as the ground plane and still allow me to mount the antenna where I'd planned. Thoughts? Regards, Troy Scott ________________________________________________________________________________
Subject: Handburn on antenna : fact or mythology ?
Date: Jun 01, 2003
Hi Bob and all, Here is a question that has kept bothering me for several weeks : A month ago I witnessed the electrician in an FBO advise his co-wokers never to touch a comm antenna during transmission. He said he did once and got a handburn. Question : How hot can an antenna get ? Was he telling the truth, or was he just reporting another hangar tale ? What is the physics behind the story ? Thank you for any feedback or explanation Regards Gilles ________________________________________________________________________________
Date: May 31, 2003
Subject: Re: Handburn on antenna : fact or mythology ?
It doesn't really get hot, but there is a bunch of energy there. (5-25W). You could get and RF burn, which isn't the same as grabbing the wrong end of a soldering iron. When I first got my ham license, I got a Swan 250 I think, and the first time I tuned it up (I didn't know what I was doing), I got zapped pretty good. burned the tiniest hole through the tip of my finger. Gilles.Thesee wrote: > > Hi Bob and all, > > Here is a question that has kept bothering me for several weeks : > A month ago I witnessed the electrician in an FBO advise his co-wokers never > to touch a comm antenna during transmission. He said he did once and got a > handburn. > > Question : How hot can an antenna get ? Was he telling the truth, or was he > just reporting another hangar tale ? What is the physics behind the story ? > > Thank you for any feedback or explanation > Regards > > Gilles ________________________________________________________________________________
Date: May 31, 2003
I have been burned by the RF from a ham radio. Touching one of those antennas during a transmission is NOT a "cool" thing to do. What happens is that you do NOT kow you are being burned until it is way too late. It is like the RF is boiling the blood inside your finger and you don't notice until it reaches the boiling point. Once I let go of the antenna (it was on a roof and someone transmitted when I did not expect such to occur) that is when it really burned for a while. I don't know how much energy was transmitted into my fingers but I do know it was enough. It is probably kinda like you don't want to be inside a microwave oven while it is on. It won't get hot but your insides REALLY will. James > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Gilles.Thesee > Sent: Saturday, May 31, 2003 6:04 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Handburn on antenna : fact or mythology ? > > > <Gilles.Thesee@ac-grenoble.fr> > > Hi Bob and all, > > Here is a question that has kept bothering me for several weeks : > A month ago I witnessed the electrician in an FBO advise his > co-wokers never > to touch a comm antenna during transmission. He said he did once and got a > handburn. > > Question : How hot can an antenna get ? Was he telling the truth, > or was he > just reporting another hangar tale ? What is the physics behind > the story ? > > Thank you for any feedback or explanation > Regards > > Gilles > > ________________________________________________________________________________
Date: Jun 01, 2003
Thanks to Tom and James for their answers. Boiling blood, that's hair raising ! Never had considered that. Cheers, Gilles ________________________________________________________________________________
Subject: Should I label wires at the connector end ?
Date: Jun 01, 2003
Hi Bob and all, Soldering 18-20 wires to a 25 pin D-Sub is an easy task, thanks to Bob's Shop-Note. I succeded in obtaining a neat array of wires in no time at all. But I went into the trouble of labelling each wire at the connector, which took twice the time and ended in a not too neat bunch of labels. Here is my question : Is it worth the trouble to label the wires at the connector end ? After all, isn't the pin number there to help identify the wire ? Thanks for your advice and feed-back on best practice. Cheers, Gilles ________________________________________________________________________________
Date: Jun 01, 2003
In common surgery, a surgeon will use a skin scalpel, but then does the majority of cutting AND WELDING of tissue with a "Bovie", the generic name for a hundred-year-old (!) electrosurgery unit. The device works by vibrating the water molecules inside the tissue cells until they explode. Thus the surgeon parts tissue like Moses through the Red Sea. Remarkably, a small tweak to the current, frequency and wave shape and the surgeon can stop bleeding and even weld tissue back together. A remarkable and NON-thermal device. Typically the voltage is hundreds of volts, the frequency is maybe a megahertz, and the delivered power can be 250 watts. Yikes! So why doesn't the patient jump right off the table like Galvani's frog? Nerve conduction progresses by the cells ions communicating from one nerve cell to another. In order to successfully conduct, the ion must travel across the cell to the cell wall. But if the electrical current reverses before this can happen, the ion only gets jostled around and never completes the whole journey. It turns out curiously, that maximum sensitivity to electrical frequencies peaks at 50-60 hertz. So what could the transmitter antenna do to your hand? if the antenna were thin enough, and tuned just right, it could cut your flesh to the bone with almost no thermal damage to adjacent tissue, so NO it's not "hot". Most antennas have too large an area to do much cutting. Nevertheless your hand would not like it even though there would be little thermal injury and no electrical shock. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Date: Jun 01, 2003
>> Soldering 18-20 wires to a 25 pin D-Sub is an easy task...Is it worth the trouble to label the wires at the connector end ? If it were me, I would just document the number/wire relationship and put it with the rest of the planes diagrams, notes, etc. You could also make a small label and put it near the connector if possible, however, if once everything gets closed up and such it my not be practical to read the label and then the docs make the most sense. Don -----Original Message----- From: Gilles.Thesee [mailto:Gilles.Thesee@ac-grenoble.fr] Subject: AeroElectric-List: Should I label wires at the connector end ? --> <Gilles.Thesee@ac-grenoble.fr> Hi Bob and all, Soldering 18-20 wires to a 25 pin D-Sub is an easy task, thanks to Bob's Shop-Note. I succeded in obtaining a neat array of wires in no time at all. But I went into the trouble of labelling each wire at the connector, which took twice the time and ended in a not too neat bunch of labels. Here is my question : Is it worth the trouble to label the wires at the connector end ? After all, isn't the pin number there to help identify the wire ? Thanks for your advice and feed-back on best practice. Cheers, Gilles direct advertising on the Matronics Forums. ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Re: Cheap blind encoder.
Date: Jun 01, 2003
----- Message d'origine ----- De : "Robert L. Nuckolls, III" : Envoy : jeudi 15 mai 2003 06:24 Objet : Re: AeroElectric-List: Cheap blind encoder. > You can drive multiple loads with one encoder but you need an array of > diodes to avoid cross-coupled problems between loads. I don't > recall now exactly how the diodes are oriented. I searched the > net and found some encoder loads (transponders) that claim > to have isolation diodes installed. > ................. > > The neatest way to install this raft of diodes > is to lay out a simple etched circuit board with > d-sub connector to bring wires onto and off the > board. For driving two loads, there's a total > 27 wires . . . a single 37-pin D-sub would > do it. > Hi Bob and all, What could be a simple way to make the above etched circuit board ? I'm not equipped for etching circuits, nor designing them. Any suggestions ? Thanks, Gilles ________________________________________________________________________________
Date: Jun 01, 2003
Subject: Z-11
Bob I'm trying to download Z11 in order to get a more legible copy than the one in the Aeroelectric Connection. I want to enlarge it to make it more compatible with a pair of 72 year old eyes. When I download it, all I get is a lot of text/garbage not the drawing. What am I doing wrong. Airplanes I know... computers, well that's another story. Thanks, Bob Devaney ________________________________________________________________________________
Date: Jun 01, 2003
Subject: Re: Z-11
I just downloaded and it works as advertised. I opened it with TurboCAD LE. Are you saving it first? R ----- Original Message ----- From: <Bobdeva(at)aol.com> Subject: AeroElectric-List: Z-11 > > Bob > I'm trying to download Z11 in order to get a more legible copy than the one > in the Aeroelectric Connection. I want to enlarge it to make it more > compatible with a pair of 72 year old eyes. When I download it, all I get is a lot of > text/garbage not the drawing. What am I doing wrong. Airplanes I know... > computers, well that's another story. > > Thanks, Bob Devaney > > ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED - MICROAIR RADIOS AND ICOM MICROPHONES
Date: Jun 02, 2003
Folks, Below is a repeat of an advisory from an Australian glider parts supplier which may explain to you some sensitivities of Midroair radios matched to Icom hardware. Regards, David Francis, VH-ZEE, Canberra, Australia. TO ANYBODY IN GLIDING USING MICROAIR RADIO AND ICOM BOOM MIC (the thin and short silver booms and insert not changed) please read on and alert others within your club I am realising there are still Microairs radios linked to Icom flexible boom mics. There can be problems with this installation as I have found the hard way and I know Nigel Andrews the designer has found this also. It shows itself that every now and then a transmittion does not get out and the radio is blamed for the fault. After about 3 different radios in an ASH25E I changed the electret insert in the Icom booms and it has been perfect since. I have just this week heard of a IS28 at Camden with a Microair and the thin silver Icom booms and radio problems!! Also Canberra Club were planning to upgrade radios and they had the Icom booms. In the past I sent out almost 50 microphones (to many countries I might add) with a changed spec insert which I was caught by and all had to come back. For some reason unknown to me Microairs are touchy when it comes to electret inserts. The fix is simple remove the Icom insert and change to Altronics part no C 0170. I do know there is a DSE insert which is OK but you should check with Nigel for exact cat no. There is a trick in getting them apart as you can only just get the insert unsoldered as a knot in coax restricts removal. This knot can be moved by undoing the mic head from gooseneck with mini-mini allen key. I can supply inserts at $2.30 if you can not get them locally. Alternatively I have an exchange service for Icom mics and at the same time I strengthen the base so hopefully they will not fail in the future. The big problem is I only have one exchange boom that I can send out at a time. If your glider is out of air for Form 2 then that is a good time to return same. I suggest a green paint dot on insert to indicate it has been changed. So if you see somebody in your club not on this list and the have the Microair/Icom combination please alert them as it would be wonderful to see this problem gone once and for all !! PLEASE!!!! Bye Ian McPhee Box 657 Byron Bay NSW 2481 Australia Tel +61 (0)2 66 847 642 Mob +61 (0)428 847 642 iankmcphee(at)bigpond.com www.mrsoaring.com <http://www.mrsoaring.com/> and being revamped next week!!. . ________________________________________________________________________________
Subject: Odyssey PC680 terminal with larger ring terminal
Date: Jun 01, 2003
The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). I was planning on using the 2 AWG 5/16" ring terminals that came with Van's basic wiring kit. How have others handled this...do you have to use ring terminals with a smaller hole, or can you use the 5/16" terminal? It looks like once tightened it'll be fine, but I'm curious if it's generally acceptable that way. Sorry if there's an obvious answer to this... )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 01, 2003
Subject: Re: Odyssey PC680 terminal with larger ring terminal
Dan, Get on the Aeroelectric website, choose tools and materials, and somewhere down the list are ring terminals for #2 wire with an assortment of hole sizes. I just got some and they work great. Joel Harding On Sunday, June 1, 2003, at 08:45 PM, Dan Checkoway wrote: > > > The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). > I > was planning on using the 2 AWG 5/16" ring terminals that came with > Van's > basic wiring kit. > > How have others handled this...do you have to use ring terminals with a > smaller hole, or can you use the 5/16" terminal? It looks like once > tightened it'll be fine, but I'm curious if it's generally acceptable > that > way. > > Sorry if there's an obvious answer to this... > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > _- > ====================================================================== > > ________________________________________________________________________________
Date: May 31, 2003
Gilles.Thesee wrote: > >Hi Bob and all, > >Here is a question that has kept bothering me for several weeks : >A month ago I witnessed the electrician in an FBO advise his co-wokers never >to touch a comm antenna during transmission. He said he did once and got a >handburn. > >Question : How hot can an antenna get ? Was he telling the truth, or was he >just reporting another hangar tale ? What is the physics behind the story ? > >Thank you for any feedback or explanation >Regards > >Gilles > Gilles, A well designed antenna is not supposed to get hot. If it gets hot that means that there is somewhere a high contact resistance and it is converting power from the transmitter into heat rather than into waves. However, some heat will be generated in your hand if you put it too close to the operating antenna in the area of a strong field. Same thing as placing your hand in a microwave oven, except a different power level. A microwave oven generates hundreds of watts, or even above a kilowatt. The airplane transmitter usually generates below 10W, and only a fraction of that would be coupled into your finger. That power is comparable to a very small soldering iron, but you would not like to hold even a small operating soldering iron in your hand. Making it short, an antenna with a power of several watts might make a small burn if you touch it, but stay away from high power antennas, they can make large burns. If you touch a high voltage area of an antenna fed with several hundred watts, an arc like in an electric welder will start between your finger and the antenna creating a lot of damage. With higher power antennas it is easy to get in trouble even without touching them. Get too close and they will overheat you and ruin your eyes or kidneys which are very heat sensitive, no matter that antenna is quite cold. The bad thing is that when the whole body is uniformly heated we do not feel much of a problem as it is in the case of localized surface heating, and the result might be very bad. But I hope you are not installing several kilowatt transmitter in your plane : ) Jerzy > > ________________________________________________________________________________
Subject: 10nF mylar cap.
Date: Jun 01, 2003
I decided that I'd like to make the warning circuit Jim Weir put in this months KitPlanes. I visited my local Radio Shack and was able to get everything except the 10nF mylar capacitor. They told me that they have never stocked capacitors this small!!!! All the other local sources had nothing either and I'm reluctant to try Mouser or Digikey for one mylar capacitor. Does aanyone have any suggestions or better yet does anyone have one of these they could sell me? Any help gratefully received. Rob Rob W M Shipley RV9A N919RV Fuselage - now a canoe!!! ________________________________________________________________________________
Date: Jun 01, 2003
terminal Another way to do it is to get a SAE Terminal Adapter Kit which has brass posts that screw into the PC680 and then you can use a 3/8" brass bolt for your ring terminals. I got mine from Cell Energy, Inc Part # 3217-0006 , not cheap they were about $15. I also just saw them in the latest Wick's catalog at about the same price. Wally Enga RV7 N757E >The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). I >was planning on using the 2 AWG 5/16" ring terminals that came with Van's >basic wiring kit. > >How have others handled this...do you have to use ring terminals with a >smaller hole, or can you use the 5/16" terminal? It looks like once >tightened it'll be fine, but I'm curious if it's generally acceptable that >way. > >Sorry if there's an obvious answer to this... > >)_( Dan >RV-7 N714D >http://www.rvproject.com > ________________________________________________________________________________
Date: Jun 01, 2003
The PC680 terminals use a female 6 mm metric thread. This is approximately 1/4 inch for sizing ring terminals, but users will have to locate 6 mm bolts/cap screws or whatever to do the final connection. (Unless Odessy is including the bolts these days - they were not included with my PC680). Jim Oke Winnipeg, MB ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: AeroElectric-List: Odyssey PC680 terminal with larger ring terminal > > The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). I > was planning on using the 2 AWG 5/16" ring terminals that came with Van's > basic wiring kit. > > How have others handled this...do you have to use ring terminals with a > smaller hole, or can you use the 5/16" terminal? It looks like once > tightened it'll be fine, but I'm curious if it's generally acceptable that > way. > > Sorry if there's an obvious answer to this... > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Jun 01, 2003
Subject: Re: My Fuel Gauge Design
> > >>On 5/29/03, Eric M. Jones" wrote: >>(snip) >>Put ten tiny tiny tiny 0805 size PTC thermistors on a flex circuit with a >>Gortex sleeve over it. Arrange these logarithmically so that they can be >>read-out by a 10-led bar graph. Stuff it through a 1/4" rivnut installed in each >>tank. On the instrument panel, 10 leds100%, 9 leds70.7%, 8 leds50%, 7 leds35.4%, 6 >>leds+25%, 5 leds17.7%, 4 leds12.5%, 3 leds8.8%, 2 leds6.2%, 1 led4.4%. >> >> >\ > Just guessing the principle of operation..The thermistors are heated by current, The thermistors in liquid are efficiently cooled, their temperature is almost equal to the temperature of the liquid, and their resistance is low. The thermistors above the liquid do not have much cooling , they get hot, their resistance goes up. The system monitors resistance of the thermistors and can figure out the position of the surface of the liquid. However, temperature of the liquid is not constant, it can vary between say 40C on a hot day in Oklahoma to say -20C on a cold day somewhere further North . To make it more complicated all PTC thermistors that I was working with had positive coefficient within relatively narrow temperature range, and outside of that range they behaved like standard NTC thermistors. I believe that all PTC thermistors behave that way. That would require to select a PTC thermistor with positive coefficient temperature range somewhere above the highest posible ambient temperature, say above 50C. Here comes a possible problem. When it is very cold the PTC thermistor runs into normal NTC range, its resistance goes up, the thermal power generated in the thermistor goes down, and that power might not be sufficient to heat it up to 50 deg even if it is above the liquid. There is another possible problem. Imagine that it is very hot outside, the thermistor is additionaly heated by the current, it gets very hot until it jumps over the PTC range into the normal NTC range. Now its resistance decreasesas as it gets hotter, which pumps more current into it, which makes it hotter and lower resistance, which pumps even more current, etc., until it melts. Both problems can be solved driving the thermistors from a proper current source. However, the second problem might still happen producing false reading rather than melt down. There is an additional problem of comparing (changing with ambient temperature) resistance of the submerged thermistors with also changing with the ambient resistance of the thermistors above the surface. It is possible that there is a trick which might make it easy, but it seems again that interpretation of the results would be the easiest with a microcontroller that would sequentially measure resistance of thermistors and set the liguid level between the group of thermistors with equal (but not constant) resistance, and the first hotter one. Am I missing something? Is there an easy way? Jerzy > > ________________________________________________________________________________
Date: Jun 01, 2003
They have them, they probably did not recognize the nF reference. Ask for a 0.01uF cap, it is the same size. They show up on the Radio Shack website. They carry capacitors much smaller, as low as 1pF (0.001nF). Sometimes you need to purchase capacitor packs to get what you want there. James I decided that I'd like to make the warning circuit Jim Weir put in this months KitPlanes. I visited my local Radio Shack and was able to get everything except the 10nF mylar capacitor. They told me that they have never stocked capacitors this small!!!! All the other local sources had nothing either and I'm reluctant to try Mouser or Digikey for one mylar capacitor. Does aanyone have any suggestions or better yet does anyone have one of these they could sell me? Any help gratefully received. Rob Rob W M Shipley RV9A N919RV Fuselage - now a canoe!!! ________________________________________________________________________________
Date: Jun 01, 2003
Subject: [ Wolfgang Trinks ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Wolfgang Trinks Subject: LUN2141 Regulator Schematic http://www.matronics.com/photoshare/Wolfgang.Trinks@flugbereitschaft.com.06.01.2003/index.html o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ________________________________________________________________________________
Date: Jun 01, 2003
10nF = .01uF. Radio Shack has them. nano-Farad is a relatively recent term. You won't find in in most catalogs (e.g. Digikey). 1 nano farad is still often written as 0.001 uF 1000 pico Farad (pF) = 1 nano Farad (nF) 1000 nano Farad (nF) = 1 micro Farad (uF aka mFd) 1,000,000 microFarad (uF) = 1 Farad milliFarad is not used. Or at least I've never (in 50 years) seen it. regards, -john- john(at)loram.org www.loram.org -----Original Message----- From: Rob W M Shipley [mailto:Rob(at)RobsGlass.com] Subject: AeroElectric-List: 10nF mylar cap. I decided that I'd like to make the warning circuit Jim Weir put in this months KitPlanes. I visited my local Radio Shack and was able to get everything except the 10nF mylar capacitor. They told me that they have never stocked capacitors this small!!!! All the other local sources had nothing either and I'm reluctant to try Mouser or Digikey for one mylar capacitor. Does aanyone have any suggestions or better yet does anyone have one of these they could sell me? Any help gratefully received. Rob Rob W M Shipley RV9A N919RV Fuselage - now a canoe!!! ________________________________________________________________________________
Subject: Expando Foam and Custom Boxes...
Date: Jun 01, 2003
I'm in the process of retrofitting my Garmin GPS 195 handheld unit to my panel (I love this unit - one of the best I've seen even though it's an old one by technology's standards). Because my panel is small (Zodiac 601) and the unit's full height will interfere with my layout I've taken the GPS apart and looked for ways to mount just the screen and buttons to the panel and save the 1.5 inches of 'wasted' built-in antenna space which is exactly what I need to get the unit to fit. It does look like I'll be able to rig something together for the panel mounting the key components of the GPS, but will then have to put the main circuit board for the GPS in a box and mount it behind of the panel where I have more space options. I remember seeing an article about if you needed a quick dirty way to keep a circuit board secure in a box, you could use the expanding insulation foam to secure the circuit board. Obviously, this would make working on the board in the future difficult if not impossible, but I highly doubt I'll be troubleshooting a high denisty board with 99.9% surface mounted components. Also, this would make sure the board was protected from the vibrations as well. Any way, was hoping to get some thoughts on using the expanding foam to secure the main PCB in a box - pros or cons... Thanks! Don Honabach Tempe, AZ - 601HDS P.S. If for some reason this doesn't work, I can always just go purchase a Garmin GPS Pilot III which will fit very nicely without any mods, but that would be the easy way and then I'd end up with a smaller GPS screen ;) ________________________________________________________________________________
Subject: Re: Expando Foam and Custom Boxes...
Date: Jun 02, 2003
Hello Don, How about putting the board inside a baggy or a zip-lock bag before potting it in the foam. Then if there even came a need to look at the board it might more easilly reached. Jim in Kelowna ----- Original Message ----- From: "Don Honabach" <don(at)pcperfect.com> Subject: AeroElectric-List: Expando Foam and Custom Boxes... > > I'm in the process of retrofitting my Garmin GPS 195 handheld unit to my > panel (I love this unit - one of the best I've seen even though it's an > old one by technology's standards). Because my panel is small (Zodiac > 601) and the unit's full height will interfere with my layout I've taken > the GPS apart and looked for ways to mount just the screen and buttons > to the panel and save the 1.5 inches of 'wasted' built-in antenna space > which is exactly what I need to get the unit to fit. It does look like > I'll be able to rig something together for the panel mounting the key > components of the GPS, but will then have to put the main circuit board > for the GPS in a box and mount it behind of the panel where I have more > space options. > > I remember seeing an article about if you needed a quick dirty way to > keep a circuit board secure in a box, you could use the expanding > insulation foam to secure the circuit board. Obviously, this would make > working on the board in the future difficult if not impossible, but I > highly doubt I'll be troubleshooting a high denisty board with 99.9% > surface mounted components. Also, this would make sure the board was > protected from the vibrations as well. > > Any way, was hoping to get some thoughts on using the expanding foam to > secure the main PCB in a box - pros or cons... > > Thanks! > Don Honabach > Tempe, AZ - 601HDS > > P.S. If for some reason this doesn't work, I can always just go > purchase a Garmin GPS Pilot III which will fit very nicely without any > mods, but that would be the easy way and then I'd end up with a smaller > GPS screen ;) > > ________________________________________________________________________________
Subject: battery bus directly from battery terminal?
Date: Jun 02, 2003
Bob, In all of the Z figures the battery bus is supplied power from a wire that comes off the "always hot" terminal of the battery contactor. In my particular case, because of where I would like to mount the battery bus fuse block, I'd like to power the it directly from the battery's (+) terminal in order to satisfy the "6 inches or less" requirement and still be able to locate the battery bus fuse block in a reasonable location. Is this acceptable, wiring directly from the (+) terminal as opposed to from the contactor's hot terminal? If so, is there any advantage or disadvantage to using a separate ring terminal vs. soldering the smaller battery bus wire right into the 2 AWG ring terminal for the wire to the battery contactor? I figure a separate ring terminal (and just stack 'em) makes the most sense but figured I'd ask. Thanks in advance, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: Need advice on small connector for avionics
I would like to have small connectors between my audio panel and the various avionics for easy removal of tray and upgrade, or to just pull tray and be able to work behind the panel. I would appreciate thoughts and places to buy and brand name or an numbers. Also, can someone please give me a basic briefing of the pin insertion and retraction tools, are all Mollinex the same for instance or are there different sizes. Thank you Skip Simpson ________________________________________________________________________________
Date: Jun 02, 2003
krasinski(at)direcway.com> >>> 5/29/03, Eric M. Jones" wrote: >>>(snip) >>>Put ten tiny tiny tiny 0805 size PTC thermistors on a flex circuit with a >>>snipped Exactly. Thermistors have been used for level sensing for a long time too. But they only recently were available in tiny 0805 SMD. Some other changes in technology make this scheme more attractive that previously. >However, temperature of the liquid is not constant, it can vary between >say 40C on a hot day in Oklahoma to say -20C on a cold day somewhere >further North . Yes. The thermistor I plan to use has a 70C transition. The ones I have in the prototype are 110C, so they get hotter than I would like, but they are tiny and as they say...It's only a prototype.... >To make it more complicated all PTC thermistors that I >was working with had positive coefficient within relatively narrow >temperature range, and outside of that range they behaved like standard >NTC thermistors. ........... >That would require to select a PTC thermistor with positive coefficient >temperature range somewhere above the highest possible ambient >temperature, say above 50C. The transition temperature is all that's important here. It must be above any likely fuel temperature. BTW--Gasoline flash point is minus-40C, boiling point is +40C to 200C more or less. >runs into normal NTC range, its resistance goes up, the thermal power >generated in the thermistor goes down, and that power might not be >sufficient to heat it up to 50 deg even if it is above the liquid. Yes. That could be. So a parallel resistor in close proximity to the PTC might be required. Sounds like R&D. >There is another possible problem. Imagine that it is very hot outside, >the thermistor is additionally heated by the current, it gets very hot >until it jumps over the PTC range into the normal NTC range. Now its >resistance decreases as it gets hotter, which pumps more current into >it, which makes it hotter and lower resistance, which pumps even more >current, etc., until it melts. Yes, however I surmise if it gets THAT hot out. My airplane will melt first. >Both problems can be solved driving the thermistors from a proper >current source. However, the second problem might still happen >producing false reading rather than melt down. Maybe... >There is an additional problem of comparing (changing with ambient >temperature) resistance of the submerged thermistors with also changing >with the ambient resistance of the thermistors above the surface. It is >possible that there is a trick which might make it easy, but it seems >again that interpretation of the results would be the easiest with a >microcontroller that would sequentially measure resistance of >thermistors and set the liquid level between the group of thermistors >with equal (but not constant) resistance, and the first hotter one. We're going to see. A microprocessor would still be a good addition to any system. >Am I missing something? Is there an easy way? >Jerzy I think a PTC thermistor system could be the simplest method. It is even possible to build ONE long monolithic flexible thermistor. How would it change with fuel level??? BTW--I still have my amazing self-heating pitot tube that calmly maintains a 30C temp. Inside are 30C PTC thermistors. Nothing else. Thanks for the great input. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Date: Jun 02, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
>I remember seeing an article about if you needed a quick dirty way to >keep a circuit board secure in a box, you could use the expanding >insulation foam to secure the circuit board. Obviously, this would make >working on the board in the future difficult if not impossible, but I >highly doubt I'll be troubleshooting a high denisty board with 99.9% >surface mounted components. Also, this would make sure the board was >protected from the vibrations as well. > >Any way, was hoping to get some thoughts on using the expanding foam to >secure the main PCB in a box - pros or cons... I suggested the foamed-in-place encapsulation for securing spider-webbed assemblies using techniques described in http://www.aeroelectric.com/articles/cladboard/cladboard.html If your device is assembled onto an etched circuit board, there's no need to secure it further. If fact, an enclosure is only useful while the assembly is being handled. Unless it's in danger of being kicked or otherwise damaged after installation, or you need a metallic enclosure for RFI protection, there's little value in even putting a box around it. A number of our products are offered sans enclosure and suggested that they simple be installed as-is like this: http://216.55.140.222/Catalog/AEC/9005/9005.jpg Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Jun 02, 2003
avionics > >I would like to have small connectors between my audio panel and the various >avionics for easy removal of tray and upgrade, or to just pull tray and be >able to work behind the panel. I would appreciate thoughts and places to >buy and >brand name or an numbers. > >Also, can someone please give me a basic briefing of the pin insertion and >retraction tools, are all Mollinex the same for instance or are there >different >sizes. Every manufacturer of a removable pin connector uses unique tooling unless the connector is built to some standard like the D-subs mentioned below . . . >Thank you Skip Simpson The Type D Subminiature (D-sub) connectors like those on the back of your computer are probably the most user friendly devices you can get . . . prices and tooling are attractive too. See http://www.aeroelectric.com/Catalog/tools/tools.html#rct-3 http://www.aeroelectric.com/Catalog/tools/tools.html#dse-1 http://www.aeroelectric.com/Catalog/connect/connect.html#S604 Shells for these connectors (as well as solder cub versions of the connectors) are available from virtually every electronic supply store not the least of which are Digikey and Radio Shack. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
terminal > >The PC680 terminals use a female 6 mm metric thread. This is approximately >1/4 inch for sizing ring terminals, but users will have to locate 6 mm >bolts/cap screws or whatever to do the final connection. (Unless Odessy is >including the bolts these days - they were not included with my PC680). > >Jim Oke >Winnipeg, MB Hawker supplies hardware with the batteries but they're packaged separately. Many distributors don't take pains to make sure the little bag of hardware goes out with the battery. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: 10nF mylar cap.
> >I decided that I'd like to make the warning circuit Jim Weir put in this >months KitPlanes. I visited my local Radio Shack and was able to get >everything except the 10nF mylar capacitor. They told me that they have >never stocked capacitors this small!!!! All the other local sources had >nothing either and I'm reluctant to try Mouser or Digikey for one mylar >capacitor. >Does aanyone have any suggestions or better yet does anyone have one of >these they could sell me? >Any help gratefully received. Yup, you got questions, they got answers. "nano" is 10 to the minus 9th exponent. In the US manufacturers and designers have largely ignored this multiplier preferring to use "micro" (10 to the minus 6) and "pico" (10 to the minus 12) multipliers. Electronics diagrams from other parts of the world have taken advantage of the intermediate nano multiplier ever since I can remember . . . 1 nF is 1000 pF and .001 mF So the 10 nF capacitor callout can also be written as .01 mF or 10,000 pF . . . and Radio Shack has had them since day-one. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
terminal > >The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). I >was planning on using the 2 AWG 5/16" ring terminals that came with Van's >basic wiring kit. > >How have others handled this...do you have to use ring terminals with a >smaller hole, or can you use the 5/16" terminal? It looks like once >tightened it'll be fine, but I'm curious if it's generally acceptable that >way. > >Sorry if there's an obvious answer to this... It's best to get a terminal that fits the screw . . . electrical connection integrity is a function of PRESSURE that the threaded fasteners are expected to place on the mated parts. If the hole in a terminal is oversized, the ability of a fastener to provide this pressure is compromised. B&C can supply you with terminals with exactly the hole size you need. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: Z-11
> >Bob >I'm trying to download Z11 in order to get a more legible copy than the one >in the Aeroelectric Connection. I want to enlarge it to make it more >compatible with a pair of 72 year old eyes. When I download it, all I get >is a lot of >text/garbage not the drawing. What am I doing wrong. Airplanes I know... >computers, well that's another story. Sounds like you were looking at or trying to print the file contents without using the appropriate application to open it. The drawings are in .dwg format by AutoCAD and are compatible with a number of other cad programs not the least of which are those supplied on the CD rom from our website. The CD can be downloaded at http://216.55.140.222/CD/AEC8_0.zip or purchased at http://www.aeroelectric.com/Catalog/AECcatalog.html Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: battery bus directly from battery
terminal? > >Bob, > >In all of the Z figures the battery bus is supplied power from a wire that >comes off the "always hot" terminal of the battery contactor. In my >particular case, because of where I would like to mount the battery bus fuse >block, I'd like to power the it directly from the battery's (+) terminal in >order to satisfy the "6 inches or less" requirement and still be able to >locate the battery bus fuse block in a reasonable location. > >Is this acceptable, wiring directly from the (+) terminal as opposed to from >the contactor's hot terminal? > >If so, is there any advantage or disadvantage to using a separate ring >terminal vs. soldering the smaller battery bus wire right into the 2 AWG >ring terminal for the wire to the battery contactor? I figure a separate >ring terminal (and just stack 'em) makes the most sense but figured I'd ask. Stacking terminals is fine. But I wouldn't loose any sleep over the 6" rule-of-thumb either. I think there is value in having the battery bus feed come from a relatively permanent connection like the battery contactor as opposed to using a termination subject to routine maintenance . . . Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
In a message dated 6/1/03 7:50:40 PM Pacific Daylight Time, dan(at)rvproject.com writes: << The cap screws on the Odyssey PC680's terminals are 3/16" (I believe). I was planning on using the 2 AWG 5/16" ring terminals that came with Van's basic wiring kit. >> I have what is supposed to be a clone of the PC 680 from Battery Web .com. The terminal cap screws on my battery are metric size 10, or 0.224 in. I used a "D" drill to open the holes in some 3/16" terminals. Worked for me. Harry Crosby Pleasanton, California RV-6, firewall forward ________________________________________________________________________________
Date: Jun 02, 2003
Skip, Unsolicited testimonial: The RCT-3 crimp tool found on Bob's website works great. With this tool and a bag of machined male and female pins, building up d-subs is very fast. Strip the wire, drop a pin in the tool, crimp, plug it into the d-sub connector body. When all the wires are in there, add the shell and you're done. Dan ________________________________________________________________________________
Date: Jun 02, 2003
Subject: RE: RF burns from antenna . . .fact or mythology ?
> > >I have been burned by the RF from a ham radio. > >Touching one of those antennas during a transmission is NOT a "cool" thing >to do. > >What happens is that you do NOT kow you are being burned until it is way too >late. It is like the RF is boiling the blood inside your finger and you >don't notice until it reaches the boiling point. Once I let go of the >antenna (it was on a roof and someone transmitted when I did not expect such >to occur) that is when it really burned for a while. > >I don't know how much energy was transmitted into my fingers but I do know >it was enough. It is probably kinda like you don't want to be inside a >microwave oven while it is on. It won't get hot but your insides REALLY >will. Don't know about the blood boiling bit . . . but consider the following: The dielectric strength of air is about 1,000 volts per .001" of airspace. This is means that if you put your finger within .001" of a conductor carrying 1,000 volts more potential than your body, you can get a arc. Once the arc starts, air in intervening space is ionized and it now takes much less than 1,000 volts to sustain the arc. An arc is HOT . . . energy is released in a relatively small volume which elevates temperatures in the arc to well over 1,000 degrees. Boil blood? Probably. Cook meat? Probably. Get your attention via the nervous system? One certainly hopes so. How does that voltage get there? Take a peek at Figure 13-5 in the 'Connection. Hmmm . . . just noticed an error in that figure . . . the bottom label on the y-axis is zero. It should be minimum . . . I've fixed the figure and uploaded to http://216.55.140.222/temp/DIPOLE.pdf Anywho, this figure illustrates the distribution of voltage across the antenna's length. A 1/2-wave dipole is shown, a 1/4-wave vertical monopole is similar . . just half the structure. If we're conducting 5-watts of power into the low impedance point on the antenna (center or base) then voltage at the base will be on the order of E(squared)/R=watts or E(squared)= 5-Watts * 50-Ohms = 16 volts. Now, as you move toward the end of the antenna the current in antenna rod goes down while the voltage goes up. How high? Saw the reasoning behind that calculation once but don't recall now what it was . . . but trust me, at the FREE END of an antenna, the voltage can become high enough to get your attention. Recall that a laser rated in a few hundred milliwatts is capable of concentrating that power into a very small area so that POWER DENSITY (watts/cc) can be a spectacular number. Same thing happens with the itty-bitty transmitter arcing off the top of an antenna to your finger. It may not excite a LOT of nerves but the few it does hammer on get really irritated. Frequency of the energy has an effect too. 130 Mhz RF is more penetrating and will propagate across smaller gaps that DC. I've held my hand in front of an operating radar antenna on the B-52 and felt a slight warming. In years past, doctors hooked patients up to diathermy machines operating at 27 MHz for the therapeutic value of deep penetration heating effects. Got one of those treatments for a kidney disorder when I was a teenager. I've not seen such a machine in a doctor's office in about 45 years but the machines are still out there. See http://www.mettlerelec.com/diatherm.html http://www.fda.gov/cdrh/safety/121902.pdf http://www.orthoteers.co.uk/Nrujp~ij33lm/Orthdiathermy.htm https://www.dmc.org/health_info/topics/spor3327.html Here are links where higher energy densities are used for surgical effects. http://www.mbnsclinic.co.uk/diathermy.htm http://www.cochrane.org/cochrane/revabstr/ab002211.htm While radio frequency energy has qualities different than DC or ordinary line frequency AC . . . it's not particularly "magic" . . . just simple-idea based physics. Bob . . . ________________________________________________________________________________
Date: Jun 02, 2003
> >Hi Bob and all, > >What could be a simple way to make the above etched circuit board ? I'm not >equipped for etching circuits, nor designing them. >Any suggestions ? > >Thanks, >Gilles There's free diy software for crafting and ordering boards available from http://www.expresspcb.com/ I'm not sure they can or will ship internationally. I could do the layout, order the boards and then forward them to you. How many radios are you tying to the encoder and how many of them do not already have isolation diodes? Bob . . . ________________________________________________________________________________
Date: Jun 03, 2003
----- Message d'origine ----- De : "Robert L. Nuckolls, III" : Envoy : lundi 2 juin 2003 20:49 Objet : Re: AeroElectric-List: Cheap blind encoder. > > > > > >Hi Bob and all, > > > >What could be a simple way to make the above etched circuit board ? I'm not > >equipped for etching circuits, nor designing them. > >Any suggestions ? > > > >Thanks, > >Gilles > > There's free diy software for crafting and ordering > boards available from > http://www.expresspcb.com/ > > I'm not sure they can or will ship internationally. > I could do the layout, order the boards and then > forward them to you. How many radios are you tying > to the encoder and how many of them do not already > have isolation diodes? > > Bob . . . > Bob, Thanks for your offer. I downloaded the software and I'll try to produce an acceptable setup. My intention is to connect a Garmin GPS 400 and a Becker ATC-4401 transponder to an Ameri-King 350 encoder. The GPs already has the diodes built in. I don't know yet for the Becker. I asked them but no response to date. As soon as the radios arrive I'll perform the test you described. Or maybe someone around knows for the Becker ? Cheers, Gilles ________________________________________________________________________________
Subject: PTT - Ground Wire
Date: Jun 02, 2003
I had an avionics shop build the wire harnesses for my nav / com radios. It all looks good except for a question on the PTT wiring. The UPS SL15 manual shows the PTT switch wired between the Mic PTT (tip) and Mic Lo (ring) on the Mic jack, that is, two wires in a closed circuit with the switch in between. The Mic Lo then goes to on to ground in the system. My avionics guy ran just one wire from the Mic PTT (tip) to the actual PTT switch and told me to take the other side of the PTT switch to ground. It all looks good, logically, but is different that the closed circuit diagram as well as the ones that Bob has printed as examples. Is this proposal going to cause me problems, with not running another wire back to the mic jack? Duane ________________________________________________________________________________
Subject: Cheap blind encoder.
Date: Jun 02, 2003
>> What could be a simple way to make the above etched circuit board ? You may also want to try a do it yourself home project for the PCB. A lot of electronic stores have kits that you buy to make your own PCBs at home. I got into this about a year or so ago to make a USB based ISO7816 data logger for my business to help better understand how these devices work. After a few attempts I was able to make some really nice boards that used surface mounted uControllers with a 100+ pin count by using just my laser printer, some paper, UV light, and required chemicals. If you've ever developed pictures the 'old fashion way' it's pretty much the same. Only hard part is getting a good starting image when dealing with super small surface mount ICs and traces, but for the diode project any old laser printer or even an inkjet would work fine. Good Luck, Don -----Original Message----- From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] Subject: Re: AeroElectric-List: Cheap blind encoder. --> > >Hi Bob and all, > >What could be a simple way to make the above etched circuit board ? I'm >not equipped for etching circuits, nor designing them. Any suggestions >? > >Thanks, >Gilles There's free diy software for crafting and ordering boards available from http://www.expresspcb.com/ I'm not sure they can or will ship internationally. I could do the layout, order the boards and then forward them to you. How many radios are you tying to the encoder and how many of them do not already have isolation diodes? Bob . . . direct advertising on the Matronics Forums. ________________________________________________________________________________
Date: Jun 03, 2003
You may want to check these people on yet a different technique of making PCBs This is the method I prefer. Rino http://www.mnsi.net/~boucher/makepcbs.htm Don Honabach wrote: > > > >> What could be a simple way to make the above etched circuit board ? > > You may also want to try a do it yourself home project for the PCB. A > lot of electronic stores have kits that you buy to make your own PCBs at > home. > > I got into this about a year or so ago to make a USB based ISO7816 data > logger for my business to help better understand how these devices work. > After a few attempts I was able to make some really nice boards that > used surface mounted uControllers with a 100+ pin count by using just my > laser printer, some paper, UV light, and required chemicals. If you've > ever developed pictures the 'old fashion way' it's pretty much the same. > Only hard part is getting a good starting image when dealing with super > small surface mount ICs and traces, but for the diode project any old > laser printer or even an inkjet would work fine. > > Good Luck, > Don > > -----Original Message----- > From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Cheap blind encoder. > > --> > > > > >Hi Bob and all, > > > >What could be a simple way to make the above etched circuit board ? I'm > > >not equipped for etching circuits, nor designing them. Any suggestions > >? > > > >Thanks, > >Gilles > > There's free diy software for crafting and ordering > boards available from > http://www.expresspcb.com/ > > I'm not sure they can or will ship internationally. > I could do the layout, order the boards and then > forward them to you. How many radios are you tying > to the encoder and how many of them do not already > have isolation diodes? > > Bob . . . > > direct advertising on the Matronics Forums. > -- ________________________________________________________________________________
Date: Jun 02, 2003
Subject: Re: PTT - Ground Wire
> >I had an avionics shop build the wire harnesses for my nav / com radios. >It all looks good except for a question on the PTT wiring. The UPS SL15 >manual shows the PTT switch wired between the Mic PTT (tip) and Mic Lo >(ring) on the Mic jack, that is, two wires in a closed circuit with the >switch in between. The Mic Lo then goes to on to ground in the system. > > >My avionics guy ran just one wire from the Mic PTT (tip) to the actual >PTT switch and told me to take the other side of the PTT switch to >ground. It all looks good, logically, but is different that the closed >circuit diagram as well as the ones that Bob has printed as examples. >Is this proposal going to cause me problems, with not running another >wire back to the mic jack? The "ring" terminal is microphone HI . . . are you sure their diagram doesn't show connection to the "barrel" or "sleeve" connection which then goes to ground? The barrel or sleeve connection is usually MIC LO and PTT return to ground. The tech's suggestion is how tens of thousands of external PTT switches have been wired and will probably be okay. Bob . . . ________________________________________________________________________________
Subject: LR3C terminals
Date: Jun 03, 2003
This is probably a silly question, but I'd rather ask than do it wrong... On the LR3C alternator controller from B&C, what type of wire terminals are ideal to use with the screws, ring terminals or spade terminals? Spade terminals seem like they'd work better since you wouldn't have to remove the screw to install...but B&C doesn't sell spade terminals...which implies to me that they're not recommended. Am I over-thinking this? )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 03, 2003
Subject: Merging wiring - FWF
Bob Hi! from UK Did some light reading of Aero Connection Manual this morning over breakfast to establish some guidance over wiring compatibility. Very wholesome! Still need your words of wisdom! In an effort to keep efficient and 'tidy' Wiring, can you advise or confirm that it it probably be OK to merge various Instrument Sensor wires in 22 AWG unsceened with the Magneto screened wires (18 AWG) into a single loom, separating again once through Firewall conduit. I have 22 AWG Screened if more suitable. Regards Gerry Gerry Holland Europa 384 Tri-gear G-FIZY +44 7808 402404 gnholland(at)onetel.com ________________________________________________________________________________
Date: Jun 03, 2003
Subject: Re: LR3C terminals
> >This is probably a silly question, but I'd rather ask than do it wrong... > >On the LR3C alternator controller from B&C, what type of wire terminals are >ideal to use with the screws, ring terminals or spade terminals? Spade >terminals seem like they'd work better since you wouldn't have to remove the >screw to install...but B&C doesn't sell spade terminals...which implies to >me that they're not recommended. > >Am I over-thinking this? Conventional wisdom calls for ring terminals over threaded fasteners. The open spade terminals are frowned upon because they would fall off if the screw got loose . . . but if the screw is loose, then operation of the system is problematical anyhow and we've designed the system to be protected from results of any faults due to wires falling off . . . It's probably more of a craftsmanship issue than a safety issue. Bob . . . ________________________________________________________________________________
Subject: Transpondeur cable question
Date: Jun 03, 2003
Hi Bob and all, The Becker AT4401 transponder installation manual calls for RG 223/U coax for the 175 watt version, and RG 58/U or RG 223/U for the 250 watt model. We didn't know that before installing RG 58/U cable in the plane. How do those two cables losses compare for a length of 17 ft (5 meters) at 1030 or 1090 MHz ? And could we install RG 400, easier to find in short lengths ? Thanks, Gilles ________________________________________________________________________________
Subject: Mid-Continent turn coordinator -- tilt question
Date: Jun 03, 2003
Having heard only good things about Mid-Continent instruments, and having heard several negative comments about the Falcon turn coordinators, I opted to buy the Mid-Continent turn coordinator from Chief. My only concern (so far) is that on the back of the instrument it reads: "Calibrated for installation in vertical panel" Maybe I'm reading into it, but on my RV-7 the panel has an 8-degree forward tilt. Should I be concerned about this turn coordinator functioning properly? It's my assumption that only *attitude* gyros need to be specially calibrated for the 8-degree tilt (so the horizon lines up properly). Is that the case? Thanks in advance, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 03, 2003
Subject: Re: Transponder cable question
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >The Becker AT4401 transponder installation manual calls for RG 223/U coax >for the 175 watt version, and RG 58/U or RG 223/U for the 250 watt model. >We didn't know that before installing RG 58/U cable in the plane. > >How do those two cables losses compare for a length of 17 ft (5 meters) at >1030 or 1090 MHz ? >And could we install RG 400, easier to find in short lengths ? I added RG223 to the coax loss chart I published a year ago. You can find it at: http://216.55.140.222/temp/coaxloss.pdf 223 is and "old" coax with PVC jacket . . . if it were my airplane, I'd use RG-400. If I had a scrap of RG-141 laying around (solid conductor version of 400), I'd use up the scrap before I bought new RG-400. Bob . . . ________________________________________________________________________________
Date: Jun 03, 2003
Subject: Re: Mid-Continent turn coordinator -- tilt question
In a message dated 6/3/03 5:29:06 PM Central Daylight Time, dan(at)rvproject.com writes: > Maybe I'm reading into it, but on my RV-7 the panel has an 8-degree forward > tilt. Should I be concerned about this turn coordinator functioning > properly? It's my assumption that only *attitude* gyros need to be > specially calibrated for the 8-degree tilt (so the horizon lines up > properly). Is that the case? Good Evening Dan, That instrument definitely need to be mounted in a vertical panel. If you have an eight degree slanted panel, you either have to have an instrument calibrated that way at the factory or use an eight degree wedge to get it back in the proper plane. Canting the gyro makes it act like a Turn Coordinator. That is all a TC is. It is a rate gyro mounted at an angle of between thirty and forty-five degrees (very often 37 degrees) to the level so that it will be sensitive to both roll and yaw. A Turn and Bank that is properly mounted will be affected only by yaw. Obviously, the speed, and thus, the angle of attack, being flown will affect that to some degree, but the instrument manufacturers do make provision within the instrument for mounting in slanted panels so that the instrument will be as little affected by extraneous sensing as is possible. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 03, 2003
In a message dated 6/3/03 5:29:06 PM Central Daylight Time, dan(at)rvproject.com writes: > "Calibrated for installation in vertical panel" > Good Evening Once Again Dan, I obviously didn't read your original message correctly prior to sending my message. You have a Turn Coordinator and not a Turn and Bank. My message was specifically oriented toward proper mounting of the T&B not a TC. However, the same thing applies. It should be mounted as the manufacturer intended. You can purchase rate instruments that are calibrated for slanted panels. Since the TC never tells the truth anyway, I guess mounting it correctly would not be as important as is mounting a T&B correctly, but I would imagine mounting it eight degrees off of where it was designed to be could adversely affect the ratio as to whether the instrument was indicating roll or yaw. The Rate of Turn indications during a stable coordinated turn would probably be acceptably close even when mounted on a slanted panel. Best, though, to get an instrument matched to your panel. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 03, 2003
Dan, I wonder how it could know? I mean, even if it's in a vertical panel, what about if you were in a climb, or a descent, or a turn. Assuming it's only important during startup, what about if you were starting on a slope? Or in a tailwheel? No panel could be *exactly* vertical, could it? Perhaps it just means a grossly vertical panel, i.e. not a horizontal panel. I'll be interested to hear a definitive answer. Cheers. Nev -- Jodel D150, UK. ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: AeroElectric-List: Mid-Continent turn coordinator -- tilt question > > Having heard only good things about Mid-Continent instruments, and having > heard several negative comments about the Falcon turn coordinators, I opted > to buy the Mid-Continent turn coordinator from Chief. My only concern (so > far) is that on the back of the instrument it reads: > > "Calibrated for installation in vertical panel" > > Maybe I'm reading into it, but on my RV-7 the panel has an 8-degree forward > tilt. Should I be concerned about this turn coordinator functioning > properly? It's my assumption that only *attitude* gyros need to be > specially calibrated for the 8-degree tilt (so the horizon lines up > properly). Is that the case? > > Thanks in advance, > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ________________________________________________________________________________
Date: Jun 04, 2003
Bob, Talk of a quick answer ! Now a naive question : does a 30 db/100 ft loss give a 6 db loss for 20 ft ? I forgot about those logarithmic functions. Our cable loss must be less than 18.5 db (17-18 ft cable). Thanks a lot, Gilles > > I added RG223 to the coax loss chart I published a year ago. > You can find it at: > http://216.55.140.222/temp/coaxloss.pdf > > 223 is and "old" coax with PVC jacket . . . if it were my > airplane, I'd use RG-400. If I had a scrap of RG-141 laying > around (solid conductor version of 400), I'd use up the scrap > before I bought new RG-400. > > Bob . . . ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jun 03, 2003
It makes we wonder if the turn coordinator in the Navaids autopilot will work in a tail dragger? Or should these be setup in the level and not worry about them in the ground attitude? Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Working on Canopy of Finish Kit ----- Original Message ----- From: "Neville Kilford" <nkilford(at)etravel.org> Subject: Re: AeroElectric-List: Mid-Continent turn coordinator -- tilt question > > Dan, > > I wonder how it could know? I mean, even if it's in a vertical panel, what > about if you were in a climb, or a descent, or a turn. Assuming it's only > important during startup, what about if you were starting on a slope? Or in a > tailwheel? No panel could be *exactly* vertical, could it? > > Perhaps it just means a grossly vertical panel, i.e. not a horizontal panel. > I'll be interested to hear a definitive answer. > > Cheers. > > Nev > > -- > Jodel D150, UK. > > ----- Original Message ----- > From: "Dan Checkoway" <dan(at)rvproject.com> > To: > Subject: AeroElectric-List: Mid-Continent turn coordinator -- tilt question > > > > > > > Having heard only good things about Mid-Continent instruments, and having > > heard several negative comments about the Falcon turn coordinators, I opted > > to buy the Mid-Continent turn coordinator from Chief. My only concern (so > > far) is that on the back of the instrument it reads: > > > > "Calibrated for installation in vertical panel" > > > > Maybe I'm reading into it, but on my RV-7 the panel has an 8-degree forward > > tilt. Should I be concerned about this turn coordinator functioning > > properly? It's my assumption that only *attitude* gyros need to be > > specially calibrated for the 8-degree tilt (so the horizon lines up > > properly). Is that the case? > > > > Thanks in advance, > > )_( Dan > > RV-7 N714D > > http://www.rvproject.com > > > > > > ________________________________________________________________________________
Date: Jun 03, 2003
T&B's and TC's depend on being mounted a certain way - the axis of the gyro with respect to the motion of the airplane. The orientation of the single axis gyro effects to which axis (yaw, roll, pitch) it is coupled. The difference between a T&B and a TC is that the TC gets coupled to the roll axis of the aircraft by being tipped off-axis from vertical. This means that rolling into a bank without also turning will cause a TC to respond, but a T&B will ignore it - no coupling. Unless you are planning to do IFR while in a 3-point attitude (while its foggy at the airport?), neither instrument will care a whit the orientation of the instrument while on the ground (taildragger/tricycle). Once you are flying, then it will matter. I have to imagine the both the T&B and the TC will behave slightly differently when in a low airspeed climb because the orientation of the yaw axis is slightly different then when in cruise. Regards, Matt Prather N34RD > > > It makes we wonder if the turn coordinator in the Navaids autopilot will > work in a tail dragger? Or should these be setup in the level and not > worry about them in the ground attitude? > > Larry in Indiana, RV7 Tip-up O-360 3XG reserved. > Working on Canopy of Finish Kit > ----- Original Message ----- > From: "Neville Kilford" <nkilford(at)etravel.org> > To: > Subject: Re: AeroElectric-List: Mid-Continent turn coordinator -- tilt ________________________________________________________________________________
Date: Jun 03, 2003
><Gilles.Thesee@ac-grenoble.fr> > > >Bob, > >Talk of a quick answer ! >Now a naive question : does a 30 db/100 ft loss give a 6 db loss for 20 ft ? yes. RG-400 is about 24 db/100 ft at GPS frequencies. 20ft of cable yields 1/5th that amount or 4.8 db. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2003
BobsV35B(at)aol.com wrote: >......Canting the gyro makes it act like a Turn Coordinator. That is all a TC is..... > However, canting can be done a few ways. Among others, the gyro can be canted normal way where the rear part of the instrument (that is the part pointing in the direction of the flight) goes down and the dial up, or it can be canted the other way i.e. rear part of the instrument moved up in respect to the dial All right, all right, I know that nobody cants panels the last and wrong way, but this is how they tilt a gyro in order to make it into a Turn Coordinator. In the Turn Coordinator when the left wing goes down, even before the turn started, the gyro "feels" and shows it as a left turn because of the canting. Easy to see that effect of the wing going down if you imagine the gyro at an extreme and never used cant angle of 90 deg,. i.e. rear of the instrument up, and the dial down. That gives the left turn signal a little before the start of the turn, which is a good info, but it makes the indicator more nervous. But look what happens if you mount the gyro in a normally canted panel. Now if the left wing drops down, even before the left turn started, the gyro feels it and shows it as the RIGHT turn. Eventually, the indicator will go left as you develop the left turn. That makes the gyro behaving in a slow, lazy and confusing way, with all these symptoms increasing as you increase the canting angle. Not a good idea. However, if you have a Turn Coordinator, where the gyro is internally canted "rear up" around 30 deg, or more, and if you mounted it in a normally canted panel tilted by a few degrees, you would still have a Turn Coordinator with a slightly less effective internal canting . If you increased the canting angle of the panel to an unlikely 30 degrees, you would find that your turn coordinator behaves like a normal Turn and Bank, because the canting of the panel cancelled the internal canting of the gyro. You would detect confusing indications only if you used a panel with a huge canting of over 30 degrees Jerzy ________________________________________________________________________________
Date: Jun 04, 2003
In a message dated 6/4/03 12:02:56 AM Central Daylight Time, krasinski(at)direcway.com writes: > However, if you have a Turn Coordinator, where the gyro is internally > canted "rear up" around 30 deg, or more, and if you mounted it in a > normally canted panel tilted by a few degrees, you would still have a > Turn Coordinator with a slightly less effective internal canting . If > you increased the canting angle of the panel to an unlikely 30 degrees, > you would find that your turn coordinator behaves like a normal Turn and > Bank, because the canting of the panel cancelled the internal canting of > the gyro. You would detect confusing indications only if you used a > panel with a huge canting of over 30 degrees > Jerzy > Sounds fair to me! I still think the only proper use for a canted gyro is as a sensor for a cheap autopilot. It makes a lousy flight instrument. Just one guys opinion! Happy Skies, Old Bob ________________________________________________________________________________
Subject: flap circuit using DPDT relay
Date: Jun 04, 2003
Bob, I'm wondering if you have seen this design before: http://www.infinityaerospace.com/Flap.pdf I bought the cheap Radio Shack relay (http://www.radioshack.com/searchsku.asp?find=275-218) and wired it up according to the drawing and it works perfectly. I'm just curious if you see any potential snags by using that design. Thanks, )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 04, 2003
question > >In a message dated 6/3/03 5:29:06 PM Central Daylight Time, dan(at)rvproject.com >writes: > > > "Calibrated for installation in vertical panel" > > >Good Evening Once Again Dan, > >I obviously didn't read your original message correctly prior to sending my >message. You have a Turn Coordinator and not a Turn and Bank. > >My message was specifically oriented toward proper mounting of the T&B not a >TC. However, the same thing applies. > >It should be mounted as the manufacturer intended. You can purchase rate >instruments that are calibrated for slanted panels. Since the TC never >tells the >truth anyway, I guess mounting it correctly would not be as important as is >mounting a T&B correctly . . . Bob, I understand your preference for pure-yaw rate sensing as a panel display for turning rate indicator but I need to call you on the rhetoric . . . a turn coordinator is just as "truthful" as any other instrument on the panel in terms of what it's designed to do. Successful integration of the turn coordinator into nearly 100,000 light aircraft over decades speaks to it's utility for service as both wing leveling and as a panel display for hand flying the airplane sans gyros. I've shot many a no-gyro approach behind a turn-coordinator and ridden shotgun for other pilots while they honed their skills at the same task. While performance of this instrument might be considered a compromise of features found in rate gyros of old, I'll suggest that the industry has demonstrated the "losses" to be minimal in exchange for useful "additions". I've flown both instruments and my personal preference favors the turn coordinator. Individual preferences aside, may I suggest it's disingenuous to label the turn-coordinator as untruthful. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Jun 04, 2003
> From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> > Subject: Re: AeroElectric-List: 10nF mylar cap. > > 1 nF is 1000 pF and .001 mF > > So the 10 nF capacitor callout can also be written > as .01 mF or 10,000 pF . . . and Radio Shack has > had them since day-one. > > Bob . . . > Minor nit, Bob. 1nf is 1000pF or 0.001uF (the lower case m is reserved for milli, while lower case u is used for micro) MikeM ________________________________________________________________________________
Date: Jun 04, 2003
In a message dated 6/4/03 10:00:51 AM Central Daylight Time, bob.nuckolls(at)cox.net writes: > I've flown both instruments and my personal preference > favors the turn coordinator. Individual preferences > aside, may I suggest it's disingenuous to label > the turn-coordinator as untruthful. > > Bob . . . > Good Morning Bob, We have been through this before and I am afraid we will have to agree to disagree. When I am rolling down a runway after making a turn onto the runway just before takeoff and my rate gyro shows an indication that I am either turning or rolling while the airplane is going straight with the wheels are solidly on the ground I think it is fair to say that the instrument is not telling the truth. When I have to check the indication of other instruments to tell whether that instrument is telling me that I am rolling or yawing, I feel the instrument is not telling me the truth. If I am flying a nice knife edge, the instrument will be telling the truth as far as the fact that I am neither rolling nor yawing, but if there is any sense in my head that it is depicting a wings level situation, it is definitely not presenting any indication that is consistent with the current state of the flight. I think I mentioned early on that I installed TCs in all of my training airplanes when the unit first became available. I had applauded it's use as a low cost sensor for autopilots and felt that it would make a good instrument to aid in partial panel flying. It was only after several years of use that I gradually came to my present position. I think the TC is largely responsible for the plethora of accidents we have experienced when pilots are presented with a partial panel scenario. I wholeheartedly agree that a competent pilot can use either successfully. I now feel that a pilot trained and competent in the use of a T&B is more likely to retain that competency than one who has been initially trained in the use of the TC. That has to do with the mindset of the pilot and how both instruments integrate into normal everyday flying, but that is an even longer story and I will let it go for now. Your's for differences of opinion. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 04, 2003
Subject: d sub shells
I'd like to echo some of the recent sentiments regarding dsub connectors and crimp pins. I've found them to be very user friendly. My question is about the shells for the connectors. In a couple of places behind my panel there's just not room to use the shell. I've supported the wires next to the connectors to relieve any stress. Is this an ok practice? thanks, Robert Dickson RV-6A electrical ________________________________________________________________________________
Date: Jun 04, 2003
Subject: MAC trim gauge & switch connection
I'm installing a mac/Ray Allen elevator trim servo in the elevator of my Rv-6A. I've read Bob's article on using a modified dsub connector to hook up the servo, but I'm not sure how to best connect the led trim gauge and the switch in the panel. Both of these items mount from the front of the panel, making it difficult to install and remove them on a temporary basis during panel construction. I suppose I could just connect them on a temp basis for testing using wire nuts, then butt splice them during final panel installation, but I'm curious as to how others may have dealt with this situation. thanks, Robert Dickson RV-6A electrical ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: MAC trim gauge & switch connection
><robert@thenews-journal.com> > >I'm installing a mac/Ray Allen elevator trim servo in the elevator of my >Rv-6A. I've read Bob's article on using a modified dsub connector to hook up >the servo, but I'm not sure how to best connect the led trim gauge and the >switch in the panel. >Both of these items mount from the front of the panel, making it difficult >to install and remove them on a temporary basis during panel construction. >I suppose I could just connect them on a temp basis for testing using wire >nuts, then butt splice them during final panel installation, but I'm >curious as to how others may have dealt with this situation. Why not put connectors on these leads too? Bob . . . ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: d sub shells
><robert@thenews-journal.com> > >I'd like to echo some of the recent sentiments regarding dsub connectors and >crimp pins. I've found them to be very user friendly. > >My question is about the shells for the connectors. In a couple of places >behind my panel there's just not room to use the shell. I've supported the >wires next to the connectors to relieve any stress. Is this an ok practice? Sure. Our targets use shell-less d-subs in some places and we passed some pretty rough environmental stress tests. If the connector is used in a system that would give you heartburn if it quit, then you could sho-goo the backside of the connector . . BUT ONLY AFTER you're sure it's wired correctly. It's VERY hard to move pins around after they're potted into place. Bob . . . ________________________________________________________________________________
Subject: BNC soldier style connectors
Date: Jun 04, 2003
Bob, I want to use soldier style BNC connectors with RG400 coax. A Jim Weir article said DigiKey sells AMP male soldier style connectors under part no. A24424-ND. However, on their website, the picture looks like it has a crimped collar on the coax cable and the discription says "CONN PLUG BNC RG174, 188 CRMP TIN" and customer service wasn't knowledgeable. Is this what I want or do you know the correct PN if it isn't? Thanks, Rick Fogerson RV3 wiring Boise, ID. ________________________________________________________________________________
Date: Jun 04, 2003
I installed both elevator and aileron trims in my plane. I mounted the two indicators and the aileron trim switch on a removable sub panel. Everything connects with a DB15 connector. See: http://mthobby.pcperfect.com/ch601/images/DCP01826.JPG The MAC accessories are next to the compass. Michel --- Robert Dickson <robert@thenews-journal.com> wrote: > Dickson <robert@thenews-journal.com> > > I'm installing a mac/Ray Allen elevator trim servo > in the elevator of my > Rv-6A. I've read Bob's article on using a modified > dsub connector to hook up > the servo, but I'm not sure how to best connect the > led trim gauge and the > switch in the panel. > Both of these items mount from the front of the > panel, making it difficult > to install and remove them on a temporary basis > during panel construction. > I suppose I could just connect them on a temp basis > for testing using wire > nuts, then butt splice them during final panel > installation, but I'm > curious as to how others may have dealt with this > situation. > ===== ---------------------------- Michel Therrien CH601-HD http://mthobby.pcperfect.com/ch601 http://www.zenithair.com/bldrlist/profiles/mthobby http://pages.infinit.net/mthobby __________________________________ ________________________________________________________________________________
Date: Jun 04, 2003
I found the 26 gauge wire a little small for crimp connectors and you are right, the D-sub pins in behind the panel seem unnecessary. I just soldered these connections and covered them with shrink. I know, I know......I used the "s" word. However, in the case of these small wires, it works fine. Randy F1 Rocket #95 http://mywebpages.comcast.net/f1rocket/ ----- Original Message ----- From: Robert Dickson <robert@thenews-journal.com> Date: Wednesday, June 4, 2003 1:34 pm Subject: AeroElectric-List: MAC trim gauge & switch connection > <robert@thenews-journal.com> > > I'm installing a mac/Ray Allen elevator trim servo in the elevator > of my > Rv-6A. I've read Bob's article on using a modified dsub connector > to hook up > the servo, but I'm not sure how to best connect the led trim gauge > and the > switch in the panel. > Both of these items mount from the front of the panel, making it > difficultto install and remove them on a temporary basis during > panel construction. > I suppose I could just connect them on a temp basis for testing > using wire > nuts, then butt splice them during final panel installation, but I'm > curious as to how others may have dealt with this situation. > > thanks, > > Robert Dickson > RV-6A electrical > > > _- > ======================================================================_- = - The AeroElectric-List Email Forum - > _- > ======================================================================_- = !! NEWish !! > _- > ======================================================================_- = List Related Information > _- > ====================================================================== > > > > ________________________________________________________________________________
Date: Jun 04, 2003
I wired the MAC with a 5 pin Deans connector. These are gold plated pins with a very positive connections, easy to install and readily available. (R/C hobby stuff)After final connection the entire assembly will be protected with an appropriate sized piece of heat shrink. Darwin N. Barrie Chandler AZ ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: AeroElectric-List: MAC trim gauge & switch connection > > FWIW, I'm planning on using individual D-sub pins/sockets (available from > B&C) for cases like this where I need removable connectors on 24 AWG wires. ________________________________________________________________________________
Date: Jun 04, 2003
I used a 5-pin flat Molex-type connector along with a single pin connector for the dimmer for each indicator. The trim indicator dimmer gets pulled high to dim the LEDs so it's connected to the panel light switch in parallel with the wire to the panel dimmer. The single pin connector made the harness routing a little cleaner. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > > > --> <robert@thenews-journal.com> > > I'm installing a mac/Ray Allen elevator trim servo in the > elevator of my Rv-6A. I've read Bob's article on using a > modified dsub connector to hook up the servo, but I'm not > sure how to best connect the led trim gauge and the switch in > the panel. Both of these items mount from the front of the > panel, making it difficult to install and remove them on a > temporary basis during panel construction. I suppose I could > just connect them on a temp basis for testing using wire > nuts, then butt splice them during final panel installation, > but I'm curious as to how others may have dealt with this situation. > > thanks, > > Robert Dickson > RV-6A electrical > ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: BNC soldier style connectors
> >Bob, >I want to use soldier style BNC connectors with RG400 coax. A Jim Weir >article said DigiKey sells AMP male soldier style connectors under part >no. A24424-ND. However, on their website, the picture looks like it has a >crimped collar on the coax cable and the discription says "CONN PLUG BNC >RG174, 188 CRMP TIN" and customer service wasn't knowledgeable. Is this >what I want or do you know the correct PN if it isn't? > Thanks, You want the military designation UG-88/U which is Amphenol's p/n 31-202 and Digikey's catalog number ARF1040-ND Installation instructions can be on page 299 of this document. http://www.amphenolrf.com/products/AssemblyInstructions/bnc.pdf Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Jun 04, 2003
Greg being fairly unsure of myself in matters electrical, I'm trying to understand exactly what you mean by this statement. > The trim indicator dimmer gets pulled > high to dim the LEDs so it's connected to the panel light switch in parallel > with the wire to the panel dimmer. > Regards, > Greg Young - Houston (DWH) I gather you've got a separate dimmer just for the LEDs. Are they unacceptably bright if undimmed at night? I've only got elevator trim and it seems like a hassle to install a dimmer just for that one gauge if it really isn't necessary. thanks for your help, Robert Dickson RV-6A electrical ________________________________________________________________________________
Date: Jun 04, 2003
><robert@thenews-journal.com> > > > >> I'm installing a mac/Ray Allen elevator trim servo in the elevator of my > >> Rv-6A. I've read Bob's article on using a modified dsub connector to > hook up > >> the servo, but I'm not sure how to best connect the led trim gauge and the > >> switch in the panel. > >> Both of these items mount from the front of the panel, making it difficult > >> to install and remove them on a temporary basis during panel construction. > >> I suppose I could just connect them on a temp basis for testing using wire > >> nuts, then butt splice them during final panel installation, but I'm > >> curious as to how others may have dealt with this situation. > > > > Why not put connectors on these leads too? > > > > Bob . . . > >what kind of connectors? will shrink-tubed d-sub pins be ok, as Dan >suggested? I prefer d-subs for this kind of application. But individually covered d-sub pins works too. What you don't get is pull-apart resistance . . . but then wire bundles aren't flight control cables. They're not hard to install so that they don't have tension on them. When you use individually covered d-sub mates, put an overall cover of heat shrink over the array of connections. Then use a nice, tight string-tie or tye-wrap at each end of cover to provide some pull-apart protection. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: Merging wiring - FWF
> >Bob Hi! from UK > >Did some light reading of Aero Connection Manual this morning over breakfast >to establish some guidance over wiring compatibility. Very wholesome! Still >need your words of wisdom! > >In an effort to keep efficient and 'tidy' Wiring, can you advise or confirm >that it it probably be OK to merge various Instrument Sensor wires in 22 AWG >unsceened with the Magneto screened wires (18 AWG) into a single loom, >separating again once through Firewall conduit. I have 22 AWG Screened if >more suitable. > >Regards > >Gerry There is no advantage in adding shields to any wires that share the bundle with magneto p-leads already shielded. Be sure to hook up the shields as depicted in several places on the Z-figures . . . ground the shield at the engine end only and use the shield to provide a ground for the magneto control switch. Other wires that might share wire routing and/or firewall penetrations with the p-leads need not be shielded unless the installation diagrams call for shielded wires. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2003
Robert, There is a dimming function built into the indicator. It's a day/night mode affair, not variable. It's counter intuitive to me but when you apply power to the dimmer wire, the LEDs go dim. I hooked it up so the panel light switch provides the power to the LED dimmer. I've just got 2 wires from the switch, one to the indicator and the other to a rheostat dimmer that feeds all the other panel lights. You can power the LED dimmer from any source, even a dedicated switch. I figured when it was dark enough to light the panel I'd want the LED's dimmed too. I'm somewhat electron challenged as well and it took a while to decipher MAC's wiring diagram but maybe this will help. Greg > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Robert Dickson > Sent: Wednesday, June 04, 2003 3:46 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: MAC trim gauge & switch connection > > > --> <robert@thenews-journal.com> > > Greg > being fairly unsure of myself in matters electrical, I'm > trying to understand exactly what you mean by this statement. > > > The trim indicator dimmer gets pulled > > high to dim the LEDs so it's connected to the panel light switch in > > parallel with the wire to the panel dimmer. > > > Regards, > > Greg Young - Houston (DWH) > > I gather you've got a separate dimmer just for the LEDs. Are > they unacceptably bright if undimmed at night? I've only got > elevator trim and it seems like a hassle to install a dimmer > just for that one gauge if it really isn't necessary. > > thanks for your help, > > Robert Dickson > RV-6A electrical > ________________________________________________________________________________
Date: Jun 04, 2003
> >Robert, > >There is a dimming function built into the indicator. It's a day/night mode >affair, not variable. It's counter intuitive to me but when you apply power >to the dimmer wire, the LEDs go dim. I hooked it up so the panel light >switch provides the power to the LED dimmer. I've just got 2 wires from the >switch, one to the indicator and the other to a rheostat dimmer that feeds >all the other panel lights. You can power the LED dimmer from any source, >even a dedicated switch. I figured when it was dark enough to light the >panel I'd want the LED's dimmed too. I'm somewhat electron challenged as >well and it took a while to decipher MAC's wiring diagram but maybe this >will help. Two level dimming is not uncommon for something that is basically illuminated all the time . . . like an LED bar graph. To be visible in sunlight, one generally designs for the LEDs to run max bright . . . which would be too bright for the dark cockpit. So . . . the "dim" wire is exactly that . . . a wire that tells the indicator to go into the dim mode. Depending on how sophisticated their input signal conditioning the indicator may switch from bright to dim for any voltage that appears on the DIM COMMAND wire. This would let you hook the DIM COMMAND wire to a string of dimmed panel lights such that any time they are ON at any intensity, the trim indicator goes to the dim mode. Given that the Ray Allen installation drawing calls for hooking DIM COMMAND to a "hard" 14v upstream of any dimmer control suggests that this is not the case. If you use B&C dimmers in the recommended configuration, there is NEVER less than 4 volts on any lamps . . . the system is turned OFF by max counter clockwise rotation of dimmer knob which simply reduces the panel lamps to minimum voltage for any usable light output . . . quite dim. If the Ray Allen indicator used a sophisticated sensor with a wide voltage range, then it would probably not go to the "day-bright" mode when panel lamps are reduced only down to 4v. Suggest you consider hooking the DIM COMMAND line to some other night lighting circuit like nav lights. Any time the nav lights are on, the indicator intensity goes to dim. Bob . . . ________________________________________________________________________________
Date: Jun 04, 2003
Subject: Re: ground plane
> >Bob, > >I've been following the thread about the optimum ground plane for the >transponder. What is the optimum diameter for a circular ground >plane? I'd like to mount the antenna on a 7" diameter aileron bellcrank >access plate on the bottom of the wing of my Glasair. Others have done >this, but I'll figure out something else if you think I should. The "optimum" tuned ground plane is same radius as height of antenna . . . or about 5.2" diameter for transponder. But it will probably work just fine on the access plate too. Bob . . . ________________________________________________________________________________
Subject: Power buss feed connection
Date: Jun 05, 2003
RE: Power buss feed connection Bob or anyone, what is the preferred method for connecting the primary + feed to the main buss or other power buss? As I see it, one could connect it to one of the PIDG and put a large rated fuse in it or is it better to connect it to the metal screw post at the end of the buss? What other use could the metal screw post be used for? Larry in Indiana, RV7 Tip-up O-360 3XG reserved. Starting to work with Bob's power busses ________________________________________________________________________________
Date: Jun 05, 2003
Subject: Re: Power buss feed connection
Or one could get the male faston adapter meant to be used for the battery bolt. It has three tabs and one big slot for a big battery bolt. For use with smaller bolts we use on the airplane one could solder the correct ring terminal to get rid of the slot. I think I got them at either Radio Shack or at an Auto supply place. Paul ======== > >RE: Power buss feed connection > >Bob or anyone, what is the preferred method for connecting the primary + >feed to the main buss or other power buss? As I see it, one could connect >it to one of the PIDG and put a large rated fuse in it or is it better to >connect it to the metal screw post at the end of the buss? What other use >could the metal screw post be used for? > >Larry in Indiana, RV7 Tip-up O-360 3XG reserved. >Starting to work with Bob's power busses -- ________________________________________________________________________________
Date: Jun 05, 2003
Cheers, Just so's it doesn't appear that Ol' Bob is alone in the Turn and Bank persuasion, I heartily agree with his stand and will have but a T&B in my Europa for coordinated footwork (and perhaps the odd clumsy stumble out of cloud). Ferg ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Date: Jun 06, 2003
> The "optimum" tuned ground plane is same radius as height of > antenna . . . or about 5.2" diameter for transponder. But > it will probably work just fine on the access plate too. > > Bob . . . Bob, I'm afraid my transponder ground plane is 5.5" diameter. Will that make a big difference ? Shall I have to make a new one ? Thanks, Gilles ________________________________________________________________________________
Date: Jun 05, 2003
Subject: Another shielding question
Bob: Hoping for your expert opinion. I am using a SoftCom ATC-2P intercom with a KX-125 Navcom. The factory prewired harness for the intercom has only unshielded wires. I have installed it as received but I have routed the mic and phone jack wiring so as to keep them at least 2 inches away from other wires except for a span of about 3 inches where all the wiring passes through one panel. Now I am installing the KX-125, for which I have to fabricate the harness, and the wiring diagram calls for shielding on the connections to the intercom. This would require disassembly and rewiring of the installed intercom harness, a tough job because I potted the backside of the connector. My question is, if I continue to keep the audio and mic key wires separate from other wires, is it reasonable to expect that I can forego shielding on these lines, or should I "bite the bullet" and rework the intercom harness now? BTW, I am using your single point "forest of tabs" for all grounds, including avionics. Harry Crosby Pleasanton, California RV-6, firewall forward and finishing electrical ________________________________________________________________________________
Subject: Ratchet Crimper
Date: Jun 05, 2003
Bob & List: I'm looking for a quality ratchet crimper and lugs for #2 & #4 welding cable. I'm trying not to buy the real expensive ones, unless I have too. Any recommendations would be appreciated. Thanks Byron ________________________________________________________________________________
Date: Jun 05, 2003
Subject: ground plane for comm.
Lancair Legacy still early in construction; only thing done in cockpit so far (besides loadpads) is seat reinforcement and canopy latch. q: should I install the comm. ant. groundplane (there's already a slot for it on the belly) now or wait 'til later? peter goudinoff L2K #200 ________________________________________________________________________________
Date: Jun 05, 2003
Subject: Re: Ratchet Crimper
> >Bob & List: >I'm looking for a quality ratchet crimper and lugs for #2 & #4 welding >cable. I'm trying not to buy the real expensive ones, unless I have too. >Any recommendations would be appreciated. >Thanks >Byron I solder this size terminal. There are so few terminals to put on and good tools are expensive. There's an article on how to solder the big wires on my website at: http://www.aeroelectric.com/articles/big_term.pdf I own about a dozen crimp tools but nothing bigger than the 10-12AWG PIDG terminal. Bob . . . ________________________________________________________________________________
Date: Jun 05, 2003
><Gilles.Thesee@ac-grenoble.fr> > > > > The "optimum" tuned ground plane is same radius as height of > > antenna . . . or about 5.2" diameter for transponder. But > > it will probably work just fine on the access plate too. > > > > Bob . . . > > >Bob, > >I'm afraid my transponder ground plane is 5.5" diameter. Will that make a >big difference ? Shall I have to make a new one ? Nope . . . keep on truck'n Bob . . . ________________________________________________________________________________
Date: Jun 05, 2003
Subject: V=IR problem
I have an 8 day clock that wants 5V for the internal light. I have a 12v airplane. I know if measure the clock's resistance with an ohm meter I can figure out how big a resistor to put in line with it. Can someone walk me through the equation? ________________________________________________________________________________
Date: Jun 05, 2003
Subject: Re: V=IR problem
In a message dated 6/5/03 10:34:01 PM Central Daylight Time, richard(at)riley.net writes: > I know if measure the clock's resistance with an ohm meter I can figure out > > how big a resistor to put in line with it. Can someone walk me through the > equation? > Just curious, why not use a ZENER? Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 05, 2003
> >I have an 8 day clock that wants 5V for the internal light. I have a 12v >airplane. > >I know if measure the clock's resistance with an ohm meter I can figure out >how big a resistor to put in line with it. Can someone walk me through the >equation? Light bulbs have a very steep positive temperature coefficient of resistance. The resistance reading you'll get with an ohmmeter will be much lower than actual operating resistance. You need to attach the clock to a 5v power supply and measure the current with the lamp operating. Then subtract 5v from 14v to get the resistor drop. Your formula is R=E/I so divide the voltage drop by measured current to yield appropriate size resistor. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2003
V=IR is the start You want 5 volts across the clock, so measure its resistance. Now you know Vclock and Rclock, so calculate Iclock from equation. Say Rclock is 5ohms, the Iclock would be 1A. Now we know the current through the circuit needs to be 1 Amp, and we need to drop 12-5=7 volts across the other resistor. So, Vres is 7 volts, Iclock=Iresistor=1A, so again, using the equation we can find the R value you need is 7ohms. Size your resistor power by P=I 2 * R, so 1*1*7, or 7watts in the case. Oversize it by a factor of about 2 I'd say to be safe. Also, you might want to consider 14.4 volts in these calcs instead of 12, depending on how you set up your electrical system. These are all hypothetical, but should help you get it figured out. Basically, sum of all current in and out of a node is zero, and sum of all voltages around a loop is also zero. Hopefully you can see these laws at work in the above example. Another way would be to just use a small 7805 5v voltage regulator that takes 12 in and would put out enough 5V to run your clock. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of richard(at)riley.net Subject: AeroElectric-List: V=IR problem I have an 8 day clock that wants 5V for the internal light. I have a 12v airplane. I know if measure the clock's resistance with an ohm meter I can figure out how big a resistor to put in line with it. Can someone walk me through the equation? ________________________________________________________________________________
Date: Jun 05, 2003
>Just curious, why not use a ZENER? My understanding was that a Zener wouldn't let me dim the internal lighting with the rest of the panel. If I'm wrong, please let me know. If I string together 3 D cells, would that be close enough to 5 v to get an accurate voltage drop? ________________________________________________________________________________
Date: Jun 05, 2003
Actually, I've found it difficult to reliably measure the resistance of a lamp directly with an ohmmeter - if it's LED, you won't get a meaningful answer, and if it's incandescent, the cold resistance is different from the hot (lighted) resistance. Also, if there's any electronics in it at all (apparently not, by "8-day clock" I take it to mean it's mechanical, only the light needs electrical), I would not depend solely on a dropping resistor anyway, I'd want a 5.1v Zener in there too. But, given a mechanical clock, I'd simply first find the current it uses at 5 volts (use a milliammeter and 4 NiCads or NiMHs), then divide that into 9 (14-volt supply - 5-volt desired = 9-volt drop)... Example: let's say you find it uses 50 milliamps (.05A) - you want to drop 9 volts so that would be 9/.05 or 180 ohms. Wattage is I*I*R, or 1/20*1/20*180 in this case... about 1/2 watt so make it a 1-watt resistor and make sure it has a bit of room to breathe. Maybe it would just be better to swap the 5-volt for a 12-volt lamp if possible? -John R. richard(at)riley.net wrote: > >I have an 8 day clock that wants 5V for the internal light. I have a 12v >airplane. > >I know if measure the clock's resistance with an ohm meter I can figure out >how big a resistor to put in line with it. Can someone walk me through the >equation? > > > > ________________________________________________________________________________
Date: Jun 06, 2003
In a message dated 6/5/03 11:17:19 PM Central Daylight Time, richard(at)riley.net writes: > My understanding was that a Zener wouldn't let me dim the internal lighting > > with the rest of the panel. If I'm wrong, please let me know. > Good Evening Richard, I am definitely one of those electrically challenged types, but I have used Zeners for dimming purposes. What is so nice about a Zener is that it drops the voltage to the required voltage regardless of what the load is. I guess I should say; as long as the load is within the capacity of the zener. The first time I used one was to dim a set of four GPS annunciator lights. Since they were sometimes all on at the same time and other times only one or two were on, a resistor wouldn't work. The zener did the job perfectly. I think it is all just magic! Surely, some of the folks on this list will explain it much better than I can. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 05, 2003
You're right about the zener cancelling out the dimming to a large degree - as for 3 D-cells, it's close enough (4.5 volts) but 4 NiCads are closer (NiCads start out near 1.4 volts, but quickly drop to 1.25 under about any load) -John R. richard(at)riley.net wrote: > > > > > >>Just curious, why not use a ZENER? >> >> > >My understanding was that a Zener wouldn't let me dim the internal lighting >with the rest of the panel. If I'm wrong, please let me know. > >If I string together 3 D cells, would that be close enough to 5 v to get an >accurate voltage drop? > > > > ________________________________________________________________________________
Date: Jun 05, 2003
Bob, that's indeed a great way to independently dim a set of lamps, independent of load... but I think Richard has the opposite requirement - a fixed load that he wants to dependently dim with the master dimmer. A zener won't work for that. -John R. BobsV35B(at)aol.com wrote: > >In a message dated 6/5/03 11:17:19 PM Central Daylight Time, >richard(at)riley.net writes: > > > >>My understanding was that a Zener wouldn't let me dim the internal lighting >> >>with the rest of the panel. If I'm wrong, please let me know. >> >> >> > >Good Evening Richard, > >I am definitely one of those electrically challenged types, but I have used >Zeners for dimming purposes. What is so nice about a Zener is that it drops >the voltage to the required voltage regardless of what the load is. I guess I >should say; as long as the load is within the capacity of the zener. > >The first time I used one was to dim a set of four GPS annunciator lights. >Since they were sometimes all on at the same time and other times only one or >two were on, a resistor wouldn't work. The zener did the job perfectly. I >think it is all just magic! > >Surely, some of the folks on this list will explain it much better than I >can. > >Happy Skies, > >Old Bob > > > > ________________________________________________________________________________
Date: Jun 05, 2003
Larry, Use the post with a ring terminal and a locking nut or lock washer. That is what that post is for. It would be useless to put the current for the whole fuse block through a big fuse: the fuse protects nothing. Also, the PIDG connectors may be useful to 20 amps, but your fuse block could draw more. The ring terminal is the appropriate connection here. If you wish to protect the feed wire from the contactor to your fuse block, you could use a fusable link if it exceeds the 6 inch rule. Bob Nucholls does not worry much about exceeding the 6 inch rule according to a recent post, so a longer wire to the contactor with attention paid to avoid chaffing the insulation should be OK. Jim Foerster J400, 50% ________________________________________________________________________________
Date: Jun 06, 2003
> >I'm afraid my transponder ground plane is 5.5" diameter. Will that make a > >big difference ? Shall I have to make a new one ? > > Nope . . . keep on truck'n > > Bob . . . Thanks, Gilles ________________________________________________________________________________
Date: Jun 06, 2003
Why not get a 12 volt bulb? Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh Editor, EAA Safety Programs cgalley(at)qcbc.org or experimenter(at)eaa.org Always looking for articles for the Experimenter ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: V=IR problem > > > > >I have an 8 day clock that wants 5V for the internal light. I have a 12v > >airplane. > > > >I know if measure the clock's resistance with an ohm meter I can figure out > >how big a resistor to put in line with it. Can someone walk me through the > >equation? > > Light bulbs have a very steep positive temperature > coefficient of resistance. The resistance reading > you'll get with an ohmmeter will be much lower > than actual operating resistance. > > You need to attach the clock to a 5v power supply > and measure the current with the lamp operating. > Then subtract 5v from 14v to get the resistor drop. > Your formula is R=E/I so divide the voltage drop > by measured current to yield appropriate size resistor. > > Bob . . . > > ________________________________________________________________________________
Date: Jun 06, 2003
In a message dated 6/5/03 11:52:01 PM Central Daylight Time, jrourke@allied-computer.com writes: > Bob, that's indeed a great way to independently dim a set of lamps, > independent of load... but I think Richard has the opposite requirement > - a fixed load that he wants to dependently dim with the master dimmer. > A zener won't work for that. > > -John R. > Makes sense to me! I hadn't picked up on that data correctly. I guess the dimming would have to be separately supplied for the unit powered by the zener. More complications. Thanks for the explanation. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 06, 2003
Byron I use a T&B # TBM5. It comes with several dies. It works with there color keyed lugs. Best regards Ron Raby ----- Original Message ----- From: "Byron & Jean" <byronjean(at)ticon.net> Subject: AeroElectric-List: Ratchet Crimper > > Bob & List: > I'm looking for a quality ratchet crimper and lugs for #2 & #4 welding cable. I'm trying not to buy the real expensive ones, unless I have too. Any recommendations would be appreciated. > Thanks > Byron > > ________________________________________________________________________________
Date: Jun 06, 2003
> >In a message dated 6/5/03 11:17:19 PM Central Daylight Time, >richard(at)riley.net writes: > > > My understanding was that a Zener wouldn't let me dim the internal > lighting > > > > with the rest of the panel. If I'm wrong, please let me know. > > > >Good Evening Richard, > >I am definitely one of those electrically challenged types, but I have used >Zeners for dimming purposes. What is so nice about a Zener is that it drops >the voltage to the required voltage regardless of what the load is. I >guess I >should say; as long as the load is within the capacity of the zener. > >The first time I used one was to dim a set of four GPS annunciator lights. >Since they were sometimes all on at the same time and other times only one or >two were on, a resistor wouldn't work. The zener did the job perfectly. I >think it is all just magic! > >Surely, some of the folks on this list will explain it much better than I >can. A zener has a relatively constant voltage drop. So, Consider a 5v lamp in series with a 9v resistor to run full bright from a 14v supply. At 14v, all lamps will be max bright. Reducing dimming supply voltage by say, 2 volts, will drop the supply to 14v string by (2/14)*100 or 14%. Voltage on the 5v string will go down by 2v as well. (2/5)*100 is 40%. Reducing dimming supply still further to say 9V will have the 14v string about half-bright, the 5v string will be dark. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2003
> >Or one could get the male faston adapter meant to be used for the battery >bolt. It has three tabs and one big slot for a big battery bolt. For use >with smaller bolts we use on the airplane one could solder the correct >ring terminal to get rid of the slot. I think I got them at either Radio >Shack or at an Auto supply place. > Paul >======== > > > > > >RE: Power buss feed connection > > > >Bob or anyone, what is the preferred method for connecting the primary + > >feed to the main buss or other power buss? As I see it, one could connect > >it to one of the PIDG and put a large rated fuse in it or is it better to > >connect it to the metal screw post at the end of the buss? What other use > >could the metal screw post be used for? > > > >Larry in Indiana, RV7 Tip-up O-360 3XG reserved. > >Starting to work with Bob's power busses The treaded post on the end of the fuseblock was designed to be the feedpoint for the bus. If you perceive some design advantage in an alternative configuration, can you support it with a dissertation of simple ideas upon which the whole is founded? Not trying to be preachy or sanctimonious here. In fact, a good designer has to acknowledge that there could be a suite of configurations based on good assemblage of simple ideas. It then becomes a trade-off based on complexity, cost of ownership, efficiency, etc. There may a number of ways to skin a cat but one of them will be most attractive depending on circumstances other than skinning technique. So, if you have an alternative configuration to consider, pull together the underlying pieces that hold it up. Bob . . . ________________________________________________________________________________
Date: Jun 06, 2003
Byron, Although not exactly what you asked for (a ratchet crimper), a Nicopress tool does a good job on the big terminals. -- Joe Long-EZ 821RP Clarkston, WA [original message] ================== Bob & List: I'm looking for a quality ratchet crimper and lugs for #2 & #4 welding cable. I'm trying not to buy the real expensive ones, unless I have too. Any recommendations would be appreciated. Thanks Byron _ ________________________________________________________________________________
Subject: crimping large ring terminals
Date: Jun 06, 2003
This may be a silly question, but what tool is used to crimp terminals for wires larger than 10 AWG? I have a vinyl insulated ring terminal for a #8 wire (source: Van's basic wiring kit) but no tool (that I know of) to crimp it with. Should I scrap it and solder/heat-shrink it instead? I'm just as happy doing that if I have to buy YET another expensive tool. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 06, 2003
I was able to rent some from the local electrical supply house. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Joe Dubner Subject: AeroElectric-List: Re: Ratchet Crimper Byron, Although not exactly what you asked for (a ratchet crimper), a Nicopress tool does a good job on the big terminals. -- Joe Long-EZ 821RP Clarkston, WA [original message] ================== Bob & List: I'm looking for a quality ratchet crimper and lugs for #2 & #4 welding cable. I'm trying not to buy the real expensive ones, unless I have too. Any recommendations would be appreciated. Thanks Byron _ ________________________________________________________________________________
Date: Jun 06, 2003
From: "I-Blackler, Wayne R" <wayne.blackler(at)boeing.com>
Bob's solder and heat shrink method works extremely well for 8WAG to 2AWG and is simple, effective and perfectly acceptable for our aeroplanes. I completed mine (2AWG and 4AWG) last weekend and saved $300-$600 on hand crimpers. Now, if you really desperately want to crimp, you can get it done, but remember to verify clocking with the person doing your crimping. Cheers - Wayne Blackler IO-360 Long EZ Getting closer... Seattle, USA -----Original Message----- From: Dan Checkoway [mailto:dan(at)rvproject.com] Subject: AeroElectric-List: crimping large ring terminals This may be a silly question, but what tool is used to crimp terminals for wires larger than 10 AWG? I have a vinyl insulated ring terminal for a #8 wire (source: Van's basic wiring kit) but no tool (that I know of) to crimp it with. Should I scrap it and solder/heat-shrink it instead? I'm just as happy doing that if I have to buy YET another expensive tool. )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Jun 06, 2003
Subject: Re: Zenerology
> >Since the subject of using zeners for dimming control is being >discussed, could someone please offer an explanation of how they work? >The little bit of research I have done says they are intentionally >reverse-biased diodes that conduct when their rated voltage level is >reached. If this is correct, how does this act like anything more than >a switch with a voltage threshold? http://myweb.tiscali.co.uk/robert.booth/uni/docs/Industrial%20Electronics.pdf http://www.americanmicrosemi.com/tutorials/zener.htm http://jever.phys.ualberta.ca/~gingrich/phys395/notes/node60.html http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/zener.html http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/zenereg.html#c1 http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/limiter.html#c1 Bob . . . ________________________________________________________________________________
Subject: Sealed coax connectors
Date: Jun 07, 2003
Hi Bob and all, Found in old issues of Avionics magazine some adds from Pic wire. They talk about sealed BNC and TNC connectors to prevent moisture problems. Any opinions ? Regards Gilles ________________________________________________________________________________
Subject: Torque measurement with strain gauge
Date: Jun 07, 2003
Bob or anyone, I'm installing a Blue Mountain EFIS and this allows me to set up 'instrument gauges' with any label that I want, as long as I can get an analog voltage to represent the measurement. I would like to measure HP output from the engine. HP=(Torque)(RPM)/5252. Strain gauges are old technology with which I have no experience. A strain gauge on the prop shaft is hard to interface. Power and signal must pass either sliding rings and brushes :>(( or else use some magnetic and optical coupling. However, strain gauges on the engine mount would be easy to connect, but I'm not sure that I could separate torque moments from the linear stresses of just holding the weight of the engine. I believe that there are strain gauges with a 45 degree pattern that respond to torque more than to linear stress, but I hardly know where to start reading. Or, has anyone tried this and found that it is impossible? I did send off to Omega for some literature. I envision building a Wheatstone bridge arrangement feeding an instrumentation amplifier. Any thoughts/pearls/war stories? ________________________________________________________________________________
Date: Jun 06, 2003
Subject: Re: Torque measurement with strain gauge
This months Circuit Cellar had an article about a horsepower monitor for an automobile http://www.circuitcellar.com/flash2002/second.htm They used a RF link from the drive shaft to the monitor CPU. Something to think about, prop hub or something for a light weight RF unit. jmfpublic(at)attbi.com wrote: > > Bob or anyone, > I'm installing a Blue Mountain EFIS and this allows me to set up 'instrument > gauges' with any label that I want, as long as I can get an analog voltage to > represent the measurement. I would like to measure HP output from the engine. > HP=(Torque)(RPM)/5252. Strain gauges are old technology with which I have no > experience. A strain gauge on the prop shaft is hard to interface. Power and > signal must pass either sliding rings and brushes :>(( or else use some > magnetic and optical coupling. However, strain gauges on the engine mount > would be easy to connect, but I'm not sure that I could separate torque moments > from the linear stresses of just holding the weight of the engine. I believe > that there are strain gauges with a 45 degree pattern that respond to torque > more than to linear stress, but I hardly know where to start reading. Or, has > anyone tried this and found that it is impossible? I did send off to Omega for > some literature. I envision building a Wheatstone bridge arrangement feeding > an instrumentation amplifier. Any thoughts/pearls/war stories? > > > > > > > ________________________________________________________________________________
(Aeroelectric-List)
Subject: Nav antenna next to Comm
Date: Jun 07, 2003
Bob, or anyone, I have a Jabiru J400 with the comm antenna in the vertical fin, just ahead of the rudder. There is a channel in the horizontal stabalizer where the elevator lies with a perfect fit for some one inch wide brass strip, possibly 0.020 thick. This would give a broadband, low Q horizontally polarized antenna. My receiver is a UPS SL-30, a modern design. Will I have cross-talk problems transmitting on the comm frequencies while receiving VOR, or using the third harmonic of the antenna for glide-slope? Jim Foerster ________________________________________________________________________________
Date: Jun 07, 2003
The Vishay Measurements Group website has a vast quantity of info about strain gauges. They sell Wheatstone bridge arrangements on a single guage. Try: http://www.vishay.com/brands/measurements_group/guide/guide.htm I did a project with a Wheatstone on a prop shaft using radio to get the signal off the shaft, but it was a pain. Slip rings can have noise problems. If you cook up a easy way to do it, drop me a line . Strain gauges on the motor mount tubes doesn't sound very practical. Dan. ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Shielding question
Bob: Hoping for your expert opinion. I am using a SoftCom ATC-2P intercom with a KX-125 Navcom. The factory prewired harness for the intercom has only unshielded wires. I have installed it as received but I have routed the mic and phone jack wiring so as to keep them at least 2 inches away from other wires except for a span of about 3 inches where all the wiring passes through one panel. Now I am installing the KX-125, for which I have to fabricate the harness, and the wiring diagram calls for shielding on the connections to the intercom. This would require disassembly and rewiring of the installed intercom harness. My question is, if I keep the audio and mic key wires separate from other wires, is it reasonable to expect that I can forego shielding on these lines, or should I "bite the bullet" and rework the intercom harness now? BTW, I am using your single point "forest of tabs" for all grounds, including avionics grounds, except the strobes, nav lights and landing lights in the wing tips. Harry Crosby Pleasanton, California RV-6, firewall forward and finishing electrical Harry Crosby Pleasanton, California RV-6, firewall forward ________________________________________________________________________________
Date: Jun 07, 2003
In a message dated 6/6/2003 10:10:35 PM Eastern Standard Time, jmfpublic(at)attbi.com writes: > Or, has > anyone tried this and found that it is impossible? Good Morning jmf, I don't believe anyone has found it to be impossible, but it has been tried before. I am not sure who did it, though it might have been Texas Insruments and Al Hundere may have been involved. To the best of my recollection, it was in Texas and the strain gauges were affixed to the engine mounts in a Beechcraft model 18. The circa was around 1960. It was hoped that a low cost torquemeter could be developed. The reports were favorable, but it never made it to market. Maybe it is time to try again with modern technology, it might work great! Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 07, 2003
> >Bob or anyone, >I'm installing a Blue Mountain EFIS and this allows me to set up 'instrument >gauges' with any label that I want, as long as I can get an analog voltage to >represent the measurement. I would like to measure HP output from the engine. >HP=(Torque)(RPM)/5252. Strain gauges are old technology with which I have no >experience. A strain gauge on the prop shaft is hard to interface. Power and >signal must pass either sliding rings and brushes :>(( or else use some >magnetic and optical coupling. However, strain gauges on the engine mount >would be easy to connect, but I'm not sure that I could separate torque moments >from the linear stresses of just holding the weight of the engine. I believe >that there are strain gauges with a 45 degree pattern that respond to torque >more than to linear stress, but I hardly know where to start reading. Or, has >anyone tried this and found that it is impossible? I did send off to Omega for >some literature. I envision building a Wheatstone bridge arrangement feeding >an instrumentation amplifier. Any thoughts/pearls/war stories? ========= Why not just buy an automotive gadget that gives direct readout of acceleration, horsepower plus other things. Pretty simple just turn it on and read the numbers while in motion. No wires to connect. Many outfits sell the gadgets. Do a Google search and find one to fit your needs/desires. Start with www.gtimer.com Paul -- ________________________________________________________________________________
Subject: Crow Bar OV Protection
Date: Jun 07, 2003
Hi Bob, I am installing your Crow Bar OV Module and was wondering if it would be okay to use a 7 amp breaker instead of a 5 amp? The smallest gauge wire in the circuit is 16 G except for the OV module wire which appears to be smaller. I already have a 7 amp breaker available in the panel, do I need to replace it with a 5 or can I just use it? Thanks, Ned ________________________________________________________________________________
Subject: Wire labels
Date: Jun 07, 2003
Hi, I am new to the list. I am building a Cozy MK4. I have seen some wire labels that are printed on shrink tube. Are these labels available or do you need some sort of "printer" to make them? Thanks Dean Head Cozy MK4 #1040 ________________________________________________________________________________
Subject: Re: Crow Bar OV Protection
Date: Jun 07, 2003
Hey guys never mind. Dad had a 5 amp breaker in his 60 year collection of parts! Thanks, Ned ----- Original Message ----- From: <315(at)cox.net> Subject: AeroElectric-List: Crow Bar OV Protection > > Hi Bob, > > I am installing your Crow Bar OV Module and was wondering if it would be okay to use a 7 amp breaker instead of a 5 amp? The smallest gauge wire in the circuit is 16 G except for the OV module wire which appears to be smaller. I already have a 7 amp breaker available in the panel, do I need to replace it with a 5 or can I just use it? > > Thanks, > Ned > > ________________________________________________________________________________
Date: Jun 07, 2003
Check out www.kroy.com. They have several models (650 and 2500) of shrink tube printers. I bought mine on Ebay for $80 including 6 cartridges of shrink tubing. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dean Head Subject: AeroElectric-List: Wire labels Hi, I am new to the list. I am building a Cozy MK4. I have seen some wire labels that are printed on shrink tube. Are these labels available or do you need some sort of "printer" to make them? Thanks Dean Head Cozy MK4 #1040 ________________________________________________________________________________
Date: Jun 07, 2003
Hi Dean, At last, a question on this list I can answer! I use MS word and a 6 point font to print a sheet of labels, then cut them up with scissors and insert the label between the shrink tubing and the wire. Just about any printer and plain paper works great. Regards, John Slade ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Wire labels
The specific shrinktube and the Kroy printer necessary to produce the labels are available at Graphic Products, ; 1-800-788-5572. The printer is a Kroy K3000-PC; use Kroy 1/8" yellow shrinktubing. Incredible job. Well worth the expense. Kenneth Melvin FEW Mustang N51KX ________________________________________________________________________________
Date: Jun 07, 2003
> >Hi Dean, >At last, a question on this list I can answer! >I use MS word and a 6 point font to print a sheet of labels, then cut them >up with scissors and insert the label between the shrink tubing and the >wire. Just about any printer and plain paper works great. >Regards, >John Slade For an illustration of how this works, see: http://www.aeroelectric.com/Catalog/wiring/s817c.jpg http://www.aeroelectric.com/Catalog/wiring/wiring.html#s816c Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Sealed coax connectors
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >Found in old issues of Avionics magazine some adds from Pic wire. They talk >about sealed BNC and TNC connectors to prevent moisture problems. >Any opinions ? > >Regards >Gilles Some offerings in BNC connectors have gaskets in them to reduce probability of splash getting into the connector but NONE are gas tight . . . meaning that environmental circulation of moisture due to atmospheric pressure changes WILL happen. I wouldn't make any special effort to buy a super-whizzy coax connector for an OBAM project . . . Now, if it's a taxpayer funded military project, then the sky's the limit. You can go for gold plated too . . . Bob . . . ________________________________________________________________________________
Subject: Mom-on toggle
Date: Jun 07, 2003
I'm looking for a off-(on) toggle switch for use as a starter engage switch. Same functionality as the push button that Bob sells, but I want the form-factor of the toggle switches. This will be used with the red flip-guard. Anyone know a source? I guess one of the three-position switches would work [xx-xx-(on)], but ... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Subject: Circuit breaker recommendation
Date: Jun 07, 2003
Hi All, I am going to use Bob's OVP module and I will need to buy a circuit breaker. Can someone make a recommendation for a CB. A specific brand, type number & suplier would be helpful. Thanks, Paul ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Circuit breaker recommendation
> > >Hi All, > >I am going to use Bob's OVP module and I will need to buy a circuit >breaker. Can someone make a recommendation for a CB. A specific brand, >type number & suplier would be helpful. > >Thanks, Paul Any 5A breaker will do. The folks who sold you the OV protection module sell a miniature 5A breaker at: http://www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?7X358218 Aircraft Spruce has one a bit larger at: http://www.aircraftspruce.com/catalog/elpages/pbcircuitbrkr.php See p/n W23X1A1G5 5 CB-230 5A $11.950 Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Mom-on toggle
> >I'm looking for a off-(on) toggle switch for use as a starter engage >switch. Same functionality as the push button that Bob sells, but I >want the form-factor of the toggle switches. This will be used with the >red flip-guard. Anyone know a source? I guess one of the >three-position switches would work [xx-xx-(on)], but ... CARLING 6FB5H73XA: ALLIED STOCK # 683-5121 http://www.alliedelec.com/catalog/pf.asp?FN=896.pdf Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Bob - Now that the subject came up again, it would really help to have a feel for the right sizes. Could you complete the following table for sizing of shrink wrap? Of course, it varies with the terminal, pin, # of wires, etc., but a general size for each would be OK. Many thanks in advance and again for your past help. All wire is Mil 22759 22AWG: Size: 20AWG: Size: 18AWG: Size: 16AWG: Size: 14AWG: Size: 12AWG: Size: 10AWG: Size: 08AWG: Size: 06AWG: Size: 04AWG: Size: 02AWG: Size: ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Wire cross sectional area
Anyone Anyone have a reference for the cross sectional area for Mil Spec Wire #24-#2 and sq inch preferred. Thanks Jerry N414PM Reserved Wiring ________________________________________________________________________________
Date: Jun 07, 2003
> > >Bob - > >Now that the subject came up again, it would really help to have a feel for >the right sizes. Could you complete the following table for sizing of >shrink wrap? Of course, it varies with the terminal, pin, # of wires, etc., >but a general size for each would be OK. Many thanks in advance and again >for your past help. > >All wire is Mil 22759 > >22AWG: Size: >20AWG: Size: >18AWG: Size: >16AWG: Size: >14AWG: Size: >12AWG: Size: >10AWG: Size: >08AWG: Size: >06AWG: Size: >04AWG: Size: >02AWG: Size: It depends on the kind of heat-shrink you are using. MOST shrinks drop to 1/2 their manufactured size when heated. However, referring to the catalog page: http://216.55.140.222/temp/Allied_p301.pdf we see shrink ratios as high as 4:1 Here's an excerpt from the spec for Mil-W-22759/16 wire . . . most commonly used for aircraft. http://216.55.140.222/temp/22759-16.pdf This chart gives you the overall diameter limits for the various gages of wire. You'll want ot select shrink that will close to some value just smaller than the wire for best fit. As it turns out, there are only a few sizes necessary to cover all the bases in applying shrink covers over wire labels. These are offered by B&C at http://www.aeroelectric.com/Catalog/BCcatalog.html down near the bottom of the listing. There's even a kit of assorted sizes and quqantites that will probably have enough of every size necessary in 2:1 clear shrink to do an airplane project. Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
> >Bob or anyone, >I'm installing a Blue Mountain EFIS and this allows me to set up 'instrument >gauges' with any label that I want, as long as I can get an analog voltage to >represent the measurement. I would like to measure HP output from the >engine. >HP=(Torque)(RPM)/5252. Strain gauges are old technology with which I have no >experience. A strain gauge on the prop shaft is hard to interface. Power >and >signal must pass either sliding rings and brushes :>(( or else use some >magnetic and optical coupling. However, strain gauges on the engine mount >would be easy to connect, but I'm not sure that I could separate torque >moments >from the linear stresses of just holding the weight of the engine. I believe >that there are strain gauges with a 45 degree pattern that respond to torque >more than to linear stress, but I hardly know where to start reading. Or, >has >anyone tried this and found that it is impossible? I did send off to Omega >for >some literature. I envision building a Wheatstone bridge arrangement feeding >an instrumentation amplifier. Any thoughts/pearls/war stories? It's been done but it's pretty ugly. First, the stress on a prop shaft is rather low . . . seems there is a decidedly enthusiastic interest in not having prop shafts break. When one goes to measure strain on a prop shaft surface, the values are exceedingly small. After you've amplified them up to usable values, you find that every power pulse from a firing cylinder puts gobs of modulation on the envelope of average torque. Aerodynamic loads and gyroscopic loading add further degrees of uncertainty. The task is challenging electronically too. The best approach I've see was to power the measurement system from battery and radio the data off the prop from a TM transmitter housed in the prop spinner. Some fancy footwork with a digital signal processor integrated the very ratty raw data into usable information. Is this a short term investigative effort or are you trying to make your suite of engine instrumentation look like you've got a turbo-prop installed? Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Nav antenna next to Comm
> >Bob, or anyone, >I have a Jabiru J400 with the comm antenna in the vertical fin, just ahead of >the rudder. There is a channel in the horizontal stabalizer where the >elevator >lies with a perfect fit for some one inch wide brass strip, possibly 0.020 >thick. This would give a broadband, low Q horizontally polarized antenna. My >receiver is a UPS SL-30, a modern design. Will I have cross-talk problems >transmitting on the comm frequencies while receiving VOR, or using the third >harmonic of the antenna for glide-slope? On VOR maybe but it's only while you're transmitting. On GS, probably not. Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Subject: Re: Wire cross sectional area
> > >Anyone > >Anyone have a reference for the cross sectional area for Mil Spec Wire >#24-#2 and sq inch preferred. Are you wanting the overall sizes or cross section of the conductor? For overall size of wires, refer to the excerpt from the spec I just published for the Mil-W-22759/16 wire at: http://216.55.140.222/temp/22759-16.pdf If you're wanting the finely tuned cross sectional area of the copper, you can calculate based on numbers of strands use in layup and compute cross section for sum of strands of the gages cited. Here's a list of data on solid strands over a limited range WIRE TABLE FOR SOLID, ROUND COPPER CONDUCTORS Size Diameter Cross-sectional area Weight AWG inches cir. mils sq. inches lb/1000 ft =============================================================== 10 -------- 0.1019 ------- 10,380 ------ 0.008155 ----- 31.43 11 -------- 0.09074 ------- 8,234 ------ 0.006467 ----- 24.92 12 -------- 0.08081 ------- 6,530 ------ 0.005129 ----- 19.77 13 -------- 0.07196 ------- 5,178 ------ 0.004067 ----- 15.68 14 -------- 0.06408 ------- 4,107 ------ 0.003225 ----- 12.43 15 -------- 0.05707 ------- 3,257 ------ 0.002558 ----- 9.858 16 -------- 0.05082 ------- 2,583 ------ 0.002028 ----- 7.818 17 -------- 0.04526 ------- 2,048 ------ 0.001609 ----- 6.200 18 -------- 0.04030 ------- 1,624 ------ 0.001276 ----- 4.917 19 -------- 0.03589 ------- 1,288 ------ 0.001012 ----- 3.899 20 -------- 0.03196 ------- 1,022 ----- 0.0008023 ----- 3.092 21 -------- 0.02846 ------- 810.1 ----- 0.0006363 ----- 2.452 22 -------- 0.02535 ------- 642.5 ----- 0.0005046 ----- 1.945 23 -------- 0.02257 ------- 509.5 ----- 0.0004001 ----- 1.542 24 -------- 0.02010 ------- 404.0 ----- 0.0003173 ----- 1.233 25 -------- 0.01790 ------- 320.4 ----- 0.0002517 ----- 0.9699 26 -------- 0.01594 ------- 254.1 ----- 0.0001996 ----- 0.7692 27 -------- 0.01420 ------- 201.5 ----- 0.0001583 ----- 0.6100 28 -------- 0.01264 ------- 159.8 ----- 0.0001255 ----- 0.4837 29 -------- 0.01126 ------- 126.7 ----- 0.00009954 ---- 0.3836 30 -------- 0.01003 ------- 100.5 ----- 0.00007894 ---- 0.3042 31 ------- 0.008928 ------- 79.70 ----- 0.00006260 ---- 0.2413 32 ------- 0.007950 ------- 63.21 ----- 0.00004964 ---- 0.1913 33 ------- 0.007080 ------- 50.13 ----- 0.00003937 ---- 0.1517 34 ------- 0.006305 ------- 39.75 ----- 0.00003122 ---- 0.1203 35 ------- 0.005615 ------- 31.52 ----- 0.00002476 --- 0.09542 36 ------- 0.005000 ------- 25.00 ----- 0.00001963 --- 0.07567 37 ------- 0.004453 ------- 19.83 ----- 0.00001557 --- 0.06001 38 ------- 0.003965 ------- 15.72 ----- 0.00001235 --- 0.04759 39 ------- 0.003531 ------- 12.47 ---- 0.000009793 --- 0.03774 40 ------- 0.003145 ------- 9.888 ---- 0.000007766 --- 0.02993 41 ------- 0.002800 ------- 7.842 ---- 0.000006159 --- 0.02374 42 ------- 0.002494 ------- 6.219 ---- 0.000004884 --- 0.01882 43 ------- 0.002221 ------- 4.932 ---- 0.000003873 --- 0.01493 44 ------- 0.001978 ------- 3.911 ---- 0.000003072 --- 0.01184 Bob . . . ________________________________________________________________________________
Date: Jun 07, 2003
Thanks you all for the comments and resources. The Circuit Cellar reference was unclear as to the mechanics of the torque measurement, but it did not involve a strain gauge. Bob confirmed my suspicion that the very strong prop shaft would lead to very little strain for the applied stress, and thus a tiny signal, full of noise. Also, hanging something on the prop shaft that could fly off, or get unbalanced, demands real engineering and care in manufacture. "First, do no harm". The engine mount is far more flexible, and thus gives a much larger output to a strain gauge. I can average out the vibration. The Blue Mountain software is quite flexible in the setup page, and a moving average is easy to do. And yes, I would like to have the instrumentation look like a turboprop, Bob! Mainly, it will help to compare propellers, but it may also give early warning of engine malfunction. Or, early warning of pilot malfunction if I try to take off at high density altitude with insufficient power. I like reassurance. Jim Foerster Jabiru J400 50% done ________________________________________________________________________________
Subject: Engine torque measurement
Date: Jun 08, 2003
I've often wondered if measuring the engine deflection in the engine mounts would be a practical method of determining torque. The idea would be to attach a position sensor to opposite cylinders, since that is a convenient location where two sensors could be placed as far from the centerline as possible and in the same plane as the crank. Engine mount deflection is not linear with applied and it probably changes significantly with time, but it might be a way to grasp a large enough signal to be practical. Common-mode effects due to G loading and thrust would presumably be cancelled. One could also use strain gages on the engine mount tubing, but the stresses are very low and because of the geometry canceling the common-mode effects would be difficult. Any comments? Gary Casey ________________________________________________________________________________
Date: Jun 08, 2003
Subject: Re: Engine torque measurement
In a message dated 6/8/2003 6:33:23 AM Mountain Daylight Time, glcasey(at)adelphia.net writes: > > I've often wondered if measuring the engine deflection in the engine mounts > would be a practical method of determining torque. The idea would be to > attach a position sensor to opposite cylinders, since that is a convenient > location where two sensors could be placed as far from the centerline as > possible and in the same plane as the crank. Engine mount deflection is not > linear with applied and it probably changes significantly with time, but it > might be a way to grasp a large enough signal to be practical. Common-mode > effects due to G loading and thrust would presumably be cancelled. One > could also use strain gages on the engine mount tubing, but the stresses are > very low and because of the geometry canceling the common-mode effects would > be difficult. Any comments? > > Gary Casey > > On all the dyno's I have run there where several ways to monitor loads. On the Stuska brake it was a fluid filled diaphram that send the fluid pressure to the 12" gauge in the control room. You could suppress most engine pulses with a inline needle valve. On the Superflow dyno's there is a electronic strain gauge and you program out the pulses with their software. All dyno's have the brake sitting on two rather large bearings and the force of the engine torque is measured by monitoring the retarded and regulated rotation force loaded by the brake. I would imagine a person could weld up a mount that incorperates a similar set up with the motor sitting a a cradle with two rubber mounted large bearing, one at each end of the engine. You can then weld a pad for the strain gauge / load diaphram and get info from that. It would need to resist thrust loads too. Just my two cents worth. Ben Haas Haas Racing Products. Jackson Hole Wy. N801BH. ________________________________________________________________________________
Subject: RE: Wire Labels
Date: Jun 08, 2003
>> >> >>I use MS word and a 6 point font to print a sheet of labels, then cut >>them up with scissors and insert the label between the shrink tubing >>and the wire. Just about any printer and plain paper works great. >>Regards, John Slade > > For an illustration of how this works, see: > > http://www.aeroelectric.com/Catalog/wiring/s817c.jpg > http://www.aeroelectric.com/Catalog/wiring/wiring.html#s816c > > Bob . . . > I recently rebuilt my instrument panel, and I used this method for wire labels. Instead of printing the labels on plain paper however, I printed them on self-stick return address labels (1/2" x 1 3/4", Avery 5267). I used one return address label for each wire label. The wire designation (a number in my case) was printed 20 times on a single label -- 5 columns of 4 rows (in 6 point font). I then cut the label between the five columns. This gave me five labels for each wire -- one for each end plus three spares. (Those of you who always do everything exactly right the first time would have no need for the spares.) I found it much easier to just wrap the self-stick label around the wire and then add the heat-shrink tubing, rather than trying to coax an uwilling plain-paper label under a piece of tubing. The self-stick label makes a fairly decent wire label all by itself, without the heat-shrink tubing. I used the labels without tubing to replace some of the "flag" type labels that I used when I originally wired the airplane. To print the labels, I used an Excel spreadsheet. By using a number for each label, I was able to prepare all the labels that I needed, without a lot of typing. I printed a whole sheet of 80 labels then cut it into strips; each strip had 20 consecutively numbered labels. It did take some fiddling to get the spreadsheet rows and columns setup to index properly with the sheet of labels. If anyone wants a copy of my spreadsheet, please contact me OFF LIST and I will send you one. Mark Nielsen RV-6; 812 hrs. ________________________________________________________________________________
Date: Jun 08, 2003
I make the labels using a pTouch style labeler. They're easy to make and stick to the wire while I slide and position the clear heat shrink into place. Works very well. Andy Morehouse Grumman AA-5 N7167L future RV builder > From: "Dean Head" <banana(at)atlantic.net> > Subject: AeroElectric-List: Wire labels > > > Hi, > I am new to the list. I am building a Cozy MK4. I have seen some wire labels > that are printed on shrink tube. Are these labels available or do you need > some sort of "printer" to make them? > Thanks > Dean Head > Cozy MK4 #1040 > > ________________________________________________________________________________
Date: Jun 08, 2003
I have heard that on the old big round engine airliners they leaned the engine by using a gage that measured the engine output. It was either torque or thrust. The engine was leaned for maximum output and just a tad beyond (lean of peak). So they knew how to do what you want to measure in the early 50s and therefore must be old technology. Might look up how they did it. If all you are interested in is a relative measurement my guess is that a few strain gages on the engine mounts should do it. If on the other hand you want a real accurate torque measurement it might be more difficult. ________________________________________________________________________________
Subject: D-Sub for Idiots
Date: Jun 08, 2003
??Is there a "D-Sub for Idiots" publication available?? I want to utilize these connectors. I think I understand where to buy pins, crimpers, and wire. I think I know how to crimp and insert pins. BUT when it comes to connector shells I am totally lost. I am currently looking at an application that tells me to use a Female connector to mate with a Male DB-25P. I find the recommenced source, Mouser, and enter DB-25P in the search window. I immediately get 30 matches to my inquiry, all different. ??What am I missing?? ________________________________________________________________________________
Subject: RE: Mom-on toggle
Date: Jun 08, 2003
Larry and Bob, I looked up the Carling switch 6FB5H-73-XA, Allied stock # 683-5121, and find that it is a ON-NONE-(0N) SPST unit. Larry, you intend to guard that switch with the hinged cover which ensures that the toggle is down unless lifted to activate. This means that the switch would be ON if I'm interpreting this correctly. Two lines up in the catalog is the Allied stock # 683-5119 which is OFF-NONE-(ON). Seems to me that this is what you want. http://www.alliedelec.com/catalog/pf.asp?FN896.pdf Jim Foerster ________________________________________________________________________________
Date: Jun 08, 2003
Here ya go with the Red cover: http://www.kilbyenterprises.com/ Tom... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Larry Bowen Subject: AeroElectric-List: Mom-on toggle I'm looking for a off-(on) toggle switch for use as a starter engage switch. Same functionality as the push button that Bob sells, but I want the form-factor of the toggle switches. This will be used with the red flip-guard. Anyone know a source? I guess one of the three-position switches would work [xx-xx-(on)], but ... - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com 2003 - The year of flight! ________________________________________________________________________________
Date: Jun 09, 2003
In a message dated 6/8/03 7:06:05 PM Central Daylight Time, tomschiff(at)attbi.com writes: > I have heard that on the old big round engine airliners they leaned the > engine by using a gage that measured the engine output. It was either > torque or thrust. The engine was leaned for maximum output and just a > tad beyond (lean of peak). So they knew how to do what you want to > measure in the early 50s and therefore must be old technology. Good Evening Tom, Those were referred to as Torquemeters and they worked by measuring the movement of the planetary ring gear in the reduction system. No reduction gearing, no torquemeter. We not only used them for normal leaning, but to check that the engine was producing normal power on every takeoff. They were every nice things to have. As to leaning lean of peak, we leaned the Turbo Compound R-3350 on the DC-7 ten percent lean of best power, advanced the spark and leaned some more. There is nothing new under the sun. Lindbergh did the same thing only he didn't have a torque meter. However, he had the next best thing. He had a fixed pitch prop. By developing the numbers on a test engine, he knew just how big a drop he needed to get the engine into the best BSFC range. The problem was the same back then as it is today, you had to get even fuel distribution to successfully run the engine on the lean side. Incidentally, I mentioned a few days ago that there has been development work done on using strain gauges on the engine mounts to develop a low cost torque meter. It would be nice to have. Al Hundere developed the use of an EGT gauge because there wasn't any reasonable way to get a low cost torque meter on our small engines. By running an engine on a test stand and noting the EGT readings at various mixtures and power settings, we can approximate what was done on the old piston airliners. The actual temperature read on the EGT gauge is basically immaterial. The important thing is what it is telling you as to how far you are from best power. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: RE: Mom-on toggle
> > >Larry and Bob, >I looked up the Carling switch 6FB5H-73-XA, Allied stock # 683-5121, and >find that it is a ON-NONE-(0N) SPST unit. Larry, you intend to guard that >switch with the hinged cover which ensures that the toggle is down unless >lifted to activate. This means that the switch would be ON if I'm >interpreting this correctly. Two lines up in the catalog is the Allied >stock # 683-5119 which is OFF-NONE-(ON). Seems to me that this is what >you want. > >http://www.alliedelec.com/catalog/pf.asp?FN896.pdf > >Jim Foerster An on-none-(on) switch simply means that the switch is a single-pole, two-position switch with no center position and electrical conductivity AVAILABLE in both extremes. Whether you hook up to both is optional hence the opportunity to wire the switch as (off)-none-on or off-none-(on) or on-none-(on) . . . this is why we don't stock the off-xxx-(on) versions of any switch . . . it just makes us stock different configurations of switch while adding no utility with respect to how the switch is used. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: D-Sub for Idiots
> >??Is there a "D-Sub for Idiots" publication available?? I want to utilize >these connectors. I think I understand where to buy pins, crimpers, and >wire. I think I know how to crimp and insert pins. BUT when it comes to >connector shells I am totally lost. > >I am currently looking at an application that tells me to use a Female >connector to mate with a Male DB-25P. I find the recommenced source, >Mouser, and enter DB-25P in the search window. I immediately get 30 >matches to my inquiry, all different. ??What am I missing?? Same problem as walking into a hardware store and asking for a "6-32 screw", they come in all sizes, shapes, materials and finishes. Check out this page from Digikey catalog: http://216.55.140.222/temp/DK119.pdf At the top of left hand column you find the Amplimite series of d-sub shells (the Diary Queen variety) and just below are the 109 series military qualified (Haggen-Das variety) connector shells. Radio Shack has 9 and 25 pin shells (I am mystified as to why they don't stock the 15 pin sizes . . . I've written to them several times to let them know that there ARE some other sizes of noteworthy utility). Looking through the Digikey catalog will give you a good (but small) overview of the variety of d-sub products available but I'm betting that the page cited above will cover your needs. See center column of: http://216.55.140.222/temp/DK131.pdf for low cost plastic back shells. If you don't need 15 pin shells and hoods, RS is an option for local off the shelf parts . . . buy the crimp variety and throw away the pins that come with them in favor of the machined pins like those at the bottom left corner of page 119 or from our website at http://www.aeroelectric.com/Catalog/BCcatalog.html Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Smoking a fusible link
Bob, When you did your experiments with fusible links, did you get any numbers on how many amps it takes to actually melt a fusible link? For example, if I use a 22 or 20 awg wire for the fuse link, I can look on the wire chart and tell how many amps they can safely carry without overheating, but at what minimum amperage will they physically melt through and open the circuit? I'm just interested in a ballpark figure, like 30 A or 100 A or whatever the case may be. Assume free air (not in a bundle). Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D paint prep... The best thing to hit the internet in years - Juno SpeedBand! Surf the web up to FIVE TIMES FASTER! ________________________________________________________________________________
Date: Jun 09, 2003
From: Scott Bilinski <bilinski@kyocera-wireless.com>
FWIW.......I know YAK 52's have a % power gage. > >In a message dated 6/8/03 7:06:05 PM Central Daylight Time, >tomschiff(at)attbi.com writes: > >> I have heard that on the old big round engine airliners they leaned the >> engine by using a gage that measured the engine output. It was either >> torque or thrust. The engine was leaned for maximum output and just a >> tad beyond (lean of peak). So they knew how to do what you want to >> measure in the early 50s and therefore must be old technology. > >Good Evening Tom, > >Those were referred to as Torquemeters and they worked by measuring the >movement of the planetary ring gear in the reduction system. No reduction >gearing, >no torquemeter. We not only used them for normal leaning, but to check that >the engine was producing normal power on every takeoff. They were every nice >things to have. As to leaning lean of peak, we leaned the Turbo Compound >R-3350 on the DC-7 ten percent lean of best power, advanced the spark and >leaned >some more. > >There is nothing new under the sun. Lindbergh did the same thing only he >didn't have a torque meter. However, he had the next best thing. He had a >fixed >pitch prop. By developing the numbers on a test engine, he knew just how big >a drop he needed to get the engine into the best BSFC range. > >The problem was the same back then as it is today, you had to get even fuel >distribution to successfully run the engine on the lean side. > >Incidentally, I mentioned a few days ago that there has been development work >done on using strain gauges on the engine mounts to develop a low cost torque >meter. It would be nice to have. > >Al Hundere developed the use of an EGT gauge because there wasn't any >reasonable way to get a low cost torque meter on our small engines. By >running an >engine on a test stand and noting the EGT readings at various mixtures and >power >settings, we can approximate what was done on the old piston airliners. The >actual temperature read on the EGT gauge is basically immaterial. The >important thing is what it is telling you as to how far you are from best >power. > >Happy Skies, > >Old Bob > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Jun 09, 2003
<> Yes, but it is not tied to the M14P's planetary. It's just a tach, percent of max RPM. Russian training thinking. And you can't lean it either. Dan ________________________________________________________________________________
Date: Jun 09, 2003
In a message dated 6/9/03 9:03:52 AM Central Daylight Time, bilinski@kyocera-wireless.com writes: > FWIW.......I know YAK 52's have a % power gage Good Morning Scott, Any idea how it works? I have no familiarity with the engine used in the YAK 52. Does it have a built in gear reduction unit? If so, a torque measuring device may be incorporated. However, RPM is also required to get a reading of the power being developed by the engine. I imagine such a combination instrument could be built using only mechanical components, but with electronic devices, it should be a no brainer. Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 09, 2003
From: Philip Hildebrand <phildebrand(at)pritchardindustrial.com>
Subject: Avionics switch
In spite of Bob's recommendations, I am planning on installing an avionics switch due to the cold weather operations in Canada. Other than the avionics switch I am wiring to Z14 with a 60 amp alternator and a 20 amp alternator. Loading for each avionics bus will be well under 20 amps. - Would a switch rated 20 amps be the right way to go or should I add a relay? - If I need a relay, would the Perfect Cube SSR from Eric at Perihelion Design be a good choice for this application? Philip Hildebrand Email: phildebrand(at)pritchardindustrial.com Winnipeg, Canada ________________________________________________________________________________
Subject: Oil Level Switch
Date: Jun 09, 2003
I am planning to have a small container to catch the oil draining from the turbocharger on my Mazda RX-7 Rotary engine (which is converted for aircraft use on the Mustang II kitplane that I am building) and will use an electric oil pump to transfer the oil from the container back to the engine crankcase. This is necessary because my aftermarket turbo is mounted too low for a gravity drain-back. The electric pump only needs to operate long enough to pump oil out of the container when it gets full and stop when the container is empty. What I am looking for is some sort of a sensor/switch that will detect when the oil level is at the top of the container to turn the pump on, and will detect when the oil level is at the bottom of the container to turn the pump off. I have seen several devices/methods to turn a switch on when the oil gets too low, but what I need is just the opposite and it needs to detect/switch at maximum and minimum levels. Does anyone have suggestions or ideas regarding an oil level sensor with a switch that works as described above? Oil Level Switch I am planning to have a small container to catch the oil draining from the turbocharger on my Mazda RX-7 Rotary engine (which is converted for aircraft use on the Mustang II kitplane that I am building) and will use an electric oil pump to transfer the oil from the container back to the engine crankcase. This is necessary because my aftermarket turbo is mounted too low for a gravity drain-back. The electric pump only needs to operate long enough to pump oil out of the container when it gets full and stop when the container is empty. What I am looking for is some sort of a sensor/switch that will detect when the oil level is at the top of the container to turn the pump on, and will detect when the oil level is at the bottom of the container to turn the pump off. I have seen several devices/methods to turn a switch on when the oil gets too low, but what I need is just the opposite and it needs to detect/switch at maximum and minimum levels. Does anyone have suggestions or ideas regarding an oil level sensor with a switch that works as described above? ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: Avionics switch
Philip, What about cold weather operations requires the use of an avionics master? Just curious. How cold are you talking about? I would think a 20A switch would be fine. Using relays adds to the parts count which generally has a negative effect on reliability. I would only use relays in a few applications. These include where the switch I want to use (for form factor reasons) isn't up to the electrical requirements for the application. Or, where the use of a relay allows me to save on the use of a bunch of heavy wire. Or where I can avoid running long runs of unprotected wire. None of these seem relevant here. Regards, Matt Prather N34RD > > > In spite of Bob's recommendations, I am planning on installing > an avionics switch due to the cold weather operations in Canada. Other > than the avionics switch I am wiring to Z14 with a 60 amp alternator and > a 20 amp alternator. Loading for each avionics bus will be well under > 20 amps. > - Would a switch rated 20 amps be the right way to go or should I > add a relay? > - If I need a relay, would the Perfect Cube SSR from Eric at > Perihelion Design be a good choice for this application? > > > Philip Hildebrand > Email: phildebrand(at)pritchardindustrial.com > Winnipeg, Canada > ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: Oil Level Switch
Date: Jun 09, 2003
----- Original Message ----- From: "Rogers, Bob J." <BRogers(at)fdic.gov> Subject: AeroElectric-List: Oil Level Switch > > I am planning to have a small container to catch the oil draining from the > turbocharger on my Mazda RX-7 Rotary engine (which is converted for aircraft > use on the Mustang II kitplane that I am building) and will use an electric > oil pump to transfer the oil from the container back to the engine > crankcase. This is necessary because my aftermarket turbo is mounted too > low for a gravity drain-back. The electric pump only needs to operate long > enough to pump oil out of the container when it gets full and stop when the > container is empty. > > What I am looking for is some sort of a sensor/switch that will detect when > the oil level is at the top of the container to turn the pump on, and will > detect when the oil level is at the bottom of the container to turn the pump > off. I have seen several devices/methods to turn a switch on when the oil > gets too low, but what I need is just the opposite and it needs to > detect/switch at maximum and minimum levels. > > Does anyone have suggestions or ideas regarding an oil level sensor with a > switch that works as described above? > Hi Bob, I fly a RV-6A with a Rotary 13B engine without a turbo at this time, but I am planning on installing one and I have the same problem. Here are my thoughts on the scavenger pump operation. 1. If the drain container fills up and is not pumped down, it is very likely that the oil will back up to the turbo shaft, push past the seals and cause smoking exhaust, if this continues sufficiently long, I would imagine that the shaft would eventually "coke" from the overheated/burnt oil on the shaft and may require a rebuild of the turbocharger. Not something you want to have happen very often. 2. If the drain container remains empty (all oil always pumped out as soon as it comes in) then depending on the size of your drain container, you have a lot (continuos?) operation of the pump which would like shorten its operational life (maybe). Since I fly with an electric fuel pump on at all times and that pump has shown no signs of wear after 200 hours of flight time and close to 260 engine operation time, I think the simpler approach might be to have your pump operate at all times the engine is operating. An oil level switch/detector is simply another part that can fail. Fewer parts = less likely of failure of the system - all other things being equal. Here's two things you could do to provide an increased comfort level. I presume you will have a fuse or circuit breaker in the scavenger pump power line. Should either blow/trip then you have a pump problem indication and you take corrective action. Also, you might rig a small LED in a visible spot on your instrument panel powered off DC power to the pump terminal. Should power fail to get to the pump terminal or should the pump short out the LED will go out (of course in the latter case your fuse or circuit breaker should also blow/pop giving you a backup indication). Then there is always the visual indication of your exhaust making like an airshow aircraft trailing smoke {:>) I know this doesn't answer your specific question, but thought I would throw it in for your consideration. Be very interested in hearing how your Mustang II does with a rotary. Best Regards Ed Anderson RV-6A N494BW 200+ Rotary Hours Matthews, NC eanderson(at)carolina.rr.com ________________________________________________________________________________
Date: Jun 09, 2003
There are times when the airplane is parked outside with the tanis heater warming the engine but the cabin could be down to -25C. Further to my initial question, should the avionics bus be protected by a circuit breaker, or are the individual breakers for the radio, HSI, etc sufficient? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Subject: Re: AeroElectric-List: Avionics switch Philip, What about cold weather operations requires the use of an avionics master? Just curious. How cold are you talking about? I would think a 20A switch would be fine. Using relays adds to the parts count which generally has a negative effect on reliability. I would only use relays in a few applications. These include where the switch I want to use (for form factor reasons) isn't up to the electrical requirements for the application. Or, where the use of a relay allows me to save on the use of a bunch of heavy wire. Or where I can avoid running long runs of unprotected wire. None of these seem relevant here. Regards, Matt Prather N34RD > > > In spite of Bob's recommendations, I am planning on installing > an avionics switch due to the cold weather operations in Canada. Other > than the avionics switch I am wiring to Z14 with a 60 amp alternator and > a 20 amp alternator. Loading for each avionics bus will be well under > 20 amps. > - Would a switch rated 20 amps be the right way to go or should I > add a relay? > - If I need a relay, would the Perfect Cube SSR from Eric at > Perihelion Design be a good choice for this application? > > > Philip Hildebrand > Email: phildebrand(at)pritchardindustrial.com > Winnipeg, Canada > ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Date: Jun 09, 2003
Bob, Thanks for your response. > > I wouldn't make any special effort to buy a super-whizzy coax > connector for an OBAM project . . . > > Now, if it's a taxpayer funded military project, then the > sky's the limit. You can go for gold plated too . . . So no special connectors. And no heatshrink, no nothing ? thanks, Gilles ________________________________________________________________________________
From: "Steve Richard" <steve(at)oasissolutions.com>
Subject: Cable Tie Mounts
Date: Jun 09, 2003
I'm building a fiberglass airplane. I'd like to use cable ties to hold most of the wire. What is everyone using for cable tie mounts? Lanciar uses click-bond at $1.65 each. Panduit has some for 90 cents each. Both appear easy to install but expensive. Steve Richard steve(at)oasissolutions.com ________________________________________________________________________________
Subject: Comm antenna port to handheld questions
Date: Jun 09, 2003
Hi Bob and all, I'm considering the building of a 'cockpit port to comm antenna' for a portable VHF. Of course several questions arose. 1) What do I use to solder brass shim stock ? Soldering iron, small torch ? And are there any hints and tips I should know before launching into the real thing ? (except what's already in Bob's Shop Note). 2) How do I solder the shield braid to the shim stock ? Just as if it were a bunch of wires ? 3) I was unable to locate a radio Shack 174-248 jack in this part of the world. Any one around know a source for an equivalent part in Europe ? Thanks Gilles ________________________________________________________________________________
Date: Jun 09, 2003
Hi Steve I use the cheepo adhesive stick on type that don't stick very well. If you put a dot of epoxy in the center when you stick them on, the adhesive holds them in place until the epoxy cures and then they are very secure. Tom -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve Richard Subject: AeroElectric-List: Cable Tie Mounts I'm building a fiberglass airplane. I'd like to use cable ties to hold most of the wire. What is everyone using for cable tie mounts? Lanciar uses click-bond at $1.65 each. Panduit has some for 90 cents each. Both appear easy to install but expensive. Steve Richard steve(at)oasissolutions.com ________________________________________________________________________________
Date: Jun 09, 2003
The stick on types will not hold (long term) if there is a constant pull/tug/tension on the wire. I use them only when I want to keep a wire from being floppy/sagging etc. > >Hi Steve > >I use the cheepo adhesive stick on type that don't stick very well. If >you put a dot of epoxy in the center when you stick them on, the >adhesive holds them in place until the epoxy cures and then they are >very secure. > >Tom > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve >Richard >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Cable Tie Mounts > > > >I'm building a fiberglass airplane. I'd like to use cable ties to hold >most >of the wire. What is everyone using for cable tie mounts? Lanciar uses >click-bond at $1.65 each. Panduit has some for 90 cents each. Both >appear >easy to install but expensive. > >Steve Richard >steve(at)oasissolutions.com > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: Re: Cable Tie Mounts
Date: Jun 09, 2003
I have been using varios panduit mounts. part#s TM1 TM2. I sand the back, put some Hysol on them and use a pop rivit to hold them while they dry. Ron Raby Lancair ES ----- Original Message ----- From: "Steve Richard" <steve(at)oasissolutions.com> Subject: AeroElectric-List: Cable Tie Mounts > > I'm building a fiberglass airplane. I'd like to use cable ties to hold most > of the wire. What is everyone using for cable tie mounts? Lanciar uses > click-bond at $1.65 each. Panduit has some for 90 cents each. Both appear > easy to install but expensive. > > Steve Richard > steve(at)oasissolutions.com > > ________________________________________________________________________________
Date: Jun 09, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
BobsV35B(at)aol.com wrote: > >In a message dated 6/8/03 7:06:05 PM Central Daylight Time, >tomschiff(at)attbi.com writes: > > > >>I have heard that on the old big round engine airliners they leaned the >>engine by using a gage that measured the engine output. It was either >>torque or thrust. The engine was leaned for maximum output and just a >>tad beyond (lean of peak). So they knew how to do what you want to >>measure in the early 50s and therefore must be old technology. >> >> > >Good Evening Tom, > >Those were referred to as Torquemeters and they worked by measuring the >movement of the planetary ring gear in the reduction system. No reduction gearing, >no torquemeter. We not only used them for normal leaning, but to check that >the engine was producing normal power on every takeoff. They were every nice >things to have. As to leaning lean of peak, we leaned the Turbo Compound >R-3350 on the DC-7 ten percent lean of best power, advanced the spark and leaned >some more. > > > >Happy Skies, > >Old Bob > Can you elaborate on the 'movement of the planetary ring gear' ? Was the thrust of a helical cut gear being measured, or ???? This might have application in alternative engines with reduction drives. Thanks, Charlie ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Marker Beacon Antenna Lead
I have an Apollo SL-10 intercom with a built in Marker Beacon. Unlike other avionics with antennas (Comm or Nav) the SL-10 does not have any sort of BNC connection for an antenna. The SL-10 antenna connection is merely one pin in a fully loaded connector. This leads me to believe that RG-400 or RG-58 cable is unnecessary. The installation manual says nothing about antenna leads. I intend to have a simple wire antenna in the wing tip for the marker beacon. What sort of antenna lead do I need? Will just a strand of 22AWG wire work, or should it be some sort of shielded wire? Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Jun 09, 2003
In a message dated 6/9/03 2:12:26 PM Central Daylight Time, cengland(at)netdoor.com writes: > Can you elaborate on the 'movement of the planetary ring gear' ? Was the > thrust of a helical cut gear being measured, or ???? > > This might have application in alternative engines with reduction drives. > > Good Afternoon Charlie, I can't tell you precisely, but that sounds about right. The outer ring gear had helical cuts in the outer periphery such that it would move slightly fore and aft as the torque was applied. The ring gear pushed on a series of pistons which then supplied a flow of oil to the instrument. That was calibrated to be equivalent to the calculated Brake Mean Effective Pressure which should have been developed in the cylinders to provide that amount of torque. By using a constant based on the displacement of the engine and applying the RPM to the equation, the horsepower being developed could be determined. I know that regular oil pressure was supplied to the pistons to be used as a transfer medium. I have no idea how the pressure being developed by the movement of the ring gear was isolated from the engine oil pressure. I guess we aviators didn't need to know that detail! Happy Skies, Old Bob ________________________________________________________________________________
Date: Jun 09, 2003
If your load is pushing 20 amps or more, I would look into a SSR. I personally used the powerlink JR and a SuperDiode from Eric to feed the avionics/ess buss on my airplane. To back this up, I would suggest added an ALT FEED switch directly from the battery. Two switches, a diode, and a SSR should have you sitting nice if you deem you really need the av master. I do highly recommend making it an ESS buss with the ALT FEED if you do find a need for the av master. I'm not sure why you think the cold warrants the master, but it is your plane, and if you find it necessary, my only other advise is to be sure to back it up (ie, the alt feed). --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Philip Hildebrand Subject: AeroElectric-List: Avionics switch In spite of Bob's recommendations, I am planning on installing an avionics switch due to the cold weather operations in Canada. Other than the avionics switch I am wiring to Z14 with a 60 amp alternator and a 20 amp alternator. Loading for each avionics bus will be well under 20 amps. - Would a switch rated 20 amps be the right way to go or should I add a relay? - If I need a relay, would the Perfect Cube SSR from Eric at Perihelion Design be a good choice for this application? Philip Hildebrand Email: phildebrand(at)pritchardindustrial.com Winnipeg, Canada ________________________________________________________________________________
Date: Jun 09, 2003
Individual should be fine, as long as you keep the run from the ssr/diode to the buss short. The alt feed directly from the battery buss should be fused though. --- Shannon Knoepflein <---> kycshann(at)kyol.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Philip Hildebrand Subject: RE: AeroElectric-List: Avionics switch There are times when the airplane is parked outside with the tanis heater warming the engine but the cabin could be down to -25C. Further to my initial question, should the avionics bus be protected by a circuit breaker, or are the individual breakers for the radio, HSI, etc sufficient? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Subject: Re: AeroElectric-List: Avionics switch Philip, What about cold weather operations requires the use of an avionics master? Just curious. How cold are you talking about? I would think a 20A switch would be fine. Using relays adds to the parts count which generally has a negative effect on reliability. I would only use relays in a few applications. These include where the switch I want to use (for form factor reasons) isn't up to the electrical requirements for the application. Or, where the use of a relay allows me to save on the use of a bunch of heavy wire. Or where I can avoid running long runs of unprotected wire. None of these seem relevant here. Regards, Matt Prather N34RD > > > In spite of Bob's recommendations, I am planning on installing > an avionics switch due to the cold weather operations in Canada. Other > than the avionics switch I am wiring to Z14 with a 60 amp alternator and > a 20 amp alternator. Loading for each avionics bus will be well under > 20 amps. > - Would a switch rated 20 amps be the right way to go or should I > add a relay? > - If I need a relay, would the Perfect Cube SSR from Eric at > Perihelion Design be a good choice for this application? > > > Philip Hildebrand > Email: phildebrand(at)pritchardindustrial.com > Winnipeg, Canada > ________________________________________________________________________________
Date: Jun 09, 2003
The stick on type just don't hold up. I remove the adhesive from the back, drill several small holes around the edge of the base, then 5 minute epoxy them in place with a strip of duct tape over them to hold in place. Without the small holes to give some tooth for the epoxy they can pull off since the epoxy does not bond well to the plastic. Dave Chalmers Redmond, WA -----Original Message----- From: Steve Richard [mailto:steve(at)oasissolutions.com] Subject: AeroElectric-List: Cable Tie Mounts I'm building a fiberglass airplane. I'd like to use cable ties to hold most of the wire. What is everyone using for cable tie mounts? Lanciar uses click-bond at $1.65 each. Panduit has some for 90 cents each. Both appear easy to install but expensive. Steve Richard steve(at)oasissolutions.com ________________________________________________________________________________
Subject: Magnetic Coupler - Tach
Date: Jun 09, 2003
A friend of mine is trying to simplify his Subaru tach setup (two ignitions) and was hoping to purchase a magnetic coupler that would surround the main spark park feed wire on the engine and then connect to his tach instrument, but hasn't been able to find someone that sells the coupler. Does any one know where you can get one? Thanks! Don Honabach ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: Magnetic Coupler - Tach
There are simple magnetic pickups that count flywheel teeth. Simple as dirt, and doesn't connect to anything ignition. Dan ________________________________________________________________________________
Date: Jan 02, 2004
Here's an idea Iuse: take a 1/4 rod and lay it down on your table, cover with saran, then with a piece of peel ply. Wet out scrapes of cloth (5-6 layers) on the rod, another sheet of saran and put a piece of soft foam over it all to force it down and let it harden. After it's hard, remove the peel ply and the rod and slice the layup on a bandsaw crosswise into 1/2 pieces. When you have to attach something like wires, flox one of these pieces where you want it and then double tie-wrap the wire to the holder piece. For attaching things like vacuum hoses, do the same thing but lay out two 1/4 inch rods and make your layups across the two rods. When hard, they will make a nice little inverted W that you can use a couple of tiewraps to secure a hose too. --Kent A. Steve Richard wrote: > >I'm building a fiberglass airplane. I'd like to use cable ties to hold most >of the wire. What is everyone using for cable tie mounts? > ________________________________________________________________________________
Date: Jun 09, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
><Gilles.Thesee@ac-grenoble.fr> > > >Bob, >Thanks for your response. > > > > I wouldn't make any special effort to buy a super-whizzy coax > > connector for an OBAM project . . . > > > > Now, if it's a taxpayer funded military project, then the > > sky's the limit. You can go for gold plated too . . . > >So no special connectors. And no heatshrink, no nothing ? >thanks, Do you have a connector that might be exposed to splash or rain? If not, any BNC connector will be find as-supplied Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
> >I am planning to have a small container to catch the oil draining from the >turbocharger on my Mazda RX-7 Rotary engine (which is converted for aircraft >use on the Mustang II kitplane that I am building) and will use an electric >oil pump to transfer the oil from the container back to the engine >crankcase. This is necessary because my aftermarket turbo is mounted too >low for a gravity drain-back. The electric pump only needs to operate long >enough to pump oil out of the container when it gets full and stop when the >container is empty. > >What I am looking for is some sort of a sensor/switch that will detect when >the oil level is at the top of the container to turn the pump on, and will >detect when the oil level is at the bottom of the container to turn the pump >off. I have seen several devices/methods to turn a switch on when the oil >gets too low, but what I need is just the opposite and it needs to >detect/switch at maximum and minimum levels. > >Does anyone have suggestions or ideas regarding an oil level sensor with a >switch that works as described above? Last time I took on a similar project, it turned out to be more practical to just put a timer on the pump. Run it for so many minutes out of every hour. No switches to procure, calibrate, maintain or fail to work. Figure out what the max oil flow rate is to be expected. Triple or quadruple that number. I suspect you can pump that amount of liquid in a minute or so with even a small pump. I designed the timer so that it ran the prescribed period of time at first power-up and then once per hour after that at long as power stayed on. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
> > > In spite of Bob's recommendations, I am planning on installing >an avionics switch due to the cold weather operations in Canada. Other >than the avionics switch I am wiring to Z14 with a 60 amp alternator and >a 20 amp alternator. Loading for each avionics bus will be well under >20 amps. How much under 20A? If you do a load analysis of RUNNING LOAD (not transmit loads) for each bus, you should find that ANY switch will be just fine. The switch's ratings are most critical for making and breaking a load, they CARRY several times rated current without breathing hard. It's unlikely that you'll have any avionics bus that begins to work the ordinary toggles switch beyond it's capabilities. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
> > > There are times when the airplane is parked outside with the >tanis heater warming the engine but the cabin could be down to -25C. > Further to my initial question, should the avionics bus be >protected by a circuit breaker, or are the individual breakers for the >radio, HSI, etc sufficient? What is the "simple idea" that would prompt such a decision? If there is a need for "protection" other than the protective devices usually applied to a power distribution system, there should be a reason based upon the physics of system operation that suggest value in adding another protective device. Adding parts increases cost of ownership, weight, complexity and reduces system reliability. If there's a reason for doing it, it's always a simple one. Bob . . . ________________________________________________________________________________
Date: Jun 09, 2003
> >So no special connectors. And no heatshrink, no nothing ? > >thanks, > > Do you have a connector that might be exposed to splash > or rain? If not, any BNC connector will be find as-supplied > > Bob . . . No rain expected. Except maybe for the XPDR antenna in the rear lower fairing. There are the rudder bellcrank openings, and rain or wash water COULD get into them. Cheers, Gilles ________________________________________________________________________________
From: "Werner Schneider" <wernerschneider(at)compuserve.com>
Subject: Re: VOR/GPS Indicator Relay Assembly
Date: Jun 09, 2003
Hello Bob, I'm finally there were I can get use of your design from last August, there are two major questions, I can only get easy hold of the G5V-2 relais not the ultra sensitive one does this cause any problems? Second question, is there a wiring diagramm for the switcher, as I can not see out of my diagram for the GI-106A what the pins 19,18,17,16,15 on the indicator to the 1 on the receivers are for (shields?). There is the anunciator flags pins, are they feeded by the switch which is feeding the power for the relais (double contacts?) Many thanks for your help Werner (trying to finish the panel wiring) ________________________________________________________________________________
Date: Jun 09, 2003
They come attached to timing lights for your car. > >A friend of mine is trying to simplify his Subaru tach setup (two >ignitions) and was hoping to purchase a magnetic coupler that would >surround the main spark park feed wire on the engine and then connect to >his tach instrument, but hasn't been able to find someone that sells the >coupler. Does any one know where you can get one? > >Thanks! >Don Honabach > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Date: Jun 09, 2003
Ron, Where did you buy your mounts? Telephone number? I've tried Greybar, but they don't carry in-stock. Steve Richard steve(at)oasissolutions.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Ron Raby Subject: Re: AeroElectric-List: Cable Tie Mounts I have been using varios panduit mounts. part#s TM1 TM2. I sand the back, put some Hysol on them and use a pop rivit to hold them while they dry. Ron Raby Lancair ES ----- Original Message ----- From: "Steve Richard" <steve(at)oasissolutions.com> Subject: AeroElectric-List: Cable Tie Mounts > > I'm building a fiberglass airplane. I'd like to use cable ties to hold most > of the wire. What is everyone using for cable tie mounts? Lanciar uses > click-bond at $1.65 each. Panduit has some for 90 cents each. Both appear > easy to install but expensive. > > Steve Richard > steve(at)oasissolutions.com > > ________________________________________________________________________________
From: "Reed, Britt/FSC Salt Lake" <BReed(at)slcrail.com>
Date: Jun 09, 2003
The Mini Tach ($30 option) on a twin cylinder kohler just uses a lead wrapped abot 20 times on the plug wire - -----Original Message----- From: Scott Bilinski [mailto:bilinski@kyocera-wireless.com] Subject: Re: AeroElectric-List: Magnetic Coupler - Tach <bilinski@kyocera-wireless.com> They come attached to timing lights for your car. > >A friend of mine is trying to simplify his Subaru tach setup (two >ignitions) and was hoping to purchase a magnetic coupler that would >surround the main spark park feed wire on the engine and then connect to >his tach instrument, but hasn't been able to find someone that sells the >coupler. Does any one know where you can get one? > >Thanks! >Don Honabach > > _ ________________________________________________________________________________
Date: Jun 09, 2003
In a message dated 6/9/2003 2:54:33 PM Mountain Daylight Time, bob.nuckolls(at)cox.net writes: > > > > > >I am planning to have a small container to catch the oil draining from the > >turbocharger on my Mazda RX-7 Rotary engine (which is converted for > aircraft > >use on the Mustang II kitplane that I am building) and will use an electric > >oil pump to transfer the oil from the container back to the engine > >crankcase. This is necessary because my aftermarket turbo is mounted too > >low for a gravity drain-back. The electric pump only needs to operate long > >enough to pump oil out of the container when it gets full and stop when the > >container is empty. > > > >What I am looking for is some sort of a sensor/switch that will detect when > >the oil level is at the top of the container to turn the pump on, and will > >detect when the oil level is at the bottom of the container to turn the > pump > >off. I have seen several devices/methods to turn a switch on when the oil > >gets too low, but what I need is just the opposite and it needs to > >detect/switch at maximum and minimum levels. > > > >Does anyone have suggestions or ideas regarding an oil level sensor with a > >switch that works as described above? > > Last time I took on a similar Guys, There is way more to this oil return from the turbo then what you are thinking. First, the oil flow rate is way higher through a turbo. Most have a 3/16 to 1/4" line feeding them so figure a gallon a minute. Second, the oil coming out of a turbo that is spinning 100,000 to 130,000 rpm's a minute is not a liquid. it is a foamy state and it needs to sit in a tank for some time to de emulsify so it can be pumped. Third, it is coming out of the turbo bearing housing at twice the oil temp then in your engine. You can figure oil temp out of a turbo to be in the 300 degree range. Now the real problem is finding a pump that can pump a foamy substance that is 300 degrees and at least at one gallon a minute and is electric powered. I researched this a few years back and couldn't come up with a pump. I would love to see your specs for all your componants. Of course this is just my opinion and thats coming from a guy who is stuffing an all aluminum 349 cu in. stroker V-8 Ford into my Zenith 801. Ben Haas N801BH. ________________________________________________________________________________
Subject: wire labels
Date: Jun 09, 2003
From: "iflyaa5" <iflyaa5(at)attbi.com> Subject: AeroElectric-List: Re: Wire labels Andy, I tried the pTouch labels with heat shrink but found that being thermal they would often turn black when shrinking the tubing. Maybe my heat gun was too hot but I got frustrated after several attempts and gave up. Did you have this problem, what is your secret? Mark Means I make the labels using a pTouch style labeler. They're easy to make and stick to the wire while I slide and position the clear heat shrink into place. Works very well. Andy Morehouse Grumman AA-5 N7167L future RV builder ________________________________________________________________________________
Date: Jun 09, 2003
I didn't see the option you pointed out before I ordered. Thanks. I hope the ones originally discussed will work. I had planned on not wiring the on position, just the (on) position. Won't this result in the same functionality? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com James Foerster said: > > > Larry and Bob, > I looked up the Carling switch 6FB5H-73-XA, Allied stock # 683-5121, and > find that it is a ON-NONE-(0N) SPST unit. Larry, you intend to guard that > switch with the hinged cover which ensures that the toggle is down unless > lifted to activate. This means that the switch would be ON if I'm > interpreting this correctly. Two lines up in the catalog is the Allied > stock # 683-5119 which is OFF-NONE-(ON). Seems to me that this is what > you want. > > http://www.alliedelec.com/catalog/pf.asp?FN896.pdf > > Jim Foerster ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Mom-on toggle
Thanks. I already have the cover from Wicks. I had changed my switching layout slightly and was just hunting for the elusive off-(on) switch. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com Tom... said: > > Here ya go with the Red cover: > > http://www.kilbyenterprises.com/ > > Tom... > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Larry > Bowen > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Mom-on toggle > > > > > I'm looking for a off-(on) toggle switch for use as a starter engage > switch. Same functionality as the push button that Bob sells, but I > want the form-factor of the toggle switches. This will be used with the > red flip-guard. Anyone know a source? I guess one of the > three-position switches would work [xx-xx-(on)], but ... > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > 2003 - The year of flight! ________________________________________________________________________________
Date: Jun 09, 2003
Subject: Re: wire labels
Must be too much heat. I also used the PTouch for all my labels and had no problem. I didn't use a regular heatgun, but a MonoCoat heatgun left over from my RC days. R ----- Original Message ----- From: "Mark Means" <rgvelocity(at)lmf.net> Subject: AeroElectric-List: wire labels > > From: "iflyaa5" <iflyaa5(at)attbi.com> > Subject: AeroElectric-List: Re: Wire labels > > Andy, > > I tried the pTouch labels with heat shrink but found that being thermal they would often turn black when shrinking the tubing. Maybe my heat gun was too hot but I got frustrated after several attempts and gave up. Did you have this problem, what is your secret? > > Mark Means > > > I make the labels using a pTouch style labeler. They're easy to make and > stick to the wire while I slide and position the clear heat shrink into > place. Works very well. > > Andy Morehouse > Grumman AA-5 N7167L > future RV builder > > ________________________________________________________________________________
Date: Jun 09, 2003
BobsV35B(at)aol.com wrote: > >In a message dated 6/9/03 2:12:26 PM Central Daylight Time, >cengland(at)netdoor.com writes: > > > >>Can you elaborate on the 'movement of the planetary ring gear' ? Was the >>thrust of a helical cut gear being measured, or ???? >> >>This might have application in alternative engines with reduction drives. >> >> >> >> > >Good Afternoon Charlie, > >I can't tell you precisely, but that sounds about right. > >The outer ring gear had helical cuts in the outer periphery such that it >would move slightly fore and aft as the torque was applied. The ring gear pushed >on a series of pistons which then supplied a flow of oil to the instrument. >That was calibrated to be equivalent to the calculated Brake Mean Effective >Pressure which should have been developed in the cylinders to provide that amount >of torque. By using a constant based on the displacement of the engine and >applying the RPM to the equation, the horsepower being developed could be >determined. > >I know that regular oil pressure was supplied to the pistons to be used as a >transfer medium. I have no idea how the pressure being developed by the >movement of the ring gear was isolated from the engine oil pressure. I guess we >aviators didn't need to know that detail! > >Happy Skies, > >Old Bob > >Thanks, Bob > Charlie ________________________________________________________________________________
Date: Jun 10, 2003
I think you have to use the laminated labels, not the paper ones, for fairly good immunity to heat.. I tested the paper ones in my oven, they totally blacked out... I haven't tried the laminated ones yet though. -John R. RSwanson wrote: > >Must be too much heat. I also used the PTouch for all my labels and had no >problem. I didn't use a regular heatgun, but a MonoCoat heatgun left over >from my RC days. >R > >----- Original Message ----- >From: "Mark Means" <rgvelocity(at)lmf.net> >To: >Subject: AeroElectric-List: wire labels > > > > >> >> > > > >>From: "iflyaa5" <iflyaa5(at)attbi.com> >>Subject: AeroElectric-List: Re: Wire labels >> >>Andy, >> >>I tried the pTouch labels with heat shrink but found that being thermal >> >> >they would often turn black when shrinking the tubing. Maybe my heat gun >was too hot but I got frustrated after several attempts and gave up. Did >you have this problem, what is your secret? > > >>Mark Means >> >> >>I make the labels using a pTouch style labeler. They're easy to make and >>stick to the wire while I slide and position the clear heat shrink into >>place. Works very well. >> >>Andy Morehouse >>Grumman AA-5 N7167L >>future RV builder >> >> >> >> > > > > ________________________________________________________________________________
Date: Jun 10, 2003
Yes, I didn't think about that. I had forgotten that they also make paper labels. Never even considered using them, all mine are laminated. R ----- Original Message ----- From: "John Rourke" <jrourke@allied-computer.com> Subject: Re: AeroElectric-List: wire labels <jrourke@allied-computer.com> > > I think you have to use the laminated labels, not the paper ones, for > fairly good immunity to heat.. I tested the paper ones in my oven, they > totally blacked out... I haven't tried the laminated ones yet though. > > -John R. > > RSwanson wrote: > > > > >Must be too much heat. I also used the PTouch for all my labels and had no > >problem. I didn't use a regular heatgun, but a MonoCoat heatgun left over > >from my RC days. > >R > > > >----- Original Message ----- > >From: "Mark Means" <rgvelocity(at)lmf.net> > >To: > >Subject: AeroElectric-List: wire labels > > > > > > > > > >> > >> > > > > > > > >>From: "iflyaa5" <iflyaa5(at)attbi.com> > >>Subject: AeroElectric-List: Re: Wire labels > >> > >>Andy, > >> > >>I tried the pTouch labels with heat shrink but found that being thermal > >> > >> > >they would often turn black when shrinking the tubing. Maybe my heat gun > >was too hot but I got frustrated after several attempts and gave up. Did > >you have this problem, what is your secret? > > > > > >>Mark Means > >> > >> > >>I make the labels using a pTouch style labeler. They're easy to make and > >>stick to the wire while I slide and position the clear heat shrink into > >>place. Works very well. > >> > >>Andy Morehouse > >>Grumman AA-5 N7167L > >>future RV builder > >> > >> > >> > >> > > > > > > > > > > ________________________________________________________________________________
Subject: Oil temp switch
Date: Jun 10, 2003
HI Bob and all, I know that there are vicarious NO and NC temperature dependant switches available, I was thinking of placing one on my sump (with a normal oil temp pickup as well) in various temp ratings. What epoxy would allow me to glue this to the sump? Thinking of driving a overtemp buzzer and LED on a separate circuit to the normal oil temp circuit. Ian ________________________________________________________________________________
Subject: Backup power source for ignition?
Date: Jun 10, 2003
Hi Gang, I've been rewiring my RV6A that has a Chevy 4.3L V6 with dual point ignition. I have completed the Always Hot Battery Buss with 7 amp ATC fuses running to each ignition switch then to the coils. The ignition switches are about 2 inches from the main bus and I wondered about the feasability of running a wire from the main bus to the ignition switches for a redundant power supply. With the fuses being unaccessable in flight located in the tail cone on the battery box if the fuses both blow then it will get real quiet... Would this be a bad idea? Would it need diodes to keep the 2 power sources isolated? The power from the main bus could be fused abd switched as well?? Thanks, Ned ________________________________________________________________________________
Date: Jun 10, 2003
Steve Nelco products. 781-826-3010. Do you have the Panduit catalog? There are many versions. that is the base #. I would recommend # TM1S6-C for most cases. Fits medium tywrap # 6 mounting hole in the middle. Ron ----- Original Message ----- From: "Steve Richard" <steve(at)oasissolutions.com> Subject: RE: AeroElectric-List: Cable Tie Mounts > > Ron, > > Where did you buy your mounts? Telephone number? I've tried Greybar, but > they don't carry in-stock. > > Steve Richard > steve(at)oasissolutions.com > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Ron > Raby > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Cable Tie Mounts > > > > > I have been using varios panduit mounts. part#s TM1 TM2. I sand the back, > put some Hysol on them and use a pop rivit to hold them while they dry. > > Ron Raby > > Lancair ES > > > ----- Original Message ----- > From: "Steve Richard" <steve(at)oasissolutions.com> > To: > Subject: AeroElectric-List: Cable Tie Mounts > > > > > > > I'm building a fiberglass airplane. I'd like to use cable ties to hold > most > > of the wire. What is everyone using for cable tie mounts? Lanciar uses > > click-bond at $1.65 each. Panduit has some for 90 cents each. Both > appear > > easy to install but expensive. > > > > Steve Richard > > steve(at)oasissolutions.com > > > > > > ________________________________________________________________________________
Date: Jun 10, 2003
I just finished wiring my Mustang II. I used the P touch labeler and used the TZ tape. It will stand all the heat you want to give it with no discoloration and the adhesive is adequate to hold it in place until you shrink the tube over it. I used the small pencil propane torch to shrink all the tubing and am quite satisfied with the finished product. Bill Lamb ----- Original Message ----- From: "John Rourke" <jrourke@allied-computer.com> Subject: Re: AeroElectric-List: wire labels <jrourke@allied-computer.com> > > I think you have to use the laminated labels, not the paper ones, for > fairly good immunity to heat.. I tested the paper ones in my oven, they > totally blacked out... I haven't tried the laminated ones yet though. > > -John R. > > RSwanson wrote: > > > > >Must be too much heat. I also used the PTouch for all my labels and had no > >problem. I didn't use a regular heatgun, but a MonoCoat heatgun left over > >from my RC days. > >R > > > >----- Original Message ----- > >From: "Mark Means" <rgvelocity(at)lmf.net> > >To: > >Subject: AeroElectric-List: wire labels > > > > > > > > > >> > >> > > > > > > > >>From: "iflyaa5" <iflyaa5(at)attbi.com> > >>Subject: AeroElectric-List: Re: Wire labels > >> > >>Andy, > >> > >>I tried the pTouch labels with heat shrink but found that being thermal > >> > >> > >they would often turn black when shrinking the tubing. Maybe my heat gun > >was too hot but I got frustrated after several attempts and gave up. Did > >you have this problem, what is your secret? > > > > > >>Mark Means > >> > >> > >>I make the labels using a pTouch style labeler. They're easy to make and > >>stick to the wire while I slide and position the clear heat shrink into > >>place. Works very well. > >> > >>Andy Morehouse > >>Grumman AA-5 N7167L > >>future RV builder > >> > >> > >> > >> > > > > > > > > > > ________________________________________________________________________________
Date: Jun 10, 2003
> >I didn't see the option you pointed out before I ordered. Thanks. I hope >the ones originally discussed will work. I had planned on not wiring the >on position, just the (on) position. Won't this result in the same >functionality? Apparently you missed my earlier post on this item: >Larry and Bob, >I looked up the Carling switch 6FB5H-73-XA, Allied stock # 683-5121, and >find that it is a ON-NONE-(0N) SPST unit. Larry, you intend to guard that >switch with the hinged cover which ensures that the toggle is down unless >lifted to activate. This means that the switch would be ON if I'm >interpreting this correctly. Two lines up in the catalog is the Allied >stock # 683-5119 which is OFF-NONE-(ON). Seems to me that this is what >you want. > >http://www.alliedelec.com/catalog/pf.asp?FN896.pdf > >Jim Foerster An on-none-(on) switch simply means that the switch is a single-pole, two-position switch with no center position and electrical conductivity AVAILABLE in both extremes. Whether you hook up to both is optional hence the opportunity to wire the switch as (off)-none-on or off-none-(on) or on-none-(on) . . . this is why we don't stock the off-xxx-(on) versions of any switch . . . it just makes us stock different configurations of switch while adding no utility with respect to how the switch is used. Bob . . . ________________________________________________________________________________
Date: Jun 10, 2003
> > Last time I took on a similar > > Guys, There is way more to this oil return from the turbo then what you are > thinking. First, the oil flow rate is way higher through a turbo. Most have a > 3/16 to 1/4" line feeding them so figure a gallon a minute. Second, the oil > coming out of a turbo that is spinning 100,000 to 130,000 rpm's a minute is not a > liquid. it is a foamy state and it needs to sit in a tank for some time to de > emulsify so it can be pumped. Third, it is coming out of the turbo bearing > housing at twice the oil temp then in your engine. You can figure oil temp out > of a turbo to be in the 300 degree range. Now the real problem is finding a > pump that can pump a foamy substance that is 300 degrees and at least at one > gallon a minute and is electric powered. I researched this a few years back and > couldn't come up with a pump. I would love to see your specs for all your > componants. Of course this is just my opinion and thats coming from a guy who is > stuffing an all aluminum 349 cu in. stroker V-8 Ford into my Zenith 801. > > Ben Haas N801BH. > Hi Ben, Regarding turbos and oil, as usual - it depends. The oil pressure needed to keep a turbo happily lubricated ranges from approx 10-15 psi when at idle to approx 45-60 psi at full gallop. However, the flow rate is not quite as much as you indicated (at least not with the turbos I am familiar with) and will seldom exceed 1/2 gallon/min for our size turbos (less than 3"dia wheels). Older turbos (before water cooling) often did have large oil flow for cooling as well as lubrication purposes - newer ones with water cooling generally have less oil flow). If you are not using a water cooled turbo then the oil temps can get a bit high as the oil picks up heat off the turbine shaft and housing and can get up around 60-80F above the inlet oil temp when at full boost, but the relative small amount of oil so heated (when compared to the total oil capacity of the engine) will seldom elevate the sump oil temp more than 5F-10F during boost. The principal reason you see you oil temperature increase during boost is because you engine is producing more power and therefore more waste heat There is the exception, of course, and that is if you shut the engine down after running the turbo hard - without letting the turbocharger cool down, then with no new oil/oil movement through the turbocharger, the oil remaining can indeed reach 300F or more and that will generally lead to a condition known as "coking" of the shaft and ultimately to bearing/shaft wear and failure. The water cooled turbos are generally not nearly as bad under those conditions as even with the engine off the water will still tend to carry heat away from the turbocharger. The oil temp should not exceed 250-260F and I highly recommend that if you are using a turbo, then to use synthetic oil with its higher temperature tolerance. Totally agree about the foamy state of the oil as it drains from the turbo, one of the reasons the turbos have such large drain orifices compared to the oil inlet. So you also need a container/sump to collect the foamy oil and give it a chance to settle out. Otherwise, as you indicate, it will be difficult for any pump to pump frothy oil. However, a pint size container is generally sufficient to accomplish this. I would recommend putting a slanting plate (drilled with 1/8" dia holes) from near the oil entrance to approx 3/4 way down the tank that spans the diameter of the tank. The oil inlet should be placed so that the frothy oil drops onto this plate (splitting oil flow over both sides of the plate as much as possible). This plate will induce the oil/air bubbles to collapse releasing the oil to flow down the plate to the bottom of the tank in liquid form to be pumped out by the scavenger pump. Regarding the scavenger pump, I would recommend a diaphragm type pump or piston type over a rotary. A rotary/vane impeller type pick up might have more trouble if the oil were still a bit frothy than a diaphragm or piston type pump. It needs to be a low-pressure, high volume type pump as all it needs to do it pump the oil back into the engine sump. A recommend capacity is 1 1/2 times the expected oil inflow. So if you expect 0.5/gpm of oil flow then a 1.5 gallon/min pump should do the job. Regarding turbos and aircraft, its important to verify that the change in operating conditions (i.e. decrease in ambient pressure) as you climb in altitude does not push your compressor wheel into the "surge" zone. If the boost pressure is kept constant during the climb, then the pressure ratio of P1/P2 (P1 ambient, P2boost) will increase as P1 decreases and that will move the operating point vertically on most compressor maps (toward the surge zone on the left hand side of the graph lines). FWIW Ed Anderson ________________________________________________________________________________
Date: Jun 10, 2003
><jrourke@allied-computer.com> > >I think you have to use the laminated labels, not the paper ones, for >fairly good immunity to heat.. I tested the paper ones in my oven, they >totally blacked out... I haven't tried the laminated ones yet though. > >-John R. Not sure what is being referred to by "laminated" and "paper" labels here. I have a label maker that puts out adhesive backed tape which uses a thermal process to print the text . . . totally unsuited to this task. Whole label goes black under the heat shrink. Further, I've not seen any label maker that puts out a label small enough to use on 22AWG wire. See picture at http://www.aeroelectric.com/Catalog/wiring/s817c.jpg The wire at the top is 22AWG . . . the type is a single row of 6pt. Labels printed on ordinary paper (or Avery label material) in a laser or inkjet printer are fine (caution on using colored lettering from inkjet . . . some inks are not fade resistant . . . your numbers may disappear with time). The Avery label material is not suggested for its ability to hold the label on the wire . . . you will find that when you put a label on a 22AWG wire, the label will consist of a single line of 6pt type. This skinny piece of paper is easier to work with if it sorta sticks to the wire while you pull the heat shrink over it. Once the heat shrink is centered over the label, it doesn't matter if the label has adhesive on it or not. On FAT wires, a column of numbers can be wrapped around the wire and again, an adhesive backing can hold the label in place while the heat shrink slides over it. Bob . . . ________________________________________________________________________________
Date: Jun 10, 2003
Subject: Re: Backup power source for ignition?
> >Hi Gang, > >I've been rewiring my RV6A that has a Chevy 4.3L V6 with dual point >ignition. I have completed the Always Hot Battery Buss with 7 amp ATC >fuses running to each ignition switch then to the coils. The ignition >switches are about 2 inches from the main bus and I wondered about the >feasability of running a wire from the main bus to the ignition switches >for a redundant power supply. With the fuses being unaccessable in flight >located in the tail cone on the battery box if the fuses both blow then >it will get real quiet... If you DO blow two fuses, what is likelihood that replacing either of them will make things get noisier? 7A circuits are generally quite robust with respect to actual power required to run an ignition system . . . these fuses are not going to nuisance trip. >Would this be a bad idea? Would it need diodes to keep the 2 power >sources isolated? The power from the main bus could be fused abd switched >as well?? > >Thanks, >Ned If you have two ignition systems, will EITHER run the engine independently of the other? If so, consider two batteries, one for each ignition. The second battery doesn't have to be a big one. Are you using one of the Z-figures as a baseline distribution diagram? Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Jun 10, 2003
Yup, I for one won't be available for a ride in such a setup ;( However for a somewhat different approach, "TurboTom" has been flying an ej22 where the engine sucks oil from a remote oil tank that sits lower than the normal crankcase. Essentially he has lowered the oil pan and separated it from the engine. Think he trashed the first engine when the suction line collapsed but last I heard his setup was working fine. Ken >I am planning to have a small container to catch the oil draining from the > >turbocharger on my Mazda RX-7 Rotary engine (which is converted for > aircraft > >use on the Mustang II kitplane that I am building) and will use an electric > >oil pump to transfer the oil from the container back to the engine > >crankcase. This is necessary because my aftermarket turbo is mounted too > >low for a gravity drain-back. The electric pump only needs to operate long > >enough to pump oil out of the container when it gets full and stop when the > >container is empty. > > > >What I am looking for is some sort of a sensor/switch that will detect when > >the oil level is at the top of the container to turn the pump on, and will > >detect when the oil level is at the bottom of the container to turn the > pump > >off. I have seen several devices/methods to turn a switch on when the oil > >gets too low, but what I need is just the opposite and it needs to > >detect/switch at maximum and minimum levels. > > > >Does anyone have suggestions or ideas regarding an oil level sensor with a > >switch that works as described above? > > Last time I took on a similar Guys, There is way more to this oil return from the turbo then what you are thinking. First, the oil flow rate is way higher through a turbo. Most have a 3/16 to 1/4" line feeding them so figure a gallon a minute. Second, the oil coming out of a turbo that is spinning 100,000 to 130,000 rpm's a minute is not a liquid. it is a foamy state and it needs to sit in a tank for some time to de emulsify so it can be pumped. Third, it is coming out of the turbo bearing housing at twice the oil temp then in your engine. You can figure oil temp out of a turbo to be in the 300 degree range. Now the real problem is finding a pump that can pump a foamy substance that is 300 degrees and at least at one gallon a minute and is electric powered. I researched this a few years back and couldn't come up with a pump. I would love to see your specs for all your componants. Of course this is just my opinion and thats coming from a guy who is stuffing an all aluminum 349 cu in. stroker V-8 Ford into my Zenith 801. Ben Haas N801BH. ________________________________________________________________________________
Date: Jun 10, 2003
Good point Bob. I'll just Keep It Simple. Thanks, Ned ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Backup power source for ignition? > > > > >Hi Gang, > > > >I've been rewiring my RV6A that has a Chevy 4.3L V6 with dual point > >ignition. I have completed the Always Hot Battery Buss with 7 amp ATC > >fuses running to each ignition switch then to the coils. The ignition > >switches are about 2 inches from the main bus and I wondered about the > >feasability of running a wire from the main bus to the ignition switches > >for a redundant power supply. With the fuses being unaccessable in flight > >located in the tail cone on the battery box if the fuses both blow then > >it will get real quiet... > > If you DO blow two fuses, what is likelihood that replacing > either of them will make things get noisier? 7A circuits are > generally quite robust with respect to actual power required > to run an ignition system . . . these fuses are not going > to nuisance trip. > > > >Would this be a bad idea? Would it need diodes to keep the 2 power > >sources isolated? The power from the main bus could be fused abd switched > >as well?? > > > >Thanks, > >Ned > > If you have two ignition systems, will EITHER run the engine > independently of > the other? If so, consider two batteries, one for each ignition. The > second battery doesn't have to be a big one. Are you using one of > the Z-figures as a baseline distribution diagram? > > > Bob . . . > > -------------------------------------------- > ( Knowing about a thing is different than ) > ( understanding it. One can know a lot ) > ( and still understand nothing. ) > ( C.F. Kettering ) > -------------------------------------------- > > ________________________________________________________________________________
Subject: Re: Oil temp switch
Date: Jun 10, 2003
did you mean various? ----- Original Message ----- From: "Ian Scott" <jabiru22(at)yahoo.com.au> Subject: AeroElectric-List: Oil temp switch > > HI Bob and all, > > I know that there are vicarious NO and NC temperature dependant switches > available, I was thinking of placing one on my sump (with a normal oil > temp pickup as well) in various temp ratings. > > What epoxy would allow me to glue this to the sump? > > Thinking of driving a overtemp buzzer and LED on a separate circuit to > the normal oil temp circuit. > > Ian > > ________________________________________________________________________________
Date: Jun 10, 2003
Right. The TZ-types are all laminated, I believe, and some are specially designed to resist chemicals as well, if I recall their catalog info correctly... BTW, Sam's Club has the tapes in a multi-pack now, 3 for $25 (Clear, White and Yellow, 26.2' each, 1/2-in wide) or so.... I'm not sure if there's better deals out there, but I believe they are usually $12-15 apiece? I believe all the model types PT-1100 and above use laminated tapes (TZ- and other types); while the cheaper ones (PT-65 and below) use the M-type tapes, which are all paper. -John R. Billie Lamb wrote: > >I just finished wiring my Mustang II. I used the P touch labeler and used >the TZ tape. It will stand all the heat you want to give it with no >discoloration and the adhesive is adequate to hold it in place until you >shrink the tube over it. I used the small pencil propane torch to shrink all >the tubing and am quite satisfied with the finished product. > > >Bill Lamb > > >----- Original Message ----- >From: "John Rourke" <jrourke@allied-computer.com> >To: >Subject: Re: AeroElectric-List: wire labels > > > > >> >> ><jrourke@allied-computer.com> > > >>I think you have to use the laminated labels, not the paper ones, for >>fairly good immunity to heat.. I tested the paper ones in my oven, they >>totally blacked out... I haven't tried the laminated ones yet though.
May 26, 2003 - June 10, 2003
AeroElectric-Archive.digest.vol-cb
