AeroElectric-Archive.digest.vol-cd
June 24, 2003 - July 07, 2003
> > http://www.myrv7.com
> > ----- Original Message -----
> > From: "Dan Checkoway" <dan(at)rvproject.com>
> > To:
> > Subject: AeroElectric-List: LightSpeed wiring
> >> Bob & folks,
> >> I'm installing a single LightSpeed Plasma II ignition in my RV-7
> >> (single
> > EI,
> >> single mag), and I'm considering straying slightly from the wiring
> >> installation notes provided with the LSE system.
> >> They recommend wiring directly to and from the battery and using a
> > pullable
> >> breaker. Basically, positive battery terminal direct to a pullable 5A
> >> breaker, then an optional on/off toggle switch, then the brain, then
> >> wire
> >> directly to the negative battery terminal. They recommend bypassing
> > busses
> >> in this manner.
> >> Here's what I would *like* to do instead:
> >> - power wired from a 5A fuse on the always-hot battery bus, which is
> > roughly
> >> 6" away (plus an inch or three) from the battery (+) terminal
> >> - no pullable circuit breaker, let the 5A fuse do its job
> >> - standard 1-3 ON/OFF toggle switch
> >> - ground wired directly to the 48/24 firewall ground block, which is
> >> connected to the battery via 5" of 2 AWG
> >> Do you see any potential gotchas in straying from LSE's
> >> recommendations in
> >> this way? I don't really see the purpose of using a pullable breaker
> >> when
> >> you use the optional on/off toggle switch and figure a fuse will do
> >> fine.
> > I
> >> have control in normal cases, and the wires are protected. I guess I
> > could
> >> always use a 5A breaker switch, but again I don't really see the point
> > when
> >> a fuse will do the same job cheaper, lighter, etc.
> >> As far as the ground goes, is there any possibility of noise
> >> affecting the
> >> LightSpeed when ground is shared with every device in the plane, even
> >> when
> >> it's grounded so deliberately close to the battery (but not *quite*
> >> to the
> >> negative terminal)?
> >> Thanks,
> >> )_( Dan
> >> RV-7 N714D
> >> http://www.rvproject.com
> > _-
> > _-
> > _-
> > _-
Subject: | LightSpeed wiring |
From: | "I-Blackler, Wayne R" <wayne.blackler(at)boeing.com> |
I have dual Lightspeed units (Plamsa I and III) in my Z-14 wired IO-360 powered
Long EZ. Being a composite aeroplane (like Klaus Savier's aircraft) I consider
the ground wiring to be the most important in my aircraft for EVERYTHING electrical
EXCEPT Ignition. I want to decrease failure modes as much as I can, including
during and after maintenance. I am running power direct from the batts
(main and aux to left and right ignitions), to 5A switch type circuit breakers
to the Lightspeed boxes. The ground runs back to the respective batteries as
well. The wiring is separate from everything else, and runs in the most damage
tolerant path in my aeroplane. If things turn to worms I have 17Ahr a side to
run my ignition. No reliance on anything but a battery. No problems with failed
electrical system components. The circuit breaker/switch allows me to (albeit
expensively) switch the IGN on/off. Minimum breaks. Why put half a dozen failure
points (some remote I know) between power to your ignition?
- Wayne Blackler
Subject: | Re: LightSpeed wiring |
Thanks for the education guys. Since I've already installed the
breakers, I think I'll go the fuse link route.
One thing that led me to ask the question, was the fact that figures
Z13 and Z11 have the 5 A field breaker in different locations. I
understand now that with the fuse link, the location of the breaker
isn't as important.
One variation that I've noticed is that while Lightspeed is calling for
a 3A breaker for a four cylinder engine in my instructions, most of the
responders are indicating the use of a 5 A breaker. Could you explain
the reason for the change?
Joel Harding
On Tuesday, Jun 24, 2003, at 10:58 America/Denver, Phil Birkelbach
wrote:
> The location of the breaker in the line is VERY important. You want
> the
> circuit protection device (fuse or c/b) to be located as close to the
> buss
> as possible so that you don't have unprotected wiring going any
> further than
> is necessary. Imagine if you wired it up as Lightspeed suggests. Now
> you
> have this wire let's say it's 18AWG running from the battery to this
> circuit
> breaker that is located on the panel somewhere. This wire may be up
> to 8
> feet in length or more. Now if you have a fault in that wire between
> the
> battery and the circuit breaker you have an unprotected wire that is
> pulling
> enough current to cause it's own failure and possibly the failure of
> other
> equipment and or wiring and possibly a fire. If the fuse is located
> very
> close to the battery now a fault in the wire will blow the fuse and the
> worst thing that would happen is your device would stop working.
> That is the function of a 'buss'. The 'hot' side of a buss (in this
> case a
> fuse block) is physically large enough that it can handle the full
> current
> that the battery is capable of producing. Now you put on the fuse and
> all
> of your current carrying medium is either big enough to handle it or
> protected by a device. Now about that battery buss. We use a 14AWG
> wire
> for that. It is not big enough to handle all the current that the
> battery
> can throw at it so we limit it's length to 6" or so. This way at
> least we
> are controlling how and where that wire will fail if it were to fault,
> and
> hopefully we don't locate it near other things that would be adversely
> effected by the heat generated by a wire that is failing and then we
> avoid
> using PVC coated wire so that it doesn't poison us as it melts.
> If you want to wire it up like Klaus suggests at least put a fusible
> link
> between the battery and the wire running to the circuit breaker, so
> you have
> some control over the failure mode. Personally I think Dan's way is
> better.
> Who needs a circuit breaker. Circuit breakers are for circuits that
> are
> going to nuisance trip and I think we can do a better job of designing
> these
> airplanes than that.
> Godspeed,
> Phil Birkelbach - Houston Texas
> RV-7 N727WB (Reserved) - Canopy
> From: "Joel Harding" <cajole76(at)ispwest.com>
> To:
> Subject: Re: AeroElectric-List: LightSpeed wiring
>> Phil,
>> I'm trying to decide on the best way to implement Klaus's schematic
>> also. The question I have is, how important is the location of the
>> protection in a wire run. Lightspeed doesn't show the breaker location
>> in their drawing, but I assumed that since the breaker is the weak
>> point, it wouldn't make too much difference where it is located in the
>> line. Can someone clear this up for me?
>> Joel Harding
>> On Tuesday, Jun 24, 2003, at 08:07 America/Denver, Phil Birkelbach
>> wrote:
>>> Dan,
>>> That's exactly how I plan to wire mine up. The problem that I see
>>> from
>>> their wiring description is that long unprotected wire from the
>>> battery to
>>> the breaker. I'd rather get mine fused right away on the battery
>>> buss
>>> and
>>> then I can run the wire all over the place without having to worry
>>> about it.
>>> Their thought process may be circuit reliablitly by eliminating
>>> connections,
>>> but the system that you describe should prove to be very robust
>>> besides you
>>> have another ignition source. If I were putting in two EI's then I
>>> might
>>> try to figure out an alternate way to power the other one. Like one
>>> from
>>> the E-buss and one from the battery buss.
>>> Godspeed,
>>> To:
>>>> Bob & folks,
>>>> (single
>>> EI,
>>> pullable
>>>> 5A
>>>> wire
>>> busses
>>>> in this manner.
>>> roughly
>>>> recommendations in
>>>> breaker
>>>> when
>>>> fine.
>>> I
>>>> I
>>> could
>>>> point
>>> when
>>>> affecting the
>>>> even
>>>> when
>>>> to the
>>>> negative terminal)?
>>>> Thanks,
>>>> )_( Dan
>>>> RV-7 N714D
>>> _-
>>> >>> _-
>>> >>> _-
>>> >>> _-
> _-
> _-
> _-
> _-
From: "Jos Okhuijsen" <josok(at)ukolo.fi To: <europa-list(at)matronics.com
Sent: Tuesday, June 24, 2003 2:40 AM Subject: Re: Europa-List: LEDs
Some simple math:
4 harmonics - 4 x 3 db = -12 db
12 V -12 dB = 750 mV over any wiring carrying the load.
If the length of the wiring comes anything close to the wavelength, half
or quarter of the comm freq's, adding a working antenna to this
transmitter design, you might be a nuisance to anything in quite a
reasonable range in addition to your own problems. Bypass capacitors?
Will load (overload?) the square wave generator. Jos Okhuijsen
irampil(at)notes.cc.sunysb.edu wrote:
All that you say is true under those circumstances.
Another approach might be:
no more than 2 leds in series since if one goes, they all stay dark
I put bypass caps on anything with sharp transitions, and we are
talking 10
4 harmonics to the nav/com range Course, ADF would be more likely
affected, but I would not consider putting such an Antique Direction
Flubber in my plane ;-)
-- Europa-List message posted by: Fred Fillinger
Date: | Jun 24, 2003 |
Subject: | Is the E-Bus that Essential? |
Gang,
Up to this point, I have been planning to wire up my RV-9
according to Fig. Z-11A. My understanding is the essential
bus would be used to conserve power during an alternator out
condition.
However, almost all of the things that I plan to hang off of the
main power distribution bus are switched. Therefore, I could
turn off the "non-essential" equipment to conserve battery
capacity. This being the case, do I need an E-bus?
I'm probably missing another good reason for wiring up a
separate E-bus as shown on Fig. Z-11A.
Please shoot holes in my logic before I shoot a hole in
my foot!
Rob
Subject: | Re: Is the E-Bus that Essential? |
Rob,
One benefit of the e-bus which has been identified in the past is
related to operational concerns. If the alternator dies on you, turn
on the e-bus alternate feed, turn off the master, and you are down
to your minimum load condition in easy to remember steps. This
is good, should you have forgotten to turn off your collision
avoidance lights, or are in the bumps with lots of stuff going on
around you.
If you are slick laying out the panel, you can set it up so that normal
condition is to have both bus control switch 'up.' (maybe placed next
to each other) This turns the alternator and battery on and the e-bus
alternate feed off. The endurance mode has both switches 'down.'
This turns off the alternator field and battery relay (and other non-
essentials), and closes the alternate feed connection for the e-bus. The
only disadvantage to this arrangement that I can see is that to completely
unpower the ship, the e-bus swith is in the 'up' position, and the master
is in the 'down' position. I might live with that since its easier to be
deliberate about switch settings when you are sitting on the ground.
You could argue the panel logic either way, but I still think there is a
benefit to only having two switches to worry about.
Another benefit of the e-bus is that it allows you to save the power
drain associated with the relay that connects the main bus to the
battery. This is so because the e-bus can alternately be powered by
a direct switch which is allowed for by the small loads designed for.
That lets you either have better endurance, or carry a smaller battery
with the same endurance margin.
Matt-
N34RD
> Gang,
> condition.
> my foot!
> Rob
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
>Gang,
>condition.
>my foot!
There has been a lot written about this . . . in fact,
the bus is more properly called the "endurance" bus.
Check out chapter 17 of the 'Connection which you can
download at
http://www.aeroelectric.com/articles/Rev9/ch17-9.pdf
By the way, Mr. Martin Gomez (who was so kind as to
share his experience with us) was told that I'd used
his story as but one of multitudinous illustrations
of how certified systems architecture and mind-set
boxes us into stupid and unnecessary situations.
I invited him to read the chapter cited above.
He contacted me again later and offer the following:
I just read the chapter. You were right on! I often thought
before and after my little fiasco that our electrical systems
were fine in the days when the Piper J-3 was a typical light
airplane. Now that we expect to fly in miserable weather,
relying on our avionics, it's nuts to still have the same
electrical system.
I, too, am an engineer (BS in aero, M.Eng. in EE, MS in
Applied Physics), with 20 years of experience. Of that, 9
was at a UAV company. We once lost a UAV because of an
alternator overvoltage...3 years after my emergency, and
after I had implored the avionics designers to split the bus
in two.
One of my hobbies is that I collect flight manuals for
airplanes that I'll never get to fly, including jet fighters,
airliners, etc. They do NOT put all their eggs in one
basket. It seems silly to have two radios (say) and put both
on the same bus so that one failure can zap them both.
I am indeed considering building an airplane. My current
choice is an RV-7. And you can bet that it will have a non-
standard electrical system! In fact, it was on the Van's
Airforce Yahoo group that I learned about you, and was told
that you used my AOPA article.
I would love a copy of your book, but if I'm going to benefit
from your experience, I ought to pay for it.
Martin
Martin Gomezmlg28(at)cornell.edu
A day later his order came in for the book. The e-buss
is more than load reduction . . . it's a DUAL path distribution
structure to keep minimal en-route operational equipment going
until airport is in sight and do it battery-only for duration
of fuel aboard.
>Gang,
>condition.
>my foot!
>Rob
Over and above the stuff mentioned by Matt Prather, the E-bus also
provides a more reliable power supply for the really important stuff,
as it has a separate power feed. So there are some failures that
might kill the power to the main bus, but you could select the E-bus
alternate feed and get power to the E-bus.
You'll have to decide how important it is to keep some things
powered. If the aircraft design and the way you fly it mean that a
total electrical failure would be a non-event, then the E-bus is
probably overkill for you. If you want to maximize the probability
of some items receiving power, even after single failures, then the
E-bus might be a good idea for you.
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
From: | "Phil Birkelbach" <phil(at)petrasoft.net> |
As with all electrical distribution circuits the fuse or circuit breaker is
there to protect the wire. It has nothing to do with the end device that is
on that circuit. You size the wire big enough to supply power to the device
and then size the breaker / fuse to protect the wire. I imagine that a 5A
breaker is also easier to find than a 3A.
Godspeed,
> isn't as important.
> Thanks,
> Joel Harding
> > the
> > buss
> > further than
> > you
> > circuit
> > to 8
> > the
> > pulling
> > other
> > very
> > case a
> > current
> > all
> > wire
> > battery
> > least we
> > and
> > avoid
> > link
> > you have
> > better.
> > are
> > these
> > Godspeed,
> > To:
> >> Phil,
> >> Joel Harding
> >> wrote:
> >>> Dan,
> >>> from
> >>> battery to
> >>> buss
> >>> and
> >>> about it.
> >>> connections,
> >>> besides you
> >>> might
> >>> from
> >>> Godspeed,
> >>> To:
> >>>> Bob & folks,
> >>>> (single
> >>> EI,
> >>> pullable
> >>>> 5A
> >>>> wire
> >>> busses
> >>>> in this manner.
> >>> roughly
> >>>> recommendations in
> >>>> breaker
> >>>> when
> >>>> fine.
> >>> I
> >>>> I
> >>> could
> >>>> point
> >>> when
> >>>> affecting the
> >>>> even
> >>>> when
> >>>> to the
> >>>> negative terminal)?
> >>>> Thanks,
> >>>> )_( Dan
> >>>> RV-7 N714D
> >>> _-
> >>> >>> _-
> >>> >>> _-
> >>> >>> _-
> > _-
> > _-
> > _-
> > _-
Don't forget that by running the E-buss on alternate feed and having the
master switch off you don't sacrifice a whole amp of current to keep the
battery contactor closed.
Godspeed,
Phil
Subject: Re: AeroElectric-List: Is the E-Bus that Essential?
> >Gang,
> >condition.
> >my foot!
> >Rob
> Ottawa, Canada
>Bob & folks,
>I'm installing a single LightSpeed Plasma II ignition in my RV-7 (single EI,
>installation notes provided with the LSE system.\
Wiring diagrams from most manufacturer's assume that your
electrical system is a spam-can-clone . . .
>They recommend wiring directly to and from the battery and using a pullable
>breaker, then an optional on/off toggle switch, then the brain, then wire
>directly to the negative battery terminal. They recommend bypassing busses
>in this manner.
If you have an electrically dependent engine, then there's
no reason NOT to run engine support system from an always-hot
battery bus. If you have dual support systems (two pumps one
of which MUST run to keep flying and/or dual ignition systems)
then there's no reason not to have two batteries, each with its
own battery bus to support half the engine hardware.
Fuses/breakers AT the battery bus take care of all necessary
protection.
NOISE doesn't swap between systems because they share grounds,
it propagates because they are badly wired to multiple grounds.
See chapter on noise in the 'Connection.
>Light Speed's instructions say they want us to "route the positive power
>lead to a 5A pull-able breaker and then to the battery plus terminal,
>bypassing any electrical bus or master solenoid." And "If a toggle switch is
>used as an on/off switch, it should be installed next to the breaker." And
>also: "Route the negative lead directly to the battery ground terminal (not
>airframe ground buss) to avoid ignition noise...."
This is BS on all counts . . .
Subject: | Re: isolated ground wire for avionics in metal airplane |
Would I see any benefit or detriment to using a dedicated ground wire for my
avionics in my metal airplane, isolated from the metal airframe? Thanks, Skip
Subject: | Wiring VM1000 for dual alternator installation |
From: | "Treff, Arthur" <Arthur.Treff(at)Smartm.com> |
Listers,
I'm wiring my RV-8 with Z-13. My ammeter will the embedded in the Vision MIcrosystems
VM-1000 display.
My questions are:
1) What would be the consequence if I connected the leads from both ammeter shunts
to the VM-1000? Since both alternators would be operating at different times
wouldn't the display just show the current from which ever alternator was
switched on? No doubt I'm missing something, please poke holes in my logic.
2) For those who have used a primary and an E bus and a display like the VM-1000,
where in the circuit did you wire the voltmeter? Any reason to have a voltmeter
on the main bus as well as the E-bus? OOps, that's a dumb question, I
think I just answered it myself. Current is very important to system health,
but knowing if the voltage falls below alternator output (#1 or #2) is all that
really matters, yes? Having said that, my logic is that putting a single voltmeter
accross the pnl ground plane to the started contactor would do the job.
Fire away, what am I missing?
Arthur Treff
Asheville, NC
Subject: | recording intercom with a digital voice recorder |
What about minidisk, cheap, robust, small light and they can record and
provide music when you need it.
Ian
(who will be installing a Minidisk player in the jabiru as soon as I
can).
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris
W
Subject: AeroElectric-List: recording intercom with a digital voice
recorder
I would like to tie in a digital voice recorder to the intercom for 2
purposes. First to record everything while I am doing my flight
training. Second to be able to play back what ATC just said. I found
an adapter wire in the Aircraft Spruce catalog that you stick between
the intercom and your headset plug that has electronics that convert the
headphone signal down to a mic signal. That's great for recording.
Then they have a CD Player adapter where you also insert the plug in
between the intercom and your headset plug and then plug the little 1/8"
plug into the headphone jack of a CD player or in this case the voice
recorder. But then there are the cell phone adapters. Can those be
connected to a voice recorder some how and record all intercom traffic?
And then play it back through the intercom? Then there is the issue of
mixing stereo and mono plugs. I don't really care if I loose the option
to hear stereo music as long as the signal is still coming through both
ears. Can some one please clear this up and let me know what the best
solution is? I'm also looking for suggestions on MP3
players/voice recorders.
I have also seen some MP3 player/recorders that can record from a line
in signal, would that be a better solution? Has anyone seen or used
these? The only one I know of right now is called a Ripflash. They
have several different models. Their web site is here
http://www.pogoproducts.com/
Chris Woodhouse
3147 SW 127th St.
Oklahoma City, OK 73170
405-691-5206
chrisw(at)programmer.net
N35 20.492'
W97 34.342'
"They that can give up essential liberty
to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin, 1759 Historical Review of Pennsylvania
direct advertising on the Matronics Forums.
From: | "William Bernard" <billbernard(at)worldnet.att.net> |
Subject: | Electric Gyro Question |
I've installed my electric TC and in testing it, I noticed that it would turn into
a 'generator' when it was winding down after power off: LEDs on the panel
would light and then gradually fade as the gyro spun down.
I 'corrected' this by adding a diode to the '+' side of the connection. My question
is this: Is this sort of thing normal for all electric gyros? I haven't installed
the electric DG or AH yet. Would it be worth my time to install diodes
in the feed wires now or is this likely a wasted effort?
Thanks in advance
Subject: | Re: Electric Gyro Question |
In a message dated 6/25/2003 7:07:43 AM Mountain Daylight Time,
billbernard(at)worldnet.att.net writes:
> turn into a 'generator' when it was winding down after power off: LEDs on the
> panel would light and then gradually fade as the gyro spun down.
> question is this: Is this sort of thing normal for all electric gyros? I
> haven't installed the electric DG or AH yet. Would it be worth my time to install
> diodes in the feed wires now or is this likely a wasted effort?
> Thanks in advance
Wow,,, Now that is bizarre for sure. But it does sound plausible.
>the panel would light and then gradually fade as the gyro spun down.
First, why is this a concern? Sounds like your
bus is VERY lightly loaded during power-down else
the tiny amount of energy stored in the gyro rotor
wouldn't provide so noticeable an effect. LEDs
will produce visible light at very low excitation
levels . . . you wouldn't see this effect at all
were your lamps of the incandescent type . . .
aside from the noticed effect while powering down,
why is it a bad thing and why increase parts count
and reduce performance on gyro by adding a diode?
>install diodes in the feed wires now or is this likely a wasted effort?
Depends on the instrument. If the motor is brush-type
dc motor (some turn coordinators are) then the motor
will "generate" too. If the motor is an ac induction
device, then the instrument includes an inverter to power
the ac motor from the dc bus. The best gyros are of this
design and will not "generate" . . .
Subject: | Re: Wiring VM1000 for dual alternator |
installation
>Listers,
>MIcrosystems VM-1000 display.
>My questions are:
>ammeter shunts to the VM-1000? Since both alternators would be operating
>at different times wouldn't the display just show the current from which
>ever alternator was switched on? No doubt I'm missing something, please
the VM1000 uses hall effect sensors, not shunts. You can
connect the three wires so that both sensors are powered up
all the time but you need a switch in the signal lead to
swap the instrument between sensors.
>VM-1000, where in the circuit did you wire the voltmeter? Any reason to
>have a voltmeter on the main bus as well as the E-bus? OOps, that's a
>dumb question, I think I just answered it myself. Current is very
>important to system health, but knowing if the voltage falls below
>alternator output (#1 or #2) is all that really matters, yes? Having said
>that, my logic is that putting a single voltmeter accross the pnl ground
>plane to the started contactor would do the job. Fire away, what am I missing?
since the VM-1000 doesn't help you get from
point A to point B, I'd put it on the main bus
and let it go dark during battery only ops.
One might argue that you need a voltmeter on the
endurance bus 'cause it's the battery's "gas gage"
but if you've done your load analysis versus battery
size -AND- you do reasonable periodic maintenance
on the battery, then there is zero concern for getting
airport in sight battery only, even if your alternator
crapped 5 minutes after departure.
Your engine isn't going to quit running because it
isn't being monitored. If there are things the VM-1000
can do for you en route, they are very short duration
activities that can be covered by momentarily turning
the master switch on.
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( and still understand nothing. )
( C.F. Kettering )
Subject: | Re: isolated ground wire for avionics |
in metal airplane
Ground is ground is ground . . . at some point in time the
avionics gets connected to the airframe. Some installers
have an "avionics" ground on the stack at the panel and then
connect the remote ground bus to the firewall ground bus
with a suite of 2 to 4 wires (for redundancy) . . . Unless
you're building a LA4P with a bizillion electro-whizzies on
the panel, individual ground wires to the firewall ground
bus minimizes parts count and maximizes system reliability.
From: | "Neville Kilford" <nkilford(at)etravel.org> |
Subject: | Electric Gyro Corp turn co-ordinator |
Hi guys,
Does anyone have any experience of the EGC turn co-ordinators? They look
pretty good, but anyone know how they are electrical noise-wise?
Any comments would be greatly appreciated.
Cheers.
Nev
Jodel D-150 in progress
UK
Subject: | Ring terminal sizes for contactors |
Hi guys,
Does anyone know what size studs are required for the contactors? In metric
they're M5 & M8, but I only see imperial sizes on Bob's order form.
The M8 one converts to .31" or so, but what about the M5? It's smaller than
.25", so perhaps it's #10, #8, or #6, but I've no idea what those mean!
Any help would be appreciated.
Cheeers.
Nev
Subject: | Re: Ring terminal sizes for contactors |
----- Message d'origine -----
De : "Neville Kilford"
Envoy : mercredi 25 juin 2003 17:44
Objet : AeroElectric-List: Ring terminal sizes for contactors
> Hi guys,
metric
than
> Cheeers.
> Nev
Neville,
M 8 studs perfectly fit 5/16 (or .31") terminals
M5 will be OK with # 10 terminals
Hope this helps,
Gilles Thesee
Metric since French revolution
>Hi guys,
An "M" size is in approx millimeters. A millimeter is about
0.040" An M8 would be therefore about 0.32", an M5 is about
0.20"
See
http://216.55.140.222/temp/Tap_and_Clearance_Drill.pdf
for a list of tap and clearance drill sizes for the vairious
screw sizes. Note that a free fit on a #6 screw is a #25
drill (0.145") if one were to convert this to millimeters,
it would be an M3.7
If you go to
http://catalog.tycoelectronics.com/TE/bin/TE.Connect?S=13836&M=FEAT&LG=1&I=13
you'll find a listing of terminal sizes offered in the PIDG
series from AMP. Note the data fields labeled "Stud Diameter" and
"Stud Size" You can order a terminal sized in mm/in format
or by screw size (#4, #6, etc.)
Does this help?
( C.F. Kettering )
>Gang,
>condition.
>my foot!
download at
electrical system.
in two.
Martin
of fuel aboard.
Subject: | Another Question, Different Subject |
Thanks to Bob for the answer on the TC. The main reason I installed the diode was
that the LEDs that were lit up were assosiated with the angle of attack computer.
I doubted that this would cause a problem long term, but didn't want to
take the chance. Also, it just didn't seem right the that they should light up
when the power was turned off.
I plan to not install any diodes in the power lines for the future DG and AH.
My next question is about the VOR antenna shown on page 13-16 (Figuare 13-12) in
the Aeroelectric Connection. It appears from the sketch that the central conductor
for the antenna coax is electrically insualted from the antenna itself.
Is this actually the case? Are there any revisions or updates to the sketch?
Is the thing worth building, or should I just buy an antenna>
Thanks again.
Subject: | Re: Wingtip VOR antenna |
>diode was that the LEDs that were lit up were assosiated with the angle of
>attack computer. I doubted that this would cause a problem long term, but
>didn't want to take the chance. Also, it just didn't seem right the that
>they should light up when the power was turned off.
>13-12) in the Aeroelectric Connection. It appears from the sketch that the
>central conductor for the antenna coax is electrically insualted from the
>antenna itself. Is this actually the case? Are there any revisions or
>updates to the sketch? Is the thing worth building, or should I just buy
>an antenna>
If you study the assembly carefully, you'll find that the
center conductor ties to one side of a CAPACITOR formed by
two strips of aluminum sandwiched around a piece of phenolic.
This design was purloined from an issue of RVAtor some years
ago. I found out several years later that someone else had
purloined it from one of Bob Archer's designs. I met Bob for
the first time in California at a seminar I was doing for
Aircraft Spruce. He told me that this was his original design.
If you build this antenna as depicted it will probably
perform as well as necessary . . . unless you plan to
use VOR for long range, en route navigation where NO
wingtip antenna is going to perform as well as a set of
cat-whiskers on the tail.
Bill,
I am new to the forum, so I hope I am not breaking any protocol with my
response. However, I have an answer for your VOR antenna question.
The antenna listed as figure 13-11 is a half-wave dipole antenna. When
connecting a coax to a dipole one should connect the inner wire to one rod
(it doesn't matter which one) and the outer breaded shield to the other
wire.
A ground plane antenna has the inner wire connected to the vertical rod and
the shield to the ground plane.
BTW, if your are building your own VOR antenna, be aware that the length of
the antenna is important. The closer your antenna is to 1/2 of a wave
length of the VOR signal, the better your reception will be. The formula
for finding the total length (both sides added together) is
length = 491.8 divided by frequency in MHz
Hope this helps.
CMS
C. M. Shearer
Taylorcraft N43502
March 11, 1946
Serial No. 7161
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of
> William Bernard
> Sent: Thursday, June 26, 2003 7:22 AM
> To: aeroelectric-list(at)matronics.com
> Subject: AeroElectric-List: Another Question, Different Subject
> (Figuare 13-12) in the Aeroelectric Connection. It appears
> from the sketch that the central conductor for the antenna
> coax is electrically insualted from the antenna itself. Is
> an antenna>
> Thanks again.
> Bill
Subject: | RingTerminalBoltSize |
A number 2 wire ring terminal with a hole to fit the .193" bolt that comes with
Bob's favorite battery, a Panasonic LC-RD1217P , will not clear the case but
must be ground down to bolt flush to the battery terminal. Is there any advantage
to doing this versus just using a ring terminal for a larger bolt?
Dave Reel - RV8A
List,
I am building a kitfox with the battery in the tail. Recent posts have brought
a question to mind: In my aircraft the wire running from the battery contactor
to the bus will be about 15-20 feet. Figure Z-11 indicates the wire should be
8AWG but it is not protected. If that wire somehow shorted I think I would be
in a world of hurt. Should I protect it with a fusible link ordoes the battery
haveinsufficient capacity to burn that size wire (or am I completely missing
something?)
Grant
>List,
>brought a question to mind: In my aircraft the wire running from the
>battery contactor to the bus will be about 15-20 feet. Figure Z-11
>indicates the wire should be 8AWG but it is not protected. If that wire
>somehow shorted I think I would be in a world of hurt. Should I protect it
>with a fusible link ordoes the battery haveinsufficient capacity to burn
>that size wire (or am I completely missing something?)
If your battery is located behind the seat, then you tie the
main bus feeder onto the starter contactor on the firewall
which will significantly shorten this wire.
There is no compelling reason to "protect" heavy feeders
other than to put them downstream of the battery contactor.
It is sufficient to install these wires with due diligence
for avoiding mechanical damage to the wire . . . same as
one would do for a fuel line or a control cable. Likelihood
of these feeders causing in-flight problems is extremely remote.
This fact has be recognized by the FAA in certification of
light aircraft. I'll quote Part 23 in part:
Sec. 23.1357 Circuit protective devices.
(a) Protective devices, such as fuses or circuit breakers, must be
installed in all electrical circuits other than--
(1) Main circuits of starter motors used during starting only; and
(2) Circuits in which no hazard is presented by their omission.
Bob. . .
Thanks Bob...
That is the mother of all conversion tables. Made no sense whatsoever!
I really wanted to know just what the size of #10, #8, and #6 would be (in
inches or mm).
Gilles has said that #10 is a 5mm, which should suit the contactors alright,
and I have some M8 PIDG terminals. I just need to order the .31" uninsulated
rings for the fat leads. So, I think I'm there or thereabouts. I'll shout
if I need any more info.
Cheers.
Nev
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: AeroElectric-List: Ring terminal sizes for contactors
> >Hi guys,
metric
than
> 0.20"
> See
> it would be an M3.7
> If you go to
> Does this help?
> Bob . . .
>Bill,
The "protocols" for this list-server is to offer, analyze, and
deduce practical application of simple ideas that support
the physics and art of building airplanes. Your considered
participation in this endeavor is always welcome . . .
>wire.
He was referring to the 1/4-wave, gamma-matched antenna in Figure
13-12.
This yields a length in FEET.
> inches or mm).
http://bobmay.astronomy.net/misc/drillchart.htm
)_( Dan
RV-7 N714D
Subject: | Re: RingTerminalBoltSize |
>with Bob's favorite battery, a Panasonic LC-RD1217P , will not clear the
>case but must be ground down to bolt flush to the battery terminal. Is
>there any advantage to doing this versus just using a ring terminal for a
>larger bolt?
>Dave Reel - RV8A
Having trouble visualizing this . . . I presume that your
talking about the edge margin around the bolt hole for
terminal with a 0.193"+ hole is so large that the edge
of the terminal hits the battery case and prevents alignment
of the two holes for bolt insertion.
I'm wondering how a terminal with a larger hole helps.
Usually, as hole size goes up, overall diameter of the
margin around the hole goes up too.
The drawing I have for the Panasonic battery isn't
very well dimensioned but it seems to suggest there
is a 0.315 distance from hole center to top of battery
case. This allows for a 0.600" diameter terminal
with a 0.200" hole in it to still fit the battery
terminal without modification. If the terminal you
have is too large, it is best to trim the edge
to gain needed clearance. The real meat of where
a terminal does it's job is area under the nut and
around the hole . . . the hole should fit the
bolt as closely as practical.
There are no "standards" for overall terminal
diameter around the hole versus actual hole
size. You can download a typical terminal catalog
at
http://www.hollingsworth.com/Misc/hollingsworth%20catalog.pdf
check out page 46 for un-insulated terminals
for 4AWG wire. Note that for each stud size
there can be more than one diameter offered
for overall size of the flag. If you have trouble
finding a terminal with the right hole size
and still small enough to fit the battery, you
can sometimes use hole size down down for hole
size and drill it out to fit . . . or trim a
flat on the edge as you've suggested above.
>Thanks Bob...
>inches or mm).
The chart says the range of sizes from close to loose fit on
a 10-32 threaded stud is 0.196" to 0.201" diameter drill.
Divide these by 0.039"/mm and you get 4.97 to 5.1 mm. I would
assume a 5mm terminal is available. A #8 works over range
of 0.169 to 0.177" for a mm range of 4.29 to 4.49 mm. Depending
on who is supplying your terminals, a 4mm (tight) or 4.5mm terminal
seems to be in order. A #6 stud needs 0.144" to 0.149" or
3.65 to 3.78 mm, I would guess a 4mm terminal would be best
fit on the #6 stud.
A 8 mm terminal times .039"/mm yields 0.315" in diameter . . . just
right for a 0.312" (5/16) treaded stud on the contactor.
> > inches or mm).
pretty cool chart . . . but it gives TAP drill
sizes, not clearance drill sizes.
Please excuse my lack of knowledge, but I'm confused on this diode issue
with the TC.
What is the difference between putting diode(s) on the contactors to
prevent the energy wave back into the critical parts of the circuit and
putting the diode on the TC to prevent it from doing the same or
similiar? I'm sure I'm missing something, but on the surface it looks
like the same type of problem/solution.
Thanks!
Don Honabach
From: William Bernard [mailto:billbernard(at)worldnet.att.net]
of attack computer. I doubted that this would cause a problem long term,
but didn't want to take the chance. Also, it just didn't seem right the
that they should light up when the power was turned off.
and AH.
the central conductor for the antenna coax is electrically insualted
from the antenna itself. Is this actually the case? Are there any
revisions or updates to the sketch? Is the thing worth building, or
Thanks again.
>Bob,
>I am building an all-electric RV-6A and currently planning on a dual
>alternator, single battery electrical system (a-la Z-12), with a D25 Diode
>assy providing E-Buss primary feed...fuses - not breakers.
>For overvoltage protection, a crow-bar (OVM-14) driving a B-lead contactor
>(S701-1)...or do I really need two sets - one for each alternator? I
>don't really understand how it works - looks like it (OVM-14) would short
>the circuit that normally provides power to the S-701 (easiest path)
>causing the S-701 to open....yes/no? Although it looks like the LR-3/SB-1
>alternator controllers would be one-stop shopping providing OV protection
>too?!
First, not that Z-12 is shown set up with breakers. If you go the
fuseblock route, you need to treat your alternator field supply
circuit like that shown in Figure Z-11 where there is a fusible
link coming off the bus to supply field power to the alternator
control switch. This path continues on through a 5A breaker
mandated for the crowbar ov protection . . .
The second alternator would have its own fusible link and field
supply circuit as the first alternator.
OV protection is built into the regulators B&C makes. You would
not need to add an OVM-14.
>I would prefer the autoswitching as described on pg 17-12. Are these
>mutually exclusive? OV protection is more critical to me than
>autoswitching if I have to make a choice - I'm open to education though.....
Autoswitching happens because the standby alternator is
set to regulate at 0.5 to 1.0 volts BELOW normal bus
voltage. Normal operation is for both alternator switches
to be ON all the time. Should the main alternator fail,
bus voltage sags and the #2 regulator brings the #2 alternator
on line to support ship's loads. The Alternator Load/Overload
light will flash until you reduce ship's load to or below
20A.
>SB-1's and SD-20's are not listed anywhere on your website - are they
>discontinued?
I don't sell those, B&C does at http://www.bandc.biz
>I hope that I've conveyed my intended direction...please validate or
>provide education. I would like to make sure that the pathway is valid
>given current availability of hardware.
All the hardware you need is currently available. Figure Z-12
is most often applied to airplanes that already have breaker
panels. You can certainly apply it to a new airplane with
fuseblocks provided that you make the small changes described
above to add fusible links and alternator field breakers.
( C.F. Kettering )
Don,
Diodes across relay coils allow for increased switch life by eliminating
arcing across the contacts caused by the inductive load of the application.
The illumination of LED's caused by the mechanical energy stored in the
gyro doesn't pose a reliability/durability threat to any of the components in
the circuit. I can't really see needing to turn off the bus that feeds the
gyros while in flight, while in the dark - the condition which causes the
LED's to light up. I'd guess that leaving any component on the bus turned
on while the bus feed is off would probably extinguish the LED's.
Regardless, it doesn't sound like the LED's can provide useful information
while the bus is turned off, so they can be ignored for the minute or two
that the gyros take to wind down, if the bus loads are that low.
Matt Prather
N34RD
> with the TC.
> Thanks!
> Don Honabach
snip
Subject: | Re: Terra 760 D/manual source |
I have had good luck with the following for older manuals etc.
http://www.esscoaircraft.com
The quality was good last time I used them.
Paul
From: "David J. Spencer" <djs(at)54Transmission.com>
Subject: Re: AeroElectric-List: Terra 760 D
> Ed...
> Sorry, but I don't have any advice about the technical difficulties.
> However, I have dual TXN-960s and am wondering how you got a maintenance
> manual? I'd love to have one for my 960s... have the install manual.
> David J. Spencer
> Super3
> From: "Ed Anderson" <eanderson(at)carolina.rr.com>
> To:
> Subject: AeroElectric-List: Terra 760 D
> > Hi Bob,
> > Don't know if you or anyone on the list may be able to help me with my
> > problem or not. I have a Terra 760D transceiver. I have always had a
> > problem with distortion when transmitting. Sometimes so bad folks
> receiving
> > can not understand me. At first, I though it might be the high noise
> level
> > in the cockpit, so got a better noise supression mic and also
uphosteried
> > the interior to reduce ambient noise. Nothing seemed to solve the
> problem.
> > There is no static/distortion when receiving and my side tone does not
> have
> > any distortion. I have had the transceiver in three times to have it
> > checked, but you know how an intermittent problem is - never show up in
> the
> > repair shop. Antenna and Coax has been changed as well.
> > I finally obtained a maintenance manual and noticed that the sidetone is
> > generated one transistor before the modulation transistor. This leads
me
> to
> > assume that the audio portion of the circuit is good (at least up to the
> > side tone generator) and I wonder if an intermittent condition with the
> > modulation transistor could cause distortion. It does seem worst during
> hot
> > weather. If anyone has had a similar problem and discovered the cause,
> would
> > appreciate hearing from them.
> > Best Regards
> > Ed Anderson
> > RV-6A N494BW Rotary Powered
> > Matthews, NC
AeroElectric-List message previously posted by: "Treff, Arthur"
6/26/2003
Hello Arthur, I have installed a VM1000 system in my not yet flying airplane.
I get the impression from your question that you don't have the hardware or
VM manual in hand yet and are sort of feeling your way along.
I would like to emphasize that I think the VM equipment is top quality gear
(although perhaps no longer on the cutting edge of technology) and I have been
absolutely pleased with the support that I have gotten from Lance Turk and his
people, BUT there are some "gotchas". If you don't have the hardware and
manual in hand and are very familiar with them you might be in for some surprises.
Such as:
1) There is a cigar box sized DPU (Data Processing Unit) that you must mount
somewhere with some subsequent access to. Many, many wires will run from your
engine compartment to the DPU and connect through a D sub plug that you must
wire. A flat ribbon cable will run from the DPU to the instruments in the
instrument panel.
2) The wires going to the DPU D sub plug come from sensors either attached
directly to the engine / magneto (CHT, EGT, OIL TEMPERATURE, RPM) or located in
front of the firewall (OIL PRESSURE, FUEL PRESSURE, FUEL FLOW) or located
optionally either in front of or behind the firewall (MANIFOLD PRESSURE,
AMPERAGE). Voltage feeds directly to the D sub from the bus / source that you choose
with no sensor. OAT and CAT connect directly to the DPU D sub if you are using
those sensors.
3) As Bob Nuckolls said VM uses a Hall effect sensor for amperage input. The
sensor provided by VM is a small printed circuit board with a hole in the
middle and a coil around that hole. The hole is big enough for maybe one (fat)
wire to go from the alternator to the positive side of the starter contactor (how
I wired mine). VM would like you to put this sensor in a benign environment
(aft of the firewall), but I did not want that "fat, noisy wire" in the
cockpit. If you can't put the sensor in a benign environment then VM wants you
to
protect or encase the sensor in some fashion. I found that next to impossible to
do because of its shape and size and the fat wire running perpendicularly
through the board's middle, so mine is hanging exposed from a bracket fastened
to
the front of the firewall.
4) Coming from the amperage sensor are four wires within the shieldedcable
provided by VM that lead to the D sub plug going into the DPU. It is difficult
for me to envision how you would rig two different alternators to feed the DPU,
but I'm sure that it could be done with some effort and extra hardware such
as switches (12 contact rotary?) and maybe an extra Hall effect sensor.
5) VM provides you with high quality four wire shielded cable to go from the
sensors to the DPU. But you don't need all four wires for all the sensors. You
can reduce weight and bulkiness (big issue when wiring the D sub plug) by
buying some two and three wire shielded cable and using that where appropriate
rather than the four wire cable provided by VM.
6) If you go for the VM fuel quantity system you get another printed circuit
board (naked, no enclosure) that VM calls the IO board. You must also mount
that some place and protect it as desired / needed. The wires from the fuel
sensor probes go to the IO board via another D sub connector and the flat wire
from the DPU to the instruments on the panel goes through the IO board.
Arthur, I know that this is very nutsy and boltsy and I'm sure that you know
some of this already, but the above information would have been very helpful
to me at one stage of my building. Please let me know if you have any questions
(by direct email if appropriate) and I'll give it my best shot.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
A follow-up on my quest for the guarded momentary-on toggle switch:
I'm not having much luck so far. For use with the switchguard, they
have to be mounted a certain way. Basically, the momentary-on needs to
be opposite the groove in the neck that is used for the anti-rotation
tab. The switch listed in the previous email below has the opposite
action: (on)-on as mounted in the switchguard. So, I ordered
CARLING 6FA5H73: ALLIED STOCK # 683-5119
which is listed as having a (on)-off action. But it's the same -- the
momentary on is opposite the groove. So using either of the switched
purchased so far, the starter will engage as soon as the switchguard is
flipped open, and stay engaged until the guard is closed. That's not
what I'm after.
Is the only solution to file off the anti-rotation tab on the
switchguard, or am I over looking something?
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
2003 - The year of flight!
> >I'm looking for a off-(on) toggle switch for use as a starter engage
> >switch. Same functionality as the push button that Bob sells, but I
> >want the form-factor of the toggle switches. This will be used with
> >the red flip-guard. Anyone know a source? I guess one of the
> >three-position switches would work [xx-xx-(on)], but ...
> CARLING 6FB5H73XA: ALLIED STOCK # 683-5121
http://www.alliedelec.com/catalog/pf.asp?FN=896.pdf
>what I'm after.
Nope, that's how we all do it. Most guards are not built to any
standard . . . only those done to a Mil-Spec are going to be
consistent. I've purchased guards that had anti-rotation tabs
both ways. Use anti-rotation tab washers on the BACK of the panel
for the switches and file off the tab on the guard. They'll probably
work just fine. If push comes to shove, put two tiny dots of adhesive
on the back of the guard's mounting plate. Sho-Goo or one of its
cousins works well.
> Bob
>I'm looking for pin-out info for a KX125. Have any idea where I can
>borrow or download a copy.
>Thanks
Try
http://216.55.140.222/Installation_Data/KX125.pdf
I will invite you to join us on the AeroElectric List
to continue this and similar discussions. It's useful to
share the information with as many folks as possible.
A further benefit can be realized with membership on
the list. There are lots of technically capable folks
on the list who can offer suggestions too. You can
join at . . .
http://www.matronics.com/subscribe/
Thanks!
| A lie can travel half way around the world while |
| the truth is till putting on its shoes . . . |
| -Mark Twain- |
Subject: | Grouping wires for firewall penetration |
Hi Bob,
I plan on grouping wires in the following two groups for firewall penetration:
1) CHT, EGT, and tach, oil T&P, MAP, and fuel pressure transducer wires
2) E.I. controllers (2), Alternator field and B output, and starter contactor
Is this okay?
thanks, Rick Fogerson
RV3, finish
Boise, ID
Subject: | Re: Mom-on toggle |
Larry,
FYI, I went through this same ordeal (although I didn't try as hard), and in
the end I caved and went for the pushbutton switch with protective bezel
that B&C sells. It's not as "pretty" as a red flip-up guarded switch, but I
rationalize the decision by noting that the pushbutton switch is more or
less foolproof. Less flipping and flopping...just jam a finger in there and
pull your hand away when you're done cranking. Oh, well.
)_( Dan
RV-7 N714D
Subject: RE: AeroElectric-List: Mom-on toggle
> >what I'm after.
> cousins works well.
> Bob . . .
I've considered that. But I already have the guarded toggle in my console. It
use to be a "starter enable" switch when I was going to have the starter button
on my infinity grip. I've changed it recently to just "starter". Less
complicated. Fewer potential failures. I think I'll take Bob's advice and
make it work with what I have and adjust the anti-rotation thingies as needed.
LB
--- Dan Checkoway wrote:
> Larry,
> )_( Dan
> RV-7 N714D
> To:
> > >what I'm after.
> > cousins works well.
> > Bob . . .
>Larry,
Good point. I've noted a degree of reverence for treating
certain controls in airplanes with extraordinary respect.
Recovery parachute system controls in Premier and Horizon
are in international orange boxes, switches and deploy handles
are guarded by key-locked covers when the system is not
needed. All kinds of lights come on in front of the pilot
when the system is armed. The deploy handle is black with
diagonal yellow stripes and the word "DEPLOY" engraved upon
it both right side up and upside down (just in case the
pilot is standing on his head while deciding whether
or not he wants to deploy the parachute).
Of course, operation of this life and airplane saving
device at the wrong time can produce a most undesirable
effect.
There are other controls in our airplanes designed
for single or rare event usage. Operation at
the wrong time may have a potential for doing damage
to some part of the airplane or causing the pilot some
momentary surprise for an unexpected event. The most
elegant solutions to preventing inadvertent operation
are easy. Put the control in a place where it's not
going to be mistaken for another control or inadvertently
operated while concentrating on some other task.
The starter on the Tri-Pacer I used for dual instruction
in 1960 is a good example. It was located under the
pilot's seat on the underside of a ledge. You had
to feel for it to find it and short of hitting it
with your heel during a collision with a mountainside,
there was no way that button was going to be subject
to accidental operation.
The Cherokee 235 I rent at 1K1 operates its starter
by a COMBINATION motion of TWIST -AND- PUSH IN
to start . . . in my never humble but always
honorable opinion . . . overkill. Nonetheless,
the intent of the designers was addressed with
very little extra effort and/or addition of
complexity . . . cost of ownership is entirely
another matter. That magneto switch probably cannot
be legally replaced with and ACS-510 without a great
deal of kowtowing to Washington and I'll bet that
special switch is a LOT more expensive than the
TSO'd Aircraft Spruce product.
I often hear builders voice concern for "accidental"
operation of switches and controls. Human factors
engineering is a powerful tool for reducing chances
of inadvertent operation while keeping the cost
of ownership and system complexity low. The elegant
solutions are almost always so simple as to go
completely unnoticed by the casual observer.
If one combines the starter switch with magneto
switches -AND- cross connects to be disabled when
the left mag is on -AND- groups the switches in
an area never normally accessed in flight (See:
http://216.55.140.222/temp/Switches.pdf ) then
I'll suggest that chances of inadvertent starter
operation are at least an order of magnitude
more remote than the probability of you cruising
into a mountainside.
Subject: | Re: Grouping wires for firewall penetration |
>Hi Bob,
>Is this okay?
Don't see any potential for "gotchas" here . . . but why is
your b-lead coming through the firewall?
>Don,
Excellent answer. I will add that energy residuals of turning things
off are entirely different for contactor/relay coils than for
motors spinning down. A motor can generate no more voltage than
it is supplied with for operation . . . turn it off and its output
drops immediately to some lower value and ramps down from there
as the rotor comes to a stop. A contactor coil delivers energy
via an entirely different mechanism and the voltage can be
on the order of hundreds of volts. See
http://www.aeroelectric.com/articles/spikecatcher.pdf
Subject: | Wire and Screw Sizes Tutorial |
AWG-American Wire Gage, Also known as the Brown & Sharpe Wire gage not
"gauge", and used in the United States since the 1880s when the prairies
were no longer black with buffalo, for ductile metal wires. Each wire
manufacturer faced the problem of maximizing a wire-drawing diameter
reduction while minimizing the wire breakage. "Process" had a lot to do with
this, so many made their own gage.
By our enlightened AWG standards, number 0000 wire is 0.4600 inch in
diameter. The diameter of each succeeding size, 000, 00, 0, 1, 2 etc. is
0.890525 times the diameter of the previous size. Wires get smaller as the
gage number gets bigger since these numbers simply represent the number of
the draw. Brown and Sharpe had the edge in this whole mess because THEY made
the measuring instrument too. Cool...... So figuring out any size solid wire
is simple. For example; solid 18 AWG is ummm....let's see....0.0808 inches.
For stranded wire the exercise is left to the student.
Gage sizes for guns are simply the number of lead balls equal to the weight
of a 1-inch diameter ball that will fit in your bore. Thus a 12-gage gun has
a bore that would take 12 balls that could be made from a 1-inch diameter
lead ball.
For screw studs we use the formula (0.013 times Studsize) + 0.060 = real
diameter. Thus a #10 screw is nominally 0.190 inches. But you knew that! In
New England flea markets I occasionally see antique tap and die sizes like
7-32, 9-24, 11-28 etc. Only the even sizes above #5 are used anymore.
The metric system has been the official measurement system in the US since
1866. Thank heavens for that!
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge MA 01550-2705
Phone (508) 764-2072
Email: emjones(at)charter.net
"I only regret my economies."
Reynolds Price
Subject: | sizing of current limiters on the B lead |
I am doing the Z14 system. I have a 60 amp main alt and a b&c 20 amp on the
second system. How do I size the current limiters on the B lead. ANL60 and
ANL20?
Ron Raby
Lancair ES
Subject: AeroElectric-List: Re: 10622 Capen
> >Bob,
Diode
contactor
LR-3/SB-1
> >too?!
though.....
> 20A.
> >discontinued?
> Bob . . .
> ( C.F. Kettering )
Subject: | Re: Wire and Screw Sizes Tutorial |
>lead ball.
Change that from 1 inch to 1 pound and you've got it.
Gauge represents the number of lead balls of the diameter of the shotgun
bore required to weigh one pound. For example, the diameter of the bore of
a 12 gauge shotgun is 0.729 inches; 12 lead balls of this diameter weigh
one pound.
The sole exception to this is the .410 shotgun, which has a diameter of .41
inches (i.e., .41 caliber) and is actually 68 Gauge.
It may be spelled gage for wire, but I've always seen it spelled with a u
for shotguns.
From: | "Sam Hoskins" <shoskins(at)Globaleyes.net> |
Subject: | Thanks, and Happy Trails.... |
Bob Nuckolls,
My Quickie Q-200 is re-wired and back in the air! I'm getting ready to
un-subscribe, but before I do I just wanted to thank you for the great
service you provide here.
I first encountered you at last year's Tandem Wing Coffey Break in Kansas
where you gave a one hour talk. To tell you the truth, I wasn't expecting
all that much. Maybe something on soldering technique, or what's the best
alternator for homebuilts. But, as your discussion went on it was apparent
that you were offering something unique and steeped in sound, rational
thinking.
I purchased your book and CD on the spot (the best $45 I ever spent), but
since I had already put 1,200 hours on my aircraft I wasn't quite sure what
I was willing to change.
A couple of months later I gave a PowerPoint talk to my EAA chapter
describing some basic principles from your book, and I titled the talk
"Homebuilt wiring; or If I Had To Do It All Over Again, This Is How I Would
Do It". Or something like that.
As the winter approached I had already decided to overhaul my engine and was
planning to replace my alternator with a B&C job. I started looking at the
wiring mess behind the panel and was trying to figure how I could adapt some
of your methods to my existing set-up. Finally, I just went after my plane
with a pair of wire cutters, and 20 minutes later the hangar floor was
littered with wire, switches, and circuit breakers.
Re-wiring was actually fun, as was doing my schematics and wire book. I
used the fuseblocks and main/endurance/battery bus approach and now I have a
much more reliable, and easy to troubleshoot, system. I also purchased your
low voltage warning light and it works great!
I now have five hours on the new system and everything seems to be working
well.
Your daily on-line response to problems and your advice is invaluable and
consistent. It is just terrific to have a first quality consultant so
readily available (not to mention so cheap)!
I no longer need the 15 or so daily e-mails so I will unsubscribe soon, but
I wanted to let you know how much I appreciate your service.
I hope to run into you again sometime and show you my plane.
Sincerely,
Sam Hoskins
Quickie Q-200 ~1,275 hrs
http://home.globaleyes.net/shoskins/page1.htm
Subject: | Re: Thanks, and Happy Trails.... |
Sam,
That's a very nice message for Bob and adequately expresses the
sentiments of many of us on the Aeroelectric List. Thank you for
taking the time to say what many of us feel.
Randy
F1 Rocket
http://mywebpages.comcast.net/f1rocket/
Date: Friday, June 27, 2003 1:16 pm
Subject: AeroElectric-List: Thanks, and Happy Trails....
> Bob Nuckolls,
> ready to
> Kansaswhere you gave a one hour talk. To tell you the truth, I
> wasn't expecting
> the best
> apparentthat you were offering something unique and steeped in
> sound, rational
> thinking.
> spent), but
> sure what
> How I Would
> engine and was
> looking at the
> adapt some
> my plane
> book. I
> now I have a
> purchased your
> workingwell.
> invaluable and
> soon, but
> Sincerely,
> Sam Hoskins
> _-
======================================================================_-
= - The AeroElectric-List Email Forum -
> _-
= !! NEWish !!
> _-
= List Related Information
> _-
Subject: | SD-8 Installation |
From: | "Edward O'Connor" <edwardoconnor(at)compuserve.com> |
I am about to wire up my RV for the SD-8 backup alternator and am running
out of places to put things. I searched the acehives but couldn't figure out
what to call my search. Tried the obvious but none answered my question.
My question is: Is it OK to mount the relay, the capacator, and the
regulator on the firewall side. Anyone have a picture they could E-Mail me
as to how you mounted these items on your project. RV-Pictures would be
really good. I have the main regulator mounted in the baggage compartment
but don't want to mount any more items in there if I can help it. Any advice
Ed OConnor RV-8/Panama City FL. I only get the digest of msg so a direct
e-mail in addition to post to list would be good for me. Thanks
Larry,
Pegasus Auto Racing Supplies stocks a special "reverse keyway" momentary
toggle switch for this very reason. Pegasus has these switches custom-made
by Carling. See Part Number 4422 on this page:
http://pegasusautoracing.com/pdfs/047.pdf (Note however that the switch has
solder lugs rather than faston terminals since racers seem to prefer solder
lugs. Apparently they haven't read the AeroElectric Connection!)
Chris Heitman (co-owner of Pegasus)
Dousman WI
RV-9A N94ME (reserved)
http://my.execpc.com/~cjh/rv9a.html
what I'm after.
Larry Bowen
Thanks Chris. I just wrestled with this tonight. I filed off the
keyway and assembled with some locktite type of stuff. Seems to be
holding nicely. I'll file your info away in case I need it next time.
LB
> Behalf Of C J Heitman
> Sent: Friday, June 27, 2003 10:03 PM
> Larry,
> keyway" momentary toggle switch for this very reason. Pegasus
> has these switches custom-made by Carling. See Part Number
> 4422 on this page: http://pegasusautoracing.com/pdfs/047.pdf
> (Note however that the switch has solder lugs rather than
> faston terminals since racers seem to prefer solder lugs.
> Dousman WI
> switchguard, they have to be mounted a certain way.
> Basically, the momentary-on needs to be opposite the groove
> in the neck that is used for the anti-rotation tab. The
> same -- the momentary on is opposite the groove. So using
> either of the switched purchased so far, the starter will
> engage as soon as the switchguard is flipped open, and stay
> engaged until the guard is closed. That's not what I'm after.
> Thanks,
> Larry Bowen
Subject: | A different way? |
I am about to close out the leading edge of the first wing of my
Glastar. I need to string the wiring first as the area is inaccessible
after leading edge closeout.
I would like to try something different. I am thinking of running two
heavy wires (Positive and ground out to the wing tip.) These wires would
be protected by a fusible link or a large breaker (one breaker for each
wing) and would be sized to carry the current for all of the items that
are on that wing. Near the wing tip there would be a bus that
distributes the power via solid state relays to the power consumers
listed below.
On each wing there would be
1. Landing light
2. Taxi Light
3. Navigation light
4. Strobe
5. Anything else.
There would be a fusible link at the distribution point for each relay.
Although if a link fused I would not have the option of resetting it I
would have the backups of the items in the other wing. If there were
Landing Light flashers they would be located at the wing tip bus. I
would not attempt to synchronize the flashing of the left and right
wings.
To control the relays I was thinking of running some Computer grade
10BaseT cable. There is a version to that is approved to run through
plenums in buildings and has a fire rating that I believe is similar to
that of aviation wiring.
Advantages.
1. I would not carry power through the airframe as a return wire would
be included.
2. If I wanted to add something in the future the 10 base T wiring has 4
or 5 more wires to control relays.
3. Switches should last much longer as they would be carrying only micro
amps.
4. Wiring is simplified. One pair for power and one cable for signal.
5. As the power feed will be a heavier gage than would be normally used
for any individual circuit the voltage drop caused by items with a
periodic high current drain (read strobes) should be minimized. With
less drain comes less electrical noise.
6. In the course of building the Glastar there are at least 3 mountings
and un-mountings of the wing that have to take place with only two sets
of wires this would be simplified. I plan to remove the wings one more
time after the time is flown off to paint them.
7. I could also use the remaining wires of the 10BaseT for some future
instrumentation (angle of attack, stall warning, or something that we
haven't though of yet)
I am planning on running two RG-400 wires out to the wing tip but don't
know their exact usage right now.
I would like to run the wiring through some sort of conduit my concern
is that the cable would be floating in the conduit and not tied down as
it is in spam cans. Would the cable chafe from being free inside of the
conduit or is this OK?
So what do you folks think? It is unconventional but is it OK?
Subject: | Re: SD-8 Installation |
For what it's worth, I mounted my regulator and capacitor on the front side of
the firewall. The relay mounts on a bracket placed behind the instrument panel,
over the fuel tank. I'm building a tailwind. The aircraft has not flown, but
I have two friends, one of whom has a SD-8 alternator on a Q-200 with the regulator
mounted on the firewall and another with a Glastar with the capacitor
mounted near an SD40 alternator. Both installations seem to work, so I'm not too
worried about mine.
Hope this helps
Subject: | Re: [VAF Mailing List] Alternator Quit |
>Are you using an ANL current limiter? Is that what blew? You have a fuse
>for your alternator field?
>I would post this question to aeroelectric-list(at)matronics.com (subscribe
>first if you're not already) and see what Bob Nuckolls says.
>)_( Dan
>RV-7 N714D
>http://www.rvproject.com
Dan, just ran across this note in my backlog of things to attend to,
wasn't trying to ignore the problem.
Did you hear more about the details of this event?
>----- Original Message -----
>From: "Gregory Bitzer" <gbitzer(at)cisco.com>
>To:
>Sent: Monday, June 09, 2003 10:23 AM
>Subject: [VAF Mailing List] Alternator Quit
> > Hey guys,
> > I had my alternator quit on me Friday. More specifically it was my
> > Alternator power lead breaker that quit. I wouldn't normally classify this
> > as an emergency except for the fact that I was IMC at 8,000 feet in some
> > pretty solid rain. Everything held together for me to shoot the approach
> > and land safely.
> > Has anyone run into problems when operating in rain? I was in some
>moderate
> > rain for about 25 minutes. Everything worked find when I replaced the
>fuse.
> > Unfortunately it was impossible for me to debug this in the air since I
> > used fuses rather than reset breakers.
> > Greg Bitzer
> > RV-6 Atlanta, GA
> > Get A Free Psychic Reading! Your Online Answer To Life's Important
>Questions.
> > http://us.click.yahoo.com/Lj3uPC/Me7FAA/ySSFAA/1yWplB/TM
> > Online help on this group at:
> > http://help.yahoo.com/help/groups/
( C.F. Kettering )
Subject: | Re: sizing of current limiters on the B |
lead
>Bob
>ANL20?
>Thanks
The ANL devices have fusing characteristics that approach
fusible links in terms of time-to-open at various, intermediate
current levels. Since the purpose of a b-lead fuse is to protect
the system against HARD fault (read 500-1000 amps) due to shorted
diodes in alternator, the actual size of the protection is not
terribly critical. The ANL limiters are made by a number of companies
but not all companies make all sizes. Bussman (see:
http://www.bussmann.com/library/bifs/2024.pdf
. . . does make a pretty good spread in the low current range
An ANL-35 or ANL-30 would be fine for the SD-20, an ANL-50
or ANL-60 for the 60A machine would do too. B&C stocks ANL-40
and ANL-60 which are the sizes used on their STC'd kits.
If push came to shove, I'd have no heartburn with an ANL-40
on the SD-20 alternator.
The SD-20 b-lead can also be protected adequately with the
big-dog cousin to the ATC plastic fuses. Theres a critter called
the MAXIFUSE (see:
http://www.bussauto.com/pdf/maxifuse.pdf
A MAX30 in a single fuse inline holder (available from many
automotive parts stores along with the fuse) would be fine
on the SD-20 as well. Probably less expensive and easier to
install than an ANL limiter and base.
I was hoping I'd see the topic move over to the aeroelectric-list, but I
don't think it did.
On the VAF list there were two more messages in the thread, talking about
cooling blast tubes and how water was probably the culprit. The discussion
never touched the questions I asked.
)_( Dan
RV-7 N714D
Subject: Re: [VAF Mailing List] Alternator Quit
fuse
> >)_( Dan
> >RV-7 N714D
> Bob . . .
> >To:
> > > Hey guys,
this
some
approach
> > > and land safely.
> >moderate
> >fuse.
I
> > > Greg Bitzer
> > > RV-6 Atlanta, GA
Sponsor ---------------------~-->
> >Questions.
http://docs.yahoo.com/info/terms/
> Bob . . .
> ( C.F. Kettering )
Subject: | Tach Auto Switch... |
I'm using a Subaru EA-81 engine which currently has a primary and backup
ignition. I'd like to setup a switch with two separate power feeds that
allows me to toggle between the two ignitions (only one should run at a
time). However, by having two power feeds into the switch I lose the
ability to switch the tach lead as well without installing another
switch which then becomes more complicated for basic operations. So I
started thinking about setting up an auto-tach lead switch for my tach
gauge (negative side coil based).
My thoughts are that if I used a basic relay that was powered by the
same wire that would power my ignition I could design a simple circuit
that would switch the tach lead based on which ignition was active.
However, since I'm switching the tach lead that is connected to the
negative side of the coil and my deep understanding of electronics is
limited, I was hoping to find out if my base idea was okay or if I'm
setting myself up for some unknown issues related to the coil/tach
operation. Also, if the relay switch of the tach lead is okay, would it
still be standard practice to put a diode on this small type of relay?
I hope this question isn't too basic and any input is appreciated.
Thanks!
Don Honabach
Tempe, AZ - 601HDS
>don't think it did.
Hmmm . . . understand. Can't help someone who doesn't want to
be helped . . .
Subject: | Re: A different way? |
>listed below.
>1. Landing light
>2. Taxi Light
>3. Navigation light
>4. Strobe
>5. Anything else.
Downstream circuit protection should have a fusing constant
a fraction that of the upstream protection. For example, a faulted
22AWG fuselink downstream of a 20A breaker will open the breaker
first. Suggest a ATC fuseblock for a remote distribution
bus.
>If there were
>wings.
>Advantages.
>be included.
Break one wire and everything quits . . .
>amps.
How long will they last if you don't do this? I'm flying 40 year
old rentals with original switches still in place . . .
The "wiring" may be simple but the total parts count in the system
has multiplied by factors of 10 or more . . . all othing things
being equal, reliability is inversely proportional to parts count.
Explain the physics to support this assertion.
Don't hook things up until the wings are on to stay. I'd venture
a guess that from same fleet of airplanes I fly, wings have never
been removed from most of them.
Henry Ford and Charles Kettering didn't worry about anyone's
endorsement before launching a new idea. It either flies or flops
on it's own merit and risks are never zero. Not all of their ideas
flew but when they did, the results were gratifying if not spectacular.
If you have a good foundation based on experience and/or considered
analysis of the fundamentals, then you can get a leg up on the
market by being there first. Your selling points have to offer
some combination of lowered installation time/cost, lower maintenance
time/cost, and/or increased service life by some factor that makes
it a compelling design.
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
All of those things live well on the firewall. Their service
life might be reduced by the extra temperature stresses but given
the huge number of accessories that live for many hundreds of
flight hours on the firewall, I suspect the differences would
be difficult to quantify reliably.
I wouldn't let any good firewall real estate go begging for
utilization if other spaces are cramped.
Subject: | Re: Velocity Strobe and Ammeter questions |
>Bob/Others -
>Just finished reading the 'Connection (many thanks) in preparation for
>designing/wiring my Velocity XL (www.velocityxl.com) and had a couple of
>quick (OK, mayber they're not quick, but straightforward at least) questions.
>First - I bleieve you recommend attaching both ends of the Whelen strobe
>shielding on composites. What's the best way to attach the AL foil,
>solder wire to it? I've installed a Molex connector for service at the
>strake-wing junction, what kind of connector would you recommend there,
>another Molex? And finally, would it be sufficient to put a ring terminal
>under the mounting screw for the ground connection at the light fixture,
>or should I solder the sheild to the housing, or what?
There is a bare, stranded wired IN ADDITION to the three insulated wires
under the shield. This forth wire is called a "drain wire" and its purpose
is to provide you with a convenient means for making electrical connection
to the shield-foil which is, as you've noted, impossible to make
connection with. You can extend the drain wire with a short piece of
wire, install a ring terminal and attach to mounting screw for fixture.
If you DON'T do this, in all probability, you won't know the difference.
>Second - I'm planning on going all-electric, probably with the Blue
>Mountain EFIS and a 20 vac-pad-mounted backup essential load alternator,
>and was wondering about placement of the shunt. The Z figure for canards
>shows it in the battery ground line to the canard bulkhead, which is were
>I would like to put it and measure the current to or from the battery
>regardless of configuration.
How would you use this reading? Drawing energy from either
battery in Z-14 assumes both alternators have crapped. If
you purposely load a battery even when one alternator is
still working, it should be done with the knowledge of an
accurate load analysis combined with considered preventative
maintenance of the battery. If you subscribe to this philosophy,
then having instrumentation to measure either battery current
or voltage while in flight becomes non-information.
> The dual-alt figure shows one shunt for each alternator to measure
> their individual currents, with which I'm not postive how I'd tell if the
> battery were discarging,
If your low voltage warning lights are dark, batteries
are NOT being discharged.
> . . . and I don't think is relevent if I only use the second alternator
> in the event of primary failure. Which setup would you prefer (and why)
> with my setup?
If you use B&C alternators or equal quality product in both
slots, likelihood of alternator failure due to hardware
issues is probably 1/10th that of alternators flying around
in spam-cans. Likelihood of dual alternator failure during
any single 3-hour flight is on the same order as having a
propeller or wing fall off.
A figure Z-14 system with NO instrumentation other than
low voltage warning lights is a VERY comfortable combination
to fly. It requires a minimum of pilot decision, action and
no extra-ordinary monitoring after failure for relaxed
continued flight to airport of intended destination.
Subject: | Re: Tach Auto Switch... |
I did exactly that, but did not fly with the plane
yet.
I used a relay whose coil is powered from the ignition
2 +12V circuit.
The default source (no power to the relay coil) is the
ign 1 negative side of coil. If the relay coil is
energized, then, I read the ign 2 negative side of
coil.
I tested this in my garage when I tried my engine and
it worked.
I did not install an additional diode, but I used an
automotive relay (those you can get as accessories for
anti-theft or remote starting systems).
See the relay mounted at the top of firewall near the
ignition system.
http://mthobby.pcperfect.com/ch601/images/DCP02042.JPG
Michel
--- Don Honabach wrote:
> Honabach"
> one should run at a
> switch I lose the
> installing another
> operations. So I
> switch for my tach
> was powered by the
> connected to the
> of electronics is
> was okay or if I'm
> the coil/tach
> is appreciated.
Michel Therrien CH601-HD
http://www.zenithair.com/bldrlist/profiles/mthobby
http://pages.infinit.net/mthobby
Subject: | Starter Off Switch with Single EI? |
I am installing single electronic ignition and will most likely upgrade to dual
at some future point. As I'm leaving the magneto withoutan impulse coupler on
the airplaneI'm going to wire my airplane such that the mag is grounded when
the starter is on (similar to Figure Z-11) An upper, spring loaded position on
the switch will activate the starter ground out the mag simultaneously. I can
see myself accidently hitting the starter when checking mag drop. What is the
best way to maintain the 'Starter is off once the Engine is Running' idea with
only one mag?
Right now I'm planning on running power for the strobe and starter through a 2-3
switch such that the starter isdisabled when the strobe light is on.Is there
a better way to get the 'Starter On=Mag Off' 'Engine Running = Starter Disabled'
idea?
Grant
In a message dated 6/28/2003 10:22:15 AM Mountain Daylight Time,
don(at)pcperfect.com writes:
> posted by: "Don Honabach"
> Thanks!
> Don Honabach
> Tempe, AZ - 601HDS
I am running duel MSD ignitions on my Ford and what i did was to use a triple
pole double throw switch. As you cycle between both Ignition systems the
third pole switches the positive lead going to the tach. Bob gave me the info on
sources for this switch a few months back. If ya want I will look back at my
files to find it. My problem was the first switch I ordered was physically too
big because I had already drilled out the holes for my Ign switch and the body
of it hit my transponder. I bought another one from a different vendor and
that one barely fit. If ya want I will dig out the one I didn.t use and and give
you the part #. I do remember it was not cheap.
Ben Haas N801BH.
Subject: | PIDG / Spade / Rachet Tool... |
Hey Everyone,
I'm going nuts with these Insulated PIDG-Spade Connectors and trying to
use some of my existing Racket Tools with PIDG dies.
What I notice is that the die for the connector is actually a little
bigger than the AMP PIDG connectors (i.e. the metal portion underneath
the insulation isn't quite as long as the racket based die). Accordingly
to an article that BK pointed me to on his site, it talks about crimping
1/3 back for the wire and 2/3 back for the wire's insulation. Since the
racket die is bigger than the crimpeable metal portion of the connector,
I end up with a crimp that starts at the beginning and another one that
ends at the end (if that makes sense).
I also found that Amp/Tyco has something called a Pro Crimper II and the
associated dies available for AMP PIDG connectors. Do I just need to buy
this or the one available at Aero-Electric? If that's the case, that's
great, just don't want to find out that I'm misunderstanding how the
crimp is supposed to work before adding to my crimper tool chest.
For what it's worth, I tried searching on AMP, Molex, and Ideal's
websites and wasn't able to find any documentation on using the
associated tools. For documentation on using other crimpers, just not
PIDG crimpers.
Thanks!
Don
Subject: | Follow Up Question - PIDG |
As a quick follow up. On the Insulated AMP PIDG connectors there is what
appears to be an open barrel that sort of funnels into the wire entry
point on the connector. When doing the 2nd wire insultation crimp, do
you crimp just before this barrel or do you crimp the barrel?
Thanks!!!
Don
Subject: | Re: PIDG / Spade / Rachet Tool... |
Don,
The tool you mention, the Pro Crimper, is the one I just bought, and I can
tell you it makes a pretty good crimp. The dies are a perfect fit. It does
both crimps in one go, and I simply can't pull the wire out after it's done.
However, the AMP dies are large too, just as you say. I think Bob's article
is talking about a very narrow-jawed crimp tool, that you have to use twice
to fasten one terminal (once for the wire, and once for the insulation).
However, with the Pro Crimper tool, rather than doing two separate thin
crimps across the PIDG connectors, it does two large crimps in one go, that
cover virtually all of the available grip, exactly as you describe.
If your tool is doing as I think, it's the same as the AMP tool. I've read
Bob's article "Anatomy of a Good Solderless Terminal Connection" and it seems
to meet all his requirements. If the crimp is supporting the insulation,
holding the wire properly, and is a strong mechanical joint, I can't think
there's a problem.
Hope this helps.
Nev
Subject: AeroElectric-List: PIDG / Spade / Rachet Tool...
> Hey Everyone,
> PIDG crimpers.
> Thanks!
> Don
I have heard that starter damage occurs when the engine kicks back. This can occur
after a failed start as you release the start switch and the engine is still
turning. The now-ungrounded mag fires just before the engine reaches TDC and
you potentially damage the starter. One 0-200 owner said he gets 3 kick backs
per starter before it has to be replaced (this was with an impulse-coupled mag)
I took this to heart on my Q200 and installed a circuit to disable the mag for
a few seconds after the starter switch is released. It's very simple and requires
no power other than the starter power. Take the switched 12V starter power
through a diode to a relay coil. Connect the relay contacts to the mag to ground
it during start. To keep the relay energized for a few seconds after the starter
is released, put a large capacitor across the relay coil. The relay will
close when you press the start button and open a second or 2 after you release
it. Probably a good idea to allow the circuit to be disconnected from the mag
in an emergency. I grounded the mag on the tach side of a 1/4A panel mounted
fuse powering the tachometer.
I have been using this for 80 hours. EI on the left, mag on the right. Works great.
You can tell it's working because the tach stays at zero for a couple of
seconds after start. I know it doesn't solve your concern about activating the
starter in flight but you may want to consider it to protect your starter with
a non-impulse mag.
David Chalmers
-----Original Message-----
Subject: AeroElectric-List: Starter Off Switch with Single EI?
only one mag?
idea?
Grant
Way to go Tom!
I have been looking at a simple way of doing this on a single conductor +ground.
There are lots of possibilities. As Bob would point out, maybe with some increase
of complexity. And although this may be true, weight savings is a driving
force.
But consider that not all the wiring goes to the end of the wing. Some goes to
fuel pumps, sensors, flap motors, speed brakes, whatever...
Lower voltage drop does not correlate with low noise. Remember resistive spark
plug cables are quiet. Consider coaxial cable with the shield as ground. if the
outer insulation wears through, no problem. Or consider good quality twisted
or flat two wire lamp cordage, it is very good stuff, and it comes in 105 DegC.
Good luck,
Eric M. Jones
113 Brentwood Drive
I'm not going to buy my kids an encyclopedia. Let them walk to school like I did.
Yogi Berra
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
Subject: | Voltage Regulator |
At this price of $10, why wouldn't something like this solid state voltage
regulator from J C Whitney work?
http://www.jcwhitney.com/productnoitem.jhtml?CATID=42320&BQ=jcw2
I suggest one could buy two or three and have a spare or two.
Larry in Indiana, RV7 Tip-up TMX-O-360
Working on Finish Kit
Aviation in itself is not inherently dangerous. But ..... is terribly
unforgiving of any carelessness, incapacity or neglect.
..Author unknown
Nev,
Thanks for your comments and help!
Do you happen to have a picture of spade terminal or similar that has
been crimped with the AMP Pro Crimper? Sometimes just seeing what the
preferred tool is supposed to do would tell me if the one I have is
essentially the same. I've searched the Internet and haven't been able
to find one. I was especially surprised that I couldn't find a picture
or tech document on Amp/Tyco's that would show a proper crimp using
their tool.
For what it's worth, I'd prefer to go the ratchet route. Just played
around with the non-ratchet crimper and somehow ended up crimping so
hard that I broke the wire inside (wire insulation was removed clean
with no nicks and the wire wasn't moved much at all before testing on
the fuse block). I'm sure I could get the hang of it, but I'd rather get
known repeatability.
Thanks!
Don
From: Neville Kilford [mailto:nkilford(at)etravel.org]
Subject: Re: AeroElectric-List: PIDG / Spade / Rachet Tool...
Don,
can tell you it makes a pretty good crimp. The dies are a perfect fit.
It does both crimps in one go, and I simply can't pull the wire out
after it's done.
article is talking about a very narrow-jawed crimp tool, that you have
to use twice to fasten one terminal (once for the wire, and once for the
insulation). However, with the Pro Crimper tool, rather than doing two
separate thin crimps across the PIDG connectors, it does two large
crimps in one go, that cover virtually all of the available grip,
read Bob's article "Anatomy of a Good Solderless Terminal Connection"
and it seems to meet all his requirements. If the crimp is supporting
the insulation, holding the wire properly, and is a strong mechanical
joint, I can't think there's a problem.
Hope this helps.
Nev
> Hey Everyone,
> to use some of my existing Racket Tools with PIDG dies.
> Accordingly to an article that BK pointed me to on his site, it talks
> about crimping 1/3 back for the wire and 2/3 back for the wire's
> insulation. Since the racket die is bigger than the crimpeable metal
> portion of the connector, I end up with a crimp that starts at the
> beginning and another one that ends at the end (if that makes sense).
> the associated dies available for AMP PIDG connectors. Do I just need
> to buy this or the one available at Aero-Electric? If that's the case,
> that's great, just don't want to find out that I'm misunderstanding
> how the crimp is supposed to work before adding to my crimper tool
> chest.
> PIDG crimpers.
> Thanks!
> Don
direct advertising on the Matronics Forums.
Listers,
Does anybody know of a source for the right size alternator belt for a
Lycoming IO360. Hopefully automotive or industrial. I hate to have to
pay Lycoming's price.
Local car mechanic matched the cross section but that size is not made
in very many lenghts, just too long and too short. Cars don't use
individual belts anymore.
Thanks Jim Bean
RV-8 engine room
Hi Tom,
I will leave the electrical advise for those more qualified.
As for the wires inside channels or tubes:
PVC water tubing is being used by quite a few that I have seen. The diameter
is of course determined by the expected number and size of wires etc. that
will pass through.
I am building an RV-6A and I chose to use light weight black vinyl water
tubing about 3/4" dia. though Vans supplies a good ribbed tubing that is
very light weight.
To stop the wires from suffering abrasion damage use a full double length
plus some extra of nylon cord that will stay in the tube with the wires.
Go to an upholstery shop or a sewing supply store and get some of the white
upholstery padding used to make soft cushions. the material I am talking
about looks like coarse cotton batten.
This material is white in color and will not rot.
You will not need much to make a suitable number of little pads that then
can be tied into the cord at close enough intervals to Act like a series of
gun cleaner pads that will hold the wires etc. in place.
The cord will tied at the ends to form a loop that will hang out of the tube
at both ends.
The pads will be tied along the length of one side of the loop.
With the padded cord in place the wires will stay lightly snug.
With a helper at the other end, the loop can be used to pull or snake wires
in or out what ever the future need may be.
Happy building,
Jim
Subject: AeroElectric-List: A different way?
>SNIP<
Subject: | Re: Alternator Belt |
Get the metric equivalent. There are about 2.5 cm to the inch so their
lengths have more options...about 2 and 1/2 times as many. If you need
matched sets, just buying the same metric length will give you a good set
without added expense.
W.W. Grainger has a very wide selection but I did not see metric sized belts
on their web site. Pages 256-262. I believe that many auto parts
distributors have the v-belts in metric sizes.
Subject: AeroElectric-List: Alternator Belt
> Listers,
> Thanks Jim Bean
> RV-8 engine room
Gates has metric sized belts so if you can find a Gates distributor...
> Listers,
> Thanks Jim Bean
> RV-8 engine room
As far as I know, the NAPA brand belts handled by NAPA are made by Gates. I
had to try a few different sizes before I found one that fit OK on my IO-360
but they were real good about letting me return the ones that didn't fit.
> > Listers,
> > Thanks Jim Bean
> > RV-8 engine room
>Listers,
>Thanks Jim Bean
>RV-8 engine room
The belt can vary depending on your starter ring gear
size and alternator attach hardware and its pulley size.
Many stores will exchange a belt if you take the wrong size
one home to try. A well stocked auto parts store will have
what you need, just check with them before you buy about
exchanging for another size if needed.
Call B&C at 316.283.8000 and talk to Bill. He'll be able
to ask you some questions that will let him get you very
close to the right belt the first time.
Bob .. .
>can occur after a failed start as you release the start switch and the
>engine is still turning. The now-ungrounded mag fires just before the
>engine reaches TDC and you potentially damage the starter. One 0-200 owner
>said he gets 3 kick backs per starter before it has to be replaced (this
If he would throw away the key switch and put in toggles + a push
button, the
problem goes away . . .
>for a few seconds after the starter switch is released. It's very simple
>and requires no power other than the starter power. Take the switched 12V
>starter power through a diode to a relay coil. Connect the relay contacts
>to the mag to ground it during start. To keep the relay energized for a
>few seconds after the starter is released, put a large capacitor across
>the relay coil. The relay will close when you press the start button and
>open a second or 2 after you release it. Probably a good idea to allow the
>circuit to be disconnected from the mag in an emergency. I grounded the
>mag on the tach side of a 1/4A panel mounted fuse powering the tachometer.
>Works great. You can tell it's working because the tach stays at zero for
>a couple of seconds after start. I know it doesn't solve your concern
>about activating the starter in flight but you may want to consider it to
>protect your starter with a non-impulse mag.
See figure Z-11 of http://www.aeroelectric.com/articles/Rev10/z10.pdf
This shows how to take two spring loaded toggle switches
for magneto control and wire the starter engage circuity
through the switches such that starter cannot be engaged
with the non-impulse coupled mag ON.
Works with either a mag or EI on the left side.
>dual at some future point. As I'm leaving the magneto withoutan impulse
>coupler on the airplaneI'm going to wire my airplane such that the mag is
>grounded when the starter is on (similar to Figure Z-11) An upper, spring
>loaded position on the switch will activate the starter ground out the
>mag simultaneously. I can see myself accidently hitting the starter when
>checking mag drop. What is the best way to maintain the 'Starter is off
>once the Engine is Running' idea with only one mag?
If you wire per Z-11 with EI on left mag, then the engine will start
on electronic ignition . . . this takes care of pre-flight for the
electronic ignition. After engine starts, turn right mag on. This
disables starter. Turn EI off to pre-flight the right mag. Starter
is still disengaged. Turn EI back on and finish your checklist.
>a 2-3 switch such that the starter isdisabled when the strobe light is
>on.Is there a better way to get the 'Starter On=Mag Off' 'Engine Running
>= Starter Disabled' idea?
Don't understand why you think you need to do this . . .
BTW . . .The mag drop test has significance
for a pair of identically timed mags but is meaningless
with a mixture of systems. The best test is to simply see
that the engine runs smoothly on either ignition system
irrespective of observed RPM variations between the two
systems.
>Nev,
>their tool.
Suggest you check out articles at
http://www.aeroelectric.com/articles/terminal.pdf
and
http://www.aeroelectric.com/articles/rules/review.html
There's more to it than looks . . . with some practice
you can use a non-rachet tool . . . but when a ratchet
tool is so inexpensive
http://www.aeroelectric.com/Catalog/tools/tools.html#rct-1
http://www.aeroelectric.com/Catalog/BCcatalog.html
Why struggle with it?
You can use a two-shot hand tool but I prefer the single stroke
tools similar to that cite above.
The article just talks about how to check your tool and technique
irrespective of the type of tool you use.
Subject: | Re: Voltage Regulator |
The picture shown doesn't match the part. For that series
of cars, you get a regulator like the Standard VR166
which I've referenced many times as a "generic Ford" regulator.
You can get them even cheaper yet. See
http://www.globemotorists.com/TVI%20Products/tvi_voltage_regulators.htm
Even this link doesn't tell you what the VR166
looks like. See:
http://www.aeroelectric.com/temp/Generic_Ford_Reg.jpg
Show this picture to any parts store. Tell them you want one
that looks like this. As far as I know, this package was unique
to that one series of Ford Motor Co products and any regulator
you get that looks like this will work. The link I cited above
gives bunch of cross-reference numbers by various manufacturers.
A while back I posted a message to the list saying that my import turn
coordinator was so noisy it made my radio transmissions unreadable. Bob referred
me
to his article on "Hammering the Radio Shack 270-030 filter into submission"
Well to make a long story short, I bought the filter kit for $4 and put it
together per Bob's instructions, installed it in my RV-8A and now my radio
works great!
Thanks, Bob......
Walt Shipley
Greeneville, TN
Don:
Try the MSD Tach Splitter which has two diodes installed so that you can
select either ign and see the tach indication on a single tach.
PeterVC
From: | Alexander Balic <alex157(at)direcway.com> |
Subject: | Canard Pusher Ground System |
Bob/everyone,
I have the Z-15, and it seems to show ground going from the battery to a
post on the foreword ground bus. Then a second #2 cable going from the
foreword ground bus to the rear mounted ground bus. Then a 3rd cable (or
strap) going to the engine to ground bus for the starter/alternator. I
spoke with Tim at B&C, he said that he would not want to see 3 bolt
connections between the battery and the engine case. If I have the engine
gauges (obviously in the rear), and some ground to the engine block, and
some don't - (fuel pressure comes to mind) so Tim suggested that I run the
ground to the block directly, then use the strap to go to the firewall
mounted ground buss, then run say a #6 up to the front from the rear ground
to front ground buss, so then I can ground the instruments at the front, and
even though the senders ground to the case, the instrument grounds run back
there before going to the battery. Please let me know about this, I am at
this point, and need to get some copper flying!! :)
Alex
Subject: | KX155 Pin Identification |
Hi all,
Could someone please point me to a diagram that defines the pins on a
King KX155 Nav/Com?? I have the wiring diagram but have not been able
to determine which pin on the radio represents which pin on the diagram.
I know - sounds pretty silly but I can't see any markings on the radio
other than an "S" (even took the covers off).
Thanks!
Jon Finley
N90MG Q2 - Subaru EJ-22 DD - 450 Hrs. TT - 1 Hr Engine
Apple Valley, Minnesota
http://www.FinleyWeb.net/default.asp?id=96
Subject: | RE: Crimp tools for Molex Avikrimp or PIDG terminations |
Gaylen,
Thanks a million - this is exactly what I was looking for. The pictures
answer all my questions. I've been surprised that you can purchase a
pair of cheap crimpers and they don't even have instructions - seems a
little odd since we aren't born with the knowledge of how to do a proper
crimp or more importantly how to crimp the terminal as the engineer's
invisioned to provide a robust connection.
Thanks Again!
Don
Here is our "How To" page for mil spec termination crimping:
http://www.terminaltown.com/Pages/Page7.html
Subject: Crimp tools for Molex Avikrimp or PIDG terminations
Don:
Check out our Eclipse 300-054 tool and the 300-058 die set or the
Sargent SC4140 tool with dieset. Both are ratcheted tools and these die
sets will do the double crimp in one operation.
http://www.terminaltown.com/Pages/SargentBrandCrimpers.html
http://www.terminaltown.com/Pages/EclipseCrimpTools.html
Best Regards,
Gaylen Lerohl
Subject: | Crimper - Saga ... |
Hey Everyone,
I was talking with an engineering friend and he mentioned that they also
make ratchet crimpers that put 3 crimps on the wire and one crimp on the
insulation. This sounded like a neat idea, but he then added that it's
only used for high high high end stuff like satellites, etc. In any
case, I was curious if any one had any experience with these crimpers -
where to buy, how much, overkill, etc.?
Thanks!
Don
Subject: | Re: KX155 Pin Identification |
Jon,
I have one of those Quik Shot books
http://www.qsproducts.com/
It has the pinouts for the kx-155.
If you want to borrow it or anything.
Jon Finley wrote:
> Hi all,
> Thanks!
> Jon Finley
Subject: | Re: Crimper - Saga ... |
>Hey Everyone,
I'd like to know of the brand and part number of such a
product. I cannot imagine how this makes any sense. Consider
that the "wire" crimp in a PIDG or about any other small
terminal has a wire engagement length of perhaps .125" and
often less. Consider further that the ultimate goal of
making a terminal and wire become a single entity is
satisfied by the "gas tight" interface achieved by pressing
the two malleable metals into such tight proximity that
gasses at the molecular level are excluded. If this can
be achieved with what might be called a 'single crimp'
used to attach hundreds of millions of terminals over the
past 60 years, I'm having trouble visualizing how (a)one
can even split that .125" of wire grip area into three
separate regions and (b) what might be gained by such an
effort assuming it was even possible or practical.
Subject: | Connecting Whelen Strobes |
AeroElectric-List message previously posted by: "Robert L. Nuckolls, III"
>Bob/Others - First - I bleieve you recommend attaching both ends of the
Whelen >strobe shielding on composites. What's the best way to attach the AL
foil,
If you DON'T do this, in all probability, you won't know the difference.>>
6/29/2003
Hello Bob Nuckolls and Bret Ferrell, I'd like to flog this horse a few more
lashes.
1) Bob Nuckolls really says the drain wire should be attached at both ends on
a composite aircraft? But not on a metal aircraft? Why?
2) When one receives the strobe light installation kit from Whelen the cable
already has two AMP plastic 3 wire connectors attached, one on each end. These
connectors are the ones that plug into the mating 3 wire connectors at the
strobe light ends. After cutting the cable somewhere in the middle and snaking
those two cut ends through the airframe to the vicinity of the strobe power
supply one installs the other two (different) appropriate 3 wire connectors
provided by Whelen and plugs the cables into the power supply.
3) The installation instructions say that the drain wire should be connected
to the housing / mounting of the power supply. Easy enough to do by leaving
the drain wire longer when you cut the cable, strip it, and install the 3 wire
connectors that plug into the power supply.
4) But out at the strobe light end of the cable where the Whelen installed
connectors are, Whelen has left no access to the drain wire. I suppose one could
cut back the plastic covering, remove the aluminum shield, attach a short
wire to the now exposed drain wire, and then attach that short wire to some metal
part of the strobe light housing, but I find this action both puzzling and
unnecessary.
5) Whelen has thousands of these units in service throughout the skies
mounted on both metal surfaces and composite wing tips. I am unaware of any need
to
go through the additonal effort of connecting the drain wire to the metal
light housing out at the strobe light end. Can anyone show me different?
>Hi all,
>Thanks!
See http://216.55.140.222/Installation_Data/KX155.pdf
Physical pin numbering is usually marked right on the
back of the connector. They tiny raise letters molded
on and same color as connector body. I find them useful
mostly for getting connector oriented correctly on installation.
I use a white or yellow ink pen to put a dot on every 5th
terminal location so that I can easily "count" the holes
for proper wire location when inserting a pin.
From the wiring aid I've published above, I infer that
the A1 connector is mounted upside down compared
to the A2 connector where pin designations increase in
order from left to right. I'm sure there is some reasonable
engineering explanation for this seemingly perverse
decision but be careful that you account for this as
the parts all come together.
Subject: | Re: Canard Pusher Ground System |
>Bob/everyone,
You didn't say what kind of airplane you were building and
wether or not you have an amidships battery. In any case,
you may have instruments for engine parameters that are
saddled with crankcase ground senders. This suite of instruments
works best with their own ground wire (20AWG is sufficient)
to bring crankcase ground forward to those instruments that
get signals from crankcase grounded senders.
If you don't have an amidships battery, then you don't need
a robust ground point at the firewall. The firewall ground
bus and the braid jumper can be eliminated if you wish by
taking the main ground all the way to the crankcase. Having
the "extra" set of bolted joints in the ground path is
not a great sin as long as you use robust brass hardware
(5/16 minimum, 3/8 better). I think it's cleaner to go
from aircraft structure to the crankcase with braided
strap or welding cable (much more robust with respect to
vibration/flexure stresses). If you're using welding cable
for the main ground wire, and no battery behind the seats,
then by all means take it all the way to the crankcase.
But count on a separate ground for the engine instruments
plagued with local ground senders.
If you have components on the firewall that depend on the
firwall for ground, THEN you'll need to bond the firewall
to the crankcase too. A braid strap or welding cable jumper
would be fine . . . they can be small if they don't carry
starter current.
If it were my airplane, I'd wire it per
http://www.aeroelectric.com/articles/Appendix_Z_Drawings/z15ak.pdf
and ground crankcase referenced engine instrumentation to the
firewall ground bus.
Subject: | Re: Success Story |
>referred me
>works great!
>Thanks, Bob......
The laws of physics are a wonderful thing . . . especially
when understanding them can make life more pleasant.
You are most welcome my friend . . .
>> I'd like to know of the brand and part number of such a product. I
My engineering friend works at a defense company and designs test
equipment for the various projects, etc. Next time I'm in touch I'll try
and get further information. For what's it worth, he just uses an
inexpensive AMP non-ratchet style crimper that requires two manual
crimps and has been quite happy with it. He told me about the 3/4
crimper as an FYI type of thing.
>> Consider that the "wire" crimp in a PIDG or about any other small
terminal has a wire engagement length of perhaps .125" and often less.
Does that mean that the wire should be stripped to .125"? If I measure
the a RED PIDG Spade connector, it appears that there is .250" of wire
available to crimp and ~.125" for the insulation crimp. I've taken a
picture to make sure we're on the same page and put black lines to show
the two areas I'm referring to - http://zodiac.pcperfect.com/PIDG-1.jpg
Also, I took another picture just to make sure I'm understanding where
the wire's insulation should stop and the wire should start. I'm
assuming and have been told that the insulation should not go into the
wire crimp area. In other words, stop right at the funnel entry point.
Here's another picture that might help -
http://zodiac.pcperfect.com/PIDG-2.jpg
For what it's worth, I'm sure that I'm going overkill on this matter,
but I just want to make sure I understand the process or more
importantly the 'right process' for the task.
>> If this can be achieved with what might be called a 'single crimp'
used to attach hundreds of millions of terminals over the past 60 years,
I'm having trouble visualizing how (a)one can even split that .125" of
wire grip area into three separate regions and (b) what might be gained
by such an effort assuming it was even possible or practical.
Wow! I'm really surprised to hear the argument from you Bob. Starting to
justify something by the fact that it's been used for over 60 years.
Isn't this the same argument that goes into the Avionics Bus Switch and
so on... (sorry couldn't resist - smile).
Seriously, I'm just trying to understand and if a 3 crimp connection is
even possible, it's benefits might be none or just perceived. My hopes
though is to find out or at least better understand the thinking behind
the processes.
Thanks!
Don
From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net]
Subject: Re: AeroElectric-List: Crimper - Saga ...
>Hey Everyone,
>also make ratchet crimpers that put 3 crimps on the wire and one crimp
>on the insulation. This sounded like a neat idea, but he then added
>that it's only used for high high high end stuff like satellites, etc.
>In any case, I was curious if any one had any experience with these
>crimpers - where to buy, how much, overkill, etc.?
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
Subject: Re: AeroElectric-List: A different way?
would
>listed below.
>1. Landing light
>2. Taxi Light
>3. Navigation light
>4. Strobe
>5. Anything else.
bus.
Each Relay would have it's own fuseable link sized to the intended load.
Could also be a Fuse.
>If there were
>wings.
>Advantages.
>be included.
That is true but. Loosing the lights on one wing isn't tragic, it could
be monitored to give an indication of failure of either the left or
right wing bus and finally properly installed the chance of loosing a
bus wire is probably quite low.
micro
>amps.
Just replaced all of the switches in my 31 year old Cessna 150 and they
had been replaced at least once before.
Remember I am removing the bundle of individual wires that are normally
strung out to the wing for the individual components and replacing it
with a cable. My guess is that a cable has a higher reliability than a
bunch of hand strung individual wires.
The power feed will be of a gage to handle all of the items for the wing
including the landing/taxi lights. Therefore it will be of a heavier
gage than would normally be used to just wire a strobe. With a thicker
wire comes lower resistance.
Unfortunately I don't have that option. The Glastar is a strange beast
the wings have to come of a minimum of two times during construction. In
addition if I want to run the wires through the leading edge I need to
do it before the wings are mounted. The area isn't accessible afterward.
I may get around this by using conduit and pulling the wires later.
spectacular.
maintenance
>Bob,
I mis-poke there. The wire grip for an open barrel pin is typically
.125" A machined D-sub is about .180" I just pulled a red and
blue PIDG terminal apart an measured wire grips of .170" A yellow
is .250"
If in doubt, pull the insulating sleeve off a terminal in question
and see how long the wire grip is.
That's right . . insulation should not extend into the wire grip
area. See:
No, the avionics bus was never justified based on
physical fact verifiable by repeatable experiment. It was
a POLICY based on the best guess anyone had at the time.
Solderless connector technology has been spec'd and tested
out the wazoo . . . I can cite dozens of documents which
all suppliers must observe if they expect to sell to the
US military or aerospace industry.
>the processes.
Understand. I just finished photographing some figures for
an article that I hope to finish tonight. It will be
an adjunct to the "anatomy" article.
>Thanks!
>Don
>To: aeroelectric-list(at)matronics.com
> >Hey Everyone,
> Bob . . .
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( and still understand nothing. )
( C.F. Kettering )
Thanks your follow up comments and help. I hope the new 'anatomy'
article is going well. Will it be a available as an update to the
existing AeroElectric Book or a special article published on your
website?
On a happier note - since I got side tracked on the PIDG connectors this
weekend and couldn't get any productive plane work done, I decided to
wire up the serial connectors for my EFIS and GPS units. In the process
of mounting the DB9 connectors I used a punch set I purchased a few
years back. Spent way too much money on it back then, but it's
definitely made this job incredibly easy and leaves a professional hole
for the connector.
Thanks again,
Don Honabach
Subject: RE: AeroElectric-List: Crimper - Saga ...
>Bob,
>try and get further information. For what's it worth, he just uses an
is .250"
area. See:
>years, I'm having trouble visualizing how (a)one can even split that
>.125" of wire grip area into three separate regions and (b) what might
>be gained by such an effort assuming it was even possible or practical.
>to justify something by the fact that it's been used for over 60 years.
>the processes.
>Thanks!
>Don
> >Hey Everyone,
> >crimp on the insulation. This sounded like a neat idea, but he then
> >added that it's only used for high high high end stuff like
> >satellites, etc. In any case, I was curious if any one had any
> >experience with these crimpers - where to buy, how much, overkill,
> >etc.?
> Bob . . .
( C.F. Kettering )
Ben,
Thanks for the reply and information. I wish I would of known about the
switch beforehand. I don't have a lot room around the area where my
ignition switch is going and a larger switch probably wont fit.
Thanks for the offer though.
Don
From: Benford2(at)aol.com [mailto:Benford2(at)aol.com]
Subject: Re: AeroElectric-List: Tach Auto Switch...
> backup ignition. I'd like to setup a switch with two separate power
> feeds that allows me to toggle between the two ignitions (only one
> should run at a time). However, by having two power feeds into the
> switch I lose the ability to switch the tach lead as well without
> installing another switch which then becomes more complicated for
> basic operations. So I started thinking about setting up an auto-tach
> lead switch for my tach gauge (negative side coil based).
> it still be standard practice to put a diode on this small type of
> relay?
> Thanks!
> Don Honabach
> Tempe, AZ - 601HDS
triple
info on
at my
physically too
the body
and
and give
Ben Haas N801BH.
Michel -
As always - thanks!!!!
Don
yet.
2 +12V circuit.
coil.
it worked.
automotive relay (those you can get as accessories for anti-theft or
ignition system. http://mthobby.pcperfect.com/ch601/images/DCP02042.JPG
Michel
> Honabach"
> one should run at a
> switch I lose the
> installing another
> switch for my tach
> was powered by the
> connected to the
> of electronics is
> was okay or if I'm
> the coil/tach
> is appreciated.
Subject: | Re: AeroElectric-List Digest: 30 Msgs - 06/28/03 |
Jim:
My Glasair (IO-360 Lyc.) with B&C L-60 needs the Gates 7315 (available at
reasonable price from B&C, by the way, they just need to know which of the
two alternator drive pulleys your ring gear has). It's dimensions are
9.5/10mm x 815mm.
If you have "the other one" (I forget which I have) there's another size
available. Call B&C after measuring the diameter of the pulley, and they
can fix you up either way.
Ron Cox
> From: Jim Bean <jim-bean(at)att.net>
> Listers,
> Thanks Jim Bean
> RV-8 engine room
Subject: | Fw: AeroElectric-List Digest: 30 Msgs - 06/28/03 |
Jim:
9.5/10mm x 815mm.
Ron Cox
> > Listers,
> > Thanks Jim Bean
> > RV-8 engine room
Subject: | Fw: RV-List: Vans Amp Gauge |
I am forwarding Wheeler's problem to the Lectric List. I'd like to read the
answer to this one myself.
Subject: RV-List: Vans Amp Gauge
> --> RV-List message posted by: Wheeler North
> Guys,
> I'm getting a little fed up with Van's amp gauge, and in particular with
> their lack of response to the fact that it is a bad design.
> I haven't talked to them about it in a while, but I will share with you
the
> saga so far.
> 1. It has never read correctly in that when I turn things on it doesn't
seem
> to change much (when reading alternator load) unless its a major user like
a
> light going on.
> 2. It goes massively haywire when the either radio is in xmit, and I have
> met dozens of folks with this problem.
> 3. It is the only Amp gauge I have ever seen that needs a postive and
> negative source along with the shunt lines. Consequently when the master
is
> activated it then provides a path for current to bypass the instrument
> circuit breaker when wired as per Vans schematic. If the amp gauge power
> source is disconnected Item 2 stops happening to the other Vans gauges
which
> go wacky with xmit.
> 4. I was doing some work troubleshooting a serial data problem this week
so
> I had my Fluke 99 DSO out there and decided to get a hard measure of the
> alternator load with various devices turned on. It turns out that this amp
> gauge is misreading by 14 amps, ie it reads zero until there is 14 amps
> going through the shunt. (my charging system is set up so I can switch the
> gauge between reading battery charge, or alternator load)
> Now you might think "well you must have a bad gauge" Well, I have two of
> these brand new bad gauges, as well as two of the shunts, and no
combination
> of them makes this system read correctly. I even took them completely out
of
> the aircraft and hooked them up to my recently calibrated power supply and
> found that the shunt V drop was normal, but the gauge would not read until
> the current got fairly high (My little pwr supply does not put out 14
Amps).
> Now, how do I feel about this. Well, I attempted to solve this several
years
> ago with Vans and they were very resistant to the idea of there being a
> problem. If it were happening in certified aircraft they would have had an
> AD slapped upside their putzy gauge in seconds as this design is
potentially
> very dangerous.
> So those of you who are considering this line of gauges, be forewarned,
> there are still some bugs in this design, and I'm not the only one who has
> had these problems. I strongly recoommend if you are using this gauge, get
a
> valid means to assess actual current flow through the shunt. In this
> installation I could have a 13 amp discharge and the unit would say all is
> well.
> I guess I should try talking with Tom G about it again and see if they
would
> ever be willing to look into the problems this design is having.
> Any thoughts folks???
> I like the gauge face, maybe I can swap it into a real amp gauge and just
be
> done with it. ;{)
> W
From: | "Neville Kilford" <nkilford(at)etravel.org> |
Don,
It sounds as though you have the information you need, but I've gone ahead
and put a couple of pictures on the web. Have a bins at
http://uk.photos.yahoo.com/nk1414 to see a picture of the tool and a
completed crimp. The pictures are lacking somewhat, but are okay. They're
on page 2 of the plane pictures.
Hope this helps.
Nev
Subject: RE: AeroElectric-List: PIDG / Spade / Rachet Tool...
> Nev,
> their tool.
> Thanks!
> Don
Nev,
Thanks for the picture. I also noticed that you went with what looks
like the AMP ProCrimper II tool.
In my attempts to understand how to do a proper crimp and quite honestly
failing at it, I decided to go ahead and purchase the ProCrimper II from
AMP in a PIDG Kit that includes the PIDG die and a few PIDG terminals.
My hunch is that this probably wasn't necessary, but I still didn't feel
comfortable that the crimps I was doing were top notch. I've had a few
wires break in the Terminals even though the original wire strip was
clean. Have to assume I crimped too hard or the wire length/insulation
crimp was wrong. I knew from the academic level from BK's articles what
was necessary to do a good crimp, but with a manual crimper I just
wasn't sure I was in the proper range of crimp (not too tight, not too
loose). With the import ratchet crimper I have, I just wasn't sure it
was the right one for AMP PIDG connectors.
My hope was that someone would have had a picture of the front side and
back side of the terminal so I could so how the crimp itself looked and
it's exact location on the terminal. Unfortunately, I got quite a few
pictures, but none that I could directly compare and say - cool, I'm
doing the exact same thing.
Bottom line, I figured an AMP PIDG Connector and an AMP PIDG Crimper
will help my fears that the crimp isn't up to snuff. Also, if for some
reason the kit doesn't come with instructions I can also call AMP and
since I'm using their crimper and terminals I should be able to get some
help if still needed.
Thanks again!
Don
Don,
ahead and put a couple of pictures on the web. Have a bins at
They're on page 2 of the plane pictures.
Hope this helps.
Nev
> Nev,
> their tool.
> get known repeatability.
> Thanks!
> Don
My pleasure, and I entirely understand your sentiments. As Bob says, after a
while one would get to know the right degree of pressure, but I've only about
100 crimps to do in the whole plane, so, like you, I figured, what the hell?
If we're going to live up to the Aeroelectric mission, and produce better
electrics than a production plane, we need the right tools! In any case, 80
extra for a crimp tool is a drop in the ocean compared with the rest of
plane...
Cheers.
Nev
> Nev,
> Thanks again!
> Don
> Don,
> Hope this helps.
> Nev
> From: "Don Honabach" <don(at)pcperfect.com>
> To:
> > Nev,
> > their tool.
> > Thanks!
> > Don
Easy. Make one of your ignition switches a 2-pole, double throw
switch. Use one side of the switch to control one ignition system.
Use other side to control tach connection. When the ignition controlled
by this switch is ON, tach gets signal from this ignition. When ignition
controlled by this switch is OFF, tach signal wire is transferred to
the other ignition. If that system is ON, the tach works. If that system
is OFF too, then it doesn't matter that the TACH sees no signal.
>Bob,
>website?
Here 'tis . . .
http://216.55.140.222/articles/CrimpTools/crimptools.html
>for the connector.
Please don't rub it in!!!!! I have this love-hate relationship
with d-subs. Once mounted, and if you choose to use the solid-metal
pins, I think they're the biggest value out there in connectors.
But that gawdawful hole you have to cut to mount them neatly is
a real bear . . .
I've lusted after a set of Greenlee d-sub punches for 30 years.
they used to sell for just over $200 . . . about $1000 for a complete
set. Just after I sold the parts business to B&C, I had a wad
of cash burning a hole in my pocket and I had this really great
idea . . . I was going to get a set of d-sub punches.
Dug out the catalogs and to my dismay, found that the price
has risen to nearly $500 each. No way was I going to spend
over $2300 for these punches. I've been talking to a local
tool and die shop about making my own. They think they
could do it for about $150 each. Unfortunately, that project
is WAYYYYYYY back on the burners . . .
I'm jealous . . .
From: | "Phil Birkelbach" <phil(at)petrasoft.net> |
It is very difficult to find Category 3, 5 or 5e (this is what you are
calling 10BaseT cable) that is plenum grade and not solid wire. The
stranded type of Category 5 wire is used for making patch cables and since
patch cables seldom need to be run through the ceiling they don't usually
come in plenum grade. Solid wire is more prone to breakage. If it were me
(other arguments notwithstanding) I'd run a handfull of 24AWG Tefzel wire
through there.
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB (Reserved) - Canopy
http://www.myrv7.com
would
>listed below.
>1. Landing light
>2. Taxi Light
>3. Navigation light
>4. Strobe
>5. Anything else.
bus.
>If there were
>wings.
>Advantages.
>be included.
micro
>amps.
EVERY switch in the airplane was bad? I applaud the idea
of total replacement of switches as a preventative maintenance
measure in OBAM aircraft 'cause it's usually easy and inexpensive.
Spam cans seldom enjoy this reliability enhancing measure because
of the inflated cost of replacement parts combined with
mandated hi-dollar mechanical help.
Since we're talking about OBAM aircraft, your demonstration
of added value task is to trade off the parts-count and expense
of swapping out $5 switches that are easily replaced
with a few minutes of personal attention.
has multiplied by factors of 10 or more . . . all other things
Hmmmm . . . I don't have a basis upon which to agree with that.
Aside from allowing wiring to degrade with age to the point
where insulation begins to fail, wiring is just not very
high on the list of field service failures in airplanes
whether cabled or bundled.
Fine, but what does this have to do with "noise". If I add
a resistor in series with the ground wire of any product, what
principles of physics can we cite that suggest that the
system so modified becomes either an antagonist or victim
of noise?
???? . . . you can't prewire the wing-mounted equipment, run
wires to the wing root with sufficient excess coiled up
waiting to be run into the fuselage after last attach?
How would the proposed digitized-control/common-power distribution
system mitigate this situation? You still have n-number
of wires to get wing-stuff connected to fuselage-stuff irrespective
of how the wires function.
( C.F. Kettering )
Subject: | Re: Fw: RV-List: Vans Amp Gauge |
A buddy of mine is an RV builder (personally I do glass!). He says his
Van's amp gauge does the same thing.
He's sent to "complaint" on to Van's. I'll publish what they say about it,.
I care 'cos I just bought the same gauge for my "fast glass" and it's
sitting on my bench waiting for installation.
Neil
>From: "Wheeler North" <wnorth(at)sdccd.cc.ca.us>
>To: "''RV-List Digest Server ' '"
> > Guys,
>the
> > saga so far.
>seem
>a
> > light going on.
>is
>which
> > go wacky with xmit.
>so
>combination
>of
>Amps).
>years
>potentially
> > very dangerous.
>a
> > well.
>would
>be
> > done with it. ;{)
> > W
I've e-mailed Mr. North with some additional questions.
I'll post results of my findings after I've had a chance
to know more about the product and his difficulties with it.
switch. Use one side of the switch to control one ignition system. Use
Thanks again :)
My hope was to use both poles of the switch so I could have 2 separate
power feeds/circuits for the ignitions in the hopes of making a more
robust setup.
So unless I want to go with a big bulky 3 pole switch, I'm stuck with
using some sort of auto-switch that is feed by the iginition power
feeds.
Don
>installing another switch which then becomes more complicated for basic
>operations. So I started thinking about setting up an auto-tach lead
controlled
ignition
system
>> Dug out the catalogs and to my dismay, found that the price has risen
If you're still interested, Jensen Tools has some relatively low cost
ones availables (sub $200 for each size 9, 15, 25, and 37 pin)
Here's a link the list them:
http://www.jensentools.com/product/group.asp?parent_id=11760
If for some reason it doesn't come up, here are their part #s
190-286 - 9 pin
125-156 - 15 pin
125-158 - 25 pin
190-284 - 37 pin
Don Honabach
>Bob,
>website?
Here 'tis . . .
>this weekend and couldn't get any productive plane work done, I decided
>to wire up the serial connectors for my EFIS and GPS units. In the
>process of mounting the DB9 connectors I used a punch set I purchased a
>few years back. Spent way too much money on it back then, but it's
>for the connector.
a real bear . . .
I'm jealous . . .
>Neil
Neil, can you scan and e-mail me the installation instructions
for the instrument?
Subject: | A different way? |
are calling 10BaseT cable) that is plenum grade and not solid wire.
I haven't been following this thread very closely so if I'm off-base -
sorry.
I run Plenum CAT 5/5e cable a lot for my business and it's obvious that
the Tefzel(sp?) coated wiring is much tougher and would seem to me a
better choice. While not an expert, it was explained to me that the
plenum covering is a fire issue and does not provide extra protection
over the less expensive PVC coatings.
Don Honabach
From: Phil Birkelbach [mailto:phil(at)petrasoft.net]
> To control the relays I was thinking of running some Computer grade
> 10BaseT cable. There is a version to that is approved to run through
> plenums in buildings and has a fire rating that I believe is similar
> to that of aviation wiring.
since patch cables seldom need to be run through the ceiling they don't
usually come in plenum grade. Solid wire is more prone to breakage. If
it were me (other arguments notwithstanding) I'd run a handfull of 24AWG
Tefzel wire through there.
Godspeed,
Subject: | Re: Thanks, and Happy Trails.... |
>Bob Nuckolls,
>My Quickie Q-200 is re-wired and back in the air! I'm getting ready to
>un-subscribe, but before I do I just wanted to thank you for the great
>service you provide here.
>I no longer need the 15 or so daily e-mails so I will unsubscribe soon, but
>I wanted to let you know how much I appreciate your service.
>I hope to run into you again sometime and show you my plane.
>Sincerely,
>Sam Hoskins
>Quickie Q-200 ~1,275 hrs
>http://home.globaleyes.net/shoskins/page1.htm
Sam,
Your kind words are encouraging and gratifying. I'm very pleased that
your experience here on the list has been so useful. I'd really
appreciate it if you could stay here with us on the list . . . you've
provided good input on numerous occasions and it never hurts to have
more than one folk considering answers and options.
In any case, I'll be at the tandem wing fly-in again this year.
It's one of my favorites and only a couple hours drive from
Wichita. Hope to see you there.
Subject: | Re: D-Sub punches |
>Bob,
>190-286 - 9 pin
>125-156 - 15 pin
>125-158 - 25 pin
>190-284 - 37 pin
>Regards,
>Don Honabach
Interesting! I looked around the 'net for alternatives
after the Greenlee experience but I missed these guys.
I've bookmarked the link and plan ot order a set in the
not too distant future. Thanks for the heads-up!
>Bob,
>Thanks again :)
>robust setup.
If you have two batteries and two ignitions, what's
lacking in robustness if one ign runs from one battery
and the second ign runs from the other?
I'm sorry I wasn't very clear. The Plenum grade Category 5 cable is in fact
easy to find, it is not easy to find in the stranded wire variety. Most
Plenum grade Category 5 is solid wire which is more prone to breakage. If
you can find some stranded plenum grade Cat. 5 then by all means use it.
Godspeed,
----- Original Message -----
Subject: RE: AeroElectric-List: A different way?
> sorry.
> Regards,
> Don Honabach
> Godspeed,
For those who are in a place to start using wire ties, I found a new tie
that is really much better than regular ties. I had seen them in a
magazine by another name but the email I sent to the website was never
answered. I happened on these at Home Depot today. Give them a look at:
http://www.tnb-canada.com/catalogues/pdf/en/ty_rap/1tyrap_ENG_1d.pdf
Sorry for the pdf, but that's the only picture I could find. Hope some of
you like them as well as I did.
R
>you like them as well as I did . . .
Here's the full line catalog on Thomas and Betts nylon
cable ties. Notice that the Tyrap name covers a wide
range of products. The product you're looking for is
the Ty-Fast low profile version on page J46
http://tnbelectricalworld.tnb.com/contractor/docs/tyrap.pdf
From: | John Herminghaus <catignano(at)everyday.com> |
Robert L. Nuckolls, III wrote:
>>Bob,
>>190-286 - 9 pin
>>125-156 - 15 pin
>>125-158 - 25 pin
>>190-284 - 37 pin
>>Regards,
>>Don Honabach
>Bob,
Take a look at www.buerklin.com. Search for part number 06 L 1380, and
you will get a list of all their punches. It is a german company, but
they have a sales office in Aspen.
They also have dedicated wire strippers at around $8 for wire sizes
awg20 and awg22 which I have and which work very well.
John Herminghaus
06 L 1380 <http://www.buerklin.com/main_sammel.asp?BestNr=06%20L%201380>
Subject: | Problem with web page? |
I had a note from a lister citing problems with reading our
web page at:
Seems that some of the pictures at the top of the page don't
display. He sent me a capture of the HTML code his browser
sees and indeed, some quotation marks are missing from two
of the HTML tags that call the images in question.
It would be helpful if folks would check this page and
see if any image boxes come up empty. No need to respond
to this message if the page displays okay.
I would like to receive a DIRECT e-mail if anyone
can duplicate our friend's observation.
Thanks!
( C.F. Kettering )
Subject: | Re: Problem with web page? |
Hello Robert,
Tuesday, July 1, 2003, 6:47:17 AM, you wrote:
RLNI> I had a note from a lister citing problems with reading our
RLNI> web page at:
RLNI> http://www.aeroelectric.com/Catalog/tools/tools.html
Yes, the 2 images under the heading "25 Watt, 115 VAC Soldering Iron"
appear as broken links. I'm using Win2K and Mozilla 3.1 browser.
Best regards,
Freddie mailto:lists(at)stevet.net
All images work for me. (Win2kPro and IE6.0)
Bruce
www.glasair.org
Freddie Freeloader
Subject: Re: AeroElectric-List: Problem with web page?
Hello Robert,
RLNI> web page at:
Best regards,
Additional information. All was fine with my copy of Mozilla 1.4
browser.
Bruce
www.glasair.org
Freddie Freeloader
Hello Robert,
RLNI> web page at:
Best regards,
I have a KX-125 and it had worked fine and then suddenly, it was
inoperative. Sent it out for repairs and they replaced a diode in the
power supply and two transistors in the transmitter for $350. Put it
back in and all was well for about an hour but now it seems to have
suffered the same fate again. I sent it back to the avionics shop and
have not heard what they think yet. Of course I am wondering if there
is something about the plane that created this problem with the radio,
such as a voltage spike. The transponder and intercom run off of the
same circuit and have not failed. I was going to connect a voltmeter and
fly around for a while and see what it does.
Could a bad regulator cause this problem??
Bruce Green
Eagle N110GM
The best thing to hit the internet in years - Juno SpeedBand!
Surf the web up to FIVE TIMES FASTER!
Subject: | Grounding questions |
Bob K,
Unfortunately, I already completed wiring my instrument panel before I found
your wonderful book "The AeroElectric Connection". I just read the chapter
on grounding and am concerned that I might have a problem with ground loops.
I've got a couple of questions that require some background to make sense.
I used a sheet of .060" 7075 aluminum to build the instrument panel. I have
full IFR instruments on the left, radio stack in the center, and engine
instruments on the right in the standard locations. I used the panel as a
ground for everything mounted there (G3) and then ran a number 2 wire to the
battery minus terminal. The firewall is .015 stainless (G2) that is
connected to the battery minus terminal with a number 2 wire. Number 2 was
selected for these two grounds because the two battery bus connections to
the main bus are through 35 amp breakers each. Number 2 will flow 100 amps
so it gives me a margin over the 70 amps maximum available
The crankcase has a 1 foot long 00 wire run to the battery minus terminal.
The two batteries are in a common battery box and their negative terminals
are bolted together with a 1/4" bolt. The alternators are PM units with the
regulators mounted on the firewall. The firewall and instrument panel are
electrically isolated structurally due to composite airframe.
From reading The AeroElectric Connection, it's obvious that I need to update
my wiring diagram with appropriate ground locations for each component.
Before I make the changes I want to make sure I have a good understanding of
the grounding requirements.
With that said, here are my 3 questions:
1. Will the firewall and instrument panel serve as acceptable G2 and G3
ground busses? (I don't want to rewire all the grounds if it is not
necessary)
2. To prevent ground loops should the number 2 wire connections to the
battery minus terminal from the instrument panel and firewall be replaced
with larger wire (if yes what size do you recommend)?
3. I have fuel transfer pumps nav lights and strobes in the wings, should
they be grounded to the firewall to provide the return path to the voltage
regulators?
If you're a visual type, you can see my wiring diagram at:
http://flyboybob.com/kr2/wd0001.htm. It's a seven sheet drawing that comes
up on sheet 1 power distribution. Use the pull down at the bottom of the
page to select sheet 7, Grounding.
Bob Lee
N52BL KR2 Suwanee, GA 30024
91% done only 51% to go!
Phone/Fax: 770/844-7501
mailto:bob(at)flyboybob.com
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
Subject: | Re: KX-125 problem |
Sure. Do you have ov protection? Do you have a voltmeter in the
airplane?
writes:
> the
> it
> and
> there
> radio,
> the
> voltmeter and
> airplane?
> Bob . . .
Bob, I do have over voltage protection, but I have never verified that it
is working properly. I do not have a voltmeter, all that I have is an
ammeter like in a car, with a 60-0-60 scale. It is what came with the
plane and at some point, I plan to replace it with a voltmeter. In my
last plane, I bought a davtron unit from B&C that mounted right at the
end of the buss bar and I was very happy with that. The only electric
devices in the airplane are the KX-125, a KT-76 transponder and a PS
Engineering intercom and so far the transponder and intercom have not
been affected. I plan to go flying with my handheld and connect my
multimeter to the bussbar and see what the output is and if there are any
aberations. When I put the battery in, I adjusted the voltmeter to I
believe, 13.8 as the battery manufacture recomended. Should I be looking
for high voltage excursions or just a generally high voltage??
Thanks for your help,
Bruce Green
Eagle N110GM
It's a good thing to do. I describe both bench and in-place
test procedures in
http://www.aeroelectric.com/articles/crowbar.pdf
The voltmeter is a good thing to have . . . better I think
than the battery ammeter . . . but either instrument is just
a troubleshooting assist.
> The only electric
Most automotive and aircraft regulators are set at 14.2 volts
for better recharge rates . . and while slightly elevated
with respect to optimum room temperature floating recharge, it's
not particularly injurious to the battery.
Put your voltmeter on the bus and fire up the airplane leaving
the radios off. See how stable the voltage is with
variable loading. Run up to 1800+ rpm and switch everything
but radios on. Bus voltage shouldn't wiggle by more than
0.5 volt or so.
Your story seems to favor an ov event. I'd sure check out
the ov protection to be sure.
Probably a long shot, but I wonder whether the KX-125 is susceptible
to damage from a shorted antenna. King seems like a good brand, and
so probably wouldn't sell a radio with this kind of problem, but its
something else to check.
Another point is that some devices may be more likely to be damaged
by a bus voltage problem. The KX-125 may have the least overvoltage
protect/robust design.
When you say that you adjusted the voltmeter to read 13.8, I assume
you mean that you were adjusting the voltage regulator so that the
voltmeter read 13.8?
Good luck, and let everyone know what you find.
Matt-
N34RD
> writes:
>> the
>> it
>> and
>> there
>> radio,
>> the
>> voltmeter and
>> airplane?
>> Bob . . .
> it is working properly. I do not have a voltmeter, all that I have is
> an ammeter like in a car, with a 60-0-60 scale. It is what came with
> the plane and at some point, I plan to replace it with a voltmeter. In
> my last plane, I bought a davtron unit from B&C that mounted right at
> the end of the buss bar and I was very happy with that. The only
> electric devices in the airplane are the KX-125, a KT-76 transponder and
> a PS Engineering intercom and so far the transponder and intercom have
> not been affected. I plan to go flying with my handheld and connect my
> any aberations. When I put the battery in, I adjusted the voltmeter to
> I believe, 13.8 as the battery manufacture recomended. Should I be
> looking for high voltage excursions or just a generally high voltage??
> Bruce Green
> Eagle N110GM
Subject: | Re: Grouping wires for firewall penetration |
>Hi Bob,
>1) Dual batteries, buses, and contactors in the rear.
>2) A 2AWG wire connects the two bat cons to the starter con.
>3) A 2AWG wire connects the two battery negative terminals to the inst.
>panel ground bus.
>4) An 8AWG wire connects 40amp alternator B lead to 40amp ANL and then to
>starter con.
>Rick Fogerson
Okay. So it's about a wash as to where you put the starter
contactor. If inside, then you have starter and b-leads
coming through the firewall. If outside on firewall, you have
battery feeder to the starter contactor and main-bus feeds
coming through the firewall. Either way it's two fat wires.
So if you have it mounted inside already, I wouldn't move it.
Matt, how and when can I start enlisting members into TeamGrumman? The
rules you post make a lot more sense than the GG rules.
Gary
Bob and B&C,
The fulfilment of my recent order is the singularly most impressive piece of
customer service I've ever experienced. I ordered on Saturday evening, and
the package arrvied (in good order and with nothing missing) this morning
(Wednesday) at 9.00. Elapsed time: two working days.
This is especially impressive considering I'm in the UK. Great fun, opening
a complete "electrical system in a box".
Thanks for the great service.
Kind regards.
Neville Kilford
Jodel D-150 in progress
UK
Subject: | Re: Grounding questions |
>Bob K,
Geesh! That's a hawg. All this wire carries is ground flow for
the panel mounted stuff. You can get by with much smaller, perhaps
a 10AWG.
>necessary)
G2 should be a single bolt on the firewall. Avoid running
cranking current TROUGH the firewall sheet. Your locally
grounded equipment items (see below) will flow current in the
firewall sheet but this is relatively small and does not share
a path with any potential victims.
"Loop" refers only to architecture and has nothing to do with
wire size. The goal is to have potential victims (usually panel
mounted stuff) have a common ground point at G2 . . . your
intermediate bus (panel sheet) tied to G2 satisfies this
requirement. Your ground wires are certainly robust. The 00AWG
jumper might be better located at the single bolt at G2.
>regulators?
These items are neither potential victims nor potential
antagonists and can be grounded locally.
Tried to look at it but it seems your present site provider
is involved in a turf war and we can't access your uploaded
pages. Will try later. Looks like your e-mail return address
is to the same server . . . you probably won't get this
AeroElectric-List item until the battle is won or a truce
is signed. Good luck!
Subject: | Re: Recent order |
>Bob and B&C,
>Kind regards.
>Neville Kilford
>UK
I'll forward a copy of this to the folks at B&C. I'm pleased
that they were able to provide timely response to your
needs.
<are bolted together with a 1/4" bolt.>>
Just a thought: May not be wise to bolt two heavy batteries together at
the terminals. A flexible connection seems more appropriate.
Dan
Subject: | Re: Wiring VM1000 for dual alternator |
installation
>Listers,
>I'm wiring my RV-8 with Z-13. My ammeter will the embedded in the Vision
>MIcrosystems VM-1000 display.
>My questions are:
>1) What would be the consequence if I connected the leads from both
>ammeter shunts to the VM-1000? Since both alternators would be operating
>at different times wouldn't the display just show the current from which
>ever alternator was switched on? No doubt I'm missing something, please
>poke holes in my logic.
I got a note from Vision Microsystems that answered questions
I had on how their transducers were wired. I've published a suggested
wiring diagram for dual ammeter transducers on the VM1000 at
http://216.55.140.222/temp/VM1000_Dual_Bus.pdf
Consider that you might do quite nicely without putting
an ammeter sensor on the aux alternator. If the bus voltage
is staying above 13.0 volts then you're certainly not overloading
the aux alternator. Besides, your en-route load analysis
needs to be accomplished before first flight. You KNOW
what the maximum auxiliary alternator loads are going to
be long before you ever need to load that alternator.
>2) For those who have used a primary and an E bus and a display like the
>VM-1000, where in the circuit did you wire the voltmeter? Any reason to
>have a voltmeter on the main bus as well as the E-bus? OOps, that's a
>dumb question, I think I just answered it myself. Current is very
>important to system health, but knowing if the voltage falls below
>alternator output (#1 or #2) is all that really matters, yes? Having said
>that, my logic is that putting a single voltmeter accross the pnl ground
>plane to the started contactor would do the job. Fire away, what am I missing?
If power to operate the VM1000 fits into your power
budget for sustained en route operations with the aux alternator
(and I would think 8+ amps is plenty) then run the
VM1000 from the e-bus and be aware that voltage readings
for normal operations are 0.7 volts lower than actual.
Momentary closure of the alternate feed switch will give
you the real bus voltage and show that the alternate feed
path is intact.
Subject: | Thanks - PIDG Article... |
I wanted to thank you for doing the new crimping article. It was very
educational and helped me better understand crimping, etc.
In the article I noticed you cut the connectors apart. I'm getting my
new AMP crimper this week and will cut open the crimps and compare.
Should be interesting if nothing else from a techie prespective.
Thanks again for all your help.
Don Honabach
Subject: | Re: Thanks - PIDG Article... |
>Bob,
A cornerstone of good science is the repeatable experiment.
There's no better activity than a DIY confirmation of results
to validate an idea and commit it solidly in memory. Now
YOU will be armed with another simple-idea that can be shared
with others as the occasions arise.
( C.F. Kettering )
"Avionics-list" ,
Subject: | Off list for a while... |
I'll be off list until the 14th
From: | "Richard V. Reynolds" <rvreynolds(at)macs.net> |
Subject: | Fluctuating Ammeter |
With the engine running and the alternator on, the ammeter fluctuates between +60/-60
amps
with all loads on. As the loads are reduced, i.e. the landing lights, strobes,
and nav
lights are turned off, the fluctuations reduce to +5/-5 amps.
The battery voltage is 13.6 volts before start and 15.2 volts with the alternator
on as
measured with a digital voltmeter. The voltage does not appear to be fluctuating.
I presume the RV has the standard Vans regulator and alternator.
Any thoughts on the cause.
Richard Reynolds for a friend
In a message dated 7/2/2003 9:55:08 AM Eastern Standard Time, DHPHKH(at)aol.com
writes:
> < terminals
> Dan
Dan, You are right on point here. This is a VERY important detail. Bolting
two large (heavy) masses together at a single point is begging for trouble.
Even if the battery pair were very snug and cannot move a micrometer in the
battery box, I would not subject the battery posts to this stress. A very
flexible braided jumper wire with terminal connections at battery posts is a must.
John P. Marzluf
Columbus, Ohio
Kitfox Outback (out back in the garage)
Subject: | Re: Wiring VM1000 for dual alternators |
Bob: Is the 0.7 volt drop due to the losses in the master contactor?
Marty in Brentwood TN
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: AeroElectric-List: Wiring VM1000 for dual alternator
installation
>Listers,
Vision
>My questions are:
operating
which
please
<http://216.55.140.222/temp/VM1000_Dual_Bus.pdf>
the
to
ground
missing?
path is intact.
No, from e-bus normal feedpath diode.
Subject: | Re: Fluctuating Ammeter |
>between +60/-60 amps
>strobes, and nav
>alternator on as
>fluctuating.
more than half the time, this is a manifestation of
voltage regulator instability due to excessive wiring
resistance between the bus and the regulator. 15.2 is
a tad high also and could be yet another manifestation
of resistance . . .
Try an experiment. Temporarily disconnect existing feedpath
between input of regulator and bus. Make temporary connection
between the input of your regulator and battery (+) terminal
with a piece of hefty wire like 14 to 18AWG. Fire engine up,
measure voltage at battery terminal and observe behavior of
ammeter. If it settles down and votlage at battery moves
down toward a more normal reading, then the problem lies in
the normal feedpath between bus and regulator. Wire size,
terminals, threaded fasteners, and internal resistance of
breakers and switches can all add up to a value sufficient
to upset the regulator.
Be sure to break the temporary connection from battery (+)
when the experiment is over . . . left on too long
might overheat your alternator rotor and/or run the battery
down.
>Below is the result of your inquiry. It was submitted by
>John Lee (borgny(at)rconnect.com) on Wednesday, July 2, 2003 at 18:58:27
>John Lee
>Email: borgny(at)rconnect.com
>Comments/Questions: Dear Bob,
>I have a LR3-14 voltage regulator hooked to a B&C alternator. It was set
>at the factory at 14.4 volts and for the last year it has been working
>good, except just recently it is only putting out 13.9 volts. Is this a
>heat factor or is my alternator wearing out? Should I adjust the voltage
>regulator back to 14.4 volts?
Try adjusting it upward. There might be something else
going on but adjusting is the first thing to try.
( C.F. Kettering )
>< >are bolted together with a 1/4" bolt.>>
> together at
>Dan
Good eye Dan! That one slipped by me. Battery terminals
are indeed poorly designed for structural loading. My
personal preference for battery connections is the very
pliable, welding cable like those offered at
http://www.aeroelectric.com/Catalog/wiring/wiring.html#sbl
and easily made at home.
Subject: | Dual bus VM-1000 |
From: | "Treff, Arthur" <Arthur.Treff(at)Smartm.com> |
Thanks for your research on my behalf. It was definately above and beyond the
call of duty. You should be inducted into the EAA hall of fame. Not only did
you go the extra mile and contact Vision Mirco, but you generated a schematic.
None of the drawings for my plane look as good as yours. Anyway, thanks again
for your tireless efforts.
Art Treff
RV-8 Fastback in progress
Subject: | Noise in the headset troubleshooting (long) |
Listers,
I wanted to share with you some recent events surrounding troubleshooting 'noisy
radio' problems in my 1966 Mooney, just in case this ever happens to you. The
electrical system is standard "store bought" with battery on the firewall,
60A PMA'd alternator with external Zeftronics VR with on board over voltage protection.
The output of the alt goest thru the firewall to the bus bar. (NFG).
Gage is battery ammeter and I monitor bus voltage via a feature on the Stormscope.
Regulator has 800 hours on it, and the alternator is a rebuilt with
approx 50 hours.
The scenario:
Over time, I have noticed two abberations in my plane, I have treated them as unrelated.
Here's the setup.
Every once in awhile in flight, particularly at high altitudes. I notice a slight
noise in the headset that sounds like frying bacon. It is intermittent. I
further notice that if I turn on a high load device like a landing light (250W)
the noise goes away. So, historically, I have suspected that this has something
to do with the VR, but I do nothing about it, as it's intermittent.
Additionally, Every once in awhile ATC tells me my KX-155 is totally unreadable.
I switch to the UPS GX60 and they say it's better, but not perfect. The King
is as old as they get, and it usually has to go into the shop at least every
other year, so I really do nothing about it. I'm thinking that perhaps it's
getting too hot, so I usually turn it off, and xmit on the GPS comm. Why that's
not as clear, I usually rationalize that it's an inferior radio, or antenna,
or less power than the King's 10 watts.
The scenario worsens.
Last month, the 'frying bacon' noise worsened. It was louder in the headset, and
loading up the alternator with Pitot heat and landing light lessened the volume
but did not erradicate it. I fly legs of 3-5 hours so I have alot of time
to listen and wonder. Shutting off the audio panel made the sound go away.
Hmmm.....perhaps the PS Engineering unit is starting to go... or perhaps I got
some Corrosion X into critical places in antenna wiring during my annual last
month...I also had more calls from ATC asking me to switch to another radio
than the King. So, I was thinking that the KX-155 needed to go into the shop
as did the audio panel, this can't be the voltage regulator. (not so fast, silly
boy).
Total chaos.
Last week, during climb out on a routine 190 mile trip, the noise in the headset
was really bad, and my ability to hear radio xmissions was diminished. ATC
did not like my radios at all. I was on an IFR plan, but it was VMC so I pressed
on. I tried loading up the bus, to get rid of the noise, but this no longer
helped. I shut off the audio panel and all this did was make the noise softer.
Finally, my eyes alighted on the voltage monitor. It read 11.2 volts!
The ammeter showed a slight discharge. No alternator. I pulled the 5A alt field
CB and all quieted in the headset. Ah ha! Gotcha you little bugger. A bad
somethingorother in the alt circuit. I pressed the field breaker back in and
the alt came back on line, voltge came back up to 13.8, the battery was drawing
a charge on the ammeter and the noise quieted down, but was not gone. Now
is when I really started troubleshooting. Every time I pulled the field breaker,
the noise totally died away. I happen to have a spare VR with me (I'm not
so organized usually) and the connector is accessible from under the panel.
I shut off everything except one radio, pulled the field breaker. I reached
under, found the connector and plugged in the new regulator. I reset the field
breaker, in eager anticipation of a nice fat charge, quite in the earphones
and a charging battery. I was convinced that the problem was the VR. What happened
surpriese me: the new regulator lighted the OV light, and popped off line!
OK, so a bad alternator I thought, could it be intermittently shorts in
the field, diodes, what?
The solution.
On the ramp, I pulled the side cowling and wiggled the alt terminal connections.
The field ring terminal was tight on the post, but the whole post was loose!
I wiggled the other post (goes to ground) and it too was loose as well. So
much for "Gen-U-Wine FAA repair stations, yellow tags saying Return to Service
and PMA's parts." This was a newly overhauled alternator, with approx 50 hours
on it over 3 months. I took off the ring terms, tightened down the jam nuts
on the terminal posts and reinstalled the field and ground ring terminals respectively.
My sceptical self did not really thing that this could be the cause
of the entire episode, but my return flight was the quietest I've had in a
long time, no complaints from ATC re: the King radio's quality and best of all
no frying bacon at all, not a trace.
The lesson, FWIW.
What started out as a radio annoyance turned out to be a mechanical problem on
the alternator. The radio and audio noise, as it turns out, were the best troubleshooting
tools at my disposal. Better that than total alternator failure
in the goo at night. In the future, I will not take changes in headset noise
lightly. It could be trying to tell me something.
Art Treff
RV-8 Fastback interior work.
Same airplane (1966 M20C), with an InterAv alternator conversion. Worked
perfectly for a year then started to get the occasional noise problem just
as Arthur did. Similar trouble shooting sequence (but without the spare
VR). Got slowly worse over time then my JPI started showing the low voltage
conditon, intermittantly and infrequently at first then more frequently. I
check all the connections several times. Fix came when one day I decided to
just unwrap all the wiring from the harnesses and start checking splices and
I discovered that the crimp had gone bad on the ring terminal where the
field wire attaches to the alternator. That was the first thing I had
checked in previous attempts and I checked it on several occasions. I
didn't discover it sooner because all I really checked was that the nut held
the terminal on the post well (post was solid). I had done such a good job
with the heat shrink that the mechanical connection was pretty good but of
course, not THAT good. First good tug it came right out of the crimp. 10
minutes later with a new ring terminial from my bench stock and my ratchet
crimpers... problem fixed. Execellent electrics for 3 years and 600 hours
now.
Douglas L. Dodson, Jr.
Glasair II-S FT
Flight Test Engineer, CFI-A,I,G
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Treff,
Arthur
Subject: AeroElectric-List: Noise in the headset troubleshooting (long)
Listers,
'noisy radio' problems in my 1966 Mooney, just in case this ever happens to
you. The electrical system is standard "store bought" with battery on the
firewall, 60A PMA'd alternator with external Zeftronics VR with on board
over voltage protection. The output of the alt goest thru the firewall to
the bus bar. (NFG). Gage is battery ammeter and I monitor bus voltage via
a feature on the Stormscope. Regulator has 800 hours on it, and the
alternator is a rebuilt with approx 50 hours.
The scenario:
as unrelated. Here's the setup.
slight noise in the headset that sounds like frying bacon. It is
intermittent. I further notice that if I turn on a high load device like a
landing light (250W) the noise goes away. So, historically, I have
suspected that this has something to do with the VR, but I do nothing about
unreadable. I switch to the UPS GX60 and they say it's better, but not
perfect. The King is as old as they get, and it usually has to go into the
shop at least every other year, so I really do nothing about it. I'm
thinking that perhaps it's getting too hot, so I usually turn it off, and
xmit on the GPS comm. Why that's not as clear, I usually rationalize that
it's an inferior radio, or antenna, or less power than the King's 10 watts.
headset, and loading up the alternator with Pitot heat and landing light
lessened the volume but did not erradicate it. I fly legs of 3-5 hours so I
have alot of time to listen and wonder. Shutting off the audio panel made
the sound go away. Hmmm.....perhaps the PS Engineering unit is starting to
go... or perhaps I got some Corrosion X into critical places in antenna
wiring during my annual last month...I also had more calls from ATC asking
me to switch to another radio than the King. So, I was thinking that the
KX-155 needed to go into the shop as did the audio panel, this can't be the
voltage regulator. (not so fast, silly boy).
Total chaos.
headset was really bad, and my ability to hear radio xmissions was
diminished. ATC did not like my radios at all. I was on an IFR plan, but
it was VMC so I pressed on. I tried loading up the bus, to get rid of the
noise, but this no longer helped. I shut off the audio panel and all this
did was make the noise softer. Finally, my eyes alighted on the voltage
monitor. It read 11.2 volts! The ammeter showed a slight discharge. No
alternator. I pulled the 5A alt field CB and all quieted in the headset.
Ah ha! Gotcha you little bugger. A bad somethingorother in the alt
circuit. I pressed the field breaker back in and the alt came back on line,
voltge came back up to 13.8, the battery was drawing a charge on the ammeter
and the noise quieted down, but was not gone. Now is when I really started
troubleshooting. Every time I pulled the field breaker, the noise totally
died away. I happen to have!
a spare VR with me (I'm not so organized usually) and the connector is
accessible from under the panel. I shut off everything except one radio,
pulled the field breaker. I reached under, found the connector and plugged
in the new regulator. I reset the field breaker, in eager anticipation of a
nice fat charge, quite in the earphones and a charging battery. I was
convinced that the problem was the VR. What happened surpriese me: the new
regulator lighted the OV light, and popped off line! OK, so a bad
alternator I thought, could it be intermittently shorts in the field,
diodes, what?
The solution.
connections. The field ring terminal was tight on the post, but the whole
post was loose! I wiggled the other post (goes to ground) and it too was
loose as well. So much for "Gen-U-Wine FAA repair stations, yellow tags
saying Return to Service and PMA's parts." This was a newly overhauled
alternator, with approx 50 hours on it over 3 months. I took off the ring
terms, tightened down the jam nuts on the terminal posts and reinstalled the
field and ground ring terminals respectively. My sceptical self did not
really thing that this could be the cause of the entire episode, but my
return flight was the quietest I've had in a long time, no complaints from
ATC re: the King radio's quality and best of all no frying bacon at all, not
a trace.
The lesson, FWIW.
on the alternator. The radio and audio noise, as it turns out, were the
best troubleshooting tools at my disposal. Better that than total
alternator failure in the goo at night. In the future, I will not take
changes in headset noise lightly. It could be trying to tell me something.
Art Treff
Subject: | music input jacks |
Can somebody recommend a decent 1/8" stereo music input jack that can be
panel mounted and isolated from ground somehow? I'm just assuming that
keeping the audio return isolated from ground is ideal for reducing noise
induced in the system.
Are there insulating washers available, similar to those used on headset/mic
jacks, that can be used on smaller jacks?
Thanks in advance,
)_( Dan
RV-7 N714D
http://www.rvproject.com
From: | Charlie & Tupper England <cengland(at)netdoor.com> |
Subject: | Re: music input jacks |
>Thanks in advance,
>)_( Dan
>RV-7 N714D
A Google search for 'miniature phone jack with isolated ground' yielded:
Stereo phone jack has isolated ground.
Designed for pc-board mounting, the CTP-310 and CTP-312 3.5-mm stereo
phone jacks offer optional grounded or isolated bushing and a life
expectancy of 5000 mating cycles. The mini-phone jacks can be used for
industrial, consumer, and computer multimedia sound cards, as well as
other applications requiring audio input and output. Unit price in
volume quantities is $0.20. Connect-Tech Products Inc, Carson City, NV.
(702) 883-0986.
not exactly what you want but a trip to their web site:
http://www.connect-tech-products.com/connectors/three_five/three_five_downloads/35mm.pdf
might get you what you want. CTP-354W-S1 looks like it would work, with
a couple of extra unneeded pins.
Switchcraft.com is another good bet, but their web site is being
stubborn tonight.
Subject: | ACK ELT control wire? |
7/4/2003
Hello Russ Werner and Jerry Kaidor, Below is a copy of your postings a while
back on this subject. I am confronted with the same issue with an ACK ELT O1
regarding replacing the telephone style control wire extension.
But one issue remains unresolved. Russ says you must do some wire swapping
when putting on new connectors and Jerry says the cable works fine as purchased.
Can either one of you or both revisit this issue and tell me if I can use a
standard 4 wire telephone cable as purchased with connectors already installed
or if I'll have to buy connectors, do some wire swapping and crimp on the new
connectors?
Many thanks.
'OC' Baker, Builder of KIS TR-1 #116 4/14/97 - ?/?/?
<<Message: #7465 From: jerry(at)tr2.com Subject: Re: ELT control wire? Date:
Oct 24, 2002
Russ Werner wrote: "It's just telephone cable. Not critical by any means.
Buy the 25 footer and clip off the male end. Reinstall a new male end where
you need it and
be sure to swap wires accordingly, as the ELT wires cross enroute while the
telephone wires don't."
*** Thanks Russ. That's what I did. Actually, the 25-footer worked fine
as it was wired. I had to snip the connector and crimp on a new one anyway
to fish the wire through the floor. - Jerry>>
In a message dated 7/4/03 9:09:53 PM Pacific Daylight Time,
treading(at)comcast.net writes:
<< Looking at the drawings it shows on the b+c the field wire goes from a
single terminal on the regulator but two terminals at the alt. I ran a small
link between the two then one wire back to the reg. Is this the right way. >>
Correct. I just finished wiring my B&C alternator and that is exactly what
the B&C instructions say to do.
Harry Crosby
Pleasanton, California
RV-6, firewall forward
Actually, when B&C reworks an "automotive" alternator to make an
"aircraft" alternator out of it, the connect ALL of the terminals
together so that you can't hook up to the wrong one . . . any
one of them is the right one . . .
> I ran a small
> Also I was wondering with the two alt. system will there be times when I
>could or should run both of them at the same time?
What you describe will function but it was not necessary to hook
up to more than one of whatever terminals were there . . .
Subject: | Tom Reading and other Digest subcribers, trim those |
replies .
Tom, if you look at what you "replied" to when you posted the
query about alternator connections, your message repeated the
entire digest download of the day.
No big deal but it's very helpful to trim away remnants of the
message you are using for a reply base unless they contribute
to the thread of the conversation. In this instance, none of
what followed your query was relevant to the conversation
but was quite long.
Thanks!
Subject: | LSE EI Installation |
I received my electronic ignition from Light Speed Engineering a couple of days
ago. I'm preparing to install it on my Lycoming O-235 but can't figure out how
to drill tap the holes for the sensor bracket without splitting the case.The
way I see itnowthe holes in the prop flange don't line up with the sensor bracket
mounting holes so it seems the case has to be split and the crank removed?
But then I wont have the crank to center the bracket on. How do I get the drill
behind the prop flange?
Advice from someone who has installed one would be greatly appreciated.
Grant Krueger
Subject: | Out of Office AutoReply: AeroElectric-List Digest: |
4 Msgs - 07/05/03
On vacation - back in office on Tuesday 15.07.2003
Subject: | Re: LSE EI Installation |
Apparently yours is different than mine. On my IO-320-B1A there are holes to
be drilled in the starter ring mount (flywheel) and the magnets pressed into
them and staked. I sent the mount to Klaus to be drilled. I figured he was
set up to do it properly.
Bill Lamb
Subject: AeroElectric-List: LSE EI Installation
days ago. I'm preparing to install it on my Lycoming O-235 but can't figure
out how to drill tap the holes for the sensor bracket without splitting the
case.The way I see itnowthe holes in the prop flange don't line up with the
sensor bracket mounting holes so it seems the case has to be split and the
crank removed? But then I wont have the crank to center the bracket on. How
do I get the drill behind the prop flange?
> Thanks,
> Grant Krueger
Grant,
The holes in my case were oriented properly to accept the sensor
bracket, but I've got a different model engine. Just make sure that
you are mounting the sensor bracket correctly, and then if there is a
small misalignment you can elongate the holes in the bracket or if that
doesn't work, drill new holes in the bracket. I wouldn't consider
splitting the case until all other possibilities are exhausted. You
might also give Klaus a call, he is very helpful with installation
problems.
Joel Harding
> couple of days ago. I'm preparing to install it on my Lycoming O-235
> but can't figure out how to drill tap the holes for the sensor
> bracket without splitting the case.The way I see itnowthe holes in the
> prop flange don't line up with the sensor bracket mounting holes so it
> seems the case has to be split and the crank removed? But then I wont
> have the crank to center the bracket on. How do I get the drill behind
> the prop flange?
> Thanks,
> Grant Krueger
> _-
> _-
> _-
> _-
Grant,
Sorry, I misinterpreted your your question. I guess an 90 degree angle
drill would be about he only way to drill the holes without splitting
the case, but tapping would still be a problem. I'm sure Klaus can
give more useful information.
Joel Harding
> the prop flange?
> Thanks,
> Grant Krueger
> _-
> _-
> _-
> _-
I put my volt meter on the bus and flew around for half an hour and the
voltage varied between 14.24 to 14.27 and never strayed outside of that.
I couldn't really change the load because I don't have anything to turn
on and off, the only electric things in the plane are the radio which
isn't in the plane and a transponder and an intercom. I turned the
intercom on and off and that didn't change anything.
The radio shop has the radio and I am hoping to hear from them tomorrow
as to what is wrong with it. Could a loose wire, say the power wire on
the back of the alternator cause a voltage spike? Shouldn't a radio be
able to handle something like that? If it were a case of the regulator
allowing the alternator to charge to its hearts content, I have a feeling
that I would smell the battery outgassing, it is only about a foot away
from me.
Thanks again for your help.
Bruce Green
Eagle N110GM
writes:
> that it
> test procedures in
> the
> my
> the
> > The only electric
> PS
> not
> are any
> I
> looking
> 0.5 volt or so.
> Bob . . .
> http://www.matronics.com/FAQ/AeroElectric-List.htm
> Digests:http://www.matronics.com/digest/aeroelectric-list
From: | "Steve J Hurlbut" <sjhdcl(at)kingston.net> |
I recently went to turn on the Master switch on my RV7A (almost done)
and discovered the battery was dead (I have 2 batteries). I measured the
voltage (with terminals
attached) and it read 0.06 V. I tried to charge the battery but it was long
gone.
However after removing the terminals (and noticing a small spark) and
removed the battery
from the airplane, the voltage read 4.5 V and I fully charged it to 13 V
over night.
I reinstalled the battery, connected the terminals and have not had a
problem since. I did discover
a small screw in the tray of my EXP Bus and removed it. Could have caused a
short between the casing
and circuit board? All the CB were pulled at the time except for the main
battery (can't be pulled, just
reset).
Any body have an idea of why my battery read different voltages with the
terminals connected and
disconnected and what may have caused this voltage drain? Everything in my
airplane is powered from the
power leads on the Exp Bus and the loads are well below the maximum allowed
currents.
Steve Hurlbut
RV7A
Eggenfellner Subaru powered
From: | "Werner Schneider" <wernerschneider(at)compuserve.com> |
Subject: | KX-125 and KN-75 wiring, manual discrepancy |
Dear all,
I've wired today my Nav/Com (KX-125) and the Glideslope Receiver (KN75) all
went fine, until I've detected, that in the drawing and the associated
wireliste some discrepancies concerning pin layout are.I've the Installation
Manual for the KX-125 (#006-00655-0001) dated Rev 1 January 1994.
On the diagram page 2-5 it says:
GS 108 MHZ Pin E
GS 109 MHZ Pin B
GS 110 MHZ Pin C
GS 111 MHZ Pin D
On the connector pinout diagram page 2-11 it says
A ->
GLIDESPLOPE 109 kHz
B ->
GLIDESPLOPE 110 kHz
C ->
GLIDESPLOPE 108 kHz
D ->
GLIDESPLOPE 111 kHz
I recon the diagram is right and the connector pinout wrong (as the kHz
are?)
Any help appreciated.
Kind regards
Werner (nearly ready for first power up!)
Subject: | Re: dead battery |
I think that the change in voltage connected vs disconnected confirms a
short that was actively draining the battery. Could have been the screw you
noticed in the EXP bus tray or something else that moved when you removed
the battery. Since the master was off when this happened, the problem was
in one of the areas between the battery and the master. I would make a very
through review of this area of your system.
Subject: AeroElectric-List: dead battery
long
> gone.
> removed the battery
> over night.
a
> reset).
allowed
> currents.
> Steve Hurlbut
> RV7A
Subject: | Re: Dual bus VM-1000 |
>Bob,
>the call of duty. You should be inducted into the EAA hall of fame. Not
>only did you go the extra mile and contact Vision Mirco, but you generated
>a schematic.
My pleasure. Usually, the most reliable and informative
source of data on a product is available from the manufacturer
so I'll nearly always exercise that option unless it's a stone-
simple question with an obvious answer. It's easy for me
to draw neatly . . . shucks, anyone with AutoCAD can do it.
Use any CAD program long enough and you tend to forget how
to neatly drive a pencil.
Neat is always good but good data recorded in a lucid manner
is better. I work with a battalion of 3D CAD drivers
most whom can produce very pretty drawings. Whether they
are correct and/or optimized designs is another matter.
I've visited builders who apologized for "messy" drawings.
The messy part came from obvious use of the ultimate
correction tool . . . the Pink Pearl eraser. What was
lying on top of slightly smudged pages were easily
read details of a system accurately described on paper.
Don't sell your efforts short. If your drawings describe
a clear and concise system story to you and/or future owners
of the airplane, they're to be highly prized over some
of the "good looking" stuff that spits out of laser printers!
Subject: | Re: KX-125 and KN-75 wiring, manual |
discrepancy
>Dear all,
> GS 108 MHZ Pin E
> GS 109 MHZ Pin B
> GS 110 MHZ Pin C
> GS 111 MHZ Pin D
The pinout diagram published at
http://216.55.140.222/Installation_Data/KX125.pdf
agrees with the above.
>gone.
>removed the battery
>over night.
Whatever ran the battery down was probably still attached
and loading the battery during your first measurement. Unless
the battery is in a constant discharge state for a very long
time (weeks) and depending on the rate of discharge, the termial
voltage will rise somewhat.
As long as your battery hasn't suffered a total discharge
condition for more than a day or two, it will probably
be servicable.
>problem since.
. . . the "problem" may be one of reduced capacity. What kind
of battery are we talking about here and what is its function
in your system?
>I did discover
>reset).
>currents.
Have you put an ammeter in series with the batteries in your
airplane to investigate the parked-and-locked drain current on
batteries? Aside from acknowledge loads like keepalive for radio
memories, clocks, and similar always-on loads, drain on batteries
for a parked airplane should be ZERO. The fact that you had an
unexplained total discharge of a battery suggests a need
for further assurances that something unforetold is not going
on.
If your EXP Bus has polyfuses -AND- the screw caused
a fault downstream of the fuse, it could have been driven
into a high temperature, low fault current state that
would take some time to run the battery down. The question
arises, "how does anything on the EXP Bus get powered up
with the master switch off?
>Bob,
That small a load change wouldn't help diagnose much in the way
of alternator problems. You don't have any lighting equipment
you can turn on? If your airplane is so lightly outfitted,
I'd recommend you borrow a battery shop load tester, hook
it to the battery with the engine running up 2,000 rpm or so
and crank the load up to 25-40 amps as see that the
panel voltmeter confirms an ability and willingness of
the alternator to properly accept such loads.
>from me.
If you have a bus voltage high enough to outgas an RG battery,
the OV protection system should have tripped the alternator
of line a long time ago. If the ov protection system is
functional, it should protect the airplane from miscreant
regulators and alternators.
See what the radio shop says. Be skeptical of any diagnosis
based upon your airplane having "spiked" the radio. This is a common
methodology for pushing root cause off onto the airplane . . .
especially when the technician doesn't really understand how
the radio failed. I'm not saying it never happens but after
4 decades of chasing gremlins in airplanes, I can tell you
that technicians attribute spikes with far greater penchant for
evil than the reality of good science can confirm.
The batteries are Odyssey PC625s.
I did connect an ammeter in series and the current was zero. However after
seeing the initial spark
when disconnecting the +ve terminal, I reconnected it and there was no
spark. Whatever was draining the
battery is no longer causing any problems.
I have kept track of the voltage for the past 3 days. After recharging, the
battery read 12.71 V and now after
3 days it reads 12.61 V. I seems to be constant now. All the breakers are
now pushed in and there is no current drain.
I have an Eggenfellner Subaru engine that uses a dual battery system that
can be connected through a master
relay. The only keep-alive connection I have is to power the engine computer
but that runs off the secondary battery
and the current drain is VERY small.
It is possible to power the engine computer, electrically controlled prop
(Quinti), and the back up Gyro for emergency
purposes with the MASTER off. This is through a Bus OVERRIDE switch that
surpasses the EXP Bus in the
unlikely event that it malfunctions. Nothing that is solely powered by the
ExpBus can be used with the Master off. I have carefully
checked the battery connection to the Exp Bus for shorts. The terminal has
multiple layers of heat shrink and clears the
ExpBus casing by at least 1/4".
The only other thing I can think of is the engine computer itself. Since the
batteries have been disconnected, the memory
has been erased so there is no current draw for the computer. If the battery
stabilizes at around 12.6 V I will be
content for now until I run the engine again and create the computer memory
draw.
Subject: Re: AeroElectric-List: dead battery
long
> >gone.
> >removed the battery
> >over night.
> be servicable.
> >problem since.
> in your system?
> >I did discover
a
> >reset).
my
allowed
> >currents.
> on.
> Bob . . .
Subject: | Option for alternator B-lead fuse |
I would like to get your opinion on the use of a fuse holder similar to
the following for alternator b-lead protection forward of the firewall:
http://www.crutchfield.com/cgi-bin/S-08KCpdYV9zh/ProdView.asp?s=0&cc=01&g=716&id=morephotos&pi=1&i=575CPPFH4&display=L#morephotos
These are commonly used in car stereo installations and are designed to
go under the hood, near the battery. My plan is to have it mounted to
the engine mount using adel clamps near the starter contactor. 40 Amp
fuses are available (for my 40 amp B&C alternator.) The one drawback I
can see is that the attachment of the wires is done with a set screw
rather than a clamped connection. My alternative is to use a Bussmann
JJS/JJN type fuse as shown in your book.
Your opinion?
Jeff Point
RV-6 firewall forward
Milwaukee WI
Grant,
You shouldn't have to split the cases.
You can press out one of the prop flange bushings, leaving a larger
hole in the prop flange to drill and tap through. You can do this with
a large C-Clamp and some pieces of pipe just a bit larger than the
bushing. Some tapping with a plastic hammer helps.
Carefully mark and centerpunch the location for the holes. The holes
need to be right so the timing isn't altered.
Drill to the appropriate depth with a small drill. Put some tape on the
drill to indicate depth.
Drill with the size drill recommended for the tap in a machinest's book.
(Drilling straight-in is the hard part)
Buy a three-tap set for the thread size you need. This is a set that
gradually taps the hole to the correct size. use lots of tapping fluid,
stop when needed to back out the tap and clean away chips
Piece of cake
--Kent Ashton.
> Thanks,
> Grant Krueger
From: | "Muzzy Norman E" <MuzzyNormanE(at)JohnDeere.com> |
Subject: | RE: LSE EI Installation |
On my IO-360 I had to press out one of the prop bushings. This gave enough
clearance that you could go straight in with the drill and tap. I used a
hole saw with the teeth ground off plus a bolt, nut, and washer to press the
bushing out. After installing the sensor bracket, make sure you verify that
the clearance between the sensor and magnets is correct. If you need to
shin something, or remove the sensor, it is much easier with the bushing
out. Once everything is good, use the hole saw and bolt to press the
bushing back into the prop flange. Much easier than splitting the case!
Regards-
Norm
Subject: | Re: AeroElectric-List Digest: 14 Msgs - 07/06/03 |
> ________________________________ Message 6
> From: "Steve J Hurlbut" <sjhdcl(at)kingston.net>
long
> gone.
> removed the battery
> over night.
a
> reset).
allowed
> currents.
> Steve Hurlbut
> RV7A
> I had a similar problem recently and What I discovered was the RG battery
was shot. I could charge it up and it would read 12.5 volts. the next day it
was still 12.5 volts but all I had to do was put a very low load on it and
the voltage would start dropping. I appeared as an open circuit to the
regulator and it went over voltage., fried a contactor and would have gotten
the radio except I cougt it before it did any damage. I have over voltage
protection now. the battery was only two years old. I am going to replace it
more often from now on.
> ________________________________ Message 7
Subject: | Dell Axim X5 PDA - Sunlight readable? |
Anybody have the Dell Axim X5 PDA (and the iPaq 3630 Pocket PC) ?
Is it as readable in direct sunlight as the iPaq 3630 Pocket PC?
Finn
>Grant,
>Piece of cake
>--Kent Ashton.
it would be pretty cool if someone could do a series
of photos from which a comic-book work-instruction can
be crafted. I'd be willing to post such a document
should the photos and data me made available to the
task. Klaus SHOULD be doing this but better that we
do it for ourselves than set around complaining that
he hasn't done it.
Subject: | Re: KX-125 and KN-75 wiring, manual discrepancy |
Many thanks Bob for the confirmation, seems nobody did claim this error in
the manual since 94 =(;o((
Kind regards
Werner
Subject: Re: AeroElectric-List: KX-125 and KN-75 wiring, manual discrepancy
> >Dear all,
all
Installation
> > GS 108 MHZ Pin E
> > GS 109 MHZ Pin B
> > GS 110 MHZ Pin C
> > GS 111 MHZ Pin D
> Bob . . .
Finn,
I believe you want to look for a unit that has a transflective screen.
These are what I see mentioned whenever viewing issues are mentioned and
what folks should look for if they don't want viewing issues.
Don
From: Finn Lassen [mailto:finnlassen(at)netzero.net]
Subject: AeroElectric-List: Dell Axim X5 PDA - Sunlight readable?
Finn
direct advertising on the Matronics Forums.
Subject: | Re: Dell Axim X5 PDA - Sunlight readable? |
Finn,
I've been using an Axim for about six months (Janurary); it replaced an IPaq 3650.
The Axim's screen is better in pretty much every respect - it's brighter,
easier to read in direct/indirect sunlight, and is more evenly lit when the
backlight is activated. The Axim also has much better battery life.
Thanks!
Brad "Sharpie" Benson
RV6AQB underway...
"Please buy my software, it's funding my RV6A project!" - http://www.notamd.com
*********** REPLY SEPARATOR ***********
On 7/7/2003 at 11:32 AM Finn Lassen wrote:
June 24, 2003 - July 07, 2003
AeroElectric-Archive.digest.vol-cd
