AeroElectric-Archive.digest.vol-cm
September 29, 2003 - October 13, 2003
      >         It is currently sourced from the instrument panel
      >power switch (which is in turn sourced from the master
      >power switch), and is simply a cheap switch that looks like
      >it came from Radio Shack.
      >I'm thinking of rewiring this to use a 5A circuit breaker
      >in place of the cheap switch, and source it directly
      >from the master power switch, and mount it above the
      >low voltage warning light.  My thoughts are that I can
      >pull the circuit breaker, and that effectively acts as a "switch".
      >         Is this sound reasoning, or am I missing something critical
      >and there is a better way to do this?
         The master switch is generally not a source of power
         but a closure to ground for the battery contactor.
         If it's a single pole switch now, it needs to be
         a two pole switch and wired like shown in
         various architectures depicted at:
         http://www.aeroelectric.com/articles/Rev10/z10.pdf
         Check these out and see if they offer useable
         suggestions.
Date: Sep 29, 2003
aeroelectric-list(at)matronics.com
Subject: Re: COZY: Somebody is Infected!!!
These worms have been flooding into my machine for days now, all from the cozy builders group, the canard aviators group, or the Aeroelectric list.. My virus scanner always catches them but it's darned annoying since each one needs handling. I get ~15 a day on average. To Marc + canard/ Matronics moderators; is there anything we can do to trap them at the mail servers? To Jay....don't assume you're safe because "we don't download files from each other". Damaging code can be embedded or attached to a mail and hurt you just as badly. Make sure your virus definitions are always up-to-date. Neil At 06:03 PM 9/29/03, CozyCrafter(at)aol.com wrote: >In a message dated 9/29/2003 3:01:56 PM Pacific Standard Time, >CozyBuilders(at)DrewChaplinPhoto.Com writes: >Hello all, > >I have received several messages from somebody on this list with the >"W32.Swen.A@mm" virus. I only use this particular email account for >this group, so I know it has originated here. I do not know who is >sending it out because it's hidden the user. The message appears to >come from the Network Security Department at Microsoft and has the >subject of "Current Microsoft Upgrade". The attached file name is >Pack3221. My Antivirus program is catching and I hope yours has done >the same. It's a fairly new virus and your Antivirus software has to >have been updated since 9/18/2003 to find it. As I said before, I use >the CozyBuilders(at)DrewChaplinPhoto.com email address only for this group >and nothing else. The message came in on it. > >By the way, >ROUGH RIVER WAS A BLAST!!!! >Thank you Dan & Lori Cruger for the ride! > >Well worth the Drive >Drew Chaplin >---- >Cozy Mark IV >SN# 1200 Prebuild & Planning > > >I dont know much about computers (relative) but I dont see how this is a >problem since we dont download files from each other. Please explain. Jay ________________________________________________________________________________
Date: Sep 29, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: RC Allen Gyro electrical connector - Photo Correction
> > > > > >I just got an RC Allen electric Gyro and need information on the > >connector. > >The connector is an Amphenol MS3116E8-4P and -4S. > >I am told to connect Pin A to Ground and Pin B to +14 volts. > >I cannot identify pins A and pin B on the connector, the markings makes > >no sense to me. > >I do not want to risk connecting it reverse polarity. > > See http://www.aeroelectric.com/Pictures/MS3116E8-4S.jpg > > Bob . . . Ughh!! did something silly in Photoshop with the first image and didn't check it after I uploaded it. I've corrected the poor craftsmanship and re-posted the picture. Bob . . . ________________________________________________________________________________
Date: Sep 29, 2003
Subject: Re: Z-14 with SD-8????
> >Bob > >Do you have a version of Z-14 with an SD-8 alternator using the voltage >regulator that comes with it. > >Regards > >Nick Gaglia >Livermore RV-8 Nick, When you reply to an AEList post, trim away the original document as much as you can and still provide continuity to the conversation thread. In this case, you opened a new thread where none of what you echoed back to the list was relevant to the topic yet it was a huge document . . . If the aux alternator has only 8A rated output, I think it would be much better to configure the system using Z-13. If you want dual batteries, fine. Simply add second battery per Z-30. Which ever battery is tasked with e-bus support also gets the aux alternator connection. During main alternator out operations, you don't use any of the SD-8's limited output to keep a contactor closed. You have essentially all SD-8 output available for unlimited endurance bus ops. When airport is in sight, you can close both battery contactors and have energy to burn. See http://www.aeroelectric.com/articles/Appendix_Z_Drawings/z13wDualBattery.pdf Bob . . . ________________________________________________________________________________
Date: Sep 29, 2003
> >I just got an RC Allen electric Gyro and need information on the > >connector. > >The connector is an Amphenol MS3116E8-4P and -4S. > >I am told to connect Pin A to Ground and Pin B to +14 volts. > >I cannot identify pins A and pin B on the connector, the markings makes > >no sense to me. > >I do not want to risk connecting it reverse polarity. > > See http://www.aeroelectric.com/Pictures/MS3116E8-4S.jpg > > Bob . . . Thanks Bob --- solved my problem. Rino > ________________________________________________________________________________
Date: Sep 30, 2003
From: "John F. Herminghaus" <catignano(at)tele2.it>
Subject: Re: Garmin 430 wiring problem
You can download the installation manual from Garmin's website. Robert L. Nuckolls, III wrote: > > > >> >>I am installing my Garmin 430. It was pre-wired, meaning connectors are >>wired with wires hanging out and labeled. I can not find any wires labled >>gps data out. I have d/l the pinouts from AE's site and none of the >>connectors seems to have this designation. I am trying to drive my Navaid >>with the 430 gps. I surely hope that this thing has a gps data out. Do they >>call it something different? >>Thanks >>Mike Stewart >> >> > > shuckypoo . . . I did a 430 installation in the AGATE Bonanza > a a couple of years ago and had a copy of the complete installation > manual from Garmin. Dug around in the archives and couldn't put > my hands on it. I probably gave it back to the folks at RAC. > Sorry. > > Bob . . . > > > > ________________________________________________________________________________
From: "Neil Henderson" <neil.mo51(at)btopenworld.com>
Subject: Alternator Wiring
Date: Sep 30, 2003
Thanks for the various responses to my posting, copy below. The consensus seem to be a standard sized pulley and I will machine a replacement from alloy. Still not sure about connections required. It would appear only one of the three pins is connected, other than the main power lead. Does anyone know which one? ( the connector has three small pins in a straight line ), or is there a way of testing. Thanks for your help. Regards Neil Hederson Original message >I have obtained an almost new Nipon Denzo alternator off a Toyota which I >intend fitting to a Lyco320 In my RV9. >I have a couple of questions. Firstly I assume it's internally regulated >although it has a 3 wire socket, what are the 3 connections for and is a >mating plug readily available. Van's sell one that looks as if fits. >Secondly it is currently fitted with a flat belt pulley which I need to >change this to a V belt. I seem to recall Bob Avery used to sell a larger >dia pulley, is this worth considering and if not could anyone direct me to >source of standard sized pulleys ________________________________________________________________________________
Subject: Garmin 430 wiring problem
Date: Sep 30, 2003
> You can download the installation manual from Garmin's website. I did just that a couple years ago, but I can't find the install manuals on their site anymore. A call to their support might clarify things, perhaps they can be downloaded on request. Alex Peterson Maple Grove, MN RV6-A N66AP 375 hours www.usfamily.net/web/alexpeterson ________________________________________________________________________________
Subject: Re: alternator field cut-off
Date: Sep 30, 2003
On Mon, 2003-09-29 at 19:25, Robert L. Nuckolls, III wrote: > > > > > > >Hi all, > > I'm rebuilding/rewiring some of the electrics on a > >used Glasair that I bought, and in particular know that the > >alternator field cut-off switch is not "right" at present. > > > > It is currently sourced from the instrument panel > >power switch (which is in turn sourced from the master > >power switch), and is simply a cheap switch that looks like > >it came from Radio Shack. > >I'm thinking of rewiring this to use a 5A circuit breaker > >in place of the cheap switch, and source it directly > >from the master power switch, and mount it above the > >low voltage warning light. My thoughts are that I can > >pull the circuit breaker, and that effectively acts as a "switch". > > > > Is this sound reasoning, or am I missing something critical > >and there is a better way to do this? > > > The master switch is generally not a source of power > but a closure to ground for the battery contactor. > Hi Bob, What I meant to type was master power BUSS, not switch. That's what I get when I let my fingers do the typing without the brain attached... :-) I guess the real question I have is would it be okay to just use a 5A pullable circuit breaker instead of the breaker and switch combination that is traditional for the alt. field? My thoughts, which may be wrong, is that you'd want the alternator enabled all the time anyways, unless there was a problem with it, in which case you can pull the breaker just as easily as throwing a switch. I'd source the 5A breaker from the master power buss. The alt. field is currently sourced through the circuit breaker that powers all of the panel instruments (not avionics), which doesn't seem like a good thing to me. I'd like to move it to its own breaker, but due to very limited panel space, would like to eliminate the switch and just use the breaker. You've got me doubting my memory, so I'll have to go check again to be sure, but I believe the master power switch is only a single throw, single contact switch. I think at some point I am going to have to rewire the entire plane, since I have my doubts about some of the other wiring as well, but am not ready for that task just yet. Currently I'm just trying to improve a little where I can. -Dj -- Dj Merrill Thayer School of Engineering ThUG Sr. Unix Systems Administrator 8000 Cummings Hall deej(at)thayer.dartmouth.edu - N1JOV Dartmouth College, Hanover, NH 03755 "On the side of the software box, in the 'System Requirements' section, it said 'Requires Windows 95 or better'. So I installed Linux." -Anonymous ________________________________________________________________________________
Date: Sep 30, 2003
Subject: AeroElectric-List Digest Subscribers
All AEList subscribers should be aware that when you simply reply to a List message on your screen that ALL of the incoming message gets appended to your reply. If you're a AEList Digest subscriber, it's possible to make a one-sentence reply to something with LOTS of irrelevant stuff tacked on behind it. It's a good thing to forward snippets of an original message interspersed with your comments to maintain continuity of the conversation. Every Digest subscriber needs to be especially watchful . . . it's really easy to "clog the pipes" with useless stuff. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Sep 30, 2003
Subject: Re: Alternator Wiring
> > >Thanks for the various responses to my posting, copy below. The consensus >seem to be a standard sized pulley and I will machine a replacement from alloy. Have you checked with an alternator shop? They can often supply a pulley for a price much more reasonable than carving your own . . . salvage yards are potential sources too. > Still not sure about connections required. It would appear only one of > the three pins is connected, other than the main power lead. Does anyone > know which one? ( the connector has three small pins in a straight line > ), or is there a way of testing. Thanks for your help. Are there any pin labels cast into the housing? Bob . . . ________________________________________________________________________________
Date: Sep 30, 2003
> > > > >Hi Bob, > What I meant to type was master power BUSS, not switch. >That's what I get when I let my fingers do the typing without >the brain attached... :-) > > I guess the real question I have is would it be okay to >just use a 5A pullable circuit breaker instead of the >breaker and switch combination that is traditional for the alt. field? >My thoughts, which may be wrong, is that you'd want the >alternator enabled all the time anyways, unless there was a >problem with it, in which case you can pull the breaker just >as easily as throwing a switch. Unless you've tested your alternator/regulator combination for sans-battery operations, you should consider shutting of the alternator automatically any time battery is off. This was the rational behind development of the infamous split-rocker battery-master common to so many contemporary production aircraft. It's also the reason all of our suggested power distribution diagrams show a two-pole DC PWR MASTER switch wired to produced the cited behavior. > I'd source the 5A breaker >from the master power buss. The alt. field is currently >sourced through the circuit breaker that powers all of the >panel instruments (not avionics), which doesn't seem like a >good thing to me. I'd like to move it to its own breaker, >but due to very limited panel space, would like to >eliminate the switch and just use the breaker. > > You've got me doubting my memory, so I'll have to go >check again to be sure, but I believe the master power >switch is only a single throw, single contact switch. >I think at some point I am going to have to rewire the >entire plane, since I have my doubts about some of the other >wiring as well, but am not ready for that task just yet. >Currently I'm just trying to improve a little where I can. You can do as you've suggested but I don't recommend it. If it were my airplane, it would get a two pole master switch -AND- an independent field supply breaker. Bob . . . ________________________________________________________________________________
Date: Sep 30, 2003
Subject: Re: E-mail Contact Request
>>Thank you for your inquiry to Bob Nuckolls submitted on Tuesday, >>September 30, 2003. > >Bob, >I've got an electrical problem with my Jurca Sirocco. During flight, the >voltage regulator circuit breaker tripped. It will not reset. And after >flight, if I reset it, as soon as the master switch is turned on, the V-R >breaker trips. I recently installed a new Electrosystems alternator from >Aircraft Spruce, but it worked okay until this breaker thingy started. >I'm not sure if I should suspect the new alternator, the wiring, or the >voltage regulator. My plane has the Prestolite voltage regulator, with the >separate overvoltage module next to it. Before I start replacing these >expensive components, I'd rather troubleshoot. My question is, what could >cause the voltage regulator breaker to trip? Could a wiring short cause >this? or would it more likely be the voltage regulator? Or maybe the >alternator. I've inclosed the schematic of my electrical system. If you >have an idea of where would be best to start, I sure would appreciate it. >I have an multimeter that checks voltage (DC&AC) and ohms. (radio shack >type) Thanks, Richard May > I've highlighted the drawing you sent me. You have a rudimentary trouble shooting task. Someplace along the pathway highlighted there is a short and/or failed component. I'd start at the alternator and momentarily disconnect wires until the breaker stops tripping. When you find the first clearance point for the fault, the problem lies between the last point where the fault existed and the first fault-free point. See http://www.aeroelectric.com/temp/BobMay.jpg I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. A further benefit can be realized with membership on the list. There are lots of technically capable folks on the list who can offer suggestions too. You can join at . . . http://www.matronics.com/subscribe/ Well considered and technically elegant answers to all of your questions are waiting for you there. Thanks! Bob . . . |---------------------------------------------------| | A lie can travel half way around the world while | | the truth is till putting on its shoes . . . | | -Mark Twain- | |---------------------------------------------------| ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Date: Sep 30, 2003
For those who have been living in a cave: The current virus harvests email addresses from UseNet and then spoofs the senders address from that list... The people supposedly sending you the infected mail did not send you that mail... Ranting and railing at them is a waste of energy... Make sure you know what to do to block this spam... My email firewall is showing 200 to 500 emails a day it is dumping... Denny ________________________________________________________________________________
Date: Sep 30, 2003
Subject: Microair 760 Ground Confusion
I am installing my 760 and have run into the conflict between the Microair manual and Bob's Audio Iso Amp (which I am using) instructions. Microair says to keep the microphone grounds separate from supply negative (using pin 2 on the connector exclusively) and to connect all other signals to supply neg. The Audio Iso Amp drawing 2.1 shows the headsets and PTT grounds sharing pin 2 with the mics. My instinct is to connect as Bob advises, but why the note in the Microair manual? Also, the intercom switch is shown with a panel ground- is there a specific reason this is segregated from the others? I recall some discussion on the A-list some time back but after much archive-wading could not find it- sorry to rehash! Thanks! Mark Phillips ________________________________________________________________________________
Date: Sep 30, 2003
Subject: Re: Sirroco
I saw your email re your Sirrocco. There is a Sirrocco project on Ebay and I'm looking for a project---what are your thoughts on the Sirrocco? Geoff ________________________________________________________________________________
Date: Sep 30, 2003
On Tue, 2003-09-30 at 13:17, Robert L. Nuckolls, III wrote: > Unless you've tested your alternator/regulator combination > for sans-battery operations, you should consider shutting > of the alternator automatically any time battery is off. > This was the rational behind development of the infamous > split-rocker battery-master common to so many contemporary > production aircraft. It's also the reason all of our > suggested power distribution diagrams show a two-pole > DC PWR MASTER switch wired to produced the cited > behavior. Effectively, in its current wiring, and my proposed, the alt field power is cut whenever the master power switch is off, thus disabling both battery power and alt power at the same time. The circuit breaker will allow independant cut-off of the alt. field, leaving battery power running. > You can do as you've suggested but I don't recommend > it. If it were my airplane, it would get a two pole > master switch -AND- an independent field supply > breaker. I know. The wiring at present is a mess, IMHO. I'm just trying to clean up the electrical mess on the plane, and literally will have to rewire a lot to make it "right" in my opinion (and yours). Short term, I can at least make the alt. field cutoff independant of the panel power, and long term, I need to redesign the panel to have the room to put in the appropriate breakers and switches. I just wanted to make sure I wasn't making anything worse by my proposed change. I'll poke around to see if I can find a two pole switch that will fit in place of the single pole that is there now, and make it part of the short term fix. Thanks for the advice and the great book - it has been enlightening! -Dj -- Dj Merrill Thayer School of Engineering ThUG Sr. Unix Systems Administrator 8000 Cummings Hall deej(at)thayer.dartmouth.edu - N1JOV Dartmouth College, Hanover, NH 03755 "On the side of the software box, in the 'System Requirements' section, it said 'Requires Windows 95 or better'. So I installed Linux." -Anonymous ________________________________________________________________________________
From: "Werner Schneider" <wernerschneider(at)compuserve.com>
Date: Sep 30, 2003
Hello Neil, the list will not send any attachements to you and you should know, that most of the today's mass mailing worms are spoofing the sender adress, all entries! So you can hope that finally the originator finds out about his infection by himself. I can only urge to everybody, use an always current virus scanner and update at least once a week or even better get one which will update automotically. Kind regards Werner ----- Original Message ----- From: "Neil Clayton" <harvey4(at)earthlink.net> Subject: AeroElectric-List: Re: COZY: Somebody is Infected!!! > > These worms have been flooding into my machine for days now, all from the > cozy builders group, the canard aviators group, or the Aeroelectric list.. > My virus scanner always catches them but it's darned annoying since each > one needs handling. I get ~15 a day on average. > > To Marc + canard/ Matronics moderators; is there anything we can do to trap > them at the mail servers? > > To Jay....don't assume you're safe because "we don't download files from > each other". Damaging code can be embedded or attached to a mail and hurt > you just as badly. Make sure your virus definitions are always up-to-date. > > Neil > > > At 06:03 PM 9/29/03, CozyCrafter(at)aol.com wrote: > >In a message dated 9/29/2003 3:01:56 PM Pacific Standard Time, > >CozyBuilders(at)DrewChaplinPhoto.Com writes: > >Hello all, > > > >I have received several messages from somebody on this list with the > >"W32.Swen.A@mm" virus. I only use this particular email account for > >this group, so I know it has originated here. I do not know who is > >sending it out because it's hidden the user. The message appears to > >come from the Network Security Department at Microsoft and has the > >subject of "Current Microsoft Upgrade". The attached file name is > >Pack3221. My Antivirus program is catching and I hope yours has done > >the same. It's a fairly new virus and your Antivirus software has to > >have been updated since 9/18/2003 to find it. As I said before, I use > >the CozyBuilders(at)DrewChaplinPhoto.com email address only for this group > >and nothing else. The message came in on it. > > > >By the way, > >ROUGH RIVER WAS A BLAST!!!! > >Thank you Dan & Lori Cruger for the ride! > > > >Well worth the Drive > >Drew Chaplin > >---- > >Cozy Mark IV > >SN# 1200 Prebuild & Planning > > > > > >I dont know much about computers (relative) but I dont see how this is a > >problem since we dont download files from each other. Please explain. Jay > > ________________________________________________________________________________
Date: Sep 30, 2003
> > >On Tue, 2003-09-30 at 13:17, Robert L. Nuckolls, III wrote: > > I just wanted to make sure I wasn't making >anything worse by my proposed change. > > I'll poke around to see if I can find a two pole >switch that will fit in place of the single pole >that is there now, and make it part of the short term fix. Take a look at the S700-2-10 from B&C at http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?11X358218 This is a progressive transfer switch that will probably fit the space you have. It mimics the operation of a split rocker when wired as shown in the Z-drawings. > Thanks for the advice and the great >book - it has been enlightening! My pleasure sir. Bob . . . ________________________________________________________________________________
Date: Sep 30, 2003
Subject: Re: Microair 760 Ground Confusion
> >I am installing my 760 and have run into the conflict between the >Microair manual and Bob's Audio Iso Amp (which I am using) >instructions. Microair says to keep the microphone grounds separate >from supply negative (using pin 2 on the connector exclusively) and to >connect all other signals to supply neg. The Audio Iso Amp drawing 2.1 >shows the headsets and PTT grounds sharing pin 2 with the mics. My >instinct is to connect as Bob advises, but why the note in the Microair >manual? Wire per http://www.aeroelectric.com/Catalog/avionics/760imB.pdf page 2.1 of drawings in the back. The reason I wrote my own installation manual for the 760VHF was because of less than clear and/or well reasoned instructions and terminology in the factory manual. >Also, the intercom switch is shown with a panel ground- is there a >specific reason this is segregated from the others? It doesn't matter where this grounds . . . it is not a signal line and is easier to ground it to the single point panel ground than to tie it back into the radio harness. Bob . . . ________________________________________________________________________________
Date: Sep 30, 2003
Bob, What does "progressive transfer" mean in ref to the S-700-2-10? David Carter ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: alternator field cut-off > > > > > > >On Tue, 2003-09-30 at 13:17, Robert L. Nuckolls, III wrote: > > > > > > > > I just wanted to make sure I wasn't making > >anything worse by my proposed change. > > > > I'll poke around to see if I can find a two pole > >switch that will fit in place of the single pole > >that is there now, and make it part of the short term fix. > > Take a look at the S700-2-10 from B&C at > http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?11X358218 > > This is a progressive transfer switch that will probably > fit the space you have. It mimics the operation of a > split rocker when wired as shown in the Z-drawings. > > > > Thanks for the advice and the great > >book - it has been enlightening! > > My pleasure sir. > > Bob . . . > > ________________________________________________________________________________
Date: Oct 01, 2003
> > >Bob, > >What does "progressive transfer" mean in ref to the S-700-2-10? > >David Carter Study the schematic symbols for the S700-2-10 and S700-2-50 switches in http://www.aeroelectric.com/articles/Rev10/z10.pdf figure Z11 or figure Z-11 in the Rev 10 book. These are 3 position switches . . . the schematic depicts how one side of the two-pole switch transfers at a time as you move from one position to another instead of moving exactly together as one might usually expect from a multi-pole device. Also see http://www.aeroelectric.com/articles/Carling_Micro/Carling_Micro.pdf Bob . . . ________________________________________________________________________________
Subject: Re: TRAFFIC ALERT ATD-200
Date: Oct 01, 2003
On Wed, 2003-10-01 at 23:45, Ian Scott wrote: > > HI all, > > I have asked this before, however what are people paying for the above > traffic detection device? I paid $200 on Ebay about a month ago for a refurbished unit. It works in the sense that it will tell you there is traffic nearby, but don't trust the numeric readout for distance. Mine has been as much as 2 miles off. However, it does at least warn you that something is within 5 miles, which is all I really care about. -Dj -- Dj Merrill Thayer School of Engineering ThUG Sr. Unix Systems Administrator 8000 Cummings Hall deej(at)thayer.dartmouth.edu - N1JOV Dartmouth College, Hanover, NH 03755 "On the side of the software box, in the 'System Requirements' section, it said 'Requires Windows 95 or better'. So I installed Linux." -Anonymous ________________________________________________________________________________
From: "Art/Sue Bertolina" <artbertolina(at)earthlink.net>
Subject: EDM-900
Date: Oct 01, 2003
I'm trying to determine the difference between the EDM-800 and the 900. Does the 900 add enough to your panel to justify the added cost ?. It will be monitoring a TSIO 520BE that has been built to TSIO 550 with hi-compression pistons and reworked turbo's. I intend to run the engine Lean of Peak at cruise. If anyone out there knows these instruments I would appreciate your input Art Bertolina ________________________________________________________________________________
Date: Oct 01, 2003
Subject: Re: EDM-900
In a message dated 10/1/03 3:22:33 PM Central Daylight Time, artbertolina(at)earthlink.net writes: > I'm trying to determine the difference between the EDM-800 and the 900. > Does > the 900 add enough to your panel > to justify the added cost ?. It will be monitoring a TSIO 520BE that has > been built to TSIO 550 with hi-compression pistons and reworked turbo's. I > intend to > run the engine Lean of Peak at cruise. If anyone out there > knows these instruments I would appreciate your input > Art Bertolina > Good Afternoon Art, May I suggest that you contact George Braly or Tim Roehl at Tornado Alley Turbos concerning the desired instrumentation? I think you will find the at George and Tim have the greatest amount of knowledge currently available concerning the operation, care and feeding of those engines. George occasionally makes comments on this forum. Try: http://www.taturbo.com/frames.html Happy Skies, Old Bob ________________________________________________________________________________
Date: Oct 01, 2003
Subject: Re: alternator field cut-off]
>Dear Bob, > >first let me express my thanks to your ever perpetual and never resting >dealing with >all the different questions posed to you - and this is good for the flyer >community!!! > >For some days now I follow your advice from the distance here in Germany >and also - so >I believe, I have read all your articles contained in Aeroelectrics..... Thank you for the kind words. I'm pleased that the effort is useful and makes sense too . . . >However, this subject of alternator field cut-off makes me wonder, whether >this >also applies not only to alternators, but also to GENERATORS as well. > >In our aero club we have a C172B with a Delco-Remy P/N 1101898 and >regulator P/N 1118704 ( 14V 35A). > >Since the double pole single throw master switch is very iffy ( ammeter >jerking...) >I intend to exchange it with a new one. > >Shouldn't I follow your rational and also install a sort of "progressive >transfer switch" >instead of the DPST? EXCELLENT question. In fact, some of the certified kits for generator replacement with an alternator left the original separate and independent control of battery and engine driven power sources in place. Fact is, a GENERATOR will excite and run well without a battery on line . . . independent operation and control of the two sources wasn't a problem. It wasn't until alternators came along that the classic two-switch control system became problematical. As far as I know, the split-rocker master was birthed at Cessna . . . designed so that the alternator can be turned off leaving battery on, but turning the battery off takes the alternator off too. In spite of its very simple concept and operation (you can duplicate it with the -10 progressive switch) the split rocker fit Cessna Marketing's notion of how the panel should look and operate. The spit rocker has taken on a aura of holiness over the years. I've seen many airplanes with the red, split-rocker master switch that didn't match any other switch in the airplane! So, replacement of the generator control switch with a single switch as supplied by the factory is a perfectly reasonable thing to do . . . if you ever replace the generator with an alternator, combining alternator and battery master switches into a single -10 switch (or if the split rocker gives you a whizz . . . why not?). Bob . . . ________________________________________________________________________________
Date: Oct 01, 2003
No, it's actually over speeding the alternator causing wear of the bearings. Lyc's have a very large dia. pulley on the starter ring - if you figure the ratio if it going 2500 RPM, you would be spinning the alternator 8000 RPM or more. > >Hello Neil, > >Keep in mind that the clearance between the cowling and the larger diameter >pulleys can be a nuisance factor. >Four inch would be a bit too large on my setup for an O360. On your O320 >your distance might vary. >There is a lot of info in the archives re-larger pulleys and alternator >speed. I think the main concern would be too low voltage output at idle. > >Jim in Kelowna > > .----- Original Message ----- >From: "Neil Clayton" <harvey4(at)earthlink.net> >To: >Subject: Re: AeroElectric-List: Alternator Wiring > > > > > > > Spruce sells a 4", "V" pulley. Page 245, $48.95. > > Check the ID > > Neil > > > > > > At 03:47 AM 9/27/03, you wrote: > > > > > > > > >Listers > > > > > >I have obtained an almost new Nipon Denzo alternator off a Toyota which I > > >intend fitting to a Lyco320 In my RV9. > > >I have a couple of questions. Firstly I assume it's internally regulated > > >although it has a 3 wire socket, what are the 3 connections for and is a > > >mating plug readily available. Van's sell one that looks as if fits. > > >Secondly it is currently fitted with a flat belt pulley which I need to > > >change this to a V belt. I seem to recall Bob Avery used to sell a larger > > >dia pulley, is this worth considering and if not could anyone direct me >to > > >source of standard sized pulleys. > > > > > >Thanks for your help. > > > > > >Neil Henderson RV9-A n/r Aylesbury UK > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 01, 2003
Hi "jerb", The last I heard spinning an alternator at 8000 rpm. is well within any usefull limitations on it's bearing life. As far as belt friction and adverse heat generation are conserned the older style V-belts are happier on larger pulleys. I expect this is a big part of why the auto industry went over to the Micro-V type belts. Depending on the size of the larger alternator pulley you choose you might find that the alternator output at idle is adversely effected. In the past more than one builder has encountered the need to add a blister to the cowl to clear the alternator pulley. The likelihood of this occurring is increased when a larger diameter pulley is installed. I in fact have a 3.5" pulley on my O360. this pulley clears the cowling by about 1/4" and I might have to consider reducing it's size for cowling clearance reasons. The engine came with accessories and the "starter ring" had been modified to utilize a Gates Micro-V belt that drives the alternator. He also made the 3.5" pulley It looks to me the fellow that made the pulley modifications did a great job and I will go with his idea until testing and actual use cause a change of course. I will certainly be happy to hear from a qualified person if what I have had quoted to me as safe alternator RPM. limitations needs to be brought up to speed (;}. I think a look in the archives will show that this has been hashed out some before. Try searching the archives wit (alternator rpm) or (alternator speed). Jim in Kelowna ----- Original Message ----- From: "jerb" <ulflyer(at)verizon.net> Subject: Re: AeroElectric-List: Alternator Wiring > > No, it's actually over speeding the alternator causing wear of the > bearings. Lyc's have a very large dia. pulley on the starter ring - if you > figure the ratio if it going 2500 RPM, you would be spinning the alternator > 8000 RPM or more. > > > > > >Hello Neil, > > > >Keep in mind that the clearance between the cowling and the larger diameter > >pulleys can be a nuisance factor. > >Four inch would be a bit too large on my setup for an O360. On your O320 > >your distance might vary. > >There is a lot of info in the archives re-larger pulleys and alternator > >speed. I think the main concern would be too low voltage output at idle. > > > >Jim in Kelowna > > > > .----- Original Message ----- > >From: "Neil Clayton" <harvey4(at)earthlink.net> > >To: > >Subject: Re: AeroElectric-List: Alternator Wiring > > > > > > > > > > > > Spruce sells a 4", "V" pulley. Page 245, $48.95. > > > Check the ID > > > Neil > > > > > > > > > At 03:47 AM 9/27/03, you wrote: > > > > > > > > > > > >Listers > > > > > > > >I have obtained an almost new Nipon Denzo alternator off a Toyota which I > > > >intend fitting to a Lyco320 In my RV9. > > > >I have a couple of questions. Firstly I assume it's internally regulated > > > >although it has a 3 wire socket, what are the 3 connections for and is a > > > >mating plug readily available. Van's sell one that looks as if fits. > > > >Secondly it is currently fitted with a flat belt pulley which I need to > > > >change this to a V belt. I seem to recall Bob Avery used to sell a larger > > > >dia pulley, is this worth considering and if not could anyone direct me > >to > > > >source of standard sized pulleys. > > > > > > > >Thanks for your help. > > > > > > > >Neil Henderson RV9-A n/r Aylesbury UK > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 01, 2003
Subject: Use of individual wires from a Mil-Spec C-27500 cable
Bob & Listers, I was given a large quantity of Mil Spec Aviation wiring from a friend. Some of this wire was 22 & 20 gauge C-27500 shielded 2 & 3 wire cable. Some of this cable had been stripped of it's outer sheath and shielding. This cable has color coded wires inside (red, blue & yellow). Are these individual wires OK to use on my RV-8A project? It appears that the insulation is slightly thinner on these wires as compared to individual Mil 22759/16 wires. I'd like to use this wire, but I want to make sure that I am not "cutting corners" in doing so. Opinions please. Charlie Kuss RV-8A going cross eyed looking at wiring schematics SE Florida ________________________________________________________________________________
Date: Oct 01, 2003
>From: "Ian Scott" <jabiru22(at)yahoo.com.au> >Reply-To: aeroelectric-list(at)matronics.com >To: >Subject: AeroElectric-List: TRAFFIC ALERT ATD-200 >Date: Wed, 1 Oct 2003 20:45:44 -0700 DATE_IN_FUTURE_12_24 (2.8 points) >Date: is 12 to 24 hours after Received: date > > > >HI all, > >I have asked this before, however what are people paying for the above >traffic detection device? > >Thanks > >Ian > I have no experience with the item you asked about, but, I bought one of the TPAS devices from "SureChek". It is surface-mount using velcro, or some other method, and is commonly placed on top of the panel. I like the unit a great deal, and would certainly purchase again if I was in the market. HOWEVER, the unit you mentioned may be a panel-mount-type, and the reason I'm writing this, is that the company has indicated that they will have a panel-mount unit available late this year. You might want to look them up and see if it is ready, or what it will cost. Their address an the web is:
http://www.surecheckaviation.com/index.php Hope this helps, George ________________________________________________________________________________
From: "Dean Psiropoulos" <deanpsir(at)easystreet.com>
Subject: List wierdness.
Date: Oct 01, 2003
Anyone know whats going on with the list, the last three days I have received what appears to be the prior day's list concatenated with the present day's list. Today the subject line said 17 messages but it looks like I've only received the first new message posted today followed by the last three days lists tacked on afterwords. Since the whole thing is getting to be many many pages long with this craziness and I don't appear to be receiving the days new postings, I'll have to unsubscribe from the list if this doesn't get corrected soon. Is anyone else having this problem? I'm not getting the messages as they come through so maybe if I switch to that mode (from the once daily concatenated list) things will work better (except I'll have tons more email messages every night and I don't cherish weeding through all that). Dean Psiropoulos ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Fast-ons
Bob, Just out of curiosity, why doesn't B&C use fast-ons on their voltage regulators? John Herminghaus ________________________________________________________________________________
Date: Oct 01, 2003
Subject: Re: List weirdness.
I think the List operation and digest are fine. The problem with yesterday's digest is that someone - well, okay Ronnie Brown :-) - replied to the previous day's *digest* message and included all of the digest in his post. If you look at the Digest carefully, you'll see that Message 2 from yesterday is REALLY long, then comes Message 3 and the rest of the day's messages which are all normal sized. http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2003-09-30.txt The bottom line I guess, is PLEASE when you reply to a message - ESPECIALLY a DIGEST message - edit out all of the stuff that doesn't directly apply to your post!!! Best regards, Matt Dralle Email List Admin... At 08:51 PM 10/1/2003 Wednesday, you wrote: > > >Anyone know whats going on with the list, the last three days I have >received what appears to be the prior day's list concatenated with the >present day's list. Today the subject line said 17 messages but it looks >like I've only received the first new message posted today followed by the >last three days lists tacked on afterwords. Since the whole thing is >getting to be many many pages long with this craziness and I don't appear to >be receiving the days new postings, I'll have to unsubscribe from the list >if this doesn't get corrected soon. Is anyone else having this problem? >I'm not getting the messages as they come through so maybe if I switch to >that mode (from the once daily concatenated list) things will work better >(except I'll have tons more email messages every night and I don't cherish >weeding through all that). > > >Dean Psiropoulos Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Oct 01, 2003
"Re: AeroElectric-List: List weirdness." (Oct 1, 9:57pm)
Subject: List weirdness. [Update...]
Update on this issue... Looking at my filters in some detail tonight, I discovered that my "The poster has included all or most of the Digest in their reply" Detector was broken and not bouncing messages that included all of the previous day's digest text. I've fixed the problem and the detector is once again functioning as designed! The real bottom line...? Posters still should trim that quoted reply text WAY down when replying to a message, especially a Digest message, but at least now the worst offenders will be intercepted! :-) Basically how it works is that if a poster does included all or most of the previous day's Digest in a reply, they will receive a polite email message back indicating what they've done asking that they trim the quoted text down and try reposting. Best regards, Matt >-------------- >I think the List operation and digest are fine. The problem with >yesterday's digest is that someone - well, okay Ronnie Brown :-) - replied >to the previous day's *digest* message and included all of the digest in >his post. If you look at the Digest carefully, you'll see that Message 2 >from yesterday is REALLY long, then comes Message 3 and the rest of the >day's messages which are all normal sized. > > http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2003-09-30.txt > >The bottom line I guess, is PLEASE when you reply to a message - ESPECIALLY >a DIGEST message - edit out all of the stuff that doesn't directly apply to >your post!!! > >Best regards, > >Matt Dralle >Email List Admin... > > >At 08:51 PM 10/1/2003 Wednesday, you wrote: >> >> >>Anyone know whats going on with the list, the last three days I have >>received what appears to be the prior day's list concatenated with the >>present day's list. Today the subject line said 17 messages but it looks >>like I've only received the first new message posted today followed by the >>last three days lists tacked on afterwords. Since the whole thing is >>getting to be many many pages long with this craziness and I don't appear to >>be receiving the days new postings, I'll have to unsubscribe from the list >>if this doesn't get corrected soon. Is anyone else having this problem? >>I'm not getting the messages as they come through so maybe if I switch to >>that mode (from the once daily concatenated list) things will work better >>(except I'll have tons more email messages every night and I don't cherish >>weeding through all that). >> >> >>Dean Psiropoulos > > >Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 >925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email >http://www.matronics.com/ WWW | Featuring Products For Aircraft > > >-------------- -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ------- ________________________________________________________________________________
Date: Oct 02, 2003
Subject: relay diagram for Microair PTT
--0-1662827501-1065101367=:90978 How exactly are the relays wired on the Microair PTTs? The schematic that Microair supplies is a little confusing for me. I don't like always having it hot. When the relays are installed how does it decide who gets to transmit if both switches are pushed (whoever is first? It becomes hot again so both can talk at the same time?) Which relays to use (prefereably something small and light and cheap)? Thanks! Joa --------------------------------- --0-1662827501-1065101367=:90978 How exactly are the relays wired on the Microair PTTs? The schematic that Microair supplies is a little confusing for me. I don't like always having it hot. When the relays are installed how does it decide who gets to transmit if both switches are pushed (whoever is first?It becomes hot again so both can talk at the same time?) Which relays to use (prefereably something small and light and cheap)? Thanks! Joa --0-1662827501-1065101367=:90978-- ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Re: Fast-ons
> > >Bob, > >Just out of curiosity, why doesn't B&C use fast-ons on their voltage >regulators? > >John Herminghaus The regulator was designed in the year 8 BFO . . . (before fast ons). We were not even considering their suitability and utility in system fabrication at the time. We wrestled with whether or not to use terminal screws or some kind of connector (95% of my customers for certified product shun terminal strips . . . too easy to mess up wire placement in the field). Terminal strips were chosen for cost effectiveness. Now that these regulators are part of STC'd kits, they are for all practical purposes, cast in stone. If I do any new designs for OBAM aircraft, they will be fitted with a connector. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Re: Alternator speeds and belt tensions.
> >Hi "jerb", > >The last I heard spinning an alternator at 8000 rpm. is well within any >usefull limitations on it's bearing life. B&C alternators have racked up tens of thousands of flight hours running well over 10KRPM with great success. >As far as belt friction and adverse heat generation are conserned the older >style V-belts are happier on larger pulleys. I expect this is a big part of >why the auto industry went over to the Micro-V type belts. >Depending on the size of the larger alternator pulley you choose you might >find that the alternator output at idle is adversely effected. agree >In the past more than one builder has encountered the need to add a blister >to the cowl to clear the alternator pulley. The likelihood of this occurring >is increased when a larger diameter pulley is installed. correct >I in fact have a 3.5" pulley on my O360. this pulley clears the cowling by >about 1/4" and I might have to consider reducing it's size for cowling >clearance reasons. >The engine came with accessories and the "starter ring" had been modified to >utilize a Gates Micro-V belt that drives the alternator. >He also made the 3.5" pulley It looks to me the fellow that made the pulley >modifications did a great job and I will go with his idea until testing and >actual use cause a change of course. that was a LOT of trouble and expense for nearly immeasurable benefit . . . >I will certainly be happy to hear from a qualified person if what I have had >quoted to me as safe alternator RPM. limitations needs to be brought up to >speed (;}. > >I think a look in the archives will show that this has been hashed out some >before. >Try searching the archives wit (alternator rpm) or (alternator speed). Someone asked the question a few days ago, "What is the method for PROPER tightening of the alternator belt." A fair question since I've used the phrase many times. I and folks at B&C have been digging through the engineering literature on belts. If one wishes to install a belt for a particular tension, there are many non-cheap instruments you can purchase to actually measure and thus facilitate adjustment of belt tension. Okay, how do we pick a PROPER tension and can it be done without relying on expensive and seldom used instrumentation. Further, in light of more than half a century of "stick the crowbar in there, stretch 'er tighter than hell and cinch it down" techniques used in FBO and OBAM aircraft shops alike, belt life has not bubbled up to the top of our most pressing maintenance problems. After several days of picking though the sparse data, I'm about to conclude that actual tension settings for any particular application are empirically derived by the system engineer, not the belt engineer. Belts are loosely spec'd for horsepower ratings assuming a certain RPM (usually 1750 - common motor output speed for many industrial situations) on the smallest pulley . . . which has nothing in common with the way we use the belts on airplanes. Intuitively, a belt running too tight is overstressed and life is reduced while bearing loads are excessive and reduces life of those components as well. A belt too loose slips, wears rapidly and prevents the alternator from running at max performance. The range of tension values between too tight and too loose is huge. Obviously, from the pilot's perspective, the best thing is to err on the side of too tight and watch the belt for service life issues on the ground instead of discovering them in the air. Given our knowledge of decades of service history watching quality (Gates) belts run quality (ND) alternators, the loosely defined tightening technique defined above seems quite adequate. Every time I fly, fingers run over the surface of the belt looking for any signs of frayed edges and eyes look for signs of overheat-polish on belt sides. A tug on the belt confirms that it still "cinched down tight." I've never had to abort a mission due to discovery of a questionable alternator belt. Sooo . . . if it were my airplane, (and given the small cost of a belt compared to other costs of owning an airplane) I'd continue to do the crowbar operation for tightening and put a new belt on the a new battery every year. Both of these items will be at the bottom of the list for flight safety and/or maintenance concerns. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Re: Use of individual wires from a Mil-Spec
C-27500 cable > >Bob & Listers, > I was given a large quantity of Mil Spec Aviation wiring from a friend. > Some of this wire was 22 & 20 gauge C-27500 shielded 2 & 3 wire cable. > Some of this cable had been stripped of it's outer sheath and shielding. > This cable has color coded wires inside (red, blue & yellow). Are these > individual wires OK to use on my RV-8A project? It appears that the > insulation is slightly thinner on these wires as compared to individual > Mil 22759/16 wires. I'd like to use this wire, but I want to make sure > that I am not "cutting corners" in doing so. Opinions please. >Charlie Kuss >RV-8A going cross eyed looking at wiring schematics >SE Florida Mil-C-27500 is an ASSEMBLY specification for bringing a variety of materials (wires, shielding and outer jackets) together into bundles of wire that may be shielded. See: http://www.awcwire.com/pdf/CT-G4-M27500.pdf Given the relatively modern incarnation of this specification it is unlikely that anything you find assembled under it will be unsuited for use in your airplane. I'd say, "drive on and let not your heart be troubled." Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Re: relay diagram for Microair PTT
> >--0-1662827501-1065101367=:90978 > > >How exactly are the relays wired on the Microair PTTs? The schematic that >Microair supplies is a little confusing for me. > >I don't like always having it hot. When the relays are installed how does >it decide who gets to transmit if both switches are pushed (whoever is >first? It becomes hot again so both can talk at the same time?) > >Which relays to use (prefereably something small and light and cheap)? > >Thanks! > >Joa I'm not familiar with any schematics provided by Microair that incorporate relays. Can you point me to an internet resource where I can find the drawing in question? Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
Subject: Re: Dielectric grease recommendations
> >I'm new to the forum. I just got some dielectric grease off Ebay--3 tubes ( >big ones) for about $20. I'm curious too can bearing grease work? The idea >must have started some time ago with an old-timer and I JUST BET that the >type >actually isn't all that important. (?????) Geoff If one is pre-disposed to use guckums to enhance the performance of a connection and there is a rational justification for them, probably any grease would add some level of enhancement. Having said that, I've never seen a magic potion called out on the installation drawings for any crimped terminal going into a production airplane. There is a VERY strong reluctance to use a design where "protective" processes are necessary or useful. We work hard to design out the need for any such techniques on the assembly line. Had a conversation just yesterday about a bofa-fide need to seal exposed terminals on a vendor supplied product that gets routinely rained on every time the airplane descends from altitude. We moved the sealing process from our assembly line to the manufacturer's facility where it can be inspected and controlled. There was no way we were going to ask a line mechanic to do this with repeatable results. Bottom line is that there may be a valid, engineered requirement for sprays, goops and goos in the assembly of your airplane . . . if you're concerned about a particular situation, let's pick it apart and discover the physics behind the need. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: AeroElectric-List: Re: Alternator speeds and belt tensions. > >The engine came with accessories and the "starter ring" had been modified to > >utilize a Gates Micro-V belt that drives the alternator. > >He also made the 3.5" pulley It looks to me the fellow that made the pulley > >modifications did a great job and I will go with his idea until testing and > >actual use cause a change of course. > > that was a LOT of trouble and expense for nearly > immeasurable benefit . . . Right you are Bob, It sure looks cool though! ... Lets just call it a dramatic non event (:-)! Jim in Kelowna ________________________________________________________________________________
Date: Oct 02, 2003
--0-1913595621-1065116012=:42806 www.microair.com.au/admin/uploads/ 760_install_&_user_manual_ver_M.pdf It's hard to read for some reason in this PDF but in my manual (hardcopy with the radio) it's on about page 20 and is the third "option" called "PTT relays for single mic operation". I asked a fellow here at work and he said just use two dpdt relays and wire the appropriate terminals for NC and NO but I'm wanting specific suggestions for relays that are small, light, and cheap (solid state maybe?). I'm surprised this hasn't been addressed before since it's a pain to get the co-pilot to stop talking whenever you want to make a radio call. Thanks! Joa ++++++++++++++++++++++ "Robert L. Nuckolls, III" wrote: I'm not familiar with any schematics provided by Microair that incorporate relays. Can you point me to an internet resource where I can find the drawing in question? --------------------------------- --0-1913595621-1065116012=:42806 www.microair.com.au/admin/uploads/ 760_install__user_manual_ver_M.pdf It's hard to read for some reason in this PDF but in my manual (hardcopy with the radio) it's on about page 20 and is the third "option" called "PTT relays for single micoperation". I asked a fellow here at work and he said just use two dpdt relays and wire the appropriate terminals for NC and NO but I'm wanting specific suggestions forrelaysthat are small, light, and cheap (solid state maybe?). I'm surprised this hasn't been addressed before since it's a painto get the co-pilot to stop talking whenever you want to make a radio call. Thanks! Joa ++++++++++++++++++++++ "Robert L. Nuckolls, III" bob.nuckolls(at)cox.net wrote: I'm not familiar with any schematics provided by Microair that incorporate relays. Can you point me to an internet resource where I can find the drawing in question?
--0-1913595621-1065116012=:42806-- ________________________________________________________________________________
Subject: GPS-35 / Transponder / Autopilot
Date: Oct 02, 2003
I am going to have the Garmin GPS-35 feeding the heading info to my TruTrak autopilot and I was wondering if I could also hook this signal up to my Garmin GTX-327 transponder for the automatic ALT/STBY switch? I would assume that if I paralleled the two that it may work but I thought that I would ask. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Canopy http://www.myrv7.com ________________________________________________________________________________
Date: Oct 02, 2003
> >--0-1913595621-1065116012=:42806 > >www.microair.com.au/admin/uploads/ 760_install_&_user_manual_ver_M.pdf > > >It's hard to read for some reason in this PDF but in my manual (hardcopy >with the radio) it's on about page 20 and is the third "option" called >"PTT relays for single mic operation". > >I asked a fellow here at work and he said just use two dpdt relays and >wire the appropriate terminals for NC and NO but I'm wanting specific >suggestions for relays that are small, light, and cheap (solid state maybe?). > >I'm surprised this hasn't been addressed before since it's a pain to get >the co-pilot to stop talking whenever you want to make a radio call. > >Thanks! Downloaded the manual . . . UGHhhhh! I offered to do real wiring diagrams that depicted how to connect wires together and now I see that the latest manual is not only worse for diagrams, (nobody should attempt to hook up the system in the manner depicted) the .pdf file was generated with some odd-ball font that probably only prints in part of the world. Okay, you want opposite mic disable when a PTT button is pushed. Do you want the copilot to have radio access too or just intercom? Let's figure out what's needed and do a real wiring diagram. Bob . . . ________________________________________________________________________________
Date: Oct 02, 2003
--0-1573740537-1065127919=:49265 You mean an intercom that requires a button to be pushed to talk to the co-pilot? No, I'm fine with the always hot intercom, it's just the always hot PTT (transmit on the radio) that I don't like. I would like both the pilot and the co-pilot to have PTT buttons and when one pushes theirs it cuts the other person off from talking. If you can't read the diagram I can describe what they are doing (though you obviously know already Im sure). Both relays have one NC terminal going to each mic ring terminal and another terminal in parallel with each other going between the PTT pin (7) and ground. Basically it works so when one PTT is pushed that relay closes the radio PTT circuit and opens the other persons microphone connection so that they cant talk. The Microair circuit looks fine and is pretty elementary(well, it is to me *after* the EE from work explained it!). Im just wanting your expertise in finding a couple nice tiny (but inexpensive) relays (preferably something I can solder in line and just cover with heat shrink) that will work with the currents we have here. Would be great though if you could add this feature to your manual since as you noticed the Microair manual is pretty lacking! Im sure others that arent using a separate intercom would benefit. Thanks Bob! Joa ________________________________________________________________________________
Date: Oct 02, 2003
Sorry that I can't quote a source, but recently I read that a practical way to measure drive belt tension on an alternator is to measure the torque required to turn the alternator pulley until it slips in the pulley with the belt adjusted where you think it should be. Unfortunately I also don't recall what the suggested torque reading was...maybe 10 ft. lbs. Anyway, it should be easy to set by any other method and then measure the "slip" torque. Dick Sipp RV10 N110DV RV4 N250DS ________________________________________________________________________________
Subject: Re: Low voltage warning circuit
Date: Oct 02, 2003
Bob, how could I make the low volt warning threshold adjustable or lower than 13v? I need a device to monitor rear batteries under load in a "rec vehicle" and trigger a remote start at a voltage just above the typical alarm in a large power inverter. Steve DiNieri Rv-6a n221rv I bashed this out in a hurry but I think the schematic and BOM have been brought into agreement with present manufacturing configuration. See http://www.aeroelectric.com/articles/lvwarn/9021-620.pdf If you've downloaded this recently, your browser may have the old version in cache . . . hit the reload button after download to make sure you get the latest. The schematic and BOM pages will have Rev A 10/2/3 in the title block on the latest document. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2003
I know this was meant for Bob, however according to his nice schematic, you could replace R105 with a potentiometer to adjust the trigger voltage. 10.5k ~= 13V 9k ~= 11.5V 8k ~= 10.5V Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steven DiNieri Subject: RE: AeroElectric-List: Re: Low voltage warning circuit Bob, how could I make the low volt warning threshold adjustable or lower than 13v? I need a device to monitor rear batteries under load in a "rec vehicle" and trigger a remote start at a voltage just above the typical alarm in a large power inverter. Steve DiNieri Rv-6a n221rv I bashed this out in a hurry but I think the schematic and BOM have been brought into agreement with present manufacturing configuration. See http://www.aeroelectric.com/articles/lvwarn/9021-620.pdf If you've downloaded this recently, your browser may have the old version in cache . . . hit the reload button after download to make sure you get the latest. The schematic and BOM pages will have Rev A 10/2/3 in the title block on the latest document. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2003
I would also like to mention some of my experiences, although not aircraft related. I worked as an automobile mechanic for years, I found that wires will wick liquid. That is a wire and insulator act just like a pipe for liquid. For example back in the early 80's GM had a temperature sensor on their engines that was prone to leak. It would leak slowly so most people never noticed the leak. However what would happen is the wire for the temperature sensor would wick the coolant from the sensor into the engine computer. Eventually enough coolant would get into the computer to short it out. Another example is GM's 4.3L V-6 in late 90's had a little problem where the fuel injectors would leak. Well the fuel leaked into the electrical connector, which at this point in automotive history are weather pack connectors that are sealed connections. Well the gas then wicks through the wires right back to the computer. The net result is that the gas destroys the plastic for the connectors, and in some cases it will actually fill the computer with an oily substance until the car no longer runs. Like Eric said, the crimp connection is gas tight. The exposed wires which are not crimped are not so lucky. Neither is the area between the copper and the insulation. Here is something more to think about, all the automobile manufactures are going to weather pack and sealed electrical connections. Why? If you checked the price of a weather pack connector lately you will notice they are not cheap so why is GM and others using them on all their cars? Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Eric M. Jones Subject: AeroElectric-List: Re: Dielectric grease recommendations Many people think a dielectric grease might contaminate the surface of a conductor. Of course this is not true, the grease merely fills in the air gaps. Although a "proper" crimp may be gas tight, only the conductor under the crimp is so blessed. Under a microscope the cable will be seen to possess many small channels in the pack. In theory, the channels can wick moisture and contaminants (historically battery acid) into the crimp. Why is this a concern? If all the metal in the joint were the same, we might still want to exclude water because it can freeze and force the joint open. However, a more critical need is to seal the airspaces because of the likelihood that electrolytic corrosion will occur. The metal crimp itself may be aluminum or brass or copper, the plating may be nickel or more likely tin, and the wire may be copper, and ever nickel tin or zinc plated. So electrolytic corrosion can occur. Indoors this is rarely an issue, but aircraft see a lot of water in their lives; it's a good idea to keep it out of the crimp. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net When the Okies moved to California they raised the average IQ of both states. ---Will Rogers ________________________________________________________________________________
Date: Oct 03, 2003
> >I know this was meant for Bob, however according to his nice schematic, you >could replace R105 with a potentiometer to adjust the trigger voltage. > >10.5k ~= 13V >9k ~= 11.5V >8k ~= 10.5V > >Trampas > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steven >DiNieri >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: Re: Low voltage warning circuit > > > > >Bob, how could I make the low volt warning threshold adjustable or lower >than 13v? > I need a device to monitor rear batteries under load in a "rec >vehicle" and trigger a remote start at a voltage just above the typical >alarm in a large power inverter. > >Steve DiNieri >Rv-6a n221rv You can build this any way you wish. The 1% components and the LM285 voltage reference are selected such that the setpoint is predictable to within a few percent. Note that the 10.5K and 2.49K resistors are the 1% voltage divider that determine what the setpoint is for the comparator to see 2.5 volts. If you KNOW what the desired setpoint is, then it's relatively easy to calculate a new value for one of the resistors as suggested above. If the setpoint needs to be adjustable, then making R105 a combination of say a 5K, 10 or 15 turn potentiometer and a 6.98K, 1% resistor would give you a wide range of adjustability. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2003
> >I would also like to mention some of my experiences, although not aircraft >related. > >I worked as an automobile mechanic for years, I found that wires will wick >liquid. That is a wire and insulator act just like a pipe for liquid. For >example back in the early 80's GM had a temperature sensor on their engines >that was prone to leak. It would leak slowly so most people never noticed >the leak. However what would happen is the wire for the temperature sensor >would wick the coolant from the sensor into the engine computer. Eventually >enough coolant would get into the computer to short it out. > >Another example is GM's 4.3L V-6 in late 90's had a little problem where the >fuel injectors would leak. Well the fuel leaked into the electrical >connector, which at this point in automotive history are weather pack >connectors that are sealed connections. Well the gas then wicks through the >wires right back to the computer. The net result is that the gas destroys >the plastic for the connectors, and in some cases it will actually fill the >computer with an oily substance until the car no longer runs. > >Like Eric said, the crimp connection is gas tight. The exposed wires which >are not crimped are not so lucky. Neither is the area between the copper and >the insulation. > >Here is something more to think about, all the automobile manufactures are >going to weather pack and sealed electrical connections. Why? If you checked >the price of a weather pack connector lately you will notice they are not >cheap so why is GM and others using them on all their cars? . . . accurate but anecdotal data. . . . now, how does this relate to the connectors, wire, sensors, operating conditions and history of airplanes? Interesting to think about but at the bottom line, we need to see if there are obvious, understandable shortfalls in the current toolbox of materials and techniques that warrant changes for improvement. When a need for improvement is identified, let's noodle out root cause and see if a change of design, materials, installation or maintenance will deal with the problem in a satisfactory way . . . I'm not suggesting that there isn't a good place for using dielectric or any other kind of grease. But I can give you lots of other, direct to the point experiences where sealants or protectants were at best marginal performers and in some cases, made the problem WORSE. Let's not chase boogy-beasts - the physics of the mater is always stone-simple, the logic pointing us to the elegant solution is easily understood. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: Rrelay diagram for Microair PTT
> > >Would be great though if you could add this feature to your manual since > >as you noticed the Microair manual is pretty lacking! Im sure others that > >arent using a separate intercom would benefit. > > I can do that, but it's two drawings to offer the > variants cited above. > I've added a first-come/first-served PTT relay circuit to the last page of AEC instructions for installation of 760VHF . . . this would work with any other radio too. See: http://www.aeroelectric.com/Catalog/avionics/760imB.pdf Bob . . . ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: Trutrak a/p wiring
>Comments/Questions: Hi Bob: > >I bought your manual a couple of months ago. Great stuff. Going with a >dual alternator / single battery / essential buss system as you show -- >for my RV7A. > >Question: I am installing the Trutrak DigiFlight 200 servo (stepper >motor) in my left wing at the bell crank, and I need to run power to a >wing tip strobe and position light. The position light power wire doesn't >bother me, but the strobe does. I don't want problems with the auto pilot >motor acting crazy due to getting electrical or magnetic pulses. There >are two sets of 1/4" plastic bushed holes already drilled in the wing ribs >-- one for the 1/4" OD plastic pitot line and the other for the wire >bundle. I am nervous about the strobe line being in the same bundle as >the quantity 7 of 22 AWG wires going to the stepper motor -- even with >using a grounded / shielded 16 AWG wire for the strobe. > >Am I being too paranoid? Tru trak wasn't any help when I called >them. Should I run the 16 AWG shielded wire as a 12VDC power wire -- to a >strobe control box mounted next to the wing tip -- verses running a high >voltage intermittent electrical pulse from a strobe power supply box in >the fuselage in the same wire bundle? I'm thinking the capacitor aspects >of the strobe control box should keep the spikes at bay. I don't belive the Trutrak servos contain any vulnerable electronics. With a stepper motor, the ADVANTAGES are that you can build a system with no local electronics or position feedback potentiometers. I can't think of any reason your a/p and lighting wires cannot share the same wire bundle. Wire each system as depicted in the manufacturer's installation instructions and route wiring in the most convenient manner. I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. A further benefit can be realized with membership on the list. There are lots of technically capable folks on the list who can offer suggestions too. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . |---------------------------------------------------| | A lie can travel half way around the world while | | the truth is till putting on its shoes . . . | | -Mark Twain- | |---------------------------------------------------| ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: GPS-35 / Transponder / Autopilot
> > >I am going to have the Garmin GPS-35 feeding the heading info to my TruTrak >autopilot and I was wondering if I could also hook this signal up to my >Garmin GTX-327 transponder for the automatic ALT/STBY switch? I would >assume that if I paralleled the two that it may work but I thought that I >would ask. depends on what "signals" are being exchanged. is this RS-232 serial data? If so, it's likely that one talker (GPS) can drive more than one listener. The experiment is easy to try . . . if it doesn't work, you may need a buffer-amplifier but I suspect simple parallel connection will work. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: GPS-35 / Transponder / Autopilot - REDUX
> > >I am going to have the Garmin GPS-35 feeding the heading info to my TruTrak >autopilot and I was wondering if I could also hook this signal up to my >Garmin GTX-327 transponder for the automatic ALT/STBY switch? I would >assume that if I paralleled the two that it may work but I thought that I >would ask. depends on what "signals" are being exchanged. is this RS-232 serial data? If so, it's likely that one talker (GPS) can drive more than one listener. The experiment is easy to try . . . if it doesn't work, you may need a buffer-amplifier but I suspect simple parallel connection will work. Just as I hit the "send" button, a new question arose . . . HEADING info from your GPS is almost sure to be serial. Transponders don't need heading. If they share anything with the transponder, it's ALTITUDE coming from the encoder as talker and being fed to BOTH transponder and GPS as listeners. There ARE techniques for paralleling multiple listeners onto the output of an altitude encoder. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Antenna cable routing question
Most convenient routing for my comm antenna cable (RG-400) takes it within about 3" of my Facet fuel pump- is this a no-no? Anyone have this condition in use without ill effects? Antenna on fuse bottom. Would the same apply for the xpndr antenna, also on fuse bottom? Thanks! Mark Phillips ________________________________________________________________________________
Date: Oct 03, 2003
Subject: 4 conductor shielded wire for Dynon
To all, For those of you (like me) who have been searching for 4 conductor 22 gauge shielded wire for your remote mounted Dynon Magnetometer, Wicks aircraft has special ordered 500 ft. You will need to let them know it is not in the catalogue. They expect it in next week. They will add it as a permanent item if there is a demand for it. Regards, Dave Burnham RV6A (N64FN) To all, For those of you (like me) who have been searching for 4 conductor 22 gauge=20shielded wire for your remote mounted Dynon Magnetometer, Wicks aircraft has special ordered 500 ft. You will need to let them know it is not in the catalogue. They expect it in next week. They will add it as a permanent item if there is a demand for it. Regards, Dave Burnham RV6A (N64FN) ________________________________________________________________________________
Date: Oct 03, 2003
> > depends on what "signals" are being exchanged. is this RS-232 serial > data? If so, it's likely that one talker (GPS) can drive more than > one listener. The experiment is easy to try . . . if it doesn't work, > you may need a buffer-amplifier but I suspect simple parallel connection > will work. It is RS-232. I'll probably try the parallel and if it doesn't work I can live without it being hooked to the transponder. > > Just as I hit the "send" button, a new question arose . . . HEADING > info from your GPS is almost sure to be serial. Transponders don't > need heading. If they share anything with the transponder, it's > ALTITUDE coming from the encoder as talker and being fed to > BOTH transponder and GPS as listeners. There ARE techniques for > paralleling multiple listeners onto the output of an altitude encoder. > > Bob . . . > The Garmin GTX-327 Transponder has a feature that will switch it from STBY to ALT when the groundspeed is greater than some value (I think it is 40kts). I already have an encoder and this is just an extra feature that I would like to try, if it doesn't work then so be it. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB (Reserved) - Canopy http://www.myrv7.com ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: RV-List: 4 conductor shielded wire for Dynon
DJB6A(at)cs.com wrote: > > --> RV-List message posted by: DJB6A(at)cs.com > > To all, > > For those of you (like me) who have been searching for 4 conductor 22 gauge > shielded wire for your remote mounted Dynon Magnetometer, Wicks aircraft has > special ordered 500 ft. You will need to let them know it is not in the > catalogue. > They expect it in next week. They will add it as a permanent item if there is > a demand for it. > > Regards, > Dave Burnham > RV6A (N64FN) Be sure you check your local electrical cable suppliers. I found a nearby outlet that had the four conductor 22g shielded cable for $0.45/ft. Sam Buchanan ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Re: diy annunciator panel for gps
-------------------------------1065211073 Hello. I am working on installing a Garmin 300xl gps and don't want to pay for (or need) the "factory" annunciator panel. I am wiring my cdi directly to the Garmin, so I don't need the multi pole relay to switch the cdi anyway. However, to be IFR legal, I do need "lights and switches" which I would like to put together myself. The schematic shows that most of the annunciator lights and the "approach" momentary switch are directly tied into the connector; however, the "auto/hold" lights and the "auto/hold" selection switch are tied together. The "auto/hold" function switches between automatically sequencing through the waypoints or holding on a specific way point. The "auto/hold" is laid out such that in the first position the dpdt switch lights the "auto"annunciator and closes the "auto" circuit, and in the other position lights the "hold" light and closes the "hold" circuit. That is, this switch position controls those lights. (It seems odd to me that Garmin would run the other annunciator lights off of the Garmin unit, that is, the lights indicate the circuit as the Garmin sees it, whereas the "auto/hold" lights are lit based on the switch position with no regard to how the Garmin is seeing it) I would like to make a simple annunciator panel using led's and generic mini switches (one momentary and one dpdt). Has anybody done anything like this, I would appreciate any help you can give me on this, what leds to use, etc. I could use the NAT type of switch but that seems bulky and a little pricey and I have become enamored with using some led's anyway. Thank you, Skip Simpson -------------------------------1065211073 tutf-8"> Hello. I am working on installing a Garmin 300xl gps and don't want to pay for (or need) the "factory" annunciator panel. I am wiring my cdi directly to the Garmin, so I don't need the multi pole relay to switch the cdi anyway. However, to be IFR legal, I do need "lights and switches" which I=20would like to put together myself. The schematic shows that most of the annunciator lights and the "approach" momentary switch are directly tied into the connector; however, the "auto/hold" lights and the "auto/hold" selection switch are tied together. The "auto/hold" function switches between automatically sequencing through=20the waypoints or holding on a specific way point. The "auto/hold" is laid out such that in the first position the dpdt switch lights the "auto"annunciator and closes the "auto" circuit, and in the=20other position lights the "hold" light and closes the "hold" circuit.=20That is, this switch position controls those lights. (It seems odd to me that Garmin would run the other annunciator lights off of the Garmin unit, that is, the lights indicate the circuit as the Garmin sees it, whereas the "auto/hold" lights are lit based on the switch position with no regard to how the Garmin is seeing it) I would like to make a simple annunciator panel using led's and generic mini switches (one momentary and one dpdt). Has anybody done anything like this, I would appreciate any help you can give me on this, what leds to use, etc. I could use the NAT type of switch but that seems bulky and a little pricey and I have become enamored with using some led's anyway. Thank you, Skip Simpson -------------------------------1065211073-- ________________________________________________________________________________
Date: Oct 03, 2003
Having just completed an IFR GPS installation in my certified plane I've also been contemplating what to do with my RV. Since you don't need to switch the CDI and I'm sure the Garmin has some sort of message indicator built-in like my GX-60 does, it would seem the only switch-light you need is for the "auto/hold" (called "obs/hold" on mine). All that switch does is suspend/resume the sequencing of segments on the approach. I assume it merely pulls a pin high/low and the light just indicates the position of the switch. The only feedback likely available is whether the sequence suspends or resumes as expected. A simple lighted switch should be enough. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > > > -------------------------------1065211073 > > Hello. > > I am working on installing a Garmin 300xl gps and don't want > to pay for (or > need) the "factory" annunciator panel. I am wiring my cdi > directly to the > Garmin, so I don't need the multi pole relay to switch the > cdi anyway. However, > to be IFR legal, I do need "lights and switches" which I > would like to put > together myself. > > The schematic shows that most of the annunciator lights and > the "approach" > momentary switch are directly tied into the connector; > however, the "auto/hold" > lights and the "auto/hold" selection switch are tied together. The > "auto/hold" function switches between automatically > sequencing through the waypoints or > holding on a specific way point. > > The "auto/hold" is laid out such that in the first position > the dpdt switch > lights the "auto"annunciator and closes the "auto" circuit, > and in the other > position lights the "hold" light and closes the "hold" > circuit. That is, this > switch position controls those lights. (It seems odd to me > that Garmin would > run the other annunciator lights off of the Garmin unit, that > is, the lights > indicate the circuit as the Garmin sees it, whereas the > "auto/hold" lights are > lit based on the switch position with no regard to how the > Garmin is seeing it) > > I would like to make a simple annunciator panel using led's > and generic mini > switches (one momentary and one dpdt). Has anybody done > anything like this, I > would appreciate any help you can give me on this, what leds > to use, etc. I > could use the NAT type of switch but that seems bulky and a > little pricey and > I have become enamored with using some led's anyway. > > Thank you, Skip Simpson > ________________________________________________________________________________
Date: Oct 03, 2003
So should it be assumed that the harness to the compass MUST be shielded? My harness was completed a couple months ago, but the compass (and radios) are not installed yet. Can I test if this is needed using the handheld? What would the procedure be? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] > Sent: Friday, October 03, 2003 3:55 PM > To: rv-list(at)matronics.com > Subject: AeroElectric-List: Re: RV-List: 4 conductor shielded > wire for Dynon > > > > > > DJB6A(at)cs.com wrote: > > > > --> RV-List message posted by: DJB6A(at)cs.com > > > > To all, > > > > For those of you (like me) who have been searching for 4 > conductor 22 > > gauge shielded wire for your remote mounted Dynon > Magnetometer, Wicks > > aircraft has special ordered 500 ft. You will need to let > them know it > > is not in the catalogue. They expect it in next week. They > will add it > > as a permanent item if there is a demand for it. > > > > Regards, > > Dave Burnham > > RV6A (N64FN) > > > Be sure you check your local electrical cable suppliers. I > found a nearby outlet that had the four conductor 22g > shielded cable for $0.45/ft. > > Sam Buchanan ________________________________________________________________________________
Date: Oct 03, 2003
Subject: Fuse Blocks, fuses, fusible links and CBs
--0-361577249-1065230699=:58092 Bob, I am using a derivative of Figure Z-11 architecture for an RV6. I want to feed the electronic ignition from a hot battery bus. The LSE installation instructions say to use a "pullable" 5 amp breaker. The Aeroelectric connection mentions use of a fusible link in this application. I would much prefer a fusible link with an on/off switch over a CB. Do these electronic ignition systems nuisance trip in general? I thought they were supposed to be incredibly reliable (That's why I bought it!!). What would you suggest for a feed to the flap motor. I thought I read something about this is one particular animal that can nuisance trip. If you were to recommend a CB application how would you power that off say the main bus/fuse block? I would prefer to keep the ALT FLD CB the only breaker on the panel, if practical. I haven't seen listed the expected current draw for the flap motor. Can anybody help me out here? Thanks. Greg Grigson Honolulu --------------------------------- --0-361577249-1065230699=:58092 Bob, I am using a derivative of Figure Z-11 architecture foran RV6. I want to feed the electronic ignition from a hot battery bus. The LSE installation instructionssay touse a "pullable" 5 amp breaker. The Aeroelectric connection mentions use of a fusible link in this application. I would much prefera fusible link with an on/off switch over a CB.Dothese electronic ignition systems nuisance trip in general? I thought they were supposed to be incredibly reliable (That's why I bought it!!). What would you suggest for a feedto the flap motor. I thought I read something about this is one particular animal that can nuisance trip. If you were to recommend a CB application how would you power that off say the main bus/fuse block? I would prefer to keep the ALT FLD CB the only breaker on the panel, if practical. I haven't seen listed the expected current draw for the flap motor. Can anybody help me out here? Thanks. Greg Grigson Honolulu --0-361577249-1065230699=:58092-- ________________________________________________________________________________
Date: Oct 03, 2003
Dynon I just re-read the recently released, updated version of the installation manual. It makes no reference to using shielded wire in any part of the installation. I used 4 wire, 22ga shielded because I was lucky enough to have some laying around. I would also like to know if shielded wire is neccesary or even useful in this installation. Jeff Point RV-6 panel, wiring Milwaukee, WI Larry Bowen wrote: > >So should it be assumed that the harness to the compass MUST be >shielded? My harness was completed a couple months ago, but the compass >(and radios) are not installed yet. Can I test if this is needed using >the handheld? What would the procedure be? > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com > > > > >>-----Original Message----- >>From: Sam Buchanan [mailto:sbuc(at)hiwaay.net] >>Sent: Friday, October 03, 2003 3:55 PM >>To: rv-list(at)matronics.com >>Subject: AeroElectric-List: Re: RV-List: 4 conductor shielded >>wire for Dynon >> >> >> >> >> >>DJB6A(at)cs.com wrote: >> >> >>>--> RV-List message posted by: DJB6A(at)cs.com >>> >>>To all, >>> >>>For those of you (like me) who have been searching for 4 >>> >>> >>conductor 22 >> >> >>>gauge shielded wire for your remote mounted Dynon >>> >>> >>Magnetometer, Wicks >> >> >>>aircraft has special ordered 500 ft. You will need to let >>> >>> >>them know it >> >> >>>is not in the catalogue. They expect it in next week. They >>> >>> >>will add it >> >> >>>as a permanent item if there is a demand for it. >>> >>>Regards, >>>Dave Burnham >>>RV6A (N64FN) >>> >>> >>Be sure you check your local electrical cable suppliers. I >>found a nearby outlet that had the four conductor 22g >>shielded cable for $0.45/ft. >> >>Sam Buchanan >> >> > > > > ________________________________________________________________________________
Date: Oct 04, 2003
Subject: Re: Vans gauge lamps
I'm pretty sure somebody makes an LED that has an inverted cone on the top of the body. The cone basically reflects the light out the side of the round body. I seem to recall coming across it while searching for something else a while back, might be Stanley. I'll see if I can track it down. Mike __________________________________ ________________________________________________________________________________
Date: Oct 04, 2003
Try: http://www.allegromicro.com/skncatlg/led/sel6013.pdf http://www.quickar.com/discrete.php?session=JheTrtx3 These are just a couple of the hits I got with a Google search for "inverted cone LED". __________________________________ ________________________________________________________________________________
Subject: Jabiru J400 Signed off today
Date: Oct 05, 2003
DATE_IN_FUTURE_12_24 (2.8 points) Date: is 12 to 24 hours after Received: date Man am I happy. Test flying as soon as I can. Ian ________________________________________________________________________________
Date: Oct 05, 2003
> >Hi Bob - Just reading through the entire Microair installation >Instructions and have a couple >of Q's- on the Mic relay circuit cited below, should not the Mic Hi & Mic >Lo connections to >the radio be made to the NO contacts of the relays? don't know why. you described the operation you wanted and I believe the circuit I drew will do that. I didn't take time to noodle out Microair's circuit . . . it probably does work as they intended but I didn't have time to wade through their schematic and erratic font displays. >Could you please clarify the note in section 4.3- looks like a typo... Yes, fixed it. Thanks for the heads up. I've uploaded the corrected document. >Thanks! Not tryin' to be picky, I'm just wiring mine up right now and >don't want to see no >smoke! Not a problem, I understand. Bob . . . ________________________________________________________________________________
Date: Oct 06, 2003
Oops, that should be the BLUE wires. I didn't have my morning coffee yet. ________________________________________________________________________________
Date: Oct 06, 2003
Subject: Alternator Noise in Headset
--0-1011535678-1065465776=:8230 Bob, I'm starting to develop an electrical problem in my RV-4 and I'm hoping you can help me diagnose it. I bought the RV-4 (completed) last year. It was built in 1988 and I'm the fourth owner. It's a solid airplane, but the documentation is thin and from the logbooks it appears that the electrical stuff (lights, radios) were added piecemeal over the plnae's first few years, so the electrical system is a bit tangled. For example, my nav light circuit breaker kept popping. I finally figured out that the builder / modifier has three 2-amp bulbs (6 amps) going through a 5-amp CB. So I replaced the 5A CB with a 10A CB. Worked great. However, on my next flight, I started hearing a whine in my headset. More of a tone, actually, sounding a lot like Morse from an VOR. Originally intermittent, and as I returned from a cross country it became almost constant. The whine / tone is present with the radios off, strobes off, and alternator off, although I didn't think to pull the breakers on those circuits. I can hear it in the background during intercom and radio reception. It disappears briefly after a radio transmission and then returns after a few seconds. The plane has a voltmeter, no ammeter, and I immediately noticed that the voltage was increasing to about 15.5 V and fluctuating there for a while. Then it settled down to 14.5 V. The problem comes and goes and is not entirely repeatable. Also, perhaps related and perhaps not, the LORAN stopped working a few weeks back. I had thought it had just died due to age, and I was buying a GPS anyway, so I've just left it off since and plan to remove it. I'm thinking the obvious thought that the alternator's going. Because the plane has so little documentation, I don't know the specifics of the alternator at all or how old it is, just that it's been working so far. My A&P found nothing wrong with it at the last annual 60 hours ago. I'm wondering if the impending alternator failure is putting out RF that's getting into the headset and was jamming the LORAN. Also, I've noticed that with the electrical system fully loaded up, the voltmeter needle also starts rapidly fluctuating at 14.5-15.5V. I see this when I turn on the landing light. Due to the lack of documentation I have no idea how many total amps are actually flowing through the system, so I'm wondering if turning on the landing lights actually puts the plane's total current draw above the rated output of the alternator. Is fluctuating system voltage a sign of that? If you could offer any thoughts on this, I'd appreciate it. Best, Pete Waters (registered for your class in Watsonville) --------------------------------- --0-1011535678-1065465776=:8230 Bob, I'm starting to develop an electrical problem in my RV-4 and I'm hoping you can help me diagnose it. I bought the RV-4 (completed) last year. It was built in 1988 and I'm the fourth owner. It's a solid airplane, but the documentation is thin and from the logbooks it appears that the electrical stuff (lights, radios) were added piecemeal over the plnae's first few years, so the electrical system is a bit tangled. For example, my nav light circuit breaker kept popping. I finally figured out that the builder / modifier has three 2-amp bulbs (6 amps) going through a 5-amp CB. So I replaced the 5A CB with a 10A CB. Worked great. However, on my next flight, I started hearing a whine in my headset. More of a tone, actually, sounding a lot like Morse from an VOR. Originally intermittent, and as I returned from a cross country it became almost constant. The whine / tone is present with the radios off, strobes off, and alternator off, although I didn't think to pull the breakers on those circuits. I can hear it in the background during intercom and radio reception.It disappears briefly after a radio transmission and then returns after a few seconds. The plane has a voltmeter, no ammeter, and I immediately noticed that the voltage was increasing to about 15.5 V and fluctuating there for a while. Then it settled down to 14.5 V. The problem comes and goes and is not entirely repeatable. Also, perhaps related and perhaps not, the LORAN stopped working a few weeks back. I had thought it had just died due to age, and I was buying a GPS anyw ay, so I've just left it off since and plan to remove it. I'm thinking the obvious thought that the alternator's going. Because the plane has so little documentation, I don't know the specifics of the alternator at all or how old it is, just that it's been working so far. My AP found nothing wrong with it at the last annual 60 hours ago. I'm wondering if the impending alternator failure is putting out RF that's getting into the headset and was jamming the LORAN. Also, I've noticed that with the electrical system fully loaded up, the voltmeter needle also starts rapidly fluctuating at 14.5-15.5V.I see this when I turn on the landing light. Due to the lack of documentation I have no idea how many total amps are actually flowing through the system,so I'm wondering if turning on the landing lights actually putsthe plane's total current draw above the rated output of the alternator. Is fluctuating system voltage a sign of that? If you could offer any thoughts on this, I'd appreciate it. Best, Pete Waters (registered for your class in Watsonville) --0-1011535678-1065465776=:8230-- ________________________________________________________________________________
Date: Oct 06, 2003
Subject: Re: Fuse Blocks, fuses, fusible links and CBs
Greg, As far as the flap motor goes, I've got a note that it takes 5 amps, although I don't remember where I found that. In any case, I used 16 awg wire & a 10 amp fuse. It's operated perfectly for 600 hrs with no nuisance fuse trips. Regards, Chris Good, http://rv.supermatrix.com West Bend, WI RV-6A 86CG, flying 600 hrs BTW, I'm expecting to be in Honolulu for Thanksgiving. Maybe I'll get a chance to see your project. -- --------- Original Message --------- DATE: Fri, 3 Oct 2003 18:24:59 From: Greg Grigson <iflyhawaii2(at)yahoo.com> > >--0-361577249-1065230699=:58092 > >Bob, > I am using a derivative of Figure Z-11 architecture for an RV6. I want to feed the electronic ignition from a hot battery bus. The LSE installation instructions say to use a "pullable" 5 amp breaker. The Aeroelectric connection mentions use of a fusible link in this application. I would much prefer a fusible link with an on/off switch over a CB. Do these electronic ignition systems nuisance trip in general? I thought they were supposed to be incredibly reliable (That's why I bought it!!). > > What would you suggest for a feed to the flap motor. I thought I read something about this is one particular animal that can nuisance trip. If you were to recommend a CB application how would you power that off say the main bus/fuse block? I would prefer to keep the ALT FLD CB the only breaker on the panel, if practical. > > I haven't seen listed the expected current draw for the flap motor. Can anybody help me out here? > >Thanks. >Greg Grigson >Honolulu > > ________________________________________________________________________________
Subject: Switched gnd?
Date: Oct 06, 2003
The rule of thumb seems to be to switch the positive line rather than the negative/ground for a typical circut. I have the need to break this rule and wire my fuel pump positve with no switch and switch the ground to turn it on/off. Is this a huge no-no? Bad style? No big deal? Why does it matter? Thanks, - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 06, 2003
Subject: Re: Switched gnd?
> >The rule of thumb seems to be to switch the positive line rather than >the negative/ground for a typical circut. I have the need to break this >rule and wire my fuel pump positve with no switch and switch the ground >to turn it on/off. Is this a huge no-no? Bad style? No big deal? Why >does it matter? > >Thanks, It doesn't. Control circuitry aboard aircraft are done both ways. I'm unaware of any such rule-of-thumb . . . Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 06, 2003
From: "Robinson, Chad" <crobinson(at)rfgonline.com>
> The rule of thumb seems to be to switch the positive line rather than > the negative/ground for a typical circut. I have the need to break this > rule and wire my fuel pump positve with no switch and switch the ground > to turn it on/off. Is this a huge no-no? Bad style? No big deal? Why > does it matter? This sounds like more of an issue in high voltage AC electrical wiring such as you have in your home. There you want to switch the "hot" side so that when the switch is off, there is mains voltage reaching the device/circuit. Otherwise, if the device (say, a lamp) was on, the white (neutral/return) wire would be hot, which can create a dangerous situation for anybody mucking with the wires. It's a safety issue, with lots of ramifications for both electricians and product designers. But for a 12V circuit? My car has several circuits wired this way. I can't see why it would be a problem in a plane. Maybe Bob has some guidance here? Regards, Chad ________________________________________________________________________________
Date: Oct 06, 2003
I for one would want to switch the positive side of the circuit. If the device being controlled by the switch failed in a shorted mode, there would still be positive voltage to it. The switch would not save the device as it is grounded to the frame of the vehicle, airplane. In a composite airframe this may not be a concern. In a metal airplane I would definitely not switch the negative side of the circuit. My milli pennies worth. Gee, opinions are depreciating rather rapidly, aren't they? Lyle -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robinson, Chad Subject: RE: AeroElectric-List: Switched gnd? --> > The rule of thumb seems to be to switch the positive line rather than > the negative/ground for a typical circut. I have the need to break > this rule and wire my fuel pump positve with no switch and switch the > ground to turn it on/off. Is this a huge no-no? Bad style? No big > deal? Why does it matter? This sounds like more of an issue in high voltage AC electrical wiring such as you have in your home. There you want to switch the "hot" side so that when the switch is off, there is mains voltage reaching the device/circuit. Otherwise, if the device (say, a lamp) was on, the white (neutral/return) wire would be hot, which can create a dangerous situation for anybody mucking with the wires. It's a safety issue, with lots of ramifications for both electricians and product designers. But for a 12V circuit? My car has several circuits wired this way. I can't see why it would be a problem in a plane. Maybe Bob has some guidance here? Regards, Chad == direct advertising on the Matronics Forums. == http://www.matronics.com/trouble-report == == ________________________________________________________________________________
Date: Oct 06, 2003
Subject: Re: Relay diagram for Microair PTT
--0-1904218001-1065499228=:60162 Good stuff, thanks Bob. Now if you'll hold my hand just a minute longer and suggest the "perfect" DigiKey diodes to go with both the OV disconnect relay and these relays I would be grateful. The pic on your site shows a 1N4005 but there are about a dozen of these that show up in the DigiKey website. Also, where are the red and white connectors that come with the B&C OV module kit best used? Joa --------------------------------- --0-1904218001-1065499228=:60162 Good stuff, thanks Bob. Now if you'll hold my hand just a minute longer and suggest the "perfect" DigiKey diodes to go with both the OV disconnect relay and these relays I would be grateful. The pic on your site shows a 1N4005 but there are about a dozen of these that show up in the DigiKey website. Also, where are the red and white connectors that come with the BC OV module kit best used? Joa --0-1904218001-1065499228=:60162-- ________________________________________________________________________________
Date: Oct 06, 2003
Subject: Battery Contactor vibration problem
I installed a battery master switch with contactor (one or the 3 terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. For reasons of space I installed it upside down. While testing out the electrical system I noticed that tapping with a small rubber mallet on the bracket that it's mounted to will cause it to interrupt the power momentarily. It doesn't matter if I tap from top or bottom, it seems to disconnect for a split second. I know it's disconnecting because my rotor tach goes through it's initialization test on first power up, and it's doing that every time. Also, other indicator lights flicker, so it's not just the tach, nor loose battery leads, etc. You can understand my hesitation about using this since it's a helo (they aren't the smoothest) with two FADEC's that can't be electrically interrupted. Are there any stronger or more reliable contactors, perhaps even solid state? Any suggestions for how to fix this? Thanks Vince Ackerman N777FB ________________________________________________________________________________
Date: Oct 07, 2003
That's good news. I guess I just developed that impression during my miniscule electrical experience. I know some light-weight circuits switch the ground, i.e. for enunciator lights, etc -- but I thought bigger 'appliances' had to have the + switched. Glad to hear that's not always the case. Thanks. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] > Sent: Monday, October 06, 2003 8:29 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Switched gnd? > > > --> > > >--> > > > >The rule of thumb seems to be to switch the positive line > rather than > >the negative/ground for a typical circut. I have the need to break > >this rule and wire my fuel pump positve with no switch and > switch the > >ground to turn it on/off. Is this a huge no-no? Bad style? No big > >deal? Why does it matter? > > > >Thanks, > > It doesn't. Control circuitry aboard aircraft are done > both ways. I'm unaware of any such rule-of-thumb . . . > > Bob . . . > > -------------------------------------------- > ( Knowing about a thing is different than ) > ( understanding it. One can know a lot ) > ( and still understand nothing. ) > ( C.F. Kettering ) > -------------------------------------------- ________________________________________________________________________________
Date: Oct 07, 2003
The fuse/breaker would provide protection. Would it not? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Lyle Peterson [mailto:lyleap(at)access4less.net] > Sent: Tuesday, October 07, 2003 12:01 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Switched gnd? > > > --> > > I for one would want to switch the positive side of the > circuit. If the device being controlled by the switch failed > in a shorted mode, there would still be positive voltage to > it. The switch would not save the device as it is grounded > to the frame of the vehicle, airplane. In a composite > airframe this may not be a concern. In a metal airplane I > would definitely not switch the negative side of the circuit. > > My milli pennies worth. > > Gee, opinions are depreciating rather rapidly, aren't they? > > Lyle > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Robinson, Chad > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Switched gnd? > > > --> > > > The rule of thumb seems to be to switch the positive line > rather than > > the negative/ground for a typical circut. I have the need to break > > this rule and wire my fuel pump positve with no switch and > switch the > > ground to turn it on/off. Is this a huge no-no? Bad > style? No big > > deal? Why does it matter? > > This sounds like more of an issue in high voltage AC > electrical wiring such as you have in your home. There you > want to switch the "hot" side so that when the switch is off, > there is mains voltage reaching the device/circuit. > Otherwise, if the device (say, a lamp) was on, the white > (neutral/return) wire would be hot, which can create a > dangerous situation for anybody mucking with the wires. It's > a safety issue, with lots of ramifications for both > electricians and product designers. > > But for a 12V circuit? My car has several circuits wired this > way. I can't see why it would be a problem in a plane. Maybe > Bob has some guidance here? > > Regards, > Chad > > > == > direct advertising on the Matronics Forums. > == > http://www.matronics.com/trouble-report > == > == > > > ============ > Matronics Forums. > ============ > http://www.matronics.com/trouble-report > > ============ > http://www.matronics.com/FAQ/AeroElectric-List.htm > Search Engine: http://www.matronics.com/search > ============ > > > > > > ________________________________________________________________________________
Date: Oct 06, 2003
Depends on which side is fused or breakered (is that a word?) If the postive side is fused it would protect it. If the problem is one of wiring the switch only to the negative side for some reason, I am guessing that the same reasons apply to the fuse or breaker. That means the fuse would be in the negative side and little or no protection. Another 2 mils worth of opinion. Lyle -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Larry Bowen Subject: RE: AeroElectric-List: Switched gnd? --> The fuse/breaker would provide protection. Would it not? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com ________________________________________________________________________________
Date: Oct 07, 2003
> > Larry Bowen wrote: > > > > The fuse/breaker would provide protection. Would it not? > > Lyle Peterson wrote: > > Depends on which side is fused or breakered (is that a word?) If the > postive side is fused it would protect it. If the problem is one of > wiring the switch only to the negative side for some reason, I am > guessing that the same reasons apply to the fuse or breaker. > That means the fuse would be in the negative side and little or no > protection. On the other hand, one would probably not be wiring a negative-switched device into one's standard fuse panel, that being a 12V source itself. So Larry, unless you're looking to create a separate fuse panel of all NEGATIVE switched devices, I assumed you meant that you'd have an inline fuse or breaker upstream of this negative-switched device (that is, on the supply side). Is this the case? Because Lyle is right - wherever you put the switch, the FUSE should be on the supply side no matter what. And if your breaker IS your switch, then this is not a great idea. However, I'd like to restate my point that switch/breaker location is a bigger issue in systems where the voltage is not so fun to touch - a human can die from mains voltage without ever tripping a standard 20A breaker. Therefore, you always want a way to cut off the supply side as close to the source as possible, and so the breaker is ALWAYS on the hot side. My $0.00002c. =) Regards, Chad PS - None of my dictionaries (all relatively new, FWIW) contain "breakered" as an acceptable form of "breaker". However, LOTS of electrical supply and products companies like to use it, so I say what the heck, if the people you're talking to understand what you mean... ________________________________________________________________________________
Subject: 1N4005 Selection
Date: Oct 07, 2003
Hi Joa, I'll take a shot at this one. I'm an electronics beginner and this list has helped a bunch - somone please correct me if I'm wrong. First - take a look at the packaging. DO-41 is the in-line type (see this site for a photo (http://www.jameco.com/cgi-bin/ncommerce3/ExecMacro/Jameco/searchResult. d2w/report?sort=BRR&search=1N4005)). DO-214 is a surface mount item, you don't want this unless installing on a PCB or ??? Second - take a look at "Min Qty". Not sure about you but I can pretty easily eliminate the items that have a minimum quantity of more than 100. That gets you down to about four items. That's about all the further I can help. I notice that "Glass Passivated" is much more expensive than "Silicon" (49 cents versus 4 cents). I don't fully understand your last question. I assume you are talking about the OV crowbar. The instructions are at http://www.aeroelectric.com/articles/9003_ins.pdf but you probably already have them. Jon Finley N90MG Q2 - Subaru EJ-22 DD - 455 Hrs. TT - 3.5 Hrs Engine Apple Valley, Minnesota http://www.FinleyWeb.net/default.asp?id=96 > --> > > --0-1904218001-1065499228=:60162 > > Good stuff, thanks Bob. Now if you'll hold my hand just a > minute longer and suggest the "perfect" DigiKey diodes to go > with both the OV disconnect relay and these relays I would be > grateful. The pic on your site shows a 1N4005 but there are > about a dozen of these that show up in the DigiKey website. > > Also, where are the red and white connectors that come with > the B&C OV module kit best used? > > Joa > ________________________________________________________________________________
Date: Oct 07, 2003
Hopefully it's not that complicated. This is what I want to do. Main fuse block -- 5 amp fuse -- fuel pump -- terminal strip -- infinity grip -- ground =AND Main fuse block -- 2 amp fuse -- dimmer board -- 3 enun. LEDs -- terminal strip -- infinity grip -- ground When the switch is closed on the grip, it provides ground to both the pump and it's one enun light. I couldn't get this fuctionality switching the positive unless I had one dimmer board per enun light, which is not a reasonable option. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Robinson, Chad [mailto:crobinson(at)rfgonline.com] > Sent: Tuesday, October 07, 2003 2:00 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Switched gnd? > > > --> > > > > Larry Bowen wrote: > > > > > > The fuse/breaker would provide protection. Would it not? > > > > Lyle Peterson wrote: > > > > Depends on which side is fused or breakered (is that a > word?) If the > > postive side is fused it would protect it. If the problem > is one of > > wiring the switch only to the negative side for some reason, I am > > guessing that the same reasons apply to the fuse or breaker. > > That means the fuse would be in the negative side and little or no > > protection. > > On the other hand, one would probably not be wiring a > negative-switched device into one's standard fuse panel, that > being a 12V source itself. So Larry, unless you're looking to > create a separate fuse panel of all NEGATIVE switched > devices, I assumed you meant that you'd have an inline fuse > or breaker upstream of this negative-switched device (that > is, on the supply side). Is this the case? Because Lyle is > right - wherever you put the switch, the FUSE should be on > the supply side no matter what. And if your breaker IS your > switch, then this is not a great idea. > > However, I'd like to restate my point that switch/breaker > location is a bigger issue in systems where the voltage is > not so fun to touch - a human can die from mains voltage > without ever tripping a standard 20A breaker. Therefore, you > always want a way to cut off the supply side as close to the > source as possible, and so the breaker is ALWAYS on the hot side. > > My $0.00002c. =) > > Regards, > Chad > > PS - None of my dictionaries (all relatively new, FWIW) > contain "breakered" as an acceptable form of "breaker". > However, LOTS of electrical supply and products companies > like to use it, so I say what the heck, if the people you're > talking to understand what you mean... ________________________________________________________________________________
Date: Oct 07, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Battery Contactor vibration problem
> >I installed a battery master switch with contactor (one or the 3 >terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. For >reasons of space I installed it upside down. While testing out the >electrical system I noticed that tapping with a small rubber mallet on >the bracket that it's mounted to will cause it to interrupt the power >momentarily. It doesn't matter if I tap from top or bottom, it seems >to disconnect for a split second. I know it's disconnecting because my >rotor tach goes through it's initialization test on first power up, and >it's doing that every time. Also, other indicator lights flicker, so >it's not just the tach, nor loose battery leads, etc. > >You can understand my hesitation about using this since it's a helo >(they aren't the smoothest) with two FADEC's that can't be electrically >interrupted. Are there any stronger or more reliable contactors, >perhaps even solid state? Any suggestions for how to fix this? What's your battery voltage? It may be so low as to severely reduce the holding force of the coil in the energized mode . . . but it has to sag really low. Measure the voltage across the coil while energized (battery+ terminal to small terminal). If the voltage is over 10v, I'd like to get my hands on that contactor. If you'll send me you address, I'll have B&C ship you one of their battery contactors today and you can send me your questionable device. There's something seriously wrong with it if you can get interruptions with vibration. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
> >--0-1904218001-1065499228=:60162 > >Good stuff, thanks Bob. Now if you'll hold my hand just a minute longer >and suggest the "perfect" DigiKey diodes to go with both the OV disconnect >relay and these relays I would be grateful. The pic on your site shows a >1N4005 but there are about a dozen of these that show up in the DigiKey >website. Some of those will be surface mount parts. You want leaded parts. ANY leaded part will do . . . Go to Radio Shack. Any diode of reasonable size (meaning physical dimensions) will work. This is NOT in the least critical electrically. If you look at the S701 series contactors from B*C http://www.aeroelectric.com/Pictures/s701-2.jpg these are a rather "fat" looking diode. These are 3A devices (1N540x series devices) and Radio Shack has several electrical sizes in a blister pak . . . 2 for about $1. I chose these for this application because they're mechanically robust. Where you need a smaller one like for a S704 relay http://www.aeroelectric.com/Pictures/s701-2.jpg then the smaller, glass or plastic, leaded devices are called for. ANY 1N400x diode you can find on the rack at the Shack is fine. It think they stock several electrical sizes of these as well. >Also, where are the red and white connectors that come with the B&C OV >module kit best used? Not sure. Did they come packaged with the OV module or are they part of the SD-8 overall installation kit. I think they ship some connectors that are used for alternator wiring of the SD-8. If their use is not implicit in the instructions for the kit, a phone call to 316-283-8000 or e-mail (mailto:todd(at)bandc.biz) will clear this up. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
> >I installed a battery master switch with contactor (one or the 3 >terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. For >reasons of space I installed it upside down. While testing out the >electrical system I noticed that tapping with a small rubber mallet on >the bracket that it's mounted to will cause it to interrupt the power >momentarily. It doesn't matter if I tap from top or bottom, it seems >to disconnect for a split second. I know it's disconnecting because my >rotor tach goes through it's initialization test on first power up, and >it's doing that every time. Also, other indicator lights flicker, so >it's not just the tach, nor loose battery leads, etc. > >You can understand my hesitation about using this since it's a helo >(they aren't the smoothest) with two FADEC's that can't be electrically >interrupted. Are there any stronger or more reliable contactors, >perhaps even solid state? Any suggestions for how to fix this? > >Thanks >Vince Ackerman >N777FB We had similar type of problem in the Glasairs. It was discovered that during high g loads, the contactors would separate. The fix was mounting them horizontally. ________________________________________________________________________________
Date: Oct 07, 2003
This one has been all over the map. Let's consider a few important points: (1) The techniques and rational for wiring houses in a particular way has very weak association with the wiring for vehicles including airplanes. (2) Circuit protection always goes as close to the source as practical . . . busses and batteries are the source. It matters not what is being powered or how it is controlled, location of circuit protection is the same. (3) To turn something ON or OFF one only need to get in series with the flow of current around the path from bus to ground. In many complex control systems for airplanes, there might be two or more switches, relays, solid state controls or contactors, any ONE of which is capable of turning the system OFF and all must be closed for the system to be ON. It absolutely matters not where the switch is located around the loop to achieve the desired function. (3) There are some secondary considerations from a failure modes perspective . . . a switch to ground control line COULD fault to ground and leave a system permanently ON. But given that 99% of system failures are due to wear-out or component failure, 0.9% of failures are due to wiring coming unhooked, and 0.1% of failures are due to ground faults of wire runs. Of this tiny fraction of ground faults, the majority will probably take out the supply fuse as opposed to causing any system to stick in the ON condition. Unless you enjoy getting wrapped around the axles of Part 25 or air transport category fault trees and can get excited about chasing a bureaucratic nirvana of less than one failure per million flight hours, such considerations are not worth your time and effort. The fault to ground condition is handled like any other consideration in your failure tolerant system analysis: Is it pre-flight detectable? How do I now it's failed in flight? What are the consequences of not being able to regain control if it does fail in flight? If the system is stuck on, what's necessary for comfortable termination of flight? How do I deal with it in flight in terms of (1) ignore it, (2) shut down the main bus and go to e-bus ops, (3) use the backup system, etc. etc. Bottom line is you can wire your systems up pretty much any way that improves on convenience or reduces cost or parts count and satisfies your FMEA. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
At the time I was testing it the volt meter was reading 12.4 volts, which I thought should have been enough. I didn't measure the voltage across the coil but I will. I will take you up on your offer and send you the contactor. I would like the B&C contactor sent to the below address. I will happily pay for it. No one makes a solid state contactor? I would think there would be quite a market for something like that. Thanks. Vince Ackerman 17977 NW Sauvie Island Rd Portland, OR 97231 503-621-0511 On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III wrote: > > >> >> I installed a battery master switch with contactor (one or the 3 >> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. >> For >> reasons of space I installed it upside down. While testing out the >> electrical system I noticed that tapping with a small rubber mallet on >> the bracket that it's mounted to will cause it to interrupt the power >> momentarily. It doesn't matter if I tap from top or bottom, it seems >> to disconnect for a split second. I know it's disconnecting because my >> rotor tach goes through it's initialization test on first power up, >> and >> it's doing that every time. Also, other indicator lights flicker, so >> it's not just the tach, nor loose battery leads, etc. >> >> You can understand my hesitation about using this since it's a helo >> (they aren't the smoothest) with two FADEC's that can't be >> electrically >> interrupted. Are there any stronger or more reliable contactors, >> perhaps even solid state? Any suggestions for how to fix this? > > > What's your battery voltage? It may be so low as to > severely reduce the holding force of the coil in the > energized mode . . . but it has to sag really low. Measure > the voltage across the coil while energized (battery+ > terminal to small terminal). > > If the voltage is over 10v, I'd like to get my hands on that > contactor. If you'll send me you address, I'll have B&C ship > you one of their battery contactors today and you can send > me your questionable device. There's something seriously > wrong with it if you can get interruptions with vibration. > > Bob . . . > > > _- > ======================================================================= > > _- > ======================================================================= > > http://www.matronics.com/trouble-report > _- > ======================================================================= > > _- > ======================================================================= > > ________________________________________________________________________________
Date: Oct 07, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> CBs
CBs CBs > >--0-361577249-1065230699=:58092 > >Bob, > I am using a derivative of Figure Z-11 architecture for an RV6. I want > to feed the electronic ignition from a hot battery bus. The LSE > installation instructions say to use a "pullable" 5 amp breaker. The > Aeroelectric connection mentions use of a fusible link in this > application. I would much prefer a fusible link with an on/off switch > over a CB. Do these electronic ignition systems nuisance trip in > general? I thought they were supposed to be incredibly reliable (That's > why I bought it!!). If you have a battery bus with more than one feed, then a fuseblock can be used to distribute power to the e-bus, Hobbs, clock, -AND- electronic ignition. If you like, you can feed the ignition directly from the battery contactor using fusible link. Electronic ignitions are reliable, they don't have an propensity for nuisance tripping, and power feedline protection technique is entirely optional. > What would you suggest for a feed to the flap motor. I thought I read > something about this is one particular animal that can nuisance trip. If > you were to recommend a CB application how would you power that off say > the main bus/fuse block? I would prefer to keep the ALT FLD CB the only > breaker on the panel, if practical. Do an FEMA. How what are the consequences of this system shutting down at ANY phase of flight? If your airplane will climb with flaps fully extended, then there are no worries about getting boxed in by an inop flap system. Systems will nuisance trip the circuit protection for one reason only and it's NOT because they are a flap system, ignition system or any other system. When you read about "nuisance trips" you KNOW that the system was poorly designed. It simply means that the feedwires and fuse/breaker were not properly sized for the task. Wire it up with 16AWG and start out with a 5A fuse. If you trip it, go to 7A . . . it's almost a sure bet that 10A will stay put . . . or just start out with 10A. Lots of designers do that . . .make it fat and don't worry about it. I'd rather have a more considered reason for final fuse selection. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Re: bad link to picture
> > Some of those will be surface mount parts. You want > leaded parts. ANY leaded part will do . . . > > Go to Radio Shack. Any diode of reasonable size (meaning > physical dimensions) will work. This is NOT in the least > critical electrically. If you look at the S701 series > contactors from B*C > > http://www.aeroelectric.com/Pictures/s701-2.jpg > > these are a rather "fat" looking diode. These are 3A > devices (1N540x series devices) and Radio Shack has several > electrical sizes in a blister pak . . . 2 for about $1. > > I chose these for this application because they're > mechanically robust. Where you need a smaller one > like for a S704 relay Here's the right one . . . http://www.aeroelectric.com/articles/s704inst.jpg > then the smaller, glass or plastic, leaded devices > are called for. ANY 1N400x diode you can find on the > rack at the Shack is fine. It think they stock several > electrical sizes of these as well. Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
Date: Oct 07, 2003
BTW, to where do you want me to send it?? On Tuesday, October 7, 2003, at 08:21 AM, Vince Ackerman wrote: > > At the time I was testing it the volt meter was reading 12.4 volts, > which I thought should have been enough. I didn't measure the voltage > across the coil but I will. I will take you up on your offer and send > you the contactor. I would like the B&C contactor sent to the below > address. I will happily pay for it. > > No one makes a solid state contactor? I would think there would be > quite a market for something like that. > > Thanks. > > Vince Ackerman > 17977 NW Sauvie Island Rd > Portland, OR 97231 > > 503-621-0511 > > > On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III > wrote: > >> >> >>> >>> >>> I installed a battery master switch with contactor (one or the 3 >>> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. >>> For >>> reasons of space I installed it upside down. While testing out the >>> electrical system I noticed that tapping with a small rubber mallet >>> on >>> the bracket that it's mounted to will cause it to interrupt the power >>> momentarily. It doesn't matter if I tap from top or bottom, it seems >>> to disconnect for a split second. I know it's disconnecting because >>> my >>> rotor tach goes through it's initialization test on first power up, >>> and >>> it's doing that every time. Also, other indicator lights flicker, so >>> it's not just the tach, nor loose battery leads, etc. >>> >>> You can understand my hesitation about using this since it's a helo >>> (they aren't the smoothest) with two FADEC's that can't be >>> electrically >>> interrupted. Are there any stronger or more reliable contactors, >>> perhaps even solid state? Any suggestions for how to fix this? >> >> >> What's your battery voltage? It may be so low as to >> severely reduce the holding force of the coil in the >> energized mode . . . but it has to sag really low. Measure >> the voltage across the coil while energized (battery+ >> terminal to small terminal). >> >> If the voltage is over 10v, I'd like to get my hands on that >> contactor. If you'll send me you address, I'll have B&C ship >> you one of their battery contactors today and you can send >> me your questionable device. There's something seriously >> wrong with it if you can get interruptions with vibration. >> >> Bob . . . >> >> >> _- >> ====================================================================== >> >> >> _- >> ====================================================================== >> >> >> http://www.matronics.com/trouble-report >> _- >> ====================================================================== >> >> >> _- >> ====================================================================== >> >> >> > > > _- > ======================================================================= > > _- > ======================================================================= > > http://www.matronics.com/trouble-report > _- > ======================================================================= > > _- > ======================================================================= > > ________________________________________________________________________________
Subject: Strain relieving 15 pin D-sub connectors
Date: Oct 07, 2003
What ideas have you guys come up with to strain relieve the back sides of D-sub connectors? I saw Bob's article that uses Shoe Goo (great stuff) for a soldered D-sub. This is not soldered and since it's the stick grip connector, I do not want to pot the back side with anything, in case I want to swap pins in the future. My idea so far is to take 1.5" diameter shrink tubing, and pull it over the back side of the connector metal. Shrink that side only. Then shrink the other side but not the middle, that way, I"ll get a gentle tapering sleeve. I doubt that the 1.5" tubing will shrink to the 3/8 " to tighten up on the wire bundle, so I"ll tie that end with lacing cord. Anyone else have any ideas? Arthur Treff RV-8 Wiring ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Good reference on Transient Suppression
http://littelfuse.com/PDFs/AppNotes/an9312.pdf ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Re: need info on Mitchell CD-1000 cdi
-------------------------------1065563129 Hello, can anyone give me the wiring diagram or any other information on a "Mitchell Aircraft Instruments" CD-1000 curse deviation indicator, or a way to contact the company, or any other help in finding out information about this instrument. My internet search was not successful. thank you, skip simpson -------------------------------1065563129 tutf-8"> Hello, can anyone give me the wiring diagram or any other information on=20a "Mitchell Aircraft Instruments" CD-1000 curse deviation indicator, or a way to contact the company, or any other help in finding out information about this instrument.My internet search was not successful. thank you, skip simpson -------------------------------1065563129-- ________________________________________________________________________________
Subject: Re: Alternator and electronic ignition
Date: Oct 07, 2003
I'm doing runups on my conversion with a 55 amp nippondenso alternator and have a intermitten problem. Sometimes as the volt meter reads about 13.8 volts the needle moves back and forth between lets say 13.8 and 13.9 and this causes my engine to miss fire. In other words the electronic ignition doesn't like it. This only happens (or seems so) when the battery is fully charged. If I let the battery run down a bit, it seems to charge right up to 14.1 volts and stablize. Any Ideas? I also have a miss fire a 4000 rpm. Does anyone know about the range of spark plugs to run? Colder? By how much? My engine is a nissan VQ maxima V-6. It is running great so far. I'm up to 4500 rpm static. Leonard ----- Original Message ----- From: "Vince Ackerman" <vack(at)mac.com> Subject: Re: AeroElectric-List: Battery Contactor vibration problem > > BTW, to where do you want me to send it?? > > On Tuesday, October 7, 2003, at 08:21 AM, Vince Ackerman wrote: > > > > > At the time I was testing it the volt meter was reading 12.4 volts, > > which I thought should have been enough. I didn't measure the voltage > > across the coil but I will. I will take you up on your offer and send > > you the contactor. I would like the B&C contactor sent to the below > > address. I will happily pay for it. > > > > No one makes a solid state contactor? I would think there would be > > quite a market for something like that. > > > > Thanks. > > > > Vince Ackerman > > 17977 NW Sauvie Island Rd > > Portland, OR 97231 > > > > 503-621-0511 > > > > > > On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III > > wrote: > > > >> > >> > >>> > >>> > >>> I installed a battery master switch with contactor (one or the 3 > >>> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. > >>> For > >>> reasons of space I installed it upside down. While testing out the > >>> electrical system I noticed that tapping with a small rubber mallet > >>> on > >>> the bracket that it's mounted to will cause it to interrupt the power > >>> momentarily. It doesn't matter if I tap from top or bottom, it seems > >>> to disconnect for a split second. I know it's disconnecting because > >>> my > >>> rotor tach goes through it's initialization test on first power up, > >>> and > >>> it's doing that every time. Also, other indicator lights flicker, so > >>> it's not just the tach, nor loose battery leads, etc. > >>> > >>> You can understand my hesitation about using this since it's a helo > >>> (they aren't the smoothest) with two FADEC's that can't be > >>> electrically > >>> interrupted. Are there any stronger or more reliable contactors, > >>> perhaps even solid state? Any suggestions for how to fix this? > >> > >> > >> What's your battery voltage? It may be so low as to > >> severely reduce the holding force of the coil in the > >> energized mode . . . but it has to sag really low. Measure > >> the voltage across the coil while energized (battery+ > >> terminal to small terminal). > >> > >> If the voltage is over 10v, I'd like to get my hands on that > >> contactor. If you'll send me you address, I'll have B&C ship > >> you one of their battery contactors today and you can send > >> me your questionable device. There's something seriously > >> wrong with it if you can get interruptions with vibration. > >> > >> Bob . . . > >> > >> > >> _- > >> ====================================================================== > >> > >> > >> _- > >> ====================================================================== > >> > >> > >> http://www.matronics.com/trouble-report > >> _- > >> ====================================================================== > >> > >> > >> _- > >> ====================================================================== > >> > >> > >> > > > > > > _- > > ======================================================================= > > > > _- > > ======================================================================= > > > > http://www.matronics.com/trouble-report > > _- > > ======================================================================= > > > > _- > > ======================================================================= > > > > > > ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Re: Strain relieving 15 pin D-sub connectors
> > > >What ideas have you guys come up with to strain relieve the back sides of >D-sub connectors? I saw Bob's article that uses Shoe Goo (great stuff) >for a soldered D-sub. This is not soldered and since it's the stick grip >connector, I do not want to pot the back side with anything, in case I >want to swap pins in the future. My idea so far is to take 1.5" diameter >shrink tubing, and pull it over the back side of the connector metal. >Shrink that side only. Then shrink the other side but not the middle, >that way, I"ll get a gentle tapering sleeve. I doubt that the 1.5" tubing >will shrink to the 3/8 " to tighten up on the wire bundle, so I"ll tie >that end with lacing cord. Anyone else have any ideas? How about an ordinary 15-pin backshell? See listing in upper right corner of page at: http://dkc3.digikey.com/pdf/T033/0144-0145.pdf Bob . . . ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Re: Good reference on Transient Suppression
> > >http://littelfuse.com/PDFs/AppNotes/an9312.pdf This document is typical of a whole family of texts published by folk who make (and therefore want to sell) various forms of protective devices. As sources of engineering guidance for system analysis, they're fine but the neophyte builder needs to understand that (1) while the stresses cited "can", "may" and under some conditions "will" exist, they don't ALL exist in a vehicular DC power system and (2) there are design considerations in addition to or as alternatives to a generous sprinkling of "spike" suppressors about the system (like DO-160 certification). I'm still waiting for any aviation systems designer to describe a single repeatable experiment that I can use to justify anything more than catch diodes on contactor coils and crowbar ov modules on alternators (which have been standard for years). BTW, there is a GENEROUS sprinkling of spike suppressors on the Premier I and will undoubtedly be many more on Hawker Horizon . . . composite aircraft supposedly buttressed for LIGHTNING strike. So if someone points out the fact that a certified airframe is so equipped, know that as long as it's your enthusiastic intent to stay out of thunderstorms, then your electrical system is going to be fine without them. This is not to discourage anyone from taking advantage of the knowledge these documents offer . . . but also please be aware that most of the beasts and gremlins described therein are no big deal for airplane folks. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Subject: Starter/mag switch
Date: Oct 07, 2003
From: "David.vonLinsowe" <David.vonLinsowe(at)delphi.com>
Hi Bob and list, I'm using two switches for my ignition, one for the left mag and starter (double pole) and an other switch for the right electronic ignition. I'm upgrading to an all electric panel with a Grand Raids Tech. EIS and doing away with the tach cable. What do you think about the idea of using a triple pole switch for the left mag and starter and add a circuit to switch to the EI tach info when the mag is off? The EI tach info will have twice the rpm, but I don't see that as an issue. Is there a better way? Thanks, Dave ________________________________________________________________________________
Date: Oct 07, 2003
<... charge right up to 14.1 volts and stabilize ...> Charging voltage with a fully charged battery is 14.7 volts. 14.1 would indicate to me that the alternator is loaded pretty much. Or perhaps enough line losses to make 14.7 at the alternator look like 14.1 to the voltmeter. 13.8 indicates the alternator is loaded so hell wouldn't have it. Have you checked the volts and amps at the B-post of your alternator? Seems like something's missing here .... Jim S. Leonard Garceau wrote: > > I'm doing runups on my conversion with a 55 amp nippondenso alternator and > have a intermitten problem. Sometimes as the volt meter reads about 13.8 > volts the needle moves back and forth between lets say 13.8 and 13.9 and > this causes my engine to miss fire. In other words the electronic ignition > doesn't like it. This only happens (or seems so) when the battery is fully > charged. If I let the battery run down a bit, it seems to charge right up to > 14.1 volts and stablize. Any Ideas? > > I also have a miss fire a 4000 rpm. Does anyone know about the range of > spark plugs to run? Colder? By how much? > > My engine is a nissan VQ maxima V-6. It is running great so far. I'm up to > 4500 rpm static. > > Leonard > > ----- Original Message ----- > From: "Vince Ackerman" <vack(at)mac.com> > To: > Subject: Re: AeroElectric-List: Battery Contactor vibration problem > > > > > BTW, to where do you want me to send it?? > > > > On Tuesday, October 7, 2003, at 08:21 AM, Vince Ackerman wrote: > > > > > > > > At the time I was testing it the volt meter was reading 12.4 volts, > > > which I thought should have been enough. I didn't measure the voltage > > > across the coil but I will. I will take you up on your offer and send > > > you the contactor. I would like the B&C contactor sent to the below > > > address. I will happily pay for it. > > > > > > No one makes a solid state contactor? I would think there would be > > > quite a market for something like that. > > > > > > Thanks. > > > > > > Vince Ackerman > > > 17977 NW Sauvie Island Rd > > > Portland, OR 97231 > > > > > > 503-621-0511 > > > > > > > > > On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III > > > wrote: > > > > > >> > > >> > > >>> > > >>> > > >>> I installed a battery master switch with contactor (one or the 3 > > >>> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. > > >>> For > > >>> reasons of space I installed it upside down. While testing out the > > >>> electrical system I noticed that tapping with a small rubber mallet > > >>> on > > >>> the bracket that it's mounted to will cause it to interrupt the power > > >>> momentarily. It doesn't matter if I tap from top or bottom, it seems > > >>> to disconnect for a split second. I know it's disconnecting because > > >>> my > > >>> rotor tach goes through it's initialization test on first power up, > > >>> and > > >>> it's doing that every time. Also, other indicator lights flicker, so > > >>> it's not just the tach, nor loose battery leads, etc. > > >>> > > >>> You can understand my hesitation about using this since it's a helo > > >>> (they aren't the smoothest) with two FADEC's that can't be > > >>> electrically > > >>> interrupted. Are there any stronger or more reliable contactors, > > >>> perhaps even solid state? Any suggestions for how to fix this? > > >> > > >> > > >> What's your battery voltage? It may be so low as to > > >> severely reduce the holding force of the coil in the > > >> energized mode . . . but it has to sag really low. Measure > > >> the voltage across the coil while energized (battery+ > > >> terminal to small terminal). > > >> > > >> If the voltage is over 10v, I'd like to get my hands on that > > >> contactor. If you'll send me you address, I'll have B&C ship > > >> you one of their battery contactors today and you can send > > >> me your questionable device. There's something seriously > > >> wrong with it if you can get interruptions with vibration. > > >> > > >> Bob . . . > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> http://www.matronics.com/trouble-report > > >> _- > > >> ====================================================================== > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> > > > > > > > > > _- > > > ======================================================================= > > > > > > _- > > > ======================================================================= > > > > > > http://www.matronics.com/trouble-report > > > _- > > > ======================================================================= > > > > > > _- > > > ======================================================================= > > > > > > > > > > > -- Jim Sower Crossville, TN; Chapter 5 Long-EZ N83RT, Velocity N4095T ________________________________________________________________________________
Date: Oct 07, 2003
Subject: Crowbar overvoltage protector ...
I've heard that Bob sells these "crowbar overvoltage protectors". I need one pretty bad. I've been to the web site but can't find one there. Did I hear wrong? How do I protect from alternator runaway? Thanks, Jim Sower Long-EZ N83RT, Velocity N4095T ________________________________________________________________________________
Subject: Electronic tacho & mag check
Date: Oct 08, 2003
I was thinking I would use an electronic tacho -- something like a UMA tacho / hour meter that hooks up to a magneto. Thing is, is it still possible to do a mag check from the tacho? I'm assuming that switching to the other mag during a mag check would make the tacho go to zero, and thus it wouldn't be any use for seeing the mag drop. I can't see that this would be the case though -- it seems too obvious, and presumably UMA would have thought of a solution. Does anyone have any experience of thise type of tach? Many thanks in anticipation. Cheers. Nev -- Jodel D-150 in progress UK ________________________________________________________________________________
Date: Oct 08, 2003
Leonard, First verify that the miss is caused by the alternator by disabling the alternator and running just off the battery. Then if the problem does appear to be the alternator, check alternator output and voltage as mentioned below. I will bet that the alternator has a bad diode and thus is not outputting full power (current and voltage). Also with a bad diode the alternator will output a lot of "AC ripple" which is basically noise. This noise can be misread by the electronic ignition as a signal to fire the coil, which would cause a miss. The best way to check AC ripple is with a scope, however a multimeter will work as well. Turn the meter to AC voltage and connect positive lead to B+ on alternator, and negative to alternator body. You should read less than 400mV, a rough number, of AC voltage. If the voltage is high, most likely you have a bad diode. Also check your grounds again, a bad engine ground could also cause some hiccups with electronic ignitions. Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jim Sower Subject: Re: AeroElectric-List: Re: Alternator and electronic ignition <... charge right up to 14.1 volts and stabilize ...> Charging voltage with a fully charged battery is 14.7 volts. 14.1 would indicate to me that the alternator is loaded pretty much. Or perhaps enough line losses to make 14.7 at the alternator look like 14.1 to the voltmeter. 13.8 indicates the alternator is loaded so hell wouldn't have it. Have you checked the volts and amps at the B-post of your alternator? Seems like something's missing here .... Jim S. Leonard Garceau wrote: > > I'm doing runups on my conversion with a 55 amp nippondenso alternator and > have a intermitten problem. Sometimes as the volt meter reads about 13.8 > volts the needle moves back and forth between lets say 13.8 and 13.9 and > this causes my engine to miss fire. In other words the electronic ignition > doesn't like it. This only happens (or seems so) when the battery is fully > charged. If I let the battery run down a bit, it seems to charge right up to > 14.1 volts and stablize. Any Ideas? > > I also have a miss fire a 4000 rpm. Does anyone know about the range of > spark plugs to run? Colder? By how much? > > My engine is a nissan VQ maxima V-6. It is running great so far. I'm up to > 4500 rpm static. > > Leonard > > ----- Original Message ----- > From: "Vince Ackerman" <vack(at)mac.com> > To: > Subject: Re: AeroElectric-List: Battery Contactor vibration problem > > > > > BTW, to where do you want me to send it?? > > > > On Tuesday, October 7, 2003, at 08:21 AM, Vince Ackerman wrote: > > > > > > > > At the time I was testing it the volt meter was reading 12.4 volts, > > > which I thought should have been enough. I didn't measure the voltage > > > across the coil but I will. I will take you up on your offer and send > > > you the contactor. I would like the B&C contactor sent to the below > > > address. I will happily pay for it. > > > > > > No one makes a solid state contactor? I would think there would be > > > quite a market for something like that. > > > > > > Thanks. > > > > > > Vince Ackerman > > > 17977 NW Sauvie Island Rd > > > Portland, OR 97231 > > > > > > 503-621-0511 > > > > > > > > > On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III > > > wrote: > > > > > >> > > >> > > >>> > > >>> > > >>> I installed a battery master switch with contactor (one or the 3 > > >>> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. > > >>> For > > >>> reasons of space I installed it upside down. While testing out the > > >>> electrical system I noticed that tapping with a small rubber mallet > > >>> on > > >>> the bracket that it's mounted to will cause it to interrupt the power > > >>> momentarily. It doesn't matter if I tap from top or bottom, it seems > > >>> to disconnect for a split second. I know it's disconnecting because > > >>> my > > >>> rotor tach goes through it's initialization test on first power up, > > >>> and > > >>> it's doing that every time. Also, other indicator lights flicker, so > > >>> it's not just the tach, nor loose battery leads, etc. > > >>> > > >>> You can understand my hesitation about using this since it's a helo > > >>> (they aren't the smoothest) with two FADEC's that can't be > > >>> electrically > > >>> interrupted. Are there any stronger or more reliable contactors, > > >>> perhaps even solid state? Any suggestions for how to fix this? > > >> > > >> > > >> What's your battery voltage? It may be so low as to > > >> severely reduce the holding force of the coil in the > > >> energized mode . . . but it has to sag really low. Measure > > >> the voltage across the coil while energized (battery+ > > >> terminal to small terminal). > > >> > > >> If the voltage is over 10v, I'd like to get my hands on that > > >> contactor. If you'll send me you address, I'll have B&C ship > > >> you one of their battery contactors today and you can send > > >> me your questionable device. There's something seriously > > >> wrong with it if you can get interruptions with vibration. > > >> > > >> Bob . . . > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> http://www.matronics.com/trouble-report > > >> _- > > >> ====================================================================== > > >> > > >> > > >> _- > > >> ====================================================================== > > >> > > >> > > >> > > > > > > > > > _- > > > ======================================================================= > > > > > > _- > > > ======================================================================= > > > > > > http://www.matronics.com/trouble-report > > > _- > > > ======================================================================= > > > > > > _- > > > ======================================================================= > > > > > > > > > > > -- Jim Sower Crossville, TN; Chapter 5 Long-EZ N83RT, Velocity N4095T ________________________________________________________________________________
Date: Oct 08, 2003
I have heard of people taking a couple of capacitors and connecting them in series with the P-leads, then connect both leads, after the capacitors, to the tach. I am not sure how well this would work with your tach. I personally would look for a different system that had the capability to monitor both p-leads all the time and let you know if there is any difference. That is an engine monitor which could notify you in flight of any difference in the RPMs of the left and right mag. I am currently working on building such an engine monitoring system. Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Neville Kilford Subject: AeroElectric-List: Electronic tacho & mag check I was thinking I would use an electronic tacho -- something like a UMA tacho / hour meter that hooks up to a magneto. Thing is, is it still possible to do a mag check from the tacho? I'm assuming that switching to the other mag during a mag check would make the tacho go to zero, and thus it wouldn't be any use for seeing the mag drop. I can't see that this would be the case though -- it seems too obvious, and presumably UMA would have thought of a solution. Does anyone have any experience of thise type of tach? Many thanks in anticipation. Cheers. Nev -- Jodel D-150 in progress UK ________________________________________________________________________________
Subject: Re: Electronic tacho & mag check
Date: Oct 08, 2003
Trampas, Thanks -- and let me know progress on your EMS. None of the ones out there really do what I want to do. The EI UBG-16 comes close, but it focuses on cylinder temperatures, leaving all the other inputs as poor relations. I'd really like a 2-1/4" round or small rectangular LCD gauge that, monitored different inputs and flashed up any errant values. Anyway, thanks for your tacho notes. I was thinking I might use a SPDT relay. It would normally monitor the L magneto, but when the L magneto was grounded, this would pull the relay and switch the input to the right magneto. However, I'm rather unclear on the implications of this. Any comments would be appreciated. Nev -- Jodel D-150 in progress UK ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Electronic tacho & mag check > > I have heard of people taking a couple of capacitors and connecting them in > series with the P-leads, then connect both leads, after the capacitors, to > the tach. I am not sure how well this would work with your tach. > > I personally would look for a different system that had the capability to > monitor both p-leads all the time and let you know if there is any > difference. That is an engine monitor which could notify you in flight of > any difference in the RPMs of the left and right mag. > > I am currently working on building such an engine monitoring system. > > Trampas > ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Re: Starter/mag switch
I like to keep it simple. I have two toggle switches for ignition and a push button starter. Just a theory ... Jim S. "David.vonLinsowe" wrote: > > Hi Bob and list, > > I'm using two switches for my ignition, one for the left mag and starter > (double pole) and an other switch for the right electronic ignition. > I'm upgrading to an all electric panel with a Grand Raids Tech. EIS and > doing away with the tach cable. > > What do you think about the idea of using a triple pole switch for the > left mag and starter and add a circuit to switch to the EI tach info > when the mag is off? The EI tach info will have twice the rpm, but I > don't see that as an issue. Is there a better way? > > Thanks, > > Dave > -- Jim Sower Crossville, TN; Chapter 5 Long-EZ N83RT, Velocity N4095T ________________________________________________________________________________
Date: Oct 08, 2003
> > >Hi Bob and list, > >I'm using two switches for my ignition, one for the left mag and starter >(double pole) and an other switch for the right electronic ignition. >I'm upgrading to an all electric panel with a Grand Raids Tech. EIS and >doing away with the tach cable. > >What do you think about the idea of using a triple pole switch for the >left mag and starter and add a circuit to switch to the EI tach info >when the mag is off? The EI tach info will have twice the rpm, but I >don't see that as an issue. Is there a better way? not sure about the "twice the rpm" statement but yes, most electronic tachs work best while watching only one of two mags at a time. A third pole on one mag switch can be used to swap tach sensing to the opposite mag when it is in the OFF position. It doesn't matter which mag you do this with. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
> > >I was thinking I would use an electronic tacho -- something like a UMA tacho >/ hour meter that hooks up to a magneto. Thing is, is it still possible to >do a mag check from the tacho? I'm assuming that switching to the other mag >during a mag check would make the tacho go to zero, and thus it wouldn't be >any use for seeing the mag drop. > >I can't see that this would be the case though -- it seems too obvious, and >presumably UMA would have thought of a solution. > >Does anyone have any experience of thise type of tach? Many thanks in >anticipation. see my post of a few minutes ago. Also see: http://www.aeroelectric.com/temp/elect_tach.jpg Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
> > >I personally would look for a different system that had the capability to >monitor both p-leads all the time and let you know if there is any >difference. That is an engine monitor which could notify you in flight of >any difference in the RPMs of the left and right mag. How would this happen? If you have two devices driven from the same shaft, their rpms are in lock-step with each other. If there is any difference, it would have to be because one had broken off entirely and was reading ZERO rpm. If they're running at all, they're exactly matched. Bob . . . ________________________________________________________________________________
From: "Dennis O'Connor" <doconnor(at)chartermi.net>
Subject: Rotorway Massive Failure
Date: Oct 08, 2003
A colleague of mine has a Rotorway Exec... He was taking off this past weekend... The skids were about 2 inches off the ground when he had a total power failure involving the engine/charging system... Looking it over he found blown fuses in the circuit(s) to the engine... Only the instruments are still lighting up with the master turned on... He was asking me for advice... Rotorway has him looking for a shorted wire in the harness and ignition.... I doubt that as the source of the problem... I suggested that I suspected the alternator had a major OV and/or internal short that took out the main fuses and left him with no ignition power from the battery... I recommended that he remove the alternator and take it to the local auto electric rebuilder and have it tested for output and regulation ( I do not know whether it is internally or externally regulated, and he didn't even understand the question when I asked him) Obviously there are many possible scenarios... I am aware of most of them, and will not bore the group with a recitation, and that discussion is not the reason for this message... It sounds like Rotorway does not have an essentials bus/battery with appropriate OVP and isolation for the electrically dependent engine ignition (hint, hint, Robert)... Those on the list who have or know someone with a Rotorway would be well advised to (help them) determine their level of risk of ignition failure... When/if I learn actual electrical facts about this bird and get to put hands on, and to see the electrical diagram, I will inform the list... Cheers ... Denny ________________________________________________________________________________
Date: Oct 08, 2003
> >Leonard, > >First verify that the miss is caused by the alternator by disabling the >alternator and running just off the battery. > >Then if the problem does appear to be the alternator, check alternator >output and voltage as mentioned below. I will bet that the alternator has a >bad diode and thus is not outputting full power (current and voltage). Also >with a bad diode the alternator will output a lot of "AC ripple" which is >basically noise. This noise can be misread by the electronic ignition as a >signal to fire the coil, which would cause a miss. > >The best way to check AC ripple is with a scope, however a multimeter will >work as well. Turn the meter to AC voltage and connect positive lead to B+ >on alternator, and negative to alternator body. You should read less than >400mV, a rough number, of AC voltage. If the voltage is high, most likely >you have a bad diode. > >Also check your grounds again, a bad engine ground could also cause some >hiccups with electronic ignitions. Leonard, the investigation Trampas has cited is a good one - but I have additional concerns . . . The notion that an ignition system can be affected by ANY condition on the bus other than voltage being too low to function is troubling. Any ignition system worth it's salt will function nicely to some voltage below that at which a battery is essentially dead . . . DO-160 suggests 9.0 volts. Who's ignition system are you using? Have you talked to the manufacturer as to any know sensitivities to bus quality? This is pretty important not to investigate to the best we know how to do. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Re: Crowbar overvoltage protector ...
> >I've heard that Bob sells these "crowbar overvoltage protectors". I need >one pretty bad. >I've been to the web site but can't find one there. Did I hear >wrong? How do I protect from >alternator runaway? The OV module is sold by B&C down near the bottom of the page at: http://www.bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?26X358218 There is nothing you need to do to "protect" the alternator . . . the crowbar ov system protects the AIRPLANE from a malfunctioning alternator. Got your order for a book and it's going out in a few minutes. I've forwarded your request for OVM-14 crowbar module to B&C. I suspect it will go out today. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Re: battery charger
>Below is the result of your inquiry. It was submitted by >Dennis Jones (djones(at)foxvalley.net) on Tuesday, October 7, 2003 at 16:30:28 > >Tuesday, October 7, 2003 > >Dennis Jones > >, >Email: djones(at)foxvalley.net >Comments/Questions: You use to reference battery chargers that have the >ability to monitor battery temperature as well as all the other required >items (12 ant 24 volts, starting ability). Do you still have chargers you >recommend for us aviator types? Don't worry about temperature compensation. This is unnecessary for 99% of common battery usage in airplanes. How do you plan to use this? If you have an RG battery, you can put the airplane away and come back in 6 months and the battery will be in good shape. I have several battery maintainers that I use for my portable instrumentation power packs . . . here's an example: http://www.atvpartsstore.com/automatic_battery_charger.html There are dozens that cost $30-40 range and work nice. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 08, 2003
> >At the time I was testing it the volt meter was reading 12.4 volts, >which I thought should have been enough. I didn't measure the voltage >across the coil but I will. I will take you up on your offer and send >you the contactor. I would like the B&C contactor sent to the below >address. I will happily pay for it. > >No one makes a solid state contactor? I would think there would be >quite a market for something like that. > >Thanks. > >Vince Ackerman >17977 NW Sauvie Island Rd >Portland, OR 97231 > >503-621-0511 Send your bad contactor to Bob Nuckolls, 6936 Bainbridge Road, Wichita, Ks 67226-1008 I've e-mailed B&C to get you a replacement contactor on the way with my compliments. Bob . . . >On Tuesday, October 7, 2003, at 06:45 AM, Robert L. Nuckolls, III wrote: > > > > > > >> > >> I installed a battery master switch with contactor (one or the 3 > >> terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. > >> For > >> reasons of space I installed it upside down. While testing out the > >> electrical system I noticed that tapping with a small rubber mallet on > >> the bracket that it's mounted to will cause it to interrupt the power > >> momentarily. It doesn't matter if I tap from top or bottom, it seems > >> to disconnect for a split second. I know it's disconnecting because my > >> rotor tach goes through it's initialization test on first power up, > >> and > >> it's doing that every time. Also, other indicator lights flicker, so > >> it's not just the tach, nor loose battery leads, etc. > >> > >> You can understand my hesitation about using this since it's a helo > >> (they aren't the smoothest) with two FADEC's that can't be > >> electrically > >> interrupted. Are there any stronger or more reliable contactors, > >> perhaps even solid state? Any suggestions for how to fix this? > > > > > > What's your battery voltage? It may be so low as to > > severely reduce the holding force of the coil in the > > energized mode . . . but it has to sag really low. Measure > > the voltage across the coil while energized (battery+ > > terminal to small terminal). > > > > If the voltage is over 10v, I'd like to get my hands on that > > contactor. If you'll send me you address, I'll have B&C ship > > you one of their battery contactors today and you can send > > me your questionable device. There's something seriously > > wrong with it if you can get interruptions with vibration. > > > > Bob . . . > > > > > > _- > > ======================================================================= > > > > _- > > ======================================================================= > > > > http://www.matronics.com/trouble-report > > _- > > ======================================================================= > > > > _- > > ======================================================================= > > > > > > Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Re: Rotorway Massive Failure
> > >A colleague of mine has a Rotorway Exec... He was taking off this past >weekend... The skids were about 2 inches off the ground when he had a total >power failure involving the engine/charging system... Looking it over he >found blown fuses in the circuit(s) to the engine... Only the instruments >are still lighting up with the master turned on... He was asking me for >advice... Rotorway has him looking for a shorted wire in the harness and >ignition.... I doubt that as the source of the problem... > >I suggested that I suspected the alternator had a major OV and/or internal >short that took out the main fuses and left him with no ignition power from >the battery... I recommended that he remove the alternator and take it to >the local auto electric rebuilder and have it tested for output and >regulation ( I do not know whether it is internally or externally regulated, >and he didn't even understand the question when I asked him) >Obviously there are many possible scenarios... I am aware of most of them, >and will not bore the group with a recitation, and that discussion is not >the reason for this message... > >It sounds like Rotorway does not have an essentials bus/battery with >appropriate OVP and isolation for the electrically dependent engine ignition >(hint, hint, Robert)... Those on the list who have or know someone with a >Rotorway would be well advised to (help them) determine their level of risk >of ignition failure... When/if I learn actual electrical facts about this >bird and get to put hands on, and to see the electrical diagram, I will >inform the list... >Cheers ... Denny There are MANY questions that need to be explored to adequately understand root cause of the failure and then deduce why the failure was intolerable. When you have multiple blown fuses, this does suggest a severe ov condition. I agree that a "sorted wire in harness" is going to be found as root cause. Before he gets out hammers-n-saws, have him contact me either here on the list or directly. Let's do this investigation in an orderly fashion that doesn't eliminate evidence before it can be examined. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
> >At the time I was testing it the volt meter was reading 12.4 volts, >which I thought should have been enough. I didn't measure the voltage >across the coil but I will. I will take you up on your offer and send >you the contactor. I would like the B&C contactor sent to the below >address. I will happily pay for it. > >No one makes a solid state contactor? I would think there would be >quite a market for something like that. I'm not aware of a solid state contactor capable of battery contactor service that handles bi-directional current flows commensurate with this application. The technology is out there to do it but it would be MUCH more expensive than the plain-vanilla contactor. They're old technology but quite mature and very inexpensive. If your system is failure tolerant, then the absolute quality and/or service life should not be a driving issue. I'd use them in my own airplane. Let's see what's going on with the one that's giving you problems. This is a RARE event and I'd like to understand what's happening. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
> > > > >I installed a battery master switch with contactor (one or the 3 > >terminal ones sold by Aircraft Spruce) on my Rotorway 162f project. For > >reasons of space I installed it upside down. While testing out the > >You can understand my hesitation about using this since it's a helo > >(they aren't the smoothest) with two FADEC's that can't be electrically > >interrupted. Are there any stronger or more reliable contactors, > >perhaps even solid state? Any suggestions for how to fix this? > > > >Thanks > >Vince Ackerman > >N777FB > >We had similar type of problem in the Glasairs. It was discovered that >during high g loads, the contactors would separate. The fix was mounting >them horizontally. Properly designed and operating contactors are not position sensitive. If changing mounting orientation of a contactor "fixed" anything, then it simply covered up a symptom of a profound problem with the contactor's design or quality. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Re: Rotorway Massive Failure - keyboard dyslexia repost
> > > > > > > >A colleague of mine has a Rotorway Exec... He was taking off this past > >weekend... The skids were about 2 inches off the ground when he had a total > >power failure involving the engine/charging system... Looking it over he > >found blown fuses in the circuit(s) to the engine... Only the instruments > >are still lighting up with the master turned on... He was asking me for > >advice... Rotorway has him looking for a shorted wire in the harness and > >ignition.... I doubt that as the source of the problem... > > > >I suggested that I suspected the alternator had a major OV and/or internal > >short that took out the main fuses and left him with no ignition power from > >the battery... I recommended that he remove the alternator and take it to > >the local auto electric rebuilder and have it tested for output and > >regulation ( I do not know whether it is internally or externally regulated, > >and he didn't even understand the question when I asked him) > >Obviously there are many possible scenarios... I am aware of most of them, > >and will not bore the group with a recitation, and that discussion is not > >the reason for this message... > > > >It sounds like Rotorway does not have an essentials bus/battery with > >appropriate OVP and isolation for the electrically dependent engine ignition > >(hint, hint, Robert)... Those on the list who have or know someone with a > >Rotorway would be well advised to (help them) determine their level of risk > >of ignition failure... When/if I learn actual electrical facts about this > >bird and get to put hands on, and to see the electrical diagram, I will > >inform the list... > >Cheers ... Denny > > There are MANY questions that need to be explored to adequately > understand root cause of the failure and then deduce why the failure > was intolerable. When you have multiple blown fuses, this does > suggest a severe ov condition. I agree that a "shorted wire in harness" > is probably NOT going to be found as root cause. > > Before he gets out hammers-n-saws, have him contact me either here > on the list or directly. Let's do this investigation in an orderly > fashion that doesn't eliminate evidence before it can be examined. > > Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Switched gnd?
> >Hopefully it's not that complicated. This is what I want to do. > >Main fuse block -- 5 amp fuse -- fuel pump -- terminal strip -- infinity >grip -- ground > >=AND> >Main fuse block -- 2 amp fuse -- dimmer board -- 3 enun. LEDs -- >terminal strip -- infinity grip -- ground > >When the switch is closed on the grip, it provides ground to both the >pump and it's one enun light. I couldn't get this fuctionality >switching the positive unless I had one dimmer board per enun light, >which is not a reasonable option. Drive on . . . ________________________________________________________________________________
Date: Oct 08, 2003
Bob, What happens if the points in the mag shorts or a wire breaks, or any other failure. After all one of the reasons to have dual magnetos is for back up therefore there is a perceived risk of a mag failing. Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Electronic tacho & mag check > > >I personally would look for a different system that had the capability to >monitor both p-leads all the time and let you know if there is any >difference. That is an engine monitor which could notify you in flight of >any difference in the RPMs of the left and right mag. How would this happen? If you have two devices driven from the same shaft, their rpms are in lock-step with each other. If there is any difference, it would have to be because one had broken off entirely and was reading ZERO rpm. If they're running at all, they're exactly matched. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
Subject: Alternator Noise in Headset
--0-1048268627-1065643404=:33612 Bob, Apologies if this is a duplicate post; I seem to have trouble getting this out. I'm starting to develop an electrical problem in my RV-4 and I'm hoping you can help me diagnose it. I bought the RV-4 (completed) last year. It was built in 1988 and I'm the fourth owner. It's a solid airplane, but the documentation is thin and from the logbooks it appears that the electrical stuff (lights, radios) were added piecemeal over the plane's first few years, so the electrical system is a bit tangled. For example, my nav light circuit breaker kept popping. I finally figured out that the builder / modifier has three 2-amp bulbs (6 amps) going through a 5-amp CB. So, after consulting the wire selection graph, I replaced the 5A CB with a 10A CB. Worked great. However, on my next flight, I started hearing a whine in my headset. More of a high-pitched tone, actually. I realized that it was a solid tone that was being cut off intermittently, making it sounding a lot like Morse from an VOR. As I returned from a cross country it got louder and became almost constant. The whine / tone is present with the radios off, strobes off, and alternator off, although I didn't think to pull the breakers on those circuits. I don't hear it on deck with all the avionics running off the RG battery. Inflight I can hear it in the background during intercom use and radio reception. It disappears briefly after a radio transmission and then returns after a few seconds. The plane has a VDO analog voltmeter, no ammeter. ( I plan to install an VA-1A EI volt/ammeter shortly.) As I heard the tone inflight I immediately noticed that the voltage was increasing to about 15.5 V and fluctuating there for a while. Then it settled down to 14.5 V or so. Th e problem comes and goes and is not entirely repeatable. The voltmeter reads 14.0 volts on deck with just the battery on and the engine not running (no alternator), so I think the VDO voltmeter is accurate. Also, perhaps related and perhaps not, the LORAN started telling me a few weeks back, before I heard any of this headset noise, that I was in the Southern Hemisphere when I was flying across Oregon. I had thought the LORAN had just died due to age, and I was buying a GPS anyway, so I've just turned it off and planned to remove it. Initially I was thinking the obvious thought that the alternator's going. After reading the Aeroelectric Connnetion I'm wondering if it might not be the voltage regulator. Because the plane has so little documentation, I don't know the specifics of the alternator at all or how old it is, just that it's been working well so far. My A&P found nothing wrong with it at the last annual 60 hours ago. I'm wondering if the impending alternator / regulator failure is putting out RF that's getting into the headset and was jamming the LORAN. (It turns out that the LORAN had locked onto the wrong nav solution -- that whole "two solutions to the quadratic equation" thing. Letting it sit on deck for a few minutes with the engine off allowed it to "find itself" correctly back in California. But I'm still wondering if the initial event of it getting lost wasn't related to LORAN signal jamming from the alternator / regulator.) Also, I noticed in flight that with the electrical system fully loaded up, the voltmeter needle also starts rapidly fluctuating at 14.5-15.5V. I see this when I turn on the landing light. Due to the lack of documentation I have no idea how many total amps are actually flowing through the system, so I'm wondering if turning on the landing lights actually puts the plane's total current draw above the rated output of the alternator. Is fluctuating system voltage a sign of that? This airplane is well-built structurally and the engine's in good shape, but the more I look at the electrical system, the more I relaize that it's not quite what I'd like to see. Since avionics and lights were added piecemeal over the years by different people, I wouldn't be surprised to see as basic a mistake as an undercapacity alternator. (Remember the undercapacity CB I found.) Lastly, I'm also noting that the whine showed up within two flight hours of my replacing the nav lights circuit breaker. Although I can't imagine why that would have an effect, I also should mention that the circuit breaker panel is homemade and possibly not well shielded; perhaps in the course of working with the panel to swap out the breaker I changed something. If you could offer any thoughts on this, I'd appreciate it. Best, Pete Waters (registered for your class in Watsonville) --------------------------------- --0-1048268627-1065643404=:33612 Bob, Apologies if this is a duplicate post; I seem to have trouble getting this out. I'm starting to develop an electrical problem in my RV-4 and I'm hoping you can help me diagnose it. I bought the RV-4 (completed) last year. It was built in 1988 and I'm the fourth owner. It's a solid airplane, but the documentation is thin and from the logbooks it appears that the electrical stuff (lights, radios) were added piecemeal over the plane's first few years, so the electrical system is a bit tangled. For example, my nav light circuit breaker kept popping. I finally figured out that the builder / modifier has three 2-amp bulbs (6 amps) going through a 5-amp CB. So, after consulting the wire selection graph, I replaced the 5A CB with a 10A CB. Worked great. However, on my next flight, I started hearing a whine in my headset. More of a high-pitched tone, actually. I realized that it was a solid tone that was being cut off intermittently, making it sounding a lot like Morse from an VOR. A s I returned from a cross country it got louder and became almost constant. The whine / tone is present with the radios off, strobes off, and alternator off, although I didn't think to pull the breakers on those circuits. I don't hear it on deck with all the avionics running off the RG battery. Inflight I can hear it in the background during intercom use and radio reception. It disappears briefly after a radio transmission and then returns after a few seconds. The plane has a VDO analog voltmeter, no ammeter.( I plan to installan VA-1A EI volt/ammeter shortly.) As I heard the tone inflight I immediately noticed that the voltage was increasing to about 15.5 V and fluctuating there for a while. Then it settled down to 14.5 V or so. The problem comes and goes and is not entirely repeatable. The voltmeter reads 14.0 volts on deck with just the battery on and the engine not running (no alternator), so I think theVDO voltmeter is accurate. Also, perhaps related and perhaps not, the LORAN started telling mea few weeks back, before I heard any of this headset noise,that I was in the Southern Hemisphere when I was flying across Oregon. I had thoughtthe LORANhad just died due to age, and I was buying a GPS anyway, so I've just turned itoffand planned to remove it. Initially I was thinking the obvious thought that the alternator's going. After reading the Aeroelectric Connnetion I'm wondering if it might not be the voltage regulator. Because the plane has so little documentation, I don't know the specifics ofthe alternator at all or how old it is, just that it's been working well so far. My AP found nothing wrong with it at the last annual 60 hours ago. I'm wondering if the impending alternator / regulatorfailure is putting out RF that's getting into the headset and was jamming the LORAN. (It turns out that the L ORAN had locked onto thewrong nav solution -- that whole "two solutions to the quadratic equation" thing.Letting it sit on deck for a few minutes with the engine off allowed it to "find itself" correctly back in California.But I'm still wondering if the initial event of it getting lost wasn't related to LORAN signal jamming from thealternator / regulator.) Also, I noticed in flight that with the electrical system fully loaded up, the voltmeter needle also starts rapidly fluctuating at 14.5-15.5V. I see this when I turn on the landing light. Due to the lack of documentation I have no idea how many total amps are actually flowing through the system, so I'm wondering if turning on the landing lights actually puts the plane's total current draw above the rated output of the alternator. Isfluctuating system voltage a sign of that? This airplane is well-built structurally and the engine'sin good shape, but the more I look at the electrical system, the more I relaize that it's not quite what I'd like to see. Since avionics and lights were added piecemeal over the years by different people, I wouldn't be surprised to see as basic a mistake as an undercapacity alternator. (Remember the undercapacity CB I found.) Lastly, I'm also noting that the whine showedup within two flighthours of my replacing thenav lights circuit breaker. Although I can't imagine why that would have an effect, I also should mention that thecircuit breaker panel is homemade and possibly not well shielded; perhaps in the course of working with the panel to swap out the breaker I changed something. If you could offer any thoughts on this, I'd appreciate it. Best, Pete Waters (registered for your class in Watsonville) --0-1048268627-1065643404=:33612-- ________________________________________________________________________________
Subject: Battery Contactor vibration problem
Date: Oct 08, 2003
I just coincidentally had a vendor-visit from the Crydom rep. SO, I just happened to ask him about Solid State high amp. relays. They have some with 100Amp load current (max) that operate 3.5-32 volts DC control voltage. They will switch 0-60 Volts dc. These will have to be heatsinked, of course but they will mount easily with 2 fasteners. PN's D06D60, D06D80, or D06D100. I haven't checked out their website yet. www.crydom.com FYI. W.Miller > >At the time I was testing it the volt meter was reading 12.4 volts, >which I thought should have been enough. I didn't measure the voltage >across the coil but I will. I will take you up on your offer and send >you the contactor. I would like the B&C contactor sent to the below >address. I will happily pay for it. > >No one makes a solid state contactor? I would think there would be >quite a market for something like that. ________________________________________________________________________________
Date: Oct 08, 2003
The deed is done. All systems appear to work as expected. Thanks. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] > Sent: Wednesday, October 08, 2003 1:40 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Switched gnd? > > > --> > > >--> > > > >Hopefully it's not that complicated. This is what I want to do. > > > >Main fuse block -- 5 amp fuse -- fuel pump -- terminal strip -- > >infinity grip -- ground > > > >=AND> > > >Main fuse block -- 2 amp fuse -- dimmer board -- 3 enun. LEDs -- > >terminal strip -- infinity grip -- ground > > > >When the switch is closed on the grip, it provides ground to > both the > >pump and it's one enun light. I couldn't get this fuctionality > >switching the positive unless I had one dimmer board per enun light, > >which is not a reasonable option. > > > Drive on . . . ________________________________________________________________________________
Date: Oct 08, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >I just coincidentally had a vendor-visit from the Crydom rep. >SO, I just happened to ask him about Solid State high amp. relays. > >They have some with 100Amp load current (max) that operate 3.5-32 volts DC >control >voltage. They will switch 0-60 Volts dc. These will have to be heatsinked, >of course >but they will mount easily with 2 fasteners. >PN's D06D60, D06D80, or D06D100. >I haven't checked out their website yet. www.crydom.com > >FYI. >W.Miller These are good for controlling a uni-directional load. Keep in mind that a battery contactor needs to have good performance BOTH directions . . . OUT for cranking, IN for battery charging. Inrush current to a starter motor can be on the order of 300-500 amps for several milliseconds. The relay has to shrug this off too. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2003
Wow, those look pretty slick. I'd be interested to know if you guys think they appropriate for our aircraft (continuous duty, etc...). FYI: Mouser lists the 80amp unit at $85.00. Jon > --> > > I just coincidentally had a vendor-visit from the Crydom rep. > SO, I just happened to ask him about Solid State high amp. relays. > > They have some with 100Amp load current (max) that operate > 3.5-32 volts DC control voltage. They will switch 0-60 Volts > dc. These will have to be heatsinked, of course but they > will mount easily with 2 fasteners. PN's D06D60, D06D80, or > D06D100. I haven't checked out their website yet. www.crydom.com > > FYI. > W.Miller ________________________________________________________________________________
Date: Oct 08, 2003
> >Bob, > >What happens if the points in the mag shorts or a wire breaks, or any other >failure. After all one of the reasons to have dual magnetos is for back up >therefore there is a perceived risk of a mag failing. > >Trampas I think I understand your question . . . we were discussing the value of looking for the rpm readings from two mags to be DIFFERENT . . . I suggeseted that they're either dead-nuts in lock step with each other -OR- one of them is DEAD. Were you suggesting that there should be some provision for ACTIVE mag failure warning? There have been about 250,000 airplanes built in US alone that have never had a mag failure warning system installed. An excellent demonstration of the value of the FMEA . . . and the underlying notions that (1) you're not likely to get dual failures on any single tank of fuel and (2) you'll catch the failed mag at next preflight. Some pilots do a mag-check during taxi to parking so as to get a heads-up about an unperceived failure during the flight . . . it's better to know that a mag has crapped taxiing in than during next pre-flight. An analysis of this very long and rich history of dual-mag engines for flight suggests that an active mag failure warning system is unnecessary. Bob . . . ________________________________________________________________________________
Subject: Solid state relay to replace master contactor
Date: Oct 08, 2003
Warren, I just checked out the web site for the product you mention. See it's specs at the web page below: http://www.crydom.com/pdf/D06D.pdf This unit would not work as a master contactor. It's maximum rated surge is only 270 amps. This won't cut it for all situations when cranking the starter. Charlie Kuss From: "Miller.Warren" <Warren.Miller(at)igt.com> Date: 2003/10/08 Wed PM 05:40:02 EDT > > To: "'aeroelectric-list(at)matronics.com'" > > Subject: RE: AeroElectric-List: Battery Contactor vibration problem snipped ________________________________________________________________________________
From: "Dean Psiropoulos" <deanpsir(at)easystreet.com>
Subject: Switches and breakers.
Date: Oct 08, 2003
Your infinite words of wisdom are requested Bob: I have purchased several switches and breakers from a local electronics store and am wondering about their suitability for use in aircraft (price was substantially lower than similar ones from Aircraft Spruce or even Van's). The hardware data is as follows: 1) Potter and Brumfield 50 VDC, 7.5 AMP breaker/switch, W31-X2M1G-7.50, made in Mexico, screw terminals 2) Potter and Brumfield 50 VDC, 6 AMP breaker, W58-XB1A4A-6P, made in Mexico, fast-on terminals 3) SIEMENS 50 VDC, 3 AMP breaker, W58-XB1A4A-3P, made in Mexico, fast-on terminals 4) Potter and Brumfield 32 VDC, 4 AMP breaker, W28-XQ1A-4P, !!!!! made in USA !!!!!, fast-on terminals 5) Carling Switch 15 AMP, 125 Volt AC, SPST lighted (incandescent) rocker switch, made in Mexico, fast-on terminals 6) EDK 5 AMP, 125 Volt AC, SPST lighted (LED) rocker switch, made in Japan, fast-on terminals Any good things or bad things to say about the above hardware or general words of wisdom on these items? Thanks. Dean Psiropoulos RV-6A Can't wait to start wiring! Your infinite words of wisdom are requested Bob: I have purchased several switches and breakers from a local electronics store and am wondering about their suitability for use in aircraft (price was substantially lower than similar ones from Aircraft Spruce or even Vans). The hardware data is as follows:
6) EDK 5 AMP, 125 Volt AC, SPST lighted (LED) rocker switch, made in Japan, fast-on terminals Any good things or bad things to say about the above hardware or general words of wisdom on these items? Thanks. Dean Psiropoulos RV-6A Cant wait to start wiring! ________________________________________________________________________________
Subject: Switchable tach input source for Figure Z-27
Date: Oct 08, 2003
Bob, I've been straining my pea brain studying all of your electrical schematics. I'm building a VFR RV-8A with 1 mag and 1 EI. I'm basing my system on drawing Z-11. I plan to use figure Z27 to wire my 2 toggle style ignition switches. Earlier today, you referred another lister to a free hand drawn schematic that will allow him to switch his tach imput lead between 2 magnetos. Is this possible to do in conjunction with figure Z-27 for my system? Will it require a pair of 3-3 switches? I'm using an RMI uMonitor for my tachometer. Please advise. Charlie Kuss PS Thanks again for all your efforts on our behalf. ________________________________________________________________________________
Subject: RE: AeroElectric-List Digest: 28 Mags - 10/08/03
Date: Oct 09, 2003
Hi Neville I've just made what you want for a friend with a Druine Turbulent. One mag switch is replaced by a DPDT. One half is used as the p-lead contact. The other half is used as a tacho selector. Dont put relays into such an installation. Best regards Villi H. Seemann Sen. Eng. BSEE Telephony Team Infrastructure, Network Phone (+45) 3333 2101 Cell ph. (+45) 2220 7690 FAX (+45) 3333 1130 ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Electronic tacho & mag check > > I have heard of people taking a couple of capacitors and connecting them in > series with the P-leads, then connect both leads, after the capacitors, to > the tach. I am not sure how well this would work with your tach. > > I personally would look for a different system that had the capability to > monitor both p-leads all the time and let you know if there is any > difference. That is an engine monitor which could notify you in flight of > any difference in the RPMs of the left and right mag. > > I am currently working on building such an engine monitoring system. > > Trampas > ________________________________________________________________________________
Date: Oct 09, 2003
Bob, From what I have heard and seen I would agree that dual magneto failures are rare. My thoughts were if you are building an engine monitor and have the capability to monitor both P-leads then why would you not want to have an active mag warning? My personal philosophy is that an engine monitor should monitor the engine and any related systems. That is the pilot's job is to fly the plane and enjoy the flight. An engine monitor should provide the pilot with the information he needs to fly the plane and enjoy his flight. A lot of this dual mag topic is a philosophical debate. For example I am the type of person that when a headlight burns out on my car, I replace both headlights. They were on the same amount of time, and most likely identical in construction, therefore they will most likely die about the same time. Kind of like spark plugs in that you would not change just the one that wore out first. Therefore if your mags were both overhauled at the same time using the same parts and one failed, then I am of the mind set that perceives the risk of the other one failing has just increased significantly. However in reality just like the head lights the other one may work for several more years, or just a few more hours. Thus it is all about risk management that is in the headlight example the risk of the second one failing, in my mind, is greater than the $5-$10 for a new bulb. Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Electronic tacho & mag check > >Bob, > >What happens if the points in the mag shorts or a wire breaks, or any other >failure. After all one of the reasons to have dual magnetos is for back up >therefore there is a perceived risk of a mag failing. > >Trampas I think I understand your question . . . we were discussing the value of looking for the rpm readings from two mags to be DIFFERENT . . . I suggeseted that they're either dead-nuts in lock step with each other -OR- one of them is DEAD. Were you suggesting that there should be some provision for ACTIVE mag failure warning? There have been about 250,000 airplanes built in US alone that have never had a mag failure warning system installed. An excellent demonstration of the value of the FMEA . . . and the underlying notions that (1) you're not likely to get dual failures on any single tank of fuel and (2) you'll catch the failed mag at next preflight. Some pilots do a mag-check during taxi to parking so as to get a heads-up about an unperceived failure during the flight . . . it's better to know that a mag has crapped taxiing in than during next pre-flight. An analysis of this very long and rich history of dual-mag engines for flight suggests that an active mag failure warning system is unnecessary. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2003
Subject: Re: Solid state relay to replace master contactor
<... maximum rated surge is only 270 amps ...> But wouldn't it still be ideal for an alternator relay that can be easily shut off for overvoltage> chaskuss(at)bellsouth.net wrote: -- Jim Sower Crossville, TN; Chapter 5 Long-EZ N83RT, Velocity N4095T ________________________________________________________________________________
Date: Oct 09, 2003
<> That's a great idea - except that I don't think you don't need a triple pole switch. Use a double pole switch on one mag to run the mag and starter. Another double pole switch runs the other mag and also switches the tach. Should work, right? And doesn't really add much complexity. Gary Casey ________________________________________________________________________________
Date: Oct 09, 2003
can be used to swap tach sensing to the opposite > mag when it is in the OFF position. It doesn't matter which > mag you do this with. > Bob . . .>> > >That's a great idea - except that I don't think you don't need a triple pole >switch. Use a double pole switch on one mag to run the mag and starter. >Another double pole switch runs the other mag and also switches the tach. >Should work, right? And doesn't really add much complexity. If you want to enable starter with R mag OFF and L mag ON then it takes a dedicated pair of poles as I've illustrated. If you consider it sufficient to disable the starter button only when R mag is ON, then yes, a pair of two pole toggles will do it. Running the starter through both mag switches was to minimize probability of inadvertent starter operation with the airplane parked. This is a TINY order of probability so yes, if you can give up the airplane-parked, starter-lockout then http://www.aeroelectric.com/temp/elect_tach2.gif is the schematic. If you want to retain the parked-airplane, starter- lockout, then one 3-pole switch is needed as shown in http://www.aeroelectric.com/temp/elect_tach.gif Bob . . . ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Strobe head fix
Date: Oct 09, 2003
Hi Bob and all, A friend just asked me a question about the suitable material for the strobe head on his homebuit. Can silicone be used to re-seal the glass lens to the transformer/plastic base of the head ? If so, what grade is best ? Thanks, Gilles Thesee ________________________________________________________________________________
Subject: Starter/mag switch
Date: Oct 09, 2003
From: "David.vonLinsowe" <David.vonLinsowe(at)delphi.com>
Hi Bob, Twice the rpm with the electronic ignition is because the mag is putting out one pulse per rev and the E.I. puts out two. The EIS can be configured for either one pulse or two, but it can't change in mid stream. It was also recommended that I use the mag as the primary rpm sensor because of the response time of the EIS. It can detected potential mag problems by way of an erratic rpm reading. Thanks, Dave Snip >What do you think about the idea of using a triple pole switch for the >left mag and starter and add a circuit to switch to the EI tach info >when the mag is off? The EI tach info will have twice the rpm, but I >don't see that as an issue. Is there a better way? not sure about the "twice the rpm" statement but yes, most electronic tachs work best while watching only one of two mags at a time. A third pole on one mag switch can be used to swap tach sensing to the opposite mag when it is in the OFF position. It doesn't matter which mag you do this with. Bob . . . ________________________________________________________________________________
Date: Oct 09, 2003
Hi Jim, Actually this setup is even simpler, only two switches. The left mag switch is three position with the full up position momentary, that's the starter circuit. It's been working great for the last 300+ hours. I switched to electronic ignition on the right mag and still no problems. The problem is when you do away with the mechanical tach and don't have two mags. When you do a mag check and turn it off you also loose the rpm info. Hence the need to switch over to the electronic ignition for rpm info when the mag is off. Dave Subject: Re: AeroElectric-List: Starter/mag switch I like to keep it simple. I have two toggle switches for ignition and a push button starter. Just a theory ... Jim S. ________________________________________________________________________________
Date: Oct 09, 2003
Subject: Re: Strobe head fix
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob and all, > >A friend just asked me a question about the suitable material for the strobe >head on his homebuit. > >Can silicone be used to re-seal the glass lens to the transformer/plastic >base of the head ? >If so, what grade is best ? Electronic grade (does not smell of vinegar). Bob . . . ________________________________________________________________________________
Subject: Fuse Blocks, fuses, fusible links and CBs
Date: Oct 10, 2003
> What would you suggest for a feed to the flap motor. I thought I read > something about this is one particular animal that can nuisance trip. If > you were to recommend a CB application how would you power that off say > the main bus/fuse block? I would prefer to keep the ALT FLD CB the only > breaker on the panel, if practical. FEMA is good concept but .... with many flap systems, the motor will draw more current than the flap system is designed to take if you extend the flaps when the speed is a little over the flap extension speed limit. In this case a breaker in reach is very handy because you can slow the plane down, reset the breaker and safely extend the flaps. If you have a remote fuse in such a case, a good pilot will reconsider runway length and conditions and go to another airport in case the approach speed is too high with only partially extended flaps. Of course most POHs don't give you any guidance for runway lengths with no or partially extended flaps. Under the best of circumstances this is not much fun when a breaker will let you do it the way you originally wanted to do it. I of course have no personal experience with this but have heard those dark and stormy night tales. ________________________________________________________________________________
Date: Oct 10, 2003
doesn't everyone practice flapless landings? I certainly do. Ian -----Original Message----- From: fellowsw [mailto:fellows.w(at)ewcapital.net] Subject: RE: AeroElectric-List: Fuse Blocks, fuses, fusible links and CBs > What would you suggest for a feed to the flap motor. I thought I read > something about this is one particular animal that can nuisance trip. If > you were to recommend a CB application how would you power that off say > the main bus/fuse block? I would prefer to keep the ALT FLD CB the only > breaker on the panel, if practical. FEMA is good concept but .... with many flap systems, the motor will draw more current than the flap system is designed to take if you extend the flaps when the speed is a little over the flap extension speed limit. In this case a breaker in reach is very handy because you can slow the plane down, reset the breaker and safely extend the flaps. If you have a remote fuse in such a case, a good pilot will reconsider runway length and conditions and go to another airport in case the approach speed is too high with only partially extended flaps. Of course most POHs don't give you any guidance for runway lengths with no or partially extended flaps. Under the best of circumstances this is not much fun when a breaker will let you do it the way you originally wanted to do it. I of course have no personal experience with this but have heard those dark and stormy night tales. ---------------------------------------------------- RSL COM has an extensive and competitive range of local and long distance call packages. We also offer converged multimedia and data services through our own state-of-the-art integrated voice & data network. Visit http://www.rslcom.com.au to find out more. This message is for the named person's use only. Privileged/confidential information may be contained in this message. If you are not the addressee indicated in this message (or responsible for delivery of the message to such person), you may not copy or deliver this message to anyone. In such case, you should destroy this message, and notify us immediately. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorised to state them to be the views of any such entity. ---------------------------------------------------- ________________________________________________________________________________
Date: Oct 10, 2003
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, Ian Subject: RE: AeroElectric-List: Fuse Blocks, fuses, fusible links and CBs doesn't everyone practice flapless landings? I certainly do. Ian Of course but as a perfect pilot it is a theoretical exercise for me. A Dragonair crew on the Airbus couldn't extend the flaps because of a computer design flaw and practiced one as well into Hong Kong airport. Rumor has it that it was not that much fun flying the approach 100 knots faster than normal so it probably depends on the airplane as well. ________________________________________________________________________________
Date: Oct 10, 2003
> > > >Can silicone be used to re-seal the glass lens to the transformer/plastic > >base of the head ? > >If so, what grade is best ? > > Electronic grade (does not smell of vinegar). > > Bob . . . > Thanks Bob, Gilles ________________________________________________________________________________
Date: Oct 08, 2003
I am nearly finished building my Rotorway Exec 162f. I have slightly redesigned the electrical system to be more in line with the standards and practices found in Bob's Aerolectric book. The Rotorway electrical system is rather badly designed despite the fact that it has two FADEC's that are totally dependent on a constant source of 12 volts. If you have a total electrical failure, the engine quits. Despite that, this is the first time I've heard of a total failure on any ship. They supply a wiring harness for the entire aircraft and if you want to change anything, it involves some major work. I have made an essential bus and have separated out most of the subsystems to individual breakers but decided to leave the feed from alternator and battery alone. I did add a battery master/contactor but wonder if I'm not putting in a source of failure where one didn't exist before.... I am sending Bob a copy of the electrical system schematic (I promised him a long time ago). Vince Ackerman On Wednesday, October 8, 2003, at 07:44 AM, Dennis O'Connor wrote: > > > A colleague of mine has a Rotorway Exec... He was taking off this past > weekend... The skids were about 2 inches off the ground when he had a > total > power failure involving the engine/charging system... Looking it over > he > found blown fuses in the circuit(s) to the engine... Only the > instruments > are still lighting up with the master turned on... He was asking me > for > advice... Rotorway has him looking for a shorted wire in the harness > and > ignition.... I doubt that as the source of the problem... > > I suggested that I suspected the alternator had a major OV and/or > internal > short that took out the main fuses and left him with no ignition power > from > the battery... I recommended that he remove the alternator and take > it to > the local auto electric rebuilder and have it tested for output and > regulation ( I do not know whether it is internally or externally > regulated, > and he didn't even understand the question when I asked him) > Obviously there are many possible scenarios... I am aware of most of > them, > and will not bore the group with a recitation, and that discussion is > not > the reason for this message... > > It sounds like Rotorway does not have an essentials bus/battery with > appropriate OVP and isolation for the electrically dependent engine > ignition > (hint, hint, Robert)... Those on the list who have or know someone > with a > Rotorway would be well advised to (help them) determine their level of > risk > of ignition failure... When/if I learn actual electrical facts about > this > bird and get to put hands on, and to see the electrical diagram, I will > inform the list... > Cheers ... Denny > > > _- > ======================================================================= > > _- > ======================================================================= > > http://www.matronics.com/trouble-report > _- > ======================================================================= > > _- > ======================================================================= > > ________________________________________________________________________________
Date: Oct 10, 2003
Subject: noise in headset when transmitting
In my aircraft, when I transmit on my comm radio, I hear a loud squeal in my headset. The avionics shop said it's due to the close proximity of the antenna to my headset, and the wire that goes across from one side of the headset to the other picks up the signal. The airplane is all wood, and the antenna is behind the back seat, inside the fuselage. Is there anything that can be done to get rid of this annoying noise? ________________________________________________________________________________
Date: Oct 10, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> CBs
CBs CBs > > > > What would you suggest for a feed to the flap motor. I thought I read > > something about this is one particular animal that can nuisance trip. If > > you were to recommend a CB application how would you power that off say > > the main bus/fuse block? I would prefer to keep the ALT FLD CB the only > > breaker on the panel, if practical. > >FEMA is good concept but .... with many flap systems, the motor will draw >more current than the flap system is designed to take if you extend the >flaps when the speed is a little over the flap extension speed limit. VERY rare, and the risk is easy to deduce. . . . ammeters are cheap and should be part of everyone's toolbox. If you don't KNOW how much design headroom you've got in your selection of circuit protection, then I'll respectfully suggest it's easy to find out. > In >this case a breaker in reach is very handy because you can slow the plane >down, reset the breaker and safely extend the flaps. If you have a remote >fuse in such a case, a good pilot will reconsider runway length and >conditions and go to another airport in case the approach speed is too high >with only partially extended flaps. An UNEXPECTED trip of circuit protection is a nuisance event due to poor design and should be fixed. An EXPECTED and PLANNED for trip means you're (1) flying a spam can and can't fix it or (2) you don't know how your airplane performs under the full envelope of flight conditions and made a decision not to find out. > Of course most POHs don't give you any >guidance for runway lengths with no or partially extended flaps. Under the >best of circumstances this is not much fun when a breaker will let you do it >the way you originally wanted to do it. I of course have no personal >experience with this but have heard those dark and stormy night tales. I have never had to put an airplane down on a field where the difference between having flaps and not having flaps would have made a hill of beans worth of difference. Virtually all the airports I operate out of have 1000' or more of excess runway. If one plans to push both pilot and airplane to the edge of performance limits on a landing then a successful outcome is dependent on proper energy management and manipulation of controls (where observance of flap extension speed is but one of many considerations). I've dissected dozens of dark and stormy night stories for any engineering facts they might reveal. I may have found a few useful tid-bits over the years but taken as a whole, they are pretty much devoid of real data. The pilot who wrote the story was at the mercy of his instructors, regulators and manufacturer of the machine he was operating . . . a victim of collective ignorance and pockets of arrogance that is killing the certified segment of GA. The advice these stories offer miss an important feature of an OBAM aircraft: I know it's a big shift in attitudes and thinking to take full advantage of what the OBAM aircraft community offers. In this particular case, let's not design for what MAY happen because we don't make an effort determine what WILL happen. Then, take CONTROL of it in ways that make our airplanes (and pilots) stand head and shoulders above the rest of the GA community. Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Oct 10, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> contactor
contactor contactor > ><... maximum rated surge is only 270 amps ...> >But wouldn't it still be ideal for an alternator relay that can be easily >shut off for overvoltage> depends on what you call "idea" . . . it's a trade off of weight, size and $cost$ in order to achieve some advantage in performance. If you perceive a positive return on investment for the substitution, then perhaps it is an ideal alternative. . . Bob . . . ________________________________________________________________________________
Subject: Jumper for Video Camcorder
Date: Oct 10, 2003
Bob, I want to create a jumper to go from the co-pilot's audio jack to the microphone input in a camcorder. I have stereo audio jacks. Can you point me to a schematic that would illustrate how to make a jumper with an audio jack on one end (that would convert from stereo to mono), then have the smaller mic jack on the other end? Is this feasible? I think the audio output will probably be better than the drone of the engine when videoing in flight. I am assuming that the audio output will not be too much for the mic input on the camcorder? Can you just plug a mono audio jack into a stereo jack and have it combine left and right channels? As always, appreciate any input you can provide. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL Bob, I want to create a jumper to go from the co-pilot's audio jack to the microphone input in a camcorder. I have stereo audio jacks. Can you point me to a schematic that would illustrate how to make a jumper with an audio jack on one end (that would convert from stereo to mono), then have the smaller mic jack on the other end? Is this feasible? I think the audio output will probably be better than the drone of the engine when videoing in flight. I am assuming that the audio output will not be too much for the mic input on the camcorder? Can you just plug a mono audio jack into a stereo jack and have it combine left and right channels? As always, appreciate any input you can provide. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ________________________________________________________________________________
Date: Oct 10, 2003
Subject: Re: Starter/mag switch
> > >Hi Bob, > >Twice the rpm with the electronic ignition is because the mag is putting >out one pulse per rev and the E.I. puts out two. The EIS can be >configured for either one pulse or two, but it can't change in mid stream. I'm confused . . . every 4 cyl, 4-cycle engine needs two sparks per revolution. I've seen waste-spark electronic systems that drive only two of the four cylinders each . . . monitoring one of these systems for rpm data would indeed produce 1 pulse per revolution. On the other hand, a mag is just a self-powered version of the Kettering points, capacitor, coil and distributor system . . . which would produce two point operations, i.e. two pulses per revolution. Is your EI system one of those I described above? I developed a tach multiplier module for a Dragonfly builder in AZ who was using a four-coil, waste-spark system on his 4-cyl Hapi engine. The stock VDO tachometer was unable to resolve true engine rpm because the tach signal from one ignition came in at half the expected rate. The multiplier features a phase-locked-loop oscillator that used the half-rate signal to produce a full rate output. See: http://www.aeroelectric.com/temp/VDO_Tach_Multiplier.pdf This was designed and tested for the VDO tach, it might work as-is for your tach but can be certainly modified to accommodate any differences. This or a similar device could be wired between the EI sensor signal and the tach select switch so that the electronic tach sees the proper pulse rate vs. rpm for both ignition systems. Bob. . . ________________________________________________________________________________
Date: Oct 10, 2003
> >I am nearly finished building my Rotorway Exec 162f. I have slightly >redesigned the electrical system to be more in line with the standards >and practices found in Bob's Aerolectric book. The Rotorway electrical >system is rather badly designed despite the fact that it has two >FADEC's that are totally dependent on a constant source of 12 volts. If >you have a total electrical failure, the engine quits. Despite that, >this is the first time I've heard of a total failure on any ship. They >supply a wiring harness for the entire aircraft and if you want to >change anything, it involves some major work. I have made an essential >bus and have separated out most of the subsystems to individual >breakers but decided to leave the feed from alternator and battery >alone. I did add a battery master/contactor but wonder if I'm not >putting in a source of failure where one didn't exist before.... > >I am sending Bob a copy of the electrical system schematic (I promised >him a long time ago). I seem to recall having a conversation about this airplane some years ago. I can't recall if it was a builder or a factory rep. I might even still have the drawings in a file somewhere. As I recall, the conversation didn't go very far . . . after the first few exchanges of questions and recommendations, the guy at the other end of the conversation didn't like what he was hearing and quit participating . . . Let's revisit the system here on the List . . . Bob . . . ________________________________________________________________________________
Date: Oct 10, 2003
Subject: Re: Switches and breakers.
>Your infinite words of wisdom are requested Bob: > > >I have purchased several switches and breakers from a local electronics >store and am wondering about their suitability for use in aircraft (price >was substantially lower than similar ones from Aircraft Spruce or even Van >s). The hardware data is as follows: > > >1)Potter and Brumfield 50 VDC, 7.5 AMP breaker/switch, W31-X2M1G-7.50, >made in Mexico, screw terminals > >2)Potter and Brumfield 50 VDC, 6 AMP breaker, W58-XB1A4A-6P, made in >Mexico, fast-on terminals > >3)SIEMENS 50 VDC, 3 AMP breaker, W58-XB1A4A-3P, made in Mexico, fast-on >terminals > >4)Potter and Brumfield 32 VDC, 4 AMP breaker, W28-XQ1A-4P, !!!!! made in >USA !!!!!, fast-on terminals > >5)Carling Switch 15 AMP, 125 Volt AC, SPST lighted (incandescent) rocker >switch, made in Mexico, fast-on terminals > >6)EDK 5 AMP, 125 Volt AC, SPST lighted (LED) rocker switch, made in Japan, >fast-on terminals > > >Any good things or bad things to say about the above hardware or general >words of wisdom on these items? Thanks. Dean, you may be new to the list and are unaware of our studies on goals for worry-free parts selection . . . A reliable system is based not so much on WHAT parts you use but upon HOW they are used. The reliable flight system has a FAILURE TOLERANT architecture. If you don't have a copy of the book, See chapter 17 of the 'Connection at: http://www.aeroelectric.com/articles/Rev9/ch17-9.pdf There's nothing particularly good, bad or indifferent about the list of parts you've cited. The manner in which you choose to use these parts can have a profound effect on reliability of your project. Tell us about your project and how you plan to use it. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2003
Subject: Re: Antenna cable routing question
> >Most convenient routing for my comm antenna cable (RG-400) takes it >within about 3" of my Facet fuel pump- is this a no-no? Anyone have >this condition in use without ill effects? Antenna on fuse bottom. > >Would the same apply for the xpndr antenna, also on fuse bottom? After we've accomplished basic goals for noise reduction with the use of single point grounds, proper use of shielding where REALLY useful, reducing the number of fat wires in the cockpit, all other issues drop to negligible if not infinitesimal significance. There is no good reason to avoid running your antenna coax past the fuel pump. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2003
Subject: Re: Jumper for Video Camcorder
> > >Bob, > >I want to create a jumper to go from the co-pilot's audio jack to the >microphone input in a camcorder. I have stereo audio jacks. Can you >point me to a schematic that would illustrate how to make a jumper with >an audio jack on one end (that would convert from stereo to mono), then >have the smaller mic jack on the other end? Is this feasible? I think >the audio output will probably be better than the drone of the engine >when videoing in flight. I am assuming that the audio output will not >be too much for the mic input on the camcorder? Can you just plug a >mono audio jack into a stereo jack and have it combine left and right >channels? here's how I would do it. http://www.aeroelectric.com/temp/micadapt.jpg You'll have to experiment for the right value of R. 10 ohms is a good starting point. Make adjustments in 50% increments. If too weak, try 15, 22, 33, 47 ohms, etc. If to strong, drop to 7.5, 4.7, 3.3, etc. Using small resistors, the whole network can be contained inside the shell of the headset plug. Bob . . . ________________________________________________________________________________
Date: Oct 10, 2003
Subject: Re: Fuse Blocks, fuses, fusible links and CBs
<... a good pilot will reconsider runway length and conditions and go to another airport in case the approach speed is too high with only partially extended flaps ...> Flaps on GA airplanes are not that big a deal. And any good pilot knows that if his flaps won't deploy, he can make the approach no-flap and shut down the engine coming over the fence. His rollout will be less than if he had flaps. Of course, if this is actually necessary, after he fixes his flaps, his takeoff performance will be marginal indeed. Just a theory ... Jim S. "Robert L. Nuckolls, III CBs" wrote: CBs > > > ________________________________________________________________________________
Subject: Stick-shaker for stall warning
Date: Oct 11, 2003
Friends, I'm building a 4 place Jabiru, and this has a central control stick. I am considering the addition of a stick-shaker as used by military and commercial planes. A model airplane motor, run at the "appropriate" speed and driving an eccentric weight should work. The tiny pager motors available on the surplus market are too small to be useful in a vibrating plane, however. Could you professional pilots give me an idea as to how far the stick moves, and at roughly what frequency? I suspect that 8-20 Hz would be optimum, based on no real data. Its hard to guess the motion needed as this will be frequency dependent. I would drive this motor from either a microswitch attached to a vane projecting out from the leading edge of the wing, as is used by many commercial planes with an electric stall warning device, or else drive it from an angle of attack instrument. Although auditory warning from AoA devices is good, the stall is the greatest risk for death at takeoff and landing phase of flight. The warning should not be subtle and should use several modalities. I look forward to your comments. Jim Foerster Friends, I'm building a 4 place Jabiru, and this has a central control stick. I am considering the addition of a stick-shaker as used by military and commercial planes. A model airplane motor, run at the "appropriate" speed and driving an eccentric weight should work. The tiny pager motors available on the surplus market are too small to be useful in a vibrating plane, however. Could you professional pilots give me an idea as to how far the stick moves, and at roughly what frequency? I suspect that 8-20 Hz would be optimum, based on no real data. Its hard to guess the motion needed as this will be frequency dependent. I would drive this motor from either a microswitch attached to a vane projecting out from the leading edge of the wing, as is used by many commercial planes with an electric stall warning device, or else drive it froman angle of attack instrument. Although auditory warning from AoA devices is good, the stall is the greatest risk for death at takeoff and landing phase of flight. The warning should not be subtle and should use several modalities. I look forward to your comments. Jim Foerster ________________________________________________________________________________
Date: Oct 11, 2003
Hi! I understand there is something called Bobs Aerolectric book? If so where can I buy it? I live in Norway but I also have an adress in Florida, so I could pick it up there. Regards Tore S Bristol Forewer (it seems ) builder of a FEW TF 51 ________________________________________________________________________________
Subject: Re:
Date: Oct 11, 2003
Tore, Check out http://www.aeroelectric.com/, the book you need is the Aero Electric Connection, contains lots of practical advice, it is here http://www.aeroelectric.com/Catalog/pub/pub.html. Also check the schedule of weekend seminars that Bob offers, they are excellent. Tony ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re: Stick-shaker for stall warning
I know of no stick shaker on any military plane I flew or heard of. I wouldn't want one on a plane of mine. Seems a stick shaker would have to be driven by AoA, so why not just display/sound off Alpha? Seems to me a stick shaker would be more bother than help ... Jim S. James Foerster wrote: > > Friends, > > I'm building a 4 place Jabiru, and this has a central control stick. I > am considering the addition of a stick-shaker as used by military and > commercial planes. A model airplane motor, run at the "appropriate" > speed and driving an eccentric weight should work. The tiny pager > motors available on the surplus market are too small to be useful in a > vibrating plane, however. > > Could you professional pilots give me an idea as to how far the stick > moves, and at roughly what frequency? I suspect that 8-20 Hz would be > optimum, based on no real data. Its hard to guess the motion needed as > this will be frequency dependent. > > I would drive this motor from either a microswitch attached to a vane > projecting out from the leading edge of the wing, as is used by many > commercial planes with an electric stall warning device, or else drive > it from an angle of attack instrument. > > Although auditory warning from AoA devices is good, the stall is the > greatest risk for death at takeoff and landing phase of flight. The > warning should not be subtle and should use several modalities. I look > forward to your comments. > > Jim Foerster > > < ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re:
This is a "must have" book for building a plane; Go to Bob Knuckoll's "AeroElectric" web site http://www.aeroelectric.com/Catalog/AECcatalog.html and order it ($30.50). Updates to keep it current are there too. Neil At 04:36 AM 10/11/03, you wrote: > > >Hi! > I understand there is something called Bobs Aerolectric book? >If so where can I buy it? >I live in Norway but I also have an adress in Florida, so I could pick it up >there. > >Regards >Tore S Bristol >Forewer (it seems ) builder of a >FEW TF 51 > > ________________________________________________________________________________
Date: Oct 11, 2003
Stick shakers are common in many aircraft to provide an "artificial" stall warning when the "natural" stall warning characteristics of the aircraft are deemed to provide insufficient awareness of high angle of attack situations. The F-104 most definitely had a shaker and I suspect the F-4 had one as well although modern fighter aircraft with computer tailored flight controls have less need of such devices.. A stick shaker is used on many transport category aircraft such as the Dehavilland Dash-8 (which I fly now). The objective of the shaker is not to physically move the stick (or control column) but to vibrate it back and forth as a tactile vice audible or visual (flashing light, etc.) stall warning. Grasp the stick firmly and it won't move much at all. The frequency of the vibration on the D-8 is fairly high, perhaps 120-180 hertz, as far as I can tell. The mechanism proposed sounds about right - tune the speed of the motor to adjust the frequency of the vibration and the amount of eccentric weight to adjust the intensity of the vibration to taste. You might want to think about failure modes and provide a "shaker disable" circuit breaker to pull in the event of a "failed on" situation. Most commercial installations also provide a test feature to inject a high AOA signal into the system at some point to test the wiring and motor. This is often a certification issue and the system has to be checked on a regular basis in service. This sort of complication would certainly be avoided by a commercial manufacturer if possible. Suggest you check out the stall characteristics of the Jabiru first to see what the natural stall warnings characteristics are like and if a shaker will add anything worthwhile. Jim Oke Winnipeg, Canada ----- Original Message ----- From: "Jim Sower" <canarder(at)frontiernet.net> Subject: Re: AeroElectric-List: Stick-shaker for stall warning > > I know of no stick shaker on any military plane I flew or heard of. I wouldn't want > one on a plane of mine. Seems a stick shaker would have to be driven by AoA, so why > not just display/sound off Alpha? > Seems to me a stick shaker would be more bother than help ... Jim S. > > James Foerster wrote: > > > > > Friends, > > > > I'm building a 4 place Jabiru, and this has a central control stick. I > > am considering the addition of a stick-shaker as used by military and > > commercial planes. A model airplane motor, run at the "appropriate" > > speed and driving an eccentric weight should work. The tiny pager > > motors available on the surplus market are too small to be useful in a > > vibrating plane, however. > > > > Could you professional pilots give me an idea as to how far the stick > > moves, and at roughly what frequency? I suspect that 8-20 Hz would be > > optimum, based on no real data. Its hard to guess the motion needed as > > this will be frequency dependent. > > > > I would drive this motor from either a microswitch attached to a vane > > projecting out from the leading edge of the wing, as is used by many > > commercial planes with an electric stall warning device, or else drive > > it from an angle of attack instrument. > > > > Although auditory warning from AoA devices is good, the stall is the > > greatest risk for death at takeoff and landing phase of flight. The > > warning should not be subtle and should use several modalities. I look > > forward to your comments. > > > > Jim Foerster > > > > < > > ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re: Rotorway Massive Failure
Who know's, that might have been me :) The Rotorway electrical failure is rare, but I suppose not unexpected due to the rather random design of it's electrical system. One of the problems with the wiring harness Rotorway provides is the sheer number of molex connectors. Every thing is wired through at least one, some have two or more in the circuit. The Fadecs have a complicated factory supplied wiring harness that's integrated into the ship wiring. The alternator feed is provided by two different size wires, one to the battery and another up to the overhead switch panel. Why they did it that way is unknown. Each of the alternator feeds has a (RW supplied) fuse inline at the alternator. I bought the upgrade to a 51 amp alternator but think the fuses were designed for the smaller 30 amp one. I need to check this. The battery feed goes to the overhead switch panel. Some of the changes I've made: There were only 7 fuses in the entire ship which I've now expanded to 15 c/b's. I have added a main battery/alternator breaker and a bus bar that connects all the Fadecs, Fuel Pumps and Ignition modules. All nonessential systems (lights, strobes, radios) are on separate busses with individual c/b's. I added your OV module to my alternator switch and breaker but haven't tested it as I am only now preparing for my first start. The only way I see a total electrical failure on my ship is to blow the main battery breaker (50 amp) or a battery contactor failure. If the contactor failed while the engine was running I'd still have alternator output to the bus. I'd like to further isolate the essential bus and have a backup electrical source, but weight is a major factor for not having a second battery. The fadec is very sophisticated, and automatically switchs to a backup, but both need 10 volts minimum to function, or they shut down and the engine dies. Any suggestions would be appreciated. Vince Ackerman (Contactor and wiring schematic sent to Bob via USPS on Friday) On Friday, October 10, 2003, at 11:13 AM, Robert L. Nuckolls, III wrote: > >> him a long time ago). > > I seem to recall having a conversation about this airplane > some years ago. I can't recall if it was a builder or a factory > rep. I might even still have the drawings in a file somewhere. > As I recall, the conversation didn't go very far . . . after > the first few exchanges of questions and recommendations, the > guy at the other end of the conversation didn't like what > he was hearing and quit participating . . . > > Let's revisit the system here on the List . . . > > Bob . . . ________________________________________________________________________________
Date: Oct 11, 2003
I've flown many aircraft types that were fitted with stick shakers, and they can be a very useful way to provide stall warning. A well designed stick shaker is better than aural stall warning because other noises won't interfere with it. And it is much better than a visual only display because you don't need to be looking at it to receive the warning. I'm not sure exactly what frequency the stick shakers I'm familiar with work on, but I suspect it is somewhere in the 10-20 hz range. You need to pick a frequency that cannot be confused with any natural buffet that your aircraft might have in some parts of the flight envelope. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ > >I know of no stick shaker on any military plane I flew or heard of. >I wouldn't want >one on a plane of mine. Seems a stick shaker would have to be >driven by AoA, so why >not just display/sound off Alpha? >Seems to me a stick shaker would be more bother than help ... Jim S. > >James Foerster wrote: > >> >> >> Friends, >> >> I'm building a 4 place Jabiru, and this has a central control stick. I >> am considering the addition of a stick-shaker as used by military and >> commercial planes. A model airplane motor, run at the "appropriate" >> speed and driving an eccentric weight should work. The tiny pager >> motors available on the surplus market are too small to be useful in a >> vibrating plane, however. >> >> Could you professional pilots give me an idea as to how far the stick >> moves, and at roughly what frequency? I suspect that 8-20 Hz would be >> optimum, based on no real data. Its hard to guess the motion needed as >> this will be frequency dependent. >> >> I would drive this motor from either a microswitch attached to a vane >> projecting out from the leading edge of the wing, as is used by many >> commercial planes with an electric stall warning device, or else drive >> it from an angle of attack instrument. >> >> Although auditory warning from AoA devices is good, the stall is the >> greatest risk for death at takeoff and landing phase of flight. The >> warning should not be subtle and should use several modalities. I look >> forward to your comments. >> >> Jim Foerster >> > > < ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re: (no subject)
-------------------------------1065891852 Go to and download. Outstanding value! Kenneth Melvin, N51KX -------------------------------1065891852 tutf-8"> Go to aeroelectric.com and download. Outstanding value! Kenneth Melvin, N51KX -------------------------------1065891852-- ________________________________________________________________________________
Subject: RE: AeroElectric Connection
Date: Oct 11, 2003
Glad to help. The URL for Bob's business is http://www.aeroelectric.com/ and the specific link to the book is at http://www.aeroelectric.com/Catalog/pub/pub.html with a page to buy the book at http://www.aeroelectric.com/Catalog/AECcatalog.html (where you need to scroll down almost to the bottom of the page to find the "Publications" item - both a printed version and CD-ROM version are for sale there. By browsing around at the site you may find enough information on-line to make it unnecessary to actually buy the book. However, I still recommend the book, because he explains what can best be described as his "philosophy" of aircraft electrical systems, and I think it is important to know why we do things a certain way. Best regards, Rob Housman Europa XS Tri-Gear A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Tore S. Bristol Subject: Hi! I understand there is something called Bobs Aerolectric book? If so where can I buy it? I live in Norway but I also have an adress in Florida, so I could pick it up there. Regards Tore S Bristol Forewer (it seems ) builder of a FEW TF 51 ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Duplicates and Extra HTML in List Messages Solved!!!
aeroelectric-list(at)matronics.com, yak-list(at)matronics.com Dear Listers, Well, I apologize. I discovered today why the extra HTML tags and odd repeating of messages was occuring. About 1-2 weeks ago I was troubleshooting a different problem and had commented out the section in the incoming message filter that strips out MIME enclosures and other HTML data. Duh, then I forgot to put it back! Other filters were stripping out a good deal of the stuff, but still some stuff was getting through! I've reinstated the MIME filter and things should be back to normal as of about 11am pdt on Saturday. Again, my apologies!!! Best regards, Matt Dralle List Admin. -- Matt G. Dralle | Matronics | P.O. Box 347 | Livermore | CA | 94551 925-606-1001 Voice | 925-606-6281 FAX | dralle(at)matronics.com Email http://www.matronics.com/ W.W.W. | Featuring Products For Aircraft ________________________________________________________________________________
Subject: Re:
Date: Oct 11, 2003
by the way, you'll need a 3-ring binder for it. They are commonly available in the US, I think in Europe you'll only find 2 or 4 ring binders. ----- Original Message ----- From: "Tore S. Bristol" <tf51(at)c2i.net> > > > Hi! > I understand there is something called Bobs Aerolectric book? > If so where can I buy it? > I live in Norway but I also have an adress in Florida, so I could pick it up > there. > > Regards > Tore S Bristol > Forewer (it seems ) builder of a > FEW TF 51 > > ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re: noise in headset when transmitting
> >In my aircraft, when I transmit on my comm radio, I hear a loud squeal in >my headset. The avionics shop said it's due to the close proximity of the >antenna to my headset, and the wire that goes across from one side of the >headset to the other picks up the signal. The airplane is all wood, and >the antenna is behind the back seat, inside the fuselage. >Is there anything that can be done to get rid of this annoying noise? First you need to confirm whether or not the avionics shop's off-hand diagnosis is correct. To do this, you need to have a way to "transmit" without actually radiating any signal into the air close to your headset. One way is to build a temporary antenna on a stand made of wood with 25' or so of coax on it so that you can plug it into your radio but locate it some distance away from the potential victim (in this case - the headset). Another way is to fabricate a "dummy load" like that shown in: http://www.aeroelectric.com/Pictures/DummyLoad.jpg Unhook your antenna coax and put this guy on instead. You won't be able to hear or talk very far on your radio . . . a hand-held with a rubber duck on it will talk and listen to the radio but the tower across the field and other airplanes in the vicinity won't hear you. See if the noise goes away while transmitting on the remote antenna or dummy load. What kind of headsets do you have. Are they noise cancelling and have some associated electronics unique to the headsets? Bob . . . ________________________________________________________________________________
Date: Oct 11, 2003
In a message dated 10/11/2003 8:49:20 AM Mountain Daylight Time, khorton01(at)rogers.com writes: > > I've flown many aircraft types that were fitted with stick shakers, > and they can be a very useful way to provide stall warning. A well > designed stick shaker is better than aural stall warning because > other noises won't interfere with it. And it is much better than a > visual only display because you don't need to be looking at it to > receive the warning. > If you guys really need a stick shaker to warn ya of a stall I suggest you probably should quit flying. Geez ......... ________________________________________________________________________________
Date: Oct 11, 2003
In a message dated 10/11/03 5:32:58 PM Central Daylight Time, Benford2(at)aol.com writes: If you guys really need a stick shaker to warn ya of a stall I suggest you probably should quit flying. Geez ......... Good Afternoon Benford2, While you may not want a stick shaker on your airplane, there are many airplanes where the stick shaker has been shown to be helpful, possibly even critical, in advising the pilot of a situation that could become dangerous. There are many airplanes that are beyond the point of reasonable recovery technique by the time any aerodynamic buffet occurs. The Boeing 727 is one such airplane. While I doubt that very many homebuilt aircraft will have stall characteristics similar to those of a 727, there may well be aircraft where the stick shaker does aid the pilot in stall recognition. I think you are being very shallow when you unequivocally tell people that they should NOT be flying if they want a stall warning device on their airplane. The whole idea of the movement is that we should be able to build that which best fits our individual purposes. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator ________________________________________________________________________________
Date: Oct 11, 2003
In a message dated 10/11/2003 4:47:22 PM Mountain Daylight Time, BobsV35B(at)aol.com writes: > > The Boeing 727 is one such airplane. While I doubt that very many homebuilt > > aircraft will have stall characteristics similar to those of a 727, there > may > well be aircraft where the stick shaker does aid the pilot in stall > recognition. > > I think you are being very shallow when you unequivocally tell people that > they should NOT be flying if they want a stall warning device on their > airplane. > > The whole idea of the movement is that we should be able to build that which > > best fits our individual purposes. > > Happy Skies, > > Old Bob > I respect your comments, but if a pilot does not recogonize lazy control imputs and lets the wings stall they need to practice more on slow flight. I am sure some aircrafts are sensitive to stalls and the 72 is one of them but evey time I have ever heard of stick shaker going off it is on the cockpit voice recorder the NTSB plays a few days after a pilot kills himself and all the others on board. In all my years of flying the ONLY time I have ever heard the stall warning buzzer go off was during BFR's doing stalls. Tell me Ol Bob. in what situations have the stick shaker helped you out on your flying skills?? This is how I feel so please respect me for my comments. Peace.... Ben Haas N801BH. Jackson Hole Wy. ________________________________________________________________________________
Date: Oct 11, 2003
In a message dated 10/11/03 6:36:53 PM Central Daylight Time, Benford2(at)aol.com writes: This is how I feel so please respect me for my comments. Peace.... Good Evening Ben, I do respect your feelings as to how you want your airplane equipped, I just don't feel you have the right to suggest that those who feel otherwise have no right to fly. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator PS I don't believe I have ever been "saved" by a stick shaker, but it has never hurt me either! ________________________________________________________________________________
Date: Oct 11, 2003
From: Charlie & Tupper England <cengland(at)netdoor.com>
Subject: Slobovia Outernational Airport Party Invitation
Hello all, Please remember your invitation to our party one week from today at Slobovia Outernational, just north of Jackson MS. You are all cordially invited to the next flyin lunch/supper/all-weekend-long hangar party at Slobovia Outernational Airport, 10 miles north of Jackson MS on October 17-19, 2003. If flying fun isn't enough reason to party, it's wedding anniversary time for two families here, so come & help us celebrate. Overnighters are welcome any time after noon on Friday, and are welcome to stay through Sunday. Bring your bed roll and if desired, a tent. We have lots of indoor floor space & even more outdoor tent space, so come on down! We had a great turnout in July with about 45 planes. We are hoping for at least twice that number in October. The noon meal on Saturday will again be 'pulled pork', thanks to the wonderful wives here in our strange corner of the universe. If you can stay for the hangar party Saturday night, we plan on having 'Chili & Blues' with a live band for entertainment. Bring your dancin' shoes. You can get info about our airport at airnav.com http://www.airnav.com/airport/MS71 Update: runway length is now 4800 feet. Disclaimer: Slobovia is a private airport. Pilots operate at their own risk. If you need driving directions or more info, feel free to email me at cengland(at)netdoor.com or call at 601-879-9596. FAA Identifier: MS71 Lat/Long: 32-29-42.508N / 090-17-34.325W 32-29.70847N / 090-17.57208W 32.4951411 / -90.2928681 (estimated) Elevation: 250 ft. / 76 m (estimated) Variation: 03E (1985) From city: 1 mile N of POCAHONTAS, MS Airport Operations Airport use: Private use. Permission required prior to landing Sectional chart: MEMPHIS UNICOM: 122.75 Runway Information Runway 15/33 Dimensions: 3540 x 80 ft. / 1079 x 24 m Surface: turf RUNWAY 15 RUNWAY 33 Traffic pattern: left left Obstructions: 70 ft. trees, 200 ft. from approach end of 33 ________________________________________________________________________________
Date: Oct 11, 2003
Benford2(at)aol.com wrote: > >In a message dated 10/11/2003 8:49:20 AM Mountain Daylight Time, >khorton01(at)rogers.com writes: > > > > >>I've flown many aircraft types that were fitted with stick shakers, >>and they can be a very useful way to provide stall warning. A well >>designed stick shaker is better than aural stall warning because >>other noises won't interfere with it. And it is much better than a >>visual only display because you don't need to be looking at it to >>receive the warning. >> >> >> > >If you guys really need a stick shaker to warn ya of a stall I suggest you >probably should quit flying. Geez ......... > hmmmm.... wonder if there are any airline or military pilots on this list...... ________________________________________________________________________________
Date: Oct 11, 2003
Subject: Re: T-2000 connect
> >Can anyone please confirm that the Microair T-2000 is NOT a "strobe" >type transponder and that I therefore connect the pink wire (strobe) >from my AK-350 encoder to ground? Couldn't find anything in the >archives & just wanting to be sure! > >Thanks! That is correct. See http://www.aeroelectric.com/Installation_Data/T2000-ACK350_Wiring.pdf Bob . . . ________________________________________________________________________________
Date: Oct 11, 2003
> >In a message dated 10/11/2003 5:51:43 PM Mountain Daylight Time, >BobsV35B(at)aol.com writes: > > > > Evening Ben, > > > > I do respect your feelings as to how you want your airplane equipped, I > just > > > > don't feel you have the right to suggest that those who feel otherwise > have > > no > > right to fly. > > > > Happy Skies, > > > >I see your point and I retract the comment. My main concern is that someone >fabricates a stick shaker to warn them they forgot to look at the airspeed >indicator and it jams up the controls and kills them. Anything connected to a >flight control should be bulletproof and most homebrewed stick shakers " >could" >hurt someone. This is the case of the medicine that is worse then the >disease.. And this is coming from a Zenith 801 builder who is a few hours >away from >flying a experimental with a V-8 Ford where a Lycosarus is supposed to go. I >might need some therapy too.... > >It is time for an adult beverage, hot tub and NASCAR on the tube. Life is >good in the Hole. The Lears have stick shakers, and several if not all of the Raytheon jets have them too. They're simple motors bolted to the back of the control column with eccentric flyweights. The Lears have two levels of stick shaking intensity controlled by voltage applied to the motor. They're activated at setpoints in the AOA indicator system. Stall warning sensors that drive lights and horns in GA SE aircraft could be adapted to activate a stick shaker as well. You could add one to the stick of an OBAM aircraft with very little risk to the control system since it simply "rides" on the stick and has no ability to inject or inhibit control forces. You're looking for something on the order of 5-10Hz for the "shake" frequency or 300 to 600 rpm. Most ungeared hobby motors run in the thousands of rpms and would require some voltage adjustment scheme for setting the desired rate/intensity. Theres a geared motor rated at 300 rpm at 12v with an operating range of 6-24. Specs are found at: http://www.jameco.com/jameco/Products/ProdDS/164785.pdf and the critters sell for about $24 I'm a little mystified about the concern. A stall warning tone injected into the audio system is much easier to do. After doing the obligatory stall demonstrations for the flight instructors at biennial time, I'm always amazed that anyone can get themselves into that condition "accidently". None the less, if a stick shaker is desired, it's not only possible but not terribly hard to do either. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2003
In a message dated 10/11/2003 9:07:08 PM Mountain Daylight Time, bob.nuckolls(at)cox.net writes: > > They're activated at setpoints in the AOA indicator system. > Stall warning sensors that drive lights and horns in GA SE > aircraft could be adapted to activate a stick shaker as well. > You could add one to the stick of an OBAM aircraft > with very little risk to the control system since it simply > "rides" on the stick and has no ability to inject or inhibit > control forces. > > You're looking for something on the order of 5-10Hz for the "shake" > frequency or 300 to 600 rpm. Most ungeared hobby motors run in > the thousands of rpms and would require some voltage adjustment > scheme for setting the desired rate/intensity. > > This sounds very safe then. You still would have to couple the homemade smart box to the AOA . I agree with Bob, the tone thing is the simple way to go.But, we are building experimentals so all is fair. ________________________________________________________________________________
Date: Oct 11, 2003
Bob wrote, "I'm a little mystified about the concern. A stall warning tone injected into the audio system is much easier to do." Bob, it's a good question. My plane is a canvas for my ideas--oops, just came back from a chick-flick my wife wanted to see. I mean my plane is a flying test bed, and the stick-shaker may improve safety because it works without the headset on, it uses a sensory input that is hard to ignore, and the greatest threat to me is landing in the low and slow configuration. Why not just watch the AoA indicator? Well, my eyes are mainly out of the cockpit when landing, looking for traffic and my position in the pattern. Making that turn from downwind to base to final after a long flight to an unfamiliar airport can get me banked more than I might like. Add some wind shear, and traffic distraction, and the shaker might be worth it if it went off once in ten years. I agree that the audio warning might be enough, and that is why I've asked for the opinions of pilots with more experience than mine for their thoughts: is this worth doing? If audio stall warning were good enough, why would both commercial and military planes have it? Figured it was worth some thought, anyway. Ben Ford is correct about not jeopardizing the control system with add-ons. I would add this device at the top of the stick, mounted on two standoffs, looking like a large trigger guard. Jim Foerster ________________________________________________________________________________
Date: Oct 12, 2003
Subject: RE:Stick-shaker for stall warning
Motors? Eccentrics? We are electro-whizzies ;-) How about a ball bearing in a non-ferrous tube with a coil at each end? Drive the coils with a multivibrator ckt to rattle the ball back and forth. I'm afraid this isn't my brilliance. About 25 years ago I worked with a guy that had a patent to do this. He had gotten a job offer from an airplane outfit for a lot of money. He was certain the offer stemmed from them wanting his patent. I don't remember him describing it other than "rattling a steel ball with an electromagnet". Concept is simple - an Al tube with a coil in a plastic bobbin on each end - maybe a steel slug glued in the tube under each bobbin - appropriate sized ball bearing in the center. I don't know if his idea ever went anywhere. carl ***************************** Subject: AeroElectric-List: Stick-shaker for stall warning Friends, I'm building a 4 place Jabiru, and this has a central control stick. I am considering the addition of a stick-shaker as used by military and commercial planes. A model airplane motor, run at the "appropriate" speed and driving an eccentric weight should work. ________________________________________________________________________________
Date: Oct 12, 2003
Jim, How about Piper's elegant solution -- a large round light on the panel next to the airspeed indicator. It sounds facile to make such a trivial suggestion, but it works wonderfully well and couldn't be any less expensive to make. A 1/2" round red light is surprisingly noticeable. It seems as though you would never see it, but it really does light up well. On the PA28 I fly, it's tucked under the coaming (is that how it's spelt?), and so is in shade, which helps its visibility, I suppose. Even on a summer's day it sticks out like a sore thumb. I've gone with the same indicator on my project. Hope this helps. Nev -- Jodel D150 in progress UK ----- Original Message ----- From: "James Foerster" <jmfpublic(at)comcast.net> Subject: AeroElectric-List: Re: Stick-shaker for stall warning > Bob, it's a good question. My plane is a canvas for my ideas--oops, just came back from a chick-flick my wife wanted to see. I mean my plane is a flying test bed, and the stick-shaker may improve safety because it works without the headset on, it uses a sensory input that is hard to ignore, and the greatest threat to me is landing in the low and slow configuration. Why not just watch the AoA indicator? Well, my eyes are mainly out of the cockpit when landing, looking for traffic and my position in the pattern. Making that turn from downwind to base to final after a long flight to an unfamiliar airport can get me banked more than I might like. Add some wind shear, and traffic distraction, and the shaker might be worth it if it went off once in ten years. I agree that the audio warning might be enough, and that is why I've asked for the opinions of pilots with more experience than mine for their thoughts: is this worth doing? If audio stall warning were good enough, ! > why would both commercial and military planes have it? Figured it was worth some thought, anyway. > ________________________________________________________________________________
Date: Oct 12, 2003
I think you're right to install an audio stall warning driven by an accurate, reliable AoA. Like I said before, I don't know of any tactical military planes who have it. It contradicts the mission of tactical jets (back in my day) since critical parts of the mission were done at high AoA, on the fringes of buffet. The F-104 might well have had a stick shaker if, as I heard, it suffered from sudden departure into an unrecoverable flat spin, but that's an exception. An audio warning that would keep you away from the ubiquitous "approach turn stall" would be a very reasonable safety device. I think a stick shaker is a bit much. Accurate and Reliable AoA being the key words here .... Jim S. James Foerster wrote: > ________________________________________________________________________________
Date: Oct 12, 2003
Subject: Re: RE:Stick-shaker for stall warning
<... a ball bearing in a nonferrous tube ...> How about a little horn, available at the shack (or perhaps even Wal-Mart) for about ten bucks. Then we could get back to addressing actual problems ... Jim S. Carl Coulter wrote: > > Motors? Eccentrics? We are electro-whizzies ;-) > u > How about a ball bearing in a non-ferros tube with a coil at each end? > Drive the coils with a multivibrator ckt to rattle the ball back and forth. > ________________________________________________________________________________
Date: Oct 12, 2003
Ben, Didn't you ever have wind shear training? The stick shaker was invaluable in flying the max lift profile in a downburst or wind shear scenario. Fortunately I never had the opportunity to put that training to use. Joel Harding On Saturday, Oct 11, 2003, at 17:35 America/Denver, Benford2(at)aol.com wrote: > >> > I respect your comments, but > if a pilot does not recogonize lazy control imputs and lets the wings > stall > they need to practice more on slow flight. I am sure some aircrafts are > sensitive to stalls and the 72 is one of them but evey time I have > ever heard of > stick shaker going off it is on the cockpit voice recorder the NTSB > plays a few > days after a pilot kills himself and all the others on board. In all > my years > of flying the ONLY time I have ever heard the stall warning buzzer go > off was > during BFR's doing stalls. Tell me Ol Bob. in what situations have the > stick > shaker helped you out on your flying skills?? This is how I feel so > please > respect me for my comments. Peace.... > > Ben Haas N801BH. Jackson Hole Wy. > > > _- > ======================================================================= > _- > ======================================================================= > http://www.matronics.com/trouble-report > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Oct 12, 2003
In a message dated 10/12/2003 9:09:33 AM Mountain Daylight Time, cajole76(at)ispwest.com writes: > > Ben, > Didn't you ever have wind shear training? The stick shaker was > invaluable in flying the max lift profile in a downburst or wind shear > scenario. Fortunately I never had the opportunity to put that training > to use. > > Joel Harding > > My wind shear training consisted of recognizing the potential of wind shear, keep one hand on the throttle, one on the yoke to push forward and one big eye on the air speed indicator. All stick shakers,AOA's and other devices get their imput from air speed or air speed differential from the top of the wing to the bottom of it. My point is simply. why have a series of devices to monitor a symptom when the human brain can do it much faster from the initial problem when recognized properly. This whole topic keeps my mind flashing back to that Airbus that was doing a low pass in France showing off its GREAT fly by wire, everything is automatic, who the hell needs a pilot, this bells and whistles plane can do it all attitude. If I remember it correctly, that thing settled down in trees at the end of the runway with two of the MOST capable pilots unable to do a damn thing to stop it. My best training was when my instructor covered up the airspeed indicator and told me to feel out the control imputs and see how lazy they get with slower air flowing over them. To this day I can fly the plane without looking at the ASI and guestimate within 3--5 knots of indicated by just the feel of the planes controls. The human mind is a wonderful thing ya know... Faster then the best warning devices to date. As soon as a pilot starts depending on bells and whistles instead of common sense there will probably be an accident. Ben Haas. ________________________________________________________________________________
Date: Oct 12, 2003
> > >Bob wrote, >"I'm a little mystified about the concern. A stall warning > tone injected into the audio system is much easier to do." > >Bob, it's a good question. My plane is a canvas for my ideas--oops, just >came back from a chick-flick my wife wanted to see. I mean my plane is a >flying test bed, and the stick-shaker may improve safety because it works >without the headset on, it uses a sensory input that is hard to ignore, >and the greatest threat to me is landing in the low and slow >configuration. Why not just watch the AoA indicator? Well, my eyes are >mainly out of the cockpit when landing, looking for traffic and my >position in the pattern. Making that turn from downwind to base to final >after a long flight to an unfamiliar airport can get me banked more than I >might like. Add some wind shear, and traffic distraction, and the shaker >might be worth it if it went off once in ten years. I agree that >the audio warning might be enough, and that is why I've asked for the >opinions of pilots with more experience than mine for their thoughts: is >this worth doing? If audio stall warning were good enough, ! >why would both commercial and military planes have it? Figured it was >worth some thought, anyway. Sure . . . but let's consider the airplane characteristics that drive such requirements. First, how does the airplane behave at the edge of stall? Some aircraft I've flown do quite a bit of their own shaking. Other's didn't have enough up-elevator authority to push AOA past stall. Still others had such pronounced pitch-up deck-angles as to make one wonder why the airplane didn't break long ago. Some airplanes would break easy, mush nose-nose down and then recover only to break again . . . loosing altitude slowly in something akin to an aquarium performance of a porpoise. The airplanes that get the system designers attention are those that break quickly and/or are delicately roll-balanced and are likely to sneak up on the unwary pilot in vicious ways. How does your airplane behave? Do you plan to do a lot of low-altitude slow flight (like pipeline or power line patrol)? Do you plan to operate out of short and/or obstructed fields where max performance takeoff and landing techniques will be routinely employed? If any of these answers drive you toward a decision for extra-ordinary stall warning systems, perhaps your airplane is a good candidate for a true AOA indicator systems and any attendant warnings it might provide. I can't remember the last time I heard the stall warning go off on any airplane I've rented recently . . . and certainly if it did, it was in the flare a few feet above the runway. For the kinds of airplanes I have access to and the way I use them, I consider a stall warning system completely unnecessary. If I found a stall warning system to be inoperative at pre-flight, I would not cancel the flight. Irrespective of the range of comments, suggestions and opinions presented on this topic over the past few days, it's a combination of performance of your airplane combined with your skills in the operating environment that you plan to work that drive the considered decision and elegant solution. I would suggest that your airplane has few performance characteristics in common with air transport or fighter aircraft. If the designer was doing his job, benign handling characteristics in slow flight was a goal. I'd suggest you get the airplane flying, and during the 40-hours of obligatory fly-off, go find out how your airplane behaves at 3000 feet. If it scares the socks off you at altitude, then the exercise of plan-B is very much in order. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2003
> >I think you're right to install an audio stall warning driven by an >accurate, reliable AoA. Like I said before, I don't know of any >tactical military planes who have it. It contradicts the mission of >tactical jets (back in my day) since critical parts of the mission >were done at high AoA, on the fringes of buffet. The F-104 might >well have had a stick shaker if, as I heard, it suffered from sudden >departure into an unrecoverable flat spin, but that's an exception. >An audio warning that would keep you away from the ubiquitous >"approach turn stall" would be a very reasonable safety device. I >think a stick shaker is a bit much. >Accurate and Reliable AoA being the key words here .... Jim S. > Tactical military jets have a very different set of mission requirements than most homebuilts. And the pilots have much more training than many general aviation pilots, and they fly more hours per year in their aircraft than many general aviation pilots do. So I'm not sure we should use tactical military jets as a yardstick to see whether a stick shaker makes sense in a homebuilt aircraft. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Oct 12, 2003
Subject: Re: Alternator Noise in Headset
>Bob, > > I've posted this meesage twice to the Aeroelectric Matronics list, and > I see it there, but haven't seen any response. Not that I've earned your > immediate jump-when-I-say-jump response by any means, but seeing how you > quickly respond to others makes me wonder if you're seeing this. Or do I > owe you money? > Please respond either to the list or offline to me at > pedroagua(at)aol.com if you get this. > >Thanks, >Pete Waters >(in Watsonville in November) No, you don't owe me money. My time to work the AeroElectric-List comes in variable sized pieces. Some replies can be generated in less than a minute, others take some time to consider and craft a reply. In order NOT to fall hopelessly behind, I always start with the most recent posts and work my way backwards in time. Your question was lengthy and needed some time to consider, hence on a nice, quiet Sunday morning, I've got a chunk of time sufficient to the task . . . >Bob, > > Apologies if this is a duplicate post; I seem to have trouble getting > this out. > I'm starting to develop an electrical problem in my RV-4 and I'm hoping > you can help me diagnose it. > I bought the RV-4 (completed) last year. It was built in 1988 and I'm > the fourth owner. It's a solid airplane, but the documentation is thin > and from the logbooks it appears that the electrical stuff (lights, > radios) were added piecemeal over the plane's first few years, so the > electrical system is a bit tangled. For example, my nav light circuit > breaker kept popping. I finally figured out that the builder / modifier > has three 2-amp bulbs (6 amps) going through a 5-amp CB. So, after > consulting the wire selection graph, I replaced the 5A CB with a 10A > CB. Worked great. > However, on my next flight, I started hearing a whine in my > headset. More of a high-pitched tone, actually. I realized that it was > a solid tone that was being cut off intermittently, making it sounding a > lot like Morse from an VOR. As I returned from a cross country it got > louder and became almost constant. The whine / tone is present with the > radios off, strobes off, and alternator off, although I didn't think to > pull the breakers on those circuits. Pulling the breakers would probably not have made any difference. Turning the systems off with the panel mounted controls is sufficient. > I don't hear it on deck with all the avionics running off the RG > battery. Inflight I can hear it in the background during intercom use > and radio reception. It disappears briefly after a radio transmission and > then returns after a few seconds. The plane has a VDO analog voltmeter, > no ammeter. ( I plan to install an VA-1A EI volt/ammeter shortly.) As > I heard the tone inflight I immediately noticed that the voltage was > increasing to about 15.5 V and fluctuating there for a while. Then it > settled down to 14.5 V or so. The > problem comes and goes and is not entirely repeatable. The voltmeter > reads 14.0 volts on deck with just the battery on and the engine not > running (no alternator), so I think the VDO voltmeter is accurate. Battery only operations seldom exceed 13.0 volts. Most RG batteries have an open circuit voltage of 12.9 volts at room temperature. If your voltmeter is saying "14.0", then it's off by at least 1.0 volt. > Also, perhaps related and perhaps not, the LORAN started telling me a > few weeks back, before I heard any of this headset noise, that I was in > the Southern Hemisphere when I was flying across Oregon. I had thought > the LORAN had just died due to age, and I was buying a GPS anyway, so > I've just turned it off and planned to remove it. Okay. > Initially I was thinking the obvious thought that the alternator's > going. After reading the Aeroelectric Connnetion I'm wondering if it > might not be the voltage regulator. Because the plane has so little > documentation, I don't know the specifics of the alternator at all or how > old it is, just that it's been working well so far. My A&P found nothing > wrong with it at the last annual 60 hours ago. I'm wondering if the > impending alternator / regulator failure is putting out RF that's getting > into the headset and was jamming the LORAN. (It turns out that the LORAN > had locked onto the wrong nav solution -- that whole "two solutions to > the quadratic equation" thing. Letting it sit on deck for a few minutes > with the engine off allowed it to "find itself" correctly back in > California. But I'm still wondering if the initial event of it getting > lost wasn't related to LORAN signal jamming >from the alternator / regulator.) If the noise is present with the alternator OFF, then I don't see how this system can be involved. Does the tone vary in pitch with engine rpm . . . alternator generated noises do vary in pitch with rpm and they go away when the alternator is turned off. > Also, I noticed in flight that with the electrical system fully loaded > up, the voltmeter needle also starts rapidly fluctuating at > 14.5-15.5V. I see this when I turn on the landing light. Due to the > lack of documentation I have no idea how many total amps are actually > flowing through the system, so I'm wondering if turning on the landing > lights actually >puts the plane's total current draw above the rated output of the >alternator. Is fluctuating system voltage a sign of that? No, it's more likely a separate problem, here's a post I did on this topic a few weeks ago: ------------------------------------------------------ >I felt pretty certain that if you recommended hooking the regulator right >to the back of the alternator, and then followed the appropriate >connection you knew things would settle down nicely. Well, they did just >that! The ammeter was rock steady to the charging side, and the voltage >read a solid 14.4 >Now the follow up to get these same results once the voltage regulator is >reinstalled, and not hanging off the alternator. The other thing I noted >was that when hooked up in this manner the alternator side of the split >master was not working, but I'm sure you knew that would happen. > >Let me know what's next, and thanks! Okay, this experiment was important to tell us that the components were okay and that you didn't have a flaky regulator or bouncing brushes in the alternator. I'd start at the bus (did I ask whether you're using fuseblocks or breakers?) and check to see that you have good terminals, at least 20AWG wire all the way to the regulator's "A/S" terminals. If the regulator is mounted on the firewall, grounding isn't an issue for the regulator . . . and seldom does grounding affect stability . . . only voltage setting. Also, you mentioned that the "alternator side of the split master was not working" . . . I'd bet that MOST of your circuit resistance is happening in that switch. I have a plastic bag full of perfectly good looking split-rocker switches that were sent to me after putting in a new one cured a bouncy ammeter complaint. This has occurred in countless certified ships and a few OBAM aircraft. This doesn't mean that the split-rocker is necessarily a "bad" product (it's made by Carling and uses the same guts as the S700 series toggle switches B&C sells). Regulators are sensitive to small amounts of resistance in the lines between bus and regulator. I had one builder who mounted his regulator within a few inches of the bus, tied the A/S terminals directly to the breaker with short, single, solid wire and put his alternator control switch in series with the field wire. He added crowbar ov protection to the breaker and ended up with a combination that would probably be stable over the lifetime of the airplane. In older production Cessnas, I think I counted 20 some odd crimps, connections and spring-pressure maintained metal-metal contacts between bus and regulator. As all of these joints age, they add resistance to the circuit. At some point in time, the system becomes unstable with symptoms you have observed. Thousands of spam-can owners have paid out $millions$ to ignorant mechanics who replaced EVERYTHING BUT aged/compromised wiring before finally renewing the bus-to-regulator components. In many cases, owners have reported that replacing only the spilt-rocker "fixed" the problem. Indeed this single component can be a major contributor of total loop resistance. But consider that if NEW loop resistance was on the order of 50 milliohms and had climbed to 100 milliohms with the switch contributing 25 ohms of de-stabilizing resistance. Replacing the switch drops total down to 75 milliohms and the regulator is happy again . . . but not for as long as it would be when replacing ALL sources of age/service related resistance in the bus-to-regulator pathway. The obvious, elegant solution in original design is to incorporate a regulator that separates voltage sense wires from field current supply wires. The LR-3 does just that. Any new regulators I design will have separate sense wires too. Does this suggest that the OBAM community should rip out all their three-terminal switchers and bolt on the LR-3? Not at all. The automotive style regulators have for the most part given good value but they DO have special characteristics that only one mechanic in 1000 understands. In the spam-can world, ignorance is shoveled out at $thousands$ per non-idea, in the OBAM aircraft world, we've managed to keep those costs MUCH lower . . . and much of it happens right here on the AeroElectric List. > This airplane is well-built structurally and the engine's in good > shape, but the more I look at the electrical system, the more I relaize > that it's not quite what I'd like to see. Since avionics and lights were > added piecemeal over the years by different people, I wouldn't be > surprised to see as basic a mistake as an undercapacity > alternator. (Remember the undercapacity CB I found.) The largest Full-Up IFR load I've calculated for an SE airplane with vacuum system is 27A, with electric gyros it was 31A. It is unlikely that your alternator is undersized. If the noise were present with the alternator ON, varies pitch with rpm and goes away alternator OFF, it might be that onset of the noise was due to failure of a diode in the alternator which would produce a combination of (1) reduced alternator capacity and (2) greatly increased noise on the bus. However, since I think we're talking about relatively fixed pitch noise with alternator OFF, this isn't root cause of the noise. > Lastly, I'm also noting that the whine showed up within two flight > hours of my replacing the nav lights circuit breaker. Although I can't > imagine why that would have an effect, I also should mention that the > circuit breaker panel is homemade and possibly not well > shielded; perhaps in the course of working with the panel to swap out > the breaker I changed something. > If you could offer any thoughts on this, I'd appreciate it. First impressions are that this system may be suffering from a variety of small illnesses common to electrical system architectures used in most spam cans. These problems can be made worse by marginal craftsmanship of the neophyte builder and ignorant mechanic. Just because you hear a noise in the headsets doesn't always mean that some antagonist has jumped up to torment the victim. It's not uncommon for a victim to have ailments that mimic externally generated noises. Do you hear the noise whether or not there is a radio transmission being received? I.e., heard in the intercom only with microphone and radio squelch gates closed? Is the intercom battery powered or powered from the bus? If battery powered, how about trying a new battery . . .some audio systems become squealers when the battery voltage drops and power source impedance goes up. >Best, >Pete Waters >(registered for your class in Watsonville) Great. See you in a few weeks! Given the range and magnitude of problems you've noted, it's not out of line to consider some major surgery to keep things like this from rising out of the mud in the future. We could use your airplane as a study topic at the Watsonville seminar. Bring all the drawings you have. Bob . . . ________________________________________________________________________________
Subject: Stick Shakers
Date: Oct 12, 2003
Nowadays in commercial jets we practice a lot of windshear recoveries. When ground contact is immanent we fly intermittent stick shaker to recover. The stick shaker comes on before a stall because these airplanes don't have such nice stall recoveries and there have been times when you need every bit of performance you can get. So we use the stick shaker every year in the simulator (stimulator) and hopefully never have it for real in the airplane. It does get your attention. Probably not necessary though in a light plane with more aerodynamic stall warning and docile stalls. But there have been a significant number of turn to final stalls that were not recovered from. My friend was killed like that 35 years ago. John 757,767,MD-11 etc. Long Ez, (That's the answer just get a canard!) ________________________________________________________________________________
Date: Oct 12, 2003
10/12/2003 12:58:10 PM >I'm not sure we should use tactical military jets as a yardstick to see whether a stick shaker makes sense in a homebuilt aircraft. I'm wondering if some people have missed the point here. I think it is a fact not worth debating that stall warning devices have saved lives, even if some pilots on this list are of such a high skill level as to not need them. The question had to do with how to make a stick-shaker. As a builder we get to make our own decision what we will ultimately use. Having said that here's my opinion. I think it sounds like a novel idea and would probably provide a suitable warning, but I will stick with an audible device. Craig S. 601 XL not quite half done. This e-mail message and all attachments transmitted with it from the Nuclear Generation Group of American Electric Power are for the sole use of the intended recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message. ________________________________________________________________________________
Date: Oct 12, 2003
"Robert L. Nuckolls, III" wrote: >Bob, > > I've posted this meesage twice to the Aeroelectric Matronics list, and > I see it there, but haven't seen any response. Not that I've earned your > immediate jump-when-I-say-jump response by any means, but seeing how you > quickly respond to others makes me wonder if you're seeing this. Or do I > owe you money? > Please respond either to the list or offline to me at > pedroagua(at)aol.com if you get this. > >Thanks, >Pete Waters >(in Watsonville in November) No, you don't owe me money. My time to work the AeroElectric-List comes in variable sized pieces. Some replies can be generated in less than a minute, others take some time to consider and craft a reply. In order NOT to fall hopelessly behind, I always start with the most recent posts and work my way backwards in time. Your question was lengthy and needed some time to consider, hence on a nice, quiet Sunday morning, I've got a chunk of time sufficient to the task . . . <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< You're a gentleman and a scholar and I apologize for my impatience. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >Bob, > > Apologies if this is a duplicate post; I seem to have trouble getting > this out. > I'm starting to develop an electrical problem in my RV-4 and I'm hoping > you can help me diagnose it. > I bought the RV-4 (completed) last year. It was built in 1988 and I'm > the fourth owner. It's a solid airplane, but the documentation is thin > and from the logbooks it appears that the electrical stuff (lights, > radios) were added piecemeal over the plane's first few years, so the > electrical system is a bit tangled. For example, my nav light circuit > breaker kept popping. I finally figured out that the builder / modifier > has three 2-amp bulbs (6 amps) going through a 5-amp CB. So, after > consulting the wire selection graph, I replaced the 5A CB with a 10A > CB. Worked great. > However, on my next flight, I started hearing a whine in my > headset. More of a high-pitched tone, actually. I realized that it was > a solid tone that was being cut off intermittently, making it sounding a > lot like Morse from an VOR. As I returned from a cross country it got > louder and became almost constant. The whine / tone is present with the > radios off, strobes off, and alternator off, although I didn't think to > pull the breakers on those circuits. Pulling the breakers would probably not have made any difference. Turning the systems off with the panel mounted controls is sufficient. > I don't hear it on deck with all the avionics running off the RG > battery. Inflight I can hear it in the background during intercom use > and radio reception. It disappears briefly after a radio transmission and > then returns after a few seconds. The plane has a VDO analog voltmeter, > no ammeter. ( I plan to install an VA-1A EI volt/ammeter shortly.) As > I heard the tone inflight I immediately noticed that the voltage was > increasing to about 15.5 V and fluctuating there for a while. Then it > settled down to 14.5 V or so. The > problem comes and goes and is not entirely repeatable. The voltmeter > reads 14.0 volts on deck with just the battery on and the engine not > running (no alternator), so I think the VDO voltmeter is accurate. Battery only operations seldom exceed 13.0 volts. Most RG batteries have an open circuit voltage of 12.9 volts at room temperature. If your voltmeter is saying "14.0", then it's off by at least 1.0 volt. > Also, perhaps related and perhaps not, the LORAN started telling me a > few weeks back, before I heard any of this headset noise, that I was in > the Southern Hemisphere when I was flying across Oregon. I had thought > the LORAN had just died due to age, and I was buying a GPS anyway, so > I've just turned it off and planned to remove it. Okay. > Initially I was thinking the obvious thought that the alternator's > going. After reading the Aeroelectric Connnetion I'm wondering if it > might not be the voltage regulator. Because the plane has so little > documentation, I don't know the specifics of the alternator at all or how > old it is, just that it's been working well so far. My A&P found nothing > wrong with it at the last annual 60 hours ago. I'm wondering if the > impending alternator / regulator failure is putting out RF that's getting > into the headset and was jamming the LORAN. (It turns out that the LORAN > had locked onto the wrong nav solution -- that whole "two solutions to > the quadratic equation" thing. Letting it sit on deck for a few minutes > with the engine off allowed it to "find itself" correctly back in > California. But I'm still wondering if the initial event of it getting > lost wasn't related to LORAN signal jamming >from the alternator / regulator.) If the noise is present with the alternator OFF, then I don't see how this system can be involved. Does the tone vary in pitch with engine rpm . . . alternator generated noises do vary in pitch with rpm and they go away when the alternator is turned off. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< I'll have to check that on the next flight. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> > Also, I noticed in flight that with the electrical system fully loaded > up, the voltmeter needle also starts rapidly fluctuating at > 14.5-15.5V. I see this when I turn on the landing light. Due to the > lack of documentation I have no idea how many total amps are actually > flowing through the system, so I'm wondering if turning on the landing > lights actually >puts the plane's total current draw above the rated output of the >alternator. Is fluctuating system voltage a sign of that? No, it's more likely a separate problem, here's a post I did on this topic a few weeks ago: ------------------------------------------------------ >I felt pretty certain that if you recommended hooking the regulator right >to the back of the alternator, and then followed the appropriate >connection you knew things would settle down nicely. Well, they did just >that! The ammeter was rock steady to the charging side, and the voltage >read a solid 14.4 >Now the follow up to get these same results once the voltage regulator is >reinstalled, and not hanging off the alternator. The other thing I noted >was that when hooked up in this manner the alternator side of the split >master was not working, but I'm sure you knew that would happen. > >Let me know what's next, and thanks! Okay, this experiment was important to tell us that the components were okay and that you didn't have a flaky regulator or bouncing brushes in the alternator. I'd start at the bus (did I ask whether you're using fuseblocks or breakers?) and check to see that you have good terminals, at least 20AWG wire all the way to the regulator's "A/S" terminals. If the regulator is mounted on the firewall, grounding isn't an issue for the regulator . . . and seldom does grounding affect stability . . . only voltage setting. Also, you mentioned that the "alternator side of the split master was not working" . . . I'd bet that MOST of your circuit resistance is happening in that switch. I have a plastic bag full of perfectly good looking split-rocker switches that were sent to me after putting in a new one cured a bouncy ammeter complaint. This has occurred in countless certified ships and a few OBAM aircraft. This doesn't mean that the split-rocker is necessarily a "bad" product (it's made by Carling and uses the same guts as the S700 series toggle switches B&C sells). Regulators are sensitive to small amounts of resistance in the lines between bus and regulator. I had one builder who mounted his regulator within a few inches of the bus, tied the A/S terminals directly to the breaker with short, single, solid wire and put his alternator control switch in series with the field wire. He added crowbar ov protection to the breaker and ended up with a combination that would probably be stable over the lifetime of the airplane. In older production Cessnas, I think I counted 20 some odd crimps, connections and spring-pressure maintained metal-metal contacts between bus and regulator. As all of these joints age, they add resistance to the circuit. At some point in time, the system becomes unstable with symptoms you have observed. Thousands of spam-can owners have paid out $millions$ to ignorant mechanics who replaced EVERYTHING BUT aged/compromised wiring before finally renewing the bus-to-regulator components. In many cases, owners have reported that replacing only the spilt-rocker "fixed" the problem. Indeed this single component can be a major contributor of total loop resistance. But consider that if NEW loop resistance was on the order of 50 milliohms and had climbed to 100 milliohms with the switch contributing 25 ohms of de-stabilizing resistance. Replacing the switch drops total down to 75 milliohms and the regulator is happy again . . . but not for as long as it would be when replacing ALL sources of age/service related resistance in the bus-to-regulator pathway. The obvious, elegant solution in original design is to incorporate a regulator that separates voltage sense wires from field current supply wires. The LR-3 does just that. Any new regulators I design will have separate sense wires too. Does this suggest that the OBAM community should rip out all their three-terminal switchers and bolt on the LR-3? Not at all. The automotive style regulators have for the most part given good value but they DO have special characteristics that only one mechanic in 1000 understands. In the spam-can world, ignorance is shoveled out at $thousands$ per non-idea, in the OBAM aircraft world, we've managed to keep those costs MUCH lower . . . and much of it happens right here on the AeroElectric List. > This airplane is well-built structurally and the engine's in good > shape, but the more I look at the electrical system, the more I relaize > that it's not quite what I'd like to see. Since avionics and lights were > added piecemeal over the years by different people, I wouldn't be > surprised to see as basic a mistake as an undercapacity > alternator. (Remember the undercapacity CB I found.) The largest Full-Up IFR load I've calculated for an SE airplane with vacuum system is 27A, with electric gyros it was 31A. It is unlikely that your alternator is undersized. If the noise were present with the alternator ON, varies pitch with rpm and goes away alternator OFF, it might be that onset of the noise was due to failure of a diode in the alternator which would produce a combination of (1) reduced alternator capacity and (2) greatly increased noise on the bus. However, since I think we're talking about relatively fixed pitch noise with alternator OFF, this isn't root cause of the noise. > Lastly, I'm also noting that the whine showed up within two flight > hours of my replacing the nav lights circuit breaker. Although I can't > imagine why that would have an effect, I also should mention that the > circuit breaker panel is homemade and possibly not well > shielded; perhaps in the course of working with the panel to swap out > the breaker I changed something. > If you could offer any thoughts on this, I'd appreciate it. First impressions are that this system may be suffering from a variety of small illnesses common to electrical system architectures used in most spam cans. These problems can be made worse by marginal craftsmanship of the neophyte builder and ignorant mechanic. Just because you hear a noise in the headsets doesn't always mean that some antagonist has jumped up to torment the victim. It's not uncommon for a victim to have ailments that mimic externally generated noises. Do you hear the noise whether or not there is a radio transmission being received? <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Yes, the noise was overlaid on received radio transmissions. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I.e., heard in the intercom only with microphone and radio squelch gates closed? Is the intercom battery powered or powered from the bus? <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< From what I've determined the electrical architecture in this plane is such a kludge that there ARE no distinct busses. For example, in the circuit breaker panel, the ground sides of the CBs are wired together with 14AWG wire, CB to CB in series, rather than in parallel to a bus (which could have been as simple as a piece of copper). As you mention in the Connection, obviously not the way to do it. I'll show it to you in Watsonville. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> If battery powered, how about trying a new battery . . .some audio systems become squealers when the battery voltage drops and power source impedance goes up. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Yesterday I flew a short hop battery-only (alternator switch off) and didn't hear any tone. As I recall voltage was about 13 V. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> >Best, >Pete Waters >(registered for your class in Watsonville) Great. See you in a few weeks! Given the range and magnitude of problems you've noted, it's not out of line to consider some major surgery to keep things like this from rising out of the mud in the future. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< That's what I'm concluding. I think I may be spending the next year or so redesigning and rebuilding most of the electrical architecture in this airplane. My initial thoughts are to start at the CB panel and properly divide the system into main, essential, and battery busses. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> We could use your airplane as a study topic at the Watsonville seminar. <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< I'll bring it if weather permits me to get into Watsonville VFR. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Bring all the drawings you have. Bob . . . <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< The only drawings I have are the ones I'm making through reverse engineering! But it's certainly educational. Thanks again. --------------------------------- ________________________________________________________________________________
From: "Ernest Kells" <ernest.kells(at)sympatico.ca>
Date: Oct 12, 2003
Pete: I understand your frustration at the electrical stuff. It's confusing - not like driving rivets (even visitors can point out my smilies). Bob very generously maintains this List for hundreds of subscribers. Once each year he asks for a totally voluntary contribution to help him provide the software, hardware, technical resource and archive storage for the benefit of everyone. BTW: have you made your contribution in the last 12 months ? ? Bob also provides a LOT of answers to people who submit questions to the List. In doing this he is only one participant on this List, equal to the rest of us. We all would respond to these questions - if we could. Bob answers based on his considerable knowledge - and we all defer to his expertise. This is his gift. If you don't like it you should drop the List and deal with your nearest service shop on a time and materials basis. The rest of us pay tribute to Mecca (er.. the sage of Wichita). Happy building. Ernest Kells - RV-9A O235-N2C, Wood Prop 90 plus % Complete - Wiring > > I've posted this meesage twice to the Aeroelectric Matronics list, and > > I see it there, but haven't seen any response. Not that I've earned your > > immediate jump-when-I-say-jump response by any means, but seeing how you > > quickly respond to others makes me wonder if you're seeing this. Or do I > > owe you money? > > Please respond either to the list or offline to me at > > pedroagua(at)aol.com if you get this. Thanks, Pete Waters ________________________________________________________________________________
Subject: Stick-shaker for stall warning
Date: Oct 13, 2003
HI Jim, I have just finished my J400, and the stall characteristics are very benign, much better than the older 2 seater Jabiru that I have a few hundred hours in. If you are installing the audible stall warning horn, this is more than enough protection than you need. If you wish to fully explore the very edge of the stall envelope near the ground, then may I suggest a AOA system. Ian -----Original Message----- From: James Foerster [mailto:jmfpublic(at)comcast.net] Subject: AeroElectric-List: Stick-shaker for stall warning Friends, I'm building a 4 place Jabiru, and this has a central control stick. I am considering the addition of a stick-shaker as used by military and commercial planes. A model airplane motor, run at the "appropriate" speed and driving an eccentric weight should work. The tiny pager motors available on the surplus market are too small to be useful in a vibrating plane, however. Could you professional pilots give me an idea as to how far the stick moves, and at roughly what frequency? I suspect that 8-20 Hz would be optimum, based on no real data. Its hard to guess the motion needed as this will be frequency dependent. I would drive this motor from either a microswitch attached to a vane projecting out from the leading edge of the wing, as is used by many commercial planes with an electric stall warning device, or else drive it from an angle of attack instrument. Although auditory warning from AoA devices is good, the stall is the greatest risk for death at takeoff and landing phase of flight. The warning should not be subtle and should use several modalities. I look forward to your comments. Jim Foerster Friends, I'm building a 4 place Jabiru, and this has a central control stick. I am considering the addition of a stick-shaker as used by military and commercial planes. A model airplane motor, run at the "appropriate" speed and driving an eccentric weight should work. The tiny pager motors available on the surplus market are too small to be useful in a vibrating plane, however. Could you professional pilots give me an idea as to how far the stick moves, and at roughly what frequency? I suspect that 8-20 Hz would be optimum, based on no real data. Its hard to guess the motion needed as this will be frequency dependent. I would drive this motor from either a microswitch attached to a vane projecting out from the leading edge of the wing, as is used by many commercial planes with an electric stall warning device, or else drive it froman angle of attack instrument. Although auditory warning from AoA devices is good, the stall is the greatest risk for death at takeoff and landing phase of flight. The warning should not be subtle and should use several modalities. I look forward to your comments. Jim Foerster ---------------------------------------------------- RSL COM has an extensive and competitive range of local and long distance call packages. We also offer converged multimedia and data services through our own state-of-the-art integrated voice & data network. Visit http://www.rslcom.com.au to find out more. This message is for the named person's use only. Privileged/confidential information may be contained in this message. If you are not the addressee indicated in this message (or responsible for delivery of the message to such person), you may not copy or deliver this message to anyone. In such case, you should destroy this message, and notify us immediately. Any views expressed in this message are those of the individual sender, except where the message states otherwise and the sender is authorised to state them to be the views of any such entity. ---------------------------------------------------- ________________________________________________________________________________
Subject: Strobes and comm Ant
Date: Oct 12, 2003
Friends, I'm building an AeroCanard and my Comm Ant are in the winglets. Problem is I have to run the strobe wiring out the same hole. Does anyone have an opinion on this? Will it work? John ________________________________________________________________________________
Date: Oct 12, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >Pete: I understand your frustration at the electrical stuff. It's >confusing - not like driving rivets (even visitors can point out my >smilies). > >Bob very generously maintains this List for hundreds of subscribers. Once >each year he asks for a totally voluntary contribution to help him provide >the software, hardware, technical resource and archive storage for the >benefit of everyone. BTW: have you made your contribution in the last 12 >months ? ? Actually, ALL donations go to Matt Dralle at matronics.com to support his efforts in supplying both server space and the fine software that runs the lists. My time spent on the lists is in exchange for making folks aware of my products and services. I've spent $thousands$ for print ads that produced not a single phone call much less a sale. I figure time on the list is a much better return on investment in at least three ways:. (1) You folks are helping me become a better designer and teacher by providing both venue and participants willing to think outside the box . . . (2) The attention this list brings to my website and its offerings makes this a hobby that does better-than-break even. I'm amazed that certain politicians in CA paid less than a grand in taxes on millions of income citing LOSSES on a publishing and lecturing business . . . I'm still trying to figure out how that works. This business wouldn't support me - at least not yet. But in no year have I not paid taxes on profits much less washed out taxes on my income as an engineer at RAC. So, you see this isn't so much an act of "generosity" as it is a symbiotic relationship where I hope every List participant is here because they receive good value for their time and purchases. >Bob also provides a LOT of answers to people who submit questions to the >List. In doing this he is only one participant on this List, equal to the >rest of us. We all would respond to these questions - if we could. Bob >answers based on his considerable knowledge - and we all defer to his >expertise. This is his gift. If you don't like it you should drop the List >and deal with your nearest service shop on a time and materials basis. The >rest of us pay tribute to Mecca (er.. the sage of Wichita). Happy building. >Ernest Kells - RV-9A O235-N2C, Wood Prop Gently, gently my friend. I'm sure Pete now understands how this all works and will be an active and useful participant to the list. Lookit . . . he's signed up for my Watsonville seminar. Let's not beat up on one of my customers now ;-) I couldn't do this if it wasn't fun, educational and ultimately profitable. The 'Connection is going to be my retirement business when they boot me out of RAC (or I leave 'cause it isn't fun any more). After a few hours of jousting with regulatory and corporate bureaucrats in the certified world, I can't wait to open my mail and see what kind of dragons can be slain TODAY in the OBAM community. So for the final reason . . . (3) the AeroElectric List provides a way for me to see real-time progress in crafting solutions to design and maintenance problems. If it weren't for you guys, the molasses-in-January pace of progress in my real job might have convinced me to open a BBQ stand years ago. At least there, when last week's customer walks back in the door today, you know you've done a good thing for both him and yourself. It can take years to achieve similar degrees of feedback in aviation . . . unless you're here on the AeroElectric-List. Let's cut Pete a little slack and put our heads together to see if we can figure out what's wrong with his airplane. Sound's like a real puzzlement and I'm looking forward to seeing what it turns out to be. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2003
Subject: Grounding fuel flow sender
I'm rebuilding the induction system on a Lyc IO-540. There's a Floscan transducer there already, from a previous engine instrument installation, but it looks like I'm going to have to re-position it. I know about keeping the fuel flow straight for as long as possible going in and out of the transducer, but at one point I was told that the transducer shouldn't be grounded - that it should be stepped off the engine on insulators, and that the fuel lines before and after the transducer should be rubber. This doesn't make a whole lot of sense to me, and I *really* don't want anything but stainless line for fuel on that side of the firewall. Does anyone know if this bit of advice is true, urban legend, or something inbetween? ________________________________________________________________________________
Date: Oct 13, 2003
Subject: List of tools
Hi, I'm just starting my RV8, and due to my geographically challenged location (mountains of Switzerland) I would like to buy all the tools, testers, and meters that I might for the electrical system of my RV8. I can get almost nothing locally, except very simple household wiring supplies. I have purchased the 'Connection, as Bob calls it, and am in the process of reading it. I'll be visiting the US next week, and I'd like to pick up as much of the stuff as I possibly can during this visit. I'll be back in the states for Thanksgiving as well, so it's not critical that I get everything in this visit. Does anyone know of a list of tools, and possibly suppliers, that I could use? I would much prefer to err on the side of having a tool that I will never use than to need something and to not have it, and have to wait for it to be delivered. I guess if I don't hear any suggestions I'll just buy everything I can find in all the aviation catalogues, but that seems a bit wasteful. Thanks! Mickey -- Mickey Coggins http://www.rv8.ch/ ________________________________________________________________________________
Subject: Re: RE: AeroElectric-List Digest: 28 Mags - 10/08/03
Date: Oct 13, 2003
Villi / Bob, Thanks for the info. Makes perfect sense as you describe, except... I was planning to use the dreaded key-operated mag / starter switch hence the thought about the relay. Perhaps its time to go for toggles instead. Cheers. Nev -- Jodel D-150 in progress UK ----- Original Message ----- From: <villi.seemann(at)nordea.com> Subject: AeroElectric-List: RE: AeroElectric-List Digest: 28 Mags - 10/08/03 > > Hi Neville > > I've just made what you want for a friend with a Druine Turbulent. One mag switch is replaced by a DPDT. One half is used as the p-lead contact. The other half is used as a tacho selector. > Dont put relays into such an installation. > > > Best regards > Villi H. Seemann > Sen. Eng. BSEE > Telephony Team > Infrastructure, Network > Phone (+45) 3333 2101 > Cell ph. (+45) 2220 7690 > FAX (+45) 3333 1130 >
September 29, 2003 - October 13, 2003
AeroElectric-Archive.digest.vol-cm
