AeroElectric-Archive.digest.vol-ct
December 19, 2003 - January 03, 2004
Date: Dec 19, 2003
Hi All, I would like to see a picture (or explanation) of an RV with Bob's OV module and relay for the 60A alt that VAN's sell. Thanks a lot, Amit, RV-7, wiring. ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Audio panel, of sorts...
I'm finally wiring my intercom inputs as described below with a capacitor. Does it matter which way the capacitor is oriented? - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com >Thanks Bob. How would I determine the size for the capacitor? > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com >2003 - The year of flight! > > >> -----Original Message----- >> From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net] >> > >> >I have 3 or 4 audio signals I need to capture somehow without a >> >traditional audio panel. For example, nav radio, AOA, traffic >> >detector, etc. I also have an ol' 4-place NAT intercom. >> I'm wondering > >if I can run the audio out from these various devices to the > otherwise > >unused MIC pins on the intercom. As an example, passenger 3 will > >actually be AOA annunciation. Is there any reason why this wouldn't > >work? > > This might work. You want to use a capacitor to couple audio to > these inputs to keep the microphone DC power on these pins from > feeding back into or being loaded by the audio sources. Headset > audio levels are in the same ballpark as microphone levels so > I'd say the odds are in your favor. > > Bob . . . ________________________________________________________________________________
Subject: electrical wiring
Date: Dec 19, 2003
Bob; I recently purchased your book "The Aeroelectric Connection" and noticed a conflict within. In the chapter "Electromagnetic Compatibility" page 16-12, paragraph three states "... keep fat wires away from skinny wires." which I assume to mean that the 2 & 4 gauge wires should be in a separate conduit from the 20 & 22 gauge wires. However, you then state in Appendix Z, Note 5; "Try to run ALL wiring in a single path down one side of the airplane. ... Use one side for wires, the other for engine controls." Which is correct? Thanks Dean May ________________________________________________________________________________
Date: Dec 19, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: ANL 20n current limiter source
> >Was planning to place a final order to collect remaining needs for my >electrical system and saw that the B&C site doesn't offer ANL 20 current >limiters. I figured this would be the right one for my #2 alternator, the >SD-20. If not, would I do harm by substituting an ANL 40? An ANL40 would be fine there. Alternatively you could use an automotive in-line fuse holder for a "fat fuse" . . . there is a line of plastic plug in fuses that are big brothers to the ATC plastics that fit the fuseblocks. Many automotive stores stock the Bussman HHX or something similar. http://www.bussauto.com/pdf/inlinefuseholder.pdf You can also buy fuses down to 20A for this holder at the same store . . . I'd put a 30A fuse in it. >On a similar topic, the information from Continental says that the >alternator that comes with the engine (IO-550) provides 70 amps. Should I >order an ANL 60 or an ANL 70 for the primary alternator? ANL60 from B&C would be fine here. The ANL series limiters are VERY robust compared to fuses and the potential overload on an "undersized" limiter is not an issue. Bob . . . ________________________________________________________________________________
Date: Dec 19, 2003
> >Bob, > >I picked up a used T2000 transponder, but I'm not ready to install yet. Is >there a good way to test this? > >Specifically, my concerns are turning the thing on without an antenna. I >know transmitters can be damaged without a proper load attached, but I'm >not sure how a transponder works in regards to transmitting. Does it only >repond if it's interrogated? Will it receive and interrogation signal >without an antenna attached? It won't talk without being interrogated. Why do you need to turn it on if you don't intend to have an antenna connected yet? Bob . . . ________________________________________________________________________________
Date: Dec 19, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> internally-regulated alt.
Subject: Re: OV module on RV with 60A
internally-regulated alt. internally-regulated alt. > >Hi All, >I would like to see a picture (or explanation) of an RV with Bob's OV module >and relay for the 60A alt that VAN's sell. >Thanks a lot, >Amit, RV-7, wiring. Not sure I understand your question. Does the alternator you have come with a built in regulator? Bob . . . ________________________________________________________________________________
Date: Dec 19, 2003
internally-regulated alt. internally-regulated alt. > >Hi All, >I would like to see a picture (or explanation) of an RV with Bob's OV module >and relay for the 60A alt that VAN's sell. >Thanks a lot, Aha! you did mention this in the subject line. Okay, you can take any of the Z-figs and modify alternator wiring in accordance with Z-24 . . . See: http://www.aeroelectric.com/FAQ/Internal_Regulator/ Bob . . . ________________________________________________________________________________
Date: Dec 19, 2003
It is a used unit and I guess I just wanted to make sure it would turn on(I don't have an antenna yet). I guess the best idea is to go ahead and buy an antenna and test it that way. I don't think that would cause any problems as long as it's left in standby. Of course, I'm 50 miles from the nearest radar so I don't think there would be a problem anyway. Thanks. Ken ---------- Original Message ----------------------------------
Date: Fri, 19 Dec 2003 08:30:18 -0600 > >> >>Bob, >> >>I picked up a used T2000 transponder, but I'm not ready to install yet. Is >>there a good way to test this? >> >>Specifically, my concerns are turning the thing on without an antenna. I >>know transmitters can be damaged without a proper load attached, but I'm >>not sure how a transponder works in regards to transmitting. Does it only >>repond if it's interrogated? Will it receive and interrogation signal >>without an antenna attached? > > It won't talk without being interrogated. Why do you need to > turn it on if you don't intend to have an antenna connected > yet? > > Bob . . . > ________________________________________________________________________________
Date: Dec 19, 2003
Subject: Re: Stereo (not really) intercoms
I have an installation manual for that intercom in the shop. I could scan it and email it to you if you still need it. Jim Pollard > >I have a NAT AA80-001 intercom I'm trying to wire to my RV8. It seems >that this intercom (as well as a few others I've researched) accept >stereo input -- but have mono output. What's the point of that?! I >have stereo headsets, jacks, music in, and music source...but mono >coming out of the intercom. Is this a problem, or should I just tie the >L and R together at the headset jack and press on? > >Also, if anyone has a soft copy of the owners/installation manual for >the AA80-001, could you forward to me? Thanks. > >Thanks. > >- >Larry Bowen >Larry(at)BowenAero.com >http://BowenAero.com ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: electrical wiring
> >Bob; > > I recently purchased your book "The Aeroelectric Connection" and > noticed a conflict within. In the chapter "Electromagnetic > Compatibility" page 16-12, paragraph three states "... keep fat wires > away from skinny wires." >which I assume to mean that the 2 & 4 gauge wires should be in a separate >conduit from the 20 & 22 gauge wires. However, you then state in Appendix >Z, Note 5; "Try to run ALL wiring in a single path down one side of the >airplane. ... Use one side for wires, the other for engine controls." I'll mark those paragraphs for clarification. Note 5 is correct. Engine instrumentation and controls, properly wired, are not particularly vulnerable. Furher, When all electrons running aft are counterbalanced by paired electrons running forward in the same bundle, chances of cross-coupling between systems are nil. However, running current carrying conductors down both sides of a canard-pusher has repeatedly demonstrated a willingness to hose up the magnetic compass. Hence the recommendation for single bundle running aft to the engine. In Section 16, the intent is to suggest isolation between most vulnerable victims (audio and avionics) from strongest antagonists (any wires carrying high power distribution currents like battery, alternator, bus feeds, pitot heaters, etc.) These are prophylactic measures. Incorporation does not guarantee a noise free system nor does failure to incorporate guarantee problems. It simply improves your odds and reduces the number of potential propagation paths to explore should a noise problem manifest itself. Bob . . . ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: Wiring Diagrams Available
> > >For those of you with the interest, I posted all the wiring diagrams for >my F1 Rocket on my web site today. You can get to them off of the F1 >Rocket Project page. You can view them as .PDF files using Adobe Acrobat. > >Perhaps you'll find them helpful. I don't have them all there yet as I am >still undecided on my EFIS and avionics packages. > >Let me know if you see something that looks like it will let all the smoke >out of the wires!! Randy, thanks for sharing these with the List . . . you've spent a lot of time putting them together and they're an excellent example of how to document your system. On the standby alternator, you'll need to eliminate the "AUX ON" lamp in series with the BUS feed to SB-1 reglator. Pin 6 is field supply lead for the alternator and should get a hard connection to the bus when the switch is closed. The other lamp is labeled AUX INOP . . . acttally, this light will illuminate when the aux alternator picks up a load. Normal operations call for both alternator switches to be ON. Aux alternator voltage regulator is set about a volt lower than main alternator set point. When main alternator is doing it's job, aux alternator will simple relax. If the bus voltage sags (due to main alternator failure) the aux alternator will come alive. IF system loads exceed rating of alternator, the light will be flashing. You simply reduce system loads until the light illuminates steady. If the main alternator comes back on line, the aux alternator relaxes again and the light will go out. Bob . . . ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: "CAT 5" Wire ...
Date: Dec 20, 2003
Bob, (and the rest of the list) I recently saw (while looking for something else at Best Buy) a wire bundle with strippers/crimpers that was Cat 5 wiring (but "better" ... don't remember the exact reason for the claim of "beyond"/"better" etc). But ..... I noticed that it was STRANDED wire. The wire was listed as AWG 24 I think. Since one of the concerns you mentioned before was that the wire was solid, maybe this is why it is better. My question ... Does this change your view on the potential applicability of this wire for something like the MAC trim servos (given that it is stranded?? [I understand that the Tefzel stuff is better and one can do whatever one wishes/ :-) ] For those interested, the whole thing cost about $99.00 and included a significant length of wire. (No I do not recall the length). James ________________________________________________________________________________
From: "Henrique Castro" <henriquerv9(at)hotmail.com>
Subject: VHF INSTALLATION HELP - URGENT!!!!
Date: Dec 20, 2003
Hi all, I am finishing installing my PM1000II Intercom and a KY97A Tranceiver on my RV9A. I am a little bit confused here. I have the following connections to finish. I just would like to receive orientation from who knows this connections to make sure I am doing nothing wrong.: PM1000II -> KY97A Pin#4 - Phone Lo -> PIN E? Pin#17 - Phone HI -> PIN 5? Pin#12 - Radio PTT -> PIN 9? Pin#13 - Mic Lo -> PIN K or J? Pin#25 - Mic HI -> PIN 8 ? Any help on this will be very appreciated!!! Regards Henrique Castro henriquerv9(at)hotmail.com ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Re: "CAT 5" Wire ...
Perhaps it was "Cat-5e", which is "certified" to over 500MHz, rather than the 100MHz needed for Cat-5. Both are available in stranded or solid; solid is easier to crimp to the RJ-45 plugs - but it doesn't lay flat and is easy to kink, so it's mostly used in pre-wired behind-panel installations. The stranded is a little harder to strip and crimp to the RJ45 plugs, but it kinks less and lays flatter - definitely preferred for the patch cable from the computer to the wall outlet, or jumpers on a patch panel. -John R. James E. Clark wrote: > >Bob, (and the rest of the list) > >I recently saw (while looking for something else at Best Buy) a wire bundle >with strippers/crimpers that was Cat 5 wiring (but "better" ... don't >remember the exact reason for the claim of "beyond"/"better" etc). But ..... > >I noticed that it was STRANDED wire. The wire was listed as AWG 24 I think. >Since one of the concerns you mentioned before was that the wire was solid, >maybe this is why it is better. > >My question ... > >Does this change your view on the potential applicability of this wire for >something like the MAC trim servos (given that it is stranded?? > >[I understand that the Tefzel stuff is better and one can do whatever one >wishes/ :-) ] > >For those interested, the whole thing cost about $99.00 and included a >significant length of wire. (No I do not recall the length). > >James > > > > ________________________________________________________________________________
Date: Dec 20, 2003
Subject: S704-1 relays for trim?
Because I altered my plans from having a second small batter to having two equally-sized batteries, I have a couple extra S704-1 relays. Is there any reason not to use them for trim relays? Dan O'Brien Lancair ES ________________________________________________________________________________
Subject: Re: S704-1 relays for trim?
Date: Dec 20, 2003
Dan - B&C specifically notes that they can be used for trim and flaps. Go for it. John > Because I altered my plans from having a second small batter to having > two equally-sized batteries, I have a couple extra S704-1 relays. Is > there any reason not to use them for trim relays? ________________________________________________________________________________
Date: Dec 21, 2003
Subject: Visio or IntelliCAD?
Hi, I'm looking at drawing my electrical system, and starting with Z13. I'm quite familiar with Visio, but I don't have any of the needed symbols. This seems strange, I know, but I've never done electrical drawings before. Perhaps they are on the CDs, but I can't find them. I also installed IntelliCAD, but I'm not sure my brain is ready to learn yet another drawing application. Anything more complicated than the original MacDraw gets me real confused! :-) IntelliCAD looks like massive overkill for a schematic like this. Has anyone already re-drawn Z13 or any of the other AeroElectric Connection drawings with Visio, so I don't have to reinvent the wheel? Barring that, can anyone recommend a *simple* drawing application that can manipulate .dwg files? Thanks, Mickey -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 21, 2003
Hi Mickey, Since you already know Visio, I would suggest you use it. I use Visio for my wiring diagrams, it is the perfect application for this type of drawing. No, there aren't any Visio symbols/shapes on the CD, I'm afraid you have to come up with your own. Bob; This Visio shape topic seems to be a recurring thing, perhaps we should start submitting our shapes to your for archival on the CD?? For any drawing that requires scale, precision, or dimensioning; I would use one of the CAD programs (I use IntelliCAD). Jon Finley N90MG Q2 - Subaru EJ-22 DD - 461 Hrs. TT Apple Valley, Minnesota http://www.FinleyWeb.net/Q2Subaru > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of Mickey Coggins > Sent: Sunday, December 21, 2003 7:25 AM > To: AeroElectric-List(at)matronics.com > Subject: AeroElectric-List: Visio or IntelliCAD? > > > --> > > Hi, > > I'm looking at drawing my electrical system, and > starting with Z13. I'm quite familiar > with Visio, but I don't have any of the needed > symbols. This seems strange, I know, but I've > never done electrical drawings before. Perhaps > they are on the CDs, but I can't find them. > > I also installed IntelliCAD, but I'm not sure my > brain is ready to learn yet another drawing application. > Anything more complicated than the original MacDraw gets me > real confused! :-) IntelliCAD looks like massive > overkill for a schematic like this. > > Has anyone already re-drawn Z13 or any of the > other AeroElectric Connection drawings with Visio, > so I don't have to reinvent the wheel? > > Barring that, can anyone recommend a *simple* drawing > application that can manipulate .dwg files? > > Thanks, > Mickey > ________________________________________________________________________________
Date: Dec 20, 2003
Subject: Battery Reserve Capacity Tester
Bob Due to an excess of laziness, I just bought a new BC100-1 battery from B&C to replace the 8 year old one that finally died. I cannot find a 120 volts AC clock to make your battery reserve tester and I would like to start your test plan. I will be rewiring my RV 6A per Z13 (replacing the VFR panel with an very competent IFR panel) and plan to follow your instruction to replace the battery when at 0.5 reserve capacity. Do you sell a kit to make the tester that includes the clock? Thanks Matthew M. Jurotich NASA/Goddard Space Flight Center JWST ISIM Systems Engineer m/c : 443 e-mail mailto: mjurotich(at)hst.nasa.gov phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov> ________________________________________________________________________________
From: "Dan Branstrom" <danbranstrom(at)verizon.net>
Subject: Re: Battery Reserve Capacity Tester
Date: Dec 21, 2003
If you hit the thrift stores and garage sales, 120V clocks are out there. Dan Branstrom ----- Original Message ----- From: "Matt Jurotich" <mjurotich(at)hst.nasa.gov> Subject: AeroElectric-List: Battery Reserve Capacity Tester > > Bob > > Due to an excess of laziness, I just bought a new BC100-1 battery from B&C > to replace the 8 year old one that finally died. I cannot find a 120 volts > AC clock to make your battery reserve tester and I would like to start your > test plan. I will be rewiring my RV 6A per Z13 (replacing the VFR panel > with an very competent IFR panel) and plan to follow your instruction to > replace the battery when at 0.5 reserve capacity. Do you sell a kit to > make the tester that includes the clock? > > Thanks > > > Matthew M. Jurotich > > NASA/Goddard Space Flight Center > JWST ISIM Systems Engineer > > m/c : 443 > e-mail mailto: mjurotich(at)hst.nasa.gov > phone : 301-286-5919 > fax : 301-286-7021 > > JWST URL: <http://ngst1.gsfc.nasa.gov> > > ________________________________________________________________________________
Date: Dec 21, 2003
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Visio or IntelliCAD?
I have both AutoCAD and Visio. Visio is able to import a large number of other formats, including DXF. I will be doing my wiring design schematics in Visio and, as an experiment, just tried to do an export/import of drawing Z-13. It definitely works. Unfortunately, it imports as a single large group. To use the symbols individually, one would have to ungroup them in Visio or export the desired symbols individually from AutoCAD. My version of Visio (4.0b) is fairly old and will not ungroup the entire drawing (something about running out of memory). If you have a later version of Visio (that might be able to ungroup the entire drawing), I would be happy to translate the entire drawing to DXF and email it (them) to you (or post them on the Matronics site if I can figure it out). Otherwise, you can wait until I get to my wiring and I will give you whatever symbols I use :-) . Dick Tasker, RV9A #90573 Finishing Fuselage - then the canopy :-( ... Mickey Coggins wrote: > >Hi, > >I'm looking at drawing my electrical system, and >starting with Z13. I'm quite familiar >with Visio, but I don't have any of the needed >symbols. This seems strange, I know, but I've >never done electrical drawings before. Perhaps >they are on the CDs, but I can't find them. > >I also installed IntelliCAD, but I'm not sure my >brain is ready to learn yet another drawing application. >Anything more complicated than the original MacDraw gets >me real confused! :-) IntelliCAD looks like massive >overkill for a schematic like this. > >Has anyone already re-drawn Z13 or any of the >other AeroElectric Connection drawings with Visio, >so I don't have to reinvent the wheel? > >Barring that, can anyone recommend a *simple* drawing >application that can manipulate .dwg files? > >Thanks, >Mickey > >-- >Mickey Coggins >GSM: +41-79-210-3762 >FAX: +41-86-079-210-3762 >http://www.rv8.ch/ >#82007 >Empennage complete, waiting for wings to arrive > ________________________________________________________________________________
Date: Dec 21, 2003
Subject: Noisy Turn & Bank
Listers: I am having a great deal of noise from my Falcon Turn & Bank. Winds up like the motor driving the gyro. If i pull the fuse the noise goes silent. It sounds pretty load ouside the headset, a real screaming wind up. Is this a defective guage or do I need to work at filtering it. My RV4 is running a two alternator one battery system modified from Bob's schematics. Dave N504RV ________________________________________________________________________________
Date: Dec 21, 2003
Subject: Re: Noisy Turn & Bank
> >Listers: >I am having a great deal of noise from my Falcon Turn & Bank. Winds up >like the motor driving the gyro. If i pull the fuse the noise goes >silent. It sounds pretty load ouside the headset, a real screaming wind >up. Is this a defective guage or do I need to work at filtering it. My >RV4 is running a two alternator one battery system modified from Bob's >schematics. >Dave >N504RV You need to deduce the propagation mode for the noise. Radiated magnetic or conducted electric (or both). Run gyro from 12 lantern battery and see if noise goes totally away. If so, then the noise filter described at http://www.aeroelectric.com/articles/filter/filter.html If the noise is still there, you'll need to fabricate a magnetic shield from a strip of galvanized flashing metal . . . width equals depth of instrument from rear of panel, length should be long enough to wrap around the instrument about 3 times. Hold in place with several bands of cable lace or some long, skinny tye-wraps. Bob . . . ________________________________________________________________________________
Date: Dec 21, 2003
Subject: Re: VHF INSTALLATION HELP - URGENT!!!!
> > >Hi all, > >I am finishing installing my PM1000II Intercom and a KY97A Tranceiver on >my RV9A. I am a little bit confused here. I have the following connections >to finish. I just would like to receive orientation from who knows this >connections to make sure I am doing nothing wrong.: > >PM1000II -> KY97A > >Pin#4 - Phone Lo -> PIN E? >Pin#17 - Phone HI -> PIN 5? >Pin#12 - Radio PTT -> PIN 9? >Pin#13 - Mic Lo -> PIN K or J? >Pin#25 - Mic HI -> PIN 8 ? > >Any help on this will be very appreciated!!! I am mystified by the connections you cited. My data package on the KY97A: http://www.aeroelectric.com/Installation_Data/KY97A.pdf and the PM1000II Intercom: http://www.aeroelectric.com/Installation_Data/PM1000II_A.pdf suggest they should be interconnected as shown in: http://www.aeroelectric.com/Installation_Data/PM1000-KY97A.gif Bob . . . ________________________________________________________________________________
Date: Dec 21, 2003
Hi David I had the same problem with the same T&B. I talked ACS into taking it back even though I had had it for 7 months. My argument was that I had no way of knowing it was defective until I electrified the panel and radios. I exchanged it for a more expensive quiet one. Tom Friedland -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Aronson Subject: AeroElectric-List: Noisy Turn & Bank Listers: I am having a great deal of noise from my Falcon Turn & Bank. Winds up like the motor driving the gyro. If i pull the fuse the noise goes silent. It sounds pretty load ouside the headset, a real screaming wind up. Is this a defective guage or do I need to work at filtering it. My RV4 is running a two alternator one battery system modified from Bob's schematics. Dave N504RV == == == == ________________________________________________________________________________
Date: Dec 21, 2003
>The stranded is a little harder to strip and crimp to the RJ45 plugs, >but it kinks less and lays flatter - definitely preferred for the patch >cable from the computer to the wall outlet, or jumpers on a patch panel. I am mystified by this romance with Cat5 computer cable for use in airplanes. One of many experiences during my first visit to OSH in '86 prompted me to begin working on the 'Connection . . . . . . I saw a beautiful Long-Ez wired with a liberal sprinkle of zip cord, and an assortment of automotive and house wire held together with plastic electrical tape and "Plastigrip" terminals and splices. Premier has a LOT of 24AWG airframe wire in it and the folks who put it together and maintain this airplane in the field are less than enthusiastic about it. Even with 19-strand lay-up (which Cat-5 is not), the stuff is much more prone to handling and endurance issues than 22AWG. Just 'cause the trim actuator comes with 24AWG wires in no way commits one to perpetuate the design error by extending the conductors with the same size wire, much less with a non-recommendable material. 22759/16-22 is a VERY fine wire for this application and you're going to need a bunch of it anyhow for avionics and instrumentation tasks . . . If you wouldn't run your Lycoming with Pennzoil, or re-juice your flooded battery with tap water, why would you wire your trim actuator with glorified door-bell wire? Bob . . . ________________________________________________________________________________
Date: Dec 21, 2003
Tom, Save me the trouble you experienced, which model did you get in replacement? Thanks, Jim -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of beecho(at)beecho.org Subject: RE: AeroElectric-List: Noisy Turn & Bank Hi David I had the same problem with the same T&B. I talked ACS into taking it back even though I had had it for 7 months. My argument was that I had no way of knowing it was defective until I electrified the panel and radios. I exchanged it for a more expensive quiet one. Tom Friedland -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Aronson Subject: AeroElectric-List: Noisy Turn & Bank Listers: I am having a great deal of noise from my Falcon Turn & Bank. Winds up like the motor driving the gyro. If i pull the fuse the noise goes silent. It sounds pretty load ouside the headset, a real screaming wind up. Is this a defective guage or do I need to work at filtering it. My RV4 is running a two alternator one battery system modified from Bob's schematics. Dave N504RV == == == == == == == == ________________________________________________________________________________
Date: Dec 21, 2003
Sent direct ----- Original Message ----- From: "Richard E. Tasker" <retasker(at)optonline.net> Subject: Re: AeroElectric-List: Visio or IntelliCAD? > > I have both AutoCAD and Visio. Visio is able to import a large number > of other formats, including DXF. > > I will be doing my wiring design schematics in Visio and, as an > experiment, just tried to do an export/import of drawing Z-13. It > definitely works. Unfortunately, it imports as a single large group. > To use the symbols individually, one would have to ungroup them in Visio > or export the desired symbols individually from AutoCAD. My version of > Visio (4.0b) is fairly old and will not ungroup the entire drawing > (something about running out of memory). If you have a later version of > Visio (that might be able to ungroup the entire drawing), I would be > happy to translate the entire drawing to DXF and email it (them) to you > (or post them on the Matronics site if I can figure it out). > > Otherwise, you can wait until I get to my wiring and I will give you > whatever symbols I use :-) . > > Dick Tasker, RV9A #90573 > Finishing Fuselage - then the canopy :-( ... > > > Mickey Coggins wrote: > > > > >Hi, > > > >I'm looking at drawing my electrical system, and > >starting with Z13. I'm quite familiar > >with Visio, but I don't have any of the needed > >symbols. This seems strange, I know, but I've > >never done electrical drawings before. Perhaps > >they are on the CDs, but I can't find them. > > > >I also installed IntelliCAD, but I'm not sure my > >brain is ready to learn yet another drawing application. > >Anything more complicated than the original MacDraw gets > >me real confused! :-) IntelliCAD looks like massive > >overkill for a schematic like this. > > > >Has anyone already re-drawn Z13 or any of the > >other AeroElectric Connection drawings with Visio, > >so I don't have to reinvent the wheel? > > > >Barring that, can anyone recommend a *simple* drawing > >application that can manipulate .dwg files? > > > >Thanks, > >Mickey > > > >-- > >Mickey Coggins > >GSM: +41-79-210-3762 > >FAX: +41-86-079-210-3762 > >http://www.rv8.ch/ > >#82007 > >Empennage complete, waiting for wings to arrive > > > > ________________________________________________________________________________
Date: Dec 21, 2003
Jim I got an ACS p/n 1394T100. I see the price went up a bit since I received mine about 4 months ago. (Ya sure, there isn't any inflation...) Tom -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jim Stone Subject: RE: AeroElectric-List: Noisy Turn & Bank Tom, Save me the trouble you experienced, which model did you get in replacement? Thanks, Jim -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of beecho(at)beecho.org Subject: RE: AeroElectric-List: Noisy Turn & Bank Hi David I had the same problem with the same T&B. I talked ACS into taking it back even though I had had it for 7 months. My argument was that I had no way of knowing it was defective until I electrified the panel and radios. I exchanged it for a more expensive quiet one. Tom Friedland -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David Aronson Subject: AeroElectric-List: Noisy Turn & Bank Listers: I am having a great deal of noise from my Falcon Turn & Bank. Winds up like the motor driving the gyro. If i pull the fuse the noise goes silent. It sounds pretty load ouside the headset, a real screaming wind up. Is this a defective guage or do I need to work at filtering it. My RV4 is running a two alternator one battery system modified from Bob's schematics. Dave N504RV == == == == == == == == == == == == ________________________________________________________________________________
Date: Dec 21, 2003
Hi Randy, Thanks for posting your wiring diagrams. They are Beautiful! I will be pondering over them to glean what I can for my project. On your Power Distribution Schematic you show your battery cables twisted. Reason? One small thing I noticed on the Power Distribution page. Looks like the symbol for the battery should be 180 degrees ... long line positive and short negative ... yes? Thanks again, Don B. ________________________________________________________________________________
Date: Dec 21, 2003
> >Bob, > >I know you prefer the RG-142 or RG-400 over RG-58, but are the benefits >strong enough if I already have some RG-58 on hand? Depends on what you call "benefits" . . . Obviously, RG-58 has a reasonably successful history that goes back 60 years or more and there are hundreds of miles of the stuff still flying. It's not going to fail to function. Bob . . . ________________________________________________________________________________
Date: Dec 21, 2003
Is this wiring diagram available to all? If so, where can I download it, please? Thanks, AI Nut ----- Original Message ----- From: "Don Boardman" <dboardm3(at)twcny.rr.com> Subject: Re: AeroElectric-List: Wiring Diagrams Available > > Hi Randy, > > Thanks for posting your wiring diagrams. > They are Beautiful! > I will be pondering over them to glean what I can for my project. > > > On your Power Distribution Schematic you show your battery cables twisted. > > Reason? > > > One small thing I noticed on the Power Distribution page. Looks like the > symbol for the battery should be 180 degrees ... long line positive and > short negative ... yes? > > Thanks again, > Don B. > ________________________________________________________________________________
Subject: Strobe noise (in headset) reduced w/capicitor thanks
to `lectric Bob
Date: Dec 21, 2003
I used the S251D479 filter/capacitor (fromB&C) after testing per Bob`s intructions. The noise is reduced (ATC is happier) and I can`t hear it at all at altitude. There is a snapping noise (independant of volume on the com.) and I guess I`ll have to live with it as my wing tip light assemblies are rivetted. I think I`ll make a couple of those Radio Shack filters as in a previous thread and experiment? Thanks again Bob. The whooping noise doesn`t aggravate anymore. ________________________________________________________________________________
Date: Dec 21, 2003
Just for the record, I have no plans to use this wire. Was just "discussing" what I saw since others had seemingly expressed an interest. And I was curious. :-) James > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert > L. Nuckolls, III > Sent: Sunday, December 21, 2003 4:10 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: "CAT 5" Wire ... > > > III" > > [snip] > > I am mystified by this romance with Cat5 computer cable for > use in airplanes. One of many experiences during my first visit to > OSH in '86 prompted me to begin working on the 'Connection . . . > > ________________________________________________________________________________
Date: Dec 21, 2003
> > >Just for the record, I have no plans to use this wire. Was just "discussing" >what I saw since others had seemingly expressed an interest. And I was >curious. :-) Understand. Wasn't picking on you . . . this thread pops up from time to time. It flew through the list about a year ago as I recall. It almost always starts when someone is wanting to extend the 24AWG wires on a RayAllen servo with more 24AWG . . . or doesn't want to bundle their own conductors. Bob . . . ________________________________________________________________________________
Date: Dec 22, 2003
Al, The original message: For those of you with the interest, I posted all the wiring diagrams for my F1 Rocket on my web site today. You can get to them off of the F1 Rocket Project page. You can view them as .PDF files using Adobe Acrobat. Perhaps you'll find them helpful. I don't have them all there yet as I am still undecided on my EFIS and avionics packages. Let me know if you see something that looks like it will let all the smoke out of the wires!! Regards, Randy #95 http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Dec 21, 2003
Bob, I long ago committed to avoiding any PVC insulation anywhere in my airplane (that I could control), and AFAIK even the plenum-grade Cat-5 has a type of PVC (irradiated, I think?) that, although somewhat more fire retardant, is still not nearly as good as Tefzel... My response was simply to state that Cat-5 is available in stranded as well as solid (someone said earlier not to use Cat-5 because it was solid), and why one might be better than the other in its intended application... and that the mentioned "Cat5-superior" cable was not likely superior because it was stranded, but because it was probably Cat-5e (or even Cat6). By the way, stranded UTP cable is still fairly easy to kink, certainly much more so than 22759/Tefzel-insulated wire... I've got 12-ft runs down a duct through Teflon tubing, and pulling Tefzel through it is slicker than.... well, slicker than UTP anyway! -John R. Robert L. Nuckolls, III wrote: > > > > >>The stranded is a little harder to strip and crimp to the RJ45 plugs, >>but it kinks less and lays flatter - definitely preferred for the patch >>cable from the computer to the wall outlet, or jumpers on a patch panel. >> >> > > > > I am mystified by this romance with Cat5 computer cable for > use in airplanes. One of many experiences during my first visit to > OSH in '86 prompted me to begin working on the 'Connection . . . > > . . . I saw a beautiful Long-Ez wired with a liberal sprinkle > of zip cord, and an assortment of automotive and house wire > held together with plastic electrical tape and "Plastigrip" > terminals and splices. > > Premier has a LOT of 24AWG airframe wire in it and the folks > who put it together and maintain this airplane in the field > are less than enthusiastic about it. Even with 19-strand > lay-up (which Cat-5 is not), the stuff is much more prone to > handling and endurance issues than 22AWG. > > Just 'cause the trim actuator comes with 24AWG wires in no > way commits one to perpetuate the design error by extending > the conductors with the same size wire, much less with a > non-recommendable material. 22759/16-22 is a VERY fine wire > for this application and you're going to need a bunch of it > anyhow for avionics and instrumentation tasks . . . > > If you wouldn't run your Lycoming with Pennzoil, or > re-juice your flooded battery with tap water, why > would you wire your trim actuator with glorified door-bell > wire? > > Bob . . . > > > > ________________________________________________________________________________
Date: Dec 22, 2003
I was hoping to find them or others in Visio or other CAD format, not .PDF. 8-) Thanks, AI Nut ----- Original Message ----- From: "Don Boardman" <dboardm3(at)twcny.rr.com> Subject: Re: AeroElectric-List: Wiring Diagrams Available > > Al, > > The original message: > > > > For those of you with the interest, I posted all the wiring diagrams for my > F1 Rocket on my web site today. You can get to them off of the F1 Rocket > Project page. You can view them as .PDF files using Adobe Acrobat. > > Perhaps you'll find them helpful. I don't have them all there yet as I am > still undecided on my EFIS and avionics packages. > > Let me know if you see something that looks like it will let all the smoke > out of the wires!! > > Regards, > Randy #95 > http://f1rocket.home.comcast.net/ > > ________________________________________________________________________________
Date: Dec 22, 2003
Yes, you are the second reader to catch that. I have fixed and re-posted. Thanks. I twisted the cables per the "Aeroelectric Connection". I'm not sure it is really necessary but it won't hurt anything either. Randy > > Hi Randy, > > Thanks for posting your wiring diagrams. > They are Beautiful! > I will be pondering over them to glean what I can for my project. > > > On your Power Distribution Schematic you show your battery cables twisted. > > Reason? > > > One small thing I noticed on the Power Distribution page. Looks like the > symbol for the battery should be 180 degrees ... long line positive and > short negative ... yes? > > Thanks again, > Don B. > > > > > > ________________________________________________________________________________
From: "Steve Hunt" <Stephen.Hunt19(at)btinternet.com>
Subject: Fuel sw?
Date: Dec 22, 2003
Hi, new to the list, about 8 months from first flight RV8 in UK. Three electrical bits puzzling me and wonder if you can help. 1. Have an IO 360 (injected ) engine. I am supposing that a simple toggle, on/off will suffice for the fuel pump? 2. My essential bus is to get me on the ground as soon as possible...endurance not the issue that many people want. We cannot fly IMC or at night in UK with home build. After 13000 hrs "conditioning" as an airline pilot I do not want to stay airborne with an unresolved electrical problem....especially when I have constructed the set up! In UK never far from a landable site. I want to supply the VHF, Tx Pdr, EFIS Lite(Blue Mountain ) AND Flap motor from the essential bus, normally via a silicone diode from the main bus. In non normal mode Flaps would be selected when Visual, clear to Land and committed....if any pwr left. What size , type of diode do I need for normal operation of such a system? 3. Any thoughts on best solution to wiring in the ammeter? Steve Hunt ________________________________________________________________________________
Date: Dec 22, 2003
Bob, Thanks for the comments. This now raises a couple of questions. Please see below: >On the standby alternator, you'll need to eliminate the "AUX ON" lamp in >series with the BUS feed to SB-1 reglator. Pin 6 is field supply lead for the >alternator and should get a hard connection to the bus when the switch is >closed. The other lamp is labeled AUX INOP . . . actually, this light will >illuminate when the aux alternator picks up a load. Normal operations call for >both alternator switches to be ON. Then what is the purpose of the AUX ALT switch? If it is supposed to be on always, one can always use the AUX C/B to take the Aux alternator off-line. >Aux alternator voltage regulator is set about a volt lower than main >alternator set point. When main alternator is doing it's job, aux alternator >will simple relax. If the bus voltage sags (due to main alternator failure) >the aux alternator will come alive. IF system loads exceed rating of >alternator, the light will be flashing. You simply reduce system loads until >the light illuminates steady. If the main alternator comes back on line, the >aux alternator relaxes again and the light will go out. How do I know if the AUX alternator is off line? There doesn't appear to be any warning light to indicate Battery Only operation. It appears that the Aux light coming on with a load is a redundant warning since the warning light of the primary alternator controller should be illuminated. Looks like I might be able to eliminate the Primary INOP light in this scenario then. I'm not sure how to wire this up now. I'm thinking I can eliminate the Aux Alternator switch, the Primary INOP warning light, and the AUX On light. If the primary alternator goes off line, the AUX warning light will either illuminate or flash, depending on the load, telling me that the auxiliary alternator is now carrying the load of the aircraft. If the AUX Alternator goes off line, I don't know how I'll know unless the engine monitor triggers a low volt warning. Do I have it correct? Thanks. Randy F1 Rocket http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Dec 22, 2003
Subject: Shield termination KCS55A/KI525A
Hello, I'm hoping someone can recommend where to attach the shield terminations for a KI525A HSI. I've seen photo's (cannot find link) that show the shield terminations attached to the screw on the KI525's connector strain relief. I'm really not happy with this because the strain relief is just floating in the slot of the back shell and the back shell itself is only attached electrically to the connector alignment/keying posts (still just floating). Thanks, Greg Puckett RV-8 80081 slooooow build ________________________________________________________________________________
Date: Dec 22, 2003
Subject: KG102 pin out and/or internal P.S. schematic
Hello, I need some help with my KCS55A/CNX80 installation. My KI525A has the HDG bootstrap syncro out and I'd like to utilize it to feed the HDG xyz in for the CNX80 only. Someone at a local avionics shop told me I do not have to buy a 26VAC 400HZ inverter that the KG102A has 400HZ 26VAC out and is just not shown on the KCS55 install docs. I have the KCS55 install manual and it does not show it. I'm wondering if anyone has access to a KG102A component Maint. manual. I've been told the 26vac high out is pin p but I'm not sure what I should use as a 26VAC lo (C). I would like some assurance that driving the primary coil for the bootstrap in the 525 HSI will not demand too much from the AC power supply in the remote gyro. I was told just to use case GND for the (L) side and the shield too. I'm pretty sure the CNX80 ref and xyz inputs are high impedance but I'm wondering if the primary in the 525A will draw more than the remote gyro power supply can handle. Thanks Greg Puckett Elizabeth, Colorado RV8 80081 ________________________________________________________________________________
Date: Dec 22, 2003
Subject: Choices, choices, choices . . .
From time to time, a builder writes to ask, "I got a really good deal on this kind of wire, can I use it to wire up my whizzy-giget?" Or, "Why should I go out an buy this $high$ connector that takes a special tool when this $low$ connector does the same job and installs with a soldering iron?" I've been pondering this situation for the past several days. Indulge me please while I share some past experiences: When I was in the 4th or 5th grade, I shared an interest in model aircraft construction with a cousin about 5 years my senior. He worked in a hobby shop and I think took much of his compensation in store stock. His models were all beautifully crafted and flew well. I recall a conversation about glue. His personal choice was a product called Ambroid while my personal preference was for a less expensive, faster drying Testor's model cement. As I recall, Ambroid sold for perhaps three or four times the price of Testors. It also took 12-18 hours to reach full strength. When you considered the cost of a kit, cost of engine, and hours to assemble, and a quest of lowest cost of ownership (lots of maintenance-free flying), the difference in $total$ for assembling with Ambroid vs. Testors was insignificant. He also covered in silk while I used tissue. I suspect there were additional differences in our choice materials and techniques wherein I went the $low$ route . . . but in the final analysis made little difference in the total cost of our respective projects. Perhaps it was a mute point in my case, cousin Calvin's models usually lived to fly many a mission while my own were not so fortunate. Had any of his models survived to the present time, it's a certainty that they would be the finest examples of model construction of that era. Would we build a model that way today? Epoxy wasn't around then. Nor were any form of composite materials. You had to shrink coverings to contour with multiple coats of finish, not with a hot iron. Radio control was bang-bang, rudder only at wide open throttle, today it's fully three-axis with trims accessory control channels + throttle. I open my seminars with a statement to the effect, "You folks are building the finest airplanes to have ever flown." This always raises a few eyebrows, "Wha-da-ya- mean? I don't know all that much about it." I can confidently reply, "Yes, and that's why. You participate on list servers to tap the collective gray-matter of the OBAM aircraft community. You are attending this seminar to achieve a higher level of understanding. If you break something, it gets replaced. If a part doesn't work quite right, you rebuild it as needed until it does. Unlike those new graduates bucking rivets on an assembly line while dreaming about what they're going to do after work that evening, YOU are paying attention to achieving the very best the community knows how to do. I'll suggest there is more VALUE in a nicely built RV than ANY spam can irrespective of how nice the paint looks or what electro-whizzies are bolted to the panel. Finally, no two OBAM aircraft are built exactly the same way. Certified airplanes are literally carved into regulatory stone of conformance, your airplane can freely evolve. OBAM aircraft are by definition at the leading edge of performance and value in aviation." Remember the Jimmy Stewart movie "Flight of the Phoenix"? The folks trying to assemble a man-rated, flying aircraft from a pile of salvage were not pleased to discover that their "designer's" previous experience was limited to building flying models. It took some time for folks to understand that basic principals of structures and flight were interchangeable between the worlds of miniature and full-scale. I suggest that after you've purchased kit, engine, propeller, brakes, and a panel full of whippy radios and instruments, impact on total cost for the-best-we-know-how-to-do versus materials or tools you discovered at a garage sale or hardware store is trivial. My experience at workbench of cousin Calvin stands out my memory as a benchmark of Calvin's superior sense craftsmanship. He chose to build in a manner that represented the very best the model building community knew how to do. To be sure, few OBAM aircraft builders are going to be using today's techniques and technologies 20 years from now . . . May I suggest we should be wary of tools, techniques and materials popularly used 20 years ago? May I further suggest that it's not so much a question of "will it work" as opposed to will it be something you'll look back on 20 years from now as the best we knew how to do today? Dee and I offer our best wishes for you and yours for the upcoming holidays. We're looking forward to meeting many of you in what promises to be a busy seminar schedule for next year. It's always enjoyable and gratifying to work with folks building the finest airplanes to have ever flown. Bob . . . P.S. I'd appreciate it if folks would take the time to relay this note to other list servers . . . ________________________________________________________________________________
Date: Dec 22, 2003
> >Bob, > >Thanks for the comments. This now raises a couple of questions. Please >see below: > > >On the standby alternator, you'll need to eliminate the "AUX ON" lamp > in >series with the BUS feed to SB-1 reglator. Pin 6 is field supply lead > for the >alternator and should get a hard connection to the bus when the > switch is >closed. The other lamp is labeled AUX INOP . . . actually, > this light will >illuminate when the aux alternator picks up a load. > Normal operations call for >both alternator switches to be ON. > >Then what is the purpose of the AUX ALT switch? If it is supposed to be >on always, one can always use the AUX C/B to take the Aux alternator off-line. You can do that if you wish. This system was crafted mostly to support adding a capable alternator to an existing system . . . particularly certified ships. The feds wouldn't look kindly on using a circuit breaker as a panel control. However, the C210 installation does in fact use a switch-breaker for the bus-feed control. If you eliminate the switch (and the breaker stays normally closed) the s/b alternator comes up immediately after starting the engine. > >Aux alternator voltage regulator is set about a volt lower than > main >alternator set point. When main alternator is doing it's job, aux > alternator >will simple relax. If the bus voltage sags (due to main > alternator failure) >the aux alternator will come alive. IF system loads > exceed rating of >alternator, the light will be flashing. You simply > reduce system loads until >the light illuminates steady. If the main > alternator comes back on line, the >aux alternator relaxes again and the > light will go out. > >How do I know if the AUX alternator is off line? The "AUX ALT" light will go out if the alternator is not delivering energy to the system. Further, voltmeter, loadmeter and/or lv-warning instrumentation would be expected to supplement the warning lights supplied with ship's regulators . . . >There doesn't appear to be any warning light to indicate Battery Only >operation. It appears that the Aux light coming on with a load is a >redundant warning since the warning light of the primary alternator >controller should be illuminated. The warning light for primary alternator controller is LOW VOLTS. It will continue to function in that capacity even when the main alternator is off. If the main alternator is off/failed and the aux alternator is up, the LOW VOLTS warning light should be out and the AUX ALT light would be on. If the aux alternator is off/failed, then the LOW VOLTS light will be flashing. > Looks like I might be able to eliminate the Primary INOP light in this > scenario then. Nope . . . >I'm not sure how to wire this up now. I'm thinking I can eliminate the >Aux Alternator switch, the Primary INOP warning light, and the AUX On >light. If the primary alternator goes off line, the AUX warning light >will either illuminate or flash, depending on the load, telling me that >the auxiliary alternator is now carrying the load of the aircraft. If the >AUX Alternator goes off line, I don't know how I'll know unless the engine >monitor triggers a low volt warning. Do I have it correct? If it were my airplane, I'd wire it as described in Z-12. I believe all the bases for functionality and serviceability have been covered. Bob . . . ________________________________________________________________________________
Subject: ACS2002 Voltage Selector
Date: Dec 22, 2003
Bob, I wonder if you could propose a solution for the following: The ACS2002 engine monitor uses the bus for a power source and also to monitor bus voltage. If I have the dual electrical system (Z-14), how does one select main and aux bus voltage without breaking the power source for the monitor? I assume that I would re-boot the system every time that I changed the voltage selection via a single pole double throw switch. I am sure there is a better solution. Thanks for your help. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ________________________________________________________________________________
Date: Dec 22, 2003
Robert L. Nuckolls, III wrote: >>Then what is the purpose of the AUX ALT switch? If it is supposed to be >>on always, one can always use the AUX C/B to take the Aux alternator off-line. >> >> > > You can do that if you wish. This system was crafted mostly to > support adding a capable alternator to an existing system . . . > particularly certified ships. The feds wouldn't look kindly > on using a circuit breaker as a panel control. However, the > C210 installation does in fact use a switch-breaker for the > bus-feed control. > > Hi Bob, I'm perhaps showing my newbie ignorance here, but why would the feds have an issue with using a switch-breaker as a panel control? Isn't that what they are designed for? -Dj, curious... ________________________________________________________________________________
Date: Dec 22, 2003
Subject: EGT / CHT wiring urban ....
I have always heard that CHT / EGT wires have to be the material provided with the probes all the way from the probe to the instrument. Then I heard somewhere (might have been here) that you can switch from the "trick" wire coming out of the probe to standard wire (or use a rotary switch to step through the cylinders on a single readout gauge) and maintain acceptable accuracy provided the ambient temperature at the junction was stable (like inside the cabin). Is there anything to this? Can I switch to standard wire from the firewall of an EZ or put a rotary switch and standard wire between the "trick" wire and the display? How much of all this is urban legend .... Jim S. ________________________________________________________________________________
Date: Dec 22, 2003
> If you eliminate the switch (and the breaker stays normally > closed) the s/b alternator comes up immediately after starting > the engine. That's okay isn't it? I assumed that you don't mess with the switch during start-up, but rather just leave it on. > The warning light for primary alternator controller is LOW VOLTS. > It will continue to function in that capacity even when the main > alternator is off. If the main alternator is off/failed and > the aux alternator is up, the LOW VOLTS warning light should be > out and the AUX ALT light would be on. If the aux alternator is > off/failed, then the LOW VOLTS light will be flashing. > That was the nugget of information that was missing from my brain. Thanks. Randy ________________________________________________________________________________
Date: Dec 22, 2003
Subject:
>... No, there aren't any Visio symbols/shapes on the CD, I'm >afraid you have to come up with your own. > >Bob; This Visio shape topic seems to be a recurring thing, perhaps we >should start submitting our shapes to your for archival on the CD?? That would be great! I also installed the trial version of SmartDraw, which works pretty much like Visio, and has some nice shapes. I kind of hate to plunk down another 198 bucks for an application when all I need are some shapes. It would be nice to ditch Visio, tho, now that they are part of MS, but if I stumble across a bunch of shapes that look like Bob's, I'm there. Thanks, Mickey -- Mickey Coggins GSM: +41-79-210-3762 FAX: +41-86-079-210-3762 http://www.rv8.ch/ #82007 Empennage complete, waiting for wings to arrive ________________________________________________________________________________
Date: Dec 22, 2003
I will take a stab at this one: If you get a capacitor and figure out how much current the unit needs to "stay Powered" while your momentarily switching it via the switch this would allow you to monitor both sources. How big, is really dependant of how much the unit draws and how long the "break " is in the switch I bet somebody knows how to figure that out better than I Hope that helps Jeff. Bob, I wonder if you could propose a solution for the following: The ACS2002 engine monitor uses the bus for a power source and also to monitor bus voltage. If I have the dual electrical system (Z-14), how does one select main and aux bus voltage without breaking the power source for the monitor? I assume that I would re-boot the system every time that I changed the voltage selection via a single pole double throw switch. I am sure there is a better solution. Thanks for your help. Pat Hatch RV-4 RV-6 RV-7 QB (Building) Vero Beach, FL ________________________________________________________________________________
Date: Dec 22, 2003
Subject: Re: EGT / CHT wiring urban ....
If the temperature where you make the junction between the thermocouple wire and the copper wire and the temperature at the instrument that converts the temperature to a display is the same, then there will be no error and there is no reason you cannot do this. Any temperature difference between these two points will be reflected in the reading accuracy. This inaccuracy may be negligible if it is small and you are measuring high temperatures (E.G. EGT) especially if you are primarily trying to match several temperatures or find out which one is highest. For instance, if you change wire type at the firewall which is 90 degrees while the instrument junction is 70 degrees, your readings will be off by 20 degrees high. If the temperature is the same there will be no error. The way thermocouple wires work is by generating a small voltage (mV) between the dissimilar metal wires. Every metal junction will generate a voltage which is dependent on the actual temperature and the particular metals involved. The instrument that uses the thermocouple wire input senses the temperature where the thermocouple wires connect to the instrument and compensates for the voltage generated there - resulting in a reading of the remote (EGT or CHT) junction. If you add a length of copper wire between the thermocouple wire and the instrument, then the instrument will still compensate for the temperature where the wire connects. Only now, there is no voltage being generated there since the actual junction is somewhere else. But, as noted earlier, if the temperatures of the two ends of the copper wire are similar the compensation will still work. The same thing applies if you use a switch only there are more junctions involved. Dick Tasker, RV9A #90573 Jim Sower wrote: > >I have always heard that CHT / EGT wires have to be the material provided with the probes >all the way from the probe to the instrument. Then I heard somewhere (might have been here) >that you can switch from the "trick" wire coming out of the probe to standard wire (or use a >rotary switch to step through the cylinders on a single readout gauge) and maintain >acceptable accuracy provided the ambient temperature at the junction was stable (like inside >the cabin). Is there anything to this? Can I switch to standard wire from the firewall of >an EZ or put a rotary switch and standard wire between the "trick" wire and the display? > >How much of all this is urban legend .... Jim S. > ________________________________________________________________________________
Date: Dec 22, 2003
> >I have always heard that CHT / EGT wires have to be the material provided >with the probes >all the way from the probe to the instrument. Then I heard somewhere >(might have been here) >that you can switch from the "trick" wire coming out of the probe to >standard wire (or use a >rotary switch to step through the cylinders on a single readout gauge) and >maintain >acceptable accuracy provided the ambient temperature at the junction was >stable (like inside >the cabin). Is there anything to this? Can I switch to standard wire >from the firewall of >an EZ or put a rotary switch and standard wire between the "trick" wire >and the display? See: http://www.aeroelectric.com/articles/excerpt.pdf Bob . . . ________________________________________________________________________________
Date: Dec 22, 2003
This is what I was told by a manufacturer and others (hope I remember it correctly): One needs to have the same kind of wire, kind is dependent upon the thermocouple (TC), all the way from the sensor to the final instrument. If you need a multi-way switch, use the same kind of wire to the switch, then it is conservative to use the same kind of wire from the switch to the instrument. Caveat: the switch needs to be in the same temperature zone as the instrument since the 'cold junction' matches are critical to sensor/instrument accuracy. Anytime one has a connection in the sensor wire, one creates another cold junction. One can't mix a digital instrument with an analog system and maintain accuracy to either one. HTH, AI Nut using EGT/CHT per cylinder to feed analog to digital convertor then to computer, via Analog Devices 594/595 chips. ----- Original Message ----- From: "Jim Sower" <canarder(at)frontiernet.net> Subject: AeroElectric-List: EGT / CHT wiring urban .... > > I have always heard that CHT / EGT wires have to be the material provided with the probes > all the way from the probe to the instrument. Then I heard somewhere (might have been here) > that you can switch from the "trick" wire coming out of the probe to standard wire (or use a > rotary switch to step through the cylinders on a single readout gauge) and maintain > acceptable accuracy provided the ambient temperature at the junction was stable (like inside > the cabin). Is there anything to this? Can I switch to standard wire from the firewall of > an EZ or put a rotary switch and standard wire between the "trick" wire and the display? > > How much of all this is urban legend .... Jim S. > > ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: XPDR strobe ?
Date: Dec 23, 2003
Hi all, The AK 350 encoder instruction sheet mentions a strobe wire. What is that strobe wire for ? Thanks, Gilles ________________________________________________________________________________
Date: Dec 22, 2003
AI Nut wrote: > >This is what I was told by a manufacturer and others (hope I remember it >correctly): > >One needs to have the same kind of wire, kind is dependent upon the >thermocouple (TC), all the way from the sensor to the final instrument. > This is best practice, but not necessarily required. For example, if you are measuring a high temperature (EGT) and are only tuning for some amount lean or rich of peak, then any errors caused by connecting the thermocouple wires to copper wires somewhere between the measurement and the instrument are essentially negligible - especially if the junction is at approximately the same temperature as the instrument. On the other hand, if you are trying to measure a temperature closer to ambient, it is much more important to use thermocouple wire all the way (see comment below also). >If you need a multi-way switch, use the same kind of wire to the switch, >then it is conservative to use the same kind of wire from the switch to the >instrument. Caveat: the switch needs to be in the same temperature zone as >the instrument since the 'cold junction' matches are critical to >sensor/instrument accuracy. > This is not true if you actually use thermocouple wire from the switch to the instrument. As long as all terminals of the switch are at the same temperature all the junction potentials cancel out (i.e. thermocouple from the measurement point to switch contact generates one voltage and switch contact to thermocouple connected to the instrument generates an opposite polarity voltage). >Anytime one has a connection in the sensor >wire, one creates another cold junction. > True. >One can't mix a digital instrument with an analog system and maintain >accuracy to either one. > >HTH, >AI Nut >using EGT/CHT per cylinder to feed analog to digital convertor then to >computer, via Analog Devices 594/595 chips. > > Dick Tasker, RV9A #90573 ________________________________________________________________________________
Date: Dec 23, 2003
bob whats you feeling about using the EXP Buss system and not using the normal circut breaker type set up? Tom ware ________________________________________________________________________________
Date: Dec 22, 2003
Subject: Re: XPDR strobe ?
Gilles, If your transponder uses the strobe line (most don't these days), then connect that wire. Otherwise just connect it to ground. Happy wiring. Regards, Neal Gilles.Thesee wrote: > >Hi all, > >The AK 350 encoder instruction sheet mentions a strobe wire. >What is that strobe wire for ? > >Thanks, > >Gilles > > > > ________________________________________________________________________________
Date: Dec 23, 2003
> If your transponder uses the strobe line (most don't these days), then > connect that wire. Otherwise just connect it to ground. Neal, Thank you for answering. I was able to complete the wiring last summer. Actually, I should hava asked "what is the purpose of the strobe line in a transponder ?" Thanks, Gilles ________________________________________________________________________________
Date: Dec 23, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >Robert L. Nuckolls, III wrote: > > >>Then what is the purpose of the AUX ALT switch? If it is supposed to be > >>on always, one can always use the AUX C/B to take the Aux alternator > off-line. > >> > >> > > > > You can do that if you wish. This system was crafted mostly to > > support adding a capable alternator to an existing system . . . > > particularly certified ships. The feds wouldn't look kindly > > on using a circuit breaker as a panel control. However, the > > C210 installation does in fact use a switch-breaker for the > > bus-feed control. > > > > > >Hi Bob, > I'm perhaps showing my newbie ignorance here, but why >would the feds have an issue with using a switch-breaker >as a panel control? Isn't that what they are designed for? > >-Dj, curious... Breakers and fuses protect wires and are generally placed as close to the high-current source (bus) that supplies the wire. Many builders have elected to use a mix of switch-breakers on pilots side and more common push-pull or push-only breakers on the copilot's side. This causes you to build a large bus structure that spreads across the panel. One of the fuse-block's more endearing features is the compact, nearly completely inclosed, ready made bus that runs down the middle of the assembly. In the case of the C210, I don't think they had room in the breaker panel for enough new breakers to accommodate the SD-20 installation. They were able to get the kit approved with a relatively short (but probably longer than 6") always-hot-and-unprotected wire feeding the panel mounted switch-breaker (fusible link would have been a good lick here). Using a switch-breaker in lieu of the push-pull breaker/toggle switch combination solved the logistics problem. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Re: ACS2002 Voltage Selector
> >Bob, > >I wonder if you could propose a solution for the following: > >The ACS2002 engine monitor uses the bus for a power source and also to >monitor bus voltage. If I have the dual electrical system (Z-14), how >does one select main and aux bus voltage without breaking the power source >for the monitor? I assume that I would re-boot the system every time that >I changed the voltage selection via a single pole double throw switch. I >am sure there is a better solution. Thanks for your help. Try it first. Switch transition times may be fast enough for the systems internal filter caps to hold voltage up during transfer. If not . . . You can install a capacitor across the + supply to the system to store energy needed to support he monitor during switch transition. Just as a rough idea of capacitor size, 1 amp of current flow changes the voltage across a 1 farad capacitor at the rate of 1 volt per second. Assume your system draws 1 amp and lets use 100 mS as a reasonable transition time. Assume further that the system stays active at 10v or above. Sooo . . . we can tolerate up to say 3 volts of drop for 100 mS at 1A of system draw. Taking the relationship I cited: A V ----- = ------ C S or: 1 = 3 ----- ----- C .1 transposing we get: .1 C = ----- = 33,000 microfarads 3 If your current is lower, the size of the capacitor goes down in proportion. If your allowable voltage drop is higher, the capacitor goes down in proportion. If the switch transition time is longer, the capacitor goes up in proportion. The relationships cited assume constant current draw as voltage changes which may not be true but will be in the ballpark for the purposes of this calculation. B&C stocks a 47,000 uF cap (Cat #S251D479) for $12 that has a high order of probability for taking care of this problem with no additional need for discovery. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Re: Wiring Diagrams Available
> > > If you eliminate the switch (and the breaker stays normally > > closed) the s/b alternator comes up immediately after starting > > the engine. > >That's okay isn't it? I assumed that you don't mess with the >switch during start-up, but rather just leave it on. It's your checklist. I prefer to turn everything off at shutdown and bring things back up one at a time after startup as part of a preflight analysis of system operation. Exercising switches while watching for expected results is a generally good policy. This is one reason why I prefer to turn radios off via their front panel switches (as opposed to the "convenience" of brining all radios on with an avionics master). You put your hands on each radio and see that it comes alive as opposed to flipping one switch and assuming that everything on that switch is working okay. This would apply to the aux alternator as well. The ACTION of flipping the switch in the checklist is paired with an OBSERVATION of expected behavior. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Re: Fuel sw?
> > >Hi, >new to the list, about 8 months from first flight RV8 in UK. Three >electrical bits puzzling me and wonder if you can help. > >1. Have an IO 360 (injected ) engine. I am supposing that a simple toggle, >on/off will suffice for the fuel pump? Sure. >2. My essential bus is to get me on the ground as soon as >possible...endurance not the issue that many people want. We cannot fly >IMC or at night in UK with home build. After 13000 hrs "conditioning" as >an airline pilot I do not want to stay airborne with an unresolved >electrical problem....especially when I have constructed the set up! In UK >never far from a landable site. >I want to supply the VHF, Tx Pdr, EFIS Lite(Blue Mountain ) AND Flap >motor from the essential bus, normally via a silicone diode from the main >bus. In non normal mode Flaps would be selected when Visual, clear to Land >and committed....if any pwr left. What size , type of diode do I need for >normal operation of such a system? Doesn't sound like you need an E-bus. Why put an EFIS system in an airplane that will never need it? Given the rules of engagement for OBAM aircraft in the UK, it might be practical to build this ship up like a super-J3. If you're interested in aerobatics, you could take out a LOT of weight by incorporating a minimal electrical system to support the starter and a couple of radios. >3. Any thoughts on best solution to wiring in the ammeter? If you're talking about the classic minus-zero-plus reading battery ammeter, this too is a throwback to the way we wired airplanes in 1946. Use of this instrument requires that the alternator b-lead be brought into the cockpit and tied to the main bus . . . something that is useful to avoid. Perhaps your needs are better served with incorporation of system architecture described in Van's literature for the kit. Similar systems are described in works by Tony Bingelis. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
> This is one reason why I prefer to turn radios off via their > front panel switches (as opposed to the "convenience" of > brining all radios on with an avionics master). You put your > hands on each radio and see that it comes alive as opposed to > flipping one switch and assuming that everything on that switch > is working okay. This would apply to the aux alternator as well. > The ACTION of flipping the switch in the checklist is paired > with an OBSERVATION of expected behavior. That's really a great piece of advice. I never looked at it that way. Thank you for the insight. Randy F1 Rocket http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Dec 23, 2003
Subject: Re: Shield termination KCS55A/KI525A
> > >Hello, > >I'm hoping someone can recommend where to attach the shield terminations >for a KI525A HSI. I've seen photo's (cannot find link) that show the >shield terminations attached to the screw on the KI525's connector >strain relief. I'm really not happy with this because the strain relief >is just floating in the slot of the back shell and the back shell itself >is only attached electrically to the connector alignment/keying posts >(still just floating). It's a common practice to tie shields to connector backshells in avionics installations. Obviously, this works ONLY when all connector shells are metallic . . . the goal is to get shields connected to the outer case of the accessory. If your hardware doesn't seem to achieve this goal, then tying shields to a "ground" pin in the connector is a better bet. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
> >This is what I was told by a manufacturer and others (hope I remember it >correctly): > >One needs to have the same kind of wire, kind is dependent upon the >thermocouple (TC), all the way from the sensor to the final instrument. > >If you need a multi-way switch, use the same kind of wire to the switch, >then it is conservative to use the same kind of wire from the switch to the >instrument. Caveat: the switch needs to be in the same temperature zone as >the instrument since the 'cold junction' matches are critical to >sensor/instrument accuracy. Anytime one has a connection in the sensor >wire, one creates another cold junction. It's more accurate to say that deleterious effects of any parasitic thermocouples generated when introducing foreign metals can be minimized as long as whatever is done to one side of the thermocouple path is done to the other side but in opposite polarity . . . it's a sorta two-wrongs-can- make-a-right approach. For our purposes, this rule of thumb works as error-balancing issues are small. When in doubt, don't intermix alloys in the wiring to any greater extent than necessary. >One can't mix a digital instrument with an analog system and maintain >accuracy to either one. Not necessarily true. It depends on the input signal conditioning techniques used in each instrument. It MIGHT work just fine. Bob . . . ________________________________________________________________________________
Date: Dec 23, 2003
> >bob whats you feeling about using the EXP Buss system and not using the >normal circut breaker type set up? >Tom ware I don't believe this product to be of good value. For what this item costs, you can buy ALL of the goodies needed to wire your airplane and have $ left over. Further, what ends up in your airplane is EXACTLY what you want, not what someone thinks you need in a plug-n-play product. The product isn't "unsafe" and probably performs as advertised. See: http://www.aeroelectric.com/articles/expbusad.html http://www.aeroelectric.com/articles/expbusthd.html Bob . . . ________________________________________________________________________________
From: "'Scott Richardson'" <scott_m_richardson(at)sbcglobal.net>
Date: Dec 23, 2003
So along these lines, I'm designing a engine temperature scanner that allows me to scan through the two sets of temperatures and send one of each of CHT and EGT to my RMI Micromonitor which only accepts a single CHT and EGT. In following Bob's advice around the switching of thermocouple wires, I've also tried to keep the traces around my PC board as equal in length as possible between cylinders and between the two wires in a thermocouple. I'm also intending to mount the scanner on my panel next to my RMI unit and run all thermocouple leads right up to it. So the questions I have are two: o How concerned should I be about keeping all the PCB traces the same length? From the previous discussions, it sounds like all I really need to worry about is keeping everything at the same temperature. o I'm planning on using CD4052 multiplexer IC's which are used for analog signals. These chips can pass a max of 20V p-p analog signals. Does anyone see any issues with these when the thermocouple signals are on the order of 10's of mV? o I'm assuming that in general of the J and K type thermocouples we use for CHT and EGT, that the signals are always positive or always negative (depending on how they're connected to the measuring device) in the temp ranges we use. Is this a correct assumption? As always, thanks for the help. Scott -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: EGT / CHT wiring urban .... --> > >This is what I was told by a manufacturer and others (hope I remember >it >correctly): > >One needs to have the same kind of wire, kind is dependent upon the >thermocouple (TC), all the way from the sensor to the final instrument. > >If you need a multi-way switch, use the same kind of wire to the >switch, then it is conservative to use the same kind of wire from the >switch to the instrument. Caveat: the switch needs to be in the same >temperature zone as the instrument since the 'cold junction' matches >are critical to sensor/instrument accuracy. Anytime one has a >connection in the sensor wire, one creates another cold junction. It's more accurate to say that deleterious effects of any parasitic thermocouples generated when introducing foreign metals can be minimized as long as whatever is done to one side of the thermocouple path is done to the other side but in opposite polarity . . . it's a sorta two-wrongs-can- make-a-right approach. For our purposes, this rule of thumb works as error-balancing issues are small. When in doubt, don't intermix alloys in the wiring to any greater extent than necessary. >One can't mix a digital instrument with an analog system and maintain >accuracy to either one. Not necessarily true. It depends on the input signal conditioning techniques used in each instrument. It MIGHT work just fine. Bob . . . == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Dec 23, 2003
Scott, The trace lengths will not make much difference, however you need to be careful in your circuit design as that the thermocouples often have ground loop problems. That is a CHT probe on #1 and CHT probe on #4 may have a different DC offset. Therefore you have to be careful in you mux design. Specifically most muxes have diode clamps on the inputs for ESD protection of the internal circuits (MOS transistors) therefore lets say that CHT #1 has a -1V DC offset, which can happen if the ground connection is not great. Then the mux diodes would clip this to -0.7V if the negative rail of the mux is grounded. Thus you CHT reading will not be correct. To fix this problem it is best to use a negative voltage for the Vdd of the mux, which means not only do you need a positive rail but also a negative voltage rail. The negative voltage rail is not too hard to generate using a switcher or a pump circuit but it is one more thing to consider. I know that as I designed my engine monitor I ran into a lot of problems with ground loop noise where the noise was only a few millivolts. I finally designed my unit rails such that I could have over a +/-2V ground loop with out effecting the measurement. The final results were that I could get less than 5 degrees of error in my measurements on 8 cylinders updated around 10 times a second. If you need further assistance in your mux design let me know. Regards, Trampas Stern -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of 'Scott Richardson' Subject: RE: AeroElectric-List: EGT / CHT wiring urban .... So along these lines, I'm designing a engine temperature scanner that allows me to scan through the two sets of temperatures and send one of each of CHT and EGT to my RMI Micromonitor which only accepts a single CHT and EGT. In following Bob's advice around the switching of thermocouple wires, I've also tried to keep the traces around my PC board as equal in length as possible between cylinders and between the two wires in a thermocouple. I'm also intending to mount the scanner on my panel next to my RMI unit and run all thermocouple leads right up to it. So the questions I have are two: o How concerned should I be about keeping all the PCB traces the same length? From the previous discussions, it sounds like all I really need to worry about is keeping everything at the same temperature. o I'm planning on using CD4052 multiplexer IC's which are used for analog signals. These chips can pass a max of 20V p-p analog signals. Does anyone see any issues with these when the thermocouple signals are on the order of 10's of mV? o I'm assuming that in general of the J and K type thermocouples we use for CHT and EGT, that the signals are always positive or always negative (depending on how they're connected to the measuring device) in the temp ranges we use. Is this a correct assumption? As always, thanks for the help. Scott -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: EGT / CHT wiring urban .... --> > >This is what I was told by a manufacturer and others (hope I remember >it >correctly): > >One needs to have the same kind of wire, kind is dependent upon the >thermocouple (TC), all the way from the sensor to the final instrument. > >If you need a multi-way switch, use the same kind of wire to the >switch, then it is conservative to use the same kind of wire from the >switch to the instrument. Caveat: the switch needs to be in the same >temperature zone as the instrument since the 'cold junction' matches >are critical to sensor/instrument accuracy. Anytime one has a >connection in the sensor wire, one creates another cold junction. It's more accurate to say that deleterious effects of any parasitic thermocouples generated when introducing foreign metals can be minimized as long as whatever is done to one side of the thermocouple path is done to the other side but in opposite polarity . . . it's a sorta two-wrongs-can- make-a-right approach. For our purposes, this rule of thumb works as error-balancing issues are small. When in doubt, don't intermix alloys in the wiring to any greater extent than necessary. >One can't mix a digital instrument with an analog system and maintain >accuracy to either one. Not necessarily true. It depends on the input signal conditioning techniques used in each instrument. It MIGHT work just fine. Bob . . . == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Subject: KA-134 and Wiring Diagram
Date: Dec 23, 2003
I need a wiring diagram/schematic and Owner's Manual for a Bendix/King KA-134 Audio Panel. Does anyone know where I can purchase one or have a copy they would be willing to share? I would gladly reimburse expenses.... Thanks, Jack Lockamy Camarillo, CA ________________________________________________________________________________
Subject: Resistive Fuel Sensors
Date: Dec 23, 2003
I'm installing Stewart Warner resistive fuel sensors in my RV9A. To provide some redundancy I am considering adding a set of Vans analog gauges, in series with a Grand Rapids EIS4000. Are there any concerns about having more than one gauge attached to these sensors? Thanks Mike Holland N192MH Reserved ________________________________________________________________________________
Date: Dec 23, 2003
> Are there any concerns about having more than one gauge attached > to these sensors? Now that's a question I'd like to hear the answer to. My system needs 3 oil pressure sensors (hobbs, gauge and voice annunciator). Can I use the same sensor for all of them? Same's true of oil temp & coolant temp. ________________________________________________________________________________
Date: Dec 24, 2003
From: "Ronald J. Parigoris" <rparigor(at)SUFFOLK.LIB.NY.US>
Subject: Turbo pressure to mags?
I know that when flying high, that Turbo pressure is sent to mags. In WW2 They sent pressure to ignition harnesses as well. I am not sure why this suppresses arcing???? I think a vacuum is a better insulator than air??? Is it perhaps that it is not just pressurized, but is allowing an airflow to cool things down? Thx. Ron Parigoris ________________________________________________________________________________
Date: Dec 24, 2003
Hi Bob, the background to EFIS in my "8" is as follows. I would never choose to fly IFR or at night with one engine driving the one prop thing for me to do.(despite my 13000 hrs flying...or maybe because of it?!)... My EFIS Lite weighs 520 grammes...about 3.25 Lbs. For this I get all the basic flight insts plus a GPS driven moving map plus a nav system (virt VOR with 360 "compass".) Its a heck of a lot of kit for 500 grammes! We dont have much free airspace on our little Island and we need to be able to either find our way around with great accuracy or accept help with radar headings in order to avoid all the controlled airspace when in our home builds. Yes I like aeros but I also want to tour with my `plane. The set up proposed would be very unwise given the above and our weather when visual can mean "in sight of the ground" but with perhaps no discernable horizon. So this was my logic to having stnd by power available , for at least ten minutes battery operation. This would give me time to get back on the ground in most circumstances that I can imagine when flying over land in UK. The ammeter question is well off my patch hence the dumb question. However, what I was referring was the advice on pages 7-12 and 7-13 of "The Aeroelectric Connection". I wondered if I wired it to the B lead just before my starter relay ....would that be a reasonable thing to do? Is there a better solution? Have I completely miss understood again! rgds Steve ________________________________________________________________________________
Subject: Fuel Sw
Date: Dec 24, 2003
Whoops, just re read my latest dumb question.What I meant to say was....would you recommend I fit a battery ammeter as described on page 7-14, or is there a better solution(less weighty)....or indeed is this me being old fashioned and I simply dont need one? I will try to make the Kansas seminar!!! Steve ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Re: Turbo pressure to mags?
> > >I know that when flying high, that Turbo pressure is sent to mags. > >In WW2 They sent pressure to ignition harnesses as well. > >I am not sure why this suppresses arcing???? > >I think a vacuum is a better insulator than air??? Not at all. Your spark plugs used to be tested by observing the spark gap through a windowed chamber while air pressure was adjusted until the spark would just stop. The better plugs will spark at 150 psi, poorer ones at lesser pressures. Vacuum tubes won't function with even a small amount of air present. >Is it perhaps that it is not just pressurized, but is allowing an airflow >to cool >things down? Turbo C210's and Mooney's have a small pipe that takes pressurized air downstream of turbochargers to the magneto housings. Without such pressurization, they're in danger of internal arc-over. Waveguides in the B-52 radar system are pressurized, without pressurization, the 50 kilowatt pulse of energy going out to the antenna would never make it . . . one would have a little storm of mini-lightning strikes going on somewhere in the feedline. Bob . . . ________________________________________________________________________________
Date: Dec 24, 2003
Air at atmospheric pressure is more resistant to arcing than lower pressure air. If you had a true vacuum then the arcing would be even more suppressed, but at high altitudes you only have lower pressure - not vacuum. As you mentioned, higher pressure air cools better. My $0.02... Dick Tasker Ronald J. Parigoris wrote: > >I know that when flying high, that Turbo pressure is sent to mags. > >In WW2 They sent pressure to ignition harnesses as well. > >I am not sure why this suppresses arcing???? > >I think a vacuum is a better insulator than air??? > >Is it perhaps that it is not just pressurized, but is allowing an airflow to cool >things down? > >Thx. >Ron Parigoris > > > > ________________________________________________________________________________
Date: Dec 24, 2003
----- Original Message ----- From: "Steve Hunt" <Stephen.Hunt19(at)btinternet.com> Subject: Re: AeroElectric-List: Fuel sw? > > Hi Bob, > > the background to EFIS in my "8" is as follows. > > I would never choose to fly IFR or at night with one engine driving the one prop , its not wrong to do this elsewhere,however, I simply dont think it is a good thing for me to do.(despite my 13000 hrs flying...or maybe because of it?!)... > > My EFIS Lite weighs 520 grammes...about 3.25 Lbs. For this I get all the basic flight insts plus a GPS driven moving map plus a nav system (virt VOR with 360 "compass".) Its a heck of a lot of kit for 500 grammes! > > We dont have much free airspace on our little Island and we need to be able to either find our way around with great accuracy or accept help with radar headings in order to avoid all the controlled airspace when in our home builds. > > Yes I like aeros but I also want to tour with my `plane. > > The set up proposed would be very unwise given the above and our weather when visual can mean "in sight of the ground" but with perhaps no discernable horizon. > > So this was my logic to having stnd by power available , for at least ten minutes battery operation. This would give me time to get back on the ground in most circumstances that I can imagine when flying over land in UK. > > > The ammeter question is well off my patch hence the dumb question. However, what I was referring was the advice on pages 7-12 and 7-13 of "The Aeroelectric Connection". I wondered if I wired it to the B lead just before my starter relay ....would that be a reasonable thing to do? Is there a better solution? Have I completely miss understood again! > > rgds > > Steve > > Hi! Good news; 520 g is more like 1,15 lbs so you just saved another 2,1 lbs! Regards Tore S Bristol Norway > > ________________________________________________________________________________
From: "Pete & Farrell Rouse" <pete-farrell(at)kc.rr.com>
Date: Dec 24, 2003
Ron, There is something called 'breakdown voltage' that is basically the voltage necessary to ionize the air sufficiently between a gap of a know distance to induce an arc across the gap. The breakdown voltage gets lower as the air density gets lower, thus the breakdown voltage decreases with increasing altitude. There is something called the 'Paschen Curve' that describes this phenomenon. The higher the voltage, the more probability of arcing at altitude. The only reason I am able to comment on this at all, is that I asked a very similar question in the last few days. Well, I just ran out of knowledge, so I'll shut up now..... Happy Holidays, Pete Rouse ----- Original Message ----- From: "Ronald J. Parigoris" <rparigor(at)SUFFOLK.LIB.NY.US> Subject: AeroElectric-List: Turbo pressure to mags? > > I know that when flying high, that Turbo pressure is sent to mags. > > In WW2 They sent pressure to ignition harnesses as well. > > I am not sure why this suppresses arcing???? > > I think a vacuum is a better insulator than air??? > > Is it perhaps that it is not just pressurized, but is allowing an airflow to cool > things down? > > Thx. > Ron Parigoris > > ________________________________________________________________________________
Date: Dec 24, 2003
Some sensors you can put in parallel with multiple gauges. Most sensors which have three wires, like most resistive float senders outputs a voltage on one of the pins which varies. Multiple gauges can be placed in parallel with theses sensors, assuming the gauges have a relative high impedance input. Now with that said you would have to check with EIS to determine if their unit can be put in parallel with an analog gauge. As far as oil pressure if you use a switch it is easy to have multiple devices triggered off the same switch. One of the big things in my mind about using multiple gauges is for the redundancy, however if you are using the same sensor then your redundancy is really not there, since from my experience the sensor is more likely to fail than a gauge. Personally I see a need for a back up oil pressure gauge and a back up voltage gauge, especially with electronic instruments. Let's not forget that your job is to fly the plane, with or with out engine running. As far as knowing how much fuel you have which most people have a reasonable guess based on experience, after all if you are unsure of your fuel level, then you need fuel. Regards, Trampas -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Slade Subject: RE: AeroElectric-List: Resistive Fuel Sensors > Are there any concerns about having more than one gauge attached > to these sensors? Now that's a question I'd like to hear the answer to. My system needs 3 oil pressure sensors (hobbs, gauge and voice annunciator). Can I use the same sensor for all of them? Same's true of oil temp & coolant temp. ________________________________________________________________________________
Date: Dec 24, 2003
Here is a chart that lists the dielectric strengths of various common materials. Note that vacuum is one of the lowest (worst) dielectric strengths. Regards, Matt- N34RD Dielectric strengths for insulators Dielectric strength in kilovolts per inch (kV/in): Material* Dielectric strength ========================================= Vacuum --------------------- 20 Air ------------------------ 20 to 75 Porcelain ------------------ 40 to 200 Paraffin Wax --------------- 200 to 300 Transformer Oil ------------ 400 Bakelite ------------------- 300 to 550 Rubber --------------------- 450 to 700 Shellac -------------------- 900 Paper ---------------------- 1250 Teflon --------------------- 1500 Glass ---------------------- 2000 to 3000 Mica ----------------------- 5000 > > > I know that when flying high, that Turbo pressure is sent to mags. > > In WW2 They sent pressure to ignition harnesses as well. > > I am not sure why this suppresses arcing???? > > I think a vacuum is a better insulator than air??? > > Is it perhaps that it is not just pressurized, but is allowing an > airflow to cool things down? > > Thx. > Ron Parigoris > > ________________________________________________________________________________
From: "Paul A. Franz, P.E." <paul(at)eucleides.com>
Date: Dec 24, 2003
On Wed, 2003-12-24 at 07:59, Richard Tasker wrote: > > Air at atmospheric pressure is more resistant to arcing than lower > pressure air. If you had a true vacuum then the arcing would be even > more suppressed, but at high altitudes you only have lower pressure - > not vacuum. As you mentioned, higher pressure air cools better. Voltage required to arc is actually a U shaped curve with the minimum arcing voltage to hop a 1 cm gap occurring at about 150,000 FT DA. Rather than depend on air as an insulator in high flying stuff Reynolds makes elastomer seals that aren't susceptible to this arc length creep. <http://www.reynoldsindustries.com/product/2multipin/page17.asp> The above link shows Paschen's 19th century results when this was studied. -- PAF Consulting Engineers | 427 - 140th Ave NE (425)641-8202 voice | Bellevue, WA 98005 (425)641-1773 fax | GnuPG Public Key - <http://eucleides.com/pgpkey.asc> ________________________________________________________________________________
Date: Dec 24, 2003
Ron You have it backwards. Air is a relatively poor conductor. It acts as an insulator. Since the air at high altitudes is less dense, it is not as good at insulating spark arcing. Pressurizing the interior of the magnetoes and the wiring harnesses helps suppress arcing by supplying a more dense atmosphere. Charlie Kuss > > From: "Ronald J. Parigoris" <rparigor(at)SUFFOLK.LIB.NY.US> > Date: 2003/12/24 Wed AM 02:50:06 EST > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Turbo pressure to mags? > > ________________________________________________________________________________
Date: Dec 24, 2003
Subject: Re: Fuel Sw
> > >Whoops, >just re read my latest dumb question.What I meant to say was....would you >recommend I fit a battery ammeter as described on page 7-14, or is there a >better solution(less weighty)....or indeed is this me being old fashioned >and I simply dont need one? > >I will try to make the Kansas seminar!!! Battery ammeters have some degree of utility for troubleshooting as do alternator loadmeters. The later are easier to install while maintaining a minimize the fat-wires-in-the-cockpit philosophy. I'd recommend a loadmeter if you have any ammeter at all. A low voltage warning light may well suffice for all necessary in-flight electrical system instrumentation. Bob . . . ________________________________________________________________________________
Subject: RE: Thermocouples
Date: Dec 24, 2003
<then it is conservative to use the same kind of wire from the switch to the >instrument. Caveat: the switch needs to be in the same temperature zone as >the instrument since the 'cold junction' matches are critical to >sensor/instrument accuracy. Anytime one has a connection in the sensor >wire, one creates another cold junction. It's more accurate to say that deleterious effects of any parasitic thermocouples generated when introducing foreign metals can be minimized as long as whatever is done to one side of the thermocouple path is done to the other side but in opposite polarity . . . it's a sorta two-wrongs-can- make-a-right approach.>> Bob is certainly correct here. A long time ago when we were using passive "pyrometers," really just voltmeters, to read thermocouples we even went as far as to use a special selector switch that was made of the right materials. But then I worked at a powerplant one summer and there were thermocouples half a mile away from the instrument. We ran the TC wires to a junction box, connected them to copper and ran the rest of the way in copper. For an aircraft it would work just fine that way. Splice the TC wires under the cowl to copper wires, run the copper wires to an ordinary wafer switch if you like, and then to the instrument. Just make sure you don't make a spice on one side of the circuit at a location that is at a different temperature than the splice on the other side of the circuit. It all works very easily and if there is an error it is so small that you'll never find it. Gary Casey ________________________________________________________________________________
Subject: RE: Turbo pressure to mags?
Date: Dec 24, 2003
I know that when flying high, that Turbo pressure is sent to mags. In WW2 They sent pressure to ignition harnesses as well. I am not sure why this suppresses arcing???? I think a vacuum is a better insulator than air??? Is it perhaps that it is not just pressurized, but is allowing an airflow to cool things down? Thx. Ron Parigoris>> Vacuum might be a better INSULATOR, but the higher the pressure of the air the higher its DIELECTRIC STRENGTH. In other words it will take a higher voltage to arc when the pressure is higher. And this is why the magnetos are sometimes pressurized. The problem mostly exists at the rotor where at some voltage the current will arc to another post rather than to a plug. A Naturally Aspirated engine doesn't have this problem because the pressure in the cylinder also goes down with higher altitude. A supercharged engine is typically operated at a constant manifold pressure and hence a constant cylinder pressure regardless of altitude. If the magneto is pressurized the potential for cross-firing is minimized. Gary Casey ________________________________________________________________________________
Date: Dec 24, 2003
Re mags: If you use Bendix 1200 mags, they do NOT need to be pressurized until above about 28000 feet. If you use Slick mags, they need to be pressurized above about 12,000'. Very simple. Very predictable. Very repeatable. I have flown an unpressurized set of Bendix 1200 series mags to 33,000'D.A. before they started to arc. Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Gary Casey Subject: AeroElectric-List: RE: Turbo pressure to mags? I know that when flying high, that Turbo pressure is sent to mags. In WW2 They sent pressure to ignition harnesses as well. I am not sure why this suppresses arcing???? I think a vacuum is a better insulator than air??? Is it perhaps that it is not just pressurized, but is allowing an airflow to cool things down? Thx. Ron Parigoris>> Vacuum might be a better INSULATOR, but the higher the pressure of the air the higher its DIELECTRIC STRENGTH. In other words it will take a higher voltage to arc when the pressure is higher. And this is why the magnetos are sometimes pressurized. The problem mostly exists at the rotor where at some voltage the current will arc to another post rather than to a plug. A Naturally Aspirated engine doesn't have this problem because the pressure in the cylinder also goes down with higher altitude. A supercharged engine is typically operated at a constant manifold pressure and hence a constant cylinder pressure regardless of altitude. If the magneto is pressurized the potential for cross-firing is minimized. Gary Casey --- Incoming mail is certified Virus Free. --- ________________________________________________________________________________
Date: Dec 25, 2003
Subject: Re: RE: Turbo pressure to mags?
Gary Casey wrote: ".....I think a vacuum is a better insulator than air???....." Gary, For a practical distance between high voltage wires in the range of a few mm, when you change pressure starting from the atmospheric pressure, the breakdown voltage is proportional to the pressure. At around 5,000 m (~15,000ft) the pressure reduces by a factor of two, and the breakdown voltage reduces by a factor of two. That proportional dependence is valid for any practical aviation altitude until you reach a pressure somewhere between 1 and 0.1 mmHg, which would correspond to an altitude of sub orbital ionosphere. At this pressure the breakdown voltage reaches its minimum of less than 100V in air, and this is the pressure used in neon tubes. If you reduce the pressure further the break down voltage starts increasing very fast with reduction of pressure. Vacuum tubes operated at a pressure less than 0.001 mmHg. The reason for that high breakdown voltage is that there are few atoms there and electrons can travel the whole distance between electrods without colliding with atoms and ionizing them. So, you are right that vacuum is much better insulator than air. But it is a LONG way to go from any aviation pressure at any realistic altitude to vacuum. Jerzy ________________________________________________________________________________
Date: Dec 26, 2003
Add 1000 g and you get the correct weight, I dropped the "1" ! It`s an amazingly light bit of kit, Blue Mountain produce it, they have a webb site. ________________________________________________________________________________
Subject: RE: Breakdown voltage
Date: Dec 26, 2003
<> You explained it better than I, Jerzy. One thing I didn't know is that the minimum breakdown voltage (minimum dielectric strength) occurs at a pressure other than a perfect vacuum. What I was getting at was the difference between resistance and dielectric strength. Air has a certain conductivity (when it contains a normal amount of moisture) so that might lead one to believe that it would be better to pull a vacuum in the distributor cap. The difference is that in the distributor cap we are concerned with breakdown voltage, not the insulating properties and that's why the magnetos are typically pressurized. Gary Casey ________________________________________________________________________________
Subject: Re: Resistive Fuel Sensors
Date: Dec 26, 2003
----- Original Message ----- From: "hollandm" <hollandm(at)pacbell.net> > I'm installing Stewart Warner resistive fuel sensors in my RV9A. To provide some redundancy I am considering adding a set of Vans analog gauges, in series with a Grand Rapids EIS4000. > > Are there any concerns about having more than one gauge attached to these sensors? My suggestion here, if you really want redundancy, is to get the fuel flow option for the EIS4000. Then you have two independent sources to cross check against. That is what I did. The fuel flow is now calibrated to within .5 gal. Ross mickey N9PT ________________________________________________________________________________
Subject: Removing locking pins from radio connector....
Date: Dec 26, 2003
What's the secret to removing the small locking pins from a connector (back of Bendix/King KA-134 Audio Panel)? I have a couple wires that slipped free from a pin. I need to remove the pin, re-crimp the wires, and then install them back in the connector. Jack ________________________________________________________________________________
Subject: voltage regulator location
Date: Dec 26, 2003
For a z-13 installation, I have noted on the instructions for both the LR-3 regulator, and the SD-8 regulator, capacitor, relay, & OV module, that these items should be mounted on the cockpit side of the firewall to avoid heat, water, & vibration. I'm real curious as to where most builders install them, and any good or bad experiences. How often might these devices cause smoke in the cockpit? What about access to adjust the voltage and perform the annual test on the LR-3? Also, I would be running the SD-8 12 ga output wire inside the cockpit to the devices and then back out again to the battery contactor. Any insights will be greatly appreciated. Thank you, Scott, RV7-A Scott Diffenbaugh diff(at)foothill.net ________________________________________________________________________________
Subject: Both Z-13 alternators on at same time
Date: Dec 26, 2003
Hi Bob, Just have a desire to further my education. Per Z-13, what happens if I inadvertently turn on my SD-8 while my main alternator is running? Would this be an expensive lesson with lots of smoke? Do I need to set the voltage on one a bit less than the other? Thanks. Scott RV-7A Scott Diffenbaugh diff(at)foothill.net ________________________________________________________________________________
From: "John Wiegenstein" <n727jw(at)hellerwiegenstein.com>
Subject: Securing Pins in D-Sub Connector
Date: Dec 26, 2003
Couldn't find anything in the archives, so here goes. Having ordered up the D-sub crimper, pins, etc. from B&C, I'm mulling over how to secure the pins and sockets in the D-sub connector bodies themselves. Sockets (female) seem to seat in pretty snugly, but the male pins do not. Rather than order shells for the connector bodies and finish them off that way, has anyone had good results with something simpler? I'm wondering if just a dab of RTV along the pin line, to secure the pins and wires to the connector body, would do the trick. TIA for any suggestions. John Wiegenstein Hansville, WA RV-6 N727JW (reserved) ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: Securing Pins in D-Sub Connector
In a message dated 12/26/2003 2:25:45 PM Pacific Standard Time, n727jw(at)hellerwiegenstein.com writes: > Having ordered up the > D-sub crimper, pins, etc. from B&C, I'm mulling over how to secure the pins > and sockets in the D-sub connector bodies themselves. John, Just put the pin in the backside of the connector, it snaps in place. There is an insertion tool for this, but I have never needed to use it. Doug Windhorn ________________________________________________________________________________
Date: Dec 26, 2003
> > >Couldn't find anything in the archives, so here goes. Having ordered up the >D-sub crimper, pins, etc. from B&C, I'm mulling over how to secure the pins >and sockets in the D-sub connector bodies themselves. Sockets (female) >seem to seat in pretty snugly, but the male pins do not. Rather than order >shells for the connector bodies and finish them off that way, has anyone had >good results with something simpler? I'm wondering if just a dab of RTV >along the pin line, to secure the pins and wires to the connector body, >would do the trick. TIA for any suggestions. Either connector (assuming you're using a housing DESIGNED to accept the machined, removable pins) will grasp the pins very firmly. You push them in until you hear/feel a "snap" when the retention tines internal to the housing slip past the pin's largest diameter. If you're working with (ugh 24 awg or finer wire) you may need to use the red/wht insertion/extraction tool to press the pins into place. With all the wire in my inventory, I simply push the pin into final resting place by pushing with the wire. Once properly placed, you WILL need the white end of the insertion/extraction tool to remove a pin. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> connector....
Subject: Re: Removing locking pins from radio
connector.... connector.... > >What's the secret to removing the small locking pins from a connector >(back of Bendix/King KA-134 Audio Panel)? > >I have a couple wires that slipped free from a pin. I need to remove the >pin, re-crimp the wires, and then install them back in the connector. You can buy or fabricate a tool like the one shown at: http://www.aeroelectric.com/Pictures/extraction_tool.jpg It's not likely that you'll be able to put a wire back into an already crimped pin and re-crimp it. It's a good idea to put 2-3 pound tug on a pin after crimping and before inserting pin into connector housing. If you can't achieve at least this degree of capture integrity, there's something wrong with either your crimp tool, technique or both. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Phone/Mic Jack Connector
Hi Bob and All, We plan to put two cigar power jacks and the pilot's and co-pilot's phone and mic jacks between the pilot and co-pilot seats in a "small console". This console will need to be removed during annual inspection and therefore will need a disconnect. Are there any special considerations in selecting a connector because of the the phone and mic jacks? I am thinking Molex? Possibly D-sub? Thanks, Don B. ________________________________________________________________________________
Subject: Re: Removing locking pins from radio connector....
Date: Dec 26, 2003
In case you missed this before: http://www.berkut13.com/extractor.htm Definitely read this before trying to make or purchasing a tool!!!! You will be glad you did. Enjoy, James Redmon Berkut #013 N97TX www.berkut13.com ----- Original Message ----- From: "Jack Lockamy" <jacklockamy(at)att.net> Subject: AeroElectric-List: Removing locking pins from radio connector.... > > What's the secret to removing the small locking pins from a connector (back of Bendix/King KA-134 Audio Panel)? > > I have a couple wires that slipped free from a pin. I need to remove the pin, re-crimp the wires, and then install them back in the connector. > > Jack > > ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: Both Z-13 alternators on at same time
> > >Hi Bob, > Just have a desire to further my education. Per Z-13, what > happens if I >inadvertently turn on my SD-8 while my main alternator is running? Would >this be an expensive lesson with lots of smoke? Do I need to set the >voltage on one a bit less than the other? Thanks. Nope. No damage will occur. The alternator with the higher setpoint will attempt to hog the load . . . if this happens to be the smaller SD8 alternator, it will put out up between 8 and 10 amps before the bus sags enough to wake up the larger alternator whereupon it will take up the slack. Now, UNLIKE the SD-20 which is DESIGNED to operate TOGETHER with the larger alternator in a Z-12 configuration, you DON'T want to set the SD-8 for a lower voltage and run it all the time. Unless you have the special circuitry like that built into the SD-20/SB-1 combination to alert you when the main alternator fails, running the SD-8 all the time would mask the event if your system was lightly loaded. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: voltage regulator location
> > >For a z-13 installation, I have noted on the instructions for both the LR-3 >regulator, and the SD-8 regulator, capacitor, relay, & OV module, that these >items should be mounted on the cockpit side of the firewall to avoid heat, >water, & vibration. I'm real curious as to where most builders install >them, and any good or bad experiences. How often might these devices cause >smoke in the cockpit? What about access to adjust the voltage and perform >the annual test on the LR-3? Also, I would be running the SD-8 12 ga output >wire inside the cockpit to the devices and then back out again to the >battery contactor. Any insights will be greatly appreciated. EVERY manufacturer of electro-whizzies would like for you to never get his box wet, hot, too-cold, oily, dusty, or badly beat upon . . . if they had a choice. It stands to reason that PROBABILITY of unhappy customers due to environmentally induced problems will be lower. However, Mr. Bainbridge has elected to play in the same sandbox with the big guys. Irrespective of his best wishes for his products, they should not require any more pampering that other devices designed for airplanes. All of the devices you've cited have be successfully installed both in the cockpit and under the cowl for 15 to 20 years. Design your system for installation and maintenance ease and simplicity, not for feather-bedding the components. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: MicroAir transponder wiriing harness
> Tried to mail this to: nuckolls(at)aeroelectric.com but didn't go thru. >Do you have a different e-mail address now? That account was closed when spam count topped 2 or 3 hundred a day. There is an unpublished e-mail address on the aeroelectric.com server that I use for limited purposes and is not checked as often as this on the cox.net account. Your harness has been modified per the data you provided and is out of here in tomorrow's mail. Bob . . . ________________________________________________________________________________
Date: Dec 26, 2003
Subject: Re: RE: Thermocouples
> >< >then it is conservative to use the same kind of wire from the switch to the > >instrument. Caveat: the switch needs to be in the same temperature zone as > >the instrument since the 'cold junction' matches are critical to > >sensor/instrument accuracy. Anytime one has a connection in the sensor > >wire, one creates another cold junction. > > It's more accurate to say that deleterious effects of > any parasitic thermocouples generated when introducing > foreign metals can be minimized as long as whatever is done > to one side of the thermocouple path is done to the other side > but in opposite polarity . . . it's a sorta two-wrongs-can- > make-a-right approach.>> > >Bob is certainly correct here. A long time ago when we were using passive >"pyrometers," really just voltmeters, to read thermocouples we even went as >far as to use a special selector switch that was made of the right >materials. But then I worked at a powerplant one summer and there were >thermocouples half a mile away from the instrument. We ran the TC wires to >a junction box, connected them to copper and ran the rest of the way in >copper. You can do this but the thermocouple-to-copper junction becomes the "cold" or "reference junction" . . . to achieve useable and accurate information, you'll need to either KNOW or CONTROL the temperature in that junction box. This is the configuration described in View -B-, Figure 14-10 of: http://www.aeroelectric.com/articles/excerpt.pdf In the "remote reference" scenario, I show making this connnection in an ice bath (0 degrees C) so that voltages can be converted to a useful temperature equivalent at the instrument end. I've designed systems were the j-box for a whole raft of t/c reference junctions was held at about 100C with a heater and thermostat. This provided a known correction factor to convert voltages sensed at instrument end into real temperatures. All of these discussion should be academic. REAL thermocouple wire is not hard to get nor is it expensive in the small quantities needed to wire the average SE aircraft. See: http://www.omega.com/toc_asp/subsectionSC.asp?subsection=H06&book=Temperature for a gaggle of thermocouple wire products. May I recommend the TT series wires and 20AWG stranded as particularly robust and easy to use. Of there are other combinations to choose from. There's a part-number-builder on each catalog page for wire that will tell you what a small quantity of each kind of wire will cost. For example, TT-J-20S in 25' coil is the grand sum of $32 plus shipping. The same insulation in a 24 gage stranded wire is $27. K-wires are similarly priced. Check out the rest of Omega's website for a wealth of free reference literature on thermocouples and other technologies. Bottom line is that what ever technology you use to deduce temperatures based on a thermocouple will DEPEND on a reference junction somewhere in the system. For panel mounted instruments, this reference is INSIDE the instrument. Bring T/C wires all the way up to the instrument if you expect to achieve specified performance for that instrument. Bob . . . ________________________________________________________________________________
Subject: Re: Securing Pinds in D-Sub Connector
Date: Dec 27, 2003
>>Couldn't find anything in the archives, so here goes. Having ordered up the >>D-sub crimper, pins, etc. from B&C, I'm mulling over how to secure the pins >>and sockets in the D-sub connector bodies themselves. Sockets (female) >>seem to seat in pretty snugly, but the male pins do not. Rather than order >>shells for the connector bodies and finish them off that way, has anyone had >>good results with something simpler? I'm wondering if just a dab of RTV >?along the pin line, to secure the pins and wires to the connector body, >>would do the trick. TIA for any suggestions. >Either connector (assuming you're using a housing DESIGNED to >accept the machined, removable pins) will grasp the pins very >firmly. You push them in until you hear/feel a "snap" when >the retention tines internal to the housing slip past the >pin's largest diameter. If you're working with (ugh 24 awg or >finer wire) you may need to use the red/wht insertion/extraction >tool to press the pins into place. With all the wire in my inventory, >I simply push the pin into final resting place by pushing with >the wire. >Once properly placed, you WILL need the white end of >the insertion/extraction tool to remove a pin. >Bob . . . Right you are, Bob. All the parts are from B&C, so that wasn't the problem. I just don't think I was getting those suckers all the way in there. They DO seem nice and snug now. This still leaves me with the question of whether some kind of strain relief needs to be incorporated, but these connectors aren't going to be yanked around - they should end up tied down or otherwise fixed in position except for maintenance, etc. operations. Your thoughts? John H. Wiegenstein HELLER WIEGENSTEIN PLLC 19301 - 8th Ave. NE, Suite A Poulsbo, WA 98370 (360) 394-3500 (360) 394-3503 FAX johnw(at)hellerwiegenstein.com www.hellerwiegenstein.com ________________________________________________________________________________
Date: Dec 27, 2003
Subject: Horizontal Contactor
Hi Bob and All, Quick question. Is there any concern about mounting a battery contactor with the coil tube in the horizontal position? Given the pounding that our seaplane will take on the water I wondered if there was any problem with the coil holding the contact bar in a horizontal position verses pulling it down while in a vertical position. Thanks, Don B. ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Dec 27, 2003
I did what Bob suggests to make it convenient and maintenance friendly. I put it right in the lower part of my instrument sub-panel on which meets the suggestions of the voltage regulator designer too. I can see it when the tip up is open and I can adjust the voltage if need be. And annually I can easily see to trip the #2 and 6 terminals to be sure the LR3 still works. Indiana Larry, RV7 Tip-up On Finish Kit and FWF ----- Original Message ----- From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: voltage regulator location > > > > > > >For a z-13 installation, I have noted on the instructions for both the LR-3 > >regulator, and the SD-8 regulator, capacitor, relay, & OV module, that these > >items should be mounted on the cockpit side of the firewall to avoid heat, > >water, & vibration. I'm real curious as to where most builders install > >them, and any good or bad experiences. How often might these devices cause > >smoke in the cockpit? What about access to adjust the voltage and perform > >the annual test on the LR-3? Also, I would be running the SD-8 12 ga output > >wire inside the cockpit to the devices and then back out again to the > >battery contactor. Any insights will be greatly appreciated. > > EVERY manufacturer of electro-whizzies would like for you > to never get his box wet, hot, too-cold, oily, dusty, or badly > beat upon . . . if they had a choice. It stands to reason that > PROBABILITY of unhappy customers due to environmentally induced > problems will be lower. > > However, Mr. Bainbridge has elected to play in the same sandbox > with the big guys. Irrespective of his best wishes for his products, > they should not require any more pampering that other devices > designed for airplanes. All of the devices you've cited have > be successfully installed both in the cockpit and under the cowl > for 15 to 20 years. Design your system for installation and > maintenance ease and simplicity, not for feather-bedding the > components. > > Bob . . . > ________________________________________________________________________________
Date: Dec 27, 2003
Subject: KX 145 squelch problem
Hi listers. I have an old KX145 that only has a few hours on it (plane was in storage for 20+ years). During retesting of the plane I discovered a problem with the radio. If I turn the squelch down so I don't hear any static, I don't receive anyone (right at the very left end of the dial). When I turn it up and am willing to listen to the annoying static (so much for the noise cancelling headphones) everyone comes through nice and clear. Any ideas where I should start looking here? Anyone have schematics for this radio? Thanks, Jeff ________________________________________________________________________________
Subject: Manual master switch
Date: Dec 28, 2003
This was, I believe covered once before, but I don't remember the consensus: What are the pros/cons of using a manual master (battery) switch instead of the tradition relay contactor? It looks to me like the advantage is that it eliminates a failure mode and reduces the wiring complexity. The disadvantage is that there is likely a longer wire run from the battery that is unprotected. In my case the battery(s) will likely be located in the baggage compartment or rear of that, so the wire run is significant. The plane is plastic, though, so with appropriate wire runs the likelihood of a short to ground can be made to be negligibly small. I remember in car wiring design the idea was that the battery wire is large enough so that the battery will go dead before the wire will burn, although I don't know if it actually works that way. My idea is to mount the battery switch on the sidewall next to the pilot. Gary Casey ________________________________________________________________________________
Date: Dec 28, 2003
Subject: sample Z figures
Hi, I'm confused, nothing new. There is no example in appendix Z of a single alternator, dual battery system, is there? I'm planning on a subaru conversion, so I'll need a constant, automatic source of electricity. I don't know of any subaru conversions that have two alternators, so two batteries will be a must. I guess I want something like figure 17-6, but I don't quite understand how any of this is automatic. I'm missing the part where I wire my engine computer to both "always hot" battery busses, and it always gets juice. It all seems clear when I'm reading at the coffee table, but when I start to draw my own stuff, I realize how little I understood! Thanks! Mickey -- Mickey Coggins ________________________________________________________________________________
Date: Dec 28, 2003
Subject: Re: Manual master switch
In a message dated 12/28/03 8:28:47 AM Central Standard Time, glcasey(at)adelphia.net writes: What are the pros/cons of using a manual master (battery) switch instead of the tradition relay contactor? It looks to me like the advantage is that it eliminates a failure mode and reduces the wiring complexity. Good Morning Gary, Just as further food for thought, have you considered using a manual switch operated by a mechanical mechanism? The Sud Est Caravelle had a manual arrangement for shifting a bunch of 28 volt batteries into a much higher voltage arrangement for engine starting. I have forgotten the exact voltage, but I think we had enough batteries in series to supply something around one hundred and twenty volts to the starter for engine start. I do remember that the voltage would drop fifty or sixty volts during the start. (We had to monitor the voltage and shut it down if the voltage fell too low) There was a lever just to the left of my seat that I would operate to switch the battery bank from the series to the parallel mode. As soon as the engines were both started, I would move the lever to the twenty-eight volt position. Moving the lever also did things of which I have no knowledge to restore normal twenty-eight volt system operation. As I say. I have no idea what all the lever accomplished, but I do recall that all of the switching was manually done by moving that lever. It would add several points of mechanical failure, but it would save running that heavy wire and all of the attendant voltage drop. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Dec 28, 2003
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: sample Z figures
Not necessarily a recommendation, as I am going to develop my own electrical design, but if you go to www.eggenfellneraircraft.com there is a complete design there for what you want. It does, (unfortunately in my opinion) use the EXP Bus system, but it does all you want. Dick Tasker, RV9A #90573 Mickey Coggins wrote: > >Hi, > >I'm confused, nothing new. There is no example in >appendix Z of a single alternator, dual battery >system, is there? > >I'm planning on a subaru conversion, so I'll need >a constant, automatic source of electricity. I >don't know of any subaru conversions that have two >alternators, so two batteries will be a must. > >I guess I want something like figure 17-6, but >I don't quite understand how any of this is >automatic. I'm missing the part where I >wire my engine computer to both "always hot" >battery busses, and it always gets juice. > >It all seems clear when I'm reading at the >coffee table, but when I start to draw my own >stuff, I realize how little I understood! > >Thanks! >Mickey > > >-- >Mickey Coggins > > > > ________________________________________________________________________________
Date: Dec 28, 2003
Subject: Avionics for sale
These will be going up on Barnstormers next week, but I thought I'd give the folks here first crack. 1) Microair T-2000 transponder. 4 digit serial number (so there are no outstanding mods to take care of,) never installed, in original packaging. With harness by Bob, full warrantee. $1400. Retail $1700 plus the price of the harness. 2) Apollo CNX80. New, never installed or run in any way, less than 30 days out of the factory, in original packaging. Full warrantee. $9000 Retail $1195 ________________________________________________________________________________
Date: Dec 28, 2003
From: "David A. Leonard" <dleonar1(at)maine.rr.com> board',
Off.topic(at)matronics.com, long.and.rambling.with.social.commentary..@matronics.com
Subject: How do I solder My son's x-mas present, the 'electricity
board', Off topic, long and rambling with social commentary.. board', Off topic, long and rambling with social commentary.. Help! I have a toy for my 9 year old boy.. it's a kit, with a PCB, and a another PCB that solders to it. They both have tabs with silver contacts on them, the small PCB seems to fit into a slot on the motherboard, and the tabs align with each other on the back side of the motherboard. They meet at a ninety degree angle to each other, the tab with the connection solder leads sticks thru the motherboard. Kind of like this l_ , so it looks like I need to bridge the contacts. This contraption (The new component) needs to have various switches soldered to the board it a la our dear departed Heathkit catalog, and then a speaker and batteries..it eventually makes farm animal noises. (Does my heart good as it seems as though Heathkit is long gone!) I have soldered various components to boards in the past, but most had wires or leads that went thru the board, this is just tabs next to each other, like 8 on each board, with about 1mm separating the tabs. Do I just try to heat the adjacent tabs at the same time and flow some solder across the gap? My old man, (who is 74 , an orthopedic surgeon wannabe engineer..got into MIT right after WWII, and was told that if he went to Med school the army would pay for it and make him an officer...) got it for the 'electricity board' he built for the kid a few years ago..it is in for an overhaul/upgrade....(he did one for me in about 1963..I was three at the time..but there were no chips on that one). He couldn't figure out how to solder this new item, and decided I'd know how... By the way, the 'electricity board' is one of his coolest teaching inventions..it consists of a battery pack, a few DPDT knife type switches, a momentary on switch, a variable resistor, some LED's (my '63 model didn't have these), an electric motor with a propeller, a buzzer, some light bulbs, a horn, etc, , all mounted to a 12" x 18" plywood board. Also included with the set are ten or fifteen alligator clipped jumper leads, in red and black. Each component has its leads soldered to a terminal suitable for clipping an alligator clip jumper lead to it. From this basic bread board, we can teach all those neato concepts like..complete circuit, resistance, positive and negative, series, parallel, short circuit..you guys get the idea. You can hook it up in endless configurations. The only problem with this toy is that as the owner and beneficiary of it, you end up with some strange looks from the adults around you, when you are ten years old and you tell them that "you need to clean off the ground connections on this battery if you want your boat to start"...or "you better watch the polarity on those jumper cables, you are hooking your two cars up in series..I don't think they are going to like 24 volts..!" You get a lot of disbelieving looks, but eventually those adults will do what you tell them. It really pisses them off when a little kid knows more about it than they do.....eventually(later in life) they just hire you to deal with the problems... did you ever notice how hard it is when they are stumped and have to ask for help... they tend to resent the help sometimes as it challenges their egos....That is what I like most about this list..we all seem to realize we don't know it all...(except me of course)....and how nice it is to have someone to ask! I don't think I've ever seen any arrogance or attitudes on this list.. no flame wars, no insults..just a lot of good old help..and "do me a favor, show me where I'm wrong"! Most people don't really have a clue about how this stuff works, in fact most adults would probably benefit from a few hours with the "Electricity board"..I know it formed the basis for my understanding of the concepts....A/C and especially three phase caused a little head scratching later in life, and those pesky PFM (pure F***Magic) electronics concepts are just starting to emerge from the murk of my understanding! This Aero Electric list has helped me greatly! Anyway.. I realize this is an AIRPLANE internet group, but I figger if I can learn the boy to make electronics himself, I have a shot at him not becoming a useless consumer/know nothing type, and then, if he 'needs' an aircraft..he'll have the necessary 'can do' attitude( I refer to it, and myself as "too numb to be scared") and the skills it takes to make or repair one. I haven't built an aircraft, I bought a Bellanca Viking..I do a lot of the maintenance on it, (personally pulled one of the jugs at the last annual and ground the valves)and through the use of this website, have fixed many(all actually..we can't have less than a working bird now can we?) of the electrical problems that baffled the various ' FAA cerified expert maintenance facilities". Specifically to date these are some of the problems that this list has helped me through: 1. the unstable charging system due to poor connections in the field wire/master switch circuit.. A loose Fast-on was the worst culprit..tested fine with continuity, but the resistance went up due to the loose connection and vibration, and created instability in the regulator...That one fooled all the other owners and shops for twenty years and several thousand dollars of component replacement, according to the logs..I personally had a shop replace the alternator, and I replaced the regulator before I wised up and found the problem myself). I was on to that one from figuring it out myself when I read the Aero-Electric website article on Cessna split master switches, and gained a much better understanding of what was going on. 2. The 'disappearing transponder return' ...Avionics shops told me "all Vikings (cloth planes in general) have that problem..'Lectric Bob suggested a 5.4" copper disc at the base of the antenna for a good ground plane..stuck it on the ouside of the plane under the tail...Problem GONE!! ..There are a few other Vikings now flying with a copper disc ground plane now as well... 3. My Century 1 Autopilot not following the heading bug (contact cleaner at all the connections). 4. The MOSFET replacement in MY BMW heater control board..(well this stuff is useful for more than just aircraft now isn't it?) So I really do appreciate all you folks efforts here.. I think we have one heck of a great list! Thanks for the help, I need to look good for the kid here..he hasn't figured out that I'm just a guy yet..still thinks I can do anything...and I guess I would like to hold on to that for another few weeks at least! Sorry for the long post, I was in a writing mood, and I warned you guys in the header! Dave Leonard N77FE '72 SuperViking 300 (with fully functioning electrical system and avionics/autopilot) ________________________________________________________________________________
Date: Dec 28, 2003
From: "Richard E. Tasker" <retasker(at)optonline.net> the 'electricity board',
Subject: Re: How do I solder My son's x-mas present,
the 'electricity board', Off topic, long and rambling with social commentary.. the 'electricity board', Off topic, long and rambling with social commentary.. You have the answer already. As you said, just bridge the gap with solder. You do not really have to solder to each part simultaneously - put a "blob" on one part and another blob on the other part and then reflow the solder a bit to connect them. Alternately, you can use short pieces of wire to help connect the two parts - just soldered flat on the boards. I suspect that this is also a structural connection so the solder blobs is the best way. This is actually a fairly common interconnection method is some consumer products. If the PCBs are phenolic (brown) be careful of the soldering temperature. Dick Tasker, RV9A #90573 David A. Leonard wrote: board', Off topic, long and rambling with social commentary.. > >Help! >I have a toy for my 9 year old boy.. it's a kit, with a PCB, and a another >PCB that solders to it. They both have tabs with silver contacts on them, >the small PCB seems to fit into a slot on the motherboard, and the tabs >align with each other on the back side of the motherboard. They meet at a >ninety degree angle to each other, the tab with the connection solder leads >sticks thru the motherboard. Kind of like this l_ , so it looks like I >need to bridge the contacts. > >This contraption (The new component) needs to have various switches >soldered to the board it a la our dear departed Heathkit catalog, and then >a speaker and batteries..it eventually makes farm animal noises. (Does my >heart good as it seems as though Heathkit is long gone!) I have soldered >various components to boards in the past, but most had wires or leads that >went thru the board, this is just tabs next to each other, like 8 on each >board, with about 1mm separating the tabs. Do I just try to heat the >adjacent tabs at the same time and flow some solder across the gap? > >My old man, (who is 74 , an orthopedic surgeon wannabe engineer..got into >MIT right after WWII, and was told that if he went to Med school the army >would pay for it and make him an officer...) got it for the 'electricity >board' he built for the kid a few years ago..it is in for >an overhaul/upgrade....(he did one for me in about 1963..I was three at >the time..but there were no chips on that one). He couldn't figure out >how to solder this new item, and decided I'd know how... > >By the way, the 'electricity board' is one of his coolest teaching >inventions..it consists of a battery pack, a few DPDT knife type switches, >a momentary on switch, a variable resistor, some LED's (my '63 model >didn't have these), an electric motor with a propeller, a buzzer, some >light bulbs, a horn, etc, , all mounted to a 12" x 18" plywood board. Also >included with the set are ten or fifteen alligator clipped jumper leads, in >red and black. Each component has its leads soldered to a terminal suitable >for clipping an alligator clip jumper lead to it. > > From this basic bread board, we can teach all those neato concepts >like..complete circuit, resistance, positive and negative, series, >parallel, short circuit..you guys get the idea. You can hook it up in >endless configurations. > > The only problem with this toy is that as the owner and beneficiary of >it, you end up with some strange looks from the adults around you, when >you are ten years old and you tell them that "you need to clean off the >ground connections on this battery if you want your boat to >start"...or "you better watch the polarity on those jumper cables, you are >hooking your two cars up in series..I don't think they are going to like >24 volts..!" You get a lot of disbelieving looks, but eventually those >adults will do what you tell them. > >It really pisses them off when a little kid knows more about it than they >do.....eventually(later in life) they just hire you to deal with the >problems... did you ever notice how hard it is when they are stumped and >have to ask for help... they tend to resent the help sometimes as it >challenges their egos....That is what I like most about this list..we all >seem to realize we don't know it all...(except me of course)....and how >nice it is to have someone to ask! I don't think I've ever seen any >arrogance or attitudes on this list.. no flame wars, no insults..just a lot >of good old help..and "do me a favor, show me where I'm wrong"! > >Most people don't really have a clue about how this stuff works, in fact >most adults would probably benefit from a few hours with the "Electricity >board"..I know it formed the basis for my understanding of the >concepts....A/C and especially three phase caused a little head scratching >later in life, and those pesky PFM (pure F***Magic) electronics concepts >are just starting to emerge from the murk of my understanding! This Aero >Electric list has helped me greatly! > >Anyway.. > > > I realize this is an AIRPLANE internet group, but I figger if I can >learn the boy to make electronics himself, I have a shot at him not >becoming a useless consumer/know nothing type, and then, if he 'needs' an >aircraft..he'll have the necessary 'can do' attitude( I refer to it, and >myself as "too numb to be scared") and the skills it takes to make or >repair one. > >I haven't built an aircraft, I bought a Bellanca Viking..I do a lot of the >maintenance on it, (personally pulled one of the jugs at the last annual >and ground the valves)and through the use of this website, have fixed >many(all actually..we can't have less than a working bird now can we?) of >the electrical problems that baffled the various ' FAA cerified expert >maintenance facilities". > >Specifically to date these are some of the problems that this list has >helped me through: > >1. the unstable charging system due to poor connections in the field >wire/master switch circuit.. A loose Fast-on was the worst culprit..tested >fine with continuity, but the resistance went up due to the loose >connection and vibration, and created instability in the regulator...That >one fooled all the other owners and shops for twenty years and several >thousand dollars of component replacement, according to the logs..I >personally had a shop replace the alternator, and I replaced the >regulator before I wised up and found the problem myself). I was on to >that one from figuring it out myself when I read the Aero-Electric website >article on Cessna split master switches, and gained a much better >understanding of what was going on. > >2. The 'disappearing transponder return' ...Avionics shops told me "all >Vikings (cloth planes in general) have that problem..'Lectric Bob suggested >a 5.4" copper disc at the base of the antenna for a good ground >plane..stuck it on the ouside of the plane under the tail...Problem GONE!! >..There are a few other Vikings now flying with a copper disc ground plane >now as well... > >3. My Century 1 Autopilot not following the heading bug (contact cleaner >at all the connections). > >4. The MOSFET replacement in MY BMW heater control board..(well this stuff >is useful for more than just aircraft now isn't it?) > >So I really do appreciate all you folks efforts here.. I think we have one >heck of a great list! > >Thanks for the help, I need to look good for the kid here..he hasn't >figured out that I'm just a guy yet..still thinks I can do anything...and I >guess I would like to hold on to that for another few weeks at least! > >Sorry for the long post, I was in a writing mood, and I warned you guys in >the header! > >Dave Leonard N77FE '72 SuperViking 300 (with fully functioning electrical >system and avionics/autopilot) > > > > ________________________________________________________________________________
Subject: Re: How do I solder My son's x-mas present, the 'electricity
Date: Dec 29, 2003
>From: David A. Leonard (dleonar1(at)maine.rr.com) Sun Dec 28 - 7:45 PM >Help! >I have a toy for my 9 year old boy.. it's a kit, with a PCB, and a another >PCB that solders to it. They both have tabs with silver contacts on them, You can solder a hundred years and not discover the difference between 60% tin-40% lead and 63% tin-37% lead solders. Most sources give the melting points and that's that. But the real difference in tin-lead solders is far more subtle: 60-40 solder has a small "mushy" temperature range. 63-37 goes from solid to liquid with no mushy range at all (That's called eutectic). The smaller the tin (first digit) the greater the mushy range. This is important if there are gaps to bridge, and there always are. When soldering sheetmetal or stained glass for example, you really want a large range of mushy so you can stick a whole mess of solder onto the part to fill gaps, so you might use 50-50, which has a liquid temperature of 461F (maybe it's time for a propane torch) and a mushy range of 56F. Why is 63-37 so common? It is shiny and pretty when it solidifies. This makes assemblers proud. It is also great for solder plating PCBs for example. The 60-40 solder solidifies like a wax--first the lead solidifies, then a second later the tin solidifies. This leaves a hazy, frosted surface. You can also remember: 1) Tin melts at a lower temperature than lead, improves wetability, costs more, and is more flexible. 2) Lead melts at a much higher temperature, is poisonous, costs very little, is stronger but easier to fatigue crack. 3) There is a great difference between solders of the same kind. Ersin is very good, Alpha Metals has found its way into my junk box. Dave--use 60-40. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Date: Dec 29, 2003
Gary you've brought some of my thoughts to the surface which is usually dangerous. The pros of a manual switch seem to be no holding current and a bit of security/theft protection if it is hidden or at least not on the panel. Well it turns out that the massive but low cost metal unit sold by Summit racing (and even cheaper at my local farm supply) is actually heavier than an electric contactor. Flaming River make some that look to be composite and lighter. One sells for around US$80. complete with an 18" remote handle extension. Another version has a removeble plastic key. However it is easier to provide security with a small switch or in other ways. If I hard wire my battery to the starter, same as when my car engine was in its first life, then it seems that there is no particular need for a large contactor anyway. A small 40 amp relay (or even two for redundancy) would suffice for killing power to the distribution system. And even they won't kill battery bus power to my two efi and ignition computers. Anyway I'm having trouble justifying the need for a battery contactor or manual switch. Seems it wouldn't really kill power to very much of my aircraft for crash protection etc. and I'd need one for each of two batteries. Then there is the starter contactor which doesn't seem to add much protection either. There are a lot of car fires but the heavy battery to starter wire doesn't seem to be a problem in those, near as I can figure. Please correct me if someone believes otherwise. Bob has mentioned in the archives that he prefers to use a starter contactor even with automotive starters like mine. Fewer connectors and lower resistance between the alternator, battery, and starter is attractive though. Ok this is already long (which I hate to do as it tends to discourage comments) but I might as well mention my 40 amp ND internal voltage regulator alternator and my 20 amp John Deere PM alternator. Both have been fitted with large pulleys to slow them and help limit max current output. Do I add two more contactors for over voltage protection? Well I'll load the PM alternator with always on lights/strobes and perhaps a fuel pump. Do I really care if it runs away and stuffs a few extra amps into the battery till I can get on the ground? An old flooded battery would warm up and vent some electrolyte and shrug it off. Not sure about a small RG battery. I need to be informed about the regulator failure but I'm not as convinced that I need an active OV protection contactor here. It could be done with a small 40 amp relay or the one B&C sells though. The 40 amp ND alternator was chosen for both weight and so that a regulator failure would not result in a hundred amps being available as in the car. Of course any voltage spikes have to be lower too with a small unit. OV protection is probably a good idea here though since I am planning to use small batteries and the efi will only stand so much ov. Since we are thinking out of the box a bit, what about a normally open relay that adds say 30 amps of load to that alternator in the event of an ov. Switch in an electric windshield defroster or car heater perhaps? That would control the ov situation but still leave enough power available to run my engine for an unlimited time without even bothering to switch to my redundant efi system powered from the PM alternator. And a relay failure would only disable the ov protection whereas an ov contactor failure or activation would kill the alternator output. Such an approach also avoids extra connectors in the wire between the alternator and battery. Seems I might still want one heavy duty crossfeed contactor for engine starting if I use two small batteries but those batteries actually cost more than one large and one small battery... Cost is secondary here though. Or it looks like my PM alternator will probably run fine with a large capacitor and ov protection instead of a small battery... Ken > > In a message dated 12/28/03 8:28:47 AM Central Standard Time, > glcasey(at)adelphia.net writes: > What are the pros/cons of using a manual master (battery) switch instead of > the tradition relay contactor? It looks to me like the advantage is that it > eliminates a failure mode and reduces the wiring complexity. > Good Morning Gary, > > Just as further food for thought, have you considered using a manual switch > operated by a mechanical mechanism? >snip ________________________________________________________________________________
From: "Dan Branstrom" <danbranstrom(at)verizon.net>
Date: Dec 29, 2003
(snip)Well I'll load the PM alternator with always on lights/strobes and perhaps a fuel pump. Do I really care if it runs away and stuffs a few extra amps into the battery till I can get on the ground? An old flooded battery would warm up and vent some electrolyte and shrug it off. I know that you've thought long and hard about what your choices are. They aren't mine. To make the choices you're talking about, I would want the following answers: What is the exact voltage produced if regulators fail? What is the time that the items turned on will tolerate that voltage? What is the amount of heat generated over the time of the overvoltage? Is the higher internal resistance of a flooded battery worth it? How much does this shorten the life of your battery? Where are the gasses vented during the overcharge? (It's my understanding that both electrolyte and hydrogen would be given off). Even though it may be minimal, what is the extra weight needed to protect structures and terminals from corrosion, and do I want to inspect all the wires close by for corrosion? Where does the electrolyte go if the battery is cracked in an accident? If the pullys are running slower, how much electricity is generated at low engine RPM's? I know that some car fires are caused by accidents that have forced battery terminals on to metal, shorting the battery itself. (I've seen that one, but flames didn't break out, but there was enough smoke to be scary. The wrong sized battery contributed to that one, and the accident jammed the hood closed, so it took some tools to get the hood open and disconnect the battery). To me, I'd rather trust an O.V. crowbar circuit, R.G. battery, and contactor. Dan Branstrom ________________________________________________________________________________
Date: Dec 29, 2003
>I know that some car fires are caused by accidents that have forced battery >terminals on to metal, shorting the battery itself. (I've seen that one, >but flames didn't break out, but there was enough smoke to be scary. The >wrong sized battery contributed to that one, and the accident jammed the >hood closed, so it took some tools to get the hood open and disconnect the >battery). My daughter lost her first car, a Honda Accord, to a battery that slipped forward when she stopped and bumped a curb. The battery terminals contacted the chassis and started a fire that she never noticed when she got out of the car and walked away. The fire slowly engulfed the entire compartment and "melted" the entire engine. Nobody noticed a thing hours later, except that the hood looked a little darker than usual. The first indication of a problem was when she got in again and tried to start the car, and she couldn't push the clutch in because all the liquid had been boiled out. No explosion, no raging blaze, no nothing. Just a completely totalled vehicle. Dave Morris ________________________________________________________________________________
Subject: Mounting OVM-14?
Date: Dec 29, 2003
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
I am collecting the parts to implement the ground power circuit that Bob recommends but am at a bit of a loss about how the OVM-14 is mechanically mounted. It doesn't appear that just putting ring terminals on the wires is sufficient - would sticking it to the contactor with RTV do the trick? What have others done? ________________________________________________________________________________
Date: Dec 29, 2003
Subject: Re: Mounting OVM-14?
> > >I am collecting the parts to implement the ground power circuit that Bob >recommends but am at a bit of a loss about how the OVM-14 is mechanically >mounted. It doesn't appear that just putting ring terminals on the wires >is sufficient - would sticking it to the contactor with RTV do the >trick? What have others done? That would work. Or use a large diameter (1") piece of heatshrink to support it by one of the fat wires coming to or leaving the contactor. Bob . . . ________________________________________________________________________________
Date: Dec 29, 2003
> Anyway I'm having trouble justifying the need for a battery contactor or > manual switch. Seems it wouldn't really kill power to very much of my > aircraft for crash protection etc. and I'd need one for each of two > batteries. I use one and only one Master Switch (used on boats) in the ground circuit. Theses switches are rated at 400 to 600 amps. Mine is from West Marine No. 335870 Then there is the starter contactor which doesn't seem to add > much protection either. There are a lot of car fires but the heavy > battery to starter wire doesn't seem to be a problem in those, near as I > can figure. Please correct me if someone believes otherwise. Bob has > mentioned in the archives that he prefers to use a starter contactor > even with automotive starters like mine. Fewer connectors and lower > resistance between the alternator, battery, and starter is attractive > though. > > Ok this is already long (which I hate to do as it tends to discourage > comments) but I might as well mention my 40 amp ND internal voltage > regulator alternator and my 20 amp John Deere PM alternator. Both have > been fitted with large pulleys to slow them and help limit max current > output. I think the larger pulleys do not limit max current, it only reduce rpm and makes it easier on the alternator bearings. > Seems I might still want one heavy duty crossfeed contactor for engine > starting if I use two small batteries but those batteries actually cost > more than one large and one small battery.. I have a small battery (17 AH) to start my engine, it is a Mazda rotary 13b engine. That small battery is doing just fine. I use the second battery to feed my electronics including the engine controller. > Ken >> ________________________________________________________________________________
Subject: SD-8 Voltage Regulator Potential Overheating
Date: Dec 29, 2003
Hi Bob & fellow Listers, Reached the point where I felt comfortable with my total system design utilizing Z-13 & was placing the order with Tim at B&C today when the topic of loading the SD-8 came up. When I indicated I had designed it for 8 amps or less continuous, Tim informed me the regulator was designed for 2 to 3 amps continuous and would most likely fry at 8 amps unless some sort of cooling was provided. If located in the cockpit, it should have additional heatsinking and a fan would be a good idea, but there could be electrical noise. If mounted on the firewall in the engine compartment there would be less noise, but it would need substantial heat sinking, and/or a blast tube. In an earlier response, Bob mentioned if loaded greater than 8 amps continuous, a heat sink was necessary, or possibly a more robust regulator like the KeyWest. I Google searched KeyWest and only found one hit, where someone experienced regulator failure due to overheating with a Rotax & it also destroyed their alternator. Also was not able to find the KeyWest website. Anyone have its URL? Does anyone have experience running the SD-8 continuously at 8 amps? Unless I have overlooked something, neither the installation instructions for the SD-8 nor Z-13 mention heat sinks or blast tubes. Am I missing something or might Z-13 users experience regulator overheating if their main alternators fail? (according to Tim, the stuff inside the regulator housing starts to ooze out when overheated) Thank you in advance for your assistance with this issue. I have put my order on hold until I have a better understanding. Scott, RV7A Scott Diffenbaugh diff(at)foothill.net ________________________________________________________________________________
From: "Gilles.Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Source for an AIM artificial horizon
Date: Dec 30, 2003
Hi Bob and all, Does anyone know of a reliable source for a used AIM 1100 electric artificial horizon (14 V, tilt preferably 4.5) ? Any info appreciated. Thanks, Gilles Thesee ________________________________________________________________________________
Date: Dec 30, 2003
Subject: Microair 760 intercom
Bob/all: The built-in intercom of my Microair 760 transceiver is so noisy at normal cruise speeds that It's almost impossible to carry on a conversation with my passenger. The radio is installed in an RV-8A which is notoriously noisy. I recently purchased a Softcom intercom which comes with a wiring harness. Several wires from the intercom ( mic key, headset audio and mic audio) go to the radio, while the other wires are to connect to the headphone & mic jacks. Since I already have the jack wired up, using your wiring harness and wiring diagram, will I need to rewire the jacks using the wiring provided with the intercom? By the way, none of the IC jack wires are shielded. Any suggestions are appreciated...... Walt Shipley ________________________________________________________________________________
Date: Dec 30, 2003
> >Gary you've brought some of my thoughts to the surface which is usually >dangerous. The pros of a manual switch seem to be no holding current and >a bit of security/theft protection if it is hidden or at least not on >the panel. > >Well it turns out that the massive but low cost metal unit sold by >Summit racing (and even cheaper at my local farm supply) is actually >heavier than an electric contactor. > >Flaming River make some that look to be composite and lighter. One sells >for around US$80. complete with an 18" remote handle extension. Another > version has a removeble plastic key. However it is easier to provide >security with a small switch or in other ways. > >If I hard wire my battery to the starter, same as when my car engine was >in its first life, then it seems that there is no particular need for a >large contactor anyway. A small 40 amp relay (or even two for >redundancy) would suffice for killing power to the distribution system. >And even they won't kill battery bus power to my two efi and ignition >computers. What do you do if the starter contactor sticks? How do you drive all the fat wires to "max cold" in anticipation of an unplanned arrival with the earth? >Anyway I'm having trouble justifying the need for a battery contactor or >manual switch. Seems it wouldn't really kill power to very much of my >aircraft for crash protection etc. and I'd need one for each of two >batteries. Then there is the starter contactor which doesn't seem to add >much protection either. There are a lot of car fires but the heavy >battery to starter wire doesn't seem to be a problem in those, near as I >can figure. Please correct me if someone believes otherwise. Bob has >mentioned in the archives that he prefers to use a starter contactor >even with automotive starters like mine. Fewer connectors and lower >resistance between the alternator, battery, and starter is attractive >though. How much is "fewer" and "lower" in comparison with the total and how would you perceive the difference if you had no prior knowledge of what "more" and "higher" was? >Ok this is already long (which I hate to do as it tends to discourage >comments) but I might as well mention my 40 amp ND internal voltage >regulator alternator and my 20 amp John Deere PM alternator. Both have >been fitted with large pulleys to slow them and help limit max current >output. Do I add two more contactors for over voltage protection? Why did you cripple some perfectly good alternators? What is the advantage of slowing down an alternator that runs most happily at high rpm? The BIG downside for generators was low output at idle and taxi RPMs but if you put a smaller pulley on them, the brushes would wear faster. When alternators came along, all the downsides went away but you have brought them back . . . >Well I'll load the PM alternator with always on lights/strobes and >perhaps a fuel pump. Do I really care if it runs away and stuffs a few >extra amps into the battery till I can get on the ground? Are you planning to call the runaway condition an "emergency" or a "maintenance event"? An airplane fitted with sufficient controls, notification of failure and options for alternative operating modes means that which drive the pucker factor up in spam-can pilots is no big deal for an OBAM aircraft pilot. > An old flooded >battery would warm up and vent some electrolyte and shrug it off. Not >sure about a small RG battery. I need to be informed about the regulator >failure but I'm not as convinced that I need an active OV protection >contactor here. It could be done with a small 40 amp relay or the one >B&C sells though. > >The 40 amp ND alternator was chosen for both weight and so that a >regulator failure would not result in a hundred amps being available as >in the car. Don't understand. A runaway alternator is never capable of delivering lots of amps over and above the nameplate rating. They are ALL capable of delivering lots of volts . . . 100 or more in cruise rpm with the small pulley of choice. This is what ov protection is about. > Of course any voltage spikes have to be lower too with a >small unit. Define "spike", where it's generated. How long does it last and how much energy does it contain? This term is stirred into every worried discussion about electrical systems with complete lack of understanding about what it is, where it comes from and how a system may be configured so that for the most part it will not exist. In the world of cookie-cutter certified ships and FAA approved flight schools, pilots have neither the knowledge or the options of using their knowledge to improve the machines they fly. None the less, many of our brethren in the OBAM aircraft community carry this baggage with them into the world where the finest aircraft to have ever existed are built. >OV protection is probably a good idea here though since I am >planning to use small batteries and the efi will only stand so much ov. >Since we are thinking out of the box a bit, what about a normally open >relay that adds say 30 amps of load to that alternator in the event of >an ov. How about shutting off the offending alternator in case of an ov condition? > Switch in an electric windshield defroster or car heater perhaps? >That would control the ov situation but still leave enough power >available to run my engine for an unlimited time without even bothering >to switch to my redundant efi system powered from the PM alternator. And >a relay failure would only disable the ov protection whereas an ov >contactor failure or activation would kill the alternator output. Such >an approach also avoids extra connectors in the wire between the >alternator and battery. What is the service history of "extra connectors" between the alternator and battery. How many connections have you had to repair on your automobile or any other vehicle? Suppose a lead between the alternator becomes disconnected, how is this any more likely or how is the result any different than a wire coming unhooked in the regulator or somewhere else in the system so as to make the alternator unusable? Would it not be better to design your system for "failure tolerance" . . . a system that offers a plan-b alternative to failure of ANY component? >Seems I might still want one heavy duty crossfeed contactor for engine >starting if I use two small batteries but those batteries actually cost >more than one large and one small battery... Cost is secondary here >though. Or it looks like my PM alternator will probably run fine with a >large capacitor and ov protection instead of a small battery... Instead of taking an egg beater to the experience base of that which has gone before us, may I suggest that you consider the suite of z-drawings and find one that most closely matches your perceived needs. Let then consider together how that system falls short. It may be that some modification of the architecture described is in order . . . or perhaps even a new architecture is called for. Let's discuss your perceptions of worrisome events and sort them into two piles: (1) ol' mechanic's tales/hangar legends and (2) real threats which we'll address by considered design and mitigating operating techniques. The goal is to configure a system about which you have NO worries and an operating philosophy that virtually guarantees that you complete a leg of a mission all the way to airport of intended destination without breaking a sweat. I'm confident that you'll find that many of your concerns are not founded upon good science and once you understand how your system of choice works, your confidence level will raise markedly. More important, your system reliability (of which the pilot is a critical component) will stand head-and-shoulders above that of certified aviation. Bob . . . ________________________________________________________________________________
Date: Dec 30, 2003
Subject: Re: Architecture questions for an RV7
>Bob, > >I am building an RV 7 using all B&C electrical products, including >the 60A alternator and 20A vacuum pad mounted alternator and >SB1-14 and LR3C-14 voltage regulators. The architecture includes >a separate battery master switch and individual alternator field >switches. (I am using one of your main bus/essential bus architectures >with dual alternators, diode feed to the essential bus and alternate >switched path to the essential bus. This arrangement is as shown in >skeleton figure 17-2 of your Aero Electric Connection manual >rev 10 dated Nov 2001). First, why are you installing two big alternators? How do you plan to use this airplane and how is it going to be equipped? For this combination of alternators, Figure Z-14 is the system of choice for folks who NEED this much engine generated power. >I have what seems like a trivial question: If I have a main bus >fault for example, is there any importance as to the order of >opening/closing the battery master and essential bus switches. >If not why can't the essential bus alternative feed switch be >replaced by a direct connection? If I close the essential bus feed >switch by accident whilst the battery master switch is still closed >are there any implications? "Faults" to the bus are so rare as to be unworthy of procedural consideration. The philosophy of the architecture in Figure 17-2 (and Z-11) is to provide (1) an alternative feed path for power to electrically powered items that will essentially insure comfortable arrival at airport of intended destination and (2) provide a way to reduce en route loads during battery only operation to a value that compliments goal (1) cited above. If you have two engine driven power sources in the form of 40+ and 20A machines, en route energy conservation is not an issue. Therefore, it seems more practical to consider figures 17-5 and Z-14. But first things first, why have you selected this particular pair of alternators? >Apologies if the following questions should be addressed to B&C I am not >sure of their e-mail address? > > >If I open the battery master switch without opening the alternator field >switches first, will this have any detrimental effect on the alternators? If wired per any of the Z-figures with a 2-10 master switch, this issues is mute. The switch is configured to bring the alternator on last and off first. Unless you've specifically designed and tested your proposed system for alternator only performance, operation without a battery is an iffy proposition and not recommended. >Are there any other circumstances when using your voltage regulators and >alternators that can damage either of them by incorrect operation of the >battery master switch and/or the individual field switches. For example, >by opening a field switch with the engine running and the battery master >switch closed ? I should perhaps mention that I am asking this question >because there are dire warnings in some Automobile maintenance manuals, >and indeed on an American Web site dealing with some marine installations, >that an engine must on no account be run without the battery being >connected else alternator damage may ensue as a result of a rise of output >voltage to 100V or so. But this advice may not apply to your arrangements ? It sure does . . . that's what drove the configurations described in Appendix Z. >I plan to use the battery temp sensors on both regulators. This option is >not shown on the SB1-14 regulator. Is this available and if so are the >connections to pins 1&6 as per the LR3C-14 No, the temperature sensor is useful in very few situations and not recommended unless you plan to spend long legs of a trip at 25,000 feet on oxygen where you might cold-soak a battery. >I want to keep my instrument panel as neat as possible! I have >standardised all my warning and indicator lights as high intensity LEDs >with internal dropping resistors. Can I use one of these in place of your >supplied low voltage warning filament lamp on the LR3C-14? Yes, see http://www.aeroelectric.com/temp/LV_Led.jpg >I am also planning to be able to test all the warning lamps on my panel >with a single push to test button, applying a ground or 12v as >appropriate. For the alternator warning lights I was planning on using a >relay to temporarily disconnect the low voltage warning light from pin 5 >on the regulator and connect to ground therefore placing 12v from the main >bus across the light to test its operation. Is this ok? If you're using LEDs throughout, I wouldn't bother about PTT. The life of an LED is so high that you're MUCH more likely to loose functionality of an annunciator for reasons that are not tested by your PTT system. Keep the parts count down and check list shorter by leaving this low-value feature off. I will invite you to join us on the AeroElectric List to continue this and similar discussions. It's useful to share the information with as many folks as possible. A further benefit can be realized with membership on the list. There are lots of technically capable folks on the list who can offer suggestions too. You can join at . . . http://www.matronics.com/subscribe/ Thanks! Bob . . . -------------------------------------------- ( Knowing about a thing is different than ) ( understanding it. One can know a lot ) ( and still understand nothing. ) ( C.F. Kettering ) -------------------------------------------- ________________________________________________________________________________
Date: Dec 30, 2003
Subject: Re: Microair 760 intercom
> >Bob/all: The built-in intercom of my Microair 760 transceiver is so noisy at >normal cruise speeds that It's almost impossible to carry on a conversation >with my passenger. The radio is installed in an RV-8A which is notoriously >noisy. A hot mic intercom depends on GOOD noise cancelling microphones unless you use the intercom push-to-talk feature. If you have the ptt feature in place, the 760's intercom feature will be no better/worse than any system. >I recently purchased a Softcom intercom which comes with a wiring harness. >Several wires from the intercom (mic key, headset audio and mic audio) go to >the radio, while the other wires are to connect to the headphone & mic jacks. > >Since I already have the jack wired up, using your wiring harness and wiring >diagram, will I need to rewire the jacks using the wiring provided with the >intercom? By the way, none of the IC jack wires are shielded. I suggest you wire in accordance with the diagram supplied with the intercom. Bob . . . -------------------------------------------- ( A beginning of the end is marked by ) ( replacement of experience and common ) ( sense with policy and procedures. ) ( R. L. Nuckolls III ) -------------------------------------------- ________________________________________________________________________________
Date: Dec 30, 2003
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> Overheating
Subject: Re: SD-8 Voltage Regulator Potential
Overheating Overheating > > >Hi Bob & fellow Listers, > > Reached the point where I felt comfortable with my total system > design >utilizing Z-13 & was placing the order with Tim at B&C today when the topic >of loading the SD-8 came up. When I indicated I had designed it for 8 amps >or less continuous, Tim informed me the regulator was designed for 2 to 3 >amps continuous and would most likely fry at 8 amps unless some sort of >cooling was provided. If located in the cockpit, it should have additional >heatsinking and a fan would be a good idea, but there could be electrical >noise. If mounted on the firewall in the engine compartment there would be >less noise, but it would need substantial heat sinking, and/or a blast tube. This is a new one on me! I'll have to look into this. > In an earlier response, Bob mentioned if loaded greater than 8 amps >continuous, a heat sink was necessary, or possibly a more robust regulator >like the KeyWest. I Google searched KeyWest and only found one hit, where >someone experienced regulator failure due to overheating with a Rotax & it >also destroyed their alternator. Also was not able to find the KeyWest >website. Anyone have its URL? I've not heard much about Key West lately. It was a really popular regulator for Rotax systems for folks building Pulsars and Kitfoxes and it was mentioned a lot when I belonged to those lists years ago. >Does anyone have experience running the SD-8 continuously at 8 amps? Unless >I have overlooked something, neither the installation instructions for the >SD-8 nor Z-13 mention heat sinks or blast tubes. Am I missing something or >might Z-13 users experience regulator overheating if their main alternators >fail? (according to Tim, the stuff inside the regulator housing starts to >ooze out when overheated) This is a mind-blower . . . there are many hundreds of SD-8's flying as the ONLY source of engine driven power. If they've had problems with regulator performance, I've been unaware of it. Based on this, I've shown the SD-8 as a really useful and reliable second source in Figure Z-13 . . . if this is NOT the case, then I've got a lot of explaining to do to a hundred or more builders who have installed Z-13. Watch this space! >Thank you in advance for your assistance with this issue. I have put my >order on hold until I have a better understanding. Good idea . . . Bob . . . ________________________________________________________________________________
Subject: Re: manual master switches, over-voltage controllers
Date: Dec 30, 2003
December 19, 2003 - January 03, 2004
AeroElectric-Archive.digest.vol-ct
