AeroElectric-Archive.digest.vol-cx
February 10, 2004 - February 24, 2004
Dave Morris
At 05:44 AM 2/10/2004, you wrote:
>I'm seriously considering manufacturing a small annunciator panel
>from Stanley LED light bars. These are the ones with part numbers
>like MU04-2101 sold by Digikey, etc. I am wondering what options I
>would have to put legends on the face of the light bars. What looks
>good and lasts a long time? I am also looking for ideas on how to
>package the resistors, etc needed to limit the current. Does anyone
>have any pictures they could point me too?
>Thanks,
>Kevin Horton RV-8 (finishing kit)
>Ottawa, Canada
>http://go.phpwebhosting.com/~khorton/rv8/
Subject: | Re: AeroElectric-List Digest: 29 Msgs - 02/09/04 |
In a message dated 2/10/04 2:56:55 AM Eastern Standard Time,
aeroelectric-list-digest(at)matronics.com writes:
<< For $300 and 4 pounds you can have a SECOND engine driven
> power source.
> Bob . . .
I think you mean a Third source. (Battery =1, Alt =2, Second Alt = 3) >>
Key word is "engine-driven." It would be the second source and an important
one.
Stan
Subject: | Re: LED light bar annunciator panel? |
From: | John Schroeder <jschroeder(at)perigee.net> |
Kevin -
Drop Mark Phillips an email. He has a great design for a panel and used
these LED's in his annunciator panel. We plan to use them too, but are not
sure how to do the lettering. There is an outfit that will custom-make a
backlit plexi panel. If we can get it a little more customized, we may go
that route.
Mark: Mark Phillips
Backlit panels: http://www.aircraftsimulators.com/products.html
Subject: | Re: Mag/E.I. switches |
> Hmmm . . . at ANY
> RPM? What happens when you do ignition system checks by turning
> them off and on one at a time to observe operation of each system
> independently?
At low RPM (Below 1700) it doesn't seem to effect it. Besides, if you turn
off the magneto to check the E.I.& plugs and turn it back on there is little
sense in turning off the E.I. system when you see the RPM increase when the
magneto is switched on. If the magneto side is fouling plugs running them
is a way to "hopefully" clean an dismiss and carbon deposits. I usually
turn off the E.I. system at 1000 rpm only for a moment and right back on
just after start up. A smooth idle verify's the magneto plugs are firing
and at run-up the mag is switched of to check the amount of RPM drop.
In reality were checking not only magneto operations but just as much
sparkplug operation. With an E.I. system all your checking is plugs unless
you have a variable advance in which case you -Could- check that too.
Flying the same plane all the time allows a "feel" for engine smoothness and
EGT/CHT numbers then back up the feeling.
Those different shaped switches also make it easier to "feel" for the switch
whether light or dark. Electronics can do alot but they can fail at the
point of "when the engineer didn't think of that." I don't like to be
dependant on electronics 100%. They fail and can't adjust withoput adding
more weight to the system. When I fail - I usually loose a little weight
and hopefully I can adjust... And quickly :-))
Dale Martin
Lewiston, ID
LEZ-235
Subject: | Re: RE: Load dump protection |
I agree that careless owners need protection. There is no way we can protect
against all loose or broken connections but we can add the simple and low
cost Diode (low cost in 'do it your self ' or $30 for a pre made up diode
with lugs attached). The loose/ broken connection is the first fault and our
designs should protect against that fault from causing additional damage
like the Alternator, or worse, avionics/engine systems etc. Thus boaters
have solved the problem but that requires action to impliment as you note.
However I was referring to the add on Load dump diode mentioned in an
earlier post (or the one I suggested that is already tested and qualified
for that purpose) . With that diode added there is protection against what
you say.
Currently that ""switch"" is the fault and that fault propagates to the
alternator and depending on the wiring design to the main electrical bus
etc. The Load Dump diode stops the propagation
There is a simple solution but as you say its not "stock". The designer(s)
need to research the issue and provide the external FIX NOT provided by
"off the shelf alternators". My point is acft have the same problem and the
same solution is available and has been for decades but has been overlooked
in most designs.
Load dump protection exists as an add on and why are we beating it to death
when there is an existing simple proven fix.
On a related subject I had a frayed starter cable (at the starter end so
hard to see). It finally broke and during starting sparked as the engine
torques. This was back before TVS was used on that auto. I destroyed 3
discrete electronic modules that were on the main battery bus from the HV
transients. NONE of the electronics modules that were on the accessory bus
were damaged as they were disconnected by the IGN switch during starting.
AS far as autos are concerned sure the same can happen but I stand by my
statement there are millions of autos with stock electrical systems and they
all depend on a solid battery connection for protection.
I should have said while Load Dump is a concern in autos, the MFGR's are not
concerned about it enough to do anything as the battery is normally
connected solidly at least during the warranty period. Adding a $1 device or
changing a design of a regulator is very costly and that money is not spent
lightly.
Finally as you point out the energy in the alternator windings is already
there and the regulator can only stop new energy not what is already there
so Load dump can be a real concern with external regulators also. Even OVP
do not address current energy just future energy.
Paul
----- Original Message -----
Subject: AeroElectric-List: RE: Load dump protection
> < autos, as in
> autos the "B" lead is always directly wired to the battery. Thus there is
no
> "switch" to be accidentally opened to cause load dump action. Also there
is
> no OVP included as its rare and not a concern in the auto mfgrs mind. At
> least a couple of years ago I was unable to find ANY auto mfgr alternator
> that protected against load dump...I do not understand the need for
> additional testing in this case. The
> Boaters have long since solved the problem and so why are we still
> investigating it??>>
> Load dump protection in autos is still a real thing. There is a "switch"
> between the alternator and the battery and it is the battery terminal
> itself. The worst case, that is mostly worried about by boat
manufacturers,
> is a loose connection on the battery terminal that vibrates, repeatedly
> opening and closing. The electronics builders for boats find that it has
> not been "solved" as you imply, but is almost a normal situation. The
usual
> scenario is that the boater stores his boat over the winter, then finds
the
> battery is dead. He removes the battery and charges it for 10 minutes
(the
> family is waiting) and then puts it in the boat and just pushes the
battery
> cable on. The loose cable vibrates, the battery is accepting maximum
charge
> and the voltage transients are incredible - and repeated many times a
> second. Also, the battery doesn't have to be disconnected to have a load
> dump. Any time a large load is shut off the alternator has to instantly
> reduce its output, which it can't do because of the inductance of the
field
> windings. Of course, having the battery there tames the load dump to a
very
> manageable amplitude.
> Gary Casey
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
Subject: | Re: Load dump issues |
>I have watched this discussion and am concerned that the
>issue/facts/solution is going off track a little.
>Load dump is NOT unique to internally regulated alternators. ANY alternator
>can and will exhibit load dump when wired such that the load can be removed
>from the "B" lead when the alternator is generating power. IE
>internal/external/new/old/rebuilt are all the SAME with regard to Load Dump
>concerns.
That's not what was said. The problem is load-dump tolerance
of the REGULATORS internal to rebuilt alternators Van's sells vis-a-vis
regulators in OEM alternators which MAY be more resistant.
Regulator chips advertised by Onsemi and others call out "load dump
protection."
I mentioned in a post last week that the externally regulated
Bonanza alternators are wired in a way that I could manually
generate a "load-dump" event by manipulation of switches.
>All alternators, regardless of design, need protection or they can dump
>damaging loads either back to the alternator or to the expensive avionics
>depending on what opened and where.
Correct. We've had this discussion before. The risk is predicated
on battery contactor failure (or pilot operation of the contactor
at inappropriate times) while the battery is being charged. After
that, the duration and amplitude of the event is dependent upon many
system variables.
>Designs that disconnect the "B" lead when OVP is detected are great as long
>as there are Zero false trips. Bob has said many times that his OVP can and
>does (while very rare) false trip. This can result in alternator damage due
>to a false trip and not acceptable to me.
Correct . . . and the goal of this activity is to make it acceptable
to you and the rest of the OBAM aircraft community.
But it doesn't seem to be happening except for a limited population
of alternators which at the moment are all Van's rebuilts. We'll be
testing some factory fresh ND alternators in a few weeks. The working
hypothesis of the moment is that it's zero risk to airplane and strong
risk only to those alternators with regulators built with technology
falling short of what ND might do for a factory fresh product.
The same experiments offer an opportunity to put the 'scope on and
gather some real-time, real-life data.
>Alternator damage with a real OVP trip is not an issue as the alternator has
>already failed.
True
>There are more modern OVP I/C's that have provision for not false tripping
>on narrow spikes as they have adjustable delay to trip times. I suggest that
>this design approach be used to prevent a OVP protection device from
>causing damage from a not quite perfect design.
The OVM-14 and derivatives used in the B&C's products are all
adjustable for trip response. After our experience with the
super-noisy Bonanza's I belive nuisance tripping from dv/dt
effects of very low energy, narrow spikes has been resolved.
Thousands of those devices were in service with successful service
histories until Bonanza came along . . . and I believe we've
slain that dragon as well.
The only kind of nuisance trip we expect to see now will be an true
overshoot of the regulator/alternator combination . . . over which
we have no control when our OVM-14 is purchased for combination with
other hardware. Nuisance tripping is not a component of the current
discussion.
>The Linear LTC1696 is inexpensive and is designed to provide reliable OVP
>with minimal additional parts.
>Eric Jones has such a OVP design and I highly recommend it IF you are
>concerned about False trips. It's already designed and available to us.
False trips are not the issue. It's manually generated trips
caused by persons at the controls deliberately opening the
alternator control switch while the alternator is loaded.
>http://www.periheliondesign.com/
>If the alternator is generating say 50 amps and 40 amps are going to the
>battery and 10 amps to the rest of the system and the battery is
>disconnected the alternator output voltage (and the acft system bus) will
>rise until the 40 amp excess is loaded. This can result in a high voltage
>spike that is not stopped with OVP devices that shut off the regulator (too
>late action). Thus potential damage to avionics etc is likely if there is a
>large enough load dump. The damaging current is already there and thus its
>too late for a working regulator with or without OVP design to stop the
>energy pulse.
>Bob has suggested that NEW alternators have such protection and so Bob
>please let us know specifically which NEW alternators have such protection
>built in so we can consider them for our use.
I have said no such thing . . . you have mis-characterized my words.
I'm not setting myself up as the great arbiter of suitable and
unsuitable alternators.
>Then there are comments about rebuilt alternators being inferior. Perhaps
>some are but then many are just as good as the original NEW alternator in
>all respects.
This is the working HYPOTHESIS as to why some alternators are failing
and others do not. There was never a blanket statement made to imply
that all rebuilt alternators are inferior in this regard.
>As for testing and evaluation of TVS devices for load dump protection and
>getting your stamp of approval why do it??
Nobody needs or is recommended to wait for my stamp of approval
for anything. It is my intention to do the repeatable experiment
and deduce the science upon which I can make recommendations.
I and several others have been looking over the 'net on the topic
and you can find a few rational pieces but plenty more built on
poor or no measurements.
I'm interested in the energy dissipated by a TVS connected across
a 60A alternator experiencing a load-dump event. I am also interested
in current magnitudes and wave-shapes. If you have measured data
you can share that speaks to this event, I'd appreciate having access
to it.
I'm also going to see how brand new ND alternators behave in this
situation.
You mentioned a fat capacitor across the b-lead as an alternative
technique. Interesting . . . a 22,000 uF cap impressed with a 60A
constant current pulse rises at 2700 volts/second. So if we wanted
to limit the load/battery-dump event to 24 volts max, then
the event duration could not exceed about 3.6 milliseconds. Hmmmm . . .
sounds reasonable. I'm going to look at that too.
>There are such devices available that are designed, tested and industry
>approved for this specific application and rated for the largest alternator
>likely to be found on any acft. The ST LDP24A is one and rated for 500amp.
That 500A figure is completely meaningless when cited out of
context. ALL TVS devices will carry 500A for some duration.
This is a dynamic total energy study where current, voltage and
duration all contribute to the understanding. I object to phrases
like "industry approved" . . . industry is only slightly more useful
than government in bestowing its blessings on things. Processes
and techniques explained with the building blocks that are
simple-ideas of science will stand by themselves and do not gain
value when "approved" by anyone.
>I do not understand the need for additional testing in this case. The
>investigating it??
One member of the list noted that the boaters were being offered
a 70-cent TVS for $29.95 . . .that's why. If you have data from
an experiment that tells us whether or not the 70-cent TVS has
been properly sized and you can share it, then I won't have to
do it . . . or can you point me to a published paper that
describes the experiment?
>With all due respect my comments are intended to be helpful.
Factual but off-point. Nuisance trips and damage therefrom
are not the problem that started this thread. The phenomenon
pops up on what we've observed is a limited population of alternators
wired per Z-24 and only when used in a manner outside the
normal operating envelope for aircraft alternators. The testing
is not intended to confirm or deny need for the TVS. I want to
understand the event and validate the selection of a suitable
component.
The catalogs list hundreds of TVS parts each obviously suited
to some kind of task. The LDF24A is just one of many such
parts and may well be the holy grail of load dump defense
but I'd like to know the details. In the mean time, your
recommendations are welcome and can be operated upon by anyone
on the list as they see fit.
Cook-book engineering suffices for 99.9% of the system design
work going on in the world. We're studying application
of a circuit seldom needed but EXTREMELY useful when it is
needed. I'd like to understand more than what the books choose
to tell us.
For example, I'm working a problem right now where a high
quality, 4 amp, Honeywell SM series Microswitch is failing OPEN
after a few hundreds of cycles. The contacts drive a pair of #327
lamps (0.04A each). The switches are clean and not overly
stressed from an environmental perspective. I'm discovering
an ELECTRICALLY driven phenomenon that I've not seen mentioned
in any text to date (that doesn't mean it hasn't been written
about . . . only that I can usually re-discover the problem
faster than I can scan through all of the print literature).
Every time this happens in the airplane, it generates a
$kilo$ maintenance event.
Have another problem where a mil-spec relay is sticking CLOSED
after a relatively short service life in the airplane. Interestingly
enough, BOTH of these cases seem to be related to the same
phenomenon. I'll know more in a couple of weeks. The
knowledge to be gathered is coming off the workbench.
This event also generates a $1,000+ cost to return the aircraft
to service.
I can also tell you that I've had experts from the manufacturers
of these products set across the table from me and suggest
that I must be using their product in a manner outside
their specified operating envelopes . . . but to a person,
not one could describe the experiment to confirm or refute
the hypothesis. What I think I'm zeroing in on is a phenomenon
that few folks bother to control in the design and specification
of switch contacts.
I'm not recommending or suggesting that anyone wait on
me for anything in their decision making processes. I'm
only saying that right now, I don't have enough data
to offer an explanation of the simple-ideas that will ultimately
support any recommendation I might offer in the future.
In the mean time, a very easy answer to the problem is
don't turn the alternator off while the engine is running
except for the obvious case of malfunction.
From: | Jerzy Krasinski <krasinski(at)direcway.com> |
Subject: | Re: Compass shielding |
hollandm wrote:
I'm getting interference between an electric turn coordinator and a compass (about
2 degrees). Before I start moving things around I was wondering if it would
be possible to shield the compass by surrounding it with some copper screening
or the like, sort of mu-metal chamber approach.
Has anyone tried this and if so did it work?
Do not bother with shielding the compass, it will not work. The compass
MUST be exposed to external magnetic field, this is how it finds
directions.
Two degrees is a very small deviation. Do you always hold your heading
with two degrees precision?
The question is if this deviation is caused by the presence of the turn
coordinator, or is it caused by switching the coordinator on. If it is
caused by the current make sure that you do not have a current loop,
i.e. use two twisted wires (power and ground) to power the turn
coordinator, rather than one wire and ground next to the coordinator.
If you use two twisted wires and still get the deviation, you could put
a magnetic screen around the turn coordinator. The best would be
miumetal or European permalloy. If you cant get these use a soft iron
sheet wrapped around the coordinator. Cooper would not work.
If the deviation is not current related you have no problem. Even a
bigger deviation would be within the compass compensator limits. The
compensating screws are somewhere on the compass and are described E-W
and N-S. If your compass does not have the compensation screws you
should throw it away and replace by one with these screws.
Here is one of possible compensation procedures:
1) Point the plane to exactly to the magnetic North using another
external precise compass or or some other method.
(Do not use the compass that you compensate to find North, that
compass will most likely show some deviation.)
Turn N-S screw with a brass screwdriver until the compass of your
plane shows N, i.e. reduce the deviation to zero
2) Swing the plane to the magnetic East established by the external
precise compass
Turn E-W screw until compass shows East, i.e. reduce the deviation
to zero
3) Swing the plane to the magnetic South. Read deviation of the compass.
Turn N-S screw until the deviation is reduced to 1/2 of the
original deviation.
4) Swing the plane to the magnetic West. Read deviation of the compass.
Turn E-W screw until the deviation is reduced to 1/2 of the
original deviation.
Go back to point 1) and repeat the whole procedure again. Pay attention
to the size of the corrections, now they should be much smaller than
those during the first swing.
Go back to point 1) . Swing it around again. This time you should get
almost stable situation.
Go back to point 1) . Swing it around without touching the screws and
write the deviation of the compass as a function of direction. Read it
every 45 degrees. The deviations should be very small, but no compass in
a plane with all the iron around would show exact directions.
Make a graph of the deviation and glue it to the compass, or next to it.
Jerzy
Only to you Stan,
How important in the engine driven power supply's when the engine quits?
Maybe you have a use for two alternators right about then but I sure don't.
A very good battery or will give my essential bus the power to do the
required thing and maybe even restart the engine. Alternators have never
started an engine for me yet. This is why a running dual E.I. systems is
nuts to me. If you don't have enough energy to run the systems on battery
power it is a special feeling to know the magneto is not dependant on an
alternate source. Unless you have a big system it doesn't make sense to
this systems designer.
It all depends on the size of the project. No one system fits all. And
here I am talking small 2 place airplanes, night flying capable with limited
weather penetration ability.
Systems which allow for a failure of the alternator and then plan for the
pilot to land in the next 30 to 60 minutes are doable. Systems which allow
you to make your desired destination are heavy and add cost.
Dale Martin
Lewiston, ID
LEZ-235
Subject: AeroElectric-List: Re: AeroElectric-List Digest: 29 Msgs - 02/09/04
> > power source.
> > Bob . . .
important
> one.
> Stan
From: | Mark Steitle <msteitle(at)mail.utexas.edu> |
Subject: | Re: Capacitive Fuel Gauges |
> So, if you have a probe you like and a piece of shielded wire
> picked to connect probe to electronics, the task is to mate the
> electronics to the probe/cable combination. Jim's schematic includes
> empty and full adjust pots. What you need to know is how close
> the probe you have comes to the one Jim describes. His circuit
> CAN be made to work with about ANY probe.
> Bob . . .
Thanks Bob,
I have contacted the manufacturer for this information. Will have to wait
and see what they say. If that fails, I will have to find a way to measure it.
Mark S.
From: | Charles Brame <charleyb(at)earthlink.net> |
Subject: | Determining Speaker Requirements |
I have a small, nice looking speaker that I would like to install in my
OBAM. However, it has no markings indicating its impedance. My intercom
system specifies a 4 ohm speaker.
How does one determine the impedance of a speaker?
Can I assume an ohmmeter between the speaker terminals will show the
correct impedance?
In a message dated 2/10/04 9:31:54 AM Central Standard Time,
jschroeder(at)perigee.net writes:
> that route.
Hi John-
If you got the AutoCad dwg of the circuit you can see the mask I used to
label the annuciator- I just opened the drawing, selected a print window around
the mask and printed on overhead projection sheets on a laser printer. It's
just taped to the back of the overlay in the correct position. Works great in
7.4 hours of ACTUAL FLYING TIME so far!
8-)
Best wishes-
Mark (ripsteele is dead- long live fiveonepw(at)aol.com!)
Subject: | Rotary Spreadsheet |
Mark
Here is a spread sheet that will calculate engine parameters for a one, two,
three or any (must change cell value to number of rotors you want} number of
rotors. Ihave expanded the results sheet to show air flow in CFM and
lbs/min as well as btu heat factors and other useful parameters. The engine
calculations are within 2-5%. The cooling results are less valid but has
shown good correlation with folks using evaporator cores
Ed
Ed Anderson
RV-6A N494BW Rotary Powered
Matthews, NC
From: | Richard Tasker <retasker(at)optonline.net> |
Subject: | Re: Determining Speaker Requirements |
No. Measuring with an ohmmeter will only give you the DC resistance of
the speaker windings - this is NOT the rated impedance. There are ways
of determining the rated impedance but it requires more than an ohmmeter
for test equipment. A higher impedance speaker will not hurt your
intercom - it will just make the maximum volume lower. It is unlikely
that the speaker is much lower than 4 ohms.
Dick Tasker, RV9A #90573
>correct impedance?
>Charlie
Subject: | Re: Rotary Spreadsheet |
Sorry, Folks.
Hit the send button before engaging brain
Ed Anderson
Matthews, NC
Subject: AeroElectric-List: Rotary Spreadsheet
> Mark
two,
of
engine
> Ed
> Ed Anderson
> Matthews, NC
Subject: | Re: Z12 e-bus questions |
>Hi all (Bob),
>I'm planning on using a Z-12 type system on my Rocket. One battery, two
>alternators.
>I notice the e-bus alternate feed is through a 7 A (fuse?) via a 16 AWG wire.
>Two questions: For peace of mind would a breaker be the best way to go
>here?
>I'm thinking that I can easily overload the 7 amps just with the e-bus as
>described in Z-11. The plane will be outfitted for night flying, and needs a
>fuel booster pump. So if I end up with more than 7 A (which either I will
>have, or be very close to) when I loose the main power (assuming two dead
>alternators), and throw the switch, at least I can get smart, shed load and
>reset the breaker. For the most part though, I plan on using fuses,
>because I
>too have never reset a breaker were there wasn't a problem that resetting the
>breaker actually helped, and I plan on having each circuit with it's own fuse.
>Second question: Why only 7 amp protection device off the batter bus? The
>wire should be able to handle 12 amps? So why not use the protection
>device to
>protect the wire, since each of the devices coming off the e-bus will be
>protected on it's own?
>Thanks in advance, and also for all the past advice.
The Z-figures are intended to define the ART of system
design. This is where you pick through the big box of
Erector-Set, Tinker-Toy, and Lego parts to see how they
best fit together in a system that supports your project's
mission. The Z-figures should NOT be taken as verbatim
of the SCIENCE which dictates component selection.
When you "assuming two dead alternators", you're
getting ready to address a REALLY bad day. The likelihood
of dual failures in any single tank of fuel is extremely
remote. Any piece of wire more than 6" long taking a feed
from a bus with high fault current capability (your battery
may well deliver upwards of 500-1000 amps in a hard fault),
then we say it needs protection. If you're e-bus, e-bus
alternate feed and battery bus can be all wired up with
6" pieces of wire, you don't need any fuse or fusible link.
If the wires are longer, then . . . well, shucks. Now,
if you need an e-bus alternate feed exceeding 5A from
the battery (or battery bus) then using a relay as shown
in:
http://www.aeroelectric.com/temp/E-BusFatFeed.gif
seems prudent. This architecture provides a low power
version of a battery contactor to provide at-the-battery
control of a feeder. The same caveat exists for all
feeders from the battery whether e-bus alternate feed
or feeders to goodies that support an electrically
dependent engine. You mentioned a fuel pump . . . I
wouldn't drive this from the e-bus but directly from
the battery bus via it's 5A or less fuse and no relay
or a 7A+ fuse and a relay.
The VERY FIRST documents you need to craft in your
electrical system design are a tabular listing of each
feeder that comes off each bus. The system that feeder
supplies, the size of protection be it a Lego fuse or
Tinker-Toy breaker, size of the wire, then draw 7 columns
where you're going to deduce and add up the current draw
on each feeder under the following headers, (1) preflight,
(2) taxi, (3) takeoff/climb, (4) vfr cruise, (5) ifr cruise,
(6) approach to landing and (7) alternator-out.
Go get this document:
http://www.aeroelectric.com/temp/LoadAnalysisHandOut.pdf
The first page is an example of how to start this task.
The second page is blank so you can fill in what fits for
your project. You need one page for each bus.
Note that this document becomes a list of all the goodies
in your airplane, how much energy each combination takes
for operation. It can also be an index for your page-per-system
documents that will ultimately record how your airplane
is wired.
Subject: | LED light bar annunciator panel? |
I would like the AutoCAD file for the Label of the annuciator please.
Jeff.
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
Fiveonepw(at)aol.com
Subject: Re: AeroElectric-List: LED light bar annunciator panel?
> that route.
Hi John-
around
in
8-)
Best wishes-
Subject: | Re: For Bob, Comment? |
> > There is an upcoming program on Public Broadcasting: NOVA: The Deadly
>It deals with an inflight fire caused by electrical arcing.
>Have seen this program a couple of weeks ago, It make you wonder how a
>commercial aircraft can have its wiring set up in such away that the pilots
>were unable to isolate the entertainment system from the main cockpit Bus!
>No breakers tripped to alleviate the problem, just smoke from behind
>panelling,
>I find it hard to believe that circuits are shared without proper regards
>too overload wire protection, Its criminal that so many folk lost their
>lives due to a preventable wiring short circuit.
It's a little more subtle than what you seem to perceive.
The soft-fault condition in wiring has been a design issue
for a number of folks for at least ten years if not longer.
Irrespective of the type of wire (Kapton may be crappy but
Tefzel can be mechanically damaged too) we can have openings
in the insulation that promote the low current arc that doesn't
draw enough current to trip the breaker. The higher the voltage
goes, the bigger the problem becomes. This is a VERY hot (no
pun intended) topic with the 42V car-guys.
The fact that this particular fault happened in the entertainment
system is irrelevant. It could have happened in any system. When
the pilots were confronted with smoke, there was no way they
could know nor would they care which system was having trouble . . .
Eaton and others are working on smart circuit breakers that
can detect the unique current signature of a soft-fault. They've
perceived a really big market opportunity for replacing all the
breakers in a panel . . . while expensive, it's probably cheaper
than rewiring an airplane.
This incident, typical of all accident scenarios, is a joining
of links in the chain. Breaking any link would have averted the accident.
(1) cracks in wires on (2) system voltage high enough to
support a soft-fault arc (3) close proximity of combustible
insulation (4) inaccessible to crew to fight fire (5) and
so rare an event that the crew could not conceive how much
trouble they were in. Had emergency condition behavior
been initiated sooner, etc. There are probably other links
in this deadly chain I've missed.
While I've ranted as much as anyone about Kapton, we cannot
ignore the fact that this single failure did not cause the
accident without the assistance of numerous other conditions
piling on too.
There's plenty of blame to go around.
From: | Charlie & Tupper England <cengland(at)netdoor.com> |
>correct impedance?
>Charlie
If it's a typical voice coil type speaker (and it almost certainly will
be) then DC resistance measured with an ohm meter will be about 60% to
80% of the actual impedance of the speaker. As long as the DC resistance
is at least 2.5-3 ohms, you will be safe in hooking it up to your
system. If it's an 8 or 16 ohm speaker, it will probably still work. It
might not be quite as loud as a 4 ohm speaker, but there is so much
variation in efficiency among various speakers that yours might end up
being louder than any random 4 ohm speaker you might find.
Audio/electronics tech in a previous life
Subject: | RE: Load dump protection |
I'll suggest we're not "beating it to death." The standard
approach to education is "put tab(A) in slot(B) and trust
me it will work."
It is incumbent upon anyone who aspires to the title of
teacher to figure out ways to explain and better yet,
demonstrate the underlying simple-ideas that support
any design solution. All this discussion has been here
before and will come around again under some new
circumstances in the future. All of this "beating"
is but a couple of weeks out of THIS semester, like
the inimitable Arnie, it WILL "be back."
I've been reluctant to sign up to "stick TVS(a)
into system(b) and trust me it will work" because
until the current discussion, there was no demonstrable
need to protect every accessory in the airplane from
demons not fully characterized. When the demonstrable need
finally presented itself, it may well turn out to be
vulnerability in a component where the manufacturer
deliberately chose to ignore the risk!
E.G. Microair says anything over 16v puts their radios at
risk. Hmmm . . . even the lowly TVS won't help us here.
If I were to dragon-proof the Microair radios, I'd have
to design power conditioning EXTERNAL to the radio that
Microair should have made INTERNAL to the radio.
I agree that a TVS has a 99.9% probability of being
the elegant fix to offset what may be a conscious
decision on the part of a product designer to short-
change his customers. I'd like to know the numbers.
I'm not resisting the idea at all. But I will
understand and be able to explain the simple-ideas
and repeatable experiments that support it before I
integrate it into the curriculum for my seminars.
In the mean time, all this "beating" is healthy
stirring of the floobydust from which we'll sift
the science and elegant solutions.
Made an interesting discovery today while chasing down the source of EMI
from my Dynon. Like many, I have a distinct noise in the headsets,
which goes away when the Dynon is turned off. My electric system is the
main bus/ essential bus, per Lectric Bob. Both the Dynon and Comm are
on the essential bus. While futzing around, I turned the E bus switch
on while leaving the power master on. The noise instantly decreased
about 80%. The battery is getting rather tired from so much ground use,
and the voltage at the Dynon was showing 10.4V. When the E bus was
switched on, the voltage increased by 0.7V (the amount dropped by the
diode feeding the E bus.) Intrigued, I hooked up the battery charger
and tried it again. The voltage at the Dynon was now 12.5V with the E
bus and battery switches on, and the remaining noise decreased by about
half, to a level I consider pretty close to acceptable. In addition,
the strobe noise I was experiencing also disappeared.
For those experiencing EMI on the ground (not yet flying, like me) you
may want to give this a try. I have not had a chance to test this with
the engine running yet, perhaps in a day or two I will have time to do so.
My theory as to why this is, and it is an uneducated SWAG- the noise
filter circuits inside all of the boxes (Dynon, radio and strobe
supplies) are not functioning because of the low voltage, while the
units themselves appear to work. What does anyone think of that?
Jeff Point
RV-6 getting very close
Milwaukee WI
From: | Dj Merrill <deej(at)thayer.dartmouth.edu> |
> me it will work."
FWIW, I've found the discussion very interesting
and educational. I certainly didn't know much about the
topic before this. Please, continue as necessary! :-)
I've also learned why the switched labeled
"alt cutoff" in the already-built experimental plane I bought does
nothing once the engine is running.
I have one of those internally regulated alternators
that once it has power, continues to self-excite
regardless of the cut-off switch. Which is why I
am waiting with baited breath to see where this
discussion goes, since I'll likely "fix" the issue.
-Dj
Subject: | Re: Dynon and EMI |
I really appreciate that point as I am getting ready to purchase the Dynon
EFIS. Wonder how it will be affected when the 24 volt battery is low.
Hmmm..... Interesting.
- Dale
Subject: AeroElectric-List: Dynon and EMI
> Jeff Point
> Milwaukee WI
Subject: | Compass shielding |
The disturbance occurs on switching on the TC and appears to be reproducible.
Concerning the suggestion to obtain mumetal for shielding or permalloy, where would
one obtain such materials?
In the mean time I'll get some tin as Bob suggests and get back to the group.
Excellent, thanks. Just a couple more questions for the un-informed (me).
See below.
SNIP> If the wires are longer, then . . . well, shucks. Now,
> in:
In both cases you mention going larger than 5A a relay is required? Is this
just because it is driving a motor (pump) or what am I missing here? I don't
need to put a relay in for all loads larger than 5A do I?
I had almost done this, at least for the first three columns (I had one more
column for switch required/type). I like your document better and looks as
though it will guide me in a more analytical path.
Jeff
> is wired.
> Bob . . .
Check Goodfellow at www.goodfellow.com. You need a thick foil. I think
they have 0.125 mm. The problem is that they sell this stuff in rolls
and you need much less. Ask them about distributors.
Jerzy
Jerzt
You can find more at this damn long addressL
http://search.netscape.com/ns/boomframe.jsp?query=mu-metal&page=1&offset=0&result_url=redir%3Fsrc%3Dwebsearch%26amp%3BrequestId%3D18de54f3a00ff8ca%26amp%3BclickedItemRank%3D1%26amp%3BuserQuery%3Dmu-metal%26amp%3BclickedItemURN%3Dhttp%253A%252F%252Fwww.goodfellow.com%252Fcsp%252Factive%252Fstatic%252FA%252FNI03.HTML%26amp%3BinvocationType%3D-%26amp%3BfromPage%3DNSCPIndex&remove_url=http%3A%2F%2Fwww.goodfellow.com%2Fcsp%2Factive%2Fstatic%2FA%2FNI03.HTML
would one obtain such materials?
What brand is the T&B? (One of those Chinese knockoff I'll bet)
Bruce
www.glasair.org
hollandm
Subject: AeroElectric-List: Compass shielding
reproducible.
where would one obtain such materials?
group.
Embedded comments
alternator
removed
Dump
> >concerns.
vis-a-vis
> protection."
I was not saying you had said what I was saying. My point is that ALL
alternators internal and external need to be addressed. The fact that Onsemi
has a regulator with internal load dump does not mean the regulator of a
2004 alternator has load dump protection. The I/C mfgrs have been pushing
load dump protection for at last 20 years that I am aware of with limited
success until recently where modern autos can have thousands of dollars of
electronics at risk.
I have not seen any hard evidence that Van supplied regulators are of lesser
quality, circumstantial perhaps but there may be other reasons.
I was trying to point out that the problem may be very widespread (in
potential)and its only recently that its showing up on Vans acft and perhaps
there only because of pilot procedures and the large number of these
experimentals.
Yes and I think that any design that allows of improper use of unguarded
switches results in damage is unacceptable, at least my acft.
I have a friend who has another spam can (high end acft) that blew an
alternator when the master was pulled when smoke in the cockpit was noticed.
The smoke cleared and the master was reset and the alternator was NG. Later
shown to have several diodes shorted presumably due to load dump. There was
an external reg that was unharmed. This acft was wired by the factory that
way
> system variables.
I agree but a design that allows a pilot to simply throw the wrong switch
and cause alternator or worse failure is a bad design. Even switch layout on
the panel is not acceptable to me as we are dealing with Private pilots who
can make mistakes.
long
and
due
I hope you will test curent production ND NEW alternators to prove your
theory
tripping
that
The following is from a recent post of yours and over the years has been
repeated several times a year. This with regard to the OVP module design you
have provided to all of us. The LTC1696 is specifically designed so you can
set the trip pulse width time to avoid nuisance tripping from short spikes.
This is not possible with your design per your supplied schematic.
"Nuisance tripping of the crowbar ov module is rare but it
HAS happened and at higher rates than real ov tripping.''
> discussion.
Disagree as we should be addressing every application not just a matched
set from B&C.
As a nuisance trip with out load dump protection can fail the alternator and
this should not only be addressed but mitigated. Failure of a protection
device should never cause failure of the device being protected. Just as
failure to use a specific switching procedure should not damage components.
(too
a
its
> >energy pulse.
Then why not include every alternator in the discussion ?, not limit it to
Vans rebuilt internal alternators
protection
Recent comment from you I was referring to.
""It is therefore my belief that the very popular 40 Amp Denso bought new
from
Niagra has a regulator which has dump logic in it. ""
I was simply stating that without a battery some regulators are unstable
and adding a capacitor has been proven to stabilize the regulator. If the
battery charge current (the source of the load dump) is small when the
battery is disconnected the capacitor will dampen the spike. It may not be
of much help with a 50 amp Load dump.
alternator
500amp.
Its not meaningless IF you take the time to look at the data sheet which was
my intent. I never intended to provide all the details, just the link. In
this case the duration is specified at 0.2 second (more than long enough)
and clearly longer with 1/10 the current we are dealing with vs. the rated
500 amps.
Thank you for well thought out replies.
Paul
Subject: | Load dump protection |
> Perhaps I should have need more specific with my comment about "beating it
> to death. The industry has decided that the solution to Load dump
protection
> is simply a TVS added to the regulator. Thus I was simply saying The only
> decision is the specific TVS to add to our Alternators.
> While some "modern" internally regulated alternators may be protected from
> load dump its unclear how ANY externally regulated alternator will control
> load dump as the protection MUST be across the "B" lead to ground.
> As for testing, I am all for it but with the vast number of alternators
and
> regulator combinations internal and external (including the ever popular
low
> cost Ford) it would seem that there is no reasonable way to provide 100%
> assurance. Not that that is a requirement.
> My basic point was and is that until proven innocent every alternator
> (internal OR external regulator) needs a "B" lead load dump TVS.
> Another concern is the Load dump TVS voltage can be quite high relative to
> 16V during the peak current of the load dump. Thus, equipment not rated
for
> something over 20V should be looked at carefully. As you have often
> suggested not all equipment meets DO-160 but should.
> Paul
> death
> > me it will work."
Embedded comments
alternator
removed
Dump
> >concerns.
vis-a-vis
> protection."
experimentals.
way
> system variables.
can make mistakes.
long
and
due
theory
tripping
that
> discussion.
set from B&C.
(too
a
its
> >energy pulse.
protection
from
alternator
500amp.
500 amps.
Paul
Subject: | Only to you Dale |
Dale,
Guess I misunderstood the original statement. I happen to agree with you on
the dual EI systems.
Stan
In a message dated 2/11/04 2:57:20 AM Eastern Standard Time,
<< How important in the engine driven power supply's when the engine quits?
alternate source. >>
Jeff,
Properly designed and tested EMI filtering in a product will work from it's (the
products)
minimum to maximum specified operating voltage. The filters characteristics need
to be matched
to the characteristics of the internal active circuits.
Every product I have designed, from a simple residential water softener control
to industrial
machine controls were / are tested to comply with stringent radiated and conducted
emissions and
susceptibility standards (EMC standards). These tests insure that the product
will not
interfere with other products and are not affected by radiation from other products.
Typically, all connections, not just the power connections, to / from a product
need filtering
to meet the EMC standards. Months ago, Dynon indicated to me that they didn't
have a formal EMC
test program for their product. What you have observed may be a result of that
policy.
James A. Rodrian, P.E. (Defiant)
Grafton, WI
Microprocessor-based product development since 1977.
Time:
Jeff Point
Subject:
Dynon and EMI
from my Dynon.
Jeff Point
Milwaukee WI
I'm getting dizzy.
Jim,
When you say filtering - Is that synonymous for shielding? In your
opinion - is the Dynon EFIS missing the mark here or is there a simple
solution for a demanding builder?
Dale Martin
Lewiston, ID
LEZ-235
Subject: Re: AeroElectric-List: Dynon and EMI
> Jeff,
it's (the products)
characteristics need to be matched
control to industrial
conducted emissions and
product will not
products.
product need filtering
didn't have a formal EMC
that policy.
> Grafton, WI
> Time:
> From:
> Jeff Point
> Subject:
> Dynon and EMI
EMI
> from my Dynon.
> Jeff Point
> Milwaukee WI
> > protection."
Didn't say there was. this is the WORKING hypothesis that will
have to be proved, disproved or discarded as irrelevant.
>experimentals.
The POTENTIAL is certainly widely spread. I don't think anyone
ever said the risk was zero. It did not become a marketplace issue
until Van's noted a demonstrable problem and published
a 'fix' that was short on understanding and increased the risk
of more expensive difficulties in terms of OV failures.
>way
Yup, that's the nature of the beast called an FAA certified
flying machine.
> > system variables.
>can make mistakes.
Goodness or badness can debated interminably. Risk however is
readily studied and can be used to make considered decisions
for both design and operation. It is a fact that ANY airplane,
spam can or otherwise can generate the load-dump event by opening
the master switch while the alternator is loaded. If putting
guards over any switches makes someone feel better, so be it.
>long
>and
>due
>theory
That's what I said. B&C uses factory fresh ND alternators
as cores for their products. however, I'll suggest that my
testing of these particular alternators will not PROVE my
theory about Van's machines, only confirm that the present
production NDs are relatively immune from damage by load-dump.
The real meat of this test will be to know how much energy
we're talking about and the form it takes.
>tripping
>that
Excuse me? How is the current design not adjustable for
delay? The RC time constant of the voltage sense circuit
can be adjusted for increased or decreased response time.
The LTC1696 is a nice chip. It starts a timer based on
excursions past a threshold and resets the timer if
voltage falls below the threshold before timeout. I've
implemented that function several times for customers
using a non-integrating front end detector driving a
fixed time delay later.
The aircraft industry likes to embrace Mil-STD-704
notions about OV events where integrating the sensed
signal up front makes the ov sensing both TIME and AMPLITUDE
sensitive. They expect to see the ov trip time go down
as the fault voltage goes up. The LTC1696 doesn't work this
way. However, EITHER philosophy can be used to fabricate
an effective ov protection system.
The only nuisance tripping we've experienced in about 10+
years was a marked dv/dt event that first cropped up in
production Bonanzas. We now believe that the few cases
of nuisance tripping we observed before the Bonanza mod
program were similarly generated. Since that time, I've
had no conversation with anyone where their "nuisance trip"
was not ultimately confirmed to be a true ov condition
or overshoot due to poor regulator performance.
> > discussion.
>set from B&C.
You put words in my mouth again. I said poor combinations of
alternator and regulator. In these cases, I'm talking about regulators
that shouldn't be used on any machine . . . has nothing to do with
B&C's products. These were regulators that would overshoot so badly
on real load-dump (battery still connected) that they tripped
the ov protection.
No argument here.
Who was proposing anything different? Again you mis-characterize
my words. My goal is to publish a change to figure Z-24 that will
be a recommended configuration for all installations. I don't
have nor do I want to control the brand or source of alternator
anyone chooses to use. Figure Z-24 is never going to say something
like , "Use this configuration for Brand A but not for Brand X".
It will be recommended for ALL internally regulated alternators.
We'll probably add it to other Z-figures and discuss it in the
chapter on ov protection. This activity will undoubtedly confirm
the size and usefulness of a low cost mitigation philosophy that
might as well be included in all systems . . . although our experience
with both OBAM and certified aircraft has demonstrated this failure
mode be a very low risk.
I'll also present findings from this activity to my fellow sparkies
at RAC. Whether or not anything happens there is problematical.
Return on investment dollars will be tough to justify on such a
rare and probably undocumented event. We're advancing the art
in OBAM aircraft systems design at a rate that far outstrips
the efforts in spam cans.
> > >protection built in so we can consider them for our use.
>from Niagra has a regulator which has dump logic in it. ""
Simply a statement of fact. Someone suggested that Niagra offered
new ND machines and to date, I've not heard of anyone blowing
a Niagra alternator wired per Z-24. It's true that we may hear
of it tomorrow . . . but for the moment, a simple belief concerning
features they may (or may not) contain. It's not intended to be
a recommendation to anyone. Those will be fully defined when Z-24
is updated and I publish the article on the experiments.
Never can tell. Since you didn't refute or confirm my 3.6 millisecond
hypothesis, we'll still go to the test bench and do the science.
It's an interesting feature to explore.
>500 amps.
Now you've qualified your 500A pronouncement in a useful way.
The DATA SHEET for this or any other device offers us insight
to an ability to manage energy. No alternator is going to produce
a 500A surge to any protective device. The original statement
suggested that this 500A device was suitable for any sized alternator.
The number 500 is impressive but irrelevant when pulled out of context.
My pleasure sir.
Subject: | Twisted pair cable |
Bob, do you have a favorite shielded twisted pair cable that can be used
for various things ahead of the firewall and behind it? Do you like the
Belden 82729 or is there something better?
Dave Morris
Subject: | Noobie Questions |
From: | "Metcalfe, Lee, AIR" <Lee.Metcalfe(at)jocogov.org> |
I have a Lancair 320 that I bought from the builder. I am planning to
re-wire the electrical system this spring to update it (12 years old)
and replace some amateurish workmanship. I attended Bob's seminar last
weekend and learned a lot, but I still have a lot of questions. I'm
sure I'll be back with more questions as I plan the new system, but here
are my first three...
> None of Bob's Z-figures show any circuit protection in the battery
contactor control circuit (BAT master to battery contactor solenoid).
Is this an oversight or is protection not needed?
> I see no provision for an avionics fan on any of the bus drawings.
Should not the avionics fan be connected to the main bus (or e-bus if
you have one) via circuit protection? The current set-up in my plane is
the avionics fan is hard-wired to a power source (haven't found it yet)
with no circuit protection (confirmed by pulling all circuit breakers
and it still runs with the BAT master on).
> I am planning on using B&C's LR-3 alternator controller. Do I still
need circuit protection on the B-lead, which will be tied to the
switched side of the battery contactor (it is currently tied to the main
(and only) bus through a 35A breaker).
All advice appreciated!
Lee Metcalfe
Flying Lancair 320 (500+ hrs.)
From: | "Glen Matejcek" <aerobubba(at)earthlink.net> |
Jerzy-
>directions.
According to my friends in the HUD manufacturing business, your statement about
shielding the compass rendering it useless is incorrect, at least with respect
to mu metal. I suppose this could be different with flashing material, but
IIRC shielding damps dynamic magnetic fields such as EMI, while the earth's magnetic
field is static from the compass' frame of reference. Having said that,
it still makes more sense from the theoretical perspective to shield the antagonist
rather than the victim. Most likely from the practical application perspective,
also.
Glen Matejcek
Subject: | Re: Noobie Questions |
Hi Lee,
Some good questions. I took a stab at answering them below.
> contactor control circuit (BAT master to battery contactor solenoid). Is
One side of the master contactor is made hot from by the very short
run to the big lug on the contactor. No protection needed there. The
other side of the contactor, which gets connected to the master
switch, provides a ground path for the contactor to be activated. If this
wire is faulted somewhere, the worst thing that can happen is that the
master contactor stays on all of the time.
Maybe (hopefully) there is an in-line fuse to a connection to a battery
bus? Never the less, I like your idea of running any required avionics
fan onto the main bus. I would only connect it to the e-bus if
something on the e-bus actually requires cooling. If an essential piece
of equipment does require supplemental cooling, I would consider
that as a strike against it. It would be nice to shed the load imposed
by fans when on a limited power budget.
If you are going to stick with a single battery, single alternator system,
I would wire it up like Z-11. The alternator B-lead protection is in the
form of an ANL close to the alternator. In Z-11, the (maybe) long run
from the battery contactor to the engine area is shared between the
starter and the alternator. An elegant setup.
> Lee Metcalfe
Sounds like a good project.
Matt-
N34RD
Subject: | GPS Data port wiring |
Hello Learned Listers,
I am trying to put a 9 pin serial connector under my panel for the purpose
of allowing a serial (RS-232) connection that comes out of a GPS (a Garmin
196 in this case) so that a laptop can update its map info.
The laptop only has USB ports (they are both USB version 2.0), so I need to
get a USB-to-RS232 converter cable to make the connection.
Two questions:
1. should the 9 pin connector be male or female, and,
2. should the the tx and rx leads be reversed on the connector, or is that
already done in the USB cable?
If someone has already wired this and could let me know in advance of
getting the cable and installing the 9 pin connector, and doing my own
experiments, I would appreciate it.
Gary Liming
From: | Chad Robinson <crobinson(at)rfgonline.com> |
Subject: | Re: GPS Data port wiring |
> Two questions:
The USB cable creates a port identical to what you would have on the laptop if
you had a real serial port. That is, a 9-pin male DTE (terminal side) port.
Your GPS device almost certainly provides a 9-pin female DCE (communications
side, such as a modem) port. The best option would thus be a 9-pin female
connector, assuming you're creating your own. Wire it straight through, pin
for pin, because the mapping is generally done in the device, not the cable.
If it doesn't work, try a null modem adapter, and if that makes it work it's
usually a simple enough matter to swap pins 2 and 3 so you don't need the
adapter anymore. No reason to lose sleep over it.
Be careful with these USB cables. There are different quality devices, and
some of them are really only designed to connect serial mice to a PC, not any
other type of serial device. That is, they don't actually create serial ports.
Devices based on FTDI's chipset, which you can find dozens of on eBay on an
average day, are a good bet - these provide a device driver that actually
creates a virtual serial port that your map software can talk to.
Chad
Not needed. There's no way you can put that wire at risk.
The Z-drawings are intended only to convey architecture . . . not
details as to what gets powered from which bus or with which size
fuse/breaker. The first documents you need to complete are the
load analysis documents for each bus. See:
http://www.aeroelectric.com/temp/Load_Analysis.pdf
Here is where you account for nearly every device in the
airplane, where it gets power from, under what conditions
it is used and how much power it takes.
Your current fan may be protected with an in-line fuse.
The convention is to put a current limiter (fat fuse) in series
with the b-lead to protect the rest of the airplane from the
hazards of shorted diodes in the alternator.
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
That depends upon which converter you get. Take note of the gender on the
laptop, and on the Garmin, then go to a computer store that has gender
matchers, the converter, and cables with different kinds of ends. Make it
if you can't buy it, it isn't hard.
HTH,
AI Nut
Subject: AeroElectric-List: GPS Data port wiring
to
> Two questions:
> Thanks,
> Gary Liming
Thanks for the help so far, but has anyone wired this up? The Garmin only
provides Tx, Rx, and ground pins on its own round 4 pin connector that also
provides power to the unit, so it is not possible to say if its DTE or DCE
(which determines DSR/DTR and RTS/CTS behavior) or to determine the
connector gender. Presumably this means one does need to connect Rx on the
Garmin to Tx on the 9 pins side of the USB cable as well, but I was hoping
not to get it right the first time.
I am not so much concerned about the ruggedness of the USB cable, since it
is only used to update the GPS data (or unload data to the laptop) while on
the ground.
Thanks again,
Gary Liming
DTE and DCE only refer to which direction the data flows on which line.
Other (control) lines do various jobs that apparently the Garmin doesn't
need or support.
Gender of the connectors refers merely to whether there are pins (male) or
holes (female.) Purely a mechanical issue.
Very basically, get connectors that will mate the male to the female ends.
Then, connect the tx line from one device to the rx line on the other
device, and vice versa. Ground to ground. Done.
Subject: Re: AeroElectric-List: GPS Data port wiring
the
it
also
the
on
> the ground.
> Thanks again,
> Gary Liming
The TC may well be Chinese, who can say these days, but it claims to be manufactured
by mid continent, model 1394T100-7Z.
I haven't been able to scratch up any galvanized tin yet and still searching for
a few square inches of mu-metal.
The electrical separation idea is a no-brainer, unfortunately there are no available
places, within my field of vision where that is possible.
Did try twisting the feed line, no effect.
It is definitely related to the electical field generated by gyro motor since it
only shows an effect on the compass when switched on.
What kind of airplane is it in.... Just curious.
-Dale
manufactured by mid continent, model 1394T100-7Z.
searching for a few square inches of mu-metal.
available places, within my field of vision where that is possible.
since it only shows an effect on the compass when switched on.
Glen Matejcek wrote:
>Jerzy-
>>directions.
also.
Magnetic compass has a very long time constant. Practically, only static component
of the field can move it. Magnetic compass with high inertia disregards fast
changing fields of EMI no matter if you attenuate them or not.
The magnetic shield attenuates the total magnetic field. The shield can not care
less if the field comes from the Earth or from a current loop. Both components
are attenuated equally.
The compass reacts to the TOTAL static magnetic field, and it can not care less
if the source of the magnetic field is a loop with current or the field of the
Earth. If there was a current loop nearby, the compass would point a wrong direction.
If you put a compass in a thin magnetic shield, you reduce the total field and
make the compass sluggish. For the case where a part of the field comes from a
current loop, the shielding would preserve the ratio of these two fields, and
the compass would still sluggishly point (the same as before) wrong direction.
So in such a case the sluggish compass is even less useful, comparing it to
the case without the shield.
If you put a compass into a thick magnetic shield, you would kill all the external
magnetic field, including the field from the current loop and the field from
the Earth. The compass in a thick shield would be blind, it would have have
no idea about external field and it would point in a random direction. In this
case the compass is totally useless.
Your last comment is correct, but it is not only a theoretical rule, it is very
practical. Practically, it is better to organize a ZOO with wild animals in cages,
while in principle one could make an inverse ZOO with viewers in cages
and free running wild animals.
Jerzy
Subject: | Bus Load Analysis |
Bob and All,
Bob ask me in a personal response a couple months back if I had done a
system analysis of the new electrical system.
Well, I had not. Compiling all the things that consume power is what began
this quest to update everything.
My question to the group is - what do we consider essential equipment...
Bob had some advise but I did not right it down. Is it possible for us to
compile a few lists for the VFR and the IFR birds from all the great minds
amoung us?
This may have been addressed in the newer updates to the Connection that I
am delinquent in renewing by only 3 years :-(
It would be a good thing to put in the Zeee Options pages :-) (Pun intended)
It has taken two weeks just to trace down a few operating amperages for some
equipment.
Is this reasonable?
Dale Martin
Lewiston, ID
LEZ-235
> gyro motor since it only shows an effect on the compass when
> switched on.
Easiest fix for the magnetic compass is to not look at it. Most planes
have gps, use that. While taxiing out, set the DG to match the gps
track.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 436 hours
www.usfamily.net/web/alexpeterson
Gary
I use the RS232 Cable that came with my GPSMAP 295. To connect with the USB
port you may need a cable such as shown at
http://www.gpscity.com/gps/brados/517.1.12685021404219988172/usb4adapter.htm
l and software to match the USB speeds to the RS232 baud rates of your GPS.
Hope this helps
Jim
Two questions:
Gary Liming
Subject: | Re: Bus Load Analysis |
>Bob and All,
There shouldn't be any ESSENTIAL equipment . . . at least not in the
sense that if one item in the airplane stops performing that you
break a sweat.
>amoung us?
What you're looking for is a list of commonly used or most useful
items under the various flight conditions.
Begin with a list of all the goodies . . . use a pencil and fill out
load-analysis forms from http://www.aeroelectric.com/temp/Load_Analysis.pdf
You need one form for each bus. Take a best guess at which bus you'll
run everything from and write it down in pencil.
Then publish your work here on the list. It's not a big task and
you can quickly type out the items on each of three or four busses.
Also list the flight conditions under which you'll consider that
item useful/necessary
Folks here will help you decide whether or not any given item
is on the right bus and help gauge its level of necessity. Then
we'll explore what stuff you plan to carry in you flight bag
to back up any items for which there is great utility but no
panel mounted backup.
Doing this in pencil lets you shuffle things around as the
task moves forward. When this is completed, then you're ready
to fill in the squares with load currents and begin to
draw your page-per-system. Note on the example sheet that
your finished document becomes a planning guide for what goes
on each bus, what protection size it gets (the drawings show
breakers but if you're using fuses, just put the protection
size on and "think" fuses), wire size, name of system, page
of your wirebook where that system's wiring will be depicted
and finally, demands that system puts on your battery/alternator
combination in each phase of flight.
This is the single most important planning document for your
system. Next comes the power distribution diagram where
you'll decided just how power is generated, stored, and
distributed to the busses.
THEN you can begin knock each system's wiring off one-page-
at-a-time. It's sorta like eating an elephant . . . one
bite at a time. But you gotta cook him first. That happens
on the load analysis pages and distribution pages. After
that, get out your spoon. It's all little bites from there
on.
>equipment.
>Is this reasonable?
. . . maybe not. If you have the installation manuals for equipment
items, they should be able to give you current draw. You can call the
manufacturer too. Another option is to power the item up from a battery
or power supply on the bench and measure its current draw. But having
a number to put in the box is not nearly so important now as getting
it listed as an action item and assigning it to the most useful bus.
> amoung us?
> equipment.
Excellent Idea! How about a spreadsheet with know values for some of
the standard equipment out there. I'll even volunteer to manage it.
This would be a huge timesaver for current and future builders who aspire
to follow the Mr. K route of electronics design. Perhaps those of you
who have completed their system analysis could forward their information
we could compile the list in short order.
Walter Tondu
http://www.tondu.com/rv7
> break a sweat.
That would be that big fan out front that keeps the pilot cool.
When it stops performing, you can actually see the pilot start to sweat...
*wink*
-Dj
Dj Merrill Thayer School of Engineering
ThUG Sr. Unix Systems Administrator 8000 Cummings Hall
deej(at)thayer.dartmouth.edu - N1JOV Dartmouth College, Hanover, NH 03755
"On the side of the software box, in the 'System Requirements' section,
it said 'Requires Windows 95 or better'. So I installed Linux." -Anonymous
From: | "James E. Clark" <james(at)nextupventures.com> |
Subject: | Bus Load Analysis .. An Idea |
I am sure someone else has thought of this but here goes ...
Bob's comments (see SNIP below) got me to thinking that it would be nice if
we didn't all have to run out and track down manuals for stuff we probably
have not even purchased yet before we do planning.
So, I think it would be a real service if someone with webspace and
capability could keep a running table of current draw on various items.
Maybe Doug Reeves could set up another one of his databases on
http://www.vansairforce.net or maybe Bob has some extra space on his new
system (hate to be asking anymore of Bob as he gives way too much already).
The table (database/spreadsheet/whatever) could have the headings ,mentioned
in the Europa worksheet (from Bobs reference
http://www.aeroelectric.com/temp/Load_Analysis.pdf) with the addition of
"Vendor" and "model #".
It would not be the definitive answer but one could look there and get a
good enough to size things answer. As more people research additonal items,
the database could grow and at some point probably capture 90%+ of what we
all are using these days.
Whadday'all think???
James
[SNIP]
> a battery
> Bob . . .
Great,
I was amazed to find out that the 12 volt Fuel pump (interrupter type) only
requires 3/4 of an amp. That seems low. For 17 plus years it has enjoyed a
5 amp breaker on the 28v system I use. Cool - Smaller/lighter wire.
Dale
----- Original Message -----
Subject: Re: AeroElectric-List: Bus Load Analysis
began
equipment...
to
minds
> > amoung us?
that I
intended)
some
> > equipment.
> Walter Tondu
Dj, What do you mean the fan in front??? Fan in the back where it
belongs!!! :-)
Dale
> > break a sweat.
> *wink*
> -Dj
> belongs!!! :-)
> Dale
Hey, I've never tried to sit backwards in my plane.
That must be interesting! *grin*
-Dj
Subject: | alternator switch |
Hi Gary
I have indeed considered such an approach complete with an ov relay that
automatically turns on an electric windshield defroster for some
additional load. I don't think I'd get any reasonable kind of load
sharing with one battery though. Both my alternators have non adjustable
regulators and it sounds like even adjustable regulators are not a good
solution to load sharing. I'd like to keep at least a moderate load on
my permanent magnet alternator rather than just wasting that energy
heating up the regulator.
Might be interesting to see if I can arrange to fully load the 20 amp pm
alternator and get stable operation with the 40 amp ND unit topping up
any extra load. With that scenario, the pm alternator would not be
capable of an ov and if the ND went ov, the pm alternator should drop
off line after some (possibly significant) transients.
I'm starting to lean towards Bob's approach for ov protection on the 40
amp ND and two small batteries in a modified Z14 system rather than more
experimenting with this right now.
Ken
> < need for an alternator switch. I am referring to an internal vr
> alternator.>>
> Here's an idea along those lines. If you have a single large (normal size)
> battery and 2 alternators, make one be of very modest output, like 40 amps,
> and the other a reasonable backup, like 8 or 20 amps. The failure mode will
> be one of them going "ov." At that low capacity you will have plenty of
> warning and will be able to increase the load (in my case 160W of landing
> lights, pitot heat, vent blower) to reduce or even eliminate the excess
> charge current to the battery. I'm not sure I'm recommending it, but it
> does seem like a reasonable approach.
> Gary Casey
Subject: | Re: Bus Load Analysis .. An Idea |
If there are no issues I will begin to compile a list of known values
for the Bus Load Analysis. This should help builders save a great deal
of time searching.
If you have done the analysis and research and you would like to provide
your input please email the following information for each accessory;
BUS, ACCESSORY, VENDOR, MODEL #, WIRE-GUAGE, FUSE, PRE-FLIGHT, PRE-TAXI, TAKEOFF/CLIMB,
VFR-CRUISE, IFR-CRUISE, APPRCH/LNDG, EMERG
If you have completed the Bus Load Analysis form and would like to send it
to me that would be great.
We'll get this tabulated and then uploaded, hopefully to vansairforce.net.
Walter Tondu
Walter,
I recall there was a person who was doing a Lancair that did a LOT of data
gathering as he had a lot of (nice) toys in that plane. If he is still
monitorong the list, he might send his spreadsheet (I seem to recall he had
built one).
This would be a good starting point for "pre-loading" the file.
Also, THANKS for agreeing to gather this.
James
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Walter
> Tondu
> Sent: Thursday, February 12, 2004 2:27 PM
> To: aeroelectric-list(at)matronics.com
> Subject: Re: AeroElectric-List: Bus Load Analysis .. An Idea
> of time searching.
> PRE-TAXI, TAKEOFF/CLIMB, VFR-CRUISE, IFR-CRUISE, APPRCH/LNDG, EMERG
> vansairforce.net.
> Walter Tondu
Subject: | Dual Battery, Single Alternator System |
I am planning an all electric system with two batteries and a single
alternator. My issue is how can I verify that both the Battery Contactor
and the Aux Battery Contactor have closed.
Looking at Figure Z-30. The starter contactor and the main bus are powered
as soon as the first battery contactor closes. If the second contactor
does not close, it is isolated from the charging system but all busses are
fully powered. This can be detected with a simple light if the cause of
the problem is in the contactor coil circuit but how can you detect the
problem if contacts simply do not close.
Applying a low voltage monitor to each Battery Bus would detect this
problem during flight but there must be a more direct method that would
detect the problem during pre-flight.
Subject: | Re: Dual Battery, Single Alternator System |
I suppose this can be done during the pre-flight
check.
Bat 1 ON - volt check
Bat 2 ON, Bat 1 Off - volt check
Bat 1 ON
Michel
--- Larry Colley wrote:
> Colley
> can you detect the
> would detect this
> Contributions
> any other
> Forums.
> http://www.matronics.com/chat
> http://www.matronics.com/subscription
> http://www.matronics.com/FAQ/AeroElectric-List.htm
> http://www.matronics.com/photoshare
Michel Therrien CH601-HD, C-GZGQ
http://mthobby.pcperfect.com/ch601
http://www.zenithair.com/bldrlist/profiles/mthobby
http://pages.infinit.net/mthobby
http://taxes.yahoo.com/filing.html
Dale,
=93Filtering=94 usually involves incorporation of capacitors, ferrite beads, and
inductors at appropriated places on the product schematic and circuit board.
(A =93filter=94 can be shown on the schematic but located improperly on the
circuit board and it will not have the intended affect of reducing EMI
problems.) Shielded wires may help but not always. Shielded wires won=92t
help if the electrical noise is =93common mode=94 and found on the ground
(shield) wire as well as the power / signal wire.
Use of filter components external to a product may reduce EMI problems. The
final solution will probably be simple. However, if compliance with EMC
requirements was not a requirement from =93day one=94 of a product development
project, it can takes weeks of engineering effort and testing to bring a
product into compliance.
Since Jeff Point is geographically close to me, I am willing to look at his
installation to evaluate the situation.
Jim
Grafton, WI
Defiant
Jim,
Dale Martin
Lewiston, ID
LEZ-235
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
Turn one battery on, see that bus comes up. You should also
hear the battery contactor "click". Turn on the second battery.
You won't normally see any change on the bus but you should hear
the second click. Turn the first battery off and see that the
bus stays hot. Turn the first battery back on.
Subject: | Re: alternator switch |
>Hi Gary
Not sure what kind of PM alternator you have . . . if it's
an SD-8, that system uses a series-pass regulator that does
not waste unused energy from the alternator. Not sure
about other manufacturers but I think Ducati regulators
for Rotax are series-pass also. There's no good reason
to run a parallel-shunt regulator any more.
Would be pleased to post anything you have to offer. Got LOTS
of server space since I own half of it.
>Great,
22AWG is smallest recommended wire, it can be nicely protected with
a 5A breaker. I still have a Facet pump on my bench that's awaiting
time to do some energy studies on it. True, these pulsed pumps take
a hefty peak current compared to their average currents. The 3/4A
average you cite doesn't seem out of line at all but I wouldn't be
surprised to see 3A peak.
Walt,
It will be WIRE GAUGE / VOLTAGE. I use much smaller wire then the 14 volt
folks and there are others using 28 volt equipment.
- Dale
> of time searching.
> Walter Tondu
>See below.
> > in:
Yup, assuming you subscribe to conventions. The goal is to
have no feeders fused at more than 5A that cannot be shut
down from the pilots position. We COULD shut down the whole
battery bus but that makes everything on the battery bus
vulnerable to a single point of failure on one of the most
unreliable electo-mechanical devices there is . . . a relay.
>Jeff
Sounds like you're out of the gate and running . . .
On 02/12 1:53, Dale Martin wrote:
> Walt,
Right you are!
BUS, ACCESSORY, VENDOR, MODEL #, WIRE-GUAGE/VOLTS, FUSE, PRE-FLIGHT, PRE-TAXI,
Walter Tondu
I don't disagree with most of what you said about the chain of
events, but I have to take exception to the comment about the crew's
reaction time being part of the chain. They were over the Atlantic
Ocean. Halifax was the closest airport that had a runway anywhere
close to long enough for them. The TSB investigation determined that
even if the crew had done an emergency descent at MMO/VMO when they
first smelled smoke that they could not have gotten on the ground
before the aircraft became unflyable. I've studied the report in
detail and spoken with the investigator who did that analysis, and I
concluded that it was credible. The only way they could have gotten
on the ground would been to have flown well in excess of MMO and VMO
during the descent, and that is not a reasonable expectation given
that could not have known how bad things were going to get.
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
>><buckaroo_banzai@the-pentagon.com>
>>Quite often, the installers of a STC system try to take advantage of what's
>>already in the aircraft without fully realizing that they may be
>>circumventing the intent of the aircraft manufacturer. It's amazing that
>>the FAA and JAA are willing to grant the STC at all!
> STC's generally cannot be grand-fathered to other airframes.
> STC is exactly what the acronym implies . . . SUPPLEMENT
> to a TYPE CERTIFICATE. These are not used as plug-n-play
> across a range of aircraft.
> STC is EXACTLY what those-who-know-more-about-airplanes-than-
> we-do like. Treat every installation like it's never been done
> before and test the hell out of it. This keeps those who
> don't understand what's happening from having to think or
> learn anything. It makes sure that some wheels get invented
> over and over again. The STC route is relatively low risk
> but also expensive because common sense approaches are
> neither encouraged or allowed. Everyone is expected to
> read and respond to a rule book. Whether or not he/she
> understands the system to which the rules are applied
> no longer matters.
I'm betting you are not a big fan of the Approved Model List STC for
the Apollo CNX-80 Integrated Avionics System. That STC allows
installation on pretty much every light single or twin just by using
the Installation Manual. There doesn't seem to be any requirement to
do any engineering analysis or specific testing.
Approved Model List:
http://www.garminat.com/dwnlds/cnxdoc/CNX80_AML.pdf
STC docs, etc:
http://www.garminat.com/cnx_docs.shtml
Ottawa, Canada
Bob and all,
Dale says,
only
enjoyed a
Bob says,
And this is the hardest thing for of non-EE's to figure out..... Meaning
not proper test equipment or the lack of understanding of using test
equipment to determine the amperage peak at the first flick of a switch or
when under a very heavy load.
Remembering back years ago - we used to hook up the entire required length,
connect everything, and keep using smaller breakers until one popped when we
threw the switch..... The old trial and fault method. It didn't account for
variables such as temperature, changes in amperage..... We would just up
the circuit breaker value by two numbers and call it good. Now that was
science. Heh-heh...
Now we just ask you :-)
Dale Martin
Lewiston, ID
LEZ-235
Subject: | Re: Compass shielding |
In a message dated 2/12/04 2:57:00 AM Eastern Standard Time,
aeroelectric-list-digest(at)matronics.com writes:
<< Easiest fix for the magnetic compass is to not look at it. Most planes
track. >>
It is easiest - I certainly use it - but if you are being vectored by ATC,
using GPS ground track is not what they are expecting of you. In many parts of
the USA, true heading and mag heading will be the same number, but they will
rarely match the GPS track. Am I splitting hairs - Yup. But, when ATC assigns
a heading, they are expecting you to fly mag heading.
Stan Sutterfield
RV-8A
Tampa, FL
>In a message dated 2/12/2004 10:07:57 PM Mountain Standard Time,
>Speedy11(at)aol.com writes:
> parts
> > of
> will
> > assigns a heading, they are expecting you to fly mag heading.
If strictly true, then GPS is useless for complying
with ATC instructions. GPS doesn't display heading (direction
airplane is pointed) but course (direction airplane is going).
Depending on winds, the difference between the two can be
10 degrees or more depending on speed of your airplane.
An ATC controller used to live on our airport and I asked
him about the "fly heading xx degrees" instruction. Since
his radar display was based on course, not heading, does
he do the mental gymnastics to account for winds. He said
no. When I give you a "heading" of 90 degrees, I'm pointing
you off into airspace well clear of other aircraft. If you
in fact give me a course of 80 or 100 degrees, it mostly
doesn't matter. If I don't get enough of an effect for my
instructions, I may follow up with come right 10 degrees
or a new heading of 100 degrees. It's like painting a portrait
with a 4" brush. He opined that flying GPS course in response
to an ATC instruction would probably make every controller
happy . . . even if your magnetically slaved DG displayed
something different due to winds. That should be a MAGNETIC course
which is, I believe, available from most GPS receivers.
>so ya just set your DG on your take off roll. Runway heading is as close as a
> magnetic compass reading. Probably closer. Stan is right about the Mag
>variation though. Here in Jackson Hole Wy the difference is 15 degrees,
My GPS receivers will optionally display either magnetic or
true. They contain a look-up table of variations that does
the calculation for you. I fly with them set for Magnetic
course display.
Subject: | Electrical current needs |
"Excellent Idea! How about a spreadsheet with know values for some of
we could compile the list in short order. Walter Tondu
http://www.tondu.com/rv7"
I seem to recall a site on the web where someone has compiled a list
of units and their current requirements.....
Perhaps a reader on this net might remember and display the site?
Ferg
Europa A064 monowheel 914
> > no longer matters.
>STC docs, etc:
This is a great example of how absurd the certification
process has become. A type certificate is issued against
a particular airframe to encompass all of the characteristics
unique to that airframe. Anything which might affect performance
must be scientifically considered and accounted for.
When the first comm transceiver was attached to an airplane,
it was well understood that the radio added to the empty
weight of the airplane, had an electrical load requirement
to be satisfied and MIGHT have some structural issues with
respect to where you poked a hole in the skin for an antenna.
Of course, the customer had an intense interest in achieving
certain performance goals from the radio after installation.
An AI, mechanic and customer worked together to see that
these simple requirements were met. A logbook entry or
at most a 337 form filled the regulatory requirements.
The thrust of an STC is to amend the TC of an airplane
to account for any ways in which installation of an accessory
or new feature does not adversely affect the performance
of the airplane. The installation of a GPS receiver has
no greater potential for impact on the airframe than did
the comm radios of 60 years ago.
The documents cited above IMPLY that each of those
airframes was evaluated for effects on performance
based upon installation of the product per the instruction
manual. I'll bet that the instruction manuals never
address variability by citing something to be done
or avoided on any particular aircraft based on model
or type certificate.
Instructions that don't speak to specific variability
between models to avoid altering airframe performance
are a demonstration of how the STC process was corrupted . . .
They threw an appearance of valuable process
at an installation for which the process was neither
necessary nor did it add value to the final installation.
The radio manufacturer pulled of a real coup in acquiring
the documents . . . that probably couldn't have been
achieved in other FAA regions. Instead of one piece of
paper covering hundreds of aircraft, the manufacturer
would need single pieces of paper for all TC's . . .
but in neither case would the STC activity have added
value.
> But, when
> > > ATC assigns a heading, they are expecting you to fly mag heading.
Ok, ok. If one reads what I originally posted, to which the above was a
reply, I said to use GPS to SET the DG, not to fly tracks. I was
stating that I can't imagine using a magnetic compass anymore to set my
DG. I prefer to use runway heading or the mag track output of my gps
while taxiing to set the DG.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 437 hours
From: | John Schroeder <jschroeder(at)perigee.net> |
Walter -
I hope this rather long posting is taken as constructive and not in any
way denigrating the effort, or your most generous offer to compile the
list. I have agonized long hours over the same problems as we designed our
system and chose the equipment to install.
I think you will be getting too rigid and complicated with this much
information. For example:
1. Why put buss in there? That will depend on the Z diagram being used,
the aircraft, its mission etc.
2. Why "Wire gauge/Volts"? Again, that is influenced by a lot of other
variables and choices - especially where the equipment will be located in
the aircraft and what type. For example, we calculated a 44 foot round
trip in a glass aircraft for the pitot tube. Others are shorter, some may
be longer. Using Bob's formula in his paper on Wire Size Selection, one
has to check their initial calculations on wire size to keep the % voltage
drop under 5%. That could nullify any figure appended to a device sent in
for the database. What about the heat dissipation if one chooses to run a
wire in a bundle?
3. Why specify the size of the fuse? Often, the manufacturer specifies it
and it has no relation whatsoever to the wire size you calculate. If you
want to put the fuse size, it should only be the size recommended by the
mfg. You could put an M after the size to denote this.
4. The various phases of flight? Again, these are subjective and will
vary a lot with the aircraft and mission. Also, emergency is a very loose
category. There are too many to list and each may or may not have an
effect on the amperage total at the bottom of each sheet. It varies also
with the Z diagram and any variation one chooses to make. One fellow
remarked a long time ago that one should add a night and day category for
all of the phases of flight because lighting becomes a major
consideration. Bottom line on this is that your database would not be very
helpful and be too big.
5. The elements of the database should be: Accessory, Manufacturer, Model
#, Amps and Fuse. From there one can tailor the rest of the data based on
their design, aircraft, missions and plain old preferences.
There would be 3 codes to add to the data. Two would be for the amps and
one for the fuse.
One would add an "M" after the amps to denote actual measured load taken
by the builder when the accessory is on. For a radio, there should be two
lines of data: one for receive and one for transmit. Same for a fuel boost
pump, if there is a high and a low mode. For something like a pitot tube,
there would be two lines: one for steady state and one for surge during
warmup.
The second code for the amps would be an "S" to denote that it is a
manufacturer's spec figure. If they have several figures, there should be
one line per figure.
The third code would be for the CB/fuzing. An "S" would be appended to
denote a manufacturer's recommended size. If someone actually experimented
to fine where a device nuisance tripped, they could add a figure and
append an "M"
The absence of a code in the amps cell would indicate caution to anyone
using that figure. I would think that once the list is initially compiled
and available to the community, there will be a refinement process and the
end point would most likely be M's or S's after each amperage. That is the
key figure we all need to make the calculations and do the design.
I would also ask that anyone furnishing a line or lines of data for a
device to state the source. I know that Panel Planner has some data and I
would not want to rely on that in my calculations. There are also a lot of
WAG's out there.
Again, I hope this has been helpful. Drop me an email if you would like to
discuss anything here. The idea is a wonderful one and the need is
certainly there. Thank you for volunteering.
John Schroeder
Lancair ES & Z-14
> > Walt,
> volt
> Right you are!
> PRE-TAXI,
Hi Jerzy-
Thanks for the amplification. It makes a lot of sense. I got back with
the source of my info, and he stood by it although in a less adamant way.
Sooo, I called a friend that does avionics development for uncle Sam, and
he agrees with you. I now sit corrected!
With regard to the inside out zoo reference, there are a couple of
aquariums (aquaria?) that are basically one big tank that you traverse by
walking along the bottom inside a lexan tube. Pretty cool! (insert grin
thingy here)
Glen MAtejcek
Alex has it right and is doing the right thing trying to shield his compass.
Runway headings change with the earth magnetic field and runways headings
are permitted to be off as much as 5. I mean if divisions for runway
headings are every 10 there has to be some room for error. For one I don't
like Speedy11's method and it doesn't comply with regs for VFR or IFR
flight. I won't quote FAR Part 91 as looking it up ourselves is a part of
continuing education we all need and if I were to tell you - you wouldn't
remember it (As now?).
All Gyro's precess and need correction including Slaved units. Relying on
GPS for sole navigation 100% of the time is nuts and illegal in some cases.
Further to use the "system" you are required to have the appropriate
equipment on board. I recall an airliner which had the Mag compass behind
both pilots but centered in the airplane and facing forward (not kidding)
and to use it would look up at a mirror to see it.
We had a similar discussion on the Canard-Aviators group last month about
GPS ground track verses mag heading and the current and ex-ATC controls in
the group spoke up and said if you turned to a heading and the controller
didn't like he would add more correction to your course and if it upset
him/her you would here - "Flight advisories/following is canceled - squawk
VFR - Good day"
Alex - You must have a forward hinged canopy on that RV-6A
Dale Martin
Lewiston, ID
LEZ-235
Subject: RE: AeroElectric-List: Re: Compass shielding
> > But, when
> Alex Peterson
> Maple Grove, MN
What about precession in your DG after flying for awhile?
How do you check it in flight to make sure it is correct?
I'm just curious, not trying to start anything... :-)
-Dj
I don't know about anyone else, but my DG needs to be "reset" many time
during a 2 hour flight. To set it once on the runway heading and then
fly out to some airport without resetting the DG for two hours isn't
going to work. Sure, I can just follow the GPS and adjust my track to
get me there but then all the other functions of the GPS don't work
without an accurate DG (wind direction, TAS etc.)
Am I missing something here? Is there another way to accurately adjust
your DG other than with a compass?
Mike Nellis
RV-6 Fuselage N699BM
1947 Stinson 108-2 NC9666K
http://bmnellis.com
*** Ok, ok. If one reads what I originally posted, to which
*** the above was a
*** reply, I said to use GPS to SET the DG, not to fly tracks. I was
*** stating that I can't imagine using a magnetic compass
*** anymore to set my
*** DG. I prefer to use runway heading or the mag track output
*** of my gps
*** while taxiing to set the DG.
*** Alex Peterson
*** Maple Grove, MN
*** RV6-A N66AP 437 hours
*** www.usfamily.net/web/alexpeterson
*** http://www.matronics.com/FAQ/AeroElectric-*** List.htm
*** Search Engine:
*** http://www.matronics.com/search
*** *** http://www.matronics.com/browse/aeroelectric-*** list
*** Browse Digests:
*** http://www.matronics.com/digest/aeroelectric-list
>Jim
>Grafton, WI
>Defiant
Hi Jim,
You're welcome to come over and have a look at my installation if you
wish, but I believe I have solved the problem. Or more, accurately,
there never was any problem, I just removed the artificial condition
(low bus voltage) which was causing the appearance of a problem. I
finally got my replacement mixture cable, and so have been able to test
with the engine running. At 14.1 bus voltage, there is no discernable
noise from the Dynon, strobes or any other source. I did use shielded
cable for the remote compass module, located in the tail, which was run
back there via a path all its own, away from any other wires.
When Dynon comes out with their "solution" for the EMI problem, I will
try it just for experimentation's sake, but I am quite happy with the
installation as it is now.
Jeff Point
RV-6 getting close
Milwaukee WI
learning more about 'lectrics every day.
Thanks for taking the time to really think this out. But I think we
can come to an agreement that this project doesn't need to be this
complicated. What we *Really* want to get out of this is the amperage
draw for popular equipment during different phases of startup, taxi,
flight and shutdown. Not all of the columns are 'required'.
Again, voluntary. Main, E-Bus, Battery are common. Any others noted and
you can pretty much tell which Z-diagram they're using. Remember, the
Z-diagrams are just a starting point, each builders makeing subtle changes.
> wire in a bundle?
Most of the equipment that will be listed in the document is common to
many aircraft, eg. in almost all cases the GPS will be on the panel and
the wiring length won't vary too much, probably not enought to warrant
a different guage. Volts used to indicate 12 or 24.
I disagree. I'm not putting a fuse in there to protect the equipment
which already has internal protection. I'm putting it in there to
protect wiring.
Remember, this is about the accessories we put in the plane. Some may
have differing amperage draws during different phases of flight.
Again, I'm going to compile per Bob's document. I think it is well
thought-out.
> one for the fuse.
> warmup.
> append an "M"
> WAG's out there.
I like the idea of the codes. But for those builders who have already
completed their analysis I doubt they will want to go back and re-do it.
I don't expect all the information received by builders to be
homogenious. I do hope that information provided helps others save time.
> Cheers,
> John Schroeder
> Lancair ES & Z-14
> > > Walt,
> > volt
> > Right you are!
> > PRE-TAXI,
Walter Tondu
Subject: | Locating Switches |
Team,
Need a favor.....
I am looking for a good source for a Locking Lever Switch. The SPST type
with ON-OFF positions. Full size - no mini's.
Have one that says UR on the side. The top comes to more of a cone shape
rather then the round dome shape that the micoswitch company makes.
If you need a picture of the one I have I'll email the picture.
Thanks in Advance,
Dale Martin
Lewiston, ID
LEZ-235
From: | "I-Blackler, Wayne R" <wayne.r.blackler(at)boeing.com> |
The only variety I'm aware of is the MS24659 series (-21A) from
Flame Enterprises
20945 Osborne St
Canoga Park, CA 91304
(818) 700-2905
The locking detents are available in a variety of positions. Check http://content.honeywell.com/sensing/prodinfo/environment/catalog/379.pdf
These are not cheap, but really good for Ignition switches IMO.
- Wayne Blackler
IO-360 Long EZ
Seattle, WA
-----Original Message-----
Subject: AeroElectric-List: Locating Switches
Team,
Need a favor.....
Thanks in Advance,
Dale Martin
Lewiston, ID
LEZ-235
Subject: | Off line for a week . . . |
Bob and almost-a-doctor Dee are off to the sunny beaches
of Puerto Rico for a week. My old boss from RAC Missiles
group has a condo there and has been inviting me down
every winter for the past ten years . . . difference this
year was that Dee heard the invitation too. The next
question was, "Well, why not THIS year, dear?"
Why not indeed.
See you all on the 22nd.
Subject: | Re: Off line for a week . . . |
Have fun! I'm envious!
Dave Morris
>Why not indeed.
> Bob . . .
Subject: | FS: SL70 Transponder |
I have one last piece of UPS avionics left - an SL-70 transponder. New and
un-installed, full warrantee, full install kit. $1750
Subject: | round transponder recommendations |
Anyone have a recommendation for a round transponder to fit into the panel?
Cheap is good!
I've heard some bad news about the one from Austraila.
David
price is always a consideration
Yes that makes a lot of sense. I think I was given some duff info on
this. It's a John Deere unit like the one shown here.
http://flyboybob.com/web_pages/kr2/electrical%20and%20instrument/dynamo2.htm
Just from looking at the fin area and 280 watts of DC output, I think it
indeed has to be a series-pass unit.
thanks
Ken
> Bob . . .
> awhile? How do you check it in flight to make sure it is
> correct? I'm just curious, not trying to start anything... :-)
Dj, good question - I'm fortunate in that my HSI doesn't precess much,
maybe 5 degrees in two hours. Obviously, one can compare it to the
magnetic compass, it is just that in my case, the errors in reading the
compass, particularly in rough air, are more than the precession of the
DG.
Dale, I'm not the one shielding anything, whoever started this thread
is.
Alex Peterson
Maple Grove, MN
Subject: | Re: round transponder recommendations |
>Cheap is good!
The only other one is the Becker.
Subject: | RE: Locating Switches |
NKK has a locking version, but it only comes with
solder lugs. Mouser carries them, about $10 ea. I
stumbled across the NKK part while looking for
something else the other day. There are probably
others out there as well.
http://www.nkkswitches.com/pdf/stogglesmedcap.pdf
http://www.mouser.com/catalog/617/857.pdf
From: | "Steve Sampson" <SSampson.SLN21(at)london.edu> |
Subject: | Z12 e-bus questions |
The thing that I never understand about this sort of analysis is why is it
assumed that the transmit switch will not be activated in this example. I
dont know the NAV/COM unit in the example below, but surely it will
significantly increase the demand on the ebus and blow any associated
fuse/breaker?
Steve
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert
L. Nuckolls, III
Subject: Re: AeroElectric-List: Z12 e-bus questions
>Hi all (Bob),
>I'm planning on using a Z-12 type system on my Rocket. One battery, two
>alternators.
>I notice the e-bus alternate feed is through a 7 A (fuse?) via a 16 AWG
wire.
>Two questions: For peace of mind would a breaker be the best way to go
>here?
>I'm thinking that I can easily overload the 7 amps just with the e-bus as
>described in Z-11. The plane will be outfitted for night flying, and needs
a
>fuel booster pump. So if I end up with more than 7 A (which either I will
>have, or be very close to) when I loose the main power (assuming two dead
>alternators), and throw the switch, at least I can get smart, shed load and
>reset the breaker. For the most part though, I plan on using fuses,
>because I
>too have never reset a breaker were there wasn't a problem that resetting
the
>breaker actually helped, and I plan on having each circuit with it's own
fuse.
>Second question: Why only 7 amp protection device off the batter bus? The
>wire should be able to handle 12 amps? So why not use the protection
>device to
>protect the wire, since each of the devices coming off the e-bus will be
>protected on it's own?
>Thanks in advance, and also for all the past advice.
The Z-figures are intended to define the ART of system
design. This is where you pick through the big box of
Erector-Set, Tinker-Toy, and Lego parts to see how they
best fit together in a system that supports your project's
mission. The Z-figures should NOT be taken as verbatim
of the SCIENCE which dictates component selection.
When you "assuming two dead alternators", you're
getting ready to address a REALLY bad day. The likelihood
of dual failures in any single tank of fuel is extremely
remote. Any piece of wire more than 6" long taking a feed
from a bus with high fault current capability (your battery
may well deliver upwards of 500-1000 amps in a hard fault),
then we say it needs protection. If you're e-bus, e-bus
alternate feed and battery bus can be all wired up with
6" pieces of wire, you don't need any fuse or fusible link.
If the wires are longer, then . . . well, shucks. Now,
if you need an e-bus alternate feed exceeding 5A from
the battery (or battery bus) then using a relay as shown
in:
http://www.aeroelectric.com/temp/E-BusFatFeed.gif
seems prudent. This architecture provides a low power
version of a battery contactor to provide at-the-battery
control of a feeder. The same caveat exists for all
feeders from the battery whether e-bus alternate feed
or feeders to goodies that support an electrically
dependent engine. You mentioned a fuel pump . . . I
wouldn't drive this from the e-bus but directly from
the battery bus via it's 5A or less fuse and no relay
or a 7A+ fuse and a relay.
The VERY FIRST documents you need to craft in your
electrical system design are a tabular listing of each
feeder that comes off each bus. The system that feeder
supplies, the size of protection be it a Lego fuse or
Tinker-Toy breaker, size of the wire, then draw 7 columns
where you're going to deduce and add up the current draw
on each feeder under the following headers, (1) preflight,
(2) taxi, (3) takeoff/climb, (4) vfr cruise, (5) ifr cruise,
(6) approach to landing and (7) alternator-out.
Go get this document:
http://www.aeroelectric.com/temp/LoadAnalysisHandOut.pdf
The first page is an example of how to start this task.
The second page is blank so you can fill in what fits for
your project. You need one page for each bus.
Note that this document becomes a list of all the goodies
in your airplane, how much energy each combination takes
for operation. It can also be an index for your page-per-system
documents that will ultimately record how your airplane
is wired.
Incoming mail is certified Virus Free.
Subject: | Re: FS: SL70 Transponder |
Richard,
If the transponder (SL-70 transponder) is still available, I'll take it off
your hands.
Marwin Goff
bucsdds(at)aol.com
Subject: | Re: Locating Switches |
Of course you can use whatever switches you like but in my humble opinion,
locking lever switches invite problems---
Here's why---standard toggle switch guards like MS25224 reliably prevent
actuation and visually signal that the switch has been operated. Locking
toggle-type switches can be and are broken by ham-fisted pilots, especially
by someone not familiar with them. NOW you have a problem. The switch is
broken AND you don't know if it has been actuated or not--and you can't do
anything about it. Not good...!
By the way--I used to sell F-16 V-max toggle switch guards on my website. I
was buying them at $3.00 each. Then the wholesale price went to $40 each
with a minimum buy of 50 pcs. One piece wholesale price $130. They hand
paint them in France...I was told. M'aidez!
By the way2--I had in my hands an actual real genuine (titanium) Space
Shuttle Switch Guard, thanks to Historic Space Systems (www.space1.com) and
with the magic of CNC and the original Rockwell blueprints they are on my
website too (in hard anodized aluminum).
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge MA 01550-2705
Phone (508) 764-2072
Email: emjones(at)charter.net
"When they say it's not about money, it's about money.
When they say it's not about sex, it's about sex."
--Dale Bumpers
Subject: | Fw: [f-AA] request for help |
Help for this forwarded message.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley(at)qcbc.org or experimenter(at)eaa.org
Always looking for articles for the Experimenter soon to be Sport Pilot
Subject: [f-AA] request for help
> ---------- Forwarded message ----------
> Date: Fri, 13 Feb 2004 22:42:47 -0500
> From: Richard Dover <rdover(at)springmail.com>
> To: aeronca-owner(at)westmont.edu
> Subject: Messages
> John
> I have tried twice to send this message to the list, it never made it. Can
you help?
> Rick Dover
> > A friend is completing a Marquart Charger and ask me the following
> question.
> > I told him I would pose the question to the knowledgeable people on this
> > great list. This is not about an Aeronca but is close (has wings).
> > Rick (N2453E) which is a Champ
> > Rick,
> > Could you post the following question on the aviation website that you
> > were referring to the other night. Thanks.
> > Pat
> > I recently purchased a rebuilt Lycoming O320 for my soon-to-be-completed
> > Marquart Charger. The paperwork with the engine refers to the "new
model
> > 20 alternator" but no other info is provided. I can not find a
> manufacture
> > name on the alternator and cannot find info on the alternator locally.
My
> > problem is that I cannot figure out how to wire the alternator. It has
a
> > lug on the lower right that is designated "B" (No problem there) and
what
> > appears to be another lug at the upper right which has a notched
insulator
> > attached (not sure what this is for) and then it has an attachment for a
> > three-connector socket (did not come with the engine). The tree prongs
> are
> > labeled "F" (I am assuming this is the field attachment point), "E" and
> "N"
> > (I am not familiar with these designations). Does anyone have any info
> > that can solve my wiring dilemma. It would be greatly appreciated.
> Aeronca mailing list
> Aeronca(at)mail.westmont.edu
> http://mail.westmont.edu/mailman/listinfo/aeronca
Subject: | Load dump issues |
I have done a fair amount of testing a couple of years ago, working with the
TVS devices, including the larger sized versions.
In my experience, they have not been adequate, alone, to prevent over
voltage spikes on load dumps, even from smaller alternators.
They help. But I have blown some of them on load dumps.
Regards, George
From: | Jerzy Krasinski <krasinski(at)direcway.com> |
Subject: | Re: Load dump issues |
George Braly wrote:
>Bob,
>Regards, George
I am not surprised. Looking at the data for 1500W devices we find the maximum pulse
is 1ms at half peak value current. That is much shorter than the expected
alternator pulse.
The non repeatable surge current is listed as 200A for 50 ms. Probably more likely
peak current would be around 50A, so that would allow some extension of the
pulse length. But that is for a nonrepeatable event.
That shows that for the alternator full current application they are beaten at
the the surge limits.
Connecting TVS devices in parallel is a waste. Their characteristics differ enough
so most of the current will go through one TVS, while others will just hang
there. Maybe measuring them and selecting them in very similar bunches would
work, but that requires building a nonstandard curve tracer for operation at
rather high currents. Probably it can be done in a crude way discharging a capacitor
through a few of them in parallel and observing the currents on a multichannel
scope.
One can easy increase the power to 3000W by connecting in series two 6.8V devices.
Unfortunately, 6.8V is the lowest voltage TVS I found, and that increases
power only by a factor of two. But if in your experiments they failed only sometimes,
that factor of two might be everything we need.
Jerzy
Eric,
Thanks for you words and research. In this pilots case they are used for
Magneto and Electronic Ignition switches. Everyone has there opinions about
what to and what not use. I'm no exception. I have flown in air that was
so ruff it took me over a minute to change radio frequencies and all I had
to do was push the Flip-Flop button. Since I am changing my instrument
panel (same plane -LEZ) and doing away with the side console where all the
switches and C/B's were located this means all the switches will be on the
left side of the panel. If I every experience that kind of turbulence
again - I would rather the Locking lever feature prevent the unintended
action of grounding the magneto or de-energizing the E.I. system. I have
guarded switches on the head rest so the back seat person can shut both
systems if I become unable to for any reason. However on the instrument
panel they are bulky and for my pleasure, unwanted. Since I have flown 550+
hours using the key switch for the mag and the Locking switch for the E.I.
without any damage the choice will be to stick with what has worked.
Secondly, I don't let others that are ham-fisted fly the airplane and in
1000+ hours someone as PIC has only occur on one flight.
Thirdly. If the switch breaks I reach into my helmet bag and pull out a new
ON-OFF switch. Never hurts to carry one spare. I just may install the
spare on the panel and run wires to a terminal block... Thanks Eric for
stirring the pot, you've given me a great idea.
Dale Martin
Lewiston, ID
LEZ-235
Subject: AeroElectric-List: Re: Locating Switches
especially
I
and
> Regards,
> Eric M. Jones
> 113 Brentwood Drive
> --Dale Bumpers
From: | "Chris Adkins" <ccadkins(at)adelphia.net> |
Subject: | Sequential turn signals...OFF TOPIC |
I know, I know...this is TOTALLY off subject...BUT...
What are all the "kiddies" using to pull off the "sequential turn
signals" trick on their cars? I can remember the days when the only way
to do it was with a geared dc motor driving a little cam which depressed
some reed switches. I'm sure it's much more elegant than that NOW, and
I'm just wondering if any of you guys know how it's done! (BTW, I have
selfish reasons too...I want them on my '88 Buick Reatta, but don't
wanna' pay $59 for the kit on Ebay).
Chris
I am new to this list and would like to ask a question.
I have mounted a video camera on my airplane with a fully articulated mount.
Previously, for audio, I led a microphone from the earcup of my headset to
the audio inpuut of the camera. This microphone was powered by a 1.5 v.
battery and I have had trouble remembering to turn it on. - dead audio. I
tried the checklist idea and it didn't work in this application. I have now
an impedence compensating set-up - Aircraft Spruce and a pretty rough item,
I think - that hard wires the headset audio to the audio input of the
camcorder. Now instead of getting the muffled roar of the engine, I get a
quite noticable alternator whine. Any ideas as to how to filter this out.
I don't hear it in the headset.
Loewll
From: | "Troy Scott" <tscott1217(at)bellsouth.net> |
Subject: | special progressive |
Gentlemen,
Is there a three-position progressive switch made so the upper two positions
are progressive, but the bottom position is only on when the switch is in
the bottom position? Like this:
Top Position: middle and upper positions on
Middle position: only the middle position is on
Bottom position: only the bottom position is on
Thanks!
Troy
You can do it with two 555 timers.
What happens is when the turn signal wire is activated, the first light is
lit and the first 555 timer starts, when it times out the second light is
lit and the second 555 timer starts, then when it times out the third light
is lit.
This is assuming the turn signal currently has a long enough "on" time. If
it does not then, you can use another 555 as a flasher, which would enable
you to set your on to off time.
Personally, however, I would not use 555 timers, as that it is complicated.
Instead I would use a cheap Microcontroller like the PIC. These
microcontroller are almost as cheap as a 555 timer and gives you lots more
flexibility.
Trampas Stern
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris
Adkins
Subject: AeroElectric-List: Sequential turn signals...OFF TOPIC
Chris
Subject: | Re: special progressive |
Troy Scott wrote:
> Gentlemen,
I haven't seen one, but you can make it yourself with a SP3T or DP3T switch
and a diode. Just put a diode between the top and middle position connectors
with the band on the diode toward the middle connection. In the top position
the diode will allow current to flow to both the top and middle wires. In the
middle position the middle will be on, but the diode will block current from
flowing to the top. And the bottom is the bottom.
A Schottky diode of reasonable size is probably a wise idea if you plan to run
any significant current from the MIDDLE position - the devices on the top and
bottom don't affect this need.
Chad
George has made general comments and I am sure at least some of us would be
interested in specific test results. I am NOT questioning what he has said,
but I am interested in what he has tried that did not work.
As for Jerry's comments consider the following.
First I agree the use of a single 1,500W TVS is not enough for worst case
load dump control, but the 5,000W units seem to be adequate (at least in
terms of the TVS power rating) for a 50A single event load dump (and it is a
single event dump producing a high voltage pulse that we are concerned with)
Any long duration event is taken care of with the OVP unit. Thus the TVS and
OVP devices work in combination to prevent systems damage from over voltage.
I have tested 1,500 watt units and verified that they can load clamp 10 amps
long enough to blow a 5 amp circuit breaker (much longer that a load dump
event). Not sure all mfgrs of similar devices will do this but after 10
tests of the same part no damage or change in part charactericts were noted.
A load dump event is NOT a failure of the alternator. Unlike the HI voltage
from a failed regulator that is controlled by the OVP unit. Load dump is the
result of: operator, circuit design, or contactor failure that allows the
alternator to become suddenly unloaded.
Operator error can be reduced with locking lever switches etc.
Circuit design can prevent operator error but introduces other issues.
Contactor failure is something that can happen and this is where something
needs to be done so a single failure does not cause another failure. First
failure is the contactor failing. The next failure is an uncontrolled load
dump that damages one or more of the following devices, Alternator diodes,
alternator regulator, and or avionics etc. on the connected busses in the
aircraft.
No single failure should cause secondary failure, if at all possible, thus
the current discussion of load dump control.
The TVS diodes are NOT intended to protect long HV events and in the case of
long HV events the OVP unit will do the job by disconnecting the alternator
in a few ms which is longer than the load dump event and is short enough to
prevent damage to the Load dump TVS (in other cases where HV is produced)
which reduces the load dump voltages while the OVP unit is disconnecting the
alternator.
The voltage does increase above the TVS rated voltage as the current
increases. For example the 500amp unit designed for load dump I have
mentioned has a voltage well over 50V during peak current conditions. While
this is far less that a non-clamped voltage its too high for our equipment.
So while the regulator in the alternator and the alternator diodes are
protected our avionics are not.
This is because the load dump condition passes thru the "B" lead to the main
bus before the contactor in the "B" lead releases from the OVP device, for
internal regulators, and removing field power on external regulators. As the
load dump energy is already in the alternator and must go somewhere
additional protection is needed.
5kw 18v TVS units are available and are rated at over 150 amp single event
pulse.
So perhaps putting several units in parallel is a practical solution. I
agree that this is best done with matched devices but consider the
following. The real conservative person decides that 3 units in parallel
with be enough. Also for this discussion that the current being shunted by
each unit has a current to voltage increase of 1V for every 10 amps of shunt
current. These are not real values but used to make my point.
So clamp voltage for each unit is assumed to be 18V, 19V, and 20V for the
units.
The first unit sees the load sump and starts clamping at 18v. As the load
current voltage gets to 19v (10 amps) the second unit starts clamping. As
the voltage still increases the third unit starts clamping.
Now at 21V the first unit is clamping 30 amps, the second unit is clamping
20 amps and the third unit is clamping 10 amps and the bus voltage is
clamped at 21v for a 60 amp load. No matching of devices was needed in the
above example with available tolerance units.
Use of an adjustable current limited power supply would allow matching at a
current of say 1-10 amps which is within the current rating depending on the
device for steady state currents and only a few seconds is really needed to
measure the voltage at the test current. Buying 10 units (at under $1 each)
is likely to produce several well matched units so the load sharing is much
better than my example above.
However the clamped voltage of 21V (in the above example) is higher than the
OVP design of perhaps 16V and may be higher that the max rated voltage of
the some avionics and either a different approach and or additional
protection may be needed.
The widely available 1,500w units can be used but will require more units to
keep the voltage peak to the desired design limit with current sharing.
The preceding is just one solution. However use of TVS devices must be done
carefully to consider not just the power pulse rating but the peak
suppressed voltage which is device and current dependent.
Keeping the BUS voltage under 20V is not easy with a 50a load dump.
The large capacitor I mentioned earlier is also a possible alternative IF
the selected capacitor is designed for low internal resistance at hi
frequency. Again some design is needed to see how well this may work.
Paul
From: "Jerzy Krasinski" <krasinski(at)direcway.com>
Subject: Re: AeroElectric-List: Load dump issues
> George Braly wrote:
> >Bob,
the
> >Regards, George
maximum pulse is 1ms at half peak value current. That is much shorter than
the expected alternator pulse.
more likely peak current would be around 50A, so that would allow some
extension of the pulse length. But that is for a nonrepeatable event.
beaten at the the surge limits.
differ enough so most of the current will go through one TVS, while others
will just hang there. Maybe measuring them and selecting them in very
similar bunches would work, but that requires building a nonstandard curve
tracer for operation at rather high currents. Probably it can be done in a
crude way discharging a capacitor through a few of them in parallel and
observing the currents on a multichannel scope.
devices. Unfortunately, 6.8V is the lowest voltage TVS I found, and that
increases power only by a factor of two. But if in your experiments they
failed only sometimes, that factor of two might be everything we need.
> Jerzy
The C&K 7211 might do what you want. It is a
miniature toggle though.
Subject: | Radio headset noise |
I've been working on eliminating noise in my headset, and here's what I found.
I have a new RV-6 and I'm using the DC laodcenter bus system with the backup
battery bus option. I had noise from my strobes, fuel pump, an alternator hum,
and a low level hum from most anything that you turned on. This could be heard
clearly using a noise canceling headset, not so clearly (except the strobe
noise) using a passive headset. I built 3 noise filters described by Bob Nuchols
on his site, two for my two strobe power supplies, and one for my audio panel
amp, which I built myself using Radio Shack parts. I was able to determine
most of the noise was coming from my bus, and not being picked up on my antenna
systems(I have 2 COM radios). I installed the filters on the strobes first
and I noticed a reduction in strobe noise. I could still hear it, but it wasn't
as harsh. Then I installed the third filter on my audio amp and it became
very silent. There is virtually zero noise. T!
he only problem is there is very little volume left from my COM radio. With the
volume all the way up at max, I can barely hear it. The question I have for
anyone out there and Bob when he gets back is, would a smaller capacitor in the
filter prevent losing so much gain on my radio? The plans Bob wrote call for
a 10uf capacitor to be used with the inductor coil, but the kit from Radio
Shack came with a 220uf capacitor. Will that have an affect on radio volume?
I probably need to make another one with a smaller capacitor or maybe connect
the filter to my radio/intercom instead of the audio amp. Looking for advice.
> Scott Hersha
I bought an alternator filter/capacitor from Aircraft Spruce. It was kind of
expensive, about $39.00, but it worked for me.
> Scott Hersha
Subject: | Re: Mag Headings |
Okay, niceez, you've launched two unprovoked attacks on me so I intend to
stand up for myself and, in the future, ask you to use restraint in your attacks.
All of my comments here are in reference to your post which is shown below.
Runway headings do change over time due to changes in the earth's magnetic
field. Runway 12 at Houston's Hobby Airport has a mag heading of 129.
When you say you don't like my method that is non-compliance with IFR and VFR
regulations, I have no idea what "method" of mine you're talking about. I
haven't suggested any method. And you can take your condescending tone (you
need to look it up yourself so you'll remember it next time and I won't have to
be bothered with you again) and shove it..
I haven't read any suggestions on this list that pilots should depend 100% on
GPS for navigation. Personally, I will not permit students to use GPS until
after their checkride. Then I will teach GPS. Since I charge nothing for
instruction, I'm not just trying to gouge students for more money. I believe GPS
is an aid to navigation that is incredibly valuable, but it is one which must
be expendable.
I missed your point (assuming there was one) when you pointed out that the
DC-9 had a reverse view mag compass. Perhaps you're giving an example of
required equipment.
It was good to hear the gospel according to the Canard-Aviators group. I'd
like to talk to the controllers in the group. I've never heard of a controller
giving two headings and then, if upset, tell a pilot to "get lost," in so
many words.
Dale, you attempt to talk like an expert - in something - but I'm not
convinced. I don't profess to be an expert in aviation, but some of my credentials
are listed below.
I'd appreciate it if you sent your attacks on me directly to me
(speedy11(at)aol.com) instead of posting them on this list. I am more than willing
to debate
off list. From now on, if I have something to say to you, I won't use list
time, I'll send it directly to you. I apologise to list members for this post,
but I'll only turn the other cheek once.
Stan Sutterfield, LtC Retired
RV-8A
Tampa
F-4, F-5, F-16, B-737, too many experimental and light aircraft to list
CFI
In a message dated 2/15/04 2:57:07 AM Eastern Standard Time,
<< Runway headings change with the earth magnetic field and runways headings
don't
cases.
> VFR - Good day" >>
Subject: | Re: Toggle switches |
Eric,
I've been looking for the F-16 toggle switch guards. But I can't afford
those prices! Guess I could make my own. They are so simple and lightweight I'm
surprised someone (like you) hasn't been producing them. I'll take a look at
your other switches.
Stan
<< By the way--I used to sell F-16 V-max toggle switch guards on my website. I
website too (in hard anodized aluminum). >>
Subject: | Contactor replacement |
Eric,
What is the status of your
1280 Peak Amp Contactor "Powerlink". Still in testing, it will soon eliminate
5 pounds of those big hand-grenade-sized contactors.?
Stan Sutterfield
From: | "Alfred Buess" <Alfred.Buess(at)shl.bfh.ch> |
There is an other option available: TRT600 or TRT800 from Filser. Not cheap, but
Mode S capable (will soon be mandatory in Europe!) and integrated blind encoder.
Have a look at
http://www.filser.de/
Alfred Buess
>>> richard(at)riley.net 02/14 3:28 >>>
>Cheap is good!
Subject: | Re: Powerlink Contactor |
>Subject: Contactor replacement
>Eric,
eliminate
>Stan Sutterfield
I'm sending one more of these out for test tomorrow. But only one is in an
aircraft and flying.
I'm not selling these yet, but I am making them on a limited basis for test.
Frankly, how to proceed is a puzzle. I do not have the test equipment to
realistically test this thing. Any suggestions?
See: http://www.periheliondesign.com/powerlinkcontactormanual.pdf
Finding someone to test this has been a chore and other projects are on the
front burner. I am going slow and trying not to promise what is in prototype
(Some of my customers and not happy waiting for promised stuff!). My website
is being updated with lots of new stuff and will be up soon.
Eric M. Jones
113 Brentwood Drive
"The man who carries a cat by the tail
learns something that can be learned
in no other way."
--Mark Twain
You guys have probably already seen this:
It's a version of the common plug-in plastic fuse. An internal LED glows to
indicate a blown fuse.
Auto Zone.
Troy Scott
From: | "Art/Sue Bertolina" <artbertolina(at)earthlink.net> |
Subject: | Ground Com Switch |
can anyone explain a ground com switch, how it is used
and the type of switch to purchase and a wiring diagram
Art Bertolina
Subject: | off topic - my car radio is driving me nuts !! |
I have had a problem with my car radio for the past several weeks and it's driving
me nuts.
Symptons: there's a clicking sound coming from it, sounds like about 4-5 clicks
a second. There is no clicking with the engine turned off, the noise starts when
the engine starts and stops when the engine stops, however the speed of clicking
does not vary with engine revs. The volume of the clicks is not affected
by the volume control, when I turn the volume way down so I can't hear the radio
station I still hear the clicks at the same volume. I hear the clicks on
AM and FM. The clicks always come from the right rear speaker. The car is fiberglass
(Corvette).
The problem started a few weeks ago and I found that if I turned the radio off
and then on again the clicks went away, sometimes I had to turn it off and on
a couple of times. Now the clicking sound is always there.
Do any of you radio gurus have a suggestion as to where I should start looking?
Thanks all,
Tony
Loose wire?
Trampas
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tony Babb
Subject: AeroElectric-List: off topic - my car radio is driving me nuts !!
driving me nuts.
clicks a second. There is no clicking with the engine turned off, the noise
starts when the engine starts and stops when the engine stops, however the
speed of clicking does not vary with engine revs. The volume of the clicks
is not affected by the volume control, when I turn the volume way down so I
can't hear the radio station I still hear the clicks at the same volume. I
hear the clicks on AM and FM. The clicks always come from the right rear
speaker. The car is fiberglass (Corvette).
off and then on again the clicks went away, sometimes I had to turn it off
and on a couple of times. Now the clicking sound is always there.
looking?
Thanks all,
Tony
Subject: | Re: Ground Com Switch |
My experience with a ground com switch was in a turbine aircraft where
it was used to power the number 1 com radio. It was used to obtain the
ATIS, get clearances, monitor the company freq, etc. You didn't have
to turn the master on so it was a simple single throw switch wired to
the hot battery bus.
>Thanks
>Art Bertolina
Subject: | RE: off topic - my car radio is driving me nuts !! |
Babb
>clicking 4-5 clicks a second. no clicking with the engineoff, the
>The volume of the clicks not affected by the volume control
>speaker.
>Tony
Procedure:
Swap right and left rear speakers (or replace right rear).
If clicks follow speaker--The speaker is bad (hope it's that).
If not, the wiring to the radio output or the output channel is bad--usually
a leaky capacitor in the output stage.
Eric
Subject: | Turn Coordinator wiring info. |
Hello IM ready to wire up my RC Allen turn coordinator and i don't have a
wire diagram for it. the T/C has the three pin connection on the back (Amphenol
MS3106A10SL-3S)
The turn coordinator is a RCA82A-11. The Pins on the Amphenol Connector are
marked A-B and C any help would be appreciated. Thanks
Bill Higgins
Pembroke Ma
Subject: | Narco Nav-121 Needle Dead |
I have a Narco Nav 121. Receives ok, To/From Flag works, but the needle
doesnt move off center. Any advice? (Other than garbage can?)
Subject: | Battery Vs bench power supply |
Hi Bob and listers,
I'm ready to smoke test the wiring and was planning on buying a power supply but
I hate to spend $80 for something I'm going to use once. I have a fairly simple
day vfr panel with dual batterys that I plan to just replace one per year
so I've always got a fresh battery plus one that is only 1 to 2 years old.
So I'm thinking of just buying a new battery now and using it to check out the
system. A year or so when I'm ready to fly I'll buy another new one and I'll
begin my planned rotation of batterys. Is there any reason that this won't be
as effective a way to smoke test the system as with a power supply?
Thanks for your opinion,
Rick Fogerson
RV3 wiring
Boise, ID
Subject: | Transponder arial location |
Hi Bob,
I've got a xpdr arial question for you. I have installed that little 3 inch long
arial with a ball (B&C) belly just aft of the firewall between the exhaust
pipes. The arial would be shielded some in the forward direction by the portion
of the lower cowl where cooling air exits and the exhaust pipes emerge from
the engine compartment. That wasn't a problem when I was going to install the
standard frp cowl but now I thinking of trying to build an aluminum cowl. How
much of a problem do you think this would be?
Rick Fogerson
RV3
Boise, ID
Subject: | Samlex Power Supply |
I am an absolute beginner when it come to electrical wiring, but based on
advice from this list I bought a Samlex 1223 Power Supply ($99) to use for bench
testing avionics and for testing electrical systems in the aircraft.
The power supply has no instructions. There are two screw terminals on the
back of the supply. What is the best method of getting power from the supply
to whatever I want to power? Are there cables I can buy? Do I have to make
some? What should the guage of the wire be? What type of connector should be
on the ends?
In advance, thanks for your help.
Stan Sutterfield
RV-8A
Tampa, FL
From: | "flyv35b" <flyv35b(at)ashcreekwireless.com> |
Subject: | Re: Narco Nav-121 Needle Dead |
Call Narco and see if they still service the 121. They haven't worked on
the NAV-11 for about 10 years.
I suspect that you have a bad left/right meter movement possibly. Of course
it could be other things. I don't know if the 121 is worth spending much
money on repair.
Cliff
----- Original Message -----
Subject: AeroElectric-List: Narco Nav-121 Needle Dead
Subject: | Re: Samlex Power Supply |
Stan,
I just bought one of those also, and I ended up using some extra 16-2
shielded wire I had laying around. I used both wires together in each
of the connectors on the power supply and doubled them over to better
fit the connector. I put ring terminals on the ends, and hooked one to
the B lead terminal on the alternator, and the other on the ground bolt
coming through the fire wall. It powers the main bus as if the
alternator was running. It has worked well.
Joel Harding
> on
> for bench
> on the
> supply
> to make
> should be
> on the ends?
> Stan Sutterfield
> RV-8A
> Tampa, FL
> _-
> _-
> _-
> _-
Subject: | VLM-14 Field Volts Hookup |
I have Bob's VLM-!4 and am hooking up the field volts wire to the Denso
internally regulated alternator, which has two connections labeled IG and L. Does
it go to one of these or someplace else? Thanks for any input.
Lance Johnson
RV-8A
Salt Lake City
Subject: | Re: VLM-14 Field Volts Hookup |
On my Denso, the ig is the one. The L is the warning light. This is all
covered in the data sheet enclosed, which is mainly in Japanese.
> From: LJoh896239(at)aol.com
> Reply-To: aeroelectric-list(at)matronics.com
> Date: Wed, 18 Feb 2004 12:24:37 EST
> Subject: AeroElectric-List: VLM-14 Field Volts Hookup
> Does
> Lance Johnson
> RV-8A
> Salt Lake City
Could you send the link please?
Sid
Auto Zone.
Troy Scott
From: | Mickey Coggins <mick-matronics(at)rv8.ch> |
Subject: | Re: Favorite "switch feel"? |
Hi,
Here is a bit of information for you:
http://www.intertechnique.fr/us/groupe/filiales/ece/index.htm
Let us know if you find something cool!
Mickey
>I was flipping a switch from a Falcon 20 the other day which made me say,
>"Wow -- that's a REALLY nice switch action! I'd like to have that switch in
>my RV." Unfortunately, it's made by ECE, a French company ("L'Equipement et
>la Construction Electrique SA"), and I don't have any ordering information.
>(The specific switch in question was provided directly by the Falcon factory
>for this simulator, so I have no way to order one on my own.)
Mickey Coggins
http://www.rv8.ch/
#82007 QB Wings/Fuselage
Subject: | RE: Favorite "switch feel"? |
>>Does anyone have a favorite brand of switch that they prefer to use, based
>>on its tactile feel and smoothness of switch action?
Now there's a man after my own heart.
If there were switches that felt like the shutter button of a Leica M3, I'd
buy them. Hewlett Packard thought switch "feel" in calculators was
incredibly important; they provide important tactile feedback. Same with
IBM. No matter what computer I use I take my own IBM/AT keyboard to use.
I once complained to a switch manufacturer that a potentiometer felt "cheap"
and was told by the manufacturer that they can make it feel any way at all
by changing the silicone grease. So I ordered per their suggestion XYZ
grease and everyone was happy.
High-priced audio equipment makers specialize in this art. But I suspect
that most corporate bean-counters are not interested in this, and many
manufacturers just stumble across it accidentally.
Everything feels good in a glob of grease.
Eric M. Jones
113 Brentwood Drive
Subject: | Whats the name of this stuff? |
I need some stuff that I call 'potting stuff'.
Its the stuff used to pour over electronics to harden the item from
moisture shaking, etc.
I want to be able to walk into Fries Electronics and tell them what I
want.
Cecil
Subject: | Re: Whats the name of this stuff? |
>I want to be able to walk into Fries Electronics and tell them what I want.
>Thanks,
>Cecil
Cecil,
Potting stuff comes in many flavors--
Urethanes, Silicones, Epoxies, etc. depends on what you want to do.
Sometimes the potted electronics must be repairable. Sometimes great thermal
conductivity is needed. Sometimes it must be clear, sometimes colored.
Sometimes very viscous, sometimes not. Sometimes flexible, sometimes like
ceramic.
You can use regular epoxy or urethane if the job has no particular
requirements. Silicones sometimes eat up fine PCB traces unless you get
electronic grade.
Just coating the circuit with clear epoxy has its "adherents". (I am so
easily amused...)
Like everything else---just Google it. Loctite and 3M make lots of the
stuff.
Eric M. Jones
113 Brentwood Drive
"People don't really appreciate how very difficult it is to be a princess."
--Princess Diana
Subject: | Re: RE: Favorite "switch feel"? |
I can relate to the need for good switch feel. I hate clunky switches that
are too hard to flip. But gadzooks Eric, I absolutely hated the IBM
keyboards, so I don't know what the HECK you're talking about! LOL!
Anyway, I was in Altex, an electronics store in Dallas today and flipped
all the switches they had on a display board there. Didn't really like any
of them. The metal ones are usually too "hard", and the ones with plastic
bat handles are usually too "soft" and easy to accidentally flip.
I did luck out with the switch panels I had built by Aircraft Simulators
(www.AircraftSimulators.com), because they feel "just right". They are
made by "Chili" and rated at 10A.
Dave Morris
>Regards,
>Eric M. Jones
>113 Brentwood Drive
All of that reminds me a discussion I once read in a gun journal.
Someone discussed parameters of several guns, and in addition to usual
parameters like weight, caliber, velocity of projectile, etc. he
included also the "feel" - whatever that means, because he never defined
that parameter. Strange thing, the most expensive guns scored the
highest in that "feel" competition. I guess, it feels good to have
something expensive (Hewlet Packard?) or rare (French?). A switch made
of unobtainium probably would beat anything else in that competition.
Jerzy
>Dave Morris
>>Regards,
>>Eric M. Jones
>>113 Brentwood Drive
Otto, Otto, Otto.
IMO, Otto Engineering has the best pushbutton switches
out there. They have a rolling sleeve action that
gives a silky smooth push to a tactile, crisp snap
followed by a "drop-through". There is no doubt when
you have actuated the switch. Grab any "real"
military stick or throttle grip and you're probably
pushing Otto switches. They also make some smaller
styles that are just as nice. Top shelf stuff.
Next in line would probably be ITW for push buttons.
For toggles, I prefer the MS3505x style for panel
applications. I think they feel robust and positive.
As someone else said, it's like the difference between
a fine gun trigger and a crappy one. Once you've
experienced a fine one you're spoiled for life.
http://antispam.yahoo.com/tools
I thought switch feel was cured by using push button switches?
For me the nice sharp manly click of a military bat switch is the best.
Arrrgh...Arrrgh... Arrgh... Arrrgh!!!
I always think the soft ones are going to break.
I have used 7 Potter-Brumfield circuit-breaker - switches called
"combination switches" and they perform flawlessly. They seem to cost a
little less then the standard switch by itself. I like saving weight and
even though Bob promotes fuses it seems inefficient to use a fuse and a
switch when the combination switch will do the work perfectly and only
requires one (1) wire out to the item requiring power and that also reduces
wiring and I don't notice weight increase verses the standard switch.
Each to there own I guess but after 1,100 of VFR/IFR flying in the LEZ the
combination switches have never given me a problem and the wiring simplicity
is something to be enjoyed.
They also have the sharp click and as most bat switches you can tell by
looking if they're on or off.
-Dale
Subject: Re: AeroElectric-List: RE: Favorite "switch feel"?
that
any
> Dave Morris
based
I'd
"cheap"
all
> >Regards,
> >Eric M. Jones
> >113 Brentwood Drive
Subject: | Re: Favorite "switch feel"? - Otto |
Lots of good info on their site: http://www.ottoeng.com/
(Photos, specs, distributors, etc.)
--- flmike wrote:
> Otto, Otto, Otto.
I was using the 5000W devices.
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Jerzy
Krasinski
George Braly wrote:
>Bob,
the
>Regards, George
likely peak current would be around 50A, so that would allow some extension
enough so most of the current will go through one TVS, while others will
just hang there. Maybe measuring them and selecting them in very similar
bunches would work, but that requires building a nonstandard curve tracer
for operation at rather high currents. Probably it can be done in a crude
way discharging a capacitor through a few of them in parallel and observing
Jerzy
Subject: | Essential bus alternate feed from two batteries |
I have a two battery one alternator RV and would like to be able to use
the power in both batteries in the event of alternator failure. I am
using Bob's Z-11 (Generic Light A/C) drawing with the Aux battery added.
Do I need two separate essential bus alternate feed switches in order to
keep the batteries isolated?
Jim
Subject: | Re: Essential bus alternate feed from two batteries |
No. Read chapter 17 in The Aero Electric Connection.
Subject: AeroElectric-List: Essential bus alternate feed from two batteries
Jim
Subject: | jack for charging battery |
There was previously a thread about using a smaller guage wire to a battery for
charging purposes and having a jack to plug in a charging source. What kind
of jack would be best for this?
Dave Ford
RV6
Subject: | Re: jack for charging battery |
I use an automotive cigar lighter type power plug protected with a 3amp
inline fuse(5 amp would work also), both mounted on the instrument panel.
That gives me a hot battery power source for a light or something and allows
me to trickle charge my battery very easily. Just connect the positive lead
to the (+) side of the battery and the (-) side to a ground bus or use the
instrument panel as ground(the plug base is grounded when mounted to metal).
Any automotive store will have a selection. It's probably not a good idea
to fast charge (10amps or more) your battery while it is in the airplane.
Scott Hersha
Subject: AeroElectric-List: jack for charging battery
battery for charging purposes and having a jack to plug in a charging
source. What kind of jack would be best for this?
> Dave Ford
> RV6
Done that, don't see it. Can you be a bit more specific? Bob's 17-6
drawing does not allow for both batteries to power the essential bus
(during alt out ops and both battery contactors open). Perhaps a 2-10
switch would do nicely here (off-on-both).
Jim
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wayne
Berg
Subject: Re: AeroElectric-List: Essential bus alternate feed from two
batteries
batteries
Jim
From: | "John Wiegenstein" <n727jw(at)hellerwiegenstein.com> |
Subject: | Stereo Hookup to Flightcom Intercom |
Just about done with wiring and panel, and have 1 issue to iron out: how to
connect my IPAQ (or other stereo device, such as a portable CD player) to
the intercom? The Flightcom 403 intercom shows 2 wires going to a .125"
jack for stereo input, and I've wired that up. Presumably these are for L
and R channel music source. But I'm thinking that on the output side of
the stereo music source, you've gotta have 3 lines: L and R source plus a
common or "ground". With just 2 lines hooked up to the source, I can hear
music thru the intercom but its "incomplete" and has a kind of echo-like,
distant sound to it (hard to describe). I'm betting I need a third wire
between the source and the .125 jack, and to then gound the (currently
unused) third contact on the jack. Can anyone help here? I'm sure
there's a simple answer that I'm missing, ands that this has been solved
many times before by others. Maybe my brain is getting mooshy after
crimping all those Fast-Ons and D-subs . . . . TIA
John Wiegenstein
Hansville, WA
RV-6 N727JW (reserved)
I am considering using the Aero'lectric aux bat system for my RV-9A, and am
also interested in how others have done this. I am also interested in where
the aux bat was located. My main thought is to have a "stand-by" bat to
replace the internal bat in the Dynon EFIS.
Ken Anderson
RV-9A
fuselage
From: | Tammy and Mike Salzman <arrow54t(at)yahoo.com> |
Subject: | Re: Otto Eng products |
Carlos,
Try this:
http://www.ottoeng.com/ottocontact.htm
Otto Engineering, Inc.
2 East Main Street
Carpentersville, IL 60110
Phone: 847-428-7171 Fax: 847-428-1956
Email: info(at)ottoeng.com
Mike Salzman
Fairfield, CA
LNCE
--- Carlos Sa wrote:
> Does anybody know where you can buy Otto Eng products?
> Carlos
Subject: | Re: Turn Coordinator wiring info. |
>back (Amphenol
>MS3106A10SL-3S)
>Bill Higgins
>Pembroke Ma
I needed the same info today, so I spent twenty minutes on Google.
All I could find was:
http://www.wingsandwheels.com/page22.htm
Then I picked up my turn and bank, and noted that it had a very nice
label which said:
PIN A - POS
PIN B - ACGT GND
PIN C - NOT USED
Have fun,
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
The Turn Coordinator the flys on my desk also has the same pin out printed
on the back.
Subject: Re: AeroElectric-List: Turn Coordinator wiring info.
> >back (Amphenol
> >MS3106A10SL-3S)
are
> >Bill Higgins
> >Pembroke Ma
> label which said:
> PIN A - POS
> PIN B - ACGT GND
> PIN C - NOT USED
> Have fun,
> Ottawa, Canada
From: | "Gerry MacDonald ( VE6QLT)" <Gerry182(at)telusplanet.net> |
Would anybody have a schematic for anICOM A-22 portable, that could answer a question.
thanks
Gerry
"Would anybody have a schematic for anICOM A-22 portable, that could answer a question.
thanks
I'd buy stock in a company that could make a schematic that understands english.
Dave Reel - RV8A
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> batteries |
Subject: | Essential bus alternate feed from two |
batteries
batteries
You need two batteries only where there are separate tasks
for each to perform during alternator out operations. Usually,
the second battery supports and electrically dependent engine
while the first supports panel mounted stuff. If you don't
have an electrically dependent engine, then just put in one,
fatter battery.
Subject: | SD-8 Overheat Prevention |
I spoke with Tim at B&C for a good period on Friday discussing the potential
of the SD-8 regulator overheating when in continuous use over 3 amps. I
must say, after being on the RV-List for 9 years and following Bob's "All
Electric on a Budget" when building my RV-6A, I was disheartened during the
conversation. He said that he was unaware that Bob was recommending this
alternator be used as a backup with essential buss loads of 8 amps until
fairly recently. After going through all the stages of grieving, I asked
what the fix was. Since the PM, SD-8 regulator needs to shed the excess
loads via heat, the only fix is to cool it. I went to the local custom
computer place and bought a heat sink and cooling fan made by Intel to cool
CPU's. I attached this to the top of the regulator via a aluminum strap and
JB Weld. It is switched to come on when I turn on the SD-8. I have no way
of telling if it going to be a fix or just prolong the fatal event. My hope
is that I will only need it for 30 min or so while I get down after a main
alternator failure.
Ross Mickey
N9PT
Subject: | Microair products |
Bob:
What is the status of the Microair products?
Are the comm and the transponder going to be available through you?
Steve
Subject: | Re: Essential bus alternate feed from two |
batteries
batteries
If your EFIS will run from the endurance-bus, I'm not sure
as to the value of adding an aux battery to your system just
to support the EFIS system. It may be that you just need to
size the main battery such that you have sufficient capacity
to support the e-bus for all loads needed to extend your
alternator-out endurance sufficiently to allow use of
fuel aboard.
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
> and L.
> > Does
> > Lance Johnson
> > RV-8A
> > Salt Lake City
Field voltage measurement feature in the VLM-14
can only be used with externally regulated alternators.
Subject: | Re: Transponder arial location |
>Hi Bob,
>inch long arial with a ball (B&C) belly just aft of the firewall between
>the exhaust pipes. The arial would be shielded some in the forward
>direction by the portion of the lower cowl where cooling air exits and the
>exhaust pipes emerge from the engine compartment. That wasn't a problem
>when I was going to install the standard frp cowl but now I thinking of
>trying to build an aluminum cowl. How much of a problem do you think this
>would be?
>Thanks,
>Rick Fogerson
>RV3
>Boise, ID
It will be fine where you've installed it.
Subject: | Re: Battery Vs bench power supply |
>Hi Bob and listers,
>supply but I hate to spend $80 for something I'm going to use once. I
>have a fairly simple day vfr panel with dual batterys that I plan to just
>replace one per year so I've always got a fresh battery plus one that is
>the system. A year or so when I'm ready to fly I'll buy another new one
>and I'll begin my planned rotation of batterys. Is there any reason that
>this won't be as effective a way to smoke test the system as with a power
>supply?
That works too. I've often suggested that folks run their
airplanes from a car or marine battery and battery charger
while under construction and don't put the real ship's battery
in until first-flight so it's new and fresh.
Why not install an e-bus and put the com radio on it? You
can bring the e-bus up before the main bus to get your
pre-flight communications covered . . . this needs to be
done anyhow so that the e-bus alternate feed path is tested
during preflight.
> >Thanks
> >Art Bertolina
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
Subject: | Re: SD-8 Overheat Prevention |
>alternator failure.
>Ross Mickey
>N9PT
Something really doesn't add up here. B&C markets this alternator
and regulator combination as being rated at 8 amps. They don't say
that there is any time limit for the 8 amp output, nor do they
specify a lower continuous rating. If this thing is only good for 3
amps continuous, why are they marketing it as an 8 amp device?
I'm really looking forward to the results of Bob's testing. My
regulator is bolted to an aluminum airframe, and I'm really hoping
that will provide enough of a heat sink. I'm going to get some
little stick-on temperature witness thingies and do a long duration,
fully loaded test of my SD-8 before I decide I can count on it for my
IFR backup electrical power.
Subject: | Re: fuse accessability |
>Comments/Questions: Bob:
>What is your understanding of the FAA regs re location of fuses and
>circuit breakers? All I find in Part 91 is a statement pertaining to SPARE
>fuses (which must be accessible to the pilot). At least one RV I know of
>that received an Airworthiness certificate recently has all its fuses
>located in a compartment between instrument panel and engine (completely
>inaccessible to pilot in flight.
>We have a new Amateur-built Designated Inspector who may be quite tough on
>details, so I want to be prepared.
There are no requirements that apply to your airplane in this
regard and few that apply to certified ships. Fuse access speaks
to articles "critical" to safe flight. Given that there are
many ways that any piece of equipment can fail and NOT blow
a fuse, it seems logical that any piece of equipment truly
REALLY critical to safe flight should have a back-up system
making the fuse accessibility issue moot. Whether or not a
bureaucrat will understand this is always a risk.
The reason I went with two batteries is two fold. First, I have one mag
and one electronic ignition (not a electrically dependant engine).
During start I thought I would use the main battery for cranking engine,
the aux battery for powering the electronic ignition (to avoid any
possibility of kick back in the event main battery voltage drops below
min required for electronic ignition). The second reason is your
recommended battery replacement plan of once a year, I will always have
one new battery and one no more than two years old. So with that said,
don't you agree that having the ability to use both batteries to power
the essential bus to is a good idea? If so, is the solution a 2-10
switch?
Jim
Robert L. Nuckolls, III batteries
Subject: RE: AeroElectric-List: Essential bus alternate feed from two
batteries
batteries
fatter battery.
Thanks for the info I just wired up the T/C and powered it up, works good!
PIN A - POS
PIN B - ACGT GND
PIN C - NOT USED
Bill Higgins
Pembroke Ma
Subject: | Flap motor overload? |
Howdy list!
I've blown the fuse on my flaps when they reach the full up position (Van's
unit in my -6A) twice now in 2 days (5 amp first, tried 7.5 & still blew- yes
wire is fat enough!) and I can't find anything wrong, linkage binding, wires
worn etc. Only thing that is unusual is that the motor seems to be trying
somewhat harder at the fully extended position (flaps up) than it does fully
retracted where it seems to freewheel more easily. Should it be freewheeling easily
at both ends, and shouldn't 5 amps be plenty of fuse for this? I don't
recall where I got the load value, but it's wired with 18ga.
Thanks!
Mark Phillips -6A N51PW - 37.4 hours in 3 weeks! What an awesome machine!
8-)
Subject: | LSE electronic ignition installation |
Greetings Bob and all, I have been off this list for several months. I
wanted to stop back to ask a question, and glean other's experience with
installing the LSE ignition.
Klaus says to pull the 14v power supply directly from the battery, run it
through a pullable 5 amp breaker, maybe through a switch, then to the
control box. Likewise, he says to run the ground directly to the battery.
My preference would be to connect the 14v line to my endurance bus,
protected by a 5a fuse. I have a 16 awg fusible link between the battery
and the endurance bus, as well as the essential bus switch.
Likewise, I would like to connect the ground to my firewall bus.
Do any of you have experience with installing the LSE ignition onto the
endurance and ground buses? What was the result?
Thanks!
Sam Hoskins
Q-200 with ~1,350 hrs.
From: | "David Chalmers" <David(at)ChalmersFamily.com> |
Sam, when I first installed my LSE ignition I wired it to the regular ground and
power bus. I have long #4 cables to the battery and the engine would crank but
wouldn't fire until the start switch was released - it wasn't getting enough
volts. I wired the LSE ground and power directly to the battery via a fuse and
have had no more problems.
Dave Chalmers
Redmond, WA
Subject: AeroElectric-List: LSE electronic ignition installation
Thanks!
Sam Hoskins
I was thinking of wiring my LSE the same way Sam was going to. I'm surprised that
the voltage from the buss is less than the battery. Why is this? I went
throught the voltage loss calcs and don't see where the volts are going. It seems
that running the power off of the battery buss and running a seperate wire
is basically the same thing. My battery is very close to the battery bus,
I have an RV, so the wires are very short. What am I missing???
Cam
Dave Chalmers
Redmond, WA
Thanks!
Sam Hoskins
Subject: | Re: Keeping flash tubes nice |
>I'm interested in this too...though I think it's really the gozillion
>joules of energy that we're sending through 'em.....
>From: "Lawson, Michael" <mikel(at)SSD.FSI.com>
>Subject: AeroElectric-List: Keeping flash tubes nice
>I am in the process of wiring my (Whelen) strobes up, and I noticed how nice
>and clear they look when new. Last time I walked around Oshkosh, I noticed
>that many flash tubes on experimentals seem to have a darkened, brownish
>look, almost like they've been overheated.
>Is this indeed caused by overheating, by having the tube enclosed behind a
>plexi lens and not exposed to the air stream for cooling, or is it just a
>natural degradation of the flash tube over time?
They do darken the inside surface of the glass over
time. A flash tube's life is rated in numbers of flashes
before it's light output drops to some pre-selected level,
usually 1/2 of original light output.
The harder the tube is "pushed" (joules per flash) the faster
the darkening and the shorter the service life.
Subject: | Spirellcell Technology |
I saw a Sears ad today that advertised a new battery technology, Spirellcell
Technology. It says - tightly compressed spiral wound cells with absorbed
glass-mat separators hold electrolyte like a sponge to eliminate acid spilling.
Have you heard of this? Is it something of value to OBAMs?
Stan Sutterfield
RV-8A
Tampa
>fuse/breaker?
The LOAD analysis is an ENERGY study first . . . do you have enough
battery/alternator capacity to produce the desired endurance . . .
and a PROTECTION study second to decide fuse/breaker and wire
sizes. As you have noted, the transmitter side of a transceiver
takes some higher, momentary current flows that set fuse and wire
size but is generally ignored for endurance since the transmit
duty cycle is very low. Both conditions have to be accommodated
in the final configuration.
Subject: | Re: Spirellcell Technology |
>Bob,
>spilling.
Don't think so. The jelly-roll cell is the first of the
RG batteries patented by Gates about 25 years ago. Optima
bought the tooling from Gates when it decided to get out
of the battery business.
See http://www.optimabatteries.com/index.asp
where you'll see "Spiralcell" used to describe Optima's
product. Hawker bought the Gates prismatic (rectangular cells) line
which became the Genesis series Hawkers and others . . .
It's a good battery but nothing new.
Mark...
Our RV6a has had a failed flap motor twice in the last 40 hours. Both times,
motor gave hint of trouble with intermittent hesitation, then complete
failure, both times in "up" position, refusing to extend. Fortunately, RV lands
just
fine without flaps, just need a tad more speed. In each case, inspection
revealed "gunk" between brushes and commutator, and upon thorough cleaning, worked
fine.
In your case, I'd sure take a look at those brushes. Clean them up with some
contact cleaner and a Q-Tip.
I've been told by knowledgable Van's employee that full extension at 100 mph
might overload motor, causing this phenom, so currently drop half flaps at
100, rest at 80. We'll see if this improves situation. In researching, found
several instances of same problem on "RV-List". Hope this helps.
Jerry Cochran
Wilsonville,OR
In a message dated 2/22/2004 11:57:06 PM Pacific Standard Time,
aeroelectric-list-digest(at)matronics.com writes:
Subject: AeroElectric-List: Flap motor overload?
Howdy list!
easily
Thanks!
8-)
I hand prop my Q-200, so loss of voltage will cranking will not be an issue.
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David
Chalmers
Subject: RE: AeroElectric-List: LSE electronic ignition installation
and power bus. I have long #4 cables to the battery and the engine would
crank but wouldn't fire until the start switch was released - it wasn't
getting enough volts. I wired the LSE ground and power directly to the
battery via a fuse and have had no more problems.
Dave Chalmers
Redmond, WA
Thanks!
Sam Hoskins
My experience with ICOM America is that they are pretty easy to deal with and accomodating.
I have two of the panel mount A-200's and an A-22 hand-held.
Why not contact them directly? I dont't have their number handy, but you can find
their phone number on the website. Just do a 'Google' search....
Good luck,
Jack Lockamy
Camarillo, CA
I built and installed the noise filter you describe from Radio Shack, except
it came with a 220uf capacitor rather than the 10uf suggested in your plans.
It filtered out all the noise.....even most of the radio volume. With the volume
on max I can barely hear it. If I use a 10uf, will I get my volume back
and still filter out the noise? I had it connected to the power line to my audio
amp and it filtered everything, alternator, strobes, fuel pump, very effectively.
Just turning off my com radio also stops all the noise. Should I try
putting the filter on the radio power line?
Scott Hersha
>ground and power bus. I have long #4 cables to the battery and the engine
>would crank but wouldn't fire until the start switch was released - it
>wasn't getting enough volts. I wired the LSE ground and power directly to
>the battery via a fuse and have had no more problems.
>Dave Chalmers
>Redmond, WA
the key word here is "long" . . . when your battery
is someplace other than on the firewall close to the
engine, #2 wire is indicated. Also, do a load test
of the battery to see that it doesn't drop below
9 volts after 15 seconds load at 300A.
Subject: | Re: LSE electronic ignition installation |
This SHOULD work fine. The only thing I would do different
is run the ignition system from 5A fuse on battery bus. You can
have the panel completely dark and still not affect the
engine.
Subject: | Re: Flap motor overload? |
>Howdy list!
>freewheeling easily
A motor that draws only 3-5A will draw 10-20A inrush during
startup. It would be very useful to get some current measurements
from your flap system while in flight. When your flyoff is
done and you can carry an assistant, it would be pretty easy
to do and share this data with the list. Post a note when
you're ready and let's talk about the setup. In the mean time
try a 10A fuse.
> >alternator failure.
> >Ross Mickey
> >N9PT
I agree. I've NOT heard anything about continuous duty
operation limits on the SD-8 before. I know the SD-8 regulator
has been through some evolutionary changes over the years
but Never had the impression that the critter wasn't
good for 8A continuous . . . and in recent years, I was
told that it would deliver 10A at 12.5 (but that wasn't
being offered as an increase in continuous duty rating).
I've not been able to make an accurate deduction of cooling
capability of the stock SD-8 regulator with bench testing.
It's a potted device. I've asked Todd to see if the supplier
will share technical details of the product with me.
In the mean time, I've forwarded a copy of this posting to
Todd and will suggest that they do some testing in-house
on various sizes of heat sink to see what it takes to
"cook" a stock SD-8 regulator. I'd like to participate
in this but right now, I've got too many things on my
plate. None-the-less, this is B&C's product . . . they
should know more about it than anyone else. If they
don't have ready answers to customer questions, it's
their duty to deduce and supply them. The question of
the hour is, "What heat-sinking and/or ambient temperature
limits are recommended for 8 amps or more of continuous
duty output from the SD-8 with it's present regulator?"
In the mean time, if any of you are in a position to
do some constructive experimentation, you might check
with your John Deere dealer about a p/n AM101406
regulator that is cited in this article:
http://home.hiwaay.net/~langford/corvair/dynamo.html
In this housing and with the cooling fins, it seems
a much more likely candidate for service at 10 Amps
plus than does the stock B&C regulator. The schematic
in the article suggests that it's a drop-in replacement
for the SD-8 regulator. It's not a bad price at $67.00
either.
It would be valuable information for someone to give
it a try on their existing SD-8 installation and report
back to us with the results.
Last November, David Carter offered this information
to us on the List:
Subject: Re: Future replacement for Rotax
Date: Nov 18, 2003
Bob, about testing a John Deere PM alternator and regulator. Here's the
info I've looked up and shared with others. A look at one of these
by you
would be a great thing. I've attached the spreadsheet as a pdf file to
this e-mail - but think attachments get stripped off. So, will copy and
paste here:
Output Alternator Regulator Weight
Amps P/N P/N LBS
20 AM877557 AM101406 4
35 AM877957 AM101406 4? (Same alternator
with internal changes,
uses same regulator)
John Deere PM alternator info - researched at Deere dealer by David
Carter
I'd like to use the 35 amp if can keep loads down enough for IFR &
night
Otherwise, I'll probably use the 85 amp - I want a PM alternator. (RV-6
with Mazda rotary engine)
I think it's clear that the 101406 regulator is CONSIDERABLY more robust
than the regulators offered by either B&C for the SD-8 and by Rotax for
the 912/914 engines. Personally, unless there are features of the
AM101406 as yet unrevealed to us, it seems a very attractive alternative.
Subject: | Re: Microair products |
>Bob:
>Steve
I've discontinued that offering. I'm going to concentrate
on product development that is unique to the AeroElectric Connection.
From: | "Eric Ruttan" <ericruttan(at)chartermi.net> |
You may carry a flight engineer during your flyoff.
(Van's
yes
> try a 10A fuse.
> Bob . . .
times,
lands just
cleaning, worked
> fine.
I don't have an RV but I was talking recently with a couple friends of mine
who do and who have had flap motor problems. It seems that it is due to
brush and commutator contamination from oil or more likely grease that has
"melted" and drained out of the bearing that is above the commutator. I
gather the RV-8 does not have the problem because the motor is mounted
"upside down" or the opposite way and the bearing is beneath the commutator.
Cliff A&P/IA
Subject: AeroElectric-List: Re: Flap Motor
> Mark...
times,
lands just
cleaning, worked
> fine.
some
mph
at
found
> Jerry Cochran
> Wilsonville,OR
> From: Fiveonepw(at)aol.com
> Howdy list!
(Van's
yes
wires
fully
freewheeling
> easily
> Thanks!
> 8-)
Hello Eric,
Monday, February 23, 2004, 6:36:42 AM, you wrote:
ER> You may carry a flight engineer during your flyoff.
What is the definition of a "flight engineer"?
Best regards,
Steve
-----BEGIN PGP MESSAGE-----
iQA/AwUBQDoV9MxYYrZi8xi9EQLpUgCg/H9DxfmPxkhupa7yg4VV/hcprIcAnRFQ
QjYNFwLEH+lCjJ+xqdSetc+U
=m4T9
-----END PGP MESSAGE-----
NO you can not.
This is a very wide spread opinion that is a misinterpretation of one of the
paragraphs in the regs and is only second, in popularity, allows a flight
instructor during the fly off. Lots of wishful thinking that is completely
incorrect.
I attended the Washington Aviation Conference on Feb 21, 2004. I personally
discussed this subject with the FAA reps and they said absolutely not
allowed.
I also discussed it with my Insurance Broker and he said the owners and acft
insurance would also be voided.
The above was the result of a heated debate in the local EAA chapter as both
reasons were being used by several members to justify 2 in the cockpit
during the 40 hours.
Bob's right on this.
Paul
EAA Tech Coun, Flight Advsor
Having a second person in the cockpit is strictly prohibited by FARs for our
amateur Built planes. Could generate a lot of problems both with the FAA and
the insurance company.
Cy Galley
Editor, EAA Safety Programs
cgalley(at)qcbc.org or sportpilot(at)eaa.org
Subject: Re: AeroElectric-List: Flap motor overload?
> (Van's
blew-
> yes
> > try a 10A fuse.
> > Bob . . .
Here's what Advisory Circular 20-27F, Certification and Operation of Amateur
Built Aircraft says about it taking someone along during the flight test
period:
13. PHASE 1 FLIGHT TESTING.
e. Restrictions
(1) Carrying Passengers. You may not carry passengers while you are
restricted to the flight test area or during any portion of your Phase I
flight test program. We suggest you use a tape or video recorder for
recording readings and other similar tasks. If you need an additional
crewmember for a particular flight test, specify that in your application
program letter for the airworthiness certificate. We will list this need in
your operating limitations.
(2) Flight Instruction. You may not receive flight instruction during your
flight test.
Terry
Subject: | Electric fuel pump circuit |
Bob & Listers,
I am currently modifying your Z-11 drawing for my specific RV-8A. I recall that
you recently recommended the use of relays for circuits drawing over 5 amps.
My Airflow Performance electric fuel pump draws about 5 - 6 amps in rush. Once
running, it draws 3.5 to 4 amps. Do I need a relay on this circuit? Would you
recommend installing this circuit on the main, endurance or battery bus? I have
an engine with 1 magneto and 1 Jeff Rose electronic ignition.
Charlie Kuss
RV-8A wiring
Boca Raton, Fl.
From: | "Phil Birkelbach" <phil(at)petrasoft.net> |
That motor is only supposed to pull 3A with a 100lb load on it. When moving
the flaps on my 7 it pulls less than 1A (no flying loads yet). Make sure
that your are not stalling the motor. It should start freewheeling just as
the flaps tuck up under the wing. You may need to readjust your pushrods.
Oh and congrats on getting your bird flying.
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB (Reserved) - Baffles / Cowling
http://www.myrv7.com
> Howdy list!
(Van's
yes
wires
fully
freewheeling easily
> Thanks!
> 8-)
It depends on where you take the power off for the main buss. The current
in the Big wire from the battery is very high during starting. The further
downstream on that Big wire that you take the main buss feed, the lower the
voltage will be. I suspect from his post that he has a battery located far
from the starter and probably has his main buss tied into the battery
contactor that may have several feet of Big wire between it and the battery.
If your's looks like mine and there is only a few inches of 2AWG wire beween
the + post of the battery and the batt side of the master contactor then you
probably don't have to worry about it. That being said I intend to feed my
LSE from the battery buss, and my battery buss is fed straight from the
battery post.
Godspeed,
surprised that the voltage from the buss is less than the battery. Why is
this? I went throught the voltage loss calcs and don't see where the volts
are going. It seems that running the power off of the battery buss and
running a seperate wire is basically the same thing. My battery is very
close to the battery bus, I have an RV, so the wires are very short. What
am I missing???
> Cam
> Dave Chalmers
> Redmond, WA
> From: Sam Hoskins [mailto:shoskins(at)mchsi.com]
> Thanks!
> Sam Hoskins
Subject: | Fw: Transponder arial location |
Subject: Transponder arial location
Hi Bob,
arial with a ball (B&C) on the belly just aft of the firewall and between the
exhaust pipes. The arial would be shielded some in the forward direction by
the portion of the lower cowl where cooling air exits and the exhaust pipes
emerge from the engine compartment. The lower part of the cowl is about even
with the arial ball. That wasn't a problem when I was going to install the standard
frp cowl but now I thinking of trying to build an aluminum cowl. How much
Rick Fogerson
RV3
Boise, ID
>battery post.
that's the way to do it!
Subject: | Re: Headset noise |
>Bob,
> except it came with a 220uf capacitor rather than the 10uf suggested in
> your plans.
The 10uf is what used to come with it. Pleased to see something
bigger being supplied now.
> the volume on max I can barely hear it. If I use a 10uf, will I get my
> volume back and still filter out the noise?
The filter is intended for use only in the power supply
lead . . . it should have nothing to do with the intensity
of desired signals. Sounds like you've wired it into one
of your audio leads instead of the power lead.
> I had it connected to the power line to my audio amp and it filtered
> everything, alternator, strobes, fuel pump, very effectively. Just
> turning off my com radio also stops all the noise. Should I try putting
That's a reasonable thing to try.
Subject: | Re: Dual fuel pumps |
>Mark: Assuming that you will be flying a low-wing (i.e.: NOT gravity-fed
>fuel) I personally would not fly with you in a plane like that. You would
>obviously have these two Facet pumps on completely different electrical
>systems - but you may end up having your face stuck in the cockpit looking
>for switches while your plane staggers to hold itself above stall on a short
>field take-off. Sounds like a statistic. You can make it work - but not
>simply. Simplicity is the ultimate sophistication. If you have the option
>of using an engine-driven fuel pump (e.g.: Lyc. or Continental) I would use
>it - backed up by a Facet electrical pump for take-off and landings. I can
>also provide back-up with my solenoid Primer for manually supplying three
>cylinders, in an emergency.
This sounds like you believe that an engine driven fuel pump
(cam operated, center-flexed diaphragm with hot engine oil
on one side and hydrocarbon-solvent (fuel) on the other all
of which is subject to the vibration and temperature variables
of being bolted to the engine) is somehow more reliable than an
electrically driven fuel pump with one moving part that
is not a diaphragm.
There are lots of electrically dependent engines flying as well
as driving. Lost the single fuel pump in my van a few weeks ago
and had to have the car towed for repairs in a shop 150 miles from
home. Over the years I've also had diaphragms go south on two engine
driven fuel pumps with similar show-stopping results. I'm not sure
I'm prepared to say that one pump is x-times better or worse than
another pump . . . fact is, either one can and will fail. This
is just the fuel delivery side . . . one could have dual electronic
ignition systems as well. There's nothing magic about the engine
driven fuel pump as a means for warding off evil spirits
that strangle engines.
The solution is failure tolerance. Design so that no single failure
brings down the house. A few years ago, a Long-Ez builder and I
concocted this all-electric fuel system with no valves (and no
fuel plumbing in the cockpit).
http://www.aeroelectric.com/temp/All-Elect-Fuel.jpg
Combining this plumbing architecture with a reliable
power supply (ND alternator combined with less than
year-old battery works) provides a level of reliability
(few fittings to leak; no valves to jam) that is hard
to equal much less beat in any certified configuration
I'm aware of.
His airplane had sight gages that let him manage fuel
transfer. In an RV I think I'd install a photo optical
level sensor in the right tank to light a light
when the tank was down to 1/3rd and a second to show
2/3rds. When the right side light came on at 1/3, I'd
turn on the transfer pump to get the 2/3rds light
to come back on. After the second transfer, I'd
leave the left tank at 1/3 for duration of flight
or until it was absolutely needed for approach to
landing.
By setting the needle valve in the 4-port primer
system to deliver fuel flow of 60-65% power, you have
a completely independent means by which you stay airborne
after suffering any number of failures in the main fuel
delivery system.
A couple of years later, John D hit the water after
discovering an unanticipated shortcoming in the airplane's
fuel system design. Three switches an a couple of lights
on the panel sure would have been nice.
The Facet pumps, unlike their Bendix thump-thump ancestors
are all solid state for controlling solenoid current
and have very simple mechanical designs. Further, when
they do quit, they don't provide an open hole by which you
fill your crankcase with fuel. This system was used to augment
an engine driven fuel pump, hence the label "Fuel Boost"
on the pump to the carburetor. Should I sense loss of the
engine driven pump, I think I would opt to descend on the
primer-port system to avoid the possibility of diluting the
oil and/or overflowing the crankcase with fuel. I think there's
reason to belive this system would perform as well or better
with no engine driven fuel pump at all.
Subject: | Load dump issues |
>Bob,
>I have done a fair amount of testing a couple of years ago, working with the
>TVS devices, including the larger sized versions.
>In my experience, they have not been adequate, alone, to prevent over
>voltage spikes on load dumps, even from smaller alternators.
>They help. But I have blown some of them on load dumps.
Have you taken any energy measurements on the load (battery)-dump
phenomenon?
I guess it depends on your local FSDO. Mine says that you can carry someone
with you if that person is required as a part a the phase I flight test.
For example, you need someone to record flight test data that you are unable
to record because of workload requirements while flying a particular
maneuver, or you need someone to look out for traffic while you are
simulating (hood) IFR flight while certifying the installation of an IFR
panel. Read the regulation. It's not open to interpretation and it's
fairly clearcut.
Scott Hersha
> NO you can not.
the
> incorrect.
personally
> allowed.
acft
both
> Paul
If your insurance company will cover you to fly your first flight, then they
should cover you when you need a second person to validate, record, or
whatever phase I flight test. That other person doesn't have to be a pilot,
in fact, that other person cannot function as a pilot on any phase I flight
test flight. He/she is only there to record data or perform some other
required function(look out for traffic while you are under the hood) that is
required for you to perform while conducting your phase I flight test. That
person cannot give instruction. If you need instruction, it has to be
accomplished under part 91 and part 61 either in a certified airplane, or an
experimental airplane operating in phase II, but not for hire. The FAA will
not allow you to give rides in phase I, however, if for safety reasons, you
need a second person for the above mentioned reasons, it is permitted under
the regulations.
Scott Hersha
our
and
> Cy Galley
> From: "Eric Ruttan" <ericruttan(at)chartermi.net>
> To:
> > (Van's
> blew-
> > yes
> > > try a 10A fuse.
> > > Bob . . .
My operating limitations did not list anybody specifically for my phase I
flight test. However, I was allowed to carry someone if required as a part
of my phase I flight test, not a passenger, as long as that person was
necessary for the testing being done.
Scott Hersha
Subject: RE: AeroElectric-List: Flap motor overload?
Amateur
> period:
> e. Restrictions
in
your
> flight test.
> Terry
I connected the filter between the bus and the power lead to my #1 COM
and it worked like a charm. This was a new filter with a 10uf capacitor. I
also wired the other filter I made with the 220uf capacitor the same way to
my #2 COM. It works just as well as #1. I can't tell any difference. I
now have a quiet, clear headset with no noise...Yea!!!
Scott Hersha
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: AeroElectric-List: Headset noise
> >Bob,
Shack,
> > your plans.
> Bob . . .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For the record a mechanical fuel pump on an airplane has two diaphragms and
if the fuel side diaphragm ruptures it pumps fuel out of a vent that should
be vented overboard. I am not certain every aircraft engine has a pump with
this feature but they do have dual diaphragms specifically so they will not
fill the engine block with fuel.
Engine driven pumps do fail but usually only because they are used beyond
there normal service life that being 3000 hours. Seems that I had an
in-tank electric fuel pump fail on two cars before 105,000 miles which is
roughly equal to 2100 hours. The problem with electric fuel pumps in cars
is the fuel contamination from the everyday pump gas. Much more so then
aviation fuel. The electric pump has a sock filter and when it gets dirty
it causes the pump to continually work harder until it fails. I have
consider doing the submerged pump in each tank or making a central sump with
easy access for maintenance because pushing fuel eliminates most vapor lock
stories.
Two electric pumps may be a good way to go but it is hard to beat a pump
that does not rely on electric power. Redundancy speaks loudly to this
airman.
Dale Martin
Lewiston, ID
LEZ-235
Subject: Re: AeroElectric-List: Dual fuel pumps
would
looking
short
option
use
can
> is not a diaphragm.
> I'm aware of.
> landing.
> delivery system.
> Bob . . .
In a message dated 2/23/2004 9:18:07 AM Mountain Standard Time,
cgalley(at)qcbc.org writes:
> Cy Galley
Some of these homebuilts get kinda complex and a second person would be a
safety factor. Tell me, What does Boeing do on their first flights of new and
unproven designs??? Is there just one pilot??? After all they all start life as
a
homebuilt...
Ben Haas N801BH.
Subject: | Two alternators-using total rated combined output |
Bob, going way back to last August - you suggested it was "not simple" and
"probably not cost effective" to install, for example, 2ea 20 amp
alternators and plan on loading them up for near 40 amps steady load - that
"balancing" and not "causing 1 to produce output over its rated value" was a
big deal. (I'm paraphrasing & summarizing from the e-mail which is quoted
below this.)
I was just thinking today of installing two John Deere PM 20 amp
alternators, using 2 different belts, so as to have a more fault tolerant
system requiring 32 to 35 amp steady load, total. I have roughly analyzed
my night/IFR system to be running about 32 amps, steady, under heaviest
loads.
Without asking you to design the system for me - I respect the work load you
already have - could you give a quick tutorial to guide me thru the design
and test of such a system? (or persuade me it's too hard to do with my lack
of knowledge and test equip)?
Sounds like 1) the "magic" has to be in the "voltage regulator(s)", not just
how the system is wired up; and 2) the most serious problem is 1 "20 amp
RATED alternator" actually having the ability to put out much more, but at
the expense of running over its "rating" and thus overheating and suffering
a "stress" it was not designed for - probably the same for the REGULATOR
that is also rated for 20 amps.
- What is the "simplest" way to a) have the two identical regulators
and alternators each share roughly 1/2 of the load, whatever it is, or, b)
allow 1 alternator to go up to its rated output and then have any subsequent
increase in load be picked up by the other alternator? Are there other
"approaches" to this?
David Carter
Subject: RE: AeroElectric-List: Alternator
> >Tom,
> >This is an answer Bob gave just a few days ago:
> >That is exactly what happens in certified ships. Figure Z-12
> > is not recommended for new design. It's an easy fix to add a
> > second alternator to an existing airplane. This this case, both
> > alternators are ON but the aux alternator regulator is set
> > for about 1 volt below normal bus voltage. Soooo . . . with
> > the main alternator working, the aux alternator relaxes.
> > If the main alternator quits, the bus voltage sags, the
> > aux alternator comes alive automatically. The SB-1 reglator
> > is fitted with a circuit to illuminate an "AUX ALT LOADED"
> > warning light and flash it if the aux alternator output
> > is higher than 20A . . . reduce load until light stops
> > flashing.
> >Terry
> > I've been trying to understand what would happen if both BC 40amp and
BC20
> >amp where on at the same time. Would this give you 60 amp capicity or
would
> >one sleep because the alt 's set point are not ever precisely the same.
> > Thanks Tom Reading RV7 wiring
> When you parallel alternators with an intent to load them
> simultaneously, getting them to share total load is
> possible but not trivial and, in my not so humble opinion,
> not cost effective.
> I would resist the notion that by having both a 40A
> and 20A alternator tied together that one has a 60A
> total capacity. This is strictly true only in a case of
> regulators designed to distribute load properly between
> two alternators.
> One might argue that should one alternator become
> overloaded, it's output sags so that the remaining
> alternator will pick up the difference thus making
> the 40+20=60 anyhow. True . . . as long as the current
> limit on both alternators is imposed by magnetic limits
> of the respective machines. For example, the SD-20 as
> installed in the Bonanza is rated at 20A . . . but being
> a 40A machine at heart, it WILL put out more if you
> load it up. However, COOLING is limited in this
> installation and operation above the 20A rating will
> put it at risk of letting all its smoke out.
> I've encountered VERY few cases where it made sense
> to add capacity of two alternators to justify
> loading a system to a value greater than either
> alternator will support. If you think you really need
> to do this, let's discuss the finer details and
> make sure you're not going to be disappointed.
> Further, be aware that to do it right suggests
> a regulator designed to truly parallel two
> machines. The Cessna 303 is the only airplane I
> am familiar with that had that capability. Lost
> the contract on that regulator system by less than
> $10 a regulator . . . the one they ended up with
> didn't work very well.
> Bob . . .
Subject: | Garmin 430 install manual |
I seem to remember that there was somewhere to download the install manual
for garmin products in particular the 430? But I can not find it on there
site, Anybody know where I can download this ??
Jeff.
From: | "ivorphillips" <ivor(at)ivorphillips.flyer.co.uk> |
Subject: | Re: Garmin 430 install manual |
I can send it as a PDF file if you want?
let me know
regards
Ivor Phillips
XS486 London UK
CM Installed,working on rudder cables,
trial fit top and wings
Subject: AeroElectric-List: Garmin 430 install manual
> Thanks
> Jeff.
Subject: | Garmin 430 and Diplexer/splitter |
Quick question,
On a Garmin 430 or 530 for that matter is a Diplexer/splitter required if
you have Bob Archer (like the one found at
http://www.vansairforce.net/articles/vorwingtipantenna/plans24bit.jpg )
Wing tip NAV antennas ?? One in each wing tip Total of TWO.
I am trying to get a hold of an install manual to confirm this for my self
but a recent contestation brought up the topic and would like answer faster
than I will probably have my hands on an install manual
Jeff.
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
> Quick question,
> required if you have Bob Archer (like the one found at
bit.jpg ) Wing tip NAV antennas ?? One in each wing tip Total of TWO.
Is the second nav antenna for a second nav radio? If so, you need one
coax from one nav antenna brought to a splitter near the 430, then a
splitter to feed the nav/loc and gs portions of the 430. I got my
splitter from my local avionics guy.
Alex Peterson
Maple Grove, MN
RV6-A N66AP 442 hours
http://www.home.earthlink.net/~alexpeterson/
>Bob,
>Scott Hersha
Success is always gratifying and I'm pleased that you're
pleased. The nagging question concerns why you needed to
install these filters in the first place. Unfortunately,
the answer lays in detailed analysis of the differences
between your system before filters were installed and
other systems that do not need filters.
Not trying to spotlight your efforts here Scott, but
your experience is perhaps illustrative of the value
in "doing a lot of things that have never been done
in 200,000+ certified ships" without demonstrable
reasons.
We often field questions about suggestions printed
in the 'Connection with respect to architecture and
techniques. Folks ask why they should go to all that
trouble when their C-172 doesn't have it and "it works
just fine."
It would be interesting to see how the variables in
your project stacked up to force adding filters to
the radios but it's probably not a practical effort.
The main thing is that your airplane's utility, performance
and comfort levels are now satisfactory to your needs.
We'll have to save the harvesting of knowledge
for another time and airplane.
A lot of my work at RAC involves harvesting knowledge
on designs already in production . . . some for 30 years
or more. In these cases, fixes to problems are retrofitted
to hundreds of aircraft and it's never easy or cheap.
There's a plaque I saw on the wall of an engineer
at one of our suppliers a few years ago that read:
"If you don't have time to do it right the first time,
how will you ever find the time to do it over?"
Here's hoping that the remaining efforts to get your
project completed are easy and cheap!
Subject: | Flap motor testing |
Thanks to all for your thoughts on the flap fuse failure fiasco- lot's of
good info... The following is long, tedious and boring (unless you're an
electrical masochist!) so delete now if so inclined............
Test results using Fluke 87 MM (10 amps max. current) connected at fuse
block. Flap motor (motion brand) is wired direct through a quality NKK DPDT switch
of the proper rating (no relays) using 18ga. My meter does have an "analog"
scale along the bottom of the display that responds very quickly, and it did
go off-scale the instant the switch is first turned on indicating over 10a on
start. This was also confirmed (If I did it correctly) by the min/max function
that records for 100 msec. which indicated "OL" or "out of range" for the
instrument. This confirms Bob's statement about inrush current. Below are my
readings, as best as I could tell while watching altimeter, airspeed, MM, and an
occasional glance for traffic (darn, no dang "required crew member"!) This
is all done with 10 amp fuse installed.
On the ground, engine off- cycled flaps repeatedly in both directions trying
to get a failure. Even held switch after full travel many times for as much
as 5 seconds with motor freewheeling, no failure, up or down.
Traveling Down: .8a
Freewheeling Down: 1.9a
Traveling Up: .9a
Freewheeling Up: 1.7a
(anyone know if this would indicate that the motion actuator has a a friction
clutch in it?)
Same values with engine running (LVWM off) at idle.
Tested again at runup (1700 rpm) and Down required .9 indicating harder work
against propwash. Up netted .8 for same reason- looks like we're getting good
data...
Climbed to 3000', trimmed for 100 mph indicated. Naturally these readings
are dynamic as the flaps change angle and airspeed falls, and the meter display
lags a little, but after repeated attempts, the values are as close as I could
get them by timing the extension/retraction - I'd release the switch while
watching the meter and verify flap had stopped at proper position- if not, I'd
re-do it. (again, no extra crewman!)
Traveling Down at 20 degrees: 2.0a
Traveling Up at 20 degrees: .7a
Trimmed for 90 mph.
Traveling Down at 40 degrees: 3.4a
Traveling Up at 40 degrees: .7a
Switch held in Up position with flaps Up in flight (motor freewheeling) 1.3a
(don't know why this is different than when sitting on ground)
One interesting thing I did notice was that when fully extending the flaps at
80-90mph to the point that the motor was freewheeling, or about 43 degrees on
my plane, the current would rise continuously until the end of travel, going
just over 5a at full extension, then as the motor began to freewheel, the
current dropped to 1.2 until I released the switch- not sure how the actuator is
constructed, but the air load is obviously not held by motor power alone...
Flaps performed flawlessly throughout this regimen, as did the rest of the
plane (omigawd what an awesome machine! - can you tell I like it?!) Now here's
the clincher. I had a little time to kill before dark and did some T&G's. The
first was pretty darn acceptable, flaps raised before taking off again and
extended normally on approach. On the second T&G I let the bottom fall out a
few feet up and got a bounce. Again raised the flaps before taking off, all is
normal. On downwind I hit the flap switch at 100 mph and NOTHING! Fuse blown
again! Same as both times before. Open for all ideas at this point!
Mark Phillips - N51PW - ONLY 1.9 HOURS TIL I GET OUT OF MY CAGE!!!!! 8-)
Subject: | Re: Two alternators-using total rated combined output |
subsequent
> David Carter
The simplest way would be to simply split the loads. Have two electrical
systems. Put Comm 1 on buss 1 and Comm 2 on buss 2, put the taxi light on
one side the landing light on the other. Two smaller batteries and a
crossover contactor for starting, and for single alternator operations. Put
a load meter on each one so you know what is going on and you've got it.
This also builds in a level of redundancy. I think Bob has a 2 alternator,
2 battery system in the Z diagrams somewhere.
There are probably some voltage regulators out there that can handle the
load sharing but I doubt that any of it would be 'simple'.
Godspeed,
Subject: | Re: Electric fuel pump circuit |
>Bob & Listers,
> recall that you recently recommended the use of relays for circuits
> drawing over 5 amps. My Airflow Performance electric fuel pump draws
> about 5 - 6 amps in rush. Once running, it draws 3.5 to 4 amps. Do I need
> a relay on this circuit? Would you recommend installing this circuit on
> the main, endurance or battery bus? I have an engine with 1 magneto and 1
Does your fuel pump run all the time or is it a backup for
an engine driven pump?
From: | "Nightingale Michael" <NightingaleMichaelV(at)JohnDeere.com> |
Possible heat build up in fuse from first two T&G's. Is the fuse cartridge a SLO-BLOW
or a standard link type?
90259 wiring
Subject: AeroElectric-List: Flap motor testing
Traveling Down: .8a
Traveling Up: .9a
clutch in it?)
data...
February 10, 2004 - February 24, 2004
AeroElectric-Archive.digest.vol-cx
