AeroElectric-Archive.digest.vol-dc
April 08, 2004 - April 22, 2004
      [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve
      Sampson
Subject: radio wiring
--> Bob - I dont know if it is just me but my copy of Adobe insists the file is damaged and cant open it....................... Steve. -----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III
See http://www.aeroelectric.com/Catalog/avionics/760imB.pdf for an exemplar wiring diagram for comm transceiver. Also, if you DO decide to install the 760VHF, I still have a few wire harnesses for that radio. ________________________________________________________________________________
Date: Apr 08, 2004
Subject: Re: attitude indicator on E-Buss or Main Buss??
BandC is http://www.bandcspecialty.com/ though I don't know if Bob actually owned them... I think BandC are the initials of Bill and Celesta Bainbridge, the founders. Regards, Matt- N34RD > > > I'm having troubles located B&C Electrical - the company Bob used to own > - what's their website thanks ________________________________________________________________________________
Date: Apr 08, 2004
BandC is http://www.bandcspecialty.com/ though I don't know if Bob actually owned them... I think BandC are the initials of Bill and Celesta Bainbridge, the founders. > > > I'm having troubles located B&C Electrical - the company Bob used to own > - what's their website thanks ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: attitude indicator on E-Buss or Main Buss??
Date: Apr 08, 2004
Comments (OPINIONS) below ... James [snip] > > would the ELECTRIC attitude indicator go on the e-buss or main? I think the basic idea is if you NEED it to get home safely in the conditions under which you might fly then put it there. > if on the e-buss and I don't have a switch for it - then if in > VFR with failed alternator - I would not need it yet it would be > running and so draining the battery? There should be adequate battery to run the things you **REALLY NEED** to get home for the period that you feel you would have to stay in the air under the conditions for which you fly. In other words determine what is gonna be your limits. - Wanna run til the tanks are dry? then you will need say 4 hours in an RV of "battery time". The more stuff you hang out there, the bigger the battery. - Want to use a particular battery? Then that says how much "juice" you have to work with ... limit things to fit how long you will need to be in the air. - Will "never" be more than 30 minutes from an airport? Then with a particular battery and a particular mix of "things" you can fit. I think you will find that Bob (and others) would suggest that you make the list of stuff you will have in the plane and then determine which of that is REQUIRED to get home. Next do a "load" analysis, i.e. mark down what the current consumption is for each item. Determine how long you will want to be upor determine the battery and you will be told how long you can stay up. If this works, you're done. If not, change the "required" list or the battery or the time you want to be up and reiterate. So you see there is no fixed answer. "It depends" on your preferences, but there is a "process" that you can use. > > How about the electric booster pump - main buss or e-buss?? Your call but I would not. It is NOT required to fly me home (unless of course the engine mechanical pump fails [in a low wing]). You probably would not have had it on when the alternator failed anyway unless you were climbing out. > > should the comm/gps/transponder all go on the e-buss- they all > have indipendend on/off switches on them - so if not needed, I > could shut them off. Which ones do **you** need to get home safely? The less you have on the "E-Buss", the longer the endurance and/or the smaller the battery required. Opinon ... the transponder does not help as much with 1) aviate, 2) navigate, 3) communicate. Doesn't generate lift, doesn't show me the way home, and doesn't do that much for the communication of the problem I have as it doesn't have voice, even though once I tell ATC I have a problem, if all else is well, I don't plan to talk much more. > > Would it also be a good idea not to put the attitude indicator > and turn coordinator on the same fuse?? - I would think one I would NOT. Your call. The last thing I want is to have a FAULTY turn coordinator fry the fuse and then take out my PERFECTLY healthy AI that I was hoping to be able to depend upon to help get me home (assuming there might have been some visibility issues). > would want both on the e-buss?? If I had power limitations, I would do at least one ... t he one I would want to depend upon in a crunch. > I'd like NOT to have another switch - how can I avoid one for the > attitude indicator. > Why a switch??? > I'm of the understanding that I ask myself "is it essential for > the completion of the flight" if so I put it on the e-buss. > Well then I would think instrument lights, radios, gps,electric > booster pump, attitude indicator, would all go on the e-buss - am > I right here?? See commentay above. It's your call. No "right" or "wrong" answer. Different "opinions" from many and some solid facts and experience from a few. I am in the "opinion" category. ;-) > > I'm having troubles located B&C Electrical - the company Bob used > to own - what's their website > thanks Try: http://www.bandc.biz/ or http://www.bandc.info/ James RV6 flying RV6A-QB under long term construction ________________________________________________________________________________
Subject: connectors on AML34
Date: Apr 08, 2004
Gentlemen, The red fast-on connectors from B&C seem to fit very well on the Honeywell/Micro Switch AML34 rocker switches, but they are really difficult to pull off once installed. Is this hardware meant to work together, or does it just happen to work? Regards, Troy Scott tscott1217(at)bellsouth.net ________________________________________________________________________________
Date: Apr 08, 2004
.187 fastons are what is needed. www.steinair.com has them. They are all difficult to come off. I would hope. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Troy Scott Subject: AeroElectric-List: connectors on AML34 Gentlemen, The red fast-on connectors from B&C seem to fit very well on the Honeywell/Micro Switch AML34 rocker switches, but they are really difficult to pull off once installed. Is this hardware meant to work together, or does it just happen to work? Regards, Troy Scott tscott1217(at)bellsouth.net == == == == ________________________________________________________________________________
Date: Apr 09, 2004
>you wrote: >Would it also be a good idea not to put the attitude indicator and turn coordinator >on the same fuse=3F=3F - I would think one would want both on the e-buss=3F=3F >I'd like NOT to have another switch - how can I avoid one for the attitude indicator. >I'm of the understanding that I ask myself "is it essential for the completion >of the flight" if so I put it on the e-buss. Well then I would think instrument >lights, radios, gps, electric booster pump, attitude indicator, would all go >on the e-buss - am I right here=3F=3F There are, of course, many opinions on how "essential" equipment should be powered. Personally, I'm not a big fan of putting everything I deem "essential" on the same buss, fuse, switch ... I would never want equipment I've already deemed essential to share any common failure point. IMHO, do NOT even consider putting the two of the best pieces of equipment you have for keeping the greasy side down on the same fuse. I would not even put them on the same buss. The idea is to keep any single failure from causing you to loose items that have no backup for and that the loss of will cause you to "break a sweat" getting back on the ground safely. I realize the odds are very remote but, the E-buss is a common failure point. Maybe our working definition of "essential" needs to be clarified. If I've deemed a piece of equipment essential for safe flight in the planned scenario, it must have a backup. That backup should not share any recourses with the equipment it is backing up. So, both pieces are not essential. One OR the other is essential. Greg ________________________________________________________________________________
Subject: Voltmeter Scaling Module
Date: Apr 09, 2004
This is a follow-up to an earlier question to and response from Bob Nuckolls regarding the Voltmeter/Loadmeter with a Voltmeter Scaling Module ("VSM"), which was at one time offered by the AeroElectric Connection (Catalog item VLM-14). The installation instructions at: http://www.aeroelectric.com/Catalog/AEC/9021/9021704F.pdf <http://www.aeroelectric.com/Catalog/AEC/9021/9021704F.pdf> are color coded, and the instructions make it clear that the magenta portion of the instructions are not applicable to permanent magnet alternators (although I do not understand why). In our earlier exchange on this subject, Mr. Nuckolls said, "If it [the alternator] has an internal regulator, then the magenta wiring and magenta instructions are not applicable to your alternator. I took this comment to mean that any alternator with an internal regulator could not take advantage of the auto switching feature or the alternator press-to-test diagnostics feature of the VSM, without regard for whether the alternator was permanent magnet or otherwise. If so, why is an internally regulated alternator not capable of using the auto switching features and the diagnostic features of the VSM? Voltmeter Scaling Module This is a follow-up to an earlier question to and response from Bob Nuckolls regarding the Voltmeter/Loadmeter with a Voltmeter Scaling Module (VSM), which was at one time offered by the AeroElectric Connection (Catalog item VLM-14). The installation instructions at: http://www.aeroelectric.com/Catalog/AEC/9021/9021704F.pdf are color coded, and the instructions make it clear that the magenta portion of the instructions are not applicable to permanent magnet alternators (although I do not understand why). In our earlier exchange on this subject, Mr. Nuckolls said, If it [the alternator] has an internal regulator, then the magenta wiring and magenta instructions are not applicable to your alternator. I took this comment to mean that any alternator with an internal regulator could not take advantage of the auto switching feature or the alternator press-to-test diagnostics feature of the VSM, without regard for whether the alternator was permanent magnet or otherwise. If so, why is an internally regulated alternator not capable of using the auto switching features and the diagnostic features of the VSM? ________________________________________________________________________________
Date: Apr 09, 2004
You may consider adding circuit breakers instead of fuses for instruments you want to turn off. Due to your long list of "essential" items, you may be better served by incorporating a "non-essential" bus that you can turn off in the event of an alternator failure and put everything you consider essential on the main bus. Good luck with your project! Trevor ________________________________________________________________________________
Date: Apr 09, 2004
Subject: What display?
I've got a Garmin GPS Model 35-HVS, which is just the GPS module which sits atop the cabin or wing. It has 12 feet or so of an 8-conductor plus ground cable which feeds . . . what? Anybody know of a display that will accept/display data from this antenna? A Garmin tech support guy said he thought a number of units were compatible, but didn't know of any specific unit. Dick Carden ________________________________________________________________________________
Date: Apr 09, 2004
Subject: Re: What display?
Here's a link to that GPS: http://www.gpscity.com/gps/brados/10131.7.12725572757114954794/oem35hvs.html Beware the long URL (paste the whole thing). The description says that it uses an RS232 (serial) interface, and NMEA com protocol. To me this says that any of the Palm Pilots with the early style serial port (not USB) should work when connected with a correctly wired plug. Then you could use one of the Palm GPS programs to control the box. Other computers that have serial ports could easily be made to work as well (including IPAQ's, etc). Link to Palm GPS Software: http://www.gpsinformation.org/dale/Palm/pilotgps.htm#soft Regards, Matt- N34RD > > > I've got a Garmin GPS Model 35-HVS, which is just the GPS module which > sits atop the cabin or wing. It has 12 feet or so of an 8-conductor plus > ground cable which feeds . . . what? Anybody know of a display that will > accept/display data from this antenna? A Garmin tech support guy said he > thought a number of units were compatible, but didn't know of any > specific unit. > Dick Carden > > ________________________________________________________________________________
Date: Apr 09, 2004
The GPS 35 is the unit Control Vision is/was selling to feed their Anywhere Map software running on a PDA (Ipaq & others). The "HVS" is one of several variants. I don't know which flavor CV uses but it plugs into an adapter box that provides a cig. lighter plug and power/serial cable to the PDA. I looked at buying one from a generic source but couldn't easily decipher the variants and the small price difference wasn't worth the effort. I already had the adapter box but then decided to spend a few extra bucks and got their new version that has the power plug and PDA cable built in. It eliminates some cables and makes a much neater installation. IMHO it was worth the extra cost. BTW, it's an excellent receiver. Good luck. Regards, Greg Young - Houston (DWH) RV-6 N6GY ...project Phoenix Navion N5221K - just an XXL RV-6A > --> > > I've got a Garmin GPS Model 35-HVS, which is just the GPS > module which sits atop the cabin or wing. It has 12 feet or > so of an 8-conductor plus ground cable which feeds . . . > what? Anybody know of a display that will accept/display data > from this antenna? A Garmin tech support guy said he thought > a number of units were compatible, but didn't know of any > specific unit. Dick Carden > ________________________________________________________________________________
Date: Apr 09, 2004
I realize the odds are very remote but, the E-buss is a common > failure point. Just curious, would you care to elaborate about this. Why would the E-buss be any more prone to failure than the main buss for instance. And what would be the failure mode? Blown fuse, failed switch or circuit breaker, etc.? Cliff ----- Original Message ----- From: <Greg.Puckett(at)united.com> Subject: AeroElectric-List: Re: attitude indicator on E-Buss or Main Buss?? > > >you wrote: > > >Would it also be a good idea not to put the attitude indicator and turn > coordinator > >on the same fuse=3F=3F - I would think one would want both on the > e-buss=3F=3F > > >I'd like NOT to have another switch - how can I avoid one for the > attitude indicator. > > >I'm of the understanding that I ask myself "is it essential for the > completion > >of the flight" if so I put it on the e-buss. Well then I would think > instrument > >lights, radios, gps, electric booster pump, attitude indicator, would > all go > >on the e-buss - am I right here=3F=3F > > There are, of course, many opinions on how "essential" equipment should > be powered. Personally, I'm not a big fan of putting everything I deem > "essential" on the same buss, fuse, switch ... I would never want > equipment I've already deemed essential to share any common failure > point. > > IMHO, do NOT even consider putting the two of the best pieces of > equipment you have for keeping the greasy side down on the same fuse. I > would not even put them on the same buss. The idea is to keep any single > failure from causing you to loose items that have no backup for and that > the loss of will cause you to "break a sweat" getting back on the ground > safely. I realize the odds are very remote but, the E-buss is a common > failure point. Maybe our working definition of "essential" needs to be > clarified. If I've deemed a piece of equipment essential for safe flight > in the planned scenario, it must have a backup. That backup should not > share any recourses with the equipment it is backing up. So, both pieces > are not essential. One OR the other is essential. > > > Greg > > ________________________________________________________________________________
Date: Apr 09, 2004
From: Hal / Carol Kempthorne <kempthornes(at)earthlink.net>
At 05:15 PM 4/9/2004, you wrote: > >The description says that it uses an RS232 (serial) interface, and NMEA >com protocol. To me this says that any of the Palm Pilots with the early >style serial port (not USB) should work when connected with a correctly >wired plug. Be careful here. RS232 is an electrical standard - each pin has a very specific function and parameters. 'Serial port' or 'serial interface' may mean RS232 but unless it guarantees adherence to that standard, it may not match at all. Think of a serial interface as bits in single file as opposed to parallel interface in which the bits are side by side. Mind, I'm not saying these things won't work together only that you need to tread with knowledge that they haven't always. Mfrs are much better than they were back when Hewlett Packard used a DB25 so-called serial interface to burn out my friend's Compaq computer. Okay, it was about 20 years ago. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Apr 10, 2004
Main Buss?? I read this as "if the e-bus fails, several things go down with it" not that it fails often. Mickey At 05:24 10-04-04, flyv35b wrote: -----Start of Original Message----- > >I realize the odds are very remote but, the E-buss is a common >> failure point. > >Just curious, would you care to elaborate about this. Why would the E-buss >be any more prone to failure than the main buss for instance. And what >would be the failure mode? Blown fuse, failed switch or circuit breaker, >etc.? -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Apr 10, 2004
Buss?? Well, if the E-bus is implemented as per Bob Nuckolls' recommendations, it should be very reliable. It will have two independent power feeds to it, and each of those feeds can be tested before each flight. The bus itself will be a fuseblock, with the live portions enclosed in plastic. So it would take some major high energy event to short the bus to ground (i.e. a crash, etc). So I wouldn't be too concerned about the E-bus providing a common-mode failure for various items. However, there might be one good reason to power an attitude indicator or TC from a battery-hot bus. Think about what your emergency procedure will be if you ever have a smoke in the cockpit event. If the source of smoke is electrical, it might be nice to be able to kill power to everything but the attitude indicator or TC. My TC is powered by a battery-hot bus. My Dynon EFIS (i.e. attitude indicator) has an internal battery. If I get smoke in the cockpit I'll kill power to the main and essential busses, pull out my handheld GPS and head for an airfield. Kevin Horton > > >I read this as "if the e-bus fails, several things go >down with it" not that it fails often. > >Mickey > >At 05:24 10-04-04, flyv35b wrote: >-----Start of Original Message----- >> >> >>I realize the odds are very remote but, the E-buss is a common >>> failure point. >> >>Just curious, would you care to elaborate about this. Why would the E-buss >>be any more prone to failure than the main buss for instance. And what >>would be the failure mode? Blown fuse, failed switch or circuit breaker, >>etc.? > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > ________________________________________________________________________________
Date: Apr 10, 2004
Subject: Ground wire for taillight bulb
Basic question. I am trying to attach a 20 ga ground wire to a single contact 12 volt light bulb socket. The power wire comes out of the end of a Neoprene cover that comes with the socket. See http://www.motormitedormancatalog.com/buyerbrowse.epc%3Freset%3DALL%26backgrdimg%3Dbackgrdimg_lighting.jpg%26category1%3DLIGHTING%26categories%3DLIGHTING The socket will be epoxed into a 7/8 diam steel tube brazed onto the trailing edge of the tailfin for a taillight. How do I attach a ground wire to the bulb socket? Someone said to solder it to the end of the socket somehow but he was kinda vague on the procedure and I lack the necessary experience to make this work... TIA, Eric Schlanser --------------------------------- ________________________________________________________________________________
Date: Apr 10, 2004
Subject: Backup devices - TC vs. attitude gyro
Is there any reason to choose a TC over an attitude gyro as a backup device to, say, a glass panel display? OTHER than cost, which is obvious? I know the TC is considered sufficient for IFR, and I know it's cheaper, but I was wondering if there might actually be a preference for it, rather than just an option. Regards, Chad ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Apr 10, 2004
I disagree that the e-buss in a common failure point. It has a backup source of power! That is twice as good as the old way of wiring. I think the E-buss can be expected to be about as dependable as the battery buss and the switch that activates the e-buss which is about as good as the battery and the wiring. Everything has potential for failure so we cannot eliminate failure. We live with risk but manage it. I like having a secondary way of powering the things on the e-buss. If you still do not feel comfortable, look for more backup in something like a second battery and/or second alternator. Indiana Larry, RV7 TipUp TMX-O-360 ACS2002 Dynon CNS430 Digitrak JeffRose Flightline Interiors Firewall Forward, Wiring w/Nuckoll's Knowledge ----- Original Message ----- From: "Mickey Coggins" <mick-matronics(at)rv8.ch> Subject: Re: AeroElectric-List: Re: attitude indicator on E-Buss or Main Buss?? > > I read this as "if the e-bus fails, several things go > down with it" not that it fails often. > > Mickey > > At 05:24 10-04-04, flyv35b wrote: > -----Start of Original Message----- > > > >I realize the odds are very remote but, the E-buss is a common > >> failure point. > > > >Just curious, would you care to elaborate about this. Why would the E-buss > >be any more prone to failure than the main buss for instance. And what > >would be the failure mode? Blown fuse, failed switch or circuit breaker, > >etc.? > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Apr 10, 2004
Subject: Re: Backup devices - TC vs. attitude gyro
At 10:27 AM 4/10/2004, you wrote: > >Is there any reason to choose a TC over an attitude gyro as a backup device >to, say, a glass panel display? My panel has a Dynon EFIS with a TC as backup. It would have an electric attitude indicator (as seen in certified setups) but money is the issue. Furthermore, the TC or AI might fail before the EFIS! Needle ball airspeed proficiency is always required of course. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Date: Apr 10, 2004
Jeff/Mickey - thanks I have it now. Clearing the cache was the trick. Thanks, Steve. --- ________________________________________________________________________________
Date: Apr 10, 2004
Main Buss?? I agree, and I don't believe anyone was saying that the e-bus is not reliable. Smoke in the cockpit is the only scenario I can see where one would need to turn it off. Somewhat related question - batteries in the back, which means battery contactors in the back. If you want to have a battery bus, doesn't this mean you have to run a long wire up to the panel that can't be shut off? Doesn't this cause problems with shorting in the event of an off field landing? Mickey At 20:03 10-04-04, LarryRobertHelming wrote: -----Start of Original Message----- > >I disagree that the e-buss in a common failure point. It has a backup >source of power! That is twice as good as the old way of wiring. I think >the E-buss can be expected to be about as dependable as the battery buss and >the switch that activates the e-buss which is about as good as the battery >and the wiring. Everything has potential for failure so we cannot eliminate >failure. We live with risk but manage it. I like having a secondary way of >powering the things on the e-buss. If you still do not feel comfortable, >look for more backup in something like a second battery and/or second >alternator. > >Indiana Larry, RV7 TipUp >TMX-O-360 ACS2002 Dynon CNS430 Digitrak >JeffRose Flightline Interiors >Firewall Forward, Wiring w/Nuckoll's Knowledge > > >----- Original Message ----- >From: "Mickey Coggins" <mick-matronics(at)rv8.ch> >To: >Subject: Re: AeroElectric-List: Re: attitude indicator on E-Buss or Main >Buss?? > > > >> >> I read this as "if the e-bus fails, several things go >> down with it" not that it fails often. >> >> Mickey >> >> At 05:24 10-04-04, flyv35b wrote: >> -----Start of Original Message----- > >> > >> >I realize the odds are very remote but, the E-buss is a common >> >> failure point. >> > >> >Just curious, would you care to elaborate about this. Why would the >E-buss >> >be any more prone to failure than the main buss for instance. And what >> >would be the failure mode? Blown fuse, failed switch or circuit breaker, >> >etc.? -----End of Original Message----- -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Apr 10, 2004
Main Buss?? > > >Somewhat related question - batteries in >the back, which means battery contactors >in the back. If you want to have a battery bus, >doesn't this mean you have to run a long wire >up to the panel that can't be shut off? Doesn't >this cause problems with shorting in the event >of an off field landing? I've put a six slot fuse block beside the battery for my battery bus. So if a wire to the front shorts out, it will blow the fuse. Yes, there may be a tiny spark where the short occurs, for a moment. But this would likely happen during the crash itself, and probably any leaking fuel would not have had time to get there first. -- Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Apr 10, 2004
> > Is there any reason to choose a TC over an attitude gyro as a > backup device > to, say, a glass panel display? OTHER than cost, which is > obvious? I know the > TC is considered sufficient for IFR, and I know it's cheaper, > but I was > wondering if there might actually be a preference for it, > rather than just an > option. > > Regards, > Chad TC's or T&B's can't tumble. Alex Peterson Maple Grove, MN RV6-A N66AP 454 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 10, 2004
Cliff, I did not mean to imply that the E buss is more likely to fail. It was that when it does you would loose a particular instrument AND that instruments backup. The E-buss should be less likely to fail due to it having more than one feed. Other than something coming in contact with the Buss itself, there are not very many "buss faults" that would take the buss out. In general, I would not be concerned too much about them if they are well protected from mechanical interference like they would be if you are using the fuseblocks with boots on the posts. If the buss itself is a copper bar screwed to a row of breakers, say running along the bottom of the panel, it's not to hard to imagine scenarios where something could come into contact with them. Greg Puckett Elizabeth, CO RV-8 80081 (slooooow build) > > >I realize the odds are very remote but, the E-buss is a common >> failure point. >Just curious, would you care to elaborate about this. Why would the E-buss >be any more prone to failure than the main buss for instance. And what >would be the failure mode? Blown fuse, failed switch or circuit breaker, >etc.? >Cliff ----- Original Message ----- >From: <Greg.Puckett(at)united.com replyto=200404100226.i3A2QsU23546@ma tronics.com> > >To: > >Subject: Re: attitude indicator on E-Buss or Main Buss?? replyto=200404100226.i3A2QsU23546@ma tronics.com> > > >you wrote: > > >Would it also be a good idea not to put the attitude indicator and turn > coordinator > >on the same fuse=3F=3F - I would think one would want both on the > e-buss=3F=3F > > >I'd like NOT to have another switch - how can I avoid one for the > attitude indicator. > > >I'm of the understanding that I ask myself "is it essential for the > completion > >of the flight" if so I put it on the e-buss. Well then I would think > instrument > >lights, radios, gps, electric booster pump, attitude indicator, would > all go > >on the e-buss - am I right here=3F=3F > > There are, of course, many opinions on how "essential" equipment should > be powered. Personally, I'm not a big fan of putting everything I deem > "essential" on the same buss, fuse, switch ... I would never want > equipment I've already deemed essential to share any common failure > point. > > IMHO, do NOT even consider putting the two of the best pieces of > equipment you have for keeping the greasy side down on the same fuse. I > would not even put them on the same buss. The idea is to keep any single > failure from causing you to loose items that have no backup for and that > the loss of will cause you to "break a sweat" getting back on the ground > safely. I realize the odds are very remote but, the E-buss is a common > failure point. Maybe our working definition of "essential" needs to be > clarified. If I've deemed a piece of equipment essential for safe flight > in the planned scenario, it must have a backup. That backup should not > share any recourses with the equipment it is backing up. So, both pieces > are not essential. One OR the other is essential. > > > Greg > > ________________________________________________________________________________
Date: Apr 10, 2004
In a message dated 4/10/04 12:29:31 PM Central Daylight Time, crobinson(at)rfgonline.com writes: TC is considered sufficient for IFR, and I know it's cheaper, but I was wondering if there might actually be a preference for it, rather than just an option. Regards, Chad Good Afternoon Chad, For What It Is Worth. For many varied reasons, I much prefer a Classic Turn And Bank rather than the more modern Turn Coordinator. In any case, I would consider a TC to be my second choice of a last ditch instrument. Both the T&B and the TC are cheaper, lighter and more reliable than an attitude indicator. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
From: "Werner Schneider" <wernerschneider(at)compuserve.com>
Date: Apr 11, 2004
Hello Chad, have a look at the new TC from trutrak, might be a good option? http://www.trutrakflightsystems.com/index.html and is affordable. Werner ----- Original Message ----- From: "Chad Robinson" <crobinson(at)rfgonline.com> Subject: AeroElectric-List: Backup devices - TC vs. attitude gyro > > Is there any reason to choose a TC over an attitude gyro as a backup device > to, say, a glass panel display? OTHER than cost, which is obvious? I know the > TC is considered sufficient for IFR, and I know it's cheaper, but I was > wondering if there might actually be a preference for it, rather than just an > option. > > Regards, > Chad > > ________________________________________________________________________________
Date: Apr 11, 2004
Hello Greg, for this reason I have: a AI on the main bus a Dynon EFIS on the e-bus a internal battery in the Dynon (good for 2 h) So even with power switched of on both busses I would be fine for attitude, altitude, speed and magnetic referenze. However, you have to live up to your worst case scenario and design your system accordingly. Werner ----- Original Message ----- From: "Greg Puckett" <rv8er(at)myawai.com> Subject: AeroElectric-List: Re: attitude indicator on E-Buss or Main Buss?? > > > Cliff, > > I did not mean to imply that the E buss is more likely to fail. It was > that when it does you would loose a particular instrument AND that > instruments backup. The E-buss should be less likely to fail due to it > having more than one feed. > > Other than something coming in contact with the Buss itself, there are > not very many "buss faults" that would take the buss out. In general, I > would not be concerned too much about them if they are well protected > from mechanical interference like they would be if you are using the > fuseblocks with boots on the posts. If the buss itself is a copper bar > screwed to a row of breakers, say running along the bottom of the panel, > it's not to hard to imagine scenarios where something could come into > contact with them. > > Greg Puckett > Elizabeth, CO > RV-8 80081 (slooooow build) > > > cator%20on%20E-Buss%20or%20Main%20Buss??&replyto=200404100226.i3A2QsU235 > 46(at)matronics.com> > > > > >I realize the odds are very remote but, the E-buss is a common > >> failure point. > > >Just curious, would you care to elaborate about this. Why would the > E-buss > >be any more prone to failure than the main buss for instance. And what > >would be the failure mode? Blown fuse, failed switch or circuit > breaker, > >etc.? > > >Cliff > ----- Original Message ----- > >From: <Greg.Puckett(at)united.com > %20on%20E-Buss%20or%20Main%20Buss??&replyto=200404100226.i3A2QsU23546@ma > tronics.com> > > >To: ndicator%20on%20E-Buss%20or%20Main%20Buss??&replyto=200404100226.i3A2QsU > 23546(at)matronics.com> > > >Subject: Re: attitude indicator on E-Buss or Main Buss?? > > > %20on%20E-Buss%20or%20Main%20Buss??&replyto=200404100226.i3A2QsU23546@ma > tronics.com> > > > > >you wrote: > > > > >Would it also be a good idea not to put the attitude indicator and > turn > > coordinator > > >on the same fuse=3F=3F - I would think one would want both on the > > e-buss=3F=3F > > > > >I'd like NOT to have another switch - how can I avoid one for the > > attitude indicator. > > > > >I'm of the understanding that I ask myself "is it essential for the > > completion > > >of the flight" if so I put it on the e-buss. Well then I would > think > > instrument > > >lights, radios, gps, electric booster pump, attitude indicator, would > > all go > > >on the e-buss - am I right here=3F=3F > > > > There are, of course, many opinions on how "essential" equipment > should > > be powered. Personally, I'm not a big fan of putting everything I deem > > "essential" on the same buss, fuse, switch ... I would never want > > equipment I've already deemed essential to share any common failure > > point. > > > > IMHO, do NOT even consider putting the two of the best pieces of > > equipment you have for keeping the greasy side down on the same fuse. > I > > would not even put them on the same buss. The idea is to keep any > single > > failure from causing you to loose items that have no backup for and > that > > the loss of will cause you to "break a sweat" getting back on the > ground > > safely. I realize the odds are very remote but, the E-buss is a common > > failure point. Maybe our working definition of "essential" needs to be > > clarified. If I've deemed a piece of equipment essential for safe > flight > > in the planned scenario, it must have a backup. That backup should not > > share any recourses with the equipment it is backing up. So, both > pieces > > are not essential. One OR the other is essential. > > > > > > Greg > > > > > > ________________________________________________________________________________
Date: Apr 11, 2004
Main Buss?? Mickey, I've got a rear battery and I placed my battery fuse block (aka bus) in the rear, near the battery. I mounted it to a 3/16" thick Delrin sheet mounted between the right side F-888 and F-889 longerons. I've got photos for anyone interested. Charlie Kuss RV-8A wiring Boca Raton, Fl. > >I agree, and I don't believe anyone was saying >that the e-bus is not reliable. > >Smoke in the cockpit is the only scenario I >can see where one would need to turn it off. > >Somewhat related question - batteries in >the back, which means battery contactors >in the back. If you want to have a battery bus, >doesn't this mean you have to run a long wire >up to the panel that can't be shut off? Doesn't >this cause problems with shorting in the event >of an off field landing? > >Mickey > >At 20:03 10-04-04, LarryRobertHelming wrote: >-----Start of Original Message----- >> >>I disagree that the e-buss in a common failure point. It has a backup >>source of power! That is twice as good as the old way of wiring. I think >>the E-buss can be expected to be about as dependable as the battery buss and >>the switch that activates the e-buss which is about as good as the battery >>and the wiring. Everything has potential for failure so we cannot eliminate >>failure. We live with risk but manage it. I like having a secondary way of >>powering the things on the e-buss. If you still do not feel comfortable, >>look for more backup in something like a second battery and/or second >>alternator. >> >>Indiana Larry, RV7 TipUp >>TMX-O-360 ACS2002 Dynon CNS430 Digitrak >>JeffRose Flightline Interiors >>Firewall Forward, Wiring w/Nuckoll's Knowledge >> >> >>----- Original Message ----- >>From: "Mickey Coggins" <mick-matronics(at)rv8.ch> >>To: >>Subject: Re: AeroElectric-List: Re: attitude indicator on E-Buss or Main >>Buss?? >> >> >> >>> >>> I read this as "if the e-bus fails, several things go >>> down with it" not that it fails often. >>> >>> Mickey >>> >>> At 05:24 10-04-04, flyv35b wrote: >>> -----Start of Original Message----- >> >>> > >>> >I realize the odds are very remote but, the E-buss is a common >>> >> failure point. >>> > >>> >Just curious, would you care to elaborate about this. Why would the >>E-buss >>> >be any more prone to failure than the main buss for instance. And what >>> >would be the failure mode? Blown fuse, failed switch or circuit breaker, >>> >etc.? >-----End of Original Message----- > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Apr 11, 2004
Hi Bob, and Chad-- Another FWIW. I know that all of us who are instrument rated have had to learn and demonstrate that we can keep the airplane right side up using only the T&B, airspeed and altimeter. And Lindberg flew all the way to Paris in a lot of IMC with no more than that. But-- a lot of pretty good pilots have lost the airplane in the confusion and transition when the AI quit. In my humble opinion, nothing beats a standby AI on the e-bus or battery bus. Really ole Jim ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: AeroElectric-List: Backup devices - TC vs. attitude gyro > > In a message dated 4/10/04 12:29:31 PM Central Daylight Time, > crobinson(at)rfgonline.com writes: > TC is considered sufficient for IFR, and I know it's cheaper, but I was > wondering if there might actually be a preference for it, rather than just an > option. > > Regards, > Chad > > > Good Afternoon Chad, > > For What It Is Worth. > > For many varied reasons, I much prefer a Classic Turn And Bank > rather than the more modern Turn Coordinator. > > In any case, I would consider a TC to be my second choice of a > last ditch instrument. Both the T&B and the TC are cheaper, lighter > and more reliable than an attitude indicator. > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Airpark LL22 > Downers Grove, IL 60516 > 630 985-8502 > > ________________________________________________________________________________
Date: Apr 11, 2004
In a message dated 4/11/04 2:57:24 PM Central Daylight Time, jimk36(at)comcast.net writes: I know that all of us who are instrument rated have had to learn and demonstrate that we can keep the airplane right side up using only the T&B, airspeed and altimeter. And Lindberg flew all the way to Paris in a lot of IMC with no more than that. But-- a lot of pretty good pilots have lost the airplane in the confusion and transition when the AI quit. In my humble opinion, nothing beats a standby AI on the e-bus or battery bus. Really ole Jim Good Afternoon Really ole Jim, My concern with using an attitude gyro as a back up has to do with the confusion that can arise as to which instrument is really working and what it is saying. It is my totally unproven theory that many of the accidents that have occurred have happened because there was too much for the pilot to look at and that confusion then prevailed. If you have two horizons and one gets lazy, how do you decide which one is working? The only way I know how do that is to look at a performance or rate instrument to see if the deviation is supported by those instruments. The air carriers all use a third attitude gyro theses days and no longer have any rate of turn instrumentation at all. However, they have two pilots and there is a a capability of at least comparing three attitude gyros. With three instruments to observe and two pilots to make an evaluation, it isn't real difficult to decide which instrument is telling the truth. If all you have is two attitude gyros, a vote has to be taken. Since most of we GA pilots will only have two attitude instruments, not three, we have to use supporting instrumentation to determine which one has failed. Since we are going to use that supporting information as our check on the attitude gyro, why not just use it to start with. My preference for using a T&B in lieu of a TC has to do with emphasis in our (read my) feeble brain. When things are going to a bad place in a handbasket, the less I have to think about the better. The main thing is to make sure the airplane is not turning. If it does not turn, you will survive. A turn needle doesn't look anything at all like anything else on the instrument panel. It doesn't tell you about a roll or pitch change. All it tells you is whether or not the aircraft is turning. Once again, stop the turn and you will survive. The rest is a piece of cake. Failure modes of the TC and T&B are pretty easy to recognize. They don't get lazy and fall to the side. They just quit working! I have two T&Bs on my panel. One is airdriven, the other is electric. I try to include at least one of them in every scan of the panel. I tell myself that I really need to know what the rate of turn is even though I realize that we have not done timed turns for the last half century. It forces me to look at my rate instrument all of the time. Hopefully, that will help me catch it, if it ever fails. Voting between the two of them is simple. The one that is wiggling is working! A standby attitude instrument on another panel is, in my not so humble opinion, worthless unless it is accompanied by a full set of instruments so that one can fly the aircraft entirely by utilizing that other panel. Cross the cockpit flying is not all that hard as long as you don't try to switch back and forth. I rather think that was what led to the demise of the Carnahans. He flew that airplane for quite sometime following his first report of difficulty. It appears that he did have quite a few options left when he finally lost it. Isn't it possible that if he had just gone to his needle ball and airspeed he may well have made it comfortably to Jefferson City? The idea is to get it to a point where even the dumbest of us can handle the situation with what we have left. In that vein, I like the idea of keeping it as simple as possible. You can recover from a spin with a T&B if you just have confidence in what it is telling you. Jump around and keep changing your mind and you won't have a chance I think Jim Younkin's TC has a lot of things going for it. I would like it even better if it didn't look so much like an attitude gyro! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Subject: Whelen strobe
Date: Apr 11, 2004
I'm thinking of putting the Whelen stobe power supply under the baggage compartment floor in my RV7A and am concerned if there would be enough cooling air there for it. There would be about 1/2" spacing below it between the exterior skin and about 1/2 " above it between the baggage floor. There are not a lot of air holes around the floor ribs in this area, so air fow is somewhat limited. It is the Whelen model HDACF. Thanks Larry RV7A, fuselage ________________________________________________________________________________
Subject: T & B vs AI
Date: Apr 11, 2004
Bob-- Point well taken. In my C33A I have the vacuum driven AI, an electric driven backup AI, and a vacuum T & B, all in close proximity on the primary panel. In the all-electric plane I'm building [read that as trying to build], I'll re-think the value of a backup electric AI. Jim ________________________________________________________________________________
Subject: "Pictorial Turn Indicator"
Date: Apr 12, 2004
http://www.trutrakflightsystems.com/index.html "Pictorial Turn Coordinator This display is like a horizon in roll and actually moves in unison with the horizon. This makes the transition from viewing the horizon much easier than the reverse display of a standard turn coordinator. For much greater life and reliability it uses a solid state gyro instead of a spinning disc. " A quick reading of the above, plus a picture of what seems to be a horizon AND a ball at the bottom tells me it is not what we used to call an Artificial Horizon. Pilots will be tempted to interpret it as just that and not realise it's not showing pitch. So, - as a cloud guidance device - it fails to provide 'unusual position' information when the aircraft is out of control. That is, it masks the lack - and I wouldn't trust it. A Turn and Bank gauge is far more useful in a pinch. Otherwise it's fine for those who believe it's there to co-ordinate rate one turns a la airline. IMHO of course. Old Bob? Ferg ________________________________________________________________________________
Date: Apr 12, 2004
Hi All- I was trying to avoid this, but I can't resist any longer. If your not interested in my ramblings on this subject, plz delete now. While I agree with Bob that a T&B is really a superior instrument to a TC (due to it's relative stability in turbulence), neither hold a candle to an AH. While Lindberg's feat was truly remarkable, it was done with the latest technology at the time and without ATC, radios, concerns over traffic or obstacles, or trouble shooting electrical systems. As much as I love radials and fabric, technology has advanced some since then. Here's the big rub: When learning partial panel (PP), the instructor typically covers up the AH and the student has to control the aircraft with the supporting instruments. Not really a big deal, and kinda fun once they get comfortable. As Bob mentioned, spin recoveries are doable and even practiced in some curricula, at least before certain reg changes. So far, so good. Now our intrepid aviator is out in some nice smooth stratus, or over water in VMC but under an overcast. Not particularly challenging at all. Now the AH croaks. Does it do something dramatic, like flip over (TU) and lay there? Nope, it's much more subtle. It starts to wind down. As it winds down, it becomes less stable and starts to precess. I.E., it starts a slow wobble, kind of a slow, low amplitude lazy eight looking manuever that gets more pronounced over the course of minutes. What happens? Since our intrepid aviator's scan centers on the AH, he looks at it most frequently. He sees an entirely reasonable, slight attitude error, say a slight climb in a right bank, which he corrects. Hmm, the supporting instruments show a descending left turn now. If he gets confused, he gets stressed. Tunnel vision. It gets worse. If he focusses on the AH, or switches back and forth between the AH and supporting instruments, Spatial Disorientation (SD) sets in and the radar track shows a fairly short series of divergent left / right turns and climbs / descents before the impact. If our intrepid aviator has the discipline to ignore the AH, all is well. The problem is that your scan is reflexive, as is the initial response to what you see on the panel. In training you saw the cover the instructor put ove the AH. In real life, you see an AH telling you to correct your attitude, NOW. It can cause a very powerfull effect (you may wonder how I know this...) The cheapest aid and insurance to the PP pilot is some sort of suction cup stickie thing, like your instructor used to cover the AH during your training. Slapping it over the failed instrument is the simplest, surest protection against succumbing to false cues. Now you are PP in the clouds for real. Not the end of the world but a significant increase in workload under IMC, unless of course you practice regularly (yeah, right...). This higher workload, higher stress situation will also increase the odds of SD, especially if it's bumpy. This is somewhat less than ideal. A second attitude indicator in what would normally be the T&B / TC hole would simplify this situation tremendously. IIRC, a good electric AH goes for about $2,500 bucks. There are surely less expensive gyros available, but if one were willing to part with $3,500 one could plug a BMA EFIS / Lite (or it's equivalent) into a somewhat larger hole and have a whole suite of instruments in one box that would require a very easy and compact scan. While I appreciate that this is not the most inexpensive way to go, flying IFR has never been cheap. Thanks to the recent advances in technology, flying IFR has never been safer... If one avails themselves of that technology AND practices. BTW, recent statistics have shown that SD accidents have shifted away from non-instrument rated private pilots and towards non-current instrument commercial pilots. Food for thought for those with tickets but no practice! Just one guy's opinions FWIW YMMV Nomex on Duck, tuck and roll gm ________________________________________________________________________________
Date: Apr 12, 2004
Subject: Re: "Pictorial Turn Indicator"
In a message dated 4/12/04 8:48:23 AM Central Daylight Time, VE3LVO(at)rac.ca writes: A quick reading of the above, plus a picture of what seems to be a horizon AND a ball at the bottom tells me it is not what we used to call an Artificial Horizon. Pilots will be tempted to interpret it as just that and not realise it's not showing pitch. So, - as a cloud guidance device - it fails to provide 'unusual position' information when the aircraft is out of control. That is, it masks the lack - and I wouldn't trust it. A Turn and Bank gauge is far more useful in a pinch. Otherwise it's fine for those who believe it's there to co-ordinate rate one turns a la airline. IMHO of course. Old Bob? Ferg Good Morning Ferg, My sentiments precisely. I would like to know just what it does respond to. If it responds to both roll and yaw, I guess making it look like a Turn Coordinator is the correct thing to do. If it shows only yaw, (As does the Garmin 196 and 296, more later) I would love to see the presentation be an electronic needle! I really don't like the idea of it looking like an attitude gyro at all. Too much chance of a misinterpretation. As an aside, the Garmin 196 and 296 have a nice standby panel available that does work quite well. It can only discern a turn and, therefore, yaw, but they have gone and used a picture of a Turn Coordinator to represent that yaw! I believe that is a major mistake in the design. The unit would be much more usable if the presentation was a needle rather than a little airplane signal. It is giving us the information we need, but in the wrong format. The best thing about a Turn Coordinator is that it does give an early indication that a yaw may develop soon. It does that by showing the roll that, in most cases, precedes the yaw. That works very well for a sensor for a low cost autopilot. Unfortunately, that mixed information is difficult for many of our feeble brains to sort out. The Garmin units show only yaw, but indicate the same as a TC. Very Bad Idea. Anybody know just what Jim's unit is really showing? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 12, 2004
Good response Glen, Also the use of an auto pilot (like the new Trio) with it's own gyro might be the best compromise yet.... my 2 cents, -Dale ----- Original Message ----- From: "Glen Matejcek" <aerobubba(at)earthlink.net> Subject: AeroElectric-List: Backup devices - TC vs. attitude gyro > > Hi All- > > I was trying to avoid this, but I can't resist any longer. If your not > interested in my ramblings on this subject, plz delete now. > > While I agree with Bob that a T&B is really a superior instrument to a TC > (due to it's relative stability in turbulence), neither hold a candle to an > AH. While Lindberg's feat was truly remarkable, it was done with the > latest technology at the time and without ATC, radios, concerns over > traffic or obstacles, or trouble shooting electrical systems. As much as I > love radials and fabric, technology has advanced some since then. > > Here's the big rub: When learning partial panel (PP), the instructor > typically covers up the AH and the student has to control the aircraft with > the supporting instruments. Not really a big deal, and kinda fun once they > get comfortable. As Bob mentioned, spin recoveries are doable and even > practiced in some curricula, at least before certain reg changes. > > So far, so good. Now our intrepid aviator is out in some nice smooth > stratus, or over water in VMC but under an overcast. Not particularly > challenging at all. Now the AH croaks. Does it do something dramatic, > like flip over (TU) and lay there? Nope, it's much more subtle. It starts > to wind down. As it winds down, it becomes less stable and starts to > precess. I.E., it starts a slow wobble, kind of a slow, low amplitude lazy > eight looking manuever that gets more pronounced over the course of > minutes. > > What happens? Since our intrepid aviator's scan centers on the AH, he > looks at it most frequently. He sees an entirely reasonable, slight > attitude error, say a slight climb in a right bank, which he corrects. > Hmm, the supporting instruments show a descending left turn now. If he > gets confused, he gets stressed. Tunnel vision. It gets worse. If he > focusses on the AH, or switches back and forth between the AH and > supporting instruments, Spatial Disorientation (SD) sets in and the radar > track shows a fairly short series of divergent left / right turns and > climbs / descents before the impact. > > If our intrepid aviator has the discipline to ignore the AH, all is well. > The problem is that your scan is reflexive, as is the initial response to > what you see on the panel. In training you saw the cover the instructor > put ove the AH. In real life, you see an AH telling you to correct your > attitude, NOW. It can cause a very powerfull effect (you may wonder how I > know this...) > > The cheapest aid and insurance to the PP pilot is some sort of suction cup > stickie thing, like your instructor used to cover the AH during your > training. Slapping it over the failed instrument is the simplest, surest > protection against succumbing to false cues. > > Now you are PP in the clouds for real. Not the end of the world but a > significant increase in workload under IMC, unless of course you practice > regularly (yeah, right...). This higher workload, higher stress situation > will also increase the odds of SD, especially if it's bumpy. This is > somewhat less than ideal. A second attitude indicator in what would > normally be the T&B / TC hole would simplify this situation tremendously. > > IIRC, a good electric AH goes for about $2,500 bucks. There are surely > less expensive gyros available, but if one were willing to part with $3,500 > one could plug a BMA EFIS / Lite (or it's equivalent) into a somewhat > larger hole and have a whole suite of instruments in one box that would > require a very easy and compact scan. > > While I appreciate that this is not the most inexpensive way to go, flying > IFR has never been cheap. Thanks to the recent advances in technology, > flying IFR has never been safer... If one avails themselves of that > technology AND practices. > > BTW, recent statistics have shown that SD accidents have shifted away from > non-instrument rated private pilots and towards non-current instrument > commercial pilots. Food for thought for those with tickets but no > practice! > > Just one guy's opinions > FWIW > YMMV > Nomex on > Duck, tuck and roll > > gm > > ________________________________________________________________________________
Subject: Re: T & B vs AI
Date: Apr 12, 2004
I have the same instruments as you describe except that I have an all electric S-Tec AP with it's TC in my V35B. But I recently just installed the B&C 20 amp standby alternator system. So that provides all the system redundancy that most light twins have, and more. In addition I am contemplating a split emergency buss with an always hot feed wire off the battery buss through a 15 amp fuse and an internal CB feeding the buss and acting as the switch to energize it with the main buss turned off. The E-Buss would be fed normal from the main through a 25 amp diode. BTW, the B&C system is a beautiful one with a very complete kit and well engineered. I was impressed with it and the installation details. Cliff A&P/IA ----- Original Message ----- From: <jimk36(at)comcast.net> Subject: AeroElectric-List: T & B vs AI > > Bob-- > > Point well taken. In my C33A I have the vacuum driven AI, an electric driven backup AI, and a vacuum T & B, all in close proximity on the primary panel. In the all-electric plane I'm building [read that as trying to build], I'll re-think the value of a backup electric AI. > > Jim > > ________________________________________________________________________________
Date: Apr 12, 2004
In a message dated 4/12/04 9:06:21 AM Central Daylight Time, aerobubba(at)earthlink.net writes: Now you are PP in the clouds for real. Not the end of the world but a significant increase in workload under IMC, unless of course you practice regularly (yeah, right...). This higher workload, higher stress situation will also increase the odds of SD, especially if it's bumpy. This is somewhat less than ideal. A second attitude indicator in what would normally be the T&B / TC hole would simplify this situation tremendously. Good Morning gm, I agree with everything you say right up to the conclusion you arrive at in this paragraph! I strongly agree that you absolutely have to cover up that failed attitude gyro. However, I disagree on what the back up should be. You have just spotted the failed attitude gyro by reference to the performance and rate instruments. Wouldn't it be easiest to continue using those instruments to maintain safe flight? If the T&B is included as a normal, everyday, part of the instrument scan, the loss of the attitude indicator becomes nothing more than an inconvenience. I have done it many times and I am no whiz bang aviator. Just had a lot of experiences. Without covering the failed gyro, it can be almost an impossible task, but once that gyro is covered, it is a piece of cake. However, remember that I qualified this by saying that you really need to include the rate instrument (whether it is a TC or T&B) in your everyday scan so that you are comfortable in that mode when the attitude gyro does abandon you. Changing to a different instrument scan is always difficult. Not impossible, but difficult. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 12, 2004
This has been an interesting discussion, and thanks to everybody who responded. I also got several off-list responses. It seems there are 20 responses and 21 opinions, to quote an old joke. I think in my particular case a 2-axis attitude gyro is still the best option, despite the fact that it can tumble. The reason I want this device is not as a backup to an existing steam or electric gyro. Instead, I want it as a backup to a glass panel, which has a solid state gyro (I suppose I should have said this originally - I meant to). That device is so accurate it's much more likely to be correct or simply gone entirely - it would take a very extreme situation to get it to "precess" the way a spinning mass could if it started to fail. (It's not mechanical.) So, the reason I want the backup instrument is to cover a case of the device simply dying - say the display connector internally goes on the fritz, and the screen goes dark? That sort of thing. This is the same answer the airlines have used. The backup instrument to the glass cockpit display in an Airbus is a traditional attitude indicator. That said, I would agree that if a traditional electric or steam attitude indicator was your primary source of information, a T&B would probably be a better backup than a 2-axis gyro since it can't tumble. Regards, Chad ________________________________________________________________________________
Date: Apr 12, 2004
----- Original Message ----- From: Fergus Kyle <VE3LVO(at)rac.ca> Date: Monday, April 12, 2004 9:44 am Subject: AeroElectric-List: "Pictorial Turn Indicator" Kyle" > > http://www.trutrakflightsystems.com/index.html > > "Pictorial Turn Coordinator > This display is like a horizon in roll and actually moves in unison > with the > horizon. This makes the transition from viewing the horizon much > easier than > the reverse display of a standard turn coordinator. For much > greater life > and reliability it uses a solid state gyro instead of a spinning > disc. " > Wow, these people really like their instruments, don't they? Are the devices that much more useful than the devices that you can get for a few hundred dollars, or is this another one of those instances where an extra zero is added to the price because someone said 'airplane'? ________________________________________________________________________________
Date: Apr 12, 2004
Maybe a pilot who observes the "Pictorial Turn Indicator" perform in a aircraft, and fails to realize it is not displaying Pitch information, shouldn't be flying IFR anyway :) Wally Enga RV7 > > Pilots will be tempted to interpret it as just that and >not realise it's not showing pitch. So, - as a cloud guidance device - it >fails to provide 'unusual position' information when the aircraft is out of >control. That is, it masks the lack - and I wouldn't trust it. A Turn and >Bank gauge is far more useful in a pinch. Otherwise it's fine for those who >believe it's there to co-ordinate rate one turns a la airline. > >IMHO of course. Old Bob? >Ferg > ________________________________________________________________________________
Date: Apr 12, 2004
Not at all. I had a 2-1/4" turn and bank by Kelly Instruments on order for nearly nine months at a price of $850. Virtually the day it arrived at the dealer I ordered it from, the TruTrak Pictorial Turn Coordinator was announced for $395. I decided to go with the TruTrak as a back-up to my Blue Mountain EFIS/one instead of the turn and bank. It's lighter and should be more reliable. Whether it is better or not is still the big question. Terry RV-8A wiring Seattle > > "Pictorial Turn Coordinator > This display is like a horizon in roll and actually moves in unison > with the > horizon. This makes the transition from viewing the horizon much > easier than > the reverse display of a standard turn coordinator. For much > greater life > and reliability it uses a solid state gyro instead of a spinning > disc. " > Wow, these people really like their instruments, don't they? Are the devices that much more useful than the devices that you can get for a few hundred dollars, or is this another one of those instances where an extra zero is added to the price because someone said 'airplane'? ________________________________________________________________________________
Date: Apr 12, 2004
richardriley(at)adelphia.net wrote: > I'm going through the same decision tree. I have the BlueMountain EFIS 1, > a 2 1/4" electric AI, and a miniature turn and slip (electric). > > I'm figuring on putting the Blue Mountain on the E-bus, and leaving the > mechanical ones off. I think the odds of having a major electrical failure > AND having the Blue Mountain go down at the same time are minimal. > > Does that match your thinking? Basically. I'm going to be starting out just doing day VFR so I'll just have the glass panel and separate AI. I would add the T&B or TC if I wanted to do IFR operations. ________________________________________________________________________________
Subject: Copper Clad Aluminum etc.
Date: Apr 12, 2004
The Super-2-CCA is finally for sale (3-4 weeks delivery), the new Website is up, God is in Her heaven, the sheep are in the meadow and all is right with the world. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net Project Management "...of that date and that hour knoweth no man...." --Mark 13:32 ________________________________________________________________________________
Date: Apr 12, 2004
Subject: "Pictorial Turn Indicator" - Welcome to
OZ My guess is that about a half hour after flying with it, you will no longer be expecting to see the horizon move up and down, and you'll integrate it into your instrument scan just fine. Now that we have cheap computers in the cockpit, there may be some HUGE changes in instrumentation coming, which is about time. Most of the instruments we use in aircraft are based on concepts from the 20's and 30's, and it's about time someone gave us a quantum leap forward. Say goodbye to scanning 9 instruments to figure out what your airplane is doing, and take a look at this: Here is a new U.S. patent 6,486,799 that may revolutionize the whole cockpit: <http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,799>http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/\ netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,\ 799 Short synopsis here: http://www.coginst.uwf.edu/projects/oz/ And to find some screen shots, try this Google search: http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=oz+human+centered+cockpit Dave Morris > >Not at all. I had a 2-1/4" turn and bank by Kelly Instruments on order for >nearly nine months at a price of $850. Virtually the day it arrived at the >dealer I ordered it from, the TruTrak Pictorial Turn Coordinator was >announced for $395. I decided to go with the TruTrak as a back-up to my >Blue Mountain EFIS/one instead of the turn and bank. It's lighter and should >be more reliable. Whether it is better or not is still the big question. > >Terry >RV-8A wiring >Seattle > > > > "Pictorial Turn Coordinator > > This display is like a horizon in roll and >actually moves in unison > > with the > > horizon. This makes the transition from viewing >the horizon much > > easier than > > the reverse display of a standard turn >coordinator. For much > > greater life > > and reliability it uses a solid state gyro instead >of a spinning > > disc. " > > > >Wow, these people really like their instruments, >don't they? Are the devices that much more useful >than the devices that you can get for a few hundred >dollars, or is this another one of those instances >where an extra zero is added to the price because >someone said 'airplane'? > > Dave Morris ________________________________________________________________________________
From: "Francis, David CMDR" <David.Francis(at)defence.gov.au>
Subject: SEC: UNCLASSIFIED RE: AeroElectric-List Digest: 7 Msgs
- 04/11/04
Date: Apr 13, 2004
Chad, The main difference between a TC and attitude gyro is not technical or cost, its the skill required to stay safe. A TC and turn and bank have no vertical guidance so the skill required to stay upright is much higher than using a artificial horizon. Considering that the average private pilot flies something like 50 hrs a year, mostly by day, then low skills in limited panel flying is to be expected of most of us. So my IFR RV7 will have two attitude gyros. The price difference is small for the reduced risk that I get in return. Regards, David Francis, VH-ZEE, Canberra, Australia > > Is there any reason to choose a TC over an attitude gyro as a backup device > to, say, a glass panel display? OTHER than cost, which is obvious? I know the > TC is considered sufficient for IFR, and I know it's cheaper, but I was > wondering if there might actually be a preference for it, rather than just an > option. > > Regards, > Chad > > ________________________________________________________________________________
Date: Apr 12, 2004
Now the AH > croaks. > What happens? Since our intrepid aviator's scan centers on > the AH, he looks at it most frequently. He sees an entirely > reasonable, slight attitude error, say a slight climb in a > right bank, which he corrects. > Hmm, the supporting instruments show a descending left turn > now. If he gets confused, he gets stressed. Tunnel vision. > It gets worse. If he focusses on the AH, or switches back > and forth between the AH and supporting instruments, Spatial > Disorientation (SD) sets in and the radar track shows a > fairly short series of divergent left / right turns and > climbs / descents before the impact. > > If our intrepid aviator has the discipline to ignore the AH, > all is well. > The problem is that your scan is reflexive, as is the initial > response to what you see on the panel. In training you saw > the cover the instructor put ove the AH. In real life, you > see an AH telling you to correct your attitude, NOW. It can > cause a very powerfull effect (you may wonder how I know this...) I believe it is necessary to install some sort of indicator to tell you exactly when a gyro croaks. Mine are vacuum driven, and I have a red warning light which illuminates whenever the suction is below about 4.5. Gyro covers are always at hand, and I'm convinced they must be covered in the event of a failure. My aircraft is uniquely equipped to be able to shut off the vacuum to the AH or HSI independantly, and I can tell you that the AH's death is slow, and would be very hard to detect, and more importantly, to accept that it has failed. I'm no psychologist and only an IFR student, but if one knows that an instrument failed before it gives erroneous readings (the vacuum alarm in this example, I know there are other failure modes), it can be covered and cause a minimum of distraction. After all, every IFR pilot has demonstrated partial panel flight and maneuvering. The trouble is the identification of the need and transition to partial panel which gets people. Alex Peterson Maple Grove, MN RV6-A N66AP 455 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Re: SEC: UNCLASSIFIED RE: AeroElectric-List Digest:
7 Msgs - 04/11/04
Date: Apr 12, 2004
So how do you tell which attitude gyro is working? ----- Original Message ----- From: "Francis, David CMDR" <David.Francis(at)defence.gov.au> Subject: AeroElectric-List: SEC: UNCLASSIFIED RE: AeroElectric-List Digest: 7 Msgs - 04/11/04 > > Chad, > The main difference between a TC and attitude gyro is not technical or cost, > its the skill required to stay safe. > > A TC and turn and bank have no vertical guidance so the skill required to > stay upright is much higher than using a artificial horizon. Considering > that the average private pilot flies something like 50 hrs a year, mostly by > day, then low skills in limited panel flying is to be expected of most of > us. > > So my IFR RV7 will have two attitude gyros. The price difference is small > for the reduced risk that I get in return. > > Regards, David Francis, VH-ZEE, Canberra, Australia > > > > > Is there any reason to choose a TC over an attitude gyro as a backup > device > > to, say, a glass panel display? OTHER than cost, which is obvious? I know > the > > TC is considered sufficient for IFR, and I know it's cheaper, but I was > > wondering if there might actually be a preference for it, rather than just > an > > option. > > > > Regards, > > Chad > > > > > > ________________________________________________________________________________
Date: Apr 12, 2004
Subject: Roll your own crowbar OV module
I build my own OV crowbar module and it functions correctly except that it operated in the 10-11 volt range. I triple checked the components and wiring. I tested the 1N4742A diode and it regulates at 12V. I changed the 1.62K ohm resistor specified for a 14 volt system to 6.04K and the circuit operates in the correct voltage range of 15.5-17 volts. Has anyone else found this? ________________________________________________________________________________
Date: Apr 12, 2004
Subject: Magneto Filters
Hi All, Had a visit today from the DAR that is going to do my inspection. In a discussion about hooking up the P-leads he suggested installing magneto filters. Chief aircraft has a couple at $34 and $45. They look to be capacitors. Good idea? Thanks, Don B. ________________________________________________________________________________
Date: Apr 12, 2004
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
> > >Is there any reason to choose a TC over an attitude gyro as a backup device >to, say, a glass panel display? OTHER than cost, which is obvious? I know the >TC is considered sufficient for IFR, and I know it's cheaper, but I was >wondering if there might actually be a preference for it, rather than just an >option. If the price of an attitude gyro isn't driving the decision, why not have a second wing leveler with its own gyros (like TruTrak and others) as the "backup" gyro? For my money, I'd install dual GPS aided wing levelers with redundant power supplies and ditch all the gyros. Cheaper and much more reliable than any scenario that puts the pilot in the loop. Bob . . . ________________________________________________________________________________
Date: Apr 12, 2004
Subject: Re: connectors on AML34
> > >Gentlemen, > >The red fast-on connectors from B&C seem to fit very well on the >Honeywell/Micro Switch AML34 rocker switches, but they are really difficult >to pull off once installed. Is this hardware meant to work together, or >does it just happen to work? Why would you want them to come off easy? Bob . . . ________________________________________________________________________________
Date: Apr 12, 2004
Subject: Re: Magneto Filters
> >Hi All, > >Had a visit today from the DAR that is going to do my inspection. In a >discussion about hooking up the P-leads he suggested installing magneto >filters. Chief aircraft has a couple at $34 and $45. They look to be >capacitors. > >Good idea? Not if you don't need them. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: Voltmeter Scaling Module
> >This is a follow-up to an earlier question to and response from Bob Nuckolls >regarding the Voltmeter/Loadmeter with a Voltmeter Scaling Module ("VSM"), >which was at one time offered by the AeroElectric Connection (Catalog item >VLM-14). The installation instructions at: >http://www.aeroelectric.com/Catalog/AEC/9021/9021704F.pdf ><http://www.aeroelectric.com/Catalog/AEC/9021/9021704F.pdf> >are color coded, and the instructions make it clear that the magenta portion >of the instructions are not applicable to permanent magnet alternators >(although I do not understand why). The magenta text and figures refer to the field-voltage measurement options which are part of the VLM-14 system. This feature works ONLY with an externally regulated alternator that has a field terminal brought out to the back of the alternator. This connection is not present on internally regulated alternators and PM alternators don't even have a field winding so the feature is useless on these machines also. >In our earlier exchange on this subject, Mr. Nuckolls said, "If it [the >alternator] has an internal regulator, then the magenta wiring and magenta >instructions are not applicable to your alternator. I took this comment to >mean that any alternator with an internal regulator could not take advantage >of the auto switching feature. The auto switching feature has nothing to do with alternator style. It takes care of switching the voltmeter function from main bus to e-bus when the main bus is shut down. It works with any combination of alternators. > . . . . or the alternator press-to-test diagnostics >feature of the VSM, without regard for whether the alternator was permanent >magnet or otherwise. Correct. The press to test diagnostic feature is applicable ONLY to alternators with external regulators. Bob . . . ________________________________________________________________________________
Date: Apr 13, 2004
Subject: radio wiring
> > >Bob - I dont know if it is just me but my copy of Adobe insists the file is >damaged and cant open it....................... Steve. Some browser/Acrobat interfaces are flaky if you simply left-click a large .pdf link and wait for it to open in Acrobat. It almost always works to right-click the link and tell your browser to store the file onto your hard drive. After download is complete, THEN use Acrobat to open the file. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: "Pictorial Turn Indicator" - Welcome to OZ
----- Original Message ----- From: Dave Morris <dave(at)davemorris.com> > Say > goodbye to scanning 9 instruments to figure out what your airplane > is > doing, and take a look at this: > > Here is a new U.S. patent 6,486,799 that may revolutionize the > whole cockpit: > > <http://patft.uspto.gov/netacgi/nph- > Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,799>http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/\ > netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,\ > 799 > > Short synopsis here: http://www.coginst.uwf.edu/projects/oz/ > > And to find some screen shots, try this Google search: > http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF- > 8&q=oz+human+centered+cockpit > Dave Morris > Heh, Dave. I'm not trying to rain on your parade, but I wouldn't look to see anything out of this effort for several years. You see, it's being worked on by 'researchers'. They don't get paid to develope products that help people in the real world. They get paid to hype possibilities and play with new technologies in laboratories. If they do the boring work of developing an actual product to sell that will save peoples lives, then they are 'sellouts' to 'commercialism'. No, even though this technology could be on the market in 6 months with the help of a few machine vision engineers, it'll stay in the lab for years as the 'researchers' milk it for all the grant money they can get. I'm not knocking researchers. They're just doing what they do. It's just that they don't develope products, they investigate. For an example of why I feel this way, consider the rotary and diesel engines that have been in 'development' for over a decade. I believe it was Tracey Crook who said that perfect is the enemy of good enough. ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: Copper Clad Aluminum etc.
----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> > The Super-2-CCA is finally for sale (3-4 weeks delivery), the new > Website is > up, God is in Her heaven, the sheep are in the meadow and all is > right with > the world. > I started asking about this, and then never finished up on it. But I still had a few questions. My reservation with the copper clad is in the connector. The problem with aluminum in connectors meant for copper is the different expansion coefficients. Correct? So we clad the aluminum in copper and then clamp down on it. -Will the connector cut through the copper and into the aluminum? -Since the Al still expands and contracts at a different rate, won't the wire eventually deform become loose in the connector? ________________________________________________________________________________
Date: Apr 13, 2004
Subject: A panel full of displays . . .
> > >Chad, >The main difference between a TC and attitude gyro is not technical or cost, >its the skill required to stay safe. > >A TC and turn and bank have no vertical guidance so the skill required to >stay upright is much higher than using a artificial horizon. Considering >that the average private pilot flies something like 50 hrs a year, mostly by >day, then low skills in limited panel flying is to be expected of most of >us. > >So my IFR RV7 will have two attitude gyros. The price difference is small >for the reduced risk that I get in return. At least one of the keep-the-dirty-side-down systems could be a GPS aided wing leveler. Often available for less than the cost of a good gyro, the wing leveler will do a better job than a pilot . . . while interfacing with other nav aids for BOTH stabilization -AND- navigation. I've oft suggested that DUAL wing levelers could replace ALL panel gyros. The major question for dual systems is a means for determining if and which one has failed . . . but that task is no more difficult and/or hazardous than figuring out which gyro display has failed. By the way, gyros can crap WITHOUT dropping the warning flag. However, given the the mechanical and electronic simplicity of modern designs, they are quite reliable compared to a gyro and they offer powerfully attractive opportunities to take the weakest (human) factor out of the equation. Whenever someone cites a list of "redundant", "standby" "emergency", etc. equipment that's being added to the panel, I cannot help but recall the demise of my good friend Terry Chapman. He had one of the most "redundant" airplanes one could ask for. See: http://www.aeroelectric.com/articles/All_Electric/N79NL.pdf For all the $thousands$ tied up in hardware on the panel of that airplane, what he REALLY needed was one killobuck wing leveler that would keep the airplane right-side-up while his adrenalin levels returned to normal. Of course, his was a CERTIFIED airplane and adding an el-cheapy wing leveler to that machine would have cost tons of no-value-added dollars. The most useful redundancy has to be features that DO NOT depend on pilot skill or physical condition for successful implementation. Gyro panel displays DO NOT fall into this category while often having a higher cost of ownership and lower reliability than equipment most likely to save the day when things are going sour. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 13, 2004
> >I started asking about this, and then never finished >up on it. But I still had a few questions. > >My reservation with the copper clad is in the >connector. The problem with aluminum in connectors >meant for copper is the different expansion >coefficients. Correct? So we clad the aluminum in > copper and then clamp down on it. > > >-Will the connector cut through the copper and into >the aluminum? > >-Since the Al still expands and contracts at a >different rate, won't the wire eventually deform >become loose in the connector? The gas-tight crimping technology is not affected by various expansion coefficients. Further, the copper clad aluminum can also be soldered. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: Roll your own crowbar OV module
> >I build my own OV crowbar module and it functions correctly except that >it operated in the 10-11 volt range. I triple checked the components and >wiring. I tested the 1N4742A diode and it regulates at 12V. I changed >the 1.62K ohm resistor specified for a 14 volt system to 6.04K and the >circuit operates in the correct voltage range of 15.5-17 volts. Has >anyone else found this? With the 1.62K resistor in place, adjust the potentiometer to approximately mid range. Adjust the power supply to a point just below the trip point and then measure voltage at (1) + end of capacitor and (2) junction of zener diode and the 392 ohm resistor and tell us what you get. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Subject: Electronic Ignition
Date: Apr 13, 2004
I am trying to decide what to do about electronic ignition. There are several on the market I have found. Are there any schematic's available to build your own. I prefer to use single coil at each cylinder using auto parts and at a later date to be able to expand to a throttle body with injector at each cylinder. My installation is for a 0200 continental on a Q200. Thanks Ron Triano ________________________________________________________________________________
Date: Apr 13, 2004
Buss?? > >would the ELECTRIC attitude indicator go on the e-buss or main? >if on the e-buss and I don't have a switch for it - then if in VFR with >failed alternator - I would not need it yet it would be running and so >draining the battery? Do you have a vacuum system? If not, do you plan to have a second alternator on the vacuum pump pad? Have you done a load analysis on your proposed installed hardware? >How about the electric booster pump - main buss or e-buss?? > >should the comm/gps/transponder all go on the e-buss- they all have >indipendend on/off switches on them - so if not needed, I could shut them off. > >Would it also be a good idea not to put the attitude indicator and turn >coordinator on the same fuse?? - I would think one would want both on >the e-buss?? >I'd like NOT to have another switch - how can I avoid one for the attitude >indicator. > >I'm of the understanding that I ask myself "is it essential for the >completion of the flight" if so I put it on the e-buss. Well then I >would think instrument lights, radios, gps,electric booster pump, attitude >indicator, would all go on the e-buss - am I right here?? Instead of "essential" lets use the word "endurance". Which of the z-figures are you considering? >I'm having troubles located B&C Electrical - the company Bob used to own - >what's their website >thanks I've never owned B&C . . . B&C now has the parts catalog items I used to feature on my website. You can find them at http://www.bandc.biz or 316-283-8000 Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Subject: TC vs,Attitude Gyro
Date: Apr 13, 2004
" If the price of an attitude gyro isn't driving the decision, why not have a second wing leveler with its own gyros (like TruTrak and others) as the "backup" gyro? For my money, I'd install dual GPS aided wing levelers with redundant power supplies and ditch all the gyros. Cheaper and much more reliable than any scenario that puts the pilot in the loop. Bob . . ." Couldn't agree more. On several occasions, the answer has been "let George do it" (for the tyros "george" was the autopilot and 'let george do it' was a wellknown phrase - I forget where). Many DC-9s were equipped with a marvellous A/H which included an OFF flag, sensing the loss of power - so we all sat Fat, Dumb and Happy. Of course that ain't the lone cause of failure. So when the bearings began to go (usually on takeoff after a prolonged layover) it slowly rolled over and the FDaH pilot took the 'plane with it. The rapid answer (while two guys argued) was to apply the A/P and let P3 decide what to do. It gave 30 seconds. Ferg ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: Electronic Ignition
You might look at the following site: http://www.megasquirt.info/ Regards, Matt- N34RD > > > I am trying to decide what to do about electronic ignition. There are > several on the market I have found. Are there any schematic's available > to build your own. I prefer to use single coil at each cylinder using > auto parts and at a later date to be able to expand to a throttle body > with injector at each cylinder. My installation is for a 0200 > continental on a Q200. > > Thanks > > Ron Triano > > ________________________________________________________________________________
Date: Apr 13, 2004
Welcome to OZ Ah, that's the great thing about experimental aviation and computers. Anybody can do whatever the heck he wants to do. I designed and sold artificial intelligence software products for 10 years that the "researchers" said couldn't be done. Microsoft even gave up on it. That's the thing about the "little guy" who is doing something for himself and doesn't have to be constrained by marketability and liability. But I do understand your point. Just one look at the design of current certified aircraft shows just how difficult it is to introduce innovation. Regards, Dave Morris > > >----- Original Message ----- >From: Dave Morris <dave(at)davemorris.com> > > > Say > > goodbye to scanning 9 instruments to figure out >what your airplane > > is > > doing, and take a look at this: > > > > Here is a new U.S. patent 6,486,799 that may >revolutionize the > > whole cockpit: > > > > <http://patft.uspto.gov/netacgi/nph-> >Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,799>http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=/\ > > >netahtml/srchnum.htm&r=1&f=G&l=50&s1=6,486,799.WKU.&OS=PN/6,486,799&RS=PN/6,486,\ > > 799 > > > > Short synopsis here: >http://www.coginst.uwf.edu/projects/oz/ > > > > And to find some screen shots, try this Google search: > > http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF- > > 8&q=oz+human+centered+cockpit > > Dave Morris > > > >Heh, Dave. I'm not trying to rain on your parade, >but I wouldn't look to see anything out of this >effort for several years. You see, it's being >worked on by 'researchers'. They don't get paid to >develope products that help people in the real >world. They get paid to hype possibilities and play >with new technologies in laboratories. If they do >the boring work of developing an actual product to >sell that will save peoples lives, then they are >'sellouts' to 'commercialism'. > >No, even though this technology could be on the >market in 6 months with the help of a few machine >vision engineers, it'll stay in the lab for years as >the 'researchers' milk it for all the grant money >they can get. I'm not knocking researchers. >They're just doing what they do. It's just that >they don't develope products, they investigate. > >For an example of why I feel this way, consider the >rotary and diesel engines that have been in >'development' for over a decade. > >I believe it was Tracey Crook who said that perfect >is the enemy of good enough. > > Dave Morris ________________________________________________________________________________
Date: Apr 13, 2004
----- Original Message ----- From: "Robert L. Nuckolls, III" > > > >-Since the Al still expands and contracts at a > >different rate, won't the wire eventually deform > >become loose in the connector? > > The gas-tight crimping technology is not affected > by various expansion coefficients. Further, the > copper clad aluminum can also be soldered. > > Bob . . . > That, I don't understand. How could it not be affected? I mean, it's just that if two objects with a mechanical connection are changing shape at different rates, something has to give...either the connection or the objects. Once either gives while hot, and then shrinks when cold, the connection starts to loosen, oxygen is introduce and the connection eventually fails. From what I have read, this was the failure mode of aluminum wire being used with connectors designed for copper. The fact that aluminum oxides are resitive is just a byproduct that makes the root failure painfully obvious. With the greatest respect, how can a connection between two dissimilar metals not eventually fail? ________________________________________________________________________________
Date: Apr 13, 2004
----- Original Message ----- From: Dave Morris <dave(at)davemorris.com> Date: Tuesday, April 13, 2004 11:25 am Subject: Re: RE: AeroElectric-List: "Pictorial Turn Indicator" - Welcome to OZ > > Ah, that's the great thing about experimental aviation and > computers. Anybody can do whatever the heck he wants to do. I > designed > and sold artificial intelligence software products for 10 years > that the > "researchers" said couldn't be done. Microsoft even gave up on it. > That's > the thing about the "little guy" who is doing something for himself > and > doesn't have to be constrained by marketability and liability. But > I do > understand your point. Just one look at the design of current > certified > aircraft shows just how difficult it is to introduce innovation. > > Regards, > > Dave Morris > Aah, a man after my own heart. One of the things I look forward to most is stringing sensors all over my airplane and running it to a copy of LabView on a laptop, or even just the motherboard of a PC hidden under the back seat. Even a 386 will be way more than enough MIPs to fully instrument an OBAM aircraft and provide feedback. ________________________________________________________________________________
Date: Apr 13, 2004
Subject: Re: A panel full of displays . . .
On 04/13 8:50, Robert L. Nuckolls, III wrote: > At least one of the keep-the-dirty-side-down systems could > be a GPS aided wing leveler. Often available for less than the > cost of a good gyro, the wing leveler will do a better job > than a pilot . . . while interfacing with other nav aids for > BOTH stabilization -AND- navigation. I don't intend on having any round steam guages in my panel. I'll have a two display GRT EFIS, single AHRS and magnetometer, Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own independant heading and altitude reference. The EFIS can accept multiple power inputs. The AP can be engaged in some unusual attitudes, and all can communicate with each other. Since this is an all-electric airplane I plan on two alternators and a single battery with Battery, Essential and Primary buses. I don't feel that an AI, TC or TB is necessary as 'backups'. No round airspeed, vsi or altitude instruments either. Maybe I've not thought about all 'events' which could happen in flight, but I believe this is enough to fly light IFR. I hate to ask this, but because this is a forum of intelligent people, here goes; Can you make a case where this would not work? And if so what would you change. (Go easy on me, please) -- Walter Tondu http://www.tondu.com/rv7 ________________________________________________________________________________
From: "James E. Clark" <james(at)nextupventures.com>
Subject: "Pictorial Turn Indicator" - Welcome to OZ
Date: Apr 13, 2004
Hmmmm .... Seems to me I saw/chatted with a guy who had a "product" based on this (or similar) technology at either the last Sun-N-Fun or Oshkosh. I recall thinking that it would take some time for me to get my "head around" the new approach, even though the person doing the demo was espousing how easy it was to interpret. It was obvious that he was into it (the concept) and had spent quite a bit of time making it work. Actually you need the "researchers" just as you need the "product developers". Sometines it is embodied in the same person. Most times at larger companies and with the larger (major) breakthroughs, they are separate. James ... experience with both p.s. More food for thought (ramblings on my part) below ... [snip] > Heh, Dave. I'm not trying to rain on your parade, > but I wouldn't look to see anything out of this > effort for several years. You see, it's being > worked on by 'researchers'. They don't get paid to > develope products that help people in the real Typically they are not paid to *develop* any products per se. More so further understanding and "discover" new concepts that *might* lead to products being developed. > world. They get paid to hype possibilities and play > with new technologies in laboratories. If they do "Hyping possibilities" is not such a bad notion when it gets others to think about what is possible. One thing I like about this particular list is that Bob encourages people to think out loud on "possibilities". He does not push for the "product" to be developed without the exploratory (and challenging) dialog. > the boring work of developing an actual product to "Boring" is in the eye of the beholder. To some, research is boring. > sell that will save peoples lives, then they are > 'sellouts' to 'commercialism'. Don't know of many people that would be called "sellouts" if they help develop something that "... will save peoples lives...". This is a bit over the top don't you think? > > No, even though this technology could be on the > market in 6 months with the help of a few machine > vision engineers, it'll stay in the lab for years as > the 'researchers' milk it for all the grant money If the market for "grant money" is say $1M and the market for "product money" is $100M, don't you think some of these "researchers" would be rushing to make a product happen? This assumes they are motivated by money, grant or otherwise. Good ideas come to market when there is an intersection of "fit for purpose", demand and possibility of delivery. I suspect that at least one of the above is missing for some reason if it is not on the market yet. > they can get. I'm not knocking researchers. > They're just doing what they do. It's just that > they don't develope products, they investigate. True. > > For an example of why I feel this way, consider the > rotary and diesel engines that have been in > 'development' for over a decade. Maybe ... just maybe, there are competitive alternatives that keep the market demand lower than what is needed for them to be a financial success. Maybe ... just maybe, there are still a few things to be worked out to insure "fit for purpose". Maybe .... just maybe, they cannot be built and delivered yet at a cost-effective price. Building one (demonstration) prototype is sometimes MUCH easier than getting geared up to deliver a product that must withstand the rigors of the marketplace ... including liability issues. > > I believe it was Tracey Crook who said that perfect > is the enemy of good enough. Yup. And I think maybe some of the items you reference are not yet "good enough" in the minds of those working on them. James > > ________________________________________________________________________________
Date: Apr 13, 2004
> >On 04/13 8:50, Robert L. Nuckolls, III wrote: > > > At least one of the keep-the-dirty-side-down systems could > > be a GPS aided wing leveler. Often available for less than the > > cost of a good gyro, the wing leveler will do a better job > > than a pilot . . . while interfacing with other nav aids for > > BOTH stabilization -AND- navigation. > >I don't intend on having any round steam guages in my panel. I'll >have a two display GRT EFIS, single AHRS and magnetometer, >Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own >independant heading and altitude reference. The EFIS can accept >multiple power inputs. The AP can be engaged in some unusual >attitudes, and all can communicate with each other. > >Since this is an all-electric airplane I plan on two alternators >and a single battery with Battery, Essential and Primary buses. Okay, with two alternators, your endurance is essentially unlimited, even with the main bus powered up. >I don't feel that an AI, TC or TB is necessary as 'backups'. >No round airspeed, vsi or altitude instruments either. > >Maybe I've not thought about all 'events' which could happen >in flight, but I believe this is enough to fly light IFR. > >I hate to ask this, but because this is a forum of intelligent >people, here goes; > >Can you make a case where this would not work? And if so >what would you change. I'd configure the endurance bus with minimum equipment for continued flight to intended destination sans BOTH alternators just as described in chapter 17. Put everything else on the main bus. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 13, 2004
Walter, My set up for my F1 Rocket is the same as yours except I added an airspeed indicator and an electric artificial horizon. I added the AH because I got a good deal on a used one. The airspeed was cheap. The worst case scenario is a total electrical failure at the bus. This is not a very likely event but it's the only thing that knocks out all the gyroscopic instruments at once. In that event, the battery backup to the EFIS should get you on the ground, unless the EFIS is cooked. Are you using an endurance bus with an alternate feed path from the battery? If not, I think a single point of failure is the master solenoid. That's the problem I currently have and I'm changing my wiring plan accordingly. In looking at all the certified setups using an EFIS, they all have a altimeter, AH, and airspeed as backup. Since I'm not IFR rated, I'd be interested in the comments of others more qualified than me. Randy http://f1rocket.home.comcast.net/ > > On 04/13 8:50, Robert L. Nuckolls, III wrote: > > > At least one of the keep-the-dirty-side-down systems could > > be a GPS aided wing leveler. Often available for less than the > > cost of a good gyro, the wing leveler will do a better job > > than a pilot . . . while interfacing with other nav aids for > > BOTH stabilization -AND- navigation. > > I don't intend on having any round steam guages in my panel. I'll > have a two display GRT EFIS, single AHRS and magnetometer, > Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own > independant heading and altitude reference. The EFIS can accept > multiple power inputs. The AP can be engaged in some unusual > attitudes, and all can communicate with each other. > > Since this is an all-electric airplane I plan on two alternators > and a single battery with Battery, Essential and Primary buses. > > I don't feel that an AI, TC or TB is necessary as 'backups'. > No round airspeed, vsi or altitude instruments either. > > Maybe I've not thought about all 'events' which could happen > in flight, but I believe this is enough to fly light IFR. > > I hate to ask this, but because this is a forum of intelligent > people, here goes; > > Can you make a case where this would not work? And if so > what would you change. > > (Go easy on me, please) > -- > Walter Tondu > http://www.tondu.com/rv7 > > > > > > ________________________________________________________________________________
Date: Apr 13, 2004
It's really quite simple. Thermal expansion and contraction of a wire within a crimped connection is not sufficient to exceed the elastic limit of the surrounding metal (meaning that there is no permanent deformation). Because there is no permanent change in size of the metal surrounding the wire the connection between the two remains air tight at all times. The same applies to the copper cladding over aluminum. The original problem with aluminum wire being used in household wiring was that the installers were not instructed to apply sufficient force, or the connections used were *by design* inadequate to do so, thus permitting exactly what you have assumed to happen. Best regards, Rob Housman Europa XS Tri-Gear A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of echristley(at)nc.rr.com Subject: Re: AeroElectric-List: Copper Clad Aluminum etc. ----- Original Message ----- From: "Robert L. Nuckolls, III" > > > >-Since the Al still expands and contracts at a > >different rate, won't the wire eventually deform > >become loose in the connector? > > The gas-tight crimping technology is not affected > by various expansion coefficients. Further, the > copper clad aluminum can also be soldered. > > Bob . . . > That, I don't understand. How could it not be affected? I mean, it's just that if two objects with a mechanical connection are changing shape at different rates, something has to give...either the connection or the objects. Once either gives while hot, and then shrinks when cold, the connection starts to loosen, oxygen is introduce and the connection eventually fails. From what I have read, this was the failure mode of aluminum wire being used with connectors designed for copper. The fact that aluminum oxides are resitive is just a byproduct that makes the root failure painfully obvious. With the greatest respect, how can a connection between two dissimilar metals not eventually fail? ________________________________________________________________________________
Subject: Backup devices - TC vs. attitude gyro
Date: Apr 13, 2004
Alex, I agree with your comments but a little note on an incident I experienced. I too have the BIG RED LIGHT for low vacuum. Flying along in marginal weather with THREE pilots (at least two of us IRF rated and current) in the plane, it took way longer than I wish to admit to discover (and accept??) that I had a vacuum failure. The slow rate of error introduction was such that I was gently turning/banking to accomodate. Finally got this feeling that something was not right and that the AH was really NOT agreeing with my TC. Took a while then BAM(!!) I noticed the big red light. I was not in IMC ... just marginal so I *could* look outside and (barely) see the ground. My point in this is that it is **very easy** for certain failures to creep up on you. We made it safely to our destination once the failure was acknowledged and returned home with it covered up. James [snip] > > I believe it is necessary to install some sort of indicator to tell you > exactly when a gyro croaks. Mine are vacuum driven, and I have a red > warning light which illuminates whenever the suction is below about 4.5. > Gyro covers are always at hand, and I'm convinced they must be covered > in the event of a failure. My aircraft is uniquely equipped to be able > to shut off the vacuum to the AH or HSI independantly, and I can tell > you that the AH's death is slow, and would be very hard to detect, and > more importantly, to accept that it has failed. I'm no psychologist and > only an IFR student, but if one knows that an instrument failed before > it gives erroneous readings (the vacuum alarm in this example, I know > there are other failure modes), it can be covered and cause a minimum of > distraction. After all, every IFR pilot has demonstrated partial panel > flight and maneuvering. The trouble is the identification of the need > and transition to partial panel which gets people. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 455 hours > > http://www.home.earthlink.net/~alexpeterson/ > > ________________________________________________________________________________
Date: Apr 13, 2004
Lighting strike? I was flying into London last summer when the airliner we were on got struck by lightning descending through clouds that were less than 4000' thick and definitely did not look like thunderstorms. The flight crew came on the intercom and said they were very surprised to get struck in those conditions. Neil Mcleod -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Walter Tondu Subject: Re: AeroElectric-List: A panel full of displays . . . On 04/13 8:50, Robert L. Nuckolls, III wrote: > At least one of the keep-the-dirty-side-down systems could > be a GPS aided wing leveler. Often available for less than the > cost of a good gyro, the wing leveler will do a better job > than a pilot . . . while interfacing with other nav aids for > BOTH stabilization -AND- navigation. I don't intend on having any round steam guages in my panel. I'll have a two display GRT EFIS, single AHRS and magnetometer, Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own independant heading and altitude reference. The EFIS can accept multiple power inputs. The AP can be engaged in some unusual attitudes, and all can communicate with each other. Since this is an all-electric airplane I plan on two alternators and a single battery with Battery, Essential and Primary buses. I don't feel that an AI, TC or TB is necessary as 'backups'. No round airspeed, vsi or altitude instruments either. Maybe I've not thought about all 'events' which could happen in flight, but I believe this is enough to fly light IFR. I hate to ask this, but because this is a forum of intelligent people, here goes; Can you make a case where this would not work? And if so what would you change. (Go easy on me, please) -- Walter Tondu http://www.tondu.com/rv7 == == == == ________________________________________________________________________________
Date: Apr 13, 2004
On 04/13 5:32, F1Rocket(at)comcast.net wrote: > > Walter, > > My set up for my F1 Rocket is the same as yours except I added an airspeed > indicator and an electric artificial horizon. I added the AH because I got > a good deal on a used one. The airspeed was cheap. > > The worst case scenario is a total electrical failure at the bus. This is > not a very likely event but it's the only thing that knocks out all > the gyroscopic instruments at once. In that event, the battery backup to > the EFIS should get you on the ground, unless the EFIS is cooked. Are you > using an endurance bus with an alternate feed path from the battery? That is the plan. Have enough direct battery juice to get down. Actually the EFIS can handle three power inputs (if I remember correctly) and it will draw power from the one with the highest voltage. So it will get wired a bit differently. > If not, I think a single point of failure is the master solenoid. That's > the problem I currently have and I'm changing my wiring plan accordingly. > > In looking at all the certified setups using an EFIS, they all have a > altimeter, AH, and airspeed as backup. Since I'm not IFR rated, I'd be > interested in the comments of others more qualified than me. What's curious is I wonder if those are there because of the way the electrical layout is on those 'certicated' planes, or, are they there because of a long standing thought process that says the 'need' to be there, when they might not. Anyway, those are cheap instruments and being non powered, except for lighting, they might get you home safely. Plus, there is the issue of transitioning from round guages, which almost every pilot flying learned with, to glass cockpit. Might be safer in the beginning. You can always take them out later and sell them on ebay. :0 > Randy > http://f1rocket.home.comcast.net/ > > > > On 04/13 8:50, Robert L. Nuckolls, III wrote: > > > > > At least one of the keep-the-dirty-side-down systems could > > > be a GPS aided wing leveler. Often available for less than the > > > cost of a good gyro, the wing leveler will do a better job > > > than a pilot . . . while interfacing with other nav aids for > > > BOTH stabilization -AND- navigation. > > > > I don't intend on having any round steam guages in my panel. I'll > > have a two display GRT EFIS, single AHRS and magnetometer, > > Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own > > independant heading and altitude reference. The EFIS can accept > > multiple power inputs. The AP can be engaged in some unusual > > attitudes, and all can communicate with each other. > > > > Since this is an all-electric airplane I plan on two alternators > > and a single battery with Battery, Essential and Primary buses. > > > > I don't feel that an AI, TC or TB is necessary as 'backups'. > > No round airspeed, vsi or altitude instruments either. > > > > Maybe I've not thought about all 'events' which could happen > > in flight, but I believe this is enough to fly light IFR. > > > > I hate to ask this, but because this is a forum of intelligent > > people, here goes; > > > > Can you make a case where this would not work? And if so > > what would you change. > > > > (Go easy on me, please) > > -- > > Walter Tondu > > http://www.tondu.com/rv7 > > > > > > > > > > > > > > > > > -- Walter Tondu http://www.tondu.com/rv7 ________________________________________________________________________________
Date: Apr 13, 2004
On 04/13 12:26, Robert L. Nuckolls, III wrote: > >I don't intend on having any round steam guages in my panel. I'll > >have a two display GRT EFIS, single AHRS and magnetometer, > >Garmin GNS 430 (IFR), and Trutrak D-IIVSG. Each has it's own > >independant heading and altitude reference. The EFIS can accept > >multiple power inputs. The AP can be engaged in some unusual > >attitudes, and all can communicate with each other. > > > >Since this is an all-electric airplane I plan on two alternators > >and a single battery with Battery, Essential and Primary buses. > > Okay, with two alternators, your endurance is essentially > unlimited, even with the main bus powered up. > > > >I don't feel that an AI, TC or TB is necessary as 'backups'. > >No round airspeed, vsi or altitude instruments either. > > > >Maybe I've not thought about all 'events' which could happen > >in flight, but I believe this is enough to fly light IFR. > > > >I hate to ask this, but because this is a forum of intelligent > >people, here goes; > > > >Can you make a case where this would not work? And if so > >what would you change. > > I'd configure the endurance bus with minimum equipment > for continued flight to intended destination sans BOTH > alternators just as described in chapter 17. Put everything > else on the main bus. I would consider the EFIS and AP as belonging on the Endurance bus. Everything else, including the GPS/NAV/COM goes on the main bus. If you do lose the EFIS, and now assuming I've lost everything else and I'm on the E-bus, I need something to give me time to get sorted out (AP). I'm assuming IFR in the soup for all the worst case scenarios. -- Walter Tondu http://www.tondu.com/rv7 ________________________________________________________________________________
Date: Apr 13, 2004
> > > > Can you make a case where this would not work? And if so > > what would you change. > > > > (Go easy on me, please) > > -- Lightening strikes? Literally. ________________________________________________________________________________
Date: Apr 13, 2004
Subject: MAC trim troubles
Bob and List... We have an RV6a with dual mac grips, pitch and aileron trim servos. Pitch servo says "MAC 8a" on it. It works fine when wired direct at the servo to 12V both up and down. When operated off stick switches, either side, "down" works fine, "up" is intermittent at best, inop at worst. This one has the "relay deck" from MAC also. It appears to have good power to the realay deck with stick switches activated. Tried to call Ray Allen Co., but they are all busy at S&F this week. I believe we have isolated the problem to either the relay deck itself or a bad connection somewhere between the deck and the el trim servo. Has anyone had a bad relay deck? We'd sure a lot rather just replace that for $35 than have to dig around under the flooring or back in the tail cone. Any and all comments, suggestions, hints, much appreciated. Jerry Cochran Cliff Gerber Wilsonville, OR ________________________________________________________________________________
Date: Apr 13, 2004
Thanks Matt, Interesting site, looks like they will have one in the future with separate coils on each plug, I will keep them in mind. Thanks Ron Triano -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Subject: Re: AeroElectric-List: Electronic Ignition --> You might look at the following site: http://www.megasquirt.info/ Regards, Matt- N34RD > > > I am trying to decide what to do about electronic ignition. There are > several on the market I have found. Are there any schematic's > available to build your own. I prefer to use single coil at each > cylinder using auto parts and at a later date to be able to expand to > a throttle body with injector at each cylinder. My installation is for > a 0200 continental on a Q200. > > Thanks > > Ron Triano > > advertising on the Matronics Forums. ________________________________________________________________________________
Date: Apr 13, 2004
COYLE INSPECTION ENGINEERS, Inc. "Copper clad aluminum wiring has no known history of the types of problems of aluminum wire." Indeed there does not seem to have been a problem with copper-clad aluminum EVER. A Google search shows that this seems to be true. The reason aluminum is so difficult to use as wiring is that the bare aluminum oxidizes and this oxide layer does not conduct electricity (copper oxides DO conduct well). Furthermore, the oxide tends to break up and absorb water and swell. There are technical solutions to this but why bother? This "Super-2-CCA" copper-clad aluminum wire is a good replacement for the 2/0 battery cable and saves about 40-50% weight per foot. This is hard to visualize, but this is about the same as getting AWG 2 battery cable that weighs about what AWG 6 weighs. Some people grimace at the price ($6.75 per foot), but you'd smile if you held a length in your hands. It looks like copper, works like copper, and weighs pretty much what aluminum weighs. Cool.......! And by the way...there's lots of this stuff in commercial airplanes. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Date: Apr 13, 2004
Eric M. Jones wrote: > Some people grimace at the price ($6.75 per foot), but you'd smile if you > held a length in your hands. It looks like copper, works like copper, and > weighs pretty much what aluminum weighs. Cool.......! > 15ft would cost, what?, about $90 more than the welding cable? I was thinking that switching to the aluminum would shave off 3lbs, but from your website the savings would be closer to 1.5lbs. That puts the weight savings at $60/lb. That's near the top of what I consider reasonable, but still within range. I'd want to run the battery lead all the way out to the starter, but then I'd have to have another lead for the avionics. The other option, as someone else pointed out, is to use the cheap aluminum wire with the connectors design for Al-to-Cu service. With this option, I'd run the battery lead up to the panel and have a jumper of welding cable run to the starter solenoid and have another jumper to a bus bar for all the avionics. I think the second option sound more elegant, but I have to investigate what sort of connectors are available. -- http://www.ernest.isa-geek.org/ "Ignorance is mankinds normal state, alleviated by information and experience." Veeduber ________________________________________________________________________________
Subject: electronic ignition options wanted, 6 cyl fixed timing.
Date: Apr 14, 2004
Hi all, after experiencing 3 coil failures in the last 5 hours, I am considddering changing to a fixed timing electronic ignition module for my 6 Cyl Jabiru, has anyone done this before, and if so with what ignition module and what type of pickup? thanks Ian ________________________________________________________________________________
timing.
Date: Apr 14, 2004
Ian, Why are the coils failing? Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, Ian Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. Hi all, after experiencing 3 coil failures in the last 5 hours, I am considddering changing to a fixed timing electronic ignition module for my 6 Cyl Jabiru, has anyone done this before, and if so with what ignition module and what type of pickup? thanks Ian == == == == ________________________________________________________________________________
timing.
Date: Apr 14, 2004
I am not sure whether they are failit because they are overdriven for the rating, (i.e. they are off a 2 Cyl engine that only does 5000rpm and they are being used on a 6 cyl with lost spark (12 sparks per rev) at 3300 RPM) i.e. they are doing 4 times the duty cycle that they usually do, or it is temperature related, I have not instrumented them up however they are supposed to be good to 100C and they are supposed to sit about 50-60 degrees c in cruise, though the under cowl temp is possible up around the 70 or so. Funny thing is that I had no failures during the 25hour test phase, and 3 failures n 5 hours on the first long cross country. Man the wife was impressed. Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of George Braly Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. Ian, Why are the coils failing? Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, Ian Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. Hi all, after experiencing 3 coil failures in the last 5 hours, I am considddering changing to a fixed timing electronic ignition module for my 6 Cyl Jabiru, has anyone done this before, and if so with what ignition module and what type of pickup? thanks Ian == == == == ________________________________________________________________________________
timing.
Date: Apr 14, 2004
Scott, Check your cap rotor, wires and plugs. If a plug wire is bad then the coil has to generate higher voltages to arc the plug. This higher voltage can cause premature failures of coils. Regards, Trampas www.sterntech.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, Ian Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. I am not sure whether they are failit because they are overdriven for the rating, (i.e. they are off a 2 Cyl engine that only does 5000rpm and they are being used on a 6 cyl with lost spark (12 sparks per rev) at 3300 RPM) i.e. they are doing 4 times the duty cycle that they usually do, or it is temperature related, I have not instrumented them up however they are supposed to be good to 100C and they are supposed to sit about 50-60 degrees c in cruise, though the under cowl temp is possible up around the 70 or so. Funny thing is that I had no failures during the 25hour test phase, and 3 failures n 5 hours on the first long cross country. Man the wife was impressed. Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of George Braly Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. Ian, Why are the coils failing? Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, Ian Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. Hi all, after experiencing 3 coil failures in the last 5 hours, I am considddering changing to a fixed timing electronic ignition module for my 6 Cyl Jabiru, has anyone done this before, and if so with what ignition module and what type of pickup? thanks Ian == == == == ________________________________________________________________________________
Date: Apr 14, 2004
Subject: Re: electronic ignition options wanted, 6
cyl fixed timing. Art, Hmmmm? Something for you to investigate perhaps? Charlie Kuss > >Hi all, after experiencing 3 coil failures in the last 5 hours, I am considddering changing to a fixed timing electronic ignition module for my 6 Cyl Jabiru, has anyone done this before, and if so with what ignition module and what type of pickup? > >thanks > >Ian > > ________________________________________________________________________________
Date: Apr 14, 2004
Ron It has been done with a waste spark system off a GM Cavalier or similar. The Coil assembly on those works fine without being connected to the main engine computer. In standalone mode it advances something like 20 degrees linearly per 3000 rpm. I can look up exact numbers if you need them. You need a steel disc with 7 slots mounted on the crankshaft (typically behing the prop) to trigger the magnetic sensor. I believe such a system to be cheaper and more reliable than most scratch built systems. Ken > From: "Ron Triano" <rondefly(at)rtriano.com> > Subject: AeroElectric-List: Electronic Ignition > > > I am trying to decide what to do about electronic ignition. There are > several on the market I have found. Are there any schematic's available to > build your own. I prefer to use single coil at each cylinder using auto > parts and at a later date to be able to expand to a throttle body with > injector at each cylinder. My installation is for a 0200 continental on a > Q200. > > Thanks > > Ron Triano > ________________________________________________________________________________
Date: Apr 14, 2004
Ron, Have you considered the Real World Solutions EC-2 system? It is a dual processor unit and is user programmable in flight, no p/c required. Handles ignition and EFI. Their website is www.rotaryaviation.com Tracy Crook is a great guy to do business with. Mark S. > >I am trying to decide what to do about electronic ignition. There are >several on the market I have found. Are there any schematic's available to >build your own. I prefer to use single coil at each cylinder using auto >parts and at a later date to be able to expand to a throttle body with >injector at each cylinder. My installation is for a 0200 continental on a >Q200. > >Thanks > >Ron Triano ________________________________________________________________________________
Subject: Re: electronic ignition options wanted, 6 cyl fixed
timing.
Date: Apr 14, 2004
How will changing to fixed timing help the coils? ----- Original Message ----- From: "Scott, Ian" <ian_scott(at)commander.com> Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. > > I am not sure whether they are failit because they are overdriven for the rating, (i.e. they are off a 2 Cyl engine that only does 5000rpm and they are being used on a 6 cyl with lost spark (12 sparks per rev) at 3300 RPM) i.e. they are doing 4 times the duty cycle that they usually do, > > or it is temperature related, I have not instrumented them up however they are supposed to be good to 100C and they are supposed to sit about 50-60 degrees c in cruise, though the under cowl temp is possible up around the 70 or so. > > Funny thing is that I had no failures during the 25hour test phase, and 3 failures n 5 hours on the first long cross country. Man the wife was impressed. > > Ian > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of George > Braly > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 > cyl fixed timing. > > > Ian, > > Why are the coils failing? > > Regards, George > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Scott, Ian > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl > fixed timing. > > > > Hi all, after experiencing 3 coil failures in the last 5 hours, I am > considddering changing to a fixed timing electronic ignition module for > my 6 Cyl Jabiru, has anyone done this before, and if so with what > ignition module and what type of pickup? > > thanks > > Ian > > > == > == > == > == > > ________________________________________________________________________________
timing.
Date: Apr 14, 2004
Check plug gaps for the same reason. ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. > > Scott, > > Check your cap rotor, wires and plugs. If a plug wire is bad then the coil > has to generate higher voltages to arc the plug. This higher voltage can > cause premature failures of coils. > > Regards, > Trampas > www.sterntech.com > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott, > Ian > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl > fixed timing. > > > > I am not sure whether they are failit because they are overdriven for the > rating, (i.e. they are off a 2 Cyl engine that only does 5000rpm and they > are being used on a 6 cyl with lost spark (12 sparks per rev) at 3300 RPM) > i.e. they are doing 4 times the duty cycle that they usually do, > > or it is temperature related, I have not instrumented them up however they > are supposed to be good to 100C and they are supposed to sit about 50-60 > degrees c in cruise, though the under cowl temp is possible up around the 70 > or so. > > Funny thing is that I had no failures during the 25hour test phase, and 3 > failures n 5 hours on the first long cross country. Man the wife was > impressed. > > Ian > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of George > Braly > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 > cyl fixed timing. > > > Ian, > > Why are the coils failing? > > Regards, George > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Scott, Ian > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl > fixed timing. > > > > Hi all, after experiencing 3 coil failures in the last 5 hours, I am > considddering changing to a fixed timing electronic ignition module for > my 6 Cyl Jabiru, has anyone done this before, and if so with what > ignition module and what type of pickup? > > thanks > > Ian > > > == > == > == > == > > ________________________________________________________________________________
Date: Apr 14, 2004
Thanks Mark, Yes I am, real world and mega squirt & spark are the two I am looking at. Ron Triano -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Steitle Subject: Re: AeroElectric-List: Electronic Ignition --> Ron, Have you considered the Real World Solutions EC-2 system? It is a dual processor unit and is user programmable in flight, no p/c required. Handles ignition and EFI. Their website is www.rotaryaviation.com Tracy Crook is a great guy to do business with. Mark S. >--> > >I am trying to decide what to do about electronic ignition. There are >several on the market I have found. Are there any schematic's available >to build your own. I prefer to use single coil at each cylinder using >auto parts and at a later date to be able to expand to a throttle body >with injector at each cylinder. My installation is for a 0200 >continental on a Q200. > >Thanks > >Ron Triano advertising on the Matronics Forums. ________________________________________________________________________________
Subject: Endurance Bus
Date: Apr 14, 2004
Using Bob's current wiring diagrams, is it okay to have both the master switch and endurance bus switch on at the same time? I assume the diode between the two buses keeps things from shorting out. Is there any long-term consequence to running with both switches on all the time? It doesn't appear so to me, but I'm not always very good at keeping all the smoke inside the wires. Thanks, Randy F1 Rocket http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Apr 14, 2004
Walter, The main thing I'd consider is that your single battery is a single point failure for the whole system. I had planned to go the same route as you and ended up settling on dual battery, single alternator. This gives up the advantage of having unlimited juice in case of alternator failure, but is more robust from the perspective of keeping the essentials going. It's also cheaper than the SD-8, doesn't extract any engine power, and in my case is even a bit lighter since my aux battery is small. If you wanted to keep the benefits that the SD-8 offers, but want to eliminate the chances (however small) of losing everything due to battery (or battery lead) failure, I'd add at least a small aux battery that can be isolated from the main battery, such that you have the SD-8 tied to the aux, and the main alternator tied to the main battery. Then you have true full redundancy and can fly hard IFR with no limitations imposed by any single failure. Just my humble .02 --Mark Navratil Cedar Rapids, Iowa RV-8A N2D fwf stuff these days... -------------------------------------------- From: Walter Tondu <walter(at)tondu.com> Subject: Re: AeroElectric-List: A panel full of displays . . . Since this is an all-electric airplane I plan on two alternators and a single battery with Battery, Essential and Primary buses. I hate to ask this, but because this is a forum of intelligent people, here goes; Can you make a case where this would not work? And if so what would you change. (Go easy on me, please) -- Walter Tondu http://www.tondu.com/rv7 ________________________________________________________________________________
timing.
Date: Apr 15, 2004
on the Jabiru the coils and electrics are contained in one package that sits on the edge of the flywheel and gets the power form magnets that pass by, as your Honda Lawn mower or stationary motor would. Ian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Cy Galley Subject: Re: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. How will changing to fixed timing help the coils? ----- Original Message ----- From: "Scott, Ian" <ian_scott(at)commander.com> Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 cyl fixed timing. > > I am not sure whether they are failit because they are overdriven for the rating, (i.e. they are off a 2 Cyl engine that only does 5000rpm and they are being used on a 6 cyl with lost spark (12 sparks per rev) at 3300 RPM) i.e. they are doing 4 times the duty cycle that they usually do, > > or it is temperature related, I have not instrumented them up however they are supposed to be good to 100C and they are supposed to sit about 50-60 degrees c in cruise, though the under cowl temp is possible up around the 70 or so. > > Funny thing is that I had no failures during the 25hour test phase, and 3 failures n 5 hours on the first long cross country. Man the wife was impressed. > > Ian > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of George > Braly > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: electronic ignition options wanted, 6 > cyl fixed timing. > > > Ian, > > Why are the coils failing? > > Regards, George > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Scott, Ian > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: electronic ignition options wanted, 6 cyl > fixed timing. > > > > Hi all, after experiencing 3 coil failures in the last 5 hours, I am > considddering changing to a fixed timing electronic ignition module for > my 6 Cyl Jabiru, has anyone done this before, and if so with what > ignition module and what type of pickup? > > thanks > > Ian > > > == > == > == > == > > ________________________________________________________________________________
Date: Apr 14, 2004
Subject: Re: Endurance Bus
Hi Randy, I assume you are talking about the 'endurance bus alternate feed'. The only effect that you will notice by having the alternate feed turned on (at the same time as the master) is that the endurance bus voltage will rise by the diode drop (maybe 0.2 to 0.6V depending on the load and what kind of diode you are using). Regards, Matt- > > > Using Bob's current wiring diagrams, is it okay to have both the master > switch and endurance bus switch on at the same time? I assume the diode > between the two buses keeps things from shorting out. Is there any > long-term consequence to running with both switches on all the time? It > doesn't appear so to me, but I'm not always very good at keeping all the > smoke inside the wires. > > Thanks, > > Randy > F1 Rocket > http://f1rocket.home.comcast.net/ > > ________________________________________________________________________________
Date: Apr 14, 2004
Hi Randy, I assume you are talking about the 'endurance bus alternate feed'. The only effect that you will notice by having the alternate feed turned on (at the same time as the master) is that the endurance bus voltage will rise by the diode drop (maybe 0.2 to 0.6V depending on the load and what kind of diode you are using). The diode does sort of keep things from shorting out, but only when you have the master turned off. Without the diode, the main bus would be powered through the fuse connecting the alternate feed to the battery bus. Regards, Matt- > > > Using Bob's current wiring diagrams, is it okay to have both the master > switch and endurance bus switch on at the same time? I assume the diode > between the two buses keeps things from shorting out. Is there any > long-term consequence to running with both switches on all the time? It > doesn't appear so to me, but I'm not always very good at keeping all the > smoke inside the wires. > > Thanks, > > Randy > F1 Rocket > http://f1rocket.home.comcast.net/ > > ________________________________________________________________________________
Date: Apr 14, 2004
With all due respect...... how many of us have a had a battery failure? I cannot believe that some of you intend medium to hard IFR with some of our homebuilts. First consider empennage, wing and prop anti icing equipment first.... Then I'll believe you need all the rest of the equipment. One battery will due if it is the proper quality..... Just my opinion, Dale Martin Lewiston, ID LEZ-235 ----- Original Message ----- From: <czechsix(at)juno.com> Subject: Re: AeroElectric-List: A panel full of displays . . . > > > Walter, > > The main thing I'd consider is that your single battery is a single point failure for the whole system. I had planned to go the same route as you and ended up settling on dual battery, single alternator. This gives up the advantage of having unlimited juice in case of alternator failure, but is more robust from the perspective of keeping the essentials going. It's also cheaper than the SD-8, doesn't extract any engine power, and in my case is even a bit lighter since my aux battery is small. If you wanted to keep the benefits that the SD-8 offers, but want to eliminate the chances (however small) of losing everything due to battery (or battery lead) failure, I'd add at least a small aux battery that can be isolated from the main battery, such that you have the SD-8 tied to the aux, and the main alternator tied to the main battery. Then you have true full redundancy and can fly hard IFR with no limitations imposed by any single failure. > > Just my humble .02 > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D fwf stuff these days... > > -------------------------------------------- > > From: Walter Tondu <walter(at)tondu.com> > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > Since this is an all-electric airplane I plan on two alternators > and a single battery with Battery, Essential and Primary buses. > > > > I hate to ask this, but because this is a forum of intelligent > people, here goes; > > Can you make a case where this would not work? And if so > what would you change. > > (Go easy on me, please) > -- > Walter Tondu > http://www.tondu.com/rv7 > > ________________________________________________________________________________
Date: Apr 14, 2004
Randy, When I asked Bob this question the answer was that this should be the normal mode of operation, ESSENTIAL BUS selected, so no matter what, you will have the essential bus powered. Pat Hatch RV-4 RV-6 RV-7 Finishing Kit Vero Beach, FL ----- Original Message ----- From: "Randy Pflanzer" <f1rocket(at)comcast.net> Subject: AeroElectric-List: Endurance Bus > > Using Bob's current wiring diagrams, is it okay to have both the master switch and endurance bus switch on at the same time? I assume the diode between the two buses keeps things from shorting out. Is there any long-term consequence to running with both switches on all the time? It doesn't appear so to me, but I'm not always very good at keeping all the smoke inside the wires. > > Thanks, > > Randy > F1 Rocket > http://f1rocket.home.comcast.net/ > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Apr 14, 2004
----- Original Message ----- From: "Randy Pflanzer" <f1rocket(at)comcast.net> Subject: AeroElectric-List: Endurance Bus > > Using Bob's current wiring diagrams, is it okay to have both the master switch and endurance bus switch on at the same time? I assume the diode between the two buses keeps things from shorting out. Is there any long-term consequence to running with both switches on all the time? It doesn't appear so to me, but I'm not always very good at keeping all the smoke inside the wires. ((((((((())))))))))) The diode keeps current from flowing into the master buss from the endurance buss when the e-buss alternate feed switch is closed. The diode allows current to flow only one way from the master buss to the endurance buss when the master switch is on. When we have a problem and need to save current, we turn on the endurance buss alternate feed switch and turn off the master switch to save current by what ever is powered via the master and that is where the diode stops the flow into the master since the endurance is powered through the switch. I have not thought about it and am not sure about leaving the switch on all the time. On the spur of the moment, I don't know why there would be long term problems with having the alternate feed e-buss switch on at all times -- However, the e-buss would act then like a switchable battery buss and we don't actually have an alternate power source since we have already used it. FYI, Because my radios are wired into the e-buss, I plan to use the e-buss to get weather info and file flight plan prior to turning the master switch on and engine start up. I will not otherwise turn on the alternate e-buss feed while engine is running unless I have an electrical problem. If I have an electrical problem when running -- such as an alternator failure, I will turn on the e-buss alternate feed right before turning off the master switch . So, for that second or two, I would have both the e-buss alt. feed and master switch on. Hope Bob chimes in here if that is not the correct plan to follow. Larry (((((((()))))))))) > > Thanks, > > Randy > F1 Rocket > http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Apr 14, 2004
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: Architecure Choices
> > >Walter, > >The main thing I'd consider is that your single battery is a single point >failure for the whole system. I had planned to go the same route as you >and ended up settling on dual battery, single alternator. This gives up >the advantage of having unlimited juice . . . . . . unlimited? That must be a really BIG battery. > in case of alternator failure, but is more robust from the perspective > of keeping the essentials going. the SD-8 is about as robust a power supply as you're going to find. It's lightly stressed, has no wearing parts, a VERY long service life and requires no periodic maintenance. > It's also cheaper than the SD-8, how may of those really big batteries will you use over the foreseeable future? How long will it take for battery replacements to add up to price of SD-8? > doesn't extract any engine power, 120 watts at 40% efficiency comes to about 0.4 hp max. That will add about 5 fpm to rate of climb on the average lightplane. > and in my case is even a bit lighter since my aux battery is small. . . . how do you get 'unlimited' energy from a battery that weighs less than an SD-8? Have you conducted a load analysis for the various operating scenarios? > If you wanted to keep the benefits that the SD-8 offers, but want to > eliminate the chances (however small) of losing everything due to battery > (or battery lead) failure, I'd add at least a small aux battery that can > be isolated from the main battery, such that you have the SD-8 tied to > the aux, and the main alternator tied to the main battery. Then you have > true full redundancy and can fly hard IFR with no limitations imposed by > any single failure. Some builders have assembled an SD-8/L-40 combination into a Figure Z-14 style architecture where the aux battery is small, not used for engine cranking, and switches or small relays used in lieu of contactors for crossfeed and battery control. Bob . . . ________________________________________________________________________________
Date: Apr 14, 2004
Subject: New SD-8 Regulator
Tim Hedding called from B&C today to tell me about a new, beefier regulator being offered for the SD-8 alternator. See http://www.aeroelectric.com/Reference_Docs/PMR1C.pdf for copy of installation and operating data. My feeling is that the original regulator is probably fine when mounted to a metal surface but the regulator/rectifier cited above was tested with especially conservative ratings in mind. Tim didn't have anything to share on pricing. He's leaving that up to Bill and Todd. If anyone is interested in this product, give them a call in about 10 days . . . I think it will be that long before they're back from Sun-n-Fun. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 14, 2004
> > >Using Bob's current wiring diagrams, is it okay to have both the master >switch and endurance bus switch on at the same time? I assume the diode >between the two buses keeps things from shorting out. Is there any >long-term consequence to running with both switches on all the time? It >doesn't appear so to me, but I'm not always very good at keeping all the >smoke inside the wires. Nope, you can run with the e-bus alternate feed switch on all the time and it doesn't hurt anything. Be sure to turn it off with all other switches at shutdown. Bob . . . ________________________________________________________________________________
Date: Apr 14, 2004
> >Randy, > >When I asked Bob this question the answer was that this should be the normal >mode of operation, ESSENTIAL BUS selected, so no matter what, you will have >the essential bus powered. I don't recall that conversation. I think I'd run with it off but it's not a show stopper either way. Just make sure your preflight checklist proves the alternate power path before startup. Bob . . . ________________________________________________________________________________
Date: Apr 14, 2004
Subject: Re: MAC trim troubles
> >Bob and List... > >We have an RV6a with dual mac grips, pitch and aileron trim servos. Pitch >servo says "MAC 8a" on it. It works fine when wired direct at the servo >to 12V >both up and down. When operated off stick switches, either side, "down" works >fine, "up" is intermittent at best, inop at worst. This one has the "relay >deck" from MAC also. Sounds like a problem with the relay deck. Could be bad solder joint, bad relay, etc. > It appears to have good power to the realay deck with stick >switches activated. Tried to call Ray Allen Co., but they are all busy at S&F >this week. I believe we have isolated the problem to either the relay deck >itself or a bad connection somewhere between the deck and the el trim >servo. Has >anyone had a bad relay deck? We'd sure a lot rather just replace that for $35 >than have to dig around under the flooring or back in the tail cone. Any and >all comments, suggestions, hints, much appreciated. You can build your own relay "deck" from locally acquired relays. The circuit is not complex. Here's a compilation of options: http://www.aeroelectric.com/Reference_Docs/PitchTrim.pdf Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 15, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
Uuuh, Bob. You read his post wrong. What he said was: >>This gives up the advantage of having unlimited juice . . . >> >> Meaning, he is choosing to use batteries and one alternator - resulting in limited juice. > > . . . unlimited? That must be a really BIG battery. > Likewise. Other than that, your comments are right on. Dick Tasker ________________________________________________________________________________
Date: Apr 15, 2004
Subject: z-14 common failure point
The cross-feed relay/contactor in a dual battery and dual alternator Z-14 architecture is a common point of failure. With a small non-cranking second battery, the crossfeed could be fused or protected with fusable links. With two batteries of the same size that both provide cranking current, that becomes more difficult. So today's question is - do crossfeed contactors ever fail in such a manner that one or both feeds short to ground? This question came to mind after observing a Docap 24059 contactor. The studs penetrate the metal case through hard plastic grommets that can't have a terribly high melting point. Now I'm wondering what is inside that could fail and short to the metal case. The Cole Hersee site also lists a "plasticized" 24117 version although I've not seen it stocked locally and it is several times the price. Perhaps I'll just insulate the metal contactor from the metal airframe. thanks Ken ________________________________________________________________________________
Date: Apr 15, 2004
From: "David E. Nelson" <david.nelson(at)pobox.com>
Subject: Coaxial Lengths
Hi Bob, Finished reading through the "Antenna" chapter last night. Back in my pre-teen days, I used to spend some time with a ham operator that operated in the HF band. Although I don't remember the equation, I distinctly remember that he'd measure all his coaxes before cutting and fitting them with connectors. I seem to recall that his reasoning for this was so that the coax was a multiple of the wavelength of the carrier freq. Is this of any relevance to our apps? Thanks, /\/elson Austin, TX RV-7A - Waiting on the wings.... ________________________________________________________________________________
Date: Apr 15, 2004
Subject: Re: z-14 common failure point
> >The cross-feed relay/contactor in a dual battery and dual alternator >Z-14 architecture is a common point of failure. > >With a small non-cranking second battery, the crossfeed could be fused >or protected with fusable links. With two batteries of the same size >that both provide cranking current, that becomes more difficult. > >So today's question is - do crossfeed contactors ever fail in such a >manner that one or both feeds short to ground? This question came to >mind after observing a Docap 24059 contactor. The studs penetrate the >metal case through hard plastic grommets that can't have a terribly high >melting point. Now I'm wondering what is inside that could fail and >short to the metal case. The Cole Hersee site also lists a "plasticized" >24117 version although I've not seen it stocked locally and it is >several times the price. Perhaps I'll just insulate the metal contactor >from the metal airframe. There's no component I'm aware of that has a failure rate of zero. There are many components with failure rates that are exceedingly small . . . in the same neighborhood as that of prop bolts and wing struts. I'm involved in an investigation of fault-to-ground failure in a solid state contactor that caused a fire . . . fortunately on the ground. One might sit right up in their chair with the wide-eyed stare and declare that this event warrants some rapid response and real "solutions" . . . However, looking at the history of this part (25+ years of service, 4 devices per airplane, fleet size in the upper hundreds, and what must be millions of flight hours with no similar failures) I do not at present perceive a need for such action. The investigation is incomplete but preliminary studies suggest that inattention to assembly procedures is the triggering event . . . not gross failure of any components. Now, do electro-mechanical contactors fail, you betcha. See: http://www.aeroelectric.com/Pictures/6041_Contactor.jpg and http://www.aeroelectric.com/Pictures/6041_Contactor_Failure.jpg This is a $high$ contactor used to control loads of well over 100A with LONG duty cycles. Contact aging increases resistance which in turn increases heat which increases resistance and the end is inevitable. Is the Z-14 crossfeed contactor at risk? It carries a PORTION of cranking current for a few seconds at the beginning of each flight. Its normal operating condition for 99.9% of flight operations is OFF. With B&C hardware for alternators, it's unlikely that the crossfeed contactor will ever be called upon to carry out a primary assigned duty as mitigator of alternator failure over the lifetime of the airplane. Even if it DOES get a call-to-service, it will carry loads at a small fraction of it's rated service and only for perhaps an hour or two until landing. Given the VERY low stress and duty cycle on this contactor, I'll suggest that there are many, many things in your system much more likely to fail than this contactor. Further, given that the continuous duty operating loads are so small, it's extremely unlikely that it will fail in an overheat mode that produces faults to ground due to insulator failure. Now, is the risk of what you've suggested zero? Nope . . . but I wouldn't loose any sleep over this one. Bob . . . ________________________________________________________________________________
Date: Apr 15, 2004
Subject: PS: z-14 common failure point
It just occurred to me that this style contactor has been used on SE certified aircraft for about 60 years as a battery contactor. This offers a tens-of-millions flight-hours experience- base. I've seen a lot of these contactors fail . . . haven't seen any catch fire or fault to ground. This same style contactor is used as battery contactor in OBAM aircraft as well. We're continuing to pile up millions of flight hours history on this part in a CONTINUOUS duty application at substantial current values. If there are valid concerns for the failure mode hypothesized then it's going to happen at the battery long before it happens at the crossfeed contactor. Bob . . . ________________________________________________________________________________
Date: Apr 15, 2004
Subject: Copper Clad Aluminum etc.
> >With the greatest respect, how can a connection >between two dissimilar metals not eventually fail? > >It's really quite simple. Thermal expansion and contraction of a wire >within a crimped connection is not sufficient to exceed the elastic limit of >the surrounding metal (meaning that there is no permanent deformation). >Because there is no permanent change in size of the metal surrounding the >wire the connection between the two remains air tight at all times. The >same applies to the copper cladding over aluminum. Rob, thank you for the illumination of "simple ideas" that support the premise of permanency of gas-tight crimps on aluminum. I hadn't considered the dynamics necessary to open a gap the terminal's grip. Bob . . . ________________________________________________________________________________
Subject: Re: A panel full of displays . . .
Date: Apr 15, 2004
> With all due respect...... how many of us have a had a battery failure? I > cannot believe that some of you intend medium to hard IFR with some of our > homebuilts. First consider empennage, wing and prop anti icing equipment > first.... Then I'll believe you need all the rest of the equipment. > > One battery will due if it is the proper quality..... I agree. I've been flying for 40 years and owned probably 20 planes during that time and have never had a battery failure or even heard of one (I am A&P/IA). And most of the time the battery gives plenty of warning that it is about to fail or already has per Bob's definition. I see a battery failure risk as being almost totally negligible in comparison to other IFR flying risks. Cliff ----- Original Message ----- From: "Dale Martin" <niceez(at)cableone.net> Subject: Re: AeroElectric-List: A panel full of displays . . . > > With all due respect...... how many of us have a had a battery failure? I > cannot believe that some of you intend medium to hard IFR with some of our > homebuilts. First consider empennage, wing and prop anti icing equipment > first.... Then I'll believe you need all the rest of the equipment. > > One battery will due if it is the proper quality..... > > Just my opinion, > > Dale Martin > Lewiston, ID > LEZ-235 > > > ----- Original Message ----- > From: <czechsix(at)juno.com> > To: > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > > > > > Walter, > > > > The main thing I'd consider is that your single battery is a single point > failure for the whole system. I had planned to go the same route as you and > ended up settling on dual battery, single alternator. This gives up the > advantage of having unlimited juice in case of alternator failure, but is > more robust from the perspective of keeping the essentials going. It's also > cheaper than the SD-8, doesn't extract any engine power, and in my case is > even a bit lighter since my aux battery is small. If you wanted to keep the > benefits that the SD-8 offers, but want to eliminate the chances (however > small) of losing everything due to battery (or battery lead) failure, I'd > add at least a small aux battery that can be isolated from the main battery, > such that you have the SD-8 tied to the aux, and the main alternator tied to > the main battery. Then you have true full redundancy and can fly hard IFR > with no limitations imposed by any single failure. > > > > Just my humble .02 > > > > --Mark Navratil > > Cedar Rapids, Iowa > > RV-8A N2D fwf stuff these days... > > > > -------------------------------------------- > > > > From: Walter Tondu <walter(at)tondu.com> > > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > > > > > Since this is an all-electric airplane I plan on two alternators > > and a single battery with Battery, Essential and Primary buses. > > > > > > > > I hate to ask this, but because this is a forum of intelligent > > people, here goes; > > > > Can you make a case where this would not work? And if so > > what would you change. > > > > (Go easy on me, please) > > -- > > Walter Tondu > > http://www.tondu.com/rv7 > > > > > > ________________________________________________________________________________
Date: Apr 15, 2004
Thanks to everyone who answered my questions. I realized after I'd built my switch panels that even though I had three independent gyro systems in my panel, I had designed in a single point of failure for all of them. I had concentrated too much on the endurance bus from the persective of reducing load during alternator failure and missed the valuable benefit of it providing an alternate feed path from the battery to my filght instruments. I reasoned away the need for the endurance bus because I have dual alternators As designed today, a battery contactor or master switch failure would have rendered my EFIS, A/P, and electric AH all useless because I left off the endurance bus. Now, I plan to move all my radios/gyros to the endurance bus and I will add a switch to my panel to power it. That switch will also serve to power the radios only before start-up for clearance/ATIS/weather etc. My endurance bus is "really" an avionics bus, but I promise not to call it that. Randy F1 Rocket (RV-6 and Long-EZ using Bob's methods) http://f1rocket.home.comcast.net/ > > > > > > > >Using Bob's current wiring diagrams, is it okay to have both the master > >switch and endurance bus switch on at the same time? I assume the diode > >between the two buses keeps things from shorting out. Is there any > >long-term consequence to running with both switches on all the time? It > >doesn't appear so to me, but I'm not always very good at keeping all the > >smoke inside the wires. > > Nope, you can run with the e-bus alternate feed switch on all the time > and it doesn't hurt anything. Be sure to turn it off with all other > switches at shutdown. > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Apr 15, 2004
Subject: Re: Coaxial Lengths
Your friend was either a novice or was building special antennas. The only reason to measure coax is if you're using the coax as an impedance matching section. Other than that, one of the key benefits of coax versus open feedline is that you can cut it to any length to wrap around obstacles. The higher you go in frequency, the higher the losses for longer pieces, so don't coil up 100 feet of coax if 10 feet will do, because it will degrade the signal. Other than that, length is of no importance. Dave Morris N5UP > > > >Hi Bob, > >Finished reading through the "Antenna" chapter last night. Back in my >pre-teen >days, I used to spend some time with a ham operator that operated in the HF >band. Although I don't remember the equation, I distinctly remember that he'd >measure all his coaxes before cutting and fitting them with connectors. I >seem >to recall that his reasoning for this was so that the coax was a multiple of >the wavelength of the carrier freq. Is this of any relevance to our apps? > >Thanks, > /\/elson > Austin, TX > RV-7A - Waiting on the wings.... > > Dave Morris ________________________________________________________________________________
Subject: Ignitions/Starting
Date: Apr 15, 2004
04/15/2004 11:09:28 AM To all of you with 1 electronic ignition and one mag - I am assuming the remaining mag does not have an impulse coupling. So your starting procedure would be to turn on both the mag and electronic ignition and then start? or just use the electronic ignition for start? Which leads to my next question... how do you handle the key switch? Does it just lock out the starter or do you also disable the electronic ignition to prevent hand propping (if possible) or is there some type of special switch being used to switch off both the mag and electronic ignition? I am planning to have normal switches for the ignitions but a simple key switch for security. So my best idea yet is to have a key switch to lock out the electronic ignition and starter and then separate switches for mag/electronic/start. Essentially the mag could be made hot with only the switch, but then the plane would be hard to start without the impulse coupling. Am I on the right track here? What have you done - Why? Thanks, Bryan ________________________________________________________________________________
Date: Apr 15, 2004
Hi Bob You state that you have "seen a lot of these contactors fail" - I am assuming that the normal battery contactor failure modes would be (1) fail to close when turned on, (2) fail to open when turned off, (3) poor conductivity due pitting of contacts (hard starting) - none of which would cause a problem in flight. Are there other battery contactor failure modes (such as drop out) that you have seen that actually did cause a problem in flight, and if so what are they?? Thanks, George in Langley It just occurred to me that this style contactor has been used on SE certified aircraft for about 60 years as a battery contactor. This offers a tens-of-millions flight-hours experience- base. I've seen a lot of these contactors fail . . . haven't seen any catch fire or fault to ground. This same style contactor is used as battery contactor in OBAM aircraft as well. We're continuing to pile up millions of flight hours history on this part in a CONTINUOUS duty application at substantial current values. If there are valid concerns for the failure mode hypothesized then it's going to happen at the battery long before it happens at the crossfeed contactor. Bob . . . _ ________________________________________________________________________________
Date: Apr 15, 2004
Subject: Re: Ignitions/Starting
Hi Bryan, Embedded comments... > > > To all of you with 1 electronic ignition and one mag - I am assuming the > remaining mag does not have an impulse coupling. Magnetos without impulse coupling (or some other method to retard the spark timing) are not suitable for starting. > So your starting > procedure would be to turn on both the mag and electronic ignition and > then start? or just use the electronic ignition for start? Both of the mags on my O-200 had impulse couplings... So, I used to turn both of them on when starting. Not unusual. Now, with one electronic ignition, I still turn both systems on, as they both properly retard the spark timing for starting. > Which leads > to my next question... how do you handle the key switch? No key switch. Removed. Using 2 toggle switches. > Does it just > lock out the starter or do you also disable the electronic ignition to > prevent hand propping (if possible) My airplane doesn't have a starter. Hand propping is the only way to make it go. Being able to hand prop might be useful, even on airplanes with starters. > or is there some type of special > switch being used to switch off both the mag and electronic ignition? The p-lead on magnetos needs to be disconnected to run, and shorted to not run. Most electronic ignition systems require the oposite conditions, ie they need to have 12V connected in order to run. I believe Klaus offers an option on some of his systems to be able to work with a normal magneto key switch, though he recommends using toggle switches instead. > I > am planning to have normal switches for the ignitions but a simple key > switch for security. Secure from what? Accidental starter engagement or from theft? I don't think a normal key switch provides any protection from either problem. I suppose that a key switch might discourage a joy rider, but I think that's about it. > So my best idea yet is to have a key switch to lock > out the electronic ignition and starter and then separate switches for > mag/electronic/start. Essentially the mag could be made hot with only > the switch, but then the plane would be hard to start without the > impulse coupling. The only way I can think to wire up what you are talking about involves essentially two electrical disconnects for engine ignition. I don't think I would choose to sacrifice in flight reliability to gain on the ground security. For security, as someone (Bob?) suggests, get one of those heavy padded chains with a high quality padlock, and figure-eight it around the propellor. > > Am I on the right track here? What have you done - Why? > > Thanks, > > Bryan > Regards, Matt- N34RD ________________________________________________________________________________
"'aeroelectric-list(at)matronics.com'"
Subject: Dynon heated AOA pitot now available
Date: Apr 15, 2004
this week for the heated AOA pitot and plans to begin shipping next week. I've ordered mine. I also currently have the PSS AOA system installed so I can do some direct comparisons. S. Todd Bartrim Turbo 13B RX-9endurance C-FSTB http://www3.telus.net/haywire/RV-9/C-FSTB.htm "Imagination is more important than knowledge" -Albert Einstein ________________________________________________________________________________
Date: Apr 15, 2004
On my RV-7 I have one Slick impulse coupled mag and one LightSpeed Plasma II. From what I understand, the LSE retards to zero (TDC) for starting. So I use both ignition sources at startup and the thing fires on the first blade when cold, first few blades when hot & purged. Whenever starting, I do this (after any required priming is complete): - master switch on battery only (all 3 buses powered on) - mag switch on (impulse coupler enables starting) - Lightspeed switch on (timing retarded to zero for starting) - engage starter After it's running I flip the master up to the "both" (battery + alt) position and check volts/amps. I don't think there would be any harm in going right to the "both" position before starting, but this method helps force me to check volts/amps after turning on the alternator (B&C L40). By the way (off topic), I just want to express more thanks to Bob for all the help during the construction process and for the excellent book. I followed your guidelines and have what sure seems to be reliable, noise-free system. About 35 hours and counting. Now if you happen to have a trick to make my Airflow Performance high-pressure fuel pump consume less power, I'm all ears!! 8-) )_( Dan RV-7 N714D http://www.rvproject.com ----- Original Message ----- From: <BFlood@Sauer-Danfoss.com> Subject: AeroElectric-List: Ignitions/Starting > > > To all of you with 1 electronic ignition and one mag - I am assuming the > remaining mag does not have an impulse coupling. So your starting procedure > would be to turn on both the mag and electronic ignition and then start? or > just use the electronic ignition for start? Which leads to my next > question... how do you handle the key switch? Does it just lock out the > starter or do you also disable the electronic ignition to prevent hand > propping (if possible) or is there some type of special switch being used > to switch off both the mag and electronic ignition? I am planning to have > normal switches for the ignitions but a simple key switch for security. So > my best idea yet is to have a key switch to lock out the electronic > ignition and starter and then separate switches for mag/electronic/start. > Essentially the mag could be made hot with only the switch, but then the > plane would be hard to start without the impulse coupling. > > Am I on the right track here? What have you done - Why? > > Thanks, > > Bryan > > ________________________________________________________________________________
Date: Apr 15, 2004
Bob, I was about to reply but saw that someone else already caught it...you just misread my post. I agree that the SD-8 is a good system and wasn't trying to make a big deal out of cost/weight/engine power savings, which are marginal differences. My main point to the original question was if I saw any potential problems with an IFR machine that uses dual alternators tied to a single battery. Your own advice to me when asking the same questions about a year ago was that dual batteries, single alternator was more RELIABLE especially for dual electronic ignition, but of course you lose the ability to have unlimited duration that you have with the dual alternator, single battery system. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing From: "Richard E. Tasker" <retasker(at)optonline.net> Subject: Re: AeroElectric-List: Re: Architecure Choices Uuuh, Bob. You read his post wrong. What he said was: >>This gives up the advantage of having unlimited juice . . . >> >> Meaning, he is choosing to use batteries and one alternator - resulting in limited juice. > > . . . unlimited? That must be a really BIG battery. > Likewise. Other than that, your comments are right on. Dick Tasker ________________________________________________________________________________
Date: Apr 15, 2004
Matt, You say you hand-prop your O-200. So do I, and I just installed a LSE Plasma III. It seems to start hard when the engine is cold. I have high compression pistons and it doesn't seem to go over the next compression stroke very easily, unless I open the throttle wider than I like to. It starts a lot easier if it's hot. Have you had any experience like this? I thought starting was going to be easier, but so far that's not the case. Sam Quickie Q-200 ~ 1,350 hrs. http://home.mchsi.com/~shoskins/index.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Subject: Re: AeroElectric-List: Ignitions/Starting Hi Bryan, Embedded comments... > > > To all of you with 1 electronic ignition and one mag - I am assuming the > remaining mag does not have an impulse coupling. Magnetos without impulse coupling (or some other method to retard the spark timing) are not suitable for starting. > So your starting > procedure would be to turn on both the mag and electronic ignition and > then start? or just use the electronic ignition for start? Both of the mags on my O-200 had impulse couplings... So, I used to turn both of them on when starting. Not unusual. Now, with one electronic ignition, I still turn both systems on, as they both properly retard the spark timing for starting. > Which leads > to my next question... how do you handle the key switch? No key switch. Removed. Using 2 toggle switches. > Does it just > lock out the starter or do you also disable the electronic ignition to > prevent hand propping (if possible) My airplane doesn't have a starter. Hand propping is the only way to make it go. Being able to hand prop might be useful, even on airplanes with starters. > or is there some type of special > switch being used to switch off both the mag and electronic ignition? The p-lead on magnetos needs to be disconnected to run, and shorted to not run. Most electronic ignition systems require the oposite conditions, ie they need to have 12V connected in order to run. I believe Klaus offers an option on some of his systems to be able to work with a normal magneto key switch, though he recommends using toggle switches instead. > I > am planning to have normal switches for the ignitions but a simple key > switch for security. Secure from what? Accidental starter engagement or from theft? I don't think a normal key switch provides any protection from either problem. I suppose that a key switch might discourage a joy rider, but I think that's about it. > So my best idea yet is to have a key switch to lock > out the electronic ignition and starter and then separate switches for > mag/electronic/start. Essentially the mag could be made hot with only > the switch, but then the plane would be hard to start without the > impulse coupling. The only way I can think to wire up what you are talking about involves essentially two electrical disconnects for engine ignition. I don't think I would choose to sacrifice in flight reliability to gain on the ground security. For security, as someone (Bob?) suggests, get one of those heavy padded chains with a high quality padlock, and figure-eight it around the propellor. > > Am I on the right track here? What have you done - Why? > > Thanks, > > Bryan > Regards, Matt- N34RD ________________________________________________________________________________
Date: Apr 15, 2004
Bryan It is imperative that any magneto has either a spark retard device (impulse coupling, shower o sparks, etc) or is inoperative while starting. You always want your start timing to be close to 0 deg, TDC. You DON'T want to have an advanced spark when the engine is turning slowly, during the start phase. An advanced spark at slow speeds can cause kickback, which is damaging to starters. Sam -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BFlood@Sauer-Danfoss.com Subject: AeroElectric-List: Ignitions/Starting To all of you with 1 electronic ignition and one mag - I am assuming the remaining mag does not have an impulse coupling. So your starting procedure would be to turn on both the mag and electronic ignition and then start? or just use the electronic ignition for start? Which leads to my next question... how do you handle the key switch? Does it just lock out the starter or do you also disable the electronic ignition to prevent hand propping (if possible) or is there some type of special switch being used to switch off both the mag and electronic ignition? I am planning to have normal switches for the ignitions but a simple key switch for security. So my best idea yet is to have a key switch to lock out the electronic ignition and starter and then separate switches for mag/electronic/start. Essentially the mag could be made hot with only the switch, but then the plane would be hard to start without the impulse coupling. Am I on the right track here? What have you done - Why? Thanks, Bryan ________________________________________________________________________________
Date: Apr 15, 2004
Hi Dale, To answer your question, very few of us have had battery failure. It's pretty rare, and many people may be comfortable with a single battery in an all-electric airplane (i.e. dual elec. ignition and IFR panel with no vacuum). Personally, I'm NOT comfortable with having all that at stake in a single battery. There have been a few battery failures reported here on this List over the past few years I've followed it, and several people I've talked to have had it happen in cars. I'm talking catastrauphic failure, where the lead or post breaks off, or something happens to the battery itself rendering the whole electrical system dead. I know, I know...they were probably poorly designed installations and/or poorly maintained, and if you have a well-designed installation without stressing the battery leads/terminals, with an RG battery rotated out every other year, the odds of failure are probably reduced to very slim. But in my case I decided to go with a small aux battery to k eep my second ignition alive in the ulikely event that it's needed. Each person can decide for their airplane and mission what they're comfortable with. --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing... From: "Dale Martin" <niceez(at)cableone.net> Subject: Re: AeroElectric-List: A panel full of displays . . . With all due respect...... how many of us have a had a battery failure? I cannot believe that some of you intend medium to hard IFR with some of our homebuilts. First consider empennage, wing and prop anti icing equipment first.... Then I'll believe you need all the rest of the equipment. One battery will due if it is the proper quality..... Just my opinion, Dale Martin Lewiston, ID LEZ-235 ________________________________________________________________________________
Date: Apr 15, 2004
Hi Sam, I have stock pistons in my O-200. It was pretty easy to start with 2 mags, and somewhat easier to start with the swapout to an LSE and a mag. Mine is easier to start when its cold, but only because it is pretty easy to flood when hot. Does your carb have an accelerator pump or primer? The way I start mine when cold is to pump the throttle (not primer equipped) 2-3 times. Then, with all of the switches off, pull 4 blades through. All switches on, and it ALMOST always starts on the first pull. When hot, the easiest starting is had by shutting down via the ignition switch, not the mixture control. When ready to go, switches on, and it usually starts again on the first pull. If I shut down via mixture and have to restart, I usually give it about a half pump on the throttle, switches hot, and then most of the time it runs on the 2nd pull. I am not sure what I would do different if I had hi compression pistons. I'll have to think about that. Does the engine fire once but not make it through to the next stroke? Or does it not spark at all? Do you have the prop 'clocked' to a position where you can get a good hard flip on it? Regards, Matt- N34RD > > > Matt, > You say you hand-prop your O-200. So do I, and I just installed a LSE > Plasma III. It seems to start hard when the engine is cold. I have > high compression pistons and it doesn't seem to go over the next > compression stroke very easily, unless I open the throttle wider than I > like to. It starts a lot easier if it's hot. > Have you had any experience like this? I thought starting was going to > be easier, but so far that's not the case. > Sam > Quickie Q-200 ~ 1,350 hrs. > http://home.mchsi.com/~shoskins/index.htm > ________________________________________________________________________________
Date: Apr 15, 2004
Dan, one other reason to stay in the battery-only position prior to start is that in BOTH you are supplying about 2-3 amps to the alternator field circuit, which is robbing power from your starter. I think it prolongs the life of your battery too to not load it down more than neccessary during a start. On my RV-4 the ammeter happens to be on the battery so you can actually see the 2-3 amps kick in when going to BOTH on the master switch. You probably knew this, but it might help someone else who might not. Pat Hatch RV-4 RV-6 RV-7 Finishing Kit Vero Beach, FL ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Re: AeroElectric-List: Ignitions/Starting > > On my RV-7 I have one Slick impulse coupled mag and one LightSpeed Plasma > II. From what I understand, the LSE retards to zero (TDC) for starting. So > I use both ignition sources at startup and the thing fires on the first > blade when cold, first few blades when hot & purged. > > Whenever starting, I do this (after any required priming is complete): > > - master switch on battery only (all 3 buses powered on) > - mag switch on (impulse coupler enables starting) > - Lightspeed switch on (timing retarded to zero for starting) > - engage starter > > After it's running I flip the master up to the "both" (battery + alt) > position and check volts/amps. I don't think there would be any harm in > going right to the "both" position before starting, but this method helps > force me to check volts/amps after turning on the alternator (B&C L40). > > By the way (off topic), I just want to express more thanks to Bob for all > the help during the construction process and for the excellent book. I > followed your guidelines and have what sure seems to be reliable, noise-free > system. About 35 hours and counting. > > Now if you happen to have a trick to make my Airflow Performance > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > )_( Dan > RV-7 N714D > http://www.rvproject.com > > ----- Original Message ----- > From: <BFlood@Sauer-Danfoss.com> > To: > Subject: AeroElectric-List: Ignitions/Starting > > > > > > > > To all of you with 1 electronic ignition and one mag - I am assuming the > > remaining mag does not have an impulse coupling. So your starting > procedure > > would be to turn on both the mag and electronic ignition and then start? > or > > just use the electronic ignition for start? Which leads to my next > > question... how do you handle the key switch? Does it just lock out the > > starter or do you also disable the electronic ignition to prevent hand > > propping (if possible) or is there some type of special switch being used > > to switch off both the mag and electronic ignition? I am planning to have > > normal switches for the ignitions but a simple key switch for security. So > > my best idea yet is to have a key switch to lock out the electronic > > ignition and starter and then separate switches for mag/electronic/start. > > Essentially the mag could be made hot with only the switch, but then the > > plane would be hard to start without the impulse coupling. > > > > Am I on the right track here? What have you done - Why? > > > > Thanks, > > > > Bryan > > > > > > ________________________________________________________________________________
Date: Apr 15, 2004
> >Dan, one other reason to stay in the battery-only position prior to start is >that in BOTH you are supplying about 2-3 amps to the alternator field >circuit, which is robbing power from your starter. I think it prolongs the >life of your battery too to not load it down more than neccessary during a >start. On my RV-4 the ammeter happens to be on the battery so you can >actually see the 2-3 amps kick in when going to BOTH on the master switch. >You probably knew this, but it might help someone else who might not. This use to be the standard advice on certified ships that it was good practice to leave the alternator and other things OFF during cranking to "save the battery". In the grand scheme of things, adding a few percent more load to a 200+ amp cranking event doesn't have much influence on battery life. Keeping the engine tuned and developing techniques that get the fires lit in a few blades is more beneficial than shaving a few amps of total loads. > > > > Now if you happen to have a trick to make my Airflow Performance > > high-pressure fuel pump consume less power, I'm all ears!! 8-) What are the physics of your pump operation? I designed a pump controller about 20 years ago for a pump that was originally designed to deliver constant pressure to an engine by means of a relief valve. During periods of low fuel flow, the relief valve cracked and ported excess flow back to tank. Simple system but use max power under all fuel flow conditions. By adding an accumulator/transducer combination downstream of the pump, power to the pump motor was throttled to maintain constant pressure at any flow. Result was very low power consumption at low fuel flows and max power needed only during full-rich, max throttle climbs. Cut power consumption by about half for most operations and increased pump brush life by three or four times. Bob . . . ________________________________________________________________________________
Date: Apr 15, 2004
Matt, I have been hand-propping this aircraft for 15 years, and probably have as many starts as hours. Probably 1,330+ I have an MA3 carb, plus a primer to the intake spider manifold. Both seem to do the same. I start mine much like you do, however with the substitution of the Plasma III starting seems to have gotten harder. It doesn't like to make it over the compression stroke after I release the blade. I attribute that to the high compression pistons, but it has gotten worse with the LSE. Sam -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Subject: RE: AeroElectric-List: Ignitions/Starting Hi Sam, I have stock pistons in my O-200. It was pretty easy to start with 2 mags, and somewhat easier to start with the swapout to an LSE and a mag. Mine is easier to start when its cold, but only because it is pretty easy to flood when hot. Does your carb have an accelerator pump or primer? The way I start mine when cold is to pump the throttle (not primer equipped) 2-3 times. Then, with all of the switches off, pull 4 blades through. All switches on, and it ALMOST always starts on the first pull. When hot, the easiest starting is had by shutting down via the ignition switch, not the mixture control. When ready to go, switches on, and it usually starts again on the first pull. If I shut down via mixture and have to restart, I usually give it about a half pump on the throttle, switches hot, and then most of the time it runs on the 2nd pull. I am not sure what I would do different if I had hi compression pistons. I'll have to think about that. Does the engine fire once but not make it through to the next stroke? Or does it not spark at all? Do you have the prop 'clocked' to a position where you can get a good hard flip on it? Regards, Matt- N34RD > > > Matt, > You say you hand-prop your O-200. So do I, and I just installed a LSE > Plasma III. It seems to start hard when the engine is cold. I have > high compression pistons and it doesn't seem to go over the next > compression stroke very easily, unless I open the throttle wider than I > like to. It starts a lot easier if it's hot. > Have you had any experience like this? I thought starting was going to > be easier, but so far that's not the case. > Sam > Quickie Q-200 ~ 1,350 hrs. > http://home.mchsi.com/~shoskins/index.htm > ________________________________________________________________________________
Date: Apr 15, 2004
> > > Now if you happen to have a trick to make my Airflow Performance > > > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > What are the physics of your pump operation? I designed a pump controller > about 20 years ago for a pump that was originally designed to deliver > constant pressure to an engine by means of a relief valve. During > periods of low fuel flow, the relief valve cracked and ported > excess flow back to tank. Simple system but use max power under > all fuel flow conditions. By adding an accumulator/transducer > combination downstream of the pump, power to the pump motor > was throttled to maintain constant pressure at any flow. Result > was very low power consumption at low fuel flows and max power > needed only during full-rich, max throttle climbs. > > Cut power consumption by about half for most operations and > increased pump brush life by three or four times. That sure sounds good to me. I'm not too familiar with the inner workings of the AFP pump & bypass valve setup, but I have to assume it's roughly the first setup you described above (constant pump operation at full blast + relief valve). I do have a fuel flow transducer downstream of the pump, of course in use & wired to my ACS2002 monitor. Not sure if that could do double duty, or how complex the "throttle" circuit would be. I don't have the knowledge or skills to design something like this on my own, but if you're aware of a simple, affordable method I'd love to learn about it. Even if the final answer ends up being that I just live with what I've got, I'm still interested in finding out about alternatives for fun. Thanks, )_( Dan ________________________________________________________________________________
Date: Apr 15, 2004
I am quite sure I remember a few months ago we were talking on this list about the idea that the Airflow Performance fuel pump is actually usually just a back-up to the engine driven mechanical pump; that unless something goes wrong with the engine driven pump, the Airflow Performance pump is turned on during takeoff and landing only as a safety precaution in case the mechanical pump fails during those critical times. I think Eric had or offered to design a fuel pump switch that would only turn the boost pump on if the fuel pressure dropped, or if the switch was put in the on regardless position. In other words, it would always be ready to turn on if needed but would not normally be running during takeoff and landing unless the pilot chose the override position. So, it would seem the best way to make the pump consume less power would be to use a switch like Eric suggested, leaving the pump off unless it was actually needed to create the needed fuel pressure. Do I remember this right? Terry > > > Now if you happen to have a trick to make my Airflow Performance > > > high-pressure fuel pump consume less power, I'm all ears!! 8-) > ________________________________________________________________________________
Date: Apr 16, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
I talked to Klaus a while back and if you dont spin the prop fast enough, you are correct it will be more difficult to start. > >Matt, I have been hand-propping this aircraft for 15 years, and probably >have as many starts as hours. Probably 1,330+ >I have an MA3 carb, plus a primer to the intake spider manifold. Both seem >to do the same. I start mine much like you do, however with the >substitution of the Plasma III starting seems to have gotten harder. It >doesn't like to make it over the compression stroke after I release the >blade. I attribute that to the high compression pistons, but it has gotten >worse with the LSE. > >Sam > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt >Prather >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: Ignitions/Starting > > >Hi Sam, > >I have stock pistons in my O-200. It was pretty easy to start with 2 >mags, and >somewhat easier to start with the swapout to an LSE and a mag. Mine is >easier >to start when its cold, but only because it is pretty easy to flood when >hot. > >Does your carb have an accelerator pump or primer? > >The way I start mine when cold is to pump the throttle (not primer >equipped) 2-3 >times. Then, with all of the switches off, pull 4 blades through. All >switches on, >and it ALMOST always starts on the first pull. > >When hot, the easiest starting is had by shutting down via the ignition >switch, not >the mixture control. When ready to go, switches on, and it usually starts >again >on the first pull. If I shut down via mixture and have to restart, I >usually give it >about a half pump on the throttle, switches hot, and then most of the time >it runs >on the 2nd pull. > >I am not sure what I would do different if I had hi compression pistons. >I'll have >to think about that. Does the engine fire once but not make it through to >the next >stroke? Or does it not spark at all? Do you have the prop 'clocked' to a >position >where you can get a good hard flip on it? > >Regards, > >Matt- >N34RD > >> >> >> Matt, >> You say you hand-prop your O-200. So do I, and I just installed a LSE >> Plasma III. It seems to start hard when the engine is cold. I have >> high compression pistons and it doesn't seem to go over the next >> compression stroke very easily, unless I open the throttle wider than I >> like to. It starts a lot easier if it's hot. >> Have you had any experience like this? I thought starting was going to >> be easier, but so far that's not the case. >> Sam >> Quickie Q-200 ~ 1,350 hrs. >> http://home.mchsi.com/~shoskins/index.htm >> > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "David Swartzendruber" <dswartzendruber(at)earthlink.net>
Date: Apr 16, 2004
Better yet, take Bob's fuel pump controller and set the fuel pressure setpoint a little lower than what the engine driven pump normally produces. You could leave the electric pump turned on all the time and it would only run when needed. If the engine driven pump could not produce enough pressure due to low engine rpm or failure, the electric pump would automatically pick up the slack. An appropriate indicator light could tell you when the electric pump was running. Dave > > > > I am quite sure I remember a few months ago we were talking on this list > about the idea that the Airflow Performance fuel pump is actually usually > just a back-up to the engine driven mechanical pump; that unless something > goes wrong with the engine driven pump, the Airflow Performance pump is > turned on during takeoff and landing only as a safety precaution in case > the > mechanical pump fails during those critical times. I think Eric had or > offered to design a fuel pump switch that would only turn the boost pump > on > if the fuel pressure dropped, or if the switch was put in the on > regardless > position. In other words, it would always be ready to turn on if needed > but > would not normally be running during takeoff and landing unless the pilot > chose the override position. > > So, it would seem the best way to make the pump consume less power would > be > to use a switch like Eric suggested, leaving the pump off unless it was > actually needed to create the needed fuel pressure. Do I remember this > right? > > Terry > > > > > > > > Now if you happen to have a trick to make my Airflow Performance > > > > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > ________________________________________________________________________________
Date: Apr 16, 2004
Subject: Max load of a KLN-88 ?
Long story, but I'm looking for the max load (amps) for a KLN-88 Loran. Reply to list or privately to pascal(at)aeroteknic.com . Thanks. -Pascal ________________________________________________________________________________
Subject: Airflow Performance HP Pump
Date: Apr 16, 2004
I will be using this same pump in my installation Dan. What is the power comsumption? You only use it for takeoff and landing dont you? Thanks, Rod Smith > Now if you happen to have a trick to make my Airflow Performance > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > )_( Dan > RV-7 N714D > http://www.rvproject.com ________________________________________________________________________________
Subject: Fuel Pump Optimization (was Ignitions/Starting)
Date: Apr 16, 2004
I also think there'd be value in encorporating a "manual override" mode, where the operator can force the pump into continuous full duty. Maybe a progressive xfer switch...up halfway is "AUTO" and up all the way is "ON". )_( Dan ----- Original Message ----- From: "David Swartzendruber" <dswartzendruber(at)earthlink.net> Subject: RE: AeroElectric-List: Ignitions/Starting > > Better yet, take Bob's fuel pump controller and set the fuel pressure > setpoint a little lower than what the engine driven pump normally > produces. You could leave the electric pump turned on all the time and > it would only run when needed. If the engine driven pump could not > produce enough pressure due to low engine rpm or failure, the electric > pump would automatically pick up the slack. An appropriate indicator > light could tell you when the electric pump was running. > > Dave > > > > > > > > > I am quite sure I remember a few months ago we were talking on this > list > > about the idea that the Airflow Performance fuel pump is actually > usually > > just a back-up to the engine driven mechanical pump; that unless > something > > goes wrong with the engine driven pump, the Airflow Performance pump > is > > turned on during takeoff and landing only as a safety precaution in > case > > the > > mechanical pump fails during those critical times. I think Eric had > or > > offered to design a fuel pump switch that would only turn the boost > pump > > on > > if the fuel pressure dropped, or if the switch was put in the on > > regardless > > position. In other words, it would always be ready to turn on if > needed > > but > > would not normally be running during takeoff and landing unless the > pilot > > chose the override position. > > > > So, it would seem the best way to make the pump consume less power > would > > be > > to use a switch like Eric suggested, leaving the pump off unless it > was > > actually needed to create the needed fuel pressure. Do I remember this > > right? > > > > Terry > > > > > > > > > > > > > Now if you happen to have a trick to make my Airflow Performance > > > > > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > > > > ________________________________________________________________________________
Subject: Re: Fuel Pump Optimization (was Ignitions/Starting)
Date: Apr 16, 2004
Oh yeah, forgot...and a warning light circuit, so you could have a lamp on the panel illuminate whenever the system is in AUTO mode and the pump is operating. It would essentially be a "your mechanical fuel pump is failing" dummy light. Otherwise you might not tune into the situation, since your indicated fuel pressure probably wouldn't really dip if the electric pump "saved it." )_( Dan ----- Original Message ----- From: "Dan Checkoway" <dan(at)rvproject.com> Subject: Fuel Pump Optimization (was Ignitions/Starting) > I also think there'd be value in encorporating a "manual override" mode, > where the operator can force the pump into continuous full duty. Maybe a > progressive xfer switch...up halfway is "AUTO" and up all the way is "ON". > > )_( Dan > > ----- Original Message ----- > From: "David Swartzendruber" <dswartzendruber(at)earthlink.net> > To: > Sent: Friday, April 16, 2004 6:33 AM > Subject: RE: AeroElectric-List: Ignitions/Starting > > > > > > > Better yet, take Bob's fuel pump controller and set the fuel pressure > > setpoint a little lower than what the engine driven pump normally > > produces. You could leave the electric pump turned on all the time and > > it would only run when needed. If the engine driven pump could not > > produce enough pressure due to low engine rpm or failure, the electric > > pump would automatically pick up the slack. An appropriate indicator > > light could tell you when the electric pump was running. > > > > Dave > > > > > > > > > > > > > > I am quite sure I remember a few months ago we were talking on this > > list > > > about the idea that the Airflow Performance fuel pump is actually > > usually > > > just a back-up to the engine driven mechanical pump; that unless > > something > > > goes wrong with the engine driven pump, the Airflow Performance pump > > is > > > turned on during takeoff and landing only as a safety precaution in > > case > > > the > > > mechanical pump fails during those critical times. I think Eric had > > or > > > offered to design a fuel pump switch that would only turn the boost > > pump > > > on > > > if the fuel pressure dropped, or if the switch was put in the on > > > regardless > > > position. In other words, it would always be ready to turn on if > > needed > > > but > > > would not normally be running during takeoff and landing unless the > > pilot > > > chose the override position. > > > > > > So, it would seem the best way to make the pump consume less power > > would > > > be > > > to use a switch like Eric suggested, leaving the pump off unless it > > was > > > actually needed to create the needed fuel pressure. Do I remember this > > > right? > > > > > > Terry > > > > > > > > > > > > > > > > > > Now if you happen to have a trick to make my Airflow Performance > > > > > > high-pressure fuel pump consume less power, I'm all ears!! 8-) > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Apr 16, 2004
> I will be using this same pump in my installation Dan. What is the power > comsumption? You only use it for takeoff and landing dont you? Yeah, just t/o, ldg, and switching tanks (low wing). It's supposed to draw 5A at 12V (I read that somewhere), but it seems to draw at least that much. I can try to nail down a more exact figure later today. I'm basing this on the observed rise in the amps reading on my ACS2002, which derives the amps/load from the hall effect sensor around the wire running from my alternator to the battery (technically to the starter contactor, but you know what I mean). )_( Dan RV-7 N714D http://www.rvproject.com ________________________________________________________________________________
Date: Apr 16, 2004
For the record - the single battery, single alternator, single E.I. system with all electric is not a gamble. On that sad day when the alternator freaks out I have the battery and one ignition that's "keeps on going," so I still make it to a facility for a repair. In case of a battery failure same scenario but the alternator supplies power and I make it to tera firma in great shape. BTW, two E.I.'s is not the most economic or lightest and it darn sure is not the best performance. In the case of a total electrical system failure the mag is still keeping the airplane moving to an airport and we are fine. After 17 years of flying this IFR capable "air-chine" and the last nine years with one E.I. I really don't get the fear. If your talking hard IFR and pretty sure your not, the systems I see in many of these new airplanes is a waste. This is the opinion of many of "People who are flying experimentals" and not building. Bob has designed some pretty great systems and taking advantage of his skillful designs would make anyone very safe. The big difference in my focus and Bob K's is that he wants to make the intended destination. Myself I want to just back on the ground and not need to change my drawers ;-)) Dale Martin Lewiston, ID LEZ-235 ----- Original Message ----- From: <czechsix(at)juno.com> Subject: Re: AeroElectric-List: A panel full of displays . . . > > > Hi Dale, > > To answer your question, very few of us have had battery failure. It's pretty rare, and many people may be comfortable with a single battery in an all-electric airplane (i.e. dual elec. ignition and IFR panel with no vacuum). Personally, I'm NOT comfortable with having all that at stake in a single battery. There have been a few battery failures reported here on this List over the past few years I've followed it, and several people I've talked to have had it happen in cars. I'm talking catastrauphic failure, where the lead or post breaks off, or something happens to the battery itself rendering the whole electrical system dead. I know, I know...they were probably poorly designed installations and/or poorly maintained, and if you have a well-designed installation without stressing the battery leads/terminals, with an RG battery rotated out every other year, the odds of failure are probably reduced to very slim. But in my case I decided to go with a small aux battery to k > eep my second ignition alive in the ulikely event that it's needed. Each person can decide for their airplane and mission what they're comfortable with. > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D finishing... > > From: "Dale Martin" <niceez(at)cableone.net> > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > With all due respect...... how many of us have a had a battery failure? I > cannot believe that some of you intend medium to hard IFR with some of our > homebuilts. First consider empennage, wing and prop anti icing equipment > first.... Then I'll believe you need all the rest of the equipment. > > One battery will due if it is the proper quality..... > > Just my opinion, > > Dale Martin > Lewiston, ID > LEZ-235 > > ________________________________________________________________________________
Date: Apr 16, 2004
Ignitions/Starting) Dan if your at Boreggo this Sat we can compare amp draw. I plan to get there at noon. Other wise I will make it a point to write down how much I am pulling. Have you called AFP? > >> I will be using this same pump in my installation Dan. What is the power >> comsumption? You only use it for takeoff and landing dont you? > >Yeah, just t/o, ldg, and switching tanks (low wing). It's supposed to draw >5A at 12V (I read that somewhere), but it seems to draw at least that much. >I can try to nail down a more exact figure later today. > >I'm basing this on the observed rise in the amps reading on my ACS2002, >which derives the amps/load from the hall effect sensor around the wire >running from my alternator to the battery (technically to the starter >contactor, but you know what I mean). > >)_( Dan >RV-7 N714D >http://www.rvproject.com > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
From: "Malcolm Thomson" <mdthomson(at)attglobal.net>
Subject: MOV?
Date: Apr 16, 2004
What are the MOV's referred to in the LA1VP WireBook example. I am starting to use this wirebook as a starting point for my Thunder Mustang. I noticed some contactors have MOV's on them but most have nothing across the coil of the contactor. What happened to using the small diodes across the coil as shown in most of the "Z" drawings? Also, where is there information on the "transient suppressor" shown in the LA1VP wirebook. Thanks. ________________________________________________________________________________
Date: Apr 16, 2004
Subject: dielectric grease
Bob, Where is dielectric grease needed and where should it be avoided? I have read your book and CD, both are excellent. Most likely the best specialty text I have ever seen. I would advise anyone building a small aircraft for the first time to read it no matter how advanced their electrical skills are. Brett __________________________________ ________________________________________________________________________________
Date: Apr 16, 2004
Subject: Re: MOV?
Malcolm Thomson wrote: > > What are the MOV's referred to in the LA1VP WireBook example. I am > starting to use this wirebook as a starting point for my Thunder > Mustang. I noticed some contactors have MOV's on them but most have > nothing across the coil of the contactor. What happened to using the > small diodes across the coil as shown in most of the "Z" drawings? > > Also, where is there information on the "transient suppressor" shown in > the LA1VP wirebook. It's probably out of date. MOV stands for "Metal Oxide Varistor," and it's basically a transient suppressor. There's a nice little graph of what a MOV does here: http://www.fujisemiconductor.com/test_web/mov/ Between certain limit voltages, it does nothing. If the voltage exceeds a preset point (you buy the MOV rated for this voltage) it starts conducting, basically shorting out the transient. They're often used in those cheap 6-outlet strips. They have their charms, but also some problems. Remember, this sucker is shorting itself out - if your bus can supply the amps, it could pass several hundred through the MOV. Toasty. That's why those 6-outlet el-cheapo strips are a bad idea. Once a surge has been blocked, you commonly lose your protection against future surges. For a contactor the best option is the diode. For real overvoltage protection, a crowbar device is faster and since they're usually SCR-based they shouldn't destroy themselves protecting you (provided they're being used as recommended, to blow a fuse or trip a breaker and shut down the alternator, the primary source of overvoltage events). This page has a nice summary of some of the benefits and drawbacks of various TVS devices: http://www.okaya.com/FAQ3.html Regards, Chad ________________________________________________________________________________
Date: Apr 16, 2004
Subject: Re: MOV?
Hi Malcolm - Greg mentioned at Sun N Fun that you are starting to wire your airplane. We are almost there and have used the L IV wirebook as a starter. As you may recall, we are using Bob's Z14 system (dual alternators and dual batteries). I added a ground power module to that and a couple of other small changes. I asked Bob some time ago about the MOV's and he said that they are no longer used in any of his recommended systems. Diodes are used now. You can download most of the system diagrams from his website. Good luck with your system and keep us posted. Cheers, John PS: Our EFIS/ONE is being shipped next week! ________________________________________________________________________________
Subject: Endurance Bus
Date: Apr 17, 2004
Recently I have noticed posts referring to an endurance bus, Is this the same as the essential bus? I have Bobs book and I see no mention of an endurance bus. Wondering if these terms referring to the same thing. Thanks Gerry ________________________________________________________________________________
Date: Apr 17, 2004
I think Bob decided "endurance bus" better reflected his philosophy of what the essential bus was all about. Terry Recently I have noticed posts referring to an endurance bus, Is this the same as the essential bus? I have Bobs book and I see no mention of an endurance bus. Wondering if these terms referring to the same thing. Thanks Gerry ________________________________________________________________________________
Date: Apr 17, 2004
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: dielectric grease
> >Bob, > >Where is dielectric grease needed and where should it >be avoided? > >I have read your book and CD, both are excellent. >Most likely the best specialty text I have ever seen. >I would advise anyone building a small aircraft for >the first time to read it no matter how advanced their >electrical skills are. Thank you for the kind words. I'm pleased that you found the work so useful. I presume you're referring to the various forms of ukum-yucky that propose to increase the transfer of heat from solid state devices to their mounting surface, usually some kind of heat sink. I haven't used any in a new design for over 20 years. There are heat-transfer, gasket-like materials that can be cut to shape, punched for holes and go on dry. See http://www.bergquistcompany.com for an exemplar product offered by Bergquist It occurs to me that you may be asking about the silcone greases popular for waterproofing. Dow Corning DC-4 has been around for 40+ years. When I was in the 2-way radio business, we would fill the interface of coax connectors on a tower with DC-4 before assembly. It would keep the moisture out of the connector. Did a net-search on the stuff and found several instances where DC-4 was recommended for moisture proofing connectors or aiding in their assembly. Here's a few . . . http://www.ramaircraft.com/Catalog/SB&AD/ramsl200001.htm http://www.lambda-emi.com/product_html/500aresource.htm http://skymate.hosting4less.com/downloadables/SkyMate%20100%20Owners%20Guide-VMS.pdf http://www.amphenolrf.com/products/AssemblyInstructions/hn.pdf http://www.dielectric.com/broadcast/instruction_booklets/IB162-A.pdf I guess I'm not a really big user of DC-4. I think the tube I have was purchased when I was in the radio business . . . about 1963. Itty-bitty amounts go a very long way. My 3 oz tube is still about half full. Bob . . . ________________________________________________________________________________
Subject: Aileron trim cable routing
Date: Apr 18, 2004
Hi Bob and all, Our project incorporates a small aileron mounted RAC Trim servo. My problem is, how do I best connect this trim through the aileron leading edge to the adjacent fixed portion of the wing ? The goal is to minimize wire flexing in spite of the aileron movements ? I have the feeling I should provide some ample wire loop to insure very light local flexing, but how could I achieve that ? Space between the aileron and the wing is rather restricted. Thanks for any opinion, Regards, Gilles Thesee Grenoble, France ________________________________________________________________________________
Date: Apr 18, 2004
Subject: Re: MOV?
> > >Hi Malcolm - > >Greg mentioned at Sun N Fun that you are starting to wire your airplane. >We are almost there and have used the L IV wirebook as a starter. As you >may recall, we are using Bob's Z14 system (dual alternators and dual >batteries). I added a ground power module to that and a couple of other >small changes. > >I asked Bob some time ago about the MOV's and he said that they are no >longer used in any of his recommended systems. Diodes are used now. You >can download most of the system diagrams from his website. MOV's were attractive to me when I began writing the book 15 years ago. They were bi-directional devices meaning that you couldn't hook one up backwards. But they were also difficult to find in very low voltage ratings and didn't do as good a job as the diode which is available virtually everywhere. The only caveat is that you gotta pay attention to the banded end and hook them up right. See later versions of those wiring diagrams in Appendix Z of the current publication which you can download at http://www.aeroelectric.com/articles/Rev10/z10.pdf if you don't have the book. Bob . . . ________________________________________________________________________________
Subject: DC-4
Date: Apr 18, 2004
Bob, I feel you have given this OBAM-friendly product short shrift. Strange to say (but true) DC-4 is specified for use as a gasket dresser when changing your champion oil filter on the Lycoming ! It will insure the filter will come off easily at change time. Don't be too generous with it as I am told the silicon will distort your oil sample spectographic analysis. So go ahead and buy a big tube of that marvelous stuff. I use it for the spark plug wires which go into holes and need moisture protection too. One other use is the #@**# nose tire on the RV 'A' models. These chin sein tires get bonded to the wheel and won't come off, so I put some DC-4 on the rims during assembly. I am afraid to put it on the mains. It would be my luck to hit the brakes real hard one day and have the tires spin around, and pinch off the tube filler neck, rendering me in the weeds. It is also great for persuading rubber or silicone things to go together. I am sure others can come up with lots of uses where a heat resistant lubricant/moisture barrier is needed which does not harm rubber or conduct electricity. Denis On Apr 17, 2004, at 8:25 PM, Robert L. Nuckolls, III wrote: > > > It occurs to me that you may be asking about the > silcone greases popular for waterproofing. Dow Corning > DC-4 has been around for 40+ years. When I was in > the 2-way radio business, we would fill the interface > of coax connectors on a tower with DC-4 before > assembly. It would keep the moisture out of the > connector. Did a net-search on the stuff and found > several instances where DC-4 was recommended for > moisture proofing connectors or aiding in their > assembly. Here's a few . . . > > http://www.ramaircraft.com/Catalog/SB&AD/ramsl200001.htm > http://www.lambda-emi.com/product_html/500aresource.htm > http://skymate.hosting4less.com/downloadables/ > SkyMate%20100%20Owners%20Guide-VMS.pdf > http://www.amphenolrf.com/products/AssemblyInstructions/hn.pdf > http://www.dielectric.com/broadcast/instruction_booklets/IB162-A.pdf > > I guess I'm not a really big user of DC-4. I think > the tube I have was purchased when I was in the radio > business . . . about 1963. Itty-bitty amounts go a > very long way. My 3 oz tube is still about half full. > > Bob . . . > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
Date: Apr 18, 2004
Subject: Re: Aileron trim cable routing
In a message dated 4/18/04 8:06:10 AM Central Daylight Time, Gilles.Thesee@ac-grenoble.fr writes: I have the feeling I should provide some ample wire loop to insure very light local flexing, but how could I achieve that ? Good Morning Gilles, Is there room to run the wire parallel to the hinge line for a little way? I have used that method to give a wire adequate flexibility when a loop would not be practical. The length of wire can even be lightly supported along it's length if that need be. All you have to do is run it through a support that does not bind it down solidly. As long as the wire is free to twist, all of the motion will be absorbed by the torsion of the wire instead of as a bending moment. A six inch length of number twenty or twenty two can stand a lot of twisting without any damage at all. The longer, the better. Works for me! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 18, 2004
Subject: Re: AeroElectric-List Digest: 13 Msgs - 04/16/04
Dale, a few more comments below: > From: "Dale Martin" <niceez(at)cableone.net> > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > For the record - the single battery, single alternator, single E.I. > system with all electric is not a gamble. On that sad day when the > alternator freaks out I have the battery and one ignition that's "keeps on > going," so I still make it to a facility for a repair. Agree 100% for VFR flying. Original question that started all this was for IFR in electrically dependent airplane with one battery though. For VFR flying and single E.I., electrical system is really optional anyway... >In case of a battery > failure same scenario but the alternator supplies power and I make it to tera > firma in great shape. The "battery failure" I was talking about was one which would take the whole electrical system down....otherwise, you'd be unlikely to have or notice any other type of failure of the battery in flight....you would notice it when you try to start the airplane for the next flight, unless there's a failure mode I'm forgetting? >BTW, two E.I.'s is not the most economic or lightest > and it darn sure is not the best performance. How do you support this claim? The dual Lightspeed Plasma II system price is comparable to two mags, and is lighter than those two mags (especially with the crank-triggered flywheel timing pickups). If the ignition system alone requires dual alternators and dual batteries, the overall weight and expense would be greater for the E.I. route, but for most of us the new electric panels are also justifying the electrical system redundancy so this upper isn't attributed only to the E.I.'s in a comparison with mags. As far as performance, I have not personally done mags vs. E.I. testing, but if two E.I.'s are "darn sure not the best performance" then the E.I. manufacturer's are lying to us, because they claim the E.I. performance to be better. Granted, the first E.I. gives you the majority of the improvements (90% +), but the second adds a measurable amount according to Klaus Savier and affirmed by Bart Lalonde who's tested them on the dyno. FWIW, my reason for going dual E.I. was primarily just standardization of the ignition system....I got tired of messing with mags when I was turning wrenches and will welcome the lower maintenance and better reliability of the E.I. system. The slight weight savings and performance improvement of the second E.I. is an added bonus. No more $$$ aviation spark plugs for me.... > In the case of a total electrical system failure the mag is still > keeping the airplane moving to an airport and we are fine. After 17 years > of flying this IFR capable "air-chine" and the last nine years with one E.I. I > really don't get the fear. If you're IFR, and you have total electrical system failure, the engine keeps running but what about your panel? I'm not saying adding an aux battery and/or alternator is the only option....for example, you could get the Dynon with the internal battery and have a handheld GPS with batteries, and that would get you down in IFR even if you had total electrical system failure. > If your talking hard IFR and pretty sure your not, the systems I see > in many of these new airplanes is a waste. > > This is the opinion of many of "People who are flying experimentals" > and not building. Bob has designed some pretty great systems and taking > advantage of his skillful designs would make anyone very safe. The big > difference in my focus and Bob K's is that he wants to make the intended > destination. Myself I want to just back on the ground and not need to change my > drawers ;-)) Agreed....my aux battery will be 3 ah capacity and cost about $10-15. In the unlikely event that the main electrical system fails completely, I will have about an hour of ignition operation to get on the ground. I don't see the need to add a ton more capacity and carry the extra weight/expense required to ensure my aux battery will outlast my fuel, since this is a backup for an unlikely scenario and I'll live with some inconvenience if I ever find myself in these circumstances... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D firewall forward stuff.... > Dale Martin > Lewiston, ID > LEZ-235 > > > ----- Original Message ----- > From: <czechsix(at)juno.com> > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > > > > > Hi Dale, > > > > To answer your question, very few of us have had battery failure. > It's > pretty rare, and many people may be comfortable with a single > battery in an > all-electric airplane (i.e. dual elec. ignition and IFR panel with > no > vacuum). Personally, I'm NOT comfortable with having all that at > stake in a > single battery. There have been a few battery failures reported > here on > this List over the past few years I've followed it, and several > people I've > talked to have had it happen in cars. I'm talking catastrauphic > failure, > where the lead or post breaks off, or something happens to the > battery > itself rendering the whole electrical system dead. I know, I > know...they > were probably poorly designed installations and/or poorly > maintained, and if > you have a well-designed installation without stressing the battery > leads/terminals, with an RG battery rotated out every other year, > the odds > of failure are probably reduced to very slim. But in my case I > decided to > go with a small aux battery to k > > eep my second ignition alive in the ulikely event that it's > needed. Each > person can decide for their airplane and mission what they're > comfortable > with. > > > > --Mark Navratil > > Cedar Rapids, Iowa > > RV-8A N2D finishing... > > > > From: "Dale Martin" <niceez(at)cableone.net> > > Subject: Re: AeroElectric-List: A panel full of displays . . . > > > > > > > With all due respect...... how many of us have a had a battery > failure? > I > > cannot believe that some of you intend medium to hard IFR with > some of our > > homebuilts. First consider empennage, wing and prop anti icing > equipment > > first.... Then I'll believe you need all the rest of the > equipment. > > > > One battery will due if it is the proper quality..... > > > > Just my opinion, > > > > Dale Martin > > Lewiston, ID > > LEZ-235 ________________________________________________________________________________
Subject: Horse Power?
Date: Apr 18, 2004
Does anyone know the formula to calculate the %HP? ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Apr 19, 2004
> > --> > > Does anyone know the formula to calculate the %HP? > If you have an accurate fuel flow meter, you can get pretty close. Fuel burn will range from something like 0.5 pounds/hour/hp if you run 100F rich of peak to about 0.42 pounds/hr/hp if you are lean of peak. These numbers are not hard and fast, obviously, and depend on ignition type, prop type (rpm vs MAP), etc., but are probably as accurate as the engine charts. Others may know the algorithm that the commercially available engine monitors with the percent hp use, I don't. Alex Peterson Maple Grove, MN RV6-A N66AP 458 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Subject: Re: Horse Power?
Date: Apr 19, 2004
Seems a little high to me On Apr 19, 2004, at 6:01 AM, Alex Peterson wrote: > > >> >> --> >> >> Does anyone know the formula to calculate the %HP? >> > > If you have an accurate fuel flow meter, you can get pretty close. > Fuel > burn will range from something like 0.5 pounds/hour/hp if you run 100F > rich of peak to about 0.42 pounds/hr/hp if you are lean of peak. These > numbers are not hard and fast, obviously, and depend on ignition type, > prop type (rpm vs MAP), etc., but are probably as accurate as the > engine > charts. > > Others may know the algorithm that the commercially available engine > monitors with the percent hp use, I don't. > > Alex Peterson > Maple Grove, MN > RV6-A N66AP 458 hours > > http://www.home.earthlink.net/~alexpeterson/ > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
From: "Werner Schneider" <wernerschneider(at)compuserve.com>
Date: Apr 19, 2004
Agree, I had on my O-320 with 23/2300 in density 4000ft with 10 deg OAT 10.2 full rich and 7.4 peak. Werner ----- Original Message ----- From: "Denis Walsh" <denis.walsh(at)comcast.net> Subject: Re: AeroElectric-List: Horse Power? > > Seems a little high to me > On Apr 19, 2004, at 6:01 AM, Alex Peterson wrote: > > > > > > >> > >> --> > >> > >> Does anyone know the formula to calculate the %HP? > >> > > > > If you have an accurate fuel flow meter, you can get pretty close. > > Fuel > > burn will range from something like 0.5 pounds/hour/hp if you run 100F > > rich of peak to about 0.42 pounds/hr/hp if you are lean of peak. These > > numbers are not hard and fast, obviously, and depend on ignition type, > > prop type (rpm vs MAP), etc., but are probably as accurate as the > > engine > > charts. > > > > Others may know the algorithm that the commercially available engine > > monitors with the percent hp use, I don't. > > > > Alex Peterson > > Maple Grove, MN > > RV6-A N66AP 458 hours > > > > http://www.home.earthlink.net/~alexpeterson/ > > > > > > _- > > ======================================================================= > > _- > > ======================================================================= > > _- > > ======================================================================= > > _- > > ======================================================================= > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2004
In a message dated 4/19/04 7:36:50 AM Central Daylight Time, denis.walsh(at)comcast.net writes: Seems a little high to me On Apr 19, 2004, at 6:01 AM, Alex Peterson wrote: Good Morning Alex, I think those numbers are very good though it results in horsepower, not percentage of horsepower as was originally asked. There are a few of our General Aviation engines that can get a .38 burn when leaned about twenty or thirty degrees below Peak EGT, but the .42 to .5 is a very good average number. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 19, 2004
In a message dated 4/19/04 8:16:54 AM Central Daylight Time, wernerschneider(at)compuserve.com writes: Agree, I had on my O-320 with 23/2300 in density 4000ft with 10 deg OAT 10.2 full rich and 7.4 peak. Werner Good Morning Werner, And what does a full rich number have to do with horsepower developed? The only thing we know when you are at full rich is that you probably have enough fuel going into the engine to combine with all of the air that is available to burn. If you are much richer than the minimum amount of fuel required for that amount of oxygen, you will lose a little bit of potential power. However, most of our GA engines require a very rich mixture at takeoff power to aid in positioniong the combustion event so as to maintain reasonable temperatures. If your 7.4 GPH figure was at peak EGT, you were probably developing around 110 horsepower. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 19, 2004
Date: Apr 19, 2004
Lycoming's Operator's Manual shows the O-360 A & E series engines (8.5:1 CR) to have a BSFC of about .55lb/hp-hr at 2700 rpm, decreasing to .52 lb/hp-hr at 2200 rpm. This is for full throttle and full rich mixture setting. The propeller load curve (partial throttle) shows it to be about .46 lb/hp-hr (min.) at 2300-2400 rpm. Info for a fuel injected IO-360A engine (8.7:1 CR) shows a BSFC of about .42 lb/hp-hr at 2400 rpm and 65% power, best economy (leaned out). This is the best you will get. Cliff A&P/IA ----- Original Message ----- From: "Denis Walsh" <denis.walsh(at)comcast.net> Subject: Re: AeroElectric-List: Horse Power? > > Seems a little high to me > On Apr 19, 2004, at 6:01 AM, Alex Peterson wrote: > > > > > > >> > >> --> > >> > >> Does anyone know the formula to calculate the %HP? > >> > > > > If you have an accurate fuel flow meter, you can get pretty close. > > Fuel > > burn will range from something like 0.5 pounds/hour/hp if you run 100F > > rich of peak to about 0.42 pounds/hr/hp if you are lean of peak. These > > numbers are not hard and fast, obviously, and depend on ignition type, > > prop type (rpm vs MAP), etc., but are probably as accurate as the > > engine > > charts. > > > > Others may know the algorithm that the commercially available engine > > monitors with the percent hp use, I don't. > > > > Alex Peterson > > Maple Grove, MN > > RV6-A N66AP 458 hours > > > > http://www.home.earthlink.net/~alexpeterson/ > > > > > > _- > > ======================================================================= > > _- > > ======================================================================= > > _- > > ======================================================================= > > _- > > ======================================================================= > > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2004
I would like to retract my previous post regarding seeming a little high. I was timesing when I should have been gozintoing to get to gph. Now I think it is exactly correct, and useful for estimating power, assuming leaning is tended to. ________________________________________________________________________________
Date: Apr 19, 2004
Good evening Bob (living a bit east of you (CH)), > And what does a full rich number have to do with horsepower > developed? nothing, you can get the exact numbers only, if you lean peak and use the fuel flow, and mine was more then the 0.5 on full rich). What would mean, another kind of formula would help more. > If your 7.4 GPH figure was at peak EGT, you were probably > developing around 110 horsepower. yeap, the table would tell that this would be around 65 % which means close to 110HP. would help A formula which would take MP and RPM into account would be easier to calculate, but it might mean to have a lookup table and where to get this? I've got once: P = 2 * PI * M * n P=Power M = torque in Nm n= rpm /min or P = Vh * pe * n Vh = cubic capacity in dm3 pe = medium piston pressure in bar n= rpm/min Power would be kW but how do I measure torque or piston pressure? Thanks Werner ________________________________________________________________________________
Date: Apr 19, 2004
> There are a few of our General Aviation engines that can get > a .38 burn when leaned about twenty or thirty degrees below > Peak EGT The Continental IO-520 and IO-550 will do this good I believe. Cliff ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: AeroElectric-List: Horse Power? > > In a message dated 4/19/04 7:36:50 AM Central Daylight Time, > denis.walsh(at)comcast.net writes: > Seems a little high to me > On Apr 19, 2004, at 6:01 AM, Alex Peterson wrote: > > > Good Morning Alex, > > I think those numbers are very good though it results in horsepower, > not percentage of horsepower as was originally asked. > > There are a few of our General Aviation engines that can get > a .38 burn when leaned about twenty or thirty degrees below > Peak EGT, but the .42 to .5 is a very good average number. > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Airpark LL22 > Downers Grove, IL 60516 > 630 985-8502 > > ________________________________________________________________________________
Date: Apr 19, 2004
>BTW, two E.I.'s is not the most economic or lightest > and it darn sure is not the best performance. How do you support this claim? ********************* Just as you said, you need two Batteries or two alternators to be safe with dual E.I's.. Second - Check the Cafe Web page for the results. Two Mags beats two E.I.'s. I guess doing this for long enough you learn to raise your eyebrows at some claims. There is more then LSE in the electronic ignition field and suspect you'll find out the better unit in years to come. I have and now have a Electro-Air unit. I have also need to used REM 37BY plugs all along due to there further reach but was told it wasn't necessary by LSE..... Not exactly accurate information. >>>>>>>>>>>> You Say- The slight weight savings and performance improvement of the second E.I. is an added bonus. No more $$$ aviation spark plugs for me.... ************ That is a big crock of ........ ?? waste! Unless you have the long duration spark the performance is less and the E.I. sparkplugs are more money then some that are available. The 386 sparkplug has been working for many people. And when you get 700 to 900 hours from aviation sparkplugs with the correct E.I. system it doesn't seem bad to me.... Each to their own but have been there and done that and never to return. ****************** You Say- >Agreed....my aux battery will be 3 ah capacity and cost about $10-15. In >the unlikely event that the main electrical system fails completely, I >will have about an hour of ignition operation to get on the ground. Seems like more complication and weight to me then a mag that keeps running without doing anything.... Just my opinion though. Dale Martin Lewiston, ID LEZ-235 ________________________________________________________________________________
Date: Apr 19, 2004
First off I wanted to mention that some people are quoting burn rates in lbs/hour/hp and some are using GPH, thus this could be some debate on the number of 0.5 lbs/hour/hp. As far as the original question, the percent horse power calculation is based on estimating the air flow into the engine. So we can go back to the text books and find the air flow equations which are a function of air temperature, manifold pressure, RPM and displacement. Then we estimate the power of engine based on the engine efficiency. Then since you are doing a percentage you will find that the air temperature, efficiency and displacement cancel out in the percentage calculation leaving you with estimated percent horsepower. Regards, Trampas Stern www.sterntech.com ________________________________________________________________________________
Date: Apr 19, 2004
Hello Trampas, so if I understand it correct we could get %HP out of a formula with MP and RPM? Would you be so kind to post this formula? I had to do some flighttesting and therefore had to go through the tables of lycoming to find a pair of MP and RPM for 75%/65%/55% HP in different density altitudes. Thanks a lot Werner ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Horse Power? > > First off I wanted to mention that some people are quoting burn rates in > lbs/hour/hp and some are using GPH, thus this could be some debate on the > number of 0.5 lbs/hour/hp. > > As far as the original question, the percent horse power calculation is > based on estimating the air flow into the engine. So we can go back to the > text books and find the air flow equations which are a function of air > temperature, manifold pressure, RPM and displacement. Then we estimate the > power of engine based on the engine efficiency. > > Then since you are doing a percentage you will find that the air > temperature, efficiency and displacement cancel out in the percentage > calculation leaving you with estimated percent horsepower. > > Regards, > Trampas Stern > www.sterntech.com > > ________________________________________________________________________________
Date: Apr 19, 2004
> so if I understand it correct we could get %HP out of a > formula with MP and RPM? This would also require temperature of the induction air. In cold air, a given MP and RPM will deliver more power than in warm air (more air, by mass, into the engine). Air at 90F will be only about 84% as dense as at 0F, barometric pressure the same. So, with identical MAP and RPM, the power at 90F will be about 84% of what it would be for the same settings at 0F. It is all about how much air mass goes into the cylinders. There are other variables, but not as important. Alex Peterson Maple Grove, MN RV6-A N66AP 458 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 19, 2004
> > Good Morning Gilles, > > Is there room to run the wire parallel to the hinge line for a little way? > > I have used that method to give a wire adequate flexibility when a > loop would not be practical. The length of wire can even be lightly > supported along it's length if that need be. All you have to do is run > it through a support that does not bind it down solidly. As long as > the wire is free to twist, all of the motion will be absorbed by the > torsion of the wire instead of as a bending moment. A six inch length > of number twenty or twenty two can stand a lot of twisting without > any damage at all. The longer, the better. > > Works for me! > > Happy Skies, > > Old Bob Hi Old Bob, Thank you for responding. The aileron trim is located at the outboard end of the aileron. The hinges are offset but I'll try to have the wires come out of the wing into the winglet and back into the aileron end, in a spanwise direction. So the motion will be mainly twisting. Regards, Gilles ________________________________________________________________________________
Subject: Intercom/handheld wiring
Date: Apr 19, 2004
Has anyone used a Softcomm ATC panel mounted intercom with a handheld transceiver like the Icom A23? Does anyone know how to wire them together? Thanks, Jack ________________________________________________________________________________
Date: Apr 19, 2004
Malcolm, What do you want the information for? If you want to determine that your engine is putting out normal power on takeoff, with a variable pitch prop, you would need to measure torque in the prop shaft, then calculate HP using rpmXtorque/5252, then dividing by the standard HP to get a percentage. If you just want the % HP in a modestly accurate way for setting up in the engine in cruise at altitude, then using the charts as given by the engine maker gives a rough idea. Using MP and temperature, you can calculate relative mass airflow into the engine. The problem is that the efficiency of the engine, based on fuel flow, varies depending upon leaning of the mixture. You may find that a calculation based on mass airflow is more accurate than one based on fuel flow, but some data from a well-instrumented aircraft engine sure would be nice to check this notion. Most likely, this has been done in the 1940's and early 1950's, but the knowledge is not well known. John Deakin writes about this, the last time I saw this was at www.avweb.com/news/columns/182146-1.html I don't recall that he addressed this topic based on mass air flow. It may have been Saab in the 1970's that used a "luftmengenmesser" to measure air mass to adjust fuel injection. This was a Bosch item if memory serves. Now that easily programmed microprocessors are available, such as the Basic units from Parallex and others, calculation of mass flow is practical in real time based upon MP and temperature. If you want to do this, a look-up table is the easy way to go, of course. I asked this question some time ago, and looked into strain gauges on the wing struts! The strain gauge on the prop shaft scares me, as it could mess up the engine, and sounds hard to design. I dropped the whole idea in favor of just completing the airplane. Jim Foerster Jabiru J400, 80% done. ---------------------------------------------------- This mailbox protected from junk email by Matador from MailFrontier, Inc. http://info.mailfrontier.com ________________________________________________________________________________
Date: Apr 19, 2004
In a message dated 4/19/04 5:33:02 PM Central Daylight Time, jmfpublic(at)comcast.net writes: I asked this question some time ago, and looked into strain gauges on the wing struts! The strain gauge on the prop shaft scares me, as it could mess up the engine, and sounds hard to design. I dropped the whole idea in favor of just completing the airplane. Good Evening Jim, If you really want to check the torque output, put strain gauges on the engine mounts. Al Hundere made up a device to do just that on a Twin Beech many years ago. I understand that it worked OK, but needed a lot of TLC to retain accuracy. I suppose you are familiar with the torque meters used on many radial engines of the forties and fifties. They worked by measuring the force on the planetary gear reduction system. More than one way to skin a cat. The nice thing about using a fuel flow to figure out what power is being developed is the simplicity of the idea. The bad thing is that it won't tell you if the engine is developing an unusual internal drag. The engine could be tearing itself up and the fuel flow indication would not reflect the power loss. A torquemeter will show that power output has been lost even though the engine is using the amount of fuel that it should be using to develop the indicated HP. In smooth air, a change in airspeed gives an excellent indication of power output and, if the airplane has a fixed pitch prop, you can easily note power changes by the change in RPM. That is how Lindbergh did it. Still works just fine. Any help? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 19, 2004
Subject: New thread about E.I. performance or lack thereof
>Subject: Re: Re: AeroElectric-List Digest: 13 Msgs - 04/16/04 >From: Dale Martin (niceez(at)cableone.net) >Date: Mon Apr 19 - 7:26 AM > > >BTW, two E.I.'s is not the most economic or lightest > and it darn sure is not the best performance. > >How do you support this claim? >********************* > >Just as you said, you need two Batteries or two alternators to be safe with >dual E.I's.. > >Second - Check the Cafe Web page for the results. Two Mags beats two >E.I.'s. I'm familiar with the Cafe reports on E.I. because I studied them before ordering my LSE units. I don't think you can look at the reports Cafe did and make a blanket statement that "two mags beats two E.I's". The report clearly demonstrates that with either one or two E.I.'s, there's a significant improvement in performance at higher altitudes and lean operation (as well as better idle and other marginal improvements). This jives with the expected results based on the physics of hotter spark and timing advance. The "Ignition Dynamics II" article does note a few conditions in which the the test results contradict what you'd expect.....that is, the performance of the mags was a bit better. The article notes that the difference was "slight" or "small" in such conditions, and speculates that the timing curve used in the subject Electroair system was to blame for the difference, over-advancing the spark causing some power loss compared to the mags (see second paragraph in t he right column of page 8 of this article at www.cafefoundation.org/aprs/ignition2.pdf). This theory makes perfect sense. In all fairness to Jeff Rose, the timing is hard to nail down without extensive testing, and impossible to optimize based only on RPM and manifold pressure. Having other sensors like cars (or the Aerosance FADEC) is required to perfect it under all operating conditions. But I recall hearing that Jeff improved the timing curve after the Cafe results came out....might have been hearsay. I know when I talked to Klaus Savier at Oshkosh a couple years ago he was aware of the article and said that the LSE system did not advance the spark as much as the tested Electroair system in the conditions where the mags were showing better performance than the E.I. The paragraph mentioned above notes that Cafe talked to Klaus at the time of writing and he was already aware that less spark advance was needed for more power under the conditions described there. And Bart Lalonde at Aerosport Power told me that there was a measurable increase in HP on the dyno with both single and dual LSE systems installed, which should translate into better low altitude performance than mags in addition to the well-established high altitude lean mixture operations. >I guess doing this for long enough you learn to raise your eyebrows at some >claims. I'm not new to aviation either and frequently raise my eyebrows at all kinds of claims out there. The great thing about this forum is we can debunk the claims that are bogus, and share information for the benefit of our fellow builders/pilots. I don't believe everything Klaus claims for his LSE system, but nor do I believe the evidence supports a statement that "two mags beats two E.I.'s", simple as that. >There is more then LSE in the electronic ignition field and suspect >you'll find out the better unit in years to come. I have and now have a >Electro-Air unit. I've heard good things about Jeff Rose and Electroair. Just curious though, why are you using an E.I. at all if, in your opinion, two mags are better? Or are you saying that one mag and one E.I. outperforms either dual mags or dual E.I.'s? I'm not poking fun at you, just trying to understand your position which appears contradictory to me. > I have also need to used REM 37BY plugs all along due to t>here further reach but was told it wasn't necessary by LSE..... Not >exactly accurate information. What is inaccurate about this? Lots of RV'ers are using automotive plugs as supplied by Klaus with the LSE system. Haven't ever heard a complaint on the RV List about them, but that doesn't mean someone out there hasn't experienced trouble with them. Can you elaborate a bit for my benefit? Should I throw out the auto plugs and put aviation plugs in my engine instead? Does this have anything to do with engine type (i.e. you are running an O-235 and I've got an O-360)? >>>>>>>>>>>> > >You Say- >The slight weight savings and >performance improvement of the second E.I. is an added bonus. No more >$$$ aviation spark plugs for me.... >************ > >That is a big crock of ........ ?? waste! > >Unless you have the long duration spark the performance is less and the E.I. >sparkplugs are more money then some that are available. The 386 sparkplug >has been working for many people. And when you get 700 to 900 hours from >aviation sparkplugs with the correct E.I. system it doesn't seem bad to >me.... > >Each to their own but have been there and done that and never to return. Ok....you've been there, done that and had a bad experience and won't do it again. Can you tell us what happened to you so that others don't repeat your bad experience? If my research on the LSE system has missed something important, I'd like to understand it. I know there's been some starting kickback issues (different subject entirely, all in the archives) but I'm not aware of spark plug problems or other operational/performance issues that would cause the kind of regrets you have experienced. Please share your experiences and data with us. >****************** > >You Say- >Agreed....my aux battery will be 3 ah capacity and cost about $10-15. In >the unlikely event that the main electrical system fails completely, I >will have about an hour of ignition operation to get on the ground. > >Seems like more complication and weight to me then a mag that keeps running >without doing anything.... Just my opinion though. Actually the aux battery arrangment is not complicated, it's quite simple and light if you size it to the task. But anyway, there's nothing wrong with your approach (single mag, single E.I.) There's pros and cons to dual mags vs dual E.I. vs the combo approach you're using, just depends on one's priorities. >Dale Martin >Lewiston, ID >LEZ-235 --Mark Navratil Cedar Rapids, Iowa RV-8A N2D finishing.... ________________________________________________________________________________
Date: Apr 19, 2004
Hey, Old Bob, about measuring torque in a planetary gear reduction system. I have a 2.85 to 1 planetary gear reduction to hang on front of my RX-8 Renesis engine on an RV-6. Have any idea how one could find out how to put a strain gage on such a gadget to get torque? The Lone Star Flight Museum at Galveston, Texas, has an excellent research library with lots of tech data on WW II aircraft. Maybe I could spend some time in there and find out how they did that torque thing - if they had started doing it by WWII. I don't remember fighters having torque meters - seems like that was something for the 4 engine transport and bomber guys with a flight engineer monitoring lots of stuff. David ----- Original Message ----- From: <BobsV35B(at)aol.com> Subject: Re: AeroElectric-List: Re: Horse Power? > > In a message dated 4/19/04 5:33:02 PM Central Daylight Time, > jmfpublic(at)comcast.net writes: > I asked this question some time ago, and looked into strain gauges on the > wing struts! The strain gauge on the prop shaft scares me, as it could mess up > the engine, and sounds hard to design. I dropped the whole idea in favor of > just completing the airplane. > > > Good Evening Jim, > > If you really want to check the torque output, put strain gauges on the > engine mounts. Al Hundere made up a device to do just that on a Twin Beech many > years ago. I understand that it worked OK, but needed a lot of TLC to retain > accuracy. > > I suppose you are familiar with the torque meters used on many radial engines > of the forties and fifties. They worked by measuring the force on the > planetary gear reduction system. > > More than one way to skin a cat. > > The nice thing about using a fuel flow to figure out what power is being > developed is the simplicity of the idea. The bad thing is that it won't tell you > if the engine is developing an unusual internal drag. The engine could be > tearing itself up and the fuel flow indication would not reflect the power loss. > A torquemeter will show that power output has been lost even though the > engine is using the amount of fuel that it should be using to develop the indicated > HP. > > In smooth air, a change in airspeed gives an excellent indication of power > output and, if the airplane has a fixed pitch prop, you can easily note power > changes by the change in RPM. That is how Lindbergh did it. Still works just > fine. > > Any help? > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Airpark LL22 > Downers Grove, IL 60516 > 630 985-8502 > > ________________________________________________________________________________
Subject: Dumb Question
Date: Apr 19, 2004
You'd think I'd know this stuff by now. However..... My starter solenoid from Van's has two small terminals on it. One is marked "S" and the other is marked "I". I assume that the "S" goes to the starter switch to energize the coil. I also assume that I just ignore the other terminal. Is that correct? Should I ground the "I" terminal? Just asking. My brain isn't working that great tonight. Randy F1 Rocket http://f1rocket.home.comcast.net/ ________________________________________________________________________________
Date: Apr 19, 2004
In a message dated 4/19/04 6:34:28 PM Central Daylight Time, dcarter(at)datarecall.net writes: I have a 2.85 to 1 planetary gear reduction to hang on front of my RX-8 Renesis engine on an RV-6. Have any idea how one could find out how to put a strain gage on such a gadget to get torque? Good Evening David, The old torque meters did it by measuring the movement of the ring gear. It was mounted so that it moved back and forth very slightly in a set of angled grooves when torque was applied. The movement was resisted by a few small oil filled cylinders. The pressure of the oil in those little cylinders was calibrated to read in torque which was generally presented as an equivalent BMEP number. I think the easiest thing would be to measure the torque somewhere in the engines mounting. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 19, 2004
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Subject: Re: Dumb Question
Don't ground it. That might tend to let the smoke out. The "I" terminal becomes live while the solenoid is engaged. It's original purpose was to bypass the ballast resistor in automotive applications. In your aircraft it can be used to signify "starter engaged" if you wish. Or just ignore it. Bob McC Randy Pflanzer wrote: > >You'd think I'd know this stuff by now. However..... > >My starter solenoid from Van's has two small terminals on it. One is marked "S" and the other is marked "I". I assume that the "S" goes to the starter switch to energize the coil. I also assume that I just ignore the other terminal. Is that correct? Should I ground the "I" terminal? > >Just asking. My brain isn't working that great tonight. > >Randy > > > ________________________________________________________________________________
Date: Apr 19, 2004
Thanks. ----- Original Message ----- From: "Robert McCallum" <robert.mccallum2(at)sympatico.ca> Subject: Re: AeroElectric-List: Dumb Question > > Don't ground it. That might tend to let the smoke out. The "I" terminal > becomes live while the solenoid is engaged. It's original purpose was to > bypass the ballast resistor in automotive applications. In your aircraft > it can be used to signify "starter engaged" if you wish. Or just ignore it. > > Bob McC > > Randy Pflanzer wrote: > > > > >You'd think I'd know this stuff by now. However..... > > > >My starter solenoid from Van's has two small terminals on it. One is marked "S" and the other is marked "I". I assume that the "S" goes to the starter switch to energize the coil. I also assume that I just ignore the other terminal. Is that correct? Should I ground the "I" terminal? > > > >Just asking. My brain isn't working that great tonight. > > > >Randy > > > > > > > > ________________________________________________________________________________
Date: Apr 19, 2004
Randy, your assumptions are correct. The "I" terminal could also be used for a starter-engaged light. If not, just ignore it. Pat Hatch RV-4 RV-6 RV-7 Finishing Kit Vero Beach, FL ----- Original Message ----- From: "Randy Pflanzer" <f1rocket(at)comcast.net> Subject: AeroElectric-List: Dumb Question > > You'd think I'd know this stuff by now. However..... > > My starter solenoid from Van's has two small terminals on it. One is marked "S" and the other is marked "I". I assume that the "S" goes to the starter switch to energize the coil. I also assume that I just ignore the other terminal. Is that correct? Should I ground the "I" terminal? > > Just asking. My brain isn't working that great tonight. > > Randy > F1 Rocket > http://f1rocket.home.comcast.net/ > > ________________________________________________________________________________
Date: Apr 19, 2004
> See http://www.aeroelectric.com/Pictures/s702wire.jpg >Don't ground it. That might tend to let the smoke out. The "I" terminal >becomes live while the solenoid is engaged. It's original purpose was to >bypass the ballast resistor in automotive applications. In your aircraft >it can be used to signify "starter engaged" if you wish. Or just ignore it. > >Bob McC > >Randy Pflanzer wrote: > > > > > >You'd think I'd know this stuff by now. However..... > > > >My starter solenoid from Van's has two small terminals on it. One is > marked "S" and the other is marked "I". I assume that the "S" goes to > the starter switch to energize the coil. I also assume that I just > ignore the other terminal. Is that correct? Should I ground the "I" terminal? > > > >Just asking. My brain isn't working that great tonight. > > > >Randy > > > > > > > > Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Apr 19, 2004
I found all the formulas for calculating the mass air entering the cylinders from a website for an open source EFI, http://www.megasquirt.info/manual/mfuel.htm You can use the formulas for calculating the mass air flow and realizing that the mass of the air is proportional to the fuel entering the engine, of course assuming a constant fuel mixture. Then the horse power will be proportional to the fuel, which is proportional to the air entering the engine. Again if you assume the air temperature is constant and the fuel mixture is constant then all you are left with is MAP and RPMs. Now if you are using a fixed pitch propeller then you can actually remove the MAP from the equation is that the horsepower required to turn prop is dependent on the RPMs and the air density, again since we want percent horsepower we assume constant air density and thus only have RPMs in the equation. Regards, Trampas Stern www.sterntech.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Werner Schneider Subject: Re: AeroElectric-List: Horse Power? Hello Trampas, so if I understand it correct we could get %HP out of a formula with MP and RPM? Would you be so kind to post this formula? I had to do some flighttesting and therefore had to go through the tables of lycoming to find a pair of MP and RPM for 75%/65%/55% HP in different density altitudes. Thanks a lot Werner ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Horse Power? > > First off I wanted to mention that some people are quoting burn rates in > lbs/hour/hp and some are using GPH, thus this could be some debate on the > number of 0.5 lbs/hour/hp. > > As far as the original question, the percent horse power calculation is > based on estimating the air flow into the engine. So we can go back to the > text books and find the air flow equations which are a function of air > temperature, manifold pressure, RPM and displacement. Then we estimate the > power of engine based on the engine efficiency. > > Then since you are doing a percentage you will find that the air > temperature, efficiency and displacement cancel out in the percentage > calculation leaving you with estimated percent horsepower. > > Regards, > Trampas Stern > www.sterntech.com > > ________________________________________________________________________________
Subject: PAR36 possibility
Date: Apr 19, 2004
Gentlemen, Are any of you familiar with this bulb?: 50Watt PAR36 5 degree spot 12V 19878 GE Halogen Lamp 50PAR36/NSP I bought one just to compare it to the "standard" 4509. It is just about as bright in the center spot, which is about the same size spot the 4509 makes. The area just outside the spot may be slightly brighter compared to the 4509. Of course the current required is just half that required for the 100 watt incandescent 4509. I have no idea how well this bulb would hold up on an airplane. It seems robust to me. The price is $9.95 each, which seems reasonable considering it's rated at 4000 hours. The incandescent 4509 is a 25 hour bulb and sells for $7.94. These prices are current at www.atlantalightbulbs.com Thoughts? Regards, Troy tscott1217(at)bellsouth.net ________________________________________________________________________________
Date: Apr 19, 2004
On 4-19-04 Bob Siegfried wrote: If you really want to check the torque output, put strain gauges on the engine mounts. Al Hundere made up a device to do just that on a Twin Beech many years ago. I understand that it worked OK, but needed a lot of TLC to retain accuracy. Good evening Bob, I considered putting strain gauges on the mount, but in consultation with my physicist cousin, it was clear that my mount would require both tension/compression as well as torque gauges on each of 6 tubes, with significant computation to make sense of all the moments involved. If I were to rebuild the mount, with a design that had a bearing with the axis pointing forward which would allow measurement of a "pure" torque, the job would be easy. I also considered putting strains gauges on the longerons attached to the firewall, but I'm not sure about the stability of that location in a composite aircraft. Eventually, I put the project on the future list. I do appreciate your description of the torque measurement in the planetary gear system on those big radials. Jim Foerster ________________________________________________________________________________
Date: Apr 20, 2004
In a message dated 4/20/04 1:54:11 AM Central Daylight Time, jmfpublic(at)comcast.net writes: I considered putting strain gauges on the mount, but in consultation with my physicist cousin, it was clear that my mount would require both tension/compression as well as torque gauges on each of 6 tubes, with significant computation to make sense of all the moments involved. Good Morning Jim. First, let's recall that Al Hundere did not find the project to be worthwhile considering the technology available fifty years ago. Nevertheless, I do believe he was measuring movement with a strain gauge at only one engine mount. He would then run the engine at known power settings and extrapolate the data from there. He was not as much interested in finding precisely how much power was being developed as he was in finding peak power. It is somewhat analogous to his use of EGT to determine the same point. He was the guru who gave us Alcor. The idea of running at a particular EGT was not what Al had intended. What he did was run an engine on a test bed and determine what the EGT read at various mixtures. He found that, on the average Lycoming or Continental, peak power occurred at somewhere around fifty degrees Fahrenheit richer than peak EGT. That was the information he wanted. He didn't particularly care what the actual temperature was, he was trying to locate peak power so that mixture adjustments could be made with consistent results. I guess he decided that it was a lot cheaper and easier to use the relativity of the EGT to find peak power than it was to find peak power directly from the torque applied to the engine mount. One more off topic comment. He also found that best BSFC generally occurred somewhere between peak EGT and thirty or forty degrees F leaner than peak EGT. Since that is a very flat curve, BSFC will be relatively constant throughout that range. Any time that you are operating in that range, you can easily tell how much horsepower is being developed by noting the actual fuel burn. Since we are, by definition, lean of peak EGT and well lean of peak power, we know that there is more oxygen available than is required to burn all of the fuel we are providing. If the engine is a conforming engine and is not developing any unusual internal stress, the fuel flow multiplied by a constant based on the combustion pressures involved will be a very accurate determination of power developed. For an average lightplane engine using an 8.5 to 1 compression ratio, you can multiply the gallons per hour times 14.9 and come very close to the power that would be shown on a dynamometer. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Date: Apr 20, 2004
In a message dated 4/20/04 7:11:48 AM Central Daylight Time, BobsV35B(at)aol.com writes: For an average lightplane engine using an 8.5 to 1 compression ratio, you can multiply the gallons per hour times 14.9 and come very close to the power that would be shown on a dynamometer. One additional comment if you don't mind. I should have noted that the above formula only works when the engine has excellent fuel distribution to it's cylinders and is operated between peak EGT and thirty to forty degrees F lean of peak EGT. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Subject: cell phone antenna
Date: Apr 20, 2004
Richard said: <> Richard, That's a great idea for the "emergency, HELP!!" version. But I'm hoping for a version that will let me receive calls. On camping trips I'm sometimes accompanied by an MD who needs to remain in contact. What about an amplifier to make up for the signal loss? -Troy tscott1217(at)bellsouth.net ________________________________________________________________________________
Subject: Fw: torque measurement
Date: Apr 20, 2004
I inquired at Alcor about Al Hundere's Twin Beech torque system - here's their reply below. David ----- Original Message ----- From: "Alcor Support" <alcorsupport(at)alcorinc.com> Subject: Re: torque measurement > Hello David, > > Most of that old data has been thrown away. As soon as, > his son returns from vacation I will ask him if he has seen > that data. > > Thanks for your inquiry, > > Rick Sonnen > ----- Original Message ----- > From: "David Carter" <dcarter(at)datarecall.net> > To: > Sent: Monday, April 19, 2004 6:50 PM > Subject: torque measurement > > > > Al [ Hundere ] successfully installed a torque measuring system on a Twin Beech in the > > '60s. Is there any technical info in the files on how he did that? There > > is continued interest in measuring torque on single engine homebuilts so > > HP can be calculated and read out on the new engine instrument systems. > > > > David Carter ________________________________________________________________________________
From: "Malcolm Thomson" <mdthomson(at)attglobal.net>
Subject: Thanks to all those HP contributors and
Date: Apr 20, 2004
I am now trying to find the "Pilot Priority Relay Assembly" which is referred to in Bob Nuckolls wiring book. Is this something that can be purchased or do we fabricate them? ________________________________________________________________________________
Date: Apr 20, 2004
From: "Rick Fogerson" <rickf(at)cableone.net> (by way of Matt Dralle <nospam(at)matronics.com>)
Subject: Alternator blast tube cooling opinion
way of Matt Dralle ) Blast tube cooling for alternators has been a common discussion. Thought everyone might be interested in B&C's opinion on their alternator. Rick Fogerson > Rick, > There doesn't need to be a blast tube to the alternator. The L-40 has two > cooling fans built into the rotor, now if you want to put a blast tube to > the L-40 that is just fine, we do recommend that you put it at least 2 > inches away, so that if it gets clogged for some reason it won't hurt the > purpose of the internal cooling fans. > > Thanks, > Todd Koerner > B&C Specialty Products, Inc > 316-283-8000 > www.bandc.biz > > comments = I am building an RV-3 with B&C 40amp alternator. > Does it need to have a cooling blast tube blowing cool air at it? > Thanks, Rick. > > ------------------------------------------------ > > > ________________________________________________________________________________
Date: Apr 20, 2004
Subject: Automotive Spark Plugs
In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com writes: > No more $$$ aviation spark plugs for me Mark said he's using two EIs and thus using all auto spark plugs. I talked to an engine builder at SnF who said the auto plugs are not holding up as well as the aviation plugs. Does anyone have several hundred hours of flying on auto plugs to substantiate or refute the claim? Stan Sutterfield RV-8A Tampa ________________________________________________________________________________
Date: Apr 20, 2004
Subject: Just wondering........
If I buy a 28 volt comm radio how can it be utilized in a 12 volt system? What needs to be done to the 12 volt system to power the radio, or can the radio be "fixed" to detune it to the existing system? Thinking outloud, but wondering if its a deal, or steal??????? :-) Sid ________________________________________________________________________________
Date: Apr 21, 2004
Alex, On the assumption you are probably looking for a reasonably accurate way to determine the percentage of engine maximum continuous rated horsepower during flight using the RPM, and MAP (manifold pressure) that you see on the gauges, here is a method that works to within about half to one percent accuracy for naturally aspirated engines similar to Lycoming, Continental, etc , when leaned in the conventional manner. 100% minus [(Max rated RPM in hundreds minus actual RPM in hundreds) times 2.5 plus (29 inches MAP minus actual inches MAP) times 3.5)] This can be done in your head with a little practice or carry along a simple calculator. An example: Assume you are at 2450 RPM and 24" MAP at a pressure altitude of 4,000 feet, with an engine having a rated maximum horsepower of 180 at 2700 RPM at sea level. The solution becomes (27-24.5) X 2.5 or 6.25 plus (29-24) X 3.5 or 17.5. Adding the 6.25 to the 17.5 gives 23.75 which is then subtracted from 100 to show 76.25 % of Rated Power. The most accurate method is of course to look up the horsepower on the engine manufacturer's data plots. In the above example, a Lycoming would show 138 HP, which is 76.7 % of the 180 Rated HP. This is correct for an ambient intake temperature on a standard day (44.7F) at the example altitude. If the actual intake temperature is different, a calculation can be made to correct this, with higher temps reducing the HP--and lower temps increasing HP. The approximate correction is 1% HP for each 10 degrees Fahrenheit difference from the standard. Jim McCulley Tailwind AeroElectric-List message posted by: "Alex Peterson" > Does anyone know the formula to calculate the %HP? ________________________________________________________________________________
Date: Apr 20, 2004
Subject: Re: Automotive Spark Plugs
I wonder if the engine builder meant that the auto plugs are having failures, or that they are burning out faster.... If they wear out faster, I don't see that as a big deal. I put 4 new NGK's in my O-200. Total cost: ~$6.00. I bet if you run the right heat range, they will survive just fine. Regards, Matt- Speedy11(at)aol.com wrote: > >In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, >aeroelectric-list-digest(at)matronics.com writes: > > > >>No more $$$ aviation spark plugs for me >> >> > >Mark said he's using two EIs and thus using all auto spark plugs. I talked >to an engine builder at SnF who said the auto plugs are not holding up as well >as the aviation plugs. Does anyone have several hundred hours of flying on >auto plugs to substantiate or refute the claim? > >Stan Sutterfield >RV-8A >Tampa > > > > ________________________________________________________________________________
Date: Apr 20, 2004
I have been running Jeff Rose (Electroair) system on left drive for about a thousand hours. No significant problems. I used auto plugs as recommended by him for most of that time, but have used REM 37BYs for the past few hundred hours, at his (changed) recommendation. Never had any problem with the 386 or C86 Auto plugs lasting a hundred hours or several hundred with cleaning and regapping. I did quit regapping them and started discarding them when I discovered I was probably damaging them when gapping them. At a buck apiece it was smarter. The airplane REM 37 BYs that I am now using are certainly sturdier, but in my normal aspirated O-360 A1A, the auto ones were just fine, too. Hope this helps your research. Denis > I talked > to an engine builder at SnF who said the auto plugs are not holding up > as well > as the aviation plugs. Does anyone have several hundred hours of > flying on > auto plugs to substantiate or refute the claim? > > Stan Sutterfield > RV-8A > Tampa > > > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > _- > ======================================================================= > > > > ________________________________________________________________________________
From: "William Slaughter" <willslau(at)alumni.rice.edu>
Date: Apr 21, 2004
When comparing anecdotal reports of auto plug life, remember that all auto plugs are not created equal. The Bosch Platinum tip plugs have a much longer service life than conventional plugs. Similarly, the AC-Delco platinum tip plugs in my '96 Impala SS go 100,000 miles between changes. Obviously, these plugs cost more than generic units, but are still much cheaper than the aviation sparkplugs. William Slaughter RV-8 Houston -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Subject: AeroElectric-List: Automotive Spark Plugs In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, aeroelectric-list-digest(at)matronics.com writes: > No more $$$ aviation spark plugs for me Mark said he's using two EIs and thus using all auto spark plugs. I talked to an engine builder at SnF who said the auto plugs are not holding up as well as the aviation plugs. Does anyone have several hundred hours of flying on auto plugs to substantiate or refute the claim? Stan Sutterfield RV-8A Tampa == direct advertising on the Matronics Forums. == == == ________________________________________________________________________________
Date: Apr 21, 2004
> > Alex, > > On the assumption you are probably looking for a reasonably > accurate way to > determine the percentage of engine maximum continuous rated > horsepower during > flight using the RPM, and MAP (manifold pressure) that you > Jim McCulley > Tailwind Jim, thanks. However, I was not the person looking for the information, some erroneous cutting and pasting makes it look that way! I don't know how well the formula fits the curves, leaning would be a major factor. Simply leaning within a few percent takes very careful work. I believe that the correction for temperature should be about 2% for each 10F degrees, though. (divide 470 degrees R by 460 degrees R, and you get about 1.02, for example) Alex Peterson Maple Grove, MN RV6-A N66AP 458 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 21, 2004
From: Scott Bilinski <bilinski@kyocera-wireless.com>
What exactly does that mean "not holding up as well as the aviation plugs". They dont last 800, 500, or even 300 hours? I have duall EI with 103 hrs, everything fine to date, and just plan to change the plugs when ever I dont like what I see. That will cost me about 20~25 bucks for all 8. Actually to get technical they are motorcycle spark plugs. > >In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, >aeroelectric-list-digest(at)matronics.com writes: > >> No more $$$ aviation spark plugs for me > >Mark said he's using two EIs and thus using all auto spark plugs. I talked >to an engine builder at SnF who said the auto plugs are not holding up as well >as the aviation plugs. Does anyone have several hundred hours of flying on >auto plugs to substantiate or refute the claim? > >Stan Sutterfield >RV-8A >Tampa > > Scott Bilinski Eng dept 305 Phone (858) 657-2536 Pager (858) 502-5190 ________________________________________________________________________________
Subject: RE: Just wondering....(28-12V radio conversions)
Date: Apr 21, 2004
>If I buy a 28 volt comm radio how can it be utilized in a 12 volt system? >What needs to be done to the 12 volt system to power the radio, or can the >radio be "fixed" to detune it to the existing system? Of course it can be modified, depending on the details. It can also be powered by a 12-28V DC-DC converter depemding on the current. But posting it on eBay and buying a 12V unit on eBay might well be the best possible choice. I have usually found this to be true. Search "aircraft radio -collection -handheld -hitec -futaba -control -controlled -hobby." The search string is needed to filter out those pesky R/C guys' stuff. You may refine this further. Try the same search on Google too. BOB: What is this http://wireless.fcc.gov/aviation/badlst.html List of Unacceptable Aircraft Radios??? Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net Teamwork: "A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ________________________________________________________________________________
Date: Apr 21, 2004
Subject: Re: RE: Just wondering....(28-12V radio conversions)
Hi Eric, > > snip > > BOB: What is this http://wireless.fcc.gov/aviation/badlst.html List of > Unacceptable Aircraft Radios??? I think these are all 360 channel comms, and don't satisfy the 720 channel requirement. > > Regards, > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge MA 01550-2705 > Phone (508) 764-2072 > Email: emjones(at)charter.net > > Teamwork: "A lot of people doing exactly what I say." > (Marketing exec., Citrix Corp.) > > Matt- N34RD ________________________________________________________________________________
Date: Apr 21, 2004
From: Erie Patsellis <erie(at)shelbyvilledesign.com>
as a point of reference.. Bosch platinums (small electrode) last about .5 hours before they're undrivable in my Audi 200 Turbo Quattro. The large platinum electrode plugs last quite a bit longer, but they make aircraft plugs look cheap. The Bosch WR(x)-DTC plugs are a triple ground electrode plug and they last 50,000 + miles. erie William Slaughter wrote: > >When comparing anecdotal reports of auto plug life, remember that all >auto plugs are not created equal. The Bosch Platinum tip plugs have a >much longer service life than conventional plugs. Similarly, the >AC-Delco platinum tip plugs in my '96 Impala SS go 100,000 miles between >changes. Obviously, these plugs cost more than generic units, but are >still much cheaper than the aviation sparkplugs. > >William Slaughter >RV-8 >Houston > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Speedy11(at)aol.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Automotive Spark Plugs > > >In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, >aeroelectric-list-digest(at)matronics.com writes: > > > >>No more $$$ aviation spark plugs for me >> >> > >Mark said he's using two EIs and thus using all auto spark plugs. I >talked >to an engine builder at SnF who said the auto plugs are not holding up >as well >as the aviation plugs. Does anyone have several hundred hours of flying >on >auto plugs to substantiate or refute the claim? > >Stan Sutterfield >RV-8A >Tampa > > >== >direct advertising on the Matronics Forums. >== >== >== > > > > ________________________________________________________________________________
Date: Apr 21, 2004
From: Tammy and Mike Salzman <arrow54t(at)yahoo.com>
You can buy a converter on ebay for this purpose. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26436&item=2474906506&rd=1 Mike Salzman Fairfield, CA LNCE --- "Eric M. Jones" wrote: > > > > > > >If I buy a 28 volt comm radio how can it be utilized in a 12 volt > system? > >What needs to be done to the 12 volt system to power the radio, or > can the > >radio be "fixed" to detune it to the existing system? > > Of course it can be modified, depending on the details. > It can also be powered by a 12-28V DC-DC converter depemding on the > current. ........... ________________________________________________________________________________
Date: Apr 21, 2004
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Unacceptable Aircraft Radios
> > >BOB: What is this http://wireless.fcc.gov/aviation/badlst.html List of >Unacceptable Aircraft Radios??? Yup, frequency tolerances had to be tightened up when the FAA in it's infinite wisdom decided that the way to get more spectrum space for airplane folks to talk to each other was to slice the spectrum into smaller pieces (watch for 8.333 Khz channel spacing to become the 'in' thing). Radios on the list are too loose for frequency tolerance and perhaps for transmitted sidebands width as well. So while we can acquire huge communications technology and capability in the form pocket sized FREE radios from cell phone companies the folks-who-know-more-about- airplanes-than-we-do keep putting Band-Aids on the 1950's, high-dollar technology we're forced to install in our airplanes. In the mean time, thousands of otherwise working radios are useless by decree so that government can minimize their costs of channel compaction while loading the users with costs for radios that will perform no better than the radios that got trashed. Aviation is the last bastion of AM communications left on the surface of the planet. Bob . . . ________________________________________________________________________________
Date: Apr 21, 2004
Subject: Battery failure modes?
What types of failures can occur to a battery in flight, assuming various alternator conditions? Does anybody have a list of failure modes? Regards, Chad ________________________________________________________________________________
Date: Apr 21, 2004
> > >If I buy a 28 volt comm radio how can it be utilized in a 12 volt > >system? What needs to be done to the 12 volt system to power > the radio, > >or can the radio be "fixed" to detune it to the existing system? What kind of radio is it? Some simply need to be wired appropriately for the voltage. Alex Peterson Maple Grove, MN RV6-A N66AP 458 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 21, 2004
Subject: 28-12V radio conversions)
Thank you for the comments and the links to the "how to" answers. I had hoped the 28 volt radios would not be desirable for the general public, and I could get one cheaper than normal for the 12 volt listings...........alas, not true. Seems everybody is out looking for a cheap comm for their homebuilt this spring. The attractive pricing has all escalated to beyond what I would call a good deal. shucks........ Sid ----------------------------- You can buy a converter on ebay for this purpose. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI dll?ViewItem&category=26436&item=2474906506&rd=1 ------------------------------------------------- > >If I buy a 28 volt comm radio how can it be utilized in a 12 volt > system? ________________________________________________________________________________
Date: Apr 21, 2004
There are a couple of high end King comm radios on ebay, but the price has gone sky high since I found them and had the question. I shall continue to try to win the lotto and get a new Micro Air, or an older Terra, S-Tec, or Becker, in 12 volts.........want to keep it light, and really don't have a lot of panel space for full size comm, or nav/comm, and then the transponder too.........my project is an Avid Speedwing and the Avids have small panels for basic VFR only........ Sid -------------------- If I buy a 28 volt comm radio how can it be utilized in a 12 volt system? What needs to be done to the 12 volt system to power the radio, or can the radio be "fixed" to detune it to the existing system? What kind of radio is it? Some simply need to be wired appropriately for the voltage. Alex Peterson Maple Grove, MN RV6-A N66AP 458 hours http://www.home.earthlink.net/~alexpeterson/ ________________________________________________________________________________
Date: Apr 21, 2004
Subject: Re: Unacceptable Aircraft Radios
In a message dated 4/21/2004 11:42:31 AM Eastern Daylight Time, bob.nuckolls(at)cox.net writes: > Aviation is the last bastion of AM communications > left on the surface of the planet. > > Bob . . . Well, ignoring Children's Band, that is true ;-) And what a great place aviation would be for Amplitude-Compandored Single Side-Band or narrow band FM. Looking at the cost of full-featured VHF amateur rigs, there's no excuse for aircraft radios to sell (new) at above 40% of their current street prices /soapbox off/ -Bill B ________________________________________________________________________________
Date: Apr 21, 2004
Stan, With 319 hours experience with an LSE CDI system and also fouled motorcycle plugs (yes that's right - fouled plugs) every 50 to 75 hours. The magneto would run smoother then the E.I. system during this. After more research we find that the truth was not told by the LSE about the proper choice of plugs. I should have been using REM 37BY's (the spark plug that was developed specifically for my engine) just like I do for the magneto. Those who I've spoke with say they get 800 to 900 hours out of there aircraft spark plugs. Having used the triple ground arm plugs from NippenDenso plugs (LSE want $15 per plug) I can say they work a little better but they still would foul during a run-up after 40 25 hours and this was due to carbon deposits the 235L2C is known for -(my best guess anyway). Most interesting is they were all on top and the aircraft REM 37BY plugs and magneto fired all the bottom plugs and ran smooth. Best wishes to LSE however I have switched to Electro-Air's E.I. which recommends Aircraft plugs or the 386 plugs that fit into the standard aircraft cylinder head. You owe it to yourself to speak with Jeff Rose of Electro-Air if your airplane use's a starter. He recommends against hand propping for those with dual E.I.'s. His system already has the "longer duration spark" that LSE wants more $$$ for and use's a 60 tooth wheel to make timing adjustments every 12 verses the once every 360 (or 720) of the LSE system. They both use manifold pressure & electronics to retard or advance the timing. Delivered price for me was $820. You can also get the optional tach and Optional display that shows the amount of Advance. The plans on Electro air also allow the installer to put in a switch to force the unit to fire After TDC for starting. (Jeff told me the unit will not fire until it registers 25 RPM and so that is why hand-propping is still a no go). The lack of engine manifold pressure should however bring it to around 5 before TDC for starting. As I stated, these are my experience's - Hope this helps, Dale Martin Lewiston, ID LEZ-235 ----- Original Message ----- From: <Speedy11(at)aol.com> Subject: AeroElectric-List: Automotive Spark Plugs > > In a message dated 4/19/2004 2:56:56 AM Eastern Daylight Time, > aeroelectric-list-digest(at)matronics.com writes: > > > No more $$$ aviation spark plugs for me > > Mark said he's using two EIs and thus using all auto spark plugs. I talked > to an engine builder at SnF who said the auto plugs are not holding up as well > as the aviation plugs. Does anyone have several hundred hours of flying on > auto plugs to substantiate or refute the claim? > > Stan Sutterfield > RV-8A > Tampa > > ________________________________________________________________________________
Date: Apr 21, 2004
I've run ordinary NGK and Nippodenso plugs top and bottom on a dual LSE O-360 and never had any problems. I change them out every other year and always lean aggresively during ground ops and below 75%. --Kent Cozy Mk IV ________________________________________________________________________________
Subject: Electric Trim Switches
Date: Apr 22, 2004
Gentlemen, I plan to have electric trim controls on the stick(s). These will need relays, since the switches are small and the currents large. I also plan to install either a pullable breaker or switch as Electric Trim Interrupt. I'm thinking it might also be good to have a direct (no relays) means of controlling the trim motors. I'm thinking of installing a pair of (ON)-none-(ON) rocker switches on the console. Is this commonly done? Or do most of you choose either stick-mounted controls or console-mounted controls, but not both? What about stick-mounted controls on the pilot's side only and console mounted controls for when the passenger/pilot takes the controls? What about a "take control" switch to determine which set of trim controls works....., is this necessary? Regards, Troy ________________________________________________________________________________
Date: Apr 22, 2004
| In a message dated 4/21/2004 11:42:31 AM Eastern Daylight Time, bob.nuckolls(at)cox.net | writes:| | > Aviation is the last bastion of AM communications | > left on the surface of the planet.| > | > Bob . . . | | Well, ignoring Children's Band, that is true ;-) And what a great place aviation | would be for Amplitude-Compandored Single Side-Band or narrow band FM. Looking at the cost of full-featured VHF amateur rigs, there's no excuse for aircraft | radios to sell (new) at above 40% of their current street prices /soapbox | off/ | | -Bill B Amen to that! Buy a handheld and wait for the final decision........... That's what decree demands... Ferg Europa Classic 914 ________________________________________________________________________________
Date: Apr 22, 2004
Subject: Re: Electric Trim Switches
Troy, You can eliminate the need for relays for electric pitch and roll servos by purchasing the new Ray Allen G307 (or G305) grips. The Honeywell Microswitch brand hat switch on these units is rated for 15 amps. See http://www.rayallencompany.com/products/stickgripsG3.html I'm building a tandem (RV-8A) aircraft, so panel switches are out of the question for me. I plan to install two toggle switches to control who has control of the electric trim (4 pole double throw ON-OFF-ON) and flaps, which are also stick grip controlled (3 pole double throw ON-OFF-ON) This will allow these functions to be shunted to either the pilot (ON) no one (OFF) or co-pilot (ON). I want the OFF position to deal with any potential "runaway" condition. Yesterday, I placed several orders for electrical parts. I asked Waytek Electronics (a Carling Technologies distributor) for pricing on these 2 switches. Carling part numbers are: HM251-78 $17.71 each 3 pole double throw with 1/4" female fast on connectors and chrome bat handle IM251-78 $$2398 each 4 pole double throw with 1/4" female fast on connectors and chrome bat handle The problem is that there is a minimum of 11 for each item to place a special order for these items. Does anyone on the list know of a Carling distributor who stocks these? Failing that, anyone want to go in on a group purchase to get these? I can supply a copy of Waytek's quote "off list" to anyone interested. Charlie Kuss RV-8A wiring Boca Raton, Fl. > >Gentlemen, > > >I plan to have electric trim controls on the stick(s). These will need >relays, since the switches are small and the currents large. I also plan to >install either a pullable breaker or switch as Electric Trim Interrupt. I'm >thinking it might also be good to have a direct (no relays) means of >controlling the trim motors. I'm thinking of installing a pair of >(ON)-none-(ON) rocker switches on the console. Is this commonly done? Or do >most of you choose either stick-mounted controls or console-mounted >controls, but not both? What about stick-mounted controls on the pilot's >side only and console mounted controls for when the passenger/pilot takes
April 08, 2004 - April 22, 2004
AeroElectric-Archive.digest.vol-dc
