AeroElectric-Archive.digest.vol-de
May 03, 2004 - May 17, 2004
4 coils (1 per cyl)
4 injectors (1 per cyl)
2 computers
2 batteries
1 alternator
I'm thinking it would be nice to have a main bus,
essential bus (backup), overvoltage protection, and
the ability to tie the batteries together for a "self
jump".
I'm also thinking that feeding the injector and coil
12 volt feeds from both bus's would be a good idea.
Switching the ground leads via a relay board.
If this has been discussed please point me to an
approximate date and I will try the archives.
Ken Bauman
__________________________________
http://companion.yahoo.com/
This email and any files transmitted with it are confidential and intended solely
for the use of the individual or entity to whom they are addressed. If you
have received this email in error please notify the system manager. Please note
that any views or opinions presented in this email are solely those of the author
and do not necessarily represent those of the company. The recipient should
check this email and any attachments for the presence of viruses. The company
accepts no liability for any damage caused by any virus transmitted by this
email.
Subject: | Which side of the firewall |
How bad an idea is it to locate circuit breakers for my two alternator
output wires forward of the firewall beside the batteries? Some
breakers spec a 60 degree C. ambient but both my breakers would be rated
50% higher than the alternator outputs. I would guess there is not a
problem as far as the trip point goes. Used breakers are handy/cheap for
me but I'm willing to cough up the bucks for both an ANL and a Maxi fuse
holder if they are necessary or clearly a better idea.
I'm also wondering which side of the firewall to mount the voltage
regulator for a John Deere 20 amp PM alternator. I'd like to keep the AC
feed from the alternator forward of the firewall instead of bundling it
with the other wires coming through the firewall. I have a lot of efi
wiring coming through the firewall. OTOH the regulator might live longer
on the cool side of the firewall if there is no problem bundling all the
wires. Due to high ambient heat after shutdown, I've pretty much
dismissed the third option which would locate it on the forward side of
the engine.
thanks for any comments
Ken
Subject: | Pressure altitude and short sparks |
"As has been discussed on this list before, denser air (a composition of
non-conductive gasses) is a better insulator (higher dielectric breakdown
capability). As the air gets thinner, its propensity to conduct increases."
"You can see that Vacuum will break down at around 20kV with a 1" gap,
whereas dense air might hold up to 75kV over the same gap."
" A plug that works properly at atmospheric pressure may display shorts when
the gap is exposed to pressurized air (which has even higher dielectric
strength)."
How can it display shorts at higher pressure and still have higher
dielectric strength?
Ferg
Europa A064
Subject: | Re: Circuit Breakers and OVPs |
When an Over-Voltage Module crowbars the alternator field line to ground, it
is extremely important to have a fast blow circuit breaker for the
Alternator Field when using a crowbar. This fine point is easy to miss.
This really might be a good reason to use non-crowbar OVPs
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge MA 01550-2705
Phone (508) 764-2072
Email: emjones(at)charter.net
" I would have made a good Pope."
-- Richard M. Nixon (1913-1994)
Subject: | Re: Pressure altitude and short sparks |
Ferg
I think they mean breakdown outside the combustion chamber. Sometimes
poor/wet ignition wires will run the engine fine at low power settings
but at high power and high compression the wires break down and the
engine misses. The voltage goes higher to fire the spark under higher
cylinder pressure.
Ken
> strength)."
> Ferg
> Europa A064
> strength)."
When the pressure in the cylinder is higher the increased dielectric strength of
the air at the electrodes might cause the plug, wire, or some other place in
the ignition chain to break down first.
Brian Lloyd 6501 Red Hook Plaza
brianl(at)lloyd.com Suite 201
http://www.lloyd.com St. Thomas, VI 00802
+1.340.998.9447 (voice) +1.360.838.9669 (fax)
There is a time to laud one's country and a time to protest.
A good citizen is prepared to do either as the need arises.
----- Original Message -----
Date: Sunday, May 2, 2004 4:00 pm
Subject: AeroElectric-List: Pressure altitude and
short sparks
Kyle"
air (a
> composition of
(higher dielectric
> breakdowncapability). As the air gets thinner,
its propensity to
> conduct increases."
20kV with a 1" gap,
same gap."
> shorts when
even higher
> dielectricstrength)."
still have higher
> Ferg
> Europa A064
I think the answer here is that pressurize air does
in fact conduct more than a vacuum, which is the
best insulator; however, rarified air is more
easily IONIZED. What you have with ionized air is a
substance is an very good conductor. The subtle
difference can have some profound implications. For
instance, get some air moving across those worn
wiring harnesses and see if they still arc.
Hmmm.... I don't see how the cylinder pressure, before ignition,
increases with engine speed. Voltage might go up, as a result of magnito
RPM increasing. But these are some of the reasons why sparkplugs should
be tested in a pressure tester every time they are cleaned and gaped.
Bruce
www.glasair.org
-----Original Message-----
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of
klehman(at)albedo.net
Subject: Re: AeroElectric-List: Pressure altitude and short sparks
Ferg
cylinder pressure.
Ken
Subject: | Re: Pitot Static Sources and Ram sources |
It would make a great science project for your high school student to
determine if there is a size tube that is unattractive to mud wasps (and
therefore best for pitot [after Henri Pitot (1695-1771), French physicist]
tubes).
For bees, it turns out that if a gap (and maybe a hole) is below a certain
size, the bee will fill it. If the gap is bigger, the bees will build comb
in it, but if it is a certain size (7.5mm +/-1.5 mm) the bees will simply
ignore it. Rev. Lorenzo Langstroth (Philadelphia in 1851) was the first
person to use the bee space in hive construction. How he determined that
bees used the metric system is truly one of the wonders of science.
You don't have to search the NTSB very hard to find "wasp-like creature in
pitot tube" accidents. And you don't have to talk to many pilots to find
hair-raising tales that thankfully didn't end up in an NTSB report. Usually
pitot tube clogs are discovered near flying speed, half-way down the runway.
For static sources I am convinced (perhaps incorrectly) that too much fuss
is made of their position. And yes, you can tee off many instruments to the
same static source, and have multiple static sources. Classically static
sources have been taken from the supports for or just behind pitot ram
sources.
For pitot ram sources, you can also tee off many instruments, and
furthermore you can have multiple ram sources (several pitot tubes) leading
into one line. This seems never to have been done in EAA aircraft. Big
planes often use two or more pitot tubes but route them to their own
instrument banks.
I am designing a spare retractable pitot tube. The prototype will appear on
my website shortly. Comments are solicited.
Eric M. Jones
113 Brentwood Drive
Ring the bells that still can ring
Forget your perfect offering
There is a crack in everything
That's how the light gets in
- - Leonard Cohen
Hi Ken,
In addition to faults in the rest of the ignition system, spark plugs have a
fail mode that causes them to not spark at the electrode, but somewhere
within the body of the plug. Often, this kind of fail will only show up when
the electrode is exposed to the increased dielectric strength of a compressed
chamber - either in the sparkplug tester, or when being run in an engine.
I am not sure I understand your last comment about spark voltage. It sounds
like you are saying there is a mechanism that adjusts spark voltage based on
cylinder pressure - something I have never heard of.
Matt-
N34RD
> Ferg
> cylinder pressure.
> Ken
>> of non-conductive gasses) is a better insulator (higher dielectric
>> breakdown capability). As the air gets thinner, its propensity to
>> conduct increases."
>> shorts when the gap is exposed to pressurized air (which has even
>> higher dielectric strength)."
>> Ferg
>> Europa A064
It doesn't but it does increase with MAP. At low power settings the throttle is
mostly closed and the cylinder is sucking against the resistance of the throttle
valve. The MAP is low, probably 10" to 15" Hg, so the pressure in the cylinder
is correspondingly lower too. If the compression ratio is 10:1 (for ease
of calculation), the cylinder pressure at TDC with 10" of MAP will be 100"
Hg. With the throttle wide open the MAP will be close to 30" and the cylinder
pressure will be 300" Hg.
This is a simplistic calculation but hopefully it is understandable.
Ferg
engine misses. The voltage goes higher to fire the spark with higher
cylinder pressure.
Ken
> strength)."
> Ferg
> Europa A064
Subject: | Feedback for Bob - Roll your own crowbar module |
Original posting 4/12/04
>>I build my own OV crowbar module and it functions correctly except that
>>it operated in the 10-11 volt range. I triple checked the components
and
>>wiring. I tested the 1N4742A diode and it regulates at 12V. I changed
>>the 1.62K ohm resistor specified for a 14 volt system to 6.04K and the
>>circuit operates in the correct voltage range of 15.5-17 volts. Has
>>anyone else found this?
> With the 1.62K resistor in place, adjust the potentiometer to
> approximately mid range. Adjust the power supply to a point just
> below the trip point and then measure voltage at (1) + end of
> capacitor and (2) junction of zener diode and the 392 ohm
> resistor and tell us what you get.
> Bob . . .
> ( Experience and common sense cannot be )
> ( replaced with policy and procedures. )
> ( R. L. Nuckolls III )
Thanks for the reply Bob,
Sorry I took so long with a response to your suggestion.
I did as you suggested. The pot is set to mid range for all of the
following voltage readings.
Designating Point (1) as the + end of the capacitor, and Point (2) as the
junction of the 392 ohm resistor, and GND as the negative lead, I got the
following readings:
1.62 K resistor in place for 14 volt operation. - Trip point = 10.4
volts.
Point (1) - Point (2) +0.436 volts
GND - Point (2) +7.6 volts
6.04K resistor replacing the 1.62K one. - Trip point = 16.22 volts.
Point (1) - Point (2) +0.538 volts
GND - Point (2) +7.36 volts
These readings made me realize the circuit was not letting the zener
regulate at 12 volts so I did the following checks.
First I disconnected the SCR trigger lead to prevent it from firing.
I reinstalled the original 1.62K resistor.
Measuring the Zener voltage from GND to Point (2):
As I increased the input voltage the voltage across the zener increases
linearly to about 8.25 volts and then starts to decrease. The input
voltage is about 9 volts when this knee occurs.
I then disconnected the 1N4148 diode and repeated the above test with
basically the same results.
With the 1N4148 diode still disconnected, I also disconnected the NPN
collector and PNP base (they remained connected together) from the Point
(2) junction. Now only the Zener and 392 ohm resistor are in series
across the supply. Again measuring the Zener voltage from GND to Point
(2):
The zener voltage tracks the input voltage up to about 11.3 volts at
which point the zener begins to regulate.
With the two transistors still disconnected, I reconnected the 1N4148
diode.
Now the voltage across the zener increases linearly up to 9 volts (input
voltage is 9.35) when suddenly the voltage drops to 1.87 volts.
When I made the statement in my original email that the zener regulates
at 12 volts, I neglected to say that I tested it out of the circuit.
Ralph Ketter
RV-6
Marysville, KS
Matt
I'm just saying that the voltage rises until the plug fires at which
point the voltage drops. With more cylinder pressure the voltage rises
higher before the plug fires. With defective ignition components it can
be that the spark gets out somewhere else before the plug fires.
Bruce
I am suggesting that cylinder pressure (and manifold pressure) rises
when one opens the throttle like it would in a manual transmission car.
Similarly with a propellor, cylinder pressure generally increases with
manifold pressure.
Ken
Ken,
Thanks for the clarification. I hadn't thought about it in the terms you
described, but I agree with what you are saying.
Matt-
> Matt
> Bruce
> manifold pressure.
> Ken
Sorry, the engine is just a constant volume air pump. Cylinder pressure
will not vary, regardless of RPM, MP, or a constant speed prop.
Now cylinder pressure after ignition is a different matter.
Bruce
www.glasair.org
Matt
Bruce
manifold pressure.
Ken
The ideal static source would be located where the pressure was the
same as the ambient air pressure. But, the aircraft forces the air
to flow around it, which causes the air to accelerate and decelerate.
Bernoulli's law tells us that the static pressure will change as the
air accelerates or decelerates. So it is quite hard to find a place
on the airframe where the static source will actually be seeing the
correct pressure. And even if you find a location that is good at a
particular angle of attack, flap angle, etc, the airflow pattern will
be different at other conditions.
So, if you want accurate altimeter and airspeed readings, then static
source location is important. If you think having an accurate static
source is only important if you fly IFR, remember that the static
source error affects the altitude reported by our transponder, and
that affects the response of TCAS equipped aircraft. If the error is
small, no problem, but if the error is large you could easily have a
TCAS equipped aircraft that would have missed you if he had just kept
flying level, instead climb or dive toward you, because your
transponder is reporting that you are at the wrong altitude.
The transponder checks that are done won't find a problem with static
source position error, as static source position error only exists
when you have air flowing around the aircraft. You need to do
careful flight tests to measure it:
http://members.rogers.com/khorton/rvlinks/ssec.html
Ottawa, Canada
http://go.phpwebhosting.com/~khorton/rv8/
Bruce,
The peak cylinder pressure does change with manifold pressure.
Regardless of whether or not there is a spark.
For a normal 8.5:1 CR engine, if no spark, peak cylinder pressure
happens at TDC, at somewhere between about 125PSI and 300 PSI,
depending on MP .
Regards, George
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce
Gray
Subject: RE: AeroElectric-List: Pressure altitude and short sparks
Bruce
www.glasair.org
Matt
Bruce
manifold pressure.
Ken
Bruce,
I respectfully disagree.
I am not sure how an engine being a constant volume air pump has
any bearing on what the pre-ignition cylinder pressure is.... Air is
compressible. As the throttle position is varied, a varying mass of the
fuel-air mixture is allowed to enter the cylinder each time the intake
valve spends some time open. If the throttle is fully open, a larger mass
of fuel-air is drawn into the cylinder on the piston's intake stroke than
when the throttle is closed. This larger mass will cause a relatively higher
pressure to be generated when the piston reaches the top of its stroke,
achieving its fixed minimum volume. This is true whether fuel-air is ever
ignited or not.
I think the throttle works by changing the volumetric efficiency of the
engine - ie, how much volume of atmospheric pressure fuel-air is drawn
into the cylinder as compared to the actual cylinder volume.
Maybe I am missing something in your explanation...
Matt-
> Bruce
> www.glasair.org
> snip
> Bruce
> manifold pressure.
> Ken
Subject: | Z-12 Main Alternator Control |
Bob:
With respect to Z-12 (Single Battery, Dual Alternator) the main alternator appears
to be controlled by the main battery master switch while the aux alternator
has a separate on/off switch.
Is there a reason for not having a separate main alternator switch as well? I
plan on this system for the RV-10 I have under construction.
The aircraft is designed with a battery location aft of the passenger compartment.
With an aluminum airframe is the 4AWG ground cable to the instrument panel
ground bus still the preferred grounding method?
Many thanks.
Dick Sipp
RV10 #65
I stand corrected. My recognized expert on the subject has spoken. I'll
just slink back into my corner.
Bruce
www.glasair.org
George Braly
Bruce,
depending on MP .
Regards, George
Gray
Bruce
www.glasair.org
Matt
Bruce
manifold pressure.
Ken
Gray
Bruce
www.glasair.org
George Braly
Bruce,
depending on MP .
Regards, George
Gray
Bruce
www.glasair.org
Matt
Bruce
manifold pressure.
Ken
To get back to the original topic, which related to altitude and ignition
system.
The cross firing that happens at higher altitudes is usually due to the air
density in the distributor. That is the rotor inside the distributor is
moving between tabs on the distributor cap, so the air acts as the
dielectric between the plug that you want to fire and the neighboring plug
or tab in the distributor. As the altitude increases it is easier for the
spark to jump to the neighboring distributor tab.
As far as the ignition system goes, basically the spark plug is has two
electrodes and the voltage potential required to jump an arc between the two
electrodes is proportional to the number of air particles between the two
electrodes. That is again the dielectric strength of the air, with cylinder
pressure this dielectric strength increases. So when the cylinder has the
most pressure, the spark plug requires the highest voltage to start the
spark. After the spark is started the voltage required to maintain the spark
decreases.
So what happens is that when the engine is under a load, like when
accelerating in a car, the cylinder pressure is very high. Thus it takes a
higher voltage to start the spark in the plug. In most engines with good
ignition components it takes about 8-12KV to start the spark on the plug.
Now in the distributor cap, at sea level it takes over 20KV to have the
spark jump to neighboring plug. Now for example imagine you go up in
altitude and now it takes about 15KV to fire neighboring plug. Now also
imagine that your ignition wires are old (higher resistance) and maybe your
plugs are worn such the gap is a bit wider and now instead of 8-12KV to fire
the plug you are looking at 15-18KV. Then at this point it is easier for the
arc to jump to the neighboring plug than your plug. Keep in mind the
neighboring plug has little compression in it's cylinder, thus the 15KV is
mainly used to jump gap in distributor cap. Thus the engine will run perfect
at low altitudes and miss or cross fire under a load at high altitudes.
Now if we want to get further into the spark plug and ignition system we
would notice that a coil is charged with energy and then that energy is
released as a spark to the plug. Thus there is only X amount of energy and
when your plugs or wires wear such that it takes higher voltages it start
the plug arcing, well this basically means it takes more energy to start the
arc, thus there is less energy left to maintain the arc. That is the spark
duration, amount of time plug is arcing, will decrease. This means that the
spark plug may not have enough time to completely ignite the fuel in the
cylinder and again you get a miss. The reason being that there is fuel and
air in the cylinder, ideally these particles are mixed really well. However
the spark plug has to ignite enough fuel particles such that they can in
turn ignite other. Thus the more fuel particles the arching of the spark
plug can hit the more likely combustion will propagate. Thus on newer car
engines they are going to wider spark plug gaps, the problem here is again
the coil has to be charged with more energy. Here again if you have one coil
for eight cylinders you can only charge it for a short time. Thus automotive
manufactures have started going to coil on plug. That is there is one coil
per plug. This means they can put more energy into the spark plug and
increase the spark plug gap, thus making it more likely you can ignite the
fuel, getting fast combustion propagation and also run a leaner mixture, one
closer to 14.7:1, and some times even leaner.
Trampas
www.sterntech.com
Lots of interesting comments on this subject, but there were some that
played a little loose on the terminology and technical details, possibly
contributing to confusion:
You can't assume that if the compression ratio is 10:1 that the pressure is
10 times the manifold pressure. The pressure actually rises as the 1.35 to
1.4 power of the volume ratio. The difference depends on leakage and the
heat rejection of the air to the cylinder walls and there is less heat
rejection at higher speed. Also, volumetric efficiency will generally rise
with engine speed, at least from cranking speeds to a mid speed range.
Therefore, the peak compression pressure will rise with engine speed. For
instance, with a 10:1 compression ratio the peak compression press will be
22 to 25 times the manifold pressure.
You can't mix the terms "conductivity" and "dielectric strength." All
material is conductive to some degree, but dry air is almost non-conductive.
However, if you apply a large voltage gradient across air it will ionize and
become very conductive. The voltage gradient at which this happens is
dielectric strength and that voltage goes up with pressure. Once the air is
ionized it takes much less voltage to maintain current flow, probably less
than 1/10 the voltage required for the initial breakdown. If you look at
the spark plug voltage with a good scope you will see the initial rise in
voltage to a very high value (maybe 10,000 to 20,000 volts) and then it will
drop to a very low value of 1,000 to 3,000 volts for the remainder of the
"burn." In order to cause this ionization, individual molecules must be
ionized. If there is a high air velocity through the gap these ions will be
blown away, inhibiting a breakdown. For this reason the required ignition
voltage does go up with engine speed as the air velocity in the combustion
chamber is essentially directly proportional to engine speed. This effect
is not the dominate one, though.
I don't know if this clarified the issue or made it more confusing.
Gary Casey
I was trying to explain things simply so that people who are not engineers or mathematicians
could quickly and easily grasp the concept.
But as I recall, the ideal gas law states,
PV = nRT
If the compression ratio is 10:1 and you have isothermal compression then the final
pressure will indeed be 10x the inlet pressure as P varies inversely with
V since n, R, and T don't change. I know that this is not totally realistic
but delta-T is going to be a lot smaller than you think because the heat of compression
will quickly transfer to the head and piston crown.
Regardless, you are correct in the details. Sorry I was being too simplistic.
I guess it depends on who you talk to. You are certainly more correct than I was
in detail.
> Bruce
> www.glasair.org
While the engine IS a constant volume air pump (in that the total
displacement of volume over a cycle is constant), the pressure generated
when the piston reaches TDC does depends on the density of the air volume
ingested by the cylinder. At low manifold pressures, the air inside the
manifold and therefore ingested by the engine, is lower in density than when
at high manifold pressures. This difference in density (not volume) is why
your air/fuel mixture needs change as well as the power you produce as you
vary the throttle opening. So taking a the same volume, but with air at say
twice the density at one intake event vs another intake event and compress
the density charge to the same TDC space and the pressure will be greater
than for the less dense charge. The engine is a constant volume machine,
but the cylinder pressure created does differ due to the different air
density in the manifold when the intake valve opens.
FWIW.
Ed Anderson
RV-6A N494BW Rotary Powered
Matthews, NC
From: | Bobby Hester <bhester(at)hopkinsville.net> |
RV-List
Subject: | Internal Regulated Alternator converted to External? |
Has anyone had there Van's internal regulated 60amp alternator converted
to external and used B&C's LR3C-14 regulator?
Does this make since to do?
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A Slowbuild wings-QB Fuse :-)
Subject: | Off topic - tracing house wiring |
Apologies for asking this on the list - but where else can one find
electrical-savy people concentrated in one place?
First - the home in question is in Hong Kong, and I've got no idea who
installed the wiring in the first place, or if I could find them even if
I knew.
Here's the challenge:
We have a concrete ceiling in our living room - with some 'loomex' type
wire imbedded in the concrete, terminating in the middle of the ceiling.
I've mounted a ceiling fan there, but cannot find where the other end of
the wire is located. I'd assumed it was at the large bank of switches
near the entrance door, as some of them did nothing. The wire doesn't go
to those switches, however, so I still cannot put power to the fan.
Somewhere in the dark recesses of my mind I recall seeing a device used
to trace wires. One part of the unit sends some kind of pulses down the
wires, and the other part is a detector for those pulses. So you clip
part a) onto the cable you need to trace, and use part b) to follow the
wire through whatever it's hidden behind.
Do any of you know what this unit might be called - or who makes them
- or where they can be purchased?
Or is this another home brew project coming up?
Thanks - Ron Koyich
Subject: | Re: Off topic - tracing house wiring |
This is the one I have
http://bkprecision.com/pressrelease/july27.html
http://www.testequipmentdepot.com/b+k%20precision/262.htm
http://www.tequipment.net/BK262.asp
The label says "made in China." No guarantee, of course, but you might be
able to get one locally.
Thanks, Richard - I found a transmitter/receiver pair in Sham Shui Po
today - but after getting them home and connected, I couldn't find the
other end of the cable anywhere in our flat!
God only knows where it goes - I wandered all over the place, including
many unlikely places, like the bath off the master bedroom. Nothing. No
warble tones except at the start of the cable.
Time for another approach - swagged power cords used to be in fashion
in the '70s.....
Again, thanks!
Ron
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
>Below is the result of your inquiry. It was submitted by
>mike speer (m.speer(at)shaw.ca) on Monday, May 3, 2004 at 10:33:36
>Monday, May 3, 2004
>mike speer
>Email: m.speer(at)shaw.ca
>Comments/Questions: Hi..
>I have RG-58/U cable that came with my ELT, it is too short for the
>location where I want to place my antenna. I would like to know if it is
>possible to use RG-400 cable as a replacement for the supplied cable.
>Thanks for all your wonderful advise...Mike
Yes. In fact, RG400 or RG142 are the materials of choice
for modern aircraft fabrication.
I will invite you to join us on the AeroElectric List
to continue this and similar discussions. It's useful to
share the information with as many folks as possible.
A further benefit can be realized with membership on
the list. There are lots of technically capable folks
on the list who can offer suggestions too. You can
join at . . .
http://www.matronics.com/subscribe/
Thanks!
( Knowing about a thing is different than )
( understanding it. One can know a lot )
( and still understand nothing. )
( C.F. Kettering )
Define "fast blow circuit breaker" . . .
The fault current that flows in the crowbar module is
something on the order of 200-300A when it trips. I'm aware
of no 5A breaker that is particularly "slow" when
presented with this condition. I can offer no
valid "concerns" to anyone who is selecting breakers for
their project where the use of crowbar ov protection is
anticipated.
From: | Mark Steitle <msteitle(at)mail.utexas.edu> |
Subject: | Re: Internal Regulated Alternator converted |
to External?
Bobby,
A while back I wrote up an explanation for some on this list on how to
convert the ND internally-regulated alternator to external regulation. I
don't see where it would matter which external regulator you use, as long
as the voltage is correct. A search of the archives should locate the
article.
Mark S.
You are right in the gas law, but the assumption of constant temperature
(isothermal) compression is incorrect. It is very close to adiabatic (no
heat transfer) than it is to isothermal. In that case V has an exponent
that turns out to be approximately 1.4. Since there is actually some heat
transfer the exponent can be assumed to be a little lower than 1.4, so 1.35
might be a better number - the higher the engine speed the closer it is to
adiabatic. You're right, it does sound a little picky except that going
from isothermal to adiabatic changes the predicted peak pressure from 10X to
24X - it can't be ignored.
Another post said:
Exactly, but only true for turbocharged engines that can maintain a fixed
manifold pressure regardless of altitude. For a naturally aspirated engine
the compression pressure drops in proportion to atmospheric pressure so
there is no more cross-firing problem at altitude than at sea level.
Also:
Typical Coil-On-Plug (COP) systems use coils that actually require SHORTER
dwell times that single-coil systems. The reason for this is that with no
losses in the plug wires it takes less spark energy to light the fire. A
byproduct of that is the voltage rise times are faster, making it more
likely that fouled plugs will still fire. But the reason for using COP
ignition is mainly to eliminate the least reliable part of the engine - the
plug wires (Then why does GM mount the individual coils on the valve cover
and use short plug wires? Have to ask them). And, yes, a leaner mixture
has a higher dielectric strength than a rich one, requiring higher spark
voltages. Automotive engines run 99% of the time at exactly 14.7:1 air/fuel
ratio so the push to higher voltages has pretty much stopped. An aircraft
engine at peak EGT is running about 15:1 and at 100 LOP is at about 16:1,
leaner than an automotive engine mixture.
Gary Casey
Subject: | RE: Off topic - tracing house wiring |
>From: Ron Koyich (Ron(at)Koyich.com)
Now hold on there Roy! Don't give up. The Aeroelectric list has a combined
IQ greater than all of China, even with Bob N on vacation. So here's my
suggestion.
The tester you have may be the wrong tool. Is it one where you attach leads
to wires and then go look for them in a fusebox? Then it won't do this job.
We need to know: Since apparently you have access to the ceiling leads only;
can you determine anything from them? Are there two leads or three? Are they
grounded to each other or ground? Is there resistance from one to the other?
Have you opened all fixtures, switches and outlets for inspection? Anything
else?
Possible approaches:
1) Metal detector. Depending on the construction of the house, might work
well.
2) Signal generator/radio method: Attach the output of the signal generator
tuned to a radio station frequency to the ceiling wires (assuming they're
not live). Use an AM radio tuned to the same frequency. When near the wire,
the radio station will be blocked. Some fiddling around may be required.
This works well to eliminate annoying radio and TV stations from the local
area as well.
3) Call an electrician.
4) Call a better electrician.
Eric M. Jones
113 Brentwood Drive
On a related subject, do you have a part # / source for a device to handle
the Load Dump issue and Internal Voltage Regulators that was discussed
here a couple of months ago?
Wally Enga
> anticipated.
> Bob . . .
Thanks, Eric - on the one hand you give me confidence that we might get
somewhere, then on the other you get my name wrong - ah, lack of
confidence creeping in.
My name is Ron - not Roy. You're not the first to make this mistake -
I think it has to do with the 'Koy' in my family name.
only; can you determine anything from them?<<
>> Are there two leads or three?<<
Three leeds. None connected to anything. No voltage and infinite
resistance between any two.
>> Are they grounded to each other or ground? <<
No - total open circuit - the other end is floating somewhere.
>>Is there resistance from one to the other?<<
No.
>>Have you opened all fixtures, switches and outlets for inspection?<<
Not absolutely every one, Eric. But nearly every one and all close by.
And I've put a warble tone on the leads and found the other ends of the
wires nowhere, including searching in every room of the apartment, and
all wiring fixtures.
>> Anything else?<<
The wires may terminate in the flat above us.
>>Call an electrician<<
My bet is he'd want to chisel out the ceiling and run a cable over to the
wall - too much mess. Decorating department has ruled out swag cord to
the fan.
If you're in the neighbourhood, Eric, please drop by and sort it out for
us....
Thanks for the suggestions - we're into deep thinking now.
Best - Ron
I had no idea what I stirred up with this topic, but found the
byplay very interesting and have archived some extensive text on same. Added
some depth to a shallow understanding of how an engine pumps out its
guts............
Thanks for the trouble taken!
Ferg
Europa A064
From: | "McFarland, Randy" <Randy.McFarland(at)novellus.com> |
Along the lines of RG 400 use, can anyone tell me why the Garmin 327
Transponder installation manual suggests in their Antenna Cable table 2-1
the max length for the cable is 8.8 feet if using RG 400?
Is this length specific to the transponder antenna only? Can I run RG 400
for Com / Nav antennas longer than 8.8 feet? (like about 20' out to the
wingtip?)
Thx
Randy
RV7A Panel wiring
From: Robert L. Nuckolls, III [mailto:bob.nuckolls(at)cox.net]
Subject: AeroElectric-List: Re: Coax Cable
>Monday, May 3, 2004
>mike speer
join at . . .
Thanks!
( C.F. Kettering )
From: | Richard Tasker <retasker(at)optonline.net> |
Subject: | Re: RE: Off topic - tracing house wiring |
Ron, we lived in HK for three years and I know what you are going
through. We had a similar problem when wires running to an outlet that
our heater/air conditioner was connected to burned out (thank goodness
for concrete or we may have had more than just burned out wiring). One
would have thought that it would have been an easy job to just pull new
wires through the embedded conduit... Unfortunately, the conduit had
evidently corroded and the old wires were trapped in the conduit. I
finally ended up just running surface wiring to the outlet. The joys of
HK construction! The fuse box was such a nightmare I didn't even want
to open the door!
If you haven't already tried, connect the wire tracer to a known set of
wires to make sure that it is working and will actually trace wires like
you want to do. Most of the tracers available in the US assume that you
have typical US wiring - no conduit, no armored cable - so they may not
work in HK where the wiring is installed in conduit embedded in concrete
with lots of rebar around (and who knows - they may have embedded the
wiring directly.
And, yes, I am sure that an electrician would do exactly what you
suggest - lots of chiseling and lots of dust...
Dick Tasker
From: | Dennis Haverlah <clouduster(at)austin.rr.com> |
To keep bugs out of my pitot tube and fuel tank vent tubes on my
Bonanza, I crumpled up a small piece of aluminum screen and pushed it
into each tube. Keep it within 1/16 to 1/8 inch of the end. No more
bugs and the air can move in or out OK. Has worked for over 10 years.
Dennis H.
>tubes).
>sources.
>instrument banks.
>Regards,
>Eric M. Jones
>113 Brentwood Drive
> - - Leonard Cohen
I would like to build an audio amplifier for my Zenith CH601HDS. I want
to mount a 3 way bookshelf speaker in the baggage compartment and feed
the headset audio to it. The speaker I have will handle 40 watts but I
think driving it with 10 -20 watts should be adequate - any thoughts?
The amplifier needs 150 Ohm input and 4 - 8 Ohm output, 12 V. DC power.
Anyone know of a source, either diagram or ready made?
Leo Gates
I am one of two that are doing an engineering test characterization and
design of a Load dump clamp.
I am sorry but that project is way behind but nearing completion of
preliminary results. There are other pressing issues (not related to load
dump) that is delaying my completing the testing.
I (we) fully expect to have one or two proven solutions available as well as
purchase info, now estimated late this month.
Paul
Subject: Re: AeroElectric-List: Re: Circuit Breakers and OVPs
> Bob,
> Thanks
> Wally Enga
ground, it
> > anticipated.
> > Bob . . .
Gary,
<From: | "Eric M. Jones" <emjones(at)charter.net> |
Subject: | RE: RE: Off topic - tracing house wiring |
Sorry about the name thing Ron.
Many good suggestions have bubbled up to the surface. I especially like the
smoke thing or the vacuum cleaner thing, if there is a conduit. Carbon
dioxide would work well too. On a humid day, CO2 would cause condensation on
the concrete where the conduit is.
Or if you can establish that the conduit or wiring is not too deep, boring
test holes with a diamond hole saw would access the wiring, not make much
mess, and could easily be patched.
Eric M. Jones
113 Brentwood Drive
"Mankind faces a cross-roads.
One path leads to despair and utter hopelessness.
The other, to total extinction.
Let us pray we have the wisdom to choose correctly."
--Woody Allen
Subject: | Re: Audio Amplifier |
In a message dated 5/5/2004 3:50:18 PM Eastern Standard Time,
emjones(at)charter.net writes:
http://www.allelectronics.com/cgi-bin/category.cgi?category=937&item=AMP-30&ty
pe=store
Eric M. Jones
Eric, Leo,
This amp calls for an AC power input not DC. But, not to worry, you may be
able to bypass internal power supply rectifier and run on DC.
John P. Marzluf
Columbus, Ohio
Kitfox Outback (out back in the garage)
From: | "Bob Miller" <drmiller(at)cvillepsychology.net> |
Subject: | Inrush current protection for lights |
I've seen little button-size devices that you insert between a standard lightbulb
and its socket that supposedly reduces the shock of inrush current that tends
to wear out filaments. A keepwarm circuit would be preferable, but my PM
alternator produces only 10 amps continuous and I'm about at that limit. Is
there anything like those button devices that might work in an aircraft as an
alternative to a keepwarm circuit? I know it won't protect the lamps from vibration
damage, but it would at least be better than nothing.
Bob Miller
Eric, John,
My thoughts exactly. I ordered one today.
Thanks again Eric and thanks John.
Leo
>pe=store
>Eric M. Jones
>Eric, Leo,
>John P. Marzluf
>Columbus, Ohio
Subject: | Re: Inrush current protection for lights |
In a message dated 5/5/2004 4:34:23 PM Eastern Standard Time,
drmiller(at)cvillepsychology.net writes:
lightbulb and its socket that supposedly reduces the shock of inrush current that
tends to wear out filaments. A keepwarm circuit would be preferable, but my PM
Is there anything like those button devices that might work in an aircraft as
an alternative to a keepwarm circuit? I know it won't protect the lamps from
vibration damage, but it would at least be better than nothing.
Bob Miller
The device you have seen I believe is simply a diode that rectifies the
voltage supply to a household light bulb. Instead of the bulb's filament dropping
the entire 120 volt AC voltage across itself, it only sees a half wave pulsing
DC supply at half average voltage. The bulb will last a long time but with
less light output. For DC voltage aircraft application I would guess using the
lowest wattage bulb that will give the minimum light that you require is
best. Keep it cooled and vibration protected and forget about browning out the
applied voltage. Why waste power on a filament protection device when you only
have 10 amps in the bank?
John P. Marzluf
Columbus, Ohio
Keystone also makes a variety of inrush limiters which are just
thermistors that have a high cold resistance and less resistance when
they heat up. Physically they look like an MOV or a large ceramic disc
capacitor. I have tried them on sealed beam lamps and they seem to only
dim the lamp very slightly. Personally I think it is not worth the
effort for automotive style lamps but it might be worth it for more
expensive certified lamps.
Ken
that
PM
> Bob Miller
> Bob,
> John P. Marzluf
> Columbus, Ohio
In a message dated 5/5/2004 7:59:28 PM Eastern Standard Time,
klehman(at)albedo.net writes:
Ken
Hello Ken,
There are so many variations to semiconductor devices it is hard to tell
exactly what it is without a data sheet. There used to be a device used in
television circuits called a VDR (voltage dependent resistor) that looked like
an
MOV in a black or dark brown disk packaging. They may still be used, I don't
know. Upon initial power up the device offers very low resistance in series
with the degaussing coil, once full voltage is realized across the coil, the
resistance climbs to near infinity, shutting off the current to the coil. Perhaps
they are actually temperature transient activated?
John P. Marzluf
Columbus, Ohio
From: | "Patrick Elliott" <pelliott(at)innercite.com> |
Subject: | Alternator from Mag drive. |
Just bought a VariEze and need a power source. I'm putting two LSE Plasma 3
systems on it and will have two empty mag holes. Does anyone know of a
light weight alternator that is driven from a magneto drive? before you
ask .. It's on a Rotorway Rw-100 which uses standard Slick mags. same mags
you'd find on an O-200
_____
Patrick Elliott
541 297 0004
Subject: | Re(buttal) Circuit Breakers and OVPs Rebuttal |
it
>>Eric
>anticipated.
>Bob . . .
Now Bob....
The circuit breaker associated with the OVP crowbar is a unique case among
aircraft circuit breakers. Typically circuit breakers used for this purpose
ARE fast blow types. I merely observe that this is a good practice to
follow. Otherwise why bother with a fast SCR or Mosfet circuit at all when a
simple NTC thermistor would do fine.
Okay. I looked up "fast blow circuit breaker" in the dictionary and it says:
"Circuit interrupting device with faster trip or quicker response than
normal." There is a picture of an Eaton 1500.
The idea that a circuit breaker will blow faster at higher current is not a
linear correlation. Most breakers are simple bimetal types.
You choose: Eaton model 700, at 1000% capacity 25 degC, trips from 0.5
second to 1.5 second.
Eaton model 1500, same conditions, trips at 0.025
second to 0.2 seconds.
My epiphany that this should be--was based on making some smoke and trying
to find out why. What I found out is that it is easier to sink hundreds of
amps than it is to interrupt it with a slow bimetal circuit breaker.
My good suggestion is simply to use a fast circuit breaker in the Alternator
Field line when using OVP.
Eric M. Jones
113 Brentwood Drive
Trampas,
You are right in that at higher altitudes it takes less voltage to jump
between tabs in the distributor or to jump a gap from a cracked plug wire.
But the condition that creates the voltage level is the pressure in the
combustion chamber, so at higher altitude there will be less voltage
required to jump the gap in the plug, which is the dominant factor. It
should only be a problem at full throttle when combustion pressure is the
highest compared to atmospheric. Then why, as Old Bob points out, would a
non-supercharged engine have a problem at high altitude? Don't know, but
here is a theory: At low altitude the engine is always run rich at full
throttle, keeping the voltage requirement down. Only at high altitude is
the engine leaned while the throttle is full open. Under lean conditions
the voltage requirement rises by some amount and I'm not sure how much -
maybe 10 or 20%? The only other explanation I can come up with is that the
distributed capacitance of the ignition wires tends to require a higher peak
voltage that is actually necessary to jump the gap in the plug. This effect
is constant with altitude, creating a coil voltage that does not drop quite
as fast as altitude rises. Just a couple of theories. Make sense?
Gary Casey
Subject: | Re: Re(buttal) Circuit Breakers and OVPs |
Rebuttal
>it
> >>Eric
> >anticipated.
> >Bob . . .
>Now Bob....
How so unique?
>follow.
There are volumes of "good practice" admonitions published
that offer little or no assistance to the reader. For example,
AC43-13 has a big table of wire types that may be considered
for use in the repair or modification of aircraft. I have yet
to meet the A/P that can wade through that pile "good practice"
advice and make a considered selection . . . not to mention
find a supplier that can sell him 20 feet of his wire-of-choice.
The term "fast blow circuit breaker" is non-quantified, and without
recommendations for a specific part number, gives the neophyte builder
no information upon which he/she can operate. I object to the
non-quantified,
non-specific recommendations because they raise concerns while
offering no specific solutions. Tossing out the "fast blow"
tidbit can serve only to raise anxiety levels.
>normal."
Luv that term "normal" . . . if you ran a parts house and
an RV builder walks in to purchase a "normal" circuit breaker,
what would you sell him?
. . . without explanations like you offered above, the
information is of little value to most of the folks who frequent
this list. The question still unanswered is what are the effects/risks
for having a model 700 versus a model 1500 breaker installed
as the field control breaker?
It's an interesting discussion for folks who make careers of
sifting the fine points of contact physics and thermodynamics.
I'll suggest that in this venue, little jewels of knowledge should
be supported by an explanation of physics and considered recommendations
for selection of parts and materials.
Subject: | Re: short Vans master relay stud length, |
again...
>Guys,
>I know this has come up before...I've got the Vans master relay with the
>oh-so-short little studs which will barely hold a single terminal let
>alone the multiple ones that I need (battery lead, e-bus feed, Lightspeed
>#1, and aux battery feed).
>Before I toss it in the useless parts bin and order a manly B&C relay on
>Viagra with a stud size worthy of my 21st Century electrical system, I'm
>just curious as to why I can't stack the aformentioned terminals directly
>on the + battery terminal? Seems I recall hearing somewhere that this is
>bad practice, but can't think of how the physics of the connection would
>be any different (i.e. less convenient or less secure) this way as
>opposed to attaching them all to the master relay stud. But I don't have
>my battery yet (planning Odyssey PC680) so I'm not sure if there are
>issues I'm unaware of....
Normally, it's not a good idea to fiddle with the assembly
hardware on this series of contactors. Improper placement
of the stud when tightening the mounting nut for the stud
might cause mis-alignment of contact faces within the
assembly and reduce life of the contactor.
Since replacement of the contactor was already being considered,
I thought we might explore the possibility of getting more exposed
threads by replacing the existing mounting nut with a jam nut
as shown in
http://www.aeroelectric.com/Pictures/stud_length.jpg
The White-Rogers contactor on the right seemed to have
good rotational stability so that replacing the original
nut with a thinner one yielded several more threads for
terminal stacking. Unfortunatly, the Cole-Hersee part has
a SPECIAL nut that cannot simply be replaced with the
plain brass jam nut. So, I guess my best recommendation
is to get the more user friendly part from B&C - or stack
terminals on the battery post. It's a threaded brass terminal
so you'd probably get away with it. Personally, I'd
go with the longer stud on a contactor.
Gary,
How about this for a theory, the air plane requires XX number of horse power
to fly at some indicated air speed. This will be regardless of altitude as
we are using indicated air speed, assume no wind and same air temperatures.
Thus to produce this horse power the pressure in the cylinders will be same
at low altitudes and high altitudes. The difference is that at low altitudes
the throttle is not opened as wide thus regulating the manifold pressure,
then at higher altitudes you have to open the throttle more to get the extra
oxygen, which will keep the manifold absolute pressure where it was at lower
altitude, again with the assumption air temperature is constant. Thus as
mentioned, in previous posts, the pressure in the cylinders is based on
manifold air pressure. Thus to produce the same horsepower at higher
altitudes you open the throttle more to match manifold pressure to the same
level as it was at low altitudes, assuming same mixture adjustment and same
air temperature.
Trampas Stern
www.sterntech.com
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gary
Casey
Subject: AeroElectric-List: Re: Pressure altitude and short sparks
Trampas,
Gary Casey
Yes. If you have a DME you can consider that it has the same limitation since
it runs at approximately the same frequency as the transponder.
> Can I run RG 400
> wingtip?)
Yes.
When you run a signal through coax some of it is lost in heating the dielectric
between the center conductor and the shield. The loss at 1000 MHz (where the
transponder signal is) is much higher than the loss at 118 MHz. There should
be no problem running VHF comm and nav signals anyplace in the airplane using
RG-400.
You can find an entire range of high-power automotive amplifiers that should do
the job for you. Get one that has line-level inputs and try that. Get one that
has an adjustable input attenuator (volume control). Most can be bridged
so that they provide more power to one output, such as a subwoofer.
>Barry M. Schulte (FLYaDIVE(at)AOL.COM) on Wednesday, May 5, 2004 at 04:19:06
>Barry M. Schulte
>Email: FLYaDIVE(at)AOL.COM
>Comments/Questions: Hi Bob:
>I have been trying to remove Strobe Whine from my audio system. I found
>on your site (GREAT SITE)a circuit using Radio Shack parts. Only problem
>is the Radio Shack Part is no longer available (Part Number 270-030,
>Filter kit. Would you have the values of the components used (Choke and
>Capicator)?
I usually attack strobe whine at the source . . .
strobe power supply. They are notorious noise sources
but generally easy to tame. Try an off-the-shelf filter
like these from Radio Shack:
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-051
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-055
Install at the power supply location. Let us know
what you discover.
join at . . .
Thanks!
( C.F. Kettering )
Subject: | Second Com Antenna Placement |
I have one Comat bent whip Com antenna mounted just aft of the battery box (next
to the firewall) in the midline of my RV6A. I have a second Archer wingtip
Com antenna in my right wingtip. The Archer is not performing up to my specifications
and I want to put a second bent whip Comat Com antenna somewhere. My
first choice would be behind the first on the midline of the belly. If I put
it there, how far back do I need to place it? Are there other locations that
would be better? My hanger mate has one on the belly and one on the turtledeck.
I don't particularly like the idea of putting the antenna on the top.
Thanks.
Ross Mickey
N9PT
From: | "Troy Scott" <tscott1217(at)bellsouth.net> |
Subject: | Re: Re Re: Re(buttal) Circuit Breakers and OVPs |
Eric and Bob,
What do you know about these ECBs listed in AS&S?
ECB-14-02
THE ALL-ELECTRONIC CIRCUIT BREAKER
This circuit breaker has no mechanical parts, except for the reset switch.
The power switching and control components are completely solid state. It
has the added benefit of over- voltage and under-voltage protection. It will
turn off if the input voltage goes too high, protecting valuable avionics or
other equipment.
The above is a quote from the AS catalog. Even if we utilize the OVP in the
B&C VR, I wonder if one of these might be a good choice for a really "FAST"
field interrupt CB?
Another thought: For the ultimate in fast and cheap, why not just use a
fuse for field wire interrupt OVP? The fuse for that one item could be
conveniently located for in-flight replacement even if all other fuses are
behind the panel somewhere.
Troy
>since it runs at approximately the same frequency as the transponder.
> > Can I run RG 400
> > wingtip?)
>Yes.
>dielectric between the center conductor and the shield. The loss at 1000
>MHz (where the transponder signal is) is much higher than the loss at 118
>MHz. There should be no problem running VHF comm and nav signals anyplace
>in the airplane using RG-400.
Something I can add to Brian's explanation is illustrated in
a page from our website at:
http://www.aeroelectric.com/temp/coaxloss.pdf
Referring to this drawing we see that RG-58 coax has about
30 db loss per 100' of length at transponder frequencies.
RG-400 (and RG-142) will have about 20 db of loss per
100'.
30 db attentuation means that a transponder signal will
loose 99.9% of it's strength while working its way down
100' of RG-58 while 99% of the signal will make it to
the other end of RG-400. Not really good figures in any
case. The point here is that RG58 has 10x the losses
as RG400 at these frequencies.
Now, consider a 10' run of coax to the transponder antenna.
RG-58 will toss off 3 db of your signal (50%) while RG-400
will toss off 2 db (about 37%). For this hypothetical
installation, there is a 12% gain in both outgoing and
incoming signal strengths for replacing RG58 with RG400
in the transponder installation for a 10' cable run.
At VHF comm frequencies, were looking at .7 db (15%) versus
.5 db (11%) for the same 10' run.
Bottom line is that EITHER RG-58 or RG-400 will offer
adequate functionality for the relatively short runs
of coax needed in light aircraft at either comm or
transponder frequencies. The biggest advantage of
RG-400 and its close cousins are modern, high temperature
and stable plastics plus the silver plated, double
shield construction.
In the case originally cited, Garmin is specifying their
equipment to meet published performance with a maximum
of (8.8/100)*20 or 1.75 db of attenuation in both transmit
and receive paths. If you need a longer run, expect
a small (probably imperceptible) degradation or you can
go with a whippier coax like RG-223 where the losses
are 17 db per 100' so you can use up to 10.3 feet of
coax without degrading performance below the published
specifications.
Subject: | Re: Second Com Antenna Placement pts rule |
My first choice would be behind the first on the midline of the belly. If I put
The best isolation will come from putting one antenna on the top and one on the
bottom. If you do that there is a chance that the receiver in one radio will
still work and not become overloaded when the other radio transmits.
If you don't care you can place both antennas on the belly. The more distance
between them you can manage, the better it will work. Try to keep them at least
1M apart.
I am still confused about why Eric says that there is a need for a fast
breaker in the field line. It seems like the only benefit to it is that
it might
shorten the duration of the over-voltage event. My impression is that
components built to DO160 standards will have no problem surviving
the transients associated with time constant required to open a standard
breaker....
As has been discussed (view in the archive), the reason not to use the
fuse is that there are short-lived bus transients present that may cause
nuisance trips of the circuit protection but which will cause no damage to
modestly rugged system components.
Matt-
N34RD
> Eric and Bob,
snip
> the B&C VR, I wonder if one of these might be a good choice for a really
> "FAST" field interrupt CB?
> are behind the panel somewhere.
> Regards,
> Troy
Subject: | Labeling of wires |
name(at)matronics.com, description(at)matronics.com, ----(at)matronics.com,
----------------------@matronics.com,
--------------------------------------------------@matronics.com
I would like to ask the group if there is some sort of labeling system that
you would recommend when labeling wires. I am not asking what the hardware
should be, but, what sort of letters or numbers or combination thereof to use to
mark all of the different wires.
Thanks, Mike
name description ---- ----------------------
Thanks, Brian.
When you say 1m apart, what distance are you measuring if they are for and aft
of each other? The distance between the mounting blocks or the distance between
the aft mounting block and the aft tip of the forward antenna?
Thanks again,
Ross
Subject: Re: AeroElectric-List: Second Com Antenna Placement
> The more distance between them you can manage, the better it will work. Try
to keep them at least >1M apart.
>it might shorten the duration of the over-voltage event.
....As if that weren't reason enough....
The purpose of a fuse or circuit breaker is to interrupt the circuit if
something bad happens.
It is not always the case that excessive current is what trips breakers. But
usually, and in every aeroelectric case except the OVP case, excessive
current determines if and when the circuit breaker trips.
Now, most circuit breaker designs are designed with thermal stresses in
mind; that is, they protect the wire from melting and starting a fire. Speed
is hardly essential. If a short circuit causes a wire to overheat, whether
you cut off the power instantly or a second later usually makes little
difference. Thus most or all other breakers should be delayed trip.
In the OVP case, the alternator field circuit breaker is essentially
modified to trip on excessive voltage, in addition to excessive current.
This is accomplished by adding a device (a crowbar) that activates the
circuit breaker.
So unlike the current activated circuit breakers, one would certainly like
to minimize the dwell time of the over-voltage condition.
Is it necessary? You be the judge.
Eric M. Jones
113 Brentwood Drive
"I wouldn't want to belong to a club that would accept someone like me as a
member."
--Groucho Marx.
> it might
I suspect that the time it takes for the output of the alternator to fall off is
a lot longer than the time it takes for the field circuit breaker to open.
Remember, the output of an alternator doesn't go off instantly when you remove
field excitation. Likewise it doesn't come on instantly when you apply field
excitation. The armature (field) has its own time constant that is a function
of applied voltage and the inductance of the armature.
Bob probably knows the typical time constant of an alternator. I am only guessing.
> specifications.
Hi Bob,
Now I KNOW I should wait to ask this question during your seminar
here in Long Beach next month, but...
After reading your post I decided to do some more research via
the web, and to try to understand cabling and the various parameters
and data provided there, because now it seems that there are
more choices than RG400, RG223 for example. Of course, all I ended
up doing was confusing myself even more. Several of the data parameters
I found interesting to note were;
a) Attenuation Ratings - at differing frequencies
b) Power Ratings - at varying frequencies
c) Cable physical properties - terminals, diameter, shielding,
environmental factors, etc.
Now I'm sure that each of these is very important when determining
which cable to use for a specific purpose as transponders, comms
and navs all have different requirements
Of couse, I also found that the numbers a) and b) above varied
greatly from site to site, some indicating nominal values and some
with max values.
Outwardly it would seem that you would be able to select a cable
based upon all the above and it would be obvious which cable to use,
provided you have accurate information.
Can you recomment a source for accurate information and possible
suggested cables for most applications?
See you in a few weeks!
Walter Tondu
http://www.tondu.com/rv7
Subject: | Re: Second Com Antenna Placement |
> Thanks, Brian.
I was thinking about the distance between the mounting bases but more distance
is better. Top and bottom is better still.
Subject: | Re: Re Re: Re(buttal) Circuit Breakers and |
OVPs
> circuit breaker.
Actually, the crowbar OVP shorts the field circuit to ground cutting off the power
to the field right now. At that point it doesn't matter if the breaker takes
1ms or 100ms to open. The field in the alternator is already off.
The crowbar OVP circuit ensures that.
No, it really isn't.
From: | "Richard Garforth" <richard(at)hawk.flyer.co.uk> |
Subject: | RF breakthro on Vans gauges |
Seen some old postings regarding this issue - Has anyone found a fix yet? My MAP
gauge goes full scale using a top antenna but only part full scale using an
underside antenna.
Richard G-RVIX(RV9A)
From: | "Alex Peterson" <alexpeterson(at)earthlink.net> |
> found a fix yet? My MAP gauge goes full scale using a top
> antenna but only part full scale using an underside antenna.
Richard, the fix is to not look at it while transmitting:>)
Alex Peterson
Maple Grove, MN
RV6-A N66AP 463 hours
http://www.home.earthlink.net/~alexpeterson/
Subject: | Help with tachometer pickup |
rv-list-digest(at)matronics.com.pts.rule.name.description.----.----------------------.--------------------------------------------------
After installing my SD20 alternator on the vacuum pad of my 0-360-A1A, I find
there isn't sufficient clearance for Van's tachometer transducer to screw
onto the tachometer outlet on the back of my engine. I built my all electric
panel around my SD20, so it will stay. Would someone help me understand my other
tachometer pickup options? Thanks.
Pete
Clearwater, FL
RV-6, installing the engine
Subject: | Re: RF breakthro on Vans gauges |
> yet? My MAP gauge goes full scale using a top antenna but only part
What have you tried? I am not familiar with Van's MAP gauge but I would not be
at all surprised to find it uses an automotive MAP sensor with three leads: power,
ground, and an output voltage that is proportional to MAP which may then
be read by a meter.
Here are the things I would try:
1. Shield the wiring from the MAP sensor to the indicator. Use some two-conductor
shielded tefzel cable such as your mic cable with the signal and power leads
inside and the shield is ground.
2. Place ferrite beads on the leads at both the sensor and indicator ends.
3. Bypass the signal and ground leads to the shield using .01 uF disc ceramic
capacitors at both ends of the wires.
Pete
Other vendors use a hall effect transistor mounted on a mag, some use a
strobe affair on the flywheel, light speed uses their timeing mechanism and
im sure there are others. I wasn't too happy with Vans cable to a
transmitter rig but was able to make it work.
Paul Schattauer
RV8 N808PS
50 hrs
Man with one tach always knows what his RPM is, man with two tachs is never
sure.
>From: PeterHunt1(at)aol.com
>Reply-To: aeroelectric-list(at)matronics.com
>To: aeroelectric-list(at)matronics.com,
>Subject: AeroElectric-List: Help with tachometer pickup
>Date: Fri, 7 May 2004 18:22:03 EDT
>find
>electric
>other
>Pete
>Clearwater, FL
Subject: | Re: Help with tachometer pickup |
Pete,
Not sure if this will help or not but I had the same problem with the
clearance on my vacuum pump. I got an extension cable from Wicks (P/N
CEE-1) that took care of the clearance problem. The cable is flexible
also.
Glasair
----- Original Message -----
find
electric
my other
> Pete
> Clearwater, FL
Subject: | Re: Labeling of wires |
In a message dated 05/07/2004 11:08:00 AM Central Standard Time,
ALWAYSPDG(at)aol.com writes:
You could use a look-up table to indicate that wire #213 is the ground wire
from the Navaid head to the servo, or you could use a system that incorporates
something more intuitive like "M7-4SRV-" which could indicate:
"M"(main bus)
"7"(circuit 7 on main bus)
"4"(fourth wire on separate drawing you have generated for this device)
"SRV"(which is either one of the wires going to the servo, or that you are a
Stevie Ray fan 8-)
"-"(this is the negative or ground wire for the circuit)
Having one of the labeling systems is VERY helpful- I used a Brady Lablemaker
and it worked well, although there are many out there- do an archive seach
for more than you could ever need........
From The PosumWorks in TN
Mark -6A - 72 hours so far and what a damn BUTT KICKIN' MACHINE!!!!!!
Subject: | stick it in a cute blonde tonight! 15 |
From: | Mickey Coggins <mick-matronics(at)rv8.ch> |
Subject: | AOPA Never Again electrical problem |
Hi,
http://www.aopa.org/pilot/never_again/2004/na0405.html
This article discusses an electrical problem. Here
is the conclusion:
"That night, a quick check of the aircraft's manual found
the problem. Apparently the alternators would not kick in
if battery power was depleted below a threshold amperage.
This condition was created during static ground checks of
the camera equipment, which resulted in alternator
shutdown. The ammeter reading was correct but so borderline
that its warning was misinterpreted. The battery was charged
overnight and the mission continued the next day without
further incident."
Is this caused by a particular type of alternator?
Of course, I'll never have this problem with my Z11+Z30
equipped RV8, but I do still fly our club's aircraft.
Mickey
Mickey Coggins
http://www.rv8.ch/
#82007 QB Wings/Fuselage
From: | "Werner Schneider" <wernerschneider(at)compuserve.com> |
Subject: | Re: AOPA Never Again electrical problem |
A voltage readout would have shown the problem before they departed
Werner
Subject: AeroElectric-List: AOPA Never Again electrical problem
> Hi,
> is the conclusion:
> further incident."
> Thanks,
> Mickey
> Mickey Coggins
> http://www.rv8.ch/
Mickey Coggins wrote:
> Hi,
> is the conclusion:
> further incident."
I have an Aztec and I have studied its electrical system in detail. My immediate
reaction is to quote some of our British bretheren and state, "what rubbish."
(Actually I said something else but Matt says I am not to use those words
here.)
If there is enough power in the battery to start the engines and run the lights
and radios, there is more than enough to excite the alternators.
The Aztec has two alternators being driven by a single voltage regulator. The
alternators are run with both fields and B-leads in parallel. I can find nothing
in the system to ensure that they share the load equally but it seems to work
just fine anyway. There is a second VR that may be switched into the circuit
should the main VR fail. A toggle switch with a red flip-up cover on the
lower center console, conveniently out of sight, selects the VR. (The Aztec isn't
big on ergonomics and there are several controls that one must locate and
operate by feel.)
So what could the problem have been? Well, my guess is that they had an overvoltage
transient which tripped the overvoltage protection relay. This type of
OVP latches and won't release until all power is removed from the buss. I bet
dollars to donuts that if they had turned off the alternators (field switch)
and then cycled the battery master, the alternators would have come back on-line.
It also points out how Bob's crowbar OVP system communicates the problem much more
clearly to the pilot. When the field breaker pops you know what is wrong
(or have a pretty good idea) and resetting the breaker puts everything to right
unless there is really something wrong with the alternator system, at which
time you resort to your essential buss and get on the ground.
Getting back to the Aztec, it is possible that a weak battery would provide insufficient
stabilization on the buss that the bus voltage could have risen too
high when the alternators kicked on that the OVP relay was activated. Still,
the battery would have to have been so dead as to not be able to power anything
for that to be the case. Regardless, cycling the alternator field switch and
the battery master should have cleared the problem.
Brian Lloyd 6501 Red Hook Plaza
brian(at)greenflashnetworks.com Suite 201
http://www.greenflashnetworks.com St. Thomas, VI 00802
+1.340.998.9447 (voice) +1.360.838.9669 (fax)
brianl(at)lloyd.com Suite 201
http://www.lloyd.com St. Thomas, VI 00802
There is a time to laud one's country and a time to protest.
A good citizen is prepared to do either as the need arises.
The Aztec has a combined volt/amp meter that has a three-position switch to display
bus voltage or load on either alternator. Part of the run up check list
is to cycle the switch through all three positions and abort if buss voltage is
not correct or if either alternator shows no load (no output). So you can't
miss this one. The meter readings are not subtle.
As I said in my previous message about this article, "what rubbish."
Mark, thanks for the information.
Subject: | Getting oxidization off wires |
Electric people.
The Florida humidity has got through my nicely crimped BNC connectors and
attacked all my antenna connections.
I'm planning to make one permanent join at the winglet (where I have a 6
inch stub of cable coming out of the fiberglass from the antenna) then run
new cable all the way to the panel. I thought I'd solder the inner cores,
shrink wrap with RTV, bring the shields together and solder them too. I need
to clean off the shielding to get a good solder connection. Currently the
shielding has black copper oxidization all the way up under the outside
cover as far as I can see. What can I dip the shielding in to get a good
join?
Other suggestions for how to do this would be welcome.
John Slade
Flying Turbo Rotary Cozy IV
http://canardaviation.com/cozy
Subject: | Re: Buttal on OVP and Circuit Breakers. |
The Aeroelectric OVP uses a Teccor S6025L silicon controlled rectifier. When
an overvoltage is sensed, the SCR (thyristor) quickly turns on and shorts
the 5A circuit breaker to ground. We want the breaker to open--but how
quickly must this happen?
Assuming the bus will supply it, the short circuit current will be
approximately 15V (16.2V-diode Vf)/(0.07CB ohm+0.01 ohm wiring
resistance)=188 Amps. (For these estimates).
Teccor's data is mainly for 50-60 Hz applications, not one-shot crowbars,
but the following limits single cycle non-repetitive surge capability---350A
peak for 8.3 milliSeconds. (Their recommended I
2*T for fusing is 510 Amp
2*
Sec, which is 50% of this.).
So we can estimate that something less than an I
2*T of 1000 Amp
2* Sec is
required. For the thyristor to survive, it must then suffer less than 188
Amps X 28 milliseconds to get an I
2*T under 1000 Amp
2* Sec (or so).
Otherwise the crowbar OVP will work maybe only ONCE.
Thus, you can clearly see that getting a circuit breaker that will trip in
less than 28 milliseconds under the specified short circuit conditions is
essential, else the OVP will fry.
I wish I could wrap all this up in a mathematically neat package, but the
trip time/overload specifications of most aircraft circuit breakers is
simply not available for currents over 10X rated load or 50A. But the
circuit breakers will trip far larger currents with ease....they just won't
specify the time lag.
----This is my experience from trying to discover why my crowbar OVP
disappeared in a flash and left a perfectly good thermal circuit breaker
untouched.
So I stand by what I said, use a fast breaker for the OVP/Alternator Field
line.
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge MA 01550-2705
Phone (508) 764-2072
Email: emjones(at)charter.net
"When the Okies moved to California it raised the average IQ of both
states."
---Will Rogers
Subject: | Re: Reformated--Re: Buttal on OVP and Circuit Breakers. |
Sorry, This is hard enough without some of the math symbols trashing the
formatting...
peak for 8.3 milliSeconds. (Their recommended I sq * T for fusing is 510 Amp
sq *
So we can estimate that something less than an I sq * T of 1000 Amp sq * Sec
is
Amps X 28 milliseconds to get an I sq * T under 1000 Amp sq * Sec (or so).
untouched.
line.
Eric M. Jones
113 Brentwood Drive
states."
---Will Rogers
hi,
My best result was from changing the radio antenna coax to double
shielded (RG-400 is good) with crimped connectors.
Jim Bean
I just checked the FAQ on Aeroelectric.com and did not find any update on
the Battery dumping subject that went around a while back. Did I miss your
reply or has the testing not been completed? I understood that you had
several ideas that you were planning to test that would provide an
inexpensive solution to this risk but then the subject went quiet.
Bob Lee
mailto:bob(at)flyboybob.com
Testing has been delayed and I have posted several updates on this; the
latest not long ago.
Other more important (to me) Tasks have kept me off this project. Plus I am
still waiting for calibration on one piece of test equipment (being done
free in spare time so its taking much longer to do, however its a 40-80 man
hour cal so its not trivial to get done free).
Yes we have a couple of solutions that appear on paper to completely solve
any Load dump issues. However to prove to Bob (and others) the solution
works, requires a high power setup with somewhat unusual instrumentation (at
least for me). I am not setup for switching and loading 50 amps at 20 to 80
volts so that has taken some time to get parts for and setup such power
testing and associated instrumentation and get it calibrated so the results
are meaningful and design margins can be determined.
My aircraft already has one solution implimentated (actually done several
years ago) based on reading extensive industry info on the subject. Thus the
planned testing is not something I need for my own design.
In the automotive design, damaging Load Dump's only can occur when there is
a failure as the battery is hard wired to the alternator "B" lead. There is
a small load dump when you turn off your headlights but the battery absorbs
the dump transient current pulse and keeps the voltage under normal levels.
The issue in aircraft is different where the battery can be disconnected
when the alternator is providing power. This can be either a design where
its a simple switch function (pilot error :-) ) or the battery contactor
failing open. Also if the OVP is used to open the "B" lead with an
internally regulated alternator any opening of the "B" lead during
alternator operation can overvoltage the alternator regulator and if that
regulator/alternator is not designed to survive load dumps it/they will
fail. The current continues for a very short time and the voltages rises
until some load path dissipates the current. The voltage rises as needed to
provide this load path and voltages can rise to very high levels. The way a
IGN coil produces the spark is similar where the primary coil voltage rises
from 12V to 350-400V where it is clamped if the spark plug has not fired and
dumped the load into the spark.
This MAY be the reason for the "reported" failures of the rebuilt ND
alternators being sold by Vans for the RV market. I do not know of ANY proof
of this however, that is "Vans alternators are inferior" to any other source
as has been suggested by some on this list.
Testing is more complex than it might seem however to be sure the solution
has proper design margin.
Consider that the industry has a simple product that is specifically
designed for this issue and one poster said that product failed for him (I
have an equivalent part and will be trying it also, however its clamping
voltage is higher than aircraft avionics can tolerate). Thus the need for
careful testing of a somewhat complex issue of transient energy etc.
Hopefully the testing will not damage the regulators in my test alternators
as I do not have a limitless supply.
Regardless its not possible to test all possible alternators and regulator
combinations so any solution must have a somewhat large design margin which
is hard to determine when the alternator/regulator(s) I have to test are not
necessarily worst case etc. For example I do not have any ND alternators nor
any of Bob's regulators to test. The peak current capability of the
alternator as well as the response time of the regulator are major factors.
I have never called it anything but Load dump as that has been the industry
term for decades. Bob, as I recall, did want to rename it (do not recall
that name) so looking for anything but Load dump will not flag any note from
me.
Regardless the testing will not be exhaustive and no warrenty it will result
in a 100% solution for everyone. The best design solution is one where its
not possible to switch into a load dump condition with pilot errors.
Thus our solution is not to try to protect the alternator/regulator but the
avionics etc on the acft by clamping the spike to levels the avionics can
survive. The OVP circuit will NOT protect from load dump as shutting off the
regulator is too late. Opening the "B" lead contactor is not a solution
either as the contactor takes a long time to open compared to the load dump
pulse.
Paul
Subject: AeroElectric-List: Battery Dump
> Bob,
your
> Regards,
> Bob Lee
Does someone have a part number and a source for a 90 degree BNC connector that
I could use where I connect the coax to the antenna.I will be mounting the antenna
under the baggage compartment floor.
Gerry 7A 70188
From: | "Richard E. Tasker" <retasker(at)optonline.net> |
Subject: | Re: BNC Connector |
I don't have a part number, but unless you just do not have the room,
you would be better off (financially and signal strength) to use a
regular straight connector and bend the cable.
Dick Tasker
>Thanks
>Gerry 7A 70188
Subject: | RF breakthrough on Vans gauges |
Brian & Jim,
Thanks for the suggestions.
Taking the easiest first both antennas are already cabled in RG400 - thanks Jim.
I explored the situation further today and found that a handheld ICOM xmitter produced
the same result - this confirmed it is RF breaking into the gauge or the
wiring and not some strange earthing issue. I next removed the gauge and MAP
sensor and cable from the aircraft and set up a simple bench test. This showed
that the RF is getting into the circuit board in the gauge (even through the
glass front). I stripped the gauge down and found there is no HF decoupling
to be seen. Also it seems the moving coil meter is centre wound ( 3 terminals)
and works on a differential output from the driver chip. The MAP sensor appears
to be a 4 arm bridge sensor with a built in regulator. I finished up fitting
five 10nF disc caps (thanks Brian) on the meter circuit board.
One across each meter coil, one across the two signal arms of the bridge input
and one from each signal input to ground. Immediately the interference was reduced
considerably. Final fix was to take the MAP sensor out of its plastic box
and fit it directly to the rear of the meter and fit ferrite beads to the two
signal leads and the power input.
The end result is a gauge that only moves a needle width with the ICOM xmitter
ant held against the meter front.
My guess is that the Vans gauge that gives similar problems, the ammeter, being
centre zero has a similar internal configuration and may respond to a similar
fix. As I am a committed Voltmeter believer I can only speculate.
Richard(G-RVIX)
Paul
I appreciate the efforts you are doing to investigate and resolve this Load
Dump anomaly.
I have more than a passing interest, as I am using this combination of an
Alternator with
Internal V.R. and Bob's O.V. Module.
When the O.V Disconnect ("B" lead) Contactor opens, I can understand the
transient current pulse caused
by the now open circuit on the Alternator side, but I fail to see, how
this could cause an O.V. spike on the
bus side, which is now isolated from the Alternator in the Load Dump scenario.
Why doesn't the bus voltage just drop to the Main Batt level or in the case
of the pilot mistakenly
opening the BATT Contactor, drop to zero?
Isn't the very condition which causes the transient current pulse, (the
Open "B" lead Contactor) ,
the result of the busses/batt no longer being connected to the Alternator?
What am I missing here?
Wally Enga
RV7
I received this in my mail the other day and felt that it might contribute much
to the erudite discussions we enjoy so much in this list. As an English ex-pat
I am intimately aware of the excellence of Lucas products and their contribution
to reliability of the fine automobiles made in the British Isles.
> << "A Treatise on the Importance of Smoke" by Joseph Lucas
> All electrical components and wiring harnesses depend on proper
> circuit functioning, which is the transmission of charged ions by
> retention of the visible spectral manifestation known as "smoke".
> Smoke is the thing that makes electrical circuits work. Don't be
> fooled by scientists and engineers talking about excited electrons
> and the like. Smoke is the key to all things electrical.
> We know this to be true because every time one lets the smoke out of
> an electrical circuit, it stops working. This can be verified
> repeatedly through empirical testing. For example, if one places a
> large copper bar across the terminals of a battery, prodigious
> quantities of smoke are liberated and the battery shortly ceases to
> function. In addition, if one observes smoke escaping from an
> electrical component such as a Lucas voltage regulator, it will also
> be observed that the component no longer functions.
> The logic is elementary and inescapable! The function of the wiring
> harness is to conduct the smoke from one device to another. When the
> wiring harness springs a leak and lets all the smoke out of the
> system, nothing works right afterward.
> Starter motors were considered unsuitable for British motorcycles for
> some time largely because they regularly released large quantities of
> smoke from the electrical system.
> It has been reported that Lucas electrical components are possibly
> more prone to electrical leakage than their Bosch, Japanese or
> American counterparts. Experts point out that this is because Lucas
> is British, and all things British leak. British engines leak oil,
> British shock absorbers, hydraulic forks, and disk brake systems leak
> fluid, British tires leak air and British Intelligence leaks national
> defense secrets.
> Therefore, it follows that British electrical systems must leak
> smoke. Once again, the logic is clear and inescapable.
> Sometimes you may miss the component releasing the smoke that makes
> your electrical system function correctly, but if you sniff around
> you can often find the faulty component by the undeniable and
> telltale smoke smell. Sometimes this is a better indicator than
> standard electrical tests performed with a volt-ohm meter.
> In conclusion, the basic concept of transmission of electrical energy
> in the form of smoke provides a clear and logical explanation of the
> mysteries of electrical components and why they fail.
> "A gentleman does not motor about after dark."
> - Joeseph Lucas, 1842 - 1903
I learned a long time ago that once you let the "Factory Smoke" out of any electrical
device, it is next to impossible to replenish it.
>Dick Tasker
> connector that I could use where I connect the coax to the antenna.I will
> be mounting the antenna under the baggage compartment floor.
> >Thanks
> >Gerry 7A 70188
Right angle connectors do exist . . . but are comparatively
expensive and not in everybody's catalog. Here's a new article
on a low cost but rugged alternative to a one-piece, solderless
right-angle connector.
http://www.aeroelectric.com/articles/BNC_Rt_Angle/BNC_Rt_Angle.html
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
>Paul
>Dump anomaly.
>Alternator with
It doesn't. The issue came to light when a number of folks
having alternators wired per figure Z-24 cycled them OFF and ON
when the engine was running and the alternator was probably carrying
moderate to high loads. The resulting load dump transient was
confined to the alternator side of the alternator disconnect contactor
and only the alternator's internal voltage regulator was damaged.
Not a thing.
Subject: | RF interference to Vans gauges |
That's one alternative. This is a down-side of some
hardware supplied to the OBAM aircraft community. Some
products are brought to the marketplace by folks who
either don't understand the value of making products
perform equal to or better than "certified" stuff -OR-
they don't understand the environment in which they
are working.
There is no excuse for not having fixed this
problem by now. I've been hearing about it off-and-on
for at least a year. As consumers you have several
choices: (1) return the hardware for refund as
"not suited to the intended task", (2) work out
and implement fixes at your own time and expense,
(3) work with the original manufacturer to see if
he/she is willing to upgrade your purchase to operate
in the real world or (4) just live with it. It
doesn't hurt anything as long as you understand
the condition and can believe the instrument all
times other than transmitting.
As always, if anyone does put the wrenches to the
manufacturer, tell them I'll offer suggestions for
modifying their design . . . perhaps even at no
cost. But since I don't own any of this stuff,
it's up to those to do own it to be responsible
consumers and squeeze these folks into useful
action.
There's an old adage that suggests "If
you continue to do as you've always done,
you will continue to be as you've always been."
A corollary to this adage says, "Until you convince
a supplier that their product has unsatisfactory
design flaws and insist on responsible adjustments,
they'll continue selling it warts and all to your
fellow builders . . . and your's won't get fixed either.
In a message dated 5/9/04 8:36:50 AM Pacific Daylight Time,
gclabots(at)execpc.com writes:
<< Does someone have a part number and a source for a 90 degree BNC connector
that I could use where I connect the coax to the antenna. I will be mounting
the antenna under the baggage compartment floor. >>
I used a 90 degree BNC adapter from Radio Shack for the same installation,
hope it works.
Harry Crosby
Pleasanton, California
RV-6, final assembly
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
Subject: | Re: 11394 Barnes |
>Email: skytop(at)megsinet.net
>Comments/Questions: Bob,
>I want to report to you on the performance of my B&C SD-8 because I almost
>called you to report a problem - that wasn't. On the initial system
>testing, I was unable to get the SD-8 to stay online. While switching
>between primary and alternate, I would see charging of 14A (primary)
>{switch to alt} 4A (SD-8 for about 1 second), then it would drop to zero
>(0A). These tests were done on the ground and it wasn't until I tested it
>again at cruise RPM that it worked okay. Now it stays at 7A. Soon, I
>will test it again to find out at what RPM it drops out after being online
>for a while.
Thank you for taking the time to share your experience with the
SD-8. You have discovered the major shortcoming for driving alternators
from the vacuum pump pad. At ramp idle and taxi speeds, the pad is under
2,000 rpm. The SD-8 will deliver no useful output at these speeds.
At cruise rpm, the vacuum pump pad runs at about 4,000 rpm and even this
speed is lower than required for maximum performance from the SD-8.
The 200G alternator is the gear driven version of the SD-8 and turns
much faster on the generator drive pad of an O-200 . . . in this
situation, the alternator is rated at 12A.
You can conduct a reasonable pre flight test of the SD-8 by turning
it on during mag checks when the engine is running relatively fast.
Turn the main alternator OFF (at idle and with minimum loads)
and turn the auxiliary alternator ON. Before bringing rpm back down
at the end of your mag check, observe that the alternator does come
up and produce some output current . . . but it will never be close
to rated output.
>You'll never know how much I appreciate your book and help on the
>"list". I'm currently unssubscribed, else I would post this for others to
>consider.
Thanks. Hope to see you back on the list on day.
With due respect I disagree, MY testing is designed to cover the several
load dump conditions not just internal regulator failure.
Its your request that specific results be done properly and documented so
others could repeat the test that has taken the time to get proper equipment
setup and calibrated.
Please read my reply to his post just sent to the group for further
comments.
While opening the "B" lead contactor can cause a "local load dump" that is
not the primary load dump of concern in my opinion and in any case only one
of several related design conditions related to load dump and its
mitigation.
Paul
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: Re: AeroElectric-List: Re: LOAD DUMP
> >Paul
Load
> >Dump anomaly.
> >Alternator with
scenario.
case
Alternator?
> Not a thing.
> Bob . . .
Yes you are missing something, at least in the general case.
The time it takes for the "B" lead contactor to open is long enough to pass
some or all of the load dump pulse to the rest of the circuit. Depending on
the equipment and its load at the time the load dump pulse has the potential
to raise the bus voltage to very values and exceed the rating of some
equipment. Alternator damage is also a consideration. Internal and external
regulators are different cases with different time constants with regard to
load dump effects.
The OVP's location and physical wiring resistances etc all are part of the
circuit. Then there is the blowing of the CB. After the CB blows the
contactor (in the case of internal regulator alternators) takes time to open
and the load dump is still in process or can be.
Thus we are concerned about the time between the start of the load dump and
the time the "B" lead contactor opens in your case. Also consider in your
case that OVP trip from OV normally is due to the failure of the internal
regulator so the regulator is already failed.
The purpose of my (and my associate) test/investigation is to determine what
one or more typical cases really look like as to the various time durations
and currents with various load dumping currents from 10 to 40 amps. That is,
the sudden loss of the battery as a load capacitor when the alternator is
generating current.
I am doing the physical testing and my partner is providing technical
analysis support as well as design analysis.
Its sure not clear to me (us) that the effect of the OVP circuit time
constant VS the start of the load dump and the "B" lead contactor time to
open results currently unknown amounts of energy past and into the main acft
buss.
I maintain there are two concerns here. One is damage to avionics due to
overvoltage; the other is damage to the alternator.
Then there are internal and external regulated alternators with associated
OVP circuit designs. Thus several different tests are needed to verify just
what is needed and how much energy must be safely dissipated.
Some of the group have equipment that is specified to have 20V max input
voltage and under 30v max is common. There is a lot of equipment NOT meeting
DO-160 and I want to design a protective circuit that protects it. Limiting
the electrical system design so that only equipment designed to DO-160 may
be nice in theory but in the real world foolish and far too restrictive to
many in the group.
In addition I have interspersed comments below.
scenario.
case
The load dump starts when the battery is disconnected and that is a long
time before the "B" lead (in your case) actually opens compared to the pulse
length.
When you remove the battery and the alternator is generating battery
charging current that current MUST go somewhere. It raises the Bus voltage
and potentially can trip the OVP circuit which blows the circuit breaker and
allows the "B" lead contactor to open. This is not zero time and while this
is happening the acft bus can reach high voltages depending on many factors.
The cause of the initial load dump is NOT the opening of the "B" lead
contactor but the loss of the battery as a "load leveler". Sure the "B" lead
contactor will cause a local to the alternator load dump and that is a
different but important concern. We do not want failure propagation in out
design. Pilot caused failure in opening the battery when the alternator is
in operation or failure of the OVP to cause alternator damage.
To me there needed to be a study of the entire load dump issue not just
protecting internal regulated alternators from damage from the actions of
the OVP circuit.
Paul
> Wally Enga
> RV7
From: | "Tom Roberts" <tom.roberts(at)pioneermachinery.com> |
Subject: | Re: AeroElectric-List Digest: 11 Msgs - 05/09/04 |
Please unsubscribe me.
Subject: AeroElectric-List Digest: 11 Msgs - 05/09/04
> Online Versions of Today's List Digest Archive
> Today's complete AeroElectric-List Digest can be also be found in either
> of the two Web Links listed below. The .html file includes the Digest
> formatted in HTML for viewing with a web browser and features Hyperlinked
> Indexes and Message Navigation. The .txt file includes the plain ASCII
> version of the AeroElectric-List Digest and can be viewed with a generic
> text editor such as Notepad or with a web browser.
> HTML Version:
http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2004-05-09.html
> Text Version:
http://www.matronics.com/digest/aeroelectric-list/Digest.AeroElectric-List.2004-05-09.txt
> EMail Version of Today's List Digest Archive
> AeroElectric-List Digest Archive
> Total Messages Posted Sun 05/09/04: 11
> Today's Message Index:
> 1. 12:21 AM - Battery Dump (Bob Lee)
> 2. 06:22 AM - Re: LOAD DUMP (Paul Messinger)
> 3. 08:35 AM - BNC Connector (Gerry Clabots)
> 4. 09:32 AM - Re: BNC Connector (Richard E. Tasker)
> 5. 12:23 PM - RF breakthrough on Vans gauges (Richard Garforth)
> 6. 12:41 PM - Re: Re: LOAD DUMP (Wallace Enga)
> 7. 05:00 PM - Smoke in wires. (Rob W M Shipley)
> 8. 05:00 PM - Re: BNC Connector (Robert L. Nuckolls, III)
> 9. 05:03 PM - Re: Re: LOAD DUMP (Robert L. Nuckolls, III)
> 10. 05:28 PM - RF interference to Vans gauges (Robert L. Nuckolls,
III)
> 11. 06:56 PM - Re: BNC Connector (HCRV6(at)aol.com)
> ________________________________ Message 1
> From: "Bob Lee" <bob(at)flyboybob.com>
> Bob,
your
> Regards,
> Bob Lee
> ________________________________ Message 2
> From: "Paul Messinger" <paulm(at)olypen.com>
> Subject: AeroElectric-List: Re: LOAD DUMP
am
man
(at
80
results
the
is
is
absorbs
levels.
to
a
rises
and
proof
source
alternators
which
not
nor
factors.
industry
from
> me.
result
the
the
dump
> pulse.
> Paul
> > Bob,
on
> your
> > Regards,
> > Bob Lee
> ________________________________ Message 3
> From: "Gerry Clabots" <gclabots(at)execpc.com>
> Subject: AeroElectric-List: BNC Connector
that
antenna
> Thanks
> Gerry 7A 70188
> ________________________________ Message 4
> From: "Richard E. Tasker" <retasker(at)optonline.net>
> Subject: Re: AeroElectric-List: BNC Connector
> Dick Tasker
connector that
antenna
> >Thanks
> >Gerry 7A 70188
> ________________________________ Message 5
> From: "Richard Garforth" <richard(at)hawk.flyer.co.uk>
> Subject: AeroElectric-List: RF breakthrough on Vans gauges
> Brian & Jim,
thanks Jim.
xmitter produced
MAP
showed
the
decoupling
terminals)
appears
fitting
input
reduced
two
xmitter
being
similar
> Richard(G-RVIX)
> ________________________________ Message 6
> From: Wallace Enga <wenga(at)svtv.com>
> Paul
Load
> Dump anomaly.
> Alternator with
scenario.
case
> Wally Enga
> RV7
> ________________________________ Message 7
> From: "Rob W M Shipley" <rob(at)robsglass.com>
> Subject: AeroElectric-List: Smoke in wires.
much
ex-pat
contribution
> > defense secrets.
electrical
> ________________________________ Message 8
> >Dick Tasker
will
> > >Thanks
> > >Gerry 7A 70188
> Bob . . .
> ________________________________ Message 9
> >Paul
Load
> >Dump anomaly.
> >Alternator with
scenario.
case
Alternator?
> Not a thing.
> Bob . . .
> ________________________________ Message 10
> Subject: AeroElectric-List: RF interference to Vans gauges
> are working.
> action.
> Bob . . .
> ________________________________ Message 11
> From: HCRV6(at)aol.com
connector
mounting
> hope it works.
> Harry Crosby
From: | Mark Steitle <msteitle(at)mail.utexas.edu> |
Subject: | ZAP-STOP Alternator Protector |
I was searching the web this morning and ran across an item that claims to
address the voltage spike problem on boats. When it comes to voltage
spikes, it seems that boats have the same potential risk as
airplanes. I'll be the first to acknowledge that I'm out of my element
here, but thought that Bob, or someone else, may know something about this
item. Here is the quote from their website...
It happens - someone turns the battery switch to "OFF" while the engine is
still running.
Even momentarily turning the battery switch to "OFF" can damage the
alternator diodes leaving you without a way to charge your battery. Either
the e-Marine Alternator Protector or the Zap-Stop will work to prevent that
damage to the diodes. The installation is very simple - just connect the
red wire with fuse to the alternator positive and the black wire to
alternator ground. It is cheap insurance.
e-Marine Alternator Protector or ZAP-STOPAlong with the integral 20 amp
slow-blow fuse, e-Marine Alternator Protector or ZAP-STOP is an ingenious
device that suppresses high voltage transients by conducting them to ground
if they rise to unsafe levels. e-Marine Alternator Protector or ZAP-STOP
helps protect alternators and electronics from damage when the battery
switch is momentarily turned "OFF" while the engine is running.
Their URL is http://www.e-marine-inc.com/products/alternators/zapstop.html
Mark S.
Bob, Paul thanks for the info. I really do appreciate the time you guys
spend trying to educate us on these elusive electrons.
I may have a situation which is somewhat easier to protect, then the norm.
It has two Odyssey PC 680 16 AH batteries.
The MAIN Batt is connected via the normal BATT Contactor.
The AUX Batt is hard wired via a large Schottky Isolation Diode
to the BUS Side of the "B Lead" Disconnect Contactor and
also feeds an always Hot AUX Bus.
So it is not possible to have both batteries disconnected
from the "B Lead" Contactor in this case.
I think my biggest concern is protecting the Internal V.R. after mistakenly
turning OFF the Master SW with the ALT under a load.
Would a large TVS like the 24V LPD24A that was discussed here
a few months back, usually save the V.R. in that situation?
Wally Enga
RV7
Subject: | Dark-n-Stormy Night Stories Redux |
Micky Coggins brought this story to our attention last week. A number
of folks responded. I've compiled the pertinent data points with
some critical review at:
http://www.aeroelectric.com/articles/neveragain/neveragain_2.html
Yes its a simple device, however some of us need specifics as well as just
what the clamping voltage is. Generally speaking electronics designed for
marine use is similar to automotive use that is they are very rugged,
something that many experimental aircraft electronic items are not.
A specific device designed for use in alternator load dump supression is
available and has been for many many years. The problem is its max clamping
voltags is well above what we are looking for to protect all likely
components in an experimental aircraft. Also I assume the 20 amp fuse is
there to cover a load dump case where the internal regulator has not failed
so the alternator current will not be clamped as long as the voltage is
reasonable.
Something designed only to protect the alternator during a load dump is a
sub set of what I am looking into. The above part not counting the CB is
available for under $2 at the on level and around $0.40 at the 100 level.
Perhaps part of the overall solution for us but not a universal solution
even in a non failed case.
Paul
From: | "Mark Steitle" <msteitle(at)mail.utexas.edu> |
Subject: AeroElectric-List: ZAP-STOP Alternator Protector 0.1
> still running.
that
ground
> Mark S.
The basis of the Zap-Stop is supposedly a Motorola MR2535L Zener diode.
This is not a bad way to go, Zeners DO have Vz temperature dependence and,
being avalanche devices are not as fast as one might like, but they are
pretty good.
The manufacturer has a nice website with interesting products:
www.xantrex.com/
Eric M. Jones
113 Brentwood Drive
Teamwork: " A lot of people doing exactly what I say."
(Marketing exec., Citrix Corp.)
Subject: | Re: Dark-n-Stormy Night Stories Redux |
A couple more comments on the the Aztec systems.
1. Landing gear and flaps are powered by a hydraulic pump on the left engine (of
course one would put the hydraulic pump on the critical engine, right?) so
it is possible to raise and lower the gear with a total electrical failure. Backup
is provided by a hand-operated hydraulic pump.
2. "Essential" buss vs. "endurance" buss: seems I got the former phrase from you
at some point in the dim, dark recesses of the past. When I implemented such
a thing in my Comanche 20 years ago I just called it my backup power source.
The EB was actually the "avionics buss" to which I cheated and connected my
they-must-always-work devices. I can't help it if you change your mind as to
the name. ;-)
3. And when the writer of the story talked about "increased drain" I suspect he
may have been referring to increased load since a loadmeter cannot show anything
but load, e.g. it is either zero or "something" and only "something" can
be increased. So I took this to mean that during the run-up, one of the alternators
was carrying all the load, which indicates that the other was doing nothing.
Since there is a tendency for one alternator to hog the load anyway, the
loss of one alternator prior to take-off may have been interpreted as "only
slightly abnormal". But I grasp at straws. I wasn't there and from reading the
story I can only say that the author was a piss-poor observer.
4. "Instruments and breakers are poor warning devices." I agree. I was not suggesting
that meters and/or breakers are good warning devices, I was suggesting
that, compared to latching type over-voltage relays, the popped breaker in
the crowbar OVP system is a positive indication that the OVP system has activated.
With an OVP latching relay you have no indication. I agree that there is
no substitute for a positive low-voltage annunciator.
BTW, one should be immediately wary when someone else in the cockpit utters the
words, "why is it doing that," or, "I've never seen it do that before."
Country Classic person: Sally Cutter (503) 682-2678
Get file folders.
Zeners are as much as 10,000 times slower than transorbs and typically
designed for longer duration, lower peak currents than transorbs.
Thankd for the detailed link however.
Paul
Subject: AeroElectric-List: Re: Zap Stop
> pretty good.
> www.xantrex.com/
> Regards,
> Eric M. Jones
> 113 Brentwood Drive
From: | Dj Merrill <deej(at)thayer.dartmouth.edu> |
Hi Tom,
Point your web broswer at:
http://www.matronics.com/subscription
to unsubscribe yourself from the mailing lists.
fyi
-Dj
> I cannot get into recommending a specific device at this time as this
would
> require significant time to research any suggested part and then make an
> educated guess.
> I want to concentrate on defining the electrical load dump pulse first and
> then look for solutions with lots of design margin.
> Testing starting this week. (assumming no more unplanned 'emergencies")
> Paul
> As the monkey said after backing into the lawn mower "It will not be long
> now"
> From: "Wallace Enga" <wenga(at)svtv.com>
> To:
> Sent: Monday, May 10, 2004 9:09 AM
norm.
> mistakenly
> > Wally Enga
> > RV7
>load dump effects.
The overvoltage protection system was never intended to address
the load dump scenario. This is true of both internal and externally
regulated alternators. I don't understand how/why characteristics
of the OV protection system figure into your study of load-dump
mitigation.
>generating current.
>buss.
>many in the group.
Absolute elephant hocky . . .
I've been designing to DO-160 Input Voltage recommendations
for over 30 years and they are neither foolish or restrictive to the
competent designer.
I just responded to a thread where folks are out looking
for Band-Aids to paste on instruments that wander
off into the weeds when comm transmitter is keyed.
Is it "too restrictive" or "foolish" to expect these
instruments function as advertised under all normal
operations of the aircraft?
DO-160 is not a "theory" but a minimum standard of
performance based on easy-to-achieve, real-world performance
that will help anyone provide good products and services
to the aviation community . . . it matters not if it's
a certified ship or an OBAM aircraft.
Suppose I were to offer a new "avgas" for $1.00 a gallon.
Would it be "foolish" or "restrictive" to expect that
I show the product capable of 100 octane performance and had no
characteristics that make it incompatible with everyone's
engines?
Shucks, there are bins of bolts in hardware stores
that will hold pieces of my airplane together. Is it
too "restrictive" or "foolish" to concern myself with
compatibility of this hardware to the intended task?
If it's not okay for fuel or wing bolts, why is it okay
for transistors? I don't understand the special case for
electrics wherein substandard performance is tolerated to
the extent that a user must accommodate it with a
super-clean electrical system.
I don't know which "group" you're citing. The folks I work with
are building the finest aircraft to have ever flown. I'll help
Van's instrument house bootstrap their products into the real world
if they're the least bit interested. If the manufacturer of a
20V limited device wants to play in the same sandbox with big boys,
I'd be pleased to assist them too. However, adding shielded
wire, ferrite beads, transorbs, or relocating antennas, etc, to
mitigate supplier disinterest or incompetence does
not fit my mission. I sincerely hope it's not a component
of anyone else's mission here on the list.
>scenario.
>case
>length.
. . . the most significant factor being that OV protection is
not designed for load dump mitigation. The output current transient
shown in data cited below says to expect peak alternator output current
about 15 milliseconds after initiation of the load dump . . . this
simply cannot be fielded by hardware designed to protect the system
from a failed regulator.
>the OVP circuit.
If you can accommodate a full load shutdown event of Figure Z-24
then you can accommodate a load dump of any other variety as well.
In response to Eric's comments about the Zap-Stop, the MR2535L device by
ON Semiconductor (was Motorola) is not a zener but a true transient
suppressor. You can see the data sheet at:
http://www.aeroelectric.com/Mfgr_Data/MR2535L-D.pdf
Figure 13 is of particular interest. If I interpret this correctly,
the exemplar load dump scenario has a time constant of 100 mS.
Peak current to be expected will be alternator rated current plus
perhaps a 20% safety factor for cold conditions. The data table
says worst case Vbr is 40v at 150 degrees C and 90 amps. Sounds
like this gizmo was made with DO-160 in mind and would work fine
with alternators rated up to 60A or so. The 40 V absolute limit
would also accommodate all the built-in regulator chips for which
I've seen data.
There are a bunch of products in the 1500W peak power range
that would substitute for the MR2535.
If your repeatable experiment shows that an alternator's output
current curve is indeed shaped like Figure 13 during the load-dump
event, then sizing a clamp-off device for any voltage is
pretty straight forward. However, to accommodate equipment limited
to 20V max, you'll probably need an active clamp . . . perhaps
a TL431 teamed with a honker P-channel power fet for a power
voltage clamp with a corner on the conduction "knee" than the typical
transient suppressor. A 20V clamp on a 60A machine would not have to grunt
more than 70 joules or so . . .
Subject: | Fw: Z-12 Main Alternator Control |
Bob:
With respect to Z-12 (Single Battery, Dual Alternator) the main alternator appears
to be controlled by the main battery master switch while the aux alternator
has a separate on/off switch.
Is there a reason for not having a separate main alternator switch as well? I
plan on this system for the RV-10 I have under construction.
The aircraft is designed with a battery location aft of the passenger compartment.
With an aluminum airframe is the 4AWG ground cable to the instrument panel
ground bus still the preferred grounding method?
Many thanks.
Dick Sipp
RV10 #65
Snipped for size.
> mitigation.
Because I am trying to define a system problem.
During the start of the load dump the system bus voltage is expected to trip
the OVP and thus its part of the circuit.
The physical circuit resistances are important when considering the currents
in the shorting elements IE the OVP and what ever is used for the load dump
its self. This, along with wiring resistances are major players with a hi
current surge that is not limited by the alternator ratings but the internal
resistance of the alternator windings as well as the external wiring
resistances. Also you state your OVP design ignored load dump but load dump
is real and likely in many acft electrical designs where its possible to
remove the battery from the system with the alternator in use. Surely any
OVP design must address that condition if only to survive as well as provide
protection. I agree the OVP is intended to protect from a failed hi voltage
regulator but load dump is in effect the same condition but very short in
duration.
meeting
Limiting
may
to
> >many in the group.
> competent designer.
In the REAL work its not hockey, perhaps in the ideal world everyone builds
to every aspect of DO-160 or even better, designs to the standards of the
automotive world, but its simply not true for some equipment. I have some,
and others on this list have, in the past, mentioned other equipment with
restrictive voltage limits.
Besides, after 40 years I can count on the fingers of one hand the truly
competent engineers I have known (out of thousands working in dozens of
companies). This based on personal contact and/or the review of
subcontractor equipment from major players in the industry in some cases.
No, but in the real world its far too common a case.
SOME Members of THIS group are part of who I am addressing along with many
who are unwilling to post directly. Some of us do not have the $$$$ to buy
the BIG boys stuff. Not everyone is interested nor can afford a $100,000
acft.
Vans is not a small boy and is likely an example of individuals wiring
components that work in many cases well and do not work well in others
simply based on how the wiring is done.
Dynon went thru a year of testing and only after production started found
some small number of customers had problems while most did not. Sure there
is a radiated noise issue with Dynon (and they are providing a free fix) but
after a year of field testing its clear its a problem unique to how the
aircraft wiring is physically wired not simply a schematic that works any
which way.
I have discussed that problem with the chief designer at Dynon and there
appears to be a simple wiring approach that is common to the cases of noise
and another wiring approach that seems noise free. In any event a series
filter fix is free and new production have better internal filtering.
My point is there is no way to test all possible conditions. I suspect Van
has had no problems with his instruments in aircraft he has wired at his
factory.
pulse
> >length.
voltage
and
this
factors.
current
Astounding statement. You seem to be saying that your OVP design was not
designed for and is not expected to survive a load dump, yet we know that
load dumps are generated when the alternator load is suddenly reduced. With
a battery still connected as in the case of say landing lights being turned
off, the battery clamps the load dump. If however, the battery is
disconnected when under heavy charge the rest of the system bus must absorb
the load dump and its likely the OVP circuit will trip.
Thus a system analysis is necessary and all components in the system must be
evaluated.
> I've seen data.
I find the referenced data sheet and Fig 13 specifically of interest in that
is so very different from other load dump Mfgrs data test conditions.
Dumping a 50 mfd cap here is compared to dumping 150,000 mfd in another
case. Who to believe? Well I tend to believe the latter as it comes from a
company who has TVS devices as a primary line and is not simply a second
source. Remember data sheets are designed to sell product and are typically
written by brand new engineers fresh from school.What's not there is more
important than what is there in many cases.
Regardless I see the need for actual load dump characterization from actual
alternators and then consider simulation with a RC circuit for test ease. I
have yet to find a data sheet where the RC circuit components are derived
from a real alternator to justify the RC value selection. There is no way to
determine the relevance of fig 13 to our real world.
As for 1.5KW devices this is simply far too small for our needs. 40 V is far
too high for me. 5KW devices were suggested months ago and a list member
noted they failed for him. (The 5kw device would seem to be an overkill from
the data sheet but?? thus the need for system testing).
grunt
I have already designed and tested a very simple circuit that appears to do
the job without any active multi part design. What remains is real world
testing. BTW transorbs 'real world knee' is very sharp, at least the many
types I have put under test real world test conditions.
Spending a lot of time discussing a solution when the problem is not well
defined is (to me) foolish. We simply do not have any data, I can find,
documentating a load dump from a "real" alternator.
I am simply unwilling to use data sheets, conjecture, pilot procedure or
"poor regulators" to isolate the approach to the alternator alone when we
have an increasing number electrically dependent aircraft being built and
ignore the potential system effects of load dump.
Paul
From: | "Troy Scott" <tscott1217(at)bellsouth.net> |
Subject: | OVP and Load Dump |
Bob N wrote:
<< . . . the most significant factor being that OV protection is
from a failed regulator.>>
An electrical novice like me buys a product based on what the name of the
product says it is. In the case of a device labeled "Over Voltage
Protection", I expect (reasonably or unreasonably) to get over voltage
protection. Until today, I hadn't realized that my B&C VR, which I thought
includes OVP, is really only a "most of the time over voltage protector".
Isn't a load dump onto the bus an over voltage event?
Bob N wrote:
<< http://www.aeroelectric.com/Mfgr_Data/MR2535L-D.pdf
I've seen data. >>
Does this mean I can add one of these to my system to complete the OVP?
Respectful Regards,
Troy Scott
Subject: | Re: OVP and Load Dump |
Troy,
I think you are confusing two different problems
Problem 1 --- A faulty V.R. / ALT putting out over 17 Volts
Bob N's O.V. Module is designed to Open the "Field " (control wire to the ALT)
and also the "B Lead" thru the Disconnect Contactor --- Isolating the Busses
from this malfunctioning charging system.
Problem 2 --- Load Dump damage to the Internal Voltage Reg in the ALT,
caused by either intentionally or inadvertently Opening this Disconnect
Contactor while the ALT is putting out a Normal Charging Current.
This problem is going to require some kind of a Transient Voltage Suppressor
on the Alternator side of the Contactor to provide a path for this "Energy"
to flow to Ground.
This is the way I understand it anyway :)
Now, I just wish someone would come up with a Part Number that will easily
handle this --- I don't care if it costs 49 cents or $49 , I long ago quit
keeping
track of the amount I am sinking in this project.
Hmm, maybe 100 of the 49 cent TVS's will do the job.
Wally Enga
RV7
>Respectful Regards,
>Troy Scott
Subject: | What's all this load dump stuff anyway? |
You load dump guys have gone way over my head and I suspect the heads of many list
readers. A dispassionate explanation of the nature of the debate and its
significance would help me and I suspect other readers without any experience
in these matters!
You are missing the larger problem, at least to some of us, and that is a
load dump onto the main bus and its likely already done what ever damage it
might do before the "B" lead contactor opens and diverts the rest of the
dump transient back into the alternator diodes and regulator.
Regardless of the reason the alternator we use have been designed to never
be disconnected from the battery when charging the battery.
With an internal regulator Bob's device can only open a relatively slow to
respond contactor.
To me its incidental if the alternator fails as the potential of major
equyipment failure in the aircfraft is a possibility.
Problem is the magnitude of the load dump pulse is dependent on the amount
of the load current dumped. 5 amps is approx 8 times smaller than a pulse of
40 amps.
Many seem fixated on protecting the alternator regulator when all that
results is alternator failure which is less concerting than failure of
flight etc equipment from an unprotected transient.
Even protecting just the internal regulator seems questionable when the
5,000watt device intended to do just that has been reported to fail in this
service.
Mfgr data sheets with called load dump simulations vary 100's of times in
magnitude.
Thus I see no way to get a handle on the problem other than to do tests of
real equipment.
Besides I want to define the problem and solve all 3 of the issues 2 below
and one above.
Should have preliminary results by the end of next week.
Paul
Subject: Re: AeroElectric-List: OVP and Load Dump
> Troy,
ALT)
Busses
Suppressor
"Energy"
> to flow to Ground.
> keeping
> Wally Enga
> RV7
thought
> >Respectful Regards,
> >Troy Scott
Subject: | Re: What's all this load dump stuff anyway? |
many list
experience
>in these matters!
Load Dump occurs anytime the alternator/generator sheds its load (like
turning
something off), because the generator/alternator stator must reduce its
magnetic field. This takes a while---almost half-a-second in the worst case.
Load Dump is at it's worst when nothing but a flat battery is being honked
on by the alternator/ generator and every other load is off---THEN the
battery gets disconnected.
The Load Dump phenomenon may not have received its proper due in the
aviation field
and some re-adjustment of "OVP" schemes may (or may not) be advisable.
Here's more detail I published earlier (and re-edited)---
The automotive people had this LOAD DUMP stuff figured out a long time ago.
The chief
document seems to be SAE J1113-11 but you have to pay big bucks to get a
look at it,
and there's that secret pledge thingy.... But the other guys have published
standards
which presumably are technically close, and they can be found online.
Standard Open-Circuit Volts Rise Time (10%-90%) Pulse duration
(10%-10%)
SAE J1113-11 ???? ???? ????
Chrysler PF9326 91.5 V 5-10 mS 300 mS
Ford CL240 60 V 1-10 mS 300 mS
ISO 7637 ???? 5-10 mS 50-400 mS
All these standards presume a quick rise from nominal to some higher
voltage, then a slower exponential decay back to the nominal base. So they
have similar graphs but different values. All these standards also have
a particular repetition rate, load impedance, and some minor details, but
they are quite similar.
Chrysler standard PF9326 (good published information can be found online)
presumes there is some load on the system. There is a circuit called the
"Load Dump Vehicle Suppression Model" that simulates what one would expect
to find in a real-world vehicle (whether or not it keeps its wheels on the
ground).
According to the Chrysler standard, the peak voltage under these condition
is 38 volts for a nominal operating voltage of 13.5V and of course a load
given by the LDVSM, about 0.5 ohms.
Paul Messinger and Associates (impeccable credentials) are setting up a test
to determine what the real numbers are and what approaches are most useful.
We await
his test results.
THEN WE'LL SEE THE FUR FLY!
Eric M. Jones
113 Brentwood Drive
"I only regret my economies."
--Reynolds Price
Subject: | Breaker type....will these work? |
Bob....would you please look at these P&B breakers (W28) and say if they'll
work for a Cozy panel?
http://my.execpc.com/~indelect/potter/pbw28.html
I like the small footprint, I want to use breakers and I like the idea of
being able to run a finger down the row and "feel" if one breaker is out of
position (ie tripped).
Many thanks
Neil
From: | Nielsen Mark <Mark.Nielsen(at)andritz.com> |
Subject: | Antenna Placement |
Bob and Others,
I am installing a NAV-COMM (SL-30) in my flying RV-6, and I have some
antenna questions.
1. Would the NAV antenna work well if it was installed in the tail cone
under the horizontal stabilizer? The balun would be installed inside the
fuselage with the "whiskers" sticking out through slots on each side of the
fuselage. The fuselage is 9" wide at that point; the antenna would be about
5" below the horizontal stabilizer.
2. Another option would be to mount the NAV antenna on the bottom of the
fuselage. The balun would be attached directly to the bottom of the
fuselage with the whiskers a 1/2" or so below the skin. How would this
work?
3. If the NAV antenna is installed on the bottom of the fuselage, how far
must (should) it be away from the COMM antenna?
4. I am also considering a Bob Archer wingtip NAV antenna. (This is not
preferred however, because of installation difficulties.) Any comments on
reception when using this antenna?
5. I am planning on using a 39" long bare wire for the marker beacon
antenna. Is there any reason why this antenna could not be bonded to the
inside of the engine cowling? (Again, wingtip installation is difficult.)
Is 39" the right length?
Any comments would be appreciated.
Mark Nielsen
RV-6, 909 hours
list readers. A dispassionate explanation of the nature of the debate and its
in these matters!
I thought someone else might take a stab at this but it seems not.
Let me start with how an alternator works. If you vary a magnetic field near a
coil of wire, you will cause an electric current to flow in that coil of wire.
Likewise, if you pass an electrical current through a coil of wire it will
create a magnetic field. You need both of these to make an alternator work.
First, there is an armature. This is the part that spins. The armature is really
a coil of wire through which current passes to create a magnetic field. When
the armature spins it makes a rapidly-reversing magnetic field. Around the
inside of the outer frame of the alternator are three coils that don't move.
They are called the stators. When the rapidly-rotating magnetic field from
the armature passes through the stator coils, the stators produce a rapidly-reversing
(alternating) current. This is rectified by the diodes into DC to power
the aircraft's electrical system.
But the output of the alternator is not constant. If the current in the armature
coil (field) is increased, the armature's magnetic field increases and the
stators produce a higher voltage. Likewise if the armature is turned faster the
output increases. The problem is, we want a constant voltage. This is where
the voltage regulator (alternator controller) comes in.
The VR is a device that measures the voltage on the bus and varies the armature/field
current to keep the voltage constant. If the voltage drops too low, the
VR applies more power (current) to the field to cause the output of the alternator
to increase. If the voltage goes too high, the VR reduces the power to
the field.
Imagine now that the VR goes nuts and stops doing its job. In one failure mode
it stops providing power to the field and the alternator stops producing electrical
power. This is bad but you can limp home on the energy stored in the battery.
The other failure mode is that the VR fails and applies full power to
the field all the time. Now the voltage goes way up, very likely high enough
to fry everything electrical in the aircraft. A runaway alternator can produce
an output as high as 100 volts, not exactly healthy for the electrical items
in your aircraft.
Bob over-voltage protection circuit discovers this high voltage long before it
is dangerous to the devices on the bus. It cuts off all power to the field thus
turning off the alternator. Now you limp home on the juice left in the battery.
No worries.
Now on to load dumping. The alternator does not react immediately to the change
in field current. It actually takes time for the armature's magnetic field
to change thus creating a time-lag in response to the applied power to the field.
So when you turn on a big load; e.g. the landing light, pitot heat, etc.;
the bus voltage drops momentarily even though the VR detects it and increases
the power to the field. Now this is not a problem.
But now imagine that you have turned on your 1000W sound system ensuring that the
alternator is being called on to deliver maximum power. Assume you turn off
the sound system, i.e. "dump the load," so that the bus voltage starts to rise.
The VR reduces the current in the field but it takes a finite amount of time
for the magnetic field in the armature to change to the new value. In the
mean time the bus voltage continues to rise. This sudden, momentary over voltage
can cause damage to electrical components. The OVP circuit won't help as
the VR has already turned down the current in the field.
What you have is 100% correct but only 99% of the story. In addition to
the scenario of your last paragraph, even if the field current could
shut down instantaneously, the output current would still not stop
immediately. Since the alternator is an inductive device the energy
stored in the stator at the instant that the field goes to zero has to
go somewhere. If the battery is still connected it will damp the load
dump of both your explanation and this last bit. However, the OVP is
intended, as well as interrupt the field current, to open the
connection between the alternator output and the battery. When it does
this, the stored energy has no where to go so the voltage will rise to
whatever it takes until something breaks down and absorbs the energy -
probably a diode in the alternator or something in the VR.
Dick Tasker
in these matters!
a coil of wire, you will cause an electric current to flow in that coil of wire.
When the armature spins it makes a rapidly-reversing magnetic field. Around the
the output increases. The problem is, we want a constant voltage. This is where
the field.
battery. The other failure mode is that the VR fails and applies full power to
in your aircraft.
No worries.
the alternator is being called on to deliver maximum power. Assume you turn off
time for the magnetic field in the armature to change to the new value. In the
Brian Hi!
Many Thanks for your explanation. It's starting.... I think to make sense.
BTW. Great place to live. I've spent time in the past across from you at St
Croix.
Gerry
Europa 384 G-FIZY
Trigear with Rotax 912 and Arplast CS Prop.
Engine and Prop getting Final fit. Fuel, Oil and Coolant very soon
Fuselage painted, Wings almost painted, Flying surfaces painted
Airframe Wiring complete, Full Size Panel 70% done .
Includes Dynon EFIS, KMD 150, Icom A-200 and SL70 Transponder. AoA Fitted.
Activity on Panel, Designing Heater Unit, Shoulder Width Mod completed.
http://www.g-fizy.com
+44 7808 402404
gnholland(at)onetel.com
From: | "Jerzy Krasinski" <krasinski(at)provalue.net> |
>............... But now imagine that you have turned on your 1000W sound
system ensuring that the alternator is being called on to deliver maximum
power. Assume you turn off the sound system, i.e. "dump the load," so that
the bus voltage starts to rise. The VR reduces the current in the field but
it takes a finite amount of time for the magnetic field in the armature to
change to the new value. In the mean time the bus voltage continues to
rise. This sudden, momentary over voltage can cause damage to electrical
components. The OVP circuit won't help as the VR has already turned down
> Brian Lloyd >
It depends what OVP circuit. A proper OVP circuit is a fast and brutally
acting device capable to sink a lot of current from the bus whenever it
detects a voltage increase above the norm. In other words it is a device
momentarily increasing the load on the bus, absorbing all the excess current
caused by the load dump. It absorbs as much current as needed to keep the
bus voltage only slightly increased above the norm, far away from damaging
voltages. In the mean time the regulator can reduce the field current so
the voltage on the bus goes back to normal. That reduces the current through
the OVP device which goes idle and the system continues to work in a
standard way.
Jerzy
sound system
deliver maximum
"dump the load,"
> so that the bus voltage starts to rise. The VR
reduces the current
for the magnetic
In the mean time
momentary over
> voltage can cause damage to electrical components.
The OVP circuit
> won't help as the VR has already turned down the
Excellent explanation Brian, but I'd like to add the
image that makes it blatantly clear to me.
Imagine you're trying to open a door. Really
stubborn door. You push with everything you have,
and even call in me, Bob and several others from
this list. We are all sweating and grunting to get
the door open. Suddenly, and without warning, your
wife, who is more intelligent than all the rest of
us combined, turns the door knob.
The resulting explosive release of force can be
referred to as a load dump.
From: | "ronald jagels" <rejnovca(at)hotmail.com> |
Subject: | LASAR Ignition Wiring |
Building an RV-8A with battery in the rear, LASAR electronic ignition and
planning to use Z-13 as a starting point for electrical systems. The LASAR
installation instructions I pulled off the internet apply to a backfit on
existing aircraft and indicate use of the conventional O-L-R-Both-Start
switch. Power is feed to the LASAR control box and then distributed to the
MAG backups with blue wire to the left MAG P lead and green wire to the
right MAG P lead. Question - has anyone wired the LASAR ignition using 2-3
switches as described by Bob in the AeroElectric Connection Book? If so how
did you wire it?
Wallace,
Thanks for your response. Actually, I do understand the difference in
alternator regulator OVP and an OV event caused by Load Dump. I just
believe that a device advertised to have "over voltage protection" should
include features that provide for common possibilities like Load Dump, which
IS a short duration high-voltage-on-the-bus event. The B&C regulator is a
separate box with wires going to and coming from it. Would it be a big deal
to add the $.49 part and a few wires which would connect to the proper
places to absorb a Load Dump? With this and maybe a few other features,
maybe then you could legitimately call it a complete OVP system. And it
doesn't matter if everybody else makes OVP systems without these features.
We're supposed to be better that everybody else, right?
Troy
Brian,
Great explanation on this mysterious electron producer.
The one paragraph below, I might quibble with you on, is
regarding alternators with Internal Voltage Regulators.
These do not have the "classic field wire", but rather a control wire.
Cutting off power to this lead may not shut the alternator down in
all situations.
That is the reason for the addition of a "B Lead" Disconnect Contactor,
along with it's Load Dump issues when inadvertently opened.
Wally Enga
>before it is dangerous to the devices on the bus. It cuts off all power
>to the field thus turning off the alternator. Now you limp home on the
>juice left in the battery. No worries.
> > Brian Lloyd >
>standard way.
>Jerzy
We're stirring two separate events together in the same pot
and blurring sharp distinctions between the two along
with consideration of practical remedies.
Over Voltage Protection addresses a condition that was largely
ignored until alternators were installed on aircraft. It's
precipitated by a failure of the voltage regulator failure and
the engine driven power source begins pushing an otherwise
normal system voltage upward. This is a gross failure of a
control device where potential energy available to damage
system components is measured in Killowatt-Seconds and the
event will proceed with no practical bound on time unless
automatic protection (or pilot intervention) steps in to
shut off the failed alternator.
Voltage settings and time versus voltage operating
characteristics have been studied and defined over the
past 40 years or so and the result is a large field of
offerings in over-voltage relays and, in the AeroElectric
case, crowbar OV protection modules.
The "load dump" phenomenon is described by simple dynamics
of an alternator and it's companion regulator to respond
to sudden reduction in load. It doesn't require a 'failure'
to initiate the event. A simple operation of the alternator
control switch on a Figure Z-24 OV protection system or
operation of the battery master in a Bonanza while the
alternator is carrying a substantial load is all it takes.
This phenomenon is a relative low energy perhaps less than
100 watt-seconds and is self terminating. The classic
OV Protection system was not designed for nor should it
be expected to deal with this event.
The technology of choice is an adaptation of zener voltage
regulator diodes especially crafted to provide a temporary
but rather robust LOAD to the alternator during the
tens of milliseconds that it takes to recover from a
sudden drop on demand for its formidable output capabilities.
This class of zener is commonly referred to as a TVS or
transient voltage suppressor. It's a device
rated to soak up large (1500 Watts or more) surges of
energy for short (less than 100 milliseconds) periods of
time.
Load dump is a RARE event in normal operation. Certified
aircraft have not been fitted with prophylactic measures
because it is so rare. This topic has been stirred numerous
times here on the List and elsewhere over the past 5 years
or so. It was not until Van's Aircraft noted that flipping
the alternator control switch in an aircraft wired per
Figure Z-24 might produce a load-dump event (that could
damage the alternator only) that the topic bubbled to
the surface again.
The debate is not whether a load-dump event can happen.
We know and accept that its occurs under specific
conditions that have become less rare because one
can accidently produce the event by flipping switches
under otherwise "normal" conditions. The conversation is
not so much a debate but a desire to understand and
confirm recommendations already circulating throughout
the automotive industry for RATING the TVS device.
It may well be that a suitable device will surface
in the form of this critter:
They cost about $3 in low quantity and are installed
by simply attaching to the back of the alternator.
One wire to the b-lead terminal, other to ground.
I've oft cited the value of "repeatable experiments"
as the foundation for good engineering decisions.
TVS devices come in hundreds of part numbers of which
perhaps 20-30 parts are best suited to our task.
There's much published literature from the automotive
industry that suggests the part cited above will do
the trick for 99% of the installations common to
OBAM light aircraft. In fact, if any of you
are especially concerned about load dump transients,
you could acquire one of these critters and install
it this afternoon and be 99% assured of having
fabricated a firewall against a .001% event.
Incidental to the outcome of the proposed repeatable
experiments are real debates as to the need for
clamping off load-dump transients at voltage
levels far below values common in Spam cans.
DO-160 cites 40 volt withstand levels for products
intended to serve in 14 volt aircraft. Many
suppliers to the OBAM community are ignorant of
or choose to ignore this simple and easily
accommodated recommendation. They offer devices
advertised with 20-30 volt limits. Some folk suggest
it is in the consumer's best interests to
accommodate these products with extra-ordinary
efforts found no where else in the aircraft
(or automotive) industry. From the perspective
of a designer with feet in both buckets, I've
suggested that we'll better serve the OBAM
aircraft community by insisting potential
suppliers educate themselves on the simple
techniques proven effective in thousands
of products intended for a certified world.
OV protection and load dump protection are
separate tasks with different requirements.
The risks for not installing protection are
well documented and not very debatable. I
have every expectation that experiments currently
proposed will not offer new and startling
discoveries . . . the numbers gleaned will
allow us to confirm a choice of devices for
a well understood task. It's going to be
something akin to deciding whether a piece
of equipment is held to the airframe with
#6 hardware . . . or would #8 be better?
There is useful debate to be conducted on
how we view ourselves as champions and
practitioners of leading edge technology.
I prefer to take advantage of 5 decades
of knowledge base on electrical system performance
upon which we will build an ever expanding
leading edge. I don't find it useful and
cannot recommend that we step back from the
best-we-know-how-to-do just to accommodate
the new kids on the block. Let's help them
join us at the leading edge instead of
spending time and dollars to craft a
system especially friendly to sub-standard
products. In the hypotheticals I cited
yesterday, it would be like putting low
compression jugs on an engine to accommodate
Nuckolls' cheap 75 octane fuel or drilling
half again more holes to install wing attach
bolts so one can use hardware store grade 5
fasteners.
No doubt some will choose to be accommodating
and that's fine too. This is, after all, an
OBAM aircraft community. If accommodation does
not compromise safety, then I'll be the last
to get really excited about anyone's CONSIDERED
decisions on configuring their aircraft. I
won't recommend accommodation when it's easy
to avoid and when the effort is beneficial
to the OBAM aircraft community as a whole.
This I will happily debate any time . . . it's my job.
If RG142 is the only coax that is used in an airplane--about how much is
used per airplane? (Now please don't say it depends...). I am trying to find
out how much weight can be saved by changing to something else, and if
RG142 ONLY can be used for everything coaxial.
Offline is best:
Email: emjones(at)charter.net
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge MA 01550-2705
Phone (508) 764-2072
From: | "David Schaefer" <dschaefer1(at)kc.rr.com> |
Bob ..
I need your thoughts on a problem I've run up against. I've followed your
single ground specifications to a tee. All my grounds are run to the single
B&C ground block. However, I have an issue. I have a 'pre-made' harness
with 8 power and 8 ground connections all on very short leads coming out of
the main cable bundle. All have ring terminals on them. I've cut off the
power side ring terminals and replace them with fast-ons to connect to my
fuse block.
However, I can't decide what to do with the ground side. Do I cut them off
and splice longer wires (3') onto the leads to get back across the plane to
the ground block? OR can I put the ring terminals on a single bolt and run
one larger wire back to the block? OR do I put a couple of bolt-studs by the
fuse blocks and ground the ring terminals to the firewall?
Will the splices 'degrade' the ground?
I'll look forward to your input.
DWS
From: | "LarryRobertHelming" <lhelming(at)sigecom.net> |
If you locate your antennas only in the wing tips it will take considerable
more coax than if you locate them in the belly of the plane. * AND* How
many antennas will you have? (Now please don't say it depends...).
Your answer will not *depend* on anything but your own desires.
Indiana Larry
----- Original Message -----
Subject: AeroElectric-List: RG142
find
> Offline is best:
> Regards,
> Eric M. Jones
> 113 Brentwood Drive
Subject: | For Bob Nuckolls |
Bob--
I've been following the load dump thread with some interest, for the plane I'm
building and the one I fly. I have had a Beech C33A for 15 years and put about
2000 hours on it. It has a 70A alt. and plenty of equip. to load it up. In all
this time I had no idea until this issue came up on the Connection that there
was the potential to trash 10s of thousands of dollars of avionics and other
equip.
There is nothing in the POH about this. In fact the POH says that in the event
of an overvoltage condition, [which would be indicated by an O-V warning light],
batt and alt switch "off momentarily, then on [this resets the overvoltage
relay]". As I understand it this in itself could generate a load dump if the batt
were switched off slightly ahead of the alt.. Am I correct?
Seems strange that the issue of load dump and operation of the master sw was not
included in the POH. Are you aware of any reason for the omission other than
that pilots rarely feel the urge to turn off the master while in flight or when
on the ground with the engine running?
Jim Kaser
>Wallace,
The LR3 regulator wires to the ship's systems with
20 and 22 awg wires of variable length. The best place
to install a TVS is as close to the source (alternator
b-lead) as practical with shortest lengths of wire. When
the TVS is finally sized, the recommended location
would not be inside the LR-3 regulator but right on
the back of the alternator. This will allow a single
recommended installation to cover all manner of load-dump
event in both externally regulated and internally regulated
machines wired per Z-24.
Bob Nuckolls,
Thanks!! I'll definitely want to include this feature. I'll stay tuned.
Troy Scott
see embedded
Subject: AeroElectric-List: Re: What's all this load dump stuff anyway?
Disagree, the vast majority of devices designed for this purpose by the TVS
component industry is for parts many times higher in rating. In fact the
ONLY part I can find that is not a 5000W unit is the above referenced part
noted by "ON" Semi (not a leader on the TVS field). (This for Alternator
Load dump suppression).
It might be of interest to point out what the following spec requires.
"The DaimlerChrysler Corp EMC spec # PF-9326 change D" states.
(Not an exact word by word quote (shortened) but technically factual)
3.5.3 Load Dump Transient test specifies a transient generator that must
produce 125 joules of energy to a 0.5 ohm resistive load with an internal
source resistance of 0.5 ohms when set to an open source voltage of 105
volts. The waveform must average 45.75v minimum over 95ms duration. Further
the test circuit pulse is shown to be above 22.65V for 300ms.
The test load used consists of FIVE of the above MR2535 in parallel each
with 0.1 individual series resistors.
This load results in a suppression of the 90+V pulse to the range of 34-38
volts over the duration of the pulse exceeding this clamped voltage which
duration is not specified in numbers but appears to be in the range of 200ms
based on waveform charted.
The above shows a voltage pulse clamped to close to the DO-160 40 V pulse
but as I recall the DO-160 40 V pulse is much shorter than 200ms and thus
does not cover maximum load dump conditions, that is, if the above
automotive test is max case. In any case it shows the apparent need for much
more than one 1500W MR2535 supporting the rest of the industries contention
that a 5000watt unit is needed.
Bob please restate for us the DO-160 Over voltage tests of one second
duration and shorter including the 40v pulse test including pulse peak and
duration/pulse shape.
To many of us the problem is important, as however unlikely a damaging load
dump occurrence is, if you experience one it can damage lots of very
expensive equipment.
Consider the automobile design. The battery is hard wired to the alternator
"B" lead and the rest of the electrical system is connected by the ign
switch. Thus in an auto only a mechanical failure can cause a load dump. IE
the mechanical connection somehow opens. Then consider automobiles have
designed in TVS protection in the dozens of electrical modules and thus have
a distributed load dump/transient protection network.
In an acft however things are connected differently. The battery is not
directly connected to the alternator "B" lead. The system each are
individually connected thru power relays to the system bus and thus there
are two relays that can cause a load dump if either is opened at the wrong
time.
The opening of the "B" lead isolates the load dump to the alternator.
The opening of the battery relay results in the acft electrical system being
exposed to the load dump. It does not matter how or what caused the battery
relay to open the result is a system wide load dump.
The old spam cans are just as likely to have a load dump as the latest
designs in that respect.
Its not usually a problem however as the load dump from battery disconnect
is not a problem unless the battery is being heavily charged AT that time
and normally this is only for a short time after initial startup.
Paul
Subject: | Re: For Bob Nuckolls |
>Bob--
>I'm building and the one I fly. I have had a Beech C33A for 15 years and
>put about 2000 hours on it. It has a 70A alt. and plenty of equip. to load
>it up. In all this time I had no idea until this issue came up on the
>Connection that there was the potential to trash 10s of thousands of
>dollars of avionics and other equip.
>event of an overvoltage condition, [which would be indicated by an O-V
>warning light], batt and alt switch "off momentarily, then on [this resets
>the overvoltage relay]". As I understand it this in itself could generate
>a load dump if the batt were switched off slightly ahead of the alt.. Am I
>correct?
Yes . . . there WILL be a load dump transient but its magnitude is a
function
of total alternator load, ratio of system loads to battery recharge load,
engine rpm, and individual alternator characteristics. Consider further
that most if not all of the equipment in your airplane was designed to
EXPECT load-dump type transients and survive them.
The worst case load dump happens when the battery is deeply discharged
and accepting strong recharge current from the alternator while at cruise
rpm -AND- minimal system loads. Increasing the amount of stuff running from
the bus in comparison to total alternator loads will reduce the magnitude
of a potential load dump event. Alternator and battery switches are
generally operated on the ground with the engine either stopped or at
>was not included in the POH. Are you aware of any reason for the omission
>other than that pilots rarely feel the urge to turn off the master while
>in flight or when on the ground with the engine running?
No, for the most part, all this discussion is a tempest in a teapot
because (1), it's a vary rare event with a huge range of variability
depending on system operating conditions and (2) we in the spam can
industry have been encouraged to design new products for aircraft with
a robust tolerance of the load-dump event. From the perspective of
Raytheon Aircraft delivering a new A-36 to a customer, concerns
for pilot induced load-dump events causing any damage is completely
off the radar screen. We've done the best we know how to do both
from regulatory and professional efforts to make this a non-issue
with certified aircraft.
It only popped up on radar screens in OBAM aircraft because
with the special case generated by Figure Z-24 OV protection applied
to internally regulated alternators where it's relatively easy
to produce a load-dump event that damages the alternator. This
happens when the alternator is cycled on and off while the engine
is running . . . and again, it probably happened on a Lycoming
engine (high alternator drive pulley ratio) and the alternator
was working hard to recharge a battery that was just used to
crank the engine. If the switch had been flipped on and off
a short time later, the event may not have been so high as
to zork the regulator.
Figure Z-24 has been in publication for about 6 years. Certainly
dozens of aircraft are flying this configuration without
having to report alternator failures because (1) they operate
the switches in the conventional manner and/or (2) load
conditions prevalent at the time of switch operation did not
produce an event with enough magnitude to damage the alternator's
regulator.
Don't loose any sleep over this my friend. 99% of what you're
seeing discussed here on the list is academic discussion
among folk who do this for a living. Like DNA where 95%
is chaos which binds together the 5% of what makes us what we are,
this voluminous discussion will lead to considered, simple and
practical solutions to something that isn't a big problem
in the first place.
I've had some private e-mails suggesting that we should take
this stuff off-list. It "confuses" or "alarms" some folks.
Well, the US Congress does a whole lot of confusing or alarming
stuff off-list too . . . and we know where that gets us. Just
be assured that when all the dust settles, those who are confused or
alarmed will be offered simple remedies while those who choose
to follow along will be richer in understanding for having
taken the time to do it.
From: | Chad Robinson <crobinson(at)rfgonline.com> |
Bob, could you please elaborate on this point? I don't understand why minimal
system load is part of the worst-case. Is the implication that pre-existing
loads other than the battery could help absorb the dump? Or is this simply a
percentages thing?
It might be nice for you to write up one of your famous articles summarizing
the physics of what happens, how to avoid them, and where they actually matter.
Chad
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> |
> cruise
> running from
> magnitude
>percentages thing?
It's a ratio . . . or percentage thing. Suppose total load on alternator
is 50A, 48A going to things on the bus and 2A to recharging the battery.
Now, flip ALL 40A of bus loads off and the alternator will do it's
overshoot thing but the battery is still on the bus to soak up the short
burst of energy that comes during the load-dump. Now, take the same scenario
and turn off the battery. Loads on alternator drop from 50 to 48, not a
big dump, no big deal.
Reverse the situation. Cold morning, battery in good condition but
dead from master being left on. Start with battery cart and turn
alternator on. Alternator pegs out at max capability to recharge
the dead battery. Say bus has a couple of amps worth of goodies
on and you open the battery master contactor. Alternator load drops
from max capability (which can be better than label ratings on
cold day) down to the couple of amps that the bus powered goodies
need. BIG drop in current, BIG overshoot which gets conducted to
whatever items are presently powered from the bus.
>matter.
It's in the mill. Will be able to complete it when all the
data are in from repeatable experiments.
(Aeroelectric-List)
Paul and Bob,
The MR2535 is $1.45, minimum order 10 units from Digikey. Using 5 of them should
not be a problem.
Jim Foerster
I had pretty much tuned out the earlier load dump discussions because it was
more than my electron challenged brain could handle but I now realize that I
recently experienced it and it's practical downside. During maintenance the
ammeter line on my Navion got connected to the buss side of the master CB
instead of the battery side (don't ask!). That put a 35amp CB in series with
the 60amp main breaker from my 50 amp generator. No problem until the engine
started and the generator came on line. The 35a blew disconnecting the
battery and creating what I now know to be a load dump. That blew all the
fuses in my GX-60, SL-30 and SL-70 rendering them useless - twice
before we found the problem. The radio shop was able to replace the fuses
and the radios appear otherwise undamaged but it wasn't pleasant, easy or
convenient (soldered PICO fuses). These are all current generation radios
which I assume were built to DO-160. But that gave me no comfort when I was
stranded without radios and none now knowing it could happen again if the
battery gets disconnected. Oddly, my SL-15/PS7000 audio panel, ACU and
various gauges escaped unscathed. Moral - if you have UPSAT radios, carry
your own supply of 2a & 7a PICO fuses. I may not be able to change my Navion
but I'd sure like to solve/prevent this problem in my RV-6.
Greg Young - Houston (DWH)
RV-6 N6GY ...project Phoenix
Navion N5221K - just an XXL RV-6A
> deeply discharged
> alternator while
> > > at
> > cruise
> > running from
> reduce the
> > magnitude
> either stopped
> > > or at
> understand why
> >minimal system load is part of the worst-case. Is the
> implication that
> >pre-existing loads other than the battery could help absorb
> the dump?
> >Or is this simply a percentages thing?
> on alternator
> the battery.
> up the short
> the same scenario
> to 48, not a
> or alarming
> are confused or
> >summarizing the physics of what happens, how to avoid them,
> and where
> Bob . . .
Subject: | Re: What's all this load dump stuff |
anyway?
Jim,
The ST BZW50-22 has about the same specs and
a little higher Peak Pulse rating of 5000W.
Prob get by with 4 of them :)
http://www.datasheetcatalog.com/datasheet/B/BZW50-22.shtml
Wally Enga
>Paul and Bob,
>should not be a problem.
>Jim Foerster
>>Well, the US Congress does a whole lot of confusing or alarming stuff
off-list too . . . and we know where that gets us. Just be assured that
when all the dust settles, those who are confused or alarmed will be
offered simple remedies while those who choose to follow along will be
richer in understanding for having taken the time to do it.<<
Thanks for the sobering thoughts, Bob.
From my years of experience with aircraft electronics and avionics, I
believe the practical answer is: load dump problems are not one of the
big problems folks need to concern themselves with. Like a spot of dust
on an elephant's butt - not a worry.
Ron
Subject: | For Bob Nuckolls: Roll your own crowbar module troubles |
This is a resend of previous information I posted but you didn't get.
I build my own OV crowbar module and it functions correctly except that
it operated in the 10-11 volt range. I triple checked the components
and wiring. I changed the 1.62K ohm resistor specified for a 14 volt
system to 6.04K and the circuit operates in the correct voltage range of
15.5-17 volts.
Designating Point (1) as the + end of the capacitor, and Point (2) as the
junction of the 392 ohm resistor, and GND as the negative lead, with the
pot at midrange I got the
following readings:
1.62 K resistor in place for 14 volt operation. - Trip point = 10.4
volts.
Point (1) - Point (2) +0.436 volts
GND - Point (2) +7.6 volts
6.04K resistor replacing the 1.62K one. - Trip point = 16.22 volts.
Point (1) - Point (2) +0.538 volts
GND - Point (2) +7.36 volts
These readings made me realize the circuit was not letting the zener
regulate at 12 volts so I did the following checks.
First I disconnected the SCR trigger lead to prevent it from firing. I
reinstalled the original 1.62K resistor.
Measuring the Zener voltage from GND to Point (2):
As I increased the input voltage the voltage across the zener increases
linearly to about 8.25 volts and then starts to decrease. The input
voltage is about 9 volts when this knee occurs.
I then disconnected the 1N4148 diode and repeated the above test with
basically the same results.
With the 1N4148 diode still disconnected, I also disconnected the NPN
collector and PNP base (they remained connected together) from the point
(2) junction. Now only the Zener and 392 ohm resistor are in series
across the supply. Again measuring the Zener voltage from GND to point
(2):
The zener voltage tracks the input voltage up to about 11.3 volts at
which point the zener begins to regulate.
With the two transistors still disconnected, I reconnected the 1N4148
diode.
Now the voltage across the zener increases linearly up to 9 volts (input
voltage is 9.35) when suddenly the voltage drops to 1.87 volts.
Do you have any suggestions to help troubleshoot of fix it.
Ralph Ketter
RV-6
Marysville, KS
From: | "KeithHallsten" <KeithHallsten(at)quiknet.com> |
Subject: | Co-ax splice method |
I'm about to close up the winglets on the Velocity I'm building, and I need to
extend the antenna wire first. The copper-foil type antenna came to me with a
short length of RG-58 attached, already glassed into the winglet. I intend to
extend it to the instrument panel with RG-400. The area where the splice will
be made will be inaccessible once I seal up the winglet, so I want to use the
parts and technique that has the lowest probability of a problem for the life
of the airframe. I could just install a male connector on one and a female
connector on the other, then mate them and cover with some heatshrink. Is this
the best approach to this situation? Thanks for your advice!
Keith Hallsten, Roseville, CA
>>I could just install a male connector on one and a female connector on
the other, then mate them and cover with some heatshrink. Is this the
best approach to this situation? Thanks for your advice!<<
That would be good practice, Keith.
Using crimp-on connectors and making sure the connectors were installed
correctly with low resistance before covered them.
Another option, rather than heatshrink, would be the NITO type self
vulcanizing tape (rubber with no sticky side - pulling the tape tight
over the previous wrap seals the connection). It's good in any harsh
environment - keeps moisture out of the connection. If your plane will
be kept in a high humidity environment you might consider it.
Ron
>>before covered them<<
Edit - Edit
...before you covered them.
Of course....
I know but picking that part is premature as to date. ALL the discussion is
based on NO real data just what mfgrs have used for their own purposes.
There are much sturdier parts available at much lower cost not that cost is
a driver here.
Paul
> Paul and Bob,
> Jim Foerster
I would like to know the DO-160 requirements associated with transients
above say 24V including pulse duration, shape and peak V where the duration
is under one second.
For example I recall there is a 40V pulse but I do not know its duration or
shape. I seem to recall there is a longer pulse at a lower voltage also.
Then there is the maximum Voltage steady state level. And perhaps others
addressing above normal bus voltage ranges.
This info will help me with the load dump testing. Specifically IF I find
what appears to be a condition that exceeds DO-160 requirements. In that
case I want to further analize the test results and it would also be a
factor in any proposed solution which would be a final part of the load dump
tests.
Paul
Subject: | LOAD DUMP TEST START |
The long waited REAL testing started on 5-13-04.
This will take as long as it takes :-) at a rate of a couple of hours per
day, but likely completed this month. (Could also be less than a week to
preliminary final results, full writeup/documentation may take months.)
Its not simple to design a test of this complexity when the results will
subject to the likes of Bob :-). I have some preconsived ideas of the
results (as do many of us, including Bob, but have set that aside and will
let the results stand for themselves. The test conditions are designed to
allow others to duplicate with reasonable accuract what I am doing so any or
all parts can be setuip in a different lab and the results should be
comparable considering the component and test equipment variations.
System level Load Dump is not a simple issue as some have tried to make it.
That is IF the objective is to detail what happens and how it can effect the
other parts of the system. Even the OVP module is part of the system during
the time it takes to open the associated 5 amp CB.
Only protection of the alternator internal diodes and regulator is one
solution and that only takes clamping the voltage to 35-40 volts and that
voltage is way too high for some equipment including some of mine.
Others will accept the above as enough and TRUST the rest of their system
meets DO-160 and that DO-160 is designed to cover load dump and the
equipment actually was tested to that specific part of DO-160. Quite a leap
of faith in my opinion but perhaps not, as only the test results will tell.
It is important to emphasize that damaging Load dumps need very special
conditions to occur. Turning off your landing lights produces a load dump
but a non failed system clamps it to harmless levels.
There are several different tests needed, starting with components,
assemblies, and ending up with system tests from alternator to battery with
simulated (resistive) equipment loads.
Voltage, current, and waveform recordings are included as needed in several
The initial test demonstrated very repeatable results and verified the
instrumentation approach.
The testing is on a very limited set of major components. I do not have the
$$ and time to test lots of components costing $$ each. TVS devices I do
have in quantity in various types, but alternators and contactors are a
different matter.
I do not consider this a problem however, as any solution must have a design
margin "Built in" of several times the measured data to cover major part
variations.
I am dismayed at the many recent comments, all apparently based on
conjecture (at least I have not seen ANY reference to ANY real data) based
on literature and concepts that have widely different conditions assumed.
Looking thru the various data sheets and application notes provides a
surprising array of examples of simulated load dumps and general comments
and NO real alternator test load dump data. Lots of opinions presented as
facts to support the authors opinion.
I do not plan on any further comments on other load dump posts/comments
until the testing is completed as to date its simply an exchange of opinion
with no facts and takes time and bandwidth.
As to comments that DO-160 equipment being designed to survive any load dump
on any aircraft; I question that, but not having the relevant DO-160 test
requirements, I have no way to comment.
Paul
Subject: | Re: Co-ax splice method |
>need to extend the antenna wire first. The copper-foil type antenna came
>to me with a short length of RG-58 attached, already glassed into the
>winglet. I intend to extend it to the instrument panel with RG-400. The
>area where the splice will be made will be inaccessible once I seal up the
>winglet, so I want to use the parts and technique that has the lowest
>probability of a problem for the life of the airframe. I could just
>install a male connector on one and a female connector on the other, then
>mate them and cover with some heatshrink. Is this the best approach to
That's what I'd do. There is another suggestion for covering the joint with
silicone tape. See S894 at bottom of page at:
http://bandc.biz/cgi-bin/ez-catalog/cat_display.cgi?9X358218#S894
This tape is not very robust mechanically so I'd put a layer of
heat shrink over it. You don't need much tape . . . one layer
stretched tight and 30-50% overlap on turns is sufficient.
Alternatively, there are internal melting wall heatshrinks
that seal and encapsulate the finished joint.
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> crowbar module troubles |
Subject: | Re: For Bob Nuckolls: Roll your own |
>Bob,
Peter, sorry for the delay on responding to this. Had a really
busy week. I've printed your values out. Got a really boring
meeting to go to this afternoon. I'll noodle over the data
then.
>15.5-17 volts.
>following readings:
>volts.
>(2):
>diode.
>Ralph Ketter
>RV-6
>Marysville, KS
( Experience and common sense cannot be )
( replaced with policy and procedures. )
( R. L. Nuckolls III )
>Bob,
>tests.
>Paul
Do you have a fax machine. I'll send you sections 16 and 17 out
of the book. I could scan and e-mail them if needs be but it would
be a huge file.
Your off line response was great thanks a lot.
Paul
> be a huge file.
> Bob . . .
Subject: | re: LOAD DUMP TEST START |
Anyone who produces a product (not a distributor or dealer) should
be expected to KNOW the capabilities of their product. If they
beg ignorance in matters of input power variability, then their
skills in other matters of the product design are suspect as well.
>diferrent matter.
My mental image derived from your words suggest the task
you describe is more complicated than it needs to be.
I don't see much value in knowing the middle ground values
for load dump events. We know what produces the worst case and
we know that some manner of energy sink is needed to
grunt the overshoot. See:
http://www.aeroelectric.com/temp/loaddumptest.jpg
This setup would allow one to take a commercial off-the-shelf
alternator (I'd use a new N-D from B&C) or any number of junk-yard
takeoffs to plot characteristics of the load dump event as it
relates to load and speed of the alternator. You'd have to start
out slow and low and work your way up to the conditions that
ultimately trash the alternator's built in regulator. Alternatively,
once the speed/load conditions are identified that put the regulator
at risk (something on the order of 40v) then one could switch
to investigation of proposed TVS devices to stand off the load-dump
event up to and including full load on alternator at 12,000 rpm.
By limiting unprotected testing conditions to those which do not
produce regulator killing spikes, one could shift attention to
the protection investigation at little risk for needing to repair
a test article. A data acquisition system or recording 'scope could
capture the voltage/current characteristics of energy dissipated
in the TVS during load-dump events.
It's would be interesting to explore ALL the variables associated
with the various hypothetical situations it seems that the most
economical effort is to size the device needed to clamp the
worst case scenario at whatever target voltage you choose
I have made the full text of DO-160 available to you. I cannot speak
to the thinking of committee members while this document was being
crafted. Don't know if they were considering alternators, generators
or both but the values speak for themselves.
See paragraph 16.5.4.4 where the worst case (Category Z) for 28v
systems cites 80v square pulse (figure 16-4) for 100 milliseconds.
and 48 volts for 1 second. This test is intended to characterize
resistance to a spectrum of surge voltages described in Figure 16-6.
14V system values are 1/2 the 28v system voltages but with the
same times so 40 and 24 volt surges apply. I've been testing
to these values for over 30 years . . . it's a no-brainer.
It seems to me that selection of a TVS device for clamping
alternator load dumps to values LESS than those described
in the first 100 milliseconds of figure 16-6 is no big deal.
The OVP system takes care of lower voltage events beyond
100 milliseconds.
This presumes, of course, that suppliers take the time and
effort to recognize the value in building voltage surge
immunity into their products as suggested by DO-160.
If one wishes to limit load-dump amplitudes to values
lower than those suggested by DO-160, then it's simply a
engineering and parts selection task with new bounds.
With a limited budget for time and dollars, it seems
prudent to limit the investigation to conditions specific
to the worst case.
Subject: | FS - EGT/CHT probes |
I've got 6 each Grand Rapids Technology EGT and CHT probes that I should
get rid of - they're extras and have never been installed or used. Hose
clamp style EGT, bayonet style CHT.
They're $444 new, I'll sell the lot for $350. I'd prefer to sell the whole lot.
Subject: | Re: re: LOAD DUMP TEST START |
From: "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net>
Subject: AeroElectric-List: re: LOAD DUMP TEST START
Agreed but then I have found many who seem to know about DO-160 and yet seem
to have other product design problems. Also its very hard if not impossible
to get thru sales to engineering to determine if the 24V max input V has
margin including passage of a specific DO-160 by test or just engineering
analysis or wishful thinking.
Expect and assume are not something I use frequently as its poor thinking in
far too many cases.
Interesting but seems to not address what happens before the "B" lead
contactor opens to the equipment on the busses.
I do not have a B&C or a ND alternator and no reason to know that its
nominal much less worst case with regard to load dump. Thus the need for any
test results to have design margin added.
As for the DO-160 your info will be of great value to me during this testing
period and far beyond.
This is a low budget test and I do not have either the time or money to get
fancy with variable speed drives, specific alternators, and extensive
testing. I am not convinced there is all that much difference in alternators
with similar current ratings. I do have a 45 and 65 amp (different brands
and neither ND) alternator to test so we will see. I am testing what my
background and education suggest needs to be tested.
However one main concern is how a major load dump interacts in an aircraft
system considering internal and external regulators and "B" lead contactors
as well as battery contactors and the OVP interaction during the initial
part of the load dump before the OVP blows the fuse starting the "B" lead
contactor disconnect etc.
That is what I have here A digital storage computing O' scope including the
built in waveform computer for calculations etc. The delays were in part
getting an expensive recal of the equipment for free (IE in spare time at
test lab).
Paul
-----Original Message-----
On Behalf Of Nielsen Mark
Subject: AeroElectric-List: Antenna Placement
Bob and Others,
the
work?
This is how mine is set up. The whiskers are under the horizontal.
This setup works great.
far
My com is located just aft of the battery box of my 6A on the
centerline. There is no interference with the Nav. I am going to
install a second Com behind the first that will be closer to the Nav. I
will report after this is tested.
Ross Mickey
N9PT
RV6A
AeroElectric-List message previously posted by: "Eric M. Jones"
5/12/2004
Hello Eric, Forgive me -- I am going to disregard your requests to respond off
line and to not say "It depends".
But I will try to put some numbers in my answer.
1) My airplane uses 9 antennas: 2 VHF NAV, 2 VHF COMM, 1 GLIDE SLOPE (not connected),
1 MARKER BEACON, 1 GPS, 1 ELT, and 1 TRANSPONDER.
2) Assume that each box requires 5 feet of coax going to its respective antenna.
This is over kill I know -- many of the coax runs are very short. This would
be a total of 45 feet of coax (9X5=45).
3) The Belden catalog says that RG 142 weighs 4.3 pounds (68.8 ounces) per 100
feet. Or .688 ounces per foot.
4) 45 feet of coax times .688 ounces per foot gives a total of 30.96 ounces or
1.935 pounds.
5) I don't know of any 50 ohm RG type coax that is significantly lighter than RG142
(which has a solid steel core), but there may be some. There are some versions
of RG 58 that are lighter -- and some heavier than RG142.
6) But even if you were to find a 50 ohm RG cable that was only half the weight
of RG142 (unlikely) and used that in an airpane like mine you would be saving
.9675 pounds. Not a trivial weight saving number, but not one that I would spend
hours on trying to accomplish.
OC
PS: I don't have any weight figure for RG 400, a copper stranded core coax of comparable
quality to RG 142. It may be a bit lighter.
One can discuss the merits of solid core versus stranded core with some valid arguments
on both sides. I've got both in my airplane.
PPS: If I were limited to using only one type of RG for everything it would be
RG 142.
Subject: | Re: Weight of RG142 |
Thanks OC,
used
per airplane? (Now please don't say it depends...). I am trying to find out
how
100
than RG142
versions
weight
of RG142 (unlikely) and used that in an airplane like mine you would be
saving
spend
>OC
The wire I have found is 0.24 ounces per foot (35% of the weight of standard
RG142). Furthermore it has improved characteristics--50% better VSWR, 22%
lower insertion loss, reduce phase and attenuation drift, etc. Making even
much lighter cable is quite possible.
The real question is what is losing a pound worth? Here's my rough estimate:
Lets say your aircraft is worth $100,000 and weighs 2,000 pounds. Does this
mean your airplane is worth $50/pound? Maybe.
A better way to estimate the savings is to look at the total operating cost
for the life of the aircraft. In this case lets imagine the aircraft will
go 10,000 hours and costs $75 per hour to fly. Thats $750,000. At the end
of this time we assume the aircraft will be valueless. So thats
$750,000/2000 pounds; or $350/pound.
Lets apply the reasonableness test to this: Does $350/pound mean that your
old tin barf-bird sitting on the ramp is worth $350/pound? No. This figure
says that the cost of moving a pound of airplane all over the sky for 10,000
hours (50 years at 200 hours per year for example) is $350. Thats perfectly
reasonable.
So how much should you pay to avoid the $350/pound expense? If you invested
$35 compounded annually at 8% return with an inflation rate of 3.1%, you
would have the $350 in 50 years. So the answer could be $35.
(This simple example does not include the increased value in having an
airplane that goes a little faster, etc.)
(I would like aeroelectric listers opinions on this!).
So in summary I really don't know. If the cable costs even nearly the same,
certainly get the better and lighter cable.
But there are certainly other factors---
A couple weeks ago there was a lister who thought my Super-2-CCA copper clad
aluminum FatWire (available in two weeks) was too expensive for the weight
saved. I honestly don't know how best to calculate such a thing. I once flew
from Van Nuys, Ca to Winslow, Az in a Cessna150 and landed with a pound of
usable fuel remaining. I would have paid plenty for that pound of fuel
instead of a extra pound of wire.
Eric M. Jones
113 Brentwood Drive
Listers, and Bob,
I know I have read about RG batterys on the list. Searched the archives for
an hour and was not rewarded.
Will a 17AH panasonic, or the like, turn over an 0-200?
It will be wired per Z-11.
I think I know the answer, but want confirmation before I order.
Kevin Boddicker
From: | "James E. Clark" <james(at)nextupventures.com> |
The **Odessey PC680" (17AH) turns O-320's and O-360's with no
problem. Thus I suspect that an O-200 can be handled.
James
> From: owner-aeroelectric-list-server(at)matronics.com
> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of
> Boddicker
> Sent: Saturday, May 15, 2004 8:50 PM
> To: Aeroelectric list
> Subject: AeroElectric-List: Batterys
> Listers, and Bob,
> archives for
> Thanks,
> Kevin Boddicker
From: | "thomas a. sargent" <sarg314(at)earthlink.net> |
Subject: | 6A gear weldment fit in a QB kit |
I have a 6A quick build. In the QB kit the main gear weldment comes
pre-drilled AND the fuselage has been pre-drilled. The problem is the
holes in the two parts don't line up very well.
How can this be, you say, wasn't it all drilled in place in the fuselage
to start with? Apparently not. Bruce at vans tells me that they drill
the gear weldment to the spar, but they don't match drill it to the
fuselage. They drill those holes in the weldment on the bench somehow.
The holes in the gear weldment that lie along the wing spar, look like
they match the spar pretty well. But the group of 4 that penetrate the
fuselage just forward of the spar appear to be off by at least 1/8"
upward. My theory at the moment is that the forward piece that screws
to the side of the fuselage (those 2 holes line up rather well) is
actually about 1/8" too low. That raises the whole outboard end of the
weldment 1/8".
I gather many QB builders have similar problems with the gear weldment.
What have other people done about it?
Tom Sargent, RV-6A QB
OOps! Posted to the wrong list. I'll try to improve my aim.
The PC680 is a vary different battery that the lower cost Panasonic (etc
brand) 17AH battery. About the only thing the two have in common are similar
AH ratings.
The PC680 is designed to have much higher cranking amps, longer life, no
need for standby chargers, hundreds of very deep discharge cycles and true
multi year life.
The real world cost (including shipping) is typically only double the lower
cost Panasonic or equivalent ($100 vs. $50 delivered). Sure it depends on
where you live.
After spending so much ( $$ ) on your aircraft I wonder why so many on this
list seem to want to go to the lowest cost battery available when the best
is so little more.
Just based on specifications the PC680 is double the cranking power of the
batteries used on most of the "Spam can" fleet up to and including the O540
etc engines.
Given the multi year life, they are actually the same cost if you replace
them every other year and more likely there is no need to replace them that
frequently. Then there is the advantage of no need for standby chargers. I
had a couple of them that were left over the winter and needed less than
1/2AH to top off after 6 months. BTW these batteries are not 2 1/2 years old
and still load test to 95% of original capacity.
Simple, no brainer, low cost, load testing is possible and I sure dislike
replacing batteries just because its a "good idea". On the other hand, I
would not fly with the lowest cost batteries in an electrically dependent
aircraft.
Paul
From: "James E. Clark" <james(at)nextupventures.com>
Subject: RE: AeroElectric-List: Batterys
> James
Subject: | Re: 6A gear weldment fit in a QB kit |
> weldment 1/8".
I had the exact same problem with my 7A. I have a QB wings and SB fuselage.
I tried all day to get that damn thing to fit. Called Vans the following
monday. Their suggestion started off like this, "get the hydraulic jack
from your car, ..." I was flabergasted. No can do.
I ordered a new one from Vans, not cheap. Fit like a glove. Apparently
they are welded in a jig. Vans indicates that if it's removed from
the jig before it cools it may have a tencancy to "slip" a bit. BS.
They wouldn't take the original in trade. Now I have a weird looking
paperweight.
I've detailed the issues on my site.
Walter Tondu
http://www.tondu.com/rv7
Subject: | Weight of RG-142 |
"(This simple example does not include the increased value in having an
certainly get the better and lighter cable. But there are certainly other
factors---"
Eric,
Your arguments are cogent, but I think too complex for the
prupose. Having helped rebuild a Yale, Stearman and several other WW II
aircraft, and in midst of building a Europa, I would say the most vital
statistic for a aircraft destined to fly for 30 years privately - is the
reliability factor.
The last thing I want to do ever again is re-route coax. It's
never out in the open but snaking from one compartment to next, trying to
get outside to an antenna. It is ALWAYS bent too tight for the corners to
remain central (creeping core which changes impedance) and one needs to know
it will be sustained through the ravages of temp and humidity over the
years. The connectors are usually poorly attached and protected, and often
must be connected in the darkest reaches of the vehicle.
For me, weight ain't even "in it". Do it once properly and
forget it.
Ferg
Europa A064
From: | "Scott & Leere' Aldrich" <flynski(at)mwutah.com> |
>where you live.
>Paul
Ebay search for pc 680, you will find Odyssey world $53.50 plus flat rate
$12 shipping anywhere in US.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=790221845
6&category=34284
> James
From: | Mickey Coggins <mick-matronics(at)rv8.ch> |
Hi,
I have not any research on RG batteries, but I was under
the impression that they have pretty much the same
specifications and ratings. What kind of things can
we use to tell them apart, besides the price?
Mickey
>AH ratings.
Mickey Coggins
http://www.rv8.ch/
#82007 QB Wings/Fuselage
From: | Matt Jurotich <mjurotich(at)hst.nasa.gov> |
Subject: | ? Pyramid PS-26KX Regulated Adj Voltage 25Amp PowerSupply? |
Folks
Anybody with experience with Pyramid PS-26KX Regulated Adjustable Voltage
25Amp Power or Pyramid products in general?
http://www.etronics.com/product.asp?stk_code=pyrps26kx&store=&catid=4071
This sounds like what I really want for bench testing my new panel. The
only alternative being seriously considered is a a much lower output
variable supply in parallel with a usable for bench testing battery.
Thanks in aadvance
Matthew M. Jurotich
NASA/Goddard Space Flight Center
JWST ISIM Systems Engineer
m/c : 443
e-mail mailto: mjurotich(at)hst.nasa.gov
phone : 301-286-5919
fax : 301-286-7021
JWST URL: <http://ngst1.gsfc.nasa.gov>
Subject: | Re: Weight of RG-142 |
Ferg,
I appreciate your wisdom and advice.
My interest in this is more to sell product than build an airplane. (Hey,
I'm broke, but building a Glastar).
RG142 has a steel center conductor so that it can be strung between poles
and run up antenna towers. Not very useful in an airplane. Furthermore the
bend radius of the wire I am researching is much smaller than standard
RG142.
Eric M. Jones
113 Brentwood Drive
>reasonable.
>Regards,
>Eric M. Jones
Excellent points. I can reinforce those ideas with the following
anecdotes from my own experience. In 1964 when I was a tech writer
for Cessna, a number commonly circulated around the
engineering department suggested "For every pound of emptly weight
added to our airplanes, it will cost the owner(s) of that airplane
$100 to buy the pound of stuff, maintain it, and purchase fuel
to carry it around over the lifetime of the airplane.
When I worked at Lear on the Gates-Piaggio GP-180 program, I asked
my management how much bonus I could offer my suppliers for weight
reduction. That got me a bunch of surprise looks. "Shucks Nuckolls,
beat 'em up for every ounce you can get . . . but why should we
offer a 'bonus'? I told them about my experience at Cessna. They
went off into a huddle and a few days later came back with a figure
of $300. I was skeptical that it was truly that low . . . but it
did mark a milestone in the way my management thought about the
economics of designing, building and operating our products. The
fact that they would offer ANY substantial number in dollars for
weight reduction was pretty cool.
A few days ago, I meet one of RAC's higher engineering management
folks in the Denver airport. He had been visiting kids in the Denver
area and I was coming back from a consulting trip in Idaho. I bemoaned
the state of an important system in one of our products that was
too complicated (astounding parts count), too heavy (about 50-60
pounds), terrible service history (been in the #1 trouble reports
slot on the airplane since day-one), and about 1.5 to 2x more expensive
than more attractive options. I proposed RAC consider of a system
that was at least 50 pounds lighter with a demonstrated
zero faults performance record for many hours on a flight test
aircraft.
I asked him what it was worth for weight reduction on this
airplane? He didn't think long before he came up with the number
of $2,000 per pound. I then described my proposal for replacing
the system and suggested that if we could carve 50 pounds out,
1/3 to 1/2 the cost of hardware, 95% of the installation
labor and offer system with an impeccable track record then
at $100,000 savings to the customer (in ADDITION to good will
generated by eliminating a troublesome system), that changing
over to the new system was essentially "free" . . . yes, there
are some up-front costs on the order of a $million but this
would amortize out VERY quickly.
He didn't argue with me. The discussion went to other topics
but it will be interesting to see what his reaction and support
is when I bring this solution up in an upcoming meeting.
Eric's observations are accurate and right on point. There
are economies of operation, financing, fabrication and
parts selection that can argue most energetically with
each other. During Voyager's design and construction
phases we were told that it takes 5# of fuel to carry
1# of airplane around the world. This means that every
pound of empty weight jacks up take off weight by 6 pounds.
Here the economies of operation held sway and every effort
was made to carve grams out of the airplane sometimes at
great expense on an airplane that had a lifetime of a
few hundred hours! Each of you needs to make
your own decisions as to which economy drives
various decisions for purchase and assembly of parts. I've
oft used the term "cost of ownership" in discussions where
the long term benefit from a larger investment up front
pays off. I've also championed the notion of parts-count-reduction
where the economies of reliability are perceived as most
important. If one can bring multiple benefits to bear
(lower parts count, lower weight, lower cost of ownership)
while improving performance . . . then I'll suggest this
is the very ESSENCE of the OBAM aircraft fabrication philosophy
that will never be fully realized in the certified world.
While OBAM aircraft have published gross weight limits, I
think we can agree that those limits can be pushed under
certain conditions (cool air, c.g. well inside limits,
etc) and certain times when they cannot. It seems that
spending lots of time and dollars on weight reduction for
weight reduction's sake may not be the same overpowering
economy in OBAM aircraft that it is in certified ships.
I'll join Eric in offering the notion that the simple-ideas
underlying the really elegant decision are easily obscured by
a lot of ol' pilot's tales and hangar wisdom. Bringing
questions out to the List is the best place to filter
the various ideas in search of the elegant solution.
<<....skip.....The wire I have found is 0.24 ounces per foot (35% of the weight
of standard RG142). Furthermore it has improved characteristics--50% better VSWR,
22% lower insertion loss, reduce phase and attenuation drift, etc.....skip....>>
5/16/2004
Hello Eric, Can you please share with us the identity, source, and cost of this
wire? Thanks. OC
PS: I found your weight analysis benefit very interesting. Please let me add another
sort-of-weight benefit consideration. The situation involved an airplane
ditching and subsequent rescue at sea within hours. In debriefing the survivors
one spoke of the desperate level of thirst that he experienced shortly after
being free of the ditched aircraft. He described the thirst as almost totally
mentally debilitating and leaving his mouth and throat so dry that he was unable
to transmit over his portable survival radio. He vowed that he would never
again fly in an airplane unless he had at least a pint of water personally available.
A pint of water weighs one pound. What is that pound worth?
From: | Charlie England <ceengland(at)bellsouth.net> |
Subject: | Re: ? Pyramid PS-26KX Regulated Adj Voltage 25Amp |
PowerSupply?
Matt Jurotich wrote:
>Folks
>Thanks in aadvance
>Matthew M. Jurotich
>m/c : 443
>fax : 301-286-7021
Since you work for NASA, I'm sure you've heard the old urban legend
about 0-G writing instruments for NASA & the Soviets.
As a corollary, you can buy a 12 V jump start pack from Harbor Freight,
WalMart, etc. for under $50 & it will have uses outside of & beyond your
a/c project.
The only thing you might need adjustable voltage for is checking a
low-voltage warning circuit. You can get that by just letting the
battery in the jump start pack run down the trip voltage of the detector.
'Better is the enemy of good enough.'
>add another sort-of-weight benefit consideration. The situation involved
>an airplane ditching and subsequent rescue at sea within hours. In
>debriefing the survivors one spoke of the desperate level of thirst that
>he experienced shortly after being free of the ditched aircraft. He
>described the thirst as almost totally mentally debilitating and leaving
>his mouth and throat so dry that he was unable to transmit over his
>portable survival radio. He vowed that he would never again fly in an
>airplane unless he had at least a pint of water personally available. A
Aha! The economics of survival. Economics has been
often described as the study of scarce resources for
which there are multiple uses. Economics isn't just about
dollars.
> dollars.
Last week I was at a technology expo for my Very Large Aerospace
Company. They had a wonderful materials display. Thinwall titanium
casting, additive titanium, laser fusing. They had a nose gear strut for a
777 made of silicon carbide fibers in a titanium matrix. They said it save
weight at about $1000/lb. At that price, it was worth it to them.
From: | "William Slaughter" <willslau(at)alumni.rice.edu> |
I have a PS-26KX that has been working well. I've owned it about a year,
and it has experienced a very low duty cycle, but it seems to be well
made, and judging by the weight, must have a healthy size transformer.
No complaints.
William Slaughter
[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt
Jurotich
Subject: AeroElectric-List: ? Pyramid PS-26KX Regulated Adj Voltage
25Amp PowerSupply?
Folks
Voltage
Thanks in aadvance
Matthew M. Jurotich
m/c : 443
fax : 301-286-7021
direct advertising on the Matronics Forums.
Subject: | Bob - Single Ground question ?? |
Bob ..
B&C ground block.
However, I have an issue. I have a 'pre-made' harness with 8 power and 8
ground connections all on very short 6" leads coming out of the main cable
bundle which is about 4' long. All had ring terminals on them. I've cut
off the power side ring terminals and replaced them with fast-ons to connect
to my B&C fuse block.
#1 Do I cut off the ring terminals and splice longer wires (3') onto the
leads to get back across the plane to the ground block (3' away)?
#2 Do I put the ring terminals on a single bolt and run one larger wire back
to the ground block?
#3 Do I put a couple of bolt-studs by the fuse blocks and ground the ring
terminals to the firewall at the local site?
DWS
>Hi,
Their ratings are what they are . . . if you want to compare
the nitty-gritty details of one battery against another, then
download the data sheets for each battery from the manufacturer.
Keep in mind that "ratings" generally don't say much about
service life . . . particularly with respect to how you want
to use the battery (crank an engine a couple dozen times a year,
fly perhaps 50 hours out of a total of 8670 hours/year. The
battery sits unattended for 8720 hours per year in a variety
of environmental conditions which MAY include the occasional
total discharge for having left something turned on.
There's just no way any manufacturer can sign up to
this task with certainty nor can he compare his product
with anyone else's product with accuracy. Therefore, one
must resort to marketing hype in an attempt to distinguish
his product from the competitors. If you want to get 100%
out of an expensive battery, then be prepared to do periodic
capacity tests and discard the battery when cap test falls
below your e-bus operations requirements (this too can be a huge
variable). You may find that the added labor and tools to squeeze
an expensive battery dry costs more than buying the cheapest
battery you can find and replacing it every year.
This goes directly to the thread I responded to earlier about
the economics of weight savings, etc. etc. Here we're talking
the economics of maintenance to maintain reliability. I
suggest the cost of ownership for the lower cost, "disposable"
battery is ultimately less than squeezing every last drop
from a $high$ battery.
From: | "Robert L. Nuckolls, III" <bob.nuckolls(at)cox.net> 25Amp PowerSupply? |
Subject: | Re: ? Pyramid PS-26KX Regulated Adj Voltage |
25Amp PowerSupply?
25Amp PowerSupply?
>Folks
>Thanks in aadvance
>Matthew M. Jurotich
This has the right specs. I'd think it was a good value for
the task.
That's kind of what I thought too. I'll just swap one
of my batteries out each year. Sort of like the info
you gave in this article:
http://www.aeroelectric.com/articles/AA_Bat_Test.pdf
Mickey
> ... I
Mickey Coggins
http://www.rv8.ch/
Subject: | Re: Bob - Single Ground question ?? |
>Bob ..
>B&C ground block.
Give #3 a try. If you don't have an noise problem from the ignition system
(and you probably won't), then there's nothing else to do. If push comes to
shove and you do get some noise, then extend the individual wires to the
ground block.
No.
>reasonable.
>Regards,
>Eric M. Jones
aircraft.
Since I've started using an automatic battery maintainer, my plane and cycle batteries
have lasted two to three times as long.
Subject: | starting-only battery |
05/17/2004 09:48:06 AM,
Serialize complete at 05/17/2004 09:48:06 AM
Probably not too many people on the list with "no" electrical system in
their airplane, but perhaps someone here could offer insight..
A friend with a Parakeet bipe (currently no electrical system) wants to
add just a starter & battery to his airplane. He'd like to know about how
much capacity one would need to get at least 3-4 starts out of a battery
then charge it back up when home. I think it's a Cont O-200. Certainly,
it could vary based on how long it takes to start, temperature, etc. But,
I'm just probing for him any stories or suggestions from the group.
It seems the amp-hour ratings decline as the load current increases, so I
don't think one could rely on capacity calculated from the normal Ah
rating.
Anyone out there with just a battery & starter for wiring demands?
Thanks.
Bob Bittner
Is there an alarm system available for exp. aircraft that has been used. I
have a keyed door but, having just installed avionics that has the
equivalent value of the GNP of a developing nation, I'd like to give
potential thieves a better run for their money than some winky door lock.
An audible alarm and potentially activation of strobe and canard flashers
would seem to be a minimu. I assume some "good" solutions have been worked
out but didn't find it in the archives. Ideas?
Chuck, in East Tennessee
Velocity XLRG
From: | "David E. Nelson" <david.nelson(at)pobox.com> |
Subject: | Re: starting-only battery |
Hi Bob,
Can't help the capacity question but I do have thought here: Might I suggest he
carry a small 12 V solar panel (say from JC Whitney) with him just in case no
power source for the charger is available. Maybe also rig it so that it
charges the battery while in flight since he's resticted to day time only
flying.
/\/elson
> rating.
> Thanks.
> Bob Bittner
~~ ** ~~ If you didn't learn anything when you broke it the 1st ~~ ** ~~
time, then break it again.
From: | Dj Merrill <deej(at)thayer.dartmouth.edu> |
Subject: | Re: Alarm System |
> Velocity XLRG
Electrify the door lock for a nice "shocking" surprise? ;-)
Seriously, though, you could probably easily adapt a car alarm,
although I'd be a little concerned about running the battery dead.
-Dj
simple-ideas
easily obscured by
I appreciate Eric's analysis so much, that I'm going
to order some copper clad aluminum wire even if I
end up not using it. I don't necessarily think his
analysis is correct, but even the fact that he made
an ATTEMPT to justify the weight savings on a dollar
savings basis is a watershed event for me. I mean,
how often do you see the adds that scream "SAVE
.08oz for only $18,000!!"
The problem I have with Eric's analysis is that it
doesn't seem to seperate out what the effect of
adding #1 will have. It just sort of lumps the
additional weight in with everything. What I really
want to get at is, "How much more will it cost me in
the long run to use the radio that is #1 heavier?"
I think the best method of analysis would derive
from Bob's experience on the Voyager project. #1
requires #5 of fuel to go around the world. I don't
see the examples of the more business type planes
being as applicable, because by their very nature
spec'd out to fly a lot more.
But the around the world voyager trip. That is a
trip of around 25,000 miles, and five pounds of fuel
is around a gallon. The numbers I hear for the
average GA pilot flight time is about 100hrs/year,
which amounts to a 2hr flight EVERY weekend. With a
200mph plane, that's about 20,000 miles per year.
So, saving a pound will save a gallon of gas a year.
Or about $3 (I'll run mogas. About $2 for me.)
Now, I don't see the typical OBAM aircraft flying
for 30 years in its original configuration. Radios,
tires possibly even engines change. Not only that,
I'm likely to sell it in a decade after my wife gets
tired of me and takes half the plane in the divorce.
Do I really care that the next guy might have a
slightly higher fuel burn? Then there is the high
probability of mother nature or an accident taking
it out. I don't have actuarial data, but I would
put the lifetime of the aircraft at 10 years.
So, how much do you spend to save $30 ($3x10years)?
Funny how my final number came so close to Eric's.
To me, that's a good number. I realize that any
analysis of this type is full of maybe's, what if's
and mostly speculation.
Hey Chuck,
What avionics did you install, and what is your exact address?
JHSF,
Jim
Subject: AeroElectric-List: Alarm System
I
worked
> Velocity XLRG
A few weeks ago I contacted a supplier who had an overstock of 15'
RG400 cables with male BNC connectors and molded strain reliefs (see <
http://webpages.charter.net/jghkah/cables/cables.html >). I bought
more than needed for my plane and sold the extras for $18/cable on the
Matronics RV list. Recently some RV list members asked whether more
cables were available.
The supplier will not be making more but, as of last week, still had
some left and was willing to sell in quantities of 12 or more (with a
significant shipping charge). If enough members of the RV and
AeroElectric would like to purchase these cables at $20 each (plus $5
dollars for shipping up to two cables plus $1 for each additional
cable) I'll order another dozen or so. If you are interested please
email me directly. I'll post a message to both lists next Monday to
let everybody know whether there was sufficient interest to justify the
order and, if so, the expected arrival date.
Jack H.
Subject: | Instrument light dimming |
All,
I am buttoning up my Berkut project for transport to the airport in a few
weeks and in the process tried out the night-flight configuration with the
newly installed canopies. I am using a single B&C dimmer unit to drive all
the instrument and radio lighting.
The mostly incandescent lighting in the radios dims down to almost nothing
and is not a problem. However, the backup 2 1/4" AS and ALT instruments are
powered by the "add-on" glow strip rings that are powered by a DC-AC
inverter. The inverter is hooked up to the same panel dimmer and it does
dim...but not nearly enough. They are still way-to-bright for night ops,
while some radio lights are at about zero illumination.
The question is, how can I achieve additional dimming on those instruments
without sacrificing too much full-bright range? I can stand a little
degradation, but not too much as the blue/green light makes them stand-out
from under the long canopy cover.
James Redmon
Berkut #013 N97TX
http://www.berkut13.com
NACA published this paper in 1924! Much of this will tease out the changes
in performance, range etc. from a weight change. Caution: Not for the
mathematically faint-hearted!
Reliable formulae for estimating airplane performance and the effects of
changes in weight, .....snip... etc.
Diehl, Walter S , Bureau of Aeronautics (Navy) (Washington, DC, United
States) NACA Report 173, 22 pp. , 1924
Abstract: The derivation and the verification of formulae for predicting the
speed range ratio, the initial rate of climb, and the absolute ceiling of an
airplane. Curves used in the computation are given in NACA-TR-171. Standard
formulae for service ceiling, time of climb, cruising range, and endurance
are also given in the conventional forms.
http://naca.larc.nasa.gov/reports/1924/naca-report-173/ (everything you
ever wanted to know about aviation)!
From NACA Technical Note 206: Charles Ward Hall 1924: Structural Weight of
Aircraft as Affected by the System of Design:
"From one point of view-- the pay load--that is, the weight which is to
be transported, whether it be mail or other goods, bombs, or machine
gun bullets, represents the only profitable part of the enterprise. A
May 03, 2004 - May 17, 2004
AeroElectric-Archive.digest.vol-de
