AeroElectric-Archive.digest.vol-dr
November 05, 2004 - November 15, 2004
      On Nov 5, 2004, at 1:51 PM, Robert L. Nuckolls, III wrote:
      >     Dead on accurate analysis sir.
      Thank you Bob.
      >     We've often
      >     heard the adage that a pilot's license is a "license
      >     to learn" but all too often, learning seems to slow
      >     down or even cease.
      >     The FAA is fond of developing new requirements for new
      >     production but allowing older airplanes to "grandfather"
      >     along in their originally certified condition. For the
      >     most part, I agree with this philosophy but with one
      >     exception. If I were made "Emperor for a day" of the FAA,
      >     I'd write a requirement for low voltage warning, periodic
      >     cap tests of batteries -OR- yearly replacement, and
      >     and dual feed e-bus installation for all aircraft that
      >     are used for night-cross-country whether VFR or IFR.
      >     It's probably the simplest change we could make to
      >     any certified ship and would make the vast majority
      >     of electrical system dark-stormy-night stories go away.
      I did in my Comanche.  My "fix" is 20 years old now and my e-buss is
      called the "Avionics buss".  It was easy when we did the new panel back
      in 1984.
      Brian Lloyd                     6501 Red Hook Plaza
      brianl(at)lloyd.com                Suite 201
      +1.340.998.9447                 St. Thomas, VI 00802
      There is a time to laud one's country and a time to protest.  A good
      citizen is prepared to do either as the need arises.
Subject: Re: Driving electronic rpm meter from both magnetos
Date: Nov 05, 2004
On Nov 5, 2004, at 2:36 PM, Scott Aldrich wrote: > > > I am not sure if it has two inputs. I was assuming it only had one > based on > the post by Mark (Fiveonepw) who said his EIS4000 is only on the right > mag. > I could have misunderstood his post. And I certainly *don't* know. Do *not* take my word as gospel on this. > I will check with GRT. That is the correct answer. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Nov 05, 2004
Subject: Re: Another bad story
>And if you are on this list, why would you have an airplane that could >experience a total electrical system failure? Because my RV8 is not yet finished, and my flying club won't let me work on our Pipers. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 05, 2004
Subject: Re: Hangar Radios
In a message dated 11/5/2004 1:42:03 PM Eastern Standard Time, brianl(at)lloyd.com writes: I listen to the BBC on my SSB HF receiver to get the news. They beat the snot out of the US news services for international balance. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 I agree with you Brian on the BBC. Trouble is, it takes me about 30 minutes of listening to tune my mind in and begin to understand the King's English! John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Nov 05, 2004
Subject: Re: Short antenna cable for back of radio
OK, no one has any idea where I can buy a little "patch cable" like the one listed below? I guess I could make one, but when I was running a big IP network, I had a rule that none of my guys were allowed to make cables. Too unreliable. Not sure I want to break this rule with my radio antenna. Thanks, Mickey >I'm looking for a short antenna cable like the one shown >on this web page. > > http://www.rv8.ch/article.php?story=20041104202747822 > >Does anyone know where I can purchase this? -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 05, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net>
You can get a cheap, digitally tuned portable radio and extended the DC power and headphone audio leads from outside to inside via a hunk of 4-wire telephone cable. Wrapped the radio up in two layers of zip-lock plastic bag along with a packet of silica-gel. Install it under a plastic bucket to shield from direct effects if wind and sunlight. At the other end, attached a wall-wart power supply and a set of amplified computer speakers. This keeps all your wiring close to the building and relatively immune from lighting strike issues. Signal strength to the radio is very good and should offer excellent quality audio. Leave it turned on 24/7 and just turn down the volume when you're not listening to it. Bob . . . ________________________________________________________________________________
Date: Nov 05, 2004
Mickey, Since nobody else replied, here's my suggestion. Check with Garmin, or ICOM. My GTX-327 transponder uses a similar plug that comes in either straight, or 90 degree. It is listed in the parts list at the back. I could get you a p/n, but I would think that any avionics shop should be able to get one for you. Mark S. > > >OK, no one has any idea where I can buy a little "patch cable" >like the one listed below? I guess I could make one, but >when I was running a big IP network, I had a rule that none >of my guys were allowed to make cables. Too unreliable. >Not sure I want to break this rule with my radio antenna. > >Thanks, >Mickey > > > >I'm looking for a short antenna cable like the one shown > >on this web page. > > > > http://www.rv8.ch/article.php?story=20041104202747822 > > > >Does anyone know where I can purchase this? > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Nov 05, 2004
In a message dated 11/5/04 9:34:49 AM Central Standard Time, brianl(at)lloyd.com writes: > If any of these things change it > is grounds to wonder what has changed in the engine even if everything > is still within "normal" specs. >>>> Seems I'll be paying closer attention in the future........ Thanks! Mark do not achive ________________________________________________________________________________
Date: Nov 05, 2004
In a message dated 11/5/04 12:38:04 PM Central Standard Time, sa(at)mwutah.com writes: > I am not sure if it has two inputs. I was assuming it only had one based > on > the post by Mark (Fiveonepw) who said his EIS4000 is only on the right mag. > I could have misunderstood his post. >>> My 2002 vintage EIS4000 has only one, which would require a switch and resistor for both p-leads- my unit came with the required resistor for one mag... Mark Phillips ________________________________________________________________________________
Date: Nov 05, 2004
On 11/05 9:47, Mickey Coggins wrote: > OK, no one has any idea where I can buy a little "patch cable" > like the one listed below? I guess I could make one, but > when I was running a big IP network, I had a rule that none > of my guys were allowed to make cables. Too unreliable. > Not sure I want to break this rule with my radio antenna. > > Thanks, > Mickey Making antennas is the absolute easiest thing I've ever done. No satisfaction like doing the work yourself. -- Walter Tondu http://www.rv7-a.com ________________________________________________________________________________
Date: Nov 05, 2004
Subject: Re: 35amp PM alternator
-----Original Message----- This is a fairly old thread (but I remember your comments) . . . but I'm planning my breaker / switches and "rough wiring" for my RV-8. Without Avionics I'm figuring the following night IFR load on approach? Heated Pitot 10A Landing Lights 8A Nav Lights 8A Strobes 8A Panel / Inst Lts 2A Gyros 2A Total 38A I may be a little high but should be close?? What am I doing wrong? Thanks, Bob Christensen Hi Bob Maybe we do things different here in the Great White North but the heated pitot and landing lights are considered as "intermittent" loads (at least on my load analyses) which may exceed the normal continuous rating. The pitot heat would only need to be on if you anticipated icing and the landing light for a very short time before touchdown! George in Langley B.C. ________________________________________________________________________________
Subject: Narco AT150 xponder light
Date: Nov 06, 2004
I'm having a new indication on my transponder (Narco AT150) and wondering if anyone has experienced this before and what (if anything) I can do about it. In the past the interrogator light has always blinked normally when the radar sweep passes it and the transponder has always worked fine. Recently I've noticed the the light blinks much more and flickers as if it's being hit by multiple radar sweeps. This has now gotten worse to the point that sometimes while enroute the light just stays on steady much of the time with occasional bouts of acting normally. I recently talked to ATC while the light was on steady and they said my data block was normal and mode C (ACK A-30) was working ok. In the area of northern Michigan that I generally fly radar sites are few and far between so I'm certain it's not from receiving multiple sweeps. When landing at my very rural grass strip the light is often still full on while taxiing back. I did notice last time when I shut off the engine while master was still on that the light went out even though transponder was still receiving power. So far it's been an intermittent problem, but it appears to have gradually gotten worse. Anybody experienced this? Any input would be appreciated. Thanks, Darrel ________________________________________________________________________________
Subject: Another bad story
Date: Nov 06, 2004
"> AM, were dating our self here!" "were" should be "we're" - apostrophe to represent missing "a". -2 "our self" should be "ourselves" - one word, and plural for "we". -6 2/10 You can do better than this. Miss Thompson, Gr4 ________________________________________________________________________________
Date: Nov 06, 2004
Subject: Ignition Noise Problem
Electric Listers, I am using a Jeff Rose EI in place of the right mag on my 0-360 powered RV8. There is a low level ignition noise that comes trough Com 1 (Garmin 430/ belly ant) and Com 2 (Becker/ wing tip Archer ant) when receiving lower power transmissions. It doesn't break the squelch. It varies with RPM and disappears with the EI off. I have talked to Jeff about this and he maintains that 90% of the time it's the ign leads arching with the less likely possibility being noise from the power lead. I have all of the ign leads isolated from each other by 1/2 "with non conducting material. Using aircraft plugs with gap of .035 as recommended. There is no sign of arching along the cables or inside of the plug barrels. The coil unit is mounted on the firewall with gnd lead to the firewall. The power lead is shielded and the gnd pigtail is grounded to the firewall with the shorter leads from the switch on the instrument panel to the battery buss (cabin side of firewall) also shielded and grounded. Would a power lead noise filter be worth a try in a situation like this? Any other ideas would be appreciated as the noise is irritating. (Definitely do not want to go back to another mag) Thanks Jim Pickrell RV8 N186JP 68 hrs TT ________________________________________________________________________________
Date: Nov 06, 2004
Jim, If at all possible try running the radios from a separate battery power source. This will tell you if the noise is being coupled through RF or power wires. Also check your ground connections.... Regards, Trampas www.sterntech.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of JPickr8358(at)aol.com Subject: AeroElectric-List: Ignition Noise Problem Electric Listers, I am using a Jeff Rose EI in place of the right mag on my 0-360 powered RV8. There is a low level ignition noise that comes trough Com 1 (Garmin 430/ belly ant) and Com 2 (Becker/ wing tip Archer ant) when receiving lower power transmissions. It doesn't break the squelch. It varies with RPM and disappears with the EI off. I have talked to Jeff about this and he maintains that 90% of the time it's the ign leads arching with the less likely possibility being noise from the power lead. I have all of the ign leads isolated from each other by 1/2 "with non conducting material. Using aircraft plugs with gap of .035 as recommended. There is no sign of arching along the cables or inside of the plug barrels. The coil unit is mounted on the firewall with gnd lead to the firewall. The power lead is shielded and the gnd pigtail is grounded to the firewall with the shorter leads from the switch on the instrument panel to the battery buss (cabin side of firewall) also shielded and grounded. Would a power lead noise filter be worth a try in a situation like this? Any other ideas would be appreciated as the noise is irritating. (Definitely do not want to go back to another mag) Thanks Jim Pickrell RV8 N186JP 68 hrs TT ________________________________________________________________________________
Date: Nov 06, 2004
Right on Miss Thompson, now how about your & you're....most evertone gets it wrong. ----- Original Message ----- From: "Fergus Kyle" <VE3LVO(at)rac.ca> Subject: AeroElectric-List: Another bad story > > "> AM, were dating our self here!" > > "were" should be "we're" - apostrophe to represent missing "a". -2 > "our self" should be "ourselves" - one word, and plural for "we". -6 > > 2/10 > You can do better than this. > Miss Thompson, Gr4 > > > ________________________________________________________________________________
Date: Nov 06, 2004
At 02:39 PM 11/6/04, you wrote: > >Right on Miss Thompson, now how about your & you're....most evertone gets it >wrong. And while you're at it, how about flounder and founder? Trembler and temblor? If you understood what he wrote, it was good enough. ________________________________________________________________________________
Date: Nov 07, 2004
Subject: Chapter 7 - Electrical System Instrumentation
Hi, What is the current state of the art for measuring battery and alternator voltage and current, both in terms of technique and products? I've read chapter 7, and I think I understand the theory, and I'd like to put it to practice. My chapter 7 dates from 1992. I think this is the current version. My system will be like Figure 17-6. I see most of the Z figures show a loadmeter for each alternator, but none for the batteries. Why is this? The Z figures show the use of a shunt to measure load. Are Hall Effect systems not preferred yet? Are the typical volt meters included with electronic instruments (Grand Rapids EIS4000, for example) adequate for measuring bus voltage? Many thanks for the info. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 07, 2004
Subject: Re: Chapter 7 - Electrical System Instrumentation
clamav-milter version 0.80j on juliet.albedo.net My chapter 7 also says 1992. If you put a shunt on the battery then it has to be large enough to handle a couple of hundred cranking amps which means not very good resolution down at a couple of amps of battery charging current. It seems that is less of a problem with at least some Hall Effect sensors that are able to withstand large starting overloads. I think a voltmeter with low voltage warning is adequate. Either will indicate whether the battery is charging or discharging but the voltmeter is useful as an early warning for monitoring the voltage regulator. The EIS hall sensor is a bit pricey at $60. but easier to install than a shunt. My EIS unit agrees within 0.2 volt of my digital multimeter and reads to 1/10 of a volt so I consider it as good as anything for practical purposes. Ken Mickey Coggins wrote: > >Hi, > >What is the current state of the art for measuring >battery and alternator voltage and current, both >in terms of technique and products? > >I've read chapter 7, and I think I understand the >theory, and I'd like to put it to practice. My chapter 7 >dates from 1992. I think this is the current version. > >My system will be like Figure 17-6. I see most >of the Z figures show a loadmeter for each alternator, >but none for the batteries. Why is this? > >The Z figures show the use of a shunt to measure load. >Are Hall Effect systems not preferred yet? > >Are the typical volt meters included with electronic >instruments (Grand Rapids EIS4000, for example) adequate >for measuring bus voltage? > >Many thanks for the info. > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Nov 07, 2004
I have hall effect current sensors for about $30, if anyone wants one. I can get them in 25, 50,100, and 200 Amp versions. I do not know about compatibility with Grand Rapids EIS but they will work with Stern Tech's engine monitors. Regards, Trampas www.sterntech.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Subject: Re: AeroElectric-List: Chapter 7 - Electrical System Instrumentation clamav-milter version 0.80j on juliet.albedo.net My chapter 7 also says 1992. If you put a shunt on the battery then it has to be large enough to handle a couple of hundred cranking amps which means not very good resolution down at a couple of amps of battery charging current. It seems that is less of a problem with at least some Hall Effect sensors that are able to withstand large starting overloads. I think a voltmeter with low voltage warning is adequate. Either will indicate whether the battery is charging or discharging but the voltmeter is useful as an early warning for monitoring the voltage regulator. The EIS hall sensor is a bit pricey at $60. but easier to install than a shunt. My EIS unit agrees within 0.2 volt of my digital multimeter and reads to 1/10 of a volt so I consider it as good as anything for practical purposes. Ken Mickey Coggins wrote: > >Hi, > >What is the current state of the art for measuring >battery and alternator voltage and current, both >in terms of technique and products? > >I've read chapter 7, and I think I understand the >theory, and I'd like to put it to practice. My chapter 7 >dates from 1992. I think this is the current version. > >My system will be like Figure 17-6. I see most >of the Z figures show a loadmeter for each alternator, >but none for the batteries. Why is this? > >The Z figures show the use of a shunt to measure load. >Are Hall Effect systems not preferred yet? > >Are the typical volt meters included with electronic >instruments (Grand Rapids EIS4000, for example) adequate >for measuring bus voltage? > >Many thanks for the info. > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Nov 07, 2004
Do you know what their output is? Hopefully, 0-5vdc? If so, I'll take a couple! David ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Chapter 7 - Electrical System Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > I have hall effect current sensors for about $30, if anyone wants one. I can > get them in 25, 50,100, and 200 Amp versions. I do not know about > compatibility with Grand Rapids EIS but they will work with Stern Tech's > engine monitors. > > Regards, > Trampas > www.sterntech.com > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Chapter 7 - Electrical System > Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > > My chapter 7 also says 1992. > > If you put a shunt on the battery then it has to be large enough to > handle a couple of hundred cranking amps which means not very good > resolution down at a couple of amps of battery charging current. It > seems that is less of a problem with at least some Hall Effect sensors > that are able to withstand large starting overloads. I think a voltmeter > with low voltage warning is adequate. Either will indicate whether the > battery is charging or discharging but the voltmeter is useful as an > early warning for monitoring the voltage regulator. The EIS hall sensor > is a bit pricey at $60. but easier to install than a shunt. > > My EIS unit agrees within 0.2 volt of my digital multimeter and reads to > 1/10 of a volt so I consider it as good as anything for practical purposes. > > Ken > > Mickey Coggins wrote: > > > > > >Hi, > > > >What is the current state of the art for measuring > >battery and alternator voltage and current, both > >in terms of technique and products? > > > >I've read chapter 7, and I think I understand the > >theory, and I'd like to put it to practice. My chapter 7 > >dates from 1992. I think this is the current version. > > > >My system will be like Figure 17-6. I see most > >of the Z figures show a loadmeter for each alternator, > >but none for the batteries. Why is this? > > > >The Z figures show the use of a shunt to measure load. > >Are Hall Effect systems not preferred yet? > > > >Are the typical volt meters included with electronic > >instruments (Grand Rapids EIS4000, for example) adequate > >for measuring bus voltage? > > > >Many thanks for the info. > > > >-- > >Mickey Coggins > >http://www.rv8.ch/ > >#82007 QB Wings/Fuselage > > > > ________________________________________________________________________________
Date: Nov 07, 2004
From: Mickey Coggins <mick-matronics(at)rv8.ch> Instrumentation
Instrumentation Instrumentation Thanks for the info. Do people typically install one of these sensors just after the alternator, as in the Aeroelectric Connection Z figures? Mickey At 15:13 07-11-04, Trampas wrote: -----Start of Original Message----- > >I have hall effect current sensors for about $30, if anyone wants one. I can >get them in 25, 50,100, and 200 Amp versions. I do not know about >compatibility with Grand Rapids EIS but they will work with Stern Tech's >engine monitors. > >Regards, >Trampas >www.sterntech.com > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Chapter 7 - Electrical System >Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > > My chapter 7 also says 1992. > >If you put a shunt on the battery then it has to be large enough to >handle a couple of hundred cranking amps which means not very good >resolution down at a couple of amps of battery charging current. It >seems that is less of a problem with at least some Hall Effect sensors >that are able to withstand large starting overloads. I think a voltmeter >with low voltage warning is adequate. Either will indicate whether the >battery is charging or discharging but the voltmeter is useful as an >early warning for monitoring the voltage regulator. The EIS hall sensor >is a bit pricey at $60. but easier to install than a shunt. > >My EIS unit agrees within 0.2 volt of my digital multimeter and reads to >1/10 of a volt so I consider it as good as anything for practical purposes. > >Ken > >Mickey Coggins wrote: > > >> >>Hi, >> >>What is the current state of the art for measuring >>battery and alternator voltage and current, both >>in terms of technique and products? >> >>I've read chapter 7, and I think I understand the >>theory, and I'd like to put it to practice. My chapter 7 >>dates from 1992. I think this is the current version. >> >>My system will be like Figure 17-6. I see most >>of the Z figures show a loadmeter for each alternator, >>but none for the batteries. Why is this? >> >>The Z figures show the use of a shunt to measure load. >>Are Hall Effect systems not preferred yet? >> >>Are the typical volt meters included with electronic >>instruments (Grand Rapids EIS4000, for example) adequate >>for measuring bus voltage? >> >>Many thanks for the info. >> -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: RE:Another bad story
Date: Nov 07, 2004
At the risk of sounding exactly like what I am decrying, I just have to say this... This thread started out with a link to a story from a fellow that had a problem during a night flight. He was man enough to share it, along with what HE did wrong, so that others wouldn't make the same mistakes, and then he expressed the belief that Someone higher than himself made it all come out OK. It was good to bring that link to our attention... we can all learn something from incidents like this. Sadly, at that point the original post got pretty caustic, and even attacked the guy's abilities and beliefs. Subsequent posts in the thread have, for the most part, had barbs in them. Lately we're correcting each other's spelling and grammar... humorous barbs, perhaps? Sure, the whole incident could have been avoided... the guy said so. Sure it was stupid... the guy said so. He thinks prayer helps... so do I... if you don't, that's your right but please leave it at that. So... where's the beef? C'mon people, all that this drivel accomplishes is to discourage the next guy from contributing something that may be very helpful. Who among us wants to take this sort of balderdash for making a confession/comment/whatever that is offered with the sole intention of being helpful? Before starting or perpetuating a negative thread like this, please ask yourself what it will accomplish. Flame away... I'm too old to give a rip :=)) Please don't clobber the list with fire, let's let this thread die... shoot direct at me: Johnny(at)wiktel.com Johnny Johnson Been flying since '62... Done lotza stupid things... And... God has been there lotza times Else... why am I still here? ________________________________________________________________________________
Subject: Chapter 7 - Electrical System Instrumentation clamav-milter
Date: Nov 07, 2004
The sensors sense positive and negative current. The outputs are 0-5V with 0 Amps being 2.5V. These are three wire sensors, ground, +5V, and signal. Placement of the sensor is up to you. I know that some people place on the main battery cable, as over current does not harm the sensors. Others place on alternator wire, while others place have used multiple sensors and placed one on the E-bus. I personally placed 200Amp one on the main battery cable of my car and installed my Pulsar 200. Since the Pulsar 200 operates down to 8V I can measure and record the starter current draw while cranking. However measuring the start current draw is not a real need, I just found it interesting. The only thing to note is that wire diameter size. Which should not be a problem, but often the sensor needs to be installed before the connectors for the wires are crimped on. Regards, Trampas www.sterntech.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of AI Nut Subject: Re: AeroElectric-List: Chapter 7 - Electrical System Instrumentation clamav-milter version 0.80j on juliet.albedo.net Do you know what their output is? Hopefully, 0-5vdc? If so, I'll take a couple! David ----- Original Message ----- From: "Trampas" <tstern(at)nc.rr.com> Subject: RE: AeroElectric-List: Chapter 7 - Electrical System Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > I have hall effect current sensors for about $30, if anyone wants one. I can > get them in 25, 50,100, and 200 Amp versions. I do not know about > compatibility with Grand Rapids EIS but they will work with Stern Tech's > engine monitors. > > Regards, > Trampas > www.sterntech.com > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Chapter 7 - Electrical System > Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > > My chapter 7 also says 1992. > > If you put a shunt on the battery then it has to be large enough to > handle a couple of hundred cranking amps which means not very good > resolution down at a couple of amps of battery charging current. It > seems that is less of a problem with at least some Hall Effect sensors > that are able to withstand large starting overloads. I think a voltmeter > with low voltage warning is adequate. Either will indicate whether the > battery is charging or discharging but the voltmeter is useful as an > early warning for monitoring the voltage regulator. The EIS hall sensor > is a bit pricey at $60. but easier to install than a shunt. > > My EIS unit agrees within 0.2 volt of my digital multimeter and reads to > 1/10 of a volt so I consider it as good as anything for practical purposes. > > Ken > > Mickey Coggins wrote: > > > > > >Hi, > > > >What is the current state of the art for measuring > >battery and alternator voltage and current, both > >in terms of technique and products? > > > >I've read chapter 7, and I think I understand the > >theory, and I'd like to put it to practice. My chapter 7 > >dates from 1992. I think this is the current version. > > > >My system will be like Figure 17-6. I see most > >of the Z figures show a loadmeter for each alternator, > >but none for the batteries. Why is this? > > > >The Z figures show the use of a shunt to measure load. > >Are Hall Effect systems not preferred yet? > > > >Are the typical volt meters included with electronic > >instruments (Grand Rapids EIS4000, for example) adequate > >for measuring bus voltage? > > > >Many thanks for the info. > > > >-- > >Mickey Coggins > >http://www.rv8.ch/ > >#82007 QB Wings/Fuselage > > > > ________________________________________________________________________________
Date: Nov 07, 2004
Subject: Re: RE:Another bad story
Hi Johnny, Perhaps I misread the comments, but I didn't get the impression anyone was trying to slam the guy for his beliefs, but to take him to task for getting himself into that situation. All of us have done stupid things that should have gotten us killed, whether we know it or not. "Why am I still here?" is probably the same question as "why am I here?" I think the overall goal of the comments on the story was to try to get people to use their brains, and save their prayers things that are truly out of their control. Mickey At 17:40 07-11-04, Johnny Johnson wrote: -----Start of Original Message----- > >At the risk of sounding exactly like what I am decrying, I just have to say >this... > >This thread started out with a link to a story from a fellow that had a >problem during a night flight. He was man enough to share it, along with >what HE did wrong, so that others wouldn't make the same mistakes, and then >he expressed the belief that Someone higher than himself made it all come >out OK. > >It was good to bring that link to our attention... we can all learn >something from incidents like this. Sadly, at that point the original post >got pretty caustic, and even attacked the guy's abilities and beliefs. >Subsequent posts in the thread have, for the most part, had barbs in them. >Lately we're correcting each other's spelling and grammar... humorous barbs, >perhaps? > >Sure, the whole incident could have been avoided... the guy said so. Sure >it was stupid... the guy said so. He thinks prayer helps... so do I... if >you don't, that's your right but please leave it at that. So... where's the >beef? > >C'mon people, all that this drivel accomplishes is to discourage the next >guy from contributing something that may be very helpful. Who among us >wants to take this sort of balderdash for making a >confession/comment/whatever that is offered with the sole intention of being >helpful? Before starting or perpetuating a negative thread like this, >please ask yourself what it will accomplish. > >Flame away... I'm too old to give a rip :=)) Please don't clobber the list >with fire, let's let this thread die... shoot direct at me: >Johnny(at)wiktel.com > >Johnny Johnson >Been flying since '62... >Done lotza stupid things... >And... God has been there lotza times >Else... why am I still here? -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 07, 2004
From: Charlie Kuss <chaztuna(at)adelphia.net> Instrumentation
Instrumentation Mickey If you install the inductive sensor on the alternator output (B) wire, the ammeter will not show a negative charge state. By placing the sensor on the battery positive cable, the meter will show both positive and negative charge situations. Charlie Kuss > Instrumentation > >Thanks for the info. Do people typically install one >of these sensors just after the alternator, as in the >Aeroelectric Connection Z figures? > >Mickey > >At 15:13 07-11-04, Trampas wrote: >-----Start of Original Message----- > > > >I have hall effect current sensors for about $30, if anyone wants one. I can > >get them in 25, 50,100, and 200 Amp versions. I do not know about > >compatibility with Grand Rapids EIS but they will work with Stern Tech's > >engine monitors. > > > >Regards, > >Trampas > >www.sterntech.com > > > > > >-----Original Message----- > >From: owner-aeroelectric-list-server(at)matronics.com > >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken > >To: aeroelectric-list(at)matronics.com > >Subject: Re: AeroElectric-List: Chapter 7 - Electrical System > >Instrumentation clamav-milter version 0.80j on juliet.albedo.net > > > > > > My chapter 7 also says 1992. > > > >If you put a shunt on the battery then it has to be large enough to > >handle a couple of hundred cranking amps which means not very good > >resolution down at a couple of amps of battery charging current. It > >seems that is less of a problem with at least some Hall Effect sensors > >that are able to withstand large starting overloads. I think a voltmeter > >with low voltage warning is adequate. Either will indicate whether the > >battery is charging or discharging but the voltmeter is useful as an > >early warning for monitoring the voltage regulator. The EIS hall sensor > >is a bit pricey at $60. but easier to install than a shunt. > > > >My EIS unit agrees within 0.2 volt of my digital multimeter and reads to > >1/10 of a volt so I consider it as good as anything for practical purposes. > > > >Ken > > > >Mickey Coggins wrote: > > > > > >> > >>Hi, > >> > >>What is the current state of the art for measuring > >>battery and alternator voltage and current, both > >>in terms of technique and products? > >> > >>I've read chapter 7, and I think I understand the > >>theory, and I'd like to put it to practice. My chapter 7 > >>dates from 1992. I think this is the current version. > >> > >>My system will be like Figure 17-6. I see most > >>of the Z figures show a loadmeter for each alternator, > >>but none for the batteries. Why is this? > >> > >>The Z figures show the use of a shunt to measure load. > >>Are Hall Effect systems not preferred yet? > >> > >>Are the typical volt meters included with electronic > >>instruments (Grand Rapids EIS4000, for example) adequate > >>for measuring bus voltage? > >> > >>Many thanks for the info. > >> > > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > ________________________________________________________________________________
Date: Nov 07, 2004
Subject: Re: Another bad story.
Before starting or perpetuating a negative thread like this, please ask yourself what it will accomplish. Amen. In a thread like this, I would hope contributors to the list could identify what went wrong and what might have been done (in hind site) to make the event more of a yawner. Even if the answer is simple, let's learn from these things. If the lesson is that someone didn't believe their instruments but should have, and that the experience could have been avoided easily with better redundancy in the electrical system (e.g., as proposed by Bob in his writings), then we should take that lesson and be done with it. I recently queried the Lancair list as to whether a 2600 foot runway was too short for a first flight in an ES. I figured it was too short, and could have offered reasons myself as to why. But I wanted to hear others' opinions. I learned that the majority think it's too short, and some have very strong feelings about why. Many expressed these feelings, along with their reasons. The thread was valuable. Had I thought people would jump on me for asking what some thought was a question with an obvious answer, I would have been more reluctant to ask. Then I might have gone with the the advice of one person I spoke with, who said "2600' is plenty." The person who gave this answer is an outstanding test pilot who knows how to save his bacon as well as anyone. But the thread illuminated risks to the airframe that I've decided aren't worth taking. If we jump on people for sharing their stupid pilot tricks (something we should all concede can happen to us), then valuable threads will go by the wayside. This would be unfortunate. ________________________________________________________________________________
Date: Nov 07, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> Instrumentation
Instrumentation Instrumentation > Instrumentation > >Thanks for the info. Do people typically install one >of these sensors just after the alternator, as in the >Aeroelectric Connection Z figures? Yes . . . hall-effect sensors are directly interchangeable with shunts. Bob . . . ________________________________________________________________________________
Date: Nov 07, 2004
> > >Hi, > >What is the current state of the art for measuring >battery and alternator voltage and current, both >in terms of technique and products? > >I've read chapter 7, and I think I understand the >theory, and I'd like to put it to practice. My chapter 7 >dates from 1992. I think this is the current version. > >My system will be like Figure 17-6. I see most >of the Z figures show a loadmeter for each alternator, >but none for the batteries. Why is this? > >The Z figures show the use of a shunt to measure load. >Are Hall Effect systems not preferred yet? > >Are the typical volt meters included with electronic >instruments (Grand Rapids EIS4000, for example) adequate >for measuring bus voltage? > >Many thanks for the info. Please keep in mind that the Z-figures are crafted to suggest architectures . . . there are many details such as breakers vs. fuses, wire sizes, fuse/breaker sizes, assignment of appliances to specific busses, AND instrumentation technologies that are subject to builder decisions based on mission, preferences and/or pocketbook. The ART of instrumentation is technology based. The lowly ammeter has been with us for over a century . . . and in it's earliest forms worked well as the simple minus-zero-plus battery ammeter common to gazillions of ground based vehicles and a huge percentage of airplanes. The battery ammeter was chosen as the lowest cost, easiest to implement display of electrical system functionality. The the present state of the ART now offers hall effect sensors, digital displays, and system monitoring functions built into devices that have many other functions than to simply monitor the state of the electrical system. The PHILOSOPHY of instrumentation is mission/user based. If as the builder/operator of the airplane, you find usefulness in monitoring and displaying lots of stuff about the electrical system's performance, then the current state of the ART is ready to address your every need/whim. The question you need to consider is, "How and when is knowledge about any particular parameter useful to me?" This should be divided into two categories (1) data useful for comfortable completion of flight and (2) data useful for diagnosing problems on the ground. As to the in-flight phase, I'd be perfectly comfortable with zero displays of either current or voltage from any part of the system assuming that (1) the battery is of known capacity and (2) a dual feedpath e-bus is incorporated and (3) the system is fitted with a low voltage warning light of high integrity for calibration and low probability for un-annunciated failure. This philosophy of system design would have made 90+ percent of all dark-n-stormy night stories concerning electrical systems go away. For example, the most recently discussed story on the list featured a mis-interpretation of readings on an analog instrument that NORMALLY reads zero when everything is working but can also read very near zero when engine driven power generation has failed and the system loads are light. This kind of instrument offers zero active warning and potentially ambiguous readings. When I'm wondering about the close-to-zero reading of the battery ammeter in an old Cessna, I turn on pitot heat or landing light to make sure it STAYS at or near zero meaning that the alternator/generator is picking up new system loads IRRESPECTIVE any reading I might try to get from the instrument's poor calibration. One cannot ignore or mis-interpret a flashing low-volts warning light. Further, when the light does come on, the procedure for dealing with the situation is established by ssytem design of the operating check lists. IF LOW VOLTS WARNING LIGHT IS ON (1) E-BUS ALT FEED switch - On (2) DC PWR MASTER switch - Off (3) E-BUS loads - minimize if practical (4) Continue flight airport with facilities to conveniently effect repairs. How many other instruments, displays, and technologies are . . . (a) Added to cost of ownership of your airplane (b) Added to the weight and complexity of your airplane, (c) Reduce space on the panel needed for potentially more useful things -AND- (d) Add distracting and non-useful data while attempting to deal with a charging system failure in flight . . . are entirely up to you. Beyond the Low Volts Warning light, all other data is useful only for diagnosing the system problem later. Your selection of panel mounted voltmeters and/or ammeters will never provide ALL the data you need to diagnose every problem. So after one has exhibited ho-hum skills for getting back on terra firma with a failure tolerant, user friendly electrical system, one should be able to whip out the trusty multi-meter and be exceptionally skilled at knowing EXACTLY what part needs to be pulled before you remove anything from the airplane. The short answer to your question is: Don't go flying without your trusty LOW VOLTS WARN system -AND- knowing how much fuel you have aboard. After that, put any additional instrumentation in your airplane that strikes your fancy and fits your architecture. The only limitation on the entire field of instrumentation choices is that none of the Z-figures is friendly to use of the classic minus-0-plus battery ammeter. Bob . . . ________________________________________________________________________________
Date: Nov 07, 2004
> >At the risk of sounding exactly like what I am decrying, I just have to say >this... > >This thread started out with a link to a story from a fellow that had a >problem during a night flight. He was man enough to share it, along with >what HE did wrong, so that others wouldn't make the same mistakes, and then >he expressed the belief that Someone higher than himself made it all come >out OK. > >It was good to bring that link to our attention... we can all learn >something from incidents like this. Sadly, at that point the original post >got pretty caustic, and even attacked the guy's abilities and beliefs. >Subsequent posts in the thread have, for the most part, had barbs in them. >Lately we're correcting each other's spelling and grammar... humorous barbs, >perhaps? > >Sure, the whole incident could have been avoided... the guy said so. Sure >it was stupid... the guy said so. He thinks prayer helps... so do I... if >you don't, that's your right but please leave it at that. So... where's the >beef? Yeah, it got a bit out of hand or perhaps out of scope for the mission of sifting real life noise for simple-ideas. The first posting was critical but not harshly so. It was no less that what anyone should expect from a good teacher. I've always encouraged folks to read the dark-n-stormy night stories in the various journals with the eye and mind-set of an accident analyst. One of my most treasured friends and mentor hired me at various times over the last 40 years to assist in his accident analysis business. We sifting the ashes, dug through piles of bent metal, and sort through hundreds of pages of testimony watching for hard data points that would help us describe what happened in terms anyone could understand and without rewriting the laws of physics. In the times I screwed something up, his response was, shall we say, less than comfortable. But the response was appropriate in that it converted the situation into a memorable and never to be repeated event. Let's try to be aware of what our words mean, why they are being written and what value they add to understanding. It's good if we're able to empathise with the folks who share their stories with us . . . that way we can be equally empathetic with respect to appropriate verbal keel hauling. That's the best way to convert that story-teller's situation into a memorable and never to be repeated event. I wonder know how many of you remember Pilot Gomez who's own dark-n-stormy-night story was featured in opening pages of Chapter 17 in the 'Connection. Years after that chapter was published, I got a note from Mr. Gomez who was told about his story being repeated in the 'Connection. He said he was an engineer too . . . and that he was in full agreement with the assessment offered as to the suitability of electrical systems in certified aircraft. He told me he'd purchased an RV kit and was about to get himself unhooked from the world of over-regulated aviation. He ordered a copy of the 'Connection. I should dig back in the records and see if I can contact him again. It would be interesting to see how he's coming along. Let's strive to be good teachers and students and to learn as much as we can from what goes on around us. It's okay to be a stern teacher but let's try to avoid dog-piling onto someone beyond what is necessary to share the simple-ideas that will make their life run smoother and with more confidence. Bob . . . ________________________________________________________________________________
Subject: Dual ignition selection
Date: Nov 08, 2004
Hi Guys, After putting together the dual-ignition distributor and still having the flywheel ignition on board, I pause to wonder. Is it safer to use the distributor for both ignitions or is it better to use one pickup from the distributor and the other from the external electronic flywheel ignition? Do failures occur at the distributor cap or rotor that would push this decision this way or the other? The only ignition failure I've had was the tach pickup on the external and that's been no trouble since replacing it. I'd be interested in opinions on the matter as it's a case for deciding which of two sets of wires to use regularly. Thanks, Larry McFarland - 601HDS - Stratus Subaru ________________________________________________________________________________
Date: Nov 08, 2004
On Nov 7, 2004, at 12:29 PM, Johnny Johnson wrote: I am probably beating the dead horse but since I started this, I feel I should reply. > Sure, the whole incident could have been avoided... the guy said so. > Sure > it was stupid... the guy said so. He thinks prayer helps... so do I... Preparation beats prayer all hollow. One needs to learn and prepare to deal with the daily mundane problems and leave to God those times when the fates conspire to kill you regardless of having done all the right stuff. Or another way of looking at it, I *KNOW* that *I* will be in the cockpit. God might not be my copilot that day. > if > you don't, that's your right but please leave it at that. So... > where's the > beef? The beef is simple. When you decide to become a pilot you take responsibility for the safe operation of your airplane to avoid harm to yourself and others. More than any other endeavor flying requires you to make the right decisions. There is no one else there to help you and no one else to blame. The gentleman's problems were basic and avoidable, problems that, if I thought one of my students couldn't handle, I would not let him or her fly in the pattern, let alone go on a solo cross country. They were all something that I am fairly certain that he was taught how to deal with when learning to fly. He avoided common sense. And, lastly, his stupidity will eventually affect the rest of us by becoming an accident statistic. That will prompt the insurance companies to affect us all in the pocket book or, worst case, it will give the FAA non-flying bureaucrats another nail for the general aviation coffin. That, in a nutshell, is my beef. > C'mon people, all that this drivel accomplishes is to discourage the > next > guy from contributing something that may be very helpful. Who among us > wants to take this sort of balderdash for making a > confession/comment/whatever that is offered with the sole intention of > being > helpful? What he said wasn't helpful. He didn't offer any sort of mechanism for recovery. He did not identify a problem for others to avoid besides, "do what you were taught, believe your instruments, and don't be stupid." Well, boy howdy, how helpful was that? > Before starting or perpetuating a negative thread like this, > please ask yourself what it will accomplish. Hopefully it will accomplish to scare someone like that from flying again until they can come up to speed learning to handle their airplane. It wasn't a mistake, it wasn't a surprise, it wasn't a combination of things that demonstrated a chain of events that would lead to an unusual result; it was just plain old stupidity. Sometimes you have to give someone a dope-slap on the side of the head to get their attention. > Flame away... I'm too old to give a rip :=)) Too bad. We need more people who give a rip. > Please don't clobber the list > with fire, let's let this thread die... shoot direct at me: > Johnny(at)wiktel.com Well, you made the point in a public forum and the public forum is where you talk it out. Unfortunately you don't get to have the last word that way. ;-) > Johnny Johnson > Been flying since '62... > Done lotza stupid things... > And... God has been there lotza times > Else... why am I still here? Perhaps you are here because, ultimately, you made the right decisions when they were needed. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Date: Nov 08, 2004
Subject: ARC/TKM MX300 pinouts needed
Trying to help a homebuilder I sold an MX300 to, does anybody have the pinouts for it? erie ________________________________________________________________________________
Date: Nov 08, 2004
Subject: Re: Dual ignition selection
clamav-milter version 0.80j on juliet.albedo.net The less parts in common, the less the chance of one failure taking out both systems. For instance could it possibly happen that the screws holding one distributor pickup come loose and both distributor pickups are damaged? Ken Larry McFarland wrote: > >Hi Guys, > >After putting together the dual-ignition distributor and still having the flywheel ignition on board, I pause to wonder. Is it safer to use the distributor for both ignitions or is it better to use one pickup from the distributor and the other from the external electronic flywheel ignition? Do failures occur at the distributor cap or rotor that would push this decision this way or the other? > > >The only ignition failure I've had was the tach pickup on the external and that's been no trouble since replacing it. > > >I'd be interested in opinions on the matter as it's a case for deciding which of two sets of wires to use regularly. > > >Thanks, > > >Larry McFarland - 601HDS - Stratus Subaru > > > ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Nov 08, 2004
Subject: Stall Horn
Guys, Does anyone know of a source for a cheap stall warning horn similar in sound to what's used on spam cans? I made my own spam-style stall vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm from Digikey for something like $1 but it sounds like a fire alarm....it's a bit more shrill and shocking than I want. Aircraft Spruce sells a Safe Flight stall horn with light for $740.00. You read that right...$740! That doesn't include the vane. So anyway, if somebody knows of a non-aircraft source for such a beastie please let me know... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring... Sign up for Juno Today at http://www.juno.com! Look for special offers at Best Buy stores. ________________________________________________________________________________
Date: Nov 08, 2004
Subject: Re: Stall Horn
How about a Cessna/Piper/Beech junkyard? I bought a 12V buzzer at Walmart that sounds a lot like a stall horn. How about an auto wrecking yard? My Jeep seatbelt buzzer also sounds like a stall horn. Regards, Matt- VE N34RD, C150 N714BK > > > > Guys, > > Does anyone know of a source for a cheap stall warning horn similar in > sound to what's used on spam cans? I made my own spam-style stall > vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm > from Digikey for something like $1 but it sounds like a fire > alarm....it's a bit more shrill and shocking than I want. Aircraft > Spruce sells a Safe Flight stall horn with light for $740.00. You read > that right...$740! That doesn't include the vane. So anyway, if > somebody knows of a non-aircraft source for such a beastie please let me > know... > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D wiring... > > Sign up for Juno Today at http://www.juno.com! > Look for special offers at Best Buy stores. > > ________________________________________________________________________________
Date: Nov 08, 2004
From: HAL KEMPTHORNE <hal_kempthorne(at)sbcglobal.net>
Brian Lloyd wrote: What he said wasn't helpful. He didn't offer any sort of mechanism for recovery. He did not identify a problem for others to avoid besides, "do what you were taught, believe your instruments, and don't be stupid." Well, boy howdy, how helpful was that? Helpful to some, Brian. I've never believed that imaginary friends would help me but I have had some similar beliefs that could have gotten me trouble. For example I have found myself believing that a machine would somehow "get better" or maybe even "heal up". It works for my body so why not for my machine? Well, it doesn't, usually. I suspect that such silly beliefs have been a factor in aircraft accidents. Maybe even more common is a belief in 'Lady Luck' or just simply luck. I was approaching San Jose International at night many years ago with very low fuel. I had used one tank down to where I figured I had a little left and was flying on the fuller tank. Well before I got over the city it occured to me that if this tank runs out, I might not have enough left in the other to go anywhere. But I crossed my fingers and got in alright. K. H. (Hal) Kempthorne RV6-a N7HK - Three trips to OSH now. PRB (El Paso de Robles, CA) ________________________________________________________________________________
Date: Nov 08, 2004
Subject: Ammeter/Loadmeter
Bob: What do you mean when you say "The only limitation on the entire field of instrumentation choices is that none of the Z-Figures is friendly to use of the classic minus-0-plus battery ammeter"? I am wiring to Figure Z-10 and where you call for a loadmeter I have installed Van's "classic" -40/0/+40 ammeter. Should I change something? I haven't lit the engine yet. Pete Hunt RV-6, finishing wiring Clearwater, FL ________________________________________________________________________________
Date: Nov 08, 2004
Subject: Re: Ammeter/Loadmeter
My appendix doesn't have a Figure Z-10... Where in the circuit does Z-10 have the loadmeter shunt located? Is it between the battery and the rest of the system (doubt that). Bob likes the architecture where the alternator B lead (power output) is wired to a shunt, and then directly to the battery side of the starter contactor. This allows the somewhat noisy alternator output to use the starter wire as its connection to the battery, and thus to have the lowest resistance path to the best noise filter in the airplane. A downside of this architecture is that you don't have any visibility (if this is the only instrumentation) of whether the battery is getting charged (or discharged). The shunt will only give an indication of how much current the alternator is providing. The loadmeter would only provide a negative reading if the alternator fails (and shorts somehow). This architecture combined with a bus voltmeter is perfectly adequate... If the bus voltage is good, and the loadmeter is up, everything is okay. Placing the shunt between the battery and the rest of the system will either require a high amperage shunt/ammeter (to handle hundreds of amps of cranking current), or you can just live with the ammeter peggin (hard) when you crank the starter - plus some heat buildup in the shunt. Regards, Matt- > > Bob: > > What do you mean when you say "The only limitation on the entire field > of instrumentation choices is that none of the Z-Figures is friendly to > use of the classic minus-0-plus battery ammeter"? I am wiring to > Figure Z-10 and where you call for a loadmeter I have installed Van's > "classic" -40/0/+40 ammeter. Should I change something? I haven't lit > the engine yet. > > Pete Hunt > RV-6, finishing wiring > Clearwater, FL > > ________________________________________________________________________________
From: "earl_schroeder(at)juno.com" <earl_schroeder(at)juno.com>
Date: Nov 09, 2004
I'll throw out another idea suggested by Jim Weir. I used a 0-50MV meter to indicate current flow by connecting it to each end of wire I wished to measure by looking at the voltage drop across the wire. I didn't care about the absolute value but only if it was other than normal. To prevent 'slamming' the meter during starting I installed a miniature relay in the sensing line which opens when power is applied to the starter solenoid. By selecting an appropriate resistor installed in parallel with the meter and a switch labeled X1 - X10 I was able to select the most sensitive position depending on what I have turned on. (like pitot heat or not) I have two meters: one for battery current and the other for alternator. So far this method has worked fine for me. Earl ________________________________________________________________________________
Subject: GRT EFIS/Engine Monitor/Moving Map yahoo list
Date: Nov 09, 2004
FYI for those interested in some common space to share and learn info about the Grand Rapids Tech EFIS, Graphic Engine Monitoring and Moving Map Display system. http://www.grtavionics.com/ * Your group information: Group name: GRT_EFIS Group home page: http://groups.yahoo.com/group/GRT_EFIS Group email address: http://mailcenter2.comcast.net/wmc/v/wm/41901FE5000DB8410000389A2200748184970C0E0397050C9A04?cmd=ComposeTo&adr=GRT%5FEFIS%40yahoogroups%2Ecom&sid=c0 FYI for those interested in some common space to share and learn info about the Grand Rapids Tech EFIS, Graphic Engine Monitoring and Moving Map Display system. http://www.grtavionics.com/ >http://www.grtavionics.com/ * Your group information: Group name: GRT_EFIS Group home page: http://groups.yahoo.com/group/GRT_EFIS >http://groups.yahoo.com/group/GRT_EFIS Group email address: http://mailcenter2.comcast.net/wmc/v/wm/41901FE5000DB8410000389A2200748184970C0E0397050C9A04?cmd=ComposeToadr=GRT_EFIS@yahoogroups.comsid=c0 onclick="return doCompose(this);" ">http://mailcenter2.comcast.net/wmc/v/wm/41901FE5000DB8410000389A2200748184970C0E0397050C9A04?cmd=ComposeToadr=GRT%5FEFIS%40yahoogroups%2Ecomsid=c0 ________________________________________________________________________________
Subject: ELT Access
Date: Nov 08, 2004
11/08/2004 Hello Bob Nuckolls and Other Electricals, I am trying to nail down the regulatory requirement for pilot access to and control of ELTs from the cockpit while airborne. The ELT TSO-C91a does not contain the requirement itself, but I have been told that the requirement can be found in one of these two RTCA documents which are referenced by the TSO. DO-183, Minimum Operational Performance Standards for Emergency Locator Transmitters-Automatic Fixed-ELT (AF), Automatic Portable-ELT (AP), Automatic Deployable-ELT (AD), Survival-ELT (S) Operating on 121.5 and 243.0 Megahertz DO-182, Emergency Locator Transmitter (ELT) Equipment Installation and Performance Unfortunately these two documents from the RTCA cost money. Would anyone have access to these documents and be willing to help me locate the specific access requirement (if it exists)? Many thanks. OC ________________________________________________________________________________
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
Subject: RE: ELT Access
Date: Nov 09, 2004
A review of FARs 91.205 (Equipment requirements) and 91.207 (ELTs) shows no requirement for pilot access or control of an ELT. The documents you mention are, I believe, performance specifications, not regulations. Dennis Glaeser > 11/08/2004 ------------------- Hello Bob Nuckolls and Other Electricals, I am trying to nail down the regulatory requirement for pilot access to and control of ELTs from the cockpit while airborne. The ELT TSO-C91a does not contain the requirement itself, but I have been told that the requirement can be found in one of these two RTCA documents which are referenced by the TSO. DO-183, Minimum Operational Performance Standards for Emergency Locator Transmitters-Automatic Fixed-ELT (AF), Automatic Portable-ELT (AP), Automatic Deployable-ELT (AD), Survival-ELT (S) Operating on 121.5 and 243.0 Megahertz DO-182, Emergency Locator Transmitter (ELT) Equipment Installation and Performance. Unfortunately these two documents from the RTCA cost money. Would anyone have access to these documents and be willing to help me locate the specific access requirement (if it exists)? Many thanks. OC ---------------------------------------------- ________________________________________________________________________________
From: "Olivier Le Carbonnier" <olcdlm(at)laposte.net>
Subject: Stall Horn
Date: Nov 09, 2004
why not a AOA ? Olivier LC France ICQ#: 82067330 sanglier(at)laposte.net http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings -----Message d'origine----- De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de czechsix(at)juno.com Envoy : lundi 8 novembre 2004 19:34 : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com Objet : AeroElectric-List: Stall Horn Guys, Does anyone know of a source for a cheap stall warning horn similar in sound to what's used on spam cans? I made my own spam-style stall vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm from Digikey for something like $1 but it sounds like a fire alarm....it's a bit more shrill and shocking than I want. Aircraft Spruce sells a Safe Flight stall horn with light for $740.00. You read that right...$740! That doesn't include the vane. So anyway, if somebody knows of a non-aircraft source for such a beastie please let me know... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring... Sign up for Juno Today at http://www.juno.com! Look for special offers at Best Buy stores. ________________________________________________________________________________
Date: Nov 09, 2004
My thought too, but thath was not what the question was. Also if $740 is a lot of money, $800+ is more ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Stall Horn
Not cheap... I have seen them start at $600. MAP > > > why not a AOA ? > > Olivier LC > France > ICQ#: 82067330 > sanglier(at)laposte.net > http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings > > -----Message d'origine----- > De : owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de > czechsix(at)juno.com > Envoy : lundi 8 novembre 2004 19:34 > : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com > Objet : AeroElectric-List: Stall Horn > > > > > > Guys, > > Does anyone know of a source for a cheap stall warning horn similar in > sound to what's used on spam cans? I made my own spam-style stall > vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm > from Digikey for something like $1 but it sounds like a fire > alarm....it's a bit more shrill and shocking than I want. Aircraft > Spruce sells a Safe Flight stall horn with light for $740.00. You read > that right...$740! That doesn't include the vane. So anyway, if > somebody knows of a non-aircraft source for such a beastie please let me > know... > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D wiring... > > Sign up for Juno Today at http://www.juno.com! > Look for special offers at Best Buy stores. > > ________________________________________________________________________________
Subject: RE: Another bad story
Date: Nov 09, 2004
Hi Brian, I wasnt trying to pick a fight here, but you got my hackles up a bit so I ll respond. You say we should keep the discourse public--fine for now to the rest of you, my apologies. My point--that I apparently didnt make very well--was simply that deriding someone in public does no good, and in fact will discourage others from contributing. That our victim didnt format it in a way that pleased you is unfortunate, but please give us credit for being smart enough to get the message. You make several excellent points about the situation, but I humbly submit, sir, that you are not the only one in this old world with discernment or insight. IMHO it simply was not necessary to drag this guy thru the brambles in public--it should have been done privately, if at all. You have a different God than I do if you believe that He might not be there that day that preparation beats prayer all hollow that the fates conspire but thats your right. Ive been shot at--have you? I KNOW that Im here because of the intervention--on more than one occasion--by Someone larger than myself, not because of making the right decisions, not because of luck or beating the odds or having great skill. You can rationalize it any way you want, lecture me all you want, but you wont change my mind. If you could have been in the cockpit with me, I think you would look at things a little differently today--twas single seat or I would have invited you along :=) Ive been pretty blunt, on purpose. Please understand that none of this is intended to be a personal attack on your knowledge or integrity or any of that good stuff. We disagree on style and apparently on core beliefs Im simply calling it like I see it, without fluff. I trust it will be taken in that spirit. Regards, Johnny Johnson Johnny(at)wiktel.com From: Brian Lloyd <brianl(at)lloyd.com> Subject: Re: AeroElectric-List: RE:Another bad story On Nov 7, 2004, at 12:29 PM, Johnny Johnson wrote: I am probably beating the dead horse but since I started this, I feel I should reply. > Sure, the whole incident could have been avoided... the guy said so. > Sure > it was stupid... the guy said so. He thinks prayer helps... so do I... Preparation beats prayer all hollow. One needs to learn and prepare to deal with the daily mundane problems and leave to God those times when the fates conspire to kill you regardless of having done all the right stuff. Or another way of looking at it, I *KNOW* that *I* will be in the cockpit. God might not be my copilot that day. > if > you don't, that's your right but please leave it at that. So... > where's the > beef? The beef is simple. When you decide to become a pilot you take responsibility for the safe operation of your airplane to avoid harm to yourself and others. More than any other endeavor flying requires you to make the right decisions. There is no one else there to help you and no one else to blame. The gentleman's problems were basic and avoidable, problems that, if I thought one of my students couldn't handle, I would not let him or her fly in the pattern, let alone go on a solo cross country. They were all something that I am fairly certain that he was taught how to deal with when learning to fly. He avoided common sense. And, lastly, his stupidity will eventually affect the rest of us by becoming an accident statistic. That will prompt the insurance companies to affect us all in the pocket book or, worst case, it will give the FAA non-flying bureaucrats another nail for the general aviation coffin. That, in a nutshell, is my beef. > C'mon people, all that this drivel accomplishes is to discourage the > next > guy from contributing something that may be very helpful. Who among us > wants to take this sort of balderdash for making a > confession/comment/whatever that is offered with the sole intention of > being > helpful? What he said wasn't helpful. He didn't offer any sort of mechanism for recovery. He did not identify a problem for others to avoid besides, "do what you were taught, believe your instruments, and don't be stupid." Well, boy howdy, how helpful was that? > Before starting or perpetuating a negative thread like this, > please ask yourself what it will accomplish. Hopefully it will accomplish to scare someone like that from flying again until they can come up to speed learning to handle their airplane. It wasn't a mistake, it wasn't a surprise, it wasn't a combination of things that demonstrated a chain of events that would lead to an unusual result; it was just plain old stupidity. Sometimes you have to give someone a dope-slap on the side of the head to get their attention. > Flame away... I'm too old to give a rip :=)) Too bad. We need more people who give a rip. > Please don't clobber the list > with fire, let's let this thread die... shoot direct at me: > Johnny(at)wiktel.com Well, you made the point in a public forum and the public forum is where you talk it out. Unfortunately you don't get to have the last word that way. ;-) > Johnny Johnson > Been flying since '62... > Done lotza stupid things... > And... God has been there lotza times > Else... why am I still here? Perhaps you are here because, ultimately, you made the right decisions when they were needed. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Low Voltage Warning Light
Bob, Is there a simple schematic for a low voltage warning light for an All-Electric on a Budget system with an externally regulated alternator and a generic (Ford?) voltage regulator? Can't find one in the Connection or on your site, or at least haven't recoginized it. Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Re: Garmin GPS antenna
In a message dated 11/3/04 8:02:31 AM Eastern Standard Time, harley(at)AgelessWings.com writes: Harley, Thanks again for the info. The new antenna from gpsgeek works great! And it sure beats the price of the Garmin. Dale Ensing > First, it's not just an antenna...it's also an amplifier of sorts. But, > if it really is faulty, it may be a better choice to get one of these > units instead of Garmin...I think you'll find they are basically the > same thing. > > http://www.gpsgeek.com/page3.html > > ________________________________________________________________________________
Date: Nov 09, 2004
Evenin', Dale... You're welcome! Glad it worked for you... Now that you've tested it, I know what to do if I ever run into that problem! H. DWENSING(at)aol.com wrote: > >In a message dated 11/3/04 8:02:31 AM Eastern Standard Time, >harley(at)AgelessWings.com writes: > >Harley, >Thanks again for the info. The new antenna from gpsgeek works great! And it >sure beats the price of the Garmin. >Dale Ensing > > > >>First, it's not just an antenna...it's also an amplifier of sorts. But, >>if it really is faulty, it may be a better choice to get one of these >>units instead of Garmin...I think you'll find they are basically the >>same thing. >> >>http://www.gpsgeek.com/page3.html >> >> >> >> > > > > ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Re: Low Voltage Warning Light
> >Bob, > >Is there a simple schematic for a low voltage warning light for an >All-Electric on a Budget system with an externally regulated alternator >and a generic (Ford?) voltage regulator? Can't find one in the >Connection or on your site, or at least haven't recoginized it. Sure. See: http://aeroelectric.com/articles/lvwarn/LVWarn-ABMM.html http://aeroelectric.com/articles/lvwarn/9021-620.pdf Bob . . . ________________________________________________________________________________
Date: Nov 09, 2004
Subject: Re: RE: ELT Access
> > >A review of FARs 91.205 (Equipment requirements) and 91.207 (ELTs) shows no >requirement for pilot access or control of an ELT. The documents you >mention are, I believe, performance specifications, not regulations. > > Dennis Glaeser Thank you sir, I was going to say the same thing but didn't get to it before you did. Bob . . . ________________________________________________________________________________
Date: Nov 09, 2004
> > >My appendix doesn't have a Figure Z-10... Where in the circuit does >Z-10 have the loadmeter shunt located? Z-10 (and all latest z-figures are always available at http://www.aeroelectric.com/articles/Appendix_Z_Drawings in both ACAD .dwg format and .pdf Adobe format. Figure Z-10, as do all 'Connection Z-figures, suggests loadmeters because they're friendly to the recommended architectures that avoid bringing the alternator b-lead into the cockpit. >Is it between the battery and the >rest of the system (doubt that). Bob likes the architecture where the >alternator B lead (power output) is wired to a shunt, and then directly to >the >battery side of the starter contactor. This allows the somewhat noisy >alternator output to use the starter wire as its connection to the >battery, and >thus to have the lowest resistance path to the best noise filter in the >airplane. >A downside of this architecture is that you don't have any visibility (if >this is >the only instrumentation) of whether the battery is getting charged (or >discharged). The shunt will only give an indication of how much current >the alternator is providing. The loadmeter would only provide a negative >reading >if the alternator fails (and shorts somehow). This architecture combined >with >a bus voltmeter is perfectly adequate... If the bus voltage is good, and the >loadmeter is up, everything is okay. > >Placing the shunt between the battery and the rest of the system will either >require a high amperage shunt/ammeter (to handle hundreds of amps of >cranking current), or you can just live with the ammeter peggin (hard) when >you crank the starter - plus some heat buildup in the shunt. Given that voltmeters, and all forms of ammeters are at best, diagnostic tools, the probability of comfortable completion of any flight hinges more on knowing when the alternator quits and knowing how well the battery will run the system for the remainder of flight are key data points. Assuming one has active notification of low voltage, there is no operational "advantage" to be achieved by installing a minus-0-plus ammeter as opposed to a loadmeter. Matt correctly notes that adding a battery ammeter to any of the z-figures requires a huge shunt and instrument immune to starter current loads. In my never humble opinion, increases weight and cost with zero return on investment. Bob . . . ________________________________________________________________________________
Date: Nov 09, 2004
> >Bob: > >What do you mean when you say "The only limitation on the entire field of >instrumentation choices is that none of the Z-Figures is friendly to use >of the >classic minus-0-plus battery ammeter"? I am wiring to Figure Z-10 and where >you call for a loadmeter I have installed Van's "classic" -40/0/+40 ammeter. >Should I change something? I haven't lit the engine yet. The ammeter you have was originally intended for installation as a battery-ammeter in the historically popular automotive electrical system architecture. You can wire this instrument as an alternator loadmeter just keep in mind that it will ALWAYS read zero and above. Not a 'bad' thing, it simply tosses off half of the useful scale of the instrument. The danger is that some individual not familiar with how it's used may believe it to be a battery-ammeter based on it's markings . . . and might mis-interpret what it's saying. For example, after an hour of flight, your loadmeter is going to read present load on the alternator which is always a positive value. Another pilot might become concerned when what he perceives as a battery-ammeter never goes to zero indicating the battery is charged. The important thing is that YOU understand how it should function so that you can properly interpret what it tells you. Bob . . . ________________________________________________________________________________
From: "Kingsley Hurst" <khurst(at)taroom.qld.gov.au>
Subject: Grounding
Date: Nov 10, 2004
Bob, I will have my battery forward of the firewall and within 200mm (8") of the engine ground stud. I will also have a firewall ground kit (B&C) on the composite firewall no more than 300mm (12") from the battery. Assuming all cables will be properly restrained, in connecting up the earth straps which routing method would you prefer? 1) Battery -ive to Firewall Gnd to Engine Gnd or 2) Battery -ive to Engine Gnd to Firewall Gnd or 3) Battery -ive to Firewall Gnd and another Battery -ive to Engine Gnd Left to my own devices I would choose No 2 because I think it is the most likely way to prevent the smoking behind the panel problem you cited in the 'connection'. Also, I think I would use a continuous strap with a third flag terminal somewhere in the middle so that in the event of the connection at the engine coming loose, I would still have battery power. I am well aware that losing battery power in my little VFR aircraft would not really matter, nevertheless, if there is such a thing as 'best practice' in this regard, I would prefer to adopt it. Thank you in anticipation Kingsley Hurst Europa Mono Classic 281 in Oz. ________________________________________________________________________________
Subject: Re: ELT
Date: Nov 09, 2004
From: "Giffen A. Marr" <GAMarr(at)Charter.Net> Date: 2004/11/09 Tue PM 07:34:41 EST Subject: ELT <> 11/09/2004 Hello Giff, Thanks for your response. My question about the regulatory requirements for pilot access to or control of the ELT while in flight are not answered by FAR Sec. 91.207. The audit trail goes like this: 1) FAR Sec. 91.207 (a) (1) says that one must have an *approved* ELT for our operations (with some exceptions). In FAA parlance that means approved by the FAA Administrator. 2) There are other ways of having the FAA Administrator (or his authorized representative) approve things, but the TSO process is the most commonly recognized way. 3) TSO-C91 is rendered obsolete for new installations after June 21, 1995 by FAR Sec. 91.207 (a) (1). 4) TSO-C91a is the currently effective TSO for ELTs. One must either have an ELT that meets TSO-C91a or have an ELT that has been approved by the FAA Administrator by some other means. 5) TSO-C91a, like so many other TSOs, is a bare shell of a document that provides no meat within itself, but instead provides references to other documents that are the real guts of the TSO. 6) Without access to the pertinent referenced documents the answer to my question is unknown. I am unwilling to accept all the hearsay, gossip, and rumor that so many people are willing to put forward on this subject. I want to see the applicable portions of the referenced documents for myself. OC ________________________________________________________________________________
Subject: Stall Horn
Date: Nov 10, 2004
where ? Olivier -----Message d'origine----- De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt Prather Envoy : mardi 9 novembre 2004 21:19 : aeroelectric-list(at)matronics.com Objet : RE: AeroElectric-List: Stall Horn Not cheap... I have seen them start at $600. MAP > > > why not a AOA ? > > Olivier LC > France > ICQ#: 82067330 > sanglier(at)laposte.net > http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings > > -----Message d'origine----- > De : owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de > czechsix(at)juno.com > Envoy : lundi 8 novembre 2004 19:34 > : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com > Objet : AeroElectric-List: Stall Horn > > > > > > Guys, > > Does anyone know of a source for a cheap stall warning horn similar in > sound to what's used on spam cans? I made my own spam-style stall > vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm > from Digikey for something like $1 but it sounds like a fire > alarm....it's a bit more shrill and shocking than I want. Aircraft > Spruce sells a Safe Flight stall horn with light for $740.00. You read > that right...$740! That doesn't include the vane. So anyway, if > somebody knows of a non-aircraft source for such a beastie please let me > know... > > Thanks, > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D wiring... > > Sign up for Juno Today at http://www.juno.com! > Look for special offers at Best Buy stores. > > ________________________________________________________________________________
Subject: Re: RE: Another bad story
Date: Nov 10, 2004
On Nov 9, 2004, at 4:38 PM, Johnny Johnson wrote: > > > Hi Brian, > > I wasnt trying to pick a fight here, but you got my hackles up a bit > so I > ll respond. You say we should keep the discourse public--fine for now > to > the rest of you, my apologies. I am not trying to pick a fight either. I apologize for getting your hackles up. > My point--that I apparently didnt make very well--was simply that > deriding > someone in public does no good, and in fact will discourage others from > contributing. That our victim didnt format it in a way that pleased > you is > unfortunate, but please give us credit for being smart enough to get > the > message. You make several excellent points about the situation, but I > humbly submit, sir, that you are not the only one in this old world > with > discernment or insight. IMHO it simply was not necessary to drag this > guy > thru the brambles in public--it should have been done privately, if at > all. Hmm, he chose to make it public by submitting it to a very large public forum. His behavior affects us all. I apologize if you think I was too harsh. Unfortunately I live in a world where my flying, something very important to me, is controlled by the whims of government bureaucrats who know nothing of flying. They believe that their job is to make flying safe at all costs. Since flying is not inherently safe but is rendered safe by the proper attitudes and responses of the people operating the airplanes, I get powerfully annoyed when people operate an aircraft in a stupid and unsafe manner. The bureaucrats are eventually going to figure out that perfect safety occurs when there are no aircraft flying. That meets their stated goals but I don't believe it meets mine. > You have a different God than I do if you believe that He might not be > there that day that preparation beats prayer all hollow that the fates > conspire but thats your right. I have had prayers that, for whatever reason, have gone unanswered. I do not pretend to know or understand the wisdom of God. Since I have no control over that aspect of life I focus on the things that I *CAN* control. At no point did the gentleman in question need divine intervention to solve his problem. All his problems would have been solved by doing what he was taught in the beginning. > Ive been shot at--have you? Not that I believe that this is germane to the issue but, no. I have had the muzzle of a gun placed in my face and I was fairly sure that I was experiencing the last moments of my life. I have also faced life-threatening situations, many in the cockpit of an airplane. When one penetrates an embedded CB, one prays (yes, prays) that the AI doesn't tumble because flying partial-panel in that situation would probably lead to an end-of-life experience equal to that of being shot with the exception that I would have minutes to contemplate the end. I only hope that, should something like that happen, I will still be trying to fly the airplane right up to the end. That said, I do believe that I have met the challenges that life has handed me and acquitted myself acceptably ... so far. > I KNOW that > Im here because of the intervention--on more than one occasion--by > Someone > larger than myself, not because of making the right decisions, not > because > of luck or beating the odds or having great skill. You can > rationalize it > any way you want, lecture me all you want, but you wont change my > mind. If > you could have been in the cockpit with me, I think you would look at > things > a little differently today--twas single seat or I would have invited > you > along :=) And I would have liked to have gone along. The end of the Vietnam war and the first Arab oil embargo convinced me that things were not going to be all that interesting in the USAF for a pilot so I got out. I am not interested in changing your mind. I would just like to see people take responsibility for what they can change and not depend on God to save their sorry ass when they have failed to do what they should have done. Yes, I hope and pray for divine intervention when I desperately need it. OTOH, I hope and pray that I have done all I can to avoid the need for divine intervention. You know, that is what this list is all about: preparation so as to avoid the need for divine intervention. This is a very good thing. > Ive been pretty blunt, on purpose. Blunt is good. I like blunt as you no doubt have deduced. > Please understand that none of this is > intended to be a personal attack on your knowledge or integrity or any > of > that good stuff. No worries. I will be happy to buy the first round should we meet. > We disagree on style and apparently on core beliefs Im > simply calling it like I see it, without fluff. I trust it will be > taken in > that spirit. Which spirit do you prefer: beer, wine, or whisky? :-) > Regards, > Johnny Johnson > Johnny(at)wiktel.com > Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Subject: Re: RE: Hmmmm...
Date: Nov 10, 2004
On Nov 10, 2004, at 8:07 AM, Johnny Johnson wrote: > > > The missile I lobbed yesterday was edited somehow, probably by > automatic > stripping of MS Word formatting?? Most punctuation was gone--it looks > pretty corny. The missile I was replying to was fine for some reason. You should try to make sure that your mail program is sending plain text, not HTML, RTF, or MS-anything. Matronics strips anything that could possibly carry a virus or worm. If you prepare your messages using MS-word you will most likely give your recipients formatting heartburn. Plain text is understood by every email system in the world. MS-word is far less universal. > And this was in the header, I didn't put it there. Wonder what > that's all > about? I didn't think this was about winning or losing. > My guess is that this is part of the SPAM identification system, the most common being Spamassassin. It has many rules looking for key words, phrases, and patterns. When you get enough of them it decides the message is SPAM. You had a low probability phrase in your text, probably, "who really wins," which matched so it assigned a value of 0.09 to it. Spamassassin usually requires the message to achieve a score of 5 to be deemed SPAM. > > This thread has died as far as I'm concerned, much to the relief of > many I'm > sure. My apologies to all of you for venting. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Subject: ELT Access
Date: Nov 10, 2004
AeroElectric-List message previously posted by: "Glaeser, Dennis A" <> 11/10/2004 Hello Dennis (and Bob Nuckolls), Thank you for your inputs. Dennis, you are right. The answer to the question of what is the specific regulatory requirement for pilot access to and control of the ELT while airborne cannot be found in either FAR Sections 91.205 or 91.207. But if the requirement for that access and control is contained in the references to TSO-C91a and the basis for the *approved* ELT, that you are required to have in your aircraft per FAR Sec 91.207, is TSO-C91a then you must by regulation meet that requirement. I am not satisfied with hearsay, gossip, rumor, beliefs, or speculation. These are readily available very cheap and I can generate my own. They do not resolve the issue. The requirement either exists in black and white print or it does not and I feel an obligation to know the facts. The facts are not in readily available US Govt documents, but are instead contained (or not) in references provided by an independent standards organization, the RTCA. The closest that I have been able to come to these references is these two titles: DO-183, Minimum Operational Performance Standards for Emergency Locator Transmitters-Automatic Fixed-ELT (AF), Automatic Portable-ELT (AP), Automatic Deployable-ELT (AD), Survival-ELT (S) Operating on 121.5 and 243.0 Megahertz DO-182, Emergency Locator Transmitter (ELT) Equipment Installation and Performance OC PS: This issue may come up when the initial airworthiness inspector of your amateur built experimental aircraft insists that you have such access and control over your ELT because it is *required by regulations* or he will not grant the airworthiness certificate. Is he correct? ________________________________________________________________________________
Subject: RE: ELT
Date: Nov 10, 2004
Hi OC- > 5) TSO-C91a, like so many other TSOs, is a bare shell of a document that provides > no meat within itself, but instead provides references to other documents that > are the real guts of the TSO. FWIW, the EDMO wesite says: A remote panel control switch with visual activation monitor, previously an optional accessory, is now required in all (AF) automatic fixed installations and many of the (AP) automatic portable installations, is now included in the complete kits. My installation manual from Ameri- King says: NOTE: The Remote Unit is Required by C91a. It is not optional. My local fed says: Where is the remote control for the ELT? You know that's required now... > 6) Without access to the pertinent referenced documents the answer to my question > is unknown. I am unwilling to accept all the hearsay, gossip, and rumor that > so many people are willing to put forward on this subject. I want to see the > applicable portions of the referenced documents for myself. > > OC If you still must see the source document (DO-183), it is available from RTCA for $48, plus shipping and handling. Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Stall Horn
I'll take this opportunity to correct myself a bit.. Aircraft spruce has a vane style unit for $545 here:
http://www.aircraftspruce.com/catalog/inpages/aoartangle.php It seems they pretty much go up from there. Another option, depending on how much cool stuff you are going to put in the panel is the Dynon EFIS. They are having some teething trouble, but I think they'll sort it out. They offer an AOA pitot probe for $200 (only works with their EFIS). The total cost would be about $2600 which while a pretty good value is not cheap. http://www.aircraftspruce.com/catalog/avpages/efisd10.php Matt- > > > where ? > > Olivier > > -----Message d'origine----- > De : owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt > Prather > Envoy : mardi 9 novembre 2004 21:19 > : aeroelectric-list(at)matronics.com > Objet : RE: AeroElectric-List: Stall Horn > > > > > Not cheap... I have seen them start at $600. > > MAP > >> >> >> why not a AOA ? >> >> Olivier LC >> France >> ICQ#: 82067330 >> sanglier(at)laposte.net >> http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings >> >> -----Message d'origine----- >> De : owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de >> czechsix(at)juno.com >> Envoy : lundi 8 novembre 2004 19:34 >> : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com >> Objet : AeroElectric-List: Stall Horn >> >> >> >> >> >> Guys, >> >> Does anyone know of a source for a cheap stall warning horn similar in >> sound to what's used on spam cans? I made my own spam-style stall >> vane/tab that I'm putting in the LE of the wing. I bought a piezo >> alarm from Digikey for something like $1 but it sounds like a fire >> alarm....it's a bit more shrill and shocking than I want. Aircraft >> Spruce sells a Safe Flight stall horn with light for $740.00. You >> read that right...$740! That doesn't include the vane. So anyway, if >> somebody knows of a non-aircraft source for such a beastie please let >> me know... >> >> Thanks, >> >> --Mark Navratil >> Cedar Rapids, Iowa >> RV-8A N2D wiring... >> >> Sign up for Juno Today at http://www.juno.com! >> Look for special offers at Best Buy stores. >> >> > > ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Re: ELT
> >From: "Giffen A. Marr" <GAMarr(at)Charter.Net> >Date: 2004/11/09 Tue PM 07:34:41 EST >To: >Subject: ELT > ><look at the international standards, ICAO Annex 6 Part I contains the >requirements in Chapter 4, Systems and Equipment. I would be very >surprised if the RTCA Document has any reference to accessibility. It >should only contain engineering performance requirements for the unit. >Giff Marr>> > >11/09/2004 > >Hello Giff, Thanks for your response. My question about the regulatory >requirements for pilot access to or control of the ELT while in flight are >not answered by FAR Sec. 91.207. The audit trail goes like this: > >1) FAR Sec. 91.207 (a) (1) says that one must have an *approved* ELT for >our operations (with some exceptions). In FAA parlance that means approved >by the FAA Administrator. > >2) There are other ways of having the FAA Administrator (or his authorized >representative) approve things, but the TSO process is the most commonly >recognized way. > >3) TSO-C91 is rendered obsolete for new installations after June 21, 1995 >by FAR Sec. 91.207 (a) (1). > >4) TSO-C91a is the currently effective TSO for ELTs. One must either have >an ELT that meets TSO-C91a or have an ELT that has been approved by the >FAA Administrator by some other means. > >5) TSO-C91a, like so many other TSOs, is a bare shell of a document that >provides no meat within itself, but instead provides references to other >documents that are the real guts of the TSO. > >6) Without access to the pertinent referenced documents the answer to my >question is unknown. I am unwilling to accept all the hearsay, gossip, and >rumor that so many people are willing to put forward on this subject. I >want to see the applicable portions of the referenced documents for myself. See http://members.eaa.org/home/homebuilders/faq/ELT's%20and%20Homebuilt%20Aircraft.html http://www.artex.net/faq_remoteswitches.html http://www.alaska.faa.gov/faifsdo/mechairnews1.htm http://www.forpilots.com/archive/rec.aviation.owning/18/msg18463.htm http://www.avionicswest.com/articles/eltupdate.htm RAC's bizjets have 91a certified ELTs and no remote switches. Bonanza's have had remote switches for a few years but did not initially install them when the 91a ELTs became available. Part 91 does not speak to installation requirements, only to the periodic testing of "controls" as-installed. I'm not clear about the concern . . . It's not clear that installing the remote switch is a REQUIREMENT or simply an option provided by the design that adds some degree of optional convenience to the operator. I presume you're planning to install an ELT irrespective of any requirements to have one. If it's a new (TSO-C91a) model, and comes fitted with a remote switch option, would it not be a prudent thing to utilize it in your project irrespective of requirements? For my money, if I wanted an ELT that REALLY works, I'd go for the GPS aided location option as well. This ELT broadcasts your exact location which has a lot better resolution than satellite based locator system. If you have a list of RTCA documents you'd like to see, post it and I'll see if I can put my hands on them. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net>
Subject: Re: Grounding
> > >Bob, > >I will have my battery forward of the firewall and within 200mm (8") of >the engine ground stud. I will also have a firewall ground kit (B&C) on >the composite firewall no more than 300mm (12") from the battery. > >Assuming all cables will be properly restrained, in connecting up the >earth straps which routing method would you prefer? > >1) Battery (-) to Firewall Gnd to Engine Gnd >or >2) Battery (-) to Engine Gnd to Firewall Gnd >or >3) Battery (-) to Firewall Gnd and another Battery -ive to Engine Gnd > >Left to my own devices I would choose No 2 because I think it is the >most likely way to prevent the smoking behind the panel problem you >cited in the 'connection'. Also, I think I would use a continuous strap >with a third flag terminal somewhere in the middle so that in the event >of the connection at the engine coming loose, I would still have battery >power. I am well aware that losing battery power in my little VFR >aircraft would not really matter, nevertheless, if there is such a thing >as 'best practice' in this regard, I would prefer to adopt it. For the most part, ground "reliability" is not a real issue. Other than cases where a mechanic failed to properly install fasteners, the actual configuration of grounding is important only from a perspective of noise (ground loop minimization). #4 wire is entirely sufficient for all fat wires in your installation. A single braided strap from crankcase to firewall ground stud is sufficient. A single 4AWG connection between battery (-) and firwall ground stud is next. These two wires take care of your fat-wire portion of the ground system. Consider use of #4 welding cable for battery (-) and battery (+) connections irrespective of what type of wire is choosen for the rest of the system. Welding cable is quite flexible and will reduce stresses on battery posts to an absolute minimum. Virtually all battery post failures I've become aware of in OBAM aircraft have been the result of connection with very stiff 2AWG Tefzel wire or worse yet, connection with sheet metal or "bus bar" from battery terminals to ground and/or adjacent contactor. You are more at-risk for loss of battery due overly robust terminal connections than from connections that are too few or too light. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2004
In short, NO, he is not correct! If your inspector says that control of the ELT in the cockpit is required by regulation, ask him (or her) to show you that regulation! (and a TSO is NOT a regulation) Any references to cockpit controls in a TSO would be to specify the performance requirements of such a device, but does not require that it exists. The TSO may have specs for lots of options (i.e. portable antenna, microphone, indicator lights, ...) but that does not mean that they are required by regulation. If your unit is TSO'd, it's legal. If you want optional stuff, it has to be covered by the TSO as well, but it is still optional. The FARs cited specify what is required - and cockpit controls are not there, so they are not required! Go out to the flight line of your local FBO and see how many certified airplanes have a cockpit control for the ELT - I'll bet it will be very few, if any! Cockpit controls are a convenience for testing (2 sweeps during the first 5 minutes after the hour), and occasionally re-setting after a 'firm arrival', without having to open up access panels to get to the actual unit. Dennis Glaeser -----Original Message----- From: bakerocb(at)cox.net [mailto:bakerocb(at)cox.net] Subject: ELT Access AeroElectric-List message previously posted by: "Glaeser, Dennis A" <> 11/10/2004 Hello Dennis (and Bob Nuckolls), Thank you for your inputs. Dennis, you are right. The answer to the question of what is the specific regulatory requirement for pilot access to and control of the ELT while airborne cannot be found in either FAR Sections 91.205 or 91.207. But if the requirement for that access and control is contained in the references to TSO-C91a and the basis for the *approved* ELT, that you are required to have in your aircraft per FAR Sec 91.207, is TSO-C91a then you must by regulation meet that requirement. I am not satisfied with hearsay, gossip, rumor, beliefs, or speculation. These are readily available very cheap and I can generate my own. They do not resolve the issue. The requirement either exists in black and white print or it does not and I feel an obligation to know the facts. The facts are not in readily available US Gov't documents, but are instead contained (or not) in references provided by an independent standards organization, the RTCA. The closest that I have been able to come to these references is these two titles: DO-183, Minimum Operational Performance Standards for Emergency Locator Transmitters-Automatic Fixed-ELT (AF), Automatic Portable-ELT (AP), Automatic Deployable-ELT (AD), Survival-ELT (S) Operating on 121.5 and 243.0 Megahertz DO-182, Emergency Locator Transmitter (ELT) Equipment Installation and Performance OC PS: This issue may come up when the initial airworthiness inspector of your amateur built experimental aircraft insists that you have such access and control over your ELT because it is *required by regulations* or he will not grant the airworthiness certificate. Is he correct? ________________________________________________________________________________
Date: Nov 10, 2004
From: Christopher Stone <rv8iator(at)earthlink.net>
-----Original Message----- From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> Subject: Re: AeroElectric-List: Ammeter/Loadmeter > >Bob: > >What do you mean when you say "The only limitation on the entire field of >instrumentation choices is that none of the Z-Figures is friendly to use >of the >classic minus-0-plus battery ammeter"? I am wiring to Figure Z-10 and where >you call for a loadmeter I have installed Van's "classic" -40/0/+40 ammeter. >Should I change something? I haven't lit the engine yet. The ammeter you have was originally intended for installation as a battery-ammeter in the historically popular automotive electrical system architecture. You can wire this instrument as an alternator loadmeter just keep in mind that it will ALWAYS read zero and above. Not a 'bad' thing, it simply tosses off half of the useful scale of the instrument. The danger is that some individual not familiar with how it's used may believe it to be a battery-ammeter based on it's markings . . . and might mis-interpret what it's saying. For example, after an hour of flight, your loadmeter is going to read present load on the alternator which is always a positive value. Another pilot might become concerned when what he perceives as a battery-ammeter never goes to zero indicating the battery is charged. The important thing is that YOU understand how it should function so that you can properly interpret what it tells you. Bob . . . Bob... Why not then just a voltmeter? No shunt required. As long as it reads 13.8 - 14.5V you know the alternator is supplying power. How does a loadmeter keep the B-lead out of the cockpit?. The B-lead has to feed the bus. The bus is in the cockpit. What am I missing here? Chris Stone ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Re: [RV-8] Single Point Grounding
> >This issue arose recently for builders of Lancair ES's, which typically >mount the battery(s) in the rear for weight and balance reasons. Awhile >back Bob published a diagram labelled Z-14RearBats.pdf, or something like >that. This is a modification of Z-14 when batteries are mounted in the >rear. This diagram calls for groundblocks in front and back with a fat >wire connecting them. Then you can ground items in back to the rear >ground block. > >I can send this to you if you need it, or perhaps Bob can make it >available on his site? >................ > >I have the same question, and I will have two batteries >in the back. > >It seems like grounding on the airframe at the back, >plus a good copper cable or Super-2-CCA FatWire >
http://www.periheliondesign.com/fatwires.htm also >running up front, grounded from place to place, would >be the best solution. Perhaps I'm making this more >complicated than it needs to be. >Mickey > >At 11:53 06-08-04, Scott Chastain wrote: >I took Bob Nuckoll's course last fall and am slowly getting through the >manual. I will have an aft battery installation which presents a special >problem. I had planned on using the Nuckoll's design for the single point >grounding system, where the negative lead from the battery is brought up >to a ground bus on the firewall. There, all avionics from the panel are >grounded to a "forest" of fast-on >connectors, and on the forward side of the firewall, the engine is >grounded along with other components under the cowling. One benefit of >doing this is to eliminate noise, according to Bob. However, I had not >planned on having to run two battery leads up to the firewall. It would >seem silly to add the extra weight by having both the negative and >positive leads run up that far on an aluminum bird. Has anyone already >done this to conform with the Bob Nuckoll's >design? If not, for those of you who are aleady flying with a rear battery >installation, where have you run the negative lead and where do you ground >most, if not all, of your panel equipment? Have you encountered noise >problems by not having the single point ground? >Thanks! The rear mounted two-battery grounding diagram was published at: http://www.aeroelectric.com/articles/Appendix_Z_Drawings/Z-14_Rear_Bats.pdf Airplanes have used airframe ground for rear mounted batteries for nearly 80 years and the vast majority have performed "satisfactorily" to this day. There is a high probability that if you use airframe as battery (-) connections for your rear mounted batteries in an aluminum airplane, you'll be fine . . . especially if you adhere to the single point ground philosophy for potential victim systems. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2004
Subject: RE: Ammeter/Loadmeter
> > > >Bob: > > > >What do you mean when you say "The only limitation on the entire field of > >instrumentation choices is that none of the Z-Figures is friendly to use > >of the > >classic minus-0-plus battery ammeter"? I am wiring to Figure Z-10 and where > >you call for a loadmeter I have installed Van's "classic" -40/0/+40 ammeter. > >Should I change something? I haven't lit the engine yet. > > The ammeter you have was originally intended for installation > as a battery-ammeter in the historically popular automotive > electrical system architecture. > > You can wire this instrument as an alternator loadmeter > just keep in mind that it will ALWAYS read zero and above. > Not a 'bad' thing, it simply tosses off half of the useful > scale of the instrument. The danger is that some individual > not familiar with how it's used may believe it to be > a battery-ammeter based on it's markings . . . and might > mis-interpret what it's saying. For example, after an hour > of flight, your loadmeter is going to read present load on > the alternator which is always a positive value. Another > pilot might become concerned when what he perceives as > a battery-ammeter never goes to zero indicating the battery > is charged. The important thing is that YOU understand > how it should function so that you can properly interpret > what it tells you. > > Bob . . . > > >Bob... > > >Why not then just a voltmeter? No shunt required. >As long as it reads 13.8 - 14.5V you know the alternator is supplying power. > >How does a loadmeter keep the B-lead out of the cockpit?. >The B-lead has to feed the bus. The bus is in the cockpit. >What am I missing here? Sure! How about no meters at all? They don't help you fly or operate the airplane, only troubleshoot the airplane. Since you don't need to troubleshoot in flight then the active notification of low voltage (warning light) combined with proper attention to battery condition is all you'll ever need to comfortably bore holes in the sky. Wrong cause-and-effect. Loadmeters don't keep b-leads out of cockpit, taking the b-lead out of the cockpit necessitates elimination of the battery ammeter. See chapter on electrical system in instrumentation. If you really gotta HAVE an ammeter then loadmeters are as good as any and are less subject to ambiguous deductions due to lack of understanding. Re: recent thread concerning dark-n-stormy-night story on generator failure. But as you've correctly observed, voltmeters are good too . . . but again, you gotta watch 'em. 95% of pilots in certified ships are unaware of failure of alternator until the panel goes black and by then they're all out of options. By all means, install whatever number of steam or digit gages strikes your fancy but don't leave the ground without active notification of low voltage and a confident knowledge of battery condition with respect to capacity. Bob . . . ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Re: ELT
Hi Bob, Can you point me to a model? I'm in the market for one, and can only find the portable units. Thanks, Mickey > ... For my money, if I wanted an ELT that REALLY > works, I'd go for the GPS aided location option as well. > This ELT broadcasts your exact location which has a lot > better resolution than satellite based locator system. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 10, 2004
Subject: Re: Re:Stall Horn
> >> If you need a horn to tell you when your RV is about to quit flying - >> then >> you aren't flying enough !!!!!!!!!!!!! >> Now, now... I didn't mean to start a long thread on the merits of Stall Warning. I agree wholeheartedly that a stall warning device shouldn't replace good piloting skills and thorough knowledge of how an airplane handles and feels leading up to (and through) the stall. When I'm flying any airplane, I don't depend on the stall warning system to make up for carelessness on my part....my goal is to never allow myself to get into a situation where the stall warning would need to alert me of an impending stall that I'm not already well aware of. But...statistics say that some people get bit by stall/spin accidents year after year. Some of them were probably careless, ignorant or unfamiliar with the airplane, but not all of them...a number have been highly experienced pilots flying an airplane in which they had thousands of hours logged. How many of those statistics happened in airplanes with stall warning devices vs. those without, I don't know (i.e. I don't know how much of a safety ben efit a stall warning system is statistically). Stall warning doesn't guarantee my safety, but I don't think it means I'm paranoid or inept if I decide to put it in my airplane. I just think it's nice to have, just in case. There are other things on my airplane that are nice to have, but not necessary, like autopilot, attitude indicator (I'm VFR only), a fuel flow meter, a nosewheel, an electronic engine monitor with alarm, a GPS, etc. None of these devices should replace good piloting skills, judgement, or careful attention to flying/navigating the airplane. But all of them have been deemed useful and practical by ME for making MY flying experience safer and more convenient. I'm sure some will disagree, which is fine...but this is my airplane, my money and my butt in the seat, so I get to decide what goes in it and for what reasons : ) Some will assume that my decisions are based on lack of confidence in my flying abilities, and I don't expect anything I've said here will change their perception of me, or their perception of themselves that their superior abilities will never ever allow them get bit...to each their own. In the case of my stall warning system, I bought a microswitch and small piezo alarm and rolled my own. I have all of about $5 invested in it right now. I'm not convinced that spending upwards of $1K for a full-blown AOA system is worth it for MY goals (although I think AOA would be nice to have!). My original post was just asking about alternatives for the warning horn because my piezo alarm sounds, well, a bit more "alarming" than I want it to. I'd like it to get my attention but not give my passenger a heart attack. I'll take the advice of several folks and call an aircraft salvage yard... --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring.... Sign up for Juno Today at http://www.juno.com! Look for special offers at Best Buy stores. ________________________________________________________________________________
Date: Nov 10, 2004
Makes perfect sense to me.. In addition to finding a different warning horn, you might be able to make one you have sound like you want. How does it sound if you wrap it in a layer of duct tape? Or, how about putting a 100ohm resistor in series with it? Regards, Matt- > > > >> >>> If you need a horn to tell you when your RV is about to quit flying - >>> then >>> you aren't flying enough !!!!!!!!!!!!! >>> > > Now, now... > > I didn't mean to start a long thread on the merits of Stall Warning. I snip > would be nice to have!). My original post was just asking about > alternatives for the warning horn because my piezo alarm sounds, well, a > bit more "alarming" than I want it to. I'd like it to get my attention > but not give my passenger a heart attack. I'll take the advice of > several folks and call an aircraft salvage yard... > > --Mark Navratil > Cedar Rapids, Iowa > RV-8A N2D wiring.... > > > Sign up for Juno Today at http://www.juno.com! > Look for special offers at Best Buy stores. > > ________________________________________________________________________________
Date: Nov 10, 2004
----- Original Message ----- From: Matt Prather <mprather(at)spro.net> Date: Wednesday, November 10, 2004 2:28 pm Subject: Re: AeroElectric-List: Re: Re:Stall Horn Prather" > > Makes perfect sense to me.. In addition to finding a different > warninghorn, you might be able to make one you have sound like you > want. How > does it sound if you wrap it in a layer of duct tape? Or, how > about putting > a 100ohm resistor in series with it? > > Regards, > Here's an idea you can experiment with. The piezo alarms work by creating an oscillation across a crystal, right? The frequency is that of the crystal. What happens if you scratch or drop a touch of glue onto the crystal to changes its frequency? ________________________________________________________________________________
Date: Nov 10, 2004
Many years ago, as a poor teenager, I often used a soft pencil to add mass to scanner xtals to lower the freq... erie echristley(at)nc.rr.com wrote: > > >----- Original Message ----- >From: Matt Prather <mprather(at)spro.net> >Date: Wednesday, November 10, 2004 2:28 pm >Subject: Re: AeroElectric-List: Re: Re:Stall Horn > > > >> >> >Prather" > > >> >>Makes perfect sense to me.. In addition to >> >> >finding a different > > >>warninghorn, you might be able to make one you >> >> >have sound like you > > >>want. How >>does it sound if you wrap it in a layer of duct >> >> >tape? Or, how > > >>about putting >>a 100ohm resistor in series with it? >> >>Regards, >> >> >> > >Here's an idea you can experiment with. The piezo >alarms work by creating an oscillation across a >crystal, right? The frequency is that of the >crystal. What happens if you scratch or drop a >touch of glue onto the crystal to changes its frequency? > > > > ________________________________________________________________________________
Subject: Re: ELT
Date: Nov 10, 2004
FYI, here is a website that evaluated several of the 406 Mhz EPIRBs, some with built in GPS. McMurdo Ltd had a unit in their booth at Ohskosh, but nobaby seemed to have been briefed on it availablilty or cost. Good luck. http://www.equipped.com/406_beacon_test_toc.htm -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: Re: AeroElectric-List: Re: ELT ________________________________________________________________________________
Subject: Keep warm circuit for Landing/Taxi lights
Date: Nov 10, 2004
Bob, I have questions about the implementation of a keep-warm circuit you recommend in Chapter 12 of the Connection for filament bulbs. I plan to use 75W Halogen bulbs for Landing & Taxi lights (CreativeAir). How do you determine what amperage these bulbs will draw at lower voltages? Is there a way to predict this, or do you just test? You also mention a DIY keep warm power supply, but I don't see one described, unless: Is it the solid state dimming control circuit in Fig 12.8 with a fixed resistor set to get the desired voltage per above? I also did a search for DC-DC converters and found this: http://www.datel.com/data/power/lsn-d12.pdf. These claim over 80 percent efficiency, which sounds good. How efficient is the LM317K circuit in comparison? Are their other circuits you'd recommend for this function? Thanks, Dennis Glaeser ________________________________________________________________________________
Subject: ELT Access
Date: Nov 10, 2004
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com> Date: 2004/11/10 Wed AM 10:51:16 EST Subject: RE: ELT Access 11/10/2004 Hello Dennis, Thank you for your response. It is very passionate, but a bit shy on logic and facts. Ill comment in pieces below: <> We dont know that yet because we have not seen the pertinent documents referenced by TSO-C91a. <> Not every regulatory requirement is spelled out in detail in the FARs themselves. Something can be a regulatory requirement because it appears in an approval document for a piece of equipment that is required by regulation to be approved. <<(and a TSO is NOT a regulation)>> You are right. A TSO itself is not a regulation, but if a regulation requires an approved piece of equipment and you are using a TSOd item to show that your item is indeed approved, then that TSO is fulfilling a regulatory requirement. Here is FAR Sec 21.601 (b) (4) QUOTE: An article manufactured under a TSO authorization, an FAA letter of acceptance as described in 21.603(b), or an appliance manufactured under a letter of TSO design approval described in 21.617 is an approved article or appliance for the purpose of meeting the regulations of this chapter that require the article to be approved. UNQUOTE. Does this leave any doubt in anyones mind regarding the regulatory status of a TSOd piece of equipment that is fulfilling a regulatory approval requirement? <> That is your opinion, not fact, and it is not shared by someone at AOPA who wrote on this subject. Here is an extract from an email that I received from AOPA. QUOTE: One of the major changes the FAA made in going from TSO C91 to TSO C91a was to require a cockpit mounted remote switch to allow the pilot to manually activate the ELT and as a visual monitor of when the ELT is active. The requirement is outlined in RTCA/DO-183, Section 2.1.12 and DO-204, Section 2.2.6.UNQUOTE Unfortunately the person at AOPA who sent me the email was not the original author of that extract. He had extracted it from some TSO material that he found at AOPA while searching for an answer to my ELT access question. AOPA does not have the RTCA documents so they are unable to confirm what the documents say. <> Just stating an opinion vehemently does not make it fact. <> The reason for the many aircraft that will be found without cockpit control and access of their ELT is that those installations were made prior to June 21, 1995. See FAR Sec 91.207 (a) (1). We know that cockpit control and access were not required prior to that date. <> I have no disagreement with what you write there, but for new ELT installations after June 21, 1995 cockpit control and access of the ELT while airborne may be a regulatory requirement and Id like to absolutely confirm or deny that fact by reading the pertinent RTCA documents. It was never my intent to get sidetracked into semantical discussions regarding regulatory requirements in general and I apologize to readers for proceeding down that rabbit trail above. It is just not in my nature to accept hearsay, gossip, rumor, speculation, opinion, and beliefs when I am looking for facts and I know that the facts do exist. OC ________________________________________________________________________________
Date: Nov 11, 2004
Subject: ELT Access
---------------------------------big snip --------------------- I have no disagreement with what you write there, but for new ELT installations after June 21, 1995 cockpit control and access of the ELT while airborne may be a regulatory requirement and Id like to absolutely confirm or deny that fact by reading the pertinent RTCA documents. It was never my intent to get sidetracked into semantical discussions regarding regulatory requirements in general and I apologize to readers for proceeding down that rabbit trail above. It is just not in my nature to accept hearsay, gossip, rumor, speculation, opinion, and beliefs when I am looking for facts and I know that the facts do exist. OC ------------------------------------------- OC - You have aroused my curiosity - just what would be the useful purpose of requiring or having access to the ELT while airborne? The only reason I can think of would be for ditching on a oceanic flight, and in that case you should probably have a PLB or water activated ELT stowed in your life raft. George in Langley ________________________________________________________________________________
From: "Olivier Le Carbonnier" <olcdlm(at)laposte.net>
Subject: Stall Horn
Date: Nov 11, 2004
yes but the answer from man from AngleOffAttack is: ------------------------------ The difference is that our AOA works. If you think about it, the advantage of the under wing pitot tube is that the airflow is always flowing about parallel to the under side of the wing. Because of this the airspeed indication (IAS) is accurate no matter what the angle of attack (AOA). Conversely, the under wing is a lousy place for an AOA sensor. This is because the air changes direction way before it reaches the wing and when it reaches the wing the airflow is about parallel to the wing surface no matter what the AOA. Now, if you try to fix this by moving the pitot tube further from the wing to get into undisturbed air, you may improve the AOA sensing ability somewhat but the IAS now has errors with changes in AOA. Did you ever wonder why the AOA probes on Airbus airliners are way ahead of the wing on the nose of the fuselage? They actually have to be one and one half chord ahead of the wing to get into undisturbed air. The beauty of our system is that it senses pressures on the top and bottom of the wing (aerodynamic sensing) and divides that differential pressure by the dynamic pressure producing a Cl (coefficient of lift). Those familiar in the art know that coefficient of lift and AOA vary uniquely with each other. We avoid the pit falls of both pressure on probe sensing systems and vane systems. Also you have some redundancy. Consequently, we sell more AOAs than all the other AOA folks combined. If you want an AOA that works, let us know. Our AOA is based on sound aerodynamic principle . Any other would only be a glorified IAS indicator. ---------------------------------------------------- Olivier -----Message d'origine----- De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt Prather Envoy : mercredi 10 novembre 2004 16:33 : aeroelectric-list(at)matronics.com Objet : RE: AeroElectric-List: Stall Horn I'll take this opportunity to correct myself a bit.. Aircraft spruce has a vane style unit for $545 here: http://www.aircraftspruce.com/catalog/inpages/aoartangle.php It seems they pretty much go up from there. Another option, depending on how much cool stuff you are going to put in the panel is the Dynon EFIS. They are having some teething trouble, but I think they'll sort it out. They offer an AOA pitot probe for $200 (only works with their EFIS). The total cost would be about $2600 which while a pretty good value is not cheap. http://www.aircraftspruce.com/catalog/avpages/efisd10.php Matt- > > > where ? > > Olivier > > -----Message d'origine----- > De : owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt > Prather > Envoy : mardi 9 novembre 2004 21:19 > : aeroelectric-list(at)matronics.com > Objet : RE: AeroElectric-List: Stall Horn > > > > > Not cheap... I have seen them start at $600. > > MAP > >> >> >> why not a AOA ? >> >> Olivier LC >> France >> ICQ#: 82067330 >> sanglier(at)laposte.net >> http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings >> >> -----Message d'origine----- >> De : owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de >> czechsix(at)juno.com >> Envoy : lundi 8 novembre 2004 19:34 >> : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com >> Objet : AeroElectric-List: Stall Horn >> >> >> >> >> >> Guys, >> >> Does anyone know of a source for a cheap stall warning horn similar in >> sound to what's used on spam cans? I made my own spam-style stall >> vane/tab that I'm putting in the LE of the wing. I bought a piezo >> alarm from Digikey for something like $1 but it sounds like a fire >> alarm....it's a bit more shrill and shocking than I want. Aircraft >> Spruce sells a Safe Flight stall horn with light for $740.00. You >> read that right...$740! That doesn't include the vane. So anyway, if >> somebody knows of a non-aircraft source for such a beastie please let >> me know... >> >> Thanks, >> >> --Mark Navratil >> Cedar Rapids, Iowa >> RV-8A N2D wiring... >> >> Sign up for Juno Today at http://www.juno.com! >> Look for special offers at Best Buy stores. >> >> > > ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Nov 11, 2004
> > #4 wire is entirely sufficient for all fat wires in your > installation. A single braided strap from crankcase to > firewall ground stud is sufficient. A single 4AWG connection > between battery (-) and firwall ground stud is next. These > two wires take care of your fat-wire portion of the ground system. > Consider use of #4 welding cable for battery (-) and battery (+) > connections irrespective of what type of wire is choosen for the > rest of the system......... > > You are more at-risk for loss of battery due overly robust > terminal connections than from connections that are too > few or too light. > > Bob . . . > Bob: When making one's own #4 welding cables for + and - battery post connections, what do you recommend for shrink down or cover material that is heat and fire rated for covering the cable located on the engine side of the FW? Larry ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Hall Effect Sensor and JPI EDM 900
I installed my EDM900 in my Lancair. Continental IO-550N, 12V system. My left mag came with a Hall effect sensor already installed. I snipped off the connector and used a Molex connector to connect to the wires coming from the JPI tach feed. At high RPMs, sometimes, not all the time, I get a fluctuating RPM reading, all the way from 3500 to 0, and then back to normal. JPI recommended replacing the sensor that came with my engine with the one that came with the unit, no surprise there! Replacing the sensor means retiming the mag, and I'd rather avoid that if it's not the sensor. Could it be the Hall effect sensor? Or do I have a bad wiring connection somewhere? Mike Easley Colorado Springs ________________________________________________________________________________
Subject: Re: Keep warm circuit for Landing/Taxi lights
Date: Nov 11, 2004
I would like to suggest that Keep-Alive circuits should probably be rethought or abandoned. Here's my thinking: 1) These waste energy--typically a couple dozen watts. For reduction of input surge, using a thermistor or a soft start circuit is easy to do and wastes no energy. 2) If shock and vibration is the problem--maybe addressing the shock and vibration mechanically is a better approach. 3) Does anybody have data that says these actually help? I would guess that for long filament lamps they do... but for halogens--I'm from Missouri. Get rid of your filament lamps. Let's discuss this on the list. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net "I want to die peacefully in my sleep like my father did.... Not screaming in terror like the passengers in his airplane." --anonymous ________________________________________________________________________________
Date: Nov 11, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> lights
lights lights > > > >I would like to suggest that Keep-Alive circuits should probably be >rethought or abandoned. Here's my thinking: > >1) These waste energy--typically a couple dozen watts. For reduction of >input surge, using a thermistor or a soft start circuit is easy to do and >wastes no energy. How is energy expended to add value to a system a "waste"? Further, if the system is implemented with dc/dc converters, the entire drain on the system is under 5 watts and is present only when the alternator is running (keep alive runs from main bus only). >2) If shock and vibration is the problem--maybe addressing the shock and >vibration mechanically is a better approach. >3) Does anybody have data that says these actually help? I would guess that >for long filament lamps they do... but for halogens--I'm from Missouri. > > Get rid of your filament lamps. > >Let's discuss this on the list. When the lighting chapter was written (about 10 years ago) the popular incandescent lamps for OBAM aircraft favored the classic aircraft and some automotive sealed beam lamps. The idea for a keep-alive system was derived from laboratory data I'd seen on lamps wherein maintaining a lamp's OFF temperature above the brittle/ductile transition temperature provided a 5x to 20x increase in filament life due to vibration in during the OFF state. Modern sealed beams (which use capsuled halogens) and automotive headlamps using cartridge lamps are already many times more robust than their ancestors. Due to their very low cost and long life, no value is added with the $time$ it takes to add a keep-alive system. Nav light bulbs, particularly the reflector style lamps were aircraft unique and $20 each retail at the time. Obviously, those have been eclipsed by modern lamps as well. We don't talk about Narco Super-Homers . . . (see http://www.aeroelectric.com/Pictures/P1012780.JPG ) . . . . in the certified world journals and texts any more, non-halogen "aircraft" lamps need to disappear from tomorrow's texts as well. The next revision to the lighting chapter will not discuss keep alive systems. LED nav lights and halogen automotive derivative lamps for landing and recognition are the value leaders today. If the HID lamps get to where they can offer similar visibility, operating speeds, and pricing as the lowly incandescent lamp, then they may become next year's value technology. Now, on might still consider inrush-limiters but not for the reasons you might suspect. We discovered a transient noise generation problem on the Bonanzas a couple of years ago that was triggering the OVM crowbar system in the B&C regulators when the landing/taxi light systems were cycled on together. This turns out to be a combination of long wires to the wings, super heavy contacts of an "aircraft quality" switch/breaker . . . ( see http://www.aeroelectric.com/Pictures/W31_1.jpg ) . . . with contacts that bounce like a golf ball and generated some amazing noises while working to raise a cold lamp filament up to operating temperatures. It was easier to "fix" the regulator to ward of this new antagonist than to add inrush limiters to calm the antagonist. I'll suggest it's a bit early to write off the incandescent lamp entirely. One of those $5 halogen cartridges has a strong probability of lasting for as long as anyone owns their airplane and they don't need pampering. Bob . . . ________________________________________________________________________________
Date: Nov 11, 2004
OC, The folks who write regulations should be forced to pass a logic test! I think the bottom line is that ELTs are required to have a cockpit control as part of their design to comply with the TSO, but the equipment requirements in the FARs do not specificlly require it be installed (were probably written before the TSO changed). Since the equipment is there, why not just install it? I'd still argue that you couldn't be denied an airworthiness certificate if it is not there, but if the inspector feels otherwise it would be more hassle than I'd be willing to endure to press the issue. Discussing regs is often a passionate activity, since they are SO logical ;-) Dennis -----Original Message----- From: bakerocb(at)cox.net [mailto:bakerocb(at)cox.net] Subject: ELT Access From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com> Date: 2004/11/10 Wed AM 10:51:16 EST aeroelectric-list(at)matronics.com Subject: RE: ELT Access 11/10/2004 Hello Dennis, Thank you for your response. It is very passionate, but a bit shy on logic and facts. I'll comment in pieces below: <> We don't know that yet because we have not seen the pertinent documents referenced by TSO-C91a. <> Not every regulatory requirement is spelled out in detail in the FAR's themselves. Something can be a regulatory requirement because it appears in an approval document for a piece of equipment that is required by regulation to be approved. <<(and a TSO is NOT a regulation)>> You are right. A TSO itself is not a regulation, but if a regulation requires an approved piece of equipment and you are using a TSO'd item to show that your item is indeed approved, then that TSO is fulfilling a regulatory requirement. Here is FAR Sec 21.601 (b) (4) QUOTE: An article manufactured under a TSO authorization, an FAA letter of acceptance as described in 21.603(b), or an appliance manufactured under a letter of TSO design approval described in 21.617 is an approved article or appliance for the purpose of meeting the regulations of this chapter that require the article to be approved. UNQUOTE. Does this leave any doubt in anyone's mind regarding the regulatory status of a TSO'd piece of equipment that is fulfilling a regulatory approval requirement? <> That is your opinion, not fact, and it is not shared by someone at AOPA who wrote on this subject. Here is an extract from an email that I received from AOPA. QUOTE: One of the major changes the FAA made in going from TSO C91 to TSO C91a was to require a cockpit mounted remote switch to allow the pilot to manually activate the ELT and as a visual monitor of when the ELT is active. The requirement is outlined in RTCA/DO-183, Section 2.1.12 and DO-204, Section 2.2.6.UNQUOTE Unfortunately the person at AOPA who sent me the email was not the original author of that extract. He had extracted it from some TSO material that he found at AOPA while searching for an answer to my ELT access question. AOPA does not have the RTCA documents so they are unable to confirm what the documents say. <> Just stating an opinion vehemently does not make it fact. <> The reason for the many aircraft that will be found without cockpit control and access of their ELT is that those installations were made prior to June 21, 1995. See FAR Sec 91.207 (a) (1). We know that cockpit control and access were not required prior to that date. <> I have no disagreement with what you write there, but for new ELT installations after June 21, 1995 cockpit control and access of the ELT while airborne may be a regulatory requirement and I'd like to absolutely confirm or deny that fact by reading the pertinent RTCA documents. It was never my intent to get sidetracked into semantical discussions regarding regulatory requirements in general and I apologize to readers for proceeding down that rabbit trail above. It is just not in my nature to accept hearsay, gossip, rumor, speculation, opinion, and beliefs when I am looking for facts and I know that the facts do exist. OC ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Strobe power supply grounding
I'm installing a Nova Electronics Superpak 906 strobe power supply in my RV, and the installation instructions say, with emphasis: Note: The power supply baseplate must be connected to chassis ground (GND) to reduce radio interference. Since there is also a ground wire with the power wire, wouldn't it actually cause *more* noise to do this, since the device would be grounded in two different places? Seems to me like it would it be better to electrically isolate the baseplate, and run a ground wire from it back to the airplane common ground. Am I missing something here? Thanks for your advice. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 11, 2004
> > > > > > > #4 wire is entirely sufficient for all fat wires in your > > installation. A single braided strap from crankcase to > > firewall ground stud is sufficient. A single 4AWG connection > > between battery (-) and firwall ground stud is next. These > > two wires take care of your fat-wire portion of the ground system. > > Consider use of #4 welding cable for battery (-) and battery (+) > > connections irrespective of what type of wire is choosen for the > > rest of the system......... > > > > You are more at-risk for loss of battery due overly robust > > terminal connections than from connections that are too > > few or too light. > > > > Bob . . . > > > Bob: When making one's own #4 welding cables for + and - battery >post connections, what do you recommend for shrink down or cover material >that is heat and fire rated for covering the cable located on the engine >side of the FW? There are no "heat and fire rated" materials for this task. There are materials called out on the type certificate for a particular airplane that become "approved" because they're on the bill of materials for that airplane . . . this says nothing about how the materials were selected or what ratings were deemed significant when the material was selected. For your OBAM aircraft, I recommend a double-wall, self-sealing heat shrink by Alpha or 3M. You may be able to buy single chunks of this material (1/2" original size) from a local electrical contractor supply house. This stuff is pretty nice because it is mechanically very rigid when it sets (mimics the insulation support feature of a PIDG terminal) and it seals the joint at the same time (better than a PIDG terminal). See EPS-300 and EPS-200 materials at: http://dkc3.digikey.com/PDF/T043/1202.pdf Now, suppose you've got some 1/2" regular heatshrink available and you don't want to order a $7.00 + shipping piece of internal melting wall tubing just to use 3" of the 4' on your airplane. Two layers of plain vanilla heatshrink will dress up the joints nicely. Make the second layer 1/4" to 1/2" longer than first layer and center it on the first layer so that it totally covers. They'll still be working just fine the day your airplane is scrapped. Bob . . . ________________________________________________________________________________
Date: Nov 11, 2004
I have the same power supply. I followed the directions and have no noise. That's all I can offer. - Larry Bowen, RV-8 23.5 hrs. Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > Sent: Thursday, November 11, 2004 9:31 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Strobe power supply grounding > > --> > > I'm installing a Nova Electronics Superpak 906 strobe power > supply in my RV, and the installation instructions say, with emphasis: > > Note: The power supply baseplate must be connected to chassis > ground (GND) to reduce radio interference. > > Since there is also a ground wire with the power wire, > wouldn't it actually cause *more* noise to do this, since the > device would be grounded in two different places? > > Seems to me like it would it be better to electrically > isolate the baseplate, and run a ground wire from it back to > the airplane common ground. Am I missing something here? > > Thanks for your advice. > > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > > ========= > ========= > Matronics Forums. > ========= > http://www.matronics.com/FAQ/AeroElectric-List.htm > ========= > > > > > > ________________________________________________________________________________
Date: Nov 11, 2004
Hi Larry, That's good info. I searched for 'strobe' on your site but didn't find anything. Can you tell me where you mounted your strobe power supply, and where you put your "central" ground? Best regards, Mickey At 20:02 11-11-04, Larry Bowen wrote: -----Start of Original Message----- > >I have the same power supply. I followed the directions and have no noise. >That's all I can offer. > >- >Larry Bowen, RV-8 23.5 hrs. >Larry(at)BowenAero.com >http://BowenAero.com > > >> -----Original Message----- >> From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] >> Sent: Thursday, November 11, 2004 9:31 AM >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: Strobe power supply grounding >> >> --> >> >> I'm installing a Nova Electronics Superpak 906 strobe power >> supply in my RV, and the installation instructions say, with emphasis: >> >> Note: The power supply baseplate must be connected to chassis >> ground (GND) to reduce radio interference. >> >> Since there is also a ground wire with the power wire, >> wouldn't it actually cause *more* noise to do this, since the >> device would be grounded in two different places? >> >> Seems to me like it would it be better to electrically >> isolate the baseplate, and run a ground wire from it back to >> the airplane common ground. Am I missing something here? >> >> Thanks for your advice. >> -----End of Original Message----- -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Date: Nov 11, 2004
I can't find it on my site either! It's mounted behind the rear baggage area. I used some .063 plate to make a platform to go from the middle rib across to the lower longeron. The power supply bolts to that platform. The bare wires from the three strobe cables are braided together and crimped with a ring connector. It's secured to one of the bolts holding the plate down. I thought I took a picture. I'll try to find it. - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > Sent: Thursday, November 11, 2004 2:22 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Strobe power supply grounding > > --> > > Hi Larry, > > That's good info. I searched for 'strobe' on your site but > didn't find anything. Can you tell me where you mounted your > strobe power supply, and where you put your "central" ground? > > Best regards, > Mickey > > At 20:02 11-11-04, Larry Bowen wrote: > -----Start of Original Message----- > >--> > > > >I have the same power supply. I followed the directions and > have no noise. > >That's all I can offer. > > > >- > >Larry Bowen, RV-8 23.5 hrs. > >Larry(at)BowenAero.com > >http://BowenAero.com > > > > > >> -----Original Message----- > >> From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > >> Sent: Thursday, November 11, 2004 9:31 AM > >> To: aeroelectric-list(at)matronics.com > >> Subject: AeroElectric-List: Strobe power supply grounding > >> > >> --> > >> > >> I'm installing a Nova Electronics Superpak 906 strobe > power supply in > >> my RV, and the installation instructions say, with emphasis: > >> > >> Note: The power supply baseplate must be connected to > chassis ground > >> (GND) to reduce radio interference. > >> > >> Since there is also a ground wire with the power wire, wouldn't it > >> actually cause *more* noise to do this, since the device would be > >> grounded in two different places? > >> > >> Seems to me like it would it be better to electrically isolate the > >> baseplate, and run a ground wire from it back to the > airplane common > >> ground. Am I missing something here? > >> > >> Thanks for your advice. > >> > -----End of Original Message----- > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > > ========= > ========= > Matronics Forums. > ========= > http://www.matronics.com/FAQ/AeroElectric-List.htm > ========= > > > > > > ________________________________________________________________________________
Subject: ELT Access
Date: Nov 11, 2004
AeroElectric-List message previously posted by: "Glen Matejcek" <> 11/11/2004 Hello Glen, Thanks for your input. My experience has been similar to yours -- many sources pretty sure of the requirement, but none of them able to identify or produce the specific source of that requirement. I know the documents are available from RTCA for cash, but there are three possible documents in play, DO-182, DO-183, and DO-204. I didn't want to pay for all three -- much rather spend the cash for beer and avgas -- not necessarily in that order and definitely not in combination. Hence my request to this group for a free look. OC ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Re: The List Fund Raiser - Great Gifts!
Matt, do you have a Paypal account? If not, I can have you ding my business credit card. What's your pleasure? Bob . . . ________________________________________________________________________________
From: "Gilles Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: Fw : Understanding strange LVWM behaviour
Date: Nov 11, 2004
Bob, Hope you won't mind my posting a copy of my previous message about my LVWM mystery, as it may have got through unnoticed. Any suggestions as to where to direct the investigation ? If necessary I can resend the diagram pictures. Thanks in advance Best regards, Gilles =================================================== Hi Bob, This is off-list because of the attachment. We started our engine last week. Everything electric worked beautifully thanks to your help and knowledge. There is only one minor bug I'm unable to fix. The engine is a Rotax 914. The circuit is wired as per figure Z 16 with an auxiliary battery, an auxiliary battery management module from Eric Jones, and a low voltage warning module AEC 9005-201 for the aux battery. The low voltage warning module is controlled by a small relay to avoid constant illumination of the annunciator when the power is off. For reasons unknown to me I can't seem to have this aux battery Low Volts light work as expected (the module works OK on the bench). - When the master is ON (engine OFF), the Main Bat light works, but the Aux Bat light doesn't. I was expecting to have both lights illuminate when their respective battery voltage is below 13 V. - When the E-Bus switch is ON and the Master OFF, the Aux Bat light illuminates but not the Main Bat light, which is normal. - During the tests I noticed the Aux Bat light illuminates briefly when I switch the Master OFF. What am I missing ? Thanks for your help Regards, Gilles Thesee Grenoble, France ________________________________________________________________________________
Subject: ELT Access
Date: Nov 11, 2004
AeroElectric-List message previously posted by: "Robert L. Nuckolls, III" <<....skip....If you have a list of RTCA documents you'd like to see, post it and I'll see if I can put my hands on them. Bob>> 11/11/2004 Hello Bob Nuckolls, Thanks for the offer -- that was the object of my original request. I am led to believe that the ELT access requirement would be found in DO-182, DO-183, or DO-204. Thanks for your help. OC ________________________________________________________________________________
Date: Nov 11, 2004
Subject: CH Products Control Stick Switches Electrical Specifications
There has been discussions about the CH Products control sticks (http://www.chproducts.com/retail/aircraft.html) on the newsgroups lately. I have two of them, but there was a question about what the switch ratings were. I contacted Kevin Williamson of CH Products and he was kind enough to supply me with a set of sample switches (from Omron) and the part numbers thereof. I downloaded the complete data sheet from the web, reviewed the specifications and then called the Omron factory representative. There are a few minor errors in the datasheet available on the web, so the rep emailed me the revised (corrected) sheets. I also discussed with him the specifications listed and got clarification, although it turned out that when I received the revised data sheets, the specification is very clear now. The bottom line is that the electrical rating for all three different switches is: 1-50mA, at 5-24V. The explanation for the ratings is: 1. The lower values (1 mA at 5V) are to make sure that the switch sees enough energy when switching to keep the contacts clean. Any lower values would not guarantee that the contacts will always make proper contact over the life of the switch. If for some reason the load being switched is too low, a resistor could be added in parallel with the load to increase the current to at least 1 mA. 2. The higher values (50 mA at 24V) are the maximum values that should be switched that will not damage the switch. Switching any higher loads will risk damaging the contacts - either welding them shut or warping them or causing excessive arc damage - and will certainly shorten the life of the switch. 3. These ratings are for a resistive load, so if they are to be used with a relay or motor the contacts MUST be protected with a diode or other type of snubber network! Of course, the manufacturer always has a margin in the design so if one chooses to switch 55mA at 14V (for instance), the switch will probably still have a reasonable life. However, pushing them to 100 mA or more will definitely shorten the life and may result in a catastrophic failure at some point. These switches are rated for a lot of actuations so their use in an airplane should be no problem. The hat switches are rated for 300,000 operations (minimum), the switches on the top face of the stick are rated for 100,000 operations (minimum) and the trigger (typically used for push-to-talk) is rated for 1,000,000 operations (minimum). To put these numbers in perspective, let's assume you make one flight every day for ten years. For each flight you could use the hat switch to trim the airplane 82 times in each direction, you could actuate the flaps (assuming that is what you use the two gray switches on the top of the stick for) 27 times each up and down and you could push-to-talk 274 times. I am satisfied that the switches used are as robust as you will find and the ratings are adequate for the task. Just don't go overboard on what you connect direct to the switches and your CH Products control stick will have a long and happy life! Dick Tasker ________________________________________________________________________________
Date: Nov 11, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> behaviour
Subject: Re: Fw : Understanding strange LVWM
behaviour behaviour >Bob, > >Hope you won't mind my posting a copy of my previous message about my LVWM >mystery, as it may have got through unnoticed. >Any suggestions as to where to direct the investigation ? >If necessary I can resend the diagram pictures. > >Thanks in advance >Best regards, >Gilles No problem. >=================================================== >We started our engine last week. Everything electric worked beautifully >thanks to your help and knowledge. > >There is only one minor bug I'm unable to fix. > >The engine is a Rotax 914. The circuit is wired as per figure Z 16 with an >auxiliary battery, an auxiliary battery management module from Eric Jones, >and a low voltage warning module AEC 9005-201 for the aux battery. >The low voltage warning module is controlled by a small relay to avoid >constant illumination of the annunciator when the power is off. I'm lost. I don't understand why you have a second auxiliary battery management module installed along with the low voltage warning module. Aux battery management is built into the AEC9005 product. >For reasons unknown to me I can't seem to have this aux battery Low Volts >light work as expected (the module works OK on the bench). > >- When the master is ON (engine OFF), the Main Bat light works, but the Aux >Bat light doesn't. I was expecting to have both lights illuminate when their >respective battery voltage is below 13 V. I'm not sure I'm visualizing your wiring correctly. If you tried to send me some attachements in a direct e-mail, I don't see them in either my old in-files or trash-files. Try sending them again to the b.nuckolls_at_cox.net account. >- When the E-Bus switch is ON and the Master OFF, the Aux Bat light >illuminates but not the Main Bat light, which is normal. > >- During the tests I noticed the Aux Bat light illuminates briefly when I >switch the Master OFF. I'll have to see your schematics to be of any real assistance. Bob . . . ________________________________________________________________________________
Subject: Antenna Ground Planes on Carbon Fiber
Date: Nov 11, 2004
I am getting ready to install the ground plane for my transponder antenna mounted on the bottom outside on a Lancair IV-P. The manual calls for a 12 inch round ground plane installed on the inside of the aircraft, between the gear legs. A week or so ago, there was a post that said that the ground plane for the transponder should be 5.2 inches in diameter. I have two questions: Is there anything to be gained by going to a 12 inch ground plane as opposed to the 5.2 inch diameter specified in the post and does it make any difference on a carbon fiber aircraft whether the ground plane is located on the inside or outside of the skin? Giff Marr LIV-P/20B 28% ________________________________________________________________________________
Subject: Re: Fw : Understanding strange LVWM behaviour
Date: Nov 11, 2004
Bob, Thank you for your help. ...... a low voltage warning module AEC 9005-201 for the aux battery. > >The low voltage warning module is controlled by a small relay to avoid > >constant illumination of the annunciator when the power is off. > > I'm lost. I don't understand why you have a second auxiliary battery > management module installed along with the low voltage warning module. > Aux battery management is built into the AEC9005 product. There is only one battery management module, and it works as expected. The AEC 9005-201 doesn't have a battery management capablility but only a low voltage warning feature capable of switching an annunciator. I'd like to have it monitor the aux battery voltage. ......... Try sending > them again to the b.nuckolls_at_cox.net account. > I'm sending them again. Best regards, Gilles ________________________________________________________________________________
Subject: 406 Mhz GPS ELT
Date: Nov 11, 2004
AeroElectric-List message previously posted by: Mickey Coggins < ... For my money, if I wanted an ELT that REALLY > works, I'd go for the GPS aided location option as well. > This ELT broadcasts your exact location which has a lot > better resolution than satellite based locator system.>> 11/1/2004 Hello Mickey, I don't think that a practical, affordable, GPS reporting, TSO-C126 approved, 406 Mhz ELT compatible with a 12 volt airplane exists. I'd love to be proved wrong. Let us know what you find. You can start your search here <<http://www.cospas-sarsat.org/Beacons/typeApprovedListByManufacturer.htm>> and move on to the various manufacturers listed. Be very precise / meticulous in your search -- you are entering a swamp with many diverting alligators. Realize that you are looking for an ELT, not just a beacon. OC ________________________________________________________________________________
Date: Nov 11, 2004
Try http://www.artex.net/3_freq_beacons.html, bring your wallet. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: 406 Mhz GPS ELT AeroElectric-List message previously posted by: Mickey Coggins < ... For my money, if I wanted an ELT that REALLY > works, I'd go for the GPS aided location option as well. > This ELT broadcasts your exact location which has a lot > better resolution than satellite based locator system.>> 11/1/2004 Hello Mickey, I don't think that a practical, affordable, GPS reporting, TSO-C126 approved, 406 Mhz ELT compatible with a 12 volt airplane exists. I'd love to be proved wrong. Let us know what you find. You can start your search here <<http://www.cospas-sarsat.org/Beacons/typeApprovedListByManufacturer.ht m>> and move on to the various manufacturers listed. Be very precise / meticulous in your search -- you are entering a swamp with many diverting alligators. Realize that you are looking for an ELT, not just a beacon. OC ________________________________________________________________________________
Date: Nov 11, 2004
I found the worthless harness and will send it. I did not get any jacks from you because I told you that I had already installed them and would not need more. Tom -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: 406 Mhz GPS ELT AeroElectric-List message previously posted by: Mickey Coggins < ... For my money, if I wanted an ELT that REALLY > works, I'd go for the GPS aided location option as well. > This ELT broadcasts your exact location which has a lot > better resolution than satellite based locator system.>> 11/1/2004 Hello Mickey, I don't think that a practical, affordable, GPS reporting, TSO-C126 approved, 406 Mhz ELT compatible with a 12 volt airplane exists. I'd love to be proved wrong. Let us know what you find. You can start your search here <<http://www.cospas-sarsat.org/Beacons/typeApprovedListByManufacturer.htm>> and move on to the various manufacturers listed. Be very precise / meticulous in your search -- you are entering a swamp with many diverting alligators. Realize that you are looking for an ELT, not just a beacon. OC ________________________________________________________________________________
From: "Kingsley Hurst" <khurst(at)taroom.qld.gov.au>
Subject: Strobe Ground Circuit Question
Date: Nov 12, 2004
Bob et al I have a Kuntzleman Strobe and in reading the 'Noise Trouble Shooting Guide' supplied with the kit, it says QUOTE "The ground path is very, very important. The strobe circuit draws high current through the ground circuit." END QUOTE Since I have always understood the current is the same in both the feed and ground circuits, could someone please enlighten me as to what is meant by the 'high current through the ground circuit'. I don't have the unit completely installed yet so don't have any noise problems, just trying to understand ! Thanks all Kingsley Hurst Europa Mono Classic 281 in Oz. ________________________________________________________________________________
Date: Nov 11, 2004
Eric and Bob, Thanks for the responses. The Taxi and Landing lights are the only filament bulbs I plan to have, and they will be halogen. The good news is that they are cheap and do seem to last a long time. I can't remember the last time I replaced one on a car. The hassle of replacing it is worse than the part cost. So scratch the keep warm circuit. Minimizing inrush current seems like a good idea, so I'll look into thermistors and soft start circuits - any pointers would be welcomed of course! Dennis Glaeser ________________________________________________________________________________
Date: Nov 11, 2004
Subject: Re: Strobe power supply grounding
> > >I'm installing a Nova Electronics Superpak 906 >strobe power supply in my RV, and the installation >instructions say, with emphasis: > >Note: The power supply baseplate must be connected to >chassis ground (GND) to reduce radio interference. > >Since there is also a ground wire with the power wire, >wouldn't it actually cause *more* noise to do this, since >the device would be grounded in two different places? > >Seems to me like it would it be better to electrically >isolate the baseplate, and run a ground wire from it >back to the airplane common ground. Am I missing >something here? > >Thanks for your advice. Many electronic devices for aircraft have separate power and chassis ground connections. The chassis ground is for RFI/Shielding and the power ground is separated so that the designer can utilize a remote power ground IF the system calls for it. In this case, the case gets grounded to airframe in a metal airplane and, as we've already discussed, it's okay to get your power ground remotely for the strobes, pitot heat, landing, taxi and nav lights. Where major benefits are realized is for single point, firewall grounding of potential victims (mostly panel mounted stuff). Take the strobe supply ground to one of the same bolts that holds the strobe to the airplane. Bob . . . ________________________________________________________________________________
Date: Nov 11, 2004
Mickey, Here is a pic of the strobe power pak. http://bowenaero.com/mt3/archives/2003/01/ap_servo_strobe.html - Larry Bowen Larry(at)BowenAero.com http://BowenAero.com > -----Original Message----- > From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > Sent: Thursday, November 11, 2004 2:22 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Strobe power supply grounding > > --> > > Hi Larry, > > That's good info. I searched for 'strobe' on your site but > didn't find anything. Can you tell me where you mounted your > strobe power supply, and where you put your "central" ground? > > Best regards, > Mickey > > At 20:02 11-11-04, Larry Bowen wrote: > -----Start of Original Message----- > >--> > > > >I have the same power supply. I followed the directions and > have no noise. > >That's all I can offer. > > > >- > >Larry Bowen, RV-8 23.5 hrs. > >Larry(at)BowenAero.com > >http://BowenAero.com > > > > > >> -----Original Message----- > >> From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > >> Sent: Thursday, November 11, 2004 9:31 AM > >> To: aeroelectric-list(at)matronics.com > >> Subject: AeroElectric-List: Strobe power supply grounding > >> > >> --> > >> > >> I'm installing a Nova Electronics Superpak 906 strobe > power supply in > >> my RV, and the installation instructions say, with emphasis: > >> > >> Note: The power supply baseplate must be connected to > chassis ground > >> (GND) to reduce radio interference. > >> > >> Since there is also a ground wire with the power wire, wouldn't it > >> actually cause *more* noise to do this, since the device would be > >> grounded in two different places? > >> > >> Seems to me like it would it be better to electrically isolate the > >> baseplate, and run a ground wire from it back to the > airplane common > >> ground. Am I missing something here? > >> > >> Thanks for your advice. > >> > -----End of Original Message----- > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 QB Wings/Fuselage > > > ========= > ========= > Matronics Forums. > ========= > http://www.matronics.com/FAQ/AeroElectric-List.htm > ========= > > > > > > ________________________________________________________________________________
Date: Nov 11, 2004
>From: glaesers (glaesers(at)wideopenwest.com) >Minimizing inrush current seems like a good idea, so I'll look into >thermistors and soft start circuits - any pointers would be welcomed of >course! Dennis Glaeser The standard method of limiting current inrush is with a Thermometrics Inrush Current Limiters. Digikey stocks these in a variety of forms. There are particulars like how much you want to limit the current and how much reduction in current you can accept (there will be some). If you don't want to get too technical: For a 35W lamp--use Digikey KC004L, for a 50W use a KC003L. Remember that these get hot and are supposed to get hot. Don't try to cool them off!--in fact they should be protected from cooling. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net "Everything you've learned in school as "obvious" becomes less and less obvious as you begin to study the universe. For example, there are no solids in the universe. There's not even a suggestion of a solid. There are no absolute con- tinuums. There are no surfaces. There are no straight lines." - R. Buckminster Fuller ________________________________________________________________________________
Date: Nov 12, 2004
Ouch! Looks like I'll be installing a regular ELT, and buying a "handheld" 406 Mhz device. Sure hope these come down in price soon. >Try http://www.artex.net/3_freq_beacons.html, bring your wallet. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: RV 8 roll Trio roll servo install
Date: Nov 12, 2004
you guys with the tru track servos have it made. Seems the Trio/Air Nav roll servo's possible arm orientations and sheer overall size won't allow for installation in there. The only place I see it will fit without modifying the floor panels is up front of the spar on the right side. Anyone else able to fit the Trio servo where Larry but his Try Track servo? > > Mickey, > > Here is a pic of the strobe power pak. > > http://bowenaero.com/mt3/archives/2003/01/ap_servo_strobe.html > > - > Larry Bowen > Larry(at)BowenAero.com > http://BowenAero.com > > > > -----Original Message----- > > From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > > Sent: Thursday, November 11, 2004 2:22 PM > > To: aeroelectric-list(at)matronics.com > > Subject: RE: AeroElectric-List: Strobe power supply grounding > > > > --> > > > > Hi Larry, > > > > That's good info. I searched for 'strobe' on your site but > > didn't find anything. Can you tell me where you mounted your > > strobe power supply, and where you put your "central" ground? > > > > Best regards, > > Mickey > > > > At 20:02 11-11-04, Larry Bowen wrote: > > -----Start of Original Message----- > > >--> > > > > > >I have the same power supply. I followed the directions and > > have no noise. > > >That's all I can offer. > > > > > >- > > >Larry Bowen, RV-8 23.5 hrs. > > >Larry(at)BowenAero.com > > >http://BowenAero.com > > > > > > > > >> -----Original Message----- > > >> From: Mickey Coggins [mailto:mick-matronics(at)rv8.ch] > > >> Sent: Thursday, November 11, 2004 9:31 AM > > >> To: aeroelectric-list(at)matronics.com > > >> Subject: AeroElectric-List: Strobe power supply grounding > > >> > > >> --> > > >> > > >> I'm installing a Nova Electronics Superpak 906 strobe > > power supply in > > >> my RV, and the installation instructions say, with emphasis: > > >> > > >> Note: The power supply baseplate must be connected to > > chassis ground > > >> (GND) to reduce radio interference. > > >> > > >> Since there is also a ground wire with the power wire, wouldn't it > > >> actually cause *more* noise to do this, since the device would be > > >> grounded in two different places? > > >> > > >> Seems to me like it would it be better to electrically isolate the > > >> baseplate, and run a ground wire from it back to the > > airplane common > > >> ground. Am I missing something here? > > >> > > >> Thanks for your advice. > > >> > > -----End of Original Message----- > > > > -- > > Mickey Coggins > > http://www.rv8.ch/ > > #82007 QB Wings/Fuselage > > > > > > ========= > > ========= > > Matronics Forums. > > ========= > > http://www.matronics.com/FAQ/AeroElectric-List.htm > > ========= > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Nov 12, 2004
From: "William Yamokoski" <yamokosk(at)lakemichigancollege.edu>
Subject: Re: Grounding
Hi Folks, In my Glastar, I have two batteries about 10' aft of the firewall. I have each separately connected to the firewall ground stud, the other side of which connects to the engine via a grounding strap. Other than weight reduction, is there any advantage to moving those battery (-) fat wire ground points off the common ground stud and further aft, to the cage itself. I can't think of any electrical advantage, but that's why I ask the experts. Thanks for any input. Bill Yamokoski, N4970Y 415 hrs on the EggenSoob still getting intermittent reports that my radio is unreadable, still wondering why ________________________________________________________________________________
Date: Nov 12, 2004
> > >Hi Folks, > In my Glastar, I have two batteries about 10' aft of the firewall. I > have each separately connected to the firewall ground stud, the other > side of which connects to the engine via a grounding strap. Other than > weight reduction, is there any advantage to moving those battery (-) fat > wire ground points off the common ground stud and further aft, to the > cage itself. I can't think of any electrical advantage, but that's why > I ask the experts. No, what you have is the best from an electrical perspective. > Thanks for any input. >Bill Yamokoski, N4970Y >415 hrs on the EggenSoob >still getting intermittent reports that my radio is unreadable, still >wondering why I'm assuming you've checked antenna SWR. What kind of antenna and were installed. Intermittent complaints can be associated with "holes" in radiation pattern for the antenna. See: http://www.aeroelectric.com/Pictures/Antenna_Pattern.gif A pilot trying to talk on this antenna might get a lot of otherwise unexplainable complaints. Does your radio have a "sidetone" . . . can you hear yourself and do you always hear yourself well in the headsets? Next time ask about "unreadable" Do they mean strong signal but distorted audio or weak signal -AND- audio? Bob . . . ________________________________________________________________________________
Date: Nov 12, 2004
Subject: Re: Strobe Ground Circuit Question
> > >Bob et al > >I have a Kuntzleman Strobe and in reading the 'Noise Trouble Shooting >Guide' supplied with the kit, it says QUOTE "The ground path is very, >very important. The strobe circuit draws high current through the >ground circuit." END QUOTE > >Since I have always understood the current is the same in both the feed >and ground circuits, could someone please enlighten me as to what is >meant by the 'high current through the ground circuit'. I don't have >the unit completely installed yet so don't have any noise problems, just >trying to understand ! They're simply quoting Kirchoff's law that says for every electron going into the system, there'a a companion electron exiting the system . . . I.e. same current in both supply and ground return lines. What you quoted from the instruction manual is a lousy attempt to explain something . . . I wonder if the writer really understands what he's trying to write about. For the composite airplane, you'll need both power and ground return lines to the strobe. Take your (-) power lead from strobe to on of the mounting bolts for the case then come off that same bolt with the ground lead to your single point ground. Run ground and plus leads together for as far as practical before they separate to route to switch and ground stud. If you have a noise problem after doing this, then a filter AT the STROBE supply is called for . . . let's cross that bridge as we come to it. Bob . . . ________________________________________________________________________________
Subject: RE: 406 Mhz GPS ELT
Date: Nov 12, 2004
The reality of the 121.5/243 ELT system is that they will begin to degrade in 2006 (the Russians aren't launching anymore of these satellites). The old system is OFFLINE Feb 2009. Does anyone have a clear description of what is required in OBAM aircraft as far as 406 MHz Emergency Locator Thingies (or whatever)? My guess is not much. There are many more nautical 406 MHz locators. The ACR GlobalFix 406 EPIRB http://store.yahoo.com/landfallnav/globalfix.html can be bought for under $850 in quantity of one. It is possibly to internet together a Buyer's Club to purchase a pallet of these if they are suitable for OBAM aircraft use. Let's see what the price might be and any technical issues before proceeding. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net ________________________________________________________________________________
Subject: ELT Access
Date: Nov 12, 2004
AeroElectric-List message previously posted by: GMC <> 11/12/2004 Hello George, Thanks for your question. Now for a round about answer. I have a very low regard for the investment to return benefit ratio of our presently required ELT's. I felt that they were unwisely forced upon us by the US Congress in a knee jerk reaction to the loss of one of their members in a plane crash in Alaska. So as I was building my airplane I wanted minimal ELT impact. I had my professionally built instrument panel built with no remote ELT control panel. After I purchased my ELT, which included a remote control panel, and got ready to install the ELT without the control panel, I decided to find out if this would be acceptable to the FAA. My research generated a whole bunch of hearsay, gossip, rumor, speculation, opinions, beliefs, etc. indicating that the remote control panel was required, but I could not nail down the specifics of that requirement. So I made a last minute install of the control panel in a manner that was acceptable to me, but I wasn't entirely happy because the remote panel installation was not part of my overall design concept. Came the time of my very first test flight and I could not fly because every time I keyed my number one VHF communication radio the ELT was activated. I was able to shut down the ELT with the remote panel switch and taxi back to my hangar. I disconnected the ELT and flew without it (this is legal) for that flight. Before my second flight I moved the ELT antenna a bit further away from the number one VHF communication antenna and rotated the ELT antenna ninety degrees. This solved that inadvertant ELT activation problem. Several weeks later I was returning to the airport and using my number two VHF communication radio for the very first time (it had been off to Garmin for repair). My ELT was activated when I made my very first transmission on tower frequency. This was very disruptive, but I was able to shut my ELT down very quickly with the remote panel switch. This particular activation scenario has never happened again. When I performed my first annual inspection of the ELT (required by FAR Sec 91.207 (d)) I found the remote switch to be pretty useful. One of our local Lancair 360 builders had inadvertant ELT activiation that he attributed to VHF communication wiring being in proximity to some ELT wiring. His remote ELT control switch was useful in shutting down his ELT. So I am a convert -- if one must have an ELT then the current regulatory requirement (I believe that requirement exists even though I have not yet seen it with my own eyes) for pilot access and control from the cockpit is a good thing. I hope this answers your question. OC PS: I am not philosophically opposed to an ELT that would justify the return on the investment. I think that a compatible (with our 12 volt airplanes), practical, affordable, 406 Mhz ELT, preferably with GPS location capability, would be a great thing. If it exists, I can't find it. PPS: In anticipation of a forced landing (crash) and survival situation (been there, done that) one should always have with them a portable handheld VHF radio with fresh / unused batteries (don't depend upon old rechargeable batteries). Some may find great comfort in also carrying a 406 Mhz EPIRB. See <<http://www.navcen.uscg.gov/marcomms/gmdss/epirb.htm>> ________________________________________________________________________________
Date: Nov 12, 2004
> >Hi Folks, > I can't think of any electrical advantage, but that's why > I ask the experts. No, what you have is the best from an electrical perspective. Thanks very much. I'm assuming you've checked antenna SWR. That was one of the first things checked a couple of years ago What kind of antenna and were installed. Intermittent complaints can be associated with "holes" in radiation pattern for the antenna. See: http://www.aeroelectric.com/Pictures/Antenna_Pattern.gif A pilot trying to talk on this antenna might get a lot of otherwise unexplainable complaints. I have a copper strip dipole mounted in the vertical stabilizer. The strip is not exactly vertical....it pretty much parallels the slope of the leading edge of the vertical stabilizer Does your radio have a "sidetone" . . . can you hear yourself and do you always hear yourself well in the headsets? MicroAir 760. It does have a sidetone, which I have turned down to the point where I can hear myself consistently and well in the headsets. At the factory setting there was a strong "echo" effect in the headsets. This went away when I turned the sidetone down a bit. Next time ask about "unreadable" Do they mean strong signal but distorted audio or weak signal -AND- audio? The signal is strong but distorted Would there be much point in trying a different antenna? Thanks for all the help Bill Yamokoski ________________________________________________________________________________
Date: Nov 12, 2004
Subject: Re: RE: 406 Mhz GPS ELT
Eric_ we'd probably want to work out an impact-activation feature for the ELT (rather than water immersion or manual "on" only, right? -Bill B ________________________________________________________________________________
Date: Nov 12, 2004
On Nov 12, 2004, at 11:57 AM, Eric M. Jones wrote: > > > The reality of the 121.5/243 ELT system is that they will begin to > degrade > in 2006 (the Russians aren't launching anymore of these satellites). > The old > system is OFFLINE Feb 2009. > > Does anyone have a clear description of what is required in OBAM > aircraft as > far as 406 MHz Emergency Locator Thingies (or whatever)? The real problem is not whether a 406MHz EPIRB would be suitable and would help people to find you should you go down. That they do very well and certainly meet the spirit of the law. The problem is whether or not they meet the letter of the law which, as we know, has nothing to do with actually getting the job done. The 121.5MHz/243MHz ELT which does such a poor job of helping people find you meets the letter of the law and makes FAA types happy whether or not it actually performs the desired function. I don't know whether any of the very fine and inexpensive 406MHz EPIRBs available from various sources for somewhat reasonable prices also would. Guessing from experience with the FAA I would have to guess that they do not since they cost way too little to have the FAA certification surcharge built into their price. So, if it doesn't cost wildly too much, it probably does not have FAA approval. And, yes, I am jaded. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Date: Nov 12, 2004
At 09:32 AM 11/12/04, you wrote: >The 121.5MHz/243MHz ELT which does such a poor job of helping people >find you meets the letter of the law and makes FAA types happy whether >or not it actually performs the desired function. I don't know whether >any of the very fine and inexpensive 406MHz EPIRBs available from >various sources for somewhat reasonable prices also would. Guessing >from experience with the FAA I would have to guess that they do not >since they cost way too little to have the FAA certification surcharge >built into their price. So, you buy an inexpensive 406 MHz EPIRB with built in GPS, and two cheap 121.5 ELT's off EBAY. Put new batteries in on of the ELT and mount it in the airplane. Salvage the impact switch from the second, hack it into the manual "on" switch of the EPIRB. Tuck it in a box that just happens to be the right size to hold it. ________________________________________________________________________________
Date: Nov 12, 2004
On Nov 12, 2004, at 1:57 PM, Richard Riley wrote: > > > At 09:32 AM 11/12/04, you wrote: >> The 121.5MHz/243MHz ELT which does such a poor job of helping people >> find you meets the letter of the law and makes FAA types happy whether >> or not it actually performs the desired function. I don't know >> whether >> any of the very fine and inexpensive 406MHz EPIRBs available from >> various sources for somewhat reasonable prices also would. Guessing >> from experience with the FAA I would have to guess that they do not >> since they cost way too little to have the FAA certification surcharge >> built into their price. > > So, you buy an inexpensive 406 MHz EPIRB with built in GPS, and two > cheap > 121.5 ELT's off EBAY. > > Put new batteries in on of the ELT and mount it in the airplane. > Salvage > the impact switch from the second, hack it into the manual "on" switch > of > the EPIRB. Tuck it in a box that just happens to be the right size > to > hold it. That seems like quite a sensible approach! OTOH, I would tend to want to disable the "operational" ELT to keep it from generating false alerts. The remote control switch on the panel that has positions "off/arm/on" might prove to be useful for that purpose. Brian Lloyd 6501 Red Hook Plaza brianl(at)lloyd.com Suite 201 +1.340.998.9447 St. Thomas, VI 00802 There is a time to laud one's country and a time to protest. A good citizen is prepared to do either as the need arises. ________________________________________________________________________________
Date: Nov 12, 2004
Thanks a lot for the clarification. I'm just starting my wiring, and it is coming along well, mainly thanks to all I've learned from your book and the list. I'm really enjoying it. Best regards, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=YyVgDmZaNVrvg7P+8Pp4siUvND57e4ryYX3qO6RN37/8v1Wk7b0IKw9eHjzGr2qny2XuLdILrm/boVJWQuEZiYWhLgYRRRCWmmJDPjHAV2Oq5+FqhMxH6EDQQvxQiRmjH5o4ao7mNLmXDfcH0eKz86ZWiRotADQnNNN9FyCuj5s;
Date: Nov 12, 2004
Quick question about Halogens: How well do they survive in a wig-wag setup? is the constant on and off a problem for these bulbs? On a related note, has anyone looked at using clear UltraBrite LEDs as recognition lights? Do these do well with a wig-wag setup? This site is marketing a "taxi" light combined with a strobe that may prove interesting in recognition: https://ssl.perfora.net/gs-air.com/sess/utn;jsessionid=1541956839198eb/shopdata/index.shopscript Dan Fritz --------------------------------- ________________________________________________________________________________
Date: Nov 12, 2004
clamav-milter version 0.80j on pop-7.dnv.wideopenwest.com What the heck, lets get a bit technical (I'm an Aero Engr - so you may have to take it slow ;-) You seem to have selected thermistors rated for about twice the amperage for the light. Based on that, for a 75W bulb I'd use the KC022L. Now since it won't be operating at I-max, the resistance won't be the min value (.02 ohms). So for argument's sake, lets use .03 ohms. That means a voltage drop of .39 (I used 13V for all calculations). 3% doesn't seem so bad. Regarding the inrush current - As the thermistor rated current goes up the initial resistance goes down (some dumb law of physics no doubt). The KC022L's resistance (0.7 ohms) is less than half the bulb's (about 2 ohms). So the bigger the bulb the higher the initial current. How much initial resistance is enough? I guess anything is better than nothing. I'm thinking that limiting the inrush current is as much about being kind to the whole electrical system as it is about bulb life - am I out in left field on that? Anyway, they're cheap enough to try. It's wierd to think of something getting hot and going down in resistance - kind of like nichrome wire in an inverse universe! Thanks for your help, Dennis ------------------------ There are particulars like how much you want to limit the current and how much reduction in current you can accept (there will be some). If you don't want to get too technical: For a 35W lamp--use Digikey KC004L, for a 50W use a KC003L. Remember that these get hot and are supposed to get hot. Don't try to cool them off!--in fact they should be protected from cooling. Regards, Eric M. Jones www.PerihelionDesign.com --------------------------- ________________________________________________________________________________
Date: Nov 12, 2004
Seems like it would make sense to certify an impact sensor that could activate the locator of your choice. Then the low volume switch would be the only piece subject to aviation prices and the locator could take advantage of the economies of scale and technical improvements that non-aviation markets enjoy. But no, that would never work. Never mind... Greg > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of SportAV8R(at)aol.com > Sent: Friday, November 12, 2004 11:18 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: RE: 406 Mhz GPS ELT > > > Eric_ we'd probably want to work out an impact-activation > feature for the ELT (rather than water immersion or manual > "on" only, right? > > -Bill B ________________________________________________________________________________
Subject: 406 Mhz GPS ELT cost issues
Date: Nov 12, 2004
As both a pilot and boater in Florida, I suggest that anyone interested in acquiring a 406 MHz ELT or EPIRB pay special attention to the cost of replacing the battery. I have carried a Litton Marine 406 MHz portable EPIRB for the last 8 years, and had the "joy" of getting a replacement battery. At $600 installed, it was a shock even to my certified airplane parts budget. The new ones will obviously be less expensive, but my queries to vendors a Oshkosh and boat shows indicated most dealers haven't the foggiest what the battery replacement procedure or cost will be. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce Gray Subject: RE: AeroElectric-List: 406 Mhz GPS ELT --> Try http://www.artex.net/3_freq_beacons.html, bring your wallet. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: 406 Mhz GPS ELT AeroElectric-List message previously posted by: Mickey Coggins < ... For my money, if I wanted an ELT that REALLY > works, I'd go for the GPS aided location option as well. > This ELT broadcasts your exact location which has a lot better > resolution than satellite based locator system.>> 11/1/2004 Hello Mickey, I don't think that a practical, affordable, GPS reporting, TSO-C126 approved, 406 Mhz ELT compatible with a 12 volt airplane exists. I'd love to be proved wrong. Let us know what you find. You can start your search here <<http://www.cospas-sarsat.org/Beacons/typeApprovedListByManufacturer.ht m>> and move on to the various manufacturers listed. Be very precise / meticulous in your search -- you are entering a swamp with many diverting alligators. Realize that you are looking for an ELT, not just a beacon. OC ________________________________________________________________________________
Date: Nov 12, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Keep warm circuit for Landing/Taxi lights
Actually, if you look at the specific data sheet for these parts: Using 75W @ 13V gives us 5.77A - which is close enough to 50% of the 12A rating. Looking at the data sheet, one finds that the resistance at this current is 0.06 ohms which gives us a voltage drop of 0.35 V. So, your 3% calculation is not far off - although I have no idea what you did to get your numbers. Remember, E=I*R, I=E/R, R=E/I :-) . Actually, based on the vendors data sheet, I would probably choose the next lower size that is rated for 8A max. Using this one, the starting resistance is 1.3 ohms vs 0.7 ohms for the 12A device. The resistance at the operating current is essentially the same so the voltage drop would be the same. As far as your further comments about the 0.7 ohms adding to the bulb's resistance, you are correct that it adds, but your value for the bulb's resistance at start is way off. Your estimate of two ohms is basically correct when the bulb is operating (R=13V/5.77A=2.25ohms). However, before the bulb warms up, its resistance is less than 0.5 ohm (probably much less but I do not have a milliohmeter to measure it accurately). That means that you are reducing the inrush current by a factor of (0.7 + 0.5) /0.5 or almost 2.5 times - probably more if we knew the actual start resistance. So we are limiting the inrush current to approximately: I = 13V / 1.2 ohms = 10.8A Much better than: I = 13V / 0.5 ohms = 26A! Or, if you use the next lower rated limiter you can limit the current to: I = 13V / (1.3 + 0.7) ohms = 6.5A Not much more than the steady state current of 5.77A. The reason for using current limiters is, as you suggested, as much to be gentle on your electrical system (not to good to use a 15A switch to turn on a bulb with a 26A surge, but fine for a 10.8A surge) as to increase the life of your bulb by limiting the shock of turning it on. Dick Tasker glaesers wrote: > >What the heck, lets get a bit technical (I'm an Aero Engr - so you may have >to take it slow ;-) > >You seem to have selected thermistors rated for about twice the amperage for >the light. >Based on that, for a 75W bulb I'd use the KC022L. Now since it won't be >operating at I-max, the resistance won't be the min value (.02 ohms). So >for argument's sake, lets use .03 ohms. That means a voltage drop of .39 (I >used 13V for all calculations). 3% doesn't seem so bad. > >Regarding the inrush current - As the thermistor rated current goes up the >initial resistance goes down (some dumb law of physics no doubt). The >KC022L's resistance (0.7 ohms) is less than half the bulb's (about 2 ohms). >So the bigger the bulb the higher the initial current. How much initial >resistance is enough? I guess anything is better than nothing. > >I'm thinking that limiting the inrush current is as much about being kind to >the whole electrical system as it is about bulb life - am I out in left >field on that? Anyway, they're cheap enough to try. > >It's wierd to think of something getting hot and going down in resistance - >kind of like nichrome wire in an inverse universe! > >Thanks for your help, > > Dennis > >------------------------ >There are particulars like how much you want to limit the current and how >much reduction in current you can accept (there will be some). > >If you don't want to get too technical: For a 35W lamp--use Digikey KC004L, >for a 50W use a KC003L. >Remember that these get hot and are supposed to get hot. Don't try to cool >them off!--in fact they should be protected from cooling. > >Regards, >Eric M. Jones >www.PerihelionDesign.com >--------------------------- > > > > ________________________________________________________________________________
Date: Nov 13, 2004
From: "Ronald J. Parigoris" <rparigor(at)SUFFOLK.LIB.NY.US>
Subject: 914 second alternator?
I was looking through aircraft spruce tonight and saw a 8 amp permanent magnet alternator. http://www.aircraftspruce.com/catalog/eppages/sdaltreg.php Would this work on a vacuum pad on a rotax 914 and put out rated amps? If I were to run second fuel pump from this and a 2 amp strobe power supply, what sort of battery would be needed? Could you get away with no battery? If not any other ideas? This is for a Europa XS. Thx. Ron Parigoris ________________________________________________________________________________
Date: Nov 13, 2004
From: Mickey Coggins <mick-matronics(at)rv8.ch> lights
lights lights Hi Dan, Good find. I think the taxi light, facing aft, would make a great tail light. One on the top of the rudder, and the other on the bottom would rock. Too bad I've already purchased a power sucking A500 for over 150 USD. Mickey >On a related note, has anyone looked at using clear UltraBrite LEDs as recognition lights? Do these do well with a wig-wag setup? This site is marketing a "taxi" light combined with a strobe that may prove interesting in recognition: > >https://ssl.perfora.net/gs-air.com/sess/utn;jsessionid=1541956839198eb/shopdata/index.shopscript > >Dan Fritz -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage ________________________________________________________________________________
Subject: Rotax 914, dual alt
Date: Nov 13, 2004
Hi Bob and all I am working on a Dyn Aero MCR 4S, to be equipped for IFR flying (ad-hoc avionics, pitot heat...), powered by a Rotax 914 (electrically dependant). I know the Rotax alt won't deliver enough power for all my stuff. So I need to add a second alternator. I don't have enough room in the cowling to put a belt driven one, so my only reasonable option is the SD 20. With the vacuum pump pad turning at 0.54 the engine rpm, it could nearly deliver 20 amp at 5200 RPM, which is not so bad. Well, I studied all your wiring diagrams in appendix Z, and none consider using the rotax alternator, a second alternator running permanently, and 1 battery. I realise the Z-14 is best of the best, but I'd really rather have only 1 battery. The Z-16, with the 2nd alt wired as per Z-13 would fit my needs, but what about the compatibility of both alt running at same time ? Is it possible to keep the OV module on the Rotax alt, and also benefit from the LR3 OV protection ? If an OV occurs, how to know from which regulator it comes ? Finally, what kind of wiring diagram seems to you to be most appropriate to my situation ? Thanks in advance for your help Manuel Bonniot Luxembourg ________________________________________________________________________________
Date: Nov 13, 2004
Subject: Re: Stall Horn
In a message dated 11/8/2004 1:38:54 PM Eastern Standard Time, czechsix(at)juno.com writes: Guys, Does anyone know of a source for a cheap stall warning horn similar in sound to what's used on spam cans? I made my own spam-style stall vane/tab that I'm putting in the LE of the wing. I bought a piezo alarm from Digikey for something like $1 but it sounds like a fire alarm....it's a bit more shrill and shocking than I want. Aircraft Spruce sells a Safe Flight stall horn with light for $740.00. You read that right...$740! That doesn't include the vane. So anyway, if somebody knows of a non-aircraft source for such a beastie please let me know... Thanks, --Mark Navratil Cedar Rapids, Iowa RV-8A N2D wiring... Mark, take a look at this one: (Radio Shack #273-055) _http://www.radioshack.com/category.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F003%5F0 00&Page=2_ (http://www.radioshack.com/category.asp?catalog_name=CTLG&category_name=CTLG_011_002_003_000&Page=2) it's not a piezo but, a mechanical buzzer. If mounted in the right place and on the right material, it can make a lot of racket similar to what you are familiar with in a spam can. Question is, will it survive the A/C environment? John P. Marzluf Columbus, Ohio Kitfox Outback (out back in the garage) ________________________________________________________________________________
Date: Nov 13, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> lights
lights lights > > >Actually, if you look at the specific data sheet for these parts: > >Using 75W @ 13V gives us 5.77A - which is close enough to 50% of the 12A >rating. Looking at the data sheet, one finds that the resistance at >this current is 0.06 ohms which gives us a voltage drop of 0.35 V. So, >your 3% calculation is not far off - although I have no idea what you >did to get your numbers. Remember, E=I*R, I=E/R, R=E/I :-) . > >Actually, based on the vendors data sheet, I would probably choose the >next lower size that is rated for 8A max. Using this one, the starting >resistance is 1.3 ohms vs 0.7 ohms for the 12A device. The resistance >at the operating current is essentially the same so the voltage drop >would be the same. Are you interpreting those data values right? These devices have a HIGHER cold resistance than HOT resistance. The I think the numbers you've quoted above are the cold values. This means that when you add 1.3 + wiring + lamp resistance all together, you get about 2 ohms total. Now calculate inrush at about 7A. After the limiter warms up. About two seconds. It's hot resitance should be about 0.1 ohms or less. When the lamp is drawing 5A, then drop across the limiter should be about .5 volts or less. Bo0b . . . ________________________________________________________________________________
Date: Nov 13, 2004
Since I was sworn to absolute secrecy on this, I only posted it on my website. But this looks like the ticket. Prices (I hope) soon. http://www.periheliondesign.com/AeroFix%20FCC%20Approved.pdf Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 Phone (508) 764-2072 Email: emjones(at)charter.net "Doctors are the same as lawyers; the only difference is that lawyers merely rob you, whereas doctors rob you and kill you too." ~ Anton Chekhov ________________________________________________________________________________
Date: Nov 13, 2004
clamav-milter version 0.80j on pop-7.dnv.wideopenwest.com Dick, Thanks for a more complete analysis. I rounded more than you did, so I'm pleased my numbers are as close to yours as they are. I had no clue what to use for a starting resistance for the bulb, so my education is one notch higher. I was also thinking of the next lower size, but wasn't sure about running it closer to it's I-max. Is longevity an issue for things like this that run so hot? For the occasional and relatively short time those lights are on, it's probably a non-issue. Thanks again, Dennis Glaeser ________________________________________________________________________________
Date: Nov 13, 2004
AeroElectric-List message previously posted by: "Eric M. Jones" The reality of the 121.5/243 ELT system is that they will begin to degrade in 2006 (the Russians aren't launching anymore of these satellites). The old system is OFFLINE Feb 2009. Does anyone have a clear description of what is required in OBAM aircraft as far as 406 MHz Emergency Locator Thingies (or whatever)? My guess is not much. There are many more nautical 406 MHz locators. The ACR GlobalFix 406 EPIRB http://store.yahoo.com/landfallnav/globalfix.html can be bought for under $850 in quantity of one. It is possibly to internet together a Buyer's Club to purchase a pallet of these if they are suitable for OBAM aircraft use. Let's see what the price might be and any technical issues before proceeding. Regards, Eric M. Jones 11/13/2004 Hello Eric and Others, There seems to be a great lack of understanding on the subject of ELT's and 406 Mhz ELT's in particular. Let's see if we can create a list of simple factual statements that will reduce the amount of time being spent on conjuring up a 406 Mhz ELT for amateur built experimental aircraft. 1) FAR Sec 1.1 QUOTE: Approved, unless used with reference to another person, means approved by the Administrator. UNQUOTE 2) FAR Sec 91.207 says airplanes must have QUOTE: .....attached to the airplane an approved automatic type emergency locator transmitter that is in operable condition for the following operations.....UNQUOTE. (Some exceptions are permitted.) 3) *automatic type* means activated by a sensing switch upon impact such as in an airplane crash. A manually activated Emergency Position Indicating Radiobeacon (EPIRB) would not be an approved ELT. 4) TSO C126, 406 MHz Emergency Locator Transmitter (ELT), is the normal method the FAA uses to determine that such an ELT is approved. In theory the FAA permits alternate methods of approval, but in the case of a device like a 406 Mhz ELT that interfaces extensively with equipment outside the airplane an alternate approval method would be very expensive and time consuming. Just take a look at TSO C126 and, if you can get them, the referenced RTCA DO documents. 5) The presently available 406 Mhz ELT's are expensive. Aircraft Spruce lists the Artex G406-4 model for $1,456.95. 6) If one desires GPS input to the ELT additional expense and hardware is involved. 7) The GPS input hardware to the Artex 406 Mhz ELT's requires 28 volts. 8) The airworthiness inspector at the initial inspection of an amateur built experimental aircraft would most likely require that an approved ELT be installed. (With a remote control capability from the cockpit, but that is another thread). This *approved* requirement exists because: a) There is no exception for amateur built experimental aircraft from the FAR Sec 91.207 ELT requirement. b) The ELT equipment in the aircraft is expected to operate with external to the aircraft equipment such as the satellites for the SARSAT System without creating any interference to that system or other aircraft.## There does not appear to be a readily available, inexpensive, cookbook approach to putting 406 Mhz ELT's into our amateur built experimental aircraft. I welcome additional useful factual additions to the above list. OC ##PS: I make this point because not every item in the amateur built experimental aircraft fulfilling a FAR requirement for approved equipment must, in fact, be approved. Seat belts and shoulder harnesses are two items in this category. You must have them, but they need not be approved by TSO or otherwise. ________________________________________________________________________________
Subject: Re: Antenna Ground Planes on Carbon Fiber
Date: Nov 13, 2004
> > I am getting ready to install the ground plane for my transponder > antenna mounted on the bottom outside on a Lancair IV-P. > The manual calls for a 12 inch round ground plane installed on > the inside of the aircraft, between the gear legs. A week or so > ago, there was a post that said that the ground plane for the > transponder should be 5.2 inches in diameter. I have two > questions: > Is there anything to be gained by going to a 12 inch ground > plane as opposed to the 5.2 inch diameter specified in the post > and does it make any difference on a carbon fiber aircraft > whether the ground plane is located on the inside or outside of > the skin? > Narco also says, for nonmetal aircraft skin, use a minimum 12" diameter ground plane. I would presume they know what's best to tell transponder installers, and it's probable that once beyond some radius referenced to 1/4 wavelength -- 2.6" with the fudge factor, it doesn't matter much. I'll propose also that affixing it to carbon fiber skin, whether electrically bonded to the actual black stuff or not, makes it further moot. I've fiddled with a crude test setup at VHF frequencies and a monopole antenna, using an antenna analyzer. Yes, there was an effect to adding black cloth larger than the 1/4 wave length ground plane. It appeared similar on either side of the foil ground plane -- simulating it being either inside or outside the A/C -- but nothing to write home about. Reg, Fred F. ________________________________________________________________________________
Date: Nov 13, 2004
Uumm, yes... What about my discussion leads you to think that I calculated it incorrectly? When I said that "The resistance at the operating current is essentially the same so the voltage drop would be the same.", I meant the same as the higher rated unit. Sorry if that was unclear. Dick Robert L. Nuckolls, III wrote: lights > > > >> >> >>Actually, if you look at the specific data sheet for these parts: >> >>Using 75W @ 13V gives us 5.77A - which is close enough to 50% of the 12A >>rating. Looking at the data sheet, one finds that the resistance at >>this current is 0.06 ohms which gives us a voltage drop of 0.35 V. So, >>your 3% calculation is not far off - although I have no idea what you >>did to get your numbers. Remember, E=I*R, I=E/R, R=E/I :-) . >> >>Actually, based on the vendors data sheet, I would probably choose the >>next lower size that is rated for 8A max. Using this one, the starting >>resistance is 1.3 ohms vs 0.7 ohms for the 12A device. The resistance >>at the operating current is essentially the same so the voltage drop >>would be the same. >> >> > > Are you interpreting those data values right? These devices have a HIGHER >cold > resistance than HOT resistance. The I think the numbers you've quoted > above are the cold values. This means that when you add 1.3 + wiring + > lamp resistance all together, you get about 2 ohms total. Now calculate > inrush at about 7A. After the limiter warms up. About two seconds. It's > hot resitance should be about 0.1 ohms or less. When the lamp is drawing > 5A, then drop across the limiter should be about .5 volts or less. > > Bo0b . . . > > > > ________________________________________________________________________________
Subject: Re: ectric-List:AOA was Stall Horn
Date: Nov 13, 2004
Its an interesting statement where facts are taken out of context and a conclusion made that only "mine works". Sadly your conclusion is incorrect. Its one thing to suggest your system is the greatest (OK; its just advertising) but to suggest that the other competing systems do not work is "at best not nice" as its simply incorrect to suggest that. I am a retired Aeronautical engineer (aerodynamics area) and some 5 years ago was interested in developing a "AOA" indicator for my personal aircraft as well as potentially a very low cost system for use in the experimental aircraft market. My comments are intentionally worded to allow non engineers to understand my point and as such, are not always precise engineering. BTW I determined that a minimal featured system could be sold for under $200 (and still can be). First, what is needed is an indication is the amount of lift remaining, not a really precision Angle of Attack (AOA). There are many ways to sense the relative AOA in a manner that provides the pilot info on how close the aircraft is to a stall but also above stall in some "linear" indicator so regardless of the aircraft load (pilot and low fuel vs. many passengers and fuel) the pilot can determine the correct approach speed for the aircraft weight. While the AOA associated with stalling is constant, the speed that the stall occurs goes up with wing loading. The classical stall warning horn is not suitable for approach speed control as its "all or nothing" and generally set too close to the real stall to be useful. Without a good AOA indicator the pilot must guess how much faster the approach speed must be under full load vs. near empty. This also works well in determining just when to pull back (rotate) on Take off :-) It's also important to note that there are hundreds of different wing airfoils and the stalling AOA of each case can and does vary some what and, over a large range in some used airfoils. Thus there is not one size fits all "AOA" and each aircraft needs to be individually calibrated Not to suggest that once a RV6 is calibrated that all RV6 aircraft can use the same cals. However what worked on a Cessna will not necessarily work for a RV etc. Now to some basics. You have the complex system of pressure difference and computer equations to a really fine job but its "in my opinion" a great overkill for many. To state, as the following post states, this is the only one that works (not at all true); there are other systems that also work quite well. The classical vane below the wing (Right Angle) and the fixed probe (Lift Reserve), as well as the third port on the Dynon Pitot head for example. Pitot heads work well in cruise flight but have increasing airspeed errors as the real AOA of the head mounted on the wing increases into the stalling angle. This error is significant at 10 degrees in many heads and with the stalling AOA usually above that, the pitot error is large as the stall AOA is reached. This error is used by Dynon to determine the approach to stall indication (with a third sensor port). My point is that your statement that the airflow is nearly parallel to the wing as its gets very close is correct but 6" or more away from the wing the airflow is not parallel and can be and is used to determine relative AOA which is reliable info for the intended purpose of determining the relative AOA for best safe approach speed. The C150/172 has a very large airspeed error at the stall (using the conventional pitot head). The Piper probe set 4" below the middle of the wing is much more accurate but not zero error. So the moving vane positioned at least 6" below the wing can and does provide a real means of sensing the needed AOA (Further away is better). The Lift reserve system uses a fixed probe with two pressure ports set at different angles and these probes are also around 6" below the wing.The Dynon probe is similar to the lift reserve as it has a third pressure port set on a face below the normal pitot probe. All three of the above systems provide cockpit info on the amount of lift available and thus the ability to adjust the approach speed (for example) to match the aircraft gross weight with the same margin of airspeed. All are far simpler that your system and lower cost and do work well. All also have something sticking out of the wing which your system does not. To some that is a very desirable feature but the end result in info provided to the pilot is essentially the same. Potentially your system is more accurate but as the simple systems are typically more accurate than the average pilots ability to control aircraft attitude, the need for more precision is moot. ANY system is so much better than none, I suggest the proper sales pitch is that everyone needs an AOA system and ours is the best but any is far better than none! I have personally flight tested the moving vane setup on several different aircraft and found it to work well and perform as intended. I have a friend with a Lift Reserve system on his Bonanza and is very pleased with it and as he is a retired airline pilot he knows the value of a AOA system. Either system permits safer flight. These systems are not a glorified airspeed (as you suggest) as they sense and display the real stalling speed margin as it varies with load. Depending on the effectiveness of the flaps there needs to be a flap position feedback to the system as the flaps may produce significant changes in the lift coeficant of the wing. ALL systems are the same in this respect. However the pilot can simply fly a slightly different place on the display and accomplish the result. Not ideal but far better than not having an AOA. I found that even the very effective flaps on the Cessnas could be compensated with flying one bar different on the AOA indicator vs flap position compensation (Nice feature but not a requirement!). If you fly an aircraft where the gross weight varies over a small range like a single place aircraft there is little need for a AOA system. However as the weight range increases to perhaps as much as the empty weight of the aircraft then its really helpful and many of us feel it is an essential device. I reply to your post only because you have made false/misleading statements about the competition that need a response. There are lower cost systems that do work. ALL systems including yours have advantages and disadvantages. Cost, retrofitability, type of aircraft, etc. all are considerations and one system does not fit all. Having an AOA systerm on ALL general aviation aircraft could be a great safety addition. Paul ----- Original Message ----- From: "Olivier Le Carbonnier" <olcdlm(at)laposte.net> Subject: RE: AeroElectric-List: Stall Horn > > yes but the answer from man from AngleOffAttack is: > ------------------------------ > The difference is that our AOA works. If you think about it, the advantage > of the under wing pitot tube is that the airflow is always flowing about > parallel to the under side of the wing. Because of this the airspeed > indication (IAS) is accurate no matter what the angle of attack (AOA). > Conversely, the under wing is a lousy place for an AOA sensor. This is > because the air changes direction way before it reaches the wing and when > it reaches the wing the airflow is about parallel to the wing surface no > matter what the AOA. > > Now, if you try to fix this by moving the pitot tube further from the wing > to get into undisturbed air, you may improve the AOA sensing ability > somewhat but the IAS now has errors with changes in AOA. Did you ever > wonder why the AOA probes on Airbus airliners are way ahead of the wing on > the nose of the fuselage? They actually have to be one and one half chord > ahead of the wing to get into undisturbed air. > > The beauty of our system is that it senses pressures on the top and bottom > of the wing (aerodynamic sensing) and divides that differential pressure by > the dynamic pressure producing a Cl (coefficient of lift). Those familiar > in the art know that coefficient of lift and AOA vary uniquely with each > other. We avoid the pit falls of both pressure on probe sensing systems > and vane systems. Also you have some redundancy. > > Consequently, we sell more AOAs than all the other AOA folks combined. If > you want an AOA that works, let us know. Our AOA is based on sound > aerodynamic principle . Any other would only be a glorified IAS indicator. > ---------------------------------------------------- > Olivier > > -----Message d'origine----- > De : owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt > Prather > Envoy : mercredi 10 novembre 2004 16:33 > : aeroelectric-list(at)matronics.com > Objet : RE: AeroElectric-List: Stall Horn > > > > > I'll take this opportunity to correct myself a bit.. Aircraft spruce has a > vane style unit for $545 here: > > http://www.aircraftspruce.com/catalog/inpages/aoartangle.php > > It seems they pretty much go up from there. Another option, depending > on how much cool stuff you are going to put in the panel is the Dynon > EFIS. They are having some teething trouble, but I think they'll sort it > out. They offer an AOA pitot probe for $200 (only works with their > EFIS). The total cost would be about $2600 which while a pretty good > value is not cheap. > > http://www.aircraftspruce.com/catalog/avpages/efisd10.php > > Matt- > > > > > > > where ? > > > > Olivier > > > > -----Message d'origine----- > > De : owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de Matt > > Prather > > Envoy : mardi 9 novembre 2004 21:19 > > : aeroelectric-list(at)matronics.com > > Objet : RE: AeroElectric-List: Stall Horn > > > > > > > > > > Not cheap... I have seen them start at $600. > > > > MAP > > > >> > >> > >> why not a AOA ? > >> > >> Olivier LC > >> France > >> ICQ#: 82067330 > >> sanglier(at)laposte.net > >> http://sangliervolant.chez.tiscali.fr Van's RV-8 n81939 wings > >> > >> -----Message d'origine----- > >> De : owner-aeroelectric-list-server(at)matronics.com > >> [mailto:owner-aeroelectric-list-server(at)matronics.com]De la part de > >> czechsix(at)juno.com > >> Envoy : lundi 8 novembre 2004 19:34 > >> : aeroelectric-list(at)matronics.com; rv-list(at)matronics.com > >> Objet : AeroElectric-List: Stall Horn > >> > >> > >> > >> > >> > >> Guys, > >> > >> Does anyone know of a source for a cheap stall warning horn similar in > >> sound to what's used on spam cans? I made my own spam-style stall > >> vane/tab that I'm putting in the LE of the wing. I bought a piezo > >> alarm from Digikey for something like $1 but it sounds like a fire > >> alarm....it's a bit more shrill and shocking than I want. Aircraft > >> Spruce sells a Safe Flight stall horn with light for $740.00. You > >> read that right...$740! That doesn't include the vane. So anyway, if > >> somebody knows of a non-aircraft source for such a beastie please let > >> me know... > >> > >> Thanks, > >> > >> --Mark Navratil > >> Cedar Rapids, Iowa > >> RV-8A N2D wiring... > >> > >> Sign up for Juno Today at http://www.juno.com! > >> Look for special offers at Best Buy stores. > >> > >> > > > > > > ________________________________________________________________________________
Date: Nov 13, 2004
I can't speak from experience (plane is still under construction), but they are designed for this type application and should work fine. Their temperature rating is -50 to 175C. Using their calculations for temperature rise, the 8A rated unit running at 6A would have a temperature rise of 92C. When added to an ambient of 40C (assuming a hot day) gives you 132C - still 43C lower than the maximum allowed temperature. According to their data, the 8A rated unit can handle 6A at temperatures up to 100C before exceeding its design ratings. I believe either would work fine, but your choice. Dick Tasker glaesers wrote: > >Dick, > >Thanks for a more complete analysis. I rounded more than you did, so I'm >pleased my numbers are as close to yours as they are. I had no clue what to >use for a starting resistance for the bulb, so my education is one notch >higher. > >I was also thinking of the next lower size, but wasn't sure about running it >closer to it's I-max. Is longevity an issue for things like this that run >so hot? For the occasional and relatively short time those lights are on, >it's probably a non-issue. > >Thanks again, > > Dennis Glaeser > > > > ________________________________________________________________________________
Subject: Re: 914 second alternator?
Date: Nov 13, 2004
Ronald J. Parigoris wrote: > I was looking through aircraft spruce tonight and saw a 8 amp permanent magnet > alternator. > > Would this work on a vacuum pad on a rotax 914 and put out rated amps? Not enough RPM at cruise, due the gear ratio of the 914 redrive box. I'd figure 5A for planning purposes. Does your 914 have the pump drive kit installed? If not, the drive kit isn't cheap, meaning fair bucks total for just a few extra amps, but I found it easy to install on a new engine. > If I were to run second fuel pump from this and a 2 amp strobe power supply, what sort of > battery would be needed? If you're concerned about the small probability of complete failure of the main electrical system and also the B&C alternator, then you'd want enough reserve capacity to be able to run one fuel pump + maybe engine instrumentation long enough to land someplace fairly soon now. As a practical matter, a 5-7Ah sealed, lead-acid battery is cheap and light, so why fuss over probabilities. > Could you get away with no battery? B&C would have to say if the regulator could be damaged, but still the setup could be noisy enough to cause problems in the avionics. Maybe enough size in an electrolytic capacitor would fix it though. If the idea is also emergency power for one fuel pump and maybe engine instrumentation, upon failure of everything else, at low RPM like on final, the B&C "8 amp" alternator may not enable enough fuel flow. > If not any other ideas? If all you'll run on the B&C setup are the boost/emergency backup pump plus strobes, 2A worth of strobe power doesn't sound like enough light output per FAA rules, meaning for daytime use not worth anything for safety, IMO. So unless you want something for almost-legal and occasional night flight, you could go for day-VFR only. If you want fully redundant power for one pump, it's possible a switchable pack of alkaline D-cells may supply enough (plus the fuel pressure gauge) to be of value. A timed test with the engine not running -- worst case for current draw -- is worth a try. I recall FAA has approved at least one certified plane with such a periodically-replaced alkaline pack to supply IFR backup power to an electric AH gyro, presumably roughly same draw as the 914 fuel pump. Reg, Fred F. ________________________________________________________________________________
Subject: RE: 914 second alternator?
Date: Nov 13, 2004
Check the Europa-List archives for the April-June 2001 timeframe. I posted several lengthy articles on this. Basically, you can add an SD-8 or SD-20 to the Rotax vacuum pump pad, but because the pump drive spins more slowly than AND2000 standards, you will get much less current. The 914 PTO spins even more slowly, with less output. From my posting of 4/27/01 entitled: "Re: Europa_Mail: Speeding up the Rotax 914 Vacuum Pump PTO" "Note the clear knee in the output curves. The SD-8 and 20 are clearly designed for the Lycoming, and, perhaps conveniently, the 912, but on the 914 the SD-8 is down 40% or so at economy cruise, and down 15% at max RPM. The SD-20 is no better than 50% of rating! Note also that at most cruise power settings the Rotax internal generator is producing full output!" This is why Rotax's recommended additional alternator uses a belt off the prop shaft. One Europa builder went so far as to mount a Honda alternator to the rear shaft bearing of the 914 driven by a flexshaft. To get 10A off the Rotax PTO, you need to use an SD-20, but this is an expensive and heavy "solution" that doesn't fit within the Europa cowling. But then, neither does the belt drive alternator. Shaun ________________________________________________________________________________
Subject: Tail Light - Bulb Type?
Date: Nov 13, 2004
Hi all, I've got a little project going and I'm not near the airport to check on this myself. I have Whelan position lights. Could someone please tell me whether the tail light is the type of bulb with the two little nubs (that retain the bulb in the socket) the same distance from the 'end' of the bulb or are they off-set (like the multi-filament break light bulbs)?? Thanks so much!! Jon Finley N90MG Q2 - Subaru EJ-22 DD - 465 Hrs. TT Apple Valley, Minnesota http://www.FinleyWeb.net/Q2Subaru ________________________________________________________________________________
Date: Nov 13, 2004
bakerocb(at)cox.net wrote: > 5) The presently available 406 Mhz ELT's are expensive. Aircraft Spruce lists the Artex G406-4 model for $1,456.95. My plan: Buy the cheapest, sorriest excuse for an ELT that I can get off eBay that will pass the inspection right now.** Upgrade to the 406MHz device when the price becomes more reasonable.*** Carry the cheaper handheld devices on any cross country. **Not being found is somewhat less of a worry for me. I live in the heavily populated Eastern US. ***The assumption is that the price will drop, because the price of electronics always drops. But these are TSO'ed aviation devices. With the FAA watching over them, they don't have to follow the laws of economics that everything else does. -- http://www.ernest.isa-geek.org/ "This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." ________________________________________________________________________________
Date: Nov 13, 2004
clamav-milter version 0.80j on pop-7.dnv.wideopenwest.com Whew - they do get hot! And (6A-squared * .06 ohms) means it's putting out 2.16W. I agree that the 8A unit is the way to go. Any recommendations on physical installation? Would it be better to install it near the light, or at the switch end - or does it matter? Dennis Glaeser I can't speak from experience (plane is still under construction), but they are designed for this type application and should work fine. Their temperature rating is -50 to 175C. Using their calculations for temperature rise, the 8A rated unit running at 6A would have a temperature rise of 92C. When added to an ambient of 40C (assuming a hot day) gives you 132C - still 43C lower than the maximum allowed temperature. According to their data, the 8A rated unit can handle 6A at temperatures up to 100C before exceeding its design ratings. I believe either would work fine, but your choice. Dick Tasker ------------------------------------------ ________________________________________________________________________________
Date: Nov 13, 2004
> >Since I was sworn to absolute secrecy on this, I only posted it on my >website. But this looks like the ticket. Prices (I hope) soon. > >http://www.periheliondesign.com/AeroFix%20FCC%20Approved.pdf That is an interesting device, but it doesn't look like it qualifies as an "approved" ELT. It would need to have a means to automatically activate it, and it would need an airframe mounted antenna at the very least. So, it might be a very useful device to have in your pocket, but you would still need to have an approved ELT. Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://go.phpwebhosting.com/~khorton/rv8/ ________________________________________________________________________________
Date: Nov 13, 2004
In a message dated 11/13/2004 2:51:53 PM Central Standard Time, echristley(at)nc.rr.com writes: My plan: Buy the cheapest, sorriest excuse for an ELT that I can get off eBay that will pass the inspection right now.** Upgrade to the 406MHz device when the price becomes more reasonable.*** Carry the cheaper handheld devices on any cross country. Good Afternoon Ernest, You bring up a very good point. Why should we be forced to carry an ELT at all? Someone earlier said it was forced upon us by a congressman who lost a friend in a survivable accident in Alaska. My recollection is that it was a U. S. Senator from Colorado that shoved it down our throats. I think the name was Dominick or something close to that. I believe his friend died from exposure after a few days when no one was searching for him and I believe the location was here in the lower forty-eight. If not in Colorado, at least, somewhere in the West. Personally, as long as portable radios have been available, I have carried one with me any time that I strayed from heavily traveled byways (like following Highway 66). Anybody but me remember the Baysides? I also carried a high altitude Jeppesen chart that showed what frequencies the air carrier traffic would be using in the area over which I was flying. If I was in good enough shape following the accident to get out the radio, I would have tuned it to the area frequency and waited until I heard somebody give a position report. Believe it or not, we formerly made a lot of such reports. As soon as the report was completed, the plan was to call the aircraft and tell them of my problem. Before 9-11, hardly anybody ever monitored 121.5. You had a much better chance of working a flight that was on center than you did of raising anybody on 121.5. But, I am wandering again. The point I wish to make is that it should be up to us as individuals to make the decision as to how much protection we desire should an unfortunate occurrence befall us. I think my old method was lot better than the ELT solution as it was forced upon us in the early days of such a requirement. I suppose the new 406 with GPS supplementation would be nice to have, but is it really necessary for us to have that much protection from ourselves? I would put in no more than was required to meet the absolute minimum FAA standard. Beyond that, I would carry a handheld Comm unit and a handheld GPS in a small emergency bag that could be easily removed from the aircraft. That is what I do now. With a double supply of batteries for the handhelds, I think I am protected as much as I want to be. I don't give a hoot whether the ELT works or not. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Airpark LL22 Downers Grove, IL 60516 630 985-8502 ________________________________________________________________________________
Subject: Pitot Heat inrush question
Date: Nov 13, 2004
I was thinking (always a dangerous endeavour)... if it is a good idea to use a thermistor to limit the inrush on a landing/taxi light, what about Pitot Heat? It's also just a big (about 100W I think) resistive load, sort of like a light bulb - just not as bright. Or is it... It just so happens that a heated pitot is the one thing I have! (a used Cessna unit - bought on eBay) My multi-meter says it has 2.2 ohms cold. So at 13V, that means 5.9A of current initially. So apparently it is different than a light bulb which has a much lower resistance when cold. If my 100W assumption is correct, then at 13V the current is 7.69A. So that would indicate not much of an inrush is going on, so no thermistor needed. Does this sound right? Thanks, Dennis Glaeser ________________________________________________________________________________
Date: Nov 13, 2004
Subject: Re: Pitot Heat inrush question
I did some bench testing a few years ago with a 5814 heated pitot tube. You can see a graph of the current vs time analysis here http://bmnellis.com/pitotcurrent.htm There is also a link on the page that shows the actual data. Keep in mind this was a bench test so inflight data might be a little different with the air rusing by and cooling things down. http://bmnellis.com/pitotcurrent.htm -- Mike Nellis Austin, TX CMRA #32 Honda RC51 '97 YZF1000 '47 Stinson 108-2; RV6 (Fuselage) http://bmnellis.com glaesers wrote: > >I was thinking (always a dangerous endeavour)... if it is a good idea to >use a thermistor to limit the inrush on a landing/taxi light, what about >Pitot Heat? It's also just a big (about 100W I think) resistive load, sort >of like a light bulb - just not as bright. > >Or is it... > >It just so happens that a heated pitot is the one thing I have! (a used >Cessna unit - bought on eBay) My multi-meter says it has 2.2 ohms cold. So >at 13V, that means 5.9A of current initially. So apparently it is different >than a light bulb which has a much lower resistance when cold. If my 100W >assumption is correct, then at 13V the current is 7.69A. So that would >indicate not much of an inrush is going on, so no thermistor needed. > >Does this sound right? > >Thanks, > > Dennis Glaeser > > > > ________________________________________________________________________________
Date: Nov 13, 2004
Hi Dennis I purchased a used AN 5812 Cessna style pitot from a radio shop that is going out of business, they had used the pitot as a loaner. The shop measured and recorded the current inrush at 14.01 volts as 16 amps tapering to 10 amps. Manufacturers paperwork states that this pitot draws 6.4 to 8 amps. George in Langley I was thinking (always a dangerous endeavour)... if it is a good idea to use a thermistor to limit the inrush on a landing/taxi light, what about Pitot Heat? It's also just a big (about 100W I think) resistive load, sort of like a light bulb - just not as bright. Or is it... It just so happens that a heated pitot is the one thing I have! (a used Cessna unit - bought on eBay) My multi-meter says it has 2.2 ohms cold. So at 13V, that means 5.9A of current initially. So apparently it is different than a light bulb which has a much lower resistance when cold. If my 100W assumption is correct, then at 13V the current is 7.69A. So that would indicate not much of an inrush is going on, so no thermistor needed. Does this sound right? Thanks, Dennis Glaeser ________________________________________________________________________________
Date: Nov 13, 2004
> > My recollection is that it was a U. S. Senator from Colorado that shoved > it down our throats. I think the name was Dominick... Yup. The below link has history of the ELT, discusses the various TSO's, and the 406mHz issue: http://www.iawg.cap.gov/DSM/beaconstory.htm > Beyond that, I would carry a handheld Comm unit and a handheld > GPS in a small emergency bag that could be easily removed from the > aircraft. And don't forget a cell phone. Seems lately there are news reports of stranded people in really remote areas able to use a cell phone to call 911. > I think my old method was lot better than the ELT solution as it was forced > upon us in the early days of such a requirement. The gov't couldn't prove aircraft ELT's save hardly anybody. I searched many years of the NTSB database, and could not find many cases where an ELT assisted search much at all, much less an actual "save." To the contrary, it's common to read about crashes in very remote areas, where NTSB still cites a witness report or someone reporting a probable crash near yonder mountain to police. I tried some CAP web sites; you'd think if their unit ever saved anyone in an airplane, they'd brag about it. No luck. I checked the site of the gov't consortium that oversees all this. They cite one year, 2002, where worldwide, 57 people in aviation incidents were rescued. That's not many at all on this big planet, even if the self-serving statistic has exaggerated what really were saves due to an ELT (they use the weasel word "assisted"), as gov'ts like to do. Reg, Fred F. ________________________________________________________________________________
Date: Nov 13, 2004
> > >Hi Dennis > >I purchased a used AN 5812 Cessna style pitot from a radio shop that is >going out of business, they had used the pitot as a loaner. The shop >measured and recorded the current inrush at 14.01 volts as 16 amps tapering >to 10 amps. Manufacturers paperwork states that this pitot draws 6.4 to 8 >amps. > >George in Langley > > > > >I was thinking (always a dangerous endeavour)... if it is a good idea to >use a thermistor to limit the inrush on a landing/taxi light, what about >Pitot Heat? It's also just a big (about 100W I think) resistive load, sort >of like a light bulb - just not as bright. > >Or is it... > >It just so happens that a heated pitot is the one thing I have! (a used >Cessna unit - bought on eBay) My multi-meter says it has 2.2 ohms cold. So >at 13V, that means 5.9A of current initially. So apparently it is different >than a light bulb which has a much lower resistance when cold. If my 100W >assumption is correct, then at 13V the current is 7.69A. So that would >indicate not much of an inrush is going on, so no thermistor needed. > >Does this sound right? Here's some data I took on a bunch of heated tubes off a Beechjet about three years ago. These are 26 volt nominal tubes rated at about 250W while melting ice. http://www.aeroelectric.com/Pictures/Pitot_Heater_R.pdf The curve shows temperature resistance measurement for the tubes in a vacuum. The chart in the upper left corner is current draw while in a crushed ice bath (zero C). Note that while the surface of the tubes were at freezing, the heaters were running about 140 degrees C and had a resistance of about 2.7 ohms. Scaling these down to a 100W tube would increase the operating resistance to about 6.76 ohms for a 26v tube, and 3.88 ohms for a 13v tube. Assuming the same temperature coefficient for the heater material, a 3.38 ohm operating heater setting at 0C waiting to be turned on will have a cold resistance on the order of 2.63 ohms for an inrush at 13 volts of 5A. So what you've measured on the tube you have in hand is consistent with the measurements I've made on other tubes. I had an unmarked 13v tube in my shop a couple years ago that a builder wanted test data on. It's inrush was just over 16A and settled out at 12A in the ice bath for what I would have called a 150 watt tube. Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 13, 2004
lights lights > > >Whew - they do get hot! And (6A-squared * .06 ohms) means it's putting out >2.16W. I agree that the 8A unit is the way to go. Any recommendations on >physical installation? Would it be better to install it near the light, or >at the switch end - or does it matter? > >Dennis Glaeser I used these on the GP-180 in the taxi light fixtures. we made some fiberglas "socks" to slip over the device using wood-burning stove door gasket material you can buy at any fireplace store. A tripple layer of glas kept the clamp that mounted it from soaking off the heat. Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: Re: RE: 406 Mhz GPS ELT
>> Beyond that, I would carry a handheld Comm unit and a handheld >> GPS in a small emergency bag that could be easily removed from the >> aircraft. > >And don't forget a cell phone. Seems lately there are news reports of >stranded people in really remote areas able to use a cell phone to >call 911. The GPS is key. There was a crash recently in the hills of Oregon where the guys survived the crash, called 911, and it still took them over 10 hours to be found. One died in the meantime. >The gov't couldn't prove aircraft ELT's save hardly anybody. I >searched many years of the NTSB database, and could not find many >cases where an ELT assisted search much at all, much less an actual >"save." If the Feds can home in on a low power pirate radio station in about 15 minutes, it seems like if they wanted to, they should be able to find an ELT that is actually designed to be found. Not sure why this does not seem to be the case. -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
From: "Europa (Alfred Buess)" <ykibuess(at)bluewin.ch>
Date: Nov 14, 2004
Manuel, The electrical system of my Europa XS (not yet flying) with a Rotax 912S is based on two alternators working in parallel if the power consumtion needs it. The setpoint of the regulator for the Rotax alternator is set at 14.3 V, the setpoint of the regulator for the vacuum drive pad alternator (a SD-8 in my case) is set at 13.8 V. If the power consumption exceeds the output of the Rotax alternator, the bus voltage will fall below 14.3 V and at 13.8 V the SD-8 will come alive. This means the SD-8 works more like a boost alternator than an emergency alternator. If you are interested, I could send you a CAD-file (.dwg) of my electrical system. Alfred Alfred Buess Laenggasse 81, CH-3052 Zollikofen, Switzerland Tel.: +41 (0)31 911 63 32, Fax: +41 (0)31 911 56 32 E-Mail: ykibuess(at)bluewin.ch Europa XS #097, Monowheel, Foam shortwing, Rotax 912S, Airmaster 332 CS --> Hi Bob and all I am working on a Dyn Aero MCR 4S, to be equipped for IFR flying (ad-hoc avionics, pitot heat...), powered by a Rotax 914 (electrically dependant). I know the Rotax alt won't deliver enough power for all my stuff. So I need to add a second alternator. I don't have enough room in the cowling to put a belt driven one, so my only reasonable option is the SD 20. With the vacuum pump pad turning at 0.54 the engine rpm, it could nearly deliver 20 amp at 5200 RPM, which is not so bad. Well, I studied all your wiring diagrams in appendix Z, and none consider using the rotax alternator, a second alternator running permanently, and 1 battery. I realise the Z-14 is best of the best, but I'd really rather have only 1 battery. The Z-16, with the 2nd alt wired as per Z-13 would fit my needs, but what about the compatibility of both alt running at same time ? Is it possible to keep the OV module on the Rotax alt, and also benefit from the LR3 OV protection ? If an OV occurs, how to know from which regulator it comes ? Finally, what kind of wiring diagram seems to you to be most appropriate to my situation ? Thanks in advance for your help Manuel Bonniot Luxembourg _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: ELT's
Date: Nov 14, 2004
These ELT's are FAA-FCC-TSO-C91a approved. Some have panel mounted on/off and are much less expensive. Hope this helps. http://store.wagaero.com John _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
clamav-milter version 0.80j on juliet.albedo.net Yup, unless something dramatic has happened in the last couple of decades, there is likely still a high probability that the closest units/aircraft dispatched to investigate an ELT do not have VHF direction finding equipment. Politicians want a response for the press. A successful rescue is secondary. Add in the probability of poor weather for a visual search, how large the search area is, and the life of ELT batteries, and you can begin to see why the GPS coordinates can be so important. Too often it takes more than a day to find a wreck only a couple of miles from the runway in non-urban areas. There have certainly been cases where the ELT's value was many hours sooner notice of a crash and narrowing the search are dramatically, but the coordinates are still key to a rescue. For controlling search costs alone, you can bank on having to buy a 406 mhz gps enabled ELT fairly soon! Ken Mickey Coggins wrote: > > > >>>Beyond that, I would carry a handheld Comm unit and a handheld >>>GPS in a small emergency bag that could be easily removed from the >>>aircraft. >>> >>> >>And don't forget a cell phone. Seems lately there are news reports of >>stranded people in really remote areas able to use a cell phone to >>call 911. >> >> > >The GPS is key. There was a crash recently in the hills of Oregon >where the guys survived the crash, called 911, and it still >took them over 10 hours to be found. One died in the meantime. > > > >>The gov't couldn't prove aircraft ELT's save hardly anybody. I >>searched many years of the NTSB database, and could not find many >>cases where an ELT assisted search much at all, much less an actual >>"save." >> >> > >If the Feds can home in on a low power pirate radio station >in about 15 minutes, it seems like if they wanted to, they >should be able to find an ELT that is actually designed to >be found. Not sure why this does not seem to be the case. > >-- > >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________ DomainKey-Signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; b=v4IWbN12X7nAQq5MiL5Fxx408NiikXqVs4TACA/U1luQGL8TDI2cJ9Hm6QTJWhd5Sag/mp4HQwEA91QKCqiAiA6xeSH2A/4D3C7Pjz8u+dwFm6cCdc9YYJcEh49WNI+nXr95ZyhRQVEaqoroonP74Vwo4XpbDszjGEYmSwtMRMo;
Date: Nov 14, 2004
Subject: Re: [Bulk] RE: 406 Mhz GPS ELT
> >Since I was sworn to absolute secrecy on this, I only posted it on my >website. But this looks like the ticket. Prices (I hope) soon. > >http://www.periheliondesign.com/AeroFix%20FCC%20Approved.pdf Looks like a very interesting device, indeed. Please keep us posted when they put out a price for it. Since the price of "approved" 406MHz ELTs probably won't come down for quite some time, and since the old 121.5 ELTs are so rarely useful in effecting survivor recoveries, I think I'll just get a unit similar to the above as well as an inexpensive (relative) 121.5 ELT and just activate the 406 unit prior to any off-airport landing. Alternatively, I'm sure some enterprising EE could hack into one of the non-approved 406 units and devise a G-activated switch to turn it on. I'd be an interested customer for something like this. The advantages of of transmitting a GPS position on a 406 unit seem clear to me. The quicker they can find me (should the need arise) the better I feel Dan Fritz --------------------------------- _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: smaller fast-on connectors for microswitches
Hi Listers, I've got a Omron microswitch for my AOA flap sensor, and it has some tabs that look like of like faston tabs, but they are a bit smaller. Can anyone suggest a place where I can buy some of these terminals? I tried slogging through the digikey website, but if you don't know exactly what you want there, you're hosed. Is it possible that these 0.187" (3/16"?) terminals are the right size? http://www.aircraftspruce.com/catalog/elpages/pidg.php Many thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 QB Wings/Fuselage _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: smaller fast-on connectors for microswitches
Those are certainly all the standard faston sizes. You have to either look at the switch datasheet or carefully measure the switch tabs to determine which (if any) are suitable. To choose the correct part you have to determine: 1. the width of the tabs 2. the thickness of the tabs 3. the wire size to be used Dick Tasker Mickey Coggins wrote: > >Hi Listers, > >I've got a Omron microswitch for my AOA flap sensor, >and it has some tabs that look like of like faston >tabs, but they are a bit smaller. > >Can anyone suggest a place where I can buy some of >these terminals? I tried slogging through the >digikey website, but if you don't know exactly what >you want there, you're hosed. > >Is it possible that these 0.187" (3/16"?) terminals are the >right size? > > http://www.aircraftspruce.com/catalog/elpages/pidg.php > >Many thanks, >Mickey > >-- >Mickey Coggins >http://www.rv8.ch/ >#82007 QB Wings/Fuselage > > >_-===================================================================== >_->_-= -- Please Support Your Lists This Month -- >_-= (And Get Some AWESOME FREE Gifts!) >_->_-= November is the Annual List Fund Raiser. Click on the >_-= Contribution link below to find out more about this >_-= year's Terrific Free Incentive Gifts provided by the >_-= The Builder's Bookstore www.buildersbooks.com! >_->_-= List Contribution Web Site >_->_-= http://www.matronics.com/contribution >_->_-= Thank you for your generous support! >_-= -Matt Dralle, List Admin. >_->_-===================================================================== >_-= - The AeroElectric-List Email Forum - >_-= This forum is sponsored entirely through the Contributions >_-= of List members. You'll never see banner ads or any other >_-= form of direct advertising on the Matronics Forums. >_-===================================================================== >_-= List Related Information >_-= Post Message: aeroelectric-list(at)matronics.com >_-= UN/SUBSCRIBE: http://www.matronics.com/subscription >_-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm >_-= Search Engine: http://www.matronics.com/search >_-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list >_-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list >_-= Live List Chat: http://www.matronics.com/chat >_-= Archives: http://www.matronics.com/archives >_-= Photo Share: http://www.matronics.com/photoshare >_-= List Specific: http://www.matronics.com/aeroelectric-list >_-= Other Lists: http://www.matronics.com/emaillists >_-= Trouble Report http://www.matronics.com/trouble-report >_-= Contributions: http://www.matronics.com/contribution >_-===================================================================== > > > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
From: Robert McCallum <robert.mccallum2(at)sympatico.ca>
Mickey; It's possible. All you have to do is check the width and thickness of the tabs you have, with a vernier calliper, micrometer or like instrument and compare the measurements you get with the chart you linked to. When you find a connector with matching dimensions and the wire size you desire, you've found the right one. This is the reason the chart you show gives the width and thickness dimensions of the tab the connector is designed to work with. Hope this clarifies the problem for you Bob McC Mickey Coggins wrote: >Hi Listers, > >I've got a Omron microswitch for my AOA flap sensor, >and it has some tabs that look like of like faston >tabs, but they are a bit smaller. > >Is it possible that these 0.187" (3/16"?) terminals are the >right size? > > http://www.aircraftspruce.com/catalog/elpages/pidg.php > >Many thanks, >Mickey > > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: AOA
Date: Nov 14, 2004
From: "Olivier Le Carbonnier" <olcdlm(at)laposte.net> Subject: RE: AeroElectric-List: Stall Horn << ....skip....The difference is that our AOA works....skip....>> 11/14/2004 Hello Olivier, Would you please identify which AOA is *ours* and where to get some information on it? Thanks, OC _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Mickey, I am using a similar switch to detect flap position, also an Omron with 3/16" tabs. FWIW, I found suitable fast-ons for 20-22 ga wire at the local Napa store. Doug Windhorn In a message dated 11/14/2004 7:40:01 AM Pacific Standard Time, mick-matronics(at)rv8.ch writes: > Hi Listers, > > I've got a Omron microswitch for my AOA flap sensor, > and it has some tabs that look like of like faston > tabs, but they are a bit smaller. > > Can anyone suggest a place where I can buy some of > these terminals? I tried slogging through the > digikey website, but if you don't know exactly what > you want there, you're hosed. > > Is it possible that these 0.187" (3/16"?) terminals are the > right size? > > http://www.aircraftspruce.com/catalog/elpages/pidg.php > > Many thanks, > Mickey _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> microswitches
microswitches microswitches > > >Hi Listers, > >I've got a Omron microswitch for my AOA flap sensor, >and it has some tabs that look like of like faston >tabs, but they are a bit smaller. > >Can anyone suggest a place where I can buy some of >these terminals? I tried slogging through the >digikey website, but if you don't know exactly what >you want there, you're hosed. > >Is it possible that these 0.187" (3/16"?) terminals are the >right size? Here's the Digikey page with all the PIDG Fast-On terminals: http://dkc3.digikey.com/PDF/T043/0196.pdf Most basic switches ("microswitches") use the .187 (3/16") size (AMP 640917-1) Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: Re: Rotax 914, dual alt
> > >Manuel, > >The electrical system of my Europa XS (not yet flying) with a Rotax 912S >is based on two alternators working in parallel if the power consumtion >needs it. The setpoint of the regulator for the Rotax alternator is set >at 14.3 V, the setpoint of the regulator for the vacuum drive pad >alternator (a SD-8 in my case) is set at 13.8 V. If the power >consumption exceeds the output of the Rotax alternator, the bus voltage >will fall below 14.3 V and at 13.8 V the SD-8 will come alive. This >means the SD-8 works more like a boost alternator than an emergency >alternator. If you are interested, I could send you a CAD-file (.dwg) of >my electrical system. > >Alfred To my knowledge, there are no vacuum-pump, pad-driven alternators that will produce useful amounts of snort on the 912/914 series engines. Their pads are just too slow. Didn't somebody on the list point us to a successful belt driven add-on to the Rotax in a Europa? I seem to recall having seen photos. >I am working on a Dyn Aero MCR 4S, to be equipped for IFR flying (ad-hoc > >avionics, pitot heat...), powered by a Rotax 914 (electrically >dependant). I know the Rotax alt won't deliver enough power for all my >stuff. So I need >to add a second alternator. I don't have enough room in the cowling to >put a >belt driven one, so my only reasonable option is the SD 20. With the >vacuum >pump pad turning at 0.54 the engine rpm, it could nearly deliver 20 amp >at >5200 RPM, which is not so bad. This puts your pad at which is 2800. The pad on a lycoming or continental runs at 1.25 to 1.4 of crankshaft which is about 3200 RPM where the SD-20 is rated. Further, I'm not sure the SD-20 fits the Rotax. Have you discussed this with B&C? Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Collins 331H-3G CDI Pinout?
Date: Nov 14, 2004
Would anyone have a pinout for a Collins 331H-3G glideslope indicator? I will be connecting it to a KNS-80 RNAV. The KING equipment is no problem to find pinouts for, but the Collins info seems to be hiding from me. Regards- Norm _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Rotax 914, dual alt
Date: Nov 14, 2004
Bob, I had a similar issue using the vacuum pad on a Jabiru engine and have talked to B&C at Oshkosh and Sun-N-Fun for the past 2 years. They basicly said, "Sorry". So I designed a flat belt drive for a Toyota alternator, and use the built in Jabiru alternator just to manage the backup battery and tach input. Anyone can drop me an E-mail if they want some photos. Jabiru had ~7" space to fit in a 90 Amp alternator, a new 55 A Nippon Denso that's 5 lb lighter is regularly on EBay for ~$110. Jim Stone -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AW: AeroElectric-List: Rotax 914, dual alt --> > > >Manuel, > >The electrical system of my Europa XS (not yet flying) with a Rotax >912S is based on two alternators working in parallel if the power >consumtion needs it. The setpoint of the regulator for the Rotax >alternator is set at 14.3 V, the setpoint of the regulator for the >vacuum drive pad alternator (a SD-8 in my case) is set at 13.8 V. If >the power consumption exceeds the output of the Rotax alternator, the >bus voltage will fall below 14.3 V and at 13.8 V the SD-8 will come >alive. This means the SD-8 works more like a boost alternator than an >emergency alternator. If you are interested, I could send you a >CAD-file (.dwg) of my electrical system. > >Alfred To my knowledge, there are no vacuum-pump, pad-driven alternators that will produce useful amounts of snort on the 912/914 series engines. Their pads are just too slow. Didn't somebody on the list point us to a successful belt driven add-on to the Rotax in a Europa? I seem to recall having seen photos. >I am working on a Dyn Aero MCR 4S, to be equipped for IFR flying >(ad-hoc > >avionics, pitot heat...), powered by a Rotax 914 (electrically >dependant). I know the Rotax alt won't deliver enough power for all my >stuff. So I need to add a second alternator. I don't have enough room >in the cowling to put a >belt driven one, so my only reasonable option is the SD 20. With the >vacuum >pump pad turning at 0.54 the engine rpm, it could nearly deliver 20 amp >at >5200 RPM, which is not so bad. This puts your pad at which is 2800. The pad on a lycoming or continental runs at 1.25 to 1.4 of crankshaft which is about 3200 RPM where the SD-20 is rated. Further, I'm not sure the SD-20 fits the Rotax. Have you discussed this with B&C? Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Shunt with essential bus
Date: Nov 14, 2004
Bob (and anyone else) - I'm trying to figure out how to wire my shunt for my ammeter. The problem is I'm planning on a small battery bus, and the main bus and essential bus. How can I wire the shunt so it shows the total load on the system (all three buses)? Is it possible? I guess at a minimum I want to see the load on the main and essential buses. TIA - Mitch Faatz - RV-6A Finish Kit _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
Subject: Re: Shunt with essential bus
You could use multiple shunts driving the same meter via a switch... Matt- > > > Bob (and anyone else) - > > I'm trying to figure out how to wire my shunt for my ammeter. The > problem is I'm planning on a small battery bus, and the main bus and > essential bus. How can I wire the shunt so it shows the total load on > the system (all three buses)? Is it possible? I guess at a minimum I > want to see the load on the main and essential buses. > > TIA - Mitch Faatz - RV-6A Finish Kit > > > _-===================================================================== > _-> _-= -- Please Support Your Lists This Month -- > _-= (And Get Some AWESOME FREE Gifts!) > _-> _-= November is the Annual List Fund Raiser. Click on the > _-= Contribution link below to find out more about this > _-= year's Terrific Free Incentive Gifts provided by the > _-= The Builder's Bookstore www.buildersbooks.com! > _-> _-= List Contribution Web Site > _-> _-= http://www.matronics.com/contribution > _-> _-= Thank you for your generous support! > _-= -Matt Dralle, List Admin. > _-> _-===================================================================== > _-= - The AeroElectric-List Email Forum - > _-= This forum is sponsored entirely through the Contributions > _-= of List members. You'll never see banner ads or any other > _-= form of direct advertising on the Matronics Forums. > _-===================================================================== > _-= List Related Information > _-= Post Message: aeroelectric-list(at)matronics.com > _-= UN/SUBSCRIBE: http://www.matronics.com/subscription > _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm > _-= Search Engine: http://www.matronics.com/search > _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list > _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list > _-= Live List Chat: http://www.matronics.com/chat > _-= Archives: http://www.matronics.com/archives > _-= Photo Share: http://www.matronics.com/photoshare > _-= List Specific: http://www.matronics.com/aeroelectric-list > _-= Other Lists: http://www.matronics.com/emaillists > _-= Trouble Report http://www.matronics.com/trouble-report > _-= Contributions: http://www.matronics.com/contribution > _-===================================================================== _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
On 11/14 5:24, Mitch Faatz wrote: > I'm trying to figure out how to wire my shunt for my ammeter. The problem is I'm planning on a small battery bus, and the main bus and essential bus. How can I wire the shunt so it shows the total load on the system (all three buses)? Is it possible? I guess at a minimum I want to see the load on the main and essential buses. How about using a hall effect sensor instead of shunts? -- Walter Tondu http://www.rv7-a.com _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
I'm using a little three gauge cluster from Mitchell, which uses a shunt. I don't want to have to switch between shunts either, I wonder if you can just have two or three shunts tie onto the same gauge input and have it work. I think the output of the shunts is just a 0-50 mv so perhaps it would be additive? -Mitch > > I'm trying to figure out how to wire my shunt for my ammeter. The problem is I'm planning on a small battery bus, and the main bus and essential bus. How can I wire the shunt so it shows the total load on the system (all three buses)? Is it possible? I guess at a minimum I want to see the load on the main and essential buses. > > How about using a hall effect sensor instead of shunts? > _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
microswitches microswitches > microswitches > >Thanks, guys, for the feedback. I've ordered some fast-ons from >ACS - they'll be here in about a week. No NAPA out in my neck >of the woods! NAPA is very unlikely to stock PIDG style terminals . . . Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
> >Bob (and anyone else) - > >I'm trying to figure out how to wire my shunt for my ammeter. The problem >is I'm planning on a small battery bus, and the main bus and essential >bus. How can I wire the shunt so it shows the total load on the system >(all three buses)? Is it possible? I guess at a minimum I want to see >the load on the main and essential buses. When you put a loadmeter in the alternator b-lead, then it does exactly what you've asked for . . . total load on the system. Understand that while the battery is recharging, it is part of total load but that all goes away after 30 minutes or so of operation. Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
> >I'm using a little three gauge cluster from Mitchell, which uses a shunt. I >don't want to have to switch between shunts either, I wonder if you can just >have two or three shunts tie onto the same gauge input and have it work. I >think the output of the shunts is just a 0-50 mv so perhaps it would be >additive? No, it takes some special gyrations to "add" the total value of shunts in different parts of the system. How would you use this information? Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 14, 2004
> When you put a loadmeter in the alternator b-lead, then it > does exactly what you've asked for . . . total load on the > system. ... Okay, so I'll put the shunt between the starter contactor and the master/battery contactor and it will work perfectly except when the battery contactor is shut off and the essential bus feed turned on, correct? Thanks again Bob Mitch Faatz RV-6A Perpetual Finish Kit _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Re: [Bulk] RE: 406 Mhz GPS ELT For whom?
Date: Nov 15, 2004
For whom are we buying and installing the "approved"or not 406 MHz GPS ELT, the 121.5 ELT or what have you? Be it a simple piece of a mirror, a 406 MHz GPS ELT a 121.5 ELT or what have you? The `more' effective the device is in bringing survivor(s) or the remains thereof safely back from the edge of life and death, the `less' risk, time, and money will be invested by all the souls that play a roll in carrying out the search, rescue and recovery. Those of us that consciously venture closer to the "edge" usually know at least something about the risk to ourselves. We should also be aware of the consequences and risks our various adventures gone wrong will have on others. Like it or not, our actions can unnecessarily negatively effect the Safety health wealth and happiness of an often surprisingly large number of people should things go sour. Piloting a privately owned aircraft, boat, skiing or boarding out of bounds or for that matter any other activity that removes us from our accepted communication systems and on demand contact with our homes and peer group thereby brings us just that much closer to the "edge". I'm suggesting here that should we choose to partake in activities that have the potential to leave us at the "edge" waiting and hoping that others will take it upon themselves to risk life and limb on our behalf, we owe it to them to equip ourselves with what ever information planning and alerting devices we can reasonably afford and utilize that will effectively reduce the loss and risk factors for all. The fact is that whether or not we take others into consideration when we decide to go off in search of adventure, almost invariably they will be involved when the crap hits the fan. The now lowly appreciated and often bad mouthed ELT at one time represented a break through in safety technology. It most certainly has saved many lives of both the survivors and those called upon to be their rescuers. I am inclined therefore to say that the answer to the opening question is; Whether we think about it or not the purpose of emergency locators no matter what type, are intended for the benefit of all the parties potentially involved, not just for our individual selves. Whether buying a maximum affordable minimum requirement unit or spending for the best technology doodad available, I hope the above considerations help soften the blow when the time comes to offer up the cash. I to hope that the prices for the "approved 406" go down as production ramps up. I also look forward to the day that the electronics for this gets so small that it might become an integral part of every cell and satellite phone for example. Great flights and greased landings Jim in Kelowna _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Hi Bob I mesured everything and it really seems the SD20 can fit the Rotax. About Amps, if I refer to the performance data for the SD20 on B&C website, it produces 18 A/14V at 2500 RPM, and 22 A at 3000 RPM. So, do I misread the figures ? Manuel >From: "Robert L. Nuckolls, III" <b.nuckolls(at)cox.net> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: Re: AW: AeroElectric-List: Rotax 914, dual alt >Date: Sun, 14 Nov 2004 15:05:35 -0600 > > > > > > > > >Manuel, > > > >The electrical system of my Europa XS (not yet flying) with a Rotax 912S > >is based on two alternators working in parallel if the power consumtion > >needs it. The setpoint of the regulator for the Rotax alternator is set > >at 14.3 V, the setpoint of the regulator for the vacuum drive pad > >alternator (a SD-8 in my case) is set at 13.8 V. If the power > >consumption exceeds the output of the Rotax alternator, the bus voltage > >will fall below 14.3 V and at 13.8 V the SD-8 will come alive. This > >means the SD-8 works more like a boost alternator than an emergency > >alternator. If you are interested, I could send you a CAD-file (.dwg) of > >my electrical system. > > > >Alfred > > To my knowledge, there are no vacuum-pump, pad-driven alternators > that will produce useful amounts of snort on the 912/914 series > engines. Their pads are just too slow. Didn't somebody on the list > point us to a successful belt driven add-on to the Rotax in a Europa? > I seem to recall having seen photos. > > > >I am working on a Dyn Aero MCR 4S, to be equipped for IFR flying (ad-hoc > > > >avionics, pitot heat...), powered by a Rotax 914 (electrically > >dependant). I know the Rotax alt won't deliver enough power for all my > >stuff. So I need > >to add a second alternator. I don't have enough room in the cowling to > >put a > >belt driven one, so my only reasonable option is the SD 20. With the > >vacuum > >pump pad turning at 0.54 the engine rpm, it could nearly deliver 20 amp > >at > >5200 RPM, which is not so bad. > > This puts your pad at which is 2800. The pad on a lycoming or > continental runs at 1.25 to 1.4 of crankshaft which is about > 3200 RPM where the SD-20 is rated. Further, I'm not sure the > SD-20 fits the Rotax. > > Have you discussed this with B&C? > > Bob . . . > > >_-===================================================================== >_->_-= -- Please Support Your Lists This Month -- >_-= (And Get Some AWESOME FREE Gifts!) >_->_-= November is the Annual List Fund Raiser. Click on the >_-= Contribution link below to find out more about this >_-= year's Terrific Free Incentive Gifts provided by the >_-= The Builder's Bookstore www.buildersbooks.com! >_->_-= List Contribution Web Site >_->_-= http://www.matronics.com/contribution >_->_-= Thank you for your generous support! >_-= -Matt Dralle, List Admin. >_->_-===================================================================== >_-= - The AeroElectric-List Email Forum - >_-= This forum is sponsored entirely through the Contributions >_-= of List members. You'll never see banner ads or any other >_-= form of direct advertising on the Matronics Forums. >_-===================================================================== >_-= List Related Information >_-= Post Message: aeroelectric-list(at)matronics.com >_-= UN/SUBSCRIBE: http://www.matronics.com/subscription >_-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm >_-= Search Engine: http://www.matronics.com/search >_-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list >_-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list >_-= Live List Chat: http://www.matronics.com/chat >_-= Archives: http://www.matronics.com/archives >_-= Photo Share: http://www.matronics.com/photoshare >_-= List Specific: http://www.matronics.com/aeroelectric-list >_-= Other Lists: http://www.matronics.com/emaillists >_-= Trouble Report http://www.matronics.com/trouble-report >_-= Contributions: http://www.matronics.com/contribution >_-===================================================================== > > http://messenger.msn.com/ _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: Master Switch Question
Date: Nov 15, 2004
Listers, Here is an archived post that is a perfect segueway to my question: Bob/Others I am confused and need help. In Figure Z-13 (utilizing SD-8 alternator) the DC power master switch is a 2-10. In Figure Z-12 (utilizing SD-20 alternator) the DC power master switch is a 2-3. Why the difference? Is it that with the 2-10 switch the engine is to be started with this switch in the center position? Is it that with the 2-10 switch the regulator can be disconnected from the bus for some reason, perhaps testing? The reason I am asking is I initially planned to install the SD-8 alternator and wired my panel accordingly (Figure Z-13) with the 2-10 master power switch. I have since decided to install the SD-20 which takes me to Figure Z-12 which calls for a 2-3 master power switch. Is it important that I cha nge out my 2-10 master power switch with a 2-3 switch? If not, what is the purpose for the center position on the 2-10 switch? A little help would be appreciated. Thanks. Pete Hunt Clearwater, FL RV-6, Wiring I not sure if this will help you but, I do know that with a 2-10 switch the center is for the battery and the top for the alternator. Close but it's a little more complicated than that. Alternators generally do not run well without also having a battery on line. Early electrified aircraft used generators which would come on line and deliver useful, relatively clean energy without a battery. When generators were removed from certified ships and replaced with alternators, powers-that-be deduced a need to make sure that an alternator could not be left on-line without the battery . . . and that the battery was on-line before the alternator was brought up. This design philosophy gave birth to the infamous "split rocker" master switch that has been part-and-parcel of the majority of single engine aircraft architectures for nearly 40 years. I've seen many OBAM aircraft where the builder wanted to use some whippy looking switches on the panel but had a Cesssna style split rocker switch enshrined in a place of honor. The 2-10, progressive transfer switch can provide the same action without having to resort to th e over-priced split rocker. The 2-10 looks like its brothers and cousins and mounts in the same nice round hole. Full down turns both battery -AND- alternator OFF. Mid position turns only the battery ON. Upper position leaves the battery ON and turns the alternator ON too. If one doesn't want to spend the dollars and take the time to label a three-position, progressive transfer 2-10 switch, the 2-3 is a completely acceptable substitute. In this case, battery and alternator are brought on and off together . . . an entirely satisfactory mode of operation also. When one uses a pullable breaker for the crowbar OV protection, there's a panel mounted control that permits an alternator to be taken off line for battery only ground operations (usually for maintenance) -OR- to take the alternator off line should it become unstable in flight. If it were my airplane, I'd probably use a 2-3 switch. It's inexpensive and spares can be acquired from lots of sources. Bob . . . What is the advantage of running the alternator field wire (main bus to pullable breaker to 6 on LR3C) through a double pole switch? Wouldn't it be equivalent to use a 1-3 switch for the battery master pull the breaker for the few times you want to go battery only? Alternatively, wouldn't it also be equivalent to use the 2-10 switch skip the pullable breaker? Maybe I'm misunderstanding the difference between switches breakers. Please help. Thanks, Grant _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Subject: RE: 406 Mhz GPS ELT
Date: Nov 15, 2004
Hi All- A couple of data points: That panel mounted ELT switch can of course be used to start the ELT up before the impact, if one knows the impact is coming. More important though is the cell phone issue. I accidentally discovered (no, I never read the manual) that my Nokia cell phone has GPS. If I wander down the correct menu, it asks if I want the phone to make my GPS position available ALL THE TIME (as in even when I'm not using the phone!!!!) or only when calling 911. WOW! Great safety feature, and quite handy for big brother. This, combined with the fact that PCS phones will work airborne as long as you're not too high, is a great advantage for us aviators. If you're going down in the wild, just dial 911 and your position will be known to someone in the PCS world, if you are in range of a ground station. If you can talk to the operator and convince them it's not a prank call, help should be on the way immediately. Another data point is that my EFIS will have a continuous lat/long readout displayed. One could broadcast that on the way down to jump start SAR. FWIW- Glen Matejcek aerobubba(at)earthlink.net _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Subject: Re: Master Switch Question
> > >Listers, > > >Here is an archived post that is a perfect segueway to my question: > > >Bob/Others I am confused and need help. In Figure Z-13 (utilizing SD-8 >alternator) the DC power master switch is a 2-10. In Figure Z-12 >(utilizing SD-20 alternator) the DC power master switch is a 2-3. Why >the difference? Is it that with the 2-10 switch the engine is to be >started with this switch in the center position? Is it that with the 2-10 >switch the regulator can be disconnected from the bus for some reason, >perhaps testing? The reason I am asking is I initially planned to >install the SD-8 alternator and wired my panel accordingly (Figure Z-13) >with the 2-10 master power switch. I have since decided to install the >SD-20 which takes me to Figure Z-12 which calls for a 2-3 master power >switch. Is it important that I cha > nge out my 2-10 master power switch with a 2-3 switch? If not, what is > the purpose for the center position on the 2-10 switch? A little > help would be appreciated. Thanks. Pete Hunt Clearwater, FL RV-6, > Wiring I not sure if this will help you but, I do know that with a > 2-10 switch the center is for the battery and the top for the alternator. > >Close but it's a little more complicated than that. Alternators generally >do not run well without also having a battery on line. Early electrified >aircraft used generators which would come on line and deliver useful, >relatively clean energy without a battery. When generators were removed >from certified ships and replaced with alternators, powers-that-be deduced >a need to make sure that an alternator could not be left on-line without >the battery . . . and that the battery was on-line before the alternator >was brought up. This design philosophy gave birth to the infamous "split >rocker" master switch that has been part-and-parcel of the majority of >single engine aircraft architectures for nearly 40 years. I've seen many >OBAM aircraft where the builder wanted to use some whippy looking switches >on the panel but had a Cesssna style split rocker switch enshrined in a >place of honor. The 2-10, progressive transfer switch can provide the same >action without having to resort to th > e over-priced split rocker. The 2-10 looks like its brothers and cousins > and mounts in the same nice round hole. Full down turns both battery > -AND- alternator OFF. Mid position turns only the battery ON. Upper > position leaves the battery ON and turns the alternator ON too. If one > doesn't want to spend the dollars and take the time to label a > three-position, progressive transfer 2-10 switch, the 2-3 is a completely > acceptable substitute. In this case, battery and alternator are brought > on and off together . . . an entirely satisfactory mode of operation > also. When one uses a pullable breaker for the crowbar OV protection, > there's a panel mounted control that permits an alternator to be taken > off line for battery only ground operations (usually for maintenance) > -OR- to take the alternator off line should it become unstable in flight. > If it were my airplane, I'd probably use a 2-3 switch. It's inexpensive > and spares can be acquired from lots of sources. > >Bob . . . > > >What is the advantage of running the alternator field wire (main bus to >pullable breaker to 6 on LR3C) through a double pole switch? Wouldn't it >be equivalent to use a 1-3 switch for the battery master pull the breaker >for the few times you want to go battery only? If you do as you've suggested, opening the Battery Master switch only with the engine running will not make the system shut down. The alternator will probably continue to run self-excited but with unpredictable performance. This is why the alternator/battery switch were combined into their current single two-pole switch configuration when generators (separate battery and generator switches) were taken off the airplane. In the Z-figures, when you turn the DC PWR MASTER switch OFF, the system goes completely dark at operation of the one switch and without risk of leaving an alternator on line after the battery is taken off. > Alternatively, wouldn't it also be equivalent to use the 2-10 > switch skip the pullable breaker? Sure, you still need the breaker if you're using the crowbar ov protection scheme but it need not be pullable. >Maybe I'm misunderstanding the difference between switches breakers. >Please help. Switches control things, breakers protect things. There are ways folks have attempted to combine their functions over the years but they are not cost or performance effective in the architectures depicted in Appendix Z. Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
> > > When you put a loadmeter in the alternator b-lead, then it > > does exactly what you've asked for . . . total load on the > > system. ... > >Okay, so I'll put the shunt between the starter contactor and the >master/battery contactor and it will work perfectly except when the battery >contactor is shut off and the essential bus feed turned on, correct? No, that would run starter current through the shunt. All of the Z-figures suggest wiring ammeters as alternator loadmeters. Shunts in the b-lead of the alternator. What information do you perceive is not available to you with this configuration? Bob . . . _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Subject: Re: RE: 406 Mhz GPS ELT
Matejcek" > > Hi All- > I > accidentallydiscovered (no, I never read the manual) that my Nokia > cell phone has GPS. > If I wander down the correct menu, it asks if I want the phone to > make my > GPS position available ALL THE TIME (as in even when I'm not using the > phone!!!!) or only when calling 911. WOW! Great safety feature, > and quite > handy for big brother. All new cell phones sold in the US have this 'feature', again per federal law. I was pushed through under the guise of helping to find 911 callers, but I think it had more to do with finding drug traffickers (at least the ones smart enough not to set up a deal from their hotel room). _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
From: "Gilles Thesee" <Gilles.Thesee@ac-grenoble.fr>
Subject: LVWM questions
Date: Nov 15, 2004
Hi Bob, This is just to ask if you received the diagrams I tried to send you, and if you had time to have a look at them. I know you're busy but I would really appreciate any hints as to how to conduct mmy investigations. Thanks, Regards, Gilles _-===================================================================== _-_-= -- Please Support Your Lists This Month -- _-= (And Get Some AWESOME FREE Gifts!) _-_-= November is the Annual List Fund Raiser. Click on the _-= Contribution link below to find out more about this _-= year's Terrific Free Incentive Gifts provided by the _-= The Builder's Bookstore www.buildersbooks.com! _-_-= List Contribution Web Site _-_-= http://www.matronics.com/contribution _-_-= Thank you for your generous support! _-= -Matt Dralle, List Admin. _-_-===================================================================== _-= - The AeroElectric-List Email Forum - _-= This forum is sponsored entirely through the Contributions _-= of List members. You'll never see banner ads or any other _-= form of direct advertising on the Matronics Forums. _-===================================================================== _-= List Related Information _-= Post Message: aeroelectric-list(at)matronics.com _-= UN/SUBSCRIBE: http://www.matronics.com/subscription _-= List FAQ: http://www.matronics.com/FAQ/AeroElectric-List.htm _-= Search Engine: http://www.matronics.com/search _-= 7-Day Browse: http://www.matronics.com/browse/aeroelectric-list _-= Browse Digests: http://www.matronics.com/digest/aeroelectric-list _-= Live List Chat: http://www.matronics.com/chat _-= Archives: http://www.matronics.com/archives _-= Photo Share: http://www.matronics.com/photoshare _-= List Specific: http://www.matronics.com/aeroelectric-list _-= Other Lists: http://www.matronics.com/emaillists _-= Trouble Report http://www.matronics.com/trouble-report _-= Contributions: http://www.matronics.com/contribution _-===================================================================== ________________________________________________________________________________
Date: Nov 15, 2004
Subject: Re: LVWM questions
><Gilles.Thesee@ac-grenoble.fr> > >Hi Bob, > >This is just to ask if you received the diagrams I tried to send you, and if >you had time to have a look at them. >I know you're busy but I would really appreciate any hints as to how to >conduct mmy investigations. Yes, I have them. REALLY preoccupied right now. Had to put my dad in the hospital last Wednesday and given that I'm executor of his estate and power of attorney on his business activities, it's pretty busy. I'll see if I can get to them this evening.
November 05, 2004 - November 15, 2004
AeroElectric-Archive.digest.vol-dr
