AeroElectric-Archive.digest.vol-er
July 30, 2005 - August 10, 2005
      >>ILS,
      >>>the TN200D only displays the GS. The GNS430 is rock solid out and
      >>>inbound.
      >>The
      >>>old TN200 did not have this problem; it and the GNS430 were working fine.
      >>>Also, now the Terra TN200D will not display the CDI for the VOR unless
      >>>I'm
      >>almost
      >>>on the airport; VOR on airport. The TRI-NAV is wired to display the OBS
      >>setting
      >>>as well as the radial currently on. This works OK, meaning the CDI is
      >>getting
      >>>the correct data.
      >>>The only explanation I can come up with, is that the TN200D is less
      >>sensitive than
      >>>the old TN200 and outbound the "rabbit ears" antenna, oriented with the
      >>"ears"
      >>>facing aft and under the tailcone has better reception going away from
      >>>the
      >>>ILS. This is weird; all airplanes I have seen have the VOR antenna
      >>"facing"
      >>>aft. In addition I was told by an avionics shop that dual VOR/ILS
      >>typically use
      >>>a 1-into-4 quadaplexer, rather than two VOR antennas..
      >>>Has anyone experienced like symtoms??
      >>>Wayne
Subject: Re:A Bugger of an Avionics Problem
Date: Jul 30, 2005
Correct. The only remaining component is the antenna. Since the ILS displays strong OUTBOUND as far as 30 miles, but on inbound and only when very near the LOC center, the LOC CDI indicator drops out. The same happens with the VOR CDI most of the time. I will check the balum on the "rabbit ears" antenna, in the event some corrosion has built up to the point that a split signal is too weak for the TN200D, but NOT for the GNS430 ILS. It is strong anywhere within 30 miles of the ILS airport. Hate to have to crawl into the tailcone to access this grounding point. Wayne ----- Original Message ----- From: "Charlie England" <ceengland(at)bellsouth.net> Subject: Re: AeroElectric-List: Re:A Bugger of an Avionics Problem > > > Seems pretty unlikely that all would have exactly the same problem. Can > you swap antenna cables at the radio trays, fly & try it? Ohm meter > checks of coax will detect only gross problems like DC shorts between > center & ground. If you can't swap antennas, rig up a cable with a > 'rubber ducky' & try that to see if you have a different symptom. > > Another possibility is that the radios aren't seating all the way into > the tray or the connector. Are you screwing in the chassis retaining > screw all the way & making sure that radio goes all the way into the > tray? Is this the version of the Terra with 2 separate radios + the > 'trinav' head? If so, there are several opportunities for > poor/intermittant connections at the various connectors. Slight > variations in connector mounting & chassis cutouts can prevent the sub-d > connectors from seating all the way & lead to truly bizarre symptoms. > The same thing applies to the mating coax connectors between the radios > & the tray. If the tray has shifted in the instrument panel, or if the > new radios have trim bezels from a different batch/mfgr, or , the > radio might not be going all the way into the tray. > > Charlie > > Wayne Sweet wrote: > >> >> >>Peter, >>Thanks for the reply. I replaced the coax at the tray, using new TED >>connectors rather than the funky Terra ones. I have done lots of avionics >>wiring and learned to continuity check all coax connectors. These are >>fine. >>The same problem occurs when I plug in a second (and 3rd) TN200D. I bought >>3 >>Terra NAV/COM on eBay, so have some that will be going up on eBay, >>starting >>this afternoon. >>The problem is the same for all 3 TN200D. The coax connections and >>continuity are fine. >>Very puzzling. >>Wayne >>----- Original Message ----- >>From: "Peter Davidson" <pdavidson(at)familynet.net> >>To: >>Subject: AeroElectric-List: Re:A Bugger of an Avionics Problem >> >> >> >> >>> >>> >>>Wayne, >>>I'm not familiar with the TX760/TN200D system, but it sounds like two >>>possibilities to me. >>>1) If the harness had to be rewired at all for the new components, >>>there's >>>a >>>good possibility that the coax might have been accidentally yanked on or >>>something to cause problems with the connection. >>>2) If the new components were direct replacements, I 'd say it's a >>>defective >>>TN200D. >>>-Peter >>> >>> >>> >>> >>>>I have dual VOR/ILS's; a GNS430 and a recently installed replacement >>>> >>>> >>>TX760/TN200D. >>> >>> >>>>The VOR/GS is taken from a single VOR antenna through a 1 into 4 >>>>splitter. >>>>The Terra is a replacement for an older TX720/TN200, which function >>>>well, >>>> >>>> >>>except >>> >>> >>>>for a squelch problem that Toronto Avionics fixed. I sold that system on >>>> >>>> >>>eBay. >>> >>> >>>>Anyway, this "new" Terra will not consistantly display the CDI for >>>>VOR/LOC >>>> >>>> >>>EXCEPT >>> >>> >>>>when outbound from the ILS. Then I get turned around and inbound on the >>>> >>>> >>>ILS, >>> >>> >>>>the TN200D only displays the GS. The GNS430 is rock solid out and >>>>inbound. >>>> >>>> >>>The >>> >>> >>>>old TN200 did not have this problem; it and the GNS430 were working >>>>fine. >>>>Also, now the Terra TN200D will not display the CDI for the VOR unless >>>>I'm >>>> >>>> >>>almost >>> >>> >>>>on the airport; VOR on airport. The TRI-NAV is wired to display the OBS >>>> >>>> >>>setting >>> >>> >>>>as well as the radial currently on. This works OK, meaning the CDI is >>>> >>>> >>>getting >>> >>> >>>>the correct data. >>>>The only explanation I can come up with, is that the TN200D is less >>>> >>>> >>>sensitive than >>> >>> >>>>the old TN200 and outbound the "rabbit ears" antenna, oriented with the >>>> >>>> >>>"ears" >>> >>> >>>>facing aft and under the tailcone has better reception going away from >>>>the >>>>ILS. This is weird; all airplanes I have seen have the VOR antenna >>>> >>>> >>>"facing" >>> >>> >>>>aft. In addition I was told by an avionics shop that dual VOR/ILS >>>> >>>> >>>typically use >>> >>> >>>>a 1-into-4 quadaplexer, rather than two VOR antennas.. >>>>Has anyone experienced like symtoms?? >>>>Wayne >>>> > > > ________________________________________________________________________________
Date: Jul 30, 2005
Subject: Re: Summing up OVP
I don't think anyone has spoken of any failure mode that would justify case 2. I believe a B-lead contactor has only been proposed in conjunction with an internal VR alternator. Ken bakerocb(at)cox.net wrote: > >AeroElectric-List message previously posted by: Richard Riley > > ><<..........skip.......The problem is X >It can occur when using equipment Y, under the following conditions - >If you use equipment Z instead, it won't happen......skip.......>> > >7/30/2005 > >Hello Richard, I think that your questions are right on target. I'd like to >take a layman's whack at answering them: > >A) "The problem is X" > >The problem is potential damage to an aircraft's electrical, avionics, or >instrument components from an alternator that is putting out excessive >voltage. > >B) "It can occur when using equipment Y......" > >It can occur when using either an internally regulated or an externally >regulated field controlled alternator or a permanent magnet alternator. > >C) "under the following conditions" > >When the voltage regulator (either external or internal) or the alternator >suffers a fault that causes the over voltage condition. > >D) "If you use equipment Z instead, it won't happen" > >There is no way to guarantee that, "it", the over voltage condition, will >never happen with any type of regulator or alternator. So the discussion >moves onto the ongoing thread of how to best protect an aircraft's >electrical, avionics, or instrument components from an alternator that is >putting out excessive voltage. > >1) Case one: Use an externally regulated field controlled alternator and a >mechanism that when an over voltage conditon is detected cuts off the field >current to the field controlled alternator. > >2) Case two: But what if one doesn't feel that just cutting off the field >current provides adequate protection? Then put a separate cut off mechanism >in the externally regulated alternator's output B (for battery) lead that >opens up that lead in time to protect the components at risk. > >3) Case three: But what if the voltage gets so high so quickly that the >separate B lead cut off mechanism cannot do its job in time? How high and >how quick and the best kind of B lead cut off mechanism is what the ongoing >thread is all about. > >4) Case four: Use an internally regulated alternator and depend upon the >internal regulator to not permit an over voltage condition. > >5) Case five: But what if the internal regulator fails to provide adequate >protection? Then put a separate cut off mechanism in the internally >regulated alternator's output B (for battery) lead that opens up that lead >in time to protect the components at risk. > >6) Case six: But what if the voltage gets so high so quickly that the >separate B lead cut off mechanism cannot do its job in time? How high and >how quick and the best kind of B lead cut off mechanism is what the ongoing >thread is all about. > >7) Case seven: Use a permanent magnet alternator and put a separate cut off >mechanism in the permanent magnet alternator's output B (for battery) lead >that opens up that lead in time to protect the components at risk. > >8) Case eight: But what if the voltage gets so high so quickly that the >separate B lead cut off mechanism cannot do its job? How high and how quick >and the best kind of B lead cut off mechanism is what the ongoing thread is >all about. > >So where should one's comfort level reside? Mine stops at Case one, but I am >not trying to push that down any one's throat. > >OC > > > > ________________________________________________________________________________
Date: Jul 30, 2005
> > >I don't think anyone has spoken of any failure mode that would justify > >case 2. I believe a B-lead contactor has only been proposed in > >conjunction with an internal VR alternator. > >Ken > This is my understanding as well. There are really only two "lightning rod" issues here: 1) Crowbar disconnect method VS other methods a) AEC has recommended the crowbar method for shutting down both internally and externally regulated alternators. b) Some say that the crowbar method is outdated and that there are better ways to implement this function. c) Some say that the crowbar method is hazardous due to the low internal resistance of modern batteries. d) I have yet to see a published schematic for any alternative to the AEC crowbar module. e) False triggering will be an "issue of scrutiny" with any disconnect method. 2) B-Lead disconnect & load dump issues a) AEC has recommended a B-lead overvoltage disconnect ONLY for internally regulated alternators. b) It has been shown that a B-lead disconnect can cause a "load dump" event. c) It has been shown that a load dump event can damage some alternators. d) It has been claimed that the installation of Transorbs in the right places can mitigate this problem. Tom Johnson ________________________________________________________________________________
Date: Jul 31, 2005
Tom - That also has been my understanding of the thread - in much more vague terms than you so clearly describe. Thanks for the great summary. John Schroeder > > This is my understanding as well. There are really only two "lightning > rod" issues here: > > 1) Crowbar disconnect method VS other methods > > a) AEC has recommended the crowbar method for shutting down both > internally and externally regulated alternators. > b) Some say that the crowbar method is outdated and that there are > better ways to implement this function. > c) Some say that the crowbar method is hazardous due to the low > internal resistance of modern batteries. > d) I have yet to see a published schematic for any alternative to the > AEC crowbar module. > e) False triggering will be an "issue of scrutiny" with any disconnect > method. > > 2) B-Lead disconnect & load dump issues > > a) AEC has recommended a B-lead overvoltage disconnect ONLY for > internally regulated alternators. > b) It has been shown that a B-lead disconnect can cause a "load dump" > event. > c) It has been shown that a load dump event can damage some > alternators. > d) It has been claimed that the installation of Transorbs in the right > places can mitigate this problem. > > Tom Johnson ________________________________________________________________________________
Subject: crowbar method
Date: Jul 31, 2005
AeroElectric-List message previously posted by: "Thomas Johnson" <<.......skip....... There are really only two "lightning rod" issues here: 1) Crowbar disconnect method VS other methods......skip.....>> 7/31/2005 Hello Tom, Thanks for your input. The term "crowbar disconnect method" has a dramatic, violent, attention getting, and definitive connotation to it, but it is completely non descriptive in terms of what is doing what to what. I'll bet there are dozens of readers just like me that don't know what the method actually consists of. Would you, or some other contributor, please just describe the method in simple layman's terms? I hesitate to suggest such a disruptive change in the use of a term that, through repitition, has become engraved in our consciousness, if not our understanding, but think of the value in increased understanding of using instead a phrase such as "the frammis on the whoosis" method. OC PS: And I really hate to nit pick here, but my layman's brain associates the term "crowbar method" as just an initiating or multiple step process that can lead to ending the undesired output of an alternator. To actually accomplish an alternator disconnect (opening the B lead), however,requires some additional, and apparently rather controversial, hardware. PPS: Deliberate or not, I like your "lightning rod" pun. ________________________________________________________________________________
Date: Jul 31, 2005
On 30 Jul 2005 at 23:30, Thomas Johnson wrote: > > > >> > 1) Crowbar disconnect method VS other methods > > a) AEC has recommended the crowbar method for shutting down both > internally and externally regulated alternators. b) Some say that > the crowbar method is outdated and that there are better ways to > implement this function. c) Some say that the crowbar method is > hazardous due to the low internal resistance of modern batteries. d) > I have yet to see a published schematic for any alternative to the > AEC crowbar module. e) False triggering will be an "issue of > scrutiny" with any disconnect method. > >IMHO, there is always more than one method for tackling this problem. However, I knew nothing about wiring an airplane until I came across Bob's book a few years ago. As a result, I have wired a Velocity and soon my RV9A. Bob at least has attempted to provide me(us) with a method. I can understand a company or would be enterprise who is selling a device to "crowbar" an alternator might not want to share their schematic with the list. But I think it would be helpful to explain there methodology and rudimentary circuit design. Peter Laurence Peter Laurence RV9A wings ________________________________________________________________________________
Date: Jul 31, 2005
Subject: traffic scope antenna
Hi all, For a recently purchased traffic scope I would like to install a fixed antenna. The airplane already has 2 shark fin antennae (one for the transponder and one for the DME). 1) Does anyone have a good source of shark fins (meaning good price and SWR)? I may have to replace one of the existing shark fins (coating cracked) and add another for the traffic scope. 2) How far from the existing shark fins should I install the antenna for the traffic scope? Any possible interference (e.g. from the DME?) 3) Is a less expensive solution appropriate (ebay monopole for $16.95 - http://search.ebay.com/transponder-antenna_W0QQfkrZ1QQfromZR8) ? Advantages/disadvantages of such monopole? Rumen ________________________________________________________________________________
Date: Jul 31, 2005
Subject: Summing up OVP
Taking a further step back, the OVP "discussion" comes down to a cost vs. benefit vs. risk analysis. Thus: A) most modern OBAM aircraft need a power source to run radios, EFIS, GPS, engine instruments, etc. B) the power source is most commonly an engine driven alternator. C) choices in alternators are low production volume (= high cost) specialized aviation units vs. mass-produced (= relatively low cost) automotive units, the latter also often having size/weight advantages as well. D) numberous factors go into the cost/benefit analysis of this choice. E) part of this choice is a risk analysis done to anticipate failue modes(s) and decide what sorts of protective/back-up devices should be added to the system to protect against particular modes. F) the risk analysis involves partly safety of flight issues and partly dollar costs. So that's how people have arrived at Case 5 and the "debate" about providing a cost effective over voltage protection stated in worst "worst case" terms as Case 6. Part of case 6 seems to be about protecting the alternator against damage during a possible "load dump" event during some failures. Given that the automotive alternators we are talking about are in the $100-$200 cost range, and that the avionics in some aircraft are approaching the $10,000 range (Garmin 430s, etc.), then (to myself) the alternator can be regarded as a throwaway "fuse" to protect the much more costly avionics in a complex OBAM aircraft. In my own "built to a budget" aircraft (basic VFR instruments, basic engine instruments, basic VHF & TPNDR avionics) it made no sense to spend $800 to power $1500 worth of avionics so I went with a low cost automotive alternator and spent the $25 to build a "homebrew" OVP device. This was a sensible cost vs. benefit vs. risk analysis to me. I consider there are no "safety of flight" alternator failure issues in my plain jane VFR RV-6A. As in many things in life, you pay your money, you make your choices, and you live with the associated risks. Jim Oke Wpg., MB RV-6A, RV-3 > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken > Sent: July 30, 2005 10:13 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Summing up OVP > > > I don't think anyone has spoken of any failure mode that > would justify case 2. I believe a B-lead contactor has only > been proposed in conjunction with an internal VR alternator. > Ken > > bakerocb(at)cox.net wrote: > > > > >AeroElectric-List message previously posted by: Richard Riley > > > > > ><<..........skip.......The problem is X It can occur when using > >equipment Y, under the following conditions - If you use equipment Z > >instead, it won't happen......skip.......>> > > > >7/30/2005 > > > >Hello Richard, I think that your questions are right on target. I'd > >like to take a layman's whack at answering them: > > > >A) "The problem is X" > > > >The problem is potential damage to an aircraft's electrical, > avionics, > >or instrument components from an alternator that is putting out > >excessive voltage. > > > >B) "It can occur when using equipment Y......" > > > >It can occur when using either an internally regulated or an > externally > >regulated field controlled alternator or a permanent magnet > alternator. > > > >C) "under the following conditions" > > > >When the voltage regulator (either external or internal) or the > >alternator suffers a fault that causes the over voltage condition. > > > >D) "If you use equipment Z instead, it won't happen" > > > >There is no way to guarantee that, "it", the over voltage condition, > >will never happen with any type of regulator or alternator. So the > >discussion moves onto the ongoing thread of how to best protect an > >aircraft's electrical, avionics, or instrument components from an > >alternator that is putting out excessive voltage. > > > >1) Case one: Use an externally regulated field controlled alternator > >and a mechanism that when an over voltage conditon is > detected cuts off > >the field current to the field controlled alternator. > > > >2) Case two: But what if one doesn't feel that just cutting off the > >field current provides adequate protection? Then put a > separate cut off > >mechanism in the externally regulated alternator's output B (for > >battery) lead that opens up that lead in time to protect the > components at risk. > > > >3) Case three: But what if the voltage gets so high so > quickly that the > >separate B lead cut off mechanism cannot do its job in time? > How high > >and how quick and the best kind of B lead cut off mechanism > is what the > >ongoing thread is all about. > > > >4) Case four: Use an internally regulated alternator and depend upon > >the internal regulator to not permit an over voltage condition. > > > >5) Case five: But what if the internal regulator fails to provide > >adequate protection? Then put a separate cut off mechanism in the > >internally regulated alternator's output B (for battery) lead that > >opens up that lead in time to protect the components at risk. > > > >6) Case six: But what if the voltage gets so high so quickly > that the > >separate B lead cut off mechanism cannot do its job in time? > How high > >and how quick and the best kind of B lead cut off mechanism > is what the > >ongoing thread is all about. > > > >7) Case seven: Use a permanent magnet alternator and put a > separate cut > >off mechanism in the permanent magnet alternator's output B (for > >battery) lead that opens up that lead in time to protect the > components at risk. > > > >8) Case eight: But what if the voltage gets so high so > quickly that the > >separate B lead cut off mechanism cannot do its job? How > high and how > >quick and the best kind of B lead cut off mechanism is what > the ongoing > >thread is all about. > > > >So where should one's comfort level reside? Mine stops at > Case one, but > >I am not trying to push that down any one's throat. > > > >OC > > > > > > > > > > > Photoshare, and much much more: > > > >\] ________________________________________________________________________________
Date: Jul 31, 2005
Subject: Re: crowbar method
I'll take a stab at this. Crowbar just means that when the Overvoltage trips the SCR, the SCR shorts out the power.( Kind of like throwing a crowbar across the battery to short things out.) That immediately starts dropping the voltage (a good thing) and the current flow through the CB trips the CB to permanently shutdown the alternator. The SCR causes a significant momentary current flow or pulse from the battery through the CB. There have been some (unsubstantiated in my opinion) allegations that it could be harmful in vague ways. No circuitry to do this any other way has been presented by anyone here as far as I know however one person here does sell an alternative product for shutting things down. I don't think there is much controversy over the method of opening a B lead connection for an internal VR alternator. We seem to know that a standard $15. battery contactor is simply not guranteed to do this reliably as the voltage may climb way above 12 volts and cause contact arcing. I'm sticking with the crowbar and the advantage of feedback on its performance from other list members. So far I have yet to purchase an aviation related electronic device that hasn't required modification, repair, or information in addition to what the manufacturer provided so I put a high value on understanding what I use and feedback from this list. Ken bakerocb(at)cox.net wrote: > >AeroElectric-List message previously posted by: "Thomas Johnson" > > ><<.......skip....... There are really only two "lightning rod" issues >here: > >1) Crowbar disconnect method VS other methods......skip.....>> > >7/31/2005 > >Hello Tom, Thanks for your input. The term "crowbar disconnect method" has a >dramatic, violent, attention getting, and definitive connotation to it, but >it is completely non descriptive in terms of what is doing what to what. > >I'll bet there are dozens of readers just like me that don't know what the >method actually consists of. Would you, or some other contributor, please >just describe the method in simple layman's terms? > >I hesitate to suggest such a disruptive change in the use of a term that, >through repitition, has become engraved in our consciousness, if not our >understanding, but think of the value in increased understanding of using >instead a phrase such as "the frammis on the whoosis" method. > >OC > >PS: And I really hate to nit pick here, but my layman's brain associates the >term "crowbar method" as just an initiating or multiple step process that >can lead to ending the undesired output of an alternator. To actually >accomplish an alternator disconnect (opening the B lead), however,requires >some additional, and apparently rather controversial, hardware. > >PPS: Deliberate or not, I like your "lightning rod" pun. > > ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Date: Jul 31, 2005
OC, Jim Weir wrote a nice column explaining what a crowbar circuit does and how to fashion one in the September '01 KITPLANES. If you don't have the magazine, you can read the article here: http://www.rst-engr.com/kitplanes/KP0109/KPtext.pdf John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: crowbar method AeroElectric-List message previously posted by: "Thomas Johnson" <<.......skip....... There are really only two "lightning rod" issues here: 1) Crowbar disconnect method VS other methods......skip.....>> 7/31/2005 Hello Tom, Thanks for your input. The term "crowbar disconnect method" has a dramatic, violent, attention getting, and definitive connotation to it, but it is completely non descriptive in terms of what is doing what to what. I'll bet there are dozens of readers just like me that don't know what the method actually consists of. Would you, or some other contributor, please just describe the method in simple layman's terms? I hesitate to suggest such a disruptive change in the use of a term that, through repitition, has become engraved in our consciousness, if not our understanding, but think of the value in increased understanding of using instead a phrase such as "the frammis on the whoosis" method. OC PS: And I really hate to nit pick here, but my layman's brain associates the term "crowbar method" as just an initiating or multiple step process that can lead to ending the undesired output of an alternator. To actually accomplish an alternator disconnect (opening the B lead), however,requires some additional, and apparently rather controversial, hardware. PPS: Deliberate or not, I like your "lightning rod" pun. ________________________________________________________________________________
Date: Jul 31, 2005
>I'll take a stab at this. Crowbar just means that when the Overvoltage trips the SCR, the SCR shorts out the power.( Kind of like throwing a crowbar across the battery to short things out.) That immediately starts dropping the voltage (a good thing) and the current flow through the CB trips the CB to permanently shutdown the alternator. Correct. However, the circuit breaker is not rated for this abuse. Nor is adding a small resistor to bring the currents down simple (see earlier posts), since pulse resistors are a special breed. >The SCR causes a significant momentary current flow or pulse from the battery through the CB. There have been some (unsubstantiated in my opinion) allegations that it could be harmful in vague ways. Unsubstantiated allegations? The circuit breaker is not rated for the current. It is the designer's responsibilty to make sure the design meets the requirement. To use the term "unsubstantiated allegations" seems very strange when discussing merely technical performance. The "allegations" are very much substantiated. The circuit breaker won't do the job. Look it up. >No circuitry to do this any other way has been presented by anyone here as >far as I know however one person here does sell an alternative product for >shutting things down.< I am that person. Since I sell a part called the Linear Over Voltage Module, I don't want to release the schematic, but I will tell you it uses a LTC1696 available only in an SOT-23-6 package that is not suitable for most builders to assemble. "Linear" (non-crowbar) OVPs aren't hard to design but they have 5 mosfets and 20 other parts. But the important point is that the LOVM just cuts off the field current. This is the preferred method. Let me slop a pearl....nobody has used a crowbar for this application in 30 years. >I don't think there is much controversy over the method of opening a B lead >connection for an internal VR alternator. We seem to know that a standard >$15 battery contactor is simply not guranteed to do this reliably as the >voltage may climb way above 12 volts and cause contact arcing.< True. The Kilovac "Czonka III" EV200AAANA is the contactor that will do the job and has a 100 mA coil as a bonus. (I have a few of these cheap if you contact me offlist.) Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "I tried being reasonable, I didn't like it." ---Clint Eastwood ________________________________________________________________________________
Date: Jul 31, 2005
> > > >> I'll take a stab at this. Crowbar just means that when the >> Overvoltage >> > trips the SCR, the SCR shorts out the power.( Kind of like throwing a > crowbar across the battery to short things out.) That immediately > starts > dropping the voltage (a good thing) and the current flow through > the CB > trips the CB to permanently shutdown the alternator. > > Correct. However, the circuit breaker is not rated for this abuse. > Nor is > adding a small resistor to bring the currents down simple (see earlier > posts), since pulse resistors are a special breed. > > >> The SCR causes a significant momentary current flow or pulse from the >> > battery through the CB. There have been some (unsubstantiated in my > opinion) allegations that it could be harmful in vague ways. > > Unsubstantiated allegations? The circuit breaker is not rated for the > current. It is the designer's responsibilty to make sure the design > meets > the requirement. To use the term "unsubstantiated allegations" > seems very > strange when discussing merely technical performance. The > "allegations" are > very much substantiated. The circuit breaker won't do the job. Look > it up. > > The CB specs provide an envelope of conditions under which the CB should perform as advertised, repeatedly - i.e. it will trip within a certain time, at a certain tolerance to the advertised trip current. But the spec sheet doesn't say what will happen if it is operated at other conditions. It doesn't say how its performance will be affected. So how do we know it won't do the job? Is there evidence that it won't do the job, or is the statement "the circuit breaker won't do the job" simply an unsubstantiated allegation? I'd love to see the test results that show the CB in a crowbar OVP won't do the job. Bob has described tests he has down that show the CB will do the job, and the only complaints from the field seem to be some installations that are prone to nuisance trips. The later variants of the design are reputed to be less prone to nuisance trips. If we operate the CB outside its rated current repeatedly, this could possibly affect the current at which the CB will open. But, the exact value at which it opens isn't important in this application. Normally there is very little current through the CB. If there is an overvoltage, and the OVP trips, there will be a very large current though the CB. We only need the CB to differentiate between a very small current, and a very large one. It doesn't matter exactly what its trip point is. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 31, 2005
This is where we disagree I guess Eric. Circuit breakers are used to interupt an overcurrent situation. My opinion is that the most common overcurrent situation is a short circuit. This is what circuit breakers do. If I didn't think a circuit breaker was acceptable for this I wouldn't use them anywhere else either as I'd have to replace the breaker every time it tripped and fuses are cheaper in that case. Mine still seem to do the job after several dozen OVM trips fed by modern AGM batteries... Ken >Unsubstantiated allegations? The circuit breaker is not rated for the >current. It is the designer's responsibilty to make sure the design meets >the requirement. To use the term "unsubstantiated allegations" seems very >strange when discussing merely technical performance. The "allegations" are >very much substantiated. The circuit breaker won't do the job. Look it up. > > ________________________________________________________________________________
Date: Jul 31, 2005
Kevin Horton wrote: > > > >> >> >> >> >> >> >>>I'll take a stab at this. Crowbar just means that when the >>>Overvoltage >>> >>> >>> >>trips the SCR, the SCR shorts out the power.( Kind of like throwing a >>crowbar across the battery to short things out.) That immediately >>starts >>dropping the voltage (a good thing) and the current flow through >>the CB >>trips the CB to permanently shutdown the alternator. >> >>Correct. However, the circuit breaker is not rated for this abuse. >>Nor is >>adding a small resistor to bring the currents down simple (see earlier >>posts), since pulse resistors are a special breed. >> >> >> >> >>>The SCR causes a significant momentary current flow or pulse from the >>> >>> >>> >>battery through the CB. There have been some (unsubstantiated in my >>opinion) allegations that it could be harmful in vague ways. >> >>Unsubstantiated allegations? The circuit breaker is not rated for the >>current. It is the designer's responsibilty to make sure the design >>meets >>the requirement. To use the term "unsubstantiated allegations" >>seems very >>strange when discussing merely technical performance. The >>"allegations" are >>very much substantiated. The circuit breaker won't do the job. Look >>it up. >> >> >> >> > >The CB specs provide an envelope of conditions under which the CB >should perform as advertised, repeatedly - i.e. it will trip within a >certain time, at a certain tolerance to the advertised trip current. >But the spec sheet doesn't say what will happen if it is operated at >other conditions. It doesn't say how its performance will be >affected. So how do we know it won't do the job? Is there evidence >that it won't do the job, or is the statement "the circuit breaker >won't do the job" simply an unsubstantiated allegation? > >I'd love to see the test results that show the CB in a crowbar OVP >won't do the job. Bob has described tests he has down that show the >CB will do the job, and the only complaints from the field seem to be >some installations that are prone to nuisance trips. The later >variants of the design are reputed to be less prone to nuisance trips. > >If we operate the CB outside its rated current repeatedly, this could >possibly affect the current at which the CB will open. But, the >exact value at which it opens isn't important in this application. >Normally there is very little current through the CB. If there is an >overvoltage, and the OVP trips, there will be a very large current >though the CB. We only need the CB to differentiate between a very >small current, and a very large one. It doesn't matter exactly what >its trip point is. > >Kevin Horton RV-8 (finishing kit) >Ottawa, Canada >http://www.kilohotel.com/rv8 > Others have posted on this topic who can speak with much more authority than I, but it seems to me that saying that a breaker isn't designed to open a circuit when there's a short flies in the face of all logic. It seems to me, that's why it's there in the 1st place. It isn't there to protect some device from moderate over-current; the mfgr of the device has the responsibility to do that. The breaker is there to protect downstream wire from melting/burning in the case of gross over-current conditions (shorts). Would anyone maintain that we should go find some high tech alternative for our house breakers because they aren't designed to open the circuit if someone shorts out a circuit by accidentally cutting into a lamp cord with a pair of scissors? Aren't the crowbar circuits being discussed designed to short across the supply to the field winding of the alternator? Following the 'not designed for the job' argument, is another solution needed for a traditional alternator field breaker in its traditional role considering that a wire between the breaker & the alternator might inadvertently rub against the chassis somewhere & short to ground? If the breaker is unsuitable for a crowbar circuit, it is just as unsuitable to open the same circuit if there is an insulation failure on the wire & it touches a grounded portion of the airframe. I haven't seen anyone say that repeated trips of the breaker due to hard shorts is a good thing. Most breakers aren't designed for high cycling counts; they are just there to protect against the (hopefully) rare catastrophic event. If there is repeated cycling, the problem needs to be fixed, not designed around with some high tech circuit. If I have hundreds of trip events of a circuit breaker & it eventually fails to protect the circuit, I'm probably getting what I deserve. On the other hand, if it won't protect against at least a few catastrophic short events over the life of the a/c, I've wasted my money on that high-dollar breaker. Charlie no technical degrees after my name but a career in consumer & industrial electronics maintenance behind me ________________________________________________________________________________
Date: Jul 31, 2005
>This is where we disagree I guess Eric. Circuit breakers are used to interupt an overcurrent situation. My opinion is that the most common overcurrent situation is a short circuit. This is what circuit breakers do. If I didn't think a circuit breaker was acceptable for this I wouldn't use them anywhere else either as I'd have to replace the breaker every time it tripped and fuses are cheaper in that case. Mine still seem to do the job after several dozen OVM trips fed by modern AGM batteries...Ken Nothing is as simple as it seems. The manufacturers publish specificatons on what their products are rated to do. But even in the most simple situations it is just plain wrong to think you can stretch the limits. Maybe you can get away with it once or twice--but as a design, it is always a mistake to think you know better than the manufacturer. After all the manufacture would LOVE to find out their parts work above their design--that their Buna-N Orings operate at 40 degrees F. It's money in the bank for them. And even then you risk the manufacturer's right to modify the device while remaining inside her specifications. This is a common engineer's trap. There are ALWAYS free-floating specs that the manufacurer won't guarantee. In this case, the tests haven't been done and the parts aren't specified to do the job. If a circuit breaker is called upon to interrupt a current above its designed rating (volts, amps, temp, time, etc.), the contacts can weld, the mechanism can blow apart, the materials can change properties, the spacings may be inadequate, the repeat characteristics can change. Furthermore it is up to the designer to show the design is right. Even in the case where a new design requires testing--the tests have to be done and documented. These alligators....are substantial. >The CB specs provide an envelope of conditions under which the CB should perform as advertised, repeatedly - i.e. it will trip within a certain time, at a certain tolerance to the advertised trip current. But the spec sheet doesn't say what will happen if it is operated at other conditions. It doesn't say how its performance will be affected. So how do we know it won't do the job? Is there evidence that it won't do the job, or is the statement "the circuit breaker won't do the job" simply an unsubstantiated allegation? "So how do we know it won't do the job?" We don't. But it's a silly question to ask. Think about it. Okay, maybe it WILL do the job. Maybe. >I'd love to see the test results that show the CB in a crowbar OVP won't do the job. Bob has described tests he has down that show the CB will do the job, and the only complaints from the field seem to be some installations that are prone to nuisance trips. The later variants of the design are reputed to be less prone to nuisance trips. Paul Messinger has data on the crowbar OVP showing adequate current to trash the CB. ....but he also has a burr under his saddle. And a stone in his boot. But he makes the good point and I agree, that it is not up to anybody else to show the crowbar/CB is suited for the job. That's not how science works. So don't be too annoyed that he doesn't want to finish the report. >If we operate the CB outside its rated current repeatedly, this could possibly affect the current at which the CB will open. But, the exact value at which it opens isn't important in this application. Normally there is very little current through the CB. If there is an overvoltage, and the OVP trips, there will be a very large current though the CB. We only need the CB to differentiate between a very small current, and a very large one. It doesn't matter exactly what its trip point is. Kevin Horton Kevin...Maybe, but what if you designed this into a real airplane? Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "The man who carries a cat by the tail learns something that can be learned in no other way." - Mark Twain ________________________________________________________________________________
Date: Jul 31, 2005
ceengland(at)bellsouth.net >>Others have posted on this topic who can speak with much more authority than I, but it seems to me that saying that a breaker isn't designed to open a circuit when there's a short flies in the face of all logic. It seems to me, that's why it's there in the 1st place. It isn't there to protect some device from moderate over-current; the mfgr of the device has the responsibility to do that. The breaker is there to protect downstream wire from melting/burning in the case of gross over-current conditions (shorts). Would anyone maintain that we should go find some high tech alternative for our house breakers because they aren't designed to open the circuit if someone shorts out a circuit by accidentally cutting into a lamp cord with a pair of scissors? Charlie--A short circuit can produce high currents limited only by the circuit impedance. This impedance can be very very low. That's the problem. At 14.5 volts, a short of 0.001 ohms is 14500 amps. Of course your 5A circuit breaker would emit gamma rays at this current. (I'm not kidding). Lucky for us, in the real world the circuit breaker will probably not have to handle such a current, but the crowbar/CB combination WILL suffer damage as currently designed. Bob and Paul argued the exact current---but in summary it depends on where the battery is and what the battery is. >>Aren't the crowbar circuits being discussed designed to short across the supply to the field winding of the alternator? Following the 'not designed for the job' argument, is another solution needed for a traditional alternator field breaker in its traditional role considering that a wire between the breaker & the alternator might inadvertently rub against the chassis somewhere & short to ground? If the breaker is unsuitable for a crowbar circuit, it is just as unsuitable to open the same circuit if there is an insulation failure on the wire & it touches a grounded portion of the airframe. Negatory, the normal length of wire between the CB and the alternator or regulator will reduce the current by resistance and inductance a little bit, and that is enough to allow the 5A breaker to work as designed. In the case of the OVP/CB, this grounding can be a very large current. (but it depends on layout....). Also real short circuits are rarely "slammed down hard to ground". >>I haven't seen anyone say that repeated trips of the breaker due to hard shorts is a good thing. Most breakers aren't designed for high cycling counts; they are just there to protect against the (hopefully) rare catastrophic event. If there is repeated cycling, the problem needs to be fixed, not designed around with some high tech circuit. If I have hundreds of trip events of a circuit breaker & it eventually fails to protect the circuit, I'm probably getting what I deserve. On the other hand, if it won't protect against at least a few catastrophic short events over the life of the a/c, I've wasted my money on that high-dollar breaker. Correcto. And since breakers don't have "History Recorders" on them, it's hard to know. Even the first trip can be a problem operated outside of the manufacturers specs. Maybe you'll get lucky. Or maybe you'll be in Huatabampo Mexico (a very nice town, but not many replacement parts). Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 ________________________________________________________________________________
Date: Jul 31, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> again!
Subject: Re: Paul M. has risen from the dead
again! >Geez, I see that "Pope Paul M." is once again pontificating. Lord! why >can't he be excommunicated? > >Peter Van Caulart Folks, I really would like to focus on simple-ideas, repeatable experiments and to encourage any honorable action that helps move our craft forward. This kind of response adds nothing useful to anyone's experience. I've had a ton of flack from a few who want this discussion "moved off list" or "burried" etc. etc. I've encourage folks who are upset by the discussion to please not read it. There's another group of folks who need the list deal with "where to I buy" and "how do I hook up" kinds of questions. For those folks too, I would encourage you to use the delete key. For those who are interested in learning how logic, simple-ideas, and cooperative design review can filter the BS and suggest ways to make your airplane work better, cost less and be easier to repair, then keep a finger on the pulse of things. But if any part of it upsets you for any reason other a proffering of bad science or a demonstration of bad behavior, then please don't read it. Life is too short and your airplane project is taking too long, you don't need more aggravation. Don't for a moment think that I'm one bit tense over these discussions. When I'm tense, I'll make it known and describe the exact reason why. Unless you have some specific questions and/or contribution to the discussions, please don't throw more cabbages and tomatoes. It doesn't help. Thanks! Bob . . . ________________________________________________________________________________
Date: Jul 31, 2005
Subject: Re: I've got a secret
> >If you think that's hateful, you must be new to the internet. > >Are you capable of summing up this amazingly useless, endless thread >in one paragraph? Like > >The problem is X >It can occur when using equipment Y, under the following conditions - >If you use equipment Z instead, it won't happen. > >I appreciate the free ice cream that Bob delivers here. It's not >always my favorite flavor, but it's still free. (That's a metaphor, BTW) Gentlemen, please. If you're not a participant in seeking solutions, please don't be part of an unrelated problem. Nobody is guaranteed an insult free existence . . . but keep in mind that one can only be insulted if you give someone permission to do it! Bob . . . ________________________________________________________________________________
Date: Jul 31, 2005
Eric M. Jones wrote: > >ceengland(at)bellsouth.net > > > >>>Others have posted on this topic who can speak with much more authority >>> >>> >than I, but it seems to me that saying that a breaker isn't designed to >open a circuit when there's a short flies in the face of all logic. It >seems to me, that's why it's there in the 1st place. It isn't there to >protect some device from moderate over-current; the mfgr of the device >has the responsibility to do that. The breaker is there to protect >downstream wire from melting/burning in the case of gross over-current >conditions (shorts). Would anyone maintain that we should go find some >high tech alternative for our house breakers because they aren't >designed to open the circuit if someone shorts out a circuit by >accidentally cutting into a lamp cord with a pair of scissors? > >Charlie--A short circuit can produce high currents limited only by the >circuit impedance. This impedance can be very very low. That's the problem. >At 14.5 volts, a short of 0.001 ohms is 14500 amps. Of course your 5A >circuit breaker would emit gamma rays at this current. (I'm not kidding). >Lucky for us, in the real world the circuit breaker will probably not have >to handle such a current, but the crowbar/CB combination WILL suffer damage >as currently designed. Bob and Paul argued the exact current---but in >summary it depends on where the battery is and what the battery is. > > > >>>Aren't the crowbar circuits being discussed designed to short across the >>> >>> >supply to the field winding of the alternator? Following the 'not >designed for the job' argument, is another solution needed for a >traditional alternator field breaker in its traditional role considering >that a wire between the breaker & the alternator might inadvertently rub >against the chassis somewhere & short to ground? If the breaker is >unsuitable for a crowbar circuit, it is just as unsuitable to open the >same circuit if there is an insulation failure on the wire & it touches >a grounded portion of the airframe. > >Negatory, the normal length of wire between the CB and the alternator or >regulator will reduce the current by resistance and inductance a little bit, >and that is enough to allow the 5A breaker to work as designed. In the case >of the OVP/CB, this grounding can be a very large current. (but it depends >on layout....). Also real short circuits are rarely "slammed down hard to >ground". > > > >>>I haven't seen anyone say that repeated trips of the breaker due to hard >>> >>> >shorts is a good thing. Most breakers aren't designed for high cycling >counts; they are just there to protect against the (hopefully) rare >catastrophic event. If there is repeated cycling, the problem needs to >be fixed, not designed around with some high tech circuit. If I have >hundreds of trip events of a circuit breaker & it eventually fails to >protect the circuit, I'm probably getting what I deserve. On the other >hand, if it won't protect against at least a few catastrophic short >events over the life of the a/c, I've wasted my money on that >high-dollar breaker. > >Correcto. And since breakers don't have "History Recorders" on them, it's >hard to know. Even the first trip can be a problem operated outside of the >manufacturers specs. Maybe you'll get lucky. Or maybe you'll be in >Huatabampo Mexico (a very nice town, but not many replacement parts). > >Regards, >Eric M. Jones >www.PerihelionDesign.com >113 Brentwood Drive >Southbridge MA 01550-2705 >(508) 764-2072 > But Eric, if the crowbar is after the alternator field breaker, all the wire between the battery & the breaker & load mentioned in your argument is still there (or not there). If the breaker is in danger from the crowbar, it follows that it is in danger from an inadvertent short circuit. Yet alternator field circuit breakers seem to have survived as a design since the dawn of alternators in a/c. (If I could be convinced that this 'slam down' technique really is dangerous, why do I need dozens of extra components to solve the problem? Why not just use one of those gadgets with inverse temperature coefficient used to soft start incandescent lamps in series with the crowbar?) Charlie ________________________________________________________________________________
Date: Jul 31, 2005
Subject: Re: Diode orientation
> >Bob, et al, > >My Navaid installation manual recommends a diode between the Navaid pin >7 and the Comm PTT circuit. The Navaid schematic shows a black and white >diode with a large white area and a small black stipe on one end. The >white area is oriented toward the Comm unit and the black stripe >oriented toward the PTT circuit. However, the diode I received from B&C >is mostly black with a small grey stripe at one end. > >Can I assume that the large black end of the diode equates to the large >white end on the Navaid schematic? The descriptions you're making for the parts and wiring diagram are don't give us a clear image of the instructions. Most wire lead diodes have a "band" on one end and the color of the band is insignificant. It will be some color that contrasts with the body color of the diode itself. The banded end corresponds to the "cathode". In a diode's schematic, the "bar" touched by the arrowhead is the cathode while the arrowhead itself is the anode. Electrons flow through a diode in opposition to direction of arrow. See: http://www.aeroelectric.com/Pictures/Diode_Wiring_2.jpg Some folks are confused when they see diodes used for two different tasks like "steering" as shown in -A- and -B- and spike clipping as shown in -C- and -D-. Do you have a real schematic of the wiring were the bar and arrowhead are seen in the classic diode symbol . . . or is it a comic book wiring diagram that shows only pictures? Sounds like you're working with the latter. In this case, go by which end has a band on it irrespective of color. Do they say what this diode is supposed to do? I'm mystified by the need hook any part of your comm transceiver to the autopilot. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2005
Eric M. Jones wrote: > > >ceengland(at)bellsouth.net > > >>>Others have posted on this topic who can speak with much more authority >>> >>> >than I, but it seems to me that saying that a breaker isn't designed to >open a circuit when there's a short flies in the face of all logic. It >seems to me, that's why it's there in the 1st place. It isn't there to >protect some device from moderate over-current; the mfgr of the device >has the responsibility to do that. The breaker is there to protect >downstream wire from melting/burning in the case of gross over-current >conditions (shorts). Would anyone maintain that we should go find some >high tech alternative for our house breakers because they aren't >designed to open the circuit if someone shorts out a circuit by >accidentally cutting into a lamp cord with a pair of scissors? > >Charlie--A short circuit can produce high currents limited only by the >circuit impedance. This impedance can be very very low. That's the problem. >At 14.5 volts, a short of 0.001 ohms is 14500 amps. Of course your 5A >circuit breaker would emit gamma rays at this current. (I'm not kidding). >Lucky for us, in the real world the circuit breaker will probably not have >to handle such a current, but the crowbar/CB combination WILL suffer damage >as currently designed. Bob and Paul argued the exact current---but in >summary it depends on where the battery is and what the battery is. > > >>>Aren't the crowbar circuits being discussed designed to short across the >>> >>> >supply to the field winding of the alternator? Following the 'not >designed for the job' argument, is another solution needed for a >traditional alternator field breaker in its traditional role considering >that a wire between the breaker & the alternator might inadvertently rub >against the chassis somewhere & short to ground? If the breaker is >unsuitable for a crowbar circuit, it is just as unsuitable to open the >same circuit if there is an insulation failure on the wire & it touches >a grounded portion of the airframe. > >Negatory, the normal length of wire between the CB and the alternator or >regulator will reduce the current by resistance and inductance a little >bit, >and that is enough to allow the 5A breaker to work as designed. In the case >of the OVP/CB, this grounding can be a very large current. (but it depends >on layout....). Also real short circuits are rarely "slammed down hard to >ground". > > >>>I haven't seen anyone say that repeated trips of the breaker due to hard >>> >>> >shorts is a good thing. Most breakers aren't designed for high cycling >counts; they are just there to protect against the (hopefully) rare >catastrophic event. If there is repeated cycling, the problem needs to >be fixed, not designed around with some high tech circuit. If I have >hundreds of trip events of a circuit breaker & it eventually fails to >protect the circuit, I'm probably getting what I deserve. On the other >hand, if it won't protect against at least a few catastrophic short >events over the life of the a/c, I've wasted my money on that >high-dollar breaker. > >Correcto. And since breakers don't have "History Recorders" on them, it's >hard to know. Even the first trip can be a problem operated outside of the >manufacturers specs. Maybe you'll get lucky. Or maybe you'll be in >Huatabampo Mexico (a very nice town, but not many replacement parts). > >But Eric, if the crowbar is after the alternator field breaker, all the >wire between the battery & the breaker & >load mentioned in your argument >is still there (or not there). If the breaker is in danger from the >crowbar, it >follows that it is in danger from an inadvertent short >circuit. Yet alternator field circuit breakers seem to have >survived as a >design since the dawn of alternators in a/c.(If I could be convinced that >this 'slam down' technique >really is dangerous, why do I need dozens of >extra components to solve the problem? Why not just use one of >those >gadgets with inverse temperature coefficient used to soft start >incandescent lamps (sorry; I forget the >name of the device> in series with >the crowbar?)Charlie Charlie, I have decided that this whole issue would be easier if I released the design of my Linear OVM. (email me if you want the PDF). A kit-built version is still unlikely but perhaps Bob or somone will make something similar. The circuit breaker current is limited by the impedance (the combined resistance and inductance and other contributions to reducing the current). This is highly dependent on wiring layout. >>why do I need dozens of extra components to solve the problem?.......... Which parts would you like me to remove (as Mozart might have said)? And why is my income tax form so complicated? The devil is in the details. Yes, there are other ways to do this. A thermistor might be one way. To lower the peak current throught the CB, even a loop of wire will help. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Everything you've learned in school as "obvious" becomes less and less obvious as you begin to study the universe. For example, there are no solids in the universe. There's not even a suggestion of a solid. There are no absolute con- tinuums. There are no surfaces. There are no straight lines." - R. Buckminster Fuller ________________________________________________________________________________
Date: Aug 01, 2005
> > >But Eric, if the crowbar is after the alternator field breaker, all the >wire between the battery & the breaker & load mentioned in your argument >is still there (or not there). If the breaker is in danger from the >crowbar, it follows that it is in danger from an inadvertent short >circuit. Yet alternator field circuit breakers seem to have survived as >a design since the dawn of alternators in a/c. > >(If I could be convinced that this 'slam down' technique really is >dangerous, why do I need dozens of extra components to solve the >problem? Why not just use one of those gadgets with inverse temperature >coefficient used to soft start incandescent lamps name of the device> in series with the crowbar?) The trade name for these devices is Polyswitch. These are the same devices that EXPBus and Greg Richter have embraced as their circuit protectors of choice. See: http://www.circuitprotection.com/polyswitch.asp These are simply replacements for breakers and fuses and have no ability to sense and react to an ov condition. There were two major drivers in design goals for the development of the crowbar system 25 years ago. (1) replace expensive/troublesome relays with a solid state device and (2) reduce if not eliminate all increase of power pathway resistance between the bus and a voltage regulator. Popular voltage regulators of the time did not have separate bus sense and field power leads. This opens the door for voltage regulator instability (bouncing ammeter syndrome) as aging of components between regulator and bus increase the series resistance to the point where the regulator becomes unstable. (I'm working on an article that addresses this phenomenon in response to an AeroElectric List posting concerning a bouncing ammeter). Many articles have been written about the cure for bouncing ammeter syndrome wherein the writer speaks to replacement of some component as being the cure . . . when in fact, resistance of ALL components in the power pathway contribute to the effect and replacing one of them simple reduces TOTAL resistance to some value below the threshold of instability. In a nutshell, the article I'm working on suggests that 30+ year old airplanes that present with the bouncing ammeter syndrome will benefit from complete replacement of all ohmic (pressure joints) in wiring between the bus and the regulator. Total refurbishment will put the airplane back into a factory new condition for this pathway offers a high probability of 30 more years of stable operation. Replacing but one of several contributors to the problem will 'cure' the instability for a relatively short time. Crowbar ov protection was an ideal solution to part of this problem because it inserted NO series resistance into the pathway it controlled. Further, its parts count was quite low and the design problems with system integration for controlling nuisance trips were achievable. Folks have suggested there was no good reason for doing ov protection this way . . . but had they read any of the history of the philosophy and understood all the design goals then perhaps the reasoning would have been clear. Unusual? Yes, but it was not considered and adopted as a passing fad. There were reasons traded off with system integration issues to be solved. And except for instances where individuals with agendas inserted themselves into the relationship between honorable suppliers and customers who were entitled their money's worth, the concept has performed well in the field. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2005
> >Charlie--A short circuit can produce high currents limited only by the >circuit impedance. This impedance can be very very low. That's the problem. >At 14.5 volts, a short of 0.001 ohms is 14500 amps. Of course your 5A >circuit breaker would emit gamma rays at this current. (I'm not kidding). >Lucky for us, in the real world the circuit breaker will probably not have >to handle such a current, but the crowbar/CB combination WILL suffer damage >as currently designed. Bob and Paul argued the exact current---but in >summary it depends on where the battery is and what the battery is. The battery is but ONE of many contributors to source impedance. Judicious use of crowbar ov protection demands that one not design for worst case fault currents during the crowbar event and by inference (if nothing else) our wiring diagrams suggest far less than worse case installations. Nowhere do we suggest that the system should be assembled with a .003 ohm circuit breaker and zero lead lengths between the bus and the crowbar device. So the hypothesized 700, 500 and/or 14,500 amp current flows simply never happen. The biggest 24 volt batteries we install at RAC will only dump about 3000 amps with a dead short on their terminals . . . so be wary of writers who toss around really big numbers to impress . . . they don't happen in real life. Which leaves us debating whether one should design the system to avoid damaging a breaker (which has yet to be demonstrated) during what should be a very rare event or should we concentrate on getting a failed alternator disconnected first and worry about circuit breaker life later? By the way, a runaway alternator disconnected from the bus by opening a b-lead contactor will continue to run to its own destruction. So, if the ovp system has to operate for a real ov event in an automotive alternator installation, overstress to the circuit breaker is going to be a trivial concern. I'll suggest that one not even consider the battery's source impedance in controlling crowbar fault current. ASSUME zero source impedance. Now, build enough loop resistance into the system by simply following the installation instructions and you'll be just fine. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2005
Subject: The fatwire ground blues . . .
>Comments/Questions: I am implementing your dual alt/batt/buss system on my >GA-III. I fried a ground wire(lots of smoke)due to a loose battery ground >connection while cranking the starter! The fried wire went to the fuel >flow sensor mounted on the engine block. The starter return current tried >to use the smaller wire due to a loose battery ground connector to the >Alt-Battery. Should the sensors(Vision Micro) mounted on the engine block >(fuel flow, fuel press, oil temp, oil press) have ground wires that >connect to the engine block? These wires can be potential return paths for >heavy starter current with a loose (-) battery connection. I'm not sure I visualize exactly what happened here. My recommendation is that all high current grounds like crankcase and battery(-) leads come to a firewall ground stud as illustrated in Chapter 5 of the 'Connection. Your experience is not uncommon. Folks on the airport we owned had two wire-smoking incidents similar to yours for the 6 months we had the business! Careful adherence to the ground architectures described in Chapter 5 will reduce noise and possibly prevent a recurrence . . . IF you are mindful of doors that open every time you unhook a 'fat' wire and being careful that they're all put back before you attempt to operate the system . . . ESPECIALLY crank the engine. Bob . . . ________________________________________________________________________________
Subject: RE: [luscombe-silvaire] Need help with Apollo GPS
Date: Aug 01, 2005
Back on the list. I was bumped while in OSH for some reason. Catching up and saw Bill's request on the Apollo unit. So if you're not interested don't bother reading the "too much information" below: Bill: The 360 GPS is updated with a DOS-based transfer program provided on the program diskette. I have both. The program is very, very basic and merely loads the new dataset into the unit. It is not Windows and has not been updated since about 1996. Works fine. You are, however, offered the option of saving existing user waypoints first to restore them after a new database is loaded. The software does not show any of the display on the unit itself. When the GPS was initially purchased it came with a computer interface connector to be located on the panel somewhere so updates would not require the removal of the unit. If your unit is used it may not have this remote serial connector. Also, many avionics shops skipped this step. If you don't have that then you may have to remove the unit in order to update. Pin-Out diagrams are included in the installation manual. When you order a database update from Garmin AT it will arrive on a second diskette the program will load. However, the unit does output about 3 different versions of serial data. I send moving-map serial data to my EDM800 engine monitor and it uses that information in fuel calculations. You can also use this output to run a third-party software such as Anwywhere Map, AirGator, Mountainscope or even the likes of an Aspen Avionics AT300 multifunction display. Check with the software manufacturer. Use the pin-out diagram to make your own cable or hire your local avionics tech to do it for you (be sure they use shielded cable for serial cable and ground shield at source end). The Apollo (UPSAT, GarminAT?) kit cables are strictly set up for database updates and do not contain the wires for data output for other devices. In summary, if you need to update the database use the diskette and cable as described. To use the unit as a GPS source for a laptop you will need somebody else's software and a custom cable. At that point you may like to buy a stand-alone GPS engine like a Garmin 35 or Traker Blue (if you use Bluetooth and don't want wires all over the cockpit). Call the Garmin AT guys in Salem, Oregon and talk to them at 1-800-525-6726 ext.3991. They are very knowledgeable and nice and will talk to you about your unit. They can also tell whether it has been updated to the advanced display (easy to read) or not just by the serial number. It was a sobering day for me when Garmin bought UPSAT. You'd be lucky if the unit is supported beyond another year or so. I can send a copy of the software diskette but don't have an extra data cable for you. As for the database it has encryption so it can only be loaded on one serialized unit ... no sharing possible. Jim Ivey P.S. Despite the 360 unit's slow frequency response to command inputs, most knowledgeable technicians will tell you that the GPS 360 (or 920 handheld) had the most reliable and accurate GPS engine ever produced. Antiquated in GPS years, but bulletproof. I own 2 and would like to have 3. If you buy one on eBay or Trade-A-Plane get the serial no. before bidding and call the factory to see if it has all the updates and what the repair history is. -----Original Message----- From: luscombe-silvaire(at)yahoogroups.com [mailto:luscombe-silvaire(at)yahoogroups.com] On Behalf Of WRBYARS(at)aol.com Subject: [luscombe-silvaire] Need help with Apollo GPS Greetings to All, I'm in a bit of a dilemma with my Apollo 360 GPS Moving Map Unit, (round unit installed in the panel) which was installed with the latest data in 1997. This unit can be upgraded by using a lap top computer with an "upgrade card" in the floppy drive, connected to the GPS with a serial cable, according to the Installation Guide. Does anyone have a recent "up grade card", and cable to connect up with that they would sell, loan, rent, whatever? Here is the info that the "Guide" gives on these items. PC Interface Kit (564-0052), which includes a program diskette (31/2"),the data cable (500-0263), and a reference guide. Data Cable (500-0263), a 25 pin on the GPS end, to a 9 pin dsub COM port on the PC. Also does anyone know if the GPS unit, when hooked up to a color lap top, will display the same info on the lap top that is on the "Mother" unit on the panel, and although the original unit display is in black & white, would the lap top display the info in color? If it will, then the "co-pilot"/ passenger could have a larger, in color, view, to assist the pilot with. Sorry this is so long, however I know there is a lot of Very Knowledgeable folks out there on the list, and I very much need your help. Thanks Bill _____ =09 * Visit your group "luscombe-silvaire <http://groups.yahoo.com/group/luscombe-silvaire> " on the web. * To unsubscribe from this group, send an email to: luscombe-silvaire-unsubscribe(at)yahoogroups.com <http://docs.yahoo.com/info/terms/> . _____ ________________________________________________________________________________
Date: Aug 01, 2005
From: "Ronald J. Parigoris" <rparigor(at)SUFFOLK.LIB.NY.US>
Subject: Bad Alternator ground on V-Tail!
I was working on Europa build over weekend, and a guy with a V-Tail across way was working on his V-Tail. No alternator output. I will note I helped him change it about 6 months ago, and he was having a hard job fitting it in place. It ended up whoever rebuilt it, or made it got paint on the flange, I helped him cover up everything, and did a shoeshine with a cut piece of 1 x 42 belt sander. OK till now. No charge. he went after all connectors, and it seemed to work. then after fuel it quit. he started to show me and it worked again! There was play between the 2 halves of the alternator! It was safety wired, but I suspect whoever did the painting got carried away, and got it on the mating surfaces inside the alternator. Once the paint wore away due to vibration and heat, things got loose. The hold down screws were heavily corroded as they were making that intermittent connection between the 2 halves sometimes, and the stacked pieces of metal between the 2 halves were pretty corroded as well. The screws looked 50 years old, when I am pretty certain they were new 6 months ago. Ron Parigoris ________________________________________________________________________________
Date: Aug 01, 2005
Subject: Re: Bad Alternator ground on V-Tail!
> > >I was working on Europa build over weekend, and a guy with a V-Tail across >way was working >on his V-Tail. No alternator output. > >I will note I helped him change it about 6 months ago, and he was having a >hard job >fitting it in place. It ended up whoever rebuilt it, or made it got paint >on the flange, I >helped him cover up everything, and did a shoeshine with a cut piece of 1 >x 42 belt >sander. > >OK till now. No charge. he went after all connectors, and it seemed to >work. then after >fuel it quit. he started to show me and it worked again! > >There was play between the 2 halves of the alternator! It was safety >wired, but I suspect >whoever did the painting got carried away, and got it on the mating >surfaces inside the >alternator. Once the paint wore away due to vibration and heat, things got >loose. The hold >down screws were heavily corroded as they were making that intermittent >connection between >the 2 halves sometimes, and the stacked pieces of metal between the 2 >halves were pretty >corroded as well. > >The screws looked 50 years old, when I am pretty certain they were new 6 >months ago. Good detective work. Thanks for giving us the story. They say the devil is in the details . . . and I can attest to that. Worked a problem a few years ago on a pitch trim system where many $millions$ in warranty and untold cost in customer dissatisfaction was rooted on a material change of brake material from asbestos (EPA strikes again!) to cork. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2005
Robert L. Nuckolls, III wrote: > > > > >>But Eric, if the crowbar is after the alternator field breaker, all the >>wire between the battery & the breaker & load mentioned in your argument >>is still there (or not there). If the breaker is in danger from the >>crowbar, it follows that it is in danger from an inadvertent short >>circuit. Yet alternator field circuit breakers seem to have survived as >>a design since the dawn of alternators in a/c. >> >>(If I could be convinced that this 'slam down' technique really is >>dangerous, why do I need dozens of extra components to solve the >>problem? Why not just use one of those gadgets with inverse temperature >>coefficient used to soft start incandescent lamps >name of the device> in series with the crowbar?) >> >> > > The trade name for these devices is Polyswitch. These are > the same devices that EXPBus and Greg Richter have embraced > as their circuit protectors of choice. See: > >http://www.circuitprotection.com/polyswitch.asp > > These are simply replacements for breakers and fuses and have > no ability to sense and react to an ov condition. > > > <> snip > <> > Bob . . . Actually, I was talking about retaining the standard crowbar circuit & breaker & just adding a single component (the gadget that is occasionally used to avoid large inrush current in incandescent lights) in series with the crowbar contacts that would force a ramp up of current through the trip threshold of the breaker instead of the dreaded 'slam dunk' overcurrent Eric's worried about. I only mentioned it to show that some elaborate multicomponent top secret circuit isn't needed. The primary point of my post was that if a breaker can handle rare 'slam dunk' overcurrents due to faulty wiring, it can also handle the crowbar circuit. I see no need for any additional components. Charlie ________________________________________________________________________________
Subject: I'm happy...:)
Date: Aug 01, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
With my all electric airplane (Lycoming with Emags and elctric fuel pumps only) I have found that by using a simple com radio (backup to GNS 430) in receive mode and transponder I can get my total current draw down to a shade under 8 amps which fits nicely into the SD-8 backup. Using Bob's 3 buss design I can easily save my battery reserve to do the approach/run the lights for when I land. The above assumes I run only one fuel pump (I have one in each wing root) and one Emag. Having a Pmag on a dual alternator systems seems like two layers of redundancy to me...Do we agree? Thanks Frank ________________________________________________________________________________
Date: Aug 01, 2005
> > >Actually, I was talking about retaining the standard crowbar circuit & >breaker & just adding a single component (the gadget that is >occasionally used to avoid large inrush current in incandescent lights) >in series with the crowbar contacts that would force a ramp up of >current through the trip threshold of the breaker instead of the dreaded >'slam dunk' overcurrent Eric's worried about. I only mentioned it to >show that some elaborate multicomponent top secret circuit isn't needed. > >The primary point of my post was that if a breaker can handle rare 'slam >dunk' overcurrents due to faulty wiring, it can also handle the crowbar >circuit. I see no need for any additional components. > >Charlie Aha! Understand. It's been proposed that adding a resistor in series with the crowbar module would mitigate the crowbar fault current . . . which is correct. However, It runs contrary to some original design goals. One of the neat things about the crowbar technique is that supply voltage to the alternator regulator is clamped off at about 2 volts immediately after the SCR triggers. This means that the ov condition is cooling off even before the breaker opens. Adding this resistor would increase parts count, adds a mechanical issue for packaging (see photos) http://www.aeroelectric.com/Pictures/OVM-14_A.jpg http://www.aeroelectric.com/Pictures/OVM-14_B.jpg http://www.aeroelectric.com/Pictures/OVM-14_B.jpg Finally, added resistance would have increased excitation voltage available to the regulator while the breaker was deciding to trip . . . and it takes longer to decide due to reduced fault current. This would have reduced effectiveness of the system while offering no benefits I could demonstrate. Adding the mitigation resistance any place else would have driven up the bus-to-regulator pathway resistance. This was root cause of numerous regulator instability problems. Your supposition is correct. The breaker in B&C's test stand for their regulators has experienced thousands of crowbar events (150 A or so in 14v mode, 300A in 24v mode) and last time I checked with Tim, the breaker in place today was the one I installed there about 15 years ago. Granted, it's a high-end product equal to the miniature breakers used in the majority of our aircraft at RAC. As I pointed out in an earlier post, this class of breaker is routinely qualified in test situations where potential interrupt currents are limited only by resistance of the breaker itself (28v/.04 = 700A). I suspect this is where the original 700A figure came from and was proffered as a "worst case" condition. Thing is, the product is never installed in a way that this condition can be realized. Bob . . . ________________________________________________________________________________
Subject: Crowbar CB "problem"
Date: Aug 01, 2005
Bob, Charlie, Eric, All, If there's really a concern about the possible inappropriateness or lack of reliability of a common CB in the Crowbar OVP application, why not just use a fuse? It could be located in an easy-to-reach spot. We could carry a few spares..... What's the big deal? Regards, Troy ________________________________________________________________________________
Date: Aug 01, 2005
Subject: Re: Crowbar CB "problem"
In a message dated 08/01/2005 5:11:36 PM Central Standard Time, tscott1217(at)bellsouth.net writes: why not just use a fuse? >>> One advantage of breaker is notification of OV event- you'll see it popped out... Mark ________________________________________________________________________________
Date: Aug 01, 2005
Bob, Thanks for the reply. You, and others, pointed out that the small band, regardless of the color, indicates the "cathode" end. That solved my problem - the various colors had me confused. As you surmised, the Navaid manual uses a "comic book" wiring diagram. As to the need to hook the comm to the autopilot, I quote from the Navaid manual: " The diode installed in series with the push-to-talk line, together with the wire connected from the PTT switch to pin 7, are used to kill the signal to the servo while the PTT switch is depressed. This prevents the servo from jumping around due to the presence of high level RFI on the servo power lines. The servo stays engaged during the voice transmission, but it does not move until normal operation is restored by releasing the mike button." The manual goes on to say that a metal airplane with shielded wires probably will not have a RFI problem, but that a composite airplane with unshielded wires probably will. My RV is metal, of course, but I have an obvious RFI problem with my unshielded trim indicator circuitry, so I figured connecting the diode as shown was good insurance. Charlie RV-6A N11CB San Antonio ------------------------------------------------------- > From: "Robert L. Nuckolls, III" > Subject: Re: AeroElectric-List: Diode orientation > > > > > > >Bob, et al, > > > >My Navaid installation manual recommends a diode between the Navaid pin > >7 and the Comm PTT circuit. The Navaid schematic shows a black and white > >diode with a large white area and a small black stipe on one end. The > >white area is oriented toward the Comm unit and the black stripe > >oriented toward the PTT circuit. However, the diode I received from B&C > >is mostly black with a small grey stripe at one end. > > > >Can I assume that the large black end of the diode equates to the large > >white end on the Navaid schematic? > > > The descriptions you're making for the parts and wiring > diagram are don't give us a clear image of the instructions. > > Most wire lead diodes have a "band" on one end and the color > of the band is insignificant. It will be some color that > contrasts with the body color of the diode itself. > > The banded end corresponds to the "cathode". In a diode's > schematic, the "bar" touched by the arrowhead is the > cathode while the arrowhead itself is the anode. Electrons > flow through a diode in opposition to direction of arrow. > See: > > http://www.aeroelectric.com/Pictures/Diode_Wiring_2.jpg > > Some folks are confused when they see diodes used for two > different tasks like "steering" as shown in -A- and -B- > and spike clipping as shown in -C- and -D-. > > Do you have a real schematic of the wiring were the > bar and arrowhead are seen in the classic diode symbol > . . . or is it a comic book wiring diagram that shows > only pictures? Sounds like you're working with the latter. > > In this case, go by which end has a band on it irrespective > of color. Do they say what this diode is supposed to do? > I'm mystified by the need hook any part of your comm transceiver > to the autopilot. > > Bob . . . > > ________________________________________________________________________________
Subject: Two Mags & One Input to Electric Tach
Date: Aug 01, 2005
I would like to use a Radio Shack submini DPDT switch so my Westach/Westberg Mfg. electric tach can read RPM on each magneto. I'm thinking of running a single conductor shielded 18 AWG wire from each mag switch (the same wire I'm going to use for the "P" leads) to the DPDT switch. I'll terminate the conductors and the shields separately for each side of the switch so when I throw it, I won't have the shield from the other "P" lead making contact as I would have to do if I used a SPDT switch. Does this sound like it will work? Best regards, Bob ________________________________________________________________________________
From: "Steve Sampson" <SSampson.SLN21(at)london.edu>
Subject: CAD software
Date: Aug 02, 2005
Bob - before my machine crashed i had some simple software to read and modify Z-11 for instance. I had downloaded it from a reference on your web site. Cant find it now. Can you point me to the downloads. Thanks, Steve. ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: crowbar method
Bob et all The part number for the breaker referenced below is? Your supposition is correct. The breaker in B&C's test stand for their regulators has experienced thousands of crowbar events (150 A or so in 14v mode, 300A in 24v mode) and last time I checked with Tim, the breaker in place today was the one I installed there about 15 years ago. Granted, it's a high-end product equal to the miniature breakers used in the majority of our aircraft at RAC. Thanks Matthew M. Jurotich NASA/Goddard Space Flight Center Swales contractor to the JWST ISIM Systems Engineer m/c : 443 e-mail mail to: phone : 301-286-5919 fax : 301-286-7021 JWST URL: <http://ngst1.gsfc.nasa.gov ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Subject: Electric Tail wheel tug
Date: Aug 02, 2005
Hi all, I know this is a little off topic but I am searching for mechanical components to construct an electric tail wheel tug. I need a small axle with a right angle drive similar to a differential. I have been searching the WEB but I end up with too many hits. I was thinking something from an electric wheel chair manufacturer might be able to be adapted. If anyone could suggest a few URL's to browse I'd appreciate it. Thanks, Paul ________________________________________________________________________________
Date: Aug 02, 2005
> > There are LOTS of part numbers. They are members of a class of breaker offered to the aerospace and upper-end commercial applications. Examples include: http://www.aeroelectric.com/Pictures/circuitbreakers.jpg http://www.ti.com/snc/products/controls/acb-2tc.htm http://www.ti.com/snc/products/controls/acb-7277.htm\ http://www.ti.com/snc/products/controls/acb-7274.htm http://aerospace.eaton.com/products/power_load_subsystems/circuit_breakers.html There are plenty of other suitable breakers not the least of which are the Potter-Brumfield products offered by Wicks. They also offer the miniature breakers at http://wicksaircraft.com/catalog/product_search_results.php/search=Y2lyY3VpdCBicmVha2Vy B&C has the miniature breakers suggested above. Aircraft Sruce offers the miniature breakers at: http://www.aircraftspruce.com/menus/el/circuitbreakers.html The list of suitable breakers is huge. The only breakers that have given me pause for concern that have surfaced in the OBAM aviation community are some miniature, toggle breakers that cost about $3 each are offered in someone's pre-assembled power distribution product. The name escapes me right now. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: Electric Tail wheel tug
How 'bout a right angle drive for a drill? ...or go to a pawn shop and buy a big angle grinder and gut it. I bet that gear box could take some abuse. I once knew a guy that built a tug to pull his Bonanza around out of a 1/2" electric drill motor. You might also search around the hobby robot builders sites. They have good sources for stuff like this. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Paul McAllister wrote: > >Hi all, > >I know this is a little off topic but I am searching for mechanical components to construct an electric tail wheel tug. I need a small axle with a right angle drive similar to a differential. I have been searching the WEB but I end up with too many hits. I was thinking something from an electric wheel chair manufacturer might be able to be adapted. If anyone could suggest a few URL's to browse I'd appreciate it. > >Thanks, Paul > > > > ________________________________________________________________________________
Date: Aug 02, 2005
> > >Bob, Charlie, Eric, All, > >If there's really a concern about the possible inappropriateness or lack of >reliability of a common CB in the Crowbar OVP application, why not just use >a fuse? It could be located in an easy-to-reach spot. We could carry a few >spares..... What's the big deal? Excellent question! In fact, some early American/Grumman products did just that. Crowbar OV protection in the form of a 16v zener (had to be a glass device, the plastic ones would blow up) downstream of a field supply fuse. If the alternator ran away, the zener would FALI SHORTED and take out the fuse. This was a dirt cheap, effective, but ONE-SHOT protection method. If you do get a nuisance trip, then it could not be reset in flight. Further, the designers tied the fuse into the wire bundle behind the panel. If the system ever operated, you had to replace both fuse and zener. Not very user or mechanic friendly. We elected to go with breakers since they were already in place in our customer's inventories and a part of their standard bag- of-tricks. Crowbar ov protection was slated to go onto Beech's Model 38 (Turbine Bonanza). Seems that of ALL OV protection systems available to Beech at the time, the regulator modified with crowbar ovp was the only one that would catch a 70A, 12,000rpm runaway 50x in a row and still meet specs on the 51st try. Unfortunately, the program died (seems Bonanza wings wouldn't hold enough fuel to make a turbine powered, go fast version fit Beech Marketing's business model). The last time I saw the airplane, it was sitting outside Bert Rutan's hangar at Mojave looking very much stripped down. http://www.aeroelectric.com/Pictures/38P.jpg Burt got it when he split the sheets with Beech during the Linden Blue era . . . all he wanted out of it was the engine and panel mounted stuff. In a message dated 08/01/2005 5:11:36 PM Central Standard Time, tscott1217(at)bellsouth.net writes: why not just use a fuse? >>> One advantage of breaker is notification of OV event- you'll see it popped out... Yup, that works. But it's still takes a back seat to ACTIVE NOTIFICATION of low voltage in the form of a light flashing right in your face. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
You can put an LED and resistor in parallel with the fuse and this would give you indication. We buy these little fused terminal blocks at work that have this little circuit built in. The drawbacks are that you have to have a little bit of a load downstream of the fuseblock or they don't indicate properly. This may not be an issue in this case. Also you can't troubleshoot the circuit with a voltmeter like you would think because the LED will let a few milliamps through and you'll read voltage downstream of the fuseblock even with a blown fuse. Also keep in mind that this is a parts count increase to solve a problem that seems to only exist on datasheets and not in the real world. My plane has P&B circuit breakers and a crowbar OVM on each alternator, and I ain't worried a bit. The point is to protect my $xxK dollars worth of radios from the insane alternator not to protect the circuit breaker from doing it's job. If I have an OV event and the breaker pops and dies then I'll fix the OV and replace the CB, smiling the entire time that my avionics are all oblivious to the fact that the event took place. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Here's a cheesy circuit diagram... +12Vdc -----+----(Fuse)-----+-----> Load | | +-\/\/\--(LED)--+ Fiveonepw(at)aol.com wrote: > >In a message dated 08/01/2005 5:11:36 PM Central Standard Time, >tscott1217(at)bellsouth.net writes: >why not just use >a fuse? > > > >One advantage of breaker is notification of OV event- you'll see it popped >out... > >Mark > > > > ________________________________________________________________________________
Date: Aug 02, 2005
From: "Mark R Steitle" <mark.steitle(at)austin.utexas.edu>
Paul, As I recall, there was a recent article in Kitplanes on how to build a low budget tug from spare bicycle parts. I don't recall the exact issue, but it was within the last six months. Mark S. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Paul McAllister Subject: AeroElectric-List: Electric Tail wheel tug Hi all, I know this is a little off topic but I am searching for mechanical components to construct an electric tail wheel tug. I need a small axle with a right angle drive similar to a differential. I have been searching the WEB but I end up with too many hits. I was thinking something from an electric wheel chair manufacturer might be able to be adapted. If anyone could suggest a few URL's to browse I'd appreciate it. Thanks, Paul ________________________________________________________________________________
Date: Aug 02, 2005
> >Bob, > >Thanks for the reply. You, and others, pointed out that the small band, >regardless of the color, indicates the "cathode" end. That solved my >problem - the various colors had me confused. As you surmised, the >Navaid manual uses a "comic book" wiring diagram. > >As to the need to hook the comm to the autopilot, I quote from the >Navaid manual: > > " The diode installed in series with the push-to-talk line, >together with the wire connected from the PTT switch to pin 7, are used >to kill the signal to the servo while the PTT switch is depressed. This >prevents the servo from jumping around due to the presence of high level >RFI on the servo power lines. The servo stays engaged during the voice >transmission, but it does not move until normal operation is restored by >releasing the mike button." > >The manual goes on to say that a metal airplane with shielded wires >probably will not have a RFI problem, but that a composite airplane with >unshielded wires probably will. My RV is metal, of course, but I have an >obvious RFI problem with my unshielded trim indicator circuitry, so I >figured connecting the diode as shown was good insurance. Hmmmm . . . some more of that "best practice" stuff. I was afraid that's what you were going to say. I talked with the Navaid guy (Doug something?) at OSH in '86 or '87 at some length. This was before he graduated from a table in the Flymarket to a booth in the commercial buildings. We discussed EMC issues even then and I offered to help him make his design RFI bullet proof. We discussed the same issue several times in intervening years but I was never offered the opportunity to contribute. Words in the manual concerning shielding illustrate a lack of understanding on the part of the writer. Shielding's benefits are quite specific to breaking the capacitive (or electrostatic) coupling mode between wires. It can have some limited benefits in reduction of radiated interference where it becomes a sort of short conduit, like on spark plug wires. However, shielding as a general prophylactic measure against RF intrusion or emissions is a very mixed bag. This is because shielded wires in signal and power bundles are NEVER treated as matched impedance transmission lines (al la coax antenna feeders). I've seen cases where it helped not at all or even made things worse. The #1, sure fire, best bet, works-every-time technique is to make one's black boxes immune to expected stress levels with appropriate design of the input-output circuitry including use of filters as needed. Unfortunately, it seems that NavAid has not learned of this fact in over 20 years. I'll suggest that risks to your installation are quite low due to the metal airplane being a strong attenuator of interference coming from antennas outside. You might leave the diode out and see what happens. It would be an interesting experiment to see how it goes. Further, as a consumer of their products, you are entitled to bang on their cage pretty good about this library-paste- and-bubble-gum approach to EMC control. If you have occasion to contact them in the future, you might suggest there's this gray haired ol' fart in Wichita who is STILL waiting to help them move their products into the present age. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: Two Mags & One Input to Electric Tach
> >I would like to use a Radio Shack submini DPDT switch so my >Westach/Westberg Mfg. electric tach can read RPM on each magneto. I'm >thinking of running a single conductor shielded 18 AWG wire from each mag >switch (the same wire I'm going to use for the "P" leads) to the DPDT >switch. I'll terminate the conductors and the shields separately for each >side of the switch so when I throw it, I won't have the shield from the >other "P" lead making contact as I would have to do if I used a SPDT switch. > >Does this sound like it will work? Sure. but you can make it simpler yet. See: http://www.aeroelectric.com/Pictures/elect_tach2.gif here I show the starter lockout circuit that prevents operation of starter with the non-impulse coupled magneto turned on. If you don't have/need this feature, then the circuit can be implemented with one 2-pole and a single pole switch. If you use shielded wire from mag switches to tach, then ground at tach end only. This eliminates the need for a third switch just to service the tachometer signal. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: I'm happy...:)
> > > With my all electric airplane (Lycoming with Emags and elctric fuel >pumps only) I have found that by using a simple com radio (backup to GNS >430) in receive mode and transponder I can get my total current draw >down to a shade under 8 amps which fits nicely into the SD-8 backup. > >Using Bob's 3 buss design I can easily save my battery reserve to do the >approach/run the lights for when I land. > >The above assumes I run only one fuel pump (I have one in each wing >root) and one Emag. > >Having a Pmag on a dual alternator systems seems like two layers of >redundancy to me...Do we agree? You had "layers" before going to p-mags. Changing from e-mags to p-mags is yet another layer. The neat thing about p-mags is that they are totally independent of the electrical system for normal operations in flight . . . this might suggest that p-mags are not a layer on top of existing layers but a side-by-side substitute for interdependent operations. A simple, very sensible approach to ultimate system reliability. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: Crowbar CB "problem" question
For those that have experience with an external regulator - particularly one of the B&C regulators - how often do the nuisance trips occur? If we're worried about the nuisance trips degrading field CB's, would it be a reasonable fix to replace those CBs at annual? ________________________________________________________________________________
Date: Aug 02, 2005
Hmm...true and It saves yet another precious amp, significant when you only have 8 of them in a high stress IFR/alternator goes south environment. I guess I was coming from the perspective that my FI pumps are as critical as the ignitions. The chain is only as strong as its weakest link. In other words there is no point in adding functionality to run the igntion if the FI pumps are dead anyway. For another 200 bucks to go from an EMAg to P mag I guess its pretty much a moot point in a $90k aircraft...Still can't believe I'm spending this kind of money!..:) Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: I'm happy...:) --> (Corvallis)" > > > With my all electric airplane (Lycoming with Emags and elctric fuel >pumps only) I have found that by using a simple com radio (backup to >GNS >430) in receive mode and transponder I can get my total current draw >down to a shade under 8 amps which fits nicely into the SD-8 backup. > >Using Bob's 3 buss design I can easily save my battery reserve to do >the approach/run the lights for when I land. > >The above assumes I run only one fuel pump (I have one in each wing >root) and one Emag. > >Having a Pmag on a dual alternator systems seems like two layers of >redundancy to me...Do we agree? You had "layers" before going to p-mags. Changing from e-mags to p-mags is yet another layer. The neat thing about p-mags is that they are totally independent of the electrical system for normal operations in flight . . . this might suggest that p-mags are not a layer on top of existing layers but a side-by-side substitute for interdependent operations. A simple, very sensible approach to ultimate system reliability. Bob . . . ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Subject: Z-22 question
Date: Aug 02, 2005
Rooting around the AEC website, I pulled up this diagram: http://www.aeroelectric.com/PPS/Engine/Starter/PM_Starter_w_RunOn_Relay. pdf which is essentially Z-22 with what I believe is a bridge rectifier added. I don't recall seeing mention of this anywhere else. Which is the preferred architecture? Also, I'm wondering about the sizing of the fuse (1A) on the line from the Main Power Distribution Bus in the drawing referenced above. This is much smaller than the 7A fuse on the 22AWG starter line in Z-13/8, and much smaller than the 5A that would normally be used to protect a 22AWG wire. I wonder if there is a reason for the more expensive 1A fuse. Also, if the rectifier is recommended, would the Radio Shack 276-1185 called out for the E-bus normal feedpath also be appropriate here? Thank you. John ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: Real data on OVP/etc (disinterested? DELETE)
> >Bob; > >Take a deep breath and read carefully and ignore any non technical parts but >please consider the technical comments as worth considering as many are >industry wide technical info. > >Sorry for your upset I have never been more calm. There is ALMOST nothing you've stated in your writings here that are worthy of an emotional investment. > . . . but as usual you have missed my point and not addressed >MY technical issues in a technical manner, merely replied with a personal >assault (and perhaps properly deserved). There are some technical details >here in this post as you requested and some are a repeat of my much earlier >posts, but I digress. Here is some of the data you asked for. >I am still waiting for ANY worst case design analysis showing any of your >designs is usable in all likely applications. Some of the possible false >tripping have been reported by buyers (not builders) of the OVP and all who >contacted me wanted to remain anomalous (nor were they interested in a >refund), just a good approach to the design issue as Vans says to not use >any OVP design (yours or similar approaches). Which only illustrates the ignorance of our customers promulgated by your rhetoric and Van's equally ignorant advice. It may well be that those customers were experiencing the same difficulty that we discovered on the Bonanzas which we were happy to rectify for Raytheon and would have been equally happy to rectify for others except that they'd bought into a bill of goods that painted us as incompetent. The only case I was made privy to, the pilot MANUALLY SWITCHED the alternator on and off under load. It did not involve a nuisance trip. In fact, I doubt that ANY of the failures reported to Van involved real nuisance trips . . . but it's an easy thing for unhappy customers to improperly assign blame given some highly touted but mis-informed opinions being circulated. > As we have no info on the sold >OVP design, its not possible to accept your statement that only the builders >versions are at fault. I for one wonder why the sold version would be any >different schematically. For very good reasons which I would have provided if you had asked. The sold versions are the same DIY version of some years ago before the MBS4991 went obsolete. B&C did a lifetime buy of the part to continue production of that design but we needed another approach for the DIY circuit (which was built, tested, qualified and incorporated into some production units - except for the toe stubber that Ken pointed out earlier this week). >You have suggested many times that somehow the Vans rebuilt alternators have >poor quality regulators and that is why they fail at a extremely hi rate >when used with your OVP. From what little data I could find its a failure >rate of 10% or much higher. Clearly something unique in the application of >the wiring in Vans designs or ????? Some were purchased OVP and not built up >units. It was a hypothesis . . . .do you have another? But let's not mix apples and oranges. The style of OVP has nothing to do with the failures of Van's alternator. The very act of switching the alternator OFF while loaded seems to be the trigger event. This happens whether it's an ov trip from a crowbar module, Eric's OVP module, or simply operating the switch on the panel. I'm certain that it's a load-dump event that kills the alternator's own regulator. This is an issue SEPARATE from and not affected by style of OV protection. >"Rebuilt" alternators is really a false name in the industry. They are only >repaired (what is failed is replaced, what still works is not replaced) and >the ND 60 amp unit has been around for at least 25 years. Many units have >been "rebuilt" several times. I contacted several major rebuilders around >the country (including Bosch) as well as a couple of local ones and found no >one replaces anything still working. Not even bearings were normally >replaced in some cases. Thus a "new rebuilt" alternator might have an >original 25 year old regulator or a cheep low quality import replacement or >a modern but still low cost replacement. None admitted they used OEM (ND) >regulators as replacements. The typical reply was "price competition" >prevented that approach. Thus its not possible to single out Vans as having >poorer alternators than others. > >The comments that in affect state my OVP is not the problem its Vans low >quality rebuilds is what is upsetting. (MY S%&T does not smell :-) ) I've never said that my design could not have been root cause of failures in Van's alternators due to any particularly "golden" design. What I said was that Van's alternators were failing because they were being unloaded by mis-use of switches to control the alternator that were PART of the ov system . . . the same damage would have happened irrespective of who's ov module was used . . . or even if no ov module is included in the b-lead control concept. Eric currently publishes an ov protection scheme utilizing the Killovac contactor which will fix the contactor performance issue . . . but guess what? It will still kill alternators for exactly the same reasons as before. >Then I contacted a design engineer in the semi industry responsible for the >modern one-chip regulator (not the one used by ND) and described the problem >we were having. The reply was the design would protect against the normal >load dump but was unlikely to survive a contactor contact arcing and the >opening a loaded output "B" lead. This agrees with several different >automotive test requirements for alternator design testing. The industry is >designing to the automotive equivalent of the aircraft DO-160 which is more >severe. > >At present the only known reasonably priced contactor RATED to open the "B" >lead is the Kilovac. The common contactors available are not rated to open >the voltages likely to be found under fault conditions. Agreed. Which address only ONE issue. Contactor performance as a b-lead controller. It has no bearing on either style of ov protection used or on failures of alternators due to load-dumping. >I quote from a major relay manufacturers web site for contact application. > > "Improper or excessive suppression can cause the relay to suffer from a >long release time, slow contact transfer, and contact bounce on break. All >of these conditions will increase contact arcing when load switching, which >will reduce relay life dramatically.". > >One site http://relays.tycoelectronics.com/kilovac/appnotes/transients.stm >goes on to compare six different methods of coil "spike suppression" Its >interesting to read this table and see that the common diode is the LAST >choice and the Bi directional Zener (read bi directional transorb). There >are similar tables in the USA and Europe and ALL suggest the last method of >choice is the simple diode. The simple diode works as long as the contacts >are carrying low currents and non inductive loads. In the case of the >alternator its a very different matter as the unloaded unregulated >alternator voltage can jump to hundreds of volts during the contact bouncing >during opening even with the best coil suppression method thus the need for >the Kilovac which is rated at hundreds of volts. This is yet another isolated issue that goes toward potential slowing of contact spreading velocity during opening. I've done extensive testing and published results that show marked DELAY in contact opening but not a significant slowing of spreading velocity. Tendencies to arc during opening were exactly the same whether one used no diode, a bi-directional Transorb or a plain diode. If one is worried about opening delay, the Transorb is the way to go. If one is concerned about best life for the controlling switch, the diode is the best way to go. Since my designs didn't care about delay time, I opted to stay with diodes. See exemplar test plots representative of lots of tests on a variety of relays and contactors: http://www.aeroelectric.com/Pictures/704-1DelayNoDiode.gif http://www.aeroelectric.com/Pictures/704-1DelayWithDiode.gif http://www.aeroelectric.com/Pictures/704-1OpeningTimeNoDiode.gif http://www.aeroelectric.com/Pictures/704-1OpeningTimeWithDiode.gif >I find the use of the simple diode across relay contacts one of the most >widespread miss information in the industry. IF ""Joe"" does it, it must be >OK ,or if it was not good why are relays available with one built in?. It's >very simple engineers are lazy and copy what others do far too often. Also >it works in 99.9% of the cases. It does not work in a "B" lead contactor >application however. Manufacturers will build what the engineers want >regardless of its design value. How is it mis-information if testing is used to deduce and select from one of several controlling features? When diodes were FIRST placed across the contactor coils in mid 60's, Transorbs were not around . . . although we COULD have applied a variety of spike snubbing techniques such as resistors or resistor-capacitor networks. The plain diode was used for decades across coil contactors with great success for eliminating arc-induced wear on controlling switches. Now comes the folks who are sifting the grains of sand looking for the next quantum jump in relay/contactor performance and the new kid on the block (Transorb) offers yet another opportunity for improvement. The question not asked and answered is: Do contactors and relays in light aircraft operated enough cycles per hour, month, year or even lifetime of the airplane for there to be even a measurable improvement in service life of the device? A battery contactor operates very lightly loaded and into a largely resistive load and only once per flight cycle. Perhaps 50-100 times per YEAR in a SE light aircraft. Starter contactors get the crap kicked out of them once every flight cycle . . . which is why they're specifically designed to take this extraordinary abuse. In BOTH cases, use of a diode across the coil provides the same demonstrable benefits for increasing life of the controlling switch since we "discovered" them in 1965. I'm not for a moment suggesting that substituting Transorbs for diodes is a bad thing to do . . . but I object to any inferences that my suggestions that diodes are "okay" is a promulgation of "mis-information." I've been to the workbench, got out the test equipment and demonstrated to my satisfaction that there is no value in promoting Transorbs over diodes for the ways I show them in my drawings. >I have demonstrated this in my testing and I suspect its repeatable by you >if you use a common contactor from Wicks for example. The contactor I used >was from Wicks. In one case the bounce duration was quite long and included >many bounces. Opening bounce? I'm having trouble visualizing how contacts initially moving apart reverse direction and move back together. What's the forcing function? Bounce on closure is predictable and understandable. I'd really like to repeat your experiment here too . . . please show us the setup. >My conclusion is never use a "rebuilt" internally regulated alternator with >ANY OVP device that might false trip or trigger on a short transient. This doesn't compute. Adding ANY form of b-lead control to ANY internally regulated alternator is an adventure into unknown risk. It has nothing to do with style of ov protective devices . . . false tripping or otherwise. If one subscribes to the paradigm of being able to CONTROL one's engine driven power source from the panel, then we agree that a b-lead contactor is called for in every installation of an internally regulated alternator. Now, there is RISK that the alternator can be damaged by simply turning it OFF while loaded whether the system included OV protection or not. > With >a brand new ND alternator available for $300+ and the demonstrated failure >rate in the auto industry being so low its unlikely any of us will ever see >a "fail hi" condition in a lifetime of flight. Van does not recommend any >OVP and with a modern regulator I agree its addition only reduces system >reliability. The Fail HI mode of regulator failure is a very low >probability in the failure modes of the modern regulator . Any failure of >any type is extremely low in today's new production ND alternators. Low . . . but not zero. Recall Jack's post of just last week: -------------------------------- George: The alternator that failed was a nippon denso, 60 amp, internally regulated. I'm not sure that my experience should cause others to avoid this unit. I know that hundreds of airplanes are flying successfully with them. However, if you read Bob's most recent post, you might decide to avoid all internal regulated alternators. Bob: As soon as I pull the fuel guage, I'll send it too you. What address? thanks, jack --------------------------------- >Use of any OVP has the potential of failing the alternator when it trips for >what ever reason so IF a OVP is used it needs to be extremely reliable under >all design conditions. It should never trip unless the OV is clearly of long >duration. The AEC OVP device trips in a few milliseconds and really should >not trip unless the OV is longer than what one might expect from a major >load dump. Agreed. But here you're substituting your design goals without regard to the goals of our customers (who cited DO160/MS704) when time constants were selected for the ov trip dynamics. The nuisance tripping we've experienced has NOTHING to do with the OV sense circuit and everything to do with dv/dt sensitivities of the SCR which has shown that there are antagonistic events in SOME systems that are NOT suggest by DO160/MS704. After our epiphany, we made adjustments to the circuit for all new production and for anyone who was plagued with the condition in the field at no charge. This is a DISCOVERY of a phenomenon not previously considered (by industry standard practices). No amount of analysis would have predicted the condition we were told did not exist (or at least was not previously identified). The new requirement did not come to light until the Bonanza production line produced a series of REPEATABLE EXPERIMENTS critical to identification of root cause and deduction of remedies. >YOU agreed there were cases of false tripping yet you failed to properly >analyze your design. There was absolutely no reason for a real lab test and, >in fact testing was a near total waste of time, as the false tripping >depends on a specific implementation of the classic schematic. How do you >expect to build all variations of a schematic?? You cite facts not in evidence. EVERY instance of a customer reporting a nuisance trip problem has been dealt with in a positive way if they only came forward with their complaint. Just a few days ago, I upgraded an OV module that worked as advertised for 4 years but became irritated by a new accessory in the airplane. We DID analyze the design, deduced modifications to fix the problem, and offered the fix to anyone who needed/wanted it at no charge. >How can there be repeatable tests when several major components have >important design tolerances or variables in the 5x or 10x range of >tolerances. Battery internal resistances of 5-1 or more, CB resistances of >10-1 or more. Schematic is one thing wiring diagram is another (how a >schematic is implemented and where wires are connected along a common line >in a schematic can and often does greatly affect the results. I've given you the data that supports both my analysis and test results. You still haven't told me what breaker you've tested where the manufacturer says it goes tits-up on a 50x overload. >The time tested and standard method of circuit analysis is on paper with or >without the help of software; > However the use of PC625 and the very similar PC680 are very popular >around here as are the use of dual batteries often simple wired directly in >parallel. The batteries are not the controlling factor. Wiring and breaker resistances are. Lets assume ZERO battery resistance but we still have 0.04 ohms of breaker resistance and a couple of feet of 20AWG wire for another .04 ohms when combined with a 2v drop across the SCR yields about 130 amps of crowbar current. If it would make you feel better, we COULD add the admonition to our installation manuals not to install the crowbar module or any of the LR series regulators with zero length wires . . . but given that most folks locate their equipment some distance from the bus, that worry wasn't high on our list of concerns. >You used 0.035 ohms for the CB and got trip times of a few MS. I used a CB >from Wicks and measures it at 0.003 ohms and it tripped repeatetly in the >50-70 ms range. Yes the data seems illogical but my data is repeatable here >and I accept your data also as factual. What was the brand and part number of this .003 ohm breaker? Results you're reporting are so astounding that they BEG for a repeated experiment. Please afford me the courtesy of knowing how to do it. I've uploaded data sheets on breakers I find in Wicks catalog to http://www.aeroelectric.com/Mfgr_Data/Breakers/Potter_Brumfield The two P&B data sheets speaks of 0.030 +/-30% for max breaker resistance on 5A breaker. Of course, this is a MAX value. Did you find an exemplar breaker that presented a resistance 1/10th this value? I'm amazed that one can fabricate a 5A breaker heater with so small a resistance. I've measured dozens of breakers by Woods, Mechanical Products, Klixon, and Eaton-CH and they all agree with their data sheets to present about 30-40 milliohms of series resistance in a 5A breaker. Smaller breakers are markedly higher in resistance. >There is no way you can reproduce my test data unless you use the exact same >parts. ABSOLUTELY! DEAD ON! By the same token, I cannot evaluate the validity of your test data without knowing what parts you used. You keep hammering me with these near zero-ohm breaker values and I can't find anything approaching these values in any products I can put my hands on. >This is the fallacy of your requirements that the test must be >reproducible by you to be valid. ???? Paul, this is a truly astounding statement from someone to claims to be an engineer. No sir! For CLAIMS made by ANALYSIS of test results to be valid, they should be CAPABLE of being repeated by anyone who wishes to do the work. OF COURSE this requires a complete disclosure of all materials and techniques used. Remember the cold fusion guys of about 15 years ago? They made claims that begged critical review by repeated experiment. Remember Dave Blanton's 240 hp, 6-cyl Ford conversions? How about Jim Bede's super-sonic OBAM product? Geesh! Just watch late night TV and you'll get tons of information most of which would not stand up to critical design review and repeated experiments. But the gullible consumer is not privy to real data or experience that validates the propagandist's claims. You might as well be watching a Siegfried and Roy show and believing those lions really disappear. Until they show me how I can make lions disappear, it's nothing but propaganda with an agenda. In their case, the agenda is is entertainment which I do enjoy. What's your agenda sir? Data for repeatable tests are a COURTESY that REAL scientists offer each other as and AID to investigating any phenomenon. I expected and requested no more of you and I was fully transparent in everything I used to base my claims. I've built a career on repeatable test results in the lab and in my customer's airplanes. Yes, things slip by sometimes - the only thing we can do then is act in a responsible way to rectify the problems as they arise. >Perhaps its valid where the circuit >variables are not so dependent on individual parts used but in this case the >parts variation is so huge they prevent repeatable tests. Both tests are >reasonable examples of the overall design as documented on your web site and >neither are a worst case example as only a proper analysis can define the >range of design results. > >ANY design that is to be reproduced must be analyzed using the specified >data sheet parts variations (and either specify the exact parts of consider >all the likely parts brands that could apply) and for general use NEVER >publish a design that violates the data sheet under any condition or assumes >parameters not specifically printed in the data sheet. Pleeeasssss, purdy pleeeaasse, show me the data sheets. >In any event I see no reason to continue posting. That's fine too. I sat in a meeting yesterday for several hours looking at about 50 pounds of paper on the table that included failure mode effects analysis, reliability studies that assured us we were buying a 7,000 hour MTBF product, test reports out the wazzoo, detailed worst case analysis, etc. etc. These papers presumably defined a system that we paid $millions$ for and according to all the analysis, should be the golden product. It won't run more than 10 hours without annunciating a failure and causing our customers great concern and billing our coffers many $killo$ of warranty csots. This golden system monitors dozens of potential problem areas and if you believe the marketing hype (we did) . . . it's the safest system ever to fly. Problem is, the designers forgot to offer a way to tell which one of 5 dozen faults tripped out the system. Further, as far as the FAA is concerned, the system is blessed (it passed all the qual tests) and is carved in stone. Any changes (to upgrade performance or to even fix simple nuisance trips) are horrifically expensive and time consuming to implement. I have a proven, flight-tested alternative system that has run fault free for hundreds of hours. The system that works was afforded perhaps 5% of the analysis and testing compared to the system that doesn't work. Further, ALL operating characteristics of the working system are observable at any time . . . INCLUDING those characteristics that might produce shut downs. If you want to apply the tools of detailed analysis to the crowbar (or any other) ov protection system, you must first cite ALL sources, magnitudes and configuration of your hypotheticals. Only then may we debate results to your heart's content as scientists. Analysis is a tool. It depends on proper application of good input data and lucid interpretation of results. These things are BEST conducted as cooperative critical reviews where everyone's focus is on doing the best thing for our customers and students and not lobbing cabbages. Now, HERE is where I DO get tense . . . I'll continue to object to your rhetorical, unfounded attacks on "my approach" when I'm the one who has thousands of happy customers. The few secret, unhappiest customers are those who accepted your hip-shot assessment of my engineering integrity and business ethics to the extent that they (according to you) won't take advantage of remedies I'm begging to offer. Further, you have deprived ME of benefits for having field experience upon which to deduce root cause of problems and to craft improvements to my products and servics. One of the KEY attributes of our society that served to build us into an economic powerhouse in record time is that sacred relationship between honorable suppliers and consumers who walk away from every deal happy or at least free of fraud or encroachment on their property. How many times on this List have I encouraged individuals with questions or complaints about any product to communicate FIRST with the manufacturer/supplier? Give the supplier an opportunity to do the right thing and support their customers to the best of their ability and/or business model. You have injected yourself into the relationship between me and individuals who have invested in my goods or services. Your actions, no matter how well intended, are costing me undeserved loss of both good-will in the marketplace and valuable feedback from my customers. Your actions have produced unhappy customers AND suppliers through no fault of either. There are no civil words in my vocabulary to adequately express how much this displeases me. If you do post, show me the data. If you choose not to post, I wish you well but I'll continue to worry about your crusades against myself (and probably others) who are not deserving of your dishonorable disservice. Bob. . . ________________________________________________________________________________
Date: Aug 02, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Z-22 question
> > >Rooting around the AEC website, I pulled up this diagram: > > >http://www.aeroelectric.com/PPS/Engine/Starter/PM_Starter_w_RunOn_Relay. >pdf > > >which is essentially Z-22 with what I believe is a bridge rectifier >added. I don't recall seeing mention of this anywhere else. Which is >the preferred architecture? Good find sir. I'd intended to update Z-22 to this configuration. A builder wrote me some time ago asking about spike catchers for BOTH the S704-1 AND the starter's built in contactor/solenoid. Given that we needed TWO diodes and given further that wire-leaded diodes are often clumsy to work with, this seemed like a new opportunity for the diode bridge rectifier. Note that in this case, we use two of the four diodes to accomplish the tasks suggested by his query. >Also, I'm wondering about the sizing of the fuse (1A) on the line from >the Main Power Distribution Bus in the drawing referenced above. This >is much smaller than the 7A fuse on the 22AWG starter line in Z-13/8, >and much smaller than the 5A that would normally be used to protect a >22AWG wire. I wonder if there is a reason for the more expensive 1A >fuse. 7A was necessary to control the intermittent duty contactors thought 20AWG wire to improve contactor performance under high loads on battery. 1 to 5 A are fine for 22AWG wire that only drives the S704-1 relay. B&C charges the same price for all values of the ATC fuse from 1 to 30 amps. >Also, if the rectifier is recommended, would the Radio Shack 276-1185 >called out for the E-bus normal feedpath also be appropriate here? Sure . . . mounts with one screw, doesn't need insulators, wires with 1/4" faston tabs. What could be easier? Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
> >For those that have experience with an external regulator - >particularly one of the B&C regulators - how often do the nuisance trips >occur? > >If we're worried about the nuisance trips degrading field CB's, would >it be a reasonable fix to replace those CBs at annual? I guess that depends on the breaker. The ones I sold and B&C sells are quite robust and don't present a service-life issue. I lost track of LR series devices fielded when it passed the 2,000 mark years ago. I suspect it's over 3,000 now. Until the Bonanza experience, we had a handful of reports of nuisance trips virtually all of which were fixed by identification and mitigation of the noise at the antagonist. I've not been closely coupled to the B&C experience for several years now so I cannot report first-hand about problems with fielded systems. If there were any kind of crisis, I suspect I would have had a call from them. You can contact Tim at B&C if you're needing more current data. There is a breaker in the B&C acceptance test fixture that has been subject to test trips from every LR series regulator produced since day one. As far as I know it's still there . . . but again, you'll have to ask Tim. If the breaker fails, it will present you no greater an issue than for failure of any OTHER part in the alternator system. That's what we design for . . . failure tolerance. This is a tempest in a teapot folks. Aside from an admonition not to install B&C or AEC products with zero length leads and breakers purchased from Duckwalls, I can deduce no reason to be worried. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
It's time to display my ignorance. On Aug 2, 2005, at 1:37 PM, Robert L. Nuckolls, III wrote: > > This is a tempest in a teapot folks. Aside from an > admonition not to install B&C or AEC products with zero > length leads and breakers purchased from Duckwalls, > I can deduce no reason to be worried. I don't know what Bob means here. I haven't been able to keep up with the entire conversation, there's just been so much going on with it. I've been trying to read it, but I think it would be a full time job. What is meant by "zero length leaders" ? Bob, are you saying that there's a right way and a wrong way to install these products? Is there a particular issue with breakers from Duckwalls? Color me ignorant. -Joe ________________________________________________________________________________
Date: Aug 02, 2005
> >It's time to display my ignorance. > >On Aug 2, 2005, at 1:37 PM, Robert L. Nuckolls, III wrote: > > > > This is a tempest in a teapot folks. Aside from an > > admonition not to install B&C or AEC products with zero > > length leads and breakers purchased from Duckwalls, > > I can deduce no reason to be worried. > >I don't know what Bob means here. I haven't been able to keep up >with the entire conversation, there's just been so much going on with >it. I've been trying to read it, but I think it would be a full time >job. > >What is meant by "zero length leaders" ? Bob, are you saying that >there's a right way and a wrong way to install these products? The right way is "follow the instructions". You have to go out of your way to install these in a manner that increases risks of problems. Even if there are "problems" risks to safety of flight are tiny. The reference to "zero length" leads is a mild side swipe at an experiment that exposes vulnerabilities to the crowbar ov protection system by setting it up in a manner that does not represent any way it would be installed in an airplane. Obviously, we use WIRE to hook things up and that wire has length because we can't stack all the electrowhizzies into a 1 cubic foot space in the airplane. Bottom line is that the worst of the worrisome worst case scenarios just doesn't happen. >Is there a particular issue with breakers from Duckwalls? That was a tongue in cheek reference to circuit breakers of unknown pedigree. I'm aware of no "mainstream" supplier to the OBAM aircraft community that supplies breakers I cannot recommend. Take a peek at: http://www.velocityaircraft.com/Velocity%20Store/Avionics,Electrical,autopilots,instruments/prewired_systems.html The breakers used in this assembly are not fabricated to any design requirements that I can identify. Unsafe? No, they'll probably open up when overloaded just as designed. Robust? I don't think so, but I don't know either. Rather than speculate, I'll choose to suggest you purchase from Wicks, B&C, Aircraft Spruce, or our friend up at Steinair. It's easy to suggest known good sources and very difficult to identify and/or predict questionable sources. >Color me ignorant. But obviously willing to learn . . . keep up the good quesitons! Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
> > >Hi all, > >I know this is a little off topic but I am searching for mechanical >components to construct an electric tail wheel tug. I need a small axle >with a right angle drive similar to a differential. I have been searching >the WEB but I end up with too many hits. I was thinking something from an >electric wheel chair manufacturer might be able to be adapted. If anyone >could suggest a few URL's to browse I'd appreciate it. Consider modifying a small electric winch mechanism. Maybe something from Harbor Freight? Most of the low cost, high torque speed reducers take advantage of the one-step, high mechanical advantage of a worm gear mechanism that might offer both a motor and gearbox assembly suited to your task. Worm gears are horribly inefficient but in this application, they might just be what you need. Also check out the following offerings from ebay: 7534404208 7534284982 7704814350 7535764492 Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
Subject: Re: CAD software
> > >Bob - before my machine crashed i had some simple software to read and >modify Z-11 for instance. I had downloaded it from a reference on your web >site. Cant find it now. Can you point me to the downloads. http://www.aeroelectric.com/CD/AEC8_0.zip Bob . . . ________________________________________________________________________________
Date: Aug 02, 2005
> >How 'bout a right angle drive for a drill? > >...or go to a pawn shop and buy a big angle grinder and gut it. I bet >that gear box could take some abuse. > >I once knew a guy that built a tug to pull his Bonanza around out of a >1/2" electric drill motor. You might also search around the hobby robot >builders sites. They have good sources for stuff like this. > >Godspeed, > >Phil Birkelbach - Houston Texas Great suggestions. Bob . . . ________________________________________________________________________________
Subject: The fatwire ground blues . . .
Date: Aug 02, 2005
--> AeroElectric-List message previously posted by: "Robert L. Nuckolls, III" >Comments/Questions: I am implementing your dual alt/batt/buss system on my >GA-III. I fried a ground wire(lots of smoke)due to a loose battery ground >connection while cranking the starter! The fried wire went to the fuel >flow sensor mounted on the engine block. The starter return current tried >to use the smaller wire due to a loose battery ground connector to the >Alt-Battery. Should the sensors(Vision Micro) mounted on the engine block >(fuel flow, fuel press, oil temp, oil press) have ground wires that >connect to the engine block? These wires can be potential return paths for >heavy starter current with a loose (-) battery connection. 8/2/2005 Hello Bob Nuckolls, I am concerned that your correspondent may have bigger problems than just a fried wire. I quote from the Vision Microsystems installation manual: "DO NOT: ground the transducer body to any part of the aircraft, if possible. Otherwise INSURE that the engine is EXTREMELY well grounded." Emphasis provided by the author. The manual also contains specific directions not to mount some of these transducers directly on the engine. The wiring diagram for this system shows all wires (which are color coded) from these transducers being connected to a specific pin in the DPU (Data Processing Unit). I don't know how one could come up with a "ground wire" to connect to the engine block. It is possible that the DPU was damaged while the wire was being fried. "When (before) all else fails ..... read the instructions". OC ________________________________________________________________________________
Subject: Fw: CAD software
Date: Aug 03, 2005
----- Original Message ----- From: Steve Sampson Subject: CAD software Bob - before my machine crashed i had some simple software to read and modify Z-11 for instance. I had downloaded it from a reference on your web site. Cant find it now. Can you point me to the downloads. Thanks, Steve. ________________________________________________________________________________
Date: Aug 03, 2005
Date: Aug 03, 2005
Subject: Re: The fatwire ground blues . . .
> > >--> AeroElectric-List message previously posted by: "Robert L. Nuckolls, >III" > > > >Comments/Questions: I am implementing your dual alt/batt/buss system on my > >GA-III. I fried a ground wire(lots of smoke)due to a loose battery ground > >connection while cranking the starter! The fried wire went to the fuel > >flow sensor mounted on the engine block. The starter return current tried > >to use the smaller wire due to a loose battery ground connector to the > >Alt-Battery. Should the sensors(Vision Micro) mounted on the engine block > >(fuel flow, fuel press, oil temp, oil press) have ground wires that > >connect to the engine block? These wires can be potential return paths for > >heavy starter current with a loose (-) battery connection. > >8/2/2005 > >Hello Bob Nuckolls, I am concerned that your correspondent may have bigger >problems than just a fried wire. I quote from the Vision Microsystems >installation manual: > >"DO NOT: ground the transducer body to any part of the aircraft, if >possible. Otherwise INSURE that the engine is EXTREMELY well grounded." > >Emphasis provided by the author. The manual also contains specific >directions not to mount some of these transducers directly on the engine. > >The wiring diagram for this system shows all wires (which are color coded) >from these transducers being connected to a specific pin in the DPU (Data >Processing Unit). I don't know how one could come up with a "ground wire" to >connect to the engine block. > >It is possible that the DPU was damaged while the wire was being fried. > >"When (before) all else fails ..... read the instructions". > >OC Very perceptive sir. He DID find another loose ground at the engine. Root cause wasn't a loose battery ground. Bob . . . ________________________________________________________________________________
Date: Aug 03, 2005
Subject: Audio Iso Amp problem
Bob- My kit-built amp exhibits poor audio input from my Microair 760- the audio is "clipped?" where perhaps 1/3 of the signal gets through resulting in barely audible reception. By "clipped" I mean it is like I will hear perhaps 100 msec of audio with about 200 msec silence between. (WAG at time intervals) The audio alarm from my EIS4000 engine monitor sounds perfect, however- a nice clean "beep" simultaneously with the alarm light. I changed the 150 ohm input resistors with 180s with no noticeable difference. It is the same unit I sent you for testing some time ago and you reported it was fine. Autocad dwg of audio system available if desired. Suggestions? Thanks- Mark Phillips ________________________________________________________________________________
Subject: Crowbar CB "problem" question
Date: Aug 03, 2005
AeroElectric-List message previously posted by: Richard Riley <> 8/3/2005 Hello Richard, 100 hours plus on my plane with an externally regulated (B&C), gear driven, 60 AMP alternator with no nuisance trips. Replacing CB's can be a bitch because frequently they are fastened 2 or 3 or more to a brass bar. It can take a significant amount of unfastening and then reassembling to replace one CB. OC ________________________________________________________________________________
Date: Aug 03, 2005
Subject: Re: Audio Iso Amp problem
> >Bob- > >My kit-built amp exhibits poor audio input from my Microair 760- the audio is >"clipped?" where perhaps 1/3 of the signal gets through resulting in barely >audible reception. By "clipped" I mean it is like I will hear perhaps 100 >msec >of audio with about 200 msec silence between. (WAG at time intervals) The >audio alarm from my EIS4000 engine monitor sounds perfect, however- a nice >clean "beep" simultaneously with the alarm light. I changed the 150 ohm >input >resistors with 180s with no noticeable difference. > >It is the same unit I sent you for testing some time ago and you reported it >was fine. Autocad dwg of audio system available if desired. Suggestions? Any changes to the series input resistors should be made in 1x/0.5x steps. For example, if you want to reduce gain of any one channel, the MINIMUM useful increase would be from 150 to 300 ohms. If still too hot, go to 600 ohms, etc. By the same token, if you need more gain, reduce a 150 ohm resistor to 75 ohms first, then 36 ohms. I'm hearing that some radios like to be "loaded" heavier on their phones output signals than what the amplifier provides. Before you change the 180 to anything else, try putting anything from 50 to 100 ohms ACROSS the Microair 760's headphones output leads. What your describing sounds more like some kind of bias shift than overloading. The "dummy" load may help more than anything else. Let us know what you find. I've had some good feedback from about a dozen builders of the audio isolation amplifier with some suggestions for improvements. I'm considering a second generation version . . . but to fit in the same package, we'll have to go surface mounted parts which is probably more than most builders want to tackle. If we do it, the amplifier will offered as a plug-n-play assembly. There's one going into a certified ship under a 337 installed by what appears to be a really savvy technician. I asked him to feed back impressions and suggestions too. I think this gizmo is ripe for an upgrade but there's no reason we can't make it do what you need done. Bob . . . ________________________________________________________________________________
Date: Aug 03, 2005
> >AeroElectric-List message previously posted by: Richard Riley > > ><particularly one of the B&C regulators - how often do the nuisance trips >occur? > >If we're worried about the nuisance trips degrading field CB's, would >it be a reasonable fix to replace those CBs at annual?>> > >8/3/2005 > >Hello Richard, 100 hours plus on my plane with an externally regulated >(B&C), gear driven, 60 AMP alternator with no nuisance trips. > >Replacing CB's can be a bitch because frequently they are fastened 2 or 3 or >more to a brass bar. It can take a significant amount of unfastening and >then reassembling to replace one CB. If one uses fuseblocks for all circuits EXCECPT the alternator control lead as depicted in the Z-figures, then a single breaker is usually very easy to replace. But if one uses a reasonably robust breaker as described in previous posts, risk to the breaker is WAY down on one's list of maintenance concerns and then only after experiencing a bucket full of nuisance trips. Let's FIX the nuisance trips for the sake of our breakers, nerves AND good consumer/supplier relationships. Bob . . . ________________________________________________________________________________
Date: Aug 03, 2005
Subject: Z-11 question for the electrically challenged
Bob, I will shortly be wiring my RV-7a according to your Z-11 schematic and will be using Van's internally regulated 60 amp alternator. If I choose not to employ OV protection, I assume that I simply connect terminal #4 of the Battery/Alt switch depicted on Z-11 to the field terminal of the alternator with a fuse (5A?) in between. Please advise if I am in error. Also, I gather from recent bandwidth that during normal operation, one should avoid switching the alternator off until the engine has shut down as this may be unhealthy for Van's alternator (or perhaps all alternators?). I know from flying Cessnas that occasionally the alternator will trip out and can be brought back on line via cycling of the alt switch. Will that scenario apply in your Z-11 schematic with an internally regulated alternator? TIA for your help. Joel Haynes Bozeman, MT ________________________________________________________________________________
Date: Aug 03, 2005
Fiveonepw(at)aol.com wrote: > >Bob- > >My kit-built amp exhibits poor audio input from my Microair 760- the audio is >"clipped?" where perhaps 1/3 of the signal gets through resulting in barely >audible reception. By "clipped" I mean it is like I will hear perhaps 100 msec >of audio with about 200 msec silence between. (WAG at time intervals) The >audio alarm from my EIS4000 engine monitor sounds perfect, however- a nice >clean "beep" simultaneously with the alarm light. I changed the 150 ohm input >resistors with 180s with no noticeable difference. > >It is the same unit I sent you for testing some time ago and you reported it >was fine. Autocad dwg of audio system available if desired. Suggestions? > >Thanks- Mark Phillips > You might check with an ohm meter from each input terminal on the amp to ground (with everything still hooked up but not powered up). The behavior of the 760 sounds like a current limiting circuit in an audio output stage might be trying to protect it from overload. I don't have the schematic in front of me but would expect to see at least 200 ohms from input to ground on each input. Charlie ________________________________________________________________________________
Date: Aug 04, 2005
From: "Johnson, Phillip (EXP)" <phillip.johnson(at)lmco.com>
The problem of poor grounding whilst cranking the engine has always been a concern of mine. To overcome this I have the battery ground connected directly to the engine and then all grounds connect to the engine. This way no cranking current flows through the sensor grounds under any conditions. Phillip Johnson ________________________________________________________________________________
Date: Aug 04, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> challenged
Subject: Re: Z-11 question for the electrically
challenged > >Bob, >I will shortly be wiring my RV-7a according to your Z-11 schematic and >will be using Van's internally regulated 60 amp alternator. If I choose >not to employ OV protection, I assume that I simply connect terminal #4 of >the Battery/Alt switch depicted on Z-11 to the field terminal of the >alternator with a fuse (5A?) in between. Please advise if I am in error. I wish I had some good data to offer you. As you may have gathered from much of the discussion concerning internally regulated alternators here on the List, the internally regulated alternator as a class of product is a moving target. First, there is no fixed protocol under which these alternators respond to the command signal that comes in the back on the small wire. Some alternators, I'm told, will turn ON and OFF in response to bus voltage supplied to the command input. Others will only turn ON and are not controllable from the panel switch after energized for the first time. Second, in spite of exemplary demonstrations of reliability in the automotive world (I've NEVER experienced an OV event at any time in 40+ years of driving) we know that numbers of our brethren HAVE experienced OV events in internally regulated machines with various outcomes. As a systems designer, I've taken the position that my recommendations should be crafted for the most universal application. I KNOW that 99% of all externally regulated alternators will run well with 90% of all alternator regulator products. I KNOW that removing field excitation from and operating alternator will shut it off. I KNOW there are useful techniques for sensing over voltage and removing field excitation. Therefore, combinations of externally regulated alternator, a regulator, an OV protection system -AND- ACTIVE NOTIFICATION OF LOW VOLTAGE offers a high degree of risk reduction against catastrophic failures that propagate throughout the system. >Also, I gather from recent bandwidth that during normal operation, one >should avoid switching the alternator off until the engine has shut down >as this may be unhealthy for Van's alternator (or perhaps all alternators?). Assuming that the alternator Van supplies will respond to both ON and OFF commands, there is no risk for turning the alternator ON or OFF while operating. When we went conducted the exercise of trying to make and automotive alternator look and behave like an aircraft alternator, we discovered some unhappy tradeoffs. Adding a b-lead contactor to assure positive control of ANY internally regulated alternator, we created a possibility of killing an perfectly good working alternator by turning it OFF while loaded. The risk of this happening goes away when we abandoned the technique for exercising full control over the alternator. At the same time, we lost the ability to exercise protection against OV runaway. >I know from flying Cessnas that occasionally the alternator will trip out >and can be brought back on line via cycling of the alt switch. Will that >scenario apply in your Z-11 schematic with an internally regulated alternator? If you install Van's alternator per his recommendations, there will be no OV protection to trip out. Therefore, no reason to "reset" it by exercising the alternator control switch. I have no test data or narrative of an experiment that defines how Van's alternator works. Perhaps someone on the list is flying with Van's alternator who can enlighten us. Further, I have no knowledge of Van's configuration management on alternators he sells. Its possible that one batch of alternators may be fully controllable while the next batch is Turn-On only. Lack of data makes it impossible for one to offer considered critical review of the system or to suggest system integration or operational techniques. Sorry I can't be more helpful at the moment. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2005
> > >The problem of poor grounding whilst cranking the engine has always been a >concern of mine. To overcome this I have the battery ground connected >directly to the engine and then all grounds connect to the engine. This >way no cranking current flows through the sensor grounds under any conditions. The only way one gets cranking current to flow in undesired pathways is when desired pathways coexist with undesired pathways. The ideal ground system eliminates parallel pathways so that ANY open connection produces a passive failure. Sensors that ground to their mounting on the engine should not be fitted with a second ground path. Most suppliers of such sensors suggest a means for isolating the sensor from engine case ground -or- they call for the instrument that reads the sensor to ground to the engine instead of behind the panel. This is good practice BOTH for signal integrity by elimination of ground loops and system safety against burning bitty wires when big wires get unhooked. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2005
Subject: Re: Audio Iso Amp problem (corrected)
> >Bob- > >My kit-built amp exhibits poor audio input from my Microair 760- the audio is >"clipped?" where perhaps 1/3 of the signal gets through resulting in barely >audible reception. By "clipped" I mean it is like I will hear perhaps 100 >msec >of audio with about 200 msec silence between. (WAG at time intervals) The >audio alarm from my EIS4000 engine monitor sounds perfect, however- a nice >clean "beep" simultaneously with the alarm light. I changed the 150 ohm >input resistors with 180s with no noticeable difference. > >It is the same unit I sent you for testing some time ago and you reported it >was fine. Autocad dwg of audio system available if desired. Suggestions? Any changes to the series input resistors should be made in 2x/0.5x (was 1x/0.5x) steps. For example, if you want to reduce gain of any one channel, the MINIMUM useful increase would be from 150 to 300 ohms. If still too hot, go to 600 ohms, etc. By the same token, if you need more gain, reduce a 150 ohm resistor to 75 ohms first, then 36 ohms. I'm hearing that some radios like to be "loaded" heavier on their phones output signals than what the amplifier provides. Before you change the 180 to anything else, try putting anything from 50 to 100 ohms ACROSS the Microair 760's headphones output leads. What your describing sounds more like some kind of bias shift than overloading. The "dummy" load may help more than anything else. Let us know what you find. I've had some good feedback from about a dozen builders of the audio isolation amplifier with some suggestions for improvements. I'm considering a second generation version . . . but to fit in the same package, we'll have to go surface mounted parts which is probably more than most builders want to tackle. If we do it, the amplifier will offered as a plug-n-play assembly. There's one going into a certified ship under a 337 installed by what appears to be a really savvy technician. I asked him to feed back impressions and suggestions too. I think this gizmo is ripe for an upgrade but there's no reason we can't make it do what you need done. Bob . . . -- -- incoming mail is certified Virus Free. Bob . . . -------------------------------------------------------- < Throughout history, poverty is the normal condition > < of man. Advances which permit this norm to be > < exceeded -- here and there, now and then -- are the > < work of an extremely small minority, frequently > < despised, often condemned, and almost always opposed > < by all right-thinking people. Whenever this tiny > < minority is kept from creating, or (as sometimes > < happens) is driven out of a society, the people > < then slip back into abject poverty. > < > < This is known as "bad luck". > < -Lazarus Long- > <------------------------------------------------------> http://www.aeroelectric.com ________________________________________________________________________________
Date: Aug 04, 2005
Bob, your response below sounds very important. Up until your last sentence, I was thinking, "What's wrong with a few extra grounds? They should all be at the same potential, so it seems like extra insurance." Then you mentioned the part about bitty wires taking loads they can't handle, and suddenly most of the rest makes sense. In other words, every device should have exactly one path IN for power and exactly one path OUT back to the battery. Is that what you're saying? This is how you can properly size the wires used, because the ground for one device won't inadvertently be used as ground for another device, resulting in an overloaded wire. Can you explain what a ground loop is and provide an example of how one creates one, so I can get a better feel for what to avoid? Is it okay to "chain" a the ground of a bunch of devices together before bringing them all to the battery? -Joe On Aug 4, 2005, at 8:47 AM, Robert L. Nuckolls, III wrote: > > The only way one gets cranking current to flow in undesired > pathways is when desired pathways coexist with undesired > pathways. The ideal ground system eliminates parallel > pathways so that ANY open connection produces a passive > failure. > > Sensors that ground to their mounting on the engine > should not be fitted with a second ground path. Most > suppliers of such sensors suggest a means for isolating > the sensor from engine case ground -or- they call for > the instrument that reads the sensor to ground to the > engine instead of behind the panel. > > This is good practice BOTH for signal integrity by > elimination of ground loops and system safety against > burning bitty wires when big wires get unhooked. ________________________________________________________________________________
Date: Aug 04, 2005
My three cents worth- Wired a Velocity with dual alternators using B & C's L-60, SD-20, LR3-14 and SB1A-14. We have 150 hours on the hobbs with these components with no overvoltage trips. We did have the SD-20 fail a few weeks ago and it was promptly replaced by the company. Goog folks! Peter On 3 Aug 2005 at 16:15, bakerocb(at)cox.net wrote: > > AeroElectric-List message previously posted by: Richard Riley > > > < particularly one of the B&C regulators - how often do the nuisance > trips occur? > > If we're worried about the nuisance trips degrading field CB's, would > it be a reasonable fix to replace those CBs at annual?>> > > 8/3/2005 > > Hello Richard, 100 hours plus on my plane with an externally regulated > (B&C), gear driven, 60 AMP alternator with no nuisance trips. > > Replacing CB's can be a bitch because frequently they are fastened 2 > or 3 or more to a brass bar. It can take a significant amount of > unfastening and then reassembling to replace one CB. > > OC > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2005
Subject: Audio Iso Amp Problem
Bob- You wrote: =A0=A0 I'm hearing that some radios like to be "loaded" heavier on their =A0=A0 phones output signals than what the amplifier provides. Before you =A0=A0 change the 180 to anything else, try putting anything from 50 to =A0=A0 100 ohms ACROSS the Microair 760's headphones output leads. I notice in the latest Iso Amp dwgs a Failsafe Headset (and mic) Jack added- my installation precedes this and I would like to incorporate the feature. Would adding the load resistor you mention above between the ring and tip terminals on the new headset jack be appropriate to the task? In addition, installing the Failsafe Headset Jack and using a male phone plug with a small value pot wired to its terminals would allow "fine tuning" the appropriate resistance prior to installing the resistor? These jacks would also require insulation from airframe as well, I surmise... Thanks again- Mark Phillips -6A ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Crowbar CB "problem" question
Date: Aug 04, 2005
I have the B&C LR3 regulator with Vans 30 amp externally controlled alternator. Wired per Bob's manual. No trips with 52 hours on the meter. Indiana Larry, RV7 Tip Up It Flies Teamwork: " A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ----- Original Message ----- From: "Richard Riley" <richard(at)RILEY.NET> Subject: Re: AeroElectric-List: Crowbar CB "problem" question > > For those that have experience with an external regulator - > particularly one of the B&C regulators - how often do the nuisance trips > occur? > > If we're worried about the nuisance trips degrading field CB's, would > it be a reasonable fix to replace those CBs at annual? > > > ________________________________________________________________________________
Date: Aug 04, 2005
Subject: B&C website problems
hmmm no link anymore from 'lectric Bob's website to B&C ??? B&C website, giving me errors when linking to products??? something going on?? -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Aug 04, 2005
Subject: Re: B&C website problems
Try http://www.bandcspecialty.com/ Peter On 4 Aug 2005 at 15:48, gert wrote: > > hmmm > > no link anymore from 'lectric Bob's website to B&C ??? > > B&C website, giving me errors when linking to products??? > > something going on?? > > -- > > > is subject to a download and archival fee in the amount of $500 > > > > > > > ________________________________________________________________________________
Date: Aug 04, 2005
> >hmmm > >no link anymore from 'lectric Bob's website to B&C ??? > >B&C website, giving me errors when linking to products??? > >something going on?? We removed the link in preparation for some major changes coming to our website which will include some whippy new products. I've had a few "page not found" type errors when roaming the B&C site. It wouldn't hurt to drop them a note when you discover one. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2005
Subject: Re:Real data on OVP/etc (disinterested?)
> > >George: The alternator that failed was a Nippon Denso, 60 amp, >internally regulated. I'm not sure that my experience should cause >others to avoid this unit. I know that hundreds of airplanes are flying >successfully with them. However, if you read Bob's most recent post, >you might decide to avoid all internal regulated alternators. > Hi Jack: > "Jack Eckdahl" wrote: >However, if you read Bob's most recent post, you might decide to avoid all internal >regulated alternators. No Sir, I still think internally regulated alternators (ND in particular) are a fine choice, without an adding on an OV protection device (crow bar). By fine choice I mean safe & reliable. It is lighter, cheaper, simpler and less expensive than an external regulated alternator. There is nothing wrong with a crow bar, not with standing the little technical minutiae. I have a great respect for Bob's opinions, which are based on his knowledge, experience, standard aerospace practices and certification regulations, which is all-good. To make an analogy: Lets make a stew by cooking-up several pounds of knowledge & experience. Than add an ounce of spice called opinion. The whole flavor of the stew is influence and changed by that opinion. The taste is still good, but it's a different flavored stew than if you used a different spice (opinion). That does not mean a stew with another spice (opinion) is bad. Bob has strong opinions, and is the guru of electrons who gives out design advice thru this forum, seminars and his book. He has to believe and understand the info he gives out. I don't blame him for not supporting IR alternators. He does not have detailed info on the design or can he control it. However that does not make IR alternators a poor choice or dangerous. In fact it is superior in many ways to the method of DC power generation Bob campaigns. Bob does not talk to the advantages of the IR alternator, but to be fair he does not say it is bad. He just cant recommend it, and given the choices he must pick one idea and back-up that one idea he feels is best overall for most applications. Thats OK. Pick your spice, make your stew, eat and enjoy. If you get indigestion it is your own fault. I don't criticize other Cooks for using curry spice. Bob says a crow bar and external VR is the best way to go; he has good reasons to recommend it; he is comfortable with it. He knows how it works or should work. Bob is not comfortable with IR regulators because he can't control the field directly, in other words he does not trust the IC chip and the one field driver transistor. Plus he has always used external voltage regulators at work. Fair enough. I do trust the IC chip and drive transistor. Why? They are proven in millions of cars, trucks and industrial equipment, including a good lot of kit planes as well. You can't get the FAA to certify an alternator on this basis, but again who cares if you have a kit plane. The electronic and auto industry has studied and tested these electronic components, like the ones inside a ND alternator, i.e., transistors and IC circuits. They have a known failure time in the millions of hours. The big hang up with Bob and others is the one drive transistor (external to the IC) could short out and by-pass the IC chips control of the alternator. How likely is this? The chance is slim to none, and is proven every day when millions of these alternators work with out fail, day after day, year after year, 100s and 1,000s of hours every year. I think a ND alternator with IR, without an added on crow bar, has the right spices for my stew (electrical system) and is delicious. Bob bases his design philosophy in part on a thought process of "how could you certify this?" Well if you have an experimental you don't care or need a certified accessory. I agree an IR alternator is hard if not impossible to certify with the FAA as is, without spending mega dollars doing it. So the inertia of the industry is to stay with what you know, externally regulated alternators. You can't certify an accessory based on field service history in cars and kit planes alone, but it sure speaks to its reliability. Good enough for me and many other builders. Bob works in the certified field; this is his line of work and influences his opinion. Not that there is anything wrong with that. However if you think FAA certified makes something better, you might consider a 1950's Delco or Ford Prestolite automotive generator and mechanical points voltage regulator are FAA certified on aircraft! Is that better than a small light Denso alternator with IR? Bob's crow bar is not certified. B&C alternators & regulators are not certified. Does that make them bad? NO. There is no magic to FAA certification. We have the freedom to use Denso alternators in our kit planes, an in my opinion we should exercise that option, not that Bob's baseline system is bad. I just don't think it automatically should be the De facto design. No disrespect to Bob, and sorry if that offends anyone. Why has Bob's crow bar experienced premature trips? Stuff happens. I read about the capacitor fix and understand why it helped. It seems to me, as an electronics amateur, whenever you have transient conditions (dv/dt), throw a good old capacitor in the mix. It always seems to mellow a circuit out. (mellow - a non-technical term for filter to dampen transient voltage spikes.) When in doubt put a capacitor in. (kidding) There is never a 100% guarantee any device, including a simple crow bar or a ND alternator will always work as designed. Simple things like a crow bar & circuit breaker should work as Bob would point out. The same applies to Denso alternators. However the idea propagated that a Denso failure means a colossal OV condition is not valid. The usual Denso failure mode is passive, by just dying. People want a 100% guarantees about everything in life and what they put on their aircraft. Keep it simple; consider a stand alone Denso as an elegant simple solution. Consider that crow bar could fail passively and not work when needed without the pilot being aware of it. Bob said this is unlikely. BINGO. I agree a simple crow bar should work, with emphasis on should. Same with a Denso alternator, it is unlikely you will have an OV condition. At least the ND alternator has a built in fault light (which will indicate many faults). Nothing is perfect. Take a chance on life > "Jack Eckdahl" wrote: >George: The alternator that failed was a Nippon Denso, 60 amp, internally regulated. Jack: I recall under peculiar conditions you observed your ND alternator going to 16 volts. Also with the ALT switched off it produced power after starting the engine. The technique of turning the alternator on after start was your normal procedure. Obviously something was different than before, since it always worked well and would not make power until switching it on. You also noted that voltage varied 13 to 16 with load. By using a normal procedure of manually switching the alternator ON after starting and OFF before shut down, you forced an abrupt ON/OFF thru the regulator. This is known to cause grief. (Read below-The IC chip inside the alternator is a microprocessor and its internal protections only work if it is powered during engine start and stop.) I recall pointing out sources for brand new 60 amp ND alternators to you. Not sure what you ended up doing but assume you are flying around FHD with your new ND alternator. My prediction is if you stop the practice of switching the alternator ON/OFF manually and get a NEW 60 amp ND alternator, you will have a lifetime of trouble free alternator service (with out crow bar). Odds are in your favor. The only other recommendation I have is add a cooling blast tube to the rear of the alternator, and avoid continuous operations above +30 amps. Heat is the killer of semi-conductors. ND alternators have an IC chip that provides many safety and fault protection functions including OV protection. In fact this microprocessor chip may have thousands of transistors VS. a Plain-Jane external VR with 2 or 4 transistors. Therefore doing abrupt things repeatedly stresses the chip overtime. It just was not designed to be used like that. You got away with it for a while, but eventually is started to fail (with out dramatic affect I might add). The IC chip also provides soft starts and load dump protection. SOFT START means a large demand will not cause the alternator to instantaneously slam full open but will ramp up to avoid a voltage overshoot. LOAD DUMP protection, keeps voltage variation to a min with a large drop in load. When I say load dump I don't mean dropping the B-lead abruptly with an OV relay, I mean turning the landing lights OFF. I would like to see a two-transistor external voltage regulator do this. The typical IR is more advanced than the typical ER. Paul's http://www.periheliondesign.com/suppressors.htm may solve the problem of killing a healthy ND alternators when a nuisance trip of a B-lead OV relay opening while the alternator is under load. Who knows, it can't hurt. However my electrical system design philosophy (the stew I am cooking) is to keep it simple. I assume the chance of my alternator going into a real out-O-control OV condition from a drive transistor short is so small I accept. Just like I accept my single engine will continue to turn and my single wing spar will not fail in flight. (Sometimes these also fail, but we maintain them and fly within limits to assure they get us back on the ground safely.) There has been much rhetoric about the dangers of IR alternators and the evil of that one field drive transistor. The theory is the transistor failure inside the IR bypasses the OV protection of the IC chip. This in turn causes the mother of all OV conditions. Not to beat the horse to death (which is a bloody caucus being picked at by vultures at this point), but this scenario is a theory NOT born out by the proven reliability in service. No car or kit plane I know of has ever had this condition from my research. I looked high and low and found nothing, nada, zip, zero. I am not saying it has never happened or cant happen (it can in theory), but there is no proof or documentation it has. If we are going to get scientifically rigorous, than we need the data, otherwise it is ignorant, to use Bobs words. Show me any cases of a ND alternator having a real honest to goodness (documented) shorted field drive transistor resulting in an over-voltage condition, urban legend aside. Sporadic OV module problems are much more prolific than the non-existent alleged alternator run-a-way. The voltage problem (16 volts) you had was far from a wild run-a-way. Voltage Run-a-way elicits thoughts of a train going down the mountain with no brakes, terror, panic, destruction and emotion. That is why when you tie the BAT master and ALT together, so the alternator is turned on automatically (i.e., DPST switch). If you need to shut the ALT down, manually pull the CB. > "Jack Eckdahl" wrote: >I'm not sure that my experience should cause others to avoid this unit. In my opinion using a ND alternator as is, provides an acceptable risk while gaining a lighter, simpler and cost effective electrical power source. Everything in aviation has risk, and the outcome depends on how you manage these risks. Bob says that crow bar failure is not likely. BINGO!! I am saying run-a-way voltage in a ND alternator is not likely. Again my opinion aside, facts like the field service history of ND alternators indicate their IR alternator are pretty darn good. I dont think the Japanese ND engineers that designed these devices are ignorant. (The auto industry is very aware of OV and has lots of electronics to protect.) Jack: If you replaced your rebuilt alternator with a new one, assuming you have stopped flipping the alternator ON an OFF manually, you will be fine. The BAT master should turn the ALT on simultaneously (i.e., DPST switch). If you need to disable the alternator pull the CB. > "Jack Eckdahl" wrote: >I know that hundreds of airplanes are flying successfully with them. I have no idea about aftermarket rebuilds or second tier replacement parts VS. OEM parts from ND. ND alternators can be bought new easily at discounted price if you shop around. The medium frame 60 amp ND's are more readily available as a rebuild, but they can be bought new if you look. Compare the price of a B&C and an over the counter stock 60 amp ND alternator. The whole B&C kit $820: alternator, regulator and brackets. If you buy a New ND alternator ($180 retail, $120 discounted), brackets and parts (approx $40-$60), your cost is about $250, the cost of Vans 60 amp ND alternator kit (with a rebuilt alternator). The B&C cost 3 to 4 times more. Is it worth the cost? It all depends on you opinion. Nothing wrong with spending the money but dont expect 100% reliability from the B&C, even on a dark and stormy night. Despite the B&C advertisements, balanced rotor and all, there is no proof, data or facts that the B&C system will achieve superior reliability over the stock ND alternator. However if you are talking about reliability of a B&C or Stock ND alternator set-up against certified 1950 and 60s technology factory aircraft electrical systems, than yes, they are both way more reliable than the old certified stuff. Now in theory may be B&C is better, but it cant be proven. The reason it cant be proven is the data or statistics are not available. The reason for that is no one is tracking it. Does B&C contact all customers with a service bulletin when a problem is found? That would be nice. If you point to a ND alternator problem, like the one above, than you can point to several B&C problems. >Robert L. Nuckolls, III Wrote: >Which only illustrates the ignorance of our customers promulgated by your rhetoric and Van's equally ignorant advice. Bob: I like to think they we have a different opinion not ignorant. Quote: (snip) ignorance of our customers (snip) and Vans equally ignorant advice. You just called everyone ignorant Bob. With all due respect that sounds condescending and insulting. May be you meant something else, but I take umbrage to that. No one likes to be called ignorant. Do you talk to Van. I think your crow bar is great as a simple cheap solution to protecting alternators with external regulators, which need protection, but not on IR alternators, which is designed to work without any other OV protection. Van recommends NOT installing an OV module on the 60amp ND alternator, because it can and does cause damage to them. Bob's comment and use of the word *ignorance* in describing Van's and Paul's opinion is dogmatic. I don't know Van personally but I have met him and talked to him several times over the last 15 years, building two of his kits. He is a very smart conservative guy, and has a degree in engineering, as I do. From Van's stand point ND alternators have been damaged with crow bar trips. Why did Bob call the man ignorant? Whether intentional or accidental, a crow bar trip can damage an ND alternator. This fact is bore out by the induced failure Jack had, described above. We dont know what data Van is working on. The man after all has over 4200 planes flying of his design and been in the kit plane market for 30 years, which gives him a little creditability. To call his opinion or Paul's opinion ignorant is not sensible. Everyone has the best intention here, and their suggestions are safe and reasonable in my opinion, whether you or I agree or not. I agree with Vans opinion that you should NOT use an OV module with an IR alternator, but I also agree with Bob. If you feel that you cannot rely on an IR and it's on-board OV protection than go with a crow-bar-ed external VR alternator. An external VR adds complexity, wiring, cost and weight and scheduled maintenance and testing, but it works. I can accept the IR and the minimal risk alleged that there is a statistical possibility, albeit unlikely, the field driver transistor can short. My decision to use an IR alternator and no crow bar gives me a light, simple, compact, cheaper system requiring no maintenance and testing. Plus parts are available nationwide over the counter at thousands of auto part stores and auto electric shops. Of course a NEW alternator is better than an overhauled one, but on a trip if you did have a problem, you could buy one across the street from the airport at Auto-parts-R-us, with a warranty. My old home airport had a large import auto salvage yard with in walking distance from my hanger. Therefore Van's advice is not ignorant or Pauls flavor of opinion less valid than Bob's, technical minutia aside. Bob can't guarantee the crow bar will never have a false trip or fail passively. He can't do it. Go ahead and say unlikely, but never say never. Like wise, Nippon Denso can't guarantee a high voltage failure, but ND engineers do know about OV. They understand OV and designed their product to minimize the chance of it happening. From the field service history in cars and experimental planes, ND did a great job. There are other alternator brands, some better than others, but in my opinion the ND is probably the best. The ND alternator with an IR is designed as a stand-alone unit. The interaction of and value of an OV module (crow bar) with an IR alternator is of dubious value. If the OV module can never false trip, than you will never damage the alternator. However that is not how it works in the real world. If Paul's B-lead suppressor works than that might be an option, allowing a safer way to incorporate a crow bar type device (Bob's or Paul's) safely on a ND alternator. Adding a crow bar to an IR alternator is really an effort in belt and suspenders. If you try to have your cake and eat-it to, you may end up with the worst of both worlds. Dont mix and match systems. (Too much spice in one stew is bad.) Accept the fact what ever you do, when you fly a plane, especially one you build with systems you designed, you are risking life and limb NO MATTER WHAT YOU DO. A single pilot in a single engine airplane is more risky than driving a car crazy folks behind the wheel sharing the same road. I firmly believe you can beat the General Aviation odds, but that might mean more pilot training, not more electrical gadgets. The pilot is the most dangerous thing in the plane, not the voltage regulator. Build your plane to fly with out it. I think it is fair to disagree, right? I say go with an IR alternator with no extra OV protection. My best advice is design your systems as simple as possible, while still getting the job done. Have a back-up, but be reasonable. Cheers George --------------------------------- Stay connected, organized, and protected. Take the tour ________________________________________________________________________________
Date: Aug 04, 2005
did just that, sent them an emial with specifics, actually the whole relay page seems to be fubar. Robert L. Nuckolls, III wrote: > > > > >> >>hmmm >> >>no link anymore from 'lectric Bob's website to B&C ??? >> >>B&C website, giving me errors when linking to products??? >> >>something going on?? >> >> > > We removed the link in preparation for some major changes > coming to our website which will include some whippy new > products. > > I've had a few "page not found" type errors when roaming > the B&C site. It wouldn't hurt to drop them a note when > you discover one. > > Bob . . . > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
From: "Malcolm Thomson" <mthomson(at)showmeproductions.com>
Subject: Screw terminals and Vision Microsystems' 1000
Date: Aug 04, 2005
0.03 HTML_TEXT_AFTER_HTML BODY: HTML contains text after HTML close tag 0.06 HTML_TEXT_AFTER_BODY BODY: HTML contains text after BODY close tag We are having reliability issues with a VMS 1000. Intermittent gauge readings, reboots, etc. I believe the issue is the connections to the unit which are made with screw terminals. These are the kind of terminals in which you strip the wire, insert it into the hole and then tighten the screw onto the wire. Does anyone have a suggestion of how this type of connection can be turned into something more reliable. Have others had this issue with the VMS 1000 or is it just me? Thanks. -- ________________________________________________________________________________
Date: Aug 04, 2005
Subject: Electric Tail wheel tug
Salvage Co.: C&H Sales. California. www.candhsales.com They have wheel chair motors and gear box etc. New and used Order a catalog A good read for the inventor Pugsley the RV Dog ________________________________________________________________________________
Date: Aug 04, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Microsystems' 1000
Subject: Re: Screw terminals and Vision
Microsystems' 1000 > > >We are having reliability issues with a VMS 1000. Intermittent gauge >readings, reboots, etc. I believe the issue is the connections to the unit >which are made with screw terminals. These are the kind of terminals in >which you strip the wire, insert it into the hole and then tighten the screw >onto the wire. Does anyone have a suggestion of how this type of connection >can be turned into something more reliable. Have others had this issue with >the VMS 1000 or is it just me? Funny thing about those terminal strips . . . Greg Richter likes 'em too. See pages 41 and 50 of http://www.aeroelectric.com/articles/richter/response_1.pdf These terminal strips are one step above wrapping a wire around a screw and mashing it under a washer. Not gas tight, no insulation support. I'm wondering if Greg uses these throughout is EFIS system? Anyhow, it does not surprise me that you or anyone else might have some difficulties with them. They're not very suited to a mobile environment, especially airplanes. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2005
> >At 06:47 AM 8/4/2005, you wrote: > >... > > The ideal ground system eliminates parallel > > pathways so that ANY open connection produces a passive > > failure. > >Bob, > How would I test for parallel pathways? Could I simply disconnect >the big ground braid and look for continuity between the firewall forest of >tabs and the engine? If you didn't install a parallel wired pathway, then it doesn't need to be tested. In the case under discussion: In addition to crankcase-to-ground-block fatwire, the system had a 22 or 20AWG ground wire running from some case-grounded sensor on the engine to a ground terminal on the instrument panel mounted display computer. The fact that the sensor was ALREADY grounded to the engine made the sensor groundwire a redundant parallel pathway that burned when it tried to carry starter current through the display when the fat-wire connection at the crankcase was loose. Just for grins, one COULD disconnect the fatwire from the engine and measure resistance across the open gap. Under ideal conditions, the measured value would be in kilo ohms. Under worst case but acceptable conditions a reading of as low as 100 ohms or so will be relatively risk free for noise or burnt wire issues. In the case cited above, the measurement would have been under 2 ohms . . . an invitation for smoke. Bob . . . ________________________________________________________________________________
Subject: Power/ground terminal blocks
Date: Aug 04, 2005
I'm looking for power & ground terminal blocks, and haven't been able to find them anywhere. I'm not sure if that is the correct term for what I am looking for or not. Basically I need a terminal block that will connect multiple wires to one wire, instead of acting as a pass-through/disconnect point for each wire. I want to mount them behind my panel, bring in one hot wire and one ground, and then feed each individual device from that strip. Make sense? I know something like this exists, I'm surprised they aren't easier to find. Can anyone tell me where to get these? Thanks! Steve Ruse Dallas, TX -- ________________________________________________________________________________
Date: Aug 05, 2005
Upgrade to the VM1000C. They have gone to all d-sub connectors. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Malcolm Thomson Subject: AeroElectric-List: Screw terminals and Vision Microsystems' 1000 We are having reliability issues with a VMS 1000. Intermittent gauge readings, reboots, etc. I believe the issue is the connections to the unit which are made with screw terminals. These are the kind of terminals in which you strip the wire, insert it into the hole and then tighten the screw onto the wire. Does anyone have a suggestion of how this type of connection can be turned into something more reliable. Have others had this issue with the VMS 1000 or is it just me? Thanks. -- ________________________________________________________________________________
Subject: Re: Power/ground terminal blocks
Date: Aug 05, 2005
On 5 Aug 2005, at 24:12, Steve Ruse wrote: > > > I'm looking for power & ground terminal blocks, and haven't been > able to > find them anywhere. I'm not sure if that is the correct term for > what I am > looking for or not. Basically I need a terminal block that will > connect > multiple wires to one wire, instead of acting as a pass-through/ > disconnect > point for each wire. I want to mount them behind my panel, bring > in one hot > wire and one ground, and then feed each individual device from that > strip. > Make sense? > > I know something like this exists, I'm surprised they aren't easier > to find. > Can anyone tell me where to get these? > How are you going to protect each hot wire from a short? If you are going to use CBs, then many people have a copper or brass bar that connects one side of the CBs together to distribute the power to them. If you want to use fuses, then you should look at some sort of fuseblock. See http://www.steinair.com/fuseblocks.htm. Ones with more fuses are available from B & C Specialties, but their site isn't working properly right now. http://www.bandc.biz/parts.html I recommend fuse blocks. For grounds, B and C Specialties sells a brass tab block that is designed to be used as a single point to ground dozens of things. It has dozens of tabs to take Fast-On connectors that you crimp onto the end of each wire. http://www.bandc.biz/parts.html Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 05, 2005
> By using a normal procedure of manually switching the alternator ON > after starting and OFF before shut down, you forced an abrupt ON/OFF > thru the regulator. This is known to cause grief. (Read below-The IC > chip inside the alternator is a microprocessor and its internal > protections only work if it is powered during engine start and stop.) > ... ND alternators have an IC chip that provides many safety and > fault protection functions including OV protection. In fact this > microprocessor chip may have thousands of transistors VS. a > Plain-Jane external VR with 2 or 4 transistors. Therefore doing > abrupt things repeatedly stresses the chip overtime. It just was not > designed to be used like that. You got away with it for a while, but > eventually is started to fail (with out dramatic affect I might add). > I had not heard of this before. Are you saying that I should make sure the alternator is on whenever the batteries are on? -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 05, 2005
> > >I'm looking for power & ground terminal blocks, and haven't been able to >find them anywhere. I'm not sure if that is the correct term for what I am >looking for or not. Basically I need a terminal block that will connect >multiple wires to one wire, instead of acting as a pass-through/disconnect >point for each wire. I want to mount them behind my panel, bring in one hot >wire and one ground, and then feed each individual device from that strip. >Make sense? > >I know something like this exists, I'm surprised they aren't easier to find. >Can anyone tell me where to get these? How would you use such a device in the architecture of your electrical system? Have you selected an architecture? May I suggest that you review the document which you may download at: http://aeroelectric.com/articles/Rev11/AppZ_R11C.pdf . . . pick an architecture that comes closest to what you believe you'd like to have and then consider modifying it as needed for any special requirements you might have. Then toss those considerations out here on the List for considered critical review. In particular, help us understand the concepts you described in your posting above and where this technique fits into any of the suggested architectures. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
> > By using a normal procedure of manually switching the alternator ON > > after starting and OFF before shut down, you forced an abrupt ON/OFF > > thru the regulator. This is known to cause grief. Please cite the study and a location from which we might access it . . . > (Read below-The IC > > chip inside the alternator is a microprocessor and its internal > > protections only work if it is powered during engine start and stop.) > > ... ND alternators have an IC chip that provides many safety and > > fault protection functions including OV protection. In fact this > > microprocessor chip may have thousands of transistors VS. a > > Plain-Jane external VR with 2 or 4 transistors. Therefore doing > > abrupt things repeatedly stresses the chip overtime. It just was not > > designed to be used like that. You got away with it for a while, but > > eventually is started to fail (with out dramatic affect I might add). The users of microprocessors throughout the industrial world would be astounded should suppliers of such devices express this kind of warning in the specifications for their products. I will suggest that any microprocessor product has no upper bounds for exercising it's functionality if one observes the well stated limits to external stress (voltages and currents) and accepts limit to operational agility (clock speeds). The notion that any manufacturer would field a product with the vulnerabilities cited above is mind boggling. Bob . . . ________________________________________________________________________________
Subject: Re: Screw terminals and Vision Microsystems' 1000
Date: Aug 05, 2005
Simalar probems with RMI engine monitor......After 70 hours on the airplane I am now starting to have fluctuating CHT and EGT gauge readings with the RMI engine monitor. Engine is running normally. I also suspect the connections between the sensor wires and hook-up wires to the instrument.as it is happening on all but one cylinder. The connectors are the bullet shaped push-ins and seem to be tight as it is very difficult to pull them apart. I too would appreciate hearing from others if they have had this problem and how they corrected it. Dale Ensing RV-6A We are having reliability issues with a VMS 1000. Intermittent gauge readings, reboots, etc. I believe the issue is the connections to the unit which are made with screw terminals. These are the kind of terminals in which you strip the wire, insert it into the hole and then tighten the screw onto the wire. Does anyone have a suggestion of how this type of connection can be turned into something more reliable. Have others had this issue with the VMS 1000 or is it just me? ________________________________________________________________________________
Date: Aug 05, 2005
I have had this same problem with my older Vision 800 system. One way to make the connection more robust is to wrap the stripped wire back around the insulation, say 1/8" and then insert that into the hole. Then the screw will clamp down onto the wire supported by the insulation just prior to the stripped section. Wayne ----- Original Message ----- From: "Robert L. Nuckolls, III Microsystems' 1000" <nuckollsr(at)cox.net> Subject: Re: AeroElectric-List: Screw terminals and Vision Microsystems' 1000 > Microsystems' 1000 > > >> >> >>We are having reliability issues with a VMS 1000. Intermittent gauge >>readings, reboots, etc. I believe the issue is the connections to the >>unit >>which are made with screw terminals. These are the kind of terminals in >>which you strip the wire, insert it into the hole and then tighten the >>screw >>onto the wire. Does anyone have a suggestion of how this type of >>connection >>can be turned into something more reliable. Have others had this issue >>with >>the VMS 1000 or is it just me? > > Funny thing about those terminal strips . . . Greg Richter > likes 'em too. See pages 41 and 50 of > > http://www.aeroelectric.com/articles/richter/response_1.pdf > > These terminal strips are one step above wrapping a wire > around a screw and mashing it under a washer. Not gas tight, > no insulation support. > > I'm wondering if Greg uses these throughout is > EFIS system? > > Anyhow, it does not surprise me that you or anyone else > might have some difficulties with them. They're not > very suited to a mobile environment, especially airplanes. > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 05, 2005
Subject: headset and microphone plugs
0.01 URI_REDIRECTOR Message has HTTP redirector URI >Longer form. > >I'm working on a panel mount intercom in an ultralight, trying to connect to >an Icom radio. I believe I've got a problem in the superfine wires going to >microphone and headset plugs. The previous builder connected those plugs to >an Icom connector cable (jacks going to an Icom connector). > >One way out of my trouble would be to find connectors which let me solder >"real" wire to. One is a 3/8 headphone style, the other is slightly smaller >(0.205?) for the microphone. They're the same size plugs as an aviation >headset uses. I can't seem to find these connectors sold in kit form. > >There may be other ways to solve this, but I'm almost ready to buy a >"portable" intercom (which has the connectors already wired) and break the >case to remount in my panel. > >I'd appreciate any leads on where to find connectors, or on alternate >solutions. The plugs your looking for are made by Switchcraft and may be viewed at: http://www.switchcraft.com/products/jack-122.html #480 is for the microphone, #440 is for headset side. You can purchase from folks linked below: http://www.newark.com/NewarkWebCommerce/newark/en_US/endecaSearch/partDetail.jsp?SKU=39F792&CMP=AFC-CC3763909474&QTexthttp://www.onlinecomponents.com/search-general.cfm?pn=480&manufacturer=SWITCHCRAFT&ref=Froogle and http://www.newark.com/NewarkWebCommerce/newark/en_US/endecaSearch/partDetail.jsp?SKU=39F791&CMP=AFC-CC3763909474&QTexthttp://www.onlinecomponents.com/search-general.cfm?pn=480&manufacturer=SWITCHCRAFT&ref=Froogle I note that the Newark description and illustration for the #480 is wrong but the part number and price differential suggests that if you order a #480, that you'll get the right part as described in the Switchcraft data sheet cited above. Bob . . . ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Date: Aug 05, 2005
Hi all, Although I don't know a good source, it is possible to purchase crimp pins that will solve this problem. Good quality ones are constructed in a similar manner as the push on spade connector, but have a pin instead that can be put in the terminal block. Paul ________________________________________________________________________________
Date: Aug 05, 2005
Thanks for the input Bob. The fuseblock suggested by Kevin is exactly what I'm looking for. My system will be most similar to "Z-29". Just a very basic battery-only system. My plane has no starter or alternator, although I may add a wind generator at some point in the future. I will only be powering my GPS, Intercom, and COMM radio from a battery, via something like the fuseblock Kevin suggested. I will also provide a spare 12v jack, as well as a ground charging jack. Thanks for the input, Steve Ruse Dallas, TX > How would you use such a device in the architecture of your > electrical system? Have you selected an architecture? May > I suggest that you review the document which you may download > at: > > http://aeroelectric.com/articles/Rev11/AppZ_R11C.pdf > > . . . pick an architecture that comes closest to what you > believe you'd like to have and then consider modifying it > as needed for any special requirements you might have. Then > toss those considerations out here on the List for considered > critical review. In particular, help us understand the > concepts you described in your posting above and where this > technique fits into any of the suggested architectures. > > Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
Thanks Paul. If anyone has a source or picture of what Paul is describing, please let me know. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Paul McAllister Subject: Re: AeroElectric-List: Screw terminals and Vision Microsystems' 1000 --> Hi all, Although I don't know a good source, it is possible to purchase crimp pins that will solve this problem. Good quality ones are constructed in a similar manner as the push on spade connector, but have a pin instead that can be put in the terminal block. Paul -- -- ________________________________________________________________________________
From: "Rhett Westerman" <Rhettwesterman(at)cox.net>
Date: Aug 05, 2005
Malcolm, I have almost 1000 hours on my VM1000 and never any trouble. I have many friends with this same unit that have run trouble free for long periods of time. I suspect that your wires are touching more than they are supposed to at the DPU or you have trouble elsewhere in the wiring. I do not think it is the screw terminals. best, Rhett -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Malcolm Thomson Subject: AeroElectric-List: Screw terminals and Vision Microsystems' 1000 We are having reliability issues with a VMS 1000. Intermittent gauge readings, reboots, etc. I believe the issue is the connections to the unit which are made with screw terminals. These are the kind of terminals in which you strip the wire, insert it into the hole and then tighten the screw onto the wire. Does anyone have a suggestion of how this type of connection can be turned into something more reliable. Have others had this issue with the VMS 1000 or is it just me? Thanks. -- ________________________________________________________________________________
Date: Aug 05, 2005
Malcolm - I have seen small, all-metal end caps that you crimp on to the ends of the wires. The cap is then inserted into the terminal. I have not had to do this because we do not have this kind of terminal in the A/C. John PS Are you flying the Thunder yet? O > We are having reliability issues with a VMS 1000. Intermittent gauge > readings, reboots, etc. I believe the issue is the connections to the > unit > which are made with screw terminals. These are the kind of terminals in > which you strip the wire, insert it into the hole and then tighten the > screw > onto the wire. Does anyone have a suggestion of how this type of > connection > can be turned into something more reliable. ________________________________________________________________________________
Subject: Aeroelectric List Format
Date: Aug 05, 2005
When the Federal government and IBM were struggling in court a decade ago, IBM's defense strategy was to send truckloads of documents to the government prosecutors. When the prosecutors asked for the slightest clarification on any point, IBM would ask for a geological amount of time to answer the question, then responded with more truckloads of documents. IBM kept this up until the government simply gave up and went away. This is to illustrate that all methods of argument are not equal, and some lead nowhere. I suspect that this "public email list server" has its structural limits, and we have exceeded them mightily. So what to do....? I suspect that the Aeroelectric Connection (or its clone) should be turned into a free document that can be edited continuously online like Wikipedia or other open source documents. Although one could charge for the subscription, the consensus seems to be that free subscriptions and paid advertising works better. Good textsbooks like the Aeroelectric Connection remain unread for the most part since people absorb what they find of most interest at the moment. Books also freeze a particular technical viewpoint, and the technology is changing too fast for this to be the medium of choice. The Aeroelectric list is handicapped by many operational limitations, such as no graphics attachments, no video clips, short display times (seven days goes zooming by), obscure formatting restrictions, etc. The wonders of the internet allow magical connections between people. We aren't doing it yet and as a result problems with discourse follow. The list is tiresomely repetitive, running the same debates on and on, just because the medium makes it so easy to forget all the arguments previously posted. I could suggest just numbering the arguments like the old joke about the comedian convention. Mr. X and Mr. Y lashing each other about load dump, "Well, that's old # XY-LD135Z. I thought we resolved that....let's see....two years ago? Let's put on our thinking caps (the beanie with the little propeller on it), and seek a better answer. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "What the West really has to offer is honesty. Somehow, in the midst of their horrid history, the best among the Gaijin learned a wonderful lesson. They learned to distrust themselves, to doubt even what they were taught to believe or what their egos make them yearn to see. To know that even truth must be scrutinized, it was a great discovery...." -- David Brin, "Dr. Pak's Preschool" ________________________________________________________________________________
Date: Aug 05, 2005
George you flatter me! >Paul's http://www.periheliondesign.com/suppressors.htm Should be Eric M. Jones's http://www.periheliondesign.com/suppressors.htm I borrow good designs wherever I can find them. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 ________________________________________________________________________________
Date: Aug 05, 2005
Malcolm They are called ferrules. Various manufactures. We use Weidmuller, for 22 awg the part # is 902575. There is a special crimper to put them on though. www.weidmuller.com Regards Ron Raby Lancair ES 55 hrs ----- Original Message ----- From: "John Schroeder" <jschroeder(at)perigee.net> Subject: Re: AeroElectric-List: Screw terminals and Vision Microsystems' 1000 > > > Malcolm - > > I have seen small, all-metal end caps that you crimp on to the ends of the > wires. The cap is then inserted into the terminal. I have not had to do > this because we do not have this kind of terminal in the A/C. > > John > > PS Are you flying the Thunder yet? > > > O >> We are having reliability issues with a VMS 1000. Intermittent gauge >> readings, reboots, etc. I believe the issue is the connections to the >> unit >> which are made with screw terminals. These are the kind of terminals in >> which you strip the wire, insert it into the hole and then tighten the >> screw >> onto the wire. Does anyone have a suggestion of how this type of >> connection >> can be turned into something more reliable. > > > ________________________________________________________________________________
Date: Aug 05, 2005
AeroElectric-List message previously posted by: "Malcolm Thomson" <> 8/5/2005 Hello Malcolm, VMS has abandoned the screw terminals for connecting the sensor wires to the DPU (Data Processing Unit) and gone to D Sub connections. They did this just about the time my DPU was delivered with screw terminals. I sent the DPU back to them and they converted it (Jan 2001) to the D Sub connector type, returned it to me, and it was installed by me. If you are absolutely convinced that the screw terminals are at fault it may be possible for them to convert your DPU also. Be advised that this will not be a trivial task. It will down your plane while the change to the DPU is being made. It will cost money. You may have to rewire all of your sensors since just putting D Sub connectors on your present wires may not be feasible. Wiring up the D Sub connectors is quite a chore. If you want to consider going this route contact me off list and I will mail you some instructions from the current VMS manual that will give you an idea of what is involved. Let's consider something else -- is it possible that the problem lies in the flat ribbon cable going to your gauges? These cables and the insulation piercing connectors are not foolproof and they can go bad. You can purchase cabling and connectors from the electrical supply places and roll your own replacement (contact me for advice) or you can order a replacement cable from VMS and install it. Ordering a cable from VMS is much easier of the two choices. Also tell us a little more about the reboot problem symptoms -- maybe there is something to be learned from that. Power supply wire to DPU loose? Voltage drops down during starting and the unit comes back whacky? Or.......? OC PS: I would not hesitate to email support(at)visionmicrosystems.com or call David McCluskey (360-714-8203) at VMS for help. I have the very highest regard for the integrity and capability of the customer service of VMS. I hope that their joining with JPI does not change that. ________________________________________________________________________________
Date: Aug 05, 2005
> > >George: The alternator that failed was a Nippon Denso, 60 amp, >internally regulated. I'm not sure that my experience should cause >others to avoid this unit. I know that hundreds of airplanes are flying >successfully with them. However, if you read Bob's most recent post, >you might decide to avoid all internal regulated alternators. > Hi Jack: > "Jack Eckdahl" wrote: >However, if you read Bob's most recent post, you might decide to avoid all internal >regulated alternators. No Sir, I still think internally regulated alternators (ND in particular) are a fine choice, without an adding on an OV protection device (crow bar). By fine choice I mean safe & reliable. It is lighter, cheaper, simpler and less expensive than an external regulated alternator. There is nothing wrong with a crow bar, not with standing the little technical minutiae. I have a great respect for Bob's opinions, which are based on his knowledge, experience, standard aerospace practices and certification regulations, which is all-good. To make an analogy: Lets make a stew by cooking-up several pounds of knowledge & experience. Than add an ounce of spice called opinion. The whole flavor of the stew is influence and changed by that opinion. The taste is still good, but it's a different flavored stew than if you used a different spice (opinion). That does not mean a stew with another spice (opinion) is bad. Bob has strong opinions, and is the guru of electrons who gives out design advice thru this forum, seminars and his book. He has to believe and understand the info he gives out. I don't blame him for not supporting IR alternators. He does not have detailed info on the design or can he control it. However that does not make IR alternators a poor choice or dangerous. It depends on your paradigm . . . In fact it is superior in many ways to the method of DC power generation Bob campaigns. Bob does not talk to the advantages of the IR alternator, but to be fair he does not say it is bad. He just cant recommend it, and given the choices he must pick one idea and back-up that one idea he feels is best overall for most applications. Thats OK. Pick your spice, make your stew, eat and enjoy. If you get indigestion it is your own fault. I don't criticize other Cooks for using curry spice. Bob says a crow bar and external VR is the best way to go; he has good reasons to recommend it; he is comfortable with it. He knows how it works or should work. Bob is not comfortable with IR regulators because he can't control the field directly, in other words he does not trust the IC chip and the one field driver transistor. Plus he has always used external voltage regulators at work. Fair enough. Which is not an opinion sir. Nor is it a preference for anyone's stew. For the past 70+ years, folks flying airplanes have had switches on the panel that offer (1) absolute control over all sources of power in the aircraft and (2) has a remote probability of a failure that propagates across multiple systems. The FAA requires that I work within that paradigm when offering up new systems for certification. I do trust the IC chip and drive transistor. Why? They are proven in millions of cars, trucks and industrial equipment, including a good lot of kit planes as well. You can't get the FAA to certify an alternator on this basis, but again who cares if you have a kit plane. I'm completely mystified by this statement. How does the fact that the FAA will or will not bless any particular reasoning make it an automatic no-brainer for someone building his own airplane? This isn't about regulations or opinions, it's about design goals that satisfy the paradigm under which the owner/operator of the end product. 99+ percent of OBAM airplane builders are comfortable with and most understand the paradigm that controls how certified airplanes operate. Do you have data about how the various IR alternators operate such that you can DEMONSTRATE that anything with ND's name on it will operate in the paradigm that applies to the vast majority of airplanes flying? If not, then your recommendation is not backed up by demonstrable and consistent performance characteristics and is, in fact, purely a preference for a different taste in your bowl of stew. Now, we can come forward with any number of new ideas. The e-bus was launched from the pages of the AeroElectric Connection over a dozen years ago. I sincerely hope that folks are taking advantage of this new paradigm no because you or I had any opinions about it. I hope builders incorporate this feature because they understand and appreciate its value. It's my job to instill understanding, not to convince anyone of anything. The electronic and auto industry has studied and tested these electronic components, like the ones inside a ND alternator, i.e., transistors and IC circuits. They have a known failure time in the millions of hours. No argument there. None-the-less, folks continue to come forward with their failure experiences. Not a "current generation ND alternator? Don't know. Not a stock regulator? Don't know. Would a well considered ov protection system of ANY flavor have saved the day? Probably . . . likelihood of dual failures in same system on same flight are extremely rare. At least one customer with the b-lead contactor and OVM-14 crowbar module has written to me expressing relief that the system was in place when his IR alternator went tits up. The big hang up with Bob and others is the one drive transistor (external to the IC) could short out and by-pass the IC chips control of the alternator. How likely is this? The chance is slim to none, and is proven every day when millions of these alternators work with out fail, day after day, year after year, 100s and 1,000s of hours every year. But do you agree that the risk is not zero? In fact, one of our brothers here on the list reported such an incident recently. If I were trying to convince someone of anything, I could have wished that Jack's failure would have occurred two hours out, at night, over mountains and took out a bunch of radios to boot. When one is looking for propaganda fodder, the sweat-drenched, nail-biting stories are much more useful. Gee Jack, you let us down. I think a ND alternator with IR, without an added on crow bar, has the right spices for my stew (electrical system) and is delicious. Please consume it in good health. Bob bases his design philosophy in part on a thought process of "how could you certify this?" Well if you have an experimental you don't care or need a certified accessory. I agree an IR alternator is hard if not impossible to certify with the FAA as is, without spending mega dollars doing it. So the inertia of the industry is to stay with what you know, externally regulated alternators. You can't certify an accessory based on field service history in cars and kit planes alone, but it sure speaks to its reliability. Good enough for me and many other builders. You absolutely missed the point. Again, this has nothing to do with how much this system would please or displease me, the FAA or anyone else. It has everything to do with operating within the paradigm (which the FAA happens to like - as do the vast majority of OBAM aircraft builders). Bob works in the certified field; this is his line of work and influences his opinion. Not that there is anything wrong with that. However if you think FAA certified makes something better, you might consider a 1950's Delco or Ford Prestolite automotive generator and mechanical points voltage regulator are FAA certified on aircraft! Is that better than a small light Denso alternator with IR? Bob's crow bar is not certified. B&C alternators & regulators are not certified. Does that make them bad? NO. There is no magic to FAA certification. We have the freedom to use Denso alternators in our kit planes, an in my opinion we should exercise that option, not that Bob's baseline system is bad. I just don't think it automatically should be the De facto design. You remind me of individuals who have a lot of opinions about a book they've never read. The crowbar OV protection system IS certified sir, several times over. I've stated this numerous times in this thread. All of B&C'S many STC'd installations of both belt and pad driven alternators use the LR/SB series regulators all of which have crowbar ov protection. No disrespect to Bob, and sorry if that offends anyone. You couldn't offend me if you tried. I won't permit it. You do amaze me with your lack of understanding as to what the real issues . . . Why has Bob's crow bar experienced premature trips? Stuff happens. I read about the capacitor fix and understand why it helped. It seems to me, as an electronics amateur, whenever you have transient conditions (dv/dt), throw a good old capacitor in the mix. It always seems to mellow a circuit out. (mellow - a non-technical term for filter to dampen transient voltage spikes.) When in doubt put a capacitor in. (kidding) This isn't about ov protection. It's about control. Does your ND alternator of choice turn ON and OFF at the flip of a switch? Once it's in operation, can it be turned OFF? Do all alternators with the ND brand on them operate in this manner? How does one insure at the parts counter that the alternator being considered will operate within the currently accepted paradigm? If not, then you're proposing a new paradigm. Which is fine . . . but be prepared to explain it in sufficient detail that everyone knows the physics upon which your recommendations are based . . . and they understand and accept the new paradigm. This has nothing to do with opinions, only facts and customer perceptions of value in the proposed paradigm. There is never a 100% guarantee any device, including a simple crow bar or a ND alternator will always work as designed. Simple things like a crow bar & circuit breaker should work as Bob would point out. The same applies to Denso alternators. However the idea propagated that a Denso failure means a colossal OV condition is not valid. The usual Denso failure mode is passive, by just dying. That's a no-brainer sir. 99% of all failures in all systems are passive. That's what keeps FBOs in business fixing all those things that broke and didn't bring the airplane down (or put the pilot into a situation he couldn't handle). The vast majority of accidents do not involve systems failures of any kind. People want a 100% guarantees about everything in life and what they put on their aircraft. Keep it simple; consider a stand alone Denso as an elegant simple solution. Consider that crow bar could fail passively and not work when needed without the pilot being aware of it. Bob said this is unlikely. BINGO. I agree a simple crow bar should work, with emphasis on should. Same with a Denso alternator, it is unlikely you will have an OV condition. At least the ND alternator has a built in fault light (which will indicate many faults). Nothing is perfect. Take a chance on life A romantic philosophy sir, but even the greatest of chance-takers took great pains to understand the territory into which they planned to venture. > "Jack Eckdahl" wrote: >George: The alternator that failed was a Nippon Denso, 60 amp, internally regulated. Jack: I recall under peculiar conditions you observed your ND alternator going to 16 volts. Also with the ALT switched off it produced power after starting the engine. The technique of turning the alternator on after start was your normal procedure. Obviously something was different than before, since it always worked well and would not make power until switching it on. You also noted that voltage varied 13 to 16 with load. By using a normal procedure of manually switching the alternator ON after starting and OFF before shut down, you forced an abrupt ON/OFF thru the regulator. This is known to cause grief. (Read below-The IC chip inside the alternator is a microprocessor and its internal protections only work if it is powered during engine start and stop.) I recall pointing out sources for brand new 60 amp ND alternators to you. Not sure what you ended up doing but assume you are flying around FHD with your new ND alternator. My prediction is if you stop the practice of switching the alternator ON/OFF manually and get a NEW 60 amp ND alternator, you will have a lifetime of trouble free alternator service (with out crow bar). Odds are in your favor. The only other recommendation I have is add a cooling blast tube to the rear of the alternator, and avoid continuous operations above +30 amps. Heat is the killer of semi-conductors. ND alternators have an IC chip that provides many safety and fault protection functions including OV protection. In fact this microprocessor chip may have thousands of transistors VS. a Plain-Jane external VR with 2 or 4 transistors. Therefore doing abrupt things repeatedly stresses the chip overtime. It just was not designed to be used like that. You got away with it for a while, but eventually is started to fail (with out dramatic affect I might add). This would be amusing if it weren't so serious. In one breath you extol the virtues of a "brand new" ND alternator while in the next, you cite the value of de-rating to 30 amps, supplying cooling air, modifying operating techniques that don't bother the alternator on a C-172 but might be stressful on the brand new ND . . . The IC chip also provides soft starts and load dump protection. SOFT START means a large demand will not cause the alternator to instantaneously slam full open but will ramp up to avoid a voltage overshoot. LOAD DUMP protection, keeps voltage variation to a min with a large drop in load. You cite facts not in evidence. The LR series regulators were tuned to provide the slightly under-damped servo response for step functions in both command and load. It's a classic taks for tailoring servo response. If the internal regulator were so whippy, LOAD DUMP ISSUES WOULD NOT EXIST. It's a regulator's inability to control the worst case load reduction that causes the high energy voltage transient. When I say load dump I don't mean dropping the B-lead abruptly with an OV relay, I mean turning the landing lights OFF. I would like to see a two-transistor external voltage regulator do this. Come on over to B&C . . . I'll show you one. The typical IR is more advanced than the typical ER. What's this mean? It's got 10-100x the transistors and they're all on a chip instead of soldered to a board. There are features that the older designs don't have but none of these things point to any "better" performance with issues you've cited. Paul's http://www.periheliondesign.com/suppressors.htm may solve the problem of killing a healthy ND alternators when a nuisance trip of a B-lead OV relay opening while the alternator is under load. Who knows, it can't hurt. It's Eric's product as I recall, not Paul's. Further, it has nothing to do with nuisance tripping. It illustrates a means by which an IR alternator can be CONTROLLED irrespective of the reason for controlling it. OV protection is but one more layer on a system that's already several layers deep. However my electrical system design philosophy (the stew I am cooking) is to keep it simple. I assume the chance of my alternator going into a real out-O-control OV condition from a drive transistor short is so small I accept. Just like I accept my single engine will continue to turn and my single wing spar will not fail in flight. (Sometimes these also fail, but we maintain them and fly within limits to assure they get us back on the ground safely.) You're entitled to accept any paradigm you wish. Just be sure your audience understands the paradigm shift when the proposed system does not operate like the one in a C-172. There has been much rhetoric about the dangers of IR alternators and the evil of that one field drive transistor. The theory is the transistor failure inside the IR bypasses the OV protection of the IC chip. This in turn causes the mother of all OV conditions. Not to beat the horse to death (which is a bloody caucus being picked at by vultures at this point), but this scenario is a theory NOT born out by the proven reliability in service. No car or kit plane I know of has ever had this condition from my research. I looked high and low and found nothing, nada, zip, zero. I am not saying it has never happened or cant happen (it can in theory), but there is no proof or documentation it has. If we are going to get scientifically rigorous, than we need the data, otherwise it is ignorant, to use Bobs words. This is not rhetoric to state that if the transistor shorts, the alternator takes off for the moon. It is not rhetoric to state that some IR alternators cannot be externally controlled for normal operations, much less for recovery after a failure. These are called deductions based on failure mode effects analysis. Show me any cases of a ND alternator having a real honest to goodness (documented) shorted field drive transistor resulting in an over-voltage condition, urban legend aside. Sporadic OV module problems are much more prolific than the non-existent alleged alternator run-a-way. Numerous folks have experienced failures of IR alternators. Some of them were ND alternators. Since we might expect to be in communication with perhaps 5% of the OBAM community, it's not a stretch to suggest that 3 hard failures I'm aware of over the past 8 years has been repeated 20X for the community at large. The voltage problem (16 volts) you had was far from a wild run-a-way. Voltage Run-a-way elicits thoughts of a train going down the mountain with no brakes, terror, panic, destruction and emotion. That is why when you tie the BAT master and ALT together, so the alternator is turned on automatically (i.e., DPST switch). If you need to shut the ALT down, manually pull the CB. Jack's experience was not mitigated by the fact that his alternator was "not in a wild run-away" . . . the battery was the only thing standing between his failed alternator and all the other electro-whizzies in his airplane. If the battery had been used up or even disconnected, the voltage would rise much faster and much higher. See: http://aeroelectric.com/articles/Alternator_Failures.pdf . . . also, role of the battery in an ov event starting at "Rev B" on page 6 of: http://www.aeroelectric.com/articles/Crowbar_OV_Protection/DC_Power_System_Dynamics_C.pdf > "Jack Eckdahl" wrote: >I'm not sure that my experience should cause others to avoid this unit. In my opinion using a ND alternator as is, provides an acceptable risk while gaining a lighter, simpler and cost effective electrical power source. Everything in aviation has risk, and the outcome depends on how you manage these risks. Bob says that crow bar failure is not likely. BINGO!! I am saying run-a-way voltage in a ND alternator is not likely. Again my opinion aside, facts like the field service history of ND alternators indicate their IR alternator are pretty darn good. I dont think the Japanese ND engineers that designed these devices are ignorant. (The auto industry is very aware of OV and has lots of electronics to protect.) Jack: If you replaced your rebuilt alternator with a new one, assuming you have stopped flipping the alternator ON an OFF manually, you will be fine. The BAT master should turn the ALT on simultaneously (i.e., DPST switch). If you need to disable the alternator pull the CB. > "Jack Eckdahl" wrote: >I know that hundreds of airplanes are flying successfully with them. I have no idea about aftermarket rebuilds or second tier replacement parts VS. OEM parts from ND. ND alternators can be bought new easily at discounted price if you shop around. The medium frame 60 amp ND's are more readily available as a rebuild, but they can be bought new if you look. Okay, you've fenced your paradigm in a bit tighter. You seem to be suggesting that only a "brand new ND" alternator is suited to operation in your proposed paradigm. Which part number? Will it offer positive ON/OFF control via the little wire out the back? Compare the price of a B&C and an over the counter stock 60 amp ND alternator. The whole B&C kit $820: alternator, regulator and brackets. If you buy a New ND alternator ($180 retail, $120 discounted), brackets and parts (approx $40-$60), your cost is about $250, the cost of Vans 60 amp ND alternator kit (with a rebuilt alternator). The B&C cost 3 to 4 times more. Is it worth the cost? It all depends on you opinion. Nothing wrong with spending the money but dont expect 100% reliability from the B&C, even on a dark and stormy night. This isn't about reliability. It's about failure mode effects. If the B&C goes south, it shuts down passively and lights the light. Then we bring "plan B" on line and continue the flight in comfort. This may not conform to your idea of component reliability, but it does conform to my idea of SYSTEM reliability. Despite the B&C advertisements, balanced rotor and all, there is no proof, data or facts that the B&C system will achieve superior reliability over the stock ND alternator. If you're looking for component reliability, you're correct. If you're looking for system reliability, my data is backed up by FMEA supported by 15 years of field history and a lot of experience in conducting such studies. However if you are talking about reliability of a B&C or Stock ND alternator set-up against certified 1950 and 60s technology factory aircraft electrical systems, than yes, they are both way more reliable than the old certified stuff. Now in theory may be B&C is better, but it cant be proven. So let's "assume" that it isn't? The reason it cant be proven is the data or statistics are not available. The reason for that is no one is tracking it. Does B&C contact all customers with a service bulletin when a problem is found? That would be nice. If you point to a ND alternator problem, like the one above, than you can point to several B&C problems. Until a couple of years ago, I was tightly coupled to B&C's field experience with their products. I worked out of their booth at OSH 12 straight years. I've talked to thousands of B&C customers (both happy ones and unhappy ones) Our warranty was "no unhappy customers" . . . EVERY customer was encouraged to bring any problem back to B&C for resolution. You're assertion with respect to pointing at B&C's problems is wishful thinking on your part sir. I've been there and it was my job to design products with a high degree of SYSTEM reliability and to quickly resolve what few problems did arise. >Robert L. Nuckolls, III Wrote: >Which only illustrates the ignorance of our customers promulgated by your rhetoric and Van's equally ignorant advice. Bob: I like to think they we have a different opinion not ignorant. Quote: (snip) ignorance of our customers (snip) and Vans equally ignorant advice. You just called everyone ignorant Bob. With all due respect that sounds condescending and insulting. May be you meant something else, but I take umbrage to that. No one likes to be called ignorant. I'm sorry, but you've just demonstrated your own shortfall for understanding of the issues and facts upon which your dissertation is based. Call it what you will . . . Do you talk to Van. I have talked to Van many times. I've asked to do a weekend seminar for their staff like I did for Lancair. I'm going to do one in their neighborhood and HOPE some of their staff will attend. I may have to specifically invite them and/or offer free tuition. I think your crow bar is great as a simple cheap solution to protecting alternators with external regulators, which need protection, but not on IR alternators, which is designed to work without any other OV protection. I'll suggest that you know nothing about design details and philosophy of anyone's built in regulators . . . nor are you privy to schematics upon which one bases a failure mode effects analysis. Van recommends NOT installing an OV module on the 60amp ND alternator, because it can and does cause damage to them. Bob's comment and use of the word *ignorance* in describing Van's and Paul's opinion is dogmatic. They BLAME the ov system for killing an alternator when if fact, root cause for the failure comes from attempts to CONTROL the alternator. The alternator with a b-lead contactor is vulnerable to the same kind of failure whether or not OV protection is a part of the control system. Again, call it what you will . . . I don't know Van personally but I have met him and talked to him several times over the last 15 years, building two of his kits. He is a very smart conservative guy, and has a degree in engineering, as I do. From Van's stand point ND alternators have been damaged with crow bar trips. Why did Bob call the man ignorant? Whether intentional or accidental, a crow bar trip can damage an ND alternator. This fact is bore out by the induced failure Jack had, described above. I've talked to Van at OSH and at several fly-ins. You betcha. When it comes to airframes, engines and flight controls, I am ignorant. I also don't know squat about brain surgery or particle physics. Van's forte' is demonstrably NOT founded in the physics and practice of fabricating electrical systems. His "kit" drawing is 1950's C-172 in which he has substituted a modern, IR alternator. "Ignorance" is not a pejorative but an accurate description of demonstrable fact. We dont know what data Van is working on. The man after all has over 4200 planes flying of his design and been in the kit plane market for 30 years, which gives him a little creditability. To call his opinion or Paul's opinion ignorant is not sensible. Everyone has the best intention here, and their suggestions are safe and reasonable in my opinion, whether you or I agree or not. I agree with Vans opinion that you should NOT use an OV module with an IR alternator, but I also agree with Bob. If you feel that you cannot rely on an IR and it's on-board OV protection than go with a crow-bar-ed external VR alternator. An external VR adds complexity, wiring, cost and weight and scheduled maintenance and testing, but it works. I can accept the IR and the minimal risk alleged that there is a statistical possibility, albeit unlikely, the field driver transistor can short. My decision to use an IR alternator and no crow bar gives me a light, simple, compact, cheaper system requiring no maintenance and testing. Plus parts are available nationwide over the counter at thousands of auto part stores and auto electric shops. Of course a NEW alternator is better than an overhauled one, but on a trip if you did have a problem, you could buy one across the street from the airport at Auto-parts-R-us, with a warranty. My old home airport had a large import auto salvage yard with in walking distance from my hanger. Therefore Van's advice is not ignorant or Pauls flavor of opinion less valid than Bob's, technical minutia aside. Bob can't guarantee the crow bar will never have a false trip or fail passively. He can't do it. Go ahead and say unlikely, but never say never. Like wise, Nippon Denso can't guarantee a high voltage failure, but ND engineers do know about OV. They understand OV and designed their product to minimize the chance of it happening. From the field service history in cars and experimental planes, ND did a great job. There are other alternator brands, some better than others, but in my opinion the ND is probably the best. Which part number? The ND alternator with an IR is designed as a stand-alone unit. The interaction of and value of an OV module (crow bar) with an IR alternator is of dubious value. If the OV module can never false trip, than you will never damage the alternator. However that is not how it works in the real world. If Paul's B-lead suppressor works than that might be an option, allowing a safer way to incorporate a crow bar type device (Bob's or Paul's) safely on a ND alternator. Adding a crow bar to an IR alternator is really an effort in belt and suspenders. If you try to have your cake and eat-it to, you may end up with the worst of both worlds. Dont mix and match systems. (Too much spice in one stew is bad.) Accept the fact what ever you do, when you fly a plane, especially one you build with systems you designed, you are risking life and limb NO MATTER WHAT YOU DO. Except that we CAN design an electrical system that will NEVER be a link in the chain of events contributing to a catastrophe A single pilot in a single engine airplane is more risky than driving a car crazy folks behind the wheel sharing the same road. I firmly believe you can beat the General Aviation odds, but that might mean more pilot training, not more electrical gadgets. The pilot is the most dangerous thing in the plane, not the voltage regulator. Build your plane to fly with out it. Voltage regulators are not the issue. Alternators you cannot control are the issue. I think it is fair to disagree, right? I say go with an IR alternator with no extra OV protection. My best advice is design your systems as simple as possible, while still getting the job done. Have a back-up, but be reasonable. George, the boat sailed and you weren't on it. You have misinterpreted my words and seem to have totally missed the concepts of failure tolerant design. You've demonstrated a lack of understanding of many simple You've also misstated simple facts. You've yet to demonstrate the need for supplying folks with the most universal concepts in the discipline being discussed. I don't think it's helpful to offer designs that depend on selection of a particular brand and part number of an alternator (which you have yet to identify). Put any name on it you wish sir, but it doesn't change the outcome. I'm reminded of the words of a wise philosopher who stated "When the best-you-know-how-to-do is compromised to placate those who would offer anything less, only less- than-the-best wins." Please fly your airplane in good health but I must continue to base my recommendations on the best I know how to do whether or not you understand or embrace it. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re: Control input
> >I have an FFA-approved Jeppessen flight simulator and the controls are far >too sensitive . . . the slightest input results in huge flight attitude >changes. Jeppessen no longer sells or supports the simulator, and we've >been unable to locate the author of the software so that we could get a >patch written. We've tried all the "tricks" and existing inputs, and have >managed to slow it down somewhat, but far from enough. > >During efforts to correct the problem, I found that the control inputs >function through a variable rheostat; Apparently the greater the control >input, the more current flows through the rheostat. Which leads me to >wonder if perhaps we might be able to solve our problem by use of a >resistor ahead of the reheostat; perhaps even a variable resistor so we >could experiment. > >I'd very much appreciate your thinking. Thank you for the kind words . . . Is it a rheostat (2-wire) or potentiometer (3-wire) connection? If the latter, it's easy to add resistance to both ends of the pot to scale the output voltage. If it's a 2-wire, then you need a smaller pot and some added series resistance to change the scale factors. But yes, you're perceptions of a possible solution by adjusting the resistor networks are correct. See: http://www.aeroelectric.com/temp/pot_scaling.gif Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re: Aeroelectric List Format
That's funny, I thought that Bob was giving away the updates to his book. I guess I must have imagined that. I reckon you could write your own book and give it away for nothing, but it doesn't seem fair to ask someone else to give away their hard work. Yahoogroups has most of the features that you have described. There is nothing stopping you from starting one of those or creating your own internet resource. I guess I don't see the point of just complaining about this resource, if you think there is a better way then "get after it". Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Eric M. Jones wrote: > >When the Federal government and IBM were struggling in court a decade ago, IBM's defense strategy was to send truckloads of documents to the government prosecutors. When the prosecutors asked for the slightest clarification on any point, IBM would ask for a geological amount of time to answer the question, then responded with more truckloads of documents. IBM kept this up until the government simply gave up and went away. > >This is to illustrate that all methods of argument are not equal, and some lead nowhere. I suspect that this "public email list server" has its structural limits, and we have exceeded them mightily. > >So what to do....? I suspect that the Aeroelectric Connection (or its clone) should be turned into a free document that can be edited continuously online like Wikipedia or other open source documents. Although one could charge for the subscription, the consensus seems to be that free subscriptions and paid advertising works better. > >Good textsbooks like the Aeroelectric Connection remain unread for the most part since people absorb what they find of most interest at the moment. Books also freeze a particular technical viewpoint, and the technology is changing too fast for this to be the medium of choice. > >The Aeroelectric list is handicapped by many operational limitations, such as no graphics attachments, no video clips, short display times (seven days goes zooming by), obscure formatting restrictions, etc. > >The wonders of the internet allow magical connections between people. We aren't doing it yet and as a result problems with discourse follow. The list is tiresomely repetitive, running the same debates on and on, just because the medium makes it so easy to forget all the arguments previously posted. I could suggest just numbering the arguments like the old joke about the comedian convention. Mr. X and Mr. Y lashing each other about load dump, "Well, that's old # XY-LD135Z. I thought we resolved that....let's see....two years ago? Let's put on our thinking caps (the beanie with the little propeller on it), and seek a better answer. > >Regards, >Eric M. Jones >www.PerihelionDesign.com >113 Brentwood Drive >Southbridge MA 01550-2705 >(508) 764-2072 > >"What the West really has to offer is honesty. Somehow, in the midst of their >horrid history, the best among the Gaijin learned a wonderful lesson. They >learned to distrust themselves, to doubt even what they were taught to believe >or what their egos make them yearn to see. To know that even truth must be >scrutinized, it was a great discovery...." > -- David Brin, "Dr. Pak's Preschool" > > > > ________________________________________________________________________________
Subject: Ferrels for use in screw connectors
Date: Aug 05, 2005
Bob or anyone who knows, I have a new AFS 2500 engine monitor and it has screw type connectors. I like the unit and want to use it. Does using a ferrel on each wire make this device less likely to have problem connections? TIA. Don VS ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re:Real data on OVP/etc (disinterested?)
Hi Bob, ... snipped a bunch ... I have no idea about aftermarket rebuilds or second tier replacement parts VS. OEM parts from ND. ND alternators can be bought new easily at discounted price if you shop around. The medium frame 60 amp ND's are more readily available as a rebuild, but they can be bought new if you look. Okay, you've fenced your paradigm in a bit tighter. You seem to be suggesting that only a "brand new ND" alternator is suited to operation in your proposed paradigm. Which part number? Will it offer positive ON/OFF control via the little wire out the back? I have an idea... Most people probably have access to a local auto parts retailer which has an alternator test machine (with a motor and belt drive, etc). It seems like it would be a simple task to pick an alternator off the shelf and take it to the bench and test this aspect of performance using their machine. It might take a bit of convincing of the salesperson to let you come to the back room and play with their machine. It should be easy to rig up a jumper from the control lead pigtail that could be disconnected and then grounded once the machine is up and running. Remember to tell the salesperson that the alternator is being installed in an off-road vehicle. Admittedly, that the alternator can be turned off via the control lead doesn't obviate the need for an OVP circuit. Even so, it does make it simple to be able to install an electrical system that a Cessna driver could operate without fear of damage. Regards, Matt- ________________________________________________________________________________
Date: Aug 06, 2005
> I suspect that the Aeroelectric Connection (or its clone) should be turned into a free document that can be edited continuously online I don't see that working. 1. How do you ensure quality? i.e. if its freely editable, then anyone can add any misunderstanding or inaccuracy or urban myth to it. 2. What about liability? For me in NZ, its not a big issue. But you're in the litigious USA. Perhaps you post something slightly inaccurate, or maybe it is accurate but not well explained. It's used by someone building a Lancair IV which subsequently has an electrical failure, crashes, and kills all aboard. Will the lawyers come after you? Will you be giving away information to help someone else if it means risking financial ruin? 3. Some time ago, I tried to run something similar... I called it "The Bunny's Guide to RV Building" (RV being a Vans RV-6 aircraft). As I built my RV, I added photos and text (some my own, a fair amount extracted from the RV-list archives), specifically aiming it at being an improvement on Vans' manual. The model I worked with was that I maintained the web pages, and asked people to email me with improvements, additions, etc. I got lots of feedback saying what a great resource it was. But I only got about half a dozen submissions in about 6 years. I'm not sure why it didn't work. 4. What we have now works. I've bought a copy of Bob's book, and I think it is good value. Why change? 5. Advertising-supported web sites just mean that readers pay for the content to someone else. You pay in wasted bandwidth and wasted time. 6. Books don't update themselves. A significant part of authoring is editing. 7. To some extent, the archives at Matronics are "the book writing itself". But without the editing! Me, I'm of the "think about what you're planning before destroying something" ilk. Frank >I didn't mean Bob should not be paid for his labors. I meant -- if Bob chose >to give away the book and have advertising on the site it might be a plus >for all concerned. He would probably make out better too--and the book would >update itself. > >I see you are one of the "love it or leave it" ilk. Well, mine is the >"improve it if possible" ilk > >Regards, >Eric M. Jones > > ________________________________________________________________________________
Date: Aug 05, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Eric M. Jones wrote: > >When the Federal government and IBM were struggling in court a decade ago, IBM's defense strategy was to send truckloads of documents to the government prosecutors. When the prosecutors asked for the slightest clarification on any point, IBM would ask for a geological amount of time to answer the question, then responded with more truckloads of documents. IBM kept this up until the government simply gave up and went away. I've seen this technique used many times. I used to work in the railroad accident investigation and analysis business. Asking for (or delivering) more pounds of paper than could be considered useful is common ploy used by both sides but usually when there are truths to be keep hidden. > >This is to illustrate that all methods of argument are not equal, and some lead nowhere. I suspect that this "public email list server" >has its structural limits, and we have exceeded them mightily. How so? Can you elaborate a bit? > >So what to do....? I suspect that the Aeroelectric Connection (or its clone) should be turned into a free document that can be edited continuously online like Wikipedia or other open source documents. Although one could charge for the subscription, the consensus seems to be that free subscriptions and paid advertising works better. You're certainly free to mount that kind of effort . . . > >Good textsbooks like the Aeroelectric Connection remain unread for the most part since people absorb what they find of most interest at the moment. Books also freeze a particular technical viewpoint, and the technology is changing too fast for this to be the medium of choice. Depends on the text. Physics books printed in 1945 are just as accurate for the presentation of simple ideas as a physics book printed today. Of course, the transistor and plasma display weren't talked about in '45 but superconductivity was. The simple understood. Further, I STILL prefer a printed book for random access of tid-bits from lots of data. Catalogs are good examples where looking at the whole printed page where you get side-by-side comparison of similar products. It's also difficult to match portability of the printed book. I've had a lot of requests NOT to bind the book . . . the 3-ring format lays nicely flat on the workbench. I don't see the printed book going away soon. > >The Aeroelectric list is handicapped by many operational limitations, such as no graphics attachments, no video clips, short display times (seven days goes zooming by), obscure formatting restrictions, etc. This presumes that significant numbers of participants have a desire/need to exchange multimedia items. Matt needs to be careful too about both data volumes and risks for transmission of malicious files. I have a website where I can easily publish quick illustrations. Matt has provided a photo-upload service (that same service would handle sketches scanned as .gif files). I suspect that few of the 1200 or so folks who subscribe to this List would ever upload a modern graphic so that still leaves us with a hand-full of people who would communicate with visuals more complex than text. > >The wonders of the internet allow magical connections between people. We aren't doing it yet and as a result problems with discourse follow. The list is tiresomely repetitive, running the same debates on and on, just because the medium makes it so easy to forget all the arguments previously posted. Yup, happens in boardrooms and meetings all over the world every day. At the core of any successful venture there are a cadre of holders-of-tribal-knowledge who provide instant random access to historical perspectives. We used to have a lot of them a RAC but every time one of them retires, a series of meetings somewhere in the plant become a little less guided by simple-ideas from the past. Further, the List is like a classroom . . . a new set of participants every "semester". One might rightly be disappointed if discussions ARE NOT repeated. A discussion never repeated is a discussion that has become either irrelevant -OR- has ceased to grow the collective knowledge of those who watch/participate. How many times does the average physics professor get to present an introduction to superconductivity over his/her teaching career? Now, as engineers, we should expect to become bored and impatient when it's been too long since we discussed the next greatest thing. But as a teacher, I see more value in the AeroElectric List as a classroom for simple-ideas than as a showroom for the latest inventions. I could suggest just numbering the arguments like the old joke about the comedian convention. Mr. X and Mr. Y lashing each other about load dump, "Well, that's old # XY-LD135Z. I thought we resolved that....let's see....two years ago? Let's put on our thinking caps (the beanie with the little propeller on it), and seek a better answer. I've told folks for years that the 'Connection is as much their creation as it is mine. The past few months discussions will be strong drivers in updates of the regulator, ov and alternator chapters. In fact, I might just update those three chapters. I'd be interested in your thoughts. I've been pondering ways to turn this activity into a retirement business and bail out of the certified rat-race. Thoughts have included a series of how-to-videos, seminars-on-a-DVD, a hands-on super-seminar where the attendees "wire up" a whole system, etc. By the way, Dee and I are going to be in Plymouth weekend of 13/14. I'll invite you to sit in on all or any part of the seminar . . . we'll be staying over Sunday night because of ticketing hassles so perhaps we could do some useful plotting for the future. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re: Ferrels for use in screw connectors
> >Bob or anyone who knows, >I have a new AFS 2500 engine monitor and it has screw type connectors. I >like the unit and want to use it. Does using a ferrel on each wire make >this device less likely to have problem connections? TIA. Don VS Depends on what the "ferrel" does. If it adds insulation support, it might be a useful thing to do. I doubt that quality of the connection goes up where the screw mashes down on something hoping to maintain electrical integrity. I had one reader suggest that you crimp the smaller diameter molex pins (.062") onto each wire and then put the pin into the screw-clamp. This would certainly help provide mechanical support for vibration resistance . . . but probably won't help with electrical integrity. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
> There might be room for both concepts to coexist. I agree. I enjoy the interactive conversations coming into my mailbox, and I like how easy it is to search the Matronics lists. What would be great is a FAQ that could be both a starting point for new members of the list, and a place to point someone when they ask a question that has been hashed to death. In fact, I'm pretty sure we have already discussed this issue, and someone wrote a kind of FAQ, but I can't even recall where it is. -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 05, 2005
Subject: Re: Power/ground terminal blocks
> >Thanks for the input Bob. The fuseblock suggested by Kevin is exactly >what I'm >looking for. My system will be most similar to "Z-29". Just a very basic >battery-only system. My plane has no starter or alternator, although I >may add >a wind generator at some point in the future. I will only be powering my GPS, >Intercom, and COMM radio from a battery, via something like the >fuseblock Kevin >suggested. I will also provide a spare 12v jack, as well as a ground charging >jack. > >Thanks for the input, You're welcome. Sounds like you got a good handle on it! I'd never considered the fact that Z-29 might be the whole enchilada. Good luck with your project. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
Bob, I goofed on the spelling of ferrules. Please see www.alliedelec.com/catalog/pf.asp?FN=101.pdf. The AFS2599 uses a screw connector where the screw moves a jaw like device together. I thing that the ferrules and this type of closure device should be adequate. Any thoughts? Thanks. Don -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Ferrels for use in screw connectors > >Bob or anyone who knows, >I have a new AFS 2500 engine monitor and it has screw type connectors. I >like the unit and want to use it. Does using a ferrel on each wire make >this device less likely to have problem connections? TIA. Don VS Depends on what the "ferrel" does. If it adds insulation support, it might be a useful thing to do. I doubt that quality of the connection goes up where the screw mashes down on something hoping to maintain electrical integrity. I had one reader suggest that you crimp the smaller diameter molex pins (.062") onto each wire and then put the pin into the screw-clamp. This would certainly help provide mechanical support for vibration resistance . . . but probably won't help with electrical integrity. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2005
The problem with an FAQ is that it requires a fair amount of maintenance, and then people often still won't dig into it before posting a question. Bob's book is actually the FAQ, if you ask me. And he maintains it, and doesn't charge very much for it. A rather sadistic idea: Make the interface to the list an 'ask jeeves' system. Only allow people to post questions after they have gone through the motions of searching the archive. Just kidding (mostly).. :) Bob's analogy that this list is like a classroom is one which gives me mental peace. I rather like that way of thinking about it. Regards, Matt- > > >> There might be room for both concepts to coexist. > > I agree. I enjoy the interactive conversations coming > into my mailbox, and I like how easy it is to search > the Matronics lists. What would be great is a FAQ > that could be both a starting point for new members > of the list, and a place to point someone when they > ask a question that has been hashed to death. > > In fact, I'm pretty sure we have already discussed > this issue, and someone wrote a kind of FAQ, but > I can't even recall where it is. > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > ________________________________________________________________________________
Subject: Toggle Switch & Breaker
Date: Aug 06, 2005
A couple of questions: What configuration of toggle switch (SPST, SPDT, etc) would I need to do the following: Down position - Off - Input not connected to any output Center position - Low - Input connected to one output Up position - High - Input connected to second output This would be used to feed a strobe power supply that offers both a low and a high output. A source of supply for this switch would also be appreciated. Second question: The Rotax 503 wiring diagram calls for a 15-amp fuse between the rectifier-regulator and the positive battery terminal. Would there be any reason not to use a combination toggle switch/circuit breaker, such as the W31X2M1G-15 from Wicks Aircraft Supply for this purpose? Thank you! ________________________________________________________________________________
Date: Aug 06, 2005
Subject: Re: New/rebuilt Alternators IGN wire (Was: real data
on ovp/etc) Matt wrote: >Okay, you've fenced your paradigm in a bit tighter. You >seem to be suggesting that only a "brand new ND" alternator >is suited to operation in your proposed paradigm. Which >part number? Will it offer positive ON/OFF control via >the little wire out the back? I think your paradigm is way too complicated for me, but I will try to explain. Matt I am not suggesting anything, but from common sense to me NEW with all OEM Nippondenso parts is better than rebuilt/used. (STORY) My personal experience with alternator problems, rebuilt alternators and over the counter trade-ins was on my Acura Legend. After approx 12 years and 200,000 miles the alternator stopped working altogether. I brought it to a local auto electric shop that had been in business for 60 years. You could tell because the walls and floor was littered with the remains of 100's and 100's of alternators and associated parts. Well I wanted my actual original alternator and not an exchange so decided to let them rebuild it. New brushes and something else was what it needed? I don't recall. It did not work when I replaced it so returned it. The second try worked a bit better but never as good as it had. The battery did not seem to get as much charge. Well it died again while on a road trip about a year later. I went to a local Pep Boys, near where my car died and exchanged it for a rebuild. I replaced it in the parking lot myself with minimum tools. I was impressed with the quality of the finish on the rebuild. It even came with documentation showing a Power Vs. RPM graph from a test run for that rebuilt unit. It has worked well for many years since and still is going. This car is now my dedicated airport car since I fly all the time and leave it parked for days and weeks at a time. (Side note if I am gone more than a week I disconnect the battery, because the computer will drain the battery in about 2 weeks and always has.) SO WHAT DOES THAN MEAN, nothing but may be not all rebuilds are the same. For my plane I still will buy new and for my car I guess I'll go to Pep Boys. However sometimes you can get a new one for less than a rebuild. >Matt wrote: >Will it offer positive ON/OFF control via the little wire out the back? Little black wire? I think on my wire harness it is yellow or green, but you are talking about the IGN wire that goes to the IR-internal (voltage) regulator. Positive ON/OFF Control? You don't need any POSITIVE control. When ever the engine is running the alternator should be ON, always. When ever you turn the master BAT switch OFF the alternator should be turned off (at the same time), while not under load (turning). You must never turn the BAT off with the ALT on. The IR is automatic and there is no need to manually control the alternator. If there is a fault it should shut down automatically. The IGN wire is not qusi ON/OFF switch. It is not the intent use. It does work as an ON switch in that if you start the engine with the ALT OFF (no power to the IGN wire) it should not make juice. However turning the alternator ON (power to the IGN wire) after starting the engine with it off, it will TURN ON. It will also FRY IT. Don't do it. May be you should read my SNIP. Now can you turn it off with the engine still running? I do not think so. My current plane and new 45amp ND are not running yet. I sold my last plane and can't go out and test it to tell you. However I would not even want to do it because there is no reason and I don't want to damage my alternator. Why do you want to manually shut the alternator off? Why? That is a bad idea. I never, never would turn the ALT or BAT off with the engine running (well except for one special condition). Why would you ever do this? What purpose would this serve? When would you shut a perfect alternator down with the engine running? The IR has it's own auto fault protections and will shut down. There is that rare OV case I mentioned in the previous post (SNIP) that in theory a scenario happens where nothing will turn the alternator OFF. As I said I never found any documented run-a-way cases with an IR Denso alternators. So what happens if this does occur? Most if not all the reported OV cases are old memories of old time alternators with their old time external regulators. However if you did have a runaway OV condition with your ND alternator, pulling the power to the IGN wire of the IR alternator may do nothing. First the IR should have caught it. If id did not than it may have failed. In the above scenario the regulator is by-passed. The only cure is pulling the B-lead circuit breaker (CB). You say you are using a fuse for the B-lead and not a panel mounted CB. Ok, than turn the BAT master off (the one special condition I mentioned). You are saying if you turn the BAT off than the engine will stop (EFI, dual EI, electric pumps). Well the engine will keep turning if you have a carb, mechanical FI, mags or self-powered ignition. If your engine is electrically depended, it should be on a standby battery to drive it's essential buss, separate from the main BAT bus. If you can't stand the loss of your main BAT buss, use the big u gly (alleged noisy- but not necessarily so) B-lead CB in the panel that almost every certified factory plane has. You act as a manual crow bar by pulling it. Again very unlikely and never proved to me to be a real concern. However if it did happen, you have an out. By the way if you did turn the BAT off, once the alternator burns out, and it would, you have the option to turn the BAT master back on. Land. Here is the deal, I am a KISS guy, not the Band KISS but KEEP IT SIMPLE. I would wire a Denso just like the manufactures who use them in their products (cars, trucks, tractors, folk lifts, outboard motor's, etc...). The IGN wire should be energized before cranking the engine and remain energized until you shut the engine down and than turn the BATT switch off. There is no separate switch provided to the alternator. Also according to the Niagara Air parts Kit you should (MUST) tie the ALT to the BAT. (do it like this) http://www.niagaraairparts.com/alt-instr.pdf Let the automatic functions of the alternator's internal regulator IC chip take care of starting and shutting down the alternator. There is no need to manually control it. All we have to do to start and stop the alternator is turn the pulley (start and stop the engine). I think you said so a Cessna driver can't damage it. Good idea. I don't care for the Cessna split rocker switch (tied together so you could not turn the BATT off without turning the ALT off also.) (STORY) Way back when I was an instructor about a few students (none of mine thank God) who would accidentally turn the BAT on and split the switch, leaving the ALT off, which you can do. They would start the engine, taxi out and fly away with the ALT off. They did not notice the amp meter discharge or little yellow light. After flying say less than an hour they would have a complete loss of electrical power (drained battery). Well they would find the problem and would turn the ALT on, which was off the whole time. Guess what. The alternator started pumping so much current to charge the dead battery, with all the radios and lights still on, the big CB (b-lead from alternator) would POP. They forgot to load shed before powering the alternator back on. Not wanting to reset the breaker more than once, they would than make an unscheduled stop and a call to the flight club. That is why I like a single toggle switch (DPST) for the BAT/ALT and not the Cessna split rocker style switch. -Ladies and Gentleman in the Event of an Emergency The alternator IGN goes thru a CB, so if you need to shut it down manually than pull the CB. If that does not work pull the B-lead CB in the panel (read above). A scenario that would call for this is if the alternator stopped working in flight. To save drain from the regulator, if any, pull the CB, since the alternator is not working anyway. There are procedures on the B757 that call for pulling a CB per "non-normal checklist" (emergency checklist is not used by Boeing), so it is perfectly normal to use a CB as an occasional switch. There are up to 4 AC GENS on a B757: 2 engine, 1 APU and on planes 1 Hydraulic driven GEN. All are the same 90 kVA GEN. They connect and parallel automatically and shut down if there is a fault automatically, with no pilot action. What is the point? They don't even trust airline pilots to throw the right switch so the automated it. Well not really but to the point let your little DENSO alternator's automatic IR functions work as designed; It is smarter than you when it comes to knowing when to turn itself ON and OFF. My theory is to see how few switches you can use, not how many. RV-8 should not have more switches than a B-757. Less is more, KISS Why do we have to make this so hard? Is there a need to throw a dozen switched to accomplish an engine start in a single engine airplane? >Matt wrote: >It seems like it would be a simple task to pick an alternator off the shelf and >take it to the bench and test this aspect of performance using their machine. Not sure what you paradigm you are driving at? I hope that answers your question. By all means buy a used alternator if you like. I was happy with Pep Boys for my Acura. You mention checking the rebuild in the store. That will not mean much if it craps out on your inaugural flight to Oshkosh in your new Sky Scooter 2005. However if you can, in my personal opinion (and I mean opinion), buy a new one. I have no facts to back that up. It is just my feeling NEW is better than rebuilt for an alternator. Paul asked a few questions and was told that rebuild is really RRR - Repair & Replace as (little as) required. So some parts, regulator, bearings for example might have 200,000 miles on it? I don't know if that is true. Again it must depend on who does the rebuild. Also there are aftermarket DENSO repair parts. I don't know if the quality is as good as OEM but I guess there is a chance other brand replacement parts are not as good? The nice part of Pep Boy's or AutoZone is I think you can buy a lifetime warranty. If you get on the web you might find a DENSO distributor that will sell you at least a factory re-manufactured alternator will all DENSO parts? Copy gratuitously what has worked before. This is not a test, so its not cheating. Good luck. George Subject: Re:Real data on OVP/etc (disinterested?) From: "Matt Prather" <mprather(at)spro.net> Hi Bob, ... snipped a bunch ... I have no idea about aftermarket rebuilds or second tier replacement parts VS. OEM parts from ND. ND alternators can be bought new easily at discounted price if you shop around. The medium frame 60 amp ND's are more readily available as a rebuild, but they can be bought new if you look. Okay, you've fenced your paradigm in a bit tighter. You seem to be suggesting that only a "brand new ND" alternator is suited to operation in your proposed paradigm. Which part number? Will it offer positive ON/OFF control via the little wire out the back? I have an idea... Most people probably have access to a local auto parts retailer which has an alternator test machine (with a motor and belt drive, etc). It seems like it would be a simple task to pick an alternator off the shelf and take it to the bench and test this aspect of performance using their machine. It might take a bit of convincing of the salesperson to let you come to the back room and play with their machine. It should be easy to rig up a jumper from the control lead pigtail that could be disconnected and then grounded once the machine is up and running. Remember to tell the salesperson that the alternator is being installed in an off-road vehicle. Admittedly, that the alternator can be turned off via the control lead doesn't obviate the need for an OVP circuit. Even so, it does make it simple to be able to install an electrical system that a Cessna driver could operate without fear of damage. Regards, Matt- ________________________________________________________________________________
data on ovp/etc)
Date: Aug 07, 2005
On 6 Aug 2005, at 23:33, wrote: > > Matt wrote: > >> Okay, you've fenced your paradigm in a bit tighter. You >> seem to be suggesting that only a "brand new ND" alternator >> is suited to operation in your proposed paradigm. Which >> part number? Will it offer positive ON/OFF control via >> the little wire out the back? > > Little black wire? I think on my wire harness it is yellow or > green, but you are talking about the IGN wire that goes to the IR- > internal (voltage) regulator. > > Positive ON/OFF Control? You don't need any POSITIVE control. When > ever the engine is running the alternator should be ON, always. > When ever you turn the master BAT switch OFF the alternator should > be turned off (at the same time), while not under load (turning). > You must never turn the BAT off with the ALT on. The IR is > automatic and there is no need to manually control the alternator. > If there is a fault it should shut down automatically. > > The IGN wire is not qusi ON/OFF switch. It is not the intent use. > It does work as an ON switch in that if you start the engine with > the ALT OFF (no power to the IGN wire) it should not make juice. > However turning the alternator ON (power to the IGN wire) after > starting the engine with it off, it will TURN ON. It will also FRY > IT. Don't do it. May be you should read my SNIP. > > Now can you turn it off with the engine still running? I do not > think so. My current plane and new 45amp ND are not running yet. I > sold my last plane and can't go out and test it to tell you. > However I would not even want to do it because there is no reason > and I don't want to damage my alternator. > > Why do you want to manually shut the alternator off? Why? That is a > bad idea. I never, never would turn the ALT or BAT off with the > engine running (well except for one special condition). Why would > you ever do this? What purpose would this serve? When would you > shut a perfect alternator down with the engine running? The IR has > it's own auto fault protections and will shut down. There is that > rare OV case I mentioned in the previous post (SNIP) that in theory > a scenario happens where nothing will turn the alternator OFF. As I > said I never found any documented run-a-way cases with an IR Denso > alternators. So what happens if this does occur? > How will you remove all electrical power from the aircraft in the event you ever have a smoke in the cockpit event? In theory, the fuses and CBs are supposed to prevent that sort of thing, but these events still happen due to various wiring faults (e.g. an insulation failure could cause a small ground wire to short to a large power wire - the ground wire would smoke before the circuit protection on the power wire would open). The only way to remove all electrical power in most archetures is to shut down the alternator and open the battery contactor. Even if you aren't worried about an OV event, you should consider the smoke in the cockpit case, as it could kill you, even if you are flying VFR. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 07, 2005
Subject: Re: Toggle Switch & Breaker
> >A couple of questions: > >What configuration of toggle switch (SPST, SPDT, etc) would I need to do the >following: > > Down position - Off - Input not connected to any output > > Center position - Low - Input connected to one output > > Up position - High - Input connected to second output This is accomplished with a two pole, three position, progressive transfer switch like B&C's S700-2-10 Use of this swich is illustrated in a number of the Z-figures in the book and in chapter 11 of the 'Connection. >This would be used to feed a strobe power supply that offers both a low and >a high output. A source of supply for this switch would also be appreciated. > >Second question: > >The Rotax 503 wiring diagram calls for a 15-amp fuse between the >rectifier-regulator and the positive battery terminal. Would there be any >reason not to use a combination toggle switch/circuit breaker, such as the >W31X2M1G-15 from Wicks Aircraft Supply for this purpose? How is the alternator tuned On/Off otherwise? If wired per instructions, is there no way to turn it off? One can always substitute breakers/fuses/switch-breakers for each other. Bob . . . ________________________________________________________________________________
Date: Aug 07, 2005
Subject: New/rebuilt Alternators IGN wire
> > >Matt wrote: > > > >Okay, you've fenced your paradigm in a bit tighter. You > >seem to be suggesting that only a "brand new ND" alternator > >is suited to operation in your proposed paradigm. Which > >part number? Will it offer positive ON/OFF control via > >the little wire out the back? > > >Positive ON/OFF Control? You don't need any POSITIVE control. When ever >the engine is running the alternator should be ON, always. When ever you >turn the master BAT switch OFF the alternator should be turned off (at the >same time), while not under load (turning). You must never turn the BAT >off with the ALT on. The IR is automatic and there is no need to manually >control the alternator. If there is a fault it should shut down automatically. Very good sir. We've finally arrived at the mutual level of understanding needed to resolve the new paradigm. Since day-one for the installation of power sources in aircraft, the pilot has been offered positive control of all sources in the form of panel mounted switches. These were additions to other forms of positive control like magneto switches (if you can start and stop the engine by means of fuel controls, why do we need magneto switches?), fuel shutoff valves, etc. Many of these features became part of CAA and eventually FAA requirements for certification. One might argue that since much of what the FAA requires adds no value to the safety of aircraft operation we can target ANY and ALL requirements as superfluous or unnecessary under any new paradigm we choose to embrace. The simple-idea supporting your paradigm is that you don't find it necessary to have positive control over an alternator. Now, if you wish to gain support of this paradigm, you need to do a Case-A, Case-B comparison of the ideas that support the Positive Control paradigm and demonstrate how they (1) were unnecessary or in error, or (2) have become obsolete with new technology or operating philosophies. It is inadequate to state that this new paradigm's philosophy is based only upon inarguable features of the latest-and- greatest technology. You must also supply the logic needed to encourage abandonment of the old paradigm. For example, at one time, wax and whale oil were the illumination fluids of choice and then kerosene came along only to be replaced by evaporated "white gas" (naptha) blown through mantles, etc. In each step, there were no compelling desirable features being abandoned from the old paradigm and new paradigms did not present unsurmountable or unacceptable features (nobody was ever electrocuted by a Coleman lantern and nobody ever set their house on fire by smoking while screwing in a new lightbulb). If you have such an case to make, I'm eager to hear it. Bob . . . ________________________________________________________________________________
data on ovp/etc)
Date: Aug 07, 2005
>Will it offer positive ON/OFF control via the little wire out the back?< >>Positive ON/OFF Control? You don't need any POSITIVE control. When ever the engine is running the alternator should be ON, always. When ever you turn the master BAT switch OFF the alternator should be turned off (at the same time), while not under load (turning). You must never turn the BAT off with the ALT on. The IR is automatic and there is no need to manually control the alternator. If there is a fault it should shut down automatically.<< Oh... my goodness. Where to start? I just finished doing a formal Functional Hazard Assessment for an alternator system. That, aside: Something mundane. How about troubleshooting electrical problems in the hangar? Do you REALLY want the alternator field drawing 3 amps while you have the battery ON ? In the air, what if you get a "flying" short of the spinning alternator windings that is intermittent while operating and causing lots of voltage and current spikes/faults to drop into the electrical system - - and you can't kill the alternator without killing the entire electrical system and creating an emergency? What if a diode fails and the level of electrical noise into the system makes radio communication very difficult? Regards, George ________________________________________________________________________________
Date: Aug 07, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> (Was: real data on ovp/etc)
(Was: real data on ovp/etc) > > > >Will it offer positive ON/OFF control via the little wire out the >back?< > > > >>Positive ON/OFF Control? You don't need any POSITIVE control. When >ever the engine is running the alternator should be ON, always. When >ever you turn the master BAT switch OFF the alternator should be turned >off (at the same time), while not under load (turning). You must never >turn the BAT off with the ALT on. The IR is automatic and there is no >need to manually control the alternator. If there is a fault it should >shut down automatically.<< > > >Oh... my goodness. Where to start? > >I just finished doing a formal Functional Hazard Assessment for an >alternator system. > >That, aside: > >Something mundane. How about troubleshooting electrical problems in the >hangar? > >Do you REALLY want the alternator field drawing 3 amps while you have >the battery ON ? This may not happen as long as you don't move the alternator control switch to ON after closing the battery contactor. >In the air, what if you get a "flying" short of the spinning alternator >windings that is intermittent while operating and causing lots of >voltage and current spikes/faults to drop into the electrical system - - >and you can't kill the alternator without killing the entire electrical >system and creating an emergency? > >What if a diode fails and the level of electrical noise into the system >makes radio communication very difficult? Good points for the positive control paradigm. Does anyone have additional offerings for (or against) either paradigm? Bob . . . ________________________________________________________________________________
data on ovp/etc)
Date: Aug 07, 2005
>Do you REALLY want the alternator field drawing 3 amps while you have >the battery ON ? This may not happen as long as you don't move the alternator control switch to ON after closing the battery contactor. ******************************* Bob, I thought the "no control" paradigm assumed that when the BAT switch is ON, that the alternator is powered - - with no way to interrupt the alternator. Right? In that case, the bus voltage will be <12.5 and the alternator field should be 100% energized, since the VR sense voltage set point will normally be > 13.8 Volts. Am I missing something ? Regards, George ________________________________________________________________________________
Subject: Ferrels for use in screw connectors EDITED
Date: Aug 07, 2005
Bob, I goofed on the spelling of ferrules. Please see www.alliedelec.com/catalog/pf.asp?FN=101.pdf. The AFS2500 uses a screw connector where the screw moves a jaw like device together. The contact area is about half that of a faston blade. I think that the ferrules and this type of closure device should be adequate, but would like your thoughts on this. Thanks. Don -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Ferrels for use in screw connectors > >Bob or anyone who knows, >I have a new AFS 2500 engine monitor and it has screw type connectors. I >like the unit and want to use it. Does using a ferrel on each wire make >this device less likely to have problem connections? TIA. Don VS Depends on what the "ferrel" does. If it adds insulation support, it might be a useful thing to do. I doubt that quality of the connection goes up where the screw mashes down on something hoping to maintain electrical integrity. I had one reader suggest that you crimp the smaller diameter molex pins (.062") onto each wire and then put the pin into the screw-clamp. This would certainly help provide mechanical support for vibration resistance . . . but probably won't help with electrical integrity. Bob . . . ________________________________________________________________________________
Date: Aug 07, 2005
(Was: real data on ovp/etc) > > >Do you REALLY want the alternator field drawing 3 amps while you have > >the battery ON ? > > This may not happen as long as you don't move the alternator > control switch to ON after closing the battery contactor. > > >******************************* > >Bob, > >I thought the "no control" paradigm assumed that when the BAT switch is >ON, that the alternator is powered - - with no way to interrupt the >alternator. Right? > >In that case, the bus voltage will be <12.5 and the alternator field >should be 100% energized, since the VR sense voltage set point will >normally be > 13.8 Volts. >Am I missing something ? Oh, I guess I don't know how Van suggests that it be wired, nor do I know how George was suggesting it be wired either. I HAVE seen a number of articles and drawings where the IGN wire was routed through a conventional alternator control branch of a split rocker . . . which would be emulated nicely by use of the 2-10 progressive transfer. This would allow the pilot to get the engine running before adding alternator loads. However, if wired as I suggested in earlier drawings where a 2-3 was used for DC PWR MASTER, then of course, the IGN terminal would "get hot" with the bus. Then, there's yet another configuration of modern alternators that offer the so-called, "one-wire" solution. These guys are popular with the marine and hot-rod crowd. Of course the b-lead is always hot in these vehicles. Having said that, some of the chips have an AC sense lead that gets a signal from the stator leads. Depending on the chip designer's philosophy, this signal could be used to disable the field when the alternator was not turning. An example of this philosophy can be viewed at: http://www.irf.com/product-info/datasheets/data/irvr101.pdf This puppy even offers a 9600 baud serial port for data transfer between chip and a monitor/control system. No doubt about it folks . . . there's a whole lot of whippy things goin' on out there. There may be a great temptation to embrace these new things. But we should take care lest we find ourselves in a new, unanticipated mode of operation by way of an unhappy surprise. Bob . . . >Regards, George > > >-- > > >-- incoming mail is certified Virus Free. Bob . . . -------------------------------------------------------- < Throughout history, poverty is the normal condition > < of man. Advances which permit this norm to be > < exceeded -- here and there, now and then -- are the > < work of an extremely small minority, frequently > < despised, often condemned, and almost always opposed > < by all right-thinking people. Whenever this tiny > < minority is kept from creating, or (as sometimes > < happens) is driven out of a society, the people > < then slip back into abject poverty. > < > < This is known as "bad luck". > < -Lazarus Long- > <------------------------------------------------------> http://www.aeroelectric.com ________________________________________________________________________________
Date: Aug 07, 2005
Subject: Re:Real data on OVP/etc (disinterested?) Bob
From: "Robert L. Nuckolls, III" nuckollsr(at)cox.net Subject: Re:Real data on OVP/etc (disinterested?) > It depends on your paradigm . . . That was my whole point. Bob you are focused on one small aspect. Aviation safety is a much broader subject than voltage regulators. >Which is not an opinion sir. Nor is it a preference for anyone's >stew. For the past 70+ years, folks flying airplanes have had >switches on the panel that offer (1) absolute control over all sources >of power in the aircraft and (2) has a remote probability of a failure >that propagates across multiple systems. The FAA requires that I >work within that paradigm when offering up new systems for certification. You missed the point. Opinion does guide your perspective. I dont worry what the FAA says. You are also uninformed about alternator control; I do have complete control of my IR regulator. If all hell breaks loose, I can pull that big-old B-lead 50 amp panel mounted CB out. (In a real emergency the BAT master off . My engine and flight instruments are not electrically dependent or are automatically backed up with internal batteries, Dynon, Garmin.) The only way to get true fail-safe or fail-passive system is at least two or three fully ISOLATION and independent electrical sources working side by side. >I'm completely mystified by this statement. How does the fact that >the FAA will or will not bless any particular reasoning make it >an automatic no-brainer for someone building his own airplane? >This isn't about regulations or opinions, it's about design goals >that satisfy the paradigm under which the owner/operator of the >end product. 99+ percent of OBAM airplane builders are comfortable >with and most understand the paradigm that controls how certified >airplanes operate. Bob dont be mystified. That is so condescending. What I wrote was so bewildering, you became disorient and confused. Wow I did not know my words had the power to mystify. No one is proposing a panacea here Bob and were ae a lot smarter than you give us credit for. >Do you have data about how the various IR alternators operate such >that you can DEMONSTRATE that anything with ND's name on it will >operate in the paradigm that applies to the vast majority of airplanes >flying? If not, then your recommendation is not backed up by >demonstrable and consistent performance characteristics and is, >in fact, purely a preference for a different taste in your >bowl of stew. Do I have data? Bob, that is an inane thing to ask. There are 148 models of ND alternators with internal regulators and internal fans ranging from 30 to 130 amps. There are 66 models of ND alternators with external regulators and internal fans from 90 to 136 amps. Plus there are another 15 various models with external fan models. There are a few million ND alternators in daily use, 24 hours a day, every day of the year working with excellent performance and reliability. If this does not prove, demonstrable and consistent performance characteristics, to BAD. All your posturing is absurd. You seem to lack common sense and reasonable rational. These are experimental planes. If you have never been in one, there is a warning placard that informs passengers that an experimental airplane does not meet standard aircraft certification standards. Bob, I never said my recommendation was a substitute, replacement or better than your brilliant concepts, architecture and philosophies. >No argument there. None-the-less, folks continue to >come forward with their failure experiences. Not a "current >generation ND alternator? Don't know. Not a stock >regulator? Don't know. Would a well considered ov >protection system of ANY flavor have saved the day? >Probably . . . likelihood of dual failures in same >system on same flight are extremely rare. At least >one customer with the b-lead contactor and OVM-14 >crowbar module has written to me expressing relief >that the system was in place when his IR alternator >went tits up. Bob, I am glad people write you to relive themselves. I think part of that relief is from all the misinformation and rumors about IR alternators you spread. With all the sensationalized talk it is easy to see how someone could have an unreasonable heightened sense of concern. What folks continue to come forward? You are the master of inflammatory insinuation. How many accidents have been caused by an OV and did they involve a ND alternator? ZERO. You have a better chance of your 0-2 gage-battery cable grounding, burning thru the engine mount or just falling off. Electrical system failure is a very small % of the total GA accidents. Statistically, regardless of where you put the regulator or if you use a crow bar or not, your accident statistics will not change. >But do you agree that the risk is not zero? In fact, >one of our brothers here on the list reported such an >incident recently. If I were trying to convince someone >of anything, I could have wished that Jack's failure would >have occurred two hours out, at night, over mountains >and took out a bunch of radios to boot. When one is looking >for propaganda fodder, the sweat-drenched, nail-biting >stories are much more useful. Gee Jack, you let us down. Bob that is just more emotional sensationalized comment is not worthy of an engineer, that you claim you are. You are clueless, I mean ignorant to the meaning of incident. This is what a pilot would do Bob: Over the mountains you loose your alternator; Turn off all your non-essential electrical stuff and continue to fly. You pull the ALT circuit breaker and the B-lead breaker. When you get near your alternate (nearest suitable airport) you turn the electrical stuff back on and land. Modern avionics like GPS pull a few 1/10th of an amp, so you could run on BAT power for a while. Nighttime you should have a flashlight. If you have a glass cockpit you should have enough battery power for at least 30-45min VFR and an hour plus for IFR. If you also have electronic ignition and fuel injection, all electronic you would need a bigger back-up battery. Dual alternators? My viewpoint is use a Lycoming with a mechanical fuel pump, at least one magneto or P-mag. A carburetor or mechanical FI does not need electrical power either. The Dynon, GRT-EIS-4000, Garmin and other misc items are pulling about 5 amps total. The Dynon and GPS have self-contained batteries as well. My engine is electrically independent as I feel it should be. I understand fault tolerance Sir. >Please consume it in good health. Thank you. Pass the crackers >You absolutely missed the point. Again, this has nothing >to do with how much this system would please or displease >me, the FAA or anyone else. It has everything to do with >operating within the paradigm (which the FAA happens to >like - as do the vast majority of OBAM aircraft builders). Bob, no you missed the point again. /Operating within the paradigm/ is gibberish that has no practical meaning to anyone. Common sense is the paradigm Bob. If you cant dazzle-em with facts, baffle-em with the word paradigm. It is not an affront to you or any device you have worked on. I have studied your every word and understand it. I just dont want a device that SHORTS to ground to work, no matter how clever or certified it is. I dont really care what the FAA thinks as long as I get my paper work signed. It is my butt and for a VFR plane, with no main buss electrical dependency to stay in the air, I am safe. What else can I say? What dont you understand? I designed my system to eliminate the need for a crow bar and external regulator. From personal experience with a ND alternator in my cars and plane, I expect over 4000 hours of operation before failure (200,000miles & 12 car years). So when my alternator reaches 2000 hours or 8 years I will remove and replace it. >You remind me of individuals who have a lot of opinions >about a book they've never read. The crowbar OV >protection system IS certified sir, several times over. I've >stated this numerous times in this thread. All of B&C'S many >STC'd installations of both belt and pad driven alternators >use the LR/SB series regulators all of which have crowbar >ov protection. I must remind you of yourself, since you talk about stuff you are clue less all the time. When the guy with the Subaru had the electrical failure you pontificated and criticize with little knowledge of facts. When you stated how B&C starters are better than Sky Tec with bushings and blaa blaa, The Sky Tec guy put you in your place. You should have apologized but you replied with something stupid comment about lets do some test. Again you did not have the facts. I am not perfect but you are ignorant. You also remind me of someone who loves to argue. I see B&C has a standby alternator system for the Bonanza and C210. Good for B&C. So I was not up to date. Sue me. Apologies. Do they have any STCs to replace the main alternator on any plane? If no, than why? >You couldn't offend me if you tried. I won't permit it. >You do amaze me with your lack of understanding >as to what the real issues . . . There you go again. What does that mean, I WILL NOT ALLOW IT. Whatever Bob. I was making a sincere jester of concern and you throw it back at me as if I was inconsequential and beneath you. I understand I am not worthy and of no importance. >This isn't about ov protection. It's about control. >Does your ND alternator of choice turn ON and OFF >at the flip of a switch? Once it's in operation, >can it be turned OFF? Do all alternators with the >ND brand on them operate in this manner? How does >one insure at the parts counter that the alternator >being considered will operate within the currently >accepted paradigm? Engineers? Bob you cant control everything, you only think you can. I cant think of a reason why I would turn off a perfectly good alternator with the engine running. If it did crap out I would pull the B-lead CB in my panel. That would essentially isolate it from the electrical system. (Yes I want control of my B-lead and opt NOT to use a FUSE under the cowl where I cant access it, as you suggest.) If I did not have the CB for the B-lead I could shut the BATT master off. The engine would continue to run. The Dynon and GPS would be powered by internal batteries. >If not, then you're proposing a new paradigm. Which is >fine . . . but be prepared to explain it in sufficient >detail that everyone knows the physics upon which your >recommendations are based . . . and they understand and >accept the new paradigm. This has nothing to do with >opinions, only facts and customer perceptions of value >in the proposed paradigm. I dont have customers. I am an individual and have stated so. As I clearly stated your paradigm (oh I hate that word) is valid and needed based on your position as guru. I dont have to prove anything. I have been honest in saying that ND alternators have gained over a thousand of hours on single airframes. Personally 800 hours of ND time in a plane and a total of approx 6000 hours in three automobiles (with ND alternators). As for the auto applications, the highway safety foundation has never had a problem with ND alternators, which is not true of many other alternators. Since records are not kept for experimental fleet, I am going by my experience and those of other RVs (some with 2000 hours) over 15 years. Not real scientific but it works. >That's a no-brainer sir. 99% of all failures in all >systems are passive. That's what keeps FBOs in business >fixing all those things that broke and didn't bring the >airplane down (or put the pilot into a situation he >couldn't handle). The vast majority of accidents do not >involve systems failures of any kind. Cant argue with you because you are a Master Debater. >A romantic philosophy sir, but even the greatest of >chance-takers took great pains to understand the territory >into which they planned to venture. Chance-Taker? Bob you have such a PIN HOLE view of the world , aviation and aviation safety, or at least you sound like it. I am bewildered and confounded by your very ignorant words. I am dizzy with disbelief. You dont know me and I am a very conservative ATP. This is just another feeble insult and a smoke screen for the lack of an intelligent comment with substance. I dont know what is romantic Sir, but I read what builders want to do. It is clear they are trying to make it perfect of totally fail-safe. Which is impossible with any of your suggestions or paradigm. If you like I will explain how an air transport category planes electrical system works to illustrate how unsophisticated our little DC electrical systems are. >This would be amusing if it weren't so serious. In one breath >you extol the virtues of a "brand new" ND alternator while >in the next, you cite the value of de-rating to 30 amps, >supplying cooling air, modifying operating techniques that >don't bother the alternator on a C-172 but might be stressful >on the brand new ND . . . Well Bob, for someone who claims to know how an alternator works, you appear to have a lack of any comprehension. I am not extolling any more than you are singing about the 7 th wonder of the world called a Crow bar. WHAT DO YOU MEAN? Look here, fact, semi-conductors life and reliability is a function of temperature. YOUR B&Cs alternator has a diode pack (semi-conductors) on board just like the ND, regardless of VR location. I guess B&C uses the exact same stock diodes all ND alternators have. Keeping them cool is key to any alternator life. I am using COMMON SENSE here, which you seem to be lacking from your fixation of the crow bar or center of the galaxy. If you want to assure super reliability de-rate your continuous % load. What % 50, 75? It is only a guide line Bob, don't be a pisser. Some cars have shrouds and duct air to the back of the alternator. Why? Cooling. Real engineers understand this and would not make such an inane comment. Size your alternator accordingl y. ND makes 80 or 90 amp alternators I think are the physical size as the 60 amp. Just common sense not quantum physics. If you can fit it there are 117-136 amp ND alternators designed for an external voltage regulator out the Box! >You cite facts not in evidence. The LR series regulators >were tuned to provide the slightly under-damped servo response >for step functions in both command and load. It's a classic >taks for tailoring servo response. If the internal regulator were >so whippy, LOAD DUMP ISSUES WOULD NOT EXIST. It's a regulator's >inability to control the worst case load reduction that >causes the high energy voltage transient. You cite facts not in evidence? Bob, what the heck do you mean? Whimpy? What kind of engineering term is that? That is how they work by design. AGAIN FOR THE 10th TIME CUTTING THE B-LEAD OF AN IR ALTERNATOR IS NOT GOOD FOR THE ALTERNATOR. IF YOU WANT A CROW BAR USE AN ALTERNATOR WITH AN EXTERNAL REGULATOR, OR TAKE YOUR CHANCES WITH FAULTS CROW BAR TRIPS. GO AHEAD, USE A IR ALTERNATOR, IT IS OK WITH ME. EVERY ONE KNOWS RUNNING AN ALTERNATOR NOT CONNECTED TO A BATTERY IS BAD BAD BAD. WHY IS THIS HARD TO GRASP BOB? You claim to understand failure analysis. I doubt it. If you were driving your car and the b-lead shorts (before the fuse), would you want the alternator to burn-out (fuse) or keep working and act like a welder and set the car on fire? (I have no idea what you will say, really, you would argue with a rock.). We know the OV trip caused the demise because after this event the alternator did not work anymore. ND engineers no doubt assumed this would be a rare event (because they dont recommend OV cutouts by default. There are no OV relays in non-aircraft applications). The IR has many functions and one of them looks at the B-lead. While under load it will assume a short or other fault, which it does monitor (because ND said so). Also the IC chip is connected to the B-lead and it just might be too much for it. SO WHAT. This is condition is avoidable. ND accepted this failure mode because it is not suppose to happen and is safer than making a welder out of it. >Come on over to B&C . . . I'll show you one. OK, Ill take a rain check I would love to see that >What's this mean? It's got 10-100x the transistors and they're >all on a chip instead of soldered to a board. There are features >that the older designs don't have but none of these things >point to any "better" performance with issues you've cited. Bob I think you have IC envy. Yes Bob more transistor means more features and performance. You heard of computers? Well they have millions of transistors on a small chip. More transistors the faster it works. If you built a computer like you build your B&C VR, it would be the size of a house. I would think you could grasp that. The IC chips inside most modern alternators does have logic circuits (digital processes) and self-fault monitoring. DENSO will not send me the schematics to their proprietary IC design. What I do know about special IC chips is they are made by a handful of manufactures. They all seem to have similar features. Here is a typical IC spec data sheet: http://www.freescale.com/files/analog/doc/data_sheet/MC33099.pdf >It's Eric's product as I recall, not Paul's. Further, it has >nothing to do with nuisance tripping. It illustrates a means >by which an IR alternator can be CONTROLLED irrespective >of the reason for controlling it. OV protection is but one >more layer on a system that's already several layers deep. My mistake, yes it is another layer. I have read spec sheets on devices. If you must use a crow bar on an IR regulator it might be a good add on (another add on). It might help the OV relay from arcing as I think you and Paul have argued about. >You're entitled to accept any paradigm you wish. Just be >sure your audience understands the paradigm shift when >the proposed system does not operate like the one in >a C-172. Thank you for telling me I am entitled to an opinion. I dont need your permission to have an opinion but thanks. Let me make it simple for you, the engine should never stop turning in flight. Most GA planes have engines with no reliance on external electrical power, or should. That is a good thing and should be emulated at all cost. I understand Auto engines need power for the ignition/fuel injection and pumps. That is one reason why I would not use an auto engine. However an IR alternator could still be used, but you should have an isolated power source. You never considered a DC-DC converter (battery charger) to charge isolated battery. This is used on transport category planes. >This is not rhetoric to state that if the transistor shorts, >the alternator takes off for the moon. It is not rhetoric to >state that some IR alternators cannot be externally controlled >for normal operations, much less for recovery after a failure. >for normal operations, much less for recovery after a failure. >These are called deductions based on failure mode effects analysis. Like you asked me several times above, do you have data? Look up the word rhetoric. You should know what it means since you used it: rhetoric: The art or study of using language effectively and persuasively. By throwing in the word Deduction and Failure Mode Effects Analysis in one sentence, I know you are shooting smoke. WHAT ANALYSIS DID YOU DO? FMEA is a term that describes the tools people use doing risk based assessments and root-cause-analysis. It is used in all kind of industries and processes. I see no analysis but just a lot of words Bob. Now I did not say I did formal FMEA, but I did go thru all the scenarios and made a DEDUCTION. I am not impressed when you throw a few words around. Where is this analysis? If you dont have it you are just spouting RHETORIC. My Risk-matrix result, for an IR alternator, in a little single engine plane, no engine or flight critical system dependence on electrical power, concludes the RISK is acceptable. With a B-lead CB in the pane I can control the alternator. >Numerous folks have experienced failures of IR alternators. Some >of them were ND alternators. Since we might expect to be in >communication with perhaps 5% of the OBAM community, it's not >a stretch to suggest that 3 hard failures I'm aware of over >the past 8 years has been repeated 20X for the community at >large. Numerous? OK Bob what ever you say, Failures. Hard failures? You dont even know what the word incident means. Like you asked me several times above, DO you have data? Prove it to me. You are throwing out numbers: 20 times, 3 to the power of perhaps? You are real loose with the numbers. What does that mean? What hard failure? What happened? I mean really Bob, you are hypocritical when you ask for data and expect to give none in return Sir. Other wise it is hearsay, innuendo and rumor. A few of these I tracked down where totally irrelevant and where factory planes with external regulators. Forget the Failure analysis Bull, how about some simple details. Basically WHAT HAPPENED? My I suggest if you had a smoking gun to support your view you would say so. >Jack's experience was not mitigated by the fact that >his alternator was "not in a wild run-away" . . . the >battery was the only thing standing between his >failed alternator and all the other electro-whizzies >in his airplane. If the battery had been used up >or even disconnected, the voltage would rise much >faster and much higher. Oh, Bob you dont know that. It was mitigated by the fact the voltage regulator was still functioning; it was no big deal. Voltage was between 13-16 volts. I am sure in a few years this case will grow into a fairy-tale where the pilot was electrocuted and the plane bust into flames from exploding avionics. It is all sensation but no facts. Take a deep breath. No harm no foul. Yes the battery helps any alternator. That is why my you dont disconnect it from the battery normally. If you do the alternator might be damaged. >Okay, you've fenced your paradigm in a bit tighter. You >seem to be suggesting that only a "brand new ND" alternator >is suited to operation in your proposed paradigm. Which >part number? Will it offer positive ON/OFF control via >the little wire out the back? I address this in my post: Re: New/rebuilt Alternators IGN wire (Was: real data on ovp/etc) >This isn't about reliability. It's about failure mode >effects. If the B&C goes south, it shuts down passively >and lights the light. Then we bring "plan B" on line >and continue the flight in comfort. This may not conform >to your idea of component reliability, but it does >conform to my idea of SYSTEM reliability. If it never breaks you dont have to worry about failure mode. Plan B applies just as much to a ND alternator as it does to anything you suggest. >If you're looking for component reliability, you're >correct. If you're looking for system reliability, >my data is backed up by FMEA supported by 15 years >of field history and a lot of experience in conducting >such studies. There you go. You have 15 years of crow bar data in experimental aircraft? Wow. Well the basic ND design has been around for well over 15 years. I believe you, but how did you get the data. You claim you conducted 15 years of field history study. How many are in service? What about the failures happening, which you have no idea of? One weak link in the home built world is there is no requirement to collect maintenance data. You will see maintenance bulletins the FAAs prints pertaining to all planes and sometimes a Kit plane will be in it, but most non A&P builders of experimental aircraft dont report or read this publication. There should be a FAR that requires or makes it easy for builders/repairman to report maintenance issues, including electrical. That way we would know whose alternator is failing. >So let's "assume" that it isn't? Now Bob dont be that way, you have muddled the point. You have a vested input to the B&C design. You are proud and should be. I can see plainly that discreet components and a crow bar is going to have a known failure mode. It does not mean it will not fail more, but you understand how it fails. I can say my ND alternator will be very reliable, but if it does fail, it might fail in unknown modes. I know it is reliable and will not kill me, from my FMEA analysis I did on a cocktail napkin. >Until a couple of years ago, I was tightly coupled to >B&C's field experience with their products. I worked out of >their booth at OSH 12 straight years. I've talked to >thousands of B&C customers (both happy ones and unhappy ones) >Our warranty was "no unhappy customers" . . . EVERY customer >was encouraged to bring any problem back to B&C for resolution. >You're assertion with respect to pointing at B&C's problems >is wishful thinking on your part sir. I've been there >and it was my job to design products with a high degree >of SYSTEM reliability and to quickly resolve what few >problems did arise. I think you are super defensive and sensitive, Sir. I wish to point at nothing. I dont even know about all the past problems. I am not trying to discredit anything or anyone. I think B&C is over priced not defective. However I think many comments regarding the danger of using an IR alternator ignores the high degree of reliability. The ND is an unknown since we cant look into the IC chip. However that is moot since you EXPERTS have isolate the weak link, the field driver transistor, not the IC chip. As I said the ND engineers are NOT ignorant and these products are very mature. Regardless, you can always pull the B-lead CB manually (if you have one and you should. If you want to protect an individual piece of avionics, you can use a device like a TransZorb(tm) or Mosorb that will break down at a set voltage like a zener diode. This will blow the fuse or CB for that item (like a crow bar). This may not be necessary since most modern electronics which have internal OV protection and can take 30 volts and 60 volts spike (except icom a-200). Also no one can put an exact max voltage on an OV condition. The last one was 16 volts. Yawn, no worries. > I have talked to Van many times. I've asked to do a weekend seminar >for their staff like I did for Lancair. I'm going to do >one in their neighborhood and HOPE some of their staff will >attend. I may have to specifically invite them and/or offer >free tuition. That is real nice of you. Why call the man ignorant? Did he NOT get all excited about FUSES, central ground and crow bars? Really there is nothing really new under the sun Bob. Van has common sense and an eye on the BIG PICTURE, not just the minutia of one possible electrical problem that is not that common any more. (In the old days there where lots of OV because the external VRs where crap.) >I'll suggest that you know nothing about design details >and philosophy of anyone's built in regulators . . . nor >are you privy to schematics upon which one bases a failure >mode effects analysis. Oh Geeee Bob, I suggest you have not processed the info. I told you at least 4 times I cannot get any detailed info on the IR chip inside a ND. I got some general sales claims about OV and Load Dump protection but nothing real technical. Again Load dump means 5-10 amps, not 30-60amps during a B-lead abortion from a crow bar. I have studied spec sheet for other brands of IC chip sets use for alternators. Also I have talked to NDs tech support in the US and looked maintenance manual schematics (void of details inside the IC). They dont EVER recommend cutting the alternator loose from the battery. Other than that both my cars and my plane have ND alternators with internal regulators. >They BLAME the ov system for killing an alternator when >if fact, root cause for the failure comes from attempts >to CONTROL the alternator. The alternator with a b-lead >contactor is vulnerable to the same kind of failure whether >or not OV protection is a part of the control system. >Again, call it what you will . . . I dont think it is a big deal Bob, dont be so sensitive. The crow bar got a little reputation for toasting ND alternators. No one is blaming your little baby, but there seems to be a cause and affect (Root Cause Failure Analysis per basics of FMEA you claim to understand). It seems there is a correlation. Look IR alternators are designed and installed in their auto application with out a crow bar. If you must use an IR alternator make sure the crow bar is of best design and adjusted so a false trip is unlikely. If it does POP and kill something than that is the cost of doing business with extra protection. I will not tell you about one dark and stormy night over the mountains when the crow bar blew, since that is moot and dumb emotionalism. >I've talked to Van at OSH and at several fly-ins. >You betcha. When it comes to airframes, engines and flight >controls, I am ignorant. I also don't know squat about brain >surgery or particle physics. Van's forte' is demonstrably NOT >founded in the physics and practice of fabricating electrical >systems. His "kit" drawing is 1950's C-172 in which he has >substituted a modern, IR alternator. "Ignorance" is not a >pejorative but an accurate description of demonstrable >fact. OK Bob how much as electrons changed since 1950? My guess 1950 and 2005 electrons are the same. I cant believe there is anything real bad about a 1950 Cessna with the added IR alternator. We are talking about DC circuits. Bob here is your distinguish wiring (MO) Modus Operandi: -Central Ground (excellent idea I might add) -B-lead fuse forward of firewall , connect to battery before buss** -Automotive fuse block and ATQ blade fuses -Spade connectors vs. ring -Crow bar **( Use of B-lead fuse vs. a panel CB sacrifices alternator control. Suggest the overstressed claim of noise be ignored and use a panel CB, especially if you use an IR alternator. I find it ironic Bobs technology is right out of an import car. Japanese car imports pioneered this approach to DC power distribution. The plastic fuse blocks are right out of a car. Bob likes, auto technology and wiring, but does not like the IR alternator for lack of control. Well if you use a CB for the B-lead in the panel, you have control.) Circa 1950s Cessna (and Beech / Raytheon ) probably has crazy wily-nily grounding schemes using multi point airframe grounds too much. It also probably has a big fat CB on the panel for the B-lead, which is no big deal. As far as materials I dont think Van uses 1950 wires and connectors. I am sure his kit uses new mil spec wires and modern crimped connection. HOW BAD COULD IT BE? I looked at Tony Bingelis Books and than yours, Bob. Wires are wires. DC circuits are DC circuits. We are talking about a simple DC power distribution system. You dont know Van. It is not ignorance; he just does not give a rats ass about the smallest of electrical details that will affect .0001% of his builders. If it gets the job done, than it is good enough. >Which part number? It is not my job to recommend alternators bob, but hear are some I hear has worked for RV builders: The usual suspect are Nippondenso 100211-400; (1988-85) Chevrolet Sprint 1.0L Nippondenso 100211-415; (1988-87) Chevrolet Sprint 1.0L (1995-86) Suzuki Samurai 1.3L (1989) Suzuki Sidekick 1.3L Nippondenso 100211-141, 100211-155, 100211-407; (1991-85) Toyota 4Runner, Pickup 2.4L (1985) Toyota Celica 2.4L Nippondenso 100211-203, -316, -355 >Except that we CAN design an electrical system that will >NEVER be a link in the chain of events contributing to >a catastrophe Can never say NEVER in an airplane Bob. That is the answer I expect from an electrical engineer. You can try and believe you have designed the perfect system, but there is nothing perfect. A little piece of foam destroyed the space shuttle. Apollo 13 went boom from a faulty heater. >Voltage regulators are not the issue. Alternators you >cannot control are the issue. Oh Bob Bob Bob, you love to sensationalize, you CAN control an IR alternator: First) Pull the B-lead CB or Second) Turn the master switch OFF. You have isolated the alternator. I understand what you are saying, but statistically you are myopic. The pilot is the key to safety not the engineer. Even a crap electrical system is the most reliable thing on a small plane. Loss of an alternator should not be fatal. What is a pilot doing flying IMC of mountains at night. You are a typical design engineer that feels you can control everything. I understand your engineer mentality. I dont care about a crow bar; I care about living. Dont over estimate the significance of this one item to miss the big picture. By adding this protection device you introduced another failure point. Does it justify adding it? >George, the boat sailed and you weren't on it. You have >misinterpreted my words and seem to have totally missed >the concepts of failure tolerant design. You >demonstrated a lack of understanding of many simple >You've also misstated simple facts. You've yet to demonstrate >the need for supplying folks with the most universal >concepts in the discipline being discussed. >I don't think it's helpful to offer designs that depend >on selection of a particular brand and part number of >an alternator (which you have yet to identify). Bob their you go again with the Bob-bastics and bombastic comments YOU HAVE FAILED TOO.... YOU HAVE MISSED THE POINT BOAT SAILED YOU WEREN'TT ON IT YOU LACK UNDERSTANDING OF SIMPLE IDEAS, SIR. YOUR CUSTOMERS, YOU AND VAN ARE IGNORANT On size does not fit all. I work with fail-safe Cat III landing procedures, system fault isolation manuals on transport category Jets. I am responsible for 180 min ET OP operations (long over water flights) and fully understand systems and their relation to flight safety. You think if someone does not agree they can't understand the brilliance of your crow bar or grasp the idea of redundancy or passive failure Geeeeeee. I do understand. Dont scare people with sensationalized rhetoric. That is a cheap game plan for someone who likes to be thought of as a benevolent impartial teacher and engineer. No rocket science, just basic DC circuits 101. How can you not understand that? It is not as complicated as you like people to believe. EVERY ONE KNOWS BOB CAN'T RECOMMEND THE ND ALTERNATOR. OK. YOU WIN, I AM WRONG. >Put any name on it you wish sir, but it doesn't change the >out come. Yea I have a name for it. >I'm reminded of the words of a wise philosopher who stated >"When the best-you-know-how-to-do is compromised to >Placate those who would offer anything less, only less- >than-the-best wins." Please fly your airplane in good >health but I must continue to base my recommendations on >the best I know how to do whether or not you understand >or embrace it. >There Bob . . . Well, I am reminded of two words right now myself. I am not trying to compromise your best, be placated by you or offer anyone less of anything. What does that mean anyway? It is silly. I am not offering anything. I never wanted you or need you to change your recommendations Bob. Take Care Bob ________________________________________________________________________________
Subject: Re: AeroElectric-List Digest: 6 Msgs - 08/06/05
Date: Aug 08, 2005
14, 2004) at 08/08/2005 08:06:45 AM Personally, I like the format. It opens quickly with minimal internet facilities and you can get to the pictures and free downloads from Bob if you want them. What a great deal!!!!!!!!!! Larry H. Dodge ________________________________________________________________________________
Date: Aug 08, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Just make sue the alternator has all the appropriate connections BEFORE starting the engine, and don't disconnect anything until after the engine has stopped. The way this is normally done in a car if the B lead is permanently connected to the battery and the field is switched on/off thru the ignition switch. That's why you get the red charge light come on when you first turn the ignition. This may be achieved the same way in the airplane (using Bob's Z figures) by connecting all the alternator connections to the engine side of the Master contactor, except in the case you have a means of disconnecting the whole alternator if the thing catches fire by turning off the master. By default batteries are always "ON" the alt gets connected thru the Master contactor and normally is not turned off until after the engine has stopped turning. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: Re: AeroElectric-List: Re:Real data on OVP/etc (disinterested?) --> > By using a normal procedure of manually switching the alternator ON > after starting and OFF before shut down, you forced an abrupt ON/OFF > thru the regulator. This is known to cause grief. (Read below-The IC > chip inside the alternator is a microprocessor and its internal > protections only work if it is powered during engine start and stop.) > ... ND alternators have an IC chip that provides many safety and fault > protection functions including OV protection. In fact this > microprocessor chip may have thousands of transistors VS. a > Plain-Jane external VR with 2 or 4 transistors. Therefore doing abrupt > things repeatedly stresses the chip overtime. It just was not designed > to be used like that. You got away with it for a while, but eventually > is started to fail (with out dramatic affect I might add). > I had not heard of this before. Are you saying that I should make sure the alternator is on whenever the batteries are on? -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 08, 2005
Subject: Re: New/rebuilt Alternators IGN wire
Kevin: Good Point in the event of an electrical fire you need to turn off the system, excellent point. My comment that you would not want to turn a good alternator off in-flight should be modified to include, except in the case of a fire. However I think you need to remove BAT power as well. In some kit aircraft (and GA aircraft in general) the reliance on electrical power makes turning the master BAT off impossible because the engine will quit or the cockpit instruments will blank. Serious considerations must be made when planning for an electrically dependent engine and/or instruments. The only way is a separate electrical system (at least a battery) that drives the min critical items. How you parallel them (diode) is addressed in Bob's book. Electrical fire is one of the more serious checklist on a jet liner and the SwissAir tragedy illustrates how serious it can be. There are many many buss on a Jet. The checklist calls for you to manually turn off all less critical buss-es off (utility bus), after you put on O2 mask and goggles. That still does not mean the electrical fire will be extinguished, since items are still powered, especially in the cockpit. Than if needed you are told to FIND the source and pull individual breakers. Lets just say you pray you never have this situation. I don't know how many breakers I would get pulled, since I would be on the ground ASAP. In theory you could turn everything off (AC GENS) and fly on BAT power only, which means one stand-by AI (w/ loc/gs needles), AS and ALT, Radio/Nav, cockpit dome light and electric controls. All glass would be dead (unless you buy an option with extra batteries to keep the captains glass lit). Thanks George From: Kevin Horton <khorton01(at)rogers.com> Subject: Re: AeroElectric-List: Re: New/rebuilt Alternators IGN wire (Was: real data on ovp/etc) The only way to remove all electrical power in most archetures is to shut down the alternator and open the battery contactor. Even if you aren't worried about an OV event, you should consider the smoke in the cockpit case, as it could kill you, even if you are flying VFR. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 --------------------------------- ________________________________________________________________________________
Date: Aug 08, 2005
Subject: Rotax
I am interested in creating an electrical system for a Rotax 503 points ignition single carb engine. What changes from the system described on this list, would be required. The aircraft will be an open type aircraft so weatherproofing is important as well. Bill Czygan ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Subject: Headset/Microphone jack bushings
Date: Aug 08, 2005
Dear List: It seems that the jacks supplied with my intercom came without the flanged insulating bushings needed to ensure isolation from the metal airframe. Can someone suggest a source? John ________________________________________________________________________________
Subject: Re: Headset/Microphone jack bushings
Date: Aug 08, 2005
I found a source and had to order 100. Send a prepaid envelope and I will slip as many as you need and return to you. Wayne Sweet 1520 Salinas Highway Monterey, Ca 93940 Oh, put a note to remind me what you need. I am a bit forgetful. ----- Original Message ----- From: "John Swartout" <jgswartout(at)earthlink.net> Subject: AeroElectric-List: Headset/Microphone jack bushings > > > Dear List: > > > It seems that the jacks supplied with my intercom came without the > flanged insulating bushings needed to ensure isolation from the metal > airframe. Can someone suggest a source? > > > John > > > ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Re: Alternators
Hi Dean Were the OV events that you mentioned with an internal regulator alternator? If so that might answer your question. As far as I'm concerned, I've seen nothing but anecdotal evidence of the risk from using an IR alternator. It may be extremely low and entirely acceptable but so far all I've seen is anecdotal "proof" of that. I've long ago learned that even though no one is yelling about their ND (nippondenso) overvoltage failures - it tells me little about how often such an event occurrs. There are a lot of folks making their living out of replacing ND alternators so we do know they fail in one manner or another. I don't recall any data being presented for inside the warranty period let alone outside the warranty period. Unfortunately I've seen a lot of grief in aviation caused by embracing new technology because it was available rather than because there was any need for it or demonstrated safety improvements from it. I no longer assume that something newer is better. I do agree that a modern IR alternator seems to be more reliable than a lot of the old external regulators. Personally I'd be comfortable with an IR alternator if I had a non electrically dependant engine AND an OVM module of some kind protecting the supply to that $15k radio rack that you mentioned. Someone pointed out that Jim Weir talks about that approach with guess what - a crowbar OVM. As it happens my engine is electrically dependant and my main alternator is an IR unit with the crowbar OVP and disconnect contactor - but I have redundancy powered by a second electrical system and very little avionics. Ken DEAN PSIROPOULOS wrote: > >Ok GMCJET, Eric and Paul: > >You all seem to eluding to something just as good or better than what Bob >has to offer with his externally regulated alternator and OVP. GREAT, why >don't each of you explain your COMPLETE configurations (IN PLAIN ENGLISH) >here on this list. That way, builders who are deep into the wiring stage can >make up their minds and maybe save a little money? I'm currently in that >stage and have been following this thread for a LONGGGGGG TIME hoping that >SOMEONE would produce the new cheaper, better, simpler solution for the >externally regulated and controlled alternator with OVP. I returned the IR >alternator that Van's supplied with my firewall forward kit because of >threads on this list. So far I haven't really heard anything that makes me >want to buy it back. > >I HAVE TO DECIDE very soon now whether to go ahead with my decision to buy a >B&C alternator and ER with OVP like I changed my mind to do. Do I WANT to >spend $800 dollars for these two very common items that can be had in any >autoparts store for hundreds less?! Hell no! I'd rather spend 1/3 that much >and use the rest for avgas on my upcoming first flight. But this little bug >keeps nagging at me and I don't want a runaway alternator taking out the >$15,000.00 worth of electronic equipment in my panel (even if it is DO-160 >certified). I know it happens only rarely but it DOES happen. I personally >know of people who've had this occur in both aircraft and automobiles. All >cases resulted in massive amounts of smoke behind the panel and expensive >repair bills. > > snip ________________________________________________________________________________
Date: Aug 09, 2005
Ok--the envelope is in the mail. THANK YOU! -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wayne Sweet Subject: Re: AeroElectric-List: Headset/Microphone jack bushings I found a source and had to order 100. Send a prepaid envelope and I will slip as many as you need and return to you. Wayne Sweet 1520 Salinas Highway Monterey, Ca 93940 Oh, put a note to remind me what you need. I am a bit forgetful. ----- Original Message ----- From: "John Swartout" <jgswartout(at)earthlink.net> Subject: AeroElectric-List: Headset/Microphone jack bushings > > > Dear List: > > > It seems that the jacks supplied with my intercom came without the > flanged insulating bushings needed to ensure isolation from the metal > airframe. Can someone suggest a source? > > > John > > > ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Plane-Power Alternator at OSH
Did anyone else see the Plane-Power booth at OSH, right next to Sky-Tec and not too far from B&C? http://www.plane-power.com/ I spent some time looking at their alternators, and was impressed enough that I signed up to hold show pricing when they're available, and so I can take time to learn more. They had a 70A FAA/PMA approved external regulated model, and a 60 and 70A internally regulated model, with OV protection (using the crowbar method). The price was right, and at least physicially I didn't see any issue. It was also interesting to hear that they went for full FAA/PMA approval on their alternator before they released any experimental alternators. I want to learn more about their OV module, as I'd have to assume that in order for them to put out this product, they must have done some testing to know what kind of failure damage is caused when the OV module trips. I didn't get enough time to gather my thoughts and ask every question I wanted...hoped maybe someone here could fill in some blanks. Also, they say that by next year, they want to have available an aux. alternator. I'm guessing that if I'm willing to delay that purchase, I could add it later and the total cost of my system would be WELL under 1/2 of my original plans. Their web page is still being built up, but here's a link to the 60A model. http://www.plane-power.com/AL12-EI60.htm Comments? -- Tim Olson -- RV-10 ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Alternative Engines - Geo/Suzuki
Alternative Engines - Geo/Suzuki If you are interested in alternative engines for experimental aircraft you are invited to join the flyGeo_uncensored group and learn about the fantastic Geo/Suzuki engines used in aircraft. http://groups.yahoo.com/group/FlyGeo_uncensored Both bolt on gearbox and cog belt redrives and all other aircraft conversion parts are available for very reasonable cost. Turbo versions are available also. Gearbox type redrives for around US$1750- The Geo/Suzuki engine uses about half the fuel that the two stroke engines use. The 1.3 litre four cylinder Suzuki engine beats the Rotax 912 in power and weight, again both gearbox and belt type redrives are available. The Geo/Suzuki one litre engine weighs a little more than a Rotax 582, it produces 62 HP normally aspirated but with a better, flatter torque curve. All those advantages plus flying engines with the hours up to prove them and last but not lease, far, far cheaper than a Rotax two or four stroke engine. One person on the group has over 1000 hours on one installation. FlyGeo_uncensored is a very active and helpful group that is also a fun group and is not doubt one of the fastest growing aircraft alternative engine groups. http://groups.yahoo.com/group/FlyGeo_uncensored The FlyGeo_uncensored Management ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Alternator system design goals . . .
I thought it would be useful to recap the thought processes behind the writings I've done concerning installation of alternators (and generators) on airplanes. In particular, I'll share thinking on the internally regulated alternator and try to show how we got to where we are today: Old History: From day-one, all power sources in aircraft have been controllable by the pilot from the cockpit. Without going into all the reasons old, new, come and gone, I think it's sufficient for this discussion to suggest that it's an operating mode we're all familiar with. We expect to see it in a certified ship. We were taught how to use these features both in normal and abnormal operating conditions. Recent History: For the first 8 or so revisions of the 'Connection, the writings in chapters on alternators, ov protection, and regulators cited what we knew and were currently using in certified aviation, and by default, a majority of OBAM aviation as well. A few folks at the leading edge of the OBAM aviation effort were installing automotive take-offs which offered the siren call of inexpensive, simple, light, readily available, etc, etc. However, in order to utilize these products, it was the builder's responsibility to assess suitability to task which includes questions like: (1) Does this work exactly like the system I am replacing? (2) What features of the current paradigm must I have to give up and are these trade offs acceptable? If acceptable to me, how about the guy who's going to buy my airplane someday? (3) Are there features unique to this system that require changes to system integration, operating procedures, and maintenance? Are these acceptable both to me and any future owners of this aircraft? (4) Are there any new cost of ownership considerations? (5) Does the new system have any new or shared risks with the old system? This list may not be all inclusive but it's the lion's share of considerations in play when I crafted the first version of Figure Z-24 in the 'Connection. The goal was to offer the builder a drop-in, plug-n-play substitution of an old design philosophy with a new one. The reasoning was that Figure Z-24 would directly substitute an IR alternators for the alternator/ regulator/ovp suite of components in any of the preceding architectures. For folks who wanted, could afford and appreciated the value of working with suppliers of the old technology, then configure as shown in the base drawing. If you wanted to substitute the more modern approach without giving up ANY of the features shown in the un-modified Z-figure, then Z-24 suggested a means for doing that. The Cabbage Patch: Now comes the mud puddles that were impossible to avoid stepping in. While virtually all combinations of ov protection, alternator regulators, and externally regulated alternators could be mixed/matched pretty much at will we find that not all internally regulated alternators were the same. New issues of pedigree for regulators were suggested. Some builders demonstrated a vulnerability these alternators had for being victim to their own load-dump responses just because they were turned off under load. Some alternators could be controlled ON/OFF by means of the control wire, others were Once ON, Always ON. Some folks jumped on the "evil ov protection scheme" band wagon and elected to ignore the fact that risks were the same whether the alternator was shut off (1) manually, (2) in response to a real ov event, or (3) in response to a nuisance trip of the ov protection system IRRESPECTIVE OF THE STYLE of that protection. Others suggested a degree of incompetence for anyone who even suggested that their favorite IR alternator was capable of presenting an OV event while ignoring my special obligation as author of The Book to publish the most universal solutions that met MY design goals for no change of paradigm. In the barroom brawl that ensued, folks came forward with all manner of rational for approaching the problem "differently" re-enforced with plenty of tomatoes and cabbages lobbed into the discussions that ran far afield - basically ignoring the goals cited above which MINIMIZED the shift from historical features which allowed us to: (1) Have absolute control of all power sources in the airplane (2) Be able to switch sources on/off at will at any time without regard to component safety. (3) When there were issues of switching sequence, pilots were relieved of responsibility for proper sequence by inclusion of the progressive transfer DC master (2-10) or classic split-rocker master switches. As I view the task before us now, may I suggest it can be very simply expressed as follows: (1) Are we truly interested in crafting an IR alternator installation that fits the time honored paradigm for absolute control with minimized risk for inadvertent operation of switches or worst case failures of any kind in the alternator? If the answer is "yes" then proceed to item 2. If the answer is "no", then by all means, embrace suggestions offered by the most persuasive proponents of alternative solutions. (2) There is an issue for at least some if not all IR alternators being at-risk of damage due to b-lead disconnection under load. This has several several partial solutions: (a) Placard the switch for no operation with the engine running. This means the only time the alternator would be subject to the load-dump event was during a real ov event where disconnect was necessary and protecting an already failed alternator from further damage is a moot point. (b) Add some measure of load-dump energy sink in the form of "xxxx" . . . this might be an array of Transorbs but they require sizing in very universal sense. If I put Z-24 back in the book with transorbs across the b-lead connection, I need to be convinced that this solution is good for 99+ percent of all IR alternators from which a builder might choose, INCLUDING those fitted with non-OEM regulators. (c) If (b) can be accomplished, then the prohibition cited in (a) could be lifted as well. Data concerning the nature of load-dumps was what I thought Paul was going to investigate for us some time ago. After the "investigation" was complete, no data was forthcoming, only more cabbages and tomatoes. (3) There is risk to any form of b-lead disconnect technology to deal with the OV event. An alternator running at 10,000+ rpm has a rate-of-rise for open circuit voltage that's spectacular. As contacts spread on the rudimentary control contactor, it's possible (Paul says he's demonstrated it) that an arc will form and not go out. There are a couple of trade offs here too: (a) If an energy-sink for the load-dump event can be crafted as in 2(b), then the rudimentary contactor is not at-risk for normal ON/OFF switching events. The energy-sink would protect both the internal regulator and the external control contactor from undue stresses. (b) if the energy-sink were in place, then the alternator's output voltage would be limited by the energy-sink long enough for any jelly-bean contactor to open relatively free of arcing. After a period of time, one would then be DELIGHTED if the current sink FAILED SHORTED. This (ugh!) crow-baring of the b-lead to ground would deprive the alternator of self-excitation and stall it. The event would be over in a few seconds with high probability that the alternator need only have a new regulator installed. (c) One could install a contactor suited to the high-voltage stress of the runaway alternator (killovac) and simply allow the alternator to smoke its own field winding. At least the OV event was prevented from propagating to the rest of the airplane. (4) Finally comes the issue of whether or not to install OV protection: (a) If you have a lot of faith in your alternator of choice, then leave it off. You could install a high-voltage warning light and depend on a well maintained battery to keep bus votlage reasonably low (below 18v) long enough to react and shut the alternator OFF. It would help if energy sink 3(a) were in place to allow you to open the plain vanilla contactor. Hopefully, the energy-sink system will fail shorted and bring the whole event to a happy conclusion. By the way folks, this is yet another form of (ugh!) crowbar ov-protection . . . a system DESIGNED to put a dead short on a line that needs to be pulled down. (b) If you choose to add ov protection, it's easily accomplished with any number of products including the OVM-14 crowbar module offered by B&C, Eric's passive series switch design, etc. It doesn't matter. Any of these technologies are subject to system integration issues manifested by nuisance trips which may require some attention on the part of the OV module supplier. Okay, these are the ground rules for any solution I plan to publish. The solution must come very close to meeting all the design goals for staying within the historical paradigm (but using modern components) that I cited at the outset of this posting. I am not going to publish any suggestion that there's a "golden" alternator or "golden contactor", etc that will make this task easier. Offering such a limited solution will get me a flood of e-mails and phone calls asking, "Gee, I have this xxx alternator or yyy contactor, can you tell me how to make it work too?" The new figure Z-24 needs to accommodate ANY alternator, and any contactor one might wish to use. The answers to some of these questions still depend on access to equipment I don't own but plan to. I'll invite anyone who would like to participate (and perhaps even become a member of the Hall of Fame) to post their offerings right here on the list. We can all work together to craft test plans, provide necessary materials and test equipment (hell, I'll mail my pride-n-joy 'scope to someone who's adding to the collective knowledge), and assistance in analysis of results with possible changes to future tests. Folks have suggested that my reluctance to recommend their particular vision of the ultimate solution was in fact an under-the-table condemnation of their solution. I hope the foregoing discussion adequately dispels that notion. It's been further suggested that I lack rudimentary skills necessary for component design, system integration, failure mode effects analysis, program management and delivery of honorable services to a customer. Well, my answer is this: The AeroElectric-List studies of Internally Regulated Alternator Integration in Light Aircraft is open for enrollment. You may "audit" the class and simply watch what transpires, you may participate with suggestions and questions that move the effort forward and contribute to collective understanding, or you may be an active participant in the much reviled Repeatable Experiments by which we will show that the products of our imaginations have a rightful place in the real world of OBAM aircraft. Cabbage and tomato tossers need not apply. If you want to play too, leave the vegetables at home. Let's begin with a requirements document. I'll formalize the elements cited above into the opening paragraphs of the requirements document. We can start thrashing from there. Any suggestions? Did I miss anything? Got some ideas for enhancements? Class is in session. Question 1: Does anyone within a one-fuel tank range in a Sundowner have access to a 2 hp or better, variable speed drive stand capable of running an alternator with 2" pulley over the range of 3000-11,000 rpm? Bob . . . ________________________________________________________________________________
From: "Dave & Brenda Emond" <d_emond(at)mweb.co.za>
Subject: Re: Plane-Power Alternator at OSH
Date: Aug 09, 2005
I did see that LAMAR Technologies has a Master Control unit available to experimentals. OVP, VR, three buses, external power. This unit is apparently std equip in all new Cessna's. Dave Emond 40159 ----- Original Message ----- From: "Tim Olson" <Tim(at)MyRV10.com> Subject: AeroElectric-List: Plane-Power Alternator at OSH > > Did anyone else see the Plane-Power booth at OSH, right next to > Sky-Tec and not too far from B&C? > > http://www.plane-power.com/ > > I spent some time looking at their alternators, and was > impressed enough that I signed up to hold show pricing > when they're available, and so I can take time to learn > more. > > They had a 70A FAA/PMA approved external regulated > model, and a 60 and 70A internally regulated model, > with OV protection (using the crowbar method). The > price was right, and at least physicially I didn't see > any issue. It was also interesting to hear that they > went for full FAA/PMA approval on their alternator > before they released any experimental alternators. > > I want to learn more about their OV module, as I'd > have to assume that in order for them to put out this > product, they must have done some testing to know what > kind of failure damage is caused when the OV module trips. > I didn't get enough time to gather my thoughts and ask > every question I wanted...hoped maybe someone here could > fill in some blanks. > > Also, they say that by next year, they want to have > available an aux. alternator. I'm guessing that if I'm > willing to delay that purchase, I could add it later > and the total cost of my system would be WELL under > 1/2 of my original plans. > > Their web page is still being built up, but here's a link > to the 60A model. http://www.plane-power.com/AL12-EI60.htm > > Comments? > > -- > Tim Olson -- RV-10 > > > ________________________________________________________________________________
Subject: Re: Audio Isolation Amp
Date: Aug 09, 2005
I have some questions regarding Bob's Audio Isolation Amp project... Before getting into specifics, let me first ask a go-no go question: I am looking for a "box" that will accept five mono inputs, and give one mono output. It would be used to mix the outputs of two COMs plus the alarms from some avionics devices, with the output to be fed to the COM input on an intercom. Is this feasible? Now to some specific questions, assuming that what I am proposing is feasible: On the Parts List (Page 1.2), I notice that it refers to a: 9009-100-2 ECB ASSY - MONO ISO AMP DIY FAB and a: 9009-100-1 ECB ASSY - STEREO ISO AMP DIY FAB On the web site, the following product is listed: AEC9009-301-1. Which of the above part numbers does this correlate to? In comparing the SCHEMATIC - STEREO (Page 1.7) and the SCHEMATIC - MONOPHONIC (Page 1.8), it appears that you can just build "half" the amp, jumper Pins 2 and 3 where U114 would be, and use this as a mono unit. Is this correct? Would it be necessary to cut any of the traces on the circuit board? If yes, where? From NOTE 6. RESISTORS R103 THROUGH R107 ARE SELECTED TO EQUALIZE VOLUME LEVELS BETWEEN AUDIO SOURCES. Could these be replaced with some type of screwdriver adjustable pot to make it easier to balance the levels? If so, what type/value/etc pot would be correct for this application? Could these pots be mounted on the case so they would be externally adjustable? Please feel free to add any additional information that I might have missed, and thank you! ________________________________________________________________________________
Date: Aug 09, 2005
Subject: Re: Alternator system design goals . . .
Seems like a pretty good summary! From my wishful thinking list, I'd also be happy if it could be shown that a transorb array connected to the alternator output post would short out sufficiently hard to cause battery current to trip a B-lead fuse once a serious alternator runaway started. (ie. no B-lead contactor needed). Or I would be happy to cough up for a kilovac contactor if I was convinced that is what it takes to reliably tame an OV. That might be an acceptable fallback position for many folks. Ken >snip >(4) Finally comes the issue of whether or not to install OV > protection: > > (a) If you have a lot of faith in your alternator of > choice, then leave it off. You could install a high-voltage > warning light and depend on a well maintained battery to > keep bus votlage reasonably low (below 18v) long enough > to react and shut the alternator OFF. It would help > if energy sink 3(a) were in place to allow you to open > the plain vanilla contactor. Hopefully, the energy-sink > system will fail shorted and bring the whole event to > a happy conclusion. By the way folks, this is yet another > form of (ugh!) crowbar ov-protection . . . a system > DESIGNED to put a dead short on a line that needs to > be pulled down. > > ________________________________________________________________________________
Date: Aug 10, 2005
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Apology
Eric is correct, my rant yesterday was a cheap-shot and I apologize. When I started the rant my desire was to hopefully, motivate some people into consolidating everything that has been said into a clear concise description that we could all use. My excursion into Eric's business dealings was uncalled for. One MIGHT infer from my comments that Mr. Jones is a dishonorable person when in fact I have no evidence of that. I have never dealt with the man on a business level. I INFERRED, (from comments made on this list AND a request from Eric for the Wig Wag circuit design) that he was capitalizing on other people's work and selling it as his own. I do NOT for a fact, know this to be the case. Even if that were the case, it's not illegal as long as the design data resides in the public domain or has expired patents. If you are considering a purchase from him please don't go somewhere else because of a few off-the-cuff comments I made on this list. Talk to other people who have had dealings with the man and find out what sort of business person he is. Then.MAKE YOUR OWN DECISION! And finally.I'd like to apologize to the listers, instead of providing constructive discourse, I opened my mouth and inserted my size 10 Nikes. In the future I'll stick to technical questions and answers and not get caught up in the "Venom Spewing". And yes Eric, I will cease and decist from using YOUR NAME in MY POSTS from now on. Dean Psiropoulos RV-6A builder and occasional Nike chewer -----Original Message----- From: Eric M. Jones [mailto:emjones(at)charter.net] Subject: Re: Alternators, OVP, GMCJET, Eric, Paul. OFFLIST Dean, I am trying to stay out of the innuendo and personal attacks on the Aeroelectric List. You personally attacked me and I think you owe me an apology. I don't think I did anything to merit your venom. Please leave my name out of your posts on the Aeroelectric. If you have some personal problem with me, please call. Regards, Eric M. Jones www.PerihelionDesign.com ________________________________________________________________________________
Date: Aug 10, 2005
Subject: Re: Painting Antenae
Anyone have advice on repainting a ADF loop antenna. GPS, marker beacon and fiberglass comm antenna should also be able to be rejuvenated, yes?? no??. Thanks, George in Langley BC ________________________________________________________________________________
Date: Aug 10, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Z-13/20
> > >Bob..., > >I'm building an RV-10 and started planning on using the Z-12 >architecture but I changed to Z-13/20 when it came out recently. Is it >okay to use a B&C SB-1 standby regulator and a LR-3 instead of the >two LR-3's shown in Z-13? The SB-1 is specifically designed to autoswitch an auxiliary alternator running on a common bus with the main alternator. It's special features are not needed in Z-13/20. >With the battery behind the baggage compartment, I am running a 10awg >wire for the battery buss alongside a 2awg for the alternator B lead. > Is this a violation of not running fat and skinny wires together? Is >there a guideline using the difference of awg of the wires that would help >keep the fat >wires away from the skinny wires? For example, if the difference in >the awg sizes of the two wires is greater than 10awg sizes don't >bundled them together. Battery bus? Your battery bus is NOT right beside the battery? Note the asterisk (*) on the wire segment between the battery and any of the battery busses in Appendix Z. This symbol indicates that these wires should be kept as short as practical because they're major feeders and always hot. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> >Seems like a pretty good summary! > > From my wishful thinking list, I'd also be happy if it could be shown >that a transorb array connected to the alternator output post would >short out sufficiently hard to cause battery current to trip a B-lead >fuse once a serious alternator runaway started. (ie. no B-lead contactor >needed). Crowbaring the b-lead circuit protection (70A breaker/ANL limiter) WOULD be a MAJOR event. The fusing constants for these devices is large. However, in the early days of consideration for on-the-firewall b-lead protection, the ANL hardware was set aside in favor of some fast fuses suitable for bolting into the b-lead. See: http://www.aeroelectric.com/Pictures/70-80fusekit.jpg These fuses are quite fast . . . a feature that stirred up a bit of a kerfuffle about 6 years ago on some list-server. See: http://aeroelectric.com/articles/failtoll.pdf I have pondered the hardware and energy studies for crowbaring the b-lead of an IR alternator and opening a fast fuse. Actually, the neatest way (lowest parts count) to run the IR alternator would be to add a diode in series with the alternator's output and crowbar the alternator itself to ground without loading the ship's bus. The lights wouldn't even flicker. Problem is that adding the diode tosses off .5 to 1 volt of output. The voltage regulator inside the alternator senses b-lead voltage, not control lead voltage. Adding the diode would increment the bus voltage downward and degrade battery recharging capability. If the designers had only brought out a bus-sense terminal from the internal regulator, this would be a no-brainer! The modern IR alternator is a tantalizing challenge for doing the most graceful system integration within the design goals I've set for myself. >Or I would be happy to cough up for a kilovac contactor if I was >convinced that is what it takes to reliably tame an OV. That might be >an acceptable fallback position for many folks. I am confident that this will not be necessary. There are numerous tradeoffs to be discovered and weighed against each other. It's going to take some time. In the mean time, anyone with Figure Z-24 installed is encouraged to leave it in place for the moment. Don't switch the alternator OFF with the engine running except in case of problems. If you have a system that talks to an OVM-14 crowbar module in ways that irritate it . . . PLEASE let me know about it. We need the feedback and we WILL fix all problems or give you your money back or both. I am reminded of some classroom challenges to deduce the network of components inside a plastic box with two leadwires coming out. You could use any manner of test equipment to figure out what was inside and how it was wired up. Our little IR alternator is a three-lead device we cannot open and modify. They don't all work the same way. The goal is to deduce a universal, minimum parts count, maximum energy efficient way to make them do electrical form-fit-function replacement of the machines we grew up with. An interesting and doable endeavor, we just need DATA. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> >I have some questions regarding Bob's Audio Isolation Amp project... > >Before getting into specifics, let me first ask a go-no go question: > >I am looking for a "box" that will accept five mono inputs, and give one >mono output. It would be used to mix the outputs of two COMs plus the alarms >from some avionics devices, with the output to be fed to the COM input on an >intercom. > >Is this feasible? Yes . . . >Now to some specific questions, assuming that what I am proposing is >feasible: > >On the Parts List (Page 1.2), I notice that it refers to a: > > 9009-100-2 ECB ASSY - MONO ISO > AMP DIY FAB > >and a: > > 9009-100-1 ECB ASSY - STEREO ISO > AMP DIY FAB > >On the web site, the following product is listed: AEC9009-301-1. Which of >the above part numbers does this correlate to? Both. The 9009-300-1 ECB (item 1) is called out for both versions of the isolation amplifier. >In comparing the SCHEMATIC - STEREO (Page 1.7) and the SCHEMATIC - >MONOPHONIC (Page 1.8), it appears that you can just build "half" the amp, >jumper Pins 2 and 3 where U114 would be, and use this as a mono unit. Is >this correct? yes >Would it be necessary to cut any of the traces on the circuit board? If yes, >where? no, if it were necessary, the instructions would be very specific as to where. > From NOTE 6. RESISTORS R103 THROUGH R107 ARE SELECTED TO EQUALIZE VOLUME >LEVELS BETWEEN AUDIO SOURCES. Could these be replaced with some type of >screwdriver adjustable pot to make it easier to balance the levels? If so, >what type/value/etc pot would be correct for this application? Could these >pots be mounted on the case so they would be externally adjustable? You could. Some folks do use pot in their iso-amp products/designs. The fixed resistors are much less expensive and more compact. I would have to go to a larger box and I couldn't run the boards 2-up in the fab process I'm using. Once the values are selected, they're constant over the lifetime of the airplane. It's more fuss to set it up but it won't need to be fiddled with again. ________________________________________________________________________________
Date: Aug 10, 2005
I'm a little confused here. Every IR alternator I have seen in my hot rod days had a voltage sensing terminal. In my ND unit this is called the "s" terminal and is normally wired to account for losses in the wiring (Van's doesn't use this terminal in their standard setup) Would this not take care of the forward loss thru the diode? Crowbarring a 60A nominal alternator just feels little too "Robocop" for an airplane application for me... Think I might stick with the Kilovolt disconnect for the time being. Gee maybe I could write a PHD theses on the phsychology of wiring systems in aircraft...:) Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Alternator system design goals . . . --> > >Seems like a pretty good summary! > > From my wishful thinking list, I'd also be happy if it could be shown >that a transorb array connected to the alternator output post would >short out sufficiently hard to cause battery current to trip a B-lead >fuse once a serious alternator runaway started. (ie. no B-lead >contactor needed). Crowbaring the b-lead circuit protection (70A breaker/ANL limiter) WOULD be a MAJOR event. The fusing constants for these devices is large. However, in the early days of consideration for on-the-firewall b-lead protection, the ANL hardware was set aside in favor of some fast fuses suitable for bolting into the b-lead. See: http://www.aeroelectric.com/Pictures/70-80fusekit.jpg These fuses are quite fast . . . a feature that stirred up a bit of a kerfuffle about 6 years ago on some list-server. See: http://aeroelectric.com/articles/failtoll.pdf I have pondered the hardware and energy studies for crowbaring the b-lead of an IR alternator and opening a fast fuse. Actually, the neatest way (lowest parts count) to run the IR alternator would be to add a diode in series with the alternator's output and crowbar the alternator itself to ground without loading the ship's bus. The lights wouldn't even flicker. Problem is that adding the diode tosses off .5 to 1 volt of output. The voltage regulator inside the alternator senses b-lead voltage, not control lead voltage. Adding the diode would increment the bus voltage downward and degrade battery recharging capability. If the designers had only brought out a bus-sense terminal from the internal regulator, this would be a no-brainer! The modern IR alternator is a tantalizing challenge for doing the most graceful system integration within the design goals I've set for myself. >Or I would be happy to cough up for a kilovac contactor if I was >convinced that is what it takes to reliably tame an OV. That might be >an acceptable fallback position for many folks. I am confident that this will not be necessary. There are numerous tradeoffs to be discovered and weighed against each other. It's going to take some time. In the mean time, anyone with Figure Z-24 installed is encouraged to leave it in place for the moment. Don't switch the alternator OFF with the engine running except in case of problems. If you have a system that talks to an OVM-14 crowbar module in ways that irritate it . . . PLEASE let me know about it. We need the feedback and we WILL fix all problems or give you your money back or both. I am reminded of some classroom challenges to deduce the network of components inside a plastic box with two leadwires coming out. You could use any manner of test equipment to figure out what was inside and how it was wired up. Our little IR alternator is a three-lead device we cannot open and modify. They don't all work the same way. The goal is to deduce a universal, minimum parts count, maximum energy efficient way to make them do electrical form-fit-function replacement of the machines we grew up with. An interesting and doable endeavor, we just need DATA. Bob . . . ________________________________________________________________________________
July 30, 2005 - August 10, 2005
AeroElectric-Archive.digest.vol-er
