AeroElectric-Archive.digest.vol-es
August 10, 2005 - August 22, 2005
Date: Aug 10, 2005
Subject: Re: Alternator system design goals . . .
Hinde, Frank George (Corvallis) wrote: > >I'm a little confused here. > >Every IR alternator I have seen in my hot rod days had a voltage sensing >terminal. In my ND unit this is called the "s" terminal and is normally >wired to account for losses in the wiring (Van's doesn't use this >terminal in their standard setup) > >Would this not take care of the forward loss thru the diode? > > The ones I've played with do not have a sense terminal. If a sense wire became disconnected it would result in high output so I think the heavy and presumably more secure B-lead connection is normally used for sensing. >Crowbarring a 60A nominal alternator just feels little too "Robocop" for >an airplane application for me... Think I might stick with the Kilovolt >disconnect for the time being. > > If you can crowbar it you may be able to shut it down (stall it) and prevent further internal alternator damage. Some alternators start up just fine without being connected to a battery though so I'm not sure how universal such an approach would be. If you just open the B-lead then apparently some melting may occur within the alternator which presumably could have at least some risk of causing problems (fire?) outside the alternator. As the voltage continues to rise more field current flows which causes higher voltage which causes more field current etc. until something gives... I think I should do some destructive alternator testing before I send my next old car to the wreckers ;) Ken ________________________________________________________________________________
Subject: Alternator system design goals . . .
Date: Aug 10, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Sounds like fun...On the ground..:) Eric also sells a what he calls a "whackjack" (which I have installed) As I understand it this is some kind of zener diode the shorts the output of the disconnected B lead to ground (it is also sacrificed during this process), (I'm a mechanical engineer so forgive my flaky description). I have set up my #1 alt to have the OV and field wiring switched thru a DPDT switch (normally never turned off). The idea is if it goes OV I can shut the field down too, that way I have no weired back feeding via the alt field wiring. Hoping I should be able to react before any fires get started...:) The rest of it is then normal power management, master off... Alternate feed on, prayers of encouragement towards the SD-8 etc...:) Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Subject: Re: AeroElectric-List: Alternator system design goals . . . Hinde, Frank George (Corvallis) wrote: >--> (Corvallis)" > >I'm a little confused here. > >Every IR alternator I have seen in my hot rod days had a voltage >sensing terminal. In my ND unit this is called the "s" terminal and is >normally wired to account for losses in the wiring (Van's doesn't use >this terminal in their standard setup) > >Would this not take care of the forward loss thru the diode? > > The ones I've played with do not have a sense terminal. If a sense wire became disconnected it would result in high output so I think the heavy and presumably more secure B-lead connection is normally used for sensing. >Crowbarring a 60A nominal alternator just feels little too "Robocop" >for an airplane application for me... Think I might stick with the >Kilovolt disconnect for the time being. > > If you can crowbar it you may be able to shut it down (stall it) and prevent further internal alternator damage. Some alternators start up just fine without being connected to a battery though so I'm not sure how universal such an approach would be. If you just open the B-lead then apparently some melting may occur within the alternator which presumably could have at least some risk of causing problems (fire?) outside the alternator. As the voltage continues to rise more field current flows which causes higher voltage which causes more field current etc. until something gives... I think I should do some destructive alternator testing before I send my next old car to the wreckers ;) Ken ________________________________________________________________________________
Date: Aug 10, 2005
Hinde, Frank George (Corvallis) wrote: > >Sounds like fun...On the ground..:) > >Eric also sells a what he calls a "whackjack" (which I have installed) >As I understand it this is some kind of zener diode the shorts the >output of the disconnected B lead to ground (it is also sacrificed >during this process), (I'm a mechanical engineer so forgive my flaky >description). > >I have set up my #1 alt to have the OV and field wiring switched thru a >DPDT switch (normally never turned off). The idea is if it goes OV I can >shut the field down too, that way I have no weired back feeding via the >alt field wiring. Hoping I should be able to react before any fires get >started...:) > Frank I lost you here. That sounds like an external regulator that you can turn the field off. There is no issue or concerns if that is the case as that kills the alternator completely. But if in fact you have an internal regulator then you can't turn off the field as it is connected internally within the alternator. It is only with the internal regulator that you would use a B-lead contactor. It is only with an internal regulator that you'd consider trying to crowbar the alternator output to stall it. In my previous post I was strictly talking about internal regulated alternators. Ken ________________________________________________________________________________
From: "Leo Corbalis" <leocorbalis(at)sbcglobal.net>
Subject: Re: Painting Antenae
Date: Aug 10, 2005
If your ADF loop is in black streamlined housing. do NOT paint it. The manufacturer might have some special paint. The black plastic is a static shield. I'll save the WAR story but it is real. Try your paint on a piece of paper and then cover the GPS antenna with it to see if the receiver gives you an OK on the satellite signal strength page. Leo Corbalis ----- Original Message ----- From: "GMC" <gmcnutt(at)shaw.ca> Subject: AeroElectric-List: Re: Painting Antenae > > > Anyone have advice on repainting a ADF loop antenna. GPS, marker beacon > and fiberglass comm antenna should also be able to be rejuvenated, yes?? > no??. > > Thanks, > > George in Langley BC > > > ________________________________________________________________________________
Date: Aug 10, 2005
Actually so was I...i do have an IR alt...But there is still a field wire that I am disconnecting if it goes OV toghter with the Kilovolt opening and the alt B lead shorted to ground via the whackjack suppressor. Did'nt realise the field was connected internally as well?...Hopefully the whackjack will pull it down without it bursting into flames?????? Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Subject: Re: AeroElectric-List: Alternator system design goals . . . Hinde, Frank George (Corvallis) wrote: >--> (Corvallis)" > >Sounds like fun...On the ground..:) > >Eric also sells a what he calls a "whackjack" (which I have installed) >As I understand it this is some kind of zener diode the shorts the >output of the disconnected B lead to ground (it is also sacrificed >during this process), (I'm a mechanical engineer so forgive my flaky >description). > >I have set up my #1 alt to have the OV and field wiring switched thru a >DPDT switch (normally never turned off). The idea is if it goes OV I >can shut the field down too, that way I have no weired back feeding via >the alt field wiring. Hoping I should be able to react before any fires >get >started...:) > Frank I lost you here. That sounds like an external regulator that you can turn the field off. There is no issue or concerns if that is the case as that kills the alternator completely. But if in fact you have an internal regulator then you can't turn off the field as it is connected internally within the alternator. It is only with the internal regulator that you would use a B-lead contactor. It is only with an internal regulator that you'd consider trying to crowbar the alternator output to stall it. In my previous post I was strictly talking about internal regulated alternators. Ken ________________________________________________________________________________
Date: Aug 10, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> > >I'm a little confused here. > >Every IR alternator I have seen in my hot rod days had a voltage sensing >terminal. In my ND unit this is called the "s" terminal and is normally >wired to account for losses in the wiring (Van's doesn't use this >terminal in their standard setup) > >Would this not take care of the forward loss thru the diode? Don't know but it's an exciting prospect. Do you have any documentation that describes functionality of this pin? If sense pins are left open on some designs, the system either shuts down or the regulator goes into OV condition. If the "S" pin exists and it's designed for remote voltage sensing, I'd be very pleased to have some kind of confirmation. >Crowbarring a 60A nominal alternator just feels little too "Robocop" for >an airplane application for me... Think I might stick with the Kilovolt >disconnect for the time being. Your initial impressions are understandable. But look at it this way. In ANY crowbar activity, the goal is to bring the protected lead to some very low if not zero volts as quickly as practical and with the least expenditure of ENERGY. It's easy for folks to get volts, amps, watts, and energy sorta all stirred into the same pot . . . because they're all defined in terms of each other. But an oft overlooked component of energy is that it always includes some reference to TIME. You PAY for kilowatt HOURS delivered to the back of your house, strobe lights for your camera or wing tip are measured in Joules (watt-seconds). Let's consider three different examples of crowbar events recently discussed. (1) Transorbs on downstream side of circuit breakers, (2) crowbar ov module on downstream side of field breaker, and (3) crowbar ov module on output of 60A alternator. (1) if bus voltage goes up causing a Transorb downstream of a breaker to go into conduction, the POWER dissipated in the Transorb is volts x amps. Just for grins, let us assume the fault current flowing in the Transorb is 10A driven through a 5A breaker. In: http://aeroelectric.com/articles/spike.pdf page 3, we examine the specifications for some suggested parts and find that 10A may take 2 to 10 seconds to open the 5A breaker. On the same page, we see that fault currents trough 1500 WATT Transorb have been characterized over a 10 MILLISECOND TO 100 MICROSECOND range. Hmmmm . . . how about 10 seconds? A Transorb is a special version of a zener. The 1500 Watt (peak) parts have a continuous dissipation rating on the order of 3-5 watts. 10A at 20 Volts is 200W. What is likelyhood of the device surviving 200W dissipation for 10 seconds (2000 watt seconds, 2000 Joules)? (2) Let's throw a 2v short downstream of a 5A breaker used for field circuit protection. We've hypothesized and measured crowbar events that range from 75-300 amps and trip times that range from 20 to 500 milliseconds. Here, the low current event takes the longest, the high current event is shortest. 75A x 12V = 900 watts for 500 milliseconds or 450 watt seconds. 300A x 12v = 3600 watts for 20 mS or 72 watt seconds. The really neat thing about this scenario is that the ENERGY is not concentrated in one component as in (1) above. Wiring, breaker resistance and crowbar voltage drops all get to share small portions of the total energy budget for the event. (3) Now, suppose we have a runaway 60 amp altenrator that has been disconnected from the bus and then shorted by some means as yet to be described. Keep in mind that an alternator is a constant current device. It physically cannot deliver a current flow much greater than nameplate rating. So, assume 80A. When presented with an 80A load, how long will it take for the b-terminal voltage on a self-excited, runaway alternator to be brought to heal? Great question that I'd like to explore (and will as part of the testing proposed in the conduct of this study). I'm betting it will be under 1 millisecond. As the b-terminal sags under load, field excitation goes down commensurately. The machine simply collapses into an inert heap of copper and steel with a total energy dump that's a tiny fraction of any modes discussed before. Call it "tough love" but crowbaring a diode isolated, runaway alternator is the fastest, lowest stress, minimum energy way to bring a potentially catastrophic scenario to order. I proposed to demonstrate or disprove that hypothesis in experiments that anyone is welcome to repeat to show us where we went wrong. >Gee maybe I could write a PHD theses on the phsychology of wiring >systems in aircraft...:) Please do sir! I think the AeroElectric-List has provided a wealth of examples how ignorance (sorry, I cannot think of a shorter term to describe lack of knowledge) and unwillingness to sift the sand of underlying simple-ideas wastes a lot of emotional resources. I'd rather have folks reserve emotional capital for the day they put first daylight under the wheels. In the mean time, does anyone out there have any data on the "S" terminal of any internally regulated alternator? Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> >If you can crowbar it you may be able to shut it down (stall it) and >prevent further internal alternator damage. Some alternators start up >just fine without being connected to a battery though so I'm not sure >how universal such an approach would be. > >If you just open the B-lead then apparently some melting may occur >within the alternator which presumably could have at least some risk of >causing problems (fire?) outside the alternator. As the voltage >continues to rise more field current flows which causes higher voltage >which causes more field current etc. until something gives... I think I >should do some destructive alternator testing before I send my next old >car to the wreckers ;) Correct. It's not "may" but "will" . . . We've seen several instances of destruction of the alternator's field winding when the regulator lost control of alternator output. I'm not too worried about fire . . . these wires are small gage and buried deep in the alternator. Your idea for testing is tantalizing. If you do have an opportunity to do this, let's talk about setup, photographing, and documentation for the library of repeatable tests. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
Yup that's the problem. The internal power fed to the field. In regards to your original question though it seems that there are indeed alternators out there that still use a sense line such as http://www.autoshop101.com/forms/alt_bwoh.pdf Just out of interest I should investigate the control or IGN line a bit more. I've read a couple of times that it is used to delay turning on the field until after the engine is started but I've seen several schematics that energise that line as soon as the key is turned on. Makes me think it is really there to tell the regulator to turn off the field if the engine is switched off and the alternator is not turning. Well I guess that is almost the same thing but it doesn't necessarily have to turn it off if it is still turning. Ken >snip >Did'nt realise the field was connected internally as well?...Hopefully >the whackjack will pull it down without it bursting into flames?????? > >Frank > > > ________________________________________________________________________________
Date: Aug 10, 2005
Hmmm...some very good points and a logical way of pointing out to an errant alternator that he's being a very naughty boy!...I still have the vision of Robocop holding onto the 480 V power terminals to "reset" his CPU!..:) Data on a S terminal..Hmm...I thought it was common knowledge? For years I was wondering what this litt 14GA wire was for that simply paralelled the 6Ga wire that went from the B terminal to the battery on my old MG. The little wire came from its own terminal labelled "s". On this website there is a guy that describes the hookup of 1987 Suzuki Samuri alt (I have one of these on my Soob conversion and its wired the same way. Take a look at this... http://www.f1-rocketboy.com/alternator.htm Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Alternator system design goals . . . --> (Corvallis)" > > >I'm a little confused here. > >Every IR alternator I have seen in my hot rod days had a voltage >sensing terminal. In my ND unit this is called the "s" terminal and is >normally wired to account for losses in the wiring (Van's doesn't use >this terminal in their standard setup) > >Would this not take care of the forward loss thru the diode? Don't know but it's an exciting prospect. Do you have any documentation that describes functionality of this pin? If sense pins are left open on some designs, the system either shuts down or the regulator goes into OV condition. If the "S" pin exists and it's designed for remote voltage sensing, I'd be very pleased ________________________________________________________________________________
Date: Aug 10, 2005
I have two simple toggle switches one for each ignition. I wonder if say for Ign #1 I should make this a DP switch and run the alt Ign wire through the second pole? The wire will be turned off with the Master sw (and my combined OV/ field wire switch) but that is several seconds after the engine has stopped turning. Any thoghts? For that matter I could make both the ign switches double pole and wire the second poles in parallel...That way the IGN wire would be turned off when the last ignition is shut off...I don't like interconecting critical devices like this though...what do you think? Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Subject: Re: AeroElectric-List: Alternator system design goals . . . Yup that's the problem. The internal power fed to the field. In regards to your original question though it seems that there are indeed alternators out there that still use a sense line such as http://www.autoshop101.com/forms/alt_bwoh.pdf Just out of interest I should investigate the control or IGN line a bit more. I've read a couple of times that it is used to delay turning on the field until after the engine is started but I've seen several schematics that energise that line as soon as the key is turned on. Makes me think it is really there to tell the regulator to turn off the field if the engine is switched off and the alternator is not turning. Well I guess that is almost the same thing but it doesn't necessarily have to turn it off if it is still turning. Ken >snip >Did'nt realise the field was connected internally as well?...Hopefully >the whackjack will pull it down without it bursting into flames?????? > >Frank > > > ________________________________________________________________________________
Date: Aug 10, 2005
Well I'm not too worried about my $100 alternator...if the whakjack does not save the alt I really don't care...Now Bob if you think fire is not an issue it sounds like a "Safe" setup at least? Assuming the SD-8 gets me home of course..:) Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Alternator system design goals . . . --> > >If you can crowbar it you may be able to shut it down (stall it) and >prevent further internal alternator damage. Some alternators start up >just fine without being connected to a battery though so I'm not sure >how universal such an approach would be. > >If you just open the B-lead then apparently some melting may occur >within the alternator which presumably could have at least some risk of >causing problems (fire?) outside the alternator. As the voltage >continues to rise more field current flows which causes higher voltage >which causes more field current etc. until something gives... I think >I should do some destructive alternator testing before I send my next >old car to the wreckers ;) Correct. It's not "may" but "will" . . . We've seen several instances of destruction of the alternator's field winding when the regulator lost control of alternator output. I'm not too worried about fire . . . these wires are small gage and buried deep in the alternator. Your idea for testing is tantalizing. If you do have an opportunity to do this, let's talk about setup, photographing, and documentation for the library of repeatable tests. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> > >Well I'm not too worried about my $100 alternator...if the whakjack does >not save the alt I really don't care...Now Bob if you think fire is not >an issue it sounds like a "Safe" setup at least? > >Assuming the SD-8 gets me home of course..:) > >Frank If you have an SD-8, it's a no-brainer if you load-shed to 8A or less. For about 10 years before we did the "All Electric Airplane on a Budge Article" for SA, one alternator and a well maintained battery would get most of us home too. That's the nice thing about failure tolerant design. It makes us think, plan and predict with understanding and confidence. This is the last thing a purveyor of the "next great shield against disaster" wants to happen. It's hard to sell elephant stampede insurance to folks that don't live in elephant country . . . but you gotta understand the country where you live. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> > >Hmmm...some very good points and a logical way of pointing out to an >errant alternator that he's being a very naughty boy!...I still have the >vision of Robocop holding onto the 480 V power terminals to "reset" his >CPU!..:) > >Data on a S terminal..Hmm...I thought it was common knowledge? For years >I was wondering what this litt 14GA wire was for that simply paralelled >the 6Ga wire that went from the B terminal to the battery on my old MG. >The little wire came from its own terminal labelled "s". It's common knowledge for folks who work with these parts. The closest I've ever come to a stock automotive alternator was when we did the first teardowns to see how to take the internal regulator out and modify them for operation as "aircraft" alternators. There was no interest or need to understand the parts we were taking out. In recent times, we've been distracted with fielding cabbages and tomatoes from folks who claimed great understanding of these alternators but were perhaps also distracted with broader missions. >On this website there is a guy that describes the hookup of 1987 Suzuki >Samuri alt (I have one of these on my Soob conversion and its wired the >same way. > >Take a look at this... http://www.f1-rocketboy.com/alternator.htm This looks like it has excerpts from the article done by Mr. Sullivan on autoshop101.com This is great stuff. Thanks for the heads-up guys! If it's common for the IR Alternator to be fitted with a remote sense wire, then I can see the potential for some really neat ways to implement these critters into the positive control, aircraft paradigm. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> >Yup that's the problem. The internal power fed to the field. > >In regards to your original question though it seems that there are >indeed alternators out there that still use a sense line such as > >http://www.autoshop101.com/forms/alt_bwoh.pdf Nice piece of work. I'm going to write this guy and see if he'll let me add this document to the library on aeroelectric.com >Just out of interest I should investigate the control or IGN line a bit >more. I've read a couple of times that it is used to delay turning on >the field until after the engine is started but I've seen several >schematics that energise that line as soon as the key is turned on. >Makes me think it is really there to tell the regulator to turn off the >field if the engine is switched off and the alternator is not turning. >Well I guess that is almost the same thing but it doesn't necessarily >have to turn it off if it is still turning. Good questions. The first time I worked with alternator regulators was on the Cessna generator to alternator conversions. I've got some notes somewhere from that time that speak to functionality of those terminals at the time. Of course, these were electro-mechanical regulators like: http://www.aeroelectric.com/Pictures/ALTREG6.jpg http://www.aeroelectric.com/Pictures/ALTREG2.jpg I recall that not having a light bulb to provide continuity between the bus and the "I" terminal would not allow the alternator to come on line. We later added a resistor in parallel with the lamp to make sure the alternator comes up even if the bulb is burned out. The "S" terminal looked for stator tap voltage to close the field relay and fully excite the alternator. This was a "switch" function as opposed to a "sense" function. I loosely assumed that "S" still had the same functionality in the modern parts. If it's really a voltage sense terminal, then there are very interesting prospects to consider. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
Just a note, Van's stock 60A alternator does not show a bulb in the IGN line..But shows the IGN and L (lamp?) leads tied together and fed from the master switch. The S lead they leave disconnected. Not sure if I want a charge light or not but if I do I think using an LED is a better approach than a bulb...LEDs seem to last forever. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Alternator system design goals . . . --> > >Yup that's the problem. The internal power fed to the field. > >In regards to your original question though it seems that there are >indeed alternators out there that still use a sense line such as > >http://www.autoshop101.com/forms/alt_bwoh.pdf Nice piece of work. I'm going to write this guy and see if he'll let me add this document to the library on aeroelectric.com >Just out of interest I should investigate the control or IGN line a bit >more. I've read a couple of times that it is used to delay turning on >the field until after the engine is started but I've seen several >schematics that energise that line as soon as the key is turned on. >Makes me think it is really there to tell the regulator to turn off the >field if the engine is switched off and the alternator is not turning. >Well I guess that is almost the same thing but it doesn't necessarily >have to turn it off if it is still turning. Good questions. The first time I worked with alternator regulators was on the Cessna generator to alternator conversions. I've got some notes somewhere from that time that speak to functionality of those terminals at the time. Of course, these were electro-mechanical regulators like: http://www.aeroelectric.com/Pictures/ALTREG6.jpg http://www.aeroelectric.com/Pictures/ALTREG2.jpg I recall that not having a light bulb to provide continuity between the bus and the "I" terminal would not allow the alternator to come on line. We later added a resistor in parallel with the lamp to make sure the alternator comes up even if the bulb is burned out. The "S" terminal looked for stator tap voltage to close the field relay and fully excite the alternator. This was a "switch" function as opposed to a "sense" function. I loosely assumed that "S" still had the same functionality in the modern parts. If it's really a voltage sense terminal, then there are very interesting prospects to consider. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
> > >Just a note, > >Van's stock 60A alternator does not show a bulb in the IGN line..But >shows the IGN and L (lamp?) leads tied together and fed from the master >switch. Hmmmm. Interesting. If L is for "lamp" I hope it's current limited inside the regulator. Pulling down on a lead that's expected to have a lamp in series with it could be devastating to the reguator's lamp driver . . . but perhaps it just smokes it and nobody knows or cares. >The S lead they leave disconnected. It would be an interesting experiment to hook this lead to the bus through a fuse and put a switch in it. Measure voltage at the bus with as many loads on as practical. Measure voltage with the switch open and then closed. If it's a sense lead, the bus voltage switch closed will be higher than with the switch open. >Not sure if I want a charge light or not but if I do I think using an >LED is a better approach than a bulb...LEDs seem to last forever. If you have active notification of low voltage, any other lights in the charging system are redundant. Even if it were an incandescent lamp, it will have such a low duty cycle that one lamp is likely to last the lifetime of the airplane. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
This one has more detail and some description of what happens when the S or B terminal is disconnected. http://www.autoshop101.com/forms/h8.pdf But this is a 20 year old (1983 vintage) alternator that he is describing. It's a very small sample but I've looked through a few service manuals and at a ND, a Delco, and a Mitsubishi and so far I haven't found an alternator newer than 1990 that uses what appears to be a voltage sense wire. He has a whole list of automotive stuff at http://www.autoshop101.com/autoshop15.html Ken snip >>http://www.autoshop101.com/forms/alt_bwoh.pdf >> >> > > Nice piece of work. I'm going to write this guy and see if he'll > let me add this document to the library on aeroelectric.com > > ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Subject: Com antenna ground plane
Date: Aug 10, 2005
I need some advice on my communication radio antenna installation. It is a Comant antenna, and comes with a gasket that effectively insulates the base of the antenna from the airplane skin. So the only metal-to-metal contact between the antenna and the airplane's aluminum skin will be via the four mounting machine screws. The airplane skin, and the doubler where the antenna will mount, have both been epoxy primed inside and out. I'm not sure that the rivets joining the doubler to the underside of the skin will ensure electrical continuity between them. Should I drill them out again before riveting to get rid of paint in the rivet holes? I believe I need to scrape the paint off the doubler where the washers on the mounting screws contact it, but is it necessary to have more bare-metal-to-bare metal contact between the doubler and the skin than what the rivets provide? Thanks. John ________________________________________________________________________________
Date: Aug 10, 2005
Subject: Re: Com antenna ground plane
> > >I need some advice on my communication radio antenna installation. It >is a Comant antenna, and comes with a gasket that effectively insulates >the base of the antenna from the airplane skin. So the only >metal-to-metal contact between the antenna and the airplane's aluminum >skin will be via the four mounting machine screws. The airplane skin, >and the doubler where the antenna will mount, have both been epoxy >primed inside and out. I'm not sure that the rivets joining the doubler >to the underside of the skin will ensure electrical continuity between >them. Should I drill them out again before riveting to get rid of paint >in the rivet holes? I believe I need to scrape the paint off the >doubler where the washers on the mounting screws contact it, but is it >necessary to have more bare-metal-to-bare metal contact between the >doubler and the skin than what the rivets provide? Thanks. If it were my airplane, I'd clean the area under the screw heads in the antenna base casting and around the holes on the underside of the skin where the nuts will bear. Rivets swell in holes to the extent that ordinary finishes like paint and primer are extruded out of the contact area. I wouldn't worry about ground quality. Don't clean any paint other finishes from either the underside of the antenna or on the surface of the fuselage. The 4 mounting bolts are sufficient. Pitch the rubber gasket and use a non-hardening, non-reactive gasket around the periphery of the antenna applied so that it will squish out when the antenna is mounted. Torque the mounting screws to values called out in AC43-13 for the screw material and size. Clean up the "squish" and you're finished. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2005
I never use the gasket. I bare the skin under the antenna and make sure the bottom of the antenna has good contact with the skin. Then I use caulk around the base of the antenna to keep out water. That's it. I assume the antenna comes with the gasket for pressurized aircraft. Wayne ----- Original Message ----- From: "John Swartout" <jgswartout(at)earthlink.net> Subject: AeroElectric-List: Com antenna ground plane > > > I need some advice on my communication radio antenna installation. It > is a Comant antenna, and comes with a gasket that effectively insulates > the base of the antenna from the airplane skin. So the only > metal-to-metal contact between the antenna and the airplane's aluminum > skin will be via the four mounting machine screws. The airplane skin, > and the doubler where the antenna will mount, have both been epoxy > primed inside and out. I'm not sure that the rivets joining the doubler > to the underside of the skin will ensure electrical continuity between > them. Should I drill them out again before riveting to get rid of paint > in the rivet holes? I believe I need to scrape the paint off the > doubler where the washers on the mounting screws contact it, but is it > necessary to have more bare-metal-to-bare metal contact between the > doubler and the skin than what the rivets provide? Thanks. > > > John > > > ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Re: Com antenna ground plane (expanded)
I wrote this rather quickly late last night and I see there are some murky points that need filtered: > >I need some advice on my communication radio antenna installation. It > >is a Comant antenna, and comes with a gasket that effectively insulates > >the base of the antenna from the airplane skin. So the only > >metal-to-metal contact between the antenna and the airplane's aluminum > >skin will be via the four mounting machine screws. The airplane skin, > >and the doubler where the antenna will mount, have both been epoxy > >primed inside and out. I'm not sure that the rivets joining the doubler > >to the underside of the skin will ensure electrical continuity between > >them. Should I drill them out again before riveting to get rid of paint > >in the rivet holes? I believe I need to scrape the paint off the > >doubler where the washers on the mounting screws contact it, but is it > >necessary to have more bare-metal-to-bare metal contact between the > >doubler and the skin than what the rivets provide? Thanks. > > If it were my airplane, I'd clean the area under the screw > heads in the antenna base casting and around the holes on the > underside > of the skin where the nuts will bear. > > Rivets swell in holes to the extent that ordinary finishes > like paint and primer are extruded out of the contact area. > I wouldn't worry about ground quality (due to rivets). Don't > clean any paint or other finishes from either the underside > of the antenna or on the surface of the fuselage. The 4 mounting > bolts are > sufficient. The reason for this advice is based on other conduction technologies we've discussed where the golden condition is gas-tight. One simply will not achieve gas tight connection between antenna base and aircraft skin in any areas other than those where hardware clamp up forces bring the conductors together with sufficient pressure to craft a high-integrity joint. Many a perfect paint job and formerly smooth antenna base have been literally sacrificed to craft what the assembler was told would be a high quality joint x-years from now. Since most of the areas we're encouraged to make bright and clean will have some degree of corrosion on them in 10 years, it's a given that gas-tight conditions do not exist at these points under the antenna. Therefore, it seems a wasted effort to scrape away perfectly good paint. The conductivity of 3-4 mounting screws properly installed will do the job nicely. > Pitch the rubber gasket and use a non-hardening, non-reactive > gasket around the periphery of the antenna applied so that it > will squish out when the antenna is mounted. This stuff will remain in the gaps where gas tightness has not been achieved. Good, we're depending on this filler to keep moisture out. In areas where gas-tight has been achieved, the filler gets extruded out. By non-reactive, I mean no solvents that attack paint (E-6000?) or attack metals (acetic acid RTV). Outdoor vinyl calk comes to mind as a good choice. > Torque the mounting screws to values called out in AC43-13 > for the screw material and size. Clean up the "squish" and > you're finished. You might even consider drilling out holes to install larger hardware. Most antennas mount with 10-32 screws. 14-28 cap screws might drop into the existing recesses in the antenna base. Further, you can get capscrews in very hard materials that will withstand mucho tightening. > Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
> >This one has more detail and some description of what happens when the S >or B terminal is disconnected. >http://www.autoshop101.com/forms/h8.pdf > >But this is a 20 year old (1983 vintage) alternator that he is >describing. It's a very small sample but I've looked through a few >service manuals and at a ND, a Delco, and a Mitsubishi and so far I >haven't found an alternator newer than 1990 that uses what appears to be >a voltage sense wire. The modern day regulator chip detailed at: http://www.freescale.com/files/analog/doc/data_sheet/MC33099.pdf shows a remote sense lead which is optional. There are switches in the circuitry to move between remote and local sense automatically. THIS ladies and gentlemen, is the kind of DATA I've been referring to that offers us insight into operation of the device . . . customer satisfaction (beyond meeting design goals) and "reliability" are not parts of this study. I'll call Tim today at B&C and ask if the current incoming batches of ND alternators have an "S" terminal. Bob . . . ________________________________________________________________________________
Subject: Re: Apology
Date: Aug 11, 2005
We have bought several items from Eric Jones and find them innovative and fine workmanship. Had a bit of trouble with one of them and he took it back twice to make the modification tha made it work for our application. That's service and at no extra charge. He even designed a fresh air shut off valve for the Lancair ES (very elegant and compact design) at our urging and sent us the prototype for testing. I would recommend his products to anyone for their intended use. And he's a bit of a free spirit, too. I find that refreshing, although I don't agree with his views all the time. And he answers the phone and emails. Cheers, John Schroeder > > In a message dated 8/10/2005 2:57:42 AM Eastern Standard Time, > aeroelectric-list-digest(at)matronics.com writes: > If you are considering a purchase from him please don't go > somewhere else because of a few off-the-cuff comments I made on this > list. > Talk to other people who have had dealings with the man and find out what > sort of business person he is. ________________________________________________________________________________
Subject: Vacuum switch
Date: Aug 11, 2005
I'm looking for a switch for a low-vacuum warning light. Any suggestions? ________________________________________________________________________________
Date: Aug 11, 2005
From: "Stewart, Michael (ISS Atlanta)" <mstewart(at)iss.net>
I got one from Rocky Mountain Instruments. Mike www.rkymtn.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gary Casey Subject: AeroElectric-List: Vacuum switch I'm looking for a switch for a low-vacuum warning light. Any suggestions? ________________________________________________________________________________
Date: Aug 11, 2005
You haven't seen some of my landings...:) Yes my mind went the same place on not using the lamp, If I can't find a better answer before painting the panel I might just slap one in there anyway (my alt did not come from Van's but it looks the same). That way I know its working as intended. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Alternator system design goals . . . --> (Corvallis)" > > >Just a note, > >Van's stock 60A alternator does not show a bulb in the IGN line..But >shows the IGN and L (lamp?) leads tied together and fed from the master >switch. Hmmmm. Interesting. If L is for "lamp" I hope it's current limited inside the regulator. Pulling down on a lead that's expected to have a lamp in series with it could be devastating to the reguator's lamp driver . . . but perhaps it just smokes it and nobody knows or cares. >The S lead they leave disconnected. It would be an interesting experiment to hook this lead to the bus through a fuse and put a switch in it. Measure voltage at the bus with as many loads on as practical. Measure voltage with the switch open and then closed. If it's a sense lead, the bus voltage switch closed will be higher than with the switch open. >Not sure if I want a charge light or not but if I do I think using an >LED is a better approach than a bulb...LEDs seem to last forever. If you have active notification of low voltage, any other lights in the charging system are redundant. Even if it were an incandescent lamp, it will have such a low duty cycle that one lamp is likely to last the lifetime of the airplane. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
I guess it also depends on what you mean by current. When I bought my alt it was for a 1987 (I think) ND unit...The 55amp (Much favoured by homebuilders) ND is a 1987 Suzuki Samuri. Looking at the age these are definatly from "yesteryear" but they are still "currently" available if you see what I mean. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: Alternator system design goals . . . --> > >This one has more detail and some description of what happens when the >S or B terminal is disconnected. >http://www.autoshop101.com/forms/h8.pdf > >But this is a 20 year old (1983 vintage) alternator that he is >describing. It's a very small sample but I've looked through a few >service manuals and at a ND, a Delco, and a Mitsubishi and so far I >haven't found an alternator newer than 1990 that uses what appears to >be a voltage sense wire. The modern day regulator chip detailed at: http://www.freescale.com/files/analog/doc/data_sheet/MC33099.pdf shows a remote sense lead which is optional. There are switches in the circuitry to move between remote and local sense automatically. THIS ladies and gentlemen, is the kind of DATA I've been referring to that offers us insight into operation of the device . . . customer satisfaction (beyond meeting design goals) and "reliability" are not parts of this study. I'll call Tim today at B&C and ask if the current incoming batches of ND alternators have an "S" terminal. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Gary Mine came with my standby vacuum system from Precise Flight. I think they sell them separately but might be pricy as they are certified. Paul Schattauer RV 8 808PS >From: Gary Casey <glcasey(at)adelphia.net> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Vacuum switch >Date: Thu, 11 Aug 2005 06:29:18 -0700 > > >I'm looking for a switch for a low-vacuum warning light. Any >suggestions? > > ________________________________________________________________________________
Subject: trim relay deck trim speed control
Date: Aug 11, 2005
I have the Infinity Aeropsace Trim Relay Deck, see at http://www.infinityaerospace.com/Relay_Deck_Wiring_Schematic.jpg I am trying to install a Ray Allen Speed control for the pitch trim but have a few ?? on the wiring. http://www.rayallencompany.com/RACmedia/instructionsSPD.pdf Not sure where to connect the red wire from the Speed control to the Infinity Relay Deck. The Relay Deck only has a 1. A port for Trim motor 2. B port for Trim motor 3. +12 v 4. Ground It doesn't have a provision for "blue wire" like shown on Diagram 2 of the Ray Allen schematic. I guess it is so simple that I don't see it. Thank you, Lui ________________________________________________________________________________
Date: Aug 11, 2005
> > >You haven't seen some of my landings...:) > >Yes my mind went the same place on not using the lamp, If I can't find a >better answer before painting the panel I might just slap one in there >anyway (my alt did not come from Van's but it looks the same). That way >I know its working as intended. The active notification of low voltage light being OUT says the alternator is working. The alternator warning light may not be all inclusive of alternator failures while the external low volt warning light IS all inclusive of alternator failure. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
True and I have a Dynon engine management system coming that I can set auible alarms for any parameter I want....I was more worried about what not having the light would do to the alternator and as a fall back I could add the light even though it is redundant...Guess I could add a resister instead though? What value of resistor would make sense?..Should I simply measure the resistance of a panel bulb to find out? Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Alternator system design goals . . . --> (Corvallis)" > > >You haven't seen some of my landings...:) > >Yes my mind went the same place on not using the lamp, If I can't find >a better answer before painting the panel I might just slap one in >there anyway (my alt did not come from Van's but it looks the same). >That way I know its working as intended. The active notification of low voltage light being OUT says the alternator is working. The alternator warning light may not be all inclusive of alternator failures while the external low volt warning light IS all inclusive of alternator failure. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
From: "Mark R Steitle" <mark.steitle(at)austin.utexas.edu>
I would like to ditto John's comments. I have bought some items for my Lancair ES from Perihelion Design and Eric was great to deal with and very helpful. He answered my emails promptly. I wouldn't hesitate to buy from him again in the future. Mark Steitle (No, Eric didn't pay me to say this) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Schroeder Subject: Re: AeroElectric-List: Re: Apology We have bought several items from Eric Jones and find them innovative and fine workmanship. Had a bit of trouble with one of them and he took it back twice to make the modification tha made it work for our application. That's service and at no extra charge. He even designed a fresh air shut off valve for the Lancair ES (very elegant and compact design) at our urging and sent us the prototype for testing. I would recommend his products to anyone for their intended use. And he's a bit of a free spirit, too. I find that refreshing, although I don't agree with his views all the time. And he answers the phone and emails. Cheers, John Schroeder > > In a message dated 8/10/2005 2:57:42 AM Eastern Standard Time, > aeroelectric-list-digest(at)matronics.com writes: > If you are considering a purchase from him please don't go > somewhere else because of a few off-the-cuff comments I made on this > list. > Talk to other people who have had dealings with the man and find out what > sort of business person he is. ________________________________________________________________________________
Date: Aug 11, 2005
Bob, you usually don't make such simple errors, but if the light is out it tells you EITHER that the alternator is working or the bulb is not. Best regards, Rob Housman Europa XS Tri-Gear A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Alternator system design goals . . . > > >You haven't seen some of my landings...:) > >Yes my mind went the same place on not using the lamp, If I can't find a >better answer before painting the panel I might just slap one in there >anyway (my alt did not come from Van's but it looks the same). That way >I know its working as intended. The active notification of low voltage light being OUT says the alternator is working. The alternator warning light may not be all inclusive of alternator failures while the external low volt warning light IS all inclusive of alternator failure. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
> >Bob, you usually don't make such simple errors, but if the light is out it >tells you EITHER that the alternator is working or the bulb is not. > > >Best regards, > >Rob Housman Oh, sure. One assumes the bulb is good because of a pre-flight check or some Press-to-test system. For warning lights that seldom come on, an observation that the light is on before the alternator is brought on line is usually sufficient. Low duty cycle warning lights will generally last the lifetime of the airplane. Of course, LED's are more attractive yet. Were you making a distinction as to the operational logic of an alternator warning light vis a vis a low voltage warning light? The only point I was making is that LOW VOLTAGE is an absolute indicator of inoperative alternator while there may be failure modes within the alternator that would cripple it without lighting the alternator failure light. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
> > >True and I have a Dynon engine management system coming that I can set >auible alarms for any parameter I want....I was more worried about what >not having the light would do to the alternator and as a fall back I >could add the light even though it is redundant...Guess I could add a >resister instead though? > >What value of resistor would make sense?..Should I simply measure the >resistance of a panel bulb to find out? Cold resistance of a lamp is a tiny fraction of the running resistance. A 360 ohm resistor would be quite adequate. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Tim at B&C thinks he has some engineering data on the ND alternators they use as raw stock for the L-40/L60/SD-20 series alternators. He said he would share it with me if he can find it. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Subject: turbine lightoff current
Hi folks! I'll be constructing a Helicycle helicopter, a turbine-powered single seater, after my 8A is done. The question of starter motor current draw has come up. Does anyone have hard data on the starter motor current draw over time to light off a small turbine engine like a Solar T-62? Thanks for any info! Alan Erickson ________________________________________________________________________________
Date: Aug 11, 2005
Nope, my response was literal, taking into account the fragility of tungsten filaments, not a comment on the advantages or disadvantages of any particular scheme. Best regards, Rob Housman Europa XS Tri-Gear A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Subject: RE: AeroElectric-List: Alternator system design goals . . . <robh@hyperion-ef.us> > >Bob, you usually don't make such simple errors, but if the light is out it >tells you EITHER that the alternator is working or the bulb is not. > > >Best regards, > >Rob Housman Oh, sure. One assumes the bulb is good because of a pre-flight check or some Press-to-test system. For warning lights that seldom come on, an observation that the light is on before the alternator is brought on line is usually sufficient. Low duty cycle warning lights will generally last the lifetime of the airplane. Of course, LED's are more attractive yet. Were you making a distinction as to the operational logic of an alternator warning light vis a vis a low voltage warning light? The only point I was making is that LOW VOLTAGE is an absolute indicator of inoperative alternator while there may be failure modes within the alternator that would cripple it without lighting the alternator failure light. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Re: turbine lightoff current
> > >Hi folks! I'll be constructing a Helicycle helicopter, a turbine-powered >single seater, after my 8A is done. The question of starter motor current >draw has come up. > >Does anyone have hard data on the starter motor current draw over time to >light off a small turbine engine like a Solar T-62? Does the supplier/manufacturer offer any engineering data on installation of their products? This kind of info should be a part of that package. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
> > >Hi folks! I'll be constructing a Helicycle helicopter, a turbine-powered >single seater, after my 8A is done. The question of starter motor current >draw has come up. > >Does anyone have hard data on the starter motor current draw over time to >light off a small turbine engine like a Solar T-62? These folks sell a manual for the engine: http://www.aerotecdata.com/library.html Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Electronic Circuit Breakers ?
Bob & All All this talk about the best alternator protection and nobody has mentioned the new electronic circuit breakers with high/low voltage cutout (16 & 10 volts) complete with warning light etc. Sounds like crowbar over voltage protection in miniature. Maybe these pricey ($77) items are the best way to protect my avionics stack! What say you, all I know is what I see in the Aircraft Spruce catalog. George in Langley BC ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Re: Electronic Circuit Breakers ?
> > >Bob & All > >All this talk about the best alternator protection and nobody has >mentioned the new electronic circuit breakers with high/low voltage >cutout (16 & 10 volts) complete with warning light etc. Sounds like >crowbar over voltage protection in miniature. Maybe these pricey ($77) >items are the best way to protect my avionics stack! What say you, all I >know is what I see in the Aircraft Spruce catalog. I have a couple of these things to evaluate . . . but they're pretty far back on the stove. I think they're a solid state relay with some smarts for reacting to abnormal voltages. I suspect they're a series switch that simply opens when voltages get out of range. The ones I have are fitted with miniature switches for controls. If you used one of these for an alternator field switch, they would protect the whole airplane . . . assuming we're comfortable with their switching dynamics. Bob . . . ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Off to Plymouth, MA
Dee and I are hopping the big iron bird for Boston, MA at o-dark thirty in the morning. We're looking forward to meeting 18 OBAM aircraft enthusiasts at the EAA Chapter 82 clubhouse this weekend. http://aeroelectric.com/seminars/Plymouth_2005.html If anyone has a chance to add this event to their weekend activities, you don't need a reservation, just come on in. Due to ticketing hassles, we won't be getting back until late Monday night as opposed to our usual Sunday return. I'm not even taking a computer this trip. They're too much work. I've been doing some writing using the ol' ball-point and a college ruled theme book. This $2.00, two-piece word processing tool is pretty compact, and the batteries never run down. My hand writing has improved over the past two trips, I can pretty well read it now. See you all next week! Bob . . . -------------------------------------------------------- < Throughout history, poverty is the normal condition > < of man. Advances which permit this norm to be > < exceeded -- here and there, now and then -- are the > < work of an extremely small minority, frequently > < despised, often condemned, and almost always opposed > < by all right-thinking people. Whenever this tiny > < minority is kept from creating, or (as sometimes > < happens) is driven out of a society, the people > < then slip back into abject poverty. > < > < This is known as "bad luck". > < -Lazarus Long- > <------------------------------------------------------> http://www.aeroelectric.com ________________________________________________________________________________
Date: Aug 11, 2005
Subject: Re: trim relay deck trim speed control
Lui, Sorry I didn't get to this before we had to leave. I've got it at the top of my do-do list for our return unless someone else jumps in to cover it. Bob . . . > > > >I have the Infinity Aeropsace Trim Relay Deck, see at > >http://www.infinityaerospace.com/Relay_Deck_Wiring_Schematic.jpg > >I am trying to install a Ray Allen Speed control for the pitch trim but have >a few ?? on the wiring. > >http://www.rayallencompany.com/RACmedia/instructionsSPD.pdf > >Not sure where to connect the red wire from the Speed control to the >Infinity Relay Deck. The Relay Deck only has a > >1. A port for Trim motor >2. B port for Trim motor >3. +12 v >4. Ground > >It doesn't have a provision for "blue wire" like shown on Diagram 2 of the >Ray Allen schematic. I guess it is so simple that I don't see it. > > >Thank you, > >Lui > > >-- > > >-- incoming mail is certified Virus Free. Bob . . . -------------------------------------------------------- < Throughout history, poverty is the normal condition > < of man. Advances which permit this norm to be > < exceeded -- here and there, now and then -- are the > < work of an extremely small minority, frequently > < despised, often condemned, and almost always opposed > < by all right-thinking people. Whenever this tiny > < minority is kept from creating, or (as sometimes > < happens) is driven out of a society, the people > < then slip back into abject poverty. > < > < This is known as "bad luck". > < -Lazarus Long- > <------------------------------------------------------> http://www.aeroelectric.com ________________________________________________________________________________
Date: Aug 12, 2005
From: Tammy and Mike Salzman <arrow54t(at)yahoo.com>
Subject: Re: Vacuum switch
Gary, I have been using this switch and have no problems with it. I bought a couple to have on hand should one fail in the future. I only have 17 hours on my plane, but it has worked great during that time. When I pull the throttle back to idle before shutting down, I get the alarm. http://www.surpluscenter.com/item.asp?UID=2005081210041966&item=11-2344&catname Mike Salzman Fairfield, CA LNCE --- Gary Casey wrote: > > > I'm looking for a switch for a low-vacuum warning light. Any > suggestions? > > > > > > > ________________________________________________________________________________
Subject: LR-3 problem... maybe
Date: Aug 12, 2005
Hi folks, I bought one of these nice regulators, 14v, back in 1999 for my Stag-Ez. Started flying last year, logged 50 hrs. No problems till last week, when I had the bad idea, while flying, to switch off the alternator field, to make sure the origin of the (slight) whining I heard on my headsts was caused by alternator (35 Ah Van's rebuilt unit). Yes, the whining was caused by the alternator, but since the first time I reset the field, the following problem appeared: field's breaker popping out from time to time at the beginning, then more and more often. I was watching the voltage reading on my JPI: never exceeded 4.3 V. Collateral problem: for about ten seconds after breaker's resetting the oil temp reading was jumping full scale and then came back down slowly. Could it be I managed to damage the regulator? Or the alternator? Why then? Thank you for any clue you can pass to help me diagnose and solve my problem. Gianni Zuliani Long-Ez >> Stag-Ez >> Stag-EzRG http://www.comgz.com/tristar.htm ________________________________________________________________________________
Subject: Detroit Approach freq
Date: Aug 13, 2005
" From: Cameron Kurth <cameronkurth(at)yahoo.com> Subject: Re: AeroElectric-List: Garmin 196 interferes with com radio >I would be interested in the specific VHF frequencies so I can test my setup. The only frequency that has any interference is 118.95. That just happens to be Detroit Approach. I live under Detroit's class B airspace so it's an important frequency for me. Also I'm working on my instrument ticket so I talk to approach quite abit and a channel full of static just doesn't help in my learnings :) Cam" Fred et al, This sounds to me to call for a 'stub' to short out the interference in that freq. [standard tuning stub]. Installing it in a series of lines might eliminate all but the offending unit? Comments? Ferris Buehler? Anyone? Ferg ________________________________________________________________________________
Date: Aug 13, 2005
Subject: KX-155 Power connections help!
HELP! I'm trying to wire up my KX-155/GS this afternoon and can't figure out something. The wiring diagram shows POWER IN on pins 14 and R. The wiring diagram shows GROUND on pins 15 and S. I power on the unit and nothing... so I'm looking at the wiring diagram for something I missed. There are two pins labled SWITCHED POWER IN (11 and M) and two pins labeled SWITCHED POWER OUT (12 and N). The wiring diagram shows them all connected together. My thought was that these were to power up an external CDI or something. So I hooked two power wires up to the SW POWER IN pins and then turned on the master. Immediately the radio came on! The radio now works but the ON/OFF switch on the front of the unit doesn't control the power any more. (I don't have anything connected to the SW POWER OUT right now.) Has anyone wired a KX155 and can tell me what these Switched Power pins are for and how they get wired? I don't want to go much further for fear of smoking something. Matthew 913.706.3087 (cell) matthew at n523rv.com ________________________________________________________________________________
Date: Aug 13, 2005
I have wired many KX155's. You should be able to power the unit with 14vdc at pins 14 and R. 28vdc at pins 13 and P, and with grounds at pins S and 15. If this doesn't work I would say you have something wrong with the radio (maybe a pico fuse on the power supply, not sure I don't have the schematics here in front of me.... Switched in is for bypassing the on off switch and is not normally used. Switched is for low current units that you want to control with the KX-155 such as a VOR head that requires a switched power input. Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matthew Brandes Subject: AeroElectric-List: KX-155 Power connections help! HELP! I'm trying to wire up my KX-155/GS this afternoon and can't figure out something. The wiring diagram shows POWER IN on pins 14 and R. The wiring diagram shows GROUND on pins 15 and S. I power on the unit and nothing... so I'm looking at the wiring diagram for something I missed. There are two pins labled SWITCHED POWER IN (11 and M) and two pins labeled SWITCHED POWER OUT (12 and N). The wiring diagram shows them all connected together. My thought was that these were to power up an external CDI or something. So I hooked two power wires up to the SW POWER IN pins and then turned on the master. Immediately the radio came on! The radio now works but the ON/OFF switch on the front of the unit doesn't control the power any more. (I don't have anything connected to the SW POWER OUT right now.) Has anyone wired a KX155 and can tell me what these Switched Power pins are for and how they get wired? I don't want to go much further for fear of smoking something. Matthew 913.706.3087 (cell) matthew at n523rv.com -- -- ________________________________________________________________________________
Subject: Fire Indication Probe
Date: Aug 13, 2005
I'm looking for a probe to put inside the cowl that will detect a fire and set off an alarm. I'm installing a remote fire extinguisher system and would like something to indicate a fire before the red hot firewall or leaking smoke does. Charlie Burton ________________________________________________________________________________
Date: Aug 14, 2005
Subject: RE: KX-155 Power connections help!
Mike (and list), Thanks for the email. I decided after sending my email to just do what the wiring diagram says and tie all four of those SWITCHED connections together... and it worked! The only thing I can think of is that the switched OUT pins are controlled by the on/off switch at the faceplate and are fed from the 14v power in pins (14 and R). The switched IN pins must feed power to the display. (Which is why my display worked when I put power on them directly from the bus.) It also shows that you can wire a connection OUT to the CDI, so I have that wired to pin 41 on my 209A indicator but haven't hooked it up yet to test. Sure seems like an odd way to power the display! This was my last piece of avionics to wire, so after I test the transmit on the radio tomorrow, I'll be done with avionics wiring.... on to engine monitor wiring. Matthew RV-9A Avionics! www.n523rv.com ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Split washers vs. Nyloc nuts
Hi, My fuel pumps came with what look like brass nuts and a split lock washer. These are used to hold on the ring terminals. I've read that these split lock washers are not recommended in an aviation application. I would like to replace these with a standard flat washer and a nyloc nut. Does this seem like a good idea? Photo here: http://www.rv8.ch/images/articles/20050814081622711_1_original.JPG Thanks for any feedback. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Dynon's D10A
I am considering installing a EFIS-D10A (dynonavionics.com) as a backup in certified aircraft. Has anyone had any experience with this particular unit, its reliability etc. for IFR? Rumen ________________________________________________________________________________
Date: Aug 14, 2005
Subject: more than 1 audio into intercom aux
Hi all, I was wondering, can I feed more than one audio signal from different sources into the aux input of a PS Engineering intercom? (no isolation between sources necessary?) All (2 or 3) sources will be mono. Rumen ________________________________________________________________________________
Subject: Re: Dynon's D10A
Date: Aug 14, 2005
I've been flying behind an EFIS-D10 (not the A model). I do fly IFR with it, but take note of two important items: 1) Only 16 hours (24 approaches) out of 591 hours using the Dynon were flown solely by reference to instruments. 2) I have conventional "steam gauges" (airspeed, altitude, VSI) and a Trutrak Pictorial Pilot to back up the Dynon. Early on, the EFIS-D10 had slight problems with "the leans." The unit would indicate a slight bank (~5 degrees) when the wings were level. Dynon addressed this with a software update and now the unit is as reliable, if not far more reliable, in attitude indication than any mechanical gyro I've ever flown behind. I personally don't hesitate to fly IFR with it. I seriously doubt Dynon will ever encourage anybody to use their EFIS for IFR. Nor do I. But I do it. )_( Dan RV-7 N714D (591 hours) http://www.rvproject.com ----- Original Message ----- From: <rd2(at)evenlink.com> Subject: AeroElectric-List: Dynon's D10A > > > I am considering installing a EFIS-D10A (dynonavionics.com) as a backup in > certified aircraft. > Has anyone had any experience with this particular unit, its reliability > etc. for IFR? > > Rumen > > > ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Re: Split washers vs. Nyloc nuts
In general I used the parts that came with the component unless there was an obvious incompatibility. I tossed the steel nuts that were on the brass posts of my contactors and replaced them with brass nuts and brass internal star washers. I want gas tight connections but I also don't want to encourage dissimilar metal corrosion. I don't remember what I did on the steel posts on the fuseblocks but I think I stayed with the steel nuts which I believe were nickel plated. My fuel pumps came with hardware like you describe but it was all tin plated (or solder ?) plated and I used it. The lockwashers were fairly narrow and more likely to be gas tight than a flat washer. I think from the archives and the book you will see a preference for internal star washers and brass or phosphor bronze hardware but again I'd try not to add another type of metal to the joint if possible. Ken Mickey Coggins wrote: > >Hi, > >My fuel pumps came with what look like brass nuts >and a split lock washer. These are used to hold >on the ring terminals. > >I've read that these split lock washers are not >recommended in an aviation application. I would >like to replace these with a standard flat washer >and a nyloc nut. Does this seem like a good idea? > >Photo here: > >http://www.rv8.ch/images/articles/20050814081622711_1_original.JPG > >Thanks for any feedback. > >Mickey > > > ________________________________________________________________________________
Subject: Rotax Electrical Help
Date: Aug 14, 2005
8/14/2005 Hello Rotax Experts, A friend of mine wants to buy a Rotax 912 powered S-LSA (Special- Light Sport Aircraft) powered by a Rotax 912 (xxx) engine. He is looking to me for guidance and I am very limited in my Rotax knowledge, most of which I have gained by monitoring a list of Pulsar builders for several years. My main interest / concern is with the electrical system. I have a Lockwood catalog and can look at the engine parts diagrams, but am not able to absorb the implications of it all. I would appreciate it if someone could provide a brief tutorial on the electrical inner workings and hidden mechanisms of a typical airplane powered by a Rotax 912 (xxx) engine. Some of the questions that come to mind are: 1) What generates, controls, and distributes the electrical power for engine ignition (spark plugs)? 2) Does the system in 1) above require constant electrical power from a battery to keep the engine operating? 3) What generates, controls, and distributes the electrical power for aircraft systems such as avionics and lights? 4) How many amps are available from 3) above? 5) Are there ways of increasing the amperage of 3) above by adding an additional belt driven alternator? 6) If an additional belt driven alternator is feasible does this also require some modification to the engine's voltage regulator (I have read comments that the voltage regulator in this system is a weak point). Many thanks for all your help and please add any comments you think would be helpful in addition to answers to the above questions. OC PS: As a bonus I would appreciate it if someone could explain to me the various alphabet soup letters (U, L, S, ?) that appear after the 912 engine designation. ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Re: Rotax Electrical Help
Hello OC I think to fully answer all of your questions, you simply need to be told where you should go ;-) http://www.kodiakbs.com/sdintro.htm Go to techinfo and download manuals Go to Service info, register and download all for motor you are interested in. PLEASE NOTE manual is only a starting point, you need to update it according Service info. There are many things in manual that absolute need not following, like how to vent )Prime) the oil system, and use of silicone based heat sink compound on spark plug threads, and proper spark plugs to use. You need to go back to mid 90s and update from there. I will try to answer some of your questions: 1) What generates, controls, and distributes the electrical power for engine > ignition (spark plugs)? 2 Ducati electronic ignitions. There is trigger and charge coils in the alternator area. Note especial older installs have problems with wires breaking that go into modules, the newer have modules mounted on engine and are viabration shock mounted. Supposedly if you get modules too hot, you can't turn off! > > 2) Does the system in 1) above require constant electrical power from a > battery to keep the engine operating? The 912 and 912S has both a Mechanical and electric pump to feed the constant depression type 64 Bing Carbs. Thus they are not fully electrical dependent. The 914 is electrical dependent, it has 2 higher pressure electric fuel pumps. the reason is when boosting you need to supply pressure to carbs ~ 2 to 5 pounds over airbox pressure. > > 3) What generates, controls, and distributes the electrical power for > aircraft systems such as avionics and lights? > > 4) How many amps are available from 3) above? > > 5) Are there ways of increasing the amperage of 3) above by adding an > additional belt driven alternator? > > 6) If an additional belt driven alternator is feasible does this also > require some modification to the engine's voltage regulator (I have read > comments that the voltage regulator in this system is a weak point). This will touch on #3 4 5 +6 The internal alternator is not too powerful. At best for anysort of long life and reliability keep constant draw to 12 amps or less. THAT IS MAX. It may be rated for 18 or 20 amps but will not really put that out. If you draw too many amps for long periods of time, the regulators tend to fail. You can help the regulator out by blowing ambient air on it, make a box with outlet holes and pliumb in air with scat tube. supposedly if you darw too many amps coils fail because insulation gets hurt. Just keep regulator cool, and 10 or 11 amps max and probably you will be rewarded. As far as more power, you could install Rotax belt driven alternator, I am not certain but you would best use a seperate regulator and keep on a second buss. Or just use the larger alternator and not use the internal. I have a 914 for use in a europa, and the belt driven is not happy to use. i opted to mount a ND alternator on the vacuume pad. It supposedly rewound and rated at Rotax pad speeds for some rediculous amount, I am counting on 30 amps, will run it constant at not more that 20. I am conservative i think. I will have 2 batteries, and run radios and clean on internal, this way I can start with all on, and it will run second fuel pump which a 914 is dependent on. I have not heard of anyone using a replacement to the rotax regulator with outstanding sucess. again if you made the regulator better, you would probably fry the windings. Best keep the Rotax cool and don't ask too much of it all the time. > > > PS: As a bonus I would appreciate it if someone could explain to me the > various alphabet soup letters (U, L, S, ?) that appear after the 912 engine > designation. As far as rotax designations, I am not certain exact what UL or F means, but the UL is Non Certified, and F is Certified. This is needed information when researching service info as many a time for UL motor they will send you to the F engine service document for the full score. The 912 is rated at max of 80HP. The 912S is a larger displacement, higher compression and rated max of 100HP. It is normal aspirated. The 914 is essential a 912, kinda sortta same compression and displacement but has a turbo, it is rated at 115hp for 5 mins and 100HP continuous. If you use the S you best get the Heavy Duty starter and slipper clutch. The Heavy Duty starter will fit on the 914 and newer motors come with it. the 912 will probably take it as well. This is more than you probably wanted to know. Make sure you study how the dogs take up engine power pulses, and get the latest on tensions and clearances. If you get a slipper clutch, look up the latest on that as well. All motors have dogs, with slipper they have more free play. The slipper is to aid you in event of prop strike. It is essential locked until you need it. Good Luck Ron Parigoris PS please take this information I provided from one who is not yet flying a 914, and has little practical experiance on rotax motors. I did talk to many in the know and read/study all I could find. Keep in mind any of the Rotax 900 series is closer to a motorcycle engine than a traditional aircraft engine. The 914 is 71 cubic inches and pumps out 100HP continuous and will do that up pretty high, a O-200 is 200 cubic inches and will do that only at lower density altitudes. You must be very "IN TUNE" with carburator maintenance and adjustment on the 900s, as well as gearbox maintenance. You need smooth or you will tear up gearboxes. Also keep in mind that the 900s are much happier on mogas than 100LL. Research issues caused by 100LL. All above said, you can call Lockwood and attend either a group seminar, or a individual instruction for up to i think 3 people. ________________________________________________________________________________
Date: Aug 14, 2005
Far from an expert here, OC, but I'll give you my $0.02 as a Rotax 914 user. I recommend you head over to http://www.rotax-aircraft-engines.com and pull down the PDF's for the 912, too. The Installation, Maintenance, and Operator's Manuals for the Rotax engines are all there for the taking and will give you some data to thumb through. > 1) What generates, controls, and distributes the electrical power for engine > ignition (spark plugs)? The ignition is a 'dual ignition unit of a breakerless, capacitor discharge design with an integrated generator.' It comes out of the crate ready to go. > 2) Does the system in 1) above require constant electrical power from a > battery to keep the engine operating? Nope, no external power required (... once you bump the starter). > 3) What generates, controls, and distributes the electrical power for > aircraft systems such as avionics and lights? There's an integrated generator and an external rectifier-regulator (the Ducati unit) for power. The generator is 14 V/ 20 A... but that's at 68 degF ambient. I've read that 12 A is about all you're going to get without cooling worries. However, most of the failures I've read about were firewall-mounted units inside tight cowls with no provisions for unit cooling. Take the 12 A number with a block of salt... but you might want to include some creative ducting. > 4) How many amps are available from 3) above? 12 A is the user recommended "stay below" number although the 68 degF curve says you can get 20 A at 5000 RPM (gen is fed by the crank). > 5) Are there ways of increasing the amperage of 3) above by adding an > additional belt driven alternator? Yes, there are mounting provisions on the engine for a belt driven system. > 6) If an additional belt driven alternator is feasible does this also > require some modification to the engine's voltage regulator (I have read > comments that the voltage regulator in this system is a weak point). No mod's required... the Ducati unit (i.e. - weak point) is only handling the juice from the internal generator. You'll have to decide whether you want an internally or externally regulated alternator. I ain't touching that one... ;-) > Many thanks for all your help and please add any comments you think would be > helpful in addition to answers to the above questions. The Europa list is a good source of indirect Rotax 912/914 info if you have general operating questions. > PS: As a bonus I would appreciate it if someone could explain to me the > various alphabet soup letters (U, L, S, ?) that appear after the 912 engine > designation. If it has a UL in the name it isn't certified (perhaps that means 'UltraLight'???). The big difference between the 912 UL and the 912 ULS is more HP (UL is an 79 HP engine whilst ULS is 95 HP). To add further confusion, there's also a number after all of the letters to tell you whether it's suitable for fixed pitch (2), constant speed (3), or fixed pitch convertible to constant speed (4) prop. HTH! D ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Re: Fire Indication Probe
Charlie - An innovative varieze driver "rolled his own" by stringing a twisted wire pair throughout the cowl. One wire is connected hot and the other is connected to ground. When the low temperature (cheap) wire insulation melts the wires touch and the circuit is completed to trigger his alarm. For some reason he's reluctant to test his system in flight... but it sure seems like it would work fine. D --------------------------- On 8/13/05, Charlie Burton wrote: > > I'm looking for a probe to put inside the cowl that will detect a fire and set off an alarm. I'm installing a remote fire extinguisher system and would like something to indicate a fire before the red hot firewall or leaking smoke does. > Charlie Burton > > > > > > > ________________________________________________________________________________
Date: Aug 14, 2005
This sounds like the best, simplest way to go. So, instead of asking for the "best", "highest temp insulation" wire, what is the "lowest melting point insulation" cheapo wire? David ----- Original Message ----- From: "D Wysong" <hdwysong(at)gmail.com> Subject: Re: AeroElectric-List: Fire Indication Probe > > Charlie - > > An innovative varieze driver "rolled his own" by stringing a twisted > wire pair throughout the cowl. One wire is connected hot and the > other is connected to ground. When the low temperature (cheap) wire > insulation melts the wires touch and the circuit is completed to > trigger his alarm. > > For some reason he's reluctant to test his system in flight... but it > sure seems like it would work fine. > > D > > --------------------------- > On 8/13/05, Charlie Burton wrote: >> >> >> I'm looking for a probe to put inside the cowl that will detect a fire >> and set off an alarm. I'm installing a remote fire extinguisher system >> and would like something to indicate a fire before the red hot firewall >> or leaking smoke does. >> Charlie Burton >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 14, 2005
The problem with that "good" approach is that the areas that are most likely to involve a fire are already hot enough to melt the insulation in normal operation. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of D Wysong Subject: Re: AeroElectric-List: Fire Indication Probe Charlie - An innovative varieze driver "rolled his own" by stringing a twisted wire pair throughout the cowl. One wire is connected hot and the other is connected to ground. When the low temperature (cheap) wire insulation melts the wires touch and the circuit is completed to trigger his alarm. For some reason he's reluctant to test his system in flight... but it sure seems like it would work fine. D --------------------------- On 8/13/05, Charlie Burton wrote: > > I'm looking for a probe to put inside the cowl that will detect a fire and set off an alarm. I'm installing a remote fire extinguisher system and would like something to indicate a fire before the red hot firewall or leaking smoke does. > Charlie Burton > > > > > > > ________________________________________________________________________________
Date: Aug 14, 2005
Ken - Does one have to replace the internal star washers after they are used once? Seems that it would be easy to mash the teeth flat after torquing the nut & washe once. Thanks, John > I think from the archives and the book you will see a preference for > internal star washers and brass or phosphor bronze hardware but again > I'd try not to add another type of metal to the joint if possible. -- ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Re: more than 1 audio into intercom aux
From: Gerry Holland <gholland@gemini-resourcing.com>
Hi to all. Can someone answer Rumens question. I need to know too for my PS501! > I was wondering, can I feed more than one audio signal from different > sources into the aux input of a PS Engineering intercom? (no isolation > between sources necessary?) > All (2 or 3) sources will be mono. Regards Gerry ________________________________________________________________________________
From: "Bernie Berger" <bberger4(at)tampabay.rr.com>
Subject: RE: Rotax Electrical Help
Date: Aug 14, 2005
Ah, I have a 40 amp external alternator on my Series III and have seen one on an XP. One of our builders, in Europe put one in his plane. To do so he had to do a little relieving of the cowling to make it fit but it wasn't much. Additionally, there is now a 40 amp alternator that will mount on the back of the gear box, where the a vacuum pump or a prop governor mounts. Bernie Berger -----Original Message----- From: owner-pulsar-builders(at)caseyk.org [mailto:owner-pulsar-builders(at)caseyk.org]On Behalf Of cm.coulter(at)att.net LIVINGSTON, Kip Subject: Re: Rotax Electrical Help OC The Rotax 912 uses a motorcycle alternator. It has 2 coils that produce power for the ignition. No battery is needed. Also it has lighting coils 5 I think that produces 17 amps at 5500 rpm. There is an add on alternater that uses a belt drive but will not fit in a Pulsar cowl so you will not see them used on Pulsars. Also there is a Company that makes a small Alternator that runs off the air pump drive. I think it puts out 20+ amps but not sure. Hope this helps. Clarke -------------- Original message from : -------------- > 8/14/2005 > > Hello Rotax Experts, A friend of mine wants to buy a Rotax 912 powered S-LSA > (Special- Light Sport Aircraft) powered by a Rotax 912 (xxx) engine. He is > looking to me for guidance and I am very limited in my Rotax knowledge, most > of which I have gained by monitoring a list of Pulsar builders for several > years. My main interest / concern is with the electrical system. I have a > Lockwood catalog and can look at the engine parts diagrams, but am not able > to absorb the implications of it all. > > I would appreciate it if someone could provide a brief tutorial on the > electrical inner workings and hidden mechanisms of a typical airplane > powered by a Rotax 912 (xxx) engine. Some of the questions that come to mind > are: > > 1) What generates, controls, and distributes the electrical power for engine > ignition (spark plugs)? > > 2) Does the system in 1) above require constant electrical power from a > battery to keep the engine operating? > > 3) What generates, controls, and distributes the electrical power for > aircraft systems such as avionics and lights? > > 4) How many amps are available from 3) above? > > 5) Are there ways of increasing the amperage of 3) above by adding an > additional belt driven alternator? > > 6) If an additional belt driven alternator is feasible does this also > require some modification to the engine's voltage regulator (I have read > comments that the voltage regulator in this system is a weak point). > > Many thanks for all your help and please add any comments you think would be > helpful in addition to answers to the above questions. > > OC > > PS: As a bonus I would appreciate it if someone could explain to me the > various alphabet soup letters (U, L, S, ?) that appear after the 912 engine > designation. > ________________________________________________________________________________
Date: Aug 14, 2005
In a Velocity pusher, where fire detection is far more important than a tractor configuration, I took two thermo couples intended for installation in a water jacket for automotive applications and ran the wires to the Grand Rapids EFIS. GRT EFIS, set to the engine data display, shows the temp readout of the two sensors, one each side of the engine. Should one go 'hot', it'll trigger the GRT internally set alarm level. The temp readout between flights are very consistent and comeback down to a very predictable value after a hard, hot climb. I've not calibrated them, since the absolute temperature isn't particularly important--I just want to know if something jumps 50 or 100 degrees, in which case I will immediately become very focused! Chuck ________________________________________________________________________________
Date: Aug 14, 2005
> In a Velocity pusher, where fire detection is far more important than a > tractor configuration... Just out of curiosity, why is this the case? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 14, 2005
I didn't really consider the issue of dissimilar metals. My main concern was of the nut coming loose. I guess this is not much of a problem. I'll just go with what Bosch shipped, the thin brass nut and a steel lockwasher. Thanks, Mickey Ken wrote: > > In general I used the parts that came with the component unless there > was an obvious incompatibility. I tossed the steel nuts that were on the > brass posts of my contactors and replaced them with brass nuts and brass > internal star washers. I want gas tight connections but I also don't > want to encourage dissimilar metal corrosion. I don't remember what I > did on the steel posts on the fuseblocks but I think I stayed with the > steel nuts which I believe were nickel plated. > > My fuel pumps came with hardware like you describe but it was all tin > plated (or solder ?) plated and I used it. The lockwashers were fairly > narrow and more likely to be gas tight than a flat washer. > > I think from the archives and the book you will see a preference for > internal star washers and brass or phosphor bronze hardware but again > I'd try not to add another type of metal to the joint if possible. > > Ken > > Mickey Coggins wrote: > > >> >>Hi, >> >>My fuel pumps came with what look like brass nuts >>and a split lock washer. These are used to hold >>on the ring terminals. >> >>I've read that these split lock washers are not >>recommended in an aviation application. I would >>like to replace these with a standard flat washer >>and a nyloc nut. Does this seem like a good idea? >> >>Photo here: >> >>http://www.rv8.ch/images/articles/20050814081622711_1_original.JPG >> >>Thanks for any feedback. >> >>Mickey >> >> -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 14, 2005
because you cant see or smell it Franz -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Mickey Coggins Subject: Re: AeroElectric-List: Fire Indication Probe > In a Velocity pusher, where fire detection is far more important than a > tractor configuration... Just out of curiosity, why is this the case? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing -- -- ________________________________________________________________________________
Date: Aug 14, 2005
With a pusher configuration, your tail feathers can be burning off and you may not know it until something quits or falls off, because it's all behind you. (I don't have a review mirror on the Velo--but if I did, it'd be full of Bonanzas and light twins anyhow). With a tractor, you get a face full of heat and smoke right shortly. Not good news but certainly an early warning sign, though I suppose there are event scenarios with a tractor that the initial fire might not come to your attention immediately, so a detection system still seems like a good idea. With a fire, every second truly counts! Chuck -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: Re: AeroElectric-List: Fire Indication Probe > In a Velocity pusher, where fire detection is far more important than a > tractor configuration... Just out of curiosity, why is this the case? Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 14, 2005
I did it with the Garmin 340 and used a resistor in line on each input wire. It was a 300 ohm, 1/4W. I had the Transponder (Garmin 330), the AOA (Proprietary Software Sport Model), the autopilot (TruTrak DFC 250) and the Dynon D10A. Dynon still has not implemented their audio, but intend to do so. The resistor value came from the avionics shop that wired the stack cables. I did the actual wiring for the aux(unswitched)input pin on the 340. I would call the PSA Engineering folks and ask for sure, but I'll bet they say to use a resistor. Hope this helps. John ________________________________________________________________________________
Date: Aug 15, 2005
Whilst this is cheap, I think it is probably not reliable. The question I have is... What causes the wires to move together once the insulation is gone? I expect that vibration would probably do it. Bit is 'probably' good enough? D Wysong wrote: >An innovative varieze driver "rolled his own" by stringing a twisted >wire pair throughout the cowl. One wire is connected hot and the >other is connected to ground. When the low temperature (cheap) wire >insulation melts the wires touch and the circuit is completed to >trigger his alarm. > >For some reason he's reluctant to test his system in flight... but it >sure seems like it would work fine. > >D > ________________________________________________________________________________
Date: Aug 14, 2005
John Hi! > I would call the PSA Engineering folks and ask for sure, but I'll bet they > say to use a resistor. > > Hope this helps. It does. Regards Gerry How much free photo storage do you get? Store your holiday ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Re: RE: KX-155 Power connections help!
> The only thing I can think of is that the switched OUT pins are > controlled by the on/off switch at the faceplate and are fed from the > 14v power in pins (14 and R). The switched IN pins must feed power to > the display. (Which is why my display worked when I put power on them > directly from the bus.) > Sure seems like an odd way to power the display! If I understand this correctly, not if you want to be able to dim the display independently of the auto-dim feature? Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Aug 14, 2005
Thanks Dan, this is exactly the kind od response I was looking for. BTW: > I seriously doubt Dynon will ever encourage anybody to use their EFIS for IFR. Nor do I. But I do it. > Similarly, does Garmin encourage anybody to use their panel page (gpsmap 196/296/396) for ifr? ;) But it could save one's hide in case of emergency. If Dynon is as reliable (MTBF etc.) as the handheld gps', then it proibably is a better deal @ $2195 than sporty's (also non-certified) electric # 2060A Gyro ($1595). Not saying that sporty's is unreliable, merely noticing that dynon offers a host of functions vs. very the functions found in sporty's product. Or, thinking again, maybe garmin's deal is the best one, considering the number of functions offered and same ifr/vfr/certification issues. Rumen ________________________________________________________________________________
Date: Aug 14, 2005
Thanks John. Gerry, did you receive this too? On Monday I'll call PS Engineering to discuss this and will post the answer (if I get one; they have been a bit slow, to put it mildly, to answer emails). Generally a 5-10 kohm resistor per input would be ok for passive isolation, if it does not decrease signal too much. The resistor depends on the input impedance of the intercom aux input and the output of the source/s and the number of sources. Without getting into detail, I was looking for a quick and dirty. Rumen _____________________Original message __________________________ (received from John Schroeder; Date: 03:27 PM 8/14/2005 -0400) I did it with the Garmin 340 and used a resistor in line on each input wire. It was a 300 ohm, 1/4W. I had the Transponder (Garmin 330), the AOA (Proprietary Software Sport Model), the autopilot (TruTrak DFC 250) and the Dynon D10A. Dynon still has not implemented their audio, but intend to do so. The resistor value came from the avionics shop that wired the stack cables. I did the actual wiring for the aux(unswitched)input pin on the 340. I would call the PSA Engineering folks and ask for sure, but I'll bet they say to use a resistor. Hope this helps. John ________________________________________________________________________________
Subject: Cancel
Date: Aug 14, 2005
Subject: Routing Antenna Leads
Date: Aug 14, 2005
Hello Bob & List, I'm installing my Garmin panel mounted GPS/Comm (GNC 250-XL) with Perihelion's RG+142 coax in a tube & fabric aircraft. The two antennas are about 5' apart. The installation manual says to route the GPS cable 'as far as possible' away from the Comm cable. Before reading that part I was inclined to route them right next to each other. Now I don't really know what to do. I couldn't find anything on this specific question in the archives. Is there a minimum distance for good radio performance? Thanks, Grant Krueger ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Icom A200
I am helping a friend with radio and intercom installation on an RV 6 and have run into my first roadbock. I wired the molex edge connector per installation instructions (at least I think I did!). In my first bench test, receive audio is fine. The transmitter is connected to a 52 ohm dummy load through a wattmeter. When I key the radio there is a steady tone in the headset and no power output. The TX indicator does not come on. I've double-checked wiring and it looks right. Any ideas? Thanks, Lyle Bell ________________________________________________________________________________
Subject: RE: Fire Indication Probe
Date: Aug 14, 2005
Fire detectors usually operate by detecting the UV radiation given off by a flame. Only a fire in the cowl will show any UV. The detectors are simple and easy to get from Allied Electronics, etc., and the additional circuitry not hard to make. Ideally several of them should cover all areas of interest. You could use a video camera--they are so cheap a little airplane could have a dozen of them for every conceivable task--including fire detection. Has anybody experimented with home smoke detectors under the cowl? And finally two words--E Bay. There are several "Flame detectors" for sale cheap right now. Flame detectors (or "no flame" detectors) are used in some furnaces, and I think they are UV photoelectric for the most part. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Democracy must be something more than two wolves and a sheep voting on what to have for dinner." - James Bovard ________________________________________________________________________________
Date: Aug 14, 2005
Subject: Icom A200 - - figured out my problem
After sending out my plea for help, I found my problem. It is directly attributable to crossed wires - - in my head! ________________________________________________________________________________
Date: Aug 14, 2005
Bob, Any chance of bringing this closer to the front burner? I think using the electronic CB as you mentioned is interesting - and I believe others find it interesting also. Implementing the latest technology and concepts is what drives custom aircraft building. Having your take on this CB would be valuable information. Stan Sutterfield >Bob & All > >All this talk about the best alternator protection and nobody has >mentioned the new electronic circuit breakers with high/low voltage >cutout (16 & 10 volts) complete with warning light etc. Sounds like >crowbar over voltage protection in miniature. Maybe these pricey ($77) >items are the best way to protect my avionics stack! What say you, all I >know is what I see in the Aircraft Spruce catalog. I have a couple of these things to evaluate . . . but they're pretty far back on the stove. I think they're a solid state relay with some smarts for reacting to abnormal voltages. I suspect they're a series switch that simply opens when voltages get out of range. The ones I have are fitted with miniature switches for controls. If you used one of these for an alternator field switch, they would protect the whole airplane . . . assuming we're comfortable with their switching dynamics. Bob . . . ________________________________________________________________________________
Subject: Re: Icom A200
Date: Aug 15, 2005
I once miswired that Molex plug ( on my own radio too) by getting confused, part way through the job after a meal break, as to whether each number/letter legend referred to the pin on its right or its left! Unfortunately, I got the power pins transposed in that process and managed to vaporise a pcb track inside the radio. A simple fix as it turned out but one that took a while to fault find. Sounds a little like your PTT wiring is not grounding the PTT pin on the radio, hence you aren't actually keying the transmitter. Even if your mic wiring were faulty, grounding a functioning PTT pin should produce a healthy carrier signal into the dummy load. Dont know about that tone you report though. Might be worth checking out that dummy load/wattmeter combination in case either is faulty and presenting too high a VSWR to the transmitter, causing it to shut itself off t protect its final amplifier stages. Bill ----- Original Message ----- From: "Lyle Bell" <lylebell(at)gmail.com> Subject: AeroElectric-List: Icom A200 > > I am helping a friend with radio and intercom installation on an RV 6 and > have run into my first roadbock. I wired the molex edge connector per > installation instructions (at least I think I did!). In my first bench > test, > receive audio is fine. The transmitter is connected to a 52 ohm dummy load > through a wattmeter. When I key the radio there is a steady tone in the > headset and no power output. The TX indicator does not come on. I've > double-checked wiring and it looks right. Any ideas? > > Thanks, Lyle Bell > > > ________________________________________________________________________________
Date: Aug 14, 2005
Eric, UV or Infra Red ? Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Eric M. Jones Subject: AeroElectric-List: RE: Fire Indication Probe Fire detectors usually operate by detecting the UV radiation given off by a flame. Only a fire in the cowl will show any UV. The detectors are simple and easy to get from Allied Electronics, etc., and the additional circuitry not hard to make. Ideally several of them should cover all areas of interest. You could use a video camera--they are so cheap a little airplane could have a dozen of them for every conceivable task--including fire detection. Has anybody experimented with home smoke detectors under the cowl? And finally two words--E Bay. There are several "Flame detectors" for sale cheap right now. Flame detectors (or "no flame" detectors) are used in some furnaces, and I think they are UV photoelectric for the most part. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Democracy must be something more than two wolves and a sheep voting on what to have for dinner." - James Bovard ________________________________________________________________________________
Date: Aug 14, 2005
How about a sturdy cotton thread holding open a spring-loaded NC switch? Cotton burns through, switch closes. Verify by a secondary reading of cowl air temp since thread might get oil-soaked, weakened and eventually fail from age... Maybe an IR lipstick camera and small monitor to keep a constant eye on things inside that dark cowling? -Stormy -----Original Message----- From: Chuck Jensen <cjensen(at)dts9000.com> Subject: RE: AeroElectric-List: Fire Indication Probe In a Velocity pusher, where fire detection is far more important than a tractor configuration, I took two thermo couples intended for installation in a water jacket for automotive applications and ran the wires to the Grand Rapids EFIS. GRT EFIS, set to the engine data display, shows the temp readout of the two sensors, one each side of the engine. Should one go 'hot', it'll trigger the GRT internally set alarm level. The temp readout between flights are very consistent and comeback down to a very predictable value after a hard, hot climb. I've not calibrated them, since the absolute temperature isn't particularly important--I just want to know if something jumps 50 or 100 degrees, in which case I will immediately become very focused! Chuck ________________________________________________________________________________
Subject: OVP thoughts.
Date: Aug 14, 2005
I'll start with humble apologies to all who have lost patience with this topic. For those of us still having an interest in any resolution which may be found I would like to ask the following. Given that many of us would like to use IR alternators for cost and convenience reasons the issue becomes one of how we can protect our avionics with a high degree of certainty. 1) Until a few days ago when Ken Lehman wrote about "an OVM module of some kind protecting the supply to that $15k radio rack that you mentioned." I hadn't seen anyone mention this as a solution, although I have wondered about it myself. Why couldn't this prove a good way to save our wallets leaving the alternator to be shut down manually? 2) Load dump (back emf ?) seems to be the alternator killer when crowbared under load. Bob wrote "Actually, the neatest way (lowest parts count) to run the IR alternator would be to add a diode in series with the alternator's output and crowbar the alternator itself to ground without loading the ship's bus. The lights wouldn't even flicker. Problem is that adding the diode tosses off .5 to 1 volt of output.". Why couldn't this be reduced to .2v or thereabouts with a Schottky thus making this approach feasable? These are probably naive questions but the debate so far I have found very valuable indeed. The education afforded by the constructive contributors has far outweighed the unsatsfactorily negative contributions from the cabbage tossers. Kudos to those who disagree politely and in a reasoned and constructive manner. Rob Rob W M Shipley N919RV (res) Fuselage .....still! La Mesa, CA. (next to San Diego) -- Try www.SPAMfighter.com for free now! ________________________________________________________________________________
Date: Aug 14, 2005
From: Kevin And Ann Klinefelter <kevann(at)verizon.net>
Subject: Re: RE: Rotax Electrical Help
"Additionally, there is now a 40 amp alternator that will mount on the back of the gear box, where the a vacuum pump or a prop governor mounts." >Any idea where I can get such an alternator? > > Kevin Europa with a 914 ________________________________________________________________________________
Date: Aug 15, 2005
Subject: Re: RE: Fire Indication Probe
Eric, can you suggest a small display for the videocam ? - cameras and small and cheap, but I heven't been able to come up with a convenient display (preferably to fit into a standard panel opening). Rumen _____________________Original message __________________________ (received from Eric M. Jones; Date: 08:25 PM 8/14/2005 -0400) Fire detectors usually operate by detecting the UV radiation given off by a flame. Only a fire in the cowl will show any UV. The detectors are simple and easy to get from Allied Electronics, etc., and the additional circuitry not hard to make. Ideally several of them should cover all areas of interest. You could use a video camera--they are so cheap a little airplane could have a dozen of them for every conceivable task--including fire detection. Has anybody experimented with home smoke detectors under the cowl? And finally two words--E Bay. There are several "Flame detectors" for sale cheap right now. Flame detectors (or "no flame" detectors) are used in some furnaces, and I think they are UV photoelectric for the most part. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Democracy must be something more than two wolves and a sheep voting on what to have for dinner." - James Bovard ________________________________________________________________________________
Date: Aug 15, 2005
Subject: More than 1 audio source into the Intercom Music Input
- revisited I talked to PS Engineering about the solution. The PS Engineering PS 1000 II has an input impedance of 47 kOhm (music input) (as probably do most intercoms, at least in that range). So, it is not likely that the intercom would load the output of any source, because it isn't likely that the source would have an output impedance of 47 kohm or higher. But in order for the audio sources not to affect ea. other, PS Eng. suggested to add isolation resistors to ea. source. We are basically building a signal mixer. They said I could start with 500 ohm per source (in series) and increase until signal starts to attenuate (or until signal is not unacceptably attenuated). For practical purposes, I will be adding the necessary number of 3.5mm receptacles (equaling the number of needed inputs) with 1 kOhm resistors in series in ea. signal path and will test the intercom with all available signal sources active and connected to the inputs. That way the sources will have isolation of 2 kohm between ea. other. I might actually do the test with 10 kohm pots in each path initially to determine which is the highest resistance that does not attenuate the audio of the source, then replacing the pots with resistors. Rumen ________________________________________________________________________________
Date: Aug 15, 2005
I haven't figured out how to dim the display yet... the install manual doesn't show a pin for dimming.. but the document that bob has on his site shows that pin 24 is used for 14v light dimming.... so I'm kinda confused still. I'd be concerned about dimming this circuit since it runs power out to the CDI. At least the radio works at this point! Matthew Brandes, Van's RV-9A (Wiring) #90569 http://www.n523rv.com EAA Chapter 1329 President EAA Chapter 868 Web Editor > > The only thing I can think of is that the switched OUT pins are > controlled by the on/off switch at the faceplate and are fed from the > 14v power in pins (14 and R). The switched IN pins must feed power to > the display. (Which is why my display worked when I put power on them > directly from the bus.) > Sure seems like an odd way to power the display! If I understand this correctly, not if you want to be able to dim the display independently of the auto-dim feature? Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Aug 15, 2005
>Eric, >UV or Infra Red ? >Regards, George George, There are advantages and disadvantages to the various approaches. UV--Clearly a step function. Flames, sparks and various energetic phenomena emit UV. In a normally functioning engine, zero UV is emitted even if it melts. The Hamamatsu UV Trons are insensitive to sunlight without any filtering (remarkable). These are very common and inexpensive detectors. Can be triggered by coronas and arc welders....but hey!....nothing's free. Google "Hamamatsu UV Tron". Visible--The engine exhaust gets brighter, but that's about it in the dark. The problems with visible fire alarms is that flying west at sunset might trigger photoelectric alarms. so you have to shield them carefully. Easy to use but lots of technical issues to resolve. IR--Similar to visible but easier to use. Flames produce much more IR than just hot pipes. Filters are used to look at only certain wavelengths. Makers if IR Flame detectors seem to be secretive about spectral characteristics. Some fire situations seem to demand certain spectral sensitivities. (Things-you-never-knew note: They sell fireproof IR/UV fire detectors, also detectors that are heated to keep them free from ice.) Combo units--Many units take the advantages of IR and UV and make combination IR/UV units. Hamamatsu UV Trons are so good and so cheap that almost all brand-name flame detectors are just Hamamatsus-in-a-box. I like the cotton string on Microswitch idea. Super-Glue vaporizes at a certain temperature, so you could craft a temp alarm with some glue and a microswitch. All the technology from old water sprinklers would probably work too. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Hey, it ain't rocket surgery!" --anonymous ________________________________________________________________________________
Date: Aug 15, 2005
----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Date: Monday, August 15, 2005 10:32 am Subject: AeroElectric-List: RE: Fire Indication Probe Jones" > Braly" > > > >Eric, > >UV or Infra Red ? > >Regards, George > > George, > > There are advantages and disadvantages to the various approaches. > > UV--Clearly a step function. Flames, sparks and various energetic > phenomena > emit UV. In a normally functioning engine, zero UV is emitted even > if it > melts. The Hamamatsu UV Trons are insensitive to sunlight without > any > filtering (remarkable). These are very common and inexpensive > detectors. Can > be triggered by coronas and arc welders....but hey!....nothing's > free. > Google "Hamamatsu UV Tron". > > Visible--The engine exhaust gets brighter, but that's about it in > the dark. > The problems with visible fire alarms is that flying west at sunset > might > trigger photoelectric alarms. so you have to shield them carefully. > Easy to > use but lots of technical issues to resolve. > > IR--Similar to visible but easier to use. Flames produce much more > IR than > just hot pipes. Filters are used to look at only certain > wavelengths. Makers > if IR Flame detectors seem to be secretive about spectral > characteristics. > Some fire situations seem to demand certain spectral sensitivities. > (Things-you-never-knew note: They sell fireproof IR/UV fire > detectors, also > detectors that are heated to keep them free from ice.) > > Combo units--Many units take the advantages of IR and UV and make > combination IR/UV units. > > Hamamatsu UV Trons are so good and so cheap that almost all brand- > name flame > detectors are just Hamamatsus-in-a-box. > > I like the cotton string on Microswitch idea. Super-Glue vaporizes > at a > certain temperature, so you could craft a temp alarm with some glue > and a > microswitch. All the technology from old water sprinklers would > probably > work too. > > Regards, > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge MA 01550-2705 > (508) 764-2072 > > "Hey, it ain't rocket surgery!" > --anonymous > > This is my first post, so hopefully I'll get it right. Isn't another simple option a thermal overload relay (such as a bimetallic or solid state), thermistor, or thermal fuse? Radio shack has thermal fuses of various temperatures for less than $2. A fused circuit would have to turn on a light or other warning device when it became open, but this is also pretty simple. Scott Gettings ________________________________________________________________________________
Date: Aug 15, 2005
Scott, If your subsequent posts are as good as your first, I think you've already gotten the hang of it. The downside of the detectors, alarm on a string, thermal fuse, et al, is they are on/off, 0/1. No way of trending or knowing if it's a false alarm...just that you got an alarm. Can you say 'idiot lights' that was so popular in cars of yesteryear. No information, just an alert. On the other hand, a temp readout allows you to trend a problem, assess the magnitude of it and still be given an alarm via the preset alarm point. Simple and cheap...though Eric raises important points arguing for some alternative detection technology, even if they don't give rate information. Chuck Scott Gettings wrote... This is my first post, so hopefully I'll get it right. Isn't another simple option a thermal overload relay (such as a bimetallic or solid state), thermistor, or thermal fuse? Radio shack has thermal fuses of various temperatures for less than $2. A fused circuit would have to turn on a light or other warning device when it became open, but this is also pretty simple. ________________________________________________________________________________
Date: Aug 15, 2005
>This is my first post, so hopefully I'll get it right. Scott, welcome to the fray. >Isn't another simple option a thermal overload relay >(such as a bimetallic or solid state), thermistor, >or thermal fuse? Radio shack has thermal fuses of >various temperatures for less than $2. A fused >circuit would have to turn on a light or other >warning device when it became open, but this is also >pretty simple. Scott Gettings Scott, you are inferring that high temps must equal a fire. That may or may not be so. Does a small fire equal very high temps--especially where you have the sensor? Maybe. Maybe not. Would hot exhaust pipes trigger an overtemp sensor quicker than a small fuel-leak fire? Almost certainly. A couple UV Trons and the Space Shuttle Challenger could have brought Christa McAuliffe back to teach school. But it would have required ten zillion thermal detectors to sense that errant flame. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "The problem with the world is that only the intelligent people want to be smarter, and only the good people want to improve." - E.Stobblehouse ________________________________________________________________________________
Date: Aug 15, 2005
> A couple UV Trons and the Space Shuttle Challenger could have brought > Christa McAuliffe back to teach school. But it would have required ten > zillion thermal detectors to sense that errant flame. I like the way they did it on SpaceShipOne - winding all that wire around the casing, and if any burns through, it cuts off the NO2. Could have worked on the shuttle SRBs, I think. Of course, there is no shutting those things off, but I guess they could have "ejected" them. -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 15, 2005
If you are going to have your fuel pumps in your engine compartment, I would suggest you use an all-metal self locking nut instead of a nyloc nut. The heat from the engine compartment may weaken or melt the nylon in the nyloc nut and allow it to loosen. The self locking nuts in my engine compartment are all metal. If you have a self locking nut, a flat washer should be sufficient. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: SPAM::AeroElectric-List: Split washers vs. Nyloc nuts Hi, My fuel pumps came with what look like brass nuts and a split lock washer. These are used to hold on the ring terminals. I've read that these split lock washers are not recommended in an aviation application. I would like to replace these with a standard flat washer and a nyloc nut. Does this seem like a good idea? Photo here: http://www.rv8.ch/images/articles/20050814081622711_1_original.JPG Thanks for any feedback. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 15, 2005
From: "Craig P. Steffen" <craig(at)craigsteffen.net>
> If you are going to have your fuel pumps in your engine compartment, I > would suggest you use an all-metal self locking nut instead of a nyloc > nut. The heat from the engine compartment may weaken or melt the nylon > in the nyloc nut and allow it to loosen. The self locking nuts in my > engine compartment are all metal. If you have a self locking nut, a > flat washer should be sufficient. I don't know if it's a codified regulation, but my understanding is that the FAA considers nylon locknuts forward of the firewall a big no-no. All-metal locknuts (or castle nuts) ONLY in the engine compartment. -- craig(at)craigsteffen.net public key available at http://www.craigsteffen.net/GPG/ current goal: use a CueCat scanner to inventory my books career goal: be the first Vorlon Time Lord ________________________________________________________________________________
Date: Aug 15, 2005
On a pusher (at least), maybe it would be worth looking at the difference between inlet air and the outlet air temperature. Any more than a certain delta indicates something bad is going on. An easy microcontroller project. You might have to include an offset table for powersetting to make it really good. It might not be possible to detect a small fire while at low powersetting (in a long descent for instance) without it. Other information about engine/installation health could be garnered from comparing inlet temp vs outlet temp too - a way to detect a baffle leak would show up as an extraordinarily low delta-T. This idea is probably too complex, but a lot would be learned from setting it up and looking at the data. One good thing about pushers is that the natural airflow typically pulls hot gasses away from structural and soft pink stuff. It might be tougher to detect, but it's probably somewhat less likely to hurt you. A number of pushers have suffered in flight fires, and I think most of them have landed with no injury to anyone aboard. Further, pushers have suffered a variety of leaks of oil and fuel that most assuredly would have caused a fire on a conventional plane, but only 'inconvenience' (engine out) on the pusher. An engine compartment oil or fuel leak in an RV is really bad. Regards, Matt- VE N34RD, C150 N714BK ________________________________________________________________________________
Date: Aug 15, 2005
I have flown behind the D-10 and find it to be better and more reliable then steam gauges. On one flight I had a vacuum pump failure and was left with the Dynon or the turn and bank. I used the Dynon for the ILS approach instead of the certified turn and bank. The problem you will have is getting the field approval to install that unit in a certified airplane. It is possible, but I don't think it will be easy. I do know that the "Letter Groups" are taking a hard look at some of these units as a backup for certified airplanes. Mike Larkin Lancair Legacy TS-11 Kitfox 4 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rd2(at)evenlink.com Subject: Re: AeroElectric-List: Dynon's D10A Thanks Dan, this is exactly the kind od response I was looking for. BTW: > I seriously doubt Dynon will ever encourage anybody to use their EFIS for IFR. Nor do I. But I do it. > Similarly, does Garmin encourage anybody to use their panel page (gpsmap 196/296/396) for ifr? ;) But it could save one's hide in case of emergency. If Dynon is as reliable (MTBF etc.) as the handheld gps', then it proibably is a better deal @ $2195 than sporty's (also non-certified) electric # 2060A Gyro ($1595). Not saying that sporty's is unreliable, merely noticing that dynon offers a host of functions vs. very the functions found in sporty's product. Or, thinking again, maybe garmin's deal is the best one, considering the number of functions offered and same ifr/vfr/certification issues. Rumen -- -- 8/15/2005 ________________________________________________________________________________
Date: Aug 15, 2005
Folks, check your regs. No nylon locking nuts are to be used in the engine compartment. RWF ----- Original Message ----- From: "Rogers, Bob J." <BRogers(at)fdic.gov> Subject: RE: SPAM::AeroElectric-List: Split washers vs. Nyloc nuts > > > If you are going to have your fuel pumps in your engine compartment, I > would suggest you use an all-metal self locking nut instead of a nyloc > nut. The heat from the engine compartment may weaken or melt the nylon > in the nyloc nut and allow it to loosen. The self locking nuts in my > engine compartment are all metal. If you have a self locking nut, a > flat washer should be sufficient. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Mickey Coggins > To: aeroelectric-list(at)matronics.com > Subject: SPAM::AeroElectric-List: Split washers vs. Nyloc nuts > > > > Hi, > > My fuel pumps came with what look like brass nuts > and a split lock washer. These are used to hold > on the ring terminals. > > I've read that these split lock washers are not > recommended in an aviation application. I would > like to replace these with a standard flat washer > and a nyloc nut. Does this seem like a good idea? > > Photo here: > > http://www.rv8.ch/images/articles/20050814081622711_1_original.JPG > > Thanks for any feedback. > > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > > -- > > ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Subject: Split washers vs. Nyloc nuts
Date: Aug 15, 2005
> > Folks, check your regs. No nylon locking nuts are to be used in the > engine > compartment. > > RWF Robert, Point us to the specific reg and we will check it. Obviously, from a practical viewpoint there is a temperature limit for the nylon lock nuts. I don't recall that limit right now, but most of the engine compartment is below that limit. Clearly, exhaust systems or parts near it should have all metal locknuts. Alex Peterson RV6A N66AP 654 hours Maple Grove, MN ________________________________________________________________________________
Date: Aug 15, 2005
Sorry John but I don't really know. It seems to me that there would be enough spring in the metal that it could be used again if necessary but it would be preferable to use a new one to also make sure it was clean. Ken John Schroeder wrote: > >Ken - > >Does one have to replace the internal star washers after they are used >once? Seems that it would be easy to mash the teeth flat after torquing >the nut & washe once. > >Thanks, > >John > > > > >>I think from the archives and the book you will see a preference for >>internal star washers and brass or phosphor bronze hardware but again >>I'd try not to add another type of metal to the joint if possible. >> >> > > > > ________________________________________________________________________________
Subject: Re: Small Video Display (was Fire Indication Probe_
Date: Aug 15, 2005
John - What is a fair price for one of these and where is a source? Many thanks, John > wrote: > Here is a website for a product used to digitally record inflight video > from 4 onboard lipstick cameras in our Red Star aircraft. -- ________________________________________________________________________________
Date: Aug 15, 2005
Subject: Re: OVP thoughts.
Hi Rob Someone else originally posted this link to Jim Weir's site where he uses one or more crowbar OVMs to pop the fuse(s) to the avionics. I think this is reasonable for VFR operations. It is not useful for those of us with electric dependant engines. http://www.rst-engr.com/kitplanes/KP0109/KP0109.htm You might want a handheld VHF and GPS though as then you lose main battery power to the avionics. You could use CB's and reset them after killing the alternator but I hate relying on multi-step manual procedures when under stress. On my machine I did not use battery contactors but all the non engine loads do route through a contactor to a fuse block. An OVM could also be wired to trip that contactor and protect the avionics. That presents a single point of failure for all avionics power though. No main battery power to the avionics during a trip is the problem with these methods so it is not a great solution for IFR where you want uninterupted power. It might have merit for expensive devices that have internal battery backups and warnings though. Ken Rob W M Shipley wrote: > >I'll start with humble apologies to all who have lost patience with this >topic. For those of us still having an interest in any resolution which may >be found I would like to ask the following. > >Given that many of us would like to use IR alternators for cost and >convenience reasons the issue becomes one of how we can protect our avionics >with a high degree of certainty. >1) Until a few days ago when Ken Lehman wrote about "an OVM module of some >kind protecting the supply to that $15k radio rack that you mentioned." I >hadn't seen anyone mention this as a solution, although I have wondered >about it myself. Why couldn't this prove a good way to save our wallets >leaving the alternator to be shut down manually? >2) Load dump (back emf ?) seems to be the alternator killer when crowbared >under load. Bob wrote "Actually, the neatest way (lowest parts count) to >run the > > snip ________________________________________________________________________________
Date: Aug 16, 2005
Probe_ John, Thanks for the link to this PVR. What kind of combiner are you using? That seems like the hard part... Thanks, Mickey John W. Cox wrote: > > Here is a website for a product used to digitally record inflight video > from 4 onboard lipstick cameras in our Red Star aircraft. The four > inputs are directed through a combiner into the 40gb storage unit. It > takes the high g's and shock forces and captures entire flight data > through plenty of imagery. It includes a touch-screen monitor. You can > view all four cams or select just one. > > It may meet the requirement. > <http://www.dbciglobalsource.com/PVR%20380.htm> > John Cox -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 16, 2005
Probe_ Dave Morris \"BigD\" Indication Probe_ wrote: > > I just bought a Lilliput 8" VGA display that is designed for the burgeoning > SUV kiddie movie market. (Soapbox) I think we will be seeing more and more > adults crashing their SUVs into each other because they were watching the > "kiddie movies" while driving. (/Soapbox) How many NITs (Cd per square metre) in brightness do these displays have? To be sunlight readable I expect 450-500 minimum. Doug Gray ________________________________________________________________________________
Subject: Heated pitot (newbie to the group)
Date: Aug 16, 2005
1.25 RCVD_NUMERIC_HELO Received: contains an IP address used for HELO Hi all, I have the opportunity to purchase a 24v heated pitot at a very reasonable price. Has anyone converted one of these to 12V? Has anyone used a 24v unit as-is with a 12V system? I'm not going to use it in ifr icing conditions, but I have been in a situation where dew in the pitot froze at altitude, and made landing very exciting! Thanks -Tom Hi all, I have the opportunity to purchase a 24v heated pitot at a very reasonable price. Has anyone converted one of these to 12V? Has anyone used a 24v unit as-is with a 12V system? I'm not going to use it inifr icing conditions, butI have been ina situation where dew in the pitot froze at altitude, and made landing very exciting! Thanks -Tom ________________________________________________________________________________
Date: Aug 16, 2005
From: "Dave Morris \"BigD\"" <BigD(at)DaveMorris.com> Indication Probe_
Indication Probe_ I don't know the specs. I only know that they are putting them in cars, and in my side-by-side comparisons, it wasn't as bright as my Sony Vaio laptop display. Dave Morris At 06:40 AM 8/16/2005, you wrote: > > >Dave Morris \"BigD\" Indication Probe_ wrote: > Indication Probe_ > > > > I just bought a Lilliput 8" VGA display that is designed for the > burgeoning > > SUV kiddie movie market. (Soapbox) I think we will be seeing more and > more > > adults crashing their SUVs into each other because they were watching the > > "kiddie movies" while driving. (/Soapbox) > > >How many NITs (Cd per square metre) in brightness do these displays have? >To be sunlight readable I expect 450-500 minimum. >Doug Gray > > ________________________________________________________________________________
Subject: Re: Heated pitot
Date: Aug 16, 2005
>I have the opportunity to purchase a 24v heated pitot at a very reasonable >price. Has anyone converted one of these to 12V? Has anyone used a 24v unit >as-is >with a 12V system? I'm not going to use it in ifr icing conditions, but I >have been in a situation where dew in the pitot froze at altitude, and made >landing >very exciting! > Thanks > -Tom Welcome Tom, Let's say the 24V pitot tube draws 12A. That means that the resistance should be 2 ohms and the power 288 W. If you run this at 12 V, the current draw will be only 6A and the power 72W. If it were my 12V airplane, and I planned no intentional suicidal flights into icing conditions, I'd do it. On the other hand the pitot might be set up with two heaters in series. (I've seen this). If so, you can change it to parallel. You can replace the 24V heaters with 12V heaters on some units too. For several years I've been New-England-Ice-Storm testing a thermostatic pitot tube for my Glastar that operates at 36W max. One of the odd characteristics is that it heats up only to 30 degC, so it doesn't even get to body temperature. When there is no need for heat, it draws only about 3W (~250 mA). It's on my website if you're interested. http://www.periheliondesign.com/downloads/thermopitot.pdf Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Every act of conscious learning requires the willingness to suffer an injury to one's self-esteem...." -Thomas Szasz ________________________________________________________________________________
Subject: Small Video Display NITS
Date: Aug 16, 2005
FYI, the LCD brightness in NITs probably should be in the 700 range for sunlight viewing. An IPAQ PDA has about 1000 NITs. My PCFlight Systems MFD is 1500 NITs and has no problems in bright FL sunlight. Jim Stone Jabiru J450 Clearwater FL -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Morris "BigD" Subject: Re: AeroElectric-List: Re: Small Video Display (was Fire Indication Probe_ --> Indication Probe_ I don't know the specs. I only know that they are putting them in cars, and in my side-by-side comparisons, it wasn't as bright as my Sony Vaio laptop display. Dave Morris At 06:40 AM 8/16/2005, you wrote: >--> > > >Dave Morris \"BigD\" Indication Probe_ wrote: > Indication Probe_ > > > > I just bought a Lilliput 8" VGA display that is designed for the > burgeoning > > SUV kiddie movie market. (Soapbox) I think we will be seeing more > > and > more > > adults crashing their SUVs into each other because they were > > watching the "kiddie movies" while driving. (/Soapbox) > > >How many NITs (Cd per square metre) in brightness do these displays >have? To be sunlight readable I expect 450-500 minimum. Doug Gray > > ________________________________________________________________________________
Date: Aug 16, 2005
USB camera fed to a typical USB 2.0 combiner. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: Re: AeroElectric-List: Re: Small Video Display (was Fire Indication Probe_ John, Thanks for the link to this PVR. What kind of combiner are you using? That seems like the hard part... Thanks, Mickey John W. Cox wrote: > > Here is a website for a product used to digitally record inflight video > from 4 onboard lipstick cameras in our Red Star aircraft. The four > inputs are directed through a combiner into the 40gb storage unit. It > takes the high g's and shock forces and captures entire flight data > through plenty of imagery. It includes a touch-screen monitor. You can > view all four cams or select just one. > > It may meet the requirement. > <http://www.dbciglobalsource.com/PVR%20380.htm> > John Cox -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 16, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Routing Antenna Leads
> >Hello Bob & List, > >I'm installing my Garmin panel mounted GPS/Comm (GNC 250-XL) with >Perihelion's RG+142 coax in a tube & fabric aircraft. The two antennas are >about 5' apart. The installation manual says to route the GPS cable 'as far >as possible' away from the Comm cable. Before reading that part I was >inclined to route them right next to each other. Now I don't really know >what to do. > >I couldn't find anything on this specific question in the archives. Is >there a minimum distance for good radio performance? > > Thanks, > Grant Krueger If they're both modern coax (RG400 or RG142) you can run them right together with any wires in any system. Bob . . . ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Advanced Aircraft Antenna Vs Bob Archer.
Hello Group: I'm looking for recommendations on the COM, NAV and Transponder antenna's made by Advanced Aircraft compared to Bob Archer designs when used in a composite aircraft. Anyone with real life experience or opinion? Thanks in advance. Brian Skelly Texas Europa # A276 TriGear See My build photos at: http://www.europaowners.org/BrianS ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Alternator Question
Hi, I've got a brand-new ND alternator, and when I turn the pulley, I feel a bit of resistance from time to time. It's the only alternator I've got, so I'm not sure if this is normal or not. It seems like it should turn very smoothly, with only bearing friction. Thanks for any hints. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 16, 2005
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
And resistance from te bearing seal at the front...this can sqweak a little when you fie=rst turn it. Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Subject: AeroElectric-List: Alternator Question --> Hi, I've got a brand-new ND alternator, and when I turn the pulley, I feel a bit of resistance from time to time. It's the only alternator I've got, so I'm not sure if this is normal or not. It seems like it should turn very smoothly, with only bearing friction. Thanks for any hints. Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 16, 2005
I don't have any experience in that field but I can sell you an Archer Com antenna that I was going to mount in the wingtip. I since decided that I will use a belly whip instead. Good price too. Franz RV7A -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of EuropaXSA276(at)aol.com Subject: AeroElectric-List: Advanced Aircraft Antenna Vs Bob Archer. Hello Group: I'm looking for recommendations on the COM, NAV and Transponder antenna's made by Advanced Aircraft compared to Bob Archer designs when used in a composite aircraft. Anyone with real life experience or opinion? Thanks in advance. Brian Skelly Texas Europa # A276 TriGear See My build photos at: http://www.europaowners.org/BrianS -- -- ________________________________________________________________________________
From: "ivorphillips" <ivor(at)ivorphillips.flyer.co.uk>
Subject: Re: Alternator Question
Date: Aug 16, 2005
I have Two ND alternators 40 amp/60 amp, Both are totally smooth in every direction, A strip and check is in order! Ivor Phillips XS486 London UK CM Installed, rudder cables complete, undercarriage fitted brakes working flap tube fitted wing lift pins fitted,tiebar fitted instrument panel being finalised, ----- Original Message ----- From: "Mickey Coggins" <mick-matronics(at)rv8.ch> Subject: AeroElectric-List: Alternator Question > > > Hi, > > I've got a brand-new ND alternator, and when I > turn the pulley, I feel a bit of resistance > from time to time. It's the only alternator I've > got, so I'm not sure if this is normal or not. > > It seems like it should turn very smoothly, with > only bearing friction. > > Thanks for any hints. > > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > > ________________________________________________________________________________
Date: Aug 16, 2005
On 16 Aug 2005, at 08:46, Dave Morris BigD Indication Probe_ wrote: > Indication Probe_ > > I don't know the specs. I only know that they are putting them in > cars, > and in my side-by-side comparisons, it wasn't as bright as my Sony > Vaio > laptop display. > I'm betting those cars don't have bubble canopys though, so the displays wouldn't need to be as bright as you would need in an RV. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 16, 2005
By "time to time," do you mean that it offers resistance at particular points in rotation of the shaft? It could be a number of things.. A bent shaft. Brush contact area has excessive runout, or roughness. Bad bearing.. Junk floating around in the unit. Maybe the two halves aren't mated properly (magnifying a runout problem). Maybe the fan is grossly out of round and contacting the housing in some places. It could be that the unit just needs a little break-in turning, and after 100 revs it would be fine. Alternators aren't difficult to disassemble (or reassemble), so a teardown might be the way to go. Let us know what you find.. Thanks, Matt- VE N34RD, C150 N714BK > > > Hi, > > I've got a brand-new ND alternator, and when I > turn the pulley, I feel a bit of resistance > from time to time. It's the only alternator I've > got, so I'm not sure if this is normal or not. > > It seems like it should turn very smoothly, with > only bearing friction. > > Thanks for any hints. > > Mickey > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > ________________________________________________________________________________
Subject: Re: More than 1 audio source into the Intercom Music
Input -
Date: Aug 16, 2005
Something to think about... "The PS Engineering PS 1000 II has an input impedance of 47 kOhm (music input)..." Another thing that the music input typically has is some sort of "muting" function, either partial, or full. The way this muting works, when the COM input is active, the volume on the music input is lowered. Which would result in the volume of the alarms also being lowered during COM transmissions. What I am considering doing is "mixing" all of my alarm outputs with the COM output, and feeding them into the COM input, so there would be no muting. I would then use the music input as a music input. I'm considering building one of Bob's Audio Isolation Amps to do the mixing, but if anyone knows of a reasonably priced "store-bought" unit I would appreciate hearing about it... ________________________________________________________________________________
Date: Aug 16, 2005
Subject: Re: Z-13/Z-30
> > >Vern W. wrote: > > > > > My preference is for the Z-13 architecture, but I'm pretty sure it was > >Bob N. himself who stated that the SD-8 MUST have a battery to excite it. It > >will not power up by itself. > > So what I have sort of settled on is the Z-13 plus the Z-30 additional > >battery (very small, say 4 amp) which does three things: It gives the SD-8 > >something to lean on to get it started if need be, the small additional > >battery can be use to keep (full voltage) power on my Lightspeed ignition > >when starting, and if both the main alternator and the primary battery go > >offline, the 4 amp battery with the SD-8 is plenty to keep all the important > >systems (and then some) up and running as long as needed. > > My big "problem" with just one battery is not the RG battery's > >dependability in general, but the (very?) possible occurance of a broken > >terminal. I know that's a "full bucket" as Bob says, but a broken battery > >terminal definitely qualifies as a "single point of failure" which we are > >all using as our baseline in electrical design. > > > > > >How about two batts *in parallel*? That is, straight Z-13 with no Z-30 >circuit but with two identical batts wired parallel. Eliminates the >terminal concern and an open cell as well. How about the failed battery contactor? > But this doesn't seem to be >a popular configuration. At least not from a search of the archives. >What am I missing? A shorted cell would still be disastrous but that is >far less likely and could be gotten around too. If I'm missing nothing >with this idea, than Z-13 with the SD-8 is what I'll do. If one is going to gather up concerns for open and shorted cells in well maintained RG batteries, then open control wires, failed master switches, loose nuts and bolts, and failed contactors should all be added too . . . > > I've seen some posters go a bit further and worry about scenarios of > >multiple failures, but the probabability of any more than one critical > >failure in a single flight is in the nth degree of possibility. If I lose my > >main battery, my main alternator goes over voltage, the SD-8 won't start, I > >start to smell smoke, and my one mag on the other side fails, and all this > >happens exactly while I'm flying on top a mountain range, then I'm simply > >going to assume that I have gotten a personal invitation from God to meet > >Him face to face which will allow me to enjoy the ride down :-) > > Or perhaps you have Joe Btfsplk stowed away in your baggage compartment . . . See: http://www.bookofjoe.com/2005/02/joe_btfsplk.html He rode with us on the Plymouth, MA seminar trip. Missed connections outbound, got a smoking room a 1 a.m. with not enough energy left to wrestle with the desk clerk, temperature was in 90's with fog (humidity 100%), a/c in meeting room was fritzed, slipped and went down in shower for non-smoking room (buggered right arm . . . a real handicap when you gotta wave your arms in front of a class!), missed connections outbound and spent night in Detroit, got home today 13 hrs late to learn that DERs are going to give me a ration of stuff about flying test equipment on customer airplane that I can't fix without the data . . . If it hadn't been for an exemplary bunch of seminar attendees, I would have come home really bummed out. All things considered . . . a great weekend! However, if you check the baggage compartment before departure and find the little guy in the black hat is absent, then the vast majority of what we worry about should be Wwwaaaaaayyyyyy down on the list of concerns. > > > >I made a similar comment in response to Bob earlier in this thread. :-> >Can't fight the big guy if he's got your number! > > > > In the end, I'd be just as confident to fly with the Z-19 design as much > >as the Z-13 + Z-30 design. While Z-19 is cheaper, it's a lot more weight > >that I won't need in my RV7-A. > > I'm not totally decided yet being that I won't have to start installing > >a chosen system until later this Fall, but Z-13 + Z30 looks good to me. Now > >if Bob would only add the Z-30 extra battery to the Z-13/SD-8 drawing and > >show it as one sheet... See http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdf/Z13-30.pdf Bob . . . ________________________________________________________________________________
Date: Aug 16, 2005
Hi Ken, My apologies for not being complete in my question. My thought of shutting down the primary supply to the avionics with a crowbar was with the intention of using a separate ebus battery supply to take over. Rob Rob W M Shipley N919RV (res) Fuselage .....still! La Mesa, CA. (next to San Diego) From: Ken <klehman(at)albedo.net> Subject: Re: AeroElectric-List: OVP thoughts. Hi Rob Someone else originally posted this link to Jim Weir's site where he uses one or more crowbar OVMs to pop the fuse(s) to the avionics. I think this is reasonable for VFR operations. It is not useful for those of us with electric dependant engines. http://www.rst-engr.com/kitplanes/KP0109/KP0109.htm You might want a handheld VHF and GPS though as then you lose main battery power to the avionics. You could use CB's and reset them after killing the alternator but I hate relying on multi-step manual procedures when under stress. On my machine I did not use battery contactors but all the non engine loads do route through a contactor to a fuse block. An OVM could also be wired to trip that contactor and protect the avionics. That presents a single point of failure for all avionics power though. No main battery power to the avionics during a trip is the problem with these methods so it is not a great solution for IFR where you want uninterupted power. It might have merit for expensive devices that have internal battery backups and warnings though. Ken -- Try www.SPAMfighter.com for free now! ________________________________________________________________________________
Date: Aug 17, 2005
----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Subject: AeroElectric-List: Re: Z-13/Z-30 > > > > > > > >Vern W. wrote: > > > > > > > > My preference is for the Z-13 architecture, but I'm pretty sure it was > > >Bob N. himself who stated that the SD-8 MUST have a battery to excite it. It > > >will not power up by itself. > > > So what I have sort of settled on is the Z-13 plus the Z-30 additional > > >battery (very small, say 4 amp) which does three things: It gives the SD-8 > > >something to lean on to get it started if need be, the small additional > > >battery can be use to keep (full voltage) power on my Lightspeed ignition > > >when starting, and if both the main alternator and the primary battery go > > >offline, the 4 amp battery with the SD-8 is plenty to keep all the important > > >systems (and then some) up and running as long as needed. > > > My big "problem" with just one battery is not the RG battery's > > >dependability in general, but the (very?) possible occurance of a broken > > >terminal. I know that's a "full bucket" as Bob says, but a broken battery > > >terminal definitely qualifies as a "single point of failure" which we are > > >all using as our baseline in electrical design. > > > > > > > > > >How about two batts *in parallel*? That is, straight Z-13 with no Z-30 > >circuit but with two identical batts wired parallel. Eliminates the > >terminal concern and an open cell as well. > > How about the failed battery contactor? Absolutely, Bob. All that would do is to trade off 1 SPF for another. > > > But this doesn't seem to be > >a popular configuration. At least not from a search of the archives. > >What am I missing? A shorted cell would still be disastrous but that is > >far less likely and could be gotten around too. If I'm missing nothing > >with this idea, than Z-13 with the SD-8 is what I'll do. > > If one is going to gather up concerns for open and shorted cells > in well maintained RG batteries, then open control wires, failed > master switches, loose nuts and bolts, and failed contactors should > all be added too . . . Of course, but any single failure of those kind of issues will still result in some available power, ESPECIALLY if one has the availability of an alternate exciter for the SD-8 (i.e., by adding the Z30 to Z13).. > > > > > I've seen some posters go a bit further and worry about scenarios of > > >multiple failures, but the probabability of any more than one critical > > >failure in a single flight is in the nth degree of possibility. If I lose my > > >main battery, my main alternator goes over voltage, the SD-8 won't start, I > > >start to smell smoke, and my one mag on the other side fails, and all this > > >happens exactly while I'm flying on top a mountain range, then I'm simply > > >going to assume that I have gotten a personal invitation from God to meet > > >Him face to face which will allow me to enjoy the ride down :-) > > > > > Or perhaps you have Joe Btfsplk stowed away in your baggage > compartment . . . See: I have gone through some short periods in my life where I'm sure he was my traveling companion so I'm familiar with the gentleman. I'll bet no one under 45 years old knows what we're talking about and who Joe Btfsplk is :-) oh, wait, that's :-( > > http://www.bookofjoe.com/2005/02/joe_btfsplk.html > > He rode with us on the Plymouth, MA seminar trip. Missed > connections outbound, got a smoking room a 1 a.m. with > not enough energy left to wrestle with the desk clerk, > temperature was in 90's with fog (humidity 100%), > a/c in meeting room was fritzed, slipped and went down > in shower for non-smoking room (buggered right arm . . . > a real handicap when you gotta wave your arms in front > of a class!), missed connections outbound and spent > night in Detroit, got home today 13 hrs late to learn > that DERs are going to give me a ration of stuff about > flying test equipment on customer airplane that I can't > fix without the data . . . > > If it hadn't been for an exemplary bunch of seminar > attendees, I would have come home really bummed out. > All things considered . . . a great weekend! > > However, if you check the baggage compartment before > departure and find the little guy in the black hat > is absent, then the vast majority of what we worry > about should be Wwwaaaaaayyyyyy down on the list of > concerns. > > > > > > > > >I made a similar comment in response to Bob earlier in this thread. :-> > >Can't fight the big guy if he's got your number! > > > > > > > In the end, I'd be just as confident to fly with the Z-19 design as much > > >as the Z-13 + Z-30 design. While Z-19 is cheaper, it's a lot more weight > > >that I won't need in my RV7-A. > > > I'm not totally decided yet being that I won't have to start installing > > >a chosen system until later this Fall, but Z-13 + Z30 looks good to me. Now > > >if Bob would only add the Z-30 extra battery to the Z-13/SD-8 drawing and > > >show it as one sheet... > > See http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdf/Z13-30.pdf > > Bob . . . So, you thought maybe there was something to it and decided to draw it, eh? :-) Thanks Bob! > > ________________________________________________________________________________
Subject: "Air" Switch & Antenna Ground Plane
Date: Aug 17, 2005
A couple of questions... In researching Transponders, many of the Install Manuals reference the use of an "Air Switch" to switch the Transponder in and out of Standby mode as the aircraft's airspeed crosses 30 kts+/-. Does anyone know anything about these Air Switches and/or a source for them? Will the aluminum and steel structure of a fabric-covered aircraft make a suitable ground plane for the various antennas to be used on the airplane? Thanks! ________________________________________________________________________________
Date: Aug 17, 2005
Now I thought someone on this list talked to B&C who said the SD-8 would self excite?? Remember also that if you did have a battery terminal break, your main alternator will still provide power and keep the battery contactor closed. Personally I intend to connect the SD-8 directly to the battery buss (I have a electrically dependant airplane) so assuming it will self excite it takes care of the failure of both the battery terminal and a failed #1 alternator. Am I out to lunch here?? Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vern W. Subject: Re: AeroElectric-List: Re: Z-13/Z-30 ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Subject: AeroElectric-List: Re: Z-13/Z-30 > > > > > > > >Vern W. wrote: > > > > > > > > My preference is for the Z-13 architecture, but I'm pretty sure it was > > >Bob N. himself who stated that the SD-8 MUST have a battery to excite it. It ________________________________________________________________________________
Date: Aug 17, 2005
Subject: Re: "Air" Switch & Antenna Ground Plane
Many airports now want transponders on for all ground movement. If not I would just use STBY. If you forget, DEP control will remind you. ----- Original Message ----- From: Bill Denton <bdenton(at)bdenton.com> Date: Wednesday, August 17, 2005 8:54 am Subject: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > A couple of questions... > > In researching Transponders, many of the Install Manuals reference > the use > of an "Air Switch" to switch the Transponder in and out of Standby > mode as > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > anything about > these Air Switches and/or a source for them? > > Will the aluminum and steel structure of a fabric-covered aircraft > make a > suitable ground plane for the various antennas to be used on the > airplane? > Thanks! > > > > > > > ________________________________________________________________________________
Date: Aug 17, 2005
Music Input - That is what I did with my DRE intercom. I needed to get the AOA warning into the unit and the DRE mutes the music input when something comes on the COM input. Another thing to think about is the Pilot Isolate Mode. I can let the passenger listen to the music and not the COM, and I can have COM and not music. If the warning sounds were on the music input I can isolate myself from them and not hear them at all. I just used a simple passive mixing circuit that an engineer at DRE sketched and sent to me. BTW a plug for DRE: That engineer sketched the circuit for me even though he knew that I did not buy the unit from them. I got it off of Ebay. I have had great dealings with them. Oh and the intercom sounds awesome!!!! Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Bill Denton wrote: > >Something to think about... > >"The PS Engineering PS 1000 II has an input impedance of 47 kOhm (music >input)..." > >Another thing that the music input typically has is some sort of "muting" >function, either partial, or full. The way this muting works, when the COM >input is active, the volume on the music input is lowered. Which would >result in the volume of the alarms also being lowered during COM >transmissions. > >What I am considering doing is "mixing" all of my alarm outputs with the COM >output, and feeding them into the COM input, so there would be no muting. I >would then use the music input as a music input. > >I'm considering building one of Bob's Audio Isolation Amps to do the mixing, >but if anyone knows of a reasonably priced "store-bought" unit I would >appreciate hearing about it... > > > > ________________________________________________________________________________
Date: Aug 18, 2005
Frank, the SD8 will not self excite. Period. And even if it is running it may not reliably continue to do so without a battery connected. >From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> >Reply-To: aeroelectric-list(at)matronics.com >To: >Subject: RE: AeroElectric-List: Re: Z-13/Z-30 >Date: Wed, 17 Aug 2005 07:09:15 -0700 > > > >Now I thought someone on this list talked to B&C who said the SD-8 would >self excite?? > >Remember also that if you did have a battery terminal break, your main >alternator will still provide power and keep the battery contactor >closed. > >Personally I intend to connect the SD-8 directly to the battery buss (I >have a electrically dependant airplane) so assuming it will self excite >it takes care of the failure of both the battery terminal and a failed >#1 alternator. > >Am I out to lunch here?? > >Frank > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vern >W. >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Re: Z-13/Z-30 > > >----- Original Message ----- >From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> >To: >Subject: AeroElectric-List: Re: Z-13/Z-30 > > > > > > > > > > > > > > > >Vern W. wrote: > > > > > > > > > > > My preference is for the Z-13 architecture, but I'm pretty sure >it >was > > > >Bob N. himself who stated that the SD-8 MUST have a battery to >excite >it. It > > SEEK: Over 80,000 jobs across all industries at Australia's #1 job site. http://ninemsn.seek.com.au?hotmail ________________________________________________________________________________
Date: Aug 18, 2005
SpamAssassin (score=-2.58, required 3.7, autolearn=not spam, AWL 0.02, BAYES_00 -2.60) >>Now I thought someone on this list talked to B&C who said the >>SD-8 would self excite?? That would be me :-) I spoke with Jim @ B&C and that is what I got from our conversation. But, I am also not that electrically savvy and could have mis-understood something. It would be a good thing for someone here with a good handle on the issues to talk with Jim and verify. -- Larry E. James Bellevue, WA Harmon Rocket II ________________________________________________________________________________
Date: Aug 18, 2005
Subject: Re: trim relay deck trim speed control
Lui, Sorry to take so long to get back to you. I've downloaded the data you cited below and I'm sorry to report that the Ray Allen speed control module and Infinity relay deck are not compatible. For compatibility, the relay deck needs to have separate supply lines to relay coils for control and motor power so that the adjustable output voltage of the speed controller affects only the motor and leaves relay coil supply power at full bus voltage. Bob . . . > > > >I have the Infinity Aeropsace Trim Relay Deck, see at > >http://www.infinityaerospace.com/Relay_Deck_Wiring_Schematic.jpg > >I am trying to install a Ray Allen Speed control for the pitch trim but have >a few ?? on the wiring. > >http://www.rayallencompany.com/RACmedia/instructionsSPD.pdf > >Not sure where to connect the red wire from the Speed control to the >Infinity Relay Deck. The Relay Deck only has a > >1. A port for Trim motor >2. B port for Trim motor >3. +12 v >4. Ground > >It doesn't have a provision for "blue wire" like shown on Diagram 2 of the >Ray Allen schematic. I guess it is so simple that I don't see it. > > >Thank you, > >Lui > > >-- > > >-- incoming mail is certified Virus Free. Bob . . . -------------------------------------------------------- < Throughout history, poverty is the normal condition > < of man. Advances which permit this norm to be > < exceeded -- here and there, now and then -- are the > < work of an extremely small minority, frequently > < despised, often condemned, and almost always opposed > < by all right-thinking people. Whenever this tiny > < minority is kept from creating, or (as sometimes > < happens) is driven out of a society, the people > < then slip back into abject poverty. > < > < This is known as "bad luck". > < -Lazarus Long- > <------------------------------------------------------> http://www.aeroelectric.com ________________________________________________________________________________
Date: Aug 18, 2005
> Z-13 + Z30 looks good to me. >Now > >if Bob would only add the Z-30 extra battery to the Z-13/SD-8 drawing > >and show it as one sheet... > See http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdf/Z13-30.pdf > > > > Bob . . . > >So, you thought maybe there was something to it and decided to draw it, eh? >:-)Thanks Bob! Note that the drawing doesn't have a z-figure . . . and probably won't. I've had several requests for this particular configuration and it didn't take too long to customize a copy of Z-13 and add it to PagePerSystem drawings on the website . . . Bob . . . ________________________________________________________________________________
Date: Aug 18, 2005
Folks, keep in mind that (1) OV comes from ONE and ONE source only, a mis-behaving alternator. Further, there are more devices in the airplane vulnerable to the ov condition than just "avionics". (2) If one subscribes to the notion that your particular choice of internally regulated is sufficiently immune to OV runaway events, then a choice of OV protection schemes is a moot point. (3) If you subscribe to the notion that your alternator of choice needs to be controllable for conducting pre-flight tests of auxiliary alternators -AND- for dealing with smoke-in-the-cockpit events, then some means of positive ON/OFF control from the cockpit is indicated. (4) If you're not convinced with respect to immunity from OV failures, then an OV event can be brought to heel in a relatively by means of positive ON/OFF control cited in (3). What ever means of OV sense, reaction and control, the alternator should be shut down in a reasonably short period of time (say under 500 milliseconds assuming a healthy battery - - and none of us plan to fly with a sick battery - - right?). >Someone else originally posted this link to Jim Weir's site where he >uses one or more crowbar OVMs to pop the fuse(s) to the avionics. I >think this is reasonable for VFR operations. It is not useful for those >of us with electric dependant engines. (5)If you control the OV condition at the SOURCE, then ALL vulnerable features of the aircraft's electrical system are protected irrespective of whether or not your engine is electrically dependent. >http://www.rst-engr.com/kitplanes/KP0109/KP0109.htm >You might want a handheld VHF and GPS though as then you lose main >battery power to the avionics. You could use CB's and reset them after >killing the alternator but I hate relying on multi-step manual >procedures when under stress. > >On my machine I did not use battery contactors but all the non engine >loads do route through a contactor to a fuse block. An OVM could also be >wired to trip that contactor and protect the avionics. That presents a >single point of failure for all avionics power though. No main battery >power to the avionics during a trip is the problem with these methods so >it is not a great solution for IFR where you want uninterupted power. It >might have merit for expensive devices that have internal battery >backups and warnings though. Would you care to post some power distribution diagrams that describe your architecture. The lack of battery contactors piques our interest. You've expressed some interest in management of an OV event . . . it seems that elimination of battery contactors offers possibilities for some equally exciting failure modes that battery contactors are expected to control . . . Bob . . . ________________________________________________________________________________
Date: Aug 18, 2005
> > >Now I thought someone on this list talked to B&C who said the SD-8 would >self excite?? > >Remember also that if you did have a battery terminal break, your main >alternator will still provide power and keep the battery contactor >closed. > >Personally I intend to connect the SD-8 directly to the battery buss (I >have a electrically dependant airplane) so assuming it will self excite >it takes care of the failure of both the battery terminal and a failed >#1 alternator. No, it won't. But it's easy to make sure you don't break a battery terminal . . . >Am I out to lunch here?? The SD-8 in its present configuration has been unchanged since day-one and will not come on line by itself. To the best of my knowledge, there are no plans to change this . . . although it would be easy to do. Folks who are unhappy about this and would like to see a well- considered product improvement are encouraged to make their wishes known to B&C. You ARE, after all, the CUSTOMERS. In the mean time, my personal choice for system architecture in an OBAM aircraft would be Z-13/8 and dual p-mags. This combination offers quantum jumps in system reliability over and above current certified products which are ALREADY relatively immune to electrical system failures that grow into catastrophic events. If you're willing to launch into the gray stuff in a well equipped certified ship, then an airplane fitted with upgrades offered by the Z-13/8 w/p-mags stands very tall over the certified iron. In the interest of consistency and well considered, incremental improvements to the best we know how to do today, I'll suggest that forward thinking individuals take one of the Z-figures and then identify ways in which their personal design goals are not being met. Proposed changes/additions are easy to evaluate for potential "gotchas" . . . just put them out here on the list for discussion. Folks who are still in the decision-making modes should be cautious of embracing proposed derivatives before they've been posted to the list and reduced to their component simple- ideas. This is not a discouragement of anyone's plans to install whatever system offers them the most comfort. I'm only suggesting that the neophyte builder embrace such enhancements with caution and ideally only after new ideas have been evaluated for failure to meet all design goals. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2005
Bob, This seems to be the most talked about subject on this list and to some extent the most confusing. What is your current recommendation for a "positive off within 500ms" . . . I had heard / read that you had concerns regarding earlier proposed solutions (due to parts not performing as planned)?? Thanks, Bob Christensen On 8/18/05, Robert L. Nuckolls, III wrote: > > nuckollsr(at)cox.net> > > Folks, keep in mind that > > (1) OV comes from ONE and ONE source only, a mis-behaving alternator. > Further, there are more devices in the airplane vulnerable to the > ov condition than just "avionics". > > (2) If one subscribes to the notion that your particular choice > of internally regulated is sufficiently immune to OV runaway > events, then a choice of OV protection schemes is a moot point. > > (3) If you subscribe to the notion that your alternator of choice > needs to be controllable for conducting pre-flight tests of auxiliary > alternators -AND- for dealing with smoke-in-the-cockpit events, > then some means of positive ON/OFF control from the cockpit is > indicated. > > (4) If you're not convinced with respect to immunity from OV > failures, then an OV event can be brought to heel in a relatively > by means of positive ON/OFF control cited in (3). What ever > means of OV sense, reaction and control, the alternator should > be shut down in a reasonably short period of time (say under > 500 milliseconds assuming a healthy battery - - and none of > us plan to fly with a sick battery - - right?). > > > >Someone else originally posted this link to Jim Weir's site where he > >uses one or more crowbar OVMs to pop the fuse(s) to the avionics. I > >think this is reasonable for VFR operations. It is not useful for those > >of us with electric dependant engines. > > > (5)If you control the OV condition at the SOURCE, then ALL > vulnerable features of the aircraft's electrical system > are protected irrespective of whether or not your engine > is electrically dependent. > > >http://www.rst-engr.com/kitplanes/KP0109/KP0109.htm > >You might want a handheld VHF and GPS though as then you lose main > >battery power to the avionics. You could use CB's and reset them after > >killing the alternator but I hate relying on multi-step manual > >procedures when under stress. > > > >On my machine I did not use battery contactors but all the non engine > >loads do route through a contactor to a fuse block. An OVM could also be > >wired to trip that contactor and protect the avionics. That presents a > >single point of failure for all avionics power though. No main battery > >power to the avionics during a trip is the problem with these methods so > >it is not a great solution for IFR where you want uninterupted power. It > >might have merit for expensive devices that have internal battery > >backups and warnings though. > > Would you care to post some power distribution diagrams that > describe your architecture. The lack of battery contactors piques > our interest. You've expressed some interest in management > of an OV event . . . it seems that elimination of battery contactors > offers possibilities for some equally exciting failure modes > that battery contactors are expected to control . . . > > Bob . . . > > ________________________________________________________________________________
Date: Aug 18, 2005
> > > >Frank, the SD8 will not self excite. Period. And even if it is running it >may not reliably continue to do so without a battery connected. If the capacitor shown in schematics that feature the SD-8 is included, the SD-8 will run fine sans battery . . . but it's extremely unlikely that it will ever be required to do so. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2005
Bob, As a new builder trying to develop an understanding of aircraft electrical systems, I would appreciate your detailed recommendation for achieving "control of the OV condition at the SOURCE" as stated in (5) below. I've followed the OV discussions for several weeks and remain totally confused. Thanks, Roger Mell ----- Original Message ----- From: Robert L. Nuckolls, III<mailto:nuckollsr(at)cox.net> To: aeroelectric-list(at)matronics.com Sent: Thursday, August 18, 2005 12:11 PM Subject: Re: AeroElectric-List: OVP thoughts Folks, keep in mind that (1) OV comes from ONE and ONE source only, a mis-behaving alternator. Further, there are more devices in the airplane vulnerable to the ov condition than just "avionics". (2) If one subscribes to the notion that your particular choice of internally regulated is sufficiently immune to OV runaway events, then a choice of OV protection schemes is a moot point. (3) If you subscribe to the notion that your alternator of choice needs to be controllable for conducting pre-flight tests of auxiliary alternators -AND- for dealing with smoke-in-the-cockpit events, then some means of positive ON/OFF control from the cockpit is indicated. (4) If you're not convinced with respect to immunity from OV failures, then an OV event can be brought to heel in a relatively by means of positive ON/OFF control cited in (3). What ever means of OV sense, reaction and control, the alternator should be shut down in a reasonably short period of time (say under 500 milliseconds assuming a healthy battery - - and none of us plan to fly with a sick battery - - right?). >Someone else originally posted this link to Jim Weir's site where he >uses one or more crowbar OVMs to pop the fuse(s) to the avionics. I >think this is reasonable for VFR operations. It is not useful for those >of us with electric dependant engines. (5)If you control the OV condition at the SOURCE, then ALL vulnerable features of the aircraft's electrical system are protected irrespective of whether or not your engine is electrically dependent. >http://www.rst-engr.com/kitplanes/KP0109/KP0109.htm >You might want a handheld VHF and GPS though as then you lose main >battery power to the avionics. You could use CB's and reset them after >killing the alternator but I hate relying on multi-step manual >procedures when under stress. > >On my machine I did not use battery contactors but all the non engine >loads do route through a contactor to a fuse block. An OVM could also be >wired to trip that contactor and protect the avionics. That presents a >single point of failure for all avionics power though. No main battery >power to the avionics during a trip is the problem with these methods so >it is not a great solution for IFR where you want uninterupted power. It >might have merit for expensive devices that have internal battery >backups and warnings though. Would you care to post some power distribution diagrams that describe your architecture. The lack of battery contactors piques our interest. You've expressed some interest in management of an OV event . . . it seems that elimination of battery contactors offers possibilities for some equally exciting failure modes that battery contactors are expected to control . . . Bob . . . ________________________________________________________________________________
Subject: FW: [c-a] Final (REALLY) PMag Update - Part 1
Date: Aug 18, 2005
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
0.06 HTML_TEXT_AFTER_BODY BODY": aeroelectric-list(at)matronics.com Seeing how there has been suggestions that Pmags are the way to go, I thought I would forward this on as a heads up from the canard group....... -----Original Message----- From: canard-aviators(at)yahoogroups.com [mailto:canard-aviators(at)yahoogroups.com] On Behalf Of Marc J. Zeitlin Subject: [c-a] Final (REALLY) PMag Update - Part 1 Folks: Yesterday I flew down from Fitchburg, MA to Brookhaven, NY to visit Ken Miller's shop. I had arranged with Ken to purchase an impulse magneto from him to replace the PMag that I've had on my engine. Ken would supervise the installation and help out with any issues that arose. The Emagair folks had suggested one last test for my flight down. I had thought that heat might be damaging the electrolytic capacitors in the unit, so I put a 2200 mF, 35V electrolytic across the +/- leads into the PMag (as they suggested). The thought was that if the internal caps were damaged or degraded, this would add enough capacitance to reverse the damage. No such luck (if you'd call it luck to pinpoint the problem, rather than having it still be undefined) - the capacitor did NOT change the "missing" issue that I've been having. Anyway, after an uneventful flight, I sent my wife off to visit her mother, and took the cowling off to let the engine cool a bit. I removed the Pmag, the auto plugs and the wiring harness, disconnected the MP tap to the Pmag, and made a small jumper harness to connect the magneto P-Lead back to the airplane. One thing that jumped (and I mean JUMPED) out at Ken when he examined the Pmag was damage/wear to the Pmag gear. This is supposed to be a non-impulse mag gear, which you can either take off of a non-impulse magneto, buy at a flea market, spend $400 purchasing new from Lycoming, or buy from Emagair as shown at: http://www.emagair.com/E-MAG_product_page.htm Emagair has contracted to have these made for them, but they are NOT certified. After the first 5-10 hours of use, I had seen what I thought was excessive wear on this gear. I had mentioned it to Emagair, and during one of the PMag's frequent visits home, they got to see it. At any rate, there was a LOT of wear. Ken was VERY concerned, and since I had been planning on doing an oil change within the next few hours anyway, I decided to do it there. Ken also called in two engine experts that were in hangars nearby and got them to look at the gear, as well as to look inside the accessory case and check out the engine gears. Upon inspecting the accessory case gears, no excessive wear or damage was found, except for a few small dings in the drive gear which they did not find troubling (and were probably caused by the magneto being loose last year during my flight from VA to TN to MO). This was a good thing. When we cut open the filter and examined it, there was a fair amount of ferrous metal in the filter - Ken said he's seen way worse, but it was definitely more than there should be, and it was something to be concerned with. All three of the engine folks (Ken and the other two) were convinced that the metal had come off of the Pmag produced gear. They all said that the gear should have been hardened, and shouldn't have been able to wear like that. We took a file to one tooth, and it cut easily - it obviously was NOT hardened, as the engine guys said it should have been. After much discussion and a phone call to Mattituck, they determined that since the engine had been running for about 40 - 50 hours to make the metal in the filter, and since there did not seem to be any degradation in the power output, there PROBABLY was no other damage inside the engine, but that the gear was a BIG problem. So I did the oil change, we put on a new filter, and we would test the "no damage" theory, later. to be continued: -- Marc J. Zeitlin mailto:marc_zeitlin(at)alum.mit.edu http://marc.zeitlin.home.comcast.net/ http://www.cozybuilders.org/ Copyright (c) 2005 <*> To visit your group on the web, go to: http://groups.yahoo.com/group/canard-aviators/ <*> To unsubscribe from this group, send an email to: canard-aviators-unsubscribe(at)yahoogroups.com http://docs.yahoo.com/info/terms/ ________________________________________________________________________________
Subject: FW: [c-a] Final (REALLY) PMag Update - Part 2
Date: Aug 18, 2005
0.06 HTML_TEXT_AFTER_BODY BODY": aeroelectric-list(at)matronics.com -----Original Message----- From: canard-aviators(at)yahoogroups.com [mailto:canard-aviators(at)yahoogroups.com] On Behalf Of Marc J. Zeitlin Subject: [c-a] Final (REALLY) PMag Update - Part 2 continued: We installed the new Impulse Magneto, wiring harness, and a set of iridium plugs, and timed it. With Ken's help, timing the impulse mag, which had taken me the better part of a day and a great deal of a few folks sanity to perform last year in St. Louis, took about 10 minutes. To paraphrase Sean Connery in "The Wind and the Lion": "It is good to know what one is doing". After hooking up everything, connecting the wires, hoses, lines, tie wraps, and every other damn thing that we had taken apart, we did a 2 minute test run of the engine to look for leaks or other problems. There were none. I then went up for a 20 minute flight to circulate the oil through the filter and take out any remaining metal, if any. After landing, I removed the cowl and filter, and we cut that open. There was a completely insignificant amount of ferrous metal in it, if any. That indicated to Ken that at least the engine wasn't making any metal on it's own, at least not much. He said to keep a close eye on it, so I'll be changing/checking filters every 25 hours for the next few oil changes, rather than 50 hours. The flight with the magneto was fine - no "missing", no issues whatsoever. Both mags have almost exactly the same RPM drop during runup, and everything is nominal. It feels VERY strange to be reverting to 60-70 year old technology, but I needed an airplane that I could fly every day without having to explain to my wife why it sounds like my old Volkswagen fastback that I bought for $75 in 1980, when it was already 10 years old. So there are two big issues here, as I see them. First, the "missing" issue. We still have no idea why my unit(s) continued to exhibit the "missing" problem, even after the firmware update that was supposed to fix it. Especially since it SEEMED fixed for about 15 hours just before and during OSH, and then reappeared on the temporary Emag, and then immediately on the "permanent" Pmag. This is an issue for Emagair to investigate, should they choose to do so. They will have both of my units by mid-next week, and will be refunding my money in full (which will pay for the magneto, the gear, the wiring harness, the plugs, and leave me with a couple hundred $$$ left over for some dinners in Lancaster, when we get out there :-) ). Secondly, the "gear" issue. Since Lycoming sees fit to charge $400 for a gear that, were it manufactured in quantity, would cost about $10-$20, there is great pressure to find a cheaper source. The $85 gear from Emagair is just that. However, it seems that AT LEAST FOR THE GEAR THAT I HAD ON MY PMAG, either the material, the hardening, and/or the tooth shape was NOT correct. We held the gear up to the gear on the impulse mag, and it did NOT appear identical in tooth shape, although it was a bit hard to tell due to the material displacement/wear. Since a file could touch it, we know that it was not hardened. Because of these problems, I had a lot of metal in my engine that shouldn't have been there. I may be lucky and not have this cause a problem, but if it does, I will have to have some serious conversations with Emagair regarding expenses incurred to deal with them. Let's all hope that doesn't happen. I would suggest, however, that anyone with an Emag or Pmag on their running engine remove them to examine the gear for wear/damage. Maybe my gear was an anomaly - god knows that I seem to have more than my fair share of them, but if there was a bad run of gears, folks should check to make sure that they're not making metal in their engines, too. Try to file a tip of one gear tooth - if the file takes off metal, it's not hardened. Check with YOUR engine experts to see if they concur that it SHOULD be hardened - that's what Ken and his two guys said. Anyway, I do want to reiterate that Brad and Tom at Emagair are terrific people, with a great focus on customer support and satisfaction. I REALLY hope that they are successful, and can figure out what's going on here so that in time I can get one of these units on my airplane. I request that anyone flying with these units report back to everyone, letting us know how they work, on a regular basis - if I'm the one exception that proves the rule, so be it - there's always one or two. Thanks. -- Marc J. Zeitlin mailto:marc_zeitlin(at)alum.mit.edu http://marc.zeitlin.home.comcast.net/ http://www.cozybuilders.org/ Copyright (c) 2005 <*> To visit your group on the web, go to: http://groups.yahoo.com/group/canard-aviators/ <*> To unsubscribe from this group, send an email to: canard-aviators-unsubscribe(at)yahoogroups.com http://docs.yahoo.com/info/terms/ ________________________________________________________________________________
Subject: NARCO Help
Date: Aug 18, 2005
8/18/2005 Hello Avionics Experts, My friend has a Cessna 172 with a NARCO CP 136 TSO audio control panel in it. One selects which radio to transmit on or which receivers to listen to by pushing in round buttons. No intercom is incorporated. He has been having VHF radio transmitter problems that appear after an hour or so of flight. Since both transmitters send out just basic carrier with no voice included after this failure mode happens it has been assumed that the failure may be heat related and caused within the audio panel since both transmitters are affected the same way at the same time. When the problem was discussed with a local avionics shop their analysis was that it could not be a heat related problem within the audio panel because the audio panel was a simple mechanical device with no electronics inside. Nevertheless their solution was to replace the audio control panel with a modern PS Engineering audio control panel and intercom at the cost of big bucks. Can anyone confirm this description of the inner workings and hidden mechanisms of this audio control panel? Can anyone come up with a better (cheaper) cure than the one described above? Thank you. OC ________________________________________________________________________________
Subject: Re: Avionics-List: NARCO Help
Date: Aug 18, 2005
I had that problem when I first wired my MustangII. The audio out from the mic was grounded through a pinched wired to ground behind the instrument panel. Does both pilot and copilot have that same problem? Find the audio out wire from the audio panel (btw, I have found NARCO stuff to be CRAP!) and from the affected mic and check it with a multimeter to ground. If it shows continuity to ground, that's the problem Wayne ----- Original Message ----- From: <bakerocb(at)cox.net> Subject: Avionics-List: NARCO Help > --> Avionics-List message posted by: > > 8/18/2005 > > Hello Avionics Experts, My friend has a Cessna 172 with a NARCO CP 136 > TSO > audio control panel in it. One selects which radio to transmit on or which > receivers to listen to by pushing in round buttons. No intercom is > incorporated. > > He has been having VHF radio transmitter problems that appear after an > hour > or so of flight. Since both transmitters send out just basic carrier with > no > voice included after this failure mode happens it has been assumed that > the > failure may be heat related and caused within the audio panel since both > transmitters are affected the same way at the same time. > > When the problem was discussed with a local avionics shop their analysis > was > that it could not be a heat related problem within the audio panel because > the audio panel was a simple mechanical device with no electronics inside. > Nevertheless their solution was to replace the audio control panel with a > modern PS Engineering audio control panel and intercom at the cost of big > bucks. > > Can anyone confirm this description of the inner workings and hidden > mechanisms of this audio control panel? Can anyone come up with a better > (cheaper) cure than the one described above? Thank you. > > OC > > > ________________________________________________________________________________
Date: Aug 18, 2005
AeroElectric-List message previously posted by: bniles(at)cfl.rr.com Many airports now want transponders on for all ground movement. If not I would just use STBY. If you forget, DEP control will remind you. > > A couple of questions... > > In researching Transponders, many of the Install Manuals reference > the use > of an "Air Switch" to switch the Transponder in and out of Standby > mode as > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > anything about > these Air Switches and/or a source for them?.....skip...... 8/18/2005 Hello Bill and bniles, A couple of points if I may: 1) Many modern avionics installations have an interface between the GPS box and the transponder that automatically turns the transponder on into "Standby" and then on into "Altitude" modes when appropriate. Applying power to my avionics bus causes the Garmin GNS 430 to come on if the on box switch is left in the ON position. Applying power to my avionics bus causes my GTX 327 to come on in the Standby mode regardless of any on box switch positions (they are all momentary push buttons). When the GPS tells the transponder that the airplane is airborne and going above a certain speed the transponder automatically shifts from Standby to Altitude mode -- no action at all is required by the pilot. This feature could be considered an "Air Switch" by some people. 2) If operation of the transponder is done automatically as described above, those airports that are expecting the transponders to be on while the aircraft is on the ground will have to implement some sort of override action by the pilots in order to make this happen. OC ________________________________________________________________________________
Date: Aug 18, 2005
On my GTX 330, pressing the on button overrides the stby function and the transponder functions, even if on the ground and under 30 kts. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: "Air" Switch & Antenna Ground Plane AeroElectric-List message previously posted by: bniles(at)cfl.rr.com Many airports now want transponders on for all ground movement. If not I would just use STBY. If you forget, DEP control will remind you. > > A couple of questions... > > In researching Transponders, many of the Install Manuals reference > the use > of an "Air Switch" to switch the Transponder in and out of Standby > mode as > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > anything about > these Air Switches and/or a source for them?.....skip...... 8/18/2005 Hello Bill and bniles, A couple of points if I may: 1) Many modern avionics installations have an interface between the GPS box and the transponder that automatically turns the transponder on into "Standby" and then on into "Altitude" modes when appropriate. Applying power to my avionics bus causes the Garmin GNS 430 to come on if the on box switch is left in the ON position. Applying power to my avionics bus causes my GTX 327 to come on in the Standby mode regardless of any on box switch positions (they are all momentary push buttons). When the GPS tells the transponder that the airplane is airborne and going above a certain speed the transponder automatically shifts from Standby to Altitude mode -- no action at all is required by the pilot. This feature could be considered an "Air Switch" by some people. 2) If operation of the transponder is done automatically as described above, those airports that are expecting the transponders to be on while the aircraft is on the ground will have to implement some sort of override action by the pilots in order to make this happen. OC ________________________________________________________________________________
Subject: Concentric controls
Date: Aug 19, 2005
My intercom has the squelch and volume controls on concentric shafts. The inner volume control is loose enough that vibration causes it to change position in flight. Is there a method of adding mechanical resistance to that shaft without causing the outer knob to rotate at the same time? TIA, Bruce McGregor ________________________________________________________________________________
Subject: Antenna Cable Connector Source
Date: Aug 19, 2005
No luck in the archives. Does anyone have a source for the BNC type coaxial cable connector attached to the transponder tray with a snap ring on the Garmin GTX320A? My unit came with a solder type connector & I would like to have a BNC style connection to simplify panel removal. The Garmin part number is 330-00326-00. Dave Reel - RV8A ________________________________________________________________________________
Subject: Re: Concentric controls
Date: Aug 19, 2005
>My intercom has the squelch and volume controls on concentric shafts. The > inner volume control is loose enough that vibration causes it to change > position in flight. Is there a method of adding mechanical resistance to > that shaft without causing the outer knob to rotate at the same time? >TIA, Bruce McGregor If you had a bunch of potentiometers and needed to make them all feel the same (The "sine qua non" of potentiometer manufacturers), you COULD have them machined incredibly precisely and then screw around until you went bankrupt. Or---- You could make a carefully formulated silicone lubricant that has precise "feel" characteristics. By using a particular lube, you can adjust the drag, torque, smoothness, etc. Furthermore these charactistics can be relatively temperature independent, make up for tolerance variations, and last a very long time. That's the GOOD news. The BAD news is that the special silicones are only sold in 55 gallon drums to OEMs. But Google it. You might find the one special drop you need--or failing all else, try one drop of the very heaviest silicone oil you can get. Might work. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 "Beaten paths are for beaten men." -E. A. Johnston ________________________________________________________________________________
Subject: Re: ectric-List:
Date: Aug 19, 2005
Thanks, guys, for your help. Unfortunately, I still haven't gotten an answer to my question. I originally asked: "In researching Transponders, many of the Install Manuals reference the use of an "Air Switch" to switch the Transponder in and out of Standby mode as the aircraft's airspeed crosses 30 kts+/-. Does anyone know anything about these Air Switches and/or a source for them?" Allow me to add some additional information: The Transponder that I have narrowed my focus to is the Microair T2000. The "Air Switch" is used to either ground a pin or lift the pin from ground (configurable). It will not accept GPS information. Don't laugh, but I will be using the transponder on a US Part 103 Ultralight. I will be operating just outside of the Chicago Class "B", so I'd like to make sure that I stick out a bit. I checked with the FSDO and they said I could do it, but the XPDR will have to undergo the same inspections and checks that it would if it were installed in a GA plane. And since I will be operating out of an untowered airport, there would be no advantage to having the XPDR "on" while on the ground. So, any help with the switch would be greatly appreciated.... ________________________________________________________________________________
Date: Aug 19, 2005
From: Rick titsworth <rtitsworth(at)mindspring.com>
Bruce, Just curious... Does your GTX330 turn back to STBY after landing? Rick -----Original Message----- From: Bruce Gray <Bruce(at)glasair.org> Subject: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane On my GTX 330, pressing the on button overrides the stby function and the transponder functions, even if on the ground and under 30 kts. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Subject: AeroElectric-List: "Air" Switch & Antenna Ground Plane AeroElectric-List message previously posted by: bniles(at)cfl.rr.com Many airports now want transponders on for all ground movement. If not I would just use STBY. If you forget, DEP control will remind you. > > A couple of questions... > > In researching Transponders, many of the Install Manuals reference > the use > of an "Air Switch" to switch the Transponder in and out of Standby > mode as > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > anything about > these Air Switches and/or a source for them?.....skip...... 8/18/2005 Hello Bill and bniles, A couple of points if I may: 1) Many modern avionics installations have an interface between the GPS box and the transponder that automatically turns the transponder on into "Standby" and then on into "Altitude" modes when appropriate. Applying power to my avionics bus causes the Garmin GNS 430 to come on if the on box switch is left in the ON position. Applying power to my avionics bus causes my GTX 327 to come on in the Standby mode regardless of any on box switch positions (they are all momentary push buttons). When the GPS tells the transponder that the airplane is airborne and going above a certain speed the transponder automatically shifts from Standby to Altitude mode -- no action at all is required by the pilot. This feature could be considered an "Air Switch" by some people. 2) If operation of the transponder is done automatically as described above, those airports that are expecting the transponders to be on while the aircraft is on the ground will have to implement some sort of override action by the pilots in order to make this happen. OC ________________________________________________________________________________
Date: Aug 19, 2005
Nope! No auto-stby after touchdown. That is what shutdown flows and checklists are for. ----- Original Message ----- From: Rick titsworth <rtitsworth(at)mindspring.com> Date: Friday, August 19, 2005 9:30 am Subject: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > Bruce, > Just curious... Does your GTX330 turn back to STBY after landing? > Rick > > -----Original Message----- > From: Bruce Gray <Bruce(at)glasair.org> > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > > On my GTX 330, pressing the on button overrides the stby function > and the > transponder functions, even if on the ground and under 30 kts. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > bakerocb(at)cox.net > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > > > AeroElectric-List message previously posted by: bniles(at)cfl.rr.com > > Many airports now want transponders on for all ground movement. If > not I would just use STBY. If you forget, DEP control will remind > you. > > > > A couple of questions... > > > > In researching Transponders, many of the Install Manuals reference > > the use > > of an "Air Switch" to switch the Transponder in and out of Standby > > mode as > > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > > anything about > > these Air Switches and/or a source for them?.....skip...... > > 8/18/2005 > > Hello Bill and bniles, A couple of points if I may: > > 1) Many modern avionics installations have an interface between > the GPS box > and the transponder that automatically turns the transponder on > into > "Standby" and then on into "Altitude" modes when appropriate. > > Applying power to my avionics bus causes the Garmin GNS 430 to > come on if > the on box switch is left in the ON position. Applying power to my > avionics > bus causes my GTX 327 to come on in the Standby mode regardless of > any on > box switch positions (they are all momentary push buttons). When > the GPS > tells the transponder that the airplane is airborne and going > above a > certain speed the transponder automatically shifts from Standby to > Altitude > mode -- no action at all is required by the pilot. > > This feature could be considered an "Air Switch" by some people. > > 2) If operation of the transponder is done automatically as > described above, > > those airports that are expecting the transponders to be on while > the > aircraft is on the ground will have to implement some sort of > override > action by the pilots in order to make this happen. > > OC > > > > > > > ________________________________________________________________________________
Date: Aug 19, 2005
Does the landing gear flex enough that you could use a squat switch? You could buy a small limit switch from radio shack to do that. You could use a DP pressure switch. Like found here... http://dkc3.digikey.com/PDF/T052/1514.pdf Just hook it into your pitot / static system like it was an airspeed indicator. High pressure port on the pitot line. Godspeed, Phil Birkelbach - Houston Texas RV-7 N727WB - Finishing Up http://www.myrv7.com Bill Denton wrote: > >Thanks, guys, for your help. Unfortunately, I still haven't gotten an answer >to my question. I originally asked: > >"In researching Transponders, many of the Install Manuals reference the use >of an "Air Switch" to switch the Transponder in and out of Standby mode as >the aircraft's airspeed crosses 30 kts+/-. Does anyone know anything about >these Air Switches and/or a source for them?" > >Allow me to add some additional information: > >The Transponder that I have narrowed my focus to is the Microair T2000. The >"Air Switch" is used to either ground a pin or lift the pin from ground >(configurable). It will not accept GPS information. > >Don't laugh, but I will be using the transponder on a US Part 103 >Ultralight. I will be operating just outside of the Chicago Class "B", so >I'd like to make sure that I stick out a bit. I checked with the FSDO and >they said I could do it, but the XPDR will have to undergo the same >inspections and checks that it would if it were installed in a GA plane. > >And since I will be operating out of an untowered airport, there would be no >advantage to having the XPDR "on" while on the ground. > >So, any help with the switch would be greatly appreciated.... > > > > ________________________________________________________________________________
Date: Aug 19, 2005
Yes, it does. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bniles(at)cfl.rr.com Subject: Re: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane Nope! No auto-stby after touchdown. That is what shutdown flows and checklists are for. ----- Original Message ----- From: Rick titsworth <rtitsworth(at)mindspring.com> Date: Friday, August 19, 2005 9:30 am Subject: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > Bruce, > Just curious... Does your GTX330 turn back to STBY after landing? > Rick > > -----Original Message----- > From: Bruce Gray <Bruce(at)glasair.org> > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > > On my GTX 330, pressing the on button overrides the stby function > and the > transponder functions, even if on the ground and under 30 kts. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > bakerocb(at)cox.net > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: "Air" Switch & Antenna Ground Plane > > > > AeroElectric-List message previously posted by: bniles(at)cfl.rr.com > > Many airports now want transponders on for all ground movement. If > not I would just use STBY. If you forget, DEP control will remind > you. > > > > A couple of questions... > > > > In researching Transponders, many of the Install Manuals reference > > the use > > of an "Air Switch" to switch the Transponder in and out of Standby > > mode as > > the aircraft's airspeed crosses 30 kts+/-. Does anyone know > > anything about > > these Air Switches and/or a source for them?.....skip...... > > 8/18/2005 > > Hello Bill and bniles, A couple of points if I may: > > 1) Many modern avionics installations have an interface between > the GPS box > and the transponder that automatically turns the transponder on > into > "Standby" and then on into "Altitude" modes when appropriate. > > Applying power to my avionics bus causes the Garmin GNS 430 to > come on if > the on box switch is left in the ON position. Applying power to my > avionics > bus causes my GTX 327 to come on in the Standby mode regardless of > any on > box switch positions (they are all momentary push buttons). When > the GPS > tells the transponder that the airplane is airborne and going > above a > certain speed the transponder automatically shifts from Standby to > Altitude > mode -- no action at all is required by the pilot. > > This feature could be considered an "Air Switch" by some people. > > 2) If operation of the transponder is done automatically as > described above, > > those airports that are expecting the transponders to be on while > the > aircraft is on the ground will have to implement some sort of > override > action by the pilots in order to make this happen. > > OC > > > > > > > ________________________________________________________________________________
Date: Aug 19, 2005
> "In researching Transponders, many of the Install Manuals reference > the use of an "Air Switch" to switch the Transponder in and out of > Standby mode as the aircraft's airspeed crosses 30 kts+/-. Does anyone > know anything about these Air Switches and/or a source for them?" OK. Try... http://www.pressureswitch.com/products500.html and http://www.iflyez.com/manometer.htm and http://www.omega.com/ppt/pptsc.asp?ref=PSW-141&Nav=preh04 and http://www.thomasnet.com/nsearch.html?cov=NA&heading=819017 61 Man, I love the InterNet!!!!! At 20 kts you need (at least at sea level) a switch capable of .05 psi activation. The above switch will provide that. Since it's 103, plumb a tee off the pitot or use a separate pitot, your choice. Or....again, since it's 103, a Cherry lever switch with a plate attached that activates when speed is high enough (additional drag probably not needed tho!!!) > FSDO and they said I could do it, but the XPDR will have to undergo > the same inspections and checks that it would if it were installed in > a GA plane. Not if you don't want to. Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Re: Final (REALLY) PMag Update - Part 2
>I would suggest, however, that anyone with an Emag or Pmag on their running engine >remove them to examine the gear for wear/damage. For those who need a non-impulse magneto gear for their electronic igintion: Try ECI, Non impulse mag gears $204.00 I purchased my mag gear on eBay. It took two tries, the first one was OK but slightly pitted, so I returned it to the seller with no problem. I bid and won a second gear on eBay which was in very good condition for about $80. Your factory stock magnetos have two differnt drive gears, one magneto use an impulse gear, the other magneto uses a non-impulse gear. Electronic ignitions use the non-impulse gear only. If you replace just one magneto you replace the non-impulse magneto and use the gear from the stock mag for the electronic ignition trigger (hall effect). If you replace both magnetos for electronic ignition you will need a second non-impulse gear. Other EI, like Lightspeed, give you a choice of using a magneto driven trigger (hall effect) or a crank trigger. The crank trigger mounts on the front of the engine and uses magnets mounted in the flywheel and a pick-up bolted to the front of the engine case. There is work involved in placing magnets in the flywheel but it has advatages, like no magneto gears . The magneto gear drive is easier to install in that you don't have to install magnets or trigger pickups on the engine case. Regards George >Subject: FW: [c-a] Final (REALLY) PMag Update - Part 2 >From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > >Subject: [c-a] Final (REALLY) PMag Update - Part 2 > >I would suggest, however, that anyone with an Emag or Pmag on their running engine >remove them to examine the gear for wear/damage. Maybe my gear was an anomaly >- god knows that I seem to have more than my fair share of them, but if there >was a bad run of gears, folks should check to make sure that they're not >making metal in their engines, too. Try to file a tip of one gear tooth - if >the file takes off metal, it's not hardened. Check with YOUR engine experts to >see if they concur that it SHOULD be hardened - that's what Ken and his two >guys said. > >Marc J. Zeitlin --------------------------------- ________________________________________________________________________________
Subject: Wire run questions
Date: Aug 19, 2005
0.06 HTML_TEXT_AFTER_BODY BODY": aeroelectric-list(at)matronics.com Ok, got a couple questions on how to run some of my wing wiring. Breaks down to these two things: 1) Is it necessary (other than just a good idea) to run the nav coax (RG400) away from the pitot (16ga), strobe (shielded), and landing light (18ga to HID local ballast) power lines. I have plenty of places in my ribs where I could move the coax about 12" away from the power lines. I'm already running the trim with the pitot and AOA air lines which are about another 6" away from the power runs. Basically it would look something like this ( | . . . > if I split them up with the first period being the pitot air, then the power, and finally the coax. 2) I am using the Archer nav antennas and have a ton of room in my wingtip allowing me to mount the antenna way aft of the lights. If the LED power and strobe wires don't cross the antenna, or even come near it, do I need to be concerned with running them along the antenna? If the answer is no, it gives me more incentive to run the nav coax separate as I can probably maintain the 12" clearance all the way to the antenna. I have a pretty good idea on the answer but I want to be sure. Michael Sausen -10 # 352 wing ribs ________________________________________________________________________________
Date: Aug 19, 2005
> > > > >My intercom has the squelch and volume controls on concentric shafts. The > > inner volume control is loose enough that vibration causes it to change > > position in flight. Is there a method of adding mechanical resistance to > > that shaft without causing the outer knob to rotate at the same time? > >TIA, Bruce McGregor > >If you had a bunch of potentiometers and needed to make them all feel the >same (The "sine qua non" of potentiometer manufacturers), you COULD have >them machined incredibly precisely and then screw around until you went >bankrupt. Or---- > >You could make a carefully formulated silicone lubricant that has precise >"feel" characteristics. By using a particular lube, you can adjust the drag, >torque, smoothness, etc. Furthermore these charactistics can be relatively >temperature independent, make up for tolerance variations, and last a very >long time. > >That's the GOOD news. > >The BAD news is that the special silicones are only sold in 55 gallon drums >to OEMs. But Google it. You might find the one special drop you need--or >failing all else, try one drop of the very heaviest silicone oil you can >get. Might work. High Eric, pleased to meet you in person last weekend in Plymouth! I think Bruce's problem is a bit tougher. He wants to drive up friction forces in the center shaft of a two shaft system. All the standard techniques (silicon oils, friction washers between knobs, etc) only serve to INCREASE friction between the inner shaft (end knob) and outer shaft (large knob). I don't have a suggestion for making an adjustment of center-shaft friction forces that do not apply same force to the outer shaft. By the way, anyone wishing to add that silky-smooth friction characteristic to rotary controls, some sliding controls, and even damping for some instrument movements can fiddle with high viscosity silicon oils available in small bottles from hobby shops. This stuff is used as shock absorber fluid on RC race cars. I built some nose-gear steering controls for a Hawker Horizon simulator where silicon oil filled model car shock struts offered the desired resistance and smooth feel. It's also used to "semi-lock" differentials in model cars. See: http://www2.towerhobbies.com/cgi-bin/wti0001p?Q=&I=LXBZT5 Bob . . . ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Subject: Re: Wire run questions
Date: Aug 19, 2005
The answer to both questions is NO. Indiana Larry, RV7 Tip Up It Flies Teamwork: " A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ----- Original Message ----- > > > Ok, got a couple questions on how to run some of my wing wiring. Breaks > down to these two things: > > 1) Is it necessary (other than just a good idea) to run the nav coax > (RG400) away from the pitot (16ga), strobe (shielded), and landing light > (18ga to HID local ballast) power lines. I have plenty of places in my > ribs where I could move the coax about 12" away from the power lines. I'm > already running the trim with the pitot and AOA air lines which are about > another 6" away from the power runs. Basically it would look something > like this > > ( | . . . > > > if I split them up with the first period being the pitot air, then the > power, and finally the coax. > > 2) I am using the Archer nav antennas and have a ton of room in my wingtip > allowing me to mount the antenna way aft of the lights. If the LED power > and strobe wires don't cross the antenna, or even come near it, do I need > to be concerned with running them along the antenna? If the answer is no, > it gives me more incentive to run the nav coax separate as I can probably > maintain the 12" clearance all the way to the antenna. > > I have a pretty good idea on the answer but I want to be sure. > > Michael Sausen ________________________________________________________________________________
Subject: Audio Panel
Date: Aug 21, 2005
3.03 DATE_IN_FUTURE_12_24 Date: is 12 to 24 hours after Received: date I seem to remember someone posting that they had their GMA340 modified in some way to improve the quality of the music (loudness maybe) output. I am considering getting a GMA340 but have heard they are a bit suspect in the intercom area, particularly when playing music. Any commments on a fix or there overall quality would be good. I need an Audio panel that will handle 2 VHF a MB and allow two seperate music inputs. (stereo) I want to play Straus in the front and Wiggles in the back. Chris Byrne Sydney ________________________________________________________________________________
Subject: Re: Audio Panel
Date: Aug 19, 2005
Chris - With the GMA-340, you have two music inputs that can be wired as you would like them to be. We had the avionics tech wire one input that will go to all four seats. The other input has nothing in. There is a preamp in the box and you can wire it so that it is on all the time for those music inputs that have a low signal. You can install a switch in the line and be able to turn it on or off. The problem with that preamp is that it amplifies everything, including any noise in the system. For this reason, we decided not to wire it up and will select a music box that has enough signal strength. We are not flying yet but the 340 appears to be a very good box. We do have a very, very low level of noise, but have not isolated the other gear to see if it is in the 340 or not. Based on what we have done in the checkout phase (not flying yet), I think it is probably in the 340. It is really not a problem, IMHO. Hope this helps. Cheers, John PS: We had our 340 wired by an avionics shop, so I can't tell you how to wire the dual channels you want to have. > Any commments on a fix or there overall quality would be good. > > I need an Audio panel that will handle 2 VHF a MB and allow two seperate > music inputs. (stereo) > I want to play Straus in the front and Wiggles in the back. > > > Chris Byrne > ________________________________________________________________________________
Date: Aug 19, 2005
Mike: Regarding #2) I asked Bob Archer the same question regarding the large 10 wing tip and the opportunity to run the wires away from the nav antenna. His response was not to do this and to follow the instructions and intentionally run all the other tip wiring along the angled leg of the antenna. He sent updated instructions that emphasize this. Dick Sipp RV4 700 hours RV10 40065 -----Original Message----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> 0.06 HTML_TEXT_AFTER_BODY BODY": aeroelectric-list(at)matronics.com> Subject: AeroElectric-List: Wire run questions Ok, got a couple questions on how to run some of my wing wiring. Breaks down to these two things: 1) Is it necessary (other than just a good idea) to run the nav coax (RG400) away from the pitot (16ga), strobe (shielded), and landing light (18ga to HID local ballast) power lines. I have plenty of places in my ribs where I could move the coax about 12" away from the power lines. I'm already running the trim with the pitot and AOA air lines which are about another 6" away from the power runs. Basically it would look something like this ( | . . . > if I split them up with the first period being the pitot air, then the power, and finally the coax. 2) I am using the Archer nav antennas and have a ton of room in my wingtip allowing me to mount the antenna way aft of the lights. If the LED power and strobe wires don't cross the antenna, or even come near it, do I need to be concerned with running them along the antenna? If the answer is no, it gives me more incentive to run the nav coax separate as I can probably maintain the 12" clearance all the way to the antenna. I have a pretty good idea on the answer but I want to be sure. Michael Sausen -10 # 352 wing ribs ________________________________________________________________________________
Date: Aug 19, 2005
Subject: Re: OVP thoughts
> > > Would you care to post some power distribution diagrams that > describe your architecture. The lack of battery contactors piques > our interest. You've expressed some interest in management > of an OV event . . . it seems that elimination of battery contactors > offers possibilities for some equally exciting failure modes > that battery contactors are expected to control . . . > > Bob . . . > > > Sorry but my diagrams are in pencil and not very neat ;) Essentially I have a Z-14 with no battery contactors. My main interest is two hot battery busses to feed the electrically dependant engine and I don't ever want to disconnect those engine computers from a battery. Each of those busses distributes through a 6 fuse fuseblock and has low voltage warnings. Almost everything else, including the starter, is routed through a contactor and then a 10 fuse fuseblock. If I open that contactor then it kills everything but the battery busses which is no problem as the primary gyros are vacuum operated. I know vacuum is less reliable but I prefer a six pack and vacuum was affordable at the time. There is a low vacuum warning. Instead of plumbing an engine intake manifold backup vacuum source I added a $30. flymarket 28 volt electric T&B which works just fine on 12volts with surprisingly little change in rpm or current draw. A handheld vhf and gps backup is available if needed and one cigarette lighter outlet is powered from a battery bus. There is an OVM and a B-lead contactor/relay on both the main 40 amp alternator and the 20 amp PM alternator. This was fairly carefully considered as appropriate for my needs and a bit simpler than the stock Z-14. There is no separate starter contactor but I can still kill power to the automotive starter. This also eliminates two battery contactors but adds in that one power distribution contactor. The batteries are wee 8 AH units and the crossfeed closes for cranking. Since I have 3 busses, all switches are color keyed red (left battery bus for backup engine controls), blue (right battery bus for primary engine), and yellow (the switched non essential) bus. Pilot operating simplicity was very much a consideration. All warnings (except low fuel and crossfeed closed) are done with a Grand Rapids EIS. Ken ________________________________________________________________________________
From: "Chris & Kellie Hand" <ckhand(at)earthlink.net>
Date: Aug 19, 2005
My RV-6A engine should be ready for me sometime this fall, ordered with an e-mag/p-mag combination so this thread definitely caught my attention. I asked them about it, and they have the following posted on the Innovation section of their web site (http://www.emagair.com/Innovation.htm) : Q: I read about an occurrence of excessive drive gear wear and your gears not being certified. Can you elaborate? A: As stated on order forms and price lists, our drive gears are not certified gears. We try to replicate certified gears in terms of both their dimension and their hardness. It was surprising to us (at first) to find the certified gear we had tested was not hardened. We then realized there would be advantages in keeping the drive gear (accessible and easy to replace) unhardened so it will wear before the gear it engages (inside the engine and much harder to inspect/replace). Of the numerous in-service gears that have come through our shop, we've seen only one (1) occurrence of significant wear/deformation of a drive gear. In all likelihood it was caused by some kind of foreign matter under one side of the flange when it was clamped down. That would have cocked the unit to one side, preload the gear, and cause the excessive wear. They also said you do have the option of using a certified gear if desired, as I think somebody else pointed out in an earlier reply. I don't know enough about mag drive gears to know whether certified gears are or are not hardened, or whether they should be, but am posting this as additional info on the subject and it sounds like emagair has checked on that question. Chris Hand RV-6A, finishing kit stage > >Subject: FW: [c-a] Final (REALLY) PMag Update - Part 2 > >From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > > > >Subject: [c-a] Final (REALLY) PMag Update - Part 2 > > > >I would suggest, however, that anyone with an Emag or Pmag on their running engine > >remove them to examine the gear for wear/damage. Maybe my gear was an anomaly > >- god knows that I seem to have more than my fair share of them, but if there > >was a bad run of gears, folks should check to make sure that they're not > >making metal in their engines, too. Try to file a tip of one gear tooth - if > >the file takes off metal, it's not hardened. Check with YOUR engine experts to > >see if they concur that it SHOULD be hardened - that's what Ken and his two > >guys said. > > > >Marc J. Zeitlin > > > --------------------------------- > > ________________________________________________________________________________
Date: Aug 20, 2005
Though I have not spoken yet with anyone knowlegdgeable about this news, your answer agrees well with my initial impression: the gear is so lightly loaded in this application (turning an optical encoder wheel in the E-mag and also a light-duty, rarely-loaded alternator in the P-Mag) that accelerated wear seems mechanically impossible so long as alignment is correct. If alignment is off, it's anyone's guess how well the gear would fare, and you'd be glad the soft gear took the punishment. -Stormy -----Original Message----- From: Chris & Kellie Hand <ckhand(at)earthlink.net> Subject: Re: AeroElectric-List: Re: Final (REALLY) PMag Update - Part 2 My RV-6A engine should be ready for me sometime this fall, ordered with an e-mag/p-mag combination so this thread definitely caught my attention. I asked them about it, and they have the following posted on the Innovation section of their web site (http://www.emagair.com/Innovation.htm) : Q: I read about an occurrence of excessive drive gear wear and your gears not being certified. Can you elaborate? A: As stated on order forms and price lists, our drive gears are not certified gears. We try to replicate certified gears in terms of both their dimension and their hardness. It was surprising to us (at first) to find the certified gear we had tested was not hardened. We then realized there would be advantages in keeping the drive gear (accessible and easy to replace) unhardened so it will wear before the gear it engages (inside the engine and much harder to inspect/replace). Of the numerous in-service gears that have come through our shop, we've seen only one (1) occurrence of significant wear/deformation of a drive gear. In all likelihood it was caused by some kind of foreign matter under one side of the flange when it was clamped down. That would have cocked the unit to one side, preload the gear, and cause the excessive wear. They also said you do have the option of using a certified gear if desired, as I think somebody else pointed out in an earlier reply. I don't know enough about mag drive gears to know whether certified gears are or are not hardened, or whether they should be, but am posting this as additional info on the subject and it sounds like emagair has checked on that question. Chris Hand RV-6A, finishing kit stage > >Subject: FW: [c-a] Final (REALLY) PMag Update - Part 2 > >From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > > > >Subject: [c-a] Final (REALLY) PMag Update - Part 2 > > > >I would suggest, however, that anyone with an Emag or Pmag on their running engine > >remove them to examine the gear for wear/damage. Maybe my gear was an anomaly > >- god knows that I seem to have more than my fair share of them, but if there > >was a bad run of gears, folks should check to make sure that they're not > >making metal in their engines, too. Try to file a tip of one gear tooth - if > >the file takes off metal, it's not hardened. Check with YOUR engine experts to > >see if they concur that it SHOULD be hardened - that's what Ken and his two > >guys said. > > > >Marc J. Zeitlin > > > --------------------------------- > > ________________________________________________________________________________
Subject: Was wire run questions - now Archer antenna
Date: Aug 20, 2005
That's interesting. Dan Checkoway, I believe you didn't run your wires across the antenna. How's it working for you? Michael Sausen -10 #352 wing ribs -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rsipp(at)earthlink.net Subject: Re: AeroElectric-List: Wire run questions Mike: Regarding #2) I asked Bob Archer the same question regarding the large 10 wing tip and the opportunity to run the wires away from the nav antenna. His response was not to do this and to follow the instructions and intentionally run all the other tip wiring along the angled leg of the antenna. He sent updated instructions that emphasize this. Dick Sipp RV4 700 hours RV10 40065 -----Original Message----- From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> 0.06 HTML_TEXT_AFTER_BODY BODY": aeroelectric-list(at)matronics.com> Subject: AeroElectric-List: Wire run questions --> Ok, got a couple questions on how to run some of my wing wiring. Breaks down to these two things: 1) Is it necessary (other than just a good idea) to run the nav coax (RG400) away from the pitot (16ga), strobe (shielded), and landing light (18ga to HID local ballast) power lines. I have plenty of places in my ribs where I could move the coax about 12" away from the power lines. I'm already running the trim with the pitot and AOA air lines which are about another 6" away from the power runs. Basically it would look something like this ( | . . . > if I split them up with the first period being the pitot air, then the power, and finally the coax. 2) I am using the Archer nav antennas and have a ton of room in my wingtip allowing me to mount the antenna way aft of the lights. If the LED power and strobe wires don't cross the antenna, or even come near it, do I need to be concerned with running them along the antenna? If the answer is no, it gives me more incentive to run the nav coax separate as I can probably maintain the 12" clearance all the way to the antenna. I have a pretty good idea on the answer but I want to be sure. Michael Sausen -10 # 352 wing ribs ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Low System Voltage Troubleshooting
Hi Folks I just wanted to comment on a problem I had been having for 6 years on my aircraft. This is in response to a previous post I made about 3 weeks ago & Kevin Horton & Ken Klehman were kind enough to supply some advice. The electrical system is a classic Nuckolls system. It is very similar to Z-1 as published in 1996. This is a simple system with a linear regulator, mine is a B&C LR-3B. I did not use a toggle switch but a standard aircraft key switch & Cessna style Battery/Alternator Master switch. My helper during construction was a very bright guy who has his masters in Elec. Engineering. The electrical installation is really really good due to his work. He even used waxed lacing for wire ties which looks and performs beautifully. Only 1 operational problem right from day one which was July 25, 1999. I was having so much fun flying etc. that I did not work too hard to solve it as it did not keep me out of the air but bugged me as I know it was not right. The problem was the system voltage peaked at about 13.8 V and decreased each time I added a load of any kind to the system. Each load would drop the system load by about 0.1-0.2 volts. I could easily drop the system voltage down to 12.8-12.9 volts but as most of my flying was day VFR, it rarely got there. I have an EI gauge to show volts/amps & also my Garmin 195 would display the same. (I reasoned that it made sense to have the EI gauge mounted on the Essential bus as I would want to know the condition of the battery if I had to feed the E bus directly per the alternate feed switch if the alternator went down). I did realize that my EI gauge was fed from the Essential bus and therefore would read a lower voltage due to the drop across the bridge rectifier which feeds the Essential bus from the Main bus, (or buss?). I also checked it with 2 portable digital multimeters which did not show anything was wrong with the readings. I also adjusted the trim pot on the regulator which did not help very much. I changed belts for the alternator, discussed the matter with B&C & followed the trouble shooting specs. as supplied which were all within the stated limits. Finally I decided in my finite wisdom that it must be the regulator so I purchased a new reg. at $228 from B&C and installed it with high hopes. As you probably guessed, I restarted the engine and the numbers were EXACTLY the same. What a downer! I posted my problem 3 weeks ago as I mentioned. Kevin suggested that I move the feed point of the EI gauge to the Main bus. This helped but still the drop continued. Ken suggested that I check all the points from the alternator back to the main bus i.e. look for voltage drops at each connection starting with the B lead and so forth. I did realize that I was working with a digital multimeter and was testing the system with no load applied during the resistance check & does not represent real life but I did turn loads on the see if that would show any voltage drop. All resistance drops were less than 1 ohm & therefore could see nothing obvious. I called B&C again and Tim Johnson suggested a similar course of action as per Ken & Kevin. However, his ears perked up when I mentioned my master switch. He said that may be a problem. Sure enough, I bypassed the master switch & the 5A feed breaker, (per Z-1), running a jumper from the Main bus directly to pin #6 on the regulator which is feed for the alternator field voltage & voil, after 6 years with 13 something volts max, I had 14.2-14.4 volts. I could not believe it. After many more minutes with rudder pedals digging into my head, torque tube in my back & sweat in my eyes, I only bypassed the Cessna switch & the results were the same. Now I am happily flying with a spare reg., no switch to turn the alternator off & on except for thebreaker in the system which I can pull out if I need to & making the voltage output I had always wanted. Sure makes you think though, the wonderful brand new certified part in my system was causing undue voltage drop across the switch itself & thereby depressing my system voltage by up to 1.5 volts. Many thanks to Kevin & Ken for sending me in the right direction & to B&C as well who were great. I must say my little brain was still confused as I assumed that the regulator sensing a lower than optimal voltage would adjust the alternator field voltage upwards enough to compensate. At Oshkosh, Bill Bainbridge immediately handed me his cell phone after dialing up Tim Johnson & Tim explained that in theory this was correct but the regulator may not have enough output ability to boost the system voltage back to the proper range as the reg. was starting with a lower voltage. So, the moral of the story, do not use certificated parts on your amateur built aircraft, (kidding). Seriously forget the master switch & use toggle switches. I am stuck with this rectangular hole cut into my panel & wondering if I really want to pull it out & fill the area neatly somehow with 2 toggle switches. Come to think of it, why did I buy a key switch in the first place? I should have used toggles there as well. Sorry to post such a long email. I do really hope this helps people in designing a simple, inexpensive, easy to maintain & trouble free panel. With the above changes, by Simple Z diagram is faultless. Again many thanks to the above mentioned gentlemen & of course Bob Nuckolls for a great system. Now, back to building my RV-8. Cheers Brian Cross # 81844 ________________________________________________________________________________
Date: Aug 20, 2005
Subject: AMP connector pin source
Hi, I'm trying to locate a website where I can buy AMP pins that go into a strobe AMP connector. I'm sure someplace like Digikey has them, but I can't find them on their website. What I'm looking for is just the pins on this page: http://strobeguy.safeshopper.com/32/1901.htm?949 I've got a bunch that I bought from Steinair, but they are not the same shape. Here is a photo: http://www.rv8.ch/article.php?story=200508201734405 Thanks for any hints, or part numbers, or official unique names! -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Re: AMP connector pin source
just bought a bunch, to go with creativeair's strobe supply, from Digi-key both for 20-14Awg, PhosphorBronze, pre-tin. male pins A25561-ND female pins A25562-ND I also got some more 3 pin housings, A1400-ND pin housing and A25415-ND socket housing, socket housing comes only in black from digi-key. hope this helps. Gert they are on my Dec04 catalog, page 116&117, Commercial Mate-N-Lok connectors Mickey Coggins wrote: > >Hi, > >I'm trying to locate a website where I can buy >AMP pins that go into a strobe AMP connector. > >I'm sure someplace like Digikey has them, but >I can't find them on their website. > >What I'm looking for is just the pins on >this page: > >http://strobeguy.safeshopper.com/32/1901.htm?949 > >I've got a bunch that I bought from Steinair, >but they are not the same shape. Here is a photo: > >http://www.rv8.ch/article.php?story=200508201734405 > >Thanks for any hints, or part numbers, or official >unique names! > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Re: Low System Voltage Troubleshooting
On 20-Aug-05 09:28 Brian Cross wrote: > Seriously forget the master switch & use toggle > switches. I am stuck with this rectangular hole cut into my panel & > wondering if I really want to pull it out & fill the area neatly somehow > with 2 toggle switches. Come to think of it, why did I buy a key switch in > the first place? I should have used toggles there as well. > Brian, Thanks for sharing your troubleshooting and eventual success story. Your finding is a great one to file away in my "bag of tricks". Some prefer a Cessna-style ignition switch but like you I'd rather have individual switches. I retrofitted my Long-EZ with a pushbutton (from the aviation section of Walmart) for the starter and two guarded toggles ("racing parts" from AutoZone) for the magnetos. A small aluminum panel will cover the large hole and allow you to mount your new switches if you have the room. (YMMV; I couldn't fit everything in one place so I used two aluminum panels in my aircraft.) Before: http://nicon.org/chapter328/jd/images/IgnitionSwBefore.jpg After: http://nicon.org/chapter328/jd/images/IgnitionSwAfter.jpg -- Joe Long-EZ 821RP ________________________________________________________________________________
Subject: Transponder Certification
Date: Aug 20, 2005
AeroElectric-List message previously posted by: "Jim Baker" <<......skip....... FSDO and they said I could do it, but the XPDR will have to undergo the same inspections and checks that it would if it were installed in a GA plane.>> Not if you don't want to. Jim Baker 8/19/2005 Hello Jim Baker, Are you saying that despite FAR Sec. 91.215 and FAR Sec. 91.413 that an ultralight owner / pilot can install just any old non TSO'd and non currently inspected transponder that may be incompatible with ATC equipment and fly around legally in the USA controlled airspace? Please clarify. Thanks. OC ________________________________________________________________________________
Subject: recharge/jump start recepticle
Date: Aug 20, 2005
Hi, I'm looking for a way to be able to recharge or jumpstart my battery from outside the plane which is in the back of an RV8. What I have in mind is a receptacle which is flush with the bottom of the fuse and has a rubber plug to seal it while not in use. I want the wire sized to be able to handle the current of a jump start and bolted to the battery just like the start/ground cables are. I am not aware I've seen something like this before except for a bigger version like an APU jack in military aircraft but that's overkill for an RV. But I thought I heard it discussed in past years on the list but my archive search didn't turn up anything. I was hoping West Marine would have something similar but I didn't find anything. Any ideas? thx, lucky ________________________________________________________________________________
Date: Aug 20, 2005
Hi Joe Thanks very much for your great pictures & your thoughts. You did a great job moving your switches around. I don't feel quite so silly for putting the parts in that I did. Happy flying Brian At 02:43 PM 8/20/2005, you wrote: > >On 20-Aug-05 09:28 Brian Cross wrote: > > > > Seriously forget the master switch & use toggle > > switches. I am stuck with this rectangular hole cut into my panel & > > wondering if I really want to pull it out & fill the area neatly somehow > > with 2 toggle switches. Come to think of it, why did I buy a key > switch in > > the first place? I should have used toggles there as well. > > > >Brian, > >Thanks for sharing your troubleshooting and eventual success story. >Your finding is a great one to file away in my "bag of tricks". > >Some prefer a Cessna-style ignition switch but like you I'd rather have >individual switches. I retrofitted my Long-EZ with a pushbutton (from >the aviation section of Walmart) for the starter and two guarded toggles >("racing parts" from AutoZone) for the magnetos. A small aluminum panel >will cover the large hole and allow you to mount your new switches if >you have the room. (YMMV; I couldn't fit everything in one place so I >used two aluminum panels in my aircraft.) > >Before: > http://nicon.org/chapter328/jd/images/IgnitionSwBefore.jpg > >After: > http://nicon.org/chapter328/jd/images/IgnitionSwAfter.jpg > >-- >Joe >Long-EZ 821RP > > ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Re: Transponder Certification
> <<......skip....... FSDO and they said I could do it, but the XPDR > will have to undergo the same inspections and checks that it would if > it were installed in a GA plane.>> > > Not if you don't want to. Jim Baker > > 8/19/2005 > > Hello Jim Baker, Are you saying that despite FAR Sec. 91.215 and FAR > Sec. 91.413 that an ultralight owner / pilot can install just any old > non TSO'd and non currently inspected transponder that may be > incompatible with ATC equipment and fly around legally in the USA > controlled airspace? > > Please clarify. Thanks. Well....sort of. 91.215 says US registered civil aircraft. Find where anyone, let alone the FAA, ever defines a part 103 vehicle as an aircraft. They are routinely refered to as ultralight vehicles by part 103. It then follows that if not applicable under 91.215, then 91.413 doesn't apply either. Having said that, it seems that part 103.17, Operations in Certain Airspace, would make it wise (well, more than wise actually), but not mandatory, to have a unit that is capable of "data correspondence" per 91.413, if your intent is to be precisely known as to location in the ATC system. But again, it isn't mandated. The FAA did this to themselves with the vehicle designation.... Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Re: recharge/jump start recepticle
Hi Chris, See Aeroelectric Connection by Bob Nucolls. There is a paper that describes an external connection compatible with many FBO's APUs that you can build into your RV. That is what I built into my -6A and I use it all the time when I want to run the avionics in the hangar. It would serve for battery charging, etc. also. Regards, Richard Dudley -6A flying chris macy wrote: > >Hi, >I'm looking for a way to be able to recharge or jumpstart my battery from outside the plane which is in the back of an RV8. > >What I have in mind is a receptacle which is flush with the bottom of the fuse and has a rubber plug to seal it while not in use. I want the wire sized to be able to handle the current of a jump start and bolted to the battery just like the start/ground cables are. I am not aware I've seen something like this before except for a bigger version like an APU jack in military aircraft but that's overkill for an RV. But I thought I heard it discussed in past years on the list but my archive search didn't turn up anything. I was hoping West Marine would have something similar but I didn't find anything. > >Any ideas? > >thx, >lucky > > > > ________________________________________________________________________________
Date: Aug 20, 2005
Chris, You might start in the Aircraft Spruce Catalog and look for the Piper Type Socket p/n 11-00500 as one example. There are others on that page too. Bob Nuckoll's Aeroelectric Connection site has schematics for the particular installation you describe and it is good for jump start and charging batteries as well. I chose to put in two lighter sockets on a plate and place them in the belly so that I can use battery tenders for separate battery maintenence without the capacity to jump the battery. I don't really want to fly a plane that has to be jump started. http://www.macsmachine.com/images/electrical/full/chargeportassy2.gif http://www.macsmachine.com/images/electrical/full/chargeportmount2.gif http://www.macsmachine.com/images/electrical/full/chargeplugs.gif The bottom has a removable plate cover with 2 dzus fasteners to seal it when not being used. Larry McFarland - 601HDS at www.macsmachine.com chris macy wrote: > >Hi, >I'm looking for a way to be able to recharge or jumpstart my battery from outside the plane which is in the back of an RV8. > >What I have in mind is a receptacle which is flush with the bottom of the fuse and has a rubber plug to seal it while not in use. I want the wire sized to be able to handle the current of a jump start and bolted to the battery just like the start/ground cables are. I am not aware I've seen something like this before except for a bigger version like an APU jack in military aircraft but that's overkill for an RV. But I thought I heard it discussed in past years on the list but my archive search didn't turn up anything. I was hoping West Marine would have something similar but I didn't find anything. > >Any ideas? > >thx, >lucky > > > > ________________________________________________________________________________
Date: Aug 20, 2005
You could consider either a Piper or Cessna auxillary power jack. I got a complete salvaged jack system for my C172 from Wentworth for about $125, but that was years ago. It included the brackets, contactor, and harness. I have also seen just the jacks and plugs in AC Spruce (ACS), without brackets or control system. ACS has the AN2552-3A external power receptacle designed to mount in hole in skin of aircraft. Hole is then covered with hinged access door (not included). Mates with AN2551 type plugs. Model 4621B, JUMPER PLUG #6216. Jim Stone Jabiru J450 Clearwater FL. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of chris macy Subject: AeroElectric-List: recharge/jump start recepticle --> Hi, I'm looking for a way to be able to recharge or jumpstart my battery from outside the plane which is in the back of an RV8. What I have in mind is a receptacle which is flush with the bottom of the fuse and has a rubber plug to seal it while not in use. I want the wire sized to be able to handle the current of a jump start and bolted to the battery just like the start/ground cables are. I am not aware I've seen something like this before except for a bigger version like an APU jack in military aircraft but that's overkill for an RV. But I thought I heard it discussed in past years on the list but my archive search didn't turn up anything. I was hoping West Marine would have something similar but I didn't find anything. Any ideas? thx, lucky ________________________________________________________________________________
Date: Aug 20, 2005
Subject: Wiring an RV-4
Hello AeroElectric subscribers, I'm about to begin the wiring for my RV-4. Considered BMA's printed circut board and PTC switch idea, but decided that was too expensive for my 12 circuits (about $2K). Have ordered a Blue Sea 5026 fuse block ($40) and will use Bob's concept of fly now, fix on the ground! I have the following for the panel: Dynon D10A MicroAir T2000 transponder XCOM Radio with built-in intercom Flightcom i300 Pictorial Pilot wing leveler Altrak altitude hold GRT EIS Narco 122D VOR/GS with marker beacon Garmin 296 ***Considering digital altimeter with encoder vs Dynons encoder or AK 350*** I have cables and pro-hub from Approach Systems for the XCOM, Transponder and Narco. My question is what do I do to wire up the stick-grip push buttons? (PTT, Autopilot, starter, electric fuel pump, radio frequency change)... how many can go straight to a fuse, vs being regulated before going to the device? The Blue Sea has 12 return ground terminals. Should I use these or run a seperate ground block? Appreciate your thoughts. Ron N8ZD - flying soon n8zd(at)yahoo.com ________________________________________________________________________________
Date: Aug 21, 2005
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Wiring an RV-4
> >Hello AeroElectric subscribers, > >I'm about to begin the wiring for my RV-4. Considered BMA's printed circut >board and PTC switch idea, but decided that was too expensive for my 12 >circuits (about $2K). That's interesting. I didn't know he had actually put a price on it and was offering it for sale. Of course we also don't know what all was in the "kit" but $2.000 is a real stretch given what others supply in their pre-wired, switch panel products for less than half that. More importantly, the product as last illustrated in http://www.aeroelectric.com/articles/richter/response_1.pdf was a long way from being a production offering as it was plagued with many electrical and mechanical issues. > Have ordered a Blue Sea 5026 fuse block ($40) and will use Bob's concept > of fly now, fix on the ground! > >I have the following for the panel: > >Dynon D10A >MicroAir T2000 transponder >XCOM Radio with built-in intercom >Flightcom i300 >Pictorial Pilot wing leveler >Altrak altitude hold >GRT EIS >Narco 122D VOR/GS with marker beacon >Garmin 296 >***Considering digital altimeter with encoder vs Dynons encoder or AK 350*** > >I have cables and pro-hub from Approach Systems for the XCOM, Transponder >and Narco. > >My question is what do I do to wire up the stick-grip push buttons? (PTT, >Autopilot, starter, electric fuel pump, radio frequency change)... how >many can go straight to a fuse, vs being regulated before going to the device? It's not necessary for ANY of the stick-grip wires to carry supply current. Given the small size of stick grip switches and wires, it's better to have the stick grip control the accessory system by GROUNDING. Current flowing in the stick grip switches should be in the 100mA to 1A range. Unless the accessory system can be directly controlled by grounding (like xmit PTT) then some form of control relays are called for like the relay decks offered by many for things like trim servos. >The Blue Sea has 12 return ground terminals. Should I use these or run a >seperate ground block? This will probably not be enough. Have you read the grounding chapter in the 'Connection Also check out the avionics/panel grounding concept in chapter 18. Bob . . . ________________________________________________________________________________
Date: Aug 21, 2005
> >Hi Chris, >See Aeroelectric Connection by Bob Nucolls. There is a paper that >describes an external connection compatible with many FBO's APUs that >you can build into your RV. That is what I built into my -6A and I use >it all the time when I want to run the avionics in the hangar. It would >serve for battery charging, etc. also. See http://aeroelectric.com/articles/grndpwr.pdf I'm told that Cole-Hersee now offers the same power jack with a threaded post so that the modification proposed in the article is not necessary. Bob . . . ________________________________________________________________________________
Subject: Re: NSI New Chief Engineer
Date: Aug 21, 2005
>Eric -What happened to Paul's effort with the ghost company (I don't recall >him ever parting with the name) to develop a "next generation aircraft >electrical system"... or something along those lines? Did he/they >shelve the design, scrap it, or is it now in his 'side work' pile? >Inquiring minds want to know (... well... mine does, anyway). >Pass along a congrats on the new gig! D The Ghost Company was NSI. (I would have paid money to see Paul and Lance Wheeler argue with each other.) The Next Generation electrical system is not first priority since NSI is in real trouble--"Bigger than you can imagine trouble." The Yahoo subie groups (http://groups.yahoo.com/group/E-SubieForum/) have more information. Regards, Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge MA 01550-2705 (508) 764-2072 Teamwork: " A lot of people doing exactly what I say." (Marketing exec., Citrix Corp.) ________________________________________________________________________________
Date: Aug 21, 2005
Stormy, Your idyllic vision of the gear's life would be true, IF we were dealing with "constant combustion" (turbine or jet) engines. However, our Lycomings are 4 cylinder "intermittent combustion" engines. The gears need to be hardened to take the constant "jack hammering" they receive due to this process. This process is also what made both Lycoming and Continental quit making geared piston engines. Charlie Kuss ---- sportav8r(at)aol.com wrote: > > Though I have not spoken yet with anyone knowlegdgeable about this news, your answer agrees well with my initial impression: the gear is so lightly loaded in this application (turning an optical encoder wheel in the E-mag and also a light-duty, rarely-loaded alternator in the P-Mag) that accelerated wear seems mechanically impossible so long as alignment is correct. If alignment is off, it's anyone's guess how well the gear would fare, and you'd be glad the soft gear took the punishment. > > -Stormy > > -----Original Message----- > From: Chris & Kellie Hand <ckhand(at)earthlink.net> > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Final (REALLY) PMag Update - Part 2 > > > > > My RV-6A engine should be ready for me sometime this fall, ordered with an > e-mag/p-mag combination so this thread definitely caught my attention. I > asked them about it, and they have the following posted on the Innovation > section of their web site (http://www.emagair.com/Innovation.htm) : > > Q: I read about an occurrence of excessive drive gear wear and your gears > not being certified. Can you elaborate? > > A: As stated on order forms and price lists, our drive gears are not > certified gears. We try to replicate certified gears in terms of both their > dimension and their hardness. It was surprising to us (at first) to find > the certified gear we had tested was not hardened. We then realized there > would be advantages in keeping the drive gear (accessible and easy to > replace) unhardened so it will wear before the gear it engages (inside the > engine and much harder to inspect/replace). Of the numerous in-service > gears that have come through our shop, we've seen only one (1) occurrence of > significant wear/deformation of a drive gear. In all likelihood it was > caused by some kind of foreign matter under one side of the flange when it > was clamped down. That would have cocked the unit to one side, preload the > gear, and cause the excessive wear. > > > They also said you do have the option of using a certified gear if desired, > as I think somebody else pointed out in an earlier reply. > > I don't know enough about mag drive gears to know whether certified gears > are or are not hardened, or whether they should be, but am posting this as > additional info on the subject and it sounds like emagair has checked on > that question. > > Chris Hand > RV-6A, finishing kit stage > > > >Subject: FW: [c-a] Final (REALLY) PMag Update - Part 2 > > >From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> > > > > > >Subject: [c-a] Final (REALLY) PMag Update - Part 2 > > > > > >I would suggest, however, that anyone with an Emag or Pmag on their > running engine > > >remove them to examine the gear for wear/damage. Maybe my gear was > an anomaly > > >- god knows that I seem to have more than my fair share of them, > but if there > > >was a bad run of gears, folks should check to make sure that > they're not > > >making metal in their engines, too. Try to file a tip of one gear > tooth - if > > >the file takes off metal, it's not hardened. Check with YOUR > engine experts to > > >see if they concur that it SHOULD be hardened - that's what Ken and > his two > > >guys said. > > > > > >Marc J. Zeitlin > > > > > > --------------------------------- > > > > > > > > > > ________________________________________________________________________________
Date: Aug 21, 2005
Good Morning Charlie, I know this is way out of any field of expertise that I may have, but I wonder if we may not be discussing apples and oranges here? It would seem to me that those gears in the back of the engine would encounter much lower stresses than those used to gear down a propellor shaft. As the gear only needs to deliver a timing function, I would think that a gear that had been designed to drive a magneto would have a lot more strength than is required to drive the timing device needed by the E or P mag unit. Reduction gearing on the older Lycomings has proven very reliable. So much so that most engines of that era are overhauled often with nothing being done to the reduction gears other than careful inspection. The multi-cylinder radials that powered our piston airline fleets attained amazingly long gear lives even though they were under very high stresses. Admittedly, the power pulses came a lot closer together on eighteen cylinder engines than they do on a four banger, but it does seem that those back of the engine gears should not have to be terribly sophisticated entities. Happy Skies, Old Bob In a message dated 8/21/2005 10:17:28 AM Central Standard Time, chaztuna(at)adelphia.net writes: Stormy, Your idyllic vision of the gear's life would be true, IF we were dealing with "constant combustion" (turbine or jet) engines. However, our Lycomings are 4 cylinder "intermittent combustion" engines. The gears need to be hardened to take the constant "jack hammering" they receive due to this process. This process is also what made both Lycoming and Continental quit making geared piston engines. Charlie Kuss ________________________________________________________________________________
Date: Aug 21, 2005
Bob - We installed your ground power system in addition to the Z-14 in our Lancair ES. I bought a small power supply on eBay that you had recommended (12V nominal that had been set to 13.5V by the seller). We use it all the time to check out the electrical system and instrumentation. Great setup. Works great. I would like to use the external power receptacle to plug in a battery charger/maintainer. It should work well to charge/maintain the #1 battery when just the ground power switch/cb is on and the contactor is closed. This means we give up .8 amp off the top of the charger's capacity. However, the problem comes when we want to charge/maintain the #2 battery. By using the external power jack, we have to have all four of the contactors closed - giving up 3.2 amps. The entire electrical system of the aircraft would be hot while the batteries charge. We then worry about one battery being over charged if the other one is lower. Any tender/maintainer will stay on the charge cycle until it senses the lowest battery at the peak charge before going to the maintain mode. Correct? Question: Is it a good idea to use the ground power system to charge and maintain the batteries? If so, can you recommend a maintainer and a circuit change that can do the job? Or, would it be better to just add 4 more wires and a couple of plugs to the batteries and use two of the smaller tenders? Many thanks, John Schroeder Lancair ES 85% wrote: > See http://aeroelectric.com/articles/grndpwr.pdf > I'm told that Cole-Hersee now offers the same power jack > with a threaded post so that the modification proposed > in the article is not necessary. -- ________________________________________________________________________________
Date: Aug 21, 2005
AeroElectric-List message previously posted by: Mickey Coggins <> 8/21/2005 Hello Mickey, I think you may be mixing up Molex and AMP pins and connectors. Just make sure that you are using the pins and plastic connector shells from the same manufacturer. If you are sure that your plastic shells are AMP Mate N Lok brand then you can get compatible pins from Terminal Town http://www.terminaltown.com/ Pay very close attention to part numbers. OC ________________________________________________________________________________
Date: Aug 21, 2005
Idyllic or not, we'll all have to wait and see what the longer term field experience is with these gears. For me, the most relevant point is that made by Brad, who states the Lycoming gears they were copying were also not case-hardened. If that's correct, we're probably looking at an isolated failure here. Time will tell. -Stormy -----Original Message----- From: chaztuna(at)adelphia.net Subject: Re: AeroElectric-List: Re: Final (REALLY) PMag Update - Part 2 Stormy, Your idyllic vision of the gear's life would be true, IF we were dealing with "constant combustion" (turbine or jet) engines. However, our Lycomings are 4 cylinder "intermittent combustion" engines. The gears need to be hardened to take the constant "jack hammering" they receive due to this process. This process is also what made both Lycoming and Continental quit making geared piston engines. Charlie Kuss ________________________________________________________________________________
Date: Aug 21, 2005
Amp commercial Mate-N-Lock connectors. Here are the Digi-key part numbers. A1400-ND CONN RECEPT/CAP 3 POS MATE-N-LOK A1429-ND CONN PLUG 3POS MATE-N-LOK A1422-ND CONN PIN 18-24AWG TIN CRIMP A1423-ND CONN SOCKET 18-24AWG TIN CRIMP I also used 2-pin and 4-pin versions of these (4-pin is good for strobe wing root disconnect). Vern Little RV-9A bakerocb(at)cox.net wrote: > >AeroElectric-List message previously posted by: Mickey Coggins > > ><AMP pins that go into a strobe AMP connector. > >I'm sure someplace like Digikey has them, but >I can't find them on their website. > >What I'm looking for is just the pins on >this page:......skip........ > >Thanks for any hints, or part numbers, or official >unique names! Mickey Coggins>> > >8/21/2005 > >Hello Mickey, I think you may be mixing up Molex and AMP pins and >connectors. Just make sure that you are using the pins and plastic connector >shells from the same manufacturer. > >If you are sure that your plastic shells are AMP Mate N Lok brand then you >can get compatible pins from Terminal Town http://www.terminaltown.com/ > >Pay very close attention to part numbers. > >OC > > > > ________________________________________________________________________________
Date: Aug 21, 2005
there is a difference between regular Mate-N-Lock and *Commercial* Mate-N-Lock. the strobes had the Commercial variety of Mate-n-Lock connectors, once I figured that out getting additional items was easy. I believe SteinAir sells the regular Mate-N-Lock, I know, I bought some of his 2, for a different purpose. bakerocb(at)cox.net wrote: > >AeroElectric-List message previously posted by: Mickey Coggins > > ><AMP pins that go into a strobe AMP connector. > >I'm sure someplace like Digikey has them, but >I can't find them on their website. > >What I'm looking for is just the pins on >this page:......skip........ > >Thanks for any hints, or part numbers, or official >unique names! Mickey Coggins>> > >8/21/2005 > >Hello Mickey, I think you may be mixing up Molex and AMP pins and >connectors. Just make sure that you are using the pins and plastic connector >shells from the same manufacturer. > >If you are sure that your plastic shells are AMP Mate N Lok brand then you >can get compatible pins from Terminal Town http://www.terminaltown.com/ > >Pay very close attention to part numbers. > >OC > > > > -- is subject to a download and archival fee in the amount of $500 ________________________________________________________________________________
Date: Aug 21, 2005
Subject: Battery In Tail Questions
First off, I'd like to make the statement that I am a "noob" when it comes to some of these things, but I am slowly putting things together after reading The Connection and lurking here. So be gentle if I use some incorrect "terminology". :) I will most likely have some form of Z-13. At this point most likely a Z-13/Z-30 derivative. The dual bats will be in the tail. I believe that a good place to establish the main power distribution bus connection is to connect from the starter contactor. Maybe an ANL between? Is that correct? My biggest sticking point is with the bat bus and aux bat bus being in the tail. The feeds to the bat/aux bat bus items along with the e-bus alt feed will have to run the length of the fuse. I read in The Connection that it is wise to run all these wires along one side of the plane (Page-7 Note 5)? Is it ok to have all the large and small wires routed together in one conduit? Are there other issues I have to be concerned with? Maybe I'm just making too big a deal out of it and as long as my fuses and wires are properly sized, the battery buses being located in the tail will be just fine? I guess I just need confirmation that I'm on the right track and maybe a few "gotchas" that I need to look out for. Thanks All... -Sean RV-10 #40303 http://rv10.stephensville.com ________________________________________________________________________________
Date: Aug 20, 2005
> >Hi, >I'm looking for a way to be able to recharge or jumpstart my battery >from outside the plane which is in the back of an RV8. > >What I have in mind is a receptacle which is flush with the bottom >of the fuse and has a rubber plug to seal it while not in use. I >want the wire sized to be able to handle the current of a jump start >and bolted to the battery just like the start/ground cables are. I >am not aware I've seen something like this before except for a >bigger version like an APU jack in military aircraft but that's >overkill for an RV. But I thought I heard it discussed in past >years on the list but my archive search didn't turn up anything. I >was hoping West Marine would have something similar but I didn't >find anything. > >Any ideas? > >thx, >lucky lucky - This is not exactly what you describe but worth looking at: http://solanopilots.com/quickjumpsolution.htm Find more ideas at the AEC web site at "How to Articles" under "Downloadable Reference Materials". Click on "Low Cost Ground Power Jack for Your Airplane" Bill ________________________________________________________________________________
Date: Aug 21, 2005
Thanks for all the responses. I ordered the Piper receptical and plug from ACS. It's just what I was looking for and the link below confirmed it. I think it can easily work for both a battery tender and jump starter. Lucky -------------- Original message -------------- > > > > >Hi, > >I'm looking for a way to be able to recharge or jumpstart my battery > >from outside the plane which is in the back of an RV8. > > > >What I have in mind is a receptacle which is flush with the bottom > >of the fuse and has a rubber plug to seal it while not in use. I > >want the wire sized to be able to handle the current of a jump start > >and bolted to the battery just like the start/ground cables are. I > >am not aware I've seen something like this before except for a > >bigger version like an APU jack in military aircraft but that's > >overkill for an RV. But I thought I heard it discussed in past > >years on the list but my archive search didn't turn up anything. I > >was hoping West Marine would have something similar but I didn't > >find anything. > > > >Any ideas? > > > >thx, > >lucky > > > lucky - > > This is not exactly what you describe but worth looking at: > http://solanopilots.com/quickjumpsolution.htm > > Find more ideas at the AEC web site at "How to Articles" under > "Downloadable Reference Materials". Click on "Low Cost Ground Power > Jack for Your Airplane" > > Bill > > > > > > Thanks for all the responses. I ordered the Piper receptical and plug from ACS. It's just what I waslooking for and the link below confirmed it. I think it can easily work for both a battery tender and jump starter. Lucky -------------- Original message -------------- -- AeroElectric-List message posted by: courierboy(at)earthlink.net -- AeroElectric-List message posted by: "chris macy" Hi, I'm looking for a way to be able to recharge or jumpstart my battery from outside the plane which is in the back of an RV8. What I have in mind is a receptacle which is flush with the bottom of the fuse and has a rubber plug to seal it while not in use. I want the wire sized to be able to handle the current of a jump start and bolted to the battery just like the start/ground cables are. I am not aware I've seen something like this before except for a bigger version like an APU jack in military aircraft but that's
overkill for an RV. But I thought I heard it discussed in past years on the list but my archive search didn't turn up anything. I was hoping West Marine would have something similar but I didn't find anything. Any ideas? thx, lucky lucky - This is not exactly what you describe but worth looking at: http://solanopilots.com/quickjumpsolution.htm Find more ideas at the AEC web site at "How to Articles" under "Downloadable Reference Materials". Click on "Low Cost Ground Power Jack for Your Airplane" Bill criptions page, ________________________________________________________________________________
Date: Aug 21, 2005
Subject: IR Alternator OVP
Suppose one installed an internally regulated alternator and wanted overvoltage protection. Suppose the alternator has a B lead to power the bus, a S lead to sense voltage on the bus and adjust the alternator output, and a "G" lead for grounding. Question 1 - would breaking the ground wire cause the alternator to quit? Question 2 - If so, then could one have a sensor on the B lead that, during an overvoltage, would command a contactor in the ground wire to open and thus shut down the alternator? Question 3 - Could said contactor be a solid state relay instead? Ready for the flames. Stan Sutterfield RV-8A ________________________________________________________________________________
Subject: Re: IR Alternator OVP
Date: Aug 21, 2005
The common alternators are not wired that way. There is a I lead that is alternator control when it is working properly and opening and closing the I lead turns on and off the output power coming from the "B" terminal. The L terminal is part of the so called IDIOT light in autos and really only a ground lead for a light. Some also have a S lead for remote voltage sensing so voltage drop from the B lead to the battery can be allowed for. The ground is the alternator case and not something to be controlled. The problem with internally regulated alternators is IF (extremely rare) the internal power transistor in the internal field lead shorts there is no way to remove field power and the B lead will become a constant current source and the 55 amp alternator will try to provide 70 or more amps. The B lead voltage will quickly rise until the system bus absorbs 70 amps. The battery (once fully charged) will not clamp the voltage and in many cases the voltage rises from 14v to over 24 volts at around 1/2 volt per second and can end up over 30 volts if that is what is needed to load the alternator. Its true the 70 amps will decrease as the voltage rises but in the interim your electrical system is subject to massive failure from overvoltage if nothing is done. The OVP designs floating around including aeroelectric list have demonstrated on Vans aircraft to apparently create alternator failures. The problem may be the contactor used and the common contactor is not designed for and will NOT work reliably in this application. Only a contactor designed for this application will work and one device is the Kilovac unit that is rated for the very high arcing voltages present. The redesigned NSI system will have a reliable OV protection option. Lots more later but you are much more likely to have an engine failure than an alternator High voltage output failure. Current solid state technology is not cost effective (for the B lead circuit) but costs are dropping. Paul PS I have thrown my flamethrower in the trash given my new position at NSI. There are no dumb questions just dumb replys. An educated pilot is a safer pilot. ----- Original Message ----- From: <speedy11(at)aol.com> Subject: AeroElectric-List: IR Alternator OVP > > > Suppose one installed an internally regulated alternator and wanted > overvoltage protection. > Suppose the alternator has a B lead to power the bus, a S lead to sense > voltage on the bus and adjust the alternator output, and a "G" lead for > grounding. > Question 1 - would breaking the ground wire cause the alternator to quit? > Question 2 - If so, then could one have a sensor on the B lead that, > during an overvoltage, would command a contactor in the ground wire to > open and thus shut down the alternator? > Question 3 - Could said contactor be a solid state relay instead? > Ready for the flames. > Stan Sutterfield > RV-8A > > > ________________________________________________________________________________
Date: Aug 21, 2005
speedy11(at)aol.com wrote: > > > Suppose one installed an internally regulated alternator and wanted overvoltage protection. >Suppose the alternator has a B lead to power the bus, a S lead to sense voltage on the bus and adjust the alternator output, and a "G" lead for grounding. >Question 1 - would breaking the ground wire cause the alternator to quit? >Question 2 - If so, then could one have a sensor on the B lead that, during an overvoltage, would command a contactor in the ground wire to open and thus shut down the alternator? >Question 3 - Could said contactor be a solid state relay instead? >Ready for the flames. >Stan Sutterfield >RV-8A > It's likely that the case is common with the G terminal. You can check with an ohm meter. Even if it isn't, there would be no advantage to breaking the ground because the same current flows in the return path as the B+ path. As long as the solid state relay can handle the voltage & current, sure, it will work. (There are all kinds of subtle reasons why you can and/or can't do any of the above, but the experts would have to kill you if they explained it.) < obligatory :-) > Charlie ________________________________________________________________________________
Date: Aug 21, 2005
Subject: Re: Antenna Cable Connector Source
Check with an avionics shop... this is only available from Garmin. It's a horrendous price, about $20.00. My avionics shop said to use the solder tail connector, then put an in-line BNC connector in the coax, which is what I did. Vern Little DAVID REEL wrote: > >No luck in the archives. Does anyone have a source for the BNC type coaxial cable connector attached to the transponder tray with a snap ring on the Garmin GTX320A? My unit came with a solder type connector & I would like to have a BNC style connection to simplify panel removal. The Garmin part number is 330-00326-00. > >Dave Reel - RV8A > > > > ________________________________________________________________________________
Date: Aug 22, 2005
> > > At >Oshkosh, Bill Bainbridge immediately handed me his cell phone after dialing >up Tim Johnson & Tim explained that in theory this was correct but the >regulator may not have enough output ability to boost the system voltage >back to the proper range as the reg. was starting with a lower voltage. > > Interesting story Brian. I believe you are saying that the Cessna switch was preventing the alternator from getting sufficient field current. The switch itself must have been running somewhat warm. Some guys would have found this with just a voltmeter but I'd guess that at least a few of us with such a problem might have jumpered the regulator and when that didn't fix it, replaced the alternator. So I'd say you did well to track this down with only a spare regulator to show for it. (Jumpering from the battery to the alternator would have fixed it but not just jumpering across the regulator.) The thing that I like about a key switch is that nobody can crank the engine if the key is in my pocket. I'm using a marine key switch for cranking that has a 25 amp rating. Not for mags, just for cranking. thanks for sharing Ken ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Radio problems
Fellow builders: I am building a Velocity XLRG. I wonder if you could make some suggestions to help me to trouble shoot a radio problem Im having. I have Garmin CNX-80 and SL-30 radios. I am able to transmit fine but both radios will only recieve if you are within several hundred feet. Beyond that no reception. I have dipole antennas, nav and comm in each wing that were prebuilt so I have no acess to the antennas Each wing has one comm and one nav antenna. Each radio is connected to a different antenna, right and left wing. Im not sure which antenna is the nav and which is the comm but I tried both , one working better than the other but neither one beyond a few hundred feet. From the RG-58 cable comming from the wing I have a connection in the strake to RG-400 cable that runs to the radio with one more connection about a foot behind the radio from a prewired radio stack. I would appreciate any input you could suggest. Thanks Tim ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Battery In Tail Questions
> >First off, I'd like to make the statement that I am a "noob" when it >comes to some of these things, but I am slowly putting things together >after reading The Connection and lurking here. So be gentle if I use >some incorrect "terminology". :) > >I will most likely have some form of Z-13. At this point most likely a >Z-13/Z-30 derivative. The dual bats will be in the tail. How are you going to equip and use the airplane that you find a need for four power sources? >I believe that a good place to establish the main power distribution bus >connection is to connect from the starter contactor. Yes. > Maybe an ANL >between? Is that correct? No >My biggest sticking point is with the bat bus and aux bat bus being in >the tail. The feeds to the bat/aux bat bus items along with the e-bus >alt feed will have to run the length of the fuse. I read in The >Connection that it is wise to run all these wires along one side of the >plane (Page-7 Note 5)? Is it ok to have all the large and small wires >routed together in one conduit? Yes, bundle them right together with the battery feeders. > Are there other issues I have to be >concerned with? > >Maybe I'm just making too big a deal out of it and as long as my fuses >and wires are properly sized, the battery buses being located in the >tail will be just fine? I guess I just need confirmation that I'm on >the right track and maybe a few "gotchas" that I need to look out for. No, you're okay with the architecture described. I'm just concerned that you are perhaps carrying around way too much harware and wire for the task. Why wouldn't Z-13/8 and a single 17 a.h. battery on the firewall NOT meet the needs of your proposed flight system? Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
> >AeroElectric-List message previously posted by: Mickey Coggins > > ><AMP pins that go into a strobe AMP connector. > >I'm sure someplace like Digikey has them, but >I can't find them on their website. See http://dkc3.digikey.com/PDF/T052/0122-0132.pdf Page 127 Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Transponder "air switch"
> >Thanks, guys, for your help. Unfortunately, I still haven't gotten an answer >to my question. I originally asked: > >"In researching Transponders, many of the Install Manuals reference the use >of an "Air Switch" to switch the Transponder in and out of Standby mode as >the aircraft's airspeed crosses 30 kts+/-. Does anyone know anything about >these Air Switches and/or a source for them?" > >Allow me to add some additional information: > >The Transponder that I have narrowed my focus to is the Microair T2000. The >"Air Switch" is used to either ground a pin or lift the pin from ground >(configurable). It will not accept GPS information. > >Don't laugh, but I will be using the transponder on a US Part 103 >Ultralight. I will be operating just outside of the Chicago Class "B", so >I'd like to make sure that I stick out a bit. I checked with the FSDO and >they said I could do it, but the XPDR will have to undergo the same >inspections and checks that it would if it were installed in a GA plane. > >And since I will be operating out of an untowered airport, there would be no >advantage to having the XPDR "on" while on the ground. > >So, any help with the switch would be greatly appreciated.... The "air switch" was suggested as a means for keeping the transponder from being accidently left ON during ground ops. Some airport radar systems were vulnerable to strong signal overload when bunches aircraft taxiing on the ground were replying to radar interrogations. This is unlikely to be an issue for the way you'll use a Part 103 aircraft. Even if it were an "issue" . . . it's one that is easily addressed with attention to checklists that turn transponder ON on takeoff roll and turn it back off as you leave the active runway. I recommend you not install this feature. The vast majority of certified ships flying do not have such a switch. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: OVP thoughts
> > > > > > > Would you care to post some power distribution diagrams that > > describe your architecture. The lack of battery contactors piques > > our interest. You've expressed some interest in management > > of an OV event . . . it seems that elimination of battery contactors > > offers possibilities for some equally exciting failure modes > > that battery contactors are expected to control . . . > > > > Bob . . . > > > > > > >Sorry but my diagrams are in pencil and not very neat ;) > >Essentially I have a Z-14 with no battery contactors. My main interest >is two hot battery busses to feed the electrically dependant engine and >I don't ever want to disconnect those engine computers from a battery. > >Each of those busses distributes through a 6 fuse fuseblock and has low >voltage warnings. Almost everything else, including the starter, is >routed through a contactor and then a 10 fuse fuseblock. If I open that >contactor then it kills everything but the battery busses which is no >problem as the primary gyros are vacuum operated. I know vacuum is less >reliable but I prefer a six pack and vacuum was affordable at the time. >There is a low vacuum warning. Instead of plumbing an engine intake >manifold backup vacuum source I added a $30. flymarket 28 volt electric >T&B which works just fine on 12volts with surprisingly little change in >rpm or current draw. Do you plan to have a wing leveler? If so, this is a 99% better backup to vacuum gyros than hand-flying needle-ball-airspeed. > A handheld vhf and gps backup is available if >needed and one cigarette lighter outlet is powered from a battery bus. >There is an OVM and a B-lead contactor/relay on both the main 40 amp >alternator and the 20 amp PM alternator. > >This was fairly carefully considered as appropriate for my needs and a >bit simpler than the stock Z-14. There is no separate starter contactor >but I can still kill power to the automotive starter. This also >eliminates two battery contactors but adds in that one power >distribution contactor. The batteries are wee 8 AH units and the >crossfeed closes for cranking. Since I have 3 busses, all switches are >color keyed red (left battery bus for backup engine controls), blue >(right battery bus for primary engine), and yellow (the switched non >essential) bus. Pilot operating simplicity was very much a >consideration. All warnings (except low fuel and crossfeed closed) are >done with a Grand Rapids EIS. My first impression is that you've stirred a lot of separate worries into a really big bucket full of "solutions". If you have a vacuum system, why Z-14? How is your engine electrically dependent? What loads must be powered to keep the engine running? What advantage for eliminating battery contactors outweighs the value of maximizing control over the electrical system. It's not clear what your design goals were for the changes you've cited. Can be back up to a stock Z-14 and discuss how it falls short? Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
> > >Bob - > >We installed your ground power system in addition to the Z-14 in our >Lancair ES. I bought a small power supply on eBay that you had recommended >(12V nominal that had been set to 13.5V by the seller). We use it all the >time to check out the electrical system and instrumentation. Great setup. >Works great. > >I would like to use the external power receptacle to plug in a battery >charger/maintainer. It should work well to charge/maintain the #1 battery >when just the ground power switch/cb is on and the contactor is closed. >This means we give up .8 amp off the top of the charger's capacity. > >However, the problem comes when we want to charge/maintain the #2 battery. >By using the external power jack, we have to have all four of the >contactors closed - giving up 3.2 amps. The entire electrical system of >the aircraft would be hot while the batteries charge. We then worry about >one battery being over charged if the other one is lower. Any >tender/maintainer will stay on the charge cycle until it senses the lowest >battery at the peak charge before going to the maintain mode. Correct? > >Question: Is it a good idea to use the ground power system to charge and >maintain the batteries? > >If so, can you recommend a maintainer and a circuit change that can do >the job? > >Or, would it be better to just add 4 more wires and a couple of plugs to >the batteries and use two of the smaller tenders? The ground power jack was never intended to be useful for battery maintenance. It's main attributes are to supply high current, external power for ground maintenance operations and as battery assist during cold weather starts. If you want to install maintainers (largely unnecessary on RG batteries) then a small, 3 pin connector for ground, bat 1, bat 2 with relatively small wires tied to fuses on each battery's hot battery bus is the way to support the batteries while hangared. The self-discharge rate on RG batteries is exceedingly low. If you fly just once every 6 months, there's little benefit to be realized by "plugging in". Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
> >Bob, As a new builder trying to develop an understanding of aircraft >electrical systems, I would appreciate your detailed recommendation for >achieving "control of the OV condition at the SOURCE" as stated in (5) >below. I've followed the OV discussions for several weeks and remain >totally confused. >Thanks, >Roger Mell For the moment, don't waste any good sleeping time over this discussion. There are two schools of thought being considered: Classic ov protection systems have simply shut down the offending alternator/regulator combination when an ov condition was detected. This philosophy (Plan-A) has been in place for decades and is illustrated in any Z-figures that offer ov protection solutions. Since internally regulated alternators cannot be controlled from outside during an OV event, Plan-B suggests a sprinkling of ov clamping devices (transorbs) downstream of circuit protection devices (breakers or fuses) to protect each feeder to a vulnerable component. This philosophy has also been offered as a prophylactic against the load-dump transients which ANY form of engine driven power system will produce under the right circumstances. The big question to be answered for a rational design approach is to Plan B (1) figure out a way to disconnect the errant alternator during an OV event and (2) size any load-dump clamping hardware so that it's not at-risk for failure as a result of the load-dump event. There are multiple issues intertwined here. Both load-dump and ov events are rare. Don't spend much time worrying about them and concentrate on getting your airplane finished. What ever the elegant solution turns out to be, it can be addressed at any time later in your building process. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
> >Bob, > This seems to be the most talked about subject on this list and to some >extent the most confusing. > What is your current recommendation for a "positive off within 500ms" . . . >I had heard / read that you had concerns regarding earlier proposed >solutions (due to parts not performing as planned)?? > Thanks, >Bob Christensen See my post of a few minutes ago on the same subject. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2005
Robert L. Nuckolls, III wrote: > > > >> >> First off, I'd like to make the statement that I am a "noob" when it >> comes to some of these things, but I am slowly putting things together >> after reading The Connection and lurking here. So be gentle if I use >> some incorrect "terminology". :) >> >> I will most likely have some form of Z-13. At this point most likely a >> Z-13/Z-30 derivative. The dual bats will be in the tail. >> > > How are you going to equip and use the airplane that > you find a need for four power sources? > IFR Panel, Dual Chelton screens. Initially, single lightspeed ignition, but thinking if dual. Would go dual p-mag if they were out for 6 cyl. Most common use for this bird would be long x-country family trips with the kids in the back. Z-13/20 single bat would probably cover it, but what's the extra PC680 hurt? Especially if I plan a future upgrade to dual elec ignition? Also will have elec fuel pump. > >> I believe that a good place to establish the main power distribution bus >> connection is to connect from the starter contactor. >> > > Yes. > > >> Maybe an ANL >> between? Is that correct? >> > > No > > Ok, thought I saw that somewhere in The Connection, but can't find it now. > >> My biggest sticking point is with the bat bus and aux bat bus being in >> the tail. The feeds to the bat/aux bat bus items along with the e-bus >> alt feed will have to run the length of the fuse. I read in The >> Connection that it is wise to run all these wires along one side of the >> plane (Page-7 Note 5)? Is it ok to have all the large and small wires >> routed together in one conduit? >> > > > Yes, bundle them right together with the battery feeders. > > >> Are there other issues I have to be >> concerned with? >> >> Maybe I'm just making too big a deal out of it and as long as my fuses >> and wires are properly sized, the battery buses being located in the >> tail will be just fine? I guess I just need confirmation that I'm on >> the right track and maybe a few "gotchas" that I need to look out for. >> > > No, you're okay with the architecture described. I'm just concerned > that you are perhaps carrying around way too much harware and wire > for the task. Why wouldn't Z-13/8 and a single 17 a.h. battery > on the firewall NOT meet the needs of your proposed flight system? > > Bob . . . > > Would most likely be a Z-13/20 if going with Z-13-single bat. Also, the battery has to be in the tail for w&b reasons in the RV-10. With the IO-540-D4A5 up front it is a little nose heavy as it is already. Hence the engineering of the bat tray in the rear. I WISH, believe me, that I could have a single bat on the firewall with an IO-540 up front. It would make things SOOOOO much simpler. The only way I would be able to do that is to add more dead weight in the tail. I see your point about the need for dual bat. But I was just thinking ahead along the dual elec ignition route. The only thing I was wondering is all those darn wires running up to the front and back. Anything off the bat bus, including e-bus alt feed, aux alt back to the battery contactor, etc. It's about a 10 foot run from the bat tray in the tail of the RV-10 to the front. Even if I went the standard Z-13/20 route without adding the Z-30, the requirement of the bat in the tail would dictate a lot of big wire runs to the front and back. It would seem that adding in Z-30 for future expansion would be minimal compared to the runs that are already needed? Thanks Bob... -Sean ________________________________________________________________________________
Date: Aug 22, 2005
From: "Tim Dawson-Townsend" <Tdawson(at)avidyne.com>
How about split the difference with Main Battery in back and a smaller aux battery in front? TDT -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Sean Stephens Subject: Re: AeroElectric-List: Battery In Tail Questions Robert L. Nuckolls, III wrote: > > > >> >> First off, I'd like to make the statement that I am a "noob" when it >> comes to some of these things, but I am slowly putting things together >> after reading The Connection and lurking here. So be gentle if I use >> some incorrect "terminology". :) >> >> I will most likely have some form of Z-13. At this point most likely a >> Z-13/Z-30 derivative. The dual bats will be in the tail. >> > > How are you going to equip and use the airplane that > you find a need for four power sources? > IFR Panel, Dual Chelton screens. Initially, single lightspeed ignition, but thinking if dual. Would go dual p-mag if they were out for 6 cyl. Most common use for this bird would be long x-country family trips with the kids in the back. Z-13/20 single bat would probably cover it, but what's the extra PC680 hurt? Especially if I plan a future upgrade to dual elec ignition? Also will have elec fuel pump. > >> I believe that a good place to establish the main power distribution bus >> connection is to connect from the starter contactor. >> > > Yes. > > >> Maybe an ANL >> between? Is that correct? >> > > No > > Ok, thought I saw that somewhere in The Connection, but can't find it now. > >> My biggest sticking point is with the bat bus and aux bat bus being in >> the tail. The feeds to the bat/aux bat bus items along with the e-bus >> alt feed will have to run the length of the fuse. I read in The >> Connection that it is wise to run all these wires along one side of the >> plane (Page-7 Note 5)? Is it ok to have all the large and small wires >> routed together in one conduit? >> > > > Yes, bundle them right together with the battery feeders. > > >> Are there other issues I have to be >> concerned with? >> >> Maybe I'm just making too big a deal out of it and as long as my fuses >> and wires are properly sized, the battery buses being located in the >> tail will be just fine? I guess I just need confirmation that I'm on >> the right track and maybe a few "gotchas" that I need to look out for. >> > > No, you're okay with the architecture described. I'm just concerned > that you are perhaps carrying around way too much harware and wire > for the task. Why wouldn't Z-13/8 and a single 17 a.h. battery > on the firewall NOT meet the needs of your proposed flight system? > > Bob . . . > > Would most likely be a Z-13/20 if going with Z-13-single bat. Also, the battery has to be in the tail for w&b reasons in the RV-10. With the IO-540-D4A5 up front it is a little nose heavy as it is already. Hence the engineering of the bat tray in the rear. I WISH, believe me, that I could have a single bat on the firewall with an IO-540 up front. It would make things SOOOOO much simpler. The only way I would be able to do that is to add more dead weight in the tail. I see your point about the need for dual bat. But I was just thinking ahead along the dual elec ignition route. The only thing I was wondering is all those darn wires running up to the front and back. Anything off the bat bus, including e-bus alt feed, aux alt back to the battery contactor, etc. It's about a 10 foot run from the bat tray in the tail of the RV-10 to the front. Even if I went the standard Z-13/20 route without adding the Z-30, the requirement of the bat in the tail would dictate a lot of big wire runs to the front and back. It would seem that adding in Z-30 for future expansion would be minimal compared to the runs that are already needed? Thanks Bob... -Sean ________________________________________________________________________________
Subject: Question on Z-14 dual alt system!
Date: Aug 22, 2005
Bob, Why did you use a 4AWG line from the large alternator on the Z-14 drawing? I was thinking you could use a 10AWG line for runs of less then 10 feet or so without any problems. I was wondering if I am overlooking something, what are your thoughts on this? Mike Larkin Lancair Legacy Kitfox TS-11 Iskra -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Subject: Re: AeroElectric-List: OVP thoughts > >Bob, As a new builder trying to develop an understanding of aircraft >electrical systems, I would appreciate your detailed recommendation for >achieving "control of the OV condition at the SOURCE" as stated in (5) >below. I've followed the OV discussions for several weeks and remain >totally confused. >Thanks, >Roger Mell For the moment, don't waste any good sleeping time over this discussion. There are two schools of thought being considered: Classic ov protection systems have simply shut down the offending alternator/regulator combination when an ov condition was detected. This philosophy (Plan-A) has been in place for decades and is illustrated in any Z-figures that offer ov protection solutions. Since internally regulated alternators cannot be controlled from outside during an OV event, Plan-B suggests a sprinkling of ov clamping devices (transorbs) downstream of circuit protection devices (breakers or fuses) to protect each feeder to a vulnerable component. This philosophy has also been offered as a prophylactic against the load-dump transients which ANY form of engine driven power system will produce under the right circumstances. The big question to be answered for a rational design approach is to Plan B (1) figure out a way to disconnect the errant alternator during an OV event and (2) size any load-dump clamping hardware so that it's not at-risk for failure as a result of the load-dump event. There are multiple issues intertwined here. Both load-dump and ov events are rare. Don't spend much time worrying about them and concentrate on getting your airplane finished. What ever the elegant solution turns out to be, it can be addressed at any time later in your building process. Bob . . . -- 8/18/2005 -- 8/18/2005 ________________________________________________________________________________
Date: Aug 22, 2005
Tim Dawson-Townsend wrote: > > > How about split the difference with Main Battery in back and a smaller aux battery in front? > > TDT > > I thought about that Tim. But doesn't it still require runs to the tail? If using Z-30 for example? A run between bat contactors and a run for the e-bus alt feed to the main bat bus? I'm struggling with minimizing large wire runs. I guess I just can't picture it. Maybe if I saw something in front of me it would just click I guess. "The light would go on". :) -Sean > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Sean > Stephens > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Battery In Tail Questions > > > Robert L. Nuckolls, III wrote: > >> >> >> >> >>> >>> First off, I'd like to make the statement that I am a "noob" when it >>> comes to some of these things, but I am slowly putting things together >>> after reading The Connection and lurking here. So be gentle if I use >>> some incorrect "terminology". :) >>> >>> I will most likely have some form of Z-13. At this point most likely a >>> Z-13/Z-30 derivative. The dual bats will be in the tail. >>> >>> >> How are you going to equip and use the airplane that >> you find a need for four power sources? >> >> > IFR Panel, Dual Chelton screens. Initially, single lightspeed ignition, > but thinking if dual. Would go dual p-mag if they were out for 6 cyl. > Most common use for this bird would be long x-country family trips with > the kids in the back. Z-13/20 single bat would probably cover it, but > what's the extra PC680 hurt? Especially if I plan a future upgrade to > dual elec ignition? Also will have elec fuel pump. > >> >> >>> I believe that a good place to establish the main power distribution bus >>> connection is to connect from the starter contactor. >>> >>> >> Yes. >> >> >> >>> Maybe an ANL >>> between? Is that correct? >>> >>> >> No >> >> >> > Ok, thought I saw that somewhere in The Connection, but can't find it now. > >> >> >>> My biggest sticking point is with the bat bus and aux bat bus being in >>> the tail. The feeds to the bat/aux bat bus items along with the e-bus >>> alt feed will have to run the length of the fuse. I read in The >>> Connection that it is wise to run all these wires along one side of the >>> plane (Page-7 Note 5)? Is it ok to have all the large and small wires >>> routed together in one conduit? >>> >>> >> Yes, bundle them right together with the battery feeders. >> >> >> >>> Are there other issues I have to be >>> concerned with? >>> >>> Maybe I'm just making too big a deal out of it and as long as my fuses >>> and wires are properly sized, the battery buses being located in the >>> tail will be just fine? I guess I just need confirmation that I'm on >>> the right track and maybe a few "gotchas" that I need to look out for. >>> >>> >> No, you're okay with the architecture described. I'm just concerned >> that you are perhaps carrying around way too much harware and wire >> for the task. Why wouldn't Z-13/8 and a single 17 a.h. battery >> on the firewall NOT meet the needs of your proposed flight system? >> >> Bob . . . >> >> >> > Would most likely be a Z-13/20 if going with Z-13-single bat. Also, the > battery has to be in the tail for w&b reasons in the RV-10. With the > IO-540-D4A5 up front it is a little nose heavy as it is already. Hence > the engineering of the bat tray in the rear. I WISH, believe me, that I > could have a single bat on the firewall with an IO-540 up front. It > would make things SOOOOO much simpler. The only way I would be able to > do that is to add more dead weight in the tail. > > I see your point about the need for dual bat. But I was just thinking > ahead along the dual elec ignition route. The only thing I was > wondering is all those darn wires running up to the front and back. > Anything off the bat bus, including e-bus alt feed, aux alt back to the > battery contactor, etc. It's about a 10 foot run from the bat tray in > the tail of the RV-10 to the front. > > Even if I went the standard Z-13/20 route without adding the Z-30, the > requirement of the bat in the tail would dictate a lot of big wire runs > to the front and back. It would seem that adding in Z-30 for future > expansion would be minimal compared to the runs that are already needed? > > Thanks Bob... > > -Sean > > > ________________________________________________________________________________
Date: Aug 22, 2005
> > > My first impression is that you've stirred a lot of separate > worries into a really big bucket full of "solutions". If you > have a vacuum system, why Z-14? How is your engine electrically > dependent? What loads must be powered to keep the engine running? > What advantage for eliminating battery contactors outweighs the > value of maximizing control over the electrical system. It's > not clear what your design goals were for the changes you've cited. > Can be back up to a stock Z-14 and discuss how it falls short? > > Bob . . . > > > For an experimental one off system with many homemade components and wiring, I have chosen to provide complete electronic redundancy. Sure this is probably overkill but I will not be uncomfortabe taking this automotive powered airplane on long trips or over hostile territory as far as fuel and ignition concerns. Many auto conversions never seem to go very far from home base and I don't want to stay close to home for hundreds of hours while establishing system reliability. This electrical architecture is far more flexible than adding extra small batteries for ignition or injection backup. Anyway when I realized that the vast majority of my wiring was ignition and fuel injection that would go on a battery bus anyway and that nothing else was what I considered essential, then classic battery contactors don't seem to offer me an advantage. They would add another contactor or two and not really let me de-energise any extra wiring since the contactors and batteries are all very close together. I guess one design goal was that there is no way that the battery can be disconnected from an alternator while leaving that alternator connected to any loads. That is in some ways an extension of the philosophy of running the engine off a battery bus and I think it is perhaps appropriate for an IR alternator, which is the only type that I can personally envision purchasing anymore for a new installation. I can still de-energise everything that battery contactors would de-energise. Ken ________________________________________________________________________________
Date: Aug 22, 2005
> I'm struggling with minimizing large wire runs. I guess I just can't > picture it. Maybe if I saw something in front of me it would just click > I guess. "The light would go on". :) I have not run a W&B on the RV10, but it might be possible to take the amount of weight you are adding in wiring and add it to the very end of the fuselage, and put the batteries on the firewall. I've got my batteries behind my baggage area on my RV8, but since I'm using a Subaru engine, which has a starter that does not draw as much current as a Lycoming, I only need AWG#6 welding cable from the batteries to the starter. -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Radio problems
Tim - Do you have an audio/intercomm box installed? In the setup section of theSL30, there are several choices to make in the system. Same for the 480 in its ground maintenance mode. If you have not already done so, check these settings. I don't have the manuals with me, but there are gain settings in both radios. If you have a Garmin 340 audio box, it may not be wired right for the audio feed to your headsets. Also, are the two comm antennae installed vertically in the wing tip? John > > > I am able to transmit fine but both radios will only recieve if you are > within several hundred feet. Beyond that no reception. > I have > dipole antennas, nav and comm in each wing that were prebuilt so I > have no access to the antennas Each wing has > one comm and one nav > antenna. Each radio is connected to a different antenna, right and > left wing. Im not sure which > antenna is the nav and which is the comm but I tried both , one working > better than the other but neither one beyond a few > hundred feet. ________________________________________________________________________________
Date: Aug 22, 2005
Subject: Re: Low System Voltage Troubleshooting
I'm keeping Brian's posting together in it's entirety with this response so that the whole story will be available in one message. The "Cessna style" split rocker switches have been a source of regulator instability problems on both production and certified ships for decades. This simple fact might lead one to believe that the split rocker switch was of inferior design or manufacture. Please know that all the switch guts behind the panel for the classic split rocker are exactly the same as for the S700 series toggle switches offered by B&C and others. Both switches are made by Carling. The S700 are catalog items, the split rocker is a custom. The REASON for voltage regulations problems has root cause of increased contact resistance in the closed switch. When field current AND regulator voltage sense come through the same contacts, the switch can ADD to the sum total of ALL resistances in this pathway. When they rise to a sufficiently high level, the voltage regulator can mis-behave. Quite often, folks have made the problem go away by replacing the switch . . . but this is only one of several components that contribute to the instability. There are so many split rocker switches in service (tens of thousands) that the probability of spotlighting one of these switches as contributor to voltage instability is quite high. However, replacing the split rocker with a toggle is NOT a golden solution. There is potential for the same problem to arise later no matter which style of switch is used. There are some design philosophies that will make the problem go away entirely. Its a good thing to separate field supply and voltage sense feed lines. This change was made to the B&C product lines years ago. Unfortunately, builders who use the generic Ford regulators are not able to separate the lines. Not a big deal . . . but to live comfortably with this configuration, one should minimize joints in series with the field/sense feed line. This was one of the considerations that made crowbar ov protection attractive 20 years ago . . . it provides a means for OV sense and shutdown while adding NO series resistance to the circuit. New spilt rocker switches are often tagged as problem children. Probably because they're a special order switch that tend to set in the warehouse for a long time. An unused but new switch may have some storage corrosion on what used to be shinny contacts. This may well reduce service life on what the installer believes is a "good as new" switch. This is NOT a recommendation to avoid either the split rocker OR the generic three-wire regulators. The purpose of this dissertation is to make folks aware of how these components behave under certain conditions. When and if one has a voltage instability problem, total resistance between the bus and the regulator should be reduced . . . which may include replacement of the battery master switch. > >Hi Folks > >I just wanted to comment on a problem I had been having for 6 years on my >aircraft. This is in response to a previous post I made about 3 weeks ago >& Kevin Horton & Ken Klehman were kind enough to supply some advice. > >The electrical system is a classic Nuckolls system. It is very similar to >Z-1 as published in 1996. This is a simple system with a linear >regulator, mine is a B&C LR-3B. I did not use a toggle switch but a >standard aircraft key switch & Cessna style Battery/Alternator Master switch. > >My helper during construction was a very bright guy who has his masters in >Elec. Engineering. The electrical installation is really really good due >to his work. He even used waxed lacing for wire ties which looks and >performs beautifully. Only 1 operational problem right from day one which >was July 25, 1999. > >I was having so much fun flying etc. that I did not work too hard to solve >it as it did not keep me out of the air but bugged me as I know it was not >right. > >The problem was the system voltage peaked at about 13.8 V and decreased >each time I added a load of any kind to the system. Each load would drop >the system load by about 0.1-0.2 volts. I could easily drop the system >voltage down to 12.8-12.9 volts but as most of my flying was day VFR, it >rarely got there. > >I have an EI gauge to show volts/amps & also my Garmin 195 would display >the same. (I reasoned that it made sense to have the EI gauge mounted on >the Essential bus as I would want to know the condition of the battery if I >had to feed the E bus directly per the alternate feed switch if the >alternator went down). I did realize that my EI gauge was fed from the >Essential bus and therefore would read a lower voltage due to the drop >across the bridge rectifier which feeds the Essential bus from the Main >bus, (or buss?). I also checked it with 2 portable digital multimeters >which did not show anything was wrong with the readings. I also adjusted >the trim pot on the regulator which did not help very much. > >I changed belts for the alternator, discussed the matter with B&C & >followed the trouble shooting specs. as supplied which were all within the >stated limits. Finally I decided in my finite wisdom that it must be the >regulator so I purchased a new reg. at $228 from B&C and installed it with >high hopes. As you probably guessed, I restarted the engine and the >numbers were EXACTLY the same. What a downer! > >I posted my problem 3 weeks ago as I mentioned. Kevin suggested that I >move the feed point of the EI gauge to the Main bus. This helped but still >the drop continued. Ken suggested that I check all the points from the >alternator back to the main bus i.e. look for voltage drops at each >connection starting with the B lead and so forth. I did realize that I was >working with a digital multimeter and was testing the system with no load >applied during the resistance check & does not represent real life but I >did turn loads on the see if that would show any voltage drop. All >resistance drops were less than 1 ohm & therefore could see nothing obvious. > >I called B&C again and Tim Johnson suggested a similar course of action as >per Ken & Kevin. However, his ears perked up when I mentioned my master >switch. He said that may be a problem.
August 10, 2005 - August 22, 2005
AeroElectric-Archive.digest.vol-es
