AeroElectric-Archive.digest.vol-fh
January 14, 2006 - January 19, 2006
      VHF navigation portion of the 430.
      Since you do want to fly IFR, I think you will need an approved resolver
      input device.
      Is there a resolver function available in the BMA/Lite(G3)? Can it present
      the glide path indication?
      Provided the BMA/Lite(G3) provides those capabilities, I think it  could work!
      If all you want from the 430 is IFR GPS functions, a good case can be made
      for doing it all with the 430 control unit.  Since you are the person that  has
      to approve the installation and explain your reasoning at a hearing, it  wou
      ld seem to me that you could support the GPS functions as being in  substantial
      compliance with the applicable GPS TSO even without  a separate  CDI and
      resolver.
      Happy  Skies,
      Old Bob
      AKA
      Bob Siegfried
      Ancient Aviator
      Stearman  N3977A
      Brookeridge Air Park LL22
      Downers Grove, IL 60516
      630  985-8503
      In a message dated 1/14/2006 8:24:39 A.M. Central Standard Time,
      flyboy.bob(at)gmail.com writes:
      Hi  Bob,
      It is a RV8 and I plan to fly some "light" IFR . . . I don't know  what you
      mean by "full ILS approaches" but my intent is to fly GPS/VOR  enroute
      and GPS, VOR and ILS approaches with a GNS430 . . . the only "non  TSO'd"
      piece of the puzzle is the BMA/Lite(G3).  I also have a  DigiTrak auto
      pilot.
      Anything I've read to date leads me to feel  this meets the language and
      intent of the FARs,  etc.?
Date: Jan 14, 2006
Subject: Re: EFIS Comparisons
I understand that . . . the 430 will feed the BMA/Lite for that purpose. Thanks, Bob On 1/14/06, Dan Beadle wrote: > > Dan.Beadle(at)hq.InclineSoftworks.com> > > The 430 does not have glide slope indicator. Therefore the on-board CDI > is not enough to fly the ILS, jus the localizer. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob > C. > Sent: Saturday, January 14, 2006 6:21 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: ***SPAM*** Re: AeroElectric-List: EFIS Comparisons > > > > Hi Bob, > > It is a RV8 and I plan to fly some "light" IFR . . . I don't know what > you > mean by "full ILS approaches" but my intent is to fly GPS/VOR enroute > and GPS, VOR and ILS approaches with a GNS430 . . . the only "non TSO'd" > piece of the puzzle is the BMA/Lite(G3). I also have a DigiTrak auto > pilot. > > Anything I've read to date leads me to feel this meets the language and > intent of the FARs, etc.? > > Thanks, > Bob > > > On 1/14/06, BobsV35B(at)aol.com wrote: > > > > > > > > > > Good Morning Bob, > > > > Do you intend to use the 430 IFR or VFR? > > > > Do you want to execute full ILS approaches? > > > > For VFR, there is no question that a CDI is not needed. > > > > For IFR, things get a bit stickier. Beyond that, it makes a > difference > > if > > the aircraft is experimental or normal category. > > > > Do you intend to use an autopilot with the GPS? > > > > There is no question in my mind as to whether or not the set can be > used > > successfully without a CDI for any and all GPS functions it is capable > of > > performing. Unfortunately, the FAA may not agree with that statement! > > > > Let us know precisely how you want to use it and we may be able to > offer > > some help. > > > > Happy Skies, > > > > Old Bob > > AKA > > Bob Siegfried > > Ancient Aviator > > Stearman N3977A > > Brookeridge Air Park LL22 > > Downers Grove, IL 60516 > > 630 985-8503 > > > > > > In a message dated 1/14/2006 2:49:44 A.M. Central Standard Time, > > flyboy.bob(at)gmail.com writes: > > > > I'm pretty sure you can use a GNS430 without a CDI for GPS Enroute > and > > Approach? . . . It has a "CDI" of sorts built in. I plan to use the > > EHSI > > function of the BMA Lite for ILS and or VOR CDI function and I > believe > > that > > is OK too? The GPS in the "Lite" should make a nice backup too. > > > > Regards, > > Bob > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: EFIS Comparisons
Date: Jan 14, 2006
OK, I can understand that. I hope you've been following the EFIS discussion on this list. Let me beat my drum one more time. These low cost EFIS displays (Pick your favorite) are hypnotic and compelling, if cross checks start to disagree, the pilot is going to want to keep on flying that pretty EFIS unless you hit him over the head. We don't know all their failure modes and their software (with the exception of Chelton) remains untested to the extent necessary to pass DO 178, their hardware is not DO 160 certified. That means you're the beta tester. Do you want to bet your life in that situation? Mark my words, we're going to have some experimental airplanes equipped with low cost EFIS systems get into some serious fatal trouble. That body count is going to raise the level of visibility of this issue with the FAA and soon big brother will be breathing down our necks. Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of IFR conditions. Bruce At the risk of further pounding on this dead horse whose meat is already well-tenderized, the admonishment to avoid the noncertified EFIS for IFR is a bit broad (IMHO). I fly with a dual GRT EFIS (this does not give me redundancy, just contemporary PFD and EIS display) driven by a single AHRS. For redundancy, I rely on old round AS, Alt and vertical compass and, most importantly, a Mid-Continent AI with its own internal battery. Secondary redundancy (but reliant on the same electrical system as the AHRS/EFIS is a TruTrak A/P which will take me where I want to go as long as the lights are on. So, I would concede your proposition with just a bit of technical modification, "low cost, noncertified EFIS systems are okay for VFR airplanes but stay out of IFR conditions unless you have a well thought out, well designed redundant primary flight system." But of course, I would make the same admonishment for a certified EFIS! Chuck ________________________________________________________________________________
Date: Jan 14, 2006
Bob, Yes the BMA/Lite "has" the resolver capability and does display the ILS "needles" in both the HSI and ADI mode . . . for VOR you would have to be in HSI mode. I'm not flying yet but it is an analog interface with the BMA/Lite sending OBS information back to the 430 . . . I assume the resolving function is done in the 430? and the BMA/Lite displays the to/from and CDI indication. I have an AH, TSO'd Altimeter, and AS and VSI for "back-up" I'm not sure this is all ready for prime time but by the time I'm flying and have my 40 hours flown off I plan to prove the functionality and reliability of what I just said! Thanks for your input! Bob On 1/14/06, BobsV35B(at)aol.com wrote: > > > Good Morning Bob, > > The reference to "full" ILS was meant to include a glide slope. There is > no > way that I am aware of to see the glide slope on the 430 control > unit face. > Consequently a CDI is needed. While I am not very familiar with how the > 430 > works, I also believe you will need a resolver to input VOR radials > for the > VHF navigation portion of the 430. > > Since you do want to fly IFR, I think you will need an approved resolver > input device. > Is there a resolver function available in the BMA/Lite(G3)? Can it present > the glide path indication? > > > Provided the BMA/Lite(G3) provides those capabilities, I think it could > work! > > > If all you want from the 430 is IFR GPS functions, a good case can be made > for doing it all with the 430 control unit. Since you are the person > that has > to approve the installation and explain your reasoning at a hearing, > it wou > ld seem to me that you could support the GPS functions as being > in substantial > compliance with the applicable GPS TSO even without a separate CDI and > resolver. > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Air Park LL22 > Downers Grove, IL 60516 > 630 985-8503 > > > In a message dated 1/14/2006 8:24:39 A.M. Central Standard Time, > flyboy.bob(at)gmail.com writes: > > Hi Bob, > > It is a RV8 and I plan to fly some "light" IFR . . . I don't know what > you > mean by "full ILS approaches" but my intent is to fly GPS/VOR enroute > and GPS, VOR and ILS approaches with a GNS430 . . . the only "non TSO'd" > piece of the puzzle is the BMA/Lite(G3). I also have a DigiTrak auto > pilot. > > Anything I've read to date leads me to feel this meets the language and > intent of the FARs, etc.? > > Thanks, > Bob > > ________________________________________________________________________________
Date: Jan 14, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Common Grounding
> >If you choose to use plain aluminum...expect mysterious ground problems >and the retrofit of a real ground at your first annual.... > >Bob N, Said>> > We need to make a distinction between aluminum strip having > the necessary cross section to replace an equal length of other > wire and the classic aluminum wire used by the power distribution > industry. > > A strip of alclad aluminum is no more difficult to work with than > to simply use your aluminum airframe as a ground system. We use > airframe grounds all over the airplanes at RAC and this is not > an automatic recipe for problems. It's really coarse/soft > aluminum in the old wire that make it difficult to achieve > gas tight joints and the coarse stranding is particularly vulnerable > to vibration issues. > >Eric Says: Bob, It's true that metal aircraft use the skin as a conductor, >for lighting and antennas, but I would guess where grounding is a big >concern, like sensors and complex electronics a copper ground is added. >That's also why remote industrial sensors are usually current loops, not >voltage levels. > >The forest of tabs is such a good idea...single point grounds. We're mixing apples, and grapes here. Yes, SENSORS that generate small signals are NEVER locally grounded. They'll wave around on the end of a shielded pair or trio and all outbound power, control and inbound signals and grounds are carried in the wire. This is irrespective of the aircraft's structural materials. The idea of using an embedded strip in a glass/epoxy airplane to carry (+) and (-) the length of the airplane in a canard pusher or between firewall and aft battery in a tractor airplane is no different electrically than using wires of any kind. The technology concerns are only for crafting long lived, gas tight, low resistance joints at the ends. Again, this matters not what the conductor material is, the requirements are the same so methodology has to be adjusted to accommodate characteristics of the materials chosen. In the case of coarse stranded, soft aluminum favored by the power distribution industry, folks were unwilling or unable to develop satisfactory termination techniques so the brief terms of duty at Piper (and briefer at Cessna) were abandoned. Availability of fine aluminum strands that behave pretty much like copper in the joint makes the flexibility, vibration resistance and joining technology issues pretty much go away. I believe we're using copper-clad aluminum in Premier and Horizon. I need to check that. None of the above has anything to do with architecture of the ground system. Appliances other than the small-signal devices described above are quite often grounded locally in metallic airframes. This picture . . . http://www.aeroelectric.com/Pictures/Grounding/MVC-699X.JPG . . . is but one of many examples of airframe grounding found on all of our aluminum aircraft at RAC/Beech. > >Earlier Charlie Asked: >>I've often wondered if the 'aluminum brazing' >products hyped at flyins & available at welding shops could be used to >transition from AL bar stock to a copper tab for mechanical connections. >They are supposed to work on 'most non-ferrous metals'. This might >accomplish Rick's goal of light, cheap, simple, safe. Is that worth exploring? > >Eric Says: The melting points of aluminum and copper are so different that >successfully joining the two is not a matter for the amateur. I'm guessing >that the required tools are generally outside the range of homebuilders. The "brazing" rods I saw at OSH were a basically a soft solder technique. Joining happens by alloying the surface of joined materials with the thin interface between material and the liquid solder. IF these same materials will alloy with copper too, then they're obviously suited to joining of copper and aluminum. Certainly the joints would be gas tight! That's what solder does best. I used to have some of this stuff, I'll see if I can find it and do some experiments in the shop. If anyone else has some, we'd be pleased to hear the results of your experiments too. But in any case, effective use of these joining technologies is not influenced by the melting temperatures of the materials to be joined. One may join copper to steel with tin/lead solders at temperatures much below the melting points of either copper or steel. See chapter 9 of the 'Connection Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: E-Bus Avionics Switch ?
Exactly what I'm planning, and for the same reasons (keeping GRT EFIS off during cranking, etc.) I will / should have my Excel file finished by tonight, showing this architecture with relay feed for both the primart and backup e-bus feed paths, as well as a way to share one OVP crowbar module automatically between two alternators (main and SD-8). -Bill B -----Original Message----- From: LarryRobertHelming <lhelming(at)sigecom.net> Subject: Re: AeroElectric-List: E-Bus Avionics Switch ? ----- Original Message ----- > > > Just thinking? On any of the Endurance Bus drawings. Other than the > "don't > really need it" discussion and parts count issue, what would the downsides > be of adding a S704 contactor between the D25 and E-Bus so that you > effectively used the whole E-bus as an Avionics bus. This would assume > that > the E-bus load can be easily carried by the S704 which I think is rated at > 20 amps and has low continuous draw. It would actually save several > switches for EFIS systems like the GRT which are not internally switched. > I don't see any problem other than having a switch that could fail that would stop current from getting to the e-bus. But that problem is covered because you have a switch to energize on the e-bus and bypass the D25 route. I think your idea is a good way to implement the avionics bus capability. I have been running my plane without an avionics bus and switch but have run on occassions when I would like to turn the master on and not have my transponder, encoder, and Dynon power up. I think I will implement your idea. If it turns out to be a problem, I will report back here. Bob N might want to consider this but I doubt that he will due to his thinking that today's instruments/radios do not need the protection of an avionics bus; But it does have some convience. Indiana Larry, RV7 78 hours "Please use the information and opinions I express with responsibility, and at your own risk." Achieving a certain level of success in life is only important if you can finally enjoy the level after you've reached it. L R Helming > > > ________________________________________________________________________________
Date: Jan 14, 2006
Good Morning Bob, Sounds good to me except I would strongly suggest the installation of a classic Turn and Bank Needle. There is no instrument that is more reliable and it weighs very little. When all else fails, the T&B can easily get you safely to Mother Earth. Not only that but it is completely non tumbling and can be used as guidance to recover from a spin. I am all for using modern solid state equipment. But nothing beats the T&B for a back-up! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/14/2006 10:34:25 A.M. Central Standard Time, flyboy.bob(at)gmail.com writes: Bob, Yes the BMA/Lite "has" the resolver capability and does display the ILS "needles" in both the HSI and ADI mode . . . for VOR you would have to be in HSI mode. I'm not flying yet but it is an analog interface with the BMA/Lite sending OBS information back to the 430 . . . I assume the resolving function is done in the 430? and the BMA/Lite displays the to/from and CDI indication. I have an AH, TSO'd Altimeter, and AS and VSI for "back-up" I'm not sure this is all ready for prime time but by the time I'm flying and have my 40 hours flown off I plan to prove the functionality and reliability of what I just said! ________________________________________________________________________________
Date: Jan 14, 2006
Exactly what I like about the Trio EZ-Pilot: built-in turn needle and mechanical inclinometer ball, plus it could fly the plane better than I could if I got a kidney stone or a case of the greens. It suffers no more from electrical system dependency than the ol' Turn and Bank does, so I'm happy with the substitution. -Bill -----Original Message----- From: BobsV35B(at)aol.com Subject: Re: ***SPAM*** Re: AeroElectric-List: EFIS Comparisons Good Morning Bob, Sounds good to me except I would strongly suggest the installation of a classic Turn and Bank Needle. There is no instrument that is more reliable and it weighs very little. When all else fails, the T&B can easily get you safely to Mother Earth. Not only that but it is completely non tumbling and can be used as guidance to recover from a spin. I am all for using modern solid state equipment. But nothing beats the T&B for a back-up! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/14/2006 10:34:25 A.M. Central Standard Time, flyboy.bob(at)gmail.com writes: Bob, Yes the BMA/Lite "has" the resolver capability and does display the ILS "needles" in both the HSI and ADI mode . . . for VOR you would have to be in HSI mode. I'm not flying yet but it is an analog interface with the BMA/Lite sending OBS information back to the 430 . . . I assume the resolving function is done in the 430? and the BMA/Lite displays the to/from and CDI indication. I have an AH, TSO'd Altimeter, and AS and VSI for "back-up" I'm not sure this is all ready for prime time but by the time I'm flying and have my 40 hours flown off I plan to prove the functionality and reliability of what I just said! ________________________________________________________________________________
Date: Jan 14, 2006
Which is exactly why there are zero certified EFIS systems that are certified as *primary* (in small single engines anyway). The G1000 in my C182, is specified as secondary, the primary instruments are the AS, AI, ALT - regular old vacuum driven 3.125" steam gauges... :) Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Saturday, January 14, 2006 11:30 AM Subject: RE: AeroElectric-List: EFIS Comparisons --> OK, I can understand that. I hope you've been following the EFIS discussion on this list. Let me beat my drum one more time. These low cost EFIS displays (Pick your favorite) are hypnotic and compelling, if cross checks start to disagree, the pilot is going to want to keep on flying that pretty EFIS unless you hit him over the head. We don't know all their failure modes and their software (with the exception of Chelton) remains untested to the extent necessary to pass DO 178, their hardware is not DO 160 certified. That means you're the beta tester. Do you want to bet your life in that situation? Mark my words, we're going to have some experimental airplanes equipped with low cost EFIS systems get into some serious fatal trouble. That body count is going to raise the level of visibility of this issue with the FAA and soon big brother will be breathing down our necks. Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of IFR conditions. Bruce At the risk of further pounding on this dead horse whose meat is already well-tenderized, the admonishment to avoid the noncertified EFIS for IFR is a bit broad (IMHO). I fly with a dual GRT EFIS (this does not give me redundancy, just contemporary PFD and EIS display) driven by a single AHRS. For redundancy, I rely on old round AS, Alt and vertical compass and, most importantly, a Mid-Continent AI with its own internal battery. Secondary redundancy (but reliant on the same electrical system as the AHRS/EFIS is a TruTrak A/P which will take me where I want to go as long as the lights are on. So, I would concede your proposition with just a bit of technical modification, "low cost, noncertified EFIS systems are okay for VFR airplanes but stay out of IFR conditions unless you have a well thought out, well designed redundant primary flight system." But of course, I would make the same admonishment for a certified EFIS! Chuck ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: Solder Station
> > >The ones on EBay are most likely from an enterprising set of folks who buy >them from the big electronics mfg's or repair stations and auction/sell >them on eBay. The METCAL soldering tools are the acme of soldering tools. They're only capable of delivering about 30 watts to the tip but the WHOLE 30 watts gets out there. The tips are temperature controlled. Tips are easy to change . . .just seconds even when hot . . . the cold one is ready us use in under a minute. Tip sizes range from about .2" flats to .015" points. I can solder a terminal on a 2AWG wire with the big guy and install .025" pitch surface mount chips with the other one. RAC has used nothing but METCAL for about 20 years. I dumped all of the solder stations in my shop about 6 years ago and went to METCAL's purchased off Ebay. Whole stations with power supply, wand, tips and wand holder will be more expensive. Wands take the most beating so I try to buy orphaned power supplies (picked up one last week for $40). I like to get new wands from a distributor (typically $60) and tips off Ebay (1 to $10 each). This is an excellent way to acquire what is arguably one of the most versatile soldering systems out there for well under $200. I have two on the bench, one in my grab-it-and- run toolkit and I've purchased perhaps another half dozen for family members. I've had a couple of power supplies go TU over the years but they're so inexpensive to replace, I don't bother to repair them. It's not worth the time. The supply I bought last week is a "spare". Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: Z-13 questions
> >A followup of question (2) from the peanut gallery, Bob... > >Could you oversize the fuse in the fuseblock that feeds the 5A OVP CB to >"guarantee" the breaker pops before the fuse blows? Is there a fuse rating >that'll provide the same level of hard fault protection as the 22 AWG >fuselink while still allowing the 5A OVP CB to pop first? Sure. I did some experiments with the ATC fuses a few years ago. 25A fuses will stay in place upstream of a 5A breaker. 30A wouldn't hurt anything. You might want to upsize the feeder from fuse to breaker to maybe 18AWG. But the fusible link makes so much sense here, I wouldn't recommend it. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
Quite often, in discussions like these, we tend to be hardware orientated and totally overlook the human factors engineering in the systems. With your dual GRT EFIS you're a step ahead of most. Are you cross checking as part of your normal scan? Again, the part of this equation that most worries me is (except in black screen failures) the time it takes the pilot to realize that something is seriously wrong, determine the failed instrument, and take corrective action. In some stages of IFR flight that amount of time will just not be there. If the ADI rolls inverted at 8,000 feet when you're on top, no problem. But if you're 300 AGL on the ILS?? This is the main reason for dual systems/electronic comparator/3rd gyro, to give you a chance to survive when time is of the essence. You're free to fly with whatever you want as long as it fits your comfort level. But when I see builders wanting to charge off into hard IFR with a BMA, T&B, and ASI, I just got to say - Are you sure you want to do this? Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Saturday, January 14, 2006 11:30 AM Subject: RE: AeroElectric-List: EFIS Comparisons OK, I can understand that. I hope you've been following the EFIS discussion on this list. Let me beat my drum one more time. These low cost EFIS displays (Pick your favorite) are hypnotic and compelling, if cross checks start to disagree, the pilot is going to want to keep on flying that pretty EFIS unless you hit him over the head. We don't know all their failure modes and their software (with the exception of Chelton) remains untested to the extent necessary to pass DO 178, their hardware is not DO 160 certified. That means you're the beta tester. Do you want to bet your life in that situation? Mark my words, we're going to have some experimental airplanes equipped with low cost EFIS systems get into some serious fatal trouble. That body count is going to raise the level of visibility of this issue with the FAA and soon big brother will be breathing down our necks. Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of IFR conditions. Bruce At the risk of further pounding on this dead horse whose meat is already well-tenderized, the admonishment to avoid the noncertified EFIS for IFR is a bit broad (IMHO). I fly with a dual GRT EFIS (this does not give me redundancy, just contemporary PFD and EIS display) driven by a single AHRS. For redundancy, I rely on old round AS, Alt and vertical compass and, most importantly, a Mid-Continent AI with its own internal battery. Secondary redundancy (but reliant on the same electrical system as the AHRS/EFIS is a TruTrak A/P which will take me where I want to go as long as the lights are on. So, I would concede your proposition with just a bit of technical modification, "low cost, noncertified EFIS systems are okay for VFR airplanes but stay out of IFR conditions unless you have a well thought out, well designed redundant primary flight system." But of course, I would make the same admonishment for a certified EFIS! Chuck ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Fw: common grounding
> > >It is important to keep high loads, especially noisy loads, like motors, >away from the forest of tabs. The #10 wire has some small resistance; >when you put a noisy high current through it, it will spill over to the >other equipment. (the high current would cause the tabs to momentarily >rise above ground) >I would be comfortable with a 1 foot run of #10 to forest of tabs which >were used to ground avionics and instruments. > >Most noisy loads like motors should ground back at the engine mount. >Alternatively, you could use a separate remote ground point for all the >noisy returns in the cockpit, and ground them back through an >appropriately sized wire to the main ground point. Not so. The forest of tabs ground block is not a potential ingress point for noise into other systems that share the ground. This is what SINGLE POINT GROUNDING is all about. EVERY grounded article shares the same reference. Standing in my front yard talking, we would be unaware of our earth rotation velocity on the order of 1000 mph, our earth orbit velocity on the order of 70,000 mph or the universe expansion velocity of who knows how much . . . because we're standing on the same hunk of turf that carries us along together. Single point electrical system grounds function in the same manner. It's not essential that the ground system not move electrically, it IS essential that all systems sharing the ground be unaware of the movement . . . i.e. no noise coupled from one system to another in spite of a great deal of noise being present. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
Good point. I'm going to check with Garmin, Chelton, and Avidyne and get the certification status of their systems. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alan K. Adamson Sent: Saturday, January 14, 2006 11:53 AM Subject: RE: AeroElectric-List: EFIS Comparisons Which is exactly why there are zero certified EFIS systems that are certified as *primary* (in small single engines anyway). The G1000 in my C182, is specified as secondary, the primary instruments are the AS, AI, ALT - regular old vacuum driven 3.125" steam gauges... :) Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Saturday, January 14, 2006 11:30 AM Subject: RE: AeroElectric-List: EFIS Comparisons --> OK, I can understand that. I hope you've been following the EFIS discussion on this list. Let me beat my drum one more time. These low cost EFIS displays (Pick your favorite) are hypnotic and compelling, if cross checks start to disagree, the pilot is going to want to keep on flying that pretty EFIS unless you hit him over the head. We don't know all their failure modes and their software (with the exception of Chelton) remains untested to the extent necessary to pass DO 178, their hardware is not DO 160 certified. That means you're the beta tester. Do you want to bet your life in that situation? Mark my words, we're going to have some experimental airplanes equipped with low cost EFIS systems get into some serious fatal trouble. That body count is going to raise the level of visibility of this issue with the FAA and soon big brother will be breathing down our necks. Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of IFR conditions. Bruce At the risk of further pounding on this dead horse whose meat is already well-tenderized, the admonishment to avoid the noncertified EFIS for IFR is a bit broad (IMHO). I fly with a dual GRT EFIS (this does not give me redundancy, just contemporary PFD and EIS display) driven by a single AHRS. For redundancy, I rely on old round AS, Alt and vertical compass and, most importantly, a Mid-Continent AI with its own internal battery. Secondary redundancy (but reliant on the same electrical system as the AHRS/EFIS is a TruTrak A/P which will take me where I want to go as long as the lights are on. So, I would concede your proposition with just a bit of technical modification, "low cost, noncertified EFIS systems are okay for VFR airplanes but stay out of IFR conditions unless you have a well thought out, well designed redundant primary flight system." But of course, I would make the same admonishment for a certified EFIS! Chuck ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: Fw: common grounding
> > >----- Original Message ----- >From: bob noffs >To: aeroelectric list >Sent: Thursday, January 12, 2006 8:33 AM >Subject: common grounding > > >hi all, > did i miss the answer to the original question because i am also > interested...''will a 300 mm run of #10 wire to the forest of tabs from > the grounded firewall create a groundloop? thanks all, GROUND LOOPS happen for one and one reason only. Two systems, one a potential victim and one a potential antagonist share multiple grounds that are NOT tied to each other with sufficiently low resistance. Noise currents in the antagonist system influence the victim. The act of spreading the ground system out as illustrated in Z-15 does not violate the single point ground concept as long as all grounds for any one appliance are gathered together at the same point in the ground system. For example, we added a panel ground bus to the architecture at Revision 11. ALL electrowhizzies on panel ground at this bus for convenience and the bus gets extended to the firewall on fewer, easier to connect/disconnect wires. Where do you want to mount the forest of tabs ground block? What kind of aircraft. Would a panel ground block as illustrated in chapter 18 http://aeroelectric.com/articles/Rev11/18Audio_R11.pdf be a better choice for remote locating a number of grounds for convenience while leaving the forest of tabs on the firewall? We need to know a bit more about your project and what conditions prompted the idea of moving the ground block off the firewall. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
FWIW if the alternator is internally regulated and the b lead goes through a contactor, then the CB can be downsized as it only has to power the contactor coil instead of supply the field current. I happened to have a 2 1/2 amp (2.5 amp) CB on hand and it works just fine when fed off the fuse block through a 10 amp fuse. After many crowbar OVP test trips, the fuse has never failed. Being picky, I used 18awg wire downstream of the fuse to insure that the wire doesn't overheat if shorted, and I'd go to larger wire in accordance with normal practice if using a larger fuse and a 5 amp breaker. While I used a few fuse links in other places, it was just very convenient and simple to feed the OV breaker off a fuse in my bird. A fuse link quickly starts to make more sense if one is comparing a fuse link and 22 awg wire to a 25 or 30 amp fuse and substantially heavier wire. Ken Robert L. Nuckolls, III wrote: > > > > >> >>A followup of question (2) from the peanut gallery, Bob... >> >>Could you oversize the fuse in the fuseblock that feeds the 5A OVP CB to >>"guarantee" the breaker pops before the fuse blows? Is there a fuse rating >>that'll provide the same level of hard fault protection as the 22 AWG >>fuselink while still allowing the 5A OVP CB to pop first? >> >> > > Sure. I did some experiments with the ATC fuses a few years ago. > 25A fuses will stay in place upstream of a 5A breaker. 30A > wouldn't hurt anything. You might want to upsize the feeder from > fuse to breaker to maybe 18AWG. But the fusible link makes > so much sense here, I wouldn't recommend it. > > Bob . . . > > ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: alternator b-lead bundled with engine computer
wiring Hi Mickey Well the 1992 Soob manual says the small starter is 1.0 kw and the large is 1.4 kw and that the small draws 90 amps no load at 11 volts, up to 280 amps while cranking at 8 volts, and up to 800 amps stalled at 5 volts. So I figure 200+ is in the ballpark and since 4awg is a common welding cable size, that is what I used even though my battery is reasonably close to the starter. The car used metric gauge wires that might have been a bit lighter than 4 awg. The larger starter off the automatic transmission draws up to 380 amps during cranking but you almost for sure have the smaller one I think. Ken Mickey Coggins wrote: > > > >>No.6 from the battery to the starter seems a little light for starter >>currents, though, but if it works .... I am using No.2 up to a firewall >>pass-through. >> >> > >It's a geared starter (auto conversion) so it does not require >as much current as an aviation engine starter. I can't get >anyone to tell me how much current it will require, for some >reason, but they keep telling me that #6 is enough. > > http://www.eggenfellneraircraft.com/electrical.htm > >I'll probably slap a hall effect sensor on there once I'm >ready to start the engine, just to satisfy my curiosity. > > > ________________________________________________________________________________
Subject: Wire Conduit
Date: Jan 14, 2006
I'm looking for a lightweight conduit for use in the wing to carry pitot static tubing and wing tip light wiring - probably 1/2 inch ID. Main purpose is to allow for future wire replacement after the wing is closed. Best I've seen is the slit convoluted stuff used in some autos. Anyone got better suggestions? Jim Butcher Europa XS N241BW ________________________________________________________________________________
Date: Jan 14, 2006
From: "Dan Beadle" <Dan.Beadle(at)hq.inclinesoftworks.com>
I guess I disagree with Bob a little on this. As an analog engineer, I have designed a lot of low-signal systems. The key to good analog performance is keeping noise out of the analog system. The way we do that is actually to split the grounds - a quiet ground where it matters and a noisy (digital) ground where it doesn't. The key is to keep high currents out of the analog ground, where a high current will actually create a voltage drop from one end of the ground to the other. The digital and analog grounds are considered separate sub-systems which are then tied together at a common grounding point. So Bob and I are saying the same thing, but different things.... Extending this to airplanes, I plane to keep all my avionics and instrumentation on a separate forest of tabs. That ground will tie back to a common point at the battery main lead. Other grounds, like for starter and servo motors will tie not to the forest of tabs, but to the main battery single point ground. High currents will not flow over the 1" or so from the forest of tabs to the battery single point. (I am sure Bob agrees with this too; I doubt he proposes grounding the starter to the single point forest of tabs.) Any current in the 1" ground from the forest will cause a voltage rise V=IR. Given, R is very low. But some analog signals out of sensors are only 15mV, so any significant current over even a small R can cause sensor errors. The avionics and instruments going to the field of tabs will have few amps flowing, keeping the V=IR rise very low. And, other than keying the transmitter, they will be very stable. I won't have to deal with a high current motor feeding back and injecting noise into my ground bus. For what its worth... Dan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, January 14, 2006 9:16 AM Subject: RE: AeroElectric-List: Fw: common grounding > > >It is important to keep high loads, especially noisy loads, like motors, >away from the forest of tabs. The #10 wire has some small resistance; >when you put a noisy high current through it, it will spill over to the >other equipment. (the high current would cause the tabs to momentarily >rise above ground) >I would be comfortable with a 1 foot run of #10 to forest of tabs which >were used to ground avionics and instruments. > >Most noisy loads like motors should ground back at the engine mount. >Alternatively, you could use a separate remote ground point for all the >noisy returns in the cockpit, and ground them back through an >appropriately sized wire to the main ground point. Not so. The forest of tabs ground block is not a potential ingress point for noise into other systems that share the ground. This is what SINGLE POINT GROUNDING is all about. EVERY grounded article shares the same reference. Standing in my front yard talking, we would be unaware of our earth rotation velocity on the order of 1000 mph, our earth orbit velocity on the order of 70,000 mph or the universe expansion velocity of who knows how much . . . because we're standing on the same hunk of turf that carries us along together. Single point electrical system grounds function in the same manner. It's not essential that the ground system not move electrically, it IS essential that all systems sharing the ground be unaware of the movement . . . i.e. no noise coupled from one system to another in spite of a great deal of noise being present. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: Wire Conduit
Jim, CPVC water piping. Inexpensive and light. Richard Dudley RV-6A flying Jim Butcher wrote: > >I'm looking for a lightweight conduit for use in the wing to carry pitot static tubing and wing tip light wiring - probably 1/2 inch ID. Main purpose is to allow for future wire replacement after the wing is closed. Best I've seen is the slit convoluted stuff used in some autos. Anyone got better suggestions? > >Jim Butcher >Europa XS N241BW > > > > > > > > > ________________________________________________________________________________
Date: Jan 14, 2006
Alan - Try this link on the BMA board: http://www.bluemountainavionics.com/talk/showthread.php?t=127 It has the ref and cite for the EAA paper. As I understand it, you can legally do an IFR ILS or VOR approach using external VOR/ILS inputs connected to the EFIS/ONE. However, as I read this thread and understand the BMA EFIS, you cannot use the GPS for anything other than navigation assistance. Thus, if one wants to navigate and do approaches IFR using GPS, the box has to meet more stringent criteria. I have not found the reference yet, but I believe that a WAAS approach using a GNS 480 has to have an OBS/CDI. We wired our 480 to an MD200-306(?). The EFIS/ONE cannot provide this because it cannot communicate fully with the 480. The EFIS/ONE is a wonderful piece of equipment and we look forward to using it. But it is not, in my opinion, a box into which I want to put all the eggs. I can't comment on the uncertified Chelton line because I have not followed or worked with them. John > > > John, I might be wrong and just went to look on the BMA site. I didn't > find > anything specifically, nor did I find it on or searching around the EAA > site. > > Can you post a link? You sure you aren't confusing the issue of using > the > BMA with a CNX-480 and the fact that you can't get all the nav signals > that > are needed, some most are using an external head? > > The link to specifics would help if you could please? I'm curious as > well > as I'm going down the road to a chelton panel for a Legacy and want to > make > sure I don't mess up. Guys at D2AV say I don't need and external CDI... > > Alan ________________________________________________________________________________
Date: Jan 14, 2006
Good Afternoon Bill. I hope you are correct, but I have heard rumors that the current crop of solid state accelerometer based rate sensors do not do well during violent maneuvering. Supposedly, that is one of the reasons there have been so few approved for certified use. It is my feeling that I would sooner have a tried and true instrument like the T&B for my last ditch backup. I would hope that some day I will have the confidence to use newer designs, but meanwhile, I will keep my gyroscopic turn needle. In my current spam can, I have one electric T&B and one vacuum powered T&B. However, I guess that is why we call the OBAM aircraft experimental. We are all free to experiment as we see fit! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/14/2006 10:57:18 A.M. Central Standard Time, sportav8r(at)aol.com writes: Exactly what I like about the Trio EZ-Pilot: built-in turn needle and mechanical inclinometer ball, plus it could fly the plane better than I could if I got a kidney stone or a case of the greens. It suffers no more from electrical system dependency than the ol' Turn and Bank does, so I'm happy with the substitution. -Bill ________________________________________________________________________________
From: "LarryRobertHelming" <lhelming(at)sigecom.net>
Date: Jan 14, 2006
----- Original Message ----- > > I'm looking for a lightweight conduit for use in the wing to carry pitot > static tubing and wing tip light wiring - probably 1/2 inch ID. Main > purpose is to allow for future wire replacement after the wing is closed. > Best I've seen is the slit convoluted stuff used in some autos. Anyone > got better suggestions? > > Jim Butcher > Europa XS N241BW > Check Vans aircraft. That is what RV builders use. Indiana Larry, RV7 > ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Hawker battery failure
I have some preliminary feedback from a teardown inspection that's being done on the battery we received here last year. http://www.aeroelectric.com/Pictures/Battery/Odyssey_OV There was zero moisture in the battery although the vent caps were intact meaning that all water had been converted to steam and exited the cells via the over-pressure vents. The swelling on the side suggests that the inter-cell walls became detached from the outside battery wall or that they stretched. Given that internal pressures are limited to the cracking value of the valves. See: http://www.aeroelectric.com/Pictures/Battery/Odyssey_OV/Odyssey_OV_5.jpg http://www.aeroelectric.com/Pictures/Battery/Odyssey_OV/Odyssey_OV_6.jpg http://www.aeroelectric.com/Pictures/Battery/Odyssey_OV/Odyssey_OV_7.jpg It appears that the cell walls are intact but stretched. I'm going to see if we can run some tests on those caps (and on a new battery that hasn't been hot). This battery was subject to an OV condition for considerable time and it may be that this damage took several flight cycles to go this far. Watch this space. Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
I used that very cheap milky white semirigid water pipe from the hardware store. Think it was high density polyethylene. Very easy to push wires through compared to corrogated stuff. Also more resistant to vibration as the corrogated stuff is intended to be somewhat flexible. I was advised to avoid any of the PVC's as they emit nasty toxic fumes and acids when they get hot or are exposed to flame... Ken Jim Butcher wrote: > >I'm looking for a lightweight conduit for use in the wing to carry pitot static tubing and wing tip light wiring - probably 1/2 inch ID. Main purpose is to allow for future wire replacement after the wing is closed. Best I've seen is the slit convoluted stuff used in some autos. Anyone got better suggestions? > >Jim Butcher >Europa XS N241BW > > ________________________________________________________________________________
Date: Jan 14, 2006
Ah, ok, now that helps... Ok, so here is some help. The chelton fully interfaces with the SL-30 (notice I didn't say 480 yet) for resolver info and GS, LOC signals. Actually it does this via a serial interface. The problem is the 480, which supposedly uses the same engine as the SL-30, didn't implement the serial interface the same as the SL-30 and so you can't get all the data to drive the BMA interface. You don't technically need an external display, you just need a display that can give GS and LOC information in an displayable format (could be HSI, could be HITS, could be up/down, left/right). Notice I've left alone the conversation about GPS approaches for the moment. So on an ILS or LOC/VOR approach, the BMA or Chelton can be the only display if talking to an SL-30. If there is a 480 involved, it most likely needs an external display due to the limitations of the 480 and it's inability to provide the signals that the eFIS wants. You actually can do it on the Chelton, but it requires an expensive ARINC 429 to serial converter. I'm not going to get into the GPS approach topic. There are a whole set of issues there. However, if you have a GPS which delivers the right outputs for either the Chelton or the BMA and it's Approach certified, you don't technically need the external CDI. There is no requirement that I'm aware of that specifically requires a TSO'd (don't even think there is a TSO for a CDI anyway) indicator or switch panel for that matter. As you can tell, this gets all complicated, and even more so depending on what radio the EFIS is trying to talk to... But then this isn't an Avionics forum and I'm not an expert :) Thanks tho and I'll go read the links you provided. Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Schroeder Sent: Saturday, January 14, 2006 3:23 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> Alan - Try this link on the BMA board: http://www.bluemountainavionics.com/talk/showthread.php?t=127 It has the ref and cite for the EAA paper. As I understand it, you can legally do an IFR ILS or VOR approach using external VOR/ILS inputs connected to the EFIS/ONE. However, as I read this thread and understand the BMA EFIS, you cannot use the GPS for anything other than navigation assistance. Thus, if one wants to navigate and do approaches IFR using GPS, the box has to meet more stringent criteria. I have not found the reference yet, but I believe that a WAAS approach using a GNS 480 has to have an OBS/CDI. We wired our 480 to an MD200-306(?). The EFIS/ONE cannot provide this because it cannot communicate fully with the 480. The EFIS/ONE is a wonderful piece of equipment and we look forward to using it. But it is not, in my opinion, a box into which I want to put all the eggs. I can't comment on the uncertified Chelton line because I have not followed or worked with them. John > > > John, I might be wrong and just went to look on the BMA site. I > didn't find anything specifically, nor did I find it on or searching > around the EAA site. > > Can you post a link? You sure you aren't confusing the issue of using > the BMA with a CNX-480 and the fact that you can't get all the nav > signals that are needed, some most are using an external head? > > The link to specifics would help if you could please? I'm curious as > well as I'm going down the road to a chelton panel for a Legacy and > want to make sure I don't mess up. Guys at D2AV say I don't need and > external CDI... > > Alan ________________________________________________________________________________
Date: Jan 14, 2006
The aviation department at your local home depot or lowes has plain tubing that I have used for everything from wiring conduit in the wings to pitot/static plumbing. It's the milky colored stuff....... Ralph Capen ----- Original Message ----- From: "Jim Butcher" <europa(at)triton.net> Sent: Saturday, January 14, 2006 1:29 PM Subject: AeroElectric-List: Wire Conduit > > I'm looking for a lightweight conduit for use in the wing to carry pitot > static tubing and wing tip light wiring - probably 1/2 inch ID. Main > purpose is to allow for future wire replacement after the wing is closed. > Best I've seen is the slit convoluted stuff used in some autos. Anyone > got better suggestions? > > Jim Butcher > Europa XS N241BW > > > ________________________________________________________________________________
Date: Jan 14, 2006
Subject: KI208/209 not in agreement
Hi all, I have 2 indicators - KI209 and KI208. Sometimes the CDI difference between the two, when set on the same OBS, is more than 4 degrees. Does anyone know how to get them to agree? Is this done from the radios or the indicator? Rumen ________________________________________________________________________________
Subject: Solder Station
Date: Jan 14, 2006
Ditton on the Metcals. That's all we use in our shop as well - and we learned this from the airline days. The R&E shops at the airlines had these and we liked them, so we procured some for our own use when I set up my own shop. They are lightning fast to heat up, will work on everything from hair thin wires to larger gauges and multiples. After you use one you'll never go back! Ours too mostly come off of Ebay! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Saturday, January 14, 2006 11:03 AM Subject: Re: AeroElectric-List: Solder Station > > >The ones on EBay are most likely from an enterprising set of folks who buy >them from the big electronics mfg's or repair stations and auction/sell >them on eBay. The METCAL soldering tools are the acme of soldering tools. They're only capable of delivering about 30 watts to the tip but the WHOLE 30 watts gets out there. The tips are temperature controlled. Tips are easy to change . . .just seconds even when hot . . . the cold one is ready us use in under a minute. Tip sizes range from about .2" flats to .015" points. I can solder a terminal on a 2AWG wire with the big guy and install .025" pitch surface mount chips with the other one. RAC has used nothing but METCAL for about 20 years. I dumped all of the solder stations in my shop about 6 years ago and went to METCAL's purchased off Ebay. Whole stations with power supply, wand, tips and wand holder will be more expensive. Wands take the most beating so I try to buy orphaned power supplies (picked up one last week for $40). I like to get new wands from a distributor (typically $60) and tips off Ebay (1 to $10 each). This is an excellent way to acquire what is arguably one of the most versatile soldering systems out there for well under $200. I have two on the bench, one in my grab-it-and- run toolkit and I've purchased perhaps another half dozen for family members. I've had a couple of power supplies go TU over the years but they're so inexpensive to replace, I don't bother to repair them. It's not worth the time. The supply I bought last week is a "spare". Bob . . . ________________________________________________________________________________
Date: Jan 14, 2006
hi jim, i know you wont get lighter than this. the 8' plastic tubes that make fluorescent tubes explosion proof. they even have a plastic fitting on each end that makes mounting slick. i used one in my plane. they cut easy and can be spliced with pieces cut from an unused tube. they may not be stiff enough for your needs but were perfect for me. bob noffs ----- Original Message ----- From: "Richard Dudley" <rhdudley(at)att.net> Sent: Saturday, January 14, 2006 2:13 PM Subject: Re: AeroElectric-List: Wire Conduit > > Jim, > CPVC water piping. Inexpensive and light. > > Richard Dudley > RV-6A flying > > Jim Butcher wrote: > >> >>I'm looking for a lightweight conduit for use in the wing to carry pitot >>static tubing and wing tip light wiring - probably 1/2 inch ID. Main >>purpose is to allow for future wire replacement after the wing is closed. >>Best I've seen is the slit convoluted stuff used in some autos. Anyone >>got better suggestions? >> >>Jim Butcher >>Europa XS N241BW >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 14, 2006
Subject: need some advice here, guys- alternator for RV
Armed with info gleaned from the AeroElectric list and elsewhere on the web, I went alternator-shopping at the local auto parts stores today, to see how close I could get to the recommended 70 A machine that goes by part number Lester 13353 or NipponDenso 121000-346. If I had not had the additional tidbit that it fits a '93 Dodge Ramcharger 5.2 liter pickup, I think the parts counter clerks would have been helpless to assist me. The choices that came up "in stock" were limited to one: the Dodge's optional 90 amp externally-regulated machine (reman) with a serpentine pulley, in a 125mm case. My quest for a VR-166 Ford regulator also ended with a substitute, the Sorensen VR-301. The alternator comes with its own computer-generated test output graph and data table, indicating it is capable of 126 amps at 6000 rpm, and draws 5.72 amps of field current at that output. It seems to weigh about 11 lbs on the bathroom scales. Already I'm thinking this might be more of a fire-breathing machine than I should bolt to my RV, even if it's a physical fit, which I think it will be. I'm not sure the electronic regulator will necessarily "handle" it, but not sure why it wouldn't. I don't need anywhere near the output this alternator is capable of, and I don't want my 5 amp field breaker nuisance-tripping because the field happens to want near that amount (no idea how linear the field current vs output curve might be, so no way to know field current at closer to 50-60 amps, for example.) Finally, I'm unsure how easily the V-pulley from my original Van's 35 A machine will slip onto the shaft of the new alternator. Any takers on that one? When I make the swap, I'd like to have everything go smoothly with a minimum of downtime. Basically, I'd like some reassurance that this is worth trying. I can always take it back and order the Dodge 70 amp alternator; same physical size, and ironically more money. Advice appreciated, friends. Thanks. -Bill Boyd RV-6A O-320 FP ________________________________________________________________________________
Date: Jan 14, 2006
From: Kevin And Ann Klinefelter <kevann(at)verizon.net>
check out drip irrigation tubing. lightweight, black plastic. cheap too Kevin Jim Butcher wrote: > >I'm looking for a lightweight conduit for use in the wing to carry pitot static tubing and wing tip light wiring - probably 1/2 inch ID. Main purpose is to allow for future wire replacement after the wing is closed. Best I've seen is the slit convoluted stuff used in some autos. Anyone got better suggestions? > >Jim Butcher >Europa XS N241BW > > > > > > > > > ________________________________________________________________________________
Date: Jan 14, 2006
Subject: GPS CDI (was: EFIS Comparisons)
BobsV35B(at)aol.com wrote: > Good Morning Bob, > > Do you intend to use the 430 IFR or VFR? > > Do you want to execute full ILS approaches? A set of ILS needles is required for this. This does not need to be a TSO display tho. You do not need TSO on any of the avionics except for the IFR-certified GPS. > For VFR, there is no question that a CDI is not needed. > > For IFR, things get a bit stickier. Beyond that, it makes a difference if > the aircraft is experimental or normal category. As I interpret TSO-129.whatever (for IFR GPS), the doc states that there must be a CDI in the normal visual scan of the pilot. I would consider the CDI display on the unit when mounted in a center-stack for radios to be within the pilot's normal visual scan. This therefore does not require a separate CDI. OTOH, some inspectors at the FSDO did insist on one. I don't think that TSO for it is required so something like the BM EFIS-1 should suffice. Again, my interpretation. Also, as I recall, didn't they change the requirements for installing an IFR GPS such that it no longer requires a sign-off by and inspector at the FSDO? -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 14, 2006
Subject: Re: KI208/209 not in agreement
rd2(at)evenlink.com wrote: > > Hi all, > I have 2 indicators - KI209 and KI208. Sometimes the CDI difference between > the two, when set on the same OBS, is more than 4 degrees. Does anyone know > how to get them to agree? Is this done from the radios or the indicator? The KI-208 and KI-209 contain the VOR/LOC converter. Adjustments are accomplished inside the indicator, not in the radio. GS adjustments are inside the radio as the GS converter is part of the GS module in the radio. The KX-165 has the internal VOR/LOC converter. The KX-155 does not. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 14, 2006
Bruce Gray wrote: > problem. But if you're 300 AGL on the ILS?? This is the main reason for dual > systems/electronic comparator/3rd gyro, to give you a chance to survive when > time is of the essence. > > You're free to fly with whatever you want as long as it fits your comfort > level. But when I see builders wanting to charge off into hard IFR with a > BMA, T&B, and ASI, I just got to say - Are you sure you want to do this? I regularly fly to 200' with a vacuum-powered AI, HI, and an electric T&SI. OK, I have a standby vacuum source. Frankly, a backup AI makes a lot more sense to me than a T&SI but that is not the way most GA aircraft are equipped. The current crop of electronic PFDs should be more reliable than iron gyros. And as for visually/mentally comparing two displays, you should know what the airplane is doing and can tell which display makes sense and which doesn't. You probably don't need to immediately react if you don't have an airspeed trend or a VSI trend. Also remember that without a third AHRS your comparator doesn't know which one is bad and which is good. It only knows they disagree. BTW, most AI's fail slowly. You know they are going long before they finally fail. I did experience one catastrophic failure of an AI tho'. I had one where the bearings failed and allowed the rotor to depart the gimbals. The "bang" was so loud I thought the engine had thrown a rod. But the engine kept running and the AI display began a very interesting 'dance of death'. Fortunately I was VFR at the time. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Need some advice here, guys- alternator for RV
I am very interested in helping you fit the Lester 13353, ND alternator. I'm helping another RV-6'er in using this or another high powered ND unit just like it. >It seems (Lester 13353) to weigh about 11 lbs on the >bathroom scales. Already I'm thinking this might be more of >a fire-breathing machine than I should bolt to my RV, even if >it's a physical fit, which I think it will be. (MAY BE) That is up to you. WHAT do you NEED? If you need it you need it. Add up all your items that could be on continuously with (realistic) intermediate items as a worse case and add about 25% to 55% margin to that and that is a good ball park of the alternator capacity you need. Basically you are looking at typically 6.8 to 9.0 amps per lb. The lightest ND alternator is the 40-45 amp alternator at about 6 lbs. (popular with RV'ers, like me). The next popular is a 55 amp unit and weighs about a lb more. Than there's the 60 amp unit that, that weighs about 8.5 lbs, also popular with the RV'ers. They are all compact and have been fit on RV's many times with ease. They also come with V-groove pulleys out the box. The weights of larger ND alternators are about 11-12 lbs with output of 75-140 amps (like the Lester 13353). It will likely fit, but you MAY need to make your own bracket (a stock Lycoming alternator bracket may work). You will need to remove the pulley serpentine pulley and replace it with a V- grove pulley. The ND alternators with external regulators (like the 13353) are typically for a Dodge application in the late 90's early 00's and has a mounting flange or lugs that are about .70" further out than the next physical size down. I think it will fit. I am working with a guy in Arizona who needs 80 amps on a RV and we are looking at this unit or a 90 amp unit with internal regulator. The later unit has a tighter mount fitting lug and is know to fit. The 90 amp weighs about the same as what you are looking at. Now here is the question, would you rather have a 40-45 amp or 55 amps or 60 amps that will bolt up using Van's brackets and has the V-pulley already? Is that enough power for you? If you want the 40-45 amp, that is harder to buy at auto stores because they are for industrial applications, forklifts and tractors. They don't usually have Lester #'s. The advantage of getting these units is they are made NEW from Nipponndenso with all genuine ND parts, verses rebuilds. I suggest the Niagara Air parts kit. It has everything, brackets, hardware and of course a new ND alternator. Only you know if that will work. If you add up all your load, as suggested and you are under 30-33 amps you will be fine. It's internally regulated. If you want the 55 amp unit, try Lester numbers: 14684, 12184 (available at auto stores). If you want a 60 amp alternator: Lester # 14457, 14668 13398, 13492 (available at auto stores) The only thing is all of the above alternators, 40-60 amp units, are all internally regulated, vs. the 13353 which is for external Voltage regulation. >My quest for a VR-166 Ford regulator also ended with a >substitute, the Sorensen VR-301. I'm not sure the electronic >regulator will necessarily "handle" it, but not sure why it >wouldn't.............because the field happens to want near that >amount (no idea how linear the field current vs. output curve >might be, so no way to know field current at closer If you do decide to go with the external Voltage regulation, here is a better FORD regulator, V1200 or V1300: http://195.125.241.148/Catalog/Images/V1200.jpg Voltage Set Point: 14.2 V (adjustable) Regulation: B-Circuit -Voyager Series Regulator -Adjustable Voltage (13.0-16.0 Volts) -Precise Digital Regulation (digital!!!!) -Short Circuit Protected -High Current Capability -Over Voltage protection!!!!!!!!! -Ignition or Light circuit activated with High Side Reg -Protected Against Loss of Ground and Under Voltage -LED'S for Easy Troubleshooting -Fault Detection Indicators Cost? I think less than $80!!!!! http://195.125.241.148/Catalog/Images/V1200.jpg If you have any problems finding the above or have question Contact me off line. Try me at gmcjetpilot(at)yahoo.com. George --------------------------------- Photo Books. You design it and well bind it! ________________________________________________________________________________
Date: Jan 15, 2006
the cheapest and lightest i've ever seen is shower curtain rod wrap. it's a very thin and light adjustable diameter tube (about 1") that is slit down the length. they were a $1 last i saw, in maybe 5' length. gary ----- Original Message ----- From: "Jim Butcher" <europa(at)triton.net> Sent: Saturday, January 14, 2006 2:29 PM Subject: AeroElectric-List: Wire Conduit > > I'm looking for a lightweight conduit for use in the wing to carry pitot > static tubing and wing tip light wiring - probably 1/2 inch ID. Main > purpose is to allow for future wire replacement after the wing is closed. > Best I've seen is the slit convoluted stuff used in some autos. Anyone > got better suggestions? > > Jim Butcher > Europa XS N241BW > > > ________________________________________________________________________________
Date: Jan 15, 2006
Jim, Try going to the local builders supply and getting a roll of sprinkler supply tubing. Mine is black and the wall is thin and light. I'm using it to run to the wing tips for lighting and pitot tubing. If you need to make a break in the middle do it at an inspection plate. Jim Nelson ________________________________________________________________________________
From: "Mitchell Goodrich" <mgoodrich(at)tampabay.rr.com>
Subject: EFIS
Date: Jan 15, 2006
Hi Harley, I appreciated you meeting and opening up your hangar. For my standards, it was Surely COLD!! OK it was just a little snow. The new Engine Management System, "Auracle" is progressing very well. I should have the unit Installed sometime in February, and will be at Sun n Fun with the plane, for everyone to see. It is an Amazing, Very well thought out system to view and keep track of all your vital engine functions. The display is incredibly bright in the direct sunlight, which all of Rutan Eze drivers will enjoy. I can't Wait to fly with it. Mitchell Goodrich N60P VariEze Tampa, FL 813-356-9758 ________________________________________________________________________________
From: "Alex Peterson" <alexpeterson(at)earthlink.net>
Date: Jan 15, 2006
> > CPVC water piping. Inexpensive and light. For what I feel is a better alternative, try: http://www.usplastic.com/catalog/product.asp?catalog%5Fname=USPlastic&catego ry%5Fname=78&product%5Fid=4905 If that doesn't work, go to www.usplastic.com and search for Tenite Butyrate tubing. It is the thinnest wall rigid tubing I've found, and it is available in many sizes. Alex Peterson RV6-A N66AP 704 hours Maple Grove, MN ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Re: EFIS Comparisons
Good Morning George, Another reason to keep a standard old fashioned, needle type, Turn and Bank instrument on the panel. It is the cheapest reliable instrument that can be purchased by most of us. I hope to be able to move to glass when it is proven, but, in the meantime, when I am IFR, I want something reliable to fall back on. I know that many folks are promoting an artificial horizon for such back up duty. They are MUCH more expensive, heavier, and for the ones in our price range, less reliable. Just because it is ancient doesn't make it bad. I have no data, but it seems the incidence of loss of control accidents has increased drastically in the days since the use of the T&B has been de-emphasized. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/15/2006 8:18:24 A.M. Central Standard Time, gwbraly(at)gami.com writes: There are persistent reports that some of the certified "five tube" Honeywell displays in one of the high end turbo props are going "dark" - - simultaneously. One pilot reported three such events on different trips over a period of months, for which he was present, and two other events in the same airframe when others were flying. ________________________________________________________________________________
Date: Jan 15, 2006
Hi Jim- Re: I'm looking for a lightweight conduit...probably 1/2 inch ID...Best I've seen is the slit convoluted stuff...Anyone got better suggestions? Van's aircraft sells the same stuff, only without being slit. IIRC, it is about 7/8 dia. When I installed mine, I took a handy scrap of 3/8 dowel about 2 inches long, rounded it's shoulders, drilled a transverse hole through it, and tied a length of heavy kite string to it. The string is just over double the length of the conduit. I used my blow gun to launch the dowel segment down the conduit. I had reservations about the dowel passing through the corrugated, ill fitting, flexible (read: not quite straight) tube, but figured worst case, I could pull it back out with the string. Well. The dowel, with the string in tow, shot through the conduit, out the other end, across the shop, and bounced off the far wall. For the second attempt, I held the free end of the string ; - ) and all was well. I then installed another toggle / dowel on the free end of the string. This allows me to tape a wire to the string near it's mid point and pull it through the conduit. I plan to leave the strings and toggles in the various conduits for future use as fish tapes. Perhaps not a perfectly elegant solution, but entirely effective and of negligible weight! Glen Matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jan 15, 2006
Subject: "Light" IFR???
The concept of "light IFR" should be put to rest once and for all. Once you fly into the clouds, the distinction of light or heavy IFR is GONE! IMC is IMC! (Let's not even consider ice and/or thunderstorms for this discussion.) Once IMC, you are essentially at the mercy of the controllers from that point on! When in IMC, you better plan on the possibility AND be prepared for any eventuality including an ILS approach down to minimums! Design you panel accordingly! Consider radios and an autopilot to which you can literally trust you life! Why do I feel so strongly about this? One flight in my log book stands out: I was making a trip from Cincinnati Lunken to Detroit City Airport. Because my light twin was in for maintenance, I decided to make the trip in my Long EZ. Detroit was supposed to be marginal VFR. To be conservative I filed an IFR flight plan (with the concept of "light IFR" in mind.) Got into the soup over Dayton and never saw the ground again until after one missed and finally a second successful approach close to minimums into Detroit. The concept of "kissing the ground" upon deplaning took on a whole new meaning after that experience! PLEASE keep this in mind when designing your panel! Paul Siegel ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Re: Solder Station & Solder vs Crimp
Hi guys I took a quick look at Metcals online. Looks like there are quite a number of models available. What do you recommend? As a sub-question, I wonder if one is better off crimping connections or soldering. Where do you use which? I have always thought of soldered joints as more electrically reliable. However, there is a stiff part where the solder runs up the wire. That would seem to be more prone to vibrational damage than a properly crimped joint. Thoughts? Michael Wynn RV 8 San Ramon ________________________________________________________________________________
Date: Jan 15, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Alternator for RV
> >Armed with info gleaned from the AeroElectric list and elsewhere on the >web, I went alternator-shopping at the local auto parts stores today, to >see how close I could get to the recommended 70 A machine that goes by >part number Lester 13353 or NipponDenso 121000-346. If I had not had the >additional tidbit that it fits a '93 Dodge Ramcharger 5.2 liter pickup, I >think the parts counter clerks would have been helpless to assist me. The >choices that came up "in stock" were limited to one: the Dodge's optional >90 amp externally-regulated machine (reman) with a serpentine pulley, in a >125mm case. My quest for a VR-166 Ford regulator also ended with a >substitute, the Sorensen VR-301. > >The alternator comes with its own computer-generated test output graph and >data table, indicating it is capable of 126 amps at 6000 rpm, and draws >5.72 amps of field current at that output. The plain-vanilla regulators are generally set up for 3A fields. I don't know if VR-166 style regulators will handle this load but it would be easy to test for. Since they're switching regulators, the added heat dissipation may well be within SOME regulator's capabilities but some caution is called for. > It seems to weigh about 11 lbs on the bathroom scales. Already I'm > thinking this might be more of a fire-breathing machine than I should > bolt to my RV, even if it's a physical fit, which I think it will > be. I'm not sure the electronic regulator will necessarily "handle" it, > but not sure why it wouldn't. I don't need anywhere near the output this > alternator is capable of, and I don't want my 5 amp field breaker > nuisance-tripping because the field happens to want near that amount (no > idea how linear the field current vs output curve might be, so no way to > know field current at closer to 50-60 amps, for example.) > >Finally, I'm unsure how easily the V-pulley from my original Van's 35 A >machine will slip onto the shaft of the new alternator. Any takers on >that one? When I make the swap, I'd like to have everything go smoothly >with a minimum of downtime. Basically, I'd like some reassurance that >this is worth trying. I can always take it back and order the Dodge 70 >amp alternator; same physical size, and ironically more money. The question that comes to mind is do you NEED that much snort? There are tens of thousands of certified singles flying around with 60A alternators that are greatly oversized to the task . . . not too big a deal if volume driven cost is the decision driver (Cessna used the same alternator on C150 through C210 for a period of time). However, if size and weight are drivers, then there are lighter and less expensive alternatives that may well provide all the snort you need. Better yet, they're easier to find and there's a variety of sources for mounting brackets that will fit your engine. Bob . . . ________________________________________________________________________________
Subject: IFR GPS Display
Date: Jan 15, 2006
AC 20-138A, Airworthiness Approval Of Global Navigation Satellite System Equipment, sets the requirements for IFR GPS units. Para 18d , Navigation Display,. requires that the horizontal and vertical deviation display(s) and failure annunciation be within the pilot's primary field of view. Primary field is defined as within 15 degrees of straight ahead of the pilot. Other displays may be anywhere from the airspeed indicator on the left in a standard six pack to and including an avionics center stack on the right. One method of compliance is to place an IFR GPS receiver that displays CDI/VDI, such as the GNS 480, within the primary field of view and eliminate the requirement for an external display. The geometry of my GlaStar gives a 12" wide zone in the panel for the GPS' display. Placing a Dynon or GRT PFD above or below the GPS would result in a lot of flight/navigation info directly in front of the pilot. Regards, Bruce McGregor ________________________________________________________________________________
Date: Jan 15, 2006
The issue of crimp or solder has been discussed at length on this list in the past. If you are interested, I recommend a perusal of the archives. The short answer is that either technology can be used successfully, with few exceptions, as long as it is done in a craftsmanlike manner. Both technologies require the use of appropriate strain relief, and physical support against vibrational damage. In general, if wire leading to a hardpoint (be it a crimped, or soldered joint, or some other rigid, constraining interface) is allowed to wiggle around, work hardening of the conductor will take place, and that will lead to broken wire. Regards, Matt- MLWynn(at)aol.com wrote: > >Hi guys > >I took a quick look at Metcals online. Looks like there are quite a number >of models available. What do you recommend? As a sub-question, I wonder if >one is better off crimping connections or soldering. Where do you use which? > >I have always thought of soldered joints as more electrically reliable. >However, there is a stiff part where the solder runs up the wire. That would >seem to be more prone to vibrational damage than a properly crimped joint. >Thoughts? > >Michael Wynn >RV 8 >San Ramon > > > > > > > > > ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Re: "Light" IFR???
At 08:24 AM 1/15/06, you wrote: > >The concept of "light IFR" should be put to rest once and for all. > >Once you fly into the clouds, the distinction of light or heavy IFR >is GONE! IMC is IMC! (Let's not even consider ice and/or >thunderstorms for this discussion.) In southern California airports close to the coast - like Santa Monica, Torrance, Long Beach, Orange County, Palomar, Oxnard, Santa Barbara - get "early morning and late night overcast." It's a pretty thin layer, 2 to 500 feet thick, that can last till early afternoon. It extends some mile inland. And it sits. It's stable, it doesn't change quickly or much. It burns off fairly predictably. If you can't get through it sometimes you'll sit on the ground from March till July. It's what I consider light IMC. No rain, no fog, just 30 seconds on instruments. If I'm flying back in and it deteriorates, I divert inland where - 5 miles away - it's 20 miles vis and clear. I understand that in the midwest it's another thing altogether, things change quickly. But in my climate, light IFR is a reality. OTOH, my idea of a panel for light IFR is a Bluemountain EFIS 1, Garmin 480, EHSI, and backup electric AI and T&S, airspeed and altitude. -- ________________________________________________________________________________
Date: Jan 15, 2006
> >Hi guys > >I took a quick look at Metcals online. Looks like there are quite a number >of models available. What do you recommend? Cheap ones. Buy off Ebay . . . See Ebay items: 7579854071 7580532665 7580702004 and others under "metcal" search term > As a sub-question, I wonder if >one is better off crimping connections or soldering. Where do you use which? They are for all practical purposes interchangeable technologies. One is more expensive and less process sensitive but either can produce long-lived joints. > >I have always thought of soldered joints as more electrically reliable. >However, there is a stiff part where the solder runs up the wire. That >would >seem to be more prone to vibrational damage than a properly crimped joint. >Thoughts? Much of what's circulated as fact is indeed myth. See: http://aeroelectric.com/articles/rules/review.html http://aeroelectric.com/articles/big_term.pdf http://aeroelectric.com/articles/CrimpTools/crimptools.html Bob . . . ________________________________________________________________________________
From: "Malcolm Thomson" <mthomson(at)showmeproductions.com>
Subject: Jabiru 3300
Date: Jan 15, 2006
Has anyone made up a wirebook which incorporate the wiring for a Jabiru 3300? Would you be willing to email to me? Looking for some ideas and specifically how to handle the built in alternator. The engine comes with a "Kubato RP201-53710" voltage reg and I can't find any spec on this regulator and not sure if it has OV protection etc. The alternator has two white wires coming out it that connects to the voltage reg. Any info on the Kubato reg or alternatives would be great. Thanks for the help. -- ________________________________________________________________________________
Subject: EFIS Comparisons
Date: Jan 15, 2006
That must be a confidence building experience. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George Braly Sent: Sunday, January 15, 2006 9:20 AM Subject: RE: AeroElectric-List: EFIS Comparisons There are persistent reports that some of the certified "five tube" Honeywell displays in one of the high end turbo props are going "dark" - - simultaneously. One pilot reported three such events on different trips over a period of months, for which he was present, and two other events in the same airframe when others were flying. ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Dimmer circuit for +12v switched items
Some circuits, such as the two-speed boost pump and voltage regulator power are switched to +12v rather than ground. In these cases, you can have an indicator bulb, but you can't connect it to the dimmer bus. How do you handle this situation? Thanks, Adam Molny ________________________________________________________________________________
Subject: EFIS Companies
Date: Jan 15, 2006
Greg, I have been flying with a Blue Mountain E/1 for almost two years. In that time the software has received major feature upgrades nearly every quarter, all free after purchase. Only recently, and only because they switched to Jeppeson who insisted, has BMA begun enforcing the subscription payment for database updates. I have always found the company easy to deal with and very straightforward. While it seems a few shipped systems had bugs, most of what one see complaints about on their unmoderated Board concerns builders or installers who have trouble with the sometimes telegraphically brief install manuals or with poor grounding discipline in their wiring harnesses. I have a great deal of respect for both Bob N. and Greg R. My A/C wiring is a slightly modified version of Bob's All-Electric, including a LVBM module controlling the power to the EFIS. In my opinion, Greg made some good points in his treatise on electrical system design also. We can all learn from looking at both. Like Bob said, you should infer nothing about Greg's company business practices from their design flap. You should probably wander around SnF or Oshkosh and do some of your own assessment of the people and equipment involved. Its a very personal choice. Ira N224XS ________________________________________________________________________________
Date: Jan 15, 2006
Handle the indicator bulb by switching the ground of the bulb to the dimmer. This can be quite useful. I switch the grounds of the bulbs into and out of my dimmers with a double pole instrument light switch. Hi intensity when switch off (daylight), switched to dimmer when on (night time). Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of adam(at)validationpartners.com Sent: Sunday, January 15, 2006 4:37 PM Subject: AeroElectric-List: Dimmer circuit for +12v switched items Some circuits, such as the two-speed boost pump and voltage regulator power are switched to +12v rather than ground. In these cases, you can have an indicator bulb, but you can't connect it to the dimmer bus. How do you handle this situation? Thanks, Adam Molny ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Re: Dimmer circuit for +12v switched items
This is a common problem. At this web site http://vx-aviation.com/page_2.html, you'll see a product called the IL-4A that solves this problem by converting all positively switches circuits to ground-switched, thus allowing for simple dimming. The schematic is published in the datasheet, so you can either make your own or buy the one I offer. Vern Little Bruce Gray wrote: > >Handle the indicator bulb by switching the ground of the bulb to the dimmer. >This can be quite useful. I switch the grounds of the bulbs into and out of >my dimmers with a double pole instrument light switch. Hi intensity when >switch off (daylight), switched to dimmer when on (night time). > >Bruce >www.glasair.org > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >adam(at)validationpartners.com >Sent: Sunday, January 15, 2006 4:37 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Dimmer circuit for +12v switched items > > >Some circuits, such as the two-speed boost pump and voltage regulator >power are switched to +12v rather than ground. In these cases, you can >have an indicator bulb, but you can't connect it to the dimmer bus. How do >you handle this situation? > >Thanks, >Adam Molny > > > > > > > > > ________________________________________________________________________________
Date: Jan 15, 2006
Subject: Formation Attenuator
Howdy A-list- FYI, tested initial install of Bob's attenuator switch/circuit and pleased to report it works as advertised on my Microair 760 (check archives for recent "attenuator" posts if not familiar). I originally installed a 680 ohm resistor for the "choke" (for lack of better name) and got close to two different planes today. A definate improvement on close reception when switched on, but still a bit garbled- will try with a 1.5K resistor next to see if better and will report... Mark Phillips N51PW ________________________________________________________________________________
Date: Jan 15, 2006
Bob, I do not agree with what you have to say about the T&B vs. a back up attitude indicator. Yes it costs more and may weigh a few ounces more, but what is your life worth. As far as reliability, the back up attitude indicator isn't the problem with failure. The vacuum system that most people use to power it is the common point of failure. It is my 25+ years of active flying and teaching that supports my position that the average general aviation pilot can not fly needle and ball well enough to stake their life on it. As far as when will "glass prove" itself. Well I have been flying behind glass since 1988 and have not had an undetectable failure yet. When glass fails (very uncommon compared to the old fashioned stuff.) it quits, no slow roll over or false info. Now I'll admit that some of these new cheap EFIS system may not offer the same level of fault protection as the higher priced stuff I normally use. But I would bet the newer EFIS systems are better then the 1960 Edo air attitude indicator found in most old Pipers and Cessnas. Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Sunday, January 15, 2006 7:57 AM Subject: Re: AeroElectric-List: EFIS Comparisons Good Morning George, Another reason to keep a standard old fashioned, needle type, Turn and Bank instrument on the panel. It is the cheapest reliable instrument that can be purchased by most of us. I hope to be able to move to glass when it is proven, but, in the meantime, when I am IFR, I want something reliable to fall back on. I know that many folks are promoting an artificial horizon for such back up duty. They are MUCH more expensive, heavier, and for the ones in our price range, less reliable. Just because it is ancient doesn't make it bad. I have no data, but it seems the incidence of loss of control accidents has increased drastically in the days since the use of the T&B has been de-emphasized. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 1/15/2006 8:18:24 A.M. Central Standard Time, gwbraly(at)gami.com writes: There are persistent reports that some of the certified "five tube" Honeywell displays in one of the high end turbo props are going "dark" - - simultaneously. One pilot reported three such events on different trips over a period of months, for which he was present, and two other events in the same airframe when others were flying. -- 1/14/2006 -- 1/14/2006 ________________________________________________________________________________
Date: Jan 15, 2006
The BM EFIS-1 has a CDI display built into it, therefore a second one is not required. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd Sent: Sunday, January 15, 2006 12:01 AM Subject: AeroElectric-List: GPS CDI (was: EFIS Comparisons) BobsV35B(at)aol.com wrote: > Good Morning Bob, > > Do you intend to use the 430 IFR or VFR? > > Do you want to execute full ILS approaches? A set of ILS needles is required for this. This does not need to be a TSO display tho. You do not need TSO on any of the avionics except for the IFR-certified GPS. > For VFR, there is no question that a CDI is not needed. > > For IFR, things get a bit stickier. Beyond that, it makes a difference if > the aircraft is experimental or normal category. As I interpret TSO-129.whatever (for IFR GPS), the doc states that there must be a CDI in the normal visual scan of the pilot. I would consider the CDI display on the unit when mounted in a center-stack for radios to be within the pilot's normal visual scan. This therefore does not require a separate CDI. OTOH, some inspectors at the FSDO did insist on one. I don't think that TSO for it is required so something like the BM EFIS-1 should suffice. Again, my interpretation. Also, as I recall, didn't they change the requirements for installing an IFR GPS such that it no longer requires a sign-off by and inspector at the FSDO? -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery -- 1/12/2006 -- 1/14/2006 ________________________________________________________________________________
Date: Jan 15, 2006
AC 20-138A is not regulatory for experimental aircraft unless You incorporated this into your limitations. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce McGregor Sent: Sunday, January 15, 2006 11:05 AM Subject: AeroElectric-List: IFR GPS Display AC 20-138A, Airworthiness Approval Of Global Navigation Satellite System Equipment, sets the requirements for IFR GPS units. Para 18d , Navigation Display,. requires that the horizontal and vertical deviation display(s) and failure annunciation be within the pilot's primary field of view. Primary field is defined as within 15 degrees of straight ahead of the pilot. Other displays may be anywhere from the airspeed indicator on the left in a standard six pack to and including an avionics center stack on the right. One method of compliance is to place an IFR GPS receiver that displays CDI/VDI, such as the GNS 480, within the primary field of view and eliminate the requirement for an external display. The geometry of my GlaStar gives a 12" wide zone in the panel for the GPS' display. Placing a Dynon or GRT PFD above or below the GPS would result in a lot of flight/navigation info directly in front of the pilot. Regards, Bruce McGregor -- 1/14/2006 -- 1/14/2006 ________________________________________________________________________________
Date: Jan 16, 2006
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Instrument install/annunciator lights
Those who have been here already...when you put the steam gauges in your panel, how do you fit the ones with the knobs sticking out of one corner? For the (United Instruments) altimeter it looks like I won't have a choice and will have to hog out some of the corner of the panel where the knob goes (big bump in the case under the knob). However, for the MD200 OBS (VOR/ILS indicator) and the 2 inch G meter (Falcon Gauge) the knobs have small posts that would likely fit through the screw hole if the knob were removed before installing the gauge. Can the knobs on these gauges be removed prior to installing the gauge and then re-attached afterwords? Or am I just going to have to make a small slot between the cutout and the screw hole? Also, what exactly is the bit size used to drill these screw holes? #6 screws??? Annunciator lights, I'd like to find some square ones with the colored plastic and engraved text that shows what subsystem is having a problem (commercial airline pilots know them well). I have had some great input from an RV-6A pilot who rolled his own. I've perused the web quite a while and haven't found much that might work for my application (mostly round lampholders with colored lenses but you couldn't really engrave them with text like I'm wanting). Any suggestions on this one? The only other option I can see is to use the round lampholders and have engraved text underneath each one with the subsystem being annunciated. Not the optimum solution but given what I've found so far, looking more and more viable all the time (probably simpler and quicker too). Thanks. Dean Psiropoulos RV-6A N197DM Gonna fly this spring!!! ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Hidden till needed annunciator lights?
Anyone know how to make or where to buy hidden till needed annunciator lights? My car has a row on the bottom of panel that is black and uniform, until something is illuminated. Upon turning on ignition switch, all illuminate as a test. Better yet if one were to reverse label could it be installed as a heads up display? Thx. Ron Parigoris ________________________________________________________________________________
Subject: Re: IFR GPS Display
Date: Jan 16, 2006
I'll leave the question as to whether AC 20-138A is regulatory or not to those who know the US regs better than I. But, just because something may be legal doesn't mean it is a good idea. If your installation does not match up against AC 20-138A, then I strongly recommend you should not fly IMC based on the GPS, on approach, or lower than 1000 ft above any obstacles in the enroute and terminal phases of flight. Kevin Horton On 15 Jan 2006, at 23:35, Mike wrote: > > AC 20-138A is not regulatory for experimental aircraft unless You > incorporated this into your limitations. > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Bruce > McGregor > Sent: Sunday, January 15, 2006 11:05 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: IFR GPS Display > > > > AC 20-138A, Airworthiness Approval Of Global Navigation Satellite > System > Equipment, sets the requirements for IFR GPS units. Para 18d , > Navigation > Display,. requires that the horizontal and vertical deviation > display(s) > and > failure annunciation be within the pilot's primary field of view. > Primary > field is defined as within 15 degrees of straight ahead of the pilot. > Other > displays may be anywhere from the airspeed indicator on the left in a > standard six pack to and including an avionics center stack on the > right. > > One method of compliance is to place an IFR GPS receiver that displays > CDI/VDI, such as the GNS 480, within the primary field of view and > eliminate > the requirement for an external display. The geometry of my GlaStar > gives a > 12" wide zone in the panel for the GPS' display. Placing a Dynon > or GRT > PFD > above or below the GPS would result in a lot of flight/navigation info > directly > in front of the pilot. > > Regards, Bruce McGregor ________________________________________________________________________________
Subject: Re: Instrument install/annunciator lights
Date: Jan 16, 2006
On 16 Jan 2006, at 24:52, DEAN PSIROPOULOS wrote: > > > Those who have been here already...when you put the steam gauges in > your > panel, how do you fit the ones with the knobs sticking out of one > corner? > For the (United Instruments) altimeter it looks like I won't have a > choice > and will have to hog out some of the corner of the panel where the > knob goes > (big bump in the case under the knob). However, for the MD200 OBS > (VOR/ILS > indicator) and the 2 inch G meter (Falcon Gauge) the knobs have > small posts > that would likely fit through the screw hole if the knob were > removed before > installing the gauge. Can the knobs on these gauges be removed > prior to > installing the gauge and then re-attached afterwords? Or am I just > going to > have to make a small slot between the cutout and the screw hole? > Also, what > exactly is the bit size used to drill these screw holes? #6 screws??? I've got an MD200, and the Falcon G meter. Both need a cut out for the knobs in the corner. The knob on the G meter is closer to the hole than a screw hold would be, if I recall correctly, so don't drill the holes until you have the gauge in your hands. #6 screw = #28 drill bit. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 16, 2006
kevin, ''hog out the corner''. been there last week. if you look careful you will see the face of the alt. is built up around the shaft you are talking about. that bit of panel needs to be removed to make it fit. bob noffs ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Sent: Monday, January 16, 2006 4:51 AM Subject: Re: AeroElectric-List: Instrument install/annunciator lights > > > On 16 Jan 2006, at 24:52, DEAN PSIROPOULOS wrote: > >> >> >> Those who have been here already...when you put the steam gauges in >> your >> panel, how do you fit the ones with the knobs sticking out of one >> corner? >> For the (United Instruments) altimeter it looks like I won't have a >> choice >> and will have to hog out some of the corner of the panel where the >> knob goes >> (big bump in the case under the knob). However, for the MD200 OBS >> (VOR/ILS >> indicator) and the 2 inch G meter (Falcon Gauge) the knobs have >> small posts >> that would likely fit through the screw hole if the knob were >> removed before >> installing the gauge. Can the knobs on these gauges be removed >> prior to >> installing the gauge and then re-attached afterwords? Or am I just >> going to >> have to make a small slot between the cutout and the screw hole? >> Also, what >> exactly is the bit size used to drill these screw holes? #6 screws??? > > I've got an MD200, and the Falcon G meter. Both need a cut out for > the knobs in the corner. The knob on the G meter is closer to the > hole than a screw hold would be, if I recall correctly, so don't > drill the holes until you have the gauge in your hands. > > #6 screw = #28 drill bit. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > ________________________________________________________________________________
Date: Jan 16, 2006
Why don't you lay the panel out in an AutoCAD compatible CAD program, when everything is the way you want it, send the DFX file to a laser cutter and be done with it. All 3 of my panel inserts were done that way, cost was around $100 per panel including 0.090 aluminum sheet. The time saved was tremendous. Bruce www.glasair.org ________________________________________________________________________________
Subject: Re: Light IFR
Date: Jan 16, 2006
Paul, For me, one of the important preflight actions for single-pilot IFR is to ensure that an area with reported VFR conditions is within range. The key word is REPORTED (not forecast). I learned very early that forecasts are, like, opinions. And we all know what opinions are like! My point is that the pilot is relieved of a tremendous amount of stress if he/she knows, at all times, he/she can get to REPORTED VFR conditions. A review of the forecast and trend (last several METAR)can help one decide if the current reported conditions are likely to improve or worsen. As I continue toward my destination I check AWOS, ATIS and Flight Watch to keep abreast of the latest reported weather at my destination and my chosen VFR area. If it appears my destination weather is becoming worse than I can handle, I'll set down along the way, or go to where I know the weather is good. In this way, I avoid entirely the situation of going missed at my destination and getting into my fuel reserves. Of course, a willingness to abandon the current plan always comes in handy! BTW, this is my definition of "light IFR." With an appropriately equipped aircraft and an experienced assistant (another IFR pilot or trained passenger) I'll accept higher risks on a case by case basis! Mark & Lisa Sletten Legacy FG N828LM http://www.legacyfgbuilder.com > To be conservative I filed an IFR flight > plan (with the concept of "light IFR" in > mind.) Got into the soup over Dayton and > never saw the ground again until after one > missed and finally a second successful > approach close to minimums into Detroit. ________________________________________________________________________________
Date: Jan 16, 2006
Dean: See http://vx-aviation.com/page_2.html Are these what you're looking for? The lamps are available individually or as part of integrated controllers. There are also NKK 'UB' series illuminators availabe from Digi-Key. They must be panel mounted individually and are harder to install. I think John Schroeder has used them for his Lancair. Vern Little DEAN PSIROPOULOS wrote: >... >Annunciator lights, I'd like to find some square ones with the colored >plastic and engraved text that shows what subsystem is having a problem >(commercial airline pilots know them well). I have had some great input >from an RV-6A pilot who rolled his own. I've perused the web quite a while >and haven't found much that might work for my application (mostly round >lampholders with colored lenses but you couldn't really engrave them with >text like I'm wanting). Any suggestions on this one? ... > > > > > > > ________________________________________________________________________________
Date: Jan 16, 2006
A lot of the instrument MANUFACTURERS have mounting templates for their instruments on their web sites; some of them in .pdf format that can be printed actual size. It's probably a good idea to only use them for planning purposes since, due to manufacturing tolerances, actual sizes may vary... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of bob noffs Sent: Monday, January 16, 2006 6:23 AM Subject: Re: AeroElectric-List: Instrument install/annunciator lights kevin, ''hog out the corner''. been there last week. if you look careful you will see the face of the alt. is built up around the shaft you are talking about. that bit of panel needs to be removed to make it fit. bob noffs ----- Original Message ----- From: "Kevin Horton" <khorton01(at)rogers.com> Sent: Monday, January 16, 2006 4:51 AM Subject: Re: AeroElectric-List: Instrument install/annunciator lights > > > On 16 Jan 2006, at 24:52, DEAN PSIROPOULOS wrote: > >> >> >> Those who have been here already...when you put the steam gauges in >> your >> panel, how do you fit the ones with the knobs sticking out of one >> corner? >> For the (United Instruments) altimeter it looks like I won't have a >> choice >> and will have to hog out some of the corner of the panel where the >> knob goes >> (big bump in the case under the knob). However, for the MD200 OBS >> (VOR/ILS >> indicator) and the 2 inch G meter (Falcon Gauge) the knobs have >> small posts >> that would likely fit through the screw hole if the knob were >> removed before >> installing the gauge. Can the knobs on these gauges be removed >> prior to >> installing the gauge and then re-attached afterwords? Or am I just >> going to >> have to make a small slot between the cutout and the screw hole? >> Also, what >> exactly is the bit size used to drill these screw holes? #6 screws??? > > I've got an MD200, and the Falcon G meter. Both need a cut out for > the knobs in the corner. The knob on the G meter is closer to the > hole than a screw hold would be, if I recall correctly, so don't > drill the holes until you have the gauge in your hands. > > #6 screw = #28 drill bit. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > ________________________________________________________________________________
Date: Jan 16, 2006
Ira, Thanks for the input. I did get to wander around SnF last year and look at many of the systems available. I talked directly to avionics install shops and manufacturers of the individual units. The EFIS that got the most positive responses from all was GRT. I even went to the BMA booth and asked them to comment on the bad press their company and service has received. They seemed to think the bad press was not deserved and offered that most problems occur due to bad installations by the builder. I was a little disturbed by this response. Perhaps this is due to the insufficient install manuals that you mentioned. However, I have met many people such as yourself that are using BMA systems and have great things to say about the company and product. I still love the features that the product offers and would be very happy to have a working version of the system in my panel. The only question is how many headaches lie between now and that point... Greg >From: irampil(at)notes.cc.sunysb.edu >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: EFIS Companies >Date: Sun, 15 Jan 2006 19:09:39 -0500 > > > Greg, > >I have been flying with a Blue Mountain E/1 for almost two years. >In that time the software has received major feature upgrades nearly >every quarter, all free after purchase. Only recently, and only because >they switched to Jeppeson who insisted, has BMA begun enforcing the >subscription payment for database updates. > >I have always found the company easy to deal with and very >straightforward. >While it seems a few shipped systems had bugs, most of what one see >complaints >about on their unmoderated Board concerns builders or installers who have >trouble with the sometimes telegraphically brief install manuals or with >poor grounding discipline in their wiring harnesses. > >I have a great deal of respect for both Bob N. and Greg R. My A/C wiring >is a slightly modified version of Bob's All-Electric, including a LVBM >module controlling the power to the EFIS. In my opinion, Greg made some >good points in his treatise on electrical system design also. We can all >learn from looking at both. Like Bob said, you should infer nothing >about Greg's company business practices from their design flap. > >You should probably wander around SnF or Oshkosh and do some of your >own assessment of the people and equipment involved. Its a very personal >choice. > >Ira N224XS > > ________________________________________________________________________________
Date: Jan 16, 2006
Dean, Yes the knobs can be taken off. There should be a set screw in the knob. For switches, Tyco makes a nice version. See their Command Series 16mm. Available from www.Newarkinone.com stock number 46F3130. We used these switches (164SL and 164SL5) and the same family lighted indicator (164-SZ) in our install. Rather than engraving there is a plastic lens inside the switch which can be screen printed. I had this done by Precision Dial Co. (www.precisiondial.com) (I formerly owned the company). Jim Butcher Europa XS N241BW ________________________________________________________________________________
Date: Jan 16, 2006
I don't think that "light IFR" has as much to do with equipment as it does with intent. To fly IFR, you have to be legally equipped to handle whatever equipment the type of approach you want to shoot requires. Period. Anything else is not "light IFR", it's just plain suicide. Light IFR is more to explain a person's intent and how he/she will accept minimums and alternate minimums. If a "light IFR" pilot gets into heavy soup, they will still have the equipment they need to land safely if they are equipped to fly what they filed. Now, the matter of that pilot being mentally prepared and currently trained... that's a different issue. Vern W. On 1/15/06, Richard Riley wrote: > > > At 08:24 AM 1/15/06, you wrote: > > > > >The concept of "light IFR" should be put to rest once and for all. > > > >Once you fly into the clouds, the distinction of light or heavy IFR > >is GONE! IMC is IMC! (Let's not even consider ice and/or > >thunderstorms for this discussion.) > ________________________________________________________________________________
From: "richard titsworth" <rtitsworth(at)mindspring.com>
Date: Jan 16, 2006
>The concept of "light IFR" should be put to rest once and for all. >Once you fly into the clouds, the distinction of light or heavy IFR >is GONE! .... >In southern California airports close to the coast - like Santa >Monica, Torrance, Long Beach, Orange County, Palomar, Oxnard, Santa >Barbara - get "early morning and late night overcast." It's a pretty >thin layer... My $.02: The comments/posts got me thinking about ADM, Risk Management, personally minimum, and the "reality" of IFR flight decisions. I'm not a writer, but thought I'd share my thoughts 1) to help personally crystallize them and 2) to invite/provoke comment with the desire for additional learning. I live in Detroit and agree with psiege. In the Mid-west, we can be IFR with low ceilings, low vis, multiple layers, sometimes wind/turbulence, often icing, for days/weeks and 250 miles or more in all directions - nothing to "play" with. Many experienced pilots have near-miss stories, a few others were not so lucky, and there are numerous NTSB reports about VFR into IMC. All IFR in the Midwest (or elsewhere) is IFR. If fact some VMC is really IFR (over remote areas on a dark night, in the clear over the hazy great lakes at dusk/dawn, etc). However, I did my initial instrument training while on an extended work assignment in SoCal. As rriley states, the LA "sea layer" overcast is typically "local" and relatively stable/predictable - more so than a Detroit VFR day. It often implies a different IFR scenario and offers various bailout options. In SoCal, if we're going to consider different IFR equipment/currency for Hard vs Light IFR, then the "need", is to be sure we can tell the difference and have the discipline to respect it. This is not easy as there is no real/fixed definition, the Wx briefs aren't necessarily setup to help us clearly discern it, and many Pilots will occasionally "push" the envelope - this thread is proof. The risks with a SoCal coastal sea layer may be much different than a typical Midwest "white flight", but are not insignificant. First, there's lots of traffic, lots of radio congestion, relatively tight/complex complex airspace, and fewer good off-field options over the congested metropolis - Little room for less than our full attention. But wait, the AI/DG/CDI/ALT or PFD also demand our full attention (even if for only 60-90 seconds) - Thus, the need for not stretching "field of vision" definitions or selecting equipment which may not be IFR reliable, or unnecessarily increase our IFR workload. While the existence of the sea layer itself is often stable/predictable - what's sometimes "unpredictable" about the sea layer is the ceiling. I've seen it drop from 1000ft/5mi to 0/0 in 1 min (especially on the fringes and/or close to the ocean). I've been cleared and landed on a visual approach at MRY through a (VFR) scattered layer, and then not been able to see the Ramp/Tower 1 minute later while taxing. I know MRY is technically NorCal - same point. Since the SeaLayer if often very local, the ATIS can become more? important than the TAR/TAF/AreaForecast. Yet, I'm sure we've all had an "ATIS experience" that was less than accurate - either too high or too low - or "being updated", etc. Any concept of "light IFR" still demands vigilance to MDA/MDH and needs to contain the real possibility of missed approaches and all the workload/discipline that goes with them. Additionally, SoCal has CummuliousGranite (terrain/mountains). Many "sealayer" airports are right next to them (TOA, SBA, SMA,...). Mix a night VFR flight over a scattered/broken sea layer and the dark spots/splotches (clouds and mountains) can look very similar. This can be very disorienting - even when technically VFR. Again, no room for IFR error. ATC is always there to help. But again, I've been cleared to "turn 10' right and incept the localizer...", when the localizer was 10' left. Yes a bad clearance and a mistake by ATC, but ultimately the pilot is the guy with his butt on the line and thus required to be aware of everything - even on a simple "light IFR" approach. All said, there might be "SoCal Light IFR" and I might successfully fly through it multiple times (IFR with minimum equipment/workload). BUT IT CAN STILL BE TRICKY/DANGEROUS/DEADLY STUFF. I'd never imply anything different to a student and/or fellow pilot! For a well trained/skilled/current IFR pilot, a "minimally adequate" aircraft in "SoCal light IFR" may be technically legal and perhaps within his/her personal minimums. But, the risks are real, they're still "pushing the envelope", and adding "some" stress to the entire IFR system. If we accept that, well ok, we're PIC's, and flying itself is has some risk. But if we try and convince ourselves (or passengers) of anything less, we're not being honest. Perhaps there's another ADM dangerous attitude: "I'm within the letter of the regulation (or it's ambiguity), so it's ok/acceptable". The anecdotal thought would be something like: "the regulations/minimum are just that minimums, and I should treat/respect them as dangerous ground." The FAM/AIM are decision floors set by the FAA, they are not perfect and sometimes/often unclear. Sometimes they may be/seem too conservative - but the NTSB stats indicate that, overall, they still allow pilots (like us) to get into trouble. It's up to us to take individual responsibility to raise the bar and set personally honest minimums. As a group we should be encouraging each other to honestly review/set/raise these as appropriate - since the common natural tendency is to build skill/experience/capability to otherwise lower them. My $.02 Rick ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: Jabiru 3300
> > >Has anyone made up a wirebook which incorporate the wiring for a Jabiru >3300? Would you be willing to email to me? Looking for some ideas and >specifically how to handle the built in alternator. The engine comes with a >"Kubato RP201-53710" voltage reg and I can't find any spec on this regulator >and not sure if it has OV protection etc. The alternator has two white >wires coming out it that connects to the voltage reg. Any info on the Kubato >reg or alternatives would be great. As near as I can tell, the Kubota regulators for the PM alternators are pretty much the same as similar devices by Ducati and John Deere for the same application. They do not feature OV protection. You can get the published literature on all the Jabiru offerings at: http://www.suncoastjabiru.com/downloads.htm I've published a power distribution diagram for these engines as Figure Z-20 of http://aeroelectric.com/articles/Rev11/AppZ_R11E.pdf Bob . . . ________________________________________________________________________________
Date: Jan 16, 2006
Hi all, I mostly lurk but sometimes have an opinion itch. I find the all solid state gyro developments exciting and disappointing. I agree with Bruce of Glasair - unless you have triple redundancy with automatic notification of discrepancy you probably don't get an improvement in safety. Comparison and notification is so easy to do with digital electronics that it should be a large part of the reason to go solid state in the first place. It is silly to have various digital electronics boxes working with the human operator doing the only cross-checking available. But that seems to be what the manufacturers expect of us sofar. I see a lot of features, display options and what have you on the websites but no output message specifications. The inexpensive EFIS-es would be much more useful if they all put out their measured magnitudes in real time in a PUBLICISED (and standardised, not proprietary) way and acknowledge that the 'S' does not mean 'System' but at most 'Subsystem'. I will go further: an electronic box that measures a well defined magnitude and doesn't produce it on a serial output should be considered crippled. It cannot play a role in a system. It should not be bought. If manufacturers did start to make a habit of publicly reproducing real time magnitudes on a serial output then the step from boxes to system would be simple. As a start just add comparison, alarm and display of results (have a backup for this too). Not holding my breath much longer. Cheers, Jan de Jong ________________________________________________________________________________
Date: Jan 16, 2006
Vern - Thank you for the reference. I used the LB series lights - rectangular. The also come in round and square shapes. Cheers, John wrote: > There are also NKK 'UB' series illuminators availabe from Digi-Key. > They must be panel mounted individually and are harder to install. I > think John Schroeder has used them for his Lancair. > Vern Little -- ________________________________________________________________________________
Date: Jan 16, 2006
From: "Dan Beadle" <Dan.Beadle(at)hq.inclinesoftworks.com>
I think you make a great point about the So-Cal weather. IFR is dangerous. It is a compromise: increased risk for increased utility (getting there). While " CummuliousGranite" provides some additional risk, it also makes IFR less risky: If you have problems in the June Gloom, you can most always get to VFR and proceed to a nearby VFR airport. The June Gloom stratus layer is rarely 2000' thick. Big Bear, at 6700' is always VFR during these conditions. As are the desert airports. This makes IFR-LITE a possibility in So-Cal, where it may not be in areas with low ceilings stretching for hundreds of miles. Airplanes are inherently dangerous - that is why we train. To fly IFR, we also need to equip airplanes adequately to survive any system failure. A single point of failure should not bring down an airplane. Some planes are designed to tolerate dual failures (ie. Fail the vacuum and an instrument electrical bus) The design issue is a compromise: dollars, weight, pilot work load,etc. For most of us, the most likely single point of failure is the pilot. Adding a redundant pilot (or two if we want to take a vote) probably makes more sense than dual AHRS, unless they are part of completely redundant systems (separate batteries, separate PFDs, etc.). Me, I am going EFIS, brand TBD, with a separately powered electric gyro. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of richard titsworth Sent: Monday, January 16, 2006 6:40 AM Subject: RE: AeroElectric-List: "Light" IFR??? >The concept of "light IFR" should be put to rest once and for all. >Once you fly into the clouds, the distinction of light or heavy IFR >is GONE! .... >In southern California airports close to the coast - like Santa >Monica, Torrance, Long Beach, Orange County, Palomar, Oxnard, Santa >Barbara - get "early morning and late night overcast." It's a pretty >thin layer... My $.02: The comments/posts got me thinking about ADM, Risk Management, personally minimum, and the "reality" of IFR flight decisions. I'm not a writer, but thought I'd share my thoughts 1) to help personally crystallize them and 2) to invite/provoke comment with the desire for additional learning. I live in Detroit and agree with psiege. In the Mid-west, we can be IFR with low ceilings, low vis, multiple layers, sometimes wind/turbulence, often icing, for days/weeks and 250 miles or more in all directions - nothing to "play" with. Many experienced pilots have near-miss stories, a few others were not so lucky, and there are numerous NTSB reports about VFR into IMC. All IFR in the Midwest (or elsewhere) is IFR. If fact some VMC is really IFR (over remote areas on a dark night, in the clear over the hazy great lakes at dusk/dawn, etc). However, I did my initial instrument training while on an extended work assignment in SoCal. As rriley states, the LA "sea layer" overcast is typically "local" and relatively stable/predictable - more so than a Detroit VFR day. It often implies a different IFR scenario and offers various bailout options. In SoCal, if we're going to consider different IFR equipment/currency for Hard vs Light IFR, then the "need", is to be sure we can tell the difference and have the discipline to respect it. This is not easy as there is no real/fixed definition, the Wx briefs aren't necessarily setup to help us clearly discern it, and many Pilots will occasionally "push" the envelope - this thread is proof. The risks with a SoCal coastal sea layer may be much different than a typical Midwest "white flight", but are not insignificant. First, there's lots of traffic, lots of radio congestion, relatively tight/complex complex airspace, and fewer good off-field options over the congested metropolis - Little room for less than our full attention. But wait, the AI/DG/CDI/ALT or PFD also demand our full attention (even if for only 60-90 seconds) - Thus, the need for not stretching "field of vision" definitions or selecting equipment which may not be IFR reliable, or unnecessarily increase our IFR workload. While the existence of the sea layer itself is often stable/predictable - what's sometimes "unpredictable" about the sea layer is the ceiling. I've seen it drop from 1000ft/5mi to 0/0 in 1 min (especially on the fringes and/or close to the ocean). I've been cleared and landed on a visual approach at MRY through a (VFR) scattered layer, and then not been able to see the Ramp/Tower 1 minute later while taxing. I know MRY is technically NorCal - same point. Since the SeaLayer if often very local, the ATIS can become more? important than the TAR/TAF/AreaForecast. Yet, I'm sure we've all had an "ATIS experience" that was less than accurate - either too high or too low - or "being updated", etc. Any concept of "light IFR" still demands vigilance to MDA/MDH and needs to contain the real possibility of missed approaches and all the workload/discipline that goes with them. Additionally, SoCal has CummuliousGranite (terrain/mountains). Many "sealayer" airports are right next to them (TOA, SBA, SMA,...). Mix a night VFR flight over a scattered/broken sea layer and the dark spots/splotches (clouds and mountains) can look very similar. This can be very disorienting - even when technically VFR. Again, no room for IFR error. ATC is always there to help. But again, I've been cleared to "turn 10' right and incept the localizer...", when the localizer was 10' left. Yes a bad clearance and a mistake by ATC, but ultimately the pilot is the guy with his butt on the line and thus required to be aware of everything - even on a simple "light IFR" approach. All said, there might be "SoCal Light IFR" and I might successfully fly through it multiple times (IFR with minimum equipment/workload). BUT IT CAN STILL BE TRICKY/DANGEROUS/DEADLY STUFF. I'd never imply anything different to a student and/or fellow pilot! For a well trained/skilled/current IFR pilot, a "minimally adequate" aircraft in "SoCal light IFR" may be technically legal and perhaps within his/her personal minimums. But, the risks are real, they're still "pushing the envelope", and adding "some" stress to the entire IFR system. If we accept that, well ok, we're PIC's, and flying itself is has some risk. But if we try and convince ourselves (or passengers) of anything less, we're not being honest. Perhaps there's another ADM dangerous attitude: "I'm within the letter of the regulation (or it's ambiguity), so it's ok/acceptable". The anecdotal thought would be something like: "the regulations/minimum are just that minimums, and I should treat/respect them as dangerous ground." The FAM/AIM are decision floors set by the FAA, they are not perfect and sometimes/often unclear. Sometimes they may be/seem too conservative - but the NTSB stats indicate that, overall, they still allow pilots (like us) to get into trouble. It's up to us to take individual responsibility to raise the bar and set personally honest minimums. As a group we should be encouraging each other to honestly review/set/raise these as appropriate - since the common natural tendency is to build skill/experience/capability to otherwise lower them. My $.02 Rick ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: EFIS Companies
BMA has "leading edge" products and they make a big effort to make there customers happy. That being said their install and operations manuals are not very good (I'm being kind!) therefore no doubt builders have a high rate of installation errors . . . I've been trying to figure out the GNS430 to BMA/Lite interface for two month and received better help from Treasure Coast Avionics (I'm not their customer) than Blue Mountain! The last response I received was "are you sure the wiring is right?" NO I'm not sure, but its wired per the manual!! Obviously Greg and staff are working on "more important issues" . . . but for me there are none more important. The good news is that I do believe the Greg can and will solve most any problem . . . but IMHO sometimes it takes longer than is should and problems come up that shouldn't because of limited manuals and support! Good Luck, Bob On 1/16/06, Greg Vouga wrote: > > > > > Ira, > > Thanks for the input. I did get to wander around SnF last year and look > at > many of the systems available. I talked directly to avionics install > shops > and manufacturers of the individual units. The EFIS that got the most > positive responses from all was GRT. I even went to the BMA booth and > asked > them to comment on the bad press their company and service has received. > They seemed to think the bad press was not deserved and offered that most > problems occur due to bad installations by the builder. I was a little > disturbed by this response. Perhaps this is due to the insufficient > install > manuals that you mentioned. > > However, I have met many people such as yourself that are using BMA > systems > and have great things to say about the company and product. I still love > the features that the product offers and would be very happy to have a > working version of the system in my panel. The only question is how many > headaches lie between now and that point... > > Greg > > >From: irampil(at)notes.cc.sunysb.edu > >Reply-To: aeroelectric-list(at)matronics.com > >To: aeroelectric-list(at)matronics.com > >Subject: AeroElectric-List: EFIS Companies > >Date: Sun, 15 Jan 2006 19:09:39 -0500 > > > > > > Greg, > > > >I have been flying with a Blue Mountain E/1 for almost two years. > >In that time the software has received major feature upgrades nearly > >every quarter, all free after purchase. Only recently, and only because > >they switched to Jeppeson who insisted, has BMA begun enforcing the > >subscription payment for database updates. > > > >I have always found the company easy to deal with and very > >straightforward. > >While it seems a few shipped systems had bugs, most of what one see > >complaints > >about on their unmoderated Board concerns builders or installers who have > >trouble with the sometimes telegraphically brief install manuals or with > >poor grounding discipline in their wiring harnesses. > > > >I have a great deal of respect for both Bob N. and Greg R. My A/C wiring > >is a slightly modified version of Bob's All-Electric, including a LVBM > >module controlling the power to the EFIS. In my opinion, Greg made some > >good points in his treatise on electrical system design also. We can all > >learn from looking at both. Like Bob said, you should infer nothing > >about Greg's company business practices from their design flap. > > > >You should probably wander around SnF or Oshkosh and do some of your > >own assessment of the people and equipment involved. Its a very personal > >choice. > > > >Ira N224XS > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 16, 2006
This is fairly simple with a black background. You can simply flush mount your lights in the panel, then put a mylar in front of them with the lettering clear on black. Without back-lighting on, the letters disappear, looking black also. Turn on the lamp, and bingo. The black-out feature works best with a satin textured mylar. A simple way to do this and avoid custom work is with a laser printer and some overhead transparency stock. Make up your labels with Publisher or some similar tool. Then print them. The quality of the laser is important to getting a uniform coverage. Also, you may have to scale the spacing up/down a little - there can be a couple of percent of size variation when printed. Finish off the system with a piece of smoked mylar or Lucite panel. This will give you a finished look. The surface will be hard. The smoky appearance will help mask any minor imperfections in the printing process, yet will still let enough light through. We used to use this kind of process in prototyping electronic units. Dan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rparigor(at)SUFFOLK.LIB.NY.US Sent: Monday, January 16, 2006 12:34 AM Subject: AeroElectric-List: Hidden till needed annunciator lights? Anyone know how to make or where to buy hidden till needed annunciator lights? My car has a row on the bottom of panel that is black and uniform, until something is illuminated. Upon turning on ignition switch, all illuminate as a test. Better yet if one were to reverse label could it be installed as a heads up display? Thx. Ron Parigoris ________________________________________________________________________________
Subject: Battery bus location and Hall-effect sensor
Date: Jan 16, 2006
OK, staring at Z-13 for hours has diminished the fog somewhat, but a few questions remain (1)For my RV-7A, I was planning on putting my main and e-bus fuse panels on the right hand side of the subpanel. But what about the battery bus? Z-13 suggests that the battery bus be located within six inches of the battery contactor, which in my case, is on the firewall. This appears to limit my battery bus location to the firewall as well, no? Guess I could live with that, except that its my understanding that fuses necessary for flight safety be accessible during flight. Since electronic ignition and e-bus alt feed come from the battery bus, wouldnt the firewall location be a no-no? (2) Im using a GRT EFIS, which comes with one Hall-effect sensor. I believe this can replace the shunt for the main alternator B-lead on Z-13. Is is possible and practical that the same sensor can also go around the lead for the backup SD-8 PM alternator, since both alternators wont be operating at the same time, or do I need two separate Hall-effect sensors? thanks guys Erich Weaver ________________________________________________________________________________
Date: Jan 16, 2006
The EAA disagrees. See http://members.eaa.org/home/homebuilders/faq/Equipping%20a%20Homebuilt%20for%20IFR%20operations.html Bruce AC 20-138A is not regulatory for experimental aircraft unless You incorporated this into your limitations. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce McGregor Sent: Sunday, January 15, 2006 11:05 AM Subject: AeroElectric-List: IFR GPS Display AC 20-138A, Airworthiness Approval Of Global Navigation Satellite System Equipment, sets the requirements for IFR GPS units. Para 18d , Navigation Display,. requires that the horizontal and vertical deviation display(s) and failure annunciation be within the pilot's primary field of view. Primary field is defined as within 15 degrees of straight ahead of the pilot. Other displays may be anywhere from the airspeed indicator on the left in a standard six pack to and including an avionics center stack on the right. One method of compliance is to place an IFR GPS receiver that displays CDI/VDI, such as the GNS 480, within the primary field of view and eliminate the requirement for an external display. The geometry of my GlaStar gives a 12" wide zone in the panel for the GPS' display. Placing a Dynon or GRT PFD above or below the GPS would result in a lot of flight/navigation info directly in front of the pilot. Regards, Bruce McGregor ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: EFIS Comparisons
Jan, Can you repeat that in English? :>) You sound like you know what you are talking about, but us non-electrical engineers do not. Kevin -- Kevin Seuferer -- http://www.bearhawkin.com -- Bearhawk Serial #774 -- N774KD The inexpensive EFIS-es would be much more useful if they all put out their measured magnitudes in real time in a PUBLICISED (and standardised, not proprietary) way and acknowledge that the 'S' does not mean 'System' but at most 'Subsystem'. I will go further: an electronic box that measures a well defined magnitude and doesn't produce it on a serial output should be considered crippled. It cannot play a role in a system. It should not be bought. If manufacturers did start to make a habit of publicly reproducing real time magnitudes on a serial output then the step from boxes to system would be simple. As a start just add comparison, alarm and display of results (have a backup for this too). ________________________________________________________________________________
Subject: Battery strength
Date: Jan 16, 2006
Hello all, as I am new on this list - this is my first try to get some needed information. So what I have is a 24 Volt system with a 12 Volt starter on an O360 F1A6. I was told that it should not be a problem to use the 12 Volt starter with 24 Volt as the voltage will drop anyhow to about 18 Volt and the starting process itself will not take more than 20 seconds which the starter should be capable to handle. - what is the opinion of the group on this ? - The second issue is that I need a figure of the battery strength (Ah) which is needed to start my engine. I know that this is depending on many issues and this should not be the only consideration for the strength but there must be a general idea of whether 17 Ah should do the job easily or should one go for 24 Ah or 7 Ah. Thanks for your recomendations Peter (Lancair 360 MKII, 85%) ________________________________________________________________________________
Date: Jan 16, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> sensor
Subject: Re: Battery bus location and Hall-effect sensor
> >OK, staring at Z-13 for hours has diminished the fog somewhat, but a few >questions remain > >(1)For my RV-7A, I was planning on putting my main and e-bus fuse panels on >the right hand side of the subpanel. But what about the battery bus? Z-13 >suggests that the battery bus be located within six inches of the battery >contactor, which in my case, is on the firewall. This appears to limit my >battery bus location to the firewall as well, no? Guess I could live with >that, except that its my understanding that fuses necessary for flight >safety be accessible during flight. Which of your fuses need access for "flight safety" reasons? > Since electronic ignition and e-bus >alt feed come from the battery bus, wouldnt the firewall location be a >no-no? Review chapter 17. The numbers of failures that render a system unusable and DO NOT blow a fuse outnumber the things that DO blow fuses by several orders of magnitude. Further, if you DO open a fuse in some necessary system, what is the likelihood that you'll get that system back by replacing the fuse? The fault that opened the fuse is still going to be there waiting for your new fuse. Bottom line is that if you have any system that's necessary for comfortable completion of flight, then you'd better have a backup for it and being able to access breakers or fuses for those systems is wishful thinking. >(2) Im using a GRT EFIS, which comes with one Hall-effect sensor. I >believe this can replace the shunt for the main alternator B-lead on Z-13. >Is is possible and practical that the same sensor can also go around the >lead for the backup SD-8 PM alternator, since both alternators wont be >operating at the same time, or do I need two separate Hall-effect sensors? No, one sensor will work nicely for both systems. Bob . . . ________________________________________________________________________________
Subject: Interference between Com and Autopilot
Date: Jan 16, 2006
Hello all, I am building my panel with a TruTrak DF II autopilot and 2 Becker AR3202 Coms. I have discovered that transmitting during engaged autopilot has influence on the AP in the form that the elevator goues up and the ailerons make a right turn. As the details on the up and down is second, the influence itself is of cause the problem. I have made the connections between the - high quality - HF cables and the BNCs myself (i.e. they should be OK) and use 2 standard - not self made - antennae. The question is now - what can I do to avoid this interference? more shielding, replacing the autopilot, ... BTW, the antennae are in the baggage compartment Thanks Peter Lancair 360 MKII 85% ________________________________________________________________________________
From: "Dr. Peter Laurence" <Dr.Laurence(at)mbdi.org>
Date: Jan 16, 2006
Bruce, Who did tou use? Peter ----- > Why don't you lay the panel out in an AutoCAD compatible CAD program, when > everything is the way you want it, send the DFX file to a laser cutter and > be done with it. All 3 of my panel inserts were done that way, cost was > around $100 per panel including 0.090 aluminum sheet. The time saved was > tremendous. > > Bruce > www.glasair.org > > > ________________________________________________________________________________
Date: Jan 16, 2006
On 16 Jan 2006, at 10:19, Jan de Jong wrote: > > > The inexpensive EFIS-es would be much more useful if they all put out > their measured magnitudes in real time in a PUBLICISED (and > standardised, not proprietary) way and acknowledge that the 'S' > does not > mean 'System' but at most 'Subsystem'. I will go further: an > electronic > box that measures a well defined magnitude and doesn't produce it on a > serial output should be considered crippled. It cannot play a role > in a > system. It should not be bought. > > If manufacturers did start to make a habit of publicly reproducing > real > time magnitudes on a serial output then the step from boxes to system > would be simple. As a start just add comparison, alarm and display of > results (have a backup for this too). The Dynon D-10/D-100 series EFISs output attitude, airspeed, altitude, heading, etc in text format on a serial data bus at 64 Hz.The data format is described in the operator's manual, which is publicly available on Dynon's web site. The format is bog standard ASCII data on an RS-232 serial bus. No propriatary stuff at all. It would theoretically be possible to decode that data and use it to feed an instrument comparator. But, how do we know there aren't failure modes that freezes the display (or has it display bad data), yet keeps spitting the correct data out the serial bus? We can't expect to get iron clad assurances for the amount of money we pay for the Dynon (or any other of the non- TSO'd EFIS systems). Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 16, 2006
Aircraft Engravers, www.engravers.net, ask for Wayne. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dr. Peter Laurence Sent: Monday, January 16, 2006 4:19 PM Subject: Re: AeroElectric-List: Instrument install/annunciator lights Bruce, Who did tou use? Peter ----- > Why don't you lay the panel out in an AutoCAD compatible CAD program, when > everything is the way you want it, send the DFX file to a laser cutter and > be done with it. All 3 of my panel inserts were done that way, cost was > around $100 per panel including 0.090 aluminum sheet. The time saved was > tremendous. > > Bruce > www.glasair.org > > > ________________________________________________________________________________
Subject: MicroAir products
Date: Jan 16, 2006
I'm about to order transceiver & transponder for my Sonex. I like the small MicroAir radios and they're the cheapest so far. Also, the dealer is here in Tennessee which makes it convenient. Can anyone offer feedback about them (or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also feedback on the dealer, Jabiru USA would be appreciated. Rodney ________________________________________________________________________________
Date: Jan 17, 2006
I have a microair transponder. Its worked fine for me over the past three years. I did have to send it back once for a software update but the service was quick and free. Allan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rodney Dunham Sent: Tuesday, 17 January 2006 09:23 Subject: AeroElectric-List: MicroAir products --> I'm about to order transceiver & transponder for my Sonex. I like the small MicroAir radios and they're the cheapest so far. Also, the dealer is here in Tennessee which makes it convenient. Can anyone offer feedback about them (or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also feedback on the dealer, Jabiru USA would be appreciated. Rodney ________________________________________________________________________________
Date: Jan 16, 2006
From: "Dave Morris \"BigD\"" <BigD(at)DaveMorris.com>
Subject: Re: MicroAir products
See this comparison chart: http://www.mcp.com.au/microair/comparison/comparison.html Dave Morris At 04:22 PM 1/16/2006, you wrote: > > >I'm about to order transceiver & transponder for my Sonex. I like the small >MicroAir radios and they're the cheapest so far. Also, the dealer is here in >Tennessee which makes it convenient. Can anyone offer feedback about them >(or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also >feedback on the dealer, Jabiru USA would be appreciated. > >Rodney > > ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: Hidden till needed annunciator lights?
West Coast Aviation 425-283-0460. On 1/16/06 3:33 AM, "rparigor(at)SUFFOLK.LIB.NY.US" wrote: > > Anyone know how to make or where to buy hidden till needed annunciator > lights? > > My car has a row on the bottom of panel that is black and uniform, until > something is illuminated. Upon turning on ignition switch, all illuminate > as a test. > > Better yet if one were to reverse label could it be installed as a heads > up display? > > Thx. > Ron Parigoris > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 16, 2006
FWIW I have a MicroAir in my Nieuport replica and it works fine with the open cockpit noise etc. A friend is also using one in his Stearman. He had a lot of problems initially but it was an early serial number radio. They took care of it and things are great. No complaints and may move mine to my RV as a secondary radio. Jim Thorne RV7A QB CHD ----- Original Message ----- From: "Allan Aaron" <aaaron(at)tvp.com.au> Sent: Monday, January 16, 2006 4:10 PM Subject: RE: AeroElectric-List: MicroAir products > > I have a microair transponder. Its worked fine for me over the past > three years. I did have to send it back once for a software update but > the service was quick and free. > Allan > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Rodney Dunham > Sent: Tuesday, 17 January 2006 09:23 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: MicroAir products > > --> > > I'm about to order transceiver & transponder for my Sonex. I like the > small MicroAir radios and they're the cheapest so far. Also, the dealer > is here in Tennessee which makes it convenient. Can anyone offer > feedback about them (or Becker or XCOM) ??? especially when combined > with the Jabiru 3300. Also feedback on the dealer, Jabiru USA would be > appreciated. > > Rodney > > > ________________________________________________________________________________
Date: Jan 16, 2006
Rodney, I'm using a Becker Transponder and I found the install extremely easy, operation is bulletproof. Never have any trouble with it, setup was intuitive and the human interface is very natural. Larry McFarland - 601 HDS at www.macsmachine.com Rodney Dunham wrote: > >I'm about to order transceiver & transponder for my Sonex. I like the small >MicroAir radios and they're the cheapest so far. Also, the dealer is here in >Tennessee which makes it convenient. Can anyone offer feedback about them >(or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also >feedback on the dealer, Jabiru USA would be appreciated. > >Rodney > > > > ________________________________________________________________________________
Date: Jan 16, 2006
Kevin Horton wrote: Go away for a couple of days and you drown in messages. >>If manufacturers did start to make a habit of publicly reproducing >>real >>time magnitudes on a serial output then the step from boxes to system >>would be simple. As a start just add comparison, alarm and display of >>results (have a backup for this too). There is such a standard. It is ARINC-429. > The Dynon D-10/D-100 series EFISs output attitude, airspeed, > altitude, heading, etc in text format on a serial data bus at 64 > Hz.The data format is described in the operator's manual, which is > publicly available on Dynon's web site. The format is bog standard > ASCII data on an RS-232 serial bus. No propriatary stuff at all. It > would theoretically be possible to decode that data and use it to > feed an instrument comparator. There is no such thing as "bog standard ASCII data on an RS-232 serial bus" in an aircraft (or anywhere else for that matter which is why we created SLIP and PPP in the internet world many moon back). The closest thing to something like that is ARINC-429. There you have a standard electrical bus, similar to RS-422, and a standard set of sentences and/or messages which transfer various bits of status information. I believe that just about everything your AHARS would output has an ARINC-429 message associated with it. (And it is the AHRS data whose integrity that you are interested in ensuring.) > But, how do we know there aren't failure modes that freezes the > display (or has it display bad data), yet keeps spitting the correct > data out the serial bus? We can't expect to get iron clad assurances > for the amount of money we pay for the Dynon (or any other of the non- > TSO'd EFIS systems). I know I am coming at this backward as there are a *bunch* of messages on this subject going back a couple of days that I haven't read yet but I am going to go ahead from here anyway. These are systems badly done (from a systems perspective) as are most things in the cockpit of most aircraft. Boeing and Airbus are only just recently starting to adopt the advantages learned in building large computer networks. Airbus has adopted switched 100Mbps ethernet as its data bus of choice (a very sensible move IMHO). ARINC-429 works but, boy is that ancient technology. The key point is that you have sensors that output standard messages on the bus, e.g. AHRS, air data sensors, engine data sensors, etc.; you have processing units; and you have display/control units. Virtually all of the systems out there have adopted an "all-in-one" approach because it is cheaper rather than better. But because they are "all-in-one" they don't have to try to be interoperable with other devices. At least with ARINC-429 there is some semblance of consistency and interoperability even if it is ancient, ugly technology. If it speaks ARINC-429 there is some semblance of hope. If it speaks some kind of proprietary garbage (even if it is "bog standard ASCII messages documented in the manual") it isn't going to be supported by anyone else so it is less than useful. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > > > > > > > > > > > -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
Dave Morris "BigD" wrote: > > See this comparison chart: > http://www.mcp.com.au/microair/comparison/comparison.html Microair radios suffer from front-end overload. Don't expect them to perform well near other airplanes. That is why we were talking about antenna attenuators a couple weeks back -- to deal with a deficiency in the Microair Comm transceivers. This becomes a real problem if you plan to fly formation with other aircraft. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Subject: EFIS Comparisons
Date: Jan 16, 2006
Bob, I have to agree on your take. I learned to fly partial panel with a turn coordinator ( along with the other compliments of instruments) which in my opinion is as proficient as a T&B. However, my guess is that a lot of newer pilots flying today have not developed this skill. I recommend the T&B because I think it is a much better back up than the artificial horizon. I agree You state that most T&Bs are powered by vacuum. That may be true. But then again, it may not! I'll bet a milk shake that there are more electrically powered T&Bs in service today than there are vacuum powered ones. I agree. However, there are probably more turn coordinators installed than turn and banks. Is there such a thing as a vacuum T/C? Peter Laurence ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: Interference between Com and Autopilot
Peter.Sokolowski@t-online.de wrote: > > Hello all, > I am building my panel with a TruTrak DF II autopilot and 2 Becker AR3202 Coms. I have discovered that transmitting during engaged autopilot has influence on the AP in the form that the elevator goues up and the ailerons make a right turn. As the details on the up and down is second, the influence itself is of cause the problem. I have made the connections between the - high quality - HF cables and the BNCs myself (i.e. they should be OK) and use 2 standard - not self made - antennae. > The question is now - what can I do to avoid this interference? more shielding, replacing the autopilot, ... > BTW, the antennae are in the baggage compartment What are you using for a ground plane for your antennas? Isn't the fuselage in the Lancair primarily carbon fiber? If that is the case you are going to want to get the antennas outside the fuselage. How does the TruTrak autopilot talk to its servos? Is is an analog voltage or a digital message? Frankly, I would talk with the folks from TruTrak. They can help you with RF getting into their servos and/or the control head. Given the digital nature of the TruTrak autopilot and if I understand their system properly I would suspect that the problem is occurring at the one analog point, where the analog rate-gyro signal is digitized. But TruTrak is your best bet for assistance. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: 'Light' IFR???
I sort of agree with your definition, but would add that for it to be light IFR, there shouldn't be any real chance of convective vertical cloud development, nor any real chance of ice.. Also, I would say that light IFR implies that you won't have to be on the needles for a whole flight. Before departing into a layer, I'd want recent tops reports with clear sunshine above. I think it rare to be able to call night IFR ops as ever being 'light'. A possible scenario would be the aforementioned flight to or from a coastal California location - you'd better know that it's clear and starry on top, and clear and starry at the desert airports to the east. Matt- > > > Light IFR: defined in the Midwest as being on top of or below an > overcast cloud layer with AWOS/ASOS info that tells them on the other > side of the layer there are VFR conditions -- with adequate ceiling > near the ground, or above a certain level where the overcast top is. > Light IFR pilots have not filed IFR or may not be IFR qualified or > legally equipped for IFR, but they go on the instruments long enough to > fly up or down through the clouds to the other side expecting better > conditions. > ________________________________________________________________________________
Date: Jan 16, 2006
From: "Mark R. Supinski" <mark.supinski(at)gmail.com>
Subject: circuit simplification help needed
Hello all- I'd like to 'simplify' the circuit shown in the following image: http://supinski.net:8080/injectors.jpg As you can see in the image, the circuit calls for 2 DPST switches. What I'd like to do, is implement this using only a single switch such that it ends up being (Primary only) - (Both) - (Secondary Only). Can anyone tell me how to do this? Note that when in either the (Primary only) position or the (Secondary Only) position, the cold-start terminal must be grounded. I think this can be accomplished using the 4TL1-10 microswitch Bob calls out in the wigwag article. However this part is now horrendously expensive ($69) and tough to find -- I am reluctant to buy it since I don't know if it can fit in the same spot as on of the more common switches found in AEC. Obviously a solution using a more "common" switch from B and C would be preferred... Thanks very much for any help! Mark Supinski ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: IFR GPS Display
Kevin Horton wrote: > > I'll leave the question as to whether AC 20-138A is regulatory or not > to those who know the US regs better than I. > > But, just because something may be legal doesn't mean it is a good > idea. If your installation does not match up against AC 20-138A, > then I strongly recommend you should not fly IMC based on the GPS, on > approach, or lower than 1000 ft above any obstacles in the enroute > and terminal phases of flight. I find this discussion interesting and far more complex than it needs to be. How many people have sat in their cockpit and moved across the panel pointing to each device and asking the question, "what if this failed and I am IFR?" This is a very simple procedure and it will go a long way toward figuring out whether you need to attach the specified device to the e-bus or to add a redundant unit. For instance, I can think of only one engine instrument I need to safely complete a flight -- CHT, and that only if the aircraft has cowl flaps. I can guess a MAP and RPM by sound and aircraft performance. If the engine is running then oil-P and oil-T are OK. To me, engine instruments are not critical to safe completion of a flight. And I don't need an airspeed indicator. If I know my airplane then I know that a certain power setting, MAP and RPM, is going to give me known performance. I do need an altimeter -- but only for IFR flight. If you can't get into the pattern and safely land the airplane without an altimeter, you need to go back to school. But if you have a transponder with an altitude display you have your backup altimeter for IFR flight, at least insofar as flying an ILS is concerned. (Intercept the glideslope at approximately the proper altitude and then fly the GS to the middle-marker and miss if you can't see the runway environment. You don't need an altimeter for that. And I know that some ILS's don't have markers but you get to pick one that does.) If I have a working HI (DG) and a TC or T&SI, I can probably survive loss of my AI while on instruments. I cannot survive loss of all three. That means if I have something like one of the current crop of PFDs, I need some sort of backup. And I would want my backup to be different as I wouldn't want a common failure mode. That means that if I have a BMA EFIS-1 I will probably opt for a 3-pack (ASI, alt, and AI) or a Dynon rather than an EFIS-light. Why? Well, I bet that the EFIS-1 and EFIS-light share common AHRS and software technology. That which causes one to fail might take out the other as well. I would probably backup a BMA unit with a GRT or a Dynon just so there is less commonality. But it is pretty hard to beat a 3-pack for simplicity. But if I had my 3-pack and an SL-30, I could afford to lose my whole EFIS-1. I can use the built-in CDI display on the SL-30 to fly a VOR or LOC approach. If I lose my SL-30 I can fly a VOR or NDB approach using the GPS. It may be non-certified but it will get me safely on the ground and with probably more accuracy than the VOR or ADF receiver would. And if all else fails, fly the 3-pack and holler on your handheld for a PAR at the nearest military airfield. This isn't rocket science; this is common sense. You don't need an engineering degree to sit in front of your panel (or in front of the picture of your panel) to do this. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Subject: "Light" IFR???
Date: Jan 16, 2006
Light IFR is the flying done on a computer flight simulator. IFR is not light. John Cox > > > On 1/15/06, Richard Riley wrote: >> >> >> >> At 08:24 AM 1/15/06, you wrote: >> >> > >> >The concept of "light IFR" should be put to rest once and for all. >> > >> >Once you fly into the clouds, the distinction of light or heavy IFR >> >is GONE! IMC is IMC! (Let's not even consider ice and/or >> >thunderstorms for this discussion.) >> > > > ________________________________________________________________________________
Date: Jan 16, 2006
Subject: PC680 battery
Group: I purchased a new PC680 battery a year ago with the intent of replacing the year old (now 2 year old) PC680 in my RV7A. Well, I didn't. I had mounted the ground lug that goes through the firewall too low and it was going to be in the way to replace the battery without moving the lug. Long story shorter, I've pulled my engine and sent back to Aero Sport to get the crankshaft replaced in compliance with SB566. I intend to now replace the battery (and move the ground lug higher). The question, should I use the new battery that has been sitting on the shelf in the hanger for over a year without any attention or do I need to buy another "fresh" one? Is there anything I should check? Thanks, Doug -7A 260hrs ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: D25 Diode voltage variance ??
Date: Jan 16, 2006
Anyone? Wiring per Z13 with Main Bus and E-Bus. I have the D25 diode installed between them per diagrams. Just for fun, I was checking voltage at the Main Bus which was 12.3 but on the E-Bus (one D25 and 6 inches of 14ga away), it was down to 11.7 volts for a loss of .6 volts. This seemed like a lot of voltage loss so I tried another D25 and it read an even 12.0 volts for a loss of .3. Now I'm wondering if either of these is normal and if so what is acceptable loss between the buses? Thanks Bill S 7a Ark ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: D25 Diode voltage variance ??
Bill Schlatterer wrote: > > >Anyone? Wiring per Z13 with Main Bus and E-Bus. I have the D25 diode >installed between them per diagrams. Just for fun, I was checking voltage >at the Main Bus which was 12.3 but on the E-Bus (one D25 and 6 inches of >14ga away), it was down to 11.7 volts for a loss of .6 volts. This seemed >like a lot of voltage loss so I tried another D25 and it read an even 12.0 >volts for a loss of .3. > >Now I'm wondering if either of these is normal and if so what is acceptable >loss between the buses? > >Thanks Bill S >7a Ark > Normal voltage drop across a forward biased silicon diode is ~.6 volts. ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: PC680 battery
http://www.aeroelectric.com/articles/battest.pdf Dave Morris At 08:26 PM 1/16/2006, you wrote: > >Group: > I purchased a new PC680 battery a year ago with the >intent of replacing the year old (now 2 year old) >PC680 in my RV7A. Well, I didn't. I had mounted the >ground lug that goes through the firewall too low and >it was going to be in the way to replace the battery >without moving the lug. > >Long story shorter, I've pulled my engine and sent >back to Aero Sport to get the crankshaft replaced in >compliance with SB566. I intend to now replace the >battery (and move the ground lug higher). > >The question, should I use the new battery that has >been sitting on the shelf in the hanger for over a >year without any attention or do I need to buy another >"fresh" one? > >Is there anything I should check? > >Thanks, >Doug -7A 260hrs > > ________________________________________________________________________________
Date: Jan 16, 2006
In a message dated 1/16/2006 7:00:07 P.M. Central Standard Time, PLaurence@the-beach.net writes: Is there such a thing as a vacuum T/C? Sorry, I forgot to answer this. There has been. Brittain had one that they also used as the sensor for their low cost autopilot. I do not recall seeing one that was not associated with an autopilot or wing leveler. Doesn't mean there isn't one though! Happy Skies, Old Bob Do Not Archive ________________________________________________________________________________
Date: Jan 16, 2006
Cc: While the voltage drop across vs. current through a diode is not linear, certain places within the "I-V" curve are nearly so... http://en.wikipedia.org/wiki/Image:Rectifier_vi_curve.GIF - In this application, we are forward biased. When you say that you measured the voltage drop across each diode, I assume you were checking this while it was installed in the circuit, and while the diode was conducting current.. Roughly, was the current through the diode the same in each case (same number of items connected to the e-bus)? To answer your question, 0.3V sounds a little low for a regular Si rectifier, while 0.6V sounds pretty typical (actually, still a little low). I would guess that the diode which showed a 0.3V drop wasn't carrying much (any) current at the time of the test. Regards, Matt- > > > > Anyone? Wiring per Z13 with Main Bus and E-Bus. I have the D25 diode > installed between them per diagrams. Just for fun, I was checking > voltage at the Main Bus which was 12.3 but on the E-Bus (one D25 and 6 > inches of 14ga away), it was down to 11.7 volts for a loss of .6 volts. > This seemed like a lot of voltage loss so I tried another D25 and it > read an even 12.0 volts for a loss of .3. > > Now I'm wondering if either of these is normal and if so what is > acceptable loss between the buses? > > Thanks Bill S > 7a Ark > > ________________________________________________________________________________
Date: Jan 16, 2006
The 0.6V is normal. Remember when the diode is in the circuit, you're running on alternator with something higher than 12.3V, so even with the voltage drop, it will be within tolerable limits. When the alternator is offline and you need maximum voltage, you are powering the E-bus through the switch, not through the diode, so there will be no voltage drop. Dave Morris At 08:45 PM 1/16/2006, you wrote: > > > >Anyone? Wiring per Z13 with Main Bus and E-Bus. I have the D25 diode >installed between them per diagrams. Just for fun, I was checking voltage >at the Main Bus which was 12.3 but on the E-Bus (one D25 and 6 inches of >14ga away), it was down to 11.7 volts for a loss of .6 volts. This seemed >like a lot of voltage loss so I tried another D25 and it read an even 12.0 >volts for a loss of .3. > >Now I'm wondering if either of these is normal and if so what is acceptable >loss between the buses? > >Thanks Bill S >7a Ark > > ________________________________________________________________________________
Date: Jan 16, 2006
Doug, The website on odyssey batteries state that if it was fully charged when stored it has a shelf life of two years. See note off their website below: Guaranteed longer service life - The ODYSSEY battery, with a ten year design life and a three-to-eight year service life, saves you time and money because you do not have to replace your battery as often. It is also the ONLY battery that is capable of delivering a large number of deep cycles - up to 400 when fully discharged or up to 500 when discharged to 80%. Plus, the battery is specially designed for high vibration applications. Longer storage life - Unlike conventional batteries that need to be recharged every six to twelve weeks, the ODYSSEY battery, when fully charged , can be stored for up to 2 years at room temperature (25C, 77F). At lower temperatures, storage times will be even longer. Ed A ----- Original Message ----- From: "D. Jones" <dljinia(at)yahoo.com> Sent: Monday, January 16, 2006 9:26 PM Subject: AeroElectric-List: PC680 battery > > Group: > I purchased a new PC680 battery a year ago with the > intent of replacing the year old (now 2 year old) > PC680 in my RV7A. Well, I didn't. I had mounted the > ground lug that goes through the firewall too low and > it was going to be in the way to replace the battery > without moving the lug. > > Long story shorter, I've pulled my engine and sent > back to Aero Sport to get the crankshaft replaced in > compliance with SB566. I intend to now replace the > battery (and move the ground lug higher). > > The question, should I use the new battery that has > been sitting on the shelf in the hanger for over a > year without any attention or do I need to buy another > "fresh" one? > > Is there anything I should check? > > Thanks, > Doug -7A 260hrs > > ________________________________________________________________________________
Date: Jan 16, 2006
Thanks for the reply! Seemed like a lot but I guess this isn't really important because in normal ops, the active system keeps it up and in a low voltage situation, the Main and D25 are out of action anyway and the E-Bus circuit gets remaining battery power to the E-Bus with little or no loss. Thanks Bill S -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Monday, January 16, 2006 8:53 PM Subject: Re: AeroElectric-List: D25 Diode voltage variance ?? --> Bill Schlatterer wrote: >--> > > >Anyone? Wiring per Z13 with Main Bus and E-Bus. I have the D25 diode >installed between them per diagrams. Just for fun, I was checking >voltage at the Main Bus which was 12.3 but on the E-Bus (one D25 and 6 >inches of 14ga away), it was down to 11.7 volts for a loss of .6 volts. >This seemed like a lot of voltage loss so I tried another D25 and it >read an even 12.0 volts for a loss of .3. > >Now I'm wondering if either of these is normal and if so what is >acceptable loss between the buses? > >Thanks Bill S >7a Ark > Normal voltage drop across a forward biased silicon diode is ~.6 volts. ________________________________________________________________________________
Date: Jan 16, 2006
Bob, the Brittain TC-100 you are refering to is both vacuum and electric powered, and will continue to function as long as either power source is present. I have one in my Mooney. As for recovering from a spin, while prepping for my instrument ride 26 years ago my CFI put me in an unusual attitude under the hood, and gave me the plane. The AH and DG were tumbled, so I knew I had to level the wings with the TC, and control the airspeed. Only afterwards, did I find out he put me in a spin...which I had never done at that point. Much easier recovery if you don't see the spinning earth out the window. BobsV35B(at)aol.com wrote: > > > In a message dated 1/16/2006 7:00:07 P.M. Central Standard Time, > PLaurence@the-beach.net writes: > > Is there such a thing as a vacuum T/C? > > > > Sorry, I forgot to answer this. > > There has been. > > Brittain had one that they also used as the sensor for their low cost > autopilot. I do not recall seeing one that was not associated with an autopilot or > wing leveler. Doesn't mean there isn't one though! > > Happy Skies, > > Old Bob > > Do Not Archive > > > > > > > > > > > > > ________________________________________________________________________________
From: "richard titsworth" <rtitsworth(at)mindspring.com>
Date: Jan 16, 2006
> -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of LarryRobertHelming > Sent: Monday, January 16, 2006 7:11 PM > Subject: Re: AeroElectric-List: "Light" IFR??? > Light IFR: defined in the Midwest as being on top of or below an overcast > cloud layer with AWOS/ASOS info that tells them on the other side of the > layer there are VFR conditions -- with adequate ceiling near the ground, > or above a certain level where the overcast top is. Light IFR pilots have > not filed IFR or may not be IFR qualified or legally equipped for IFR, but > they go on the instruments long enough to fly up or down through the > clouds to the other side expecting better conditions. Larry, I've noted several SERIOUS concerns with the above statements (see below). In fact, the statements seem to indicate a significant lack of understanding of FARs, safety, and risk mgt. The statements above are not boarder-line interpretation issues nor sensible risk management approaches, these are serious errors/omissions in required knowledge/experience. If the rest of your aviation knowledge/understanding is of similar depth/inaccuracy, then I feel you're likely well below the level of proficiency the most pilots expect of each other. Please note, I've taken the time to reply in an objective/constructive manner (not abusive/flippant) in the hope that you seriously seek further education/training. If you don't like my opinion, might I suggest that you get a few more from others and take them to heart (don't shoot the messengers). Additionally, while these comments may seem a bit off point for this list, the underlying theme is to think twice before short-cutting an IFR panel. Short cut your paint, interior, etc if need be, or short-cut your oil changes, bald tires, prop balancing, old mags, TBO, whatever, if that's how you value your safety/life. But when it comes to IFR equipment - you're extending your risk decisions to the rest of us. It's not just separation, even an unnecessary missed approach can stress the IFR system when others may be in an IFR hold somewhere with minimal fuel waiting for you. IFR is not only about us individually, its about the entire collective system. My concerns/feedback with comments above. If your point was that having the best available weather helps lower some of the risks associated with IFR flight, I certainly agree. However... 1. I've never heard an AWOS/ASOS that will tell you what's on the top of an overcast. They don't (someone please correct me if some do). 2. AWOS/ASOS = "automatic", means not checked/verified. Prone to all kinds of errors. Usually directional correct information, but not something you can bank on. One of the reasons instrument approaches have missed procedures is because actual conditions are not always the same as reports, especially AWOS/ASOS. 3. Good/accurate information on tops is often hard to come by. Best (only) source is often pilot reports (or ATC chatter). It's not always available nor current, nor accurate. Furthermore tops (and intermediate layers) often change, due to heating through the day, fronts, terrain, etc. If your point was that being VFR (VMC) above an overcast layer with some knowledge/expectation of high ceilings below (and a VFR descent opportunity before your expected destination) is better than being in the same with no knowledge of conditions below, I agree. Being "above a layer" in VMC without IFR capability is also legal. However... 4. Being "above a layer" without IFR capability (pilot and/or aircraft) even with knowledge of conditions below its a false sense of security at best. If you're lucky, the ceiling below is 1,000ft+ above all obstacles/terrain (well above 1000ft AGL). If not, an engine out, alt out, etc carries the very real risk of a blind approach/landing (a serious crash) - typically fatal. Worse case: fire, total power loss, radio/txpnd out, etc, = no ATC assistance = you're playing roulette (with bad odds). No good scenario results in flight in IMC (on the needles) without being certified and on an active IFR plan/clearance... 5. Flying through any IMC (clouds, etc), at any time, without being IFR certified and current (pilot and aircraft) is illegal. 6. VFR flight into IMC is one of the top causes of fatal accidents. It has been for decades (nothing new here - same issues/fatalities every year). I'm guessing the pilots who tried and died, were all relatively confident they could do it (wrong, they died). While I'm sure there are some (many?) who have made it and lived, thinking (guessing) you can do it does not correlate with success. A few hours under the hood (on the needles) during private pilot training and/or with friends might be marginally helpful, but is also not correlated with success. Those who've died have proved it. Training, testing, certification, and currency have proven much better indicators of success. I suggest you ascribe to them and suggest any/all your friends do the same. 7. Flying through any IMC (clouds, etc) in controlled airspace (Class E and above - virtually all airspace east of the Rockies above 1500 AGL) without an active IFR flight plan and clearance is illegal. 8. If you're in IMC without ATC positive control (and active IFR flight plan and clearance), what's to keep you from running into other aircraft? The big sky theory is a risk that other IFR pilots (and commercial passengers) choose not to bank on. Perhaps you're a risk taker/gambler with your life. Most of us aren't. Anyone in IMC and not on an IFR clearance is putting many other at needless risk - it's very, very, very selfish. (I'm being kind!). If you find yourself thinking you can survive IMC without training and/or ATC clearance/control, the safest thing for the rest of us, is for you to roll it over, point it straight down, and expedite your destiny. This minimizes the risk you extend to otherwise innocent folks working together to keep everyone safe. 9. Additionally, if you're in IMC without a clearance and you run into someone, everyone's dead and you're clearly at fault, their family/dependents will likely sue your family/estate for more than you have - regardless of how much you have. Flight and life insurance is not likely to even come close to the costs/suits and will never cover the hardships. Quite a legacy you leave for others. Other constructive comments. ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: circuit simplification help needed
It seems to me that you could use a 2 pole 3 position rotary switch to do this. The attached file is a terrible drawing, but it's the best I could do at home. I found some switches made by ITT, C&K M series that are 6 amps continous, 28 VDC. Hope this helps, been out of doing this for a while. Loose the design edge quick when only doing tech support. You have my disclaimer... I'm not a builder or a pilot. I hope to start lessons in the spring and build in the fall. Ric --- "Mark R. Supinski" wrote: > Supinski" > > Hello all- > > I'd like to 'simplify' the circuit shown in the > following image: > > http://supinski.net:8080/injectors.jpg > ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Re: "Light" IFR???
John W. Cox wrote: > > IFR is not light. There are different levels of difficulty in flying IFR. The skill level to penetrate a cloud layer and then break out 1000' above the ground with 2-3 mi visibility is not the same as flying in known ice, turbulence, avoiding embedded CBs, and then shooting a tricky approach breaking out at minimums. The former will permit a greater degree of inaccuracy without endangering the aircraft or passengers. I know that, depending on how I am feeling and my recent practice, I will change my go/no-go decision point. I will accept "light" IFR when I might not be willing to launch into something heavier. We can be pedantic if we choose to but the bottom line is that there are degrees of IFR difficulty. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
BobsV35B(at)aol.com wrote: > The T&B has one or two less fulcrums to fail, but both are about as simple, > light and reliable as an instrument can be. The internal construction of the TC and the T&SI (T&B) are the same. The only difference is that the axis of the gyro in the TC is canted so that the gyro responds to both yaw and roll rather than yaw only as in the T&SI. > I have mentioned this often, but I will repeat, I have two T&Bs in my > airplane, one is vacuum powered. The other is driven by electricity. I believe > that is overkill, but they are so cheap, I do it anyway! Why don't you put in a second AI? Seems to me that would serve you better than a second T&SI. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
Subject: Prescott AZ 2006 Seminar date set
Plans and dates have been finalized for an AeroElectric Connection seminar in Prescott, AZ on May 20/21, 2006. Details at: http://aeroelectric.com/seminars/Prescott.html Bob . . . ________________________________________________________________________________
Date: Jan 16, 2006
Brinker wrote: > > The GRT will also display the HSI from the SL30. And will tune the > SL30 from the MFD. Not to mention ILS and Localizer And will display your > engine monitor to either display you choose. Not sure how you get 6k for > engine monitoring. Last I checked a 6cyl was around $1100 with EIS and > probes. I didn't think that was with the full graphical engine display. > GRT is very helpful if there is a way to make it work they will try. > I have a KLN90B gps that Todd is trying figure out if it will work with > they're system now. It looks favorable, I am keeping my fingures and toes > crossed. The GRT should respond to ARINC-429 messages. If it does, it should be compatible with any nav system that outputs ARINC-429 nav info, e.g. CDI, VDI, flags, etc. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
Subject: EFIS Comparisons)
BobsV35B(at)aol.com wrote: > The reference to "full" ILS was meant to include a glide slope. There is no > way that I am aware of to see the glide slope on the 430 control unit face. > Consequently a CDI is needed. While I am not very familiar with how the 430 > works, I also believe you will need a resolver to input VOR radials for the > VHF navigation portion of the 430. Most Nav radios that have built-in VOR/LOC converters output signals intended to drive meter movements. There is even an ARINC standard for these types of signal. (I forget the ARINC number for these analog meter movement signals.) There are a lot of older ILS display heads that have the deviation indicators (CDI/VDI), the flags, and an OBS resolver. I have been able to pick these up for next to nothing. (I got one free for the asking at an old shop once.) This type of display may be used with your GPS or nav with a built-in VOR/LOC converter. No need to buy a brand-new expensive unit. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
Bruce Gray wrote: > Chelton) remains untested to the extent necessary to pass DO 178, their > hardware is not DO 160 certified. That means you're the beta tester. Do you > want to bet your life in that situation? Mark my words, we're going to have > some experimental airplanes equipped with low cost EFIS systems get into > some serious fatal trouble. That body count is going to raise the level of > visibility of this issue with the FAA and soon big brother will be breathing > down our necks. > > Low cost, noncertified EFIS system are OK for VFR airplanes. But stay out of > IFR conditions. Bruce, there are a lot of airplanes flying IFR with the gyros powered by a dry vacuum pump and you are worried about how dangerous the current crop of non-certified PFDs are? Instrument-rated pilots are supposed to be able to cross check their gyros and reject those that do not agree. That is part of the standard skill set. When things go wrong and you start to chase a dying AI, you know it. *EVERYTHING* feels wrong and your airspeed and altitude start to move. You *KNOW* you have a problem. It will pretty quickly become apparent which instrument(s) are providing you with valid information. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 16, 2006
BobsV35B(at)aol.com wrote: > I hope you are correct, but I have heard rumors that the current crop of > solid state accelerometer based rate sensors do not do well during violent > maneuvering. Supposedly, that is one of the reasons there have been so few > approved for certified use. It is my feeling that I would sooner have a tried and > true instrument like the T&B for my last ditch backup. All of the solid state rate gyros and accelerometers have maximum rates. For the rate gyros they are in degrees per second and for the accelerometers they are in Gs. If the AHRS has 160 degree/sec rate gyros then it is going to lose track if you roll the airplane too fast. (It won't really tumble but it won't indicate a roll as fast as you are actually achieving.) You can get devices that support higher rates at the expense of lower resolution and accuracy. Most aircraft do not have pitch, yaw, or roll rates great enough to reach the limits. OTOH, some OBAM aircraft do and that should be a consideration when selecting a PFD/AHRS. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
On 16 Jan 2006, at 20:49, Brian Lloyd wrote: > yak(at)lloyd.com> > > Kevin Horton wrote: >> >> >> I'll leave the question as to whether AC 20-138A is regulatory or not >> to those who know the US regs better than I. >> >> But, just because something may be legal doesn't mean it is a good >> idea. If your installation does not match up against AC 20-138A, >> then I strongly recommend you should not fly IMC based on the GPS, on >> approach, or lower than 1000 ft above any obstacles in the enroute >> and terminal phases of flight. > > I find this discussion interesting and far more complex than it > needs to > be. > > How many people have sat in their cockpit and moved across the panel > pointing to each device and asking the question, "what if this failed > and I am IFR?" This is a very simple procedure and it will go a > long way > toward figuring out whether you need to attach the specified device to > the e-bus or to add a redundant unit. I agree with all you wrote, but there is one more thing to consider too. Anyone considering using a non-TSO'd GPS receiver for IFR flight needs to also ask the question "what if the GPS receiver provided false position information and I was flying IFR?". TSO C129 units have functions that look for bad satellite data, and either exclude it, or stop providing position info. Non-TSO C129 units almost certain don't have this function, and they will quite happily use bad satellite data to calculate a bad position. If the position error is large, you will probably notice it. But, I am aware of one occurrence that happened to a co-worker. They were flying a practice GPS approach in VMC conditions. The GPS receiver gave a RAIM warning prior to the FAF, and refused to go into approach mode. They continued the approach, curious to see what the GPS was going to do. It ended up bringing them in on a path over 1 mile offset from the correct approach path. That could put you into the rocks or obstacles in some places. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 17, 2006
> > >http://www.aeroelectric.com/articles/battest.pdf The battery test suggested in the above article is a COMPARATIVE test intended to measure degradation of your used battery as compared with new. It's not designed for nor capable of offering measured values of capacity. What is/was your stored battery's terminal voltage before you put it on a charger? If above 12.5 volts, it probably possesses near new capacity. But the only way to know for sure is to test it with reasonably calibrated equipment. I'd do a cranking test with an instrument commonly found in service stations. See http://www.aeroelectric.com/Pictures/Tools/HF91129_4.jpg for a low cost offering by Harbor Freight. Put a load on the battery for pulls the voltage down to 9 volts for 15 seconds. Observe current delivered at the end of 15 seconds. It should be 300A or better. Recharge the battery and do a capacity test using some tool like: http://westmountainradio.com/CBA_ham.htm I've purchased several of these for use in various jobs and I keep one on the shelf in my shop. If you don't want to invest in such tools, AND the battery meets the cranking test at your local battery service shop, then go ahead and install it. On some nice VFR clear day, drop to battery-only operations and see how long the battery will run your endurance loads without dropping below 11 volts. Be aware that advertised service life numbers for batteries are a mixture of lab tests extrapolated to the real world conditions and/or wishful marketing hype. The real service life of a battery is strongly influenced by your battery's real-world experiences and the phase of the moon when the battery was built (just kidding . . . slightly. Building batteries is like baking cakes. The cook can have a bad day in the most prestigious of battery factories. Hawker went through a protracted bout of low quality jelly-roll cells a couple of years ago). Marketing literature is not a substitute for directly measuring a battery's performance capabilities. Bob . . . >Dave Morris > >At 08:26 PM 1/16/2006, you wrote: > > > >Group: > > I purchased a new PC680 battery a year ago with the > >intent of replacing the year old (now 2 year old) > >PC680 in my RV7A. Well, I didn't. I had mounted the > >ground lug that goes through the firewall too low and > >it was going to be in the way to replace the battery > >without moving the lug. > > > >Long story shorter, I've pulled my engine and sent > >back to Aero Sport to get the crankshaft replaced in > >compliance with SB566. I intend to now replace the > >battery (and move the ground lug higher). > > > >The question, should I use the new battery that has > >been sitting on the shelf in the hanger for over a > >year without any attention or do I need to buy another > >"fresh" one? > > > >Is there anything I should check? > > > >Thanks, > >Doug -7A 260hrs ________________________________________________________________________________
Subject: IFR GPS Display
Date: Jan 17, 2006
Question, how do you know it doesn't match up? Think about your answer. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Monday, January 16, 2006 3:42 AM Subject: Re: AeroElectric-List: IFR GPS Display I'll leave the question as to whether AC 20-138A is regulatory or not to those who know the US regs better than I. But, just because something may be legal doesn't mean it is a good idea. If your installation does not match up against AC 20-138A, then I strongly recommend you should not fly IMC based on the GPS, on approach, or lower than 1000 ft above any obstacles in the enroute and terminal phases of flight. Kevin Horton On 15 Jan 2006, at 23:35, Mike wrote: > > AC 20-138A is not regulatory for experimental aircraft unless You > incorporated this into your limitations. > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Bruce > McGregor > Sent: Sunday, January 15, 2006 11:05 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: IFR GPS Display > > > > AC 20-138A, Airworthiness Approval Of Global Navigation Satellite > System > Equipment, sets the requirements for IFR GPS units. Para 18d , > Navigation > Display,. requires that the horizontal and vertical deviation > display(s) > and > failure annunciation be within the pilot's primary field of view. > Primary > field is defined as within 15 degrees of straight ahead of the pilot. > Other > displays may be anywhere from the airspeed indicator on the left in a > standard six pack to and including an avionics center stack on the > right. > > One method of compliance is to place an IFR GPS receiver that displays > CDI/VDI, such as the GNS 480, within the primary field of view and > eliminate > the requirement for an external display. The geometry of my GlaStar > gives a > 12" wide zone in the panel for the GPS' display. Placing a Dynon > or GRT > PFD > above or below the GPS would result in a lot of flight/navigation info > directly > in front of the pilot. > > Regards, Bruce McGregor -- 1/16/2006 -- 1/16/2006 ________________________________________________________________________________
Date: Jan 17, 2006
Subject: Re: Battery strength
> >Hello all, >as I am new on this list - this is my first try to get some needed >information. >So what I have is a 24 Volt system with a 12 Volt starter on an O360 F1A6. >I was told that it should not be a problem to use the 12 Volt starter with >24 Volt as the voltage will drop anyhow to about 18 Volt and the starting >process itself will not take more than 20 seconds which the starter should >be capable to handle. If it's a permanent magnet starter, it's probably not a good idea. The earliest automotive derivatives were series wound and fairly tolerant of short duration overloads . . . it will certainly crank the engine faster thus reducing total abuse time of the starter. What are your options? Take the starter off and replace it with an newer, lighter machine or run the existing starter 'til it croaks. Who knows, you may get considerable service life from the existing starter and the risks are low. >- what is the opinion of the group on this ? >- The second issue is that I need a figure of the battery strength (Ah) >which is needed to start my engine. I know that this is depending on many >issues and this should not be the only consideration for the strength but >there must be a general idea of whether 17 Ah should do the job easily or >should one go for 24 Ah or 7 Ah. Battery size is driven more by what your no-alternator endurance goals are. Have you conducted a load analysis for alternator-out operations and selected a minimum endurance time? See Chapter 17 of the 'Connection. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2006
Subject: Re: EFIS Comparisons
Good Morning Brian, You ask: "Why don't you put in a second AI? Seems to me that would serve you better than a second T&SI." Many reasons. I would need to repeat long treatises on why I prefer the T&B over the TC along with thoughts on how MY mind works. What works for me may not work for others. On top of that, the T&B is lighter, cheaper and, in my opinion, more reliable. Incidentally, I have never disassembled either a T&B or a TC, but my local instrument guru tells me that the TC has one more fulcrum point to transfer the data from the canted gyro to the instrument face. Thus a slightly higher parts count and an ever so slightly higher chance of failure. There is no doubt that, with proper training, either a TC or a T&B can be used successfully for partial panel flight and as a device for recovery from an unusual attitude. On top of that, neither instrument will tumble as will some attitude gyros. My love for the T&B is based on it being so much different in appearance from the TC or attitude gyro and the fact that it will show only yaw where the TC shows both roll and yaw. Happy Skies, Old Bob -----Original Message----- From: Brian Lloyd <brian-yak(at)lloyd.com> Subject: Re: AeroElectric-List: EFIS Comparisons BobsV35B(at)aol.com wrote: > The T&B has one or two less fulcrums to fail, but both are about as simple, > light and reliable as an instrument can be. The internal construction of the TC and the T&SI (T&B) are the same. The only difference is that the axis of the gyro in the TC is canted so that the gyro responds to both yaw and roll rather than yaw only as in the T&SI. > I have mentioned this often, but I will repeat, I have two T&Bs in my > airplane, one is vacuum powered. The other is driven by electricity. I believe > that is overkill, but they are so cheap, I do it anyway! Why don't you put in a second AI? Seems to me that would serve you better than a second T&SI. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
$1100 is for the EIS only for a 6cyl but I plan to install a dual EFIS which interfaces to the EIS I think if you wanted a dedicated graphic display it would be a little over $3000 ----- Original Message ----- From: "Brian Lloyd" <brian-yak(at)lloyd.com> Sent: Monday, January 16, 2006 10:54 PM Subject: Re: AeroElectric-List: EFIS Comparisons > > > Brinker wrote: >> <brinker@cox-internet.com> >> >> The GRT will also display the HSI from the SL30. And will tune the >> SL30 from the MFD. Not to mention ILS and Localizer And will display >> your >> engine monitor to either display you choose. Not sure how you get 6k for >> engine monitoring. Last I checked a 6cyl was around $1100 with EIS and >> probes. > > I didn't think that was with the full graphical engine display. > >> GRT is very helpful if there is a way to make it work they will try. >> I have a KLN90B gps that Todd is trying figure out if it will work with >> they're system now. It looks favorable, I am keeping my fingures and toes >> crossed. > > The GRT should respond to ARINC-429 messages. If it does, it should be > compatible with any nav system that outputs ARINC-429 nav info, e.g. > CDI, VDI, flags, etc. > > -- > Brian Lloyd 2243 Cattle Dr. > brian-yak at lloyd dot com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > I fly because it releases my mind from the tyranny of petty things . . . > - Antoine de Saint-Exupery > > > ________________________________________________________________________________
Date: Jan 17, 2006
....be sure to review and compare the JPI engine monitor if you have not made a decision yet. D ----- Original Message ----- From: "Brinker" <brinker@cox-internet.com> Sent: Tuesday, January 17, 2006 8:42 AM Subject: Re: AeroElectric-List: EFIS Comparisons > <brinker@cox-internet.com> > > $1100 is for the EIS only for a 6cyl but I plan to install a dual EFIS > which interfaces to the EIS > I think if you wanted a dedicated graphic display it would be a > little over $3000 > > > ----- Original Message ----- > From: "Brian Lloyd" <brian-yak(at)lloyd.com> > To: > Sent: Monday, January 16, 2006 10:54 PM > Subject: Re: AeroElectric-List: EFIS Comparisons > > >> >> >> >> >> Brinker wrote: >>> <brinker@cox-internet.com> >>> >>> The GRT will also display the HSI from the SL30. And will tune the >>> SL30 from the MFD. Not to mention ILS and Localizer And will display >>> your >>> engine monitor to either display you choose. Not sure how you get 6k for >>> engine monitoring. Last I checked a 6cyl was around $1100 with EIS and >>> probes. >> >> I didn't think that was with the full graphical engine display. >> >>> GRT is very helpful if there is a way to make it work they will try. >>> I have a KLN90B gps that Todd is trying figure out if it will work with >>> they're system now. It looks favorable, I am keeping my fingures and >>> toes >>> crossed. >> >> The GRT should respond to ARINC-429 messages. If it does, it should be >> compatible with any nav system that outputs ARINC-429 nav info, e.g. >> CDI, VDI, flags, etc. >> >> -- >> Brian Lloyd 2243 Cattle Dr. >> brian-yak at lloyd dot com Folsom, CA 95630 >> +1.916.367.2131 (voice) +1.270.912.0788 (fax) >> >> I fly because it releases my mind from the tyranny of petty things . . . >> - Antoine de Saint-Exupery >> >> >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jan 17, 2006
Good Morning Ric, Welcome aboard! Stick with it and keep us advised as to how things are going. Just remember that flying is fun. If your first instructor does not make it fun, shop around until you find one that does. Getting good flight instruction is not easy these days, but it can be done! Enjoy. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Downers Grove, Illinois 630 985-8502 -----Original Message----- From: richard cannella <ric52md(at)yahoo.com> Subject: Re: AeroElectric-List: circuit simplification help needed It seems to me that you could use a 2 pole 3 position rotary switch to do this. The attached file is a terrible drawing, but it's the best I could do at home. I found some switches made by ITT, C&K M series that are 6 amps continous, 28 VDC. Hope this helps, been out of doing this for a while. Loose the design edge quick when only doing tech support. You have my disclaimer... I'm not a builder or a pilot. I hope to start lessons in the spring and build in the fall. Ric --- "Mark R. Supinski" wrote: > Supinski" > > Hello all- > > I'd like to 'simplify' the circuit shown in the > following image: > > http://supinski.net:8080/injectors.jpg > ________________________________________________________________________________
Date: Jan 17, 2006
Comment below.. > > Bob, > snip > > As far as meeting the requirement of being able to fly a T&B, most IFR > pilots could do this when licensed but never practice this task again. > You tell me how good you would be 10 years down the road without > spending more then the 5 minutes or so work with the T&B on your BFR in > great weather. Unless youre the one pilot in general aviation that does > go out every 90 days and maintains proficiency at this task. I think > your hiding behind the lack of data showing that pilots do not practice > what they do not like or are not very good at. I'm just being realistic > about the data I have collected about real world proficiency. > > Mike > Given the chances that you will have a vacuum pump failure, I propose that it's good policy to perform the majority of your proficiency work with the AI covered. And, fly more than one "no gyro" approach each time you go out (DG and AI covered). They aren't really that hard. In fact, when you ask for that from ATC, they are generally very accomodating (in a radar environment anyway). They give you the "start turn, stop turn instructions" and the only hard part is intercepting the final approach course. It helps if you practice keeping the ball centered in all maneuvers. And I don't think flying the "no gyro" procedure reduces your effectiveness at full-panel ops. I suppose the hardest thing partial panel is doing a precise holding pattern without the DG - especially on a windy/bumpy day. Break out the handheld GPS to give you course information - makes it almost too easy. Matt- ________________________________________________________________________________
Subject: RE: AeroElectric-List Digest: 66 Msgs - 01/16/06
Date: Jan 17, 2006
1) Now that the CAN-Aerospace bus definition has been around a while, will it become an accepted standard? It did achieve some success in the CAPSTONE projects. 2) Has Boeing published their message formats for Ethernet to try to establish a standard? Tony Cann 916-988-4043 From: Brian Lloyd <brian-yak(at)lloyd.com> Subject: Re: EFIS Comparisons Kevin Horton wrote: Go away for a couple of days and you drown in messages. >>If manufacturers did start to make a habit of publicly reproducing >>real >>time magnitudes on a serial output then the step from boxes to system >>would be simple. As a start just add comparison, alarm and display of >>results (have a backup for this too). There is such a standard. It is ARINC-429. (clipped) ________________________________________________________________________________
Date: Jan 17, 2006
Kevin Horton wrote: > I agree with all you wrote, but there is one more thing to consider > too. Anyone considering using a non-TSO'd GPS receiver for IFR > flight needs to also ask the question "what if the GPS receiver > provided false position information and I was flying IFR?". TSO C129 > units have functions that look for bad satellite data, and either > exclude it, or stop providing position info. Which they do wonderfully well as I have discovered. I have had GPS stop working for me on several flights, including one over water flight. Fortunately I had an ADF as a backup. Planning for loss of your primary navigation is part and parcel of flying. Heck, on one of my Atlantic crossings my LORAN packed it in. I planned for this and had a recent LORAN fix to use as a jumping-off point for DR. I had also been checking the winds aloft using the LORAN so I had a good wind set too. I navigated this way until I could get a good ADF bearing and used that as a check until I got in range of a VOR. It happens and it is not the end of the world. > Non-TSO C129 units > almost certain don't have this function, and they will quite happily > use bad satellite data to calculate a bad position. So you are going to bet your life on the RAIM feature of your GPS? You aren't going to cross check? I have had GPS fail just too often to trust GPS as my sole source of navigation, RAIM or no RAIM. In fact, it has happened to me so many times with so many different GPS receivers (which mysteriously get better later all by themselves) that I have stopped flying GPS direct for the most part. I now find that I fly most of my cross-country flights by Victor airway again. I do this because it makes transition back to VOR much, much easier and the cost in terms of time is almost always negligible. It also means that I can cross check my GPS with the VOR/DME/RNAV. I know the GPS is more accurate but I trust VOR/DME more in the long run. So if the VOR/DME and GPS are telling me the same thing, I am happy. If they start telling me different things, I am not happy but I know I have to figure out who is lying. And usually the GPS just goes toes-up with a RAIM error followed by loss of navigation information about 20 seconds later. > If the position > error is large, you will probably notice it. But, I am aware of one > occurrence that happened to a co-worker. They were flying a practice > GPS approach in VMC conditions. The GPS receiver gave a RAIM warning > prior to the FAF, and refused to go into approach mode. They > continued the approach, curious to see what the GPS was going to do. > It ended up bringing them in on a path over 1 mile offset from the > correct approach path. That could put you into the rocks or > obstacles in some places. Sure it will. It breaks like everything else. Actually it breaks more often as the USAF is still "experimenting" with degrading GPS in some areas. Most of the time it gets NOTAM'd but sometimes ... TSO C129 is not a panacea. RAIM helps but it doesn't solve the problem that GPS has a number of interesting failure modes. You cannot count on your GPS to always give you accurate information all the time. You need something else or you need to be VFR so you can fall back on pilotage. > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
bobsv35b(at)aol.com wrote: > > Good Morning Brian, > > You ask: "Why don't you put in a second AI? Seems to me that would serve you > better than a second T&SI." > > Many reasons. > > I would need to repeat long treatises on why I prefer the T&B over the TC along with thoughts on how MY mind works. I do not disagree with you over your choice of T&SI vs. TC. > What works for me may not work for others. > > On top of that, the T&B is lighter, cheaper and, in my opinion, more reliable. That is true. > Incidentally, I have never disassembled either a T&B or a TC, but my local instrument guru tells me that the TC has one more fulcrum point to transfer the data from the canted gyro to the instrument face. Ah, yes. There is a linkage there but it is pretty darned simple. It is not likely to be a source of failure. The motor is a much, much higher probability of failure. > Thus a slightly higher parts count and an ever so slightly higher chance of failure. You are splitting hairs here. > There is no doubt that, with proper training, either a TC or a T&B can be used successfully for partial panel flight and as a device for recovery from an unusual attitude. So can an attitude gyro that is non-tumbling in both pitch and roll. > On top of that, neither instrument will tumble as will some attitude gyros. But in order to be used as a replacement for a T&SI or a TC the AI must be non-tumbling. If it has stops on the gimbals it may not be used to replace the turn instrument. There are a number of non-tumbling AIs out there. Sporty's has a nice one for $1600. It also has an inclinometer (ball). > My love for the T&B is based on it being so much different in appearance from the TC or attitude gyro and the fact that it will show only yaw where the TC shows both roll and yaw. I know. And it is easier to learn to fly partial-panel with a TC as you get feedback as soon as you start to roll the airplane, long before the T&SI starts to show a turn. Still I like that the T&SI is less "twitchy" in turbulence. But if the main AI packs it in it is one heck of a lot easier to proceed using a second AI than it is to transition to partial panel. Sure we all maintain currency and proficiency but who is ever so proficient that they can fly partial panel as well as they can with an AI? Not me no matter how hard I try. To me partial panel, whether it is with a TC or a T&SI, is a serious event and probably qualifies as an emergency. Having a second self-contained AI changes that dynamic tremendously. YMMV > Happy Skies, > > Old Bob -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
David Lloyd wrote: > > ....be sure to review and compare the JPI engine monitor if you have not > made a decision yet. I will but they have a couple of strikes against them: 1. JPI is expensive. 2. JPI screwed Matt Dralle over the name "fuel scan". 3. JPI changed the data format for their engine data storage without telling the customers so that they could not continue processing their data as they had in the past. I do not think JPI is customer oriented. They do have good engineering and good products but if all the other things are equal, I will go with a different company. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
Subject: Re: RE: AeroElectric-List Digest: 66 Msgs - 01/16/06
Tony Cann wrote: > > 1) Now that the CAN-Aerospace bus definition has been around a while, will > it become an accepted standard? It did achieve some success in the CAPSTONE > projects. CAN-aerospace is a good start. I would like to see it flushed out a bit more with more standardization in the messages transported. > 2) Has Boeing published their message formats for Ethernet to try to > establish a standard? Not that I am aware of but I haven't looked for a year. There is supposed to be a new ARINC standard to address this issue. A day late and a dollar short it seems to me. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Subject: Re: Interference between Com and Autopilot
Date: Jan 17, 2006
Hello Brian, thanks for your response - please see my answers for simplicity reasons below between your mail. Problem still exists, today I have moved the cables a bit and the reactions changed. I will buy some ferit and try to put it on the servo cables. Will report results. Peter "Brian Lloyd" schrieb: > > > mailto:Peter.Sokolowski@t-online.de wrote: > > > > Hello all, > > I am building my panel with a TruTrak DF II autopilot and 2 Becker AR3202 Coms. I have discovered that transmitting during engaged autopilot has influence on the AP in the form that the elevator goues up and the ailerons make a right turn. As the details on the up and down is second, the influence itself is of cause the problem. I have made the connections between the - high quality - HF cables and the BNCs myself (i.e. they should be OK) and use 2 standard - not self made - antennae. > > The question is now - what can I do to avoid this interference? more shielding, replacing the autopilot, ... > > BTW, the antennae are in the baggage compartment > > What are you using for a ground plane for your antennas? 45 x 45 cm glass fibre with copper on it > > Isn't the fuselage in the Lancair primarily carbon fiber? If that is the > case you are going to want to get the antennas outside the fuselage. not necessarily, there are 2 models. mine is made from glass > > How does the TruTrak autopilot talk to its servos? Is is an analog > voltage or a digital message? Honestly I do not know - I assume analog > > Frankly, I would talk with the folks from TruTrak. They can help you > with RF getting into their servos and/or the control head. Given the > digital nature of the TruTrak autopilot and if I understand their system > properly I would suspect that the problem is occurring at the one analog > point, where the analog rate-gyro signal is digitized. Already done - that is one of the reason I asked the group. They have no solution - beside unbalanced antennae what I exclude. > > But TruTrak is your best bet for assistance. > > -- > Brian Lloyd 2243 Cattle Dr. > brian-yak at lloyd dot com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > I fly because it releases my mind from the tyranny of petty things . . . > - Antoine de Saint-Exupery > > > > > > > > ________________________________________________________________________________
Date: Jan 17, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Hawker battery failure
Further investigation into the puffed up battery confirmed that the inter-cell walls got so hot that the plastic stretched under pressure and after all the smoke (or should I say steam?) cleared, the walls between cells was still intact. They're running some cracking pressure tests on the vent valves. It's the opinion of those who've tested a lot more batteries than I that the event probably didn't take more than 20-30 minutes under an over-charge current that a 40 to 60A alternator would be capable of. There's a new battery qualification document (DO-293) that calls for 3v per cell at up to 8C amps be applied until all the steaming is over. No fire allowed, no breaches of battery case. I'm told that within 10 minutes of application, RG batteries are steaming vigorously and that the high energy activity is pretty well over in 30-40 minutes. Looks like the Hawker would have passed this test okay and that regulator failure was the proximate cause of the event with outcome exacerbated by lack of active notification of an OV condition and/or automatic termination of the OV event. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2006
Peter.Sokolowski@t-online.de wrote: > > Hello Brian, > thanks for your response - please see my answers for simplicity reasons below between your mail. Problem still exists, today I have moved the cables a bit and the reactions changed. I will buy some ferit and try to put it on the servo cables. Will report results. It is always very annoying to troubleshoot RF getting into devices that are not RF devices. EMI in telephones, stereos, and burglar alarms are always a pain to troubleshoot. Here are some things to try: 1. Try a ferrite bead over the entire servo wire at both ends. 2. Try ferrite beads over each individual wire in the cable at both ends. 3. Bypass the power wiring to ground at the head and at the servo using .01 ufd disc ceramic capacitors. 4. Bypass the control signal lead at both the head and servo using a .001 ufd disc ceramic capacitors. 5. Wrap several turns of the power wire around a ferrite toroid core where it enters the control head and again at the servo. I would try them in the order I have listed them. When working with the disc ceramic caps you need to keep the leads as short as possible. [sigh] RF in plastic airplanes is always a pain. I had a plastic car once and tried to mount an antenna on it with a window-screen ground plane. It never did work right. Oh, something else to consider. You could try building a coaxial dipole and mount that instead of using an aircraft antenna. The standard aircraft antenna insists on a good ground plane. A coaxial dipole does not need one but is twice as long. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 17, 2006
From: "Dave Morris \"BigD\"" <BigD(at)DaveMorris.com>
This may not cure your RFI problem, but it might be an interesting alternative antenna in your fiberglass tailcone, as it eliminates the need for a ground plane and whip antennas, and conforms to the fuselage sides, leaving the interior open: http://www.DaveMorris.com/MorrisComLoop Dave Morris At 01:05 PM 1/17/2006, you wrote: > >Hello Brian, >thanks for your response - please see my answers for simplicity reasons >below between your mail. Problem still exists, today I have moved the >cables a bit and the reactions changed. I will buy some ferit and try to >put it on the servo cables. Will report results. >Peter > "Brian Lloyd" schrieb: > > > > > > > > > mailto:Peter.Sokolowski@t-online.de wrote: > mailto:Peter.Sokolowski@t-online.de > > > > > > Hello all, > > > I am building my panel with a TruTrak DF II autopilot and 2 Becker > AR3202 Coms. I have discovered that transmitting during engaged autopilot > has influence on the AP in the form that the elevator goues up and the > ailerons make a right turn. As the details on the up and down is second, > the influence itself is of cause the problem. I have made the connections > between the - high quality - HF cables and the BNCs myself (i.e. they > should be OK) and use 2 standard - not self made - antennae. > > > The question is now - what can I do to avoid this interference? more > shielding, replacing the autopilot, ... > > > BTW, the antennae are in the baggage compartment > > > > What are you using for a ground plane for your antennas? >45 x 45 cm glass fibre with copper on it > > > > Isn't the fuselage in the Lancair primarily carbon fiber? If that is the > > case you are going to want to get the antennas outside the fuselage. >not necessarily, there are 2 models. mine is made from glass > > > > How does the TruTrak autopilot talk to its servos? Is is an analog > > voltage or a digital message? >Honestly I do not know - I assume analog > > > > Frankly, I would talk with the folks from TruTrak. They can help you > > with RF getting into their servos and/or the control head. Given the > > digital nature of the TruTrak autopilot and if I understand their system > > properly I would suspect that the problem is occurring at the one analog > > point, where the analog rate-gyro signal is digitized. >Already done - that is one of the reason I asked the group. They have no >solution - beside unbalanced antennae what I exclude. > > > > But TruTrak is your best bet for assistance. > > > > -- > > Brian Lloyd 2243 Cattle Dr. > > brian-yak at lloyd dot com Folsom, CA 95630 > > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > > > I fly because it releases my mind from the tyranny of petty things . . . > > - Antoine de Saint-Exupery > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 17, 2006
Subject: Internally Regulated Alternator Update?
Bob, Which "George" were you referring to in your email (attached)? I've searched the Aeroelectric list back emails without success. Can you share where you are headed with this effort (general architecture)? Thanks, Tim Lewis > > > >> >>Let me make sure I understand you correctly: if I locate a mechanically >>suitable IR alternator of suitable capacity, a topology for full OV >>protection and safe in-flight shut-down control of the alternator is soon >>to be published on the AeroElectric list or in the 'Connection, with >>minimal retrofitting hassle into the Z-13 or -14 architectures? > > > Absolutely. > > > >>If so, that's great! I can hold my breath that long. > > > Don't hold your breath and don't even delay flying. > The "barefoot" alternator has a good track record. > The "mod" will all under the cowl. > > > >>(I'd still like a hint on a magic part #, though. You get weird looks >>walkiong into a shop and asking for a part by spec versus what car it's >>for, as you know.) > > > George has published several recommendations > that are part number specific. Check back into > the recent archives. > > Bob . . . ________________________________________________________________________________
From: "czechsix(at)juno.com" <czechsix(at)juno.com>
Date: Jan 18, 2006
Cc: aaaron(at)tvp.com.au
Subject: MicroAir products
I wouldn't get the Microair comm if you're flying in the U.S. They have some fundamental design problems that they can't seem to understand or resolve. A buddy of mine, Alan Kritzman, went through about half a dozen iterations of their transponder with his RV-8...he also tried a new antenna, relocated it, new coax, etc. Nothing resolved the problem which is intermittent operation (replies to ATC interrogations) in our local Class C airspace here at KCID. We finally figured out that the ASR-9 radar here is a very powerful analog system (it may be the most powerful system in operation). The newer radars are digital and less powerful. Anyway there are other transmitters like the one here located around the U.S. but there are none in Australia and if you don't go near these Class C facilities you probably won't see the problem. So, there are some users here in the U.S. who have no complaints. We finally took the latest two versions of the transponder (about a year ago) into our avionics lab here at Rockwell Collins where we work as Systems Engineers. We hooked both of them up to the ATC test sets we use all the time with Collins equipment. Both the Microair units--the latest and greatest--failed all the tests. We know the test sets are good, calibrated units. We sent the results to Microair but at that point we gave up and asked for a refund. I must add that Microair's customer service has been outstanding in the sense than they are eager to resolve the problem and I'm sure they would have kept exchanging and updating their units indefinitely if we had that much patience. But their engineer(s) don't understand how to fix it and they don't have a real certified transponder test set (which is a very expensive piece of equipment and they are a small company), so they may never figure it out without access to proper test equipment. In the end they gave us a good refund and we put in Garmin units which work flawlessly. I might also add that we've heard from half a dozen others in the U.S. that have had the same problems with intermittent operation near major Class C facilities around the country (depends on the radar system in use), so it's not just a local thing at our airport. By the way the microair comm radios seem to work just fine. I hope Microair finds a fix for their transponder...I loved the compact, light weight/low power consumption of their design, and it was a major pain to have to cut a new rectangular hole in my panel for the boat-anchor Garmin (messed up my panel layout), but you've gotta have a transponder that works!! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D Subject: RE: AeroElectric-List: MicroAir products From: "Allan Aaron" <aaaron(at)tvp.com.au> I have a microair transponder. Its worked fine for me over the past three years. I did have to send it back once for a software update but the service was quick and free. Allan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rodney Dunham Sent: Tuesday, 17 January 2006 09:23 Subject: AeroElectric-List: MicroAir products --> I'm about to order transceiver & transponder for my Sonex. I like the small MicroAir radios and they're the cheapest so far. Also, the dealer is here in Tennessee which makes it convenient. Can anyone offer feedback about them (or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also feedback on the dealer, Jabiru USA would be appreciated. Rodney I wouldn't get the Microair comm if you're flying in the U.S. They have some fundamental design problems that they can't seem to understand or resolve. A buddy of mine, Alan Kritzman, went through about half a dozen iterations of their transponder with his RV-8...he also tried a new antenna, relocated it, new coax, etc. Nothing resolved the problem which is intermittent operation (replies to ATC interrogations) in our local Class C airspace here at KCID. We finally figured out that the ASR-9 radar here is a very powerful analog system (it may be the most powerful system in operation). The newer radars are digital and less powerful. Anyway there are other transmitters like the one here located around the U.S. but there are none in Australia and if you don't go near these Class C facilities you probably won't see the problem. So, there are some users here in the U.S. who have no complaints. We finally took the latest two versions of the transponder (about a year ago) into our avionics lab here at Rockwell Collins where we work as Systems Engineers. We hooked both of them up to the ATC test sets we use all the time with Collins equipment. Both the Microair units--the latest and greatest--failed all the tests. We know the test sets are good, calibrated units. We sent the results to Microair but at that point we gave up and asked for a refund. I must add that Microair's customer service has been outstanding in the sense than they are eager to resolve the problem and I'm sure they would have kept exchanging and updating their units indefinitely if we had that much patience. But their engineer(s) don't understand how to fix it and they don't have a real certified transponder test set (which is a very expensive piece of equipment and they are a small company), so they may never figure it out without access to proper test equipment. In the end they gave us a good refund and we put in Garmin units which work flawlessly. I might also add that we've heard from half a dozen others in the U.S. that have had the same problems with intermittent operation near major Class C facilities around the country (depends on the radar system in use), so it's not just a local thing at our airport. By the way the microair comm radios seem to work just fine. I hope Microair finds a fix for their transponder...I loved the compact, light weight/low power consumption of their design, and it was a major pain to have to cut a new rectangular hole in my panel for the boat-anchor Garmin (messed up my panel layout), but you've gotta have a transponder that works!! --Mark Navratil Cedar Rapids, Iowa RV-8A N2D Subject: RE: AeroElectric-List: MicroAir products From: "Allan Aaron" aaaron(at)tvp.com.au -- AeroElectric-List message posted by: "Allan Aaron" aaaron(at)tvp.com.au I have a microair transponder. Its worked fine for me over the past three years. I did have to send it back once for a software update but the service was quick and free. Allan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rodney Dunham Sent: Tuesday, 17 January 2006 09:23 Subject: AeroElectric-List: MicroAir products -- AeroElectric-List message posted by: "Rodney Dunham" -- rdunhamtn(at)hotmail.com I'm about to order transceiver transponder for my Sonex. I like the small MicroAir radios and they're the cheapest so far. Also, the dealer is here in Tennessee which makes it convenient. Can anyone offer feedback about them (or Becker or XCOM) ??? especially when combined with the Jabiru 3300. Also feedback on the dealer, Jabiru USA would be appreciated. Rodney ________________________________________________________________________________
Date: Jan 18, 2006
Subject: Re: MicroAir products
Date: Jan 17, 2006
Thanks for saving me alot of typing. ;-) I also had the same transponder experience (as did another Berkut builder in LA) - intermittent xponder operation in dense/active ATC, several exchanges of the unit with MicroAir without success, etc. And since I fly out of a towered airport under the DFW Class B, transponder ops are not optional. I replaced the unit with a Becker and have not had a single issue thus far. A more detailed account is on my website. I'll also echo the kudos to MicroAir customer support. My issues were over a year ago now, so it is possible that MicroAir has redesigned around the problem...any "alpha testers" out there? ;-) James Redmon Berkut #013 N97TX http://www.berkut13.com > > > I wouldn't get the Microair comm if you're flying in the U.S. They have > some fundamental design problems that they can't seem to understand or > resolve. A buddy of mine, Alan Kritzman, went through about half a dozen > iterations of their transponder with his RV-8...he also tried a new > antenna, relocated it, new coax, etc. Nothing resolved the problem which > is intermittent operation (replies to ATC interrogations) in our local > Class C airspace here at KCID. We finally figured out that the ASR-9 radar > here is a very powerful analog system (it may be the most powerful system > in operation). The newer radars are digital and less powerful. Anyway > there are other transmitters like the one here located around the U.S. but > there are none in Australia and if you don't go near these Class C > facilities you probably won't see the problem. So, there are some users > here in the U.S. who have no complaints. > We finally took the latest two versions of the transponder (about a year > ago) into our avionics lab here at Rockwell Collins where we work as > Systems Engineers. We hooked both of them up to the ATC test sets we use > all the time with Collins equipment. Both the Microair units--the latest > and greatest--failed all the tests. We know the test sets are good, > calibrated units. We sent the results to Microair but at that point we > gave up and asked for a refund. > I must add that Microair's customer service has been outstanding in the > sense than they are eager to resolve the problem and I'm sure they would > have kept exchanging and updating their units indefinitely if we had that > much patience. But their engineer(s) don't understand how to fix it and > they don't have a real certified transponder test set (which is a very > expensive piece of equipment and they are a small company), so they may > never figure it out without access to proper test equipment. In the end > they gave us a good refund and we put in Garmin units which work > flawlessly. > I might also add that we've heard from half a dozen others in the U.S. > that have had the same problems with intermittent operation near major > Class C facilities around the country (depends on the radar system in > use), so it's not just a local thing at our airport. > By the way the microair comm radios seem to work just fine. > I hope Microair finds a fix for their transponder...I loved the compact, > light weight/low power consumption of their design, and it was a major > pain to have to cut a new rectangular hole in my panel for the boat-anchor > Garmin (messed up my panel layout), but you've gotta have a transponder > that works!! > --Mark Navratil ________________________________________________________________________________
From: "Mitchell Goodrich" <mgoodrich(at)tampabay.rr.com>
Date: Jan 18, 2006
David, Can I suggest you take a look at a better Engine Management System. Research Zerionavionix.com Great Company, and a very well thought out Engine system, Soon to be certed. These guys are very customer oriented. Mitchell Goodrich Varieze Tampa, FL -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd Sent: Tuesday, January 17, 2006 1:04 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> David Lloyd wrote: > --> > > ....be sure to review and compare the JPI engine monitor if you have > not > made a decision yet. I will but they have a couple of strikes against them: 1. JPI is expensive. 2. JPI screwed Matt Dralle over the name "fuel scan". 3. JPI changed the data format for their engine data storage without telling the customers so that they could not continue processing their data as they had in the past. I do not think JPI is customer oriented. They do have good engineering and good products but if all the other things are equal, I will go with a different company. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Well Mitchell, I think maybe you goofed twice! :-) They might want to try: http://www.xerionavionics.com/ Seems you left out a "c". I know, it's too early ... no coffee yet. Right? :-) James On 1/18/06, Mitchell Goodrich wrote: > > mgoodrich(at)tampabay.rr.com> > > > Morning All, > > Well I really goofed this time. The engine Management System website > for comparrison is Xerionavionis.com not Zerionavionix. My > apologies. > > Mitchell Goodrich > > > <<>> ________________________________________________________________________________
Subject: Iso Amp - 2 stereo - 3 mono inputs
Date: Jan 18, 2006
Hello, I am looking to integrate 2 stereo (Garmin 396 and Ipod) and 3 mono(EIS, Traffic, 1 extra) sources into my Flightcom 403. I have studied the design of Bob's Iso Amp and like it all except that it only accepts one stereo input. Is there a clever way to add another stereo input? Also, I contacted Flightcom and they suggested (good service - 3hr response to an e-mail) just adding 1:1 Isolation transformers (Radio Shack 273-1374) to the mono inputs and running all lines to Pin 21 - that way they will be unmuted. They did not have an answer for the twin stereo inputs. Any thoughts? Cheers, Pete ________________________________________________________________________________
Date: Jan 18, 2006
An Early Good Morning, Well for all of you that tried my link to the Engine Management System Comparison, I goofed twice. Too bad spell check doesn't pick up URL mistakes also. I'd better get another cup of coffee and my glasses on. www.xerionavionix.com Check it out Mitchell Goodrich ________________________________________________________________________________
Date: Jan 18, 2006
Subject: Re: Iso Amp - 2 stereo - 3 mono inputs
><pete.howell@gecko-group.com> > > >Hello, > >I am looking to integrate 2 stereo (Garmin 396 and Ipod) and 3 >mono(EIS, Traffic, 1 extra) sources into my Flightcom >403. I have studied the design of Bob's Iso Amp and like it all >except that it only accepts one stereo input. Is there a clever way >to add another stereo input? > >Also, I contacted Flightcom and they suggested (good service - 3hr >response to an e-mail) just adding 1:1 Isolation transformers (Radio >Shack 273-1374) to the mono inputs and running all lines to Pin 21 - >that way they will be unmuted. > >They did not have an answer for the twin stereo inputs. Are you going to listen to both at the same time? A DPDT switch would let you select which source was being fed to the amplifier. Alternatively, you add second input networks of a 150 ohm resistor, 10uF cap to pin 2 of amplifier for each channel. Loaded of course as appropriate (R98/99). Bob . . . ________________________________________________________________________________
Date: Jan 18, 2006
Thank You Ferg, It is nice to know that I am not alone out there while twisting in the wind! Happy Skies, Old Bob In a message dated 1/18/2006 9:09:23 A.M. Central Standard Time, VE3LVO(at)rac.ca writes: I'm pretty certain you have the same experience and just want to say how closely to my appreciation your comments are. As our Ottawa friend said, a turn co-ordinator won't work in an inverted spin (ah well) but a 'T&B' will. It must be obvious that any less critical upset in cloud can be swiftly dealt with if you get the 'picture' a T&B gives. Keep on truckin'. Cheers, Ferg ________________________________________________________________________________
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)utcfuelcells.com>
Date: Jan 18, 2006
Bob, Another important issue might also be the speed at which the starter turns the engine. Most impulse mags will not operate properly if the engine spins too fast. This was a typical issue with the C-152 after they went to a 24 Volt system. Fred Stucklen RV-6A N926RV nuckollsr(at)cox.net > Peter.Sokolowski@t-online.de> > >Hello all, >as I am new on this list - this is my first try to get some needed >information. >So what I have is a 24 Volt system with a 12 Volt starter on an O360 F1A6. >I was told that it should not be a problem to use the 12 Volt starter with >24 Volt as the voltage will drop anyhow to about 18 Volt and the starting >process itself will not take more than 20 seconds which the starter should >be capable to handle. If it's a permanent magnet starter, it's probably not a good idea. The earliest automotive derivatives were series wound and fairly tolerant of short duration overloads . . . it will certainly crank the engine faster thus reducing total abuse time of the starter. What are your options? Take the starter off and replace it with an newer, lighter machine or run the existing starter 'til it croaks. Who knows, you may get considerable service life from the existing starter and the risks are low. >- what is the opinion of the group on this ? >- The second issue is that I need a figure of the battery strength (Ah) >which is needed to start my engine. I know that this is depending on many >issues and this should not be the only consideration for the strength but >there must be a general idea of whether 17 Ah should do the job easily or >should one go for 24 Ah or 7 Ah. Battery size is driven more by what your no-alternator endurance goals are. Have you conducted a load analysis for alternator-out operations and selected a minimum endurance time? See Chapter 17 of the 'Connection. Bob . . . ________________________________________________________________________________
Date: Jan 18, 2006
> > >Bob, > > Another important issue might also be the speed at which the starter turns >the engine. Most impulse mags will not operate properly if the engine spins >too >fast. This was a typical issue with the C-152 after they went to a 24 Volt >system. Hmmm . . . good point. Peter, did you catch this? Bob . . . >Fred Stucklen > >RV-6A N926RV > >nuckollsr(at)cox.net > > > >Peter.Sokolowski@t-online.de> > > > >Hello all, > >as I am new on this list - this is my first try to get some needed > >information. > >So what I have is a 24 Volt system with a 12 Volt starter on an O360 >F1A6. > >I was told that it should not be a problem to use the 12 Volt starter >with > >24 Volt as the voltage will drop anyhow to about 18 Volt and the >starting > >process itself will not take more than 20 seconds which the starter >should > >be capable to handle. > > If it's a permanent magnet starter, it's probably not a good idea. > The earliest automotive derivatives were series wound and fairly > tolerant of short duration overloads . . . it will certainly crank > the engine faster thus reducing total abuse time of the starter. > > What are your options? Take the starter off and replace it with > an newer, lighter machine or run the existing starter 'til it > croaks. Who knows, you may get considerable service life from > the existing starter and the risks are low. > > >- what is the opinion of the group on this ? > >- The second issue is that I need a figure of the battery strength >(Ah) > >which is needed to start my engine. I know that this is depending on >many > >issues and this should not be the only consideration for the strength >but > >there must be a general idea of whether 17 Ah should do the job >easily or > >should one go for 24 Ah or 7 Ah. > > Battery size is driven more by what your no-alternator > endurance goals are. Have you conducted a load analysis > for alternator-out operations and selected a minimum endurance > time? See Chapter 17 of the 'Connection. > > Bob . . . > > >-- > > Bob . . . < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it devine. The authority rests > < with experiment. > < --Lawrence M. Krauss > http://www.aeroelectric.com ________________________________________________________________________________
Date: Jan 18, 2006
Subject: T&SI vs. TC (was: EFIS Comparisons)
BobsV35B(at)aol.com wrote: > I am going to take the liberty of sending you something off list that tries > to explain why I think we should be teaching people to stop the turn instead > of leveling the wings. > > The short version is that when we get vertigo, it takes a lot of discipline > to believe the attitude style presentation of the TC and/or the attitude > indicator. But we are trained to ignore vertigo and to go with the instruments. We are also trained to cross-check the instruments to ensure that they are telling us the right thing. > With the turn needle, there is no need to believe the instrument over what > your senses are telling you. All that is needed is to stop the turn! Since > the turn needle tells you nothing directly about your attitude, there is no > confusion. Stop the turn by centering the needle and you will survive. It > makes no difference at all whether you think you are sideways or whether you > think you are right side up. > > I repeat -- Stop the turn and you will survive! If the wing is flying the only way you can stop the turn is to level the wings. When the lift vector is not vertical, the aircraft is going to turn. The only time this might not be true is when the wing is stalled or partially stalled as in a spin where you could be in a relatively flat attitude. Certainly the ailerons are not going to work in a spin and they are only going to make things worse. This is where the T&SI becomes critical along with your rudders. Also, older aircraft had much more effective rudders. You really could pull a wing up just with the rudder. Modern airplanes tend to have much less rudder effectiveness and you might have to unstall the wing to make the ailerons effective again in order to really stop the turn. Bob, you have a V35B (I am guessing from your email address). How effective is the ruddervator in stopping the turn? My guess is that you really need to break the stall in order to recover with that airplane. When flying partial panel (needle-ball and airspeed for us old-timers) we infer attitude from the behavior of other things, that is, airspeed and altitude give us clues as to whether the nose is up or down relative to the horizon. We infer that the wings are not level by the fact that the airplane is yawing. But none of these instruments actually tell us the airplane's attitude. Only an AI can do that directly. But I do agree with you on one thing: if the airplane departs normal flight, I want a Turn and Slip Indicator (T&SI) because it will tell me what to do with the rudder and I need to know that to stop or prevent a spin. But since I spend a lot more time in a clag with the wing flying and not stalled/spinning, I want a second AI to help me stay that way. So give me both an extra AI and a T&SI. Belt and suspenders. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
From: Brian Lloyd <brian-yak(at)lloyd.com> Subject: Re: AeroElectric-List: EFIS Comparisons > On top of that, neither instrument will tumble as will some attitude gyros. But in order to be used as a replacement for a T&SI or a TC the AI must be non-tumbling. If it has stops on the gimbals it may not be used to replace the turn instrument. There are a number of non-tumbling AIs out there. Sporty's has a nice one for $1600. It also has an inclinometer (ball). I am interested in the Sporty's AI - so I asked customer service about the non-tumbling.... Janet Jones wrote "The unit is not a non-tumbling instrument." I'll probably call Castleberry @ 512-251-5322 and ask them...thought someone more knowledgable might be able to help? This is referenced by Sporty's - AC91-75: http://www.sportys.com/terryc/images/ac91-75.pdf John ________________________________________________________________________________
Subject: FW: RE: Iso Amp - 2 stereo - 3 mono inputs
Date: Jan 18, 2006
Hi Bob - thanks for quick response - great question - I will not listen to music from both at the same time, but the 396 has terrain warnings I would want to hear when listening to the Ipod when the Xm radio audio is off. I picked up a mini DPDT on-on switch today as it is the simple/easy way to go. I'll just turn the Ipod off over the mountains!!! Pete ==================================================================== Are you going to listen to both at the same time? A DPDT switch would let you select which source was being fed to the amplifier. Alternatively, you add second input networks of a 150 ohm resistor, 10uF cap to pin 2 of amplifier for each channel. Loaded of course as appropriate (R98/99). Bob . . . ===================================================================== I am looking to integrate 2 stereo (Garmin 396 and Ipod) and 3 mono(EIS, Traffic, 1 extra) sources into my Flightcom 403. I have studied the design of Bob's Iso Amp and like it all except that it only accepts one stereo input. Is there a clever way to add another stereo input? Also, I contacted Flightcom and they suggested (good service - 3hr response to an e-mail) just adding 1:1 Isolation transformers (Radio Shack 273-1374) to the mono inputs and running all lines to Pin 21 - that way they will be unmuted. They did not have an answer for the twin stereo inputs. ________________________________________________________________________________
Date: Jan 18, 2006
Subject: Re: T&SI vs. TC (was: EFIS Comparisons)
BobsV35B(at)aol.com wrote: > "But we are trained to ignore vertigo and to go with the instruments. We > are also trained to cross-check the instruments to ensure that they are > telling us the right thing." > > Good Afternoon Brian, Before I reply I want to add that I think we are probably saying the same things different ways. I happen to agree with you but think it may be just a bit simplistic. This is why people need to add upset recovery to their repitoire. So, things we already agree upon: 1. the T 2. stopping the turn is critical to all recovery. I think we diverge elsewhere but only slightly. > I agree that we were all taught to do that, but Carnahan and his son were > both experienced pilots and they still lost the airplane. John Kennedy had a > whole lot of modern training, but he lost it as well. He had more flying time > when he was killed than I had when I was teaching instrument flight. And he made bad decisions that cost him his life. Not exactly the example I would choose. I can think of many ways that JFK jr could have saved his life and that of his passengers but we digress. > My premise is that we should not worry about which way is up. Just stop the > turn. > > >>I repeat -- Stop the turn and you will survive! < > > > You said: "If the wing is flying the only way you can stop the turn is to > level the > wings. When the lift vector is not vertical, the aircraft is going to turn." > > No argument here either. Doing it my way will actually get the wings level. > I also teach using coordinated control to stop the turn, not to just boot > the rudder. And if the wing isn't flying the ailerons aren't going to work anyway. Just "boot the rudder" is the right thing to do in that case. But if the wing is flying you want to unload the airframe and roll right-side-up. Coordinated flight is good in this case. If you are making a coordinated movement of the controls, both rudder and aileron, and you stop the turn you have, in fact, rolled to wings level. I think we are saying the same thing. > The idea is that I don't care if the pilot knows which way is up or not. If > the turn is stopped and the ball is in the middle, the wings will be level > whether we know it or not. If the ball is not in the center and the needle is, > we will still survive. Well, you can be in that state with the aircraft inverted and the nose 60 degrees down. If the ball and the needle are centered and you happen to recover inverted then you are going to end up pulling through a vertical down-line and grossly exceed the aircraft's Vne so up is a significant concept here. > I have no access to good data, but I have been an active pilot since 1946 > and an active flight instructor since 1949. (Darn, I hate it when people tell > me how long they have been flying, but it seems to fit here!) You have me beaten by two decades. I have only been flying since 1968 and only have amassed about 7000 hours. > During the first > twenty or so years, I recall very few instances of any IFR rated pilot > losing the airplane while on instruments. In general I think you are right. Training then required more understanding and less rote. In the FAA's attempt to standardize training I think that fewer pilots now really understand how their airplanes fly. But the accident statistics have shown a steady downward trend so I guess they got something right. > As I noted in my 'off list' message, it wasn't until after we had been using > the TC for IFR training that I started to notice a loss in partial panel > proficiency during flight checks given to pilots who had been trained using the > TC. I don't think you sent that one to me. > We also started to read about IFR rated pilots who were losing control after > a failure of attitude instrumentation. We have become far more dependent on the AI. There are people who used to fly IFR using only needle-ball and airspeed and were very proficient. That is less the case now. > Over the next ten years I decided to go back to the T&B in all of my own > airplanes and for any trainer I was associated with. > > The longer I championed and trained with the T&B, the more I became > convinced that part of the problem (There is more, but I am getting boring!) was our > insistence that the student must disregard his/her feelings and just believe > the instruments. I now feel, totally unsupported by any scientific data, > that what we really should be doing is just train the pilot to stop the turn and > stop telling them to believe the instruments instead of their senses. If > they stop the turn and have the ball in the center, the wings will be level > unless there is something else wrong with the airplane. We agree. But if I read you correctly, you *ARE* telling them to believe the instruments. You are telling them to believe the T&SI over all other instruments. They must believe that over what their senses are telling them. You will not stay alive by trusting your senses over your instruments. The problem with "believe the instruments" is that the instruments *can* lie. A tumbled AI will definitely lead you astray. President Reagan actually had it right when he said, "Trust but verify." That applies here in spades. Trust your instruments but verify that they are telling you the right thing. The great thing about the T&SI is that it is so simple that it is unlikely to fail. If it doesn't agree with your AI, you should serious consider what your AI is telling you. Your cross check is that the HI (DG) should be telling you the same thing your T&SI is even if it has tumbled. Sure the HI can tumble and tell you the wrong heading but it will recover almost immediately and at least show you the way you are rotating. This works well with your T&SI as a cross check. > Forget about trying to figure out whether or not the wings are level. > > Just stop the turn and you WILL survive! If you stop the turn by a coordinated application of aileron and rudder, I agree -- mostly. :-) -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
John Tvedte wrote: > > From: Brian Lloyd <brian-yak(at)lloyd.com> > Subject: Re: AeroElectric-List: EFIS Comparisons > > > >>On top of that, neither instrument will tumble as will some attitude gyros. > > > But in order to be used as a replacement for a T&SI or a TC the AI must > be non-tumbling. If it has stops on the gimbals it may not be used to > replace the turn instrument. There are a number of non-tumbling AIs out > there. Sporty's has a nice one for $1600. It also has an inclinometer > (ball). > > I am interested in the Sporty's AI - so I asked customer service about the non-tumbling.... > > Janet Jones wrote "The unit is not a non-tumbling instrument." Wow. I thought that the FAA requirement for an STC to replace a T&SI or a TC with a second attitude gyro is that it be good for 360 degrees in both pitch and roll. You have to be able to use the instrument to recover from an upset which you can't do with an AI that has tumbled. > > I'll probably call Castleberry @ 512-251-5322 and ask them...thought someone more knowledgable might be able to help? > > This is referenced by Sporty's - AC91-75: http://www.sportys.com/terryc/images/ac91-75.pdf You are right. It doesn't say "non-tumbling". Seems like a serious oversight to me. If I somehow manage to cause my primary AI to tumble my backup is likely to tumble too. If you have replaced the T&SI or TC with an AI you might not be able to recover. I guess you would then have to rely on the HI (DG) to give you turn information so you can "stop the turn". But I sure as heck would want a non-tumbling gyro in this application. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
From: "Randall Richter" <richterrbb(at)earthlink.net>
Subject: EFIS Comparisons
Date: Jan 18, 2006
I spoke to the rep at Oshkosh this summer and this seems like a very good product. The one thing that gives me pause is the fact that the software will not be user upgradeable. They will require you to remove the unit and send it in to them for upgrades. If I'm not mistaken, most of the others provide updated software via removable card or something similar, right? He said this was because they're seeking certification and that's not allowed for certified products. Which tells me they won't have an "experimental" version of this system. Randy Richter -7QB coming along VERY slowly -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mitchell Goodrich Sent: Wednesday, January 18, 2006 7:36 AM Subject: RE: AeroElectric-List: EFIS Comparisons Morning All, Well I really goofed this time. The engine Management System website for comparrison is Xerionavionis.com not Zerionavionix. My apologies. Mitchell Goodrich ________________________________________________________________________________
Date: Jan 18, 2006
Brian Lloyd wrote: > > BobsV35B(at)aol.com wrote: > >>"But we are trained to ignore vertigo and to go with the instruments. We >>are also trained to cross-check the instruments to ensure that they are >>telling us the right thing." >> >>Good Afternoon Brian, > > > Before I reply I want to add that I think we are probably saying the > same things different ways. I happen to agree with you but think it may > be just a bit simplistic. This is why people need to add upset recovery > to their repitoire. > > So, things we already agree upon: > > 1. the T (wow, a whole line disappeared. It used to read "the T and SI or TandB is a better instrument than the TC.") > > 2. stopping the turn is critical to all recovery. > > I think we diverge elsewhere but only slightly. And after a further private exchange with Bob I think we agree 100%. We were only disagreeing on how to get there. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Randy... They have TWO versions...the Auracle I is for non-certified use, and the Auracle II is for either certified or not...it is about $1500 more than the non certified version. And, from their website: "Programming the Xerion */AuRACLE (TM)/* is made quick and easy by visiting www.xerionavionix.com and requesting your aircraft specific data, downloading the file to your portable USB drive, and then plugging it into your */AuRACLE (TM)/*. It's that simple!" The USB drive is included with the unit. Harley Dixon Randall Richter wrote: > >I spoke to the rep at Oshkosh this summer and this seems like a very good >product. The one thing that gives me pause is the fact that the software >will not be user upgradeable. They will require you to remove the unit and >send it in to them for upgrades. If I'm not mistaken, most of the others >provide updated software via removable card or something similar, right? > >He said this was because they're seeking certification and that's not >allowed for certified products. Which tells me they won't have an >"experimental" version of this system. > >Randy Richter >-7QB coming along VERY slowly > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mitchell >Goodrich >Sent: Wednesday, January 18, 2006 7:36 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: EFIS Comparisons > > > > >Morning All, > >Well I really goofed this time. The engine Management System website >for comparrison is Xerionavionis.com not Zerionavionix. My >apologies. > >Mitchell Goodrich > > > > > > > > > ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Re: ectric-List:Dynon fuel flow/pressure sensor placement
Date: Jan 18, 2006
I am installing the Dynon fuel monitor and am presently doing the fuel system plumbing in the cabin area. Need tutoring from the group on the why and the where of the fuel flow/ pressure sensors. TIA Frank @ SGU @ SLC RV7A fuse/finish ________________________________________________________________________________
Date: Jan 18, 2006
Glad to hear they have listened to the masses! Randy -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: Wednesday, January 18, 2006 5:45 PM Subject: Re: AeroElectric-List: EFIS Comparisons Randy... They have TWO versions...the Auracle I is for non-certified use, and the Auracle II is for either certified or not...it is about $1500 more than the non certified version. And, from their website: "Programming the Xerion */AuRACLE (TM)/* is made quick and easy by visiting www.xerionavionix.com and requesting your aircraft specific data, downloading the file to your portable USB drive, and then plugging it into your */AuRACLE (TM)/*. It's that simple!" The USB drive is included with the unit. Harley Dixon Randall Richter wrote: > >I spoke to the rep at Oshkosh this summer and this seems like a very good >product. The one thing that gives me pause is the fact that the software >will not be user upgradeable. They will require you to remove the unit and >send it in to them for upgrades. If I'm not mistaken, most of the others >provide updated software via removable card or something similar, right? > >He said this was because they're seeking certification and that's not >allowed for certified products. Which tells me they won't have an >"experimental" version of this system. > >Randy Richter >-7QB coming along VERY slowly > ________________________________________________________________________________
Date: Jan 18, 2006
Randall Richter wrote: > > I spoke to the rep at Oshkosh this summer and this seems like a very good > product. The one thing that gives me pause is the fact that the software > will not be user upgradeable. They will require you to remove the unit and > send it in to them for upgrades. If I'm not mistaken, most of the others > provide updated software via removable card or something similar, right? > > He said this was because they're seeking certification and that's not > allowed for certified products. Which tells me they won't have an > "experimental" version of this system. That actually doesn't make complete sense. The Sandel 3308 EHSI in my Aztec allows firmware upgrade in the field. I can upgrade the firmware using the same cable that is used to upgrade the database. The same was true for my SL-60 GPS/comm. So we know that the FAA will certify devices that will allow field upgrades to the software in the box. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Subject: Re: EFIS Comparisons
See my previous reply, Brian... Harley Brian Lloyd wrote: > > >Randall Richter wrote: > > >> >>I spoke to the rep at Oshkosh this summer and this seems like a very good >>product. The one thing that gives me pause is the fact that the software >>will not be user upgradeable. They will require you to remove the unit and >>send it in to them for upgrades. If I'm not mistaken, most of the others >>provide updated software via removable card or something similar, right? >> >>He said this was because they're seeking certification and that's not >>allowed for certified products. Which tells me they won't have an >>"experimental" version of this system. >> >> > >That actually doesn't make complete sense. The Sandel 3308 EHSI in my >Aztec allows firmware upgrade in the field. I can upgrade the firmware >using the same cable that is used to upgrade the database. The same was >true for my SL-60 GPS/comm. > >So we know that the FAA will certify devices that will allow field >upgrades to the software in the box. > > > ________________________________________________________________________________
Date: Jan 18, 2006
Actually, if you want complete flexibility and STC application, the MVP-50 from EI is more configurable with all the bells and whistles. It's also has support for the Chelton box. www.buy-ei.com Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Randall Richter Sent: Wednesday, January 18, 2006 5:31 PM Subject: RE: AeroElectric-List: EFIS Comparisons --> I spoke to the rep at Oshkosh this summer and this seems like a very good product. The one thing that gives me pause is the fact that the software will not be user upgradeable. They will require you to remove the unit and send it in to them for upgrades. If I'm not mistaken, most of the others provide updated software via removable card or something similar, right? He said this was because they're seeking certification and that's not allowed for certified products. Which tells me they won't have an "experimental" version of this system. Randy Richter -7QB coming along VERY slowly -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mitchell Goodrich Sent: Wednesday, January 18, 2006 7:36 AM Subject: RE: AeroElectric-List: EFIS Comparisons Morning All, Well I really goofed this time. The engine Management System website for comparrison is Xerionavionis.com not Zerionavionix. My apologies. Mitchell Goodrich ________________________________________________________________________________
Date: Jan 18, 2006
Hey Randy & Harley, The Auracle does come 2 different ways. A single box, which means all the senders are wired directly to the head unit, and a 2 box. The data aquisition unit mounted in the engine compartment and a supplied data cable run up to the head unit. Do believe that both units are/will be certified. I vote for the 2 box. Only because of my limited wireway space, and ease of install. Both units have the same exact functionality. Mitchell Goodrich VariEze Tampa -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Randall Richter Sent: Wednesday, January 18, 2006 5:56 PM Subject: RE: AeroElectric-List: EFIS Comparisons --> Glad to hear they have listened to the masses! Randy -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: Wednesday, January 18, 2006 5:45 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> Randy... They have TWO versions...the Auracle I is for non-certified use, and the Auracle II is for either certified or not...it is about $1500 more than the non certified version. And, from their website: "Programming the Xerion */AuRACLE (TM)/* is made quick and easy by visiting www.xerionavionix.com and requesting your aircraft specific data, downloading the file to your portable USB drive, and then plugging it into your */AuRACLE (TM)/*. It's that simple!" The USB drive is included with the unit. Harley Dixon Randall Richter wrote: > >I spoke to the rep at Oshkosh this summer and this seems like a very >good product. The one thing that gives me pause is the fact that the >software will not be user upgradeable. They will require you to remove >the unit and send it in to them for upgrades. If I'm not mistaken, most >of the others provide updated software via removable card or something >similar, right? > >He said this was because they're seeking certification and that's not >allowed for certified products. Which tells me they won't have an >"experimental" version of this system. > >Randy Richter >-7QB coming along VERY slowly > ________________________________________________________________________________
Date: Jan 18, 2006
On 18 Jan 2006, at 18:10, Brian Lloyd wrote: > yak(at)lloyd.com> > > Randall Richter wrote: >> >> >> I spoke to the rep at Oshkosh this summer and this seems like a >> very good >> product. The one thing that gives me pause is the fact that the >> software >> will not be user upgradeable. They will require you to remove the >> unit and >> send it in to them for upgrades. If I'm not mistaken, most of the >> others >> provide updated software via removable card or something similar, >> right? >> >> He said this was because they're seeking certification and that's not >> allowed for certified products. Which tells me they won't have an >> "experimental" version of this system. > > That actually doesn't make complete sense. The Sandel 3308 EHSI in my > Aztec allows firmware upgrade in the field. I can upgrade the firmware > using the same cable that is used to upgrade the database. The same > was > true for my SL-60 GPS/comm. > > So we know that the FAA will certify devices that will allow field > upgrades to the software in the box. We know that some FAA Aircraft Certification Offices will certify devices that will allow field upgrades to software in the box. Maybe this is yet another area where different ACOs have different interpretations. Or, maybe the way that the company wanted to handle firmware upgrades didn't pass muster with the FAA (rightly or wrongly), and they decided to drop that feature rather than spend the money on a redesign. I've seen that scenario often enough in my day job. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 18, 2006
Subject: Xerion EIS (was: EFIS Comparisons)
Mitchell Goodrich wrote: > The Auracle does come 2 different ways. A single box, which means all > the senders > are wired directly to the head unit, and a 2 box. The data aquisition > unit mounted > in the engine compartment and a supplied data cable run up to the head > unit. > Do believe that both units are/will be certified. > I vote for the 2 box. Only because of my limited wireway space, and ease > of install. > Both units have the same exact functionality. It appears they are using a data bus. This means that they could support multiple data collection boxes. This is a *very* good idea. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Kevin Horton wrote: >>So we know that the FAA will certify devices that will allow field >>upgrades to the software in the box. > > > We know that some FAA Aircraft Certification Offices will certify > devices that will allow field upgrades to software in the box. Maybe > this is yet another area where different ACOs have different > interpretations. Or, maybe the way that the company wanted to handle > firmware upgrades didn't pass muster with the FAA (rightly or > wrongly), and they decided to drop that feature rather than spend the > money on a redesign. I've seen that scenario often enough in my day > job. Firmware updates in hex format over an RS-232 connection is just about as ugly as you can get. I can't imagine any way you could do a worse job of providing this function. (This is how both Sandel and Apollo/UPSAT/Garmin do it.) Therefore almost any other method makes more sense. The Xerion Auricle has USB bus master capability to write to a flash disk in order to write out stored engine data. This means they could also do updates this way too. I don't get it. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Evening, Mitch... Their website is a bit confusing then...I didn't see where it mentions that one or two box option (but I think that I have noticed that at least one other brand does the same thing), but it does say that the Auracle I is for non-certified applications, and the Auracle II at $1500 more is for certified. Of course, the way it is phrased may simply mean that Auracle II is ready for immediate certification where the Auracle I is not expected to be certified in the near future. If you talk to them, you might mention that there is some confusion, as witnessed by our conversations here today. I won't be getting down there for awhile...it's snowing again here ...and I've been finishing the parts I brought back here in my cellar...I'm all camped out in my warm cave until spring! Harley Mitchell Goodrich wrote: > >Hey Randy & Harley, > >The Auracle does come 2 different ways. A single box, which means all >the senders >are wired directly to the head unit, and a 2 box. The data aquisition >unit mounted >in the engine compartment and a supplied data cable run up to the head >unit. >Do believe that both units are/will be certified. >I vote for the 2 box. Only because of my limited wireway space, and ease >of install. >Both units have the same exact functionality. > >Mitchell Goodrich >VariEze Tampa > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Randall Richter >Sent: Wednesday, January 18, 2006 5:56 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: EFIS Comparisons > > >--> > >Glad to hear they have listened to the masses! > >Randy > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Harley >Sent: Wednesday, January 18, 2006 5:45 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: EFIS Comparisons > >--> > >Randy... > >They have TWO versions...the Auracle I is for non-certified use, and the > >Auracle II is for either certified or not...it is about $1500 more than >the non certified version. > >And, from their website: > >"Programming the Xerion */AuRACLE >(TM)/* is made quick and easy by >visiting www.xerionavionix.com and requesting your aircraft specific >data, downloading the file to your portable USB drive, and then plugging > >it into your */AuRACLE >(TM)/*. It's that simple!" > >The USB drive is included with the unit. > >Harley Dixon > > >Randall Richter wrote: > > > >> >> > > > >>I spoke to the rep at Oshkosh this summer and this seems like a very >>good product. The one thing that gives me pause is the fact that the >>software will not be user upgradeable. They will require you to remove >>the unit and send it in to them for upgrades. If I'm not mistaken, most >> >> > > > >>of the others provide updated software via removable card or something >>similar, right? >> >>He said this was because they're seeking certification and that's not >>allowed for certified products. Which tells me they won't have an >>"experimental" version of this system. >> >>Randy Richter >>-7QB coming along VERY slowly >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2006
Evening All, In response to the field changes of the Auracle: Keep in mind this is an "Engine Management System, not an EFIS/Guidance system. Engine functionality doesn't change, the parameteres are what they are. What "field changes" would apply to an engine system? Is there additional functionality that you expect to gain from software upgrades?? Remember engine parameters. If Xerion for some reason makes a change or fixes a bug in the software, the will, at their expense pay for shipping and complete the upgrades. Remember Xerion has a 3 year warranty. All the systems are certified. Experimental guys have the total flexability with the configuration of the unit, scales, alarms, and warnings (certified owners do not have this capability due the FAA restrictions) for the same price we have the benefits of a certified system that has been through the rigors of enviromental & software certification. Yes the software has to be Certified too. No blue screens of death here!!! Remember, the Auracle is field configurable, but not field upgradable, and never will be upgradable due to certification. If I am not wrong Xerion has an onstaff a FAA Der Last but not least the USB doggle (Memory Stick) that plugs into the front of the unit, copies your custom configuraton. If you send the unit back for whatever reason, just plug the doggle in and its back to original state. A big PLUS is the data recorder that keeps track of past engine functions for approx 500 hours. Plug in the memory stick, copy it, take it home and see how the engine has been performing( or how bad the operator has abused your engine?) Great for corporate, or rental situations. I can use it for diagnostics when I race. All in all its a well thought out system and the owners provide fantastic customer service. Give the office a call if you want to get answers directly. They will talk to you!!! Mitchell Goodrich Varieze Tampa Soon to be Flying a 2 box AuRacle -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: Wednesday, January 18, 2006 7:15 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> On 18 Jan 2006, at 18:10, Brian Lloyd wrote: > yak(at)lloyd.com> > > Randall Richter wrote: >> >> >> I spoke to the rep at Oshkosh this summer and this seems like a >> very good >> product. The one thing that gives me pause is the fact that the >> software >> will not be user upgradeable. They will require you to remove the >> unit and >> send it in to them for upgrades. If I'm not mistaken, most of the >> others >> provide updated software via removable card or something similar, >> right? >> >> He said this was because they're seeking certification and that's not >> allowed for certified products. Which tells me they won't have an >> "experimental" version of this system. > > That actually doesn't make complete sense. The Sandel 3308 EHSI in my > Aztec allows firmware upgrade in the field. I can upgrade the firmware > using the same cable that is used to upgrade the database. The same > was > true for my SL-60 GPS/comm. > > So we know that the FAA will certify devices that will allow field > upgrades to the software in the box. We know that some FAA Aircraft Certification Offices will certify devices that will allow field upgrades to software in the box. Maybe this is yet another area where different ACOs have different interpretations. Or, maybe the way that the company wanted to handle firmware upgrades didn't pass muster with the FAA (rightly or wrongly), and they decided to drop that feature rather than spend the money on a redesign. I've seen that scenario often enough in my day job. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jan 18, 2006
Brian, yes they are actually using a proprietary com/data or can buss. In the near future you will see a complete line of instrumentaion that utilizes the can-bus. Mitchell Goodrich -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd Sent: Wednesday, January 18, 2006 8:03 PM Subject: AeroElectric-List: Xerion EIS (was: EFIS Comparisons) --> Mitchell Goodrich wrote: > The Auracle does come 2 different ways. A single box, which means all > the senders are wired directly to the head unit, and a 2 box. The data > aquisition unit mounted > in the engine compartment and a supplied data cable run up to the head > unit. > Do believe that both units are/will be certified. > I vote for the 2 box. Only because of my limited wireway space, and ease > of install. > Both units have the same exact functionality. It appears they are using a data bus. This means that they could support multiple data collection boxes. This is a *very* good idea. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
From: "Gordon or Marge Comfort" <gcomfo(at)tc3net.com>
Date: Jan 18, 2006
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd Sent: Wednesday, January 18, 2006 5:20 PM Subject: Re: AeroElectric-List: T&SI vs. TC (was: EFIS Comparisons) Well, you can be in that state with the aircraft inverted and the nose 60 degrees down. If the ball and the needle are centered and you happen to recover inverted then you are going to end up pulling through a vertical down-line and grossly exceed the aircraft's Vne so up is a significant concept here. -- Brian Lloyd 2243 Cattle Dr. Brian: Can the ball be centered in the above scenario except if the aircraft is in positive "G" flight? If that is the case, it seems you will soon be past the vertical down line. If in negative "G" flight and the ball is not centered, what is the correct pilot response? Gordon Comfort N363GC ________________________________________________________________________________
Date: Jan 18, 2006
Hey Harley, yeah they have a bit of work on the site to do. If you look again, you'll see that the 4 cyl is without sensors and the other is with sensors. The actual diff between the1 and 2 box is bout 700.00 Mitchell Goodrich Modular Electric LLC Managing Partner 813-356-9758 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Harley Sent: Wednesday, January 18, 2006 8:11 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> Evening, Mitch... Their website is a bit confusing then...I didn't see where it mentions that one or two box option (but I think that I have noticed that at least one other brand does the same thing), but it does say that the Auracle I is for non-certified applications, and the Auracle II at $1500 more is for certified. Of course, the way it is phrased may simply mean that Auracle II is ready for immediate certification where the Auracle I is not expected to be certified in the near future. If you talk to them, you might mention that there is some confusion, as witnessed by our conversations here today. I won't be getting down there for awhile...it's snowing again here ...and I've been finishing the parts I brought back here in my cellar...I'm all camped out in my warm cave until spring! Harley Mitchell Goodrich wrote: >--> > >Hey Randy & Harley, > >The Auracle does come 2 different ways. A single box, which means all >the senders are wired directly to the head unit, and a 2 box. The data >aquisition unit mounted >in the engine compartment and a supplied data cable run up to the head >unit. >Do believe that both units are/will be certified. >I vote for the 2 box. Only because of my limited wireway space, and ease >of install. >Both units have the same exact functionality. > >Mitchell Goodrich >VariEze Tampa > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Randall Richter >Sent: Wednesday, January 18, 2006 5:56 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: EFIS Comparisons > > >--> > >Glad to hear they have listened to the masses! > >Randy > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Harley >Sent: Wednesday, January 18, 2006 5:45 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: EFIS Comparisons > >--> > >Randy... > >They have TWO versions...the Auracle I is for non-certified use, and >the > >Auracle II is for either certified or not...it is about $1500 more than >the non certified version. > >And, from their website: > >"Programming the Xerion */AuRACLE >(TM)/* is made quick and easy by >visiting www.xerionavionix.com and requesting your aircraft specific >data, downloading the file to your portable USB drive, and then plugging > >it into your */AuRACLE >(TM)/*. It's that simple!" > >The USB drive is included with the unit. > >Harley Dixon > > >Randall Richter wrote: > > > >> >> > > > >>I spoke to the rep at Oshkosh this summer and this seems like a very >>good product. The one thing that gives me pause is the fact that the >>software will not be user upgradeable. They will require you to remove >>the unit and send it in to them for upgrades. If I'm not mistaken, most >> >> > > > >>of the others provide updated software via removable card or something >>similar, right? >> >>He said this was because they're seeking certification and that's not >>allowed for certified products. Which tells me they won't have an >>"experimental" version of this system. >> >>Randy Richter >>-7QB coming along VERY slowly >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 18, 2006
Harley wrote: > If you talk to them, you might mention that there is some confusion, as > witnessed by our conversations here today. I sent them a number of queries. If anybody else is interested I will post the responses. Much of what I asked had to do with using it with a 9-cyl radial engine however. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Kevin, I will check again, but in my discussions with the FAA, Certed Engine Management Systems CANNOT be field upgradable, well unless its by the factory. So in reality they are, just not by the owner. Think about it, letting anyone change the funtionality of your planes critical engine instrument. The units are field configurable!! The software has to be Certified, and is intro'd into the field with no allowed changes. Each Cert'd AC and engine combo has its own parameters, no changes! Mitchell Goodrich -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brian Lloyd Sent: Wednesday, January 18, 2006 8:10 PM Subject: Re: AeroElectric-List: EFIS Comparisons --> Kevin Horton wrote: >>So we know that the FAA will certify devices that will allow field >>upgrades to the software in the box. > > > We know that some FAA Aircraft Certification Offices will certify > devices that will allow field upgrades to software in the box. Maybe > this is yet another area where different ACOs have different > interpretations. Or, maybe the way that the company wanted to handle > firmware upgrades didn't pass muster with the FAA (rightly or > wrongly), and they decided to drop that feature rather than spend the > money on a redesign. I've seen that scenario often enough in my day > job. Firmware updates in hex format over an RS-232 connection is just about as ugly as you can get. I can't imagine any way you could do a worse job of providing this function. (This is how both Sandel and Apollo/UPSAT/Garmin do it.) Therefore almost any other method makes more sense. The Xerion Auricle has USB bus master capability to write to a flash disk in order to write out stored engine data. This means they could also do updates this way too. I don't get it. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Brian - I'm interested in how 'proprietary' the data pipe between their two boxes (or coming out of one box) is. Standard CAN, RS-XXX, or something wacky? In other words, will their datastream be available for external products to 'sniff' for data? If you asked about that in/amongst your questions about your MOOSE of an engine (Russian?), I'd appreciate hearing the response(s). D Brian Lloyd wrote: > > Harley wrote: > > >>If you talk to them, you might mention that there is some confusion, as >>witnessed by our conversations here today. > > > I sent them a number of queries. If anybody else is interested I will > post the responses. Much of what I asked had to do with using it with a > 9-cyl radial engine however. > ________________________________________________________________________________
Date: Jan 18, 2006
Gordon or Marge Comfort wrote: > Brian: Can the ball be centered in the above scenario except if the > aircraft is in positive "G" flight? The aircraft must be in positive G flight for the ball to be centered. That does not mean it isn't inverted. > If that is the case, it seems you will > soon be past the vertical down line. Yes, but you might put the airframe well outside the envelope if you aren't careful. > If in negative "G" flight and the ball > is not centered, what is the correct pilot response? I was imagining an upset where the pilot "stops the turn" inverted and possibly nose pointed "down", i.e. toward the earth. In that case he/she will be positive G and accelerating. Imagine you are at the top of a loop. At that point you are wings level, inverted, and pulling positive G. As you pull through you remain positive G with increasing airspeed. Your airspeed will not decelerate until after you pulled through the bottom of the loop and the nose rises above the horizon. Regardless you will be positive G the whole way but you will gain lots of airspeed and lose a lot of altitude. But you asked about what to do if in negative G flight. Here is the recommendation for upset recovery. It works for an aircraft that has ended up either positive or negative G, upright or inverted. Upset recovery has the pilot getting the aircraft upright as quickly as possible. Standard upset recovery has the pilot pushing or pulling as necessary to "unload" the airframe so it is not pulling any significant G, either positive or negative, regardless of orientation, i.e. inverted or upright. The next response is to execute a roll to wings level. The last response is to execute a smooth pull-out without overstressing the airframe. One other thing: if the airspeed is increasing it is a good idea to reduce power/thrust to delay the arrival at Vne as long as possible. It turns out that the load limit of the airframe is for acceleration on one axis only. You can be pulling +3.8G (normal category aircraft) but you can't be rolling at the same time. The goal here is to avoid overstressing the airframe by pulling and rolling at the same time. So you unload, roll, and pull to nose level (or even nose up if you are going too fast). -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
Mitchell Goodrich wrote: > > Kevin, > > I will check again, but in my discussions with the FAA, > Certed Engine Management Systems CANNOT be field upgradable, > well unless its by the factory. So in reality they are, > just not by the owner. Think about it, letting anyone > change the funtionality of your planes critical engine instrument. > The units are field configurable!! That is funny. There is no such thing as a critical engine instrument. Our airplanes will fly safely without any engine instruments at all, except maybe a CHT indicator so we don't burn up the engine by keeping the cowl flaps closed. I would bet that I could fly any piston-powered aircraft to a safe landing without any engine damage after a loss of all engine instruments. I couldn't fly to a safe landing without my gyros (IFR). OTOH, I can update the software in my flight display instruments (Sandel in my case) or my navigation instruments (Apollo GPS/comm). What are they thinking? > The software has to be Certified, and is intro'd into the > field with no allowed changes. Each Cert'd AC and engine > combo has its own parameters, no changes! Again, that certainly is a chuckle. We use the same engine instruments without change on many different aircraft and engine combinations. I wonder what their justification is. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 18, 2006
D Wysong wrote: > > Brian - > > I'm interested in how 'proprietary' the data pipe between their two > boxes (or coming out of one box) is. Standard CAN, RS-XXX, or something > wacky? I hope it is CAN bus. > In other words, will their datastream be available for external > products to 'sniff' for data? I didn't ask but I am sure I will get around to it. It will probably be better for me to just call them and talk. I am sure that each answer will probably generate yet another question. > If you asked about that in/amongst your questions about your MOOSE of an > engine (Russian?), I'd appreciate hearing the response(s). No, I am not building a Moose. I have a Nanchang CJ6A trainer. The stock Chinese engine is a 9-cyl radial made by Huosai. We also like to replace the Chinese motor with a Vendenyev M14P which delivers 360hp instead of 285hp. The aircraft designer, Bushi Cheng, told us that the airframe was designed for a 400hp engine. Regardless, both engines are 9-cyl radials and need the same instrumentation. The only difference is that the M14P doesn't have a mixture control. It has an aneroid that adjusts the mixture in flight. The Huosai has a mixture control. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
From: "Mitchell Goodrich" <mgoodrich(at)tampabay.rr.com>
Date: Jan 18, 2006
Brian, in actuality Xerion's instrumentation is using Can-Aerospace Protocol. The system uses a dual-redundant CAN Network. Its their beleif that the CAN protocol is versatile and robust in high-noise enviroments which is why it is starting to be used more often in avionics, and is the choice in the auto industry........... Mitchell -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of D Wysong Sent: Wednesday, January 18, 2006 9:04 PM Subject: Re: AeroElectric-List: EFIS Comparisons Brian - I'm interested in how 'proprietary' the data pipe between their two boxes (or coming out of one box) is. Standard CAN, RS-XXX, or something wacky? In other words, will their datastream be available for external products to 'sniff' for data? If you asked about that in/amongst your questions about your MOOSE of an engine (Russian?), I'd appreciate hearing the response(s). D Brian Lloyd wrote: > --> > > Harley wrote: > > >>If you talk to them, you might mention that there is some confusion, >>as >>witnessed by our conversations here today. > > > I sent them a number of queries. If anybody else is interested I will > post the responses. Much of what I asked had to do with using it with > a 9-cyl radial engine however. > ________________________________________________________________________________
Date: Jan 18, 2006
Mitchell Goodrich wrote: > in actuality Xerion's instrumentation is using Can-Aerospace Protocol. > The system uses a dual-redundant CAN Network. Its their beleif that the > CAN protocol is versatile and robust in high-noise enviroments which is > why > it is starting to be used more often in avionics, and is the choice in > the > auto industry........... No need to tell me that. A couple of us started to design an cockpit instrumentation suite using a CAN bus running CAN-aerospace as an interconnect. CAN-bus is pretty slick. -- Brian Lloyd 2243 Cattle Dr. brian-yak at lloyd dot com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . - Antoine de Saint-Exupery ________________________________________________________________________________
Date: Jan 19, 2006
Subject: Re: Iso Amp - 2 stereo - 3 mono inputs
>Is there a clever way to add another stereo input? Don't know if it is clever, but..... May be the kits below: http://www.quasarelectronics.com/1010.htm http://www.quasarelectronics.com/1071.htm http://www.quasarelectronics.com/1050.htm The Garmin 396 is Stereo? Cool I did not know that. Is that part of the XM radio package? I guess I am wondering why do you need to listen to two stereo sources at the same time, but If you only need to listen to one at a time a simple toggle switching between the two stereo may be the only thing that you need. I might add that some intercoms don't do well with low gain output from small devices like iPod's, your results may vary. There are cool little stereo preamps electronic kits. Good Luck Pete. Cheers George From: "Pete Howell" <pete.howell@gecko-group.com> Subject: AeroElectric-List: Iso Amp - 2 stereo - 3 mono inputs <pete.howell@gecko-group.com> Hello, I am looking to integrate 2 stereo (Garmin 396 and Ipod) and 3 mono(EIS, Traffic, 1 extra) sources into my Flightcom 403. I have studied the design of Bob's Iso Amp and like it all except that it only accepts one stereo input. Is there a clever way to add another stereo input? Also, I contacted Flightcom and they suggested (good service - 3hr response to an e-mail) just adding 1:1 Isolation transformers (Radio Shack 273-1374) to the mono inputs and running all lines to Pin 21 - that way they will be unmuted. They did not have an answer for the twin stereo inputs. Any thoughts? Cheers,Pete --------------------------------- Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever. ________________________________________________________________________________
Date: Jan 19, 2006
Morning, Mitch.. >>you'll see that the 4 cyl is without sensors and the other is with sensors<< Ah, yes...you are correct...I see that now...guess I assumed that they would list the two units the same way...first without the sensors, then with them. If it fooled me, it probably caught a few others as well. Time for me to get back to the "cave" and the sanding... Harley Mitchell Goodrich wrote: > >Hey Harley, > >yeah they have a bit of work on the site to do. >If you look again, you'll see that the 4 cyl is >without sensors and the other is with sensors. >The actual diff between the1 and 2 box is bout 700.00 > > >Mitchell Goodrich >Modular Electric LLC >Managing Partner >813-356-9758 > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Harley >Sent: Wednesday, January 18, 2006 8:11 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: EFIS Comparisons > > >--> > >Evening, Mitch... > >Their website is a bit confusing then...I didn't see where it mentions >that one or two box option (but I think that I have noticed that at >least one other brand does the same thing), but it does say that the >Auracle I is for non-certified applications, and the Auracle II at $1500 > >more is for certified. > >Of course, the way it is phrased may simply mean that Auracle II is >ready for immediate certification where the Auracle I is not expected to > >be certified in the near future. > >If you talk to them, you might mention that there is some confusion, as >witnessed by our conversations here today. > >I won't be getting down there for awhile...it's snowing again here >...and I've been finishing the parts I brought back here in my >cellar...I'm all camped out in my warm cave until spring! > >Harley > > >Mitchell Goodrich wrote: > > > >>--> >> >>Hey Randy & Harley, >> >>The Auracle does come 2 different ways. A single box, which means all >>the senders are wired directly to the head unit, and a 2 box. The data >>aquisition unit mounted >>in the engine compartment and a supplied data cable run up to the head >>unit. >>Do believe that both units are/will be certified. >>I vote for the 2 box. Only because of my limited wireway space, and >> >> >ease > > >>of install. >>Both units have the same exact functionality. >> >>Mitchell Goodrich >>VariEze Tampa >> >> >> >>-----Original Message----- >>From: owner-aeroelectric-list-server(at)matronics.com >>[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>Randall Richter >>Sent: Wednesday, January 18, 2006 5:56 PM >>To: aeroelectric-list(at)matronics.com >>Subject: RE: AeroElectric-List: EFIS Comparisons >> >> >>--> >> >>Glad to hear they have listened to the masses! >> >>Randy >> >>-----Original Message----- >>From: owner-aeroelectric-list-server(at)matronics.com >>[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >>Harley >>Sent: Wednesday, January 18, 2006 5:45 PM >>To: aeroelectric-list(at)matronics.com >>Subject: Re: AeroElectric-List: EFIS Comparisons >> >>--> >> >>Randy... >> >>They have TWO versions...the Auracle I is for non-certified use, and >>the >> >>Auracle II is for either certified or not...it is about $1500 more than >>the non certified version. >> >>And, from their website: >> >>"Programming the Xerion */AuRACLE >>(TM)/* is made quick and easy by >>visiting www.xerionavionix.com and requesting your aircraft specific >>data, downloading the file to your portable USB drive, and then >> >> >plugging > > >>it into your */AuRACLE >>(TM)/*. It's that simple!" >> >>The USB drive is included with the unit. >> >>Harley Dixon >> >> >>Randall Richter wrote: >> >> >> >> >> >>> >>> >>> >>> >> >> >> >> >> >>>I spoke to the rep at Oshkosh this summer and this seems like a very >>>good product. The one thing that gives me pause is the fact that the >>>software will not be user upgradeable. They will require you to remove >>> >>> > > > >>>the unit and send it in to them for upgrades. If I'm not mistaken, >>> >>> >most > > >>> >>> >>> >>> >> >> >> >> >>>of the others provide updated software via removable card or something >>>similar, right? >>> >>>He said this was because they're seeking certification and that's not >>>allowed for certified products. Which tells me they won't have an >>>"experimental" version of this system. >>> >>>Randy Richter >>>-7QB coming along VERY slowly >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> >> > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 19, 2006
Subject: Floscan 201B varnish?
We are working on our 914 fuel system. It has 2 Floscan 201B transducers for flow gauge. I called Flowscan about installation, and was told if using mogas, you need to drain lines so there is no fuel in the transducer, or else the optics will get varnished over. He said 70 to 80% of the time you can take out the transducer and put a pipe plug in 1 end and use carb and choke cleaner and let it sit. But if that does not work the transducer is not serviceable. Have those out there using mogas and 201Bs been draining lines during times of inactivity? How many have needed to clean or replace 201Bs? Thx. Ron Parigoris ________________________________________________________________________________
Subject: T&B, etc.
Date: Jan 19, 2006
Bob and Brian, I enjoyed the 'byeplay' 'twixt methods explained in the use of the turn and Bank - which the Brits and others refer to as "turn and slip" indicators. Bob used the phrase "stop the turn" as a preliminary to escape from unusual positions. I'd like to modify that slightly - and welcome any remarks. As I remember, my cruel leader had me under the hood on limited panel (needle, ball and airspeed), and said, "I'll set you up, then give you control, and you regain straight and level flight". For five minutes we were all over the sky. If it weren't caged my A/H would have been broken. I felt about 3G, then weightless and the mighty leader said, "You have control". What he had done was to reef the machine to the vertical, bunted and applied full rudder. I can't tell you what excitement I experienced - until we were established in an inverted spin. The recovery was traumatic. He then explained - no other instrument could recover from that manoeuvre but the T&B. The first thing you gotta do is 'stop the yaw with the rudders, then assess the result, if airspeed then level the wings with the ailerons, and apply the throttle as required, bring her level and trim'. In ensuing weeks we expanded the idea, and soon I was happy if I had anything MORE than needle, ball and airspeed. So, Bob, maybe it should be Stop the Yaw, then Stop the Bank, then airspeed. What's true is that one must be familiar with the aircraft to get the most out of it - and perhaps few of us do that. Ferg PS: maybe it should be ball, needle and airspeed since that's the order of use. ________________________________________________________________________________
Subject: Garmin 396 to JPI FS-450 Fuel Flow Interface?
Date: Jan 19, 2006
Greetings; Does anyone have a means of connecting the new 396 to the FS-450 Fuel Flow monitor? A wiring diragram/hints/instructions would be greatly appreciated. Many Thanks; JC ________________________________________________________________________________
Date: Jan 19, 2006
Subject: Re: T&B, etc.
Fergus Kyle wrote: > > Bob and Brian, > I enjoyed the 'byeplay' 'twixt methods explained in the use of > the turn and Bank - which the Brits and others refer to as "turn and slip" > indicators. That is the term that appears in the training material that I use with my students. > Bob used the phrase "stop the turn" as a preliminary to escape from unusual > positions. And the more I think about it it, the more I agree with it. > I'd like to modify that slightly - and welcome any remarks. As I > remember, my cruel leader had me under the hood on limited panel (needle, > ball and airspeed), and said, "I'll set you up, then give you control, and > you regain straight and level flight". > For five minutes we were all over the sky. If it weren't caged > my A/H would have been broken. I felt about 3G, then weightless and the > mighty leader said, "You have control". What he had done was to reef the > machine to the vertical, bunted and applied full rudder. I can't tell you > what excitement I experienced - until we were established in an inverted
January 14, 2006 - January 19, 2006
AeroElectric-Archive.digest.vol-fh
