AeroElectric-Archive.digest.vol-ga
August 22, 2006 - August 28, 2006
      Lees Summit, MO
      matronics.com/Navigator?AeroElectric-List
Hello Bruce,
The flap switch would only be installed on the pilot's stick grip -- not co-pilot side. Also, the switch will be momentary and mounted on top of the stick making inadvertent activation difficult.
Have you considered what would happen if you or your passenger inadvertently activated the flap switch while as cruse speed? Normally, it's not a good idea to put switches on control sticks that if activated at the wrong time could adversely impact the safety of the aircraft.
Bruce
www.glasair.org
-----Original Message-----
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of wgill10(at)comcast.net
Sent: Tuesday, August 22, 2006 9:17 AM
Subject: AeroElectric-List: Flap switches/relay wiring
Im planning to install a switch for the flaps in the pilot stick grip in addition to the standard panel mounted switch that Vans supplies. Can I simply hook both switches to the same relay(s)? Any suggestions regarding relay (P/N & source). Thanks in advance for your assistance.
Bill Gill
RV-7 wiring
Lees Summit, MO
Subject: Re: RE: Pullable 80A Circuit Breaker
Date: Aug 22, 2006
While I am waiting for the real experts to weigh in, I offer the following unsubstantiated feeling: I don't think a cb "senses" either volts or amps. Rather it reacts to heat, whose generation is better measured in watts which is a function of both. I would therefore surmise that the cb in question would be well within its rated range; however would probably not trip a 14 volt load until 160 amps. well, where are the electro-experts now that we need them?? Denis Walsh On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote: > > > > Hi Stan- > >> I bought one at Sun n Fun only to discover later that it is 28v. > > 28V is the maximum system voltage for that CB. The CB you bought > should be > fine for your 14V installation. > > glen matejcek > aerobubba(at)earthlink.net > > ________________________________________________________________________________
Subject: Re: Flap switches/relay wiring
Date: Aug 22, 2006
On Tue Aug 22 09:56:28 2006, Robert L. Nuckolls, III wrote : >[ ... snip ... ] > Increased complexity of the flap controls that adds > the relatively un-robust and easy-to-hit stick grip > switches would not pass muster with the customers, > managers and regulators I work for. > > Flaps are used very sparingly during a flight. Uncontrolled > operation of flaps under certain conditions are a > recipe for a very bad day. I'll suggest that the > simplest wiring with the most robust components > will minimize probability of an unhappy event. For what its worth ...... I have a friend with an RV-7 who has a flap switch on his stick grip. It is on top, and he has _twice_ hit it while fiddling with charts/etc. in cruise. In both cases he caught it before there was a big problem ..... but he was NOT happy that it happened in either case. His conclusion is that the design is not a good one, for him at least. The flap-switch-on-the-stick idea sounded great to me until I heard my friend's story. I have decided that for me the flap switch is going on the panel within a convenient distance from the throttle. Still easy to get to in the pattern (my hand should be near the throttle most the time then anyway) and less likely to be hit accidentally. YMMV. -- Dwight ________________________________________________________________________________
Subject: Flap switches/relay wiring
Date: Aug 22, 2006
Well, whatever floats your boat. Good Luck! And be careful. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of wgill10(at)comcast.net Sent: Tuesday, August 22, 2006 10:54 AM Subject: RE: AeroElectric-List: Flap switches/relay wiring Hello Bruce, The flap switch would only be installed on the pilot's stick grip -- not co-pilot side. Also, the switch will be momentary and mounted on top of the stick making inadvertent activation difficult. Bill -------------- Original message -------------- From: "Bruce Gray" <Bruce(at)glasair.org> Have you considered what would happen if you or your passenger inadvertently activated the flap switch while as cruse speed? Normally, it's not a good idea to put switches on control sticks that if activated at the wrong time could adversely impact the safety of the aircraft. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of wgill10(at)comcast.net Sent: Tuesday, August 22, 2006 9:17 AM Subject: AeroElectric-List: Flap switches/relay wiring I'm planning to install a switch for the flaps in the pilot stick grip in addition to the standard panel mounted switch that Van's supplies. Can I simply hook both switches to the same relay(s)? Any suggestions regarding relay (P/N & source). Thanks in advance for your assistance. Bill Gill RV-7 wiring Lee's Summit, MO matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Aug 22, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> > > > Hi Stan- > > >I bought one at Sun n Fun only to discover later that it is 28v. > >28V is the maximum system voltage for that CB. The CB you bought should be >fine for your 14V installation. Glen is correct. I'll amplify his words with the notion that voltage ratings on switches and breakers are MAXIMUM level for operating voltage at the cited current level. There is no practical minimum voltage. See: http://aeroelectric.com/articles/swtchrat.pdf While this article speaks specifically to switches, the same ratings philosophies apply to breakers that are simply automated switches designed to sense current. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2006
Glen, CB's are rated in volts only to show what kind of circuit they should be used in. In other words don't use a breaker rated for 28 volts in a 120 volt circuit. A 28 volt breaker would IMHO be fine for use in a 12-14 volt circuit. It is in series with the load, so it can only know the current. It has no way of knowing the voltage or therefore the wattage of the load. It is heat activated by having a small amount of resistance, and the heating power is I*I*R. (I is current, and R is resistance.) This causes it to waste a little power (and voltage) in order to do its job. Dan Hopper RV-7A Playing with electricity since age 2 when I plugged a key into a wall outlet. Nothing happened so I plugged in another key. I'm told it sent me across the room. I've been hooked on the stuff ever since! In a message dated 8/22/2006 11:03:30 A.M. Eastern Daylight Time, denis.walsh(at)comcast.net writes: --> AeroElectric-List message posted by: Denis Walsh While I am waiting for the real experts to weigh in, I offer the following unsubstantiated feeling: I don't think a cb "senses" either volts or amps. Rather it reacts to heat, whose generation is better measured in watts which is a function of both. I would therefore surmise that the cb in question would be well within its rated range; however would probably not trip a 14 volt load until 160 amps. well, where are the electro-experts now that we need them?? Denis Walsh On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote: > --> AeroElectric-List message posted by: "glen matejcek" > > > > Hi Stan- > >> I bought one at Sun n Fun only to discover later that it is 28v. > > 28V is the maximum system voltage for that CB. The CB you bought > should be > fine for your 14V installation. > > glen matejcek > aerobubba(at)earthlink.net > > ________________________________________________________________________________
Date: Aug 22, 2006
Glen, Sorry, I should have said Stan at the top. I agree with you completely. Bob's post came in after I hit send, so I think we are all in agreement. Dan In a message dated 8/22/2006 12:02:38 P.M. Eastern Daylight Time, Hopperdhh(at)aol.com writes: Glen, CB's are rated in volts only to show what kind of circuit they should be used in. In other words don't use a breaker rated for 28 volts in a 120 volt circuit. A 28 volt breaker would IMHO be fine for use in a 12-14 volt circuit. It is in series with the load, so it can only know the current. It has no way of knowing the voltage or therefore the wattage of the load. It is heat activated by having a small amount of resistance, and the heating power is I*I*R. (I is current, and R is resistance.) This causes it to waste a little power (and voltage) in order to do its job. Dan Hopper RV-7A Playing with electricity since age 2 when I plugged a key into a wall outlet. Nothing happened so I plugged in another key. I'm told it sent me across the room. I've been hooked on the stuff ever since! In a message dated 8/22/2006 11:03:30 A.M. Eastern Daylight Time, denis.walsh(at)comcast.net writes: --> AeroElectric-List message posted by: Denis Walsh While I am waiting for the real experts to weigh in, I offer the following unsubstantiated feeling: I don't think a cb "senses" either volts or amps. Rather it reacts to heat, whose generation is better measured in watts which is a function of both. I would therefore surmise that the cb in question would be well within its rated range; however would probably not trip a 14 volt load until 160 amps. well, where are the electro-experts now that we need them?? Denis Walsh On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote: > > > > Hi Stan- > >> I bought one at Sun n Fun only to discover later that it is 28v. > > 28V is the maximum system voltage for that CB. The CB you bought > should be > fine for your 14V installation. > > glen matejcek > aerobubba(at)earthlink.net > > bsp; --> nbsp; - NEW MATRONICS LIST WIKI - ======================== (http://www.matronics.com/Navigator?AeroElectric-List) (http://www.matronics.com/contribution) ________________________________________________________________________________
Date: Aug 22, 2006
Err.. I am not an expert, but I don't think that is completely correct. Heat generated is correct, but the heat is generated solely by the current passing through the CB. The system voltage has no bearing on how much heat is generated. Draw the circuit and you can see why. The CB goes in series with the load. Beit a 2V or 200V system, a particular current through the CB causes a corresponding voltage drop across the CB while the CB is closed. The voltage rating is more related to the ability of the CB to open an operating (overloaded) circuit. The higher the system voltage the harder it is to open the circuit (break the current) for a given current. Voltage rating is likely about contact speed and distance (maybe not both). A larger system voltage implies the need for faster contacts and/or larger contact distance. Regards, Matt- > > > While I am waiting for the real experts to weigh in, I offer the > following unsubstantiated feeling: > > I don't think a cb "senses" either volts or amps. Rather it reacts > to heat, whose generation is better measured in watts which is a > function of both. > > I would therefore surmise that the cb in question would be well > within its rated range; however would probably not trip a 14 volt > load until 160 amps. > > well, where are the electro-experts now that we need them?? > Denis Walsh > > On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote: > >> >> >> >> Hi Stan- >> >>> I bought one at Sun n Fun only to discover later that it is 28v. >> >> 28V is the maximum system voltage for that CB. The CB you bought >> should be >> fine for your 14V installation. >> >> glen matejcek >> aerobubba(at)earthlink.net >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 22, 2006
On Tue Aug 22 10:53:49 2006, wgill10(at)comcast.net wrote : >Hello Bruce, > >The flap switch would only be installed on the pilot's stick grip -- not >co-pilot side. Also, the switch will be momentary and mounted on top of >the stick making inadvertent activation difficult. One followup note ... while I (strongly!) agree that having the flap switch on the co-pilot's stick would be bad news, I disagree with the statement that putting it on top of the stick would make inadvertant activation difficult. My friend has his flap switch on the top of the stick in his RV-7, and (as I said before) has accidentally deployed flaps (BRIEFLY, and only minimally, before he caught the mistake) at cruise speeds. This was due to messing with chart books while flying and having them bump the little momentary switch on top of the stick. Consider my comments only as food for thought and a story that speaks to the specific issue under debate. In the end you should clearly just do what you feel would work for you. -- Dwight ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
I get them for as little as under 25 cents each in qty of one (15 cents each for 100). All industrial electronic suppliers stock them in many types and brands. $30 will get you 100 parts including shipping in some cases. The cost difference is not significant in the big picture. Eric provides a value added KIT of parts etc its up to you to convert convenience for absolute cost. (Eric also posted the exact part number for those who wanted to get just the diodes from most any source as above) Relays with internal diodes are available simply because of demand, not for technical reasons. Engineers resist change and if it seems to work why change? Transorbs are better or (no worse in some opinions) and work in 100% of the cases. Its a "no brainier" for some of us. While they may not appear to make a difference in a 5 amp resistive load with a small relay, Transorbs are proven to have a large advantage in inductive and larger current loads with larger or different type relays. But so what! Bob has his "repeatable" test of one and is convinced he is right. One size (test) does not fit all cases and perhaps its 90% (for diodes) for the average aircraft but clearly not 99.99% based on MY own lab repeatable tests. The entire world, North America, and Europe for example, ALL say the same thing that Eric referenced about Diodes vs. Transorbs etc. Just who is out of step here???? There are hundreds in every modern auto. Given the number of autos made each year and yes Transorbs do cost more than simple diodes why would auto makers spend millions of $$ every year for them if the diode was as good and they could save all that money with diodes. Perhaps they know something not stated on this list?? If you look at the available data including the many references and read and understand the available info, its far more compelling than appears on the surface. Is "good enough" OK if you can get better for little more? I am unwilling to have another useless debate. It ends up with a lot of words/heat etc. and no opinion ever gets changed. Paul ----- Original Message ----- From: "Ernest Christley" <echristley(at)nc.rr.com> Sent: Tuesday, August 22, 2006 7:02 AM Subject: AeroElectric-List: Re: MOV's > > > >> >> >>Coil Suppression: >> >>Diodes are not the best method today. Not even the second-, third-, or >>fourth- >>best method. But in the 1960's they were the way to go. >> >> > In what aspect does the common, sub-$1, available-everywhere diode fall > short enough to justify paying $30 for your single-source solution? > > -- > ,|"|"|, Ernest Christley | > ----===<{{(oQo)}}>===---- Dyke Delta Builder | > o| d |o http://ernest.isa-geek.org | > > ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
> Coil Suppression: > > In what aspect does the common, sub-$1, available-everywhere diode fall > short enough to justify paying $30 for your single-source solution? > -- > ,|"|"|, Ernest Christley Ernest, See both of the links I posted, ref: http://relays.tycoelectronics.com/kilovac/appnotes/transients.asp See: http://www.periheliondesign.com/suppressors/SnapJack.pdf but especially: http://relays.tycoelectronics.com/kilovac/appnotes/fig48.asp You are incorrect on several points-- These are not single sourced. Every manufacturer of bi-directional Zener transient voltage suppressors seems to have a trademarked name for these: Transils, Surmetics, Transorbs, TranZorbs, TransGuards, Mosorbs; the list is endless. We call them SnapJacks. They are 18 Volt 600 Watt axial-lead bi-directional Zener transient voltage suppressors, part number P6KE18CA. The kit includes: (12) P6KE18CA (24") of suitable heat shrink tubing, (4) 1/4" faston solder adaptors (10) 6-8-10 Multistud ring tongue connectors (2) 1/4" ring tongues (2) 5/16" ring tongues (4) Faston tabs rivet or screw mount (1) Instructions and technical details, (1) Perihelion Design catalog (1) Free first-class shipping My accountant says I lost $xx,xxx on my little business in '04 and will maybe break even in '05 and '06, due entirely to my Space Shuttle Switch Guards that I sell to NASA (Perihelion Design parts are in orbit!) and the Military. Selling little SnapJack kits like this is a money loser no matter how you cut it, but I get to hang out with the most interesting people. That's worth a lot. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=56397#56397 ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
Ok, so translated into complete neophyte-speak, for the rest of "us", this means: " 1. The experts disagree (as they do in high vs low wing) 2. You can use a diode or a transorb, but do use something. 3. Pick whichever you find cheaper and more readily available. 4. A transorb can be wired up either direction, while a diode must be wired with the correct polarity. " Dave Morris N5UP At 11:51 AM 8/22/2006, you wrote: > >I get them for as little as under 25 cents each in qty of one (15 >cents each for 100). All industrial electronic suppliers stock them >in many types and brands. $30 will get you 100 parts including >shipping in some cases. The cost difference is not significant in >the big picture. > >Eric provides a value added KIT of parts etc its up to you to >convert convenience for absolute cost. (Eric also posted the exact >part number for those who wanted to get just the diodes from most >any source as above) > >Relays with internal diodes are available simply because of demand, >not for technical reasons. Engineers resist change and if it seems >to work why change? > >Transorbs are better or (no worse in some opinions) and work in 100% >of the cases. Its a "no brainier" for some of us. > >While they may not appear to make a difference in a 5 amp resistive >load with a small relay, Transorbs are proven to have a large >advantage in inductive and larger current loads with larger or >different type relays. > >But so what! Bob has his "repeatable" test of one and is convinced >he is right. > >One size (test) does not fit all cases and perhaps its 90% (for >diodes) for the average aircraft but clearly not 99.99% based on MY >own lab repeatable tests. > >The entire world, North America, and Europe for example, ALL say the >same thing that Eric referenced about Diodes vs. Transorbs etc. Just >who is out of step here???? > >There are hundreds in every modern auto. Given the number of autos >made each year and yes Transorbs do cost more than simple diodes why >would auto makers spend millions of $$ every year for them if the >diode was as good and they could save all that money with diodes. >Perhaps they know something not stated on this list?? > >If you look at the available data including the many references and >read and understand the available info, its far more compelling than >appears on the surface. > >Is "good enough" OK if you can get better for little more? > >I am unwilling to have another useless debate. It ends up with a lot >of words/heat etc. and no opinion ever gets changed. > >Paul > > >----- Original Message ----- From: "Ernest Christley" <echristley(at)nc.rr.com> >To: >Sent: Tuesday, August 22, 2006 7:02 AM >Subject: AeroElectric-List: Re: MOV's > > >> >> >> >>> >>> >>>Coil Suppression: >>> >>>Diodes are not the best method today. Not even the second-, >>>third-, or fourth- >>>best method. But in the 1960's they were the way to go. >>> >>In what aspect does the common, sub-$1, available-everywhere diode >>fall short enough to justify paying $30 for your single-source solution? >> >>-- >> ,|"|"|, Ernest Christley | >>----===<{{(oQo)}}>===---- Dyke Delta Builder | >> o| d |o http://ernest.isa-geek.org | >> > > ________________________________________________________________________________
Date: Aug 22, 2006
In a message dated 8/22/2006 10:20:11 AM Eastern Standard Time, Bruce(at)glasair.org writes: Have you considered what would happen if you or your passenger inadvertently activated the flap switch while as cruse speed? Normally, it's not a good idea to put switches on control sticks that if activated at the wrong time could adversely impact the safety of the aircraft. Bruce www.glasair.org =================================== Yup! A quick Right Cross! This is preceded by the Co-Pilots Check List: 1 - Don't say anything. 2 - Don't touch anything. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 22, 2006
In a message dated 8/22/2006 11:05:53 AM Eastern Standard Time, dwight(at)openweave.org writes: The flap-switch-on-the-stick idea sounded great to me until I heard my friend's story. I have decided that for me the flap switch is going on the panel within a convenient distance from the throttle. Still easy to get to in the pattern (my hand should be near the throttle most the time then anyway) and less likely to be hit accidentally. YMMV. -- Dwight ================================= Dwight: Hitting the flap switch is just like hitting the Mic switch. It is something you learn ... NOT TO DO. None of us were born knowing how to fly, you just have to make a concuss effort. In all cases. It is like flying: To go DOWN you push down. To go UP you pull up. But what has always confused me is ... If you keep pulling UP you go DOWN? Go figure! Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
Comments by your numbers. 1. I only know one "expert" that disagrees with the use of transorbs. I am sure they are more but the overwhelming majority of my engineering associates agree with the "true experts in the field" of relays and contacts etc. 2. Sort of true in most cases. Not usually true with contactor type relays switching inductive loads for example. There are two issues the coil inductive kick that must be addressed that affects the driver of the coil and the relay contacts which can affect the switched load by delays (seldom) and slow opening which power contactors really have a large delay in many cases and the duration and magnitude of the slow opening of a large inductive load can be damaging. 3. Sure quality and use is trumped by price. 5 cents is better than 25 cents. Using the same logic go to your rat shack and get plastic crimp terminals as they are cheaper and easier to find. 4. Transorbs are both uni-directional and bi-directional. True in one case and polarity is important in the other. However a uni-directional transorb is no better than a diode, and is a diode in that use. Paul ----- Original Message ----- From: "Dave N6030X" <N6030X(at)DaveMorris.com> Sent: Tuesday, August 22, 2006 10:52 AM Subject: Re: AeroElectric-List: Re: MOV's > > > Ok, so translated into complete neophyte-speak, for the rest of "us", this > means: > > " > 1. The experts disagree (as they do in high vs low wing) > 2. You can use a diode or a transorb, but do use something. > 3. Pick whichever you find cheaper and more readily available. > 4. A transorb can be wired up either direction, while a diode must be > wired with the correct polarity. > " > > Dave Morris > N5UP > > At 11:51 AM 8/22/2006, you wrote: >> >> >>I get them for as little as under 25 cents each in qty of one (15 cents >>each for 100). All industrial electronic suppliers stock them in many >>types and brands. $30 will get you 100 parts including shipping in some >>cases. The cost difference is not significant in the big picture. >> >>Eric provides a value added KIT of parts etc its up to you to convert >>convenience for absolute cost. (Eric also posted the exact part number for >>those who wanted to get just the diodes from most any source as above) >> >>Relays with internal diodes are available simply because of demand, not >>for technical reasons. Engineers resist change and if it seems to work why >>change? >> >>Transorbs are better or (no worse in some opinions) and work in 100% of >>the cases. Its a "no brainier" for some of us. >> >>While they may not appear to make a difference in a 5 amp resistive load >>with a small relay, Transorbs are proven to have a large advantage in >>inductive and larger current loads with larger or different type relays. >> >>But so what! Bob has his "repeatable" test of one and is convinced he is >>right. >> >>One size (test) does not fit all cases and perhaps its 90% (for diodes) >>for the average aircraft but clearly not 99.99% based on MY own lab >>repeatable tests. >> >>The entire world, North America, and Europe for example, ALL say the same >>thing that Eric referenced about Diodes vs. Transorbs etc. Just who is out >>of step here???? >> >>There are hundreds in every modern auto. Given the number of autos made >>each year and yes Transorbs do cost more than simple diodes why would auto >>makers spend millions of $$ every year for them if the diode was as good >>and they could save all that money with diodes. Perhaps they know >>something not stated on this list?? >> >>If you look at the available data including the many references and read >>and understand the available info, its far more compelling than appears on >>the surface. >> >>Is "good enough" OK if you can get better for little more? >> >>I am unwilling to have another useless debate. It ends up with a lot of >>words/heat etc. and no opinion ever gets changed. >> >>Paul >> >> >>----- Original Message ----- From: "Ernest Christley" >> >>To: >>Sent: Tuesday, August 22, 2006 7:02 AM >>Subject: AeroElectric-List: Re: MOV's >> >> >>> >>> >>> >>>> >>>> >>>>Coil Suppression: >>>> >>>>Diodes are not the best method today. Not even the second-, third-, or >>>>fourth- >>>>best method. But in the 1960's they were the way to go. >>>> >>>In what aspect does the common, sub-$1, available-everywhere diode fall >>>short enough to justify paying $30 for your single-source solution? >>> >>>-- >>> ,|"|"|, Ernest Christley | >>>----===<{{(oQo)}}>===---- Dyke Delta Builder | >>> o| d |o http://ernest.isa-geek.org | >>> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
True for a bi-directional transorb. But just to muddy the waters, I kind of like the more common uni-directional transorbs. They will still help with positive spikes (if you believe in positive spikes ;) ). Used across a contactor coil, they may delay the opening a smidge compared to a bidirectional transorb, but I suspect that, like the common diode, they are more effective at preventing negative spikes (if you believe in negative spikes comining off contactor coils ;) ). It seems to me that an 18 volt bidirectional transorb may still let negative spikes through that are large enough to damage electrolytic capacitors and perhaps solid state devices, if there is no battery in the circuit. I guess I used diodes on all the contactors and then added a few transorbs on the b-lead just because I could... Are automobiles incorporating transorbs within some devices now? I've never come across one yet that I've noticed. Ken > 4. A transorb can be wired up either direction, while a diode must be > wired with the correct polarity. > " ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
Dave, As a neophyte thanks for leading me to the bottom line here - THANK YOU !! Tony -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave N6030X Sent: Tuesday, August 22, 2006 10:53 AM Subject: Re: AeroElectric-List: Re: MOV's --> Ok, so translated into complete neophyte-speak, for the rest of "us", this means: " 1. The experts disagree (as they do in high vs low wing) 2. You can use a diode or a transorb, but do use something. 3. Pick whichever you find cheaper and more readily available. 4. A transorb can be wired up either direction, while a diode must be wired with the correct polarity. " Dave Morris N5UP At 11:51 AM 8/22/2006, you wrote: >--> > >I get them for as little as under 25 cents each in qty of one (15 >cents each for 100). All industrial electronic suppliers stock them >in many types and brands. $30 will get you 100 parts including >shipping in some cases. The cost difference is not significant in >the big picture. > >Eric provides a value added KIT of parts etc its up to you to >convert convenience for absolute cost. (Eric also posted the exact >part number for those who wanted to get just the diodes from most >any source as above) > >Relays with internal diodes are available simply because of demand, >not for technical reasons. Engineers resist change and if it seems >to work why change? > >Transorbs are better or (no worse in some opinions) and work in 100% >of the cases. Its a "no brainier" for some of us. > >While they may not appear to make a difference in a 5 amp resistive >load with a small relay, Transorbs are proven to have a large >advantage in inductive and larger current loads with larger or >different type relays. > >But so what! Bob has his "repeatable" test of one and is convinced >he is right. > >One size (test) does not fit all cases and perhaps its 90% (for >diodes) for the average aircraft but clearly not 99.99% based on MY >own lab repeatable tests. > >The entire world, North America, and Europe for example, ALL say the >same thing that Eric referenced about Diodes vs. Transorbs etc. Just >who is out of step here???? > >There are hundreds in every modern auto. Given the number of autos >made each year and yes Transorbs do cost more than simple diodes why >would auto makers spend millions of $$ every year for them if the >diode was as good and they could save all that money with diodes. >Perhaps they know something not stated on this list?? > >If you look at the available data including the many references and >read and understand the available info, its far more compelling than >appears on the surface. > >Is "good enough" OK if you can get better for little more? > >I am unwilling to have another useless debate. It ends up with a lot >of words/heat etc. and no opinion ever gets changed. > >Paul > > >----- Original Message ----- From: "Ernest Christley" > >To: >Sent: Tuesday, August 22, 2006 7:02 AM >Subject: AeroElectric-List: Re: MOV's > > >> >> >> >>> >>> >>>Coil Suppression: >>> >>>Diodes are not the best method today. Not even the second-, >>>third-, or fourth- >>>best method. But in the 1960's they were the way to go. >>> >>In what aspect does the common, sub-$1, available-everywhere diode >>fall short enough to justify paying $30 for your single-source solution? >> >>-- >> ,|"|"|, Ernest Christley | >>----===<{{(oQo)}}>===---- Dyke Delta Builder | >> o| d |o http://ernest.isa-geek.org | >> > > ________________________________________________________________________________
Date: Aug 22, 2006
Barry and all Some builders I know of even went one step farther : they put the flap switch IN THE PLACE of the trim switch. Thus they ensure consistent inadvertent operation at the worst possible time, as often as possible ;-) One of them even wrote to a flying magazine, to tell how the aircraft was dangerous, since his wife retracted the flaps during take-off ! > > Hitting the flap switch is just like hitting the Mic switch. It is > something you learn ... NOT TO DO. > If you have to learn not to actuate the switch, then it is misplaced. In 14 years teaching to fly, I never had to teach not to inadvertently actuate a correctly place flap lever or switch. You can also put the MP gauge behind the wheel at the bottom of the left panel, and the rev counter at the far right, like in some certified ships. Some aircraft builders take pride at confusing pilots. And yet, human factors and ergonomics have improved since WW I ;-))) http://contrails.free.fr/instruments_ergo.php Best regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Flap switches/relay wiring)
A lot of people seem to want to move functions onto their stick or their throttle. I would counsel some thought about how you use that function before you rush to put it on your stick. The first question is; how much do you use that function? One of the popular functions to put on the stick seems to be the IDENT function of the transponder. How often does ATC ask you to squawk IDENT? Not very often. How hard is it to reach over and press the ident button on the xpdr? Probably not too hard. An IDENT button on your stick or yoke requires you do add wiring and a switch. How much is that likely to gain you in terms of ease of use? I bet that the total amount of effort required to push the IDENT button every time ATC asks you for the life of your airplane is less than the time it will take you to wire the switch. Not a great return on investment. Now, about the flaps. Again, this is not something you are going to be using over and over again in one flight. You are going to use it once or twice per flight. Again, no big impact to have to move your hand to a flap switch on the panel or near your throttle. Likewise something like that radio active/standby frequency toggle. Since you have to put your hand up to the radio to change the frequency anyway, you may as well press the button to toggle between active and standby. So think about the kinds of things you use over and over again in flight. The short list that comes to mind: 1. radio PTT 2. intercom PTT 3. speed brakes 4. trim 5. weapons select 6. weapons release There just isn't a whole lot more you are going to use enough to justify putting it on the stick or throttle so maybe you just want to keep it simple. Brian ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: Flap switches/relay wiring)
---- Brian Lloyd wrote: > > A lot of people seem to want to move functions onto their stick or their > throttle. I would counsel some thought about how you use that function > before you rush to put it on your stick. > > The first question is; how much do you use that function? One of the > popular functions to put on the stick seems to be the IDENT function of > the transponder. How often does ATC ask you to squawk IDENT? Not very > often. How hard is it to reach over and press the ident button on the > xpdr? Probably not too hard. An IDENT button on your stick or yoke > requires you do add wiring and a switch. How much is that likely to gain > you in terms of ease of use? I bet that the total amount of effort > required to push the IDENT button every time ATC asks you for the life > of your airplane is less than the time it will take you to wire the > switch. Not a great return on investment. > > Now, about the flaps. Again, this is not something you are going to be > using over and over again in one flight. You are going to use it once or > twice per flight. Again, no big impact to have to move your hand to a > flap switch on the panel or near your throttle. > > Likewise something like that radio active/standby frequency toggle. > Since you have to put your hand up to the radio to change the frequency > anyway, you may as well press the button to toggle between active and > standby. > > So think about the kinds of things you use over and over again in > flight. The short list that comes to mind: > > 1. radio PTT > 2. intercom PTT > 3. speed brakes > 4. trim > 5. weapons select > 6. weapons release > > There just isn't a whole lot more you are going to use enough to justify > putting it on the stick or throttle so maybe you just want to keep it > simple. > > Brian Listers, I suggest that having radio station Flip/Flop and Station Scan switch ( a single pole double throw momentary switch) is a very useful item to have on the stick. If the radio stack is located away from the co-pilot, it is a necessity for them. Charlie Kuss ________________________________________________________________________________
Date: Aug 22, 2006
Date: Aug 22, 2006
In a message dated 8/22/06 5:13:32 PM Eastern Daylight Time, Gilles.Thesee@ac-grenoble.fr writes: > If you have to learn not to actuate the switch, then it is misplaced. In > 14 years teaching to fly, I never had to teach not to inadvertently > actuate a correctly place flap lever or switch. > You can also put the MP gauge behind the wheel at the bottom of the left > panel, and the rev counter at the far right, like in some certified > ships. Some aircraft builders take pride at confusing pilots. > > And yet, human factors and ergonomics have improved since WW I ;-))) > http://contrails.free.fr/instruments_ergo.php > > Best regards, > Gilles Thesee > Grenoble, France > http://contrails.free.fr ========================== Gill: You are right! And to that I would add the problem twin Beech have with the placement of the Gear switch (saw that accident). And how may of your students have pulled MIXTURE instead if throttle? But, I'd bet the fellow did not brief his wife on the Copilot Check List. Take a look in current military aircraft ... Notice the MANY safety switches? F-4 use to pickle their entire Su-21 rocket pod because their gloves got caught on the switch ... Whoops Did I do that! There was an accident at a local airport ... Plane - C-150 Pilot - CFI Passenger - TV Cameraman The accident happened on take off ... As the plane was climbing out and luckily the plane did not go past the end of the runway. Lucky only because the end of the runway was a major 4 lane highway. The passenger moved his camera bag right on top of the (panel mounted) flap switch ... C-150's don't climb well with 40 Deg of flaps! All survived, but I'd bet that CFI does not get a job with a major airline. This leads to the professor's quote: "The only way to make something idiot proof, is to remove the idiot." Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
> >Dave, > >As a neophyte thanks for leading me to the bottom line here - THANK YOU !! > >Tony > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave >N6030X >Sent: Tuesday, August 22, 2006 10:53 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Re: MOV's > > >--> > >Ok, so translated into complete neophyte-speak, for the rest of "us", >this means: > >" >1. The experts disagree (as they do in high vs low wing) >2. You can use a diode or a transorb, but do use something. >3. Pick whichever you find cheaper and more readily available. >4. A transorb can be wired up either direction, while a diode must be > wired with the correct polarity. Actually, Transorbs come in two flavors . . . uni-polar and bi-polar. Something else to keep in mind is that a Transorb is just a special variant of a zener diode. Zeners are intended for continuous duty, relatively hi energy dissipation, voltage regulation or limiting tasks and have sharper regulation characteristics than Transorbs which are optimized for short duration, relatively hi power but low energy clamping tasks. They have a might higher dynamic resistance than zeners while performing their "regulation" function. Many companies supply relays with diodes and/or diode-zener combinations already installed inside their product. For example, the S702-1 intermittent duty contactor we used to sell has the coil suppression diode built in. If one checks out the data sheet at: http://www.azettler.com/pdfs/technical_notes.pdf on page 6 we see various coil suppression techniques discussed. Incidently, the "varistor" technique at the bottom of the page is the MOV technique we've been discussing. Note that the diode-only technique is shown along with a notice that it offers long delays for release time which is consistent with the experimental data I posted earlier. Note further that there is no suggestion that this technique not be used in favor of another technique. One presumes that choices are driven by differences in circuit performance and not by a desire to minimize stresses harmful to the relay. On the same page we see the zener (transorb)-diode technique. Note that a diode is used with a zener because it too is a uni-polar device. The diode is necessary to prevent forward conduction of the zener during times the relay is energized but still allows the zener to do its voltage clamping thing during coil-spike-time. One could, of course, use the bi-polar Transorb in place of a zener (transorb)-diode network. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2006
>So think about the kinds of things you use over and over again in >flight. The short list that comes to mind: > >1. radio PTT >2. intercom PTT >3. speed brakes >4. trim >5. weapons select >6. weapons release >There just isn't a whole lot more you are going to use enough to justify >putting it on the stick or throttle so maybe you just want to keep it >simple. Well, if we're going off on this tack I would add -Master mode select (air-to-ground, air-to-air, nav, approach) -AAM cage/uncage -Waypoint step up -Weapon aiming sensor select -Sensor slew/zoom/track/scan -Autopilot/stabs disconnect -Chaff/flare release What's appropriate to small airplanes (as well as those Brian mentioned)? Autopilot disconnect Possibly waypoint step up if your GPS/EFIS allows Where's the flap switch? On the panel in front of the throttle Radio tune/flip flop? On the up front controller (just below the HUD) Waypoint insert/select? Up front controller So for those actions that are done a lot (radio tune), where you have to look in, put the box just below the glare shield so that you move your eyes a minimum distance. Might as well learn something from all those taxpayer $$$! BTW some 2 seat Pitts' had the PTT on the throttle - always seemed like a good idea if you expect to have an autopilot in the right seat. Pete ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
Comments by your numbers. 1. I only know one "expert" that disagrees with the use of transorbs. I am sure they are more but the overwhelming majority of my engineering associates agree with the "true experts in the field" of relays and contacts etc. Who's claiming to be an expert? Please cite the writings of any other individual who has measured, illustrated and explained variabilities and their effects in the manner which I've offered. The name, job title and organization of any such individual are unimportant. The numbers and explanations are. Good data and experimental technique stands by itself because it (1) makes sense and/or (2) is easily supported (or refuted) by repeating the experiment. I can demonstrate at least three cases in the past 8 years where the best that some big-name companies could bring to bear on high dollar problems was insufficient to the task. Instead of getting their fast-turn advice on how best to deduce failures of their products, it took me months and in one case years to figure it out for myself. In the end, I knew more about some aspects of their product than they did. 2. Sort of true in most cases. Not usually true with contactor type relays switching inductive loads for example. There are two issues the coil inductive kick that must be addressed that affects the driver of the coil and the relay contacts which can affect the switched load by delays (seldom) and slow opening which power contactors really have a large delay in many cases and the duration and magnitude of the slow opening of a large inductive load can be damaging. If I read this correctly, you're citing the occasional system performance issue where a 12 mS dropout delay is okay but a 60+ mS delay causes problems. Yes, I've had to deal with a few systems where multiple relays could get into operating "races" and produce unpredictable and unsatisfactory performance. I know of no situation in OBAM aviation where this could be an issue. However, in the last sentence you seem to be speaking of contact spreading velocity which I've shown is mildly affected by the form of coil spike suppression. 3. Sure quality and use is trumped by price. 5 cents is better than 25 cents. Using the same logic go to your rat shack and get plastic crimp terminals as they are cheaper and easier to find. Price has nothing to do with the design points under discussion. MOVs were attractive to me early on in spite of their price BECAUSE they were bi-directional devices. I reasoned that use of the MOV would prevent the occasional accidental mis-wiring that is possible with the decidedly uni-directional nature of diodes. However, they did not perform as well as diodes for the purpose of reducing stress on the controlling switch. Further, they were hard to find in very low conduction voltage ratings. I abandoned them in my writings after a few years in favor of readily available, lower cost, better performing, plain vanilla diode. 4. Transorbs are both uni-directional and bi-directional. True in one case and polarity is important in the other. However a uni-directional transorb is no better than a diode, and is a diode in that use. In fact, you cannot use a uni-directional Transorb (or plain-vanilla zener) unless combined with a diode to prevent forward conduction as shown in multitudes of catalogs and literature on relays. Paul At 11:51 AM 8/22/2006, you wrote: I get them for as little as under 25 cents each in qty of one (15 cents each for 100). All industrial electronic suppliers stock them in many types and brands. $30 will get you 100 parts including shipping in some cases. The cost difference is not significant in the big picture. Agreed. Let us leave cost out of it. Eric provides a value added KIT of parts etc its up to you to convert convenience for absolute cost. (Eric also posted the exact part number for those who wanted to get just the diodes from most any source as above) Relays with internal diodes are available simply because of demand, not for technical reasons. Engineers resist change and if it seems to work why change? ???? Really. You don't speak very highly of engineers. Stuck in ruts (do they never seek to broaden their horizons?) Further, they're willing to accept anything that "seems" to work. Don't you think it's incumbent upon the savvy engineer to KNOW how and why things work and not rely on mortal perception? Perhaps I benefited from not having finished school if I avoided that upper level class: Ruts and Perceptions 425 - Recipes for Failure. Transorbs are better or (no worse in some opinions) and work in 100% of the cases. Its a "no brainier" for some of us. How are they "better"? I've never said that they SHOULD NOT be used or that they were somehow inferior. The only thing I've said and demonstrated was that there is no measurable value FOR using them. The difference between NO suppression (open circuit) and the most aggressive suppression (diode) was a spread of 10% in arc-time during contact opening. A diode-transorb combo would fall somewhere in between. This means that the delta for diode-transorb versus diode-only could be as little as 1% and maybe as much a 9% . . . that was the point of the experiment, to put some bounds on a spread. Further, it's the only claim being made from analysis of the data. While they may not appear to make a difference in a 5 amp resistive load with a small relay, Transorbs are proven to have a large advantage in inductive and larger current loads with larger or different type relays. Please cite the experiments and the resulting data. Keep in mind that off-the-shelf relays of ALL sizes are available with nothing, diode-zener and diode only coil suppression. If one technique were so decidedly favorable over another technique, why hasn't the relay and contactor industry all jumped onto one bandwagon as your "entire world" citation below suggests they should? But so what! Bob has his "repeatable" test of one and is convinced he is right. I gathered data on one relay and tested three others of various sizes from 2 to 30 or so amps. The measured results with respect to effects on contact spreading velocity were similar. If the test was poorly crafted then it should be no big deal to demonstrate my error. One size (test) does not fit all cases and perhaps its 90% (for diodes) for the average aircraft but clearly not 99.99% based on MY own lab repeatable tests. Please share the data of your tests. What size relay would you like to see data on? I have some real honkers. I think I could do a 400A interrupt experiment for you. Let us compare notes. The entire world, North America, and Europe for example, ALL say the same thing that Eric referenced about Diodes vs. Transorbs etc. Just who is out of step here???? Please cite the literature. You've cited applications literature on Transorbs before that was shown to be overstated or when it came to over-voltage and load-dump mitigation. You once advocated a generous sprinkling of Transorbs on the bus . . . one for every breaker as I recall. The Transorb is a high power, low energy device well suited for mitigating short duration events . . . lightning strikes and ESD. I'm well aware of their usefulness. I stuck an array of Transorbs on an electro-whizzy just this weekend so that I could pass and ESD test in the lab tomorrow morning. At the same time, others here on the list have shown that the Transorb is not suited to a load-dump mitigation without deliberate impedance limiting of the energy source (just like the manual says). In this discussion, we're definitely in the short duration, low energy realm where a Transorb thrives. But I'll say again, I'm not campaigning against Transorbs for this application. I'm only stating that there's no compelling evidence support superior performance over the lowly diode for coil suppression when it comes to fending off the contact-eating gremlins. There are hundreds in every modern auto. Given the number of autos made each year and yes Transorbs do cost more than simple diodes why would auto makers spend millions of $$ every year for them if the diode was as good and they could save all that money with diodes. Perhaps they know something not stated on this list?? Perhaps you have special knowledge of the reasoning behind their use? Yes, we use hundreds of them on airplanes too, but they're not used on large contactors in lieu of diodes . . . for the reasons I've cited. If you look at the available data including the many references and read and understand the available info, its far more compelling than appears on the surface. Let us not talk about "surface" or "appearances". How about physics of test setups and numbers derived therefrom. Is "good enough" OK if you can get better for little more? I am unwilling to have another useless debate. It ends up with a lot of words/heat etc. and no opinion ever gets changed. It is not my wish to convince you or anyone else of anything sir. It's my intent to explain things and support my explanations with demonstrable fact and logical conclusions based on those facts. If I am in error, nobody would be happier to know the nature of the error than I. Go to the lab sir. Show us the data you've collected. I need to know how I screwed up. You name the test conditions and I'll repeat the test so we can compare results. This is where the debate becomes useful . . . not to you or I but to those who choose to read it and deduce facts of the matter for themselves. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
> >True for a bi-directional transorb. But just to muddy the waters, I kind >of like the more common uni-directional transorbs. They will still help >with positive spikes (if you believe in positive spikes ;) ). Used across >a contactor coil, they may delay the opening a smidge compared to a >bidirectional transorb, but I suspect that, like the common diode, they >are more effective at preventing negative spikes (if you believe in >negative spikes comining off contactor coils ;) ). It seems to me that >an 18 volt bidirectional transorb may still let negative spikes through >that are large enough to damage electrolytic capacitors and perhaps solid >state devices, if there is no battery in the circuit. I guess I used >diodes on all the contactors and then added a few transorbs on the b-lead >just because I could... > >Are automobiles incorporating transorbs within some devices now? I've >never come across one yet that I've noticed. > >Ken > >>4. A transorb can be wired up either direction, while a diode must be >>wired with the correct polarity. >>" A contactor coil can generate spikes of either polarity. It depends on how you switch it. Here's a trace I took off the coil of a Cole-Hersee battery contactor with no coil suppression. I dug through the archives and found some more data on devices common to the OBAM aviation electrical systems. See: http://www.aeroelectric.com/Pictures/Curves/CH_Bus_Noise_w_0p1_Cap.gif Here you see a 300+ volt POSITIVE spike because the controlling switch (battery master) is in the ground lead. Note that with as little as 0.1 uF capacitor on the supply plus whatever the bench supply (3A regulated) impedance was, the spike noise coupled to the bus was on the order of one or two volts high. And this may have been a test setup artifact (meaning smaller than observed). The point of this setup was to show that coil spikes are a danger only to the controlling device (in this case, battery master switch) and NOT to other devices on the bus. These spikes DO NOT propagate about the system on the lookout for vulnerable electro-whizzies. The next trace . . . http://www.aeroelectric.com/Pictures/Curves/CH_w_120_Ohm.gif shows the coil suppression benefits of a simple resistor. In this case, 120 ohms. The spike is notably smaller, only 90 volts or so and again, the spike coupled to the bus was tiny by comparison and probably not "real". Note the 22 mS release time for the contactor. The next trace . . . http://www.aeroelectric.com/Pictures/Curves/CH_w_1n5400.gif shows what happens with the plain diode spike suppressor. Note the very slight upward inflection of trace #2 above bus voltage where the coil energy is staining against the diode's forward voltage drop as positive going spike is clamped off. Note the 75 mS release time. The next trace . . . http://www.aeroelectric.com/Pictures/Curves/CH_w_2x18v_Transorbs.gif shows the results of a pair of 18v Transorbs (or zeners) hooked back to back to emulate the bi-directional device. Here the spike clamps off at an expected level of about 18 volts above bus voltage and we see a release time of about 14 mS. The next trace . . . http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_without_Diode.gif Shows a Cole-Hersee contactor release time ploted at some other time without a diode but this time, I captured the release time of 11 mS. The next trace . . . http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_with_Diode.gif is for the same relay and shows a 53 mS release time, again about 5x the no-diode time noted above. This data is proprotionally consistant with numbers I posted for the smaller relay earlier. Note also that one experiment with the CH contactor and diode yielded a 75 mS release time while the second was only 53 mS. This variability is to be expected and is driven by many factors including contactor temperature and manufacturing variables. The effects of any one suppression technique can be accurately compared only when all techniques are used on the same contactor and done with some effort to keep the contactor temperature constant for each experiment. Note that NONE of these traces went to the issue of contact spreading velocity and resulting arc durations . . . only changes in release time for the various techniques with a peripheral look at spike propagation to the bus. This series of traces serves to illustrate only the variability of release time which a number of articles have mistakenly assumed that proportionate decreases in contact spreading velocity automatically follow. I'll suggest that the assumed proportionality does not exist and that their is no demonstrable advantage for using one suppression technique over another in terms of performance. That suggests we're free to choose techniques based on price. The plain vanilla diode is hard to beat for price and wide spread availability. However, I'd be delighted to be shown wrong if my suggestion is in error. Bob . . . ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
I cannot let this get past as your statement is in fact TOTALLY technically incorrect (vs opinions). Below requests for links must exclude your own as they need to be unbiased! ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 7:32 PM Subject: Re: AeroElectric-List: Re: MOV's > In fact, you cannot use a uni-directional Transorb (or > plain-vanilla zener) unless combined with a diode to > prevent forward conduction as shown in multitudes of catalogs > and literature on relays. Please tell the LIST (specific link please) where a 50V uni-directional Transorb device (properly connected) is different from a 50v diode in coil supression or forward conduction for that matter. Of course if you use a Transorb alone as a diode its no better than a diode so that configuration is not addressed. Both forward conduct and both block at voltages under 50V. Heck the common 50V Zener is the same in that respect. Both also conduct in both directions if the breakdown V is exceeded. I thought we agreed the Transorb is like a zener with the special charactericts (specifically its designed for HUGE " zener current" for a very short time and perhaps 10,000 times faster as the normal Zener which is not capable of fast enough response to perform the function of transient supression. Please show me ANY reference that supports your statement (link please) that a single transorb is NOT exactly like a diode when used in relay coil supression just by its self and PROPERLY connected to work as a diode. Or a Zener for that matter. In a pinch a zener or a uni-directional transorb can act as a diode in non critical circuits as long as the Voltage rating is observed. Finally is there (in the industry) any statements that state that a diode is BETTER than a Transorb as you suggest?? (Please supply a link) I sure have not seen any and I have looked as has Eric and together we have found many to look at here and in Europe. EVERY reference we have found stated the diode is not as good as the transorb, or (Zener/diode combination). In fact the LEAST preferred part on EVERY list is the diode. Not that diodes work OK in most applications usually discussed on this list Paul ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 22, 2006
As I have stated in my original post which you (apparently do not want to respond to) I will not get into a debate with you ever again (actually on ANY subject) and this subject (transorbs) has been debated between us starting nearly 10 years ago. If you truly are interested in the reasons (pros and cons) of the various types of coil suppression please consider reviewing the references Eric posted as your reference had little info other than to illustrate the types of suppression relay delays. Yes (as you have stated) the total circuit (not just the coil) drives the suppression method and Transorbs always work and diodes only usually work. I will not respond to your comments below (however erroneous some may be) as there is no point. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 7:32 PM Subject: Re: AeroElectric-List: Re: MOV's > > > > > > Comments by your numbers. > > 1. I only know one "expert" that disagrees with the use of transorbs. I am > sure they are more but the overwhelming majority of my engineering > associates agree with the "true experts in the field" of relays and > contacts etc. > > Who's claiming to be an expert? Please cite the writings > of any other individual who has measured, illustrated and > explained variabilities and their effects in the manner > which I've offered. The name, job title and organization > of any such individual are unimportant. The numbers and > explanations are. Good data and experimental technique > stands by itself because it (1) makes sense and/or (2) > is easily supported (or refuted) by repeating the experiment. > > I can demonstrate at least three cases in the past 8 years > where the best that some big-name companies could bring to > bear on high dollar problems was insufficient to the task. > Instead of getting their fast-turn advice on how best to > deduce failures of their products, it took me months and > in one case years to figure it out for myself. In the end, > I knew more about some aspects of their product than they > did. > > > 2. Sort of true in most cases. Not usually true with contactor type relays > switching inductive loads for example. There are two issues the coil > inductive kick that must be addressed that affects the driver of the coil > and the relay contacts which can affect the switched load by delays > (seldom) and slow opening which power contactors really have a large delay > in many cases and the duration and magnitude of the slow opening of a > large inductive load can be damaging. > > If I read this correctly, you're citing the occasional > system performance issue where a 12 mS dropout delay > is okay but a 60+ mS delay causes problems. Yes, I've > had to deal with a few systems where multiple relays could > get into operating "races" and produce unpredictable and > unsatisfactory performance. I know of no situation in OBAM > aviation where this could be an issue. > > However, in the last sentence you seem to be speaking of > contact spreading velocity which I've shown is mildly > affected by the form of coil spike suppression. > > > 3. Sure quality and use is trumped by price. 5 cents is better than 25 > cents. Using the same logic go to your rat shack and get plastic crimp > terminals as they are cheaper and easier to find. > > Price has nothing to do with the design points under > discussion. MOVs were attractive to me early on in spite > of their price BECAUSE they were bi-directional devices. > I reasoned that use of the MOV would prevent the occasional > accidental mis-wiring that is possible with the decidedly > uni-directional nature of diodes. However, they did not > perform as well as diodes for the purpose of reducing stress > on the controlling switch. Further, they were hard to find > in very low conduction voltage ratings. > > I abandoned them in my writings after a few years in > favor of readily available, lower cost, better performing, > plain vanilla diode. > > > 4. Transorbs are both uni-directional and bi-directional. True in one case > and polarity is important in the other. > > However a uni-directional transorb is no better than a diode, and is a > diode in that use. > > In fact, you cannot use a uni-directional Transorb (or > plain-vanilla zener) unless combined with a diode to > prevent forward conduction as shown in multitudes of catalogs > and literature on relays. > > Paul > > At 11:51 AM 8/22/2006, you wrote: > > > I get them for as little as under 25 cents each in qty of one (15 cents > each for 100). All industrial electronic suppliers stock them in many > types and brands. $30 will get you 100 parts including shipping in some > cases. The cost difference is not significant in the big picture. > > Agreed. Let us leave cost out of it. > > > Eric provides a value added KIT of parts etc its up to you to convert > convenience for absolute cost. (Eric also posted the exact part number for > those who wanted to get just the diodes from most any source as above) > > Relays with internal diodes are available simply because of demand, not > for technical reasons. Engineers resist change and if it seems to work why > change? > > ???? Really. You don't speak very highly of engineers. Stuck > in ruts (do they never seek to broaden their horizons?) Further, > they're willing to accept anything that "seems" to work. Don't > you think it's incumbent upon the savvy engineer to KNOW how > and why things work and not rely on mortal perception? Perhaps > I benefited from not having finished school if I avoided that > upper level class: Ruts and Perceptions 425 - Recipes for > Failure. > > Transorbs are better or (no worse in some opinions) and work in 100% of > the cases. Its a "no brainier" for some of us. > > How are they "better"? I've never said that they SHOULD > NOT be used or that they were somehow inferior. The only > thing I've said and demonstrated was that there is no > measurable value FOR using them. > > The difference between NO suppression (open circuit) and > the most aggressive suppression (diode) was a spread of > 10% in arc-time during contact opening. A diode-transorb > combo would fall somewhere in between. This means that > the delta for diode-transorb versus diode-only could be > as little as 1% and maybe as much a 9% . . . that was > the point of the experiment, to put some bounds on a > spread. Further, it's the only claim being made from > analysis of the data. > > While they may not appear to make a difference in a 5 amp resistive load > with a small relay, Transorbs are proven to have a large advantage in > inductive and larger current loads with larger or different type relays. > > Please cite the experiments and the resulting data. > Keep in mind that off-the-shelf relays of ALL sizes > are available with nothing, diode-zener and diode > only coil suppression. If one technique were so > decidedly favorable over another technique, why > hasn't the relay and contactor industry all jumped > onto one bandwagon as your "entire world" citation > below suggests they should? > > But so what! Bob has his "repeatable" test of one and is convinced he is > right. > > I gathered data on one relay and tested three others of various > sizes from 2 to 30 or so amps. The measured results with respect > to effects on contact spreading velocity were similar. If the test > was poorly crafted then it should be no big deal to demonstrate > my error. > > One size (test) does not fit all cases and perhaps its 90% (for diodes) > for the average aircraft but clearly not 99.99% based on MY own lab > repeatable tests. > > Please share the data of your tests. What size relay would > you like to see data on? I have some real honkers. I think I > could do a 400A interrupt experiment for you. Let us compare > notes. > > The entire world, North America, and Europe for example, ALL say the same > thing that Eric referenced about Diodes vs. Transorbs etc. Just who is out > of step here???? > > Please cite the literature. You've cited applications literature > on Transorbs before that was shown to be overstated or when it > came to over-voltage and load-dump mitigation. You once advocated > a generous sprinkling of Transorbs on the bus . . . one for every > breaker as I recall. The Transorb is a high power, low energy > device well suited for mitigating short duration events . . . > lightning strikes and ESD. I'm well aware of their usefulness. I > stuck an array of Transorbs on an electro-whizzy just this weekend > so that I could pass and ESD test in the lab tomorrow morning. > > At the same time, others here on the list have shown that the > Transorb is not suited to a load-dump mitigation without > deliberate impedance limiting of the energy source (just > like the manual says). In this discussion, we're definitely in > the short duration, low energy realm where a Transorb thrives. > > But I'll say again, I'm not campaigning against Transorbs for > this application. I'm only stating that there's no compelling > evidence support superior performance over the lowly diode for > coil suppression when it comes to fending off the contact-eating > gremlins. > > There are hundreds in every modern auto. Given the number of autos made > each year and yes Transorbs do cost more than simple diodes why would auto > makers spend millions of $$ every year for them if the diode was as good > and they could save all that money with diodes. Perhaps they know > something not stated on this list?? > > Perhaps you have special knowledge of the reasoning behind their > use? Yes, we use hundreds of them on airplanes too, but they're > not used on large contactors in lieu of diodes . . . for the > reasons I've cited. > > If you look at the available data including the many references and read > and understand the available info, its far more compelling than appears on > the surface. > > Let us not talk about "surface" or "appearances". How about > physics of test setups and numbers derived therefrom. > > Is "good enough" OK if you can get better for little more? > > I am unwilling to have another useless debate. It ends up with a lot of > words/heat etc. and no opinion ever gets changed. > > It is not my wish to convince you or anyone else of anything > sir. It's my intent to explain things and support my explanations > with demonstrable fact and logical conclusions based on those > facts. If I am in error, nobody would be happier to know the > nature of the error than I. Go to the lab sir. Show us the > data you've collected. I need to know how I screwed up. You > name the test conditions and I'll repeat the test so we can > compare results. This is where the debate becomes useful . . . > not to you or I but to those who choose to read it and > deduce facts of the matter for themselves. > > Bob . . . > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > > ________________________________________________________________________________
Date: Aug 22, 2006
Subject: Re: MOV's
> > > > Coil Suppression: > > > > In what aspect does the common, sub-$1, available-everywhere diode fall > > short enough to justify paying $30 for your single-source solution? > > -- > > ,|"|"|, Ernest Christley > > >Ernest, > >See both of the links I posted, > >ref: http://relays.tycoelectronics.com/kilovac/appnotes/transients.asp Okay, lets take a look at this citation . . . ---------------------------------------------- * Improving Relay Operate Time Coil suppression can have a profound effect on opening time which is usually called "release time". The citation speaks of "operate time" which is usually the time it takes for a relay to close - which is NOT affected by the popular coil suppression techniques. * Calculating Pull-in & Drop-out Voltages at High or Low Temperatures * Radiation Exposure at High Voltage; Is it a Problem? * Power Conservation Schemes * High Voltage Processing of Vacuum Relays These points are not germane to the discussion at hand and will be ignored for the moment. "When a 28 Vdc relay coil is turned off, the inductive energy stored in it can create surge voltages to 1500 volts on a DC power line. With the increased use of solid state devices which are sensitive to spikes, relay coils must be suppressed to limit voltage spikes to a maximum of 50 to 80 volts." The first paragraph uses impressive numbers . . . 1500 volts will scare the pants off most neophytes. Of course, it's easy to sign up to the notion that solid state devices should be "protected" from such horrific stresses. The paragraph ends with an assertion that bringing the offending spike down to the 50-80 volt range is the magic bullet. But there's a glaring error . . . that 1500 volt spike DOES NOT propagate out onto the bus but instead is impressed across the mechanism of the controlling device be it switch or transistor. "The measure of successful coil suppression depends on the degree to which the method affects the operation of the relay. Improper or excessive suppression can cause the relay to suffer from a long release time, slow contact transfer, and contact bounce on break. All of these conditions will increase contact arcing when load switching, which will reduce relay life dramatically." Yes, slowed transfer and bounce are potentially hard on a relay. Delayed release is not hard on relays but may have an effect on system performance in time-critical situations . . . and were talking MILLISECOND criticality. The paragraph correctly infers that arcing is the proximate cause of reduced relay life. "There are a number of common ways for a relay user to suppress relay coil transients and each has advantages and disadvantages. However, the most widely used methods utilize zener-diode and/or zener-zener combinations. These combinations are compact, provide excellent suppression, and do not affect relay release-time or contact life." We've already demonstrated that the favorably rated zener-zener technique has SOME effect on release time. It's less effect than diode only but the effect is not zero. What is inferred and not supported is that diode only has a profound effect on relay life . . . an assertion I don't understand based on experiments I've conducted over the years. I've not yet been able to confirm the assertion on any size relay I've worked with to date. If someone cares to show me an experiment that supports the assertion, I'd be pleased to know of it. In the mean time, I'm inclined to treat the words of the cited posting with skepticism. They take a couple of true statements, a false statement and then infer some golden actions to be taken based on those statements. As I stated in an earlier post, there's a LOT of writing like that in the wild . . . In this case, the errors are not harmful. There's nothing inherently wrong with the proposed "gold standard" but the writing does not foster understanding. Instead, lots of myths are launched and preached as gospel because they came from the Tyco-Amp or P&B bibles. Bob . . . ________________________________________________________________________________
Subject: Re: MOV's/ opening arc
Date: Aug 22, 2006
I disagree that opening time is not significant as related to an aircraft application. I have done dozens of repeatable tests where the contact opening rate was the subject and have demonstrated the duration of the contact opening arc is extended and the arc intensity is much greater, specifically if you are looking at a big Contactor opening an inductor or generator like an alternator. This when the common diode is used across the coil. The issue of "opening time" is very important as the contact suppressor Transorb must absorb the energy from the alternator load dump over 50 ms vs. 10 ms (typical) and this means the transorb must be 5X bigger in heat rating. (The need for a contact suppressor is below a ways) The specific test set up is the contactor has either the diode or the bi-directional transorb across the coil and there is a uni-directional transorb clamping the alternator load dump on the alternator side of the contacts. The alternator is either properly running or has been failed to produce full output with no voltage control. Perhaps not clearly stated above, but the testing was done several years ago to simulate internal regulator alternators where the "B" lead was opened to protect the system (Or the pilot simply opened the "B" lead on a healthy alternator for what ever reason including the false triggering of a OV crow bar circuit. From the point of the opening of the relay coil to the end of the time the relay contacts are fully open the Transorb clipping the OV was tasked with clamping the voltage. The point is that with out the transorb to clamp the alternator output, the opening arc voltage jumped to over 100V and the open contacts continued to arc after they were fully open (this happens regardless of any OV crowbar present as the crow bar is on the other side of the open contacts). The Transorb on the alternator side clips the arc voltage during the opening process and only after the contacts were fully open and unable to restart an arc did the transorb fail short and then open. Thus the time from relay coil power off to final contact open determines the power rating of the transorb and using a diode across the coil added 40+ ms to the total time which is typically 5 times longer that the transorb must keep the alternator voltage in line if the transorb was across the coil. Further the duration and intensity of the arc was increased significantly. If the transorb was not rated high enough it failed during the process and the arc continued after the contacts were fully open. For example 50 amps for 50 ms is a lot of power for the common transorb and they fail short and then quickly fail open. Its well known that relays that are required to break DC voltages above the 40-50V range must use a arc quencher circuit or they usually will simply never stop arcing. Thus something is required to keep the arc voltage under say 35V until the contacts are well open where the contact gap is big enough to prevent a restart of the arc. My conclusion to the above tests is opening a failed internally regulated alternator where the failure was unregulated high voltage output is not as simple as some would believe and the "B" lead contactor (if not special design) has the potential to continue to arc after any type of OV protection has opened the contactor. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 8:23 PM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >>True for a bi-directional transorb. But just to muddy the waters, I kind >>of like the more common uni-directional transorbs. They will still help >>with positive spikes (if you believe in positive spikes ;) ). Used across >>a contactor coil, they may delay the opening a smidge compared to a >>bidirectional transorb, but I suspect that, like the common diode, they >>are more effective at preventing negative spikes (if you believe in >>negative spikes comining off contactor coils ;) ). It seems to me that >>an 18 volt bidirectional transorb may still let negative spikes through >>that are large enough to damage electrolytic capacitors and perhaps solid >>state devices, if there is no battery in the circuit. I guess I used >>diodes on all the contactors and then added a few transorbs on the b-lead >>just because I could... >> >>Are automobiles incorporating transorbs within some devices now? I've >>never come across one yet that I've noticed. >> >>Ken >> >>>4. A transorb can be wired up either direction, while a diode must be >>>wired with the correct polarity. >>>" > > A contactor coil can generate spikes of either polarity. It > depends on how you switch it. Here's a trace I took off the coil > of a Cole-Hersee battery contactor with no coil suppression. > I dug through the archives and found some more data on devices > common to the OBAM aviation electrical systems. See: > > http://www.aeroelectric.com/Pictures/Curves/CH_Bus_Noise_w_0p1_Cap.gif > > Here you see a 300+ volt POSITIVE spike because the controlling switch > (battery master) is in the ground lead. Note that with as little as > 0.1 uF capacitor on the supply plus whatever the bench supply > (3A regulated) impedance was, the spike noise coupled to the bus > was on the order of one or two volts high. And this may have been > a test setup artifact (meaning smaller than observed). The point of > this setup was to show that coil spikes are a danger only to the > controlling device (in this case, battery master switch) and NOT > to other devices on the bus. These spikes DO NOT propagate about > the system on the lookout for vulnerable electro-whizzies. > > The next trace . . . > > http://www.aeroelectric.com/Pictures/Curves/CH_w_120_Ohm.gif > > shows the coil suppression benefits of a simple resistor. In this > case, 120 ohms. The spike is notably smaller, only 90 volts > or so and again, the spike coupled to the bus was tiny by > comparison and probably not "real". Note the 22 mS release > time for the contactor. The next trace . . . > > http://www.aeroelectric.com/Pictures/Curves/CH_w_1n5400.gif > > shows what happens with the plain diode spike suppressor. > Note the very slight upward inflection of trace #2 above > bus voltage where the coil energy is staining against the > diode's forward voltage drop as positive going spike is > clamped off. Note the 75 mS release time. The next trace . . . > > http://www.aeroelectric.com/Pictures/Curves/CH_w_2x18v_Transorbs.gif > > shows the results of a pair of 18v Transorbs (or zeners) > hooked back to back to emulate the bi-directional device. > Here the spike clamps off at an expected level of about 18 volts > above bus voltage and we see a release time of about 14 mS. > The next trace . . . > > http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_without_Diode.gif > > > Shows a Cole-Hersee contactor release time ploted at some > other time without a diode but this time, I captured the > release time of 11 mS. The next trace . . . > > http://www.aeroelectric.com/Pictures/Curves/Cole-Hersee_with_Diode.gif > > > is for the same relay and shows a 53 mS release time, again > about 5x the no-diode time noted above. This data is proprotionally > consistant with numbers I posted for the smaller relay > earlier. Note also that one experiment with the CH contactor > and diode yielded a 75 mS release time while the second > was only 53 mS. This variability is to be expected and is > driven by many factors including contactor temperature and > manufacturing variables. The effects of any one suppression > technique can be accurately compared only when all techniques > are used on the same contactor and done with some effort to > keep the contactor temperature constant for each experiment. > > Note that NONE of these traces went to the issue of contact > spreading velocity and resulting arc durations . . . only changes > in release time for the various techniques with a peripheral look > at spike propagation to the bus. > > This series of traces serves to illustrate only the variability > of release time which a number of articles have mistakenly > assumed that proportionate decreases in contact spreading > velocity automatically follow. I'll suggest that the > assumed proportionality does not exist and that their is no > demonstrable advantage for using one suppression technique over > another in terms of performance. That suggests we're free to > choose techniques based on price. The plain vanilla diode is > hard to beat for price and wide spread availability. However, > I'd be delighted to be shown wrong if my suggestion is in error. > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: MOV's
> >I cannot let this get past as your statement is in fact TOTALLY >technically incorrect (vs opinions). > >Below requests for links must exclude your own as they need to be unbiased! > >----- Original Message ----- From: "Robert L. Nuckolls, III" > >To: >Sent: Tuesday, August 22, 2006 7:32 PM >Subject: Re: AeroElectric-List: Re: MOV's > > >> In fact, you cannot use a uni-directional Transorb (or >> plain-vanilla zener) unless combined with a diode to >> prevent forward conduction as shown in multitudes of catalogs >> and literature on relays. > >Please tell the LIST (specific link please) where a 50V uni-directional >Transorb device (properly connected) is different from a 50v diode in coil >supression or forward conduction for that matter. Okay, here's one. http://www.azettler.com/pdfs/technical_notes.pdf Check out the options on page 6. I see no instances of a single zener/transorb being suggested. How about . . http://relays.tycoelectronics.com/kilovac/appnotes/fig48.asp Again, where do we see the use of a single zener/transorb junction being suggested? >Of course if you use a Transorb alone as a diode its no better than a >diode so that configuration is not addressed. Agreed . . . but then it's not performing the zener style function that is being sought. You can certainly use the zener/transorb in this manner but why would you do that? I thought the plain-vanilla diode is now relegated to fifth rate performance in comparison to the latest and greatest answer to the airplane owners fondest dream: "Make my relays last forever". Of what value is it to have a single zener-transorb installed for the same purpose. Okay. Let's look at the drawing I posted at: http://www.aeroelectric.com/temp/Relay_Coil_Suppression.pdf In cases 1 and 2 we see an illustration of the phenomenon we're trying to control . . . tame the killer spike. In cases 3 and 4 we see the effects of the plain vanilla diode and it's ability to limit the coil collapse spike to under 1 volt. >Both forward conduct and both block at voltages under 50V. Heck the common >50V Zener is the same in that respect. In case 5 I show the only way a single transorb or zener can be employed in coil suppression. It's cathode must face the + side of the relay coil and, of course, the breakdown voltage of the device must exceed supply voltage. In the energized state, the zener is reverse biased at some point below breakdown voltage. In case 6, the coil's field collapse applies forward bias to the zener and it conducts just as an ordinary diode would as illustrated in case 4 above. I'll confess that my statement was in error to the effect that one MAY use a single zener/transorb but it's effect is no different than having used a plain vanilla diode so applying a zener in this manner is senseless in terms of using the zener's unique characteristics to achieve some design goal that a diode wont do. In case 7 and 8 I show the industry wide practice of adding both diode and zener in series but with the zener now turned over. In case 7, the diode prevents forward conduction of the zener during the energized state. In case 8 the coil's field collapse now forward biases the diode and reverse biases the zener such that it's now expected to conduct at some selected voltage to sink the coil's inductive energy. >Both also conduct in both directions if the breakdown V is exceeded. I >thought we agreed the Transorb is like a zener with the special >charactericts (specifically its designed for HUGE " zener current" for a >very short time and perhaps 10,000 times faster as the normal Zener which >is not capable of fast enough response to perform the function of >transient supression. Really? Zeners have been used in this application for decades. The techniques illustrated in cases 7/8 were developed and in service long before the advent of Transorbs. The relay coil spike is a rather sedate event compared to ESD and lightning and the plain zener's switching times have been and are still adequate to the task. >Please show me ANY reference that supports your statement (link please) >that a single transorb is NOT exactly like a diode when used in relay coil >supression just by its self and PROPERLY connected to work as a diode. Or >a Zener for that matter. > >In a pinch a zener or a uni-directional transorb can act as a diode in non >critical circuits as long as the Voltage rating is observed. Absolutely . . . and I can hold my pants up with a dab of super-glue on my butt. The question remains, why would one do that on purpose? >Finally is there (in the industry) any statements that state that a diode >is BETTER than a Transorb as you suggest?? I didn't say that. I said that there is no compelling reason to support the notion that diodes alone have a profound effect on relay service life which is the mantra used to sell the more expensive transorb. Both techniques are adequate to the spike suppression task but using service life as a compelling sales pitch for transorbs is not supported by the physics. > (Please supply a link) I sure have not seen any and I have looked as > has Eric and together we have found many to look at here and in Europe. > EVERY reference we have found stated the diode is not as good as the > transorb, or (Zener/diode combination). In fact the LEAST preferred part > on EVERY list is the diode. Yup, I'll agree with that. Most folks have taken up the mantra just as many others still believe we never went to the moon, that global warming is caused by too many SUVs and that pure democracy is the best way to run a planet. A preponderance of conforming opinion does not make it correct nor alter the laws of physics. > Not that diodes work OK in most applications usually discussed on this list Oops? Quantify "OK" . . . are you suggesting that the last few hours of explanation have all been for naught? Are you suggesting that the simple diode suppression technique is really okay after all? Gee Paul, I had some glimmer of hope that I was going to badger you into doing some real science after all these years and now you've gone all wobbly on me. Bob . . . ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: MOV's
> >As I have stated in my original post which you (apparently do not want to >respond to) I will not get into a debate with you ever again (actually on >ANY subject) and this subject (transorbs) has been debated between us >starting nearly 10 years ago. Yup, that conversation has been enshrined in bytes at http://aeroelectric.com/articles/spike.pdf >If you truly are interested in the reasons (pros and cons) of the various >types of coil suppression please consider reviewing the references Eric >posted as your reference had little info other than to illustrate the >types of suppression relay delays. Yes (as you have stated) the total >circuit (not just the coil) drives the suppression method and Transorbs >always work and diodes only usually work. I've read those references. And I've explained what I've found in them that was in error. If you want to worship at the altars of Tyco-Amp or Potter-Brumfield based on your blind acceptance of their Word, that's your choice . . . but expect to be challenged when you preach philosophies you cannot yourself explain. You expose yourself as a propagandist and not as a teacher. >I will not respond to your comments below (however erroneous some may be) >as there is no point. If you can't be a teacher then don't get into the sandbox to throw mud. Your drive-by insinuations that errors in my posting are unworthy of your time and effort is consistent with the behavior you favored 6 years ago. You stood off and threw rocks at my explanations and NEVER offered a single alternative supported by your own explanation of the underlying physics. You had plenty to complain about but never a plan consistent with anyone else's design goals but your own. You want to play? Fine. If not, then you know the way out. The unsubscribe link is: http://www.matronics.com/subscribe/ Bob . . . ________________________________________________________________________________
Date: Aug 23, 2006
Subject: B-lead Contactors (was MOV's)
> >I disagree that opening time is not significant as related to an aircraft >application. I didn't say that opening time (contact spreading velocity) was insignificant. Obviously, the slower moving contact keeps an arc established longer. What I said was that the benefits of any other coil suppression technique were not significantly better than the simple diode with respect to arc duration in the experiments I conducted. I.e, no compelling reason to take all the diodes out and put in bi-directional transorbs or transorb-diode networks. >I have done dozens of repeatable tests where the contact opening rate was >the subject and have demonstrated the duration of the contact opening arc >is extended and the arc intensity is much greater, specifically if you are >looking at a big Contactor opening an inductor or generator like an >alternator. This when the common diode is used across the coil. You use "extended" and "intensity" and "greater" which are non quantified. How much? And how does your experience illuminate the tasks before our readers on this List? >The issue of "opening time" is very important as the contact suppressor >Transorb must absorb the energy from the alternator load dump over 50 ms >vs. 10 ms (typical) and this means the transorb must be 5X bigger in heat >rating. (The need for a contact suppressor is below a ways) Opps! Stuck your foot in it sir. If you install a transorb as in cases 7/8 then the transorb is isolated from an alternator load dump by the accompanying diode. If you install per cases 5/6 then yes, alternator load dump is impressed across the transorb in the zener mode . . . but if this technique is no better than a simple diode for coil suppression, why do it? Use a plain vanilla diode and the "problem" goes away. >The specific test set up is the contactor has either the diode or the >bi-directional transorb across the coil and there is a uni-directional >transorb clamping the alternator load dump on the alternator side of the >contacts. The alternator is either properly running or has been failed to >produce full output with no voltage control. Now were far-afield from the original discussion. You've injected a feature (alternator load dump) that is a whole new consideration having nothing to do with what I was attempting to explain earlier this evening. >Perhaps not clearly stated above, but the testing was done several years >ago to simulate internal regulator alternators where the "B" lead was >opened to protect the system (Or the pilot simply opened the "B" lead on a >healthy alternator for what ever reason including the false triggering of >a OV crow bar circuit. From the point of the opening of the relay coil to >the end of the time the relay contacts are fully open the Transorb >clipping the OV was tasked with clamping the voltage. Fine. But what does that have to do with spike suppression on relay coils? >The point is that with out the transorb to clamp the alternator output, >the opening arc voltage jumped to over 100V and the open contacts >continued to arc after they were fully open (this happens regardless of >any OV crowbar present as the crow bar is on the other side of the open >contacts). The Transorb on the alternator side clips the arc voltage >during the opening process and only after the contacts were fully open and >unable to restart an arc did the transorb fail short and then open. Thus >the time from relay coil power off to final contact open determines the >power rating of the transorb and using a diode across the coil added 40+ >ms to the total time which is typically 5 times longer that the transorb >must keep the alternator voltage in line if the transorb was across the >coil. Further the duration and intensity of the arc was increased >significantly. If the transorb was not rated high enough it failed during >the process and the arc continued after the contacts were fully open. For >example 50 amps for 50 ms is a lot of power for the common transorb and >they fail short and then quickly fail open. Yes, but you're illuminating a separate issue. If the loads on a relay's contacts are particularly antagonistic such as during the load dump phenomenon on a b-lead contactor, then one has two possibilities. Increase ratings of the contactor or limit the load dump intensity or a combination of both. But this is a special case that is only slightly related to the original discussion. Further, the use of Transorbs on the b-lead contactor in lieu of diodes is not the ultimate solution. Further, getting the b-lead opened is only part of the task. How do you propose to bring a runaway alternator to heel . . . or is the plan to let it self-destruct? >Its well known that relays that are required to break DC voltages above >the 40-50V range must use a arc quencher circuit or they usually will >simply never stop arcing. Thus something is required to keep the arc >voltage under say 35V until the contacts are well open where the contact >gap is big enough to prevent a restart of the arc. >My conclusion to the above tests is opening a failed internally regulated >alternator where the failure was unregulated high voltage output is not as >simple as some would believe and the "B" lead contactor (if not special >design) has the potential to continue to arc after any type of OV >protection has opened the contactor. Absolutely . . . and I think there's a rational way to mitigate this. If current negotiations for an alternator drive stand work out, I'll be able to get the energy data you claimed to have but could/would not share some years ago. And guess what? As soon as I have the results of the tests, they will be published here and on my website. You see, I do intend to service my duty as teacher. Bob . . . ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: Flap switches/relay wiring)
Hi Dave, > > > How about putting the starter switch on the throttle, so you can do an > in-flight restart without taking your hands off the sticks and throttle. > Er, how many times in a flight do you restart your engine ? The last time I had to was 16 years ago, when the prop stopped in a vertical manoeuver during an advanced aerobatic contest. And yes, reaching for the starter switch during the 4 Gs pull out proved an interesting exercice. No one noticed from the ground. But what is the point in normal cases ? One very good location for the starter switch, is near the fuel valve, with an arrangement such that the switch is covered by the valve handle when in the closed position. No starting with the fuel valve closed. The ubiquitous (in France) Robin DR400 have this feature. PTT Trims Auto pilot disengage That's all I see necessary on the throttle and stick in a civilian airplane. Someone mentionned Intercom PTT, what's the use for such a device ? Best regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Aug 23, 2006
On Aug 23, 2006, at 5:22 AM, Bill Denton wrote: > > > Given that this started as a discussion of the hazards of having > the flap > control mounted on the stick, wouldn't mounting the speed brake > control on > the stick pose a similar hazard? IMHO, no. Speed brakes can be used at any speed without danger to the aircraft. Speed brakes don't produce a pitching moment nor do they change the capability of the structure to carry the load. If you inadvertently deploy the speed brakes in flight you can just feel stupid and laugh it off. If you inadvertently deploy the speed brakes on final you will increase the rate of descent but you could deal with that by increasing thrust (or retracting them again). No, I don't see the accidental deployment of speed brakes and the accidental deployment of flaps in the same category. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 23, 2006
On Aug 23, 2006, at 5:44 AM, Dave N6030X wrote: > > > How about putting the starter switch on the throttle, so you can do > an in-flight restart without taking your hands off the sticks and > throttle. How often do you expect to do this? How often might you do this by accident? What happens if you do this by accident? Given how infrequent its use would be I would think that leaving it on the panel is not a real problem. BTW, I would add speed brakes to my list of things that should be on the throttle (stick-equipped aircraft with the throttle in your left hand) along with the radio and intercom PTTs. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 23, 2006
> > > BTW, I would add speed brakes to my list of things that should be on > the throttle (stick-equipped aircraft with the throttle in your left > hand) along with the radio and intercom PTTs. > Hi Brian, Why a PTT for the intercom ? Thanks, Regards, Gilles, http://contrails.free.fr ________________________________________________________________________________
Date: Aug 23, 2006
On Aug 23, 2006, at 6:04 AM, Gilles Thesee wrote: > PTT > Trims > Auto pilot disengage > > That's all I see necessary on the throttle and stick in a civilian > airplane.' I would put the PTT on the throttle and I would add the speed brake too. And you are right on the auto pilot disengage. That is one of the things I forgot and *must* be on the stick or yoke. > Someone mentionned Intercom PTT, what's the use for such a device ? Some aircraft have such a high noise level that a voice-operated intercom won't work properly. You use a PTT to activated your mic into the intercom. Helicopters are known for this as are many military aircraft. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Subject: Re: MOV's/ Lets more on and stop this interchange!
Date: Aug 23, 2006
You missed my point and I am sorry. I was looking for a statement from industry where the uni-directional transorb was NOT to be used. That its not mentioned to me says its OK as it is really a zener or a simple diode if properly connected and the voltage ratings recognized. I know of no such statement as while it may be a silly application it will work just fine. I was expecting a simple " its a stupid application but you are right" from you. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 10:57 PM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >> >>I cannot let this get past as your statement is in fact TOTALLY >>technically incorrect (vs opinions). >> >>Below requests for links must exclude your own as they need to be >>unbiased! >> >>----- Original Message ----- From: "Robert L. Nuckolls, III" >> >>To: >>Sent: Tuesday, August 22, 2006 7:32 PM >>Subject: Re: AeroElectric-List: Re: MOV's >> >> >>> In fact, you cannot use a uni-directional Transorb (or >>> plain-vanilla zener) unless combined with a diode to >>> prevent forward conduction as shown in multitudes of catalogs >>> and literature on relays. >> ________________________________________________________________________________
Subject: Re: B-lead Contactors (was MOV's)
Date: Aug 23, 2006
I did change the subject to point out a case where the diode as a coil suppressor was a bad idea as it extends the opening time 5x approx. You did state as far as the relay and its drive there was no difference and usually the delay in opening was OK and I agree. But there are cases where its not OK and I stated one used in many aircraft. I did not quantify the exact results of my tests in my post as that is not important to the main point that a simple "B" lead contactor may fail to properly work. The intensity of the arc etc is not important, the fact the arc continues AFTER the contacts are fully open IS. There is a lot more testing required for any interested person in the design of a protection circuit for an internally regulated (very rare) failure of the internal regulator when the failure mode is full power out. As there are thousands of owners out there flying with internal regulated alternators I was trying to point out that the solution once suggested on this list (at one time the simple "B" lead contactor) is not always a reliable one. I had hoped that by now you had looked into a solution. Given the large numbers of aircraft so equipped it would, in my opinion have a high priority. You know simply saying to not use internal regulated alternators, just based on your word alone is not sufficient when major manufacturers/suppliers of experimental aircraft parts etc say otherwise. My point was to be an informer of a problem and yes it does relate to the Transorb in a way as I know of NO case where a transorb will not be as good as a diode. I just pointed out where a diode was NOT as good. My conclusion was you cannot go wrong with a transorb (and you can with a diode) and so far you do not seem to have case that disputes that conclusion. Personally I have changed my mind about internally regulated alternators after my tests of several years ago. I did and do not have what I consider a good solution to the problem other that the Kilovac contactor which will cleanly break a runaway alternator safely. I did mention on this list recently how to convert a ND alternator to external regulation with a simple mod to the regulator. I offered to post an article on the subject but only a couple showed interest and that was not enough for me to spend the time on it. Sorry I seem to be unable to state my point without your misunderstanding it. Paul ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 23, 2006
Bob I love 99% of your posts. You are doing a great job in helping people understand and wire their aircraft and based on my limited accident investigation of auto engine powered aircraft. I would guess you have saved hundreds of lives in the past 10 years. The stupid things people do that do not know of your information is astounding. However what I was asking for is independent backup of your conclusions as my background and experience as well as all the data I can find support my opinion not yours. What is wrong with asking for independent backup. EVERY source (several beyond what has been mentioned recently) I can find that really evaluates (and stacks) the different suppression methods put the simple diode at the bottom and the bi-directional transorb (or its equivalent) at the top. Sure the different approaches are "application dependent" as which work better and which are not as good. My point is the transorb always is good (and at the top of the lost) so why not use it. No need to retrofit and replace diodes IF you were to go on and discuss the cases where the diode was not as good. The only published paper that disagrees with me comes from you. How about an industry recognized paper that supports your position? Teachers must be able to backup what they say with independent references or the student can waver about that and anything else the teacher says. The "prove me wrong" is interesting but not useful as most students have no ability to try. I have no interest in trying to prove what the industry says in unison. I did see the proving data in the EMI lab when I worked in aerospace that supported the industry and we simply proceeded on. Why not?, there was no significant mechanical, electrical or cost difference and in some cases there was a functional improvement. Sure 90% of the time a diode was just fine but in the other cases it was not. I can and have been a teacher but you want to be a teacher and yet get upset when the student says "prove it". Using only your position (which differs from industry) is not enough for me (and some others unwilling to post) given the predictable results. A test by you of a single case or a couple of cases does not make the statement universally true in all cases. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 11:18 PM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >> >>As I have stated in my original post which you (apparently do not want to >>respond to) I will not get into a debate with you ever again (actually on >>ANY subject) and this subject (transorbs) has been debated between us >>starting nearly 10 years ago. > > Yup, that conversation has been enshrined in bytes at > > http://aeroelectric.com/articles/spike.pdf > > >>If you truly are interested in the reasons (pros and cons) of the various >>types of coil suppression please consider reviewing the references Eric >>posted as your reference had little info other than to illustrate the >>types of suppression relay delays. Yes (as you have stated) the total >>circuit (not just the coil) drives the suppression method and Transorbs >>always work and diodes only usually work. > > I've read those references. And I've explained what > I've found in them that was in error. If you want > to worship at the altars of Tyco-Amp or Potter-Brumfield > based on your blind acceptance of their Word, that's > your choice . . . but expect to be challenged when you > preach philosophies you cannot yourself explain. You > expose yourself as a propagandist and not as a teacher. > >>I will not respond to your comments below (however erroneous some may be) >>as there is no point. > > If you can't be a teacher then don't get into > the sandbox to throw mud. Your drive-by insinuations > that errors in my posting are unworthy of your > time and effort is consistent with the behavior > you favored 6 years ago. You stood off and threw > rocks at my explanations and NEVER offered a single > alternative supported by your own explanation of > the underlying physics. > > You had plenty to complain about but never a > plan consistent with anyone else's design goals but > your own. You want to play? Fine. If not, then > you know the way out. The unsubscribe link is: > > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: Potentiometers question
Bob, I am building a RV10 and am using your wiring diagram, dual Alt dual bus. I am also installing a blower motor to use as a source to blow heated air on to the windscreen. I have sourced a blower, via west marine that is 12 volts 6amp and will work I think quite nice. I would like to have a variable switch/potentiometer to control the unit, to turn it on as well as control the fan speed. I have been to DIGIKEY and Mouser to find a POT that would work, the problem is that I don't know what values to use 5K 10K 15K 25K etc&..for this application. Can you provide any guidance&.Your help is appreciated You're going to need something heftier than a panel-mounted, stand-alone potentiometer. Potentiometers are limited to currents on the order of a few milliamperes. Rheostats (really BIG potentiometers) are available to handle much larger currents on the order of amps . . . but they get so hot and are so large that mounting them on the panel (or anywhere else in the airplane) is not practical. You need a variable duty cycle motor controller. A number of folks here on the List have been modifying a kit offered by Marlin P Jones at: http://www.mpja.com/productview.asp?product=4057+MD This product is advertised as capable of handling 10A of motor current. As you can see, it's CONTROLLED by a relatively small potentiometer (milliamps) but the motor current is carried by a transistor on a heatsink (amps). I know nothing about this kit and it has some obvious packaging issues for aircraft. The electronics board needs to be mounted in some kind of box and the potentiometer brought out on leads to be mounted on the panel. Suggest you join the AeroElectric List and talk with folks who have used this kit. They can probably offer a variety of options for utilizing this kit in your project. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 23, 2006
In the automotive world, cars (at least General Motors cars) have to withstand reverse battery in case someone jumpers a dead battery with a good 12 volt battery backwards for a specified period of time. I don't remember the time. It may be 1 minute or only 10 seconds, but they don't want that to wipe out anything on the car. Maybe this applies to unidirectional Transzorbs, I'm not sure. Just a thought. Dan Hopper Retired Automotive Engineer -- Delphi Delco Electronics (was GM) RV-7A In a message dated 8/23/2006 10:16:04 A.M. Eastern Daylight Time, paulm(at)olypen.com writes: --> AeroElectric-List message posted by: "Paul Messinger" You missed my point and I am sorry. I was looking for a statement from industry where the uni-directional transorb was NOT to be used. That its not mentioned to me says its OK as it is really a zener or a simple diode if properly connected and the voltage ratings recognized. I know of no such statement as while it may be a silly application it will work just fine. I was expecting a simple " its a stupid application but you are right" from you. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 10:57 PM Subject: Re: AeroElectric-List: Re: MOV's > --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" > > > >> >> >>I cannot let this get past as your statement is in fact TOTALLY >>technically incorrect (vs opinions). >> >>Below requests for links must exclude your own as they need to be >>unbiased! >> >>----- Original Message ----- From: "Robert L. Nuckolls, III" >> >>To: >>Sent: Tuesday, August 22, 2006 7:32 PM >>Subject: Re: AeroElectric-List: Re: MOV's >> >> >>> In fact, you cannot use a uni-directional Transorb (or >>> plain-vanilla zener) unless combined with a diode to >>> prevent forward conduction as shown in multitudes of catalogs >>> and literature on relays. >> ________________________________________________________________________________
Subject: RE: Ergonomics
Date: Aug 23, 2006
Expanding a bit on where this thread has gone, let me toss out some thoughts on cockpit ergonomics and safety. I'm building an RV-8, which of course has a narrow panel. Economy of acreage is important. Also, a fundamental of crashworthiness is to not put switches where you will be impaled by them. Hence, I don't have any switches on my main panel. My basic concept for switch location is to put the highest usage switches on the stick, with the next highest usage rate and 'use 'em quick' safety related switches on the left (throttle hand) side, leaving the right side (stick hand) for the rarely used stuff. The application of this philosophy to my particular equipment list leads to the following: My RAC / MAC stick grip has PTT, 2 axis trim, A/P disconnect, and EFIS engine page call up / dismiss. Nothing on the throttle. The lower edge of the throttle quadrant ass'y is home to the cockpit light dimmers. Just above / fwd of the throttle on the left sub panel and within very easy reach of my throttle hand are my 'oh crap' switches. They include fuel pump, A/P arm / off, rear seat stick switch disable / trim sys disable, and flaps. The next row up has the music auto mute function, ARC, and OVM reset switches. Just above are the clock and the flap position indicator. The left side of the main panel holds xpder, coms, back up EFIS, and nav. Central and right is the main EFIS display. The right side of the panel holds the audio panel. The right sub panel has the trim indicators, remote ELT head, battery switches, ignition switches, EFIS 2 switch, and start switch. The right console has the exterior lights, pitot heat, Hobbs meter, and power distribution CBs. So far, I'm very happy with this layout. Of course, it' the 12th iteration of the design. I would encourage folks to take their time and prioritize and group switches according to some consistent and user friendly scheme. 'Chair flying' complete flight profiles, imagining / simulating the whole process from power up through engine start, T/o, ldg, and securing will help a lot. Besides, then you'll have a good excuse when the spouse catches you sitting there making airplane noises... glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 23, 2006
Yes I remember that interchange and its a wonderful example how selective cut and paste can change what I was saying and its context. Its a masterpiece. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Tuesday, August 22, 2006 11:18 PM Subject: Re: AeroElectric-List: Re: MOV's > Yup, that conversation has been enshrined in bytes at > > http://aeroelectric.com/articles/spike.pdf > > ________________________________________________________________________________
Date: Aug 23, 2006
Subject: Re: MOV's
> >Bob I love 99% of your posts. You are doing a great job in helping people >understand and wire their aircraft and based on my limited accident >investigation of auto engine powered aircraft. > >I would guess you have saved hundreds of lives in the past 10 years. > >The stupid things people do that do not know of your information is >astounding. Thank you for the kind words . . . >However what I was asking for is independent backup of your conclusions as >my background and experience as well as all the data I can find support my >opinion not yours. I'm only asking for independent review (yours) of what I've offered based on your perceptions of the physics and NOT upon a dump from industry's promotional literature. >What is wrong with asking for independent backup. EVERY source (several >beyond what has been mentioned recently) I can find that really evaluates >(and stacks) the different suppression methods put the simple diode at the >bottom and the bi-directional transorb (or its equivalent) at the top. >Sure the different approaches are "application dependent" as which work >better and which are not as good. My point is the transorb always is good >(and at the top of the lost) so why not use it. No need to retrofit and >replace diodes IF you were to go on and discuss the cases where the diode >was not as good. > >The only published paper that disagrees with me comes from you. How about >an industry recognized paper that supports your position? Teachers must be >able to backup what they say with independent references or the student >can waver about that and anything else the teacher says. The "prove me >wrong" is interesting but not useful as most students have no ability to try. I am NOT disagreeing with you in that the zener-diode technique certainly works 100% of the time. The entire thrust of my posting was to dispel any notions that folks who choose to use the lowly diode are at-risk for reduced relay and contactor life. It's just that simple sir. I'm mystified as to why you get wrapped around the good-better-best axle when those terms are non-quantified and not even offered in the context of exactly HOW one technique excels. You're fond of citing lots of literature while I prefer to make measurements and explore for myself the value/hazards of any technique being discussed. I've offered my experimental results for the purpose of soliciting considered critical review to either support or refute a hypothesis. I chose this technique because literature without supporting experimental data proves nothing while the repeatable experiment offered for critical review illuminates the path for success. >I have no interest in trying to prove what the industry says in unison. I >did see the proving data in the EMI lab when I worked in aerospace that >supported the industry and we simply proceeded on. Why not?, there was no >significant mechanical, electrical or cost difference and in some cases >there was a functional improvement. Sure 90% of the time a diode was just >fine but in the other cases it was not. . . . agreed . . . and I'm only suggesting that the 10% of cases were the simple diode is found lacking do not occur in the OBAM aircraft. >I can and have been a teacher but you want to be a teacher and yet get >upset when the student says "prove it". Nobody, repeat NOBODY upsets me over a discussion of facts and physics. Your the only person on this list who has succeeded in upsetting me when you alluded to a cadre of unhappy customers of my products who according to you were so intimidated by my aura that they would not return their purchases for a full refund. I could only assume that you had chosen to insert yourself into what was intended to be an honorable supplier/consumer relationship. That DID upset me. I will confess to some frustration when data and test techniques offered to support a hypothesis produces a literature storm of information not specific to discussion of the hypothesis. > Using only your position (which differs from industry) is not enough for > me (and some others unwilling to post) > given the predictable results. A test by you of a single case or a > couple of cases does > not make the statement universally true in all cases. My position differs not a whit from industry when it comes to making measurements and deducing performance or lack thereof based on those measurements. But like laundry soap, cars, and mouthwash, the promotional literature (including much of the applications notes) are not written with good science and understanding as goals. For example: I'm about ready to publish a detailed review of the data sheet for the MC33092 internal regulator where I will show that in spite of the product's modern integrated circuit manufacturing with a whole fist full of transistors, the manner in which it is used in alternators prevents exploitation of its special features. In practice, it performs no better than the two-transistor regulators we were installing on Cessnas 40 years ago. By your logic I could consider assembling a house with titanium nails and be 100% assured of future performance. When the astute system designer compares REQUIREMENTS with techniques and materials capable of meeting requirements, the competitive and successful product may very well NOT use titanium nails. Words here on the list have recommended that builders rip out all their diodes and replace them with a more expensive product and promoted by the notion that doing so has cost-of-ownership value for having made the switch. I am only suggesting that the notion is pure marketing hype and not supported by any experiments I've conducted to explore the potential benefits. I was not arguing any good-better-best, only against the notion that the product being offered produces a demonstrable return on investment. In this case a plain ol' cement coated box nail does the job. If someone chooses to use the titanium nail cause he has the time and doesn't mind the expense, fine. But I object to marketing the titanium nail with the use of unsupported assertions designed to instill worries on the part of the potential neophyte customer. There's that honorable consumer/supplier relationship thing again. Bob . . . ________________________________________________________________________________
Date: Aug 23, 2006
I agree with your title of your post. As for your comment about reverse voltage it would apply to diodes also. Paul ----- Original Message ----- From: Hopperdhh(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 23, 2006 7:33 AM Subject: Re: AeroElectric-List: Re: MOV's/ Lets more on and stop this interchange! In the automotive world, cars (at least General Motors cars) have to withstand reverse battery in case someone jumpers a dead battery with a good 12 volt battery backwards for a specified period of time. I don't remember the time. It may be 1 minute or only 10 seconds, but they don't want that to wipe out anything on the car. Maybe this applies to unidirectional Transzorbs, I'm not sure. Just a thought. Dan Hopper Retired Automotive Engineer -- Delphi Delco Electronics (was GM) RV-7A In a message dated 8/23/2006 10:16:04 A.M. Eastern Daylight Time, paulm(at)olypen.com writes: You missed my point and I am sorry. I was looking for a statement from industry where the uni-directional transorb was NOT to be used. That its not mentioned to me says its OK as it is really a zener or a simple diode if properly connected and the voltage ratings recognized. I know of no such statement as while it may be a silly application it will work just fine. I was expecting a simple " its a stupid application but you are right" from you. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> To: Sent: Tuesday, August 22, 2006 10:57 PM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >> >>I cannot let this get past as your statement is in fact TOTALLY >>technically incorrect (vs opinions). >> >>Below requests for links must exclude your own as they need to be >>unbiased! >> >>----- Original Message ----- From: "Robert L. Nuckolls, III" >> >>To: >>Sent: Tuesday, August 22, 2006 7:32 PM >>Subject: Re: AeroElectric-List: Re: MOV's >> >> >>> In fact, you cannot use a uni-directional Transorb (or >>> plain-vanilla zener) unless combined with a diode to >>> prevent forward conduction as shown in multitudes of catalogs >>> and literature on nbsp; = Use lities Day --> - NEW MATRONICS WEB FORUMS - bsp; --> nbsp; - NEW MATRONICS LIST WIKI - ======================== ________________________________________________________________________________
Date: Aug 23, 2006
Brian, > >> Someone mentionned Intercom PTT, what's the use for such a device ? > > Some aircraft have such a high noise level that a voice-operated > intercom won't work properly. You use a PTT to activated your mic into > the intercom. Helicopters are known for this as are many military > aircraft. Understand. Thank you for responding. Best regards, Gilles, http://contrails.free.fr ________________________________________________________________________________
From: "Doug Windhorn" <N1DeltaWhiskey(at)comcast.net>
Subject: Re: RE: Pullable 80A Circuit Breaker
Date: Aug 23, 2006
Matt, I am not an expert either, but I*R is not the only source of heat that might affect a CB. For thermally activated (TA) CB, it is quite possible for external heat sources to reduce the load carrying capacity of the TACB by providing "pre-heating." Say a TACB will trip when the sensing element reaches 600F (I have no idea what the actual temperature is - it may be much less than that). At ambient temperature of 70F, we have to provide enough heating to elevate the sensor temperature by 530F. However, if a situation arises which causes the ambient temp of the unit to rise, say to 300F, the amount of current the TACB to elevate the temp of the sensor an additional 300F is decreased (i.e., reduced capacity). I visited a client just this week where they were having nuisance trips of a circuit breaker. Cause: determined to be a bad connection of the CB to the bus. Remedy: the bus was flipped over to get the pitting away from the CB contacts and a secure connection was then made. Regards, Doug Windhorn ----- Original Message ----- From: "Matt Prather" <mprather(at)spro.net> Sent: Tuesday, 22 August, 2006 9:15 Subject: Re: AeroElectric-List: RE: Pullable 80A Circuit Breaker > > > Err.. I am not an expert, but I don't think that is completely correct. > > Heat generated is correct, but the heat is generated solely by the current > passing through the CB. The system voltage has no bearing on how much > heat is generated. Draw the circuit and you can see why. The CB goes in > series with the load. Beit a 2V or 200V system, a particular current > through the CB causes a corresponding voltage drop across the CB while the > CB is closed. > > The voltage rating is more related to the ability of the CB to open an > operating (overloaded) circuit. The higher the system voltage the harder > it is to open the circuit (break the current) for a given current. > Voltage rating is likely about contact speed and distance (maybe not > both). A larger system voltage implies the need for faster contacts > and/or larger contact distance. > > > Regards, > > Matt- > >> >> >> While I am waiting for the real experts to weigh in, I offer the >> following unsubstantiated feeling: >> >> I don't think a cb "senses" either volts or amps. Rather it reacts >> to heat, whose generation is better measured in watts which is a >> function of both. >> >> I would therefore surmise that the cb in question would be well >> within its rated range; however would probably not trip a 14 volt >> load until 160 amps. >> >> well, where are the electro-experts now that we need them?? >> Denis Walsh >> >> On Aug 22, 2006, at 07:06 292080008, glen matejcek wrote: >> >>> >>> >>> >>> Hi Stan- >>> >>>> I bought one at Sun n Fun only to discover later that it is 28v. >>> >>> 28V is the maximum system voltage for that CB. The CB you bought >>> should be >>> fine for your 14V installation. >>> >>> glen matejcek >>> aerobubba(at)earthlink.net >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 23, 2006
I have long ago given up trying to challenge every industry position. I do not have the time or interest to do so. When I do run across something in a design that is not consistent with the industry I do, and have investigated just what is different. The industry papers of the time were from relay manufacturers who had no reason to support one suppressor method or the other as they did not sell suppressors of any type (at the time) Their interest appeared to be to show how to get the most reliable use of their products which ranged from very small relays to huge ones and thus the recommendations were designed to be general and not always apply to any specific case. In the case of transorbs; many years ago I noted that a designer had used a diode and there were unwanted noise introduced into the system. It was determined that the opening delay and more important showed start to finish contact opening time was part of the problem. At that time I want into the EMI lab and with expert help we determined that part of the required fix was to quicken the opening contact time (not the delayed start of opening but the duration of contact opening). PART of the solution was replacing the Diode with a Transorb. There was more required that evolved contact arc suppression. The general conclusion was an across the board replacement of diodes with transorbs as it did not hurt and in rare cases prevent problems. No retrofit was made just new design used transorbs. I agree that your documented test of a small relay showed no significant time of contact opening but that is not necessarily so with power contactors seen in aircraft. Now in the case of experimental aircraft I have discovered one case the "B" lead contactor can require a transorb as a partial solution to contact arcing and continued arcing in one failure mode of the alternator. I only intended to point out that case not make a big deal of it. BTW I am not the only you have gotten up set with but perhaps the most memorable. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Wednesday, August 23, 2006 8:16 AM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >> >>Bob I love 99% of your posts. You are doing a great job in helping people >>understand and wire their aircraft and based on my limited accident >>investigation of auto engine powered aircraft. >> >>I would guess you have saved hundreds of lives in the past 10 years. >> >>The stupid things people do that do not know of your information is >>astounding. > > Thank you for the kind words . . . > > >>However what I was asking for is independent backup of your conclusions as >>my background and experience as well as all the data I can find support my >>opinion not yours. > > I'm only asking for independent review (yours) of what I've > offered based on your perceptions of the physics and NOT > upon a dump from industry's promotional literature. > > ________________________________________________________________________________
Date: Aug 23, 2006
Subject: PWRgate
Bob, West Mountain Radio http://www.westmountainradio.com/SuperPWRgate.htm makes a product call "Super PWRgate" that looks like a reasonable device to support a two battery (one large - one smaller) environment. My total load with lights etc. on is about 45-50A . . . critical load < 20A . . . really critical load < 10A? Please take a look and give your opinion. Thanks, Bob Christensen RV-8 Bldr - SE Iowa ________________________________________________________________________________
Date: Aug 23, 2006
Subject: PWRgate
Subject: Contactbounce PIX
Date: Aug 23, 2006
I have attached up some scope pictures of contact bounce as well as one of a main bus transient from the removal of a load by turning off a resistive 10 amp load. In all cases the horizontal speed is 1 ms per small square and 2 ms per large square. The vertical resolution is 5V per large square. Only small squares are clear in the transient jpg. All PIX have been greatly reduced in resolution for fast downloading. The contact bounce pix were from the contactor sold by Wicks at the time for cont duty and I added the diode across the coil. There was only enough voltage and current used to show the contact open and close and to eliminate the normal arcing as much as possible when a significant load was switched. My first point is I have seen transients that are repeatable but not high voltage on the bus. High enough to consistently trip Bobs OVP from the design of several years ago. The load was switched off with a 20 amp rated auto relay. The contact bounce on power contactors can be significant but range widely from one test to the next with the same contactor. The Kilovac has no or at most one quick contact bounce on open and none on closing. Here the opening bounce extends over 14MS from start to end. Replacing the diode with a transorb helped shorten the bounce duration but did not eliminate all the bounce. For general interest. There are lots more but I see no point in posting them as relays vary and some bounce more than others. The "fire" across the contacts can in some cases be huge whan large currents and or an inductive load is switched. Paul ________________________________________________________________________________
Date: Aug 23, 2006
sorry I've lost the original post but that is a huge fan for defrost. If you really think you need it you could also look at an automotive fan speed control arrangement. For just blowing air up through the instrument glareshield I found that a little axial fan as seen in computer power supplies seems to work fine for me. No speed control required. Ken Robert L. Nuckolls, III wrote: > > > > Bob, > > I am building a RV10 and am using your wiring diagram, dual Alt dual > bus. I am also installing a blower motor to use as a source to blow > heated air on to the windscreen. I have sourced a blower, via west > marine that is 12 volts 6amp and will work I think quite nice. I would > like to have a variable switch/potentiometer to control the unit, to > turn it on as well as control the fan speed. I have been to DIGIKEY > and Mouser to find a POT that would work, the problem is that I don't > know what values to use 5K 10K 15K 25K etc&..for this application. > > Can you provide any guidance&.Your help is appreciated > > > You're going to need something heftier than a panel-mounted, > stand-alone potentiometer. Potentiometers are limited to > currents on the order of a few milliamperes. Rheostats (really > BIG potentiometers) are available to handle much larger > currents on the order of amps . . . but they get so hot > and are so large that mounting them on the panel (or anywhere > else in the airplane) is not practical. > > You need a variable duty cycle motor controller. A number of > folks here on the List have been modifying a kit offered by > Marlin P Jones at: > > http://www.mpja.com/productview.asp?product=4057+MD > > This product is advertised as capable of handling 10A > of motor current. As you can see, it's CONTROLLED by > a relatively small potentiometer (milliamps) but the > motor current is carried by a transistor on a heatsink > (amps). I know nothing about this kit and it has some > obvious packaging issues for aircraft. The electronics > board needs to be mounted in some kind of box and the > potentiometer brought out on leads to be mounted on the > panel. > > Suggest you join the AeroElectric List and talk with > folks who have used this kit. They can probably offer > a variety of options for utilizing this kit in your > project. > > Bob . . . ________________________________________________________________________________
Date: Aug 23, 2006
From: Jon & Kathryn Hults <legacy(at)speedband.com>
Aircraft Extras in Ohio ( http://www.aircraftextras.com ) has a system that will disable your flap switch at whatever speed you want...presumably the top of the white arc. That way, inadvertent activation of your flap switch in cruise would do nothing. Inadvertent activation below flap speed would not be prevented, but would cause no harm either. I too am going to have a flap switch on my stick, but I'm also going to install Aircraft Extra's accidental flap deployment protection system. Jon Hults Legacy ________________________________________________________________________________
Date: Aug 23, 2006
Subject: "Paddle Type" Flap position switch?
I've searched in vain for a flap position switch which has a wide broad flat paddle for the toggle, similar to what Cessna uses. anybody know where you can pick one of the up? Deems Davis # 406 Fuse/Finishing/Panel http://deemsrv10.com/ ________________________________________________________________________________
Subject: Re: "Paddle Type" Flap position switch?
Date: Aug 23, 2006
On Aug 23, 2006, at 6:40 PM, Deems Davis wrote: > > > I've searched in vain for a flap position switch which has a wide > broad flat paddle for the toggle, similar to what Cessna uses. > anybody know where you can pick one of the up? Make a paddle out of wood and epoxy it to a standard spring-return-to- center toggle switch. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Subject: Flap switches/relay wiring)
Date: Aug 23, 2006
My speed brake deployment has been tested to Vne. Accendital deployment only causes the airplane to slow down. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Denton Sent: Wednesday, August 23, 2006 8:23 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) Given that this started as a discussion of the hazards of having the flap control mounted on the stick, wouldn't mounting the speed brake control on the stick pose a similar hazard? ________________________________________________________________________________
Date: Aug 24, 2006
What happens if there is an accidental deployment during the landing flare? Kevin Horton On 23 Aug 2006, at 09:05, Bruce Gray wrote: > > > My speed brake deployment has been tested to Vne. Accendital > deployment only > causes the airplane to slow down. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Bill > Denton > Sent: Wednesday, August 23, 2006 8:23 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/ > relay wiring) > > > > > Given that this started as a discussion of the hazards of having > the flap > control mounted on the stick, wouldn't mounting the speed brake > control on > the stick pose a similar hazard? > > ________________________________________________________________________________
Date: Aug 24, 2006
> >I've searched in vain for a flap position switch which has a wide broad >flat paddle for the toggle, similar to what Cessna uses. anybody know >where you can pick one of the up? See: http://www.aeroelectric.com/Pictures/Switches/FLAPS3.JPG http://www.aeroelectric.com/Pictures/Switches/FLAPS2.JPG http://www.aeroelectric.com/Pictures/Switches/FLAPS1.JPG I could give you a part number for the switch used on Bonanzas but you'd have to mortgage the dog to afford it. Best you consider the DIY project. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 24, 2006
Beware of "bells and whistles" that add complexity. More than once I've encountered costly field service issues with so called "enhancements" to performance that became problem children for at least some owners. A part that is NOT on your airplane will never be a failure/performance issue. Bob . . . > > >Aircraft Extras in Ohio ( http://www.aircraftextras.com ) has a system that >will disable your flap switch at whatever speed you want...presumably the >top of the white arc. That way, inadvertent activation of your flap switch >in cruise would do nothing. Inadvertent activation below flap speed would >not be prevented, but would cause no harm either. > >I too am going to have a flap switch on my stick, but I'm also going to >install Aircraft Extra's accidental flap deployment protection system. > >Jon Hults >Legacy > > >-- > > >-- incoming mail is certified Virus Free. >Checked by AVG Anti-Virus. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 24, 2006
I was thinking more in terms of the other end of the spectrum... What would happen if the speed brakes were accidentally deployed on short final? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bruce Gray Sent: Wednesday, August 23, 2006 8:06 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) My speed brake deployment has been tested to Vne. Accendital deployment only causes the airplane to slow down. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Denton Sent: Wednesday, August 23, 2006 8:23 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) Given that this started as a discussion of the hazards of having the flap control mounted on the stick, wouldn't mounting the speed brake control on the stick pose a similar hazard? ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: PWRgate
> >Bob, > >West Mountain Radio http://www.westmountainradio.com/SuperPWRgate.htm >makes a product call "Super PWRgate" that looks like a reasonable >device to support a two battery (one large - one smaller) environment. > >My total load with lights etc. on is about 45-50A . . . critical load >< 20A . . . really critical load < 10A? > >Please take a look and give your opinion. The question to be asked/answered is: "How does this product deliver a return on invesetment either for cost or performance over the use of simple battery contactors for each battery wired as suggested in Z-30." The same question was explored on the topic of battery isolators some years ago at: http://aeroelectric.com/articles/bat_iso2.pdf It's not clear from the West Mountain Radio instruction manual how this would be usef in an airplane. http://www.westmountainradio.com/pdf/PG40Smanual.pdf It's purpose seems to be for the "more accurate" charging of one battery and to power some accessory from either battery or AC mains as the situation dictates. This is a bit different than the philosophy offered for the installation and management of dual batteries. Be wary of "bells and whistles" that seem to offer some whizzy features. Make sure they first address REQUIREMENTS you have established for how your system needs to operate. Then evaluate return on investment for the proposed product as compared with alternatives with an eye on (1) parts count reduction - parts not on the airplane are not going to break, (2) maintainability - if it breaks in Podunk TN, how hard will it be to get it fixed?, (3) weight - a pound of airplane saved is a pound of payload earned, (4) volume - no airplane has too much room to put stuff, (5) $time$ to install - here's your "investment" and (6) operability - does it increase workload? Does it demand special words in the POH that your fellow pilots would have to stop and think about. Finally (7) how does it affect your failure mode effects analysis. How will you KNOW it's broke? Are potential failures pre-flight detectable? Is a plan-B procedure for failure called for in the POH? This may seem like I'm making a mountain out of a mole-hill but these are the rudimentary foundations for systems design decisions on "real" airplanes that have served us well for nearly a century. I've not been made privy to an alternative philosophy that has proven useful. In fact, failure to observe this recipe for success has cost many of my clients and their customers bucket-loads of money and $time$ wasted on ill-conceived systems design decisions. Your own return-on-investment study will determine the usefulness of any particular feature under consideration. Use this List as your critical design review. It's a win-win. Either you shut off the computer grinning ear-to-ear and run off to the store to buy some whippy electro-whizzie or you keep a poorly considered idea from going into your airplane. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2006
Bill Denton a crit : > > I was thinking more in terms of the other end of the spectrum... > > What would happen if the speed brakes were accidentally deployed on short > final? > > The end result would be "interesting" ;-) Fighters have speed brakes on the throttle, because they need it for formation flying, in-flight refuelling, etc. Their jet engines do not allow for quick speed reduction. On other types, airliners or gliders, the speed brakes do have a dedicated and (hopefully) unmistakeable lever. On a piston single, unless the owner is a nostalgic ex-fighter pilot, is a throttle switch really desirable ? Piston engines and props allow for quick speed reduction for formation flying, for instance. Any time you add a switch on the stick or throttle, provision must be made to avoid inadvertent actuation. I know of at least one clever guy who installed the starter switch on the throttle... Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 24, 2006
We have installed several dozen sets of speed brakes on aircraft as an option with the turbo normalizing systems for the Bonanzas. There have been lots of variations in the locations of the activation switches. I have flown all of these different locations - - from the yoke to the panel. My thoughts: Don't put anything on the stick that you will normally use once or twice during each flight. That is a mistake and generates more problems. Things that will be used multiple times - - trim, mic button, are the two most important - - are appropriate. Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Denton Sent: Thursday, August 24, 2006 7:14 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) I was thinking more in terms of the other end of the spectrum... What would happen if the speed brakes were accidentally deployed on short final? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bruce Gray Sent: Wednesday, August 23, 2006 8:06 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) My speed brake deployment has been tested to Vne. Accendital deployment only causes the airplane to slow down. Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Denton Sent: Wednesday, August 23, 2006 8:23 AM Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) Given that this started as a discussion of the hazards of having the flap control mounted on the stick, wouldn't mounting the speed brake control on the stick pose a similar hazard? ________________________________________________________________________________
Date: Aug 24, 2006
Speed brakes are usually very small drag producers that provide energy control while at high indicated airspeeds. Once slowed to a low airspeed, speed brakes represent a very small portion of airframe drag. Sometimes, takeoff performance isn't even particularly degraded with the brakes extended. Regards, Matt- > > > I was thinking more in terms of the other end of the spectrum... > > What would happen if the speed brakes were accidentally deployed on short > final? > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bruce > Gray > Sent: Wednesday, August 23, 2006 8:06 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay > wiring) > > > My speed brake deployment has been tested to Vne. Accendital deployment > only > causes the airplane to slow down. > > Bruce > www.glasair.org > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill > Denton > Sent: Wednesday, August 23, 2006 8:23 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay > wiring) > > > > > Given that this started as a discussion of the hazards of having the flap > control mounted on the stick, wouldn't mounting the speed brake control on > the stick pose a similar hazard? > > ________________________________________________________________________________
Date: Aug 24, 2006
Mr. Thesee, I just posted another message. Yours reminds me that I didn't mention a few things... Early (modern?) fighter jets often flew their final approach with speed brakes at least partially extended. This allowed them to carry nearly full power on the engine while on approach. If they had to abort an approach, the speed brakes could be stowed much more quickly than climb power could be attained from the jet. The speed brakes were relatively large, and not designed to be deployed at high airspeeds. Gliders often have truly enormous speed brakes/spoilers which allow steep approaches to be flown - drastically reducing their glide ratio. All of the ones I have seen are mechanically actuated by a large lever in the cockpit. The speed brakes that I was thinking of are like the Precise Flight units commonly installed on higher performance piston singles like Mooney's, Lancairs, Glassairs, Bonanzas and Cessna 210's. These are electrically actuated. Mounting the control switch either near/on the throttle or on the control wheel/stick might make the most sense. These units are approved for airspeeds up to Vne. http://preciseflight.com/viewpage.php?pID=10 Regards, Matt- > <Gilles.Thesee@ac-grenoble.fr> > > Bill Denton a crit : >> >> >> I was thinking more in terms of the other end of the spectrum... >> >> What would happen if the speed brakes were accidentally deployed on >> short >> final? >> >> > > The end result would be "interesting" ;-) > > Fighters have speed brakes on the throttle, because they need it for > formation flying, in-flight refuelling, etc. Their jet engines do not > allow for quick speed reduction. > On other types, airliners or gliders, the speed brakes do have a > dedicated and (hopefully) unmistakeable lever. > > On a piston single, unless the owner is a nostalgic ex-fighter pilot, is > a throttle switch really desirable ? Piston engines and props allow for > quick speed reduction for formation flying, for instance. > Any time you add a switch on the stick or throttle, provision must be > made to avoid inadvertent actuation. > > I know of at least one clever guy who installed the starter switch on > the throttle... > > Regards, > Gilles Thesee > Grenoble, France > http://contrails.free.fr > > ________________________________________________________________________________
Date: Aug 24, 2006
Gulf Coast Avionics in Florida. Robert L. Nuckolls, III wrote: > > > >> >> >> I've searched in vain for a flap position switch which has a wide >> broad flat paddle for the toggle, similar to what Cessna uses. >> anybody know where you can pick one of the up? > > > See: > > > http://www.aeroelectric.com/Pictures/Switches/FLAPS3.JPG > http://www.aeroelectric.com/Pictures/Switches/FLAPS2.JPG > http://www.aeroelectric.com/Pictures/Switches/FLAPS1.JPG > > I could give you a part number for the switch used on > Bonanzas but you'd have to mortgage the dog to afford > it. Best you consider the DIY project. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Aug 24, 2006
Matt and all, > Speed brakes are usually very small drag producers that provide energy > control while at high indicated airspeeds. Once slowed to a low airspeed, > speed brakes represent a very small portion of airframe drag. Sometimes, > takeoff performance isn't even particularly degraded with the brakes > extended. > > Thanks for the info. This type of speed brakes must be particular to some type of airplanes ? High drag but bigger engine ? I'm flying sleek airplanes with low over all drag when flaps are up, so in my opinion, even you low drag brakes would make a difference with them. Some slower airplanes with weak flap action, or even without flaps, resort to speed brakes to increase drag during approach. Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 24, 2006
On Aug 24, 2006, at 3:36 AM, Kevin Horton wrote: > > > What happens if there is an accidental deployment during the > landing flare? Remember, this is a speed brake, not a spoiler. It increases drag but has very little effect on lift. The effect of a speed brake decreases as IAS decreases. The airplane slows down but not as much as at Vne. I doubt that speed brake would really have any significant effect in the landing flare. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: MOV's
> >I have long ago given up trying to challenge every industry position. I do >not have the time or interest to do so. When I do run across something in >a design that is not consistent with the industry I do, and have >investigated just what is different. I don't think I suggested it. Obviously, industry publishes a great deal of data that is need for the make/buy/ignore decision along with information vital to integrating a device into a new design. Challenges are warranted when words taken from what appears to be well grounded, widely distributed ideas that cause readers to invest both $time$ and emotional capital for adoption of some product or idea. It's incumbent upon the astute designer (and advisor) to evaluate and understand the return on investment. It's not so much a challenge as it is a quest for understanding. The unfortunate condition is that potential customers are oft encouraged to spend $time$ on a product or activity that fails to deliver . . . or delivers a feature that's not really useful. >The industry papers of the time were from relay manufacturers who had no >reason to support one suppressor method or the other as they did not sell >suppressors of any type (at the time) Their interest appeared to be to >show how to get the most reliable use of their products which ranged from >very small relays to huge ones and thus the recommendations were designed >to be general and not always apply to any specific case. Yup . . . the universe is long on generalized recipes for success but it's not uncommon that such recipes are short on detailed explanations for applicability and return on investment . . . >In the case of transorbs; many years ago I noted that a designer had used >a diode and there were unwanted noise introduced into the system. It was >determined that the opening delay and more important showed start to >finish contact opening time was part of the problem. At that time I want >into the EMI lab and with expert help we determined that part of the >required fix was to quicken the opening contact time (not the delayed >start of opening but the duration of contact opening). > >PART of the solution was replacing the Diode with a Transorb. There was >more required that evolved contact arc suppression. > >The general conclusion was an across the board replacement of diodes with >transorbs as it did not hurt and in rare cases prevent problems. No >retrofit was made just new design used transorbs. > >I agree that your documented test of a small relay showed no significant >time of contact opening but that is not necessarily so with power >contactors seen in aircraft. I tested battery contactors too. Your decisions to take some action based on data acquired during an investigation cannot be faulted or argued with. At the same time, recommendation of broad prescriptions for applying a design technique because it mitigated a problem so specific as to required detailed investigation is not good science or business. >Now in the case of experimental aircraft I have discovered one case the >"B" lead contactor can require a transorb as a partial solution to contact >arcing and continued arcing in one failure mode of the alternator. Yup, but that's a new situation arising from an especially antagonistic load switched by the contactor. Here the load is not inductive, resistive, or lamp . . . it's an engine driven energy source with dynamics that were never considered when all the coil suppression techniques were crafted and described in the oft cited documents. I.e., those documents have almost no significance for solving the problem. >I only intended to point out that case not make a big deal of it. I wasn't making a big deal out of it either. My offering was in response to recommendations were made based on no better data than one gets for choosing laundry soap because it says "new and improved" on the box. > BTW I am not the only you have gotten up set with but perhaps the most > memorable. Really? Perhaps I need to be more skilled with the use of emoticons . . . Folks often misinterpret my state of being. When I am really upset about something, I'll make it known. When someone offers an opinion about things I've said or done, the input falls in one of two categories (1) it's a valid observation worthy of consideration and modification of future action - i.e. good critical review -OR- (2) "noise" that contains no data and should be ignored so that attention to simple-ideas is not distracted or diluted. It's relatively easy to make that determination without emotional investment. But I've readily admitted to being really wound up when individuals insert themselves between me and my customers such that I am deprived of the opportunity to keep them satisfied with their decision to use my products and services. Bob . . . ________________________________________________________________________________
Subject: flap deployment above Vfe
Date: Aug 24, 2006
There seems to be some worry about flap deployment above Vfe. Remember, Vfe is for *full* flap deployment. Most aircraft can deploy partial flaps at much higher speeds. I used to deploy a small amount of flaps on my RV-4 to help me slow down in a pinch. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: MOV's
> >Yes I remember that interchange and its a wonderful example how selective >cut and paste can change what I was saying and its context. > >Its a masterpiece. > >Paul Really? There was no intention on my part to distort any meaning in your words. If there was distortion, it was accidental. I'd be pleased to supply you the original for any editing you might wish to do that would clarify of your intent. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: Flap switches/relay wiring)
Brian and all, > I doubt that speed brake would really have any significant effect in > the landing flare. Yes they have. Used them on a Citation to shorten the float and firmly plant the wheels on landing. Now, what if the flare is a bit high and slow, or balloons, and a white knuckle pilot actuates the speed-brakes ? Macho contact with Mother Earth at best.... Best regards, Gilles, no speed-brakes http://contrails.free.fr ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: and relay coil spike suppression
> >You missed my point and I am sorry. > >I was looking for a statement from industry where the uni-directional >transorb was NOT to be used. That its not mentioned to me says its OK as >it is really a zener or a simple diode if properly connected and the >voltage ratings recognized. > >I know of no such statement as while it may be a silly application it will >work just fine. I guess I misunderstood the term "work". If one selects a zener diode for some application, it's easy to assume that the designer needs the functionality of the device as a zener. >I was expecting a simple " its a stupid application but you are right" >from you. I thought we were discussing the pros/cons of recommended techniques and the idea that your argument was offered as an off-topic ringer didn't occur to me. You wrote: >Please tell the LIST (specific link please) where a 50V uni-directional >Transorb device (properly connected) is different from a 50v diode >in coil suppression or forward conduction for that matter. >Of course if you use a Transorb alone as a diode its no better >than a diode so that configuration is not addressed. I missed the significance of the last sentence so I went off and crafted . . . http://www.aeroelectric.com/temp/Relay_Coil_Suppression.pdf which illustrates the point. My suggestion is that thrashing this little tid-bit added no value for those who choose to follow this thread. I will offer the following revision to what I wrote to wit: WAS: "In fact, you cannot use a uni-directional Transorb (or plain vanilla zener) unless combined with a diode to prevent forward conduction as shown in multitudes of catalogs and literature on relays." NOW: There is no practical value in utilization of a single unidirectional Transorb (or plain vanilla zener) because its functionality is limited to behavior that mimics the use of an ordinary diode as illustrated in cases 3/4 and 5/6 in the link cited above. The industry wide practice for using a zener in the coil suppression network of relays is illustrated in cases 7/8 were the zener is turned over and a diode added to prevent forward conduction. In this instance, the zener's unique qualities as a voltage clamping device provide the desired spike suppression characteristics while minimizing effects on relay drop out delay. Bob . . . ________________________________________________________________________________
Subject: Re: flap deployment above Vfe
Date: Aug 24, 2006
Brian, In addition to your comment, I would add that the flap deployment takes some time. If one accidently touches the flap switch (the kind mounted on the sticck) the flaps would only deploy slightly unless the pilot held the switch down. This would go beyound accidental deployment. There is also a notable reaction to deployment of flaps, and unless the pilot was overloade to the point of not having situational awareness should note that the flaps are being deployed. This will not stop every inadvertant flap deployment, but I doubt that the situation is any where as common or dangerous as some imply. Don -------------- Original message ---------------------- From: Brian Lloyd <brian-av(at)lloyd.com> > > There seems to be some worry about flap deployment above Vfe. > Remember, Vfe is for *full* flap deployment. Most aircraft can deploy > partial flaps at much higher speeds. I used to deploy a small amount > of flaps on my RV-4 to help me slow down in a pinch. > > Brian Lloyd 361 Catterline Way > brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > I fly because it releases my mind from the tyranny of petty things . . . > Antoine de Saint-Exupry > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
Good Morning Don, All that you say makes sense, but I fail to see the advantage to having so many switches on the control stick. In fact, I don't see the need for many of them to be on the throttle either. I like having a trim switch on the control stick or wheel. I think a transmit button there is very handy, but I like it even better on the throttle! I do like the idea of having an Ident button on the stick, but I have never had one so mounted. May not be worth the trouble. An autopilot disconnect switch on the control unit makes sense, but most autopilots can be easily overridden if that becomes necessary. My thought is to keep the number of switches on the stick to the absolute minimum and and place the other needed control devices in a comfortable position relative to my throttle hand. Isn't it great that we have the choice? Happy Skies, Old Bob AKA Bob Siegfried Stearman N3977A Downers Grove, Illinois --- dsvs(at)comcast.net wrote: > dsvs(at)comcast.net > > Brian, > In addition to your comment, I would add that the > flap deployment takes some time. If one accidently > touches the flap switch (the kind mounted on the > sticck) the flaps would only deploy slightly unless > the pilot held the switch down. This would go > beyound accidental deployment. There is also a > notable reaction to deployment of flaps, and unless > the pilot was overloade to the point of not having > situational awareness should note that the flaps are > being deployed. This will not stop every > inadvertant flap deployment, but I doubt that the > situation is any where as common or dangerous as > some imply. Don > -------------- Original message > ---------------------- > From: Brian Lloyd <brian-av(at)lloyd.com> > Lloyd > > > > There seems to be some worry about flap deployment > above Vfe. > > Remember, Vfe is for *full* flap deployment. Most > aircraft can deploy > > partial flaps at much higher speeds. I used to > deploy a small amount > > of flaps on my RV-4 to help me slow down in a > pinch. > > > > Brian Lloyd 361 Catterline > Way > > brian HYPHEN av AT lloyd DOT com Folsom, CA > 95630 > > +1.916.367.2131 (voice) > +1.270.912.0788 (fax) > > > > I fly because it releases my mind from the tyranny > of petty things . . . > > Antoine de Saint-Exupry > > > > > > > > > > > > > > > > > > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > Web Forums! > > > Admin. > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: AeroElectric-List Digest: 31 Msgs - 08/23/06
Hey Paul, > Yes I remember that interchange and its a wonderful example how selective > cut and paste can change what I was saying and its context. You know, Paul, it's clear that both you and Bob know more about electronics than I could ever know or for that matter probably would ever want to know. The thing is in Bob's posts he writes in such a way that dang near 100% of it makes sense to a electronics near-luddite like me. In addition, his explanations tend to highlight the underlying basic concepts well enough that I can start to figure out other things for myself. People with high technical skills that can actually teach are rare, those that are willing to do it for peanuts are almost non-existant. The only thing I've gotten out of this diode vs transorb thingy is that a transorb may be like a diode and zener together or two zener's back to back. It seems that even if it's technically better we're probably talking about a 1% optimization. Even I'm not anal enough to worry about that small an improvement. My understanding of the purpose of this list is to help people setup their electrical systems in their homebuilt airplanes. This diode vs transorb, transorb vs crowbar mental masturbation has contributed nothing to my understanding of how to setup a homebuilt. It could be that i'm just stupid (but I suspect not) and that it's greatly helped other members on the list, I just don't know. I know Bob invites a high level of debate but i'm at a lost of why you continue to post when on one hand you accuse Bob of twisting your arguments through editing and on the other hand you're looking for his approval in other posts. ie paraphrasing - "i know it's a silly application but I expected you to tell me i was right". Please make your posts more constructive if you want mere mortals like me to respect your opinion. > Its a masterpiece. > Paul c'ya, Mike __________________________________________________ ________________________________________________________________________________
Date: Aug 24, 2006
"If one accidently touches the flap switch (the kind mounted on the sticck) the flaps would only deploy slightly unless the pilot held the switch down." That is not necessarily correct... With many of the "flap controllers" which have been previously mentioned, each "bump" of the flap switch lowers the flaps a pre-programmed amount. For example the first "bump" would take the flaps to 10 degrees, the next "bump" to 20 degrees, another "bump" to 30 degrees. And typically, a single "bump" on the "up" switch fully retracts the flaps. And at least one of these controllers can be programmed to automatically adjust pitch trim as flaps are deployed/retracted. So, even a little carelessness could cause a quick and possibly dangerous reconfiguration of the aircraft... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of dsvs(at)comcast.net Sent: Thursday, August 24, 2006 10:32 AM Subject: Re: AeroElectric-List: flap deployment above Vfe Brian, In addition to your comment, I would add that the flap deployment takes some time. If one accidently touches the flap switch (the kind mounted on the sticck) the flaps would only deploy slightly unless the pilot held the switch down. This would go beyound accidental deployment. There is also a notable reaction to deployment of flaps, and unless the pilot was overloade to the point of not having situational awareness should note that the flaps are being deployed. This will not stop every inadvertant flap deployment, but I doubt that the situation is any where as common or dangerous as some imply. Don -------------- Original message ---------------------- From: Brian Lloyd <brian-av(at)lloyd.com> > > There seems to be some worry about flap deployment above Vfe. > Remember, Vfe is for *full* flap deployment. Most aircraft can deploy > partial flaps at much higher speeds. I used to deploy a small amount > of flaps on my RV-4 to help me slow down in a pinch. > > Brian Lloyd 361 Catterline Way > brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > I fly because it releases my mind from the tyranny of petty things . . . > Antoine de Saint-Exupry > > ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 24, 2006
couple of snips ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 24, 2006 7:46 AM Subject: Re: AeroElectric-List: Re: MOV's > At the same time, recommendation of > broad prescriptions for applying a design technique > because it mitigated a problem so specific as to > required detailed investigation is not good science > or business. Sorry but in business documentation and stocking two parts when one is only needed is sound business decisions. In aerospace its thousands of dollars saved, just on the paperwork etc. In this case either part cost over $50 each. 10 cents for the part and $49.90 for screening, packaging, identifying, paper etc etc. There was no way to determine how often a specific case might pop up where the transorb might be required and if one happened again the $20,000 spent on analysis of the first problem might be repeated for no good reason. If I had not taken action to switch from a diode to the transorb (across the board) and another similar problem came up there would have been hell to pay directed at me. I do not think it was bad science (but GOOD science) to use a better or more universal product and it clearly was the right business decision When we found a better solution we jumped to use it. Thus my dismay at your hard rejection of using a part that is equal or better than a diode. Perhaps its that my background is different where no failure is acceptable and a design error typically can cost more that the typical light aircraft. I have an example as you like to tell. A satellite system had a minor electrical design change that required a simple one line change ( in 6 places) in the automated system level test. One of the 6 was missed and the cost was over $1,500,000 in hardware damage. To a large extent it applies everywhere as the transorb vs the diode is a clear cut case of the transorb always works and the diode usually always works. Perhaps I missed it but I do not recall you ever saying the transorb was bad just that a diode was good enough or the transorb was not required based on your knowledge and experience. My point is the transorb is more universal and can help with unsuspecting cases now and the future when new technology might produce issues we cannot think of right now.. Surely at 15 cents each its not cost that is a factor here. snip------------------------------ >> BTW I am not the only you have gotten up set with but perhaps the most >> memorable. > > But I've readily admitted to being really > wound up when individuals insert themselves between me and > my customers such that I am deprived of the opportunity > to keep them satisfied with their decision to use my > products and services. > > Bob . . . Here I was given the decision of either not reporting the failures at all or protecting the owners demands of not being quoted by name. I do not like being in the middle but I felt then (and now) its better to report problems (specifically when it appears to be a basic design problem) than not say anything IF that is the only two choices available. The "customers" had already decided to not use that product anymore even if you gave them a replacement as well in that case a new alternator and paid the cleaning bill for their pants. In this case it was the home built version of the OV crowbar (per your plans) that false tripped and often damages the GOOD alternator when the "B" lead contactor opened. Old news now as you have changed the design. I first determined that when I built two my self it false tripped 100% of the time when I tested it. See my recent post on contact bounce and the transient I found on a full up mockup of an aircraft electrical system. BTW My OV crow bar was on a 1" by 1.5" pcb so no long leads etc. I ask you which is better. No feed back at all? or second hand feedback? I suggest that second hand feedback often results in others willing to be known by name and to step forward. IT was as I recall this that eventually led to the redesign. Personally I do not like the design concept of the use of a crowbar as used in this case so I was not interested in fixing what I felt and continue to feel is the wrong approach to the problem but that is an issue I do not wish to discuss here or in the future. I have now decided not to report any second hand failures of your products to you or the list however, because of your response to me in the past with these reports. In any event I suggest we drop the subjects and move on. Paul ________________________________________________________________________________
Subject: Re: MOV's
Date: Aug 24, 2006
Its history and best left alone. Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 24, 2006 7:50 AM Subject: Re: AeroElectric-List: Re: MOV's > > > >> >> >>Yes I remember that interchange and its a wonderful example how selective >>cut and paste can change what I was saying and its context. >> >>Its a masterpiece. >> >>Paul > > Really? There was no intention on my part to distort > any meaning in your words. If there was distortion, > it was accidental. I'd be pleased to supply you the > original for any editing you might wish to do that > would clarify of your intent. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > > ________________________________________________________________________________
Date: Aug 24, 2006
I concur...we're not bulding rocket launchers here. Bill -------------- Original message -------------- From: Michael Pereira <mjpnj(at)yahoo.com> > > Hey Paul, > > > Yes I remember that interchange and its a wonderful example how selective > > cut and paste can change what I was saying and its context. > > You know, Paul, it's clear that both you and Bob know more about electronics > than I could ever know or for that matter probably would ever want to know. > > The thing is in Bob's posts he writes in such a way that dang near 100% of > it makes sense to a electronics near-luddite like me. In addition, his > explanations tend to highlight the underlying basic concepts well enough that > I can start to figure out other things for myself. People with high technical > skills that can actually teach are rare, those that are willing to do it for > peanuts are almost non-existant. > > The only thing I've gotten out of this diode vs transorb thingy is that a > transorb may be like a diode and zener together or two zener's back to back. > It seems that even if it's technically better we're probably talking about a 1% > optimization. Even I'm not anal enough to worry about that small an improvement. > > My understanding of the purpose of this list is to help people setup their > electrical systems in their homebuilt airplanes. This diode vs transorb, > transorb vs crowbar mental masturbation has contributed nothing to my > understanding > of how to setup a homebuilt. It could be that i'm just stupid (but I suspect > not) > and that it's greatly helped other members on the list, I just don't know. > > I know Bob invites a high level of debate but i'm at a lost of why you continue > to post when on one hand you accuse Bob of twisting your arguments through > editing > and on the other hand you're looking for his approval in other posts. ie > paraphrasing - > "i know it's a silly application but I expected you to tell me i was right". > > Please make your posts more constructive if you want mere mortals like me to > respect > your opinion. > > > Its a masterpiece. > > > Paul > > c'ya, > Mike > > __________________________________________________ > > > >
> --> AeroElectric-List message posted by: Michael Pereira
> Hey Paul,
> I can start to figure out other things for myself. People with high techn ical
> understanding
> not)
> I know Bob invites a high l Q,
Date: Aug 24, 2006
Bob, I was not trying to justify the addition of any switch to the stick, just commenting on the overblown percieved danger of such a switch. And yes it is great that we have the choices. Don -------------- Original message ---------------------- From: OldBob Siegfried <oldbob(at)BeechOwners.com> > > > Good Morning Don, > > All that you say makes sense, but I fail to see the > advantage to having so many switches on the control > stick. > > In fact, I don't see the need for many of them to be > on the throttle either. > > I like having a trim switch on the control stick or > wheel. > > I think a transmit button there is very handy, but I > like it even better on the throttle! I do like the > idea of having an Ident button on the stick, but I > have never had one so mounted. May not be worth the > trouble. > > An autopilot disconnect switch on the control unit > makes sense, but most autopilots can be easily > overridden if that becomes necessary. > > My thought is to keep the number of switches on the > stick to the absolute minimum and and place the other > needed control devices in a comfortable position > relative to my throttle hand. > > Isn't it great that we have the choice? > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Stearman N3977A > Downers Grove, Illinois > > --- dsvs(at)comcast.net wrote: > > > dsvs(at)comcast.net > > > > Brian, > > In addition to your comment, I would add that the > > flap deployment takes some time. If one accidently > > touches the flap switch (the kind mounted on the > > sticck) the flaps would only deploy slightly unless > > the pilot held the switch down. This would go > > beyound accidental deployment. There is also a > > notable reaction to deployment of flaps, and unless > > the pilot was overloade to the point of not having > > situational awareness should note that the flaps are > > being deployed. This will not stop every > > inadvertant flap deployment, but I doubt that the > > situation is any where as common or dangerous as > > some imply. Don > > -------------- Original message > > ---------------------- > > From: Brian Lloyd <brian-av(at)lloyd.com> > > Lloyd > > > > > > There seems to be some worry about flap deployment > > above Vfe. > > > Remember, Vfe is for *full* flap deployment. Most > > aircraft can deploy > > > partial flaps at much higher speeds. I used to > > deploy a small amount > > > of flaps on my RV-4 to help me slow down in a > > pinch. > > > > > > Brian Lloyd 361 Catterline > > Way > > > brian HYPHEN av AT lloyd DOT com Folsom, CA > > 95630 > > > +1.916.367.2131 (voice) > > +1.270.912.0788 (fax) > > > > > > I fly because it releases my mind from the tyranny > > of petty things . . . > > > Antoine de Saint-Exupry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > browse > > Subscriptions page, > > FAQ, > > http://www.matronics.com/Navigator?AeroElectric-List > > > > Web Forums! > > > > > > Admin. > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
Mabe so but these usually have the control circuit built into the switch and that precludes stich mounting them. -------------- Original message ---------------------- From: "Bill Denton" <bdenton(at)bdenton.com> > > "If one accidently touches the flap switch (the kind mounted on the sticck) > the flaps would only deploy slightly unless the pilot held the switch down." > > That is not necessarily correct... > > With many of the "flap controllers" which have been previously mentioned, > each "bump" of the flap switch lowers the flaps a pre-programmed amount. > > For example the first "bump" would take the flaps to 10 degrees, the next > "bump" to 20 degrees, another "bump" to 30 degrees. And typically, a single > "bump" on the "up" switch fully retracts the flaps. > > And at least one of these controllers can be programmed to automatically > adjust pitch trim as flaps are deployed/retracted. > > So, even a little carelessness could cause a quick and possibly dangerous > reconfiguration of the aircraft... > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > dsvs(at)comcast.net > Sent: Thursday, August 24, 2006 10:32 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: flap deployment above Vfe > > > > Brian, > In addition to your comment, I would add that the flap deployment takes some > time. If one accidently touches the flap switch (the kind mounted on the > sticck) the flaps would only deploy slightly unless the pilot held the > switch down. This would go beyound accidental deployment. There is also a > notable reaction to deployment of flaps, and unless the pilot was overloade > to the point of not having situational awareness should note that the flaps > are being deployed. This will not stop every inadvertant flap deployment, > but I doubt that the situation is any where as common or dangerous as some > imply. Don > -------------- Original message ---------------------- > From: Brian Lloyd <brian-av(at)lloyd.com> > > > > There seems to be some worry about flap deployment above Vfe. > > Remember, Vfe is for *full* flap deployment. Most aircraft can deploy > > partial flaps at much higher speeds. I used to deploy a small amount > > of flaps on my RV-4 to help me slow down in a pinch. > > > > Brian Lloyd 361 Catterline Way > > brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 > > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > > > I fly because it releases my mind from the tyranny of petty things . . . > > Antoine de Saint-Exupry > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
Bob and all, I sure do agree with your whole message. Just a question. > I do like the > idea of having an Ident button on the stick, but I > have never had one so mounted. May not be worth the > trouble. > I'm not familiar with US ATC, but is the Ident button used so often ? After all, once you've displayed your XPDR code and the controller sees you on his radar, what is the point in pushing ident again and again ? And he (she) would not ask you to Ident while you're performing some delicate maneuver, would he (or she) ? Or am I missing something ? > My thought is to keep the number of switches on the > stick to the absolute minimum and and place the other > needed control devices in a comfortable position > relative to my throttle hand. > > Isn't it great that we have the choice? > Regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Aug 24, 2006
Good Afternoon Gilles, I think my comment to your comment will be: It All Depends! Most of my Stearman flying is VFR in the local Chicago area. Every time I go to a local towered airport, I will be asked to ident. On very rare occasions when IFR, I will be asked to ident when changing from one control center to another. That doesn't happen anywhere near as often as it did twenty to thirty years ago. I am sure that the need for an ident is somewhat variable depending on the area being flown and whether or not the aircraft is in continuous contact with officialdom. I tend to fly VFR with no flight plan and no flight following whenever that is practical. Therefore, anytime I do decide to join into the "system" I will almost always be asked for an ident. However, it doesn't happen often enough such that I would make much effort to add that capability to my control column! Happy Skies, Old Bob --- Gilles Thesee <Gilles.Thesee@ac-grenoble.fr> wrote: > Thesee <Gilles.Thesee@ac-grenoble.fr> > > Bob and all, > > I sure do agree with your whole message. > Just a question. > > > I do like the > > idea of having an Ident button on the stick, but I > > have never had one so mounted. May not be worth > the > > trouble. > > > I'm not familiar with US ATC, but is the Ident > button used so often ? > After all, once you've displayed your XPDR code and > the controller sees > you on his radar, what is the point in pushing ident > again and again ? > And he (she) would not ask you to Ident while you're > performing some > delicate maneuver, would he (or she) ? > Or am I missing something ? > > > My thought is to keep the number of switches on > the > > stick to the absolute minimum and and place the > other > > needed control devices in a comfortable position > > relative to my throttle hand. > > > > Isn't it great that we have the choice? > > > Regards, > Gilles > http://contrails.free.fr > > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > Web Forums! > > > Admin. > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
The aircraft extra FPS system does not, it allows the builder to wire whatever switch they want, including a grip switch, but what they do have is an airspeed cutout, and this would solve it when in cruise but not during approach. Dan 40269 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of dsvs(at)comcast.net Sent: Thursday, August 24, 2006 12:56 PM Subject: RE: AeroElectric-List: flap deployment above Vfe Mabe so but these usually have the control circuit built into the switch and that precludes stich mounting them. -------------- Original message ---------------------- From: "Bill Denton" <bdenton(at)bdenton.com> > > "If one accidently touches the flap switch (the kind mounted on the sticck) > the flaps would only deploy slightly unless the pilot held the switch down." > > That is not necessarily correct... > > With many of the "flap controllers" which have been previously mentioned, > each "bump" of the flap switch lowers the flaps a pre-programmed amount. > > For example the first "bump" would take the flaps to 10 degrees, the next > "bump" to 20 degrees, another "bump" to 30 degrees. And typically, a single > "bump" on the "up" switch fully retracts the flaps. > > And at least one of these controllers can be programmed to automatically > adjust pitch trim as flaps are deployed/retracted. > > So, even a little carelessness could cause a quick and possibly dangerous > reconfiguration of the aircraft... > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > dsvs(at)comcast.net > Sent: Thursday, August 24, 2006 10:32 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: flap deployment above Vfe > > > > Brian, > In addition to your comment, I would add that the flap deployment takes some > time. If one accidently touches the flap switch (the kind mounted on the > sticck) the flaps would only deploy slightly unless the pilot held the > switch down. This would go beyound accidental deployment. There is also a > notable reaction to deployment of flaps, and unless the pilot was overloade > to the point of not having situational awareness should note that the flaps > are being deployed. This will not stop every inadvertant flap deployment, > but I doubt that the situation is any where as common or dangerous as some > imply. Don > -------------- Original message ---------------------- > From: Brian Lloyd <brian-av(at)lloyd.com> > > > > There seems to be some worry about flap deployment above Vfe. > > Remember, Vfe is for *full* flap deployment. Most aircraft can deploy > > partial flaps at much higher speeds. I used to deploy a small amount > > of flaps on my RV-4 to help me slow down in a pinch. > > > > Brian Lloyd 361 Catterline Way > > brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 > > +1.916.367.2131 (voice) +1.270.912.0788 (fax) > > > > I fly because it releases my mind from the tyranny of petty things . . . > > - Antoine de Saint-Exupry > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Aug 24, 2006
Interesting that this message (from Michael) never arrived at my computer. And no you are not (building rocket launchers) but if there had been a transorb on the aircraft bus (different application than the relay, but another one of the Paul vs. Bob arguments (where Paul; says there is a transient and Bob: says no because I have never seen one) where the alternator was damaged by the defectively designed OV crow bar, dozens of pilots would not have had to replace the alternator and remove the faulty OV device. I recently posted a pix of a repeatable transient that 100% of the time tripped the OV device falsely in my own testing. As you may recall Vans strongly asked builders to REMOVE the OV device as it was damaging the alternators with false trips. Told to me by the GM at Vans at the time. This was discussed at length a couple of years ago so there is no need to recycle it now. My point is on other lists a simple " yes a transorb as Eric suggests is a safer way to go and a better solution". No need to get into a thrashing session etc. That is as technical as it ever needed to get. Paul ----- Original Message ----- From: wgill10(at)comcast.net To: aeroelectric-list(at)matronics.com Sent: Thursday, August 24, 2006 9:43 AM Subject: Re: AeroElectric-List: Re: AeroElectric-List Digest: 31 Msgs - 08/23/06 I concur...we're not bulding rocket launchers here. Bill -------------- Original message -------------- From: Michael Pereira <mjpnj(at)yahoo.com> > > Hey Paul, ________________________________________________________________________________
Date: Aug 24, 2006
The end. Clearly you are unwilling to say the bi-transorb is just as good as a diode and in some cases better. Its time to say good by to this line of discussion Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 24, 2006 8:15 AM Subject: AeroElectric-List: Re: and relay coil spike suppression > > > >> >> >>You missed my point and I am sorry. >> >>I was looking for a statement from industry where the uni-directional >>transorb was NOT to be used. That its not mentioned to me says its OK as >>it is really a zener or a simple diode if properly connected and the >>voltage ratings recognized. >> >>I know of no such statement as while it may be a silly application it will >>work just fine. > > I guess I misunderstood the term "work". If one selects a zener > diode for some application, it's easy to assume that the designer > needs the functionality of the device as a zener. > > >>I was expecting a simple " its a stupid application but you are right" >>from you. > > I thought we were discussing the pros/cons of recommended > techniques and the idea that your argument was offered as > an off-topic ringer didn't occur to me. You wrote: > > >Please tell the LIST (specific link please) where a 50V uni-directional > >Transorb device (properly connected) is different from a 50v diode > >in coil suppression or forward conduction for that matter. > > >Of course if you use a Transorb alone as a diode its no better > >than a diode so that configuration is not addressed. > > I missed the significance of the last sentence so > I went off and crafted . . . > > http://www.aeroelectric.com/temp/Relay_Coil_Suppression.pdf > > which illustrates the point. My suggestion is that > thrashing this little tid-bit added no value for those > who choose to follow this thread. I will offer the following > revision to what I wrote to wit: > > WAS: "In fact, you cannot use a uni-directional Transorb (or > plain vanilla zener) unless combined with a diode to > prevent forward conduction as shown in multitudes of > catalogs and literature on relays." > > NOW: There is no practical value in utilization of a single > unidirectional Transorb (or plain vanilla zener) because > its functionality is limited to behavior that mimics > the use of an ordinary diode as illustrated in cases > 3/4 and 5/6 in the link cited above. > > The industry wide practice for using a zener > in the coil suppression network of relays is illustrated > in cases 7/8 were the zener is turned over and a > diode added to prevent forward conduction. In this > instance, the zener's unique qualities as a voltage > clamping device provide the desired spike suppression > characteristics while minimizing effects on relay > drop out delay. > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 24, 2006
On 24 Aug 2006, at 10:43, Brian Lloyd wrote: > av(at)lloyd.com> > > > On Aug 24, 2006, at 3:36 AM, Kevin Horton wrote: > >> >> >> What happens if there is an accidental deployment during the >> landing flare? > > Remember, this is a speed brake, not a spoiler. It increases drag > but has very little effect on lift. The effect of a speed brake > decreases as IAS decreases. The airplane slows down but not as much > as at Vne. I doubt that speed brake would really have any > significant effect in the landing flare. Sorry, I thought that the Glasair installation was likely on the wing, and its deployment would reduce the lift, as well as produce extra drag. I was wondering if the loss of lift at low speed at a critical flight phase could be a problem. Air Canada had a fatal accident with a DC-8 at Toronto many, many years ago. There was a screw up in the flight deck, which resulted in the ground spoilers being deployed at about 60 ft AGL. No survivors. http://aviation-safety.net/database/record.php?id=19700705-0 If the Glasair speedbrakes are not on the wing, then my original question was not relevant. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Aug 24, 2006
Gilles Thesee wrote: > I'm not familiar with US ATC, but is the Ident button used so often ? No, it isn't. I just finished putting 75 hours on my Aztec in the last two months. (Sacramento to Dominica via Texas and Florida, much flying in Florida, and return to Sacramento via Texas and Boise.) Every flight was "in the system". I made 20+ hops. I don't think I was asked to "squawk IDENT" more than three or four times. You are correct in assuming that once you enter your assigned code, ATC rarely requests that you squawk IDENT. BTW, the times I was asked to squawk IDENT were always on an initial call-up and the facility or sector was trying to determine whether I was in their airspace prior to assigning me a discrete code. Like you, I see absolutely no need for an IDENT button my stick. But ergonomics is an issue. Sure a button on the stick is convenient but a button on the panel needn't be inconvenient. If you are building a tandem aircraft think about locating your radios on the left side of your panel so you can leave your right hand on the stick and can use your left hand to manipulate the knobs. Likewise put your switches over there too. And think about putting your PTT on the throttle in a tandem aircraft. That is how most military aircraft are configured. It may seem strange at first but later it becomes very comfortable. That is now how I prefer things. Brian ________________________________________________________________________________
Date: Aug 24, 2006
Kevin Horton wrote: >> Remember, this is a speed brake, not a spoiler. It increases drag but >> has very little effect on lift. The effect of a speed brake decreases >> as IAS decreases. The airplane slows down but not as much as at Vne. I >> doubt that speed brake would really have any significant effect in the >> landing flare. > > Sorry, I thought that the Glasair installation was likely on the wing, > and its deployment would reduce the lift, as well as produce extra > drag. I was wondering if the loss of lift at low speed at a critical > flight phase could be a problem. Probably not as the speed brake tends to be well aft of the point of maximum thickness and very little of the span. It has very little impact on lift. > Air Canada had a fatal accident with a DC-8 at Toronto many, many years > ago. There was a screw up in the flight deck, which resulted in the > ground spoilers being deployed at about 60 ft AGL. No survivors. Yeah, well, the ground spoilers are supposed to kill ALL lift. That is a completely different story. > > http://aviation-safety.net/database/record.php?id=19700705-0 > > If the Glasair speedbrakes are not on the wing, then my original > question was not relevant. And even if they are, I think you will find they have very little effect if deployed while in landing configuration. Regardless, don't take my word for it. Be sure to try it yourself. Brian ________________________________________________________________________________
Date: Aug 24, 2006
Good Afternoon Kevin, This may have little or no bearing on the subject at hand, but the DC-8 had no speed brake at all! They originally designed one that came out of the fuselage at the wing root. It was totally ineffective and the design was too far along to incorporate a speed brake in the wing structure. They fixed it by making the engine reversers usable in flight. If you wanted a speed brake function in the DC-8, you used inflight thrust reversing. They did employ ground spoilers which were designed to kill as much lift as possible. They were located along the trailing portion of the primary wing structure. Speed brakes that are intended to provide inflight drag tend to be mounted further forward on the wing and be designed so they destroy very little of the lift being developed by the wing. Obviously, there are many variations. Boeing tends to use sections of the trailing edge that also serve as ground spoilers The Caravelle a had a beautiful set of brakes that looked like big brothers of those used on gliders. In general, the inflight speed brakes have a relatively small effect on the lift being produced. The ground spoilers are designed to kill as much of the lift as is possible. No doubt many of our listers can point to exceptions where the functions are mixed even more so than on the Boeings, but the DC-8 had NO speed brakes at all within the aircraft structure. Just the inflight reversing capability. That actually worked quite well. but it sure made a lot of noise and a lot of vibration! Happy Skies, Old (Once upon a time DC-8 captain) Bob --- Kevin Horton wrote: > Horton > > On 24 Aug 2006, at 10:43, Brian Lloyd wrote: > > Lloyd > av(at)lloyd.com> > > > > > > On Aug 24, 2006, at 3:36 AM, Kevin Horton wrote: > > > Horton > >> > >> > >> What happens if there is an accidental deployment > during the > >> landing flare? > > > > Remember, this is a speed brake, not a spoiler. It > increases drag > > but has very little effect on lift. The effect of > a speed brake > > decreases as IAS decreases. The airplane slows > down but not as much > > as at Vne. I doubt that speed brake would really > have any > > significant effect in the landing flare. > > Sorry, I thought that the Glasair installation was > likely on the > wing, and its deployment would reduce the lift, as > well as produce > extra drag. I was wondering if the loss of lift at > low speed at a > critical flight phase could be a problem. > > Air Canada had a fatal accident with a DC-8 at > Toronto many, many > years ago. There was a screw up in the flight deck, > which resulted > in the ground spoilers being deployed at about 60 ft > AGL. No survivors. > > http://aviation-safety.net/database/record.php?id=19700705-0 > > If the Glasair speedbrakes are not on the wing, then > my original > question was not relevant. > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > Web Forums! > > > Admin. > > > > > ________________________________________________________________________________
Subject: Garmin GNS 530 Installation Manual
Date: Aug 24, 2006
Does anyone know where I can find a .pdf of a Garmin GNS 530 Installation Manual? Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57097#57097 ________________________________________________________________________________
Date: Aug 25, 2006
> In general, the inflight speed brakes have a > relatively small effect on the lift being produced. > The ground spoilers are designed to kill as much of > the lift as is possible. > When on the wings, "drag only" speed-brakes tend to look like fences lifted at a distance from the wing skin, in order to preserve the airflow on the wing upper surface. If they block part of the airflow on the wing, then they'll kill lift as well as increase drag. Regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Re: Garmin GNS 530 Installation Manual
> > Does anyone know where I can find a .pdf of a Garmin GNS 530 Installation Manual? > > Thanks! > Have you tried http://contrails.free.fr/gps_manuels.php ? Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 24, 2006
> >The end. > >Clearly you are unwilling to say the bi-transorb is just as good as a >diode and in some cases better. > >Its time to say good by to this line of discussion My sincere apologies . . . if that's what you were arguing, then no problem. I thought I made it clear that I had no argument with using ANY of the coil suppression techniques suggested by a whole variety of authors INCLUDING the bi-transorb, bi-filar coils, cap-resistor, resistor, diode-zener, diode or any other technique one wishes to embrace. The sum and substance of my position was (and still is) that I can demonstrate no reason for anyone to FAVOR any of those techniques over the others for the purpose of increasing relay life. In particular, I was objecting to a "new and improved" approach to selling coil suppression when, like laundry soap, the ultimate choice of any flavor would perform just fine. Under those circumstances, there's no reason for anyone to jerk out existing technologies based on concerns for shortened relay life . . . and similarly no reason not to use the most inexpensive or convenient technology at hand. That's what I meant by "practical value". Beyond that, anything that floats your personal boat will work just fine too. My head is always calculating the return-on-investment/cost-of-ownership considerations so my personal boat floats just fine on diodes. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2006
Right you are about the DC8, Bob. I too flew it (about 12 years straight). It always seemed an unnatural act to deliberately use reverse in flight.... An exception to what you say about speed brakes not having much effect on lift is the Boeing 727, an all around wonderfully capable airplane. The speed brakes (flight spoilers) were so effective you could actually lose 10,000 feet in less than 10 miles or slow from 350 IAS to 250 in about 4 miles, not something you'd want to do in a pax airplane (the descent anyway), but lots of fun with boxes. Two fine airplanes, either of which I wish I was still flying. Olen Goodwin ----- Original Message ----- From: "OldBob Siegfried" <oldbob(at)BeechOwners.com> Sent: Thursday, August 24, 2006 4:03 PM Subject: Re: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) > > > > Good Afternoon Kevin, > > This may have little or no bearing on the subject at > hand, but the DC-8 had no speed brake at all! > > They originally designed one that came out of the > fuselage at the wing root. It was totally ineffective > and the design was too far along to incorporate a > speed brake in the wing structure. They fixed it by > making the engine reversers usable in flight. If you > wanted a speed brake function in the DC-8, you used > inflight thrust reversing. > > They did employ ground spoilers which were designed to > kill as much lift as possible. They were located along > the trailing portion of the primary wing structure. > Speed brakes that are intended to provide inflight > drag tend to be mounted further forward on the wing > and be designed so they destroy very little of the > lift being developed by the wing. Obviously, there are > many variations. Boeing tends to use sections of the > trailing edge that also serve as ground spoilers The > Caravelle a had a beautiful set of brakes that looked > like big brothers of those used on gliders. > > In general, the inflight speed brakes have a > relatively small effect on the lift being produced. > The ground spoilers are designed to kill as much of > the lift as is possible. > > No doubt many of our listers can point to exceptions > where the functions are mixed even more so than on the > Boeings, but the DC-8 had NO speed brakes at all > within the aircraft structure. Just the inflight > reversing capability. That actually worked quite well. > but it sure made a lot of noise and a lot of > vibration! > > Happy Skies, > > Old (Once upon a time DC-8 captain) Bob > > --- Kevin Horton wrote: > >> Horton >> >> On 24 Aug 2006, at 10:43, Brian Lloyd wrote: >> >> Lloyd > > av(at)lloyd.com> >> > >> > >> > On Aug 24, 2006, at 3:36 AM, Kevin Horton wrote: >> > >> Horton >> >> >> >> >> >> What happens if there is an accidental deployment >> during the >> >> landing flare? >> > >> > Remember, this is a speed brake, not a spoiler. It >> increases drag >> > but has very little effect on lift. The effect of >> a speed brake >> > decreases as IAS decreases. The airplane slows >> down but not as much >> > as at Vne. I doubt that speed brake would really >> have any >> > significant effect in the landing flare. >> >> Sorry, I thought that the Glasair installation was >> likely on the >> wing, and its deployment would reduce the lift, as >> well as produce >> extra drag. I was wondering if the loss of lift at >> low speed at a >> critical flight phase could be a problem. >> >> Air Canada had a fatal accident with a DC-8 at >> Toronto many, many >> years ago. There was a screw up in the flight deck, >> which resulted >> in the ground spoilers being deployed at about 60 ft >> AGL. No survivors. >> >> > http://aviation-safety.net/database/record.php?id=19700705-0 >> >> If the Glasair speedbrakes are not on the wing, then >> my original >> question was not relevant. >> >> Kevin Horton RV-8 (finishing kit) >> Ottawa, Canada >> http://www.kilohotel.com/rv8 >> >> >> >> browse >> Subscriptions page, >> FAQ, >> http://www.matronics.com/Navigator?AeroElectric-List >> >> Web Forums! >> >> >> Admin. >> >> >> >> >> > > > ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Paul
From: "Paul Messinger" <paulm(at)olypen.com> Subject: Re: AeroElectric-List: Re: AeroElectric-List Digest: 31 Msgs - 08/23/06 Date: Thu, 24 Aug 2006 12:55:14 -0700 Sender: owner-aeroelectric-list-server(at)matronics.com X-Antivirus: AVG for E-mail 7.1.394 [268.11.3/423] Interesting that this message (from Michael) never arrived at my computer. And no you are not (building rocket launchers) but if there had been a transorb on the aircraft bus (different application than the relay, but another one of the Paul vs. Bob arguments (where Paul; says there is a transient and Bob: says no because I have never seen one) . . . Correction: never been able to "capture" a starter induced transient in spite of years of specific tests to see if such animals exist . . . It wasn't as if I were standing around waiting for one to walk by. . . . where the alternator was damaged by the defectively designed OV crow bar, dozens of pilots would not have had to replace the alternator and remove the faulty OV device. You know, it's difficult to "fix" anything when the people having problems don't talk to the supplier of the "problem" device. Out of about 4 thousand crowbar ov systems now in service both OBAM and TC, we've been made aware of and fixed about a dozen cases in the past 20 years. Two of the situations revealed new data that prompted changes to the design. I recently posted a pix of a repeatable transient that 100% of the time tripped the OV device falsely in my own testing. Yeah, some fuzzy scope traces with no test setup data and no description of the test procedure. No definition of the OV device in question. Obviously no contact with the original designer in any spirit of curiosity or helpful transfer of useful data. How am I or anyone else to interpret what you've shared? How do we make use of this data to improve on any design? As you may recall Vans strongly asked builders to REMOVE the OV device as it was damaging the alternators with false trips. Told to me by the GM at Vans at the time. This was discussed at length a couple of years ago so there is no need to recycle it now. You have just recycled it yourself, not as a point of useful information but as a hammer with an intent to injure . . . My point is on other lists a simple " yes a transorb as Eric suggests is a safer way to go and a better solution". No need to get into a thrashing session etc. That is as technical as it ever needed to get. Hmmmm "safer" . . . does it also ward of evil demons and bird flu? That sir is an excellent example of your lack of understanding and re-enforces the notion I've long suspected that your participation in this discussion has little to do with the art and science of building airplanes and a much to do with attempts to discredit me. Since you can't win with logic and good science, you're now reduced to dragging out old canards. The alternators in question were failed due to load-dump effected by b-lead disconnection for one of TWO reasons. (1) the pilot operated the alternator ON-OFF switch while the alternator was under load . . . -OR- (2) the ov system tripped for what-ever reason and opened the b-lead contactor. These events would have taken place irrespective of the technology behind the OV sensing and control. If it had been a simple zener-comparator that was overexcited and had dumped the relay, the end result would have been the same. You have, and continue to denigrate my work with exaggeration and hyperbole and never offered to assist in chasing out any bugs, real or imagined. So the "fix" was to bury heads in the sand and state our internally regulated alternators never fail in an runaway condition so we'll take that pesky control system off. Vans (like your mythical disgruntled AeroElectric Connection customers) never bothered to contact me about their problems whereupon they would have been greeted with instant cooperative and enthusiastic assistance or at least a refund of their money. It's this kind of communication and cooperation that makes things BETTER. Instead, I hear about the problems from you when you wave the news around to re-enforce your obviously dismal opinions of me. Permit me to offer a calm and well considered opinion based on years of observations (and dodging your mudballs). Hmmmm . . . I wonder if you remember your very first phone call to me a long time ago where I got a very agitated claim that you'd tried to order my book several times and you were tired of being ignored. As I recall, I could not find your order(s) in the system but shipped you a free book anyhow. Now here we are, 12-15 years later and you're still accusing me of disrespect, incompetence, dishonorable behavior, and any number of evil traits. A couple of years ago you (and Eric as I recall) went off to do some tests. I was delighted with the notion that kindred spirits with an interest in promoting OBAM aviation had the tools and time to get some badly needed data for the purposes of improving upon the best-we-know- how-to-do. At least here on the List, nothing came out of those tests but ammunition for attacking what had gone before . . . and contributed nothing to what could go on in the future. So now we come to it. You are not a teacher sir, you explain nothing. Your factual contributions to the list have been limited and punctuated with reports (which I will now call fabricated) of how unhappy or abused my customers are. You've never offered critical review of my work based on your own knowledge and understanding. You've supported your version of "science" with references to the work of others and never with work of your own. Your demonstrated behavior is the engineering manager's worst nightmare: lot's of noise, manufactured discontent and and zero work-product that one would be proud to pass along to a paying customer. Your conduct here on the List is demonstrably contrary to the spirit and intent of those who gather here to learn, to be of assistance to others and to advance the state of our art and science. On behalf of my customers to spend their $time$ to exploit my $time$, talent and resources . . . and for myself now weary of the joust . . . I will ask in what I assure you is a very calm and most polite tone to please vacate the AeroElectric-List. Bob . . . ________________________________________________________________________________
Subject: Nexus M9177/4-1
Date: Aug 24, 2006
Can somebody tell me where I can buy a single Nexus TJT-102 also known as a M9177/4-1 female adapter? These are used by Allied-Signal/Honeywell panel-mounted GPS products as a data loader port. I have the PC data cable with the male end, but I need the female end to mount in the instrument panel. I contacted the manufacturer and they won't sell me less than 50 at a time. Their direct distributors are the same. Here are the manufacturer's specs: http://nexinc.thomasnet.com/item/all-categories/telephone-jacks/tjt-102?& seo=110 If I can't find one, I'll just hard-wire an 9 pin sub-d port instead. Thanks, Michael H. ________________________________________________________________________________
Subject: Re: Paul
Date: Aug 24, 2006
Bravo, Well said Harold ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 24, 2006 7:49 PM Subject: AeroElectric-List: Paul > > > From: "Paul Messinger" <paulm(at)olypen.com> > To: > Subject: Re: AeroElectric-List: Re: AeroElectric-List Digest: 31 Msgs - > 08/23/06 > Date: Thu, 24 Aug 2006 12:55:14 -0700 > X-Mailer: Microsoft Outlook Express 6.00.2900.2869 > Sender: owner-aeroelectric-list-server(at)matronics.com > Reply-To: aeroelectric-list(at)matronics.com > X-Antivirus: AVG for E-mail 7.1.394 [268.11.3/423] > > > Interesting that this message (from Michael) never arrived at my computer. > > And no you are not (building rocket launchers) but if there had been a > transorb on the aircraft bus (different application than the relay, but > another one of the Paul vs. Bob arguments (where Paul; says there is a > transient and Bob: says no because I have never seen one) . . . > > Correction: never been able to "capture" a starter induced > transient in spite of years of specific tests to see if such > animals exist . . . It wasn't as if I were standing around > waiting for one to walk by. > > . . . where the alternator was damaged by the defectively designed OV > crow bar, dozens of pilots would not have had to replace the alternator > and remove the faulty OV device. > > You know, it's difficult to "fix" anything when the people > having problems don't talk to the supplier of the "problem" > device. Out of about 4 thousand crowbar ov systems now in service > both OBAM and TC, we've been made aware of and fixed about > a dozen cases in the past 20 years. Two of the situations > revealed new data that prompted changes to the design. > > I recently posted a pix of a repeatable transient that 100% of the time > tripped the OV device falsely in my own testing. > > Yeah, some fuzzy scope traces with no test setup data > and no description of the test procedure. No definition > of the OV device in question. Obviously no contact with > the original designer in any spirit of curiosity or > helpful transfer of useful data. How am I or anyone else > to interpret what you've shared? How do we make use of > this data to improve on any design? > > As you may recall Vans strongly asked builders to REMOVE the OV device as > it was damaging the alternators with false trips. Told to me by the GM at > Vans at the time. > > This was discussed at length a couple of years ago so there is no need to > recycle it now. > > You have just recycled it yourself, not as a point of > useful information but as a hammer with an intent to > injure . . . > > My point is on other lists a simple " yes a transorb as Eric suggests is a > safer way to go and a better solution". No need to get into a thrashing > session etc. That is as technical as it ever needed to get. > > Hmmmm "safer" . . . does it also ward of evil demons and > bird flu? > > That sir is an excellent example of your lack of understanding > and re-enforces the notion I've long suspected that your > participation in this discussion has little to do with > the art and science of building airplanes and a much to > do with attempts to discredit me. Since you can't win > with logic and good science, you're now reduced to dragging > out old canards. > > The alternators in question were failed due to load-dump > effected by b-lead disconnection for one of TWO reasons. > > (1) the pilot operated the alternator ON-OFF switch > while the alternator was under load . . . > > -OR- > > (2) the ov system tripped for what-ever reason and > opened the b-lead contactor. > > These events would have taken place irrespective of > the technology behind the OV sensing and control. If > it had been a simple zener-comparator that was overexcited > and had dumped the relay, the end result would have been > the same. You have, and continue to denigrate my work > with exaggeration and hyperbole and never offered to > assist in chasing out any bugs, real or imagined. > > So the "fix" was to bury heads in the sand and state > our internally regulated alternators never fail in an > runaway condition so we'll take that pesky control system > off. > > Vans (like your mythical disgruntled AeroElectric > Connection customers) never bothered to contact me about > their problems whereupon they would have been greeted > with instant cooperative and enthusiastic assistance or > at least a refund of their money. It's this kind of > communication and cooperation that makes things BETTER. > Instead, I hear about the problems from you when you > wave the news around to re-enforce your obviously > dismal opinions of me. > > Permit me to offer a calm and well considered opinion > based on years of observations (and dodging your > mudballs). Hmmmm . . . I wonder if you remember your > very first phone call to me a long time ago where > I got a very agitated claim that you'd tried to order > my book several times and you were tired of being > ignored. As I recall, I could not find your order(s) > in the system but shipped you a free book anyhow. > Now here we are, 12-15 years later and you're still > accusing me of disrespect, incompetence, dishonorable > behavior, and any number of evil traits. > > A couple of years ago you (and Eric as I recall) went > off to do some tests. I was delighted with the notion that > kindred spirits with an interest in promoting OBAM > aviation had the tools and time to get some badly needed > data for the purposes of improving upon the best-we-know- > how-to-do. At least here on the List, nothing came out > of those tests but ammunition for attacking what had gone > before . . . and contributed nothing to what could go > on in the future. > > So now we come to it. You are not a teacher sir, you > explain nothing. Your factual contributions to the list > have been limited and punctuated with reports (which > I will now call fabricated) of how unhappy or abused my > customers are. You've never offered critical review > of my work based on your own knowledge and understanding. > You've supported your version of "science" with references > to the work of others and never with work of your own. > > Your demonstrated behavior is the engineering manager's > worst nightmare: lot's of noise, manufactured discontent > and and zero work-product that one would be proud to pass > along to a paying customer. Your conduct here on the List > is demonstrably contrary to the spirit and intent of those > who gather here to learn, to be of assistance to others > and to advance the state of our art and science. > > On behalf of my customers to spend their $time$ to exploit > my $time$, talent and resources . . . and for myself > now weary of the joust . . . I will ask in what I assure > you is a very calm and most polite tone to please vacate > the AeroElectric-List. > > Bob . . . > > > ________________________________________________________________________________
Subject: Re: Flap switches/relay wiring)
Date: Aug 25, 2006
OK. Off topic but the 727 seems like THE plane to FLY. I know a retired 747 pilot who said the most fun he ever had, the best plane and routes he ever had were with 727s. You got to go to a lot of places not serviced by the larger planes including some class d airports and the plane itself was fun/sporty to fly. Lots of "interesting" central, south american spots too. But of course the retirement is based on final salary years so you "have to" move up to 747s if you can work it out... -------------- Original message -------------- From: "Olen Goodwin" <ogoodwin(at)comcast.net> > > Right you are about the DC8, Bob. I too flew it (about 12 years straight). > It always seemed an unnatural act to deliberately use reverse in flight.... > > An exception to what you say about speed brakes not having much effect on > lift is the Boeing 727, an all around wonderfully capable airplane. The > speed brakes (flight spoilers) were so effective you could actually lose > 10,000 feet in less than 10 miles or slow from 350 IAS to 250 in about 4 > miles, not something you'd want to do in a pax airplane (the descent > anyway), but lots of fun with boxes. Two fine airplanes, either of which I > wish I was still flying. > > Olen Goodwin > ----- Original Message ----- > From: "OldBob Siegfried" > To: > Sent: Thursday, August 24, 2006 4:03 PM > Subject: Re: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) > > > > > > > > > > Good Afternoon Kevin, > > > > This may have little or no bearing on the subject at > > hand, but the DC-8 had no speed brake at all! > > > > They originally designed one that came out of the > > fuselage at the wing root. It was totally ineffective > > and the design was too far along to incorporate a > > speed brake in the wing structure. They fixed it by > > making the engine reversers usable in flight. If you > > wanted a speed brake function in the DC-8, you used > > inflight thrust reversing. > > > > They did employ ground spoilers which were designed to > > kill as much lift as possible. They were located along > > the trailing portion of the primary wing structure. > > Speed brakes that are intended to provide inflight > > drag tend to be mounted further forward on the wing > > and be designed so they destroy very little of the > > lift being developed by the wing. Obviously, there are > > many variations. Boeing tends to use sections of the > > trailing edge that also serve as ground spoilers The > > Caravelle a had a beautiful set of brakes that looked > > like big brothers of those used on gliders. > > > > In general, the inflight speed brakes have a > > relatively small effect on the lift being produced. > > The ground spoilers are designed to kill as much of > > the lift as is possible. > > > > No doubt many of our listers can point to exceptions > > where the functions are mixed even more so than on the > > Boeings, but the DC-8 had NO speed brakes at all > > within the aircraft structure. Just the inflight > > reversing capability. That actually worked quite well. > > but it sure made a lot of noise and a lot of > > vibration! > > > > Happy Skies, > > > > Old (Once upon a time DC-8 captain) Bob > > > > --- Kevin Horton wrote: > > > >> Horton > >> > >> On 24 Aug 2006, at 10:43, Brian Lloyd wrote: > >> > >> Lloyd > >> > av(at)lloyd.com> > >> > > >> > > >> > On Aug 24, 2006, at 3:36 AM, Kevin Horton wrote: > >> > > >> Horton > >> >> > >> >> > >> >> What happens if there is an accidental deployment > >> during the > >> >> landing flare? > >> > > >> > Remember, this is a speed brake, not a spoiler. It > >> increases drag > >> > but has very little effect on lift. The effect of > >> a speed brake > >> > decreases as IAS decreases. The airplane slows > >> down but not as much > >> > as at Vne. I doubt that speed brake would really > >> have any > >> > significant effect in the landing flare. > >> > >> Sorry, I thought that the Glasair installation was > >> likely on the > >> wing, and its deployment would reduce the lift, as > >> well as produce > >> extra drag. I was wondering if the loss of lift at > >> low speed at a > >> critical flight phase could be a problem. > >> > >> Air Canada had a fatal accident with a DC-8 at > >> Toronto many, many > >> years ago. There was a screw up in the flight deck, > >> which resulted > >> in the ground spoilers being deployed at about 60 ft > >> AGL. No survivors. > >> > >> > > http://aviation-safety.net/database/record.php?id=19700705-0 > >> > >> If the Glasair speedbrakes are not on the wing, then > >> my original > >> question was not relevant. > >> > >> Kevin Horton RV-8 (finishing kit) > >> Ottawa, Canada > >> http://www.kilohotel.com/rv8 > >> > >> > >> > >> browse > >> Subscriptions page, > >> FAQ, > >> http://www.matronics.com/Navigator?AeroElectric-List > >> > >> Web Forums! > >> > >> > >> Admin. > >> > >> > >> > >> > >> > > > > > > > > > > > > > > >
> --> AeroElectric-List message posted by: "Olen Goodwin"
> wish I was still flyi ng. >
> Olen Goodwin
> To:
> > --> AeroElectric-List message posted by: OldBob Siegfried
& gt; &g t; wanted a speed brake function in the DC-8, you used
> > ; The ground spoilers are designed to kill as much of
> > vibration!
> > Happy Skies,
> >> --> AeroElectric-List message posted by: Kevin
> >> Horton
> >> > --> AeroElectric-List message posted by: Br ian
> >> Horton
> >> during the
> >> >> landing flare?
> >> increases drag
> >> a speed brake
> >> have any
> & gt;> > significant effect in the landing flare.
> >> likely on the
> >> well as produce
> >> low speed at a
> >> Toronto many, many
> >> which resulted
> >> AGL. No survivors.
> >> my origin nload,
Date: Aug 24, 2006
Subject: Re: Paul
Hey Bob, Well said - again. However, the receiver has a tin ear You have my vote!!!!!! RHDudley Robert L. Nuckolls, III wrote: > > > From: "Paul Messinger" <paulm(at)olypen.com> > To: > Subject: Re: AeroElectric-List: Re: AeroElectric-List Digest: 31 Msgs > - 08/23/06 > Date: Thu, 24 Aug 2006 12:55:14 -0700 > X-Mailer: Microsoft Outlook Express 6.00.2900.2869 > Sender: owner-aeroelectric-list-server(at)matronics.com > Reply-To: aeroelectric-list(at)matronics.com > X-Antivirus: AVG for E-mail 7.1.394 [268.11.3/423] > > > Interesting that this message (from Michael) never arrived at my > computer. > > And no you are not (building rocket launchers) but if there had been a > transorb on the aircraft bus (different application than the relay, > but another one of the Paul vs. Bob arguments (where Paul; says there > is a transient and Bob: says no because I have never seen one) . . . > > Correction: never been able to "capture" a starter induced > transient in spite of years of specific tests to see if such > animals exist . . . It wasn't as if I were standing around > waiting for one to walk by. > > . . . where the alternator was damaged by the defectively designed OV > crow bar, dozens of pilots would not have had to replace the > alternator and remove the faulty OV device. > > You know, it's difficult to "fix" anything when the people > having problems don't talk to the supplier of the "problem" > device. Out of about 4 thousand crowbar ov systems now in service > both OBAM and TC, we've been made aware of and fixed about > a dozen cases in the past 20 years. Two of the situations > revealed new data that prompted changes to the design. > > I recently posted a pix of a repeatable transient that 100% of the > time tripped the OV device falsely in my own testing. > > Yeah, some fuzzy scope traces with no test setup data > and no description of the test procedure. No definition > of the OV device in question. Obviously no contact with > the original designer in any spirit of curiosity or > helpful transfer of useful data. How am I or anyone else > to interpret what you've shared? How do we make use of > this data to improve on any design? > > As you may recall Vans strongly asked builders to REMOVE the OV device > as it was damaging the alternators with false trips. Told to me by the > GM at Vans at the time. > > This was discussed at length a couple of years ago so there is no need > to recycle it now. > > You have just recycled it yourself, not as a point of > useful information but as a hammer with an intent to > injure . . . > > My point is on other lists a simple " yes a transorb as Eric suggests > is a safer way to go and a better solution". No need to get into a > thrashing session etc. That is as technical as it ever needed to get. > > Hmmmm "safer" . . . does it also ward of evil demons and > bird flu? > > That sir is an excellent example of your lack of understanding > and re-enforces the notion I've long suspected that your > participation in this discussion has little to do with > the art and science of building airplanes and a much to > do with attempts to discredit me. Since you can't win > with logic and good science, you're now reduced to dragging > out old canards. > > The alternators in question were failed due to load-dump > effected by b-lead disconnection for one of TWO reasons. > > (1) the pilot operated the alternator ON-OFF switch > while the alternator was under load . . . > > -OR- > > (2) the ov system tripped for what-ever reason and > opened the b-lead contactor. > > These events would have taken place irrespective of > the technology behind the OV sensing and control. If > it had been a simple zener-comparator that was overexcited > and had dumped the relay, the end result would have been > the same. You have, and continue to denigrate my work > with exaggeration and hyperbole and never offered to > assist in chasing out any bugs, real or imagined. > > So the "fix" was to bury heads in the sand and state > our internally regulated alternators never fail in an > runaway condition so we'll take that pesky control system > off. > > Vans (like your mythical disgruntled AeroElectric > Connection customers) never bothered to contact me about > their problems whereupon they would have been greeted > with instant cooperative and enthusiastic assistance or > at least a refund of their money. It's this kind of > communication and cooperation that makes things BETTER. > Instead, I hear about the problems from you when you > wave the news around to re-enforce your obviously > dismal opinions of me. > > Permit me to offer a calm and well considered opinion > based on years of observations (and dodging your > mudballs). Hmmmm . . . I wonder if you remember your > very first phone call to me a long time ago where > I got a very agitated claim that you'd tried to order > my book several times and you were tired of being > ignored. As I recall, I could not find your order(s) > in the system but shipped you a free book anyhow. > Now here we are, 12-15 years later and you're still > accusing me of disrespect, incompetence, dishonorable > behavior, and any number of evil traits. > > A couple of years ago you (and Eric as I recall) went > off to do some tests. I was delighted with the notion that > kindred spirits with an interest in promoting OBAM > aviation had the tools and time to get some badly needed > data for the purposes of improving upon the best-we-know- > how-to-do. At least here on the List, nothing came out > of those tests but ammunition for attacking what had gone > before . . . and contributed nothing to what could go > on in the future. > > So now we come to it. You are not a teacher sir, you > explain nothing. Your factual contributions to the list > have been limited and punctuated with reports (which > I will now call fabricated) of how unhappy or abused my > customers are. You've never offered critical review > of my work based on your own knowledge and understanding. > You've supported your version of "science" with references > to the work of others and never with work of your own. > > Your demonstrated behavior is the engineering manager's > worst nightmare: lot's of noise, manufactured discontent > and and zero work-product that one would be proud to pass > along to a paying customer. Your conduct here on the List > is demonstrably contrary to the spirit and intent of those > who gather here to learn, to be of assistance to others > and to advance the state of our art and science. > > On behalf of my customers to spend their $time$ to exploit > my $time$, talent and resources . . . and for myself > now weary of the joust . . . I will ask in what I assure > you is a very calm and most polite tone to please vacate > the AeroElectric-List. > > Bob . . . > > > ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Subject: Paul
Date: Aug 24, 2006
Bob, We are kindred sprits in one aspect.....we calmly deliver facts in a pragmatic manner. It amazing how some people react so emotionally to this. Regards, Paul McAllister N378PJ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Thursday, August 24, 2006 6:49 PM Subject: PROBABLE SPAM> AeroElectric-List: Paul From: "Paul Messinger" <paulm(at)olypen.com> Subject: Re: AeroElectric-List: Re: AeroElectric-List Digest: 31 Msgs - 08/23/06 Date: Thu, 24 Aug 2006 12:55:14 -0700 Sender: owner-aeroelectric-list-server(at)matronics.com X-Antivirus: AVG for E-mail 7.1.394 [268.11.3/423] Interesting that this message (from Michael) never arrived at my computer. And no you are not (building rocket launchers) but if there had been a transorb on the aircraft bus (different application than the relay, but another one of the Paul vs. Bob arguments (where Paul; says there is a transient and Bob: says no because I have never seen one) . . . Correction: never been able to "capture" a starter induced transient in spite of years of specific tests to see if such animals exist . . . It wasn't as if I were standing around waiting for one to walk by. . . . where the alternator was damaged by the defectively designed OV crow bar, dozens of pilots would not have had to replace the alternator and remove the faulty OV device. You know, it's difficult to "fix" anything when the people having problems don't talk to the supplier of the "problem" device. Out of about 4 thousand crowbar ov systems now in service both OBAM and TC, we've been made aware of and fixed about a dozen cases in the past 20 years. Two of the situations revealed new data that prompted changes to the design. I recently posted a pix of a repeatable transient that 100% of the time tripped the OV device falsely in my own testing. Yeah, some fuzzy scope traces with no test setup data and no description of the test procedure. No definition of the OV device in question. Obviously no contact with the original designer in any spirit of curiosity or helpful transfer of useful data. How am I or anyone else to interpret what you've shared? How do we make use of this data to improve on any design? As you may recall Vans strongly asked builders to REMOVE the OV device as it was damaging the alternators with false trips. Told to me by the GM at Vans at the time. This was discussed at length a couple of years ago so there is no need to recycle it now. You have just recycled it yourself, not as a point of useful information but as a hammer with an intent to injure . . . My point is on other lists a simple " yes a transorb as Eric suggests is a safer way to go and a better solution". No need to get into a thrashing session etc. That is as technical as it ever needed to get. Hmmmm "safer" . . . does it also ward of evil demons and bird flu? That sir is an excellent example of your lack of understanding and re-enforces the notion I've long suspected that your participation in this discussion has little to do with the art and science of building airplanes and a much to do with attempts to discredit me. Since you can't win with logic and good science, you're now reduced to dragging out old canards. The alternators in question were failed due to load-dump effected by b-lead disconnection for one of TWO reasons. (1) the pilot operated the alternator ON-OFF switch while the alternator was under load . . . -OR- (2) the ov system tripped for what-ever reason and opened the b-lead contactor. These events would have taken place irrespective of the technology behind the OV sensing and control. If it had been a simple zener-comparator that was overexcited and had dumped the relay, the end result would have been the same. You have, and continue to denigrate my work with exaggeration and hyperbole and never offered to assist in chasing out any bugs, real or imagined. So the "fix" was to bury heads in the sand and state our internally regulated alternators never fail in an runaway condition so we'll take that pesky control system off. Vans (like your mythical disgruntled AeroElectric Connection customers) never bothered to contact me about their problems whereupon they would have been greeted with instant cooperative and enthusiastic assistance or at least a refund of their money. It's this kind of communication and cooperation that makes things BETTER. Instead, I hear about the problems from you when you wave the news around to re-enforce your obviously dismal opinions of me. Permit me to offer a calm and well considered opinion based on years of observations (and dodging your mudballs). Hmmmm . . . I wonder if you remember your very first phone call to me a long time ago where I got a very agitated claim that you'd tried to order my book several times and you were tired of being ignored. As I recall, I could not find your order(s) in the system but shipped you a free book anyhow. Now here we are, 12-15 years later and you're still accusing me of disrespect, incompetence, dishonorable behavior, and any number of evil traits. A couple of years ago you (and Eric as I recall) went off to do some tests. I was delighted with the notion that kindred spirits with an interest in promoting OBAM aviation had the tools and time to get some badly needed data for the purposes of improving upon the best-we-know- how-to-do. At least here on the List, nothing came out of those tests but ammunition for attacking what had gone before . . . and contributed nothing to what could go on in the future. So now we come to it. You are not a teacher sir, you explain nothing. Your factual contributions to the list have been limited and punctuated with reports (which I will now call fabricated) of how unhappy or abused my customers are. You've never offered critical review of my work based on your own knowledge and understanding. You've supported your version of "science" with references to the work of others and never with work of your own. Your demonstrated behavior is the engineering manager's worst nightmare: lot's of noise, manufactured discontent and and zero work-product that one would be proud to pass along to a paying customer. Your conduct here on the List is demonstrably contrary to the spirit and intent of those who gather here to learn, to be of assistance to others and to advance the state of our art and science. On behalf of my customers to spend their $time$ to exploit my $time$, talent and resources . . . and for myself now weary of the joust . . . I will ask in what I assure you is a very calm and most polite tone to please vacate the AeroElectric-List. Bob . . . ________________________________________________________________________________
Subject: Re:Flap ACAD
Date: Aug 24, 2006
Bob, I have your flap schematics in the pdf format. Would you point me to the ACAD files? Thanks Peter Laurence ________________________________________________________________________________
Subject: Re: Paul
Date: Aug 24, 2006
It was not a starter but a simple relay 10 amp on off load but I am sorry I have pulled your chain. By By Paul ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: Nexus M9177/4-1
Hi Michael, I did a froogle search on TJT-102 and found it at skygeek http://stylespilotshop.stores.yahoo.net/jb-11v.html for $18.95. I don't know anything about the company. Hope this helps, Bob W. "Michael Hinchcliff" wrote: > Can somebody tell me where I can buy a single Nexus TJT-102 also known as a M9177/4-1 female adapter? These are used by Allied-Signal/Honeywell panel-mounted GPS products as a data loader port. I have the PC data cable with the male end, but I need the female end to mount in the instrument panel. I contacted the manufacturer and they won't sell me less than 50 at a time. Their direct distributors are the same. Here are the manufacturer's specs: http://nexinc.thomasnet.com/item/all-categories/telephone-jacks/tjt-102?&seo=110 If I can't find one, I'll just hard-wire an 9 pin sub-d port instead. > > > > Thanks, > > Michael H. > -- http://www.bob-white.com N93BD - Rotary Powered BD-4 (first engine start 1/7/06) Custom Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Date: Aug 24, 2006
><PLaurence@the-beach.net> > > >Bob, >I have your flap schematics in the pdf format. Would you point me to the >ACAD files? Try: http://www.aeroelectric.com/PPS/Flight/Flaps/Flaps.dwg Bob . . . ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: Your book etc.
>Dear Bob, > After reading your book I am wanting to redo my aircraft wiring. I > have re read much of your book and have some questions: > > > 1, What is your main reason for using the heavy duty contactor > ? It does require some current to hold it down and a switch uses a spring. > 2, I also use a knife switch in the negative side of the battery > with a mechanical link to the panel. It seems to work ok and makes it > easy to take the battery out of the circuit which I like. It will have > some resistance but not much. It is one used in cars and trucks and is > available from several sources. What would you say about this? Any means you might devise to serve as a battery master disconnect is certainly possible and even encouraged in the OBAM aircraft community. The contactor is convenient and works in about any situation irrespective of the aircraft or battery location and it's easy. Many production aircraft in times past had manuall operated switches of one kind or another. I took lessons in a Piper Tri-Pacer about 45 years ago that had manual battery switch and manual starter switches. > 3. I have replaced the Rotax engine with a Corvair engine made by > William Wynne which uses two coils and a dual set of breaker points for > almost a dual ignition system, but uses only one set of plugs. I have it > running now but would like to do a rewire with an E buss and another > battery. To justify the added weight I may have to lose some weight > myself but I like the idea. I've met Mr. Wynne and read his publications. He's done some impressive work with the Corvair conversions. Why do you think you need dual batteries? > 4, Does B&C Electronics sell kits? Not that I know of. > 5. Thanks for writing a good book (may I expect some more pages?) Sure. Keep an eye on the What's New? section of our website. You buy the book only one time and you can download future updates from the website as they are published. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 24, 2006
Subject: RE: Iso Amp
>Removed U114, jumpered 2 & 3 together. Now when I apply power nothing is >amplified. That is, in stereo configuration you could hear music without >power but it was much louder with power. Now in the "mono" configuration >with the above changes, no difference can be heard in loudness when power >is applied. > Are you sure you've wired it right? Which side of the board has the connector on it? Note there are two pinout configurations depending on how the connector is mounted. See latest instruction manual for an amplification of this situation. It was recently updated and posted at: http://www.aeroelectric.com/Catalog/AEC/9009/9009-700H.pdf Check out note 14 on Page 2 ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Off to California
I had hoped to get to many more messages before we left but I'm out of time and need to pack the bags. Dr. Dee and I are headed to Auburn (Sacremento), CA for a weekend of "airplanespeak" and other good conversations. Hope to meet some of you there in person. Be back on Monday. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Aug 24, 2006
Subject: Re: Problem with Power Sources
>I just finished my RV-4 and used Bob's Z-11 plan with a Battery Bus, Main >Bus and E Bus. Somehow I have them isolated so that the main works of the >Master, the E bus switch lights the avionics, but I can't get the Main bus >to feed the E Bus without turning it on. > >At first I thought I had miswired and blown the Diode, but I replaced that >and still have the same squawk. The plane's electrical systems all work, >but I wonder what I did wrong. I also wonder if I'm placing the whole >system in jeopardy by using both switches to hot up everything. Appreciate >any troubleshooting ideas. >Ron Did you get this figured out okay? Bob . . . ________________________________________________________________________________
Date: Aug 24, 2006
Too bad the old airplanes that required "piloting" are all being retired. I enjoyed them, and I think lots of the guys that liked flying for it's own sake did. Interesting what you said about the 747...that's where I'm headed in October. Bittersweet indeed. Apologies for the off topic. Olen ----- Original Message ----- From: lucky To: aeroelectric-list(at)matronics.com Sent: Thursday, August 24, 2006 6:37 PM Subject: Re: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) OK. Off topic but the 727 seems like THE plane to FLY. I know a retired 747 pilot who said the most fun he ever had, the best plane and routes he ever had were with 727s. You got to go to a lot of places not serviced by the larger planes including some class d airports and the plane itself was fun/sporty to fly. Lots of "interesting" central, south american spots too. But of course the retirement is based on final salary years so you "have to" move up to 747s if you can work it out... ________________________________________________________________________________
From: "6440 Auto Parts" <sales(at)6440autoparts.com>
Date: Aug 24, 2006
Garmin no longer shows they're install manual's from that site ----- Original Message ----- From: "Gilles Thesee" <Gilles.Thesee@ac-grenoble.fr> Sent: Thursday, August 24, 2006 5:29 PM Subject: Re: AeroElectric-List: Garmin GNS 530 Installation Manual > <Gilles.Thesee@ac-grenoble.fr> > > >> >> Does anyone know where I can find a .pdf of a Garmin GNS 530 Installation >> Manual? >> >> Thanks! >> > Have you tried > > http://contrails.free.fr/gps_manuels.php ? > > Regards, > Gilles Thesee > Grenoble, France > http://contrails.free.fr > > > ________________________________________________________________________________
Date: Aug 24, 2006
Try Stark Avionics. They have most of them on PDF and may e-mail you one -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of 6440 Auto Parts Sent: Thursday, August 24, 2006 8:55 PM Subject: Re: AeroElectric-List: Garmin GNS 530 Installation Manual Garmin no longer shows they're install manual's from that site ----- Original Message ----- From: "Gilles Thesee" <Gilles.Thesee@ac-grenoble.fr> Sent: Thursday, August 24, 2006 5:29 PM Subject: Re: AeroElectric-List: Garmin GNS 530 Installation Manual > <Gilles.Thesee@ac-grenoble.fr> > > >> >> Does anyone know where I can find a .pdf of a Garmin GNS 530 Installation >> Manual? >> >> Thanks! >> > Have you tried > > http://contrails.free.fr/gps_manuels.php ? > > Regards, > Gilles Thesee > Grenoble, France > http://contrails.free.fr > > ________________________________________________________________________________
Date: Aug 25, 2006
> > > > Garmin no longer shows they're install manual's from that site > >>> >> Have you tried >> >> http://contrails.free.fr/gps_manuels.php ? There are about one dozen installation manuals, except the 530 installation manual, I'm afraid. Have you tried Ebay ? http://cgi.ebay.com/ebaymotors/Garmin-Avionics-Install-Manuals-CD-New-Complete-Set_W0QQitemZ290020993542QQihZ019QQcategoryZ26436QQcmdZViewItem Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Flap switches/relay)
Speed Brakes vs. Spoilers. If they are wind spoilers the kill lift in a big way and would be more of an issue than a body mounted speed brake. I put the flap switch on my RV-4 stick grip (MAC grip). To reduce the chance of accidental deployment I cut the mini-toggle switch down very very short, so to operate, you put your thumb on top to move it. It was also spring loaded to up. The MAC grip standard toggle switch lever, although small still got caught on things and caused accidental deployment. After cut down you still had to be careful and not rest things on top of the stick. The trim buttons where there and the PTT on the front. I WILL NOT DO ALL THE BUTTONS ON THE GRIP ON MY NEW PROJECT. My new project, RV-7 has the flap switch (and trim) on the panel near the throttle/prop/mixture. The wiring is way simple and the heavy duty flap switch can handle the flap motor with out troublesome relays. George RV-4, RV-7 >Subject: RE: Ergonomics (was: AeroElectric-List: Flap switches/relay wiring) >From: "Matt Prather" <mprather(at)spro.net> > >Speed brakes are usually very small drag producers that provide energy >control while at high indicated airspeeds. Once slowed to a low >airspeed, speed brakes represent a very small portion of airframe drag. >Sometimes, takeoff performance isn't even particularly degraded with the brakes >extended. > >Regards, Matt- --------------------------------- ________________________________________________________________________________
Date: Aug 25, 2006
You may have the following but JIC... I cannot find the installation manual, but I know for sure that Stark avionics has it cuz I called with a 430 question and Tony accidentally looked at the 530 manual first. Don't know whether he has paper copy or online version. <http://www.garmin.com/manuals/%7Binsert>http://www.garmin.com/manuals/GNS530_PilotsGuide.pdf GNS530_ApprovedFlightManualSupplement.PDF GNS530_QuickReferenceGuide.pdf GNS530_LBAApprovedFlightManualSupplement.pdf ________________________________________________________________________________
Subject: Re: Old Man's Musings
Date: Aug 25, 2006
Bob, I'll be going into the 200/300. Probably a good thing, since I won't have to learn the glass and automation of the 400. Olen ________________________________________________________________________________
Subject: Paul and other thoughts
Date: Aug 25, 2006
From: "Crapse, Richard W (Rick), WWCS" <rwcrapse(at)att.com>
I read the thread with Paul and I have to laugh. It reminds me of another situation with Dave Atkins and redrives for Rotary engines. He uses a spur gear setup because "planetary gears won't hold up". Tracy Crook took the engineers way and did a failure analysis on the same redrive design. Funny , they came to different conclusions. Lack of a thrust bearing and incorrect lubrication paths led to the Ross redrive killing itself, not the gear design is what Tracy found. This thing with Paul and Bob smacks of the same vein. I had the opportunity to read Bob's book, attend his seminar, and attend Greg Richter's seminar at OshKosh. Now here is another holy war that goes on. Bob and Greg will disagree with me on this, but I found it fascinating that they are aruging the same point on wiring aircraft and ground paths from two separate view points. They call it different things, but the gist is there. Greg prefers the solder and heat shrink tube, Bob prefers the Fast-On connectors. Both want a gas tight, electrically sound connection. Both talk about shielding and how to do it correctly. Bob likes fuses, Greg likes polyfuses. Differing thoughts, but both have their valid points. As someone who deals with the mighty invisible heart of radio (vacuum tubes) and who deals with SMT, TTL, CMOS devices, I can say that in SOME applications, one version of technology is superior to another, but not universally. For example, vacuum tube diodes are far quieter than their counterpart solid state brothers. However, does it justify using the vacuum tube diode in modern radio gear? If we are talking about a Hi-Fi amp or stereo, I personally like the sound of the older tube types that the solid state does not match. But then again, when dealing with aircraft radios and modern HT's versus battery life versus vibration, the solid state works just fine, thank-you very much. In sand storm conditions? Give me the vaccum tube finals, they could care less about the static charges, makes them glow brighter. And before you argue that they are dead, the next gen is coming out a nano tubes with cold cathodes for satellites. Now isn't that a surprise? I try to learn from everybody, but I always have to understand where they are coming from first and why. Much better education that way. Rick ________________________________________________________________________________
Subject: Re: Paul and other thoughts
Date: Aug 25, 2006
On Aug 25, 2006, at 7:02 AM, Crapse, Richard W (Rick), WWCS wrote: > I had the opportunity to read Bob's book, attend his seminar, and > attend > Greg Richter's seminar at OshKosh. Now here is another holy war that > goes on. Bob and Greg will disagree with me on this, but I found it > fascinating that they are aruging the same point on wiring aircraft > and > ground paths from two separate view points. They call it different > things, but the gist is there. When we were creating the technology that became the Internet, we ran into the same problem. Brilliant people would argue their points vociferously and nearly come to blows. It would usually take an equally-bright third party to determine that they were saying the same thing but using different words. The difference was usually in the inconsequential details. We even came up with a name for the phenomenon: agreeing violently. So I just shrugged and decided that Bob and Greg, and Bob and Paul were just agreeing violently ... for the most part. But when things like this happen I usually look for whoever has the simplest solution. I am going to go meet Bob tomorrow at Auburn. I have been corresponding with him for ten years and have never met him face-to- face. It should be interesting. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Subject: Re: Marketing research question Annunciated Parameters
Date: Aug 25, 2006
From: "Condrey, Bob (US SSA)" <bob.condrey(at)baesystems.com>
Has anything ever come of the annunciator panel? Bob RV-10 #40105 ________________________________________________________________________________
Subject: Noise filter noise
Date: Aug 25, 2006
Hi all, I'm wondering if someone could educate me a little on something I encountered while trying to eliminate electrical noise coming from an autopilot servo. The story goes like this: I recently installed a new autopilot servo in my Berkut (all composite). It worked perfectly, but for some reason, the servo makes a loud squealing noise in the intercom audio when it's activated. I did all the usual things - changed ground points, increased grounding, double checked shielding on cables, un-bundled wires, ferrite beads on the cables, etc. The only thing that really worked was to power the servo from a separate battery - indicating electrical propagation, not RF. I spoke with the manufacturer, and they did mention that there was a 2.5KHz PWM signal that is used to control the servo, and that the "noise" I hear is likely that. So, on to trying to isolate the servo from everything else...right. I first tried (at the manufacturer's request) a pair of capacitors (.1uf and 4700uf) in parallel, grounded off the servo power lead itself. This did slightly dampen the noise, but certainly not enough. So, I also went out and purchased a common 10-amp car audio power filter - just like those sold by Radio Shack and documented by Bob on his site - 2 caps with a choke coil potted in a case although I can not see the ratings on the caps. I placed the filter in an orientation that isolated the power source from the servo, instead of servo from power source as IT was the verified source of the noise. The good news is, that filter eliminated about 99% of the noise - and that's good to go. I have not yet done extensive tests to see if the AP now operates properly in flight with the filter in-line (possible I/O errors, proper servo feedback, etc)...that's coming soon. But, I want to explore the "weirdness" first. Now, the weird (to me anyway) part is that the filter itself now audibly "sings" with the same frequency that I had heard before on the intercom. I mean, it literally makes the noise like a speaker would. Is this normal? What would be causing that? Is this symptomatic of some additional problem that might effect servo operation? Something else I should do or try? All information and education is welcome...but remember, I'm not an EE. ;-) Eager to learn, James Redmon Berkut #013 N97TX http://www.berkut13.com By the way, this is not a common situation as the manufacturer has not seen this type of issue before...although they are doing everything they can to get this under control - under warranty, to their credit! I have no issues with the way they are handling this..so please don't pester me about that part. ________________________________________________________________________________
Subject: Strobe /beacon question.
Date: Aug 25, 2006
Hello, I have a Whalen power pack that will drive 4 units. I have aquired 2 wing tip, 1 tail and 1 red beacon. I would like some feedback as how to wire this up. I could just wire it as a 4 way strobe on 1 switch. I was thinking that it might be better to wire this so that the beacon goes on first and then adding the rest of the strobes with another switch or perhaps a 2-10 type switch. I m not sure how to do that since the power pack will have to be powered for anything to work. I was thinking it would be good to shut off the strobes in fog/clouds but still leave the red beacon going. Is this a good idea or just more work then needed? Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57330#57330 ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Problems with High EGT readings
Hey all, I've just begun to have 1450+ EGT readings on all cylinders, while the CHT's remain below 390 degrees. No attempt to richen things up (carb heat for example) improves things. I took off the cowl and see no exterior signs of trouble, removed spark plugs and they are nice and tan and even wet from running too rich. I tried a brief flight and all was normal, then on the next long leg they did it again. I recycled the Grand Rapids EIS and then only one cylinder persisted in giving me this reading. Am I right to assume it is an indicator/gauge issue or am I missing something more ominous? Thanks in advance for your ideas. Ron RV-4 N8ZD ________________________________________________________________________________
Subject: Princeton capacitance converters -- RV-7
Date: Aug 25, 2006
Hello All, I had planned to mount these capacitance converters on the sub-panel, but the shielded wire is slightly too short if routed where it will remain out of view. So, the current plan is to mount them between the seat ribs. Has anyone else mounted them between the seat ribs? Pros/Cons/any pictures? Thanks in advance for your input. Have a great weekend, Bill RV-7 wiring Lee's Summit, MO. ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Re: Strobe /beacon question.
In a message dated 8/25/06 3:40:31 PM Eastern Daylight Time, rlnelson-5(at)peoplepc.com writes: > Hello, I have a Whalen power pack that will drive 4 units. I have aquired 2 > wing tip, 1 tail and 1 red beacon. I would like some feedback as how to wire > this up. I could just wire it as a 4 way strobe on 1 switch. I was thinking > that it might be better to wire this so that the beacon goes on first and > then adding the rest of the strobes with another switch or perhaps a 2-10 > type switch. I m not sure how to do that since the power pack will have to be > powered for anything to work. I was thinking it would be good to shut off the > strobes in fog/clouds but still leave the red beacon going. Is this a good > idea or just more work then needed? > Thanks ======================= Nelson: >From your explanation all four items are flash tubes for the strobe power supply. If that is the case then the only proper way to wire them is with one SPST switch to turn on and off the strobe power supply. either ALL is ON or ALL is OFF. You do NOT turn the flash tubes on / off you turn the power supply On & Off. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Re: Noise filter noise
In a message dated 8/25/06 2:26:09 PM Eastern Daylight Time, james(at)berkut13.com writes: > Hi all, > > I'm wondering if someone could educate me a little on something I > encountered while trying to eliminate electrical noise coming from an > autopilot servo. The story goes like this: > > I recently installed a new autopilot servo in my Berkut (all composite). It > worked perfectly, but for some reason, the servo makes a loud squealing > noise in the intercom audio when it's activated. [Barry] When what is activated, the intercom or the servo? > I did all the usual > things - changed ground points, increased grounding, double checked > shielding on cables, un-bundled wires, ferrite beads on the cables, etc. > The only thing that really worked was to power the servo from a separate > battery - indicating electrical propagation, not RF. I spoke with the > manufacturer, and they did mention that there was a 2.5KHz PWM signal that > is used to control the servo, and that the "noise" I hear is likely that. > So, on to trying to isolate the servo from everything else...right. > > I first tried (at the manufacturer's request) a pair of capacitors (.1uf and > 4700uf) in parallel, grounded off the servo power lead itself. This did > slightly dampen the noise, but certainly not enough. [Barry] I gather the 47000uf cap was an electrolytic and the other was a ceramic disc? > So, I also went out > and purchased a common 10-amp car audio power filter - just like those sold > by Radio Shack and documented by Bob on his site - 2 caps with a choke coil > potted in a case although I can not see the ratings on the caps. > I placed the filter in an orientation that isolated the power source from the servo, > instead of servo from power source as IT was the verified source of the > noise. [Barry] I'm not sure what you mean my that statement. Is the filter mounted as close to the servo as posable, short leads and a clean ground? That is how it should be installed. > > The good news is, that filter eliminated about 99% of the noise - and that's > good to go. I have not yet done extensive tests to see if the AP now > operates properly in flight with the filter in-line (possible I/O errors, > proper servo feedback, etc)...that's coming soon. But, I want to explore > the "weirdness" first. > > Now, the weird (to me anyway) part is that the filter itself now audibly > "sings" with the same frequency that I had heard before on the intercom. I > mean, it literally makes the noise like a speaker would. Is this normal? [Barry] Weird to me too? Are you saying that the filter has a noise coming from it? If so then your GROUND is poor and maybe your leads too long. This of course is assuming that the filter is made well and the coils of the filter are mounted / potted securely. But, the first thing I would check is the GROUND. Other thing to check would be your crimps. I would rather have you tell me that you soldered these connection. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 25, 2006
Subject: Re: flap deployment above Vfe
From: Jon & Kathryn Hults <legacy(at)speedband.com>
Military fighter pilots have had much more "consequential" switches on their throttles and sticks for quite some time. The theory behind HOTAS (Hands On Throttle And Stick) is that you are less likely to make flight path deviations if you keep your hands on the controls...and less likely to run into something if you don't have to look inside to throw a switch. Makes sense to me. The trick is in the design of the stick. The top buttons which should probably be reserved for "consequential" switches (trim, flaps, speedbrakes, spoilers, etc..) are out of reach with a normal grasp on the stick. A conscious movement of the thumb is required to activate these switches. You do have to learn where the switches are and not to touch them when you don't want them to move. We all learned that way back in the beginning from our flight instructors...didn't we? If you want to be sure you can't activate the flaps in cruise flight, try this http://www.aircraftextras.com/ It uses a relay board to disable the flap switch above max flap speed to avoid inadvertent flap extension. I think HOTAS is another great idea that will lead to safer flying in all of general aviation thanks to experimental builders like us. My opinion, for what it's worth. Jon Hults ________________________________________________________________________________
Date: Aug 25, 2006
On Aug 25, 2006, at 11:17 AM, James Redmon wrote: > Now, the weird (to me anyway) part is that the filter itself now > audibly "sings" with the same frequency that I had heard before on > the intercom. I mean, it literally makes the noise like a speaker > would. Is this normal? What would be causing that? Is this > symptomatic of some additional problem that might effect servo > operation? Something else I should do or try? You are putting current pulses through an inductor so it has a magnetic field that is varying with the current pulses. Any steel object nearby is going to be alternately pulled and released by the varying magnetic field. It is probably the case of the inductor or the inductor's core that is making the noise. OTOH, there shouldn't be that much current change. Put the capacitor combo back at the input to the servo. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Subject: Re: Problems with High EGT readings
Date: Aug 25, 2006
On Aug 25, 2006, at 1:52 PM, Ron Patterson wrote: > Hey all, > I've just begun to have 1450+ EGT readings on all cylinders, while > the CHT's remain below 390 degrees. No attempt to richen things up > (carb heat for example) improves things. I took off the cowl and > see no exterior signs of trouble, removed spark plugs and they are > nice and tan and even wet from running too rich. I tried a brief > flight and all was normal, then on the next long leg they did it > again. I recycled the Grand Rapids EIS and then only one cylinder > persisted in giving me this reading. Am I right to assume it is an > indicator/gauge issue or am I missing something more ominous? If you have a sudden high EGT on all cylinders, check to see if one mag has stopped working. If both mags are normal and CHTs are normal, look for a gauge problem. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 25, 2006
Well, 2.5 KHz is within the audible frequency range. The A above Middle C is 440 Hz. So you're only talking about less than 6 octaves above it. All it would take is having the coil inside the filter that has this frequency applied to it being physically in contact with the case or other structure. I can envision that real easily. We usually call that "headphones" or "loud speaker". So, you might have to take it apart and make sure the filter is physically isolated from the box around it using RTV or rubber gaskets or something. Be careful about filtering the PWM signal, though. The whole purpose is to feed that signal to the servo, and if you are applying a filter that changes the shape, the servo might start functioning incorrectly. Dave Morris At 01:17 PM 8/25/2006, you wrote: > >Hi all, > >I'm wondering if someone could educate me a little on something I >encountered while trying to eliminate electrical noise coming from >an autopilot servo. The story goes like this: > >I recently installed a new autopilot servo in my Berkut (all >composite). It worked perfectly, but for some reason, the servo >makes a loud squealing noise in the intercom audio when it's >activated. I did all the usual things - changed ground points, >increased grounding, double checked shielding on cables, un-bundled >wires, ferrite beads on the cables, etc. The only thing that really >worked was to power the servo from a separate battery - indicating >electrical propagation, not RF. I spoke with the manufacturer, and >they did mention that there was a 2.5KHz PWM signal that is used to >control the servo, and that the "noise" I hear is likely that. So, >on to trying to isolate the servo from everything else...right. > >I first tried (at the manufacturer's request) a pair of capacitors >(.1uf and 4700uf) in parallel, grounded off the servo power lead >itself. This did slightly dampen the noise, but certainly not >enough. So, I also went out and purchased a common 10-amp car audio >power filter - just like those sold by Radio Shack and documented by >Bob on his site - 2 caps with a choke coil potted in a case although >I can not see the ratings on the caps. I placed the filter in an >orientation that isolated the power source from the servo, instead >of servo from power source as IT was the verified source of the noise. > >The good news is, that filter eliminated about 99% of the noise - >and that's good to go. I have not yet done extensive tests to see >if the AP now operates properly in flight with the filter in-line >(possible I/O errors, proper servo feedback, etc)...that's coming >soon. But, I want to explore the "weirdness" first. > >Now, the weird (to me anyway) part is that the filter itself now >audibly "sings" with the same frequency that I had heard before on >the intercom. I mean, it literally makes the noise like a speaker >would. Is this normal? What would be causing that? Is this >symptomatic of some additional problem that might effect servo >operation? Something else I should do or try? > >All information and education is welcome...but remember, I'm not an EE. ;-) > >Eager to learn, > >James Redmon >Berkut #013 N97TX >http://www.berkut13.com > > >By the way, this is not a common situation as the manufacturer has >not seen this type of issue before...although they are doing >everything they can to get this under control - under warranty, to >their credit! I have no issues with the way they are handling >this..so please don't pester me about that part. > > ________________________________________________________________________________
Date: Aug 25, 2006
In a message dated 8/25/06 8:41:24 PM Eastern Daylight Time, brian-av(at)lloyd.com writes: > If you have a sudden high EGT on all cylinders, check to see if one > mag has stopped working. If both mags are normal and CHTs are normal, > look for a gauge problem. ================================ Brian: If you reduce your spark in half your EGT goes DOWN not UP. Loss of a Mag reduces combustion efficiency. If the timing is incorrect EGT can go UP but usually the Oil and CHT follows. Ron said CHT was 390 F but he did not say that was his NORMAL ... Only that is below 390F. What Ron should be looking for is something that will cause LEANING ... either Less Fuel or More Air. My first place to look would be an AIR LEAK around the Carb. Second place would be the rubber coupling on the intake, but the chances of that are very slim since ALL cylinder increased EGT. Third place is an EXHAUST Leak. Around the flanges ... Ron, you didn't use those cheep soft exhaust gaskets? I have a very difficult time believing that all 4 EGT probes drifted in the same direction. Or that the EIS failed in such a manor that ONLY the EGT was affected and not the CHT. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Aug 25, 2006
X-mailer: Pegasus Mail for Windows (4.21c) > If you reduce your spark in half your EGT goes DOWN not UP. Loss of a > Mag reduces combustion efficiency. Nope. EGT should rise about 50 degrees F on all cylinders. Think a bit more about this and you'll understand why it work this way.... Jim Baker 580.788.2779 '71 SV, 492TC Elmore City, OK ________________________________________________________________________________
Date: Aug 25, 2006
On Aug 25, 2006, at 3:52 PM, Ron Patterson wrote: > Hey all, > I've just begun to have 1450+ EGT readings on all cylinders, while > the CHT's remain below 390 degrees. No attempt to richen things up > (carb heat for example) improves things. I took off the cowl and > see no exterior signs of trouble, removed spark plugs and they are > nice and tan and even wet from running too rich. I tried a brief > flight and all was normal, then on the next long leg they did it > again. I recycled the Grand Rapids EIS and then only one cylinder > persisted in giving me this reading. Am I right to assume it is an > indicator/gauge issue or am I missing something more ominous? > Thanks in advance for your ideas. > Ron > RV-4 N8ZD Hi Ron As Brian mentioned, loss of one ignition will cause all the EGTs to rise simultaneously, along with a small loss of power and slightly lower CHTs. I have had these exact symptoms caused by an ignition failure in the climb--I noticed it when EGTs went well above their normal peaks as I tried to lean. You can diagnose this quickly by cycling the mags in the air, but this is probably best done without your wife in the back seat (or so I've heard. At length.). I think it's most likely an indicator issue, but would check ignition first. I have a vague recollection of reading about similar symptoms with an EIS with a wiring issue sometime in the last few weeks. You might want to try Greg at Grand Rapids--he seems to be pretty responsive. A search of the various RV/aerolelectric forums and Doug's VAF site for "EIS" and "EGT" might turn up some relevant posts. James Freeman ________________________________________________________________________________
Date: Aug 25, 2006
Sorry Barry, but Brian is correct. Demonstrable on any mag check during run up or an in flight mag check. The flame front propagates slower with single ignition, and burns longer in the cylinder, making it hotter coming out the exhaust. FLYaDIVE(at)aol.com wrote: > > In a message dated 8/25/06 8:41:24 PM Eastern Daylight Time, > brian-av(at)lloyd.com writes: > >> If you have a sudden high EGT on all cylinders, check to see if one >> mag has stopped working. If both mags are normal and CHTs are normal, >> look for a gauge problem. > ================================ > Brian: > > If you reduce your spark in half your EGT goes DOWN not UP. Loss of a Mag > reduces combustion efficiency. If the timing is incorrect EGT can go UP but > usually the Oil and CHT follows. > Ron said CHT was 390 F but he did not say that was his NORMAL ... Only that > is below 390F. ________________________________________________________________________________
Date: Aug 25, 2006
Good Evening Barry, May I suggest that you rethink that a bit? When operating on one magneto, the EGTs will rise. Why? Because the timing is effectively retarded and the peak temperature occurs later in the combustion cycle. The fire gets closer to the point where it is measured. The actual peak combustion pressure and temperature will both be lower, but due to the timing change, the EGTs Will be higher. Happy Skies, Old Bob --- FLYaDIVE(at)aol.com wrote: > FLYaDIVE(at)aol.com > > In a message dated 8/25/06 8:41:24 PM Eastern > Daylight Time, > brian-av(at)lloyd.com writes: > > > If you have a sudden high EGT on all cylinders, > check to see if one > > mag has stopped working. If both mags are normal > and CHTs are normal, > > look for a gauge problem. > ================================ > Brian: > > If you reduce your spark in half your EGT goes DOWN > not UP. Loss of a Mag > reduces combustion efficiency. If the timing is > incorrect EGT can go UP but > usually the Oil and CHT follows. > Ron said CHT was 390 F but he did not say that was > his NORMAL ... Only that > is below 390F. > > What Ron should be looking for is something that > will cause LEANING ... > either Less Fuel or More Air. > My first place to look would be an AIR LEAK around > the Carb. > Second place would be the rubber coupling on the > intake, but the chances of > that are very slim since ALL cylinder increased EGT. > > Third place is an EXHAUST Leak. Around the flanges > ... Ron, you didn't use > those cheep soft exhaust gaskets? > I have a very difficult time believing that all 4 > EGT probes drifted in the > same direction. Or that the EIS failed in such a > manor that ONLY the EGT was > affected and not the CHT. > > Barry > "Chop'd Liver" > > "Show them the first time, correct them the second > time, kick them the third > time." > Yamashiada > > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > Web Forums! > > > Admin. > > > > > ________________________________________________________________________________
Date: Aug 25, 2006
Turning off one mag slows down the combustion process - effectively retarding the spark timing. That will cause the EGT to rise because more of the fuel air mixture will be left burning when the exhaust valve opens. Cylinder pressure WILL be lower.. See John Deak and George Braly for more info. Or.. Try it on your plane. Regards, Matt- FLYaDIVE(at)aol.com wrote: > >In a message dated 8/25/06 8:41:24 PM Eastern Daylight Time, >brian-av(at)lloyd.com writes: > >>If you have a sudden high EGT on all cylinders, check to see if one >> mag has stopped working. If both mags are normal and CHTs are normal, >> look for a gauge problem. > >================================ >Brian: > >If you reduce your spark in half your EGT goes DOWN not UP. Loss of a Mag >reduces combustion efficiency. If the timing is incorrect EGT can go UP but >usually the Oil and CHT follows. >Ron said CHT was 390 F but he did not say that was his NORMAL ... Only that >is below 390F. > >What Ron should be looking for is something that will cause LEANING ... >either Less Fuel or More Air. >My first place to look would be an AIR LEAK around the Carb. >Second place would be the rubber coupling on the intake, but the chances of >that are very slim since ALL cylinder increased EGT. >Third place is an EXHAUST Leak. Around the flanges ... Ron, you didn't use >those cheep soft exhaust gaskets? >I have a very difficult time believing that all 4 EGT probes drifted in the >same direction. Or that the EIS failed in such a manor that ONLY the EGT was >affected and not the CHT. > >Barry >"Chop'd Liver" > >"Show them the first time, correct them the second time, kick them the third >time." >Yamashiada > ________________________________________________________________________________
Date: Aug 25, 2006
On Aug 25, 2006, at 6:59 PM, FLYaDIVE(at)aol.com wrote: > > In a message dated 8/25/06 8:41:24 PM Eastern Daylight Time, > brian-av(at)lloyd.com writes: > >> If you have a sudden high EGT on all cylinders, check to see if one >> mag has stopped working. If both mags are normal and CHTs are >> normal, >> look for a gauge problem. > ================================ > Brian: > > If you reduce your spark in half your EGT goes DOWN not UP. Normally I try to be diplomatic but in this case I will make an exception. You are just plain wrong. Proof: Turn off one mag in cruise and watch your EGT go up by about 100F. Reason: With both mags working you have two flame-fronts in the combustion chamber. This means that combustion completes sooner allowing more time for the gas to transfer heat to the components in the cylinder thus leading to cooler gas going out the exhaust. When you turn off one mag you have only one flame front and the combustion time is slightly longer. There is now less time after the end of combustion and before the exhaust valve opens so your EGT is higher. > Loss of a Mag reduces combustion efficiency. Yeah, so? > If the timing is incorrect EGT can go UP but > usually the Oil and CHT follows. Actually, if you get advanced timing your CHT will go up but your EGT will go down for the reasons I outlined above. Detonation will do the same thing. > Ron said CHT was 390 F but he did not say that was his NORMAL ... > Only that > is below 390F. I read that to mean that he did not see an increase in CHT. > > What Ron should be looking for is something that will cause > LEANING ... Perhaps. The simplest explanation for a 100F rise in EGT across all cylinders without a rise in CHT is the loss of a mag. (Actually CHT will drop slightly as less heat is transferred to the head.) It is also pitifully easy to check. After that it is time for more difficult tests and inspections. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 25, 2006
>> I recently installed a new autopilot servo in my Berkut (all composite). > It >> worked perfectly, but for some reason, the servo makes a loud squealing >> noise in the intercom audio when it's activated. > > [Barry] When what is activated, the intercom or the servo? When the servo is active. The squeal is itermittent but coupled with the motion of the servo. As in when pressure is applied against the stick and the servo is commanded to move the other direction. This was without the filter installed, of course. >> I did all the usual >> things - changed ground points, increased grounding, double checked >> shielding on cables, un-bundled wires, ferrite beads on the cables, etc. >> The only thing that really worked was to power the servo from a separate >> battery - indicating electrical propagation, not RF. I spoke with the >> manufacturer, and they did mention that there was a 2.5KHz PWM signal >> that >> is used to control the servo, and that the "noise" I hear is likely >> that. >> So, on to trying to isolate the servo from everything else...right. >> >> I first tried (at the manufacturer's request) a pair of capacitors (.1uf > and >> 4700uf) in parallel, grounded off the servo power lead itself. This did >> slightly dampen the noise, but certainly not enough. > > [Barry] I gather the 47000uf cap was an electrolytic and the other was a > ceramic disc? Yup. The cap combo didn't do much to squelch the noise. The filter cuts it by 99%. >> So, I also went out >> and purchased a common 10-amp car audio power filter - just like those > sold >> by Radio Shack and documented by Bob on his site - 2 caps with a choke > coil >> potted in a case although I can not see the ratings on the caps. > >> I placed the filter in an orientation that isolated the power source from > the servo, >> instead of servo from power source as IT was the verified source of the >> noise. > > [Barry] I'm not sure what you mean my that statement. > Is the filter mounted as close to the servo as posable, short leads and a > clean ground? That is how it should be installed. Yes, they are short - about 3" from servo. I rigged up a short pig-tail so I could attach it and detach it for testing. I just mean that the filter is a stimple choke coil with a two caps in parallel like Bob has documented: http://www.aeroelectric.com/articles/filter/RS_Noise_Filters.pdf#search=%22filter%22 >> The good news is, that filter eliminated about 99% of the noise - and > that's >> good to go. I have not yet done extensive tests to see if the AP now >> operates properly in flight with the filter in-line (possible I/O >> errors, >> proper servo feedback, etc)...that's coming soon. But, I want to >> explore >> the "weirdness" first. >> >> Now, the weird (to me anyway) part is that the filter itself now audibly >> "sings" with the same frequency that I had heard before on the intercom. > I >> mean, it literally makes the noise like a speaker would. Is this >> normal? > > [Barry] Weird to me too? Are you saying that the filter has a noise > coming > from it? If so then your GROUND is poor and maybe your leads too long. > This > of course is assuming that the filter is made well and the coils of the > filter > are mounted / potted securely. But, the first thing I would check is the > GROUND. Yup. the filter itself is the source of the audible noise. It is connected to the common "nose" ground block. That block is fat wired striaght back to the battery. I'm not sure what else to "check" or how. I have opened the filter's case up, but it's components are potted with glue and I can't read the cap values. But I can see that it's just a coil, and two caps in a plastic case. > Other thing to check would be your crimps. I would rather have you tell > me > that you soldered these connection. All PIDG crimps. All have been checked as secure. Filter still singing like a canary. James Redmon Berkut #013 N97TX http://www.berkut13.com ________________________________________________________________________________
Date: Aug 25, 2006
> You are putting current pulses through an inductor so it has a magnetic > field that is varying with the current pulses. Any steel object nearby is > going to be alternately pulled and released by the varying magnetic > field. It is probably the case of the inductor or the inductor's core > that is making the noise. Humm...might be the inductor core..it's not mounted near anything else (6"+ minimum). The noise is definately coming from inside the filter case (plastic) and I can feel it vibrating with the sound. > OTOH, there shouldn't be that much current change. Put the capacitor > combo back at the input to the servo. The cap combo didn't do much at all to help the noise. Maybe a 5% reduction. Thanks for the input! James Redmon Berkut #013 N97TX http://www.berkut13.com ________________________________________________________________________________
Date: Aug 26, 2006
> Well, 2.5 KHz is within the audible frequency range. The A above Middle C > is 440 Hz. So you're only talking about less than 6 octaves above it. > All it would take is having the coil inside the filter that has this > frequency applied to it being physically in contact with the case or other > structure. I can envision that real easily. We usually call that > "headphones" or "loud speaker". So, you might have to take it apart and > make sure the filter is physically isolated from the box around it using > RTV or rubber gaskets or something. Well, the caps and coil are in a plastic case, and are installed with some kind of clear gel glue - like hot glue. I can not see that anything is touching the case without the goop inbetween. > Be careful about filtering the PWM signal, though. The whole purpose is > to feed that signal to the servo, and if you are applying a filter that > changes the shape, the servo might start functioning incorrectly. Yeah. There does not seem to be any issues with the servo operation, but then I have not flown it either. I will do some flight testing tomorrow. I also plan to disconnect the filter, setup the AP servo, get it working in flight (if I can bear the noise in the headset), and then re-connect the filter and see if there are any servo problems. I'll know more tomorrow. One thing - I can live with the singing filter if the AP works properly. It's not loud enough to hear over any engine noise....but the noise over the headsets is LOUD! James Redmon Berkut #013 N97TX http://www.berkut13.com ________________________________________________________________________________
Date: Aug 26, 2006
I've had singing capacitors in audio equipment before, it means it's a bad capacitor. Try replacing it or the whole filter assembly. Rick On 8/25/06, James Redmon wrote: > > james(at)berkut13.com> > > > Well, 2.5 KHz is within the audible frequency range. The A above Middle > C > > is 440 Hz. So you're only talking about less than 6 octaves above it. > > All it would take is having the coil inside the filter that has this > > frequency applied to it being physically in contact with the case or > other > > structure. I can envision that real easily. We usually call that > > "headphones" or "loud speaker". So, you might have to take it apart and > > make sure the filter is physically isolated from the box around it using > > RTV or rubber gaskets or something. > > Well, the caps and coil are in a plastic case, and are installed with some > kind of clear gel glue - like hot glue. I can not see that anything is > touching the case without the goop inbetween. > > > Be careful about filtering the PWM signal, though. The whole purpose is > > to feed that signal to the servo, and if you are applying a filter that > > changes the shape, the servo might start functioning incorrectly. > > > Yeah. There does not seem to be any issues with the servo operation, but > then I have not flown it either. I will do some flight testing tomorrow. > > I also plan to disconnect the filter, setup the AP servo, get it working > in > flight (if I can bear the noise in the headset), and then re-connect the > filter and see if there are any servo problems. > > I'll know more tomorrow. One thing - I can live with the singing filter > if > the AP works properly. It's not loud enough to hear over any engine > noise....but the noise over the headsets is LOUD! > > > James Redmon > Berkut #013 N97TX > http://www.berkut13.com > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 26, 2006
On Aug 25, 2006, at 9:58 PM, James Redmon wrote: > > >> You are putting current pulses through an inductor so it has a >> magnetic field that is varying with the current pulses. Any steel >> object nearby is going to be alternately pulled and released by >> the varying magnetic field. It is probably the case of the >> inductor or the inductor's core that is making the noise. > > Humm...might be the inductor core..it's not mounted near anything > else (6"+ minimum). The noise is definately coming from inside the > filter case (plastic) and I can feel it vibrating with the sound. > > >> OTOH, there shouldn't be that much current change. Put the >> capacitor combo back at the input to the servo. > > The cap combo didn't do much at all to help the noise. Maybe a 5% > reduction. I know that but it might help with the noise coming from the filter. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 26, 2006
Humm...given the potting inside the filter, I think I'd end up destroying it in the process of dis-assembly. I might try replacing the whole filter. Attached is a picture of the unit - I have not been able to track down any electrical specifics. Curious, if one of the two capacitors went bad, wouldn't it fail (at least partially) to squelch the noise and no longer "filter" as well? Or is there a partial failure mode of a capacitor that I'm not aware of? Thank you all for the help and ideas - it's very educational. I'll fly it today, and see if the servo is operating properly with and without the filter attached. (it's rigged as a small jumper cable so I can easily plug and un-plug it) I think if the AP servo works properly, I'll just let the filter audibly "sing". At least there's no appreciable noise in the headsets. James Redmon Berkut #013 N97TX http://www.berkut13.com ----- Original Message ----- From: Richard Girard To: aeroelectric-list(at)matronics.com Sent: Saturday, August 26, 2006 2:09 AM Subject: Re: AeroElectric-List: Noise filter noise I've had singing capacitors in audio equipment before, it means it's a bad capacitor. Try replacing it or the whole filter assembly. Rick ________________________________________________________________________________
Subject: Master Relay Wiring
Date: Aug 26, 2006
Is it normal for the master relay to be connected directly to ground via the master On switch? In the circuit recommended by Vans, which is probably an aviation standard design, there is no fuse or circuit breaker in series with the current flowing through the Master relay coil. Every other circuit seems to have a protection device wired in series. Perhaps someone could explain why? Barry RV6A -------- Barry Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57540#57540 ________________________________________________________________________________
Date: Aug 26, 2006
Subject: Re: Master Relay Wiring
Hi Barry, > > Is it normal for the master relay to be connected directly to ground via the master On switch? Yes > there is no fuse or circuit breaker in series with the current flowing through the Master relay coil. > Every other circuit seems to have a protection device wired in series. > Perhaps someone could explain why? > The fuse or CB protects the wire against overheating due to excessive current intensity. In this particular circuit, the current is limited by the relay coil, so no protection is needed. Hope this helps, Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Aug 26, 2006
Subject: Two Questions
Experts and Builders, I have two questons for you. 1. Where did you physically locate your alternator cicuit breaker in your airframe? 2. Is it a good idea to have a bus bar forward of the firewall to obtain power for various sensors in the engine compartment? Thank you. Stan Sutterfield ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)allvantage.com>
Subject: Thermocouple wire
Date: Aug 26, 2006
If I am going to buy wire to make my own "J" thermocouples, should I buy stranded or solid wire for use in my plane? If I buy stranded, do I silver solder the ends together the same as with solid wire? I am looking at 24 AWG wire. Does it make any difference whether you use "J" or "K" wire to the instrument that you hook it up to? In other words, can you hook up "J" wire to an EGT meter and use it to read CHT, or OAT, or oil temp, or whatever? (I understand that you can hook up "K" wire to an EGT meter and use it to read CHT..That is not what I am asking.. I am wondering if the meter is calibrated to the type of wire) Thanks, Bill Bradburry ________________________________________________________________________________
Date: Aug 26, 2006
From: "Greg Campbell" <gregcampbellusa(at)gmail.com>
Subject: Transorbs for Lancair Flap Actuator...
What size Transorb or MOV would be suitable for the flap motor on a Lancair ES ? They use an "FL1" 12v (or 24v) "linear actuator", Aircraft Spruce part # 05-66223 http://www.aircraftspruce.com/catalog/appages/flaplinact.php Lancair provided the flap actuator, limit switches, and Omrom 12vdc relays. I'm still using the "factory standard" schematic, but it doesn't utilize diodes or MOV's to protect the switches or relays. The flap motor is a pretty healthy size motor, I'm guessing the amp draw is around 8 or 10 amps. The Lancair schematic shorts the two terminals of the flap motor together when the flap is not in operation. This acts as an electronic brake and noticeably minimizes any tendency to "coast". If I wanted to add a transorb - would I just wire it in parallel with the motor leads? What size would I use? (Mine is a 12v system, but others have the 24v model.) Thanks, Greg ________________________________________________________________________________
Date: Aug 26, 2006
Subject: Re: Thermocouple wire
"Bill Bradburry" wrote: > > If I am going to buy wire to make my own "J" thermocouples, should I buy > stranded or solid wire for use in my plane? If I buy stranded, do I > silver solder the ends together the same as with solid wire? I am > looking at 24 AWG wire. > Does it make any difference whether you use "J" or "K" wire to the > instrument that you hook it up to? In other words, can you hook up "J" > wire to an EGT meter and use it to read CHT, or OAT, or oil temp, or > whatever? (I understand that you can hook up "K" wire to an EGT meter > and use it to read CHT..That is not what I am asking.. I am wondering if > the meter is calibrated to the type of wire) > > Thanks, > Bill Bradburry > Hi Bill, You need to use the type wire the instrument is calibrated for to get an accurate reading. Each type of thermocouple has a characteristic voltage vs temp. Type K thermocouples are better for higher temps like the EGT, and Type J is more suitable for lower temps like CHT. You can make a useful TC junction by twisting the wires together, silver soldering, spot welding, etc. Although twisting the wires together would only be suitable for temporary use, and you might not have a very good junction but it would work. Silver solder might not make an ideal junction but it would be stable. A good weld would be best. I've made J thermocouples by twisting the wires together and melting the joint in an ox/acetylene flame. I checked them in boiling water and they were within a degree or two of the correct temperature. The effect of having a not perfect junction is that the voltage vs temp will be lower than a good TC, but it will be stable for that particular TC. In other words, with a "bad" junction temperature will read too low. One of the rotary engine guys, Todd Bartrim, has built Thermocouples suitable for use as EGT probes. His procedure is documented at http://www.rotarywiki.org/wiki/tiki-index.php?page=EgtThermocouples Bob W. -- http://www.bob-white.com N93BD - Rotary Powered BD-4 (first engine start 1/7/06) Custom Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Subject: Re: Two Questions
Date: Aug 26, 2006
On Aug 26, 2006, at 12:59 PM, Speedy11(at)aol.com wrote: > Experts and Builders, > I have two questons for you. > 1. Where did you physically locate your alternator cicuit breaker > in your airframe? I actually used a fuse forward of the firewall. If that sucker pops you know you have a serious problem that you are not going to troubleshoot in flight. > 2. Is it a good idea to have a bus bar forward of the firewall to > obtain power for various sensors in the engine compartment? I guess that is up to you and the way you wire your engine compartment. I didn't as there was nothing firewall forward that needed power from the bus. My sensor box was powered from the display in the panel so I didn't need to run power forward. Brian Lloyd 361 Catterline Way brian HYPHEN av AT lloyd DOT com Folsom, CA 95630 +1.916.367.2131 (voice) +1.270.912.0788 (fax) I fly because it releases my mind from the tyranny of petty things . . . Antoine de Saint-Exupry ________________________________________________________________________________
Date: Aug 26, 2006
Bill, I strongly recommend you get the wire already manufactured for thermocouples. Aircraft Spruce has 15 foot lengths that you can cut to the desired lengths for very little money. The type of wire is critical to thermocouple usage. David M. Bill Bradburry wrote: > >If I am going to buy wire to make my own "J" thermocouples, should I buy >stranded or solid wire for use in my plane? If I buy stranded, do I >silver solder the ends together the same as with solid wire? I am >looking at 24 AWG wire. >Does it make any difference whether you use "J" or "K" wire to the >instrument that you hook it up to? In other words, can you hook up "J" >wire to an EGT meter and use it to read CHT, or OAT, or oil temp, or >whatever? (I understand that you can hook up "K" wire to an EGT meter >and use it to read CHT..That is not what I am asking.. I am wondering if >the meter is calibrated to the type of wire) > >Thanks, >Bill Bradburry > > > > ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Aug 26, 2006
Bill; Stranded vs. solid is your choice but bear in mind that stranded is more flexible and less prone to vibration fatigue than solid, but both will function. Any point at which the two different wire alloys are joined forms a thermocouple junction capable of generating a voltage and thus measuring temperature. Twisting them together works, just not very long term reliable, hence welding or silver solder can be used. Yes the instrument is calibrated to the type of wire. The voltage vs. temperature curves for all the various types of thermocouple wire (J, K, T, E, R, S, C,GB, etc) are quite different and the instrument range and calibration must match the wire. One reason for the multitude of types is to be able to measure temperatures through different ranges. Thus your EGT and CHT thermocouples may well be different types as might your OAT if you chose to use a thermocouple. Type J - Zero to 750 deg C Type K - minus 200 to 1250 deg C Type E - minus 200 to 900 deg C Type T - minus 250 to 350 deg C etc. ob McC ----- Original Message ----- From: "Bill Bradburry" <bbradburry(at)allvantage.com> Sent: Saturday, August 26, 2006 4:41 PM Subject: AeroElectric-List: Thermocouple wire > > If I am going to buy wire to make my own "J" thermocouples, should I buy > stranded or solid wire for use in my plane? If I buy stranded, do I > silver solder the ends together the same as with solid wire? I am > looking at 24 AWG wire. > Does it make any difference whether you use "J" or "K" wire to the > instrument that you hook it up to? In other words, can you hook up "J" > wire to an EGT meter and use it to read CHT, or OAT, or oil temp, or > whatever? (I understand that you can hook up "K" wire to an EGT meter > and use it to read CHT..That is not what I am asking.. I am wondering if > the meter is calibrated to the type of wire) > > Thanks, > Bill Bradburry > > ________________________________________________________________________________
Date: Aug 27, 2006
Subject: Re: Transorbs for Lancair Flap Actuator...
Date: Aug 27, 2006
> What size Transorb or MOV would be suitable for the flap motor on a Lancair ES ? They use an "FL1" 12v (or 24v) "linear actuator", Aircraft Spruce part # 05-66223 ..... > > Lancair provided the flap actuator, limit switches, and Omrom 12vdc relays. I'm still using the "factory standard" schematic, but it doesn't utilize diodes or MOV's to protect the switches or relays. The flap motor is a pretty healthy size motor, I'm guessing the amp draw is around 8 or 10 amps. > > The Lancair schematic shorts the two terminals of the flap motor together > when the flap is not in operation. This acts as an electronic brake > and noticeably minimizes any tendency to "coast". > > If I wanted to add a transorb - would I just wire it in parallel with the motor leads? What size would I use? (Mine is a 12v system, but others have the 24v model.) Thanks, Greg Greg, Transient supressors are installed so as to shunt the inductive coil in a relay or motor, and also to shunt to ground the positive leads on bidirectional motors. The SnapJack suppressors on my website are fine and I show the places to mount them. For 24-28V systems us 600 mA 36V bidirectional transorbs. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57844#57844 ________________________________________________________________________________
Date: Aug 27, 2006
An update to the noise issues: Well, in short, the noise problems are solved. The test flights showed that the filter disrupted the PWM signal to the extent that it was un-flyable. So, the quick fix "filter" solution was not possible. I tried various combinations of grounds and power and the only combination that eliminated the noise was feeding the unit directly from the battery and grounding it only to the battery as well. This meant isolating the unit's mounting so that it did not touch a ground in the front of the plane (battery is in the back). So, with this combination required tearing the plane apart to install dedicated lines (all out of spares), but at least all systems are functional and quite happy with one another. The one combination I didn't try was to install the filter on the intercom or audio circuit itself. I figured I'd take the simplest route to solve the problem as protecting the audio may have opened the door to at least 6 different sources (2 coms, audio panel, intercom, engine monitor, etc.). Yikes! Moral: if you are still building, do yourself a favor and pre-installed triple the number of fore-aft wires that you think you need - you'll run our of spares before you know it. ;-) Anyway, the AP tracks dead-nuts-straight-on...and no noise to boot. All smiles here...despite the bloody knuckles and pricked fingers. Thanks to those offering explanations and ideas. I learned a lot on this one. James Redmon Berkut #013 N97TX http://www.berkut13.com ________________________________________________________________________________
Subject: Davd Clark X-11 headset review?
Date: Aug 28, 2006
Hello listers, The David Clark Co. Inc. website offers what apears to be a new headset called X 11. The promo on the website looks good I have not heard or found any other reports pro or can about this product. Would anyone care to offer opinions based on actual use? Jim in Kelowna - final inspection soon ________________________________________________________________________________
Date: Aug 28, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Engine Kick-Back IO-360
> > > --> RV-List message posted by: "J. R. Dial" <jrdial@hal-pc.org> > > > > I did not break a starter but the inrush current to the > > permanent magnet starter I had dropped my voltage low enough that it > > was > > below the compliance voltage for the electronic ignition. I changed > > it > > out for a wound field starter and the problem was solved. > > If you want to know brand names etc. email me off list. > >Now here is a problem I've never heard of before. >Does anyone else have this problem and can it be >resolved without changing out starters ? >Larry Mac Donald >lm4(at)juno.com >Rochester N.Y. >Do not achcive This "problem" and "solution" has been around for a long time. When the volumes of rare-earth magnet motors was taking off in the market place (and prices coming down) we (at B&C) considered a change-over to the burgeoning technology. The change was rejected for several reasons but prominent among them was the extra-ordinary "locked- rotor" current characteristics of the PM motor. This did not present a systems issue with respect to getting the engine running but we were already aware of problems that some companies had with respect to momentary "brownouts" during the first phases of engine cranking. A typical system voltage transient during first closure of starter contactor may be seen at: http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_1.gif http://www.aeroelectric.com/Pictures/Curves/95_GMC_Safari_3.gif http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1.jpg http://www.aeroelectric.com/Pictures/Curves/99_Saturn_SL1_2.gif These are battery terminal voltages taken from our cars. The batteries are in excellent health. Note in particular, the last curve where the battery voltage stays below 9.0 volts (DO-160 recommended, "stay awake" voltage level) for about 50 mS. If the ignition system (or any other accessory) shared any supply current paths with the starter the voltage drops on wires would exacerbate the brown out conditions illustrated. Unfortunately, many folks who would sell to either the TC or OBAM aviation worlds do not take the DO-160 recommendations to heart and ignore the realities of cranking systems operation, they allow their products loose in the wild with unhappy vulnerabilities to such transients. Sometimes it's an extended reboot interval for a computer based accessory, or timing for an ignition system wherein the system delivers spark at the wrong times. One of several reasons B&C elected to stay with wound fields was to reduce probability that their product would be cited as "root cause" of problems with other systems. Contrary to popular myth, starters are NEVER root cause for misbehavior of another system, only a piece of a puzzle at best . . . for issues that would not have arisen had manufacturers of the "victimized" systems done their homework. Bob . . . ________________________________________________________________________________
Subject: Turn on ALT before engine start?
Date: Aug 28, 2006
In an airplane equipped with a Continental 0-200, would you want to turn on the ALT switch before engine start, or after? Thanks! Read this topic online here: http://forums.matronics.com/viewtopic.php?p=57936#57936 ________________________________________________________________________________
Date: Aug 28, 2006
Greg, Could you post that part of the circuit (or sketch) showing the "brake" system relays where it "shorts" the motor leads. Working on something similar for a homebuilt project with 28v. Also where you would put the transorbs. Thanx Bob Verwey A35 Bonanza ZU-DLW ________________________________________________________________________________
Date: Aug 28, 2006
From: "Johnson, Phillip (EXP)" <phillip.johnson(at)lmco.com>
The core of the inductor is probably lightly magnetostrictive which will cause the core to vibrate under electrical excitation. This is normal, however if the mechanical resonance of the core is close to the excitation frequency then it will howl quite loudly and may induce premature failure of adjacent components. If this is the case then you can damp the vibration by adding some silicone or epoxy to the inductor. This will move the natural frequency and damp the vibration. Phillip Johnson L Chief Engineer & Manager Underwater Systems Group Tel (613) 599 3280 ext. 3232 Cell (613) 799 1644 FAX (613) 599 3282 ________________________________________________________________________________
Date: Aug 28, 2006
From: "Bishop, Robert C MSgt 21 MOF/CCA" <robert.bishop(at)peterson.af.mil>
TWIMC, How on earth can I get off this "Chat Board" distribution list? I get about 300 unwanted e-mails a day... Any help would be appreciated. Thanks MSgt Robert Bishop 21 MOF/CCA W: 556-6527 (DSN 834) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob Verwey Sent: Monday, August 28, 2006 6:57 AM Subject: Re: AeroElectric-List: Transorbs for Lancair Flap Actuator... Greg, Could you post that part of the circuit (or sketch) showing the "brake" system relays where it "shorts" the motor leads. Working on something similar for a homebuilt project with 28v. Also where you would put the transorbs. Thanx Bob Verwey A35 Bonanza ZU-DLW ________________________________________________________________________________
Subject: Re:How to unsubscribe
Date: Aug 28, 2006
Mr. Bishop, go to http://www.matronics.com/subscription and follow instruction to unsubscribe. DWE do not archieve ----- Original Message ----- From: "Bishop, Robert C MSgt 21 MOF/CCA" <robert.bishop(at)peterson.af.mil> Sent: Monday, August 28, 2006 9:36 AM Subject: RE: AeroElectric-List: Transorbs for Lancair Flap Actuator... MOF/CCA" > > TWIMC, > How on earth can I get off this "Chat Board" distribution list? I get > about 300 unwanted e-mails a day... Any help would be appreciated. > Thanks > > MSgt Robert Bishop > 21 MOF/CCA > W: 556-6527 (DSN 834) > ________________________________________________________________________________
Date: Aug 28, 2006
Subject: Re: Davd Clark X-11 headset review?
Jim, I didn't get a chance to wear them in-flight for my most recent headset review (for Kitplanes - they hadn't been released before the deadline), but when I tried them on at the booth, they were incredibly comfortable, rivally the Bose X, and the audio quality was very good. If they have a try and buy deal, I'd gibe it a shot. My immediate impression was that I wished I could have flown them for the review. best, Coryt Jim Jewell wrote: > > Hello listers, > > The David Clark Co. Inc. website offers what apears to be a new > headset called X 11. > > The promo on the website looks good > I have not heard or found any other reports pro or can about this > product. > > Would anyone care to offer opinions based on actual use? > > Jim in Kelowna - final inspection soon > >
August 22, 2006 - August 28, 2006
AeroElectric-Archive.digest.vol-ga
