AeroElectric-Archive.digest.vol-gf
October 02, 2006 - October 16, 2006
      The stiffness of a system determines which of these can be ignored in any practical
      application. Designers and engineers have the job of measuring some of
      these elements and constraining the system to prevent the others from becoming
      critical. This has other physical science analogues too.
      The exercise is left for the student.
      "Everything you've learned in school as "obvious" becomes less and less obvious
      as you begin to study the universe. For example, there are no solids in the universe.
      There's not even a suggestion of a solid. There are no absolute continuums.
      There are no surfaces. There are no straight lines."
         - R. Buckminster Fuller
      Eric M. Jones
      www.PerihelionDesign.com
      113 Brentwood Drive
      Southbridge, MA 01550
      (508) 764-2072
      emjones(at)charter.net
      http://forums.matronics.com/viewtopic.php?p=65198#65198
Subject: Now G's
Date: Oct 02, 2006
"the cap moves over detent" JFTR: There is no detent, the cap is held in place by friction... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Monday, October 2, 2006 9:23 AM Subject: Re: AeroElectric-List: Now G's Those clear Bic pens are still around in my area. What I'do is weigh the cap with a precision scale, then push the cap on against a larger scale. And then do the math to get the gs... Regards, Gilles Thesee Grenoble, France http://contrails.free.fr =========================== Gilles: What you would be measuring there would be FORCE, not g's. It is the force to overcome the friction of the pen's closing mechanism. Don't use your hand in the test. It will adsorb some of the force in the opposite direction and give you a lower reading. You should hook up something like a screw / c-clamp fixture. Also, there is basically no acceleration in this test. But, you can work out the Mass of the entire pen use acceleration of 32 ft per second squared (sorry I do not recall the metric conversion) and apply it to the test. The number will not match the 200 g's I mentioned but it will be quite interesting, quite high. Force is force is force . . . whether it's applied with the hand or any other device is not material to the measurement . . . except that to measure PEAK force as the cap moves over detent might me easier to observe if the force is applied in very small, smooth increments like with the clamp. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: Connectors vs. Straight Wire
Date: Oct 02, 2006
Greetings, The entire instrument panel on my Lancair Legacy I'm building is attached to the airframe with only four bolts and is therefore relatively easy to remove in one large piece. That is, mechanically easy to remove, if it weren't for a bazillion wires connecting it to the airframe. On the other hand, the Legacy has a front hinged canopy and a removable glare shield, which provide reasonably good access to the rear of the instrument panel while it is in place. I can either run the wires from the airframe directly to the various components on the panel or I can insert D-Sub connectors between all the wires and the instrument panel. If I use connectors, it will make removing the instrument panel easier for repairs or upgrades. Running the wires directly to the panel, without connectors, will reduce the parts count but make future service more difficult. I'm torn between the two alternatives. My first thought was to add connectors to every wire in the expectation that I'll almost certainly want to remove the instrument panel at some point in the future for troubleshooting, repairs, or upgrades. Working on the panel while it's on my workbench is soooooo convenient. But there are tons of wires, many of them shielded, and running every single one of them through a connector is a big project. Considering that I have reasonable access to the rear of the panel with the canopy open and the glareshield removed, should I just plan to service the panel with it in place? Anybody who's "been there, done that" have any advice? Thanks, Dennis Johnson Lancair Legacy; painting done, still wiring the panel ________________________________________________________________________________
Date: Oct 02, 2006
Subject: Re: battery cables & Relays 'G's" skunk stink
Anybody have a centrifuge with accelerometer and want to conduct a little experiment? Dave Morris At 10:07 AM 10/2/2006, you wrote: > >I think it is time for someone with a little authority to clear this >up. My authority is so little that I have hidden it under one of the >periods in this posting. A prize awaits the one who finds it. > >1) Relay mounting. Type 70 Stancor Rodgers White Emerson Tyco. See: > >http://www.alliedelec.com/Images/Products/Datasheets/BM/STANCOR/Stancor_Industrial-Control_5760005.pdf > >So the manufacturer says, "mount plunger vertical, cap down". I >checked into the engineering data on this part and of course the >corporate conglomeratization has destroyed the engineering knowledge >that built the part. The manufacturer PROMISED they'd get back to >me.....It's not DO-160 bubela. And it's only 122 deg F max operating >temp. Etc. etc. Use the Kilovac EV200 part if you can. > >(Yes, I am selling my Powerlink Jr. III now and I am MONTHS late.) > >2) G-forces: [CAUTION-Head May Explode] Jacob Rabinow's Law (not >that he called it that...). Gracefulness is "when the first, second, >and third derivatives of the equation of motion monotonically and >simultaneously go to zero." Which is to say--when the velocity, >acceleration and impulse (the change in acceleration) smoothly and >simultaneously go to zero. > >So many mysteries--a gyro will be ruined if placed on a workbench >hard enough to be audible, but will do fine in an airplane doing >aerobatics or combat. A pencil held horizontal and dropped 12 inches >experiences G-forces that will destroy an airplane and kill a pilot. >Curtis mercury-type elapsed-time meters were 12G-rated but failed if >dropped on a workbench. > >Motion is composed of displacement, velocity, acceleration and >impulse elements. The stiffness of a system determines which of >these can be ignored in any practical application. Designers and >engineers have the job of measuring some of these elements and >constraining the system to prevent the others from becoming >critical. This has other physical science analogues too. > >The exercise is left for the student. > >"Everything you've learned in school as "obvious" becomes less and >less obvious as you begin to study the universe. For example, there >are no solids in the universe. There's not even a suggestion of a >solid. There are no absolute continuums. There are no surfaces. >There are no straight lines." > - R. Buckminster Fuller > >-------- >Eric M. Jones >www.PerihelionDesign.com >113 Brentwood Drive >Southbridge, MA 01550 >(508) 764-2072 >emjones(at)charter.net > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=65198#65198 > > ________________________________________________________________________________
Date: Oct 02, 2006
Subject: Glowing LED Warning Lights, Too Dark Now-LM317
MikeEasley wrote: My LED voltage warning lights are now too dark to see in daylight after adding the resistors in the drawing. Smaller resistors? I have been "playing" with leds on a breadboard, controlling them with a LM317. The LM317 supplies constant voltage, determined by a resistance to (the control leg, I don't know the real term). I have used a rheostat and been able to control multiple or single leds, from very bright to very dim/off. I am planning to make an annunciator for a 300xl gps, which always has 2 leds on, sometimes 3, sometimes 4. I have the LM317 between the battery positive and the leds, the leds taking power from the LM317 with their other leg grounded. The leds are in parallel. A value to me of the LM317 is to be able to maintain constant brightness of multiple leds (I plan to use all the same white leds with colored lenses for colors). The LM317 is from Radio Shack and I have only used the circuit on the back of the box-LM317, a resistor, and a rheostat, 3 parts. Could I wire a backup with a zener diode for a constant brightness? However, I have been told this LM317 won't work, that I need Pulse Width Modulation. I'm not sure why, the LM317 seems to do what I want at least on my desk at home, is cheap and low parts count. I would appreciate any reasons this would not be a proper way to control multiple identical leds-rf production? Skip Simpson ________________________________________________________________________________
Date: Oct 02, 2006
Subject: fat wire - skinny wires
I seem to remember there being some rationale for not running fat wires in the same bundle with skinny wires, but I can find a specific reference to it in the "Aero-electric Connenction". Does such a rationale exist, or am I suffering from delusions of toxic aircraft chemical fumes? My #2 battery cable currently follows a rather tortuous path from the tailpost to the front of the plane, and I could be a lot simple (and a few pounds lighter), if it just ran down the side with a bunch of wires that include microphone/headphone leads, taillight, tail strobe, fuel pump powere, and a linear actuator control leads. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Oct 02, 2006
Hello Eric You wrote: "So the manufacturer says, "mount plunger vertical, cap down" I have never taken apart or looked very close at the relay that is being talked about. I can tell you that on old Savin 220 copiers had a lamp relay they called a K-5. It had a plunger that rode inside a brown phenolic guide. It was mounted horizontal. After some time, the phenolic would wear, and make a quite useful plunger movement limiting pocket in the phenolic. It was useful in demonstrating to customers just how a high resistance connection could cause so much smoke and not trip the main circuit breaker, that is until flames were a happening and the insulation complete gave way and then tripped. It was the contacts wearing out, and the pocket limiting motion. On machines under contract I modified to a vertical plunger. Could happen in some cases 10,000 copies. It was a 115V AC 15 amp relay, the plunger was perhaps 3/16" or 1/4" in diameter. all that was needed was a .005" pocket. Ron Parigoris ________________________________________________________________________________
Date: Oct 02, 2006
Subject: Re: Now G's
Hi all, > > JFTR: There is no detent, the cap is held in place by friction... > That's right, the clear Bic has no detent. For those interested, I've just done the Bic experiment. I'll take some pictures tomorrow, and craft a preliminary report on this major contribution to the advancement of Bic science. Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
From: "Mark Chamberlain" <mchamberlain(at)runbox.com>
Subject: Garmin 396/496 Connections
Date: Oct 02, 2006
Hi folks, I just purchased a bare wire data lead for the Garmin 396/496. It has several wires coming out of it, there are a couple labeled: Voice (-), Voice (+), alarm etc. Unfortunately there are no instructions as to where they are supposed to go. For example is the "alarm" wire for an audio alarm and therefore needs to be routed to a unswitched audio hook up? Or should it go to a light on the panel? What are the "Voice" wires for? Some sort of voice audio warnings or voice in to the unit? Not sure what they would be for as the audio out of the unit is stereo and therefor requires 3 wires, not just 2. If any of you guys have used this data cable to hard wire you GPS could you throw some light on this? Thanks, Mark - RV-7 finishing up last 5% ________________________________________________________________________________
Subject: Re: Mogas versus 100LL (Mostly Off Topic)
Date: Oct 02, 2006
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Don Rivera told me directly by email. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of 6440 Auto Parts Sent: Thursday, September 28, 2006 3:46 PM Subject: Re: AeroElectric-List: Re: Mogas versus 100LL (Mostly Off Topic) Frank did you go to an AFS seminar ? If so was it worth it ? If not where did you get the info that their system will run 100% ethanol ? I have'nt found much real info on their website. Randy ----- Original Message ----- From: Hinde, Frank George (Corvallis) To: aeroelectric-list(at)matronics.com Sent: Thursday, September 28, 2006 4:48 PM Subject: RE: AeroElectric-List: Re: Mogas versus 100LL (Mostly Off Topic) When i spoke to Superior they stated Vapour lock as the issue with ethanol mix...But when i asked if they really meant vapour lock or simply boiling of fuel in the injector lines ...Which is not vapour lock I did not get an answer. Secondly with my Airflow Performance system it can run on 100% ethanol if you so desire. I have high regard for Superior, don't get me wrong but there are MANY OWTs out there that one is forced to question. ECI states lead being a lubricant for valve seats as Gospel for example...I don't buy it because, 1 it sounds ridiculous and 2 there is more and more evidence to the contrary. Now in order to preserve the warranty (if there really is one) ECI demand that you use 100LL duting break in...OK for sure i will only start feeding in mogas after 25 hours or so...Not worth the risk. Soo..if you have a properly designed fuel system (my pumps are in the wingroots) I'm having a hard time understanding the objection to ethanol mixes...Apart from the fact we're getting short changed (lower grade fuel)to support our totally excessive farm production of course...:) Now it maybe the injector line boiling is so bad it s difficult to get the engine to run smooth...Definatly a possibility. I will phone Todd Peterson next week who has offered to fill me in (metaphorically speaking) on why ehtanol in mogas is a really bad thing....Not saying that he will be incorrect, just I don't understand why not at the moment. Frank Another 5 hours and i start filling gas cans...Non ethanol...for now..:) ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jerry2DT(at)aol.com Sent: Thursday, September 28, 2006 2:05 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Re: Mogas versus 100LL (Mostly Off Topic) Excellent article on Ethanol in current Consumer Reports. A couple things for sure are that Ethanol has 30% less BTU's than Gasoline 125k btu/gal vs. 84.4), thereby translating to 32% less mileage per gal. Ethanol is cleaner, which I guess is why it is mandated in some parts. I track my car gas mileage very closely and get 8% less mpg when using a mix. The math doesn't come out quite right with the btu's, but it is a fact, at least for my car. It is alleged that Ethanol rots some seals, gaskets. My 1996 Honda motorcycle specifically disallows it's use. There is no way I'll ever use a mix of gas/ethanol in my aircraft. Superior also bans Ethanol btw, although encourages use of premium mogas for their XP360's... FWIW, .02, etc. Jerry Cochran From: "Hinde, Frank George (Corvallis)" George (Corvallis)" Indeed yes are...but do you measure the RVP before you use it?...Even if the RVP is a little high you can ajust your flying to suit. As a bit of an aside I probably wouldn't store mogas for 6 months before using it. More of a question is wat if ethanol appears in the mix...i have an invite to phone Todd at Peterson for the low down on why not to use Ethanol...I'm not convinced on that one...at least not yet. More to come matronics.com/Navigator?AeroElectric-List matronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Oct 02, 2006
Dennis. I might be late with this comment.... But Cannon Plugs, Cannon Plugs, Cannon Plugs..... Did I say Cannon Plugs? You can get them in various densities. I'd try to keep it to 3 or 4 and group things together in logical sense. I know you can get them Lancair, or there are probably other sources as well. I've not gone there yet, but when I do, it will be Deutch connectors and Cannon plugs you can be assured. Also, heat-shrink labelers are pretty cheap and are available on ebay to help keep things grouped and sorted and labeled. Alan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis Johnson Sent: Monday, October 02, 2006 11:34 AM Subject: AeroElectric-List: Connectors vs. Straight Wire Greetings, The entire instrument panel on my Lancair Legacy I'm building is attached to the airframe with only four bolts and is therefore relatively easy to remove in one large piece. That is, mechanically easy to remove, if it weren't for a bazillion wires connecting it to the airframe. On the other hand, the Legacy has a front hinged canopy and a removable glare shield, which provide reasonably good access to the rear of the instrument panel while it is in place. I can either run the wires from the airframe directly to the various components on the panel or I can insert D-Sub connectors between all the wires and the instrument panel. If I use connectors, it will make removing the instrument panel easier for repairs or upgrades. Running the wires directly to the panel, without connectors, will reduce the parts count but make future service more difficult. I'm torn between the two alternatives. My first thought was to add connectors to every wire in the expectation that I'll almost certainly want to remove the instrument panel at some point in the future for troubleshooting, repairs, or upgrades. Working on the panel while it's on my workbench is soooooo convenient. But there are tons of wires, many of them shielded, and running every single one of them through a connector is a big project. Considering that I have reasonable access to the rear of the panel with the canopy open and the glareshield removed, should I just plan to service the panel with it in place? Anybody who's "been there, done that" have any advice? Thanks, Dennis Johnson Lancair Legacy; painting done, still wiring the panel ________________________________________________________________________________
Subject: Re: Garmin 396/496 Connections
Date: Oct 02, 2006
Actually, you do have instructions - they are in the GPS unit's Pilot's Guide toward the back. Even has a diagram to show you how it all hooks up. The "Voice" lines are external speaker lines for the auto-navigation speak output - "turn right in 100 feet", etc. Has nothing to do with "aviation" related features as all of those warnings and XM music all come out the audio plug. Hope that helps. James Redmon Berkut #013 N97TX http://www.berkut13.com ----- Original Message ----- From: "Mark Chamberlain" <mchamberlain(at)runbox.com> Sent: Monday, October 02, 2006 3:37 PM Subject: AeroElectric-List: Garmin 396/496 Connections > > > Hi folks, > > I just purchased a bare wire data lead for the Garmin 396/496. It has > several wires coming out of it, there are a couple labeled: Voice (-), > Voice (+), alarm etc. Unfortunately there are no instructions as to where > they are supposed to go. For example is the "alarm" wire for an audio > alarm and therefore needs to be routed to a unswitched audio hook up? Or > should it go to a light on the panel? What are the "Voice" wires for? Some > sort of voice audio warnings or voice in to the unit? Not sure what they > would be for as the audio out of the unit is stereo and therefor requires > 3 wires, not just 2. > > If any of you guys have used this data cable to hard wire you GPS could > you throw some light on this? > > Thanks, > > Mark - RV-7 finishing up last 5% ________________________________________________________________________________
Subject: Re: Connectors vs. Straight Wire
Date: Oct 02, 2006
Hi Alan, Thanks for the reply to my question about connectors to allow removing the instrument panel. You suggested Cannon plugs. It seems to me that Cannon plugs are more expensive and less convenient to install than D-Sub connectors. I hope there's not a fundamental problem with D-Subs because nearly every electronic component I installed came with D-Subs on the back. Best, Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65345#65345 ________________________________________________________________________________
Date: Oct 02, 2006
Oh, I think they would work ok... Except, I had one bad experience. I had a monitor with a 15pin D-Sub on it. It worked for a couple of years and then all of a sudden it started to flake out... I found that the "tension" on the female pins started to fail. I would have to "cock" the connector in order that the colors on the monitor appeared correct. Finally, it just wouldn't take any jiggling to get the colors right and I had to buy a new monitor. YMMV, but there are lots of kinds of Cannon plugs, and it's a one time investment. For something like interconnects that have to survive in "hostile" environments, its just my preference, but I'll use cannon plugs. Good luck btw, can't wait to see yours sometime :)... Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dennis Johnson Sent: Monday, October 02, 2006 8:26 PM Subject: AeroElectric-List: Re: Connectors vs. Straight Wire --> Hi Alan, Thanks for the reply to my question about connectors to allow removing the instrument panel. You suggested Cannon plugs. It seems to me that Cannon plugs are more expensive and less convenient to install than D-Sub connectors. I hope there's not a fundamental problem with D-Subs because nearly every electronic component I installed came with D-Subs on the back. Best, Dennis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65345#65345 ________________________________________________________________________________
Date: Oct 02, 2006
My comment will probably be a little different from the typical..but, I'd push you to do as much straight wiring as possible. On my 1st plane I did the Canon Plug thing all over the place.....have you ever tried to troubleshoot an electrical gremlin through a bunch of canon plugs or D-Subs? It's a pain in the rear. Once you add hundreds of pins, that's hundreds of new joints that are potential future problem areas. Next, why do you really need them? Sure, it sounds like a great idea, but really....how many times do you actually take a panel in and out of plane? As far as individual components, it only takes a couple screws to drop out any of the EFIS's out there, radios slide out of trays, etc..., so you don't get much advantage there. Next, even if you wanted you shouldn't run everything through canon plugs. Audio Wires specifically can get really touchy running them through connectors...all the headset, mic, aux leads are/should be shielded and breaking that shield just creates another area for noise and more gremlins to move in. You can't shouldn't split EGT/CHT wires, nor some other sensor wires along with the heavy wires. Basically, it looks good at airshows and in magazines, but the truth of the matter is it's almost impossible to get by NOT hooking some things directly to your panel anyway and then there you are with a bunch of nice looking canon plugs, then you Still have to remove things from the panel anyway....point is no matter what your intentions you'll still probably have a bunch of stuff hooked directly to the panel anyway (pitot tubing, static tubing, maybe some antennas, fat battery wires, 02 lines if you have them, "P" leads which shouldn't be broke, air vents lines, push/pull cables, so on and so forth). I guess I'm trying to say that anytime you added un-needed connections to a particular system you are just asking for longer term troubles and an overall reduction in reliability. Keep It Simple! Most of today's major components come out of the panels so easily that I can't see a huge benefit of just adding connectors in case someday you might want to yank the whole panel out? The point is you should wire and build your airplane for the 99th percentile of it's functionality and reliability, not the 1% "whatifs". I don't know if this all makes sense or not, but if it were me (and it is dozens of times we discuss panels with customers), I really try to put function ahead of form and convince people to do what makes sense from a functional, reliable and simplicity standpoint. You can't beat it! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dennis Johnson Sent: Monday, October 02, 2006 10:34 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Connectors vs. Straight Wire Greetings, The entire instrument panel on my Lancair Legacy I'm building is attached to the airframe with only four bolts and is therefore relatively easy to remove in one large piece. That is, mechanically easy to remove, if it weren't for a bazillion wires connecting it to the airframe. On the other hand, the Legacy has a front hinged canopy and a removable glare shield, which provide reasonably good access to the rear of the instrument panel while it is in place. I can either run the wires from the airframe directly to the various components on the panel or I can insert D-Sub connectors between all the wires and the instrument panel. If I use connectors, it will make removing the instrument panel easier for repairs or upgrades. Running the wires directly to the panel, without connectors, will reduce the parts count but make future service more difficult. I'm torn between the two alternatives. My first thought was to add connectors to every wire in the expectation that I'll almost certainly want to remove the instrument panel at some point in the future for troubleshooting, repairs, or upgrades. Working on the panel while it's on my workbench is soooooo convenient. But there are tons of wires, many of them shielded, and running every single one of them through a connector is a big project. Considering that I have reasonable access to the rear of the panel with the canopy open and the glareshield removed, should I just plan to service the panel with it in place? Anybody who's "been there, done that" have any advice? Thanks, Dennis Johnson Lancair Legacy; painting done, still wiring the panel ________________________________________________________________________________
Date: Oct 02, 2006
X-mailer: Pegasus Mail for Windows (4.41) > I guess I'm trying to say that anytime you added un-needed connections to a particular system > you are just asking for longer term troubles and an overall reduction in reliability. ____________________________________________ Spot on! Besides, you'll have a lot of the panel terminated in connectors of one sort or another anyway....how hard to remove those..... Tho I kinda wish the D-sub folks would go back to the old Centronics wire bail form of shell attachment. No trying to get the screw driver on the screw head in a spot you can't easily see. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 02, 2006
Subject: Re: Glowing LED Warning Lights, Too Dark Now-LM317
The brightness of an LED is proportional to the current going through it. You need a resistor in series with each LED to limit the max current and max brightness. Connecting all those resistors to the output of your LM317 should do what you want. When you dim (lower the voltage ouput of the LED) there will be less voltage drop through each resistor and the brightness will reduce. That brightness should not change regardless of how many LED's are on because each LED has its own resistor. I think that is your answer - a separate resistor for each LED. Of course with this description, it is assumed that individual LED's are turned on by connecting its negative lead to ground. Ken L. CardinalNSB(at)aol.com wrote: > MikeEasley wrote: > > My LED voltage warning lights are now too dark to see in daylight > after > adding the resistors in the drawing. > > Smaller resistors? > > I have been "playing" with leds on a breadboard, controlling them with > a LM317. The LM317 supplies constant voltage, determined by a > resistance to (the control leg, I don't know the real term). I have > used a rheostat and been able to control multiple or single leds, from > very bright to very dim/off. I am planning to make an annunciator for > a 300xl gps, which always has 2 leds on, sometimes 3, sometimes 4. I > have the LM317 between the battery positive and the leds, the leds > taking power from the LM317 with their other leg grounded. The leds > are in parallel. > > A value to me of the LM317 is to be able to maintain constant > brightness of multiple leds (I plan to use all the same white > leds with colored lenses for colors). The LM317 is from Radio Shack > and I have only used the circuit on the back of the box-LM317, a > resistor, and a rheostat, 3 parts. Could I wire a backup with a zener > diode for a constant brightness? > > However, I have been told this LM317 won't work, that I need Pulse > Width Modulation. I'm not sure why, the LM317 seems to do what I want > at least on my desk at home, is cheap and low parts count. I would > appreciate any reasons this would not be a proper way to control > multiple identical leds-rf production? Skip Simpson > >================ > > ________________________________________________________________________________
Date: Oct 02, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: fat wire - skinny wires
> > >I seem to remember there being some rationale for not running fat wires in >the same bundle with skinny wires, but I can find a specific reference to >it in the "Aero-electric Connenction". Does such a rationale exist, or am >I suffering from delusions of toxic aircraft chemical fumes? That was a tongue-in-cheek reference to the fact that the FAT wires are those that carry largest system currents, generate the largest local magnetic fields and TEND to be ranked on the antagonistic side for noise. Audio, signal and small control wires are SKINNY types that TEND to be potential victims. Having said all that, it's easy to design systems having a mix of antagonistic and victim wires in very close proximity to each other in same bundles. But it does take some time, attention and experience to do this with consistent success. >My #2 battery cable currently follows a rather tortuous path from the >tailpost to the front of the plane, and I could be a lot simple (and a few >pounds lighter), if it just ran down the side with a bunch of wires that >include microphone/headphone leads, taillight, tail strobe, fuel pump >powere, and a linear actuator control leads. As long as you've followed the guidelines for avoiding multiple grounds (ground loops) within single systems, the noise risk for bundling the wires you've listed is very low. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2006
> > > I guess I'm trying to say that anytime you added un-needed connections > to a particular system > > you are just asking for longer term troubles and an overall reduction > in reliability. >____________________________________________ > >Spot on! Besides, you'll have a lot of the panel terminated in >connectors of one sort or another anyway....how hard to remove >those..... > >Tho I kinda wish the D-sub folks would go back to the old >Centronics wire bail form of shell attachment. No trying to get >the screw driver on the screw head in a spot you can't easily see. There ARE wire bails for keeping d-subs together. My favorite for cable-to-cable d-subs is remove the jack-screw hardware and use tye-wraps to keep them together. Also, I'd ALWAYS use the machined d-sub pins. They're of the same pedigree as the older and larger 'Cannon' plugs, etc. I'm REALLY disappointed that folks who sell really expensive avionics ship those sheet-metal, b-crimp pins with their radios. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2006
> >Hello Eric > >You wrote: > >"So the manufacturer says, "mount plunger vertical, cap down" > >I have never taken apart or looked very close at the relay that is being >talked about. See: http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1c.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1e.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1f.jpg Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 02, 2006
> >Anybody have a centrifuge with accelerometer and want to conduct a little >experiment? > >Dave Morris I've done this already . . . but the rationale for mounting the contactor in any particular orientation has yet to be supported by the underlying simple-ideas. Yes, that's what the data sheet says but fails to explain why. An there's a famous Tyco white paper that makes some perfectly good measurements from which the authors then infer but never demonstrate deleterious effects that are not driven by the same science. There IS a reason why mounting the contactor under discussion cap down is a good idea and we've already hat-danced around it . . . and it's for consideration of g-forces. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2006
Subject: RE: Garmin 396/496 Connections
The power data cable only has mono audio output. You need to wire the mini phone jack into your audio panel, one of the entertainment inputs. I bought a 15' extension cable for the audio connection. You can also drive most autopilots from the 396/496 also. So in my installation I only used the power and ground wires in the power data cable. I've contemplated cutting the XM antenna wire at the antenna and making a short pigtail so I can route wire to the XM antenna location and just plug in the antenna before flight. Just haven't got up the nerve to cut and splice the wires yet. Mike Easley Colorado Springs Lancair ES ________________________________________________________________________________
Date: Oct 03, 2006
Subject: Re:Relays 'G's" skunk stink
> >I think it is time for someone with a little authority to clear this up. >My authority is so little that I have hidden it under one of the periods >in this posting. A prize awaits the one who finds it. > >1) Relay mounting. Type 70 Stancor Rodgers White Emerson Tyco. See: > >http://www.alliedelec.com/Images/Products/Datasheets/BM/STANCOR/Stancor_Industrial-Control_5760005.pdf > >So the manufacturer says, "mount plunger vertical, cap down". I checked >into the engineering data on this part and of course the corporate >conglomeratization has destroyed the engineering knowledge that built the >part. The manufacturer PROMISED they'd get back to me.....It's not DO-160 >bubela. And it's only 122 deg F max operating temp. Etc. etc. Why would you suppose they would make this recommendation? Is the engineering knowledge behind the recommendation so esoteric that we cannot deduce it for ourselves? > Use the Kilovac EV200 part if you can. Of course everyone CAN . . . it's a matter of trades. What is the return on investment for the trade . . . and is there more than one trade? >"Everything you've learned in school as "obvious" becomes less and less >obvious as you begin to study the universe. For example, there are no >solids in the universe. There's not even a suggestion of a solid. There >are no absolute continuums. There are no surfaces. There are no straight >lines." > - R. Buckminster Fuller Interesting quotation . . . I'm fond of quotations that offer simple-ideas of easily discovered utility. How would you propose we use the learned gentleman's to guide our deliberations? Bob . . . --------------------------------------------------------- < You can never learn less, you can only learn more. > < R. Buckminster Fuller > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2006
Subject: Re: Relays 'G's" skunk stink (CORRECTION)
Anybody have a centrifuge with accelerometer and want to conduct a little experiment? Dave Morris I've done this already . . . but the rationale for mounting the contactor in any particular orientation has yet to be supported by the underlying simple-ideas. Yes, that's what the data sheet says but fails to explain why. An there's a famous Tyco white paper that makes some perfectly good measurements from which the authors then infer but never demonstrate deleterious effects that are not driven by the same science. There IS a reason why mounting the contactor under discussion cap down is a good idea and we've already hat-danced around it . . . and it's NOT for consideration of g-forces. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2006
From: "Greg Campbell" <gregcampbellusa(at)gmail.com>
Subject: Re: Alternator test lead
This has already been answered, but to add a little perspective and some math to the answer... 1) What is the purpose of the resistor in the voltage sense line? To prevent bad things from happening if the other end of the voltage sense line (or some point in the middle) accidentally shorts to ground, or in the case of a alternator field, shorts to positive. 2) What's the "worst case" scenario for the particular application? If you had a voltage sense lead running to say a battery, and the other end shorts to ground - it would try and draw hundreds of amps through a tiny sense wire. If the sense wire is small, it might act like a fusible link and go poof. (Good!) If it is big wire (you used some spare #10 wire for "sturdiness"), then it might act like a dandy heater and fire starter. (Bad!) 3) What's the "cure" ? Add a resistor in line with the voltage test point that's suitable for the "worst case". So even if you used some spare #8 wire for your voltage sense wire, but - at the battery end - you added a 1000 ohm resistor, then in a 14v system (with the alternator ON), a short would produce a maximum of 0.014 Amps or 0.196 Watts. Not much of a heater or a fire starter. (Good!) And at 0.196 Watts, a quarter Watt 1000 ohm resistor could happily dissipate that heat all day long without getting too hot. 4) What if it's a 28v system? At 28volts, a 1000 ohm resistor will draw 0.028Amps, and since Watts = Volts * Amps, or Amps^2 * Resistance, a paltry 0.784 Watts. A quarter watt resistor will get extremely hot and may even fail open. A larger 1/2 Watt resistor will get nasty hot. A 1 Watt resistor will get toasty warm, but can handle that load all day long depending on how it's mounted. (The Watt rating is almost always about surface area and ventilation.) Arguably, you might prefer the resistor to act as a fusible link in a situation like that. So a 1/8 Watt resistor might be the resistor of choice. One good overload and "poof", no more resistor. Of course, no more voltage sensing either - leading to erroneous conclusions as to the nature of the problem. The best way to tell what your resistor will behave like is to short it out and see how hot it gets. If it's going to be bundled with other wires, covered with a boot, etc.. it's best to simulate those conditions as well. 5) In the case of a voltage sense wire on an alternator field, you also have to be concerned about what happens if the voltage sense wire shorts out to positive. If the sense wire were capable of supplying several amps to the alternator field, you could get a runaway alternator over voltage. By adding the resistor, you prevent it from supplying more than a few tenths of an amp to the field. 6) Doing the math backwards on a 28volt system: a one Watt resistor of 784 ohms or higher will be fine all day long a 1/2 Watt resistor of 1,568 ohms or higher will be fine all day long a 1/4 Watt resistor of 3,136 ohms or higher will be fine all day long... For a 14 volts system, divide all the Ohms by 4... a one Watt resistor of 196 ohms will handle 1 Watt all day long (with proper ventilation) a 1/2 Watt resistor of 392 ohms will handle 1/2 Watt all day long a 1/4 Watt resistor of 784 ohms will handle 1/4 Watt all day long 7) Don't fall for the common mistake of trying to "double up" resistors in parallel to get the "required" 1 Watt rating. If you take two 1000 Ohm 1/2 Watt resistors (more readily available than 1 Watt resistors, plus they come two to the pack.) and put them in parallel you won't be happy with the results because... You've created a 500 ohm "resistor network" (use your ohmmeter and you'll see)... So on a 28v system it will draw MORE amps and MORE Watts, and each of your 1/2 resistors will be trying to dissipate 0.784 Watts and not very happy about it. So... if you're rooting through the parts bins and all you can find are 1/4 or 1/2 Watt resistors, then use the larger ohm values. Double the resistance value if necessary. It won't make a difference to your voltmeter, and if you accidentally short things out - it won't create smoke & funny smells where you don't want it to. If all you can find are two 1000 Ohm 1/4 Watt Resistors, I'd be more inclined to put them in series for an effective resistance of 2000 ohms. This would dissipate 0.098 Watts in a 14v system, and 0.392 Watts (total) in a 28v system. The heat dissipated by each resistor would be half that, well within the limits of a 1/4 Watt resistor. Bob's probably right - any resistor in the 200 to 2000 ohm range will do, especially in the 1 Watt size. I prefer to use resistors in the 1000 to 3000 ohm range in the more common 1/4 or 1/2 Watt sizes. If you have a 28v System, I'd use the higher resistance values, but you can do the math. The really important thing is that you put the resistor close to the "source", not at the measuring end of the "sense wire". It's kind of like a fuse - you want it to protect the entire run of the wire, not the "end device" which is your voltmeter. Greg ________________________________________________________________________________
Date: Oct 03, 2006
X-mailer: Pegasus Mail for Windows (4.41) > There ARE wire bails for keeping d-subs together. My favorite for > cable-to-cable d-subs is remove the jack-screw hardware and use > tye-wraps to keep them together. Must be rarer than hens teeth....all I can find is the IDC D-sub w/bail locks. Did find a bail lock kit...going price was $7 a pop with one vendor down to $3. Your Ty Wraps look better all the time. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 03, 2006
I'll take a stab. Mounting "cap down" means that gravity (and a bit of engine vibration) will separate the main current contacts after the coil is de-energized should the internal compression spring fail. Mounting the other way would have the contacts potentially closing due gravity if the spring failed with potential for all sorts of unhappy results. Thanks to Bob for the nice internal pictures of this style of contactor. (I seem to have several of them in use personally). Jim Oke Wpg., MB RV-6A & RV-3 Robert L. Nuckolls, III wrote: > > > > > > > > > Anybody have a centrifuge with accelerometer and want to conduct a > little experiment? > > Dave Morris > > I've done this already . . . but the rationale for mounting > the contactor in any particular orientation has yet to be > supported by the underlying simple-ideas. > > Yes, that's what the data sheet says but fails to explain > why. An there's a famous Tyco white paper that makes some > perfectly good measurements from which the authors then > infer but never demonstrate deleterious effects that > are not driven by the same science. > > There IS a reason why mounting the contactor under > discussion cap down is a good idea and we've already > hat-danced around it . . . and it's NOT for consideration > of g-forces. > > Bob . . . > ________________________________________________________________________________
Subject: vhf antennas
Date: Oct 03, 2006
Hi ,I'm building an rv10,and I have contradictories informations about how install the antennas,the counselor and a couple of "masters" say clean the metal from any paint and install the antenna,but the manufacturer send it with a cork gasket(one of the best insulation ),to install . any logical for this. Thanks. Hugo ________________________________________________________________________________
Date: Oct 03, 2006
Subject: Re: vhf antennas
> >Hi ,I'm building an rv10,and I have contradictories informations about how >install the antennas,the counselor and a couple of "masters" say clean the >metal from any paint and install the antenna,but the manufacturer send it >with a cork gasket(one of the best insulation ),to install . >any logical for this. >Thanks. >Hugo See: http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif From some earlier posts: >A while back you had some words of wisdom for a person who'd asked about >getting enough metal to metal contact for ground plane purposes with his >comm antenna. You mentioned to him that riveting his doubler plates to the >skin would provide plenty of contact when paint and other debris was >squeezed out during the riveting process. I have a little different twist >on this question. I made doubler plates to go inside the fuselage but don't >really want to rivet them on. The number of fasteners that hold the >antennas to the airplane will hold doublers to the skin and I don't see a >need to rivet the doublers on. This however, could cause trouble. Since >I've already primed the inside of the aluminum fuselage skin, would like to >prime the doublers so they don't corrode when water gets between them and >the fuselage skin and don't want to remove the primer from the skin......I >fear I will have insufficient connection to get good ground plane action. >The comm antennas come with a cork gasket that's supposed to go between the >outside skin and the antenna so that limits ground plane connection on the >outside skin (presently bare aluminum). Am I gonna have to bite the bullet >and rivet the doublers to get some connection or ????(the doublers have >nutplates riveted to them to accept the antenna fasteners). Any words of >wisdom here? The antennas are the standard store bought COMANT bent whips. >Thanks. Welcome to the club. When somebody decides to design a new airplane, they start with aero and power plant guys. Then come the structures and processes folks. After awhile the systems folks put in fuel, hydraulics and flight controls. When the 'airplane' is done, some guy with radios, cabin entertainment systems, etc is told, "Okay, you can have whatever space is left over . . . but don't CHANGE anything." This approach to an HF antenna installation (without CHANGING anything) has resulted in a situation where other equipment items inside the all metal airplane are suffering huge interfering energies from the HF transmitter. Had the structures and processes guys been involved since day-one to make the metal serve as both airplane and antenna, we'd have several $millions$ still in the corporate pockets instead of blowing that cash on band-aid fixes to delivered aircraft. Now, on a much smaller scale, you're presented with the same kind of problem. The laws of physics are immutable. The primary, long term, gas-tight connections between your antenna base and airframe happen right under the head and nut of the fasteners. If you need a doubler, then it needs to be well bonded to the airframe . . . and that means rivets or high pressure joints between ground conductors. If you choose not to rivet the doubler, you need to clean 2 extra surfaces before installation. See: http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif If the doubler is riveted, then surfaces between doubler and skin can be left as-manufactured but it wouldn't hurt to clean these too. I'd pitch the cork gasket and go for a thin bead of moisture sealant around outside edge of antenna base that extrudes out to zero-thickness at time of installation. PRESSURE and CLEANLINESS around the immediate circumference of the mounting screws is where it all happens. >Bob, >Speaking of the magic (grounding the base) - looking at the >Antenna_Installation.gif , >I have seen toothed lock washers used between the doubler plate and skin. >This was on a Cessna. The doubler plate was not riveted to the skin (it >came with with the antenna replacement kit). The lock washer assured better >el contact (grounding). They used externally toothed lock washers, as per >attached. Maybe a better idea would be to use the external-internal toothed >type washers (also attached). Opinions? We're really slice'n and dice'n mouse hairs here. Obviously the goal is to get a low ohms connection between the antenna base and the skin that is as good 10 years from now as it is the day we bolt it on. This comes down to a few simple-ideas: (1) pressure high enough to bring two clean surfaces into intimate gas tight contact with each other and (2) exclusion of environmental effects that include (a) contaminants and (b) loosening that work against condition (1). Some designers embrace the idea that the toothed lockwashers provide a multitude of very high pressure points . . . even to the point of upsetting metal at the points of contact to achieve (1). My concerns are that a toothed washer is a spacer between the two surfaces that may contribute to initial joint quality (1) but leaves the gap "open" for ingress of (a). In all of our bonding specs at RAC, the use of lockwashers is never suggested. Self locking all metal nuts are the preferred anti-loosening technology. In the sketch I published, 99% of the magic needs to happen in the area just around the screw hole and between skin and antenna base. All other "prepared" areas add only marginally to the quality of the joint. Obviously, the "99% conductivity area" is of very small gap and the only thing one might add is sealant or anti-moisture guckum (Like silocone grease) to fill the tiny void around the periphery of the 99% area to prevent entry of oxidizing agents. Beyond that, maintainance of pressure over time is enhanced by use of largest practical hardware torqued to upper limits and secured with some form of locking technology . . . all metal locknuts being the technology of choice. When we were selling contactors with treaded studs for fat wires, the split-ring, steel washers supplied were discarded and replaced with internal tooth, phosphor bronze lockwashers. The supplied steel nuts were replaced with brass. Again, the lion's share of conductive magic happens were the terminal comes down against the bottom nut. The lockwasher and nut on top contributes to conductivity but only a tiny fraction of the total. Bob. . . ________________________________________________________________________________
Date: Oct 03, 2006
> >I'll take a stab. Mounting "cap down" means that gravity (and a bit of >engine vibration) will separate the main current contacts after the coil >is de-energized should the internal compression spring fail. Mounting the >other way would have the contacts potentially closing due gravity if the >spring failed with potential for all sorts of unhappy results. Okay, gravity is a player here (my earlier post spoke of g-forces which should have been qualified further to aerodynamic g-forces). Suppose we hypothesize that the spring is not going to fail. Now how does orientation affect operation? Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2006
> > > There ARE wire bails for keeping d-subs together. My favorite for > > cable-to-cable d-subs is remove the jack-screw hardware and use > > tye-wraps to keep them together. > >Must be rarer than hens teeth....all I can find is the IDC D-sub >w/bail locks. Did find a bail lock kit...going price was $7 a pop >with one vendor down to $3. Your Ty Wraps look better all the >time. Take a look at page 17 of: http://www.aeroelectric.com/Mfgr_Data/Connectors/ITT_Cannon/dsub_accessories.pdf The next greatest thing are Positronic's V series spring loaded slide latches. See page 10 of: http://www.connectpositronic.com/pdf/SubDAccess_C007RevB1.pdf Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2006
Ok, thats made everybody against the manufacturers,I will follow the mass. Thanks > > From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> > Date: 2006/10/03 Tue PM 01:08:28 EDT > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: vhf antennas > > > > > > >Hi ,I'm building an rv10,and I have contradictories informations about how > >install the antennas,the counselor and a couple of "masters" say clean the > >metal from any paint and install the antenna,but the manufacturer send it > >with a cork gasket(one of the best insulation ),to install . > >any logical for this. > >Thanks. > >Hugo > > > See: > > http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif > > From some earlier posts: > > >A while back you had some words of wisdom for a person who'd asked about > >getting enough metal to metal contact for ground plane purposes with his > >comm antenna. You mentioned to him that riveting his doubler plates to the > >skin would provide plenty of contact when paint and other debris was > >squeezed out during the riveting process. I have a little different twist > >on this question. I made doubler plates to go inside the fuselage but don't > >really want to rivet them on. The number of fasteners that hold the > >antennas to the airplane will hold doublers to the skin and I don't see a > >need to rivet the doublers on. This however, could cause trouble. Since > >I've already primed the inside of the aluminum fuselage skin, would like to > >prime the doublers so they don't corrode when water gets between them and > >the fuselage skin and don't want to remove the primer from the skin......I > >fear I will have insufficient connection to get good ground plane action. > >The comm antennas come with a cork gasket that's supposed to go between the > >outside skin and the antenna so that limits ground plane connection on the > >outside skin (presently bare aluminum). Am I gonna have to bite the bullet > >and rivet the doublers to get some connection or ????(the doublers have > >nutplates riveted to them to accept the antenna fasteners). Any words of > >wisdom here? The antennas are the standard store bought COMANT bent whips. > >Thanks. > > > Welcome to the club. When somebody decides to design a new airplane, > they start with aero and power plant guys. Then come the structures > and processes folks. After awhile the systems folks put in fuel, > hydraulics and flight controls. When the 'airplane' is done, some > guy with radios, cabin entertainment systems, etc is told, "Okay, > you can have whatever space is left over . . . but don't CHANGE > anything." > > This approach to an HF antenna installation (without CHANGING > anything) has resulted in a situation where other equipment items > inside the all metal airplane are suffering huge interfering > energies from the HF transmitter. Had the structures and processes > guys been involved since day-one to make the metal serve as both > airplane and antenna, we'd have several $millions$ still in the > corporate pockets instead of blowing that cash on band-aid > fixes to delivered aircraft. > > Now, on a much smaller scale, you're presented with the same > kind of problem. The laws of physics are immutable. The primary, > long term, gas-tight connections between your antenna base and > airframe happen right under the head and nut of the fasteners. > > If you need a doubler, then it needs to be well bonded > to the airframe . . . and that means rivets or high pressure > joints between ground conductors. If you choose not to > rivet the doubler, you need to clean 2 extra surfaces before > installation. See: > > http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif > > > If the doubler is riveted, then surfaces between doubler > and skin can be left as-manufactured but it wouldn't hurt > to clean these too. I'd pitch the cork gasket and go for a > thin bead of moisture sealant around outside edge of antenna > base that extrudes out to zero-thickness at time of > installation. PRESSURE and CLEANLINESS around the immediate > circumference of the mounting screws is where it all happens. > > > >Bob, > >Speaking of the magic (grounding the base) - looking at the > >Antenna_Installation.gif , > >I have seen toothed lock washers used between the doubler plate and skin. > >This was on a Cessna. The doubler plate was not riveted to the skin (it > >came with with the antenna replacement kit). The lock washer assured better > >el contact (grounding). They used externally toothed lock washers, as per > >attached. Maybe a better idea would be to use the external-internal toothed > >type washers (also attached). Opinions? > > We're really slice'n and dice'n mouse hairs here. Obviously > the goal is to get a low ohms connection between the antenna > base and the skin that is as good 10 years from now as it is > the day we bolt it on. This comes down to a few simple-ideas: > (1) pressure high enough to bring two clean surfaces into intimate > gas tight contact with each other and (2) exclusion of environmental > effects that include (a) contaminants and (b) loosening that work > against condition (1). > > Some designers embrace the idea that the toothed lockwashers > provide a multitude of very high pressure points . . . even to > the point of upsetting metal at the points of contact to achieve > (1). My concerns are that a toothed washer is a spacer between > the two surfaces that may contribute to initial joint quality (1) > but leaves the gap "open" for ingress of (a). > > In all of our bonding specs at RAC, the use of lockwashers is > never suggested. Self locking all metal nuts are the preferred > anti-loosening technology. In the sketch I published, 99% of the > magic needs to happen in the area just around the screw hole and > between skin and antenna base. All other "prepared" areas add > only marginally to the quality of the joint. > > Obviously, the "99% conductivity area" is of very small gap and > the only thing one might add is sealant or anti-moisture guckum (Like > silocone grease) to fill the tiny void around the periphery > of the 99% area to prevent entry of oxidizing agents. Beyond > that, maintainance of pressure over time is enhanced by use > of largest practical hardware torqued to upper limits and > secured with some form of locking technology . . . all metal > locknuts being the technology of choice. > > When we were selling contactors with treaded studs for fat wires, > the split-ring, steel washers supplied were discarded and replaced with > internal tooth, phosphor bronze lockwashers. The supplied steel > nuts were replaced with brass. Again, the lion's share of conductive > magic happens were the terminal comes down against the bottom nut. > The lockwasher and nut on top contributes to conductivity but > only a tiny fraction of the total. > > Bob. . . > > > > > > ________________________________________________________________________________
Subject: Strobe Wiring
Date: Oct 03, 2006
I am installing Whelen wingtip strobes on my RV8. I have installed a molex multi-pin plug at the wing root in the event that I ever have to remove the wings. Does anyone feel that this is inviting a problem with electrial "noise" in my system. I know that this is a shielded cable. I am a novice and would welcome any comments or suggestions. Jeff -------- Jeff Moreau RV8A Virginia Beach, VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65535#65535 ________________________________________________________________________________
Date: Oct 03, 2006
Well, "cap down" means that gravity (in the usual aerodynamic sense of positive G maneuvering loads) will assist the internal spring in separating the high current contacts when the coil energizing current is removed. This would help in opening sticking contacts due to dirt, deteriorated contact surfaces, and the like. Jim Oke Wpg., MB Robert L. Nuckolls, III wrote: > > > >> >> I'll take a stab. Mounting "cap down" means that gravity (and a bit >> of engine vibration) will separate the main current contacts after >> the coil is de-energized should the internal compression spring fail. >> Mounting the other way would have the contacts potentially closing >> due gravity if the spring failed with potential for all sorts of >> unhappy results. > > Okay, gravity is a player here (my earlier post spoke of > g-forces which should have been qualified further to > aerodynamic g-forces). Suppose we hypothesize that the > spring is not going to fail. Now how does orientation > affect operation? > > Bob . . . > ________________________________________________________________________________
Date: Oct 03, 2006
Subject: Re: Strobe Wiring
Jeff, Having installed a system with similar plugs etc, I could only say that I've never experienced electrical noise with the strobes active or not. They've been unplugged several times. Good plugs........ Larry McFarland - 601HDS at www.macsmachine.com Jeff Moreau wrote: > >I am installing Whelen wingtip strobes on my RV8. I have installed a molex multi-pin plug at the wing root in the event that I ever have to remove the wings. >Does anyone feel that this is inviting a problem with electrial "noise" in my system. I know that this is a shielded cable. I am a novice and would welcome any comments or suggestions. >Jeff > >-------- >Jeff Moreau >RV8A >Virginia Beach, VA > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=65535#65535 > > > > ________________________________________________________________________________
Date: Oct 03, 2006
Eric said: > I think it is time for someone with a little authority to clear this up. > My authority is so little that I have hidden it under one of the periods > in this posting. A prize awaits the one who finds it. > > 1) Relay mounting. Type 70 Stancor Rodgers White Emerson Tyco. See: > > http://www.alliedelec.com/Images/Products/Datasheets/BM/STANCOR/Stancor_Industrial-Control_5760005.pdf > > So the manufacturer says, "mount plunger vertical, cap down". I checked > into the engineering data on this part and of course the corporate > conglomeratization has destroyed the engineering knowledge that built the > part. The manufacturer PROMISED they'd get back to me.....It's not DO-160 bubela. And it's only 122 deg F max operating temp. Etc. etc. Bob replied: > Why would you suppose they would make this recommendation? Is the engineering knowledge behind the recommendation so esoteric that we cannot deduce it for ourselves? I assume we can figure it out. My analysis is that the type-70 contactor has poor water-tightness (especially around the electrical terminals). This is a bit less of a problem with the cap down. Also, when energized the plunger contacts an iron stop that is part of the magnetic circuit when closed. There is no room in the space and the plunger MUST be allowed to contact the stop or the coil will draw excessive current, etc.--The cap-down orientation prevents accumulation of debris in the plunger-stop space. So my vote is that gravity is the lesser issue. On the other hand the contactor was designed for cars, not airplanes--so who knows what they considered. > > "Everything you've learned in school as "obvious" becomes less and less > obvious as you begin to study the universe. For example, there are no > solids in the universe. There's not even a suggestion of a solid. There > are no absolute continuums. There are no surfaces. There are no straight > lines." > - R. Buckminster Fuller Bob . . . > Interesting quotation . . . I'm fond of quotations > that offer simple-ideas of easily discovered utility. > How would you propose we use the learned gentleman's > to guide our deliberations? > Bob, I like this quotation because Fuller suggests casting out "learned" assumptions and looking at problems without preconceptions. This is more philosophical than practical of course, but I like the idea that what we should begin by assuming everything we know is wrong. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65550#65550 ________________________________________________________________________________
Date: Oct 03, 2006
At 03:37 PM 10/3/2006, you wrote: >Bob, I like this quotation because Fuller suggests casting out >"learned" assumptions and looking at problems without >preconceptions. This is more philosophical than practical of course, >but I like the idea that what we should begin by assuming everything >we know is wrong. Or at least more complicated than we were first taught. For instance in that Physics 101 class when the teacher (foolishly) said "assume this is done in a vacuum and there is no drag". Then you find out the earth is not a perfect sphere, the adiabatic lapse rate is not uniform, electrons do not flow from positive to negative, and so on. It's really depressing ;) Dave Morris ________________________________________________________________________________
Subject: Pull to low
Date: Oct 03, 2006
Is the term "pull to low" synonomous with connect to ground? -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65568#65568 ________________________________________________________________________________
Date: Oct 03, 2006
Mr. Nuckolls, I am disappointed and saddened to see you engaging in the "I've got a secret" style of information dissemination. If it is in the archive, please say so. If you have the answer, please give it. Cordially, Raymond Julian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, October 03, 2006 12:11 PM Subject: Re: AeroElectric-List: Re: Relays 'G's" skunk stink (CORRECTION) > >I'll take a stab. Mounting "cap down" means that gravity (and a bit of >engine vibration) will separate the main current contacts after the coil >is de-energized should the internal compression spring fail. Mounting the >other way would have the contacts potentially closing due gravity if the >spring failed with potential for all sorts of unhappy results. Okay, gravity is a player here (my earlier post spoke of g-forces which should have been qualified further to aerodynamic g-forces). Suppose we hypothesize that the spring is not going to fail. Now how does orientation affect operation? Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2006
Subject: Re: Pull to low
That's probably a safe way to interpret that direction.. As a point of note, there are several different specification standards for the digital electrical signaling that is used to make one device communicate with another. Some examples are TTL, LVTTL, SSTL.. Each one may have a somewhat different definition for what voltage level is required on an input for the device to interpret the signal as a logic "low" (or zero). For many (most) applications, grounding an input will be interpreted as a logic low signal. Some interfaces allow an input to float up to 600mV (or higher) and still be interpreted as a low. Hope that helps.. Regards, Matt- > > Is the term "pull to low" synonomous with connect to ground? > > -------- > Milt > N395V > F1 Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=65568#65568 > > ________________________________________________________________________________
Date: Oct 03, 2006
It's a paedagogic style. One that has fallen out of favor recently and has been replaced with "when you take the test, the answer will be ...." I was trained old-school, and I like the way Bob teaches. It encourages independent thought. Dave Morris At 05:51 PM 10/3/2006, you wrote: > >Mr. Nuckolls, > > I am disappointed and saddened to see you engaging in the "I've got a >secret" style of information dissemination. > > If it is in the archive, please say so. > > If you have the answer, please give it. > >Cordially, >Raymond Julian > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert >L. Nuckolls, III >Sent: Tuesday, October 03, 2006 12:11 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Re: Relays 'G's" skunk stink >(CORRECTION) > > > > > > > > >I'll take a stab. Mounting "cap down" means that gravity (and a bit of > >engine vibration) will separate the main current contacts after the coil > >is de-energized should the internal compression spring fail. Mounting the > >other way would have the contacts potentially closing due gravity if the > >spring failed with potential for all sorts of unhappy results. > > Okay, gravity is a player here (my earlier post spoke of > g-forces which should have been qualified further to > aerodynamic g-forces). Suppose we hypothesize that the > spring is not going to fail. Now how does orientation > affect operation? > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Oct 03, 2006
> >Eric said: > > > So the manufacturer says, "mount plunger vertical, cap down". I checked > > into the engineering data on this part and of course the corporate > > conglomeratization has destroyed the engineering knowledge that built the > > part. The manufacturer PROMISED they'd get back to me.....It's not > DO-160 bubela. And it's only 122 deg F max operating temp. Etc. etc. > > >Bob replied: > > Why would you suppose they would make this recommendation? Is the > engineering knowledge behind the recommendation so esoteric that we > cannot deduce it for ourselves? > > >I assume we can figure it out. My analysis is that the type-70 contactor >has poor water-tightness (especially around the electrical terminals). >This is a bit less of a problem with the cap down. Agreed > Also, when energized the plunger contacts an iron stop that is part of > the magnetic circuit when closed. There is no room in the space and the > plunger MUST be allowed to contact the stop or the coil will draw > excessive current, etc. Plunger position or even the presence of a plunger does not influence static coil current. >--The cap-down orientation prevents accumulation of debris in the >plunger-stop space. So my vote is that gravity is the lesser issue. On the >other hand the contactor was designed for cars, not airplanes--so who >knows what they considered. Having disassembled more than a dozen of these devices over the years, I think we can make a pretty good guess. The springs are not real strong so the force of gravity would add a significant aiding or opposing force depending on orientation. This wouldn't be much of a concern for getting the critter closed . . . but contact spreading velocity would probably see a larger delta due to orientation than for decay rates of the magnetic field in the coil. I'll see if I can figure out a way to go measure that sometime. Also, the bore of the coil bobbin is plastic. More than one solenoid has become erratic due to erosion of bobbin interior due to a horizontal sliding core. In the case of contact spreading velocity for improved contact life, cap-down helps. For bobbin erosion, either vertical orientation would be okay. It MIGHT be that they considered moisture effects . . . it's NOT a sealed relay and a non-sealed housing hit with cool splash WILL suck in water. Better that it's pooled in the cap than allowed to drip down over contacts, spring and plunger. If we were using these devices in an industrial control situation with hundreds of operations per day (with expectation for achieving a HIGH percentage of rated life), then religious observance of orientation cap-down would probably yield an increase in service life. Given that these devices in light aircraft operate perhaps a couple hundred times per year (and at loads much lighter than rated) the probability is that most of us will experience a maintenance event on these contactors due to environmental effects as opposed to wearing effects. > > > > "Everything you've learned in school as "obvious" becomes less and less > > obvious as you begin to study the universe. For example, there are no > > solids in the universe. There's not even a suggestion of a solid. There > > are no absolute continuums. There are no surfaces. There are no straight > > lines." > > - R. Buckminster Fuller > > >Bob . . . > > > Interesting quotation . . . I'm fond of quotations > > that offer simple-ideas of easily discovered utility. > > How would you propose we use the learned gentleman's > > to guide our deliberations? > > > > >Bob, I like this quotation because Fuller suggests casting out "learned" >assumptions and looking at problems without preconceptions. This is more >philosophical than practical of course, but I like the idea that what we >should begin by assuming everything we know is wrong. Agreed . . . and according to some demonstrably practical folks like Dr. Virgil Elings, one should always proceed forward with a fine attunement to actions that are not helping or even worse, going in the wrong direction. I made his one-sided and limited acquaintance when a reader pointed me to this interview of Dr. Elings at: http://webcast.ucsd.edu:8080/ramgen/UCSD_TV/11762.rm the audio on this presentation was pretty poor. I've done some post processing on it and placed a temporary copy at: http://www.aeroelectric.com/Temp/Virgil_Elings-Look_at_the_Big_Picture.mp3 I believe both Fuller and Elings would agree that one of mankind's biggest impediments to progress is the blind acceptance of preconceptions coupled with equally blind obedience to those who would hand out pre-conceptions be they in the form of bad science or bad plans. There is risk that some folks grab onto an idea like the Fuller quotation with a liberal dose of fundamental attribution error. Like: "Nothing is real, nothing is what it seems to be. Everything is irrelevant. Everything I do is irrelevant. I am irrelevant. Mr. Fuller said so." That's why I gravitate more toward folks like Kettering, Kelvin, and most recently Elings. Their ideas don't take much interpretation. They really jump out at you. They encourage healthy skepticism and stand up well to the repeatable experiment. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2006
> >Mr. Nuckolls, > > I am disappointed and saddened to see you engaging in the "I've got a >secret" style of information dissemination. > > If it is in the archive, please say so. > > If you have the answer, please give it. I'm disappointed that you're disappointed. When was the last time you sat down in a class where the instructor walks in and says, "We have a test next Friday, the answers are on the board. Class dismissed." If there is no discussion, then there's no measure of the exchange and retention of ideas. My first teaching job was at Great Lakes Naval Training Base 40 years ago. Instructors I worked with habitually taught to the test questions. I refused to do it then and I'm not going to start now. Patience my friend. It's not my intent to be secretive or obtuse. Bob . . . ________________________________________________________________________________
Date: Oct 03, 2006
Subject: [ Larry Rosen ] : New Email List Photo Share Available!
From: Email List Photo Shares <pictures(at)matronics.com>
A new Email List Photo Share is available: Poster: Larry Rosen Lists: AeroElectric-List Subject: Modified Z13-20 for Peer Review http://www.matronics.com/photoshare/LarryRosen@comcast.net.10.03.2006/index.html ---------------------------------------------------------- o Main Photo Share Index http://www.matronics.com/photoshare o Submitting a Photo Share If you wish to submit a Photo Share of your own, please include the following information along with your email message and files: 1) Email List or Lists that they are related to: 2) Your Full Name: 3) Your Email Address: 4) One line Subject description: 5) Multi-line, multi-paragraph description of topic: 6) One-line Description of each photo or file: Email the information above and your files and photos to: pictures(at)matronics.com ---------------------------------------------------------- ________________________________________________________________________________
Date: Oct 03, 2006
I am currently building a Vans RV-10 and I am to the point where I will soon need to start the electrical wiring. After thinking through the various options for the electrical configuration, I decided a single battery dual alternator design based on Z-13/20 is what I am going to put into my airplane. Some of the factors into the decision is redundancy and reliability for my all electric panel, along with my analysis of the loads for everything I "want" on the e-bus. My load analysis shows a continuous load of 12 amps with a maximum load (no diversity) of 25 amps. I modified the base Z diagram to accommodate a battery that will be mounted in the tail cone. If you would take a look at my modified Z-13/20 design and comment back it would be greatly appreciated. Modifications to the base diagram are highlighted in yellow. The drawing is in pdf format and you can find it here <http://lrosen.nerv10.com/Electic/Elect_R1.pdf> or a write up and link can be found here <http://lrosen.nerv10.com/Electic/index.html> Thanks -- Larry Rosen RV-10 #356 http://lrosen.nerv10.com ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Subject: Re: [ Larry Rosen ] : New Email List Photo Share Available!
Date: Oct 04, 2006
The first thing that jumps out Larry is that the starter contactor is unlikely to ever pull in with the warning light connected in series with the start button and the coil. Bob McC ----- Original Message ----- From: "Email List Photo Shares" <pictures(at)matronics.com> Sent: Tuesday, October 03, 2006 10:47 PM Subject: AeroElectric-List: [ Larry Rosen ] : New Email List Photo Share Available! > > > A new Email List Photo Share is available: > > Poster: Larry Rosen > > Lists: AeroElectric-List > > Subject: Modified Z13-20 for Peer Review > > http://www.matronics.com/photoshare/LarryRosen@comcast.net.10.03.2006/index.html > > > ---------------------------------------------------------- > > o Main Photo Share Index > > http://www.matronics.com/photoshare > > o Submitting a Photo Share > > If you wish to submit a Photo Share of your own, please include the > following information along with your email message and files: > > 1) Email List or Lists that they are related to: > 2) Your Full Name: > 3) Your Email Address: > 4) One line Subject description: > 5) Multi-line, multi-paragraph description of topic: > 6) One-line Description of each photo or file: > > Email the information above and your files and photos to: > > pictures(at)matronics.com > > ---------------------------------------------------------- > > ________________________________________________________________________________
Subject: Re: Modified Z13-20 for Peer Review
Date: Oct 04, 2006
Ooops pushed send too quickly. The first thing that jumps out Larry is that the starter contactor is unlikely to ever pull in with the warning light connected in series with the start button and the coil. Same comment applies to contactor used to engage "E" bus in series with its warning light. The warning lights need to be from the switch/coil junctions to ground and the switches need to apply voltage directly to the coils. Bob McC ----- Original Message ----- From: "Larry Rosen" <LarryRosen(at)comcast.net> Sent: Tuesday, October 03, 2006 11:47 PM Subject: AeroElectric-List: Modified Z13-20 for Peer Review > > I am currently building a Vans RV-10 and I am to the point where I will > soon need to start the electrical wiring. After thinking through the > various options for the electrical configuration, I decided a single > battery dual alternator design based on Z-13/20 is what I am going to > put into my airplane. Some of the factors into the decision is > redundancy and reliability for my all electric panel, along with my > analysis of the loads for everything I "want" on the e-bus. My load > analysis shows a continuous load of 12 amps with a maximum load (no > diversity) of 25 amps. I modified the base Z diagram to accommodate a > battery that will be mounted in the tail cone. > > If you would take a look at my modified Z-13/20 design and comment back > it would be greatly appreciated. > Modifications to the base diagram are highlighted in yellow. > The drawing is in pdf format and you can find it here > <http://lrosen.nerv10.com/Electic/Elect_R1.pdf> > or a write up and link can be found here > <http://lrosen.nerv10.com/Electic/index.html> > > Thanks > > -- > > Larry Rosen > RV-10 #356 > http://lrosen.nerv10.com > > ________________________________________________________________________________
Date: Oct 04, 2006
Mr. Nuckolls, It is my opinion that your particular style of teaching is appropriate for students that are only marginally interested in the question and in seeking the solutions. I make the assumption that those who subscribe to the list and take the time to read and reply to the list have a high level of motivation. I would be served better by the presentation of as much of the available data as practical at the beginning of the solution process. Thank you for taking the time to respond. Cordially, Raymond Julian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, October 03, 2006 9:08 PM Subject: RE: AeroElectric-List: Re: Relays 'G's" skunk stink (CORRECTION) > >Mr. Nuckolls, > > I am disappointed and saddened to see you engaging in the "I've got a >secret" style of information dissemination. > > If it is in the archive, please say so. > > If you have the answer, please give it. I'm disappointed that you're disappointed. When was the last time you sat down in a class where the instructor walks in and says, "We have a test next Friday, the answers are on the board. Class dismissed." If there is no discussion, then there's no measure of the exchange and retention of ideas. My first teaching job was at Great Lakes Naval Training Base 40 years ago. Instructors I worked with habitually taught to the test questions. I refused to do it then and I'm not going to start now. Patience my friend. It's not my intent to be secretive or obtuse. Bob . . . ________________________________________________________________________________
From: "Kingsley Hurst" <khurst(at)taroom.qld.gov.au>
Date: Oct 04, 2006
Larry, May I respectfully suggest you connect your starter warning lamp between the downstream side of the starter contactor and ground. If you ever see the light on when you are not pressing the starter button, you will know that the starter contactor has stuck in. IOW, watch the light as you press the starter button and it should go out immediately the button is released. Cheers Kingsley in Oz. ________________________________________________________________________________
Date: Oct 04, 2006
I have a suggestion for the reasons a manufacturer wants the relay mounted in a certain orientation, based on experience doing similar things. It has mostly to do with water: Generally, you want to mount the part in a way that water has the least chance of getting inside, so the cap is made like a roof so the water runs off. Also, you want to have the internals arranged in a way that a drop of water inside has the least chance of causing a corrosion failure. That might be to have the electrical connections to the coil at the top - or the contacts could be at the top if they are more vulnerable. Reasons like this make far more sense than G-load resistance. Gary Casey ________________________________________________________________________________
Date: Oct 04, 2006
I guess there are always differing viewpoints Raymond which is often a good thing. When I read the answers quickly I am less likely to retain the knowledge although I guess I can always come back and search the archives which is perhaps part of your viewpoint. But when there is some give and take on a question, someone often comes up with a new idea or two that goes beyond what the "teacher" would have given and we learn more than we otherwise would. A dynamic classroom is usually more fun for all. Ken L. raymondj wrote: > >Mr. Nuckolls, > >It is my opinion that your particular style of teaching is appropriate for >students that are only marginally interested in the question and in seeking >the solutions. > >I make the assumption that those who subscribe to the list and take the time >to read and reply to the list have a high level of motivation. > >I would be served better by the presentation of as much of the available >data as practical at the beginning of the solution process. > >Thank you for taking the time to respond. > >Cordially, >Raymond Julian > > > ________________________________________________________________________________
Date: Oct 04, 2006
Subject: RE: Thoughts on Teaching
> >Mr. Nuckolls, > >It is my opinion that your particular style of teaching is appropriate for >students that are only marginally interested in the question and in seeking >the solutions. I disagree. Permit me to elaborate: I was exceedingly fortunate in my formative years to have enjoyed the attention of an engineer at Boeing who was also an amateur radio operator. I knew ALL the hams within about 20 blocks of my house. Ed was particularly influential in that he never directly answered a question. He began to ask me questions . . . laying foundations which supported the answer I was looking for. More often than not, I would end up answering my own question. The process of mental imaging and logical assemblage of simple-ideas were powerful teaching tools. I used those tools only years later when he got me my first teaching job at Wichita U in an adult education course where a number of my students were former foremen of mine at Boeing. A few years later, those tools served me (and my students) well at Great Lakes. I'll respectfully suggest that the marginally interested student is ONLY seeking answers. Charles Kettering once noted: "Knowledge is not understanding. One may know a great deal and yet understand nothing." It's the INTENTLY interested individual that ENJOYS and will take the time to ponder the underlying support for a concept so that understanding is achieved. >I make the assumption that those who subscribe to the list and take the time >to read and reply to the list have a high level of motivation. One may be motivated to do many things and on many levels. The hallmark of achievement at anything is never a turn-key process. Tiger Woods probably hits balls every day. Yehudi Menuhin picked up his violin every day. Thomas Edison's thinking was probably NEVER silent on the task of pondering some new problem. If there are other ways to achieve understanding, I don't know what they are. However, if I can make it fun too, THEN there is hope for gathering the marginally interested student into the conversation as well. Therefore I (and those who would take time to participate here on the List) are stuck with the best I know how to do today. It's never easy but if it isn't fun too, then folks are free to take their business elsewhere. >I would be served better by the presentation of as much of the available >data as practical at the beginning of the solution process. >Thank you for taking the time to respond. I understand but as I wrote earlier I am disappointed that you are disappointed. Please understand that if my motivation were to simply be a disseminator of esoteric knowledge, then I am in danger of being replaced by Ask.com and Google. If I am to honor those to took the time to share with me in years past, then it's my duty to understand the value of what they gave me and to pass my inheritance forward. Bob . . . ________________________________________________________________________________
Subject: Pin extraction tool KMA 24 or PMA 7000
Date: Oct 04, 2006
Anyone have any idea of the name or number for the honeywell pin extraction and insertion tool for the connectors on KMA 24 or PS eng PMA7000 audio panels and where I can get them?? -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65705#65705 ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: RBM/Stancor/White-Rogers Contactors
> >I have a suggestion for the reasons a manufacturer wants the relay >mounted in a certain orientation, based on experience doing similar >things. It has mostly to do with water: Generally, you want to >mount the part in a way that water has the least chance of getting >inside, so the cap is made like a roof so the water runs off. In this case, the mfgr has suggested "cap down" . . . but yes, water may have been a driving consideration. > Also, >you want to have the internals arranged in a way that a drop of water >inside has the least chance of causing a corrosion failure. That >might be to have the electrical connections to the coil at the top - >or the contacts could be at the top if they are more vulnerable. >Reasons like this make far more sense than G-load resistance. Sure. Of course, the guys who designed this thing have been dead for decades. The guys who wrote/modified the data sheets over the years are not accessible to us. So the best we can do is apply whatever understanding we can to the question. I've encountered several failure modes on sophisticated products where the present powers-that-be go to great lengths to obfuscate reality. Unlike engineers who are interested in exercising and improving on the best-we-know- how-to-do, others will exert no small effort to avoid confessing to less-than-the-best. It's a lawyer thing. It may be that the orientation suggestion on the data sheet was added after years of field experience where water became a consideration. That might have been during the era of floating cowl issues on Cessnas back in the 70's . . . but I doubt it. For every airplane that carries an RBM/Stancor/White-Rogers contactor, there's hundreds of boats, fork lifts, etc. that use them too. Bottom line is that we'll never know the original thinking or intent. The alternative is due diligence for reverse engineering. Disassemble a design looking for the simple-ideas that both support a hypothesis or explain a failure. In any case, if the task is done well, it's not uncommon for the consumer of a legacy product to end up knowing more about that product than the manufacturer! That happens all too often in aviation (and I suspect elsewhere). To recap I think we can agree that (1) cap-down orientation improves probability of survival for cool splash ingestion of water (water pools away from vitals). Hmmmm . . . wonder about adding a drain hole in a down-facing cap! (2) cap-down increases gravity aided, contact spreading velocity for an improvement of contact service life. Any other thoughts out there? Bob . . . ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: Pin extraction tool KMA 24 or PMA 7000
> >Anyone have any idea of the name or number for the honeywell pin >extraction and insertion tool for the connectors on KMA 24 or PS eng >PMA7000 audio panels and where I can get them?? Do the connectors have any numbers or brand names on them? It's seldom possible to identify tools specific to connectors based on the brand of product that uses the connector. If you can see any identifying clues as to the manufacturer of the connector, then we can access catalogs for those devices and identify descriptions and sources for the tools. If you have a digital camera, take some closeups of the connector body and email them to me. Perhaps I can identify the connector by seeing its design. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: Thinking things electic
Date: Oct 04, 2006
Raymond, I recently heard an interesting saying. It goes like this... 5% of the people think. 10% of the people think they think. and 85% of the people would rather DIE than think. When I graduated from medical school my head was crammed full of "answers". I could spout facts like nobody's business. Then I met the public and realized I didn't know how to "doctor" people. In other words, I didn't know how to think like a doctor! This revelation came early in my career in a busy ER in Knoxville, Tennessee. I had a patient with a sore throat and I didn't know how to treat it, or even where to go to find out. Shocking, isn't it? I was already an MD. In fact, I already knew how to treat heart attack, stroke and many serious and life threatening conditions. But I didn't know how to evaluate that sore throat! I was taken aback, as you might guess. Fortunately, I had a teacher supervising me who was ready to fill the gaps in my knowledge. And, even more fortunately, I learned from him how to evaluate patients, or more correctly, their problems. At first, I was miffed at him because when I asked him how to treat this patient, he handed me an article to read! I was busy! The ER was jumping and this "minor" problem was bogging me down. But, since I wasn't the only MD on duty, and I was in training after all, I sat down and quickly read the article. After I was done, I knew what to do. But, most curious of all, I had been exposed to the thought processes of the author and it transformed my thinking! I have continually worked to hone my skills as a medical thinker for the past 25 years. But that teacher was the beginning of my real medical education. Likewise, Bob Nuckolls has been the beginning of my electrical education. He makes it fun and rewarding. I like it so much I've read the 'Connection at least a half dozen times. I read this list every day. I've come to LIKE wiring airplanes! When I tell my OBAM airplane buddies, they just shake their heads in disbelief. One even asked if I would wire his! :o) You see, they're in the 3rd group. At least concerning electrons. They don't want to have to think about wiring their sky charriots. They just want to fly them! And, who's to blame them for that? That's why most of us build the dern things, isn't it? They are content to wire theirs according to the suggested diagrams supplied with the kit. Why not? It works, doesn't it? But we AeroElectric listers are the chosen few. Either by education or avocation we find ourselves thinking things electric. Sure, we want answers, but, even better, we want our fancies tickled! That's what Bob is doing here. We like it! We'll have the "answer" soon enough. But I'd like to know if my manner of thinking works! After all, I may be up there screaming along in my Sky Scorcher someday when things go awry and I'm gonna be all I've got to get things managable! I want the confidence to get that done. And Bob's method of teaching fills that need for me. At least concerning things electric. Rodney in Tennessee Unabashed Nuckollhead ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: Connectors vs. Straight Wire
>Hi Stein, > >Thanks so much for your very thoughtful reply to my question about the >trade-offs between straight-wiring my instrument panel to the airframe >wiring and the alternative of putting connectors in every wire so that I >can remove the panel for service. > >I think I'll take your advice and go with the straight-wire concept, >without connectors in every wire. The airplane I'm building has better >than average access to the panel in-place and most of the stuff in the >panel are relatively easy to remove. From a servicing perspective, consider making your panel from "modules" of flat sheet, each removable for servicing. Make wire bundles to each module long enough to allow pulling the module out for access while extending a bundle. When mounted for operation, coil the bundles behind the panel and secure with tye-wraps. If your bundles are not too populace, this is a good way to maintain both serviceability =AND wire integrity. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: hugo rv10
Hi Hugo The steinair website may help you. http://steinair.com/connectors.htm I believe that any connector that fits RG-58 will fit RG400 and I used a $20. imported crimper that worked fine for me. Ken L. gommone7(at)bellsouth.net wrote: > >Hi all,still with antennas questions, >almost everybody suggest to use rg400u coaxial cable ,good, i ordered,now the choice in the usual catalogs have a very restricted choice of BNC connectors (only one tipe )will fit the RG 400,and can't be solder,ok order allready the 70 dol crimping tool.but still one part missing wich is a metal sleeve wich slide over the conection and allow to be crimped,if I'm rigth ,no body sale thats sleeve,can some one help me to understand or a place to order the part. >thanks ,and sorry for my lack of knoledge in electrical systems >Hugo > > ________________________________________________________________________________
Date: Oct 04, 2006
Without knowing exactly what kind of socket/pin combination you have, it's impossible to know for sure. However, I but it uses the same card-edge Molex KK pins/connectors that most other King radio equipment uses. If so, this will help you out: http://www.berkut13.com/extractor.htm James Redmon Berkut #013 N97TX http://www.berkut13.com ----- Original Message ----- From: "N395V" <n395v(at)hughes.net> Sent: Wednesday, October 04, 2006 8:43 AM Subject: AeroElectric-List: Pin extraction tool KMA 24 or PMA 7000 > > Anyone have any idea of the name or number for the honeywell pin > extraction and insertion tool for the connectors on KMA 24 or PS eng > PMA7000 audio panels and where I can get them?? > > -------- > Milt > N395V > F1 Rocket ________________________________________________________________________________
Date: Oct 04, 2006
Ken is correct. Dimensionally, RG-58 and RG400 are close enough to use the same connectors and application tools. The only 'catch' is to get your 'cheap' tool and connectors from the same supplier . . . presumably, like me, they'll make sure that their connectors are compatible with their tools. It's a rare problem but NOT zero risk. Alternatively, one can purchase mil-spec connectors and tools from anyone with a high expectation for mix-n-match between tools and connectors. Bob . . . > >Hi Hugo > >The steinair website may help you. >http://steinair.com/connectors.htm >I believe that any connector that fits RG-58 will fit RG400 and I used a >$20. imported crimper that worked fine for me. > >Ken L. > >gommone7(at)bellsouth.net wrote: > >> >>Hi all,still with antennas questions, >>almost everybody suggest to use rg400u coaxial cable ,good, i ordered,now >>the choice in the usual catalogs have a very restricted choice of BNC >>connectors (only one tipe )will fit the RG 400,and can't be solder,ok >>order allready the 70 dol crimping tool.but still one part missing wich >>is a metal sleeve wich slide over the conection and allow to be >>crimped,if I'm rigth ,no body sale thats sleeve,can some one help me to >>understand or a place to order the part. >>thanks ,and sorry for my lack of knoledge in electrical systems >>Hugo >> > > >-- > > >-- incoming mail is certified Virus Free. >Checked by AVG Anti-Virus. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: Thinking things electic
X-mailer: Pegasus Mail for Windows (4.41) > You see, > they're in the 3rd group. At least concerning electrons. They don't want to > have to think about wiring their sky charriots. They just want to fly them! > And, who's to blame them for that? Let's look at that a different way. First a backgrounder... My Dad taught me to fly. He was a CFII and and A&P w/ IA. I learned to fly and learned systems and the why and how of those systems and could work on them, too. On the other hand, I'm neither of the above. Those folks who just want to "fly" aren't, I believe, being properly grounded in systems theory, either mechanical/electro- mechanical/electrical. Those with a passion for learning beyond "flying" make better pilots in my estimation. I'm marginal when it comes to pure electrical but can generally get the information I need to act on some issue. I have a better handle on mechanical/electro-mechanical. Am I a whiz? Nope. Not even close...just persistent and methodical. Not thinking will get you in world of hurt. Don't question conventional wisdom and you'll have to accept the consequences. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Subject: hugo rv10
Date: Oct 04, 2006
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Radioshack also has one for 11 bucks Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Sent: Wednesday, October 04, 2006 8:49 AM Subject: Re: AeroElectric-List: hugo rv10 Hi Hugo The steinair website may help you. http://steinair.com/connectors.htm I believe that any connector that fits RG-58 will fit RG400 and I used a $20. imported crimper that worked fine for me. Ken L. gommone7(at)bellsouth.net wrote: > >Hi all,still with antennas questions, >almost everybody suggest to use rg400u coaxial cable ,good, i ordered,now the choice in the usual catalogs have a very restricted choice of BNC connectors (only one tipe )will fit the RG 400,and can't be solder,ok order allready the 70 dol crimping tool.but still one part missing wich is a metal sleeve wich slide over the conection and allow to be crimped,if I'm rigth ,no body sale thats sleeve,can some one help me to understand or a place to order the part. >thanks ,and sorry for my lack of knoledge in electrical systems Hugo > > ________________________________________________________________________________
Date: Oct 04, 2006
I am finding it more and more difficult to remember things by rote. I do much better when someone tells me WHY something is a certain way, because then I can derive the answer over and over again, if I should forget the actual answer. For instance, I forget the final approach speed I'm supposed to use in a C-172. But if I know that you can derive that number from 1.3 times the stall speed, then I can compute it for any airplane, not just the C-172. Sometimes there are other factors that have to be considered in an answer. For example, my instructor tells me that the final approach speed for my Mooney should be 80mph. Nail that 80mph and I've got a great shot and a great landing. But 80mph I can get in a thousand different ways. One of them has the nose pointed way up into the sky and full power. That's 80mph. One has the nose exactly at the horizon, and less power. Should I be using either of those "80" attitudes when setting up for landing? No. Neither should I be using the "all power off" 80, because it turns out, that, too is 80, but the sink rate is way too high. So, my instructor tells me the other factors that go into the 80 I should have. I should have about 400fpm sink rate, then adjust manifold pressure to get 80. And he explains all about the amount of angular change to round out the flare with a 400fpm sink rate versus a 600fpm sink rate, etc. etc. He asks me, when there is a 20mph headwind, does that change your rate of climb or your angle of climb? Does it change your angle of descent? So what should you do when landing into a strong headwind? If he just said "remember the answer is 80", that would not teach me what I really need to know to handle all situations that I'm going to encounter. An interesting thing I learned by seeing the inside of the contactor was the spring. Now, admittedly that spring is hardly stressed, and will probably never break, but if the contactor is mounted upside-down, then voila, the spring is not needed because gravity will do the same job. So there's another, albeit tiny, data point. (I will admit that I've been cursed with "but why" ever since I was a kid.) Dave Morris At 11:18 AM 10/4/2006, you wrote: > > > You see, > > they're in the 3rd group. At least concerning electrons. They > don't want to > > have to think about wiring their sky charriots. They just want to > fly them! > > And, who's to blame them for that? > >Let's look at that a different way. First a backgrounder... > >My Dad taught me to fly. He was a CFII and and A&P w/ IA. I >learned to fly and learned systems and the why and how of those >systems and could work on them, too. On the other hand, I'm >neither of the above. > >Those folks who just want to "fly" aren't, I believe, being properly >grounded in systems theory, either mechanical/electro- >mechanical/electrical. Those with a passion for learning beyond >"flying" make better pilots in my estimation. I'm marginal when it >comes to pure electrical but can generally get the information I >need to act on some issue. I have a better handle on >mechanical/electro-mechanical. Am I a whiz? Nope. Not even >close...just persistent and methodical. > >Not thinking will get you in world of hurt. Don't question >conventional wisdom and you'll have to accept the >consequences. > > >Jim Baker >580.788.2779 >Elmore City, OK > > ________________________________________________________________________________
Subject: hugo rv10
Date: Oct 04, 2006
Thanka at all. hugo ________________________________________________________________________________
Subject: hugo rv10
Date: Oct 04, 2006
Date: Oct 04, 2006
Subject: RE: Coax Crimp tools
> > >Radioshack also has one for 11 bucks > >Frank I think the 'low cost' coax tool at RS is for television "F" connectors. They also list a tool with hex dies and a "small" hole for about $18.00 See http://tinyurl.com/jbn46 For MOST of the RG-58/RG-400 connectors out there you need a reasonably accurate .213" hex die (shield sleeve) and a .068" square or hex die (center pin). I've encountered tools that were properly marked but in fact were slightly over or under-sized and didn't produce the desired crimp. You can take a pair of calipers with you to the store http://tinyurl.com/8b18 and check the tool before you buy it. Go for .213" minus .000" plus .001" and .068" plus/minus .001" These tools are made and offered by dozens of folks from all walks of technology and while most are pretty good, you don't want to find one that's not so good AFTER you've bought the tool and are needing to FINISH the job. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2006
Good point. The Radioshack deal is in fact listed for RG58 and appeared to work very well. FWIW Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, October 04, 2006 10:40 AM Subject: AeroElectric-List: RE: Coax Crimp tools --> (Corvallis)" > > >Radioshack also has one for 11 bucks > >Frank I think the 'low cost' coax tool at RS is for television "F" connectors. They also list a tool with hex dies and a "small" hole for about $18.00 See http://tinyurl.com/jbn46 For MOST of the RG-58/RG-400 connectors out there you need a reasonably accurate .213" hex die (shield sleeve) and a .068" square or hex die (center pin). I've encountered tools that were properly marked but in fact were slightly over or under-sized and didn't produce the desired crimp. You can take a pair of calipers with you to the store http://tinyurl.com/8b18 and check the tool before you buy it. Go for .213" minus .000" plus .001" and .068" plus/minus .001" These tools are made and offered by dozens of folks from all walks of technology and while most are pretty good, you don't want to find one that's not so good AFTER you've bought the tool and are needing to FINISH the job. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2006
They are standard molex/narco/king/pse square molex type pins. Instead of spending $40-60 on the "official" pin tool...do the following Flatten the end of a piece of .040" safety wire...works great. Use a "bobby pin" Use a flattened paper clip or - what we use in my shop. Take an old piece of a hacksaw blade, take it to be belt sander and sand a nice small flat "finger" into the end of it about .040" wide. Works great and rarely breaks, and doesn't cost anything! Any of the above solutions will work great. Cheers, Stein. >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert >L. Nuckolls, III >Sent: Wednesday, October 04, 2006 9:42 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Pin extraction tool KMA 24 or PMA 7000 > > > > > >> >>Anyone have any idea of the name or number for the honeywell pin >>extraction and insertion tool for the connectors on KMA 24 or PS eng >>PMA7000 audio panels and where I can get them?? > > Do the connectors have any numbers or brand names on > them? It's seldom possible to identify tools specific > to connectors based on the brand of product that uses > the connector. If you can see any identifying clues as > to the manufacturer of the connector, then we can access catalogs > for those devices and identify descriptions and sources > for the tools. > > If you have a digital camera, take some closeups of > the connector body and email them to me. Perhaps I can > identify the connector by seeing its design. > > Bob . . . > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Subject: Re: Relays 'G's" skunk stink
Date: Oct 04, 2006
Bob said: > Plunger position or even the presence of a plunger > does not influence static coil current. Oops...Yes you are right... Re: Fuller Quote-- At least I have refrained from using as a signature: "Concepts of space and time are certainly doomed." Dr. Edward Witten -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65797#65797 ________________________________________________________________________________
Date: Oct 04, 2006
I'd like to take this opportunity to put in a plug for Steinair. Throughout my project he and all of his employees have been immensly helpful in answering questions, giving advice, expediting parts, and finding sources in order to help me complete my panel. I am sure they consumed many valuable hours out of their busy schedules to help. This is one top notch group of people. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65813#65813 ________________________________________________________________________________
From: "Roger Venables" <roger(at)nwtradingpost.com>
Date: Oct 04, 2006
Jeff I recently attended the EAA electrical workshop and asked the same question (different plane!) The answer I got was that the shielding should be bridged, that is solder tags to the shielding on either side and connect through the molex plug Hope this is helpful Roger Venables Zenith 701 Kenmore, WA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jeff Moreau Sent: Tuesday, October 03, 2006 12:17 PM Subject: AeroElectric-List: Strobe Wiring I am installing Whelen wingtip strobes on my RV8. I have installed a molex multi-pin plug at the wing root in the event that I ever have to remove the wings. Does anyone feel that this is inviting a problem with electrial "noise" in my system. I know that this is a shielded cable. I am a novice and would welcome any comments or suggestions. Jeff -------- Jeff Moreau RV8A Virginia Beach, VA Read this topic online here: http://forums.matronics.com/viewtopic.php?p=65535#65535 ________________________________________________________________________________
Subject: hugo rv10
Date: Oct 04, 2006
Thanks again for the answer,but personaly never purchase cheap tools,use few times but allways do perfect job. Now my next question. ELT antenna,in a 180knots airplane I thinks a flexible spring antenna will be out of question ,I belive can't be mount inside an a aluminum plane,I found a spot under the vertical stabilizer ,the 10 use a thin fiberglass fairing,what you guys thinks will work?,.eventualy need to work only one time,in a shallow accidents probably don't needed but in a bad one ,the the antenna will be pointing up and almost at the highest point,(sorry for the humor) here the pictures , thanks again ,Hugo ________________________________________________________________________________
Date: Oct 04, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> >They are standard molex/narco/king/pse square molex type pins. Instead of >spending $40-60 on the "official" pin tool...do the following > >Flatten the end of a piece of .040" safety wire...works great. >Use a "bobby pin" >Use a flattened paper clip > >or - what we use in my shop. Take an old piece of a hacksaw blade, take it >to be belt sander and sand a nice small flat "finger" into the end of it >about .040" wide. Works great and rarely breaks, and doesn't cost anything! > >Any of the above solutions will work great. Aha! THAT kind of tool. I've got a bunch of them, none are purchased. See: http://www.aeroelectric.com/Pictures/Tools/extraction_tool.jpg . . . any dimestore pocket screwdriver can be dressed down with your sander, grinder, etc to provide the proper tab dimensions for unlocking this style of pin. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2006
> >I'd like to take this opportunity to put in a plug for Steinair. > >Throughout my project he and all of his employees have been immensly >helpful in answering questions, giving advice, expediting parts, and >finding sources in order to help me complete my panel. I am sure they >consumed many valuable hours out of their busy schedules to help. > >This is one top notch group of people. Stein (like a number of folks I know) operates under what I call the Olive Ann Beech philosophy of business: "Take care of the customer and the bottom line will take care of itself." Not only that, all the time you MIGHT have spent trying to craft, implement and track a "plan" is spent having fun solving problems and making things work. The best blood pressure medicine I know of . . . Bob . . . ________________________________________________________________________________
From: "William Slaughter" <willslau(at)alumni.rice.edu>
Subject: Re: Relays 'G's" skunk stink (CORRECTION)
Date: Oct 04, 2006
Raymond, Have you considered buying the Aeroelectric Connection book? It's got lots of info right there for the reading. William Slaughter RV-8 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of raymondj Sent: Wednesday, October 04, 2006 1:43 AM Subject: RE: AeroElectric-List: Re: Relays 'G's" skunk stink (CORRECTION) --> Mr. Nuckolls, It is my opinion that your particular style of teaching is appropriate for students that are only marginally interested in the question and in seeking the solutions. I make the assumption that those who subscribe to the list and take the time to read and reply to the list have a high level of motivation. I would be served better by the presentation of as much of the available data as practical at the beginning of the solution process. Thank you for taking the time to respond. Cordially, Raymond Julian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, October 03, 2006 9:08 PM Subject: RE: AeroElectric-List: Re: Relays 'G's" skunk stink (CORRECTION) > >Mr. Nuckolls, > > I am disappointed and saddened to see you engaging in the > "I've got a >secret" style of information dissemination. > > If it is in the archive, please say so. > > If you have the answer, please give it. I'm disappointed that you're disappointed. When was the last time you sat down in a class where the instructor walks in and says, "We have a test next Friday, the answers are on the board. Class dismissed." If there is no discussion, then there's no measure of the exchange and retention of ideas. My first teaching job was at Great Lakes Naval Training Base 40 years ago. Instructors I worked with habitually taught to the test questions. I refused to do it then and I'm not going to start now. Patience my friend. It's not my intent to be secretive or obtuse. Bob . . . ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Master contactor doesn't work anymore?
I have a friend who needs help. (We'll call him "Sparky") "Sparky" was just about to leave the airport for the evening but had one last thing to do in the control tunnel in his F1 Rocket.. The BNC connector to the comm antenna was disconnected at the time and it accidently flopped down onto the master contactor and hit one of the two smaller poles resulting in a spark. (The large poles had rubber boots insulating them, but unfortunately no boots on the smaller poles) When "Sparky" went to turn on the master switch ( a Cessna style split master switch) the master contactor no longer functioned. "Sparky" left the airport in disgust so as not to be late for dinner, but now he needs to know how to proceed tomorrow with trouble shooting to get the master contactor to function again. Will "Sparky" need to replace the master contactor? Or, will he have to replace the Cessna style split master switch? Or, has the 22AWG wire between the contactor and master switch acted like a fuseable link and need to be replaced? How can I...I mean "Sparky," do some diagnostics before resorting to "swaptronics" of components??? HELP! Paul Siegel ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Re: Master contactor doesn't work anymore?
> >I have a friend who needs help. (We'll call him "Sparky") > >"Sparky" was just about to leave the airport for the evening but had one >last thing to do in the control tunnel in his F1 Rocket.. The BNC >connector to the comm antenna was disconnected at the time and it >accidently flopped down onto the master contactor and hit one of the two >smaller poles resulting in a spark. > >(The large poles had rubber boots insulating them, but unfortunately no >boots on the smaller poles) > >When "Sparky" went to turn on the master switch ( a Cessna style split >master switch) the master contactor no longer functioned. > >"Sparky" left the airport in disgust so as not to be late for dinner, but >now he needs to know how to proceed tomorrow with trouble shooting to get >the master contactor to function again. > >Will "Sparky" need to replace the master contactor? Or, will he have to >replace the Cessna style split master switch? Or, has the 22AWG wire >between the contactor and master switch acted like a fuseable link and >need to be replaced? > >How can I...I mean "Sparky," do some diagnostics before resorting to >"swaptronics" of components??? > >HELP! This is a job for Mr. Cliplead. He's been known to come in a variety of colors and lengths. I've got several dozen of his uncles and cousins hanging in my shop. If you have only one, recommend about three feet long and fitted with alligator clips (insulated if you want to get fancy). Start with using the cliplead to ground the master contactor terminal that goes off to the master switch. This should energize the master contactor with the usual "thunk". If so, then the problem lies with wiring and/or switch. If not, then a closer look at the contactor is in order. Is it a 3-terminal contactor? If so, then "tunkless" probably means contactor replacement. If a 4-terminal, check to see if the jumper between BAT terminal and the OTHER small terminal burned. Seems possible given the grounding nature of a free-lance coax connector. If the contactor "thunks", then check out wiring by applying Mr. Clippy between airfram ground and the contactor side of the battery master switch. "Thunk"? switch or ground wire on other side of switch is bad. No "thunk"? Wire between switch and contactor is open. Bob . . . >Paul Siegel > > >-- > > >-- incoming mail is certified Virus Free. >Checked by AVG Anti-Virus. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 04, 2006
Subject: Knurl driver....
X-mailer: Pegasus Mail for Windows (4.41) Does anyone have a source for a knurled nut (ring) driver as were used on older switches/breakers? Tessco (?) used to have one..these things are rare. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Subject: Radio Rack Screws
Date: Oct 05, 2006
I am assembling my radio stack. The supports to holding the radio trays together are AL angle. Do the screws holding the whole assy together have to be brass? I only have metal. Regards Chris ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Re: Radio Rack Screws
Chris Most Stainless Steel alloys are not magnetic either, so that could also be used. Take a magnet with you to the vendor. Check a sample of a SS screw to make sure it's not magnetic, before you buy it. I also used Stainless Steel nutplates on my panel for that reason. Charlie Kuss > > >I am assembling my radio stack. >The supports to holding the radio trays together are AL angle. >Do the screws holding the whole assy together have to be brass? >I only have metal. > > >Regards >Chris > > ________________________________________________________________________________
Date: Oct 04, 2006
H i Charlie, I was just going to contact you when I saw this e-mail. I send you a money order for the replacement o-rings for the brake system of my RV7 about 5 weeks ago but have not received the rings. I am wondering if you received the money. Please let me know Thanks Franz -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie Kuss Sent: Wednesday, October 04, 2006 9:13 PM Subject: Re: AeroElectric-List: Radio Rack Screws Chris Most Stainless Steel alloys are not magnetic either, so that could also be used. Take a magnet with you to the vendor. Check a sample of a SS screw to make sure it's not magnetic, before you buy it. I also used Stainless Steel nutplates on my panel for that reason. Charlie Kuss I am assembling my radio stack. The supports to holding the radio trays together are AL angle. Do the screws holding the whole assy together have to be brass? I only have metal. Regards Chris AeroElectric-List Email Forum - http://www.matronics.com/Navigator?AeroElectric-List - NEW MATRONICS WEB FORUMS - http://forums.matronics.com - NEW MATRONICS LIST WIKI - http://wiki.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Subject: Stop the Nuckolls bashing
Date: Oct 05, 2006
Please guys, I fear the alienation of 'the' Bob is drawing inexorably nearer. Take it off list if you have an ongoing issue. Bob Verwey A35 Bonanza ZU-DLW ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Re: AeroElectric-List Digest: 38 Msgs - 10/04/06
I got mine from lane pilot store on ebay stores scott At 01:55 AM 10/5/2006, you wrote: >Subject: AeroElectric-List: Pin extraction tool KMA 24 or PMA 7000 >From: "N395V" <n395v(at)hughes.net> > > >Anyone have any idea of the name or number for the honeywell pin >extraction and >insertion tool for the connectors on KMA 24 or PS eng PMA7000 audio panels and >where I can get them?? > >-------- >Milt >N395V >F1 Rocket -- ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Cessna Tray...
I'm looking for other things to check before I dis-assemble the radio rack. I have a older narco cessna replacement radio with a bad display. Discussed with the radio shop and bought a new Michel TKM MX300 to replace the radio. The new MX300 doesn't want to slide in the last 1/8 or 1/16 of an inch. All the contacts seem to be making up except the com antenna. - Vor works fine - both Nav and HIWAS. - I can get some hiss with the Squelch test button but no AWOS. MX300 Radio works fine in another airplane. Different MX300 has the same problem in this airplane. Checked antenna connections. old Narco works fine, as well as an old RT328. Unless you all have a suggestion, me and A&P are going to pull the tray and try to find why the radio doesn't make up the Com antenna connection. Nothing obviuos in tray or back of radio. Mitch Williams Chickasha Wings Inc. ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Re: Knurl driver....
> >Does anyone have a source for a knurled nut (ring) driver as >were used on older switches/breakers? Tessco (?) used to have >one..these things are rare. I haven't seen those listed in the catalogs for years. I used to have one but don't even recall the last time used or even saw it. I'll ask around. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 05, 2006
Mr. Nuckolls, Reasonable people may disagree. Thank you again for your thoughtful replies. I don't believe the cause of herding electrons will be further served by any additional input from me on this topic. Cordially, Raymond Julian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, October 04, 2006 7:03 AM Subject: AeroElectric-List: RE: Thoughts on Teaching > >Mr. Nuckolls, > >It is my opinion that your particular style of teaching is appropriate for >students that are only marginally interested in the question and in seeking >the solutions. I disagree. Permit me to elaborate: I was exceedingly fortunate in my formative years to have enjoyed the attention of an engineer at Boeing who was also an amateur radio operator. I knew ALL the hams within about 20 blocks of my house. Ed was particularly influential in that he never directly answered a question. He began to ask me questions . . . laying foundations which supported the answer I was looking for. More often than not, I would end up answering my own question. The process of mental imaging and logical assemblage of simple-ideas were powerful teaching tools. I used those tools only years later when he got me my first teaching job at Wichita U in an adult education course where a number of my students were former foremen of mine at Boeing. A few years later, those tools served me (and my students) well at Great Lakes. I'll respectfully suggest that the marginally interested student is ONLY seeking answers. Charles Kettering once noted: "Knowledge is not understanding. One may know a great deal and yet understand nothing." It's the INTENTLY interested individual that ENJOYS and will take the time to ponder the underlying support for a concept so that understanding is achieved. >I make the assumption that those who subscribe to the list and take the time >to read and reply to the list have a high level of motivation. One may be motivated to do many things and on many levels. The hallmark of achievement at anything is never a turn-key process. Tiger Woods probably hits balls every day. Yehudi Menuhin picked up his violin every day. Thomas Edison's thinking was probably NEVER silent on the task of pondering some new problem. If there are other ways to achieve understanding, I don't know what they are. However, if I can make it fun too, THEN there is hope for gathering the marginally interested student into the conversation as well. Therefore I (and those who would take time to participate here on the List) are stuck with the best I know how to do today. It's never easy but if it isn't fun too, then folks are free to take their business elsewhere. >I would be served better by the presentation of as much of the available >data as practical at the beginning of the solution process. >Thank you for taking the time to respond. I understand but as I wrote earlier I am disappointed that you are disappointed. Please understand that if my motivation were to simply be a disseminator of esoteric knowledge, then I am in danger of being replaced by Ask.com and Google. If I am to honor those to took the time to share with me in years past, then it's my duty to understand the value of what they gave me and to pass my inheritance forward. Bob . . . ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Knurled nut driver
> >Does anyone have a source for a knurled nut (ring) driver as >were used on older switches/breakers? Tessco (?) used to have >one..these things are rare. Hey Rev - is this what you're looking for? http://www.stewmac.com/shop/Electronics,_pickups/Tools:_Toggle_switch_wrench.html Jim Sinke N93634 KLZU --------------------------------- ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Re: RE: Coax Crimp tools
In a message dated 10/4/06 1:46:08 PM Eastern Daylight Time, nuckollsr(at)cox.net writes: > I think the 'low cost' coax tool at RS is for television > "F" connectors. They also list a tool with hex dies and > a "small" hole for about $18.00 > > See http://tinyurl.com/jbn46 > > For MOST of the RG-58/RG-400 connectors out there you > need a reasonably accurate .213" hex die (shield sleeve) > and a .068" square or hex die (center pin). I've > encountered tools that were properly marked but in > fact were slightly over or under-sized and didn't > produce the desired crimp. > > You can take a pair of calipers with you to the store > http://tinyurl.com/8b18 and check the tool before you > buy it. Go for .213" minus .000" plus .001" and > .068" plus/minus .001" > > These tools are made and offered by dozens of folks > from all walks of technology and while most are pretty > good, you don't want to find one that's not so good > AFTER you've bought the tool and are needing to FINISH > the job. > > Bob . . . ==================== Listen to what Bob says! Or you can simply use the soldering pencil you already have. And the wrench already in your tool box. And not have to worry or bring a caliper to the store. And not have to drive to the store. And save the gas for the plane. AND learn the simple task of how to make a moisture protected wrench and solder BNC. Guad, I love being old school. I don't have to learn new ways to do old thing and reinvent the wheel. Kisses Bob Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Oct 05, 2006
Subject: Re: Knurled nut driver
X-mailer: Pegasus Mail for Windows (4.41) > >Does anyone have a source for a knurled nut (ring) driver as > >were used on older switches/breakers? Tessco (?) used to have > >one..these things are rare. > > Hey Rev - is this what you're looking for? > > http://www.stewmac.com/shop/Electronics,_pickups/Tools:_Toggle_switch_wrench.html I'd seen this one listed and thought it might be a candidate. Thanks for the heads-up. The one I'd seen before looked like a split, tapered tube with a threaded ferrule to squeeze the tube around the nut. I may end up having to get busy on the lathe and make one. I'd have to figure out how to knurl the ID of the end, tho....hmmmmm. Take apart a steel knurling tool wheel and use a hyd. press? Maybe. Thanks, all. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 05, 2006
Jim, Not to be an additional bearer of bad tidings but several years ago I needed several of those knurled rings that go on the circuit breakers. I checked the internet and went to the nut and local nut and bolt companies in town. Nobody could match it. I finally contacted the company that made the breaker and talked to someone who had a few lying around that he could give me. Hope you have better luck Tim Shankland Jim Baker wrote: > >Does anyone have a source for a knurled nut (ring) driver as >were used on older switches/breakers? Tessco (?) used to have >one..these things are rare. > >Jim Baker >580.788.2779 >Elmore City, OK > > > > ________________________________________________________________________________
Date: Oct 05, 2006
Where does one buy stainless nutplates? Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie Kuss Sent: Wednesday, October 04, 2006 9:13 PM Subject: Re: AeroElectric-List: Radio Rack Screws Chris Most Stainless Steel alloys are not magnetic either, so that could also be used. Take a magnet with you to the vendor. Check a sample of a SS screw to make sure it's not magnetic, before you buy it. I also used Stainless Steel nutplates on my panel for that reason. Charlie Kuss I am assembling my radio stack. The supports to holding the radio trays together are AL angle. Do the screws holding the whole assy together have to be brass? I only have metal. Regards Chris AeroElectric-List Email Forum - http://www.matronics.com/Navigator?AeroElectric-List - NEW MATRONICS WEB FORUMS - http://forums.matronics.com - NEW MATRONICS LIST WIKI - http://wiki.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 06, 2006
Bevan, The first step is to know the part number for the SS parts. This is actually rather simple. You simply add one to the last digit of the more common MS part number (The K1000 numbers used by Vans Aircraft are actually part of an obsolete numbering system). As an example, a common nutplate (old system calls them K1000) is the MS21047-xxx (x denoting the screw hole size). The SS version of this nutplate would be MS21048-xxx. I purchased my SS nutplates from M&M Aerospace Hardware. M&M has 5 locations around the country. They are geared towards selling to aviation professionals, but will sell to individuals. Early last year I made a "group purchase" of these SS nutplates for people on the Yahoo RV8 List. I did this because M&M offers pricing discounts when hardware is ordered in lots of 100. The discount is very significant. M&M's web site is below. http://www.mmaero.com/us/index.cfm M&M carries all the "hard to find" stuff that other vendors don't have. Charlie >Where does one buy stainless nutplates? > >Bevan > > >---------- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie Kuss >Sent: Wednesday, October 04, 2006 9:13 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Radio Rack Screws > >Chris > Most Stainless Steel alloys are not magnetic either, so that could > also be used. Take a magnet with you to the vendor. Check a sample > of a SS screw to make sure it's not magnetic, before you buy it. I > also used Stainless Steel nutplates on my panel for that reason. >Charlie Kuss > > >> >> >>I am assembling my radio stack. >>The supports to holding the radio trays together are AL angle. >>Do the screws holding the whole assy together have to be brass? >>I only have metal. >> >> >>Regards >>Chris >> >> >>AeroElectric-List Email Forum - >>http://www.matronics.com/Navigator?AeroElectric-List >>- NEW MATRONICS WEB FORUMS - >>http://forums.matronics.com >>- NEW MATRONICS LIST WIKI - >>http://wiki.matronics.com >>- List Contribution Web Site - >>-Matt Dralle, List Admin. >>http://www.matronics.com/contribution > > >href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >href="http://forums.matronics.com">http://forums.matronics.com >href="http://wiki.matronics.com">http://wiki.matronics.com >href="http://www.matronics.com/contribution">http://www.matronics.com/c > ________________________________________________________________________________
Date: Oct 06, 2006
from the gc / waldom catalog http://www.gcwaldom.com/catalog.html Knurl-Nut Wrenches Tightens or loosens knurled finish nuts. Collet-type pressure jaws provide positive vise-like grip. Reverse quarter turn loosens jaws and drops nut. 1/16" adjustment takes finish nuts of slightly less or greater size. Hollow collet barrel fits the long shank of many toggle switches. Cat. No. 00-9358-0000 N.S.N. 5120-00-88-4009 5/8" dia. Nut Cat. No. 00-9359-0000 Scott @ william morgan warbirds (not my email addr) At 01:55 AM 10/5/2006, you wrote: >From: "Jim Baker" <jlbaker(at)msbit.net> >Subject: AeroElectric-List: Knurl driver.... >X-mailer: Pegasus Mail for Windows (4.41) > > >Does anyone have a source for a knurled nut (ring) driver as >were used on older switches/breakers? Tessco (?) used to have >one..these things are rare. > >Jim Baker >580.788.2779 >Elmore City, OK -- ________________________________________________________________________________
Date: Oct 06, 2006
Subject: Re: Stop the Nuckolls bashing
Judging from Bob's patient answers to innumerable queries, from the didn't-read-the-F-manual to from-one-EE-to-another-EE types, I don't believe he will be alienated anytime soon. Many years of teaching have apparently taught him that in any audience there are people for whom the phrasing of a question is exhaustion enough, leaving them only with the threshold consciousness needed to scribble down the answer. I've gotten that plaintive "Dude!, I asked you for the time, not how to build a clock!" reaction, usually from those taking a course because it's required, not because they are interested in the subject. As a guy who can only understand amps and volts in terms of water spurting from a garden hose - and I have to be looking at one to get a clear picture, I am more likely than most on this list to reach for the inhaler if an answer to a question leaves me with another question. But, hey, I figure I'm learning, so I reach for the 'Connection, call Stein, reread installation instructions, search the archives, kick the cat, or have another beer, and try to work it out for myself. Keep teaching, Bob, and set up a fee schedule for those who want one-line answers. ________________________________________________________________________________
Date: Oct 06, 2006
X-mailer: Pegasus Mail for Windows (4.41) > > http://www.gcwaldom.com/catalog.html > > Knurl-Nut Wrenches Whoo, hooo! Bless you, William! Just the item I was looking for. Guess the lathe will have to wait. Thanks! Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Oct 06, 2006
Subject: Switching between comm feeds
Like most Long's/Cozy's, I built a comm antenna into each winglet. I ran coax's from both winglets to the panel. I'd like to install a switch so I can switch between antenna's. There's such a switch behind my TV that the kids use to switch between DVD or cable feed. It's a flaky Radio Shack thing, but it works (if you fiddle with it). Is there a higher-end version that I can install behind the panel for switching between antennas? Many thanks Neil -- ________________________________________________________________________________
Date: Oct 06, 2006
From: "Richard E. Tasker" <retasker(at)optonline.net>
Great info, but does anyone actually carry them? I couldn't find a distributor that even recognizes that they still exist... Dick Tasker William Morgan wrote: > > > from the gc / waldom catalog > > http://www.gcwaldom.com/catalog.html > > Knurl-Nut Wrenches > Tightens or loosens knurled finish nuts. > Collet-type pressure jaws provide positive vise-like grip. > Reverse quarter turn loosens jaws and drops nut. > 1/16" adjustment takes finish nuts of slightly less or greater size. > Hollow collet barrel fits the long shank of many toggle switches. > Cat. No. 00-9358-0000 > N.S.N. 5120-00-88-4009 5/8" dia. Nut > Cat. No. 00-9359-0000 > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Oct 07, 2006
In a message dated 10/4/2006 10:48:41 PM Eastern Standard Time, psiegel(at)fuse.net writes: Will "Sparky" need to replace the master contactor? Or, will he have to replace the Cessna style split master switch? Or, has the 22AWG wire between the contactor and master switch acted like a fuseable link and need to be replaced? How can I...I mean "Sparky," do some diagnostics before resorting to "swaptronics" of components??? HELP! Paul Siegel ================================== Hi Paul: Tell Sparky I HATE 'swaptronics" even more than "swapmechanics". The first thing Sparky has to do is pull out the schematic for the bird. The second quick fix is to check ALL fuses and circuit breakers. Usually in the wiring of Master relays there is a fuse in the B+ control lead of the coil. Turning on is done by either completing the ground of the coil or the B+. >From your explanation it seems like the Ground is what is being used to complete the circuit and the Ground of the coax hit the B+ side of the relay ... Results POP of the 'hopefully' installed fuse. Use the schematic and trace the circuit to find the fuse. Or trace the wire from the relay. If you want to do a meter test, check resistance from each control stud (small terminals) to Ground. Also go back to the Master Switch and check for Voltage. Hope this helps, but! Tell Sparky to do this BEFORE he has any Beers. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Oct 07, 2006
Two semesters of EE as an undergrad.... Three quarters of Communications Engineering in grad school.... Still nothing beats: Bob's experience, wisdom, and his book with free updates! - Rich ________________________________________________________________________________
Date: Oct 07, 2006
Subject: new to this list
Hello, I have just completed the fuselage on the RV-9 I am building and am about to begin the process of putting in all things electric. I find myself overwhelmed with the vast unknown pool of knowledge and I just don't know where to jump in or begin. I have the Aeroelectric book on order. I have talked with Bob. Up until this point in the building process I have found pretty clear instructions for each step (ok, sometimes the plans and drawings were a little vague) but not for electric installation. Is there a "cook book" to use to at least have a place to begin? Mike Ice Anchorage, Alaska ________________________________________________________________________________
Date: Oct 07, 2006
Mike, Van's does sell a wiring harness for your RV-9. I bought one for my RV-8A but didn't use it because I had so many things I wanted to do another way. But, it did come with "put this here and use this wire to connect it to that" instructions. You might want to get just the instructions for the wiring kit for the RV-9 to review. Terry RV-8A finishing Seattle _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael T. Ice Sent: Saturday, October 07, 2006 8:58 AM Subject: AeroElectric-List: new to this list Hello, I have just completed the fuselage on the RV-9 I am building and am about to begin the process of putting in all things electric. I find myself overwhelmed with the vast unknown pool of knowledge and I just don't know where to jump in or begin. I have the Aeroelectric book on order. I have talked with Bob. Up until this point in the building process I have found pretty clear instructions for each step (ok, sometimes the plans and drawings were a little vague) but not for electric installation. Is there a "cook book" to use to at least have a place to begin? Mike Ice Anchorage, Alaska ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Date: Oct 07, 2006
Mike You have the cook book on order...Aeroelectric.... I am there now and am in the learning process. First determine aircraft mission. Determine budget. Design electrical system to meet aircraft mission and budget. ASK QUESTIONS after your own research. Check out others electrical plan. Submit your plan to others for suggestions. Order supplies. Ask questions through the whole process. Don't get side tracked by the intellectual joustings. Follow Bob's advice and you will not go wrong. Frank @ SGU and SLC wiring and other stufffffff....RV7A >From: "Michael T. Ice" <aurbo(at)ak.net> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: new to this list >Date: Sat, 07 Oct 2006 07:57:36 -0800 > >Hello, > >I have just completed the fuselage on the RV-9 I am building and am about >to begin the process of putting in all things electric. I find myself >overwhelmed with the vast unknown pool of knowledge and I just don't know >where to jump in or begin. > >I have the Aeroelectric book on order. I have talked with Bob. > >Up until this point in the building process I have found pretty clear >instructions for each step (ok, sometimes the plans and drawings were a >little vague) but not for electric installation. > >Is there a "cook book" to use to at least have a place to begin? > >Mike Ice >Anchorage, Alaska ________________________________________________________________________________
Date: Oct 07, 2006
Subject: Re: new to this list
Frank and others, Thanks for the prompt replies and advice. I will take it to heart and do as you suggest. Don't worry about me getting caught up in the intellectual jousting, I am way to busy. Scottish Proverb: Be happy while you're living, for you're a long time dead. Mike Ice ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Saturday, October 07, 2006 11:50 AM Subject: RE: AeroElectric-List: new to this list > > > Mike > > You have the cook book on order...Aeroelectric.... > > I am there now and am in the learning process. First determine aircraft > mission. Determine budget. Design electrical system to meet aircraft > mission and budget. ASK QUESTIONS after your own research. Check out > others electrical plan. Submit your plan to others for suggestions. Order > supplies. Ask questions through the whole process. Don't get side tracked > by the intellectual joustings. Follow Bob's advice and you will not go > wrong. > > Frank @ SGU and SLC wiring and other stufffffff....RV7A > > >>From: "Michael T. Ice" <aurbo(at)ak.net> >>Reply-To: aeroelectric-list(at)matronics.com >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: new to this list >>Date: Sat, 07 Oct 2006 07:57:36 -0800 >> >>Hello, >> >>I have just completed the fuselage on the RV-9 I am building and am about >>to begin the process of putting in all things electric. I find myself >>overwhelmed with the vast unknown pool of knowledge and I just don't know >>where to jump in or begin. >> >>I have the Aeroelectric book on order. I have talked with Bob. >> >>Up until this point in the building process I have found pretty clear >>instructions for each step (ok, sometimes the plans and drawings were a >>little vague) but not for electric installation. >> >>Is there a "cook book" to use to at least have a place to begin? >> >>Mike Ice >>Anchorage, Alaska > > > ________________________________________________________________________________
Date: Oct 07, 2006
Subject: Burned out switch
I just experience my second switch failure in 100 hours. The first time is was the master switch (loose switch terminals), this time it was my Strobe power supply switch. Symptoms: tripping breaker at shut down, and burned fast-on terminal insulation at the switch. An inspection of the switch showed that the terminals were loose and discolored, indicating high internal temperatures. Bench testing with a constant current power supply indicated flaky terminals and overheating. I would expect the Strobe switch would be more susceptible to failure due to the constant power characteristics of the strobe power supply. As switch resistance increases, the current in the circuit would tend to increase as the strobe power supply tries to keep putting out the same power. This would quickly lead to thermal runaway in the switch. For example, if the switch resistance was high enough to cause a 4 volt drop across the switch, the strobe current would rise from 7 amps (nominal) to more than 10 amps, tripping my breaker. The switch would also overheat. This would also tend to cause a breaker trip at shut-down, because the voltage would drop from 14 to 12 as the engine stopped, increasing the strobe power supply draw. So... lesson learned. It also confirmed my suspicions that the breaker was tripping for a reason! Vern Little ________________________________________________________________________________
Date: Oct 07, 2006
Subject: Re: Burned out switch
Very interesting! What can you tell us about the quality of the switches? I would think the opposite, with the master having more duty. At least the strobes have a bit of time to cool so maybe less of a load! On 10/07/2006 6:16:48 PM, Vern Little (rv-9a-online(at)telus.net) wrote: <rv-9a-online@telus. > net> > > I just experience my second switch failure in 100 hours. The first time > is was the master switch (loose switch terminals), this time it was my > Strobe power supply switch. > > Symptoms: tripping breaker at shut down, and burned fast-on terminal > insulation at the switch. > > An inspection of the switch showed that the terminals were loose and > discolored, indicating high internal temperatures. > > Bench testing with a constant current power supply indicated flaky > terminals and overheating. ________________________________________________________________________________
Date: Oct 07, 2006
One thing you can start doing before you even get "The Book" is to start making a list of all your electrically operated equipment. Everything from strobe lights to fuel pumps to electronic ignition systems, clocks, radios, etc. Get the manufacturer's specs on each one and write down the "Current" requirements for each. These will be stated in milliamps or Amps. For radios, it may give one current requirement for receiving and a different one for transmitting. Note that this is NOT the "fuse size" or "breaker size" given. If they only give you the electrical requirements in Watts, remember you can convert Amps = Watts / Voltage. Then sort your list by a) things you MUST have on all the time in order to stay aloft b) things you are required by FAR to have turned on at night-time c) intermittent loads, such as strobe light maximums, radio transmitter maximums, fuel pumps that run for a short time and then turn off, etc. etc. d) unusual loads that you may only require once in a blue moon, such as landing lights, pitot heat, etc. d) things that are luxury items, such as iPods, 2nd radios, This will help you start understanding how you might want to divide up the equipment onto the various buses you will be creating. It will also help you start understanding the maximum size alternator and battery you will need, what size wire to expect, fuse sizes, etc. etc. The book will make this all clearer, but this will give you something to start working on before the book arrives. Dave Morris At 10:57 AM 10/7/2006, you wrote: >Hello, > >I have just completed the fuselage on the RV-9 I am building and am >about to begin the process of putting in all things electric. I find >myself overwhelmed with the vast unknown pool of knowledge and I >just don't know where to jump in or begin. > >I have the Aeroelectric book on order. I have talked with Bob. > >Up until this point in the building process I have found pretty >clear instructions for each step (ok, sometimes the plans and >drawings were a little vague) but not for electric installation. > >Is there a "cook book" to use to at least have a place to begin? > >Mike Ice >Anchorage, Alaska ________________________________________________________________________________
Date: Oct 07, 2006
They are Carling switches with the riveted fast-on terminals. My master switch was defective from first flight, but not 'burned out'-just loose rivets leading to fluctuating field current in the alternator. The load on the master switch is only about 3 amps maximum. The strobe has about a constant 7 amp load (nominal). If the voltage drop, this current increases, as I mentioned... thus overloading the switch and circuit breaker. Strangely, the Master switch driving the alternator field has the same characteristics (a drop in bus voltage increases the current through the switch). I have a third switch that is suspicious as well... but I haven't determined if it's the fault of my flap motor. I've contacted the supplier (B&C). They replaced my Master switch, but I haven't heard back yet on the other one. I'm not worried about a replacement... I was concerned that they had a bad batch of switches. Vern A DeMarzo wrote: > Very interesting! What can you tell us about the quality of the > switches? I would think the opposite, with the master having more > duty. At least the strobes have a bit of time to cool so maybe less of > a load! > > > On 10/07/2006 6:16:48 PM, Vern Little (rv-9a-online(at)telus.net > ) wrote: > . > > net> > > > > I just experience my second switch failure in 100 hours. The first time > > is was the master switch (loose switch terminals), this time it was my > > Strobe power supply switch. > > > > Symptoms: tripping breaker at shut down, and burned fast-on terminal > > insulation at the switch. > > > > An inspection of the switch showed that the terminals were loose and > > discolored, indicating high internal temperatures. > > > > Bench testing with a constant current power supply indicated flaky > > terminals and overheating. > > * > > > * ________________________________________________________________________________
Date: Oct 07, 2006
Dave, Thanks for the great ideas. I have begun to make lists and your right it gives me something to do which is a big help. Mike ----- Original Message ----- From: "Dave N6030X" <N6030X(at)DaveMorris.com> Sent: Saturday, October 07, 2006 4:55 PM Subject: Re: AeroElectric-List: new to this list > > > One thing you can start doing before you even get "The Book" is to start > making a list of all your electrically operated equipment. Everything > from strobe lights to fuel pumps to electronic ignition systems, clocks, > radios, etc. > > Get the manufacturer's specs on each one and write down the "Current" > requirements for each. These will be stated in milliamps or Amps. For > radios, it may give one current requirement for receiving and a different > one for transmitting. Note that this is NOT the "fuse size" or "breaker > size" given. If they only give you the electrical requirements in Watts, > remember you can convert Amps = Watts / Voltage. > > Then sort your list by > a) things you MUST have on all the time in order to stay aloft > b) things you are required by FAR to have turned on at night-time > c) intermittent loads, such as strobe light maximums, radio transmitter > maximums, fuel pumps that run for a short time and then turn off, etc. > etc. > d) unusual loads that you may only require once in a blue moon, such as > landing lights, pitot heat, etc. > d) things that are luxury items, such as iPods, 2nd radios, > > This will help you start understanding how you might want to divide up the > equipment onto the various buses you will be creating. It will also help > you start understanding the maximum size alternator and battery you will > need, what size wire to expect, fuse sizes, etc. etc. > > The book will make this all clearer, but this will give you something to > start working on before the book arrives. > > Dave Morris > > > At 10:57 AM 10/7/2006, you wrote: >>Hello, >> >>I have just completed the fuselage on the RV-9 I am building and am about >>to begin the process of putting in all things electric. I find myself >>overwhelmed with the vast unknown pool of knowledge and I just don't know >>where to jump in or begin. >> >>I have the Aeroelectric book on order. I have talked with Bob. >> >>Up until this point in the building process I have found pretty clear >>instructions for each step (ok, sometimes the plans and drawings were a >>little vague) but not for electric installation. >> >>Is there a "cook book" to use to at least have a place to begin? >> >>Mike Ice >>Anchorage, Alaska > > > ________________________________________________________________________________
Date: Oct 08, 2006
Subject: automatic electric trim switch
Hi, I'm installing a trio avionics altitude hold, and it has a cool feature where it will trim the aircraft for you when it is on. They recommend a radio shack bridge rectifier (part number 276-1183) and a DPDT relay (275-206) to allow the normal trim to work even when the altitude hold is engaged. I vaguely recall someone selling a little kit with a the stuff needed so that the pilot and co-pilot can use the trim without having to switch manually. I assume this must be the same thing. Anyone have any links to this product? I'd like to see if it either has better packaging or other features that might be useful. Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
From: "Europa (Alfred Buess)" <ykibuess(at)bluewin.ch>
Date: Oct 08, 2006
Mickey, I use the Matronics Governor - http://www.matronics.com/governor/index.htm - it has the additional advantage of speed regulation of your trim servo. Greetings from Zollikofen and best wishes, Alfred Alfred Buess Europa XS #097, Monowheel, Foam shortwing, Rotax 912S, Airmaster 332 CS -----Ursprngliche Nachricht----- Von: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Mickey Coggins Gesendet: Sonntag, 8. Oktober 2006 15:35 An: aeroelectric-list(at)matronics.com Betreff: AeroElectric-List: automatic electric trim switch --> Hi, I'm installing a trio avionics altitude hold, and it has a cool feature where it will trim the aircraft for you when it is on. They recommend a radio shack bridge rectifier (part number 276-1183) and a DPDT relay (275-206) to allow the normal trim to work even when the altitude hold is engaged. I vaguely recall someone selling a little kit with a the stuff needed so that the pilot and co-pilot can use the trim without having to switch manually. I assume this must be the same thing. Anyone have any links to this product? I'd like to see if it either has better packaging or other features that might be useful. Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
From: "europa flugzeug fabrik" <n3eu(at)comcast.net>
Date: Oct 08, 2006
rv-9a-online(at)telus.net wrote: > The strobe has about a constant 7 amp load (nominal). If the voltage drop, this current increases, as I mentioned... thus overloading the switch and circuit breaker. Uh, no, the current decreases with decreased voltage. Fred F. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=66562#66562 ________________________________________________________________________________
Date: Oct 08, 2006
Subject: Forced Learning
Dave, Why do you think everyone must study and learn the "lesson?" We are all learned people in different subject areas. I am willing to bet that anyone who monitors or participates in this forum is not lazy, ignorant, stupid, or unwilling to learn. In fact, just the opposite is true. We are all learning. BUT, when all I need is the time, then that's all I need! I have other, more important things to do than learn how to build the clock (it probably wouldn't keep correct time anyway). Academics don't understand that. Engineers and pilots do. Stan Sutterfield Tampa RV-8A "Dude!, I asked you for the time, not how to build a clock!" reaction, usually from those taking a course because it's required, not because they are interested in the subject. As a guy who can only understand amps and volts in terms of water spurting from a garden hose - and I have to be looking at one to get a clear picture, I am more likely than most on this list to reach for the inhaler if an answer to a question leaves me with another question. But, hey, I figure I'm learning, so I reach for the 'Connection, call Stein, reread installation instructions, search the archives, kick the cat, or have another beer, and try to work it out for myself. ________________________________________________________________________________
From: "Paul McAllister" <paul.mcallister(at)qia.net>
Date: Oct 08, 2006
Mickey, I have the one Matt sells and its great!. Take a look at http://www.matronics.com/governor/index.htm Paul Europa N378PJ ________________________________________________________________________________
Date: Oct 08, 2006
Sorry, Fred... the strobe power supply is a "constant power" as opposed to a resistive load device. If you decrease the voltage to the power supply (subject to the lower operating limit), the current increases in order for it to generate the same strobe output power. That's why the current required at 28V is about half that required at 12V. Vern europa flugzeug fabrik wrote: > > > rv-9a-online(at)telus.net wrote: >> The strobe has about a constant 7 amp load (nominal). If the voltage drop, this current increases, as I mentioned... thus overloading the switch and circuit breaker. > > Uh, no, the current decreases with decreased voltage. > > Fred F. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=66562#66562 > > > > > > > > > > > ________________________________________________________________________________
Subject: charging system problems
Date: Oct 08, 2006
I am still trying to figure this thing out. The bus voltage is a constant 14.5 volts. On the last two flights I made (1hr each) I had to reset the system twice in the first 10 min or so. The rest of the flight everything seemed to work fine. Collin, Bearhawk (N370CC) >Let me try to describe the problem as best I can. I am using a Van's 35 >amp alt. a VR-371 voltage/over-voltage protector, and a Electronics >International (VA-1) guage installed in the alt lead. Also using a Odyssey >680 battery. > >The problem is this: Everything seems to work just fine until maybe 10-15 >minutes into the flight when the discharge light on the VA-1 comes on. I >can reset the system by recyling the field breaker and everything goes >back to normal--charging again. This will last maybe another 10-15 >minutes and the whole process repeats itself. I have checked all my >conections, replaced the battery, and now am beginning to suspect the >alternator or even the regulator. But I need some advice before I go >replacing stuff that doesn't need replacing. (been there done that before!) If your system needs "reset", then the symptoms suggest that the OV protection system in your voltage regulator is being tripped. This becomes a problem of deducing whether a real OV condition existed -or- the circuit is being nuisance tripped. It's a rational component of troubleshooting to suspect any component. But it's much better to do measurements to determine the physics behind the difficulty before embarking on a swaptronics excursion where one can only hope to pick the right component . . . with the attendant risk that NONE of the components replaced will fix the problem. What are your bus voltages when the system is operating normally? I'm curious as to how you integrated the VR-371 voltage regulator with a Van's alterantor. I was under the impression that Van's sold only internally regulated machines. Let's do the detective work before you pull out any hardware. Bob . . . ________________________________________________________________________________
Date: Oct 08, 2006
europa flugzeug fabrik wrote: > > >rv-9a-online(at)telus.net wrote: > > >>The strobe has about a constant 7 amp load (nominal). If the voltage drop, this current increases, as I mentioned... thus overloading the switch and circuit breaker. >> >> > >Uh, no, the current decreases with decreased voltage. > > Uh, no, yourself. This is an electronic product and will try to keep the strobe firing voltage the same regardless of the input voltage. That means that the power to the strobe head is relatively constant - which is what you want. To do this the strobe supply draws more current if the input voltage falls (power = voltage x current). Dick Tasker -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Oct 08, 2006
Mike, Welcome aboard! You've met a few folks on the List and for the short term at least, I'll leave you in good hands. I've got some pressing family matters that will keep me out of circulation for a few days. Bob . . . >Hello, > >I have just completed the fuselage on the RV-9 I am building and am about >to begin the process of putting in all things electric. I find myself >overwhelmed with the vast unknown pool of knowledge and I just don't know >where to jump in or begin. > >I have the Aeroelectric book on order. I have talked with Bob. > >Up until this point in the building process I have found pretty clear >instructions for each step (ok, sometimes the plans and drawings were a >little vague) but not for electric installation. > >Is there a "cook book" to use to at least have a place to begin? > >Mike Ice >Anchorage, Alaska ________________________________________________________________________________
Date: Oct 08, 2006
> >Dave, > >Thanks for the great ideas. I have begun to make lists and your right it >gives me something to do which is a big help. > >Mike Check out the blank form at: http://www.aeroelectric.com/articles/LoadAnalysis.pdf You need one for EACH bus, typically main, e-bus and battery bus. Work this in #2 pencil and use pink eraser for modifying the work product. If you're handy with Excel, you might consider downloading the spread sheets at: http://www.aeroelectric.com/PPS/Load_Analysis These are good examples and starting points for developing a load analysis that describes what your dream machine is going to look like. This is a good exercise to do BEFORE you buy any hardware or start drilling holes in the panel. The load analysis is a living document so get comfortable with it (you'll be 95% DONE until a year after the airplane flies). Bob . . . ________________________________________________________________________________
Date: Oct 08, 2006
Subject: Off line for a few days . . .
My stepmother of some 47 years pass away last Friday after nearly 2 years of very uncomfortable wrestling with inoperable cancers. She was 90. There's a gathering of the clan in Medicine Lodge, Kansas this week. Given that my father is not in the best of health either, I'm the surrogate head of family on my father's behalf with number of important but not necessarily unwelcome tasks to attend to. Should be back in the saddle on Thursday. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 08, 2006
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Mickey, This might have been it.... http://www.f1-rocketboy.com/tcm.html Cheers, Michael Sausen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Sent: Sunday, October 08, 2006 9:35 AM Subject: AeroElectric-List: automatic electric trim switch --> Hi, I'm installing a trio avionics altitude hold, and it has a cool feature where it will trim the aircraft for you when it is on. They recommend a radio shack bridge rectifier (part number 276-1183) and a DPDT relay (275-206) to allow the normal trim to work even when the altitude hold is engaged. I vaguely recall someone selling a little kit with a the stuff needed so that the pilot and co-pilot can use the trim without having to switch manually. I assume this must be the same thing. Anyone have any links to this product? I'd like to see if it either has better packaging or other features that might be useful. Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Oct 08, 2006
rv-9a-online(at)telus.net wrote: > Sorry, Fred... the strobe power supply is a "constant power" as opposed to a resistive load device. If you decrease the voltage to the power supply (subject to the lower operating limit), the current increases in order for it to generate the same strobe output power. If you are referring to a strobe power supply designed for 14V/28V, well then yes we do have a different story. Whelen is like that, but I just now put a 4.0 A Whelen PS on the electronics bench, and the 4.0V spec is apparently peak current, which occurs in a very brief spike. At 12.3V, that spike is 4.5A, and mostly below 4.0 through the up/down cycle. At 14.1V, it is within spec at brief peak. For a 7A Whelen supply, that predicts to no more than an extra 1.0 amp at peak run off batt only, verses charging voltage. If we then look at the trip curves of a breaker, we will see that a 10A breaker (presume you have that) does not trip instantly at 10A, or even a notable amount above that, except after many seconds lapsing. So whats causing your problem such as to burn up fast-ons, I dont know. Perhaps others can help. Fred F. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=66644#66644 ________________________________________________________________________________
Date: Oct 09, 2006
Subject: Re: automatic electric trim switch
Europa (Alfred Buess) wrote: > I use the Matronics Governor - http://www.matronics.com/governor/index.htm - > it has the additional advantage of speed regulation of your trim servo. Thanks for the pointers! I also found one on this site: http://www.strongpitchtrim.com/ With the rocketboy trim, I now have three to chose from. Most excellent! -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Oct 08, 2006
Sorry to hear of your loss. Raymond Julian -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Sunday, October 08, 2006 8:53 PM Subject: AeroElectric-List: Off line for a few days . . . My stepmother of some 47 years pass away last Friday after nearly 2 years of very uncomfortable wrestling with inoperable cancers. She was 90. There's a gathering of the clan in Medicine Lodge, Kansas this week. Given that my father is not in the best of health either, I'm the surrogate head of family on my father's behalf with number of important but not necessarily unwelcome tasks to attend to. Should be back in the saddle on Thursday. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 09, 2006
It would be really cool if there could be a side-by-side comparison test with all three solutions. Particularly the functions, strengths and weaknesses of each product. Bret ----- Original Message ----- From: "Mickey Coggins" <mick-matronics(at)rv8.ch> Sent: Sunday, October 08, 2006 11:45 PM Subject: Re: AW: AeroElectric-List: automatic electric trim switch > > > Europa (Alfred Buess) wrote: >> I use the Matronics Governor - >> http://www.matronics.com/governor/index.htm - >> it has the additional advantage of speed regulation of your trim servo. > > Thanks for the pointers! I also found one on this site: > > http://www.strongpitchtrim.com/ > > With the rocketboy trim, I now have three to chose from. Most excellent! > > -- > Mickey Coggins > http://www.rv8.ch/ > #82007 finishing > > > ________________________________________________________________________________
Date: Oct 09, 2006
Bob My sympathy and prayers are with you and your family. I just lost my 93 year old father to prostate cancer. He gave me my love of aviation and all things mechanical. Frank @ SGU @ SLC wiring a RV7A >From: "raymondj" <raymondj(at)frontiernet.net> >Reply-To: aeroelectric-list(at)matronics.com >To: >Subject: RE: AeroElectric-List: Off line for a few days . . . >Date: Sun, 8 Oct 2006 23:14:05 -0500 > > > >Sorry to hear of your loss. > >Raymond Julian > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert >L. Nuckolls, III >Sent: Sunday, October 08, 2006 8:53 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Off line for a few days . . . > > > > >My stepmother of some 47 years pass away last Friday >after nearly 2 years of very uncomfortable wrestling with >inoperable cancers. She was 90. > >There's a gathering of the clan in Medicine Lodge, Kansas >this week. Given that my father is not in the best of health >either, I'm the surrogate head of family on my father's >behalf with number of important but not necessarily unwelcome >tasks to attend to. Should be back in the saddle on Thursday. > > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Oct 09, 2006
Bob, Thanks. Family first. Besides I am in good hands as you say. Mike ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Sunday, October 08, 2006 5:38 PM Subject: Re: AeroElectric-List: new to this list > > > Mike, > > Welcome aboard! You've met a few folks on the List and > for the short term at least, I'll leave you in good > hands. I've got some pressing family matters that > will keep me out of circulation for a few days. > > Bob . . . > > > >>Hello, >> >>I have just completed the fuselage on the RV-9 I am building and am about >>to begin the process of putting in all things electric. I find myself >>overwhelmed with the vast unknown pool of knowledge and I just don't know >>where to jump in or begin. >> >>I have the Aeroelectric book on order. I have talked with Bob. >> >>Up until this point in the building process I have found pretty clear >>instructions for each step (ok, sometimes the plans and drawings were a >>little vague) but not for electric installation. >> >>Is there a "cook book" to use to at least have a place to begin? >> >>Mike Ice >>Anchorage, Alaska > > > ________________________________________________________________________________
Date: Oct 09, 2006
Many power supplies, especially switching regulator types, exhibit what's called 'negative resistance'. This means that if the input voltage to these power supplies increases, the power supply input current decreases. These types of power supplies do not work well when powered from a source that has a high resistance... such as a malfunctioning switch. In fact, they will oscillate quite nicely in certain conditions-- producing oscillating current and voltage at the input side... which can really mess up other devices tied to the input bus. I had to deal with this problem on power supplies that I designed for a nuclear research facility (Cyclotron). I would expect that the Whelen strobe power supply does not oscillate under these conditions due to conservative design, but they still will exhibit the inverse relationship between input voltage and input current, and can therefore lead to higher than rated input currents as the source voltage drops... and pop the breaker. As a side note: This also proves that there is rarely a 'nuisance trip' of a circuit breaker... it was trying to tell me something was not right. In the end, the wiring was fine, but the terminals, switch and circuit breaker were all toasted. BTW, a new switch, terminals and breaker and everything is now working fine. V europa flugzeug fabrik wrote: > > > rv-9a-online(at)telus.net wrote: >> Sorry, Fred... the strobe power supply is a "constant power" as opposed to a resistive load device. If you decrease the voltage to the power supply (subject to the lower operating limit), the current increases in order for it to generate the same strobe output power. > > If you are referring to a strobe power supply designed for 14V/28V, well then yes we do have a different story. Whelen is like that, but I just now put a 4.0 A Whelen PS on the electronics bench, and the 4.0V spec is apparently peak current, which occurs in a very brief spike. At 12.3V, that spike is 4.5A, and mostly below 4.0 through the up/down cycle. At 14.1V, it is within spec at brief peak. For a 7A Whelen supply, that predicts to no more than an extra 1.0 amp at peak run off batt only, verses charging voltage. If we then look at the trip curves of a breaker, we will see that a 10A breaker (presume you have that) does not trip instantly at 10A, or even a notable amount above that, except after many seconds lapsing. So whats causing your problem such as to burn up fast-ons, I dont know. Perhaps others can help. > > Fred F. > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=66644#66644 > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 09, 2006
Mickey How goes the install of the Subaru? Here is what I got, and they were great to work with, doing custom configs as necessary to meet my requirements. http://www.aircraftextras.com/ Dan RV10E -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mickey Coggins Sent: Sunday, October 08, 2006 10:35 AM Subject: AeroElectric-List: automatic electric trim switch Hi, I'm installing a trio avionics altitude hold, and it has a cool feature where it will trim the aircraft for you when it is on. They recommend a radio shack bridge rectifier (part number 276-1183) and a DPDT relay (275-206) to allow the normal trim to work even when the altitude hold is engaged. I vaguely recall someone selling a little kit with a the stuff needed so that the pilot and co-pilot can use the trim without having to switch manually. I assume this must be the same thing. Anyone have any links to this product? I'd like to see if it either has better packaging or other features that might be useful. Thanks, Mickey -- Mickey Coggins http://www.rv8.ch/ #82007 finishing ________________________________________________________________________________
Date: Oct 09, 2006
Subject: Small audio jack question
I bought an Intercom that allows two music inputs (one for the kids, one for the grownups). I bought small sockets from Radio Shack. They expect the usual "tip-ring-sleeve" 3-contact arrangement. But looking at the male jack on an electronic device I own, it has 4 contact surfaces on the male pin. So what's the forth one for and will I need it? Many thanks Neil ________________________________________________________________________________
Date: Oct 09, 2006
Subject: Re: Small audio jack question
>I bought an Intercom that allows two music inputs (one for the kids, one >for the grownups). I bought small sockets from Radio Shack. >They expect the usual "tip-ring-sleeve" 3-contact arrangement. But looking >at the male jack on an electronic device I own, it has 4 contact surfaces >on the male pin. >So what's the forth one for and will I need it? Wondering if you have what's called a "closed circuit" jack intended to disconnect a "primary" load (like built in speaker) when the "secondary" load (like headphones) is plugged in. A schematic for such a jack is attached. It has a total of 5 connections right and left inputs, right and left outputs, plus ground. f6e8ad.jpg Does this look like it matches your jack? What's the Radio Shack catalog number for the part you have? Bob . . . ________________________________________________________________________________
Subject: ELT/CHT cable extension
Date: Oct 09, 2006
Bob, what is the best method to extend the EGT/CHT cables? I'm doing a panel upgrade and need to add about 6" to each. Glenn654 N654RV RV-4 @ OKZ ________________________________________________________________________________
Date: Oct 09, 2006
It's not terribly unusual to see a 4-conductor stereo jack/plug wired with separate grounds for each channel, i.e. L+ L- R+ R- If you need a source for these plugs/jacks, I'll look them up for you... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Monday, October 9, 2006 2:37 PM Subject: Re: AeroElectric-List: Small audio jack question >I bought an Intercom that allows two music inputs (one for the kids, one >for the grownups). I bought small sockets from Radio Shack. >They expect the usual "tip-ring-sleeve" 3-contact arrangement. But looking >at the male jack on an electronic device I own, it has 4 contact surfaces >on the male pin. >So what's the forth one for and will I need it? Wondering if you have what's called a "closed circuit" jack intended to disconnect a "primary" load (like built in speaker) when the "secondary" load (like headphones) is plugged in. A schematic for such a jack is attached. It has a total of 5 connections right and left inputs, right and left outputs, plus ground. f6e8ad.jpg Does this look like it matches your jack? What's the Radio Shack catalog number for the part you have? Bob . . . ________________________________________________________________________________
Subject: Re: FAA Part 91.205
Date: Oct 09, 2006
10/09/2006 Hello Rob, The FAA has a back hand way of applying FAR Sec 91.205 to Amateur Built Experimental Aircraft (ABEA) and it takes a little research and careful reading of different documents to sort out what applies when. First, if you are operating the ABEA day VFR then none, I repeat NONE, of 91.205 applies to the instrumentation or equippage of that aircraft. (See Note 1 below). Hard to believe isn't it, but that is true because as you noted 91.205 applies to aircraft with standard category US airworthiness certificates and not to our ABEA's that instead receive special airworthiness certificates. (This is what permits very simple ABEA's like a Woody Pusher or Breezy to fly legally day VFR with nothing in the way of 91.205 instruments or equipment if the builder / pilot chooses to do so). Second, the instant that you start operating that ABEA at night or under IFR then 91.205 comes into play, not to the entire extent (See Note 2 below) that it does for aircraft with standard airworthiness certificates, but compliance with 91.205 for ABEA's does become extensive. Why is that? It is because each ABEA has been issued a special airworthiness certificate that includes a set of Operating Limitations that contain these words "After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under VFR, day only." The intent and interpretation by the FAA of that sentence is that if the ABEA is operating VFR at night then paragraphs 91.205 (b) and (c) must be complied with. If the ABEA is operating under IFR then paragraphs 91.205 (b), (c), and (d) must be complied with. (I suppose that some sea lawyer could argue that for day IFR one would not have to comply with 91.205 (c) (1) and thereby not comply with 91.205 (b), but that is not the way that the FAA interprets the word "appropriately" in that sentence in the Operating Limitations.) Because this subject is a bit convoluted I have put together a table that lays the information out in fairly compact reference form. I will send you a copy of this table attached to a separate email. If anyone else would like a copy just email me. This table was also published on page 50 of the June 2006 issue of Kitplanes magazine. Please let me know if you have any questions. OC -- The best investment we will ever make is in gathering knowledge Note 1: While 91.205 (b) (15) may not apply that does not excuse an ABEA from complying with 91.207 regarding ELT's. Note 2: Certain sub paragraphs of 91.205 refer to needing "approved" items. This issue becomes a bit fuzzy because since there are no certification criteria published for ABEA how can one determine whether an item is "approved" or not for installation in an ABEA? A commonly taken position both by many builders and by FAA and DAR initial airworthiness inspectors of ABEA's is that if the item can affect operations by other aircraft as well as the ABEA, such as exterior lighting for example, then an item which has been approved for installation on standard airworthiness certified aircraft will be required on the ABEA. On the other hand arguments have been successfully made that if the item affects only the internal functioning of the ABEA, such as seat belts and shoulder harnesses for example, then these items do not have to be "approved" (by a TSO marking for example). I have been involved in a few of these discussions and, with the aid of communication from FAA headquarters, have forced the inspector to back off the TSO marking requirement for both seat belts and shoulder harness which were already purchased and installed by the builder. I do not recommend letting it get to that point though. Instead I recommend coordinating with the inspector before the belts are purchased to determine his individual requirements. ----- Original Message ----- From: "Rob" <punchy(at)frontiernet.net> Sent: Monday, October 09, 2006 1:07 PM Subject: FAA Part 91.205 OC, I was wondering if you could clearify FAA Part 91.205 for me. As I understand this FAR it applies to powered civil aircraft with a standard category U.S. airworthiness certificate. Is our experimental airworthiness certificate under this catagory? It requires a manifold pressure gauge for each altitude engine. It does not require a CHT or EGT. This does not seem right for experimental aircraft. I would much rather have a CHT and EGT than a manifold pressure gauge although I have all three on my KIS. I was also wondering if my VFR day only plane needs to have a strobe and nav lights? Maybe you could enlighten me. Thanks, Rob ________________________________________________________________________________
Date: Oct 09, 2006
Hello OC, I'd appreciate a copy of the table you mentioned Because this subject is a bit convoluted I have put together a table that lays the information out in fairly compact reference form. I will send you a copy of this table attached to a separate email. If anyone else would like a copy just email me. This table was also published on page 50 of the June 2006 issue of Kitplanes magazine. Thanks, Tony Babb Velocity SEFG 62% done, 78% to go www.alejandra.net/velocity ________________________________________________________________________________
Date: Oct 09, 2006
Subject: Re: ELT/CHT cable extension
Get the same exact type of cables you have on each sensor now. IIRC, the minimum add-on is 12 inches but I don't remember why. Aircraft Spruce has some at pretty good prices. You could get a 6 footer and cut it down to what you need. David M. glennpaulwilkinson wrote: > Bob, > what is the best method to extend the EGT/CHT cables? > I'm doing a panel upgrade and need to add about 6" to each. > > Glenn654 > N654RV > RV-4 @ OKZ > <<>> ________________________________________________________________________________
Date: Oct 09, 2006
> > I was wondering if you could clearify FAA Part 91.205 for me. As I > understand this FAR it applies to powered civil aircraft with a > standard > category U.S. airworthiness certificate. Is our experimental > airworthiness > certificate under this catagory? It requires a manifold pressure > gauge for > each altitude engine. It does not require a CHT or EGT. This does > not > seem right for experimental aircraft. I would much rather have a > CHT and > EGT than a manifold pressure gauge although I have all three on my > KIS. I > was also wondering if my VFR day only plane needs to have a strobe > and nav > lights? The reference to an "altitude engine" requires a study of FAR 1.1 to see that it means "a reciprocating aircraft engine having a rated takeoff power that is producible from sea level to an established higher altitude." I.e. it means a turbo-charged or super-charged engine. Anyone who has such an engine really should have a MP gauge, whether FAR 91.205 applies to them or not. Kevin Horton Ottawa, Canada ________________________________________________________________________________
Subject: Re: Off line for a few days . . .Off line for a few
days . . .
Date: Oct 09, 2006
My condolences on your loss, Bob. Marty in Brentwood TN ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Subject: Radio Rack Screws
Date: Oct 09, 2006
What am I missing? What difference does it make whether the screws or nutplates are ferrous metal or not? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Byrne Sent: Wednesday, October 04, 2006 11:31 PM Subject: AeroElectric-List: Radio Rack Screws I am assembling my radio stack. The supports to holding the radio trays together are AL angle. Do the screws holding the whole assy together have to be brass? I only have metal. Regards Chris ________________________________________________________________________________
Subject: Re: Radio Rack Screws
Date: Oct 10, 2006
Electrolysis? Aluminium and brass? Maybe stainless steel might be the choice. Bill ----- Original Message ----- From: "John Swartout" <jgswartout(at)earthlink.net> Sent: Tuesday, October 10, 2006 1:25 PM Subject: RE: AeroElectric-List: Radio Rack Screws > > > What am I missing? What difference does it make whether the screws or > nutplates are ferrous metal or not? > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris > Byrne > Sent: Wednesday, October 04, 2006 11:31 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Radio Rack Screws > > > > I am assembling my radio stack. > The supports to holding the radio trays together are AL angle. > Do the screws holding the whole assy together have to be brass? > I only have metal. > > > Regards > Chris > > > ________________________________________________________________________________
Date: Oct 10, 2006
And, Bob...remember that the connecting wire itself is part of the thermocouple can affect the reading if not matched, connected or handled correctly. If you want to do it the way the professionals do (or did, in my case...retired )connecting the wires mechanically with connectors whose metal parts also match the wire type is preferable. Soldering them may cause a degradation in the accuracy, especially if the joint is in a location where the temperature may be different. Read everything you ever wanted to know (and a lot you don't care about) thermocouples here: www.omega.com/temperature/Z/pdf/z021-032.pdf Omega also has the connectors you want. Harley Dixon ------------------------------------------------------------------------ David M. wrote: > > Get the same exact type of cables you have on each sensor now. IIRC, > the minimum add-on is 12 inches but I don't remember why. > > Aircraft Spruce has some at pretty good prices. You could get a 6 > footer and cut it down to what you need. > > David M. > > > glennpaulwilkinson wrote: > >> Bob, >> what is the best method to extend the EGT/CHT cables? >> I'm doing a panel upgrade and need to add about 6" to each. >> >> Glenn654 >> N654RV >> RV-4 @ OKZ >> <<>> > > ________________________________________________________________________________
Subject: Re: new to this listnew to this list
Date: Oct 10, 2006
I'm at a similar stage of construction of my -8A QB. I started with Bob's book, then the EAA library, then the B&C, SteinAir and other catalogs (in many cases there are explanations for using an offered product). I also attended Bob's seminar in Auburn, CA. One thing has helped me: first develop a very detailed understanding of the basics - crimping, wire selection, grounding, bus design, contactor operation, etc. I agonized over the avionics suite but finally decided on the AFP 3500, Garmin 396/496, SL30, ICOM Comm2, PS Enginering Audio Panel, GTX 327, and TruTrak ADI Pilot. I also decided to use a taxi light but no landing light, a heated pitot, Van's strobes and position lights, and fuzes instead of circuit breakers. Also decided on a fuel injected engine. With all these goodies in mind, I then made preliminary architecture choices (Bob's Z-13 with two alternators and one battery; exact products still TBD), decided on fast tabs wherever possible, did an initial bus distribution design (batt, main and endurance), decided on a common firewall ground bus, will use conduit for the fuselage wire runs, used EPanel Builder to see if it all fits (along with standard altimeter, VSI and AS backup gauges) then thought about specific switches and warning lights. Finally, carefully analyzed where it'll all go (several iterations). Just starting the detailed wiring selection and design. Nothing installed yet, but I'm confident that a one-wire-at-a-time attitude will provide a doable solution. Paul Valovich Ridgecrest, CA ________________________________________________________________________________
Date: Oct 10, 2006
John I'm simply trying to eliminate as much steel and iron from the instrument panel. I'm using a panel mounted whiskey compass. Stainless steel, brass and aluminum do not affect the compass. Charlie Kuss > > >What am I missing? What difference does it make whether the screws or >nutplates are ferrous metal or not? > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris >Byrne >Sent: Wednesday, October 04, 2006 11:31 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Radio Rack Screws > > > >I am assembling my radio stack. >The supports to holding the radio trays together are AL angle. >Do the screws holding the whole assy together have to be brass? >I only have metal. > > >Regards >Chris > > ________________________________________________________________________________
Date: Oct 10, 2006
Okay-I see. At least the screws and nutplates don't move. I think my magnetic compass can be compensated. Seems like even that big hunk of iron just behind the propeller would have some effect on the compass. I guess if it turns out to be a problem, I'll be going back to this thread to look for those SS parts. John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie Kuss Sent: Tuesday, October 10, 2006 10:19 AM Subject: RE: AeroElectric-List: Radio Rack Screws John I'm simply trying to eliminate as much steel and iron from the instrument panel. I'm using a panel mounted whiskey compass. Stainless steel, brass and aluminum do not affect the compass. Charlie Kuss What am I missing? What difference does it make whether the screws or nutplates are ferrous metal or not? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [ mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Byrne Sent: Wednesday, October 04, 2006 11:31 PM Subject: AeroElectric-List: Radio Rack Screws I am assembling my radio stack. The supports to holding the radio trays together are AL angle. Do the screws holding the whole assy together have to be brass? I only have metal. Regards Chris AeroElectric-List Email Forum - http://www.matronics.com/Navigator?AeroElectric-List - NEW MATRONICS WEB FORUMS - http://forums.matronics.com - NEW MATRONICS LIST WIKI - http://wiki.matronics.com - List Contribution Web Site - -Matt Dralle, List Admin. http://www.matronics.com/contribution ________________________________________________________________________________
Date: Oct 10, 2006
Subject: Re: Thinking things electic
I'm not sure if Dr. Dunham intended eclectic or electric in the subject line, but both would have been appropriate. I still am not convinced that we must all be so trained on electrics as to be able to derive all electrical answers from our base knowledge. Sometimes we don't need the huge foundation of knowledge. To use Dr. Dunham's example, my grandmother knew how to treat a sore throat (she completed the fourth grade), yet she had virtually no knowledge of medical techniques. I'm not trying to put down Dr. Dunham, I'm just saying we don't always need to know everything in order to accomplish a relatively simple task. But, occasionally, we need confirmation from someone who has that knowledge. We need someone who will look at our electrical plans, and instead of saying study Z-99 and come back tomorrow, give us advice on how to best implement OUR desired plan. After I do a load plan and draw my schematics I need someone trained (large knowledge base) in electrics to analyze my concept and help me find errors. I am willing to pay for such advice and I suspect others are willing to do the same. In many cases, builders don't have the time or desire to learn it all. STILL, Dr. Dunham makes me think. His is the best argument I've seen on this forum in favor of indepth learning as opposed to adequate knowledge. I commend you for your thoughts. I think I'll rethink my own thoughts and try to implement some of your thoughts. How's that for eclectic? But, I am serious when I say that. I will strive to think more instead of depending on others to do my electrical thinking. Until I reach that level of learning (I may never reach it), any electrical experts out there willing to help me analyze my electrical? I'll pay a 3 month electrical advice retainer such that I can call and send emails for advice. Bob? Stan Sutterfield 5% of the people think. 10% of the people think they think. and 85% of the people would rather DIE than think. When I graduated from medical school my head was crammed full of "answers". I could spout facts like nobody's business. Then I met the public and realized I didn't know how to "doctor" people. In other words, I didn't know how to think like a doctor! This revelation came early in my career in a busy ER in Knoxville, Tennessee. I had a patient with a sore throat and I didn't know how to treat it, or even where to go to find out. Shocking, isn't it? I was already an MD. In fact, I already knew how to treat heart attack, stroke and many serious and life threatening conditions. But I didn't know how to evaluate that sore throat! I was taken aback, as you might guess. Fortunately, I had a teacher supervising me who was ready to fill the gaps in my knowledge. And, even more fortunately, I learned from him how to evaluate patients, or more correctly, their problems. At first, I was miffed at him because when I asked him how to treat this patient, he handed me an article to read! I was busy! The ER was jumping and this "minor" problem was bogging me down. But, since I wasn't the only MD on duty, and I was in training after all, I sat down and quickly read the article. After I was done, I knew what to do. But, most curious of all, I had been exposed to the thought processes of the author and it transformed my thinking! I have continually worked to hone my skills as a medical thinker for the past 25 years. But that teacher was the beginning of my real medical education. Likewise, Bob Nuckolls has been the beginning of my electrical education. He makes it fun and rewarding. I like it so much I've read the 'Connection at least a half dozen times. I read this list every day. I've come to LIKE wiring airplanes! When I tell my OBAM airplane buddies, they just shake their heads in disbelief. One even asked if I would wire his! :o) You see, they're in the 3rd group. At least concerning electrons. They don't want to have to think about wiring their sky charriots. They just want to fly them! And, who's to blame them for that? That's why most of us build the dern things, isn't it? They are content to wire theirs according to the suggested diagrams supplied with the kit. Why not? It works, doesn't it? But we AeroElectric listers are the chosen few. Either by education or avocation we find ourselves thinking things electric. Sure, we want answers, but, even better, we want our fancies tickled! That's what Bob is doing here. We like it! We'll have the "answer" soon enough. But I'd like to know if my manner of thinking works! After all, I may be up there screaming along in my Sky Scorcher someday when things go awry and I'm gonna be all I've got to get things managable! I want the confidence to get that done. And Bob's method of teaching fills that need for me. At least concerning things electric. Rodney in Tennessee ________________________________________________________________________________
Date: Oct 10, 2006
John The biggest issue is distance from the compass. Magnetic steels and iron parts are not normally used in the instrument panel. Look at the radio rack trays used. They are all either aluminum or stainless steel for this reason. Charlie Kuss ---- John Swartout wrote: > Okay-I see. At least the screws and nutplates don't move. I think my > magnetic compass can be compensated. Seems like even that big hunk of iron > just behind the propeller would have some effect on the compass. I guess if > it turns out to be a problem, I'll be going back to this thread to look for > those SS parts. > > > > John > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Charlie > Kuss > Sent: Tuesday, October 10, 2006 10:19 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Radio Rack Screws > > > > John > I'm simply trying to eliminate as much steel and iron from the instrument > panel. I'm using a panel mounted whiskey compass. Stainless steel, brass and > aluminum do not affect the compass. > Charlie Kuss > > > > > > > > What am I missing? What difference does it make whether the screws or > nutplates are ferrous metal or not? > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [ > mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris > Byrne > Sent: Wednesday, October 04, 2006 11:31 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Radio Rack Screws > > > > I am assembling my radio stack. > The supports to holding the radio trays together are AL angle. > Do the screws holding the whole assy together have to be brass? > I only have metal. > > > Regards > Chris > > > > > > > AeroElectric-List Email Forum - > http://www.matronics.com/Navigator?AeroElectric-List > - NEW MATRONICS WEB FORUMS - > http://forums.matronics.com > - NEW MATRONICS LIST WIKI - > http://wiki.matronics.com > - List Contribution Web Site - > -Matt Dralle, List Admin. > http://www.matronics.com/contribution > > > > ________________________________________________________________________________
From: "William Slaughter" <willslau(at)alumni.rice.edu>
Subject: new to this listnew to this list
Date: Oct 10, 2006
Paul, One tip here. I use EPanel Builder for conceptual layouts and like it a lot, but it is very easy to create combinations that will not fit on the panel in real life. I have an actual CAD drawing for the final fitting. If you don't have a CAD program available, measure your combination on the instrument panel blank before getting totally invested in a particular design layout. Happy wiring! William Slaughter RV-8 Wings -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Valovich, Paul Sent: Tuesday, October 10, 2006 9:14 AM Subject: Re: AeroElectric-List: new to this listnew to this list I'm at a similar stage of construction of my -8A QB. I started with Bob's book, then the EAA library, then the B&C, SteinAir and other catalogs (in many cases there are explanations for using an offered product). I also attended Bob's seminar in Auburn, CA. One thing has helped me: first develop a very detailed understanding of the basics - crimping, wire selection, grounding, bus design, contactor operation, etc. I agonized over the avionics suite but finally decided on the AFP 3500, Garmin 396/496, SL30, ICOM Comm2, PS Enginering Audio Panel, GTX 327, and TruTrak ADI Pilot. I also decided to use a taxi light but no landing light, a heated pitot, Van's strobes and position lights, and fuzes instead of circuit breakers. Also decided on a fuel injected engine. With all these goodies in mind, I then made preliminary architecture choices (Bob's Z-13 with two alternators and one battery; exact products still TBD), decided on fast tabs wherever possible, did an initial bus distribution design (batt, main and endurance), decided on a common firewall ground bus, will use conduit for the fuselage wire runs, used EPanel Builder to see if it all fits (along with standard altimeter, VSI and AS backup gauges) then thought about specific switches and warning lights. Finally, carefully analyzed where it'll all go (several iterations). Just starting the detailed wiring selection and design. Nothing installed yet, but I'm confident that a one-wire-at-a-time attitude will provide a doable solution. Paul Valovich Ridgecrest, CA ________________________________________________________________________________
Subject: Question on Z-13 and E-Buss (Lengthy)
Date: Oct 10, 2006
I'm approaching the time where I need to spend some time on this board but forgive the somewhat basic nature of the questions. I'm starting to work on installation of the Z-13 architecture in an RV-7, IFR with dual GRT EFIS, and Garmin stack (SL-30/480/327), P800B audio panel, and TT DigiFlight II AP. I've done the load analysis and have come up with the following ( do have a full spreadsheet with each phase of flight listed against Normal Ops, Main Alt Fail, and Battery only): Main Buss: Total 26.5A Alt Field Lights - Taxi Lights - Nav Lights - Strobe Pitot Heat Flap Motor Auto Pilot - Pitch Auto Pilot - Roll Auto Pilot - Control Head E-Buss: 6.4A Alt Field EFIS 2 HIS Magnatometer/ AHRS Trim - Roll Trim - Pitch Turn Coordinator GNS-480 (Nav) GNS-480 (General) GNS-480 (Com) GTX-327 (Xpondr) Battery: Average 4A EFIS 1 ADI Fuel Pump Starter EDI 4000 (Eng Monitor) GMA-340 (Audio) SL-30 (Nav) SL-30 (Com-Rec) SL-30 (Com-Tx) EI #1 (P-Mag) EI #2 (P-Mag) Lights - Lnd "Lights - Flood/Cargo -.1 Cargo - .1 Panel- .5A Cockpit - .2" Main Battery Contactor Starter Contactor Clock The list for the Battery buss seems extensive but my thoughts were that if stuck on top IFR, these items are potentially needed. Yes, that assumes both main and SD-8 alternator went south. The question is, using an SD-8, can run over 8A on the buss? Is this a valid distribution of components? Some of these on the Batt buss are also used for start (EIS) or ground ops (lights, clock). The other question is can I split the power leads on the SL-30 without making the radio inop for receive- only? ________________________________________________________________________________
Subject: S700 2-10 Switches
Date: Oct 11, 2006
I am using Z13/8 for wiring my Cozy. At this stage I am installing one PMAG and one impulse Slick. As I intend to eventually run two PMAG's I am installing two S700 2-10 switches. After repeated efforts I still do not understand the connection on these switches at all. The question is, how do I wire the Slick to the 2-10 switch. I need to know which tabs the shield and core attach to. Thanks Chris Byrne SYDNEY ________________________________________________________________________________
Subject: Re: Question on Z-13 and E-Buss (Lengthy)
Date: Oct 11, 2006
Look more closely at the Z-13/8 schematic. Notice that the E-bus bypasses the battery contactor by running through the B-bus path. Therefore, the battery contactor draw is only on the M-bus. Next, most of the loads on your B-bus are more appropriate for the other busses. Your B-bus should most likely contain only the items you want hot at all times, IE: those items you always want on, even when not operating such as your clock, hobbs, dome light (In your case, the cockpit light) or an accessory plug. Remember the purpose of your E-bus: to provide an uneventful transition from normal operations to an endurance method to safely get you where you are going with the movement of 2 switches (turn off the master/battery and turn on the alternate feed). Once you arrive, you can turn the master/battery back on and use your other systems for approach and landing with a full battery to provide the extra load capacity. Here are some specific things to consider: The chance of both alternators failing the same bag of gas is very, very remote. You will probably be starting with both the M-bus and E-bus on; no real reason to start on just the B-bus that I know of, adding that capability clutters up your B-bus (remember, there is no way to turn off your B-bus other than disconnecting the battery. If you introduce a switch, then you really don't have a B-bus. The EIS-4000 may be on the E-bus and be on for start and during the endurance flight. Some folks say the engine info is not needed for endurance flight and they are probably correct. My view is that it is a GOOD thing to have in endurance mode IF YOU CAN AFFORD IT. Wire 1 DU, the AHARS and the magnetometer to the E-bus, make sure you have an on/off switch for the EFIS per GRT recommendations. The EIS-4000 doesn't need a switch. >From the B-bus: Move the fuel pump, starter, starter contactor, second com/nav, battery contactor, EFIS 1 ADI, GMA-340, landing light, flood/cargo lights to the M-bus. Leave the clock, cockpit lights and both mags on the B-bus (P-mags are optional here because they will generate internal power over approximately 700 rpm). Check the GMA-340 to see if it has a power off default to direct feed for #1 COM/NAV. I bet it does and therefore, no power to the audio panel is needed to operate #1 com/nav on the E-bus. Consider placing the A/P on the E-bus. If you are IFR, you'll want this for safety and peace of mind. You can have "normally-off" items on your E-bus with no penalty. I have a windscreen fan on mine. It only draws .45 amps and it is a transient load, not continuous so it doesn't add into my E-bus load. I'll turn it on for short periods if my glass fogs. You didn't provide your load analysis so I don't know how you calcuated the trim. I assume you understand the trims are transient loads and don't effect your E-bus load. I'm not a GNS-480 user but I believe they have com/nav/GPS/WAAS. Look over your load numbers and see if the extra load over and above that of just the SL-30 is worth the allocation. You may decide the SL-30 is enough. It meets the FAA requirements and is an extremely powerful device. I bet you will have a backup handheld GPS when you are IFR. You can easily wire your panel to allow you to plug the handheld into the EFIS and AP through an isolator switch. In this way, you save some of your load for other items and still have your GPS and com/nav. You will lose the WAAS enabled IFR GPS but you will have VOR/LOC/GS and the EFIS enhancements of your handheld GPS to include full capability of the AP. The GTX-327 should go on the M-bus. It is not required for safe continuance of flight. The FAA has transponder-inoperative procedures. Should you really need to ident, you can turn the M-bus on for a minute to make contact. The transponder takes 1.5 amps and is almost 20% of the output from the SD-8. Save that power for more important things such as the AP. Finally, you are not limited to a total of 8 amps on your B and E-busses. Your battery will make up for any deficiencies. Say your total endurance load is 9 amps, the SD-8 will provide 8 amps and the battery will make up the extra 1 amp. Even a poor battery should be able to provide 1 amp for a tank's worth of fuel; it did start your engine after all. If you notice some problems developing down the road, you can start to remove loads from the E-bus as the need arises. Remember, the E-bus is there to provide you a no-brainer, no-sweat method to safely and quickly reconfigure your electrical system to an endurance mode with the movement of 2 switches no thinking, no troubleshooting and no calculations. I don't know the answer about configuring the SL-30 to power only receive mode. I think it has 2 power feeds, 1 for com and 1 for nav. I don't make any assertions that my observations are complete or even accurate. Just provideing another perspective that might help you. I found this part of building to be very fun and informative. It's where the learning and operational planning merge. Your methods and results may vary. Jekyll Read this topic online here: http://forums.matronics.com/viewtopic.php?p=67159#67159 ________________________________________________________________________________
Subject: Two shunts on one amperometer
Date: Oct 12, 2006
Hi all, As I'm not decided where is the best place to connect the shunt of my amperometer, I was considering to use two shunts: one on the alternator output and the other checking all the electrical loads (except starter). The two shunts would go to the gauge through a a S700-2-3 ON-ON double pole switch. The advantage would be to be able to check alt output and, in case of alt failure, check the battery depletion rate. Any comment or criticism from the experts? Gianni Zuliani Tel/Fax +41 91 9710850 Mobile +41 79 3373439 Long-Ez >> Stag-Ez >> Stag-EzR http://www.comgz.com/tristar.htm ________________________________________________________________________________
Date: Oct 12, 2006
Subject: Re: Magneto Switches and Wiring
In a message dated 9/14/2006 6:14:29 AM Eastern Standard Time, SMITHBKN(at)aol.com writes: Listers, I've read Bob's book and searched the archives but still can't seem to find answers to confirm that my desired approach on magneto and starter wiring will work (or maybe there is a simpler way). I have two traditional magnetos for an IO-360. I would like to have a toggle switch for each mag, and a momentary toggle for the starter (with a toggle guard for added protection of inadvertent activation). I don't fully understand the "impulse" aspect of the magneto. Could someone help explain such and outline the correct wiring for this setup? Thanks, Jeff ================================== Jeff: Did you get a useful answer as yet? The idea of dual toggle switches (SPST) is PERFECTLY acceptable. The switch should be a good quality and physically robust just for S&G's I used a 15 Amp switch ... ONLY because of the solid feel the switch had in opening and closing and that it would function well with gloves on. Impulse coupling - In this regard there is a lot to say and understand - but, here is the short and simple response: 1 - If you have dual Mags usually in 99.9% of the cases the LEFT Mag is the impulse Mag. 2 - For a few extra bucks you can make BOTH mags impulse mags. It will require: Impulse Mag Impulse Mag drive gear Longer mounting studs (2) Adapter ring Ring gasket Seat gasket The advantage of dual impulse mags is more spark to start the engine and much less chance not being able to start when the pawl fails... Double your chances of starting. 3 - The Normal spinning of the prop is NOT fast enough to induce an electrical current into the Mag coil to produce a spark. 4 - The Normal timing of a Mag is 25 DBTDC and that is not at a proper point for the spark to fire and START the engine. 5 - The impulse Mag has a Pin and a Pawl. The Pawl catches on the pin (at LOW RPM's) and cocks back a spring. When the pawl is released two things happen: a> The Spring SNAPS the Mag's spinning Magnet at a much higher speed which induced a voltage into the Mag coil. More speed equals more spark. b> The delayed action of the snap also occurs at TDC which is a better timing location for the starting of the engine. 6 - Once the engine has started the centrifugal force of the higher spinning RPM throws the pawl to the outside and away from the pin so this disarm the impulse portion of the impulse Mag. I have dual impulse mags on my O-320. Only because I was stranded for 3 hours when the impulse Mag failed. OK, wiring ... Simple ... Mag Wiring - ON is OFF and OFF is ON. When the Mag switch is DOWN - ON ... YES ... ON. You are GROUNDING the 'P' Lead of the Mag and this sends the spark created by the Mag to ground and away from the spark plugs. When the Mag switch is UP - OFF ... YES ... OFF. The Ground is removed from the 'P' Lead and the Mag is HOT and ready to send a spark to the spark plugs. When you say "Toggle Guard" I guess you are referring to that fancy RED Plastic cover over the Starter Switch? Sure that is a good idea. BUT DON'T put them on the MAG switches ... Only on the Starter Switch. Hope this helped? Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Date: Oct 12, 2006
Subject: Re: Two shunts on one amperometer
> >Hi all, > >As I'm not decided where is the best place to connect the shunt of my >amperometer, I was considering to use two shunts: one on the >alternator output and the other checking all the electrical loads >(except starter). >The two shunts would go to the gauge through a a S700-2-3 ON-ON double pole >switch. >The advantage would be to be able to check alt output and, in case of alt >failure, check the battery depletion rate. >Any comment or criticism from the experts? Measuring the battery depletion rate for alternator-out operations by installing n ammeter suggests that you're not planning to control battery life by a combination of (1) choosing a battery capacity sufficient to operate KNOWN loads for what ever duration you choose as part of your design for alternator-out operations (Plan-B). (2) maintaining the battery with either periodic capacity tests or preventative maintenance by replacement so that conditions under Plan-B are satisfied. The point is that KNOWING battery loads "right now" is useless if you don't know what the battery's capacity is. Further, planning to do any kind of mathematical gymnastics in flight so as to pick-and-choose from electrical items you're not going to turn off is poor design . . . it distracts from your duties as pilot while you fuss with systems analysis under duress while in flight. The most useful instrument under battery-only operations is the voltmeter, not the ammeter . . . and then only to tell you whether your planning and maintenance efforts have paid off. If the battery drops below 11.0 volts sooner than you've predicted, then you know you've blown the design goal for achieving and maintaining a PREDICABLE level of performance under battery-only operations. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 12, 2006
>I m approaching the time where I need to spend some time on this board but >forgive the somewhat basic nature of the questions. > > >I m starting to work on installation of the Z-13 architecture in an RV-7, >IFR with dual GRT EFIS, and Garmin stack (SL-30/480/327), P800B audio >panel, and TT DigiFlight II AP. > > >I ve done the load analysis and have come up with the following ( do have >a full spreadsheet with each phase of flight listed against Normal Ops, >Main Alt Fail, and Battery only): > > >Main Buss: Total 26.5A > >Alt Field >Lights - Taxi >Lights - Nav >Lights - Strobe >Pitot Heat >Flap Motor >Auto Pilot - Pitch >Auto Pilot - Roll >Auto Pilot - Control Head > > >E-Buss: 6.4A > >Alt Field >EFIS 2 HIS >Magnatometer/ AHRS >Trim - Roll >Trim - Pitch >Turn Coordinator >GNS-480 (Nav) >GNS-480 (General) >GNS-480 (Com) >GTX-327 (Xpondr) >Battery: Average 4A >EFIS 1 ADI >Fuel Pump >Starter >EDI 4000 (Eng Monitor) >GMA-340 (Audio) >SL-30 (Nav) >SL-30 (Com-Rec) >SL-30 (Com-Tx) >EI #1 (P-Mag) >EI #2 (P-Mag) >Lights - Lnd >"Lights - Flood/Cargo -.1 > Cargo - .1 > Panel- .5A > Cockpit - .2" >Main Battery Contactor >Starter Contactor >Clock It's not clear from your narration that you've categorized this list of loads for modes of operation. Not all loads are on for all modes of operation. The battery bus has things on it that are (1) not necessary for keeping an engine running or (2) need to be operable on the ground with the rest of the airplane powered down. Suggest you use this form as a guide: http://www.aeroelectric.com/PPS/Load_Analysis/Blank_Form.pdf prepare one page for each of the three busses. Decide which load item will feed from which bus, what CONTINUOUS loads they present to the bus and under what conditions those loads would be present. > > >The list for the Battery buss seems extensive but my thoughts were that if >stuck on top IFR, these items are potentially needed. Yes, that assumes >both main and SD-8 alternator went south. The question is, using an SD-8, >can run over 8A on the buss? Is this a valid distribution of components? >Some of these on the Batt buss are also used for start (EIS) or ground ops >(lights, clock). The other question is can I split the power leads on the >SL-30 without making the radio inop for receive- only? Don't understand the "receive only" mode . . . if you don't punch the mic button, then you're in a receive only mode no matter how power is wired to the transceiver. All SL-30 loads would be supplied by the e-bus which needs to be pre-flighted anyhow by closing the e-bus alternate feed switch before closing the master contactor. Get your ATIS and Clearance before bringing the main bus up and starting the engine. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2006
Seems like extra work and expense for little gain Gianni. With a shunt on the alternator you can quickly become familiar with the current draw of various items. After an alternator failure it is very unlikely that you can manage the current draw for any specific battery life unless you have a brand new, tested, fully charged battery at room temperature, and have a second pilot to fly the plane while you fiddle with it. Just turn everything off that is not needed and revert to a previous plan that probably entails use of an E-bus. Ken L. Gianni Zuliani wrote: > >Hi all, > >As I'm not decided where is the best place to connect the shunt of my >amperometer, I was considering to use two shunts: one on the >alternator output and the other checking all the electrical loads >(except starter). >The two shunts would go to the gauge through a a S700-2-3 ON-ON double pole >switch. >The advantage would be to be able to check alt output and, in case of alt >failure, check the battery depletion rate. >Any comment or criticism from the experts? > >Gianni Zuliani >Tel/Fax +41 91 9710850 >Mobile +41 79 3373439 >Long-Ez >> Stag-Ez >> Stag-EzR >http://www.comgz.com/tristar.htm > > ________________________________________________________________________________
Date: Oct 12, 2006
Subject: Anti-rotation washer
What is a good source for tabbed anti-rotation washers? None of the toggle switches I bought had them. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Subject: SD-8 Self-Excitation Option
Date: Oct 12, 2006
I can't find the message now, but I believe I recall Bob saying that with the SD-8 self-excitation circuitry (Z-25), the SD 8 would be on all the time. If this is true (my knowledge of electronics is not sufficient to determine this for myself) it seems that, while innovative, this is not really useful. If one wants the SD-8 to always be on, the same battery that starts your engine could excite the SD-8 at the start of each flight. The only way self-excitation would be useful would be if you were out in the bush with a dead battery and had to hand-prop to start the engine. First, is it correct that with Z-25 the SD-8 would always be on? Second, I realize that the SD-8 is always spinning whenever the engine is turning, but is there any disadvantage to having it always on-line? Third, could Z-25 be altered to allow self-excitation only when needed? ________________________________________________________________________________
Date: Oct 12, 2006
Date: Oct 12, 2006
Subject: Re: Anti-rotation washer
B and C sells them.. Go here: http://www.bandc.biz/parts.html And enter "washer" into the search window. The first hit is the one I think you need.. Not sure if the diameter of the switches are all the same, however. Regards, Matt- > > > What is a good source for tabbed anti-rotation washers? None of the > toggle switches I bought had them. > > -- > ,|"|"|, Ernest Christley | > ----===<{{(oQo)}}>===---- Dyke Delta Builder | > o| d |o http://ernest.isa-geek.org | > > ________________________________________________________________________________
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Date: Oct 12, 2006
Ernest - I have bought those washers from both SteinAir and B&C. neal What is a good source for tabbed anti-rotation washers? None of the toggle switches I bought had them. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Oct 13, 2006
Date: Oct 12, 2006
Subject: Re: SD-8 Self-Excitation Option
>I can t find the message now, but I believe I recall Bob saying that with >the SD-8 self-excitation circuitry (Z-25), the SD 8 would be on all the >time. If this is true (my knowledge of electronics is not sufficient to >determine this for myself) it seems that, while innovative, this is not >really useful. If one wants the SD-8 to always be on, the same battery >that starts your engine could excite the SD-8 at the start of each >flight. The only way self-excitation would be useful would be if you were >out in the bush with a dead battery and had to hand-prop to start the engine. Yup, you got it. Generators of yore carried sufficient residual field magnetism to come on line without benefit of external power sources. Generators that have stood idle for a long time may loose this residual and require recharging of the field poles with a technique called "flashing". Alternators were seldom if ever designed to support any residual in the field so the vast majority of alternators in service require external startup energy to come alive. This can be an exceedingly small voltage . . . say between 0.2 and 1.0 volts of field voltage. However, given the very high speeds for rotating a typical alternator on Lycoming engines, some folks have reported that their modern alternators will come alive without benefit of external voltage applied. >First, is it correct that with Z-25 the SD-8 would always be on? The SD-8 is a PERMANENT MAGNET alternator . . . if it's spinning, it's producing voltage. So in this sense, it's always ON and there's nothing you can do to change that. Many SD-8 users have noted, however, that the REGULATOR supplied with the SD-8 will not come alive solely on voltage supplied from the alternator side of the system. Again, an exceedingly small voltage on the system side of the regulator (about .6 volts) to forward bias one of the critical solid state devices in the regulator would kick-start the regulator. The notion of being "always ON" or "ON-OFF under panel control" does not have the same meaning for the SD-8 system as for it's bigger generator/alternator cousins. However, given the special duty assigned to the SD-8 in a Z-13 installation, it's not an unreasonable design goal to have the system become useful whether or not there is a battery present. Earlier discussions about the quality of SD-8 power sans battery suggests that a "self-excitation" feature is useful. I've suggested that B&C pursue this as a product improvement but until that happens, Z-25 is the way to make it happen. >Second, I realize that the SD-8 is always spinning whenever the engine is >turning, but is there any disadvantage to having it always on-line? It's not "on line" until a connection exists between the regulator output and the bus. There are many systems in aircraft that operate similarly. A number of generator installations on turbine aircraft can be taken "off line" by opening the reverse current control contactor . . . the generator is still up and running, producing whatever voltage the regulator commands . . . but no utilization of that energy can be made until the contactor is closed. This is how the SD-8 operates under the Z-13 architecture. Know that if you pre-flight the SD-8, the first time you turn it on after the engine is started, it will come alive and remain alive as long as it's being turned by the engine. The only thing that the Z-25 mod gets you is a cold startup sans battery. > > >Third, could Z-25 be altered to allow self-excitation only when needed? Sure. Put the relay in series with the AC output from the alternator . . . but then a second set of contacts on the same relay would be used to keep a small amount of bias current from constantly loading the battery when the airplane is parked. You double the probability of relay failure while adding no operational value for having done so. Hence the configuration of Z-13 as you see it whether or not modified per Z-25. Bob . . . ________________________________________________________________________________
Date: Oct 12, 2006
Subject: Re: S700 2-10 Switches
> > I am using Z13/8 for wiring my Cozy. >At this stage I am installing one PMAG and one impulse Slick. >As I intend to eventually run two PMAG's I am installing two S700 2-10 >switches. After repeated efforts I still do not understand the connection on >these switches at all. > > The question is, how do I wire the Slick to the 2-10 switch. I need to know >which tabs the shield and core attach to. See: http://www.aeroelectric.com/PPS/Engine/Ignition/EMag-Magneto_Wiring_Options.pdf Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 13, 2006
Bob. Thanks very much. I note the date on the REV-A- was yesterday. Your efforts are very much appreciated. Chris Byrne SYDNEY ________________________________________________________________________________
Date: Oct 12, 2006
Hehe... That'd prolly be *today* in the US :)... At least the version I saw, had a 10/12/06 date, or for you down unders... A 06/10/12 date. Anyway, it's still the 12th in US land :)... Good luck and a very timely creation and response Bob! Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Byrne Sent: Thursday, October 12, 2006 6:05 PM Subject: Re: AeroElectric-List: S700 2-10 Switches --> Bob. Thanks very much. I note the date on the REV-A- was yesterday. Your efforts are very much appreciated. Chris Byrne SYDNEY ________________________________________________________________________________
Date: Oct 13, 2006
Matt Prather wrote: > >B and C sells them.. Go here: > >http://www.bandc.biz/parts.html > >And enter "washer" into the search window. The first hit is the one I >think you need.. Not sure if the diameter of the switches are all the >same, however. > > >Regards, > >Matt- > > > >> >> >>What is a good source for tabbed anti-rotation washers? None of the >>toggle switches I bought had them. >> >> > Thank you, Matt. I had looked on B&C's sight before, but couldn't find the washers listed seperately. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Oct 13, 2006
Subject: re: Thinking things Electric
From: Speedy11(at)aol.com Date: Tue, 10 Oct 2006 13:09:04 EDT Subject: AeroElectric-List: Re: Thinking things electic Sender: owner-aeroelectric-list-server(at)matronics.com X-Antivirus: AVG for E-mail 7.1.408 [268.13.2/471] I'm not sure if Dr. Dunham intended eclectic or electric in the subject line, but both would have been appropriate. I still am not convinced that we must all be so trained on electrics as to be able to derive all electrical answers from our base knowledge. Sometimes we don't need the huge foundation of knowledge. To use Dr. Dunham's example, my grandmother knew how to treat a sore throat (she completed the fourth grade), yet she had virtually no knowledge of medical techniques. Absolutely! There are no imperatives for the depth of knowledge to which one should aspire in setting the course for life beyond the minimum necessary for self-sufficiency. I'm not trying to put down Dr. Dunham, I'm just saying we don't always need to know everything in order to accomplish a relatively simple task. But, occasionally, we need confirmation from someone who has that knowledge. Yup, virtually all of us use the services of folks who specialize in certain talents and resources to support our occasional need. I never used a mechanic much 20 years ago but find it's not a good use of my time to do the things my mechanic does for me today. We need someone who will look at our electrical plans, and instead of saying study Z-99 and come back tomorrow, give us advice on how to best implement OUR desired plan. And many do DESIRE that service . . . I get dozens of packages in the mail and email every year from folks who may or may not have studied any of the Z-figures with the hope that I'll study his/her plan and suggest places where the bugs are hiding. In many cases, their understanding and skill of the language and syntax (symbols and drawings) are such that it would take a lot of hours to achieve a lucid understanding of the proposed system. After I do a load plan and draw my schematics I need someone trained (large knowledge base) in electrics to analyze my concept and help me find errors. Say I were to purchase a little successful grocery store, would it be wise to completely re-arrange the order of things in the room . . . or would it be a good idea to study and understand why things are placed where they are? Some large retailers spend gazillions of dollars in with human factors geeks studying the ways to optimize product flow off the shelves. A little mom-n-pop grocery store didn't have a big marketing budget, but perhaps they fiddled with changes and observed their effects over the years so that when I came along at their retirement, the business being offered had already benefited from optimization. EVERY time I begin a new design task, I've found it useful to study and understand the history of what's gone before. There are often times perfectly good wheels that do not need re-inventing . . . along with design features worthy of replacement because of poor diligence on the part of earlier designers and/or technology obsolescence. This is why the z-figures were crafted. The notion was that having selected an architecture for the operational and redundancy features, then all that remained was to specify appliances, wire sizes, fuse/breaker sizes and what style of switches were most attractive. Probability of intractable error is small. This is why my consistent suggestion to new builders is to "pick a z-figure that most closely matches what you believe your design goals to be . . . then let's talk about modifications fix any perceived shortfalls." More often than not, perceived shortfalls are not founded on simple-ideas or useful operational features and can be disregarded. The z-figures were never intended to be a collection of dreams pulled from where the sun don't shine. They've evolved over the years and have become rather stable today because "mom-n-pop have been making considered re-arrangements of cans on the shelves". Further decisions for changes are limited to what sizes of cans and perhaps what brands to stock. I am willing to pay for such advice and I suspect others are willing to do the same. In many cases, builders don't have the time or desire to learn it all. Quite correct. And there was a time when I thought it would be a nice adjunct to my business to offer custom wirebook services. I hung out the shingle and in a few months of minimal advertising, I had a backlog of work that I'd never dig out of. Problem was, the work was very much like that which many of my contemporaries are occupied with . . . pushing around large piles of paper. I can do it but it's the last thing I want to do in spite of the fact that it paid very well. STILL, Dr. Dunham makes me think. His is the best argument I've seen on this forum in favor of in-depth learning as opposed to adequate knowledge. I commend you for your thoughts. I think I'll rethink my own thoughts and try to implement some of your thoughts. How's that for eclectic? But, I am serious when I say that. I will strive to think more instead of depending on others to do my electrical thinking. Until I reach that level of learning (I may never reach it), any electrical experts out there willing to help me analyze my electrical? I don't go into McDonalds expecting to order a t-bone and I don't expect Subway to offer a cheesburger and fries. But I patronize either on occasion . . . with fully informed expectations of what is offered in exchange for my $time$. There are numerous folks here on the list who are most capable and willing to offer good critical review and advice. Scan your drawings and post them. I don't take up any tasks that come in through my mail-boxes but I will do tasks that come up in this forum . . . that is what's offered on the menu in this intellectual restaurant. I'll pay a 3 month electrical advice retainer such that I can call and send emails for advice. Bob? Save your money and instead invest the $time$ necessary to communicate your ideas to the group. You're swapping dollars expended to hire "expert" advice for $time$ to exploit the collective talents of those who choose to "dine" here. The end product (your airplane) will probably be better and your participation will leave a legacy of expanded understanding for those who participate and observe . . . to my mind a MUCH better return on investment. Bob . . . ________________________________________________________________________________
Date: Oct 13, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: 'Scope offer from Saelig
A few days ago I mentioned an oscilloscope being offered by Saelig at: http://saelig.com/ I just received the one I had on order. It's a rough clone of the Tektronix TDS200 series scopes. Only 25 Mhz but it's in color. Comes with two probes ($50 value alone). The USB cable and attending software lets you dump both image and tabular data to a computer. Here's the test setup on my bench. http://www.aeroelectric.com/Pictures/Tools/PDS5022S_OWON_Scope.jpg Once the data has been dumped to the computer it can be manipulated in a variety of ways including print to hard copy. Haven't had occasion to do any serious measurements but I can say that for $299, it's a hell-of-a-buy. I'm going to use it as my 'beater' scope to drag around for looking into problems on airplanes and save my Tek for less stressful bench work. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 13, 2006
I'm not sure that I'd want self excitation for my system. Also FWIW I now believe that the 20,000 uF capacitor on the output of the PM alternator regulator may be a really good idea. I omitted it because I hard wired the output to an 8AH battery (without a battery contactor) and figured that would suffice. There was no apparent electrical noise from the alternator. As mentioned recently though, I started the engine once with a completely dead battery. I closed the crossfeed contactor (Z-14 architecture) and observed the alternator charging. Upon opening the crossfeed contactor, the OVM module immediately tripped and cut power to the input of the regulator. I did that a couple of times. Problem was that the John Deere regulator was now failed in the full on mode. I surmise that the totally dead battery was ineffective at absorbing any current and keeping the voltage down and that the regulator fried itself during the few milliseconds that it took for the OVM to trip. The crossfeed autocloses during cranking and I had previously closed it with the engine running with no problems. Actually the system also ran fine with the failed VR and the crossfeed closed as long as system loads were kept above the 20 amp output of the PM alternator. I replaced the regulator but being hard headed I have not added a capacitor. I now know enough not to bring the alternator on line with a dead battery. However I did add some transorbs which might limit the voltage for the short period until the OVM trips if I should be silly enough to accidentally do somethng similar again. I didn't learn much from an autopsy on the VR other than it uses output semiconductors that appear to be fabricated on a copper plate instead of off the shelf devices. The circuit board used surface mount devices and I gave up on drawing a circuit diagram. I would like to find a reasonably simple circuit for a homemade replacement VR. I don't really have the time to properly test a completely new design. Ken L. Robert L. Nuckolls, III wrote: > > > >> I can t find the message now, but I believe I recall Bob saying that >> with the SD-8 self-excitation circuitry (Z-25), the SD 8 would be on >> all the time. If this is true (my knowledge of electronics is not >> sufficient to determine this for myself) it seems that, while >> innovative, this is not really useful. If one wants the SD-8 to >> always be on, the same battery that starts your engine could excite >> the SD-8 at the start of each flight. The only way self-excitation >> would be useful would be if you were out in the bush with a dead >> battery and had to hand-prop to start the engine. > > > Yup, you got it. Generators of yore carried sufficient > residual field magnetism to come on line without benefit > of external power sources. Generators that have stood > idle for a long time may loose this residual and require > recharging of the field poles with a technique called > "flashing". > > Alternators were seldom if ever designed to support > any residual in the field so the vast majority of alternators > in service require external startup energy to come alive. > This can be an exceedingly small voltage . . . say between > 0.2 and 1.0 volts of field voltage. However, given the > very high speeds for rotating a typical alternator on > Lycoming engines, some folks have reported that their > modern alternators will come alive without benefit of > external voltage applied. > > >> First, is it correct that with Z-25 the SD-8 would always be on? > > > The SD-8 is a PERMANENT MAGNET alternator . . . if > it's spinning, it's producing voltage. So in this sense, > it's always ON and there's nothing you can do to change that. > Many SD-8 users have noted, however, that the REGULATOR > supplied with the SD-8 will not come alive solely on > voltage supplied from the alternator side of the system. > Again, an exceedingly small voltage on the system side > of the regulator (about .6 volts) to forward bias one > of the critical solid state devices in the regulator > would kick-start the regulator. > > The notion of being "always ON" or "ON-OFF under > panel control" does not have the same meaning for the > SD-8 system as for it's bigger generator/alternator > cousins. However, given the special duty assigned to > the SD-8 in a Z-13 installation, it's not an unreasonable > design goal to have the system become useful whether or > not there is a battery present. > > Earlier discussions about the quality of SD-8 power > sans battery suggests that a "self-excitation" feature > is useful. I've suggested that B&C pursue this as a > product improvement but until that happens, Z-25 is > the way to make it happen. > > >> Second, I realize that the SD-8 is always spinning whenever the >> engine is turning, but is there any disadvantage to having it always >> on-line? > > > It's not "on line" until a connection exists between > the regulator output and the bus. There are many systems > in aircraft that operate similarly. A number of generator > installations on turbine aircraft can be taken "off line" > by opening the reverse current control contactor . . . the > generator is still up and running, producing whatever voltage > the regulator commands . . . but no utilization of that > energy can be made until the contactor is closed. This is > how the SD-8 operates under the Z-13 architecture. > > Know that if you pre-flight the SD-8, the first time you > turn it on after the engine is started, it will come alive > and remain alive as long as it's being turned by the engine. > The only thing that the Z-25 mod gets you is a cold startup > sans battery. > >> >> >> Third, could Z-25 be altered to allow self-excitation only when needed? > > > Sure. Put the relay in series with the AC output from > the alternator . . . but then a second set of contacts > on the same relay would be used to keep a small amount > of bias current from constantly loading the battery when > the airplane is parked. You double the probability of > relay failure while adding no operational value for > having done so. Hence the configuration of Z-13 as you > see it whether or not modified per Z-25. > > Bob . . . ________________________________________________________________________________
Date: Oct 13, 2006
> >I'm not sure that I'd want self excitation for my system. What's the down-side for having it? >Also FWIW I now believe that the 20,000 uF capacitor on the output of the >PM alternator regulator may be a really good idea. The value of this capacitor is to enable operations of the SD-8 sans battery . . . but if you don't have a battery -or- the capacitor -or- self excitation feature, then the SD-8 is at risk to being "stalled" if inadvertently overloaded during alternator-only ops. >I omitted it because I hard wired the output to an 8AH battery >(without a battery contactor) and figured that would suffice. I think the SD-8 regulator has places a small load (milliamps) on any power source that is not disconnected during power down. >There was no apparent electrical noise from the alternator. As mentioned >recently though, I started the engine once with a completely dead battery. >I closed the crossfeed contactor (Z-14 architecture) and observed the >alternator charging. Upon opening the crossfeed contactor, the OVM module >immediately tripped and cut power to the input of the regulator. I did >that a couple of times. > >Problem was that the John Deere regulator was now failed in the full on >mode. I surmise that the totally dead battery was ineffective at absorbing >any current and keeping the voltage down and that the regulator fried >itself during the few milliseconds that it took for the OVM to trip. The >crossfeed autocloses during cranking and I had previously closed it with >the engine running with no problems. Actually the system also ran fine >with the failed VR and the crossfeed closed as long as system loads were >kept above the 20 amp output of the PM alternator. > >I replaced the regulator but being hard headed I have not added a >capacitor. I now know enough not to bring the alternator on line with a >dead battery. However I did add some transorbs which might limit the >voltage for the short period until the OVM trips if I should be silly >enough to accidentally do somethng similar again. Contrary to the fondest wishes of several past participants, the lowly Transorb is not suited for soaking up the overflow from a runaway alternator . . . and without carefully crafted source impedance control, they're not suited for corralling a load-dump event either. I've had great success using them to stand off indirect effects of lightning . . . but energies in normal and abnormal events from engine driven power sources are just not something we can reasonably expect a Transorb to handle. >I didn't learn much from an autopsy on the VR other than it uses output >semiconductors that appear to be fabricated on a copper plate instead of >off the shelf devices. The circuit board used surface mount devices and I >gave up on drawing a circuit diagram. I would like to find a reasonably >simple circuit for a homemade replacement VR. I don't really have the time >to properly test a completely new design. Here's a schematic that is quite common to all PM alternator regulators. http://www.aeroelectric.com/Pictures/Schematics/PM_Regulator/Kubota_Schematic.jpg This design looks like it's free of power-down leakage. As long as the Q4eb, Z1, D6 pathway is out of conduction, it doesn't appear that anything would be turned on. There are no voltage dividers across the battery lead either. Bob . . . ________________________________________________________________________________
Subject: another dark and stormy night story
Date: Oct 13, 2006
http://www.aopa.org/pilot/never_again/2006/na0610.html Once again they're talking about how dangerous it is when the lights go out, but there's no mention of why they did or how to keep it from happening. Pax, Ed Holyoke ________________________________________________________________________________
Date: Oct 13, 2006
> > snip >> There was no apparent electrical noise from the alternator. As >> mentioned recently though, I started the engine once with a >> completely dead battery. I closed the crossfeed contactor (Z-14 >> architecture) and observed the alternator charging. Upon opening the >> crossfeed contactor, the OVM module immediately tripped and cut power >> to the input of the regulator. I did that a couple of times. >> >> Problem was that the John Deere regulator was now failed in the full >> on mode. I surmise that the totally dead battery was ineffective at >> absorbing any current and keeping the voltage down and that the >> regulator fried itself during the few milliseconds that it took for >> the OVM to trip. The crossfeed autocloses during cranking and I had >> previously closed it with the engine running with no problems. >> Actually the system also ran fine with the failed VR and the >> crossfeed closed as long as system loads were kept above the 20 amp >> output of the PM alternator. >> >> I replaced the regulator but being hard headed I have not added a >> capacitor. I now know enough not to bring the alternator on line >> with a dead battery. However I did add some transorbs which might >> limit the voltage for the short period until the OVM trips if I >> should be silly enough to accidentally do somethng similar again. > > > Contrary to the fondest wishes of several past participants, > the lowly Transorb is not suited for soaking up the overflow > from a runaway alternator . . . and without carefully crafted > source impedance control, they're not suited for corralling > a load-dump event either. I've had great success using them > to stand off indirect effects of lightning . . . but energies > in normal and abnormal events from engine driven power sources > are just not something we can reasonably expect a Transorb > to handle. > Understood. But transorbs might have kept the voltage reasonble for the few milliseconds that it took for the OVM to trip as mentioned in the top paragraph. The dead battery did not limit the voltage or the OVM would not have tripped. A large capacitor might have helped a bit. I think transorbs might help in this situation. The J.D. regulator goes for $100. in my neighborhood. > snip > > Here's a schematic that is quite common to > all PM alternator regulators. > > http://www.aeroelectric.com/Pictures/Schematics/PM_Regulator/Kubota_Schematic.jpg > > > This design looks like it's free of power-down leakage. > As long as the Q4eb, Z1, D6 pathway is out of conduction, > it doesn't appear that anything would be turned on. There > are no voltage dividers across the battery lead either. > > Bob . . . Gee if they had only put component values on that schematic ;) Ken L. ________________________________________________________________________________
Subject: charging system problems
Date: Oct 13, 2006
I am still trying to figure out the glitch in my charging system. I wrote about this a couple of weeks ago, I am new to this group, haven't figured out how to include all the past discussion without retyping it all over again. I beg your patience. To rehash the problem. Everything seems to work fine until five or so minuites into the flight when the system begins to discharge. I can reset the system by recycling the field breaker and everything goes back to normal, for another few minutes. After I recycle the system the second time, I can continue the rest of the flight with no problems. The bus voltage is a constant 14.5 volts. I am using a Van's 35 amp alt, VR-371 regulator, Electronics Int. VA-1 guage installed in the alt. lead. This is a "Bearhawk" aircraft. (tubing fuselage, metal wings) I didn't discover this group until I had already wired the plane so I know I have done some things that I would do differently if I had it to do over again. My battery (Odyssey 680) is grounded to the engine mount. Engine is grounded to the mount via a bolt on the oil sump. I know, I know... there is a better way, just that I copied what I saw on numerous other planes. My wiring diagram is one that I borrowed from one of Tony Bengelis' books. Still hoping someone out there can shed some light on this.. Collin ________________________________________________________________________________
Subject: rv10 antennas
Date: Oct 13, 2006
Good evening folks, Hugo with an RV10 ,actually 1300 punds of aluminum wich soon or later will be an rv10, Question I install a VOR-glideslope antenna at the top of the rudder,the cable finish at the mid section ,I suppose I need a diplexer in order to use both features,the cable split at mid fuse ,asking,will be OK ,in your opinion connect with male -female at the mid section an install the splitter under the panel,or use the juncion there to instal the diplexer,I wonder if will be any kind of lose in the reception. thanks for the help. Hugo ________________________________________________________________________________
Date: Oct 13, 2006
Subject: Re: charging system problems
Hello Collin, I am not clear how you know that the system is "discharging".. If the bus voltage is solid at 14.5V, then the alternator is regulating, and keeping up with system demands. Or, what's the bus voltage during the discharge? If you go to the archive search engine: http://www.matronics.com/searching/ws_script.cgi And enter "Collin", you can see everything you have posted to the Aeroelectric list (be sure to select that Archive as the thing to search).. Regards, Matt- > I am still trying to figure out the glitch in my charging system. I wrote > about this a couple of weeks ago, I am new to this group, haven't figured > out how to include all the past discussion without retyping it all over > again. I beg your patience. > > To rehash the problem. Everything seems to work fine until five or so > minuites into the flight when the system begins to discharge. I can reset > the system by recycling the field breaker and everything goes back to > normal, for another few minutes. After I recycle the system the second > time, I can continue the rest of the flight with no problems. The bus > voltage is a constant 14.5 volts. I am using a Van's 35 amp alt, VR-371 > regulator, Electronics Int. VA-1 guage installed in the alt. lead. This > is a "Bearhawk" aircraft. (tubing fuselage, metal wings) I didn't > discover this group until I had already wired the plane so I know I have > done some things that I would do differently if I had it to do over again. > My battery (Odyssey 680) is grounded to the engine mount. Engine is > grounded to the mount via a bolt on the oil sump. I know, I know... there > is a better way, just that I copied what I saw on numerous other planes. > My wiring diagram is one that I borrowed from one of Tony Bengelis' books. > > Still hoping someone out there can shed some light on this.. > > Collin ________________________________________________________________________________
Date: Oct 13, 2006
Matt, Ok, I forgot to mention that the discharge light comes on. The amp reading goes to "0" and the voltage drops to 12.8 (a fully charged battery) Thanks for the reply Collin ----- Original Message ----- From: "Matt Prather" <mprather(at)spro.net> Sent: Friday, October 13, 2006 7:53 PM Subject: Re: AeroElectric-List: charging system problems > > > Hello Collin, > > I am not clear how you know that the system is "discharging".. If the bus > voltage is solid at 14.5V, then the alternator is regulating, and keeping > up with system demands. Or, what's the bus voltage during the discharge? > > If you go to the archive search engine: > > http://www.matronics.com/searching/ws_script.cgi > > And enter "Collin", you can see everything you have posted to the > Aeroelectric list (be sure to select that Archive as the thing to > search).. > > > Regards, > > Matt- > >> I am still trying to figure out the glitch in my charging system. I >> wrote >> about this a couple of weeks ago, I am new to this group, haven't figured >> out how to include all the past discussion without retyping it all over >> again. I beg your patience. >> >> To rehash the problem. Everything seems to work fine until five or so >> minuites into the flight when the system begins to discharge. I can >> reset >> the system by recycling the field breaker and everything goes back to >> normal, for another few minutes. After I recycle the system the second >> time, I can continue the rest of the flight with no problems. The bus >> voltage is a constant 14.5 volts. I am using a Van's 35 amp alt, VR-371 >> regulator, Electronics Int. VA-1 guage installed in the alt. lead. This >> is a "Bearhawk" aircraft. (tubing fuselage, metal wings) I didn't >> discover this group until I had already wired the plane so I know I have >> done some things that I would do differently if I had it to do over >> again. >> My battery (Odyssey 680) is grounded to the engine mount. Engine is >> grounded to the mount via a bolt on the oil sump. I know, I know... >> there >> is a better way, just that I copied what I saw on numerous other planes. >> My wiring diagram is one that I borrowed from one of Tony Bengelis' >> books. >> >> Still hoping someone out there can shed some light on this.. >> >> Collin > > > ________________________________________________________________________________
From: "Richard Garforth" <richard(at)hawk.flyer.co.uk>
Subject: RV10 VOR/GS Antenna
Date: Oct 14, 2006
Hugo, I found that the standard Commant antenna will not fit on the fin. The rudder movement is too great and hits the dipoles. Several RV10s I saw at Osh had them fitted to the bottom rear fuselage. Some GA a/craft have them fitted on the fin 'back to front' to provide clearance. Normal practice is to position the diplexer with the Nav equipment. Richard ________________________________________________________________________________
Date: Oct 14, 2006
>> >> Here's a schematic that is quite common to >> all PM alternator regulators. >> >>http://www.aeroelectric.com/Pictures/Schematics/PM_Regulator/Kubota_Schematic.jpg >> >> >> This design looks like it's free of power-down leakage. >> As long as the Q4eb, Z1, D6 pathway is out of conduction, >> it doesn't appear that anything would be turned on. There >> are no voltage dividers across the battery lead either. >> >> Bob . . . > >Gee if they had only put component values on that schematic ;) >Ken L. This circuit is not one that would benefit much from gain and bias optimization. I'll bet if you used 2N3906 for all transistors, 1K for all resistors, 1N5243 for zener, and 1N400x for small diodes, it would come up and run just fine. There are a variety of options for SCR's and power diodes in the rectifier. SCR's should be selected to trigger on less than 10ma else value of R3 needs reduction accordingly. Bob . . . ________________________________________________________________________________
Date: Oct 14, 2006
Subject: Re: rv10 antennas
> >Good evening folks, >Hugo with an RV10 ,actually 1300 punds of aluminum wich soon or later will >be an rv10, >Question I install a VOR-glideslope antenna at the top of the rudder,the >cable finish at the mid section ,I suppose I need a diplexer in order to >use both features,the cable split at mid fuse ,asking,will be OK ,in your >opinion connect with male -female at the mid section an install the >splitter under the panel,or use the juncion there to instal the >diplexer,I wonder if will be any kind of lose in the reception. >thanks for the help. Passive antenna splitters or diplexers are not something for nothing devices. For every pico-watt of energy entering one port, the sum of energies leaving the other ports is less than a pico-watt. Yes, there are losses in these devices but few GA users would find them to be objectionable or even observable without aid from pretty sophisticated test equipment. We use them in the biz jets a lot. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: Ground Wire for Starter Contactor?
Date: Oct 14, 2006
Hi List, I followed the Z-11 diagram for my simple system & see that the starter contactor has a 'firewall ground'. To me, that means it grounds through the stainless steel firewall it is mounted on. Indeed, that is what my ohmeter says & I'm confident it will perform fine (As I'm not flying yet & haven't quite fired up the engine yet, I haven't actually seen the contactor work) However, this seems to conflict with the single point ground idea basic to Bob's philosophy. My starter contactor is the only component of my system without a dedicated wire running to the forest of ground tabs. Any experienced advice or opinions on this? I've been absent the list for a long time & couldn't find anything on this in the archives. Hope you haven't already gone over it a hundred times. Thanks, Grant ________________________________________________________________________________
Date: Oct 14, 2006
> > >Matt, > >Ok, I forgot to mention that the discharge light comes on. The amp >reading goes to "0" and the voltage drops to 12.8 (a fully charged battery) > >Thanks for the reply > >Collin Given that the alternator in question is externally regulatred, the system lends itself to rudimentary trouble shooting techniques. I believe I referred you to Note 8 on page Z-8 of http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf as a guide for chasing out the bugs. It would be useful to know what field voltage the alternator is seeing during a failure. This means that you need to bring a wire into the cockpit from the alternator's field terminal and watch it with a voltmeter so you can observe and report the readings during normal and failed operations. Bob . . . ________________________________________________________________________________
Date: Oct 14, 2006
Subject: Re: another dark and stormy night story
> >http://www.aopa.org/pilot/never_again/2006/na0610.html > >Once again they're talking about how dangerous it is when the lights go >out, but there's no mention of why they did or how to keep it from >happening. > >Pax, > >Ed Holyoke It's sad that flagship publications like AOPA Pilot, Sport Aviation, etc. are so disconnected from the real mission (journalism and teaching) that so little of what they publish is truly useful. It's even sadder that folks who read the articles believe they're getting the best-we-know-how-to-do advice simply because of the publication's prestige. Bob . . . ________________________________________________________________________________
Subject: anti-rotation washer
Date: Oct 14, 2006
Beats the devil outta me, Sarge. (a) The search button is `way at the bottom, after scanning a bunch of lines (b) When poked, filled with WASHERS, it revealed 17 items, most of which had no washers except if one is to read each one in order and search by eyeball for an applicable WASHER, (c) Thass when I gave up. Fetch me the dictionary. Ferg Kyle Europa A064 914 Classic ________________________________________________________________________________
Date: Oct 14, 2006
Subject: Re: Ground Wire for Starter Contactor?
> >Hi List, > >I followed the Z-11 diagram for my simple system & see that the starter >contactor has a 'firewall ground'. To me, that means it grounds through >the stainless steel firewall it is mounted on. Indeed, that is what my >ohmeter says & I'm confident it will perform fine (As I'm not flying yet & >haven't quite fired up the engine yet, I haven't actually seen the >contactor work) >However, this seems to conflict with the single point ground idea basic to >Bob's philosophy. My starter contactor is the only component of my system >without a dedicated wire running to the forest of ground tabs. > >Any experienced advice or opinions on this? > >I've been absent the list for a long time & couldn't find anything on this >in the archives. Hope you haven't already gone over it a hundred times. The commonly utilized automotive starter contactors do get a ground for the coil through the base provided that the firewall sheet is metallic and your system has a firewall ground stud and forest-of-tabs for other systems. This is fine as installed. The contactor is VERY intermittent duty and is neither a potential victim nor potential antagonist for ground-loop coupled noises. I guess I should add "starter contactors" to the list of items that integrate nicely into airplanes using LOCAL grounds. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 14, 2006
> > >> The commonly utilized automotive starter contactors >> do get a ground for the coil through the base provided >> that the firewall sheet is metallic and your system >> has a firewall ground stud and forest-of-tabs for >> other systems. > >Sorry I may have missed it, but did we ever get to the bottom of why the >"newer" B&C battery contactors have rubber boots on the mounting tabs? If >we have that model, should we remove the boots, or otherwise ground the >contactor? Never did see any documents or conversation that explained why the boots were added and/or considered a good thing to do under any circumstances. I'm thinking we're on firm ground to recommend removal for installation under the prevailing philosophy. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 14, 2006
Subject: Re: anti-rotation washer
> >Beats the devil outta me, Sarge. >(a) The search button is `way at the bottom, after scanning a bunch of lines >(b) When poked, filled with WASHERS, it revealed 17 items, most of which >had no washers except if one is to read each one in order and search by >eyeball for an applicable WASHER, >(c) Thass when I gave up. >Fetch me the dictionary. >Ferg Kyle >Europa A064 914 Classic I presume you're looking for keyway washers for the standard toggle switch. B&C has them listed in their "all parts" order form at: http://www.bandc.biz/cgi-bin/ez-order/order?X358218 Do a an EDIT_Find-in-this-Page search for S700KW and it will jump to the line item where you can enter a quantity in their shopping cart utility. This is a good page to access for B&C. I believe it's a single url that lists every line item available for sale irrespective of where it appears in the catalog pages. Bob . . . ________________________________________________________________________________
Subject: need AOL Communicator
Date: Oct 14, 2006
Just had to replace a dead hard disk, and lost the AOL Communicator software that allowed me to automatically sort AeroElectric email digests into the AeroElectric folder. AOL no longer lists it as a download. Anyone have a copy of the software they could send me? Philwhite9(at)aol.com (Mazda 20B in an RV-10) ________________________________________________________________________ ________________________________________________________________________________
Date: Oct 14, 2006
Ed They didn't mention it because they probably didn't know what to say. Lots of unexplained things happened in the "old days" because things just weren't understood. Trouble is there are too many 20-50 year old airplanes still flying today in the face of newer technologies. Makes me think of all the old patched up cars in Cuba when they could have much newer models. One of the main reasons I am building my own is because I want something better than 1950' technology without the unreasonably high cost of a certified aircraft with modern technology (if one even exists). Voltmeters, ammeters, E-buss, Engine monitors with alarms etc and knowing how to use them makes OBAM aircraft much better in my opinion. Having the right equipment (technology) and knowing how to use it is better than just "noticing" that the panel lights "seem" a little dim. I know simpler is better when all other things are considered equal, but for me, a more "complex" machine is more "capable". I will learn the systems. Bevan RV7A starting canopy today (wish me luck). -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Holyoke Sent: Friday, October 13, 2006 10:18 AM Subject: AeroElectric-List: another dark and stormy night story --> http://www.aopa.org/pilot/never_again/2006/na0610.html Once again they're talking about how dangerous it is when the lights go out, but there's no mention of why they did or how to keep it from happening. Pax, Ed Holyoke ________________________________________________________________________________
Date: Oct 14, 2006
Or use an Archer wing-tip antenna (from Steinair & else where). Minimize the number of connectors for best performance. Pete -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of gommone7(at)bellsouth.net Sent: Friday, October 13, 2006 6:52 PM Subject: AeroElectric-List: rv10 antennas Good evening folks, Hugo with an RV10 ,actually 1300 punds of aluminum wich soon or later will be an rv10, Question I install a VOR-glideslope antenna at the top of the rudder,the cable finish at the mid section ,I suppose I need a diplexer in order to use both features,the cable split at mid fuse ,asking,will be OK ,in your opinion connect with male -female at the mid section an install the splitter under the panel,or use the juncion there to instal the diplexer,I wonder if will be any kind of lose in the reception. thanks for the help. Hugo ________________________________________________________________________________
Date: Oct 14, 2006
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Saturday, October 14, 2006 11:40 AM Subject: Re: AeroElectric-List: Ground Wire for Starter Contactor? - > >Sorry I may have missed it, but did we ever get to the bottom of why the >"newer" B&C battery contactors have rubber boots on the mounting tabs? If >we have that model, should we remove the boots, or otherwise ground the >contactor? Never did see any documents or conversation that explained why the boots were added and/or considered a good thing to do under any circumstances. I'm thinking we're on firm ground to recommend removal for installation under the prevailing philosophy. Bob . . . I tried to get the "boots" off and gave up. I think they are oin to stay. Any good ideas as to how to remove them? --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Oct 14, 2006
Subject: Re: AeroElectric-List Digest: 38 Msgs - 10/02/06
I've just seen the Garmin GXM 30 "smart antenna" for the first time. Apparently it supports XM radio and XM weather on "compatible" Garmin GPS systems (396 and 496, for example). Does anyone know if it is compatible with any of the other systems out there such as AnywhereMap or Vista or similar? The WxWorx receiver is several times more than the GXM 30. Was wondering if it is a suitable substitute?? Regards, Lee... ________________________________________________________________________________
Date: Oct 14, 2006
> > Never did see any documents or conversation that > explained why the boots were added and/or considered > a good thing to do under any circumstances. I'm > thinking we're on firm ground to recommend removal > for installation under the prevailing philosophy. > > Bob . . . > > > I tried to get the "boots" off and gave up. I think they are oin to >stay. Any good ideas as to how to remove them? Hmmmm . . . I guess I've never seen them either. Got a digital camera? Send me some pictures. I note that B&C is still using the pictures I took. Bob . . . ________________________________________________________________________________
Date: Oct 14, 2006
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Saturday, October 14, 2006 8:13 PM Subject: RE: AeroElectric-List: Ground Wire for Starter Contactor? > > Never did see any documents or conversation that > explained why the boots were added and/or considered > a good thing to do under any circumstances. I'm > thinking we're on firm ground to recommend removal > for installation under the prevailing philosophy. > > Bob . . . > > > I tried to get the "boots" off and gave up. I think they are oin to >stay. Any good ideas as to how to remove them? Hmmmm . . . I guess I've never seen them either. Got a digital camera? Send me some pictures. I note that B&C is still using the pictures I took. Bob . . . Will try to take some tomorrow. The contactor is mounted and I am not sure that I can get a good enough shot to show any thing about the boot attachment. They appear to be molded on and I think the legs were drilled to allow the molding to form pass a through to hold them on. ________________________________________________________________________________
Date: Oct 15, 2006
Subject: Sparky's misadventures conclude
Thanks to 'lectric Bob's (and others' on the list!) help, the non functioning master contactor problem has been solved! Turns out that Mr. Cliplead revealed that when sparks flew, the jumper from the BAT terminal to the little fourth terminal on the B&C contactor had burned through, which wouldn't let electrons activate the little solenoid inside the contactor. Installing a new jumper solved the problem! Lesson learned...install those little rubber boots on ALL exposed "hot" terminals! As a side note, what precipitated the problem was "weak" com radios. In an attempt to fix that, the connections for the com antenna ground plane were checked, leading to the sparks when the antenna connector flopped over onto the master contactor. Turns out THAT problem was caused by a malfunctioning relay that regulated the access from the two com radios to a single com antenna. Both com radios had to go back for repair. When one radio transmits directly into another through a common antenna, bad things happen. Another lesson learned...yeah it is nice to try to minimize the number of external antennae on a metal airplane for esthetic and drag reasons. But the entire point of having redundant radios to back each other up is lost when a single point failure of the necessary relay connection between the two radios and the single antenna can knock out all communications! So THAT is why Sparky's Evo will be sporting TWO com antennae on the belly now! Paul Siegel ________________________________________________________________________________
Date: Oct 15, 2006
Subject: Re: Question on Z-13 and E-Buss (Lengthy)
One thing I find useful when you get bogged down in M-bus vs E-bus vs B-bus divisions is to go flying and start turning off everything electrical. Eventually you realize just how little you really need to have, unless you're in IMC with ice. For instance, the turn coordinator is sometimes presumed to be important, but in VFR, it's just not needed at all, so it doesn't have to be sitting there on the e-bus drawing all that current. Also, remember in the event of an off-field emergency landing, you want to be able to shut off your fuel pump and some other things you've currently got wired to your battery. Dave Morris At 11:27 PM 10/10/2006, you wrote: >I'm approaching the time where I need to spend some time on this >board but forgive the somewhat basic nature of the questions. > >I'm starting to work on installation of the Z-13 architecture in an >RV-7, IFR with dual GRT EFIS, and Garmin stack (SL-30/480/327), >P800B audio panel, and TT DigiFlight II AP. > >I've done the load analysis and have come up with the following ( do >have a full spreadsheet with each phase of flight listed against >Normal Ops, Main Alt Fail, and Battery only): ... snip ... > >Battery: Average 4A > >EFIS 1 ADI >Fuel Pump >Starter >EDI 4000 (Eng Monitor) >GMA-340 (Audio) >SL-30 (Nav) >SL-30 (Com-Rec) >SL-30 (Com-Tx) >EI #1 (P-Mag) >EI #2 (P-Mag) >Lights - Lnd >"Lights - Flood/Cargo -.1 > Cargo - .1 > Panel- .5A > Cockpit - .2" >Main Battery Contactor >Starter Contactor >Clock > >The list for the Battery buss seems extensive but my thoughts were >that if stuck on top IFR, these items are potentially needed. Yes, >that assumes both main and SD-8 alternator went south. The question >is, using an SD-8, can run over 8A on the buss? Is this a valid >distribution of components? Some of these on the Batt buss are also >used for start (EIS) or ground ops (lights, clock). The other >question is can I split the power leads on the SL-30 without making >the radio inop for receive- only? > ________________________________________________________________________________
Date: Oct 15, 2006
> > > > > I tried to get the "boots" off and gave up. I think they are oin to > >stay. Any good ideas as to how to remove them? > > Hmmmm . . . I guess I've never seen them either. Got > a digital camera? Send me some pictures. I note that > B&C is still using the pictures I took. > > Bob . . . > >Will try to take some tomorrow. The contactor is mounted and I am not sure >that I can get a good enough shot to show any thing about the boot >attachment. They appear to be molded on and I think the legs were drilled >to allow the molding to form pass a through to hold them on. Did you get it from B&C? I'll call them tomorrow and see if they'll send me a sample. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2006
10/15/2006 Responding to an AeroElectric-List message posted by: "Tinne maha" Hello Grant, Back when I was building my airplane with a stainless steel firewall I had occasion to do some electical circuit checking with a multi meter. I was getting some erratic results and eventually came to the conclusion that there was some sort of self created insulating surface film on the stainless steel surface. I could get good consistent meter readings only by specifically piercing that film with the sharp point of the meter probe. This led me to the conclusion that just bolting my starter contactor to the firewall may not give me the best electrical grounding connection. My starter contactor case is grounded to the brass firewall forrest-of-tabs through-bolt. Works great. Maybe some electrical guru on this list can verify or dispute my findings. OC -- The best investment we will ever make is in gathering knowledge _____________________________________ AeroElectric-List message posted by: "Tinne maha" Hi List, I followed the Z-11 diagram for my simple system & see that the starter contactor has a 'firewall ground'. To me, that means it grounds through the stainless steel firewall it is mounted on. Indeed, that is what my ohmeter says & I'm confident it will perform fine (As I'm not flying yet & haven't quite fired up the engine yet, I haven't actually seen the contactor work) However, this seems to conflict with the single point ground idea basic to Bob's philosophy. My starter contactor is the only component of my system without a dedicated wire running to the forest of ground tabs. Any experienced advice or opinions on this? I've been absent the list for a long time & couldn't find anything on this in the archives. Hope you haven't already gone over it a hundred times. Thanks, Grant ________________________________________________________________________________
Date: Oct 15, 2006
Subject: Re: short course on bus loading (was Q on Z-13 and
E-Bus) > >One thing I find useful when you get bogged down in M-bus vs E-bus vs >B-bus divisions is to go flying and start turning off everything >electrical. Eventually you realize just how little you really need to >have, unless you're in IMC with ice. For instance, the turn coordinator >is sometimes presumed to be important, but in VFR, it's just not needed at >all, so it doesn't have to be sitting there on the e-bus drawing all that >current. > >Also, remember in the event of an off-field emergency landing, you want to >be able to shut off your fuel pump and some other things you've currently >got wired to your battery. > >Dave Morris > >At 11:27 PM 10/10/2006, you wrote: >>I'm approaching the time where I need to spend some time on this board >>but forgive the somewhat basic nature of the questions. >> >>I'm starting to work on installation of the Z-13 architecture in an RV-7, >>IFR with dual GRT EFIS, and Garmin stack (SL-30/480/327), P800B audio >>panel, and TT DigiFlight II AP. >> >>I've done the load analysis and have come up with the following ( do have >>a full spreadsheet with each phase of flight listed against Normal Ops, >>Main Alt Fail, and Battery only): Start out supposing that you're going to put ALL the electro- whizzies planned for your project into a nice ol' restored but original architecture C-170. The Main bus is all you got. Figure out if you have sized the alternator to carry the loads under various flight conditions and still have 15A or so headroom for battery recharging. If you're going to have a plain-vanilla, Z-11 or an SD-8 enhanced Z-13, you figure out what gizmos are useful for the en route mode of flight, i.e. ENDURANCE MODE. Add up CONTINUOUS loads on these devices and then see if you have sized the battery for ALT OUT ENDURANCE with NO ASSIST for the design goals you've established. Keep in mind that: (1) battery capacity is NOT a linear function of load vs rated capacity. The apparent capacity falls as loads increase primarily due to internal resistance of the battery. (2) the BEST way to assess battery capacity to a design goal is to CapCheck it under the en route load determined above. (3) if you're a Z-11 system, the what's in the battery is all you have. Leave 25% or more of your real capacity for approach to landing. Knowing the required real capacity under Plan-B operations is how you size your battery selection. (4) if you're a Z-13 system, then the e-bus can be loaded to the full capacity of the SD-8 while holding 100% of the battery's stored energy in reserve for approach to landing. E-bus means ENDURANCE-bus . . . its design goal is to prevent an emergency by encouraging well crafted Plan-B and preventative maintenance programs for the properly sized battery. Battery-Bus loads fall in two classes: (1) things necessary to keep an electrically dependent engine running. When you have bad smells in the cockpit, it's useful to be able to turn EVERYTHING off and not have the engine quit. Don't forget to consider Battery Bus loads in the endurance modeling described above. (2) things useful on the ground during loading, unloading and storage support. Clocks, utility lighting, battery maintenance, etc. Every item not needed for alternator-out endurance ops for 99% of your planned flight regimes goes on the Main-Bus. Yes, if you find yourself in bad weather and the main alternator craps, you do have an emergency. That's Plan-C . . . get on the ground and or out of IMC ASAP. Plan-B numbers are irrelevant. Keep in mind that you can always bring the main bus back up and run anything in the airplane . . . but now you have an emergency and Plan-C is in effect. Rethink your distribution of loads based on this philosophy and see what it looks like. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2006
> >10/15/2006 > >Responding to an AeroElectric-List message posted by: "Tinne maha" > > >Hello Grant, Back when I was building my airplane with a stainless steel >firewall I had occasion to do some electical circuit checking with a multi >meter. I was getting some erratic results and eventually came to the >conclusion that there was some sort of self created insulating surface >film on the stainless steel surface. > >I could get good consistent meter readings only by specifically piercing >that film with the sharp point of the meter probe. > >This led me to the conclusion that just bolting my starter contactor to >the firewall may not give me the best electrical grounding connection. My >starter contactor case is grounded to the brass firewall forrest-of-tabs >through-bolt. Works great. > >Maybe some electrical guru on this list can verify or dispute my findings. > >OC -- The best investment we will ever make is in gathering knowledge Yup. Surface treatments for stainless -and- aluminums do NOT make for good electrical connections. In the big iron birds we "bond" electro-whizzies to the airframe by cleaning the area around the holes (bonding brush or scotch-bright pad on your die-grinder) and then using fasteners capable of generating and sustaining a lot of force. I'd recommend nothing smaller than 8-32 hardware for attaching terminals and appliances to the airframe . . . 10-32 is really good. Use all metal locking nuts too. Bob . . . ________________________________________________________________________________
Date: Oct 15, 2006
Subject: 12 volt accesory outlet
I am approaching one of the last electrical task on my RV-7A. I installed a 12 volt outlet on the panel but I would like to verify the wiring and fuse selection for this device. The outlet came with no instructions. It did include 3 fast-on terminals which 2 are blue and one red. That would suggest that one of the connecting wires would be smaller than the other 2? There are 2 tabs in the outlet that are brass in color and one tab that is silver. Any help here would be much appreciated. Thanks John. __________________________________________________ ________________________________________________________________________________
From: "John Swartout" <jgswartout(at)earthlink.net>
Subject: electrical system for review and critique
Date: Oct 15, 2006
Apologies, Erich. You were absolutely right about sizing an ANL current limiter for the B-lead. I just found the reference at http://www.aeroelectric.com/articles/anl/anlvsjjs.html, bottom of page 2 to top of page 3. Sorry for my obtuseness. John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Erich_Weaver(at)URSCorp.com Sent: Tuesday, August 01, 2006 12:35 PM Subject: AeroElectric-List: electrical system for review and critique Hey again John I checked the archives regarding your reference on the 60 amp fuse - I dont think you are interpreting this quite right. The original post was not really about Z-13, but a modified starter set-up that had been suggested. Also, the MAX 60 fuse is something different than an ANL current limiter - check out the link posted in Bob's reply from the archives: http://www.bussmann.com/shared/library/catalogs/Buss_Auto-Fuse_Cat.pdf I cant provide a direct reference - probably something from the AeroElectric FAQ files - but I still think that the ANL40 is pretty robust fuse and is fine with the 40 amp alternator. Somebody please correct me if Im full of it. Erich Weaver ________________________________________________________________________________
Date: Oct 15, 2006
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert L. Nuckolls, III Sent: Sunday, October 15, 2006 8:40 AM Subject: RE: AeroElectric-List: Ground Wire for Starter Contactor? > > > > > I tried to get the "boots" off and gave up. I think they are oin to > >stay. Any good ideas as to how to remove them? > > Hmmmm . . . I guess I've never seen them either. Got > a digital camera? Send me some pictures. I note that > B&C is still using the pictures I took. > > Bob . . . > >Will try to take some tomorrow. The contactor is mounted and I am not sure >that I can get a good enough shot to show any thing about the boot >attachment. They appear to be molded on and I think the legs were drilled >to allow the molding to form pass a through to hold them on. Did you get it from B&C? I'll call them tomorrow and see if they'll send me a sample. Bob . . . Yes it was from B&C. I was not able to get any useful pictures today. Hope you can come up with a way to remove the boots without damaging the contactor. ________________________________________________________________________________
Subject: 80A Fuse on Z-13
Date: Oct 15, 2006
Coming off the starter contactor in the Z-13 diagram, there's an 80A fuse between the current limiter and the starter contactor. Electrical systems are my weakness but is this an in-line fuse? If so who stocks the 80A? Thanks, Jim RV-7 Almost starting to wire ________________________________________________________________________________
Date: Oct 15, 2006
The ANL limiter is the 80A fuse. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of PIAVIS Sent: Sunday, October 15, 2006 8:10 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: 80A Fuse on Z-13 Coming off the starter contactor in the Z-13 diagram, there's an 80A fuse between the current limiter and the starter contactor. Electrical systems are my weakness but is this an in-line fuse? If so who stocks the 80A? Thanks, Jim RV-7 Almost starting to wire ________________________________________________________________________________
Date: Oct 16, 2006
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Press-to-talk switch wiring.
I have UPS Aviation Technologies (now Garmin) SL-30 and GX-65 radio stack with their audio panel (actually PS6000 guts and UPS AT nameplate). In the installation drawings they show the PTT switch across two of the microphone connections (Mic Key and return) but don't say anything about shielding or twisting the pair. Lectric Bob's drawings show a twisted pair of wires from the Press to Talk switch to the radios. Is there anything to be gained by doing this if the installation drawings don't show it? I know the fields cancel each other out in a twisted pair but if these are not twisted will they pick up unwanted electrical noise and feed it into the Mic inputs? I have the pilot's PTT on a Ray Allen stick grip, the wires will feed through a common hole in the spar along with a bundle of other wires (mostly power wires for strobe pack, taxi, landing, position lights and pitot heater). What I would like to do is utilize the 5 conductor wire that Ray Allan sells (for use with his Stick and Trim Servos) to connect the PTT to the radios. The three other wires in this cable will carry discrete signals for Ez Pilot Servo disconnect, Radio frequency flip/flop and a light that will be used intermittently by the trim control module to display status and faults. The Ray Allan 5 wire bundle is not shielded and the wires are twisted but only about 1 turn for 1.5 inches of length. If I need to use twisted pair will this work or will there be interference from the other wires in the bundle (these wires will only have signal very intermittently)? Will the 1 twist per 1.5 inches of length be enough to satisfy a requirement for a twisted pair? Thanks. Dean Psiropoulos RV-6A N197DM Last 1% of the 90% to go ________________________________________________________________________________
E-Bus
Date: Oct 16, 2006
Bob et all, One of the first things every builder is told to do when designing the electrical system for their OBAM aircraft is to determine the type of flying they intend to do, figure out what equipment they need to comfortably fly that way, determine the CONTINUOUS load of that equipment, and size your bus's, wires, fuses, alternators, batteries, etc. accordingly. It is information that seems pretty hard to come by in most manufacturers specs, yet supposedly everyone who has designed a panel and electrical system to support it has needed this info. Where did they get it? It seems to me that one of the most valuable resources that could be made a permanent yet updatable part of this list either in the FAQ's, or archives, or somewhere, would be a list of the most commonly used equipment (I don't think it would really be that long ) and continuous load numbers for that equipment. I'm not saying this should necessarily be a job for you (although your contributions would certainly be welcome), but just a have this forum as a home for the list. It could be a categorized list ( Nav/Coms, Coms, Transponders, MFD's, EFIS's, T&B's etc.) and be something that subscribers could add to, and update as they found numbers for new equipment as it hit the market, yet the older equipment would still be there for those not using the latest, and greatest in their plane. Is there some place that you or anyone else on this list knows of where this info is readily available? Thanks for your thoughts, and any light you can shed. Dustin Paulson GlaStar builder > From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> > Subject: AeroElectric-List: Re: short course on bus loading (was Q on Z-13 > and > E-Bus) > If you're going to have a plain-vanilla, Z-11 or an SD-8 > enhanced Z-13, you figure out what gizmos are useful > for the en route mode of flight, i.e. ENDURANCE MODE. > Add up CONTINUOUS loads on these devices and then > see if you have sized the battery for ALT OUT ENDURANCE > with NO ASSIST for the design goals you've established. > Rethink your distribution of loads based on this > philosophy and see what it looks like. > > Bob . . . > > -- ________________________________________________________________________________
Date: Oct 16, 2006
> > >Bob et all, > >One of the first things every builder is told to do when designing the >electrical system for their OBAM aircraft is to determine the type of >flying they intend to do, figure out what equipment they need to >comfortably fly that way, determine the CONTINUOUS load of that equipment, >and size your bus's, wires, fuses, alternators, batteries, etc. accordingly. > >It is information that seems pretty hard to come by in most manufacturers >specs, yet supposedly everyone who has designed a panel and electrical >system to support it has needed this info. Where did they get it? > >It seems to me that one of the most valuable resources that could be made >a permanent yet updatable part of this list either in the FAQ's, or >archives, or somewhere, would be a list of the most commonly used >equipment (I don't think it would really be that long ) and continuous >load numbers for that equipment. I'm not saying this should necessarily be >a job for you (although your contributions would certainly be welcome), >but just a have this forum as a home for the list. > >It could be a categorized list ( Nav/Coms, Coms, Transponders, MFD's, >EFIS's, T&B's etc.) and be something that subscribers could add to, and >update as they found numbers for new equipment as it hit the market, yet >the older equipment would still be there for those not using the latest, >and greatest in their plane. > >Is there some place that you or anyone else on this list knows of where >this info is readily available? > >Thanks for your thoughts, and any light you can shed. that's been discussed. A number of members on the List have published their load analysis data. I've posted a few of them at: http://www.aeroelectric.com/PPS/Load_Analysis What you're suggesting would be a great resource and as I recall, some folks volunteered to compile the list . . . but it has not been discussed in some time. Bob . . . ________________________________________________________________________________
Date: Oct 16, 2006
Subject: Re: Press-to-talk switch wiring.
> > >I have UPS Aviation Technologies (now Garmin) SL-30 and GX-65 radio stack >with their audio panel (actually PS6000 guts and UPS AT nameplate). In the >installation drawings they show the PTT switch across two of the microphone >connections (Mic Key and return) but don't say anything about shielding or >twisting the pair. Lectric Bob's drawings show a twisted pair of wires from >the Press to Talk switch to the radios. Is there anything to be gained by >doing this if the installation drawings don't show it? I know the fields >cancel each other out in a twisted pair but if these are not twisted will >they pick up unwanted electrical noise and feed it into the Mic inputs? > >I have the pilot's PTT on a Ray Allen stick grip, the wires will feed >through a common hole in the spar along with a bundle of other wires (mostly >power wires for strobe pack, taxi, landing, position lights and pitot >heater). What I would like to do is utilize the 5 conductor wire that Ray >Allan sells (for use with his Stick and Trim Servos) to connect the PTT to >the radios. The three other wires in this cable will carry discrete signals >for Ez Pilot Servo disconnect, Radio frequency flip/flop and a light that >will be used intermittently by the trim control module to display status and >faults. The Ray Allan 5 wire bundle is not shielded and the wires are >twisted but only about 1 turn for 1.5 inches of length. If I need to use >twisted pair will this work or will there be interference from the other >wires in the bundle (these wires will only have signal very intermittently)? >Will the 1 twist per 1.5 inches of length be enough to satisfy a requirement >for a twisted pair? Thanks. There is no requirement to twist PTT wires. I often twist pairs or trios of wires specific to a task just to keep them together and easily identified in a wire bundle. Also, twisted wires put lower stresses into the strands for situations where you're bringing PTT wires up the control stick and the wires will be subject to a lot of flexing at the bottom. You can use the wire you've cited . . . Bob . . . ________________________________________________________________________________
Date: Oct 16, 2006
Subject: Re: Are all active GPS antennas equilvalent?
In a message dated 9/25/2006 12:42:13 PM Eastern Standard Time, vision0241(at)hotmail.com writes: are all the active aviation gps antennas (trimble, king, garmin, lowrance, etc) interchangeable? which specificiation do i need to look at to evaluate the equivalence? ===================== Only if you believe all men are created equal! The difference is whether they are active or passive. Passive does not offer any GAIN. Active offers a built in amplifier which offers some gain. NO additional wiring is required if you get an Active antenna. On LONG runs of antenna coax you may want a bit of a foot-up with an antenna with gain. What is a long run? I don't know. My Passive antenna came with about 10 feet of coax and works well. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
Subject: New battery option
Date: Oct 16, 2006
For those of you that are using/considering a 17AH 12VDC RG battery for your craft you might be interested in what I just found out when looking to get another Panasonic 17AH 12VDC RG battery. Panasonic now has a 20 AH battery that is only .22 pounds heaver at 12.56 pounds and it only costs $6.69 more. That looks like a good deal to me. Here is the info from http://digikey.com. DigiKey has links to the factory datasheets for these batteries. DigiKeyPN Mfg PN Description Price P174-ND LC-RD1217P BATT SEALED LEAD ACID 12V 17AH Panasonic - BSG $40.67 P231-ND LC-X1220P BATT SEALED LEAD ACID 12V 20.0AH Panasonic - BSG $47.36 Regards, Bob Lee N52BL KR2 Suwanee, GA 91% done only 65% to go! ________________________________________________________________________________
Date: Oct 16, 2006
Subject: Re: New battery option
Looks interesting. I think you meant to say "14.56 pounds," though. Wouldn't you know I just ordered my third Odyssey PC-625 for the plane last week. Maybe next time I'll try one of these. -Stormy On 10/16/06, Bob Lee wrote: > > For those of you that are using/considering a 17AH 12VDC RG battery for your > craft you might be interested in what I just found out when looking to get > another Panasonic 17AH 12VDC RG battery. Panasonic now has a 20 AH battery > that is only .22 pounds heaver at 12.56 pounds and it only costs $6.69 more. > That looks like a good deal to me. Here is the info from > http://digikey.com. DigiKey has links to the factory datasheets for these > batteries. > > DigiKeyPN Mfg PN Description > Price > P174-ND LC-RD1217P BATT SEALED LEAD ACID 12V 17AH Panasonic - BSG $40.67 > > P231-ND LC-X1220P BATT SEALED LEAD ACID 12V 20.0AH Panasonic - BSG $47.36 > > Regards, > > Bob Lee > N52BL KR2 > Suwanee, GA > 91% done only 65% to go! > > ________________________________________________________________________________
Date: Oct 16, 2006
On second thought, having just looked up the Odyssey, the Panasonic is 1.3# heavier, and its numbers don't look any better to me (except price). Maybe I'll stick with Odyssey until something better comes along. (IMO, $30 is a fair price to shave 1.3# from an airframe. At that price, I'll take 200# off, please :-) Comments? -Bill B On 10/16/06, Bill Boyd wrote: > Looks interesting. I think you meant to say "14.56 pounds," though. > > Wouldn't you know I just ordered my third Odyssey PC-625 for the plane > last week. Maybe next time I'll try one of these. > > -Stormy > > On 10/16/06, Bob Lee wrote: > > > > For those of you that are using/considering a 17AH 12VDC RG battery for your > > craft you might be interested in what I just found out when looking to get > > another Panasonic 17AH 12VDC RG battery. Panasonic now has a 20 AH battery > > that is only .22 pounds heaver at 12.56 pounds and it only costs $6.69 more. > > That looks like a good deal to me. Here is the info from > > http://digikey.com. DigiKey has links to the factory datasheets for these > > batteries. > > > > DigiKeyPN Mfg PN Description > > Price > > P174-ND LC-RD1217P BATT SEALED LEAD ACID 12V 17AH Panasonic - BSG $40.67 > > > > P231-ND LC-X1220P BATT SEALED LEAD ACID 12V 20.0AH Panasonic - BSG $47.36 > > > > Regards, > > > > Bob Lee > > N52BL KR2 > > Suwanee, GA > > 91% done only 65% to go! > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Oct 16, 2006
Subject: Re: 12 volt accesory outlet
In a message dated 10/15/2006 5:55:20 PM Eastern Standard Time, rv7a.builder(at)yahoo.com writes: I am approaching one of the last electrical task on my RV-7A. I installed a 12 volt outlet on the panel but I would like to verify the wiring and fuse selection for this device. The outlet came with no instructions. It did include 3 fast-on terminals which 2 are blue and one red. That would suggest that one of the connecting wires would be smaller than the other 2? There are 2 tabs in the outlet that are brass in color and one tab that is silver. Any help here would be much appreciated. Thanks John. =========================== John: Not Enough Good Information (N.E.G.I.) I'm guessing ... The "outlet" is a cigarette lighter jack??? Since you have three wires: One is for an internal light. One is B+ One is GND The center is B+ The case is GND And you will have to play with it. To find what the third one is. Again ... Guessing it is a light. The fuse goes on the B+ I would use a 10 Amp Fuse / CB MAX. Wire size 14 AWG Mil Spec of course. Barry "Chop'd Liver" "Show them the first time, correct them the second time, kick them the third time." Yamashiada ________________________________________________________________________________
and E-Bus
Date: Oct 16, 2006
----- Original Message ----- From: "Dustin Paulson" <dustinp(at)hughes.net> Sent: Monday, October 16, 2006 8:55 AM Subject: AeroElectric-List: Re: short course on bus loading (was Q on Z-13 and E-Bus > > > > Bob et all, > > One of the first things every builder is told to do when designing the > electrical system for their OBAM aircraft is to determine the type of > flying they intend to do, figure out what equipment they need to > comfortably fly that way, determine the CONTINUOUS load of that equipment, > and size your bus's, wires, fuses, alternators, batteries, etc. > accordingly. > > It is information that seems pretty hard to come by in most manufacturers > specs, yet supposedly everyone who has designed a panel and electrical > system to support it has needed this info. Where did they get it? > > It seems to me that one of the most valuable resources that could be made > a permanent yet updatable part of this list either in the FAQ's, or > archives, or somewhere, would be a list of the most commonly used > equipment (I don't think it would really be that long ) and continuous > load numbers for that equipment. I'm not saying this should necessarily be > a job for you (although your contributions would certainly be welcome), > but just a have this forum as a home for the list. > > It could be a categorized list ( Nav/Coms, Coms, Transponders, MFD's, > EFIS's, T&B's etc.) and be something that subscribers could add to, and > update as they found numbers for new equipment as it hit the market, yet > the older equipment would still be there for those not using the latest, > and greatest in their plane. > > Is there some place that you or anyone else on this list knows of where > this info is readily available? > > Thanks for your thoughts, and any light you can shed. > > Dustin Paulson > GlaStar builder > > >> From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> >> Subject: AeroElectric-List: Re: short course on bus loading (was Q on >> Z-13 and >> E-Bus) >> If you're going to have a plain-vanilla, Z-11 or an SD-8
October 02, 2006 - October 16, 2006
AeroElectric-Archive.digest.vol-gf
