AeroElectric-Archive.digest.vol-gj
November 23, 2006 - December 04, 2006
      > If you truly believe there is Design one so I can build it and you can prove
      me wrong.
      > OR tell the poor questioning soul how to "carefully crafted locations designed
      to minimize the number of
      > grounds and risks for ground-loop noise."
      > Ya CAN'T because each plane is different the wire runs vary and there is NO SUCH
      FREEKEN thing as a GROUND LOOP in a DC circuit.
      > Barry
      Barry is absolutely correct.
      Unfortunately, we don't use real grounds in real things. Theoretically-real grounds
      are hard to carry around since they weigh...oh let's see....INFINITE. Your
      fuel economy would be terrible.
      So we use "ground" as slang to indicate where all the (usually) negative conductors
      are connected (mostly). It is perfectly possible to have no DC ground in
      an airplane, and in fact, composite airplanes just use a second conductor to borrow
      those little electrons from the battery.
      The problems occur when we share conductors (AC, DC, Negative, Positive, or jumping-around-a-lot),
      because then old Devil Mr. Ohm demands his due.
      PS: A DC circuit is only DC if it sits perfectly still. If you turn it ON or OFF
      it is AC if only for an instant. Managing that instant is the whole career of
      some engineers.
      Hope this helps.
      "Every act of conscious learning requires the willingness to suffer an
       injury to one's self-esteem...."
           -Thomas Szasz
      Eric M. Jones
      www.PerihelionDesign.com
      113 Brentwood Drive
      Southbridge, MA 01550
      (508) 764-2072
      emjones(at)charter.net
      http://forums.matronics.com/viewtopic.php?p=76530#76530
Date: Nov 23, 2006
From: Bill Bradburry <bbradburry(at)allvantage.com>
Subject: Z-19 questions
I really would like some advice on the below question. I assume that it seems pretty simple to some but it is beyond me.... Thanks, and Happy Thanksgiving. Bill B *Subject:* */Z-19 questions/* *From:* */Bill Bradburry/ (/bbradburry(at)allvantage.com/ )* *Date:* */*Wed Nov 22 - 11:00 AM*/* *Bob, and others, I am installing a fuel injected Mazda rotary engine and trying to follow the Z-19 guidelines for dual battery, single alternator. Looking at the engine primary and secondary circuit, I need to install a primary and secondary fuel pump, plus I want to power the coils and the injectors off of the battery buss. How should I do this? I suppose I could take the fuel pump diode output and switch it to either of the two fuel pumps??? What about the coils and injectors? Should I set up similar circuits for them, or is there a better way to reduce parts??? I would appreciate any guidance you guys could give me. Thanks and Happy Thanksgiving! Bill B * ________________________________________________________________________________
Subject: Ampmeter reading
Date: Nov 23, 2006
Bob et all I installed a digital Ampmeter, connected to a 50mV Shunt which is installed in the #6 cable which comes from the alternator (Subaru engine) to my Exp Bus board. I assume that this ampmeter indicates the current being produced by the alternator, obviously with the engine running. But, every time I run the engine (stil at my garage, not yet flying), the ampmeter indication runs very quickly from, let's say 13.7 down to 8.2, then up to 14,6, again down and again up, very quickly. Why am I geting this kind of reading? Anything wrong or it's just indicating what it shoud? Carlos ________________________________________________________________________________
Date: Nov 23, 2006
Subject: Re: Ampmeter reading
Carlos, Depends on what your looking for . If you want to know the current being produced by the alternator you have it in the right place and the readings might be right. If you want to know is my battery being charged or discharged you should put it in series with the lead from the battery that goes to everything except the starter. In this location you will know if you are in a sustainable condition. An alternator can be putting out it rated current but if your aircraft is consuming more than that you have a limited amount of airtime. Tim Shankland Carlos Trigo wrote: > Bob et all > > I installed a digital Ampmeter, connected to a 50mV Shunt which is > installed in the #6 cable which comes from the alternator (Subaru > engine) to my Exp Bus board. > I assume that this ampmeter indicates the current being produced by > the alternator, obviously with the engine running. > But, every time I run the engine (stil at my garage, not yet flying), > the ampmeter indication runs very quickly from, let's say 13.7 down to > 8.2, then up to 14,6, again down and again up, very quickly. > Why am I geting this kind of reading? > Anything wrong or it's just indicating what it shoud? > > Carlos > > ________________________________________________________________________________
Subject: Re: Icom A200-Help!
Date: Nov 23, 2006
I'm currently wiring an A200 and like many others I thought I'd cross-check the very basic installation instructions that were provided. I've downloaded and looked at the http://www.aeroelectric.com/Installation_Data/IC-A200_Icom_Installation_Wiring.pdf document, but that actually raised a bigger question. Maybe I just need another jolt of caffeine, but ... The ICOM document shows the Molex connector from the front rather than the rear wire entry side. The .pdf document shows the connector from the wire entry side (i.e. rear), BUT ... the pin numbers and letters are in the exact same order as the ICOM front view. The physical connector shows the expected reversed order. Can anyone who's wired and tested one of these confirm the orientation for me? i.e. Power / ground wires on the left or right when viewed from the rear. Thanks in advance. P.S. Many thanks to Bob for his efforts and willingness to share his knowledge ... it is appreciated. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76568#76568 ________________________________________________________________________________
Date: Nov 23, 2006
Bill, Check the molex connector for the neutral key for finding the proper side. 1 thru 8 and A thru H begin the first half of the connector and A has no connector at all. The opposite side only has 7 spaces, so orientation and placement of the wires should be evident by checking the radio and connectors. Larry McFarland - 601HDS at www.macsmachine.com Bill McMullen wrote: > > I'm currently wiring an A200 and like many others I thought I'd cross-check the very basic installation instructions that were provided. I've downloaded and looked at the http://www.aeroelectric.com/Installation_Data/IC-A200_Icom_Installation_Wiring.pdf document, but that actually raised a bigger question. Maybe I just need another jolt of caffeine, but ... > > The ICOM document shows the Molex connector from the front rather than the rear wire entry side. The .pdf document shows the connector from the wire entry side (i.e. rear), BUT ... the pin numbers and letters are in the exact same order as the ICOM front view. The physical connector shows the expected reversed order. > > Can anyone who's wired and tested one of these confirm the orientation for me? i.e. Power / ground wires on the left or right when viewed from the rear. > > Thanks in advance. > > P.S. Many thanks to Bob for his efforts and willingness to share his knowledge ... it is appreciated. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=76568#76568 > > > ________________________________________________________________________________
Date: Nov 23, 2006
Thanks Larry. I think I was just being over cautious ... I'm doing this from scratch and first had to insert the polarizing key into my blank Molex connector. It does match the radio and I've looked at the PCB traces to verify the obvious ground connections. Your post made me look at it again and I still think I've done it properly such that the wiring will match the markings on the connector. In essence, I guess my post was a round about way of saying that I think the .PDF drawing has an error in it's connector pictorial. I hate the smell of expensive smoke and also hope that no one else makes a mistake. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76591#76591 ________________________________________________________________________________
From: "S. Ramirez" <simon(at)synchronousdesign.com>
Date: Nov 23, 2006
Mofo, I can download it. I'm doing it right now! I thought this book cost money, and here it is in PDF on the fucking internet. I'll see you at the airport Saturday morning. Thanks a bunch. Simon Ramirez, Consultant Synchronous Design, Inc. Oviedo, FL 32765 USA 407-365-8928: home/office 407-221-8928: mobile Xilinx Alliance Partner Copyright C 2006 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Thursday, November 23, 2006 11:53 AM Subject: AeroElectric-List: Z-19 questions --> I really would like some advice on the below question. I assume that it seems pretty simple to some but it is beyond me.... Thanks, and Happy Thanksgiving. Bill B *Subject:* */Z-19 questions/* *From:* */Bill Bradburry/ (/bbradburry(at)allvantage.com/ )* *Date:* */*Wed Nov 22 - 11:00 AM*/* *Bob, and others, I am installing a fuel injected Mazda rotary engine and trying to follow the Z-19 guidelines for dual battery, single alternator. Looking at the engine primary and secondary circuit, I need to install a primary and secondary fuel pump, plus I want to power the coils and the injectors off of the battery buss. How should I do this? I suppose I could take the fuel pump diode output and switch it to either of the two fuel pumps??? What about the coils and injectors? Should I set up similar circuits for them, or is there a better way to reduce parts??? I would appreciate any guidance you guys could give me. Thanks and Happy Thanksgiving! Bill B * -- 5:41 PM ________________________________________________________________________________
Date: Nov 23, 2006
That one is and old version. Mofo, I can download it. I'm doing it right now! I thought this book cost money, and here it is in PDF on the fucking internet. I'll see you at the airport Saturday morning. Thanks a bunch. Simon Ramirez, Consultant Synchronous Design, Inc. Oviedo, FL 32765 USA 407-365-8928: home/office 407-221-8928: mobile Xilinx Alliance Partner Copyright C 2006 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Thursday, November 23, 2006 11:53 AM Subject: AeroElectric-List: Z-19 questions --> I really would like some advice on the below question. I assume that it seems pretty simple to some but it is beyond me.... Thanks, and Happy Thanksgiving. Bill B *Subject:* */Z-19 questions/* *From:* */Bill Bradburry/ (/bbradburry(at)allvantage.com/ 49E28.9030501(at)allvantage.com>)* *Date:* */*Wed Nov 22 - 11:00 AM*/* *Bob, and others, I am installing a fuel injected Mazda rotary engine and trying to follow the Z-19 guidelines for dual battery, single alternator. Looking at the engine primary and secondary circuit, I need to install a primary and secondary fuel pump, plus I want to power the coils and the injectors off of the battery buss. How should I do this? I suppose I could take the fuel pump diode output and switch it to either of the two fuel pumps??? What about the coils and injectors? Should I set up similar circuits for them, or is there a better way to reduce parts??? I would appreciate any guidance you guys could give me. Thanks and Happy Thanksgiving! Bill B * -- 5:41 PM Lynn A. Riggs riggs_la(at)yahoo.com St. Paul, MN BH #656 Kit #22 http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html --------------------------------- ________________________________________________________________________________
Subject: Re: Z-19 questions
Date: Nov 23, 2006
Simon Ramirez, Please refrain from the offensive language. It is not appropriate for this list exchange. Dale Ensing ----- Original Message ----- From: "S. Ramirez" <simon(at)synchronousdesign.com> Sent: Thursday, November 23, 2006 8:41 PM Subject: RE: AeroElectric-List: Z-19 questions > > > Mofo, > > I can download it. I'm doing it right now! I thought this book cost > money, > and here it is in PDF on the ******* internet. > > I'll see you at the airport Saturday morning. > > Thanks a bunch. > > Simon Ramirez, Consultant > Synchronous Design, Inc. > Oviedo, FL 32765 USA > 407-365-8928: home/office > 407-221-8928: mobile > Xilinx Alliance Partner > > Copyright C 2006 > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill > Bradburry > Sent: Thursday, November 23, 2006 11:53 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Z-19 questions > > --> > > I really would like some advice on the below question. I assume that it > seems pretty simple to some but it is beyond me.... > Thanks, and Happy Thanksgiving. > > Bill B > > *Subject:* */Z-19 questions/* > *From:* */Bill Bradburry/ (/bbradburry(at)allvantage.com/ > 49E28.9030501(at)allvantage.com>)* > > *Date:* */*Wed Nov 22 - 11:00 AM*/* > > *Bob, and others, > I am installing a fuel injected Mazda rotary engine and trying to > follow > > the Z-19 guidelines for dual battery, single alternator. Looking at > the > > engine primary and secondary circuit, I need to install a primary and > secondary fuel pump, plus I want to power the coils and the injectors > off of the battery buss. > How should I do this? I suppose I could take the fuel pump diode > output > > and switch it to either of the two fuel pumps??? > What about the coils and injectors? Should I set up similar circuits > for them, or is there a better way to reduce parts??? > I would appreciate any guidance you guys could give me. > Thanks and Happy Thanksgiving! > Bill B > * > > > -- > 5:41 PM > > > ________________________________________________________________________________
Date: Nov 23, 2006
I apologize to everyone on this list for the previous offensive email that I accidentally posted. I thought I was responding to another email from a personal friend, unrelated to the email that you saw below mine. I goofed big time. Please accept my apologies, and it will not happen again. I contacted Bob N. about what to do, but decided to post an apology nonetheless. I also apologize personally to Bill Bradburry, who had nothing to do with the email. Simon Ramirez ________________________________________________________________________________
Date: Nov 23, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: 24V 12V grounds
> > > > One more time! > > > > There is NO SUCH FREEKEN thing as a GROUND LOOP in a DC circuit. > > > > If you truly believe there is Design one so I can build it and you can > prove me wrong. > > OR tell the poor questioning soul how to "carefully crafted locations > designed to minimize the number of > > grounds and risks for ground-loop noise." > > Ya CAN'T because each plane is different the wire runs vary and there > is NO SUCH FREEKEN thing as a GROUND LOOP in a DC circuit. > > > > Barry > > >Barry is absolutely correct. > >Unfortunately, we don't use real grounds in real things. >Theoretically-real grounds are hard to carry around since they weigh...oh >let's see....INFINITE. Your fuel economy would be terrible. > >So we use "ground" as slang to indicate where all the (usually) negative >conductors are connected (mostly). It is perfectly possible to have no DC >ground in an airplane, and in fact, composite airplanes just use a second >conductor to borrow those little electrons from the battery. > >The problems occur when we share conductors (AC, DC, Negative, Positive, >or jumping-around-a-lot), because then old Devil Mr. Ohm demands his due. > >PS: A DC circuit is only DC if it sits perfectly still. If you turn it ON >or OFF it is AC if only for an instant. Managing that instant is the whole >career of some engineers. > >Hope this helps. Golly gee Eric. Talk about slicing and dicing the dictionary. An alternating current system is one that changes polarity, I.e. like positive for 1/2 cycle and reverses for another half cycle. I.e., it ALTERNATES. Stating that DC becomes something other than DC just because it is dynamic suggests a vernacular from another planet. Okay folks. Where Eric (and I presume Barry) lives. Any DC system that is not absolutely rock stable is no longer a DC system but . . . what? Oh yes, at what point do you draw the line on stability sir? 1-volt "wiggles"? 1-millivolt wiggles . . . how about microvolt wiggles? Taking this notion to the molecular extreme, one might say that, "There is no such thing as a DC system." Even a battery generates some "wiggles" in output voltage as electrons within the chemistry jump from ion to ion. My teachers would disagree with your definitions sir as do I. For the purposes of common language and understanding here on the List and just so we're all on the same page, let us stipulate: That (1) alternating current power distribution systems are likened to that which comes out of your wall sockets and (2) direct current power distribution systems are likened to that which runs our automobiles. Further, DC systems that are less than stable are still DC systems with distortion (noise). AC systems suffer distortions too (mini-brownouts, switching transients and yes, the effects of GROUND LOOPS). To argue differently may impress the neophyte but it borders on bizarre in the venue where I work. >"Every act of conscious learning requires the willingness to suffer an > injury to one's self-esteem...." -Thomas Szasz What a bummer idea! I'll suggest a alternative: "Every act of conscious learning requires a willingness to seek out and understand the simple-ideas (fundamentals) for the systems of interest. One's self-esteem is enhanced by the ability to use those simple-ideas in ways that are useful. One's self-esteem is really bolstered when CUSTOMERS are willing to support your livelihood by PURCHASING inventions you SUPPLY based on your understanding of those fundamentals." -Bob Nuckolls I've read some of Szasz's work. He posits some interesting and even attractive ideas but he's obviously not grounded in reality. For example. He suggests, "abolition of involuntary hospitalization: No one should be deprived of liberty unless he is found guilty of a criminal offense. Depriving a person of liberty for what is said to be his own good is immoral. Just as a person suffering from terminal cancer may refuse treatment, so should a person be able to refuse psychiatric treatment." I've had a lifetime experience with a mother who has suffered from paranoid schizophrenia since her teens. I've witnessed a virtual miracle of productive integration into family and society when interventions were working along with her suffering in a 24/7 living hell of nightmares when she decided she was cured and dumped her protocols. Szasz speaks a language attractive to amoral passivists but as your chosen quotation illustrates, he does not philosophize in simple-ideas. May I suggest more forward-looking philosophers who have demonstrated the value of their philosophies for living many times over? Try Charles Kettering, Ayn Rand, Virgil Elings, just to name a few. These folks do not wallow in self-deprecating ideas and nostrums for living. Not one bummer quote from the lot! Bob . . . ________________________________________________________________________________
Date: Nov 23, 2006
Simon, You have done all that is necessary and expected. Our society is replete with individuals who, when indulging in a dishonorable activity, will hat-dance around the the event rather than accept responsibility and offer restitution. Your willingness to step up to the bar and set things right is as much as any of us can ask. We're all sorry it happened but in light of your subsequent behavior, I'll suggest it's an event unworthy of further attention. I'm perfectly willing to move on from here without prejudice. I'll ask others on the list to join me. Bob . . . > > >I apologize to everyone on this list for the previous offensive email that I >accidentally posted. I thought I was responding to another email from a >personal friend, unrelated to the email that you saw below mine. I goofed >big time. Please accept my apologies, and it will not happen again. I >contacted Bob N. about what to do, but decided to post an apology >nonetheless. > >I also apologize personally to Bill Bradburry, who had nothing to do with >the email. > >Simon Ramirez ________________________________________________________________________________
Subject: Re: D10-a check lists and POH
Date: Nov 23, 2006
Ken, Please send what you have on hand there. Do you need any contact information? Thanks, Jim ----- Original Message ----- From: "Ken Harrill" <kharrill(at)osa.state.sc.us> Sent: Wednesday, November 22, 2006 10:34 AM Subject: AeroElectric-List: Re: D10-a check lists and POH > > > Jim, > > I have one for my RV-6, 180 hp, C/S that I will be glad to send you. I > can't attach it to this message because it does not have an acceptable > file extension. > > Ken Harrill > ken.harrill(at)columbia.sc > > -------- > Ken Harrill > RV-6 > Columiba, SC > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=76415#76415 > > > ________________________________________________________________________________
Date: Nov 24, 2006
Subject: More Great List Comments - Please Make A Contribution!
Dear Listers, There's a little less than one week left for this year's List Fund Raiser. I thought it would a great time to share a few more of the great comments I've been receiving from Contributors regarding what the Lists mean to them. There are some particularly poignant ones in this batch and I encourage you to have a look at some of them. Don't forget that once you make your Contribution, the Contribution Squelch kicks in and you won't receive any future messages from me regarding the Fund Raiser this year! This holds true for the Realtime and Digest distributions and now also the HTML and TXT links included with the Digest! (Note that for technical reasons, if someone replies to one of my contribution messages, the Squelch will _not_ be activated, and you will still receive it. Contribution messages will also still be found on the Forums site and the List Browse). Please make your Contribution today to support these List services! Pick up a great Gift too! http://www.matronics.com/contribution Thank you! Matt Dralle Matronics Email List Administrator ============================= WLAS #2 ============================ Tackling my project without the List would be like building on a deserted island. The List has made me part of a learning (and laughing) community. -Larry W Thank you for providing such a fantastic resource for us Kolbers. I'm very happy to contribute towards keeping such a wonderful resource available. -Geoff T ..you do a great service for the flying community by providing this service. -John L ..solidly administered. -James C A great source of information. -Ralph S The Lists have likely saved a numbers of lives... -James F ..exceptional user service. -Larry W Better than a magazine! -Aaron G Thanks to your List I will be able to finish and fly my project. Without the help of the great people on your List I doubt it would have happened. -Ed G I learn something on a too regular basis thanks to these lists! -Ralph C ..valuable service. -John F ..a well administered service. -Stewart C Great forum! -Ronald C A great service! -Andy H Been reading the lists since my first RV in 1999. Good work and as necessary to me as a rivet. -Albert G The lists are a great help. -Gary S This resource has been critical to my building success so far. -Timothy F Great system and support! -Richard P Very helpful in the building my CH 701. -Ralph S Another year of entertainment and pleasure! -Larry B A great resource for all of us. -Larry W Another year of great service! Once again, the information is worth more than I can ever contribute. Thank you also for the "community" that the List fosters. I cannot tell you the number of times that seeing an friend's name come up has caused so many awesome memories to come flooding back - along with the eager desire to gather with these great guys again. I love hearing the beginner's enthusiasm, the builder's progress, and the flyer's success... -Robert B Our list has great info and I love reading the "Flame Posts! " -Stephen M Great service! -James B Excellent source of information. -David P You provide a very valuable service to the aviation community. -David H The RV related lists have been a tremendous help in the construction of my RV-7... -Norman R Awesome list!! -John E Great bunch of guys and very knowledgeable! -Herbert G Thank you for making it so easy to stay in touch with my fellow RV-10 builders. -David J I love the list and have been a reader for a long time. -James V Continues to be a great service! -George A Awesome List server. -Deke M Many of us would never finish our airplanes without [the List]. With it, I'm getting close! -Ronald C An excellent source of both information and inspiration! -William R Forums and format are easy to use. -Jack B Great help with my kit building. -Ralph H Super service. -Richard N Still loving it. -Jared S You have a fantastic web! -Harvey R ..a great service. -James M Glad you are there... -David A I get some great information on your list. -John P Fantastic service. Couldn't have made it as far as I have without it. -Stephen T A great learning experience with my RV-6A. -Ron B Great resources! -Jason H Well done. Very valuable. -Jeffrey D Great resource for the experimental aircraft community. -Chris H This List has been one of the most helpful tools in building my RV-10, since I build alone, and do not have any help readily available. Without the List, I could not have embarked on building my RV-10. -Jim H You run a great list there. -James H Really like the Kolb List. -Don W ============================= WLAS #2 ============================ ________________________________________________________________________________
Date: Nov 24, 2006
No such thing as over-cautious. You are correct that the pinout on the .pdf file is wrong. You are also correct that the pinout letters and numbers are embossed on the connector. With a pair of +1.25 Diopter "cheater" from Walgreen's and a good bright light, I can just barely read them. Go with the IC-A200 "Installation Instructions". They work well. Rodney in Tennessee PS, mine never had a Polarizing Key. Still works fine. _________________________________________________________________ Get FREE company branded e-mail accounts and business Web site from Microsoft Office Live ________________________________________________________________________________
Date: Nov 24, 2006
Is this what our friendly discussion group has come to John "S. Ramirez" wrote: Mofo, I can download it. I'm doing it right now! I thought this book cost money, and here it is in PDF on the fucking internet. I'll see you at the airport Saturday morning. Thanks a bunch. Simon Ramirez, Consultant Synchronous Design, Inc. Oviedo, FL 32765 USA 407-365-8928: home/office 407-221-8928: mobile Xilinx Alliance Partner Copyright C 2006 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Thursday, November 23, 2006 11:53 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Z-19 questions --> I really would like some advice on the below question. I assume that it seems pretty simple to some but it is beyond me.... Thanks, and Happy Thanksgiving. Bill B *Subject:* */Z-19 questions/* *From:* */Bill Bradburry/ (/bbradburry(at)allvantage.com/ 49E28.9030501(at)allvantage.com>)* *Date:* */*Wed Nov 22 - 11:00 AM*/* *Bob, and others, I am installing a fuel injected Mazda rotary engine and trying to follow the Z-19 guidelines for dual battery, single alternator. Looking at the engine primary and secondary circuit, I need to install a primary and secondary fuel pump, plus I want to power the coils and ________________________________________________________________________________
Date: Nov 24, 2006
In a message dated 11/23/2006 10:31:05 PM Eastern Standard Time, nuckollsr(at)cox.net writes: "There is no such thing as a DC system." Even a battery generates some "wiggles" in output voltage as electrons within the chemistry jump from ion to ion. =========================================== Hi Bob: I do live on my own planet, but unfortunately I have to share it; I would even accept a planetoid. GREAT statement above Bob. That is what I learned also. We must have read the same books at one time or another. But, why in your GROUND explaination/seranio (your post explaining ground loops) did you pick thermocouples and group them under the DC Ground umbrella? If you recall thermocouples when first produced were done so as a floating (non-grounded) device. And in many cases as a non-shieled device. This led to may erroneous reading on the gages ESPECIALLY when digital read-outs with low voltage sensing circuits came into play. So the method of correcting and stabilizing became a GROUNDED thermocouple. But, in this case you are talking Fruit Salad ... You know ... Apples & Oranges. They are close, but throwing them into the same bowl, I feel does not truly explain the issue. I think it is only confusing to many out there. Too much Tech-Know-Babble, sounding too much like Professor Irwin Cory. The topic is DC GROUNDS. And you know me I keep things SIMPLE ... K.I.S.S. M.E. SIMPLE. And for those that just might still be interested in the basics and how to eliminate about 98% of your electronical issues and NOISE issues here is the short version of the basics: GROUND at the SOURCE (Alternators, Batteries, Avionics and the like). CLEAN YOUR GROUNDS ADD MORE GROUNDS to DC Circuits - Battery to Engine, Battery to Firewall, Firewall (after additional grounds have been added) to Panel and YES I strongly believe in a nice heavy gage Ground Terminal Block. Or at least a Brass Nut & Bolt. [I believe my above statement is what started this debate - MORE Grounds do HELP] DC Circuits Ground at BOTH ENDS AF (Audio Frequencies) Ground ONLY at the Source RF (Radio Frequencies) Ground at BOTH ends Crazy thing here ... Alternators produce BOTH AF & RF, so what do you do? GROUND at BOTH Ends. YES! GROUND! After you do the grounding THEN you can start playing with Inductors & Capacitors and Transient Suppressors. This is the short list. I very seldom need to do more than that to prevent or remove a problem. Barry ________________________________________________________________________________
Subject: Pitot heater - current sensor
Date: Nov 24, 2006
Bob, Say - I noticed diagram PitotHeat.pdf on your website... This seems like a slick low cost way to know if your pitot heater is actually drawing current. Could I also use this for a fuel boost pump? Do you have a picture of a finished unit and how you would wrap the wire around it, heat shrink, etc? Thanks, John ________________________________________________________________________________
Subject: Auto-pilots
Date: Nov 24, 2006
Hey listers, I'm looking around at auto-pilots. Obviously searched the net a bit, but still wondering, any recommendations from the list? Bob Verwey A35 Bonanza ZU-DLW ________________________________________________________________________________
Date: Nov 24, 2006
Rodney : Thanks for the re-inforcement that I'm really not going crazy as the grey hairs start increasing. I only wish I could get away with just +1.25 cheaters to see these markings ... they're some of the hardest ones to read. I sincerely hope Bob sees this and updates his diagram. It's a great expansion on a very poor installation manual but my biggest concern is that someone goes with it's pinout diagram rather than getting out their magnifying glass and looking at the physical connector. I am surprised that no one else has noted and commented on this discrepency. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=76759#76759 ________________________________________________________________________________
Subject: Re: Auto-pilots
Date: Nov 24, 2006
On 24-Nov-06, at 10:44 AM, Bob Verwey wrote: > Hey listers, > I'm looking around at auto-pilots. Obviously searched the net a > bit, but still wondering, any recommendations from the list? > > Bob Verwey > A35 Bonanza ZU-DLW Do you need an installation for a type-certificated aircraft, or amateur-built? What capabilities do you want? Wing leveler only? Heading select? Altitude hold? Airspeed hold? Vertical speed hold? Altitude preselect? Coupled ILS? Coupled GPS? Coupled approach VNAV? Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Nov 25, 2006
Since I only got 1 answer (thanks Tim), here it goes again: Bob et all I installed a digital Ampmeter, connected to a 50mV Shunt which is installed in the #6 cable which comes from the alternator (Subaru engine) to my Exp Bus board. I assume that this ampmeter indicates the current being produced by the alternator, obviously with the engine running. But, every time I run the engine (stil at my garage, not yet flying), the ampmeter indication runs very quickly from, let's say 13.7 down to 8.2, then up to 14,6, again down and again up, very quickly. Why am I geting this kind of reading? Anything wrong or it's just indicating what it shoud? Carlos ________________________________________________________________________________
Subject: travelliing to Ottawa
Date: Nov 24, 2006
I will be visiting in the Ottawa area from this coming Thursday Nov. 30 until Dec 9. I will have time to sight see and visit in and around the Ottawa area. If any aircraft homebuilders want to share and compare notes and pictures, coffee, etc. please advise as to contact information. Thanks, Jim in Kelowna - Finished RV6-A waiting for the paperwork to be returned ________________________________________________________________________________
Date: Nov 24, 2006
Carlos I don't think there are many Exp bus user's here but I would consider this abnormal unless you have a flashing beacon or something that is intermittantly drawing current. Does the voltage fluctuate? My hall current sensor is quite steady on my EIS monitor with my Subaru. I do have strobes. The current pulses to the injectors and ignition do vary by several amps but that happens much too quickly for current sensors or voltmeters to register anything other than a steady average current. Ammeters just aren't fast enough to register those pulses. There are some posts in the archives about fluctuating ammeters that might assist you. Ken Carlos Trigo wrote: > Since I only got 1 answer (thanks Tim), here it goes again: > > Bob et all > > I installed a digital Ampmeter, connected to a 50mV Shunt which is > installed in the #6 cable which comes from the alternator (Subaru > engine) to my Exp Bus board. > I assume that this ampmeter indicates the current being produced by > the alternator, obviously with the engine running. > But, every time I run the engine (stil at my garage, not yet flying), > the ampmeter indication runs very quickly from, let's say 13.7 down to > 8.2, then up to 14,6, again down and again up, very quickly. > Why am I geting this kind of reading? > Anything wrong or it's just indicating what it shoud? > > Carlos > > ________________________________________________________________________________
Date: Nov 24, 2006
Subject: Re: To ground loop . . . or not, that IS the question.
>In a message dated 11/23/2006 10:31:05 PM Eastern Standard Time, >nuckollsr(at)cox.net writes: >"There is no such > thing as a DC system." Even a battery generates some > "wiggles" in output voltage as electrons within the chemistry > jump from ion to ion. > >=========================================== >Hi Bob: > >I do live on my own planet, but unfortunately I have to share it; I would >even accept a planetoid. > >GREAT statement above Bob. That is what I learned also. We must have >read the same books at one time or another. Then you agree with Eric's assertion that once a DC system "wiggles" that it has now morphed into an AC system? > >But, why in your GROUND explaination/seranio (your post explaining ground >loops) did you pick thermocouples and group them under the DC Ground >umbrella? >If you recall thermocouples when first produced were done so as a floating >(non-grounded) device. And in many cases as a non-shieled device. This >led to may erroneous reading on the gages ESPECIALLY when digital >read-outs with low voltage sensing circuits came into play. So the method >of correcting and stabilizing became a GROUNDED thermocouple. Yup, you do live on a different planet. I've never had to shield a thermocouple. Digital instruments intended to read thermocouple voltages came with specifications as to what kind and amount of common mode voltages they would tolerate. I've worked with all of them. If one understands the performance and limits of the hardware at hand, one may expect reliable results. So, assuming you're using equipment that is NOT tolerant of whatever common mode noises are present and assuming further that you DO ground the thermocouple at the sense end and your measurement equipment is also grounded at some other point in the system, then yes . . . one should not be surprised that the GROUND LOOP so generated produces poor results. > But, in this case you are talking Fruit Salad ... You know ... Apples & > Oranges. They are close, but throwing them into the same bowl, I feel > does not truly explain the issue. I think it is only confusing to many > out there. Too much Tech-Know-Babble, sounding too much like Professor > Irwin Cory. Okay, how about use of remote sensing in power generation control systems . . . or the case I cited where we fixed an instrumentation interference problem by making eliminating a ground loop in the airplane's DC power sysrem? >The topic is DC GROUNDS. And you know me I keep things SIMPLE ... >K.I.S.S. M.E. SIMPLE. >And for those that just might still be interested in the basics and how to >eliminate about 98% of your electronical issues and NOISE issues here is >the short version of the basics: >GROUND at the SOURCE (Alternators, Batteries, Avionics and the like). >CLEAN YOUR GROUNDS >ADD MORE GROUNDS to DC Circuits - Battery to Engine, Battery to Firewall, >Firewall (after additional grounds have been added) to Panel and YES I >strongly believe in a nice heavy gage Ground Terminal Block. Or at least >a Brass Nut & Bolt. >[I believe my above statement is what started this debate - MORE Grounds >do HELP] No, you said: "There is NO SUCH FREEKEN thing as a GROUND LOOP in a DC circuit." >AC Circuits Ground at BOTH ENDS >AF (Audio Frequencies) Ground ONLY at the Source >RF (Radio Frequencies) Ground at BOTH ends >Crazy thing here ... Alternators produce BOTH AF & RF, so what do you >do? GROUND at BOTH Ends. YES! GROUND! >After you do the grounding THEN you can start playing with Inductors & >Capacitors and Transient Suppressors. > >This is the short list. I very seldom need to do more than that to prevent >or remove a problem. Now that's an illuminating dissertation. If it's "babble" one is striving for, you've achieved it. I'm sure every new builder on the List now knows exactly what you're describing but the fact that you're finding issue with my words suggests that that chapters on grounding, noise combined with architecture drawings in appendix Z in the 'Connection are are now in doubt. Barry, I just don't have the time or energy to discuss this with you. If you have a goal of being helpful, it's just not coming through. Tell you what. Write up a critical review of the work you find in the 'Connection. Be specific. Use clear words and syntax that brings to light anything I've written that leads anyone astray. If you want to be a teacher in this venue, you'll have to act like one. Ship me the document and I'll publish it on the website. Here's an example of the format: http://aeroelectric.com/articles/rules/review.html You've demeaned my honor and my intelligence. Now back it up with simple-ideas and illuminating anecdotes from your experience. But if all you're going to do is sit on the edge and throw in mud balls, then go away. You're not entertaining or helpful. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2006
Date: Nov 24, 2006
>Is this what our friendly discussion group has come to > >John You're a day late and a dollar short my friend. This VERY friendly discussion group has not "come to anything" as a result of the note you've cited. Furthermore, the whole matter was put to rest hours ago. Bob . . . ________________________________________________________________________________
Date: Nov 24, 2006
> >Bob, > >Thank you for publishing your most welcomed letter of forgiveness. It means >a lot to me, especially coming from a man whom I admire in many ways. You >don't know me well, because I am a recent newcomer (within a year) and >mostly lurker. I am not in the wire system planning phase of my homebuilt >project yet, so I choose to stay mostly quiet until I stick my foot in my >mouth. :) You are not alone sir. Matt tells me there are over 1300 folks subscribed to this list and obviously, the vast majority must find value in watching the conversations go by else they would simply unsubscribe. Be silent or participate as the need suits you but please don't hesitate to jump in for clarification or expansion of an idea that seems to have relevance to your plans or understanding. >I do have one favor to ask of you before I go. Since my original email as >well as two respondents' emails have both the offensive language AND my >business information in the salutation, may I ask of you to go into whatever >mechanism you have to un-archive them? It reflects badly on my associated >partner company, Xilinx, and un-archiving would be greatly appreciated here. >If I have to do something extra myself to solve this problem, then please >let me know. You would have to contact Matt Dralle about that. He holds the "keys to the system" as it were. No doubt there is a way to get into the files and work on them. >Thank you so much and have a nice Thanksgiving season. . . . and you too sir! Bob . . . ________________________________________________________________________________
Date: Nov 24, 2006
Subject: Re: Pitot heater - current sensor
>Bob, > >Say - I noticed diagram PitotHeat.pdf on your website... > >This seems like a slick low cost way to know if your pitot heater is >actually drawing current. > >Could I also use this for a fuel boost pump? > >Do you have a picture of a finished unit and how you would wrap the wire >around it, heat shrink, etc? > >Thanks, > >John I've not published any specifics on utilizing reed-switches as current sensors. They're used in MANY similar applications on our production airplanes. Light ON says system IS powered and IS drawing current. Reed switches come in lots of sizes and sensitivities. Get a 275-232 reed relay from Radio Shack. Remove existing excitation coil and rewind with 22AWG for up to 10A circuit and 16AWG for up to 20A circuit. Find minimum number of turns that will close the relay contacts when your electro-whizzie is powered at about 10 volts (end of battery life). http://www.aeroelectric.com/Pictures/Misc/CurrentSense.jpg http://www.aeroelectric.com/PPS/DeIce/Pitot_Heat.pdf I've considered packaging calibrated current sensors either with reed switches or perhaps more sophisticated electronics . . . but the reeds are simple, inexpensive and reasonably rugged after installation. You'll need to be gentle on these things while working with them. After the design is fixed, consider "potting" the werks in hot-glue. For individual loose reed capsules check out http://tinyurl.com/yfb3rf http://mpja.com/productview.asp?product=7459+SW http://www.goldmine-elec-products.com/prodinfo.asp?number=G13078 http://www.goldmine-elec-products.com/prodinfo.asp?number=G13997 http://www.goldmine-elec-products.com/prodinfo.asp?number=GP57 It takes some experimentation but the simple-ideas that support the invention are sound. We've been doing this in GA aircraft for decades. Bob . . . ________________________________________________________________________________
Date: Nov 25, 2006
Subject: One more Z-19 try!
My original question has generated absolutely no interest!! Lots of discussion of measurement systems, are you grounded when only one foot is on the floor, etc., but my silly little question has been ignored for days even when it was embroiled in the screwup of the month! {:<( Surely you guys don't want me to have to go and figure this out on my own!! My blood would be on your hands!! {:<) Here tis' again: *Bob, and others, I am installing a fuel injected Mazda rotary engine and trying to follow the Z-19 guidelines for dual battery, single alternator. Looking at the engine primary and secondary circuit, I need to install a primary and secondary fuel pump, plus I want to power the coils and the injectors off of the battery buss. How should I do this? I suppose I could take the fuel pump diode output and switch it to either of the two fuel pumps??? What about the coils and injectors? Should I set up similar circuits for them, or is there a better way to reduce parts??? I would appreciate any guidance you guys could give me. Thanks and Happy Thanksgiving! Bill B ________________________________________________________________________________
Date: Nov 25, 2006
OBAM, Heading select & alt hold, coupled GPS would be nice! Thanx Bob Verwey A35 Bonanza et al _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: 24 Nov 2006 08:25 PM Subject: Re: AeroElectric-List: Auto-pilots On 24-Nov-06, at 10:44 AM, Bob Verwey wrote: Hey listers, I'm looking around at auto-pilots. Obviously searched the net a bit, but still wondering, any recommendations from the list? Bob Verwey A35 Bonanza ZU-DLW Do you need an installation for a type-certificated aircraft, or amateur-built? What capabilities do you want? Wing leveler only? Heading select? Altitude hold? Airspeed hold? Vertical speed hold? Altitude preselect? Coupled ILS? Coupled GPS? Coupled approach VNAV? Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: One more Z-19 try!
> > >My original question has generated absolutely no interest!! Lots of >discussion of measurement systems, are you grounded when only one foot is >on the floor, etc., but my silly little question has been ignored for days >even when it was embroiled in the screwup of the month! {:<( > >Surely you guys don't want me to have to go and figure this out on my >own!! My blood would be on your hands!! {:<) > >Here tis' again: Yes it has. I've been pondering the underlying philosophy behind what I will offer later today. Bob . . . ________________________________________________________________________________
Date: Nov 25, 2006
I have the Pictorial Pilot and AlTrak so I vote for TruTrak! I would have invested in the ADI Pilot if it was available when I purchased. Both work great in my Lancair. Earl Bob Verwey wrote: > > OBAM, Heading select & alt hold, coupled GPS would be nice! > Thanx > Bob Verwey > A35 Bonanza et al > > > > ------------------------------------------------------------------------ > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Kevin Horton > *Sent:* 24 Nov 2006 08:25 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* Re: AeroElectric-List: Auto-pilots > > On 24-Nov-06, at 10:44 AM, Bob Verwey wrote: > >> Hey listers, >> I'm looking around at auto-pilots. Obviously searched the net a bit, >> but still wondering, any recommendations from the list? >> Bob Verwey >> A35 Bonanza ZU-DLW > > > Do you need an installation for a type-certificated aircraft, or > amateur-built? What capabilities do you want? Wing leveler only? > Heading select? Altitude hold? Airspeed hold? Vertical speed hold? > Altitude preselect? Coupled ILS? Coupled GPS? Coupled approach VNAV? > > Kevin Horton > RV-8 (Finishing Kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > * > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.kitlog.com">www.kitlog.com > href="http://www.homebuilthelp.com">www.homebuilthelp.com > href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > > * > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Nov 25, 2006
Unless one is familiar with rotary engines there is perhaps little that can be said. Will the thing continue to run and make sufficient power to stay airborne if either primary or secondary ignition or injectors fail? No point have multiple power sources if it just multiplies the things that can kill the engine. I'd suggest you look at what others have done and then ask specific questions. Have you looked at the Real World Solutions website? Ken Bill Bradburry wrote: > > > My original question has generated absolutely no interest!! Lots of > discussion of measurement systems, are you grounded when only one foot > is on the floor, etc., but my silly little question has been ignored > for days even when it was embroiled in the screwup of the month! {:<( > > Surely you guys don't want me to have to go and figure this out on my > own!! My blood would be on your hands!! {:<) > > Here tis' again: > > *Bob, and others, > I am installing a fuel injected Mazda rotary engine and trying to > follow the Z-19 guidelines for dual battery, single alternator. > Looking at the engine primary and secondary circuit, I need to > install a primary and secondary fuel pump, plus I want to power the > coils and the injectors off of the battery buss. > How should I do this? I suppose I could take the fuel pump diode > output and switch it to either of the two fuel pumps??? > What about the coils and injectors? Should I set up similar > circuits for them, or is there a better way to reduce parts??? > I would appreciate any guidance you guys could give me. > Thanks and Happy Thanksgiving! > Bill B ________________________________________________________________________________
Date: Nov 25, 2006
I'm a fan of TruTrak. http://www.trutrakflightsystems.com/ttfsproducts.html I've chosen TruTrak for my RV-6 project. I'm flying a Trio autopilot in our RV and it works well. http://www.trioavionics.com/index.htm You'll find happy customers of both companies out there. Pax, Ed -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob Verwey Sent: Saturday, November 25, 2006 6:42 AM Subject: RE: AeroElectric-List: Auto-pilots OBAM, Heading select & alt hold, coupled GPS would be nice! Thanx Bob Verwey A35 Bonanza et al _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton Sent: 24 Nov 2006 08:25 PM Subject: Re: AeroElectric-List: Auto-pilots On 24-Nov-06, at 10:44 AM, Bob Verwey wrote: Hey listers, I'm looking around at auto-pilots. Obviously searched the net a bit, but still wondering, any recommendations from the list? Bob Verwey A35 Bonanza ZU-DLW Do you need an installation for a type-certificated aircraft, or amateur-built? What capabilities do you want? Wing leveler only? Heading select? Altitude hold? Airspeed hold? Vertical speed hold? Altitude preselect? Coupled ILS? Coupled GPS? Coupled approach VNAV? Kevin Horton RV-8 (Finishing Kit) Ottawa, Canada http://www.kilohotel.com/rv8 href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/ch ref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.ma tronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Nov 25, 2006
Bill, First, you never said how you intend to manage the engine (ie fuel, timing, mixture, fuel pressure, and such). IMHO the eaisiest way to do so is to utilize the EMC (engine management computer). In doing so many of your queries will become mute. The computer generally will manage all of these and as far as powering from the battery bus, it doesn't care where the power comes from. Some systems (such as Ford) utilize primary and secondary fuel pumps, it depends on the operating parameters like timing advance curves, return fuel pressure, coil dwell, and in general the design of the system. If primary and secondary components are needed to maintain your system, the computer will be designed to manage them. If you just want redundancy, one of the easiest ways is to duplicaate that portion of the system with a seperate circuit. Having ran a hot rod shop for many, many years, we have done conversions on just about every kind of vehicle. As a general rule, we may modify the parameters of the computer and streamline the sensors but, we hardly ever try to re-invent the management system itself. A place to start with Mazda powerplants is Adkins Rotary Specialties out of Tacoma, Washington. There are several ohters that are really knowledgeable but, we had excellent luck working with them on Mazda type situations. As far as reprograming the computer, there are several outfits that can do just that. One of the one's we use can actually design and build a totally new EMC for the application if our requirements are that far outside of the O.E.M. spec.s.(really exotic). Just a suggestion... Jim Duckett, RV-7A ----- Original Message ----- From: "Bill Bradburry" <bbradburry(at)allvantage.com> Sent: Saturday, November 25, 2006 6:11 AM Subject: AeroElectric-List: One more Z-19 try! > > > My original question has generated absolutely no interest!! Lots of > discussion of measurement systems, are you grounded when only one foot is > on the floor, etc., but my silly little question has been ignored for days > even when it was embroiled in the screwup of the month! {:<( > > Surely you guys don't want me to have to go and figure this out on my > own!! My blood would be on your hands!! {:<) > > Here tis' again: > > *Bob, and others, > I am installing a fuel injected Mazda rotary engine and trying to follow > the Z-19 guidelines for dual battery, single alternator. Looking at the > engine primary and secondary circuit, I need to install a primary and > secondary fuel pump, plus I want to power the coils and the injectors > off of the battery buss. > How should I do this? I suppose I could take the fuel pump diode output > and switch it to either of the two fuel pumps??? > What about the coils and injectors? Should I set up similar circuits > for them, or is there a better way to reduce parts??? > I would appreciate any guidance you guys could give me. > Thanks and Happy Thanksgiving! > Bill B > > > ________________________________________________________________________________
Date: Nov 25, 2006
Bill, Your needs are similar to what us Subaru guys need to do. So while I'm not there yet, may I suggest you look at Eggenfellner.com for their solutions. The needs are very similar to a Rotary setup. They have many flying and many more under construction. Theirs is based on the Expbus but I think it may be changing. Z-19 based system is what I'm wanting to do but don't know enough yet to advise you. Bevan RV7A Eggenfellner H6 on order -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Sent: Saturday, November 25, 2006 10:01 AM Subject: Re: AeroElectric-List: One more Z-19 try! Unless one is familiar with rotary engines there is perhaps little that can be said. Will the thing continue to run and make sufficient power to stay airborne if either primary or secondary ignition or injectors fail? No point have multiple power sources if it just multiplies the things that can kill the engine. I'd suggest you look at what others have done and then ask specific questions. Have you looked at the Real World Solutions website? Ken Bill Bradburry wrote: > > > My original question has generated absolutely no interest!! Lots of > discussion of measurement systems, are you grounded when only one foot > is on the floor, etc., but my silly little question has been ignored > for days even when it was embroiled in the screwup of the month! {:<( > > Surely you guys don't want me to have to go and figure this out on my > own!! My blood would be on your hands!! {:<) > > Here tis' again: > > *Bob, and others, > I am installing a fuel injected Mazda rotary engine and trying to > follow the Z-19 guidelines for dual battery, single alternator. > Looking at the engine primary and secondary circuit, I need to > install a primary and secondary fuel pump, plus I want to power the > coils and the injectors off of the battery buss. > How should I do this? I suppose I could take the fuel pump diode > output and switch it to either of the two fuel pumps??? > What about the coils and injectors? Should I set up similar > circuits for them, or is there a better way to reduce parts??? > I would appreciate any guidance you guys could give me. > Thanks and Happy Thanksgiving! > Bill B ________________________________________________________________________________
Date: Nov 25, 2006
There are many happy customers of both the TruTrak and Trio autopilots. They both have alt hold and coupled lateral GPS. But, neither one offers heading select. They both have track select, using track from the GPS. This isn't the same as heading select, but you could manually turn to the desired heading, then have the autopilot hold the current track. If you want heading select, I think you would need to purchase a Blue Mountain EFIS system and their autopilot. Or maybe S-Tec + an expensive heading gyro with a heading output. Heading select requires a gyro system that outputs heading, which is generally fairly expensive. Some of the newer low cost EFIS systems have an AHRS with a magnetic field sensor to get heading, but I don't think any of them output the same type of signal as a gyro with heading output, so you can't use them in place of a mechanical gryo, unless the autopilot was built around the AHRS, as with Blue Mountain. Kevin Horton On 25 Nov 2006, at 09:41, Bob Verwey wrote: > > OBAM, Heading select & alt hold, coupled GPS would be nice! > Thanx > Bob Verwey > A35 Bonanza et al > > > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] On Behalf Of Kevin Horton > Sent: 24 Nov 2006 08:25 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Auto-pilots > > On 24-Nov-06, at 10:44 AM, Bob Verwey wrote: > >> Hey listers, >> I'm looking around at auto-pilots. Obviously searched the net a >> bit, but still wondering, any recommendations from the list? >> Bob Verwey >> A35 Bonanza ZU-DLW > > > Do you need an installation for a type-certificated aircraft, or > amateur-built? What capabilities do you want? Wing leveler only? > Heading select? Altitude hold? Airspeed hold? Vertical speed hold? > Altitude preselect? Coupled ILS? Coupled GPS? Coupled approach VNAV? > > Kevin Horton > RV-8 (Finishing Kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > > > href="http://www.aeroelectric.com">www.aeroelectric.com > href="http://www.buildersbooks.com">www.buildersbooks.com > href="http://www.kitlog.com">www.kitlog.com href="http:// > www.homebuilthelp.com">www.homebuilthelp.com href="http:// > www.matronics.com/contribution">http://www.matronics.com/ > chref="http://www.matronics.com/Navigator?AeroElectric-List">http:// > www.matronics.com/Navigator?AeroElectric-List _- > http://www.matronics.com/Navigator?AeroElectric-List _- > =========================================================== ________________________________________________________________________________
Date: Nov 25, 2006
One way to do multiple power sources for critical systems is to have power from each bus going through a diode to the device of interest. That way the critical system will continue to receive power even if one of the power sources fails, but a fault on one bus cannot take out the other bus, as the diodes provide protection. This approach is used quite a bit in type-certificated aircraft with critical systems. The critical systems should also be designed so that no single failure of the system can prevent successful completion of the flight. And, there should be a way to check for dormant failures on some periodic basis (e.g. if you use diodes to provide multiple power sources - you would want some way to confirm that both diodes were functional). Kevin Horton On 25 Nov 2006, at 13:01, Ken wrote: > > Unless one is familiar with rotary engines there is perhaps little > that can be said. Will the thing continue to run and make > sufficient power to stay airborne if either primary or secondary > ignition or injectors fail? No point have multiple power sources if > it just multiplies the things that can kill the engine. I'd > suggest you look at what others have done and then ask specific > questions. Have you looked at the Real World Solutions website? > Ken > > > Bill Bradburry wrote: > >> >> >> My original question has generated absolutely no interest!! Lots >> of discussion of measurement systems, are you grounded when only >> one foot is on the floor, etc., but my silly little question has >> been ignored for days even when it was embroiled in the screwup of >> the month! {:<( >> >> Surely you guys don't want me to have to go and figure this out on >> my own!! My blood would be on your hands!! {:<) >> >> Here tis' again: >> >> *Bob, and others, >> I am installing a fuel injected Mazda rotary engine and trying >> to follow the Z-19 guidelines for dual battery, single >> alternator. Looking at the engine primary and secondary >> circuit, I need to install a primary and secondary fuel pump, >> plus I want to power the coils and the injectors off of the >> battery buss. >> How should I do this? I suppose I could take the fuel pump >> diode output and switch it to either of the two fuel pumps??? >> What about the coils and injectors? Should I set up similar >> circuits for them, or is there a better way to reduce parts??? >> I would appreciate any guidance you guys could give me. >> Thanks and Happy Thanksgiving! >> Bill B > ________________________________________________________________________________
Date: Nov 24, 2006
If I can determine and find the right stepper motors, I plan to build my own :) David M. Bob Verwey wrote: > Hey listers, > I'm looking around at auto-pilots. Obviously searched the net a bit, > but still wondering, any recommendations from the list? > > Bob Verwey > A35 Bonanza ZU-DLW > > > >------------------------------------------------------------------------ > > > > ________________________________________________________________________________
Date: Nov 25, 2006
Subject: multiple engine leads from one source
Does anyone know if you can pull multiple leads off of CHT probes, EGT probes, and Oil Temp to feed two different engine analysis systems. I have a Vision Micro system VM1000 and now a new Grand Rapids EIS. I would Like to use both as back up but would also like not to have to install duplicate CHT, EGT, oil temp Probes. Thanks Tim ________________________________________________________________________________
Date: Nov 26, 2006
Bill, did you look at the drawing I posted on the Rotary list, is there some problem that you see with my system? Greg > > Bill, > > Your needs are similar to what us Subaru guys need to do. So while I'm > not > there yet, may I suggest you look at Eggenfellner.com for their solutions. > The needs are very similar to a Rotary setup. They have many flying and > many more under construction. Theirs is based on the Expbus but I think > it > may be changing. Z-19 based system is what I'm wanting to do but don't > know > enough yet to advise you. > > Bevan > RV7A > Eggenfellner H6 on order > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken > Sent: Saturday, November 25, 2006 10:01 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: One more Z-19 try! > > > Unless one is familiar with rotary engines there is perhaps little that > can > be said. Will the thing continue to run and make sufficient power to stay > airborne if either primary or secondary ignition or injectors fail? > No point have multiple power sources if it just multiplies the things that > can kill the engine. I'd suggest you look at what others have done and > then > ask specific questions. Have you looked at the Real World Solutions > website? > Ken > > > Bill Bradburry wrote: > >> >> >> My original question has generated absolutely no interest!! Lots of >> discussion of measurement systems, are you grounded when only one foot >> is on the floor, etc., but my silly little question has been ignored >> for days even when it was embroiled in the screwup of the month! {:<( >> >> Surely you guys don't want me to have to go and figure this out on my >> own!! My blood would be on your hands!! {:<) >> >> Here tis' again: >> >> *Bob, and others, >> I am installing a fuel injected Mazda rotary engine and trying to >> follow the Z-19 guidelines for dual battery, single alternator. >> Looking at the engine primary and secondary circuit, I need to >> install a primary and secondary fuel pump, plus I want to power the >> coils and the injectors off of the battery buss. >> How should I do this? I suppose I could take the fuel pump diode >> output and switch it to either of the two fuel pumps??? >> What about the coils and injectors? Should I set up similar >> circuits for them, or is there a better way to reduce parts??? >> I would appreciate any guidance you guys could give me. >> Thanks and Happy Thanksgiving! >> Bill B > > > ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: Second Pump Option on Z-19
> > > >> >> >>My original question has generated absolutely no interest!! Lots of >>discussion of measurement systems, are you grounded when only one foot is >>on the floor, etc., but my silly little question has been ignored for >>days even when it was embroiled in the screwup of the month! {:<( >> >>Surely you guys don't want me to have to go and figure this out on my >>own!! My blood would be on your hands!! {:<) >> >>Here tis' again: > > Yes it has. I've been pondering the underlying > philosophy behind what I will offer later today. Without knowing more about how tollerant your engine engine is with various failures of hardware, I'm presuming that you're interested in Figure Z-19 but noted that it supports only one fuel pump. After some pondering of the failure modes, it seems practical that your second pump simply be added to one of the battery busses (in this case the Main Battery bus) as shown in revision M to Figure Z-19 as posted here . . . http://www.aeroelectric.com/PPS/ACAD_Architecture_Dwgs/Z19M.dwg http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19M_1.pdf http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z19M_2.pdf The primary pump and ECS both get supplied from dual power sources with no single points of failure upstream of the diodes as before. Obviously, failure of #1 pump stops the engine so if you want a second pump, it's sufficient to power it from one of the battery busses through it's own switch. I presume you'll have a fuel pressure gage so to pre-flight, you turn on the #2 pump momentarily to watch for rise in fuel pressure before you power up the engine using the #1 pump in normal operation. Bob . . . ________________________________________________________________________________
Date: Nov 25, 2006
Subject: Re: multiple engine leads from one source
>Does anyone know if you can pull multiple leads off of CHT probes, EGT >probes, and Oil Temp to feed two different engine analysis systems. I >have a Vision Micro system VM1000 and now a new Grand Rapids EIS. I >would Like to use both as back up but would also like not to have to >install duplicate CHT, EGT, oil temp Probes. Thanks Tim You can . . . IF. It's dependent upon the signal conditioning circuitry in the two instruments. Some systems will tolerate paralleling as you've suggested but without seeing schematics of the two systems and/or talking with the designers, it's not possible to make a recommendation. Bob . . . ________________________________________________________________________________
Date: Nov 25, 2006
Hi Kevin, Almost right.....but...Even the lowest priced TruTrak has an internal magentometer (along with a little gyro/accelerometer) that allows you to fly the airplane in magentic heading mode and select the heading in 1 degree increments, or you can steer to a new magnetic heading. Naturally you have to calibrate the thing before doing that, but the TruTrak's have been this way since day one. I'm not 100% sure about Trio's AP's (even though I sell those too) but I don't have one of theirs installed in my plane....whereas I've been flying behind the TruTrak stuff for awhile now. All of the above can be accomplished with the GPS removed from the aircraft. Then it won't follow a course, but the magenetic heading is the "backup" in case the GPS signal gets inturrepted or doesn't work, etc... It's much nicer to have the GPS hooked to either of them, put a flightplan or "direct 2" in the GPS, hit the NAV button and let go! Either way, you'll be happy! Cheers, Stein. >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin >Horton >Sent: Saturday, November 25, 2006 2:26 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Auto-pilots > > > > >There are many happy customers of both the TruTrak and Trio >autopilots. They both have alt hold and coupled lateral GPS. But, >neither one offers heading select. They both have track select, >using track from the GPS. This isn't the same as heading select, but >you could manually turn to the desired heading, then have the >autopilot hold the current track. > >If you want heading select, I think you would need to purchase a Blue >Mountain EFIS system and their autopilot. Or maybe S-Tec + an >expensive heading gyro with a heading output. > >Heading select requires a gyro system that outputs heading, which is >generally fairly expensive. Some of the newer low cost EFIS systems >have an AHRS with a magnetic field sensor to get heading, but I don't >think any of them output the same type of signal as a gyro with >heading output, so you can't use them in place of a mechanical gryo, >unless the autopilot was built around the AHRS, as with Blue Mountain. > >Kevin Horton > > ________________________________________________________________________________
Date: Nov 25, 2006
Stein, I did look at the TruTrak web site before posting, and found no mention of a heading select mode, but digging deeper now I see some mention in the Quick Reference Guide for the DigiTrak. The info in the Quick Reference Guide is a bit spartan though. If you want to fly a particular heading (vice a track), how do you tell the autopilot to turn to that heading? Can the heading mode be used if the GPS is functional? Kevin On 25 Nov 2006, at 19:47, SteinAir, Inc. wrote: > > > Hi Kevin, > > Almost right.....but...Even the lowest priced TruTrak has an internal > magentometer (along with a little gyro/accelerometer) that allows > you to fly > the airplane in magentic heading mode and select the heading in 1 > degree > increments, or you can steer to a new magnetic heading. Naturally > you have > to calibrate the thing before doing that, but the TruTrak's have > been this > way since day one. I'm not 100% sure about Trio's AP's (even > though I sell > those too) but I don't have one of theirs installed in my > plane....whereas > I've been flying behind the TruTrak stuff for awhile now. > > All of the above can be accomplished with the GPS removed from the > aircraft. > Then it won't follow a course, but the magenetic heading is the > "backup" in > case the GPS signal gets inturrepted or doesn't work, etc... It's > much nicer > to have the GPS hooked to either of them, put a flightplan or > "direct 2" in > the GPS, hit the NAV button and let go! > > Either way, you'll be happy! > > Cheers, > Stein. > > >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >> Kevin >> Horton >> Sent: Saturday, November 25, 2006 2:26 PM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Auto-pilots >> >> >> >> >> There are many happy customers of both the TruTrak and Trio >> autopilots. They both have alt hold and coupled lateral GPS. But, >> neither one offers heading select. They both have track select, >> using track from the GPS. This isn't the same as heading select, but >> you could manually turn to the desired heading, then have the >> autopilot hold the current track. >> >> If you want heading select, I think you would need to purchase a Blue >> Mountain EFIS system and their autopilot. Or maybe S-Tec + an >> expensive heading gyro with a heading output. >> >> Heading select requires a gyro system that outputs heading, which is >> generally fairly expensive. Some of the newer low cost EFIS systems >> have an AHRS with a magnetic field sensor to get heading, but I don't >> think any of them output the same type of signal as a gyro with >> heading output, so you can't use them in place of a mechanical gryo, >> unless the autopilot was built around the AHRS, as with Blue >> Mountain. >> >> Kevin Horton >> >> >> > > ________________________________________________________________________________
Subject: Hugo Rv10#40456
Date: Nov 25, 2006
My apoligize to Robert Nuckolls in write wrong he's name. Hugo ________________________________________________________________________________
Date: Nov 25, 2006
As usual you are wise beyone your years! It's only a very basic magnetic heading...you have to 'point' the airplane to a specific heading of sorts, and once engaged a click of the knob or turn of the wheel (on my pic/pilot) moves you one degree. You can't tell it to go to a specific heading without a known starting point....hopefully referenced to your compass or something. It's mainly a backup thing in case everything else in your airplane fails (or you're me and you forgot to plug in the GPS then the batteries go dead)! To use it with the GPS functional and installed, you need to remove the GPS data feed, either by shutting the GPS off or turning of the NMEA data stream. Hope that clears things up. Like I said....you were kind of right - I just had to point out that one little bit. Of course it's not the most powerful bit of functionality in the world, but then it's not meant to be. It's supposed to cover your rear in the case of other things failing. Like I said, I'm not 100% sure about the Trio, and really not sure about how the BMA in reality actually provides that info (and if it even really does or still uses some GPS input), but I do know more about the TTAP's. Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Kevin Horton Sent: Saturday, November 25, 2006 8:05 PM Subject: Re: AeroElectric-List: Auto-pilots Stein, I did look at the TruTrak web site before posting, and found no mention of a heading select mode, but digging deeper now I see some mention in the Quick Reference Guide for the DigiTrak. The info in the Quick Reference Guide is a bit spartan though. If you want to fly a particular heading (vice a track), how do you tell the autopilot to turn to that heading? Can the heading mode be used if the GPS is functional? Kevin ________________________________________________________________________________
Date: Nov 25, 2006
Hi Tim, With some probes yes, and others no. The most likely answer to your question is no. I'm a bit confused to begin with why you have 2 engine monitors (both have quite a good history of reliability) with GRT having literally THOUSANDS of those units flying with little to know problems that I've known about. Splicing CHT's & EGT's could be a slippery slope...there are many different kinds of wire & probes between mfgrs (such as shielded/unshielded, grounded/ungrounded, solid/stranded, etc..). All are setup to read certain specifics. Paralleling onto them could cause lots of problems. Some transducers however allow you to split their signals. It's much easier on powered/excited probes than plain old resistive ones. In basic resistive probes if you "tack on" other things it can significantly vary the readings... Hope that helps. In the end I'd just say stay away from that and decide which engine monitor to use. Two of them is frankly a bit of overkill in my opinion. If the fan is turning you're most likely ok :) Duplicate CHT's & EGT's don't buy you much - you can't possibly watch all of each systems indications all the time anyway. If they don't match, now you have to try and decide which one is the "master" or is "right". If you're doing this when you have a problem then you're not flying the plane. Anyway, enough of my bantering. I get this question asked with surprising regularity and I still can't figure it out! Sorry for being sarcastic, that's not my intent. I'm just trying to point out that with added complexity comes reduced reliability and little gain in form or in function. Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of TimRhod(at)aol.com Sent: Saturday, November 25, 2006 4:06 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: multiple engine leads from one source Does anyone know if you can pull multiple leads off of CHT probes, EGT probes, and Oil Temp to feed two different engine analysis systems. I have a Vision Micro system VM1000 and now a new Grand Rapids EIS. I would Like to use both as back up but would also like not to have to install duplicate CHT, EGT, oil temp Probes. Thanks Tim ________________________________________________________________________________
Date: Nov 25, 2006
Thanks for the input Tim ________________________________________________________________________________
Date: Nov 25, 2006
Kevin Horton wrote: > (snip) > Heading select requires a gyro system that outputs heading, which is > generally fairly expensive. Some of the newer low cost EFIS systems > have an AHRS with a magnetic field sensor to get heading, but I don't > think any of them output the same type of signal as a gyro with > heading output, so you can't use them in place of a mechanical gryo, > unless the autopilot was built around the AHRS, as with Blue Mountain. > > Kevin Horton Hi Kevin & Steine I hope I am not wrong here but I have been told that the GRT Sport EFIS that I am installing will output heading, VOR and GPS signals to the Trutrak autopilot all in the same RS232 format as the normal GPS nav output. Therefore I am expecting to have GPS nav mode, heading select or VOR/ILS tracking from my Trutrak ADI 2 when it is in Nav mode . This requires the $400 moving map option in the Sport. In my installation the A/P will normally get all inputs from EFIS but is switchable directly to the GPS output for nav if the EFIS fails. George in Langley BC 7A GRT Sport & Trutrak ADI-2. ________________________________________________________________________________
Date: Nov 25, 2006
You know the old saying: never use just 2 watches... David M. Stein Bruch wrote: > Hi Tim, > > With some probes yes, and others no. The most likely answer to your > question is no. I'm a bit confused to begin with why you have 2 > engine monitors (both have quite a good history of reliability) with > GRT having literally THOUSANDS of those units flying with little to > know problems that I've known about. Splicing CHT's & EGT's could be > a slippery slope...there are many different kinds of wire & probes > between mfgrs (such as shielded/unshielded, grounded/ungrounded, > solid/stranded, etc..). All are setup to read certain specifics. > Paralleling onto them could cause lots of problems. Some transducers > however allow you to split their signals. It's much easier on > powered/excited probes than plain old resistive ones. In basic > resistive probes if you "tack on" other things it can significantly > vary the readings... > > Hope that helps. In the end I'd just say stay away from that and > decide which engine monitor to use. Two of them is frankly a bit of > overkill in my opinion. If the fan is turning you're most likely ok > :) Duplicate CHT's & EGT's don't buy you much - you can't possibly > watch all of each systems indications all the time anyway. If they > don't match, now you have to try and decide which one is the "master" > or is "right". If you're doing this when you have a problem then > you're not flying the plane. > > Anyway, enough of my bantering. I get this question asked with > surprising regularity and I still can't figure it out! Sorry for > being sarcastic, that's not my intent. I'm just trying to point out > that with added complexity comes reduced reliability and little gain > in form or in function. > > Cheers, > Stein. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > TimRhod(at)aol.com > Sent: Saturday, November 25, 2006 4:06 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: multiple engine leads from one source > > Does anyone know if you can pull multiple leads off of CHT probes, > EGT probes, and Oil Temp to feed two different engine analysis > systems. I have a Vision Micro system VM1000 and now a new Grand > Rapids EIS. I would Like to use both as back up but would also > like not to have to install duplicate CHT, EGT, oil temp Probes. > Thanks Tim > > >href="http://www.aeroelectric.com">www.aeroelectric.com >href="http://www.buildersbooks.com">www.buildersbooks.com >href="http://www.kitlog.com">www.kitlog.com >href="http://www.homebuilthelp.com">www.homebuilthelp.com >href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > > >------------------------------------------------------------------------ > > > > ________________________________________________________________________________
Subject: Re: Icom A200-Help!
Date: Nov 25, 2006
I've been informed by a number of people that the A200 is identical design to the BendixKing KY96. it certainly seems functionally identical and I recall the trays fit each other's radio. Bob, if you do get that icom manual pse confirm ? I'm a radio tech and got some of the BK manual from the avionics dealers (they quite rightly weren't keen to give me the whole manual) every time i'm asked to set up an A200 I just do as I have for the BK. The mod. level adjust pot works backwards too, just like the original- talk about attention to detail! Therefore any wiring setup used for the BK hot mic intercom should apply to the A200. Ralph, C150 / CH701 -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77001#77001 ________________________________________________________________________________
Date: Nov 26, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Hugo's antenna questions
> >Hi All, >I 'm installing a Comant antenna in the top cabin of my RV10(composite)it >is a VHF-GPS-Weather data, while I have no problem in doing so in the >metal part ,in the cabin(after I read Bob Nicklaus booK) it looks like I >must install a ground plane inside the cabin. >The book is very fast in explaining,(cut a one inch cooper and weld ) >(call 3m for materials) and so on,it does not mention the lengths of each >leg nor the diameter of the round plate, does it need to be aluminum or >copper? Radials under an antenna should be the same length as the antenna itself. For example, If the comm antenna is 23" in height above the skin, the radials under it should describe a circle (or skeleton of a circle) that has a radius of 23". Therefore the disk may be of any size and the radials of any length as long as distance from tip of a radial measured to the center of the disk is the same as the height of the antenna. The disk serves two purposes: Provide a doubler under the antenna and an radio frequency ground for the antenna. You can make the disk and radials out of aluminum but you'd have to rivet the ends of the radials to the disk to get a good electrical connection. I prefer to use copper or brass. If you don't need to add structural doubler, the disk may be quite thin . . . .005" brass shim stock would work. When you use copper or brass and make the radials from copper or brass, one may attach the radials to the disk by soldering which provides an electrical connection with great longevity. In cases were the radials are short (2.6" under a transponder antenna) then the entire ground plane can be one solid disk. Here the disk may be aluminum, brass or copper. >Thanks >The book is very good ,but its still way beyoong me since I don't want to >became an electronic engineer before learning how to build an airplane, >I'm still thinking many builders want to learn how to build a panel >without the necessity of knowing how an alternator is built ,or how many >inches are the quarter wave(watever that means)I thinks the first >technician who will be able to show pictures at what a diode look like and >wich point needs to be solder ,will sale a tons of books,and don't try to >convert every body in master panel designers. The AeroElectric Connection is not an attempt to convert anyone to anything. It's simply a collection of simple ideas that offers more than the traditional "cook books" bur falls far short of making an engineer out of anyone. It was crafted with the idea that the informed builder is the most confident builder both in terms of building and operating his/her airplane. A great many of our fellow pilots operate their airplanes much as they do their cars. The machines are just appliances with knobs, levers, and fuel tanks. They are competent enough in operating the machine to get a license but have little if any knowledge about how it works (and perhaps don't care). >Its my personal opinion only. If you don't believe you received fair value for your purchase, just let me know and I'll refund your money. Bob . . . ________________________________________________________________________________
Date: Nov 26, 2006
Hugo, why have you decided to mount the Com antenna on the top? most of the transmissions will be between the aircraft and ground based stations, I believe that most of the RV-10 builders are mounting their Com antennas on the bottom of the aircraft where they also have the advantage of the metal skin. FWIW Deems Davis # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ ________________________________________________________________________________
Date: Nov 26, 2006
> The commant in the roof is a triple in one ,is my 2nd VHF(#1 is at the bottom ,bend commant),is my GPS and because soon or later I will need WX data it does to.It is very expensive about 750.00 ,but still cheaper if purchase separate ,I was tinking with one in the cabin I will reduce some drag,plus in some unfortunate event something hits the bottom,still have the top one. hugo > From: Deems Davis <deemsdavis(at)cox.net> > Date: 2006/11/26 Sun AM 10:26:01 EST > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Hugo's antenna questions > > > > Hugo, why have you decided to mount the Com antenna on the top? most of > the transmissions will be between the aircraft and ground based > stations, I believe that most of the RV-10 builders are mounting their > Com antennas on the bottom of the aircraft where they also have the > advantage of the metal skin. FWIW > > Deems Davis # 406 > Finishing - ( A Misnomer ! ) > http://deemsrv10.com/ > > > > > ________________________________________________________________________________
Date: Nov 26, 2006
Thanks for the answer. Please don't misunderstend me, the book is great, and I still think you are a real gentleman, the same opinion I have when I talked to you at the time I ordered the book, even if I sound sarcastic (I have the same problem at home with my kids,it runs in my family blood.) You still answered properly ,like every time somebody in the list tries to make you loose yor temper. My only purpose is the positive criticism,I think it is never too late to learn from others,I'm 50 and still probably do not know anything. Being very knowledgeable in some profession does not mean it is easy to be a teacher,you see ,in my opinion when you try to teach somebody with no notion of the subject matter ,you must to go down to their level and start from there ,I hope you don't still missunderstand me ,I wish I can help you in improve the manual, so that the common mortals guys ,who one day decided to build an airplane will be able to manufacture their panels,and I thinks is very easy Thanks for the help. Hugo Terrosa Ps. If you need a manual ,you must purchase one,because I don't think I'll be sending mine back. > > From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> > Date: 2006/11/26 Sun AM 09:19:15 EST > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Hugo's antenna questions > > > > > > >Hi All, > >I 'm installing a Comant antenna in the top cabin of my RV10(composite)it > >is a VHF-GPS-Weather data, while I have no problem in doing so in the > >metal part ,in the cabin(after I read Bob Nicklaus booK) it looks like I > >must install a ground plane inside the cabin. > >The book is very fast in explaining,(cut a one inch cooper and weld ) > >(call 3m for materials) and so on,it does not mention the lengths of each > >leg nor the diameter of the round plate, does it need to be aluminum or > >copper? > > Radials under an antenna should be the same length as the > antenna itself. For example, If the comm antenna is > 23" in height above the skin, the radials under it should > describe a circle (or skeleton of a circle) that has > a radius of 23". Therefore the disk may be of any size > and the radials of any length as long as distance from > tip of a radial measured to the center of the disk is > the same as the height of the antenna. > > The disk serves two purposes: Provide a doubler under the > antenna and an radio frequency ground for the antenna. You > can make the disk and radials out of aluminum but you'd > have to rivet the ends of the radials to the disk to get > a good electrical connection. I prefer to use copper or brass. > If you don't need to add structural doubler, the disk > may be quite thin . . . .005" brass shim stock would > work. > > When you use copper or brass and make the radials > from copper or brass, one may attach the radials to > the disk by soldering which provides an electrical > connection with great longevity. > > In cases were the radials are short (2.6" under > a transponder antenna) then the entire ground plane > can be one solid disk. Here the disk may be aluminum, > brass or copper. > > >Thanks > >The book is very good ,but its still way beyoong me since I don't want to > >became an electronic engineer before learning how to build an airplane, > >I'm still thinking many builders want to learn how to build a panel > >without the necessity of knowing how an alternator is built ,or how many > >inches are the quarter wave(watever that means)I thinks the first > >technician who will be able to show pictures at what a diode look like and > >wich point needs to be solder ,will sale a tons of books,and don't try to > >convert every body in master panel designers. > > The AeroElectric Connection is not an attempt to > convert anyone to anything. It's simply a collection > of simple ideas that offers more than the traditional > "cook books" bur falls far short of making an engineer > out of anyone. > > It was crafted with the idea that the informed builder > is the most confident builder both in terms of building > and operating his/her airplane. A great many of our > fellow pilots operate their airplanes much as they do > their cars. The machines are just appliances with knobs, > levers, and fuel tanks. They are competent enough in > operating the machine to get a license but have little > if any knowledge about how it works (and perhaps don't > care). > > >Its my personal opinion only. > > If you don't believe you received fair value for > your purchase, just let me know and I'll refund your > money. > > > Bob . . . > > > > > > ________________________________________________________________________________
Date: Nov 26, 2006
> >Thanks for the answer. >Please don't misunderstend me, >the book is great, and I still think you are a real gentleman, the same >opinion I have when I talked to you at the time I ordered the book, even >if I sound sarcastic (I have the same problem at home with my kids,it runs >in my family blood.) You still answered properly ,like every time somebody >in the list tries to make you loose yor temper. My only purpose is the >positive criticism,I think it is never too late to learn from others,I'm >50 and still probably do not know anything. Being very knowledgeable in >some profession does not mean it is easy to be a teacher,you see ,in my >opinion when you try to teach somebody with no notion of the subject >matter ,you must to go down to their level and start from there ,I hope >you don't still missunderstand me ,I wish I can help you in improve the >manual, so that the common mortals guys ,who one day decided to build an >airplane will be able to manufacture their panels,and I thinks is very easy >Thanks for the help. >Hugo Terrosa Not at all sir. I'm just making sure that 1300 or so other folks on the List understand too! Bob . . . ________________________________________________________________________________
Subject: Re: Antennaes and primer
Date: Nov 26, 2006
Well for the most part it wasn't the primer. Sanded the primer of and the GPSs got a little better but com nav stil were pretty much TU. Replaced all the coax connectors I had put in, still no joy. Hooked up my portable nav/com to the antenna cables and it worked great.Bench checked th com/nav... no problems. Must be the tray...not quite. When I purchased the units Garmin compels their suppliers to wire the trays with pigtails including antennaes. You guessed it the pigtail coaxs were poorly assembled with the inner insulator melted. The com had 2 shield whiskers touching the center conductor. The nav was a dead short. Thanks to all for the input. -------- Milt N395V F1 Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77086#77086 ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Direct e-mails to Bob . . .
I just "cleaned" the in-basket for the personal e-mail account going back to June. I note that I had to "dump" about 200 direct e-mails where individuals were seeking one-on-one attention . . . mostly on topics that have been or should be discussed here on the List. I do answer a goodly number of direct e-mails but I encourage everyone to post their questions on the List . . . for several reasons. First is sharing the conversation with a whole lot of builders who find value in watching these exchanges go by. Second, there may be multiple individuals with good answers too . . . if the exchange happens in my personal e-mail "closet", the benefits of community wisdom are lost. Finally, because I believe the List is so important, I put any available time on the List first. Direct e-mails on airplane building take a back seat and once they're more than a week old, they're quite likely to drop entirely off my radar screen. I'm sure that some of those 200 odd folks are disappointed but if any of you didn't hear from me, it's not out of disrespect or even an unwillingness to be helpful. There are only so many hours in the day. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: 275-218 DPDT relay wiring
Date: Nov 26, 2006
Anyone has wiring diagram for wiring up Radio Shack 275-218 DPDT relay to a coolie hat switch used for trim? There are two coil terminals.. I assumed one for each switch position (eg. up/down).. but do they need to be "energized" (feeding it +12V)? Both? Only one? I could try a few different things, but would rather ask before I start making smoke in the garage :) What I've got so far is: 1 & 2 are jumpered together and go to ground. 3 & 4 jumpered together and go to +12. 5 & 6 are outputs that go to the motor.. just not sure about these two coil terminals (7 & 8). Thanks! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77135#77135 ________________________________________________________________________________
Subject: Battery Sizing
Date: Nov 26, 2006
Greetings Fellow Builders, Have couple straight forward questions on sizing for a duel battery set up in a F1 Rocket with high compression (10 to 1) AEIO540 Lycoming, duel Plasma III Ignitions, duel B&C alternators a 60 amp and a 20 amp. Right now for electical I'm just building the battery box which will be slightly different that the plans since I want to go with (2) B&C 12V 16 A.H. batteries rather than the single 35 A.H. battery the plans call for. I plan on building the (Z-14) Dual Battery, Duel Alternator, Split Bus type system out of Bob's book down the road in 6 months or so. Questions: 1) will the duel battery set up 32 A.H. total still be enough in most cold weather conditions maybe down below freezing 15 or 20 flights a year? I'm running a B & C NCS206-149-12 starter. 2) Any special mounting tips two be aware of with two batteries? Keep a space between them? Thanks Ralph Hardin Seattle Wa. ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Foil Shielding
>Bob.. >Can you suggest a good way to ground shielded wires that use foil for >shielding? I like your method for the braided wire, can find no reference >for foil shielding. Thanks. As you've observed, wires may be "shielded" by a variety of techniques. The earliest shielding was accomplished with an over-braid of fine wires. Obviously, braided wires cannot offer 100% coverage for shielding effectiveness. Know that for the vast majority of things we do in airplanes requiring shielded conductors, one layer of tightly overbraided wires will achieve 80% or better coverage and is just fine. I think back in 60' or early 70's, Belden Wire and cable figured out a simpler way to increase shielding coverage and simplify construction by using thin aluminum foil to instead of overbraid. One problem was that the aluminum foil was a muther-bear to make connections so a "drain wire" was added to the stranding makeup of the cable. The drain wire may be inside or outside the foil and is always uninsulated so that it makes contact with the foil over length of the cable. See a couple of documents on my website at: http://www.aeroelectric.com/Mfgr_Data/Wire/Belden The short answer to your question is, "Don't try to mess with the aluminum foil as a conductor. Find the Drain Wire and use it to achieve connection to the foil." Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Re: 275-218 DPDT relay wiring
> >Anyone has wiring diagram for wiring up Radio Shack 275-218 DPDT relay to >a coolie hat switch used for trim? > >There are two coil terminals.. I assumed one for each switch position (eg. >up/down).. but do they need to be "energized" (feeding it +12V)? Both? >Only one? I could try a few different things, but would rather ask before >I start making smoke in the garage :) > >What I've got so far is: 1 & 2 are jumpered together and go to ground. 3 >& 4 jumpered together and go to +12. 5 & 6 are outputs that go to the >motor.. just not sure about these two coil terminals (7 & 8). See http://www.aeroelectric.com/PPS/Flight/Trim/trim2.pdf You need two relays to do the architecture above. Use 1/2 (one pole) of each relay to control the + up and + down side of the trim actuator. Bob . . . ________________________________________________________________________________
Date: Nov 26, 2006
Thanks.. apparently, can be done by doing this, which avoids using 2 relays: http://www.infinityaerospace.com/Flap.pdf that's what I was looking for exactly. PS. Bob, it'd be very helpful to add this to the PPS drawings... beats buying/using 2 relays. -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77175#77175 ________________________________________________________________________________
Date: Nov 26, 2006
> >Thanks.. apparently, can be done by doing this, which avoids using 2 relays: > > http://www.infinityaerospace.com/Flap.pdf > > >that's what I was looking for exactly. > > >PS. Bob, it'd be very helpful to add this to the PPS drawings... beats >buying/using 2 relays. Not if you want to use the coolie hat switch. The single relay circuit runs motor current through the pilot's control switch. The coolie hat switch would certainly not withstand the current required to run a flap motor. It might be okay with the current to run a Ray-Allen actuator but one would have to publish that caveat on any drawing of this architecture to warn the builder that not only the relay but the switch needs to be rated for motor load currents. This is why I publish the generic 2-relay drawings you see on the website. This architecture ALWAYS works with ANY motor and switch combination because the switch handles relay coil currents only. The 2-relay architecture also provides dynamic braking by putting a dead short across a spinning motor when the motor is de-energized. Reduces coast against the limit switches. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Re: Battery Sizing
>Greetings Fellow Builders, > >Have couple straight forward questions on sizing for a duel battery set up >in a F1 Rocket with high compression (10 to 1) AEIO540 Lycoming, duel >Plasma III Ignitions, duel B&C alternators a 60 amp and a 20 amp. > >Right now for electical I'm just building the battery box which will be >slightly different that the plans since I want to go with (2) B&C 12V 16 >A.H. batteries rather than the single 35 A.H. battery the plans call for. >I plan on building the (Z-14) Dual Battery, Duel Alternator, Split Bus >type system out of Bob's book down the road in 6 months or so. > >Questions: >1) will the duel battery set up 32 A.H. total still be enough in most cold >weather conditions maybe down below freezing 15 or 20 flights a year? I'm >running a B & C NCS206-149-12 starter. If the batteries are up front and you plan to use both batteries for cranking, then there's zero risk of problems. Actually, one of those batteries will crank the engine nicely. It's wire size/lengths that will cripple an otherwise capable battery. >2) Any special mounting tips two be aware of with two batteries? Keep a >space between them? They can mount tight. If they have lead posts, be sure to use nice soft connecting wires . . . like 4AWG welding cable irrespective of what size/style of fat wire is used elsewhere. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 26, 2006
Thanks.. that makes sense.. I'm using this for trim (Ray Allen).. not flaps.. -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77191#77191 ________________________________________________________________________________
Date: Nov 27, 2006
Subject: List of Contributors Coming Soon - Make Sure You're
Listed! Dear Listers, The List of Contributors (LOC) is just around the corner! On December 1st I post a list of everyone that so generously made a Contribution to support the Lists. Its my way of publicly thanking everyone that took a minute to show their appreciation for the Lists. As a number of people have pointed out in their Contribution comments, the List seems at least as valuable of a building/flying/recreating tool as a typical your magazine subscription! And how interactive is a magazine, after all? :-) Won't you take minute and assure that your name is on the upcoming LOC? Tell others that you appreciate the Lists. Making a Contribution to support the Lists is fast and easy using your Visa, MasterCard, or Paypal account: http://www.matronics.com/contribution Or, by droping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) I would like to thank everyone that has so generously made a Contribution thus far during this year's List Fund Raiser! Remember that its YOUR support that keeps these Lists running and improving! Don't forget to include a little comment about how the Lists have helped you! Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 26, 2006
Subject: Re: Icom A200 - Question for Stein
> >I've been informed by a number of people that the A200 is identical design >to the BendixKing KY96. it certainly seems functionally identical and I >recall the trays fit each other's radio. Bob, if you do get that >icom manual pse confirm ? I'm a radio tech and got some of the BK manual >from the avionics dealers (they quite rightly weren't keen to give me the >whole manual) every time i'm asked to set up an A200 I just do as I have >for the BK. The mod. level adjust pot works backwards too, just like the >original- talk about attention to detail! > >Therefore any wiring setup used for the BK hot mic intercom should apply >to the A200. I presume you're asking me about this issue. I've not dabbled in the details of the various radios for about 20 years and those radios were the kinds of systems that go into the big GA aircraft. So aside from a bit of interconnect data left over from a bygone era of my career, I no longer have access to or posses current knowledge of the details you're asking about. The honorable Stein Bruch might be your best bet for answering this question. Stein, can you help us out here? Bob . . . ________________________________________________________________________________
Subject: Z-13 for internally regulated alt
Date: Nov 27, 2006
I'm wiring my Zenith 601HD with a Stratus Subaru EA-81 engine using a modified version of Z-13 - the Generic wiring diagram. Part of the modification to that diagram is to accomodate the internally regulated alternator. Z-13 uses a 2-10 Battery/Alt Master switch, so the batter contacter is engaged in the first On position and both battery and alternator are connected in the second position, indicating use of a 2-3 switch. I can see an advantage of being able to take the alternator off line without shutting down the whole system using the 2-10 switch. However, a note on the wiring diagram for the OVM-14 overvoltage protection module says both the battery and alternator must come on and go off at the same time. Which switch is recommended in this situation? What is the reason for bringing the battery and alternator on and off together? Thanks very much for any help or advice. Bill Steer ________________________________________________________________________________
Subject: Re: Z-13 for internally regulated alt
Date: Nov 27, 2006
Oops. That "indicating use of a 2-3 switch" should have been on the "However" sentence, not the one about the 2-10 switch. Sorry for the confusion. Bill ----- Original Message ----- From: "Bill Steer" <steerr(at)bellsouth.net> Sent: Monday, November 27, 2006 8:25 AM Subject: AeroElectric-List: Z-13 for internally regulated alt > > > I'm wiring my Zenith 601HD with a Stratus Subaru EA-81 engine using a > modified version of Z-13 - the Generic wiring diagram. Part of the > modification to that diagram is to accomodate the internally regulated > alternator. Z-13 uses a 2-10 Battery/Alt Master switch, so the batter > contacter is engaged in the first On position and both battery and > alternator are connected in the second position, indicating use of a 2-3 > switch. I can see an advantage of being able to take the alternator off > line without shutting down the whole system using the 2-10 switch. > However, a note on the wiring diagram for the OVM-14 overvoltage > protection module says both the battery and alternator must come on and go > off at the same time. > > Which switch is recommended in this situation? What is the reason for > bringing the battery and alternator on and off together? > > Thanks very much for any help or advice. > > Bill Steer > > > -- > 11/26/2006 11:30 AM > > ________________________________________________________________________________
Date: Nov 27, 2006
> >I'm wiring my Zenith 601HD with a Stratus Subaru EA-81 engine using a >modified version of Z-13 - the Generic wiring diagram. Part of the >modification to that diagram is to accomodate the internally regulated >alternator. Z-13 uses a 2-10 Battery/Alt Master switch, so the batter >contacter is engaged in the first On position and both battery and >alternator are connected in the second position, indicating use of a 2-3 >switch. I can see an advantage of being able to take the alternator off >line without shutting down the whole system using the 2-10 switch. In the early days of the Z-figures and before we had sources for reasonably priced 2-10 switches, the 2-3 COMBINED with the breaker associated with a crowbar ov protection system offers both normal operational control of battery/alternator system (it matters not whether they are ON/OFF together or progressively switched OFF/BAT/BAT+ALT). The pullable breaker offers a means by which an alternator can be kept quiet on the ground during battery only ops. You can use either combination but know also that many if not all internally regulated alternators cannot be shut down from outside should the regulator fail in a ov runaway condition. A system for offsetting that feature was published in the 'Connection some years ago (Figure Z-24 combined a b-lead contactor and OVM-14). Mis-use of this architecture (operating the alternator ON/OFF control while alternator was under load) precipitated some damage to alternator regulators. The word went out that the circuit was "flawed and not recommended." One can debate the politics of this statement endlessly but the bottom line is that I withdrew Z-24 in its original form. A new control philosophy is being explored that will offset the shortcomings of the original Z-24. See: http://www.aeroelectric.com/PPS/DCPwr/OV/z24a_Preliminary.pdf It's by belief that this product will allow any time, any conditions, ON/OFF control of an IR alternator without regard to system safety. Short answer to your question is that I recommend the 2-10 switch because it integrates nicely with the proposed 9004-1 Controller. But if you install a 2-3, the system will come on line and function as advertised but without the ability to control the alternator at will. >However, a note on the wiring diagram for the OVM-14 overvoltage >protection module says both the battery and alternator must come on and go >off at the same time. >Which switch is recommended in this situation? What is the reason for >bringing the battery and alternator on and off together? Where do you find this? I'm trying to understand the context of the statement, at the moment it doesn't seem valid . . . You can go either way but the 2-10 is recommended for the reason cite . . . Bob . . . ________________________________________________________________________________
Date: Nov 27, 2006
Thanks, Bob. I'll certainly go with your recommendation for the 2-10. To answer your question about the source of the statement that said the battery and alt must come on and off together... The OVM-14 from B&C came with two wiring diagrams enclosed - one for internally and one for externally regulated alternators. Both diagrams have a statement that says "IMPORTANT - BATTERY CONTACTOR AND ALTERNATOR SHOULD COME ON AND OFF TOGETHER." Bill > > Where do you find this? I'm trying to understand the > context of the statement, at the moment it doesn't > seem valid . . . > > You can go either way but the 2-10 is recommended for > the reason cite . . . ________________________________________________________________________________
Date: Nov 27, 2006
> >Thanks, Bob. I'll certainly go with your recommendation for the 2-10. > >To answer your question about the source of the statement that said the >battery and alt must come on and off together... The OVM-14 from B&C came >with two wiring diagrams enclosed - one for internally and one for >externally regulated alternators. Both diagrams have a statement that >says "IMPORTANT - BATTERY CONTACTOR AND ALTERNATOR SHOULD COME ON AND OFF >TOGETHER."\ Hmmm . . . okay. That doesn't appear in one of my publications. Thanks! Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 27, 2006
Hello Mr Hardin, I am just confused by the use of "Dual" and "Duel". "Duel(ling) Alternators" sounds like some kind of weird techie cartoon. Or bad regulator design. "Duel(ling) Batteries" sounds like something navel (hah!) gunners would get involved in. I apologize for picking on your message - there are so many typos/usage problems posted. This message is no worse, though it did tickle my fancy more than some others have.. Typos/usage problems can cause real headaches when communicating about topics that require some amount of precision. Some people might say "Well, they know what I mean. It's obvious." Sometimes it isn't. Sometimes it's the decimal place or the minus sign. Hmm. Here's to re-reading what you've typed before clicking the Send button. You don't have time to proof read? Do you have time to send clarifying messages when the first one you sent had errors/mistakes in it? And, if you're going to make a mistake because you don't have time to look up the correct spelling, make the mistake consistently.. A useful (though overly laden with advertisements) resource: http://www.dictionary.com Best regards, Matt- > Greetings Fellow Builders, > > Have couple straight forward questions on sizing for a duel battery set up > in a F1 Rocket with high compression (10 to 1) AEIO540 Lycoming, duel Plasma III Ignitions, duel B&C alternators a 60 amp and a 20 amp. > > Right now for electical I'm just building the battery box which will be slightly different that the plans since I want to go with (2) B&C 12V 16 A.H. batteries rather than the single 35 A.H. battery the plans call for. > I plan on building the (Z-14) Dual Battery, Duel Alternator, Split Bus type system out of Bob's book down the road in 6 months or so. > > Questions: > 1) will the duel battery set up 32 A.H. total still be enough in most cold > weather conditions maybe down below freezing 15 or 20 flights a year? I'm > running a B & C NCS206-149-12 starter. > 2) Any special mounting tips two be aware of with two batteries? Keep a space between them? > > Thanks > > Ralph Hardin Seattle Wa. > ________________________________________________________________________________
Subject: Continental IO-240: Alternator quit working
Date: Nov 27, 2006
Hello, Yesterday during flight my alternator quit charging. It is a Ford design with a Continental part # 633661 and using a Zeftronics R15VOL regulator (which is showing a green light on it's self diagnostic system). It is a direct drive on the rear of the engine. I am currently checking voltage/ohms, etc. I noticed today that the alternator cooling fan does not turn when the crankshaft is rotated by hand or when the engine is running. Does this mean something mechanical has broken and my failure to charge is actually caused by the alternator not turning? I have read about a gear coupling on some larger enginesbut cant find any info regarding the alternator set up on the IO-240. Any info regarding my failed system would be greatly appreciated! Thanks in advance! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen N-789DF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77430#77430 ________________________________________________________________________________
Date: Nov 27, 2006
Well said, now onto the difference between "your" that which belongs to you, and "you're" meaning ....you are. Harold Kovac......no stranger to typos or other errors ----- Original Message ----- From: "Matt Prather" <mprather(at)spro.net> Sent: Monday, November 27, 2006 4:37 PM Subject: Re: AeroElectric-List: Battery Sizing > > > Hello Mr Hardin, > > I am just confused by the use of "Dual" and "Duel". "Duel(ling) > Alternators" sounds like some kind of weird techie cartoon. Or bad > regulator design. "Duel(ling) Batteries" sounds like something navel > (hah!) gunners would get involved in. > > I apologize for picking on your message - there are so many typos/usage > problems posted. This message is no worse, though it did tickle my fancy > more than some others have.. > > Typos/usage problems can cause real headaches when communicating about > topics that require some amount of precision. Some people might say > "Well, they know what I mean. It's obvious." Sometimes it isn't. > Sometimes it's the decimal place or the minus sign. Hmm. > > Here's to re-reading what you've typed before clicking the Send button. > You don't have time to proof read? Do you have time to send clarifying > messages when the first one you sent had errors/mistakes in it? > > And, if you're going to make a mistake because you don't have time to look > up the correct spelling, make the mistake consistently.. > > A useful (though overly laden with advertisements) resource: > > http://www.dictionary.com > > > Best regards, > > Matt- > > >> Greetings Fellow Builders, >> >> Have couple straight forward questions on sizing for a duel battery set > up >> in a F1 Rocket with high compression (10 to 1) AEIO540 Lycoming, duel > Plasma III Ignitions, duel B&C alternators a 60 amp and a 20 amp. >> >> Right now for electical I'm just building the battery box which will be > slightly different that the plans since I want to go with (2) B&C 12V 16 > A.H. batteries rather than the single 35 A.H. battery the plans call > for. >> I plan on building the (Z-14) Dual Battery, Duel Alternator, Split Bus > type system out of Bob's book down the road in 6 months or so. >> >> Questions: >> 1) will the duel battery set up 32 A.H. total still be enough in most > cold >> weather conditions maybe down below freezing 15 or 20 flights a year? > I'm >> running a B & C NCS206-149-12 starter. >> 2) Any special mounting tips two be aware of with two batteries? Keep a > space between them? >> >> Thanks >> >> Ralph Hardin Seattle Wa. >> > > > ________________________________________________________________________________
Date: Nov 27, 2006
Subject: Re: Continental IO-240: Alternator quit working
If the IO-240 is like the O200 (and other small Continentals with alternator/generator drive) it might look like this: http://www.bandc.biz/200gdesc.html There's a forged/milled piece (?) a pair of rubber bushings and a stamped sheet socket that together are used to transmit torque from the engine to the alternator. I think that in the O200 setup, the rubber bushings are kind of wear items. They get squished flatter and flatter. The few airplanes I have checked have a fair amount of slop between the gear and the alternator rotor - caused by this squishing. I suppose that if the rubber deteriorated far enough it might cause the drive fingers to fail... Unfortunately, I think if that happens it will probably drop metal into the accessory case. :( Aircraft spruce has the parts for the alternator drive: http://www.aircraftspruce.com/catalog/eppages/generatorattparts.php Again, I don't know if any of these parts are compatible with the IO-240.. The IO-240 might have more in common with the IO-360. Matt- > > > Hello, > Yesterday during flight my alternator quit charging. It is a Ford design > with a Continental part # 633661 and using a Zeftronics R15VOL regulator > (which is showing a green light on it's self diagnostic system). It is a > direct drive on the rear of the engine. I am currently checking > voltage/ohms, etc. > > I noticed today that the alternator cooling fan does not turn when the > crankshaft is rotated by hand or when the engine is running. Does this > mean something mechanical has broken and my failure to charge is actually > caused by the alternator not turning? I have read about a gear coupling > on some larger enginesbut cant find any info regarding the > alternator set up on the IO-240. Any info regarding my failed system > would be greatly appreciated! Thanks in advance! > > Travis :) > > -------- > Travis Rayner > Mobile, AL > Skystar Vixen > N-789DF > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=77430#77430 > > ________________________________________________________________________________
Date: Nov 27, 2006
Hello Mr Hardin, I am just confused by the use of "Dual" and "Duel". "Duel(ling) Alternators" sounds like some kind of weird techie cartoon. Or bad regulator design. "Duel(ling) Batteries" sounds like something navel (hah!) gunners would get involved in. Matt, I take responsibility for beginning the "duel." I guess there are cases where spell checker won't make up for my lack of proof-reading or spelling ability. Once it gets into a thread it seems to take on a life of its own. I certainly didn't mean to start a verbal "duel." I am much more interested in learning how to install and wire an airplane with "dual" alternators and "dual" batteries. I stand corrected. Thanks for the link. Don Owens http://www.dictionary.com Best regards, Matt- -- 1:40 PM ________________________________________________________________________________
Date: Nov 28, 2006
Subject: Who is "Matt Dralle" & What Are "The Lists"? [Please
Read] Dear Listers, Who is Matt Dralle and what exactly are these Lists? Well, I've been working in the information technology industry for over 20 years primarily in computer networking design and implementation. I have also done extensive work in web development and CGI design during this period. I started the Matronics Email Lists back in 1990 with about 30 fellow RV builders from around the world. Since that time, I have added 63 other kinds of aircraft related Lists to the line up and numerous other List related services such as the Forums, Wiki, Archives and Search Engine just to name a few. For flexibility and reliability, I have chosen to run all of my own servers here locally. Other List-related systems include a 1 Gigabit, fully switched network infrastructure, a commercial-grade Netscreen firewall, a Barracuda spam filter, a local T1 Internet router, and a commercial-grade business T1 Internet connection with full static addressing. The computer servers found here include a brand new, quad-processor Xeon Linux server for List web services, a dual-processor Xeon Linux system dedicated to the email processing List functions, and another P4 Linux system serving as a remote storage disk farm for the archives, databases, and for an on-line hard drive-based backup system with 3.2 Terra Bytes of storage, soon to be upgraded to over 6 Terra Bytes! This entire system is protected by three large, commercial-grade uninterrupted power supply (UPS) systems that assure the Lists are available even during a local power outage! Speaking of power, imagine how much electricity it takes to run all of these systems. One month this Summer, I had a staggering $1368 bill for electricity alone! I recently upgraded all of the computer racking infrastructure including new power feeds and dedicated air conditioning for the room that serves as the Computer Center for the Matronics Email Lists. This year I added another rack to house the new MONSTER quad-processor web system that didn't quite fit into the first rack! Here's a composite photo of the List Computer Center before the addition of the second rack: http://www.matronics.com/MattDralle-ListComputerCenter.jpg As you can see, I take running these Lists very seriously and I am dedicated to providing an always-on, 24x7x365 experience for each and every Lister. But building and running this system isn't cheap. As I've stated before, I don't support any of these systems with commercial advertising on the Lists. It is supported 100% through List member Contributions! That means you... and you... and YOU! To that end, I hold a List Fund Raiser each November and ask that members make a small Contribution to support the continued operation and upgrade of this ever-expanding system. Its solely YOUR Contributions that keeps it running! Please make a Contribution today to support these Lists! http://www.matronics.com/contribution Or, by dropping a personal check in the mail to: Matronics / Matt Dralle PO Box 347 Livermore CA 94551-0347 USA (Please include your email address on the check!) Thank you! Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 28, 2006
11/28/2006 Hello Travis, You most probably have a failure of the elastomeric coupling drive of the alternator. TCM Service Bulletin SB95-3B describes this coupling in detail and I have attached a copy of that SB to this email. If you can not see it please let me know and we'll work on another way to get it to you. Buying a replacement coupling from TCM is very expensive. There is an outfit in Texas that rebuilds them and will sell you one for a cheaper price. Try Drake Air Inc at 800-542-6899. They may also know it as ATA Number DAP-1016. http://www.drakeair.com/details.asp?id=635796 According to the IO-240 part manual the IO-240 uses the one piece P/N 635796 one piece coupling. I don't see that coupling as being available from Aircraft Spruce, but you could check with them. Please let me know if I can be of further help. OC -- The best investment we will ever make is in gathering knowledge. Subject: AeroElectric-List: Continental IO-240: Alternator quit working From: "FlyboyTR" <flyboytr(at)bellsouth.net> Hello, Yesterday during flight my alternator quit charging. It is a Ford design with a Continental part # 633661 and using a Zeftronics R15VOL regulator (which is showing a green light on it's self diagnostic system). It is a direct drive on the rear of the engine. I am currently checking voltage/ohms, etc. I noticed today that the alternator cooling fan does not turn when the crankshaft is rotated by hand or when the engine is running. Does this mean something mechanical has broken and my failure to charge is actually caused by the alternator not turning? I have read about a gear coupling on some larger enginesbut cant find any info regarding the alternator set up on the IO-240. Any info regarding my failed system would be greatly appreciated! Thanks in advance! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen N-789DF ________________________________________________________________________________
Date: Nov 28, 2006
Subject: 28v diesel engine
>Comments/Questions: Bob, > >I am installing a DeltaHawk diesel engine in my homebuilt and they have >decided to go with a 28 VDC starter and alternator. I have already >purchased most of my avionics in 14 VDC. I can buy a step-down >transformer from Aircraft Spruce, but is there a good way to run parallel >14 V batteries for power and still use the 28 V alternator for >charging? Seems like I'm between a rock and a hard place. Yup, your sure are! There's no graceful way to do this. The best solution is to use 2 batteries in series for cranking, change to parallel for operating and running a 14v alternator. bob . . . ________________________________________________________________________________
Date: Nov 28, 2006
Thanks for the information! I have sent Drake Air an email regarding the drive coupling. In order to remove the alternator I have to pull the engine! ...nothing is ever easy! Again, thanks to all for the input and support! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen N-789DF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77593#77593 ________________________________________________________________________________
Date: Nov 28, 2006
Good Morning OC, May I add a comment? If someone does have a slipping Elastomeric coupling, don't let it be discarded. They can be refurbished for about one third the cost of a new coupling. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 --- bakerocb(at)cox.net wrote: > 11/28/2006 > > Hello Travis, You most probably have a failure of > the elastomeric coupling > drive of the alternator. > > TCM Service Bulletin SB95-3B describes this coupling > in detail and I have > attached a copy of that SB to this email. If you can > not see it please let > me know and we'll work on another way to get it to > you. > > Buying a replacement coupling from TCM is very > expensive. There is an outfit > in Texas that rebuilds them and will sell you one > for a cheaper price. Try > Drake Air Inc at 800-542-6899. They may also know it > as ATA Number DAP-1016. > http://www.drakeair.com/details.asp?id=635796 > > According to the IO-240 part manual the IO-240 uses > the one piece P/N 635796 > one piece coupling. I don't see that coupling as > being available from > Aircraft Spruce, but you could check with them. > > Please let me know if I can be of further help. > > OC -- The best investment we will ever make is in > gathering knowledge. > > Subject: AeroElectric-List: Continental IO-240: > Alternator quit working > From: "FlyboyTR" <flyboytr(at)bellsouth.net> > > Hello, > Yesterday during flight my alternator quit charging. > It is a Ford design > with > a Continental part # 633661 and using a Zeftronics > R15VOL regulator (which > is > showing a green light on it's self diagnostic > system). It is a direct drive > on > the rear of the engine. I am currently checking > voltage/ohms, etc. > > I noticed today that the alternator cooling fan does > not turn when the > crankshaft > is rotated by hand or when the engine is running. > Does this mean something > mechanical has broken and my failure to charge is > actually caused by the > alternator > not turning? I have read about a gear coupling on > some larger enginesbut > cant find any info regarding the alternator set up > on the IO-240. Any info > regarding my failed system would be greatly > appreciated! Thanks in > advance! > > Travis :) > > -------- > Travis Rayner > Mobile, AL > Skystar Vixen > N-789DF > ________________________________________________________________________________
Subject: Pitot heater performance
Date: Nov 28, 2006
Anyone, I'm not underdstanding a point in the http://www.aeroelectric.com/articles/Pitot_Heater/Gauging_Pitot_Heater_Pe rformance.pdf on Bob's website...namely that "If you are considering an AN5814 heated pitot tube installtion, the data gathered suggests that the tube be wired with 14AWG in a metal airplane and perhaps 12AWG in a plastic airplane." SO - why perhaps 12AWG in a plastic airplane....? John ________________________________________________________________________________
Date: Nov 28, 2006
Hi Ralph, Spelling issues aside, I'm curious why you're putting a Z-14 in a Rocket? Will you be flying lots of IFR, or is there another reason? Thanks, Marc -------- Marc RV-7, flying Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77642#77642 ________________________________________________________________________________
Date: Nov 28, 2006
Subject: Competely Off topic, but Nifty
I've been busy working on my electric drag bike lately, instead of my rotary RV-7. That is why I have been silent on the list lately. This has absolutely nothing to do with rotary aircraft, but I figured since it is fun for me, it would be enjoyable for other high-performance/electronics nuts as well. A group of us laptop-toting, pocket protector nerds managed to impress the ultimate "tough room" of beer swigging tattooed bikers at the All Harley Drag Racing Association season finale at Las Vegas Drag Strip. We are the only Non-Harley to run at the Las Vegas event, ever in history. We set a record while we were at it. Video on YouTube (Watch us plasma a motor on the finish line): http://www.youtube.com/watch?v=RpAZci9m0 Fact Sheet http://www.killacycle.com/KillaCycleFactSheet.pdf A few pictures: http://www.killacycle.com/BurnOut.JPG http://www.killacycle.com/Speed.JPG http://www.killacycle.com/Launch.JPG Time Slips http://www.killacycle.com/TopTimeSlips.JPG Let me know if you need more info. Now you understand why you haven't heard from me lately. :-) Bill Dube' bike(at)killacycle.com ________________________________________________________________________________
Subject: Re: Homebrew AHRS?
Date: Nov 28, 2006
Malcolm, If you are having trouble with your Crossbow NAV425EX, please contact us directly. Crossbow is committed to our customers and we will do everything in our power to ensure that you are receiving proper operation from your AHRS. Since we started the upgrade program, we have had dozens of these units completed and have not had any further problems with the NAV425. -------- Michael Smith Application Engineer Inertial Systems Crossbow Technology msmith(at)xbow.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77656#77656 ________________________________________________________________________________
From: "Malcolm Thomson" <mthomson(at)showmeproductions.com>
Date: Nov 28, 2006
Will you confirm that your test sites are now trouble free? I would really like to get these units working properly. Malcolm. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike@Crossbow Sent: Tuesday, November 28, 2006 1:36 PM Subject: AeroElectric-List: Re: Homebrew AHRS? --> Malcolm, If you are having trouble with your Crossbow NAV425EX, please contact us directly. Crossbow is committed to our customers and we will do everything in our power to ensure that you are receiving proper operation from your AHRS. Since we started the upgrade program, we have had dozens of these units completed and have not had any further problems with the NAV425. -------- Michael Smith Application Engineer Inertial Systems Crossbow Technology msmith(at)xbow.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77656#77656 -- 4:00 AM -- 4:00 AM ________________________________________________________________________________
Date: Nov 29, 2006
Subject: basic Ford alternator wiring questions
I'm finally free to experiment with my new "Coyote" project with a Lyc. 320. I will be using the regular "Cessna" alternator/VR at least to begin with (day vfr with electric starter/minimal avionics), basically a copy of my Cardinal to start. My confusion starts when I examine the Cessna alternator wiring: My certified Cardinal has the same style alternator, wired as follows (all wires are shielded): #8 from alt. A+ lug to Alt breaker, shield grounded to alt. case only #8 from alt ground lug to firewall bolt, shield at each end tied to end terminal #18 from alt Field lug to VR F lug, shield grounded to alt case and firewall bolt #18 from alt A+ lug to VR A+ lug, shield grounded to alt case and firewall bolt #18 from VR S lug to square metal filter lug to power buss, shield grounded to firewall bolt and again next to filter, shield end at power buss floats The above is per the factory manual, except for the shielded #8 ground wire, the Cessna manual shows an unshielded #18. I assume the factory used shielded wire for abrasion protection and/or noise protection, and that the #8 shielded ground wire was an undocumented later field change? Questions: 1. I understand the Connection to say that shielding alternator/VR wiring is not necessary for noise protection, did I miss something? 2. Does a shielded ground wire create any noise problem potential? If the engine ground straps are in good shape, is there any reason for the #8 ground from alternator to firewall? Or for any separate ground wire from the alternator, inasumch as the alternator is bolted to the engine with all metal bolts (no insulated washers)? 3. Is there any reason to run the A+ wire from the alternator to the VR A+, I would prefer to run a shorter wire from the VR A+ to the alternator side of the A+ alternator fuse on the firewall (1 foot of wire on the firewall instead of 4 feet of wire running beside the hot engine)? 4. Is there a need for wire protection, by shielding or otherwise, since it runs next to the hot engine from the alternator? 5. Skycrafters sells a high temp "Varglass" sleeving advertised as being rated to 200 degrees C. Is this an appropriate protection for the wires? I can't find any information on the internet. 6. What temp rating should I use for the wires running next to the engine? 7. Simply, is the following good practice for a Ford style alt/vr: all unshielded: #8 "A+" (alt to big fuse); #18 "F" (alt to VR); #18 VR "S" (VR to power buss); #18 VR "A+" (VR to alt side of big fuse)? This seems less complicated than my Cardinal. Thank you. Skip Simpson ________________________________________________________________________________
Date: Nov 29, 2006
Subject: re: Basic Ford alternator wiring questions
I'm finally free to experiment with my new "Coyote" project with a Lyc. 320. I will be using the regular "Cessna" alternator/VR at least to begin with (day vfr with electric starter/minimal avionics), basically a copy of my Cardinal to start. My confusion starts when I examine the Cessna alternator wiring: My certified Cardinal has the same style alternator, wired as follows (all wires are shielded): #8 from alt. A+ lug to Alt breaker, shield grounded to alt. case only #8 from alt ground lug to firewall bolt, shield at each end tied to end terminal #18 from alt Field lug to VR F lug, shield grounded to alt case and firewall bolt #18 from alt A+ lug to VR A+ lug, shield grounded to alt case and firewall bolt #18 from VR S lug to square metal filter lug to power buss, shield grounded to firewall bolt and again next to filter, shield end at power buss floats The above is per the factory manual, except for the shielded #8 ground wire, the Cessna manual shows an unshielded #18. I assume the factory used shielded wire for abrasion protection and/or noise protection, and that the #8 shielded ground wire was an undocumented later field change? Questions: 1. I understand the Connection to say that shielding alternator/VR wiring is not necessary for noise protection, did I miss something? No, you didn't. I was a tech writer at Cessna when the shielding protocols were first adopted on the single engine alternator installations. A prophylactic combination of "good things" were sprinkled onto some noisy airplanes where alternator noise was heard in the new ADF installations. The noise was reduced or eliminated and the practice adopted. There were NO formal studies as to the operating characteristics or effectiveness of any particular "good thing". The guy doing the work was a PhD physicist but he had no test equipment and zero experience with EMC issues. Nobody in the local industry did. Beech went on to acquire extensive testing facilities and experience but the roots of curiosity never took hold at Cessna's single-engine plant. 2. Does a shielded ground wire create any noise problem potential? If the engine ground straps are in good shape, is there any reason for the #8 ground from alternator to firewall? Or for any separate ground wire from the alternator, inasumch as the alternator is bolted to the engine with all metal bolts (no insulated washers)? Multiple ground wires give rise to dreaded DC GROUND LOOP and while they don't obviously "hurt" in most cases, they never help either. Bolting the alternator to the engine and strapping the engine to a single-point ground on the firewall is sufficient. 3. Is there any reason to run the A+ wire from the alternator to the VR A+, I would prefer to run a shorter wire from the VR A+ to the alternator side of the A+ alternator fuse on the firewall (1 foot of wire on the firewall instead of 4 feet of wire running beside the hot engine)? I presume you're talking about a remote sense wire from the regulator. Cessna adopted remote sensing protocols in their regulator specs in the 80's and attached (+) and (-) sense wires directly to terminals on the alternator. The notion was that should an alternator experience an electrical disconnect downstream, that remote sensing at the alternator would prevent an unstable or runaway condition. Risks for wiring as you've described are not high . . . and you concerns for "wires next to hot engines" are not operable. Tefzel wire is quite content in the engine compartment compared to the nylon/PVC or nylon/dacron/PVC wire we were using before Tefzel. 4. Is there a need for wire protection, by shielding or otherwise, since it runs next to the hot engine from the alternator? No. 5. Skycrafters sells a high temp "Varglass" sleeving advertised as being rated to 200 degrees C. Is this an appropriate protection for the wires? I can't find any information on the internet. There are a variety of sleeving materials offered to satisfy a variety of protection concerns but for Tefzel wire under the cowl there are few if any concerns. Radiant heating from exhaust stacks are the high-stress heat sources. Keep your wires and accessories away from those antagonists and good order will exist under the cowl. 6. What temp rating should I use for the wires running next to the engine? Tefzel is rated for continuous operation at 150C and is quite sufficient for the appplication we're discussing. 7. Simply, is the following good practice for a Ford style alt/vr: all unshielded: #8 "A+" (alt to big fuse); #18 "F" (alt to VR); #18 VR "S" (VR to power buss); #18 VR "A+" (VR to alt side of big fuse)? This seems less complicated than my Cardinal. Thank you. Skip Simpson Keep in mind that what appears to be "more complicated" may have roots in rational design decisions (like the remote sensing at the alternator terminals) while others are wild ass guesses (like the shielding). Just because it has been done on tens of thousands of "certified" airplanes does not validate the science behind the practice. Operational risks for "rewiring" as you've suggested are very low. Shielding any of these wires is a waste of $time$ and empty weight budgets. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
Bob, The fuel injection control system on the diesel engine may require 28 volts for operation. Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, November 28, 2006 7:17 AM Subject: AeroElectric-List: 28v diesel engine >Comments/Questions: Bob, > >I am installing a DeltaHawk diesel engine in my homebuilt and they have >decided to go with a 28 VDC starter and alternator. I have already >purchased most of my avionics in 14 VDC. I can buy a step-down >transformer from Aircraft Spruce, but is there a good way to run parallel >14 V batteries for power and still use the 28 V alternator for >charging? Seems like I'm between a rock and a hard place. Yup, your sure are! There's no graceful way to do this. The best solution is to use 2 batteries in series for cranking, change to parallel for operating and running a 14v alternator. bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
> >Bob, > >The fuel injection control system on the diesel engine may require 28 >volts for operation. > >Regards, George Hmmm . . . so those guys are going electronic too . . . I guess it comes down to a $time$/weights/parts-count issue. Depending on how much current the engine needs, it might be better to use a small 28v battery and step-up inverter as opposed to a 14 volt battery and step down inverter to support already purchased avioncs. To craft decision right may take as much engineering $time$ as the delta-dollars to sell the 14-volt goodies and buy 28-volt versions. Life can get complicated sometimes! I had a weird phone call yesterday from a guy building a Seawind who was planning to install a PT-6 engine. He started out asking where to buy 100A fuses and I steered him onto the usual suppliers. The conversation expanded to wire sizing and system architecture for engines with starter-generators and it was obvious that he had little knowledge and no experience with the issues. Yet as I attempted to steer him in the right direction, he insisted on arguing with my suggestions. I kept telling him that I wasn't going to argue with him and that our conversation was taking time from my work for a paying customer. He kept asking questions and then arm-wrestling with the answers. I finally suggested that he hire a professional to craft a wirebook for his airplane and offered by services at $150/hour. He replied, "For that kind of money I'll do it myself" whereupon I opined, "Then I guess you don't need me" and hung up. That's the first time I've ever had to forcibly terminate a conversation with a builder. I do wish the fellow well but I'm not optimistic! Some of life's complications are truly intractable. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
Malcolm, I can confirm that we have not seen a repeat of any of the items called out in our service bulletin nor have we seen any new failures in the upgraded units. We have over 30 of these units in the field and have not had any further problems with the NAV425EX. If you are running the NAV425EX, we offer this update for free and will do everything possible to minimize any down time to your aircraft. -------- Michael Smith Application Engineer Inertial Systems Crossbow Technology msmith(at)xbow.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77845#77845 ________________________________________________________________________________
Date: Nov 29, 2006
From: "Stovall Todd Lt Col AF/A4RX" <Todd.Stovall(at)pentagon.af.mil>
Michael, I'm considering purchasing the OP Tech EFIS which uses the NAV420. Has it suffered the same problems as the 425? Thanks, Todd -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike@Crossbow Sent: Wednesday, November 29, 2006 10:43 AM Subject: AeroElectric-List: Re: Homebrew AHRS? --> Malcolm, I can confirm that we have not seen a repeat of any of the items called out in our service bulletin nor have we seen any new failures in the upgraded units. We have over 30 of these units in the field and have not had any further problems with the NAV425EX. If you are running the NAV425EX, we offer this update for free and will do everything possible to minimize any down time to your aircraft. -------- Michael Smith Application Engineer Inertial Systems Crossbow Technology msmith(at)xbow.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77845#77845 ________________________________________________________________________________
Date: Nov 29, 2006
First, I would like to apologize for hijacking the thread. That wasn't my intention. In reference to the original topic, what Malcolm and others have said is completely correct. We are approached by customers occasionally that complain that they could build the unit for far less because the parts are relatively inexpensive. Yes, the parts aren't too expensive but the software is very complicated and you will need to rely upon some sort of aiding (GPS, Kalman filtering, Airspeed, etc..) to improve performance of an AHRS. MEMS gyro's without this aiding are really not accurate enough for aviation in my opinion. By the time you are done creating software and testing a fully functional unit you would have saved a significant amount of money by purchasing a completed solution. Now, if you want to create an AHRS for your personal enjoyment...then yes it's probably worthwhile. In regards to OP Tech, we have not seen any failures with the NAV420's that we shipped to OP Tech, but a very large percentage of the ones that were shipped to OP Tech were already updated with the latest hardware/firmware so we wouldn't expect to see much. The early units that were shipped OP Tech have also come back to be updated and we haven't been informed of any problems with those units. Crossbow is aware of the delay and inconvenience that we have put our NAV425EX customers through and on behalf of Crossbow I would like to personally apologize for the amount of time that it took to get this fix in place. We have been updating these units since May of this year and are confident that the fixes we have in place remedy all noted issues that are stated in the service bulletin. -------- Michael Smith Application Engineer Inertial Systems Crossbow Technology msmith(at)xbow.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77859#77859 ________________________________________________________________________________
Date: Nov 29, 2006
-----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, November 29, 2006 10:04 AM Subject: RE: AeroElectric-List: 28v diesel engine >--> > >Bob, > >The fuel injection control system on the diesel engine may require 28 >volts for operation. > >Regards, George Hmmm . . . so those guys are going electronic too . . . I guess it comes down to a $time$/weights/parts-count issue. George/Bob: The fuel injection system on the Deltahawk is mechanical (unless they have changed recently} so there are no electrical requirements other than starting. Gordon Comfort N363GC ________________________________________________________________________________
Subject: Re: ratcheting crimp tool source
Date: Nov 29, 2006
For those looking for an inexpensive crimp tool that appears identical to the one sold by B & C, check out Harbor Freight- item 93977. I bought one today for $15 TJ --- http://USFamily.Net/dialup.html - $8.25/mo! -- http://www.usfamily.net/dsl.html - $19.99/mo! --- ________________________________________________________________________________
Subject: RE: AeroElectric-List Digest: 14 Msgs - 11/28/06
Date: Nov 30, 2006
I just came across this information regarding an auto starter motor adaptor. Has any on the list seen this or used the plans ? http://abianconi.hypermart.net/Starter-Adapter.html Martin in Oz ________________________________________________________________________________
Date: Nov 29, 2006
I pulled the engine today for access to the alternator. There was one nut (top) that was almost impossible to remove (ended up removing the starter for easier access) on the alternator. The drive gear on the end of the alternator shaft rotates freely! I have emailed Drake Air (also left them a voice mail...have heard back from them) regarding their rebuilt units. This does not look like a field serviceable part as shown in the Aircraft spruce book (doesn't look the same)! I would welcome any contact names for parts suppliers/rebuilders that would carry this part. I also realized today that I need to replace the motor mount bushings! Thanks again! Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen N-789DF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=77940#77940 ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Strobes wiring
Date: Nov 29, 2006
I am in the process of wiring the tail / wing strobes. I have grounded each wire at the power pack location by bundeling them together and securing them to the strobe power pack base. Now the ??? At the strobe end should the ground wire be grounded at this point or taken back to the fairwall ground block. Also the foil shield does it get any special treatment or just terminated at each end with no attachment to the airframe. TIA Frank @ SGU and SLC wiring / fiberglassing RV7A _________________________________________________________________ Stay up-to-date with your friends through the Windows Live Spaces friends list. ________________________________________________________________________________
Date: Nov 29, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. >Nuckolls, III >Sent: Wednesday, November 29, 2006 10:04 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: 28v diesel engine > > > >--> > > > >Bob, > > > >The fuel injection control system on the diesel engine may require 28 > >volts for operation. > > > >Regards, George > > Hmmm . . . so those guys are going electronic too . . . > I guess it comes down to a $time$/weights/parts-count > issue. > > George/Bob: The fuel injection system on the Deltahawk is mechanical >(unless they have changed recently} so there are no electrical requirements >other than starting. Good to know. That makes integration of that engine a whole lot easier! Thanks Gordon. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
> >First, I would like to apologize for hijacking the thread. Nobody "hijacks" anything if they have good data to share . . . > That wasn't my intention. In reference to the original topic, what > Malcolm and others have said is completely correct. We are approached by > customers occasionally that complain that they could build the unit for > far less because the parts are relatively inexpensive. Yes, the parts > aren't too expensive but the software is very complicated and you will > need to rely upon some sort of aiding (GPS, Kalman filtering, Airspeed, > etc..) to improve performance of an AHRS. MEMS gyro's without this > aiding are really not accurate enough for aviation in my opinion. By the > time you are done creating software and testing a fully functional unit > you would have saved a significant amount of money by purchasing a > completed solution. Now, if you want to create an AHRS for your personal > enjoyment...then yes it's probably worthwhile. > >In regards to OP Tech, we have not seen any failures with the NAV420's >that we shipped to OP Tech, but a very large percentage of the ones that >were shipped to OP Tech were already updated with the latest >hardware/firmware so we wouldn't expect to see much. The early units that >were shipped OP Tech have also come back to be updated and we haven't been >informed of any problems with those units. > >Crossbow is aware of the delay and inconvenience that we have put our >NAV425EX customers through and on behalf of Crossbow I would like to >personally apologize for the amount of time that it took to get this fix >in place. We have been updating these units since May of this year and >are confident that the fixes we have in place remedy all noted issues that >are stated in the service bulletin. Mike, thanks for monitoring the List and for joining this conversation. Did we meet at Raytheon's Missiles Division when Crossbow came out to propose an AHRS for our AQM-37D target upgrade? I looked for my business cards from those meetings but they were now quite some time ago . . . about 10 years I think. bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
Subject: Re: RE: AeroElectric-List Digest: 14 Msgs - 11/28/06
> > >I just came across this information regarding an auto starter motor adaptor. >Has any on the list seen this or used the plans ? > >http://abianconi.hypermart.net/Starter-Adapter.html > >Martin in Oz I've .pdf'ed the data package and posted at: http://www.aeroelectric.com/Reference_Docs/Starters/Lycoming_Starter_Adapter.pdf If anyone has a chance to try this out, please post your discoveries here on the List. Bob . . . ________________________________________________________________________________
Date: Nov 29, 2006
>For those looking for an inexpensive crimp tool that appears identical to >the one sold by B & C, check out Harbor Freight- item 93977. I bought one >today for $15 >TJ That's a good tool. I've checked them against similar and it appears to be a member of the clones for this style of tool. They're on sale right now on the Harbor Freight website for $10. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 29, 2006
> > >I am in the process of wiring the tail / wing strobes. I have grounded >each wire at the power pack location by bundeling them together and >securing them to the strobe power pack base. I'm not sure which wires your're referring to. The cables from each tube assembly are usually 20AWG twisted trios with a foil shield and drain-wire. You ground each drain wire to the strobe power supply base. All other wires ought to drop into pins on connectors > Now the ??? At the strobe end should the ground wire be grounded at this > point or taken back to the fairwall ground block. Also the foil shield > does it get any special treatment or just terminated at each end with no > attachment to the airframe. Nothing attaches to the airframe at the tube end of each cable. What does the installation drawings for the strobe system show? The drawings should be very explicit as to how each conductor in their system is connected. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Nov 30, 2006
Subject: Last "Official" Day Of The List Fund Raiser!
Dear Listers, Well, its November 30th and that means three things... 1) Today I am now officially 43 years old... (arg...) 2) It marks that last "official" day of the List Fund Raiser! 3) Its the last day I will be bugging everyone for a whole year! :-) If you use the Lists and enjoy the content and the no-advertising, no-spam, and no-censorship way in which they're run, please make a Contribution today to support their continued operation and upkeep. Your $20 or $30 goes a long way to further the List operation and keep the bills paid. I will be posting the List of Contributors next week, so make sure your name is on it! :-) Thank you to everyone that has made a Contribution so far this year! It is greatly appreciated. List Contributions: http://www.matronics.com/contribution Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Nov 30, 2006
11/30/2006 Hello Travis, You wrote: " I have emailed Drake Air (also left them a voice mail...have heard back from them) regarding their rebuilt units." I am puzzled by your posting. Has Drake responded or not? Have you submitted a RFQ (request for quote) using the form on their web site? http://www.drakeair.com/rfq.asp?id=635796 Have you telephoned them? 1-800-542-6899 Usually they are very good about responding because they are sometimes dealing with airplanes that are grounded and need parts sent quickly by FedEx overnight or other fast means. You wrote: " This does not look like a field serviceable part as shown in the Aircraft spruce book (doesn't look the same)!" You are right. There are two different versions of this coupling as explained in the TCM service bulletin SB95-3B (copy attached). The IO-240 uses the one piece coupling P/N 635796 and the Aircraft Spruce catalog has parts for the multipiece coupling. You wrote: "The drive gear on the end of the alternator shaft rotates freely!" Have you removed the coupling from the alternator to ensure that the shaft itself is not sheared and that just the elastomeric portion of the coupling has failed? And that the alternator shaft is not seized? You wrote: "I would welcome any contact names for parts suppliers/rebuilders that would carry this part." Any decent FBO or repair shop that orders parts from TCM should be able to get the alternator coupling from a TCM parts distributor, but it will be much more expensive than a rebuilt one from Drake. There may be other rebuilders of this coupling, but I am not aware of them. I would lean harder on Drake. You wrote: "I also realized today that I need to replace the motor mount bushings!" The elastomeric bushings are part number 530740 and are available from Aircraft Spruce. Please let me know how you make out. OC -- The best investment we will ever make is in gathering knowledge. PS: As mentioned by Old Bob, your old alternator coupling core is worth money to Drake. Subject: AeroElectric-List: Re: Continental IO-240: Alternator quit working From: "FlyboyTR" <flyboytr(at)bellsouth.net> I pulled the engine today for access to the alternator. There was one nut (top) that was almost impossible to remove (ended up removing the starter for easier access) on the alternator. The drive gear on the end of the alternator shaft rotates freely! I have emailed Drake Air (also left them a voice mail...have heard back from them) regarding their rebuilt units. This does not look like a field serviceable part as shown in the Aircraft spruce book (doesn't look the same)! I would welcome any contact names for parts suppliers/rebuilders that would carry this part. I also realized today that I need to replace the motor mount bushings! Thanks again! Travis :) ________________________________________________________________________________
Date: Nov 30, 2006
Looks like I missed a word! Have NOT heard back from them. I called yesterday afternoon after returning from the airport. they were closed. I will call them this morning. I have several leads on the part. TCM lists it at $1659.32. Crazy! I have not removed the coupling yet. The alternator turns freely (using the fan). The gear easily spins and turns inside the coupling housing but the housing does not turn (only when using the fan). Thanks for the TCM bulletin and the part #'s for the bushings. Your help is sincerely appreciated! Travis :) ----- Original Message ----- From: bakerocb(at)cox.net To: flyboytr(at)bellsouth.net Cc: aeroelectric-list(at)matronics.com Sent: Thursday, November 30, 2006 7:43 AM Subject: Continental IO-240: Alternator quit working 11/30/2006 Hello Travis, You wrote: " I have emailed Drake Air (also left them a voice mail...have heard back from them) regarding their rebuilt units." I am puzzled by your posting. Has Drake responded or not? Have you submitted a RFQ (request for quote) using the form on their web site? http://www.drakeair.com/rfq.asp?id=635796 Have you telephoned them? 1-800-542-6899 Usually they are very good about responding because they are sometimes dealing with airplanes that are grounded and need parts sent quickly by FedEx overnight or other fast means. You wrote: " This does not look like a field serviceable part as shown in the Aircraft spruce book (doesn't look the same)!" You are right. There are two different versions of this coupling as explained in the TCM service bulletin SB95-3B (copy attached). The IO-240 uses the one piece coupling P/N 635796 and the Aircraft Spruce catalog has parts for the multipiece coupling. You wrote: "The drive gear on the end of the alternator shaft rotates freely!" Have you removed the coupling from the alternator to ensure that the shaft itself is not sheared and that just the elastomeric portion of the coupling has failed? And that the alternator shaft is not seized? You wrote: "I would welcome any contact names for parts suppliers/rebuilders that would carry this part." Any decent FBO or repair shop that orders parts from TCM should be able to get the alternator coupling from a TCM parts distributor, but it will be much more expensive than a rebuilt one from Drake. There may be other rebuilders of this coupling, but I am not aware of them. I would lean harder on Drake. You wrote: "I also realized today that I need to replace the motor mount bushings!" The elastomeric bushings are part number 530740 and are available from Aircraft Spruce. Please let me know how you make out. OC -- The best investment we will ever make is in gathering knowledge. PS: As mentioned by Old Bob, your old alternator coupling core is worth money to Drake. Subject: AeroElectric-List: Re: Continental IO-240: Alternator quit working From: "FlyboyTR" <flyboytr(at)bellsouth.net> I pulled the engine today for access to the alternator. There was one nut (top) that was almost impossible to remove (ended up removing the starter for easier access) on the alternator. The drive gear on the end of the alternator shaft rotates freely! I have emailed Drake Air (also left them a voice mail...have heard back from them) regarding their rebuilt units. This does not look like a field serviceable part as shown in the Aircraft spruce book (doesn't look the same)! I would welcome any contact names for parts suppliers/rebuilders that would carry this part. I also realized today that I need to replace the motor mount bushings! Thanks again! Travis :) ________________________________________________________________________________
Subject: Alternator Recommendations
Date: Nov 30, 2006
Hi, I am new to the Matronics newsgroups although I have been reading the post for a while this is my first time writing in. I'm building a Zenith 601HDS and will probably go with William Wynne's Corvair conversion. I'm trying to figure my electrical loads before installing the landing lights and closing up the wings and don't believe the typical JD garden tractor alternator is sufficient for my application; I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off base and maybe I shouldn't use a pair of 100 watt off road lights for landing lights. I'd like your recommendations for a small lightweight automotive alternator. From what Ive read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators? There seems to be differing opinions on the whether the load dump issue is a real concern or not. I understand Bob Nuckolls is working on a product to nullify the concern with using internally regulated alternators. Is there any news on this product at this time? Attached is my initial swag at my electrical loads. :D -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78118#78118 Attachments: http://forums.matronics.com//files/ch601hds_electrical_loads_analysis1_106.xls ________________________________________________________________________________
Date: Nov 30, 2006
I sympathize with your conversation on the Seawind. We get those phone calls around here on engine issues. Usually they are all good. But sometimes - - somebody who is way behind the power curve wants to engage in protracted debates over well settled issues. Regards, George -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, November 29, 2006 9:04 AM Subject: RE: AeroElectric-List: 28v diesel engine > >Bob, > >The fuel injection control system on the diesel engine may require 28 >volts for operation. > >Regards, George Hmmm . . . so those guys are going electronic too . . . I guess it comes down to a $time$/weights/parts-count issue. Depending on how much current the engine needs, it might be better to use a small 28v battery and step-up inverter as opposed to a 14 volt battery and step down inverter to support already purchased avioncs. To craft decision right may take as much engineering $time$ as the delta-dollars to sell the 14-volt goodies and buy 28-volt versions. Life can get complicated sometimes! I had a weird phone call yesterday from a guy building a Seawind who was planning to install a PT-6 engine. He started out asking where to buy 100A fuses and I steered him onto the usual suppliers. The conversation expanded to wire sizing and system architecture for engines with starter-generators and it was obvious that he had little knowledge and no experience with the issues. Yet as I attempted to steer him in the right direction, he insisted on arguing with my suggestions. I kept telling him that I wasn't going to argue with him and that our conversation was taking time from my work for a paying customer. He kept asking questions and then arm-wrestling with the answers. I finally suggested that he hire a professional to craft a wirebook for his airplane and offered by services at $150/hour. He replied, "For that kind of money I'll do it myself" whereupon I opined, "Then I guess you don't need me" and hung up. That's the first time I've ever had to forcibly terminate a conversation with a builder. I do wish the fellow well but I'm not optimistic! Some of life's complications are truly intractable. Bob . . . ________________________________________________________________________________
Date: Nov 30, 2006
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Personally I don't have an issue with one wire alternators, I ran one in my Zodiac for over 400 hours and it worked flawlessly. This is assuming you don't have hugely expensive avionics stack either...In my IFR RV7 I still run a one wire but have an Overvolt circuit and contactor...But I still don't expect any real issues. Bob will point out that many doggy old spam cans are running alternators that came out of the Ark! Anyway, the homebuilders choice for many years has been the 1987 Suzuki Samuri Alternator..Its a real gem, lightwieght, powerful (55amps in theory) and extremely reliable...The only time mine acted up was when the back of the alt was continually sprayed with oil that worked itsway to the brushes, then it became intermittent. Replaced the brushes and it was fine. As to your loads, you really don't need to assume your landing lights are part of your running loads as these should only be used intermittently...Having said that, if your running electric fuel pumps only then there is a risk of leaving your LL on and pulling down the battery voltage...I would use a small LED as a warning that you have your lights on. The Suzuki alternator will fit your requirements very nicely however. Regards Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wingrider Sent: Thursday, November 30, 2006 6:06 AM Subject: AeroElectric-List: Alternator Recommendations --> Hi, I am new to the Matronics newsgroups although I have been reading the post for a while this is my first time writing in. I'm building a Zenith 601HDS and will probably go with William Wynne's Corvair conversion. I'm trying to figure my electrical loads before installing the landing lights and closing up the wings and don't believe the typical JD garden tractor alternator is sufficient for my application; I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off base and maybe I shouldn't use a pair of 100 watt off road lights for landing lights. I'd like your recommendations for a small lightweight automotive alternator. From what Ive read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators? There seems to be differing opinions on the whether the load dump issue is a real concern or not. I understand Bob Nuckolls is working on a product to nullify the concern with using internally regulated alternators. Is there any news on this product at this time? Attached is my initial swag at my electrical loads. :D -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78118#78118 Attachments: http://forums.matronics.com//files/ch601hds_electrical_loads_analysis1_106.xls ________________________________________________________________________________
Date: Nov 30, 2006
Subject: Re: 28v diesel engine
Reminds me of the Monty Python routine "I came here for an argument." :-) Also, they say that arguing with an engineer is a lot like wrestling with a pig in the mud. You soon will realize that the pig is actually enjoying it. Bill D. George Braly wrote: > > >I sympathize with your conversation on the Seawind. > >We get those phone calls around here on engine issues. > >Usually they are all good. But sometimes - - somebody who is way behind >the power curve wants to engage in protracted debates over well settled >issues. > >Regards, George > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Robert L. Nuckolls, III >Sent: Wednesday, November 29, 2006 9:04 AM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: 28v diesel engine > > > > > > >> >> > > > >>Bob, >> >>The fuel injection control system on the diesel engine may require 28 >>volts for operation. >> >>Regards, George >> >> > > Hmmm . . . so those guys are going electronic too . . . > I guess it comes down to a $time$/weights/parts-count > issue. > > Depending on how much current the engine needs, it > might be better to use a small 28v battery and step-up > inverter as opposed to a 14 volt battery and step > down inverter to support already purchased avioncs. > > To craft decision right may take as much engineering > $time$ as the delta-dollars to sell the 14-volt > goodies and buy 28-volt versions. > > Life can get complicated sometimes! > > I had a weird phone call yesterday from a guy > building a Seawind who was planning to install a > PT-6 engine. He started out asking where to buy > 100A fuses and I steered him onto the usual suppliers. > > The conversation expanded to wire sizing and system > architecture for engines with starter-generators and > it was obvious that he had little knowledge and no > experience with the issues. Yet as I attempted to > steer him in the right direction, he insisted on > arguing with my suggestions. I kept telling him that > I wasn't going to argue with him and that our > conversation was taking time from my work for a paying > customer. > > He kept asking questions and then arm-wrestling > with the answers. I finally suggested that he hire > a professional to craft a wirebook for his airplane > and offered by services at $150/hour. He replied, > "For that kind of money I'll do it myself" whereupon > I opined, "Then I guess you don't need me" and hung up. > > That's the first time I've ever had to forcibly > terminate a conversation with a builder. I do > wish the fellow well but I'm not optimistic! > Some of life's complications are truly intractable. > > Bob . . . > > > > ________________________________________________________________________________
Date: Nov 30, 2006
Subject: Re: Alternator Recommendations
> >Hi, I am new to the Matronics newsgroups although I have been reading the >post for a while this is my first time writing in. > >I'm building a Zenith 601HDS and will probably go with William Wynne's >Corvair conversion. I'm trying to figure my electrical loads before >installing the landing lights and closing up the wings and don't believe >the typical JD garden tractor alternator is sufficient for my application; >I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off >base and maybe I shouldn't use a pair of 100 watt off road lights for >landing lights. > >I'd like your recommendations for a small lightweight automotive >alternator. From what Ive read it sounds like I should stick with the >three wire alternators and shy away from the one wire versions but are >there recommendations for specific alternators? > >There seems to be differing opinions on the whether the load dump issue is >a real concern or not. I understand Bob Nuckolls is working on a product >to nullify the concern with using internally regulated alternators. Is >there any news on this product at this time? I've acquired an alternator drive stand and hope to spend some time getting it wired up over the xmas holidays. In any case, the internally regulated automotive alternator is the wave of the future and certainly the better value. Drive ahead with any alternator choice that meets your power requirements knowing that any enhancements to the alternator's operability are easily added on at a later time. Bob . . . ________________________________________________________________________________
Date: Nov 30, 2006
Hi Rich FWIW I run an electonic ignition, EFI, and two 38 watt halogen projector lights wig wagging, but not much in the way of avionics and I typically see just over 20 amps daytime and about 26 amps when I add the nav lights. Even at night with the two 38 watt lights on continuously plus two 50 watt landing lights for approach, my wee 40 amp nippondenso (with a homemade large pulley to slow it) still seems to maintain voltage. I've never seen the low voltage warning on the ground either although I usually kill the two 50 watt landing lights while taxiing. While in theory it is fine if the landing lights draw down the battery a tiny bit on approach, it would be a distraction to get a low voltage warning on final. You would either learn to ignore the warning (not good) or disable it when the lights are on which is also not good. My 88 watts per wing of halogen landing and taxi lights is perhaps more than needed but it is appreciated on black nights on runways with no approach lights. Now I also run a 20 amp John Deere PM alternator on a separate system which drives backup EFI, ignition, and strobe lights. It really does put out 20 amps in flight but its output falls off rapidly such that it will not maintain voltage with all those things running during normal ground handling. So while a single John Deere is adequate for daytime operation without exterior lights, you are correct that it would not be very satisfactory for ground running at night for me. With a carb and no EFI electric fuel pumps the 20 amps would be fine I think but exterior lighting would have to be watched on the ground at night and I'd also be looking for LED nav lights. I don't know what your Fujitsu thing is but my conventional nav lights draw a lot more than the 1 amp on your spreadsheet. My ignition also draws a couple of amps. One amp seems a bit low for ignition. Electronic ignition may draw considerably more at high rpm than at idle. The corvair would likely spin the John Deere faster than I am though so that might help. BTW I don't see any real difference between a "one wire" alternator and a automotive internally regulated alternator. The warning light function usually doesn't make a good low voltage warning. The ability to remote sense the voltage that some regulators have doesn't make much difference to us. The ability to delay turnng on the alternator until after engine start also has little value and is not normally used. We know that some of the oem alternators can be turned off but many of us don't believe one can count on that function either once a regulator has failed - so again not much value to that. Ken Wingrider wrote: > >Hi, I am new to the Matronics newsgroups although I have been reading the post for a while this is my first time writing in. > >I'm building a Zenith 601HDS and will probably go with William Wynne's Corvair conversion. I'm trying to figure my electrical loads before installing the landing lights and closing up the wings and don't believe the typical JD garden tractor alternator is sufficient for my application; I expect a full load amp draw of between 35 and 40 amps. Maybe I'm way off base and maybe I shouldn't use a pair of 100 watt off road lights for landing lights. > >I'd like your recommendations for a small lightweight automotive alternator. From what I"ve read it sounds like I should stick with the three wire alternators and shy away from the one wire versions but are there recommendations for specific alternators? > >There seems to be differing opinions on the whether the load dump issue is a real concern or not. I understand Bob Nuckolls is working on a product to nullify the concern with using internally regulated alternators. Is there any news on this product at this time? > >Attached is my initial swag at my electrical loads. > > :D > >-------- >Rich Whittington >Tullahoma, TN >Zenith 601HDS Under Construction > > > ________________________________________________________________________________
Date: Nov 30, 2006
Subject: P-lead shield ground
Should the shielding on p-leads for Bendix mags be grounded at both ends or just at the "Off-Left-Right-Both-Start" switch end? Thanks Neil -- ________________________________________________________________________________
Subject: Switch source
Date: Nov 30, 2006
For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole toggle switch which is designated by Bob Nuckols AeroElectric Connection by 2 -70 , and the B&C website seems not to sell it ( it would be part # S-700-2-70 ). Anybody knows a source for that particular switch? Carlos ________________________________________________________________________________
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Date: Nov 30, 2006
Carlos - I believe I received a similar switch as part of my fuselage kit. neal RV-7 N8ZG For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole toggle switch which is designated by Bob Nuckols AeroElectric Connection by 2 -70 , and the B&C website seems not to sell it ( it would be part # S-700-2-70 ). Anybody knows a source for that particular switch? Carlos
Carlos -
neal
RV-7 N8ZG
Carlos
Date: Nov 30, 2006
Subject: Re: P-lead shield ground
Essentially a recurring question. Discussion on this topic can be found in the archive quite easily. Follow the link at the bottom of each aeroelectric email for access to the archive search tool. An answer: On the magneto end, the shield should be connected to the body of the magneto (sometimes integral to the "P" lead connector) and the center conductor should be connected to the "P" lead. On the switch end, each shield should be connected to the "G" terminal of the switch. The center conductor should be connected to the "L" or "R" terminal. NO additional connections should be made (no "grounds" per se). A picture is worth a bunch: See Figure Z-26 in the latest Z appendix downloadable here: http://www.aeroelectric.com/articles/Rev11/AppZ_R11J.pdf Regards, Matt- > > > Should the shielding on p-leads for Bendix mags be grounded at both > ends or just at the "Off-Left-Right-Both-Start" switch end? > > Thanks > Neil > > > -- > > ________________________________________________________________________________
Date: Nov 30, 2006
>Carlos - > >I believe I received a similar switch as part of my fuselage kit. > >neal >RV-7 N8ZG > > >For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole >toggle switch which is designated by Bob Nuckols AeroElectric Connection >by 2 -70 , and the B&C website seems not to sell it ( it would be part # >S-700-2-70 ). >Anybody knows a source for that particular switch? Newark has one at: http://tinyurl.com/soyjx The Microswitch cross is 2NT1-70. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: Re: Switch source
Date: Nov 30, 2006
----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, November 30, 2006 10:24 PM Subject: RE: AeroElectric-List: Switch source >>For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole >>toggle switch which is designated by Bob Nuckols AeroElectric Connection >>by 2 -70 , and the B&C website seems not to sell it ( it would be part # >>S-700-2-70 ). >>Anybody knows a source for that particular switch? > > > Newark has one at: > > http://tinyurl.com/soyjx > > The Microswitch cross is 2NT1-70. > > Bob . . . > Thanks Bob Now, who is the American soul (fellow homebuilder) who is willing to do a favor to a Portuguese soul who needs that switch ($24.55) but doesn't want to pay Newark's $25 handling fee (only for international customers in a sale less than $100) and maybe another $30 or $40 (around 50% in taxes over invoice value, including hf and freight cost) to the customs in Portugal? If someone can do it, please contact me off-list. Carlos ________________________________________________________________________________
Date: Nov 30, 2006
Seems like Neal was looking for a switch with momentary contacts - maybe like (also at Newark): http://tinyurl.com/uvv93 If that one isn't quite right, there are other (on)-on-(on) switches at Newark, and their website is pretty nicely organized for finding things. Matt- > > > >>Carlos - >> >>I believe I received a similar switch as part of my fuselage kit. >> >>neal >>RV-7 N8ZG >> >> >>For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole >>toggle switch which is designated by Bob Nuckols AeroElectric Connection >>by 2 -70 , and the B&C website seems not to sell it ( it would be part # >>S-700-2-70 ). >>Anybody knows a source for that particular switch? > > > Newark has one at: > > http://tinyurl.com/soyjx > > The Microswitch cross is 2NT1-70. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Nov 30, 2006
Sorry Carlos, I misidentified the original poster of this switch request (what was I just saying about proof reading posts? :| ).. You might try Googling the Honeywell part number to find a vendor with a more favorable shipping policy than Newark has.. I searched for "2TL1-70 Honeywell" (the momentary contact switch) .. and found a bunch of places that sell it (some in France and Italy if that helps). Regards, Matt- > > > > ----- Original Message ----- > From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> > To: > Sent: Thursday, November 30, 2006 10:24 PM > Subject: RE: AeroElectric-List: Switch source > >>>For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole >>>toggle switch which is designated by Bob Nuckols AeroElectric >>> Connection >>>by 2 -70 , and the B&C website seems not to sell it ( it would be part # >>>S-700-2-70 ). >>>Anybody knows a source for that particular switch? >> >> >> Newark has one at: >> >> http://tinyurl.com/soyjx >> >> The Microswitch cross is 2NT1-70. >> >> Bob . . . >> > > Thanks Bob > > Now, who is the American soul (fellow homebuilder) who is willing to do a > favor to a Portuguese soul who needs that switch ($24.55) but doesn't want > to pay Newark's $25 handling fee (only for international customers in a > sale > less than $100) and maybe another $30 or $40 (around 50% in taxes over > invoice value, including hf and freight cost) to the customs in Portugal? > If someone can do it, please contact me off-list. > > Carlos > > ________________________________________________________________________________
Date: Nov 30, 2006
Thanks for the information, I'll research the Suzuki alternator. The Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation using PocketFMS and Voyager. My nav lights are LED's that's why the amp draw is so low. Now I just have to figure out how to mount an alternator to the rear of the Corvair. -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78303#78303 ________________________________________________________________________________
Date: Nov 30, 2006
Rich, I just went through this for my Bearhawk. I spent a lot of time trying to find a Samurai alternator; they are no longer available new. Niagra Airparts no longer carries the ND, either. I did find and ND 45 amp internally regulated alternator for $175 at: http://www.litechracesystems.com/Products.html It arrived this week and is a new ND part no. 18504-6220. Good luck, Mike C. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Wingrider Sent: Thursday, November 30, 2006 5:32 PM Subject: AeroElectric-List: Re: Alternator Recommendations Thanks for the information, I'll research the Suzuki alternator. The Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation using PocketFMS and Voyager. My nav lights are LED's that's why the amp draw is so low. Now I just have to figure out how to mount an alternator to the rear of the Corvair. -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78303#78303 ________________________________________________________________________________
Date: Nov 30, 2006
Why does this need to be an (on) on (on) switch instead of the plain old common (on)off(on) flap switch? I guess I'm not aware of a flap system in an RV that requires such a configuration and why a standard old flap switch that we all have used on our RV's (supplied by Van's, us, etc..) for years wouldn't work!? Please enlighten me....I'm just curious! Cheers, Stein. >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert >L. Nuckolls, III >Sent: Thursday, November 30, 2006 4:25 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: Switch source > > > > > >>Carlos - >> >>I believe I received a similar switch as part of my fuselage kit. >> >>neal >>RV-7 N8ZG >> >> >>For my new (remodelled) flaps system I need an (ON)-ON-(ON) Double Pole >>toggle switch which is designated by Bob Nuckols AeroElectric Connection >>by 2 -70 , and the B&C website seems not to sell it ( it would be part # >>S-700-2-70 ). >>Anybody knows a source for that particular switch? > > > Newark has one at: > >http://tinyurl.com/soyjx > > The Microswitch cross is 2NT1-70. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Dec 01, 2006
Answers in order of post appearance :-) : Matt No problem with your misidentification. I will google it and try to find a more favourable vendor. Kevin Thanks very much for your offer. If I cannot find a better source, I'll come back and ask for your help from Canada. Stein No wonder you're curious. The reason I need this kind of switch is because I'm installing the Flaps Positioning System that I bought from Aircraft Extras, which calls for 3 switches : 1 selector switch between Automatic and Manual operation ( SPDT On-On switch ), 1 Automatic Flaps switch ("normal" SPDT (On)-Off-(On) ), which operates the flaps to stop where you programmed it and automatically positions the elevator trim, and finally a Manual Flaps switch, which is a back-up or emergency switch, to operate the flaps when and if the system fails. This last switch connects the flap motor directly to +12V and must be acomplished by 2 SPDT On-None-(On) switches, or (I figured it out, I hope I'm right) by 1 DPDT (On)-On-(On), wich is what I'm looking for Richard I surely got the flaps switch from Van's (although I couldn't find it - well, I got it some 4 years ago), but as you can see from the above explanation, it doesn't suit my need, unless I use a double relay board. Also, thanks for your offer to get the switch for me. I'll get back if I can't find it. Aren't this internet groups so GREAT to get help and knowledge!!? Carlos ________________________________________________________________________________
Date: Dec 01, 2006
> > >Answers in order of post appearance :-) : > >Matt >No problem with your misidentification. I will google it and try to find a >more favourable vendor. > >Kevin >Thanks very much for your offer. If I cannot find a better source, I'll >come back and ask for your help from Canada. > >Stein >No wonder you're curious. The reason I need this kind of switch is because >I'm installing the Flaps Positioning System that I bought from Aircraft >Extras, which calls for 3 switches : 1 selector switch between Automatic >and Manual operation ( SPDT On-On switch ), 1 Automatic Flaps switch >("normal" SPDT (On)-Off-(On) ), which operates the flaps to stop where you >programmed it and automatically positions the elevator trim, and finally a >Manual Flaps switch, which is a back-up or emergency switch, to operate >the flaps when and if the system fails. This last switch connects the flap >motor directly to +12V and must be acomplished by 2 SPDT On-None-(On) >switches, or (I figured it out, I hope I'm right) by 1 DPDT (On)-On-(On), >wich is what I'm looking for Hmmmm . . . how likely is it that an inability to move flaps in this airplane presents a hazard to outcome of the flight? I am exceedingly suspicious of systems offered to the OBAM community that add any kind of automation to the movement of aerodynamic surfaces with motors. In the heavy iron business we have rigorous protocols for the design and testing of any motor driven flight surface. The concerns are not for inability to move the surface but for unintended and unanticipated motion during a high risk phase of flight. Too many designs offered to the OBAM aircraft community worry about inability to move surfaces (as it seems with your description). I've not flown many kinds of airplanes but after the Cessna 150's got their flap extension angles reduced from 40 to 30 degrees, there are no airplanes in my experience that are likely to get into trouble by failure of flaps to move from any current position. This includes airplanes like our Premier I. If I used an airplane in situations were high reliability, positive control of flaps was desirable, the most attractive systems are operated by a handle on the floor. As soon as you start adding features for motor drive, automatic extension, backups to backups, etc. I'm wondering if the "concerns" for useful operation of flaps isn't generated more my marketing hype than for convenient, reliable, low risk use of flaps. A part that is not installed on your airplane is not at risk of failure and offers the lowest cost-of-ownership. Bob . . . ________________________________________________________________________________
Date: Dec 01, 2006
>> >> Stein >> No wonder you're curious. The reason I need this kind of switch is >> because I'm installing the Flaps Positioning System that I bought >> from Aircraft Extras, which calls for 3 switches : 1 selector switch >> between Automatic and Manual operation ( SPDT On-On switch ), 1 >> Automatic Flaps switch ("normal" SPDT (On)-Off-(On) ), which operates >> the flaps to stop where you programmed it and automatically positions >> the elevator trim, and finally a Manual Flaps switch, which is a >> back-up or emergency switch, to operate the flaps when and if the >> system fails. This last switch connects the flap motor directly to >> +12V and must be acomplished by 2 SPDT On-None-(On) switches, or (I >> figured it out, I hope I'm right) by 1 DPDT (On)-On-(On), wich is >> what I'm looking for. Carlos, I will be using the same system and have pretty much decided to delete all the optional switches. I think if the Flaps Positioning System fails, well I'll consider the flaps have failed. I consider that if you have electric flaps on an aircraft you have to be trained to use your machine without flaps. I think adding all backup hardware is looking for more trouble. My 0.02 cents, Pascal GROELL RV-7A #72588 www.notreavion.net ________________________________________________________________________________
Subject: Auto-pilots
Date: Dec 01, 2006
I have always admired the in the electronics arena -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David M. Sent: 24 Nov 2006 06:54 PM Subject: Re: AeroElectric-List: Auto-pilots If I can determine and find the right stepper motors, I plan to build my own :) David M. Bob Verwey wrote: > Hey listers, > I'm looking around at auto-pilots. Obviously searched the net a bit, > but still wondering, any recommendations from the list? > > Bob Verwey > A35 Bonanza ZU-DLW > > > >----------------------------------------------------------------------- >- > > > > ________________________________________________________________________________
Date: Dec 01, 2006
> >Thanks for the information, I'll research the Suzuki alternator. The >Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation >using PocketFMS and Voyager. When alternator shopping based on the recommendations of others, it's useful to know that there's no such thing as a "Honda" or "GEO_Metro" alternator. 95% of the world's supply of alternators is manufactured by a handful of companies of which folks like Bosch and Nipon Denso are major players. It's unfortunate that so many different versions of electrically identical alternators are offered in so many mechanical variations. But this is like choosing and/or attempting to mandate the language of measurement. It's an attractive idea but fruitless to suggest that all auto manufacturers get together and pick a suite of say 25 parts around which everyone will design their electrical systems. Certainly the parts jobbers and dealers would be delighted . . . as perhaps customers. They'd certainly cost less. Bottom line is that on the shelves of any well stock parts supplier, there are dozens of alternators that will perform just fine in your airplane. The value in selecting a "Honda" alternator may come from the fact that somebody has published drawings for the mechanical interface between THAT particular alternator and YOUR engine. Just keep in mind that electrical and quality issues are tiny considerations compared to size, weight and ease of integration into your airframe . . . and that the number of choices open to you run far beyond anyone's particular preferences or recommendations. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 01, 2006
Subject: Super-Battery pedigree?
>Hi Bob, > >Got your email from a builder friend of mine. I guess you are an electrics >expert, so perhaps you can answer my battery questions. > >I fly a Glasair I RG that I finished in 1988. In 1986, when I began to >work on the retractable gear, I bought a 12 volt sealed battery from a >company in Scottsdale, AZ called Electromarketing. I found them in Sport >Aviation. > >Long story short, that battery is still ticking in my Glasair. About 3 >years ago in the winter, it didn't have quite enough umph to start, so I >put a trickle charger on it that came with the battery. It was so old, >that the polarity had fallen off. I figured 50-50 chance and left it >overnight charging. The next day the battery was stone dead. It wouldn't >close the relay. I figured my magic battery was finally dead. However, I >extracted it from the battery box in the tail and brought it home and put >a different charger on it. Back to life she came. I had not opened that >battery box in over 15 years. > >Have you ever heard of a battery lasting this long? > >Do you know what happened to that company? I'd like to buy another battery >from them if the need ever arises. > >I still have the receipt from that company, but have been unable to find >them. I asked EAA about it years ago, but never got a response. I'm sorry, I'm not familiar with that company. They are probably a distributor and not a manufacturer. I'm not aware of anyone having the success you've experienced. When that battery finally becomes unserviceable in your airplane, you might consider shipping it to me. I'll see if I can identify the source. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 01, 2006
Subject: Avionics power distribution
> Hi Bob, > >Question: Van's RV10 standard Van's wiring schematic. From Avionics master >SCB to the live feed stud on subpanel. All avionics feed from this stud, >Garmin 340 audio panel, GNS530, SL30 Navcom and GTX330 mode S. Is it >acceptable to use an inline fuse in each individual wire coming from the >feedstud or is a fusepanel better? I'm not able to visualize your question. The architectures I recommend and the reasons behind their development are cited in http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf and Chapter 17 of the book. Obviously, there are many variations on a theme that will "function". The need for an avionics master switch disappeared over 25 years ago but it's a concept that lingers on, deeply rooted in our aviation mind-set. If you want to send me a drawing of your proposed architecture, I'll try to be more specific in my answer. Bob . . . ----------------------------------------- ( Experience and common sense cannot be ) ( replaced with policy and procedures. ) ( R. L. Nuckolls III ) ----------------------------------------- ________________________________________________________________________________
Date: Dec 01, 2006
> >I have always admired the in the electronics arena > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David M. >Sent: 24 Nov 2006 06:54 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Auto-pilots > > >If I can determine and find the right stepper motors, I plan to build my own >:) The rule of thumb asks for 30 lb-in of torque at the actuator output shaft. You don't want your one-pass gear reduction to exceed 10:1 (very hard to do anyhow) and 5:1 to 7:1 is better. So you need a stepper good for breaking out of position against a 3 to 6 lb-in load. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 01, 2006
Yes Bob I agree, but there are alternators that have less than a stella reputation, the Van 35A "Honda" alternator being a case in point. The "Suzuki Samurai" is a ND unit and for the life of me I can't find the ND part number. It was indeed used on many cars the biggest difference being whether it was fitted with a V belt pully or a serpentine. When I found my 80A "Toyota Camry" alt for my IFR RV it cam with a serp pulley, An alternator rebuilder kindly found me a v pulley that fitted. Once you get past the pulley the rest is just fabricating suitable brackets to suit. I would post a note to the "Stratus group" as someone on there will have the part number handy. I would be very surprised if this alt was no longer available. Cheers Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, December 01, 2006 8:21 AM Subject: Re: AeroElectric-List: Re: Alternator Recommendations --> >--> > >Thanks for the information, I'll research the Suzuki alternator. The >Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation >using PocketFMS and Voyager. When alternator shopping based on the recommendations of others, it's useful to know that there's no such thing as a "Honda" or "GEO_Metro" alternator. 95% of the world's supply of alternators is manufactured by a handful of companies of which folks like Bosch and Nipon Denso are major players. It's unfortunate that so many different versions of electrically identical alternators are offered in so many mechanical variations. But this is like choosing and/or attempting to mandate the language of measurement. It's an attractive idea but fruitless to suggest that all auto manufacturers get together and pick a suite of say 25 parts around which everyone will design their electrical systems. Certainly the parts jobbers and dealers would be delighted . . . as perhaps customers. They'd certainly cost less. ________________________________________________________________________________
Date: Dec 01, 2006
A quick check with Google found this http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizard.js p?year=1987&make=SZ&model=SAM--001&part=Alternator&dp=true Best regards, Rob Housman A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Hinde, Frank George (Corvallis) Sent: Friday, December 01, 2006 8:51 AM Subject: RE: AeroElectric-List: Re: Alternator Recommendations Yes Bob I agree, but there are alternators that have less than a stella reputation, the Van 35A "Honda" alternator being a case in point. The "Suzuki Samurai" is a ND unit and for the life of me I can't find the ND part number. It was indeed used on many cars the biggest difference being whether it was fitted with a V belt pully or a serpentine. When I found my 80A "Toyota Camry" alt for my IFR RV it cam with a serp pulley, An alternator rebuilder kindly found me a v pulley that fitted. Once you get past the pulley the rest is just fabricating suitable brackets to suit. I would post a note to the "Stratus group" as someone on there will have the part number handy. I would be very surprised if this alt was no longer available. Cheers Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, December 01, 2006 8:21 AM Subject: Re: AeroElectric-List: Re: Alternator Recommendations --> >--> > >Thanks for the information, I'll research the Suzuki alternator. The >Fujitsu is a Tablet PC I plan to attach to the panel for gps navigation >using PocketFMS and Voyager. When alternator shopping based on the recommendations of others, it's useful to know that there's no such thing as a "Honda" or "GEO_Metro" alternator. 95% of the world's supply of alternators is manufactured by a handful of companies of which folks like Bosch and Nipon Denso are major players. It's unfortunate that so many different versions of electrically identical alternators are offered in so many mechanical variations. But this is like choosing and/or attempting to mandate the language of measurement. It's an attractive idea but fruitless to suggest that all auto manufacturers get together and pick a suite of say 25 parts around which everyone will design their electrical systems. Certainly the parts jobbers and dealers would be delighted . . . as perhaps customers. They'd certainly cost less. ________________________________________________________________________________
Date: Dec 01, 2006
Subject: Vx Aviation Products now Available Directly from Aircraft
Extras Aircraft Extras Inc., and Vx Aviation have entered into a distribution agreement in which all of Vx Aviations products will be distributed by Aircraft Extras. This agreement will reduce shipping time and cost, and give customers broader access to an extensive line of innovative products. Aircraft Extras is located centrally in Columbus, Ohio, and Vx Aviation is located near Vancouver, BC Canada. The founders of the two organizations are both RV builders and engineers. Many of the innovative products developed or marketed by them were developed for use in RVs, but have applications in most amateur-built/experimental aircraft. Many of the builders who frequent vansairforce.net or the aeroelectric-list at matronics.com are familiar with Rich Meske (Aircraft Extras) and Vern Little (Vx Aviation) from postings or as customers of their products. Aircraft Extras now markets Vx Aviations external AoA indicator for Dynon EFIS systems, an audio bus for Sigtronics intercoms, annunciator controllers and wiring accessories for the Rocky Mountain engine monitor. In addition, Aircraft Extras sells Trutrak Flight Systems autopilots, systems for flap positioning, trim control, fuel and oil level warning,, plus various useful add-ons, enhancements, accessories and the famous Meske Tip-Up/Slider modification kit for RVs. A complete list of Aircraft Extras products is available at www.aircraft-extras.com. The Vx Aviation home page is www.vx-aviation.com. For more information: Rich Meske, Aircraft Extras Vern Little, Vx Aviation Thank-you Vern Little ________________________________________________________________________________
Date: Dec 01, 2006
Subject: Re: Auto-pilots
Be sure to test the load on the stick with the wires on the stepper shorted together. This "plug braking" mode offers MUCH more resistance to movement than does the motor with open leads. Since the driver silicon is quite likely to fail shorted (or stuck "on",) you must be able to move the stick with shorted motor leads. Also, be sure that the output driver is protected from the very large voltages that the stepper will generate when the stick (or control surface) is jerked around quickly. You can also arc across the stepper windings if the driver circuit doesn't have something to limit these voltages. Some sort of mechanical clutch or shear pin in the servo drive is a prudent addition. A toothed rubber belt can be selected that will break/slip if need be. The basics can be simple, but the details can get quite complicated. :-) Bill Dube' > ________________________________________________________________________________
Date: Dec 01, 2006
That's the one!...I had to shorten the link to make it work by removing the "wizrd.js" part then I could step thru to 1987 Suz samurai. $130 for a new alt...Can't beat that with a stick! Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Rob Housman Sent: Friday, December 01, 2006 9:22 AM Subject: RE: AeroElectric-List: Re: Alternator Recommendations --> <robh@hyperion-ef.us> A quick check with Google found this http://replacement.autopartswarehouse.com/parts/autopartswarehouse/wizar d.js p?year=1987&make=SZ&model=SAM--001&part=Alternator&dp=true Best regards, Rob Housman A070 Airframe complete Irvine, CA ________________________________________________________________________________
Date: Dec 01, 2006
I thought a simple breaker in the power supply line would be enough. Remove the power and a stepper should free-wheel. Are there other failure modes even with power removed? Thanks, David M. Bill Dube wrote: > > > Be sure to test the load on the stick with the wires on the stepper > shorted together. This "plug braking" mode offers MUCH more resistance > to movement than does the motor with open leads. Since the driver > silicon is quite likely to fail shorted (or stuck "on",) you must be > able to move the stick with shorted motor leads. > > Also, be sure that the output driver is protected from the very large > voltages that the stepper will generate when the stick (or control > surface) is jerked around quickly. You can also arc across the stepper > windings if the driver circuit doesn't have something to limit these > voltages. > > Some sort of mechanical clutch or shear pin in the servo drive is a > prudent addition. A toothed rubber belt can be selected that will > break/slip if need be. > > The basics can be simple, but the details can get quite > complicated. :-) > > Bill Dube' > >> > > ________________________________________________________________________________
Date: Dec 01, 2006
Stepper may not freewheel with the power removed from the driver circuit. If the silicon is shorted, the stepper will plug brake. If you force the stepper to spin too fast, you can blow out the silicon with over-voltage, and perhaps cause it to short. The back-feed of voltage into the driver circuit (on or off) from the spinning stepper can cause all sorts of problems. If you simply spin the stepper itself too fast, you can possibly arc over, then short the windings, causing it to plug brake. Your auto-pilot system should be designed to be tolerant of all of these fault scenarios. Steppers don't really "freewheel", instead they "cog." Bill Dube' David M. wrote: > > I thought a simple breaker in the power supply line would be enough. > Remove the power and a stepper should free-wheel. Are there other > failure modes even with power removed? > > Thanks, > David M. > > > Bill Dube wrote: > >> >> >> Be sure to test the load on the stick with the wires on the stepper >> shorted together. This "plug braking" mode offers MUCH more >> resistance to movement than does the motor with open leads. Since the >> driver silicon is quite likely to fail shorted (or stuck "on",) you >> must be able to move the stick with shorted motor leads. >> >> Also, be sure that the output driver is protected from the very large >> voltages that the stepper will generate when the stick (or control >> surface) is jerked around quickly. You can also arc across the >> stepper windings if the driver circuit doesn't have something to >> limit these voltages. >> >> Some sort of mechanical clutch or shear pin in the servo drive is a >> prudent addition. A toothed rubber belt can be selected that will >> break/slip if need be. >> >> The basics can be simple, but the details can get quite >> complicated. :-) >> >> Bill Dube' >> >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 01, 2006
Seems I've read of autopilots having a clutch of sorts. I would think that an electromechanical clutch could be included which would allow decoupling of the stepper motor from the control bellcrank. The clutch would failsafe in the decoupled configuration.. Regards, Matt- > > > Stepper may not freewheel with the power removed from the driver > circuit. If the silicon is shorted, the stepper will plug brake. If you > force the stepper to spin too fast, you can blow out the silicon with > over-voltage, and perhaps cause it to short. The back-feed of voltage > into the driver circuit (on or off) from the spinning stepper can cause > all sorts of problems. If you simply spin the stepper itself too fast, > you can possibly arc over, then short the windings, causing it to plug > brake. > > Your auto-pilot system should be designed to be tolerant of all of > these fault scenarios. > > Steppers don't really "freewheel", instead they "cog." > > Bill Dube' > > David M. wrote: > >> >> I thought a simple breaker in the power supply line would be enough. >> Remove the power and a stepper should free-wheel. Are there other >> failure modes even with power removed? >> >> Thanks, >> David M. >> >> >> Bill Dube wrote: >> >>> >>> >>> Be sure to test the load on the stick with the wires on the stepper >>> shorted together. This "plug braking" mode offers MUCH more >>> resistance to movement than does the motor with open leads. Since the >>> driver silicon is quite likely to fail shorted (or stuck "on",) you >>> must be able to move the stick with shorted motor leads. >>> >>> Also, be sure that the output driver is protected from the very large >>> voltages that the stepper will generate when the stick (or control >>> surface) is jerked around quickly. You can also arc across the >>> stepper windings if the driver circuit doesn't have something to >>> limit these voltages. >>> >>> Some sort of mechanical clutch or shear pin in the servo drive is a >>> prudent addition. A toothed rubber belt can be selected that will >>> break/slip if need be. >>> >>> The basics can be simple, but the details can get quite >>> complicated. :-) >>> >>> Bill Dube' >>> >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Lightspeed ignition wiring
Date: Dec 01, 2006
Hi Looking for views on Lightspeed ignition wiring. The installation manual says to run power and ground wires direct to battery terminals to suppress radio interference. With a battery being in the rear of the aircraft and one main fat wire running up to the firewall what thoughts does anyone have on using the fatwire terminal on the start relay instead of running (hot) wires all the way back to the battery terminals. Any real life experience out there? Thanks Chris ________________________________________________________________________________
Date: Dec 01, 2006
From: "David Chalmers" <David(at)ChalmersFamily.com>
I did exactly what you describe with a Plasma II. I had a fat wire running to a battery in the rear and connected the ignition to the fat wires at the engine. Didn't work too well. The voltage drop in those fat wires when starting was a problem. Symptoms were engine would spin great but wouldn't fire until starter switch was released. I rewired it per instructions with dedicated hot wires back to the battery for the ignition and have had no further problems. Dave Chalmers TriQ200 N4016G 250hrs Redmond WA -----Original Message----- From: Chris Fordham [mailto:fconsult(at)telus.net] Sent: Friday, December 01, 2006 6:35 PM Subject: AeroElectric-List: Lightspeed ignition wiring Hi Looking for views on Lightspeed ignition wiring. The installation manual says to run power and ground wires direct to battery terminals to suppress radio interference. With a battery being in the rear of the aircraft and one main fat wire running up to the firewall what thoughts does anyone have on using the fatwire terminal on the start relay instead of running (hot) wires all the way back to the battery terminals. Any real life experience out there? Thanks Chris ________________________________________________________________________________
Date: Dec 01, 2006
> >Be sure to test the load on the stick with the wires on the stepper >shorted together. This "plug braking" mode offers MUCH more resistance to >movement than does the motor with open leads. Since the driver silicon is >quite likely to fail shorted (or stuck "on",) you must be able to move the >stick with shorted motor leads. Brushless dc motors have permanent magnet rotors that do have a substantial backdriving force with the windings shorted . . . but except for a small "gogging" force, the backdriving torque is velocity related. In other words, the motor can't "lock up" the shaft with simple shorted windings . . . it can only resist motion with resitance going up as velocity increases. A stepper (or at least all the motors I've worked with) don't have PM rotors and generate no driving EMF or velocity related backdriving resistance. >Also, be sure that the output driver is protected from the very large >voltages that the stepper will generate when the stick (or control >surface) is jerked around quickly. You can also arc across the stepper >windings if the driver circuit doesn't have something to limit these voltages. Again, no permanent magnets, no back emf. > Some sort of mechanical clutch or shear pin in the servo drive is a > prudent addition. A toothed rubber belt can be selected that will > break/slip if need be. I size the pinion gear width and material to provide the last-ditch, mechanical fuse. Usually at about 60 to 100 lb-in of back driving force. > The basics can be simple, but the details can get quite complicated. :-) That's the nice thing about steppers. Very low parts count. Very low risks to manual operability whether energized or de-energized and all without clutches and brakes. Bob . . . ________________________________________________________________________________
Date: Dec 01, 2006
> >I thought a simple breaker in the power supply line would be enough. >Remove the power and a stepper should free-wheel. Are there other failure >modes even with power removed? > >Thanks, >David M. No, steppers have very benign failure modes and none are "runaway" events. You don't want to OVERSIZE the motor because you're depending on the steppers INABILITY to hold position while energized should the electronics hang up. In a de-energized state, steppers are very free wheeling. Bob . . . ________________________________________________________________________________
Date: Dec 01, 2006
> >Stepper may not freewheel with the power removed from the driver circuit. >If the silicon is shorted, the stepper will plug brake. If you force the >stepper to spin too fast, you can blow out the silicon with over-voltage, >and perhaps cause it to short. The back-feed of voltage into the driver >circuit (on or off) from the spinning stepper can cause all sorts of >problems. If you simply spin the stepper itself too fast, you can possibly >arc over, then short the windings, causing it to plug brake. > > Your auto-pilot system should be designed to be tolerant of all of > these fault scenarios. > > Steppers don't really "freewheel", instead they "cog." Bill, can you cite me a part number and manufacturer of a motor that exhibits these characteristics? I've done about a dozen programs with steppers of various sizes (20A machines with 400 oz-in of breakout torque) and all would freewheel nicely when de-energize and generated no back-emf. I suppose one COULD build a stepper with a PM rotor but it would be difficult to achieve the 1.8 degree stepping angle rotors that have strong permanent magnet poles. Bob . . . ________________________________________________________________________________
Date: Dec 01, 2006
> >Seems I've read of autopilots having a clutch of sorts. I would think >that an electromechanical clutch could be included which would allow >decoupling of the stepper motor from the control bellcrank. The clutch >would failsafe in the decoupled configuration.. A VERY common feature in autopilot servos of yore and even today with the large servos used to fly bizjets. But the little stepper driving a single pass gear train to hold a heading is not capable of producing breathtaking maneuvers and it's output torque is sharply limited. Bob . . . ________________________________________________________________________________
Date: Dec 02, 2006
Subject: Re: Lightspeed ignition wiring
Chris, I have one LightSpeed installed on a IO-320. I had Lightspeed send me a new signal pickup assembly with longer than normal wires. The hot wire goes to a combination circuit breaker/switch and then to the positive battery terminal. Besides the radio noise issue, I believe the real reason is to eliminate points of failure in the wiring run. In my case the only problem I can experience is a broken wire or a broken switch. Otherwise the power will always be delivered where it is needed to run the system. On 12/1/06, David Chalmers wrote: > > > I did exactly what you describe with a Plasma II. I had a fat wire running to a battery in the rear and connected the ignition to the fat wires at the engine. Didn't work too well. The voltage drop in those fat wires when starting was a problem. Symptoms were engine would spin great but wouldn't fire until starter switch was released. I rewired it per instructions with dedicated hot wires back to the battery for the ignition and have had no further problems. > > Dave Chalmers > TriQ200 N4016G 250hrs > Redmond WA > > -----Original Message----- > From: Chris Fordham [mailto:fconsult(at)telus.net] > Sent: Friday, December 01, 2006 6:35 PM > To: AeroElectric-List(at)matronics.com > Subject: AeroElectric-List: Lightspeed ignition wiring > > > Hi > Looking for views on Lightspeed ignition wiring. The installation manual > says to run power and ground wires direct to battery terminals to suppress > radio interference. With a battery being in the rear of the aircraft and one > main fat wire running up to the firewall what thoughts does anyone have on > using the fatwire terminal on the start relay instead of running (hot) wires > all the way back to the battery terminals. Any real life experience out > there? > > Thanks Chris > > ________________________________________________________________________________
Date: Dec 02, 2006
AutoZone lists the 1987 Suzuki Samurai for $96 with a limited lifetime warranty and show it to weight 7.7 lbs. Now if I could find someone in southern Tennessee or northern Alabama with a Corvair in a Zenith 601 I'd like to have a look at how much room is available to mount this alternator. -------- Rich Whittington Tullahoma, TN Zenith 601HDS Under Construction Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78614#78614 ________________________________________________________________________________
Date: Dec 02, 2006
----- Original Message ----- From: "Pascal GROELL" <pgroell(at)yahoo.fr> Sent: Friday, December 01, 2006 3:43 PM Subject: Re: AeroElectric-List: Switch source > Carlos, > > I will be using the same system and have pretty much decided to delete all > the optional switches. > I think if the Flaps Positioning System fails, well I'll consider the > flaps have failed. > I consider that if you have electric flaps on an aircraft you have to be > trained to use your machine without flaps. > I think adding all backup hardware is looking for more trouble. > My 0.02 cents, > > Pascal GROELL > RV-7A #72588 > www.notreavion.net > Bonjour Pascal C'est toujous agrable de trouver quelq'un de ce cot de l'Atlantique. Well, it is really your choice to not use the optional switches, and not having the back-up/emergency functionality. However, on one hand, that's not what the factory (Aircraft Extras) recommend. On the other hand, have you considered what will you do in the following occasions?: - you are doing or practicing slow flight, with your flaps at the maximum deployment, and the FPS-Plus fails. If you are somewhere far from a landing point, you will have to go there very slowly... - you are flying towards a short runway airfield, and before landing your Flap Posit. system fails. How are you going to land without some amount of flaps deployed? - You are in short final to any kind of airfield, with your flaps deployed at maximum, and suddenly some obstacle occupies your runway. If your FPS fails, how are you going to go-around? Although I'm aware these are low probability situations, they are nevertheless some reasons why I want to have back-up/emergency manual control of my flaps Amicalement Carlos ________________________________________________________________________________
Subject: Re: Continental IO-240: Alternator quit working
Date: Dec 02, 2006
I wanted to bring closure to this issue. Please accept my sincere appreciation to all those that provided a wealth of information. The elastomeric puck was the failed part. I sent Drake Air my old part so it could be rebuilt. They charge $450 for this service. Aircraft Spruce does NOT carry this part. They carry the rebuild parts for a different drive coupling. I have attached some pictures showing the coupling and the engine removal. Again, Thanks to everyone for your help and support. Travis :) -------- Travis Rayner Mobile, AL Skystar Vixen N-789DF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78625#78625 Attachments: http://forums.matronics.com//files/vixen_engine_alternator_removal16_609.jpg http://forums.matronics.com//files/vixen_engine_alternator_removal18_202.jpg http://forums.matronics.com//files/vixen_alternator_drive_coupling6_144.jpg http://forums.matronics.com//files/vixen_alternator_drive_coupling5_170.jpg http://forums.matronics.com//files/vixen_alternator_drive_coupling1_911.jpg http://forums.matronics.com//files/vixen_alternator_drive_coupling3_105.jpg ________________________________________________________________________________
Date: Dec 02, 2006
Carlos Trigo a crit : > > > > ----- Original Message ----- From: "Pascal GROELL" <pgroell(at)yahoo.fr> > To: > Sent: Friday, December 01, 2006 3:43 PM > Subject: Re: AeroElectric-List: Switch source > >> Carlos, >> >> I will be using the same system and have pretty much decided to >> delete all the optional switches. >> I think if the Flaps Positioning System fails, well I'll consider the >> flaps have failed. >> I consider that if you have electric flaps on an aircraft you have to >> be trained to use your machine without flaps. >> I think adding all backup hardware is looking for more trouble. >> My 0.02 cents, >> >> Pascal GROELL >> RV-7A #72588 >> www.notreavion.net >> > > Bonjour Pascal > > C'est toujous agrable de trouver quelq'un de ce cot de l'Atlantique. > > Well, it is really your choice to not use the optional switches, and > not having the back-up/emergency functionality. However, on one hand, > that's not what the factory (Aircraft Extras) recommend. On the other > hand, have you considered what will you do in the following occasions?: > - you are doing or practicing slow flight, with your flaps at > the maximum deployment, and the FPS-Plus fails. If you are somewhere > far from a landing point, you will have to go there very slowly... > - you are flying towards a short runway airfield, and before > landing your Flap Posit. system fails. How are you going to land > without some amount of flaps deployed? > - You are in short final to any kind of airfield, with your > flaps deployed at maximum, and suddenly some obstacle occupies your > runway. If your FPS fails, how are you going to go-around? > > Although I'm aware these are low probability situations, they are > nevertheless some reasons why I want to have back-up/emergency manual > control of my flaps > > Amicalement > Carlos Bonjour Carlos, I would do the same I would do if my flap switch or flap motor would fail in these situations. I see no differences. But that's each builders choice, and I respect yours. Hope I we can meet one day on this side of the Atlantic. Happy building. Pascal > > ________________________________________________________________________________
Date: Dec 02, 2006
> Hope I we can meet one day on this side of the Atlantic. > > Pascal And where exactly are you building ? Next January I will go to Barcelona and do some skiing in the Pyrines, so if you are in south of France .... Carlos ________________________________________________________________________________
Date: Dec 02, 2006
Subject: Questions??
Hi Bob, In the John Deere alternator and regulator frequently talked about here is the rectifier in the regulator? And, Is the alternator generating 3 phase AC ? And, about what voltage is the output of the alternator. Also, since we know that the # 5 terminal must be connected to voltage or the alternator doesn't work. I have tried this and it is true. Then what is the circuit like? And would it be a good place to connect the overvoltage crowbar to? Enjoyed your lectures at Bloomington recently. Cleone ________________________________________________________________________________
Subject: Tach pickup
Date: Dec 02, 2006
I'm wiring tach pickup wires to a switch that selects which mags gives the tach signal. This switch is right above the two mag toggle switches. Since I'm using EIS 4000, they say to wire from the P-lead through a 27k resistor to the tach selector switch. Any concerns with just using a small pigtail off of the P-lead wire at the mag switch (going into the tach selector switch)? I'd prefer not to run another wire all the way to the mag itself just for tach signal. My concerns here are noise and functionality (eg. to ensure it works as wired up). Also, any concerns with running the P-lead shielded wire together with the rest of wires, or should I find a separate path and firewall penetration just for these two wires? PS. Why does 20AWG shielded wire's inner conductor appear to be thinner than regular 20AWG tefzel wire (measured diameter including insulation)? It looks the same to me as 22AWG tefzel wrapped in shielding (and my stripper won't strip it at 20AWG setting). Thanks! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78685#78685 ________________________________________________________________________________
Subject: VOR antenna splitter?
Date: Dec 02, 2006
Resurrecting an old thread here. I'm working on building a new panel with a GNS 430 (needs separate VOR and GS inputs) and a SL-30 (internal diplexer so needs GS and VOR on same coax). My question is, with the referenced splitters/couplers, does the glideslope freq range get stripped off of the VOR outputs? (Real question, if I use the CI-505, will my SL-30 see the GS freqs from one of the VOR outputs?) I understand I'm getting less energy to the receivers, but I want to give a single antenna a try before I add a second during this retrofit. Thanks much, John RV-8 94DW -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, April 06, 2005 5:55 PM Subject: Re: AeroElectric-List: VOR antenna splitter? --> > > >I am thinking of adding a Garmin AT SL 30 NavCom to the CNX 80 > >Both have internal splitters for the localizer and the glide slope. It >OK to use ONE VOR antenna for both boxes? I recognize I would be >introducing a single point failure but it seems sufficiently remote. I >am concerned that both would have adequate signal levels. > >An archives search on antenna splitter gave no guidance. See http://www.aircraftspruce.com/catalog/avpages/com_couplers3.php These work good and last a long time. Bob . . . ________________________________________________________________________________
Date: Dec 02, 2006
This exchange might be helpful... No. It only passes VOR frequencies. Use our new CI 5120 instead. Don Jeckell Comant Industries Tel (714) 870-2420 Fax (714) 870-5133 x546 -----Original Message----- From: Bill Denton [mailto:bdenton(at)bdenton.com] Sent: Friday, March 24, 2006 2:34 PM Subject: Question RE: CI-502 Hello! Does the CI-502 Dual VOR Splitter allow glideslope signals to pass through it to the receivers? Thank you! ---------------------------------------------------------------------------- - -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of John Erickson Sent: Saturday, December 2, 2006 4:10 PM Subject: RE: AeroElectric-List: VOR antenna splitter? Resurrecting an old thread here. I'm working on building a new panel with a GNS 430 (needs separate VOR and GS inputs) and a SL-30 (internal diplexer so needs GS and VOR on same coax). My question is, with the referenced splitters/couplers, does the glideslope freq range get stripped off of the VOR outputs? (Real question, if I use the CI-505, will my SL-30 see the GS freqs from one of the VOR outputs?) I understand I'm getting less energy to the receivers, but I want to give a single antenna a try before I add a second during this retrofit. Thanks much, John RV-8 94DW -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, April 06, 2005 5:55 PM Subject: Re: AeroElectric-List: VOR antenna splitter? --> > > >I am thinking of adding a Garmin AT SL 30 NavCom to the CNX 80 > >Both have internal splitters for the localizer and the glide slope. It >OK to use ONE VOR antenna for both boxes? I recognize I would be >introducing a single point failure but it seems sufficiently remote. I >am concerned that both would have adequate signal levels. > >An archives search on antenna splitter gave no guidance. See http://www.aircraftspruce.com/catalog/avpages/com_couplers3.php These work good and last a long time. Bob . . . ________________________________________________________________________________
Date: Dec 02, 2006
Subject: Re: Tach pickup
> >I'm wiring tach pickup wires to a switch that selects which mags gives the >tach signal. This switch is right above the two mag toggle >switches. Since I'm using EIS 4000, they say to wire from the P-lead >through a 27k resistor to the tach selector switch. > >Any concerns with just using a small pigtail off of the P-lead wire at the >mag switch (going into the tach selector switch)? I'd prefer not to run >another wire all the way to the mag itself just for tach signal. My >concerns here are noise and functionality (eg. to ensure it works as wired up). . . . suggest you wire as shown in http://www.aeroelectric.com/PPS/Engine/Ignition/Mags_with_Electronic_Tach_A.pdf >Also, any concerns with running the P-lead shielded wire together with the >rest of wires, or should I find a separate path and firewall penetration >just for these two wires? No. Run them together with other stuff as long as shields are grounded as shown above. >PS. Why does 20AWG shielded wire's inner conductor appear to be thinner >than regular 20AWG tefzel wire (measured diameter including >insulation)? It looks the same to me as 22AWG tefzel wrapped in shielding >(and my stripper won't strip it at 20AWG setting). Maybe because it's not 20AWG wire but 22AWG. How do you come to believe that it's actually 20AWG wire. If there's a mil number on the wire it will looke somethign like 22759/16-20-9 where 22759 is the base spec. Slash 16 is the sub spec. 20 is the AWG and 9 is color. If there's a third dash number then it's the stripe color. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 02, 2006
Bob, many thanks for the suggestion. I like the simplicity of it very much! :) Wish I found this drawing before drilling a hole for the selector switch... but no biggie, the hole can be filled. I do have a quick follow-up question -- the drawing I was using (toggle mag switches with start button) call out for 20 AWG shielded wire for P-leads... This drawing calls out for 18AWG shielded... Any concerns with using 20, which I have on hand? Or should I be ordering 18? As for size of the wire.. I got the 20AWG shielded from B&C... Found the numbers on it and they read: M27500-20 TG1T14 So I guess it is 20AWG.. but again.. I gotta use 22 setting on the stripper to strip it.. Thanks again! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78713#78713 ________________________________________________________________________________
Date: Dec 02, 2006
Subject: Re: Questions??
Cleones wrote: > > Hi Bob, In the John Deere alternator and regulator frequently talked > about here is the rectifier in the regulator? Yes. > And, Is the alternator generating 3 phase AC ? No. It is single phase AC. There are only two wires coming out of it. > And, about what voltage is the output of the alternator. It will go up to about 200 volts open circuit but when loaded it will be in the vicinity of 15 volts depending on how you measure it. > Also, since we know that the # 5 terminal must be connected to > voltage or the alternator doesn't work. I have tried this and it is > true. Then what is the circuit like? And would it be a good place to > connect the overvoltage crowbar to? Enjoyed your lectures at > Bloomington recently. Cleone I interupt the wires into the regulator. In the past Bob has said that either into or out of the regulator will do the job but I wanted to be able to cut power to the regulator in case it was overheating or internally shorted. The regulator uses the battery connection to turn itself on and to sense the battery voltage so that it can regulate to 14.4 volts nominal output. Ken ________________________________________________________________________________
Date: Dec 02, 2006
Ummm Is this a test ;) ? Why wouldn't 20 awg shielded wire have a 20awg center wire?? Ken snip > >> PS. Why does 20AWG shielded wire's inner conductor appear to be >> thinner than regular 20AWG tefzel wire (measured diameter including >> insulation)? It looks the same to me as 22AWG tefzel wrapped in >> shielding (and my stripper won't strip it at 20AWG setting). > > > Maybe because it's not 20AWG wire but 22AWG. > How do you come to believe that it's actually > 20AWG wire. If there's a mil number on the wire > it will looke somethign like 22759/16-20-9 where > 22759 is the base spec. Slash 16 is the sub spec. > 20 is the AWG and 9 is color. If there's a third > dash number then it's the stripe color. > > Bob . . . ________________________________________________________________________________
Date: Dec 02, 2006
Hmm.. but this makes the start button "live" when both mags are off... Is this a big concern in "real life?" I did like the other drawing a bit better when the button was live only when left was on and right off.. I guess can't have it all? :) -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78721#78721 ________________________________________________________________________________
Date: Dec 02, 2006
"Robert L. Nuckolls, III" wrote: > > >PS. Why does 20AWG shielded wire's inner conductor appear to be thinner > >than regular 20AWG tefzel wire (measured diameter including > >insulation)? It looks the same to me as 22AWG tefzel wrapped in shielding > >(and my stripper won't strip it at 20AWG setting). > > Maybe because it's not 20AWG wire but 22AWG. > How do you come to believe that it's actually > 20AWG wire. If there's a mil number on the wire > it will looke somethign like 22759/16-20-9 where > 22759 is the base spec. Slash 16 is the sub spec. > 20 is the AWG and 9 is color. If there's a third > dash number then it's the stripe color. > > Bob . . . > > I use quite a bit of the 22 AWG shielded wire. The MIL spec for the shielded wire I've been using and which seems to be commonly available is M27500. The insulation is thinner than 22750/16. I haven't seen shielded wire with 22750/16 conductors. Bob W. -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.4 Hours Total Time Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Subject: Re: Switch source
Date: Dec 03, 2006
On 2 Dec 2006, at 08:23, Carlos Trigo wrote: > > > - You are in short final to any kind of airfield, with > your flaps deployed at maximum, and suddenly some obstacle occupies > your runway. If your FPS fails, how are you going to go-around? > > Although I'm aware these are low probability situations, they are > nevertheless some reasons why I want to have back-up/emergency > manual control of my flaps As Pascal indicated, there are many possible reasons why flap systems may fail. If it is not possible to safely do a go-around with the flaps fully extended, this suggests that the maximum flap angle is too great. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Dec 03, 2006
> >Bob, many thanks for the suggestion. I like the simplicity of it very >much! :) Wish I found this drawing before drilling a hole for the >selector switch... but no biggie, the hole can be filled. > >I do have a quick follow-up question -- the drawing I was using (toggle >mag switches with start button) call out for 20 AWG shielded wire for >P-leads... This drawing calls out for 18AWG shielded... Any concerns with >using 20, which I have on hand? Or should I be ordering 18? No, the currents that flow in these wires would be easily handled by 22AWG wire. There's a kind of rule-of-thumb for wires under the cowl, especially those that control the mags to make them mechanically robust. This suggests the use of 20 or even 18AWG wire. I've seen some drawings call out 16AWG. >As for size of the wire.. I got the 20AWG shielded from B&C... Found the >numbers on it and they read: M27500-20 TG1T14 So I guess it is 20AWG.. >but again.. I gotta use 22 setting on the stripper to strip it.. Interesting. This probably speaks more to the accuracy of the dies in your tool as opposed to variabilities in the actual size of the wire. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 03, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> >Ummm >Is this a test ;) ? >Why wouldn't 20 awg shielded wire have a 20awg center wire?? >Ken > Was just inquiring as to the pedigree of the wire. I have a spool of perfectly good wire where the wire itself is not marked but label on the spool is incorrect. Just asking about the data he had to KNOW that the wire was indeed 20AWG. The source and markings suggest the wire is the size he believes it to be . . . which leaves tool variabilities as the probable cause for his observations. Bob. . . >snip > >> >>>PS. Why does 20AWG shielded wire's inner conductor appear to be thinner >>>than regular 20AWG tefzel wire (measured diameter including >>>insulation)? It looks the same to me as 22AWG tefzel wrapped in >>>shielding (and my stripper won't strip it at 20AWG setting). >> >> >> Maybe because it's not 20AWG wire but 22AWG. >> How do you come to believe that it's actually >> 20AWG wire. If there's a mil number on the wire >> it will looke somethign like 22759/16-20-9 where >> 22759 is the base spec. Slash 16 is the sub spec. >> 20 is the AWG and 9 is color. If there's a third >> dash number then it's the stripe color. >> >> Bob . . . > > >-- > > >-- incoming mail is certified Virus Free. >Checked by AVG Anti-Virus. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 03, 2006
> >Hmm.. but this makes the start button "live" when both mags are off... Is >this a big concern in "real life?" I did like the other drawing a bit >better when the button was live only when left was on and right off.. I >guess can't have it all? :) Yeah, that was a problem but I ran out of poles on the left mag switch. You could get a 3-pole switch for the left mag and produce the functionality you're interested in. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Subject: Pitot Current Draw
Date: Dec 03, 2006
I have a pitot on an Exp. Aircraft that was designed for a heavier aircraft. To accommodate the high speed and high altitude cold, the pitot was configured to get very hot, with consumate amperage demand. Given the lower demands of a GA aircraft, is there any way of reducing the heating of the pitot (very warm to the touch would be fine...I don't need to be able to brand someone!) with a consumate reduction in amperage demand? Chuck Jensen ________________________________________________________________________________
Date: Dec 03, 2006
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Pitot Current Draw
There are ways, but what leads you to believe that the pitot is really too hot? The whole purpose of the heater is to keep it clear in any condition - rain, freezing rain, cold ambient, etc. Depending on what plane you have, you will be flying at upwards of 200 mph through all this (hopefully NOT freezing rain) and the last thing you want is for the pitot to freeze up. Dick Tasker Chuck Jensen wrote: > >I have a pitot on an Exp. Aircraft that was designed for a heavier >aircraft. To accommodate the high speed and high altitude cold, the >pitot was configured to get very hot, with consumate amperage demand. >Given the lower demands of a GA aircraft, is there any way of reducing >the heating of the pitot (very warm to the touch would be fine...I don't >need to be able to brand someone!) with a consumate reduction in >amperage demand? > >Chuck Jensen > > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Dec 04, 2006
Subject: Dumb questions
Hi Bob and all, A buddy asked me to help him design his electrical circuit. Here are some question for you experts : - What size fuse or breaker for a facet (round) fuel pump : 5 amps, 7.5 amps, 10 amps ? - What breaker size for a B&C Lycoming O-360 starter solenoid ? Thanks in advance, Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Dec 03, 2006
"Robert L. Nuckolls, III" wrote: > > Was just inquiring as to the pedigree of the wire. > I have a spool of perfectly good wire where the > wire itself is not marked but label on the spool is > incorrect. Just asking about the data he had to > KNOW that the wire was indeed 20AWG. The source > and markings suggest the wire is the size he believes > it to be . . . which leaves tool variabilities as the > probable cause for his observations. > > Bob. . . > > > >snip > > Nope. I finally found a quick summary for the M27500 specification. (Available at http://www.awcwire.com/pdf/CT-G4-M27500.pdf.) M27500 can be made with any M22759 wire. M22759 with different /no. have different insulation thicknesses. I've been buying M27500-22TG3T14 which turns out to have M22759/18 wire in it. That's specified by the TG. Here are some wire outer diameters per the M22759 spec.: M22759/16 20 AWG 0.058 - 0.062 M22759/18 20 AWG 0.049 - 0.053 M22759/16 22 AWG 0.050 - 0.053 This data is from http://www.jaguarind.com/products/teflon/teflonwire.html So if you have the M27500-20TG wire, the OD of the wire is identical to the OD of M22759/16 22 AWG. If you want M22759/16 wire in your M27500 shielded cable, it has to be M27500-xxTExxxx. My experience stripping the 22 AWG M22759/18 wire with the 22 AWG setting on my stripper is that sometimes it works and sometimes it slips. Once it's slipped, the insulation has been thinned some more and I have to complete the strip with my el cheepo stripper similar to your picture http://www.aeroelectric.com/articles/strippers/mvc829.jpg Bob W. -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.4 Hours Total Time Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Date: Dec 03, 2006
Bob W. -- that's it. I mic'ed both tefzel 22 and this shielded 20 and they both came out at 0.050... My stripper doesn't wanna strip it at 20.. but works at 22 fine.. so I'm good to go. I decided to keep the selector switch, as I didn't like having a live starter button... It does appear that using a 3 pole switch woudl be ideal. Since my left mag switch is close to the rib, not sure if 3 pole switch would fit in there (not sure about its size).. so this will work good. Thanks to everyone! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=78891#78891 ________________________________________________________________________________
Date: Dec 03, 2006
I would like to add that the pitot tube should burn your hand if you grab it after it has been on for more than 1 or 2 minutes. There are ways, but what leads you to believe that the pitot is really too hot? The whole purpose of the heater is to keep it clear in any condition - rain, freezing rain, cold ambient, etc. Depending on what plane you have, you will be flying at upwards of 200 mph through all this (hopefully NOT freezing rain) and the last thing you want is for the pitot to freeze up. Dick Tasker Chuck Jensen wrote: > >I have a pitot on an Exp. Aircraft that was designed for a heavier >aircraft. To accommodate the high speed and high altitude cold, the >pitot was configured to get very hot, with consumate amperage demand. >Given the lower demands of a GA aircraft, is there any way of reducing >the heating of the pitot (very warm to the touch would be fine...I don't >need to be able to brand someone!) with a consumate reduction in >amperage demand? > >Chuck Jensen > > > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- Lynn A. Riggs riggs_la(at)yahoo.com St. Paul, MN BH #656 Kit #22 http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html --------------------------------- ________________________________________________________________________________
Date: Dec 03, 2006
Good Evening Lynn, Dick and Chuck, In a previous life, I flew quite a few airplanes that had a high and a low heat for the pitot tubes. They were on low for ground operations and on high heat for airborne use. I think it was controlled by a strut switch, but not sure. Worked well though. Happy Skies, Old Bob --- Lynn Riggs wrote: > I would like to add that the pitot tube should burn > your hand if you grab it after it has been on for > more than 1 or 2 minutes. > > "Richard E. Tasker" wrote: > Tasker" > > There are ways, but what leads you to believe that > the pitot is really > too hot? The whole purpose of the heater is to keep > it clear in any > condition - rain, freezing rain, cold ambient, etc. > Depending on what > plane you have, you will be flying at upwards of 200 > mph through all > this (hopefully NOT freezing rain) and the last > thing you want is for > the pitot to freeze up. > > Dick Tasker > > Chuck Jensen wrote: > > Jensen" > > > >I have a pitot on an Exp. Aircraft that was > designed for a heavier > >aircraft. To accommodate the high speed and high > altitude cold, the > >pitot was configured to get very hot, with > consumate amperage demand. > >Given the lower demands of a GA aircraft, is there > any way of reducing > >the heating of the pitot (very warm to the touch > would be fine...I don't > >need to be able to brand someone!) with a consumate > reduction in > >amperage demand? > > > >Chuck Jensen > > > > > > > > > > > > > > > > > > -- > Please Note: > No trees were destroyed in the sending of this > message. We do concede, however, > that a significant number of electrons may have been > temporarily inconvenienced. > -- > > > > > > > > > Lynn A. Riggs > riggs_la(at)yahoo.com > St. Paul, MN > BH #656 Kit #22 > http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html > > --------------------------------- ________________________________________________________________________________
Date: Dec 03, 2006
> >I have a pitot on an Exp. Aircraft that was designed for a heavier >aircraft. To accommodate the high speed and high altitude cold, the >pitot was configured to get very hot, with consumate amperage demand. >Given the lower demands of a GA aircraft, is there any way of reducing >the heating of the pitot (very warm to the touch would be fine...I don't >need to be able to brand someone!) with a consumate reduction in >amperage demand? Altitude and speed have little to do with a pitot tube's need to transfer heat to the surface. The kind of ice that a pitot tube is expected to handle happens at lower altitudes and relatively slow speeds. It's the super-cooled water droplets that freeze instantly on contact that represent the largest challenge to the pitot tube's ability to shed ice. If you've ever witnessed an ice-tunnel test on a piece of aviation de-ice equipment, you'd realize that if your pitot tube is being seriously challenged, then knowing altitude and airspeed are probably the least of your concerns. Icing conditions you're likely to survive can probably be shed by a relatively whimpy pitot tube deice heater but these are exceedingly difficult things to quantify. Pitot tubes we THOUGHT were adequate 30 years ago are scoffed at today. Intuitively, your assertion is not in error, ANY amount of heat will shed SOME ice. SOME ice is survivable while OTHER ice is not. Given the changes in de-ice certification protocols over the years, it becomes difficult to put numbers on "any", "some" and "other". So difficult that for anyone to offer you advice advocating "this many watts as opposed to that many watts" may be blowing smoke you-know-where. When that stuff starts appearing anywhere on your airplane is not the time to be experimenting with the adequacy of your pitot heater decisions. The best rule of thumb is put on the biggest heater you can find/afford but plan on the expeditious 180 no matter how robust you belive your heater to be. Bob . . . ________________________________________________________________________________
Date: Dec 03, 2006
Hi Bob, Staying out of icing if possible is good advice. I lost pitot static instruments 2 or 3 times in a full deicing equipped Navy jet over a 3 year period. It gives you quite a chill in the spinal area to see your airspeed dropping off so quickly to zero. I happened to be level at the time of loss. Icing of the pitot tube turns your airspeed indicator into an altimeter for all intents and purposes. The higher you go the higher the airspeed you'll see. The lower you go the lower the airspeed. You can see how hazardous that is since you'll climb and show higher airspeed with the nose way up, right to the stall and spin. Another sound piece of advice is to know what airspeed a given attitude and power setting will give you and don't mess with your configuration any more than necessary to land. Safe flying, Bob Sultzbach Need a quick answer? Get one in minutes from people who know. Ask your question on www.Answers.yahoo.com ________________________________________________________________________________
Date: Dec 04, 2006
Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, December 03, 2006 11:31 PM Subject: Re: AeroElectric-List: Pitot Current Draw --> >--> > >I have a pitot on an Exp. Aircraft that was designed for a heavier >aircraft. To accommodate the high speed and high altitude cold, the >pitot was configured to get very hot, with consumate amperage demand. >Given the lower demands of a GA aircraft, is there any way of reducing >the heating of the pitot (very warm to the touch would be fine...I >don't need to be able to brand someone!) with a consumate reduction in >amperage demand? Altitude and speed have little to do with a pitot tube's need to transfer heat to the surface. The kind of ice that a pitot tube is expected to handle happens at lower altitudes and relatively slow speeds. It's the super-cooled water droplets that freeze instantly on contact that represent the largest challenge to the pitot tube's ability to shed ice. If you've ever witnessed an ice-tunnel test on a piece of aviation de-ice equipment, you'd realize that if your pitot tube is being seriously challenged, then knowing altitude and airspeed are probably the least of your concerns. Icing conditions you're likely to survive can probably be shed by a relatively whimpy pitot tube deice heater but these are exceedingly difficult things to quantify. Pitot tubes we THOUGHT were adequate 30 years ago are scoffed at today. Intuitively, your assertion is not in error, ANY amount of heat will shed SOME ice. SOME ice is survivable while OTHER ice is not. Given the changes in de-ice certification protocols over the years, it becomes difficult to put numbers on "any", "some" and "other". So difficult that for anyone to offer you advice advocating "this many watts as opposed to that many watts" may be blowing smoke you-know-where. When that stuff starts appearing anywhere on your airplane is not the time to be experimenting with the adequacy of your pitot heater decisions. The best rule of thumb is put on the biggest heater you can find/afford but plan on the expeditious 180 no matter how robust you belive your heater to be. Bob . . . ________________________________________________________________________________
Date: Dec 04, 2006
Good Morning Chuck, Believe 'twas I who mentioned a strut switch. In any case it is switch mounted on a landing gear strut that switches something on or off when the aircraft is airborne. Such a switch is often used to prevent gear retraction when the aircraft is on the ground. It is not at all uncommon to have a strut switch on a nose gear that will actuate a relay which controls multiple functions when the aircraft is airborne. The dual heat pitot tube has often been activated by a nose gear strut switch on airplanes I have flown. I have never seen a pilot activated switch that handled that function, but I see no reason why one could not be installed if that is your desire. You could even have multiple heat choices if you wanted the added complication. Happy Skies, Old Bob --- Chuck Jensen wrote: > Jensen" > > Okay, I appreciate everyone holding forth that it's > stupid to fly in > ice....I'm not that dumb, I only look it. However, > the question stands, > how does one knock down the heat and current draw. > Richard mentioned a > 'strut switch'....whoever that is. Can someone > enlighten us > non-electrical types. What I'm concerned about is > being in the clouds, > close to freezing and loose electrical--I'd just as > soon not have to > turn off the pitot heat because it's sucking the > battery dry in short > order; I'd rather it be in long order. > > Chuck Jensen > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] > On Behalf Of > Robert L. Nuckolls, III > Sent: Sunday, December 03, 2006 11:31 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Pitot Current Draw > > > Nuckolls, III" > --> > > > Jensen" > >--> > > > >I have a pitot on an Exp. Aircraft that was > designed for a heavier > >aircraft. To accommodate the high speed and high > altitude cold, the > >pitot was configured to get very hot, with > consumate amperage demand. > >Given the lower demands of a GA aircraft, is there > any way of reducing > >the heating of the pitot (very warm to the touch > would be fine...I > >don't need to be able to brand someone!) with a > consumate reduction in > >amperage demand? > > Altitude and speed have little to do with a pitot > tube's > need to transfer heat to the surface. The kind of > ice that > a pitot tube is expected to handle happens at > lower altitudes > and relatively slow speeds. It's the super-cooled > water droplets > that freeze instantly on contact that represent > the largest > challenge to the pitot tube's ability to shed > ice. > > If you've ever witnessed an ice-tunnel test on a > piece > of aviation de-ice equipment, you'd realize that > if your > pitot tube is being seriously challenged, then > knowing > altitude and airspeed are probably the least of > your concerns. > > Icing conditions you're likely to survive can > probably be > shed by a relatively whimpy pitot tube deice > heater but these > are exceedingly difficult things to quantify. > Pitot tubes > we THOUGHT were adequate 30 years ago are scoffed > at today. > > Intuitively, your assertion is not in error, ANY > amount of > heat will shed SOME ice. SOME ice is survivable > while OTHER > ice is not. Given the changes in de-ice > certification protocols > over the years, it becomes difficult to put > numbers on "any", > "some" and "other". So difficult that for anyone > to offer you > advice advocating "this many watts as opposed to > that many > watts" may be blowing smoke you-know-where. > > When that stuff starts appearing anywhere on your > airplane > is not the time to be experimenting with the > adequacy of > your pitot heater decisions. The best rule of > thumb is put > on the biggest heater you can find/afford but > plan on the > expeditious 180 no matter how robust you belive > your heater > to be. > > Bob . . . > > > > > > > > > Click on > about > provided > www.buildersbooks.com > Admin. > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > > > > ________________________________________________________________________________
Subject: Belly Com Antenna Shadowing
Date: Dec 04, 2006
From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com>
I'm getting ready to mount my bent-whip com antenna on the belly of my RV-9A (tricycle gear). I would like to mount it near the main landing gear weldment forward of the spar where the bottom skin is thicker and where I can easily reach the BNC connector during flight. Can anyone give me an idea how much shadowing will occur from the gear leg? Thanks Daniel Snow RV-9A, Electrical ________________________________________________________________________________
Subject: Re: Belly Com Antenna Shadowing
Date: Dec 04, 2006
It works fine in that location. -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=79001#79001 ________________________________________________________________________________
Date: Dec 04, 2006
Robert Sultzbach wrote: > >Hi Bob, > > Staying out of icing if possible is good advice. I >lost pitot static instruments 2 or 3 times in a full >deicing equipped Navy jet over a 3 year period. > I've been following this thread, and this post begs the question I've been mulling over. What good is a heated pitot in an airplane without deicing equipment? I'm thinking that if the pitot is covered in ice, then so is the rest of the plane. Your airspeed is now next to useless, because all those stall speed numbers are now meaningless. Whatever they were before, they changed when the ice modified all the airfoils and the CG. A cockpit referenced backup altimeter would seem to give the best bang for the $time$...not terribly accurate, but sufficient to keep you out of cumulous granite until you can improve your situation. Ernest (a sunny day flyer). -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 04, 2006
Daniel, I just ordered a bent whip antenna to mount on the belly of the RV-9 I am building. I am considering mounting it on the other side of the fuselage so that the co-pilot can reach it. Why? I thought that if I ever have a radio failure and have to switch to hand held then I will just ask the co-pilot to hook up the radio rather than me doing it while trying to fly and navigate. If I don't have a co-pilot at that moment then I guess I will get to practice my "lost comm." procedures. I remember during my initial flight training many years ago my instructor would yank the microphone out of my hand and tell me, "The Wright brothers invented the airplane not Marconi, FLY the Plane". Mike Ice RV-9, Electrical ----- Original Message ----- From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> Sent: Monday, December 04, 2006 4:13 AM Subject: AeroElectric-List: Belly Com Antenna Shadowing > > > I'm getting ready to mount my bent-whip com antenna on the belly of my > RV-9A (tricycle gear). I would like to mount it near the main landing > gear weldment forward of the spar where the bottom skin is thicker and > where I can easily reach the BNC connector during flight. Can anyone > give me an idea how much shadowing will occur from the gear leg? > > Thanks > > Daniel Snow > RV-9A, Electrical > > > ________________________________________________________________________________
Date: Dec 04, 2006
Didn't your CFII tell you to break the glass on the VSI if that happens. But your altimeter wouldn't be effected by a pitot blockage. We all have heated static ports, right? Alternate static air valves? Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Monday, December 04, 2006 9:27 AM Subject: Re: AeroElectric-List: Pitot Current Draw Robert Sultzbach wrote: > >Hi Bob, > > Staying out of icing if possible is good advice. I >lost pitot static instruments 2 or 3 times in a full >deicing equipped Navy jet over a 3 year period. > I've been following this thread, and this post begs the question I've been mulling over. What good is a heated pitot in an airplane without deicing equipment? I'm thinking that if the pitot is covered in ice, then so is the rest of the plane. Your airspeed is now next to useless, because all those stall speed numbers are now meaningless. Whatever they were before, they changed when the ice modified all the airfoils and the CG. A cockpit referenced backup altimeter would seem to give the best bang for the $time$...not terribly accurate, but sufficient to keep you out of cumulous granite until you can improve your situation. Ernest (a sunny day flyer). -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 04, 2006
Chuck, Thank you for addressing this scenario. I, too, would like to hear others respond. As for me, icing or not, if I lose my main alternator, I would switch on Endurance mode (which is only 8 amps...thus, no pitot) and land that puppy ASAP. This is not an emergent situation. Not so with your stock Cessna. A well designed electrical system can make a huge difference in the outcome of a flight. Bret Smith ----- Original Message ----- From: "Chuck Jensen" <cjensen(at)dts9000.com> Sent: Monday, December 04, 2006 7:13 AM Subject: RE: AeroElectric-List: Pitot Current Draw > > > Okay, I appreciate everyone holding forth that it's stupid to fly in > ice....I'm not that dumb, I only look it. However, the question stands, > how does one knock down the heat and current draw. Richard mentioned a > 'strut switch'....whoever that is. Can someone enlighten us > non-electrical types. What I'm concerned about is being in the clouds, > close to freezing and loose electrical--I'd just as soon not have to > turn off the pitot heat because it's sucking the battery dry in short > order; I'd rather it be in long order. > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Robert L. Nuckolls, III > Sent: Sunday, December 03, 2006 11:31 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Pitot Current Draw > > > --> > > >>--> >> >>I have a pitot on an Exp. Aircraft that was designed for a heavier >>aircraft. To accommodate the high speed and high altitude cold, the >>pitot was configured to get very hot, with consumate amperage demand. >>Given the lower demands of a GA aircraft, is there any way of reducing >>the heating of the pitot (very warm to the touch would be fine...I >>don't need to be able to brand someone!) with a consumate reduction in >>amperage demand? > > Altitude and speed have little to do with a pitot tube's > need to transfer heat to the surface. The kind of ice that > a pitot tube is expected to handle happens at lower altitudes > and relatively slow speeds. It's the super-cooled water droplets > that freeze instantly on contact that represent the largest > challenge to the pitot tube's ability to shed ice. > > If you've ever witnessed an ice-tunnel test on a piece > of aviation de-ice equipment, you'd realize that if your > pitot tube is being seriously challenged, then knowing > altitude and airspeed are probably the least of your concerns. > > Icing conditions you're likely to survive can probably be > shed by a relatively whimpy pitot tube deice heater but these > are exceedingly difficult things to quantify. Pitot tubes > we THOUGHT were adequate 30 years ago are scoffed at today. > > Intuitively, your assertion is not in error, ANY amount of > heat will shed SOME ice. SOME ice is survivable while OTHER > ice is not. Given the changes in de-ice certification protocols > over the years, it becomes difficult to put numbers on "any", > "some" and "other". So difficult that for anyone to offer you > advice advocating "this many watts as opposed to that many > watts" may be blowing smoke you-know-where. > > When that stuff starts appearing anywhere on your airplane > is not the time to be experimenting with the adequacy of > your pitot heater decisions. The best rule of thumb is put > on the biggest heater you can find/afford but plan on the > expeditious 180 no matter how robust you belive your heater > to be. > > Bob . . . > > > ________________________________________________________________________________
Subject: Re: VOR antenna splitter?
Date: Dec 04, 2006
I have the same setup, GNS430 and SL30. I attached a BNC T-connector directly to the VOR/GS input connection on the splitter. Connected VOR/GS antenna cable to 1 branch of the T, and ran a short cable to the SL30 from the other branch of the T. That way, SL30 gets both VOR and GS, while the 430 gets the split outputs from the splitter. I don't know how much signal loss I have, but it has worked well for almost 2 years. The SL30 does pick up the glideslope a bit sooner than the 430. I haven't noticed a consistent difference in VOR range between the two. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=79066#79066 ________________________________________________________________________________
Date: Dec 04, 2006
Bruce Gray wrote: > >Didn't your CFII tell you to break the glass on the VSI if that happens. But >your altimeter wouldn't be effected by a pitot blockage. We all have heated >static ports, right? Alternate static air valves? > >Bruce >www.glasair.org > > > > Hard to do without a mechanical VSI 8*) Breaking the glass on your EFIS is just not pretty. If I did have a mechanical VSI, I still wouldn't break the glass on it. Just no point in going around busting up perfectly good instruments. I assume that if ice is building up to block the pitot, the static is very close to being next in line. Then you have to be aware enough to notice that something is sneaking up on you. I've never had it happen, but what I understand is that the meter slowly becomes more and more innacurate. It doesn't just fall over dead. A backup device feeding from a safe alternate source (like cabin air), will give you a much quicker heads up. That might be a good feature to have on an EFIS. Compare the cabin to static pressures and raise an alarm if they get out of range...then display both 'altitudes' if the pilot chooses. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 04, 2006
Why not run coax to a bulkhead jack on the panel so either one of you can reach it with a patch cord from the handheld? Regarding antenna location, I doubt you'll notice shadowing from the gear legs. I have done my RV-6A this way and it's not an operational issue. I abandoned wingtip antennas due to shadowing and a subsequent turtledeck location due to severe RF in the cockpit (headphones) due to _lack of_ shadowing. I could not ameliorate that problem with ferrites on the headset cabling, so I gave up and moved the comm whip to the belly between the gear legs where it apparently belongs ;-). You will likely experience front-end overload when close to another transmitter- signals will sound garbled- but that's not shadowing and should not depend much on antenna location anyway. Best, -Stormy On 12/4/06, Michael T. Ice wrote: > > Daniel, > > I just ordered a bent whip antenna to mount on the belly of the RV-9 I am > building. I am considering mounting it on the other side of the fuselage so > that the co-pilot can reach it. Why? I thought that if I ever have a radio > failure and have to switch to hand held then I will just ask the co-pilot to > hook up the radio rather than me doing it while trying to fly and navigate. > If I don't have a co-pilot at that moment then I guess I will get to > practice my "lost comm." procedures. I remember during my initial flight > training many years ago my instructor would yank the microphone out of my > hand and tell me, "The Wright brothers invented the airplane not Marconi, > FLY the Plane". > > Mike Ice > RV-9, Electrical > > ----- Original Message ----- > From: "Snow, Daniel A." <Daniel.Snow(at)wancdf.com> > To: > Sent: Monday, December 04, 2006 4:13 AM > Subject: AeroElectric-List: Belly Com Antenna Shadowing > > > > > > > > I'm getting ready to mount my bent-whip com antenna on the belly of my > > RV-9A (tricycle gear). I would like to mount it near the main landing > > gear weldment forward of the spar where the bottom skin is thicker and > > where I can easily reach the BNC connector during flight. Can anyone > > give me an idea how much shadowing will occur from the gear leg? > > > > Thanks > > > > Daniel Snow > > RV-9A, Electrical > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Dec 04, 2006
LOL, it's always the simple solutions that evade me... Thanks much... John -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of steveadams Sent: Monday, December 04, 2006 10:09 AM Subject: AeroElectric-List: Re: VOR antenna splitter? --> I have the same setup, GNS430 and SL30. I attached a BNC T-connector directly to the VOR/GS input connection on the splitter. Connected VOR/GS antenna cable to 1 branch of the T, and ran a short cable to the SL30 from the other branch of the T. That way, SL30 gets both VOR and GS, while the 430 gets the split outputs from the splitter. I don't know how much signal loss I have, but it has worked well for almost 2 years. The SL30 does pick up the glideslope a bit sooner than the 430. I haven't noticed a consistent difference in VOR range between the two. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=79066#79066 __________ NOD32 1899 (20061204) Information __________ ________________________________________________________________________________
Subject: Instrument mounting screw washers
Date: Dec 04, 2006
Awhile back someone mentioned here or on the Glasair.org BB that model railroad wheel washers were ideal size for the instrument mounting screws. I can't find the message. I tried the model railroad show in VA Beach this weekend to no avail. Anyone have a line on where to get these critters? Mark Banus Glasair II ________________________________________________________________________________
Date: Dec 04, 2006
Subject: Re: Super-Battery pedigree?
I seem to recall that some Mazda Miata's (not all) had a special battery with an ~10 year life span. Maybe follow that lead. Ed Mueller N3730G RV10 in Progress Robert L. Nuckolls, III wrote: > > > >> Hi Bob, >> >> Got your email from a builder friend of mine. I guess you are an >> electrics expert, so perhaps you can answer my battery questions. >> >> I fly a Glasair I RG that I finished in 1988. In 1986, when I began >> to work on the retractable gear, I bought a 12 volt sealed battery >> from a company in Scottsdale, AZ called Electromarketing. I found >> them in Sport Aviation. >> >> Long story short, that battery is still ticking in my Glasair. About >> 3 years ago in the winter, it didn't have quite enough umph to start, >> so I put a trickle charger on it that came with the battery. It was >> so old, that the polarity had fallen off. I figured 50-50 chance and >> left it overnight charging. The next day the battery was stone dead. >> It wouldn't close the relay. I figured my magic battery was finally >> dead. However, I extracted it from the battery box in the tail and >> brought it home and put a different charger on it. Back to life she >> came. I had not opened that battery box in over 15 years. >> >> Have you ever heard of a battery lasting this long? >> >> Do you know what happened to that company? I'd like to buy another >> battery from them if the need ever arises. >> >> I still have the receipt from that company, but have been unable to >> find them. I asked EAA about it years ago, but never got a response. > > I'm sorry, I'm not familiar with that company. > They are probably a distributor and not a manufacturer. > I'm not aware of anyone having the success you've > experienced. When that battery finally becomes unserviceable > in your airplane, you might consider shipping it to > me. I'll see if I can identify the source. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Subject: Super-Battery pedigree?
Date: Dec 04, 2006
They have a special battery alright. It mounts in the trunk and has two small tubes to vent gases to the outside, but I sure haven't been getting 10 years out of them, but maybe there is a special one that I don't know about. There is at least one after market battery available for the Miata, but I usually go to the dealer and pay the Big Price (around $100). Terry Rv-8A in progress '92 Miata since '95 I seem to recall that some Mazda Miata's (not all) had a special battery with an ~10 year life span. Maybe follow that lead. Ed Mueller N3730G RV10 in Progress ________________________________________________________________________________
Date: Dec 04, 2006
Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Monday, December 04, 2006 9:27 AM Subject: Re: AeroElectric-List: Pitot Current Draw --> Robert Sultzbach wrote: >--> > >Hi Bob, > > Staying out of icing if possible is good advice. I >lost pitot static instruments 2 or 3 times in a full >deicing equipped Navy jet over a 3 year period. > I've been following this thread, and this post begs the question I've been mulling over. What good is a heated pitot in an airplane without deicing equipment? I'm thinking that if the pitot is covered in ice, then so is the rest of the plane. Your airspeed is now next to useless, because all those stall speed numbers are now meaningless. Whatever they were before, they changed when the ice modified all the airfoils and the CG. A cockpit referenced backup altimeter would seem to give the best bang for the $time$...not terribly accurate, but sufficient to keep you out of cumulous granite until you can improve your situation. Ernest (a sunny day flyer). -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 04, 2006
Have you tried the aviation department at Home Depot? Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Banus Sent: Monday, December 04, 2006 2:11 PM Subject: AeroElectric-List: Instrument mounting screw washers Awhile back someone mentioned here or on the Glasair.org BB that model railroad wheel washers were ideal size for the instrument mounting screws. I can't find the message. I tried the model railroad show in VA Beach this weekend to no avail. Anyone have a line on where to get these critters? Mark Banus Glasair II ________________________________________________________________________________
Date: Dec 04, 2006
Old Bob, I reread your posting more carefully this time which leads me to a follow up question. Now that I understand what a 'strut switch' is (which I knew by a different name), I'm curious how the 'low heat' for the ground operations worked. In other words, how did it provide low heat on the ground and high heat in the air? Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of OldBob Siegfried Sent: Sunday, December 03, 2006 10:02 PM Subject: Re: AeroElectric-List: Pitot Current Draw --> Good Evening Lynn, Dick and Chuck, In a previous life, I flew quite a few airplanes that had a high and a low heat for the pitot tubes. They were on low for ground operations and on high heat for airborne use. I think it was controlled by a strut switch, but not sure. Worked well though. Happy Skies, Old Bob --- Lynn Riggs wrote: > I would like to add that the pitot tube should burn > your hand if you grab it after it has been on for > more than 1 or 2 minutes. > > "Richard E. Tasker" wrote: > Tasker" > > There are ways, but what leads you to believe that > the pitot is really > too hot? The whole purpose of the heater is to keep > it clear in any > condition - rain, freezing rain, cold ambient, etc. > Depending on what > plane you have, you will be flying at upwards of 200 > mph through all > this (hopefully NOT freezing rain) and the last > thing you want is for > the pitot to freeze up. > > Dick Tasker > > Chuck Jensen wrote: > > Jensen" > > > >I have a pitot on an Exp. Aircraft that was > designed for a heavier > >aircraft. To accommodate the high speed and high > altitude cold, the > >pitot was configured to get very hot, with > consumate amperage demand. > >Given the lower demands of a GA aircraft, is there > any way of reducing > >the heating of the pitot (very warm to the touch > would be fine...I don't > >need to be able to brand someone!) with a consumate > reduction in > >amperage demand? > > > >Chuck Jensen > > > > > > > > > > > > > > > > > > -- > Please Note: > No trees were destroyed in the sending of this > message. We do concede, however, > that a significant number of electrons may have been > temporarily inconvenienced. > -- > > > > > > > > > Lynn A. Riggs > riggs_la(at)yahoo.com > St. Paul, MN > BH #656 Kit #22 > http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html > > --------------------------------- ________________________________________________________________________________
Subject: Pitot heater solder
Date: Dec 04, 2006
Ok - I'm installing an AN5812 Pitot heater... The installation instructions specify a QQ-S-571 lead-silver solder. The connectors do appear to be silver plated. Doing some searches for QQ-S-571 yielded some silver bearing solders in the 1.5% to 2.5% range. The QQ-S-561 is the spec for silver solder. I was wondering if a Sn62Pb36Ag02 alloy would do the trick. Thanks, John ________________________________________________________________________________
Subject: RE: Instrument mounting screw washers
Date: Dec 04, 2006
Bruce, That was my first stop. ________________________________________________________________________________
Date: Dec 04, 2006
As the original owner of a '95 Miata I know that the original battery lasted just a bit longer than ten years, but I also know that here in SoCal the climate imposes no real demands on the battery so getting that "long" life probably says nothing about the battery. As far as I can tell (from the lack of standard size aftermarket batteries that will fit, a total of zero that I've found) this is a non-standard SIZE specified by Mazda to fit into a tight space and there is not anything special about the design. Aside from the size the only difference I can see is the outrageous price. Best regards, Rob Housman A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Ed Sent: Monday, December 04, 2006 11:19 AM Subject: Re: AeroElectric-List: Super-Battery pedigree? I seem to recall that some Mazda Miata's (not all) had a special battery with an ~10 year life span. Maybe follow that lead. Ed Mueller N3730G RV10 in Progress Robert L. Nuckolls, III wrote: > > > >> Hi Bob, >> >> Got your email from a builder friend of mine. I guess you are an >> electrics expert, so perhaps you can answer my battery questions. >> >> I fly a Glasair I RG that I finished in 1988. In 1986, when I began >> to work on the retractable gear, I bought a 12 volt sealed battery >> from a company in Scottsdale, AZ called Electromarketing. I found >> them in Sport Aviation. >> >> Long story short, that battery is still ticking in my Glasair. About >> 3 years ago in the winter, it didn't have quite enough umph to start, >> so I put a trickle charger on it that came with the battery. It was >> so old, that the polarity had fallen off. I figured 50-50 chance and >> left it overnight charging. The next day the battery was stone dead. >> It wouldn't close the relay. I figured my magic battery was finally >> dead. However, I extracted it from the battery box in the tail and >> brought it home and put a different charger on it. Back to life she >> came. I had not opened that battery box in over 15 years. >> >> Have you ever heard of a battery lasting this long? >> >> Do you know what happened to that company? I'd like to buy another >> battery from them if the need ever arises. >> >> I still have the receipt from that company, but have been unable to >> find them. I asked EAA about it years ago, but never got a response. > > I'm sorry, I'm not familiar with that company. > They are probably a distributor and not a manufacturer. > I'm not aware of anyone having the success you've > experienced. When that battery finally becomes unserviceable > in your airplane, you might consider shipping it to > me. I'll see if I can identify the source. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Dec 04, 2006
At 05:27 PM 12/2/2006, you wrote: > >Cleones wrote: > >> >>Hi Bob, In the John Deere alternator and regulator frequently >>talked about here is the rectifier in the regulator? > >Yes. > >> And, Is the alternator generating 3 phase AC ? > >No. It is single phase AC. There are only two wires coming out of it. > >>And, about what voltage is the output of the alternator. > >It will go up to about 200 volts open circuit but when loaded it >will be in the vicinity of 15 volts depending on how you measure it. > >> Also, since we know that the # 5 terminal must be connected to >> voltage or the alternator doesn't work. I have tried this and it >> is true. Then what is the circuit like? And would it be a good >> place to connect the overvoltage crowbar to? Enjoyed your >> lectures at Bloomington recently. Cleone > >I interupt the wires into the regulator. In the past Bob has said >that either into or out of the regulator will do the job but I >wanted to be able to cut power to the regulator in case it was >overheating or internally shorted. >The regulator uses the battery connection to turn itself on and to >sense the battery voltage so that it can regulate to 14.4 volts nominal output. > >Ken Ken, > Thanks. Let me consider this. So.. doesn't this indicate > using a NO relay? This circuit might be carring very high current > at the time the relay opened. Hopefully the contacts would not be > welded closed and the spinning alternator would not be delivering > current to the regulator and we would achieve the desired > results. I don't know if an attempt to fuse the AC output at a > little more than the rated current of the alternator is called for > or not. This might not be advisable because it might cause the > charging to be shut down unnecesarily. Do you agree with my > thoughts? Also regarding the # 5 connection of the regulator. I > started the engine and made sure the alternator was working with > the wire connected and then redid this with the wire off. The > first time the voltage was about 14 volts and the second time it > was just a little over 12. Thanks again. Cleone > > ________________________________________________________________________________
Date: Dec 04, 2006
I took the easy way out and countersunk all my instrument mounting screw holes. (NOT) Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Banus Sent: Monday, December 04, 2006 3:54 PM Subject: AeroElectric-List: RE: Instrument mounting screw washers Bruce, That was my first stop. ________________________________________________________________________________
Date: Dec 04, 2006
I take it that what you're looking for is a flat washer with the same diameter as the screw head. Will you need #4, #6, and #8's? Bruce www.glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Banus Sent: Monday, December 04, 2006 3:54 PM Subject: AeroElectric-List: RE: Instrument mounting screw washers Bruce, That was my first stop.
November 23, 2006 - December 04, 2006
AeroElectric-Archive.digest.vol-gj
