AeroElectric-Archive.digest.vol-gk
December 04, 2006 - December 14, 2006
Date: Dec 04, 2006
Subject: Pitot Current Draw
Good Evening Chuck, That I do not know much about, but I do recall one airplane where the low power was twenty eight volt DC and the high temperature used 115 volt, 400 cycle, AC. I would imagibne all of the varying power ones used some variaton of high and low voltages. Dropping resistors sure wouldn't solve your problem, but an electronically cycled DC voltage may work. Hopefully, 'Lectric Bob will have an idea! Happy Skies, Old Bob --- Chuck Jensen wrote: > Jensen" > > Old Bob, > > I reread your posting more carefully this time which > leads me to a > follow up question. Now that I understand what a > 'strut switch' is > (which I knew by a different name), I'm curious how > the 'low heat' for > the ground operations worked. In other words, how > did it provide low > heat on the ground and high heat in the air? > > Chuck Jensen > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] > On Behalf Of > OldBob Siegfried > Sent: Sunday, December 03, 2006 10:02 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Pitot Current Draw > > > Siegfried > --> > > Good Evening Lynn, Dick and Chuck, > > In a previous life, I flew quite a few airplanes > that > had a high and a low heat for the pitot tubes. They > were on low for ground operations and on high heat > for > airborne use. > > I think it was controlled by a strut switch, but not > sure. > > Worked well though. > > Happy Skies, > > Old Bob > --- Lynn Riggs wrote: > > > I would like to add that the pitot tube should > burn > > your hand if you grab it after it has been on for > > more than 1 or 2 minutes. > > > > "Richard E. Tasker" > wrote: > E. > > Tasker" > > > > There are ways, but what leads you to believe that > > the pitot is really > > too hot? The whole purpose of the heater is to > keep > > it clear in any > > condition - rain, freezing rain, cold ambient, > etc. > > Depending on what > > plane you have, you will be flying at upwards of > 200 > > mph through all > > this (hopefully NOT freezing rain) and the last > > thing you want is for > > the pitot to freeze up. > > > > Dick Tasker > > > > Chuck Jensen wrote: > > > > Jensen" > > > > > >I have a pitot on an Exp. Aircraft that was > > designed for a heavier > > >aircraft. To accommodate the high speed and high > > altitude cold, the > > >pitot was configured to get very hot, with > > consumate amperage demand. > > >Given the lower demands of a GA aircraft, is > there > > any way of reducing > > >the heating of the pitot (very warm to the touch > > would be fine...I don't > > >need to be able to brand someone!) with a > consumate > > reduction in > > >amperage demand? > > > > > >Chuck Jensen > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- > > Please Note: > > No trees were destroyed in the sending of this > > message. We do concede, however, > > that a significant number of electrons may have > been > > temporarily inconvenienced. > > -- > > > > > > > > > > > > > > > > > > Lynn A. Riggs > > riggs_la(at)yahoo.com > > St. Paul, MN > > BH #656 Kit #22 > > > http://home.comcast.net/~lariggs/wsb/html/view.cgi-home.html-.html > > > > --------------------------------- > > > > > > > > > > Click on > about > provided > www.buildersbooks.com > Admin. > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > > > > ________________________________________________________________________________
Date: Dec 04, 2006
Subject: Re: Pitot Current Draw
Pitch reference - Yes, if you want to paint a gloomy picture lets throw in night time, snow showers, over water and your venturi icing up and the gyros slowing down, well with a heated pitot at least you could still fly needle ball and airspeed! Lost a friend who did not have pitot heat, you cannot fly with needle ball and altimeter. George in Langley BC > > I've been following this thread, and this post begs the question I've > been mulling over. > > What good is a heated pitot in an airplane without deicing equipment? > I'm thinking that if the pitot is covered in ice, then so is the rest > of the plane. Your airspeed is now next to useless, because all those > stall speed numbers are now meaningless. Whatever they were before, > they changed when the ice modified all the airfoils and the CG. A > cockpit referenced backup altimeter would seem to give the best bang > for the $time$...not terribly accurate, but sufficient to keep you out > of cumulous granite until you can improve your situation. > > Ernest (a sunny day flyer). > ________________________________________________________________________________
Date: Dec 04, 2006
Subject: Re: Pitot Current Draw/Static Ports
Hi Bruce I know you said that with tongue in cheek, but it is interesting point. If I remember correctly an alternate static valve or heated ports are not required (Canada) if it can be demonstrated that the static ports are not susceptible to icing. I opted for alternate static valve on my RV's however I think that with dual static ports on the aft end of a tapering fuselage they would be immune to icing unless the aircraft was flown in a side slip. Anyone ever heard of side static ports icing over/up? George in Langley BC > > Bruce Gray wrote: > snip >> We all have heated >> static ports, right? Alternate static air valves? >> > ________________________________________________________________________________
From: "Keith Hallsten" <KeithHallsten(at)quiknet.com>
Subject: RE: Pitot Current Draw
Date: Dec 04, 2006
Chuck, I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a "Known Ice" type of airframe. If I should find enough ice to overwhelm my "lightweight" pitot heating system, I have bigger problems than the pitot. I'm not flying yet, but that's my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen (cjensen(at)dts9000.com ) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen ________________________________________________________________________________
Date: Dec 05, 2006
Hi, Keith, That was exactly my thought process also. I didn't want a red hot branding iron to bore my way through ice cubes...just warm enough to keep the pitot stuffed full of rain water from freezing. If the icing is bad enough that it freezes over a warm-to-very warm pitot, I've got bigger problems that a red hot pitot won't solve. Since no ideas have been tossed out, I wonder if there is an efficient means of cycling the pitot heater on/off at some interval, such as on for 30 seconds, off for two minutes. This would reduce the total current draw if a person was in the soup, lost electrical and needed whatever extra time available to get to safety but didn't dare to turn off the pitot in marginal icing conditions. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith Hallsten Sent: Monday, December 04, 2006 10:36 PM Subject: AeroElectric-List: RE: Pitot Current Draw Chuck, I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a "Known Ice" type of airframe. If I should find enough ice to overwhelm my "lightweight" pitot heating system, I have bigger problems than the pitot. I'm not flying yet, but that's my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen (cjensen(at)dts9000.com ) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen ________________________________________________________________________________
Date: Dec 05, 2006
Subject: Re: RE: Pitot Current Draw
Chuck this is exactly what the Gretz heated pitot does. http://www.gretzaero.com/ (ie cycles the power on/off to keep it warm enough to melt ice, but not constantly hot. Deems Davis RV10 # 406 Finishing - ( A Misnomer ! ) http://deemsrv10.com/ Chuck Jensen wrote: > Hi, Keith, > > I wonder if there is an efficient means of cycling the pitot heater > on/off at some interval, > > Chuck Jensen > ** > >* >* > ________________________________________________________________________________
Date: Dec 05, 2006
From: Lapsley R & Sandra E Caldwell <lrsecaldwell(at)earthlink.net>
Subject: Aux Altenator switching.
I am using Z13 with the 8 amp aux alternator. I would like to insure that when I turn on the Aux Alt that the Main Alt is off. I plan to use a dpdt (on-none-on) switch for the Aux Alternator. The aux alternator would be wired normally. The main alternator field would be wired in series with the Aux alternator such that when the Aux Alt is off, the field power is enabled to the Main Alt switch (Bat & main alt switch.). When the auxs alt switxh is on the main alt field would be disconnected. Does anyone see any problem with this plan? Roger ________________________________________________________________________________
Date: Dec 05, 2006
Subject: RG 400 into Molex crimp terminal, best way?
I need to bring RG400 marker beacon coax into my PS Eng., audio panel using a "Molex" crimp terminal on the coax. This seems like a mismatch sizewise. (I believe it is a Molex K.K. .156 Terminal Connectors (crimp pins), P/N 08-05-0302, Mouser P/N 538-08-05-0302, .33-cents each, looks the same as the crimp pins for the Narco Mk12D and King KNS-80 and KI-206, the King part number is KPN-030-1107-30. Can anyone verify this is the correct Molex number, the measurements match what I have.) 1. What is the best way to connect the RG400 to the Molex crimp terminal? a. Crimp the center conductor to Molex crimp terminal, if so the insulation around the center connector is pretty large, do I simply trim it to #18 size for the insulation crimp? I have been unsuccessful in obtaining a good crimp on the RG400 and end up with a fragile connection. There isn't room to add heat shrink to stiffen it up, since the crimp is a tight fit in the connector box. I assume coax is generally designed for the bnc type connectors and that center conductor flexability is not usually an issue. b. Crimp or solder a short length of #18 to the center conductor for ease of crimping the #18 to the Molex crimp terminal? Stabilize the joint with heat shrink. c. Strip back the center conductor about an inch, put some heat shrink on the center conductor for better grip by the Molex on the insulation? d. Is there an alternate coax that is more crimp friendly, to create a pigtail that connects to the RG400? I prefer to avoid extra connections (in general), and with my service loop (coax bundled with intercom/mike/speaker wires) and mounting position I don't forsee needing to disconnect the marker beacon coax for future addition/deletions of avionics from the audio panel. e. Other ideas? 3. I have tried crimping these with the "changeable jaw" crimper, not pretty. It's probably my lack of technique, but can anyone recommend a user friendly crimper-ebay has "Molex HTR1031E Crimp Tool" is this the right tool for these Molex crimp terminals? I couldn't find anything on the archives, my apologies if I missed it. Thanks for any help, and Bob thanks for the reply on the alternator wiring, I now understand the function of the extra A+ wire. Sincerely, Skip Simpson ________________________________________________________________________________
Date: Dec 05, 2006
OldBob Siegfried wrote: >Dropping resistors sure wouldn't solve your problem, >but an electronically cycled DC voltage may work. > >Hopefully, 'Lectric Bob will have an idea! > >Happy Skies, > >Old Bob > > Actually, the dropping resistor could work. Heat output is a function of wattage, which is given by V^2*R in a DC circuit. If you could find a way to add an extra high wattage resister in series with the pitot heating element, you would be dropping the current requirement. A 150 watt heater is going to have a resistance around 1 ohm in a 12V system. Add a 1 ohm resistor in series, and the circuit will burn up 75 watts. The resistor will suck down 37.5W and the heater will get 37.5 (ignoring line losses for the moment). If you could find a way to use the pitot mounting as a heat sink for the resistor, it might actually be workable. I still don't think it's a good use of $time$, but that's just me 8*) -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 05, 2006
Keith I think you have your assumptions are not correct. While your transposition of the formula E=I*R is correct, The formula for Power consumption is PIE or P=I*E, so if you have half the volts, the amps will double to maintain the same wattage. So if you are counting on the actual current draw to go down it will not in this case, in fact it will double to keep the same heat. Now that is not to say you can not limit the draw and run the pitot colder, but then that would negate having a pitot. Am I missing something? Dan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith Hallsten Sent: Monday, December 04, 2006 10:36 PM Subject: AeroElectric-List: RE: Pitot Current Draw Chuck, I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a "Known Ice" type of airframe. If I should find enough ice to overwhelm my "lightweight" pitot heating system, I have bigger problems than the pitot. I'm not flying yet, but that's my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen (cjensen(at)dts9000.com ) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen ________________________________________________________________________________
Date: Dec 05, 2006
Good Morning Ernest, That will drop the voltage and make the pitot tube cooler, but it is my understanding that such was NOT the problem he was attempting to solve. What he wants to do is reduce the current. Adding a dropping resistor just puts that current somewhere other than into the pitot heater. Cycling the power would reduce the heat AND the current required. Happy Skies, Old Bob --- Ernest Christley wrote: > Christley > > OldBob Siegfried wrote: > > >Dropping resistors sure wouldn't solve your > problem, > >but an electronically cycled DC voltage may work. > > > >Hopefully, 'Lectric Bob will have an idea! > > > >Happy Skies, > > > >Old Bob > > > > > > Actually, the dropping resistor could work. Heat > output is a function > of wattage, which is given by V^2*R in a DC circuit. > If you could find > a way to add an extra high wattage resister in > series with the pitot > heating element, you would be dropping the current > requirement. A 150 > watt heater is going to have a resistance around 1 > ohm in a 12V system. > Add a 1 ohm resistor in series, and the circuit will > burn up 75 watts. > The resistor will suck down 37.5W and the heater > will get 37.5 > (ignoring line losses for the moment). If you could > find a way to use > the pitot mounting as a heat sink for the resistor, > it might actually be > workable. > > I still don't think it's a good use of $time$, but > that's just me 8*) > > -- > ,|"|"|, Ernest Christley > | > ----===<{{(oQo)}}>===---- Dyke Delta Builder > | > o| d |o http://ernest.isa-geek.org > | > > > Click on > about > provided > www.buildersbooks.com > Admin. > > browse > Subscriptions page, > FAQ, > http://www.matronics.com/Navigator?AeroElectric-List > > > > > ________________________________________________________________________________
Date: Dec 05, 2006
Best practice is not to wire the RG-400 directly into the connector, but rather to use something like AWG20 on the center conductor, put a solder sleeve over the shield with a pigtail of another AWG20 then run the two wires into the connector - and of course support the coax so it does't rip out the wires. You can see a picture of our typical Mkr Bcn pigtail here: http://www.steinair.com/images/store/MKR.jpg We have a black/white strip for the ctr conductor and a black wire for the shield (which is kind of hidden in the picture). Hope that helps. Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of CardinalNSB(at)aol.com Sent: Tuesday, December 05, 2006 8:23 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: RG 400 into Molex crimp terminal, best way? I need to bring RG400 marker beacon coax into my PS Eng., audio panel using a "Molex" crimp terminal on the coax. This seems like a mismatch sizewise. (I believe it is a Molex K.K. .156 Terminal Connectors (crimp pins), P/N 08-05-0302, Mouser P/N 538-08-05-0302, .33-cents each, looks the same as the crimp pins for the Narco Mk12D and King KNS-80 and KI-206, the King part number is KPN-030-1107-30. Can anyone verify this is the correct Molex number, the measurements match what I have.) 1. What is the best way to connect the RG400 to the Molex crimp terminal? a. Crimp the center conductor to Molex crimp terminal, if so the insulation around the center connector is pretty large, do I simply trim it to #18 size for the insulation crimp? I have been unsuccessful in obtaining a good crimp on the RG400 and end up with a fragile connection. There isn't room to add heat shrink to stiffen it up, since the crimp is a tight fit in the connector box. I assume coax is generally designed for the bnc type connectors and that center conductor flexability is not usually an issue. b. Crimp or solder a short length of #18 to the center conductor for ease of crimping the #18 to the Molex crimp terminal? Stabilize the joint with heat shrink. c. Strip back the center conductor about an inch, put some heat shrink on the center conductor for better grip by the Molex on the insulation? d. Is there an alternate coax that is more crimp friendly, to create a pigtail that connects to the RG400? I prefer to avoid extra connections (in general), and with my service loop (coax bundled with intercom/mike/speaker wires) and mounting position I don't forsee needing to disconnect the marker beacon coax for future addition/deletions of avionics from the audio panel. e. Other ideas? 3. I have tried crimping these with the "changeable jaw" crimper, not pretty. It's probably my lack of technique, but can anyone recommend a user friendly crimper-ebay has "Molex HTR1031E Crimp Tool" is this the right tool for these Molex crimp terminals? I couldn't find anything on the archives, my apologies if I missed it. Thanks for any help, and Bob thanks for the reply on the alternator wiring, I now understand the function of the extra A+ wire. Sincerely, Skip Simpson ________________________________________________________________________________
Date: Dec 05, 2006
I loved the way you did your wire marking. Is that available at Steinair? What is the part number? Dave Henderson RV-7 N925LW (Lord Willing) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. Sent: Tuesday, December 05, 2006 10:41 AM Subject: RE: AeroElectric-List: RG 400 into Molex crimp terminal, best way? Best practice is not to wire the RG-400 directly into the connector, but rather to use something like AWG20 on the center conductor, put a solder sleeve over the shield with a pigtail of another AWG20 then run the two wires into the connector - and of course support the coax so it does't rip out the wires. You can see a picture of our typical Mkr Bcn pigtail here: http://www.steinair.com/images/store/MKR.jpg We have a black/white strip for the ctr conductor and a black wire for the shield (which is kind of hidden in the picture). Hope that helps. Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of CardinalNSB(at)aol.com Sent: Tuesday, December 05, 2006 8:23 AM Subject: AeroElectric-List: RG 400 into Molex crimp terminal, best way? I need to bring RG400 marker beacon coax into my PS Eng., audio panel using a "Molex" crimp terminal on the coax. This seems like a mismatch sizewise. (I believe it is a Molex K.K. .156 Terminal Connectors (crimp pins), P/N 08-05-0302, Mouser P/N 538-08-05-0302, .33-cents each, looks the same as the crimp pins for the Narco Mk12D and King KNS-80 and KI-206, the King part number is KPN-030-1107-30. Can anyone verify this is the correct Molex number, the measurements match what I have.) 1. What is the best way to connect the RG400 to the Molex crimp terminal? a. Crimp the center conductor to Molex crimp terminal, if so the insulation around the center connector is pretty large, do I simply trim it to #18 size for the insulation crimp? I have been unsuccessful in obtaining a good crimp on the RG400 and end up with a fragile connection. There isn't room to add heat shrink to stiffen it up, since the crimp is a tight fit in the connector box. I assume coax is generally designed for the bnc type connectors and that center conductor flexability is not usually an issue. b. Crimp or solder a short length of #18 to the center conductor for ease of crimping the #18 to the Molex crimp terminal? Stabilize the joint with heat shrink. c. Strip back the center conductor about an inch, put some heat shrink on the center conductor for better grip by the Molex on the insulation? d. Is there an alternate coax that is more crimp friendly, to create a pigtail that connects to the RG400? I prefer to avoid extra connections (in general), and with my service loop (coax bundled with intercom/mike/speaker wires) and mounting position I don't forsee needing to disconnect the marker beacon coax for future addition/deletions of avionics from the audio panel. e. Other ideas? 3. I have tried crimping these with the "changeable jaw" crimper, not pretty. It's probably my lack of technique, but can anyone recommend a user friendly crimper-ebay has "Molex HTR1031E Crimp Tool" is this the right tool for these Molex crimp terminals? I couldn't find anything on the archives, my apologies if I missed it. Thanks for any help, and Bob thanks for the reply on the alternator wiring, I now understand the function of the extra A+ wire. Sincerely, Skip Simpson href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c href "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matroni cs. com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Dec 05, 2006
Dan, I believe the pitot heating element is a simple resistor. Adding series resistance in line with the heating element will indeed LOWER the current through the circuit, as well as lowering the voltage drop across the pitot element. I am pretty sure the pitot heater is not a constant power device (which is what I think you were describing). Regards, Matt- > Keith > I think you have your assumptions are not correct. While your > transposition of the formula E=I*R is correct, The formula for Power > consumption is PIE or P=I*E, so if you have half the volts, the amps > will double to maintain the same wattage. So if you are counting on the > actual current draw to go down it will not in this case, in fact it will > double to keep the same heat. Now that is not to say you can not limit > the draw and run the pitot colder, but then that would negate having a > pitot. > Am I missing something? > Dan > > _____ > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith > Hallsten > Sent: Monday, December 04, 2006 10:36 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: RE: Pitot Current Draw > > > Chuck, > > I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I > have a 14 volt electrical system, its power consumption will be reduced > by a factor of 4 (power = V * V / R). I figure that is sufficient for > my purposes, because a Velocity is NOT a "Known Ice" type of airframe. > If I should find enough ice to overwhelm my "lightweight" pitot heating > system, I have bigger problems than the pitot. I'm not flying yet, but > that's my position for now. > > Actually, now that we all have GPS available to us, loss of pitot is not > as critical as it used to be. With a fat margin to allow for wind, > flying by groundspeed is generally a fair approximation. > > Regards, > > Keith Hallsten > > > Subject: RE: Pitot Current Draw > From: Chuck Jensen (cjensen(at)dts9000.com > =8984A39879F2F5418251CBEEC9C689B32870D7(at)lucky.dts.local> ) > Date: Mon Dec 04 - 12:06 PM > Wow, I must be hard-of-speaking (or writing). I concede that flying > > into icing when not so equipped is not a good idea, but if a person > > flies IFR in the winter most anywhere in the continental US, sooner or > > later, they'll pick up some ice. Even if my wings start looking like > > something that should be used to cool a gin and tonic, I don't want to > > lose air speed indication. Granted, I may not know what my new stall > > speed is, but I would like to know WHAT my speed is...and I can't do > > that with a pitot full of ice. > > So, the question on the table is still the same, is there a way off > > 'turning down the heat' and reducing current draw? > > Chuck Jensen > > ________________________________________________________________________________
Date: Dec 05, 2006
Hello Bob, Adding series resistance causes the total resistance rises, so the total current drops. That will reduce the total circuit power as well as the power delivered to the pitot (less voltage drop across the pitot). I agree that this is an inefficient way to accomplish the task - wasted heat on the dropping resistor. A simple way (from a drive circuitry standpoint) to accomplish the task would be to have a pitot tube with two heating elements. They could be different sizes (wattage values). Turn on the "ground" element to keep it warm while taxiing, and a "branding iron" element to stave off a full arctic blast. Turn both on at once so you know how fast you're falling out of the sky.. :) Actually, your idea of cycling the pitot heat probably works great too (maybe that's how it's actually done). The only downside I can think of is that cycling a high power device can cause weird noise events on the power bus (dimming lights). Probably not a big deal if installed/wired properly (low impedance path to the battery). Regards, Matt- > > > Good Morning Ernest, > > That will drop the voltage and make the pitot tube > cooler, but it is my understanding that such was NOT > the problem he was attempting to solve. > > What he wants to do is reduce the current. > > Adding a dropping resistor just puts that current > somewhere other than into the pitot heater. Cycling > the power would reduce the heat AND the current > required. > > Happy Skies, > > Old Bob > > --- Ernest Christley wrote: > >> Christley >> >> OldBob Siegfried wrote: >> >> >Dropping resistors sure wouldn't solve your >> problem, >> >but an electronically cycled DC voltage may work. >> > >> >Hopefully, 'Lectric Bob will have an idea! >> > >> >Happy Skies, >> > >> >Old Bob >> > >> > >> >> Actually, the dropping resistor could work. Heat >> output is a function >> of wattage, which is given by V^2*R in a DC circuit. >> If you could find >> a way to add an extra high wattage resister in >> series with the pitot >> heating element, you would be dropping the current >> requirement. A 150 >> watt heater is going to have a resistance around 1 >> ohm in a 12V system. >> Add a 1 ohm resistor in series, and the circuit will >> burn up 75 watts. >> The resistor will suck down 37.5W and the heater >> will get 37.5 >> (ignoring line losses for the moment). If you could >> find a way to use >> the pitot mounting as a heat sink for the resistor, >> it might actually be >> workable. >> >> I still don't think it's a good use of $time$, but >> that's just me 8*) >> >> -- >> ,|"|"|, Ernest Christley >> | >> ----===<{{(oQo)}}>===---- Dyke Delta Builder >> | >> o| d |o http://ernest.isa-geek.org >> | >> >> >> Click on >> about >> provided >> www.buildersbooks.com >> Admin. >> >> browse >> Subscriptions page, >> FAQ, >> http://www.matronics.com/Navigator?AeroElectric-List >> >> >> >> >> > > ________________________________________________________________________________
Date: Dec 05, 2006
Lloyd, Daniel R. wrote: > Keith > I think you have your assumptions are not correct. While your > transposition of the formula E=I*R is correct, The formula for Power > consumption is PIE or P=I*E, so if you have half the volts, the amps > will double to maintain the same wattage. So if you are counting on > the actual current draw to go down it will not in this case, in fact > it will double to keep the same heat. Now that is not to say you can > not limit the draw and run the pitot colder, but then that would > negate having a pitot. > Am I missing something? > Dan Yes. You're missing http://www.sengpielaudio.com/calculator-ohm.htm I keep a copy of that taped to the inside of my electronics toolbox's lid. You've got 12V (actually 13.4). Double the resistance, you halve the current (I=V/R). Halving the current will also cut the power in half (P=V*I), decreasing the heater effectiveness as you state; but the original problem was the builder willing to settle for a drop in effectiveness in exchange for extended battery life. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 05, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Aux Altenator switching.
> > >I am using Z13 with the 8 amp aux alternator. > >I would like to insure that when I turn on the Aux Alt that the Main Alt >is off. Why? > I plan to use a dpdt (on-none-on) switch for the Aux Alternator. The > aux alternator would be wired normally. The main alternator field would > be wired in series with the Aux alternator such that when the Aux Alt is > off, the field power is enabled to the Main Alt switch (Bat & main alt > switch.). When the auxs alt switxh is on the main alt field would be > disconnected. > >Does anyone see any problem with this plan? Don't see a need for it. Further, any part that is NOT on your airplane is not going to be a part that fails. Having one switch exert command and control over systems that are supposed to back each other up does not produce nice failure modes effects analysis. There is no danger to any equipment on the airplane by having both alternators on at the same time. I'll recommend you install Z-13 as published. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 05, 2006
> > >Hi Bruce > >I know you said that with tongue in cheek, but it is interesting point. If >I remember correctly an alternate static valve or heated ports are not >required (Canada) if it can be demonstrated that the static ports are not >susceptible to icing. I opted for alternate static valve on my RV's >however I think that with dual static ports on the aft end of a tapering >fuselage they would be immune to icing unless the aircraft was flown in a >side slip. Anyone ever heard of side static ports icing over/up? Don't know if anyone has actually seen them ice up but static ports on our new Horizon are heated. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 05, 2006
OldBob Siegfried wrote: > >Good Morning Ernest, > >That will drop the voltage and make the pitot tube >cooler, but it is my understanding that such was NOT >the problem he was attempting to solve. > >What he wants to do is reduce the current. > >Adding a dropping resistor just puts that current >somewhere other than into the pitot heater. Cycling >the power would reduce the heat AND the current >required. > >Happy Skies, > >Old Bob > > > Yes it would, but compared to adding a series resistor it will also add a semi-complex cycling circuit (with the definition of complex being left as an exercise for the reader). My suggestion would only be useful if it were possible to use the heat generated from the resistor. If I were trying to accomplish this on my installation, I would bolt the resistor to the pitot's base using heat-sink grease at a point that would put it under the fairing. The pitot becomes the heat-sink for the resistor (as well as the internal heating element). Using the previous numbers that I pulled out of the ether, the resistor and heater would produce 37.5W of heat each. The heater's power would be as efficient as the unmodified version, but the resistor's heat has to jump across a couple interfaces and down the pitot's post. Overall, the pitot heater would be less than half as effective. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 05, 2006
>Hi, Keith, > >That was exactly my thought process also. I didn't want a red hot >branding iron to bore my way through ice cubes...just warm enough to keep >the pitot stuffed full of rain water from freezing. If the icing is bad >enough that it freezes over a warm-to-very warm pitot, I've got bigger >problems that a red hot pitot won't solve. > >Since no ideas have been tossed out, I wonder if there is an efficient >means of cycling the pitot heater on/off at some interval, such as on for >30 seconds, off for two minutes. This would reduce the total current draw >if a person was in the soup, lost electrical and needed whatever extra >time available to get to safety but didn't dare to turn off the pitot in >marginal icing conditions. We need to define "efficient". If this means highest reliability and minimum parts count, then a series resistor can be used to reduce energy dissipated in the tube (and total energy consumed by the system) but even tho the tube heat is reduced, the resistor dumps energy too. The most efficient electrically is a switchmode step-down converter that can supply power to the pitot heater at any voltage while limiting losses in the heat controller to 20% or so of total power. But this is a busy piece of electronics that adds parts count to the system but when operating properly, offers the lowest risk for noise problems while offering complete adjustability of the low power mode. You can also duty cycle switch the tube and while this offers a VERY efficient means of controlling energy, it puts repetitive pulses of current on the bus that WILL generate considerable noise (I'm working a similar problem right now on a $14M$ airplane that has a $50K$ coffee maker installed on it). Help us understand your primary goal. Certainly, energized pitot tubes offer considerable hazard on the ground. How about a switch that keeps the tube off unless RPM is over 1000 rpm? How about an airspeed switch? Both of these systems could be fitted with warning lights that show a de-energized pitot heater when the pitot heat switch is ON. Help us understand your design goals. Using a 28v tube is an option too. Given the temperature coefficient for the heaters, running a tube at 1/2 voltage still produces more than 1/4 rated power. But keep in mind that there is a thermal resistance component between a heater and the pitot tube's surface. See: http://www.aeroelectric.com/Pictures/Curves/Pitot_Heater_R_Plot.pdf The data point at 9.85 amps was taken while the surface of the tube was being held at 0C in an ice bath. These are the worst case conditions for icing but note that while the surface was at 0C, the heater itself was running at about 140C! See: http://www.aeroelectric.com/Pictures/Curves/Pitot_tube_temps_at_altitude.pdf This data was collected on a flight to 41K feet. Note that at cruise, the pitot tube's SURFACE temperature (LT4) was running over 100C at 200Kts IAS and RAT of -35C. This was the same tube plotted in the earlier graph. Just be wary of advice supported by anecdotal experiences. The "numbers" that describe the tube's ability to shed ice are locked into the physics and not all tubes are the same. Attempts to control the tube's power consumption increases parts count and raises needs for additional monitoring to let you know when the control system has failed so that you can bypass it and go to full power. Some power control schemes have system integration issues to consider as well. Be wary too of any notions that "a small portion" of design power is a useful thing to design into your system. Let's consider your design goals. Exactly why and under what conditions do you want to moderate pitot tube performance? Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
http://www.gretzaero.com/ga1000.html If the control system for this tube is designed to actively maintain the SURFACE temperature of tube at ice-shedding temperatures, then it's a good thing to do. I've considered pitot tube controllers based on measuring resitance of the heater during OFF time of a duty cycle controller . . . but knowing heater temperature is not the same as knowing tube surface temperature . . . for reasons cited in the other post. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 05, 2006
Bob, Does your comment "There is no danger to any equipment on the airplane by having both alternators on at the same time. " Does this mean if I add a John Deere 20a and run at the same time as my Rotax 18 Amp unit that I can get 38 amps max case? Any down side to doing this? Thanks, Paul =============== At 08:35 AM 12/5/2006, you wrote: > > > >>Caldwell >> >>I am using Z13 with the 8 amp aux alternator. >> >>I would like to insure that when I turn on the Aux Alt that the >>Main Alt is off. > > Why? > >> I plan to use a dpdt (on-none-on) switch for the Aux >> Alternator. The aux alternator would be wired normally. The main >> alternator field would be wired in series with the Aux alternator >> such that when the Aux Alt is off, the field power is enabled to >> the Main Alt switch (Bat & main alt switch.). When the auxs alt >> switxh is on the main alt field would be disconnected. >> >>Does anyone see any problem with this plan? > > Don't see a need for it. Further, any part that is > NOT on your airplane is not going to be a part that > fails. Having one switch exert command and control over > systems that are supposed to back each other up > does not produce nice failure modes effects analysis. > > There is no danger to any equipment on the airplane by > having both alternators on at the same time. I'll > recommend you install Z-13 as published. > > Bob . . . > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Subject: RE: RE: Instrument mounting screw washers
Date: Dec 05, 2006
Bruce, These are actually the screws that attach the Al 2 panel inserts to the Glasair Fiberglass panel. I'm not sure what # they are. I'm looking for washers that do not extend much past the diameter of the attaching screw. Standard washers are to wide and look funny on the panel. Mark ________________________________________________________________________________
Date: Dec 05, 2006
Robert L. Nuckolls, III wrote.... We need to define "efficient". If this means highest reliability and minimum parts count, then a series resistor can be used to reduce energy dissipated in the tube (and total energy consumed by the system) but even tho the tube heat is reduced, the resistor dumps energy too. The most efficient electrically is a switchmode step-down converter that can supply power to the pitot heater at any voltage while limiting losses in the heat controller to 20% or so of total power. But this is a busy piece of electronics that adds parts count to the system but when operating properly, offers the lowest risk for noise problems while offering complete adjustability of the low power mode. You can also duty cycle switch the tube and while this offers a VERY efficient means of controlling energy, it puts repetitive pulses of current on the bus that WILL generate considerable noise (I'm working a similar problem right now on a $14M$ airplane that has a $50K$ coffee maker installed on it). Help us understand your primary goal. Certainly, energized pitot tubes offer considerable hazard on the ground. How about a switch that keeps the tube off unless RPM is over 1000 rpm? How about an airspeed switch? Both of these systems could be fitted with warning lights that show a de-energized pitot heater when the pitot heat switch is ON. The primary goal is to reduce power load of the pitot during all operating phases, as the pitot runs unnecessarily hot (though I don't know exactly what temp it should run at, my belief is branding iron hot is more then necessary for a GA aircraft that is not ice equipped). Of particular importance, should I have an electrical generation failure and am in 'cold clouds', I prefer to leave the pitot as long as possible to preclude loss of AS indication. The duration of this operation, limited by battery life, will be directly, and primarily, affected by the draw of the pitot heater. In fact, the 15amp draw is about equal to everything else that needs to run. The goal is to reduce the effective draw of the pitot to 7 amps, or less, either on a continuous basis or as an average of the on/off cycle. A secondary goal is not to screw up radios and reliability. Help us understand your design goals. Using a 28v tube is an option too. Given the temperature coefficient for the heaters, running a tube at 1/2 voltage still produces more than 1/4 rated power. But keep in mind that there is a thermal resistance component between a heater and the pitot tube's surface. See: http://www.aeroelectric.com/Pictures/Curves/Pitot_Heater_R_Plot.pdf The data point at 9.85 amps was taken while the surface of the tube was being held at 0C in an ice bath. These are the worst case conditions for icing but note that while the surface was at 0C, the heater itself was running at about 140C! See: http://www.aeroelectric.com/Pictures/Curves/Pitot_tube_temps_at_altitude .pdf This data was collected on a flight to 41K feet. Note that at cruise, the pitot tube's SURFACE temperature (LT4) was running over 100C at 200Kts IAS and RAT of -35C. This was the same tube plotted in the earlier graph. In the Velocity, I intended to neither fly in an ice bath, or at 41K feet--though I get your points :-). Just be wary of advice supported by anecdotal experiences. The "numbers" that describe the tube's ability to shed ice are locked into the physics and not all tubes are the same. Attempts to control the tube's power consumption increases parts count and raises needs for additional monitoring to let you know when the control system has failed so that you can bypass it and go to full power. Some power control schemes have system integration issues to consider as well. Be wary too of any notions that "a small portion" of design power is a useful thing to design into your system. Let's consider your design goals. Exactly why and under what conditions do you want to moderate pitot tube performance? During all phases of ground and flight operations. In short, I wish the pitot (off a warbird) was a 28v unit that was run at 12v--I suspect that would be about right for reduced pitot heat and current draw. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
> >Bob, >Does your comment "There is no danger to any equipment on the airplane by >having both alternators on at the same time. " > Does this mean if I add a John Deere 20a and run at the same time as my > Rotax 18 Amp unit that I can get 38 amps max case? Any down side to doing this? There's a difference between risks for damage and performance as shared suppliers of loads to the system. The problem is getting respective voltage regulators of two engine driven power sources to appropriately share total loads based on their respective capabilities. I've designed such regulators but the technology I've used is not compatible with PM alternators. It would take a start from scratch effort to get the proportionate paralleling performance that's desired when running two power sources. Yes, you can run two alternators and count on their added capacities for total engine driven power . . . but without hardware specific to making them share loads, you'll find yourself fiddling with the regulation setpoints a lot. If you can bolt a 20A PM alternator to your engine, why not a 40A ND alternator with some REAL capacity to run the whole airplane and save the smaller alternator for backup a-la Z-13/8? Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
But wouldn't you still be wasting electrical power as heat on the resistor? If the overall goal is to reduce power consumption, IE make the battery last longer, you would not want additional resistance. Or am I all backwards? I went with the Gretz Pitot, because it stays at a constant lower temp and power cycles itself to maintain that temp, so overall I am using less power, rather than just dumping it as heat. Dan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Sent: Tuesday, December 05, 2006 11:22 AM Subject: RE: AeroElectric-List: RE: Pitot Current Draw Dan, I believe the pitot heating element is a simple resistor. Adding series resistance in line with the heating element will indeed LOWER the current through the circuit, as well as lowering the voltage drop across the pitot element. I am pretty sure the pitot heater is not a constant power device (which is what I think you were describing). Regards, Matt- > Keith > I think you have your assumptions are not correct. While your > transposition of the formula E=I*R is correct, The formula for Power > consumption is PIE or P=I*E, so if you have half the volts, the amps > will double to maintain the same wattage. So if you are counting on the > actual current draw to go down it will not in this case, in fact it will > double to keep the same heat. Now that is not to say you can not limit > the draw and run the pitot colder, but then that would negate having a > pitot. > Am I missing something? > Dan > > _____ > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith > Hallsten > Sent: Monday, December 04, 2006 10:36 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: RE: Pitot Current Draw > > > Chuck, > > I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I > have a 14 volt electrical system, its power consumption will be reduced > by a factor of 4 (power = V * V / R). I figure that is sufficient for > my purposes, because a Velocity is NOT a "Known Ice" type of airframe. > If I should find enough ice to overwhelm my "lightweight" pitot heating > system, I have bigger problems than the pitot. I'm not flying yet, but > that's my position for now. > > Actually, now that we all have GPS available to us, loss of pitot is not > as critical as it used to be. With a fat margin to allow for wind, > flying by groundspeed is generally a fair approximation. > > Regards, > > Keith Hallsten > > > Subject: RE: Pitot Current Draw > From: Chuck Jensen (cjensen(at)dts9000.com > =8984A39879F2F5418251CBEEC9C689B32870D7(at)lucky.dts.local> ) > Date: Mon Dec 04 - 12:06 PM > Wow, I must be hard-of-speaking (or writing). I concede that flying > > into icing when not so equipped is not a good idea, but if a person > > flies IFR in the winter most anywhere in the continental US, sooner or > > later, they'll pick up some ice. Even if my wings start looking like > > something that should be used to cool a gin and tonic, I don't want to > > lose air speed indication. Granted, I may not know what my new stall > > speed is, but I would like to know WHAT my speed is...and I can't do > > that with a pitot full of ice. > > So, the question on the table is still the same, is there a way off > > 'turning down the heat' and reducing current draw? > > Chuck Jensen > > ________________________________________________________________________________
Date: Dec 05, 2006
Subject: DIY Starter Adapter for Lycoming
Last week sometime someone mentioned an article for fabricating an adapter that bolts an automotive starter to a Lycoming. I've captured and .pdf'ed the article for easier downloading and printing. This is a nice piece of work and worthy of consideration if you're interested in such things. http://aeroelectric.com/Reference_Docs/Starters/Lycoming_Starter_Adapter.pdf Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 05, 2006
I think it is better described like this, you double the resistance, half the current is felt on each device, but the power drop across the circuit is still the same, IE the pitot only gets half as hot and the resistor is getting the other current, and no net gain or loss on wattage consumption. Correct? -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Tuesday, December 05, 2006 11:33 AM Subject: Re: AeroElectric-List: RE: Pitot Current Draw Lloyd, Daniel R. wrote: > Keith > I think you have your assumptions are not correct. While your > transposition of the formula E=I*R is correct, The formula for Power > consumption is PIE or P=I*E, so if you have half the volts, the amps > will double to maintain the same wattage. So if you are counting on > the actual current draw to go down it will not in this case, in fact > it will double to keep the same heat. Now that is not to say you can > not limit the draw and run the pitot colder, but then that would > negate having a pitot. > Am I missing something? > Dan Yes. You're missing http://www.sengpielaudio.com/calculator-ohm.htm I keep a copy of that taped to the inside of my electronics toolbox's lid. You've got 12V (actually 13.4). Double the resistance, you halve the current (I=V/R). Halving the current will also cut the power in half (P=V*I), decreasing the heater effectiveness as you state; but the original problem was the builder willing to settle for a drop in effectiveness in exchange for extended battery life. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 05, 2006
> >Robert L. Nuckolls, III wrote.... > > We need to define "efficient". If this means highest > reliability and minimum parts count, then a series resistor > can be used to reduce energy dissipated in the tube > (and total energy consumed by the system) but even tho > the tube heat is reduced, the resistor dumps energy too. >The primary goal is to reduce power load of the pitot during all >operating phases, as the pitot runs unnecessarily hot (though I don't >know exactly what temp it should run at, my belief is branding iron hot >is more then necessary for a GA aircraft that is not ice equipped). Of >particular importance, should I have an electrical generation failure >and am in 'cold clouds', I prefer to leave the pitot as long as possible >to preclude loss of AS indication. The duration of this operation, >limited by battery life, will be directly, and primarily, affected by >the draw of the pitot heater. In fact, the 15amp draw is about equal to >everything else that needs to run. The goal is to reduce the effective >draw of the pitot to 7 amps, or less, either on a continuous basis or as >an average of the on/off cycle. A secondary goal is not to screw up >radios and reliability. Okay, get an adjustable power supply good for 7 amps or more. Hook it to your pitot tube and adjust the voltage for 7A of current draw. This probably won't be at 1/2 your normal system voltage but something a bit lower. Wait for things to settle out as the tube needs some time to arrive at a new temperature and load. Once the new voltage is determined, calculate the value of resistance needed to supply this new voltage assuming a 14v bus. Value of R = (14 - NewVolts)/7 Your resistor will dissipate something on the order of 50 watts and the needed resistance will be on the order of 1 ohm. I'd recommend you get a 2.0 ohm, 100W adjustable resistor like an AVT100-2.0 found at: http://dkc3.digikey.com/PDF/T063/1403.pdf During the first opportunity to do some in-flight measurements, I'd monitor the voltage across the pitot tube in flight to see how much effect that slip stream air flow affects power drawn by the tube. If you see a need to increase the voltage, you can always adjust the resistor to some new value. In fact, you may want to install a 225w resistor. The 100 ohm resistor has a current rating of I^2*R=100 or 7A. This means that if you need to increase the operating current above 7A, you'll overload the 100W resistor. A 225w resistor has a current rating of about 11 amps and would be most likely to cover all the bases for your final adjustment setpoint. These resistors are on ceramic tubes and relatively robust as mounted when you use the brackets that come with the resistor. Resist the urge to mount these devices on heavy and/or rigid structure that might put strong bending forces on the tube. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
> > >But wouldn't you still be wasting electrical power as heat on the >resistor? If the overall goal is to reduce power consumption, IE make >the battery last longer, you would not want additional resistance. Or am >I all backwards? >I went with the Gretz Pitot, because it stays at a constant lower temp >and power cycles itself to maintain that temp, so overall I am using >less power, rather than just dumping it as heat. Yes, the resistor gets hot too but TOTAL energy is down. Assume a 1 ohm operating resistance for a pitot tube. 1 ohm produces a current draw of 14A for a total wattage of 196 watts. Now put a 1 ohm resistor in series with the pitot tube. Current drops by half to 7A for a TOTAL wattage of 98 watts. Half this wattage will be dissipated by the pitot tube, the other half in the resistor. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
Lloyd, Daniel R. wrote: > >But wouldn't you still be wasting electrical power as heat on the >resistor? > Yes. >If the overall goal is to reduce power consumption, IE make >the battery last longer, you would not want additional resistance. Or am >I all backwards? > > This setup would only work if you arranged for the pitot tube to be the radiator for the resistor. If you stick the resistor at the switch, then you haven't gained anything (unless maybe you were also needing a hand warmer). >I went with the Gretz Pitot, because it stays at a constant lower temp >and power cycles itself to maintain that temp, so overall I am using >less power, rather than just dumping it as heat. >Dan > > Back to the original question, I just remember Eric posting a howto on how to use some temperature gradient resistors he has for sale to moderate pitot heat current. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 05, 2006
> > >I think it is better described like this, you double the resistance, >half the current is felt on each device, but the power drop across the >circuit is still the same, IE the pitot only gets half as hot and the >resistor is getting the other current, and no net gain or loss on >wattage consumption. >Correct? no . . . at 1/2 current each device gets 1/4 the original power dissipation because votlage across each device is also down by 1/2. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
Great example, now I better understand. THX -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, December 05, 2006 2:36 PM Subject: RE: AeroElectric-List: RE: Pitot Current Draw > > >But wouldn't you still be wasting electrical power as heat on the >resistor? If the overall goal is to reduce power consumption, IE make >the battery last longer, you would not want additional resistance. Or am >I all backwards? >I went with the Gretz Pitot, because it stays at a constant lower temp >and power cycles itself to maintain that temp, so overall I am using >less power, rather than just dumping it as heat. Yes, the resistor gets hot too but TOTAL energy is down. Assume a 1 ohm operating resistance for a pitot tube. 1 ohm produces a current draw of 14A for a total wattage of 196 watts. Now put a 1 ohm resistor in series with the pitot tube. Current drops by half to 7A for a TOTAL wattage of 98 watts. Half this wattage will be dissipated by the pitot tube, the other half in the resistor. Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
Yes, the small ND sure has merits and probably had the same issues as any add on alternator for the Rotax. I wont need 40a but 25 or 30 would be nice to simplify my electrical system. Then the Rotax marginal unit would just be a backup. Thanks for your input, Paul =================== At 10:39 AM 12/5/2006, you wrote: > > > >> >>Bob, >>Does your comment "There is no danger to any equipment on the airplane by >>having both alternators on at the same time. " >> Does this mean if I add a John Deere 20a and run at the same time >> as my Rotax 18 Amp unit that I can get 38 amps max case? Any down >> side to doing this? > > There's a difference between risks for damage and performance as > shared suppliers of loads to the system. The problem is getting > respective voltage regulators of two engine driven power sources > to appropriately share total loads based on their respective > capabilities. > > I've designed such regulators but the technology I've used > is not compatible with PM alternators. It would take a start > from scratch effort to get the proportionate paralleling > performance that's desired when running two power sources. > > Yes, you can run two alternators and count on their added > capacities for total engine driven power . . . but without > hardware specific to making them share loads, you'll find > yourself fiddling with the regulation setpoints a lot. > > If you can bolt a 20A PM alternator to your engine, why > not a 40A ND alternator with some REAL capacity to run > the whole airplane and save the smaller alternator for backup > a-la Z-13/8? > > Bob . . . ________________________________________________________________________________
Date: Dec 05, 2006
> >Yes, the small ND sure has merits and probably had the same issues as any >add on alternator for the Rotax. I wont need 40a but 25 or 30 would be >nice to simplify my electrical system. Then the Rotax marginal unit would >just be a backup. Keep in mind that your alternator has two functions: (1) carry the max running load for equipment on board and (2) recharge the battery. (Battery charging energy) = (alternator energy) - (running loads). Just because your alternator is 'oversized' is not necessarily a bad or even undesirable thing. If you had a hard time getting the engine started or want to go flying after extended ground maintenance ops from the battery, then being able to reload the battery quickly with just your alternator output is a pretty nifty thing. What's the weight difference? A 40A ND alternator compared to the JD PM alternator + rectifier/regulator? I'll bet it's about a wash and for my money, I'd take the 40A ND over a 20A JD machine any day. The SD-8 at 3.5 pounds and its compatibility with the AND20000 pad on the back of the engine is the recipe for success . . . but I've never understood the perceived allure for the larger PM alternators as compared to the smaller wound-field devices. Bob . . . ________________________________________________________________________________
Date: Dec 06, 2006
Subject: Aural warning box
I just took delivery of a new Trike with an EIS. It has one warning light located so far out of my line of sight I'm thinking it will be virtually worthless. Has anyone got any ideas, or better yet built something that provides an aural warning through the intercom system? I'm thinking of something more than just a warning horn. And, as long as I'm here, the trike is powered by an HKS700E 4 stroke engine that has dual electronic ignitions. According to the manual, and experience in the field, the ignition systems drop off line when input power drops below 10 volts. I'd like to add an emergency backup battery for the ignition system and electric fuel boost pump only. What I'd like is a device that seamlessly cuts in the backup and warns me so I can get down. A Powersonic PS 1270 for a battery looks like a good fit, but doesn't allow enough for a latching relay, too. Is there a circuit that will do what I want with minimal current draw, too? Have the moon, wanting the stars, too, Rick -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Dec 06, 2006
Subject: Re: Aural warning box
>I just took delivery of a new Trike with an EIS. It has one warning light >located so far out of my line of sight I'm thinking it will be virtually >worthless. Has anyone got any ideas, or better yet built something that >provides an aural warning through the intercom system? I'm thinking of >something more than just a warning horn. >And, as long as I'm here, the trike is powered by an HKS700E 4 stroke >engine that has dual electronic ignitions. According to the manual, and >experience in the field, the ignition systems drop off line when input >power drops below 10 volts. I'd like to add an emergency backup battery >for the ignition system and electric fuel boost pump only. What I'd like >is a device that seamlessly cuts in the backup and warns me so I can get >down. A Powersonic PS 1270 for a battery looks like a good fit, but >doesn't allow enough for a latching relay, too. Is there a circuit that >will do what I want with minimal current draw, too? How big is your existing battery. How much current does the ignition system draw? What kind of alternator and regulator is installed? Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 06, 2006
Weight difference? The JD 20 amp PM is about 2 lb lighter than the 40 amp ND. That could rise to about 2.5 lb if one adds a OV contactor to the ND. The new ND was cheaper than the JD + regulator though for me. Theoretically the ND should have a cleaner (less noise) output although that made no noticeable difference for my system. I actually agree with Bob's post but I did not have an accessory pad for a SD-8 and chose a JD rather than a 40 amp ND as a second alternator for OV considerations as well as the 2.5 lb saving. Perhaps I'm wrong, but I had more confidence that a small relay would interupt the 20 amp ac output than I have that a cheap contactor will interupt the 40 amp dc output. The expensive OV contactor would have cost me more than an ND alternator and replacing/servicing it would have been more difficult. Also I prefer not to have excessively large alternators since a small alternator that is running full on with a failed regulator will cause the voltage to rise slower than a large unit and it will take longer to "cook" a battery since less amps are available. With OVM protection most of that wouldn't matter. However I have an electrically dependant engine. Many years ago I was in a position of having to cycle a generator on and off to get out of clouds largely based on how bad the battery smelled between cycles. As it boiled and melted, the liquid electrolyte battery absorbed a lot more excess energy than my RG batteries will. Since there was no low or high voltage warning, the smell from the battery was the first indication of a problem back then. Anyway with the JD I know that even worst case I can fairly easilly load the thing to capacity and manually keep the voltage nominal and that was attractive to me. Ken Robert L. Nuckolls, III wrote: > > > >> >> Yes, the small ND sure has merits and probably had the same issues as >> any add on alternator for the Rotax. I wont need 40a but 25 or 30 >> would be nice to simplify my electrical system. Then the Rotax >> marginal unit would just be a backup. > > > Keep in mind that your alternator has two functions: (1) carry the > max running load for equipment on board and (2) recharge the battery. > (Battery charging energy) = (alternator energy) - (running loads). > Just because your alternator is 'oversized' is not necessarily a > bad or even undesirable thing. If you had a hard time getting the > engine started or want to go flying after extended ground maintenance > ops from the battery, then being able to reload the battery quickly > with just your alternator output is a pretty nifty thing. > > What's the weight difference? A 40A ND alternator compared to > the JD PM alternator + rectifier/regulator? I'll bet it's about > a wash and for my money, I'd take the 40A ND over a 20A JD > machine any day. > > The SD-8 at 3.5 pounds and its compatibility with the AND20000 > pad on the back of the engine is the recipe for success . . . but > I've never understood the perceived allure for the larger PM > alternators as compared to the smaller wound-field devices. > > > Bob . . . > > ________________________________________________________________________________
Date: Dec 06, 2006
Rick The aural warning part should be easy as I believe all the GRT EIS units have that feature. In fact I believe mine is a 12 volt square wave output tone that goes on and off with the warning light. It required considerable reducing to feed it into the intercom and is pretty loud even with a 470k resistor between it and my intercom input. Even with a good light location, it is always the intercom tone that gets my immediate attention. Ken Richard Girard wrote: > I just took delivery of a new Trike with an EIS. It has one warning > light located so far out of my line of sight I'm thinking it will be > virtually worthless. Has anyone got any ideas, or better yet built > something that provides an aural warning through the intercom system? > I'm thinking of something more than just a warning horn. > And, as long as I'm here, the trike is powered by an HKS700E 4 stroke > engine that has dual electronic ignitions. According to the manual, > and experience in the field, the ignition systems drop off line when > input power drops below 10 volts. I'd like to add an emergency backup > battery for the ignition system and electric fuel boost pump only. > What I'd like is a device that seamlessly cuts in the backup and warns > me so I can get down. A Powersonic PS 1270 for a battery looks like a > good fit, but doesn't allow enough for a latching relay, too. Is there > a circuit that will do what I want with minimal current draw, too? > > Have the moon, wanting the stars, too, > Rick > > -- > Rick Girard > "Ya'll drop on in" > takes on a whole new meaning > when you live at the airport. ________________________________________________________________________________
From: "Terry Miles" <terrence_miles(at)hotmail.com>
Subject: In line fuses - when to use
Date: Dec 06, 2006
Hi Bob, I went to your seminar back about two years ago now at Wicks. I am actively wiring a Velocity. This is not a theory-like query, I have the wire on the table and trying to make my drawings work!! Here's the situation: Due to my size at 150 lbs and the pusher widedeck IO540 hanging off the end...I will clearly need some ballast in the nose. My decision was a 2nd battery. I will have two 55 amp hour Optima batteries. Here's the basic structure: BATTERY ONE Thru a dedicated 700 1-2 I will connect the BATT DC1 solenoid output to the main bus. I will wire the alternator output back to the ship's side of that same battery contactor to be my distribution line and as a charge wire. (This same wire will carry the current limiter.) BATTERY TWO Thru a dedicated 700 1-2 I will deploy the BATT DC2 solenoid output via an unfused #8 awg as a dedicated distribution wire to the avionic/critical bus. There will be no hard wiring between alternator output and my DC2 system until I close the link between main and avionics busses. I will not wire the alternator output back to the DC2 battery. The DC2-to-alternator link will only come thru the commonly accepted main-to-avionics diode logic. Only after the engine is started will I put the alternator on line, and only after that will I tie the isolated buses and batteries together thru the Main to Avionic link. So my question is about when I need in-line current limiters. Given this design, and with only one alternator, I only need one in-line current limiter, right? Is it acceptable for me NOT to fuse my DC2-to-Avionics distribution wire? I will of course fuse all the users downstream of that. Thanks for the ear.and the help Terry Miles Velocity XL-RG-5 Wiring ________________________________________________________________________________
Date: Dec 06, 2006
Subject: Re: Questions??
Cleones wrote: > > At 05:27 PM 12/2/2006, you wrote: > >> >> Cleones wrote: >> >>> >>> Hi Bob, In the John Deere alternator and regulator frequently >>> talked about here is the rectifier in the regulator? >> >> >> Yes. >> >>> And, Is the alternator generating 3 phase AC ? >> >> >> No. It is single phase AC. There are only two wires coming out of it. >> >>> And, about what voltage is the output of the alternator. >> >> >> It will go up to about 200 volts open circuit but when loaded it will >> be in the vicinity of 15 volts depending on how you measure it. >> >>> Also, since we know that the # 5 terminal must be connected to >>> voltage or the alternator doesn't work. I have tried this and it is >>> true. Then what is the circuit like? And would it be a good place >>> to connect the overvoltage crowbar to? Enjoyed your lectures at >>> Bloomington recently. Cleone >> >> >> I interupt the wires into the regulator. In the past Bob has said >> that either into or out of the regulator will do the job but I wanted >> to be able to cut power to the regulator in case it was overheating >> or internally shorted. > > >> The regulator uses the battery connection to turn itself on and to >> sense the battery voltage so that it can regulate to 14.4 volts >> nominal output. >> >> Ken > > > Ken, > >> Thanks. Let me consider this. So.. doesn't this indicate >> using a NO relay? This circuit might be carring very high current at >> the time the relay opened. Hopefully the contacts would not be >> welded closed and the spinning alternator would not be delivering >> current to the regulator and we would achieve the desired results. I >> don't know if an attempt to fuse the AC output at a little more than >> the rated current of the alternator is called for or not. This might >> not be advisable because it might cause the charging to be shut down >> unnecesarily. Do you agree with my thoughts? Also regarding the # 5 >> connection of the regulator. I started the engine and made sure the >> alternator was working with the wire connected and then redid this >> with the wire off. The first time the voltage was about 14 volts and >> the second time it was just a little over 12. Thanks again. > > Cleone Cleone Yes I use a NO relay. My alternator switch applies power to the "Battery" connection on the regulator and to the OVM module and it closes the NO relay. Your voltage readings are indeed what I would expect to see. Fusing the output of an alternator won't provide Over Voltage protection. It is done to simply to protect the wire from battery current if the alternator should short out. So in this case my fuse or circuit breaker is between the battery and the regulator to protect the wire from overheating because of battery supplied current if there is a short in the regulator or the alternator. I think I had a 30 amp CB on hand and used that. I hope I'm not muddying this for you. My wires from the alternator to the regulator are sized at 12 awg to handle the 20 amp max output so they are not at risk from the alternator if the regulator shorts. Putting the OV relay in those ac wires would provide a means of disconnecting the supply to the regulator though which is what I did. Ken ________________________________________________________________________________
Date: Dec 06, 2006
Bob, Good morning. The alternator is a PM type that puts out 210 watts above 4000 RPM. The regulator is a zener diode unit supplied with the engine. The only information I can find on current draw for the ignition is that the CDI's require 3 amp fuses. The battery is an 18ah AGM type. I searched the online manuals for any revisions to the ones supplied with the engine and this is all the info I can find. Rick On 12/6/06, Robert L. Nuckolls, III wrote: > > nuckollsr(at)cox.net> > > > >I just took delivery of a new Trike with an EIS. It has one warning light > >located so far out of my line of sight I'm thinking it will be virtually > >worthless. Has anyone got any ideas, or better yet built something that > >provides an aural warning through the intercom system? I'm thinking of > >something more than just a warning horn. > >And, as long as I'm here, the trike is powered by an HKS700E 4 stroke > >engine that has dual electronic ignitions. According to the manual, and > >experience in the field, the ignition systems drop off line when input > >power drops below 10 volts. I'd like to add an emergency backup battery > >for the ignition system and electric fuel boost pump only. What I'd like > >is a device that seamlessly cuts in the backup and warns me so I can get > >down. A Powersonic PS 1270 for a battery looks like a good fit, but > >doesn't allow enough for a latching relay, too. Is there a circuit that > >will do what I want with minimal current draw, too? > > How big is your existing battery. How much current does > the ignition system draw? What kind of alternator and > regulator is installed? > > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Dec 06, 2006
With regard to installing an additional charging devise on a Rotax 91X four stroke, the vacuum pad spins slower than a Lyc. or Cont. I know of no alternator larger than the SD20S that will fit on the vacuum pad, with the SD20S being of the very best quality. I forget the exact output of the SD20S using a LR3C (that eats a bit of power compared to a switcher) but at cruise ~ 18 amps sounds correct on a 12 volt system. You need the short nose SD20S (not SD20) to fit the Rotax. If you look on B+Cs website under Cessna 210 for the SD20S. The output is identical to the SD20, just the shorter nose. Actual it is a beautiful custom casting drive side half of the alternator, the drive coupling is awful nice as well. If anyone knows of a 40 amp alternator that will put out above 30 amps on a Rotax vacuum, I am all ears. Some have taken a 40 amp alternator and drive it direct off the crankshaft with a flex coupling and bracket it off the engine mount. A bit off topic but semi pertinent: Keep your Ducati Rotax regulator as cool as you can If you ask more than 12 amps continuous from the Rotax generator the regulator will fail in short order. If you keep changing regulators the windings supposedly fail on the generator SD20S with a LR3C is probably more robust at 18 amps than the supposedly 18 or 20 amp internal generator is at 12 amps. I plan to limit continuous of the SD20S to ~15 amps I forget exact set point of Ducati, think 13.6 or 13.7 volts, the LR3C comes with ~14.4 but is adjustable. If you have both chargers on line, the SD20S will do for the most part most of the work if setpoint is above the Rotax generator. At less than cruise RPM the SD20S will not put out 18 amps, at taxi RPM not even close, I am not flying yet, but I believe that the Rotax generator will help out a little at this time if the SD20S is slumping voltage down to Ducati setpoint. If you do use a SD20S, make sure you use one vacuum pad gasket, but be sure to measure that the male driven spline on the SD20S is not bottomed inside the female drive spline. (No big deal if it is, a few strokes on the plastic male spline with a file rectifies (the fit) on the alternator! Perhaps there is .750" of engagement, I needed to remove on my 914 .070", not even up to the edge of the chamfer) Ron Parigoris ________________________________________________________________________________
Date: Dec 06, 2006
From: Bill Bradburry <bbradburry(at)allvantage.com>
Subject: AEC9005-301-1A Module
Bob, I intended to set my plane up following the Z-19 drawing. It appears that the Over/under voltage monitor module is no longer available. I can find no link to the instructions for building one?? Are the boards you were selling still available or are they gone? How should I reconfigure the Aux battery switch if the "auto" capability is no longer available? Thanks for your excellent support and assistance for the OBAM group. I notice that most of your daily responses start at around 3:00-3:30 AM!!! When,(if??) do you sleep??!! Bill B ________________________________________________________________________________
From: "Ing. Gottfried Komaier" <gottfried.komaier(at)gmx.net>
Date: Dec 06, 2006
Bill, if you are searching only for an Over/Under Voltage Sensor: "BC207-1" is what you will need . Have a look at: www.bandcspecialty.com/cgi-bin/ez-catalog/cat_display.cgi?6X358218 Gottfried Vienna/Austria -----Ursprngliche Nachricht----- Von: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] Im Auftrag von Bill Bradburry Gesendet: Mittwoch, 06. Dezember 2006 20:46 An: aeroelectric-list(at)matronics.com Betreff: AeroElectric-List: AEC9005-301-1A Module --> Bob, I intended to set my plane up following the Z-19 drawing. It appears that the Over/under voltage monitor module is no longer available. I can find no link to the instructions for building one?? Are the boards you were selling still available or are they gone? How should I reconfigure the Aux battery switch if the "auto" capability is no longer available? Thanks for your excellent support and assistance for the OBAM group. I notice that most of your daily responses start at around 3:00-3:30 AM!!! When,(if??) do you sleep??!! Bill B ________________________________________________________________________________
Date: Dec 06, 2006
Subject: Rotax Aux Altenator switching.
Hi Ron Yup! I'm the origional designer and buillder of the 40A alternator off the crankshaft. The Rotax series engine is just not capable of anything approaching what we want for electrical power. We are all electrical hogs in our wants on the panel. I'm guilty as I now have a Lycosoris with a 60A alternator and a back up of 8A on the vac. pad. on my new build. We just have to reconcile our "needs" with what we "want". Its the same as my new build for the emergency or just to get by power source of 8A. What do you not "need". Part of the thoughts are what will you need that requires so much power. I went with LED running lights to reduce the power req. for night flight. Plus, landing lights are needed for only a short time and thus can run off the battery for the short time in the pattern. The game for Rotax drivers is to minimise the electrical loads and still get the stuff you really "need" and have your "AA" batterys for back up for the hand held transmitter and GPS. What else do you really need? I know- just look at my new panel and see how the pot is calling the kettle black! But I've been there with my Europa and I used the 40A alt and used about 18 to 20 but it was because of the strobe light system requirements. It would really hog the power when charging the capacitors for the next pulse. The real key would be a maker of strobes that used less power. Jim Nelson ________________________________________________________________________________
Date: Dec 06, 2006
Subject: Re: Pitot Current Draw
Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen ________________________________________________________________________________
Date: Dec 06, 2006
Ernest, Please explain what you mean by a cockpit referenced backup altimeter. I don't think I've ever heard of any thing like that. And how would it help keep you from hitting the ground? Maybe you're referring to alternate static air. But the question wasn't on heating the static port - it was on losing pitot ram air to ice. Personally, I'll take the heated pitot. Stan Sutterfield A cockpit referenced backup altimeter would seem to give the best bang for the $ ________________________________________________________________________________
Date: Dec 06, 2006
Bret, Chuck is not suggesting he would continue flying in IMC in icing conditions. In fact, he hasn't suggested he would even let himself get into that situation. He simply wants to know how to wire his airplane to accomplish two pitot heat settings - low and high. I surmise from your comments, since you said "icing or not" that you believe the loss of main alternator in IMC with the potential for icing (less than 10 degrees Celsius) is not an emergency situation. I would classify that as a emergency, whether I'm in a C-172 or a whiz-bang OBAM aircraft. Stan Sutterfield As for me, icing or not, if I lose my main alternator, I would switch on Endurance mode (which is only 8 amps...thus, no pitot) and land that puppy ASAP. This is not an emergent situation. Not so with your stock Cessna. ________________________________________________________________________________
Date: Dec 06, 2006
The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you=92re doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It=92s not like flying on a sunny day. But once you get use to it and prepare for it, it=92s not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don=92t have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman=92s terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. The reason that the pitot uses so much power (in general) is that is what it takes to keep ice off the probe in 100% humidity at temperatures < 10dec C. Sorry for the poor and somewhat sarcastic answer, but I think Chuck brought it out in me. Regards, Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, December 06, 2006 6:57 PM Subject: AeroElectric-List: Re: Pitot Current Draw Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen "http://www.aeroelectric.com"www.aeroelectric.com "http://www.buildersbooks.com"www.buildersbooks.com "http://www.kitlog.com"www.kitlog.com "http://www.homebuilthelp.com"www.homebuilthelp.com "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List -- 11/22/2006 -- 11/22/2006 ________________________________________________________________________________
Subject: Jabiru Starter contactor and solenoid
Date: Dec 06, 2006
I have a Jabiru 3300 and have a 702-1 starter contactor from B&C. Looking at Z-20, from aeroelectric, they are running the 4 AWG wire to the starter solenoid. It looks like the "solenoid" supplied by Jabiru is really just another contactor. It is wired and works the same as the 702-1 but with out the diode. If I hook it up as depicted in Z-20 all I will be doing is to energize the coil on the Jabiru supplied solenoid with the 4 AWG wire from the 702-1. It sure looks to me that all I will be doing is putting two contactors in series. I am not sure of the value in this. I am considering just leaving off the Jabiru solenoid and connecting the 702-1 directly to the starter. Is this smart or is there something I am missing? Thanks Matt www.zodiacxl.com ________________________________________________________________________________
Subject: GPS Antenna
Date: Dec 06, 2006
Are GPS antennas generic so they can be hooked up to any receiver? A friend of mine has a L1/L2 antenna manufactured by Sensor Systems and wants to hook it up to a handheld Lowrance. Mike C. ________________________________________________________________________________
Date: Dec 06, 2006
Here's an idea that may draw snickers, jeers, and possibly gasps of horror. My sister (like lots of peoples' sisters) has a curling iron heated by butane.. Why doesn't anyone have a pitot tube heated directly by the combustion of a hydrocarbon (gasoline/jetA might be problematic without a pump). It would be tremendously efficient compared to hauling around a gigantic alternator. It would run for hours on a tiny amount of fuel. It could be thermostatically controlled, and be amazingly light weight. I know, it's not an "electric" idea... Matt- ________________________________________________________________________________
Date: Dec 06, 2006
For developing your own answer based upon your stated needs, I'll defer to Bob N. and the other smart aeroelectric types. For an off-the-shelf solution that may also fit your needs, have you looked at http://www.gretzaero.com/ga1000.html? Rob Wright RV-10 with Gretz Aero Fuselage ~snip~ The GA-1000 is Gretz Aero's totally new design of a heated Pitot tube. It is molded from a very high-tech Polymer material that has nearly the same thermal conductivity as metal. This new design has electronics embedded in the Pitot tube. It also comes with a small electronic control module that will mount close to the Pitot tube in the wing. This electronic control module controls the heat of the Pitot and provides information to the pilot regarding thermal and heater performance of the Pitot tube. This information is presented by way of a 3/16 inch diameter multi-conductor cable that has a very small circuit board with three LED's on it. This LED circuit board is already attached to the cable. The LED circuit board is designed to be placed behind the panel and allow the LED's to protrude through the panel at a convenient location to the pilot. The three LED's are: Green = circuits are working and temperature of Pitot tube is well above freezing: Yellow = current is being provided to the heater due to low temperature: Red = temperature is low at the Pitot tube and needs heat. There will be times when one or two LED's will be lit. If no LED's are lit, there is a problem with power getting to the Pitot tube. The GA-1000 is great for small electrical generating systems in light aircraft. The heater in the Pitot draws 7 Amps, and that is only when the electronic control module calls for heat. The heater will cycle on and off as needed to maintain the proper temperature. During the times when heat is not needed or called for, the electronic control module draws less than .1 Amp. The Gretz Aero GA-1000 heated Pitot tube comes complete with: GA-1000 heated Pitot tube, electronic control module, LED circuit board and cable, screws for Pitot tube to mounting bracket installation, mounting hardware for mounting the electronic control module, and of course, complete instructions. The complete weight of the entire kit is 397 grams or 14.0 oz. The GA-1000 Pitot tube has a very sleek and modern shape that is pleasing to the eye. It is very dark gray to black in color. If the builder feels the need, it can be painted with automotive high temperature engine paint. This is available at most auto parts stores. The GA-1000 will fit the standard Gretz Aero Pitot Tube <http://www.gretzaero.com/mountbracket.html> Mounting Bracket Kits. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, December 06, 2006 7:57 PM Subject: AeroElectric-List: Re: Pitot Current Draw Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: Rotax Aux Altenator switching.
Hello Jim "The real key would be a maker of strobes that used less power." I am using Kunzleman strobes with a combo head. The 2 strobes I think draw 2 amps, and the LED position draws not much. Ron Parigoris ________________________________________________________________________________
Date: Dec 07, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: AEC9005-301-1A Module
> > >Bob, >I intended to set my plane up following the Z-19 drawing. It appears that >the Over/under voltage monitor module is no longer available. I can find >no link to the instructions for building one?? Are the boards you were >selling still available or are they gone? >How should I reconfigure the Aux battery switch if the "auto" capability >is no longer available? I'm replacing the 9005 series products with a new technology. You can get a pre-view at: http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf There will be a version that offers the same functionality as the old 9005-301-1 ECB from which the LVW/ABMM product was assembled. However . . . The 9011 as depicted offers TWO independent LV warning channels that offers the same functionality as the 9005, just not automatic. One LV channel is used to watch the main bus, the other watches the aux battery bus. If the pilot fails to close the aux battery switch after starting the engine, then only the main bus warning light goes out. The ADVANTAGE of this architecture and operating philosophy is that a failed aux battery contactor can be spotted with the 9011 installed where it will go un-annunciated with the 9005. The third output channel drives a latching relay suitable for shutting down PM alternators, and older generators in an OV condition. It can also be used on wound-field alternators. I really didn't want to "step back" to the relay technology but it's appeal is universal applicability to virtually all engine driven power sources. >Thanks for your excellent support and assistance for the OBAM group. > >I notice that most of your daily responses start at around 3:00-3:30 >AM!!! When,(if??) do you sleep??!! You're welcome. The times posted for List messages is Pacific time were the server is located. I'm generally up about 6 and check the e-mail first thing. I'm usually in bed by midnight. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 07, 2006
>Ernest, >Please explain what you mean by a cockpit referenced backup altimeter. I >don't think I've ever heard of any thing like that. And how would it help >keep you from hitting the ground? >Maybe you're referring to alternate static air. But the question wasn't >on heating the static port - it was on losing pitot ram air to ice. "Cockpit referenced" is a specific term for "vented to cockpit atmosphere" . . . which is what the vast majority of alternate static sources do. The piper Pacer and Tri-Pacer didn't have static systems. The altimeter was simply mounted to the panel and vented to cockpit as was any VSI and/or altitude encoders added at later dates. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: GPS Antenna
>Are GPS antennas generic so they can be hooked up to any receiver? A >friend of mine has a L1/L2 antenna manufactured by Sensor Systems and >wants to hook it up to a handheld Lowrance. > > If it's an un-amplified antenna, it's interchangeable. If an "active" antenna, there are no industry wide standards for such antennas and there is risk that an antenna not specifically designed to service your receiver will work. That doesn't mean that there aren't a whole lot of active antennas that will nicely interchange . . . only that folks who build receivers would dearly love for you to use their antenna and are not likely to give you a list of other, equally suitable antennas. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 07, 2006
Mike, If I was able to draw the sarcasm out of you, I'd had to see what a pro could do! (:-)). Actually, I've done the calculations and am satisfied of the results, even if not confirmed by empirical data. The current pitot draws about 15 amps. By comparison, my older, but very adequate (as in--never iced up) pitot drew 7 amps. While not on a first name basis with any electrons, I assume that an amp is an amp and is generally going to produce a certain amount of heat, which is apparently adequate, based on empirical experience. So, if 7 amps was good enough in the old pitot, I was thinkin' that 7 amps was probably good enough for this pitot. I could hire a thermodynamist to confirm all this, but I'll go out on a limb and employ common sense instead--it's cheaper and often, just as accurate. As to your suggestion of simply using a bigger battery, I didn't notice any calculations showing how big and how many batteries I should have. However, if by limiting heat output in the pitot, I cut my amperage in half, I can calculate that the draw from my current battery will be 1/2 as much and last twice as long (but not for the full load, since the pitot is only a fraction of the total load; unfortunately, a high fraction). As to the suggestion to just turn it off.....duh, the reason we have a heated pitot is--never mind, it makes my head hurt. Sorry for my poor response and sarcasm, but I think you brought it out of me. All the forgoing is just kidding. Not many people intentionly flying their GA craft into icing and not many lose electrical power generation, but when the two are combined, even though the odds are it happening are small, the odds of ending up dead are quite large. So, if there was a reasonably simple mechanical/electrical means of reducing the current draw of the pitot, I wanted to do it. Kind of like flying an airplane--not many of us have real good reasons for doing it, but we just want to do it. Chuck Jensen Mike wrote.... The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you're doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It's not like flying on a sunny day. But once you get use to it and prepare for it, it's not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don't have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman's terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. The reason that the pitot uses so much power (in general) is that is what it takes to keep ice off the probe in 100% humidity at temperatures < 10dec C. Sorry for the poor and somewhat sarcastic answer, but I think Chuck brought it out in me. Regards, Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, December 06, 2006 6:57 PM Subject: AeroElectric-List: Re: Pitot Current Draw Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on the Contribution link below to find out more about this year's Terrific Free Incentive Gifts provided by: * AeroElectric www.aeroelectric.com * The Builder's Bookstore www.buildersbooks.com * Aeroware Enterprises www.kitlog.com * HomebuiltHELP www.homebuilthelp.com List Contribution Web Site --> http://www.matronics.com/contribution Thank you for your generous support! -Matt Dralle, List Admin. - The AeroElectric-List Email Forum - --> http://www.matronics.com/Navigator?AeroElectric-List -- 11/22/2006 -- 11/22/2006 ________________________________________________________________________________
Date: Dec 07, 2006
Maybe these people http://gilsson.stores.yahoo.net/ can tell you if the Sensor Systems antenna works with the Lowrance handheld GPS. Dale Ensing ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, December 07, 2006 8:24 AM Subject: Re: AeroElectric-List: GPS Antenna > > > >>Are GPS antennas generic so they can be hooked up to any receiver? A >>friend of mine has a L1/L2 antenna manufactured by Sensor Systems and >>wants to hook it up to a handheld Lowrance. >> >> > > If it's an un-amplified antenna, it's interchangeable. > If an "active" antenna, there are no industry wide standards > for such antennas and there is risk that an antenna not > specifically designed to service your receiver will > work. That doesn't mean that there aren't a whole lot > of active antennas that will nicely interchange . . . only > that folks who build receivers would dearly love for > you to use their antenna and are not likely to give you > a list of other, equally suitable antennas. > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > > ________________________________________________________________________________
Date: Dec 07, 2006
Subject: : Rotax Aux Altenator switching.
That sounds really nice. Where did you find them? Jim ________________________________________________________________________________
Subject: Need engine rpm pickup for Lycoming 360
Date: Dec 07, 2006
I am finally ready to start hooking up wires on my Zenith 801 with Lycoming O-360a1a. I have a Aveo E-1 and MaxFlight on my panel and need an electronic RPM pickup for the Lycoming. My ultralight (Quicksilver GT400) was very simple to wire up as it had a pulse wire from the electronic ignition already. No electronic ignition on this old Lycoming (Bendix mags). Any suggestions? Jay Herron CH801 95% complete Salem, OH Read this topic online here: http://forums.matronics.com/viewtopic.php?p=79835#79835 ________________________________________________________________________________
Date: Dec 07, 2006
"Chuck Jensen" wrote: > The current > pitot draws about 15 amps. By comparison, my older, but very adequate > (as in--never iced up) pitot drew 7 amps. While not on a first name > basis with any electrons, I assume that an amp is an amp and is > generally going to produce a certain amount of heat, which is apparently > adequate, based on empirical experience. So, if 7 amps was good enough > in the old pitot, I was thinkin' that 7 amps was probably good enough > for this pitot. I could hire a thermodynamist to confirm all this, but > I'll go out on a limb and employ common sense instead--it's cheaper and > often, just as accurate. > Not quite true Chuck. Your old pitot tube was about 2 ohms. You were drawing 7 amps from around 14 volts. Power is I^2 * R = 98 W. Now you have a pitot that's about 1 ohm drawing 15 amps from 14 volts (0.933 ohms but who's counting). Drop the current in this pitot to 7 amps and power is only 49 W. It was suggested by someone that the dropping resistor could be mounted on the pitot also which would help, but still not be equivalent. Bob W. (Not a thermodynamist but I learned ohms law at an early age.) -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.7 Hours Total Time Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Subject: Landing Radar....!
Date: Dec 07, 2006
Well, no, it isn't, BUT it works the same way....... The basis is a back-up sensor which warns you when backing, that you are approaching ( a pre-set distance from) a reflected object with a 'beep'. Mine works with 42 kHz out and 24kHz in, I think. (sub-audible frequencies). These are common in the auto shops now. I revised mine (according to a great friend and mentor, Graham Clark) to give a sliding tone (in the earphones) from a high at 5 feet to a low at 5 inches. This I believe will be most useful over smooth ground (of course) for monowheel or conventional tailwheel drivers, airframe. Trigear drivers just have to feel their way down. However I am told that the newer versions of the 'backup' sensor now incorporate this feature. The Lockheed TriStar carried a descent radar which produced a 'pip' of increasing frequency from 250' AGL to 50' then stopped, just as it got interesting...... With all these solid state devises, I'm getting close to a 1/7 scale L-1011........! Ferg Kyle Europa A064 914 Classic ________________________________________________________________________________
Date: Dec 07, 2006
Bob, Thanks for the (correct) information. As a child, I lead a sheltered existance and wasn't allow to play with Ohms, Amps and other foreigners, so this is new to me. There's a whole new, big, world out there to learn about. P.S., I still want to reduce my current draw! Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob White Sent: Thursday, December 07, 2006 10:23 AM Subject: Re: AeroElectric-List: Re: Pitot Current Draw "Chuck Jensen" wrote: > The current > pitot draws about 15 amps. By comparison, my older, but very adequate >(as in--never iced up) pitot drew 7 amps. While not on a first name >basis with any electrons, I assume that an amp is an amp and is >generally going to produce a certain amount of heat, which is >apparently adequate, based on empirical experience. So, if 7 amps was >good enough in the old pitot, I was thinkin' that 7 amps was probably >good enough for this pitot. I could hire a thermodynamist to confirm >all this, but I'll go out on a limb and employ common sense >instead--it's cheaper and often, just as accurate. > Not quite true Chuck. Your old pitot tube was about 2 ohms. You were drawing 7 amps from around 14 volts. Power is I^2 * R = 98 W. Now you have a pitot that's about 1 ohm drawing 15 amps from 14 volts (0.933 ohms but who's counting). Drop the current in this pitot to 7 amps and power is only 49 W. It was suggested by someone that the dropping resistor could be mounted on the pitot also which would help, but still not be equivalent. Bob W. (Not a thermodynamist but I learned ohms law at an early age.) -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.7 Hours Total Time Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Subject: LED backlit rocker switches
Date: Dec 07, 2006
Hey all - I've been monitoring this list for awhile now - I'm building an RV-10 - and I wondered if any of the electron whizzes could help me. I'm trying to find a good source for custom legend LED backlit rocker switches for my project. I've historically done quite a bit of night flying, and after I got my instrument rating, which I did 100% at night (with the one exception of the checkride!) I vowed that I would not accept anything less than complete readability of all controls and switches at night in the cockpit. It just seemed so crazy that I had to juggle 3 flashlights in the cockpit - one red led flash attached to my headset, a small red maglite for cocpit instruments farther away from the pilot position, and one more large one to look for ice on the airframe (yikes!). then I'd get into my car after a long night of flying, turn on the lights, and have no trouble reading any of the controls or switches. This is how I want my aircraft to be! All controls self illuminating, and a flashlight for emergency use only! Seems so simple, but I've been confounded at every turn. Anyone have any suggestions? Thanks in advance! cj #40410 fuse www.perfectlygoodairplane.net ________________________________________________________________________________
From: "6440 Auto Parts" <sales(at)6440autoparts.com>
Subject: Re: LED backlit rocker switches
Date: Dec 07, 2006
I agree looking for a switch that is always lit and readable not just when in the on position is like looking for a needle in a haystack. I fianally decided to go with the cheap EL light strips under the panel. But I don't do much night flying anyway. Randy ----- Original Message ----- From: "Chris Johnston" <CJohnston(at)popsound.com> Sent: Thursday, December 07, 2006 10:20 AM Subject: AeroElectric-List: LED backlit rocker switches > > > Hey all - > > I've been monitoring this list for awhile now - I'm building an RV-10 - > and I wondered if any of the electron whizzes could help me. I'm trying > to find a good source for custom legend LED backlit rocker switches for > my project. > > I've historically done quite a bit of night flying, and after I got my > instrument rating, which I did 100% at night (with the one exception of > the checkride!) I vowed that I would not accept anything less than > complete readability of all controls and switches at night in the > cockpit. It just seemed so crazy that I had to juggle 3 flashlights in > the cockpit - one red led flash attached to my headset, a small red > maglite for cocpit instruments farther away from the pilot position, and > one more large one to look for ice on the airframe (yikes!). then I'd > get into my car after a long night of flying, turn on the lights, and > have no trouble reading any of the controls or switches. This is how I > want my aircraft to be! All controls self illuminating, and a > flashlight for emergency use only! Seems so simple, but I've been > confounded at every turn. Anyone have any suggestions? > > Thanks in advance! > > cj > #40410 > fuse > www.perfectlygoodairplane.net > > > ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: : Rotax Aux Altenator switching.
Hello Jim As far as Kuntzleman combo LED position and strobe "That sounds really nice. Where did you find them?" Home: http://www.kestrobes.com/ Combo Head: http://www.kestrobes.com/our_strobe_hds.html Double Dual Magnum: http://www.kestrobes.com/ddm_models.html Dual Magnum strobe under 2 amps, and for both starboard and port, red, green and both sides aft white 2/3 of an amp total! The lens cover is I think vacuum formed?? It is OK in clarity, not superb, overall price is low. Unit is not certified, and to be honest I don't care all that much if I am absolute legal to the absolute letter of the law, paramount to me is that my strobe and position LEDs allow me to be seen. In my case with a Rotax 914, if you overburden the electrical system with an approved strobe / position light system, fail your generator and kill your battery, without electrical power to at least 1 fuel pump, well "Silent Night" will begin to play. Absolute/official checking to make sure position lights meet specs is not an easy and cheap thing. I am more worried that certified planes with approved position lights and strobes don't have the inside of lenses dirty, high resistance wiring or less than new output bulbs. He sells to military I think for Helicopters, and think he says they will meet specs, but too costly to test. I tried out my position LEDs, and for certain comparing right next to local Beechcraft/Piper and Cessnas they work very well. The size of the LED illumination is a bit smaller than the traditional, not much, but it is more intense, overall very visable. Coverage as far as area of visibility is very good with 2 wingtip Combo heads compared to Cessna and Piper 2 wingtip strobes and 2 tip position lights and tail white from observing on ground and from top obf building, I didn't test inflight from below, but extrapulating from test, I am easily happy to trust my life and all others on the ability for me to be seen. On my Europa XS Monowheel I am going low draw strobes/position, SD20S with LR3C main and internal generator as backup / help out with temp high loads or low RPM, and a total loss 2200mA 13 cell NiMh backup battery in starboard headrest. Backup battery (under 2 pounds) can run 1 pump with autonomous wiring in seconds, even start the motor! Or for absolute certain run the prop for an airstart. After soaring, it is true you should consider yourself a glider once you shut down motor and treat as you can not restart, when I do try a inflight restart and my battery that just passed a load test the week before "opened", in seconds the NiMh can effortless help out when in 1500 FPM sink! Can also run Main or E-Bus. Ron Parigoris ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: RE: Pitot Current Draw
raymondj wrote: > >Rodney (O Wise Master), > > Pretty arrogant of you to think that you have control of or responsibility >for another's actions and to think that you have any right to try to impose >your values on another by attempting to control their actions. > > > Oh, get over yourself already. Until you start forking over some cash, you have no right to demand that anyone answer your questions at all, let alone in any particular fashion. Many of us sign in here because it is a good place to mull over and exchange ideas. That includes not only how to do things, but why to do things. This list, like most, is a conversation, not just an answering service. I get to choose how I share what I know. That's MY right. It's pretty arrogant of you to think that you have control of how another person shares his own knowledge, and to think that you have any right to try to impose your values on another by attempting to control their actions. That said, the original poster was provided with several avenues to pursue: a power cycler, a series resistor, and Eric's thermal gradient resistors (sorry, Eric, can't remember the proper name). The merits and drawbacks of each were discussed. So you he had to spend a few days watching the ideas bounce around a bit. How much more did that cost vs. paying a consultant? Was anything learned in the interim that is probably useless right now, but was free to you none the less, and possibly useful in the future? I reached deep and gave what little knowledge I had. Others did the same, teaching me some stuff which I consider more than adequate payment for my efforts. I controlled no one, and no one controlled me. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 07, 2006
In a message dated 12/07/2006 7:31:48 AM Central Standard Time, cjensen(at)dts9000.com writes: So, if there was a reasonably simple mechanical/electrical means of reducing the current draw of the pitot, I wanted to do it. >>> Not sure if this would work for you- just a possible solution: http://mpja.com/productview.asp?product=4057+MD It is a pulse-width modulation speed control for DC motors. I used one for dimming my panel LEDs. It is rated for 10 amps, so if the pitot heater drew more, you "might" have to add an appropriate resistor between the board output and the pitot, but not sure about this. You could use a DPDT switch on the panel for Pitot Heat with "Full" in one position, wired direct to the the heater, and the other side "Adj" (or something appropriate) that would supply power to the speed controller. This would also require adding the control pot to the panel to adjust the controller, or you could just set it to an acceptable partial setting and do without the adjustability. DISCLAIMER: lest somebody take this suggestion and go out and kill themselves, don't blame me! No sarcasm at all here, and please remember this is a venue for advancing the art of experimental aviation electrical systems, not commentary on opinions of personal philosophy- let's stay on mission, folks... >From The PosumWorks in TN Mark Phillips ________________________________________________________________________________
Date: Dec 07, 2006
Hey Chuck, Putting a resistor in series does reduce your current draw.. Are you happy with how much so? Has your question been answered? Your original question didn't quantify your goal. As has been mentioned, there are solutions to this problem which can deliver more power to the pitot tube for less total current expended, but they require more circuitry/figetry to accomplish. Matt- > > > Bob, > > Thanks for the (correct) information. As a child, I lead a sheltered > existance and wasn't allow to play with Ohms, Amps and other foreigners, > so this is new to me. There's a whole new, big, world out there to > learn about. P.S., I still want to reduce my current draw! > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob > White > Sent: Thursday, December 07, 2006 10:23 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Pitot Current Draw > > > "Chuck Jensen" wrote: > >> The current >> pitot draws about 15 amps. By comparison, my older, but very adequate > >>(as in--never iced up) pitot drew 7 amps. While not on a first name >>basis with any electrons, I assume that an amp is an amp and is >>generally going to produce a certain amount of heat, which is >>apparently adequate, based on empirical experience. So, if 7 amps was > >>good enough in the old pitot, I was thinkin' that 7 amps was probably >>good enough for this pitot. I could hire a thermodynamist to confirm >>all this, but I'll go out on a limb and employ common sense >>instead--it's cheaper and often, just as accurate. >> > > > Not quite true Chuck. Your old pitot tube was about 2 ohms. You were > drawing 7 amps from around 14 volts. Power is I^2 * R = 98 W. Now you > have a pitot that's about 1 ohm drawing 15 amps from 14 volts (0.933 > ohms but who's counting). Drop the current in this pitot to 7 amps and > power is only 49 W. It was suggested by someone that the dropping > resistor could be mounted on the pitot also which would help, but still > not be equivalent. > > Bob W. (Not a thermodynamist but I learned ohms law at an early age.) > > > -- > N93BD - Rotary Powered BD-4 - http://www.bob-white.com > First Flight: 11/23/2006 7:50AM - 0.7 Hours Total Time > Cables for your rotary installation - http://www.roblinphoto.com/shop/ > > ________________________________________________________________________________
Date: Dec 07, 2006
Chris Johnston wrote: > >Hey all - > >I've been monitoring this list for awhile now - I'm building an RV-10 - >and I wondered if any of the electron whizzes could help me. I'm trying >to find a good source for custom legend LED backlit rocker switches for >my project. > >I've historically done quite a bit of night flying, and after I got my >instrument rating, which I did 100% at night (with the one exception of >the checkride!) I vowed that I would not accept anything less than >complete readability of all controls and switches at night in the >cockpit. It just seemed so crazy that I had to juggle 3 flashlights in >the cockpit - one red led flash attached to my headset, a small red >maglite for cocpit instruments farther away from the pilot position, and >one more large one to look for ice on the airframe (yikes!). then I'd >get into my car after a long night of flying, turn on the lights, and >have no trouble reading any of the controls or switches. This is how I >want my aircraft to be! All controls self illuminating, and a >flashlight for emergency use only! Seems so simple, but I've been >confounded at every turn. Anyone have any suggestions? > >Thanks in advance! > > I compromised. Digikey has toggle switches with LEDs in the handles. I used different colors for various items. Water pumps are blue. Fuel pumps are red. Engine controls are green. All lighting is yellow. They're all rated at 30A 12VDC, and cost right at $5 each...except for the blue which I was surprised to find cost $9. (I didn't look that closely until after I had the order placed). I daisey chained them all the LED ground tabs together and brought a single wire to an MPJA motor controller for dimming. They do dim, but I would like quite a bit more range. I don't think I have the controller calibrated correctly. The blues are harshly bright, but everything else glows nice and softly. This doesn't completely solve what you're looking for, but with an intimate knowledge of the switch placement and color patterns, I think it is an improvement. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Dec 07, 2006
In a message dated 12/07/2006 12:21:33 PM Central Standard Time, echristley(at)nc.rr.com writes: The blues are harshly bright, but everything else glows nice and softly. HI Ed- Used the same dimmer with similar rockers and had to add about 1000 ohm resistors (maybe 2000, IIRC) to choke down the blue LEDS. Resistors were added to the ground faston tabs on the switch for the LED ground. Now back to the original question, which was WHERE TO GET LED BACKLIT ROCKER SWITCHES: I have also spent much time looking for same. Best I've come up with so far are not LED, but found these from Aerocraft: http://www.aerocraftparts.com/Categories.aspx?Category=38940ec0-b260-4e9f-a23c -b80ff8e89c67 (or go to www.aerocraftparts.com/ and look for Electrical\Switches\Rocker Switches). These are incandescent. I ordered a sample, but they are a bit bigger than I'd like, so I am now looking at these: http://www.engravers.net/aircraft/rocker_switches.htm which are available with neon or incandescent bulbs. Will order a sample and see how they look. If anyone DOES know of some alternatives, particularly with LEDs I'd love to hear about them! >From The PossumWorks Mark ________________________________________________________________________________
Date: Dec 07, 2006
Carling 632 series switches seem like they might fill the bill: http://rocker-switches.carlingtech.com/illuminated-rocker-switch__37.asp#elibrary Link to a descriptive pdf file: http://www.carlingtech.com/pdf/CarlingSW_622_632.pdf Then get them custom engraved.. Or engrave them yourself.. I suspect it wouldn't be too difficult. Matt- > > > Hey all - > > I've been monitoring this list for awhile now - I'm building an RV-10 - > and I wondered if any of the electron whizzes could help me. I'm trying > to find a good source for custom legend LED backlit rocker switches for > my project. > > I've historically done quite a bit of night flying, and after I got my > instrument rating, which I did 100% at night (with the one exception of > the checkride!) I vowed that I would not accept anything less than > complete readability of all controls and switches at night in the > cockpit. It just seemed so crazy that I had to juggle 3 flashlights in > the cockpit - one red led flash attached to my headset, a small red > maglite for cocpit instruments farther away from the pilot position, and > one more large one to look for ice on the airframe (yikes!). then I'd > get into my car after a long night of flying, turn on the lights, and > have no trouble reading any of the controls or switches. This is how I > want my aircraft to be! All controls self illuminating, and a > flashlight for emergency use only! Seems so simple, but I've been > confounded at every turn. Anyone have any suggestions? > > Thanks in advance! > > cj > #40410 > fuse > www.perfectlygoodairplane.net > > ________________________________________________________________________________
Date: Dec 07, 2006
If memory serves, Airpax.net has switch/breaker assys that have the lever illuminated, used them on my RV3 30 yrs ago. John ----- Original Message ----- From: Matt Prather To: aeroelectric-list(at)matronics.com Sent: Thursday, December 07, 2006 2:52 PM Subject: Re: AeroElectric-List: LED backlit rocker switches Carling 632 series switches seem like they might fill the bill: http://rocker-switches.carlingtech.com/illuminated-rocker-switch__37.asp# elibrary Link to a descriptive pdf file: http://www.carlingtech.com/pdf/CarlingSW_622_632.pdf Then get them custom engraved.. Or engrave them yourself.. I suspect it wouldn't be too difficult. Matt- > > > Hey all - > > I've been monitoring this list for awhile now - I'm building an RV-10 - > and I wondered if any of the electron whizzes could help me. I'm trying > to find a good source for custom legend LED backlit rocker switches for > my project. > > I've historically done quite a bit of night flying, and after I got my > instrument rating, which I did 100% at night (with the one exception of > the checkride!) I vowed that I would not accept anything less than > complete readability of all controls and switches at night in the > cockpit. It just seemed so crazy that I had to juggle 3 flashlights in > the cockpit - one red led flash attached to my headset, a small red > maglite for cocpit instruments farther away from the pilot position, and > one more large one to look for ice on the airframe (yikes!). then I'd > get into my car after a long night of flying, turn on the lights, and > have no trouble reading any of the controls or switches. This is how I > want my aircraft to be! All controls self illuminating, and a > flashlight for emergency use only! Seems so simple, but I've been > confounded at every turn. Anyone have any suggestions? > > Thanks in advance! > > cj > #40410 > fuse > www.perfectlygoodairplane.net > > > > > > > ________________________________________________________________________________
Date: Dec 07, 2006
Hello people, new to list here, and just thinking about the RV-10. I have a bit of experience in electronics and things electrical. While I don=92t have a circuit right now to show you for the desired purpose of regulating current to the pitot (I=92ll need a bit of time to look up a good one) things to keep in mind are: Just a power resister to drop the current will waste =BD the power in the limiting resister. Use the PWM with caution, as it may produce noise in the electrical system (depending on the frequency of the oscillations) that may affect your other systems, and be a cause for great frustration in locating the interference. Give me a few days to do some looking, and maybe I can find a better solution. Lower frequency is better, go for something that cycles in seconds, not milliseconds. Craig Smith. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Sent: Thursday, December 07, 2006 12:42 PM Subject: Re: AeroElectric-List: Re: Pitot Current Draw In a message dated 12/07/2006 7:31:48 AM Central Standard Time, cjensen(at)dts9000.com writes: So, if there was a reasonably simple mechanical/electrical means of reducing the current draw of the pitot, I wanted to do it. >>> Not sure if this would work for you- just a possible solution: http://mpja.com/productview.asp?product=4057+MD It is a pulse-width modulation speed control for DC motors. I used one for dimming my panel LEDs. It is rated for 10 amps, so if the pitot heater drew more, you "might" have to add an appropriate resistor between the board output and the pitot, but not sure about this. You could use a DPDT switch on the panel for Pitot Heat with "Full" in one position, wired direct to the the heater, and the other side "Adj" (or something appropriate) that would supply power to the speed controller. This would also require adding the control pot to the panel to adjust the controller, or you could just set it to an acceptable partial setting and do without the adjustability. DISCLAIMER: lest somebody take this suggestion and go out and kill themselves, don't blame me! No sarcasm at all here, and please remember this is a venue for advancing the art of experimental aviation electrical systems, not commentary on opinions of personal philosophy- let's stay on mission, folks... >From The PosumWorks in TN Mark Phillips ________________________________________________________________________________
Date: Dec 07, 2006
We also are using Jim Nelson's crankshaft driven alternator on our Europa Rotax 914. It works very well!! I have also supplied all the necessary parts to others - my local machine shop does a great job. We don't attempt to run both the B&C alt and the Rotax simultaneously. During pretakeoff checks, we verify the Rotax system is operational for use as a backup, but we use the B&C. Note that if you use the vacuum pump drive on 912 / 914 Rotax, it rotates at a slower speed than Lyc / Cont so B&C SD 8 and SD 20 put out less current than rated. Also, a Rotax crank shaft driven alternator runs at 5000 rpm, much less than the rpm that the manufacturer rates the alternator at. B&C L60 at 5000 rpm is 46 A; L40 at 5000 rpm is 33A. We've supplied kits for both. We have L60 on our 914 - fills in the space in the engine mount pretty well. Also note that FAR 91 requires "approved position and collision lights". In this case FAR 23 applies to experimental. Last I checked, the Kuzlemann lights do not meet the spec. But then your inspector probably won't notice or question them. We fitted Whelen lights to our Europa. Jim & Heather Butcher Europa N241BW Read this topic online here: http://forums.matronics.com/viewtopic.php?p=79961#79961 ________________________________________________________________________________
Subject: Aluminum Bus question for Bob
Date: Dec 07, 2006
Bob, How can I calculate the current carrying capacity of aluminum for sizing of aluminum bus bars? Can I convert copper AWG to square inches then apply a factor for aluminum? Any idea what the factor would be? I want to jump 3-4 inches from a GPU plug to the main bus. #4 copper should be adequate but what size aluminum bar would be equivalent? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 www.AirCraftersLLC.com ________________________________________________________________________________
Date: Dec 07, 2006
Mmm sort of.. I've seen the details of this topic danced around a bit so far.. First, let's assume that it's not practically possible to mount the dropping resistor in such a way that it dissipates it's heat into the pitot tube. Best case scenario mounts the resistor to the same fasteners that attach the heater to the wing. Many inches from the place that needs to get hot. Point: Let's assume the old, adequate heater used 100Watts when wired to the bus. Let's further assume the new one uses 200Watts when wired to the bus. That the old heater was adequate says that 100Watts is enough power (the right amount) for what Chuck wants to do. The challenge is to get the new heater to only use 100Watts. The way pick a dropping resistor which will do that is slightly complex. First, find the equivalent resistance of the new heater. That can be found by noting R=V^2/P = 14V*14V/200W = 0.98ohm. Great. Now we need to look at how much current needs to be shoved through the 0.98ohm resistor to get 100W. That can be found by using I = sqrt(P/R) sqrt(100/0.98) = 10.101A. Need to pass 10A through a 1ohm resistor to burn 100Watts. Good, passes the bs check. Now, let's look at what the total series resistance needs to be in order to get 10.1A through the circuit. That is R= V/I = 14V/10.1A = 1.386ohm. So, the total loop resistance needs to be 1.386ohm. 0.98ohm of that is coming from the pitot tube, and the other 0.41ohm comes from the dropping resistor. The power lost in the resistor can be found a couple of ways; I'll show one... P= (I^2)*R = 41Watts. The current without the dropping resistor is I = P/V = 200W/14V = 14.3A. Summary: To use a dropping resistor to get the equivalent amount of heat from the pitot tube (goal) reduces the current from 14.3A to 10.1A, and wastes 41Watts on the resistor. As has been mentioned, picking a resistor value equal to the equivalent resistance of the heater divides the current consumed by the circuit by two, but the power delivered to the tube itself by four. Maybe that's not an adequate amount of power for the tube to function. Certainly it wouldn't perform as well as the old pitot tube. Regards, Matt- snip > > Just a power resister to drop the current will waste the power in the > limiting resister. > snip > Craig Smith. > > > _____ > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Fiveonepw(at)aol.com > Sent: Thursday, December 07, 2006 12:42 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Re: Pitot Current Draw > > > In a message dated 12/07/2006 7:31:48 AM Central Standard Time, > cjensen(at)dts9000.com writes: > > So, if there was a reasonably simple mechanical/electrical means of > reducing > the current draw of the pitot, I wanted to do it. > >>>> > > > Not sure if this would work for you- just a possible solution: > > > http://mpja.com/productview.asp?product=4057+MD > > > It is a pulse-width modulation speed control for DC motors. I used one > for > dimming my panel LEDs. It is rated for 10 amps, so if the pitot heater > drew > more, you "might" have to add an appropriate resistor between the board > output and the pitot, but not sure about this. You could use a DPDT > switch > on the panel for Pitot Heat with "Full" in one position, wired direct to > the > the heater, and the other side "Adj" (or something appropriate) that would > supply power to the speed controller. This would also require adding the > control pot to the panel to adjust the controller, or you could just set > it > to an acceptable partial setting and do without the adjustability. > > > DISCLAIMER: lest somebody take this suggestion and go out and kill > themselves, don't blame me! No sarcasm at all here, and please remember > this is a venue for advancing the art of experimental aviation electrical > systems, not commentary on opinions of personal philosophy- let's stay on > mission, folks... > > >>From The PosumWorks in TN > > Mark Phillips > > ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: Need engine rpm pickup for Lycoming 360
> >I am finally ready to start hooking up wires on my Zenith 801 with >Lycoming O-360a1a. I have a Aveo E-1 and MaxFlight on my panel and need >an electronic RPM pickup for the Lycoming. My ultralight (Quicksilver >GT400) was very simple to wire up as it had a pulse wire from the >electronic ignition already. No electronic ignition on this old Lycoming >(Bendix mags). Any suggestions? You can read rpm from across the p-lead connections of an operating magneto. When you say 'electronic RPM pickup' I would hope that your instrument defines what that means. Many electronic tachs have been built and marketed that will read RPM from a magneto. Others depend on "real" 5 or 12v square waves from a hall effect device (some will read the spinning magneto magnet right through the housing). Still others may be unique pick-up technologies that expected something way out of the mainstream. What do the instructions for your instrument say? Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: Pitot Current Draw
> >"Chuck Jensen" wrote: > > > The current > > pitot draws about 15 amps. By comparison, my older, but very adequate > > (as in--never iced up) pitot drew 7 amps. While not on a first name > > basis with any electrons, I assume that an amp is an amp and is > > generally going to produce a certain amount of heat, which is apparently > > adequate, based on empirical experience. So, if 7 amps was good enough > > in the old pitot, I was thinkin' that 7 amps was probably good enough > > for this pitot. I could hire a thermodynamist to confirm all this, but > > I'll go out on a limb and employ common sense instead--it's cheaper and > > often, just as accurate. > > > > >Not quite true Chuck. Your old pitot tube was about 2 ohms. You were >drawing 7 amps from around 14 volts. Power is I^2 * R = 98 W. Now >you have a pitot that's about 1 ohm drawing 15 amps from 14 volts (0.933 >ohms but who's counting). Drop the current in this pitot to 7 amps and >power is only 49 W. It was suggested by someone that the dropping >resistor could be mounted on the pitot also which would help, but still >not be equivalent. > >Bob W. (Not a thermodynamist but I learned ohms law at an early age.) We touched on this in an earlier post. Recall that while you're reducing the current through the heater by 1/2, this drops the voltage across it by 1/2 also for a new dissipation value of 1/4 the original which comes to 29.5 watts for the tube and 29.5 watts dropped across the companion resistor for a system total of 49 watts. If one is applying a rule of thumb that "7 amps was adequate" then the goal is to drop the 15A tube (14 x 15 = 210 watts) down to what the original tube ran (7 x 14 = 98 watts). Obviously this is not a drop to 1/4 power but 1/2 power. So to get 98 watts dissipated in the new tube at 1 ohm resistance then I(squared) x 1 = 98. The new value for current drops NOT to 7A but to 10 amps. Given 14 volts applied and 10 volts needed for the new pitot heater then we need to drop 4 volts at 10 amps in the power reduction resistor. This calculates out to 4/10 or 0.4 ohms. The resistor will dissipate 4v x 10A or 40 watts. So, to keep the same heat delivered to the pitot tube we can only drop the current from 15A down to 10A. Total system draw will be 140 watts instead of the original 210 watts with 100 watts in the tube and 40 watts in the resistor. The foregoing assumption of equivalency holds only if the two tubes distribute their energy over the same number of square inches of tube surface. Equivalency for ice-melting abilities is measured in watts per square inch of power density. Bob . . . ________________________________________________________________________________
Date: Dec 07, 2006
> >Mmm sort of.. I've seen the details of this topic danced around a bit so >far.. Good job Matt. You picked it right up and beat me to it! Bob . . . ________________________________________________________________________________
Date: Dec 07, 2006
Subject: Re: Pitot Current Draw (Duty Cycle Control Case)
> > > So, to keep the same heat delivered to the pitot tube (USING A RESISTOR) > we can only drop the current from 15A down to 10A. Total system draw > will be > 140 watts instead of the original 210 watts with 100 watts in the > tube and 40 watts in the resistor. > > The foregoing assumption of equivalency holds only if the two > tubes distribute their energy over the same number of square inches > of tube surface. Equivalency for ice-melting abilities is measured > in watts per square inch of power density. Let us consider the duty cycle controller. If you put a transistor in series with the pitot tube heater and drive it with a 50% duty cycle square wave, an interesting thing happens . . . The PEAK power is still 14v x 15A or 210 watts. But since the heater is operating only 1/2 the time, the AVERAGE power is now down to 1/2 of peak or 105 watts. Interestingly enough, the AVERAGE current will also be down to 7A. The conservation of energy rules are not violated. In the resistor case, there are LOSSES in the current dropping device while a duty-cycle driven transistor has minimal losses (as low as 1 watt!). As others have mentioned, the down side of this scheme is that your bus gets whacked with a 15A pulse for each operating cycle of the heater system. One can explore relatively high frequency switching to avoid seeing the panel lights flicker (and believe me, they WILL) but this might cause audible noises elsewhere. Suggest about 30 Hz for minimum observability and below the audio frequencies of interest in the rest of your electro-whizzies. Bob . . . ________________________________________________________________________________
Date: Dec 07, 2006
Chuck, I like you! Few people are able to understand my sarcasm and read between the line when I hammer on the keys=85. I response to what you just wrote, if in fact 7amps will do and your sure of that. Then what you are saying is the current (no pun) version of pitot tube is over kill (also no pun intended). All these assumptions being true then all you would have to do is reduce the voltage until the current is at 7. Have fun, Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Thursday, December 07, 2006 6:27 AM Subject: RE: AeroElectric-List: Re: Pitot Current Draw Mike, If I was able to draw the sarcasm out of you, I'd had to see what a pro could do! (:-)). Actually, I've done the calculations and am satisfied of the results, even if not confirmed by empirical data. The current pitot draws about 15 amps. By comparison, my older, but very adequate (as in--never iced up) pitot drew 7 amps. While not on a first name basis with any electrons, I assume that an amp is an amp and is generally going to produce a certain amount of heat, which is apparently adequate, based on empirical experience. So, if 7 amps was good enough in the old pitot, I was thinkin' that 7 amps was probably good enough for this pitot. I could hire a thermodynamist to confirm all this, but I'll go out on a limb and employ common sense instead--it's cheaper and often, just as accurate. As to your suggestion of simply using a bigger battery, I didn't notice any calculations showing how big and how many batteries I should have. However, if by limiting heat output in the pitot, I cut my amperage in half, I can calculate that the draw from my current battery will be 1/2 as much and last twice as long (but not for the full load, since the pitot is only a fraction of the total load; unfortunately, a high fraction). As to the suggestion to just turn it off.....duh, the reason we have a heated pitot is--never mind, it makes my head hurt. Sorry for my poor response and sarcasm, but I think you brought it out of me. All the forgoing is just kidding. Not many people intentionly flying their GA craft into icing and not many lose electrical power generation, but when the two are combined, even though the odds are it happening are small, the odds of ending up dead are quite large. So, if there was a reasonably simple mechanical/electrical means of reducing the current draw of the pitot, I wanted to do it. Kind of like flying an airplane--not many of us have real good reasons for doing it, but we just want to do it. Chuck Jensen Mike wrote.... The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you=92re doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It=92s not like flying on a sunny day. But once you get use to it and prepare for it, it=92s not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don=92t have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman=92s terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. The reason that the pitot uses so much power (in general) is that is what it takes to keep ice off the probe in 100% humidity at temperatures < 10dec C. Sorry for the poor and somewhat sarcastic answer, but I think Chuck brought it out in me. Regards, Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, December 06, 2006 6:57 PM Subject: AeroElectric-List: Re: Pitot Current Draw Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen -- Please Support Your Lists This Month -- (And Get Some AWESOME FREE Gifts!) November is the Annual List Fund Raiser. Click on the Contribution link below to find out more about this year's Terrific Free Incentive Gifts provided by: * AeroElectric HYPERLINK "http://www.aeroelectric.com"www.aeroelectric.com * The Builder's Bookstore HYPERLINK "http://www.buildersbooks.com"www.buildersbooks.com * Aeroware Enterprises HYPERLINK "http://www.kitlog.com"www.kitlog.com * HomebuiltHELP HYPERLINK "http://www.homebuilthelp.com"www.homebuilthelp.com List Contribution Web Site --> HYPERLINK "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion Thank you for your generous support! -Matt Dralle, List Admin. - The AeroElectric-List Email Forum - --> HYPERLINK "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List -- 11/22/2006 -- 11/22/2006 href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m a tronics.com/Navigator?AeroElectric-List "http://www.aeroelectric.com"www.aeroelectric.com "http://www.buildersbooks.com"www.buildersbooks.com "http://www.kitlog.com"www.kitlog.com "http://www.homebuilthelp.com"www.homebuilthelp.com "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List -- 11/22/2006 -- 11/22/2006 ________________________________________________________________________________
Date: Dec 07, 2006
"Robert L. Nuckolls, III" wrote: > > > > > >"Chuck Jensen" wrote: > > > > > The current > > > pitot draws about 15 amps. By comparison, my older, but very adequate > > > (as in--never iced up) pitot drew 7 amps. While not on a first name > > > basis with any electrons, I assume that an amp is an amp and is > > > generally going to produce a certain amount of heat, which is apparently > > > adequate, based on empirical experience. So, if 7 amps was good enough > > > in the old pitot, I was thinkin' that 7 amps was probably good enough > > > for this pitot. I could hire a thermodynamist to confirm all this, but > > > I'll go out on a limb and employ common sense instead--it's cheaper and > > > often, just as accurate. > > > > > > > > >Not quite true Chuck. Your old pitot tube was about 2 ohms. You were > >drawing 7 amps from around 14 volts. Power is I^2 * R = 98 W. Now > >you have a pitot that's about 1 ohm drawing 15 amps from 14 volts (0.933 > >ohms but who's counting). Drop the current in this pitot to 7 amps and > >power is only 49 W. It was suggested by someone that the dropping > >resistor could be mounted on the pitot also which would help, but still > >not be equivalent. > > > >Bob W. (Not a thermodynamist but I learned ohms law at an early age.) > > We touched on this in an earlier post. Recall that while you're reducing > the current through the heater by 1/2, this drops the voltage across it > by 1/2 also for a new dissipation value of 1/4 the original which comes > to 29.5 watts for the tube and 29.5 watts dropped across the companion > resistor for a system total of 49 watts. Just a minor point - the 49 W is already 1/4 of the power consumption of the 'new' pitot tube. The only point I was making was that "I assume that an amp is an amp and is generally going to produce a certain amount of heat" was not correct. Bob W. > > If one is applying a rule of thumb that "7 amps was adequate" then the > goal is to drop the 15A tube (14 x 15 = 210 watts) down to what the > original tube ran (7 x 14 = 98 watts). Obviously this is not a drop > to 1/4 power but 1/2 power. So to get 98 watts dissipated in > the new tube at 1 ohm resistance then I(squared) x 1 = 98. > The new value for current drops NOT to 7A but to 10 amps. Given > 14 volts applied and 10 volts needed for the new pitot heater then > we need to drop 4 volts at 10 amps in the power reduction resistor. > This calculates out to 4/10 or 0.4 ohms. The resistor will dissipate > 4v x 10A or 40 watts. > > So, to keep the same heat delivered to the pitot tube we can only > drop the current from 15A down to 10A. Total system draw will be > 140 watts instead of the original 210 watts with 100 watts in the > tube and 40 watts in the resistor. > > The foregoing assumption of equivalency holds only if the two > tubes distribute their energy over the same number of square inches > of tube surface. Equivalency for ice-melting abilities is measured > in watts per square inch of power density. > > Bob . . . > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.7 Hours Total Time Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Subject: RE: Pitot Current Draw
Date: Dec 07, 2006
MessageWow! This discussion has really taken on a mind of it's own....I see almost 41 posts in this thread! As usual and in my own sarcastic way, I'm really confused and boggled as to why we're even discussing this (and to the unbelievably detailed technical minutia that has arisen out of something like this)....when there is a perfectly good heated pitot on the market that does EXACTLY what you want it to do....it varies the current to the tube from .1 Amps to 7 Amps depending on it's own temperature. When it doesn't need the heat it just idles, when it does it shoves more power out there. Why re-invent the wheel...someone already has and his name is Warren Gretz! I swear, just reading all these posts will waste more time than the $400 and some odd bucks it takes to buy one brand new....no messing around with all kinds of crazy little electrical components...bolt it on and go! Just my 2 cents as usual! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Chuck Jensen Sent: Tuesday, December 05, 2006 7:18 AM To: aeroelectric-list(at)matronics.com Subject: RE: AeroElectric-List: RE: Pitot Current Draw Hi, Keith, That was exactly my thought process also. I didn't want a red hot branding iron to bore my way through ice cubes...just warm enough to keep the pitot stuffed full of rain water from freezing. If the icing is bad enough that it freezes over a warm-to-very warm pitot, I've got bigger problems that a red hot pitot won't solve. Since no ideas have been tossed out, I wonder if there is an efficient means of cycling the pitot heater on/off at some interval, such as on for 30 seconds, off for two minutes. This would reduce the total current draw if a person was in the soup, lost electrical and needed whatever extra time available to get to safety but didn't dare to turn off the pitot in marginal icing conditions. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith Hallsten Sent: Monday, December 04, 2006 10:36 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: RE: Pitot Current Draw Chuck, I mounted a 28v Known Ice pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a Known Ice type of airframe. If I should find enough ice to overwhelm my lightweight pitot heating system, I have bigger problems than the pitot. Im not flying yet, but thats my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen (cjensen(at)dts9000.com) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Dec 07, 2006
Jay, Advanced Flight Systems has a tach sensor that screws into the mag. Another way is to purchase a tach drive sensor that screws into the tach drive on the engine. Check Aircraft Spruce or Wicks for this. Don ---- Jay Herron wrote: > > I am finally ready to start hooking up wires on my Zenith 801 with Lycoming O-360a1a. I have a Aveo E-1 and MaxFlight on my panel and need an electronic RPM pickup for the Lycoming. My ultralight (Quicksilver GT400) was very simple to wire up as it had a pulse wire from the electronic ignition already. No electronic ignition on this old Lycoming (Bendix mags). Any suggestions? > > Jay Herron > CH801 95% complete > Salem, OH > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=79835#79835 > > > > > > > > > > ________________________________________________________________________________
Date: Dec 06, 2006
If you want to vary the power to the heater, there are dozens, if not hundreds of designs for adjustable switching power supplies. A switching supply fed by ship's power that's capable of supplying full current to the pitot at full voltage would be the most efficient way to vary the power. This does not address weight issues or the wisdom of reducing the effectiveness of the pitot heat. Mike wrote: > The only way I can answer this question is to tell a story. First, > flying in the ice is something many pilot do every year and sometimes > often. If you know what youre doing and are prepared then the risks > are minimal. I have been flying in ice with airplanes that are able > to handle it for better then 20 years. Its not like flying on a > sunny day. But once you get use to it and prepare for it, its not > that big of a deal. A few words of advice, no two icing days are the > same. Only experience will help you here. My personal feeling on ice > in piston powered planes, you dont have many out when the weather > gets bad. When in ice greater then light find a place to land ASAP. > > > > As for you electric question; First the easy answer is to put a bigger > battery in the airplane. Second, why would you think that using less > power for pitot heat is going to be any better then turning the pitot > heat off all together? Unless you run a thermal equation on the > speed, temperature, and heat (laymans terms) required to guarantee > the anti-ice properties needed, then everything your doing is just a > big guess anyway. And I guessing that since I have to go to the book > to do said equation thoroughly, I would guess the electrical formula > by comparison would be a piece of cake. I know this is not what you > want to hear but the facts are the facts. The reason that the pitot > uses so much power (in general) is that is what it takes to keep ice > off the probe in 100% humidity at temperatures < 10dec C. > > > > Sorry for the poor and somewhat sarcastic answer, but I think Chuck > brought it out in me. > > > > Regards, > > > > Mike Larkin > > > > > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com > Sent: Wednesday, December 06, 2006 6:57 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Pitot Current Draw > > > > Chuck, > > You have just experienced the main thing I dislike about this forum. > When you ask for advice or assistance, you will commonly get critique > on why you should not do what it is you want to do. It takes several > attempts at explaining that you don't care about opinions - you simply > want assistance. For example, I've asked how to sample volts and amps > in multiple places in my electrical system. I got "you don't need to > know that info while you're flying." Regardless, I want to be able to > do that so how can I do it? Answer: since I don't think you should do > that I'm not going to tell you how to do it. > > As you've discovered, getting an answer can be very frustrating. > > Still, I've learned a lot about electrical stuff here and I continue > to learn. So, I still find the forum of value. > > I wish I had the answer for you - I would provide it. But, I don't. > Hopefully, you will get an acceptable answer. > > Stan Sutterfield > > > > Okay, I appreciate everyone holding forth that it's stupid to fly in > ice....I'm not that dumb, I only look it. However, the question > stands, > how does one knock down the heat and current draw. Richard > mentioned a > 'strut switch'....whoever that is. Can someone enlighten us > non-electrical types. What I'm concerned about is being in the > clouds, > close to freezing and loose electrical--I'd just as soon not have to > turn off the pitot heat because it's sucking the battery dry in short > order; I'd rather it be in long order. > > Chuck Jensen > ________________________________________________________________________________
Date: Dec 08, 2006
Subject: Matronics Fund Raiser - 2006 List of Contributors
Dear Listers, I would like to thank everyone that made a Contribution in support of the Lists this year! It was really nice to hear all great comments people had regarding the Lists! As I have said many times before, running these Lists is a labor of love. Your generosity during the List Fund Raiser only underscores the great sentiments people have made regarding the Lists. If you haven't yet made a Contribution in support of this year's Fund Raiser please feel free to do so. The nice List gifts will be available on the site for just a little while longer, so hurry and make your Contribution and get your great gift. Once again, the URL for the Contribution web site is: http://www.matronics.com/contribution I would like to thank Andy Gold of the Builder's Bookstore ( http://www.buildersbooks.com ), Paul Besing of Aeroware Enterprises ( http://www.kitlog.com ), Jon Croke of Homebuilt HELP ( http://www.homebuilthelp.com ) and Bob Nuckolls of AeroElectric ( http://www.aeroelectric.com ) for their extremely generous support during this year's Fund Raiser through the contribution of merchandise. These are great guys that support the aviation industry and I encourage each and every Lister to have a look at their products. Thank you Andy, Paul, Jon and Bob!! Your support is very much appreciated! And finally, below you will find a web link to the 2006 List of Contributors current as of 12/7/06! Have a look at this list of names as these are the people that make all of these List services possible! I can't thank each of you enough for your support and great feedback during this year's Fund Raiser! THANK YOU! http://www.matronics.com/loc/2006.html I will be shipping out all of the gifts in the next few weeks and hope to have everything out by the end of the month. In most cases, gifts will be shipped via US Postal Service. Kitlog Pro serial numbers should go out via email this weekend. Once again, thank you for making this year's List Fund Raiser successful! Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Dec 08, 2006
As others have mentioned, the down side of this scheme is that > your bus gets whacked with a 15A pulse for each operating cycle > of the heater system. One can explore relatively high frequency > switching to avoid seeing the panel lights flicker (and believe > me, they WILL) but this might cause audible noises elsewhere. > Suggest about 30 Hz for minimum observability and below the > audio frequencies of interest in the rest of your electro-whizzies. > There are >1F, < 2mOhm capacitors that one could use to mitigate: http://www.electronixwarehouse.com/car/accessories/capacitors.htm#spl (be careful charging/discharging - operate like a short circuit) 15A for 1/60th causes 0.25V dip on charged 1F. Maybe not as practical as buying off the shelf, but interesting. Cheers, Jan de Jong ________________________________________________________________________________
Date: Dec 08, 2006
Here is an excerpt of a reply I got from Bob on a related question several months ago. For more considerations, review the original message from the archive (or email me and I'll send it). Rick Titsworth 313-506-5604 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, January 11, 2006 1:45 PM Subject: Re: AeroElectric-List: Common Grounding ... I'm building a composite airplane with AFT batteries (Lancair ES). This would normally result in two large wires/cables running from the aft batteries/contactors up to the firewall/engine (alt and starter) - one live(+) and one ground (-). Why not incorporate/embed a "solid" electrical conductor (ground) which runs the length of the fuselage. For example, this could be an appropriately sized aluminum bar/rod/strap... Depends on how much time you want to spend on it. 2AWG copper is 4 oz per foot. Assuming 8' of cable from battery to firewall gives you 2# of installed weight. 2AWG is about .25" diameter or .05 square-in of cross section. Alum is 63% conductivity of copper so you'll need about 0.08 square-in of alum. A piece of 0.050" x 1.6" wide fills the bill. 96" x .05 x 1.6 is 7.7 cu" of aluminum. 0.1 pound per cubic inch is about 0.8 pounds. Expected weight savings is about 1.2 pounds. You could bring the strap up the inside of the firewall and clamp it up to the firewall ground bus. If you used copper strap, you could solder it to the ground strap for a really good joint. Original message/reply continues... _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Thursday, December 07, 2006 7:19 PM Subject: AeroElectric-List: Aluminum Bus question for Bob Bob, How can I calculate the current carrying capacity of aluminum for sizing of aluminum bus bars. ________________________________________________________________________________
Date: Dec 08, 2006
These switches are rated for 125v AC ....... are they OK for 12v DC??? and will the neon backlight work on 12v DC?? Len __________________ Carling 632 series switches seem like they might fill the bill: http://rocker-switches.carlingtech.com/illuminated-rocker-switch__37.asp#elibrary Link to a descriptive pdf file: http://www.carlingtech.com/pdf/CarlingSW_622_632.pdf Then get them custom engraved.. Or engrave them yourself.. I suspect it wouldn't be too difficult. Matt- > > > Hey all - > > I've been monitoring this list for awhile now - I'm building an RV-10 - > and I wondered if any of the electron whizzes could help me. I'm trying > to find a good source for custom legend LED backlit rocker switches for > my project. > > I've historically done quite a bit of night flying, and after I got my > instrument rating, which I did 100% at night (with the one exception of > the checkride!) I vowed that I would not accept anything less than > complete readability of all controls and switches at night in the > cockpit. It just seemed so crazy that I had to juggle 3 flashlights in > the cockpit - one red led flash attached to my headset, a small red > maglite for cocpit instruments farther away from the pilot position, and > one more large one to look for ice on the airframe (yikes!). then I'd > get into my car after a long night of flying, turn on the lights, and > have no trouble reading any of the controls or switches. This is how I > want my aircraft to be! All controls self illuminating, and a > flashlight for emergency use only! Seems so simple, but I've been > confounded at every turn. Anyone have any suggestions? > > Thanks in advance! > > cj > #40410 > fuse > www.perfectlygoodairplane.net > > ________________________________________________________________________________
Date: Dec 08, 2006
Craig/Matt/Bob/Bob again/et al Thanks for the technical responses which transcends the proclamation that only dummies fly in ice. And Stein, you have a point if I was only trying to use some reject hand-me-down pitot and I was too cheap to get one of Gretz's very elegantly functional pitots. This isn't about functionality, this is about aesthetics. I have a sharkfin pitot off an old warbird that I use at the tippy-point of the Velocity. The sharkfin perfectly picks up the lines of the winglets, yadda, yadda.....trust me, it's just a personal preference. Unfortunately, the heating elements in it were obviously designed for use in cold weather areas. In the winters, when they saw this sucker coming in, the ramp and line crews left the warmth of their burning trash barrels to comeover and stand by the pitot where there was some real heat!!! My conclusion is if I want to keep the pitot (which I do), I either live with the current draw, which is really not a serious problem for the 60amp alternator and just hope I don't need it at the same time that I start suddenly have a shortage of electrons. While the resistor fix may work, because of the loss to the resistor, the overall amperage reduction is minimal.....kind of like having to spend a $100 to get a $20 tax reduction. The more attractive alternative is duty cycle--assuming it doesn't put me in electron hell. Anyhow, I appreciate the many responses and the many tangents engaged. As to those who thought the thread went on too long and contain too much irrelevant material, just remember--that's why we sort through the pile of straw and horse s--t that was shoveled out of the horse barn with our bare hands---on the oft chance there might be a pony in there somewhere. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. Sent: Thursday, December 07, 2006 11:31 PM Subject: RE: AeroElectric-List: RE: Pitot Current Draw Wow! This discussion has really taken on a mind of it's own....I see almost 41 posts in this thread! As usual and in my own sarcastic way, I'm really confused and boggled as to why we're even discussing this (and to the unbelievably detailed technical minutia that has arisen out of something like this)....when there is a perfectly good heated pitot on the market that does EXACTLY what you want it to do....it varies the current to the tube from .1 Amps to 7 Amps depending on it's own temperature. When it doesn't need the heat it just idles, when it does it shoves more power out there. Why re-invent the wheel...someone already has and his name is Warren Gretz! I swear, just reading all these posts will waste more time than the $400 and some odd bucks it takes to buy one brand new....no messing around with all kinds of crazy little electrical components...bolt it on and go! Just my 2 cents as usual! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Chuck Jensen Sent: Tuesday, December 05, 2006 7:18 AM To: aeroelectric-list(at)matronics.com Subject: RE: AeroElectric-List: RE: Pitot Current Draw Hi, Keith, That was exactly my thought process also. I didn't want a red hot branding iron to bore my way through ice cubes...just warm enough to keep the pitot stuffed full of rain water from freezing. If the icing is bad enough that it freezes over a warm-to-very warm pitot, I've got bigger problems that a red hot pitot won't solve. Since no ideas have been tossed out, I wonder if there is an efficient means of cycling the pitot heater on/off at some interval, such as on for 30 seconds, off for two minutes. This would reduce the total current draw if a person was in the soup, lost electrical and needed whatever extra time available to get to safety but didn't dare to turn off the pitot in marginal icing conditions. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith Hallsten Sent: Monday, December 04, 2006 10:36 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: RE: Pitot Current Draw Chuck, I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a "Known Ice" type of airframe. If I should find enough ice to overwhelm my "lightweight" pitot heating system, I have bigger problems than the pitot. I'm not flying yet, but that's my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen (cjensen(at)dts9000.com ) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m a tronics.com/Navigator?AeroElectric-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/c h ref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m a tronics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Dec 08, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>Wow! This discussion has really taken on a mind of it's own....I see >almost 41 posts in this thread! As usual and in my own sarcastic way, I'm >really confused and boggled as to why we're even discussing this (and to >the unbelievably detailed technical minutia that has arisen out of >something like this)....when there is a perfectly good heated pitot on the >market that does EXACTLY what you want it to do....it varies the current >to the tube from .1 Amps to 7 Amps depending on it's own >temperature. When it doesn't need the heat it just idles, when it does it >shoves more power out there. Why re-invent the wheel...someone already >has and his name is Warren Gretz! I swear, just reading all these posts >will waste more time than the $400 and some odd bucks it takes to buy one >brand new....no messing around with all kinds of crazy little electrical >components...bolt it on and go! If the ONLY reason to have a discussion is to make a buying decision on a product, then indeed discussing the physics upon which it operates may be a "waste of time" for some individuals. I'd like to believe that the folks who hang out here are also interested in acquiring a confidence in their decisions based on understanding as opposed to market popularity or customer faith in a particular product. I'm working an EMC problem at RAC right now that is generating a ton of $100/hr email generation and and digestion that ranges all the way from techs to division managers. 99% of what's been written so far has hashed over a lot of facts (knowledge) and feelings (popularity contests) but as engineers, our duty is to not only find and fix the problem but to help everyone understand how we got there. Bob . . . ________________________________________________________________________________
Date: Dec 08, 2006
> >As others have mentioned, the down side of this scheme is that > >> your bus gets whacked with a 15A pulse for each operating cycle >> of the heater system. One can explore relatively high frequency >> switching to avoid seeing the panel lights flicker (and believe >> me, they WILL) but this might cause audible noises elsewhere. >> Suggest about 30 Hz for minimum observability and below the >> audio frequencies of interest in the rest of your electro-whizzies. > >There are >1F, < 2mOhm capacitors that one could use to mitigate: >http://www.electronixwarehouse.com/car/accessories/capacitors.htm#spl >(be careful charging/discharging - operate like a short circuit) > >15A for 1/60th causes 0.25V dip on charged 1F. > >Maybe not as practical as buying off the shelf, but interesting. > >Cheers, >Jan de Jong Point well taken. Earlier I mentioned a problem with bus voltage stability encountered with a $50K coffee maker on a $14M airplane. For the entirety of my career I've signed up to the notion that the ship's battery is "the best filter in the airplane". Evidence to the contrary has been laying on the table in front of me since day-one but went unnoticed because I failed to explore the questions. Turns out that a battery presents its specified milliohm source impedance to the bus only while it's DELIVERING energy. Once you elevate the battery's terminals above the energy delivery value (as for charging and maintaining) that battery's resistance to small voltage perturbations disappears. I did some quick-n-dirty looks at tying 1F capacitors across the bus. In this case 50A pulses that produced 4-volt perturbations with a battery on line dropped to 1-volt excursions with a 1F capacitor . . . right in the ballpark with your assertions above. Problem was that while the battery allowed 4-volt, 25 mS perturbations to generate noticeable flicker in cabin lights, the 1-volt perturbations were stretched by the longer system time constant with a capacitor installed. At 50 mS, the 1-volt perturbations were MORE noticeable than shorter pulses of greater intensity! Who would have thunk it? In any case, these studies have generated a profound change in the way I view vehicular bus dynamics. It's interesting how easy it is to be snookered into a belief structure that is wrong. Not just because it's heavily preached and deeply held . . . but because the question, "how does this work?" was never asked. Bob . . . //// (o o) ===========o00o=(_)=o00o======== < Go ahead, make my day . . . > < show me where I'm wrong. > ================================ ________________________________________________________________________________
Date: Dec 08, 2006
> > > > > We touched on this in an earlier post. Recall that while you're reducing > > the current through the heater by 1/2, this drops the voltage across it > > by 1/2 also for a new dissipation value of 1/4 the original which comes > > to 29.5 watts for the tube and 29.5 watts dropped across the companion > > resistor for a system total of 49 watts. > >Just a minor point - the 49 W is already 1/4 of the power consumption of >the 'new' pitot tube. The only point I was making was that "I assume >that an amp is an amp and is generally going to produce a certain >amount of heat" was not correct. > >Bob W. Agreed! Bob . . . ________________________________________________________________________________
Date: Dec 08, 2006
> 15A for 1/60th causes 0.25V dip on charged 1F. Forgot to mention - 0.25V discharge dip is on top of 0.03V resistance drop dip of 15A and 2mOhm. ________________________________________________________________________________
Date: Dec 08, 2006
Bob, Don't forget just to have a little fun every now and then. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, December 08, 2006 6:18 AM Subject: RE: AeroElectric-List: RE: Pitot Current Draw >Wow! This discussion has really taken on a mind of it's own....I see >almost 41 posts in this thread! As usual and in my own sarcastic way, I'm >really confused and boggled as to why we're even discussing this (and to >the unbelievably detailed technical minutia that has arisen out of >something like this)....when there is a perfectly good heated pitot on the >market that does EXACTLY what you want it to do....it varies the current >to the tube from .1 Amps to 7 Amps depending on it's own >temperature. When it doesn't need the heat it just idles, when it does it >shoves more power out there. Why re-invent the wheel...someone already >has and his name is Warren Gretz! I swear, just reading all these posts >will waste more time than the $400 and some odd bucks it takes to buy one >brand new....no messing around with all kinds of crazy little electrical >components...bolt it on and go! If the ONLY reason to have a discussion is to make a buying decision on a product, then indeed discussing the physics upon which it operates may be a "waste of time" for some individuals. I'd like to believe that the folks who hang out here are also interested in acquiring a confidence in their decisions based on understanding as opposed to market popularity or customer faith in a particular product. I'm working an EMC problem at RAC right now that is generating a ton of $100/hr email generation and and digestion that ranges all the way from techs to division managers. 99% of what's been written so far has hashed over a lot of facts (knowledge) and feelings (popularity contests) but as engineers, our duty is to not only find and fix the problem but to help everyone understand how we got there. Bob . . . -- 11/22/2006 -- 11/22/2006 ________________________________________________________________________________
Subject: FW: RE: Need engine rpm pickup for Lycoming 360
Date: Dec 08, 2006
glen matejcek aerobubba(at)earthlink.net > [Original Message] > From: glen matejcek <aerobubba(at)earthlink.net> > To: AeroElectric-List Digest Server > Date: 12/8/2006 8:56:02 AM > Subject: RE: Need engine rpm pickup for Lycoming 360 > > Hi Jay- > > >... need an electronic RPM pickup for the Lycoming... > > Westach makes a unit that screws right on to the tach drive and (I believe) outputs a 5V pulse train. > > glen matejcek > aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 08, 2006
> >Bob, > >Don't forget just to have a little fun every now and then. > >Mike My work is fun . . . or I wouldn't do it! The coolest feeling in the world for me is to go to bed understanding something that I didn't understand that morning. Bob . . . ________________________________________________________________________________
Date: Dec 08, 2006
Chuck, I think the capacitor suggested with a PWM might be your best bet. I have some mil-spec voltage regulators that I think may work as part of the circuit. These are the same regulators that Cessna uses in their panel dimmer circuits, just a more rugged version. Give me a day or 2 to hit the application notes, and I think I can give you a circuit that is cost effective, efficient and produce little noise. That is if someone else doesn't beat me to it. Since I see this component used already in certified aircraft it should be suitable for your application, provided it can handle the current necessary to keep it at the right temp. Some years back I worked with some very precise temperature controllers for infra-red black-body heat sources. Temperature controls accurate to +-.01 deg. C. CS _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck Jensen Sent: Friday, December 08, 2006 8:19 AM Subject: RE: AeroElectric-List: RE: Pitot Current Draw Craig/Matt/Bob/Bob again/et al Thanks for the technical responses which transcends the proclamation that only dummies fly in ice. And Stein, you have a point if I was only trying to use some reject hand-me-down pitot and I was too cheap to get one of Gretz's very elegantly functional pitots. This isn't about functionality, this is about aesthetics. I have a sharkfin pitot off an old warbird that I use at the tippy-point of the Velocity. The sharkfin perfectly picks up the lines of the winglets, yadda, yadda.....trust me, it's just a personal preference. Unfortunately, the heating elements in it were obviously designed for use in cold weather areas. In the winters, when they saw this sucker coming in, the ramp and line crews left the warmth of their burning trash barrels to comeover and stand by the pitot where there was some real heat!!! My conclusion is if I want to keep the pitot (which I do), I either live with the current draw, which is really not a serious problem for the 60amp alternator and just hope I don't need it at the same time that I start suddenly have a shortage of electrons. While the resistor fix may work, because of the loss to the resistor, the overall amperage reduction is minimal.....kind of like having to spend a $100 to get a $20 tax reduction. The more attractive alternative is duty cycle--assuming it doesn't put me in electron hell. Anyhow, I appreciate the many responses and the many tangents engaged. As to those who thought the thread went on too long and contain too much irrelevant material, just remember--that's why we sort through the pile of straw and horse s--t that was shoveled out of the horse barn with our bare hands---on the oft chance there might be a pony in there somewhere. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of SteinAir, Inc. Sent: Thursday, December 07, 2006 11:31 PM Subject: RE: AeroElectric-List: RE: Pitot Current Draw Wow! This discussion has really taken on a mind of it's own....I see almost 41 posts in this thread! As usual and in my own sarcastic way, I'm really confused and boggled as to why we're even discussing this (and to the unbelievably detailed technical minutia that has arisen out of something like this)....when there is a perfectly good heated pitot on the market that does EXACTLY what you want it to do....it varies the current to the tube from .1 Amps to 7 Amps depending on it's own temperature. When it doesn't need the heat it just idles, when it does it shoves more power out there. Why re-invent the wheel...someone already has and his name is Warren Gretz! I swear, just reading all these posts will waste more time than the $400 and some odd bucks it takes to buy one brand new....no messing around with all kinds of crazy little electrical components...bolt it on and go! Just my 2 cents as usual! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Chuck Jensen Sent: Tuesday, December 05, 2006 7:18 AM Subject: RE: AeroElectric-List: RE: Pitot Current Draw Hi, Keith, That was exactly my thought process also. I didn't want a red hot branding iron to bore my way through ice cubes...just warm enough to keep the pitot stuffed full of rain water from freezing. If the icing is bad enough that it freezes over a warm-to-very warm pitot, I've got bigger problems that a red hot pitot won't solve. Since no ideas have been tossed out, I wonder if there is an efficient means of cycling the pitot heater on/off at some interval, such as on for 30 seconds, off for two minutes. This would reduce the total current draw if a person was in the soup, lost electrical and needed whatever extra time available to get to safety but didn't dare to turn off the pitot in marginal icing conditions. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Keith Hallsten Sent: Monday, December 04, 2006 10:36 PM Subject: AeroElectric-List: RE: Pitot Current Draw Chuck, I mounted a 28v "Known Ice" pitot on the nose of my Velocity. Since I have a 14 volt electrical system, its power consumption will be reduced by a factor of 4 (power = V * V / R). I figure that is sufficient for my purposes, because a Velocity is NOT a "Known Ice" type of airframe. If I should find enough ice to overwhelm my "lightweight" pitot heating system, I have bigger problems than the pitot. I'm not flying yet, but that's my position for now. Actually, now that we all have GPS available to us, loss of pitot is not as critical as it used to be. With a fat margin to allow for wind, flying by groundspeed is generally a fair approximation. Regards, Keith Hallsten Subject: RE: Pitot Current Draw From: Chuck Jensen ( cjensen(at)dts9000.com) Date: Mon Dec 04 - 12:06 PM Wow, I must be hard-of-speaking (or writing). I concede that flying into icing when not so equipped is not a good idea, but if a person flies IFR in the winter most anywhere in the continental US, sooner or later, they'll pick up some ice. Even if my wings start looking like something that should be used to cool a gin and tonic, I don't want to lose air speed indication. Granted, I may not know what my new stall speed is, but I would like to know WHAT my speed is...and I can't do that with a pitot full of ice. So, the question on the table is still the same, is there a way off 'turning down the heat' and reducing current draw? Chuck Jensen href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List ________________________________________________________________________________
Subject: Aluminum Bus question for Bob
Date: Dec 08, 2006
The electrical conductivity of aluminum alloy 6061-T6 is 43% IACS (International Annealed Copper Standard) and 2024-T351 is 30% IACS. The highest conductivity aluminum alloy (if we can call 99.6% pure aluminum an alloy) is 1060-O with 62 %IACS. So, if you are using conductor grade aluminum such as 1060 for your bus bar (not easy to find in your local Home Depot) use a cross section that is 1/0.62 = 1.6 times the cross section of copper bus bar. More likely you will use 6061 so the cross section must be 2.3 times that of copper for equivalent current carrying capacity. If you use aluminum wire assume that the stuff is made with conductor grade aluminum. Best regards, Rob Housman A070 Airframe complete Irvine, CA -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dave Saylor Sent: Thursday, December 07, 2006 4:19 PM Subject: AeroElectric-List: Aluminum Bus question for Bob Bob, How can I calculate the current carrying capacity of aluminum for sizing of aluminum bus bars? Can I convert copper AWG to square inches then apply a factor for aluminum? Any idea what the factor would be? I want to jump 3-4 inches from a GPU plug to the main bus. #4 copper should be adequate but what size aluminum bar would be equivalent? Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 www.AirCraftersLLC.com <http://www.buildersbooks.com> <http://www.homebuilthelp.com> ________________________________________________________________________________
Date: Dec 08, 2006
Subject: Re: LED backlit rocker switches
They should work fine for many 12V DC applications. See: http://www.aeroelectric.com/articles/swtchrat.pdf The Neon backlight won't work on 12V DC, but LED is what was asked for.. The datasheet shows 6V, 12V, and 24V DC LED setups, plus one which presumably lacks a dropping resistor (unbalasted). Matt- > These switches are rated for 125v AC ....... are they OK for 12v DC??? and > will the neon backlight work on 12v DC?? > > > Len > > > __________________ > > > > > Carling 632 series switches seem like they might fill the bill: > > http://rocker-switches.carlingtech.com/illuminated-rocker-switch__37.asp#elibrary > > > Link to a descriptive pdf file: > > http://www.carlingtech.com/pdf/CarlingSW_622_632.pdf > > > Then get them custom engraved.. Or engrave them yourself.. I suspect it > wouldn't be too difficult. > > > Matt- > > >> >> >> Hey all - >> >> I've been monitoring this list for awhile now - I'm building an RV-10 - >> and I wondered if any of the electron whizzes could help me. I'm trying >> to find a good source for custom legend LED backlit rocker switches for >> my project. >> >> I've historically done quite a bit of night flying, and after I got my >> instrument rating, which I did 100% at night (with the one exception of >> the checkride!) I vowed that I would not accept anything less than >> complete readability of all controls and switches at night in the >> cockpit. It just seemed so crazy that I had to juggle 3 flashlights in >> the cockpit - one red led flash attached to my headset, a small red >> maglite for cocpit instruments farther away from the pilot position, and >> one more large one to look for ice on the airframe (yikes!). then I'd >> get into my car after a long night of flying, turn on the lights, and >> have no trouble reading any of the controls or switches. This is how I >> want my aircraft to be! All controls self illuminating, and a >> flashlight for emergency use only! Seems so simple, but I've been >> confounded at every turn. Anyone have any suggestions? >> >> Thanks in advance! >> >> cj >> #40410 >> fuse >> www.perfectlygoodairplane.net >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: Exterior Lights (Again)
Date: Dec 08, 2006
12/08/2006 Hello Jim, 1)You wrote: "Also note that FAR 91 requires "approved position and collision lights". In this case FAR 23 applies to experimental." I am not so sure that it is all that definitive. Can I please provide an opinion (copied below) from a previous exchange on this subject? --------------------- COPY FOLLOWS ------------------------------ ----- Original Message ----- From: <bakerocb(at)cox.net> Sent: Thursday, November 09, 2006 11:43 AM Subject: Reasonable qualification for flight hardware? > 11/09/2006 > > Responding to a previous posting by Dave N6030X > Hello Dave Morris, You wrote: "You probably need to find out whether the > FARs on light intensity apply to experimental aircraft or not." > > This is a question that has no clear cut answer. Let's examine the > regulatory issue in the context of exterior lighting: > > 1) The Operating Limitations for each ABEA (Amateur Built Experimental > Aircraft)** include the following sentence: "After completion of Phase I > flight testing, unless appropriately equipped for night and/or instrument > flight in accordance with 91.205, this aircraft is to be operated under > VFR, day only." > > 2) To the FAA this sentence means that if the ABEA is operated day VFR > that none of the instrument and equipment requirement provisions of FAR > 91.205 would apply. > > 3) This means that during day VFR operations not even FAR 91.205 (b) (11) > regarding the requirement for an anticollision light system would apply. > > 4) But as soon as the aircraft is operated at night or in instrument > flight, either day or night, the provisions of FAR 91.205 (b) (11), (c) > (2) and (c) (3) regarding exterior lighting would apply. > > 5) Each of the subparagraphs listed in 4 above contain the word > "approved". > > 6) But since there are no published certification standards for ABEA there > is no criteria available to measure approval against and one could > conclude that any exterior lighting on an ABEA would be acceptable. > > 7) But logic raises the issue of interface with other aircraft.## The > purpose of exterior lighting is to permit other observers in the air and > on the ground to see the ABEA and react accordingly. If the ABEA is > inadequately lighted then a hazard to others could exist . > > 8) This line of reasoning would permit the initial airworthiness inspector > to examine the exterior lighting of the ABEA with regard to its adequacy. > The inspector could conclude, if exterior lighting is present, that the > builder intended to operate the aircraft at night or in instrument > conditions and that therefore some specified level of performance should > be attained by that lighting. > > 9) A reasonable level of lighting performance to be expected could be > equivalent to that required of type certificated aircraft. > > 10) It is unlikely that the inspector would have either the equipment or > the inclination to actually measure the exterior lighting performance > during his initial airworthiness inspection. > > 11) One course of action for the inspector to ensure that the ABEA > lighting installed would meet some accepted performance standard would be > for him to require the ABEA to have installed exterior lighting approved > for installation in type certificated aircraft. > > 12) The issue may become confused if the builder installs some new > technology lighting (like LED's) that to any unbiased observer is > obviously superior to conventional lighting, but does not carry any kind > of FAA approval marking. To what extent is the initial airworthiness > inspector willing to sign off such lighting? > > So I think that the answer to your question: "Do the FARs on light > intensity apply to ABEA or not?" depends upon the actions of the > individual initial airworthiness inspector. It may also be possible that > an FAA inspector during a ramp inspection could raise this issue. > > OC -- The best investment we will ever make is in gathering knowledge. > > **PS: Some people prefer the more benign sounding, but less precise term, > OBAM (Owner Built And Maintained) aircraft. > > ##PS: There are other items of ABEA equipment where interface with other > aircraft or the ATC system require specified levels of performance. Some > that come to mind are communication radios, altitude encoders, > transponders, navigation equipment, and ELT's. In most cases the easiest > way to ensure that specified levels of performance will be met is to > install approved equipment such as that marked to meet a TSO (Technical > Standard Order) ----------------------- COPY ENDS --------------------------- Subject: AeroElectric-List: Re: : Rotax Aux Altenator switching. From: "h&jeuropa" <europa(at)triton.net> We also are using Jim Nelson's crankshaft driven alternator on our Europa Rotax 914. It works very well!! I have also supplied all the necessary parts to others - my local machine shop does a great job. We don't attempt to run both the B&C alt and the Rotax simultaneously. During pretakeoff checks, we verify the Rotax system is operational for use as a backup, but we use the B&C. Note that if you use the vacuum pump drive on 912 / 914 Rotax, it rotates at a slower speed than Lyc / Cont so B&C SD 8 and SD 20 put out less current than rated. Also, a Rotax crank shaft driven alternator runs at 5000 rpm, much less than the rpm that the manufacturer rates the alternator at. B&C L60 at 5000 rpm is 46 A; L40 at 5000 rpm is 33A. We've supplied kits for both. We have L60 on our 914 - fills in the space in the engine mount pretty well. Also note that FAR 91 requires "approved position and collision lights". In this case FAR 23 applies to experimental. Last I checked, the Kuzlemann lights do not meet the spec. But then your inspector probably won't notice or question them. We fitted Whelen lights to our Europa. Jim & Heather Butcher Europa N241BW ________________________________________________________________________________
Date: Dec 08, 2006
Subject: New Topic! Wire label-making machines
In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark ________________________________________________________________________________
Subject: Decreasing current to DC Motor
Date: Dec 08, 2006
I have EFI pumps that move way too much fuel for my purposes. Is there an inexpensive way to starve the current to the pump motor so that output is decreased without harming the motor? The pump normally draws 7 amps. Thanks John ________________________________________________________________________________
Date: Dec 08, 2006
From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Mark, I have the Dymo. Works good, lasts long time. J Prints on a shrink tube also. Michael Sausen -10 #352 Fuselage From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Sent: Friday, December 08, 2006 10:50 AM Subject: AeroElectric-List: New Topic! Wire label-making machines In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark ________________________________________________________________________________
Date: Dec 08, 2006
In a message dated 12/08/2006 7:22:38 AM Central Standard Time, len.baxter(at)gm.com writes: These switches are rated for 125v AC ....... are they OK for 12v DC??? and will the neon backlight work on 12v DC?? See: http://aeroelectric.com/articles/swtchrat.pdf One thing I don't like about the 622/632 series Carlings is that the lit rocker operators are clear colors (not translucent) so they may not be very easy to read if engraved. Take a look at these: http://www.carlingtech.com/pdf/CarlingSW_LRG.pdf Might be a better choice, and many operator colors, clear and translucent, but not LED- still 12v incandescent. Mark ________________________________________________________________________________
Date: Dec 08, 2006
Michael, Which one, where'd you get it, how much....yada yada? Ralph Most of my wiring's done - little pieces of laser printed paper stuffed into shrink tubes...... -----Original Message----- >From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net> >Sent: Dec 8, 2006 1:17 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: New Topic! Wire label-making machines > >Mark, > > > > I have the Dymo. Works good, lasts long time. J Prints on a shrink >tube also. > > > >Michael Sausen > >-10 #352 Fuselage > > > >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Fiveonepw(at)aol.com >Sent: Friday, December 08, 2006 10:50 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: New Topic! Wire label-making machines > > > >In a message dated 12/07/2006 10:37:52 PM Central Standard Time, >stein(at)steinair.com writes: > > I'm really confused and boggled > >Stein- what do you guys use to label your wires? I've used Brady >lablemaker pro (dot matrix through ribbon) but machine is T-up and >looking for replacement, preferably one that prints shrink tube. One >RV-lister recommended the Dymo Rhino Pro 5000. Any other >recommendations out there from actual users of one of these type >machines? > > > >And no, I'm not printing & cutting out itty bitty labels and slipping >them into little pieces of clear shrink tube- I need a one-shot machine >to get this done and move on... > > > >Mark > > > > ________________________________________________________________________________
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
Subject: Re: RE: Pitot Current Draw
Date: Dec 08, 2006
Amen, Stein! And it took two weeks for the response that actually answered Chuck's original question! Larry ________________________________________________________________________________
Date: Dec 08, 2006
Subject: Re: Decreasing current to DC Motor
This is just like the pitot tube question.. Old EFI systems had pressure regulators that returned unused fuel to the tank. The pump was big enough to provide all the fuel the engine could burn plus a little bit (to be returned to the tank). My understanding is that newer automotive systems have returnless pressure regulator/pump systems which use pulse width modulation (PWM) to regulate pump output. I think it's likely that your pumps could use such a system. Out of curiousity, wouldn't it make more sense to get pumps that are of the correct scale for your application? At the same time, and with no intent to insult your inteligence.. Fuel systems will require the correct pressure to be maintained at the full flow rate consumed by the engine (when flat-out).. Most IC engines will need around 0.65 lbs/hp/hr of fuel. So, a 180hp engine will use 180hp * 0.65 lbs/hp/hr / 6lbs/gal 19.5gal/hr. When your make 100hp, you don't want to over lean, so the system should have some headroom to provide extra fuel.. Maybe 25gal/hr at system pressure would be a good target for a 180hp engine.. Regards, Matt- > I have EFI pumps that move way too much fuel for my purposes. Is there an > inexpensive way to starve the current to the pump motor so that output is > decreased without harming the motor? The pump normally draws 7 amps. > > Thanks > John ________________________________________________________________________________
Date: Dec 08, 2006
Those are nice looking - probably better than the ones I proposed from a readability standpoint. I wonder of the 632's could be frosted during the engraving process. Seems like that would solve the issue. Matt- > In a message dated 12/08/2006 7:22:38 AM Central Standard Time, > len.baxter(at)gm.com writes: > These switches are rated for 125v AC ....... are they OK for 12v DC??? > and > will the neon backlight work on 12v DC?? > See: > > http://aeroelectric.com/articles/swtchrat.pdf > > One thing I don't like about the 622/632 series Carlings is that the lit > rocker operators are clear colors (not translucent) so they may not be > very easy > to read if engraved. Take a look at these: > > http://www.carlingtech.com/pdf/CarlingSW_LRG.pdf > > Might be a better choice, and many operator colors, clear and translucent, > but not LED- still 12v incandescent. > > Mark > ________________________________________________________________________________
Subject: Firewall penetration
Date: Dec 08, 2006
I have the need to bring several bundles of wire through my RV-7 firewall. I have some of the two-piece, stainless, firewall shields, but can't help but think there is a better way. Any great ideas out there [Question] Thanks, Don Owens Read this topic online here: http://forums.matronics.com/viewtopic.php?p211#80211 ________________________________________________________________________________
Date: Dec 08, 2006
.....I ordered a sample, but they are a bit bigger than I'd like, so I am now looking at these: <http://www.engravers.net/aircraft/rocker_switches.htm> http://www.engravers.net/aircraft/rocker_switches.htm which are available with neon or incandescent bulbs. Will order a sample and see how they look. If anyone DOES know of some alternatives, particularly with LEDs I'd love to hear about them!.......... CAUTION: I ordered these AML switches for my Glasair and received the NEON bulbs (AML36). You do not want them as they will not light up with 14V. You will need the incandescent bulbs for 14v (AML-34). ________________________________________________________________________________
Date: Dec 08, 2006
Michael, I am not familiar with these machines how does it print on shrink tubing? Don Owens Mark, I have the Dymo. Works good, lasts long time. :-) Prints on a shrink tube also. Michael Sausen -10 #352 Fuselage In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark -- 12:53 PM ________________________________________________________________________________
Subject: Re: Firewall penetration
Date: Dec 08, 2006
Don: Since you are building an RV look in the Vans catalogue under Firewall Shields. The "One Hole Eyeball" (EYEBALL TTP-125) is very superior to the two piece shields as well as the others. You drill one hole (albeit a large one). No rivets or screws. You don't have to install the split halves until you are completely done your project (can always add an extra wire). Only two negatives: First, it's expensive (worth every penny). Second, you have to remember to screw the retaining ring on when you install the eyeball -- before you run any wire) Don't ask how I learned that lesson. Other places sell them for roughly the same price - around $25.00. Good luck with your project. ----- Original Message ----- From: "Don Owens" <springcanyon(at)methow.com> Sent: Friday, December 08, 2006 3:24 PM Subject: AeroElectric-List: Firewall penetration > > > I have the need to bring several bundles of wire through my RV-7 firewall. > I have some of the two-piece, stainless, firewall shields, but can't help > but think there is a better way. Any great ideas out there [Question] > > Thanks, > Don Owens > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p211#80211 > > > ________________________________________________________________________________
Date: Dec 08, 2006
BINGO! These are almost exclusively what all of us "in the business" use on panels. The Honeywell AML's are top quality, and you can get the rockers in a variety of colors. Best of all, the are nicely sized and egrave VERY nicely from Wayne at Engravers.... I would stay away from the Carlings. We've used them before and frankly they are kind of a crappy switch (both of the series mentioned previously in this string). Regarding lights, don't waste your time on incandescents for the AML's. It's not a matter of IF they will burn out, but WHEN. In all the panels we build we put only LED's in them....plus the neat thing is the LED's are avaiable in a variety of colors, so if you put them behind the white rocker covers, you get a nice blue, orange, gree, etc.. color when they are turned on! Anyway, they are not cheap but the switches are very high quality and professional looking. Believe me, we've used almost every rocker out there (Carling, Otto, Eaton, etc..) and as of today the only thing we really encourage is the Honeywell AML's. Just my 2 cents as usual! Cheers, Stein. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Mark Banus Sent: Friday, December 08, 2006 2:37 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Re: LED backlit rocker switches ......I ordered a sample, but they are a bit bigger than I'd like, so I am now looking at these: http://www.engravers.net/aircraft/rocker_switches.htm which are available with neon or incandescent bulbs. Will order a sample and see how they look. If anyone DOES know of some alternatives, particularly with LEDs I'd love to hear about them!.......... CAUTION: I ordered these AML switches for my Glasair and received the NEON bulbs (AML36). You do not want them as they will not light up with 14V. You will need the incandescent bulbs for 14v (AML-34). ________________________________________________________________________________
Date: Dec 08, 2006
Try the K-Son #2011xlb available from www.magesupply.com it is a little expensive at $319 but I have the one it replaces and I would not give it up. You can get tubes for any size wire you use in an airplane. Don -----Original Message-----[dsvs] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Sent: Friday, December 08, 2006 8:50 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: New Topic! Wire label-making machines In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark ________________________________________________________________________________
Date: Dec 08, 2006
The kit I bought is The Dymo RhinoPro 5000: http://global.dymo.com/enUS/ProductAccessories/RhinoPRO_5000_Hard_Case_K it.html If you scroll down to accessories you'll see that you can get label cartridges that are actually shrink wrap tubing. They also have a polyester label that is very durable. Look around and you can find the kit for about $150. Michael From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of springcanyon Sent: Friday, December 08, 2006 2:53 PM Subject: RE: [Spam] RE: AeroElectric-List: New Topic! Wire label-making machines Michael, I am not familiar with these machines - how does it print on shrink tubing? Don Owens Mark, I have the Dymo. Works good, lasts long time. J Prints on a shrink tube also. Michael Sausen -10 #352 Fuselage In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark ________________________________________________________________________________
Date: Dec 08, 2006
Probably that link needs to be www.imagesupply.com and the model needs to be the 2012xlb (don't think the 2011 support tube tape at least not from the imagesupply website anyway... FWIW, Alan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Vs Sent: Friday, December 08, 2006 9:37 PM Subject: RE: AeroElectric-List: New Topic! Wire label-making machines Try the K-Son #2011xlb available from www.magesupply.com it is a little expensive at $319 but I have the one it replaces and I would not give it up. You can get tubes for any size wire you use in an airplane. Don -----Original Message-----[dsvs] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Sent: Friday, December 08, 2006 8:50 AM Subject: AeroElectric-List: New Topic! Wire label-making machines In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List ________________________________________________________________________________
Date: Dec 08, 2006
Right on both counts, sorry about that. Don -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Alan K. Adamson Sent: Friday, December 08, 2006 6:55 PM To: aeroelectric-list(at)matronics.com Subject: RE: AeroElectric-List: New Topic! Wire label-making machines Probably that link needs to be www.imagesupply.com and the model needs to be the 2012xlb (don't think the 2011 support tube tape at least not from the imagesupply website anyway... FWIW, Alan ---------------------------------------------------------------------------- -- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Vs Sent: Friday, December 08, 2006 9:37 PM To: aeroelectric-list(at)matronics.com Subject: RE: AeroElectric-List: New Topic! Wire label-making machines Try the K-Son #2011xlb available from www.magesupply.com it is a little expensive at $319 but I have the one it replaces and I would not give it up. You can get tubes for any size wire you use in an airplane. Don -----Original Message-----[dsvs] From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Sent: Friday, December 08, 2006 8:50 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: New Topic! Wire label-making machines In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.kitlog.com">www.kitlog.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/chref "http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics. com/Navigator?AeroElectric-List ________________________________________________________________________________
Subject: Re: Exterior Lights (Again)
Date: Dec 08, 2006
12/08/2006 Hello Jim, Thanks for your prompt and considered reply. You wrote: "The standard is for lighting not ABEA." Yes, there is a published standard for exterior lighting in FAR Part 23. The issue is: Does that Part 23 standard, in a formal, explicit, regulatory manner, apply to exterior lighting installed on an ABEA (Amateur Built Experimental Aircraft)? Or, more broadly, does any published FAA standard apply to an ABEA and the equipment installed upon it? A while back I was involved in an issue where a DAR performing an initial airworthiness inspection on an ABEA was attempting to force a builder to replace his seat belts / shoulder harnesses with those marked with TSO tags. I appealed to FAA Headquarters on behalf of the builder and William O'Brien replied thusly: on 09/02/2003 "Subject: Re: Shoulder Harness TSO. There is no certification requirement for a TSO shoulder harness for amateur-built. The word experimental means that the aircraft does not meet a standard." This tells me that no explicit, published, formal regulatory standards must be met by either the equipment on an ABEA or the ABEA itself. So why don't we have just a bunch of unsafe junk flying around in the form of ABEA's? It is because: A) Most builders are reasonable people, and B) There is a significant weight of process, training, accepted airworthiness practices, and Administrator level approval or disapproval power in the hands of the initial airworthiness inspector of each ABEA. And I believe that those inspectors give more weight to those equipment items on ABEA that can affect other aircraft and ATC operations than they do to an item that would affect only the occupants of the ABEA. That is why those occupants are given fair warning by mandatory signs and a placard in that ABEA that they are entering territory not entirely protected by published US Government aviation standards. As I have pointed out previously there are certain items of equipment that must meet interface, compatibility, and functional criteria with entities outside of the ABEA itself and usually the easiest way to accomplish those goals is to install a piece of FAA approved equipment. OC -- The best investment we will ever make is in gathering knowledge. ----- Original Message ----- From: "Jim Butcher" <europa(at)triton.net> Sent: Friday, December 08, 2006 5:48 PM Subject: Re: Exterior Lights (Again) > Interesting comment. After reading your COPY I have to agree that ABEA by > 91.319 (d) (2) can operate day VFR without fulfilling the requirements of > 91.205. To operate night or IFR then 91.205 applies and approved is > defined > in FAR 1.1 as "approved by the Administrator". The most common way that > is > done is by FAR, in this case, FAR 23. > > I guess I disagree that " 6) But since there are no published > certification > standards for ABEA there is no criteria available to measure approval > against and one could conclude that any exterior lighting on an ABEA would > be acceptable." The standard is for lighting not ABEA. > > Just my interpretation. > > Jim Butcher ________________________________________________________________________________
Date: Dec 09, 2006
Subject: Re: Pitot Current Draw
Mike Larkin, I don't mean to be sarcastic, but you didn't answer any questions - at least any questions that had been asked. Chuck asked about how to wire his pitot heat so as to have the option to cycle from low heat to high heat. I don't agree with Chuck regarding the wisdom of using a lower heat setting to save power in IMC icing conditions if the alternator fails, but his question is not, "Should I use a lower heat setting?" His question is, "How do I wire so to obtain my choice of heat settings?" We all have personal stories to tell. They aren't relevant to Chuck's question unless they are related to how one wires one's electrical system to obtain high-low pitot heat. My personal philosophy regarding icing conditions in SE piston powered aircraft is exactly the same as yours. But, my philosophy about flying in icing conditions is not relevant to Chuck's question. The only answer or opinion that Chuck wants is the one that describes to him how to wire his electrical system to permit high and low pitot heat settings. We have to leave it to him to decide if such a system is adequate and if it is wise to employ it in icing conditions. Regards, Stan Sutterfield The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you=92re doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It=92s not like flying on a sunny day. But once you get use to it and prepare for it, it=92s not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don=92t have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman=92s terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. The reason that the pitot uses so much power (in general) is that is what it takes to keep ice off the probe in 100% humidity at temperatures ________________________________________________________________________________
Date: Dec 09, 2006
Matt, An interesting concept. Stan Sutterfield Why doesn't anyone have a pitot tube heated directly by the combustion of a hydrocarbon ________________________________________________________________________________
Date: Dec 09, 2006
Dr. Rodney, Tell me, o wise one, how can one read the mind of another to determine whether or not he might misuse information you provide? You, and others, cannot police everyone's thoughts. Nor should you. Regards, Grasshopper I believe I have some measure of culpability for the actions of others if I have enabled them in some way to DO something bad with the information they're gathering. And, I believe the listers here believe that too! We listers want everyone here to play safe! ________________________________________________________________________________
Date: Dec 09, 2006
Thank you, Raymond. I could not have said it better. Stan Sutterfield Rodney (O Wise Master), Pretty arrogant of you to think that you have control of or responsibility for another's actions and to think that you have any right to try to impose your values on another by attempting to control their actions. Raymond Julian Kettle River, MN. ________________________________________________________________________________
Date: Dec 09, 2006
Wow, a recent first flight? Tell us about it. Do you have photos posted anywhere? Couldn't connect to your web site. Stan Sutterfield Bob W. (Not a thermodynamist but I learned ohms law at an early age.) -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com First Flight: 11/23/2006 7:50AM - 0.7 Hours Total Time ________________________________________________________________________________
Subject: RE: Firewall penetration
Date: Dec 09, 2006
Hi Don > I have the need to bring several bundles of wire through my RV-7 firewall. > I have some of the two-piece, stainless, firewall shields, but can't help > but think there is a better way. Any great ideas out there [Question] I used Bob's stainless grab bar idea, and really like it. Search the archives, look at http://aeroelectric.com/articles/Firewall_Penetration/firewall.html , and consider using the cut off ends of a handicapped shower grab bar. I think I paid $14 or $17 for the shortest one I could find, which of course yielded up 2 penetration fittings. One is big enough to handle 3 heavy engine / prop control cables, 2 bowdens, the MP line, a #2 battery cable, and the power feed from the alternator. The other one on the other side of the fire wall has all the sensor lines. I'm quite happy with the way it has turned out- glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 09, 2006
You may want to look into the light strips. Come in different lengths and sizes. Low power consumption. jerb At 10:20 AM 12/7/2006, you wrote: > > >Hey all - > >I've been monitoring this list for awhile now - I'm building an RV-10 - >and I wondered if any of the electron whizzes could help me. I'm trying >to find a good source for custom legend LED backlit rocker switches for >my project. > >I've historically done quite a bit of night flying, and after I got my >instrument rating, which I did 100% at night (with the one exception of >the checkride!) I vowed that I would not accept anything less than >complete readability of all controls and switches at night in the >cockpit. It just seemed so crazy that I had to juggle 3 flashlights in >the cockpit - one red led flash attached to my headset, a small red >maglite for cocpit instruments farther away from the pilot position, and >one more large one to look for ice on the airframe (yikes!). then I'd >get into my car after a long night of flying, turn on the lights, and >have no trouble reading any of the controls or switches. This is how I >want my aircraft to be! All controls self illuminating, and a >flashlight for emergency use only! Seems so simple, but I've been >confounded at every turn. Anyone have any suggestions? > >Thanks in advance! > >cj >#40410 >fuse >www.perfectlygoodairplane.net > > ________________________________________________________________________________
Date: Dec 09, 2006
Stan, You're right in that there was a lot of circling of the opinion vultures before the meat was ripe to eat on this one--but it wasn't wasted time. As you pointed out, my question was 'how to do it' and not 'is it a good idea'. Eventually, the first question was answered though the early hits addressed the second question, which was not asked. However, as said, that was not wasted time. All education and wisdom on this site is not necessarily committable to a formula. The opinions expressed, some relevant, others not, at least got me thinking...which is a good thing for all of us to do when we are doing something non-standard. Sometimes, we get so focused on a goal that our mental blinders causes us to lose sight of the peripheral issues which are raised for (re)consideration by some of the misdirected postings. So, I dug through that pile of straw and stuff and found the pony. I didn't like his color or his size, but he is what he is, so now I have to decide what to do about him. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Saturday, December 09, 2006 12:45 AM Subject: AeroElectric-List: Re: Pitot Current Draw Mike Larkin, I don't mean to be sarcastic, but you didn't answer any questions - at least any questions that had been asked. Chuck asked about how to wire his pitot heat so as to have the option to cycle from low heat to high heat. I don't agree with Chuck regarding the wisdom of using a lower heat setting to save power in IMC icing conditions if the alternator fails, but his question is not, "Should I use a lower heat setting?" His question is, "How do I wire so to obtain my choice of heat settings?" We all have personal stories to tell. They aren't relevant to Chuck's question unless they are related to how one wires one's electrical system to obtain high-low pitot heat. My personal philosophy regarding icing conditions in SE piston powered aircraft is exactly the same as yours. But, my philosophy about flying in icing conditions is not relevant to Chuck's question. The only answer or opinion that Chuck wants is the one that describes to him how to wire his electrical system to permit high and low pitot heat settings. We have to leave it to him to decide if such a system is adequate and if it is wise to employ it in icing conditions. Regards, Stan Sutterfield The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you=92re doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It=92s not like flying on a sunny day. But once you get use to it and prepare for it, it=92s not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don=92t have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman=92s terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. Thee it to him to decide if such a system is adequate and if it is wise to employ it in icing conditions. Regards, Stan Sutterfield The only way I can answer this question is to tell a story. First, flying in the ice is something many pilot do every year and sometimes often. If you know what you=92re doing and are prepared then the risks are minimal. I have been flying in ice with airplanes that are able to handle it for better then 20 years. It=92s not like flying on a sunny day. But once you get use to it and prepare for it, it=92s not that big of a deal. A few words of advice, no two icing days are the same. Only experience will help you here. My personal feeling on ice in piston powered planes, you don=92t have many out when the weather gets bad. When in ice greater then light find a place to land ASAP. As for you electric question; First the easy answer is to put a bigger battery in the airplane. Second, why would you think that using less power for pitot heat is going to be any better then turning the pitot heat off all together? Unless you run a thermal equation on the speed, temperature, and heat (layman=92s terms) required to guarantee the anti-ice properties needed, then everything your doing is just a big guess anyway. And I guessing that since I have to go to the book to do said equation thoroughly, I would guess the electrical formula by comparison would be a piece of cake. I know this is not what you want to hear but the facts are the facts. The reason that the pitot uses so much power (in general) is that is what it takes to keep ice off the probe in 100% humidity at temperatures < 10dec C. Sorry for the poor and somewhat sarcastic answer, but I think Chuck brought it out in me. Regards, Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: Wednesday, December 06, 2006 6:57 PM Subject: AeroElectric-List: Re: Pitot Current Draw Chuck, You have just experienced the main thing I dislike about this forum. When you ask for advice or assistance, you will commonly get critique on why you should not do what it is you want to do. It takes several attempts at explaining that you don't care about opinions - you simply want assistance. For example, I've asked how to sample volts and amps in multiple places in my electrical system. I got "you don't need to know that info while you're flying." Regardless, I want to be able to do that so how can I do it? Answer: since I don't think you should do that I'm not going to tell you how to do it. As you've discovered, getting an answer can be very frustrating. Still, I've learned a lot about electrical stuff here and I continue to learn. So, I still find the forum of value. I wish I had the answer for you - I would provide it. But, I don't. Hopefully, you will get an acceptable answer. Stan Sutterfield Okay, I appreciate everyone holding forth that it's stupid to fly in ice....I'm not that dumb, I only look it. However, the question stands, how does one knock down the heat and current draw. Richard mentioned a 'strut switch'....whoever that is. Can someone enlighten us non-electrical types. What I'm concerned about is being in the clouds, close to freezing and loose electrical--I'd just as soon not have to turn off the pitot heat because it's sucking the battery dry in short order; I'd rather it be in long order. Chuck Jensen ________________________________________________________________________________
Date: Dec 09, 2006
Thanks Matt. No offense taken. Knowledge is knowledge. I've found that most EFI systems are content to move copious amounts of fuel and I think that it's because the gearotor pump design, in the size that is found on cars, seems to move between 40 and 65 gph.One can find pumps of slightly less capacity, but they are almost all fitted with push on barbed connections. Mine are push-on at the intake (about 1 psi) and threaded AN fitting on the high pressure end. One pump moves 46 gph @ 45psi @ 7A through 1/4" line! Both push 78 gph. I need a single pump output of about 30 gph.The problem is my single pump is at the edge of cavitation; both on, and I can see air in the transparent intake tubing. A fellow lister gave me a part # for a Napa pump that is the right capacity, but the pump has barbed fittings and needs adaptation. I'm probably going to go this route, but I thought I'd check with the List to see if there was an electrical solution. Pulse width modulation is a possibility but has it's own problems of whacking the bus with surges and potentially causing problems with other equipment. JOhn ________________________________________________________________________________
Date: Dec 09, 2006
In addition to a glareshield electrolumenescent strip (which I quite like) and integral instrument lighting I wired a couple of $5. miniature Home Depot LED gooseneck lights in series and put them on a dimmer. One on each side of the cockpit above the doors. The gooseneck is about 3" long. They originally contained little button cells and are intended to clip onto a shirt pocket so that the little gooseneck LED can be pointed where you need it. The light spreads out to about a 12" round beam by the time it hits the panel. I have a separate overhead incandescent map light so I don't normally leave the LED's on but they are sometimes handy for illuminating specific switches and they are very low power consumption in case of electrical problems or loss of other lighting. They are wired to the battery bus. These are not ideal as I had to run another ground wire down the gooseneck to isolate the ground wire from the aluminum battery case. You could insulate the case from the airframe I suppose. Seemed like a better idea than holding a flashlight in my teeth though which I was determined not to do... Switch lighting should really allow both identification AND being able to see whether the switch is on or off at a glance. Heavy iron machines often have backlit labeling and lighted 'on' indicators to achieve that. Sometimes the 'on' indicator even confirms functionality such as nominal current is flowing, or valve is open, rather than just indicating switch position. Ken jerb wrote: > > You may want to look into the light strips. Come in different lengths > and sizes. Low power consumption. > jerb > > At 10:20 AM 12/7/2006, you wrote: > >> >> >> Hey all - >> >> I've been monitoring this list for awhile now - I'm building an RV-10 - >> and I wondered if any of the electron whizzes could help me. I'm trying >> to find a good source for custom legend LED backlit rocker switches for >> my project. >> >> I've historically done quite a bit of night flying, and after I got my >> instrument rating, which I did 100% at night (with the one exception of >> the checkride!) I vowed that I would not accept anything less than >> complete readability of all controls and switches at night in the >> cockpit. It just seemed so crazy that I had to juggle 3 flashlights in >> the cockpit - one red led flash attached to my headset, a small red >> maglite for cocpit instruments farther away from the pilot position, and >> one more large one to look for ice on the airframe (yikes!). then I'd >> get into my car after a long night of flying, turn on the lights, and >> have no trouble reading any of the controls or switches. This is how I >> want my aircraft to be! All controls self illuminating, and a >> flashlight for emergency use only! Seems so simple, but I've been >> confounded at every turn. Anyone have any suggestions? >> >> Thanks in advance! >> >> cj >> #40410 >> fuse >> www.perfectlygoodairplane.net > ________________________________________________________________________________
Date: Dec 09, 2006
Thanks Glen - That's perfect - just what I was looking for. :) Don Owens Read this topic online here: http://forums.matronics.com/viewtopic.php?p409#80409 ________________________________________________________________________________
Date: Dec 09, 2006
Subject: Re: New Topic! Wire label-making machines
This outfit has the rhinopro 3000 for $65. Says it prints on heat shrink. >http://www.provantage.com/dymo-15605~7DYMO02H.htm > ________________________________________________________________________________
Date: Dec 09, 2006
michael, i am interested in the dymo labeler #5000 you have. how would it work for labeling the panel? do the labels really stick? i also read something about being able to print on shrink tube. is this true? thanks in advance, bob noffs ----- Original Message ----- From: RV Builder (Michael Sausen) To: aeroelectric-list(at)matronics.com Sent: Friday, December 08, 2006 8:50 PM Subject: RE: [Spam] RE: AeroElectric-List: New Topic! Wire label-making machines The kit I bought is The Dymo RhinoPro 5000: http://global.dymo.com/enUS/ProductAccessories/RhinoPRO_5000_Hard_Case_Ki t.html If you scroll down to accessories you'll see that you can get label cartridges that are actually shrink wrap tubing. They also have a polyester label that is very durable. Look around and you can find the kit for about $150. Michael From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of springcanyon Sent: Friday, December 08, 2006 2:53 PM To: aeroelectric-list(at)matronics.com Subject: RE: [Spam] RE: AeroElectric-List: New Topic! Wire label-making machines Michael, I am not familiar with these machines - how does it print on shrink tubing? Don Owens Mark, I have the Dymo. Works good, lasts long time. J Prints on a shrink tube also. Michael Sausen -10 #352 Fuselage In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes: I'm really confused and boggled Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines? And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on... Mark www.aeroelectric.comwww.buildersbooks.comwww.kitlog.comwww.homebuilthelp. comhttp://www.matronics.com/contributionhttp://www.matronics.com/Navigato r?AeroElectric-List ________________________________________________________________________________
Date: Dec 09, 2006
Subject: LED Strobe Lights
How about these strobes? Has anyone looked into them? The appear to be LED based, but also appear expensive. They also have integrated strobe/position lights. http://www.flightcomponents.com/content/view/48/ Dan Fritz --------------------------------- ________________________________________________________________________________
Date: Dec 09, 2006
They apparently sell some rather pricey heat shrink for it. 1/2, 3/8 and 1/4 inch flat widths. Is any of that going to grip a 22ga wire very well? I'm interested in this technology, but want to know more before I buy any new toys. -Bill B On 12/9/06, sarg314 wrote: > > This outfit has the rhinopro 3000 for $65. Says it prints on heat shrink. > > >http://www.provantage.com/dymo-15605~7DYMO02H.htm > > > > ________________________________________________________________________________
Date: Dec 09, 2006
In a message dated 12/9/2006 6:26:35 PM Central Standard Time, sportav8r(at)gmail.com writes: Is any of that going to grip a 22ga wire very well? >>> They claim the 1/4" stuff will go down to 1.18mm- I measured some 22awg tefzel at 1.25mm. Pretty close, but oughta work. Still not too tickled that it only seems to print the tube on one side. Leaning towards the Brady ID Pal that will print multiple rows that can be wrapped around the wire, plus if you screw up, you can remove the old sticker and put on a new one without removing the termination... Mark ________________________________________________________________________________
Subject: DYMO RhinoPRO3000 label writer
Date: Dec 10, 2006
I looked it up as suggested and believe it's useful BUT the price of heat shrink comes out to about $5 a foot, or perhaps 75cents a label (mistakes excepted). Rolls come in 5 foot lengths. Any- body find better source? Ferg Kyle Europa A064 914 Classic ________________________________________________________________________________
Date: Dec 10, 2006
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: LED Strobe Lights
>How about these strobes? Has anyone looked into them? The appear to be >LED based, but also appear expensive. They also have integrated >strobe/position lights. > ><http://www.flightcomponents.com/content/view/48/>http://www.flightcomponents.com/content/view/48/ > >Dan Fritz We had some meetings at RAC where the principal and their rep did some presentations on this and other LED based exterior lighting products. I wasn't on the evaluation team tasked with looking into incorporation of the devices on our aircraft . . . but maybe I could track them down and ask about their findings. I'm unaware of any efforts to get them on our airplanes at the moment. We DO use the Wheelan white LED tail lights on several models. Bob . . . ________________________________________________________________________________
Date: Dec 10, 2006
Hey Chuck, One more idea (I think I've read all of the other messages on this topic - I haven't seen this idea before)... How about modifying the heating element in the heater. Possibly a heating element from a more modest pitot tube could be installed... Matt- Chuck Jensen wrote: > Craig/Matt/Bob/Bob again/et al > Thanks for the technical responses which transcends the proclamation > that only dummies fly in ice. And Stein, you have a point if I was > only trying to use some reject hand-me-down pitot and I was too cheap > to get one of Gretz's very elegantly functional pitots. This isn't > about functionality, this is about aesthetics. I have a sharkfin pitot > off an old warbird that I use at the tippy-point of the Velocity. The > sharkfin perfectly picks up the lines of the winglets, yadda, > yadda.....trust me, it's just a personal preference. > Unfortunately, the heating elements in it were obviously designed for > use in cold weather areas. In the winters, when they saw this sucker > coming in, the ramp and line crews left the warmth of their burning > trash barrels to comeover and stand by the pitot where there was some > real heat!!! > My conclusion is if I want to keep the pitot (which I do), I either > live with the current draw, which is really not a serious problem for > the 60amp alternator and just hope I don't need it at the same time > that I start suddenly have a shortage of electrons. While the resistor > fix may work, because of the loss to the resistor, the overall > amperage reduction is minimal.....kind of like having to spend a $100 > to get a $20 tax reduction. > The more attractive alternative is duty cycle--assuming it doesn't put > me in electron hell. Anyhow, I appreciate the many responses and the > many tangents engaged. As to those who thought the thread went on too > long and contain too much irrelevant material, just remember--that's > why we sort through the pile of straw and horse s--t that was shoveled > out of the horse barn with our bare hands---on the oft chance there > might be a pony in there somewhere. > > Chuck Jensen > * * > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *SteinAir, Inc. > *Sent:* Thursday, December 07, 2006 11:31 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* RE: AeroElectric-List: RE: Pitot Current Draw > > Wow! This discussion has really taken on a mind of it's own....I see > almost 41 posts in this thread! As usual and in my own sarcastic way, > I'm really confused and boggled as to why we're even discussing this > (and to the unbelievably detailed technical minutia that has arisen > out of something like this)....when there is a perfectly good heated > pitot on the market that does EXACTLY what you want it to do....it > varies the current to the tube from .1 Amps to 7 Amps depending on > it's own temperature. When it doesn't need the heat it just idles, > when it does it shoves more power out there. Why re-invent the > wheel...someone already has and his name is Warren Gretz! I swear, > just reading all these posts will waste more time than the $400 and > some odd bucks it takes to buy one brand new....no messing around with > all kinds of crazy little electrical components...bolt it on and go! > Just my 2 cents as usual! > Cheers, > Stein. > > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]*On Behalf > Of* Chuck Jensen > *Sent:* Tuesday, December 05, 2006 7:18 AM > *To:* aeroelectric-list(at)matronics.com > *Subject:* RE: AeroElectric-List: RE: Pitot Current Draw > > Hi, Keith, > That was exactly my thought process also. I didn't want a red hot > branding iron to bore my way through ice cubes...just warm enough > to keep the pitot stuffed full of rain water from freezing. If the > icing is bad enough that it freezes over a warm-to-very warm > pitot, I've got bigger problems that a red hot pitot won't solve. > Since no ideas have been tossed out, I wonder if there is an > efficient means of cycling the pitot heater on/off at some > interval, such as on for 30 seconds, off for two minutes. This > would reduce the total current draw if a person was in the soup, > lost electrical and needed whatever extra time available to get to > safety but didn't dare to turn off the pitot in marginal icing > conditions. > Chuck Jensen > * * > -----Original Message----- > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf > Of *Keith Hallsten > *Sent:* Monday, December 04, 2006 10:36 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: RE: Pitot Current Draw > > Chuck, > > I mounted a 28v Known Ice pitot on the nose of my Velocity. > Since I have a 14 volt electrical system, its power consumption > will be reduced by a factor of 4 (power = V * V / R). I figure > that is sufficient for my purposes, because a Velocity is NOT a > Known Ice type of airframe. If I should find enough ice to > overwhelm my lightweight pitot heating system, I have bigger > problems than the pitot. Im not flying yet, but thats my > position for now. > > Actually, now that we all have GPS available to us, loss of pitot > is not as critical as it used to be. With a fat margin to allow > for wind, flying by groundspeed is generally a fair approximation. > > Regards, > > Keith Hallsten > > > *Subject:* */ RE: Pitot Current Draw/* > *From:* */ Chuck Jensen/** (**/_cjensen(at)dts9000.com_/* > *)* > > *Date:* */ Mon Dec 04 - 12:06 PM/* > *Wow, I must be hard-of-speaking (or writing). I concede that flying* > > *into icing when not so equipped is not a good idea, but if a person* > > *flies IFR in the winter most anywhere in the continental US, > sooner or* > > *later, they'll pick up some ice. Even if my wings start looking like* > > *something that should be used to cool a gin and tonic, I don't > want to* > > *lose air speed indication. Granted, I may not know what my new stall* > > *speed is, but I would like to know WHAT my speed is...and I can't do* > > *that with a pitot full of ice. * > > *So, the question on the table is still the same, is there a way off* > > *'turning down the heat' and reducing current draw? * > > *Chuck Jensen* > > >* > >href="http://www.aeroelectric.com">www.aeroelectric.com >href="http://www.buildersbooks.com">www.buildersbooks.com >href="http://www.kitlog.com">www.kitlog.com >href="http://www.homebuilthelp.com">www.homebuilthelp.com >href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > >* > >* > >href="http://www.aeroelectric.com">www.aeroelectric.com >href="http://www.buildersbooks.com">www.buildersbooks.com >href="http://www.kitlog.com">www.kitlog.com >href="http://www.homebuilthelp.com">www.homebuilthelp.com >href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > >* > >* > >href="http://www.aeroelectric.com">www.aeroelectric.com >href="http://www.buildersbooks.com">www.buildersbooks.com >href="http://www.kitlog.com">www.kitlog.com >href="http://www.homebuilthelp.com">www.homebuilthelp.com >href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > >* > >* > > >* > ________________________________________________________________________________
Date: Dec 10, 2006
Stan, You are correct, I was having some fun expressing my view that in my opinion this issue as a builder or flyer is not something worth pursuing. For the real down and dirty instrument flyer this issue just over complicates the business of flying safe to save a few amps. A simple point, a pitot heat system is a safety item much like a fire extinguisher (KISS). I have a different philosophy then many on this site but not all. I answer questions using a strait forward set of rules meeting My basic philosophy. I work towards putting things into the field that work and can be maintained buy the builder. My work goes directly to the builder who is working to get a complete project into the air that is safe, maintainable, reliable, and cost effective both in time and money. But I do respect the more micro of you folks on this board. Without your work and ideas we would not have the wonderful opportunities we have today. So we coexist. My main focus in aviation is safety of operation, both in maintenance and flight. Mike Larkin ----- Original Message ----- From: Speedy11(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Friday, December 08, 2006 10:44 PM Subject: AeroElectric-List: Re: Pitot Current Draw Mike Larkin, I don't mean to be sarcastic, but you didn't answer any questions - at least any questions that had been asked. Chuck asked about how to wire his pitot heat so as to have the option to cycle from low heat to high heat. I don't agree with Chuck regarding the wisdom of using a lower heat setting to save power in IMC icing conditions if the alternator fails, but his question is not, "Should I use a lower heat setting?" His question is, "How do I wire so to obtain my choice of heat settings?" We all have personal stories to tell. They aren't relevant to Chuck's question unless they are related to how one wires one's electrical system to obtain high-low pitot heat. My personal philosophy regarding icing conditions in SE piston powered aircraft is exactly the same as yours. But, my philosophy about flying in icing conditions is not relevant to Chuck's question. The only answer or opinion that Chuck wants is the one that describes to him how to wire his electrical system to permit high and low pitot heat settings. We have to leave it to him to decide if such a system is adequate and if it is wise to employ it in icing conditions. Regards, Stan Sutterfield ________________________________________________________________________________
Date: Dec 10, 2006
From: =?ISO-8859-1?Q?Andr=E9_Beusch?= <andre.beusch(at)bluewin.ch>
Subject: Garmin GNS430 Nav board repaired twice
I have a Garmin GNS430 in my Glasair Super II. The comm is connected to a dipole antenna in the vertical stabilizer, the nav is connected directly (no splitter) to the dipole antenna in the horizontal stabilizer. Both are the antennas that were provided by Stoddard Hamilton, the kit manufacturer, and were installed as per the instruction manual. The antennas perform well. Both times, the VOR/LOC lost 30 dB of sensitivity, apparently the input stage was destroyed. The first repair cost me about $1000, the second was warranty. I wonder if someone had this problem with any kind of nav receiver. Garmin said that it could have been overloaded by the comm transmission because the antennas are to close to each other. (they don't say anything about this in the installation manual) Many people use a splitter for NAV/glideslope, so their receiver gets less signal and would perhaps not be exposed to this problem. As an electronics engineer, I'd like to understand this and will make a measurement of the power that actually gets in the Nav receiver. I have a 250 MHz oscilloscope for that. This nav receiver should pass RTCA DO-196, if someone has these documents handy, I'd be interested to see what the damage input power should be. I also consider putting a 6dB attenuator or an RF limitter on the Nav antenna input. Any opinions? Thanks, --Andre Beusch ________________________________________________________________________________
Date: Dec 09, 2006
Thanks, Bob. I'd never heard that term before. Didn't know about the Tripacers either and I owned one! Stan Sutterfield "Cockpit referenced" is a specific term for "vented to cockpit atmosphere" . . . which is what the vast majority of alternate static sources do. The piper Pacer and Tri-Pacer didn't have static systems. The altimeter was simply mounted to the panel and vented to cockpit as was any VSI and/or altitude encoders added at later dates. Bob ________________________________________________________________________________
Subject: GNS430 VLOC/GPS wiring
Date: Dec 11, 2006
A friend has a GNS430 with an HSI in his RV8A. He's starting to train for IFR in it. When he switches from VLOC to GPS tracking the HSI does not switch to track the GPS waypoint. It continues to track the VOR or Localizer. Is this a wiring issue? ________________________________________________________________________________
Date: Dec 11, 2006
Subject: Re: GNS430 VLOC/GPS wiring
It doesn't sound like wiring to me?? There are a number of 'configuration' menus that make everything work. I would talk to a quailfied avionics shop, Garmin or the company that made the HSI and see what they think? Regards, Bob in SE Iowa On 12/11/06, Eric Parlow wrote: > > A friend has a GNS430 with an HSI in his RV8A. > He's starting to train for IFR in it. > > When he switches from VLOC to GPS tracking the HSI does not switch to track > the GPS waypoint. > It continues to track the VOR or Localizer. > Is this a wiring issue? > > ________________________________________________________________________________
Date: Dec 11, 2006
Subject: Cherokee Panel Standard Six Pack Conversion
Ladies and Gents,=0A=0AI have my eye on an older Cherokee 180 (1963) with t he older instrument layout common to that vintage. Wondering if anyone has any experience converting that layout to the standard "six pack" via a cer tified repair station. I know this has been done many times on other aircr aft and in this case all the instruments are in place, but they are in the wrong places. How much would this change cost (ballpark) ?=0A=0AThanks!=0A Rich ________________________________________________________________________________
Subject: Z-13 v. SD-8 distribution Diagrams
Date: Dec 11, 2006
I'm in the process of wiring up the SB005-1 (S704-1?) relay with the SD-8 volt regulator and the OVM. The SD-8 distribution diagram (Dwg 504-500 rev E, 9/29/04) seems to differ from the Z-13 diagram and I'm wondering which to follow. Dwg. 504-500 refers to the relay as SB005-1, and elsewhere, it looks like the part number is S704-1. I'm not sure if these are one in the same or not. The photo at http://www.bandc.biz/S704-1_tips.html is even different and includes an additional diode installed where the OVM-14 should be installed. Anyone have a good diagram or guidance on which drawing is correct? I'm thinking that Z-13 may be the correct drawing for the application. Jim -7 Wiring ________________________________________________________________________________
Date: Dec 11, 2006
Subject: Re: Cherokee Panel Standard Six Pack Conversion
Rich, I have a 1963 Comanche which had the old "Shotgun" instrument array. I had it redone in a modern sixpack with a radio stack, full IFR. Made my own padded leather panel covers. That was in 1990. I recall about $10,000. Well worth it. LRE ________________________________________________________________________________
Date: Dec 11, 2006
On 11 Dec 2006, at 01:01, Eric Parlow wrote: > > > A friend has a GNS430 with an HSI in his RV8A. > He's starting to train for IFR in it. > > When he switches from VLOC to GPS tracking the HSI does not switch > to track the GPS waypoint. > It continues to track the VOR or Localizer. > Is this a wiring issue? Which make and model HSI? Is this one of the HSIs that is covered in the GNS400 Series Installation Manual? Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Dec 12, 2006
12/12/2006 Hello Andre, I am trying to better understand your antenna connections. You wrote: "The comm is connected to a dipole antenna in the vertical stabilizer, the nav is connected directly (no splitter) to the dipole antenna in the horizontal stabilizer." The GNS 430 box has two separate inputs for VHF nav and glide slope. As you say this is frequently done by using one VHF nav antenna and then splitting that input just before it enters the GNS 430 box. When you say that your nav is connected directly (no splitter) to the antenna does that mean that you are also feeding the glide slope input directly from some separate glide slope antenna? What is the status of the unit now? You have it back repaired and are not using it for concern over damaging it again with comm transmissions or ---? Comant industries has a wide array of couplers that you might consider using to combine and or split inputs to your GNS 430 from nav / glide slope antennas in order to protect the input stages from excessive comm transmission inputs. http://www.comant.com/home.cgi?ua=sgroup&crit=Couplers/Diplexers/Combiners OC > From: =?ISO-8859-1?Q?Andr=E9_Beusch?= <andre.beusch(at)bluewin.ch> > Subject: Avionics-List: Garmin GNS430 Nav board repaired twice > > > I have a Garmin GNS430 in my Glasair Super II. > The comm is connected to a dipole antenna in the vertical stabilizer, > the nav is connected directly (no splitter) to the dipole antenna in the > horizontal stabilizer. > Both are the antennas that were provided by Stoddard Hamilton, the kit > manufacturer, and were installed as per the instruction manual. The > antennas perform well. > Both times, the VOR/LOC lost 30 dB of sensitivity, apparently the input > stage was destroyed. > The first repair cost me about $1000, the second was warranty. > I wonder if someone had this problem with any kind of nav receiver. > Garmin said that it could have been overloaded by the comm transmission > because the antennas are to close to each other. > (they don't say anything about this in the installation manual) > Many people use a splitter for NAV/glideslope, so their receiver gets > less signal and would perhaps not be exposed to this problem. > As an electronics engineer, I'd like to understand this and will make a > measurement of the power that actually gets in the Nav receiver. I have > a 250 MHz oscilloscope for that. > This nav receiver should pass RTCA DO-196, if someone has these > documents handy, I'd be interested to see what the damage input power > should be. > I also consider putting a 6dB attenuator or an RF limitter on the Nav > antenna input. > > Any opinions? > > > Thanks, --Andre Beusch ________________________________________________________________________________
Date: Dec 12, 2006
Subject: RE: Pitot Current Draw
> >Geeez, I guess that's why I ask electrical questions. Now that I think >about it, it makes sense...size does matter. > >Chuck Jensen > > >Bob W. wrote... > >Shorten the element if you would like MORE heat, lesson I learned as a >teenager. I had a piece of nichrome wire that I wanted to get red hot. >(I have no memory of what I was trying to do other than that.) I >stretched the wire out and clamped on an electric cord I could plug into >the wall. It got a little hotter than I wanted. Well, I knew ohms law >and I knew P=I^2*R so the obvious solution was to cut R in half to get >half power. When I plugged it in, that sucker got white hot so fast I >didn't have time to blink. Haven't had much trouble keeping ohms law >straight since. :) Pitot tube heaters are not like those used in your toaster. See: http://tinyurl.com/yyuted The heater wires are wound on a flexible mandrel contained within the "tube" visible in these pictures. The winding pitch is varied so as to put optimized heat sources at various places throughout the pitot-tube structure. Lots of heat in the probe, not so much around the corner, lots more in the mast. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: Jabiru Starter contactor and solenoid
Subject: AeroElectric-List: Jabiru Starter contactor and solenoid I have a Jabiru 3300 and have a 702-1 starter contactor from B&C. Looking at Z-20, from aeroelectric, they are running the 4 AWG wire to the starter solenoid. It looks like the "solenoid" supplied by Jabiru is really just another contactor. It is wired and works the same as the 702-1 but with out the diode. If I hook it up as depicted in Z-20 all I will be doing is to energize the coil on the Jabiru supplied solenoid with the 4 AWG wire from the 702-1. It sure looks to me that all I will be doing is putting two contactors in series. I am not sure of the value in this. I am considering just leaving off the Jabiru solenoid and connecting the 702-1 directly to the starter. Is this smart or is there something I am missing? First, the Z-figures are ARCHITECTURE drawings and not intended to dictate wire sizes, breaker/fuse sizes, or equipment choices. They are simply foundations upon which your own system details are laid. The apparent "dual starter contactors" anomaly you've cited is discussed in the article at: http://aeroelectric.com/articles/strtctr.pdf Depending on what features are specific to the starter supplied with your Jabiru, the specifics illustrated in Z-20 may not apply. If your existing starter is fitted with the hi-inrush, pinion engagement mechanism typical of B&C starters, then the "dual contactor" philosophy -or- the Starter Boost relay shown in Z-22 is recommended to enhance the service life of your starter push button or switch. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Conversion to Experimental
> >---------- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chuck >Jensen >Sent: Tuesday, December 12, 2006 5:13 AM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Conversion to Experimental >In reading about conversion of six-packs and upgrading panels in older >planes, et al, if a person wants to upgrade to a glass panel, is there a >reason more people don't just slap an "Experimental" label on the >certified plane and put in a non-certified panel, such as GRT, TruTrak, et >al. It's understood that the plane is devalued by making it >"Experimental" but then, the value is also increased with the upgraded >panel. And, with the difference between a certified glass panel and a >very good, but non-certified glass panel, you can stick the difference >($30,000 - $50,000?) in your pocket and buy a lot of gas. > >Since it doesn't seem to be done by many people, I must be missing something? Yeah, it's called the FAA. I've placed many an x-ticket on a certified ship for the purpose of conducing engineering research. But the FAA's stance x-ed TC aircraft for the purpose of conducing engineering tests and the airplane cannot be used as a standard TC aircraft until restored to certified condition. We have a small fleet of experimental aircraft used for research and development but these aircraft cannot be used for anything except company engineering business. The "experimental" tag on OBAM aircraft gives rise to a lot of mis-understanding. 99% of the OBAM aircraft flying are obviously not experimental but Owner Build and/or Maintained. In Canada, you can de-certify an older out-of- production aircraft and begin to own, operate, modify and maintain it as if it were an RV or Kitfox. These aircraft are far from "experimental" in the engineering and development sense of the word. The owners are simply attempting to breath new life into older airplanes by modernizing some of its features. Converting an older airplane to a new 6-pack or glass-panel configuration is often done by qualified shops under a 337. The gentleman who initially inquired about this can enlist the help of an AI, local flying-fuzz and install any new gear and panel arrangements that have been used on other aircraft with no more than the usual bureaucratic difficulties. It's done all the time. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
From: =?iso-8859-1?Q?Mich=E8le_Delsol?= <michele.delsol(at)microsigma.fr>
Date: Dec 12, 2006
I've been using the Rhyno 5000 - I find that I have to be really careful on printing the labels - many in a single pass so as not to minimize waste. The yellow heat shrink tubes are really expensive and if not careful, one can go through them at a pace which makes the labels a significant cost item. For that matter, it is much like colour printers - cheap printer but you get whacked on the cartridges. This being said, I find the Rhyno a great product and time saver. Michele RV8 - Finishing -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fergus Kyle Sent: dimanche 10 dcembre 2006 16:06 Subject: AeroElectric-List: DYMO RhinoPRO3000 label writer I looked it up as suggested and believe it's useful BUT the price of heat shrink comes out to about $5 a foot, or perhaps 75cents a label (mistakes excepted). Rolls come in 5 foot lengths. Any- body find better source? Ferg Kyle Europa A064 914 Classic ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: Conversion to Experimental
Robert L. Nuckolls, III wrote: In Canada, you can de-certify an older out-of- production aircraft and begin to own, operate, modify and maintain it as if it were an RV or Kitfox. I'm wondering if this 'de-certified' aircraft can then be moved to the US and that designation remains? If so, perhaps I can take my 'ol C-150 up there for a visit and upgrade?? ________________________________________________________________________________
Subject: New Topic! Wire label-making machines
Date: Dec 12, 2006
Affirmative - it does grip 22 with the smallest heat shrink tube they have. I've done it. Michele RV8 - Finishing -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Boyd Sent: dimanche 10 dcembre 2006 01:24 Subject: Re: AeroElectric-List: New Topic! Wire label-making machines They apparently sell some rather pricey heat shrink for it. 1/2, 3/8 and 1/4 inch flat widths. Is any of that going to grip a 22ga wire very well? I'm interested in this technology, but want to know more before I buy any new toys. -Bill B On 12/9/06, sarg314 wrote: > > This outfit has the rhinopro 3000 for $65. Says it prints on heat shrink. > > >http://www.provantage.com/dymo-15605~7DYMO02H.htm > > > > ________________________________________________________________________________
Date: Dec 12, 2006
To all, Rick was right on the money. If and when you convert an airplane=92s airworthiness from Standard to Experimental many things change. The first issue is what type of Experimental Certificate will you apply for and be approved for? In order to convert an airplane you must have a new Airworthiness Certificate issued which will be accompanied by a list of Limitations for operation. The list of limitations are covered by Advisory Circulars which are generally not regulatory for part 91 operations but the limitations issued with the new airworthiness certificate will change that. The list of limitations issued are derived from the AC=92s that cover these types of conversions. There is some latitude with these limitations but you never know until you do it. Unless you get an FAA inspector or DAR if authorized to issue an Experimental Exhibition Certificate (many are not) to cope a previously issued set of limitations without question, you will be subjected to their interpretation of the AC=92s in question. As for valuation, that is very subjective. If you take a new $1,000,000 Baron and are able to convert it to an Experimental certificate I would think you would loose as much as 75% or more of the original value due to the new limitations and insurance issues. But if you take an old Cherokee 140 and upgrade it with a bigger engine, new glass panel, IR video, ect. The overall selling amount would improve but would most likely not cover the cost of the improvements and therefore the value would remain close to the same.. Here is a different view, what if you bought an old Cherokee 140 for $10,000 with an old panel and run out engine. Your good with you hands and can do good work that an A&P would like. Let=92s assume that you were able to convert the aircraft Certification to Experimental Exhibition with very relaxed limitations. You and you=92re A&P friend overhaul the engine, repair cracks, corrosion, broken parts (for example: door handles, head liners, switches, lighting, seats), up graded the avionics to a new glass panel, and certify during the condition inspection the aircraft airworthy. You would be able to do this any way you would like within the scope of the newly issued limitations. If you had to do this with a Standard Airworthiness Certificate this could be cost prohibitive if you had to meet part 43 with a $10,000 airplane that is only worth $20,000 in good condition with a Standard Certificate. This example would be one reason I would consider a conversion to Experimental. But as mentioned above you would have to have a good handle on the re-certification process or one might find them selves with a 1500 pound paper weight at the end of the day. Mike Larkin -- 11/22/2006 -- 11/22/2006 ________________________________________________________________________________
Date: Dec 12, 2006
From: =?windows-1252?Q?Andr=E9_Beusch?= <andre.beusch(at)bluewin.ch>
Subject: Re: Garmin GNS430 Nav board repaired twice
> > When you say that your nav is connected directly (no splitter) to the > antenna does that mean that you are also feeding the glide slope input > directly from some separate glide slope antenna? Yes, one antenna for VOR in the horizontal stabilizer, and one for the GS, on the floor behind the baggage compartment. > > What is the status of the unit now? You have it back repaired and are > not using it for concern over damaging it again with comm > transmissions or ---? I have disconnected the VOR antenna. I will install either a 6 dB attenuator or an rf limiter and hope it will not happen again. > > I have now measured the voltage across a 50 Ohms terminator at the VOR antenna connector when transmitting with the GNS430 com (no modulation). The maximum measured voltage in the com frequency range was about 3.5 Vpp (at 123 MHz), which equals to 1.24 Vrms. That is 14.9 dBm, at 50 Ohms a power of 31mW. The peak power at 70 % modulation would be 87 mW. (19.4 dBm) I don't know the spec of the GNS430 nav receiver, but IMO, this level should not be destructive. --Andre ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: Firewall penetration
I saw Bob's idea and may adopt some of that, but then I think about the rather large holes for the rudder bars to the nose wheel steering and I'm stumped. My plane is a Zenith Zodiac and it looks impossible to keep a fuel fed fire from blasting right in. Not a pleasant thought. Cleone At 12:21 PM 12/9/2006, you wrote: > >Thanks Glen - That's perfect - just what I was looking for. :) > >Don Owens > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p409#80409 > > ________________________________________________________________________________
Date: Dec 12, 2006
> > I saw Bob's idea and may adopt some of that, but then I think about > the rather large holes for the rudder bars to the nose wheel steering > and I'm stumped. My plane is a Zenith Zodiac and it looks impossible > to keep a fuel fed fire from blasting right in. Not a pleasant thought. Older airplanes with such big rods did with sliding covers riding on the rods and sliding against the FWL, or resorted to non-fire "socks", made of leather for instance. This way movement is allowed without letting gas or flame pass. Why not have a try ? We have a Zenith in the hangar, and indeed the firewall is as gas tight as a sieve...And once we even found the bars buckled. For variation on Bob's theme and suitable putty, I gathered some info here : http://contrails.free.fr/engine_cpf.php Regards, Gilles Thesee Grenoble, France http://contrails.free.fr ________________________________________________________________________________
Date: Dec 12, 2006
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
On the Zodiac you have two areas like that. One is the nose wheel rods the other is the throttle rod penetrations, Neither of them are easy to seal. Frank Zodiac 400 hours RV7a 52hours -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Cleones Sent: Tuesday, December 12, 2006 10:43 AM Subject: Re: AeroElectric-List: Re: Firewall penetration I saw Bob's idea and may adopt some of that, but then I think about the rather large holes for the rudder bars to the nose wheel steering and I'm stumped. My plane is a Zenith Zodiac and it looks impossible to keep a fuel fed fire from blasting right in. Not a pleasant thought. Cleone ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Safe cabin heater
>Date: Tue, 12 Dec 2006 12:42:51 -0600 > >From: Cleone <cleone(at)rr1.net> >Subject: Re: AeroElectric-List: Re: Safe cabin heater? As Bob said at least once, "people on this list are worried about everything" or something close to that. In my mail today was an advertisement about a new advanced quartz infrared portable heater. It reminded my of a small unit that the office girls were using in a local office to keep their feet and legs warm. They said it really worked. This company claims more than I can believe but is it worth looking into? www.edenpure.com I have survived over 5000 hours of flying exhaust type heaters and like a lot of people have been concerned. ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: Safe cabin heater
Cleones wrote: > This company claims more than I can believe but is it worth looking > into? www.edenpure.com > This is one sponsor of Paul Harvey. I believe it would work fine in a residence... were you thinking in an aircraft? Earl ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: DYMO RhinoPRO3000 label writer
Michele: Do you have to use a special type of heat shrink, or will any old type work? Michle Delsol wrote: > >I've been using the Rhyno 5000 - I find that I have to be really careful on >printing the labels - many in a single pass so as not to minimize waste. The >yellow heat shrink tubes are really expensive and if not careful, one can go >through them at a pace which makes the labels a significant cost item. For >that matter, it is much like colour printers - cheap printer but you get >whacked on the cartridges. This being said, I find the Rhyno a great product >and time saver. > >Michele >RV8 - Finishing > > > > ________________________________________________________________________________
Date: Dec 12, 2006
On 12 Dec 2006, at 10:53, Earl_Schroeder wrote: > > > Robert L. Nuckolls, III wrote: > > In Canada, you can de-certify an older out-of- > production aircraft and begin to own, operate, modify and > maintain it as if it were an RV or Kitfox. > > I'm wondering if this 'de-certified' aircraft can then be moved to > the US and that designation remains? > > If so, perhaps I can take my 'ol C-150 up there for a visit and > upgrade?? > Nope, once an aircraft is moved to the Owner Maintenance category, you can't even cross the border into the US. The Owner Maintenance category is not recognized by ICAO, so it is not recognized by any other country. Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Dec 12, 2006
Bob is correct in his interpretation of Canadian regulation, but in answer to your question, my understanding is NO! And not only that, but the FAA has apparently also decided that planes which have followed this procedure are no longer even allowed to fly into the US at all, even when still registered in Canada and flown by a Canadian pilot. There are no such exclusions on Canadian OBAM aircraft which are welcomed across the border with very little hassle. Go figure. This fact has put a considerable damper on the desirability of this conversion. Also under Canadian law, once the plane has been de-certified under this rule it is then ineligible to ever be converted back into the TC category. Bob McC Toronto, Canada ----- Original Message ----- From: "Earl_Schroeder" <Earl_Schroeder(at)juno.com> Sent: Tuesday, December 12, 2006 10:53 AM Subject: Re: AeroElectric-List: Conversion to Experimental > > Robert L. Nuckolls, III wrote: > > In Canada, you can de-certify an older out-of- > production aircraft and begin to own, operate, modify and > maintain it as if it were an RV or Kitfox. > > I'm wondering if this 'de-certified' aircraft can then be moved to the > US and that designation remains? > > If so, perhaps I can take my 'ol C-150 up there for a visit and upgrade?? > > ________________________________________________________________________________
Date: Dec 12, 2006
Subject: Re: quiet
Got your message Rob...too many folks out in their shops building I guess! Wish I were one of them! LOL!=0A=0A=0A----- Original Message ----=0AFrom: Rob Wright =0ATo: rv10-list(at)matronics.com; Rob Wr ight ; aeroelectric-list(at)matronics.com=0ASent: Tu esday, December 12, 2006 6:50:09 PM=0ASubject: AeroElectric-List: quiet=0A =0A=0AI don=A2t normally see so little activity on the list or in my inbox, so here=A2s a test email. My service has migrated some of its services an d I don=A2t trust it yet.=0A =0ARob Wright=0ARV-10 Fuse=0A =0ADo not archiv ======== ________________________________________________________________________________
Date: Dec 13, 2006
Kelly McMullen wrote: > Experimental Exhibition, limited to flying to airshows, exhibitions, etc > which have to be reported, may be restricted, no flight over congested > areas, etc. Probably prohibits pax beyond "required" crew as well. > "Limited" is a subjective term in this case. First, you're given a practice area that is something line 100 mile radius or so. The category includes a lot of fast airplanes, and the pilots really do need a large area to practice for proficiency. This is actually a good provision. Then at the beginning of each year, you tell the FAA all the flyins that you might want to attend. No need to restrict yourself, just tell them you might want to go to all of 'em. There's also no penalty if you don't quite make it there and have to stop somewhere short of the destination. Finally, for the most part, there is no restriction on passengers just for it being an exhibition plane. I've heard that the FAA is cracking down on this category, but historically the restrictions have been a paper tiger. You can pretty much do whatever a normal GA pilot would do, you just have to take a couple more steps to cover your tracks. ________________________________________________________________________________
Date: Dec 12, 2006
At 08:21 PM 12/12/2006, you wrote: > > >And I live in New Jersey and have a bridge for sale cheap near New York... >Does this "work"? Yes, it puts out heat - the exact same amount any >other electric heater of the same wattage does. It might be safer >than other heaters if it really operates at a lower temperature, but >a watt is a watt. > >It wouldn't even "work" in your airplane because it requires 120V, not 12V. If you want to stay warm with a 12v electrical system, look into electric snowmobile pants and jackets. -- ________________________________________________________________________________
Date: Dec 12, 2006
Or look at heated seat inserts here http://www.classicaerodesigns.com/web/public/Products/ProductDetail.asp?Prod uctID=37&ProductCategory=Accessories&ProductCategoryID=1 Or use motorcycle clothes that plug into 12 volt accessory outlet, very warm. Very low power consumption because its close to your skin and covered by your outer clothes. Bevan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Riley Sent: Tuesday, December 12, 2006 9:27 PM Subject: Re: AeroElectric-List: Safe cabin heater --> At 08:21 PM 12/12/2006, you wrote: > > >And I live in New Jersey and have a bridge for sale cheap near New York... >Does this "work"? Yes, it puts out heat - the exact same amount any >other electric heater of the same wattage does. It might be safer than >other heaters if it really operates at a lower temperature, but a watt >is a watt. > >It wouldn't even "work" in your airplane because it requires 120V, not 12V. If you want to stay warm with a 12v electrical system, look into electric snowmobile pants and jackets. -- ________________________________________________________________________________
Date: Dec 12, 2006
At 01:09 AM 12/13/2006, you wrote: >Then at the beginning of each year, you tell the FAA all the flyins >that you might want to attend. No need to restrict yourself, just >tell them you might want to go to all of 'em. There's also no >penalty if you don't quite make it there and have to stop somewhere >short of the destination. You can also update your list at any time. Like, for instance, the night before you fly off across country, you fax them an update to include your cross country proficiency flight. -- ________________________________________________________________________________
Date: Dec 13, 2006
You have to use the Rhyno 5000 cartridges - they come as yellow tubing which has been flatened in several sizes. Michele -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of sarg314 Sent: mercredi 13 dcembre 2006 02:01 Subject: Re: AeroElectric-List: DYMO RhinoPRO3000 label writer Michele: Do you have to use a special type of heat shrink, or will any old type work? Michle Delsol wrote: > >I've been using the Rhyno 5000 - I find that I have to be really careful on >printing the labels - many in a single pass so as not to minimize waste. The >yellow heat shrink tubes are really expensive and if not careful, one can go >through them at a pace which makes the labels a significant cost item. For >that matter, it is much like colour printers - cheap printer but you get >whacked on the cartridges. This being said, I find the Rhyno a great product >and time saver. > >Michele >RV8 - Finishing > > > > ________________________________________________________________________________
Subject: RE: Safe cabin heater
Date: Dec 13, 2006
Hi All- >It wouldn't even "work" in your airplane because it requires 120V, not 12V. IIRC, the Vari-eze crowd was installing 12V ceramic heaters to keep their toes alive in the winter. Sorry, I don't recall any specifics, but I think that those who employed this technology were happy with it. Then again, they WERE in plastic airplanes... ; - ) glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Dec 13, 2006
Just curious... Does the 3000/5000 shrink tubing come rolled up into a special cartridge along with an ink tape - or do you feed the flattened tubing in separately? Has anyone experimented with flattening "regular" heat shrink tubing and then trying to print/label on it? I think I even have some white "regular" tubing that came flattened. Does anyone with a 3000 or 5000 have a picture of the tubing before printing/cutting? How long is the flattened tubing before printing/cutting? Is there any "leader" on it? Is there any waste at the ends when printing? How do the small sizes stay centered when printing? Rick ________________________________________________________________________________
Date: Dec 13, 2006
Given the many postings about all the hurdles to conversions, one comes away with the over-mastering impression that the FAA is THE hurdle. Not that it's unsafe, unwise or stupid, but it's a bad idea because the FAA says so. I can understand the FAA being control freaks for commercial aviation--a lot of traveling people are involunatarily putting themselves in situation out of their control and they deserve protection from unscrupulous, unsafe operators. Whether the FAA accomplishes that or not, some may argue with, but the intent is clear. But as we step down the aviation food chain, why the FAA feels the need to obsess over control of personal aircraft is less understandable. Is it so outrageous an idea that if someone wants to put 6" letters EXPERIMENTAL on an aircraft, that they shouldn't have great leeway in what they do...much as the OBAM does? Owning a C150 that was not owner built and is subsequently converted to Experimental is no different than owning an RV that was built by someone else. Both have to be inspected by an A&P. How is one more, or less, safe than the other? With that said, and given the personality of the FAA, I stand amazed (and thankful) that the 51% rule was reviewed and the repercussions seem to have been minimal--to date. This initially looked very much like the proverbial 'camel's nose under the tent' problem, but the FAA seemed to show considerable restraint in reining in the most egregious examples that were pushing the boundaries without going on a boundless witch hunt. Gads, if only the world were perfect!! Chuck Jensen ________________________________________________________________________________
Date: Dec 13, 2006
Subject: Re: RE: Safe cabin heater
The only 28v VariEz I worked on was for a builder in Canada who wanted to fly in the wintertime . . . and wanted to use all-electric heat. We put a 28v, 100A alternator on the airplane. About 5A of that was used to run the airplane, 80+ amps were used to heat the cabin. Most of the "toe warmers" offered by suppliers to OBAM aircraft were selling 300W fan-heaters. This guy built a 2200 watt fan heater and reported "usable" performance for all but the coldest days but even this boss hog heater was too small until he spent a lot of time sealing the cockpit. Bob . . . > > > >Hi All- > > >It wouldn't even "work" in your airplane because it requires 120V, not 12V. > >IIRC, the Vari-eze crowd was installing 12V ceramic heaters to keep their >toes alive in the winter. Sorry, I don't recall any specifics, but I think >that those who employed this technology were happy with it. Then again, >they WERE in plastic airplanes... ; - ) > >glen matejcek >aerobubba(at)earthlink.net > > >-- >12/11/2006 4:32 PM > > >-- incoming mail is certified Virus Free. >Checked by AVG. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 13, 2006
Can't you still buy 12V hair dryers that the trailer campers used to use...? Obviously, sealing the airframe is a prerequisite....... -----Original Message----- >From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> >Sent: Dec 13, 2006 9:46 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: RE: Safe cabin heater > > >The only 28v VariEz I worked on was for a builder in Canada who >wanted to fly in the wintertime . . . and wanted to use all-electric >heat. We put a 28v, 100A alternator on the airplane. About 5A of >that was used to run the airplane, 80+ amps were used to heat the >cabin. Most of the "toe warmers" offered by suppliers to OBAM aircraft >were selling 300W fan-heaters. This guy built a 2200 watt fan heater >and reported "usable" performance for all but the coldest days but >even this boss hog heater was too small until he spent a lot of time >sealing the cockpit. > >Bob . . . > > >> >> >> >>Hi All- >> >> >It wouldn't even "work" in your airplane because it requires 120V, not 12V. >> >>IIRC, the Vari-eze crowd was installing 12V ceramic heaters to keep their >>toes alive in the winter. Sorry, I don't recall any specifics, but I think >>that those who employed this technology were happy with it. Then again, >>they WERE in plastic airplanes... ; - ) >> >>glen matejcek >>aerobubba(at)earthlink.net >> >> >> >> >> >> >> >> >> >>-- >>12/11/2006 4:32 PM >> >> >> >>-- incoming mail is certified Virus Free. >>Checked by AVG. > > > Bob . . . > > > --------------------------------------------------------- > < What is so wonderful about scientific truth...is that > > < the authority which determines whether there can be > > < debate or not does not reside in some fraternity of > > < scientists; nor is it divine. The authority rests > > < with experiment. > > < --Lawrence M. Krauss > > --------------------------------------------------------- > > ________________________________________________________________________________
Date: Dec 13, 2006
From: "Charles Kaluza" <charleskaluza(at)verizon.net>
Subject: Alternate feed to Lightspeed
We have 360 hours on our RV6A with one mag and the Lightspeed II unit which has worked well. We have had one kickback when starting on the Lightspeed with a low battery. Spoke with Klaus about using my backup battery as an additional power source for the unit. He thought it would be fine as long as I used a Shottky diode (90SQ030) to prevent back feed from the auxiliary battery to the main. The engine starts better on the Lightspeed but we have been starting on the mag since the kickback. I am debating using power from the E-Bus which I have activated during start vs. running the Aux. power direct from the Aux. battery. The second option would allow better charging of the Aux. battery. I worry about excess current flow if the Aux. battery is low causing the 5 amp fuse on the Lightspeed to blow. Any advice? The Aux. battery is currently charged through my Rocky Mountain monitor. Thanks for the help. Kaluza ________________________________________________________________________________
Date: Dec 13, 2006
At 12:43 AM 12/13/2006, you wrote: > >Or look at heated seat inserts here >http://www.classicaerodesigns.com/web/public/Products/ProductDetail.asp?Prod >uctID=37&ProductCategory=Accessories&ProductCategoryID=1 > >Or use motorcycle clothes that plug into 12 volt accessory outlet, very >warm. Very low power consumption because its close to your skin and covered >by your outer clothes. > >Bevan >Thanks to all who have made comments. I will stop in a motorcycle >shop and see just what the power consumption is at the first >opportunity. If they can keep their toes from getting frostbitten I >won't make a heoric effort to close up every leak in the >cabin. Ha. Cleone PS; Wonder what an 82 year old would look like >in leather.? >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard >Riley >Sent: Tuesday, December 12, 2006 9:27 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Safe cabin heater > >--> > >At 08:21 PM 12/12/2006, you wrote: > > > > > > >And I live in New Jersey and have a bridge for sale cheap near New York... > >Does this "work"? Yes, it puts out heat - the exact same amount any > >other electric heater of the same wattage does. It might be safer than > >other heaters if it really operates at a lower temperature, but a watt > >is a watt. > > > >It wouldn't even "work" in your airplane because it requires 120V, not 12V. > >If you want to stay warm with a 12v electrical system, look into electric >snowmobile pants and jackets. > > >-- > > ________________________________________________________________________________
Date: Dec 13, 2006
And furthermore, is there a better printer out there that some are using to mark shrink tubing? Don Owens Just curious... Does the 3000/5000 shrink tubing come rolled up into a special cartridge along with an ink tape - or do you feed the flattened tubing in separately? Has anyone experimented with flattening "regular" heat shrink tubing and then trying to print/label on it? I think I even have some white "regular" tubing that came flattened. Does anyone with a 3000 or 5000 have a picture of the tubing before printing/cutting? How long is the flattened tubing before printing/cutting? Is there any "leader" on it? Is there any waste at the ends when printing? How do the small sizes stay centered when printing? Rick -- 11:49 AM ________________________________________________________________________________
Date: Dec 13, 2006
Subject: Re: Alternate feed to Lightspeed
>We have 360 hours on our RV6A with one mag and the Lightspeed II unit >which has worked well. We have had one kickback when starting on the >Lightspeed with a low battery. Spoke with Klaus about using my backup >battery as an additional power source for the unit. He thought it would >be fine as long as I used a Shottky diode (90SQ030) to prevent back feed >from the auxiliary battery to the main. The engine starts better on the >Lightspeed but we have been starting on the mag since the kickback. > >I am debating using power from the E-Bus which I have activated during >start vs. running the Aux. power direct from the Aux. battery. The second >option would allow better charging of the Aux. battery. I worry about >excess current flow if the Aux. battery is low causing the 5 amp fuse on >the Lightspeed to blow. Any advice? > >The Aux. battery is currently charged through my Rocky Mountain monitor. This issue (and others like it) have surfaced dozens of times over the past 15 years. There are some products not designed to work in the real world of airplanes. In this case, a software fix to the product in question would prevent inadvertent kick-backs due to low bus voltage or any other stimulus. Adding an aux battery per Z-30 has always been the universal Band-Aid for this phenomenon. Further, it offers an opportunity to run other electrically-dependent engine accessories from a "protected" supply. No diodes needed (therefore no charging issues). Battery may be any practical size needed to address your endurance needs. Closing the contactor may be automatic . . . See: http://aeroelectric.com/articles/lvwarn/LVWarn-ABMM.pdf or manual or manual with warnings . . . See: http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf Any item needed to keep an engine running should be operated from an always-hot battery bus . . . if you got bad smells in the cockpit, you need to be able to shut EVERYTHING down without having the engine quit. Bob . . . --------------------------------------------------------- < What is so wonderful about scientific truth...is that > < the authority which determines whether there can be > < debate or not does not reside in some fraternity of > < scientists; nor is it divine. The authority rests > < with experiment. > < --Lawrence M. Krauss > --------------------------------------------------------- ________________________________________________________________________________
Date: Dec 13, 2006
Subject: Re: Z-13 v. SD-8 distribution Diagrams
>I m in the process of wiring up the SB005-1 (S704-1?) relay with the SD-8 >volt regulator and the OVM. The SD-8 distribution diagram (Dwg 504-500 rev >E, 9/29/04) seems to differ from the Z-13 diagram and I m wondering which >to follow. Dwg. 504-500 refers to the relay as SB005-1, and elsewhere, it >looks like the part number is S704-1. I m not sure if these are one in the >same or not. > > >The photo at ><http://www.bandc.biz/S704-1_tips.html>http://www.bandc.biz/S704-1_tips.html >is even different and includes an additional diode installed where the >OVM-14 should be installed. > > >Anyone have a good diagram or guidance on which drawing is correct? I m >thinking that Z-13 may be the correct drawing for the application. Both are. The S704-1 and similar relays (like eggs, flour and milk) are used in a variety of recipes and each recipe may treat that ingredient in a manner that is not consistent elsewhere. When you're baking a cake, you don't take a handful of recipes from multiple sources and then attempt to resolve differences between them. When someone publishes a recipe, you need to know if it's from a credible source and if the recipe is a demonstrated pathway to success. If those conditions are satisfied, then run with it. Bob . . . ________________________________________________________________________________
Date: Dec 13, 2006
The HSI is a Century NSD-1000(Electric) Is there a unique config in the 430 for this HSI? > >A friend has a GNS430 with an HSI in his RV8A. >He's starting to train for IFR in it. > >When he switches from VLOC to GPS tracking the HSI does not switch to >track the GPS waypoint. >It continues to track the VOR or Localizer. >Is this a wiring issue? Which make and model HSI? Is this one of the HSIs that is covered in the GNS400 Series Installation Manual? Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: Elect. map guage
Date: Dec 13, 2006
I am wiring up my Grand Rapids EIS and found out that the model that I have only has one aux input. I had planed on useing one input for Fuel press. and the second for Manifold pressure. With only one aux input available on my unit, I've decided to use it for fuel press. which allows for a low press warning. MAP doesn't need a warning so I will use a guage. I already have a Grand Rapids Manifold press sensor output 0 to 5volts. Does anyone know whair I can get an electric 2-1/4" 0-5volt map guage? Thanks Bill S. ________________________________________________________________________________
From: "Jae Chang" <jc-matronics_aeroelectric(at)jline.com>
Subject: DYMO RhinoPRO3000 label writer
Date: Dec 13, 2006
Here is a P-touch labeller on sale for $68.43 at buy.com with free shipping. http://www.buy.com/retail/product.asp?sku=10372536&loc=101&sp=1&adid=17662 I don't have one, but just noticed it and remembered the discussion on this list. It piqued my curiosity. I wanted to know what these labels actually looked like, since I have never seen one. http://www.amazon.com/exec/obidos/ASIN/B0002AZ2RY/pricegrabbercpc11-20/ref=nosim The link on amazon.com has a better picture. It actually shows a few sample wires with wire labels attached. It sure does look nice for labelling wires. One comment on here, though, mentions that he thought quite a bit of the labels were wasted. I am probably years away from needing one. Jae ________________________________________________________________________________
Date: Dec 13, 2006
Seems like a golden business opportunity for someone with a deluxe-o labelling set-up: market a kit of pre-printed heat shrink wire labels in various alpha and numeric combinations as well as commonly used words, like comm1, nav2, audio in, etc. Printed in bulk, they're bound to be more cost-effective than wasting alot of $5 / foot heat shrink in your own home ;-) -Bill B On 12/13/06, Jae Chang wrote: > > Here is a P-touch labeller on sale for $68.43 at buy.com with free shipping. > > http://www.buy.com/retail/product.asp?sku=10372536&loc=101&sp=1&adid=17662 > > I don't have one, but just noticed it and remembered the discussion on this > list. It piqued my curiosity. I wanted to know what these labels actually looked > like, since I have never seen one. > > http://www.amazon.com/exec/obidos/ASIN/B0002AZ2RY/pricegrabbercpc11-20/ref=nosim > > The link on amazon.com has a better picture. It actually shows a few sample > wires with wire labels attached. It sure does look nice for labelling wires. > > One comment on here, though, mentions that he thought quite a bit of the labels > were wasted. > > I am probably years away from needing one. > > Jae > > ________________________________________________________________________________
Subject: Annunciator Panel Update?
Date: Dec 13, 2006
Anybody got an update on the potential annunciator panel that was being discussed several months ago? Thanks Bob Read this topic online here: http://forums.matronics.com/viewtopic.php?p=81412#81412 ________________________________________________________________________________
Date: Dec 13, 2006
My old copy of the Garmin Installation Manual shows how to wire the NSD-1000 HSI, and there is no mention of any special issues. I looked at the list of configuration menu items, and didn't see any that were obviously relevant to your problem. My installation manual shows a possible cause. The HSI lateral and vertical deviations are supposed to be wired to pins on connector 4001. These pins send either VLOC or GPS deviations, depending on what is selected. But, there are VLOC only lateral and vertical deviation pins on connector 4006. I can't find a description of what comes out of those pins if the GNS 430 is selected to GPS, but it is possible that they would continue to send VLOC data. Maybe your friend's HSI is connected to those pins rather than the ones on connector 4001. Who did the wiring? Kevin Horton On 13 Dec 2006, at 13:49, Eric Parlow wrote: > > > The HSI is a Century NSD-1000(Electric) > Is there a unique config in the 430 for this HSI? > >> >> A friend has a GNS430 with an HSI in his RV8A. >> He's starting to train for IFR in it. >> >> When he switches from VLOC to GPS tracking the HSI does not >> switch to track the GPS waypoint. >> It continues to track the VOR or Localizer. >> Is this a wiring issue? > > Which make and model HSI? Is this one of the HSIs that is covered > in the GNS400 Series Installation Manual? > > Kevin Horton RV-8 (finishing kit) > Ottawa, Canada > http://www.kilohotel.com/rv8 > ________________________________________________________________________________
Date: Dec 13, 2006
Well, a TC aircraft has to be inspected by an A&P?IA annually, unlike an OBAM. Chuck Jensen wrote: > Owning a C150 that was not owner > built and is subsequently converted to Experimental is no different than > owning an RV that was built by someone else. Both have to be inspected > by an A&P. How is one more, or less, safe than the other? > > W ________________________________________________________________________________
Date: Dec 13, 2006
Since I started this discussion, thought I'd chime in on my purchase decision. I've opted for a Brady ID Pal, for about $100. It doesn't print heat-shrink tubing, but the Dymo Rhyno cartridges are pretty pricey for only 5 feet of tube. The standard cartridges are smaller (less total length) on the Dymos, and Brady claims there is less waste (margin) on their labels. We'll see.. My thinking is that if I really NEED a heat-shrink tube label, I'll make a standard label and apply a clear shrink-tube around it. Usual suspects might be anything FWF. But the MAJOR factor was that using the wrap-around labels, you can print up to 4 (I think) lines of text on each label- a no-brainer since this kind of label is vastly easier to read when you are standing on your head with a maglite in your teeth trying to find the "E1-26A" wire in that bundle going to the audio panel. Whatever. My best investigations indicate that the heat-shrink tubes only get one line of text- not too handy, IMHO... Will produce a "product evaluation report" upon reciept and use of Brady label machine... >From The PossumWorks in TN Mark ________________________________________________________________________________
Subject: Heat shrink labelling
Date: Dec 14, 2006
Just another approach. We got 400 pairs of numbered heat shrink, 300 pairs of 3/32" and 100 pairs of 1/4" - Each label being 3/4" long, www.merithian.com - total cost was about US$60. Every wire / cable then has one label on each end and a spreadsheet for look up for wire size / termination / routing / function. So far has worked really well. Carl -- ZK-VII - RV 7A QB - finishing? - New Zealand http://www.rvproject.gen.nz/ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Sent: Thursday, 14 December 2006 4:17 p.m. To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: DYMO RhinoPRO3000 label writer Since I started this discussion, thought I'd chime in on my purchase decision. I've opted for a Brady ID Pal, for about $100. It doesn't print heat-shrink tubing, but the Dymo Rhyno cartridges are pretty pricey for only 5 feet of tube. The standard cartridges are smaller (less total length) on the Dymos, and Brady claims there is less waste (margin) on their labels. We'll see.. My thinking is that if I really NEED a heat-shrink tube label, I'll make a standard label and apply a clear shrink-tube around it. Usual suspects might be anything FWF. But the MAJOR factor was that using the wrap-around labels, you can print up to 4 (I think) lines of text on each label- a no-brainer since this kind of label is vastly easier to read when you are standing on your head with a maglite in your teeth trying to find the "E1-26A" wire in that bundle going to the audio panel. Whatever. My best investigations indicate that the heat-shrink tubes only get one line of text- not too handy, IMHO... Will produce a "product evaluation report" upon reciept and use of Brady label machine... From The PossumWorks in TN Mark ________________________________________________________________________________
Date: Dec 14, 2006
My 2 cents on wire numbering. My schematics are identified via two letters ' FP for Flaps, PW for electrical power etc. Each wire on a particular schematic has its number, starting with 1 and going up Each wire belongs to a circuit identified by two letters, independent of the schematic, starting with AA, then AB, then AC etc. All this of course is contained in spread sheets via an export of the schematic wire identification labels. Each wire is therefore numbered as follows: SSNNCC where SS is the schematic, NN is the number and CC is the circuit. Hence when I look at a wire, for example FP34EA I know that it is wire #34 on the Flaps schematic and it belongs to circuit EA (power to the flap motor ' excel spreadsheet). The reason for labelling the circuit in is that two wires MUST be on the same circuit when they join. Hence if I find two wires on a connector with labels FP34EA and PW45EA respectively then I know it is OK. But if the circuits do not match ' they are not connected correctly. An EA wire should connect to another EA wire and nothing else. This is the key to render connecting things together pretty well fool proof as far as connector blocks are concerned. That=92s it ' I found it makes connecting things and tracing them quite easy ' saves a lot of time and reduces the risk of a =91Smoke gets in your eyes..=92. Later on, when time comes for maintenance or trouble shooting, this numbering system should be a great help. Of course, if the schematic is wrong=85 Michele RV8 - Finishing _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carl Morgan Sent: jeudi 14 d=E9cembre 2006 07:08 Subject: RE: AeroElectric-List: Heat shrink labelling Just another approach. We got 400 pairs of numbered heat shrink, 300 pairs of 3/32" and 100 pairs of 1/4" - Each label being 3/4" long, www.merithian.com - total cost was about US$60. Every wire / cable then has one label on each end and a spreadsheet for look up for wire size / termination / routing / function. So far has worked really well. Carl -- ZK-VII - RV 7A QB - finishing? - New Zealand http://www.rvproject.gen.nz/ -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Fiveonepw(at)aol.com Sent: Thursday, 14 December 2006 4:17 p.m. Subject: Re: AeroElectric-List: DYMO RhinoPRO3000 label writer Since I started this discussion, thought I'd chime in on my purchase decision. I've opted for a Brady ID Pal, for about $100. It doesn't print heat-shrink tubing, but the Dymo Rhyno cartridges are pretty pricey for only 5 feet of tube. The standard cartridges are smaller (less total length) on the Dymos, and Brady claims there is less waste (margin) on their labels. We'll see.. My thinking is that if I really NEED a heat-shrink tube label, I'll make a standard label and apply a clear shrink-tube around it. Usual suspects might be anything FWF. But the MAJOR factor was that using the wrap-around labels, you can print up to 4 (I think) lines of text on each label- a no-brainer since this kind of label is vastly easier to read when you are standing on your head with a maglite in your teeth trying to find the "E1-26A" wire in that bundle going to the audio panel. Whatever. My best investigations indicate that the heat-shrink tubes only get one line of text- not too handy, IMHO... Will produce a "product evaluation report" upon reciept and use of Brady label machine... >From The PossumWorks in TN Mark ________________________________________________________________________________
Date: Dec 14, 2006
Subject: Re: Alternate feed to Lightspeed (easy fix)
Kaluza: That would be fine to drive the LSII from the main bus and AUX battery with a Schottky diode. Here is Klaus diagram I modified as I think you described. http://img218.imageshack.us/img218/7803/presentation1wm4.jpg (you may get by with less than a 4.5 amp/hr battery, depending on your endurance needs) Skytec also has suggestions: http://www.skytecair.com/EI.htm (notice the capacitor solution, independant of using the Aux battery, a 50,000 mfd cost about $36.00. I like the battery better if you already have it and its suitable.) Is the rocky mountain really up to charging the battery? You may have to decided that. There is no reason why you can't let the airplane charge it is there? What kind of aux battery is it? The reason you may have got a kick back after 360 hours is your main battery is starting to get weaker (from age) and possibly cold weather is affecting it. Also the starter may be draining more with cold weather starts, lowering the voltage during start. Never the less having the ignition w/ AUX pwr during start will fix it. AUX does not drive the starter so voltage stays up. No EI is immune from start kick back with super low
December 04, 2006 - December 14, 2006
AeroElectric-Archive.digest.vol-gk
