AeroElectric-Archive.digest.vol-gt
March 03, 2007 - March 13, 2007
      >Hi Bob ...
      >Couldn't agree more with the idea of using a venturi's to drive a
      >single instrument.  The idea of driving a vacuum driven horizon has
      >pulled at me for some time.  The group of three info providing life
      >savers ... attitude, airspeed and altitude are all air driven and
      >simple.  The only one needing vacuum could easily be driven with an
      >8" venturi.  The venturi does require high velocity air over and
      >through it to pull the vacuum.  My son and I were experimenting
      >yesterday with a venturi 6" long X 2" diameter.  It will drive a
      >turn needle (as it's designed to do) but a horizon needs more beef
      >to sustain it.  I like the idea of putting the venturi in the cowl
      >exit air and I will try that with a couple other venturi's.  I also
      >will create a gill type venturi which could be placed on the side of
      >the fuselage, right beside the inst panel so the vacuum could be
      >within about a foot of the horizon.  When I have the mods completed
      >on my RV4 (before Spring) it will be used for this test bed.  The
      >venturi is but one of these test items.  Has anyone on the list
      >messed with a gill type venturi?   My fondest hope would be to
      >create something made similar a NACA vent that could simply be
      >bonded/riveted onto the sheet metal and plug in a vacuum
      >line.  Done!  It's probably more involved than just that but it's
      >the essence of the thought.
      >You have to admit Bob, one peek at a vacuum horizon is worth 20
      >peeks at a T&B ... : )
      >Jerry Grimmonpre
      >----- Original Message -----
      >From: <mailto:BobsV35B(at)aol.com>BobsV35B(at)aol.com
      >To: aeroelectric-list(at)matronics.com
      >Sent: Friday, March 02, 2007 4:00 PM
      >Subject: AeroElectric-List: Backup Electric Vacuum Pump
      >Good Afternoon Steve,
      >What I don't understand is why more folks don't use venturi's.  They
      >work well, are cheap and are very reliable. If they are mounted on
      >the belly in the path of the airflow from the engine, they even have
      >reasonable protection from ice.
      >Many airplanes flew in heavy IFR weather for many years using
      >nothing but a venturi to power all of the instruments. What gave
      >venturi's a bad name was when foolish people started to mount them
      >on the side of the fuselage instead in the airstream behind the
      >engine.  I have a small venturi powering a single T&B. If all else
      >fails, I can easily control the airplane with just that one T&B. If
      >I have any altitude information at all it is easy. Add a handheld
      >GPS and I have more than the fanciest airplanes had in the thirties.
      >One point though. Partial panel can be done with a turn coordinator,
      >but I much prefer the classic T&B. It is about the most reliable
      >mechanical instrument we have ever had. Some day, I am sure there
      >will be a solid state turn indicator that will replace the T&B.
      >However, until that time. Get a T&B, power it with a small venturi
      >and spend a thousand bucks on dual training getting thoroughly
      >familiar with using the T&B to control the airplane.
      >Happy Skies,
      >Old Bob
Date: Mar 03, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: batteries
> > > >N1DeltaWhiskey(at)comcast wrote: > > What is the voltage drop you expect in #4 vs. #2 wire for a 6' run > (out and back) while flowing about 250 amps? >This is apparently about a Rotax 91x engine, though? The starter relay >supplied with my kitplane for a 912/914 is 70A. More consistent with the >kW spec of the starter motor. Maybe 50A average? "Ratings" on switching contacts are to be considered with a grain of salt . . . or sand. The probability of satisfactory service life is only loosely related to "ratings". The ratings are based on numbers of times a contact can SWITCH certain kinds of loads . . . interestingly enough, starter motors on engines are almost NEVER included in the suite of standard loads for the establishment of ratings. For example, the el-cheeso battery contactors used on tens of thousands of GA aircraft are RATED at 70A, yet we've routinely cranked engines through these devices with draws of 200-300 amps for decades. Given the enduring presence of these critters in the marketplace, one must deduce that users are seeing a satisfactory service life. I.e., good value for the investment. The thing that's hard on devices that switch starters is not the average running current. The switch-killer is the locked-rotor or inrush current that flows in the milliseconds that the motor is accelerating up from zero velocity while at the same time, contacts on the switch are making MULTIPLE closures. See: http://www.aeroelectric.com/Pictures/Curves/switch_transition.jpg These are switches and not contactors but the effects are similar for all such devices. In a millisecond to a millisecond and a half, these switches close, open and re-close many times. This is why we SWITCH starter loads with STARTER CONTACTORS. These have exceedingly thin and light contacts compared to continuous duty contactors . . . these contacts are driven together with much greater force so as to minimize the bouncing and contact resistance. See: http://www.aeroelectric.com/Pictures/Contactors/S702-1b.jpg Another consideration for service life is total operations per flight hour extrapolated out to total operations per year. In the average GA aircraft, any switch or contactor is hard pressed to see more than a few hundred operations per year . . . a device that is RATED in the tens of thousands of operations at RATED loads that may not be representative of what the switch really sees in the airplane. It's easy to see that many components might deliver satisfactory service life in terms of chronological age in the airplane in spite of being "overloaded" with respect to catalog ratings. Keep in mind too that connections, and contacts for switching devices ADD TO THE TOTAL loop resistance and may DOUBLE the total loop resistance when compared wire resistance alone. These are some of the reasons why it's not terribly useful to agonize over the resistance of 2AWG vs 4AWG or the ratings of any particular switch or contactor over another. The ultimate test of your cranking system's ability to get the engine moving is only measurable with some pretty sophisticated test equipment. I have a DAS that will gather 2000 samples per second so that instantaneous energy losses in the various components and wire lengths can be quantified and decisions made for optimization. I'm not trying to discourage anyone from a quest to understand the finer details of their ship's electrical system . . . but know too that decisions made on rudimentary, single item calculations and/or catalog data for components may not stand on solid physics. Bob . . . ________________________________________________________________________________
Date: Mar 03, 2007
Subject: Backup Electric Vacuum Pump
In a message dated 3/3/2007 1:31:39 P.M. Central Standard Time, jerry(at)mc.net writes: You have to admit Bob, one peek at a vacuum horizon is worth 20 peeks at a T&B ... : ) Jerry Grimmonpre Good Afternoon Jerry, I am not so sure I would agree. It is possible to have two artificial horizons that are both active and that change attitude when you roll, but one may be accurate and the other not. You have to decide which is correct. Attitude gyros do occasionally get the "leans". In at least ninety-nine and forty-four one hundredths of a percent of the times, if the T&B is wiggling, it is working. And, if we are confused as to where up is, it is hard to believe an instrument that does not agree with our senses. However, we don't have to agree with the T&B. If it says we are not turning , we will survive. It makes no difference at all where we think up is. No turns, no problem! Not only that, but even a cheap old airline pilot can afford one. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 03, 2007
Good Afternoon Dave, I don't think doing whatever anyone wants to do to their personal experimental aircraft is ever insane. And, as a matter of fact, my 1978 Bonanza is now an all electric machine, so I do agree that going all electric is a reasonable thing to do. If someone does wish to add another back up to whatever is being used, adding a single T&B powered by a single Venturi is about as light and cheap as any standby can be. There is absolutely no requirement in the FARs that any of our older airplanes have any redundancy at all. My first Bonanza had one vacuum pump, one vacuum T&B, and one vacuum directional gyro. No attitude gyro and no back up for the Vacuum. Perfectly legal for IFR at the time. I added an electric T&B because I wanted a little more redundancy than was installed in the airplane when I bought it. When the Attitude Gyro was added to the list of instruments required for IFR light, I added a vacuum driven attitude gyro. Still -- No redundancy required. While some of the more recently approved airplanes do have redundancy built into their certification limitations, we have no more requirement for redundancy that do the homebuilders among us. To each his own and all that stuff! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/3/2007 2:05:45 P.M. Central Standard Time, N6030X(at)DaveMorris.com writes: I don't know about you guys, but if I were building an experimental and had no Type Certificate I had to abide by, I would be spending my time figuring out how to build a bullet proof electrical system and getting rid of anything that had the word Vacuum in it. It's an old, archaic technology that, at the present date, serves ONLY to make gyros cheaper. The vacuum pumps are less reliable or long-lived than an alternator, and you're basically building a parallel power system for gyros that adds weight and complexity, hoses, filters, etc, and so on. If you've got redundant electrical, and you are now worrying about a backup vacuum system, you're basically building QUADRUPLE parallel systems to power gyros. That's insane to me.
Subject: Re: Backup Electric Vacuum Pump
Date: Mar 03, 2007
Old Bob ... Wouldn't you opt for a vacuum horizon, even one that has the leans when the EFIS locks up on final to an instrument runway? This has happened while vectored to a runway not selected in the EFIS. It ended happily to another pilot who resorted to backup instruments. Any instrument or piece of hardware that will get your wings near level, even a leaning vacuum driven horizon, is better than none at all . Bottom line is EFIS requires back up stuff to level the wings and stay out of the weeds ... autopilot, vac horizon, t&b, altimeter and airspeed. Betting on EFIS alone is something not even Boeing does. Jerry ... ________________________________________________________________________________
Date: Mar 03, 2007
Good Evening Jerry, I like the T&B. If I had to choose between having only an artificial horizon or only a T&B , I would take the T&B every time. The company took away our T&Bs back when I was flying the 720. I flew it between 1968 and 1972 so imagine the T&B was eliminated in about 1970. I do recall that the first time I got in turbulence after that was when I first missed the T&B. I had not realized I had been using it to kill the Dutch roll, but as soon as it started, my eyes fell to where the T&B had been located. I realize that I also suffer from the disease of primacy. When I was getting my instrument training, we were not allowed to use an Artificial Horizon or a Directional Gyro. All the training and all the check rides were done strictly on partial panel. I managed to learn how to use those fancy gyros later in life, but I have always reverted to the T&B when things started to get confusing. Since I tend to get confused easily, I looked at the T&B a lot! It is still the most reliable mechanical instrument available. And it is light, cheap, and simple. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/3/2007 4:25:28 P.M. Central Standard Time, jerry(at)mc.net writes: Old Bob ... Wouldn't you opt for a vacuum horizon, even one that has the leans when the EFIS locks up on final to an instrument runway? This has happened while vectored to a runway not selected in the EFIS. It ended happily to another pilot who resorted to backup instruments. Any instrument or piece of hardware that will get your wings near level, even a leaning vacuum driven horizon, is better than none at all . Bottom line is EFIS requires back up stuff to level the wings and stay out of the weeds ... autopilot, vac horizon, t&b, altimeter and airspeed. Betting on EFIS alone is something not even Boeing does. Jerry ...
Date: Mar 03, 2007
>Old Bob ... >Wouldn't you opt for a vacuum horizon, even one that has the leans when >the EFIS locks up on final to an instrument runway? This has happened >while vectored to a runway not selected in the EFIS. It ended happily to >another pilot who resorted to backup instruments. Any instrument or piece >of hardware that will get your wings near level, even a leaning vacuum >driven horizon, is better than none at all . Bottom line is EFIS requires >back up stuff to level the wings and stay out of the weeds ... autopilot, >vac horizon, t&b, altimeter and airspeed. Betting on EFIS alone is >something not even Boeing does. >Jerry ... The least expensive, lightest, most useful and simplest backup for any panel presentation of attitude is the GPS aided wing leveler. If one is concerned for reducing risks for failure of some piece of panel equipment degrading the day's flight into an unhappy event, the most risk free reversion mode is to let a/p take over. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: Stereo Input Jack
Date: Mar 04, 2007
G'Day Carl Thanks for your help Carl. I am still a bit confused though. I should have been a bit clearer, I am trying to wire the female socket. This sort of stuff is not my forte. Stein did mine and I did clarify it once with them but have lost the info, I have had a bit going on lately. I might just have to pester them again. Mine should have flown in Jan but I have had a bit of a hiatus. Regards Chris ----- Original Message ----- From: Carl Morgan To: aeroelectric-list(at)matronics.com Sent: Saturday, March 03, 2007 6:28 PM Subject: RE: AeroElectric-List: Stereo Input Jack Hi Chris, Assuming your harness was made be Stark (which I think it was) and it is the same as mine.... DB44-340-J2:23 - Music 1 L In Audio In - White DB44-340-J2:24 - Music 1 R In Audio In - White/Orange DB44-340-J2:25 - Music 1 Return Audio In - White/Blue Standard 3.5 mm music jack Tip - Left Channel Ring - Right Channel Sleeve - Ground / Common HTH, Carl -- ZK-VII - RV 7A QB - finishing? - New Zealand http://www.rvproject.gen.nz/ -----Original Message----- From: Chris Byrne [mailto:jack.byrne(at)bigpond.com] Sent: Saturday, 3 March 2007 7:45 p.m. To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Stereo Input Jack I have a stereo jack to install for input to a GMA 340. The jack has one long lug which I will attach the white wire to. The jack has 2 shorter lugs, a bronze colour and a silver colour. I have a 3 wire cable from the GMA340 wired by the supplier. Which lug should the white/blue wire and the white/orange wire go to or dosnt it matter. The logic to the earphone jack is white/blue to tip and white/ orange to the ring if that helps. Thanks Chris Byrne SYDNEY href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ------------------------------------------------------------------------- ----- 2/03/2007 4:19 PM ________________________________________________________________________________
Date: Mar 03, 2007
In a message dated 3/3/2007 4:40:52 P.M. Central Standard Time, Bobs V35B writes: Betting on EFIS alone is something not even Boeing does. Jerry ... Just a bit more Jerry, I am not ready to rely on having nothing but glass. In fact, I do not believe I will buy a glass cockpit for several years, if ever. I am happy with the classic instruments and I will buy as cheap an MFD as I can get to play with while I fly the airplane in reference to "traditional" information. I would imagine that I will buy glass when it becomes cheaper than traditional instrumentation. I DO believe that will eventually happen. Odds are that I will still have an Airspeed, T&B and Altimeter all in a row very close to my primary scan area! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503
Date: Mar 03, 2007
Good Evening Bob, I do agree that having a wing leveler is a great idea. I even like the way Mooney hooked it up so that we had to press on a button any time we wanted to hand fly the airplane, but I do not believe you will find ANY wing leveler that can be installed as cheaply as can a venturi powered vacuum T&B. An electrically powered T&B is even cheaper if you do not count the cost of having an electrical system to power it. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/3/2007 4:50:04 P.M. Central Standard Time, nuckollsr(at)cox.net writes: The least expensive, lightest, most useful and simplest backup for any panel presentation of attitude is the GPS aided wing leveler. If one is concerned for reducing risks for failure of some piece of panel equipment degrading the day's flight into an unhappy event, the most risk free reversion mode is to let a/p take over. Bob . . .
Subject: Electrolumenesent Light.
Date: Mar 04, 2007
Bob I finally got around to daisy chaining my lighting strips. It works well. I had a bit of trouble working out how to attach the wires to the strips though. I found a strip of PCB material with 6 lugs attached to it. They were held in place by inserting them through the holes in the PCB material and folding over 4 small ears. Just a matter of unfolding the ears and removing them from the PCB. A nail through the lighting strip and attaching the lugs worked well, solder on your wire prior to attaching the lugs to the illumenesent strip. Chris Byrne SYDNEY ________________________________________________________________________________
From: "kesleyelectric" <kesleyelectric(at)chooseblue.coop>
Subject: Turbocad question
Date: Mar 03, 2007
Having recently picked up Turbocad, I find that I can open and edit the Z drawings, but cannot get the program to keep the wires attached as various components are moved around. If my old copy of Visio is able to create attach points anywhere on the figure and do dynamic connector lines (wires), I'm sure T-cad 10 should be able to, but I have yet to discover how to enable it. Any help appreciated. Tom Barter Avid Magnum ________________________________________________________________________________
Date: Mar 03, 2007
Subject: Re: Turbocad question
kesleyelectric wrote: > Having recently picked up Turbocad, I find that I can open and edit > the Z drawings, but cannot get the program to keep the wires attached > as various components are moved around. If my old copy of Visio is > able to create attach points anywhere on the figure and do dynamic > connector lines (wires), I'm sure T-cad 10 should be able to, but I > have yet to discover how to enable it. Any help appreciated. > Tom, Unfortunately TurboCAD does not have the "rubber banding" capability of Visio and some of the electrical schematic CAD programs. There isn't any way to drag a component and have all the lines (wires) stay attached and be repositioned after dropping the component. Steve ________________________________________________________________________________
Date: Mar 03, 2007
From: Dennis Golden <dgolden@golden-consulting.com>
Subject: Re: Battery Tenders as recharging tools . . .
James H Nelson wrote: > > Where is a good place to buy the Schumacher chargers? > > Jim Nelson Got mine at Wal Mart -- Dennis Golden Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Mar 03, 2007
>kesleyelectric wrote: >>Having recently picked up Turbocad, I find that I can open and edit the Z >>drawings, but cannot get the program to keep the wires attached as >>various components are moved around. If my old copy of Visio is able to >>create attach points anywhere on the figure and do dynamic connector >>lines (wires), I'm sure T-cad 10 should be able to, but I have yet to >>discover how to enable it. Any help appreciated. > >Tom, > >Unfortunately TurboCAD does not have the "rubber banding" capability of >Visio and some of the electrical schematic CAD programs. There isn't any >way to drag a component and have all the lines (wires) stay attached and >be repositioned after dropping the component. Like in AutoCAD, it's called Stretch under the modify pulldown. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 03, 2007
Pump >Good Evening Bob, > >I do agree that having a wing leveler is a great idea. > >I even like the way Mooney hooked it up so that we had to press on a >button any time we wanted to hand fly the airplane, but I do not believe >you will find ANY wing leveler that can be installed as cheaply as can a >venturi powered vacuum T&B. > >An electrically powered T&B is even cheaper if you do not count the cost >of having an electrical system to power it. But, like all presentations under glass, it depends on the integrity of a sensor/display/perception/reaction servo loop of which includes a human having to work with the reality of a rare but now present failure. N/B/AS is a useful but exceedingly lousy alternative to stable gyros. I wouldn't own an airplane without a gps aided wing leveler just because it makes flying so much more relaxed . . . whether the stuff under the glass is working or not and a whole lot lower risk when it is not. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 03, 2007
Good Evening Bob, May I take that to mean that you would want a GPS aided wing leveler in a Stearman?, Piper Cub?, Luscombe?, Cessna 140? Cessna 172, Beech Musketeer?, Beech Bonanza? North American AT-6? Twin Beech? Where would you draw the line? All of the above? None of the above? Some of the above? I have never flown any airplane that had a GPS aided wing lever though I have flown and owned plenty that did have wing levelers. We all have to make individual decisions on what we feel meets our individual level of risk, but requiring a GPS aided wing leveler is not real high on my list of necessities. Interesting that you think such a device is imperative. Just goes to show, there is a wide range of desires among us all. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/3/2007 8:11:28 P.M. Central Standard Time, nuckollsr(at)cox.net writes: But, like all presentations under glass, it depends on the integrity of a sensor/display/perception/reaction servo loop of which includes a human having to work with the reality of a rare but now present failure. N/B/AS is a useful but exceedingly lousy alternative to stable gyros. I wouldn't own an airplane without a gps aided wing leveler just because it makes flying so much more relaxed . . . whether the stuff under the glass is working or not and a whole lot lower risk when it is not. Bob . . .
Subject: Re: affordable panels
Date: Mar 03, 2007
I also have had a great experience dealing with Affordable Panels. Fabian is patient, fair, and easy to work with. I just received my panel a couple weeks ago and had a question last Saturday. I thought I would just call and leave a message for him, but he actually picked up the phone and helped me out over the weekend. Great product and great service. Greg RV-7A Raleigh, NC >From: John Morgensen <john(at)morgensen.com> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: affordable panels >Date: Fri, 02 Mar 2007 17:50:13 -0800 > > > >I am still designing my panel but let me make a few points anyway: > >1. The modular panel does cost some panel space and flexibility. That may >or may not be significant. > >2. If you have 2 big screens in your panel, then you have 2 large access >holes for maintenance. > >I am leaning toward Van's standard panel. > >John Morgensen RV9A > >Mark/Kara Phillips wrote: >> >> >>Fabian is very knowledgeable about his product and will go out of his way >>to help you. Very positive experience. >> >>Mark Phillips >>Williamsville Illinois >>----- Original Message ----- From: "Dennis Jones" <djones(at)northboone.net> >>To: >>Sent: Friday, March 02, 2007 2:05 AM >>Subject: AeroElectric-List: affordable panels >> >> >>> >>> >>>Any one have feed back on there experience with Affordable Panels service >>>or product? >>> >>>Thanks >>>Jonsey >>> >>> >>> >>> >>>Read this topic online here: >>> >>>http://forums.matronics.com/viewtopic.php?p=98264#98264 >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> > > _________________________________________________________________ Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. Intro*Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 ________________________________________________________________________________
Subject: Re: What is insane? Was: Backup Electric Vacuum Pump
Date: Mar 03, 2007
That's the difference between a pilot and a cockpit resource manager Steve Read this topic online here: http://forums.matronics.com/viewtopic.php?p=98585#98585 ________________________________________________________________________________
Date: Mar 03, 2007
>Good Evening Bob, >May I take that to mean that you would want a GPS aided wing leveler in a Stearman?, >Piper Cub?, Luscombe?, Cessna 140? Cessna 172, Beech Musketeer?, >Beech Bonanza? North American AT-6? Twin Beech? Sure, why not? The answer is simple for most owners but for myself, I wouldn't own one of those airplanes because I need to stand in line at too many windows begging permission to make it better. >Where would you draw the line? All of the above? None of the >above? Some of the above? You have just illuminated the reason that those airplanes are all rotting away never to be replaced. The GPS aided wing leveler is mechanically no more difficult to install in one of those airplanes than in an RV. But those who claim to know more about what's good for us have become the mill-stones between which those airplanes are slowly turning to dust. >I have never flown any airplane that had a GPS aided wing lever >though I have flown and owned plenty that did have wing levelers. >We all have to make individual decisions on what we feel meets our >individual level of risk, but requiring a GPS aided wing leveler >is not real high on my list of necessities. Interesting that you >think such a device is imperative. Depends on what your design goals are. For most of the the folks on this List, reducing cost of ownership is a goal. Dependency on a T&B traded for dependency on a GPS aided wing leveler offers a lower cost of ownership over the lifetime of the airplane. >Just goes to show, there is a wide range of desires among us all. If the "desire" is to minimize the probability of an unhappy ending to a piece of equipment failing, then the design goals are pretty clear. I've watched the conversations here on the List and elsewhere for over a decade that vigorously debated the value of this technique or piece of equipment over that . . . But seldom did the conversation recommend reversion modes that reduce, not increase pilot workload. I'm dead-nuts serious about the admonition in my signature tag . . . an exceedingly small number of pilots accomplish daily practice for standard (much less reversion) modes flight in IMC. I understand that you may be personally comfortable . . . and perhaps world class in skills and willingness to fly through clouds with the venerable tools of yesteryear. I've done it too. But I cannot in good conscience recommend that the neophyte builder embrace these techniques today when there are better options that are cheap as a percentage of the total cost of acquiring, owning and operating an airplane. In a cost-of-ownership accounting, the venturi-driven T&B offered as a gift will be more expensive in $time$ expended than what's needed to install the modern alternative. Further, the GPS aided wing leveler adds value to a high percentage of every flight while the T&B is useful for calibrating your rudder pressure on climb-out, setting rudder trim, and being there to assist with the management of a failure that you hope will never come but demands a perpetual investment of $time$ to make sure you are ready when it does. Very few of us are professional pilots. Those of us who are should be mindful of advice which presumes that all listeners are interested in (or even capable of) achieving levels of proficiency needed to avoid quantum jumps in risk after certain failures. This isn't about a "wide range of desires" but simple failure modes effects analysis in a market place where the pilots come with a wide range of capability and willingness to spend $time$ necessary to level the risks if not lower them. One of the reasons why I see an opportunity for OBAM aviation to excel in accident reduction is because we can readily take advantage of modernization opportunities for reducing workload without begging anyone's permission. When the GPS aided wing leveler is present, failure of the primary display does not generate an immediate need to revert to a whole new mode of flying. When one is depending on primary attitude displays to stay upright, then reversion to N/B/AS aviating at the same level of risk demands and investment of $time$ for maintenance of proficiency. The GPS aided wing leveler will hold track to within a degree or so all day, every day and doesn't need a bit of practice to stay "world class" at the task. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 04, 2007
Good Morning 'Lectric Bob, Thank you for the very complete analysis of my position on the validity of using a T&B and venturi as a low cost back up to whatever else is deemed desirable in a flying machine. I have been reading your freely presented views since the days when the connection was from Down By The Riverside Press. (or, something close to that) Always a pleasure and your writings are always able to jiggle some thought out of my very uneducated brain. Nevertheless, I do think my responses have some merit. The original question that started this particular string had to do with providing a low cost source of vacuum. The Venturi is a low cost option. It is susceptible to icing, but when placed in a warm airstream behind the engine it has been shown to handle ice quite well. Vacuum pumps do fail. Especially the modern dry pumps if they are not replaced or serviced in accordance with the manufacturers instructions. I still think the venturi is a viable option. I recognize that you cannot take the time to read everything on this list. However, I think you would find that I have always said that I will happily embrace a newer technology whenever it fits my needs (and my price point!). There is nothing I would like better than having a solid state autopilot that would be reliable enough such that I did not have to know how to fly by instruments to be able to operate in cloud. If I were to be dropped in the wilderness with nothing to sustain me, I would surely die. Many of my ancestors would have been able to survive in those same conditions. Having accepted modern conveniences to keep me alive, I think I would be able to accept fully automatic flight sometime in the future. Just not yet. I recognize that I am old and am happy with current knowledge. It does allow me to feel comfortable flying a lot of those flying machines that are "rotting away". If the new breed of aviators is comfortable flying without the ability to control their flying machine while in cloud, that is fine with me. The venturi powered T&B in my Stearman is very comforting. You infer that flying a partial panel is difficult. I contend that it is NOT particularly difficult, IF adequate training has been received. There is no doubt that the skill is being lost. Most larger airliners lost their T&Bs almost forty years ago. To my knowledge, none ever had a turn coordinator. Chances are that many of the more modern airline pilots would have a problem flying with the basic needle ball and airspeed. I contend that the skill is relatively easy to attain ... IF the skill is desired! You very correctly stated that a skill not exercised tends to be lost. One of the reasons I like the T&B over the TC is because I find it relatively easy to integrate into my basic scan. I do so by using the T&B to check my rate of turn even though basic attitude reference is being obtained from an artificial horizon. This day and age, rate of turn is not regularly considered, but by keeping the rate of turn in mind, I force myself to include the T&B in my normal scan which makes it much easier for me to use should a failure occur. You make reference to my background as a professional pilot. I agree that I have had an opportunity that not every pilot has, needs, or wants. However, I have also been a flight instructor for fifty-eight years and in those fifty-eight years have trained many an instrument pilot. Not all of them have retained their partial panel skills, but many have! I do not contend that my way is the only way, just that it is a useful way. I see that I have wandered all over the landscape where the original intent was to suggest a low cost source of vacuum to someone who was looking for such a source. Once again, my lack of education has done me in, --- but I am having fun! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/3/2007 11:24:12 P.M. Central Standard Time, nuckollsr(at)cox.net writes: --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" >Good Evening Bob, >May I take that to mean that you would want a GPS aided wing leveler in a Stearman?, >Piper Cub?, Luscombe?, Cessna 140? Cessna 172, Beech Musketeer?, >Beech Bonanza? North American AT-6? Twin Beech? Sure, why not? The answer is simple for most owners but for myself, I wouldn't own one of those airplanes because I need to stand in line at too many windows begging permission to make it better. >Where would you draw the line? All of the above? None of the >above? Some of the above? You have just illuminated the reason that those airplanes are all rotting away never to be replaced. The GPS aided wing leveler is mechanically no more difficult to install in one of those airplanes than in an RV. But those who claim to know more about what's good for us have become the mill-stones between which those airplanes are slowly turning to dust. >I have never flown any airplane that had a GPS aided wing lever >though I have flown and owned plenty that did have wing levelers. >We all have to make individual decisions on what we feel meets our >individual level of risk, but requiring a GPS aided wing leveler >is not real high on my list of necessities. Interesting that you >think such a device is imperative. Depends on what your design goals are. For most of the the folks on this List, reducing cost of ownership is a goal. Dependency on a T&B traded for dependency on a GPS aided wing leveler offers a lower cost of ownership over the lifetime of the airplane. >Just goes to show, there is a wide range of desires among us all. If the "desire" is to minimize the probability of an unhappy ending to a piece of equipment failing, then the design goals are pretty clear. I've watched the conversations here on the List and elsewhere for over a decade that vigorously debated the value of this technique or piece of equipment over that . . . But seldom did the conversation recommend reversion modes that reduce, not increase pilot workload. I'm dead-nuts serious about the admonition in my signature tag . . . an exceedingly small number of pilots accomplish daily practice for standard (much less reversion) modes flight in IMC. I understand that you may be personally comfortable . . . and perhaps world class in skills and willingness to fly through clouds with the venerable tools of yesteryear. I've done it too. But I cannot in good conscience recommend that the neophyte builder embrace these techniques today when there are better options that are cheap as a percentage of the total cost of acquiring, owning and operating an airplane. In a cost-of-ownership accounting, the venturi-driven T&B offered as a gift will be more expensive in $time$ expended than what's needed to install the modern alternative. Further, the GPS aided wing leveler adds value to a high percentage of every flight while the T&B is useful for calibrating your rudder pressure on climb-out, setting rudder trim, and being there to assist with the management of a failure that you hope will never come but demands a perpetual investment of $time$ to make sure you are ready when it does. Very few of us are professional pilots. Those of us who are should be mindful of advice which presumes that all listeners are interested in (or even capable of) achieving levels of proficiency needed to avoid quantum jumps in risk after certain failures. This isn't about a "wide range of desires" but simple failure modes effects analysis in a market place where the pilots come with a wide range of capability and willingness to spend $time$ necessary to level the risks if not lower them. One of the reasons why I see an opportunity for OBAM aviation to excel in accident reduction is because we can readily take advantage of modernization opportunities for reducing workload without begging anyone's permission. When the GPS aided wing leveler is present, failure of the primary display does not generate an immediate need to revert to a whole new mode of flying. When one is depending on primary attitude displays to stay upright, then reversion to N/B/AS aviating at the same level of risk demands and investment of $time$ for maintenance of proficiency. The GPS aided wing leveler will hold track to within a degree or so all day, every day and doesn't need a bit of practice to stay "world class" at the task. Bob . . .
Date: Mar 04, 2007
>Good Morning 'Lectric Bob, > >Thank you for the very complete analysis of my position on the validity of >using a T&B and venturi as a low cost back up to whatever else is deemed >desirable in a flying machine. > >I have been reading your freely presented views since the days when the >connection was from Down By The Riverside Press. (or, something close to that) > >Always a pleasure and your writings are always able to jiggle some thought >out of my very uneducated brain. > >Nevertheless, I do think my responses have some merit. > >The original question that started this particular string had to do with >providing a low cost source of vacuum. > >The Venturi is a low cost option. No argument. > >It is susceptible to icing, but when placed in a warm airstream behind the >engine it has been shown to handle ice quite well. Vacuum pumps do fail. >Especially the modern dry pumps if they are not replaced or serviced in >accordance with the manufacturers instructions. > >I still think the venturi is a viable option. Also no argument. > >I recognize that you cannot take the time to read everything on this list. >However, I think you would find that I have always said that I will >happily embrace a newer technology whenever it fits my needs (and my price >point!). There is nothing I would like better than having a solid state >autopilot that would be reliable enough such that I did not have to know >how to fly by instruments to be able to operate in cloud. > >If I were to be dropped in the wilderness with nothing to sustain me, I >would surely die. Many of my ancestors would have been able to survive in >those same conditions. > >Having accepted modern conveniences to keep me alive, I think I would be >able to accept fully automatic flight sometime in the future. > >Just not yet. Which IS your preference . . . > >I recognize that I am old and am happy with current knowledge. It does >allow me to feel comfortable flying a lot of those flying machines that >are "rotting away". > >If the new breed of aviators is comfortable flying without the ability to >control their flying machine while in cloud, that is fine with me. > >The venturi powered T&B in my Stearman is very comforting. > >You infer that flying a partial panel is difficult. I contend that it is >NOT particularly difficult, IF adequate training has been received. "IF" is the operative word here . . . > >There is no doubt that the skill is being lost. Most larger airliners lost >their T&Bs almost forty years ago. To my knowledge, none ever had a turn >coordinator. > >Chances are that many of the more modern airline pilots would have a >problem flying with the basic needle ball and airspeed. > >I contend that the skill is relatively easy to attain ... IF the skill is >desired! > >You very correctly stated that a skill not exercised tends to be lost. One >of the reasons I like the T&B over the TC is because I find it relatively >easy to integrate into my basic scan. I do so by using the T&B to check my >rate of turn even though basic attitude reference is being obtained from >an artificial horizon. This day and age, rate of turn is not regularly >considered, but by keeping the rate of turn in mind, I force myself to >include the T&B in my normal scan which makes it much easier for me to use >should a failure occur. > >You make reference to my background as a professional pilot. > >I agree that I have had an opportunity that not every pilot has, needs, or >wants. However, I have also been a flight instructor for fifty-eight years >and in those fifty-eight years have trained many an instrument pilot. Not >all of them have retained their partial panel skills, but many have! > >I do not contend that my way is the only way, just that it is a useful way. > >I see that I have wandered all over the landscape where the original >intent was to suggest a low cost source of vacuum to someone who was >looking for such a source. > >Once again, my lack of education has done me in, --- but I am having fun! That's what it's all about. Fun and risk reduction. You've offered nothing that's arguable. Nor have I. You've encouraged new builders to take advantage of a system that has a exceedingly low initial cost and if they're willing to do the investment of $time$ for training and sustaining the skill, it's one option. My approach is that of a systems integrator where the pilot is a close second place behind the airframe in the study of need for reliability in flight system components. I have observed first-hand how a pilot who took all the courses, spent a lot of time in his airplane, and outfitted it with everything you and I both would recommend . . . except a stand alone wing-leveler that would back up the very expensive system that proved to have vulnerabilities. Still, the mechanical failures he was presented with should have been no big deal . . . except that he experienced a real upset in the clouds and upon recovery he no doubt had a cabin full of excited passengers. Then while wrestling with the unbelievable fact that all this $high$ stuff with backups on top of backups was behaving in unanticipated, unpracticed ways he needed to revert to an alternate mode of flying the airplane. It's a situation that is exceedingly difficult to train for. I presume that a goodly number of our brothers are building airplanes they intend to use for point-A to point-B transportation. On long legged trips the probability of encountering less than clear weather is higher . . . and the possibilities for having company in the cabin goes up. This paints a different situation than one experiences while under the hood with a pilot riding shotgun who can SEE what's really going on. The shape of the airframe/pilot performance limits envelope is different, variable and many features cannot be anticipated. If one EXPECTS to bore holes in clouds and wants the minimum cost of ownership for a reversion mode of flight management where the risks are on a par with flight by stable gyro presentations, then a wing leveler is THE solution. My personal vision of the ideal machine for poking around in the fog has dual wing levelers with a failure monitor system. This suit of hardware would be expected to do ALL handling of the ailerons while in IMC. Then I can leave all the presentations off the panel because they're no longer needed and the cost of ownership for having them goes to zero. Over the lifetime of the airplane where I would expect to spend less than a few percent of total flight time in IMC, the dual wing-leveler system offers exceedingly low $ownership$ and risk compared to the legacy systems the gray-beards have grown up with. That doesn't mean others among us shouldn't embrace and even enjoy owning and operating a legacy system. It's a matter of design goals. If one enjoys stalking game with a bow and arrow and the risk of going hungry is low or immaterial, great. But if one needs to provide food for himself and perhaps others . . . and technology enhanced tools for harvesting game are available, then the optimum choice is clear. If a builder is considering N/B/AS referenced flight as a backup for "safe" flight, then he/she must be anticipating some willingness (or accidental probability) for venturing into clouds. So no matter how good you, I or anyone else is with the legacy flight instrumentation systems, we are remiss in our duties as teachers if we do not explain all of TODAY'S options and assist the readers in understanding requirements for getting a low risk return on the cost of ownership. The low cost installation commits one to a future investment of $time$ that should be fully explained while the builder is still in the decision making phase and before hardware is purchased and holes cut in the panel. This isn't about anyone else's levels of skill or personal preferences. It's a study of return on investment and options for real risk reduction. Bob . . . ________________________________________________________________________________
Date: Mar 04, 2007
I'll throw another variable into the equation. Under the heading of "GPS ain't no guarantee neither"... Yesterday while flying Eastbound under the floor of the rather complex Class B airspace north of Dallas, my GPS suddenly said "No Sat", and flopped over on its back. I figured it was just a quick "blink" and kept flying. It stayed offline. I flew a 360 to see if it would reaquire on any other satellites, but it didn't. I rebooted it. I rebooted the PDA it was hooked to. I rebooted the WX Worx box. I checked the power lights. (All while staying upright and without busting the Class B). Since I was trying to get from Dallas to Shreveport, I powered up my backup Loran and looked up a few VORs while I was at it. Then I used the Loran to give me the distance from the Addison airport whose airspace I also needed to stay out of. Finally, I decided I had time to go land at McKinney and figure out what was wrong with the GPS, and at that instant, it came back online and stayed that way all the way to Shreveport and back. What I neglected to try was powering off my COM radios, since there are reports that some local oscillator frequencies interfere with GPS under certain conditions. I didn't have the luxury of powering off my transponder, since I was deep inside the Mode C circle. But here's a case where high technology failed and it was a good thing to have a backup. Dave Morris At 10:41 AM 3/4/2007, you wrote: > > > >>Good Morning 'Lectric Bob, >> >>Thank you for the very complete analysis of my position on the >>validity of using a T&B and venturi as a low cost back up to >>whatever else is deemed desirable in a flying machine. >> >>I have been reading your freely presented views since the days when >>the connection was from Down By The Riverside Press. (or, something >>close to that) >> >>Always a pleasure and your writings are always able to jiggle some >>thought out of my very uneducated brain. >> >>Nevertheless, I do think my responses have some merit. >> >>The original question that started this particular string had to do >>with providing a low cost source of vacuum. >> >>The Venturi is a low cost option. > > No argument. > >> >>It is susceptible to icing, but when placed in a warm airstream >>behind the engine it has been shown to handle ice quite well. >>Vacuum pumps do fail. Especially the modern dry pumps if they are >>not replaced or serviced in accordance with the manufacturers instructions. >> >>I still think the venturi is a viable option. > > Also no argument. > >> >>I recognize that you cannot take the time to read everything on >>this list. However, I think you would find that I have always said >>that I will happily embrace a newer technology whenever it fits my >>needs (and my price point!). There is nothing I would like better >>than having a solid state autopilot that would be reliable enough >>such that I did not have to know how to fly by instruments to be >>able to operate in cloud. >> >>If I were to be dropped in the wilderness with nothing to sustain >>me, I would surely die. Many of my ancestors would have been able >>to survive in those same conditions. >> >>Having accepted modern conveniences to keep me alive, I think I >>would be able to accept fully automatic flight sometime in the future. >> >>Just not yet. > > Which IS your preference . . . > >> >>I recognize that I am old and am happy with current knowledge. It >>does allow me to feel comfortable flying a lot of those flying >>machines that are "rotting away". >> >>If the new breed of aviators is comfortable flying without the >>ability to control their flying machine while in cloud, that is fine with me. >> >>The venturi powered T&B in my Stearman is very comforting. >> >>You infer that flying a partial panel is difficult. I contend that >>it is NOT particularly difficult, IF adequate training has been received. > > "IF" is the operative word here . . . > >> >>There is no doubt that the skill is being lost. Most larger >>airliners lost their T&Bs almost forty years ago. To my knowledge, >>none ever had a turn coordinator. >> >>Chances are that many of the more modern airline pilots would have >>a problem flying with the basic needle ball and airspeed. >> >>I contend that the skill is relatively easy to attain ... IF the >>skill is desired! >> >>You very correctly stated that a skill not exercised tends to be >>lost. One of the reasons I like the T&B over the TC is because I >>find it relatively easy to integrate into my basic scan. I do so by >>using the T&B to check my rate of turn even though basic attitude >>reference is being obtained from an artificial horizon. This day >>and age, rate of turn is not regularly considered, but by keeping >>the rate of turn in mind, I force myself to include the T&B in my >>normal scan which makes it much easier for me to use should a failure occur. >> >>You make reference to my background as a professional pilot. >> >>I agree that I have had an opportunity that not every pilot has, >>needs, or wants. However, I have also been a flight instructor for >>fifty-eight years and in those fifty-eight years have trained many >>an instrument pilot. Not all of them have retained their partial >>panel skills, but many have! >> >>I do not contend that my way is the only way, just that it is a useful way. >> >>I see that I have wandered all over the landscape where the >>original intent was to suggest a low cost source of vacuum to >>someone who was looking for such a source. >> >>Once again, my lack of education has done me in, --- but I am having fun! > > That's what it's all about. Fun and risk reduction. > You've offered nothing that's arguable. Nor have I. > You've encouraged new builders to take advantage of > a system that has a exceedingly low initial cost and > if they're willing to do the investment of $time$ for > training and sustaining the skill, it's one option. > > My approach is that of a systems integrator where > the pilot is a close second place behind the airframe > in the study of need for reliability in flight system > components. > > I have observed first-hand how a pilot who took all the > courses, spent a lot of time in his airplane, and outfitted > it with everything you and I both would recommend . . . > except a stand alone wing-leveler that would back up > the very expensive system that proved to have > vulnerabilities. Still, the mechanical failures he > was presented with should have been no big deal . . . > except that he experienced a real upset in the clouds and > upon recovery he no doubt had a cabin full of excited > passengers. Then while wrestling with the unbelievable > fact that all this $high$ stuff with backups on top > of backups was behaving in unanticipated, unpracticed > ways he needed to revert to an alternate mode of > flying the airplane. It's a situation that is exceedingly > difficult to train for. > > I presume that a goodly number of our brothers are > building airplanes they intend to use for point-A > to point-B transportation. On long legged trips the > probability of encountering less than clear weather > is higher . . . and the possibilities for having > company in the cabin goes up. This paints a different > situation than one experiences while under the hood > with a pilot riding shotgun who can SEE what's really > going on. The shape of the airframe/pilot performance > limits envelope is different, variable and many features > cannot be anticipated. > > If one EXPECTS to bore holes in clouds and wants the > minimum cost of ownership for a reversion mode of > flight management where the risks are on a par with > flight by stable gyro presentations, then a wing > leveler is THE solution. My personal vision of the > ideal machine for poking around in the fog has dual > wing levelers with a failure monitor system. This > suit of hardware would be expected to do ALL handling > of the ailerons while in IMC. Then I can leave all > the presentations off the panel because they're no > longer needed and the cost of ownership for having > them goes to zero. > > Over the lifetime of the airplane where I would > expect to spend less than a few percent of total > flight time in IMC, the dual wing-leveler system > offers exceedingly low $ownership$ and risk compared to > the legacy systems the gray-beards have grown > up with. > > That doesn't mean others among us shouldn't embrace > and even enjoy owning and operating a legacy system. > It's a matter of design goals. If one enjoys > stalking game with a bow and arrow and the risk of > going hungry is low or immaterial, great. But if one needs > to provide food for himself and perhaps others . . . > and technology enhanced tools for harvesting game > are available, then the optimum choice is clear. > > If a builder is considering N/B/AS referenced flight > as a backup for "safe" flight, then he/she must > be anticipating some willingness (or accidental > probability) for venturing into clouds. So no > matter how good you, I or anyone else is with > the legacy flight instrumentation systems, we are > remiss in our duties as teachers if we do not > explain all of TODAY'S options and assist the readers in > understanding requirements for getting a low risk > return on the cost of ownership. > > The low cost installation commits one to a future > investment of $time$ that should be fully explained > while the builder is still in the decision making phase > and before hardware is purchased and holes cut > in the panel. This isn't about anyone else's levels > of skill or personal preferences. It's a study of > return on investment and options for real risk reduction. > > Bob . . . > > ________________________________________________________________________________
Subject: Beginner advice needed and greatly appreciated!
Date: Mar 04, 2007
Hi Guys, I have been following this list for about 3 years. In the beginning 99.99% went over my head but now only 99.9% is not understood. One thing I have learned is that this is a great place to learn and get help. Ok, I am just starting to wire my capacitance fuel senders for a RV7. At present I have not acquired any tools. Over time my data base of saved "tooling messages" is quite extensive. Based on that knowledge and recent rereading of Bob's articles on the use of said tools I have formed a few questions that maybe someone can help me with. I know technique is critical. Regardless of price is it easier to get up to speed and precision with a tool like Daniels Mil Spec crimper or is the B&C RCT-1 just as (difficult / easy) to learn and master. My next question is what tools will I need to finish the RV wiring system. It may not seem like it but you have all been teaching me alot in a few short years. Thanks Paul ________________________________________________________________________________
Date: Mar 04, 2007
Probably not relevant to this specific problem, but worth noting... In the installation manuals for Garmin's 400W and 500W series units, it states the following: "Ground-based cell phones that are on, even in a monitoring state, can disrupt GPS performance." I know there have been all sorts of nebulous warnings floating around from time to time, but this is the first specific one I've seen. Hope it's useful to some of you guys... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dave N6030X Sent: Sunday, March 4, 2007 11:23 AM Subject: Re: AeroElectric-List: Backup Electric Vacuum Pump I'll throw another variable into the equation. Under the heading of "GPS ain't no guarantee neither"... Yesterday while flying Eastbound under the floor of the rather complex Class B airspace north of Dallas, my GPS suddenly said "No Sat", and flopped over on its back. I figured it was just a quick "blink" and kept flying. It stayed offline. I flew a 360 to see if it would reaquire on any other satellites, but it didn't. I rebooted it. I rebooted the PDA it was hooked to. I rebooted the WX Worx box. I checked the power lights. (All while staying upright and without busting the Class B). Since I was trying to get from Dallas to Shreveport, I powered up my backup Loran and looked up a few VORs while I was at it. Then I used the Loran to give me the distance from the Addison airport whose airspace I also needed to stay out of. Finally, I decided I had time to go land at McKinney and figure out what was wrong with the GPS, and at that instant, it came back online and stayed that way all the way to Shreveport and back. What I neglected to try was powering off my COM radios, since there are reports that some local oscillator frequencies interfere with GPS under certain conditions. I didn't have the luxury of powering off my transponder, since I was deep inside the Mode C circle. But here's a case where high technology failed and it was a good thing to have a backup. Dave Morris At 10:41 AM 3/4/2007, you wrote: > > > >>Good Morning 'Lectric Bob, >> >>Thank you for the very complete analysis of my position on the >>validity of using a T&B and venturi as a low cost back up to >>whatever else is deemed desirable in a flying machine. >> >>I have been reading your freely presented views since the days when >>the connection was from Down By The Riverside Press. (or, something >>close to that) >> >>Always a pleasure and your writings are always able to jiggle some >>thought out of my very uneducated brain. >> >>Nevertheless, I do think my responses have some merit. >> >>The original question that started this particular string had to do >>with providing a low cost source of vacuum. >> >>The Venturi is a low cost option. > > No argument. > >> >>It is susceptible to icing, but when placed in a warm airstream >>behind the engine it has been shown to handle ice quite well. >>Vacuum pumps do fail. Especially the modern dry pumps if they are >>not replaced or serviced in accordance with the manufacturers instructions. >> >>I still think the venturi is a viable option. > > Also no argument. > >> >>I recognize that you cannot take the time to read everything on >>this list. However, I think you would find that I have always said >>that I will happily embrace a newer technology whenever it fits my >>needs (and my price point!). There is nothing I would like better >>than having a solid state autopilot that would be reliable enough >>such that I did not have to know how to fly by instruments to be >>able to operate in cloud. >> >>If I were to be dropped in the wilderness with nothing to sustain >>me, I would surely die. Many of my ancestors would have been able >>to survive in those same conditions. >> >>Having accepted modern conveniences to keep me alive, I think I >>would be able to accept fully automatic flight sometime in the future. >> >>Just not yet. > > Which IS your preference . . . > >> >>I recognize that I am old and am happy with current knowledge. It >>does allow me to feel comfortable flying a lot of those flying >>machines that are "rotting away". >> >>If the new breed of aviators is comfortable flying without the >>ability to control their flying machine while in cloud, that is fine with me. >> >>The venturi powered T&B in my Stearman is very comforting. >> >>You infer that flying a partial panel is difficult. I contend that >>it is NOT particularly difficult, IF adequate training has been received. > > "IF" is the operative word here . . . > >> >>There is no doubt that the skill is being lost. Most larger >>airliners lost their T&Bs almost forty years ago. To my knowledge, >>none ever had a turn coordinator. >> >>Chances are that many of the more modern airline pilots would have >>a problem flying with the basic needle ball and airspeed. >> >>I contend that the skill is relatively easy to attain ... IF the >>skill is desired! >> >>You very correctly stated that a skill not exercised tends to be >>lost. One of the reasons I like the T&B over the TC is because I >>find it relatively easy to integrate into my basic scan. I do so by >>using the T&B to check my rate of turn even though basic attitude >>reference is being obtained from an artificial horizon. This day >>and age, rate of turn is not regularly considered, but by keeping >>the rate of turn in mind, I force myself to include the T&B in my >>normal scan which makes it much easier for me to use should a failure occur. >> >>You make reference to my background as a professional pilot. >> >>I agree that I have had an opportunity that not every pilot has, >>needs, or wants. However, I have also been a flight instructor for >>fifty-eight years and in those fifty-eight years have trained many >>an instrument pilot. Not all of them have retained their partial >>panel skills, but many have! >> >>I do not contend that my way is the only way, just that it is a useful way. >> >>I see that I have wandered all over the landscape where the >>original intent was to suggest a low cost source of vacuum to >>someone who was looking for such a source. >> >>Once again, my lack of education has done me in, --- but I am having fun! > > That's what it's all about. Fun and risk reduction. > You've offered nothing that's arguable. Nor have I. > You've encouraged new builders to take advantage of > a system that has a exceedingly low initial cost and > if they're willing to do the investment of $time$ for > training and sustaining the skill, it's one option. > > My approach is that of a systems integrator where > the pilot is a close second place behind the airframe > in the study of need for reliability in flight system > components. > > I have observed first-hand how a pilot who took all the > courses, spent a lot of time in his airplane, and outfitted > it with everything you and I both would recommend . . . > except a stand alone wing-leveler that would back up > the very expensive system that proved to have > vulnerabilities. Still, the mechanical failures he > was presented with should have been no big deal . . . > except that he experienced a real upset in the clouds and > upon recovery he no doubt had a cabin full of excited > passengers. Then while wrestling with the unbelievable > fact that all this $high$ stuff with backups on top > of backups was behaving in unanticipated, unpracticed > ways he needed to revert to an alternate mode of > flying the airplane. It's a situation that is exceedingly > difficult to train for. > > I presume that a goodly number of our brothers are > building airplanes they intend to use for point-A > to point-B transportation. On long legged trips the > probability of encountering less than clear weather > is higher . . . and the possibilities for having > company in the cabin goes up. This paints a different > situation than one experiences while under the hood > with a pilot riding shotgun who can SEE what's really > going on. The shape of the airframe/pilot performance > limits envelope is different, variable and many features > cannot be anticipated. > > If one EXPECTS to bore holes in clouds and wants the > minimum cost of ownership for a reversion mode of > flight management where the risks are on a par with > flight by stable gyro presentations, then a wing > leveler is THE solution. My personal vision of the > ideal machine for poking around in the fog has dual > wing levelers with a failure monitor system. This > suit of hardware would be expected to do ALL handling > of the ailerons while in IMC. Then I can leave all > the presentations off the panel because they're no > longer needed and the cost of ownership for having > them goes to zero. > > Over the lifetime of the airplane where I would > expect to spend less than a few percent of total > flight time in IMC, the dual wing-leveler system > offers exceedingly low $ownership$ and risk compared to > the legacy systems the gray-beards have grown > up with. > > That doesn't mean others among us shouldn't embrace > and even enjoy owning and operating a legacy system. > It's a matter of design goals. If one enjoys > stalking game with a bow and arrow and the risk of > going hungry is low or immaterial, great. But if one needs > to provide food for himself and perhaps others . . . > and technology enhanced tools for harvesting game > are available, then the optimum choice is clear. > > If a builder is considering N/B/AS referenced flight > as a backup for "safe" flight, then he/she must > be anticipating some willingness (or accidental > probability) for venturing into clouds. So no > matter how good you, I or anyone else is with > the legacy flight instrumentation systems, we are > remiss in our duties as teachers if we do not > explain all of TODAY'S options and assist the readers in > understanding requirements for getting a low risk > return on the cost of ownership. > > The low cost installation commits one to a future > investment of $time$ that should be fully explained > while the builder is still in the decision making phase > and before hardware is purchased and holes cut > in the panel. This isn't about anyone else's levels > of skill or personal preferences. It's a study of > return on investment and options for real risk reduction. > > Bob . . . > > ________________________________________________________________________________
Subject: SL30 and Dynon
Date: Mar 04, 2007
I would like to get opinions and thoughts from anyone driving the HSI feature of the Dynon D10A or D100 from a Garmin SL30 Garmin. I'm thinking of doing this in lieu of having a DG and a CDI/LOC/GS/GPS indicator like a MD200-306 indicator and wondering about the pros and cons of this. I already have a Altitude Indicator. Marty ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Backup Electric Vacuum Pump
That's a very interesting point, because it was the one time I've flown in the past 5 months where I accidentally left my cellphone turned on in my coat pocket all the way in the baggage compartment and couldn't reach it, so I just left it alone. Hmmmmmmmm Dave Morirs At 03:12 PM 3/4/2007, you wrote: > >Probably not relevant to this specific problem, but worth noting... > >In the installation manuals for Garmin's 400W and 500W series units, it >states the following: > >"Ground-based cell phones that are on, even in a monitoring state, can >disrupt GPS performance." > >I know there have been all sorts of nebulous warnings floating around from >time to time, but this is the first specific one I've seen. > >Hope it's useful to some of you guys... > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dave >N6030X >Sent: Sunday, March 4, 2007 11:23 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Backup Electric Vacuum Pump > > >I'll throw another variable into the equation. Under the heading of >"GPS ain't no guarantee neither"... > >Yesterday while flying Eastbound under the floor of the rather >complex Class B airspace north of Dallas, my GPS suddenly said "No >Sat", and flopped over on its back. I figured it was just a quick >"blink" and kept flying. It stayed offline. I flew a 360 to see if >it would reaquire on any other satellites, but it didn't. I rebooted >it. I rebooted the PDA it was hooked to. I rebooted the WX Worx >box. I checked the power lights. (All while staying upright and >without busting the Class B). > >Since I was trying to get from Dallas to Shreveport, I powered up my >backup Loran and looked up a few VORs while I was at it. Then I used >the Loran to give me the distance from the Addison airport whose >airspace I also needed to stay out of. Finally, I decided I had time >to go land at McKinney and figure out what was wrong with the GPS, >and at that instant, it came back online and stayed that way all the >way to Shreveport and back. > >What I neglected to try was powering off my COM radios, since there >are reports that some local oscillator frequencies interfere with GPS >under certain conditions. I didn't have the luxury of powering off >my transponder, since I was deep inside the Mode C circle. But >here's a case where high technology failed and it was a good thing to >have a backup. > >Dave Morris > > >At 10:41 AM 3/4/2007, you wrote: > > > > > > > >>Good Morning 'Lectric Bob, > >> > >>Thank you for the very complete analysis of my position on the > >>validity of using a T&B and venturi as a low cost back up to > >>whatever else is deemed desirable in a flying machine. > >> > >>I have been reading your freely presented views since the days when > >>the connection was from Down By The Riverside Press. (or, something > >>close to that) > >> > >>Always a pleasure and your writings are always able to jiggle some > >>thought out of my very uneducated brain. > >> > >>Nevertheless, I do think my responses have some merit. > >> > >>The original question that started this particular string had to do > >>with providing a low cost source of vacuum. > >> > >>The Venturi is a low cost option. > > > > No argument. > > > >> > >>It is susceptible to icing, but when placed in a warm airstream > >>behind the engine it has been shown to handle ice quite well. > >>Vacuum pumps do fail. Especially the modern dry pumps if they are > >>not replaced or serviced in accordance with the manufacturers >instructions. > >> > >>I still think the venturi is a viable option. > > > > Also no argument. > > > >> > >>I recognize that you cannot take the time to read everything on > >>this list. However, I think you would find that I have always said > >>that I will happily embrace a newer technology whenever it fits my > >>needs (and my price point!). There is nothing I would like better > >>than having a solid state autopilot that would be reliable enough > >>such that I did not have to know how to fly by instruments to be > >>able to operate in cloud. > >> > >>If I were to be dropped in the wilderness with nothing to sustain > >>me, I would surely die. Many of my ancestors would have been able > >>to survive in those same conditions. > >> > >>Having accepted modern conveniences to keep me alive, I think I > >>would be able to accept fully automatic flight sometime in the future. > >> > >>Just not yet. > > > > Which IS your preference . . . > > > >> > >>I recognize that I am old and am happy with current knowledge. It > >>does allow me to feel comfortable flying a lot of those flying > >>machines that are "rotting away". > >> > >>If the new breed of aviators is comfortable flying without the > >>ability to control their flying machine while in cloud, that is fine with >me. > >> > >>The venturi powered T&B in my Stearman is very comforting. > >> > >>You infer that flying a partial panel is difficult. I contend that > >>it is NOT particularly difficult, IF adequate training has been received. > > > > "IF" is the operative word here . . . > > > >> > >>There is no doubt that the skill is being lost. Most larger > >>airliners lost their T&Bs almost forty years ago. To my knowledge, > >>none ever had a turn coordinator. > >> > >>Chances are that many of the more modern airline pilots would have > >>a problem flying with the basic needle ball and airspeed. > >> > >>I contend that the skill is relatively easy to attain ... IF the > >>skill is desired! > >> > >>You very correctly stated that a skill not exercised tends to be > >>lost. One of the reasons I like the T&B over the TC is because I > >>find it relatively easy to integrate into my basic scan. I do so by > >>using the T&B to check my rate of turn even though basic attitude > >>reference is being obtained from an artificial horizon. This day > >>and age, rate of turn is not regularly considered, but by keeping > >>the rate of turn in mind, I force myself to include the T&B in my > >>normal scan which makes it much easier for me to use should a failure >occur. > >> > >>You make reference to my background as a professional pilot. > >> > >>I agree that I have had an opportunity that not every pilot has, > >>needs, or wants. However, I have also been a flight instructor for > >>fifty-eight years and in those fifty-eight years have trained many > >>an instrument pilot. Not all of them have retained their partial > >>panel skills, but many have! > >> > >>I do not contend that my way is the only way, just that it is a useful >way. > >> > >>I see that I have wandered all over the landscape where the > >>original intent was to suggest a low cost source of vacuum to > >>someone who was looking for such a source. > >> > >>Once again, my lack of education has done me in, --- but I am having fun! > > > > That's what it's all about. Fun and risk reduction. > > You've offered nothing that's arguable. Nor have I. > > You've encouraged new builders to take advantage of > > a system that has a exceedingly low initial cost and > > if they're willing to do the investment of $time$ for > > training and sustaining the skill, it's one option. > > > > My approach is that of a systems integrator where > > the pilot is a close second place behind the airframe > > in the study of need for reliability in flight system > > components. > > > > I have observed first-hand how a pilot who took all the > > courses, spent a lot of time in his airplane, and outfitted > > it with everything you and I both would recommend . . . > > except a stand alone wing-leveler that would back up > > the very expensive system that proved to have > > vulnerabilities. Still, the mechanical failures he > > was presented with should have been no big deal . . . > > except that he experienced a real upset in the clouds and > > upon recovery he no doubt had a cabin full of excited > > passengers. Then while wrestling with the unbelievable > > fact that all this $high$ stuff with backups on top > > of backups was behaving in unanticipated, unpracticed > > ways he needed to revert to an alternate mode of > > flying the airplane. It's a situation that is exceedingly > > difficult to train for. > > > > I presume that a goodly number of our brothers are > > building airplanes they intend to use for point-A > > to point-B transportation. On long legged trips the > > probability of encountering less than clear weather > > is higher . . . and the possibilities for having > > company in the cabin goes up. This paints a different > > situation than one experiences while under the hood > > with a pilot riding shotgun who can SEE what's really > > going on. The shape of the airframe/pilot performance > > limits envelope is different, variable and many features > > cannot be anticipated. > > > > If one EXPECTS to bore holes in clouds and wants the > > minimum cost of ownership for a reversion mode of > > flight management where the risks are on a par with > > flight by stable gyro presentations, then a wing > > leveler is THE solution. My personal vision of the > > ideal machine for poking around in the fog has dual > > wing levelers with a failure monitor system. This > > suit of hardware would be expected to do ALL handling > > of the ailerons while in IMC. Then I can leave all > > the presentations off the panel because they're no > > longer needed and the cost of ownership for having > > them goes to zero. > > > > Over the lifetime of the airplane where I would > > expect to spend less than a few percent of total > > flight time in IMC, the dual wing-leveler system > > offers exceedingly low $ownership$ and risk compared to > > the legacy systems the gray-beards have grown > > up with. > > > > That doesn't mean others among us shouldn't embrace > > and even enjoy owning and operating a legacy system. > > It's a matter of design goals. If one enjoys > > stalking game with a bow and arrow and the risk of > > going hungry is low or immaterial, great. But if one needs > > to provide food for himself and perhaps others . . . > > and technology enhanced tools for harvesting game > > are available, then the optimum choice is clear. > > > > If a builder is considering N/B/AS referenced flight > > as a backup for "safe" flight, then he/she must > > be anticipating some willingness (or accidental > > probability) for venturing into clouds. So no > > matter how good you, I or anyone else is with > > the legacy flight instrumentation systems, we are > > remiss in our duties as teachers if we do not > > explain all of TODAY'S options and assist the readers in > > understanding requirements for getting a low risk > > return on the cost of ownership. > > > > The low cost installation commits one to a future > > investment of $time$ that should be fully explained > > while the builder is still in the decision making phase > > and before hardware is purchased and holes cut > > in the panel. This isn't about anyone else's levels > > of skill or personal preferences. It's a study of > > return on investment and options for real risk reduction. > > > > Bob . . . > > > > > > > > > > > > ________________________________________________________________________________
Date: Mar 04, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: 18 AH Battery Test Data
>Listers, >FWIW I have been following the procedure of replacing my 18/17.X AH RG >battery annually for the last two years. This year, I decided to do an >endurance test on the "old" battery. Using an automotive two filament >headlamp with the filaments in parallel, I was able to start at a current >of 6.7 amps drain to simulate an endurance buss demand with a failed >alternator. The battery has been used for one year including about 40 >flight hours and 50 engine starts. >The battery is a 17-18 AH sold by Batteries Plus sometimes with the name >Xtreme Plus. >My engine is an O-320 with 110 plus hours on it. These batteries turn the >engine over very "smartly" only observed at temperatures above 60F. >At the beginning of the test, the current was 6.7 A and at the end at 5.6 >A . This decline is partly explained by the voltage decline as well as >filament resistance decrease with temperature in the lamp. >These results are consistent with the specification sheet provided for the >Xtreme Plus batteries which predicts a two hour endurance at 6A. > >Regards, > >Richard Dudley Good data sir. Thanks for sharing. Richard's experiment underscores the idea that MOST RG/VSLA batteries are capable of providing satisfactory service for periods of more than a year. The problem to be cited and solved is what are YOUR personal requirements for support of electro-whizzies in the alternator-out, endurance mode? Further, what is your $time$ and $equipment$ investments worth to track your battery's performance? I have a number of batteries in the shop that are used for various portable power applications . . . some are over 5 years old. Some are down to less than 80% of original capacity. However, the equipment needed to check a battery's present ability is always available as a standard component of my professional tools. The $time$ for me to put a dipstick into a battery's capacity takes perhaps two minutes total time. One minute to hook it up to the tester and another minute to return it to the rack where a Battery Minder will top it off. When I grab a battery and saddle up to do a task, I know what the battery can be expected to do for me. A lot of folks got upset at my recommendation for yearly replacement of the ship's battery. But if you can buy an 18/20 AH battery for about $30 then what is the cost of ownership trade off to test the battery perhaps one or two times to determine serviceability over the lifetime of the battery? Obviously, the more expensive the battery, the more likely it is that acquiring and using test equipment becomes attractive. Richard didn't describe his own operating requirements for load and endurance but it seems likely that he might use the battery for another year. Assuming he tests in another year and then discards the battery, his cost of ownership is ($acquisition$) + 2x($test$) divided by 2. Nobody is in a position to make any really useful recommendations for battery replacement without having a lot of data about how you expect your battery to perform and knowing what your $time$ is worth when expended on the task of battery maintenance. Bob . . . ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Re: Backup Electric Vacuum Pump
Remember - the feds can turn off the GPS system with any perceived threat - so I'd be careful about pure IMC in an A/C where GPS is only source of data. I noted it was "down" during the Super bowl. bobf Dave N6030X wrote: > > > That's a very interesting point, because it was the one time I've > flown in the past 5 months where I accidentally left my cellphone > turned on in my coat pocket all the way in the baggage compartment and > couldn't reach it, so I just left it alone. Hmmmmmmmm > > Dave Morirs > > At 03:12 PM 3/4/2007, you wrote: >> >> >> Probably not relevant to this specific problem, but worth noting... >> >> In the installation manuals for Garmin's 400W and 500W series units, it >> states the following: >> >> "Ground-based cell phones that are on, even in a monitoring state, can >> disrupt GPS performance." >> >> I know there have been all sorts of nebulous warnings floating around >> from >> time to time, but this is the first specific one I've seen. >> >> Hope it's useful to some of you guys... >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dave >> N6030X >> Sent: Sunday, March 4, 2007 11:23 AM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Backup Electric Vacuum Pump >> >> >> >> >> I'll throw another variable into the equation. Under the heading of >> "GPS ain't no guarantee neither"... >> >> Yesterday while flying Eastbound under the floor of the rather >> complex Class B airspace north of Dallas, my GPS suddenly said "No >> Sat", and flopped over on its back. I figured it was just a quick >> "blink" and kept flying. It stayed offline. I flew a 360 to see if >> it would reaquire on any other satellites, but it didn't. I rebooted >> it. I rebooted the PDA it was hooked to. I rebooted the WX Worx >> box. I checked the power lights. (All while staying upright and >> without busting the Class B). >> >> Since I was trying to get from Dallas to Shreveport, I powered up my >> backup Loran and looked up a few VORs while I was at it. Then I used >> the Loran to give me the distance from the Addison airport whose >> airspace I also needed to stay out of. Finally, I decided I had time >> to go land at McKinney and figure out what was wrong with the GPS, >> and at that instant, it came back online and stayed that way all the >> way to Shreveport and back. >> >> What I neglected to try was powering off my COM radios, since there >> are reports that some local oscillator frequencies interfere with GPS >> under certain conditions. I didn't have the luxury of powering off >> my transponder, since I was deep inside the Mode C circle. But >> here's a case where high technology failed and it was a good thing to >> have a backup. >> >> Dave Morris >> >> >> At 10:41 AM 3/4/2007, you wrote: >> > >> > >> > >> >>Good Morning 'Lectric Bob, >> >> >> >>Thank you for the very complete analysis of my position on the >> >>validity of using a T&B and venturi as a low cost back up to >> >>whatever else is deemed desirable in a flying machine. >> >> >> >>I have been reading your freely presented views since the days when >> >>the connection was from Down By The Riverside Press. (or, something >> >>close to that) >> >> >> >>Always a pleasure and your writings are always able to jiggle some >> >>thought out of my very uneducated brain. >> >> >> >>Nevertheless, I do think my responses have some merit. >> >> >> >>The original question that started this particular string had to do >> >>with providing a low cost source of vacuum. >> >> >> >>The Venturi is a low cost option. >> > >> > No argument. >> > >> >> >> >>It is susceptible to icing, but when placed in a warm airstream >> >>behind the engine it has been shown to handle ice quite well. >> >>Vacuum pumps do fail. Especially the modern dry pumps if they are >> >>not replaced or serviced in accordance with the manufacturers >> instructions. >> >> >> >>I still think the venturi is a viable option. >> > >> > Also no argument. >> > >> >> >> >>I recognize that you cannot take the time to read everything on >> >>this list. However, I think you would find that I have always said >> >>that I will happily embrace a newer technology whenever it fits my >> >>needs (and my price point!). There is nothing I would like better >> >>than having a solid state autopilot that would be reliable enough >> >>such that I did not have to know how to fly by instruments to be >> >>able to operate in cloud. >> >> >> >>If I were to be dropped in the wilderness with nothing to sustain >> >>me, I would surely die. Many of my ancestors would have been able >> >>to survive in those same conditions. >> >> >> >>Having accepted modern conveniences to keep me alive, I think I >> >>would be able to accept fully automatic flight sometime in the future. >> >> >> >>Just not yet. >> > >> > Which IS your preference . . . >> > >> >> >> >>I recognize that I am old and am happy with current knowledge. It >> >>does allow me to feel comfortable flying a lot of those flying >> >>machines that are "rotting away". >> >> >> >>If the new breed of aviators is comfortable flying without the >> >>ability to control their flying machine while in cloud, that is >> fine with >> me. >> >> >> >>The venturi powered T&B in my Stearman is very comforting. >> >> >> >>You infer that flying a partial panel is difficult. I contend that >> >>it is NOT particularly difficult, IF adequate training has been >> received. >> > >> > "IF" is the operative word here . . . >> > >> >> >> >>There is no doubt that the skill is being lost. Most larger >> >>airliners lost their T&Bs almost forty years ago. To my knowledge, >> >>none ever had a turn coordinator. >> >> >> >>Chances are that many of the more modern airline pilots would have >> >>a problem flying with the basic needle ball and airspeed. >> >> >> >>I contend that the skill is relatively easy to attain ... IF the >> >>skill is desired! >> >> >> >>You very correctly stated that a skill not exercised tends to be >> >>lost. One of the reasons I like the T&B over the TC is because I >> >>find it relatively easy to integrate into my basic scan. I do so by >> >>using the T&B to check my rate of turn even though basic attitude >> >>reference is being obtained from an artificial horizon. This day >> >>and age, rate of turn is not regularly considered, but by keeping >> >>the rate of turn in mind, I force myself to include the T&B in my >> >>normal scan which makes it much easier for me to use should a failure >> occur. >> >> >> >>You make reference to my background as a professional pilot. >> >> >> >>I agree that I have had an opportunity that not every pilot has, >> >>needs, or wants. However, I have also been a flight instructor for >> >>fifty-eight years and in those fifty-eight years have trained many >> >>an instrument pilot. Not all of them have retained their partial >> >>panel skills, but many have! >> >> >> >>I do not contend that my way is the only way, just that it is a useful >> way. >> >> >> >>I see that I have wandered all over the landscape where the >> >>original intent was to suggest a low cost source of vacuum to >> >>someone who was looking for such a source. >> >> >> >>Once again, my lack of education has done me in, --- but I am >> having fun! >> > >> > That's what it's all about. Fun and risk reduction. >> > You've offered nothing that's arguable. Nor have I. >> > You've encouraged new builders to take advantage of >> > a system that has a exceedingly low initial cost and >> > if they're willing to do the investment of $time$ for >> > training and sustaining the skill, it's one option. >> > >> > My approach is that of a systems integrator where >> > the pilot is a close second place behind the airframe >> > in the study of need for reliability in flight system >> > components. >> > >> > I have observed first-hand how a pilot who took all the >> > courses, spent a lot of time in his airplane, and outfitted >> > it with everything you and I both would recommend . . . >> > except a stand alone wing-leveler that would back up >> > the very expensive system that proved to have >> > vulnerabilities. Still, the mechanical failures he >> > was presented with should have been no big deal . . . >> > except that he experienced a real upset in the clouds and >> > upon recovery he no doubt had a cabin full of excited >> > passengers. Then while wrestling with the unbelievable >> > fact that all this $high$ stuff with backups on top >> > of backups was behaving in unanticipated, unpracticed >> > ways he needed to revert to an alternate mode of >> > flying the airplane. It's a situation that is exceedingly >> > difficult to train for. >> > >> > I presume that a goodly number of our brothers are >> > building airplanes they intend to use for point-A >> > to point-B transportation. On long legged trips the >> > probability of encountering less than clear weather >> > is higher . . . and the possibilities for having >> > company in the cabin goes up. This paints a different >> > situation than one experiences while under the hood >> > with a pilot riding shotgun who can SEE what's really >> > going on. The shape of the airframe/pilot performance >> > limits envelope is different, variable and many features >> > cannot be anticipated. >> > >> > If one EXPECTS to bore holes in clouds and wants the >> > minimum cost of ownership for a reversion mode of >> > flight management where the risks are on a par with >> > flight by stable gyro presentations, then a wing >> > leveler is THE solution. My personal vision of the >> > ideal machine for poking around in the fog has dual >> > wing levelers with a failure monitor system. This >> > suit of hardware would be expected to do ALL handling >> > of the ailerons while in IMC. Then I can leave all >> > the presentations off the panel because they're no >> > longer needed and the cost of ownership for having >> > them goes to zero. >> > >> > Over the lifetime of the airplane where I would >> > expect to spend less than a few percent of total >> > flight time in IMC, the dual wing-leveler system >> > offers exceedingly low $ownership$ and risk compared to >> > the legacy systems the gray-beards have grown >> > up with. >> > >> > That doesn't mean others among us shouldn't embrace >> > and even enjoy owning and operating a legacy system. >> > It's a matter of design goals. If one enjoys >> > stalking game with a bow and arrow and the risk of >> > going hungry is low or immaterial, great. But if one needs >> > to provide food for himself and perhaps others . . . >> > and technology enhanced tools for harvesting game >> > are available, then the optimum choice is clear. >> > >> > If a builder is considering N/B/AS referenced flight >> > as a backup for "safe" flight, then he/she must >> > be anticipating some willingness (or accidental >> > probability) for venturing into clouds. So no >> > matter how good you, I or anyone else is with >> > the legacy flight instrumentation systems, we are >> > remiss in our duties as teachers if we do not >> > explain all of TODAY'S options and assist the readers in >> > understanding requirements for getting a low risk >> > return on the cost of ownership. >> > >> > The low cost installation commits one to a future >> > investment of $time$ that should be fully explained >> > while the builder is still in the decision making phase >> > and before hardware is purchased and holes cut >> > in the panel. This isn't about anyone else's levels >> > of skill or personal preferences. It's a study of >> > return on investment and options for real risk reduction. >> > >> > Bob . . . >> > >> > >> > >> > >> > >> >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Re: Battery Tenders as recharging tools . . .
> >Many thanks Bob. My charger from Napa does not seem to bring the charge >up beyond 12.5v even when the charger has been on the battery for 5 >days. You need to track and plot the voltage during the recharge cycle on a battery you know has been discharged to some substantial degree. One expects the voltage to be sustained at about 13.0 volts after a recharge cycle has terminated. See: http://www.aeroelectric.com/Pictures/Curves/schumacher_2.jpg and http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf What you may be seeing after 5 days is the charger's normal drop to a sustaining level after the battery has been topped off. What brand of charger is it? Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Re: Beginner advice needed and greatly appreciated!
> >Hi Guys, > >I have been following this list for about 3 years. In the beginning >99.99% went over my head but now only 99.9% is not understood. One thing >I have learned is that this is a great place to learn and get help. > >Ok, I am just starting to wire my capacitance fuel senders for a RV7. At >present I have not acquired any tools. Over time my data base of saved >"tooling messages" is quite extensive. Based on that knowledge and recent >rereading of Bob's articles on the use of said tools I have formed a few >questions that maybe someone can help me with. > > I know technique is critical. Regardless of price is it easier to get > up to speed and precision with a tool like Daniels Mil Spec crimper or is > the B&C RCT-1 just as (difficult / easy) to learn and master. The RCT-1 is for PIDG terminals. Daniels tools >My next question is what tools will I need to finish the RV wiring system. >It may not seem like it but you have all been teaching me alot in a few >short years. Thanks Have you reviewed the article on "Getting Started" that I posted at: http://aeroelectric.com/articles/Getting_Started.pdf The commonly needed crimp tools and their applications are discussed in this piece. For the most part you can get all the tools you'll need at decent prices at: http://bandc.biz http://steinair.com although there are many other places you could look too. Harbor Freight has been offering a satisfactory PIDG tool at: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93977 This is probably the first tool you need to acquire and is equivalent to the ratchet-handle, PIDG tools sold at many stores. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 04, 2007
Paul You need to do a few test crimps no matter what tool you choose. Bob's comic book articles are quite useful. I think you will be pleased with anything from places like B&C or Steinair. It is always possible to mess up a crimp no matter what the tool but there is not much more risk going economical in my opinion and you will likely be surprised at how easy it is. I was. Ken Paul K wrote: > > Hi Guys, > > I have been following this list for about 3 years. In the beginning > 99.99% went over my head but now only 99.9% is not understood. One > thing I have learned is that this is a great place to learn and get help. > > Ok, I am just starting to wire my capacitance fuel senders for a RV7. > At present I have not acquired any tools. Over time my data base of > saved "tooling messages" is quite extensive. Based on that knowledge > and recent rereading of Bob's articles on the use of said tools I have > formed a few questions that maybe someone can help me with. > > I know technique is critical. Regardless of price is it easier to > get up to speed and precision with a tool like Daniels Mil Spec > crimper or is the B&C RCT-1 just as (difficult / easy) to learn and > master. > > My next question is what tools will I need to finish the RV wiring > system. It may not seem like it but you have all been teaching me alot > in a few short years. Thanks > > Paul ________________________________________________________________________________
Subject: RE: SL30 and Dynon
Date: Mar 04, 2007
Oops, I mean Attitude Indicator, it's electric not vacuum. Marty -----Original Message----- From: Emrath [mailto:emrath(at)comcast.net] Sent: Sunday, March 04, 2007 3:24 PM Subject: SL30 and Dynon I would like to get opinions and thoughts from anyone driving the HSI feature of the Dynon D10A or D100 from a Garmin SL30 Garmin. I'm thinking of doing this in lieu of having a DG and a CDI/LOC/GS/GPS indicator like a MD200-306 indicator and wondering about the pros and cons of this. I already have a Altitude Indicator. Marty ________________________________________________________________________________
Subject: Monitoring external temperatures
Date: Mar 04, 2007
Question: I would like to hear from anyone who has wired a temperature gauge such that a warning light indicator is illuminated when the temp falls below freezing (or some other significant value). Have you included an override to silence the warning light and did you build a delay into the mechanism to interrupt or disable the warning light? Thanks ________________________________________________________________________________
Date: Mar 04, 2007
Subject: Radio interference to instruments
>Comments/Questions: When I push my PTT switch to transmit on my radio I >get an increase in manifold pressure and either a large increase or >decrease in ammeter reading. This is intermittent and happens about 80% >of the time. All works great with the radio off. Sounds like these instruments were not designed to live in the real world of airplanes. They seem to suffer from radio frequency interference. Check your coax cables from transceiver to antenna. If the shield ground comes loose at either end, the coax can radiate very strongly into airframe wiring. You might try putting a ferrite cable-choke-core over the bundles going into the back of these instruments. See: http://tinyurl.com/28bdgm Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Subject: Stolen aircraft... C-FBCG...help requested
Date: Mar 04, 2007
All listers, Although this is not specific to our list, please forgive me and have a look. Especially those located in BC, Alberta and the Pacific Northwest. Timely awareness/communication may help to solve this crime. Keep an eye out at your airport and pass this along to anyone/group you think may be able to help this guy find his aircraft. Bevan RV7A Finishing kit ----- Original Message ----- From: Gary West / PFC <mailto:kgwest(at)shaw.ca> Sent: Sunday, March 04, 2007 11:41 AM Subject: Missing, and presumed stolen airplane C182 C-FBCG...help requested please Hello fellow fliers........ I hope you can assist me in locating my aircraft which went missing the night of March 1 from Oliver Airport, in the south Okanagan of BC. It was last seen at the airport in March 1st morning and was not there when I went to check on the plane this afternoon, March 2nd. They picked the first clear night in a while and a nearly full moon to steal it. It may have been stolen for smuggling or it may be taken somewhere to be stripped or altered (e.g., painting or false registration) and then moved elsewhere over time. The plane is a 1966 Cessna 182, white in colour with two thin stripes along the side, one green and the other brown. It has Rosen sun visors (green pull down sun visors) and green tinted windows. As noted above it has the Canadian Registration C-FBCG on both sides of the fuselage in brown vinyl letters. It has a piece of purple carpet cover on the glare shield which will be visible through the window. Interior is avocado green as are the seats. It has wing strobes and a tail beacon. I've sent this to the COPA Flight contacts in BC and Alberta and I'm hoping that you might send this email to others in your clubs and to other nonmember pilots in your area in case the plane turns up at an airport near you. I suspect they took it south (we're only 15 miles north of the US border) and have notified all authorities there of the theft in case they can find it once the thieves are finished with it. However, I believe that other pilots will give me a better chance of finding it, since there are only so many places to land and there are COPA/AOPA members everywhere who may be able to assist with their eyes and ears at their airports. If you have contacts in Idaho, Washington or Montana please forward this email to them in case they see it. I just bought it as my move up aircraft last year and would like to get it back. I thought it was safe at a locked, fenced airport with doors locked but it appears that was not enough. I've included photos of the plane taken in January this year. If you have any information on this aircraft, please contact me by email or by phone at 250 498-2205. Alternatively, contact the police in your area and give them any information. The police file rests with the Oliver, BC detachment of the RCMP. Thanks for your consideration Bill Michael Osoyoos, BC -- 1:58 PM -- 1:58 PM ________________________________________________________________________________
Subject: Garmin 530W Install manual
Date: Mar 05, 2007
From: "Stewart, Michael (ISS Atlanta)" <mike.stewart(at)us.ibm.com>
On the downloads page, one link above the how to garmin link. Here is the direct link. Mike http://www2.mstewart.net:8080/Downloads/gns430w_IM.pdf -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim Lewis Sent: Saturday, March 03, 2007 11:24 AM Subject: AeroElectric-List: Garmin 530W Install manual Does anyone have access to a Garmin 530W Install manual? I've tried <http://www2.mstewart.net:8080/Downloads/howtogetagarminmanual.htm>, but I haven't stumbled on to the correct file name yet. Thanks, Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 850 hrs RV-10 #40059 under construction ________________________________________________________________________________
From: "McFarland, Randy" <Randy.McFarland(at)novellus.com>
Date: Mar 05, 2007
Thx for the question. I have the same problem. I have a SD8 and Denso 60amp being monitored by a EIS 4000 engine monitor. The alarm goes off almost every time I key the Mic PTT due to one or both Amp readings going out of limits (typically decrease) Doesn't seem to matter whether I am transmiting using Garmin 430 or KX125. I'll check my coax cabling and shields. Randy -----Original Message----- From: Robert L. Nuckolls, III [mailto:nuckollsr(at)cox.net] Sent: Sunday, March 04, 2007 8:36 PM Subject: AeroElectric-List: Radio interference to instruments >Comments/Questions: When I push my PTT switch to transmit on my radio I >get an increase in manifold pressure and either a large increase or >decrease in ammeter reading. This is intermittent and happens about 80% >of the time. All works great with the radio off. Sounds like these instruments were not designed to live in the real world of airplanes. They seem to suffer from radio frequency interference. Check your coax cables from transceiver to antenna. If the shield ground comes loose at either end, the coax can radiate very strongly into airframe wiring. You might try putting a ferrite cable-choke-core over the bundles going into the back of these instruments. See: http://tinyurl.com/28bdgm Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Expresspcb... Free CAD software
I've been playing around with express schematics CAD software for a while. It's pretty useful and it's "free". Anyone else out there using this? Cheers, Jay http://www.expresspcb.com/ExpressPCBHtm/Free_cad_software.htm Bored stiff? Loosen up... Download and play hundreds of games for free on Yahoo! Games. http://games.yahoo.com/games/front ________________________________________________________________________________
Subject: Re: Expresspcb... Free CAD software
Date: Mar 05, 2007
Hi Jay, Yes, I've used the ExpressPCB schematic and PC board software for a number of years. What's very nice is once you draw the schematic - it can aid you in drawing a PC board design. It has a node highlighter (for lack of a better word), so that when the PCB drawing is linked to the schematic drawing and you click on a node (pin, resistor, etc) all the nodes on components in the drawing that element is connected to will light up. So you immediately know where you have to draw the traces. There are a couple of minor down sides, its library of ready symbols and components is a bit on the skimpy side - but, they do provide the means for you to create and dimension any component yourself. Once you get use to using it, it only takes a minute or two to whip up another component and then store it in the "custom" component library. Also you can not directly produce the PC board industry standard "Gerber files" used to produce PC boards - so you are sort of locked in with ExpressPCB. You can get a Gerber file from them but it will cost you $60. On the other hand, they have some very reasonable board quantity offers (for example 3 boards for $51 - to get this price the boards have to be 3.8"x 2.5" or smaller) and they will get the boards back to you within 3-4 workdays. I'm just finishing up 3 PCB board designs and have sent the first off for them to make. I have probably had 10-13 designs done by them over the years and been happy with them all. I have looked into other PC board manufactures due to the limitations (no Gerber files, no capability to make stencils for surface mount components - yet) , but have not found any that induced me to switch. Ed Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html ----- Original Message ----- From: "Jay Brinkmeyer" <jaybrinkmeyer(at)yahoo.com> Sent: Monday, March 05, 2007 11:42 AM Subject: AeroElectric-List: Expresspcb... Free CAD software > > > I've been playing around with express schematics CAD software for a while. > It's pretty useful and it's "free". Anyone else out there using this? > > Cheers, > Jay > > http://www.expresspcb.com/ExpressPCBHtm/Free_cad_software.htm > > > Bored stiff? Loosen up... > Download and play hundreds of games for free on Yahoo! Games. > http://games.yahoo.com/games/front > > > ________________________________________________________________________________
Date: Mar 05, 2007
May or may not be relevant... Keep in mind that your power consumption goes up quite a bit when you key the mic. Your transponder also has pulsed of higher power consumption. I've heard of guys who set their alarms based on the airplane running with everything turned on. But when they key their mic, especially when the transponder is also transmitting, they get an alarm. As I said, maybe not relevant to your situation, but you might consider it... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of McFarland, Randy Sent: Monday, March 5, 2007 10:25 AM Subject: RE: AeroElectric-List: Radio interference to instruments Thx for the question. I have the same problem. I have a SD8 and Denso 60amp being monitored by a EIS 4000 engine monitor. The alarm goes off almost every time I key the Mic PTT due to one or both Amp readings going out of limits (typically decrease) Doesn't seem to matter whether I am transmiting using Garmin 430 or KX125. I'll check my coax cabling and shields. Randy -----Original Message----- From: Robert L. Nuckolls, III [mailto:nuckollsr(at)cox.net] Sent: Sunday, March 04, 2007 8:36 PM Subject: AeroElectric-List: Radio interference to instruments >Comments/Questions: When I push my PTT switch to transmit on my radio I >get an increase in manifold pressure and either a large increase or >decrease in ammeter reading. This is intermittent and happens about 80% >of the time. All works great with the radio off. Sounds like these instruments were not designed to live in the real world of airplanes. They seem to suffer from radio frequency interference. Check your coax cables from transceiver to antenna. If the shield ground comes loose at either end, the coax can radiate very strongly into airframe wiring. You might try putting a ferrite cable-choke-core over the bundles going into the back of these instruments. See: http://tinyurl.com/28bdgm Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 05, 2007
Yep, I did my whole schematic with it. Somebody else had posted a library of custom parts, which I expanded. Bill > I've been playing around with express schematics CAD software for a while. > It's pretty useful and it's "free". Anyone else out there using this? ________________________________________________________________________________
Date: Mar 05, 2007
Whenever I hear of RF producing a DC voltage effect somewhere, I immediately think "corrosion". Dissimilar metals, moisture, corrosion, rectification. I've seen bad splices wipe out an entire manufacturing plant's data network, but only when it rains. Check your connectors for white powder and the back of your panel for moisture. Dave Morris At 11:06 AM 3/5/2007, you wrote: > >May or may not be relevant... > >Keep in mind that your power consumption goes up quite a bit when you key >the mic. Your transponder also has pulsed of higher power consumption. > >I've heard of guys who set their alarms based on the airplane running with >everything turned on. But when they key their mic, especially when the >transponder is also transmitting, they get an alarm. > >As I said, maybe not relevant to your situation, but you might consider >it... > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >McFarland, Randy >Sent: Monday, March 5, 2007 10:25 AM >To: 'aeroelectric-list(at)matronics.com' >Subject: RE: AeroElectric-List: Radio interference to instruments > > > > >Thx for the question. >I have the same problem. I have a SD8 and Denso 60amp being monitored by a >EIS 4000 engine monitor. The alarm goes off almost every time I key the Mic >PTT due to one or both Amp readings going out of limits (typically decrease) >Doesn't seem to matter whether I am transmiting using Garmin 430 or KX125. >I'll check my coax cabling and shields. >Randy > >-----Original Message----- >From: Robert L. Nuckolls, III [mailto:nuckollsr(at)cox.net] >Sent: Sunday, March 04, 2007 8:36 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Radio interference to instruments > > > > > > >Comments/Questions: When I push my PTT switch to transmit on my radio I > >get an increase in manifold pressure and either a large increase or > >decrease in ammeter reading. This is intermittent and happens about 80% > >of the time. All works great with the radio off. > >Sounds like these instruments were not designed to live >in the real world of airplanes. They seem to suffer from >radio frequency interference. > >Check your coax cables from transceiver to antenna. If the >shield ground comes loose at either end, the coax can radiate >very strongly into airframe wiring. > >You might try putting a ferrite cable-choke-core over the >bundles going into the back of these instruments. See: > >http://tinyurl.com/28bdgm > > > Bob . . . > > ---------------------------------------- > ( IF one wishes to be "world class" at ) > ( anything, what ever you do must be ) > ( exercised EVERY day . . . ) > ( R. L. Nuckolls III ) > ---------------------------------------- > > ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Re: Monitoring external temperatures
>Question: I would like to hear from anyone who has wired a temperature >gauge such that a warning light indicator is illuminated when the temp >falls below freezing (or some other significant value). Have you included >an override to silence the warning light and did you build a delay into >the mechanism to interrupt or disable the warning light? > >Thanks The product highlighted at: http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf can be fitted with software to do the kinds of things you've asked about . . . but as a stand-alone device, not a gage with warnings. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Subject: Shrink wrapping RG-58
Date: Mar 05, 2007
I've heard several times that RG-58 coax should not be shrink wrapped. The Lightspeed electronic ignition installation manual specifically states "Do not shrink wrap RG-58". I cannot find anything that formally states as a general rule that RG-58 should not be shrink wrapped or what problems it creats. I would like to perform the simple application of clear shrinking lables on co-located coax antenna leads. Is this acceptable? Can anyone shed some light on this? Thanks, Roger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=98921#98921 ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Re: Shrink wrapping RG-58
Roger Bentlage a crit : > > I've heard several times that RG-58 coax should not be shrink wrapped. The Lightspeed electronic ignition installation manual specifically states "Do not shrink wrap RG-58". > I cannot find anything that formally states as a general rule that RG-58 should not be shrink wrapped or what problems it creats. > Roger, The RG58 insulation is polyethylene. Heating will allow the insulation to flow and disturb the geometry of the core element relative to the outer braid, changing the coax impedance. So...don't ;-) And don't squeeze them with Ty-Wraps either. Concerning the coax label, how about a nice little label attached to the crimped metal collar at the BNC connector ? FWIW, Regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Mar 05, 2007
Subject: Re: Garmin 530W Install manual
Mike, Thanks for the reply (and the work you devoted to building the page). I'm actually looking for the *530W* vice 430W install manual. I tried modifying the 430W install manual URL, but was not successful. Do you have any hints for me? Thanks, Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 850 hrs RV-10 #40059 under construction Stewart, Michael (ISS Atlanta) wrote: > > On the downloads page, one link above the how to garmin link. > Here is the direct link. > Mike > http://www2.mstewart.net:8080/Downloads/gns430w_IM.pdf > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim > Lewis > Sent: Saturday, March 03, 2007 11:24 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Garmin 530W Install manual > > > > Does anyone have access to a Garmin 530W Install manual? I've tried > <http://www2.mstewart.net:8080/Downloads/howtogetagarminmanual.htm>, but > > I haven't stumbled on to the correct file name yet. > > Thanks, > > Tim Lewis > > ________________________________________________________________________________
Date: Mar 05, 2007
Tim Im sorry I was confused and I cant read! Please try this link for the 530W. Ill update the web page tomorrow with a link. But should should get you by for now. http://www2.mstewart.net:8080/Downloads/530w_IM.pdf I apologize for the confusion. I sent it to you direct but its too big. Best, Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim Lewis Sent: Monday, March 05, 2007 6:02 PM Subject: Re: AeroElectric-List: Garmin 530W Install manual Mike, Thanks for the reply (and the work you devoted to building the page). I'm actually looking for the *530W* vice 430W install manual. I tried modifying the 430W install manual URL, but was not successful. Do you have any hints for me? Thanks, Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 850 hrs RV-10 #40059 under construction Stewart, Michael (ISS Atlanta) wrote: Atlanta)" > > On the downloads page, one link above the how to garmin link. > Here is the direct link. > Mike > http://www2.mstewart.net:8080/Downloads/gns430w_IM.pdf > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Tim > Lewis > Sent: Saturday, March 03, 2007 11:24 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Garmin 530W Install manual > > > > Does anyone have access to a Garmin 530W Install manual? I've tried > <http://www2.mstewart.net:8080/Downloads/howtogetagarminmanual.htm>, but > > I haven't stumbled on to the correct file name yet. > > Thanks, > > Tim Lewis > > ________________________________________________________________________________
From: "William Slaughter" <wslaughter(at)houston.rr.com>
Subject: Battery Tenders
Date: Mar 05, 2007
The Battery Tender Plus arrived back home today - thanks. If I'm reading the graphs right, it did perform rather differently than the previously tested "Batter Minder" (actually a Deltran Battery Tender Jr., wasn't it?) While the "Battery Minder" climbed to not-quite 14.0 and then dropped to float mode, the BT+ appears to have climbed smoothly to 14.2 volts, and then held between 14.2 and 14.4 for a dwell time of over an hour (if the time axis is the same as the earlier test), before dropping back to 13.2 float. This profile is just as advertised on the Deltran website. It's nice when things perform as advertised. Thanks for running these tests. William -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, March 02, 2007 10:04 PM Subject: RE: AeroElectric-List: Battery Tenders > > >Bob, >Speaking of Battery Tenders... I sent my Battery Tender Plus off to you via >UPS on 2/22/07. Please let me know if you've received it or if I need to >start tracking. I received it, did a test with it and put it back into the mail today. I published a plot on a Battery Minder some months ago at: http://www.aeroelectric.com/Pictures/Curves/Battery_Minder_Recharge.pdf Your Battery Tender did this recharge profile. http://www.aeroelectric.com/Pictures/Curves/Battery_Tender_Recharge.pdf We can deduce that both of these products service the "top off" protocols and then drop to similar sustaining voltages. Thank you for donating the use of your charger for this experiment. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 05, 2007
Bill, Is this library of parts available for download? I started to use this software to do my schematics, but was spending to much time trying to draw components that were not available with the program, so I resorted to hand drawings. Dave G. Bill Steer wrote: Yep, I did my whole schematic with it. Somebody else had posted a library of custom parts, which I expanded. Bill > I've been playing around with express schematics CAD software for a while. > It's pretty useful and it's "free". Anyone else out there using this? ________________________________________________________________________________
Subject: Links to Garmin Manuals
Date: Mar 06, 2007
OK Gents, I now have a spot for you to get as many of the Garmin manuals as I have on file for my personal use. Lately the W's(WAAS) have been hot which spawned these discussions. You may use the link below to retrieve them. To name a few I have GNS430, GNS530, GMA347, GNS530W, GNS430W, GTX327, GTX330, MX20, SL40 If I get others Ill put them there. I don't keep every revision of every unit of every variant. I sure wish Garmin would just simply make these available to the public. Not like these are some big secret or anything. Makes life complicated for all of us. Hope this helps. Mike http://www.mstewart.net/Downloads/downloads.htm ________________________________________________________________________________
Date: Mar 06, 2007
Subject: Not all chargers . . .
Was looking for some tools in the mess-shop yestereday and ran across a Schumacher "smart charger" still in the box. I'd purchased it at WallyWorld last year some time with the intent of seeing how it behaved compared with their lesser products. I had a 32AH Panasonic RG battery in a partial state of recharge in the electronics shop. I replaced the 1A Battery Minder with the 12A Schumacher smart charger and produced the following performance curve. http://www.aeroelectric.com/Pictures/Curves/schumacher_5.jpg Here we see that the protocol boosted the battery to the top-off phase pretty quickly. 12A recharge would be expected to have a steeper slope than the 1A charger. The battery was held in top-off for a little over 3 hours before dropping to a sustaining voltage of 13.5 volts. The 'noise' on the voltage traces shows up only after the recharge current drops below the boost level and continues after the voltage is allowed to drop to sustaining levels. I presume this is the effect of some form of 'desulfating' activity. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 06, 2007
Subject: Garmin 430 and 530 connectors
Does anyone know if there is much difference in the wiring pinout and the connectors to go from a Garmin 430 to a 530 ? The connectors look the same but the P/N is one number off 4001 to 5001 etc. Could you just take the connectors off the back plate of the 430 and make any necessary pin changes and put the connectors back on the 530 back plate ? Thanks, Chad Feldpouch ________________________________________________________________________________
Date: Mar 06, 2007
Good Evening Chad, Nothing authoritative here, but I took a 530 to the shop to be updated to a 530W and was told that the 530W and the 430W wiring was identical and, in fact, interchangeable. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/6/2007 10:34:18 P.M. Central Standard Time, 1pouch(at)sbcglobal.net writes: Does anyone know if there is much difference in the wiring pinout and the connectors to go from a Garmin 430 to a 530 ? The connectors look the same but the P/N is one number off 4001 to 5001 etc. Could you just take the connectors off the back plate of the 430 and make any necessary pin changes and put the connectors back on the 530 back plate ? Thanks, Chad Feldpouch
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 07, 2007
Not directly related, but similar... There is a good article in this month's Aviation Consumer on that details all the gotchas on the upgrade from a x00 to x00w. The biggest issue appears to be the antenna and the type of coax you may currently have installed. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CHAD Sent: Tuesday, March 06, 2007 11:30 PM Subject: AeroElectric-List: Garmin 430 and 530 connectors Does anyone know if there is much difference in the wiring pinout and the connectors to go from a Garmin 430 to a 530 ? The connectors look the same but the P/N is one number off 4001 to 5001 etc. Could you just take the connectors off the back plate of the 430 and make any necessary pin changes and put the connectors back on the 530 back plate ? Thanks, Chad Feldpouch ________________________________________________________________________________
Subject: Garmin 430/530 and WAAS
Date: Mar 07, 2007
Has anyone had the 430/530 WAAS conversion done and installed it? We need to know if there were any modification needed to the plane's wiring or antennas. ERic-- RV-10, 40014 N104EP ________________________________________________________________________________
Subject: Transponder noise
Date: Mar 07, 2007
After installing my radio stack (GNS 430, SL-40, GTX 330, GMA 340) and firing it up for the first time, I find that I can hear the ticking transponder broadcast signal in my headset (as well as on a AM/FM radio that was turned on in the shop at the time). I thought my com antennae may be to close to my transponder antenna, but I can still hear the ticking broadcast even when the com radios are turned off, and only the audio panel is left on. The ticking stops when the transponder is placed in standby mode or turned off, so I know that is where it is coming from. Thanks for any ideas on how this can be cured? ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Re: Garmin 430/530 and WAAS
Good Morning Eric, It is almost a certainty that the antenna will need to be replaced and there is a good possibility that the antenna lead will need to be replaced. There is a minimum length required and that minimum length is longer than what has been used for many installations. If your current installations uses RG-58, it must be replaced regardless of length. Other than that, no problem at all! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/7/2007 7:14:30 A.M. Central Standard Time, ericparlow(at)hotmail.com writes: Has anyone had the 430/530 WAAS conversion done and installed it? We need to know if there were any modification needed to the plane's wiring or antennas. ERic-- RV-10, 40014 N104EP
Date: Mar 07, 2007
Eric Parlow wrote: > Has anyone had the 430/530 WAAS conversion done and installed it? > Here is some info concerning the 'WAAS' discussions: [thanks to Brent Regan] Earl Wide Area Augmentation System (WAAS) uses a series of strategically placed ground stations that receive the GPS signal from the GPS constellation, compare the reported position to the known position and calculate the difference. This difference between the two is used to infer the signal propagation delay through the ionosphere. The ionosphere is very dynamic and not very predictable. The delay "coefficients" are then transmitted to three (two currently in service) specialized WAAS satellites that then transmit the correction data back to earth. (simplified explanation). "WAAS Compatibility" simply means that the GPS receiver can receive the signals from the three WAAS satellites. Most GPS receiver can do this. The trick comes in being able to process the WAAS data and use it to correct your position information. There is a lot of math involved and it must be done in real time so it requires a beefy Digital Signal Processor (DSP). Think of it this way, your telephone is "FAX Compatible" just like most GPS receivers are "WAAS Compatible". You telephone can dial a FAX number and receive the pops and screeches but it has no way to process the data into a facsimile of a document. WAAS Capable GPS receivers (like the FreeFlight) have an internal DSP in addition to the receiver to make use of the WAAS data. Do not confuse "WAAS Compatible" or "WAAS Enabled", the ability to receive WAAS data (easy), with "WAAS Capable", the ability to receive AND process the WAAS data (hard). Caveat Emptor Regards Brent Regan ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Re: Transponder noise
> >After installing my radio stack (GNS 430, SL-40, GTX 330, GMA 340) and >firing it up for the first time, I find that I can hear the ticking >transponder broadcast signal in my headset (as well as on a AM/FM radio >that was turned on in the shop at the time). >I thought my com antennae may be to close to my transponder antenna, but I >can still hear the ticking broadcast even when the com radios are turned >off, and only the audio panel is left on. The ticking stops when the >transponder is placed in standby mode or turned off, so I know that is >where it is coming from. >Thanks for any ideas on how this can be cured? While your antagonist and victim have been identified, you still need to identify the propagation mode. When presented with your situation, we know that there is a combination of three things that may eliminate the noise problem or at least reduce it to unnoticeable levels. (1) Fix some issue with the antagonist that doesn't conform to industry practice for integrating the product into an aircraft. (2) Fix some issue with the victim that doesn't conform to industry practice for integrating the product into an aircraft. (3) Eliminate or attenuate the propagation mode that brings energy from the antagonist to vulnerable components of the victim. When anyone hears a short burst of "buzz" synchronous with illumination of the transponder REPLY light, 90% of the time it's an RF detection of the reply pulses someplace in the audio stream. Obviously, our best starting assumption is to set actions (1) and (2) aside. Most of the time, the hardware we install has been competently designed and tested to live in the aircraft environment. So let's talk about (3). What kind of audio panel? What are the connectors on the back like? Is your airplane composite or metal? Where is the transponder antenna mounted with respect to the panel? Bob . . . ________________________________________________________________________________
Date: Mar 07, 2007
Here is one avionics shops information about the upgrade. http://www.lancasteravionics.com/ Deems > Date: Wed, 7 Mar 2007 08:54:37 -0600> From: Earl_Schroeder(at)juno.com> To: aeroelectric-list(at)matronics.com> Subject: Re: AeroElectric-List: Garmin 430 arl_Schroeder(at)juno.com>> > Eric Parlow wrote:> > Has anyone had the 430/530 WAAS conversion done and installed it?> >> Here is some info concerning th e 'WAAS' discussions: [thanks to Brent > Regan] Earl _________________________________________________________________ Discover the new Windows Vista E ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Garmin GPS antenna. Cheap.
List, I just bought one of these puppies from Pac Avionics store, and works perfectly with my G-296. For some reason it doesn't show on Garmin's website, maybe because at $29 it's too inexpensive. It has a small footprint of about 1.5" sq. and 9 foot lead, BNC connector. Haven't seen any chatter on it so here it is... _http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737&pageView=1_ (http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737&pageView=1) Jerry Cochran
Date: Mar 07, 2007
Subject: Re: Garmin GPS antenna. Cheap.
I bought a antenna for my Garmin 296 off of ebay. $18.88 plus 4.95 shipping Just search for: Antenna for GARMIN GPSMAP 295 296 376c 396 GPS Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Jerry2DT(at)aol.com wrote: > List, > > I just bought one of these puppies from Pac Avionics store, and works > perfectly with my G-296. For some reason it doesn't show on Garmin's > website, maybe because at $29 it's too inexpensive. It has a small > footprint of about 1.5" sq. and 9 foot lead, BNC connector. Haven't > seen any chatter on it so here it is... > > http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737&pageView=1 > <http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737&pageView=1> > > Jerry Cochran > > > > > ------------------------------------------------------------------------ > AOL now offers free email to everyone. Find out more about what's free > from AOL at AOL.com. > > ________________________________________________________________________________
Date: Mar 07, 2007
Bobby, You may not have it yet, but I was wondering if the magnetic backing will peal off easily. I wouldn't want any magnets in the airplane that are not necessary. I suppose there are no mounting holes for screws but perhaps double sided tape on the glair shield would work well. Bevan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bobby Hester Sent: Wednesday, March 07, 2007 5:35 PM Subject: Re: AeroElectric-List: Garmin GPS antenna. Cheap. I bought a antenna for my Garmin 296 off of ebay. $18.88 plus 4.95 shipping Just search for: Antenna for GARMIN GPSMAP 295 296 376c 396 GPS Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm Jerry2DT(at)aol.com wrote: List, I just bought one of these puppies from Pac Avionics store, and works perfectly with my G-296. For some reason it doesn't show on Garmin's website, maybe because at $29 it's too inexpensive. It has a small footprint of about 1.5" sq. and 9 foot lead, BNC connector. Haven't seen any chatter on it so here it is... http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737 <http://www.buyersedge.com/Product/prodDesc.asp?XOS=3665737&pageView=1> &pageView=1 Jerry Cochran _____ AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com. href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List ________________________________________________________________________________
Subject: GPS antenna.
Date: Mar 07, 2007
I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using. Bevan ________________________________________________________________________________
Date: Mar 07, 2007
Subject: Re: GPS antenna.
I use the antenna that came with my Garmin 296 car kit in the plane and I use the extra one I bought off ebay when I travel in rental car. The Garmin one in the plane is mounted on my glare sheild with velcro :-) Goto this page http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm and scroll to the bottom, them click the picture to enlarge. I think the one off ebay with the magnet would work just fine here also. It might mess with the compass, not sure. Surfing the web with my laptop from Hopkinsville, KY Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm B Tomm wrote: > I assume a remote GPS antenna will work fine on my RV7 located on top > of the glare shield but under the windshield. Is anybody operating > with this configuration successfully (Garmin 296 or 396)? If so, > which antenna are you using. > > Bevan > > > > ________________________________________________________________________________
Date: Mar 08, 2007
Yes this will work fine. I have 5 little hockey puck antennae's on my glare shield. (3GPS and 2 XM) 2 panel GPS's, and one 295 that my wife gets in the rear. One XM wx on the grt and one XM for radio. Photo on the Mirrors link on this page. http://www2.mstewart.net:8080/super8/index.htm It makes for short wire runs, light weight, and ease of service IF you have access panels. If you have more than one GPS antennae, they need to be several inches apart or you will get signal degradation between them, although they will work. Mike _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm Sent: Wednesday, March 07, 2007 10:07 PM Subject: AeroElectric-List: GPS antenna. I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using. Bevan ________________________________________________________________________________
Date: Mar 08, 2007
I have the 296 with the Garmin remote antenna mounted with Velcro on the glare shield and it works well. However, I discovered the placement of the antenna in relationship to the GPS unit is a factor. My 296 is mounted externally on the panel at the top of the radio stack and just below the glare shield over hang. When the remote antenna is place on the aft edge of the glare shield right above the GPS it well not work. Moved to the far forward part of the glare shield, next to the windshield, it works fine. I confirmed this outside the airplane. With the GPS in my hand and receiving signal using the stub antenna, I switched to the remote antenna and held it in the same position as the stub antenna. The GPS soon stop working. When I held the remote antenna at arms length it resumed working. My original setup was a 295 mounted in the same location with the remote antenna mounted just above it and it worked. Can anybody explain this to me? Could the magnet in the 296 remote be the cause? Dale Ensing ----- Original Message ----- From: B To: aeroelectric-list(at)matronics.com Sent: Wednesday, March 07, 2007 10:06 PM Subject: AeroElectric-List: GPS antenna. I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using. Bevan ________________________________________________________________________________
Date: Mar 08, 2007
What kind of audio panel? What are the connectors on the back like? Is your airplane composite or metal? Where is the transponder antenna mounted with respect to the panel? Bob . . . Bob, The audio panel is Garmin GMA 340 with 2 large D-sub connetors on the back. I had Approach Systems build the harness for it, as well as all the other avionics, and use their avionics hub to connect everything together. The plane is a highwing GlaStar, which has chrome molly passenger cage surrounded by a fiberglass fuselage, and vertical stabilizer. It has aluminum wings, rudder, and horizontal stabilizer. I built a composite battery shelf that spans the fuselage sides behind the bulkhead that seperates the baggage compartment from the empanage. In addition to the battery on one end, the ELT is located on the other end, and the transponder antenna inbetween, with the ground plane mounted on top of the shelf, and the element hanging underneath. This places the antenna about 8 feet behind the panel. I thought the foil tape marker beacon antenna glassed to the belly of the empanage may be picking up the transponder broadcast since it is hooked directly to the audio panel. So this morning I went out and diconnected the marker beacon coax from its lead on the audio panel harness, while I listened to my headset. However there was no change in the ticking when I diconnected the coax. I did notice a significant change in the volume of the ticking when my physical position changed as I moved around the plane to make the disconnection. I also noted that when I turned off the ANR on my LightSpeed headset, the ticking was no longer audible, but I really don't want to fly without the ANR since it makes radio transmissions so much easier to hear. It does seem like there is something in the headset or ANR circuitry that is picking up the transponder transmission. Has anyone else experienced this? and if so did you find a fix?? Thanks Dustin Paulson Read this topic online here: http://forums.matronics.com/viewtopic.php?p=99421#99421 ________________________________________________________________________________
Date: Mar 08, 2007
Mike. I looked at the link showing your panel. Very nice. Quick question: I see your initial design was using the Garmin 480 GPS navigator, then you changed to the 430 GPS. Do you think Garmin will obsolete the 480 soon? John _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Stewart, Michael (ISS Atlanta) Sent: Thursday, March 08, 2007 3:39 AM Subject: RE: AeroElectric-List: GPS antenna. Yes this will work fine. I have 5 little hockey puck antennae's on my glare shield. (3GPS and 2 XM) 2 panel GPS's, and one 295 that my wife gets in the rear. One XM wx on the grt and one XM for radio. Photo on the Mirrors link on this page. http://www2.mstewart.net:8080/super8/index.htm It makes for short wire runs, light weight, and ease of service IF you have access panels. If you have more than one GPS antennae, they need to be several inches apart or you will get signal degradation between them, although they will work. Mike _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of B Tomm Sent: Wednesday, March 07, 2007 10:07 PM Subject: AeroElectric-List: GPS antenna. I assume a remote GPS antenna will work fine on my RV7 located on top of the glare shield but under the windshield. Is anybody operating with this configuration successfully (Garmin 296 or 396)? If so, which antenna are you using. Bevan http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com ________________________________________________________________________________
Date: Mar 08, 2007
Subject: Re: GPS Antenna
Folks, That one from Garmin has no magnet, besides it is (allegedly) waterproof, so could be mounted outside if you wish. However, it's so tiny, very unobtrusive on the glare shield with velcro or carpet tape. Jerry Cochran From: Bobby Hester <bobbyhester(at)charter.net> Subject: Re: AeroElectric-List: GPS antenna. I use the antenna that came with my Garmin 296 car kit in the plane and I use the extra one I bought off ebay when I travel in rental car. The Garmin one in the plane is mounted on my glare sheild with velcro :-) Goto this page http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm and scroll to the bottom, them click the picture to enlarge. I think the one off ebay with the magnet would work just fine here also. It might mess with the compass, not sure.
Date: Mar 08, 2007
Subject: Alternator field current
Folks, I may be having a brain lockup, but trying to determine field current for the old 14184 type Van's alternator. I just began running my engine for the first time, and thought I had it wired per Z-11. I had inserted a 5a fuse onto the field circuit at the bus because I thought this would be equivalent to inserting one inline after the switch as Z-11 shows instead of the 22AWG fuselink. Z-11 looks like this circuit has double protection with the fuselink and 5a fuse on the same circuit . Well, upon first start, the 5a fuse on the buss blew, so I have two questions for Bob and/or other smart people on this list. 1) Why the "extra" protection on the field circuit? 2) What typically would the current draw be on the field circuit for this 35a alternator. I checked the archives and manuals, no joy... BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 Any/all advice/input appreciated... If you have an immediate answer, please email me as well at jerry2dt(at)aol.com Jerry Cochran RV6a FAA inspection today!!!
Subject: GNS 430W Antenna Requirements
Date: Mar 09, 2007
3/9/2007 Hello List Experts, It is fairly well documented that Garmin wants high quality antenna cable (RGU 142 or 400) to be used for the GNS 430W and it must be between 13 and 35 feet long. I can understand a maximum limit. I cannot understand the physics or electronic principles behind the minimum length requirement. Can someone please educate me? Thanks. OC -- The best investment we can make is the effort to gather and understand knowledge. ________________________________________________________________________________
Date: Mar 09, 2007
Subject: Re: GNS 430W Antenna Requirements
Good Morning OC, When I asked that question, I was told they need the additional attenuation supplied by the extra length. Seems kinda unusual to me, but the techie who told me that is a pretty sharp tack! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/9/2007 7:15:36 A.M. Central Standard Time, bakerocb(at)cox.net writes: I can understand a maximum limit. I cannot understand the physics or electronic principles behind the minimum length requirement. Can someone please educate me? Thanks.
Date: Mar 09, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Alternator field current
> >Folks, > >I may be having a brain lockup, but trying to determine field current for >the old 14184 type Van's alternator. I just began running my engine for >the first time, and thought I had it wired per Z-11. I had inserted a 5a >fuse onto the field circuit at the bus because I thought this would be >equivalent to inserting one inline after the switch as Z-11 shows instead >of the 22AWG fuselink. Z-11 looks like this circuit has double protection >with the fuselink and 5a fuse on the same circuit >. >Well, upon first start, the 5a fuse on the buss blew, so I have two >questions for Bob and/or other smart people on this list. > >1) Why the "extra" protection on the field circuit? The wire running from the bus to the switch and breaker is an extension of the bus. This wire is at very low risk of being faulted and not having protection. The protection needs to have a response time sufficiently long to allow the downstream breaker to do its job if called upon . . . hence the fusible link. > >2) What typically would the current draw be on the field circuit for this >35a alternator. I checked the archives and manuals, no joy... 2.5 to 4 amps depending on the design. I presume that the alternator IS designed to run with an external regulator? When the engine is running and loads on the system are light, the field current can drop below 1A. > >BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 Did you add the ov protection too? If, except for the (fusible link substitution) you're wired exactly like Z-11, I'd recommend that you install the fusible link and the put an ammeter in this lead to see what the real static current (engine stopped) is for he field circuit and report back to us. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 09, 2007
> > >What kind of audio panel? What are the connectors > on the back like? Is your airplane composite or > metal? Where is the transponder antenna mounted with > respect to the panel? > > Bob . . . > >Bob, > >The audio panel is Garmin GMA 340 with 2 large D-sub connetors on the >back. I had Approach Systems build the harness for it, as well as all the >other avionics, and use their avionics hub to connect everything together. > >The plane is a highwing GlaStar, which has chrome molly passenger cage >surrounded by a fiberglass fuselage, and vertical stabilizer. It has >aluminum wings, rudder, and horizontal stabilizer. > > >I built a composite battery shelf that spans the fuselage sides behind the >bulkhead that seperates the baggage compartment from the empanage. In >addition to the battery on one end, the ELT is located on the other end, >and the transponder antenna inbetween, with the ground plane mounted on >top of the shelf, and the element hanging underneath. This places the >antenna about 8 feet behind the panel. But it also places the panel and all stuff in the cockpit right in the antenna's major radiation pattern. I've never been too happy with the notion of internal transponder antennas. Sticking them out the bottom of the fuselage offers an opportunity to reduce radiation to the ship's other systems by a factor of 100 or more. >I thought the foil tape marker beacon antenna glassed to the belly of the >empanage may be picking up the transponder broadcast since it is hooked >directly to the audio panel. So this morning I went out and diconnected >the marker beacon coax from its lead on the audio panel harness, while I >listened to my headset. However there was no change in the ticking when I >diconnected the coax. >I did notice a significant change in the volume of the ticking when my >physical position changed as I moved around the plane to make the >disconnection. Yup. Your antenna location is filling the cockpit with RF stresses . . . moving around within the cockpit will "stir" the pattern of maximum stress. > I also noted that when I turned off the ANR on my LightSpeed headset, > the ticking was no longer audible, but I really don't want to fly without > the ANR since it makes radio transmissions so much easier to hear. >It does seem like there is something in the headset or ANR circuitry that >is picking up the transponder transmission. Has anyone else experienced >this? and if so did you find a fix?? Is the ANR headset specifically for aircraft? It may or may not be designed to live in the aircraft radio noise environment. In any case, try moving the antenna to the belly and put either a tuned (radius equal to antenna mounted height) or a would-like- to-be-infinite (as generous as practical) ground plane over the antenna's mounting location. In this case, an 'oversized' ground plane goes to the task of minimizing radiation in the direction of the cabin. Bob . . . ________________________________________________________________________________
Date: Mar 09, 2007
I would be curious to hear the official answer for this, too, because I've worked with antennas since 1971 and tracked amateur satellites for many years, and I couldn't figure out initially why they would have a minimum length. If anything, common sense would dictate they should want it as short as possible to have as LITTLE attenuation as possible when trying to pick up satellites that are hundreds of miles away. But this is an amplified antenna, and the preamp is there to help pull the satellite signal out of the noise. Once it has done that, they need to make sure the resulting output doesn't swamp the front-end of the GPS receiver. So they picked a length of coax that would attenuate the signal just enough to give a clean signal at the receiver. By using the coax as an attenuator instead of resistors inside the receiver, if at some point during some installation it is discovered the attenuation is too great, the installer can just slice a foot or two off the coax and get more signal strength, and there is no need to ship units back and forth to and from the factory to replace attenuators. Dave Morris (the standard Dennis Miller waivers apply) At 07:45 AM 3/9/2007, you wrote: >Good Morning OC, > >When I asked that question, I was told they need the additional >attenuation supplied by the extra length. Seems kinda unusual to me, >but the techie who told me that is a pretty sharp tack! > >Happy Skies, > >Old Bob >AKA >Bob Siegfried >Ancient Aviator >Stearman N3977A >Brookeridge Air Park LL22 >Downers Grove, IL 60516 >630 985-8503 > >In a message dated 3/9/2007 7:15:36 A.M. Central Standard Time, >bakerocb(at)cox.net writes: >I can understand a maximum limit. I cannot understand the physics or >electronic principles behind the minimum length requirement. > >Can someone please educate me? Thanks. > > >---------- >AOL now offers free email to everyone. Find out more about what's >free from AOL at <http://www.aol.com?ncid=AOLAOF00020000000339>AOL.com. > ________________________________________________________________________________
Subject: Never Again Online
Date: Mar 09, 2007
Today there was another article in "Never Again Online" that is a reassuring read. http://www.aopa.org/pilot/never_again/2007/na0703.html It makes me appreciate the dual alt electrical system I am installing in my plane even more... Thanks Bob! Bret Smith RV-9A "Wings" Blue Ridge, GA www.FlightInnovations.com ________________________________________________________________________________
Subject: antenna placement
Date: Mar 09, 2007
When putting the Com and Transponder antenna on the belly of a metal plane is there a distance that they should be apart?? Thanks Dale ________________________________________________________________________________
Date: Mar 09, 2007
bakerocb(at)cox.net wrote: > > 3/9/2007 > > Hello List Experts, It is fairly well documented that Garmin wants > high quality antenna cable (RGU 142 or 400) to be used for the GNS > 430W and it must be between 13 and 35 feet long. > > I can understand a maximum limit. I cannot understand the physics or > electronic principles behind the minimum length requirement. > > Can someone please educate me? Thanks. Working in telecom, I get a lot of experience to fiberoptics. We often have to insert an attenuator in the line when doing our tests. The circuits were designed to power miles of optic cable, and if you use just a few feet the power from the transmitter will 'saturate' the reciever. This is akin to watching a TV in a dark room with the brightness turned up WAY to high. Everything begins to blend together in one big mush. -- ,|"|"|, Ernest Christley | ----===<{{(oQo)}}>===---- Dyke Delta Builder | o| d |o http://ernest.isa-geek.org | ________________________________________________________________________________
Date: Mar 09, 2007
Subject: Re: antenna placement
> >When putting the Com and Transponder antenna on the belly of a metal plane >is there a distance that they should be apart?? Thanks Dale They're not terribly antagonistic to each other. Get the widest practical spacing but don't bust yer buns over it. Bob . . . > ________________________________________________________________________________
Date: Mar 09, 2007
Here's the latest word I received from Comant... "Standard separation for antennas is 36 inches. This is especially true for transmitters like VHF and Transponder. The transponder is a continuous high power pulse. If space is an issue non transmitters may have to violate this rule of thumb. In other words, 36 inches in all cases - if unable to achieve this, make sure the no antennas are within 36 inches of a transmitting antenna." Hope this is useful... -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dale Fultz Sent: Friday, March 9, 2007 9:08 AM Subject: AeroElectric-List: antenna placement When putting the Com and Transponder antenna on the belly of a metal plane is there a distance that they should be apart?? Thanks Dale ________________________________________________________________________________
Date: Mar 09, 2007
OC, Is the minimum length cable required for both COM and NAV? Bret Smith RV-9A "Wings" Blue Ridge, GA www.FlightInnovations.com ----- Original Message ----- From: <bakerocb(at)cox.net> Sent: Friday, March 09, 2007 8:12 AM Subject: AeroElectric-List: GNS 430W Antenna Requirements > > 3/9/2007 > > Hello List Experts, It is fairly well documented that Garmin wants high > quality antenna cable (RGU 142 or 400) to be used for the GNS 430W and it > must be between 13 and 35 feet long. > > I can understand a maximum limit. I cannot understand the physics or > electronic principles behind the minimum length requirement. > > Can someone please educate me? Thanks. > > OC -- The best investment we can make is the effort to gather and > understand knowledge. > > > ________________________________________________________________________________
Date: Mar 09, 2007
From: "Walter Fellows" <walter.fellows(at)gmail.com>
Subject: Re: Never Again Online
It is a shame the pilot in the article provided no attempt whatsoever to explain the cause of the electrical failure. Perhaps he is another pilot who believes that planning and checklists can completely replace experience and intimate knowledge of the airplane and its systems. On 3/9/07, Bret Smith wrote: > > Today there was another article in "Never Again Online" that is a > reassuring read. http://www.aopa.org/pilot/never_again/2007/na0703.html > > It makes me appreciate the dual alt electrical system I am installing in > my plane even more... Thanks Bob! > > Bret Smith > RV-9A "Wings" > Blue Ridge, GA > www.FlightInnovations.com > > * > > > * > > ________________________________________________________________________________
Date: Mar 09, 2007
Not OC here but it is only for the GPS antenna. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 3/9/2007 9:56:41 A.M. Central Standard Time, smithhb(at)tds.net writes: Is the minimum length cable required for both COM and NAV?
Date: Mar 09, 2007
>Today there was another article in "Never Again Online" that is a >reassuring read. ><http://www.aopa.org/pilot/never_again/2007/na0703.html>http://www.aopa.org/pilot/never_again/2007/na0703.html > >It makes me appreciate the dual alt electrical system I am installing in >my plane even more... Thanks Bob! Thank you for sharing this find with us. I've posted the commented article at: http://www.aeroelectric.com/articles/neveragain/Stress_Changes_Everything.pdf I would encourage all newcomers to the List to review the pieces posted at: http://www.aeroelectric.com/articles/neveragain/ . . . along with Chapter 17 in the 'Connection that speaks to SYSTEM RELIABILITY and crafting flight systems that (1) meet your mission needs and (2) not subject to failures that generate an emergency. To recap: # Nuckolls' first law of airplane systems design sez: "Things break" # The Second: "Systems shall be designed so that when things break, no immediate hazard is created." # The third: "Things needed for comfortable termination of flight require backup or special consideration to insure operation and availability" # The forth: "Upgrading the quality, reliability, longevity, or capability of a part shall be because you're tired of replacing it or want some new feature, not because it damned near got you killed." If these tenants are observed (not difficult to do) then it makes no difference where you buy your parts, how much money you spend on them or which parts you select. You're free to try any selection with the goal of exploring how long it will last or how well it will perform. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 09, 2007
Bret Smith wrote: > Today there was another article in "Never Again Online" that is a reassuring read. http://www.aopa.org/pilot/never_again/2007/na0703.html > > It makes me appreciate the dual alt electrical system I am installing in my plane even more... Thanks Bob! > > Bret Smith > RV-9A "Wings" > Blue Ridge, GA > www.FlightInnovations.com > Summarization: I fly without a low voltage warning light and keep nearly depleted batteries in my handheld radio. My ships battery probably has one foot in the grave and another on a banana peel, but I really don't know because of the lack of a low voltage light and the fact that I've never checked it. I like to fly with every light blazing whenever possible. I got very concerned one day when my alternator gave up the ghost and the airport was busy. I didn't want to divert to a less used airport, and I didn't want to upset my wife. Fortunately, the handheld worked well enough to get landing clearance from ATC. ________________________________________________________________________________
Date: Mar 09, 2007
I just had my 430 updated yesterday. Actually, I took it to my avionics shop on February 20. They sent it to Garmin who then refurbished my old box with new knobs, screen, new GPS processor, replaced BNC connectors, and realigned everything. My shop had to make a new RG-400 cable with 3 db loss. That wound up being a 14' cable to reach the new GPS antenna that is mounted about 10" in front of the 430 rack. Otherwise, absolutely no changes to my Velocity's wiring. I then flew GPS approaches into 3 different airports, one ILS approach, and engaged the autopilot to make sure all was working OK. One word - NICE! The GPS glide slope is nice and smooth - not twitchy like an ILS. The Glide Slope starts working as soon as you turn inbound at the IAF and works all the way down to the ground. Once on the ground, GPS altitude is within 10 feet (that is the resolution of the altitude readout) of the runway elevation. It was easy to transition from the legacy 430 to the new 430W. This upgrade is HIGHLY RECOMMENDED!!!! ________________________________________________________________________________
Date: Mar 09, 2007
> > >Bret Smith wrote: >>Today there was another article in "Never Again Online" that is a >>reassuring read. http://www.aopa.org/pilot/never_again/2007/na0703.html >> >>It makes me appreciate the dual alt electrical system I am installing in >>my plane even more... Thanks Bob! >> >>Bret Smith >>RV-9A "Wings" >>Blue Ridge, GA >>www.FlightInnovations.com >> >Summarization: > >I fly without a low voltage warning light and keep nearly depleted >batteries in my handheld radio. My ships battery probably has one foot in >the grave and another on a banana peel, but I really don't know because of >the lack of a low voltage light and the fact that I've never checked >it. I like to fly with every light blazing whenever possible. >I got very concerned one day when my alternator gave up the ghost and the >airport was busy. I didn't want to divert to a less used airport, and I >didn't want to upset my wife. Fortunately, the handheld worked well >enough to get landing clearance from ATC. Let's not whack on this guy too hard. First, we should look to his teachers . . . and the teachers of his teachers. My own instructors of some 26 years ago were woefully ignorant of electrical system physics and function. Folks seldom rise above their teachers. Recall too that only a small percentage of what is taught is retained. It's probably fair to assert that the teachers are not getting any better. This leads us inexorably to the notion that a majority of today's GA pilots are potential victims of the same or similar situations. In a segmented, planned activity where everyone is responsible only for their own part of the plan (and can make your life exceedingly miserable for transgressions), nobody is responsible for final outcomes. If this guy's story appeared in the NTSB records as another smoking hole, it's doubtful that the report would cite all the ways in which his teachers and other suppliers of goods and services delivered less than the-best-we-know-how-to-do thus contributing to his demise. Given the $time$ that it takes to assemble an OBAM aircraft it's doubtful that the costs per pound of airplane are much better than buying a spam can. Where the real return on investment comes is the fact that folks who seek out and exploit the teachers in the OBAM venue can ultimately become one with their machine. There's value that goes far beyond performance and utility when the individual at the controls UNDERSTANDS the performance and limits of both himself and all the flight system equipment. Understanding that operates in an unregulated environment gives us all a real leg-up for taking responsibility for our own outcomes. Something our spam-can-flying/government-schooled brothers are not even aware of. But be forewarned that anyone who frequents this List will be hard pressed to garner sympathy for an unhappy outcome if your own smoking hole comes about because of a lack electrical system integrity or performance. Unlike the guy who wrote the AOPA story, YOU have teachers here that DO understand and are willing to help you understand too. Recall that the hero of the story in Chapter 17, Martin Gonzales wrote me some years later to report that deductions I made concerning his story were dead on . . . he reported also that an RV kit was on order. Somebody might do Mr. Shalhoub a good turn by inviting him to join a few of the more illuminating Lists on matronics. Bob . . . ________________________________________________________________________________
Subject: "It all depends."
Date: Mar 09, 2007
While reading the latest edition of Aviation Safety magazine today I ran across the following... To quote someone with more hours in more types of aircraft than many of us can ever hope to have - "Old Bob" Siegfried - "It all depends." Well, we're in the presence of greatness here! :O) Way to go Bob. Rodney in Tennessee _________________________________________________________________ Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. Intro*Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 ________________________________________________________________________________
Date: Mar 09, 2007
Subject: Re: "It all depends."
In a message dated 3/9/2007 5:35:35 P.M. Central Standard Time, rdunhamtn(at)hotmail.com writes: Well, we're in the presence of greatness here! :O) Way to go Bob. Rodney in Tennessee Blushing profusely here!! Thank you for the nice comment. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503
Date: Mar 09, 2007
This list has the honor of the attention of at least two great gentlemen named Bob on it; maybe more. You both set a fine example of both knowledge and manners for the rest of us. Terry _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Friday, March 09, 2007 3:37 PM Subject: Re: AeroElectric-List: "It all depends." In a message dated 3/9/2007 5:35:35 P.M. Central Standard Time, rdunhamtn(at)hotmail.com writes: Well, we're in the presence of greatness here! :O) Way to go Bob. Rodney in Tennessee Blushing profusely here!! Thank you for the nice comment. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 _____ AOL now offers free email to everyone. Find out more about what's free from AOL at <http://www.aol.com?ncid=AOLAOF00020000000339> AOL.com. ________________________________________________________________________________
Subject: Transponder location in the panel
Date: Mar 09, 2007
Bob, All this talk about transponder "Antenna" locations has me thinking about the location of the transponder itself. Will my Becker 2 1/4" transponder (250watt) be "polite" to the Trutrak autopilot sitting next to it within 1/4"? Or should I locate a less critical device in the hole right next to the transponder? If so which device would likely get along in close proximity with the transponder? Voltmeter, electronic fuel gauge, electronic tach, electronic clock? Bevan RV7A Getting ready to start the electrical installation ________________________________________________________________________________
Subject: RE: Transponder location in the panel
Date: Mar 10, 2007
Hi Bevan, Re: All this talk about transponder "Antenna" locations has me thinking about the location of the transponder itself. Will my Becker 2 1/4" transponder (250watt) On a tangent, I have the same unit and having noted the relatively high power consumption compared to the coms sharing the stack, elected to put the xpdr at the top. This ought to help keep my avionics as cool as practical behind the panel. FWIW- glen matejcek aerobubba(at)earthlink.ne ________________________________________________________________________________
Date: Mar 10, 2007
Subject: automatic flap controls?
>Comments/Questions: Hi Bob. >This is Luigi from Rome ,Italy. >I'm looking for a scheme to realize a flap electrical circuit to have two >or three pre-set position. For instance T.O. approach and landing. Is >there any project ? Thank you for any help. >The info discovered on aeroelectric.com are simply fantastic. Thank you for the kind words. I'm pleased that you find the work useful. One needs to approach automatic systems for moving flight control surfaces with caution. While relatively easy to do the desired task, one needs to minimize if not eliminate risk of inadvertent motion. The system should be designed such that a failure which causes motion to occur at the wrong time does not precipitate a situation the pilot or the airplane cannot be expected to handle. So, the answer to your question is, "yes, it's relatively easy to craft the automatic flap positioning system." I've considered offering such a device as a product from aeroelectric.com However, given that flaps are operated for less than 1% of total flight time per flight cycle, I've not convinced myself that the $time$ needed to craft the suitable system is cost effective given that manual flap operation does not represent a significant work load item for operating an airplane. Therefore, this is not going to become an offering from my website and I don't recommend them as a useful addition to the light aircraft. Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 10, 2007
Bob & List Remarks embedded... In a message dated 3/9/2007 5:46:25 A.M. Pacific Standard Time, nuckollsr(at)cox.net writes: > >Folks, > >I may be having a brain lockup, but trying to determine field current for >the old 14184 type Van's alternator. I just began running my engine for >the first time, and thought I had it wired per Z-11. I had inserted a 5a >fuse onto the field circuit at the bus because I thought this would be >equivalent to inserting one inline after the switch as Z-11 shows instead >of the 22AWG fuselink. Z-11 looks like this circuit has double protection >with the fuselink and 5a fuse on the same circuit >. >Well, upon first start, the 5a fuse on the buss blew, so I have two >questions for Bob and/or other smart people on this list. > >1) Why the "extra" protection on the field circuit? The wire running from the bus to the switch and breaker is an extension of the bus. This wire is at very low risk of being faulted and not having protection. The protection needs to have a response time sufficiently long to allow the downstream breaker to do its job if called upon . . . hence the fusible link. NOW I understand... Thanks!! > >2) What typically would the current draw be on the field circuit for this >35a alternator. I checked the archives and manuals, no joy... 2.5 to 4 amps depending on the design. I presume that the alternator IS designed to run with an external regulator? When the engine is running and loads on the system are light, the field current can drop below 1A. The alternator is from the AV dep't of Autozone, appears to be same as the 35A one from Van's with the identical 14184 part #, so I assumed it needed external regulation, as does theirs. Could it possibly be IR? Not at the hangar, so can't look. > >BTW, if it matters, this is the "Generic Ford" regulator as per Z-11 Did you add the ov protection too? If, except for the (fusible link substitution) you're wired exactly like Z-11, I'd recommend that you install the fusible link and the put an ammeter in this lead to see what the real static current (engine stopped) is for he field circuit and report back to us. Bob . . . Yes, I did use OV from B&C and as I said, only put the 5a fuse on the main buss, not just before the OV as per Z-11. Don't recall why, but I deleted the fusible link... Probably simply an error. ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- Bob, Thanks so much for all you do. Jerry Cochran ____________________________________ AOL now offers free email to everyone. Find out more about what's free from AOL at _AOL.com_ (http://www.aol.com/?ncid=AOLAOF00020000000339) .
From: "llsbiii3(at)netzero.net" <llsbiii3(at)netzero.net>
Date: Mar 11, 2007
Subject: Tool help please
Hi Bob, During the demolition of a nuclear plant a box of electrical tools were being thrown away. I rescued the tools even though I did not know what they were. I did recognize the terminal ends and knew to clear ones wer e better (PIDG) than those at Wall-mart. Thanks to your web site I now know one was an AMP T-head and how the terminal end is positioned. Howe ver I do not know just exactly what the other tools are, I suspect one i s used on 10-12 size terminals, and how they are used. I also have some unknown electrical connectors. Can some one tell me what these are and how they are used. Pictures are attached. Thanks Sherman Butler RV-7a
Hi Bob,
During the demolition of a nuclear plant a box of ele ctrical tools were being thrown away.& nbsp; I rescued the tools even though I did not know what they we re.  I did recognize the t erminal ends and knew to clear ones were better (PIDG) than those at Wal l-mart.  Thanks to your we b site I now know one was an AMP T-head and how the terminal end is posi tioned.  However I do not know just exactly what the other tools are, I suspect one is used on 10- 12 size terminals, and how they are used.  I also have some unknown electrical connectors.  Can some one tell me what these are and how they are used.  Pictures are attached.
Sherman Butler
RV-7a
/9j/4AAQSkZJRgABAQEBLAEsAAD/4RO5RXhpZgAASUkqAAgAAAAWAA4BAgALAAAAFgEAAA8BAgAG AAAAIgEAABABAgALAAAAKAEAABIBAwABAAAAAQCA/xoBBQABAAAANAEAABsBBQABAAAAPAEAACgB AwABAAAAAgB7/zEBAgAQAAAARAEAADIBAgAUAAAAVAEAABMCAwABAAAAAgB3/2mHBAABAAAAcAEA AAGkAwABAAAAAABt/wKkAwABAAAAAABG/wOkAwABAAAAAAAt/wSkBQABAAAAaAEAAAWkAwABAAAA JgAg/wakAwABAAAAAAAW/wekAwABAAAAAAAJ/wikAwABAAAAAAAJ/wmkAwABAAAAAAAF/wqkAwAB AAAAAAAH/wykAwABAAAAAAAF/1YDAAAgICAgICAgICAgAABOSUtPTgBDT09MUElYIEwxAAAsAQAA AQAAACwBAAABAAAAQ09PTFBJWCBMMSBWMS4yADIwMDc6MDM6MTAgMjA6MjQ6NTQAAAAAAGQAAAAW AJqCBQABAAAAfgIAAJ2CBQABAAAAhgIAACKIAwABAAAAAgAAACeIAwABAAAAMgAAAACQBwAEAAAA MDIyMAOQAgAUAAAAjgIAAASQAgAUAAAAogIAAAGRBwAEAAAAAQIDAAKRBQABAAAAtgIAAASSCgAB AAAAvgIAAAWSBQABAAAAxgIAAAeSAwABAAAABQAAAAiSAwABAAAAAAAAAAmSAwABAAAAGQAAAAqS BQABAAAAzgIAAIaSBwCAAAAA1gIAAACgBwAEAAAAMDEwMAGgAwABAAAAAQAAAAKgBAABAAAAAAQA AAOgBAABAAAAAAMAAACjBwABAAAAAwAAAAGjBwABAAAAAQAAAAAAAAAKAAAAQAEAAB0AAAAKAAAA MjAwNzowMzoxMCAyMDoyNDo1NAAyMDA3OjAzOjEwIDIwOjI0OjU0AAIAAAABAAAAAAAAAAoAAAAe AAAACgAAAD8AAAAKAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAAGAAMBAwABAAAABgAAABoBBQABAAAApAMAABsB BQABAAAArAMAACgBAwABAAAAAgAAAAECBAABAAAAtAMAAAICBAABAAAA/Q8AAAAAAAAsAQAAAQAA ACwBAAABAAAA/9j/2wCEAAkGBwgHBgkIBwgKCgkLDhgPDg0NDh0VFhEYIx8lJCIfIiEnKzgvJyk1 KiEiMEIxNTk7Pj8+JS5ESUQ9STg9PjwBCgoKDgwOHA8PHDwoIig8PDw8PDw8PDw8PDw8PDw8PDw8 PDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8PDw8PP/AABEIAHgAoAMBIQACEQEDEQH/xAGiAAAB BQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNR YQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldY WVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TF xsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVi ctEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqC g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl 5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AMuNcAZqdVrhOwlVakC0wJFWpAvSmIkC1Iq0DI7m 6trOMSXU8cKngF2Az9PWse68X6RbnCSSzsO0cZ/9mxVxg5bEuSRl3fjW4I/0WwSMdnnfg/hx/Os4 +INevDiCYD/Zgg3/AK4P866oYZbyZi6nYkgh8UzsCkt6pPeVggH4E/0ruIhJ5KecVMm0bio4z3xU VVBfCODfUcRxUZFZFDSOKYRSaAYRTGHNAFVRUyLWRqTIKlVaYiVUrNutXEckkVpD57Rf61y4VE/H ufaqSJbsZOpeJ9QtAsa2kMcpGTvyw/DBrEl13Wr04N48an/nmRGB+I5rVU01e5k6jvaxm3Udy6ee 0qzEnaSWZuf97ofzrRsbzRoYALuxujKOpjn4b6424rWnFt+6S5q9mWYvEOm27E2mg26kdHdt7fmR U7+OLsLtis7ZR77j/Wuj6s5fEw50tkV38aao3SO1X6I39TXWeGdVbV9O86ZVWVGKOF6E+o/AiorY dQjdBGd2apFMYAcVyGg0jPSmMKAGMKjIpAV1Wp0XisjUlRamVaoRLsO07ThscH0rgrOS1SGSy1F5 EZZNxYbSyt3BBq4pvYibS1ZU1a7tprlI4t32eNNi4IyQOh4/lWRMXLBLdWZf7uMkmt+Rpcpz86cu YfHBdxO6yRTE42qGUjbz+lNNvID8zR+/7wH+RruoU+VXZLabuhwt16mTI/2EJP64qxBpdzP/AKiz upQe4TH+NaSnGIK7NC38J6pL/wAuiovrI/P8/wCldd4a0Z9HtnjmkVpJG3kIOBwBXJXrqUeVGkY2 ZsEYFMI49jXHY0ExgUwiiwEbCmECkMhRanReKzNCZVqZFpgTKvFYeseFrTUrhrhZHgmb7xChg3vg 9/pVRfK7kzjzKxUt/BSxt82oKy/9eqg/nmtKPwtZouJbu8kH90yfL+VdH1h2sjm+rxvdjB4P0bzG dopGyc4L8Vdh0HSIMCOxjJ7bstn86Trza3NVBItpbQQjMVvGmP7qAU/kjjH1rO9x2GMD60mKAGke lMI4piG4PPNNYe1IBjCoiKVhjVWp0WszUmRamRRQBKo4p4HtTEKq090KOyNjKnBpiDFV44mN3LM6 YIARP93qfzP8hQ0K5McZqGGMxQJGcHaNoPsOn6VVtRCNxTT1qrEsYRj0ppGegzTsITjOOhpDSYIj YYqJhSGCLU6LWRsTKOOKr6hqdlpixm9m8vzDhAFLFj6YANMTZLaajaXdgl7BMpt36OTj889Kfa6n YXUjRW95BNIoyVSQMQPwqkibk0l7bW43XM8UK/3pHCj9ap3/AIs0JLhmOoxncFJ2qzc4weg9qdrM VyhJ420VPuyyyf7if4kVVuPHunxn93bzscd8DP5E0AZ83xEHSHTfxab/AOtVWXx3qjrm3sLfHqVZ v5GqSZLaKEvjPXn7wQ/9swP/AEKqr+JPEE5x9vY/7ip/7KKqxNxN3ie6+7Nqjg/3fNA/lQPD3iG6 +/FdNnvLIB/6E1PlFcsW/gXUZHXzzFEhPzHfkj8AP611Emh3cjDF8bcKQQYV2kY6457+/pXNWpSl OLj0LjJWdzbVSsaqzFyAAWI6+9McdTWwhyCnyv5NvJLjOxC2PXAzWRseZzeI9Xdy32+RSeygAD6V ah8QvNFbrqEAupYXZonZ8duh9f8A9VaWVjO7uZF/cJcXs7lVjDP5mE5AJ64/Go900Myi3kZSDgOC QasgWUTvOZLlnlwQhkkJPOOBnn8q0dI8OXl/KgW2ldSMljmNR/wIjn6YppCbOmTwG7ptk+yR5H3l aRmH6gVmTaVbWOry2ur5SJQAjxW4IYD+LnJ6Y6Z6U0DNW00/wm2NupyEekkxjH5YFaSaZ4TVlCiw dzyN8+8n82oA0oNM01FDQWVoB2ZIl/nirIVUGEUKPQVRI1ueaYR6UAJt4ppWpZSEIqJvWpGSp0pL yJp7G4hj+/JEyL9SCKxNzyGRCjFXXayHDA9c/SpEWI47++f8/wCTWiMmK+3jaWB64z61KbNyY9qK zlh+7J5I9+/9atEs0dTF4dge1+ywspVNxEaj1AzwB+PPck81V0q+1GylLWV7HHnggzxkH8CcU1qJ 6G7b+JPEvSOOGf6IG/8AQTTrzX/EM2EvfDK3MY6FrSTr7ZzQ1YFqZ82qwMD9t8KzxnoStxIn6EYr Ku7zSpJCYorq3AGChVZAD9cqaLhYqfaIEbfbyNGex2sh/QtViPxDfQn93qd2B2/eM4/IgUXFYuw+ M9Yjx/p8cvtJEo/kKvRePNRBxLb2coH9wlT+pouFjSh8fWJA8+1uEPfYVb+ZFXYPGWjTEAyyxE/3 4z/TNFwN48VGaRRIgqZawNjC1vwtb6nK1xCyxTMctkfKx/DkVht4M1OMnyFgPushH86pXJZPY+Cb 7cDPLFCvfacn/P411WjeH7HSRuiTfKert/T0rRMixr7VYbWAIPUEVSfRNKlP7yxhOfbFAiu/hPQJ Dk6bDk98H/GoH8EaA3/Lpt/3TimIiPgjSE5he6iP+zMwqtP4ItnGBqV4B6GQt/OqsK5nzeAYz93U S3+/AhqnL8Pps/JfW5/3oQP5UcouYqTfD+9H3ZbJ/pvH9ahHgvV4WzHFaEYKnEnUH/ezRyBzEMng 3VieLJRn0nWmx+CdULDdFHH7mUH+VLlY7naeHtKfSbEwyztNIzbicnC+wzWgxpDJk6VItYo3JFPp UoNUiWPBOKcGHFUiWPUZp+KoTF6dKCTTJEI4qJhjrTQmRMM+lRt8oLMeB15qkSZF94i0iyz59/CW H8MZ3n8lzWOnje0nvIra0srqbzGC5wAfwGef0ockFjpyf0phJ9aTGiNjUZOTUsomU1Mh4rA3JR1y Kq61cyWukXk8LbZUiYo2OjY4P51aJZxFp4p1CyJiLSTmaIENO5ba2Tkj29vardn4k1KPy5ZbiGeN yQYwACuMegyM5461pFW3M277Ha6Xfx3tvHNE4ZHAPuD6H3qLVPEWn6VKIbh5GnKhvLijLHH16D8T TaJTM/8A4Su4uIpJbHSmKICczTKp/IZ/nVG48S64c+Xa2SqD/EWz/P8ApRysOaJRm8ReIgHPm2yh f7kWR+ZrPl8T6+6YW+O89lgTH8jVcrFdFBtX8SXbFVu7t29Il2n/AMdFNbQPEOpEGeC6kPrcyYx/ 30aVrhexoW3gO6fH2q6hhHogLn+g/Wun0Xw7Y6Pl4FaScjBlkOT9B6Cnyivc1TUZPakykRseeajY 1LGTIamQ1ijYkBrM8W7n8N3qpjcVX/0IVSJZ5nMXa6V9rjtgjHatG2jOxSewxkVsZGhbXtxpyCSB 2jQ/6zC5wMemKVtXMzbo9LuyG537cF/eq5rE2ubel6Zc6jphnjhkjQscxO20ttYgj5cnsRjj61e0 Oxhu4EiW9iDLgYdGLN6EHcP6mqTuS0bB8JWP3p/Nlz1ViMH9M/rT10TTrYYis4hjpuXcR+JoaBMe ybVAAwB0AqJuM0hkZHrTDgdKkZGx9KjY0mUROajY1IyZTUytWJsSKeB61k+L5zDoMqrgtI6oM/XP 9KtEs8+JJmjViGYNk46jjvWxZQjYF7sa2MjqTPBY2AaO1i8x12qI1AZjj/POapade6cLTEsrWt10 EqxSbh+Q4PHUc88HNXZXIWx3WiiGW0iNqgSDGEAUqABxwDg4q5ceErHUdzshikfktHjk+4PH9feh ko5S98P+I9CZ5LBpWjzkm1fep9zE3T8Nxqhb+Mp4mMWqWYdk+8Ycqy/VG6fmPpRcZrWeu6bqBAtr pPMP/LN/lf8AI9fwq05wTUsohY81Ex9KQyNmxUTNSGRlsVEWpDJVaplbIrBGzJA2KzfElrLfaasc KbykgcqOpABHHvzVolnEyWssF0zXFu8GR8quMH61qW6rG0W6aFvl3ErkhTzweBz9PUVqncyasjo4 NMkvIcXTtEpO5UUAkH1Oc/lVnw/q9h4a1DyNZMkA3ZFx5TGNs88EA4+h6Vd9dTO1z0Y3/hfxIitb arZrOMESxSosv59atNp6Wdvvt9Un28kZdXyPqwNJX2Katqcvqvim4tGZGSC4QdCAVJ/HJH6Vy1/4 o0XVP3Wq6adw6EgPt+jcEfhWnKkRe5x/iSPRwsb6VPLIGJ3RyKTs/EgH8yao2PiG/s8LBduVH/LO X51+nPI/DFZS0ehotjotK8Yfap4ra6tSskjBFeI5XJ9Qeg/E10Zas6nNKDUNH09TSk4Kac9VfX0G Mwz7VEzDbnvXOoV/ZU0nZq179uvf+up0udD2tRtXTvy279O2n9WEeRM8Y/z/AJFV5XDO23AHbFc+ Fp4uNS9Z6W27bb9/W79ToxdTByp2oLW+/ffbt6WXoSI1TKa60cQ8N0qRW7VaJZHPFFcxGOeNZEPY 1FaaZp9u4kitlDjkFiWx9MnirRmzQRqtROGBVgCD1BHWtEQyJvDmgXxLXOmwhj/FFmM/+O4pv/Cv tIfm01HVbU+kdwCo/MU3HsK7ILj4eSxgmDxPeD/rrbrJ/UVkXPgrUUJ2a3by/wC/YqP5GpcG+o1K 3QzpvCusRg7X0qf/AH1kQ/oayrrQNTRCJtJSXH8VvcjH/fLDNQ4SWzK5k+hjzGbS7iKXyrixljzt eaIjcf1FbGl+MpllWPUQksROPNjGGX3I7j8qE+4HXiVJI1eNgysMgg8EUwtzVAQu1RM1AH//2f/b AEMACAYGBwYFCAcHBwkJCAoMFA0MCwsMGRITDxQdGh8eHRocHCAkLicgIiwjHBwoNyksMDE0NDQf Jzk9ODI8LjM0Mv/bAEMBCQkJDAsMGA0NGDIhHCEyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjIyMjIyMjIyMjIyMjIyMjIyMv/AABEIAwAEAAMBIgACEQEDEQH/xAAfAAABBQEBAQEBAQAA AAAAAAAAAQIDBAUGBwgJCgv/xAC1EAACAQMDAgQDBQUEBAAAAX0BAgMABBEFEiExQQYTUWEHInEU MoGRoQgjQrHBFVLR8CQzYnKCCQoWFxgZGiUmJygpKjQ1Njc4OTpDREVGR0hJSlNUVVZXWFlaY2Rl ZmdoaWpzdHV2d3h5eoOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK 0tPU1dbX2Nna4eLj5OXm5+jp6vHy8/T19vf4+fr/xAAfAQADAQEBAQEBAQEBAAAAAAAAAQIDBAUG BwgJCgv/xAC1EQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS 8BVictEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4 eXqCg4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri 4+Tl5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/AOXQnzB07dqvK2Rnj8qzwQswq+vI5rhmdkWK D83b8qdtB5OPypCFBoPJqCh3PbH5UoYkc/ypB04o5FMBcsDwAPwp3JPb8qQe44pygcgCgBNxz0BP 0p27I7flQFJpMYPPNADySQOn5UoyBnj8qFB7nj2oPNAC7jjHH5Ugz2x+VHBPsKUUIQ7J3dAD9OtB 3dePypuCDySaUED3osA77vJ/lRvJzjH5UctTlBxzTAFyeuPbilL/ACnGPypAT0o49ePSgBwzt7fl SZJ64B+lKGGOOlDDI5oAXsOmfpQW56D8qCMgGkwSc4NMBckc4H5UoPzdB+VNwfuinBSBwRigBQee o/KnFjk9M/SkxjnikOaAHZwOgz9KATnkD8qQAsMilxgUAOJGcjH5UZ7nH5UigH1xTsAZxQIQtz2P tigMx6Y/KjAzTwQPagA5UdvypMnpx+VKWBGaToAM9aAAEDqR+VKGOCCF49qAQOwoHzZ4pgODHGcD n2pcn2P4U0naozQp7jNAAW5OMflT93TAAP0FJ8vIpnQdzSAkAOSOPypuCe4/KlHJBHBNK2OgoGJ7 nH5U4FsYHf2FJtG6n5wcCgBASPvAflT8cdR+VAyeDx6UdBjP40AAyW7flS5xkYGPpQBtzSKxJIxx QA4OewGPpSE4OePyFLgY60FemPzpgBZiP4cfSmg5YdPfinlCOTyKaeCSP0oAUDjt+VKr+w/KjJI6 c0YzjIxQBIGyvOM+uKYpycHGPpSnA/wpuAeeaAFOc5yAPoKcCCpzjP0ph7ADmlUHPI5oAUuQcDH5 UmMHPH5ClxhgSc0r8jAFACFs9QPyFKCRjp+QpEwevWlycEfrQArMc9B+VMLnGOOPan4bHA4puRlg fwoAXPGcj8qQvkdB+VJz2NHrk80AGWXqBj6ClPOMYH4UbqQthuBxQITkHacdPSnKWA6D8hTWZj7e 9OUgLTAQnkng/hTWPJGB+VOJxkYpg5ORQK4oyckY/IUmSBzg/hTJJFhOWZVz/eOKpS67plsT51/b qe43g/youK9jRUkdh+VBcg8gflXPTeNNDiBxdM5HZEJzVGX4g6auRHb3L+hwBTV30FzI67dnPT8h TQ2Dnj8q4d/iFHn91pz/APApBUR+IUn8Gmp9WkNVyy7C50egeZ06flSEgnjGPpXAD4gz5/5B0f8A 38NSJ8QgOZNObB/uyUOEuwc6O5wevH5UpOOOPyrmbLxvpd86xN5ltI3AEg4J+tdGjBgD1NKz6j5k 9hx39gD+ApSzY6Lx7UM2QKF4HSgYm7tjH4U0k55x+QpxwF4PNJjjJFMBRJ8uMDP0oaQsBwB+FR45 64p4B2ngGgQp54wPyoHy+n5Ui5Xg9KQ5ZhQFxGJbkYH4Upc5BIH5CnADJ9aaw9BQA0tk8bfypDn0 H5UAAdRSEc96AFUnrx+VGT6Dn2pMZIGKcMZ5zxQAh44wPyphJPG3j6U8jHekyfegQnAwePypCeR0 /KkbIODTgPTmgAPQk4/IUIcg5x+ApGbjnrRnI4FAAQQM8Y+lIMY5x+VIDtOCaXJPagBAx6AD8qQn HXB/CpAo47CmspHIpgMzxjA/KkbIIIx+VKM5obPpSAFckjp+VOZsEHj8qZ93jGaRjmkA/OV4x+VN B7HH5UAD1NJzzjpQAp4HY/hSMdw4Az9KMfL1pQtADd3IHB/CkJAPQflQVwfrS9ODzTAOcjgflSE+ oH5Uc5pSBj3oAQkkdB+VB/D8qOQOvFJjPegBN3Hb8qaXbpx+VPIHGOKMg0ARE/T8qXJHPH5UMMe9 GO+OaADJI7flTRgN26+lOpoHIPvSAwWGZfTpV4LwKqEDzB+FXuigVMy4gBkU7jHpTR1p/wCNZliL z0pwXHWgLjkUEkn1oAfs+Uc0qkA9KaCTzTl6cigBQcUE88U3HOe1OAx9KLCFGcc9aDxwKOfwp/Tr zTAYoxTx+lMOSTinrjvxQAbSOc0oUHFKOTRkjmgBGHNPHTrTQuSCTTlzmmAoTueKQg9eopSSeppc ADgkUAJtAA9KQ56YzSjr1pR1zQABR3zTgSB6mjIPJ6+lIevWgBcEnjvQoIzmkGTinbee9AhdvHQU E4BzS+goIIxjn60AIOQOMU7I9BSjFNwN3AoAkA+UGmZOKdknA44pducHHNADMZ65pVXvnin4+XrS Fe3emAMML2OaRRxn0p2MY9qGOOgoAbjJp4K4z3ph5OaTbzkmgB5XOKUAgY7Uo6d8UuSPegY0LjPr TxnGKQYwcnml6jA60AABB7U9vTGKYC2QDzinEZPPFACKOMGg8EYFLwBxThjjNAC8Y5703aSe4pxX PzY6UpPfvQAbOmKCpDcHmgU7qMDnigBEHOSMZoY5FOJxjn86CARwOaAED49xTeQc44NO2YGR0FKe QcUAKo6mk+7jnJpFcEYobqCOaAFYj86YDg8U8HkHFJwCeOaAGgHP409Qc80nIyetKMN3w1ACspUj nrSA4yetBOBgjJ9qUDAyRxTENGSee9GzbyTTvl68ilbBT0A9KADfnOO3SmqAW9D70xmSNSzsqr6s cVmXXibR7EHzr6IsP4U+Y/pSuJs1ifmIIpT93JxXF3nxEs0JFpaSzH1fCisO58davcZEKw24/wBk ZP5mqUZPZE86PTWIAJziqk+q6daD/Sb2GPHUFxmvI7rVdRvCftN7M+e24gfkKp4HXqfetFRmxOZ6 dceN9GgYhJZJyP8Anmn9TWXP8RBki105iOxkfH8q4X5QOlLv44q1h+5Lmzpp/HWsTZMaQRf7q5/n WbceIdauP9ZqEoB/uYX+VZJduxpuT61osMiXNE0k00zEzXMsh/23JqLCj3pO+KUqMe9bKhYnmFyM 9KCw7CkCMeMGp47cnjB/EVp7JIXMyDdRuq6LB2BwnFP/ALLdh2X3JqlGKFdlAZNBU4rSFlHGp3Sg kdhUb+QgPzZosugrmcy8civRPBetvdWJs5iTLAAFY/xL2rgJWDNheldD4NgmOqeYmQoQ7vpWFaC5 bjTdz0sPu780oYgYyT71HAfl6VIwz0riaOhO6HcbeaXbkc00dSOwp33unFIZGRjk04fdyD3pvOcd 6UZ3dKADcScmmk5NPxjJIowCOCKAGFTng04EhcdaNvrnFJwD14oEA44IpoIyQc4p7HuOlR4LHFMB celN3HOP1p23BOTSYHpwKAFzkf1pDkcgc0u0HpxSHgdc0AIVB470jDYB600zxxyhGfDEcVIcngni knrYCMjjP50ueMUpXsDmkK4/wpiDbkdKBxzTgRjHShwpAxg/SgBOcdKQtShsCmnBOaBiAEc96bnj Oafzim57AYpMBuaUdMEUH25NCk5pWAQnAwB1oHH40p46jmjPPFMBCpIoGaRwzDCtg0EFcDJzQArE Ypg5p2AeTQBk+1AAOBjFIeaGFHagBNq/j70BcGnYGPWgnH40CIzmjG4Zp5BxnNNb5VyKYyPkHkUH Oc9KccMMml28UgI+/WnqAGBppAU55pc5YCgDDUZmHPpV76CqkK7pevarmBUTLgIBk9KCO1KCPxp3 H1rMsTPbvTgMD3owB0oHTrigA2nFOGc9cUhyAMmhckZ7GmA7BPSlCkdTRjIG004/d54oEA5pccki mgccGnjpzQAgJPJApeMc80EHv0pw/P60ANxk8U4fMMGl7HH6Uxep5pgOB46dKXBwTmjIB65p4wB6 mkA3GADnNAAbk0oXcOBSsAOKYBgE470uzbzQnUmgjLDJ4oATDEij2FPwR8vb1oJyeBQIQDinDIGP ypoXvT8570ANJI4NPVTjOc0mwE5JzSrkcimAYycYpdoHWgMew5oLeo5oAQD3qTPvTQMjsKM9MCgB SCMUc+2KUDJwRmg8cYoAciArzSYA4BoHA649qTtQAhAznrTsAjpTcEHIPFPB5xQAqYIINJg0pAJ9 KfgYycGgBhQADPBNPyVXAx7UmDnOKXBPQUxibqCQaOBxgg0pXAFIBvIGeufWpeMcimDpjrRnb75o Af8AN0UDFGePehc+vNClixwOO+aAFAwMk0Ajt0pW4Xp196AB0pgHrg5NHT2pDkZwOlIA2eeRQA4k jkcikAOM5pQ3PWgZwRQIBtBxSZI4pAuG+anH5VxnA9SaAuKMHHJFL8pPvWXd+INJss+fqECsvVVb cfyFYl18QtOiJFtbz3DDocbV/WjV7E8yOv24PFIcBc9682vPiBqc+Rb28EAPc5Y1iXWv6teAifUZ tp/hQ7R+lWqcmLnPWp9Rs7VS1xdwxD/bYCsa58a6LbZAuWnI/hjUnP415a2GOXJY+rHNL9MCrVFv clzZ3Nz8RSwZbTT8+jSt0/AViXXjLXLoYW4SBT2iXH61gZ560da1WHiQ53Jp7q5uWzcXU0p/2nJq EKAMjFHUU7yzxWyoxRLkJtY/NikOR1qaONxyM1KLOeYYIYnOatQsFylnNL19614dBuJAG27VHcnF Tf2bBbHMt1ED6Kc1dkibmFtY8U9IHfPHStYyadGSTukP5Uw6pBEQI4E/Gqt2QroopZykcIT+FTpp U5HK4HvSyazOV2rhfoKqyahPIOZGP41VmK5oppEanM1xGg9zTvI06E/PLv57CsYvK57mgQTyH7po a7sLmy97psKfu4WZvUmqr6qMnZGo+gqvHpdxIeFP4Veh8NXkuNsLn8MVLcVux2bKbarMw2hsD0FR NeTSdWNdDB4PuWI3BV+pzWnD4NxgyOf+ArUupBByM4gtM/GDTktpnPSvRoPCtnH99XY+5rSt9HtY MFIEB9cc1DxCKUDz7TvD1zeSL8hVM8swwK73S9Jh06IRw/Mf4mx1NaccKLj5cVKqhOg4rmqVeYuM QQeWKXBJzQDzx+VPI4x0NYGg1jgcHn6UnJJ7Uu35ecijGFIHSkMFwfrSMuTx19qAdvQZpOTmgBc4 GCaNox15pyqCOhNIeMc0AJnBweaQgck/hTmII4ppzjjrTENGTnijBTkUhBzweacVOBz0oAbzk+tB 6U/grTegPQ/hQBHKGaMqrbT64zQAQBk5p2MdeTTWU9aAB442OSoOOmaO+KBzTioGD3pgwIGOKTpg 9aD60nakIRjz0ozjpT8Z5ppO3jGKYB2pp6YoIOM5pQCVoAbtJwKU4X60oJI54oZcnOaQDGALZHWk HPHSnYxz0NJ0/GgYHBbBFOwAeKGYDvkUhO4jigQ3AGT3pO5PU04YJIpCp7GgY35i3J4p2eB2pucG gg5zigQEknrQT2oKr1zzSAnp3pDAntTefyp3Pqc0oHGKAExke9NJOCDTsgfWmkZPJoAaMilJ7UYK nGM5p3GenNADGOBikXlhjilzz0pFyWHGKYGXbITk+1Tkd6RfkQADtSgHGT0rGWrNFsAGTTscYozz 6UoOTyKRQFT60Y7+lPOD7UgAxQAnPtThuPBOKQrjmnZJ4FAgzgYzzQKTCg8807G4ZximA7kHtinY 75qPoOetP5xxQAHNKGIpcA/SgqKQDR+Qp6Y9aQen86UZAOFpiF2jlutLwfWjnvinAjGAOaBhkkcU bccmjPpQMMD1FAgAXPWnEBulJ7cU8fKvtQAnGPpTehPrTs55GKAAOtMBOB0NGfQU7bxweKMYPt60 ALnjrxS7flGKTYv1pV5oAX+IHGaMDPFKcdjQFJ4NABg+ooXjqKcR2xScY4FACf7QoBLN6UZIPFPB Hpk0AEa84JzTto7UzB65NPUgDvmgBM5GACTSZx1H5Uq/TmnDGeOc0wG5+bB604Jx16c0rAenNJnC YANAAGwD1/GnAkrkAU3aMVIuKAEK9+hPekx7Zpxz2FKDmgBq4U808DI6YFJxyKMHHXNIBSCPpSBs NQXOOeQPSky34dqYDgATkH8KeQSMVDJIsKlpXWNR1LHGKyLrxXpFkzB71ZGH8MQL/wAqQm7G104z n8KCdvQZ7Vx8vxCtIz+5sp5D/tEKKzrj4gX8h/0ezt4h23sWNOz7C5kd/wBeowaa8kcCs0kiIO+5 sV5VdeKNavPv3zRr6QqErKlked90sjyt6uxP86fLIXOen6p4u020spvIuo5roIfLjTkFu2TXmd3q Wr6pLuu7uR8/w7iFH0AqHIA6YoVir7hwRWkVykPXcjVWj6qmfWplkiJO+FvXKtUfrSqQD7Yq+Zis PzbNyGdP95aXyVcZWWM+27BqLaSOAalSzmfnyjj1IxVxm0LlF+xz/wDPMke1NNtKDjY35VMtsYTl 7lIRns/P6VZh1CS2b9zeyyN/DuUEfrWiqx6ktWKItJmPCH8qtRaRdOMiJseuKfL4mvXY70h3disY X9BVWTXL6XP71ufTiuiLutDNs0F0VlTdK6KPc0hSwt+Hl3n0UVjmS5nOSXY1Iljdyn7hpgrs0W1O 1jP7uEdKgfW5Af3YC/SpIPDd7MQfLYg+1att4LuGwXUD/eNJuC3HyyObk1K4mPMjkemaiAnkPCnm vQrbwVEq5ZufZa1bfwvZxfej3H3qHXgtilTPLk0+6kxweav2/h28lYFY5CfpXqkemW8KDbEgHsKm EEYIwuKh4rsUqZ5zb+DrmU5cAeu41p2/glQPncD6LXcBFQ8U4gcCsnXkxqBy0XhC0TBYFsevFX4/ D1lGAVhXj1Ga2j8y4I/GosEN1qHUkyuVFaOyiiICoAPYVIIVBwFxVjaeKaTzgDmp5m9wshgjXPQU 8cdqViMdMGm5xwfyqbjEIAPTJpoyufen4yR2oYggjmgA+YrSe2eaVc7c+lKOTk0AgH5VIBzzzikY 84pucDrSGKxOfamFweTwKdknnHFBG4jOKBjB1yOPSnbuMAc+tLgluSKULwT3oERkmlUDB5Jo+8em cUE5OQfoKAF2rxjNJ0PXNBB25JpBgHgZoAV1745pC3yYPWnBiDzk5pGIx2xQBGRlaAT2P50vB70i 5ZzTEITzk/pTgoYZNPCDdgmmtgUANKgZ7fSm7iBwMjvTiARnNNyxyKQAORnp7UgHPan8Y5NNwMDA 5pgKDjrS/eJpMgYzTSD24pAAGTwKADnGaaGxwDzS5O4ZFMAb1NJk59BTmJIzik6jkUgG4yaUjnGK Vep56U4kelAEZH5UAZXJobIwMUDOMUANPK4xSheKXj1pQRjigBm3HPWmkHHPSn57YNIp7EfiaAAY HBFKSMcCmknOMUv0NADCSD0oJyOlKc9abnH/ANegBcZpD14oznjPFKMDnNADOvfFGMtThg0bcHig BvI9hTlPzDJpmD0xinBeRz3oGUjz1xjFJilf72AO1HVc9KwNRNuRknmlBxikyADSqeelAMUHk55F ABLZowM9eaUYPfNADsZH9Kbg5z2pyt2HX1pQO5HBoARQOoqTmmYO7A6U8jOBTAaRzyc09RgUAAdO tBwKAFP1pRmmjJ6CnYbGCaBABlqdyGxQq9yaVsfjQMaWz3pyjntSAc5IH0pwGe2PpQIXIGABzSZw eRTgvOQPxpCM9TQA7apXOaAg29aAAe+aMk9KYChRg+1BAI9acFJHApcYHAoAaF+X2pcY+lOHTg0j ZzigBBjrTgAzUKoxjFGMdKAEcDdTlJHOKCCcHFOA4wR+NADSwPFJjkZFP+U44oK8ZA4oAaRk/SpB 8qdKYOtOJHtTAAATuNIQc5qQAHBz1pDkNjt60ABUEUAcHFGV2nJ4A6+lZ1zr+l2eUmvoVYdgcn9K LibS3NFf0oPXAOa59/GujqTtklk9NsR5/OmL420jBz9oU+8X/wBenyvsT7SPc6QHBxTl981gw+LN GbJN3t/3kIqG78aaTbL+6eWduwiXj8zQ0w50dPn5T0pgYkgAZrz678f3TFltLJIx2aUlj+Q4rFu/ E+sXgIlv5VU9ViGwfpRyy7B7RHq899bW4IuLiGLA/icCsa58YaNb5C3JmPpEpP615Y829tzksx6l jk0eavuKapsXO2d5c+PlwwtLE/70r4/QVjXfjHWLlCouEiU/wxJg/nXN+aPelEop8i6ibZZmuJp2 JllkkJ7uxaoc9ewpgkzTgd2cAn6VWiELx6k0uaaSKTjOKYDs/nRmgLnmmng0ABNNBUtguBUM7sFJ HSllt0jgR/nbcu7f2z6U7CL4jtEUFpXc+ir/AFphvLSI/LBvP+02ax/NbG3JxWlpV/p9o3+maaLr n728gj8Ohqku5Lb6Eo1C4lOy2gABOcIlXINH1q+I/cygY6t8orrNF13w7KoSKaK0bH3JV2H8+ldX CYTGskZWRT0ZTkGneCBanncXga+eLc0kIb0yTTz4E1QkYkgC+u416QpVsEAAVLgHgdKFVtsiuVHm 9v8AD65Lbp54+D2zWvB4KgRg0j59guK7DbgHHNIMHGeuelN15MfIkYkHhayjz+63fU1ow6RaQcLE o+gq5naSeOe1QXN7bWahrmeKEdjI4Ws3Ukx2Q8QRqeFFSbQOAozWT/wkuiDltUteP9uoZfGGgJyd SibjooJ/pS1YaG1nDAfoKeSV+vpXMSeOdCUjZPK/+7CxqF/H2lgfJBeufaID+tHLLsHMjqiWbOT8 tKAFHOK46bx5BgBNKu29NxApjePJyPk0STHQFpcf0pqnLsFztCeKPl6GuGPjLWJB+70eBOeC8pqu /i7XjkLb2EfuTn+tNU5Br2PQSxH0pmCDkmvOZvFniDvc2Kf7qA/1qrJ4n1xxzqqKf9hAP6VaoTFc 9Q3gjBpDhh3ryh9f1huutTD2XA/pVZ9X1J87tWu2z/00IqlhZsXPY9g4IwQcjpTSQOSR+deNNeXM nLX10x95W/xqFpHY/NLKfq5qlhJvqTzntZljXO6WNcerCq76hYL9++t1PvKK8YIU9ST9TSYXGNox 9KtYJ9xe0PYm13SYsg6naj/toKs2+oWd3uFvcxSkd0cGvFcKe36UI7wyiSJ2jdTwynBFJ4R3tcPa NHuI+YcnilXjvxXH+EvFLX4+xXrD7Qoysn98f411wYE9ciuWUHF2ZopJ7D9x6AULlvSkzk4xSkkc bakoQjB5pcjHtR5efmJpDwaADOeegpSVxkDNKMFCWFIPlHA4oAbnOM0oTDZB4IoPfGMUY+X0NAhr DGAKRh0FKeueTSHk8cmgBMAnGKcFA6UjDHB60A4zzQAHIbPFNIJ5Jp2/jnBpoY5xQA3B7HpS4IHJ p3QUHBXNAhgNK2QPak6mlYZ4oAQc+lBFKPl68mhjxnjNADDgE+vrQoz/APWoALmlXg0DEzjigAnm nlNxBApvJGB+NADQM5OKcM9KBxxmmOSG9RSAUnOab9DzTmHHFAPByB+NADdpzk0YI74zQWx9KCeA e1ACYx1pp56k4pxXPOeKQjJ4NABs4yDQ2aDxx3ozQA3vQVytOYjv0pvGfrQAzGCfSndPxpSox1oP Tg0AJwDgikY56UZyDmkLYHvQADk8mhcFxzSjlaAvIoAokk9OvFAx3zSk5xxxilUBs4FYGw33xxTg D1xSNnOKXpxTAMevSgJ8xpQB60beOvNAAB9c07acdaXbwOaBlT60ALtPbrSg8+9KGFJnnpQADk0u 3nFH0GKcOlAAvApQeuTz703kc4/OnAEnkflTAAccZ605effHekCYNOAPQdKBCcnjFOBIHvSZyaVc Y5GaAHEkjJo7Z65oAPegKev6UAIeBmnKCPSlAz2zT+3HagBoYg4pS2R6e4pM5+tAUY60ALnj2p4H qabsAGc045AzTsAuwE8g0hwOnWkDHpil2+x5osAoUsvOaVRg/MeKVRkd8+9OYACgBOME449qYuST jp708HauBzQGAGMUAMxtzinrlutIVxkg/nUN1dxafbPcXUgjiUZJP9PegTdiy20BmYhVXkknArld T8Zwxy/Z9OQXEudvmMcRqf61g6trV3rtwLcubW1IzHEePM9Nx96p5jYG3UtvKiMW5T7rjvmtIw7m EqjexNfXOqXsqNqNxIYjLsdEO1F/KqhhS01GMyKixBucf4c1s2/h69uWzd3IETYLon8RFakPhvTI eTDvPqxquaMdAVOT1ONvLhLgReXuBAO4N659aSyjTzDLIDsTnHrXfwaVoTxTiWe0tZIwMLIdu/Pb NZl1o9vcWvkQSFFCkL3HNDrK3KgVB3vcgsPEsbRrbJbK6l9u1Y0wfwIyfzrE1GG3u7jzrUpEHcqV PA3elWE8PMjCB5ra2PU3E8uwD3z3qtcfZUjaGyuRKIBvMyjhmz1HtTtFNSixe8/dkZbBlJU8EcUm eKmmt3h2sxDI4yrg5DUissDKXhEhborHAreKuczuiAjPUCk2qewNPeVWYqY1Uj+6cikxzTtYLtDd q/3aPLT0P504DOcUdqVkHPIaY096PKAPDEEdxTwCcelX7e0CyxmZQ8boWRgeKTjFFKc2ZrRszZ35 PvTvLb1FaAuNPiunIYSq8ZASNTkN6VoaT4U1vxBuk07SbuWIcmQrtQD/AHm4pKKexpeoYBSQ9Bmm mKQnhDmu1TQ9G0IyDXfEtpFIRg2tiPtMn44+UH8as2Ov+HNNR7jTvDwnCD/j51aTfn6RrgVD5FuV FyZ55LDIUIKH8qqNHIFxscAdu1ekSeMNJvLeSO5gkSR2zvgs0EajHCgdRz3rmdSEBWOWA/fznHT8 KlS97laKl8PMmc0I2borc+1PFtMekbflWmCfWnbiTW3IYe18jMFpO3WPj3q3Ztqdg4a0upIPZJMD 8qmzzRmnyIXtWdDp/jXWrfCXi290meT91v04rc/4T22CjFpNu9N4wK4KkZsdTzSVJN2QKpLod0/x BQZIsHx/tSf/AFqoXHjzUZhttLW3g/23JY/hXIkluaQ+xrohhI9TRSl1N248Q6vdDFzrDIjdUgXb x+FZUr2hdmImuHP8czVV5o/GtlQjHYOdjw6q2RGuPTFTpfOgwkcQ99gJqrijFU4RYKTRdbUJ2ySV BPXCgVF9qlBLBiCe9QfSjtR7OPYOd9yc3k7YzK5/GozPKert+dM70lVyJbITkx5Zm6sfzppNBwDw aTtVJJCuGfejmgUv407CuJSHmloxQAmDS0lLVWC4UYNB60e1FhB0pD81LQaVkBJZzNa3ccyNtdGB Feu2N4tzbRTqeHUE144eGBr0bwhcmXTAhbmM4rixcFdSLizrVfOOOKeDyc9KgiYnvmpu4yc+1cDR umO3Z4qNweBnrThjcOKD97pxUjBQxGD2pX9M0YwSQaTNMAVQFOT+FNOSaeBu6+nFJtAXg0gEANAX nrzSdTxSkN+VAABluTTXPzDAGPWgEA8/pT/lPJouIi5J4NKFwadjIP8AKmbtvUUADFT2P0pvIHPS lySwNBycjpQAck8ilHBx3ppJ4H60FyTjAoAftJyDTdmB2+tG4Dg9fWk3bicDigBCB0HHvRg9aUJn BIpep4oAZk+uKGyOhpxG3rzSEZxjNADc8dDmjovvSncM5pN3cikMQk44oI4GRQWyeOKME96BDSvW gjK+lO4xkmkJBOBTGJg4pMZ6nmn9eophUdqBARxSYwM0EcClA4oGNbrTfmHpUgIJwRTSBk84pAIB /ezUOXacqExHjg561Y2+vWmkUAIcqKQYI5pQuRilGRxgUCE6UgyT7UEHuKACCMetAykeDjFIpC5P el64PTgUuBxxWBsIp5zTjgH1NNZSBntTsZIpgKFyv9aVOBik+nT0pcjb0oAM9s04460nHHFGOfag BynsBSkHPtS4HGKXkrQAzHPWpFBHANNXp0FSDp6UwE6dRxSlh24pCPQ0Yb25oEL2znIpR0x+lAGT UmCRkUAMxgU4dRkUhyCBjinY96AEJ9qcCccUZHAoB5xyKYhQcYBp4ORnvUe33zThx349qBigZJ9a UAc00DJ607BVeaBXFDDoRSfePPShQCCe9KvLCgB23FHO7p0p2MH2FIvfgkUxhuOOBSEk44obHYUq AdB1oAUZIHanbM8+9AGCM9qVjtPXrSAbK6xozOQEAySe1eba3q761qC7mljsIyRFtXOT/eIrovGm pOlpHp9uVElzy5z91B1/OuRinngSPYkcmfkQxtwT6H8+laU49TnqSu7EcpeeRbeSSOX5hi4GSVFd No+hxWf7+U+bIfukjoKpaRZTAwxTI0YDFyUYEOPQ/SuguruKytnuJw/lIOQgyfyoqTeyLpwtqy0O en5VU1fUf7HijcxxvK7Y8t25A9SKy73xMtvpkd1bK8ck2QgcYK471zMMWoavMSSxBOeef/11MKd9 xznbRG9b/YdfvHkvIoVnj+5g7A4PbHetvHl8AYA4wB0rkrjR5reNWEhDgc5UitjQrya5tXinJMkL BcnuDUzhbbYuL6M0bm2S8t2hkAOehI6GuPnRbfzLfy1RxkcDqMd67bnNcxrkWNVXA++Ofyp05PYm pG9mZcLpHH9mklV4nGcrzsb1/wAaqvGjP5czsFXoQM4/CpD5SfuVhO/pvZ/8KtXloEi3yyKJkUAq vzbj9fpXZojjuzPkit4xshdpDnl2XAP0FR85paM80yG7i1dtNMnu13JgAkhd38RHYVSFW7fUJ7KJ kQB1kO0Rt0JNDuloONm9SZtUTTdPks57cST78pG68AHqT3HQU7TLaC+sC+sX8dhY5JHBZ2/3FHU1 XmurbTY5bM7pbqQYuZsZI4+6M9Kr3ZR7WydQOIyBz05rDm1OlQSR1dp4o0Hw7g+HPD0clwvS+1U+ a31WMYA/GsfW/E+va9Btv9duJIV6Wqfuox7BVwKxYtrOA77QTyT2prjD8HIzQ23ux77lfYOFj49s dTW4bZLGyjtrx5FjnAk8wrhVbjj3x3qHSk0IrM2rzXoZSNkNtGDvH+8elX7jxbp9tKp0zQImeMYS fUJTO35dKJK4KyNGw8Ipd2wuDqKOuMhLeF5HP5DA/GsPU0WK5W3RSBGOQeSPr70+88ceItQhMNzq ssVt/wA8LZREn/jtRRSRhQ1sZTvXlMZycc5PerSk9zKbSWiKncU/HpT5YHhfbIMMQDj2PNMHXmtz nsIRSU7+VRM+Dhaai5OyBK4rMB9ajyScmjoaMkV0whymqSQvFNNKSaTNbJAFGKKXtTAKBR0oFTYd xaKKDTAQijpS0HmmIbSU6imAUdaKKBBSUUlAB3pc5pKWqAKTtRR2oEFFFFDAQ12PgmfErxHowzXH kHFb/hGTbq0a+vFcuJV4FR3PTYWIxgcetWFYBuaqpwQM1aXPt9a82RvERgARin4GAT3puAX5PFIU yeDx61BQpO0UikntTSM8AZxQpOelIZIdxYE0j7f4aFOfWlKZGBxTAjVe+CKXtxzml+Ytg00qRxnm gQuzac4yaCdoz+lB7cmkzl6QDc856UjZPTk0/HJBHFLlWAA7UDIt5HWlBG0n1p7gHg96gYkcfrSd 0AZ/OpB04HNQjJxgVKpGOTQncGgLYHIpR0GOaCnTvR06cVQhckDmkV+uadgZ5ppHzYWiwCkAjJFN 5JxjFPYlQB3pu7ikAMgA9aZt6+lO3cYPIppJxnpQA3bz7U4LSgeppu7FACMPTpQuAfajsTS7cf1p AIxOeDTD0pxIz0pmcNimMMc8nilIz0pDxzil3HHSkAvTrTWAJzQDk80FjwKADqaKQk4oznBzTEBH qKOMdKCcjgUh6UhgzZ6GgdRzTOacucj1NAFDGce4oCkEZNOOfxpDnp+dYmw/kj2pO30ox8oANKVz zQA4D5aFHHWg445oXr7UAKMc+tKBkcA0p9sU3PbOKAJAMds0vJHXimrnqRS45piFIHrxS78LxzSY JGaX0oAXjHPWjr+FCgY+brS7RQAD7x5p4OeB0qMjBxT8+9MQu3PO78KXJFKBxSjH1xQMbuxS9ecY oxuPTinEDI9qBCYBTIFHTBxTsjbtpVByB2oAQHkHp+FP+9jJNNZdppVB60wHYw3J9sU7KjgDNNfk jNIAO3WgBx55A/OlHJz3p+CFwKYVJYY/GgAKlucjApwBUCkHHTvTlHFAx2D+dN3LyCwBJwMnvSjr jOaRolLDgHB3c+opCPONUdr/AMSXcvmHELiFAuOAOvXtnNYk9xcpOoYhGjOVAUKAfXAqKUST3czK rMzSMeAT3qza6bJcl1LbHRlUhuwPeuqKSWpxN82iN/wzM07SGTaWAOMDFdEQCMEA/WuZ0sxabeQx Bsu6ZfDA4OTx+VdRjOMcg9DXLU+LQ7Kb905HxbbMbq0mdituUKZC5AYcgH0zUUWtnQ4hJBGrOMbA ema7X7JHdKYJY1dH42npWP4l8E3FgywG1lGedpYEqPUHuK0hPSzJnTu7o5z/AIS7Ub+UR3SwtG5x hEwVrp9LsTawF2GGkIOD2FULbw1c2tjvtJVjvS3ymVQVRfYevvW/bwzxWkSXEwlmC4dwOpqZ2+yV FNbhsyRgVyWtzeZrMajqGrrtQlXTrJpZjtcjhe9cBJK02oJMw6vmnCDZE5q9jPPEjj0JFWHui9kl uUGVcnf3xjpUW0SXjqcgNJjj61tRaZbmUYBZNr9TnLAZxgAH8K6nJJK5yqLbdjCxSda1DZ7muYmi SKQBSm87OM89aqfZlHmgzR748YVTu3fQimpIlxZAvXFRTXghlVdm4oQwOehrVGkyeeYlmhaYf8sy 21j+dZ6mCx1W7W/thIyIQsbg438en41MpK2hcIa6mgE8MX/+mXOq3FpcMcyQC3L5b1BrKvLyB51S 2RhbRjapbgn3NGqXVlcC3WytzGEUhywALeg4649aopg8FsfWsorTU3b1Na30+W6XfCYyvqZAMfXN Le2iWCAy3Vs8p/5ZwyhyPqRwKylVs4Ckj6VYms5khWUQsqE43MMCqSE32IsM4aZsYNVS3JPanO+F KIT7ntTcZXgVSRFzoho9rb2L3TXO7KZjbchX7ueR1PJx7Ypugo1xEYRPLFnOWQZH41hxRiQ4wfwF a1hGsER89JSh/uHFEYy1uxTktie5iETqouBNgdu3tVduM56VZuTbJFGYQwODu3HnrxWc8hc9MD0r ppU3MxtqOaQngZxTKTBpc9hXbGmorQtaIKD7UelFVYLiUDrS0dqYgxSgUCkNKwxaKSinYLi0tJ3p aVguGKKKO9MLgTmkpcUuw9hRYVxpHakxirEdpPL9yJ2PspNW4tD1CUZFpKM92XH86G0twM00mBWy PD1yF3TSQRDv5kqikOk2UfM2rWq46hAzn9BS54rqPUxqXHNa4h0OH713dTn0SIKPzJoF9pEPMWmS Sn1mmx+gpc66IRk7DU0dlczYEUEjn2Umrp12VT/o1paW/wDuxbj+ZzUUutapOMNeTAeinaP0o5pd g0Hrot4ozKgiH/TRgtNezghHz3MbH0TmqTNJIcuzMT3JzSeWSetK76sB0gXOE5Fa3hhCusQkddwr MEWB05re8J28h1iN9pKrknisK8rwZSR6EFy2eeatKPlqFQSeBipxkKCT+FedI1iKUKrR/DtPWlPz DFBXgYzUFjFGCcGn7P4gfqKAuCSOtIc5JHpQA7PQdDTWzjA7UAEjPegDg5oAFU7c4qNs5qUsQMc1 H1OaAExuAxQo2tk9aflQOOtNbPY0ADEkkUBcHNOLELz0pgPc0APb5QMd6hnUHAFSk5UZOcdKYx5B UUbgRrGV681IQG7dO1HLDNKvTjp70JWAbkrx2NPBU896RjkcAU3HPvQIcx45pnG/A60u3JzS7cfj QA05x3NJsLHningHpnik34/CkMbjA600jnkmntg80igkZPSgBoB780vUGqcd+0l35KW0oUdXYYFX jgjrzSTuFmNC4HXFMPWn00j86YBgVG8Y3h++MVKMAU0nn2pBcZkg+1BGe+RT+3NMIx0p2GJkUhpw QBetO2gfU0rAMAPpxSY9cYp/U8UMnNAhvK9BmjO4UoI/GlwMUwGHrxxQv3gac3FKACwPakBnZIwA KXnnIp2PT2oZcc1ibCqtBHJFAbaKUDJyaAFCg8Ckwc+tL7Cl7cdaAG8j7xpwwOw56UHaOvWlULnO M0wFU7eDTgeeBxSA5NKMg4oAAfSnL9KUAEUmMdKAFI5z3peevrxSKaeACuDTAYBz06U4D5gaU5X6 GgYI5HNAhxGemMUh6cDg0LheDmnJg5GMUAC424PXsaCrNzmlG0cd6U5yMUwDAAGck0vB+7nHrTTn Puafnao5pADClXrxSEg0D6A0wFK5I5pwwOnNNx3xg04E9higYoywIORTh8vXpTe/J5qXk8UAMOM9 OaRSQcdacTnpyaRfm4xzQA4HFHUUuMNg0pQ7T0/CgTPJ4XezvLu2EUrv5rptVsDk45pBbW8U8n20 FEZC0flybskds/nWp4lifTNfaaPZ5V4A5LjhWHXp+dZdwiPbeezyEpgIz4Cuc8gL1/Gt0cr0+Q+S PZbw3KwrBGxITLEs/vXSaNq8M0YhuTtbsx71gLc3t5ZNLNcxx2YOJBGoyPbHvUAt7hEM8cMot+xf rj3pShzrXdFRnyvTY9CudLuLyzkjtJPmYfK6ckH6VFpuh+II3Mmoz3d8+0KoYMVX6Zrk7LWriBh5 Vw6Y7E1uxeKdV8vC30gH1rFU57Gzqw3Orh8O6hL80qR2yd3uHC/p1qhqeo6PoSERym+uwOqjCKfb /wCvXOT6pdXIzPdSOP8Aabisi8kWZSq8/TpXVGhpc5pYi7sg1JtV1m6AaCaWUnIiiUuQPwqK58O6 rYxi5u7N7aJRktMwX9M5qpNqV9ZkxQXMlvG4xtjO0t+NUJ0Jt/PuHkMjnCBySW9TzVpWj6kyeuxW 37pnkXjLZBFa9q0t6jN5El1JAu8lpyMD2ArHQcVctL2Sy8wxj5nXGc9OQc/pROOlkRGWupqBWVpT LFZwJEFZpPLMrHPQcn3qteXl/azmJbnCYBBiQICCMjoKik1i4kunuNkQLqFdNuVOO+Kgmvbi4D+Z JkOwYjA6gYFRGDvqVKatoWrnWJZeY41ikZQJJQcs2Bjr2rJuLYSuZizbjgf/AFzUpcRqDjJPTNRv M88EgLMQvBxwBmm+WOiQ4KUtbmdKhWRkDBsHqpyDTWVlUblYBuRkYzU8SRxXSC6Enk5+Yx9ce1T6 pqD6lOgziCFRHAn91B0/Gpvqa201KsRYDCzMo9M1etdPF7DdPLqESGGPftlY5f2X3rM2kHBrai0a 3l0Q3huG8/y2kEeBjAbH1/GhvlBK5jNsyNo4rYtNOsrvTmjhnL6kV81I84XAPK89WxzWSibn2jJq Q20qEYHXp61Ti2tBKSW4xUZpQoJBzzjtXQRambO3SONR8pJOT94kYyfpWVGghHqx60HJOSea6qdD mWplJ3ehJcTvcyeY4AP+yMCoqXBpcZFd8YqKshDaKdtNKEPYUwGClzT1hc9AalSymc4VGYn0GaLM VyvQK14PDepzjcllMR6lCB+ZqceHpkyszwxkcndIMilZBcwipFLsJHSugTS7CIZmv4jzjCgk07bo sWcyySEDjAwDRdC5jnhEx6CpFtZXxhSc1t/2hp0XMcGSPXmmP4gCDEVui+/FLm7ILmemlXT9Im/K rtv4bvZlJKKqjqWYCon8Q3nO3YufbNVpNZ1CU5a6f8MCpbm9rFKxrHw20S5mkUH2phtdHtB/pMzy Sf3Y2AA/GsKW6nmyZJZGJ9WJqMBm7UrS6sLm8dT0mEfudOVyO8jFv8KYfEboMQ2ltH7rEM/rWOIS epqRYMUrR6hdl5/EepOu0XDKvony/wAqqSaheTH555G+rGl8kDtTvKFTeC2QWKZMjckkn1NGxqui HJp622T0NP2iQ+UoiMnvT1hz2rRW0b+7U8WnzPgIhOfQZrN1RqJliCniEVvx+Hb2Qj9yw+vFXovC NwxG9kX9ah1vMfKcp5IxThDjjbmu6h8HxKAZJGOPQAVoweHLGHH7kOR3c5rN1kNROI0vS5byQBIt w9WHyj613WnaXFYx5jX94333xjP+ArRhtYoyAkagdgBgVORgnAxXPOfMylEjji43Hk05ko3nbjFG dx5NZNmiEwuDk804HOOaMdBjgUxg2RQBI2M4HNNK/LwaaC2eMU4sAOlKwCoo24I59qYwwT7Uu4jH PNKwyuM80AM4bvQQSMDrRtx160KQBnGaADYQM0gqRXGCOp96iKnJPTNOwAeTjGKCD19KMY+tLgqC SOKAGKSQe1AH0p2AD060gxuIPFIQmAD6gU4HPAGKQqR06UpAB6D2pgGcUmc0442gk4NNOexpAG3g 4pOevpSj0o6euaAGHt70YXHSlKk80gwBggmgY3ccgHpTgefSlIwQcUp56UAMbBb3pF9aCWHUUv3R QAgBbrS7cDrSZ5pQ/WkA0529KTg9aV+ec8U0dP8AGgBSMCm4B5pST36UEDt0oAYV75FA4Oc5pSPw oYAGgBMnPFKxNJ0NKDnr+VADMAdetKMUpxn1oPvQAvQU3B3gjpQeaFOQPrSAohecc9Kfg56cUH5T yOwoBPrWRsLggU4cDnpSZ4pG5+lAD1IHWkPqKXHy0nT1+lFgArnnrTsZHvSr06UDg0wEUjp3pV5N LjPPFKM4/pQA/YOMc0Y4NIC3TpS4zyaABRg8VJu5GRUYB7UpDH6UCHN0pF65FAXK9cU4EjjHFACk +lLjIximjg9KkGDxj8qAGj5T05pwwBSBCc8mgcDpz70wHHAHHU0gGRSqmTk8GnoCFNADV65PSlwN 3HFLkkYPAzRsI6UwA5HXmgDjOacFI6ikQ4PTigY7+HgYJp6nFAUEd+KME9c0gDcA2cUopBjpQPvZ oEOPfIz70bTjAz+dBJOKO/JOaAMPxLo41PTHUKPOj+dG9/SuBgktfLYX+TKnB3Z3Y7Bewr1wcj5j Xl3ibTvsOrSRMuIpMyQv7HqPwNawfRmNRdUY5uQLgukeyMkfuweCB2NXvtsd5dNHEHiNwwDySNna P7o9qzHieJQWwQehFR4zXRypnKpNG/qP2W1QBVcSPjCkY2gDByPc1WhnjOOcfjWScnuTQCQKcY2V mKTu7o3RcxL3/GmTalGI9qjJrG3MR1o6jmtlLSxjydzWg8SahaR+VCts6c486BZCPpmsq6uJru4M 07bnPYDAH0FMII6UKpOc1moxTukauUmrMUdOlFOC0bD6U7CGrkciipFhcnAFSrYzSHCox+gpqDey Jckisy71AHUU1I2RXAGA33h61s2/h7UrjHl2czfRDWtb+ANenwfsMiAjrJhR+tN4Wcnew1iYwVrn IbARtcZH8qjaBIV3IASTj5uwr0GP4e3EXzXmoWFsD2ecE/kKlPhXw5aj/S9ZS5GOY7cHJ/E1osM7 WbSM/rcb3ueaeQbqVtgbIAHAGKvw216IPIaSXyP7gcKMemfSu8jfwLYxeWNPl3A53Lckk/XikbxL 4XtSfsuhJIexmdn/AMKFh6a+J3E8XJ/DE4caYok3xxhOwUEufzNE8JgYIykOf4e4rspfHspgf7BZ 2Nlt/wCWgt1JH0HOTXNNq8CzST/Z/tNzI255rhskn1wOK1VKHQuDqS1mrGZHaTSn5Y2bPoKuw+Ht SnYCOynYn0Q1OfE+oKCIXWEHtGgFVZtZ1O4GJb24YHsZDW9l2Nbs2YPA2qMqtOLa2Q8Bri5SP+Zr Tj8F6LBGG1DxhosJzgpE7TMP++RXDEOxyeT70oRu3FJtvZjVztZ7DwNZxYXW7+9mB5EFmEUj6uf6 VnSan4bgdjbaPczjopubkD9FFc75THqacsB9am9t2DTNx/E0K4+zaPYw477C5P13GoJfFOpOfklW IekSKg/QVnC2zyaeLYUudD5RLjVLy5z5tzO+f70hNVTJI3rV37MBTxZ57Ue0SDlM794fWgo9aosj n7tSLYk/w1LrD5TG8lqcLc+hrdTS5nPyxO2PRTVyPw/esMi3cD3GKh1xqJzItSe1OWzPpXXReFL1 yMooz6tV1PB8oHzyqv0BNZuuVyHDC19qetsSeATXoEfg+EffldsddqgVdt/DNjE3zRlv95qh4gfK ebiykJyFIqdNMuJMbY2OfQZr1BNHtIWysEanH90VYWFEGFTAqHiB8p5pF4cvpSP3DjPqMVfg8H3T YL7VHua79VGcYpzKpIxkVDryGonHxeD0TmWU49FWr9v4Xshy24/U10LZLdaCozgCodRsfKZcWiWS HAgTPqRVxbWFFAVAMdgKshATz+FKRt5xU8zCyIhGgOQlJsQfSpeoOBTRjpjNIBCvXApdo2+hoJOe OlDc89DQAmDjBpM8YpNwB5zSDOckgfWgZR1IXjtbLabQBIGds847jFXcY5x1pwx1bI96Ap7nFTbW 5TYfeGc4poJJ5p2DgqCKaflwD1piHqo5yeBSbcmkLHgClDkMFx1oAYQRkgZxSZ4JxUjL83J49qTn sKAGAknpzQVINOK7ee9BBKljQIjz83p6YqXgLjPNMwAATS7h260DAAnkDmmkcHPWnqpXnpSNkZOe tAhqgsuc00qO1HOMigZ6mgBR8o56Glwp6UgOR1pQMKaAAqccnApoGD1yBSdDzmngDqDigBufm4GB QzdQRTgoI9qRlGc54oAaueuaAeen40hHzUvQYNACHPtSKecMcUpxnGaafl4znNIAdgW4H40DPvmj 8KUHJPagY3gHgU3G49KeFOaQnmkAnQYIpPelPzEUmc0wDGRzwKMgLjvS4B6dKTA9aAGkcjNISRT+ MZppznNADMZIOeaUdeBzTitIBjBpAA+9z1pO9KePpTR+dAC9BjNIOGHHGaTH1FLzuH1oAqEnIJ6Y FIML2qRuv4UDA61ibDApApw7UuOMUY28UxCgduRT8KD0JxTRyeBTiOPWgYZyQRwKUr8uaF6UNkCg BVXA5FO7e9IvPagA4OO3WgQvXjGKcRn6U3O4cCngcc5FADeR0p4I79abtA70vGOOtMByqSM0EZHp QuQMU7J6GgBoxnAzTgvfrRtwc9KcSMUACgHHtQV5BzSrgg8daQISvAAAoAcDzgU8A5GaYEHfmnby OnagBxYenFNGT070gYk9KkUY9h60wE5Uj0pxXcODxTRncQMUpDA5zQMcAR6UDJPP86VVyM0jKCet Ahyr3zShTgk8UAAc55FPBJXnFACYOB0pByT7UjjB+8CD6UDgY60hikhh9Kytc0ZNbsHgYhZE+aKT H3W/wrT6dqXpyOlUnYlq+h43cxXOn3L21xGUkU4Kt0NRFoH++hVvVTXq2taHa63bnzV2zAfJIO1e d6p4a1DSyS8ReLPyyLyDW8XfZnPKP8yM8W9s44udvruU0fYhglbmE+2Tmq7KR1Qj6Uwjnqau81uj Nwi9mWhZyZ4ZG+jVKml3Uh+VEwfWRR/Ws/HoT+dLyOm7NXGUuxLppLc3ofDF5Jy0lqg9TMD/ACq5 H4WiRQbjU7VM9QNx/pXLCW5UZWV1/Gnwyyu+J5nYHoc963jO28TmlCT2Z166V4et/wDX6lJJj/nn Hj+Zpwu/Clt923nnb/bkAz+QrmhaxjsT+NPWBB/DV+1fQj2Le7Ol/wCEp0a3XFpoVuW7l8t/M0N4 +vVXFpYWkI9UiUf0rnhEo6KKf5ZzwKTrS7gsPHqacvjfxJMnlrdvGnTCnFZ02q6vdEtLeykn1c0q QO33VYn2GatQ6TeTEbLaU/8AATUOp3LWHj0RmFbiXJknc/jTTbZ+8zH8a6KPw3qLj/Uhf95gKuxe EbvIMkkaj8TUuou5qqL6I5IWkY/hqSFFQl/JRwOzDIrtY/CCcb7hifRVAq7D4TsV+8JW+rY/lUOr E1jRaPL7iLzJ3coq5OcKMAfhUYt/au+1TwjNJd+ZYxq0JUZXdyD+NVU8JXp6wx593raNdW3K5Gca Lf2pwh5ruovCdwWIYW6Y78mrUfhM4+aaEf7sQ5/Oh4iI+RnnghJ42nNSraysMiNvyr0qPwvECB9p kIxztAH9KtL4bsQfmVnP+2xNQ8Sh8jPMEsZj1XH1NWYtLmkOFVmJ7KpNeoQaVZwZC20YI77atCBQ MgAD+dQ8T2K9meZxeG72XpbyfiMVdi8JXZ+8EX/ebNeiRxgKcAZ7Uhi3NjGKzdeTGoI4qLwgxALy j8Fq/D4UtVHzl2P1xXTCLZgDrTSpJ3d6h1JMfKjHTQNPi/5d1JH97Jq3HY20YASBRj0WrxHA6/Sj byanmYWK6whSQBgU/wApceuO1SNhcf3qUN3x+NF2MjUbD0xmlwdpbjApzYZvpSbtucrmkA0Kdu0d 6XZhSuBnrQZAPrSA/N7D1oAcFz1oAQHGOfSmmQBuO9Nyc5JwTQhDx6gU1u2ORSgnoGGKYwxz0zTG BK7ct+FKCCNwwDTPLJyOSPX0pzgKnfNAAGYnmgtnvTScoMU0A9c4HegQbtr4Jxnpz1qR/u8/kKiK AsCQCByKcTn2oAMkjgEU1i3Tv60u1j6GjcVPSgBApxhvXrSvjhaccE5ppXceDQA7ACDIJpAxBIBA HoaVi+3aKaE6/wAqQA3PI600Zzyv50/ABwCfxNA3Z7YzQMbt5BPFAwD8vJ9qUkBjkcegpVJz0xQI aeBycZppc5wAakbJ4xjPrTSNr89aAEZsDFGWC5wCfejHPP505xjGDyKYCYGctgexpDwTgDBpOWPq fek/h+brQAFjuwvNGCO2TRvA4zSZ5x0oAQUhJJ4FSAY4wKY7bTjax+lAAFHc0oYYIzxSKNwPak+7 1xjHekA4Ju/i/OkPDYzTUlV0yrAr7HNJjLcULUB3JOP5Ubu3pSqMcgUvy45pgMAIbJajIBx1pQD6 ihQx7gGkA1j83TFOIDDGKUn5un40fdOc8UAR8rx1pBwSevtS8bsjoaAaQCE89MUYyeTTuGP060hA JxQA0DrgUmMcmnhgMjtTSMnOfwoAOO360jEEYGKCvIpNg5oGJyOD0oPA6ZHtSbsEjFCkZ/xoAM+m aYrMSQUIFSMc0DC8k0AMwOlA4yegoJ+bIFBBNAASSMikBO4U7gdaaGy45pAVSecYNOGTwTQBvYem KcVUDJOMdKyNhFBzkClOcc0D60YyOD+dADlyMHpStyeBmm468U4cDimAD5OetKctz0/CgDqacppC ADDZNOKjrTVILZp5O7pwKYCDJHOPwpATnAPFLtwQSc1IMAUANwDjFOA4pvVutLg45PFACgGlbI6d e9KD7Yo6jjrQAijPJzS4y2B09KASBz+VOUgHJ4pgGMZpy5C5NJ8rck80u0Y560gHHG30zTQvp+dI MlfWnjkY6f0pgIB83PAp5455NOxjHQg96M84wMCgARvalyM85prZIOOKco+SgAUDOcHNH3W55+lK RTlU88UANUFzzwKk24X0pBnHB5zSjkYNABg8dDQwOP60u3nA60HOMHvQAhXaOAT70o/1eMUq8Hae tNPJI6e9AhCCBzTdqtjIBXuDzTiGK5A696FHy45HqaYjOvPDWkXgLtbBXPeI7fxrFm8C2zf6u5lQ f7SA11gYIcZ/KjOfUg9K0VSS6kuEX0OKPgHGdl6hP+1F/wDXqJ/AlyB8s8Df8BYV3mCDgdfel2nn mq9tPuR7KD6HAL4DuVb940LqOoWQgn9Kry/D66LnZcxp9ST/AEr0c/Iy4HWmn5iWzk0/byF7KK2O Kj8FXOBvuIyP9gE1bg8GwAjzJ5G57ACuuWMmPORUiqhTB5Pej2sh+zijnYvCtgoyY2bB/iarsei2 ETjZaxZ91zWv8owO2KCFD7gBUucu5XKikLONBhI1Uey1KIVAGBz3qzyMZGQaAAM8++KlsCEwnAAA zTvKffg9B3qQOcZHbtS+dntwOaBjDCM4yCaHXAwPzpAwBJBpC6NyM0CG7McLxjtRsY9Sc04nuOtI zY+tAwMfP3gPwpRDwBxx3pfNJAGBn1ppc7iKAH+XsUkEUhUHOPxFDuAF9fpSBvm7+uKAHKo7D8qF XJ9MdjTGOTwT+FG5lAB6GgQ8HJPal3ZGB1qPlm64zTAdrYxx60DJ/MBBOOR6UxpPl4OaYWyRjgU1 sofl5zQINxxz+FKjE5wTmk/hGRxSs2U4GKAE9TnLGjkDmhBlevPv1pM4P3sfWmAZ4xnmlCknBzTG XcetA3KvB4FACuMHg/hSKpJII4HGKX7316Up+UgigCNs5PGAKcBu5Jyae7Er6fWmbTjJOKAB1AGR 1pOSoHenZJ47etKFCnHemBGshUEEUM/HTANSEhc9MmkC5A4HHegREAwB4oHOMnn3p23Jweo6UnU4 xjFADnAVDgVE3I471K7HgDvUYU5+YUAKhOMHp6UxVy3GakC4OCDj1pQeRjgUANZSBwDzTkXt0xTi f73ApmD2ORQA50JGRxTST7YHFKcLwSTnrSMmSPagLiqM9h+NNbIbg0H5eho2kjOaAQ0ucjcelKDn nNGz3yfSgEqcEA4oAOTyOPeo2J3cinHIPoKadzHnpQA4gEDkD2oU8/MRSqAB82DTCv4j1NAhS2WI z+QpDk8YzT8AL0AoTAPHNAyNh7Ypy43c8nFSHAzxTAWJyBgetAhmSvvSsdy88Ghido4pu4d6AALw MmnMqSIUYDBBBFGMjr+FNOQ2RQMr2lnDZRGKIHBJPJqyB8ucDigfNg4HWnHC845pJWAZgno3FKVy CM80ofK+1BweTTERjIHTNOA4PBzQc8YpCxzQMVcflSOw/ClzxnvUZznpSAGAxwKQ9OOKXDDntRgU ABxg4600g8DNOGB25o2YOcUAJtx3zQEOc/ypxGTTTuB4oAQjrnrRyVxmlOSMnrTBuBPFIBcA0w5z 8vT1pWOWzTcEnjOKYAT260YzjJ/CjoelB5OaQARzxSfXin470xue9MA28Z6ik24IPfNLyO9KvzMM +tICtjbjBwcUct16elKwy1AU9MVkbCEcjpUgUfhTcClBIGDQAch8U4cGmnOfel9yMUAO6mjBxgUL 83SnUACgD71P+U4/pSAZ56U4DJOABQA2lyCMGl9jz704KPSmIb7UoHFKExyTxTsAnpx60DEKjGc0 DJHFOBBbA6UoUGgBoB+ppw4GDxSjG7jrQwJPWgBuwdc8dqkUA8g8CkxgeuaUADp/OgBxAGM9KQYG eTSqN3HUelIQqnHFAAeMYHH1pc4OSOKbz26VIgJUjGT70AKyggEdfSnbiAOAaT7uOhoOM9QD7UAH zY6CnZ2gE0qdCDj60hAYYycUAO6jIPWk7ZNKqcZzgUY64PNADl3EZHFIeTkHmhQx4/nTWU5wTx3w KAHA469RQwLHsPpSgYApwAxgce9AEJVgeTkGpABxgZIp20etM745piF7nKjn1p4CqMg5PpTACM56 UigHJGfbFAD8ZOMYz3pWHcUmGxjJ/GmMW3e1MQ4DI3MR+FAjHXdTSTnoOB0p4bjj8jQAoYgbRzQr jnK4p3PbHIqPhWwy0xWJGZcDnn0pFyQSTyKNqMAM4IpyMMFdvzY/CgLDt56A54phPA9abyG5NKAC dw+mMUAJuOM55o3EkgHHrSEKDjb+FPCkrn/IoAazYUDtQp/Gk2spwBz608D5Mc0AN/HmlyCfU0AY 6jpQVDD/AAoENZR1BxS7ehyD9aNpHfPFLwoz6UAO5Ixjn1pgJBwacOeQetNO7OMUALvH3gPzoBGC R1pABjBIz7Uq52HB6dc0wE5Ue/vSHB571De3cdhYzXcx+SJdx9z2FZeha2uqIkb/APH1tLuiqcKM 8c1PMr2Glpc3FGORSY5OOSKcF2jHc9sUFfmPQ1QrEeecA8+hpQvUDOR1p5weMDNIARk44oAbkY+Y fSgZcfd/OnDIJ3cigfLyBxQAzaM9sHtT8AvtAxgUMcnjqaVGUAlhzQBj6HdzXME0dw5aeGZoycY+ lawUAZPJ7YrnYZ47LxVeRbwFuSpUAfx45FdEAQRk8Hk1EHdDkrMay7iewBpv8QyT74p5PoeKUAHO cgVoSMOcfdOKXhl4HHrSbzuIBp6lcc5yKAI9oxyee1NJZeDn2FSHJxnAA6UmQegoAaxLZNAChcE4 +lKVBGP5UzlDgmgAYkkkDH1pFyo3GpW6DJqF23nauDjvTEPJ3AckUmSvAOPfvRgkbf1zTcAEqDkj uTQA75SOpzSBjsOT09KNpHGMD1oGM88f1oENyDgnNSggjr+FNJBHy4AFMVip6/hQMefSk3beB196 cMMlRuMOAPxoEBJDfzpGHHBzTlye4IPFBIXjimgGggKQBS4yBg0hkDDkYpVPGaAEORxmgkn3HrTm wRgGk25XBPTsKAGdxzn6Uu4kDKn2xTAp38HNSFiDgUAJu29KaWxTicHJx9KTKuR296AE3ZpF2/8A 6hSso7EZFKpKjBxQA3bx97nsMUpHAJOSPWnPlhk44qPcCfvCgB6kbeMU0nLcnNL15HNJjJpAGO3S kOT1NOIA7/hRgHnOBQA1VPPNNZcd6lGBwDxTXAByMmgBoBpT16D60pBH/wCumDK89aAF3YHNJkDN OABHPWmEYNAxoBzmlOW6Hml3YHApB17jNIBBnrj8aTcTwacRjH9KTGRnH60wEPX0pecc0FQDnOaQ k7c+lIBMA9aaBg5pw9SfypCMcjNADWJLdxRjAz3pxYnim+oxQA4nAz3qMgnnGKcGIGOopd3HTIoA apAB4zSqQSMCmkk8cgU4YyoXrSAruM/MD2FIM45pxI6d8CkB56cnvWSNhR05NAGelGzg04DjpimA nIHNOyMUnU46D3pykNkHFIAAz0NP24+vtTAvpxThxigB3G4dqdj5uaYOee1OGQcdqYhSMDigAk5p cYII5pWBIyO9AwPQDNOB7UmBijP4UAJgdjT1GBk9PWkxjoadyUxjigABGeBzTicDJFIqkihtwGTi iwCr83X9aAoB44oUgrnFSBd3XGBQAg+WgIDyRz6050DL8tIoO0DtQA08cDP0qRQQOF5pAAGyeacH Cjkce1MBu3nBHNOVVzgjBoOxjzkZp2AOx9qQDVXJJxipSOOB+NRHlwoznripFJ24NAAnyZzj8Kfw wBzQemMAUmABw2DQIQAZODwKeFJUgmm8Hgn8KUsVHFADS4Bx1x2pS5IA4/GnLGMbu5oCEt7CgBGb avzHgUY3DK81Iy4Xn9aRcDkDH9aAGE8c0ImF3E4HannuScH0NJuAG0jHpTAjVt5PWndOAD75NO2l AOmD0ppU5z2oEO28Zx+VNwjYB7HrT8gDpn8aQoQcgYBpgKoOfl6Ujg9s8U5DjnvTiwPPGR19qAI1 IIHTPvTtpB5Pb1obaeQPypdp3EE/hQA3qen0BpTxxnJ7CkHPJ/Cnhs8Ede9ADWG1eQMjvRGflzml 68Zp2VORihAIwBYenqKQAEnGOPQUBSeB0pzKFHJPNADCA3ofpRjHGetShVC4puVDcCgQ3Z/e44pH xtAIqQjaT0IoDAgcZoQEI4HTil5JxnFSPngCkUfLhiM0wEVdrZ6GlwMn0o5k4J6U2WSO2tZJpm2x xqWY+wpeYHK+LJzeXFvosDIvBnnZjgAAZA/rU/g7TvIsZL5xiS4Py57IOn51kWMGn6wb241JbsX1 24FksQwuSfmJPoq13VtClvAkaDaijCqOwrCn70nI1louUV9/XvQibsgnFD56nmkBYAnk10GTFMYA 3Ek/SlUZ/wDr0jMCMZODQCoXkjBoEIV+YHPT0pGG05H4UFRnOaUbWGD1pgMKk9ePTmnAZXGPxpCC OtO7gZoA5DxJA1rrVvdqQB8r5Jxkg4x+RrqUy8WVBxjrWX4pCLZ28piVwkmPm56gjNS6FdG80mGV 8liMHjuOKwp6VJRLnqkzRB2040mN3AFH8O3rXQjMChYjb09aVgT15pAdq4BpN/cmgBhXJytNyRwB j3qQtnAAApSMLx+lMQzIA+brSOM0uQGCkH64ppJ3d89hQABwB0NNwAc7etO68np3p7gdSc/SgBoO G55okwyjKHGelICVPQEU7c2Cc80ANcgcn8qZjcMmn5DNg5ppB7UxDSGUjgAU8dOxoA/vcfWgAFuB zQA7gDPU1CysQcP1qTvTWUE564oAbtyo25H0pApJOeop3BPIxS5CsP50ANZDjcDx6Uqqw7celOL/ ADc9KN5K5xQIZsDNyMUr4AwBmk4wSaTNAxc7DntSFcHd1pwBK9Me9JkrjZ+dAhN3XC596VTmmA4y KcOm4Ec0ANcYOcmkDEqCKdwAc8mhQW5PT2pgBJI96RU444zRx9CKXBI3ZpAG7HBFM4yeOtOJXjH6 0KNxye1AxRg/LnmlIX8O5qJlIanZOMc0AOC7ehyDQG544Ipmc8ZGKXZgZzzSAUnJ5/SmgcnPSnjH Y4NNVsMfWgYAe1Gz0/nRknmkLc4AoAVh8vSoypAxnFKCSc56UMRnoc0CE2jp2pOBSgcdDQBz05oG IG9aDzyOlKxweuTTSST0pAIFzmkwemcil6A56038aYAygHIpmeemKdz3GfSkPDelIAGOhOaCMf4U uQTwMGk3YOCM0AI3+TTlGSO3NM7dOKE5YdaAISDuyPQU4nA9aXPYDNKMYwR+NZGwnzelOJO0cdKQ HJxn86UEng0rAGARkkflSqgwD3pPb0pV7CgB+ce9NAy1AU9OlKMgde9MQ457incYzigHJ9aB1xmg BcjHFKuRxjijbg8A0oGc0DAg7uentTsfSk74zQCfwFACqOfalx82MHFGSeT+VPAJ6UAG4gYxSYBP vTTkcGnquD0oAcq4GeaOp5pScDA6+tIFzyTzQAu7kelO6nikwCDgUKOOGGfSmA4rnrxSAZyMdKcp z97Oe1OK4O7PFABjAzilxlc55phbj2pxIKgDpSAaM7sZIp5IAFJlV4A5pAGY56UwHj0OTQCD3/Ol AYH1oZc8+nWkIbs2/wAVO2jGQfwpM8dadhiPl4NAC5O30oBIPqaaWYHDYP1oyN2RgZ7UAOO5vQfj SDcT06UpAHpz3FIh7ZzTAcCRzgZ96ThzzwaUnNC8HGfrQAx4ypADGnHPAIOO1KTk/N07EUEMc5xi gQ3IHfnNL944LUgA6YxinDGP5UwFHOMdKUrtZcjr2FNDk4CjinBScZUgDigBrEoSwHBpB8xB5I7m pdu0E9aRUZU3EYH0oARh8vtUY28nnj0p/mA5xxikVexzQAgB7HAPY08YUYJ4pQOSMYxQcnhhQAmf TtQW3CkXHWlUDdj9aBCLleKc24nOMe9IQAd2alx0GT6mmBE24Z4z70qbdoGevelOdxC4x3pSdoCh eRQA3IzgdqTjnIxTuvI/GmDOAc5oAdjoR1rA8XT50G7iMm1wisfmxkFsY9+/FbpwDk9O9cf4pvlu ZkITdDCOFcffPp9KxrS5Y2LgrsseF1l1GZdRnhESRx+VCoGF/wBoius3Dbj0rI0C8lvLINJbpAuc RoucYH1rW2gcg/hVwioxViZSbeo1sZwDmheDjJAowc5zikLENx+daEjgAfek8vaRgUobGCDinZYE ck/SgCPbjnrmkOA3HJqRizfKAMU0DB5BJoADjZ96kUgdASe5xQRx2603BwDQBV1eJJ9LmVywAGcj qMVlaI6QSzWiFxjDgM27hhnqP5V0HDqVdQwPGPWsHSNJurC/mkaJViYbQS2c8nBx24rCUJe1jJGi kvZuLN0LlcZ+tJgjoO9OViTwOnWl35Ukde1dBkNIyD/LFR/xetKN2D8pye9JjnPYUwEOA3TdTi3T AA9aA2egxTOrHIIFAhQRnB+8felxuBB49zQ2NnAH1PWowpIyDn60wF2heCOO1G3auMZFOIG3gc00 5b1wKAFBDDH60HGMD86ZkhtoHFOU9QCBQITcBkDIpVYDPXAobheR+VNBJGO3pQAMSTkKaUKQMZP5 UZAGcZpSzMOuBigQAY4PX1pnT2pdwAGcmnNjuBjrQAwkEj5uPT0pGJBABOPelBUc4AzTRuBPemAh JJ5pw96QxsOe1IqgHJGfagBwAIOAAfWkBwQOvrQxzyfyFNAGeP5UAPfpjPNN3YPIyRQWA6jn2pvO fQUAPBUHcBj1BpGIP3eM9sUhYnGaM8420AIAMk4NGAF7gUq/KuWPH8qaWBP3jj6UAO3jHyDB96QE 4yaXAPpQwAHFAAwDLnoaECjocGkyMZbk04YcbSBSASRgcDv7UhAGMU0gKcdRT1K7STQAm0Adqbk5 p5A7dKbgYyBQMGOcYHNNYHIOKlABGMg8dqYSScGkAADtQeRnpRg4ODikOcYxQMUA44ppJLc4p2Fw eo9qYME4oELjGeaD157UhGDihevXigAAyOaRgQPrQ7kdMUZz1NIY3g9c0mOc4p3y0nbFMBgOeCOK Urx60nOaOCaADb+FMz+dSDpyaZjnPU0gDI28j8aRSAwxS4z1NIFGRzQBFnn8B/KnZ7mg53YFBHH/ ANesjYd9KTBAGaTOBwacCetIBMHPGKePUGkwQc9qAMtTELkjrzTwARmm4OeeKeML1HNAw6EEUFul GQAR1zRjoQOlAheSDyaMsD705TyRQRyMDn6UDBcnvilHB5zS88CngAKfWgA4pobBJzQOG5Ax70pI 4549qAD5iQTipB7U1VJGQM+1AyD0oAQZPNPZgBxxnvShfl6c+tLgdufc0xDRnPJOacR83J7d6O3X mgDJ5596Bi54z/KnE7uuQKacHoeaUc5G40AOAO7FGSP8aDkDOaXIz0GKQACrL6U4OVGB19aXauOn BpqrlTgZpgOzgElsk+lJx17UEEAcUoDHJHQUCHArjPT6ik5zkHrR8o+93pHGBu/SkApVmGTz+FNC YPHUdjT1JIGOM0rDHJAxTAACRyeB2peq520ZBUYHWhhg0AAIzwOabnDcilU5bAGBTwMct+GBQIjO fwpSWOOcCkfjoc5oAHHXNMBwwozgkn3ppIycrj2pxIPTOfWlVAELE5oAQEdQMU/dlepBPFKMKOBy aQDnPQUAJkKCe3vW7cIs+nFAOq1jKgMqKMYLDNb6rlMVD3HbQ5OAsshikBDA4NWlB78ntTdXjMV2 jKcbuKEPAJrV6q5mnrYkJJyCAKjPBweop+7PTv3pe/bNIq5GqlVyQMdacAu7I6H1oBO7gcUKNvPe gA6H6+1PzkZx2xTCS3PpSKGzzxzQIUALHu7Gmhi/U8460FWzjtmnFMEd6AA/LwKaxx1J/DtRuw2c U/bnjafxpgRTQvcWkkULqGZSAx7VzKWOu2XlxT29rcRJliwUfOT1GcZwO3pXV5CZ25B6UeY2CCfz rOdNSdyozsipZsGgXMJhJHKkdKt+XggdvU0isOTnqKfu5wSOnStCRnGelIuN3Ip4jLMSeM+1N29s jFACFcsSpPPajftXGSCaGUheMYprDAz0NAhW3Eg9qBux1z9KN3TOfrSDp94ZNMAYqehyaMjZhhhv rxSYIIGc0MpLcc47UAKAc5OB9DSfMDk9D70pG1Bu5K8ik4bBHp3pgBw3bH0phPPcU/rwKCDjkAkj igBm8MeCcDikXB9RTxtT60j85OKEIDkHOdxxmmDLElh1p+0bckjmkX733R/SmIaQACAD9TTQdvHX PFPZNzkse1NVeemRmgAdeN36U3eB3/CnsS3FNxjqPxoAaTu55FGMY789BSkADP8AOl9yAR7UAIGI NGcc4zQyEjBJ/Km8g47/AEpiHsDgHimfMelOJOCCee4po4PfH0oAOQfu05VbJI4pPMABAxSggEYz k+lAhNoXkt+lNkXJDc4pXcn65pAzYOBk+9MB2cJ14pgweQCaXPTNBBznPX3pAIcnkAUncZ6e1KOM r0xQ+TjqaYDMrnjOfendSOg9/Wm8qemTSluDigBWH1ppBxncPpSE8gYzn3oIw3XNAMM8cj86Q44J p6YJyaYRgkA0rAOUDnPINN4zjPFBYEY6+1KDleEx+FMLjcY6k59KXdwARg0jA5IFIgIJypH170gH ZBPFA9AKT7pyFIJ9aXPPTBoAXGOKTO3ggUpJxnvSbgTz1pDF4I460hPOKaWC8bSDSiQf/XoGOHfN NL4PtTgRiggEcUAM+9nHApegzxSgYzgUoG8cCgBhViRRkj3FSBcd6jYDoCaAGsM9CB60mO2aGJNI CuPpSAULk80h64pBJ8+AeaeQD70AR5xTTg+1OIyxpCBjigBOCfSkO0cZo4PNLkHrQMQ4A45oGAwP rRgdRQBkj60AMPBz7ChsHpQ/BAwc4FIAetYmw4KCKXgU3PT1p65zQITBPuKQU9uBj1PWgKVAJPNA xQc8fzpV6ndSgEkECg8E0CF6AGjjPpQBzgc0EEGgY77oBFPDHbTVYEE+lKBuHJoAUvxwKUg7KQrg fKMkUu7IwetMAUAkZp+1QPamjk8ml60AAHJGad904BNKPfg0blU4HNIBc/Lgd+5o6Djk00nI4pwJ HfimAmccYIz604DuRzTuTzj8aFIOQSaADkjsKF46nk07aMcYx3poweM4xQArLzjOBSHII5+goz82 MnFSnpxzQAmTgdqVTt7Uxiw6g/WlDcYPNAiTfkYHHqTSIvJAzzTAN/A6U4AgY5oAaT8w70/OFOBm jYCOnNIOfwoAVTkCnkA55zUajDctkdeKXeq5IzTsIcG49KUDd7U0qGYHOPw60pADcE8UAPXKHk8U jP8AjSH5iMnA70KMHOM0AKBtbjkH1po++SBTgT/ntQNpyO5osA5SrN0x7GkwNue5PSkI46/pQrAN gkUCF+YnIyMU7aQRnpSAktnoKTcSenFMCTgEPkAqQeTXQREMgPtXPqgwePxrcsm326HPaoluUtjH 8QLhEkxnawNVLd9yAEZx0rT12PfZyfSsiybEec8EVrH4TL7RZYjbjbj6VGvBORgU/qwOePSkI9Dm kWBXIBUnr0NBDKeOMU4KNhyOfrTTu4GQBQIcoJBowykf0pMYOc0fNu7GgBTJiT19aQjc+R9aGAbk cGmEFWUYOD1YdqAJAwVvSnluMk4zUWzAyQBSswJG3P1NADv4ckA/0ph2noTk+tOI+UHNGeDkDPpQ IiIwRT0BZs8D3pMAgg9T2pc7CMdaYDy+DtQnIoZsrk5zTBgjOeaCAVGW59M0AID83PSlO3HBzmkD YXafzpqnnrinYBWG0gdaAMZGPxp7YwCTSBdw68+tIBmAG4OaduG3pz9aMHIHBIoUYY7qYDCwxzwf endRhcdOvc0HHXr6UiKDkmgQg4J25+tIM89c04kYKikxjg9aAG8Zxu5NIS/QdPShgM5FBYg8GnYQ FgFwRzS7yVPy9BTDu4GfegPx8o57imAMoLbi1KuQOCKUfc7ZPbNMYHdwePagVx43bTnGKarjBG38 aQK5HIbHeo5HUE5KgD1IFADmwRgdPShSCQe1Vnv7CL/WXdqjerSj/GqcviTR4CwfVbX8Gz/Ki6A1 2cbsZOKG+7kHI9a51/Gfh1FAa/3+yRk1Uk+IOiRqQn2h8dMJii6A6kluuKRWz1NcbN8SdP58qxmP +84qhJ8SWyfK05R6bnJpXQWZ6E+M4HemqCpOSRXmcnxG1Jv9Xa26fgTVaXx/r0mcSRJn+6go5gsz 1bqc8n3pGyp6ED1rx2bxhr03Dag4/wB3iqcuv6rNxJqE7f8AAzRzMLHtX3OdwA9yBTJL60T5nvIF I65kFeHPeXMnL3EjfVjURkJ/iJPvTuwse1y69pKZ36lbAj0fP8qqSeLdDiBzfqx/2EJrx7eaQtnp S1DQ9Xk8eaKigB53x6R4/rVOT4haao+SC4c/gBXmeSaO1GoaHob/ABIgAxHp7H/eeqsnxIuST5Vh Cp9yTXC4NFFmF0dfJ8Q9WY5SO3Q/7lV38ea4/S4RT7IK5jNICKLCudBJ4x12TrfOPpxVRvEmrv8A ev5/++zWVmkzRyjuaJ1vUm63k5PrvNNOs6geTdzH/gZqh70gPNHKguaA1m//AOfub/vs08a9qS4x eTf99msyijlQrnWaHruqXN0Y2neUY6PIRg11Avb5SMq+fRZRzXK+D0+eWQkYyByOa7GWygu2jMit lM4ZTjrxXi4ytyVbLRG9NXQ221K+csHEiYPBcDkVJda7PY2zTSGAgf3/AJc+31qjqWq2mjvFDN5h 3LkMBnil0+/0/X7eeNAXVfldZFwee9Yxr14pVNeU05Y7PcW08eWTnFxbyIP7yHOK6Cy1rT7/AB9m ukJ/uk4P5VxMvhK2tlmuZ7mZ4I0JEcSAEVxxuWhnL27MAD8pJ5r1qFdVk/Zu9jCUHHc9yJJbPanh uOleXad46vrSNI5kWZF67icmu50PXoNatjJEjRlThlY5roT7ozbNkMSeKQkcA0ZGPlGDQSM9aodx jA5+U0hHHQVI2D0OPamEEDgigYwLg5NPZgFAFJu9etNAK4NAB6npTO/HSn55ye9NOCeOKQADjjim kfNx0oIIanbjjBoAYWwMGhchhj1p23j2oXlhjpQMY2PTORSAAd8U84IGfwpAoA5rE2GhSTwePWn5 IzikzjgU9QPegQgB6Z60DPen4zzSdTigAzg4FP27kppAPIPPpTkXPB/KgBO3HalCjjOc0/gDA4NO j44PWgYwIPpT8DGcUpUZ6kUwqS1MBwBIpduOaXoOePen8Ad6AGEZpVG0dOKQDnJ6VIcEAYzQAZJp qgEH1HWnAZGD0FGAOBzQAiqcZ7UoAH07+1I5ZelAJOSeKBXHDjjtTifm6fjREc57j3oIGSORjpQA 8AEHA59abkg4oHyjj9aCwJBNAClOPU05T04+tJvBXk4pqyYJGKAHk4ye3tS9TjHFJjjOPwpd2QDg Aj0pgATH19qUDBxmmj1JNKq56Ek96QhWXH3abkBenWhnA4wc00krjPI9KpIVxU9uM04AKeTknpim Fg2M8D2qVdpXpgdsUMBRndgDIowN3XA9qVQCPY+tKqnJ6UgEIIPHSnDjk+nSlJw2O2e1NBBzzQFw LgLnmmAYJYU5gFOMA4ppYBSQAPwp2AkDfKOx9c0w4yCDnH50yOTgg8Zp4Oe35GnYVyQbZBk5B96Q bhyRkCljG49eKeB19MUhicN8vIBrX0s/6OE/unFY6rld3f61paU2GkXPfNTIaLGpRB7ZxjtXL2YO wDPQY/KuvuhuiI9q5CAFbqRAOFc1pDYzluXcYbgg96XOOAKcSAuAMU1uOT0pFDQGHIPy+4o35PKg +maQzLnHXFAZGUjP4GmApKl8YH49qDtXgdOlRqRnHT3p6sQeoOaLCuKRgDkkU5s7BjH4Uhkz0HSk B5B75osAmDnkDGM0ZPr07UPJgnAGT1pAx6H9KLASAjbz3p4baCBjrkZqBDngZJ9Kdxu+ZgOO5Aos K45mBz2puQnJqrLe2kWRLdwKPeVQf51TbxBo8PMmqWo9vMz/ACougNNiFPTOe1OGAc5PTpWDN428 OxddRRjj+BSazp/iJoSNlHuZAP7seM0XQanXF+Cc8io92fmAx79q4mT4n6dH/qrG4b/eYDNUpPiZ I+4QaUPbLE/youh2Z6MDkHP4Uxn24/vZ615u3j3xBMAbfTUUevlMcVVk8U+LZufliz38sLS50PlZ 6msmzoc59Kc27dwvJ7eteOS694jkU+ZqpRc9BKB/KqM9/qMgzNq8jk9hKTT5hcrPbnkRQGdkQf7T AVWfVLGDPmX9oh9DKK8OY7iN95I+evJo2Wm4bnlZe5A5ouw5T2STxPocW7zNTt8jpgk/yqpN478P xjH21nP+zGa8lzaKTiKRhnjLY4pGkgxhIMe5NF5BZHpz/EjQ48bIrpyO4UCqMvxMsw+YtNmb0LSA f0rzwz9MRoPwppnctn5QfYYp2kLQ7qX4mXBH7rS4wf8AacmqUvxE1iTmK2toz/uk/wBa5AyueC1N LtnJJNOzFdHSSeOfEDE7blI/XbGKpy+LPEEww+qS4PZSBWKWB7U3NPlFcvyazqsufM1O5YH/AKaG qrTSycyXEjfViaiz260A4o5UHMO2oepY0u1PSgEfSjNFguLwBwtITx0FBY0maLCuLzSZPrSZOKac 5p2C4v40Z5pKTmiwXHZHNJnmkHAoxQAuaTNLg+lG0+lACZo6d6XaaApNACZoyaeImPY08WsxAIif B6HaaBEGaKtCwuT/AMsW/EU4adP3Cr9WFAFKlAGKufY1HD3MK+uDmgrYqADcM577UoApd8UYPpV0 SWY+7DPIfQnFAuEGdlmvH9580AUyp9KVY2J4UmrZupcfLHAmOPu5o+13J6ygD/ZUUAVxbTHpG35U 8WFwf+WZp5muGPNw30rrdH0GyvdNguJbmcu4y37wAA/lWNetGjHmkVFczsU9Akaxh8mWzkGWLGYL n6Culh1RPnBinUL0zGfm+lKujW6gAXt1gdP34/wqQaNEeRd3f/f7P9K8SvWoVZczTOmEXFWuc/4i nbUrby1sLrzEb5WwMYrO8OSyaNqTNdI8UUke1iVPB7V2Q0Yj7t7dfiwP9KDpTj72oy490WrjiqKp OlbQHBt3uc5daprGob0t5bWG3bMbDdkkHueM1hDw7fNcGMeWFH8ZbAI9QDzXe/2fAD899O59EwCf yFTxaJFKwdbRmbpvmJz+Va0K7iuWjD8BTSfxM5K38L2iBWuJHuH7xwkKPxNdZ4ftYIp3FrEI4lG0 gc5NaUOi26qPOHmf7PRfyFaCRRxLhFCKOgUYFd9KnUvzVGYyaeiH7Ap600g9KUtu+lJnP1rpJG4w w/rSluKcQMYNNJGNoGRSAYTkj0pcDPt70u1QOT+VJt4zQA3GM88U05xkUvtQQQMGgAwT0PFIvHpT gAw4pCB9SKBiOeOtIoOR9aQkn6U5W+YfWkBF3HfgU7nApM4PI7CnrzwaxNhuPm4PFSAgdqTuPanN yR7UAIzDooxRtOc96MZ5pOR9KBjxjnjFPQgdfWm7hgcUbQcYzTAXgk804ZOSO1JjAFLjBIoAVWIB zyaUcNk96OBxQOSaAHnGMdaZnpnBp+zvk00qAenWgBykYyR+VOBKjjvSAgDNCYzmgB4LdCopCCW4 6e1LnDAnkUhCknBxQICu1smn4PXHHvUanHXmpCBjk++KAHYX0wfak24GSenrSGTB6UnmYPHenYVw LH8KAGIDdce1NlYBcj0zXjF1ruq3Uj+Zfz43H5Q5AHPoKduxPMe0SkRqHdkUdyzAYrKm8S6Lbu0c uow70OCFy2Pyrx5pJZT+8ldif7zE1KtuRC0u0uwBKIO/v9KOV9Q5j1BvHOiJdLbieV2cgbxGQoz6 5ro4gJIwynKkZB9a+exIxOSTnOTXrHgbxEL6wFhOw8+EfK394VTjYFK52AB28807IVSAMk96aSSB k8GhwvB71Nh3ELKi7upqLezcdqazrzu7Uit6cjvirSIb1JVTOCc5z0zUueQB0rOuNV0+xBN1fwxE fwlsn8hWHe+PtLtzttlnuT67dq/maljTOvMgHyjOabv4GB+NeeSfEiUyDZpse0f3pDn9K1NN8fWd zJsvIGt93RlO5R9e9A73Ox3sAOaaGBfrxUSTxyIssbh42GQwOQaA3JOBinYTZZY5HB6VEHLAg1EZ N2QTxSqxAOOBVKIrji4XPc+4oTccL2phcsCMU4OAM5465osFyfJVQBn609c884FQRmQ42qSMZ6UN dRxKTPPFEP8AbcL/ADqXYaZZVwAeatabIFucZxuFctd+LdGtDsW6F3N2ithuOfr0Fc9fePtWgulN voZi28qZiWJ/KobjsWk+x7PJFm3LbuK4t326pPsBIDDP1rgZ/if4tmGESGIf7MX+NYdx4o8S3Mxl kvSjnklSFpxlYhxbPZcszAqG574qKaSNWw8gTHOCwFeJyaprM+fN1Vh9ZhVVnklfE+qD67mb+VPm HZntcmoWUTEvewD/AHpB/SqkviTR4vvahAfpk14xi3LYe4kK+oUmplGm7hhbqQf8BFF2HL3Z6rL4 10OLn7XvI9BVOb4iaMoG1Z5DnsOK868zS1bmyumHoZlH9KV7nT8Yj0th7vck/wAhSvLsFo9zuJfi ZaKMRWEre7NVOX4n3G3EWnxrjuzVyBv4kGI9NtF923Of1NKur3cZHlC2j/3LdP6g0e++ge4up0Z+ IetTDZBbw5Pom40v9v8AjO6QtFFNGh7iLaPzOK57/hINWA+XUZk/654X+QqEXMl5Jm9ubmYejSE5 /Ojlmx81NG3PN4gfm61qG3z1D3Sg/kCazniV8/aPESsf9nzH/pU1rqNnps0ckOmWUjKck3UfmA/g TirX9pWGozE3mnWcCOc+ZaQ7Nv4A4Ip+z7v8Bc8eiMv7NowAMuoXcvslvj/0Jqf/AMU5GeLfUpvX c6Jn9DVW8RIp3WNgyZ+Vh3FVN1Hsk+rD2jXQ1DdaSg/daLn3kuWP8gKa2pwhNsWlWMZ/vYZj+prM 3GjOetP2URe1Zopq93EmyIW6AdxApP5kU06zqR/5fZB/uYX+QqiOetAx2p+zj2E6ku5M95cyf6y5 mb6yGoScnliT9aO1GMVSil0JbbDjFHWgj0pQuadhXEyBQDmnbcZowKYXGk02pccZxmk256CiwXIi OKMcVIVbGCOKVY3fhVLH0AzRYVyE00jPFXF0+6kPyW8rf7qE1OmhajJ0s5h/vLj+dFrAZgX1NLtF a3/CP3wzuWJMf3pVH9aUaIyg77qBcdcNnP0oAyNgpMACtr+zLNADJqEY9QFPFRhNHjYeZdM4HULg ZpAZQBFFafn6Gi5Czu3s3H6Cl/tLTFAEelF/Tezf40XC5mYNAUnpzWqNVG3dFpMCqDjcyjr+NRvq 94rEpBBGfYDj9KAuUltpWzhGOPQU8WFy3/LGT8VxUrarqLnPnKv0BqBrq9c83Ln3Ap6hclXS7lhk x4x6kCnf2VLnDPGv1aoCk79ZJ2+hpfsTyH/Vyn6saLCuT/YIUGXu419qb5Vgg+a7Gc9AKYNPw3+r T8TUyaZIeFQE47An+VFguR79NX+OV/oKGurEAbbaVvcmr0eg38+NtvO30iNXI/B+qSYH2WXH+1hf 5mnyhcxftcYzs08cd2NJ9vlC5S3gQfTmupi8B6i+N6Rrn+/MD/KrUfw9nxl57dB/wJqOULnGG9vR 0eNQeeBTTcXb8Pctn2Fegw+AIgwV7sdf4YgP5mrqeBdOT708749GC/0p8oXPLgkz8tLK2fQ0hs2b qHP++1euJ4R0iIAmFpMdncmr0Wkafbj93ZW6n18sH+dHKhXPHIdOlfiOHP8AuqTn8qvw+GtSl5Sz mbPT5Mfzr1+NUjACIq/QUuXLHCj60aAeXw+CNUkYEwBPd5AKvRfD+6YgSTW65+rV6CA2ORS7gvTq KNAOKT4eIB894P8AgMX+JqePwDZgHfdTE/7KqK68MHo2nvx75oA5hfA+mAHM9wf+BD/CtO28OWMc YjR5Aq9uK0gmed3Sngj7tRKKluhptbGedBs8/K7EfQUjaBbKCRKR6cVo84xjgGjtzWbo0+xfPLuZ f9iRd7hsewqRNFskIJDyH3PBq6fbnNHKnGBSVGmtohzy7jI4oojiNAn0FS/LtOajOc9KOQMgcGtL CJM7RxjPWmEdz3ppJzzSqSOaYICOBjijgdjRk5oJOMY5NIYjOTj0oAABPU0NwORRwFzQAZB60mDu 2g07lhkAcUwgk+gpANz6ignIxSjuKQdeBzQAgXHPb2oH3sDg07cTkcZqN2KDdjNAxsj7TgjIpVIY g9BSbdy5YZzTMbmAQlealgPCep9KeqEDNJgg8jnAp69D2NZG4jdQAMUY3PSEc5NPRsEnFMAK7RjB oCCnc45zikHTkcUAKBkdjR+GKAAemakO0AAnmgBFJxyMipBhuo/GmZG00KSFOO9AChcnOeKB8pye lKp+XFGe1AD93y8DH1pmT1pdvHr9KQkAHbxQDFHPWlX5Rn9KpXOpWVhzdXMcZPYtz+VUT4s0Nclr 38kPNCYjbDAtnBxUgYHPGfSuabxnoqnIuWPsIzSjxto2CWmkx7RmgDos57UgILZJrnf+E70QD5Wn b/tn/wDXrOvPH9khC2ttLKx67sKBTBnabhjBFNIGeBzXNaX4006+fyrjNpNkBQ/Kn8a6EuCAc5B6 n1q0rkNjmKnjFeHOuJ5AP77fzr27zBnIGcV47c2brfXe8MqRzMrMB3ycD6mnazJ3ZBFC8rKqDJPA Hqa6e0tGIEY/eSsApPsOgHtVCwtzGFbH71uMD+Eeldzoul/ZUWeVQXbpntXPK9aXKtkbpKnG73PM /Eegz6NfAOB5Uw3IR0z3FVNJ1GXTb+K4jJBQ8j1Fet+IdIi1vTZLZ/vn5on/ALrdq8jeykt5nimT ZJG21lPrXTayscybvc9ii8S6WLGG6mvY41dchM5b3GKyLz4hWEeRbW8s7diSFX/GvNCCx4+6op8l u7WpkAO1e4FTytlNnU3njvU5mIghggHbgsf1rEudZ1O7J8+8nYHsGwPyFZ8JZkRm6dKc/wArcGqs iQOSck5PrS9TUZbHenRn5uopgS+WTTSClSBxnrSOcjjFMbOp8HeIXsrkWNxJm2lPGf4G9a9CVick cj2NeIoxQlwx4GaRHmnXKyy+YWCqA559qBN3PcPmY8BuPak38FcEEeteKW95cxozC7uVwccSNj+d Sf2/qagrHqF106+cx/rRcVj1fU9b0/Rod97dBWYZWJRl2+g/rXEX/wARL2Rimm26W6dnlG9/y6Cu Rkklnmaad3kkb7zu2SaTGPak02GxoXXiDWbz/j41K5YegfaPyGKz2ZpDl2Zj7nNNC5brViOKL+Ny P90Zo5Uh3ZX5xx0qTzZQB+9cf8CNSS24EZljfzE6E4xg+4qt1osmF2PMmerMfxpuR2FJS44p2Qrs TI9KAfSlxTwo7UWAaPpSgnrS7ecYpQMc9qYCZNKT27mnbRgUmKBDSKMelOxnsaNvQYosFxmKltmw snTpjmmlCaW2B3yDv1oAns2lhmEwRXPTDruHNQOJI7knGATyK7fwre+EooQviGK8YjI/0dAfpWHr CW9/qZOlW0/2ctlA65cj3ApKKevUtt7dDHnJDL7iocZ61py6TevPDEbSZJH4VXjKlvpmtb/hDJoL aOe91TSLUSDISS8DP9Cq5INNLWwrO12csBxR7V0y6Hoca5n8QxHHUQW7t/6FinKng+3AM17fznBw FCRj+tOy7k3OYK845pAh7CuobVvCMOBFp00wz1eUk/pTP+Eq0iPH2Xw5Bx03gnFK6A5wRvn7tTpY 3c3KQSPn+6pNbo8bX6qVttLs4VPJ/dL/APXqq/i7X5flW4SEH+4AP5Cj5AQR+HdVkAK2MxHuuP51 aXwtfbohM0NuJDgGSQcfXHSs+41bVZ3KtqUkq5684P4E1WMd1JndPOx9uBRr2DQ2RoNuCfM1O3XA B6E/hTWsNHhJ8zVAfXYlY40yV8ErIc/3mqRNLZWGViQerYNPURoGfw/A2RLcSMDxtIH8qDq+iIcx 6Y8h9XZjz+lVobFkdWDREgg7cEg+3Hara6Jd3UzvHbT8knbFA2Bn0pajIz4gt0/1GjQL6bkzj8zT ZPEd+zAJBDFj0AH8hWivhDU5QB9hufcttX+dXIvAl+2N1tGn/XSf/CjlFc5065q7FgtwE/3SarPe 38p+e9b/AD9a7qL4fXG7Ek1onuFZquJ4BjBw977/ACQgfzNPlQHmhEzN81xM2fQ4/lSGzd/4ZX+p NetReBrBRmSe6k+jBR+gqePwfpUec2zP6F5Gp2A8gTTT1MA6fxEU9LBlIwYgfwNezxeH9LhwFsLb 6lM/zq0LKCPBjt4lAPIVAv8ASiwjxdNHuZDmNZGX/YjJq9F4X1GRAfstyV/657R+tewYVR3KjnAp Ng3AgZAHUmiyA8ti8EapIoJtmVR0LyqKtxfD+7YZkNsnsXZj+gr0hgCueKRBtB+lGgHCw+ACOXuY lGf4Yc/zNXY/Aton3rqdj/sqq117HPGzH8qYCScA/WmBz8XgzTFHzLK5ByQ0vX8quReF9JjB/wBD jPpuJP8AWtZQCcYwPahgMEE9KAKcel2EPKWkC/7sYqdIokwqIo7jAp/DE4wcdKZ8yHoKNQEAQSYJ 6UEncQAMeuKU7sghQTSnaR3B9qAEJ5xjH1pSC3JOBTBux0JpcbutAhpwOFPPSlQDv0pSmOc/hTdw B6GgYYIPPSgg44OPrQzDbigOMetADSvTnJp+cIDjPrSfePAAxTskAgikA0ucHpTQSSMcUOA30pFX B60AL8wGBTwSRzSAcjLE07tx0FIY37rDnikK/NkUMuVJGaRGIXb1+lADg5wRimk7mz0pc89KUsN3 A570gBSe+Mmm5Ykg4NKxAHQ80372fl/WgYE+gximtuApSDxQcAcHmkA0kntTgB+NJnIBxTupFAxD 1weKcg5NEnp+tMG5evSkMHGDkkYoDbuwxSnB5IyKTIB/qKAFYhvugig4Ax3oY5I4pAP84oAZgZJ4 oBUcYobHemnnoMYoAUY5yKGA78mjn6U0gGgBSOOpFNU7WAxzThk/SlALHpxSGMIOR64FLyevr1pS QW5z0pwYAYNYGw3aTyaORx+tOduwP5UAnpTAVWypBOcUmcd+KXbzjmjhW5FAxVyfpS7cg5NGQfUU 8emaAEC7Vzml46kUDJPy9KcTng0CGgnPvTsbuuacuccLzR1FAC46VynivxI2m/6HZsBcsMu3XYp/ rXSXE4t7eSVuEjUsfoBmvH726kvrya6mPzysWPt7UrXdhSZXnmlnfc7s7nuTkmoTu5AKkipEB89R /eBAPoa14dFNkDLqE0cKCPzFAbLP6ACtY2vYh7XMNGD5yMEdqU5piZaR36AnilPXGaolajjkRsR1 xU9jpd5fEG2gaUDG4jov19Kg6L1/CpIri5t43SC4ZEfhlB60rvoNW6lrW9PGk3q23nxyzIBvMZyA T2zXV+FPEBaP+zrpun+qcn9K4YKc+YzFmJ6mpIrh4ZFK9fWqvqStNz2RWPpWB4lslktvOjiXzN2S VXkn1rPg8YQ2+kJJMjSzqQm1TjPuai/4TuP/AJ8ST7v/APWokk1YFdO6NPw/oxjUXNwOT91SK6Mk 5x0rjIfG8kzhItPX6tIcfyqpdeJr2WX5rp0GeEtwAB+PU0k4xVkVLmk7s75s98j0ryXXLprrXL2R u8zKPoDj+lb2na5exSOLW4adnO7ybls5Ps3UVzOoXaX1/NdCLyjKxZkH8Ld6d7kNWGwym1uRL5Qm jPVDzWhqGtXN/YR2KQw29qDvCRoFyfc96ychSu1855OB0qb5SvzSN+FCVh3urESqEwo5x3pHyfap WiiXo5NKsasrddw7UBYr4yOaUAA5qfyRgcH3pCkZxtUg45z60xMbv9qcqtIcKCT6CknkFvGGVFY9 81XfUJ2jMauERuqoMZoFcW6lCkwgjP8AFz+lNtmaPay/fDZX6iqpIX5uD61P9rDFUSEDHT1oAe8p YlR1JyT7mlRRjtTAFU5fknrtqeJFmk2RgKT03tgfnSukUk3ohrccHFNJ4qa7tJbNts23cehRwwP4 iq3IJ4pppq6E1bRj0z82OT2q3bxiTKE4JHHGfwqmrlGVl4I5q8l7F8rFWSQdWRsZ/KgBPJeD7Qsq FRswQeMHtWeDVq5uvNyqjahOTk5JPuarAdqAFFFOVc07YScAc0wGYp65PFaenaXHM+69la3t/wC+ FyfwB61r2ninSNAJGl6VDdXQ/wCW10glwfYH5RVW7iuY9noWpX7AW1ncS5PHlxFv5CuitPhh4su9 oTRLoA95F2D9akl+LfjGePy47s26AcLCqR4/75FZs3i7xXqG7zdUuG5yczMcfrS17F3gb0Xwi8QK xF29hZ4OD592gI/DNXD8L7G1K/b/ABbo8Q7iJzIR+VcS6alOS8+oTZb7x2jk/Wl/s7d/rLm4kz/e lI/lT1E5xOzl8KeB7IH7R4puLgjtb2mP1Y1Rk/4Vza5G/WJ2/wBqeJAfyBrm5NLtFkK+TE5GDnzC /wCHJqWPTYVZh5C4x/CmMfpRquoua+yL1zrPg0KBbaQ5PI3NdO7foAKw4Z9IS/aZluHjJ/1IQ4I+ taZtgyrGr5RSeOMkn0xRD4cuZZfMhtLubPpGQB+YGaTbfUVia38UiOZ49N0XTIkXBDzQh2/HdWrB 461uCBturm2kJ/1dnbxxgfiBXM6po93pd1DLcWxt1nUqF46j8TiqToVUYPXsaLt6MNtSLUdY1fVb hptQ1O5uZN33ppCxH09Kki0xGI3SysSM8ELmlsLGC61i3ivJmhglbY0iY+UnoefevRovBGmQRgNL cuR67R/SiKJk/M4RLCyjbBt4nPHLsX/makaC3XJSGBN2c7Ux/SvQoPDOjRtue2Mg/wCmkjH9MitS LRdMiUGDTrb2/dA/zqnoG55K1mk7ZXa2eAFjyR9Knh8PXFwQIrO8dvURnB/MV7FHAkagBVUeijH8 qcYfmD5z9am4zy2HwfqkihP7PKr6ySBf61dh8C3rZMjWcWevJYj9K9FdCc8gU5UAXB/WlcZwkfgR 96h70BSDueOMDHsAf51ej8E2CY82e6k/4GFz+QrqyuAMY59KQL6UAYdv4S0iMjNp5v8A10kY/wBa v2+h6bAfk0+2X38sGtEgBQFBDVGN5OcH8KLgRLBHGT5UaIP9lAKmK9PmNPUkLjJ6d6ifcwyOv9KY gwoY8fTikVTg8+55qTChfmHPtTQoJwTxmgADL7Gms67uM0pAyeOBUZYgjgfjTAcHYMRgj1701t2O MClwMccH1zSYbYcdcUALgheSPXrTcnOQBj+VHzYx1BpyEqSp6dqBDV3KOR160AcbQOBS7cSAZJ70 5WXnHr3oAYyFcZxk0h4+bAx060obcSSP1pQVK9MH1pgIzsRwOntTB2+Xn3p5GRkZpnG77v60gAk5 x1z+lPC9c9OtJxtznB96BIApx1pgNIHGD9KVlPGW/Gmn5iQOlLg4APQ0CEIOMq36UwBicnqe5qTj pyPTFJ8yjn86Bjdrc0mPmHJwaRmJzj86eo6E46UANxg+/fmlK8e/fNK2SRgj8qRj2HWgRGwGRjgU pBxkjP0p2FCn19qCTjGRSGNAIGaGbnp0oU/w8YoxyKYAwLHPakCgDpSjlqCGPU9KQAAM8EilCkd6 Q5z659KAw3dP/rUhgW4yD0pmfQYp7D5h1xTSvz9aAEPTO6lXjkUhX8qcik8A8UADDPzD8aZnNPbI PPSjtzikMaDnjFIcdcU4YxxzSBd2PSgBOB/DSlR19KUqcjnmlADHr0pANJLKO1C9fmGaUhg2M8U0 kqMjnPpQMcdo4PemHHbJpcZXJ60u3AoAbQrdcH8KQMCPemnA5xmkA7Azgqc01lAGRQMHoxBoVTnn ke1ACAg8U0qQQaeRt6cULknBzQMaTt780KScYoIxkD9aFOMDoKABh0ye1CnnFAJ6Y4Io5Xgn8qwN xe/NPUqOByaQZA9RSqMcj8qBiHglicAd6eAjoCD75oPzEf1pR8ooAMA96VQNvPJpgwDinZPagQ4c LwKcMcd6byBz+VOyPemA7aSODSBSSM0gJHIo6njpQBneJpTH4cv2H/PEj8+K8jYcV6r4sOPDV5no VA/8eFeUsRmiO5LGkZIz2pr5cjzJGYehNLnJpMgVaJYEg5wAB2ApvU0pbJ6U4yZhMZG1B8xIHzE+ mfSqJ2GYx1o3elDFSqFN5DHC8dabjmhAOzThgsAfSm9umDT4xlx0oQMntkjglDyx+eg6xscA/lV1 9YtbSMMmi2bEngvuOP1qrgYyTWZeTm4mESA7EOB7n1pOCluNSa2Oiu79L6wW5jtILV2/dlYAQCB3 OazGYqQqkDHerenRwTQyaaLhTICCjkYG7HK//Xpj2VxFIUkgkLDjgdaUUloOV3qRW5lEqOvD7gM0 zWIPI1SVP91m+pANdHYaSlpanVNTAhtYRuSNjhpW7BR3P6Vyt9O97ey3DAB5n3FR0Ht+Aq1uTJWQ wRNsMmDs6bqkhUEdTjp1rPuZnd9uTtXgCnQeZFcqkgZSSOCOapkI14og0gULuJ6VIkkUM5WRl3A4 +UgiqN3K8cWEOCeDVeOynksXu43VljOJFz8yj1x6UrX2Hc6J0huIN0RO4dQOc1nkDPuKh025ZSSP lxxxUs8xRd23JJ7UIehVvV+4D05qvFFF5hDdB7ZqW7Yv5ZIIOKbEDtYhjsOAaaJY8QQ7hhM9qYyk TlEVQ3Q4HSpwQgyFI45J559qbZKDKGPU5IpNjSLVtYRhcyYP16Zp91bqYv3aoQvUAYJpQSIU+n61 NAhZgTRa47mIy4zt+5npTQdp5HFTSFTczFfulzjPpml8vzBwuT0ot2C5BnBq5YaZe6pcLb2FpNcz N0jiQsf0pkVsscq/a2aKDuwXJ+lWJvEN7sW20x5LK2X+GFyrP7uw5J/SqsTdXNI+CtZh/wCPq3jt fX7TOkePzNLH4ds4323XiDSICOv+kGTH/fINc0baWVmdsnuzEZ/Ek0CBOcuQPTIFNegmdkmk+E7e ULdeLEkHf7JZySfq2K1Te/DSwtN0I1fULsDgTBYY8+/U156kVtnDN+JJqysWnBQS+W7hY8/qaLsa asT6jeS6pdOIyqW4OD5X3foPakt7OMKF37FPtjn+tXbO2bUbiK009NzN6jG31Le1ekaL4cstLjXY gkuCMNOwyT9PQU0iWcNb+Gr+5UGKwncAffcbB/48R/KtSHwTqWAzC2iOf4pMkfkDXoiW5xnO71p6 wgjkYHf2qWNHGQ+Bpi377UUx/sRsf5kVcj8DWan97czSA+gVf6GuqCHgcEU9YzySOB2qSjBj8J6V F96B5P8AflYgfkRVuHQdLQgpYW/HqmT+taRQN1yMdKDtxyxIphciFtGhCJGqDH8IAx+VTCPjABJ6 c0qooAI+Xj161IDtXaR8x9aAOV8Y6V9v0Ntq/vYWEiH3FechY5oFfGCeGB6g9xXtVwVliaNowyMM EGvJ/EWjzaVqMjRIzRyfMB/eHr9R3pPTUEYbx4O1hkHvXU6F4zksY1tdUWSaBRhJ1+Z1How/i+vW ubG2WIHkqejehqFhlsN1q076olruet2Oq6XqYU2V7bzMeqhsMPqp5rUWRo8Agr9RXhphSR/nUH37 1ftr7VLMf6Jqt3Eo6KZCy/kc1V31J5bHsqy5GBjA70pk3IeMZ9a8th8a+IrbAd7O6UdpIdp/NcVd T4jXYYfadIiYesM5H6EGodilc9GLqeMg/WkJyRjk1xEPxG00/wCusL6E+oCuB+orQh8c+H5D/wAf 5hJ7TQsv9KWganTlWPJ6HsKNykcHGPSsuDxHpV1t8nVLJz2HmjP61fjlDplcP7xnd/KmMl3Ev8p7 UM5xtz+VRrKQTlSg9xQHznc2Md6LCuPzlumfTNJgg8mmiUdWPA7U8v5idCBnggUALvyvPBA61Huy vQH3NIWKjDfSkV14GB70APyeBio3HzYwS1SFtq4HPFR4+YHd9RTAAvI3Y+lH3mIHTFOKgsDmjldz HkjjkUWEJtwgycU0LtycEn1NO4Y56mnADOB260ABwVznv1qIgMTu6A9KcxxgHOM9qQrzuApgLuz0 AGO2KTO5cdhTh8q9Mk0zBB5IH0oAN3OAeMelNwGOGIPvTjnnOAvv1pFTBznigAcspC9gKZz/AAnr 6Uqnk5JOKQcHHQ0ADBkbOeO9HzFuOcDjNPONnP05puDjHUUAKGGeTz+lBO445P071Hkk4wfrUm9S MHORQAwg8gYHPIpSp5IxQOZOvXilUAg8jNADBgk7qAVB6Z4607BXryPakGN3HQ9qBAPrimMnPBzU uB0/WmqpHPXmgYxAQDkA/wA6ApJ4OKcSMnI60Ig+lACYx0+8f1o5HB70vCkjv/Kmk5PHPvSGHUDP SlI5wOlGckc9KdtJakAhBxlTj8abghstzTyNoPGaA+AOATQA0KHyefoKVVI6npSKTk4GKXH1pDGs Q3Hvmm85wATTyBnjNA4JHzYoAZsP09qX7ox1pxI6E5o2jGfWgBNw/Gm8g8daMEtxSkYbikMTnpj5 qOePajALYzzRjb1oAQLkZ6EU58EYPWmMxB46U7hlGetADAuB0yKQZc4PFKw2sCvegnvjmgBFTuc5 pRjHoKM8D9ab3/lQAdT7U0nB4HzU7OOT2pjsM8UDGnOc9KXgMM+tHXiheoyKQXKqm+GoOrLEbQgF XBwwOOmKuYIApxXDZPpQBz/SsTcccGnEfL2pi8k46U9TzzSAANq5OTSZzg96XJbOOmaXAB54oATj A9aAGJzmlNKAOvP0pgKgJySaVn5wAKAPm44pwjAOTQAnJ6daAMHOTjvT244x0pOPrTAwvGUoXw3O vZmQH/vqvK3OTXpPjuTZoSp03TKP5mvNGpR3IYwnim5zTiATyaTHtVkiE0c5zS49KCKoBGaR3Xc5 2pwgHAFFBFJQIXFSxL8xJNMAx2pzMVVnXqB0oEy0QCMjFZ8sYiuA4wCQWGamtpZZFYt29Rilmi8/ aGGNucHNF9QaH6VZxyW8lxMxA7Y9atJr+pQRCGO8lWMcDvj8apqGS38oMQvoKI0TI3EgVNru7Lvb RDp7me7kEk0jyyYwGckmmCIqwP8AF/KrMi2yqdk0hI6blxn9aiBUEZfg+g6VcXYza1KktkWk3Iep 5BpYrRhKZZW3N7nNaSzIsWwPxnJGBzUUjRcbJS3HpRcdiGSETRlTxUcdldJG8YlMcUowx5AcZ6e/ Sp4phHJuz9Kla6EiHcxyAAo7AU7isRxQiCMIp4qUDjnGKh8xfWlEg9aAK94dkqsDjavFWLoWqx2n 2Z2ceXmVcYw3171BOvnOOmMcg1IY3jtQisrLncQOo4pokYNpGB09qZbuYicj5gcUKcMM8A96QKdx x0pMpGxalJEZowpc8lX+7+HentcM1uY28mCIcSGBSWcehJPH4VkhmBGwkMOmK19F8P3+s3Ahghkf d/Cqk/nRGLuNyuZKwNPIViQ7c8ZrtdA8FySQfbbwGO2UZLHH8q7CLwxofgi0iu9auYrm/HItlxtT A43fjXAeJfHl9rMrQWvyRcqNowMewFa6R9TJtvYh8VX+nxD7HZxqSMgn19/auagsb2e1ke2tWeNO WYDpXS6T4PYot7rMht4GG5Vf78g9hVnU9eihi+x6bEIoVGAP6n3qXfdjtbRHOadocWolfterx2cr f8s5onLEevTFdHa+ANMbG/WmkbuEVU/ma5uS4eVyX+dj/EeTTY7+8hBWK7nRTxgOSDUttbItJM76 28AaIuN4uJ/fz/8AAVr23hHQYcEaXFx3fLH9TXmCazqMZBFwGx/ejU/0p58Q6urK0d7NCR/zycgf l0oU31iJwXSR7Fb2dnaIVtbWGEHr5agZq3F90ZA68Vy3hfxTFrlqsE7Kmoxj516eaP7y/wBRXQhs ZIOfrWlrq6IbtuaCzDBQ9fbpSCQFiGOOOPeqiOBzxTy/mHI/lS5WHMT7un8s04EqoOeCenpUKgHH NSE5XBI498VLRVx4fAJ3fhSJhvam5Cjlc0pIwCAOP7vFKxRIxHAycelC4546UnBG44H0NNQ5fkde lAEzgHjms/VNMt9UtjbzjAPKuOqH1FXdx4AAyelNbIYnGOwoA8u1XR7zRLnzhtRm+7KV3RzezD1/ Wsea+jZibvSzGe8tk2R/3ya9jkjjmVo3RZEbghhnI+lc9feC7Cdt1q72znnH3k/xFK1ncd7qx55b Q6feti31a2R/+ed0TA35nK/rVw6DqaKzR2UkyD+O3IlH5qTWpf8AgW/x8sEF0o6FGAb8jXOz+Gr2 xcuLW7tT13IGXH4iq5iXEiljliYrLHJGfR0K/wA6aAOgwfxq7a6x4lsX/wBF1+74x8ssu8fk1TT+ I/EU21ru00y92nOZtPjy31KgGnzDsrGS6ZUgCmFB3AxV9tbUylrnwvYnI6W8ssX/ALMajfU9FkH7 zStTtnzyYrlZB+TKP509CbGe8MTctGD+FEcSxndC7xn1RyP5Voeb4eeI7dUvYH7LPZAj81b+lILW xlH7jWtPY/8ATTfEf1WlZMNRIdX1i24h1i9UDsZSw/XNX4vGXiWEY+3RzAdpYFP6jFV10O7mOIHt rg4JHkXCNwPxqOTR9ThBMlhcgDuIyR+Yo5QuacnjjVri0nguILRRJEy+am5SuRjOMmuct73VLbH2 bUbmMdglyf5ZpZkl8tk8twTwflPSqZj2Ec1Lj3Gn2N2Lxb4ohwP7QlkA/wCesav+uKvw/EXW4G/0 i1spvrGyH9DXKKWB+XI981IJpQceY34nNFgbO1i+J5OBPow+sNx/Qir8HxI0eQ/v7e+h/wCABx+h rzoyN3CN9VFJlCeYUH0JFPUWh6zD468OzLxqSxn0ljZf6Vowa5pl4AINSs5T2AmXP614psgJGQ6g nkg5xTGggLEB+PVkouwsj30crvTDDr8pz/KlDnvkH3714FGJIfmguCh/2JCpq/BrniC2wINVvQPT ztw/XNO/kHL5ntpYgjBzQclARn3ryOHxx4ntzl7mOUf9NoAf5Yq/F8TNUVStxp1pKPVSyH+tHMhW Z6aN2CS2PalR8j5m9sVwEPxMtTxcaVcJ7xSq2PzAq/B8QtDkx5jXUJz1eHP8iaOZBZnYFhkgjFNO cdR9cViReLfD90Bs1e2U+khKH9RWjDeWk/8AqLu3lHrHMp/rTuhalggIQfX0owu7jP1NO2OqglSe 4OKQMrcNxTC4gUnJHJz0NSfNkgimqw2gZ+hpAxVyC3596ABmGcimEsy/LwKc2Dye9HHAzxQFhB90 n0ph+uM81MAvYEfWjCgDOfwpDGKTtxyKYC27kcVKWPTJNN/hyODRYBVZcEcj6009+c05SCRxj0zQ VXOCQM0ANDe2TTsg9qTAUg7uKCw5GetABt6Z596btU/WgMcbfT1pQQvBIP40hiMBxjOaeDlQR97o ajcjsOaXdlACcUAOwCOc0gxyAKAeARSjsMZNIBOF9RmkLEeuKeRkc8e1MbIGD+FAxpwVx3oDECgE dxilyM47UgEwPz70oyAcdKCnp0oPC4yPwoAQE59qQ8tx0pOSPb0NIpwaAHALu60jLnknNDDnpil3 ZUjikMbgdM0Y+bngUDC4pSSRjpmgBDjj0phAz0qTA24BpoA7D9aAGsvHWgjHQ8UrDJpPm9qAGkE8 CgqoxT+QKYAR1FA7jGbFKB84yeM0rggdKUYyM55pAOY7mGR2pAcGlJG/HfA/lSjBz1rE3F3cClwp GelM49TmpVUHmgBg3Af1pxycetOPGO4pPlbFACdOnUU4dMUjDJ46elOU4HpQgHIoAyaV29KQAjnP tRtw3PNADlclSDz7Ui/e6UqDGc9KXIA9DTEch4+Y/wBn2qYJzKxPHoK86YZNej+PA5sbU4BG9gfy z/SvN2JzSjuyWPt0Ek6IVJBOKfeQpCybRgsMkE5xSWfzXSjG7rxT9QXbOo2Kp25+Ue5quoPYq96O /SgZzTgKokYR6DNLjngU4AUuBTEKsMjLlUYj2GaQqysVIIPcVJFI6sFV2GT2NWbieITTq8Cuxc4c scikBTwQAcH2pQCRWlJKiafAXSJiUIUY5zk81WjmhYxIbeNSCMuM5NA7EL28scYdo2CN0Yjg0stp cRoHeF1Q9yKvXLHzHcp5X70bQXyGGaiuYmVpnQtHGzYYs+d/Pai4rFZrG5VSxhO1RknI4FMa1nEQ lMRCeuatTq0aOsSrHBnGdwJf/PpUt3sczSbIghH7tlb5m6cU7hYotaTCLzDGduMk5HA+lRhfxq/c J+6aaRSsr4AAcEH8BVLJ7cU0JjTGOwoKcdMU8g4BzShTn71MRH5dSpFkZGMDvRt56mpUXK4ANMEi PacmkPHfmpilNZB6UkNooXI8uRWB+VuPYGhJYtwUSAnOOKk1Bf8AQ1P+2APyqvFbxMqMpYN35707 ErRnr3gn4UzavCmoXciw2R5MjHqPYVveI/Hmi+CNPbSvDUIDtkPdZyzH2/xryq18ba/p2lNpcF2X tOyMSQKu6B4H1HXEOs63M1npgO5rifhpPURr3NO8noU0t1sZH/E78Zan5USTTu5zsXJ/Emupg0zR PBsG66ePUNWK5VY2BSE9vqamvvE9npFlJpnheKS1tW+Vpn/1sg/2mH8hXGTzkvuLEs3X3qkktiL3 Luo6zdatPJNcyMFxyP6VmMzOgTcEXsFUD8T606M+cskYPzHlfwp0Mce1hLLHGegDAlvoABUbvUrp oUv3jOxKY2nBKjimMDu6Yq5cI0Ebq+Ud3GEJ5AHrVMk7iWbrQhAFoyVNJyDwaOvtTAUZBV0JSRTl WU4IP1rpLHxvrNkgScx3kY/56rhv++hXOAADJNO3Y+UHigPU72D4hWzhVntPLz1wx/wq8njnSiv3 mU+hf/ECvNlxxkZoYKw6AUe93D3ex6tD4s0iQD/SGUZ9VP8AI1dh8QafNJtW5GR6qeK8ZCKRyaTY AeOtL3+4/cPc11WzxgXkB9ycH9akF7byAiO5iY9MCRf8a8MVpV+ZZnX6ORinrc3SE7bmQHp96i8/ Idodz3ZHLYIGWx1XmlDSLjcDgeo614VHeXqH5Lhwcc4NWotZ1WHBjvp1+kh/xou+wrLue1CXBJx+ FKzkqM5NeOp4s8QRj5dSm49TnP51aj8deIYiCbhHHo8Kn+lO/kK3mesBmC4wPqO9Isvy5K4PQE81 5WnxM1WF/wB5DaS+3lkfyNWE+Kk3Im0i3bPdJWX/ABougsz03JbkGpA5K8MfwrzmP4o2Zx5ulyqP RJwf5ir0XxO0MriW1vUPqoVh/Oi8QtI7Ga0tJl/fWsEoJ/jQGs+Xw3osx4sIlJ6mMlf5GsmL4ieG n+9dXEZ/27c/0zVyHxj4bnxjWrdP98Mv8xRaLC8gfwdphU+XLdxN2xLuH/jwNUJfBCHlL1PUCW3U 5/FcVuW+u6ROf3er2LDoAJ1BP51dWaK4P7m4if12yqc/rT5ULmZw1z4BuZR8hs5DjHylo/55rJuP h9fx5BsGY+scyN/hXqqpJx+7Y8dQKjZjlSQy46Ucocx4xceDrmAHzLS6jI9YGP6jNUxY31icw30s B9BK0f8APFe5M7bwRx/unrSMuR86q4x0YA/zo5WHMjxFdY1KwYNd3LXcJBUJLJuGfXNWR4i0ecYu NJdDjkxTZ/HkV3Hi3wlJq/2eXTVt4pY9wdQFQOD0J461xc3gTXYwT9gWQZ6x7W/kf6UaoWjBLvw1 MOJbuAn+/GGA/I08WWizYMOrwZ7CRWWsa48Oanbk+dptwg9djf4VntbFCQyyKfQ4o5mHKdX/AMI/ 5hJjubWVe2yZc/kagl8PXaglYWbHdRmuY2soyHYH3BFSx3t5FzFdsMekhFHN3QWZozaZcJ96Nx9V NVzbSggYNSR6/q8YA+0OwHPzYap/+EnvAcT28En+9Hii6DUomORTgrj8KYVYdRWoPENq6HztMTH9 5CRR/aGiS/ehuIjjsQRRp3HdmaGcdCwH1p3muOrZ+ozWio0iT/V3hUn++mKd/ZtvKP3V5bsf9/FO y7iuZZfjlUP1FIdhHKY+hrTOizY+Qo/+6wNQvpVwoOYz+VKw7lAxxnuw/DNNEEfUMAfpirLWsicF Tx7UwxMvUGlYLkkN1fWwBgvp48dNk7D+tX4vFHiOAjZqdwwHZ8OP1FZRQ1EQQehotYdzqYviBr8Q AlFrKo/vw7T+YIrQi+JdxgfaNKgf3jlKn9c1w3mOBgM2PrR5rkckH6ikB6VD8S9Nc/6Rp13H/usr j+laEHj3w7NkNdTQk/8APSA/0zXk27I5Rc+1JuXupH0NO7CyPa4vE+izn91q1oTjoz7T+tX4ruGf DRTwuD/zzcN/I14MfLIwc/iKaAo5VgPpxRzMVkfQbBgPutj6VHkbeRzXhcOpajbH/R9Quo8f3JmH 9avQ+LfEVv8Ad1KZgO0ih/5inzC5T2XOG5BINIGAbJ/AV5WnxE1xQBKlpLj+9DtP6Gr0XxMmz/pG lRt7xzFf5g0cyHZno55GeKRWXJOPauJt/iVpjEedY3kfrhlf/CtKLx14dmGDeSw5/wCesJH6jNO6 FZnRc5OBSs2RytUrHU7HU9/2G8iuAmN2w9M+tXSTjHBo9AuAP5/SkbABJpyvxlqQkOCf0FKwACNv Ao3HOOxpAcDOaUHoCcigY8YBxkE01+mc0DGeBQeAQTxSAaxIFIATjAp7LhAe1NOMggjPvQMdxnAY n8Kb05LY+ooy2felJV8gg5pANDFvTFHA6DB9aAgwefpSLw2MZ+tAClj06/SmkHPHepCvqeD6VGQA efwoAUKQBQwzz29KcGwMDn1NBPy9KAGZGOlM53cfyqRgetMxhunWgYucnJ6VH0PXGac2c4zxTQpx 1oAUEDvz70u4Ee1NHzdadjC0gGksegpE5YZ9aVjxgU1flYfWkMkIJIPsP5UcAf0pSOwPYU0AcnNY m4q5p+4im4PUCnLjGCaAHDkUhxnj86UZ5GeKDgcdTQAobC4pw4GCaaoyDzSg0AOPPAPFGPQ9D3pq jjrUioWOcYx3piEIzg84pwVsHHrQf9kU7d04+tAHO+MIHn0EtGpLxSK3Hp0P868tmVlkK+le1XkC 3VtLbvysilT+NeQ6haPazyQTDEsRKN+HQ0tmJmdyvQ4NBJLZJJPvS4OelHUVaJI3YlsL+J9KR2kj XccMCeo7VqaNpp1HdDEVNyHPyMcbh9avazp1jpOibHuEk1KWUfuozuESAdz6k04tPQUk0rmArZAO cg81agijZGeUtt3BQF6kmqca4iUdKnguGhyAFYZzhhkU2JF2fTmgMrK37tELbsjJIOOlQ2tqLqCW QyhGTH3unfr+VQyXsru5YjLrtPHbOadb+fJFLFEQEIBfnHAP/wBekMe9uBKUMqptUN8+ecjOBVn7 CnkCRQ2AB824HcdpPA7YIxVK7M5kWSZlckBQwORgdqkguLqTbHG2NoPIwMDGOTQGg21j+0XCRs2A xxnPSrb2kMFqk0jCXIHCN8uST3/CqjQvbKs6SxsN2Moeh/Kpku7tleZJcCNQDgAcZ44+ppiQ37Mv 29YNxCllHvzip3tImtXnjiII7ZJwAcZrP8xi5ck5zndVhpZpLUyGUlNwQjPXvTsFyzbw25JYN5ih CWDIRt/LrTbqMCNZo4TGrORz7YqpFO8bbo2Kn2NK0zvwzM3OeTR1FuHUdelKo7+tIOnOKU+xqhC1 IjbeAM5qJQMjIzUm3nimFx5NT2On3WoyMkC5VRudzwsa+rHsK1bbQEtrZL7WpWtLZ8eXCB+/n/3F 9P8AaPFLrGpSCEWUVuLCzUhksVO5m9Gmbufai1gZzGsMpdIYmDRRDAbGNx7moIFHkg45z+laVzps stuJn+Vnb+L09aali+TjaAPujNBJWjcJKjBsYPpmuuuPFWpeJwtvf3UYeFAkKsfLRgOwA4B6Vz32 CRlClkAHtTl07Gf3mfwpPbRlJ9GVLuaWOZklQrIpwQaqmYv7Guhjtomj8q6Tzk9c4YfQ0svhywli Mllf7JM/6m4H8mHFQ5tfEUoX2OeGVwc4PrVlbmcN/rCcjkkZqw+j3sTiNoSx7bSOaWLTLxmwLeTO cAbCea0ikyG7FRhklidzHqSaZhBjOc10KeDdemh85bCZYyMlmQgY+vSqcnhbUg+3dEW/ulwMVTi0 K5jN7Cmng55rYHhnUyu5YVYdeJV/xpR4Z1bdxYStj+7g/wBaOVhdGMoyw5q0sIZemKuNoOpwkFtP uFHvGaSXTL2JVYxgg9gwyPr6U0hFdbUc5lQKOeahdFQ4D5qx9guyeYSKVtPnG1imfXjpSaYFMgHk Ghj6cirBgnT/AJZH6YqJo5O8Z+lDQERbngce1PbaT8hJH0xSiN+hjb8qUIRwUb8BRYZHux061LG5 x0oEQI5yPwpoTa3X8KAH7hn5ailOR98g0/uRmq92cIODyaTAoHOcn1op20mjbg8gVJQ3tQadt9qA o70hDaDn1pdtG2gY089hSjg8cH24pcVbjty0Il+xytGSVEmSFyOvNFguyOO+vIT+6u7hCP7krD+t XovFOvwf6vWL1cdjMT/OqEsaeY2wbUXgknNJ5StC7gnKkDnvnP8AhRYLm5F478SxkEamz4/56Rq3 9KvQ/EvX4wBItlMP9uDGfyIrloYVkdVYSM7HAVMf1qd7WBYUOZEkbgFyNpI78cgU1cDro/inqIx5 mmWbcdVZ1/qatw/FRM5l0Y59Yrj/ABFeclSrEcZFJii7FZHqUXxS01l2y6fexj/ZdW/wqyPiH4Zu FIuIrnkY/e2qv/WvJNp/umkp8zCyPU5Na8A3n+tjt1Pvaun8hULaf8P7v7l/BET/AHZ2X/0IV5jz SHrRzMLI9IbwZ4Wuv+PXX41PbM0bf4VDJ8NXkI+yazbyZ9f/AKxNeekDqQPyoGVORx9KL+QWO0l+ G2vof3Rgm56B8fzFZ114K8SQOxk0qVj1PlgN/I1hJe3UX+rup0/3ZWH9atR+Idahx5erXox0/fMa LoBk2kahbkiawuI/96NhVcxNGcMrA+xzWvH418SxjC6xckejYb+YqT/hONaYYna0uB/02tI2/pRo IxRJJEw2vIv1yKmj1O9jO5LhwP8Aeq9J4m87/X6NpL/SAof/AB1qhfVdPlBD6LEmf+eNw6/zzSGI mv3q8Mwf6qDU415y2JLWFs+gxWe82nOfltrmL6Sq38xUTPbliwabP+1ii4jdi1yziBeTTI5cjhWc 4/SqKXFrOSxjaFD/AHcsB+dV7aSw8mVblpfMIHllVyFOecimw3ghBVTkE5IIp3bQWLpjtX6XaD/e BFL/AGeD/q7i3ce0mDUAvYCfuDkYIIFAe1OWMcfXsaAJm0y5AyIyR6qQagktZUPKMPqKeiW4yNzR gnqHzinh2QYjvpU578ikBTKEHvSAc1oeZcn7s8chA/iWkDS8GW1gIPfv+lAFAijOPWtGQQxAedp8 qkgH5H7evSoStiRktPF6bkzQMqb2HelDHPIB+oqx9ntmwUvE57MCKX7AxPySwv8ASQUAVWKEfcFN UJnuKsPp9yv/ACxYj1AzULQyL95GH1FIDR0jVr7Rp5JdNmCl1AdWQMGA6cGugi+IOtR/621s5fqh U/oa5CNGycZzUu6RccmmB20PxJcH/SNHU/8AXOYj+Yq9F8R9LbHnWV5F6kbW/wAK87MzdDj8qZu9 QKNRaHqkfjrw9N8rXcsfu8LD+WavW3iPRJ1wmq2ue259v868cIGelG1CMbad2Gh7ol7BPjyrmCQH +5Kp/rUyliPunHrXgYRAfl4+lWIru7g/1N5cR/7shFF2Fj3PdzycY9aA4z6mvG4vEuuwYKarcHH9 87v51ci8da9EMNNDKP8AbiGf0pXHY9ZLZ5xSKx5GfzFeaQ/EXUVGJrG2kH+yWX+taMfxJiYATaZI v+5KD/MUXCx3ZUrjoaNoJz2ArD0TxNZa55i24ljkj5aOQDOD3FbgI2YPOaNxDSNwz0xQVBXjrRn8 qXAxmgYxQQeBSk+lKenBxTSCAKAHe5pjHJz+FDk8YNMKE/WkMUtgYxSr05poA5yc0vBxg0ABw3Sk yQOcUu0LjvQxB56igBO4ximdHHrmne+MU0kBh9aAHsN3A7AUqrjrSseenOBSqSRyawOgQcdPWnnO cYBzRignA96AAA96RskjnApUIP1FHU0CHDCgUHnrSgE8Yp3bBxxQMbjDAA8VIWxxTBjPPQ05umOt MQA8dMmkGfxoBIzxSgFuo+tADxESOCK4zxpoxYDUolJ2gJMB3HZvwrtDyB1HNMnjE0TRMu5WGCPW kxM8QuIjG2f4T0PrVfvXXanp39mXcttNDvtjyvHIHYisC509kbdA3nRYzuUcj6ihS1sxNdUUgCTl XKN/eU4qMxDduZyx96lx61E/AOM1oiWO/Gm4BHFOVeBS49qoQz8as2jlWdQ0a7lxiQZB9qhC5Oaa QQcGkJMs3BVLcRBkZy5Y7OQOOlJbOoSWNjt8xcbvTkH+lQxRtI6ooyWOBWna2KKpMjQy/vEXCtnG TzT2Q1uQTgR2McXmxu3mFiEOeMCo4ZFW0nUsAzbcD155q2LOJUc4y6RMZB2U4ytC29vsF4eVWPcY 9vG4cYz9eaVwaZUtGRLhWkwQM4yMjOOOPrVq8n8yyWIyxO3mbv3abcDGPQVnc56Zp3enYSYigD3p wINAGWApzIRLj/69MQ0HmnEnJFaEWjXLYacLbR4B3znaMew6n8KuRyaTYDdFCb+X/npOCkYPsvVv xqrCK2maPeXytMgSOCP788p2on1Na8d9pmho32CKO8vs/wDH5cJmNP8AcjPU+5rFv9Vu9Qws8pkV T8igBVX2CjgVCls8qb3cRoPvMxxRfsBebWL17trszyyXTghp5TuYgjGB6D6VKI7PTLYXupsxkcZg tgcvIfU+g9zWU+qRW522CieVf+XiRflU/wCyvf8AGtDSfC15rAfU72dorQkbrybq3sinlvw4pWHc preXWqXhd8JnkIBworRWxvJWEdpbtcTgbmRSAFHqSa0rOxj80WWmR+bIv3pWXhR6sf6V2elaTHYW 2wfM7HdJIRyx/wAPQVSimTexw8PhzX5jzYwRD1ecf0rQj8HaswBkls0PoCxP8q7xIghGcgmpjH8w x6VDSKUmcQngm5IJk1CP6LFmqOo+DryAF/K+0xD+KPOR/wAB616MI8cUvzYAB6dMUrdhtnib209s zCOS5UDqEl/oaS31bU7C5WaG7mSRTkF0GfzFey3Wm2N6D9ptUc+pXBH4jmsW48G6ZM37szR57Bg2 PzFCuhnFa98SvEus2Udpd3X7tOAE43e5x1/GuVOsXRJ3yMa9F1L4e7oy9tIkhHIUjafw7VzS+HEJ eO4XypkOCP8A61F+5JhLrUynO81bj8SXCggSsPoa0X8MQgEh+n+zVZvDkO0tvKgLu+ZSOKoGSReL 7yI5Wdh9DWtbfEO5jYGSK2n4wRNCrZ+tYB8OLtBWVTk46nrUZ8OPuAWRSSMgBuoppvoydOx2EPxC smCi40fT3HcLHt/kalPjbQZAN2gW/uA7D+tcS3hu6GccD6ioW0C8XorH8KfPLuHLHsd/F4r8MEAN oy5AwSJjnNWo/E/gp1VZNEfPfbcdfrxXmB0e9X/lm35GoWsbtDyrD61XtJC5UevjWfh9OhB0m5Vz zvEw4/SnrL8PZYQGg1BXJ5YOp/8ArV435V0vZqA10vTfR7Ri5Ue1pY/DmZAxu9QjP+1GpyfwqxF4 Z+HlzjGuSxnPV4sV4as90nTfTxe3anBL0uZlWR7o/gHwGWUp4liAwcjAOTVaf4ZeELuHZB4qtUJ5 yyA4H0JFeMDVbtRw7Cnrrd4P+Wj/AImldlaHq83wS0iXBsvGNm3HIkC4z+BqvJ8B7oqPs3iPS5D3 ySK81TxDdpwJGH41Mvim/XIEzc+vNSPmR2Vx8C/E8ZXyrjS5snGVucY9+RUMfwO8YSA7YrBsf3bt TmuX/wCErvMH5jyc1JF4xv4mykjqfVWK/wAqAujbm+DHjaIgDSlfJxlJ0I/nWXN8MPGkDOr+Hb07 RklAGH4YPNOHjm/Ax50uP981OvxA1RWLLfXak+k7f40BdGWvgHxLlxJo97CUPKvA+fwwKr3uj6lp 9sITHdshGWJgkRUPcciusi+KWtLuP9qXpZhtLGYkgZzx6VOPijqkkbxzajcOrEEiQK/8xTVhXPPz Z/J8swUlRujkUhs98cVHFbtKjmEGQqB8qgkn3wP8816PJ8SLqeXzGliMmR832WPt+FPj8cwrL58M FhFMeN62wUgdxkHpRZCuefjTrq2i3y20wZn2LhOWb0HtWfN5gldXQqwYgr6e1ekTeIrK5jjiks7N oxnK7n5z1Oc1QZNCmeQNYxBWOV2zH5f8aGkO5wWCTgDJNSLFxlvyzXax6ZorpKskOCVK+YJASOhG AenTGfeo5PD2nzny4ZChwCCTkKO4X/69IDk/MiVWwqE+jZOfpVViGJIGB1xXXz+ErEBxHqErOpHB iGMeuQapyeEpwTslRlx8pJxn8KVwObAB6dadHguMjKZyR6itseGLsFWwjKDhgHx9aim0K6jkxHEx iY9cgkD3xRdBYzYox5Uz5xjG3IzxUT4kmGAACQOK0ZtNuLUllWVkbK7tuM0xNJuFgNxINkSnGCfm J64A6/jQFihJgZUKAAxwe9NMZRQWU89M1deFJZWkjzGTztk9Seg9hUDrIm6MPvUnkjocUwKuKMVK HkVSoxg9eKVFeQsR94Dp0zQIj8ttpIxx19qRULU8bhlfXrT493LiIsv3eBnmgCPyeCQ6/TNRkU5j yeMe1Kuz+In8KAGqpY4HWjafSlAy2AfxpzvngE49+9AEeO9KATT0yMn+EdaR33noAPQUAMpQxHc0 lGKAHrK6kEOw/Gplll7M351XpcsOhoAtCaYDiQ/jS/ap8AbgQO2KrqzHrUmKAH/aW7oh/CnK6TSb TCqnHY9ahI9qdb/8fA+hoAnjmSJjlJASOMHvTxfMp/18y/7xzir9vZXSWL3KwMYJAV8zZkcHsay5 42DjOCPalZ9QVrDZvOuZiUk3/wC0eM0wrdxEglgRgkZqdc+WCOMHg1BKGLksSSepzQGjHK91tJOO OMMvJNN+1OD80SH8KapdWBV2BHIIPSl8yUcbiRjHPNAWHG6Qj/V7foaPtEPHDj9aYZGxgohzjqo7 U3cDnMa/hTAsCSE/x/mKUFD0lT86qY/2cU0qPQ0XEXcHPBU/Q0mxjztP4VS2804M46MRRcC1tPel BZehqsssoPDtUy3EuOSD9RQM6nwTIx1+MdAUbOO9engnPNeM6VrFxY3ZmgRPNCkKdvT14retfiNf JgXFjbzL32kof60kK2p6UzgEAUoJP0ri1+IdgGj8yymRWHzEMG210Wma1YashaxuPMIGWUqQR+dO 6Haxpk8+xpHAAwCaQkkU1icjNAACQOlLnGMilHPOcUjYzjjJoAawAORSZXPWnFTnqPwppWgYpXjJ P5000pPFIxIxjkUAHcUYBYfWkPTJpVYA0g8yQg5JA7CmgNuIzT2bkYz2pCCTkGsDoF3c4pRg+hxT SPWlUEHigAA7EU4ZH0oAzgj8qcSce1ACjJOAaRRgnPWkHtSk4PHFMQu3JowQeKVGBHSnLgZI5FAA CcdOtLu7Gjdknik6k0ASBgw60mG69vWmqoOMHFLkgnnjvQBn6xpceo2xUgBx91vSvO7u1uNNu2HK sD1HevVQRgr1rPv9KgvoissQB7MOopNC2PM2ltbhj9stwWP/AC0h+Vvy6VVfTLeUboLxQf8AnnKu D+fSt7VPDs9iWkwfLJ4Ycj/61YkttIq5K5+hpJdmF+6K7aPfJjFu0g9Y/mH6VWkikhO2SN0b0ZSK vwTzQNmOWRGHQg4q/N4g1K6fFxP5w44kUHpT5przHywaOeBpDXSDVbeRiZ9JspMjoI9v8qR7nR2Y mTR1TPA2TMKaqPrEXs13OejdonVx95TkVYW+eMDyooo8Or5VepHStHfpDE/8S6UDt+/P+FRudNz+ 7sW/4HKarmv0J5bdSgt1Num+bmYEPkdc00zS+R9n3fuy27b71eae2+7DYxfixJoN3KmVSGJMdxGM 1SfkTbzKcVrPIRshds9MKan/ALNmGDKY4VPeRwP060kt9dSD57hyPTNVw2ecn3p3JZeEGnW2DJNL cN6RLsX8z/hUg1X7PkWUENsf76pvf/vo9PwrMXLnu30qdbWU4JXaPequFriSXEk0hkkdnkJ5dzk/ nSrE8uAAfrVuGwVfmfJ7+1WlRAcdcdlpAiG2skLhWIDE8E9qzpbG+u7ySCZSzxHGwH5F9/8A69bf CsNzBMjgDkn2rWsdC1C+IbYbSIgAySj52Hsv+NNCaMS00m2sG33YWWTI8tFPGfp/FXV2+l6hqrI9 +z29uoG2JT85Hp6KK29N8PWliNyKXmPWaTlj/h+Fa8cWDgKOKq/cEVLCwgs4VigiWNAfur/nmtJY VYfKSc0iKGO0ccZqVQFXANS2PlEaPsTnFK3GDtA46U2Qk9O1NViW+bp2PpSGOOD1GKXbkfSmltuR jNCuWOc446UgHt0wORQoz6UinJPP4U8EAY6UADIrDjr7Vn3Ol2V84a5tI5GHAJHP51cyRninxj6j NPfcPMw5PC2kH/l1MZ9UkYf1qJvCmmhQFa7U+qzkj8jXRFQ5wcDApBEAeo+hpckewcz7nNHwfA5+ S+u174cq39KjbwaSVZNTYEDAL26n+VdVs7kdPQ04wlhxkCjlQcxxsnhG7JOL22ctjO63Izjp0NRH wlqKqFWWyIVtw5cHNdqI2x3GKUoT1GOcU+ULnCP4Y1byPLMFsyAfw3BB6+4qAaBq6RbPsAfg4YTo T+or0FgckY6U1RjP8zRbzF8jzv8AsTUIQRLpNxIM8H5GI/I1G+k8Dfo92PcQ5/ka9IHBIYc9qNp6 AcD0o17hp2PLn0yzBxJZ3UZ/2rdxUDadpfeRk/3kYfzFesAsD34HANJIm4fwkH6U9e4aHkh0nSm+ 7dxj6tTf+Efs3PyXcB9t6/416w1vAw+aGNiP7yCov7M05xl7C1b6wr/hRqKyPKz4UV/uSwsfYioX 8HzjpGp+hr1NvD2iyvk6dag+yYqJvC+isSfsCLz/AAsw/rRdhZHlh8I3YGRbMR6ioG8K3YyPs0v4 CvWG8L6QT+7jnjH+xcOP600+GLUDMN7qEZ/2bkkfrRd9gsjyN/DtynWGUf8AAagfRrhf4X49Ur2B vD8iYI1i+HsxV/5imnQ74H5NXYjriS1jNO/kFvM8cbTJl6gfitNOny9lSvYX0TU2P/H3YP6B7TGf yNRHQdQBAMGkyf8AAXWi4rHkBsZunlj6g0w2k4/gP516zLoV2x/5BGnsDxlJyP5ioH8PSnOdBz/1 zuVP88UXQWZ5YYZx2akInH96vSW0JQSH0O/BH9wqw/RqrSaJaKDvsNSj7nMBP8s0aBqefCSdf4mF KLqdejGu2fSdNPVrlP8Afgcf0qs+labkj7an/AlI/mKNA1OVF/cr/wAtG/Onrqt0pB8xuPeujOhW TfdvbZs/7Y/xpjeGkYZSWFvoRRYVzEXXrxf+Wr9fWpV8SXijHmH8a0D4UlJ4CkfWoX8MTr/yz/I0 cocxCnim7VtxYE+pANP/AOEmdzmWGF/qgqJvDs4/gb8DULaDcr/yzf8AKlyjuXP7ft3x5ljbnBz9 3FOGsaaWBbTYeB2NZjaPOvVX/wC+aibTJ15wfxBo5UPmNg3uiSZL2LD6SUzdoUi/Mk6knsQcVjmw m9Ka1pOP4c/jU8iDmN42/huRf9fdx4GOFUk0LpugsMR6rPEG6hov8DXPG3mHVTTDFMOqt+VHL5hz HQN4f0p/9XrMP/A42GaaPC9u/wAy6nakdvmIP8qwCZB/e/Kk82UDqafKwub8fht0Zgs9tKGGD+9H 9ahk8M3LvgMmewQqR/OscXEo/iNPF5MOd7fnS5X3Hc0x4bvEUqQSv3iAPSoH0C7J4CKOwwePrxUK ancoCFlcBhg809dXuk4Ezj8aLMLoadBvduQIj9Hph0a+BwYfx3DipxrFzjHmGnjXLk9Xz9RRaQXR RbTbpMnyHI9QKa1lcgE+TIB7rVuTUpH6Nt9cd6F1GXdzI2OmKNQ0Kf2eUISVIx7U9YZNoJQj8K04 dZaLOAMkckjNTf22GUB1Q49hTuSY5jcdVpgJilV8dOtbB1GFySY059qgeS2lPKAfSmB1fhvxt/ZO g3Oh3drBc6dcv5isy/NExGCRjr9K53Vbm0urovaxKkeeAowKpLAvPlSqB6NV+00lp8M9xbovX79O 9wWmxludqhe+c1CTk811Q0jTEP727U+pTmh9J0Mg4vnz/uVLkhnJ8UY966OTSdMAPl3oJ9CtVjpl uBgXKH+tFwMQ4pMCtZ9MiwcTIcHtUZ00LjMqH6GgDN20hHetA2I5w68e9NNlH180Dj0oAoYH40mB V37GvP7wU02yA43UAVKUE1Z8lBgZzS+Wo6Ci4aiWztG4cLyMjP1GKj8pwTngZqcDC4HFJ1GCc0rj SITGrYCk+5Ndv4Bt3juzkHBUn8K5e0szK/TA716h4a0z7BYh3XEknJHoOwpbkvsbjcDjpTN3sPrU hyw4FRqMEnHNaDAcAjOaaMZxS9QeKQfLhsZpABJDdacSQTQcMRnimsOgFAC5XPvSA4zScZ2kUhXB welAxWOMqRzTVBLjnk0uQp96E5bIHekBM5yOeuAKReQO1AILDPHAo4z7VgdAo6e9PCkkEDFMyM5H egMcg9qAHkfMaXg5H5UHBGe9Ifu8etAh6r+J70hOegowex5pBhSMjmmA8L+AoA5JoDEnAGRTju7Y FADRuFK3AG2kIyOBzT0AwMfrTAVGAPK0Z+bjilwMYpPlCnBBpAGTggY9+KTJzz92lxnkH8KQ4B9D TEIyJKCrAEHsawdS8LwzsXt8RMe2MrXQgALk9adgY60mriuecXnhy8tM77cundo+RWSbEqeM59K9 bCgkioZrK2uPlkgjY+pUUWaDQ8le0cDcufxFNMEzAfIpJ6V6XN4Z09uBG0Z9UY1Uk8IRN/q7l1b/ AGlBFF32DQ882zKMlAOcVHOsspC7AT7V3cnhCc9LiPnplTVZ/Bt8ANphb6MR/ShSfYGkcSIZlKsR 06GnyQyEhmOM+9da/hLU1OVt1Ze/70UweFNUPP2ZB9ZRVXJscmLcMwZj06AVaS2jIGF575rpk8H6 lIclbZMnHzOTj8hVuHwRcnHnXkSf7iE/zNO4WRy0MQQfdAJ9BipGUAHcwU9ea7SLwZa5zPcXEpHY EKP0rWtPDum2hDR2ce/+8w3H8zT1Foed2djeXZxb2s0+e+3av5mt6y8IXUoBupkt1/uRDc35niu2 Fvt+UDI+tSKu1uBz609BGRp2g2OngGC3Uzd5X+Zz+JrTjiwckDPvU4j2n0BpQoXp+tO4WGqu0Dp+ FKRh+mfcU4ngYxkUjMNmM89aVwFyAT6mkV/m4PHvQfnX0oXABAwaBighifWkwc/KTQHGemD3oDA5 zzn1piFjGGIPU80MmTkdaBnrkClGTznH9aAEYFQOOacTwM4NJwTwc0m0ZJzQA9V/d8H2pw4X3HSm gqBkfrRuLMcDFADmbI5wMenekDd+tR7T34pRtC5JI+lAEyy8devHNKJCB0yahyAOQTTlYEHqM/rT ETKwHXqaCyseWz3qI8jA/MUDJIwue1AiUnB9DQFBHJBFRtlUx370DK9Bge5oGSBVPJIpRsxgKD6m otwzxn6UfNznigRKyITgj6UFFGB/KoVV/XI+tPzsxntTAcYACDg/nQEXkY5PqOlIZN3K5BHvTRO2 M5OfSgQ5bfOWWhowSQPxpqszAkN9RTQ5JPP40DsOEJxwPxpnlyfMMYXvUoZ15PP1pS7gcDPtQIhE W0cigxMQMAkDtUhlJPbinifA5A/xpgV/LZscYpCrZ4HQ9asG4XOdoHuO9OWRMZxk/WgCpJkgAL83 pTAjNwOB71ckdPvFe3ryKZvXOeq4646UCIdhAAz+Xao8bQVY8evrVrzIyMd+9KWiA6AnHPtTApqX CEAcduaaVLg+YF59RmrhCcZwKaSmccfWmIz3sLSQHdbQt65iB/pVZtC0yTltMtef+mQ/pWuQu4AY 5pCBkhSpHSlYZhSeG9FIyNNiH+6WU/oajHhfSzkrDMvptuXGP1rfEIYnLYpDEq+oPrRyoV2c43hS yJ+S5vo/YTZ/nUTeE05CX92P94I39K6YwehyfSmiLB3Z6cU+VBdnLHwpJ/BqbH/ft1P8sVBJ4XvV OBe2zA/3oCP5Gux2ZIGelJ5B/vDn1osgucU/hfUR0ewk/wC+x/jUEnhnURz9js3/AN2fH81ruxDj jjk+tEkeCBx6cU7CueeP4cvwDu0lDj+5Oh/wqCTw9cZ/5Atzn/ZKt/Jq9HWIkgADNMeNg3PGD0os FzzJ9CKj5tLvk/7Yk/yzVaTRoFPz291Gf9qB/wDCvVxE/wDdz7inEvgAEkY5FFguePNpVhyHkKH/ AG1I/mKjfRrBul1D+LCvYgC2C+WyfrUbWkLn5oYyfdAc/pRYLnj3/CPW7j5Joj9GH+NMPhnP3XB+ hr1yTS7CQfvbK1Zv9qFf8KpvoOlN/wAw21B9QmKLBc8rbwzMOh/WoX8O3C9K9X/4RvS2GfsSqP8A Ydh/I1EfCunsOPtK+y3DUrDueTPod0p+4TULaRdr/wAsj+VeuS+E7TZlLm9Q/wDXQHP5ioW8JxAD bf3IHuiH+lLlC55I2n3S9YWqM2s69Y2/KvXG8JMR8moqeP47Yf0NQN4TuwQRc2jemY2H9TRyhc8n KyDqrD8KMsPWvUZPCt9n/V2b/R2H8xVZ/C10Rzp0Tc/wyr/XFLlHc85UO33TUgScdM13L+F5k5Ol S/8AACh/rUT+HpEXmwu1/wC2Wf5GjlC5xn78djSZm9DXXtoZHW1uh9YW/wAKiOjR9xMv1iYf0pWH c5bfNjHzUnmS+hrpm0qAdZCPqpH9Kb/ZcPUTpRYLnN+ZN6Gl8yXvmuh/syLOPPjz/vCj+yo/+e8R /wCBCiwXOdDyD1pQ7nsa6A6UgP8ArY/zoGlp2lSlyhcwst6GlAc9FroF0gnG0M3+7GT/AEqwugXJ IC2twf8AtkR/OlyjucyEkPanCGQ11sXhe8kOPssg/wB9lX+tX4fCE+7azQL6nJf/AAo5Qcjh1tGb 1q7baWzuo2nJ6ADJP4V3lv4Vt4/9dK7ey4Uf41r22nWlmn7iFVJ6t1J/GnyiuYOh+HVgKTXaDA5W I849zXVDGBjp6CmAAgDtUn3SB6UWsCAsfWmDJoZgXzTiVC0wE3AHnrTckc9AaUZ65zmk3Bsg0hjS wJ69KQk5zShQvSmnk4JoGL1O4jpSkkjpRjpzzSEHPJAoEAG4/SgNtYDFKxI4FMALOMUhkxK7u54F BycelIR3xzgU9D8nI6VgdABQ3Ip2RgDqBQDgEkdaQY6UALy3Apyg5z1oBXr3FNRuvXihATEjHvTA PekySeSKC2DjPFMQoDZ5NOY5IyaNwK8DHvTgo3ZNAAxIIAFJgxtnsac2AexprNnoOaAF3YBoA54p MDBNKSABnvTESZCLggHPcdajyT2o57fnSjKgEetADhxk84xSAEEE04njI60FwVxmmhDsrgE44per Aj86Zxg9RThjqR2oEK684ApVUEn0FNBOeuR705WA5wRTGDAb8FacRjkZPtQ7bgGzQrnJ54oEI6ZX I/EUBMLj8qcD82CeMU4fd45GaBDAmecc0MoAPymnu46YprScAUwBU3dOM04ps+U0IwB5x7U4spY8 ZJHWgAC88AjNLxyBxTN2B8vWo1V84z36mgRMePlK5P1pyquOCRx3qMLhgSeaGc5IFMBwCjpmlwoJ 6ZpBhU/nSYYckH2FAgA3KQTxSdTtGffFLuZRwAB604EYB6e9AxgByVxx1BNO9CMCh+2DmnDYQSfw oDcQoSvXmkGBwSc0E7RuOGz3pS4K9OtMQhZhwOnrTo+ByeD60zfhenFKrqRgr+NACjklRz9KANjd TUnykfKfm9jSE9B1PtTC4hww6ml2hjg5PsKXdtAGDUe7Y/qT3JpAGACeuPepQMgE9KjKktzwO/NL n+EdD3piJVOTgdO+O9IxznnA/rSfd4BwaMcYJzmgBVOc5yaRgS3I4oZdo5JHvTQ2T1496AHY5449 BQzcgZ/Cl5xkGjGRz1/lQIeMYyWAqNeOB2pMY43ce9SJkDB6elMBCxBx3pGAY9ac2Rj69KQlT1XG PegQYPYZx3pP4uMgetOP3euSfWmDJH+NADwCc80zow5z7ZpVyoOTjNNTl956jp60AKykNlfypuCW OBSs53cn8qaG4yOuaAHcKPfvR8hAI6980MS6gAfXNJg4G4gY9KYAxOMZzTM/Mc8euKeMg5GOKbgj J6ZoAMY6UNyOV4PNMGR1OfapR8qAsaYhpGU2jp6ZpGBjXG0kY6k05mzj0x6VE2cj0oEICzDHXHv0 oUgZGQKYoYEMvBqTaeCetAAG2520wuy5zmjAY/zpCuV6nIpgKCD0OKGJYEdMUmQDnv3xTHOR1OaA JMlTweT2pCWxjkYqIEngDkdyaexA6cE+lADt5wNp/EilMpLYIBB9qiGSMZ596cBxjPWmIk5ByMH1 xSSuJBuPLCmP8vPWmYA65GenNMRJ5mwDCnBHagyqvIXj60wAbRiowp+YE0AWEYcbutKWXGSOPWoM MMEEcjFDbwQB096AsTeaoByM5po8v7x6+lQgZHQkj3oUENnJX6jNAE37vnGMGk/djG3kHrUJ6df6 UikjK54oAlbZ3GcGm4XaQOM0m7HDDPrTdwyTnn0p3AcFXZhqQopIUZyajJ5OSQPSgPl1PbNICR1x hcc+9M2Adc/SnsxD5yfxoJYnO4Gi4DCoOBjj1xTmRduAcfWkB6kk/wCNNLd2J/AUBYNvXk/Snm3O 0bXyTRkMOTz9KTe+TgdKAsNeM9N5P1NMFupJJC/l1qYOcZIBpBJnnGPwpDIGt4ieYkz7qKVLaLP+ rj/75FSeYC5BFBcngD8qAsNNvGrZ2r9cCgIMnA4+nFPJZh247UwucnHApDsDFscnj2qNgXGTnPan lt3B6UDgEHBFAWI8BOe/tTxgCkXnqac2AMEUhjGwBn+dAiyM84pXAKA5pFdl6nikMTjp6U7A65Pv Tc7mziggnvQCHZDD2pjL2yacBjp0pDyDnn2pDFB7Hmm5O7O3P1o3DHSjOTkGgBGzzgCmde1OfOcm m/L+NIAwcAjPHWkYEkc/nSqcZzRkde1AxGB9aRWKkc96U8joM0DORwDzSGSjJP4CnZ9OaYchvwFK DxnpWBuSE8AjrSAZ5yKUfMOPyo2gjAHWgNwUdiKdkE4pFTsTTwgoEMwVpwPHI496TqcHinnAXGfz pgIMAjP4U5sk9OB2qPduwAOlPVwAQR1oAdu+TPP401OSKUHK7RzikVG69qYEhxnpzTSPnX096DnA zSj86BD8gEUmMnuMUFFYZzSj3PtQJgccfzoIGcnn0xS8fh3pOOcZBxTAM78DBxUnOMEVECw6U/Oe tMQoO08ilLgNxTCT0PfvRgtwDj3oAk3HBNGN3NM5BxyalA4GDxTEIB1zyPWhTtHUfSlzxjA5pgX5 +tAEmVU7h+tKfm7jPoajfPbGKdt44IOKAJNvy/ypuAG4zTg5K4PT2ppO3BU0AD5VwQOKcH7nGPam GXIxzmkByMUAPJHBNN5ZsLTRu6DP408Z3DjimJjx90ZBz70px64P86Y3L9CaRvXOaAHbRuye1N43 +31o4IIGaEVeh/nQBKNoGcY9qaRk8cUjDbjaMetMU/Mc5GPypgSKecEDNGCNxKnHsKC2SCuM45FG 8uPvYoENboOfzpcA+n4UDbkAkGnnA44GaYDUUqMZpd21hjrTxhOmPbFBOeSB7UgANnPY+tNYFsMG HoacrsARjr6UjDDgFuD6UxCHcWBPpT0AOWB49KZnYfb1pVYYGaAAuC+cY7fWgZJPFIQTkjHNKC2A O9ADg3y84PsaFXnOBx7Uq4deRg/SgKwJ/qaAEO7OMdacg564HpSAlgeeaACSAxPFMQ8g7Tn/APVS de4wB2pGIU4yTjvSYPQEY6k0ASBvU8UjYY/dwfXFMbaFBBOadvDrx1HWgBCOME0gxxil7DJH40jb gM9BnrRcBW69PxoUbeVGSaapO7jnFBZhjANAhMYY5zyelBWMA4HWkzkkZOcd+9OHucfhQAwHYe+P 5UZAOTnB6Zp4C9xknvSkLnk8UARlecqSDSgMwPt1oJUcj8qUtgDHX2piGsvBIHIpuGZVzxxxS5c5 UDApOAQAw49aAEy2QM9qblhjpjvSsWJJHIHcdqbuDDBPTrkUwHgL/wDqoU9R07ZpMYHHekI2kZ4P pTENKFG9M96TB3YYcetSqcjcTgU1sgEgZoAZt252n3xQQDz3pQSy5FM3HuKAGsfmwR+XemY3PuIq XeScjk+lNfg7u5oAX5ccj9aRiMYxgUi9OFGP5UE56cUwEOWABOfQmkJwKNpXHX607A/iOQaBCAnt 064pqks4OMCnhSDgY60g4/hP09KAFcYOVNIpz1PNPJG045NRk59iO9MQnOT6UFgMAjANL0Jz09qa TlSM5HoaBgxzjB6+tIOuOtNwAOTSghjxxQASMMDBwf1pCCcEdaUqM8ck0E5GRjFADfvDJ69KVMdM fjTm27cjmmZOewoAMHOA3X1pQCjfNx9O9IBznjnvTjhSN3OaAsNkORwaaqjuTmnlQRlc57U1QFOW NIYg4OAc0qN1JzThhhTcEEgHigAG5ScdKR2btUijHfGaZgZ+Y59MUANABOT1oHJI6UcDPbFKj4PS kA7JQY601iCpB70NhieopjDCk8igYoORjOQBik659R+tIGIXrzQDk0gFBI69RTmI2/WkzxyOO5pp I6Dn0oAaSRRkgYPSkBwafjcAPSkMbgg8Hilx6mg+g/WkHfLc0gAqex4pGO3kenNKG4PSmMAwxk4o GLwwHPvQTjpTQvvgU7HPNIBWAcY6VEcDgnJp5O09c02Ttk5JoAbnnkcUKeO2aCOOKVQMZxz70DEL MO2acudw45zSbu1IpwRwc0gJTyevOBTwOhxTNvIz6CpANvIPFYHQKcYz+lKCOM0gOaFHzH0oAlyM ZApuSeM8Un3elCMMYPWmIeFXig9SKacdjQEzzmgAOQO1KCe4zQPTH40mT3/CmA9xkZFKpO0HBFIo z64p3TA7UADMTgYx9KeF2xmmHJGMfjSqTtIbpQICBjPINKuCOtMb0FKMjrwfWmAuc8LzSoMHB5pF znGOakAwOTzQIYwyeO3apFHyA4qNs54qVeRjpTEJnjnIpRjsfzppyOMZFKBvOAaAFzubtxUhYAYF QgMnGc+tOXGOTTAcpPTGT60ikhj6e4peh4NIeQD70ALvyeO1P3DuPypmMjLYA7EUqHghTz2oELnn IzQ2TTPmB60EluuB/WgByDcSQPrTiAAOTn0pEPoCR9aVgTxxTAUsFwCMH3peTnP6UmFA5BHsaQkc HOKBMeWxx6fpTWbbgqOPalBOf7wp2UYbgenYUANOccpj3oQ7eTg0jSrnbnNLgFcKOtMCRSrntjPe mMnXDUBSgzuBNAYh8jn60AOCAAHOG9aaBzktmjdnr+lKTuXaB09KQBgbvTvTs4/h49TUYTIHAPvU wwBz0NMQhAJxg59RQF+XuPWlJbb8oyKaqsTx3PU0wBSd2ATS84GQM+tO24HOKAODigBqjnpk0h4b GafkrkHB+lKoGOnPvQIZkZwKcrYIzSMCB1x6UqnPvjqTQAoBU7iRz2pzZK5HApmSc4H407Hy5JJ9 /SmITGOeD9aXOe+DTXAHRsKf0oCg8dR6mgBrDL/eHFPU5X0HrTWQcDPPakQgMc849aAHYHpn2pp4 +8Dmn7hjOMUjAgqT3/SkA0+uMUrAEZJyKVgrMCy8g9qVUDHg/hQBGoycjgflTu/Tjuc0pXBA757U MACcnPtTARgR0FAcjuKXqvP8qMAYoEAOeM96TA3fNTyMLj8zTAD0PzUAKHB4PTtTW4OQM+9Ljrxx TdvOCOKYDWUN/EQRyMd6Yy/PnAFStHsHXBpGQkZJ5PSgBq8DI/KkGMnAyaeoI+8M/WlU8jHUegpi GcY4bnuMUx+MHJHalcDzMjrQeud2KYDjyOD0qLOO/Sn7cfNnORxTCPc++aBDQxByB9aafvEE4Bp+ 0ITyR7etJt3Z4waAGBeTyc04gg/409FC9OveiTG0mgCFDlzx9eaU8H2pBycAfhTwmRk4pgNA9ScZ 45pGyvQkg9qeBhtoGPc80EDGc/nQIjDdTye1SZG4cnpTWVufX1HekO7GefrQA7OOSBmkYr7DPpTV G4EknNN3A9W5HencAY8ELzTQOOQfwp5JIAIGB+dIpw2TyKAGZzgUEryOaXawbkUj4UfL64oAUP0B wB60meTjP4UDC8g/nTGlSNSXkRB6ucUWEPKg9W59qTcfu5GBWNe+KtKs8iW8ViO0fJrnL74i26ZF pbFj/ec0NorlZ3bOFPOOfSmSSog3F1Qf7RAryW88b6vd5CSCFT2QYrFn1C8uWzLcyNn/AGqhzRSj 3PdRdRyAbJFfB/hYGlO0qD3+teCxXt1bOHhuJFYdw1dt4X8c3Mt1FY6jiRHOFl7qfehSXUTVj0YH C5OKTdhsYz3pjElAeMU/gjriqJHZ3j8KYzDgAdKaDjp1707BIGBg0DG43A8ZIpd3y4H50q/KDnHP amBAr9aQxSzEZpOeD1FKQVbA70mSoOMcUABTikOQMCl5xkUbi3JFIBpJIwaAeOKVx8ufShV4yTk0 hjG47mlGdtBB3Zz+BpScHk0XAYQcjPWjAHU4pxjBOSx+tBBUAE596Qxg5kx3qQgAdOaYx446imhy SDmgAJOd2Kduz1pCAx5OBTeN3GcUhg2MZJ5pKU47DNNPXP8AKgQ7IHPegN2xTSCcClx8vvQMYeuR UgPzAAUxRnoOadjBHbmgBxyT+Ap6e9OK4/IUIgyTXOdA7GORzTgM8mmngADrTs+/WgBNxDHvTtpC k0HG33zQDxg0xCfwZoRjjHSnY+XFNVTzmgB4wBxSrjcMikzjjvTh05xxQA5eScUxy1AbAJ5FOyDg kjBpiEVqVioPAphPIGevpSkHHzZ4oAd3HGM+tKeTTOVGQOalVgRk0xMM468U4NkZppJPBwaCPlOP woAU8tzx3pVKk54zSKeMHrQykA44pgPYgihTg+melNQfLxSrjPuKBCn5j3FGABg5470uQ3UYpqkk 4PQUwHL0OOcetICcnAFKMjOOppnzZyAc/SgQ8jjkcilBx04PtSFgSMZ3elO/h5xQA5Y++c+1IRvX PHWljLHPoKM4fBGR7UwG5A4AxRuyOTzStyRx9c0EADGCPegVxBubg9qCMEDPNKzjGB3qIEB8DtVJ CbJ8gDA6+1NHC7sde1M8w5x2p4bjjrQK4vynJIwfegB+meO1NXljkGn+5zgUhgRtcZNO+UEkEmgN uGQOtIDgYGFFAw+9zjrTioIwvBNKuAQNv407dlunAoAQLgAEc/0oVQDjJ9qczEdutISAfc0CFIIb 5cnilDcA4pofr70AnAz1oAkI7kdaZyegAHsacCWxuwOOKFfAA6imAnVT04oX0LH8KXI/H0o2kdMC gQPk/QUuOnAwaTaSvXJpF3DIzx70ASMGZcDAFMwwXpShmAyxOfSgA8gnn0oAZtyORwe1AbHGMelO zzlucGlwpP8AnNAC8FRzz3pjKTyTwPalIx0yacOBgD8zQIYA20nFN3BmySRipD0x37imj5Tyoz6i mAD/AHetDnA4/WlDDOCTmmnlgOoNAC8gA4AHrQcZ4NOHHBximquDu/SgBGOPmU8+9OXJ5I60SDuR 1pAx2jPWgQpPO0cmhRuB7kUpXnp1FJgqBTAbgmT5jmlf659qcp564ppGec/hQAzuAVGfWlOTyaUd QOCaTq2CKYBvwMdeKbuQggDB9aGXaD3OO1IN6gblHtQAx1OeTQFK4wM+9KZPrkdsdaRnJHQ0CFJB I6celR5xnBpdoABz9aOd3HamApBI7E0iqBnnn0phZj070444JH45oAMlXyBQzjBz1+lNUggdfxpS B0BoAaSdoGQfrQWG3jk0mDxnH4CgnPqPU0CADHPenAjvnmk3gKO/pim7yw296dhXJCuB8vNNwe3H vUe4jJyfrjioJ76CFN0lxFGOvLgZoGTjgE9s0cDOOe9Yd54t0a2A33gcjqEFYV18R7KIsLa2eT0L Gi6Q+Vs7gsCCeKiMi7P7oHXdwK8uu/iDqc2Vt0SFfYc1hXWuanekma7kOfek5pD5T2C517TLIMZ7 yMEdlOTXO3vxF0+DcLaFpm9WOBXmTs0jbncsfc03Az0qefsPlR1d98QNTutwgVIFPTaK5651TULw kz3MjZ681V5FAXJpXbHoNIycsSTS8DoKdtxSqoIbPWlYVxmKcqnrSggdKUtzRYVxuwGui8LeHZ9Q v1kaNhbq2WfHH0HvVLQtFn1u/SGMFYgcvIRwo/xr1uzs47C1jt4BtjTgY60JXE30LSnCBcdKdnnp zScg54x60vUYzWghNoA3cn6U4vxwKRW+U4GKQnOcdKBig8ZpO2SKXA2+tJgKMgE+tIA3YPXgUnPP P4UDGOOaaxP0oGKQ3BNBPI5pfvcZpnA44pAPLgDHemkjt0pGByMUn3TtoAcQDjB5puD3pcgHiggk ckUhiYGMA/8A1qDtxjNID7007SeCaAA4HSmhhnoKewXGM03YByKAAg5zxSbSoznpS8jHagkM2KQC ckcGmjNOJ29KaWyaBinPcCkJ49TSezcUY44P40APXpnikYgkDNJnBHH/ANejneOAATQBO3BHPYUo J5wRTSeeeeBQuM4rA3AHJznkU8ZPNIFyeuKd0NADsnFJuBzjikY8YFIBzwKAHLzjvT1wc56im5yc rwR1FBbk9RkUAPLD8aFIzyaZtyMqPzp+MDkUxDyc8daQ7ehHSkDgYFKPXpmgBBnbjtTwu49eKGx5 eT1oVgAOxoEKy4FNX6gUrMDmgbduBTQCfdOTUikYAFNK4IIAxSH6j8KYE2QRzSZDdf50xWIU5oBy eetAhxwBj1o6HPWheeo49KkAXII4z60wGbjg0oTCjFKQpHvQMgcUAIWPHFNJbk9vQUZwCSa878T+ Mrj7RJYaa5jRDtkl7sfb2oEd3carYWX/AB8XcMR9Gbmq6+JtFlO1dQiz75FePqTK++Rmd89znNT/ ANn3LDzUXC4yFok1HdjWq0R7Tb3Ec6hoZUkQ91bNTAdxya8WsNXvtIuFmtpWTB+ZM8fiK9a0nUU1 TT47lcBmHzKOxp2Fpa6L5bI5B+opjMCMcikPfIP51Ex5xjA/lTSJbEJboGx+NCsVzuNY914g02zc iS4DMOCsY3EVmy+NLZciK2lb3ZgKvQnU6zcWGCRTweK4xfG0YHNk2fUSf/Wq9beMtPk4miliPrww FPQLM6odODg0ikr94gk9DVG11G2vI91rOkox0B+YfhVhZQQRS5QbsTk0b+g65qDOCMnil3Anrj6U +UXMXBLgDpke1IDl8kn3qujDIPIWpUbk9qTiO5PkEcjNNOeAR+NCEY+7+Oak4KipsMbuH8IwenWm jO+lHyn29acMn6etADyuefu1GB+8AOPpmnM2T149qTAGMDNADgpJGOlAGeM8ihWwSpOB60i9z2zj igBwGw5JzSYLDdjFJ0JIOfrUgO9fb2NADRjIOCaJBgDB+tKSsfvSHGOOeaYhWQFB60zGMdeaezAc 4J7U1nHAxj6CgA3svFP+8ASMe1NV1I5H5U3k9c/Wiwhx4Y4PPf2pBhh3oBHQ8mm7mRjg07AOBCtn seOaW4U+SXT5QOc460wN84wOaVySAMg+uKLBcghnWcAhwCBlhnkU9LhpZCsajA/jPSgOVJKgZPfv SKFQkhcEmizC6JGbk7iOKQctjnH1pCwByWTjvmoHnhjOTcRf99inYC3ggjnigvjGec1SOo2S8NeW 4+sgqvJremo2TqEGB230WDU1CMjjPFJyTleBWQ3iTSUXnUYCfQE1CfFeirk/2hHn+6AaNBWZuq67 uVOaRpAxwM1zj+MdDz8179CFqJvG+hDn7S+fUL/9enoFn2OmBBYbugpu4k5UfKPWuWbx9ogA/eSk 98AVWb4h6UilUWUjPTpSuh2Z2JOCOfyphbBJx9R61xEnxIsRylpI31P/ANaqsnxLjBJSyyMdyad0 HKzvsgkgflUgwAT3rzJ/iZcD/V2kQ+oqtL8StUfhI4V/4AKOZBys9QeQA8UrEt8oU+pryCTx9rcm P34UDptAFUpvFutTk7r2X/vo0uZBy+Z7QzFACWC49TUMmoWsf+suoF+rivEZNW1CYnfcyHP+1Vdp ppPvSsfq1HOCij2ifxJpEAJa/jz6KDWbN490aD7pkl9QBXkuM9WzRgD1pc7Hyo9EufiRbji2sc+h ZjWRc/EPU5RiKOOP0wK5PHHC0gBpc0g0RrXXirWbsESXkm30BrJlubmYkyTu31NGxj1HFMxzwKLM fMN+pzR36U7aO9O2ZNHKK4ztilxU3lKqkueBzTI3idwpDKD/ABGjlFcbtoxxUssZjOAcioxTtYBO B60EccUd6Cc0AICaVPvc9KMHvxUkcEkrBEUlicDjJP0HU0gIG4NbOgeHbrW7kKMRwA/PI3Qf/Xre 0LwNJKVn1LMSdRH/ABH6+ld/bWsVvCIYYljjQYAUdKFFsly7EGm6bb6VZrbW0YCjqT1Y+pq4xHXt 7UbcHnNCjI6Vpay0Eh+OPl4/GkOcEdaB7j8qbnjHIx2pFASTz39qXHA4570AADn86Q+oJzSAkAHX 9KRmG7B60hY44/OoyDnJ5zQMCMHI5zSMcAk9hk0uPTrSjlsdMUAIGBGOtAGG70rIAw4oPT3pAI3X rx7UmctnPHvTVwxpR15/CgBRyTjg0gyTgc0mR0pHO3BWkMUkgYGKac44pQwAz3NAPOc0AJyRyRTQ xpeNwJo6kY6UAKpPrx70nQ8nNHUcUgHtyKAALk8g0jZB6ClGWGT0oORwaQxoIBww60EYHNIeRz0F JkEY6mgBu6pkzgZwKixgcZxTkI3CgCZg34YFA4HyjOakc8j6D+VMUqDmsDck6Y3U0ctQSCKTgCgB SKcp+UUgPy8c0oB60ABcFge4pwbJPGePyppGTwaMkMM0wJRwp5poG49eKTrTgvIxQIdtweadjAJx j0pDnAFKG9TxQAhBP3qk25XHtTAADkmngjtTAjVNuQelSKowaRgCMZpcfLjuO9AgPyCk5OfSjAC8 tzSZ+WmA/qMAY96AQPrTN3OB+JpwIYY/WgQ7q3BwfSlJOTupox+IozknFMBwAJ3dD7UhbJwM0ueA RRlScEUCEcbYy2OQM14JM5a6kkzyzsfzNe6ag/lafcHPSNj+hrwplxyOacdyJGrpUYeZCR6mu50z QBdx+bM5VT0VetefWtxJC6mPP3cV0CeKNThVUW5YKBheBWM6XNPmlqjohP3LJmJrqCDVrmFeVVyo z14ro/BOoMs0cRkIXoRmuV1Odrm5eZzudiWY+pqtbXk1uQYpCmDyR6Vu46WRjGVnqe16nrVlplq8 lzMu4DiMHLN9BXnup+Jb3VXYBzDBniNDjI9z3rAMjynzHYsx7nmnp9KtR7kOXYmzTgTj1FIOBjt1 NI7iIKNu52OFX1p6IW44DinbT171ftdIllxLcmQJj7sZAx+dVGSWObyp1I4/dvjAYD+tJSvoNxst xYpZInDozI46MpwRXU6R4pdCsWofvFPAmUfMPr61yxGRx1FPQYGarYVz1MOsgR0YNGwyGHORSqh3 bs1w+j6zLp/ySHfbE5IP8HuK7aKVJoUlhYOjjcrDkEVRLJgwwc55PHFOV8cbjmotpxk04DnOc0WF ctKxbjnHapuSM9MdqrRswPLipVYE8nmoaLTJB6ntTgcik2seRg0DKg569hUDAA9cfgKc5AUADH86 QfMOOPrRwMcgkUwF2kpkcg0Fcjjj2pd3HXFRMSPp7U7CJlbAxkgUzzcSHgZ+lAwFPJx6mqVzqVja Zae6gT6uKBl/IPXrn1oDfKw4yK5S88d6FaA4uDK47ItYl18UoFBFnYFv9qRqV0PlZ6EZG3EDjNAb K4PBPevJZ/H/AIgvAfs8ccCHoVAH61SuG8VXozNcSbSM58zipc0h8h6+99bQEiW7hjH+24qhP4s0 aDIl1OEkf3cmvHzpdxLkzXkkjA4KxozHP44z+FVVtrITBGNzIc4xgJz+PSl7Tsh+zXU9Ym+Inh6A nbJNMf8AZTFZtx8UrAZ8nT5X54LNXFT2+n2QwdOVpM42td7yPqFGP1pqX8SLiLR7EHGAXQuf1NLn qPaJXJDqzpZfipcsMW9hAn1JJqm3xA8SXBxbxY9PLhJ/pWUNW1JSTClvCP8AplboP6VA2pas5+a+ uB9HI/lR+9fQP3S6my2u+NbgcJegf7m3+dV5D4rlTfNM8a5/5aXKKfyzWQwvJiN80jk/3mJpospW GRzRyVX1QvaU0W5TqXPnajD/AOBGf5VUdpeM3iH/AHSxqRbLC7mYZ9KPsR64+h9atU5dWS6kehWL Nz++3fhTC7Z+/wD+O1cSwd3CryzHAAqWXTjbSyQy/LJGcMOuDT5GTzmdk/3jjp0qPk+tdFb6RDJa pKyXUxdiNkCg4xjqcH1qpqOnR2l48KOWVccnqMjODjuOlCgHMY+PrSbfrV82uBncKmsbRJL6FXPy 7wW47Dk0+Ri5iglpNJcCBY280ttCng59KdHZyyicgYMKF2B68dvr1/Kugk+yzzR3kcjtNA4Mu8Bd 654Iweo6flQLuzW5TcTuMpWeQDiRACobHrg80uUdzIXS903lL5xP9/y8IvGck+lZ/l89K17u4aZY lWSQqkSoQW4JHGR+GKp7QKFHuFykYyKbtP41dcDHAqEoB9afKTcgwelG2pcY5I4oxzT5QuRhTT9o FKTg47UDO3INFguN20EdKM8UAcc0hijjjHFO79KbkZpwPFMLiFjg81CVqbnHSkZDjJ4oERDpnvSq TuFOEfvn6VLHiElivHq3FIY4rvHzDI7ioHhDSNsG1CflBOSB6VMboOcAj/gILGrVro2qXpzb6bcu Ou5htFAvUrSqAgBOOO9QpGzZIBI+ldVa+BNWuCDPNb2w+m9q3rP4dacihr66uLo913bVp2bFzJHm j7FOC6g+xyf0q7ZaPqGosBaWM8oP8RGxR+Jr1y00DRrJB9m0+BCBjcV3H8zV4AHjH6cU+UXMzg9O +Hsxw+oXaR8f6uAZP4sa62w0Ow0jaLW2VWOMyN8zn8TV/bk9aeOFzupqKF6iEbeRzSKTk44NISQw zyPypzY3CmFgy5HzDANNIYk4GRTmf5cdqbjtSKQ4HKZ5yO1J19vWkwemD9acemMEe9IY1unTik/Q U7OQBt59aQ8HGKAGkbejZFBPycHNJuDcU8BeopDGfjiggnqaccFfQ0ADGM0AN3Et7UjEAA559KHP OCRTicpgAfWgCPJB9KCN2MCnFce9IDgcd6VgBQB6cd6Rzmkzk5I/GlJ9BQMaF+YDORTcHNL0PIpc YHFIBB/tCnoRkjtURyO9PU+n50AKeGFBBC5xyaa5yaTf25NACKSBjpSsuDzzSE5PNKWyM9qAGgg5 UZ/Go8EN6ClPWlbO0UgDJIpAcMBnqaQegp3GRz0NAyfcensKApyDzxRz29BRnjFYG47PPNN+81Ck lsVJuBJB60AIoxkjjFLnuKjyR34qVRu6daADaSN3alUAj1pfakzg+9MBcYXAGaVck0M+OgpFJ+9n FAh56nJ59KVQQDx9aFIPWlZsDCmgBpOTinIrKOO9J8pHTml3dB1IpgP3dRTQxFJgkY79acqkAc/p QAJyx3Hk9KcU+U4/I0hByM4pefqKYgA29Mc0MR1xn6UbGOece1IoI60APGMc9aTbj8adhttICQev H1oENUknB4qQDb6U1SORilGFHTNMDL8RyiLQL9jjiBhkfSvILRVwd4yMV6r4wk8vwxf4/ijx9ORX llsNsW4EEnqPSnEhlkJGVOFC4P3j3pzJuG3FMjfnOMgdqv2kJu7gYXr2Fa2uRcw7xGjk2+2apKc7 hjnFbmtReVql3ER/qtqdOhAGawyNsnXvSYomhb/NCmRzirzJEuzyznKjJPY96oWRzGQT904q4vBx 0q9wJQoIqbTrUXWtxxng+WSM+oqlNI/yhe3U0kd3cRzI8B23CHKOOx9/Wsp3a0NIWTTZ6FFZLchI bREnkcjGx8n6Yql8StCvNAl0GN1VDclnI9GUDI/WuMh1TVbfVmvrYQwu5yRESq578Vvatr2o+ILi C51e+FzLDGUiAGAgPX/9dNXaCSjumZxGCPX61J8pXj/9dRsQ3IxUYL+YCpwBzx3q2Zkk04ihYL8z P8oHvXV+Dr3NvJaySqF4MSA/XOK425icRpNtO0SqGK8Yyas2svkHERZdjkqe/wCdC3Bo9V56dc0h bnbgLWBo+vi7xBdMFl6LIejfX3reBIPT86sholUAjvVhAD3xiqu/uM1IpbqTwKTVxp2LSY+7n8qc eBjPFRiRcg45pdxZuuaixaY9MYOSTWZqeu6ZpJAvbuOFmG5Y8ZJH0q+7hI2csFUcsScAD61434yv V1vxA89riSCKMRK4/ixnJ/M1Lv0GvM7O8+JekQ5FvHPOw9toNc/e/E7UJSRZ20UA7EjJFclHpkjk bvlH0q1Hpka9QWP1xRyyYOcUOvPFOuahkT38mD2U4FZ2ye5b5mlkP4mtZLQI3yxqPwqcQTBfkBz7 U1T8xOqZKaReuNy2cpHXOKvWWiThZrq4gbyYFB2kY3MTgD/PpWhbrqUQ3JGXGOcMBj8629KvJbqy urJkInOHRT1YryQPfBP5VXs4onnbKGm+FpdQS4Mnz3kcH2hY3XKBeoGM9SP5itDT9NvEtVuLeOOd 2XJmTbGlufRu/wCfBrodFkjm1GO/UbwYRHNGqksrAYBwOoIHbpVGPQp2eUSqbW13fNJL8oIz2B5Y +lLkQ+dlW70pgJtUuVie6tIgUSN8x5OCHHrw2fqK5OCwWSbe4Lljk5r0LUpUFncNHlBOBDHGy4O0 YGfyUfnXPR27EnABI7+taU46ETZJc6bC2nTsbeOMuFKlVIwARwcAAnn9axksgFPygeldH9oVbYxb GJK47Y/lVEIQeg9qcVYUmUINPkuHKIB688Y9yaVdEc3DxyyQxqib2dmyAvHTHXrWtZITKVPl/MCA ZDgZ96knJgjjyIC7giVEG4be2ccZ+lD7IEYT6bBBIhlmLwOpZWhGM84xz05qSawiVYTbxyZlJUJK cntgg8cc1otc23nWyyKZI4Sx2qoA56AD/GoLqaF5fMiW4Mmc73bOPwA4paj0Fks4LeexmS3cpE/l zELkuwPXn1zx9KqXMIu43ma4uS0ThGMi5ABP6H2q1/plyg4ZlVsh2OMH6morqa4kJinkYgHn5sjP r70KIXRQuLaCDb9luZJW7lk24+nJqaeSD7Ys728VyHgTIcnAYDBzg+1Sw2aTRyMfOOCAFiTJ5z/h U39mRxsfOMqKYd4LgAqc45FDsCM57jNvJFGPK3S7wsZwoGMEY/KqMihm6jJFbcVkkW1biJW2zryD kOCDjn0yKqy3FxdGaBlRgoLMu0DZj09KNL6D1ZkmI9CQKRkUDKkqR79alCZ780jRgY56j0p2FcgR QTyOKayqKn8v5cg5HvTNhPekCZCUz0GBTCvWrQQ/4UhgYgnbSG2VCoz6U0oCDxzV5bJ5OFUk9MKM 1Z/si5KB3i8tQOrYXP50m0twMNlI4IpuM9BWpPaW8eBLe2yfSTcfyFQFrNGHlSSzf7sWP51PMirM piJmOAD06UCNvQ1qxx3FztFppU7kdSxJz+Qq5D4Y1+5OVsUhH+32/M0XuLY57yWJ6U/7O2cEH8q7 CH4f6rJgz38MQ9EPP6CtGD4b2XDXV5PL64UD+ZNFmHMjzwpGh+Z1z6FqVXjzgB2OeAqmvVrbwTod ucC1Mh9Xcn9BWpBpGnWYHk2kCe6oM0+Vi5jx2G0vrg4t9Pnf/gJ/wrTh8HeILkgm0igB7yMM/rXr bn93hQQvtTFxjJ6dqaiK7PP7X4b3bjN5qG1c4Kxrn/Cta18AaHbcyiW4b1dsfoK6snIPXApgHOeK dkg1Kdro+m2XFvZwR+4QZ/OrnIAGcjtzTz8xA96ZKNuAp47+1AWGcZpyt27UucDlc/hTdpOe1ACd yOvcU5Tk7MY78UoXBPPPamYPJOfY0DJNuPw9aYTvG0cY7U52yMcjFNUd8igAx8vvQRyAMZ96fn5e MUxxuOR+lADAWJ/pT8hQMg5+lICVyccU45IzwfapKG9ckHilOSRu6UmCCQCBTjnb6Y60AJkgZXj3 poOetKCcYOKCDwBSACRgjAphY8jtSgckd6Ru+BQNB2JPIpc4yO3rTVYFeeaRsdj+NABkEkHFNbgY FABJ5PNKRzwODQA1WOBmlLZI9KTaVOc8U5cjrxSGHUjHHrmhlxyKUkY60hOBj0oAiz14pctjtQx3 EcUE84zQAgJ7il3enApMHOCeKaT2/KkAN97pxTs55xikJB60m8DigBMbieeaBkcE8UZxSdeelAC4 B5HFNPQgUoB55paAGKdpwaF5frxSMxJoVSXFIZMzH8gKenQZpQdxxjsKaWwSKwNyTORn8qQYP3ul NH1NPA+XBH40CDaM8HIpwGOVpoXAwafkgAYpgNzjk1IAGUGmZ3deKcPlI9KAALyeKfjK4NNb5TvG fpShtyccGgBSABgHNKODkUzBAHNO27Tzn1pgSHaeuAfam4A5HSkA3Ec08rQAncU5WGcZpm0+9OBx xgHjvQIcT1HWkGQOOlCliM44pCcnimA7qacFPTIpobC05cfe70AOzjjPNIOByvHrSYz3p+crj86Y hNowMcimsrAbvSnZI7fLSs2R7etAjk/Hh/4plwWAzIvGcZ9q8uimMThh2r0X4jyEaTbLnhp84P0N ebFW38ZxTiiL2ZvxS2piWV1bkdAOtWf7WuLWEmzijtwP+WjcvVKzBNpFyRx3pbzcLVgSMYx0rRXQ nYr3EvnxvNIxaZyWkdj96sliGO4dKnuJQ1uAMAA1SgYMxVumM5oYjQsc+btGfnHHvWgQVbHfpWXa SkMnJwrcfjWo7AKzHPPerjsJlfcGm2F+CefapkUZAxVSFkSYsea1kjW4dtuSG5VQOScdP51Ba2IS DI2EAOBzQkQD8k9ODU0jRNDEyDBVSG496QZkTqPlHTPagQ0SBQflwM44/nU1uNkZ568gGoRGxXdt K9sn3qxFjzQMAY59qYEF+hea1jVd2ZAccc+tLGCrPkfxnBz2qSa4FvfQE8tlguRxkgjkHqKmkRRL tGCu0YwcimiWCMQeOK6fR9dwBb3bZXosndfrXNdBxTt2xc1SEelK425QggjgjvUivkAGuL0zWZbJ QjfPEf4GPT6V0lrqtpcqAsmxz/C/H61QmjRJA4qvealbabbfaLyYRx9AO7H0A71j614otdIXyYwL q+fiOBDnHu2KzLXQr24ZdU8Q3AjkcZjiHzOB2AXoo/WpfZAlbVlDWdV1bxHIbeGGaKwHPlJ1YerV Vg0zZgYTPTGK6eJ2K/ZbcbEdgTjv9T6VXvbXyZMxFXHcr3pxSCUmzJOmkrncB+FB0+IBTvLDuOlX Sru2VHTtStGzqpZSoPQ1RBR8uBGOBzTtvQY2/Xinm2V3YFiO+RSeQqHGcj1Ip6CIig7sDn0Oalhi P2lZYSqbcEFW5BpyhpCI0QKD0NP2Kq5JIbPUUrDNXzbadvNubfM/eWFthb6jkE++KnFxZRbWitGk mzgefKXA98DFZMbNvHOf61K0oQjABJHHaiwXYt7O0jtd39wiJ2YnAx9Kzo9Z0tmIF2yjdgMVIU/j WDqtxd6vqZtQcxxNtEa92Hc09/Dl6lm85RSqruK55xUub+yVyq3vHWI0MsYkgkSVDyCO/wCNJGiu Dx16Y7VyXhy7ls9VSzZmEU2dqnoGxXdpGruWiUkfyq4vmRElylRrRoyBIhBxnB64qaeC1S2Vkhk3 SA4ZpPukH0A5/wDr1OYsgnqe+etRn5oxE/AUkg59ev8AKm0JMrLZ2wt5bqMMzcIEYZCOQec/QHFS FFgW2Z7qcLsBMUa8Ht1z7HtUkQKwOhbCOcnPqOlMeCV1ACEjBx7VPK2VdIYIBcWyf6PLOVZgAhIK g4IrMvrfypmzGE77Q2QK2I9J1CVcRW0xB68GlPhXVmIL2rRr3Z+AB75pqLE5qxhW0iKkqNK0aso+ ZBk5B+opst1HEY1hLyAK4Jk77hjgDpWw3hvarGa6gTnH+s3Z/Kq0mkWEKgzX6DB5OQB+pqWknqxx bexjfbJEgMHVCc9On0NRXF5czjazkg9c9/r61pyzaBCMNfhz6Rgv/Kqo1bS0GLe0vbh+3AQfrk1D nDoaJSM1IpMjCEmphbSs2CBu/ujkn8K1YV129X/QtBVQR9+QM/H44FX4fC3im7P+kX8Vkp6rFhTj 6KP60c76IVkt2YX9lSqm6RRGD0Mh2D9agZ9Nt8F76Jn/ALkKmQj8uK7CL4cWQkDX99PdP37fqc1t W3hPRbMAR2EbMO8nzH9aXvsLxR5wl/ZyHFvpt9dP7kRj8gCatw2HiG6ANtokFuh+60qFj+bGvTEt lhAWFUjA6BFC/wAqnZQFUEZzRyX3Yc3ZHni+E/Et0oW71cQIf4IyF/RRU0fw3tCN15ezzH+f5k13 AQE5z+FPI5welChFA5M5m08FaFbjizL/APXRv8MVqRaVp1tjybK3j9wgrQC54UZppXYucc1VkSMY sqqsMYOSAcnAC96QoOhGKdjLDkHijowUgfnTHYaI+Ov50MhUdTj0pQxySSaQuMZ7D2oAaeBuwcik ID4JGCfSpC42qe3rSZHPb3oGI2FGM5oUL3NISGPcmgDHsaBCyFcdgfXNRqwBwBn8Kc2eo603kjBP FIYvBOccCkZADwfpzTQQDgGng/NyMjFACZOOh4GajPOOKkyAuM0wsCMYxQAo+960F/k28mk3FSQO hoIO4EZzQAuRt9aYMnOBx3FLghs4FA6+9IBvOcVJu2rgn86QF8HGPelXqOPzoGNGM80pKZ29B3oY ANjpk96awCnHUjvSGLhc9aR2PXn/ABpMkDINKwPBJ4oAYDnJIIpzE56UgVT3OPShuOhNAB/D70oO RjFNJ4zQCwJxxSGKVwuQMk0xeeMc04s23pxQFPJNDAZwh5/Ckzz6+mKeyEDOeKjHyk0ASbcDNMZs HkYqRTu9hTJDkjvSAMZph4B9TShiBQx455PXNAwBwMdDTSCX9qBj0wDSMw7GkAjDB9TQuOuaMlOe 1NJByQT9KAFIXBNNx3zQB82DxSHg4AoAU9f8aaXz0HFKAc/0ppODigBwB655pM8YNDnJwKQFV64o ACMD1pV6jJ69qMgjI6ULkMOO/SkMnyAwA9qVjzgjHvSOcvx6ClXH+NYGwEZAwTTuQPWmq2T0pwz3 6UABzjn1qQHHao8/lTlYfjTAk5PXimPwaTO1s9qD8xyKAHknGaXOcEdfSmnoSCQBSx5HzGgCRl+U ZPNNIOAMmgvk8/gaeFGOaYCAkfhQclhQ5zwDQuMjNMCQsAD1/Go0wze9Ob5l60owR8tAhxGeB1FM IYZJpynAyetIcnJxigBQQ1L9047GmAYb604E9+SOlMQFtpxUiAHknmo9pbAJpwwDx0oAeWI6Ubdw z0pAQSOR+VO3qARxmgRwXxLkH2awi4OJGb9AK4CVhsBQ12nxHYHULKLI4iZuPqK4cEenFVEh7m/A u2GPthRUeoFPspD854H1qB5iGCySyByudka/dHv71FfSv5SRyfNzuVsdRVXEZzR+YuA3fFRyWv2W ULu3bhnpV21QSyDCk7TkcVLKgNxDvIX5sEn0p8pJRTgEd8cVrtmWDdn7y5NZBYJIcgGr9qweyZT1 XIpxB7DHjUv8hx2571ajEsLxttI3KSrZ4IBxVK3Xe5yTkDIHrWtDm8tljMiLJBzGpIwwJ5H17/nS LQjXEzMolUAHHbrSxpmRlHy5G0kVJMVWcxPtZoiBlD0x296WI/vcsoyTkDNADtu07AT8o9aEXdIe SFHJ+WnBMsz7hndt21IvHKnBqiGVp7b7RewxqjSlwwCBgO3cnoPer81vi3imRAgBKcNnp71Qulii KNIW2srAlc5wSM4pbFvOtS+Q20j5g/A9cCmgLXIA9aVOR70rIMcZ6d6VOMfSmkSJNOIQGbBzxgsF /U1ntfXOqzrBp7NDAq/PI56kjnFM1Z5sRQBcLPwXIB6HnHpV+BoLSyjjgDbmOMD9PxNK5S20NfS7 K00m2/chWum+/PJ976D0FWXeaSY7iXZj/Cc/rWHIlySB9ojL8fIyk/rn+lb2g38X2WRWh8u4iYq6 sRk47E/lVRaJd97l6OGVEVymwYwQahnmjVwpwQvTaOp9SKr6lrhbEatkjOOc4rJF8iEs27ce5FNr UlX6mzGU2kkZcngdhUCl2kYZBCnoKoDUYcglsc/hTo9RgMjsGAOevQVV0Kxe5BJ3AAdeetJIiiMg Y4qq+oQjo2c00alGFwp46Ug5WTuNqYUD1FOIdgd5xjpiqa3ivIqk7gTwDXVab4avdRthNLcWlhB1 33UoTj2HU0BZ9Dn0JWQdBii9Y7oyDwB6dK6wab4P01R/aXiUTPnJFnET+GTSS+JPhvaxPCun3V/j lfNkxk/hUuSRpGlN62OAs7H7FrMpuGVAx8xC3G8E849SK9Tux4aTwsJ4nlkvnj8vy9w25IwTjFcJ 4q8fW+taO2nJ4es4rWPDRttKumOAQx5zVCLwnrcdlHeQa3bJE6qUQStu+b0GMn61KuthtK3vCeHP Dl7r3jArZRhorRTLO2cAei/XNeiR+HmtwqXd/Z24xzunUkGuEHhrVLHR7qS11OcyGJpkiiXbuYck P6nGaqaV4S17WtOh1BryMQzjcpeXJI+gFVFuOjRElF63PRmh8LQJi88RQ7h2hQuazbjWPA1qxIkv rg7uBgKMVjW/w2ckfadTXHXEcZP6kitW2+H2lw8zTXEpHbIUfoM/rT5pk2gU5PH2hQMRZ6EJSOjS yM+PyxVKT4k6i2EtNNs4PQpCM/ma7G38IaFbjiwjd/WQlz+prSh062tsLBawxAdNsaj+QpXn3H7q 2R53/wAJR441NW8prna3G2NCufyGP1pi6H4yv+ZnZM85kkH9STXqBUs/qR6dqftVTwRu9KTi31Hz M83i+Huq3S/6bq5AI+6rMf5Yq7B8NNKi2meeec9+Av8AjXeHbjH8XvTOmA3SjkQc0jnLTwfoVt0s EcjvIxb/AOtW1DYWlsgWC2ii/wCuaBf5VJ5eJPTjipD0H94VSQhgjAHAH41XI+fPere4svvUb56+ nrTEQnOeRmmycHj9al/HGO/pTFBZi3GKTGRsmACaa4/drz3qZhnGTletN2hyN3SkMiAK4Hc9DTGP XjkHFTMNgwO3SmYz2zQAxDgYwaR256Z9qdkAY6UmNrc9/WkMQYC7l4z2pmCSGBG3rTmBBBzSkEDA wKAI2ABwOe9Hykj096UgEDJFNK49DQAEhSVOMGmnggD8OaXbk8nikIBfnOO2aAHK/GGUjPemnngc 807p06+1IQUbBHHrmgBACARTclsggZ9qc5yeCMZ5prkHoMEelADTwCDx3oHAB705dxGMD3ppyDjG R7UALtypJ57io8bsgjpTxnB4wKdxjOMfSkOxHjAHIqXGSDwDTHA2nikHyjqcUDHkAtyOabtJHynB NA+Y5yc0mCOV6fWkIXkdfzFNLFW47ilDZB9aQ8DcR81ACud3OOajHLcYBNKrE54z2xRtwMnqDQMc 20EAjn1pGBJ+8MU0njI5ozg4oAUYLEAAUjHnAwKQd+eKYcZ46Uhi9T70iggnPWgna3BpCQfXNADs /QUmCRnNNLYPrTg2AfegBNw+tBC7c5JpM4PTI9RSYzzk49KQCDBPU0uQF5PWmYPYZzTsY6igA54x RkbSKQuA2P0pOMe5oGNII4NOAHU0Z+TBxmhydooAQkEEdajzt6Dil/nSdsdaQDhz1HNID83ShST0 6il3f3qBAcZpoxk5pS2WpuBnHWgY1sZ5zSMozTiOvpTfu/1oAdwMUbskEcU3duXgUqDDcikMsbe4 PagZB5PFJhmP5U7bkdaxNgHBp+ePSoi2MD9aeOe9ADiM/WlIAGe9HXtSnp2NACAFupwaUnH1pOhB 6U4tjHegBwPy9PrSscYI6UzeS3Sngk8kUwAHpgU4ndjAxRlcUm7b0oAcBj3xRtGM5xScnoeKQYxk 0xEoC7cZ5pqjHTimqORnpT8DOaAF6LjrSA5GKRmPJ4pAO/NAD9+OD+dHA5FNyTzmjBJ60xEilce1 Kp5PFMzjr2pyNuyKBC5z82MUZO3JAo7beooX07UAcf46sLeewjuSMTo21W9j1H6V5sQFOAMMK9Q8 bFTYQKD1kz+Qrz+e084b0GGHX3q47GbWpGshkleeOSNd64dW7H2pt44dECdEHU9yaa1hcHaVQcHn B60ssFxtw0TADvVeomQRTGMHacE+lNMhYncc0iRN5yjBIJ5FWWtI5LuNPL4ILYz7U7MRnsNzD3rT iQQXEsWBzGrHHriqnlqt0EB+UNgcVoIwa8uW6DaOTQgvoM0uMfbAWVHSNWcq3TAGatQTiVWSREYN 0yMbcnqKhs0zI0rswVVY5A68cVcgSG4HnhsTZHAQY6elDLiV1/ct853lTjjoatp+8hLKpL4G0++a bcR7b/cRlCR15FXZEAlVY1AVhkAHt1pdAKwLRy4cLl+hXpmpcYNEi7grLg44H0o56ZqokMZOZA6s iSN5cDudr7QBnGT6/SpYLieeAyMgVGZVTG0A4Hb9KjmgE06lmzGkW54wxBYZNNtpjBJ9kSBisoHJ ycMO4PbqOKYtCywOOTn1p2dqHApgVsHdkngdMVKR8h4qhMydQiH7mdj91tpHXg96nWfAik2krG4Y qBk4wQcfTOammg88FcgK3BJHQVnzyXNkI0MLhk5Uj5WIxxWUrp3Li01qb0U0MkBJaAxfe80OKwJ/ EYiuLnyFUgyZVmz8wC7eR+Ga56d5JJWd12knJGMU1YmfBI5pOQJItvq105J80gk5JHGaZ/aV2RzM 5H1qSHT55CNkLMPpWjHprovz6WrHqSWbn9aT5uiKXK92ZI1C5/56NTv7RuMAeYRWu1moYFtEGPQS N/jSiygLZ/sM49BM3+NTzT/lZVo/zIyF1K5GAJDUi6vdr0f9K2xY2O3B8PTbs9RcPT4tHsbhtqaJ eKf9m6xj/voUuef8rHyx/mRk2urXjvy33SMKAMsewFdNY6L4g11BJ58iwn+IuVQ/Q4Jb68CsWz0l F8SpZOjwoZxFskOWGeuSPrXuFvAsKLHEoCKMKo7Ct6a5tzCcuXY4W1+GylN11qALdSI4s/qxP8q2 LTwNosC4K3EhxzvlwD+AxXUEHGMinLGA3PeteRGXNJmJceE9Ll0y4toLGBGliZA+wFgSOuetc94a 15P7Ag02+hUPZO0TMFG9WB9fT2r0IqqJxk/SvNPGelvo+s/2vCh+x3hCzgdEkH8X41LfK7ouOujN lptsxeC4YjqCP4hTPDeoQ6XO+mynybaWQtbOw+VWPVCew9K5/Tr9hIYN2Y3PBz0PrReq5kkikGez Kaq99QtbQ9UXKgDAB75FOA+YEV53pGu61pyrHtGo2a9IpH2yIPRW7/Q11el+KdL1OUQxTG3uv+fa 5ARwfbPB/CquieXqjdGOo+nBp+FOAQR71GzESDIG4dulSeYSMdfwpWFcQ46jj1pDGM5z16ZpyMWO OAB19qlU5XDAYzQMiRG4OBx+NK7Zbay4P0qdEAHVlHbI4/OmMCzf7PqelICuQuc5x6CmsCMrwanZ V25CUw49OnPNAEA3Fvu8Uvytx0x2NSDBbkcGkcDbgLgUAQFcDk8UwnbnCjnripCRxjpSABiBgY60 rDIyy4Jxg+1MZht759qlZACRkVEVwSQaBojC5UZ5owOh7VIXODgfXioW5APT1pALgcAUrKD36dqT YByCc4pQAvNAEXl57njoKa+4jAI96kYZ5FRHAyPWkMQDPAHNP6rhlzj1pADtJ25H1pmSc4B49TQA rLnoMfjSA4OcfnRu9Bik+YdDQMXD7s03Jc5btT1Ynr1prjGSKLgNBGNvSkVTu6ZFJnJz/Kn/ADAb uOKQDSw6Yx64pp4PAz9al5blePUU04Bx3oAacbQRnPehVPrjNIx4yPWk68jigYpJYkc8UmC3bFCg jORSg/NyaAEGACGFCgEcHj3NKXAYgYPvTSduDnIPPSgQp4fAPHYGkJOKQnnnkfyoAz34oGMJIbNO LEKOue9MOVPI4qUYIJB/OkA0EEGkOc+tIG64o3ZPIoAVmxnCjnjNRnAPAp3y+tJzmkMaQRk7eO1N 5ODmnkE9ScUm08kZNABtH40EEUDjGfwp23vmgCP+I0mc54z70Nwc8++KAcH2oAcFOKYzH7pp4YAU hGFzx+NIBhB7GlH3eaF6E4xTcHOM4FAwxtbNLu4pO+TTScjp+NACvjgio+ScgcU452jFAGR70gG8 nvzSHnv9acBjrSEdsUAGcdKbjHIp3IXg/nTe2SfwoAASRzSEE04Y4PWjOTweKAG9+OKBksD70ZAO O9Ko+YemaBljn9BRz+FNBORn0FKRk8VgbhjBxTwOKQDGCaOhoEPxxxRuPXNNzkf1p6lcc9qAGtyP enA4XJORTSeelSKAVP8AKgLAjDGaCw60mNowKT7xxjimBIgxnJ+lP2k4NMXtxTx7etADcbG9qViT SvkURtuGDQIEYAgHijeQSetBUbhzTio4JpgN4JAHWnBgvBOe1B6jBwKQgE0AOwD34pDgHAoxwe1A OMDGc0xDxsP5UmQOlIAC3Ap2OvagQ5Rnv1pGzuzySKAny5zSKXU8mgDkvGrZS1Xnqx/lXFDO4MM/ Suw8akm4tQSPuMf1rlolDybSuSeB7VpBaEPcfMFsmgW9kEJmUOgPJ2nv9KfdxmFSVdXRhlWU5BrH 8WCZ/E91kEohWJPQBVA/pWnYR48PuWJJDn8OKLu4dLmTGQXHNXI1Q3wUn7sZ5J5zioLdA0yBmA6n PToM1NbBmubh1jLsI+oH3emeK0WxmylAoa9Jb+Ek1ajCtLeEnC5AzUNlGJNRiV2wjtyR6VNAcvd4 GQZMYFIfQlkHliPyS210GSx79+lOtJBFcq2zIDjjPUd6aqFcA5H+8OlSbCCpAPXPy96GUh7sZbhp WG0sxOT3Ga0cJ5vyOWQAFTjB9/1rPMasu0gkDg1bt8KFdJPlHGCvIP40kMlA2bjyGbkAjpSEc5OK mmBdt+eOw9Pp6VFjBx+HSqRDIbmB5ZvM3qiJGqnnGep4q1bXLwRMiE75wA5AzkZ/+sKq3kTPNOyn MscKGMHoCTjkd63YPCGpyEG51mVQ3JW3jC0/Qm9igYySWEUgHXLLtH5mo5Lm1h/1txAoHUGUfyGa 308DadvzcyXNwP8AprMev4VqW3hrR7Qgw2FuuO+zJ/WnaRPMjiI7uGf5YFknbPAihY/qa0I9P1W6 2mLTbhgOAZpAgrvoYY4seWgA7ACpg+wZC5Hoe1Zvm7lq3Y8z1fwrqUmm3M9xBZwrChk+Viz8e5qv o+lWkVsk0yBiwzz2rs/G155Phe5CH5pSsf5nmuVtsx6YspzkL8oB7inGybBq6NCW9SztR5MEW3J5 bAx+NRFhNb+cHjMarlmDjGc9B6mrx8PWlpYrcXtys14T/qyMqvrjPA9KrSaMl3D9oso1S5HI2rhZ OPusB1z69q0aluReOxXUKSADnI4qSOIjAZQCOpplrLHOsFwoO0oDtP5cn26V0WhaDd65fLBaJ8g5 eRvuovqTTT0uJrWwmj6Nf6zIILOAuR94+n41N4tGn+ArEJLKt1rMo+SNRlYvc+p9K0vE/wAQbDwX YPovhpVkuV4mugM5bpge/vXmmm6ZqXinWTe3s7vIxzLK3Ijz2Hq1RKcm7I0VOMVeQnhTSr3VddW+ m3YjcO7novfGe7GvXFbgZPNVrDToNOtktraIJGnQZySfU+9WlCljkVcVZGcnzEig56dalj5x0OKV VLAY4FSKgBGPzoYIRBx3wCTVXULSPUbKW1nj3xSjaymrZ2tlQcY7etOUYHSkM8h1HQrvw1ebVR57 bOVUfeA9V9fp1rQSSLWLAT27pI6dXz8w9iOtel3VhDfQtFPGHRux6/UHtXAa54FvLSf7dpMkizKc l4vv/wDAl6N9RzU2cfQd09zKtJZbe43ByrDt2zW013o17bCPV9NaeQ9GjIAHuD1FYsGsyRMYde09 n2nBvLRclf8AeTt+VbtpBZX0Cvpl5a3iNnCRkLIv1Q9PwpqXYGupkjUNU0uYDSdUl8g9Le9Pmpj0 B6itzTPH62zBde0yW3H/AD3tx5sR+vcVi3kAhuhE0eMsQQeOfpURjlD+VGQA68Hv1ppseltT0NfE mjzafPf2+oQTW0cZkfY3zADttPOag0jxjoOrbRb3ypJnHlTfI368GvNLvSrD7SUuYXjfaXMkGAcd B7HJrIufD5b57K4WQHkK3yv+RocmCjA+hpPNZFbGE7DOR+FMKu6Y2sR6CvArHxP4k8PSiKK6mVF/ 5YzZK/ka7XSvi3BIFj1axaFh1ltzkfipoUkDpvoz0V4XC/dbg45pu1MfxD681S0/xBpWtIv2DUIZ uOE3bXH1Bq6w5xzntV2Id1oyN49nAOffNMJyMHg4qRiqg5Pzds1GM5wSMelSAhxuAwM460xyegIp zDkkc4qMyANnGM8UAMOWOeuOtBwpGBSrwTgjmmkcHHWkMY3I6d6aAACpHWpCCQaa3BJ6Y6UhkRyO MZAHel3BvoKcSCB/KmEYegdhm4Dgck0hAJwRzTioBpWU9V6Uh2EUbVx1FI4z06UobGFJ4+lNJboc YoAibaANuc96UPlQOc0oUHqOfrTWBGCPxxSAUk+1NOfpUu4Ec96YRk4ANAEeRn3p5VgAc8H3pSF2 jNM37SARwKAFcEA4qPO0c8/Wn7+D60w7e/zfSgY3eM8im4x9frTuN2SMrTQckkjA7YoAd5hPAWmn Jbpn1zTwp5YGmtgjsB7UgGjaDyOakyM5I4pp4jwtM3EnaAc+tAD2CnJ7U0cnC9KQqT1NNDAdDz60 APZeKYGIUjtUisOm7NMLY4GMUANAyPSkweeTg+tDHkLmkP3gKBigADpijnJ44pxX5ck8Up4X1PcU gEyO9N9uf8KCRuzmg4xgZzQAm3g56UcgDJ4pM7egoz6c0ANJbHA+tCjPXk0gzk4BpQSAaAEOccUn mHGKXcW4NNYjtQA4PtGKZkb+vFAyVyabnPX8hSAe7D/9dNB7Ucbee9IMYwPzoAQ5B46U9QMHOKYT nHNLknrQMGO7pUZJPFSkgA9qYTQA3rS/KDzijPHSmYyeRSAeCO1NLEGj0pcdATQA0hiQc07gnB60 Eeh4pqj5h70DLPf8BQPU0jnLDHoKQHPPauc2H57ZozkelNH3s04+3SmA4KKdtApoI6ZpMjdxQBKO MZp3AbpUZIJzmgHPJNADick4oGVHHPtSZyM0A96AQ/JbkinE8dPxpAwxTgcjimIQ+5qEySLKoCgo Tyan4IxxTPunIpNN7DTSeo8tj3pA25sE4FN3etPGAMiqEOJB4zSnGRk0o2leaa47nigBcjBB6UgO D7UgPHtR1XimIdkl+O9LjDelNXKsM4qTIBHpQKw4ElcAVEenOafn5jjpTXG0bs0AcP4vl2alEqqW HlevTk1zlrqkVpepK8JcxsG2E8E+laHjK8M2rSLAdyxqoZ17Vyw3M+AuWPvVxdkQ2XLi9kvLiSeY Zkkcu2OmSc1LFehLWWBkILNkHPHTBqqkb8/cOOu08ignHzAVSJuWrSVYbgvtVgY2UhwCOQR3qezV dt3ICpXGzAcdf8KyVbBLHmrMM+yORNqgv1arTJaI7CYRXKvIoYYIAIyKsafnypT6yHioNPYLfpxn HT69qs2CjymLHgyE4BxQhsmc52YGMHDHPB96kkSNQFjfPAJ9vbFRhslg4BGe3rUm0l1IGD0570mN E0QMb71AZu4zzVyRP3qSpyCPmUDoPf8AGofIdnXbFvfjAHc9qm3K67vLIbJDY6f/AFqQx+zJGSCO 4zQy7ZOe9Ean5SWC9jntT3T94OQcdMVSJZWlyt9MC2MmFePc16Or/JnLD0rh44YpTJlA7rMfnA54 xjPpit23u7sRKVlEgI/5aDP8ua0iQzcEi/Q09Sp6nJrGj1KQjM1tgesbZ/Q1bjv7WTnzNhHZxg0y LGgGKkZPenvJu6H9KrZyuUIPvnNG4k5xg+1S4lKRheOU3eGZn5BSSNgB/vY/rXMQSSjSxg/fGFGe 4IP9K6bxpKB4ZnjbG6VkRRnvuB/pXN21xb6daRRXwVoHHyTDkKfRvQ1nLRmkNUdIyC9gUsx8phuG Pft7V2Oj6XYx6VcanOn2ezgjyRk4LAcAE9WJ7e9ebaVZSSXrPa6sYPMxiRJQgHPO5SCG46dK7ZbD TYmjk1PxfcTwRsT5UpD7eOCAPlzmtLyaJ5Y31KHhrw5d6haW+lfZ4o5wxneYKRtRs5Dn2/nWh4n8 Qmy0m48OeD4i6QL/AKbfDoT6Z/pQmtS6zZzaR4WBtrDP+manJw8vsPf2FWHW2ttLj0y1g8u3hyTu 6ufU+/uaFDm9AlPl1W549aRLNMsM29bpn2zM3U5YYI/CvYrHT4NNgS2s49kSjAHv6n3rjNd0EvLH eWcapcRMHQqvXHPPrXUaHra6tanzE8m8hO2aA8FT6j2NEYcrJcuZXNccHA/GpEAz0+uaaRwDjj2p 4zjJ61ZA9c9s4NSgFgAeT2qMHqBVjnHC5NJopMFQY5IJ7U8KO5poXI4qVUIHt70hjlOO4/Cn72Lj Iz9aVFHJ7CpNmTkcCgRnX2iafqfNzbKZO0q8OPow5rktU+GUcztPZTBpByCx8uQf8DXr+Ir0JVQD ANPCY4HA9qlpMautjxq7tPE+i7UugLuBGBCXyf8AoMq8fnikg8Q6b9oj/tK1m02QZ2u674z9GFe1 gZG0qCO4PesDWvB2m31jcyWtusF2Y2KCM7VZscBl6H8qWqHe+5xN5pBu4re+iuILn7UPkjhbc8cY 6ZHvyayZ9GTJUPk/3Tx+lc2o13Q5iER3EZwfIJJX6r1FbFj8QvMxFqMEVyo+UiVeR/UVSkmDjf4R JbSaJSpAljxjZKu5fwz0rMm0qylzlXt39V+ZfyPIrro9R0jUATb3DQMekcnzp+fUVFLpwYbtgdf7 0XzD/GnYV2jhZNFu7c+bayBwOQ0Tcj8OtammePfEOkFYpJ/tUK9Y7gbsfj1FaE1oQ+6Mke61UmVn BFzAk49SMMPxFTytbFKfRnW6Z8TNIvmVNQjls5CMEj50z/MV1lnewX8Qls7iKZDzmNt2Pr6V4lPp dpMT5Ehib+7JyPzFVkg1PSpBNbSSxEHiSJuP0o52twtF+R785IGM1GjKWwepryWw+JGsWuyPUI0v I14yw2t+YrsdK8faHqJVXma0kP8ABP0/AimpJg4M6x8gdBmocnGf0ApY50mj8yN1kjPRlOQaXI4w Rmm0SMHJyp/Okfkc0EjBK0wlmwMde1SMRck4wcA0pA65xRtKjmmtgrQBG2S3JxS5IUgninfKV7Zp ow2QeBSKG8cZOaON3XFJjnGcikOc4H50AB6cAj3qMksPvc1KfrTdoLcc0gEAJj6DNIcjrxQSw78d xSbzyMfjQAPzzkZHam7s98n3o2460hAzwKBgE+bGeKNgBz60u444IqNi2cmgBxBByAM0AnoMGgKC mM4NN4U9KQD+AvQce9RkA8nH0p27Poab7sMe9ACYbOelLwDy1J5nOB1pPmHJ/CgBr568kiheRnAF OVuxFA9B+VADWPPvTWBxg9PalO0t6UhJ3YHSgAKjAOTSBD25obgZPelD9AKAAnAxzTd529D6ZpxO 4cdaZjbwT1oGBU8elNYnIOKeSD05pNoJGeKQCc4xik+nWnMOf880zp2oAVuBx+NNGTS54I6UwHnj 86AHhfXj0pCBjmnZ54pjEAEGgBpbIOaF6ZFNIJG6lUkHjpSAQn5hTlUc54pGUE5ApDwcAZoGGBvy KXt1/CmgY6n60N90460ADMcYxxTST60qHsaRs54oAUbsZz0puRzzSEgDnrTM496AJG6DpikJ7dKQ n5Qe9GeMkUgFH3fSkDkNk0E4HNAOcA4oGWCRnIA6ClBwO1ISM446CkLc4rnRuPJ6cU5eOvWosnNS DpgimICRu4o3DpinYGKAn40AJg4yKcq5Xp9aCQOOaXeMcUAOXHSjAB60gwOab155xTAkGc8Dj0pQ fXpUasQPY07Hc0CHCkA4zQFDetHTA6U9QDBLdOKftIoAI9qVjjn1oAQE5xSk5GCMikPrSY9zQA8d AR+NKFBO4ioxG3rxnmpRwpApiFIGOmf6UYHpSKwyBmlcnpQApyOmKr37FLOeTcPlQn9KmUkHkEmq msyFNGu22gDym/lQyXsePlzIX3McN1OaagZZHG0jehCEjg/Q0zZywGcCtC3mea2ihdyUiyVX+6Se cfkK06E7kNrGC8KpBsdD87k9RVmcQvdtJEvyMR270+WLz3V5WLFfwzVMSNvVQMDd0q4kstXVqnk/ Kqh8MQcdfTNZ80ZhiXdIjOeCFz8px0NalzOGsRNjBSNjtHsaxp5TNIXJyD0z2FN2JQ6zcJciRxlV 5NX7MqYVIHViRn61mBSzLGnG88+wrXSMBEAAAB/KiIMm2ZYxhec5GKekZAGevUbulNjIEoG5eP4x 16U9clMMwbHSpe5aViwjT4R0G4Jzwc4q0rAIztyc/nUCMgO5SqALzgcCpZinmfIAVBzg+vrRYdyX avBwOBnJNM5LL3BHb60gcqPY+1SRf6yMD/PNUiGW7Xi1lmbORK24Z5HzVsQCKSESIeG4HPBFZkaR R2EVy8gjLlgSQcnLEnHqK1rKKOCwSVG3xyHhgMrjv+PQVokZiyBXVfL2gqOck5q9JYJFbJasB5rj zJm/uD0/lVDcDcIwH7rI471rBP3I8wmQStyw6YzyP6U0JmcLDaTMTtfnAX5T7VnarrY0BsT3BeRg CkDAMx+vcD60ni/W20uNdPspV/tF5AcqQRCmM56feJP4YrCGiQRWUcjz/aLy4XMzNkmLPQc9Sevt Uyl0RcY9WZ2oa/Lrd6kt4gjhQfu4lPAPr7mtLSdQihDIyJJHJwyMAQR6Gs+58O/ZzvjunmjHMiug J29ypGOR1xWVfQvpeoSW4lYlcEZ44PQ1guaLuzRuMlZHeJ4U0O+3TRQy2zHjZbzlVB9cHNXtP8G6 NZjzr/zbwZ+USzbgPbaMZrgLTW7uEAJI2PrWpD4juYwCT09ulbqUexm4y7nqdrBN9jjghi8mFQcK gC5B9hSPDcq+BEzsOAvU15v/AMJhqHa4fpjrTofGmpIOZ2b6npWqqRWxHs33PTINLvZDmS1k+b2z j8Kpan4N1SSVdX0e3mXUIOdpTAlX+6fWuLt/iRrtq2I72QDsCc1rWnxe8QQjDTpJnj50zj3rNu5U aeu50GkaxFrFj5yL5cqEpNCx5jYdQa01OR0rznw9ftL49lngZmS7DNNuH3mIyTj616TGADRB8yuK aSYudzAgGpwp6g5HuajCgncGAzUyKQnOPzqiLkir8vt7dalCjHp/hQirj39TUoAZcY4NSUCdMbfx qQQksBmnxpwAB+dTqhHbNIZGIcKBnipliG3nNPRcjJ61Mq/jSYWIRFgdeKVdw6ZOKs7eAOB60/YA MgUhmNf6LYamQ17aRzMvRyMMPow5ri9Z+FljfI7QSIzfwpcJz+Ei8j8c16VIV24BHPaoGUnGBx3N FhWPnfVvh5qujtviM0QHdx5kf/fa8j8RWSmpa5ojB5Y5Aqn/AFsZ3L+Yr6ZkVT25rDv/AAxpWoOz PbLFKeskJ2E/lwfypJPoVzM8Xt/GNtfOGvFBcnlx1P41oB7W6j320ysT2bqK3tc+FMFy7SWXlux5 /wCeL/mPlP5VwGp+Eta0G4IBlXHIWddhP0YZU0+ZrcXusuXVjMsg3Rsqt0OOPzqsI54Gyrsp9jVS LxHqGn4jvYZFX/aHB/Hoa0YdY069+9+6cjqOKd0wsytN5NwoWaBS3d04NVJdJt3AMMnPo3Brb+yL Kp8l0f6HBqnNbmM4ZSpz1NFgTsZttc6xokm+0uZ4h1+Unaa6XTviZdRYTU7NZh0MkXyN/gax9zop AJ2+/IqtNFDKvzxgE914qbNbFc19z1LS/F2i6nhYbxYpD0jm+U/4VtBvl3Y4Pccj8K8Gk0wk5hkB 9BnBqxZeINc0RtsN1MqDqjHKn8DT5u4+WL2Pb87j1z60wtjoOvFeeaX8TFyF1K0we8kJ/oa7HT/E WlaooNpeRs//ADzY7W/I09HsJxaNTaOOvPemMMH5T0pxfHUUwuMkDnPpRYlA44z3pBjIyeD6UgIY e9OIx1PFIY1twbbkEetGcAAikYkE/pTSehIPNIYrHrx0pgbGcginLhs81G3LYJ49aAHDaTkZ4oYE D0z0poLdBxTscD5skH8KAGkKvXr60mOrU7aDkE03oKBjd53AAfXNIUJbNPwC2c8etDE9ugoER4Ge TinodxOe1MZuehoDjaeuaBhwOQPyoJzggkNS52jhahBbdyaQD+hGeSTzih9ueaRjz1puffIoATIH TOKPvHinE5BximgEHJ6mgAYbeMU3ODnFPwSTn9aSQ7eAKAGhs84ppJz0pTyOTg0g9aQxUBHPIoY8 0owo6800sMcUAKx+X1qNs9zzQTtPsaTBJGTQA7gmgjsDSdOKOMg9hQA3cc4pGU7u2ae2000kAEd6 AAErwTx7UmaRSCcUHn8KQBuYcimliO3PelIOMg0jEEe9AADuozz7d6bx0pRgDgj6UDDOG603JJpx wBmmlgOQKAA5Y8jmm4OPagMd2TRzn2oADypoAO2g9cDpTsj1pAN9jSgAMBxTSo3ZzTe4NAFzo3I4 wKUrxkYpGbJ/AUDJHNYHQINxp/J56UwdfanAnpQIdRuYDijAI9KTkHigBc88ilJ5GKQbt1OUc5oA cDxikzxjvSnjoDSZHTFMQA9MjNSbhjpTBnGcU4AEUAAYUucnp0pm0DtTs7cdaYiQEA807gDFQhsH FSBs0DExgnrmlGSDikDY60ZyaYiVemB1pAwQcnmo9xXkH86Utu6igByYJNOwM96Qfc4pAW5HX60w F2kd6yvFEpj8OXhzz5ePzOK1QWVc1z/jCUnQnGeGdRj15oJZ5tgxjOOSO9TWYO1m45OPpTZhtcAn Ip0KnYdsZznqDWnUguA7V4NZ07FU3jIIGRVti/ll3Vgo4JB6VCVIwCNwIwRTRLMqC/uZh5BkIj6H 6ZzirsMIkcB2CIvVj0xUckYjYhUA+gp00cscMce75pxnaD2z/wDWo9Rktgm4vMV68L9K0SxG1Vxl u1Qwp5UQQDipAgeRc9vWrekSFuPQMHztG08A1YQKWwFwTxwe1RqOWXsckbTU8IUDB7np1rOxqiTZ EAy+WQAdvJzmpVXbKFCnHTOKrsAk0kfUDkH3qWAhkBIxkA9e9NMQ6RyrbcdKmtmPmKR2NVCD5hye c96vWa7pFHf1rRGbLn2W7uba1KlFjjG1vMXlG6hh69a1LS3MFmUV9y8sQccH2/Gse0up7VLXfGyp 5DqSHyHOeQyn2PFaas4jAk3K+0Zq0SxysQ5YgDnkZrYsyZIowqkyJjAJ9axOBGzdckAZ61oWlysE qJu+dupI7e9NbiZwGr5k8Z6g7YJDgexG0VsC4Bb53CJJtKsxwu4DaVPbPFXPFenpNrp1JI0jiZRC 7Iu0Bh0ZvryCfYVlRPNEXSFgW/iRgCp/CsE/ecepq/hTNlb/AOzRyLEVdpFKrChDFieNxx0AznJr PjtNP127lgltFdII1jjkBKvwOeR1qNYLyW3byhHAGGGWNQmfyq0ETTNPkkVQrRxnpxk4/wDr1du5 ndbHP2OlwXDPHHIQFYgHqcZ4q8/huTOFmyD/ALPNR+H4GaZ5CCFUYz2zXWWwDZDL+NKMdByepyq+ EtSO3aEIbpkgVPF4I1uVysduGGcbs4H512sERx0JGeOOtdHpqs6CIkrs+bk8U+QTmzyxPh/r+4br CQqeNwPFWIPh7rr7T/Z9zgn7yqDXttjIwwrYZR6Vt2bEEHAI7e1JoSbZ4y/hK98HwafrtxZzlATH dgYJRT0bA/Gujs9Ssr+NWtbqOViM4DDIHuK9Vkhiu7ZopkWSJxhlYZBFcPq/wl8P6jK01t51lKxz mFuM/SlCdtC3G5RORgMMY9qlBPy/L0rIm+HXi3StzaTrzToPupKc/hzWOut+KbFmW7s7C5K8HblW /TitVJMjl8zuUUgbgMU7MqXAPlgwkEu27oe3Fchb/EG2Uql7pl5b+rRkSD+lbNp408O3R2pqUcWe MXClDQ9RqMjpUGFzxk9qmUA5wOR0xVOzu7a4X/Rrm3uAeV8uUH+Rq6qyfeZWXj0qWgs1uSqDghvW pIlznjn0FKu1hjggfhQSFPy/MRUlEiqwboNoH41JjI6ZqNWDfeP0xUo3MvGAB60gIXjXBGCPSogm cj0qwqbl6kd+aY4Ctn8qAsV3i3KQeDjg1A0OEDd8VdYfKSuSKh2lQ2RnPNArFJ4pG4XCj1xzVWSB PKdAA+R8+8ZDfWtCUbflOTu7VXkKqhLKwPoBVITOQ1HwTpN7C7JEbd2HJjPyk+6ng1w2qfCiXa8t mAcd4G2H/vg8H8DXsO1chpM7ewHH51A/JJA/Knypi1PnS50nW9Hcjl9vVGBRx/wE/wBDTYvEkiAR XUZB9GGK9/u7OO9VormISA9nXI/WuYv/AId6ZewkQ5gxn5XG9PyPI/A1PK1sVz9zzmK7sLtPkfy2 PbtTZbMqmVww/wBmrmrfDTULHMlrkr2MTbh/3yeRXN/8TnTZGR43cL94Ac/keaXM1uNWexbaJgeO vvTcOMhiCPRhkUkOvW0/yXEWxu+Bg1fEVtcrm3nVvYnmjmTCzRlSWluzFTGY29V5FVWspYm3QuG9 1PNbctqyk7lO496q/ZzuOMg9qbimPmaFsPFWtaXhVuWkjH/LOX5hXVaf8RbWYhb+2aBj1ePlfyrj ZVkSPMihlPr1qqY4ZOVJX61Oq2Kvfc9lstXsL8B7S7imz2BwR+FaW/jnke9eCiGaBhJE7L6MpxWz p/jLWtOwjyi4j/uyjP60+buHKuh6594HHQU1pFA2jpXG6f8AECxnxHdxPbserD5lrpbbULW9QPa3 EUq/7Dc/lT0ZNmi4pyOaXv0poYMvHFAPB5xRYVwG3HOCPrSs2McAg0wrkZzikOSM5H5Uhjv3h4PA pOdvP50mSSMdfSlbpn9MUWARjwBgfWhXyPp2oHTilBKMeOKQxhbnpkUo4PqDTRnd7Upwc80wAtzg HpTcleRTec9OaCCTkmkAhZi3PelBxSkqDk801iq5PrQAFs9RQXx3GDRw3OabgYPJBoAdk7uDmhlz 2xUYY7sU8EjIpDGlQOozSHI6HH0p24A4xzTXAA/pQAZAGOuaYDyRQoBOSTRjA6daYAcke4pN+O3N H3VzTC2etIBxfI6UZwMnvTcdTQcelACM3YDmlAJPTmkGOacGwTigAIAB9aBzikZse9KWAANADG+U jHT0pDk44wKcdvU0zOenFAAVA75pg+971IRjrTSMn2pANL4PNCtntQ3PFGMHPpQMVjleBz3pjE8c 1J0XNRdD7UAKgzn+VOyAaRTg5xxSM2egoAa3t0oHGMetIT+tKDggFaQFvOD7YFAyfpTAfm/AUvPP pWB0Dzkjg0q9c9xTCc8DIpAKBEu7d9KX7veowfTmnc96BDgT+FOU8cVGCR1oBxQMn3fL70wsOwpP xpwxjkfjTEOB4HNBJFNI4yKMnp1zQA/oue9AIx3pqnsOtLyOppgLxmjgdBSscYPamhgPagB4APGa fjANR5+bPFPyW4zimIamN2D196eTTMHr3oAJPNAEg+7nNLkbc5IpofauKTO4cmmIeCGX+tc54x/5 BaLnrKDXQgY7CuW8bSFLGEA9ZP6UCZyJgaRvMKjGOKYpIyAOOuasLKWt0XPAqxbs8BYoBkjHI7Gr TJsRwIXSWKRco64P+NUJAwjw4IkjO1uO9bdsArDd8qjqazNUu4ri5lljiVAQFBUY3Adz71otjN3M vaTKuTgHqadblri4aduQPlT2qvNKQhAHzNwK0IEWOJFxwBSitQZYXLfLk/hTmZlwME9uKEOAMYqb GRwPaqbuEdBsMirIrMgbIwQTxVq2EayLuywP51U8ooAQ3TnFWbYbwQpyPQDoaixpuWo5lMILKuM4 3kZNJEzLltoA7VExAVlPHHaljcZJIwCBTQmKqlmYY+bOcjpVyyZBJl87QDnHXpVNfvHb0qzDIIo5 pM4IiYg+hwapEGi0EBgtlt8weU+0Z+YtHgdT65q4+WWNt+5e2Tniqlnci4SOQMjoqD94uMluhGO1 LcT4ULxjsBxWhmTK2WAGeOlRM5E4IwS3GagWaSLIBBPv0qjPfFJvstsn2m8boichfqe1S5JDSuzo bi+gRC0svPQsfmB47iuM1C9sLe6VrG4IU/eTsh/2T6e3augtvCEl4RNq907k/wDLCM4UV0FvoWnW y7ILGBV7/ICfzNRK8tdik0tjkrS+Z0QbwQ3Q0mu3DpYx2+75pXH5Vf1Xw0+nO13Zoz2xOXgX7yH1 X/CsC6uRf6rA4bfGqAZx0P8AjQql/dluPkXxI2dJh8i12jPzHdmt+2iLYA6n0rLs1GFAbjtW5Zqy tgDIPQ1tboZNm1ZQFkJbHbac9K37eDEOzIBzlSB7Vj2IkTcxChQOhPWta2lffHJ5IYL0TPWnYk2N Njwqru3kjLHpj2rctlAHPTNZFpuwp2hBt+6OxrctOmDgk88VjJmkUXF+6MdKWiisTUK4rWPD9uJr i5idSHbeYyeM12ci742UHBIIzXOLo99O3lzNhUAXezZ3cdQPXNVF2Jkro831jVNJ0ou97ZvMFOyK FTt3N3Gew6dKq6XpNv4lby9U8OnSBKpNvdx5VS3UB1JPB9a9L1rwHpuqva3CrturabzQzZIk9Q35 U6Xw9NfN9mlHlQZBZ16nHQCr5k9SUrK1jyy5+HjQuxtbh8rwCDjJ9sdKdaaP4ps4430/WbpMn5Ym lJ/SvVJfDlzB81pOj4XG2Zc5/Ht2rKsrHUG1ZIJYpY41bcTj5cDjr6VonHoTzVFpc5AeIPHmmEfa Yo7tfSaAfzGKswfE6/t2xqPh8FR95oHI/Q5r1Ca1EqZZM7eBmsy60m3njKyQoQTyNoFTdMrmmt0m c3a/FLw3IQJ47y0P/TSLP8q3bPxXoGoEm11m0LP2d9h/I1nXXg/SpS+62Vf7pTtWJd/DvS5mYhfL btgdafKujD2i6o9EjjSRVkjcSgj+BgQfypzodp+XBHJBryc/D29thvstVmh2/wB1yD/OkWXxxpjl IdbacKOFmXeCPxpcjGpwfWx6ozAKMA81G5B+YA9OeK80i8eeKbJit9ptldL32Aof0q7H8T7ZgU1H Rry3B7xMHH64o5WVZPZnbyFnzjj3I4NUMkj96qMTzgE8/wCNZdt4+8MXQCDUDAxP3biMp+vStSO8 sL5d1pfW0xP/ADzlVv0zQiXFroQSRknczEjOQg/rTZHKjJxkVYkheJsYPTcCRVU4LbjklatIzuMZ +7FiB2qEsWLHHH1604vkAYzzxTGypwMU7ARSjeuCOevHas+70yz1CMLdW8cmOBuUce+avMwOe340 1wQcDr69qQHC6v8ADzT71i0LmNh2cbh+fWuL1HwLqunEtbrKwB6r84/TmvZzy3K85ppwGzkZz171 DgmNNrY8EXUNT05ik8ZdV698f4VZi1y0uB+8Qo3qD0r1+/0jTr3Pn2ySN67cH864zWPh1bzOz2kq o2OEkU/zFQ4NPQvnvuYUUUd/G7W7byq7iPasee3CyEgHrTb/AEjUtCujCJCJWXI8t85GcdfyqOPU poWIurcnvkChy6MpLsOy6c5Ip4IcZZQfepYrmzuhw4VvQ8U+SAouQMj1paAVGt43HHH1pgiuLVt8 ErxnsVJFWSV9aaSQOKGNGlZeNdXsiFnIuYx2k6/nXVWHjvSrvCXAe2c+vK1wBeNwVlTtwV4qM2SS bjG68dm4NHM0Gj3R7HbX9vdpm3mSVeuVOalZwRyCPWvFIzd2cm+CZ42HcHFbtj441O1wlyq3C+rd fzquZBy9j1BWCkk9xQ7AgVy2neNdMuyFmdrd/RxkfnW/FdQ3KB4ZFcHupyKBWa3LaD5QM03dkgde aYpxz1pR03Y60AOIAbikPC89aYZM+lIzcD5qQAHPp+NKSSuCKbnOPT3pxIHFAC4G3nk4qJiPTNPI J5/lTNxBOaBgRjB7H1qpeXbxEQxFFbYZHlflYkHcjufQex9KtFgw+lZ0imWa4yB888UR6/dADf1I /GubFVJU6fu7tpfezpwlKNSr7+yTf3K40T3KmLEtwrPwn2qJQkh9Dt5UnHGfy7Va+3ILL7TsbdnZ 5XG7fnbs+ueP1pdSDNYTsMZQeYPqp3D9RUfkCS4uY2LKvmrIpRsEHaB/T9axXPSq+zUr8ydr91+h s/Z1qLqOPK4tXt2fr1IBNdSNIDLNI6cOLWNNiN3UF+WP+eKktrx5GRJXWRJAfLlCbDkfeRl7MP6H 0qQP9lb7Nb28kxRA3DKOpPUk9yDVa3LPfmI7TKkpnn2fdQlNqqM9TjnPsfWs1KVOrGCqOUnuvLv5 eRo4RqUpTdNRgvhfW/bz8zQHHPP0pQNx46ClHA4PFN3AAkHFekeYJcTRQQbpc7c4GAWJPYADqaoG W4Ys7PHDteMfZ8BnCswGWOeCeeB6d6tzxi4j2sXUA5BRtpB+tUTBHbvMkSBF/wBHPHc+YeSepP1r kxTqqzg7K69XdpfcdmEVKV4zV3Z+ism/vL5ZI0LM21FBJJ7AVn/aJnkUuZkLrvSCBFLKnYuzcAnH T+eKs3p32piIH7xljOfQsAf0NOjTdcXUh6tLj6AAD/E/jRWlKdWNFOys27b9AoRjCjKtJXaaST21 vr+BXgumDJufzIpGKK7JsdXHVHHrxwfb6Zu5GOKoyrg3gXGAYZxnPXOD+iVd6inhpyvKnN3cX+Fr oWKhG0KsFZSX4p2dhGXj39KhuJmiAEah5ZGCRqTgFj6+wAJPsKnLjbULQJMVdndHQkqyNgjIx/Ku ifNyvk36HNDl5lz7dSq05USM1zdOqHDywwp5a464BySB3xmrEEkgkaGUozgBlkQYWRT0IHbpz/8A XqOVhaW6QQKGkIEcCE9T/gOpNRTP5Uc6RHclrb+SG6ZYDn8uPxz6VwxU6VaEOdyune/5+Wp6EnTq 0Jz5FGzVrfl56CtdSTbG3ukUhIhSFA0koHBYk8Kv/wBbnnFCXDJlt7vEHCSCVQskTHpnHBU56j17 84mMQjuinAWKFIlA/H/635VG8e+a4jGAJrRwSfVTwf8Ax41l7Sp7H61zPvbpa/8Al1NvZUvb/VOV dr9b2/z6Dp5n3+VEUjIQySSvysaDvjufQex9KhWRyY1Sa4V34j+0xKEkPodvKk9s/wD1qFzLbXDn A82WKM9fugBiP1I/GpLw/wCiSSdWT94Pqp3D+Va/vK8puMmuXRW72vr3Mf3dCFPminzau/a9tO2w PcPNbho1dG37XUKGZMHDDHfBpm9+nnXfP/TqKnddl9cgYwzK/HuoH9P1plzK6wnygPNciOPP94nA /wAfwqo3r0o1XNx01tb9UyJ2w9WVFQUtdL3v5bNDI5D+4kS4eRZJGQo8IU/KDk/gQB+NTk9+9V0R VmZYj+6t1FvH74+8fqTx/wABqfHGBV4PndJSk27669un4EY1QVZxgrW0dtr9fxE70fxdaawIPWgM QR6ZrpOQu4BIPQ4FLg9Kjb5SMegpclu9YG48emaPung9aZu56U4HoCeKAFxz9KeDupCQRSDg8GgB +Bk56UzPOM5FKc9DSDnOKBDwR1704NTO9PIwKYDs4xzQxH400DoTQeWpgOA7jilA9aOmQaQN2oAe w4GKQgMRnrSA4PtTgQCCaAEwc80u6h+eRSKPemIkLDbkU0OTnP4UmMA0gOcmgB4G4e9OII9BTFyT kVIc5BNMQhYHFY3iLSjqmnMIgfOj+dB6+1a5Hz56ilDYBwOaBPU8qtZVj3LMpBHUdwasw3sSn542 YEfKR2rofEPh0XDNd2wxJ/GPWuTktrlPlMYIHFJTSerHZtbEt5cGQhVysZ5Oe9Zk0gZuOBU0sU+w l/lX2BNQm0eUqIgzIerEYq1NPRMzatuJFbO0guGIMYUkYPf3q9HjaBgjinC2WC3aNTn3x1pUxtOK 0vZEWuPXg4NTHhRzUC9QB1qQZzQMrz3Uok8iHlz1bGdorS0vwrdXh3K8r7/lBDH5SfpVrwxokur3 18kGDMkYkCE8sB1xXW6E6wXcUjNt8ph8o6HFZRmpScexs4OKT7nEXNhqei6h/Z+qRSozDdG0iY3A cU8gA16Z8W9W03VdK0cQgG+jmJyvVU28g+xOPyrzDOXrVdjKS7lhAqoT0PatPT4t1vck9VhYrgBs t261kq3QV0/hi0inmme4YpAihpHxkKNw5I71cUQ9igES3ZxG2VJyPlC4/Cqskqq3mysFXryai1K/ hgkdtwA3EADuc9BS2GgXWrEXOoForbOUg7t9aUpdEJLqyGEX2uTGHT18u3zh7gjj8K6zSdHtdJh8 uFP3h+9IeWY/WrkEMVtCsUSKiKMAKMAVIp+brmhK2rC9yZFDc1IBj+tR5xx2p2Rjkg5obGkSFQ/y 9jXK654elAuLjSsI8nMsOOJMd/Y11KDAJzTyAc8Dp1NTKKluO7WqPONI1MZaGYFJY+GR+CK6mzdJ yDHKB+Pesfx5o0I0p9VhAjuYCuWHG9ScYNefWuuXdq+6OZh+NaRqJaMnk5tT3mz+0xRSI5wyAHBH c/8A1hWnYaim4PIg3DjCcV5FpHxM1KyIWSQSLxkGux0z4m6TO4F5a4BBBK471d09hOnLoep2F5bz RjHfua37TYVO3HWuB0rxV4UvHTbcvbkDHJOK6a3gtLhQ1jrZIPQbwazkioxkt0dHRWJ9m1W2XfHe i5AH3SACauxXk+B58DL7gVly9irl6imrIrDginVIwooooAKTApaKAI2XjBxVSWPk7f1q44yaryNg YIIPariSynKnyq2B7mqFzGdvGB9a1JyChOckVlTkMwIbp1rREMoTu5jyBgdBzgA1jXl2xUlsnqAP X3rYlCjLgKcdAT0/CsS98sFvLIzjkn1rVGRnTSkgg7VJHOKypyr5BVc9Per1zKrKm1vnHU4rOmKm QHIIPOadx2KstpaTRbHhTI53beucdfYVjXmk26St5TbcHAZOK2JXKggc59+tVZADGdxIxycikVdr Yy4b/XdLB+zavdoP7u/IP51p2/j7X4E2XP2S6TH/AC0Ta35rWfc4eT7xI+lZ10uAMZ29wakvmfU7 W1+I9o5AvdNngH96FhIP8a17fxdoF8dsWpRq2eFnzGR+deVLKCCoAyPWkkhSQfPgVWpN49UezLKk +HhlSVfWNgR+lSElCwwc+/8ASvEY4jbsGglkibPVGINa8HiLxBabfK1OSQDgLNh/50XHZPqeqLKO pGc1CWzyccd68+h8eatFxdWdtcDPVcoauR+P7F3H2iwuYv8AcYOB/KloHK+h2ZkwOACT3qtPnIOc msa38X6HcYX7d5R9JUK4rSW+tLhQ0N5BMD/ckWhCafY43VdWOneMWvI/LkezjDNG65UccZ99xB/C uNNwsrsc5DEkgjNXtWuGlkvGZy73FwS5IxlV4X+tZ32UxhWJHzcjBzxWMnc120IJbW2ckmIoezIa I0vbX57W5Eij+Fj2/GppVKrkA4Hf1qqWJIINZtXGnYsf2uh4u7MI395BirKLBdJm3uEJ/uscGqPm sVKsAwPYiongtmbhTE3qppWaDQuS28iN8yMB64qMdPeo45r+CPEc4liH8Lc/pU8WpWbEJe2zwv8A 30/wo5mFr7DXZsdaa2wr8w/KrP2eKXm1uI5gf4c7WH4Gq8sUkRxIjKfQimmmFiF7RWyUYHHvg0sE 97YyBreeSMj0OKTcMUeYQOTn60DudDY+OdQtxsu41nX+8RhvzrqdN8Y6XdqEaUwSHtJ0/OvNt0bg ZXafamNbd1II9qrmYaM9oSRJI/NR1dTzlTkUDDDk15BYXt/Yzobed1AYZXdweeleuREsgz1I5p3u SyQAZxmgjB4NBUH603PHvmgCTP44prMOgFIelIF+bjpSADwMjFZk0nlS3Ryco0dzj/ZGFb9FNajK SPaqdzbmVkeOQxTR52SAZ4PUEdweOPYVhiaTqU7R3TTXy1OnC1o0ql5bNNP0asGoShrUxqQTcYiT B67upH4ZP4VELnZcSyKhkElwIUG4KOF9fqGH1pkenSKQUW1t2IIMkEZ3AHrtzwtWWs4TafZcERAA DDcjHIIPXOec+tYqFWpU9pJctk0uur6mzqUadL2cXzXab6aLpqN2WuoRiSS3RmGUYMAWQg8jP1qr FjzI3WQu0dy0EbnkshXJUnvg55/2akbTpXctItrOxGDI6MjN/vbTg1Jb2nlsryspZF2xpGm1Ix32 j1PqalwrVZQ5oWad73X4ddfMuM6NGM+Sd1JWSs/x6aeRbAJFMZcnpSSoZreSIOULoVDDtkdahtom t4jHkHLE/KCAPYZJ/nXdd3sefZWvcmye/Wqc/wDrps/9O/8A6MNWgcHnrVeaB3mLrIoVvL3KVyfl YsMHPHWsq8HOFl3X4NM1w9SMJ3l2f4poW+JFq8nP7rEgx1+Uhv6UscgF3cRKwO4iVOeqsByPxBqc dOTzVF7AqFjVYZoVz5aTKcxZ7Kw5x7VnWhNVI1YK9k015P8A4Y1oVIOlKjUdrtNPzX/DiM4k+0FW P72aO3XGOdpy2Pzb8qvEk8VVhtyjpJIUyi7Y4412pGO+B6+/8qsHPFPDU5R5pz3k7+nRIWJqQlyw p7RVvXq2IwGDUM8wgRcIzyOdqRr1c+n/ANftTbS1NtEUMgYnHQEZwMZ5J5NSSLJ5kckTorpkfMuQ cj6itZyn7NuK97sZQjT9olN+71ZUVZBM6RyBrxhtnuF+7AvXy0z3/wD1nsKnNqn2OS3jBClCowfU evrTGtmLEmGwJJyT9m6k9/vURwCO4Em23TClcQxbM5I68n0/WuPCwqwfvw1e7uvy7dkdmLnRnH93 PRbRs/z792Ktwsk8Uu7i5gV192H3h+o/Wo3mw13IrY8mDyxj++54H14X86V7YjcEEUkLNvMMykhW /vKRypz/AF6UsNucpvESRRnckMK4UN/ePcmo9hV9n9Wt7ve/S99u/TsafWKPtfrV/ettbra2+1uv cY2IortFJzEY7gD/AGRgN+imnXXz24iVuZ2Ea7e+euPwyfwqWaEs6SxyNFMmdrgZ4PUEdwfT2qus EkZzHHa2zEEGWFDuGeu3PC1o4VqUp+zjdS13tZ2tr/wDKNSjVjD2srOOm17q99PP1J/MEt5dSA5A k2L/AMBAB/XNRGbE0twAGFouEU/xTPwB+AI/77qSNVjRURcIowB1qBYZAEjkkVo1laXhMFmOcZOe 2f0FOeHkqEaEdtE/Tr94oYmLxEsRPzaXn0+79CSKPyYkjyWKjlvU9z+J5qUcg5pDnNGT2rttbQ4W 7u7ADJ5oGM4A70hJx70inmkBbyN3PoKPemn69hRnHFYG48EY5pwG4E+lRbxjnpT1bHemA7OBzTs8 cUwt3oGc80gJSOhFAIx06UD0ob2piFByKUP19aiOScU/BAzQA4ZORjijGDTd7ZqTIwDnmmgAEsOa ftBPFM3Z7UmT1FAEhJ7YoLFj0HNR8jqaeCcUCHHFIDxgc0maToeaYC4yMY5pwGBg8U0Htu5peOlA DtwAxijcTjnikyBxSjHHpTEPBzxim7eaUgDoaRgOxoEAI6EVQutGtLptzx7W9VOKu84FOyccUnFS 3C7WxhN4YgLYEsm304qvc+EUERa1mZH9G6GulVj0NBbtUqlFbA5Se7PO7rTryzytxAxXpvXkVmld pOMketeqFVbgjINZF94ftboMyII5D3HQ/hV3kvMnQ4VWwOeD2p4arF9p72bskwZXz8v91h7Gquwc bTj2NaKSZLVixbXV1Z3AubOd4J1GA6nt6H2p/wDbWsZ48kHOSwPX3xVdDxwDTvmPSl7ON+bqV7SX LykoaaSVprqZpZm7noPYU4DJ5piK5PzCpiY4V3yMAorSxne5KkbNzgCn3OsNZ2kthbPmS4TZKeyL 7/lWRcaq0mY7Y7UPBcjP5CtPR/DNxfYluQY7Y8kH78n19BScuiHbqzQ8NafaXTtfSRtKyYSNpOen U11iDLfL09Kjt4EhiSONAqIMACrSqAOKpWRNm2IEOeRx6U7Z83ApwyaQtjFJu40hx7DoakVAR0pg dTjIpwfIHPAoGPAwOhOKN56UAhh14p20DnigRBd2kN9ayW9zGskci4ZWGQa851DwBLGzNBCsqZJA ibaw/A8V6b6HHWlC+wzScbgeGXfh6e1cqxeJh/DOhT9elUntbu35aNiv95eRX0HLbxzLh0UqeCCM ism68I6VdMSLfyXP8UDbf06UuWQcx4pDfzQn5XZTWzZ+Kr63KlZm4967K/8Ah2zMfIuY5c9p48H8 xXNX3gXUbbJNlNgfxQkSD8utClJFKZpwfELUkTabqX/vo1vad8T9QjQKbl8D1NeYy6XNC5USLuH8 LgqfyNQNHdQctG498VaqMbd9z3yy+Kc7ACQo3qSK6ex+JVjIoWVcH2NfMEd9IhxuIq7Fq8yDhz+d HMnuhH1bF400qWLeJwD/AHTVyPxHp8pAWZDn/ar5Vh8RzoPvZq7F4snX+NvzotBjPqcaraEZ8wfg amW8gdcrIp/GvmGDxvcpwZWA+tacHxGu4+PPJ+tHJHuI+h3uVJ+VhVaS4DEgEZFeK2/xJkxh3BOK nX4gI3LM2T/t9KpQXch3PVpJ/lO45UcnNZdxfKD95Np/vdq8/XxlFKuDK/J79qX/AISSDBxMTkdC KpRRDTOolvY2LZkA/QVk3UqnJU/Ko6+lYUmqq/zCcE46E9ajN15n/LRc/WruTymnNKvnbgeAeKoS /wCuI8wFRxuHNVJblySQwLemarid3BGcY5qbjsWJNp3EMeO9V5CG6Nz70qkkbu3pVeYMDhc5HrSu FivM+M85NUZwG69asukhJZu9UpI3KYHr1NQ5FpFRgA3Az70wseTkE+nc1Mbchj83PpTVgOGXGD/n iqUxcpCrnIJ4zUiSBmIJ57UzyZQpX86RYzjgc0c6Y7Cs4yeefrUbkl9wA/CnFAW96DG+3ip5kHKQ FATgrTHtwEyVIBPHOKsBTt5ByaAhIyeg6Cp5kNXM17JWJIZl+hprQ3AAVZzgdAea0Qik8jr2oaHg letK6K1MzfeqhQlXX3quWkQ5MX4itXbu/wAaiaMfrRoK7M7zwDyGH1FCsjgkv0Ga0TCvcVG9vEw+ 6PypWHcqxFmOFOTjPFShyYd0ihucYYc0w2idVyD6g1E1swPEjZ9zSsFyRra2dd0ZeOTPUHinia/h G3eJ4x2PNVmjmU/eBpyzuvVTgdxU8o0yYXdvJlZo2hf26U7yPMH7l1k9dp5qE3UbrtkXI/2hTRBA 5BgkMbfWjVDHFSpIOQfehWZfpTxLdxLtZUnQeozS/aLR1IZHif06ijmCxe0KA3+vW0ZHyRnzG/Cv U0baM4rivAFoD9qvm/iPlp9OpruAeOlXHuR1DPPHXFA+YCk7U5AcEg1QxBkH1zS/dpGyDz17Ucbe etIBxfPApuO56U3OCM0EnOKBik8cUzAzxRyBS9xmgAJ784ppbJz2PalYjkCmkZHTFIBwzwaQnvTQ c4HNA+9zQA1k5oOM8dqU+9Ip2igAFKRzzSYzRuIGKAEZSCKYetPDc4NJ940AN3d8UpbIyOtIQAaT pyDTATcSNtNIwuTzS5CnrSNnoMmkAu4NxjijIHApmCXxnFOAwevNACscqOaZwxxQRuPXik4B60AB ODjtR1BxQeO2aPcUhiZ796GJzxSnHpzUZ3E8HpQA/I70g6cDimgkjnk0uTkUAWCPm/AUvfmkyD19 BQMVzm5JgYFKcBeKZyO9OGccUCAEHpTs0AYoGaBig4ODTyflxmo8HPXNOBJHSmAuc8U/oKYDjrRx nINAhy8jJoAx3zSqRikJ2nkdaAHcbfelHr+dMB9jmnAk0wHYHXrR1GBkUmOnFLg9jQIQ4x70rAjH pQFJppb+GmA8EevNDfjSDBXNJk460AOUinBqZ06c0ucsOKYiQHmgtxjFJuAOCKQMM460CHAHt0ox 8v40inr6U4dfb0oATG7ocGg8EZNI4AOQcU0tkc8+1MQucGnZyOaaoUcZpcYpiIZrWG6jMc0YYHsa 52+8LFfms5MD+63+NdSMbc5/GlyCeeKlwTC9jz2TStQt2INsx9wMj9Kr7L1CcWzf98mvSQPUUFF7 gUJTXUd12POlstWuV2xWrg+u01btvA9/ckPeTBVPYnP6V3ikLx2qZSVOO1NRb3ZLfZGFp/haw0/a 4j82UfxPz+lbO0A8DFTK2aYatK2wtyLaOwp49MU704pCcHp+FUITceAeMU4gED5uKaeDzzmnZXZ7 0AKNoPrTxtxkUzjbkCheORTAlHXrinluOlQh/apA3y4AxQIeB8op3OfSo1Y96kMgpgSKcc/lTyxy CTyah5I46U9X5GO3amImxnJ7UKcEkDmmbyegpRnv1piEms7O8QLcWscuc58xA1Yt14H0e4JMMUlp k/8ALByB+R4rfTG0fzqyjBR1z2NLlTF6Hnt78NC4LWt9FIvZZ4sE/itYF18OdXhBZbASL2NvKD+h wa9mGAMcVJGBvBApezXQOZnzvd+Hb2ybE8FzAfSWFgPzqgbG4/gaOT2Vxn8q+plAKgcHB78ise+8 P6ZfybbjT7R+ckmIc/iKTg0NTZ82vBdx8tDIB9KhMzr1BH1r6Gm+H3hyXLC3lgJH/LtMygfzrKuP hVazZNrqdwuOgnjSQH+tTysfOeHC6YdGNPF9Iv8AGa9Yn+D18w/dXGmy+xV4/wBeRWJefCjWbdyq 6aJvT7Ncq+fwODS1Hzo4ZdTmXo5/Op01qdf48/Wty4+HOtQkg6Tqa444g3j81JrGuPDN1b/6wTR/ 9dYHT+Yo5h8yJF8QTAcmrMfiVh1B/Osc6RMPuzwn/gYH86b/AGPe9kVv91gaLjujoU8SRn7wJqwn iG0PJUg1ybabfKOYH/KomtLtOsLj8KAujuovEFiwAYkfjVldZ0psbpGH415z5dwvWNvypD54/gf8 qn5jTiemreaJIQGuXXns1SbNFYYW+bJP9/oK8t82VezUv2mQevFS4vux+72PVl0vRJc51Qqe2Gp6 6JYP/q9WXHbLDk15OLyUD7zfnS/bpf77fnUckv5irw7Hra+FYpOV1WMn3K0w+EWYuUv4TjnoK8pX Up1PEr/nUg1i7HSd/wA6XJU/mD92eknwpclgqTxOT6Ch/COoKQAYiTxjmvOk1+/jOVuZB/wI1ZTx XqiMGF5KMf7RocavcPcO1bwvqayFFjV2HUA1A2hanETvtj+Brm4vHGsRHIu3z7mrsfxF1dVKtMGB 67gDStV8gtHuaR0m9XBe0kHfpmmPYyqButmH1UimQ/Ei8QANDE3GDxitCH4lwmMJPYIw7nNL96ug ci7mFLCEHKEe1VjGpIHIro5PGukXJBNn5f61Auq6BOctw2c8rVKpJaOIez8zDaA5IBzTGt3HO38j XWRW+hXYAjulRvQtxVseEluE3217G5PIXINHt0txOmzhHiKnG00xkGORiuvn8I6nH83lhgPSsq60 e8txiS3ce+2rjWi+pPKzBZR9aiKZP1rQktmXqpGPUVAUxxWilcViqYlyMgdad9h8071QiLnDf3vp Uvl4GTkgDrXXa7qNrqPkLYWcUMcNukapGOgA5P1NWkmtRehwciSwscEgD0phaSVT91s9yOa1L8qs QyuGxz71mQfxY9ah2uPodtoXifS9P0+G0kini2LhmwGBPc+tdHb67pt1/qb2I/7LHaf1rysnA6Uw 4FWpWElE9oSQNHkHKnuOacjgdeK8chvrq2IaC4ljP+yxFbVn4x1O1O2ZluF/2xg/mKOZD5ex6WeW 45x3pgOScVz2n+MdNvSElLW0h4w/K/nW+rKyhlIIPQjnNMWw/dxzSjkcimFjxxSZY9KQDmySAeMU 3PWjLNgHoKUjAzQMZzTlJB56Uq9aazDp1oARvvAgikPB9aQYxjNI/TApABPtRkE4xTATT/daAGls EnFLndznFBJ5zjFMbk9KAHE5oBxTd23HFDAe+aYC9Wyc49aYR6CnlgqgYxUef7tIBCpHbNAZj7Cn FsDGKQEEHFAA2Ac5zSZyMHig9DTPMA4NAAeDijjGe9NYgnIoHP40AByO9IcgZz+FKTgYpvNIBd54 zxQR2pMEjrzQM9+tAwxjpQvUU3dt60obDZoAtYOPwpwxmmbs4+gpe9c5uOyM09T1qMEZpy5HTmgB c0uT2pN2O1AOaAJFX5eaUdPamA+hqRCCtMAx6c00HnGKdjkkUcjrQIdwOnSgEZ/nSZDAUp4oAdx0 pGYYA70A00jJFNASISBz0pVHzcmmA07JpiFbIPWmj9aezdzUZIB+U0AOAahicc0gYg0oIagBUPGD TscAimHqMU8ECgQHJpFHvRkZ4FIeuMUwHZK96dkGm5o5OaaEOJpqt29aTGO9Ck8ggGmSyTAPNIT0 oDgcYozjmgBAecdKcxNRliRuBxS5bHvTAeGxSscmol4PWnk4GOtAhcd+1KD05pFbsTThg59KYEoN JwWyTTQBjrQ4OM0xDlPBBzimFiFA/nQHz27UgAOecUAOOdo9TRkkAYpeccmm57DnFMB+dvQ5o2+j UA8ehpeSOxpiHAkdxT1bnLEYqEAdCaXaCeuRQJk3JJIp3JAz1qLJ4AqQYB64piJQ2fvGpFVWquG5 wDxUwYimBIqtnk1ICNuD1qEbuMmlLfMOlMRMCcYHAJqTdxk4zVdWZWzmnmRWxkj3BpgW0Ylsgexx U6NyVcbV9upqorsSCKuQsOCTz70yWS7yFCLwvTPepoyd3PTNQyuiAFQBz0602ObexBGBQBcIAOF6 E54p4clAARgc8GouDjONvHAFPLRhCVIBHtzSYWJUaViAuNuefSp4SkaEHgHqe1U4mbO5jgfrT0k2 pgszHJ+ZjUtDLwlG5QMsAOM8Cl+0icEOwdR/f6Csm6lubmZbeBljUj97IeePQVetreK3hjj4Pl+v b6UrD0CW1s7kbGsLafHeSFSP1FZ03g/w3KTLcaJYs54J8kLj8BWuJC2dhpqplclSxzyCaVkFjnJf AHhOQbY9DRWP8Syuv8jVZvhn4WVWLwXkbYwqrePgH1rrHnGdp4A756VE2JQOM59afKhWOEn+GOiE EQ3WoA44/fAjP4iqT/CmzIONSul9Mqjc/lXouREp6MvuOlV5ZkAb5ctxijlQWPNpPhTESduqkY67 7Zf6GqUnwqfG5dRt2HvbEf8As1enM4JC4+rVEzbmYDgehp8iFdnlU3wtuVQMtzYuT2Mbg1Qf4Z34 BPl2bcdpGH9K9glK7M43HGOagyu3OR04GaTpod2eNzfDfUl+7ZxuPWOcH+YFUZfAWoKCfsE4/wB1 lP8AWvbfvdMD6VHgE5YA0vZhdnhcngjUkzmxvFx/0zz/ACNUpfC15Fy0Uy/70LD+le/Ngg/LUe3k dFo9mPmZ89tok69WAPuCP51EdKn7Mh+jCvoYxh+qg4/vDNU7jS7OQfPZwEnrmMGp5GPmZ4C2nXS/ 8sz+FRtb3CdY2Fe6v4c0iTO6wiBPcDH8qpyeENJZsbJUz/ckP9aORhzM8SPmL1BFHmMK9em8C2b5 2XMoH+0it/hWbcfD3ORHNEx77kK/yJqbND5jzZbh16MRVuHV7uD/AFc7r9GrqJ/AF2pbbGjY/uSf 41lXHhC+hzmCYAf7Gf5UilMfbeNdatsbL2T8Tmta3+JGohQtwkU6js61ysuiXURxjn0IxVV7K5j6 xtUOnF9Cvas76PxnpN0SL3TcZ6mM09J/C99nE7wE/wB5eK84IdfvKR+FAlYHqan2Memg+dPdHoV1 oceVNhdwXSMOVV8MPzrGxqXh64Eklu/lno2MjFc0l3KnIcj8auxa7exAKLhyvoTkVVpWsL3b3HXt 62o3JZY9pP8ACBgCkjgMac5BrQt/EzRpse2t3B6nyxn86uDWdJuUCzWrRt3ZGz+lK8l0C1+pisOO aiZa2J006Yj7Ncfg4xVZ9Nc8xurfQ1XP3FylBR84ye9Nc5JOasvayx5LIcDvVZxgdMVSdxCRIHLZ yAFJrU0nxJfaQwRXMlvnmJzx+HpWbEwWGU9+AKjABiJPXNMdz1fSNctNYi3QNtkA+aJjyP8AGtNW IBxXjFvPNazrNDI0ci8qynFeheHvE0eqAW90RHdjp6SfT39qpS7ia6o6QHcf51JtUios7ScZzSlv emIdjI49KYAaVeDxzSNnJOaAGrjJz+tKSB/jTOvOKQFifagByjJoJIJB6UcDFNI545pDFZgKRWXO APzprc/Smg7e1ADz8zZIpDyfenZFIPu5zTARjxyOaYflGakJyMYqNiMcmgA3Z70Hg03AA5pecZpA NzkHHNMYgDJpRnNBUhsmgBBgjNLnpg0pxTB96gAYc9aQtjrzTu3amlie1AxQcDgU08c009c0buOl AC8HkmlUjOajB554p6nDUgLOemPSnZ70mCMcdhSgH+7XObinn7tLj1ODSFScdaCuOeTQBKCe/NIW HpUYBz3qQqTg4NACg8YxzThxTVUjnBpcMT0NMB4NA5pAGx0NJlumKAHjjrQcZ5pNrYzg8UmGJ6UC JM8UwvnoKUZxyKcvTG39KYCDJPtT9wxg9aTaQc4OKbyW6GgQ4kE0mMcikYMORmnhDjvTAOgz3oxg 5HegehBo2t6GgQ4EEe9AIPbNM2MOxzUir0yKYDRx3pwIzntTWU9MUKvqDQA/bk57UpAzgE00bwcA GlIY545piYhyM9OKAeM0w7ie4pwBx0NMQuc9aBk5GaQBsYwcUDKnABxQIAME560/O3tSYJ7Uhzjj NMA5zmnZ74pvPcGlUnHQj8KBAOucU4HBFCqeozilKkDODTAMn8KcrcdabkjsaMnrg0xDwcA004Bz g0EHGSDzSKCf4TTAduLDmnBcdPSm4JPSlORwFoATJJ96k5wB3pF4PKmlJbdwDQAgwG6j8KeDxUYX nOD+VP8AmxjBpoQpb5etKoGODzSY4xtJpyqfemIfzgfpTwflB6fSozkAfKTThvA4BxTEThvlA/Og Mp9MimKrN68dsUmzk8c5poCfcMAU5ApJzx6VFsPXB/KpQTgDBz9KYiVWA4z0qRWbH3uKiC8g7Tip gmFzyKLCHrJs46g804TE4xn1qNR3PTtxSjIbIQ8etMC4rsyY547U9J1GR1I7Y61TAYsDyc1IGIIw h+tAF5ZDIRjIX0PWpNoAOcYHeqcYkbOOAOgxU7kqhGMnHXFICeN8N8oCqec4xmpd6hhubIqiHYr0 JJ796liB/usPfFJoZcaYKgP3ecZ9KZl3+bBx796YrA7lAOfpSDzGYg7gB2FKwEhhz825gfUimOoB X5ipx/epzssYHJ56Z61AxJb5YSzHvjpRYQ2QIVOW+mO9QLtDZ+8MflUzI4LIyHOeNlRGEICCHY9x 2qkAyZgq5Kj24qqzMxPAAz19Kszow+d1VFJ4B4Jz6CoXz0RWGP8AZxQBASpGSXI7YFAYdQAB6E5o cEbs7uOaaU2ryDu9CKAGMMtxnNMYjldvA704qWOccGmkHHA4oAYSMDpkfrQWG3p09KTb14ORzwKQ 7z/AcGgYzJwcU3IJz1+tLhs4KnJ9aaIyr8jikAjNuYknNN45ByadsKZwvH0pDuI+6aBEZyvQU3kn gZNSYJHANMYHPQ0hkW3HXrSFRjGOKlKsRgA1GVAPfOfSkOxC0COpV0Vx6MM1QuNB06cHdaxg+qja f0rUII5GcVG4cnhcUrILHM3Pg6xkyY2dM+uGFZF34CHJikib6gr/AI13wQkDg8UjD+HBpcqGeT3X gq9hBxC+MZyuGFY8+h3cJ5U/ipFe3mPjlSahlgWYAMgPswzS5Quzwl7W4i+9G1RbmU8givbJ9BsL gHfbKCe6DFYl54JtpcmJiPZlzS5WO55gJWHOalS7kTo5H411l14EulBaJN2P7p/pWDdeHb21J3RO Mf3lIqbApEa6pNjDNkehpHu1l6qKqPZzxn5o2/KovmXqCKVkVcuHaehpSSI9oHfOapBzUizEd6YF jPqKehKsHVirA5BB5FQCfOM4p4mT0ouB6P4d1s6hEtvcyg3IHyk/xj/GugXgdea8eguXjlWSBmV1 OQR2r0nw/q51Sz3OMXCcPjv71UZLZia6m0X9cD6U0tkcngUCMnkg0hHAOCO1UIbnnA4pc4HWk2k5 4P40oUknOR7YoGJkkZBpCeOtGD2U01lc44OKQDZGORilRWPJpDGSQSOnapDk/dzmlZ3AZ/F9KCST 9aQgjrnNKFI5weKoBN20kU3AbqaftJ7UwhgcBTQAhYYoDNjjOKQg7uhpQrAEnOKAGg9xQCSKcBnj BpuCo6HFIBuQT1xSDIyc0bTuzjApBkEjBoAQjoaXtzRk5wQaGyB0oAQnNIRgUrHPamZJ9aBgORnF O2nIpAT6cUb/AJhwaAP/2Q= /9j/4AAQSkZJRgABAQEBLAEsAAD/4RWdRXhpZgAASUkqAAgAAAAWAA4BAgALAAAAFgEAAA8BAgAG AAAAIgEAABABAgALAAAAKAEAABIBAwABAAAAAQCb/xoBBQABAAAANAEAABsBBQABAAAAPAEAACgB AwABAAAAAgCH/zEBAgAQAAAARAEAADIBAgAUAAAAVAEAABMCAwABAAAAAgCM/2mHBAABAAAAcAEA AAGkAwABAAAAAAB//wKkAwABAAAAAACM/wOkAwABAAAAAACK/wSkBQABAAAAaAEAAAWkAwABAAAA JgCB/wakAwABAAAAAAB//wekAwABAAAAAAB5/wikAwABAAAAAAB6/wmkAwABAAAAAACI/wqkAwAB AAAAAACB/wykAwABAAAAAAB0/1YDAAAgICAgICAgICAgAABOSUtPTgBDT09MUElYIEwxAAAsAQAA AQAAACwBAAABAAAAQ09PTFBJWCBMMSBWMS4yADIwMDc6MDM6MTAgMjA6MjU6MjIAAAAAAGQAAAAW AJqCBQABAAAAfgIAAJ2CBQABAAAAhgIAACKIAwABAAAAAgCC/yeIAwABAAAAMgCC/wCQBwAEAAAA MDIyMAOQAgAUAAAAjgIAAASQAgAUAAAAogIAAAGRBwAEAAAAAQIDAAKRBQABAAAAtgIAAASSCgAB AAAAvgIAAAWSBQABAAAAxgIAAAeSAwABAAAABQB2/wiSAwABAAAAAABy/wmSAwABAAAAGQBz/wqS BQABAAAAzgIAAIaSBwCAAAAA1gIAAACgBwAEAAAAMDEwMAGgAwABAAAAAQBz/wKgBAABAAAAAAQA AAOgBAABAAAAAAMAAACjBwABAAAAA2Bq/wGjBwABAAAAAVpl/wAAAAAKAAAAQAEAADEAAAAKAAAA MjAwNzowMzoxMCAyMDoyNToyMgAyMDA3OjAzOjEwIDIwOjI1OjIyAAIAAAABAAAAAAAAAAoAAAAe AAAACgAAAD8AAAAKAAAAAAAAAAAAAAAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAgICAgICAgICAgICAgICAgICAgIAAGAAMBAwABAAAABgAAABoBBQABAAAApAMAABsB BQABAAAArAMAACgBAwABAAAAAgAAAAECBAABAAAAtAMAAAICBAABAAAA4REAAAAAAAAsAQAAAQAA ACwBAAABAAAA/9j/2wCEAAQDAwQDAgQEAwQFBAQFBgsHBgYGBg4KCggLEA4RERAOEA8SFBoWEhMZ FA8QFx8XGRscHR4dERYgIyAdIhodHRwBBAUFBgYGDQcHDRwTEBMcHBwcHBwcHBwcHBwcHBwcHBwc HBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHBwcHP/AABEIAHgAoAMBIQACEQEDEQH/xAGiAAAB BQEBAQEBAQAAAAAAAAAAAQIDBAUGBwgJCgsQAAIBAwMCBAMFBQQEAAABfQECAwAEEQUSITFBBhNR YQcicRQygZGhCCNCscEVUtHwJDNicoIJChYXGBkaJSYnKCkqNDU2Nzg5OkNERUZHSElKU1RVVldY WVpjZGVmZ2hpanN0dXZ3eHl6g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TF xsfIycrS09TV1tfY2drh4uPk5ebn6Onq8fLz9PX29/j5+gEAAwEBAQEBAQEBAQAAAAAAAAECAwQF BgcICQoLEQACAQIEBAMEBwUEBAABAncAAQIDEQQFITEGEkFRB2FxEyIygQgUQpGhscEJIzNS8BVi ctEKFiQ04SXxFxgZGiYnKCkqNTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqC g4SFhoeIiYqSk5SVlpeYmZqio6Slpqeoqaqys7S1tre4ubrCw8TFxsfIycrS09TV1tfY2dri4+Tl 5ufo6ery8/T19vf4+fr/2gAMAwEAAhEDEQA/APrdAwOV5weR0qykoYDOcjnFaEkqsSwzipVLE8jg Doe9IY6NyrHsB7U9zls8AAdSKBhjKe1C8denakA3aD90Ckf5HAxkEc0hjHB24BwfeoNuWI7n0FAD Dwg7/X1qvINrZHBpiIh0ORyOhqrKm7cEAz7GmBnzIS4LHax4xnpVGRBHE6nKgHOB3/wqkBnXEJKH GXB7MtZ8lpsOU+U9cL1xTuB6WnyqpYkj+L/PrViMneBgDjFQBNyhAA4qTd0DjtSAnQkoR2HFPRBn 5mxj8KBiqqF+c5HQGnHbvHU0gAjHU9+MGmtEpJOTj0pAQFdxIGfxprbV7ZPpQMicDjcMD+lMlIIx j5SKYinPkDJUYHOOmahZWZCQucHv1piKUkbYAfhgexrPnUo/XcW45ORVAZ0pBUgqpUevas1yhcsx wFXjH+femM9NRAEOz5sjGO361Mg8uMYGR7VAhw+aQZx+VTIgXI75z9aBkvb5eOfSlxgDHHrQA7bg ggE571JsLfxUmAxlOQM5GePX6Ur44wDk8UhkJ6gcgAVGTtGfvA0ARO5IwFO36dKhY7j8x6Dv60xE Ex/P061WLEAFfmGcHB5pgVZGDSZJ5x0NUpyzMGVgwPcUwM65iJIcj5T6dqzZFCq2DgEYOec1QHpK D5eW688VMpLDKkBR61IiaNQGwp4xxzkVN8zL2/CkAgUuQQPcmpVUcYOCD0oKJNpY4yeffmtG5git dGknkGHRCxJPSpbEYelXsepaHZ38SSRJdwJOiuuGAZQQCOxwanILZBJ9yaBkLr8zHP61F1bkEA0A IWU8c49QOtQSRH+AimIquCWA5IHtUL4BIyCTxg0wIJkRoyDtHUD2qhPDgFjkgYpoRnSFUnZR1x+H 5VRn2pKy79icZAbJP4VQz0RYyJQJBjP+eRU0agMBznJ4/rUiJ0TJzHyKk+6xDZ/CkA88gcjp3p6r lyQQSPSgZo6dCJZt7DhOmaualt/s2UOAVKkEGpYHG+G7gX/hOxnRNqmIIvuF4H8s1psfl6igZC8b 44GeeOOtNKZTDfJ7ZoArMmCeeOvWmmEt8wB3HsaYiCRQDjJJHftVTygWYg4OPpTAgIJcq68noOOP pVS4IOMM2M49M/jVIChJGoRvLZAp7hs/1rMuI8yNtJHH0xTGejABRhOfUU9OFwOWz6c1JJYXGzp8 3Wn7S2CQaQyVQWQ5G4DuO1SBACCuc9gKBm1p0e20yerHNc38S9afQ/h3qV1bDdcrCRAv96Q8Iv4s QPxqHsC3ItA0pND8IaZpUBJFnbRwbj/GVUAn8TzV5kBPPPrTGc94y8UQeE9BEywfa764byrK1DbT M+OST2UDlj2HqSBUHg/Xz4n8HW1+/M2THNtiZEZx1ZQ38LZBHJ4PWub28fb+x8rmvsn7L2nmazth hkfWm+bkKeTz2rqMCNk8x9xPsAKqSR9sgY4AximIqTA7ipwM9OOKottKlCBwcYz19/amMpyybEYq rAg4GOfbms2VjvMpOCueMcfiKYz0FQi4UYX15qZELICB8q9OeKQiVcjJ44PUGrCYwM5we1ICVGGS pG33xUyxhiNqqc+lAzfiXZCo7AV5v49lGq+NfDGi/fjlvhdzrnpHADID/wB/BGPxqGCOldCq5Qbj kZ+n+earajeW2k6VcX2oSiG1t4y8jn0Ht6+g7k4obSV2UlfRHjs1pqXjzx4kt1EEinjCeUSCLeEc mE89SdrOf4vu9AK9jgs4NL0yK0t12pHwCOpOeSce/wDOvEy5OrUniX10X9fcehi3yRjRXQryrjgH J6c9a5iLXpG+JV1ockAEUViLlJATnO4Ag/8AfS4/3T1yMexOfK4ru7HBGN032NydyHIXhRVSeTgD gHHatjMqswUAMSCe49Ko3K/unYD5c8gcH+VMCk+RuCsxfPy5PH51SLcsH2glvf8ATimM7dMscqBg nsegq4HG0IoXP0/WkImQBUyV+b1qYHGNxxmkBMrKy7VP5VctIybpAenWkykbUjbISfQV5jpqDWPj PrOocNFpdkllFntJI2+T9Eh/Ooe6COx2DA7dvOScYrxX4h+ItUvvFX9n2enG7s7KbbCjZWKW4XBM kpGDsQsMKOWYZ4A3Dy80rezoWXXQ7sHTU6mvQ9G8I6NJo2irLqLrNqVwoMziJUA46BVAUfh+uK2J n3txx7ZrswtH2NGMOxz1p883IgkZGJ6gjufSvOba6hn/AGitRiEigLpflhifvuHjLAepUEEgdNwz 1p12lKF+/wCjFTvaXodlI5BZTjaeck4zVZ3WRCABxxXWYFSeQ+XuJBVT17VAzg27Bw2QM4zjNMZS cCRCAwyOec/yrPuA20hEAwcZzxn6UwO3i+Z9wI59OtWl4j4ILA+lIROjF3Ung98mpwQznDng4x1F AyaGPAHoD9K1dNTM7HnjjmpYyXWLtbPTZHY4CqSa4P4ZRGfwfcas4OdYv5r0E9WQtsiP4xxofxqP tDXwjviD4t0/wx4RuzcThruVPLjgTmQluAdvJPoBjkkDvXNfDPSvtFpHdapeeZdxNumtZJlkljlP zO0mO+W6DjuCcgDx6yp18ZGEn8OvzR3w5qeHckt/yPRrl1wcE7TznpVZnAQ4OMjAJr2keeRn769x 6eleLK0TftP6UsX+sUakZjvzyRCFyO3A/Q15mMv7WlbuddC3JP0PV5o1KjDH5V6Cqkr5kZeTgZ5N eojjKlwT8p3YbgHHGM+5qkTsckknBJwe/wDniqAz7x/LbAbPzdcc+mP8+tVTc/IYuqFcgn/9XWmM 7SGRmhUk/N04OelWkcluW3Z9Bn9KTEWkf5gM1PExBwBnnp60AXonCpuJCgcnIrVsYgV81XKb8MOM dvSpYzifitca2PD8Gm+GbU32o6rMbOElwiwkozGRj2VQhP5DvXU6TpMWg+G9P0uzAWCytkt48j+F FCj+VQt2PofOmpeFvFV18U7eTxF4cklNvcy339p2V+DM6rlVK5QDJBP7rJ2jGOeR6F4E+HDeEfEG qapdam99NdKI4FBKqIuCWcZ5kJHXoAABXzuBwqeKlOpfmhf017HrYnEfuVCGzt+B3Ekq9epPXFU3 lYfKDwfxr6U8gbHNyRuUkg14jZaxBcftURkQuZZYb4BniKqDG4jG3PX5Yzk/7Q5Oa87FN+1pepvT lFRkn1R6/LM4RhhWA6n0qlNO/BC4GMbsH5uv/wBavSOcqGUSbUEZLL1IOPrVWV8oWyGCgj0H+eKY GZLMTJvkBGDgKTz9P5/4VTadG8z5SxAwBgUxnZ7ZFZssrAnoRV2GRRGPmySSeR2pCLcUwki+b5c/ rViHIb37CgDSiXORk49a5qXwV4kTU5rjRfG11ao7kxwXNoLhIxngcuMj3PP1rKpByWjsaQkovVXH RaH44uvH/h4662mz6Vp9w88t5ZSsjyfunUK0TDjLMOhIwD616LNCGG3GR3zzSipW94mTTfumdqNl DdWbQXMKyxP1RhkVlx28en2EVrDu8iIbY97ljjsMnnjp+FPlXNzdR8ztYpSsA2Tn69qrMVTcVGc9 TjirJK6TCKQBW3E9Mt2rxqwFvN8cdCubW63vLHqDhN6kOGlkyw9cYxx+OMV4+NbWIopLqenhVH2F Vt207b/5HqrF3DA53Dpg96pTXDupUOF7fPgf1/rXsa9DzFYrzSsr7zz7nGT78GqbuTGfmIOf0+lU gM6SUSNiRQBnC81ScrtIWQ5QELk9D68UAdrBdhkVMZwuOR2q3FKirszwOg9DTEW4Zj5SkH1zn61c STLAHHHTHekBrW8gKr2HXFbVqVPDd6TGaCMMAZp/bmpJKF2ylcE47cViXDruII4AoKMq5c5J2nA6 lRz+FUZZ13KBxn1WmBVN4iSEuQ3OMV5DaaLqI+Mmn6lf6L5Gn6fFdRpctLEysXnmkVlUNuXiULyA eDXHWpSnUhJdDopzShJPqegvriLGQoJQgDK/5/zmsq51khgWdxgZVRxzz149P5V2GFjMvvEKtlS5 G3Bw2MMP096y5vER3fLKgjA4A5oGZM/idY5ZPLbIA6Z49f6VnT+KxFJgr1HGD2oTCx6fb6kNpY4D H0GBV2K+yysz5PHHrVkmit+FwqoXAABA7VfhvwJcZJoCxq215nac8/8A162bG/zjLDr361LA0mvw xRkbkHP4VZGpqUJGNvVcHrUjaRkXd+Quwdf51jT35DMC340wMa61JXkJLYPQKMjNZE+qxpn7wQ9d oJI/DvTCxiXWuR+YT9zZxhu9Y1zrTtHlmIPYEjpUsaMG611nnblcAYD7uv1rDu/EjhGHmElW+8P8 KBmFe+Ksgh5DwMjHrnv+ZrEufEjuCfMOVIwO1TcpGPLrzHBD+x5qjNrb7ss+M+9K5SR9FR6mEBO0 jjGcVdtdWZmCh90YABOOF962MbGhFqREO0YAJ5Hr61eh1LlFV8ggjOen+f8APSgZq2+qqu3DHdkg 5rUttZjdwqS5YDjJpAakesebGCxGF6Ec5pH1kRACNvlPPPT6UgKNzrSshIfjHINY11rCeWSXI7gb uD+NA7HO3+sKxBWRQc8Hrgd+/wDn8K52811EkJglXjOSAeT6UrjSOfu9fDK6EjcTjKnFYGpeICEK oduRzmTpU3HY5i78StHu3SZYfyrDk8UxfbcTHYnOCclQ2DtJHORnBPHrwa5sT7V0Zqi7Ss7Ps7ad +p1YZUo14OsrwTV0uqvr26eZn6n4s08+OC63EY0tZYmJMbYZfkDALj/ePIHQ+2edu/FVo3hlVWUR 36MCVKn5vmbdyOOVMeM/8836ZG7yFHHfVcPGMrSXLz31ukveV9dW+v4ntOWX/W8RKcbwfPyW0Sbf uu11ol0/Avax4y0B9SQWbxkK21JRCdgbY4EjjaMqWMJKhTgpJhTkb+O8R+LkvfFV/NYLGlkZmWAR IUUxjhTtPTIAJ9yeleZltPN4YhTxkk4crsk9neOj6t2vq3Lrrrr6maVcnnh3DBQanzK7a3Vparol ezslHpppp9RQ6opiyC3znqDgf5+lalrrKLDgHB4Pt9a+3PhUXP7aCZZG3MR+eBU6a0u/cJO+Tg/n /KgRdTXoxMnllo8nnYOv4Vq2uuqgCFgSAQAefTnj3pXKsXItdddwBTcDyATn8utNufEQZDmTHHQd fwoGZt74jVY18xtjFcdSO/XH+Fc/c+InkLZckDsOn6f0qWxnPXWun5gjnHuetYt1rxbcgJz6jjOa m47HO3OusN2DxnHbiuc1LXiYyUIYc5INQ2WonKXfiAZKqTtPHTpWBdakxmYsQAO9YuR0KKMu4vfM zyc96oyTswxn9aybNEiAHK89aaeOKm4z/9n/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsLDBkSEw8U HRofHh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwLDBgNDRgyIRwh MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjL/wAARCAMA BAADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcICQoL/8QAtRAAAgEDAwIE AwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS0fAkM2JyggkKFhcYGRolJico KSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1dnd4eXqDhIWGh4iJipKTlJWWl5iZ mqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW19jZ2uHi4+Tl5ufo6erx8vP09fb3+Pn6 /8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcICQoL/8QAtREAAgECBAQDBAcFBAQAAQJ3AAEC AxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMzUvAVYnLRChYkNOEl8RcYGRomJygpKjU2Nzg5OkNE RUZHSElKU1RVVldYWVpjZGVmZ2hpanN0dXZ3eHl6goOEhYaHiImKkpOUlZaXmJmaoqOkpaanqKmq srO0tba3uLm6wsPExcbHyMnK0tPU1dbX2Nna4uPk5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEA PwD1ky78ABQcDjaM9KXL9wo+oFKro7DjDYHP4UrxhwQ2d3rVCFVsdSv/AHyKC+TgICPcCoSABtc4 9MUqeYv3l+XsaAJ1Yjuo+iinedIpO1VP1UVHlD/FzQquPunNAEiM7ffCr77RSt/skN+ApmWH3+Kd iPHyk0AOB45xn02ilUv1Krj/AHRSCQrxto3NnAP50AOJ3crtz67RTRJt6hfrtFNVepyQKG3N2G2g CZXUcgA+5UUrS/LkBTn/AGRVaM9Scn2qTCn1WgB7SMSCu0+20U52JUcLn/dFReXg5P5ikZuQP1oA cWZRggfTaKEPJIx9Noo3k9cNTQqkZzg+lAEoc4PC/wDfIpN7YJ2r/wB8imfMB14p4AZfvGgBFL4+ 6v8A3yKeFYjJ2rj/AGRQCgHJJppKtxg0AOaU9AVP0UUoBPzfKf8AgIqHIU/Jwfen5IOW4PtQA4s2 eQuP90UCTHZcem0U0uTjcMj2prRkjcORQA9nJXjb/wB8imozuCDtyP8AZFNTGcD73vS/MW3cZHWg AO5jgbcj/ZFTLIyrtYLjt8ophIYbh94UbWZdwPHcUhkyyb/lIUHt8opp3DPCkf7opAQVwRyOhpck 8g8jtQAgbPykAeh2il3Mey5H+yKbuz1HH8qUAP0OGoAaWwMlQP8AgIpPM9SpH+6KeVbGevqKjwvH y0AK07KMfLn/AHRQsmBk7cn/AGRQmzdkjileJN3TigB2/AyQv5CgSDOdq/8AfIqPy+flOQKUjIwK AJDI7HGFx/uikLuTjj/vkUm4ouOopAcDNADiSOy/98imlip+UL/3yKQ7j2OaTa3WgB4Zs5O0exUU NJk52r+CionyCM8im7ucqCKALAcnkhST/silL7VxhT/wEVF83BPH0pSvGSc5oAXzARxt/wC+RQHI 6hf++RSBBnjml4JOB0oACWdcjAx/sims5IB4P/ARTy23BFNG0PjsaAI95AI+X/vkU8S4AYFc/wC6 KDGM/SlEC84P0oAGlIbcduP90UvmDqhGf90VGcspX0pFVgODmgCdnIHzKv8A3yKi3gqRhf8AvkUu cjGaRYwwPY0AKAQM/KR/uilDHaen/fIph3IvPSnoNyYHWkMQysU+6p/4CKfvbYPlX8hUWCgIJ4py Ln+LFAh7MdoO0D/gIponbcRhf++RT2bjBINRFTnOOKYDjJuH3Vz/ALooDk/ex/3yKZjHtS89hzSA l8046Lj/AHRTSwYdAP8AgIqPcB94c0bs8A/hQAYweMH8BSbmz/CP+AinbccngUzJJwg/OmAu5152 rj/dFIzll4x+Qp3JHzsAPSmFRtwmaAGBiDtIUAf7Ip25icKBj/dFAjdhggCnBQmAX4oAVWJ4wB+A prSENtAX3+UUjlcYXqaZ05xzQA8uNuFxn/dFLynJCnP+yKYqYBYnrQpJJB5HagCSIsSfu5/3RS+e SxGF/wC+RUWWJ+XjFLtKc+tAEhIHzADP+6KY027nCj/gIpoJydxx7UbSTk9KAFGWOSF2np8opfNP 3cLn/dFITztA60mNvP8AEOtAAXKjPyk/7oqF5ZCeg/75FPfk5zyaOgwBk0AKsjKOAuf90U4yFvvB c/7oqE5TrUikBM/xUABDAbgV/wC+RRljzgfkKB8zZY4FI+M45xQAnzM3QfkKUlxwAv5Cm7kUcZpN wAzzmgBGLIcYXP0FL5pI24X/AL5FJuXvnJpVCAdeTTAeJgBgqP8AvkUpZAmeM/7opvlY+bcKYRk8 9KAGq7KSTt57bRSM5wScZ/3RSrGSSc4xTCCzcngUAKsnGTtJ91FKWIXJC/kKaFycleKXABwc4oAY uCOwP+6KUuQcfJ/3yKUiNzwelRMDnAINFwJipxkbfyFRtjHzKv5ChY2xwc0rcjaVouBX+bd8gAH0 FLkt2yfoKeYHxkZxUTttIBBFAD1IxggE/wC6KMqD8yj6bRSK2eACB60m5ASBlmouAx4w7fKAoHqB UDSGJwuAfwFSyhiRuyKZ5O5geQKYDw25wGCgfQVZZBsBjC/kKqqnzetKGdG+U/hRqIVxk/MoH/AR Td2DjAx9BUomVuHHPrTJYiRmNhii4DMnPy4/IUZBHIGf90Uw7lPynOOopd+8cgA0ARSBl5wPYACm /v8Aq4Cr7qKmDmMkgbjSGRpR+94FAxiF3G0OoH+6KZNtj4UBz64FTtHHt/dtn3qAOI88biKYisXY HhQPwFNZ2buuf90VYZ97ZK8elMYKf+WeDSHciEsiEDCn8BUonU8OAT/uik8vjpk0OMDBQA0ASbx2 KgfQUGUk7cgr9BVYr2BpwypBGKBE+O+F/wC+RSDAkBwAB7Cmi4J7HApAyPKOwzRcDqXHmNkDaQBx +FIrMTtydvc+lPlRlYB/QYI+lMwxPzfKfbvSAdtC/wC2D39KXcVXDHKmgNj7gx6im7cnK/lQA1to 5AyKekhPAamj5eQMjuKVWRWzjAoAm3HoVoIUjKjBo8/K4XBHrTQVPcg0APG5fQ0cPxnFKvTJ6U8K jjOaAGhiBgj5aC27p0pGDA8cim5BOAOaQEqMpBBGBSK/OAOPehUC8tz7U1+/OPamBIHCg45Poai4 aQ5+U0w8sMHBqQE9T8woAcIyMk9PUUmAfvHNDHI+Uke1NwWAIHSgCQ7VXhuPSkVvlwDRtUjJBBp2 FCdf0oAjHvUqtk4A49aaFXA60HavqBQA6Tap4wab5mAO/tTHx2Xj2oVAAD1pASoBncOvoaeTxz8p qMZI5496Aw2lGOfQ0AB5PI57GgEgE/xDqKRXK/Kw4ppO5sk8j9aBjiy7d4696MlACpyD1FMVWAL9 vSpE4G4d+1ABv6HHFSghhx94U0gqu4DKnrTQADnn2NAEpyBkc+ophx9PQ0odl5xuFG9fTg9qAAZP IbkU0yAZ+X6ighCQM9e9IcqfUUAIGRjjoaUowIwTg0wqp5xg1LHIV+UjIoAYCyGnFs9+falKAvvB x7UgxvOOKAEWXafnFOLZ5AAoZARkgmkEftigBd+e9IT+XvQB2J4pxwRgAmkA3cegFOwpHIxTCSvS mM7MuSaYErfJg5zUYbc3HFNByR1qXYDyTk+1IBS3GO/qKOVIbPFMZCp+Y8GnovJXqMcUAGzJ56da YcsMKOVqQDbyx6UpIVsgcGmA09VbP1pQcOfakxww701uVDHrSAkKqWOeM96iUYJGe9PLFkHHSmt8 sg5yDQAjKR1FOQ4HHPtTpDsHB4pqqGG4NzQA4DI/pTT1wgxTejcnJpxLYGKAEZOMtzQcMOBimtuP UU08Kf6UDJAMDkZ96CR0BNNRwUFPAz939aADGeSQaaWwemPekCEHLHmnlsL0zQAmAR1zTRgHilVC 3PT2pJAM+lAhQynqeaYxJOM4pNmBnt600jLcc0DHYA560u8kfKMUwK3TNO4HYk0CGsWPfNKqgj1p N7HgAAU1Awkxnj1pgPK7TkjAoALA+lSOPlHemAOx46UAMKYGCxpN+RgDpUhwM9zTY1wxJ/KgB67F wc9etOVdwIPQdKYIgzlc8dqaxIOAelACtGX+cH7tLvGAO9IJdhwe9NyFz6mgB8mFxjrUe45zj5u9 IfVuvaj5i2aAF6fKOc0gO0YHNPZQvC9TTFcDIZefWgBrOoO096RoyAGByKe0YwWPOaRRtGQcj0NA DRk/e4oZsnb2pd276U0gHtxQAfKTwtAfBxtBNGdpwFpSyjHyc0AOGFOSBmjIJyVFIroTllpd8ZPQ 4oARsZyV4pu5GPCmlZVfrkCjai8K2KABpFIxjFRDrx0pzkAYGDTWbavAzQA/eOg6+lRsxyRipBGh TceGNM2lV65oAZ8p6D60wIjNk5FKW5Ix+NKGVR81MBpXByCcU0lu7VKSGHyk1GwHqaAGkyBfleo1 VpHAkzzUh6gg0ryKvXOfagRHNAyH5G4FRo5BwOvrVhPLb5nYkelK0kbHEceTQMiDhRl/mpP9Zkg4 HpSPbsQSzhfaiNAuTuoAXodqjmh1IHvSCZWOO4pyzc7SMj1oArsrd+Pegq4X5WNTswY96YUIOVb8 DTEMEZI96jNtLnJ6VOSccnBpgEp5DErRcdivl0bCg/jRvJPzDPtUxQE43EfWkeFV6Nk0gI/lIwfl FNVHXOwAr6mhkI6nPtRvcfKGwKADMfc/N6UpR3I6AVE2GcBVy1OYShCCeR6UwFdNhwoLe9QOT6YP 1pRJt4LEn0oDg8GMmgBUXAy20ikZUIJQ4NTQpDISGG2o5YSGO0/KKAIUDkbSAaUR7XUE85oTasnO adIdsgPXmgDrzJyFk+6QMH8Khdcd8r2PpSud5BHMeB+HFKrhBg/MppACgnHOG7H1pTjr0YdqCpA5 PydsdqXrwevY+tAhpzI3yjBpNqo2X/GngHPzHBpfLSQnHPvQBDsjIJUke1OG8rjbkUpVV6r+NKHP AVs+1AAB/t49qkBII+XHvUTkEDIwRT2d/LBHK96AJCcng0hXueKjU9No2/Wnb+enNIYodk5xmjcJ j06d6aSemCacAAACaBDlVSDnk9qTaR8vYUB/mJAwBQW/d89T1oGKxAGBwTQqcYJxUYyxz+VSEKEy x6UxDmLKmD+dDE7BTsZiyp3D0ppUMgxwfQ0gGmTDAYNNJLkHjHpTxH83Iz7UeWA3yjn0oGKq4PHH sacdo9j603cc4f8AKpkCshz0oAhJJ6/mKUqq/N69RSnCn5Dge9JlR7NQA8lXTAPNQqB9wj8aHyOS B+FRl2JDUASlW3Yz0/WnKwJ4HTqKYjLghuWNPaIqNynBoAk5Vcocj0phf/ZxQAdu4D64oBx0wwPa gB6hWGVO00EbT865HqKadvb8qVWYcA59jQAwmPpTk6YJ496H2t/DhqjKEdOBQBOYienIqM4BIINC tImD2qTzlcYcYPrQBENwbK8ilKlyCSBSkIp65BpRtXoM0AJltwUnj2pxGVwuSaA+TkYFJyQTzSAa PfGafknvSKpC52j8aCe2c+woAUbQen50jBW6UwjP3gaAHA4PFMB5AU88UmCTkDFIcfeyTTtxPQYz SAa4wcscinByVBAxikdcDr+NKq8kE8EUAI3D+uRSgho8E4xSE5QexoKAn696AFB5BHQ8Uu0ZZevc VFnZ8vXFSswO1s0AR8k7c9aciKwIJ5FGw7uO1DLyRuwetADHABwxNOUBdozxSmMFeXp2xQBh6AFK qG+9SF8Z5pSoDj5hSmLc33hQBCHLAgEYoLBU5ANIytGxHUU0IXU80DGx4DnH4CpSWPLDH0pgDA52 8CpNy4yDz70CAE9uR70ZXvwaDk9R+VJt/L3oAcXcDgAikzk+h96TIUcDmk3bj82DQArLTcKDzxUm c8Lx9aZ5a/xHmgBpkB4Wm/NzzipQgB7CkZQOp4pgIqLjJpXAC/KOai38nFIXJHOaAJ1fcnGBTAOc B+aiU7TjHWnliBwB+FAC+WQcufxpOFORyKQ529fwpMENgAgGgB4BZc5xihyq9BnNMwxbDcCplXch XHTvSGQrHwXJ5Hak27yGxT3BbgHA6GkDFBtx9KYhpBZsZpzIFHoaUAdTwaaSRyeR2oAEOF5+92pp YoctyDTgOd+efSgKT978KAGhgeQfwpp+ZjjihwM46e9NCZbGePWgBQ2PpQcMfl4FOZTjA5FNBCfW gY1gY+B81G7YMsvNSDYVLZw1M5bknigQ1Rv5xj2qbAUfdNRchsA08O4OAc0ALvU9M03I6AjNNJye OPWgEZwoz60APWNQMkg1Ew5NOZlXBYU1ir+y0ARhmB2nmpAyrxmlXbj5eTSMity2M0ANKrnPGaim jz0HNTBFYYOQKXy1A65p3AojzIm9qm3K55ODUvkYB+bOaZ5LjkYNAAqjOc050iYZzzTA7ocYFIzl +gGaQEEkWw58zj0qWMKF+Vj9aaQ6NkqDUkc5Y42AUwIyI0OW3MfemPIGG1Ise5qy5TIOKhdGflUP 1NAFdIgGyzAGp1kT7rDj1pBbP1bFIVToKAJwoX5kwarSz+owaQMYzxSsY5Bh+G9aPUQwPG4xg08Z UfIxx6VWMDococilRznAzn3oGWGYv1xmmNnGAoPvQckcjJ9aYUlxhQcUAOHlKM4O6qzxiV8scfSr A+Vfmxn3qPDO3TC+tADGXyx8p4qSPJznGCKaUAzg7jTYw28bsn2oAAqruwoz6mpVQhQwxk0jofNA bgU9QNjYPTpTArSx7Tljz7U1VfrnANSyuvynqaZyRyePSkMb2wFzjvTWKtjI5BqUyYGAuAaWBIzI Ax5NFwOlyAwx8owMj8KZI23JRfl75prOu4HgcDn8KlXYRknNAiJJgo2nkVIoYjn7vYntTGUCT5OV PX2p4fDbJDx2IoEDMAdrjJ7U/d9B7CmFFc+tKUKjhhSGKQxHAwPU01VVumSfakL7PvLupPOkH3VA WmIk2sq/NjFR7RkqpPrUiMH+VwST3pQpKkN1WgZEpzjd2qdQzcADFRk4kwPutUill9sUgFxhs55p q4AJPLGgriQ7mwDTQx5CqPrQIUsOmKVUJIJORTNp5PepFJGCx/KgY7qwAprxgt9KRnJfA4NKw6DO DQIeBheePcUhDFQM/jSI7ICCMijgrlT36UATKdrDcPxqN+JNw4pwb5gM8+hocKWG4YoGMDknoCKA QD1INDoNwwwpRkdBQAuWPcEUpKcbRk004H3ufpTCEzkErQBKFPUHPqDSYVmCkbablwueuehqSNgR +9B+tACeQN2c0rBlGOuac0ag/I+KZhw+W/SgBwXH3Tg+hqNgVPI/GpS4I+cfjTT0weRQAxGGfm/O pQA3uPUVEUbHy8j0oHsSpoAmKnqCCKZux1GRSbnBzmnMQ2Mjn2pAGUb7rYPpTCG3EetKUQH5sAeo oD7DwM0wGKg/jzTxgcqpIoZ2YgrjHpQJQMgjbQBIgOzOAKax2jBPWkLA8L1NNYhmIOARSAczrgYJ pisPMyoxSLHznqKemDn5aYD3cMSGpoBC5AJFC98c+xp/AHHBpANAITg/hTgQByMUMeNrD8RSNkYA O4elACSDp6e1KBhSRz701juI2duoo8wFeBg0AIgbJHBNKxyArcUiDJypwakyAdrjJ9aBkZUo2R0N NZSxynGKm8oqQ2dwpXZCRg4agRGhctyQOKdt5OSM0FvmwRz2NNDspIZc+9ACnGzqKTI2jpTskp90 UhJKdBQAHGR0pWyGHPFBB+XgUyQ8j5aADaxbOeKCNnIGT60w5Ixg05OVIdiD6UDAtucehpAqgkMf pS5ypRcHHemYwQep70ASDK/dFKSO/NMyQfQU4so96BDsZBx096hK4JNKXJ46U7gDJoAZvIHSjJI4 4+tPHPOKYSN2KAGknu2KVRkdM0nllsgnp2qQNtxjpQMbs2gk8U0qDg5pSDzk0qoSCtAhBGpB9qkQ ooIx9KbgDH5Gk5HXsaYDi4bjbTPmIPIBFK2TyBgGmkcgsetIBGUlgwbNO3lWB6A0DADDGcdKQvuT GOlAAR1APWhVYDJ6imsCSrL0pZNwAINMBhbLYJxT0Bzk00IHPPT1p5BU46igAYbzxxio2LbsGp/l C0zp15zQBH5ZZgo60jIU46Gp9gjHmA01wWYsRzigCHDAHmkVSeWGRQ/znHIp4Bb5AaAItm9uOlSO 21doHNPMaxL9/mkVCfmPegBgQkABuTTvKK4UOMnrSHMRLVCWPUEbj70ATNERwGHvTQpHC4NRKjuc ZxUixOnA5P1oAR48DLDNR+WW5YED0qVlKDLZJpvz/wARIHpQA0cHCiggK2epp4JbpjHrSFCOFGT6 0AIJRgbhQQp5XOKQoF5Y5PpQDnpwKAF2KejkGmbG6CSnHaTimMCPpQA14WPJYZprQyKOMEUuCxwr ZoZSo5JpgND4ByPwpAWP3U5pQQeD+dKu4ng4FIBPmQ5IoMjEd8U/gHnk0xifUAUwIyshyVYkUBRj 5+tI0oUfL1pvmBj85/KgBxT8RURTrxUwPORyKGAYdOaYFZXZGO3n2NO8wPwUAPtSlCCTTCnIOKQE ojI/h49qdkDoxHsai2uPu7qUSA8MSD7iiwDHYA/NzSLIGwGG1af5BkOcg1HLFsABJFFgB2SNsofl oWcfeVajeIOQKNu1QooAVpjI4JHU06csrfL0xTVQk5AzjoKJXZUJYc0ICDzSy8L0709dnDMaiBDR kDg0RIGPzt0oAtMwaNdi5x3NRKuJQW656U5t23C8KKbGRvzjJzQBuSR7JARlgQPw4qVVwPmI+gqS UA42j5cDP5VFGcMV4+tACnLodoIxTYw4UnG73NTKArhuoPWnlSuQDgHkUCIQ5YfNwacFbAKnP1pm VLcjA9alUJ/C350AA5GGBpREN23sakEpUYC7qgdyXDA7SO1ICw6lIwODiowwOHH0NK0jcMRwRUYj z3+9QMkkwOPyNPVCTkdx3qt5jKRnnHFWFcsM0AJJ0wTyKQKTz0oO4kkcGhOOJAT7igQKuA2TSgqQ OenrUiqyglcEVE4BAYDDdxQMe3JHH5U4puxxj3qMbivXn0pu7nqc+lAEq/Llc7hTApGcdM05JBk9 valzhj/M0ADDcBz+dOLsuM9vWo8lgCVzg9akcrt4bHsaACQowB28j0oG7Hyt+BpuCQCVwPUUmOeD k+9AD8EDlPxFNdUPqD70bivXNOEm4c4I9KAGoG3fe3Adql81j8u0UgCnqmKa6AHKkmgBx2kcfKaU FgetR7z0xTh/sn8DQBJvBHzLj3FMKjqDSAnH+NLgjllx7igBo4zzShm74YUHb9fpTT0+U/nQA7bk ZAIpNuAcGkxJxwaeVc4ycfSgBiBu65+tSkepUCmqh6E0/wAtO7CgBqkDIGKYTk4fke1TARgdzSMY 89DigBg8scrzSMAUJwKcxjOAgwaUbWbBGPcUANUbY8ZzUiABeuDSMuSAOaOTwDz6GgBGUHAPDevr SlcnBODTwQ3DjFNZcHJ5X1oAYVzIATg0MCGGeD605SGJ3dOxp6nghxkdjSAgAJfPQ08RqeR970oK 7cA9DSkbcevY0AIFIOSOKCGycfMtOVtzfMMEdqUyAZ2CkBGHZeB92kIWTBXrSlgzehpuNuCODQA8 cPgjNBGM91pVYOwzw1KQVfFAEKdCSpK1IFBjzilB2ZwOM80KTtYDlaAGOMoOoNNdCMFmPtUwQmPg /gajZCQAeDTAYS24KOaTJD7mGalO7ghelJn5zxw1AxrKc7ugxSjanuGFOByNpHIoAAG3H0oEM27s oeD2poRgDu7VMQPvdGFMckMC3TvQBFliflHFSheMnk07KrwPumo3TBGW49qAELe9IRnHHNLhQelK +4YIHSgBQMEHOPWkI5IA9xSZGSM5PWpDjCsfpQMj6kHrnrS9BknpTiM7lHHem8A465FAhepIAwDS Ljd6k0dhnjBoxhjtHvQAvJQg9RTcdse/NPyA+euRTGPc8YNACsyjaR1PFMRPnIPegLu3Y+opT2bq e9AxVAQFccVCH9889KmyWIzwKiCBJCOpoAlUDaSOPakQEHn8qGRiuQelOSUAcjJoENxubOOB1pGC qck1ICWc44BqF1AU57UAOBDbh260shwFI78UxTwpUe1Ky/Lyc4NMCMYwVHWjayHd3p+G3HGAKYxA bkGgBW/eDO0fWhPMBwo496aDGO5pQyn+MgUAEgDD5+DUIjC/Njk9KcxQt97IoDZbrkCgBAu0nJxU iYVcmTmoyrPLngj0pxyz7MAUAMZgDu3k+1ClmGWP4UpTacCMGlATqyGgBV3P2AFMLMsh28UEjfjk D0pG3Y4Bx70AOzzk8tUcgY89vanBwBgdaT73JOPagCJWXf3zUo4zzkHtTHKHgDB9ajVijcnNAD2R FOVODSlsjDj8aXG8ZBH0ppyv3hTAhZChyvK0mGOOTVjbxkdKAqMDng0AVzM6Ljbn3pv7s8scn0zU rREc7gRRhAOAA1AMrOhbhflFMWNQSC3SrTZJG4LihmA4AX60ARoGGNjZHpUu4d+DURGDkMfwppfL YGT9aYiXgnBqvLGUOdxp7Ej1qMsTjk0hjlkKjiT8CKBPuY71VqRmBHzDB+lIsqovMYPvQA/euMqv 5U0kNyT09aRNjfMQVNK6u6nbyKAGKpZie3tSHaHOe1PVvLXHQ1G5HfAzQAm8hgF5+lNklLZ3c47G kygywJBpGjGzfuyT2oQEKknJC9aVVCnOefSnqHJwBhakW2VPm3biaAEJZl/uikQ/vUVRn3pZFbHz cD0pPljClD82aBnQyqyv6AgYA+lCoNyueM8EUksgVyuScAc/hTkwc9yeaBEmMMU9eQaDlkHUsKQt uQOTyO1J5h52jg0gI2jckkHHelVSQAR+IpEZ+cDNKrNg7sjHagCZflGQ4+lMchjyOD3pCwbaAOve lCsoIJzjpQA5BmNlBzTcny85wQaeq5wwOKZIpXcANwoAUAPJ83ygineWY2+UF19ajwNgKsWx2qxG cplSfpTAaX9Rx7UAsDkDcvpS4B6jaaBuUjHH170gHL8xOw4PpTDhxjo1KF3yHHytSMN64YYYd6AA oQOSQw6UjvuUDZhhShsptc4PbNMO7ODn2NACqdzcnb9KViVbIGfrTiqhRu4o2hj8lADQX25IIFOM i8AjNI4cDLHI9KdHtPUdqAGkrxtc59Keu5h8wDD2qMoTk44p24RrxkGgBxUHgEr9acVCDoGqHztz AMc+1PLKcDoT6UAKWwvJK0il8nnj1pzEqpyuRSQn+7+RoAkXJGWx9aGjB6DPvSEqM7uKUNnkHj1o AQcDGdw9KUyY4HA9DS7lPbn1FNKkjP3sUgFyvXac+tGHP8IxRvP3eAKML/eJoAcAwGC4H0oOzuWJ podQcbOfen+b9BQABQRwhP1pwWTH3FH1poZmPBNIQ/Q7qAHsrgZ3KBUfPXcKcABxtJNRuM8bcUAC sjE5ODTlB6jn6U1doHIyKejAZ2Hj3pgKgJ5BwadkO3PDCkZwMDbzTVYMMMcGkA/d8u1xzRlkXB+7 TT0w3A7GkJYELnI9aAHlNiZXkHtTN/y7cfLTiXV8Y+WmsB95D+FACAkvwcin7jGRuwRUSuV5HIoP zDnnNADmYtJleacvL5HB9KQYVhj9ak+SRvQ0ARugLdMGm5+UhulSOCGCv07GkKED5unY0AMZeFP5 Gnh9xCuPxowdo5omj2rkdBSAAu1yM0mCrnjB9qZHKCxDVJ0cEHIPamAqvhTntSySZUZH0NJhWLYO PamAYXBPIoAeG5B7HrSFcPt/KhgCB6GlbkKe60ANJIIYde9OcqVyOvWmseVbseDTWUq5GMg0DFlI aMMOtRhtw+Y8ehpFJTKjv2NOjCjOR83vQAm4BSvT0pFBPU04hSckZNNJPQfpQBKAB2H1NNbDZGTS Ltxzk07zVBxjmgBioBjA56GnKBtYdSKT52b2oB2SdhmgRJgtg9KjwR07HrQWwvXgU7cGU4HUUAMI ALDqTzSEnALcCmByG9eKCpdevTtQA7IKZXqDSSDdg9SetNAYEjoD2p8YIX0NACKCOd34UFjyMYqQ KOp/Om53MQpzQA0oR8xPHWmB/wB7kDrT93ylWpvRMnpQBNtO8c4BpFVV3Coy7EKVNO3ASDd1NACK zEDHTOKR1AYgnORQx+8M4A5pW+8pHcdaAI0JMeOmDT8jBApqoBu7mnbQcbuBimAgIyOcnFBjYjkU 1gqDH8qaA5GQ3FADyAP4TUMnJxjH4U9XIbGcmlIcElj1oAiEcYHXJpVjweDin7iDwP0pGO4ct+Qo AY/ygkMc1CS2ASTmpQuW5JwKYuCzZBx2oAk3fLgMc0mARw5zSKNqc5zRGNuTRYBDGQQ++nSeYwGG 4NPRRIxB6dqlKgw4XqKAKigKOetIwY9elPC7WPOT6UgQn5iMUAQld/HQU0DZnPIqyU3cngUiR59x QBEG7inPJlQGGR61I8aKODg01EDZyaAIgylgQTj0qQyBuo/SmSoikbWOaXaxH38fhTAQkLkDmmEZ O5iB7VIMKMKwJpGQYyzj6UgImlLZAAI9cU0NjgY/Kpgu4fe2imNGi8+ZzTAYX568/So2XeejZ/Kl bGeWP1pVMecZZ/pQFhi70f51yKSXJcFGx7VJIznhF49DUOMk7htNMB5LOoUsuajkiaNMjDUoIjOD HuFEhVsbFINAFY71GTkH0qxHK4TBYfSlGCMMOaaEBbg9KQCsnmpnOCKhEYZtucgU9o8k7SQaiKGM 5B3ZpsEPnjSIDaee9RMQcccegp4DPkkH8ajKjOe/tSAdGXb5R8q+9TrIgUqV59qjBLYB4FOKRr9x vmPY0AKq+YTluPSoXDJIAo70SlYxyfm9RTEDuQwOVz0oGdK65cHoAAD+VSIAmQOo5qFkbzflOQQD z9KeH5BI56GkIkBG8gDhvWkRVyQzHikJIUEnoelB3M24JhT3oAUkLINvemMChLk/L6VL8hPJ3H2o cAqRigCFGRyVXj0NTYEbZB3E9qhKOo4TIpoIByWxQBLgMDklTSYkBBxwR+dLE3JO0sD39KnCgp8j Z9qAIlUONrfKfUUBHQ4z071IQR7j0pQygY6igAzxtcYPY0uCOH+ZexFL1XqGT+VNA2jodtAAQN4J PHrQQxyDz6GndB2ZaYflPGdpoAAyldkg5HQ0i5Ybc49zSBxggru96RjwARgdiKAHnegwy7gOlOBj xk5X2FMRSR945p4D7vug0AOV03AA5+tLuRGOAKhcKW6YNJ8o7E0AK7735yPpSuZNvIyKVCw5KEil fLL8vHtQAihS2SoFDRqZAVYCntGcc9PUU1YlK5LfnQArnkBjQFXtyPalCoHGRnikwAeAR+FAChgO Mbh708FB0GPamhj02g09c4IdRntQAhznkYpGJA4XNOBbpnA9DRkj2oARWyMstDY6qaYwbOSaBnrg AUhjvKUjJJJ9qVZEAx5fNICytjOAaR8KdwBJpiJBK3YAUhkZhgtz7UbWdc4CikC4wA4pAKAQMnNG 0Houfc0ELjl80ny9yaADaV64PtUYBJPIHtT22jkKfrTFGScKT70AOyR2496lGxlBI/Gow2OD8x9K UZBxJwtAD/kXgncD0pjYGBjjtS4GMLyPWkVfmGecUAPRGP8AHgelMIKE8VKSAPlOfamEEqew96AG EgEFPxFKTkj5cA9KTEa9fxp0nA+Q5oAVouQc5FKRjGKjDYxzgjtT5GJA3DHvQAOeMZpRIqja3Ipp BI+Xn3pwCjqNxNADcbl+Q5FGX2Y/nSbQC2OPQULLhcOKAGKAXB6VKWXPI59RTCAR8p/CjByccfWg Yp3bhnGPUUhyDjqBSjAPfNOLAtzwaADjZ7HpR/CG/OmqdoKt+BpVYbcfgaAHOvy5H3TTGPK5OD2N PRhsKt+FROdyehHSgBTkNgjdnoaQoRyzAe1C84OSKcVU9c59aAIgNxOM0oXHXipSAgz96m/KRkn8 DQAoRmX0FGzZ0Xn3pBK+QEHFKS2eSM0AIVYjJbFR45yOTTyATjqaUswGAAPagCP7w+c/hTkICYCk 00snf71PQqPvAigRCgYycjFSYUFuxp2D/CPlNLhVBx196BkJB4LDA9aePlJ280yRWcADIpQoT7x5 9qAFOHPcGkI8twT09qfliOQMeooZVAyDn2oERs25iMcGjAELe1Kzg7SFwaUoSWB4BFMCAsxTgcCn HdsBPT1pU+6ygZNPSIvDlu3akBHwHIHORTtrMikngGnfKhUjk0mWYMOgBoGI5UBgKZGWZfm6VIwR WGecioBlmIA4oES7lDfL+tHDHkY+lMAA+9+VO3E8KOPemAhiAbI4pTwflJP1pFYryevpTjM23OAK BjWbj5mFN8zC8AUvmq3Gzn3pjBc/MMfSgQbm7Ac00BzIM4FOAJHTA9aRnCr03GkMV43L4B4pGD8A Ec8VImTHuJwajVgSxzTEKD5Y9xUkLctkYzUOfMkDfw09c7s9hQAmMS5NOJzkdqbN94c9aUkBVx34 oACu5gB0NRFvKzg8jtUgbA+ho2KytnvQBAZd7gMODQCASoNN2kkc5pQOTnmgAEipjIBpzKr+oH1q MouMjmmhGLYI+WmAu4KcIM04LnljT0WEDhTTXVW4CsBQBE79lzmomHPzZJqbCgYVW+tRhAeFRmb1 NADGjyuWXA+tRwiQMfKAx71P5WB+8BA+tCkIMKoI9aAHMrKuXxmq0i7/ALw4qzuiIyQahkKtnBIH vQBEGCjCkn2pjOdw4wKmXy8bRgmkkhbbll49qYDy4ZflALVWZWBznB9BSozxudqkL60qyISdoye5 NIBjSsVA4FRSPzlTg1M4B7g+1RmFS3B/CgYsczJF1z9RTUk3vwoB9aWeL5VUcAdqbEOcInPqaBBI rAZL5PtTI13MCATj1qwIuu+RR9KREj2sdxP0oGV9m9mJIA96ajlZMJnGasELEmAnJ9arLIfNAOAu elMR1rg/iAOPwpuDhgBjPIzUhBLDHdRyfpTdpDgc57mpAjcHbkHqO9EbyFRkGps7RggcetNXLZA6 e9ADtq/3ufalXMefl/E0FAO/PtSgOoycfjQAGX+90pjrCCCAGz1FNdgW9RS7AQGVgPagByALkx/k aUcsWAw3oKQnaMnOaeNr4wSretACrh/4sMPWhgdwyBn+dIykH5xkf3hS7uRk8diaAAAZyp2nuD3p QzgkAAj0obgfMu4HuKaNvQkg9jQAvGcgEeop2zA3K2R3BphcqexP86a0vOQpX1oAUqM5A4PXFNAI b5envQGwcq34U4OT2B9hQA7B7gGlZdozk5pq56/doOGblt31oGNcMBywb2pUJB4H50OSDjaMe1OA kK54IoESFn7jbTXztG4jHqKVXOACdwocIwwFx9aAFKrs+VzQn3OU3Ck8hiPlIxQokRepxQApIB+6 VpVlYjAdfxpd6H74pMwjoM0ABkPcZ+lISG6lqAVBOzP0oLyZ4HHvQAgJ9CRRvbGO1G91PC4p27d1 AFADS2B8vFKhUjJUkmlIO0AYoUBf4+fSgBxViOwxTN24YFPPJBOaaxbPy4ApAIBg7WyadgnogA96 Y+AQS+W9qduVl5LE+lAC7WwcYHvTNuTw+TSjA6g0uzttwKBhjn5359qQLgnc2PTFOBAGNmT60oXb yVyKBEYxvxn8aft3NgtuFKVBBZePamjgAd/UUAAwv0p5yMd/cUcMMHoKZsIIw2M0AOBXOetK7Fhg nilOEXkc+oqNm3D5Rz60ADhQo9KVn+XAXApmAABzu96kBG3jk+tAyMLgbv5048r8x/CnKSybQM+9 OWNFGSdx9KAG7spwcUkbgY4/GkUAk5OMHpSdOCeM9KBE2cP8oznvUZVd5DcmhmO0dsU1TvIAHPrQ MaE2vjPNSrk8PyKbIuAGH3gealQeZ940AIdoGF5FI2OCPxFPYKnA5pi/MCGHNADGA8wdeaNgyQwx nuKcRujI7g0hBXawPHcUAKh25X7wFNAByoOD6GnHG/kbc0jrtYE9PUUAMBK5HQ08KVG40h4O4YYe lAy3Q4HoaAELjOFHJpFVcZdsntThh+MbT600w7CSWz3oEC7mHykYpGYIwPVvSl27ypXgGkYEIRjO O9Aw35YN0FEhJ9vemLnJXr7VJhjGSwyKAGABl6fjTx+66HP1phcfKEpzDGGbrQIdvLHC/KaRgBku M/ShnLYG3j1pwAUZDZPoaBjSWxwPloG0Djr6GnEl/wDZppAU/MM+9ACfMTx8tG0dGGD60pPQk5FM Ys3+76UCHGQeVgDJFJhmKknAIpq4Xdjj2pwJKrngZoAQFYj0yTSo+4MDxUbja+R+lC7mY0wH5RVU 570hYszBaYFTHzA9adICjAp0IoAjZfuljRnnjp60oIHBPNSKVH+FADExtyeaeF39+PaiQK68cNUS q0fqDQBK6ADAfBqAoe7Zp+4nqT+VJv8AUAigBCpxnimANvyuPxp/yt0Ao3KOCn4igBAMt83y/wAq bI20gKM+4pplO4rj5aFckkKuB70AI4cDk4B9KNxKgKp+tOGF68n0oLknj5KQwReCnTHJNPYgJ7EU pXaAxOfWoJMuxVTwOaYiQ4MQPcGkA3dR15FNRgxC4PPWpGGwgelAEaHO4HvTwTsB/Com+Vz6U9Tk FQODQBE21XYk4NNZnKZA49aJ0DqpIzjilhygIY8dgaAEGfKDDk08uSg4z701MEt/DUo2qvzce9AE Sg55filkm2cc/gKHORwPxFV/MKN8qlj70ASgtIMs+B6YpnmlTtRqQ7nPTbSPkNg4B9RTsA8gsMs5 PtTXCMP3fJqN49pDPJkegoDquREufegB0aqgy+QaXBcH5wF96FIZdxYlvShiB97DH0oAjMDEfuyv 1phd4hhjvNPfoSwwPQGoAxY4UED1NAB5ok74PpUcgcD5ht/rUhXaMDr64pyso/1mW96BkIUheeKV GXcBnGKsEI4ytVjGrOQ3T1FAD5lJ6HtUCKwBLMQPap/sx2/u3JHpml8vauGBB9aYiJSqrxHknvUu MqBvCj2qsXPm7eSP9mnZYc7QPcmkMkcIHJ+ZwKrrhps7Qoz3p+5zlQaRU2MCSOvSgDp3YiTaOWAH 8qXLsevPtT9nlnB6kDP5UiyEg7AFX1pCAQnGWIH1oO1R3NOBj4Jyx96XeDwF4oAZ5nOFH40hY555 PvTmA7n/AL5qNkyOOP50AGUHHOTT/L3f7J7UxeP9YpI9alxxjdkHvQAm1sYOMj9aaMDIOR9aer4G 1ufQ0pweHH0NADQGTo2VNLnaPmXK+lIVGMA4NMYOp+8TQBKCq/xfKaR2H3eGB6YqJWCn5hx3BqXY o5U/KaAFAQ8MCD2NIVLHAbkUMrgYJ3L6ikO0L8wOexFACeWcngH1pVUA9/wpEQgZ39fWlXd8wBFA D/nGemPehY/MQk8EUqk5JA6inDAcE9GHSgBEwnIGRigFTznafSgkkY6YpMoACRnFAClgRjbg+opf KlOOQwpC/denoaRXkOccCgBxBXhjt+lA44D5FGVI+bk+9NwuMgEGgCXemAGjzSHZngFaZmVRx0oD sR8/8qAHBW7baTLAfP8ApSjyzwQadti7P+dADAy9GY/jTf3ZOATTzgehpcpjOMH2oAjAx2JqQf7v PrSA56A0pZuoFAATkYIoIUDgZoDEnkc0MT2AzQA0sQOEFId/UjANJvfIGOakG6UYYgCgYq4xwMmk KknJbB9KQIB91ulICA2WOaBEgJPBAFCsq9+PegYPUnFMbaORz9aQCn1B4pm4g5HX1pevTk+lJk7g GHAoGS/wgetKgz15ApFw3Q/SnZ2AgjJ9aBCMuc4OPY0ijZnI5pQc4HUU5TvLe1AxsilgrEYz6Uiq MfN8o9KfKThOKaQM5bk9hQAicqwAwtC4cYHBHen9Gy35VGrBnIbj0oEJt2uVPOe9McqjdyTU4IRg f50s6rIodeooGQkFlyecUg+RgR61Ko4we4qIgleTjHFAErMobOMgimZxnkcUkY3oVHanFUUKxGfW gAzvXKjBFPxhQ5P1qMMPMxtIB70KFIKs3SgCcgBsjowqPHDJTQzshC9qZ5jKyk0AK7nAJGcUudy5 Bx7Go2bLHb35qTepXDrg+ooANoPJ4akOc4YZHtSFWC8nK0KxxhOnvQA4Ngc8rUUp5yD+BprAk/L1 p6o0i/N1FABGTt5PTtUmTuIXoRQpQYPrxTWJ2ntg0AGQvPVhQpJYqeFNIP8AWAgcN3oZQAcnlaAE IXGF6g9aJEYKCTkUFwD8o4NPjUyKVc9KAIg2VwOtSDbgF+D60wgrzjjpTEJcdenagRLvypHVfWmZ OTs+YU1c5POMdqUnLDHyj1oGPG3GQfm9KjIZuTxzTiMAnGT61FuyWGcnrQBIf3TEsAcimod/GcD3 pMblVi3IprSOGKgBvegRNt8vnOTTAGeQ4GBTUzkMTUkrAcjr7UAMjIjYhwcU6WYOw2DIpqh1l+Yb gR3pSI8FhwQe1ADQATnGaXAPFKpzzTiQeGH4imBGYye/FG8rxuP0NSNuXp8wqPd5h54oAUS844NK cdlFN6dgaZuGflyKAJGCDqhHvTd6AH5SaNynh91AZVGUyaAI/wB2w3EEGlJJA3AbfUUAq/3Ttz2I oClfvH8KBibQvKfMKaFMp3Z4HalaVSdq8GnpFgfNwfUUARTOGwi5Bph5UkcEd6nbIcZUFaYSqyHH Q9qBEeSqbj1PTFWPMBjBbHPeq4DbDnjBpS44GM0ASACSM47U1Pu8dRUe1kckng9hTQzeZ8pwD1zQ BLkcjHuKQx7gGbpSM+zAxub2oD7gc8DrigBkmSNq80kZIBEgyPQ1KrhjhR170SRDAYnkdaAGjeTx wh7UpzgjaBikV+Nq/nT8BOXagCtKkrjjgVHs2ABiSfSrMsm8fLwKjjBcFcfiadwsQlATkfkaMANk gr7Clf5GIHUUmS3I+Y9yaBitgDgFQaCr49PqKViqpkZJpI5HcbWbb9aBETjoCAfoaA6r1UirCqAM YXNJLGpQEJz60AV3IJyCaVJScho8j1pGTtkimhpAdqvmhgOdo/4cj2qPK9zTnDnqoPvSZJGCgYUD E2AjMclDPKqEO/FRsoJ4Ug0q5U5Ckn3oEMSNDkh2yaf8qcYyfU04MxGZMKPQUB4gCRGxHqaAGbkx ySfYCnoSGBWDv1ammYj7qj8BQsksjDIOM9zQB0Uz/PtB3MQM/lSBflJb8hR5e4hiMAAfjxSu3HAz SARAQDnin4P0HvTELA4Ax7mpgpY9Onc0AMCjtk09U5znFBKr1JdvQUDnl22j0oAd5yoNpGRUOSxJ UYWnEgNiNcr3p4K4yv5UANVcDIOVPanhsLtdeOxoAB+ZPxFL82D/ABD09KAG4U/KTg9jSYzwSWPp TsjGGXjsaZtJcYbB7UAIQ6n/AFeaQFc4wVzUpMhfqD2prSbXwUz2oAQZXjdSKXABxu9qWTbwR09K khRGUjJFADSV2AkY5pFRS3B604xnaec800A7sbefUUAKqvkAGnAEKM8nNII8Ny3FOHCEDoDQArxk sdx7ZpoG0FVFSPyw6nimhORuPGOlAETBgQetTAL/ABfLQQSFKjA6UOgKfMckUAKdvbDUhYj6U1VU MQpqQl+gANAyPd0+X8jS5OMFgPrS4H8Q2mkYIpGDQIaNu4cZ+lSny8HCZNMAA+6AfpSmRl7Y+tAE e0g/KuPapAH4GcUFnYdVpu7szEGgB5Rwc7s/SjjPWm/KOpNOO08FefWgBdqnqc00gKeDSkADgU6N +p2igBMo33ic+1IdhOecUrHeeFx700Re+aAHgjGFUD60ZA9DSeWo+8w+lLsU9W49KBgee4J9KAoI O8/SnZiAwATSKFbk5pCGE8YUZpApx83NSHZzww96QnI45FACKgY5XjHahs5Pt3pei5zzQE3KSCc0 DFAwoAoVgisG4NSxgEDcOnSonw7MDQIJD+7UjqaVTxiMZbuTTesa4OMcVKEKjPX3FAxm0L1O5qjY Zfnr6U9MM2Fz7k0rYVvlGTQA1lYA55FLCQcr0oeUhfm6moUJDZzxQBI2VbC9qa64bBPWpOZGwMAd 6QLwGP8ACaAGI3zDHHanMCjEHnPSnAZc8fSnEBirEcjrQBES7KMLwKcCoIOOvWpcfOV6BqiIZcqO cc0ABU+YQDgGk+6rKVz706R1IX1prphl2ng0CGoisuScGgb0z8uRQcBircfSlDso9VoGINvVTz6U FQx+b5T7UpCMPk4NAyh+bn60AJ9zgjOO9IjDLAd6a7bnBXOO9PICcnqOaAGAEnH61IdqsGJ68Uxi WORwDShVAIP4UAJydyjjHINNJyw5yTwaCCQG6Y4NIMKDgZz3oAmWMICrdD0NNd8HjqKRTvXa5wR0 pMhlwB8woEISR6Yb1pueOmCPSpUAKlZDj0pu3ZwrZzQMQRg89aZsJYDPHpTt+M5GCKRjuxg0AISw DAfdpyBQRjjIoUMjMpGaAqnaQe/SgAVN8bADoetAVUYHOMipPmVmUDioQBgMxzg0AKSxUqAMDvTG QAA4Ip5z5nT5SKRpMJjHIoEMZnG1ieKPl8xgByRSLll+bOQamk2hUegZHsKqCWp4dcYPWo8MSyr0 60iYx157g0xDydoyCRSedn5So+tLjjg/gaTcB1UUAGO4AxTCVI5RloyXPyIaUgk/PkUAN4AwckUj YC/K2KeAR91vzFRSBi/XFAChWbAPT1FNaJg+Q5K0qlo8k1Khyu4jHuKAIGCbsg8ineftAXrQUDvn oB3FRlcPnGRQBYRhgFTlvSholcktw1NUAHjApuS8hDHigBp+fK/rSbWjjIUbjTmXD/u6RX2H1agB oIfBlXB9KbINy/Kdo96Dv8ze/JPQVO0ilQrJ1oArRsoG4/nSS7pcErhfanmGMNiNsH0pkxkUbR3o AcskaDC9e1Dlz97gN2qGNRIP9pfSnlmABfpQNDXkJXCDBWkSVXHXc1JJmUhgdq98UpiGwFAM+ooE SqoLZJ5pXZR93r6VGqtGn94mkBAb5cFqYAcP9/g0oUHmMYx1prL/ABM34UglLnEYx70gAlFGf4qY d0hwRtX1pSF39csOoprvzhj+FMZJ5YAyp+b19acGYDrn1FQgtgA/KtLvxkKMtQISVZCdwAK+lRkJ joQamVyudx47ikMZOWjO4elAEBYDgMaQdPlYGgh1J/d59aYfLJxtKmiwD1Zz1AP1pry7OikH0pCo A4f86Qgt1Y49qAJVLhMmJQT3JqKUSFclgAOwFSLFI2MHA9TTpLZduZJ+PQUwK0ZVs7pdoFNj2bwz SnGelK8cJYBQSo/WnsYiVQJtXPNIDqJCeABngdO3FRnhfmYAegpWZjwTtAA/lUe0FtwXd7mkA5XA +6uacWLfebj0FNC55LZPoKkAA7AfWgBjSlRhFx70zBByx3ZqX5N2Sc0EhuOB6GgAQY+aN/qKeQSM qOe9REAdeD2IqRQwwc4b+dACZB5GVYdRUiseWQ59RTTydx+8KTKn5kOD3FAEnmADnoaQFeWPbpTD 8uCPmB60hOcfLxQBJt7hsYqFldmyOac2Nu0EgmnKGA+XBxQApb90AU59aYcY+U4PpTySOCCMUxyW xkY96AFBOACaeW2nphfWgAAYIz70pTDDccigBUXexIyfenKnDZPOaXBVSU4HpUIc7Tj1oAsOD8uO KbwCpxk00twoZqcXAQBRn3oAGb5OmOaFIZmA54pFXAyp3e1IrKsnJC5pANZDgEHn0p3mbgONvvSb s5UcHPWgYzhgfrTAcWAwRlqjfJO7aAKfvKnoMUh2sp559KACIbX5fg0TIpG4MT6imlVyCAakQ7gw 29RQBECuBgfnUpc7QNgqNVL98YpVRzlSx4oGKWZXxgAe9KAx5zinypwvOT70gQeuD6GgQNwBkjPt SAZ5c/lSlFHsaT5QeOtAxGU4yp4pqIWYDkCpDtQZyM0fNIM4CikAvyocYBPvTizbckDHtTcKoGCM 0oAb7z8elAhA+fu4B9KXGPvfKaaxXsD9aQMAMklh6GmBIxZsBenrUTAoRzzmpd2R8h2+1Rsu7pwf ekMJW3ADHWpUBWJgahAwwzxip25BAoADwin1psanLMQeelTwpuALc1aCgdqBGbtby8FT1pwJXAFa OB6VFJCp5xQBVfDL8vBqMkKAp+U+tPkJiOcZAqEt5vIx+NAxWGfmI/GoypB3LyKlTGcd6kZVbGRt oAiVyo9zT3cBNpGCe9Hl5OT0HemgHdkjK0ASAAKCrZxSK20MGGM0wgbhtOPakd2LAH6UAK8h2hh2 70oYhst0IqNhnAHAFKxyg9aAHqylGJ/Ck2Dyt26mupyMD64p4bAOACB1oAYdwwxGc0za6sSeR7U8 SMAePloIwmQeDQAoZHOOhpJMquW5x0pNmFyR+NNCuWxuyPSgCIM23IB5qcYCq5/GiMASEE1G0Z3H nr0oAc7ZBA6DvTFPcZJp2N0Yx260i4TJ7UAPxzlvutSMyr8h5HY0iksu1uFPSkBGGUrkjpQAnDjJ PK00thg0f40pCkg5x6inFCOhyPagBpBYbjSBSOUbd7U9cqeRke1KI0YnaxGaABHBRlYYPvTjCpjD A4I9KYNyFg67vejcNow2O2KBDvmVwTyCKYVGWxwRzT9zbASOhpW2s4PHIoAQsysrdQaYzKdwxzQy v5fBzg0BQXGe4oANzBFbFEi5Y54yKXG0MvXHSk3lowcZIoAjRmDdODThtkVlzgjpSMSrZB6dqR2j b5hwfagBdxUqSOnBpmV3suOT0pGLsvt60rc4buO9MBcNjrSjbgjNIVkZe2PWmtEAc7qAFXcGyvSp mKyrgnBquXfPy8j1pMu33gKAFbzQCFO4UBjswcGh2aNd23mkYmQAsuPpQA1ldiAhyO4oHmLxnb7G nBiF+Vcn1pVkJG6Rc0AN2OhIJHNKF2/hQrMzZOMUwysGIwCKAHKMkseKFG0EkcmmktIQoGPanjI4 Y8CgAVW2E1EobOcA1NJIoX5WyT2ppYKn3gDQBGVEknzqVA9KVV3PlZOB2NSbyI+qkmmNlE5Tk9xQ AgVixZkBHtTSQXOCR7Gnq4RM7iPrQDuHIDZoAi2mPlQCTRKMQnepz1GKeY43cAErimypKCAjBhQB BGWNuRjk1Mu0JjlWFQO7iYDbjHWpZnLAYHWmBGzMTycL/eqF2KN+6GR61IEOcE/hTwgBOz5SP1pD IR8xy7ZJ7U4Rtjd0X0FIvyyfMtSFskAf/rpiIi/9wYPr60oQBdzfe9KkkUYGBj2qNnwwB7d6AI23 ueeBTWfZwoyalYeZ0bB9KYoWPIfrQARkS5DnBpVR0b5G20BVLcijCgYD8ehoAkYuByM+4qB2dhho 8j1FPXk4WXB9DS+TcqdykGgClLgHGD+IqQSsqAKoX3q08nH72H8QKpy7Cw25Psae4D/vcmUsfQU2 RWbjgD3NNEgBIxtobYwwAzNSAadqYCvux1xUwmjdgix5Pc4qFlYAIi4z1qRI5ICuMb2PAoGdGwXI 8tS3A5J9qjZsN+8OF9BSsGycHAwMj8KAqrIDt3Ke5pCHqxzhVCqehNIyEthmPsadt/h6jsfSnphg Vblh0oAjC4GV+h96CoPGc+lKEY8ngilGFPy8k0AKqcAMflqQpt4PK9jSbc/ePXtUZYklGbA9qABi Vb5ufSlO1uc7fWm7C3TgeppVQDuCaAFChULK2RTUdipGBj1pdgf7nB7inLEEH86AG5BOcHNPXaMZ PTmlB3cAAd6Aqlh3J64oAczZj6cmoyuWyRkDtT2+Zz2AoZgEAHUmgBFyQQOPY09ePujPsaYy4+8c /SlDEAZ49DQAOMoTk5HYU3+AfLipipZMjA96Rgqx4brQA0kAg7cmmp/rCRwfSlZuRjJUUFkLjAz6 0AP3bidnytTHSKTHmrllOR9akxHgZbBpMg/KeR6ikBG0pztZOfWnJuIwT8v8qcw5y3boaa37sZ9a Yxu1Q20EtnvUyqikDHUVECMB+9DHgHnIPFAh5cAhTjikEgDYHOaTaQxwOozTShG1880hhlwSq4/G nK+GPOM0AKHyzfeFKdoxgdDQMGclRyaVT/eBb3pxOcgCkXeAPlwKYhwT+6Mg+tI6jHQg1JH83t70 juwyMjHrQIg8tcZIJqQAAAAY/GlPCDLflSbULEkmgBxiJTK449KYpbB6EU5DtUlc5pCwMfzAgmkB IrnbyoIqIbcZThvQ04FtnI/GkYDaOMn1FAwUZYb+PepJCBGAOeetMK7gpfpTGJwAM7c0AShBsJPJ 60qnJPvxRgCNsdadCuWB9BQBZiBCipqao4p1AgpjkAZp9MfpQwKU5GDWZG5+1mPPykE4rQn4U5rl NR8Q22k6kkU6k+YM7h/CM1DdmOx0yswGNv51LyFx19qrWV4l7CssfzIehqwwJYBeQKsQu8oAB09D UmweXkdahJ3ttxnFPDbCB1U0DEC8EEYYUzdkktwRwPepZxxuWo8eZhDgH1oAVeByMU1FyGOcegoy QAh4PvSsAFwvBNACIxGWNITn7owxowwG0c+tJ0bKnGO1ADsbmAA5HUUEbjgceopUw4JPDUqjJO48 9jQAbggxjj0qJhxvU4PpUkgzhW/Oo5FwQo5HrQAjcsoJwx6mlkVlI4yB3pYxuQhu1ClwNpGR3oAb wMY6NQyEYXuKAodzg9OlJgyHdg5FACOdvy4+U9DUikFcrjcvWowGZyueO1Ix9Rg9DigB7FJBkjaT 3pi4BIVsEfrTlQgfIwZfQ1E6h2zyjChgSh8Hpg04BWOfutTV5+9g+9ISPumgCRQ4k5GRUbop3ZGD 1qVWZRkfMKaXDtzwT1BoEMjJClRyKMq8fHDA0cRtkcik3IQxA59KBjwSMr1BFBw0YPcGmxuQc4zi lXD7sHB9KBDj8jg5yCKZnBZcYBo+8qj+IU50ChXzzQBAMgg446GnlIz904PpTmGTgcBu9NwqDDjn 1FMBhjYZzxUZAVe/1FWFLsvGCtNKoOQcH0NAECh1OSxwal8sEbtwNNZSzYAxSBQoGQd3rQA8eYoO 1ARUZyeNmKXfs4O404+V3Zs0ANMZA5VsUwru6qwxTiw/56EikLjaPnzQAKCfl2sBT/Lxj5DtqMzM OFYkfSn7wRkynPpQAjgdFTmlAKLyq0wbc53GjarEcMwoAQMSDlwPpQtuSu4MSO9L5e9uEwB3qXcV TYOfpQBEYyxyqjiozIS+GTpStuThHyT2NGSoCnqaAF3RlsshwPSg7Hf5XIAp+AE9/wBKYo8vkpnP pQArqxIAIak4GSyYHtSqFJLFWGaQsA4RX/OgBFXglW596jEjbz8p46YqzID5ZDKCPaq6qiJwSpoA apV3LNkGmtgt14HcVPtdE/haoiFGBtwTTABwpJpix5XIPNPlOAB696M7U4oAhViGYkDPfNIsil+Q dvr6VYZU8r5hzUCIUQnH1FAATvbg4xQIt+5hyR1FMyNvfB/Spo1ZF3bh+JoGVgpJ4UginFYsZdzu p00hPIIB9qYMbd7MufegQC42cKA31pWkRuJEXPtULgyHI2ipIxtXmEH3BoAhcKJPlJxUqlsfLKfp U2+MjDQkfhSH7NtxyKBkBkmXvn60wzhjh0A9xT3hRyTHKfpVcwsWx/OgRI8kR4VSW9SKhbzUACnr TisqcHGPap7d4yhZkJI70XAYmYxktuftSmN1IdmO9jwKRXcytL5YVR0zSDzZJBIzYOflApgdLLtc qyHkAZH4VGME9Pl70skQVgUPYZ/Kg5jGAMg1ID0TjYTgdjTHZQQQfmX070iOC2GPIpsg+YFRn1NA ErS+ZyOMU0yAAgDiliU7shd2fWn+WEySQPagCMsxAYDGPWkLjr3+lOIH3mJ9hTWIbk59gKAFXe/J 6e9SqqYwT83qKYuf4ePY0DOTtH1FADz97D8ehqQERj5xketMRhIMN0FDBmOzqvrQAh5BYng9qehC oWGMnpVfLeZjqtOZGZt2doFAEu0AgE5J5OKR/mOQQAO1RopfvgnvUgVV4f7w6GgAXLHC8fWl+UD3 9DRhu4/EUzOeqnjvQBKpYjjp3BoCYHHzZpV+YZbdTOCdwZhQBMu5F+ZKiyRINsdBf1ZiaeqnAJk5 oAR8kZK5oU7VwOQe3pTtzE53A4poIJ54btQA4fmo60x8jlcFKdyowBhjQw/dbumOooAiUAKy/jTl JYcDtS45z6inx/KuKAGF3JXHpimhDtIJ6GpPupnvmlUHDZHPWgYuxfKBxSMoXIHcUJ80be1KXBKG gBF93xxTA4B2hj1qQbOSeuajcgscDikAoCgn7wNO24UfKcn1pqtuPqBSEMJASSQelAiVgcgYApM8 E7hQcZJ29u9JnC9F5oAcMbPvGhlXaASaCSMDI/KhiSRyT+FAxcDICHPsaQgFsfdNG3LkjPFIpILb x1oEPXBUbhx2poG5QQcYNNbPGOlKr4jwBkk9qBjmYMxUHNWYU2rUcUXzFsYJq0oxQA4UtJS0CA1E 9SGon6UmBnXbEKa8f8TSNd+MniXJ8sJEPr1P869fvR8hryqG18/xzMzqR/pJJ3e1Rb3kUj0nRLc2 +mpHghlAzWmnUZHJ71HCu1dgHBFOZ9qrjrWpITDY2R19qYrGRT0zSswYDH36aVOdwOMdqQxyOVbD cihk5Ljoe9DFWTjhqQSbMqeR0oAAQ/3uvY0mcN8wqQqFTI5U1Ef9Xz07GgAGd3XHoafjICtwx70J woV+nY0ADd83K9jQASfLhW/OnbwgAYZHrTC3zkNyvakOVXPVTQAo4YsPmWmEYIZTnJ6U7BAGznPU UoCsc/dI6CgBuVBw3BNKjbXJJyDTGYliSM44pGXC4U/hQA9sDMi0bh5YZTikQrIu08H1pkigDb39 aBCsrIQR35ppfLhsexpxlOzkdO9JGcHnjNAxQozkGhlP8XPoakKBvY+1R4kjB3DcKBDBlG2vkZ6G pD83B+92IppIK7W6Hp7UL/dzgjoaBiHeh4NBkVhhxz6inMQeHyCO9RMMYA596AHGNyOuVpuMfd/O hWZTyeKlLK4wBj3oER/dHP504Lu5xx6ikeMpyeaQO2flOPrQAM2zjrTlOVznI9DS5Q9sH1prqVGT +YoAeXLrhE6UbR1yc+hpiS4HIx704lj97BFACb+cKCKFUH74BPrTfNXOENKcnl+ntTAH2HgZB7U3 y3IyzAinEpn5TzSMh65GPrQAzeV4H5mmsWPIK07e54UHHvSNGvVgDQBGu9jkKtOw2fmQZFKpiIwu QaVkTb80hzQMAzkfLGM1Ht+b7g305BzjzCBT8RgcPk0CGOZcY2Ae9N/fBQAfxFK4C/6yTK+1NZgA RG/FAAqspJaSl3FQT39aiZk2AZYk0vlllAY4oAduTrJ19RTkiLfOGyPQ1EUQHaAQ1SKG7/KPagAP L46Y7GmySbSFHBNSMoH3WBNQFF3bmz9DQBY8yQDG0EVGHwSzx/jTcB+ASopHBXqWx7UAKGR2xlhi nn5mwMMBUAyF+/yfUUm1o03HDMfQ0ASsfm6EAULIrk7h9KiV5FAHIz61KZV24ZfxFAERQvLw2QPW lCgy4ORUqptQnOR1xTI88nr7GgAnj3Jt6Z71VIZWC7ssKtq2WJHbsahkXLGXGMUwIpJQGXaM+op0 rxsuVBJ7imqVyXxwaVVQsW/hoAhJYr8qL9DUTpJuywUfWrDpG5OzJI7jtUHlnfjDN9aBi+Vv+6VF P8qRRyAR7Ggqp627fgaacHosgx60APBcfwNinB0bgtg+hFQrO68bj+Ip5bzCDjkd6BCSKF5C8+op m9iPnyQPSnyPjnP4VXcsTnaR7igaJY5FQ/ICw9DTpbtZMRqhX1qscquQp3eoqPDscc7z+lAFiWdT hFB2r1piTuzrhepwtRquGwScDqcVJvZWDA8k/KMUCOpkGMEr/COR9KiDNgoMNn1pZXEbr1C4GPyo IJG8gH3FIBptykZYk7qWPcFySAPelEjZOCTntSeS27LNgGgBzS4GB+lRht+d2QR0HrUm1VBKDd7m mrgnLdfX0oAVFYqRgY96CfLGAM57GpSCR/eHqKaSg5c5/pQAwHj5Oc04Nxhh8x7ilUfx/lR1JJ4P agBXBVQAPxFIzsuMDr3FNUsgJNOBIGQOvagB67iMKn1NJ8pbDn8qdhuhzk0qxBOTj8aAGkOOAMp6 96aXAJBXNKzkt9449BSsRnhTjvigBv7w4GTt9KkXOduTSKy8nc2aXIAyHOfpQA5mI4DH8qFO4/e4 FMDk8FufWnsMgYYUALubd0Uihyr/AC8A+1N3beOKb5ZGWwPpQA4pjAIyPUUZzyeQOhpE3L8o79Qa cdpOB8poAcjEEluR2NMzjdxlTTiQPlHBpOhAH4+9ADkHzqT6UJjzD7Gjofl4PoaaMbjg4agBzAsW x0Bph37wN3Uc0/dgMCOaR8DFAC7cAgHkim7VwvPQ8044A3EEgjjFR4UJ3zSHcn2rkr60rKqjA9Ki RedxBpScEnqKAG7VBxu/KkBYt3wKcSNufWkXgcseaYgGTnjP1p4HI+6MU35VYZz709CuCQhxQAo5 b7w4oGCxO405SQCdgoDsF6DNIYgwASSaaxTIwSadkn7zD6UNkleBigBjMCPXmpYo8nOKjC7pSOwN XEXAoAei08Ugp1AgooooAQ1E1SGo2oGUrldymuKWwaLxbNI20q6iROOR2PP1ruZhwa57VAILiG5H BU7CfY//AF6kDdhPKt6jFRyEkMOmDmmQTA2yEc4qU48zJOSw6VQDF+cgjhh3qQMAfm+9TQhxjO32 puCOG/A0ADKS2entS7Q7Yxz604MF4Iz70LkSc/dNAAXKEL69qV1HGOh60fLv6/jQD5ZzQArYEeOq 9qap8tOeVNDfOd0f4ilC9+/cGgBmCoyOQaCMY2c+1Gcv8g6dqccEE/dagBuQzfLkN6UjbgcyCmjr 83B9RTyHxlyCvpQA2PkkLzQVx/rDg9qUHgGMbfrTsr/y1HPrQAwIM5PQ96R42B3feWkZyGIQ5B7U iuwOD+VACHg4XkHqDUgUEYwQBTwI5Rxw1Id6ZB/OgBi8fdfn0NP849JFwPWozxyw/EUp3KvPzL60 AKwAHqpqIjyz1ypqRdpGM8GmyRlByNynuKADeX+VuCOh9aRsKuV+8Kjw33ScjsakVwFK4596AIhk 5ZxilD54Xj60/cD9zknsaQop68H0oAXzdpwRn3pjYbml3cbcDHvQNiryfwoENDBwFGd1P+ZGGTv/ AKUp+cEKML+tG9E+43zehpgMbGNzHafSmFXkG4kgVM2chpeR2AqF/nYgMV9qQD1dcbRjNBQqck5H 1qNVlH8Aan7ADlwwpgG9ugUH6il2qTliRR5iAYRt31pCNxG47aAHGTHCMGpvJGXGfYU0p6Lj/a9a MCPnJzQA4bM8ZUGhiir1U0j5k+98o7VHsx8oH4mgB5G5cnaBSE8fIq/Wm4Ctlxu9BSuSRtEeAaAE JA+9tz6U3kjkoooVNhz5WT7mnMveRVC+1AEDldpw3I9KRC2OSSKlDQg/u8H2pwy44GB6GgBA6J06 +hoY8A52+3rUchAOANxpyRl8bjn2NAAFZm4XHuKl2GMfOAy+tJvEYIXn/ZqFw7Akttx2NAEjbGGI jz6VF5cjMMkqB2qNJVHAUlj3FWlkKIMjcDQAzD9yCBTcBm3MvyjuKkwpXAIyeoNNlj8tBszjuKAB MHJD59jTSu58FOB3FQ+bjov51IMovmKx560wHOQfkU8980xzt+UHmnoc/Oygk96jkUM2c4NADSZA vOCPbrTxMPL2uuRUMm5PvHj1pg3vzvBX0osMfvUcR/Mp61CxcE/IdnrUnlxgktKVPtTjGu3H2gmg RWRABlWcE1IqMpJJc+lPVQMDccCnhImP+tYGgCJWfuHFSLnGW3YFKyqPuzbmpCkrIczAD0FAyHzU dyu3cB3prluMsAvt1pEQqx28knrTng3rukbDKelMQgKgfd3GoSZVyOF9KkMgCkIM4qNZZOcjctAC BnyCQM+o6UP5i9F5PcUjAdU3KfQ0LkqR5hX60hjldzhdg2jqfWkWRjJu2A5OBUbRMo4lwP50RuTI o3YOcCgR1EiuzbnIA2jA/CmjdjIGKexG4E46Dr9KQ75G4Uke/SkAwcklhg+opwIDfMS3pilaMgfM /wCAqINtXaE2570AT7GY7gce1Ah6EthqbFuUgN931FSGPacoS1ABl14Y7V/nUbRrklSferCYkG1+ aY+IzhSMelADEUg5BOB29aeyktuCnAoAEq4DbRTljzwZDgUAJhm5ZRinA4GSwApGCH+I4piZDEbc rQBKh3c8mlKMxJxgCmYZvuEKfSlQvu2yMRQAgQk5wfwpNrk9DxUjlc4DH8KTjoN3vQAza2c4IxRu IOWB/KlYjH8QWl4ODlsUAKpUjJ/lSL1JBBHvTWY9s04N5i7TgEd6AFZQwyVGPY0xUPUHA9M1IwY4 VhkeopoPOfvKKAHbVx8zENSnCrzyKF2sd3BHoe1LkckcqO1ACDGMn5gentS+WAMqevajaMFwcH0p u49ehoAXawXNIhCjLA80BtxDEsAPan5yc9R3oATIGW6imSFX2jOMDmpHVWX5OvpUSxsTgED1zQAo GRw+KOcbdwIFKWZRjapo80YxsFADhJngvgU07d2Q2RTtwxhVU5pfbaKQxq7XPTaacFw2e9NORwRx 7U/cUUcZWgQ1wWOB97uKVMFdpJz6UqAHnrQyg98DPUUDG5IOCtPAY/dUAepoxEvJYtSdTwCBQA7G w8gGg5IyPu0gdQfl69xSqd75xj2oAlhjwMnrVhRTUGKkAoAWloooEFFFFADTTGp5qNqBleXpXO6+ pfTLkA/MIyw+o5/pXQTHg1z+tsBZXGf+eb/yNSwRJodwbrTIXHIZQc1rjBwD971riPAN28umhHfc iAY9q7QbiM9BVASFgpxJyexFGNx2scCkUjPyjP1pTH3P5UAJ9z5cbh6005Awx+XtTizBcKMijy84 bOR6UAMUMgI6qe9P24xv5X1oDgcKMr6elLsK4J5U0AITtI2/hig/OMudp7U75U+6NwNNKllz/DQA 1Wx169jSMxc7WGPenBwvygbh/KkCeYxA/KgBCGXAHzj1oVQDuJPHY08fJ904PoajdifvE7qAFZ88 R8jvTc7v9r2pNhyGPy/SpflXG4YPqKAIDCSCVOPY0ivt4YZ9+9TOGbHp6ioyFHBPPrQAcNyPzqRX YDn5lqEo6nOAF9aUE8haAJwR9V9KTYcZQ8f3TUQOD8xwfSpNxHzKKAIztLYI2mnhtnyNyp71Iyxz IGzzUYBPykY96AEKKjA9VNRvHuHzcY6Gpc+WNj856GmYdm2noOlAEShuNvNOypP7zrTmwnbBHWkw QpY4agAMbN8wPy+lNCgNk/MPWhWZ/wDZpQpJ4x9RQIUvn5R8pPSgRhMgAMfWjLL1AP1pgfc3Qr9K YChQx6kGlK4HZvenebg7cAk9qRFUk5BB9u1ACLHMenFKyyKuX+YU8uU6Pn2qE+Zu3EjB7UgEDIOU XnvQfKcZY4b0oDfNnbtNOCKzgOPxpgMy44A+WnqFx8py3oaeUMfCnK03aAcoMN3oAaYznLZ+lIeQ VUYHenmYZ+YEmo2Bfk5UUAKsSAA5NNdhn5XJNBkY8KTtpAAmcHJPtQAbUBLM7GoXAcnhytSkk8ZJ P0pMEEbtxPpQAwW4A3DA+tKJd/yjkdM1L9n8xSzbh6UbVjGCM+4oAb5RU7h839KjLF22gdO9THcv zZ49qjc7+MY9xQAnyqOG3H071GQzN864X3prOYyQpDfhTlmdhw2T6GgB4hjjIeMjPpRlXOTlCP1q M7c91ejc/RxlPUUAOLZyCASf4hSxw8583PtSIO0J47g04iMD5shqABlctyqsoppEZO3BWpMR4+WQ 59KcFZUOcNQBVaE/wPThvAw4yPUUEYyWQgeopVLAfI+fY0AV7jYACATT44pHAZNuPQ0r8HLKVP04 pCQq7lHPbBpgOYOhw+0fhTfLjPO8flSrNcbQWjDLSESOfkUA0DInGw5Eq/iKjYu33mUD6VOY5U+8 isaQo55aIYoAgVwBtVVJ9aQjaf3g/I1IxXdiOPYfU07ygPmc59+1Aitgu4EeQPU1IIWGXZ9xHY07 eScIBgUu5Q4MmQf0NAELNz8o4prpkZVgB7HmrE6grujHy1WXyjnflW9aAGEtjG8N9aBGSv3gfanO sQ+8uQOjCm9x3HqKBjSypwynHoahIjaQbODnpVzeNuHXevrUSeWJvlXIJoA6l1BOVVQMDk/SmFzn Cnj2qQxNIRjgYGc/SlMCIPmfikIh3AdOTTGWQnLAtVjzEXhFpCWbqQooAjUnGAc/7NPTIPBwB2qM lQ22MEN607Zg/vGJb1FAEwKyDA+VqgkjB+X+L1qQjON3T1pwzjbjI9aAIFi5CsdpqwF/gC/jTWRQ px81N8wxpgHAP6UAOkBU4LhfpSbsDg/jUWBIeWJ/CpUhT+Etu96AJDt2g9z1NKW2rxhhSNkH5xj3 FREFTvTmgCZDtGV6+hpjSOW2n5c96AS2GcYJ6YqTPHzjPoaAGojYwG3CnfdGB+RpwG3kdPUUbsrl lz70ANCgcDgn1pfLI4xzRlcZBzS72HzDmgBEDgHb+OaZje/XbUzksoy+M+lQMo3YEhJ+lACbF3Hc SD6igIT/ABEe+KcM4xg0vmD7vINACDH8THilLB8Dcc0NIiDbk80ix7V3oc0APLGNQN/HSnLlVyGB qMYblx+FKBnmP7o7UADcHcR9MU9QSu4imbgxyp59DSYb1x7UDJA2M5jyfag7erIaaJSMKCd3pQzS nqMUCHosfJ2mlGzG7Bx2qPzJCdoXPqcUNK44xigB6gMxK8expCcvle3Y0z5jjGc+1OO4qMr3oAkT CgsOG9KbjzDwMGlXJA3DI9afjevUCkMiyI845+tJlzzuGPSlxu+U9c9aUKqnnhh0oAAoPQbWqWIZ JJ9ajOSPnH0IqeEYUUATqOKeKaKfQJhRRRQAUUUUANNROeDUjVC5oGVpTxzXL+KZfs+iX02M7YH/ AFBH9a6WZsZrj/Gko/4R6+QnG+PaPqSKlgZHw5doYXXbnpzXo6DzDnP/AAGuH+HwMemEPGMbsbq7 gxnYChqgY7IBwo59KUDd97NPRRjnrUbM27aBn3oAR+AMfnTUBbgnBFSbRjn8hSMMfd4oAGwnsf50 0lyAcYHpQGVR0z7GlKM65DcelABuCj5OT6U088g4PpRuVRgj8aQrkbmP0IoAeu36NSLhWJfg+opF XIy34GmHcrcc/WgCSRWblehpqrtHzD8KegOMnhh2pdyyDnhqAGbQ33W/A0NCV5HJ9KXy9gyT83rR uZRtbqe4oAYAecMR7Gm4VzwPm9KkfsvUetAjDcDn3oAYpIOH49qHTL4XjipNq7tr9e1I0TY5Py0A N6AqwyadEPmx+hpAypgOeexpDl2+Xgjv60APmQIcqce1GfPXA4xUEnzHOfmHalRCQXVvwoAfhcbW GT2NNIz8r8EdKC7OmAvI70gIYZP3hQIaA3bkj1prbyPubfpUjEyJuHy460CU7dp5Hc0DGIZGG1dp A607ds4ZD9aQKo5Q5FI0pOMcj0NAgLCTjPFNxtkwvX2p/mIRjZg+1Kiorg85PrQMYwIGcc0+FiWI FOfLMy/w4pFwCu0dRjimIQqrduc0x4Fxnccg1ITtyo65zSlcAk9xmgBgiYA5PT1oU7gOMdqkB8xh 6EVG52fKPWgBWb92QvUGq5D7d5OPWpwVQsO5FV1DyswbgdqAFMgXoDn1o3Snqc1JlBEFI56UjMFx yOe1IBfM8teBUbSu2MJx64pdjE5ZhikIdsgNhaYDWnkHyomaQGU/MQadsKAHNNyzE5OF+tAAzSsd qt9eaBhOQ2X9KAhboBj3p3EZwNuaAJUiLrv6GonGSQ42j1FBlIBzJ+VMV8tukzigBrQ55420wxkK dihh61OcPnDYHpTQGztjOPrQBCqMvzEg/wCyadhCcsSh9KfIzJw6bj6iomKjlzn2NADyrdf4R3FI r7htxuHc96Rd3Y4H901ICJDjbt9xQA10jUZTk+lRvuYDaxB7ipZEEC7hz7iq/wA0i5Y7V9e5oAfH NIp2gbvWnyPG38Ox6jCAj92xXHUmkeNCBlyx9qAGh5wD8ysPemhA5+aQKfSk2KmA4x75pTLCqHdF uHrTAcIGj+7cZFOIJH+tGahK5TciYFRi68vh4sj1oAsFSh3GegGaX/lsu0VGZo51z5WQPSkVYx0h bPsaQyUl1G3KMfSmrDNu3Njb6Zpn7qJslGz6U0vvbneqUxD5MvkJGQfUVCoZc+ZhsetKXcHELblp eCCZj+VACOyyDbESG9DVcSyRSYljyO9TNtLYDYUd+9MkEixnkOp7+lAAW3cxLkehoDAnDIVNCR4j DK+T6UCQvwVBxQO4NGwGSPl9RUBRluEKdM1P5jIcIc/7JpnmKWXPyODQM6LzyH8sMcADp9KPMbOA pYnuadMAcMi4GB/KhZcj5aRIhEh5JxSp8vJOaDE55OTn1NOEQ4y2PpQApw4+bp7Uh3LkKOPelMir 0wPpTfM5+RefU0AO2lVy3I/u0wyMOEHHpTgG5LHr60m6MdT+AoAQNhMqeT6UAbuAh3etOfGAVAX6 0qlz0PHtQAiqwYhiF+lPKjHBNLtCnJXP1NBaQ/dCqKAGhgvUlvrTnBIDIuB3FM2RsfnY7u+KkBKK ccrigCPBDZOce1PUlGweppobOQ3I7Ypw3OPQj9aAFDdWHQdVoHmNyuApoCgHcOB3pW4Gwcg96AGq jbidwxTwSDuyM+lMj25Ktxinb0zjPIoAcByWLDntRnBzuGfpTTljksB+FNJUdDkmgCUyso6rTGkJ XAUMfWmGNTy7gGgsScDAx3oAbtycsAfapV3AYUcd6RRtPzct2xS5Lv02E9DQAvyjBznHapAolHHy n0phCqOeG9fWk+ZjyStAD2G3gjnsRTCjkfPytSLIEO1xn3FOMbHLBsKe1AyLCryDmkLkjJY0rbTw F2nv703bhuf0oECvJ/DketKNzcsSfwpzEgYGRSqJccHigYgJXPJ/AUBiBjB5p2WU8ZzTWD5ySRQI QN/Cmc1ImxMbzhvSo8MeQCvvQFJPzc0DJmBbk4C+tNyE4Hz+9IEXu5I9KXKKcxgmgBSrHBzwT0q1 GOKqxkvJ0wKuIOKQDxTqQUgPzEUCHUUUUAFFFIaAGMagkNTPVaU9aQylcvgGvOvHV8VtYLdTkyy5 I/2V5/mRXdX8m1DXlHiac3viVoUbP2ZRHj3PJ/nj8KljR2fgAyfYiF5TOcGu5XDN8vyt3Fc74SsR a6ZHuXY5Gc10ajqW/AirEKcM3PDCgHc2D+lNHAJIyvrTQ5jXOcg0AOLYY44FMzjpzmg4IHOSaGJD bRgUALtXrIce1MZiSNvyipVSNV3Ocmml1PCDHuaAGovPPA70jnDfLnbSHjgck9SacqM3096AGgNk 4PFIBnJz+FDHacD5j7UElyAwIHqKAAPu4bjHSlIyM9G7UBMkEjI9RT8dmPTpQAiMQCH5PpTT8ucd fQ04bt+fT9aV5EbgrzQAwAH5ckE96CxhwQP/AK9P2YXP3h+tMB4zjco7UCHlkcZbg0zzPlK557Up lVxjGAPaoyMjOBzQMeoVxtfrS7SAEOQeoNMUHH3TkelOMnmLt6GgQxvvYH3/AOdG0feJI9RSBSp6 /MKcjAsS45oGIA27cnT0pW2FNxBBpGkTcdo/KjGBu+8D2oERlic+X+OaAgXkgjNPYE8hMDvSBcqS Hz7GmA3IY8cD2pS67dpwT2I600lQcAYJp4jTGWGCe9IBAoXkHNOPzrkngU3yiDu7eopVG92FADn+ ZlxwOlNztXA6g9aUnMQA6g80uAu73GaABgFbJ/iFNBLbSeF6YoOXjDE9KY7EjYvY0wHeZygHriny AKSMdRnNRgBFYdxzT2y21270gGqN0iMwxkYpkgYSHBwBUm792cfwmklcOVI7jGaYEBRQ55yx6UbN vL8n1FIR5ZySSR2NIGJbgEMex6UALt53E4HpSmbsIjj1p4UH/WDB/SmF3UFUUMKAGbl6sufSnY3c 7QB6UIHVs4H41IPMYfNhVoAhJOPljBNJzxgLnvUjhV4Dn8KZmNVIQF2Pc0AARU5cHNNM+Dg/P6Cm MkoXluT+lSJGqgFgCfUUANIJcM3yj0pzOzjCjgdxTuWPJ49DUcjHOAnHqKAFDlQApJJ9aRkGNzKG PYinoUHUkfWlfa33SCfagCBlZvvZ204S+Wu1fmz2NIzzR9sk04ONhxgPTAge5JIU/L7ULnPA3N79 Kj+XduflqkL7V7gmkAPxzINx9BTt7YAMYQfrTBHIRu+6KcNinklmoGRyorLlEYkdz0qGMklg2VHp 2q6xnKYC4X6VHtPl/wAJ9jTERphcmN9p9D0pmxZyV37X/nQMhsAZX0NPUI5+VQSOx60DIjavHxkA +o6VIg2/K2c+tOy65BUsvelKgr8gxn1oAjPkbj+8O70NKI1blpsD0NRsqKfmGWNKiKpy5BHpSAkk eFFAQ5b1FRlQQWfDe4pzSIeIoww7+1OCx4BA+opiKq5ZxtUYPFK0PkoWDnPoad+65KZ3A9KZKc/f ztPNAEImVeD96pUZmfAA571WlEaSAx8j3p8MgZxk7SD0oYyYxMQS3BHcVDIj5AK7we/pV3zNhZW5 BHWnRqh2N70Aa7IAfmJYbRx+FJE7glVQAfSpGlG8L0fA/lTyGKZIANIRERM5+8MUeSf4mxTsu3G4 KKbsjXJd2Y0AJ+6Tvn6UolY8omB9KQSR7sLH0oZpT22igB2xj99gAaiZEUjBxSkZxyzewp6xuP4V Qep60AIq99pPualEjEbRhfemZTnc5Y+1OwT0TAoACyjnczt6VHIxx8wKZ96m2uoJUD8aiIWUnzG+ b0oAehIUDaGpwCt1bB/u1GI3VeOB6ignjjlvWgB6oQMEBQelPB2kEckdTUal3XDnOOwqYShU2lea BimM9SflNRSPtG0DPoacGY8PwtAA/wCWXPsaBChN6bjgEUHaMMi57GkA4+Y7T6UxC5LBSAKAJSGx uKimlnzkx8e9NQZOGkp52jrLk0AIMMOY+fWkIIH3Dj1p24AcMaMyEEjJWgBqoVGc5Wj5m4U5UU5V 7q31FO3LnKnDelADcBVyGB9j1pAzMpB4HvSEpvORhqCWfhxj3oAXgDEZz606MsDyc+1ATyxuBGPW lLh+OP8AeoAmfa6DGAagwehXj1pfuNnJJ9aUOr8OaQx2xdvy5JppDA8hvpT0QfwtgU4qV/jzQBXL c8BhS+w3Mak2Fz96l8qRfutQAwIx+9nHpQAwOApNOKTn7xz9KTMidO1AACwPIAHpS7hztGfUUoCy HLNhqbITtIAGfUUAS24GM+tW1HFQQjCgVYFAMWkAIJNOooEFFFFABSE0tMY0AMc1Tnbg1Zc1RuWw DSGYeqXKQI8shGyMF2z6AZryrRYX1TWRJJlZJpC7HHqc12Xjm98jRLhVbDTkQj8eT+grL8AWb3F9 5rAYQcZqY6srY9Rs08i0SNhxjrVzbtj45B7VXHygLj8DUx6jb37VZIhGF+X8RUT7MDsfSppCjYB4 NMJTH3c470AR8ZyFORSbic4WpA7ov3fxNI2QByOaAE8pyMtxTliwvb60ZGfmYk+gp4Td1BC0DGAI oyMuaQyMfQA9vSnEID+74NNKHOXH40CEBEZ27cg96kCbB6qajB+YDG5ak3bflHKn9KAE24kBXhad JzlT0PQ0h/d+6mkHy8N0PSgAPyjYR9DSKmDl+po4Y4boOhp28/cbGaAG7cn92acMMcYwRUTHZwg5 9BXF+M/GcenwPYWUhNz0mkQ/d/2QfX1NTKSirjSuyXxV4zi0icW+nGOW4U/OSMqPb/E1q+GNYn17 R1vbmGOKTeVwmdpHGDz9a8i0vT5dVuPtM+7yc5+b+P6e3869N0XWLbTYY9OIYOfnGBwM9P5VzQrc 1S1zadNRhc6lnYLtQDP1qNQAMknPtTkdSobaaaMMc5IFdZzhgsd28fjQE8w/ex6044Y4BGKGG0YC An2pgIV2nHGfWmKpPLcU4Lt+Yqc/Wh2DHkED1pAPWYqNuM0xgmMn16UoUAHZzimNuI+YgGgBRtQb s7h6GnZBTIIB9DUXltwdwIzxSuxYbdgx3NACtIXUL0A6kUwPiUCMUodVwqxnB6mnF0CjCYOetMCT 7isGwMjNQq29kY8DpSuyuyt270jFAGVevUUhknDBkHJqOP5dytUseEZXPcVHI6mYHG0D9aBCr87A noRTjuaIj+6aYTlvQA5p27dIVBwpFMBgfO4YwCKj58vpjFP3jIXuDjmnMgRtwOSe1AEJyzbxyO4p y7QPl5J7GhkckhgAPanIyMoU4HvQBGd7MADx3FOJMa/ID9KsGMKPlwRUYQE8nkdj2oArq0jHJOMd jSs/mjaxKjpmpHR26LlKj3D7v6HtQAzBi4QhzSHaTypBPcUrRgnABB7kGpABGBtbJ9DQAwho1yj7 vY0nzH5pIyMelP2HO51/I9Ka0nO2Nz7gigBQ4Y4Q5PoaayhX3OCPcU3KgcjLHutNABBLSEfWgBW/ ecIwI96jWKRG4HPbBpTlj8oBHqKdu2HqQaAAsVJLbgaiMik/McfSp/P38DB+tI8cbdU2n1FAyDdn gDj1p6IsZL/fPvSFlX5cjNMaQL1+92ApiJmVpxkkqtM2RxrhWOfWmq8kn+skCqO1A2k8DI9TSGL5 sx4LbV9ajIQvgSFm+lSbI2zlmYntSm3MYBzlfftTENMUp/1hGPUU2SFlIYMD7inguo+STcP7ppPm 3cEK3oelADN7qMuQ3uKXLP0GB61G6urlmIDf3expB5rtx8nqD3oGSsYzhf4vWopLd42DbgRUyiNQ egb0qGWVyoIyoFADRLCrMpyG7Ypu52GX4HqKVljldRHyx7mmmN4SVkG5T70AODJnCDqOtRNlsAkE 9MUwCMAsoOQeeaFKsSTGwNAAYyQGVV4PNJPCSQ+RkjtUwCKWXacEZFJ8vkh9rcGgBoaQRhmII6c0 6ISrHu4AzUKhpmOwHaKUPKzjkBFPSkM6YrkjaOMDr16U5EVTyxI9KVwzMNwCjA+YfSmnCcg5PqKC R/0Q4pp3FgAg/GmtI7AAnHoaaNx+8wUj0oAlKsD8zBfpURZFboWPqacCT159zQ2CAOv0FACeZLtw gCj1xRtDDcxLUoLfdK89OaXy9vO78BQACWML8owfSg+YwznijZGj7gOO9SmQAfKooAiXDcOSDTmj iU5P500yvnDAY9hSAbzhCfoaAHBmPCHcvpR8p/2W9KXyz/HlfpTjhBjAb3oGMCshBxjnr61K0rdw GFRAlmwhJHcGpRGSD29qAFG1xndj2pNy5wgw3rTQiKfunAp+SfuIAPegRG+Djc2aQDDYXOD3NSuM Dnbmo2ZioO4DFACBAH5JqQDbzjj6U0tjDA596lBdgP3iigBhkyOB+lNBdMYbPsKlZCRgyD6U0box wQaAG4DkFc59KdtycMoVvWnA+ZyOGpCXBxJ07GgBducCT8CKGjwuVO4UmMLknK0gJHMZ+XvmgYwH b3JB/hzUgA69B/dp+EYZQ/NSeUp/1g59aQBhgvyDK+9NyitkLmpvKIGUaoSJC/3eaAF3oc4U/nS/ u+M7jSBiOSpzUgZx/ACKYCDyTj5jS7F6rKaUuveKmjaM/LigAOegfmk5yMtSkHPyinDd3jBoAj2R nlpKcqKGG1sinMflwYgKWFfm46UgLCjipF54PWkUU8UAxaKKKBBRRRQAGo2NPNRMcUDIpDWZePhD V+VuKxdRkwhHrUsZ5p45uhNqFnZ9lBlYe5OB/I11/geyMOnrJg/N7c157qcg1HxbclfnUSiFfovH 8816/olobfTok3fw/jRBAzVDgEbjkUNgyD5uB0oWNV/hznuaQArITwPpVCFwN+QCaV2+XG4DmlJT HUs1N5LDC4oAR2BH8TUvlliCF/Om4bfgECpSR3b8qAGlWUHDAmm7XY4dsUuY1zhST3oG5jkH/gJo AaWJ4Iz7inKDwc7l9KOB0+U+lIMk8fLQA7C5JU4PpUa5RjvHBp6Fd/zcEd6ViS2G5WgBchR83K03 gttP3T3oYgcdVNAyPkOMHvQApOFKnp2NNQcfP17GnKA5KN26Vn6zq0Gi6fJc3JyF4jQdXbsKTdgs YvjLxOmh2PkwHOoTDjB5iT+99fSvLbW1m1dzFO7m3Dl2XAwSccZ6npzU815qHiPUXDsrF5fMeTHI 7Z+gHQV1Flp8dtAscYwo45615mJxGtkdtCl9pj7O3VYlAG1QMdO1ZdvPcQeJWu75fs1tv+TzmCna OBwTmp/EGrRaXZhQA87HEcZPVvX6D+dY9h4fa9C3mpEySv8AMQ5yc+tZUp+z99lzjz+6esad4j0r UpBb2l5FPIBkiPP8+lajGJhgDBrgNF02OHVLWGGI4X97IycbQOgP1Nd6qJtyGAPfNenQqSqR5mcV SChKyFMUaLw3NRYYnA5NPELM27qtNdQh4DCtzMYd/K4OaMHZtYHI9KlMqoBjO4etNWRvNJ2jBpDE Xy1XOSD3pmVbO7kU9wd5xwpqJQXzjbigAURqcnIU0rsijCOc/SlKKF+ZfxzTdsXfIFMQqfKOZBn3 ody/G9cUN5RGQTx6imkRlc5FIBFVpFIyAoqQADaVHBGCaaigMGLAKaep3KyKQB2NADWZguwc4PWo jlvvHIFSSkDbtbDHjNMZWIAYcHuKYDy29VxxxzSn7qsT0pqbURlBzjpSoC5IYcHpSACQ0mMcHvUp i2pw+cVG7AxYABYU1SxYZO0UwHeYHbLKQB39adsRic4x2pRKo+XAP0ppjSU5J249KAGkPEcqSfak aQufmQg+tSrG45U5X0pWkVRiRMUAVjO0bYUkj3p/mBhtwCT1NN8lXY7WwD2oMRhX5f0oAdtiX7pI agQsfmOCajC4O58A+9N83dwhIFAD3J6AEDvTN23ptY07znA2qMml3RhfmTn1oAaFT+MEHrxTfIWU ffOPSniMSMG8wj2okVk+7hv50AQyRhBjOMdCKYATzITjsRSkqWIcEGk27eSxC+hoAdjceMFe+KeN w4jOR6GodwLAD5AfyNP5Q4BAJ70AI7CPllB9ab5kTcpHlv5VIyMzDzDkf3hSS7ETAx9RTAqOf32G G9vQdqsLASoMpwOwFVfMdZ9qLn3qZXUfNLLyOxoAmMqqMRw5x3qu7Sv1Hyn0NKtxM5YRIClNLui5 GQ3ow4oAVYMjeoIPqKjkkIGJAx9CKsJcSqn3BzUMss2d3l8Uh2IYmJb51ZlHc9qla4AOPvDsfSnB nZcNuVfpTRtU7UbPqSKYhpZVwZG3Z6Y7UjiSSM4YMnp6VJ5apySjk9qia3bOQMZ/umgZADKANnzE H0qRppSyiQce9NKyRHgNmmnfIfnfB9DRYZMmAXCpyfTpSbpMD5OvFIqSR5ZWX86SOSQjHvnPYUCH fOCrkAdjTGkZ90aDI70MXmbYucevalY+UvlxjLdyKAEBLYjQfU0wxxGYAyYC+/WmO7ou1R9TUCxZ kXKMzZzQB1kkzI21umBx+FRmTJwCF9vWhzlwHBBwP5Uojw4J+Ye9IQoRWHGd3qTSjer7SQCaV3Y5 CgACliEWM4YnHegB4VMZbLEetO81V4H6CmOAqbiPwNIGJHAAFADn3NyFI9zTA4IwWIx2o78n86Qq pOQSWHoKAAA5xg7T3NSCIBuZPwpQ/wAufL6etBkK8gKKAGv8v3CSacsqADcpDetN3Fuc496YyliA gLY9qAJxK54HIpQqqNw6+lMiQg8nY1PIA5fn3FADWkO7AUA+tLudiNzgD2p5wRyBtqPau75VLfWg Bcr2Y5FGVyBuJNGcckKPagZY8lVoGPVEPJzR+7UHI+lAYL/GKbvJPBoEOVgU27aAI/48/hSqTj/W AUHBJ+fdQAuIM5yc04GH0JpoBz/CPrTtrDuv4UAMbvsUik8042v0p7bwRjFDbsYK5BoGMKD7yEn2 oEaseDtI7U5IznchIx2oLZJEnBoAAWTrgH19amWZXG1xiowAMZIK+tSARjlRmkAhwOAfl9aRt68g 5WleP5cofwqJfMzw2PY0wFEnz4ORS7hniSlO7jcDSbYzy2QfcUALuccbwabuyeTinGNCOHOPSk8s Z6nigBwC/wDPU0o6jEhNRlB3yTRsXA6igB5Zt3JzU0I4zUHUd+tW4xgUgRKOlOFIKdQIKKKKACii igBpqFzUrGoJDikMrTtgGuY1y8W1tpp2PESM/wCQroLp8A15/wCOLvy9JeLOGuJFiH06n+VTLYaO Z8J2jXOqxvIp3E7ifevaLeNo41GAox3rzrwBZFGecHJ+6Aa9HDNgBhgCrWwnuOznqeaRmOMFefUU qkEkLyPSnDbwGH4UANEpHAUClxk7ncfhSEZbaOPrSYRAaAHK0e7J5xT3fnCqBnvUOAflK7geaeWI XG3NACrtDZHBHXNK5U8Dr6iowWcYbGKRkYYB4U0AOIx97kdjSPnaM4x29abgLwDkUoT+JTnHagBQ flCryD+lKw+XCnPtTQctkcMaQ53ZJx70DHQ4A+YEE+tOZSMq2SD0oXEpGeCOlPU7vkbrQBG7rDC7 SMqKgLFj0AHU1454q1+fxHqnlwo32eL5YkVgDtPf6muk8f8AiMEjRbeVQC2Jnz19voO9YPh/SIlc XanfkfI5UgnjlsHoD0A9PrXFia6irI2o0nJ6l3QdHFjagEfvXwZSPX0HsK0L+8g020aSRgoClyT/ AAr64/Qe9XF2wQh8HJOAB/F7VxU8lx4i137HA7C2gfNxMvRmHG0ew6D8TXlQXM3KWx3yelkGk2cu v6kdXu0xFnEEZ6AD/P511DItvG0kh+VBk+9XLa2WCJYYUCqAAAB0FXNLtxeX24xh7WBuXP8AHIPT 2H86ukpV6llsRNqnEv6Dpz2dq0r/AOtuG8yT29B+FbIbfwyA471KqIU+Qc0bNowwr3UlFWR5rbbu xhCAdStMVDy28Z96c3zH2FRlgxwBnFUIk2l0JZQcVA2Pu7SD7U532gjdj3piykd8n3oAVyoTbuO7 pzSYCrgMDTvM7tHk0m5SOYjQAwqTj5c0pRhjCc/Wk3D+6RRuIPGTQA4o+3pzULoV5ZfwqR+eSabk g53D8aYhiBzyy/L6U7IdxsXA70pmcH7wx6dqV5EK5xhj3FAACi9QGHpQMscqdo9DTQoHJOfcUNIW +UDPvQBJlEb5hg1GGLc9AD1pFJ6r8/1p20bjnjjpQApHzFU6N3pUzGhU4OO1LCC8eAORSqArh2Oe xpAN3RkDKbfemtEJAdr8VLI24kbcqOahbZIfkylMABlVPlzxSpI3V/mNRmVon2I2frT+2Zl/KkMV nWT+AqPWmlVUjZJk+9KGEnCthfegxbVzwaYhSrsPm2n2qFthyApU+ooYktwrD1NIZAowr8ntigAL KgwrBj70KhPzOp/ChlwA0iqR7UhLDiJuP5UAIz5IRW5+lO5jAzyfY0zc0fTDE9qTI++w/AUAPcj7 zofY1GD5oIYEqD0NSJH5pyHI9jTZA7nYuDjuKAFOGXYnI7g9qb5IRfkP/ATSA+UvzcH1pwbzeT93 1HWgCPMx+509DULBifnXB9M1OWCtt+8PammPJDs2aAGCRNytt29qPJibcxPOe1IRkbQAeetOZFAY AnJoGGDDnb37Co2d9o3AOpPTuKUQSFlZHGaSVnOQwAYHqKBCKwdyu1gBQzwnu4+tNLyIQT1PtS+e zDayqfwpgOjMUn/LQgfWpBAg4WUY96qebGQcpjHXFO/0bbna2T6GkOxO0ewZ2o341XYOxwImA9Qa akMTtlpmX0BNTg+SmEuAfbNMQ2NUXPzMvqWokkQgKsiufpQ7TydVDL6Cm+ZAow0JB9qAImhOCxUY /wBk1CI3JwpIX0NTMsUhJyyCmqF6eYdg/M0DHx73HloML3IodkhXy4sFu5NIHeQ+VB8q92okjSLC J80h6mgCFBI+eyij96pD5GWPFSmNjiMnAHJppUSSg7iFXpigDocfP8iljgfM30o2jPzPlvQU92di AxCLgcDr0pBtDZVOe5NIQ5I1cHIIHrTCpH3eQO9P3gcs24+g6Uz72SDtPoKAAFP4su38qcSG6nA9 qZuxwUwfWl8lm+Yt+VAClFx8gH1Y0gixy0gH0pzRA4LE4FLuhXgDcfegABjHq9DE7cbQAaPMIHCg D6U3eTyQzGgBFOzhUz9akVpsZ4FJl/8AZX60hwOCxY+lAAWDElzlh6UokZVwQdp9aXGR9wD3ppDE j+IegoAM5PysT7GnZduBwBSKiA7iQvtQZlbj07igCURkDOwZ9zTCCDyBTVYAck4pSUP3c/WgaHBX 7BaXy3JyStNVl7tSloieASaAHDaM8JSeZjoo/KnLtJ+WPHvS7CT92gQg5HJWmgDH3qfsOfuj86f9 3+6KAIwrZ44p6hh/GKUEnuKTD7uwoGGAzffwfWl284f5vekKMV/1ij1pqZGTvyfSgQ/ao6Hj0oUf N8jc+hpN6uRuGKUxkAkHAoGG7Bwwwfak+XJ35HvSBsfKRkepp+No5UMKAFXp8slBLn0NIAgHyflR u9VyKAEyQeQKUF+o20b0zzGaRmj6BTn3oAeXk7KvtThI5HKiox5foQacFU9Gx9aQDtxdx0wKsIKr QKecnPNW16UAOFOpBS0CCiiigApDS01jQAxjVeU8VMxqrM3FIZnXsmENeX+M5/tWrWlpn5Y0Ln2L Hj9B+tejai527R1PAryiRn1bxTO6HKGbYv8Aur8v9Kh6spHpnhCwFppUQYFmIzmulK/L854qnpSL a2cca/MAMVdbkHj860JGDodi596TaScv271JllTH8qYqlySQTQAoVeSWz2phwDhuRUoBQYCj8aYV z8zMPwoGO3ll2quFFMYuvQ0ZT+Ikj2pVAc4249KAGrgDBBzUgwwwzfgaQ7xkFRj6U3aWOQfwoEOK rj5KjZCDknGaerdVUZFKEyM5yPQ0AJuDAKVx70FfLXkbhSlgvCjPtQAx6n8KAFUJgBW5rA8V+IIt D0x3Z9twR8mOoHr9fSrHiXXLbw/pD3hUNcE7YIc8yP8A4DvXnd9aX3iS6S81QCCQyDbCkmegB6du CK569ZQVjWlTcmYukWsur3slxdIChIL5Gfog/PJNdvAoixuIAPU+1Rx21vp1q8jKEhiGTjt/9esy z1C61VnbeIrFZQrRooLMByQT/SvJleq+Y71aOiKniDWJZHisrIkXNx8seOSiHjP1P8q3tE0mHR7B bZFHmE5c4wSaxvDmnIdTv9TdzOTM8cMjDGQDjI9K6Z28pPMfLEkAKOrE9hWdTVqnEa0XMyVY2ubm O1iOHlBJb+4nc/0FdJZ2CWVusUIEcaDCiq+j6ebRN8oDXMhzK3Yeij2FbEmxVG455r2MNQVGHmzg q1OdiQDb8z/nSzkE8AnNNDE52cexpoGSckg10GQPgJgrUaKoGWOKexYkZOQKY3zHABx3xTEMK7iS duB0pqRmR+mAKe+OADmkY4wACKYiNi+/APSnrLMR0WnHAHX86jKs/IK0APzKTgqv4UjYx70wxuR0 P50nlnvkEe9ADSEPBbjNG2I8BsexqRYxjOAwpMIM7VyfemBGQnQ8Gj5QpO3gd+1O3KDjGCeorznx beXes6k9rp+4wwIcqH2jPr1rKrVVNXZpCDkz0EMh6Ag+1SKFb73P0rjfAGti5019OvZC15bNjk5J XtXZBWblenrVU5qauiZLldh5IB45Pp3oAZm6Z9qCAi5dcH1pVlbqvzCrJHENESVXOahI8xiM4PpU om4bI5qCR1WPcR81IY6R2AUAc9DTS+0bMcnvUaySAHH69aVCJCRn5qABwEBJX/gVOVRt3b8g0jR7 Dy3NNA3KS52/SmIl3oeBgmlCJ1LYP1qFVIXcFBA70vmB+BGSRQBK7OgwpUmmqjYy8YJ9RUeArbmV gaiaTc21WcD1oAe5yCBketN4QAJg+4pVZUTa+cnoaYymI7+x6YoAUgDlxub2oClmJbDY6D0pAPMb cw+hFBy5IHI7kUAOVst+7OfWpHKlePlcetM27RkH8R1owzDc4JTt60ARjMxKycDtSKNmPLIJ9Kkc hR8g3exohjjZNxOH9qAGRq6TMz4BI6UTKXI2DafWlYuZcNyp70Sjy0GwkjNAFZsIzJgl+5FSj5GH OSRTfMVRIF5JHemxcKhk70DGtME27Scg80nn5LgZOexFSuAFdQMAc01Z4DICR25yKAItzCMHBzTG fbgFsfUVYSSMEqAcE8CiaSNojk9PbmmBVLLuKqV5705UdedvHtTvMiCg4Ut9KUmWT7kYC98GkBGy tKcbD9cULAiZD/mash2jAAzn0pryOcmRVK+mKYisApbEZ/8AHqd5QT5nLU1zZnB2FSfSozFG/wDy 1fHpQFiQvuOF3BfUim+Um4Atk0fMvyRzED3HSnKPKO4yqx+lAyZlaNf7o7CowVt13MRvNCSvITJI pKr0poeOSRpJEIHYGgBpkLHy1I55Y1JEiNIAD8qnnNRFYs/KMM36VJIkMYSNT8zHk0BodBIMEEAE YHJPtTAjSHA5H6U4xxo33t5wOPwp25m9EHfFIQbEjHzkfQU1nBUqiYHrSEqD8o3t60js4IL8L6Cg BU3gZGGHpSq/J2nB9KFTIyhxSgqeCmD60AGTyDkH36GkMWR8wC+9PI24B+YetJ53OAMigZHnYQN+ 4U9WHqTTg4bkIB9aX5jj5gKBDQpI+6aUDb/EBT/L3dWY0pj24woH1oAjyM5Csx/SmtKwIUAD6VLg E/O+MdhQJI1XEak/hQAz7MHXczYpPucAY/rSspHOce1JGQCfM6UAOUjGSmTTiMD7mPpTlAPMI/Ok IYE5PPpQBHtyeM0oIU9M07e7DG4LTeU6tn8KBjzIx6I2KXa5HTApgmOOM8+tPDAjBkNAhQg75/E0 YVeqj86NsP8AEWpCYkBO0mgB3mKP4acWLDHl5FRAq3O3IPQ+lL8yrgAkUAJtYn7m2k2HBK/SnCRm O0c0143U8k0DFikCjaR+dSod2cHI9KgjADYY5JpxTY+Q1AFgKsn3SAfSkG+NuRxUILxnnv0NTCY9 GXK0AOBRuVIDelDru6HB9BTW8sjIP4UA9s/iKQChW6bsfWmsjAkyDd7ipMP0bBHrRuKcdR6UAR7c DuRSHgZU8e9S71J44Poaa+1iBj5s80ASwjC1YUVEg4qUUAOFLSCloEFFFFABUbU81G1A0RuapTtg VakPFZ902FNIZzniC++x2Nzc5/1MbN+OOP1xXBeCdOe71VHfcUX5mIPWt3xzdhdK8jdgzzBceoHJ /XFS/DqzlO+dEIGcEnoamOruN7HoluVSMIqjOKkYFjh249BTlh2/M7Ae1LuT+EZrQkT5VGFUk+9O XzGHTaKaXKn3pGZ3GOeaQDmCqPmfrUbGNRhTninKqqAGOacZF4ATNAznNFTWG1Oa4up91plkEbIV zzwQMcV0IZznatNYyMemBQSwIBfnviklYG7jyzLySM1Hnfnfx9KdiJRyxLelL8p+6pxTEM3BTtxk +tGHJB/lUqnb0T86T52BIXFADGIx0z7imSyLBC9xNIscMal3kPRQOpNSBSDgHn0rzzxxrL6jdJoN pMkcZYGQA5M5Hb6D9aic1FXKjG7MLVdUn8S62t/+8itoyyWqlQVVRg5PPVvp6V0Gn2zKvmOTvbpk dMnNZ+j6WI4lzny1987jk81vBguM9D0rxa1RzkejCKirGF4xmeHRFC/deZVb6YJ/mKytLkj05bLT 7m0edryXLJ5mwR5/iJ9sV2LrFMoSVdy5yCACVI6EZ7iqqWMJu1uSqvcKuzzSoBI7ZqY1VGPK0Jxb ZJp9qttbrEoAVcn0HXJNauj2guZft0q/IP8Aj2Vh+b/U9qqRWr6hMbRT+6TDXDD07J+Pf2rrIIlG wY4xgD0rtwVD/l5I569T7KFQM3QYp7IC2CeTUybY5CPWopifNHYV6JzCMGUEYyPWmKxbKnp6VMCC GxzUTAMwycYoEIW2j5euOlICoXLDa1NZWz0yBUO9i4H3h6GmBYVeCeD9aaACckEUx5OgIIzThIQP l/WgAKhmwH/OkdCowMUu71XJPpTDgnLZX60AHlvtxg59c00xtjLSbc9qeHbnbIMe9MZsnaQGPrQA wAKMgtntTmkYgFkB9xSiDC9SD70rAqeR+IoAgkVhGXV+cdDXn1tIE1rVcKpxbH6+1eizSLIMKOcH Nedwqf8AhINTKlVAtTvZj29P1rz8d9k6qGzOb8H3LW+s30/G7MY+Y9i+K9mSbAHGD7dK8R8Oxhrr UcLx5sOB16v/APWr2mAlYwCMf7Nb4XZmVb4iXezjDHdk1PCNm7NRsQqrxgk9BQgJVmY8V0mIbg4K juai2gMueTmn7iQqqMD1pBtVlPVqYCFGYk5GOvvUfzEHAxnuetIThiz5AzxipCxK/PjZ2xQMEfZx 980p2EZJIb+7SIgJOw8frUZOJMDJagRIs2QUcbRSrhRlXx9aPmC7mG8fyqPzg52CL60AOZ5TkBgx 9aTEsY+6pJpHKJyUYE0zcgXJdh3GaABjKnzSKCKFXed6nB/umkUrIc+aQKR1DthZfm+lAA7biRgo 3r2pwXylJOMn+IUNHIi8tuHrimJG7H5WyPSgBBl3yclc8EVYMxjj+bDD2qPATj7jVERk5f5fQ+tA E0TKWDlhz+lN8wNvAI69arjazbQO/J7VKfJiZlGMkUAOkmQmNUOTStxGygZPeocxRxZBG+mLI7ll ROvXNAyUIodcAEkUhUBfm5INIh2ooGNwPapCpDuepI6UAMkRnkBwACOlV3hJUEquAanlcFVJfkdc dqruEG4tISD0FMQ8LscNhefemiOZnJVV/GoYpUT5SpZe5q5hJE3Kfk9jzQMiTIchoQxFK0gYkLCw 9xUEsY83apcKepo5UbVmNAWJVaNMklwfzqKWcs2EkwPUinBpcYDqT704ecow8CuvrQFiJI8pzsYm hoV2kBCre1SeVD1aF0NNKxgEpI49jQBCi4OGb86VoUkYdD7g0kzYT5sEGki4+6/4GgCVoWYhA2FH Wo2ikfOGwi9PelkuMjarY/vUqyZGSQEX360aAORHjj812BPYGoxG2fNfGSeBUpnLHe6jYOgBpkdz vlDmJ8A8ACgLs3t23HTGB/KkLL3JPsKbLGoYEN2GQPpSqeMIuKQC73xxhB39ab5mWwh/OkKjPzuB 7d6PlHAUgnoc0CF3HdknB9KDJI7bDx79qkwQB5hBX1FIQrHKcj3oANromTIPpSLs6hs5pNqqAdwP tTtofhUP4UAPTy1JLEk1Isqn7seaiWN1HzYzUoLY5cKKAHlpuwVRTGAB+eUn2qNsf3makCMTkJz7 0DH5UfcjJ9zSqJS2MqopreZnlgPpTWRccyc+1Ah7kKxU/N700fIBu+YZoV2C/c49aXYxyUP4UATD CDcjAD0qN5/MOCMD1qNQvQnn0qVdsi7WwD7UAN2KhHO4fyp6TDn5Nw+lH2dV/i5FGc8FMGgY7yjI dygCla3xyWANN/eKeCFppYnhyTn0oAc8asMZwR2pqHsDn2pwHHC7hTimGB4ANAC5xwo59DR1P90+ lBXbyzfjTGY4wc4PQ0APYhOVHzUpbzIwSckdqYpIGD09TSw9WUdD3oARiGIwAD3FK6HcCRgDtTgg EZ/vA0F84DnINACsF2ZQZNNyCQSefSnxsB8vQVESQSMHr1oAcy4GWGMUu5WHGRQHJXLjIowCwC9P SkA9S46MD9aV5BkZGD7U0xr/ALp7U4qeAcZ9aAFWQH74/Gl+VpBt6AU0BgenFLECTnHU5oGWUqQU 1RTxQJiiiiigQUUUUANJqGRsdASalaonoGiCRuKyb6TahNaUxwDWFqUnG31qWNHmnjG4W51mG2Lc QR5I/wBpjn+QFej+EI/I0SARjAK5PHNeUbm1fxPKwXKSTELjso4H6CvbNJtYrezjjQldoA5ogtLh IulcjOdx75pq7icglT6UOGDYBOPannhcdfaqEKoA5xk+ppGJYks/T0oJGAo49qUFAcFcEUAIm1Qc ITnvSqHLEgYFPLsV+XC0xm+XG4n6UAJgbjvfpTCUJ4yacc7cBfoTRnbxkD2FAxVwMfJz70pmbOAB moydx6tilC54VOPWgQO5ByXGfQUK24EsxxSeW27lR0qtqF9DpdjJcyuAFHyof4j6Um0ldjS6GP4r 8QQ6Lp0mx/3zL64Kj/E15xodpLe6k1zNjzs5lYHmNe0YPr6/lTL++n1/V/tQd2cyHyE24BYHG8+w 7D6V1+l6dFp9ksSg5HLMerE9TXk4ms2zupU+VFrAjiAAxxge1Uby68lDvICgcEmtuDTL67jDQ24Z D0YsAKZPo0MUDNqSxERndIisHO3sORgEmuTVK7WhbnG+5mWcwuLZJE+bdxViWV4pI4IYjLcynCoO gH94+wpN9tY27zJAlvCOVhjPQnsM9zWxoemvAHu5nJu7gAsOyL2UVvhqHtZXeyJrVOReZo6TZR2N v5SnLHLO/wDeY9TV5TwD6HrTY0CH5+PpT2BBx/DXtWtojgAnbNnrmlnByCelI4A2kdaJTvUDtQAk bAHj0qJxubDH8KkI2yLtGAe9RSEK/qaYgHmKpx90VGXV3UAYPc1MjF2YHgdcVGzDbtC85oAeU2Hc 3zUjEueAAPeo0l9GyfQ1JkSZ3fLQA3IzgKQfWmM+GGWDZ9aesrHIABUd6jkCOMAc0ADRGQZYhfpS LEAM/kRQylRt5BPWgcfKD+NAEnKxnLbiak52sD6VCTuZR2zTmbaH9T2oAjkX5ey/KfxrztGCa3qx VBtFtk5bGeteiSZdWJ7KTivPIxjVtcY5JW1yFC9f/rc15+N3idNDZnNeEeb6/KjB8+AHPb5zXsgb OeO9eMeFGIur5nHIuIB9fmNeyRcW7Enmt8NszOt8RIJBvxjJpUyyuW6ZqKMCMg5yTTxlonLNiuky Hhidu0Y4qOM5fjk0oJO3HAxSRH5jggY6mgBQqiIg8tmnGEKgIPPpSKf3B2jn1pxG1ULNQBErP5h3 ALgdqTcqoMDJzTiS8rdhioRh/lUYx1NMRJGcJlmwSelDMi8kYPtSQgAFd25hTzGMfvFP1FAFctIX yT8tIS8h+8MDtipHCSHaCVFL5SKvEgyelAEbscABVyaEwMr5fzUNC4BIYEmkKFCBtyx96AHp5p4H T0p6KmePkamxhkU5/nQFaTPyce5oAjuXLlY2Xv1HSkYOMIDuB6e1TldiYPI96qibC7VU9etAxPL8 pSobnrinLbDzA7k8jvTSzBy23kjjNP8AnkVC7bVB7UCEjVUD55PY0xfnZSW46Gl2rHIygFs96eoA jycAg9KYwCH5gBtA5+tOY/MpQdeCaQhnnBJwpHShnCwYAyVPSkIb5ChH3dRzUPyzbQoHA71Nu+fM nAYdKhIHltsQEjoaYEeFifg4JPQ0rbY25ypbp6ULJAR+8XJ9fSpVOF34Dp29qQxjByoCujZppDR8 FI3Y+9PVYSTKDj2NMDW8zFjlcelMBCmwbnj2+4pFbA3BiM9M0iMWJyX2DoacyGQcOTQA8zThfkIY +hqEXcrNtaAMR1ApPJkB5Vqb5WXyGdT3OKAEkmRjtNuwoVY3T5QcehpHaUSBTIOOjEU5mZGDtjP9 5elADSIl4KnnvjmopIEBBDZXHrU7XIkXayqT2amB+A3lj6igBqxowAVMe5arEcflkDzgoz0FV1VZ A29SM9PSiJYSwV5dmD6UCOjKAPydzYHA+lKysRgsEHp3pDIwOFQKNoz+VM3ucYUZ9TSAg2Ym3Rjn 1JqdWL8P19cU0I5J8whT6iniJx947l7YoGI0ap1cHPanKqsMINpHvTTEgG4Hd7GkHz8RuAB60CFK ANh+DmrCg4AL7RUKopOC+c+pp2yNCG3FvxoAkwhPBJp4RAM7SajFyoHyR80hndgc4FAE4ZuiKKa6 vj55Ao9BUJmYjCHn2FKqlgC4P1NAwYoMYyaVXRTgr16U2RCSNzYApn3RjnHegRKQ6jk7l9KcPm+6 dv8As02MMBlPu+9TBUcZBw1ADAgJw4wfWnGLyzkfpSbzkKy8etKH8s5B3LQAEnqOfelGXGHxSNhh uU49qiH+s4Jx3oGSAqB6j3p3yn7oyKYYlSXJp5PlYPX6UCDL44GKFO5SrEAilL713AYHcUxgmRwe aAFBPY7vWggnLdx2pVXjb0A6U5iPlY8joaABRuILdDTvusDxxxTeSCoGMcigEFSByetAD2OJeeAa aRlTgdKG5jDE8igk7ht4DCgYjLja+RSSOxCkDGDzS5ABUjpSqQ4IJwKQCAjdg8g0oQkE55FKVBKk c08x7X4PBpgMDg/Kw/Kn7CB8rZHoajZWUkcZpFkYDJoAeSQDg9eMVPGMLUG5ZGGBg96soM4pDJVp 4popwoExaKKKBBSGlpGoAYaifpUjGoXNIoqXDcGuQ8S332LTrq4Bw0cZ2/7x4H6muqumwprzjx3P mxit88zy8j2Xn+ZFZyY0ZPgizM2qJIScryfevZoRtjUEA1538PLEqskrZxkYJ6V6KSeB1HtWsVZC luCgFiwbb9aQAliSPxFK+COCQfegHZgEflQIQMMknkdqWPPJzz70pCO+OKWSJhgBiaAGj5m5+X+t LuycYwPUUm4qNpGT0xR91ev4GgBrjHOSRTc7cfJz1BNOLYAAGD70uzI3FgT6CgYfMwyzAKOwpS7B RgcHoai+7059qiur2Gxs2mnYKF7etJtJXYJX2G3moxWFs9zOcAdFHVj6CvK/FOuTazfSQNIUjRN0 xH3UT+4PcmrfiDXprmbzXwpkbZawYyQf7xqppOnRXjQoPLmt7Z2ZrkDm5lPVjn+EdB+fevNr4hy9 DrpUrbmj4f0pwi3U8apM6hUQDiNB0ArudP0hQn2m+/dwIN2x+Pxb2pLFLXRdP/tHUHWPj5Aev4D1 rzfxh45udcY2ttmGyBx5atzIff8AwrnhBX5p/d/mOUpTfLHbudL4n+IsUY+x6Id4I2ecgxz0G32q OwluLqxhWbkK29iTlpH9WPfHauQ0XQ7j7WktwoB2/KOu0ev6EV2LRvtS0gB86UbY1HYd2PsKzqXr T7s2jGNOJNpNmus6kbqQH7FattiX/nrJ3b6DoK7KJcdOPrVPTNPW0s47aIbY41wD6+9aAKR4GN3v XtUqapwUUefObnK44HauWXr3NOdw6gr9KYWY8k5HpTflOQPlFaEkmAUPdhTQA0BY01G2cHvSZxuj zigBHkzENvUVEw53tzmpAAIWUU1ji3X1piGx7mYEnANMGVLGpCCiKOuTUbjD7fWgCRIk8rcRyO9E iNgEnI60o6FPxpznES/WgCGAlQcDj0NSlVKMSORTmUK6Gm9XZe1AERRlwwOSR3pu1l6jDHv2qQtl QT2NLtJJYP17UAQMCMY6+opduEOW5Pc07BJ3MCAPSgfO3IyB0oASVMRtz/Aa89EciahrTRSIQ9uA 3I4GffvXoFwWWNwOQVIrzeS4+y6nqzgYAQYzkcgf/qrz8Z8UTqofCznvCjp9qvC4CgXcAI/4Ea9l VQzHB+X1rxrw/JHNJeSwFSrXUB6HqScivY4gFjUDKt6Gt8NszKt8QoA8/jnHanY+Ry/rwKArRyKD 39KQgkSAKfxrpMhM5ZQ3p0pIl3P6CnCLayOeaYJCZOAQM80AS7wsLKOTntTXzhCefak3KqPxkjpT ZHLQq69fcdKAH4/end6dKYEdiMDjPapEcrguoY+opN4w3l8t6GmIaECOwA70uGJOWYD3puVDbyxV vel+0tyGUY9aAFMmBgbWNMwSdzpx7U8SQD5ivamsyOMAsoNAyFtuS2GHpTQUGTuIY1O0e4BVl4Hr TWUR/M8iknvQIYiryTKc+hpxlK85yfUU1vmztUMPUVFEWjJJHHcGgCdZWfG5c4podiXVEAJFIjm4 k+QbAOtOYGOTjknjNAELI4jUs/Pv2pqx92foenrTmVVRjK/OeKjUozcbiuOtMCWWZY5EMK5Y9fSk 2SO7GQ4J5pGkIiyi8jvT1WV3SSRhgjoKQEeH3oy7sZ5qcIil1PJPNRyOQGRByDUkbKCrnByMUAQO jSQgtyFPSm7vIkAhGd3Y1Y2s5dOgPSo2WIxgEEOO47UDGmzjnGWUhqgkjeN9m47f51MzSRxkMdyn oR1qOOdYwyvll9TTQCssUhVOUY9/Wh02DyygZfUdabtwpkjO9T29Klt5MAk/MD2PUUARO0kaYQAp 6YqNI06tI6n0qztWWXfGcEDpVacyqfmA4oAc24YCXR/GnbblRgOrZqv5oVNzqhJ/SnRNHIc78egN IBzROOZI8e4poXLERyf8BarQWYj5JVYelVHSQSYb5W7UwDy3VsYX6EU1omySPkY9u1TCWVRtmjBH YimSySAYADL6jqKAIUdo/vDK/wAqXd9pcKQFcdD60haVOcBlPUelIkizSKrfKynjHegaOlcrEPvj oOfwqEs5ALEbadJtyNi5GBkH6UwtE7AFTkflQSLgsvyy5H1oGAOJTjuKm8uJlBHB9qYCoJBQHHQ0 gI2SPAwx3emKRVRQMq5J9qkJkc/Kg/Kl8qZiDzQMVCeAsXT1pwt5W9FFSqrKMkgfjTJJAvWTP0oE L9nAALyYx6GkWKLdwCR701GjPZmNS+axGI48GgY8kqvyoB9ars7k4ZiPehncNiRufagKGbk5HpQA Kf4Sd3+1UpjyMsc+/pQWC5WNaSOFnyS3HpQIMFeV/MU8bW5bhqYN6sVHOO1BAJ9/SgCYvvG1hget QBWVyFGRUgy3D9BS5Ecg54NAAI8ruB59Kayh1z0YU6QgPlB+NRn/AFwweT1FAyRvMMYb0oJKMPlO DQGZgyYIpy7TEc9RQAxdxYquBntTgB5Zz1FBIJV1AHqaU7Vk65yKBChiSGxgdM0nCsV6nqKQbmjO eADSk/MhQZoGOHVWY8dDQCQ5Cjg03G0nfk85pHlLEFRigCVVUblJJNJhtnpimrIiuOeTTwQXIY9e 1AAPvgjoRSAAMfrQF+THYUrhdwwOtACMh+bsOop28ugxzijy+Ad3PTrSopG5fyoAGJOHYcU1ihyv vUgYGEgjkUwtGxGR2oAWJcMeciraCq0QCgZq0vSkMeKdTRTqCQooooAKaTTqY1AIjY1Xkbg1M5qr M2AaRRn3smFNeU+MLkXGvRW5yRDGB9Gbk/0r0y8fe4TONxxn0ry628zVfE8svl70knJUe2eP0ArJ 6yLWx6h4RsjZ6NEPlcsoY+1b67TyQQarWccaQRog24HarR3DgcitzMaMMTkgimgDqWK/WnZQnGNt BQk8NuFIBAoAJPI9adGxHzAbgaYQQdvT27U4naMA4J79qAH5SUkng1G2Gb5SSBx9KCcLhgAfWjIj Tjp3oAaxB+Uc0gA+6hwfelUruyQRnoacVUHnHPegYxM+YQw3EDOB3rz/AFjU555JTqEBiEZ3RjJB XsB7n2rvLm4jsInu5mxEgyT6+gFeQ63qN34i1IzrGZIzKBFEvImkHQf7qgZJrjxbWiub0FrexRFt PqeqtHJ8szjBCni3i9M/3m/QV21rLaaPDEDBvjjHyoDtHHqewqlplhHplm8kjb5WzJNKRyx6k1xW sa3c6xMI4ty2zMAFHVvSvMtKo7ROzRLU0PE/iS51y+8lJA6jh3HC/wC6g7D371X0nS98ySyqGOfk UjvWjp+gSWak3cSRyFQ2GPzKp9q6Cxs8BX2BeAAB2/8Ar1Eqi+CGxcY8q5mS2qQ2VuWkOAPmkYdS fQV0+j6aY4jdzIPtU4Hyf8807L/U+9Zel6f9vuBcuFa1hb5FPSRx3+g/nXUKMHPTHSvTwdDlXO9z hxFXmdkTbCGG5vwp+DjI4HvSB/ly6596jaRX4ZiPpXcc4mctwMH1oZgBhx+IoycdAVpo27sqc47G gCQoGA5yRzUbEmQP2HBoLFVycgmhc+UwJ96YgyPN2+tNGdzL6UYzGH7ilXh9xH3hQAMdyr7Ux+ZQ ccYp6cI479qY3+qz3BoAdEczH0xSt0ZfSmqpjCselIfvt/tUALJL+4Vu4pYzhwT0YVGATGyH71Iz /Kg7jrigCXG7eOwprsCgUDkjrTshX6jDCowRtYHkigB4Z0QAjINIXVcYBFJGzFQx9akO2XIPUc5o AqyElJGDAjaeteZ3u6a/1lFV/kjBYjovA/nXo9+6wW7E4weBXlesaw+n3d+lrK8RulCyBFBDfXIN efik5VFY6qHwu5leEFXyb3J+T7dBj82r2qEOQC3zqBgeteS+FraGSxZLTIna4SR9zHDbSegPTrXr a9ACNr9yK3wz0ZjV+IlRd7BskY7GpHyqsR3qNmKgAjPuKc5EkQABJHrXSZkTbyqE9KgcN52Dj6VM sj42lPlHeh4WKllIyaAInCo7Z6Y5qSN42ttoPPvSKil/mORjmo0ijJyjYYHFADXEgXCrj3FAcAAN w3qKtGRgQjLgHvTXt03Ek44pgM25x5nzr6+lMMaf8s/mHpTTvDcHC+opSyqpIBDe3SgQqrHk7jtb 3pT8x4cYqOJ4n5lBzT9p/hQFKBht4znIqFkaX7qhlHWrQeJIsBcH+6ahJRVwh8tj29aBDVZUIC5R vTsaHj3HM4OPValDAL+9Uf71MeP+INuX0oGiMREjMZ49RTWQIMh2c/rT13ZOz92fQ9KCHHLqoz1Y UARqsWSZDz703zhlfLUnHBNSEKvzSEMPamPOiKwRCcnigAjk2hxtz7Uu6WeLjgKeTTB5sjq5+XI4 96RhLvKbxg96Yh7KUIAbLMPzpwAUpv8AlI7VGQiQqd3zjqacwkZAZBlfWkMluJP3q7QQO5poAgBJ BdT3pZJF8tQq7l7kdqaYC3zxSHf/AHTTAjhGWLRHKj+FqbLsklVU+Vu4IqJGkjmIddre1OllV0LF SH7GgCRtyTAAbcenQ06VkddpGx+xHeo7e4cKPNjyPUUrosxymSvcGkAqxNCoLDP+0KN4uPlcDA/i FHmtGuwYYHjB6igRKiF4W+b+6aBEckGMLtDr6rUP2dGc+WTx19qseaYhuIw5/hPQ0ABvmBCydSO1 MCu6GFMh+e+KjeRxzv3g+tTPLulAMYJH60xkhZsFSh/SgdwVZ2T5HwP7ppjb0GQ+1h2p3lStzDJu A7ZpoQFgZGyR+dAEYMsgMinB7jFKgSGVGZhhjwfQ05/NR8qMx9zShY0YZUyI36UAdBIin5mYA4HG fameahwuzHHWgPFkbkycDk/SnNKrDCxcDqaBAkrISFTcKeJGkJVYxn3pvmtt3IgApm6R23KQpH60 AS/6TGc8EemOlOCOy5aYgmowXc/PIQfSjauejHFIB2yJTzITSqYsfJGT9aTzI1Iwg/Gl80kccD2o GO/eHgqqCmuxzgP064pChcYAajy2xtGBQAuY1Ubl3Z7mhCykEAbTTREAf3jc9jT1lERwBuU96YiZ gpQMhwwpMmQbvukU0gE74iST2qRUWTk8OKQAjb/kYbTTvLCdenY00tn5cDeOhqMl+klAEm7ccd/W muuB8x5pv3uEPSlQ7gRIc/0oAC0jR/d/GlwVCyH8TT4pSRtABAoVMl9xz7UAODguCBkEUgjA3AnB pq5ABX1p54lBLZ46UDIwHaIgDpQWAAO05FTJyWA6Go2ZEQgnLUAIHLMcjAPalEwWPAHINIMMyk8U jhonOMEUAL5g3AsevtS7t6EDgCovmaPJHGacpKHJHWgBSF6gYPrTyY1IbJJ7mkD7kI20hxtGF/Gg BwDk4VutSBh5fK9O9MySRgcetPX+IZoAcdjHg9eeKftIYMO/rUYZcgEdPSnY3JkHp2NADlD72G3g /pUbAY6YOakJIKtTDkzdKQE0Y4FTLxUaCpVoGOFOpBS0EhRRRQAhNRsae1RtQNET1RuWwpq5IeKz bxsKalsZy3iK9Nrp13MrYZYyFPueB/Oud8C2siaiDtMgC8fWpPGt0Raw2+T++lyfov8A9citn4e2 p8hrognJwD6Cogru5b0R30RRYwHGDTtuFJVuacGEgOD0qPbgkkED2rUzEG5QQQDmnfKo+VsN6U1M HJ3EemaUANy350ABYqh3rwR1pqIWGQc+1KxYjb1ApuTgBeD3oABndg8DPSmy5U4XOfSpGYkrkc+t D583046UAMYfu1YnpUsi/uQRUTkeTliFUcknoBXPN4kuJtSa1hhdpsgQWqkfOp6u5GdoxzjrWdSr GG5cYOWxoeI7RLjTY2llEaI2csMqSRgZFed6EZ9T8SXdxOkSJaIsMCQphEU5+79e9dn49bUIdCU2 xVGJwoyM7sdcn05rB0SFra3DTOZJ5AvmNtCkkD2ry8ZK8nY66Hwmw9qrxHA/A1ytt4dtLHXftEj7 IV+eANwqyZ4yfQdRXXLOCpXFVbiGKcFJlV19COtcMZSSaNlvqU7xUu7mNo5JXiTkmUg5YnqD1x3q WOCW8njsYJCjPlpHH8Cev1PQUsriGMMq5JOxEA+8x6AV0mmacLFFViGnkw0r+p9PoK7MHh+d3eyM q1TlVkTWcMdtapEibUUbVA7VaVDgbTn1FOTHOQMCmscOCDtzXsnCDEg4HBPY00qvU8GnmTPDAH3o 2DGQ2c9qYiJgVIK8CjIIwVxz1FLg59PakLDJJ4oAdnLAA7gKDtPyqcH0piqSem0nnNHK/M3T1oAY 4ZSY1xinMymEL3HrSj5iSeQO4qNOXK4yM0APJG5Cp9jSuPnMY9M0oX5SMcDpTRyBJ+FAhzn9wADy KYx+dGz04o4EpB+6aauPKfPbpQMcMfae/So/lErrnPpTyMwBxyRQqqDvHX0NMBhBcKW4CnGKdlFm wD160wMcMpU4PSnKvyKw5IpANfeCwHTtUi/Lg/3hg0bmDktgjFIdrxnB6dM0AcP4l1yVMCL93GSQ GYZPXGcVUsvDOj6nYy3l79pdlPJ87Gf0qv4tZTEuY9w5GM46kV0WlBX8HyByFLDBIIPT+vFeJOcn K9zuaskkefX93B4f1KaTSJ2mt0fGJ+d349a9P8O6wNW01bjGxxjdG3OOOx7ivFtcZftbMvIJ5H9a 77w3e/Z20qLnZPG2/HbGMV1YeTU/UyrRXLc9BVwCTyCe1DyA87SD+lNWRf8AeFKXBUqgJB7HtXon MMUz7dyjcDQEkOcNj2oidwPl4I7GnspkwWO1qAGGOPOSxVx2PQ1HlFYl+D6inumziQ7hng0wOqDA jLrTAfJLIIyMBh600MXTBYZNNDSYOzAX0NNVIlKkkls8gUgEaWSM7AMjvxxSgDaSeGPUVYcgqQFw B3pJQG8rHemBUjQjcX6DoMVYA+TemV9qU5DsoHvTyymLYp6jpQIgLiQgyIcditKVL/dIYDtTULKC qMM9MUrYXAKlG9R0oAikZycR5Hqrd6RW2EckP/d7VYLBU+cZH94UjABdwAfPbvQMQsHH75R7EUeU WTch3L6VHtJJJO3/AGSaYJED7UdkPueKAHNgfw7WFV2NwJfMaMY9atkqw2yN+IpDAxXKybl9KAKw 8+ePAG0A094wAu0kg8NUhgLcJJtbvTE3bDGz4IOMigByxRxq6sxyemaarysmBzH3phj+dfOYsOgN SPiJOOfTFACW+YlZl5UHlTRIRMpeMlCKiijeeUln2+wpxZVzG5ww9KYiCVnYKZOOwapowBujL5BG RkUDzWt2DBTj1oBYPGxCnIxSGNQyJGdrxkA8hqak/O5SobuM8U4HErxMi4NV3hZZGTZwTQFiyjxz yEt8jjvStlX5PTocVWkXEYBGT69xT45XSIDIcHqD1FAyfzEmbEpGOxpkylcBfnHr6U2WBHiDI4yO xNQRCVBneVamIGWMMcFsmpY+F2K6vnsetNCzMfMwCR6VJG8bkmVSp7HGKBCmNUGfmRqjbABZgHPZ qshGkOUcMvYGqs0WXxtKf7Q5FACAO/L/AHfUUilYHAbBjY1DJJIgwpHuR3qWOKN8dmP60DN4SI6/ 6nqB/Kk8x422hDjHemxNOygIAFAHzH6U6RNuC0oDUMQ4Rl/mQD6U3Y7kchWFQiQlvlcg+tPCrJjd KcigB4hkZiXfmnxqh+82DUG5QTu3H096k2ySR5VMUgJj5CH196BMqkKI6g2MVAJ49qcYFz5hO4Yx 1oAlaVyOHCj2pgC7+rMf50AIgxj6GpFlBG3bn3oGPPy8OvymkZAFO0jaetBMmPmxs9agYFW+Vhig Q+PEfMbZ9RUoHmHcDtbuKj2IuGQ/MOtJ5jSEYG09/egCYlWG3GGFIc5AlGR2pN2VG0fPTwpmUq5w aBkcgAOYzSIPN4PB9KUjymAprZyG4ABoEORvJkKkVK3Dgk8HtUUoOVKfnUvG0N1IoGIhJDKOKbtX CsWPFTHO4MMcionVn3ADJoAa8jbiVampJtYk9T60vlvjO0DHag5DqSo+lACiUk4UDrVkKBhmxyKh aRODswfpTWy68Px70AI8aNKpdmIXkKDxn1qTa3ByCKYrbWXAzTn+cfKcc9KSSQDiNrY7mkw2w5/C hSVP3uakCuTlsEUwGDlPvYFPCZ4DDFKSuMFKacE8ZwKAEKur9CRTgXU89+lK2WXBBUigFuC2MAYF ADvN/d4x0ojJdixHWomxtIAqaJcAUhlhRUgpi1IKBDh0paQUtAgoopD0oAa1RMae1ROaCiGQ1k37 4Vq0pW4rEv3GcE4B6ms5saPL/Fl0Z/ES2y/MsMaqQP7x5P8AMV6j4TtEt9HgVMqSuWBrye0Q6r4j kkxu+0XDEY64zx+mK9ssbf7PaIqnOB1NOmtAkWzwQhGCacCyfKpyO9NDtj5sEH1pflUfKTk1ZIhb e2AB70M/ljHftSoBk7xg05wO/IoAYg3IWHBqNQOd2R7075XcKuealRRtZe/pQBHJkxgY/Gl6Opzx jvRj92Rz1pHGSg6cUDM/WYr+bSZINN2C4mcIS4BAU/ePPtWVdTab4C0x5Wbz9RuRuaR/vOQOT7Ct bU7mezsWuLdm82FsrGFz5meNteU30F74jlOq38ztG8hQIV2lcdiO1cGImozfc6KUXJeRn3niC+8S 64pkmkMaMCoY8D2ArsLdmRA2STjv3rJsdPht1URxgY4BrbiiLBeOlcM2mdMdEWo5M98GpWZUUuzA KBkk9hWLqmpNp/7uKISXLDKIf5mtXStI1HULWB9WZI4shmgVcNL6bvQe1OnhZVHpsTOqomppFkJ2 TUJUOP8Al3Q/wj+99TW9jLKelM8vZGoB/Cpl5K8HgV7MIKEeVHDKTk7sNuIj69TQwBVSc8U/goxJ wah2lsYOMdqoQAAn5D+dDDAIPB9aGIAwVIPbFN2Ow5bIpiIy7HgEGmjG/jnvVgoka8Lk9hUBQkgt hcUAKz/wjv1poyMYywPY08AFs4NP3ZIAwMUANG0L8vDelIfl+UjBPcUMys+G7dxSqTng7lHrQIXe UTBGR60yNgFdRTgNzZU9O1Mm6gj5W7+lACE5g9x6UpHK8deuabGxWUh/SpVBAYrgigZHvKOY8cDn NLIytgMvXuKPM3HJ6nsajO4P04FMRMV2r8uCvvUaklGTHJpCwJAB2+1O83EgO3npmkMAgKbmOCKi lJccDA9RVgKQzbuhqtI5VTtz0pPYaPOvE6NI0W1DIxJAC9ua6PS0a28JTo52Ns3EBetZ94EN0o29 M8/jXQwKq6LKMAkIwwT1r5v2rdXkPUqU7U1I8N13Z5rMpJJPUdMV3WiRk32hLwf3L5z+FcV4iQG7 dsKvOABnArttObytT0JVOcQPtYfxcivUpO8kctX4T0L5YsZGPTFBnyOEOf7wqYOXj27BuoeAvFng GvROQRA7LlsbT3FK0fBYsGHpSrCdgYP25FNUKQxGcjtQAx3GNyAk9MGo977iANh9T0p4LlfuYGe4 oVGaVt7AUARKgYks+G/Q08BFjXaOc0eXGHYHJPY0xTIEAC4APWncCbJaRi3AxUZLOFPAxzUhQ+aS xzx0qMk42+1ACq+ZSc9RTVj3HKnnvinIoUDAG7HNKcIiheuaAIkQEyHacg9aVXd2PO4DqDTXZ4CV Uj34pxZNgyCjdj60CFX5n+Q49jSORvwQVx3FJ/qh84357jtSqxVem9e4oAMtLncoZB/EOtRPGgGY wJPb0p7NJjMK7fr0qu5liKs2A57imMaCVJO0j/ZNSCRSR95CP1pzTMFAkAdT6dqhcqcFASc4waQX JjPCTtk3Z9RVQkLMREWYH1FTozxkkRDPowpAd75IEbD0oAhKeYCd5U+lTxyJEAMkt3zUkoUqDIMM OjCq8pdlUkAKOhWgNxPOP2k7OD71OgUzguvJHOajeLJRugxT5CVVGQgn3oAmWNGEgPBqm6R+WCGb cp9asoT5xMnAIqmyoWlCNjvzTAZMp84Fd3bGauxRlHDscsR3qs8eQmXzx60plRo0Hm8ikA4yLPKQ +EZe4FQ7Qs2W/BhUrwfvfvcEVWG+KNhuyB2NMaHSfMeQfqvSkUxy4VtwI6nNNQv5RKKSD1pGDBNx VlY0CJ1CLL8zNipJHaU7YmVlA5BqojNs3JIpb+6wqZV+Tc0eD3K0CHs5j+Xy2DH+6aBcNGuM7vZh TVkZcsJOPRqVZVckzx8etACM0Lr+8XDH0qo0BEyMkhK54Gau+TFPny3+X0NU2gEc23J3Z4xQM6Vl YRjL9hwPpUTR5U5UcjqTzSybQw+ZmOBwPpTljZl3EBV/U0gGoionBDDuDQQjLlPypcRdYzg+nrTw 0bcHCvTEIky8o0Z6elOBlT5oxlKCwJww59RQrSJ90fnQA4Hzevyt6UxkaP7x4z68VID5w5AVqQow +WQ5XtikAkZj5xwal3p0UYb0xTGgUYdeQOtSIRjt9aAE3PztHHcGo5It43A/hUvmqeM596Y7E54x 70ARIMcnNWPkkXrtNREMEyfu0xwoIYHNAEwlAGP4h3pcuxz900xHWYYC/N2NO3EcOTntgUDHMd6H j5gOpqJCWUgnJ7U9hIBuJ474pImwTxQBMyl4gSelLEQEK45pBlo2HQClj2q3HcUABBZQT2NL8wJI 6e1MKuc84FA3AYJOfagRIInbq3BHSk8tgMA5IpBlvvuRTsBBgPg0DFEcrDnAFNeD5cEc+1GZScq3 FNEzK2GBJ9aAECt6Ee9A3jnB+tS+eCuCM00MCe5/2aAHB0I+fg+opFG4krJj2JpFjLD29KUYCkFa AHGN+qkGhQ6HOzJpBg/d3A08Mw4DgigBxmx95KXzV28flimGRwOQDQCCckAc9qAEkKtjAw2eanQc VX4MpwcgVZSkNEop4pi1KKBC0UUUCCkalpjmgCNzUDmpHNV3OBQUVrh8A1ynie++x6PdzjBZYyFB 7k8D+ddDey4U15545vM2UFtnHmzbj9FH+JFYzLiV/AdpHcamsjYDRrkA168gIUZQgAda8++H1lmA zOnBPyuK9DBbIQEtito6ImW4uS/oQOlLt3HrnHal5Axtx9acAGUkHDD8KCQyf7uRTXj+QlSSfQUZ 2nczHNIpLM27BBFAAEChSBz3zTgAS3WkLnYMEH6809OWPHTvQMjUYhY96ToAxPHWnjBDAMRWH4k1 ddPsvLUgzv8AKq+pqKk1CPMxxi5OyMrXdYlk1GG0strSo4kLEZCYOfzrDvbyW3hnnu5VkSebdhx8 zHGDtx2HFPixY2kk0zEzSDfNJ3APb6muK1/V2uJML6YRAfuLXkNurK7O5JQVkdZpd1aXspit5kZg f9WD8w/Crt9qX2G4XT7GIXOpydEAyI/dvf2rkPB/hO6128WSJ/JWE72n5G32B9TXo2hxwQ63MLCz hZCm2e4Q5+cZ+6T1HY+vWtKdOLmkyZydnYraB4ReCY6lqspnvnO4+in3/wA4rqx9wkjp39acgKkg E+4qRgBFtC4Jr1YpRVkcTbY1QTHntU4HzL9Oah2YI2nGOoqwMbcMvPrQA1ivOaQx4Xjn6UAHnGGW k3A52nafegBpbAyRkVE5xypIHenM6sSpxu9aYrZGH4piFMwbheCKQkD3J9aR1xnuP5Ui4XkHd9aA HbpNuAKQKE5YjNP87J+7imHBbJH40wFdjs+UcfSmjAX5TtPvQdxbr8o9KCNx45FIQ7sNwwfUUxiS nPOf0pTuAwp+oNN6txxjtQAwoy4PUVIoHRSVJ9aM5c5GCB17UqkE5bn0IoGOkBVScAj9ajQHb8p4 9DTtxJ2qc88g0PtKnB2tQIjCo5P8J96QgRnFK4bgFcj1oC4GRhhQMlVy67ZOOKguMxQuOCuDTlcn hOR6Go2jby5dx/hPB+lJ7DW5xsjBbhGJyCcfXNb0xb/hG55FHIHX0Ncb4jIURLESvK4A/wCBV1oO 7wYHQIEZcllBGOOc/rXzcaX7znZ6tareKieJ6y7NckNuwxz149673S226roSscgWzY/MV5/rAUXj 7sZJ656ivRdGRG1vRgw/5dGxn/eFenS+NHJV+E9CQliTkAYpwUFfmbtTIIj827t0qQKoxn0r0jkE hZGGOTRCG3SfKKdbsqnHFKJf3jbRkUAQbX8k8gc05Il8/LMTxSfOyH696dsAmBJJyKAEyiSPgdqj DMYuFwM04uglfA7UwM7xrhcDNAD8fvMue1Rq+4gqOPWnyBEfLtk4qKSQqqhR1FMBd4Wde4ApFwz7 s8A1CwZQDn8+9OG5VIxjNAErrvuGPHA9aYzsXVQoIxzTuV3knqtJG23aWHagRXkKyShVcjHUVMAF AUbg1NAJAcIDzxU8KysS5wPQUwInRnXaA+PUVCYZFP8Aqt31NXFE4ydwwai8uZiSJABSGRYlUcwg UxdzyAhFBpZUlAIacHPQU2KRYVB27jn1oAnaNnQ7ic+lV8JtzhvQ1JHduZjlSAegNMDPKJVAwAc0 XCw1XYfIOT6HpSsojBH8X900qgIhPHTNK482SJyPlIxTENMxkjQgYxxUiIFt3BOSDRIR5e1F6HrU ap5sko3YyOlAxxkDMigE570hRFkdTggj0piny1QMpwDjIp80YE4ZTncOlIBn7rykOAMHGM1H9njc PggAH1pQEEJBABDdKbsQuwRgMjNMBkkTRlCHLAjjnpVbaZLghSUPv3qVnACnsDzR+5MgbccH0oAc XaJhuAUevapTcl2wyB1HdRxQw2DaGDqR0aoA/l5WPIPpQA+aS2ZgSrLSNhTuhnyD2NPWeKRfKki+ fHcVVxGFZHQqc8GgLk4mkf78YZB1xQ8sLnaoKetVRlVxHJznoatRSMqASRBh6ikBC6nrCwPuDTYz LuBB3MD3qcxQvNlTsBqYQSQnKsGFMDVcSM2IxjAGc/SnxpGR88hLemaiJdpPnPYYI6dKd5RGNxAx yDQBYMULjaODTWVAdrjB7GmCMuDvb6EUioMYkyV7HNIROGVQFkxjsaN4QY+8pqEbFOD8yn9KcHER +UZU+1ADshvuLkevpTleQja+MdjSZJG6NeO4pQCy5HHqKAF8tl535X0oUxHJDfNSCIkEq56d6b5a bgxOCOD6UDFLFWOFzSlyy8AFfepBNHja3WomYqx2rmgQuCvfch7elHlKv7zgr6UxWKHf1HcelPJA G9PmHdaBjcE8x8D1qXIZRk/NQDgblxz2oMaOMs2DQIVWIOB09KWNEEmf0pmckqB070vAIz8xoGTD J3gcCmhgoXFNQMzHJOKTeEO3BOKAHSlt4J4GKYJSvAPFEwZzkuAB2pAnygDFAiQOWGFKk+9OIHBZ cn2phiPUA0pQoN27qKBiqMH5gVWpf3LLjPJ7mojKQp3KSKMLnJORQACMryBgetOIwQc800g8dcUv zr7j1oAkEh7jBpd+3PGSe9IsvGCOKeGjK4J5oAA/HzDr7UoCHnGKYQf4W5pQrgfMM0AOwoHemkAY LLkdzSgheqkHsBTZnXymIJoASEd/WrSiq0RG0VZU0hkqipBUSmpRQIWiiigQVCxqVjxULmgaImNV bgkowU4OODVhzVOdsA0DMfUJdqEE5OK8w8SzfadeEA+YRIqke55P8xXoWpy5YjOB3NeY6aW1PxM0 /TzZ93P93PH6Vk9WWj1/wnZix0WJFXlgG56iugQfMN2AT3xUNsF+zgqChHTnORVldvys2D6Edq2M xQMBlzke9RgEknHyjvUm4NIQBTRgZxk+xpAI48xQQMAelN+6wA6Yp+Aqkbse2aUglhkAgd8UAQjI XIPfmpgwUsc8Ad+Kgnkjt7d5ZWCqnJJ7V5p4i1/WNajdtKk3W6As0CxkcD/0Ksa1eNPfc1p0nUeh 6Bfava2FpJIZUdsZCqwJrhJLxr29k1CeN3YA+VEOcY/+vWHaa6tzp8unvAiagJFKXEYBUKeo98H0 qo/iDVIYru1u7VEkjUIZY8hQp/x9a82rVnVeuh1wpxhsO13Wy4aNOQefdm7mqXh3w7eeIdUjiiU7 T80sh5Cj+lV9E0a+8Q61FahDlzkk9EX1r2B4IfCOkxaVpS7rycEtKw6di5/oKuyjFt7Iht3st2R6 hcW2i2C6HpLGFYkzcSgZKDuPdjWH4b8ZWkc8lg2mzwhT8jLgsV7ZU4z+FSXcltZWX2ZcySk7pJGO ST3zXIai1mW865JWMMAWUZP0A9a4IY9ureCOlYRez1PZLa+srvASdC56Ix2P/wB8nBqd0IJxkgdq 8lbUfsthPeS2ikXIFvp9tKd8vA/vdQO7EfSu78HHUZPDkBv5RK68RyHqw759geBXs4fEOro0cFWj ybM3l2E5zgilaUgFT81MAGSXPI7Cl5bovy11mAzc2PlOB6UAA8E9KekfGWNDSIvCDJoAPlA4T8aa 2WG0kYpDIWxyBTcs3Cj8TQAGM5+90ppKH5SPm9aUqR99/wAqbsDHgH60ANZyowSDik8wgYQZB9af GAh+YZApx+ZyUIGO1ACLgLnkE0oHdsg+tIZMna4P1pzbsYX5gaAGFwB83PoRTlIMeXGDSNCVO9j+ FMYln57dqYCtlVCg5BP41JEVAwcj2NQheck/NT3OFwTlj09qQD4h87mo8kuQ65A705nKoFHU+lMG 8D5SDntQA7dt5U5B7GjG8/3TSKik5J2v60pYjjr70AOyEHzfmKgmkba5ONu05NSKAJOTuz2pLhMj aBhWGDSew1ueba9tuHQ4bywQWcKTjGf8a3v+Eo8PR+D3g/tODKptYGFz83p0rM8ZxGDS5fKXa4wA M9+KnW9mT4YvJsVcyeX8qjp37V4UU1KzPQm00meWX+b66MtqfNhByCik8fSvQNJy2taQVOdtsfw+ auH0Bpk8ZW1vFJLEsj/vFyOQRmux8P6lLqfiyWUWghjgDQrtyc4bqT6mu2inzmNZ+6elxrIA43dR mnKmQNx600CQuCGGCtBG1kUnJr0TkHRbIXAPJNKJwJnwpPFIcCYYGaQlzIxCYoAZl2jYjgE0oX96 u58jFKsbGHk/lS7EWRM+nWgBgZVkcKpPFNUO8aljgE9BUglTzJAO1My+1cLjnvQASxqJMnk4ps2B 5a0sm8yEMRzUZj/eruOcCmA2c7mCgZwKT5iy8dKdI2JGwpIA60kaljubgGgB833mHtSSZQRAdxii RyZjtAxRLvNym0AgLQAchUQHBPQYqOQyxqVycetOEjCZQUOF9O1N81pi/lru9jxQA1VOOJG+me9P jUAfPvJqNDL5qgLtx1yetPmnmVyoAGaYhyj5iRHge9Rp+7mPmYAboKazTSoI0cA017cxSo8sm4nt SGPd42uQ+eB2obJkfbgAjio5fKR1cZJz0FSKzTzglCq46GgLlaMO7BiTtAp7SM0SlRwD1qZVCuo7 A1HLIscTKoOd1MBwlBgbHB9KTgy7jwdvYVGVdQWjIkLDJGelPjUOVZ22nHQmkBFvkWM5+ZQ1SzNG +wg7T9ahcyYdf4c5yKlk8poo854NAyNgwEmcNz1pJHiVk3AjI5wKc0TAybDxjvUbSsoj8xPlFMRA wUhwMFQc02YQfISSrd8dKdLKrSMU+UdhTv3rwj9wHHrQBF5DSQh0k3Y7N2pvmnaMnJHX2pWdVICq yN/dPSnBo2x5qFT6ikMk8lJ1DxyfOB3pJWkVAsi7/eoykkZ3xHK+1P8AMmIx8pDdQaYiFWQna68j pUsakPiOXbnkUyVXjXLRk+4o3RlFfJU+1IZPIGZCpUM3dhVQSSBlBlbg9KsDeq+YkwP+yaapWXId TnOcjtTQjdKyLGuCWTAJP4U4LvUfPuB6ih5i8W37vyj+VMhTfHu3YxzQBKSI+C24Y6d6RAAmTgr6 VFkCVN7dfSpAwVSVBI3UhEmVAJTB9RTDKisNnU9qYGG84Qhiae0ZaVdmFI60ASJNk5Tg+lPyznIw pHaoQrF9rth/UUrgR5LOS1AxXYbj8+G9KFkRxtAJPpTQ0buueDikLYOFU9etAEwdJBsKEOOtO/eL w+NvrUL7lZSwAB4zTy5aP5jjFAEnkIo3Dk0HJXdHgeopjP5agqCwNKNzfMOMdqAHI2CCgznqKU7V PznOaj8wIQYxjsanIjZAzGgCLazfMh4qQFFAYEbu9RszLyvT1pRsYZ/iNAEg3Mcg4H86jdlEgwM4 7UclfmOMdKdKq7VK9fWgBCm45JwPSmbduFXPrmnjqVckY704qMcnr0NACRmTPJ4NSklRkjIqI5Uf N69acsmF7/SgCT7qgryDzg0BEfpwe9N3puPqeoqQxjjYaAG7CjEr+INOO8H7v4UjMyMQfu9mo84D qTn1oAdwSDnHtinbVY4BFJuR+CcGhwoOM4J7igBdhAJ5p2COc8CmI7g44p3mEnlM0AODFm5bFJKg eNl744p2+MnlSKT5D0bFAFSBj0PBHBq2pNRCMCZiKnC1ID1bFSB8VEBS4oAnEgpd4qAHikJphYnZ lqBjTS1Rs9ACO1Z90+FPNWZJQBWVfTgIeaTGcp4kvPs+n3Uu7BCFR9Tx/WsD4e2b3Or7woMcQ6mp PGd2PssUGeZZcn6KP8SK6T4a6c0VtLcDaBIePXA/lUw1ZT0R6HGFUDBBOMdKUEMowDweQRSkEey+ uKQOAn8jWhA4Aqx4zxxTVckEPknsQKcrAsS3BoyHU4PekAPtZemTTB94NyABTiCvufeuZ8W+IJNN tltLTm8uPlULzt9TUVJqEeZlRi5OyMLxXrkmo3LabavmFTiRgep9KyrKAs6xxkrFH3BxuNQ21swX C5eRurdcnua2YIUtoMs8Y2DJywya8SrV5ndnpQhyrQybjwhG8wudPf7NcDkqB8jf4V5r4mXWba/a PUPOjjdh7xtjp7V7HJrEMMYCAOxGeDWNfXF3q0DW/wBjgSBjg+ZHuIHrRSqST1WgpRKnhnxVZ+Hd Nt5bTMjygLcEruVW6gYzkHiuluL+T7MNSnZvtF18yK452+oHYCuJ0+KKfWn0LSLAXMAUs0VxCF37 RywI5X2Oa3Lq0uZFVLaSS4aJcNZTnFxCo/u9pF9xzWWKoV5U/cd4l050+f3tGU7q5MjHLADqzE4F UrK2ivWm1e+PlaPY/Nu9fp6s3QUWNi3iHWEsUJSAPtbPr1O72AqfxFcWEl2II/8AkA6W22NFP/H3 cf3j6gdKxwuHa3R0YistomVeanM8o1i8iEdxMnlWNop+W3h/xPf1zXUeCdR1OadY1mZomOWVjkAV w8IudZ1TCoXmlbgDoPYe1eyeF/D40axUSAGY/eb+le9Qp2VzyKs+h0nmL5e0ckjmot7cKvIpwVR/ vGl5VegBNdZgLtO3JOPrUeB0AJ96ezDjHzfWhnIHVR7UAMxsPOB7GgsW4ycD0p21OCcsaaSxJCgA etACgBeoyaCxIxnGfSkAUYO7cRSbecqKAEY7flXk01h5Yzjn2pGVmcFht9xSKWB4O4d6AFSTAwfm HvT1YAFlPPpUe0N1+U0rLtI9O9AErTFxt281G+EAC8t/Kk8xS2F6dzUedzZGcDqaAJVXb7tTNw8z n7x/SkDMVOOB6mm4BXgYHrQA53ycA8Dqe9Og6kk0kMK/fY00MASVB60ATSgnlvu05PkPHKmkdsod x6UrNmJMUAJJ+7kBUc0TAHYx5JpJQDIv0ocr5ak0hnC+PADaSkAkBwcD6ilugy/DtWTy8lslS3Iz 04qp4zmE2EycMx6dvStC4sCPhssYO4K/mKSeT/nJrxJO82/M7mrKKPL/AAwDJ44tCx43ErtGe2Of SvUfBcKiznYgKxmk+bHUbjXlnh92s/FEUhxxIRxXrfhVJLe0uoXPyC4facc4Jrvw799mFbZHReUP NXDHpwTSlSJl3Y470m3IRt2R05pZTHFMrE5BrtOceZR9oAUZ4pGd97kDtTUkjaYuqn0odnO44xn1 oAdtb7OMtikKIJEyc8ZokRvIALUDZ5gOeAO5oAahALlVpql/lyOfSnq6Irjj8KaHYhCq0ARSLI0u S2MHHFSCNfPBzniomV3mwTjnkVYjCpK3oBTAhkUgsBxR5ZUpuPA7UpkXzDznmmXTZcZO3HagBWcE uFHzDtSq+AXxhvQ1Ck29DgEMehNEu/aBJk+4oAQSEybidrehp+RGPmBVuucdaiUAyYLblHf0qY53 KAd8VACrIoAEoBz3qORQWJJynb1qVkiVc5yD0B7VExhRdqocnqfWgRWBj6iTD9qapiyzSuXk7Yqd /LVQI4MntRnYjFoR9TQhgkEYKSY71YkmRW3ZAwKqsZpVUhgqD0qNngjkALF29PWgCxuBUMB/F61B Id3mjb34OKf8+FBUBScgCiZwqyqM5PSmBFGY414JWQ+9OZTIf364U9GFRwLtwWOXPYirJfzAEYFR 6GkCKm9wzLGdyDjNSyq0kKfJjnrTZLfZISrYwOlHntJEIwhGD97tTAcokUyDcCMd6ilmkCxh48LU kgCEjJwRz71VZhJgFyF7ZoAdL9nll/ucenFKkksMQCfMKZIo27igK+q0iqrRjZJ8+elAFk3Cyjbc wEe+KYIFKkRPkf3TUga7iX5lEiVXk2u25V8th6UgBS8RK4K+x70F4+Vk+RscEUjzSsuXjDY/iFRb Y5dxHOB39aYDhI7RlS5x0B9ac6CGFUYZ30gTfsjGdw561ZkIldYz1XrSApGBfOEeetNSN4LoKz7U J5qbBdnO4KR3qFUHnATy7hngjvTsBvTRbihOVwB078U+FR5bk5NNZGkiG58EAfyqJUPluoYnigC4 BEFj4AoDxxxsoPANQRxhYoyx71N+6G/pQA52UoCq85Bpkok3I6DGetOaVVwB3FK8rGJWC9KQhAGe QBzgjvQISchvmxSbmmZRjbkU+LKZVyfc0ANKAIvIBzSq+0OG7d6Ag25znnrT2Rd7jHGKAFkcSRqN tJGhbcvSmFtsQ28jNSRSZnPGNwoGJjZHkjODTlVXY4JFKWHlsD1BoADMCOOKAGNuWPdjvTgCy7gw 57UAkQsGFIseYw6ttNAC5YDH5inKv8Snn0pUkDcPwfWkkXHP5GgLib9wKkYx0qUEiHOOneo1Hzjz Pzp6sBCVUZwaAGkhST97I/KkBBGcZ9qXBO1s/hTQQm4Y5oAkDDB5OPSnDlWKgYx0NNUB0Bxg0qpn jP40ANKL2JHFPXIGM5FM+Zcb+uMZFKx5/CgCYE9TyBQMYOUzTIiD/F+dSl2UELyDQA0hCOuCacIm CjDAj3pNyk8oR708BcHnFADSrgAFc+4pV4/hOfY9KX5wDg5PpS7mGMjigA68E0GMAbhjFO8xR1UU qjedx/AUgCJO5qYLQoxTxSAaUzS7akFLgUwuQ7aQrVjApMCgLlRlqvKMCr8gAFUpxwaQGPe3HlKe a5u91DcGJcKg5LE4Aqx4p1BNPtJbiXOxBnA7nsK8pvdXvNSmw7sI26RA/KPw7/jWV9S0tC3qt+ur 6oGjz5EI2Rk9+eT+Ne0+FLUWujW6JwSgOAMcmvJfCvhm61bUQGHlwDBdz0HtXutpAttCkcYyqrjP Tp7VrBWQpD8blDFmJHUmnFPk4zj8qMZDcn8KNxwOwpkjEG2Qg00Al2DABTTk2IfUZ65oYEvjjnoK YCEkIyq3JB2k84NcFruj3cF2L6aVWiIKtI/BHsMdK7zChwW696x/Elk2o6bLam3hu4HHzwyZG76E dDXPiKXPE0pT5ZHnE+v+HNPGJtRhJX+GJGkP6VT/AOE58OuwWGO8mbOBshCg/ma4jxD4ZvrW9b7N A8lnuwrLkmP/AGXHY/oa2fDXgvUiv9pz6dN9mi6blxn3968+cI048z3O6M1J2Okv/F9pp2m/a3sZ Az8RxvLy35Cs238eNdssS2UUMjDAJ5Ga5rxKZtR1lLWNGKxrg4HStLT9KW1VXmj3v6EVz86jC8t2 act3ZHsfhKWxutLW8tIYkuZV23DgZZmHbPpVnWNAsdWAMgKTpykinDKfUGvMdLu9Q8P3jGAOIbgB lGOAR1H5V6NoPiG11eFNzjzQMEZxk16eFrQq09Dir0pQlc5bWrTUtP3DUbVrqMqVF5bt5cjqRjD4 4b6nmuHvElvp4oymyGMbYohztH+Ne+TolxE0bgGNhhlx1rBtvB+nxakbuONtuMhH5APtWjw65roj 2rtZmf4J8MDTLUXU8IW4f+8OgrsPlJ6lsUhUKAgJPtTgrn5QNo9a3SsrGO+oi5J3EhQO1NBUsTgm nsFU/McnvTWkx8qLgCmAAM4y3y/Sk/dp1BY0YYjLNgUodBwg57mgA+Zh02ik2og680MHONzYHtTc xjuSaAHhlC5NN81jkIn501sk9MU0yYHLflQA/Dt99gBTCsaDAYk1GA7NzwKfs29W5oACzEcrketR 8ZPzbvQUu8qTu5HtTdqn5h8uO9ACAg5AUg+lKW2YBH4CjDOcDgetPUrGOOW9TQAm0jDScD+6KRiN uTx6Cg8nLEk0MoVdzHJ7UAIgkmQA8J7U0uEzGo57GpELOgA+Ud6UIirnjPrQA1ImKne3bpUzkCFc dajyXLgDHFKyHyl+bnNACOH3qST0pl2wisGfOCATUrpl1BbtVW/AGnyAelRUdotlR1kjznWZBd6h CmQhzk7vb/8AXXZatp90vhGOE3MIiCdGU5PpXDakC+uWkcYJkdiOO/Su18Xa/pmleFrW1v7vy57i L93Gi7mYY6+w968SEeY7pt8ySPHJkFlqiPvjyr5Oz0r1Tw5eu8043Dy2VHAHrjB/lXkWp4eeKeKR pIXYBX49e9ej6LObfXYI1yyNaDgf7xrsw+kzKuvdO5HlsgO4swNPZpDKo8vIxwaaPLaNd2A3pT1M nnL3Fekcg07pJCEwp9aHSREJds4NTBkWRj6DpUOJTgsCVY8Y7UAKz+Y6qJDtoaOMyNk/dFMkSMyg jAbuKd8iCQvjJFMCJZgsZUJkZ60JcSL91NwFLglAYRweoNNCuMhR5ZxQARvMZS+MD0qxEobc7Mc+ lRqnA3NtP86bKuGB3kUAQpgTs6tk54U1LPIT8zgcCofL2kLJkkjhlFOkiZYvmbzFP5igBYnVlIVh 9DSNMYnyQSB2PShIA+NvGOx60rkKpR13A8dOaAI4Zd25kX5vQ1PC/G/lGzyCOtQvEQgETdeo704z KsYSUEYFAEjTRv8AMG2kduxpkbiTLmQD0FRsqJEWOCGPGO1MaSTygI41I9aAJS8e8kyE7fSkDwu5 DbivtUMbyohARS2fTmp4mjYASDb9RQBG9xCuRHCW/lSokEnzH5H96fLCvmAxP74FI8mcJNFjPRhQ Ap8zcpYgrng1HNEskjuWxtonjEY+VyQBwKrzblVBk5ftTAlUNtBkUsOzDtTid7/KdyrUiRPHHujf PHKmq6hVt3lZtrE9aBChMuxL/LjuaVpgLZRGOR2qsEmkjZkcAD260zCwxZbhs9RQMfJvL+Y5I9Qa VJ0ClGQOvrR9od12gqynt3pBCu3c0RjHqKAE/dMMoxQn+E9KkaOZMMY1cdyKTyskFHDg9uhqNrjy zj5kb60D3JIrkBjiUqP7rUrTiU4ePI/vConcyqPNjBHYjrSARxHKSFf9lu9AhzL5PzxOcHqpqMEl 1YjhjzSTSlx8y7V9QOtKk0a7UPzDHBoAnK7rgyr/AA+lNDlhJKp570yGQRLJvP3vu0PiG23Z+Vjz QA9VVrX/AFgDVVBVpAI0LMDyPWnSPEgUxksactxKsiuI1B/nR0A3zbmNSGJKkDp9KiiiyxwTgipp JJFHyAEED+VVo2YP35PNICwqIYV9j3qXbGHYcciq0K5VwSQQaseWvmqxycjFMAGzIPHSl3B4cI2c HmoygVMgZINEbqoK8KTSEHmAyjCMGA69qfG7u7KVOT3NL565CsOR0NME6pJ0oHYcFYIQTwDTiFEh yc5WovM3B8ZYE9qerFZsY/h4oAeMm3OFwR3puzMoO4DIpVVzC3zUR7Q6bhz6mgBkZ5kVjyCefWpV X7jISaftUyPUe3YAVPGaAHo+VdWHNABWHPbNKhV2YGmDckRGcrmgBwAK8flTRIQm0fMM80oReCCe aRECFxjigCTYWZWzwe1PAKM4B49Kb0RWHTNOJDyH0xQAwHIBXg+lKADIyt1xTVVcbs8g9KXjdhiR xQA5lIT73HpSqWC4ByOwqNBuUgmnghEBXqKAHfwtuGfpQeMbeR70ZLP0xUrFOpG3tigCMYYbse2B Tsqv8WKbtUnKfLTjEQucZoAkUMe4IpzqRyVzimE7VwcjigMzDAbigABUDkNnPAp+QSFBOaQbiRgA 8dqfkAAsvGaAM+O7abW5rJdpjgiV5GByQ7E4X8hn8a1lHFc34WguNuoXl4iJcXV5IxC9AqnaP5V0 gNSthseKcKZmlzTEPzTt1R5pc0ASbqTdTAaM0BYGNVpVyDVgmoX6UgPOfiVZvLoDtGDhZEZvpmub 8EeFv7auRLcHbbxdT/ePoK9J1+3ju7Ka3kGVlUofxqj8Oo0i0MKVXKuykAZbIOKmK95lX0OqtLC2 sI1jt4UjUDHHerJRWHTHPXvS9yMZHsKeSMH2rQkjOVyMtn2pBlowQTj0NSBgduRjPFN8vr82frSA jCYbkE8+nFSE5cAJz701/lbB3Z/SmySBe3y+ooAWRf3oz19RUTjqOfrinRzRtJjJDjnB708MpY5B DH2oAy7rQ7C5PnPCPOI2+ZH8rY9COhqjrn2qLQTYsuV2hROAQBjpn0/HiugIPOPTkVG+W/1gBz6V nUpRmi4ycWeGw6LdabdS+fG7zSNuVjyGz0IP+FdpofhG5lAnukKr1wev5V1N7oiSRH7KIUXqYJVz G30xyp9xUFlrEumhbS6QxtnEcdw33h/sSdG+h5rx8TgZOWraj5HZHES5fc3GXnhyK5tmiLYbqrEd COlcx4f0N31K4Kzm3lifEkW3ofUH0NegwaxYXDiKR/ImI/1Uw2n8Ox/CsbXLb+ztSi1WBSc/JMq/ xr/j/hWeGpfU5qSnzRf4Ec86l4T36GvBGsSFSSzCpcbuC1RxTxtGJYXDI65XHcGlO1juyV9q+gRx j3ZYsKBlqZliOTimKGZxtz9aUpjJbPTrQA9QmcDJNNcMSRmkLBW3KcjsKY8mW4Ugn0oAfsVRlzSb yeI149ah2scMTn2qTzWUEFOvpQApbAO4jBqPcPuquPejG4ZyAfegIWPJFACH1kc0oVmH7tcfWjyz yDSgMucNxigCM7xwx5pc5xkcetN3lQec+uaeuMfKcE9jTEBjQYZTkehpjIrHoQR2pkgVc8kH0p6O ZIsS4XHQilcYxpeNv8qApYcHApdygEImTihELNhgRn9KAGiYI23bz61Y3RlNxwaZJ5UYx1Y1X8lm AZshaAJTNxhU4pMEqrfeGeRQu5FIBBWmjJHyHBoAlEy/OQcHpzTmO6Neap/KhO8MG+lWdu5UPIFA D5CokHc4rK8Q34sdAnn2gkYAB9zWqyEScHPFZevWYvtFkt5V/dlgxx7GoqfC7hq/h3PJ21wz3nzK WXcMqvejxlpd/ruow61EgisbiJIUaRwNrIvIqS9sksvEFvFajAbk84716X4xCx+DbbNtC5AUkP24 6j3ryIJNtomhTxlKtzVJ3XY8MtgmnabqEE4V/MeIREg8MrZJH4cfjXoHhy8E2v2rxJuAtAuPfca8 2u/NudTEbKSrOAQO2TXpPh8rZeKWh2cC3XoMYzXVQS5joqzqyk+ZWR6CFHlqXIDg9KnhaTz9o5wO tMCbkjZuD2709JBA7Z5/CvQMR5XaXbIOaiYsWQICQBzilzvVmPyrmmefsl+VTs6ZA6UwHbI5ZScZ Yd6aY/LJLDnpmpIWRpGZOT0zSsCinzMHPNIBhYqeg2AckdajMm8nA3g9MDpStkxlgcBjimY2cdP9 odKYhrqSoywYDsOopkiu8eN569+oqTywgBzux3HepU2yMDIuAaB3KyiYYCOHXHIoBbflCA3cVfkS FVyB+AqmwiYZKsOc5oC4hZpA2TtPemMBjcZAVH508SRqPus7eppPJEoYvGVz6UBcrllEu5ScetSt OsnyOoOe/enx2myIEqHX9ah4BJI57e1AhZIyr5U7lxzSLcKJBjjHBHakRRgtlhnt2p6xRgZcBSe/ agY+cPNtMaYA5OOtNKuycNx/dbqKI5nt8bhkE8ZqeZo5RjoxFAEEKbOQSh9D0prTmWcLIMBafOf9 HRDyzHANQGMpvOQQo6nrQA9n86UnHyg4FPCh7sEAbUFRKpCxgnJ61NCAEkkyOe9ADJZgElxnPbFM Zdtqu88GgkLCNvLMelJO3KK5xgZIFAyJsNGTHkc4qAhhke/ep4h5oC8qAc4xUm1BEN3QtTFcrrBG 0pMikEdx2qbe8akLKHHZTTUBPmGMnHvUK8yjcMkelILDmIJzJGYh3IpViz8yt5oHZqSV827MXx22 1XLkqvylR6joaB2JZAittw0b9gDxTSpU5k2vT42cHAZXI9aZKVBJlBD+1MRE7l1BUEDPSnbwV2qo U9yaaSfLUbgp9qdGjE8KWNIY07TFsVSTn71TO6tbrF1YdRUbvt+Vvl5+7SviACSM5Y9iKYhhhcjb javvUceYplAJPPQ1MM3C5kYqeo9Kfw2FdRkfxCgDdGGw4LA4Hy/hTHmBdSFKnvUpf58Adh834UyV 0Aw33hznFIBolZHYYGWFSDzDGrg81AsgMiOVyTSCWQlkAAwc4pgWdkjF1J5xkUjwgNufqRQs7Fg5 4IHSnq5nV8np2oAasYV1fOQfepQ0XmngdKreSBtKuSc1MCiSZYYPekBE2FLeWCMnNTqdzruGOODU AKneQCMd6nVgxTf6daAHR5RH7ilUq4jPpTU+UORytGAyKVIBzQA9kZZiV54pI3BTB4IPenBv32G4 4pCgKFhxzQBJ5e6U4xyKjVmRWDdjxTkcrNhs9OtKSDvz3oAV1wquOtORgXZWHUVGcrEDyQKfkNKO wIoAYQyp8vIz0p20tIBnBxUYZxuXgAGnlH3KVbrQAzYfmJbDA1IVyQHPJFR/NlgzYI604qPlBbIP fNADkTIYdvWjaoGQeRSK6qSud2KBkqSw4pgSkkkHJ5HWhlfGTzQOFXZ09PSnIS/Izn0NIBuQ3G0i ng5YANSB2DEFKQEM5ATmmIkfcQACDin7ggw0e7jtVdFIfPIGelT8gcNn60hiB024wQc044RWbOSB nFNLFB93dmhQHOWB47CgCtFewgffRcnOCQKnN2AM8Y+tYuteHob395DIYpRzgjKn/CuJllEcskQm UshwwVulYym10Likz08agnfipUvYm/jH415MZJM9X+uTT47m4Q5SWVSPRjWft32NPZLueurKr9CD 9DT99eWxavqMeCLhj/vAVo23iu+ixvVXHscVSrx6idF9D0LdRmuWtPF9vKVWceWf9ocfmK3Ir2OZ AynIPQg5FaKUXsZuDW5dJqGVsA0nnA96r3MuEPNUSYerzguqZ71g/DvUxJdXtqQSGlaRCD0BJ7U7 xFe+RaXVxnHlxsR9eg/WsX4ZF/7Wcgn/AFfPHXmog/eLex7LjA4//XQMsPmAH40HOOhOR2NJ5Z3L g8A8itDMXBxkgcU376nGPpSlXyMOcdwRQ0aqDzjNAxpD9D+GaaY1K/NyT1FOIxySTj8aRiGwPuns RQBVFoTcCVZSR1xirG0jBFNLYbG0/X1qRVyMklTSSSGR7VzuUEv6kUmRu/pUm1yThvxxSkfMFzkm mA3yxIPm4HpVe6t7e5ha3uYUliPVWGamPmcjHFDMC2Fx070WuBymoeHbyzil+wul3ZAZ+xXB3Ef7 jdRWJa6jBcTJbyTXVuUYK9tOxyB/sk9a9A2kMWdjVHVNDs9Yt3W4iG7HyyLwy1yVcJCetjaFeUdz K8PXUNvfXulpKJoElBtWPBwRkrz1wa6QLvBY9ewrztvDur6brNs0Uz3VvC42Mew9CK7+JZDCHJ57 r3rekmo2ZnNpu6JiRgbgQPam5ORtwy98mgysBtIFKGTkdDWhBCcMcbcAUmMLtDZx0zUrqW+50PFR GIpyw5oAZtJUEgg0FtgAVsnsDQ0jADaaYr4GNoJNADn3MuWXP0pm4PwoI96U7WPDEZ7GmZf7uMe9 ACr8rck59DTyCwO75T7U0K0YO75hQrFj8vT0NAAzBVAYA54GDUXkl/mBIx2z0qVvLB6YP6VGxZ8n ke4oAjYD+I5NLHgLy2RTzGxcbsbfUVJiFevJoARZkVflGaFMj5I4obDD5FxQqvCNxb8KAI3jZMvI NwxQJQB8p/A0PcF0KMMe9VHifG5WGfrQBbx5hJztNIzoDtI+bpkVENzgK3DdyKfhlHzASL6igBY2 BXDHJPSrTqMJg1UynQcj9RVhgdybWoAeQwduc8Vk6/dtZ6JNJsB4x16VpBnzISM4rE8Txy3OgtBE uXd15J4AzzUVPgdy6fxo8+lxc6pHcgbXTBBPNdjrGqTyaHDZ3sazqVyWcYY1x8N0tjqqWrRZYsFL 7uBXY+LLO4ttDtbpwsg24KgYYE+9fPxVR3sew5UbpSPKdQsETUo7lJXUCRWYPzwD612+iKLjxfcT xuHQW8SjHPauDuNTW6vltxC6yFtoPYnNdh4QEkGt3CN8rqiKVI68V6GDUr++cWK5be6elMZCiEHN PRSilm5NME5ZAuzaacJFW3csd2a9M4RBu2jIBUmnblCtjoevFRMwwvPQZxSL8/coRz9aYCp+73eW eKdI2ABvySOlMZgqGLb16EVEkLRn5vnb+VAChSwB+6B1U8ZqeOVPuqCM9jUJbcGWXJB6etLjChyd yjpxyKAJdqhv7p9M0nV8E4qPJdfmG5O/qKFlG/aqhgOx60CJRiP7sik98mmNJK5whRc9SaGG770P FRuxJ2pDk/WgY45QbjIoPcmoZJWbGJQU7+9Pw3eAbuwJ4oaOTO5lQUASR3KpCQgZv61HMXlQAR7S e/pTFaR3C70VQeopJGUTANMzD2FACSQMqrucEd6HkZY/ukjpzSD5SxwZAexpdrXS7MhVHQCgQsSh 5ACDgDPNEYGHcZwTgGhR5UL8nJ4FOQCNEQ/wjJ5oARwGmXJyEH61FLkoozy7ZNLvyrsScscCoWZ3 lGzoq560DSJJWCsxDHAGAKGZjaAZ2g9T61FEhaEs4yzHin3J3COLlVFHUY7IMkaRgkgck0rRjzZH bJwKYpNt+8U7lxz7VGJzKNqn7xzk+lMQ8NGqkrknFNOWIDnCgZxSEBUAHLOe3anhclzIeRgCgBuX EAVflHekhKIrsRyB1NOlfcCiDjgZqIqscZBOWPSgBkn7wLwAaj/es7gkbFHAqd1AmRARnGaaQQjj 1OKQ7kCsAmdvzE9RTZiEdcMXPf2qaSHakaKAO9QOR5+QDgUASQW6PJ5jNgfyqy92EGyFPYGq7FHI ypjz7VEzRqMJvbNCCw6QpnfM25+wFV2leRwMHA9KsiFVG+Vwue1OSSONSEQsx4BouAkbiMjaQ6Hq D2p/yswaF8EH7pqKSBiNzYQH3qGIBJtpG7ngimI6llNuQp5BA4/CoJA3zMV3LjgelWmIdgz8NgYz 9KiKhjubIA70gKzMWRXxgr0Bp2JzhyoIPOOlS+WHyGX5exFNjV8537kB6UwGrk554+vSmpu3kK5x 6561ZkjjbAztJqupETuAM5PNFwJ41jGwbznPIFEq7pGOMqBUcZDSjYmPXNWCxXcNoz6UgI1ZDEwU Y7AVY2Mpj7jHSoxH8rEdc1YRwroGGDigCNGI34P4Ugx5QZTzmnSID5hX71RKCIl4IbNAE5wZhnGc U05jViSSM9PSlyDOA3XFRtKVDBumetAFhCGlAznIprhgzkVXy0TqyncCKnjlDrITxntQA5JVeDGc H3pSmGQqe1IYg0AYD5gKUSYZMigBmCwcNwaXa6lSWOD6U9gGLUkhbYoNACNFucnJJApgjZXU+h4p 371GJHORSMzlFwKAJEVI2bv3pI90hwvUnpmkWL5zuPWnkrgKFAI4BFADhjGSdpz0oL5JAyCOhpWG Vw46jimDoAOnrQBMh+Q7zlj3pApGe3oakX5YirfdHOaTGOh/dgcn0oAVG2nDfNRIoZsLyKYvynIa nox3buhoAcF2nn7vc96YNzHK5A6U44yCTgnvT8lwE4AzndQAyVVkjMcnOeM157q/w6uJJZJ7G4DB sny24I/GvRhwuAOp609Q2SM7RUuKYJ2PGH8Ha9GQi20x9DHIP8ahPhXxAvIiu2J6BWP+Ne37UVem eO1IQY9pUDHc1Dpov2kjwxtK8RwFtsV7heDlScVA19q9scSgE/3ZI8GveEUPLwMHqfemTWlvLzJB HJJ0UuAQKl0Svas8Oi12cA+daqQOu04NaVl4jjt3DQXMtsT2YfKf6V6ZceD9Gu1k32UaO/Upx/Ks G++GNjNGVtbmSNhz8w3fhU+yad0Uqqe5Vh8W3gTLxwTL/eQ4/lxVweIkuU4Uhv7p61x+p+D9Y0KU GBvNjbHzw5xn3FYp1TVbWQqxBZf7yClzSW4e69jo/FlwTo0hAPzyICPbOf6Vr/Cu0Xyrq5YDduCq D6V53PqN7fsq3E7sueU6D8q9l+H1r5Hh+JgPlkJfOOfzrWnu2RJWR1o3HrjHbFGxeOKUHNLWhkNI 460mMDAGadkH3pmwqflJ+hPFACHAHTNMDAE+oPQ09iAc45PpTduHwMkEdaBiH5ck/NnkUvLcsCvt T2GUGQMimBg+Ccj2oAX5gm0HnsaTZkhm6jvSmMPhiPu+hpHJb5VHbpQA0sMEL07n0pvCkbRn1+lK RuxuwOPTrSYYqORjGKAItyF2Un5gM9Keh3Drn9KTcmQq4z3pmCCVyFcfrQMGI3AMgHvR937p605n 2qQRwO+Ki3glmyQTwRQIduwvzgVG8aSHdnFKTu+g7E96Y7AkAj64oAUgoB5bA+3pTj5h+Zvu+lII 1I+UnjtTd0mOcFaAEaQFgNvApm9E4UfMaV925VAwTyOaaTs64b1NAx4jD8sKR8jhPmFJltxAJTHJ B70hITgcGgQDOM5xjnBpPMLlsrg9cikKsXDM3X09Kf5cQQnkgdKAIiVJ243fWhY5Np2nA9DTyN6g x4B96Qq2c7uPSgBhwq5dvbApQ0Z4CliPWl82MZyhJpN28/ImKAHBJCeDtFRP1wzE80rI45LjHYUg kRRkqWNAArlMAqCppTFHI25GwfSl8wyAjhe9ReWgfchLNjtQAhibdjO0/wA6cgkiPTPt607y5WGW 6fypqyPFzkMKAH7on+8Aj0g5kwWxjuKa08Ug+dcGoi21SACc8cUDLG0qjENnJrP1uR4dNcnGCQoq 4A6whl5PpmsvxJIxs0QjjeOfzrGu7UpPyN8PDnqxicZa6NLc6+LssqIWyc/Wu88Yw/bfDyW9vKC/ Hb0rlYGw/XFampSMIIBuJG2vmqeLnyydj26uXx9pGzPIv7Ju7TWYZJYH2CQEsOnWu70Hy5PFF7IG xxHh/T5RVbUyD15pfCUckutXhU5BC8H2UV6WXV3WbbOHMMP7FJXPQgzAYxkDgN600wKcbXI7ketO glEcWCvyrxQ7A8xDdXtHlXYpjT+9tYfrQZSxXzhtUdDTCehk+bjp3pNry8gZjHY0gJhIUHADLnhv SnJCuTKsmWPJyaZvWBDtYFTxt9KWPEpCKCoHJPrTAieVXcq4KkHrTBtjJO7NWGaJJCHweMVXBjMu 452emKAJIrlJj2XHU+tJJ5CEuJcMaR2t948vr1xjpQZbdPvAMfTFAWGA+YpDzEfSjapO1ZSF9e9C tA772XAHTApkssTMwjQgjoD3pDFk8tBgTsW96oicvMqyOxRuhFXlMTJtCZbuSKcsSxuJNhwOmRWc 1K65S04pWYyNYkLZ3Me1P5wcRjB7kVIyyuNyoo9jUZEucyMqjsM1oQRlJEQvnA74qBZ49zbcq579 jVourNgNu7HHSknhtxGGX5WPQ0xERMh8tGIPPQU+Zid2Op4FQW7Kjt8wyRjJ61LvjVgSdwX+dADX QjYrH5RyRS7/AJG8sAluARzUTM08pbBAY1ZYrCFUEKyjNAxsUarcKjt0FO86JrlgwDHoPaqykzti TKbjwxqTyGiG0ASD+93piGXcAZAwOM9AKh2SwDDLw3GamWJnk3BgdvVSac10XmAdMKKAEWSJGX5s lRzUcm5oTJ2J6A0TmMM8ijcSMA1WwWUbXOSfuHvQBP5mIFQDJPeo4VaS5+Y/KvOac02FPy4KjGKb GwWNzggmkBMjf62Y9BwCaCAIUJ6sc5qHefKEY+6amJ3SpGBjAyTTAR2+8x6KMVXjReDt5J796lb5 g3uaSUhEULyR3pALK63WEzsI4BqHyXjYrIx2/wB4CpQ0SWo3DLN6daXa8UeUbep7GgZV/dbyXJcD pVhN7/MihF7E0bEb/V4D+hpjxscKCQe60CI5NpY73LEVHHNKzjCjGeOKncptEYQhh1qNCxkCjbGt AHTyE3LArwoAz+VN3kfLjI7ikjZMBYmOcDr9KlP3cOvzeopgNJGdqHafQ0hUBdp4Pcim7ShBPze+ eRTslB8hznsaBCkZAH3v5iolYIGBXIJ5PpTy6xjLZVj6UQtsDsw3A0hjQoVyV+bjP0pFkKZLg89W p8SnzHdfyphcM2Mgf7JpgSbgUZ0OeasB1bbuqukZ2kx9c5xQSGOG4YetICV28sv3Bp3WFSMHFU5G dQcksDU5TbboyHqelAEhyswDDPHWomY7W6MmakV2MoDLnA6VGeEY4wCelACKcMGjOf8AZp5Qygsh 2+1NiwXynp0qYrn514egB0cu1PLPWnuVJQZzUe5XOG4amOjBweRQBJ5hUsPX1pysGVc/hTFYMSHG G9aMOCAQcZ4xQBIwIfK5NK2yNFJPJNG7JwB2pjxhUXdyc8UgJShkbIOKYp8v5SCT2oR2JAXgdxQM mXcvpyDTAe2QqkHI9KVFxjH5Ugwz5HUdqkABcsOCO1ADiecAcelDAgjBG3knNNzubng0qjLbW6dq AEZQWBH4VIH2gj7woK9FPahY1CgKaAFwAgbPHpT0DE/L096YPldlIyASAfanltqY9RjigB6jaSR1 9Kd95mK4GeeaYq5TJPahiSoH8Wf0oAeG2dAScdKUDacAe+KbudVDMBjOBTl8zezZyp9qABhsO5ep py9MtjJ7UvOOfwphTDnc3HBFIZYAPXtRtHfnNIGLYKgEeuacRkj2oJAjcOQPoaybzwzpF+ztc2cT M5yWA2t+YrWzhc0bl4yeaTSe4HGv8NtGZ2eNpkXOQobOPxNdFpWkW+kWi29qXCAk/Mc1oYB5pw6U JJbDuxMdOelKaT3xS0xCY/GkI4wOKdUWSrYJyD0oAa6bkYZIzxnNOxjByeBg5p/IOABilIoGRHIO SPypSMgfNgj0pwB5BOe9NCjcM7s0AIxwvJ+WkGPlz94dMUuMjr3zQFwPm7d6AE4bkg4qKU/MADjP ANSkFvYdOahO1vkkRgCcZFADTEIyQQN+MhvWgZ/jGcelOK7eOCBQ3y4I7jpQA11LLuXn2qIqAwwB nuCKdv2EkcZ7U8DPXIY0AReWoHPXOfrTHxG2BnBP6VLuwxHUVC5w+c5GOlMBzNtHynr/ACpm7C4B yM8CkADKRnFJtO4HHTnIoAfIMMmOvuKryHMvHFTyykFDxnHWmKAVYse/SkAxyT9/k461GvzOFJ4P rU5QM4C+lMeF1fI/OgBWEsXJwwxwKYCzyFshR09hQyyHjfTWVFbLnr6UDJdik7i4/CmlgD8pJqIe WGO3P508NKTwvHrQIQSOAVEeMjOe1NJJG7zApFPGSRubGDSlYPu96AIfu42gv9aeC+3ldueOlOIY EmMfjTH84j5mAFADhFE3LNzSnYn+rJPvVM5EmNrN64qRCEwIW4HUEUDJJDc9FPbNRx7iSGyGqQSG RgGyD9ajeRlHzg8dCKAEkfC4dMn1pse4Llhkd6cJR1JDoKcjCRi0ZwP7poAkY+Yi+WMe1ZWtwma1 UZIZXBIAzng1pGYCRVC4JriNZ1G/lkkcSSbFYgCPgY+tc2Kmo02n1OjDKXOpR6FYS39rqCm5t0Sy z8zDl8Z9K1fFGvaS1lCNI8ya4XjDghQMd896zPDGtaa+pGC7066vJicY8vzefxNdN4tm0ix04SS6 BOgYZEiWikA474PFeLGlFKSSR6EsTJzTk3f1POUn1i/lVZdKKRMcGVHyF+o61t+FIJLTXdQBILoQ rYP+yK5KXxE3nY024nUbjhBx+GO9dV4R1C4vr8G4iVZZB877NrNj19frXdhIQpOyVrnPi6s6q957 HfBROg2kqeh96neNY0ypwVHShDGynAwQOoqJdzKN3c16p5w0LuYF8q3bPepDkRllGGHQ9qSdGnba nRRzTfO+QQqpBHrQBG8XmSpnlu+KnRvLDmiMBC7Z6Ckdt0IQEnPcUwuRRIWjMjHOaSUO5WJMAepF WWIRUiAGTQ21XOew60hme7mJTgKWHGcU2MP80rxg454qwFWSQf3epzTHkDFsg7T2xQAyKVyc7Pvc jjpTZpZJHCqg3A8ACrLXCiNEUckflR5qpKXKA4HamIjSSZRtK4NIEu5Tls4zSrcSSSGTb8vYelOa 9lZTsQL/AL1ADWgnzgvx/Oozp8suN77R6U+JpnbczqPxp8jlQQZgSegFAIZ9nMI2+YuewprxxrHi SQNn0pUWBTukcu38qZujeXCREigYpijW3DLFu9+9NXCxYT5lPJB60PPNFKquq7Tzj2pxaC4BIYxu PTvQIqLI/mjYSGz0NOk/eOPN+VvWpeYkAKCQY+8OtMihRzuJ3HrtNA2SbZGAAG+MD8aWNxCP3Tli Byp60wOfMIg+U9welIXXO2RcSf3qAJSUnJ8weU3t3qNmeJdrLuT+9jpSSRySYMmSo6EdqXzt37o/ MMYFAEZVY7cN3Y96SVUuCgQHCjJqVFjKjzGwR2NQCVYYm2EFmOBimIj2hUyTk55oYFIVb+8elIYW ITB+8c4qTyzLc7N3ypSAQLhEOME9RSK4BkYH5zwtOaRTM+f4RxVUKGcNnvkYNAFu3/1JVxtYHJz3 oiVZGYsMKTgUjyMxC4DA8bh1FLMwhVUGDgUAU7iFmuwI84Xmnodr7lfa3oe9ME7ZZlGc/pTxKkuB ImMcbqAYryDPzph+uRUsU6niQfQ1HIWRcHDoO46imK4lG90IA7igCSfG/I4bFVyoWVTIM56EVPtd FLK+/PY1BEQzfvQVbNBR0MaIWZw21sDg/Snw3DbSXG7HFQK6ktvUgev4U+3EioXABXOaZBaUIRuB wx7GkZHUlmUH3FIjJIcsNp7UuZAeu5BSGRjMpJdsL6NT/IfG9GyByB60oeOZ9rLjFSumxCYzQBU8 1kJOAr+lNAEq5YYcnrUjbbhcsMOOlRMrxKoc8daAJ4y0OVbJPrVkBJxhwA3Y1WiYBCX+YeppzpIB ujOVoBhJC8QI6g96U5WJQMe9CTysQoUY70pBTAKZXvQAi5eXKkFgKcG+UiRcEmkCoDvUlT6U4Mzj BwaABkDSZjIBxTwS3yPwwHWoFBM3I28dqnODxIPoRQAu35RuHI70BuiuOPWkEhT5X5X1p7KfvLyD QAMmRkHPvSqzpweRSIxBwMY70uRncDn1FACMTu3IcDqQakLLIqgnkcik+SXgcGmkbB0z70APz83z DB9aYuQWLdezClBIUk8ilYYi+T5lxQAyP5HJJznvT9xBU9PU4pjLiIkDkckU+JsxYegCRTld5B+t OiO5umCOlNI2xkckEcU5BtXryehoAkT59wbqOKCSOGXp3pVO5eBhu/vSmT+Ej5ujZoAQMSCMZFA2 8quSfT0oz8yqrbcdaEOcsBhs/nQA9T8o5yM808uoHQ/l1pIxvkycZ9D605du/aSMgUDE3Aplwee2 OBUkTZGCeevFMO8qFK8Z6CpFIC5xjHHFIBzYPTr14owrx+tKFyu0DilHy8LjPagQyPKjuKmDZAwK g2OWyxxipF2sAp7cUAyQDjBFJgNyMZHGadSCgQtFFIRnocUAAzjk0HpR0/GloAKTHIIpc01uPm54 9BQAvrmg8g0bvl3AH6UtACDp70z5gST09u9SU3k+hoARslcLTD8i/Mfl74qUjjim4Az70ARMVYBf 4DyGppyEYDmn7cAYGCc8Uwja+5VxgcigY0gdjg9hUJfe3PBH61JLg5cZUkY5qOUbWxjGeQaAAHLc jKildMgFep6U5McjODgYHTNMUbwRyCDTAbkomAMH1qKRCxUAgjbk1KA21s8sKQDYA3WgCPblDzzT cN5OSfrTwPN3ckUjZx5Y5x+tADEjBYMeh6c0SKNre3SpX4CdqibBZj1xQBEqyC4Ulhs29Mc5pbiR iAR9MipEOWTdjpio3IPToDSGNUKuQ5J96AEYkKQR7UrbXHykBgOlMUYHy4VgfTrTEAUZPHIpcOG+ Rvl9DTd7n74/EU/zBjB/SgCF8nJPrjFSbkfDKOcdfQ+lSMEkjJ3At61CybVAbG3PakA7EgGfMFN3 kfwlyfWiRVyChJpyrMRxgCgBhdmz0QUmImHHJPenhEBO87m9KQgN91do9aAAwgD5249RUQf52z8y j1oULnaXLdajYO+QqYX6UDJvKSXLxkKO9N2D+A4bP4UI7xxkDke1SxbByDu9j2oAilR1ILEZFcrc 6XcRrdvcxhoC6/Zz6D5sg12JBJ55U9Kytdi2WSEORl8Y7dK5sTFOm7mtFtTRwHh3MHjiNQAVLrnI wB+P1ruPik0o0i3EZO0sd+GxXGeHQv8AwmYxD526RR1xjp/Kut+LBP8AZ1qNvy/Nk5/SuGlFcsvk dEn+9R41pES3PiC2STeY9+Sp6A/5xWuurXmma/dw2z7YorgqvHPFZmgL/wAVHbjkfN0rufD9jb3G vanvhR/9JY5Iz3reirzIrOyO00ueS7sRM/BIGcdzVp2O5VXkKMnFNRFSJIY8AE8gelTDEUUj9SOB XoI5BqSkI7J19PWmxjzW3uuGFNgQSjerYfsKd5pw+Vw3Q4oAXfmPan8Tc1JIFjaNQT7D1ph/dpGO OuTT0Je53HsOlACgfv8AJOcCoJGLtJzgetOaQ+c+OoquZCI1XGSzZOKBki/NnbnCjFEhEduqAfMT SNIIrU7cFicUN8qx7hye/pQA91RHTOMgZyetVmCsjyMcZJxSTSeZOxH3QMVDLLB5aJuJI/u0wJY4 MoGaQoOvB605IYGb5m+Ue9VSwmCghgo/iFSi4SJMeWG+tAE7fZUUYJPpjvTEMJYuUJNNhYv+92IA emaV5XkIUOmAOcGgQocM/wAsJK1KhmDHCKi1CZAF/wBaePQVXeV5ELKzMBQA+5bEgMz5HQYqBojM paFsge9RxqpO8nJHZqlGwRhtrIc4B7UXGEV29ooVxntzUyFbnLFgjAVHKv7gtKgbPRhzUckLMNyv uUDscEUAWWd9m0rnH8QpmAGLE7wRz7UxLwRx7c7hjnimgLM5ZDtYDp2oAUTukn7tvlPBBp0uzzQy ja3fNVnuFXJdcMD1qWVluFjdgAB+tADX3MGwcsDmmloRIADnj9ae0oEjxKAeKpH93GWxlg1FwsWo LhEkZnzgdPams7IN8ZGZO3eq87KzjgYYZPNDEs6un3R2NFwsTuwMSZwHzyM9allVIGj44x2qirh7 hi3bkYqa4bzIldTyB0ouKxLGz7mkB/GoJJPMdmZtuBT1kU4BJVsfhUdwnyqWGBnlh3FCAajjGQxV 8cZ6Gpi4MXln5W9+9Vc7WAI3x44pWO4Ej5kXt3FCAeskkJ2+vUU9WQsPKO0jqvY1B5mYyTypH4ih FKIXzvXv60wJ3lDMA3yt7U9BISrAh8VXCo0ZZZBu9DUccskUgbBAzyO1IZ04YiPaV+UAc/hSw+Zg lGDKO1I2UhCIwKsozntxT8xpGqhirfzNMRIZ0kxGRhval2Mo2wvkHtUIZ4lzKgbNPiUfejfBP8Jo Am3KoxImDTM5JKP9AaZLcSK211G31NIixjDnjPQ0gJxhs+YMN2NMILOPNwUHSje2/a/Kf3qU53YU 7kPWgB2MYCAMh6+1LJJ5cTbOfamFWjG6NuB1WmwlWYt0buDQNCxgNHv5B9vWp45CBjcCcd6aVyN8 fBzytSjy5I84w2KBDJBgbiM1CnzMGTjHWplZNuN34GoHVzIdowPagEWN0UgwrfPSMWjIV+R2OKhT BIBG1vWrocFdsgB96BkLDK5B4NEUxTINNlV1OYydvWkMQYh89f0oAmI3/MnQ9KbtOeWw3pTVLD92 D0705chwZOtAhQWcYIxipvMEcfzciomdixCrg9jTc+ud/pQA9wcbo+/alLYAxwxpke5pSOgpwOXI fj0FMCR2xgH6GlAAYIT8rUFcHk5XFLkMMA0gHngBOx6GnjIQKT8o6GoCzb9hPuKn3Hbtbr60AJyp xk8c5pz4wkmcseooK4xu6etIeXAbGD0IoAczBwueCOfrT0ywBA49abghmxgjoaWPKoQvbtQBICN5 yOT3oATOSDlRSKMg4yacjENuPIPHFADywyCucY6+9OLAMAOc/wA6ajKRjuOMVKGDMVxgg9KQCg43 N3HaiIKBuBGGORQipuZvXrSqBtznjt7UAJtO4+nY05lJGBx70N8w+XBNJyWA9OtABGuCTuJ7cmnk 4IGCc0iADoMUufSgQc560tFFACd8UE4HTNLTAX8xgQNp6EUAPo70UUAFHUUUZoAD0poPGcYz2p1M YgAEjntQAMw6Z5pWUN1+tNbIwcbieM+lAJIG4ckc4oAZJhjjGcd/Sm7RvJOTkdaei/LkfkaQldvB ye4oGQPlgI2GU9fSl28BTgkdPalkQNkZwSOnrSMo2BgMnpnvQMikQLMCO/NPV9oxjk9D60jAvtII 64pshO0qykY4BoEM35YjGaD91QnU0kR2oxzzTmUKQc4weMUwG4CMevIpCgxnPOOfanDEk42nk0jH G8fhQBHI+UUY/Go8guQBxindYskDOcYNBOX3EDJFIBsmQqgZznFIMeW6++TTXYhdx5INRvIG5U7C TznvTAUBHOR8pPQ0SK2Ah/Onq6FPnGMnrSANkk8r2z2oAaA8Y4G4HrQGGBgfWpE3A5U59RRKULY+ 6e+KQERjiOTuIB7Cj5VzglgRmnEwLgDmmNv/AIVwp6GgBPMn6BAF9aaztn5mPNNIkJ+aQ49BTkhJ 4CnjuTQAKQcAIRz1NNlZg21ycHuKl3NGuPvAGo22yclv+AmgaGsEWIGLn1NSR3aBdhAzULRRjO0F T6A8UggU8OMHNAFpYkYb0IzUPDSYxtNRqZImwrcelWEkjdTvGGHrSAVJSHCyfw1leIJRJYDH/PQ4 +mK0ARsYgZ96xNemij0+FS4Vi7ZGecYrDEfw2a0fjRzXg/H/AAl4xgZfBPfGK6v4o7RpURJBbDAA joMcmuR8L3dpYeJ0nvbhIId+Qz5znHf0FbXxD1+w1GCOGwvIp8DnYc81wU/gl8jpabqJnl2hqB4g gYdQTx+Fd74UZP7V1IyMQGuWX5RnHNcLoySQ65HJKhVc8MeAa7fwcVfU9QYjObl8A+ma6MP8TMq+ x3ka7GXJHAz6VG7b4h1Kk9KR5FYvsfPGD6USHywmwZOOma9A5R7PEUBHyP6UiZW2LsRknrUe5JlZ pV2t2xULSSHbCw+QnORQFizuMtzHkgKB09ak83bO+Mk9BVaSYRTEqMqo5+lNtpAVkmJyADgHrQA9 W2wysT8zHFRzjy7VGI5PcUgO+2aQ9M02aV5UQx48tev1pIY143EaOrEKxzg9qWe5lLR5UlAOWFJc XaSQxrwCOoHaljdIj5UnzKw496AIZp23HAwp44oMEU6hbfg9zVe6Vo5cbyAfurVy1ZbYbnXGR94D igByWphhI3gkdearBGZiZFwvbbUrK08haFxsPOM1A13Pany2QE4piJQuCET5weuO1WRDbGPJBU+t VIzDIdwZkk7ntSTXLqPLkAZf7wpBuSMWwFjw8YqByvzeUxV+6npSKjMrNA2E/u0sU8LArKORQVYi lujFb7ZIjuOcN6VWt7qUlUDM6/3DVuaEfZyQ4KjsagQQLF8q7H7Ed6hpt6MLosmYqvyZ/wB1qWWQ GMj5o3x68VC7yeSu4CRT/EKZK2YSQQy+h6itEIdDJGOHyGH8XamGfEvzHgjAK1VWUqwCAkkcg1GC +Wx0B5BoBFlGKF/MZWweh70qyyOGVMKM9DULFvMUnBLDrU0cQkjZtxDCkBNE4S4ViOSMGnKytcSj sapSSZjXd94HrUm/ZKnPDCgBG2sm5s4DYpvmYt5F/XvUczEO8YPyg5qMN504XPykc0AWrOWNMb+p HegMZHlIO30FVZSvlJj7wbFEsjRyqEb7wxQND4piJATkjpjFSNPujYKSpB5U1TW48kYII2nOalWV JLpum0rRsL1LBmUWquG5U4470yZs+WUbGepqmsiAyK/C9qQyn7IT15poC6XDNhvl9COhphlkjkxj 5PbpVVJCseVbPHKmhZ9oJGCO6mgC7ceW6q6jacc0sDlsbHDf7Jqglw0ZJVchuxpjXCtICFMbZ7Gg djttoXDK3zEDIP0qRXFwSJFxjpUVy8jSqFTBwMj8KjZt/wAoDK3rTJLKMzMUlGV7Gh/3A39QehFQ qC/yvLhfemfOGCq29KAWpZiPmHc3zD0p0hZQBHhkPUHtSoqqm+HHHVabGS2ZOFYfw0ASq3lp8nzD uvenIPKUyJyD1HpUSL5j78bW9D3p0jHbhflbPIoAkBFw4ZOMCnYVs5O1x3xVcbT/AKr/AFg5IqTJ myJflPbFACrPskKnk9M0rRGQ537Se1NYLGNr/N7ihC2cN07GkMXySB8/XqMUruVC55HrThODmM8+ 5qJEbc+TlR2oESKyvOMcoRnNS4IbaTlaqQc7uxB4+lXj88Ssp5HWgGKJBGMDkVC8RLliRg8ilbbC QV5zUhiDDceD160AM371BjGCOvFSr5bj5j81RpIFYbOQetNZEik5J554oAmYgkDG30NIu3O1uSO9 ABIww+Xrmo3ZkbK4weDQBJk4yvTPWpIyJQc9fcVGG2xbgc+1Ism1sqOtMBUYq5BJPbFPjO4njDUq lZYywxkUka7l54NIA5ZsH7w71Oqsy4/E02MZZgcbh+tJlhLnP3R0pgSb2B2PzxShiq9Mg0ine+H/ AEp527QBjPfNIBMclkbj0qVjuKkcuBjjoah4Eg25GRTz85X+FgO3egCUHdweCBwKVCTyeO1NBBXa c7s/epwOyPDZJBoAk2FWbnnjBo3Nuzxn1qMASPnLKCMYNO+UkEEjt0oAlIYjawG361Jg7wAflA54 qLAO9WJ+vepC4ACgnpSAUhUJcDk4pQfmxj6mogC+cseDkf4U8uisFPBY/nQA/oc9qRSSxzShgDtP HpTW4OcE0CHsdozjNHNM8wjqjH6c08HIz/OgAZtozRzxQetBPI4oAWijvSEgED1oAWkOccUtNCne TuOPSgBw96Rm2jPUe1GaQcL1z70ANBxjBBz0pCcyY459+aCQCM4H1pvcFjyP1oGOBK4XOT61CWUA nHfFPeQBckgA9BVcsdp4x05PWgCUqC55G4cg02U7kJA+lNz5UoZgfSgsPLx2PTFAxuWUKCMADj3N NldW4PQink/Lu7jqKikG4Z6LQA0na+B0HNM3gphuDnHNIm7cOT/jShSQ2cdfyoAcrBJ0UKckE57D FMdjvIIp7fKoOce1MDfvCT1IoAQNuhwpwOppu4KF56j9afFgBqj2kjcexoEI/wAsbDuDzTYwGTcw IOchqJATwmctyfSpI3CwhX6D1pgVNnUKNwB5zSoZsnaR6nNTGFidysT7VBJvUfN96gBFm+chiQRU okhAzksTUG8hP3kR+tNCHG0/KW75oAssNy/IoHoabtC8tJ+FRFJCTliDTdrIMSAHPcUASNcxr8qK S3ao3luDj5SEPcUgKxj5V4JpUn38IDu9DSGWElUxELncOuaru6SJ8w2NnqO9TK8abnK4PtVeV/MO I4zj+8aAHqTEvzgFM/eB6U9mLD93hl9+tVlxGFBYNntTztZw8b7G7jsaBEnljduHOKY8ilSGHI6Y pnncbXzG2OT61BvIQnazEnAIFAy2XMVsPM6H0rH8RQvNp6mzgV7lT8p71flaUhY5MZouEIkjb7oH apaTVhp2PHNf02+ubofaIZ1fvhf/AK1ZUFibe4/eRzOynOJAuP5V7rFEkt48jqOBxkVDLZWshlJh Ri3T5aydFNWL9rI8nfXb824hitYI1B4YruP+FdJ4NjdkcPkuxJZvUmupn0q1gtlItosk5PyjNT21 vFFLv2qpA7DFVCmo7Eym5bk8GYIGDcgnGaeGM9zx8qqOOepqN5dyoiHqTziqc0rJeMu4AKOSK1JN C6kITY6/OOhqB2li2AqCf4TUUV6rcTfN2HrTpY2dFZZOnQUBYYs0ksx2gcdRnrUlw6+UVRDG59eh qNNqg+YhDf3hURlYyfMC46DFAE8k5SEQuCAe4FNMz2K8ESI3NQysN6ljv9s9KMGZMx7ic8g0ASIq STAjkuM49KcIjFIwlbJHKnNQBgONu2Veg9am3G5jBc4deStAhHxeSHJIKjFJbzebm3P3c96qi7YT MwXjocU6WDy2EwJJznihjJyNjuitgLyKrrIZGXzuVz1FMWdpJJMjA649DTVzsBP3c9KLhYvXbR+S BDgn1qishSL52zznHpTFy8jFOw6CnGBHtlL5J3dRQBIJ0mz5TeXxznvUcc5kIQqOuM0kqxiUKozk VTjZkyTnAbpQBdKyDfHGTt6gGovMeOPDAmnJfoEfjDU37arQjfGDmgB0dwBDlGKt6E8U+R45YyGG x8fgapkRPFuV+h6Gh3DQHY2SByDQgLLonlxknnpuFNwEnkBOSV6+tQLcobUKT8wNOZwLuM9mSgAM hwjdlNTW8pMzr0B6VTLD5hnoaWOXFyBng0MCYAb5I2PI5xTJJ9scb4ztOMGm71W8YZySOlVpW+Zk yODkUDJnk2yF2x8y1HE4XYdwzmopJN5j6ccGonACNg4IagC4WLrL/s8ioi5fZJnBBxVYyupK9mFS o2LUexpAPldwZFbBB5ppBHlODjNJM4aQAdxUYkLquRkKaAuSMXSUjG7I6CqwmIZlJK1beULOr47V WcpvcsOvNMB8s6BE2D5vaoml3ODnDDrUBT5N4PANNGfM3McZ70AW2nBI2nkdqetzG7jzFwc9RVQy FByFdfUUscy7x0PsaLgegZmi+YSBnwOv0qeKSUcuik0xoSzjbGSMDkfShlKg/KRjuKq5A+WcE7Gi 9+KSDylHzKQTUC5bkbufWpg2F5cE/SgZJhWOYZOc85qclJBhsI2Ouar+dkgCNW9xShFf5pFIAoAl 8wKdh+8OjYqXbv4kOD2IqESRRjaxBB6Ggh8fMxMZ7igCR2EXy9+xFQyO7yhWGCOp9aFZYpSDllYc H0oVtqtn5lOcGkBNG4UkS4KnvSbihZT80Z5FVlkLW7RuOOmRTgXWLghwOOtMGToQjZ/5Zt0pyyeU xDc7uQRTNuIwV5XuvWmy54ZOg6gigCQkmVXRcbetWAXDYH3WHWq8C7R5inKnqKexblFz6g5oAfkR SGNuc9KkUmSMhjgr2qqGLnnllPNSITu81jle4FIBEcMzKBhe596mUr91xn0NRT7SN0YBBFNhMigM eQeMUwLYZtoz9ymSYVhjlT2pom5wnB9DTSCeQMn0oAlUmPnGVPWllChf9lv0qPfmMLnDE4xUv3VC P0NADUPlDGOPap2G6Dch+aoiCFKspx2NG5olwBxQBLESfnByR96nOxPPr0piEhSV4pWbHzg++2kA eYRIBtIPepvNDEbuD04phKsQpGGHY01hzg9u9AEjDAwScZ4wakTaWGelRI7Lk4/KnRsOq8+o9KAJ lcDhs1KuOQ3TvmqrSfOBjPvUqyjLHnJ9aAJzjAO4D1FNLsACuCx6ioWZSvAxnBxU0axBNuffr3oG Spl2UlMDsc0hbdIQpGR29fpSb1zsLcryCKdy6tscA4wDjvSAkJwFGCCfaiRFIAkI5PGaarMECvgs Bzj+dPAGwK3zdxmgQ8DACjnAqOTgEk/lQz/KSpz/AEpDIpHzDb9DQCGK5cjYNpzzUyk9G4NQu5jb Ix7Cm+d5i4IAFIdiztDDkn8DT803G5cZx9KNgA46+ppkigkk8cUtMUMoAbn1NPBz0oAKKKYzAcZx noaAF4Hy0yU/IQAc9sU8HJwSM/0qvNIyvwu705oGgVi2d3zN2xQS2N3GBxiljKqvHGetAOw/MBg8 0DGgxsyjbyOOabI3Zh82eB607I3EjHXANNZgHJYZHbvmgBrEuSXUdeme1JjDEKPlxwfSmk7wCMcd Tmms+1wRyO5oAUjCE9uce9RvgsmDkY6UjsWYgn6UwSfKvAHOKAHs+1+w9KTklwTmkmwrK4PbFG79 4wIxxQIa4BjAxmmtkSJj9acv+pbjv1NM3Hr2PWgBSCj5wQGz0pquAjA5pxyLlSfukU2Q4k2dutAE ayAOp5GfWlnljZguOvPFNmRlUHsOgqIBwrNwPTNMCRJNhIG7aOaHk3KMISD3qD7TN12jHSkF1I5x jA78UASNcupxtO0Y5PemGRpH3OCoHSm7l2ktIc/SmEO0g2tkehoAmNxk7cFh60rAhd6HdjqKj3oq 7SQrenrUQ3q24MAD69KAJVQytlW24/hNOMkacSLg9M1H5wJCADce4ocMqfMN4PekA1SdxZVYjPen swCjzJBGv90VCSdgXzCq5z+NRqYiQGy/f2phYc3Lf6OhLD+I08qq5Mr5f60jTOBjhV7AVXlVMkuj EHj6UMB0spdCHBKjo3vTEaREQA5TOaYd8UZbIeM9h2qUOhaMRkEkenSkMmeSJ5EYMM989qHImusA nAHXtUUkYW9UjG7HQUwEiZ9+VA6Ad6AJ4nH7wAZB4qqsuyI56E4yKfFPHHE4HLnnAqOV0Nsijgsa AJZXE0kSg5VfUdaZcyoGlB4OMAetRPmGdOcZGagmljaRpMEnsPSgZIm8mMM2B+VR4SWR0BKjPWpN slxGrDCAeveo1lihLLJ99u4oAmeJIhl13Z6OKql3Viy52g8Zp6SlSSG3KOxpr7bpvl+XA5FAib7f HMghPOeM0rbbQho2DAjp1zWWymJicc+gNKHZjuc9B0oAuM4mcsg2MByDSG9MbKiKB6kVULPKcdB6 1KssQTbIPxHWgZbkA2CZGBYdc1DJcAOskRye/pVYzlWMQOY26EUK6wSeUSSCMjNAE6MFfc2Nsg60 ecZVaHPToaqgM0hV2OeqihrrZ84A3DgigB1tIIVcMRznmlVnkCY4XPfvVJgXXzWIwxqcziIxDngZ oEWYNkRlyfWqvms8QwSF3U1G3rLK/HpUYfzBGvQZoGWZnxMir1xzUUS7U3E9W70s7LHMoBwMc1Ck w8tfTdQASFf3r8ZB4xSBsqyr6ZFU5ZynmYGQWqZX+4V6HigY0vhPmUg9itSwKu/DkkkcEVX3nyiv 9xqQTESJtHPrSE0WYwBHKrEcGmFyJITnOKi37JJMnJNQSTfLGRxg0wsW2f8AeSL2qNJR56HOBVRp 2Mzds01JT5qcA0mD2L1xOI7vdg4xVXzdkzEEkHtSXj4lUj0qFpssCRjIpgWFmTZ1+YGmSOWY7e4y BVceU6MGbDCmAvGwKsDkd6ALaXG5xuG0YxUgk/0d1HY1n/aVOA3BB704HmQK3B5pATNK6lDntinR zDyXDcHNUmmJ2E8bfSpTNHtYH60DLLzAvHzwOtRXUg8zGeCOtViAyKwbjNQybxJx849KYFvzmEOO CuaDLv27BniqcbFs/Nt/2af5kYPB2sPSgROCo53FT70plTI3rgk9RVRmYndIMr2NIjsz/L8wHY0D sesky7wsTgjA/lS4uN2XYH2FUWLxNyMcDofam+dM4IUMF9fWqINBrqRW2eXmoy/mH502+wqqszQk MSTn1qUXryNtGMepFFg9C0gt1+6zAmn+XK4wj4B9ahVghDMit9DSSS7gDhoxQArjygyNFuPXINMi uGLDcSI/7tIr7f3nmZI7Gnw4fcCRxyPegCWYxtHti6HqKjWQlQqg8dR6UrphjPF26gUiSAuJ14zw aEA44EyyJ90ffFO3LFcAYJQ803JjYzf8s368UqruiZTksOVPqKALERC3J+YbCOBS52SEHlX4FV1x LbbBxIvSpY285AOjoKAJ4wISUbOD0qOQyA4UY285oLmeIKDhlpWczQjIO4daTAVCsSrN1z1FSSAs wccRtxxVdSmSW6dMGniRs+SPun+LNMCWNlT923KnpSyQbRv3dOw71VI2uUOS3UGp0kIUGTJA/SgC UMJFAA2tUbMYTk/e9aikl3MCnA7GplYfcblvWkAp+fkjaQM/WnGRZtsZPzetRSo8T7i2R6CjIfDI CHHXFMC1lh+7bv0NObhdrcHsageYygA8MDTzIZV8tyA46UgHK7RNljkHvTi46qcjuCKi83CbHGcc ZoUjyzt5oAncBwGQ/N1/CnKS4AJ/OolbncvX0p7DzCCud2OlADljYEkHgUsajbzj5uM01DvQgZBH ampIxVoiNuTkigCwoOQvVWPUHmiNCXIZu5GcdqZuMagsvGKXeeCpySeaBk8W0MQ56cBsVIX2uAqA jHf1qtGQcEncPQ0qlvmRDlk9e9Ai0oDSsHXBb72O1LEzBdu0gA888ketQL5hIbeue4bvTwzyLkjy gO55zSGW+OACC3akBDxnGVbHQjoajQ7gMnkdcUiPtfJJI96AJCw27MZPeoYl2vyQQf5VMu7r1I6H NMdtj7uCOmMdaAHSSCPGBnHfHSq6zqS/7kgN3qSQ5XCHgDOD2FQZeRcjAXqSaQF6FyY/u9BwKmBy ucY9qoxNkfJuI7ntVncCMb856dqYmiTOc9aBxwBgdqgUiNiHfBHtUFtqEV+ZWt2IaFzG6uMc0roL Fv5udpOfelTgMCQSDShjwTwaaWA+ZcEg8gGmAblIEmCM8ZxzUdwCwGOKkckkAYxnnNQTMAcA5NAI RQNmSuWHHB60btw+fr2PSolZY85OQe4p+OB8wIJoGOVc4B+7ntUe8L8mOnApJZCikqCR049ahI3j O/BFADmYYbaoz0qFpAAMjkUKcggA5HqaGQbSckN6UAPb53Eh79qiZyAQR0NJuJGOgXue9IWJOcdV 4oEPILqMkcdPSk3YkDN3FMZtwAUfWmNKCycjA65oGSknyyoHamB8QEfhQxInA6gionySyc49qALE a+YocscioJmb7Su3tTw2+FtnATnk1VZiCpdsP9KYieeSTb0FQjz2UZUEAdKcEkkRSSAB3z1pAZVU gN3oGhSjhMsoye1NC3DDaMAEdaBFOeXkz7HpSESDhX7UCHG3IH3yuetRvCWU4YgjoQad5LMD5kmO PWonEeBGJM0DIwULYucZHQjvUhVyoCHMZppht0bLPziqv24xyERcjPQ0CLYQAAcAjrk1HcOy/LG2 R6USGNiryvjIzgUI4HIQH0NADI4jJncpIqQBI8K7BeOAO9MkkmaQjcEXFMLQRc7WdvU+tADifMyE QmkmYrGMkE/3c0b5pe4jUHnFVmngiyEyz/3j0zQAFwyH+Dj7p71GG/fKY1KdOvehZd+GnB6ZBAoM zEHaA6dN3pSGWhLGLwljl8dKhWV3kmc4A5qG2MZlckEnp1qMuyxTFw2O1AAjEIzIfXmmCcnYcH5e 9Czqlu4GDxkVMgxAD8uSM4NAEVxc+ZcgBTgjFIlvKVywVVNNALy72fGOhA4pkjuzYG76+tA/Imfc R5fmE4HQdqh2C3YsCJPbNM3yY2xDB6Ek0xo1gBLzgsaBE6j5t6kDjO00TXIkAQLsb+8OlVzMZ8Aj ao4yBUM90kQ8vh/9odqBotGZIlKyjccdRUKB5stjKe1QKxVRyGDdzStOUYLCxJ7rQBY81Y0IcZPb 1qMfMd7EeXnrSZRgzO2GAqo8kijk7Qe1IRJJMXfZARtzxUquWiYtzJGetVGj2w+ccgnoB3qJHO7I bgnoaBmhLMZVV0+8OtMJVcseQwpIWWNimRtYZzVaSUtuiHrTAe92vkeWnXNMjIkYF2PSh4VaNSOD 3FVvLkjlDfw0CLbF/K2g/LQZVBiA/h64qBphkDo3tUJLecXY4PY0DLskhkmLHG0Cq8k+FRU9fWoX mkd2x6daaSqsoBy2PypASuo2DOdxOc01ZAkXJ6GnEj5Rk5AzVcgC3LsSeelAEhcs0gU/KRuNI77E Qrx6moGfBznAx0qNmdoQScLmgZO1wBOxBLHHWoPNYMD/AA5pvmKJPk6Ypu4njHegC1JhpDz2qsz+ WUPvUkjYf/gNVpWLKmOeaALM86vIMelR+Yyuo6iq0pGVZPvdxR5jAoT0zQFiyBHLvBHI6VExeJlI OQexqJvmdyjYNHmn5QwJ96BDzIjqwcYbPSgqwb5CeR0qB/mZsHkHvQrskgJOOKBk0coxhxgg9ac+ wswXqRxVbzVZCjcEnrRuIdcHGBSAcfMSMEevek84qQWGD61C08itg8jPSnyTJIFIOPWmMleSMrnv UeAqhgd2e1RPsZRjK5pVjMYznigNCRS2OuAP4TTxIvCgbWPpUBm3cEceopwwvIO6gD0wxyFx5gYc D+VSiTHCK2fQ00iSRh+9CjAOD9Kd5rRDargk1ZmTRyx5Pmp+dSeZbynaq7fc1VzNsDSrkU8XCsuF i46dKBlwW0KruEvzdRzUUpmYhFywqqzQbc72DZqSJXdtyTAegzzQBKroiFXTDHvQEVWKo/z9qaZp N+JI9wXvUblSwdDtI5wT1oEWUEtv+6YjD0gVo2MBztbpSyM1xGr9SnpTk/0pd4OGWgB8W5Ua2kXI PANJyreXj5l/UVGJGnXcPvx/rRvaSMzL98cEe1AEzSYcTIBgcNQoMTeenIY5PNQowGAx+Vz8wNTs BADGT8jdKAZIp2ETpwhPNDvsfz1yVPWkQiOIwueD0NRCbycwOSdwxSYJBKpb97/ATzUkTCYbCQNv Q1DGPJYpJkqw4pksTowOcIeeKCmWFuYydhU7wcZNPR/LILncMYOO9VzuYqWjyB/EKnhQEb4j82ME E0xFkxJOnBAX0pqv5eUZeB0NQs+2JtqkEHB+tNDyB13jgdfSgROZDv4+ZMY+lKrCOYZbr0NMyGyY +voe9R4UuN3B64NAFuVlDggZwecUkpDESRKNuc49KhDhpA0bEN0K+tTOwbaV+VgOlAEkTpKuH4Ip I4yRjuvT3qMjhmHD1NA27AOT8v05pAPBIkyOCB2p2/LqQcYzUSk5bBz7UkS5yD17ZoAsYDc52E9K XcBneNpJxmoEYk7GPzVOGDYVxlTQA4SFVVWwyr0zTBL8w8sEU1cl2XJIB64p0Jj+Ysc59KBko3OS xwNx5qWPPmAMvI7+1RIQAFc5HofWlRymGGcKMZoESlldiOv+NPK4UHcQD27UwPvIZn+bnnFCzl12 ZAyQeeopDLKlQuckN29DTcqX5ZlJPqKjedowuDuPcUgZiwJwf9ntQBZVzgcDPfmh2DjG3jr7VCJi HyMY9MUpkdvk+UA0ANVl2Hj5ieM05QFTDkAZzlaYZljYgqwOeeO1G3zGDIzGMdQ3Y0DHRzNHKQh3 Rn9KnE2TnH51Cn7piWIIb05pqyBn2qQQx47CgROzOHBAzjsaijhhjuJJlj2vIPnPr9aeHIwflLDq QePzpWTduZt2D7UWQEi7hksQwb7oApQFXJ456gVTiBiTaASmeQTnFPDE9B1PYcUASyMD8zEDHoag QlwY+QSchiac+DkP1x09KYr4Tbxx0oASQKsWB17+9NhIK5XPHanNlsNtG7v7U1trEbSR7CgBC5ck A/L0/GmnaFO0LuPHP9KjMgVjkfMe/rTmZThsfP0FACsvAIPI61CrHfvOQB1pwdjIFLAEHnPcUmFU bwxK+mKBDnXdGrIQQx5qOQnzMgfMO/bFCyEtjjaelMmZYWG/hF70DEz8uHGDjrSogaFn29OM+lRs N75YZUdPalSYqCi/dJzj1NAh5IMgI7daaDi43HvUb4Y/IeRT/NTA3fKw9e9MCMS4mZNp2jqaZIVQ Byd2elLNOEX5FJZvQVBbvK5y6DBzgAUAToomiGwlV96HiMfR6heZVXC5UHr9aYuzh3lY9+e1Aycw zOM+aR6UjxmJSWlP51Xa4DHaHY+hHFM2IWw0jZoAkRPNJV5KULBHLsDZYDmq8ymMfun3ZqKOKWPE rEZIzj0oGXpIQVIABB9e9RNCgiAOxQvpTWvz93aGb0qNVW4bk+WfakIZNKiOBG5YemOKsw3SMQSu f6VFK0UC7HUMT3HWqjTBIy6v8gP3aYGjLcw/wLvOcZ9KqvcbWJYhfYCq4uWk+VPkGO3BqF5IouzS OT3FIZJLM0ikq/I4/CnpcRqip9n3di1VpHlaIgoAnpjt9aSKdsbUAJPUd6BF4pgBhID6LUDFj0+T jp601dgP39r+9Es7sQjoNv8AfFAAWSE7iSr+o71W+1mRXQnrTpdkf3CJAecE1DCib2kB/wCA0AJ+ 6WNiWPsakjmQqAA7HpSzTIy7Vjww9qWPeinEYGe9IY4ylB8sRB681B5k8zYZtq5qZ/PbhmAPfHaq +yKMfvJcnHOKYIkk8uEYaTPsKhijiuJDnoehpqmNn3FSfSlkunj+WNFB7UCLE3+iRnDArjpWOFLy FjjntVgy+aS88mR6Com/egKgwSaB7B5vdAAR70BgiFiTvbpinzosYWMYz1NMyDLluiCkIeN8pCEY buaQqQ4RzuwOtPWYRxFzyzdAKiJ8uJ5X+8elA7D2LTSgscRJ6VUkfMhcAbSeKV5WEQXbweuKqPOS 4A+6KALHmnADcYPFSTXAjKMo7VH5kRhww+c9M1EIJSC3UelACwXGWJfPPShp35WNt3sagYCX5R8h pjq8BO0kn1FAFkFc7mJD+hpDI2cOPlNVvMVsGQ596UOJCMt8vbNAwaUruK9CeopY50MhJps0kaIR GcetUzKv8I5oEarzxlSVPzY6VSNwPK2nr6VAz5Udj65oeTEYVQCe5xQMmMix7SfmJ7VGxdoy7H5c 9KgDhCM8nHanGUmPpQBPkeYMcDFIGRVc5Gc1TkmaQj5ugojCuCS3PpSAtPJufgcYqBjtAK889qcx JY7eMCoixTaQefSmATENhgcPnpQJcbQVzzTJ3WQqcY7EUzcEKhuntSAsFQxdgdvvTFmKBM5I9aag 3lgDgVGQ6FV6qKBkzMrs/bv9ahJbILfMp7CkZlVmBPUUzLIwK8imBKjocgjjPTvQ/UbSfpTTLG5G 9cH1FI3HKncKQWF3FWOe/rTRtL4Ix9aTkkFhkU8FX4HJ96LgLIgBAU035+gPXtUTK+WKnkUiiQqz FuB70AOEmMjo1JvZZB2pomUsAeDjBqZdjoR/EKQz1SSZJjhU2qAM/lSfuEXA3b/WoNytgIcDAGfw qQFIxxIGb3rQzsSoob70xA9M09d6/LHIMepqFFYkMwDD0phcu20QkCmIuKAg+ZVamvt5coUHtUUS RJnLsH65NTb5iQFAZByDQA4KyLuSXr2NHRf3ighuARUbzF22PHhR1IoUF3KKcqORmgCWPNvJtz8r dKmf/RGBQYDVEFNyhGfmT0qSJ/tIETn5loAZIGhKyqSQ3pTn+RldP9WeTSwsGDxSfw8CmwswVoX6 npSAcFVpCTjY3GakVvtHyMfmXoaiVfKBifoRxTFJg3EnDdRTAnVy0gj4LpQy+cTt++OtVyTIDNED u/ip0bDh0b5m+9SGizGAwKSfNIp49qkjHmMYpuvUUGEGLzEPz96YZftKAR/LID1oAmdltNu45Bpg QyMXhbb7VC6zNwW+cVB5rxvhc78800BfEyIpSXIY9/WmtGxXuU9aiSdCAZRuz3FS7JcqUP7s8jmg LCA7AEQZyevpT0JckSfTNCvC6kH5XFMDSJKrEcdBuHBoESuBFIhHORwR2qR+g38e4quDjiPLVJ5q ttSX8aQydWzEQ2TzwaIZShwPmUDk+lIF2xfITjnI7YqBHKglec9QaALZbLAjjnqKfG6SsMgcHtVa GRS24cK3YDoaF+Rn3HnPBpiLk6I2fLHzDkU2ByH+bDDurVGHdsbOGHXPel3fOGQ4Yde9ICaUiJkk RhwcYHcU0kCXIBC/Sm5Ej/OTgenrUuXdQCFZUGM98UAJ5ezDs+4HuD/Spg7LghhweDUe5IceYqvG eoPUVErMd3lt8o5+buPagC0GYHG0Hn+E1IqkNnaAOtVwytjbhSOM1IHmaLjG7uDQBMWVWAxtB701 SjOeQAO+ODTFLhckcjseamR1KqpQ89e2KQx8ciAHjcMc1GCpbcjbT2yaa8qgjKBucHK4p4aMjAVT x0/pQA0bVDGTDE4JJal82GHByBu67jmoZWjVsqp5/hYZFIpzlWjVR/dI4oAsM6umUj3H+9kjFQmN UbcTgH0oEjRMTg7TTJwZFzs2gnGQcg0AWAzKMqh2jqccVMJuc89Pwqmrl2MbdVx05qbd5Shd42N7 0ICTJYFjndnqTxTt5Kna3zenrUa5YlSePT1oyyc8Db27mmIQscgk/MD0HanEDA64P61GQWIcnGe1 N3MkhGcDrk+lIZKRtHU89TTMEg54HrTGk+baAcetMllPHBOPTvTAVsYIOMVGy9GU4Ye/NOyQ24kH jpQxR1wp+bnFIAg2vuMmBJ0C00ttYgjJAxz0FRvuhODnPXNRSXEauglZlL8ADvQBNvFuQwbGeAai aNJ1KTrv7qM9KQjHzyEZ6qOwpPNJAkC89KNwHyhoBvzkdStML7ZRgA7lz+FPlfB+blSPyqGRU3bk Y9PWgB4ibljx9aibDSZb5jntQ8qgfM+7IxgVGC6xfJHj3NMRI7OW2ooC57mozuRuo24o8olVZ3Kk nsahkMkGEGXBOcnmgfkPP7s5I3j1B4FV5GiYlvmA781JngCF+c8rVebeGTAAz2Ht1oCxNEISGydv HQinfZlkcfPtG3JJqq8wdhEI+hyalLCNVJhO3uc80hj3gG8IJB0pnlGQEGbC9KgaQKjN5bAnoaiW QKg+V274oAtm1iTnzwG7VUcqW2iTlurDtUOZJnzjAp8jIuEjiG4ccmgVixst05aTccY471EXtv8A nm21eoFR+Xj74H0NTSXEEaeWNpY9QKB2uCTwBCyxfpTHvDkBIhk1A1xnCLhfXAqIuqKT8xbtg0Cs TF551PmuEHYZ7VGfKR+GLsB2qMLLIM+UQD3p2ZIsIVXFACfOQdx4A/Go47hxkhuOhFS+RwHmmwDU cj2oXavJ7GgdhrTRbQQCCeMilVgWUFTgdGFVN6l9uNyjnjtUts8oY5UCPpzSAsS72lRQVIPO7NJL kMqGbJqBzH9oJDH8Ki3o0nIJ7ZoAsPLEPlDMxPWmh40/g3E9SaYsyCUCOIEAdajnuG5JKgdQKYEr TyuNsaBBUciKuWkmyx7Zqq108vyg4PTimnavEpO71oBDjgcDpnrUiTAuSvRRxUbS/uti4Ge9MlCw wKqnLHtSAmRvvTPy3QVEGL/IvUnk1CGYqFkBC9adHKql2A5HAoAnlKrJsXkr1qNm86UBiNq9qiWU KrSMfmPrUZZiuDxuPWgB08rO2U4HQVDuUkLtAI6n1psz8FV4296ZHtRcscnuO9MCw0TABm5A6e1J 9paM4B471A1wwcAZx6GmyShzt27W9aAJprmNgAo+Y96jE/lr86lh71WdmXA2gHuaaZXcAbgRSH5E sj+cD5ceKazlIwDGQexpVkKIMMAO1MaV3+YlSKBWGmZthLKD2GKb52V5TgVCpcvuBAX0p7sXPAAp DFL5BwOKYk5XIHOfWmMQfl3Yb2phbB2lc+9AEibdxckbvQ05rhl+VB1quTtGScim+eNuMfjQFiQ4 z6P6U9QuMvlSKrrKFPzfNila6VxtAOKBk4uQrnPJ6VGrh3+bioPOWNTgE/Wmtc+Zw64FAWLEjFyE HOe9MkPlFQ3NReaVwUO4DtTJJg7gk4PvQOxOjs0hKnA64pXnYt3qAS88j8acZAAQSD/OlcCQMkqs SeaQFlTP3lqpvwW2kgetBuGwqrn60AWTKpPyj8DSBSOjYPoagEgZG7MO9IJmUDcM5oAupOU++nPr UE043HaPxFVzc5GDyKRnXblT17UDLHmHqGzkVGJjyvSqu85JB6Uv2jg8c0XFYt/KVDZpFchww4Gc GqSv5hPOBT9xUgZOKBntrGJFC7M8DP5VVZYi+5VOKY6tMxkaTAwDwfanJduqbQAB6kVoYolQwNwW Kn61IFI5imFRMryL/q1J7EU1XC8SREY7imBOHd8hgrH6UrOYxhoyB7VF+6bGGZc0hlkUgbw6j1pA h5kURkh8MT0NJ5jpgAktntUbbpC2FHHpTYXKNvZSGFCAufaVjCyIfm6MKUzFCJU6t1qGXaZAOMOM 1CXVJfLdsKehoGi87B0V4yN4+9ipc/aNsiY3IKz4WeF89c9DVqJjDiRDwevtTsIcZnnkEZGCOaVz 9qUICA69feq8s2bndH97HUUuREFmjPzN2JpDROG+y4AwVPapRF5JWZBlTyRUSYC+YxDK3X2oS4dF bgtF0BFMRKskgl3MxEbU653QsHh/i9KiEispTOc9Ae1Iri2JjcZz0PWkMkilM45ba4680x5pI2Ix kdjUCq6ylmbard6teYsKBXG5emaAHLEjRh0fJH3kNOFywwIzjHG01XMRZfNiOFHvUgKXMQULtYHn ii4IRnWYfM2JB2FTh5doE44HQVEYxbDDruHY9xThM8ijgNH3J60ASkhVDxfMCe1REmSXEny+mKcX S1XcpJBPI9aQOL3KYIAOQ3SgBVlaN/LyR6c96ntmUysXPOe9RqSFEc33hwDinrgsgfuuNwoAlJ8u U8ZRumB0p2Ng/eMM9sjtUccoUtHJyT096fIuQEJ+Xr70AAlV5AVG3A5wetWEmEa+YhA4ww9qrKS7 7BjI6H1pqMIvl5znBFAEu4yIXXIB605JcAKeQe9ISzEOMhehHrSHEY4Xg8gmgCwyLgRyBgQc5J60 gJ+ZU5XrkdqTcsh2ncvcZOaYQ/mEx8cYPNAidFViSG+YdR603bIZmG4pjjaaaIw6lw/zEcg8YoHm YzJKcjgALn9aBk+ZyxBGB61LDNMB1z2NVRLJu4mG3HQjnNSrO+T6jvQBaRnO7IGewNAeRSFaNeeh NQm7Y8bEx6gUn2htm88A+vFAEkmc7cDOcU1GkJwcnscCmeaG+b+ZpCwLbt2PcHFICzgFNpUOx45N QbCrEMrBB7UhLdRJ+BqQbtg3MTn0PH5UARdHJRhx696erOVJIzjg5HFJuVhhRk/SmRSiNjuHP+ea AJw0hUEYGOg9KZ/q1B80t65/rSNIf9Yoxg+lRMqsxOcnvQBcVtwwOVI6moJnZQAeMHjioGkkyqhl PYAE/KKeJNyFWySO1AE58uWJV3YJHNMbK/6vnnnNQqqFm8xipI+XHb60ZeIbV+YH170AIXYZ3Ngf wgD9SacZwQBwGPTiqrTBwY9mcevNLtYBNpBA68/dH+NAMnkdkALfMT29Kj8sSOX25IpgcqpK8gep pyyx7cA4b9KAGrI6SnaPlA7/ANKb5pw5VQAMcE9ak8xDw3y9s5qOVEkKlWz9O5oAiLSeVguBn1Oa YDHEhDSFiTkkdqklCTYL7VA4wB3qN5EJCLEWVe9Axm9pSQicA4yaVnkR8SNlKe3ntyq7B05pPLjj GZWBx60CIzMx3KPurTUc535GAOQTUizRPhUTC+tQXFzCHCkZC+lA9hQsbMXyYz1C9jUSKu4vIpBx kEUqlJyy8jAyD6VFLciJBE2HU9aBCRqGkLhjt9aJWTeFEuD6jrTGnEERWNsgnOD0FV1uQEJKDcaB osZR5AonJHcmnyRwqOJjmq8MgGd0YNNklRyo8vAzyKBE0UUW12eTqODSBbRcEykn9aiN1DgIEGc5 INVriWJm3hMDv70DLDNGzkKx29ck0kLW4JYnOPXvUBuoUj+WMbugqNJTIQAFA96Qy9JeRvlY4eR3 xURlEZyYTnsarvdND8ocEngegqJ5pZPmc5HtQIuefcy8AAJ/OoJUkxgzcnpUEjyuqrHuPrUKxyby w7eppgjSSyLp+9fIAqtJNbW+5Vj3EdM0g+0yjaH2r65qN4EjGGcEn1pARrOwVmAAJ4wKdh1jBkYl SOtDTW0YCjmlkY3KqEb5fTNACqoWLcig565qNN5LPuVR0pxEdvGVL/Me1R5t0iOWJJHNADFceYSZ CfpUUu2WQoik+9OFxHFHny8+5qATyuSVAVaAFdTbj5hyajWXectyvpSOVHMkm5vSoHcH7hoCxZln 3uqxcY9ajL/ON5x71XaRiMHA96QqcB2+cUDLRlbBG4MtRSOuxVi6k81FGCSShwPSkLKhOeHHSgLE rN8yq549aJJRITt4VehqGSU7SZOnQGmNIQihR8vUmgRMxOAvXPJpLiMjacYGO1Na5WMA8HFQyXrS fdU496QxT95Tk7fWmSMpYEEsfWmF5JPl42ikYkLkuB7UwsMlZgRgEr3poJklMcRWIKhkllflY0Hf Hc+g9j6UhbPG4YpUAGl3rgj95PHET/sjaf6n8658TUlCn7u7aX3s6cJSjUqe/sk39yuKgimZI4p7 lZX4jN1GoSQ+nHK596ge5JG0Qt5m/wAvys87842/nUM8xUeYCS0ZDj6g5/pVnV/9H1ad0ZlfKyIU 4IO3H9P1rFOdKr7NSvdO1+6/TU2ahWpe05bOLV7dn+oriGJ2innuJZV4cWqLsRvTLck/54qOQmJY 3WTz4Js+XKF2nI6qw7Ef0PpVeyivLnetvbtIy4ZizgcsTyc/Q0+7lSziTTWfzLoTefOUBCplcBRn rxjn2NQpOFSMFNyl1Xl38i3GM6UpuCjFbPrft5+Y85A4GfemJOVyCv1qIy4HUimSXEeB13e1d559 iw8i8H5txOAqgkk+gFSzWk0VlNczypFLEUJt1wzAMQPnPYnngeneswzsGUpI8bg5DKcEfQ1ZtNo0 jVj1z5BJJySd56nua5cQ6is4uyuvV6pHVho0ndSV3Z+ismyIzBCWY/KBkmrbJBbLE9/JMksq70tr dAWVexcnv7fzrNgX7RdwQ8bXlRTn0LAVb1qdzrt2e4IUc9AFH/1/zpVZSlUjSTtdNu3y/wAyqMYx pSrNXaaSvtrf/IdcoIoIrqGQ3FrKxVXZdrow/hYfh1/+tVbzBJ/s/WrdkXn0HVonwNhSYH37/wDo H61kfaMHb1HrVYecvehJ3cX+G6FiIRtGpFWUl+OzLhkMRwO9EatdTJDEuZ5G2oD0+p9gMn8KqiQA Zzn2pI7mWCZZ4JWikXIDDGeevWtpc3K+Xcwgo8y5tjVkGlWkjW819eO6HDzRxr5aHvxyTjv1qG9g k0668qR1cMoeOVRgOp7/AF/z3rOiEtxLHa267pZDtQH+Z9h1JrR8QzRi4isoWDpZwCEsf72P6YH6 1xx56daMOZyve9/z8tTtlyVKM5uKja1rfl56CRW0KWkd5qM8scU5PkwwKC8gH8RJ4A/+t606eCL7 J9uspnlto2CTJKoEkROMZxwRzS+KMx6jBbLgJDboqgdO/b8B+VJ4dzO+p2Z6TWhznsRwP/Qqz9pU 9l9Z5n3t0tf/AC6mvsqftvqvKu1+t7f59CKzge/mdEkWKKNTJLMw4jT19z/gfSpoodMv5Ba2d7dx 3JGImuUGyQgdOBkZplmTH4P1GdcbppkjPrgbf8T+dZEdwYZo5gPnjdXHOOQQa0fPWlPlk1y6K3pf Ux9yhGHNFPm1d+17adti0riO5EN2XhCuVlKLuZcdeO/NXCmiuAf7Rvse1sP8Kb4oi8nxBORjEiq+ B9Mf0rJgjkup4reA4klcIuegJ7/1pxbrU41OZx06W/VCmvYVJUlFPXrf9GbF7Z2kGmwXtreTSiaQ oqyxhSQM5PrwRWcMEcvVvxBcRrfpZ2/FvZRiFBnqf4j9eg/CskzBzgdavDOTpqUne+uvbp+BGLUF VcYq1tNO/X8S4WAGCefWgyMvX5gKqFnUeooE5XGK6LnNY9siZY5d3LDGMfhVkkzrtjAUepqFZ1Z9 qoF+UVG5aM7g/HoK6PU5yYrJbHmUmpFupCpAw57L3qv9oWRdpU9O9RoIllJV2UmkMurcPGcyQfLj nHal32sy+Yh4PUVF50iptLAjsSKiS3aJWO3duOSRQBbCbELxOCMdBUkTPLHlsH+dZykqSVYr6qe9 WYvmaML174oAeJQC6SDp0NDRq0W08uOdwphbIlD9c1HHKUjZh09aQIlVGLIMnPY1MJgQUTlgfnAF QRO8syquVGOT3pwUxM7RE57incHuWbdoxOcAnNE8Ygbe4+Vjn6VBay+VJuZeCasXUouJIxg7M0MB UfzX+XPl9DS3AMJIhOR6Z6VWBMcpSJhipAxB+fiTHTsaAHkqmC/3iM5p8TfNmbDL2PpRFICc3C8d qR41dT5ZytFwHM4k+Vj8vUU6LfEFZxuqqo83IyQE7GrEcr+UQeUFAEioXbzI2+QnlaezQsMKNsma iZiiYhb5W+8tKZ4dmD8r0DBpWjwsobGM5JpGlBUNAePSkPmNH+8+6ehFRqzRyGSPALDBGOPSgRZj Al4A2+u41IN0MmzgKR1FAEP2dVGN+OKSPdCCswznoSaAJhIG3JI/I6GkWUN+6xk9jVdsE/PwOxp4 zKRhdrL39RQBZgI3hHBDDgnrinMfOEiFvnUna3TIqDKhSyE7x1x3ociQ+Zu4HY96AJI5jLiMDDD+ LNOO1mMpI35wwFVWPm4khBXBwanjYBS6gGTuPWgCxE2X2A7kY/lU28LujcZz0b0qgrtJNtxtHoO1 SCZIm2SkfnQBI48oqGcnH3S3H61LGxbayvkHG4DqKhL+dEcDCA8c5pY/J2I8b4YH5gRwaAJ+DkSN hueadv5CbgF9SMioM5ys5+Vu4HanREIQifMvTmkAh3s3mx5IHXHOKnjljCtuj+bs2ehpf3bNuQJF nhgnAP4VA0ikHhlI9RTAe13HtZWjY7RkhetLHcxuwjkVwwGcdqYp2IR1yOD705XQIA8ZJHIwcc0h lhJItxGAfY96kN0jAr99RwVcVASWJdYsKTnBNKbpjkld7YxhueKYh6SAEhECgcccj9aTzETdHlSo 71XGBt4YkcAYp5uzlAVHy9BjpQBZjIVcq+Dnlf8ACo5ApfdvI9eKSWdiBKI0Qd8d/wAKrNNvIUIS rnBOOlJjJDcJ8yZwBwPekjwwAZt2f4V5I/CoZY1j25YFc5wTzmneXsUMlxEWPZc5FAiw5SJW5OfQ 8YNNiuN+VCAAc5PWoRI8Ryyq+Octg1GlxvRiSOuCVGKYFna5IyNw/wA80edJEyqsZdj/AAEc1Ery qMoN47hhimrcBskKFYjn1pDJzIGGM7DnkHiojGSRlxGP7wGT+VRttZ/3jAZ5460OZFYlPmi+vNAh rtmQ7lYxL/F3NDlAE3oWHUqvXHXmgSKQShxj+E00EDe4bbI3GaYDRfsMpGOnr70sKKCJWlIxyAKj KlGwUJPb3o2qo/eLtbsAeKQyZ5IlfjOR+f1pVlRRiNSSepPrVVHWOYGZd3vTznBkD7UPBxQAs105 zlhnuB2qvIVODkn6mpPMjQfKhbjkmot0lwT8oVexoAAg27Wk259Ka5UqYo0ySPvetBENum5n3seM Z6VGjPLlYgFGOSe1ICXymgXcp3Y6imwyRu5LgB+/HSoXjnQ5Vt2OuKZJIkybMbG7npmgAkmgaQ7o jgdMdKY/ks4ITCimTEwJtZd47GmQzsgGMEH1pgW5Ht1AJVgcVXBhEZdt249M0sl3GXCupAXk8cU1 7yGQgKOB7daQWGobdhlyemM1WkeHcDklccCpJrmELtVBzUUk0KrtCfMaBoSLyXf5s4FPd4dyhVbj qaaLqONCAgx1z70wXMYDMV56igBpkiVvuE55JpWuN4G2I7RVb7QXJYqMH1oLTT8J8uPTigGWPtcg +VIwD0pojmLEu6gfWqg3LMEkYjFOk+Q5DFh7UCLLFQrF5x+FU3lQudoLAcEmmMkciglsPnpT1YQx 7ZEGD3oAEByzgAoeopnnFZAyZHPSnEFV3xn6iodpPzMwU/SgGTST+acmPkdTTZZPl+6oyeBUIIJ3 M5PtUTZdzsUnFAEssw2ct+AquxdhjHHrTJC4cYwD6UFgBgvzjoelACNhjtLYpjE52kY9xTlUZy68 e1DDDALyB2NAwYsqjHI9KYxAUYYhuwNI7B3+UlT6VC8q+aRJzjuKQyx5gICkYPqKY8wiIDEPVczk n5AxWmNKqMCFJPvTAe8hYjBJUHpSi4JfaiGo2dmO8LtwOlRCZy/ysB70rhYmZW6swBpojPV5MCoH faTnLe5qBmkcjsPrQBaeVFOFck+1RMyZLspP1NQ/c/iFQyTAr980DRa+0fJhEGakgcyaTqMK/wCs iZLgL7cZ/RTVASpt75PXFPW4e2mS4t2MUq8A9QQeoI7iufEU3UhaO6s18nc6MNVVKpeWzun89AQm eSO3By0zhBt7g9T+WTVzUJHu9dljgKMzOIk3MFGQvIz9ciq41F4wz2tjZ2szggzRISwz1256VnnJ A25Xachgx3A5znPrnmslGpUn7SS5bJpddX1NXOlTp+zi+a7TfTRdCVwXldZVCyRsUYZ5Ug+tXZ5D ceHorqeQvNDcmKKVhlnXHIz3xzz/ALNV21XzmzeabZ3U2MGVlKMwHriqt5fzXrRrII0SNcRwxLtR PoPWpcatSUeaNmne91+HXXzLjKlSjLlldNWtZ/j008hzSu235gRSs5Tg4qidxQg8VJLKru0ixpFu OdkYIVfYZNdd3c4rK1x5cnJwM1essjQ9YJPP7j/0M1ll8gY60+O9mhtbm2Cp5dxs3kg5G05GKzrR c42Xdfg0zSjNQld9n+KaHQXHkTRzZIMTq5I54BBq/wCIYxFrkz7htmVZUPXcCMZH4g1j+YOgWr0G rmO1S1urW3vbeL/VCcHdH7A+lZ1YzVRVYK9rq3r/AMMa0ZwdN0pu17O/mv8Ahy7ZHyfDOoTs2PtU qwIf7wHXH5t+VY8gTICHmpb3VJdQaMSKkcMYxHDEuEQew9feqZkUHgc+tOhCUeaU95O/+SCvOMuW ENoq36tkjts69aSJZru4SCGNpJnOERe/+A96jluFkK4hjj2oFIQEbiP4jk9TVjTtSm0y7+1wJGz7 Cu1wcYOPT6Vc5T5G4rUygoc6Unp1Na4uoPDUD2ltKsuqyDE9wORCP7q/59z2Fc6Zi4YKSTyck5JP rWufErO7M+k6WWY5JMGST+dUr7UjfiM/Y7S2Mef9RHt3Zx1/KubDxqQfvx1e7uv6t2OrFSpzXuT0 Wys/6v3NfxLIJprK/Q7o7q3Ug/7Q5I/UfrTfD8nkWur6ix2iK38pW7bzzj89v51nWGtS21sbSa3g u7QncIZxwreqntRf6vLfW620cMNraRnKwQDCk+pPeo9lUVP2FtO9+l+3fp2NPbU3U+sX97tbra2/ br3L+mZufCmqWiktJEy3Cr6jjP1+6ayLKI3l9bWyc+dKq8Htnk/lmm2d/c6feJcW0myRQRyMhh3B HcVoN4lMMbvZaZZWdzICGnjXLDPXHpWjjVpyl7NX5td9na33ehmp0qkYe0duXTa91e/3+ovim6+0 a/c7HBWPbGMeoHI/MmpvDiraRXutSjclpGViBHDSN/8ArA/4FXNlieSSSeSSck1ek1WdtGh0sJGk CP5hZc7nPJ559/0FEqLVFUY7aJ+nX7xRxEXXdaXm169Pu/QrtKZGLOxZySWYnqT1pMgDORmoCT1P WjPHArrOO99WWFnYDnkUpZX6cVBkjqfwpC2SMcUhnvjiBhuQktgdPpUSF2kIYY9M02VxE2bcZGBT DPJKMZAb2rpOYuGJgm4DLdgKZ53OJIMMO4qtHM8B+9k/yqyJpJVwVBoAXzIm+VwVo27R+7m/A0w3 Bj4li+X1xTBLFnnIBoAkeR9m0jJI60QyN5gONpUdPWopVG0NHJkUwTE7uOcY3Urgi1JcK1vtAy5N MgV3GW4Hb0qNk2qnUFqtROSioAc7utAyYKVuMIcHFTWgCJJI2CagVxG7t1OKIATC8jnj0oAQtvV3 JwN3Sp2ffLGijjHJFVfmkhwAACe9T+YkciqOSF5pgG+IbkbIfPBqTYUGZiWXHDDtUflD7OZX+8en HSoRPJnaDuQdRQItGQngfNH6+lKMH5oGOF6qe/0qBW3E+TwMcinKdx2odrAdKAJzJHK2wfK/c011 MPGTntz1oDxEASqVf2701MlgJ8kdj6UALFu3Eg7Wx0PSnbo52CE7XB6ikkbbwDkE8Edqrxv5TEMM k96NwNH7QYYzG43DHFQRkwozqSwY9PSk5jUM/wA6Go4WZWJQZUngMaALUapKhZG2vnv2pfMlYiOQ ZXs1VhGWk67Fbv71ZWZ4Y9p+YDvQBJlNpjOSe2aZuYZUNiQGqhldm3N69RQ8/mL82RngkUDNEEIw dMMzdaN3kt5rYKsMEEVTjJhh3AblPB9akt9sybGYYHAUigROZwHKRcqefanmPyCsw5Wo4TFFMY3G QQcYODRG0jZilc+V2NAEr3UZkBjXDEfM2eabMyhxJIC+7+JarPGon2kfKf4hSwSmNwG5APIPSgET lwQ3lNlSOV6EGmW106xjIw4ODx1qaTyWkHlrtJHbmkZU6NHyeAVpDJ0u1n+SQY9QDUroUkBgJAx3 qi/+rVQq7QeHC/N9CaeHkiYbXLDOOtAaFgSRZyxG/wDLmkUxzO3nMy8cAHAz60krC4jBZlVx8rEr g8etQs7IPLIDrnqOOKALweMjaNxHGCTU0aWm0+czH0aNsFaomaOBiixkZxyTSCWPJym3HBKt196A sW13SP5ayY7AnjNLuwcGRdyjGMVXEqsoIi3++aUS7cKIeWoAlUsrliSFPY9D9KZgydGEe091zuod hsBER8wdSWyD+FCuCuJExjkHNMRMNi4JJLDvmmTTOoIUgnPpmmsckYEaAfhmmOxjYrGgJODkcigA UOd26Nvl/wA805LtUUqchiMEqP60xpG83fJIdvpmo5pFK/KQmed2etIZY86cIMIpj69Oaq8PMREp WRiMDNMBdAWjkZwR90HP6U5nLeWhiMc4/vcE/WgaJGkZJCjOSw7H1pxMrDzDAQgO0Mvr9KrxsCT5 vAz97NSAEqGhfev1oAeJDglwMevpTEWUp50Tg/7OagMirwQ6N3B6UkDvtbbz6gHoKALBkjmByRG3 rnrULkAhS2cDqKiMkUjHKFccc9ajMboCwjYqT97tQIuC6VsAgFBSSSDbmP5+ckegqo7IqqG4PpUk TwBflYqwHc0XCw5sucrtROuG7VC8qRlcNuyOnpQ9ykh2ODj1HeoxNFEpAQkdQOuTSCzJDO7vkJ+d RSu2Msx9wDgUM85UvIRGrDABHNVmljX5QxcE5zQMk8xBg43Hrz2p7TsV5ITnqOlU3lySD8oPOBSk hhyxPHagC298VTapHpk1UZzv3Sck/dNRNu7tuU9DikM3OxRuHfFAixDOV3b0Dg45J6UspTbvib5j 2qDcoBMX3um01Bv2kuTtYdB60BuWPtSpGUlXk98VU3qpyCcdTxTjNG5AkQY9qgeUGQ+UMLnke1Ay QTwOSxU8e1LGYZWLMeO1V3lDsFWPB/nT33hAuxV+lACuIC+1SSo6+9DNAqhcE+lMVHRSTtx6k0m1 s7srjtQIeZIcgCMk0j3DKh2Jtqq08qyH8s4qKR2DDc5I9qB2JfPaT/WDAJ5NAJXBhO4VEY2lQlGy B2qIHyR1KsKAJyVkcA8MO9K8jL8jjctQiRWU7wQf71NUui5PzJQBMTuIMTcDqtI0qEYdfm6VChyS 8bYJPSmtMJHw/wApFAFx5IoY8hR9ap/bPLJPVfQVXd5C20DctMOxV6EGkBMP9Icur7TTZWMZwy9e 9QlvKUep7imeY0hyTkDsaBlgy+WnynPtUaSAuXJ2moJGQjKkg9xUMlwPL2nr60AWSGZi5OBUA2hi Sc1XaWThM5H1p77gAowM0MZJJN/d+X2qHzASGJ3H0pHZI+mWJ/SmhmVdwAFK4E29yMtwKrAoDnJY +maV3+XLPk+lQrKEHC80DsPzJL1+Ue9IQM8uTiq8krnJY0hcFMggE0gJSY1cb2z7VGzoZPlTNVd3 z55I9actywJKqKBk7ysW4TBpCZH5PQVWEzsSScU7eCMb6QWJSZM4DDFRvvXowzTCVA+/zUZdDyWO aQxzM8bZJyTTCzK244zUbsBzmkblM5oCw4zHPA61Hv6hqacqAQ1MLEHAOSetAEySgDgUrzkjHSq6 SGMkEU8kkZK0DQplKjANNySMlsUmQc5XBphOTgDilcBWbJABpCccBqF2+lMOC3Si4DvlC9SSaBJt GOtN3qD0pryDsKB3Hc/epDk8mmb22+1IWYjikBIX4x+tIDtHtUaH1pScUAP385pj4OKQNhTnrSHk igBT1xmkzyKXPWggHkflQAuQWwRmkYZ6HApO9HfmgBAcZyM0v3uelOYgrhaaE4oA92FwsBCt8wwO lQvkuTCMUbhIgwAAAOtRbxG33siuk5h0ZUOVl+8acHNuTzlTQUSYghQPenJGY22Ou5T3oAnU+cny uD7GoXZozsdQR2qGWJoDlOVJ/KpIo/O5MnSk9dgQwZ80bhhR2q2qL5IP8RNQsrQgksCOgNIhZWTO dvWgZPK5eVUPIA61PvC7BHyR1quo8+VgOB61IrLGG55xjNAiaMhYHdjzTkLNaEt93+dQAMLfJ7mn vKTbqg47UDHmTCRIM5zT12iSRickCovkEqZ6KKgw0heUMAM8CmBckYy26jJVTUG1llIiJwOvvStO JYo0Py4pTklhGQMdTQA5GEp2xjYw6571LvUfIfllHQ+tQO4RQrgbj6U6Mhj++U+oY0CJBkkecvzd jUjSPEMH5lP6VXuHKsq53D19KVX8oE53qR0oAnACJ5iEtng1WZsszY4HQUo+X94hxn+GmlvNkBYf N3FAFiPeFV0IIx0NR+YZJRk7aYpEuVRimD0ofdHtDmgCyXMajfyD0I606Nzxk79x/IVUEjbwQ2UP H0qZML86Hp94UAaUccSxk9VNZ7hJJCqcAevFCSb2yh2+3rU48qTAbhqAI42aJyQCB780+W4XAaPh h1pCkkLb2JIzxjmoTIrhvM4OetFxEplSRg3HmfTmhJGDlmbjuKrqVXaSeM8GrJKr12upoKJJLlZQ NpHpmpJ1BhR8jcvX3qgWLY2LhfXFW2C7U5PI5oETo3EW0EDpmlnT9+VLHaOciqqM6IG3NjODxyKk meXeN3Ixxxg0gL8aMY28qTcjclG71HudSchV/wBkd6qxylI+CwOR/wDXqybhZF2ygjHQ0xil/M6A iUnHTrQZ1BZXjxIBtJOQR7VAbhDhSwHo1Sm4RATL8+ecnvSCwCOTdvLDaB1z2qVZVB3KFJXnHrVa NhcMcA7O+DileOOJuH3j1A6UAWFmOMImGz60+S8kUZdSxPc8mq6Tr8uMH+lMuLjbIowSOxoAsp5s qBiTjPIxjiiRtgbaRgn8RUVvdCRdsjfKT19Klee0j4hDk55yQQf0pgKu3IIDMfU8U7e+3h8KOu3k iq7SyMvyhYx6YqEs24ZJJx6UgROqmV28pXlAPLHj86kwsSrhtxYchkHy+w9arCQocL0PB5xSPKsS MjTSKSPuIBnPvmiwXFkkfzQ8TsGHGQcVIsiSMRI2XPVyapEzN95GHHUU7dEqBGKtzkuBzQBc4RgA 2UPXApv7/hbaPYoGXZulQRai1uzxxCN8j5iVGcUPqDyLnlc8AUAI900h2OPm9SKIw8YVt6nPcGmb ZJRuUEe5NO+yMEYiQD+tDAjdcs5Y55+8O1CzIj43sR+WaQkgjLZPtUf+jsxJkGe9Ay40luF3FQPQ Dk1S/cMu4HHtURQxNvHzJ29qa5hf5g20j170gQ7LqN4AK1N9oTaCrbXHcVTmlLoFZcKPSmC3eQjZ 8vGfagLkrTSSOykEntzSESLHk4XPaoBcmFjGU3SZ60+QsF8yRx9KAI3L9GQkZ4NI0/lp5ceCTwfa mPPNImBwntSRSxxdjvoAUMzDLPsI/h6U8MqqBjY3rUMhO4NJg5GRtNRtK7nHVR29KAJmYlSzkAHo RTJJCwCsMqP4u1Rljtwpz7GmrlRjd9VpDJchU+VlYEdD2piOUBKkZ9DTHdWJw2zHao1kWWTJOMdD QJF2PypOH4f1NV5UbzeGO0d6ZPIw4PJPQimi4MQwfmoAaTmTYzHb60SoDgROTS4jkUsTyarMkkfK kigCc3KKoRhzUQRG+YP+BNMXbvHmDJ9abLbhhuR+OuM0ASpOInNMkmR2w5qp5jRDAyfrQOvPGexo AssBtwh3A9qR5BgKhw3pUagglkYZ9KruzGTJBB9aALUjDb02moy21cS/gag+0bsK3IHeiSQHAB3A 0APRnAZlOQelRPKzna3T1oaYRjg8DtRHMhUsR+FAxGG3JRs9qj3oqnPysKR3V2+Q7R6VBJJGgIb5 mPQUBYTfJMw4H1qNvkl+f5hTyziLj5RUW+MJ3ZjSHYUgvJmMYFIWPmfvG/Wmh3AGflXvUZePDNks e1K47EzuC2yNfzpsuSFDMBUCSOzcYGaUhfMy7ZxRcLWHM6jCrzmo3ZmbaFwaaZhuJReBUa73O5mp DsJMcEKzcU1iqjKqaD5Yfk5xUL3BBIAzQFhxaTaW6egphA2+jd6YX38EkU1pM/Lj8aQyR8gKCPxp HAVcjmoxJk89B0o3Z+YHj0oHYcoD9aayd+1IfmOQcVGeG2kkUCHn5QRwc01T8hXvSlVUct1pmw5y DxSuMBjyyW61Dzuzmnsev8qY7kgACgLC5Jb3pwkYnntUJPzAYqTcB2oYIVmbvimkk9CBTd2SSQcU jHGeKQx24g4zTGIHAPNJ07Un0HNAC8AE55pN64wRk008dqTr1FAhcnHHSnLyMj8qaAe1LkHjoaGM VsH6005A5p+No5GT60hA70rjGd6Bktml659KQA4JWmIdu45HejqeKTkYz2oVRtznBpAHU80OD3Io zjkjj1oOCc9aYCZxg077x44pnU0oypoBHsbF1OQSeBxUyPvABwKgExPUckCl2v1BArpOUm2NG2Qc irnnr5AHU1RSVMfOcmk3sjEqML70eQy0sw27HHFRuRCfkOR6CoHPmYO/n2oiDBuefrQBMGZ8EZOO xqdXLyYbgYqJAA2/pimLJlmfOBQBbhkKb9nI/lTlUNDuI5JqoCVgyDgMalaUrbqq9aBlq4YCGNM4 pjyjKKoOKgbdJKmDk4p7MI5ueSBSCxKv3pHY/hSodwUEFVzUCHKNITwTwKeHB2cYAFAFmdN7LtGA agM5jHl479aWacllC9QPyqOJlZwJD1PWhCZYSIMQ7PuXP5U1pWjZkX5hULu6uUQnYDz6U6KRN7be SRyKYCSS7Y8K3NLFI8QDsCR6VG0YKuejdhS2xfG4nI9KQF1QXXzVPT+GopZd2GwQehIqIu+792cD PIqw7xNEM9cUDHAoxBXrjg+9NcycK4yexNVMs2ChOenpVxZ1WIrJw2O9AgRWiYlWU98GpFIlY5AQ +naqTkHDZxzUouAU2sOvRhTAttL5YxjDU4SEfNIRk96rbxHGC2GHQnNMD9zkoelAF0yy7RuPHY0y cqy88Me9QSSKIh82VPUVGziQgj5RQBYVzuCYHHTIq0YNgRnUc9B2rNMpRRjJz3qdbmTyQR8wFIr0 LUpSNmUZHHApu9nRSWxt6VC1yx2luQaI5AFdXzkHIIoEWI3cI4C+9S+cXWMkMOMEGq6XCiTJbgjp SrcKFIOeDkUwLSOWQjcvynjccZpZpF3JnAPQ4Paq6yK29eCDSHBhViDwaQtBJIwZNkY496RUYDnk nt6VLLFgiWJmORyDSFY3cbGIyOhPNA7iRu8efKOfY1P9qcxjPD55GKqHdHwwII754qYygt+8Tbng 7e1ACNcITtGVcnr0zUyMNuJMHjqTTJliKhVlWZezbdpFRqgU4fLLQMmUFn3RlUQnk44p0jMjYiCk juOhqDyyBmJjnGCM9acGZSCowwGCKALCiGU5nkIwONtMadR8kUYz0y3NQGSGTIf5T2OcYoZ4dgAB OO+aAsTrC8+dzcr14qNlVX2Rg+aDjBIFRB3QEoCV7809iJ8KgWNx3bPPvQDJY7iXYVclc8HnqKgl hRRlW46n3qGcSIQpfINRlOC3m4+vT6UC3LYu0KjbErbRwFUD86dJdqwJWAqpPKk/1qJLqGM8fO3o KHulZSFjyxoCwhllc/L8gHTAqN5JhkPuIzwRSBp+vIPpTGknPDfLmlcY8SM33kOe2TSOqMqqML39 hUPlBicyflRJGYELq7PzyO1AWGzSSRLtDEqf4vao2EZUEPlvQdqZ5wkbG7GT900kiiBlYEMc9qAJ gm4Es5BHamfaWiJXJx2OKgeRmY7zjHUChGMihWwENAFgyxqCEIkduCcYqIKU5lOR2Heo3AilHk8/ WlYnaDJkGkBOrlwGPyr6YqGZ0xhRketRNMc/T1qBmZl+XjHegZLFKkcnzdPeiVlY5QgE+nNVljYg 78Z/vZoEu35IhuPrTEStuVcvtUfrUZ8yQ7VGFHO6jhVLStuY9qimmlYAIu1enFIBSil9mfm9qkJM IIdQVx2pkcqRrypB9TVd5Wx8jZXPNAWLCyBTuBzj1poImcsDjHaquS567eelNeZsgAYx6UDLLMTJ g8e9Oa4ONpG5fWq6tx+8OVpjkscRHjvQA6S5w+Bgg1GG3nhtvtTWKIeeG/nUTkEfMcZ9KAJ2cSEI eg7imyMA20HcKiB8teMMKiOGbJOMUAStIAAASDmnmby0wy5Haq+0sS+Sw9KiZ9zhTkY7UAWdishZ SM+lQDIcsSRzTJHdVG04J44pyTjG1xn3pDFkkBwrgHPemt+7Xchzx0pNuW3IfwqB2+fC8HP50XCw Z3vz8pNQFysnHzY70sjFm+fNIMwqWAyKGAplMn3mwPSm+anAQcioZAWUtnHtUSyAd/mpDLTEy4yc CoHdEBHUimlmPU49KY/lk4zzSKSHF3CZHHvSo8YQktzUDSP93OBUUhVcYOSeooAsmX5cIvXvTTkD 5mwKg88tgDgUjlmIH5k0gJAygdMmoJCWY4FPO0dyaYdxBOMCi4yIEb+akVigJxmomyvuaQEnAHWg ESABiTnFIQdwJpActg8UFyoweaVxg8gIwRzQOmW5zTNmcsDSb8HFIBxUkcHIqNnboOBTjJ/dNN3A 8N1oACPk600kgD1pAdp55z0ocenegBGzuB9KXeT1FIRgdeaaRjgGgLDjIT24FNMjHtSck4zQfQGg YhdyaTcaXHHWjaAetADSGx15pBkHmnH5erUmN3fmi4rD8k/SkPtSZI4pwIxweaQxA2PelAzz2o29 d1J9OlACnkfLTTkYpScYNGd5+lACE8HNLgbMUn8QB6UOuDkGgA5HHUUgPOcUg5BNOHAwaYhOrZFL zxxk0gXnigs1ID2BpPMA2gKMCmLIFOHJPvULwOoBDZ4FPSJCmWbmuo5iY4blf0pyljw2c+9QrOYz tRc474pzSSzDJXAoCxMIih5Ip2RHncxGarlwB1O6l+dx+8HFIew/zZNpHUGn/KsfuTUe5lXaBlaV EAbIOT6UwJpCW2KTgDtQ8gaVFGQKiXfJMSc4FCsTIR6dKQFtJP337sdBUbsSHck7jwKrozISUJ3G nrKAv7xTnNAFhSBGgPfqKdJJufYp46ZqnI5eUFM4xUiuJBzkEUwLXmxqxDdcdaHkyq8YXviqbByw 3IQvripnLBMJkr3pATu6hsISQw71EgMbAocsaYSSFKg49cU4MUA4PWgCWJ9kjeYOTTY3fc20Aj0p +N0671OCOlQOjxTlUJ56UAWHuEMZXbtemwuJk2v8p9agVS0h89Tn1xTgrKCETOOhoAsZ2Ky8cU5H SUAS8ehNVhw+X3YIpFZ3+RgdnrQIsR7XJTOR0+tKUCAqpIYdjUYAjJCZPpQse/c3O+gY5SwyxYA+ h70/LEE42+1Mjyf9YpwOM0BwCy4JHrQAoClNwJz3B6Uu9XiJBwwpqKWhYYxjpUQBVSCmfcUASF2f GeMdvWrEUp2lfLIIHIqvAPMRi2RtPBNTRvI0nHTH50AWRNH9nHqp9KdDOGmAA3b+xHWoY3Ch0bg/ SqwZywIUjBxkCgaLjpEZPl+RQ2CD/DSsiLkcEHnrUMgAzgMWprI5jV+QBwaALeAoQqevWkAcb1DZ qG33bGOzIX1HFDPNG4badpHpQBZjmuNg2ngdeKcs0bqxdWSTtgcVDHLISwQYxzika5DgLKrK30oA nFypHlyfnUwk8sAjBjrPAY5ypYetOMRCBlJKjrQBfURyKWjwWHbvTSUI5Uo+fXrVZI5CN8bfhR58 jZEkbiQHqBxQA/zHtmOBnPrzTXv2fgKA3uaUzKVCOoJPekwqrgRgj+8BzQAghZmDStkNyOanWOBX AiIBx0z/AI1DuDrxn8RVZ22yHYocn+8KALkk5t34Ab2phubiY/u9oB/MVRD3ETZdTz6jpS+Y7tne V+goAnYsGbdJ9Tmm/umwWYnHYUKkKryGY9896DcKpwsBGe5HBpAOJXho4sdsigSzqxP8I74qB7iT bgR+/tTftspXHljd244oGT/a5N2CwUdqGmDj/W5I7YqslvNINxHXqTSPbGPlWJJ9O1FwsOkCjILl Tn8qQStGcOPMT36VWmE8a/PllHtzUazMchSQvoe1AFmWZJCvlpjvUe7y2/vNTjEzAbUIz0JHWh4f s43HJpXFYRBht8w4PantIsvyxjAqt5jzEA5VfelnIjO2M5/2h0NAyV38gcfMfSq7zySEFgR7GhJH XllOD1z3ps04fhV/GgELkli0n3uwFNaQJ9489lFQhyTtQEt6ntQdsBLNl3PagLDyZJcFzsSkMnG2 HGP71RuXk+Z8gdloCkKNwKp6UASKoU5PztSO6p945bsKj3M/yRqQB3NRn92RkbmP6UAPO6U5cYXH HNNLqoIjXn1prbjnecegqMOSMBSAKBpCFeoclT1zQJfLHTcPWmPucHCkmkRjEcNz7UCJCFZSQ2Pa o2kZW+UbfekdVb5wcHsBTDM6qflz+FICyNsifP8AnVGVQHOCSKT7W+MMOM0hmZs7R8vvQMFVuqPn HanvIGG1hg1CAFG5SQx55p6k4/eJnPegEOLGFMo2R6U1HjkB3jn1qN0LnahPqaimcxrtcc+1AWJt hBJVs4qJpY8lTwe9Q5lEWR071EjL1bJoGTPNt4jzzSq6kfvOvvVTc+75RwKe8ylQHHzetJgPkByc HK0zedvHIHamAun3RuzQSuCQeaVxpDZQZcBcD1quwEfB5NPdye2D60wuMYIyfWgZG8r4OOQKiyWO QSKfJGw5HIqMP0XHPrQFhzSMVOfzqDccVM2QMDkU0qDjbx7UrjGqxQ7j0qRSZT1+WmjGCDTUYiTg HFJhYdJKFG1Rz61EXZzgdBUrgbtx6VGXbHyrj3ouNiBSTycUu5Ix8vJoCEDLmo2OeFFILD9wYEd6 j8wLwTxUbBw2KURjHzUAOaTBAXvUbsenenFSBk03lTuoAacoDkcmljGfmboKADI2T0FLnd/uihgk Jkk7j+FKxwOvJoAxyfwFM5Y5NJDA5IoD4xkc0pzjOOBSAgnJoAXcmPekAUnml2AnIprDj7tGgCna OlL8nUmmDI7Zpfk78GgAIUgk9e1Nz+FLwT3o27j6UBqKDmjGOlLjA4HNGCvJoARSS3NPLBR/Soy2 elKBjkjNIBp+YjFPUYIJpNzHhRQFOeTTAUld3FMz696f8i89aaX3nAGBQgG7scU7IA45oC8kAE0v 3R93mgOg3OB159KFyTzxQAW9KcAewoBH/9k ________________________________________________________________________________
Subject: Wig wag revisited
Date: Mar 11, 2007
Working on the wig wag system using the B+C flasher. What is going on inside that flasher? I set it up on the bench with a DPDT switch. one side powers the flasher , the other the right and left landing lights. the set up works as is, and the bench ohm meter read 4.5 Kohm between the two terminals. The switched side of the flasher sees 14 volts when the landing lights are on, but I don't think that can present a problem. Based on this I this I don't think I need to set up the steering diode bridge, but thinking is not the same as knowing. Also an unsolicited plug: I bought the Dynon installation kit over a year ago. This week when I actually wanted to use it, I found the D-sub crimper wouldn't retract two of the pins. A call to B+C sent a new one out. I was actually looking for advice, as the tool is over a year old, although never used, but they went out of there way to help. ( do you think Rotax is going to extend there warranty on the 912S even though it is still in the shipping box?) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=99955#99955 ________________________________________________________________________________
Date: Mar 11, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Wig wag revisited
> >Working on the wig wag system using the B+C flasher. > >What is going on inside that flasher? > >I set it up on the bench with a DPDT switch. one side powers the flasher >, the other the right and left landing lights. >the set up works as is, and the bench ohm meter read 4.5 Kohm between the >two terminals. > >The switched side of the flasher sees 14 volts when the landing lights are >on, but I don't think that can present a problem. Based on this I this I >don't think I need to set up the steering diode bridge, but thinking is >not the same as knowing. The proof of the pudding is the repeatable experiment. Give it a try and see what happens. The schematic on page 3.0 of the suite of drawings http://www.aeroelectric.com/PPS/Lighting/WigWag.pdf . . . was developed to have a single switch where down is OFF, mid is Wig-Wag and up is BOTH ON. If you don't mind full down not being an off position, then what you propose may be operationally fine. It would help if you would post a schematic. Bob . . . ________________________________________________________________________________
Date: Mar 11, 2007
Subject: Re: Tool help please
>Hi Bob, > >During the demolition of a nuclear plant a box of electrical tools were >being thrown away. I rescued the tools even though I did not know what >they were. I did recognize the terminal ends and knew to clear ones were >better (PIDG) than those at Wall-mart. Thanks to your web site I now know >one was an AMP T-head and how the terminal end is positioned. However I >do not know just exactly what the other tools are, I suspect one is used >on 10-12 size terminals, and how they are used. I also have some unknown >electrical connectors. Can some one tell me what these are and how they >are used. Pictures are attached. The blue tool is a universal 4-quadrant crimper for machined pins. The knob on the handle sets the crimp depth for various sizes of pins. You're mission the suite of positioners that hold the pin in the right location for applying the crimp. Each style of pin has its own positioner. The 59239 tool is for yellow PIDG terminals and splices for 10-12 AWG wire. The 59245 tool is for installing the center conductor pin of some coax connector. I don't recognize the parts in the other photo. Bob . . . ________________________________________________________________________________
Subject: Popped CB
Date: Mar 12, 2007
I started my 912ULS for the first time. Ran like a charm. However, at both starts the alt cb popped. I used the Z16 diagram. Obviously I have "crossed wires" some place--any ideas? Thanks Frank McD ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Putting things into perspective
Re: locations of electrowhizzies in the airplane . . . Let's consider some tidbits from recent comments about location. >All this talk about transponder "Antenna" locations >has me thinking about the location of the transponder >itself. Will my Becker 2 1/4" transponder (250watt) >be "polite" to the Trutrak autopilot sitting next to >it within 1/4"? Or should I locate a less critical >device in the hole right next to the transponder? >If so which device would likely get along in close >proximity with the transponder? >Voltmeter, electronic fuel gauge, electronic tach, electronic clock? . . . and >The Comant antenna folks in their installation instructions >specify a minimum of 36 inches IF possible. Further apart >IS better. But, closer will USUALLY work! In virtually every manufacturer's installation manuals, we find various and sundry recommendations to be considered if the owner wants optimum performance from the product. Batteries are accompanied with suggested maximum recharge currents, temperature compensated charging and float voltages, etc. Antennas, it's suggested, should be located no closer than n-inches to another antenna or conductive materials. Radio installations should be cooled and/or isolated from heat sources. Tires should be checked for inflation and held at such-and-such pressures, etc. What's never included in these instructions are quantified or qualified consequences for failure to observe these admonitions to the letter. There are a variety of possibilities. First, suppose a manufacturer spells out a lot of detailed instructions for optimum performance and for some reason, the customer comes back with a complaint. It's an easy CYA action to ask, "Well, did you follow all the recommendations?" Another possibility is that while the recommendations are based on laboratory conditions deduced during product development, there were no quantified studies that detail the consequences for letting the recharge voltage stray from optimum by n-volts, or allowing some piece of a transceiver to exceed optimum by n-degrees of temperature. It's left up to installer and operator to discover these things for themselves. Degrees of concern range from a notion that practical deviations from optimum are known to have little significance . . . others worry to the point of obsession with concerns that departures from optimum pose a threat of unsatisfactory performance if not catastrophic hazard to the device. These are the things that system integrators learn while the manufacturers are relatively content to coast along offering best-of-all-worlds conditions for optimum performance of their product. In real life, many products live and work in less than "ideal" situations yet they perform in a manner that the user perceives as satisfactory. In the vast majority of cases, we'll never know how the vhf comm and transponder systems affect each other if the antennas are only 23 inches apart or how many more flights we might get from a battery that is charged at 14.6 versus 14.4 volts. The point of all this is an attempt to assuage unnecessary concerns for slicing and dicing installation and operational considerations with some notion that we'll perceive a real return on investment for the effort. Virtually every time someone pops up on the list with a real performance problem, root cause for their perceptions turns out to be rather gross errors of installation. Wires crossed, ground loops, coax connector loose, perhaps the piece of equipment was never intended to be used that way . . . or maybe something is just broke or worn out. The golden rule of thumb is do as much as is practical to comply with the manufacturer's best wishes. Get on a community List like this and see what insight the experience base of the system integrators has to offer. Keep the knowledge of compromises you made in your hip pocket to examine as possible causes for problems that probably wont but may manifest later. By so doing, you gain knowledge that adds to your own skills as a system integrator that can be shared with others at some time in the future. Bob . . . ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Re: RE: Transponder location in the panel
> > >Hi Bevan, > >Re: All this talk about transponder "Antenna" locations has me thinking >about >the location of the transponder itself. Will my Becker 2 1/4" transponder >(250watt) > >On a tangent, I have the same unit and having noted the relatively high >power consumption compared to the coms sharing the stack, elected to put >the xpdr at the top. This ought to help keep my avionics as cool as >practical behind the panel. Design considerations for devices designed to live and work on the panel of your airplane include the knowledge that there ARE potentially incompatible antagonists and victims that need to function side-by-side. This is part of what DO-160 testing is all about. Unless the installation instructions specifically warn against any particular locations, then there's no good reason to create any new worries about it. Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 12, 2007
Subject: OV condition in old Bonanza
>Comments/Questions: A good friend of mine has completed an RV6 and >recommended that you were the only one to answer my question. > >I just replaced the voltage regulator on my A36 Bonanza that I have owned >for 20 years - 1977 E-1058 - The reason for the replacement was that we >had an over voltage condition that caused a number of avionics to fail. I >am trying to find out the cause of the failure, and if it was just a >failure of the regulator or anything else. Root cause was probably failure of the voltage regulator . . . however, there are exceedingly rare but not zero risk that some other defect in wiring or internal to the alternator caused the ov condition. A follow-up consideration is that the OV condition was permitted to continue to an unhappy result because either (1) no OV protection was installed or (2) the OV protection system was failed. >My question is: The charging system in this bonanza has a 3 amp fuse in >the alternator field wiring located on the engine side of the fire wall. >This fuse block is out exposed to the elements. The fuse holder brackets >holdding the fuse were noted to be corroded. My question is could the >corrosion have caused the regulator to not read the field voltage and >cause the "inductive kickback" or voltage spike. > >We cleaned up the fuse bracket after installing a new Zeftronics voltage >regulator. But I need to know if this could happen again due to corrosion. If the system is operating normally after having replaced the regulator, then failure of the original regulator is mostly likely the root cause. Did your replacement regulator come with OV protection built in? Does your system have an OV protection devices installed that failed to function earlier? I'll dig around in the drawings at Hawker/Beech to see how the airplane was wired when it left the factory. Corrosion at the fuse holder would not have caused an OV condition. Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 12, 2007
Subject: Re: Popped CB
> >I started my 912ULS for the first time. Ran like a charm. However, at >both starts the alt cb popped. I used the Z16 diagram. Obviously I >have "crossed wires" some place--any ideas? When did the breaker pop? As soon as you pushed the starter button? When you released the starter button? Do you have a diode across the coil of your starter contactor? Did you have the alternator turned ON while cranking or did you turn it on after the engine was running? Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Subject: RF noise from EFIS
Date: Mar 12, 2007
Trying to figure out a problem I'm running into where an EFIS screen seems to be putting RF noise into my radio. The noise seems "small" -- as in it can't be heard if there's a strong signal being received, but can be heard if there's no transmission or as background while receiving poor signal. It never breaks the squelch on the radio at all, so it can only be heard if I pull the squelch button on my SL-40. noise goes away if antenna is disconnected, in which case all I can hear is normal radio static. noise can be heard if rubber ducky antenna is connected instead of the Comant antenna (so I'm not sure it's my real antenna installation at issue here, but could be?) Due to the setup I have, I can hook this antenna right behind the radio, or at the end of the coax run.. didn't notice any difference between the two. Tried Radio Shack ferrite choke at various locations and it didn't seem to do anything. Tried some RS in-line choke (in-line with radio +, as well as EFIS + and ground) which also didn't do anything either. coax doesn't run close to the EFIS screen, and for the most part, it's not close to other wires. I have a 2-screen setup and both (and either) produce this noise... have not tried transmitting, so no idea what kind of impact it'd have (if any) on outgoing transmissions.. focused on reception at this point. again, since it doesn't break the squelch, it's not a big big issue, but it's annoying and would love to see it go away :) any thoughts? Thanks! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100146#100146 ________________________________________________________________________________
Date: Mar 12, 2007
Bob Sorry for the delay. I attempted to learn the express software for this, and simply could not get it off my clipboard. so here is the free hand version. Sorry about the quality but I think it tells the basics
AOL now offers free email to everyone. Find out more about what's free from AOL at http://www.aol.com. ________________________________________________________________________________
Date: Mar 12, 2007
From: Peter Braswell <pbraswell(at)alterthought.com>
Subject: Re: RF noise from EFIS
Bet you've got an BMA E1? I had the same problem. Got into the system setup and go to RF squelch. The factory setting is 56. I had to run my up to 70 to get rid of the scratching in my system. All is well now... Those ferrite thingies from RS DO NOT WORK! peter ----- Original Message ----- From: "N777TY" <microsmurfer(at)yahoo.com> Sent: Monday, March 12, 2007 6:33:44 PM (GMT-0500) America/New_York Subject: AeroElectric-List: RF noise from EFIS Trying to figure out a problem I'm running into where an EFIS screen seems to be putting RF noise into my radio. The noise seems "small" -- as in it can't be heard if there's a strong signal being received, but can be heard if there's no transmission or as background while receiving poor signal. It never breaks the squelch on the radio at all, so it can only be heard if I pull the squelch button on my SL-40. noise goes away if antenna is disconnected, in which case all I can hear is normal radio static. noise can be heard if rubber ducky antenna is connected instead of the Comant antenna (so I'm not sure it's my real antenna installation at issue here, but could be?) Due to the setup I have, I can hook this antenna right behind the radio, or at the end of the coax run.. didn't notice any difference between the two. Tried Radio Shack ferrite choke at various locations and it didn't seem to do anything. Tried some RS in-line choke (in-line with radio +, as well as EFIS + and ground) which also didn't do anything either. coax doesn't run close to the EFIS screen, and for the most part, it's not close to other wires. I have a 2-screen setup and both (and either) produce this noise... have not tried transmitting, so no idea what kind of impact it'd have (if any) on outgoing transmissions.. focused on reception at this point. again, since it doesn't break the squelch, it's not a big big issue, but it's annoying and would love to see it go away :) any thoughts? Thanks! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100146#100146 ________________________________________________________________________________
Date: Mar 12, 2007
Understand. What you've shown should function just fine. Bob . . . >Bob > >Sorry for the delay. I attempted to learn the express software for this, >and simply could not get it off my clipboard. so here is the free hand >version. Sorry about the quality but I think it tells the basic ________________________________________________________________________________
Subject: Popped CB
Date: Mar 13, 2007
Frank, I wired my SkyRanger/912UL via Z-16 also. It does the same thing. I just start the engine with the MASTER in the BAT position and then go to BAT/ALT after the engine is running, then turn on all loads. Shut-down is opposite sequence.* Bob, I didn't install a diode across the starter contactor coil but plan to. Will check next time I crank her up to see exactly when it happens and give you another data point. Rodney in Tennessee * I use the "5-M's" mnoemonic to remember shut-down sequence. ...Music - turn off all loads. ...Mags - check. ...Mixture - full lean (for the 912UL I just pull throttle to the idle stop). ...Mags - off. ...Master - off. _________________________________________________________________ Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month. Intro*Terms https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117 ________________________________________________________________________________
Date: Mar 13, 2007
Radio, What kind of EFIS? Not all EFIS systems are created equal! I would bet that you have a BMA system! If so, I have worked with a few customers with similar problems. The only thing that helped was to incorporate shielded wires (which BMA doesn't like to use) and move the antenna away from the main processor. The BMA stuff makes an unacceptable amount of RF noise. One of the many reasons they will never get a TSO. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of N777TY Sent: Monday, March 12, 2007 3:34 PM Subject: AeroElectric-List: RF noise from EFIS Trying to figure out a problem I'm running into where an EFIS screen seems to be putting RF noise into my radio. The noise seems "small" -- as in it can't be heard if there's a strong signal being received, but can be heard if there's no transmission or as background while receiving poor signal. It never breaks the squelch on the radio at all, so it can only be heard if I pull the squelch button on my SL-40. noise goes away if antenna is disconnected, in which case all I can hear is normal radio static. noise can be heard if rubber ducky antenna is connected instead of the Comant antenna (so I'm not sure it's my real antenna installation at issue here, but could be?) Due to the setup I have, I can hook this antenna right behind the radio, or at the end of the coax run.. didn't notice any difference between the two. Tried Radio Shack ferrite choke at various locations and it didn't seem to do anything. Tried some RS in-line choke (in-line with radio +, as well as EFIS + and ground) which also didn't do anything either. coax doesn't run close to the EFIS screen, and for the most part, it's not close to other wires. I have a 2-screen setup and both (and either) produce this noise... have not tried transmitting, so no idea what kind of impact it'd have (if any) on outgoing transmissions.. focused on reception at this point. again, since it doesn't break the squelch, it's not a big big issue, but it's annoying and would love to see it go away :) any thoughts? Thanks! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100146#100146 -- 2/8/2007 -- 2/8/2007 ________________________________________________________________________________
Date: Mar 13, 2007
It affects the BMA Sport and Lites as well and is worse in composites than metal planes. Actually BMA encourages the use of shielded wires for anything running out of the EFIS. As mentioned above you should avoid if possible running any EFIS wiring near your antenna lines. Also the can around the EFIS is not necessarily connected to the ground of the circuit boards so the can itself should be grounded as well as the EFIS. Look for any wires from the EFIS that terminate in a dead end ( are not connected to anything) and eliminate them they are acting as a transmit antenna. Likely culprits are ap disconnect wires on the stick running next to your PTT and engine monitoring circuits not yet hooked up. The shield on sheilded cable should be grounded at both ends. If you are not using a serial port turn it off. Hopefully you can reduce the noise to a level where it can be overcome with the squelch setting as noted above. -------- Milt N395V F1 Rocket www.excaliburaviation.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100281#100281 ________________________________________________________________________________
Date: Mar 13, 2007
Thanks guys.. just to clarify a few points: 1) It's not BMA... it's GRT. 2) It doesn't need squelch adjustment -- it never breaks the squelch.. doesn't even come close to that. 3) It doesn't affect normal transmissions -- those are recieved 5 by 5.. radio does a great job of getting rid of all that noise when good transmission is received. 4) coax doesn't run close to any efis wires.. I ended up reviewing BMA message boards, and what I can see there is that BMA guys are A LOT more affected than I am... I don't have symptoms they're describing where increasing squelch takes care of the noise... Thanks again! Radomir -------- RV-7A N777TY (res) Read this topic online here: http://forums.matronics.com/viewtopic.php?p=100293#100293 ________________________________________________________________________________
Subject: wiring diagram benefits?
Date: Mar 13, 2007
I may be asking for a beating here, but exactly why should I create detailed wiring diagrams? I wired my RV-7A myself following the Z-13/8 schematic, and have relatively easy access to all my electrical compone nts. All wires are labeled on both ends, indicating where they came from and where they are going to. I probably should have sketched out the wirin g diagrams as I completed routing each wire, but it can still be done now without too much trouble since my forward top skin is still off. Ok, I admit to a touch of laziness here, which is enhanced by a growing anticipation of the first engine start and flight, but I am having difficulty describing to my self exactly what future scenario makes tha t wiring book a must have. Go ahead and set me straight. Or hey, feel free to tell me "never did it, never needed it" as well. regards erich weaver ________________________________________________________________________________
Date: Mar 13, 2007
Subject: Re: wiring diagram benefits?
It's not for your benefit right now. It's for your benefit in 3 years when you scratch your head and wonder what the heck you did this or that for, and for the next guy who buys your plane and has no idea what you were thinking. Same reason programmers add comments to their software. You should see the undocumented mess I inherited under my panel. The only way I'll ever figure it out is to take it all apart and put it back together again. And that will take about a week of effort. Document it now, and generations that follow will thank you. Dave Morris At 11:33 AM 3/13/2007, you wrote: >I may be asking for a beating here, but exactly why should I create >detailed wiring diagrams? I wired my RV-7A myself following the >Z-13/8 schematic, and have relatively easy access to all my >electrical components. All wires are labeled on both ends, >indicating where they came from and where they are going to. I >probably should have sketched out the wiring diagrams as I completed >routing each wire, but it can still be done now without too much >trouble since my forward top skin is still off. Ok, I admit to a >touch of laziness here, which is enhanced by a growing anticipation >of the first engine start and flight, but I am having difficulty >describing to my self exactly what future scenario makes that wiring >book a must have. > >Go ahead and set me straight. Or hey, feel free to tell me "never >did it, never needed it" as well. > >regards > >erich weaver > ________________________________________________________________________________
From: "Doug Windhorn" <N1DeltaWhiskey(at)comcast.net>
Date: Mar 13, 2007
Erich, Food for thought: If you need your leading edge open now to trace the wiring, think about where you will be when you close the leading edge, then a year from now, and 5-years from now. If you cannot draw your wiring diagram now without even looking at the wiring - don't you think you will be in trouble down the road? Labeling the wires will help, but there is nothing like a good diagram to help in understanding an airplane's electrics. To save time now - and to make for a winter time project, draw your diagrams in pencil now and make nice ones for permanent documentation later. You could start with Bob's Z diagram and add the various label names you used on your wires (specially if you used abbreviations), along with wire gauge, color, etc. Also, be sure to add any connectors with the pin number. Consider adding manufacturer & part numbers for replacement purposes. Those electrical diagrams you do now may be worth $$$ down the road. Consider that I, and probably others, would not even consider buying a plane without thorough documentation, unless it was at a "bargain" price. Doug Windhorn ----- Original Message ----- From: Erich_Weaver(at)URSCorp.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, 13 March, 2007 9:33 Subject: AeroElectric-List: wiring diagram benefits? I may be asking for a beating here, but exactly why should I create detailed wiring diagrams? I wired my RV-7A myself following the Z-13/8 schematic, and have relatively easy access to all my electrical components. All wires are labeled on both ends, indicating where they came from and where they are going to. I probably should have sketched out the wiring diagrams as I completed routing each wire, but it can still be done now without too much trouble since my forward top skin is still off. Ok, I admit to a touch of laziness here, which is enhanced by a growing anticipation of the first engine start and flight, but I am having difficulty describing to my self exactly what future scenario makes that wiring book a must have. Go ahead and set me straight. Or hey, feel free to tell me "never did it, never needed it" as well. regards erich weaver ________________________________________________________________________________
Date: Mar 13, 2007
Dave N6030X a crit : > > > It's not for your benefit right now. It's for your benefit in 3 years > when you scratch your head and wonder what the heck you did this or > that for, and for the next guy who buys your plane and has no idea > what you were thinking. And what if one piece of equipment doesn't work as expected (things sometimes happen), and you don't have a proper diagram to reflect on ? I did a one page per system wire book, and took time to update it after every change I made, and wiring and troubleshooting proved a breeze. Troubleshooting ? Yes I experienced troubles with off-the-shelf equipment (not my wiring), and had to pinpoint the cause. And when isolating a circuit during maintenance, I refer to my book, because wiring was 4 years ago now, and things fade away in my mind. So, I did, and I'm happy I did. Regards, Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Mar 13, 2007
Hi Erich, You need a wiring diagram if only to keep notes of how things are and after you're gone, the next owner needs some hint of where you put things. I did a wiring diagram because there are just too many things to remember only 3 years after the fact. Nice to know what bundle of wires to look to when things go down. Saved me on two occasions so far. Modifications also require some idea of how you're loaded before the fact, so if nothing else, do a simple one. See link and modify them to suit you if you want. http://www.macsmachine.com/images/electrical/full/primary-wiring.gif http://www.macsmachine.com/images/electrical/small/primary-wiring-(SH-2).gif http://www.macsmachine.com/images/electrical/full/primary-wiring-(SH-3).gif Larry McFarland at www.macsmachine.com Erich_Weaver(at)URSCorp.com wrote: > > I may be asking for a beating here, but exactly why should I create > detailed wiring diagrams? I wired my RV-7A myself following the Z-13/8 > schematic, and have relatively easy access to all my electrical > components. All wires are labeled on both ends, indicating where they > came from and where they are going to. I probably should have sketched > out the wiring diagrams as I completed routing each wire, but it can > still be done now without too much trouble since my forward top skin > is still off. Ok, I admit to a touch of laziness here, which is > enhanced by a growing anticipation of the first engine start and > flight, but I am having difficulty describing to my self exactly what > future scenario makes that wiring book a must have. > > Go ahead and set me straight. Or hey, feel free to tell me "never did > it, never needed it" as well. > > regards > > erich weaver > ________________________________________________________________________________
Subject: re: wiring diagram benefits
Date: Mar 13, 2007
Thanks for the input on this guys. I remain open to what you are sayin g, but indulge my hard headedness for a minute longer. I readily admit th at I will quickly forget details of my electrical system in the near future. However..... It seems to me that the wiring diagrams chief benefit is for mulling th ings over from the convenience of your own living room. If I start messing with my electrical system its likely to be because something isnt working, a nd this will require me to gain access to the various components of the electrical system. The hidden components of my electrical system (AHRS box , fuseholders, wig-wag flasher, voltage regulator, etc) are relatively easily accessible and if any of these are not easily identified by loo ks alone, they are labeled. Every wire coming from such components is lab eled with respect to exactly where it is coming from and where it is going t o. Therefore, I will be able to check that the electrical connections are sound at both ends of every wire segment. I will also be able to check that the wires go to the right connection point on each component by comparing my connections with what is presented in the manufacturer's documentation, which I have carefully cataloged in my building binders. I can further check that components are actually connected as labeled wit h a continuity tester. In short, it seems to me that most of the truly valuable information on my electrical system can be gained from the schematic and when necessary f or repairs, visual inspection/testing of the individual components and at their electrical connection points. The actual route the wires take between components seems almost irrelevant to me. I am not terribly persuaded by arguments of some perceived future value to future buyers of my plane. First, Im not sure I buy the argument that my plane will be worth less. The phrase "Comprehensive wiring diagrams available" doesnt seem to show up much in adds for experimentals. And f or those buyers that have the desire/need to know my electrical system, I still think the schematic and good labelling practices I have adhered t o, along with manufacturers' documentation provide a solid basis for diagnosing and resolving problems. Okay, I can already see the aero-electric masses collectively shaking t heir heads back and forth at me. Nomex flame suit donned. Fire away. Concrete examples of how your wiring diagrams saved the day, and conversely, how my annotated Z-13/8 schematic and comprehensive compone nt and wire labeling are woefully inadequate will be enthusiastically received. Just between us girls, I'll bet there are more than a few out there wit h virtually no electrical documentation combined with complete ignorance of their system. They may even be conspiring to sell these planes to othe rs! : ) ________________________________________________________________________________
Date: Mar 13, 2007
> >It affects the BMA Sport and Lites as well and is worse in composites than >metal planes. > >Actually BMA encourages the use of shielded wires for anything running out >of the EFIS. Which suggests a profound lack of knowledge as to how noises should be kept inside the product . . . >As mentioned above you should avoid if possible running any EFIS wiring >near your antenna lines. Antenna lines are coaxial transmission lines and not vulnerable to ingress of noises . . . >Also the can around the EFIS is not necessarily connected to the ground of >the circuit boards so the can itself should be grounded as well as the EFIS. "ground" is an un-quantified, un-qualified term term when it comes to taming the noises emitted from an accessory. Spent the whole day in the lab today "sniffing" the noise performance of an airborne super-server that's destined to share volume within an airplane with lots of VERY sensitive spook receivers. Anyone who pushes their noise containment duties off on the installer by suggesting broad brush admonitions to shield everything and keep stuff away from coaxes doesn't have a clue . . . >Look for any wires from the EFIS that terminate in a dead end ( are not >connected to anything) and eliminate them they are acting as a transmit >antenna. Likely culprits are ap disconnect wires on the stick running next >to your PTT and engine monitoring circuits not yet hooked up. > >The shield on sheilded cable should be grounded at both ends. > > >If you are not using a serial port turn it off. Let's do some detective work and see if the real leak can be identified before you start shot-gunning with hopeful remedies. What radio is being affected? Know that most of the glass dial noise problems radiate from the opening covered by the LCD. What does the "noise" sound like? How is the noise affected by positioning various controls of the victim radio? Bob . . . ---------------------------------------- ( IF one aspires to be "world class", ) ( what ever you do must be exercised ) ( EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
March 03, 2007 - March 13, 2007
AeroElectric-Archive.digest.vol-gt
