AeroElectric-Archive.digest.vol-hb
July 13, 2007 - August 01, 2007
      B&C.  However, a buddy of mine recently experienced a
      contactor failure in flight and it caused me to experience a
      few "What If!?" nightmares.  I'm back to reconsidering my
      original decision...
      I wish I could skip the contactor entirely, but the
      components hanging off the master bus aren't switched (no
      ON/OFF control) so I need a master contactor to switch power.
      The options I toyed with initially were a mechanical can
      (S-701), a solid state relay (Crydom D06D series), or a "hot
      rod" manual switch.
      I've had good personal experience with the cans (no failures
      yet in hundreds of hours of flying).  Sure, they get hot and
      use/waste a little power but they have a good heritage.  Had
      my buddy not experienced a failure, I probably wouldn't have
      worried at all.  Now, I can't avoid worrying.
      I've had good experience with the Crydom SSRs, too, and have
      only seen one coaxed to failure by a well-intentioned
      technician (25 Adc through a 7 Adc device... poof!).  Low
      power consumption, rugged, compact, moderately priced.
      I've quizzed folks here about using manual "hot rod"
      contactors and received some great feedback (e.g. - don't
      use the cheap ones!).  Seemed bulletproof at first, but
      recent posts suggested these things can/have/will fail, too.
        Perhaps it's just a problem with the cheap ones?  Dunno.
      So, I'm sitting at square one (again!) trying to determine
      which of these options is most likely to keep me out of hot
      water.  I realize there is no "100% reliable" solution, but
      I'm weighing my options to get the greatest number of 9's in
      the long run.
      Any feedback/wisdom from you folks will be greatly appreciated.
      D
Subject: Re: best contactor reliability -- mechanical, solid
state, or manual?
Date: Jul 13, 2007
On 13 Jul 2007, at 04:38, D Wysong wrote: > > I have a remotely operated application where the loss of the master > battery contactor will result in the loss of data/money/time (... > and dignity!). My baseline design resembles a "Z" diagram (thanks > Bob!) and I planned to use a mechanical, continuous duty contactor > like the S-701 from B&C. However, a buddy of mine recently > experienced a contactor failure in flight and it caused me to > experience a few "What If!?" nightmares. I'm back to reconsidering > my original decision... > > I wish I could skip the contactor entirely, but the components > hanging off the master bus aren't switched (no ON/OFF control) so I > need a master contactor to switch power. > > The options I toyed with initially were a mechanical can (S-701), a > solid state relay (Crydom D06D series), or a "hot rod" manual switch. > > I've had good personal experience with the cans (no failures yet in > hundreds of hours of flying). Sure, they get hot and use/waste a > little power but they have a good heritage. Had my buddy not > experienced a failure, I probably wouldn't have worried at all. > Now, I can't avoid worrying. > > I've had good experience with the Crydom SSRs, too, and have only > seen one coaxed to failure by a well-intentioned technician (25 Adc > through a 7 Adc device... poof!). Low power consumption, rugged, > compact, moderately priced. > > I've quizzed folks here about using manual "hot rod" contactors and > received some great feedback (e.g. - don't use the cheap ones!). > Seemed bulletproof at first, but recent posts suggested these > things can/have/will fail, too. Perhaps it's just a problem with > the cheap ones? Dunno. > > So, I'm sitting at square one (again!) trying to determine which of > these options is most likely to keep me out of hot water. I > realize there is no "100% reliable" solution, but I'm weighing my > options to get the greatest number of 9's in the long run. > > Any feedback/wisdom from you folks will be greatly appreciated. I assume that this is not an aircraft we are talking about. If you have an application where you must absolutely ensure continuity of power, then you have to assume that any single component could someday fail, no matter how good quality that component is. How about two contactors in parallel, with some sort of periodic check to ensure that they are both working, or some way to monitor them to have evidence that they are both working? For monitoring, you could have each contactor feeding through a diode, and monitor the voltage between the contactor and the diode. If the contactor fails, that voltage will drop. If the voltage shows that both contactors are closed, you could monitor that voltage to show that each contactor can be opened (one at a time, so you don't stop providing power to your application). Kevin Horton RV-8 (finishing kit) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Date: Jul 13, 2007
Subject: Re: Low transmit volume on Valcom 760
Assuming that you've already tried a different headset to be sure it's not the headset mic, check with VAL on whether there's a mic gain control in the radio. (not the volume control on the front panel) Some headsets with electret condenser mics have a gain control in the mic itself. It would be a tiny recessed screw in the mic housing. Charlie Chad wrote: > > I don't have access to SWR but I went further away with the handheld > (couple hundred feet I guess) and it's the same thing. You can hear and > it's relatively clear, just really quiet. > > chad > > > Subject: Re: Low transmit volume on Valcom 760 > From: Robert Feldtman (bobf(at)feldtman.com) > Date: Thu Jul 12 - 3:57 AM > > Might be okay - Automatic gain control (AGC) on handheld may have > cut down > the volume - try to talk to somebody a further distance away. check > your > SWR. probably okay > > bobf > > On 7/11/07, Chad wrote: > > > > > > > > Hello all, new subscriber here looking for some helpful advice. > > > > I'm finishing up my instrument panel and did some radio testing > > tonight. I have a Valcom 760 radio hooked up to a fiberglass rod > type > > antenna. I can receive great, in fact I was picking up traffic in > the > > pattern at an airport about 40 miles north of here with the > airplane in > > my garage. That said, I switched to a known unused channel and tried > > some transmitting (listening on my handheld about 15 feet away) > but the > > volume was almost inaudible. I had to practically shout into my > headset > > mic in order to really hear and understand anything. I've checked > some > > of the basics with the wiring and don't see anything obvious. > > > > Anyone have any tips on what to check or what the problem might > be? I'm > > afraid that everyone will be able to hear me key the mic, but will > > struggle understanding me with this low output volume. > > > > Regards, > > > > Chad > > ________________________________________________________________________________
Subject: CDI Switch?
Date: Jul 13, 2007
What's the best way to switch the CDI input from GPS-WAAS to Nav1 to Nav2? I have the Garmin GI106A, GNS430W, SL30 combination. The GNS430W allows you to switch between GPS-WAAS and NAV1 internally. Also the GNS430W and the SL30 are feeding GPS/VOR/ILS to the Blue Mountian(BMA) EFIS/One. The GNS430W via an analog connection and SL30 via the serial link. The BMA autopilot is only able to be driven by the BMA EFIS/One. Sincerely, ERic-- RV-10, N104EP ________________________________________________________________________________
Date: Jul 13, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Circuit for automatic fuel pump engageing
>Hello all, > >I am looking for some hints / circuits for automatic switching of my fuel >transfer pumps. As it is standard with the Lancair 360, I have two wing >tanks and a header tank. As I do not want to switch on the transfer pumps >manually every 30 minutes, probably forgetting it at all, I want to build >in an "intelligent" circuit doing it for me. >My set up is, that I have a capacitive level sensor in the header tank, >providing 0 to 5 Volt depending on the fuel level. In addition, I have an >independent sensor at about 15 gallons which will give me a last warning >in case the circuit or transfer pumps isnot working. > >Does someone already went through this experiment and is willing to share >his wiring drawings with me ? Even it is possible to develop something >like that by my one, one does not have to re-invent the wheel. The board that assembles the product described in these documents . . . http://www.aeroelectric.com/Catalog/AEC/9011/ Has up to 4 a/d inputs and up to 3 open collector, moderate current pull-downs (1A) and good program space. If you could send me a schematic of your "manual" system and a brief Product Performance Specification as to how you'd like the thing to work, I'll have my software guy look at it. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 13, 2007
Subject: Re: Z-19
>I am going with the Z-19 Rear batteries in an RV-8 with the 2.5 SC engine >with Supercharger. >My question is why not be able to operate the second Fuel Pump from either >battery? >Seems like it would give another option for keeping the fuel flowing. Mine >will be wired this way. How many failures are you planning to stack? I've seen some airplanes wired where the owner was able to select backups to backups . . . the architecture offered a hose of variables for powering things up in case this failed, and then that failed too, etc. The probability of dual failures on any one tank of fuel is exceedingly low. Properly maintained RG batteries (when installed to accommodate relatively fragile lead posts) are exceedingly reliable. The failure mode effects analysis process is a deduction of all the what-if's but for our purposes, we don't need to go more than one layer deep. Given the quantum jump in alternator and battery reliability, you can comfortably assume that altenrator failure will be rare and both properly maintained batteries will be there when you need them. >Thanks to Bob N. for all he does. My pleasure sir. I'm pleased that you find the efforts useful. Bob . . . ________________________________________________________________________________
Subject: Re: Antenna
Date: Jul 13, 2007
Bob, Normally a metal cage type structure will shield the antenna from radiating, if the cage openings are smaller than around 3 feet, that is assuming you mean to have the antenna inside the fuselage. It is possible to actually connect to parts of the structure, at strategic points, and use the structre to radiate, in some cases, but this is a difficult process. If the matching point is not correct, the cable will radiate and cause problems for other avionics too. For a tube / fabric airframe, antenn drag is not an issue, use a normal or swept back wire antenna, mounted at a tubing juncion or on a pice of metal panel as far away from the engine as practicable. For an Avid flyer, the rear turtledeck is aluminium and works well. Ralph, radio tech in NZ -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123680#123680 ________________________________________________________________________________
Subject: Connecting a Garmin (Apollo) SL40 COM to a PS Engineering
PMA4000 Audio Panel
Date: Jul 13, 2007
Since I'm a rookie at this, I just re-read the section in the Aerolectric Connection about Audio Panels. The answer to this is not in there. I am having trouble with the naming conventions provided by two different vendors in their documentation. I believe that they are calling the same things by different names. That would be a great injustice on their parts if intentional, so I am sure that it is just my inexperience playing the major role here. Anyway, for connecting the COM to the Audio Panel, here are the pertinent connection labels and pins: On the Garmin SL40 COM: Headphone - 14 Audio Ground - 13 Mic 1 - 8 Mic Ground - 7 TxKey - 4 On the PMA4000 Audio Panel: Com 1 Audio HI - Top-19 Com 1 Audio LOW - Top-7 Com 1 PTT - Bottom 22 Com 1 Mic Audio HI - Bottom 21 Com 1 Mic Audio LO - Bottom 9 What I'd like is for some to confirm that they match up (are connected ) as follows: Headphone - 14 to Com 1 Audio HI - Top -19 Audio Ground - 13 to Com 1 Audio LO - Top - 7 Mic 1 - 8 to Com Mic Audio HI - Bottom - 21 Mic Ground - 7 to Com 1 Audio LO - Bottom 9 TxKey - 4 to Com 1 PTT - Bottom - 22 Thanks for suffering thought these details with me. It seems that PS Engineering refers to the ground as "LO" consistently. Jeff Davidson ________________________________________________________________________________
Subject: Re: Connecting a Garmin (Apollo) SL40 COM to a PS Engineering
PMA4000 Audio Panel
Date: Jul 14, 2007
I'm just about to go through the same thing only with an SL30. If you call Tony at Stark Avionics I'm sure he will have the correct answer. He has been very helpful in my other endeavors so far. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy 704-362-0005 Home 704-281-7884 Cell ________________________________________________________________________________
Date: Jul 14, 2007
7/14/2007 Hello Eric, Great equipment choice. Switching can be done with a mulltiple pole remote relay controlled by a push button switch that shows which mode you are in. Ameri-King has some relays: http://www.ameri-king.com/ So does Northern Airborne Technology, but their web site is pretty opaque. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." From: "Eric Parlow" <ericparlow(at)hotmail.com> Subject: AeroElectric-List: CDI Switch? What's the best way to switch the CDI input from GPS-WAAS to Nav1 to Nav2? I have the Garmin GI106A, GNS430W, SL30 combination. The GNS430W allows you to switch between GPS-WAAS and NAV1 internally. Also the GNS430W and the SL30 are feeding GPS/VOR/ILS to the Blue Mountian(BMA) EFIS/One. The GNS430W via an analog connection and SL30 via the serial link. The BMA autopilot is only able to be driven by the BMA EFIS/One. Sincerely, ERic-- RV-10, N104EP ________________________________________________________________________________
Date: Jul 14, 2007
state, or manual? > >On 13 Jul 2007, at 04:38, D Wysong wrote: > >> >>I have a remotely operated application where the loss of the master >>battery contactor will result in the loss of data/money/time (... >>and dignity!). My baseline design resembles a "Z" diagram (thanks >>Bob!) and I planned to use a mechanical, continuous duty contactor >>like the S-701 from B&C. However, a buddy of mine recently >>experienced a contactor failure in flight and it caused me to >>experience a few "What If!?" nightmares. I'm back to reconsidering >>my original decision... Help us with a bit more information about your application. What kind of vehicle? What kind of environment? What's the energy requirement to maintain data in vulnerable systems. It's often much easier to arrange for brownout and/or momentary power loss for a few items than to back-up the whole system. Finally, it's almost always better to have a plan-a/plan-b modus operandi than to scratch around for "more reliable" hardware. EVERYTHING will break at some point in time. Give us a rundown of your equipment that must stay awake and what the power requirements are. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2007
Engineering PMA4000 Audio Panel
At 20:28 7/13/2007, you wrote: >What I'd like is for some to confirm that they match up (are >connected ) as follows: > >Headphone - 14 to Com 1 Audio HI - Top -19 >Audio Ground - 13 to Com 1 Audio LO - Top - 7 >Mic 1 - 8 to Com Mic Audio HI - Bottom - 21 >Mic Ground - 7 to Com 1 Audio LO - Bottom 9 >TxKey - 4 to Com 1 PTT - Bottom - 22 > >Thanks for suffering thought these details with me. It seems that >PS Engineering refers to the ground as "LO" consistently. > >Jeff Davidson Should work fine Jeff, as you've indicated. -Back in the days-, before all our new solid state electronics, many audio systems were truly 'balanced'; that is for increased noise rejections capability neither signal was ground referenced, but referenced to one another. A ground referenced shield covered the pair. Low signal level signals, microphone lines for example, are still, in professional systems, done this way. However, the higher level 'line' level signals, that used to be 500 or 600 ohm balanced lines, have for the most part become single-ended; with a high signal and a ground return completing the path. You will note most of our com radios have a ~500 ohm output and most intercoms and audio panels have their input impedance spec'd as ~500 ohms despite the fact generally in newer equipment neither really is. It's a carry over for compatibility with as MS would name, legacy equipment. But still a good idea when properly implemented and interconnected. Problem here with 'single ended (not balanced) systems' is that the signal will "see" any stray currents and voltage drops through the resistance of the real world as an additional voltage. That additional voltage will appear as unwanted noise, or whatever, with the signal we desire; an especially bothersome issue with the low level signals our microphones provide. With the higher level line signals it's less a problem, but is just ignored by many manufacturers. PS, to their credit, didn't ignore the real or old world and provisioned their equipment with both hi and low inputs for those wishing to use shielded twisted pair cable to reduce noise in all interconnects. While their "lo" may still be very similar to ground, it is still provided and by following their IM one can end up with an audio system having greater immunity to externally generated noise; this by running the 'lo' along with the 'hi' and not using the airframe as the signal return. It's very important to keep the microphone jack mounting bushing, and to a lessor degree the headphone as well, insulated from the airframe and rely on the LO wire to provide that connection. To not do so negates the advantage of what PS has provided us. Ron Q. ________________________________________________________________________________
Date: Jul 14, 2007
Subject: Re: Plane-Power
> > > >Hi Bob, > >I was just curious if you had had any time to explore any of Plane-Power's >internally regulated alternators on that fancy alternator stand? > >Thanks, No. My duties with an ageing father in Medicine Lodge, putting down new hardwood floors on my house and needs of my new clients (out of town 4 days last week and 3 days next week) have push my drive-stand project back into the corner. Actually, I have no particular plans to test Plane-Power's products. They are wired exactly the same architecture and alternator control philosophy that you would get if if you did a B&C LR-3 installation on an externally regulated alternator . . . or figure Z-11 from the book. I intend to explore the energy questions on alternators in general with a goal of achieving positive on/off, any time, any conditions control of an internally regulated alternator that is NOT modified per the Plane Power manufacturing philosophy. I.e. off the shelf automotive. I can deduce no reason to be skeptical of Plane Power's product performance claims. Bob . . . ________________________________________________________________________________
Subject: Where to start
Date: Jul 14, 2007
Ok, so I'm doing a little remote diagnostics. I've got a friend who has a dual battery, dual alternator system. It's flown for 75 hrs with no problems and now has developed an odd on. It uses 2 12v Odyssey batteries, and a regular Continental alternator and an SD-20 both regulated with B&C LR3's. Charging starts out fine and in about 15 mins, both alternators shut off and he's on battery only until he descends to a lower altitude (not predictable) or shuts down the electrical for some time and then brings both Alts back on line. We've tried the turn on a load, turn off a load routing, also he had been flying with his crosstie on all the time and this last flight he stared with crosstie on and then turned it off and it made no difference. Anyone care to offer the short version of where to start and what to look for besides the obvious, wire loose, connector broken, ground failed, etc? Thanks in advance, Alan ________________________________________________________________________________
Subject: Re: CDI Switch?
Date: Jul 14, 2007
I think Perihelion Design has a relay for the job. (Originally a B Nuckolls design). http://www.periheliondesign.com/18polerelays.htm Parts list and PCB design are free for the asking. Assembled unit is cheap. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123775#123775 ________________________________________________________________________________
state, or ma
Date: Jul 14, 2007
Some reuse from an email to a customer here...) Compare--- ____________________Type 70_____GX-11 Weight.........................12.5 Oz.............18 Oz Temp...........................50 DegC...........75-85 DegC (50 degC 122 F) makes the type 70 unusable.... Position........................Cap Down..........Any Environmental...............Dust-Proof.........Hermetically sealed Coil Suppression............Must be added....Built in B&C Type 70 uses diodes, GX-11 uses transorbs (SnapJacks!) Continuous Amps............80 at 50C..........150A at 75C Inrush A.........................150...................500-2000 Open against Vmax.......... 35V.................>>100V (...same as Kilovac) Hold current.....................1.0 A................700 mA (Kilovac is 100 mA, Gigavac has lower hold currents on request) G-force opening...............2G ??................>>10G Anyway the GX11 will be about $120, but the Type 70 ($37.00 from Newark) is not really useable in my opinion. You may want the accessory contacts and long leads...couldn't hurt. The Kilovac EV200aaana (aka Blue Sea 9014) is still great (similar to the Gigavac GX11). The type 70 is problematic even if very common and long in the tooth. It is deficient in three main areas: 1) Poor coil suppression (this can be retrofitted to improve it) 2) Inadequate operating temperature. My GUESS is that the early ones had fiber/bakelite interiors, now they are Nylon. Regardless 122F spec is way too low to use. 3) Inadequate G force withstand. 2G ?? 4) Open against Vmax. 35V. They caould sustain an arc if the alternator runs away. Pure solid state solutions are not quite ready. I have experimented with this, and continue to do so. There are some remarkable devices in development. Mechanical contactors--"Flaming River" seems to come up when people talk about quality. I would like some people to describe what happens to lower quality mechanical contactors, but I haven't heard details. "The despotism of custom is everywhere...the standing hindrance to human advancement." --John Stuart Mill -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123780#123780 ________________________________________________________________________________
Date: Jul 14, 2007
Subject: Re: Where to start
> > >Ok, so I'm doing a little remote diagnostics. I've got a friend who has a >dual battery, dual alternator system. It's flown for 75 hrs with no >problems and now has developed an odd on. > >It uses 2 12v Odyssey batteries, and a regular Continental alternator and an >SD-20 both regulated with B&C LR3's. > >Charging starts out fine and in about 15 mins, both alternators shut off and >he's on battery only until he descends to a lower altitude (not predictable) >or shuts down the electrical for some time and then brings both Alts back on >line. We've tried the turn on a load, turn off a load routing, also he had >been flying with his crosstie on all the time and this last flight he stared >with crosstie on and then turned it off and it made no difference. > >Anyone care to offer the short version of where to start and what to look >for besides the obvious, wire loose, connector broken, ground failed, etc? > >Thanks in advance, >Alan The airplane should be flown with the CROSS-TIE OPEN. This is the whole purpose of dual, independent systems is to eliminate the possibility of a failure affecting both systems. If leaving the cross tie open does not change the observed phenomenon, then I suspect a wiring error. The cross-tie contactor is, for some reason remaining closed. There has to be something else going on as well. The only thing I can think of that would have such a profound effect on both systems is a flaky ground connection between crankcase and firewall ground stud. Bob . . . ________________________________________________________________________________
Date: Jul 14, 2007
> > > >> >> >>Ok, so I'm doing a little remote diagnostics. I've got a friend who has a >>dual battery, dual alternator system. It's flown for 75 hrs with no >>problems and now has developed an odd on. >> >>It uses 2 12v Odyssey batteries, and a regular Continental alternator and an >>SD-20 both regulated with B&C LR3's. >> >>Charging starts out fine and in about 15 mins, both alternators shut off and >>he's on battery only until he descends to a lower altitude (not predictable) >>or shuts down the electrical for some time and then brings both Alts back on >>line. We've tried the turn on a load, turn off a load routing, also he had >>been flying with his crosstie on all the time and this last flight he stared >>with crosstie on and then turned it off and it made no difference. >> >>Anyone care to offer the short version of where to start and what to look >>for besides the obvious, wire loose, connector broken, ground failed, etc? >> >>Thanks in advance, >>Alan > > The airplane should be flown with the CROSS-TIE OPEN. This is > the whole purpose of dual, independent systems is to eliminate > the possibility of a failure affecting both systems. If leaving > the cross tie open does not change the observed phenomenon, > then I suspect a wiring error. The cross-tie contactor is, for > some reason remaining closed. There has to be something else > going on as well. The only thing I can think of that would > have such a profound effect on both systems is a flaky ground > connection between crankcase and firewall ground stud. Got my keyboard cord tangled around my eyeteeth and couldn't see what I was typing. Ignore all the above about cross-tie operation. I can see that I'd mis-read the significance of the cross-tie switch in your dissertation of observed events. Check out that grounding thing. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 14, 2007
Subject: Semi-Custom Products
I've been working on a line of new products for the AeroElectric Connection website that will be unique to AEC. We're going to resist being a dealer for other folks products. One project utilizes an ECB and enclosure that has features described in these two illustrations: http://www.aeroelectric.com/DIY/A15_Package.jpg http://www.aeroelectric.com/DIY/Do-Much_Board_Schematic.pdf The schematic would never have ALL components installed, and in some cases, components left of are replaced with solid jumpers. However, depending on what parts are installed, their values, and what software is installed in the microcontroller, we can craft a variety of products with 98% commonality of bill of materials. The first product to be offered under this design and marketing philosophy is described at: http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf . . . except that it will have a 15-pin connector on it instead of a 9-pin. I'm publishing the schematic for the more technically inclined. Perhaps the architecture will suggest an application close to your own wishes for a smart black box to do some task. If so, let's talk about it and see if my software guy can't whip it out in reasonably short order and save you a lot of development time to craft a nicely packaged electro-whizzy. Or, if you want to do your own byte-pudding I could offer you a kit of ECB and enclosure from which you could move your project ahead. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 14, 2007
Thanks Bob, and that is where we are going to start. Couple more tidbits... In talking with my friend. I found another strange oddity. He has enunciator lights that are connected to the LV warnings on the VR's, but they never went on. Also in talked with him, he said he has a "test" curcuit for his annunciators and only those 2 don't light. So, I think there is a couple of things we need to look at... The ground issues in general and the annunciation system. Something is allowing the alternators to start charging and then to drop off line at some point, but because the LV warnings don't flicker, he doesn't find out about the event until the engine monitor determines an LV condition and screams in his ear... At least we have some places to start.... If you think the LV curcuit being open might have a residual effect let us know that too... Thanks as always, Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, July 14, 2007 1:26 PM Subject: Re: AeroElectric-List: Where to start --> > > > >> >> >>Ok, so I'm doing a little remote diagnostics. I've got a friend who >>has a dual battery, dual alternator system. It's flown for 75 hrs >>with no problems and now has developed an odd on. >> >>It uses 2 12v Odyssey batteries, and a regular Continental alternator >>and an SD-20 both regulated with B&C LR3's. >> >>Charging starts out fine and in about 15 mins, both alternators shut >>off and he's on battery only until he descends to a lower altitude >>(not predictable) or shuts down the electrical for some time and then >>brings both Alts back on line. We've tried the turn on a load, turn >>off a load routing, also he had been flying with his crosstie on all >>the time and this last flight he stared with crosstie on and then turned it off and it made no difference. >> >>Anyone care to offer the short version of where to start and what to >>look for besides the obvious, wire loose, connector broken, ground failed, etc? >> >>Thanks in advance, >>Alan > > The airplane should be flown with the CROSS-TIE OPEN. This is > the whole purpose of dual, independent systems is to eliminate > the possibility of a failure affecting both systems. If leaving > the cross tie open does not change the observed phenomenon, > then I suspect a wiring error. The cross-tie contactor is, for > some reason remaining closed. There has to be something else > going on as well. The only thing I can think of that would > have such a profound effect on both systems is a flaky ground > connection between crankcase and firewall ground stud. Got my keyboard cord tangled around my eyeteeth and couldn't see what I was typing. Ignore all the above about cross-tie operation. I can see that I'd mis-read the significance of the cross-tie switch in your dissertation of observed events. Check out that grounding thing. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 14, 2007
Subject: Re: Garmin 430 transmitter problem
I received the following advice from a local avionics tech. "First thing I would look at is the Com1 circuit breaker. The 430 has two power circuits... one for the com and one for the nav/gps. The nav/gps will light the unit up and allow the Nav and GPS to work, but if the com side isn't getting any (or is getting low) voltage, then you would have transmission issues. So check the breaker to make sure it isn't giving a high resistance when closed, and that you have voltage going to the power pins on the com plug. It might just be best to replace the com breaker with a new one just to be sure. The next would be to swap com coaxes between the SL30 and the 430. If it follows the antenna, then you know it is the coax, antenna, or bonding issue. If it doesn't then you know you have an issue with the 430 transmitter." I haven't had a chance to go back out to the airport yet, but the very first thing I will check will be that I have a good ground to the 430's com circuit. Then, his suggestions. FWIW, one of Garmin's Aviation Field Service Engineers replied to my email with "This sounds like a problem in the GNS430 itself and will need to come back for repair." I'll advise what I find and do. David ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: RE: S700 2-50 Switch / Electric Fuel Pump
Date: Jul 14, 2007
Finishing up the switch wiring on my RV7A Panel. I am using Z13/8 to wire the aircraft. I am using the S700 2-50 switch to activiate my electric fuel pump. The momentary switch up side primes the engine and the full on down would be used incase of the primary fuel pump failure. The engine id fuel injected. Now the question. I am not quite sure how to wire this switch up to make all of this happen..... Frank @ SGU RV7A Panel/Wiring just about ready to hang the engine....when he gets here!!! _________________________________________________________________ http://liveearth.msn.com ________________________________________________________________________________
Date: Jul 14, 2007
Answer found............Page 11-2 AeroElectric connections. Once again thanks Bob...... Now back to tryinjg to find other obvious things known to most that i can ask questions about Frank @ SGU RV7A Panel/Electrical >From: "Frank Stringham" <fstringham(at)hotmail.com> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: RE: S700 2-50 Switch / Electric Fuel Pump >Date: Sat, 14 Jul 2007 15:28:52 -0600 > > > >Finishing up the switch wiring on my RV7A Panel. I am using Z13/8 to wire >the aircraft. I am using the S700 2-50 switch to activiate my electric fuel >pump. The momentary switch up side primes the engine and the full on down >would be used incase of the primary fuel pump failure. The engine id fuel >injected. Now the question. I am not quite sure how to wire this switch up >to make all of this happen..... > >Frank @ SGU RV7A Panel/Wiring just about ready to hang the >engine....when he gets here!!! > >_________________________________________________________________ >http://liveearth.msn.com > > _________________________________________________________________ Need a brain boost? Recharge with a stimulating game. Play now! http://club.live.com/home.aspx?icid=club_hotmailtextlink1 ________________________________________________________________________________
From: "Christopher Barber" <CBarber(at)TexasAttorney.net>
Subject: Switch guards, switch locks, locking switches?
Date: Jul 14, 2007
My project is an all electric bird (Velocity SE) with a rotary engine. Since if I loose power things get quite I am using Bob's duel alternator/duel battery set up. What I am curious about is the switches in the cabin. Currently I have all the switches up high on the panel a bit right of center towards the co-pilot position. I hope to not have a passanger who would inadvertanlty flip a switch down and off, HOWEVER, you never know what may get tangled or a stray move may flip a switch....in my set up, if my coil switch or primary injectors get switched off I will start sweating. Also, I don't really mind the switches where they are, but I do have a couple of other places I would like them, but I placed them here as to minimize being bumped. My question is what other options do I have to either guard against accidental deactivation. I have purchased a couple of aviation locking toggles from ebay, but they are kinda small and may not be up for the task (but at $13.00 I couldn't go too wrong...they may work for my coil switch and primary fuel). The regulare priced DPDT (for my contactors and injectors) seem to start at close to $60.00 a piece...a bit much for my police salery if other options will surfice. I have also considered those installing some of the switch guards you see in old nuclear missle bunker movies that they would open to expose the firing buttons for the big ol' missles. I considered installing them upside down (which is really easy) so that they are on when the cover is closed thus making the switch impossible to turn off by mistake. This seems really fool proof, however, the guards, while cheap, are pretty big and do not look all that, well, elligant. Also, I was watching the Astronaut Farmer last night on PPV and saw the little hard wire loops that where installed next to the switches on each side of the individual switches in his space capsule and this reminded me of the ones NASA used to use....maybe still do. Donno. These seem to be just half circles that make grabbing the switch very deliberate and minimizes potential knocks. Finally, it seems as if I have seen bars held in by springs that lay across a series of switches to keep them in place. What say ye? Insight? Wisdom? Warnings? Observations? WAG's? Thanks. All the best, Chris Barber Houston ________________________________________________________________________________
Date: Jul 14, 2007
Date: Jul 14, 2007
Subject: Re: Switch guards, switch locks, locking switches?
You might look at www.PerihelionDesign.com<http://www.periheliondesign.com/> for switch guards...... -- John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Jul 15, 2007
Saw this on eBay. Expensive but a possibility. http://cgi.ebay.com/ebaymotors/New-Reproduction-NASA-Space-Shuttle-Switch -Guards_W0QQcmdZViewItemQQcategoryZ50466QQihZ008QQitemZ180138370945QQrdZ1 Raymond Julian Kettle River, MN ----- Original Message ----- From: Christopher Barber To: aeroelectric-list(at)matronics.com Sent: Saturday, July 14, 2007 8:26 PM Subject: AeroElectric-List: Switch guards, switch locks, locking switches? My project is an all electric bird (Velocity SE) with a rotary engine. Since if I loose power things get quite I am using Bob's duel alternator/duel battery set up. What I am curious about is the switches in the cabin. Currently I have all the switches up high on the panel a bit right of center towards the co-pilot position. I hope to not have a passanger who would inadvertanlty flip a switch down and off, HOWEVER, you never know what may get tangled or a stray move may flip a switch....in my set up, if my coil switch or primary injectors get switched off I will start sweating. Also, I don't really mind the switches where they are, but I do have a couple of other places I would like them, but I placed them here as to minimize being bumped. ________________________________________________________________________________
Subject: Connecting Shieled Wires
Date: Jul 15, 2007
I'm looking for information about connecting two shielded wires together. Example inputs from other sources to a PMA 8000 audio panel: Should the shields be butt spliced along with the other wires into a one big mess? Should all wires and shields be connected with Sub D connectors? Should the shields be left cut and unattached? Are there other methods? Thanks in advance for any input. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Jul 15, 2007
In a message dated 7/15/2007 2:30:57 A.M. Central Daylight Time, raymondj(at)frontiernet.net writes: Saw this on eBay. Expensive but a possibility. _http://cgi.ebay.com/ebaymotors/New-Reproduction-NASA-Space-Shuttle-Switch-Gua rds_W0QQcmdZViewItemQQcategoryZ50466QQihZ008QQitemZ180138370945QQrdZ1_ (http://cgi.ebay.com/ebaymotors/New-Reproduction-NASA-Space-Shuttle-Switch-Guards_W0Q QcmdZViewItemQQcategoryZ50466QQihZ008QQitemZ180138370945QQrdZ1) Raymond Julian Kettle River, MN Did you note that this is our own Eric Jones (PerihelionDesign.com)? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 15, 2007
I sell the half-loop and the space shuttle guards on my website. In fact NASA and millitary now buys them from me. (Perihelion Design has "parts in orbit"...when I mentioned this to a friend he said that HE had "parts that left the solar system on two Voyagers"...so you can't win). I call the half-loop guards NASA X-plane guards, but they were also used on many aircraft. The flip-up toogle guards (non-mil spec) in many colors are being sold almost for FREE on MPJA: http://www.mpja.com/prodinfo.asp?number=16100+SW "Ring the bells that still can ring; Forget your perfect offering! There is a crack in everything; That's how the light gets in." ---Leonard Cohen -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123898#123898 ________________________________________________________________________________
Date: Jul 15, 2007
Subject: Re: Connecting Shieled Wires
At 03:29 7/15/2007, you wrote: >I'm looking for information about connecting two shielded wires together. > >Example inputs from other sources to a PMA 8000 audio panel: >Should the shields be butt spliced along with the other wires into a one big >mess? >Should all wires and shields be connected with Sub D connectors? >Should the shields be left cut and unattached? >Are there other methods? Without a bit more information, this can have a number of solutions, but I believe one can safely say regarding microphone lines; They should be one continuous run from the microphone source, or jack, to the input of the amplifier. This does not preclude intermediate connectors and cable segments, but the shield should remain connected to itself throughout the length, and should not have connections to other shields or the airframe except at a single point, the input to the amplifier at the audio panel/intercom. A shield cut and unattached at either end is no longer a shield. Ron Q. ________________________________________________________________________________
Date: Jul 15, 2007
Aerotronics, in Montana, supplies rocker switches that live behind transparent, springloaded doors. W-a-a-a-y Cool! www.aerotronics.com , Kit Panels, New Glasair, Steve Thomas' Panel , lower left corner. ________________________________________________________________________________
Date: Jul 15, 2007
No, I must admit, I didn't. I got to the price and quit reading. Raymond Julian Kettle River, MN. ----- Original Message ----- From: BobsV35B(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Sunday, July 15, 2007 7:28 AM Subject: Re: AeroElectric-List: Switch guards, switch locks, locking switches? In a message dated 7/15/2007 2:30:57 A.M. Central Daylight Time, raymondj(at)frontiernet.net writes: Saw this on eBay. Expensive but a possibility. http://cgi.ebay.com/ebaymotors/New-Reproduction-NASA-Space-Shuttle-Switch -Guards_W0QQcmdZViewItemQQcategoryZ50466QQihZ008QQitemZ180138370945QQrdZ1 Raymond Julian Kettle River, MN Did you note that this is our own Eric Jones (PerihelionDesign.com)? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 ------------------------------------------------------------------------- ----- Get a sneak peak of the all-new AOL.com. ________________________________________________________________________________
Date: Jul 15, 2007
Yep, I think I am gonna go with your half loop x-plane solution. Kinda like the "retro-futuristic" look. May place my online order in just a bit. Thanks guys. All the best, Chris www.LoneStarVelocity.com Christopher Barber Attorney and Counselor at Law 5110 Bissonnet, No 418 Bellaire, Texas 77401 Serving the Needs of Senior Texans 281-464-LAWS (5297) 281-754-4168 Fax www.TexasAttorney.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Eric M. Jones Sent: Sunday, July 15, 2007 7:34 AM Subject: AeroElectric-List: Re: Switch guards, switch locks, locking switches? I sell the half-loop and the space shuttle guards on my website. In fact NASA and millitary now buys them from me. (Perihelion Design has "parts in orbit"...when I mentioned this to a friend he said that HE had "parts that left the solar system on two Voyagers"...so you can't win). I call the half-loop guards NASA X-plane guards, but they were also used on many aircraft. The flip-up toogle guards (non-mil spec) in many colors are being sold almost for FREE on MPJA: http://www.mpja.com/prodinfo.asp?number=16100+SW "Ring the bells that still can ring; Forget your perfect offering! There is a crack in everything; That's how the light gets in." ---Leonard Cohen -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123898#123898 ________________________________________________________________________________
Date: Jul 15, 2007
Slight correction to John's comment below. The switches behind the clear plastic spring-loaded doors are push-button switches, not rocker. They are SPST, and so have limited application. However, I'm using them for my ignition switches, one left and one right on a Z-14 architecture. But they are indeed way-cool! Best Regards, Steve Thomas ____________________________________________________________________ On Jul 15, 2007, at 10:50 AM, John Burnaby wrote: > Aerotronics, in Montana, supplies rocker switches that live behind > transparent, springloaded doors. W-a-a-a-y Cool! > www.aerotronics.com , Kit Panels, New Glasair, Steve Thomas' > Panel , lower left corner. > > > forums.matronics.com_- > =========================================================== > ________________________________________________________________________________
Date: Jul 15, 2007
Chris, <> Mouser (mouser.com) has medium capacity locking toggle switches at reasonable cost. For example their NKK SPST (633-S1AL-RO) is rated at 20 amps DC for $10.25. I like the looks of the handle on this switch. Mouser gives excellent service and they don't mind small orders. Tom Kuffel ________________________________________________________________________________
Subject: Belly antenna
Date: Jul 15, 2007
Hello, As an omnidirectional antenna radiates at right angle, a belly bent whip antenna should radiate in a plan at right angle of the aircraft longitudinal axis. Hence the range should be very limited compared to a vertical antenna... Does somebody know if this is the case or not ? Thanks in advance for your science :-) Philippe RV9A Brussels - Belgium ________________________________________________________________________________
Date: Jul 15, 2007
Subject: Re: Belly antenna
Bent belly whip antenna is slightly compromised in the vertical polarization plane for com signals but hardly a noticeable difference from a straight whip. John Greaves VariEze N81JG ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 15, 2007
Raymond <> <> Pull handle out, move to desired position, release. They lock in all positions (two for on-none-on or on-none-off and three for on-off-on). Tom Kuffel ________________________________________________________________________________
Date: Jul 15, 2007
Thanks Tom. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst" ----- Original Message ----- From: "The Kuffels" <kuffel(at)cyberport.net> Sent: Sunday, July 15, 2007 4:41 PM Subject: Re: AeroElectric-List: Switch guards, switch locks, locking switches? > > > Raymond > > < lock/unlock ( I'm guessing pull out) and if they lock in one or both > positions>> > > <> > > Pull handle out, move to desired position, release. They lock in all > positions (two for on-none-on or on-none-off and three for on-off-on). > > Tom Kuffel > > > ________________________________________________________________________________
Date: Jul 15, 2007
Bent or sloping whip makes virtually no difference. The ground plane is still flat, the magnetic component of the radiated field is caused by current flow, most of which occurs in the first third of the whip, so this portion is the area to leave straight. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123983#123983 ________________________________________________________________________________
Date: Jul 15, 2007
You can be sure anything painted red or with obvious guards will be tested by your passengers! Mixture controls in Cessnas are a favourite target. I would go for the purple or blue "missile switches" although the genuine MS25224-1 I used to control a turbine are nicer to look at and handle. The flip covers referred to are probably Honeywell push switches, we have loads of them at work, they have a stack of microswitches operated by a paddlewheel from the pushbutton. Trouble is, if the illumination lights fail, its hard to tell if they are set to on or off position. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=123987#123987 ________________________________________________________________________________
Date: Jul 15, 2007
Subject: Re: Z-19
Thanks a million Bob, my days with the Saturn V moon rocket, triple module redundancy, sometimes rears it's head. Think I will go with your original diagram. Paul ************************************** Get a sneak peak of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Landing Taxi lights wig wag
Date: Jul 15, 2007
I had a problem today that I cannot solve. I hooked up the landing and taxi lights through a SSF1 flasher according to one of Bobs diagrams The system uses 2 2-10 switches with middle position for wig wag. The lights are Duckworth 100 watt with the wire from the lamps going to ground on the last rib along with the grounds for the nav lights Connected a battery to the main buss and forest of grounds. The landing light works but the taxi light fuse (7.5A) blew and the flasher did not work I removed the wires from the flasher and again the landing light worked and the taxi light fuse blew. I reversed the wires at the taxi light with the light filament wire now going to the switch and the light housing wire going to ground. The reversed filament wire was connected the the switch wire with a clip wire and the ground wire was connected to gnd point without the nav ground. Everything worked- Taxi-Landing light and wig-wag I then connected the wires for final connection using knife splices and a ring terminal for the ground. Hooked the battery back up and nothing works not even the landing light. The fuses are not blown, the panel instruments and nav lights work. The flasher buzzes when the landing light is off and the Taxi light switch moves through the middle position. The only difference was hooking the nav ground back up at the same time. I don't have enough knowledge to know if this could cause the problem. Thanks for any advice or information Jerry Forrest RV6A ________________________________________________________________________________
Date: Jul 16, 2007
Subject: Re: Z-19
>Thanks a million Bob, my days with the Saturn V moon rocket, triple module >redundancy, sometimes rears it's head. Think I will go with your original >diagram. >Paul Understand. I have a client right now that believes it is better to have two position sensors for a flap system than just one. I'm trying to help him understand that if you can design your system to be tolerant of any single failure then one sensor by definition will suffice. If failure of the pilot to KNOW flap position at all times creates a strong potential for hazard, then you need THREE sensors and a validity evaluation system that compares all three data values, tosses out the one that is bad and annunciates the failure (cause we're now down to two . . . one more sensor crap and we're toast). Two sensors in a fail-proof approach is not sufficient. Figure Z-19 presupposes that all the things I think I understood about engine operations are true at the time I crafted the diagram. If some new condition or requirement comes along concerning these automotive conversions (or I mis-understood some feature that has always existed) then some shuffling of the switches and wires may be in order. So I hope that you nor anyone else here on the List believes that Z-19 or any other architecture is somehow sacred, golden, or guaranteed to please for ever and ever amen. It's ALWAYS good to question and to raise your own alarms should you perceive that common understanding of requirements has not yet been achieved. This is why I always query an individual about perceptions of shortfall when changes to the Z-figures are suggested. I and everyone else on the List NEEDS TO KNOW when some new, useful or necessary feature is called for. So please don't take my questioning as some defense of my ideas at the expense of your own. Our common goal should be the elegant solution. Maximize functionality and safety with the minimum of parts count, weight and cost while keeping operating procedures as simple as we can. When things are going sour in the cockpit, you don't want a feature of poor human factors design adding to your misery. Bob . . . ________________________________________________________________________________
Subject: Dual HSI/CDI wiring question
Date: Jul 16, 2007
Can the analog GPS/Nav/ILS output from the GNS430 be spliced to drive a HSI(pilot side) and a separate CDI(Co-Pilot side) at the same time? Thanks, ERic-- RV-10, N104EP ________________________________________________________________________________
Date: Jul 16, 2007
Subject: Re: Landing Taxi lights wig wag
> > >I had a problem today that I cannot solve. >I hooked up the landing and taxi lights through a SSF1 flasher >according to one of Bobs diagrams >The system uses 2 2-10 switches with middle position for wig wag. >The lights are Duckworth 100 watt with the wire from the lamps going >to ground on the last rib along with the grounds for the nav lights >Connected a battery to the main buss and forest of grounds. Don't understand this. Have you grounded lamp fixtures to the airframe locally . . . and then added another wire from vicinity of lamps to the forest of tabs ground block too? You need only one ground. Either from each accessory to the firewall ground block -OR- local grounds to an all metal airframe but not both. >The landing light works but the taxi light fuse (7.5A) blew and the >flasher did not work >I removed the wires from the flasher and again the landing light >worked and the taxi light fuse blew. Fuses blow because of failure of some pieced of equipment on the protected line (rare) or some wiring fault that has produced a hard ground. In this case, the later condition is probable . . . >I reversed the wires at the taxi light with the light filament wire >now going to the switch and the light housing wire going to ground. >The reversed filament wire was connected the the switch wire with a >clip wire and the ground wire was connected to gnd point without the >nav ground. >Everything worked- Taxi-Landing light and wig-wag Yup, the fixture appears to have an internal ground connection to one of the lamp terminals. The wire coming from the lamp housing should go to local ground only. The free filament wire now goes to the switch. >I then connected the wires for final connection using knife splices >and a ring terminal for the ground. >Hooked the battery back up and nothing works not even the landing >light. The fuses are not blown, the panel instruments and nav lights >work. >The flasher buzzes when the landing light is off and the Taxi light >switch moves through the middle position. > >The only difference was hooking the nav ground back up at the same >time. I don't have enough knowledge to know if this could cause the >problem. Assuming your switches are properly identified for terminal connections (see Note 15 on page Z-9) then the only thing that could prevent this system from working as advertised is a wiring error. If your fixtures have internal grounds, you need to make sure that same lead goes to local ground . . . this should stop the fuse blowing thing. I believe that flasher doesn't like to be loaded on one output terminal only. BOTH switches need to be in WW (mid position) for the flasher to function as designed. I think you have one or more wiring errors. Bob . . . ________________________________________________________________________________
Subject: Flap switch
Date: Jul 16, 2007
Can a Cessna flap switch be used instead of the Ray Allan switch for a trim servo??? If so does someone have a wiring diagram?? Thanks Dale ----- ________________________________________________________________________________
Date: Jul 16, 2007
> >At 03:29 7/15/2007, you wrote: >>I'm looking for information about connecting two shielded wires together. >> >>Example inputs from other sources to a PMA 8000 audio panel: >>Should the shields be butt spliced along with the other wires into a one big >>mess? >>Should all wires and shields be connected with Sub D connectors? >>Should the shields be left cut and unattached? >>Are there other methods? > >Without a bit more information, this can have a number of solutions, but I >believe one can safely say regarding microphone lines; > >They should be one continuous run from the microphone source, or jack, to >the input of the amplifier. This does not preclude intermediate >connectors and cable segments, but the shield should remain connected to >itself throughout the length, and should not have connections to other >shields or the airframe except at a single point, the input to the >amplifier at the audio panel/intercom. > >A shield cut and unattached at either end is no longer a shield. Not quite true. Shields should be terminated as shown in the installation wiring diagrams. Sometimes one end only is connected, sometimes both ends. Follow directions. The only time a shield ceases to function as intended is when BOTH ends are floating. If a shielded line needs to be taken through a connector, give the shield it's own pin. I.e., a shielded, twisted trio of wires takes 4 pins to transition a connector. Don't struggle to bring shields "up tight" against the back of a connector housing. Exposing 2-3 inches of "protected" conductors on a connector installation is no big deal. Make all your shield terminations outside the connector backshell so that only individual strands of wire pass through the strain relief and into the connector. Bob . . . ________________________________________________________________________________
Date: Jul 16, 2007
Subject: jumping on the big iron bird again.
Will be off-list for the rest to today thru Wednesday this week. I'll leave things in the capable hands of others who have demonstrated their skills as teachers . . . and others who have yet to discover that they have the gift too. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 16, 2007
Subject: Re: Flap switch
> >Can a Cessna flap switch be used instead of the Ray Allan switch for a >trim servo??? If so does someone have a wiring diagram?? Thanks Dale >----- Cessna has lots of flap switches. One of them may be what you're looking for but you can make one really easy too. See: http://www.aeroelectric.com/Pictures/Switches/Flap_Switch.jpg Bob . . . ________________________________________________________________________________
Date: Jul 16, 2007
> >Can a Cessna flap switch be used instead of the Ray Allan switch for a >trim servo??? If so does someone have a wiring diagram?? Thanks Dale >----- Cessna has lots of flap switches. One of them may be what you're looking for but you can make one really easy too. See: http://www.aeroelectric.com/Pictures/Switches/Flap_Switch.jpg http://www.aeroelectric.com/Pictures/Switches/FLAPS1.JPG http://www.aeroelectric.com/Pictures/Switches/FLAPS2.JPG http://www.aeroelectric.com/Pictures/Switches/FLAPS3.JPG http://www.aeroelectric.com/Pictures/Switches/Toggle_Shaft.jpg Bob . . . ________________________________________________________________________________
Date: Jul 16, 2007
At 07:50 7/16/2007, you wrote: My poor wording: "unattached at either end" = not connected at either end. I think we totally agree. Ron. >>A shield cut and unattached at either end is no longer a shield. > > Not quite true. Shields should be terminated as shown in > the installation wiring diagrams. Sometimes one end only is > connected, sometimes both ends. Follow directions. The only > time a shield ceases to function as intended is when BOTH > ends are floating. ________________________________________________________________________________
Date: Jul 16, 2007
Subject: switching from Z-11 to Z-13
----- Original Message ----- From: Michael T. Ice Sent: Wednesday, July 11, 2007 10:04 PM Subject: AeroElectric-List: switching from Z-11 to Z-13 Hello, I have already wired my aircraft with the Z-11 schematic. But now I am switching to E-mags ( 1 P-Mag & 1 E-mag) and need to rewire towards the Z-13 schematic. My questions are: Can the 2-10 switch be used as the Dc Power master switch instead of the 2-3. I see in the Z-13 the 5 A Fld Alt is on the other side of the switch. Why? Can I just leave the 2-10 in place as wired in the Z-11 and will it work for the 2-3 in the Z-13? I see the 2-10 switches in the Z-11 that were used for mag switches are now 2-5 in the Z-13. Is there any way to use the 2-10's, or are the 2-5's so different that I have to use them? Or should I just order the new switches from B&C and wire them in like the Z-13? I also see that the mags in the Z-11 required shielded wire. It looks like the E-Mags don't require shielded wire. Is that correct? Why? Thank you, Mike Ice Anchorage, Alaska ________________________________________________________________________________
Date: Jul 16, 2007
Thanks Bob,, Now would you have a wiring diagram to wire the switch up ,, instead of using the rocker switch that came with the servo??? Thanks Dale ----- Original Message ----- ________________________________________________________________________________
Date: Jul 16, 2007
I use blade-type ATO fuses and by simply removing the com circuit's fuse and replacing it with a new one, the problem went away. The one I removed ohmed out like all the others, so I suspect it was perhaps that the fuse had dislodged itself slightly in the fuse block. Checking the most accessible and simplest issue seems to have worked. Thanks for all the feedbacks. David ________________________________________________________________________________
Subject: Re: best contactor reliability -- mechanical, solid
state, or ma
Date: Jul 16, 2007
I just ran across these. They should do. They are a little more expensive than the GX-11 or the Blue Sea 9012 (Kilovac EV200aaana). Frankly I can't see an advantage unless you find them on sale. http://www.omron.com/ecb/products/pdf/en_g9ea_ec.pdf Interesting note on coil suppressor from the Omron data sheet: They caution that a varistor or a Zener plus diode should be used as a protective circuit for the coil. "Using a diode alone will reduce the switching characteristics." Never use diodes for this purpose on relays, especially contactors. "What the West really has to offer is honesty. Somehow, in the midst of their horrid history, the best among the Gaijin learned a wonderful lesson. They learned to distrust themselves, to doubt even what they were taught to believe or what their egos make them yearn to see. To know that even truth must be scrutinized, it was a great discovery.... " -- David Brin, "Dr. Pak's Preschool" -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124190#124190 ________________________________________________________________________________
Subject: Garmin GA 27c low profile GPS Antena Cable extension?
Date: Jul 16, 2007
I have a Garmin GA 27c low profile GPS Antenna [ Part number 010-10052-05 ]and I need to extend the antenna lead. Has any one done this before and how did it work out? What did you use? Per the box it has: 8 feet of RG174 cable with MCX connector I would like to use rg-400 but do not know how to connect them properly, the GPS does use the small MCX connector, anybody have a source for that? plus I would need a disconnect at the wing root. Thanks in advance Jeff. ________________________________________________________________________________
Subject: Re: GTX327 power switching
Date: Jul 16, 2007
I'm having the same problem as Sam as detailed in his email below. Does anyone have a solution to this? I've tried adjusting contrast/brightness with no affect. Thanks, Mike Creek -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of phd1993 Sent: Wednesday, November 15, 2006 7:59 PM Subject: AeroElectric-List: Re: GTX327 power switching I have been bench/panel testing my GTX327 during cable assembly prior to final installation in my panel and I can confirm the Pin 1 / Pin 15 configurations. Now my question - if I have power supplied via Pin 15 and ground on Pin 25 WITHOUT connecting either the transponder antenna or the altitude encoder what should the GTX327 display at power on? How about power on while holding down the FUNC button. All I am getting is the "backpanel" illuminated with no other display items. Is this proper? Or do I need to connect either the antenna, the altitude encoder, or both before I start seeing any items displayed on the panel? Feedback appreciated. Thanks, Sam H. Zenith 701 kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=74927#74927 ________________________________________________________________________________
Date: Jul 16, 2007
Subject: Figure z-19
Z-19 doesn't appear to be on my Aeroelectric CD, and I can't find it online. Would anyone happen to have a close approximation in DXF format that they'd like to share? DWG appears to be a more advanced file format with the ability to add 3D information. Most of the lower rung/open source CAD programs don't like it (maybe because the company added closed, proprietary extensions that can't be read without paying Autodesk a royalty). I'm using Kubuntu, and Wine isn't working well with the Windows programs on the CD. ________________________________________________________________________________
Subject: KMD 150 Install manual needed
Date: Jul 16, 2007
I need an install manual for my KMD 150. Thanks in advance, Jim Bowen _________________________________________________________________ http://liveearth.msn.com ________________________________________________________________________________
Date: Jul 16, 2007
Subject: Re: RV-List: KMD 150 Install manual needed
JAMES BOWEN wrote: > --> RV-List message posted by: "JAMES BOWEN" > > I need an install manual for my KMD 150. Thanks in advance. > Jim Bowen I thought about scanning my copy and sending it to you, then thought "Hmmmm, wonder what Google says?" (I've tried before to find it soft copy on the web, but never had any luck.) Both the installation manual and pilot's guide are here: http://www.seaerospace.com/king/kmd150.htm Steve (now with a soft copy IM to back up my hard copy!) ________________________________________________________________________________
Date: Jul 17, 2007
Subject: Re: best contactor reliability -- mechanical, solid,state,
or manual? The system is 25 ADC (worst case) at 28 VDC with a nominal load of about 17 ADC. The spec environment (vibe, temp) is similar to the Summer cockpit of my C150 with a prop that needs to be dynamically balanced. Worse than a lab bench but better than under the hood of a Hummer. All components are rated for -40 C to +85 C (operating) thus far. Unfortunately, there are no "non-critical" components in the system so ANY power loss is bad news. Again, I'm trying to weigh the pros/cons of mechanical, solid-state, or manual master battery contactors for this application. I considered using parallel contactors (as suggested here) to avoid the single point contactor failure but found myself staring down the slippery slope of increased parts count and complexity. Perhaps the "best" answer is a manual contactor with dual contacts (one of those big 1/2/Both switches). ??? Any guidance (including "shut up, quit worrying, and use the darn can!") will be appreciated. :-) D -------------------- >>> I have a remotely operated application where the loss of the master >>> battery contactor will result in the loss of data/money/time (... >>> and dignity!). My baseline design resembles a "Z" diagram (thanks >>> Bob!) and I planned to use a mechanical, continuous duty contactor >>> like the S-701 from B&C. However, a buddy of mine recently >>> experienced a contactor failure in flight and it caused me to >>> experience a few "What If!?" nightmares. I'm back to reconsidering >>> my original decision... > > Help us with a bit more information about your application. > What kind of vehicle? What kind of environment? What's the > energy requirement to maintain data in vulnerable systems. > It's often much easier to arrange for brownout and/or momentary > power loss for a few items than to back-up the whole system. > Finally, it's almost always better to have a plan-a/plan-b > modus operandi than to scratch around for "more reliable" > hardware. EVERYTHING will break at some point in time. > > Give us a rundown of your equipment that must stay awake > and what the power requirements are. > > Bob . . . ________________________________________________________________________________
Subject: Re: KMD 150 Install manual needed
Date: Jul 17, 2007
-------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124315#124315 ________________________________________________________________________________
Date: Jul 17, 2007
I think what you need is what I sell lots of--the True Servo Conversion for MAC/RACs. TSCMR. This is a teeny module that converts the external position signal that you get from a voltage divider potentiometer or even a bank of push buttons to control a MAC or RAC trim box. See: http://tinyurl.com/2qo222 These are the parts they left out of the trim box that would have made it a servo. This also solves the problem of how to connect all those tiny trim box wires. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124343#124343 ________________________________________________________________________________
Date: Jul 17, 2007
Found out my problem was low input power voltage below 10. With proper voltage, everything works fine. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michel Creek Sent: Monday, July 16, 2007 8:22 PM Subject: RE: AeroElectric-List: Re: GTX327 power switching I'm having the same problem as Sam as detailed in his email below. Does anyone have a solution to this? I've tried adjusting contrast/brightness with no affect. Thanks, Mike Creek -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of phd1993 Sent: Wednesday, November 15, 2006 7:59 PM Subject: AeroElectric-List: Re: GTX327 power switching I have been bench/panel testing my GTX327 during cable assembly prior to final installation in my panel and I can confirm the Pin 1 / Pin 15 configurations. Now my question - if I have power supplied via Pin 15 and ground on Pin 25 WITHOUT connecting either the transponder antenna or the altitude encoder what should the GTX327 display at power on? How about power on while holding down the FUNC button. All I am getting is the "backpanel" illuminated with no other display items. Is this proper? Or do I need to connect either the antenna, the altitude encoder, or both before I start seeing any items displayed on the panel? Feedback appreciated. Thanks, Sam H. Zenith 701 kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=74927#74927 ________________________________________________________________________________
Date: Jul 17, 2007
Subject: Re: Figure z-19
Ernest, Attached is a dxf file of the original Z19. If you want the rear battery option let me know and I will send it to you. Paul LeDoux Sharpsburg, Ga. RV-8 in progress ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 17, 2007
Guys, I made myself a 12v power supply for the garage/hangar from an old computer power supply to get over the problem of low voltage problems. Needs some internal surgery to install an on-off switch (5 mins on Google provided the answer as most power supplies now switch off on a signal from the mother board). Runs for ever, stabilized voltage (that I believe can be tweaked up to 13 or 14v, but I haven't found out how) and can deliver up to about 20A. Means that I don't have to charge a battery all the time and I can buy a fresh PC680 just before I'm ready to go flying. Peter RV-6A, DR-107 & RV-7 (building) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michel Creek Sent: 17 July 2007 16:14 Subject: RE: AeroElectric-List: Re: GTX327 power switching Found out my problem was low input power voltage below 10. With proper voltage, everything works fine. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michel Creek Sent: Monday, July 16, 2007 8:22 PM Subject: RE: AeroElectric-List: Re: GTX327 power switching I'm having the same problem as Sam as detailed in his email below. Does anyone have a solution to this? I've tried adjusting contrast/brightness with no affect. Thanks, Mike Creek -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of phd1993 Sent: Wednesday, November 15, 2006 7:59 PM Subject: AeroElectric-List: Re: GTX327 power switching I have been bench/panel testing my GTX327 during cable assembly prior to final installation in my panel and I can confirm the Pin 1 / Pin 15 configurations. Now my question - if I have power supplied via Pin 15 and ground on Pin 25 WITHOUT connecting either the transponder antenna or the altitude encoder what should the GTX327 display at power on? How about power on while holding down the FUNC button. All I am getting is the "backpanel" illuminated with no other display items. Is this proper? Or do I need to connect either the antenna, the altitude encoder, or both before I start seeing any items displayed on the panel? Feedback appreciated. Thanks, Sam H. Zenith 701 kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=74927#74927 ________________________________________________________________________________
Subject: Re: Low transmit volume on Valcom 760
From: "privatepilot03" <cjstenson(at)ameritech.net>
Date: Jul 17, 2007
I couldn't sign up to the forums with my avidflyerss screen name for some reason, so I created this one. Anyway, I tried adjusting the gains on both the radio and headset with little if any improvement. At this point, I'm leaving everything as is until I get the plane done and actually try it at the airport and in the air. Maybe it's fine, I don't know, but it sure seems quiet to me. Thanks Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124381#124381 ________________________________________________________________________________
Date: Jul 17, 2007
PSILeD(at)aol.com wrote: > Ernest, > > Attached is a dxf file of the original Z19. If you want the rear > battery option let me know and I will send it to you. > > Paul LeDoux > Sharpsburg, Ga. > RV-8 in progress > > > Get a sneak peek of the all-new AOL.com > <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982>. I'm good now (heh, just my opinion). I've been able to load the file into QCad and do some editing. I also found dwg2dxf. There was only an RPM, but I used alien to convert it to a deb file (Linux file installation formats). "dpkg -i" installed the deb without any other arguments. So I'm cooking with gas now. Thanks, guys. ________________________________________________________________________________
Date: Jul 17, 2007
I'm going to use Aeroelectric suggestion :-) The problem is finding the switch. The type of the one received with the Van's kit is as hard to toggle as a contactor ! The genuine Cessna switch is awfully expensive !!! Philippe -----Message d'origine----- De : owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] De la part de Dale Fultz Envoy : lundi 16 juillet 2007 15:47 : aeroelectric-list(at)matronics.com Objet : AeroElectric-List: Flap switch --> Can a Cessna flap switch be used instead of the Ray Allan switch for a trim servo??? If so does someone have a wiring diagram?? Thanks Dale ----- ________________________________________________________________________________
Date: Jul 17, 2007
I have a genuine Cessna 150 switch. I just need to find out if it can be wired into the system instead of using the supplied switch from Ray Allen that was with the servo.. ----- Original Message ----- ________________________________________________________________________________
Date: Jul 18, 2007
Eric the subject is a flap motor not a MAC servo. Peter Laurence ----- Original Message ----- From: "Eric M. Jones" <emjones(at)charter.net> Sent: Tuesday, July 17, 2007 10:35 AM Subject: AeroElectric-List: Re: Flap switch > > > I think what you need is what I sell lots of--the True Servo Conversion > for MAC/RACs. TSCMR. This is a teeny module that converts the external > position signal that you get from a voltage divider potentiometer or even > a bank of push buttons to control a MAC or RAC trim box. > > See: http://tinyurl.com/2qo222 > > These are the parts they left out of the trim box that would have made it > a servo. This also solves the problem of how to connect all those tiny > trim box wires. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=124343#124343 > > > ________________________________________________________________________________
Date: Jul 18, 2007
From: "George, Neal E Capt MIL USAF 605TES/TSI" <Neal.George(at)hurlburt.af.mil>
Peter - If I understand the descriptions... Eric's TSCMR, when combined with RAC's position sensor (attached to the flap mechanism), can be configured to approximate the Cessna-style set-forget flap switch. ************************ Eric the subject is a flap motor not a MAC servo. Peter Laurence > > I think what you need is what I sell lots of--the True Servo Conversion > for MAC/RACs. TSCMR. This is a teeny module that converts the external > position signal that you get from a voltage divider potentiometer or even > a bank of push buttons to control a MAC or RAC trim box. > > See: http://tinyurl.com/2qo222 > > These are the parts they left out of the trim box that would have made it > a servo. This also solves the problem of how to connect all those tiny > trim box wires. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net ________________________________________________________________________________
Date: Jul 18, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> >I have a genuine Cessna 150 switch. I just need to find out if it can >be wired into the system instead of using the supplied switch from Ray >Allen that was with the servo.. Cessna had a LOT of different flap controls. Need a photo, p/n, perhaps a schematic of the system it came out of. Baring that detail of data, you can send me the switch and I'll deduce its suitability to task. Bob . . . ________________________________________________________________________________
Date: Jul 18, 2007
Subject: AUDIO ISOLATION AMP PC BOARD
Bob, I ordered a PC board on July 6 and received a email confirmation that I would be getting an email with instructions on how to make payment. Nothing yet. Have tried to reach you via phone, email and email via your web site. Do you still supply the boards? Regards, Wally Hunt Rockford, IL RV-4 Finishing Kit 815-262-3153 ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 19, 2007
Subject: Re: AUDIO ISOLATION AMP PC BOARD
>Bob, > >I ordered a PC board on July 6 and received a email confirmation that I >would be getting an email with instructions on how to make >payment. Nothing yet. Have tried to reach you via phone, email and email >via your web site. > >Do you still supply the boards? > >Regards, > >Wally Hunt >Rockford, IL Yessir! Sorry about the delay. We've been out of town a lot and got behind on order fulfillment. Your board goes out today and I've sent you a Paypal invoice. Bob . . . ________________________________________________________________________________
Date: Jul 19, 2007
> Eric's TSCMR, when combined with RAC's position sensor (attached to the > flap mechanism), can be configured to approximate the Cessna-style > set-forget flap switch. By the time one buys the separate products and wires them together, wouldn't it just be a lot simpler and probably cheaper to just buy an FPS-Plus-nt (http://www.aircraftextras.com/ ) for $200 and plug and play?john ________________________________________________________________________________
Date: Jul 19, 2007
Subject: Perihelion
I just want to comment on excellent service by Eric Jones of Perilhelion Design. I ordered 3 switch guards last Sunday, got notice of shipping the same day (!) and received same Wednesday... These are the CNC-machined ones and are bee-yoo-tiful!! Thanks Eric, may you live long and prosper!! Jerry Cochran ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 19, 2007
Subject: Watson AHRS
Is anybody on the list using the Watson AHRS with their Chelton/Sierra Flight Systems EFIS? I have a Chelton EFIS-SV and Watson but have not installed it yet. I'd be interested in your comments on the Watson unit? Are you still using it or have you upgraded to Crossbow or Pinpoint? Many thanks in advance..... -- John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Jul 19, 2007
Subject: VOR whiskers antenna balun available
Some months ago I fabricated a VOR antenna balun for "whiskers" so that I could illustrate an article on the topic which I published at: http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html This device is surplus to me and I'd like to sell it. First direct e-mail to me with a $20.00 offer + $2.00 postage gets it. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Subject: RE:Oshkosh
Date: Jul 19, 2007
Will you be at Oshkosh? If so, how can I find you? Gordon Comfort ________________________________________________________________________________
Date: Jul 19, 2007
Subject: Re: RE:Oshkosh
Yes. Thursday through Sunday. I'm doing two presentations. One on Thursday afternoon and one on Friday night. My cell phone is (316) 209-7528. Looking forward to seeing you guys again! Bob . . . > >Will you be at Oshkosh? If so, how can I find you? > >Gordon Comfort > > > ><http://www.matronics.com/Navigator?AeroElectric-List>http://www.matronics.com/Navigator?AeroElectric-List > > >incoming mail is certified Virus Free. >Checked by AVG. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 19, 2007
MessageYup, driving over on Tuesday staying until Sat. or Sun. I will probably be at Van's at 10:00 AM each day. Looking forward to seeing you there. Dick S ----- Original Message ----- From: gordon or marge To: aeroelectric-list(at)matronics.com Sent: Thursday, July 19, 2007 5:09 PM Subject: AeroElectric-List: RE:Oshkosh Will you be at Oshkosh? If so, how can I find you? Gordon Comfort ________________________________________________________________________________
Date: Jul 19, 2007
re-posting since nobody has replied.... I have a Garmin GA 27c low profile GPS Antenna [ Part number 010-10052-05 ]and I need to extend the antenna lead. Has any one done this before and how did it work out? What did you use? Per the box it has: 8 feet of RG174 cable with MCX connector I would like to use rg-400 but do not know how to connect them properly, the GPS does use the small MCX connector, anybody have a source for that? plus I would need a disconnect at the wing root. Thanks in advance Jeff. ________________________________________________________________________________
Subject: Perihelion Power Protector Proposal
Date: Jul 20, 2007
I talk to many builders who are particularly concerned about frying their expensive avionics and glass panels. These parts are typically 1/3 of the airplane cost. Planning the wiring of a small aircraft involves installing systems to safeguard the buses against failure of the alternator. Either an internally regulated alternator or its more adaptable brother with an external regulator still has the potential problem of a runaway condition, as well as a short circuit of the main battery to alternator B-lead, and frequent load dump OV conditions. A solution is herein proposed Linear Technology has introduced a clever device, the LT4356-1 Overvoltage Protection Regulator and Inrush Limiter to address all these worries. Not only thatthey list Automotive/Avionic Surge Protection is one of its chief applications. The LTC approach takes the high voltage from a load dump or failed alternator and REGULATES it while the situation is being tamed. The IC package is 3mm X 4mm and drives a big N-MOSFET that does the heavy work of regulating the voltage. So what happens? Normally the alternator current is carried by the fully on N-MOSFET. Assume the current is 50A, and the Rds(on) is 0.012 ohms. The dissipation would be only 30W. This is easy to handle with a reasonable heat sink. Assume the alternator and/or the regulator goes cuckoo. This could happen if the alternator field winding shorts to the B-lead output or the sense lead in the regulator opens, or other untoward goings-on. The alternator output goes into an upward voltage spiral. This voltage is not unlimited, especially if there is a load on it, but could be 80 VDC. Now the LT4356-1 REGULATES the output via the big N-MOSFET on a heat sink. The aircraft buses never sees more than 14.5 Volts (or whatever is desired). This is true for the short time (500 mS) load dumps, and it will regulate a runaway alternator for a time determined by whatever the N-MOSFET and heat sink can dissipate. The LT4356-1 has a timer circuit to protect the N-MOSFET. If the time expires and the stress continues, the fault warning signals an impending power-down and the N-MOSFET shuts off the B-line. Additionally, some models of the LT4356-1 have a spare amplifier/comparator that can be used for any purpose (not shown here). It operates from 4 to 80 VDC, and withstands 30V and up to 100V. A series low voltage P-MOSFET or a Schottky diode can be added to protect against a shorted alternator that would draw reverse current. The device has built-in protection again high current shorts of the B-Line to the battery. The drawing shows a basic form. A few additional parts are necessary. However, consider the parts that WOULDNT be necessary: The B-Line contactor, The OV monitor, The load dump preventer, The B-Line fuse, The alternator switch. No crow bar or linear over voltage switch. I dont have current plans to market this but will build one for myself. Discussion is invited. See attachment for a pdf version of this note with drawing. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=124938#124938 Attachments: http://forums.matronics.com//files/power_protector_rev_a_851.pdf ________________________________________________________________________________
Date: Jul 20, 2007
Subject: Re: Perihelion Power Protector Proposal
Interesting.. Kind of a regulator on a regulator.. Do you see that the addition of this circuitry will meaningfully negatively impact the stability of the existing regulator? Existing alternator systems are filtered by a low impedance connection to the battery. It seems that it might be good to design the set point of this regulator quite a bit higher than the primary - as a means of limiting interaction between the systems. Regards, Matt- > > > I talk to many builders who are particularly concerned about frying their > expensive avionics and glass panels. These parts are typically 1/3 of the > airplane cost. > > Planning the wiring of a small aircraft involves installing systems to > safeguard the buses against failure of the alternator. Either an > internally regulated alternator or its more adaptable brother with an > external regulator still has the potential problem of a runaway condition, > as well as a short circuit of the main battery to alternator B-lead, and > frequent load dump OV conditions. > > A solution is herein proposed > > Linear Technology has introduced a clever device, the LT4356-1 Overvoltage > Protection Regulator and Inrush Limiter to address all these worries. Not > only thatthey list Automotive/Avionic Surge Protection is one of > its chief applications. > > The LTC approach takes the high voltage from a load dump or failed > alternator and REGULATES it while the situation is being tamed. The IC > package is 3mm X 4mm and drives a big N-MOSFET that does the heavy work of > regulating the voltage. > > So what happens? Normally the alternator current is carried by the fully > on N-MOSFET. Assume the current is 50A, and the Rds(on) is 0.012 ohms. The > dissipation would be only 30W. This is easy to handle with a reasonable > heat sink. > > Assume the alternator and/or the regulator goes cuckoo. This could happen > if the alternator field winding shorts to the B-lead output or the sense > lead in the regulator opens, or other untoward goings-on. The alternator > output goes into an upward voltage spiral. This voltage is not unlimited, > especially if there is a load on it, but could be 80 VDC. > > Now the LT4356-1 REGULATES the output via the big N-MOSFET on a heat sink. > The aircraft buses never sees more than 14.5 Volts (or whatever is > desired). This is true for the short time (500 mS) load dumps, and it will > regulate a runaway alternator for a time determined by whatever the > N-MOSFET and heat sink can dissipate. > > The LT4356-1 has a timer circuit to protect the N-MOSFET. If the time > expires and the stress continues, the fault warning signals an impending > power-down and the N-MOSFET shuts off the B-line. > > Additionally, some models of the LT4356-1 have a spare > amplifier/comparator that can be used for any purpose (not shown here). It > operates from 4 to 80 VDC, and withstands 30V and up to 100V. A series > low voltage P-MOSFET or a Schottky diode can be added to protect against a > shorted alternator that would draw reverse current. The device has > built-in protection again high current shorts of the B-Line to the > battery. > > The drawing shows a basic form. A few additional parts are necessary. > However, consider the parts that WOULDNT be necessary: > > The B-Line contactor, > The OV monitor, > The load dump preventer, > The B-Line fuse, > The alternator switch. > > No crow bar or linear over voltage switch. > > I dont have current plans to market this but will build one for myself. > > Discussion is invited. > > See attachment for a pdf version of this note with drawing. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=124938#124938 > > > Attachments: > > http://forums.matronics.com//files/power_protector_rev_a_851.pdf > > ________________________________________________________________________________
Date: Jul 20, 2007
Eric M. Jones wrote: > > I talk to many builders who are particularly concerned about frying their expensive avionics and glass panels. These parts are typically 1/3 of the airplane cost. > > Planning the wiring of a small aircraft involves installing systems to safeguard the buses against failure of the alternator. Either an internally regulated alternator or its more adaptable brother with an external regulator still has the potential problem of a runaway condition, as well as a short circuit of the main battery to alternator B-lead, and frequent load dump OV conditions. > > A solution is herein proposed > > Now the LT4356-1 REGULATES the output via the big N-MOSFET on a heat sink. The aircraft buses never sees more than 14.5 Volts (or whatever is desired). This is true for the short time (500 mS) load dumps, and it will regulate a runaway alternator for a time determined by whatever the N-MOSFET and heat sink can dissipate. > > The LT4356-1 has a timer circuit to protect the N-MOSFET. If the time expires and the stress continues, the fault warning signals an impending power-down and the N-MOSFET shuts off the B-line. > I'm confused by this part. It'll regulate indefinitely (if the load is low enough), but it has a timer to turn off the N-MOSFET. 1) Is the timer based on power? For example, it will run indefinitely with a 20A load, ten minutes with a 30A load, but one thirty seconds with a 40A load? Could it be set to drive multiple N-MOSFET for increased power handling. 2) Is the timer configurable, so that I could provide active cooling and set it to run indefinitely regardless of the load? 3) Does it reset /is it resettable after a cool-off period? Yeah, the alternator is on the fritz, but this device will let it run for short periods to insure the plane make it all the way to the crash site. 4) Assuming appropriate answers to the above, what would be the impediment to using this device as the primary regulator? It looks like an extremely simple, compact solution, with the absolute simplest interface possible. It looks like a very promising solution at first glance. ________________________________________________________________________________
Date: Jul 20, 2007
Eric M. Jones wrote: > > I talk to many builders who are particularly concerned about frying their expensive avionics and glass panels. These parts are typically 1/3 of the airplane cost. > > Planning the wiring of a small aircraft involves installing systems to safeguard the buses against failure of the alternator. Either an internally regulated alternator or its more adaptable brother with an external regulator still has the potential problem of a runaway condition, as well as a short circuit of the main battery to alternator B-lead, and frequent load dump OV conditions. > > A solution is herein proposed > > Linear Technology has introduced a clever device, the LT4356-1 Overvoltage Protection Regulator and Inrush Limiter to address all these worries. Not only thatthey list Automotive/Avionic Surge Protection is one of its chief applications. > > After my previous email, I found the data sheet. http://www.linear.com/pc/productDetail.jsp?navId=H0,C1,C1003,C1006,C1065,P38400#simulateSection The timer is configurable. They have way to order samples, and an LTSpice setup to run simulations with. Dang-it!! Another project! 8*) ________________________________________________________________________________
Date: Jul 20, 2007
Subject: Re: Garmin GA 27c low profile GPS Antena Cable extension?
Jeffrey W. Skiba wrote: > > re-posting since nobody has replied.... > > I have a Garmin GA 27c low profile GPS Antenna [ Part number 010-10052-05 > ]and I need to extend the antenna lead. > > Has any one done this before and how did it work out? What did you use? > > Per the box it has: > > 8 feet of RG174 cable with MCX connector > > > I would like to use rg-400 but do not know how to connect them properly, the > GPS does use the small MCX connector, anybody have a source for that? plus I > would need a disconnect at the wing root. > > Thanks in advance > > Jeff. Google is your friend. http://www.google.com/search?num &hl=en&q=mcx+extension+cable+&btnG=Search to: http://www.google.com/products?q=mcx+extension+cable+&num &hl=en&um=1&sa=X&oi=froogle&ct=title 1 minute, request to reply (on dialup & one-finger typing while eating supper) Charlie ________________________________________________________________________________
Subject: Water in Master switch
Date: Jul 20, 2007
Vans old 35 amp Honda alt External Regulator Split "Cessna" type master switch ------------------------------------------------------------------------- During rainy weather canopy was opened and water got on the master switch. Tried to mop it up but looked like some went down in the switch. Next day started the aircraft and no amps charging after engine start. Normal bus voltage with engine running is 14.2v now showing 12.2 ( no alt power ) Shut down and blew compressed air into master switch. Restarted amps charging and normal bus voltage 14.2 noted. Flew a series of orientation flights. (kids summer camp) After the 6th flight noticed a hum/beat sound in the radio/intercom. Bus voltage was 15.8v Shut off alt on split master, voltage went down to 12.6v then turned alt switch back on voltage returned to normal 14.2 hum/beat went away. After engine start the higher voltage was noted several times but could be fixed by turning the alt switch off then back on. It would then stay at the normal 14.2v for the rest of the flight. ----------------------------------------------------------------------------------------------------------- Should I: (1) Replace the Master switch and recheck. (2) Replace the Master switch and Voltage Regulator (3) Replace the alt with a new plane-power 60amp int reg with overvoltage protection I don't want smoke in the cockpit. If the Voltage regulator was damaged I don't want to start the engine again on the old unit. Thanks in advance guys, Mike _________________________________________________________________ http://im.live.com/messenger/im/home/?source=hmtextlinkjuly07 ________________________________________________________________________________
Subject: DG Short
Date: Jul 21, 2007
My "el cheapo" DG quit working about ten minutes into my first flight. The 1 Amp fuse blown that protected the DG and its wiring was blown. The DG was still dead after replacing the fuse and the fuse didn't blow again. I pulled the DG and sent it back to its manufacturer. They reported that a circuit board was fried from a high voltage power surge. I say that is BS. No other fuses were blown and there are no other indications of a power surge. My bird is all electric, externally regulated, with over voltage protection. The OV CB has never opened. It is my opinion that the el cheapo circuit board shorted out on its own, causing the fuse to blow. Any comments? Charlie Brame RV-6A N11CB San Antonio ________________________________________________________________________________
Subject: Avionics master switch/relay
Date: Jul 21, 2007
I am wanting to use an avionics master switch or relay with my electrical system. My question is: Do I need to put all of my avionics on a separate bus then control the power to that bus by the avionics master? Also,what if I want just a portion of my avionics on my endurance bus? I have looked at all of the Z figures and cannot find an example. Thanks in advance for your help. Ed RV-7 About to hang the engine ________________________________________________________________________________
Date: Jul 21, 2007
Subject: Re: Avionics master switch/relay
Ed, Go to the archive search engine and type in avionics master switch. Lots of info. It may change your mind. If not do it your way and put in an avionics master switch and a separate bus for avionics. If you decide to go with out an avionics master than just put what you "need" to successfully land after the "dark and stormy night" episode on the endurance bus and put the rest on your main bus. For an example take a look at the Z-11 schematic. Notice the way the main and endurance buses are laid out. Mike Ice Hanging the motor ----- Original Message ----- From: jedwood(at)earthlink.net To: aeroelectric-list(at)matronics.com Sent: Saturday, July 21, 2007 6:57 AM Subject: AeroElectric-List: Avionics master switch/relay I am wanting to use an avionics master switch or relay with my electrical system. My question is: Do I need to put all of my avionics on a separate bus then control the power to that bus by the avionics master? Also,what if I want just a portion of my avionics on my endurance bus? I have looked at all of the Z figures and cannot find an example. Thanks in advance for your help. Ed RV-7 About to hang the engine ________________________________________________________________________________
Subject: Re: Water in Master switch
Date: Jul 21, 2007
Change master sw. Regulator side of switch is creating a voltage drop, and telling regulator to increase output voltage. 99.9% sure it will cure your problem of over voltage Bill ----- Original Message ----- From: "Mike Adams" <asav8tor(at)hotmail.com> Sent: Saturday, July 21, 2007 1:37 AM Subject: AeroElectric-List: Water in Master switch > > > Vans old 35 amp Honda alt > > External Regulator > > Split "Cessna" type master switch > > ------------------------------------------------------------------------- > > During rainy weather canopy was opened and water got on the master switch. > Tried to mop it up but looked like some went down in the switch. > > Next day started the aircraft and no amps charging after engine start. > Normal bus voltage with engine running is 14.2v now showing 12.2 ( no alt > power ) > > Shut down and blew compressed air into master switch. > > Restarted amps charging and normal bus voltage 14.2 noted. > > Flew a series of orientation flights. (kids summer camp) After the 6th > flight noticed a hum/beat sound in the radio/intercom. Bus voltage was > 15.8v > > Shut off alt on split master, voltage went down to 12.6v then turned alt > switch back on voltage returned to normal 14.2 hum/beat went away. > > After engine start the higher voltage was noted several times but could be > fixed by turning the alt switch off then back on. It would then stay at > the normal 14.2v for the rest of the flight. > > ----------------------------------------------------------------------------------------------------------- > > Should I: > > (1) Replace the Master switch and recheck. > > (2) Replace the Master switch and Voltage Regulator > > (3) Replace the alt with a new plane-power 60amp int reg with overvoltage > protection > > I don't want smoke in the cockpit. If the Voltage regulator was damaged I > don't want to start the engine again on the old unit. > > Thanks in advance guys, > > Mike > > _________________________________________________________________ > http://im.live.com/messenger/im/home/?source=hmtextlinkjuly07 > > > ________________________________________________________________________________
Date: Jul 21, 2007
New switch installed. All is good. Rock steady again at 14.2v Took the old switch apart. Looked like a whole lot of junk in there. AL dust and junk from when the acft was built? It was moist and almost pastey. Thanks, Mike _________________________________________________________________ http://newlivehotmail.com ________________________________________________________________________________
Date: Jul 21, 2007
Hey Mike, If this is about your RV-4 I think you should just give up and consider just giving it to me. ;>) Jim Bowen - Hope ya get it figured out. >From: "Mike Adams" <asav8tor(at)hotmail.com> >Reply-To: aeroelectric-list(at)matronics.com >To: AeroElectric-List(at)matronics.com, asav8tor(at)hotmail.com >Subject: AeroElectric-List: Water in Master switch >Date: Fri, 20 Jul 2007 23:37:18 -0700 > > > >Vans old 35 amp Honda alt > >External Regulator > >Split "Cessna" type master switch > >------------------------------------------------------------------------- > >During rainy weather canopy was opened and water got on the master switch. >Tried to mop it up but looked like some went down in the switch. > >Next day started the aircraft and no amps charging after engine start. >Normal bus voltage with engine running is 14.2v now showing 12.2 ( no alt >power ) > >Shut down and blew compressed air into master switch. > >Restarted amps charging and normal bus voltage 14.2 noted. > >Flew a series of orientation flights. (kids summer camp) After the 6th >flight noticed a hum/beat sound in the radio/intercom. Bus voltage was >15.8v > >Shut off alt on split master, voltage went down to 12.6v then turned alt >switch back on voltage returned to normal 14.2 hum/beat went away. > >After engine start the higher voltage was noted several times but could be >fixed by turning the alt switch off then back on. It would then stay at >the normal 14.2v for the rest of the flight. > >----------------------------------------------------------------------------------------------------------- > >Should I: > >(1) Replace the Master switch and recheck. > >(2) Replace the Master switch and Voltage Regulator > >(3) Replace the alt with a new plane-power 60amp int reg with overvoltage >protection > >I don't want smoke in the cockpit. If the Voltage regulator was damaged I >don't want to start the engine again on the old unit. > >Thanks in advance guys, > >Mike > >_________________________________________________________________ >http://im.live.com/messenger/im/home/?source=hmtextlinkjuly07 > > _________________________________________________________________ http://newlivehotmail.com ________________________________________________________________________________
Subject: EGT sensor installation location
Date: Jul 21, 2007
Looking at the 2 attached pics of the left and right side of my engine, what would be the best place to install the EGT sensors. Just thought I'd get some input from anyone who might know if there is a best way to do it.?There are 4 of them for my GRT EIS. Thanks Brian 701Builder.com ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 22, 2007
Why not make the endurance bus and the avionics bus one and the same. On a friends RV7 we are doing this. He has a 60 A B&C alternator and a 20 A B&C standby alternator. The avionics/endurance bus is fed from the Main Bus through a diode and a S704-1 B&C relay switching circuit. Additionally, the avionics/endurance bus can be fed from the Battery Bus through another S704-1 relay switching circuit. Schematics available on request. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Jul 22, 2007
Subject: My iPaq and Anywhere Map is on eBay.
Morning, everyone... Being the impulse buyer that I am, I couldn't resist getting the latest and greatest from Control Vision. And since it came bundled with Anywhere Map installed, built in GPS, two mounts and all the other bells and whistles that I already have with the previous Anywhere Map system I got from them, I now have two almost identical units. So, I am selling the older iPaq on eBay, with everything that I got with it, and more, to hope to offset the cost of the new system by a dollar or two. Still works perfectly (used it last week) and the database is up to date. No reserve, starting at $10, so have a look for all the details ...most of your questions will be answered by the extensive listing and the links I've provided there. If you or someone you know is interested, it'll be selling in 10 days. You can find it here: http://tinyurl.com/yvsha3 Harley Dixon Long EZ N28EZ Canandaigua, NY ________________________________________________________________________________
Date: Jul 22, 2007
Subject: Semi-Custom Products
Bob This may not fit into your philosophy of versatility but FWIW if I were in the market for the LV/OV control board I would prefer to see the lights and switch already mounted within the module. Second best would be a pre-wired remote panel of lights and switch or at least the option of purchasing those unassembled parts at the same time. I have learned that it is nice to have all such remote assemblies of switches or lights easily removeable as a unit for serviceability rather than mounted in individual holes in the instrument panel. In addition where I've used a single DB connector on a device for both power and a remote panel, I've found it difficult to remove the remote panel for service or modification since the connector is also hardwired to the aircraft. We have completed 130 flight hours with our Z-14 wired subaru now without any nuisance OV trips. The only electrical issue is that I recently purchased a comfortable David Clarke headset and with our fairly quiet engine, I now hear weak but annoying strobe whine that I couldn't hear in cruise with other headsets. I have already followed most of your wiring recommendations so it may take me awhile to solve this one especially since the strobes operate off a different alternator and battery as the radio and intercom. Ken >From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> >Subject: AeroElectric-List: Semi-Custom Products > > >I've been working on a line of new products for the >AeroElectric Connection website that will be unique >to AEC. We're going to resist being a dealer for other >folks products. > >One project utilizes an ECB and enclosure that has >features described in these two illustrations: > >http://www.aeroelectric.com/DIY/A15_Package.jpg > >http://www.aeroelectric.com/DIY/Do-Much_Board_Schematic.pdf > > >The schematic would never have ALL components installed, >and in some cases, components left of are replaced with >solid jumpers. However, depending on what parts are installed, >their values, and what software is installed in the microcontroller, >we can craft a variety of products with 98% commonality >of bill of materials. > >The first product to be offered under this design and >marketing philosophy is described at: > >http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf > >. . . except that it will have a 15-pin connector on it >instead of a 9-pin. > >I'm publishing the schematic for the more technically >inclined. Perhaps the architecture will suggest an application >close to your own wishes for a smart black box to do some >task. If so, let's talk about it and see if my software >guy can't whip it out in reasonably short order and save >you a lot of development time to craft a nicely packaged >electro-whizzy. Or, if you want to do your own byte-pudding >I could offer you a kit of ECB and enclosure from which >you could move your project ahead. > > > Bob . . . > > ________________________________________________________________________________
Date: Jul 22, 2007
Subject: http://smartaircraftsystems.com/
List, This new product just popped up on the radar. What do you all think, does it show potential? Jerry Cochran Here is the web site for the new Smart Aircraft Management Systems, "SAMS" _http://smartaircrafhttp://smhttp_ (http://smartaircraftsystems.com/) Still preliminary and lots of housekeeping and text editing but its basically complete. This is a all solid state electrical system with no relays mechanical CB, fuses, or contactors in the power path from the battery (s) to the end user equipment, Integrated into this system is a complete fault detection and warning system that includes relational logic to detect and warn if two or more monitored conditions exist that alone is not a fault but the specific combination of conditions will generate a fault. Both Visual and Audible warnings are available. This fault detection system includes the ability to have different levels of limit checking and the modules are interconnected using the automotive type CAN serial bus. This fault system is independent of the hardwired electrical power system for reliability. With solid state switches and built in over current protection the result is a simple to wire electrical system. Its been in work for several years. Feel free to ask questions. Paul ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 22, 2007
Subject: Re:EGT sensor installation location
I put mine all about 1.5" down from the exhaust flange. I would angle them back about 45 deg. I didn't and it's easy to bump then when doing maint. Jerry Cochran Subject: AeroElectric-List: EGT sensor installation location From: ruruny(at)aol.com Looking at the 2 attached pics of the left and right side of my engine, what would be the best place to install the EGT sensors. Just thought I'd get some input from anyone who might know if there is a best way to do it.?There are 4 of them for my GRT EIS. Thanks Brian 701Builder.com ************************************** Get a sneak peek of the all-new AOL at http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Jul 22, 2007
Ed, If you still want to use an avionics master after reading all Bob has written you could try using 2 avionics buses, each energized by a relay both of which are switched by one double pole switch. Put your essential avionics on one bus and provide that with power direct from the battery via an emergency switch and diode. If the emergency switch is a double pole item also it could control power to your essential/endurance, non avionic, bus as well. Please be aware that the parts count has gone up and reliability has probably gone down, and I have not tried this set up. Yours, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jedwood(at)earthlink.net Sent: 21 July 2007 15:57 Subject: AeroElectric-List: Avionics master switch/relay I am wanting to use an avionics master switch or relay with my electrical system. My question is: Do I need to put all of my avionics on a separate bus then control the power to that bus by the avionics master? Also,what if I want just a portion of my avionics on my endurance bus? I have looked at all of the Z figures and cannot find an example. Thanks in advance for your help. Ed RV-7 About to hang the engine ________________________________________________________________________________
Subject: Re: EGT sensor installation location
Date: Jul 22, 2007
Brian, I just had some installed on my 0-320 and the A&P said they had to be within 4 inches of the block. Jeff Wings ----- Original Message ----- From: ruruny(at)aol.com To: zenith-list(at)matronics.com ; aeroelectric-list(at)matronics.com Sent: Saturday, July 21, 2007 11:49 PM Subject: AeroElectric-List: EGT sensor installation location Looking at the 2 attached pics of the left and right side of my engine, what would be the best place to install the EGT sensors. Just thought I'd get some input from anyone who might know if there is a best way to do it. There are 4 of them for my GRT EIS. Thanks Brian 701Builder.com ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Subject: Double-shielded coax
Date: Jul 22, 2007
Can someone explain the benefits of double-shielded coax cable? A friend of mine mentioned it's either a requirement or strongly suggested when doing the GNS430 WAAS upgrade - so what happens, does it help reduce line loss and/or does it really reduce EMI? Also, we were discussing whether it'd be beneficial to use double shielded from the mag p-lead -> key switch -> mag ground and then subsequently grounding the outer-most shield to the airframe. I wasn't sure where to stand with this concept as I thought the idea of using a single shielded wire isolated from the A/C ground enabled current pulses going opposite ways to cancel most noise. Any thoughts will be appreciated! -Andy RV-7 FWF ________________________________________________________________________________
Date: Jul 22, 2007
>From: "Eric M. Jones" <\">emjones(at)charter.net>\ > >Planning the wiring of a small aircraft involves installing systems >to safeguard the buses against failure of the alternator. Nice I like it. Here are a couple of things may be to incorporate? How about 100% isolation/protection 100% of the time? The idea is an "A" system and a full time isolated "B" system. I was thinking about a DC-DC battery charger & second battery. This would make an independent "B" system from the "A" main bat and alternator system. The "B" battery charger/battery whould give continuous protection, as long as the charger did not go crazy or the "B" battery did not explode, which is unlikely. If the charger failed the battery should still be there. http://www.powerstream.com/DCC.htm No mater what happens with the alternator the battery charger will isolate. Down side is 3.3 lbs, cost, plus 2nd battery weight. You should install a manual relay to by-pass the charger and bring the "protected" "B" system on-line with the main "A" system as a back up. Jets use battery chargers for similar reasons and also because the main "A" system or systems are AC not DC. However battery chargers do isolate the DC system. ** The SECOND jewel I came across: "BatteyLink" ACR (tm) ** http://bluesea.com/category/2/products/7600 Before you all poo-poo it, it's NOT a parallel battery bank diode. It is a smart/logic controlled auto charge relay (ACR), and it isolates and protect for low and high voltage. Voltage is user settable. Click on the tabs & the hyper links (the hyper text is monochrome and not obviously hyper links at least on my screen, so hunt around the link about). This would be instead of a battery DC-DC charger. Here's the instructions: http://bluesea.com/files/resources/instructions/6330.pdf With optional switch you can override. It's not made to parallel for starting, but it can in a pinch up to 60amps. There's many ways you can incorporate this ACR into a protected essential "B" system in your wiring hierarchy. Just thoughts, Cheers George --------------------------------- Boardwalk for $500? In 2007? Ha! ________________________________________________________________________________
Date: Jul 23, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Firewall shields
Question on stainless steel firewall shields. I'm using two of them, one covers my EGT/CHT harness (8 cables each containing two individual insulated thermocouple wires surrounded by a yellow or brown cover of, I believe, tefzel). The second one covers my VM-1000 sensor cables (half dozen 4 conductor with foil shield and tefzel outer cover). The CHT/EGT hole in the stainless firewall has a plastic busing installed and the harness fits through this bushing slightly snug and the firewall shield just fits around the whole thing without having to squeeze the shield against the wires. The sensor cables make use of a hole I originally cut through the firewall for an eye-ball control cable mount. The hole is quite large and a bushing would still leave the harness not centered in the firewall shield and sitting on the thin firewall shield material. I've cleaned up the shear marks and smoothed the edges on the firewall shields but am still a bit nervous about the thin material chaffing the wires, especially the large sensor wire hole. Any thoughts/ideas on this? Am I being too paranoid? Since we can no longer procure asbestos to make gaskets to go under the shield what is everyone doing here? Are you using some sort of grommet over the edges of the stainless shields to protect your cables from chaffing....or? Thanks. Dean Psiropoulos RV-6A N197DM Last of the wiring. ________________________________________________________________________________
Subject: Re: DG Short
Date: Jul 22, 2007
Charlie, Could you give please P/N and the manufacturer of your DG? Nick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=125298#125298 ________________________________________________________________________________
Date: Jul 23, 2007
The DG is a Falcon (Wultrad) model DG02E-3H. Chinese made el cheapo purchased from AirCraft Spruce. Charlie RV-6A N11CB San Antonio ------------------------------------------ > > Subject: AeroElectric-List: Re: DG Short > From: "Nick1" <na_derevnu(at)canada.com> > > > Charlie, > Could you give please P/N and the manufacturer of your DG? > Nick > ________________________________________________________________________________
Date: Jul 24, 2007
Subject: DIY - In the ear headphones
I've been looking into building a in-the-ear type headset using low-end earphones, following the example given at http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm I bought the Phillips ANR headphones from Target. I've got Jim Weir's impedance matching circuit article describing how to use the audio transformer, so the headphone portion is in the bag. The hangup is with the microphone. I found some discussions where Jim said that an amplifier is needed to use an electret element. Well, I picked up Item# 270-090 from Radio Shack today. http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs¤tTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary It has a wiring diagram on the back of the package that seems to indicate that the single transistor amplifier is already built into the package. I was going to ask if that was in fact what it indicates, and inquire whether it would work with the RST-443 intercom. Then I got antsy and just went and tried it. With only two leads, you know I had to hook it up backwards and feel disappointed for a minute until I figured out to turn the leads around. Then it was "WOOHOO!!" all the way. I'm now well on my way to having the equivalent of a $500, in-the-ear headset, and it's only costing me about $50. (Testing is incomplete, but others have reported resounding success.) ________________________________________________________________________________
Subject: ELT Question
Date: Jul 23, 2007
All, I'm installing a standard Ameri-King AK-450 ELT in my RV-7A to satisfy the FAA. I have a question about the coax wire connection. I need a couple extra feet of cable for my installation. I'm putting the antenna under the tail fairing and the ELT behind the baggage wall. Is it a good idea to use RG-400 to make a longer cable? Asside from the obvious "because Ameri-King says not to," is there a reason why this won't work? Maybe it would be necessary to tune the new cable/antenna combination? If so, do I need special equipment? Thanks, Greg _________________________________________________________________ Need a brain boost? Recharge with a stimulating game. Play now! http://club.live.com/home.aspx?icid=club_hotmailtextlink1 ________________________________________________________________________________
Date: Jul 23, 2007
Greg, Here's a fast answer. I seem to recall a "best practices" suggestion (don't know if it's a requirement) is to install the ELT, coax and antenna close together WITHOUT passing the antenna cable through any bulkhead. The idea here is that the further they are apart, the more likely that any one of those three critical parts will be damaged in a crash rendering the system useless. Put the whole setup together in the most survivable location. Probably near the tail. Bevan RV7A Not flying yet. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Greg Vouga Sent: Monday, July 23, 2007 8:53 PM Subject: AeroElectric-List: ELT Question --> All, I'm installing a standard Ameri-King AK-450 ELT in my RV-7A to satisfy the FAA. I have a question about the coax wire connection. I need a couple extra feet of cable for my installation. I'm putting the antenna under the tail fairing and the ELT behind the baggage wall. Is it a good idea to use RG-400 to make a longer cable? Asside from the obvious "because Ameri-King says not to," is there a reason why this won't work? Maybe it would be necessary to tune the new cable/antenna combination? If so, do I need special equipment? Thanks, Greg _________________________________________________________________ Need a brain boost? Recharge with a stimulating game. Play now! http://club.live.com/home.aspx?icid=club_hotmailtextlink1 ________________________________________________________________________________
Subject: Solar Charger
Date: Jul 24, 2007
I am wanting to purchase a solar powered charger that is compatible with an ODESSY battery. This will be used as a trickle charger/battery maintainer. By the way can you get a solar charger that will give a full charge and revert to trickle? Regards Chris Byrne SYDNEY ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Re: ELT Question
it will work fine. RG400 is expensive, but nice, RG58 will do just fine. bobf W5RF On 7/23/07, Greg Vouga wrote: > > > > > All, > > I'm installing a standard Ameri-King AK-450 ELT in my RV-7A to satisfy the > FAA. I have a question about the coax wire connection. I need a couple > extra feet of cable for my installation. I'm putting the antenna under > the > tail fairing and the ELT behind the baggage wall. Is it a good idea to > use > RG-400 to make a longer cable? Asside from the obvious "because > Ameri-King > says not to," is there a reason why this won't work? Maybe it would be > necessary to tune the new cable/antenna combination? If so, do I need > special equipment? > > Thanks, > Greg > > _________________________________________________________________ > Need a brain boost? Recharge with a stimulating game. Play now! > http://club.live.com/home.aspx?icid=club_hotmailtextlink1 > > ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Re: DIY - In the ear headphones
Keep us posted! Bill B ...satisfied Lightspeed Mach one user but out $400... On 7/23/07, Ernest Christley wrote: > > echristley(at)nc.rr.com> > > I've been looking into building a in-the-ear type headset using low-end > earphones, following the example given at > > http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm > > > I bought the Phillips ANR headphones from Target. I've got Jim Weir's > impedance matching circuit article describing how to use the audio > transformer, so the headphone portion is in the bag. > > The hangup is with the microphone. I found some discussions where Jim > said that an amplifier is needed to use an electret element. Well, I > picked up Item# 270-090 from Radio Shack today. > > http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs¤tTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary > > > It has a wiring diagram on the back of the package that seems to > indicate that the single transistor amplifier is already built into the > package. I was going to ask if that was in fact what it indicates, and > inquire whether it would work with the RST-443 intercom. Then I got > antsy and just went and tried it. With only two leads, you know I had > to hook it up backwards and feel disappointed for a minute until I > figured out to turn the leads around. Then it was "WOOHOO!!" all the way. > > I'm now well on my way to having the equivalent of a $500, in-the-ear > headset, and it's only costing me about $50. (Testing is incomplete, > but others have reported resounding success.) > > ________________________________________________________________________________
Date: Jul 24, 2007
Ernest, Does the ANR portion of the Phillips headphone still function after your tweaking? And how do you suspend the mike? I am enamored of the Lightspeed Mach One, but if one can home brew the same thing for $50, I might become an electronerd yet! John ________________________________________________________________________________
Date: Jul 24, 2007
John Burnaby wrote: > Ernest, > > Does the ANR portion of the Phillips headphone still function after > your tweaking? The ANR sits between the plug and the speaker. I've not verified it yet, but none of the tweaking I'm attempting should affect the ANR function at all. > And how do you suspend the mike? > Flox to the end of piano wire that wraps around your head. For maximum clarity, you want to encase the mic in a box with just one tiny hole directed at your mouth. Basically, you want to block sound from all directions, except where your voice is coming from. I'm still working on this part. ________________________________________________________________________________
Date: Jul 24, 2007
Actually the "tin can with a hole in one end" approach to microphone design will give you an omnidirectional mic, which although intuitive, is not what you need. See http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml for how a unidirectional mic is made. Best regards, Rob Housman Irvine, California Europa XS Tri-Gear S/N A070 Airframe complete -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Tuesday, July 24, 2007 11:24 AM Subject: Re: AeroElectric-List: DIY - In the ear headphones > And how do you suspend the mike? > Flox to the end of piano wire that wraps around your head. For maximum clarity, you want to encase the mic in a box with just one tiny hole directed at your mouth. Basically, you want to block sound from all directions, except where your voice is coming from. I'm still working on this part. ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Re: Double-shielded coax
> >Can someone explain the benefits of double-shielded coax cable? > >A friend of mine mentioned it's either a requirement or strongly suggested >when doing the GNS430 WAAS upgrade - so what happens, does it help reduce >line loss and/or does it really reduce EMI? Double shielding has some exceedingly small benefits to propagating radio frequency energy from point A to point B through exceedingly RF noise environments. Since GPS transmitted signals are below ambient noise, it's a good idea not to "waste" your system's inherent signal to noise ratio with a potentially degraded feedline installation. Now, having said that, it's unlikely that anyone crafting an OBAM aircraft will realized benefit from the double shielding. The major jump in coax quality for RG400 vs. RG58 is modern, higher temperature, environmentally robust insulations. PVC and Polyethylene were whippy-do materials in WWII, but cousins to teflon are the materials of choice today. The choice is not so much one of performance as-installed but one of longevity in service combined with doing the best we know how to do. It's similar to the evolution in finishes. Nobody would consider painting their airplane with cellulose based dope (al la Hindenberg) no matter how good it looks when compared to an equally fresh coat of Imron. >Also, we were discussing whether it'd be beneficial to use double shielded >from the mag p-lead -> key switch -> mag ground and then subsequently >grounding the outer-most shield to the airframe. I wasn't sure where to >stand with this concept as I thought the idea of using a single shielded >wire isolated from the A/C ground enabled current pulses going opposite ways >to cancel most noise. No. Shielding in these applications are for mitigation of ELECTROSTATIC coupled noises and there is no benefit to using double shielded coax for p-leads. Ground as shown in the z-figures at the engine end only. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 24, 2007
Or how about wiring per figure on page 4 of http://aeroelectric.com/articles/avmaster.pdf Bob . . . >Ed, > > >If you still want to use an avionics master after reading all Bob has >written you could try using 2 avionics buses, each energized by a relay >both of which are switched by one double pole switch. Put your essential >avionics on one bus and provide that with power direct from the battery >via an emergency switch and diode. If the emergency switch is a double >pole item also it could control power to your essential/endurance, non >avionic, bus as well. Please be aware that the parts count has gone up and >reliability has probably gone down, and I have not tried this set up. > > >Yours, Peter > > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >jedwood(at)earthlink.net >Sent: 21 July 2007 15:57 >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Avionics master switch/relay > > >I am wanting to use an avionics master switch or relay with my electrical >system. My question is: Do I need to put all of my avionics on a separate >bus then control the power to that bus by the avionics master? Also,what >if I want just a portion of my avionics on my endurance bus? I have looked >at all of the Z figures and cannot find an example. > > >Thanks in advance for your help. > > ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Re: http://smartaircraftsystems.com/
There's a bunch of new electrical system management products coming on line these days. I've consulted for several manufacturers of such products. The question to be asked and answered is what is the $cost$ to save how much $time$ and at what reduction in system reliability - particularly with respect to single points of failure propagating across multiple systems. What are the weight penalties and perhaps most importantly, if one decides to stay with traditional management techniques and philosophies, what other useful electro-whizzy could be purchased with dollars not invested for added convenience or "gee whiz". Without arguing for or against such systems, I would encourage every potential user to deduce for themselves the return on investment in the product for how they intend to use the airplane while keeping in mind an old adage my grandfather might have offered . . . "Sometimes the best way to drive a nail is with a hammer." Bob . . . >List, > >This new product just popped up on the radar. What do you all think, does >it show potential? > >Jerry Cochran > > >Here is the web site for the new Smart Aircraft Management Systems, "SAMS" > ><http://smartaircraftsystems.com/>http://smartaircraftsystems.com/ > >Still preliminary and lots of housekeeping and text editing but its >basically complete. > >This is a all solid state electrical system with no relays mechanical CB, >fuses, or contactors in the power path from the battery (s) to the end user >equipment, Integrated into this system is a complete fault detection and >warning system that includes relational logic to detect and warn if two or >more monitored conditions exist that alone is not a fault but the specific >combination of conditions will generate a fault. Both Visual and Audible >warnings are available. This fault detection system includes the ability to >have different levels of limit checking and the modules are interconnected >using the automotive type CAN serial bus. This fault system is independent >of the hardwired electrical power system for reliability. With solid state >switches and built in over current protection the result is a simple to wire >electrical system. Its been in work for several years. > >Feel free to ask questions. > >Paul > > >---------- >Get a sneak peek of the all-new ><http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982>AOL.com. > > http://www.matronics.com/Navigator?AeroElectric-List > > >incoming mail is certified Virus Free. >Checked by AVG. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Re: Semi-Custom Products
> >Bob > >This may not fit into your philosophy of versatility but FWIW if I were in >the market for the LV/OV control board I would prefer to see the lights >and switch already mounted within the module. Second best would be a >pre-wired remote panel of lights and switch or at least the option of >purchasing those unassembled parts at the same time. I have learned that >it is nice to have all such remote assemblies of switches or lights easily >removeable as a unit for serviceability rather than mounted in individual >holes in the instrument panel. In addition where I've used a single DB >connector on a device for both power and a remote panel, I've found it >difficult to remove the remote panel for service or modification since the >connector is also hardwired to the aircraft. Keep in mind that the Do-Lots assembly is capable of being configured for a multitude of tasks . . . many of which may not even have lights and or switches. If I were addressing the single application cited, then yes, avoiding the remotely mounted electronics module would be desirable. One could always configure their own installation with the necessary and useful in-line connectors to accommodate a maintenance situation. >We have completed 130 flight hours with our Z-14 wired subaru now without >any nuisance OV trips. The only electrical issue is that I recently >purchased a comfortable David Clarke headset and with our fairly quiet >engine, I now hear weak but annoying strobe whine that I couldn't hear in >cruise with other headsets. I have already followed most of your wiring >recommendations so it may take me awhile to solve this one especially >since the strobes operate off a different alternator and battery as the >radio and intercom. Start with a test battery made up of a couple 6v lantern batteries to run the strobe supply with a short cable and batteries located right at the power supply. You need to deduce the propagation mode. I suspect it's conducted and a relatively simple filter at the power supply will fix it. Bob . . . ________________________________________________________________________________
Date: Jul 24, 2007
Rob Housman wrote: > > Actually the "tin can with a hole in one end" approach to microphone design > will give you an omnidirectional mic, which although intuitive, is not what > you need. See > http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml for > how a unidirectional mic is made. > > Boy, did you save me some rabbit chasing. I've now got all the pieces working (except the microphone housing), and I've had to do practically nothing. The Phillps ANR Earbuds come with a 1/4" adapter that will plug directly into the intercom. The sound is excellent. My intercom is mono, so I have some work to do there, but there's nothing to do otherwise. I have to add a 3/16" adapter to the end of the microphone, and I think a small bottle cap and a piece of foam double-sided tape will make it into a nice cardoid. The piano wire bends nicely around my ears and the back of my head, and is very comfortable with a little heatshrink added. ________________________________________________________________________________
Date: Jul 25, 2007
Hi Chris, I buildt one myself using a single voltage regulator LM338K and a couple of resistors and caps.LM338 is $10.- and will handle up to 5A.It provides a constant adjustable output voltage and keeps the battery charged. Karl Ahamer Mittagong/Australia -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Chris Byrne Sent: Tuesday, 24 July 2007 7:31 PM Subject: AeroElectric-List: Solar Charger I am wanting to purchase a solar powered charger that is compatible with an ODESSY battery. This will be used as a trickle charger/battery maintainer. By the way can you get a solar charger that will give a full charge and revert to trickle? Regards Chris Byrne SYDNEY 23/07/2007 7:45 PM 23/07/2007 7:45 PM ________________________________________________________________________________
Date: Jul 24, 2007
Ernest Christley wrote: > > > Rob Housman wrote: >> <rob@hyperion-ef.com> >> >> Actually the "tin can with a hole in one end" approach to microphone >> design >> will give you an omnidirectional mic, which although intuitive, is not >> what >> you need. See >> http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml >> for >> how a unidirectional mic is made. >> > Boy, did you save me some rabbit chasing. > > I've now got all the pieces working (except the microphone housing), and > I've had to do practically nothing. The Phillps ANR Earbuds come with a > 1/4" adapter that will plug directly into the intercom. The sound is > excellent. My intercom is mono, so I have some work to do there, but > there's nothing to do otherwise. I have to add a 3/16" adapter to the > end of the microphone, and I think a small bottle cap and a piece of > foam double-sided tape will make it into a nice cardoid. The piano wire > bends nicely around my ears and the back of my head, and is very > comfortable with a little heatshrink added. As someone else pointed out, a directional mic would be helpful. Also, building one starting with an omni is a non-trivial task. Buying an el-cheapo a/c headset or a used one & cannibalizing it for its mic *is* a trivial task. (You also get the proper mic connector in the bargain.) One the guys on an ultralite list I monitor is using ANR earbuds under his regular headset. He reports that noise reduction is really good. :-) Charlie ________________________________________________________________________________
Date: Jul 24, 2007
Yeah, maybe, but the rabbit is still hopping along. I pointed you to the theory but now you have to get the design to agree with theory. The trick is to calculate the time values in the referenced article so that the sound from the rear arrives at the front side of the diaphragm in phase with the sound from the front. The velocity of sound at 30 deg C is 350 meters/second. Best regards, Rob Housman Irvine, California Europa XS Tri-Gear S/N A070 Airframe complete -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Tuesday, July 24, 2007 3:43 PM Subject: Re: AeroElectric-List: DIY - In the ear headphones Rob Housman wrote: <rob@hyperion-ef.com> > > Actually the "tin can with a hole in one end" approach to microphone design > will give you an omnidirectional mic, which although intuitive, is not what > you need. See > http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml for > how a unidirectional mic is made. > > Boy, did you save me some rabbit chasing. I've now got all the pieces working (except the microphone housing), and I've had to do practically nothing. The Phillps ANR Earbuds come with a 1/4" adapter that will plug directly into the intercom. The sound is excellent. My intercom is mono, so I have some work to do there, but there's nothing to do otherwise. I have to add a 3/16" adapter to the end of the microphone, and I think a small bottle cap and a piece of foam double-sided tape will make it into a nice cardoid. The piano wire bends nicely around my ears and the back of my head, and is very comfortable with a little heatshrink added. ________________________________________________________________________________
Date: Jul 24, 2007
Charlie England wrote: > > > Ernest Christley wrote: >> >> >> Rob Housman wrote: >>> <rob@hyperion-ef.com> >>> >>> Actually the "tin can with a hole in one end" approach to microphone >>> design >>> will give you an omnidirectional mic, which although intuitive, is >>> not what >>> you need. See >>> http://www.prosoundweb.com/install/spotlight/cardioid/cardioidmics.shtml >>> for >>> how a unidirectional mic is made. >>> >> Boy, did you save me some rabbit chasing. >> >> I've now got all the pieces working (except the microphone housing), >> and I've had to do practically nothing. The Phillps ANR Earbuds come >> with a 1/4" adapter that will plug directly into the intercom. The >> sound is excellent. My intercom is mono, so I have some work to do >> there, but there's nothing to do otherwise. I have to add a 3/16" >> adapter to the end of the microphone, and I think a small bottle cap >> and a piece of foam double-sided tape will make it into a nice >> cardoid. The piano wire bends nicely around my ears and the back of >> my head, and is very comfortable with a little heatshrink added. > > As someone else pointed out, a directional mic would be helpful. Also, > building one starting with an omni is a non-trivial task. Buying an > el-cheapo a/c headset or a used one & cannibalizing it for its mic *is* > a trivial task. (You also get the proper mic connector in the bargain.) > > One the guys on an ultralite list I monitor is using ANR earbuds under > his regular headset. He reports that noise reduction is really good. :-) > > Charlie > > Well duhhh... Is it obvious that I waited until after posting to read the link? ________________________________________________________________________________
Date: Jul 25, 2007
Rob Housman wrote: > > Yeah, maybe, but the rabbit is still hopping along. I pointed you to the > theory but now you have to get the design to agree with theory. The trick > is to calculate the time values in the referenced article so that the sound > from the rear arrives at the front side of the diaphragm in phase with the > sound from the front. The velocity of sound at 30 deg C is 350 > meters/second. > Yeah, that's one way to go about it. Another method involves my Echelon headset and a pair of calipers 8*) ________________________________________________________________________________
Date: Jul 24, 2007
Subject: Off to OSH
I'm offering two presentations at OSH this year. One on Thursday afternoon and the other on Friday night (open Q&A session). Dr. Dee is unable to accompany me on this trip so my father-in-law is coming along to share driving duties (and to find out what this OBAM aircraft thing is all about!). I'll be off line until Sunday. Hope we can meet some of you there! Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
From: "dougshep(at)netzero.com" <dougshep(at)NetZero.com>
Date: Jul 26, 2007
Subject: RV-9A Flap position control
Building an RV-9A. Is there a schematic available that shows how to con trol the Flaps in 0, 10, 20, 30 degree increments? Maybe a DC servo con trol circuit? Also, in an all metal airframe, is it acceptable to use stainless steel hardware to ground returns to the airframe?
Building an RV-9A.  Is there a schematic available that sh ows how to control the Flaps in 0, 10, 20, 30 degree increments?&nb sp; Maybe a DC servo control circuit?
Also, in an all metal airframe, is it acceptable to use stainles s steel hardware to ground returns to the airframe?
Subject: Flight Cheetah FL190 GPS?
Date: Jul 26, 2007
Does anyone on the list have any personal experience with owning/using the Flight Cheetah FL190 GPS? If so, what is your general overall impression and would you recommend it. Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html ________________________________________________________________________________
Subject: Re: Flight Cheetah FL190 GPS?
Date: Jul 26, 2007
Ed, I just started using one of those about two weeks ago. I was interested in it because of it's size and cost as compared to the 496. It has all of the functionality of the Garmin and then some on a 9" screen (about 3X the size of the 496). I am hooked on the XM weather, and a unique feature that calculates the best altutide for fuel burn and time. So far it's worked as advertised and I'm anxious to see their Hi-way in the Sky module. Two things about it I don't like so much. First, it's big (I know, I know) and I'm having trouble finding a good place in the cockpit for it (mine has a suction cup mount), and the other is the wires. I spent some time routing them out of sight, but there are two from the unit (power and USB) and then all the plugs, hub, XM antennas and GPs antennas. That's no different than the Garmin though (if you use an external antenna). One other thing - as a portable unit it's OK with me that it has a Windows XP interface (it's nice with wireless in an FBO for checking eMail) but I have concerns about Windows and stability . . . . . nothing serious yet though. Jeff Dalton Wings ----- Original Message ----- From: Ed Anderson To: avionics-list(at)matronics.com ; RV-List Sent: Thursday, July 26, 2007 8:10 PM Subject: AeroElectric-List: Flight Cheetah FL190 GPS? Does anyone on the list have any personal experience with owning/using the Flight Cheetah FL190 GPS? If so, what is your general overall impression and would you recommend it. Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html ________________________________________________________________________________
Date: Jul 26, 2007
_____ Building an RV-9A. Is there a schematic available that shows how to control the Flaps in 0, 10, 20, 30 degree increments? Maybe a DC servo control circuit? Check this: http://www.aircraftextras.com/FPS-Plus.htm Also, in an all metal airframe, is it acceptable to use stainless steel hardware to ground returns to the airframe? A cad plated screw will do for about 25 years Peter Lauence ________________________________________________________________________________
Date: Jul 26, 2007
Thanks, Jeff I am down to one old eye ball and the black/white Garmin 195 is getting about as long in the tooth as I am. So a larger colored screen certainly has appeal. But, while I have like the Garmin, I like the idea of software upgrades rather than buying hardware each time and the data base subscription costs seemed more reasonable to me. Mine 195 is canopy (suction cup) mounted and I took their actual size printout and there is room enough in that location. Well, good luck, I would be interested in hearing from you after you have flow with it for a spell. Best Regards Ed ----- Original Message ----- From: jdalton77 To: aeroelectric-list(at)matronics.com Sent: Thursday, July 26, 2007 8:38 PM Subject: Re: AeroElectric-List: Flight Cheetah FL190 GPS? Ed, I just started using one of those about two weeks ago. I was interested in it because of it's size and cost as compared to the 496. It has all of the functionality of the Garmin and then some on a 9" screen (about 3X the size of the 496). I am hooked on the XM weather, and a unique feature that calculates the best altutide for fuel burn and time. So far it's worked as advertised and I'm anxious to see their Hi-way in the Sky module. Two things about it I don't like so much. First, it's big (I know, I know) and I'm having trouble finding a good place in the cockpit for it (mine has a suction cup mount), and the other is the wires. I spent some time routing them out of sight, but there are two from the unit (power and USB) and then all the plugs, hub, XM antennas and GPs antennas. That's no different than the Garmin though (if you use an external antenna). One other thing - as a portable unit it's OK with me that it has a Windows XP interface (it's nice with wireless in an FBO for checking eMail) but I have concerns about Windows and stability . . . . . nothing serious yet though. Jeff Dalton Wings ----- Original Message ----- From: Ed Anderson To: avionics-list(at)matronics.com ; RV-List Sent: Thursday, July 26, 2007 8:10 PM Subject: AeroElectric-List: Flight Cheetah FL190 GPS? Does anyone on the list have any personal experience with owning/using the Flight Cheetah FL190 GPS? If so, what is your general overall impression and would you recommend it. Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Jul 26, 2007
Subject: Re: RV-9A Flap position control
At 14:55 7/26/2007, you wrote: >Also, in an all metal airframe, is it acceptable to use stainless >steel hardware to ground returns to the airframe? Check out chapter 11 of 43.13, specifically tables 11-14, 11-15 and 11-16 as well as figures 11-20, 21 and 22. Also a good resource: http://www.eaa1000.av.org/technicl/corrosion/galvanic.htm Ron Q. ________________________________________________________________________________
Subject: The hottest T-shirt at Oshkosh
Date: Jul 26, 2007
Bret Smith RV-9A (91314) Mineral Bluff, GA www.FlightInnovations.com ________________________________________________________________________________
Subject: Re: The hottest T-shirt at Oshkosh
Date: Jul 26, 2007
That made me laugh out loud. Jeff Dalton ----- Original Message ----- From: "Bret Smith" <smithhb(at)tds.net> Sent: Thursday, July 26, 2007 10:50 PM Subject: AeroElectric-List: The hottest T-shirt at Oshkosh > > > > Bret Smith > RV-9A (91314) > Mineral Bluff, GA > www.FlightInnovations.com > > ________________________________________________________________________________
Date: Jul 27, 2007
FPS system, manufactured by Aircraft Extras. http://www.aircraftextras.com/ dougshep(at)netzero.com wrote: > > Building an RV-9A. Is there a schematic available that shows how to > control the Flaps in 0, 10, 20, 30 degree increments? Maybe a DC > servo control circuit? > > Also, in an all metal airframe, is it acceptable to use stainless > steel hardware to ground returns to the airframe? > > * > > > * ________________________________________________________________________________
Date: Jul 26, 2007
jdalton77 wrote: > Ed, > > I just started using one of those about two weeks ago. > > I was interested in it because of it's size and cost as compared to > the 496. It has all of the functionality of the Garmin and then some > on a 9" screen (about 3X the size of the 496). > > I am hooked on the XM weather, and a unique feature that calculates > the best altutide for fuel burn and time. > > So far it's worked as advertised and I'm anxious to see their Hi-way > in the Sky module. > > Two things about it I don't like so much. First, it's big (I know, I > know) and I'm having trouble finding a good place in the cockpit for > it (mine has a suction cup mount), and the other is the wires. I > spent some time routing them out of sight, but there are two from the > unit (power and USB) and then all the plugs, hub, XM antennas and GPs > antennas. That's no different than the Garmin though (if you use an > external antenna). > > One other thing - as a portable unit it's OK with me that it has a > Windows XP interface (it's nice with wireless in an FBO for checking > eMail) but I have concerns about Windows and stability . . . . . > nothing serious yet though. > > Jeff Dalton > Wings > > > ----- Original Message ----- > *From:* Ed Anderson > *To:* avionics-list(at)matronics.com > ; RV-List > > *Sent:* Thursday, July 26, 2007 8:10 PM > *Subject:* AeroElectric-List: Flight Cheetah FL190 GPS? > > Does anyone on the list have any personal experience with > owning/using the Flight Cheetah FL190 GPS? If so, what is your > general overall impression and would you recommend it. > > Thanks > > > Ed Anderson > Rv-6A N494BW Rotary Powered > Matthews, NC > eanderson(at)carolina.rr.com > http://members.cox.net/rogersda/rotary/configs.htm#N494BW > http://www.dmack.net/mazda/index.html > >* > >href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >href="http://forums.matronics.com">http://forums.matronics.com > >* > >* > > >* > How about visibility in bright sunlight? Pax, Ed Holyoke ________________________________________________________________________________
Date: Jul 27, 2007
Luved it Harold ----- Original Message ----- From: "Bret Smith" <smithhb(at)tds.net> Sent: Thursday, July 26, 2007 10:50 PM Subject: AeroElectric-List: The hottest T-shirt at Oshkosh > > > > Bret Smith > RV-9A (91314) > Mineral Bluff, GA > www.FlightInnovations.com > > ________________________________________________________________________________
Date: Jul 27, 2007
What was it? -----Original Message----- >From: Harold Kovac <kayce33(at)embarqmail.com> >Sent: Jul 27, 2007 9:31 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: The hottest T-shirt at Oshkosh > > >Luved it >Harold >----- Original Message ----- >From: "Bret Smith" <smithhb(at)tds.net> >To: >Sent: Thursday, July 26, 2007 10:50 PM >Subject: AeroElectric-List: The hottest T-shirt at Oshkosh > > >> >> >> >> Bret Smith >> RV-9A (91314) >> Mineral Bluff, GA >> www.FlightInnovations.com >> >> > > ________________________________________________________________________________
Date: Jul 27, 2007
A green t-shirt with block letters that said, "I am NOT gmcjetpilot". Bruce -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Friday, July 27, 2007 9:57 AM Subject: Re: AeroElectric-List: The hottest T-shirt at Oshkosh What was it? -----Original Message----- >From: Harold Kovac <kayce33(at)embarqmail.com> >Sent: Jul 27, 2007 9:31 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: The hottest T-shirt at Oshkosh > > >Luved it >Harold >----- Original Message ----- >From: "Bret Smith" <smithhb(at)tds.net> >To: >Sent: Thursday, July 26, 2007 10:50 PM >Subject: AeroElectric-List: The hottest T-shirt at Oshkosh > > >> >> >> >> Bret Smith >> RV-9A (91314) >> Mineral Bluff, GA >> www.FlightInnovations.com >> >> > > ________________________________________________________________________________
Date: Jul 27, 2007
Jeff, I am considering the same. After seeing their comparison to the 496, it really appears to have advantages. I am especially interested in the approaches and how well it does when compared to a certified 430W/530W. I like the fact that it posts the elevation in the approach you are supposed to be at. Yes, the wind/fuel mileage thing also looks very useful. I believe it also has popup for fuel prices. This unit seems particularly useful as an IFR backup. When comparing all of the others, they all seem to have shortcomings over the Cheetah. I may try the optional floor mount to see how that works. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jdalton77 Sent: Thursday, July 26, 2007 8:38 PM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: Flight Cheetah FL190 GPS? Ed, I just started using one of those about two weeks ago. I was interested in it because of it's size and cost as compared to the 496. It has all of the functionality of the Garmin and then some on a 9" screen (about 3X the size of the 496). I am hooked on the XM weather, and a unique feature that calculates the best altutide for fuel burn and time. So far it's worked as advertised and I'm anxious to see their Hi-way in the Sky module. Two things about it I don't like so much. First, it's big (I know, I know) and I'm having trouble finding a good place in the cockpit for it (mine has a suction cup mount), and the other is the wires. I spent some time routing them out of sight, but there are two from the unit (power and USB) and then all the plugs, hub, XM antennas and GPs antennas. That's no different than the Garmin though (if you use an external antenna). One other thing - as a portable unit it's OK with me that it has a Windows XP interface (it's nice with wireless in an FBO for checking eMail) but I have concerns about Windows and stability . . . . . nothing serious yet though. Jeff Dalton Wings ----- Original Message ----- From: Ed Anderson <mailto:eanderson(at)carolina.rr.com> To: avionics-list(at)matronics.com ; RV-List Sent: Thursday, July 26, 2007 8:10 PM Subject: AeroElectric-List: Flight Cheetah FL190 GPS? Does anyone on the list have any personal experience with owning/using the Flight Cheetah FL190 GPS? If so, what is your general overall impression and would you recommend it. Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Jul 27, 2007
MessageGlenn, I couldn't find a place for the floor mount in my Cherokee so I went with the suction. The approaches work well - you can't "fly" the ILS like some units, but it does offer you complete guidance. One feature I like (it's not huge) is the extended runway center lines on the screen that make it really easy to find and line up with the active runway. Jeff ----- Original Message ----- From: longg(at)pjm.com To: aeroelectric-list(at)matronics.com Sent: Friday, July 27, 2007 3:44 PM Subject: RE: AeroElectric-List: Flight Cheetah FL190 GPS? Jeff, I am considering the same. After seeing their comparison to the 496, it really appears to have advantages. I am especially interested in the approaches and how well it does when compared to a certified 430W/530W. I like the fact that it posts the elevation in the approach you are supposed to be at. Yes, the wind/fuel mileage thing also looks very useful. I believe it also has popup for fuel prices. This unit seems particularly useful as an IFR backup. When comparing all of the others, they all seem to have shortcomings over the Cheetah. I may try the optional floor mount to see how that works. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jdalton77 Sent: Thursday, July 26, 2007 8:38 PM To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: Flight Cheetah FL190 GPS? Ed, I just started using one of those about two weeks ago. I was interested in it because of it's size and cost as compared to the 496. It has all of the functionality of the Garmin and then some on a 9" screen (about 3X the size of the 496). I am hooked on the XM weather, and a unique feature that calculates the best altutide for fuel burn and time. So far it's worked as advertised and I'm anxious to see their Hi-way in the Sky module. Two things about it I don't like so much. First, it's big (I know, I know) and I'm having trouble finding a good place in the cockpit for it (mine has a suction cup mount), and the other is the wires. I spent some time routing them out of sight, but there are two from the unit (power and USB) and then all the plugs, hub, XM antennas and GPs antennas. That's no different than the Garmin though (if you use an external antenna). One other thing - as a portable unit it's OK with me that it has a Windows XP interface (it's nice with wireless in an FBO for checking eMail) but I have concerns about Windows and stability . . . . . nothing serious yet though. Jeff Dalton Wings ----- Original Message ----- From: Ed Anderson To: avionics-list(at)matronics.com ; RV-List Sent: Thursday, July 26, 2007 8:10 PM Subject: AeroElectric-List: Flight Cheetah FL190 GPS? Does anyone on the list have any personal experience with owning/using the Flight Cheetah FL190 GPS? If so, what is your general overall impression and would you recommend it. Thanks Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: Re: S700 2-50 switch wiring
Date: Jul 27, 2007
HELP!!!!!!!!!!! I am using an S700 2-50 switch to activate my fuel pump. So far I have been unable to brake the code. I have so far used multiple schemes .......I can get it to work to this point....toggle down OFF.....toogle mid position (on)......toggle up notta?????????????...for the momentary on. Right now I have #2 to power bus, #5 to ground, #1 to pump motor...red, #6 to pump motor....black , and #3 to #6. Thanks for any and all suggestions. Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway _________________________________________________________________ http://newlivehotmail.com ________________________________________________________________________________
Subject: Vacuume pressure warning light
Date: Jul 27, 2007
My VistaPrint Electronic Business CardI would like to add a vacuum pressure warning light to my ship's panel. What do you guys recommend? Is there a particular vacuum pressure switch that I can connect to my vac line that will illuminate a panel lamp in the event the vacuum pressure slides to an unsafe level - or is there another (better) way to do this? Michael H. ________________________________________________________________________________
Date: Jul 27, 2007
Subject: Re: Vacuume pressure warning light
Michael, I purchased a vacuum switch from Precise Flight, Inc several years ago. I just looked at their website and could not find that switch. You might contact them to see if they still sell the switch. It was part of a vacuum backup system that used manifold pressure. But they sold the switch separately. They may have discontinued it because of the move toward all electrical panels. Regards, Richard Dudley RV-6A flying Michael Hinchcliff wrote: > I would like to add a vacuum pressure warning light to my ship's > panel. What do you guys recommend? Is there a particular > vacuum pressure switch that I can connect to my vac line that will > illuminate a panel lamp in the event the vacuum pressure slides to > an unsafe level - or is there another (better) way to do this? > > Michael H. > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 27, 2007
Michael- This switch, along with a blinking LED, should work fine: http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn ame The chamber is SS. The problem is, it would need a field approval for certified aircraft - and local FSDO's may not be very sympathetic to messing with the vac system. I'd like to get my hnads on such a field approval for my own installation. Anyone? Best Rumen _____________________Original message __________________________ (received from Michael Hinchcliff; Date: 06:32 PM ________________________________________________________________ I would like to add a vacuum pressure warning light to my ship's panel. What do you guys recommend? Is there a particular vacuum pressure switch that I can connect to my vac line that will illuminate a panel lamp in the event the vacuum pressure slides to an unsafe level - or is there another (better) way to do this? Michael H. ________________________________________________________________________________
Date: Jul 27, 2007
Frank, Are you trying to control another device besides the pump with the switch? Like a primer with the momentary on? If so try this: 2 to power buss 5 to aircraft ground 1 to pump motor red 5 to pump motor black 1 to momentary contact device positive 4 to momentary contact device ground This would keep the pump on while the primer is momentarily energized. ( by switching the power buss lead of the pump and the ground lead of the primer) Dale Ensing ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Friday, July 27, 2007 5:43 PM Subject: AeroElectric-List: Re: S700 2-50 switch wiring > > > > HELP!!!!!!!!!!! > > I am using an S700 2-50 switch to activate my fuel pump. So far I have > been unable to brake the code. I have so far used multiple schemes > .......I can get it to work to this point....toggle down OFF.....toogle > mid position (on)......toggle up notta?????????????...for the momentary > on. Right now I have #2 to power bus, #5 to ground, #1 to pump > motor...red, #6 to pump motor....black , and #3 to #6. > > Thanks for any and all suggestions. > > Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway > > _________________________________________________________________ > http://newlivehotmail.com > > > ________________________________________________________________________________
Date: Jul 27, 2007
Frank, On the Z-11 drawing it shows that the power from the main bus goes to #5 with a jumper to #2. Why do you have a ground on #5? The grounds go on the other side of the fuel pumps and it shows both of them grounded to the panel. It seems to me that the way you describe it you have the switch shorted out. I am not an electrical genius just another guy wiring up an RV so I hope you get some other suggestions. Mike Ice Fire wall forward, rewiring the mag switches for emag/pmag, adding accessories to the motor. ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Friday, July 27, 2007 1:43 PM Subject: AeroElectric-List: Re: S700 2-50 switch wiring > > > > HELP!!!!!!!!!!! > > I am using an S700 2-50 switch to activate my fuel pump. So far I have > been unable to brake the code. I have so far used multiple schemes > .......I can get it to work to this point....toggle down OFF.....toogle > mid position (on)......toggle up notta?????????????...for the momentary > on. Right now I have #2 to power bus, #5 to ground, #1 to pump > motor...red, #6 to pump motor....black , and #3 to #6. > > Thanks for any and all suggestions. > > Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway > > _________________________________________________________________ > http://newlivehotmail.com > > > ________________________________________________________________________________
Subject: wiring the 2-50 switch
Date: Jul 27, 2007
Frank, If you have the AeroElectric Connection manual - see page 11-18. Looking at the back of the 2-50 switch, with the keyway UP, the contact numbers are: 6 - 3 5 - 2 -- power IN to contacts 2 and 5 - each side is independent (4-5-6 independent of 1-2-3) 4 - 1 When the switch is in the DOWN position (opposite the keyway): - contacts 5 and 6 are connected - contacts 2 and 3 are connected When the switch is in the MIDDLE position: - contacts 5 and 6 are still connected - contacts 2 and 1 are connected (no power to 3) In the UP (momentary position): - contacts 5 and 4 are connected (no power to 6) - so the 5-4 combination is the only one that is 'momentary' - contacts 2 and 1 are connected (no power to 3) Hope this helps. Dennis Glaeser ________________________________________________________________________________
From: "Ivor Phillips" <ivor.phillips(at)ntlworld.com>
Date: Jul 28, 2007
I have used a XV600 vacuum switch with three terminals, One N/C and one N/O so I can have both a vacuum low warning light and a engine tach time from the one instrument, You can adjust the switch to suit your installation , http://www.valvesystems.co.uk/catalog/Type-XV600-Vacuum-Switches-p-1-c-5 0.html regards Ivor Phillips -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Hinchcliff Sent: 28 July 2007 00:32 Subject: AeroElectric-List: Vacuume pressure warning light I would like to add a vacuum pressure warning light to my ship's panel. What do you guys recommend? Is there a particular vacuum pressure switch that I can connect to my vac line that will illuminate a panel lamp in the event the vacuum pressure slides to an unsafe level - or is there another (better) way to do this? Michael H. ________________________________________________________________________________
Subject: Re: wiring the 2-50 switch
Date: Jul 28, 2007
Hi Guys As a matter of interest from whom do you get your (e.g.: 2-50) switches from Cheers John PPL-England - - RV-9a 'wings' ----- Original Message ----- From: "glaesers" <glaesers(at)wideopenwest.com> Sent: Saturday, July 28, 2007 4:15 AM Subject: AeroElectric-List: wiring the 2-50 switch > > > Frank, > > If you have the AeroElectric Connection manual - see page 11-18. > > Looking at the back of the 2-50 switch, with the keyway UP, the contact > numbers are: > > 6 - 3 > 5 - 2 -- power IN to contacts 2 and 5 - each side is independent (4-5-6 > independent of 1-2-3) > 4 - 1 > > When the switch is in the DOWN position (opposite the keyway): > - contacts 5 and 6 are connected > - contacts 2 and 3 are connected > > When the switch is in the MIDDLE position: > - contacts 5 and 6 are still connected > - contacts 2 and 1 are connected (no power to 3) > > In the UP (momentary position): > - contacts 5 and 4 are connected (no power to 6) - so the 5-4 combination > is the only one that is 'momentary' > - contacts 2 and 1 are connected (no power to 3) > > Hope this helps. > > Dennis Glaeser > > > ________________________________________________________________________________
Date: Jul 28, 2007
Yes, this should work nicely. Thank you! ----- Original Message ----- From: <rd2(at)evenlink.com> Sent: Friday, July 27, 2007 7:47 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > Michael- > > This switch, along with a blinking LED, should work fine: > > http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn > ame > > The chamber is SS. > > The problem is, it would need a field approval for certified aircraft - > and > local FSDO's may not be very sympathetic to messing with the vac system. > I'd like to get my hnads on such a field approval for my own installation. > Anyone? > > Best > Rumen > > > _____________________Original message __________________________ > (received from Michael Hinchcliff; Date: 06:32 PM > ________________________________________________________________ > > I would like to add a vacuum pressure warning light to my ship's panel. > What do you guys recommend? Is there a particular vacuum pressure switch > that I can connect to my vac line that will illuminate a panel lamp in the > event the vacuum pressure slides to an unsafe level - or is there another > (better) way to do this? > > Michael H. > > > ________________________________________________________________________________
Date: Jul 28, 2007
Mike It appears that all roads as they say lead to Rome or in this case to the motor working. #2 to power bus, #5 to ground #1 to red wire from pump motor # 6 to black wire from pump, #1 to #3 gives me continuity in toggle mid and momentary up position. Thanks for the help I am still wrestling with this is the final results for the aux fuel pump/prime. Frank @ SGU RV7A Wiring >From: "Michael T. Ice" <aurbo(at)ak.net> >Reply-To: aeroelectric-list(at)matronics.com >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Re: S700 2-50 switch wiring >Date: Fri, 27 Jul 2007 18:44:18 -0800 > > >Frank, > >On the Z-11 drawing it shows that the power from the main bus goes to #5 >with a jumper to #2. Why do you have a ground on #5? The grounds go on the >other side of the fuel pumps and it shows both of them grounded to the >panel. It seems to me that the way you describe it you have the switch >shorted out. > >I am not an electrical genius just another guy wiring up an RV so I hope >you get some other suggestions. > >Mike Ice >Fire wall forward, rewiring the mag switches for emag/pmag, adding >accessories to the motor. > >----- Original Message ----- From: "Frank Stringham" > >To: >Sent: Friday, July 27, 2007 1:43 PM >Subject: AeroElectric-List: Re: S700 2-50 switch wiring > > >> >> >> >> >> >>HELP!!!!!!!!!!! >> >>I am using an S700 2-50 switch to activate my fuel pump. So far I have >>been unable to brake the code. I have so far used multiple schemes >>.......I can get it to work to this point....toggle down OFF.....toogle >>mid position (on)......toggle up notta?????????????...for the momentary >>on. Right now I have #2 to power bus, #5 to ground, #1 to pump >>motor...red, #6 to pump motor....black , and #3 to #6. >> >>Thanks for any and all suggestions. >> >>Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway >> >>_________________________________________________________________ >>http://newlivehotmail.com >> >> >> >> >> >> > > _________________________________________________________________ ________________________________________________________________________________
Date: Jul 28, 2007
John, I get all my switches from B&C, www.bandc.biz/. Mike ----- Original Message ----- From: "JOHN TIPTON" <jmtipton(at)btopenworld.com> Sent: Saturday, July 28, 2007 2:29 AM Subject: Re: AeroElectric-List: wiring the 2-50 switch > > > Hi Guys > > As a matter of interest from whom do you get your (e.g.: 2-50) switches > from > > Cheers > > John PPL-England - - RV-9a 'wings' > > > ----- Original Message ----- > From: "glaesers" <glaesers(at)wideopenwest.com> > To: ; > Sent: Saturday, July 28, 2007 4:15 AM > Subject: AeroElectric-List: wiring the 2-50 switch > > >> >> >> Frank, >> >> If you have the AeroElectric Connection manual - see page 11-18. >> >> Looking at the back of the 2-50 switch, with the keyway UP, the contact >> numbers are: >> >> 6 - 3 >> 5 - 2 -- power IN to contacts 2 and 5 - each side is independent (4-5-6 >> independent of 1-2-3) >> 4 - 1 >> >> When the switch is in the DOWN position (opposite the keyway): >> - contacts 5 and 6 are connected >> - contacts 2 and 3 are connected >> >> When the switch is in the MIDDLE position: >> - contacts 5 and 6 are still connected >> - contacts 2 and 1 are connected (no power to 3) >> >> In the UP (momentary position): >> - contacts 5 and 4 are connected (no power to 6) - so the 5-4 combination >> is the only one that is 'momentary' >> - contacts 2 and 1 are connected (no power to 3) >> >> Hope this helps. >> >> Dennis Glaeser >> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 28, 2007
Frank, Are you using the AeroElectric schematics? If so look at the Z-11 figure and you will see that to wire the fuel pump and primer you come off of the endurance bus 3 amp fuse with a 22 awg wire to the #5, there is a jumper that goes to #2, then there is a 22 awg wire that goes to the primer off of #4 and a 22awg to the fuel boost pump off of #1. There are no grounds off of the switch. The devices you are trying to power are grounded at the device or run a ground from them back to your ground block. I wired my switch just like I described and it works just fine. How are you numbering the switch pole positions. With the keyway pointing up and facing away from you. The numbers are from the bottom left 1, 2, 3 then on the right bottom up, 4, 5, 6.. www.aeroelectric.com/articles/switches.pdf The 2-50 switch is a real neat switch, it is an on-on-on switch. Perhaps to get the switch to do what you want it to do you need an different switch? Maybe next week when everyone is back from Oshkosh you will get a better answer. I am heading out for the weekend to go hiking and camping in the mountains, first this morning we will do some hovercraft flying. Good luck. Mike ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Saturday, July 28, 2007 4:26 AM Subject: Re: AeroElectric-List: Re: S700 2-50 switch wiring > > > Mike > > It appears that all roads as they say lead to Rome or in this case to the > motor working. #2 to power bus, #5 to ground #1 to red wire from pump > motor # 6 to black wire from pump, #1 to #3 gives me continuity in toggle > mid and momentary up position. > > Thanks for the help I am still wrestling with this is the final results > for the aux fuel pump/prime. > > Frank @ SGU RV7A Wiring > > >>From: "Michael T. Ice" <aurbo(at)ak.net> >>Reply-To: aeroelectric-list(at)matronics.com >>To: aeroelectric-list(at)matronics.com >>Subject: Re: AeroElectric-List: Re: S700 2-50 switch wiring >>Date: Fri, 27 Jul 2007 18:44:18 -0800 >> >> >>Frank, >> >>On the Z-11 drawing it shows that the power from the main bus goes to #5 >>with a jumper to #2. Why do you have a ground on #5? The grounds go on the >>other side of the fuel pumps and it shows both of them grounded to the >>panel. It seems to me that the way you describe it you have the switch >>shorted out. >> >>I am not an electrical genius just another guy wiring up an RV so I hope >>you get some other suggestions. >> >>Mike Ice >>Fire wall forward, rewiring the mag switches for emag/pmag, adding >>accessories to the motor. >> >>----- Original Message ----- From: "Frank Stringham" >> >>To: >>Sent: Friday, July 27, 2007 1:43 PM >>Subject: AeroElectric-List: Re: S700 2-50 switch wiring >> >> >>> >>> >>> >>> >>> >>>HELP!!!!!!!!!!! >>> >>>I am using an S700 2-50 switch to activate my fuel pump. So far I have >>>been unable to brake the code. I have so far used multiple schemes >>>.......I can get it to work to this point....toggle down OFF.....toogle >>>mid position (on)......toggle up notta?????????????...for the momentary >>>on. Right now I have #2 to power bus, #5 to ground, #1 to pump >>>motor...red, #6 to pump motor....black , and #3 to #6. >>> >>>Thanks for any and all suggestions. >>> >>>Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway >>> >>>_________________________________________________________________ >>>http://newlivehotmail.com >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > _________________________________________________________________ > > > ________________________________________________________________________________
Date: Jul 28, 2007
Frank, I just realized it doesn't matter how you number that poles on the back of the switch as long as you know that the two poles in the middles are #'s 2 & 5. The switch is actually 2 switches in one with the power lead going into the middle position on each switch. Have fun. Mike ----- Original Message ----- From: "Frank Stringham" <fstringham(at)hotmail.com> Sent: Saturday, July 28, 2007 4:26 AM Subject: Re: AeroElectric-List: Re: S700 2-50 switch wiring > > > Mike > > It appears that all roads as they say lead to Rome or in this case to the > motor working. #2 to power bus, #5 to ground #1 to red wire from pump > motor # 6 to black wire from pump, #1 to #3 gives me continuity in toggle > mid and momentary up position. > > Thanks for the help I am still wrestling with this is the final results > for the aux fuel pump/prime. > > Frank @ SGU RV7A Wiring > > >>From: "Michael T. Ice" <aurbo(at)ak.net> >>Reply-To: aeroelectric-list(at)matronics.com >>To: aeroelectric-list(at)matronics.com >>Subject: Re: AeroElectric-List: Re: S700 2-50 switch wiring >>Date: Fri, 27 Jul 2007 18:44:18 -0800 >> >> >>Frank, >> >>On the Z-11 drawing it shows that the power from the main bus goes to #5 >>with a jumper to #2. Why do you have a ground on #5? The grounds go on the >>other side of the fuel pumps and it shows both of them grounded to the >>panel. It seems to me that the way you describe it you have the switch >>shorted out. >> >>I am not an electrical genius just another guy wiring up an RV so I hope >>you get some other suggestions. >> >>Mike Ice >>Fire wall forward, rewiring the mag switches for emag/pmag, adding >>accessories to the motor. >> >>----- Original Message ----- From: "Frank Stringham" >> >>To: >>Sent: Friday, July 27, 2007 1:43 PM >>Subject: AeroElectric-List: Re: S700 2-50 switch wiring >> >> >>> >>> >>> >>> >>> >>>HELP!!!!!!!!!!! >>> >>>I am using an S700 2-50 switch to activate my fuel pump. So far I have >>>been unable to brake the code. I have so far used multiple schemes >>>.......I can get it to work to this point....toggle down OFF.....toogle >>>mid position (on)......toggle up notta?????????????...for the momentary >>>on. Right now I have #2 to power bus, #5 to ground, #1 to pump >>>motor...red, #6 to pump motor....black , and #3 to #6. >>> >>>Thanks for any and all suggestions. >>> >>>Frank @ SGU RV7A Panel Complete except for HS34....Wiring underway >>> >>>_________________________________________________________________ >>>http://newlivehotmail.com >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> > > _________________________________________________________________ > > > ________________________________________________________________________________
Date: Jul 28, 2007
Does this mean that you guys are running more than 6" vacuum in order to put the warning light out?? I had thought that 5" was about normal?? I'm using a solid state sensor to feed my EIS but have only set the regulator for about 5". However sometime after a hundred hours or so my imported horizon became somewhat erratic and unreliable. Ken " New WASCO model 414-0005. Compact size vacuum switch. Single pole contacts open at 6" Hg., close at 3" Hg. Factory setting non-adjustable. Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port 1/8" NPT. 30" Hg. max. Shpg. 1/4 lb. rd2(at)evenlink.com wrote: > >Michael- > >This switch, along with a blinking LED, should work fine: > >http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >ame > >The chamber is SS. > >The problem is, it would need a field approval for certified aircraft - and >local FSDO's may not be very sympathetic to messing with the vac system. >I'd like to get my hnads on such a field approval for my own installation. >Anyone? > >Best >Rumen > > >_____________________Original message __________________________ > (received from Michael Hinchcliff; Date: 06:32 PM >________________________________________________________________ > >I would like to add a vacuum pressure warning light to my ship's panel. >What do you guys recommend? Is there a particular vacuum pressure switch >that I can connect to my vac line that will illuminate a panel lamp in the >event the vacuum pressure slides to an unsafe level - or is there another >(better) way to do this? > >Michael H. > > ________________________________________________________________________________
Date: Jul 28, 2007
Yes, 5 in Hg is normal. I'm going to wire this so the light illuminates when the pressure falls above the 6 inch Hg range (i.e. vac failure). If it does not work out, I'll be out just 8 bucks. ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> Sent: Saturday, July 28, 2007 12:12 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > Does this mean that you guys are running more than 6" vacuum in order to > put the warning light out?? I had thought that 5" was about normal?? > > I'm using a solid state sensor to feed my EIS but have only set the > regulator for about 5". However sometime after a hundred hours or so my > imported horizon became somewhat erratic and unreliable. > > Ken > > " New WASCO model 414-0005. Compact size vacuum switch. Single pole > contacts open at 6" Hg., close at 3" Hg. Factory setting non-adjustable. > Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port 1/8" > NPT. 30" Hg. max. Shpg. 1/4 lb. > > rd2(at)evenlink.com wrote: > >> >>Michael- >> >>This switch, along with a blinking LED, should work fine: >> >>http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >>ame >> >>The chamber is SS. >> >>The problem is, it would need a field approval for certified aircraft - >>and >>local FSDO's may not be very sympathetic to messing with the vac system. >>I'd like to get my hnads on such a field approval for my own installation. >>Anyone? >> >>Best Rumen >> >> >>_____________________Original message __________________________ >> (received from Michael Hinchcliff; Date: 06:32 PM >>________________________________________________________________ >> >>I would like to add a vacuum pressure warning light to my ship's panel. >>What do you guys recommend? Is there a particular vacuum pressure switch >>that I can connect to my vac line that will illuminate a panel lamp in the >>event the vacuum pressure slides to an unsafe level - or is there another >>(better) way to do this? >> Michael H. >> > > > ________________________________________________________________________________
Date: Jul 28, 2007
Hmmm I don't think that will work Michael. If I read this correctly, it seems to me that switch will do nothing at all unless it has more than 6" of vacuum applied at every startup. After that then the contacts would close at shutdown or whenever vacuum fell to less than 3". Ken Michael Hinchcliff wrote: > > > Yes, 5 in Hg is normal. I'm going to wire this so the light > illuminates when the pressure falls above the 6 inch Hg range (i.e. > vac failure). If it does not work out, I'll be out just 8 bucks. > > ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> > To: > Sent: Saturday, July 28, 2007 12:12 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > >> >> Does this mean that you guys are running more than 6" vacuum in order >> to put the warning light out?? I had thought that 5" was about normal?? >> >> I'm using a solid state sensor to feed my EIS but have only set the >> regulator for about 5". However sometime after a hundred hours or so >> my imported horizon became somewhat erratic and unreliable. >> >> Ken >> >> " New WASCO model 414-0005. Compact size vacuum switch. Single pole >> contacts open at 6" Hg., close at 3" Hg. Factory setting >> non-adjustable. Contacts rated to 5 Amps at 230 volt AC. Spade >> terminals 1/4". Port 1/8" NPT. 30" Hg. max. Shpg. 1/4 lb. >> >> rd2(at)evenlink.com wrote: >> >>> >>> Michael- >>> >>> This switch, along with a blinking LED, should work fine: >>> >>> http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >>> >>> ame >>> >>> The chamber is SS. >>> >>> The problem is, it would need a field approval for certified >>> aircraft - and >>> local FSDO's may not be very sympathetic to messing with the vac >>> system. >>> I'd like to get my hnads on such a field approval for my own >>> installation. >>> Anyone? >>> >>> Best Rumen >>> >>> >>> _____________________Original message __________________________ >>> (received from Michael Hinchcliff; Date: 06:32 PM >>> ________________________________________________________________ >>> >>> I would like to add a vacuum pressure warning light to my ship's panel. >>> What do you guys recommend? Is there a particular vacuum pressure >>> switch >>> that I can connect to my vac line that will illuminate a panel lamp >>> in the >>> event the vacuum pressure slides to an unsafe level - or is there >>> another >>> (better) way to do this? >>> Michael H. >>> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Subject: please remove me from list thanks
Date: Jul 29, 2007
Date: Jul 28, 2007
Did not make Oshkosh but there is spirit. Super! Of coruse its the hottest Tee-shirt. I LOVE IT, but I want a cut of sales. Figure @ $50 a pop they'll sell out. I think its hilarious. Some one has a sense of humor, which is refreshing. Life is too short and this is suppose to be fun. Peace. My next shirt will be a big read circle with a diagonal & the word CROWBAR, ha ha. The Real GMCJETPILOT PS I want Tee-shit with the NOT crossed out. LOL >From: "Bruce Gray" >Subject: RE: AeroElectric-List: The hottest T-shirt at Oshkosh > >A green t-shirt with block letters that said, "I am NOT gmcjetpilot". > >Bruce --------------------------------- Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool. ________________________________________________________________________________
Date: Jul 28, 2007
Subject: Very bad RFI
Hello, I joined this list with the hope that I could try to solve my problem in my Q2 with a Revmaster engine. At 450 hours on the engine I converted to auto plugs. I changed the heads and replaced the aviation plug connection with auto plug connections supplied with the conversion. The RFI is so bad that my transponder reply light looks like a timing light. My Tru Trak auto pilot won't stay booted up, and the noise is heard on my com. Things I've tried are...Lonestar mag filters and eliminator power filter. Checking all grounds and relocating several to a common grounding lug. Wrapping the plug connections with tin foil to try to shield the interference. Checking all of the antenna connections. Disconnecting various radios and avionics,trying to isolate a particular source. Nothing worked. I used my handheld radio in the cockpit and didn't pick up any noise. I also called Revmaster and they is the ones who suggested trying the tin foil shielding. The engine is carburated and uses a Bendix 3000 series dual mag. Plugs are NGK resistor plugs, gapped at .016". Hopefully someone has a suggestion, or should I consider going back to the aviation setup. Is there a different harness that would work? The unfortunate thing is that any work that is done on the magnito requires that the engine is removed enough to access the mag which is recessed into the firewall. Thank you. Dave D. --------------------------------- ________________________________________________________________________________
Date: Jul 28, 2007
Hello, Ken. Since the vacuum system will always initialize at atmospheric pressure (29.92 Hg give or take) at each startup and then work it's way down to 5" Hg after startup, the switch should work fine according to my interpretation of the description, "Contact open at 6" Hg., close at 3" Hg". I interpret that the contactor will be disengaged (i.e. light off) while between 3-6" Hg, which is what I'm looking for. Please let me know if you think I am overlooking something here. ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> Sent: Saturday, July 28, 2007 3:00 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > Hmmm I don't think that will work Michael. If I read this correctly, it > seems to me that switch will do nothing at all unless it has more than 6" > of vacuum applied at every startup. After that then the contacts would > close at shutdown or whenever vacuum fell to less than 3". > Ken > > Michael Hinchcliff wrote: > >> >> >> Yes, 5 in Hg is normal. I'm going to wire this so the light illuminates >> when the pressure falls above the 6 inch Hg range (i.e. vac failure). If >> it does not work out, I'll be out just 8 bucks. >> >> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> >> To: >> Sent: Saturday, July 28, 2007 12:12 PM >> Subject: Re: AeroElectric-List: Vacuume pressure warning light >> >> >>> >>> Does this mean that you guys are running more than 6" vacuum in order to >>> put the warning light out?? I had thought that 5" was about normal?? >>> >>> I'm using a solid state sensor to feed my EIS but have only set the >>> regulator for about 5". However sometime after a hundred hours or so my >>> imported horizon became somewhat erratic and unreliable. >>> >>> Ken >>> >>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole >>> contacts open at 6" Hg., close at 3" Hg. Factory setting non-adjustable. >>> Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port 1/8" >>> NPT. 30" Hg. max. Shpg. 1/4 lb. >>> >>> rd2(at)evenlink.com wrote: >>> >>>> >>>> Michael- >>>> >>>> This switch, along with a blinking LED, should work fine: >>>> >>>> http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >>>> ame >>>> >>>> The chamber is SS. >>>> >>>> The problem is, it would need a field approval for certified aircraft - >>>> and >>>> local FSDO's may not be very sympathetic to messing with the vac >>>> system. >>>> I'd like to get my hnads on such a field approval for my own >>>> installation. >>>> Anyone? >>>> >>>> Best Rumen >>>> >>>> >>>> _____________________Original message __________________________ >>>> (received from Michael Hinchcliff; Date: 06:32 PM >>>> ________________________________________________________________ >>>> >>>> I would like to add a vacuum pressure warning light to my ship's panel. >>>> What do you guys recommend? Is there a particular vacuum pressure >>>> switch >>>> that I can connect to my vac line that will illuminate a panel lamp in >>>> the >>>> event the vacuum pressure slides to an unsafe level - or is there >>>> another >>>> (better) way to do this? >>>> Michael H. >>>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > > ________________________________________________________________________________
Date: Jul 28, 2007
Subject: Re: Very bad RFI
I'll be interested to hear the replies on this. I am thinking about going to auto plugs for the same RFI reason on my LOM engine (Czechoslovakian) -- I'm planning on getting racing wire with 150 ohms per foot and shielding it with braid (you can get it from Aircraft spruce) and grounding only the mag end, and using heat shrink to hold the other end on the plug without a ground at each end (which defeats the shield).. Keep us advised as to what you do. bobf On 7/28/07, Dave Dugas wrote: > > Hello, > > I joined this list with the hope that I could try to solve my problem in > my Q2 with a Revmaster engine. At 450 hours on the engine I converted to > auto plugs. I changed the heads and replaced the aviation plug connection > with auto plug connections supplied with the conversion. The RFI is so bad > that my transponder reply light looks like a timing light. My Tru Trak auto > pilot won't stay booted up, and the noise is heard on my com. Things I've > tried are...Lonestar mag filters and eliminator power filter. Checking all > grounds and relocating several to a common grounding lug. Wrapping the plug > connections with tin foil to try to shield the interference. Checking all > of the antenna connections. Disconnecting various radios > and avionics,trying to isolate a particular source. Nothing worked. > > I used my handheld radio in the cockpit and didn't pick up any noise. I > also called Revmaster and they is the ones who suggested trying the tin foil > shielding. > > The engine is carburated and uses a Bendix 3000 series dual mag. Plugs > are NGK resistor plugs, gapped at .016". Hopefully someone has a > suggestion, or should I consider going back to the aviation setup. Is there > a different harness that would work? The unfortunate thing is that any work > that is done on the magnito requires that the engine is removed enough to > access the mag which is recessed into the firewall. Thank you. Dave D. > > ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Jul 28, 2007
Michael; The system starts out at give or take 29.92 inches of positive pressure, then gets "sucked" down to "zero" positive pressure by the vacuum pump, then gets sucked down further until 1" of vacuum (or negative pressure) is created, then 2" of vacuum etc until finally you have, give or take, 5" of vacuum. It will, in theory, never reach 6" of vacuum unless your vacuum regulator fails and allows the pump to create "extra" vacuum if it's capable. Your switch will therefore switch on as it passes 3" of vacuum, but it will be "ON" at the normal vacuum of 5", it will never reach 6" to turn "OFF", just the opposite of what you describe. (ON between 3 and 6, not OFF) Bob McC ----- Original Message ----- From: "Michael Hinchcliff" <cfi(at)conwaycorp.net> Sent: Saturday, July 28, 2007 5:31 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > Hello, Ken. Since the vacuum system will always initialize at atmospheric > pressure (29.92 Hg give or take) at each startup and then work it's way > down to 5" Hg after startup, the switch should work fine according to my > interpretation of the description, "Contact open at 6" Hg., close at 3" Hg". > I interpret that the contactor will be disengaged (i.e. light off) while > between 3-6" Hg, which is what I'm looking for. Please let me know if you > think I am overlooking something here. > > > ----- Original Message ----- > From: "Ken" <klehman(at)albedo.net> > To: > Sent: Saturday, July 28, 2007 3:00 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > > > > Hmmm I don't think that will work Michael. If I read this correctly, it > > seems to me that switch will do nothing at all unless it has more than 6" > > of vacuum applied at every startup. After that then the contacts would > > close at shutdown or whenever vacuum fell to less than 3". > > Ken > > > > Michael Hinchcliff wrote: > > > >> > >> > >> Yes, 5 in Hg is normal. I'm going to wire this so the light illuminates > >> when the pressure falls above the 6 inch Hg range (i.e. vac failure). If > >> it does not work out, I'll be out just 8 bucks. > >> > >> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> > >> To: > >> Sent: Saturday, July 28, 2007 12:12 PM > >> Subject: Re: AeroElectric-List: Vacuume pressure warning light > >> > >> > >>> > >>> Does this mean that you guys are running more than 6" vacuum in order to > >>> put the warning light out?? I had thought that 5" was about normal?? > >>> > >>> I'm using a solid state sensor to feed my EIS but have only set the > >>> regulator for about 5". However sometime after a hundred hours or so my > >>> imported horizon became somewhat erratic and unreliable. > >>> > >>> Ken > >>> > >>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole > >>> contacts open at 6" Hg., close at 3" Hg. Factory setting non-adjustable. > >>> Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port 1/8" > >>> NPT. 30" Hg. max. Shpg. 1/4 lb. > >>> > >>> rd2(at)evenlink.com wrote: > >>> > >>>> > >>>> Michael- > >>>> > >>>> This switch, along with a blinking LED, should work fine: > >>>> > >>>> http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn > >>>> ame > >>>> > >>>> The chamber is SS. > >>>> > >>>> The problem is, it would need a field approval for certified aircraft - > >>>> and > >>>> local FSDO's may not be very sympathetic to messing with the vac > >>>> system. > >>>> I'd like to get my hnads on such a field approval for my own > >>>> installation. > >>>> Anyone? > >>>> > >>>> Best Rumen > >>>> > >>>> > >>>> _____________________Original message __________________________ > >>>> (received from Michael Hinchcliff; Date: 06:32 PM > >>>> ________________________________________________________________ > >>>> > >>>> I would like to add a vacuum pressure warning light to my ship's panel. > >>>> What do you guys recommend? Is there a particular vacuum pressure > >>>> switch > >>>> that I can connect to my vac line that will illuminate a panel lamp in > >>>> the > >>>> event the vacuum pressure slides to an unsafe level - or is there > >>>> another > >>>> (better) way to do this? > >>>> Michael H. > >>>> > >>> > >>> > >>> > >>> > >>> > >>> > >>> > >> > >> > >> > >> > >> > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 28, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> > >Frank, > >If you have the AeroElectric Connection manual - see page 11-18. > >Looking at the back of the 2-50 switch, with the keyway UP, the contact >numbers are: > > 6 - 3 > 5 - 2 -- power IN to contacts 2 and 5 - each side is independent > (4-5-6 >independent of 1-2-3) > 4 - 1 > >When the switch is in the DOWN position (opposite the keyway): > - contacts 5 and 6 are connected > - contacts 2 and 3 are connected > >When the switch is in the MIDDLE position: > - contacts 5 and 6 are still connected > - contacts 2 and 1 are connected (no power to 3) > >In the UP (momentary position): > - contacts 5 and 4 are connected (no power to 6) - so the 5-4 > combination >is the only one that is 'momentary' > - contacts 2 and 1 are connected (no power to 3) > >Hope this helps. > >Dennis Glaeser Also, be aware that there are two configurations for the 2-10 switching philosophy depending on who makes the switch. See note 15 and illustration in: http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf Bob . . . ________________________________________________________________________________
Date: Jul 28, 2007
Subject: Home from OSH but still out of service for a bit
My father's condition took a turn for the worse while at OSH and we returned two days early. Will be heading to Medicine Lodge, KS in a few minutes and will no doubt be very occupied on other matters for the near term. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 28, 2007
This switch almost certainly works on gauge pressure, rather than absolute pressure. Gauge pressure is the difference between the pressure of interest and ambient pressure. The vacuum system will have a gauge pressure of zero prior to engine start, and the vacuum will increase to a gauge pressure of about 5" Hg once the engine is running (i.e. the absolute pressure in the vacuum system will be 5" Hg lower than ambient pressure). If the spec sheet values are accurate, the contacts would remain closed unless the vacuum ever got greater than 6" Hg, which should only happen if the regulator fails. I don't think this switch will work for you. But, all you risk is $8 and a bit of time and energy. Kevin Horton On 28 Jul 2007, at 17:31, Michael Hinchcliff wrote: > > > Hello, Ken. Since the vacuum system will always initialize at > atmospheric pressure (29.92 Hg give or take) at each startup and > then work it's way down to 5" Hg after startup, the switch should > work fine according to my interpretation of the description, > "Contact open at 6" Hg., close at 3" Hg". I interpret that the > contactor will be disengaged (i.e. light off) while between 3-6" > Hg, which is what I'm looking for. Please let me know if you think > I am overlooking something here. > > > ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> > To: > Sent: Saturday, July 28, 2007 3:00 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > >> >> Hmmm I don't think that will work Michael. If I read this >> correctly, it seems to me that switch will do nothing at all >> unless it has more than 6" of vacuum applied at every startup. >> After that then the contacts would close at shutdown or whenever >> vacuum fell to less than 3". >> Ken >> >> Michael Hinchcliff wrote: >> >>> >>> >>> Yes, 5 in Hg is normal. I'm going to wire this so the light >>> illuminates when the pressure falls above the 6 inch Hg range >>> (i.e. vac failure). If it does not work out, I'll be out just 8 >>> bucks. >>> >>> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> >>> To: >>> Sent: Saturday, July 28, 2007 12:12 PM >>> Subject: Re: AeroElectric-List: Vacuume pressure warning light >>> >>> >>>> >>>> Does this mean that you guys are running more than 6" vacuum in >>>> order to put the warning light out?? I had thought that 5" was >>>> about normal?? >>>> >>>> I'm using a solid state sensor to feed my EIS but have only set >>>> the regulator for about 5". However sometime after a hundred >>>> hours or so my imported horizon became somewhat erratic and >>>> unreliable. >>>> >>>> Ken >>>> >>>> " New WASCO model 414-0005. Compact size vacuum switch. Single >>>> pole contacts open at 6" Hg., close at 3" Hg. Factory setting >>>> non-adjustable. Contacts rated to 5 Amps at 230 volt AC. Spade >>>> terminals 1/4". Port 1/8" NPT. 30" Hg. max. Shpg. 1/4 lb. >>>> >>>> rd2(at)evenlink.com wrote: >>>> >>>>> >>>>> Michael- >>>>> >>>>> This switch, along with a blinking LED, should work fine: >>>>> >>>>> http://www.surpluscenter.com/item.asp? >>>>> UID 05081210041966&item=11-2344&catn >>>>> ame >>>>> >>>>> The chamber is SS. >>>>> >>>>> The problem is, it would need a field approval for certified >>>>> aircraft - and >>>>> local FSDO's may not be very sympathetic to messing with the >>>>> vac system. >>>>> I'd like to get my hnads on such a field approval for my own >>>>> installation. >>>>> Anyone? >>>>> >>>>> Best Rumen >>>>> >>>>> >>>>> _____________________Original message __________________________ >>>>> (received from Michael Hinchcliff; Date: 06:32 PM >>>>> ________________________________________________________________ >>>>> >>>>> I would like to add a vacuum pressure warning light to my >>>>> ship's panel. >>>>> What do you guys recommend? Is there a particular vacuum >>>>> pressure switch >>>>> that I can connect to my vac line that will illuminate a panel >>>>> lamp in the >>>>> event the vacuum pressure slides to an unsafe level - or is >>>>> there another >>>>> (better) way to do this? >>>>> Michael H. >>>>> >>>> >>>> >>>> ________________________________________________________________________________
Date: Jul 28, 2007
Please forget this post. My mind was completely somewhere else and this description is obvious nonsense. Sorry. Bob McC ----- Original Message ----- From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca> Sent: Saturday, July 28, 2007 7:01 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > Michael; > The system starts out at give or take 29.92 inches of positive pressure, > then gets "sucked" down to "zero" positive pressure by the vacuum pump, then > gets sucked down further until 1" of vacuum (or negative pressure) is > created, then 2" of vacuum etc until finally you have, give or take, 5" of > vacuum. It will, in theory, never reach 6" of vacuum unless your vacuum > regulator fails and allows the pump to create "extra" vacuum if it's > capable. Your switch will therefore switch on as it passes 3" of vacuum, but > it will be "ON" at the normal vacuum of 5", it will never reach 6" to turn > "OFF", just the opposite of what you describe. (ON between 3 and 6, not OFF) > > Bob McC > > ----- Original Message ----- > From: "Michael Hinchcliff" <cfi(at)conwaycorp.net> > To: > Sent: Saturday, July 28, 2007 5:31 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > > > > > Hello, Ken. Since the vacuum system will always initialize at atmospheric > > pressure (29.92 Hg give or take) at each startup and then work it's way > > down to 5" Hg after startup, the switch should work fine according to my > > interpretation of the description, "Contact open at 6" Hg., close at 3" > Hg". > > I interpret that the contactor will be disengaged (i.e. light off) while > > between 3-6" Hg, which is what I'm looking for. Please let me know if you > > think I am overlooking something here. > > > > > > > > ----- Original Message ----- > > From: "Ken" <klehman(at)albedo.net> > > To: > > Sent: Saturday, July 28, 2007 3:00 PM > > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > > > > > > > > Hmmm I don't think that will work Michael. If I read this correctly, it > > > seems to me that switch will do nothing at all unless it has more than > 6" > > > of vacuum applied at every startup. After that then the contacts would > > > close at shutdown or whenever vacuum fell to less than 3". > > > Ken > > > > > > Michael Hinchcliff wrote: > > > > > >> > > >> > > >> Yes, 5 in Hg is normal. I'm going to wire this so the light > illuminates > > >> when the pressure falls above the 6 inch Hg range (i.e. vac failure). > If > > >> it does not work out, I'll be out just 8 bucks. > > >> > > >> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> > > >> To: > > >> Sent: Saturday, July 28, 2007 12:12 PM > > >> Subject: Re: AeroElectric-List: Vacuume pressure warning light > > >> > > >> > > >>> > > >>> Does this mean that you guys are running more than 6" vacuum in order > to > > >>> put the warning light out?? I had thought that 5" was about normal?? > > >>> > > >>> I'm using a solid state sensor to feed my EIS but have only set the > > >>> regulator for about 5". However sometime after a hundred hours or so > my > > >>> imported horizon became somewhat erratic and unreliable. > > >>> > > >>> Ken > > >>> > > >>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole > > >>> contacts open at 6" Hg., close at 3" Hg. Factory setting > non-adjustable. > > >>> Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port > 1/8" > > >>> NPT. 30" Hg. max. Shpg. 1/4 lb. > > >>> > > >>> rd2(at)evenlink.com wrote: > > >>> > > >>>> > > >>>> Michael- > > >>>> > > >>>> This switch, along with a blinking LED, should work fine: > > >>>> > > >>>> > http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn > > >>>> ame > > >>>> > > >>>> The chamber is SS. > > >>>> > > >>>> The problem is, it would need a field approval for certified > aircraft - > > >>>> and > > >>>> local FSDO's may not be very sympathetic to messing with the vac > > >>>> system. > > >>>> I'd like to get my hnads on such a field approval for my own > > >>>> installation. > > >>>> Anyone? > > >>>> > > >>>> Best Rumen > > >>>> > > >>>> > > >>>> _____________________Original message __________________________ > > >>>> (received from Michael Hinchcliff; Date: 06:32 PM > > >>>> ________________________________________________________________ > > >>>> > > >>>> I would like to add a vacuum pressure warning light to my ship's > panel. > > >>>> What do you guys recommend? Is there a particular vacuum pressure > > >>>> switch > > >>>> that I can connect to my vac line that will illuminate a panel lamp > in > > >>>> the > > >>>> event the vacuum pressure slides to an unsafe level - or is there > > >>>> another > > >>>> (better) way to do this? > > >>>> Michael H. > > >>>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >>> > > >> > > >> > > >> > > >> > > >> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jul 28, 2007
Michael Since it is called a vacuum switch, I'm guessing it is referenced to atmospheric and the switch points are 3" and 6" below ambient atmospheric pressure. The 30" max vacuum in the specification tends to confirm that to me but I could be wrong about that. Ken Michael Hinchcliff wrote: > > > Hello, Ken. Since the vacuum system will always initialize at > atmospheric pressure (29.92 Hg give or take) at each startup and then > work it's way down to 5" Hg after startup, the switch should work fine > according to my interpretation of the description, "Contact open at 6" > Hg., close at 3" Hg". I interpret that the contactor will be > disengaged (i.e. light off) while between 3-6" Hg, which is what I'm > looking for. Please let me know if you think I am overlooking > something here. > > > ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> > To: > Sent: Saturday, July 28, 2007 3:00 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > >> >> Hmmm I don't think that will work Michael. If I read this correctly, >> it seems to me that switch will do nothing at all unless it has more >> than 6" of vacuum applied at every startup. After that then the >> contacts would close at shutdown or whenever vacuum fell to less than >> 3". >> Ken >> >> Michael Hinchcliff wrote: >> >>> >>> >>> Yes, 5 in Hg is normal. I'm going to wire this so the light >>> illuminates when the pressure falls above the 6 inch Hg range (i.e. >>> vac failure). If it does not work out, I'll be out just 8 bucks. >>> >>> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> >>> To: >>> Sent: Saturday, July 28, 2007 12:12 PM >>> Subject: Re: AeroElectric-List: Vacuume pressure warning light >>> >>> >>>> >>>> Does this mean that you guys are running more than 6" vacuum in >>>> order to put the warning light out?? I had thought that 5" was >>>> about normal?? >>>> >>>> I'm using a solid state sensor to feed my EIS but have only set the >>>> regulator for about 5". However sometime after a hundred hours or >>>> so my imported horizon became somewhat erratic and unreliable. >>>> >>>> Ken >>>> >>>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole >>>> contacts open at 6" Hg., close at 3" Hg. Factory setting >>>> non-adjustable. Contacts rated to 5 Amps at 230 volt AC. Spade >>>> terminals 1/4". Port 1/8" NPT. 30" Hg. max. Shpg. 1/4 lb. >>>> >>>> rd2(at)evenlink.com wrote: >>>> >>>>> >>>>> Michael- >>>>> >>>>> This switch, along with a blinking LED, should work fine: >>>>> >>>>> http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >>>>> >>>>> ame >>>>> >>>>> The chamber is SS. >>>>> >>>>> The problem is, it would need a field approval for certified >>>>> aircraft - and >>>>> local FSDO's may not be very sympathetic to messing with the vac >>>>> system. >>>>> I'd like to get my hnads on such a field approval for my own >>>>> installation. >>>>> Anyone? >>>>> >>>>> Best Rumen >>>>> >>>>> >>>>> _____________________Original message __________________________ >>>>> (received from Michael Hinchcliff; Date: 06:32 PM >>>>> ________________________________________________________________ >>>>> >>>>> I would like to add a vacuum pressure warning light to my ship's >>>>> panel. >>>>> What do you guys recommend? Is there a particular vacuum pressure >>>>> switch >>>>> that I can connect to my vac line that will illuminate a panel >>>>> lamp in the >>>>> event the vacuum pressure slides to an unsafe level - or is there >>>>> another >>>>> (better) way to do this? >>>>> Michael H. >>>>> >>>> >>>> >>>> >>>> ________________________________________________________________________________
Date: Jul 28, 2007
I run dual DIS (distributorless) ignition with high voltage coil joiners on my subaru with a total of 12 high voltage ignition wires. I have no igniton noise or interference but I do run highly recommended premium 8.5mm Taylor spiral wound racing wires. I run 40 thou spark plug gap and I think my ignition voltage is quite a bit higher than most magnetos. The Taylor website used to explain a fair bit about ignition wires but as I recall mine are considerably more than 150 ohms per foot. Ken Robert Feldtman wrote: > I'll be interested to hear the replies on this. I am thinking about > going to auto plugs for the same RFI reason on my LOM engine > (Czechoslovakian) -- I'm planning on getting racing wire with 150 ohms > per foot and shielding it with braid (you can get it from Aircraft > spruce) and grounding only the mag end, and using heat shrink to hold > the other end on the plug without a ground at each end (which defeats > the shield).. Keep us advised as to what you do. > > bobf > > On 7/28/07, Dave Dugas > wrote: > > Hello, > > I joined this list with the hope that I could try to solve my > problem in my Q2 with a Revmaster engine. At 450 hours on the > engine I converted to auto plugs. I changed the heads and > replaced the aviation plug connection with auto plug connections > supplied with the conversion. The RFI is so bad that my > transponder reply light looks like a timing light. My Tru Trak > auto pilot won't stay booted up, and the noise is heard on my > com. Things I've tried are...Lonestar mag filters and eliminator > power filter. Checking all grounds and relocating several to a > common grounding lug. Wrapping the plug connections with tin foil > to try to shield the interference. Checking all of the antenna > connections. Disconnecting various radios and avionics,trying to > isolate a particular source. Nothing worked. > > I used my handheld radio in the cockpit and didn't pick up any > noise. I also called Revmaster and they is the ones who suggested > trying the tin foil shielding. > > The engine is carburated and uses a Bendix 3000 series dual mag. > Plugs are NGK resistor plugs, gapped at .016". Hopefully someone > has a suggestion, or should I consider going back to the aviation > setup. Is there a different harness that would work? The > unfortunate thing is that any work that is done on the magnito > requires that the engine is removed enough to access the mag which > is recessed into the firewall. Thank you. Dave D. > > ________________________________________________________________________________
Date: Jul 28, 2007
Bob, you are right. Our vacuum systems require negative 3-5" Hg of vacuum pressure as a opposed to a mere "reduced" pressure that I was thinking of. I confirmed this in the EA-AC-65-15A - A&P Mechanic's airframe handbook. Hence we have VACUUM switch and not a PRESSURE switch. Thank you for the clarification. So, with that said, could a transistor or switch not be used to turn the light off when the vacuum switch engages between 3-5 in Hg? Michael ----- Original Message ----- From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca> Sent: Saturday, July 28, 2007 6:01 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > Michael; > The system starts out at give or take 29.92 inches of positive pressure, > then gets "sucked" down to "zero" positive pressure by the vacuum pump, > then > gets sucked down further until 1" of vacuum (or negative pressure) is > created, then 2" of vacuum etc until finally you have, give or take, 5" of > vacuum. It will, in theory, never reach 6" of vacuum unless your vacuum > regulator fails and allows the pump to create "extra" vacuum if it's > capable. Your switch will therefore switch on as it passes 3" of vacuum, > but > it will be "ON" at the normal vacuum of 5", it will never reach 6" to turn > "OFF", just the opposite of what you describe. (ON between 3 and 6, not > OFF) > > Bob McC > > ----- Original Message ----- > From: "Michael Hinchcliff" <cfi(at)conwaycorp.net> > To: > Sent: Saturday, July 28, 2007 5:31 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > >> >> Hello, Ken. Since the vacuum system will always initialize at atmospheric >> pressure (29.92 Hg give or take) at each startup and then work it's way >> down to 5" Hg after startup, the switch should work fine according to my >> interpretation of the description, "Contact open at 6" Hg., close at 3" > Hg". >> I interpret that the contactor will be disengaged (i.e. light off) while >> between 3-6" Hg, which is what I'm looking for. Please let me know if >> you >> think I am overlooking something here. >> >> >> >> ----- Original Message ----- >> From: "Ken" <klehman(at)albedo.net> >> To: >> Sent: Saturday, July 28, 2007 3:00 PM >> Subject: Re: AeroElectric-List: Vacuume pressure warning light >> >> >> > >> > Hmmm I don't think that will work Michael. If I read this correctly, >> > it >> > seems to me that switch will do nothing at all unless it has more than > 6" >> > of vacuum applied at every startup. After that then the contacts would >> > close at shutdown or whenever vacuum fell to less than 3". >> > Ken >> > >> > Michael Hinchcliff wrote: >> > >> >> >> >> >> >> Yes, 5 in Hg is normal. I'm going to wire this so the light > illuminates >> >> when the pressure falls above the 6 inch Hg range (i.e. vac failure). > If >> >> it does not work out, I'll be out just 8 bucks. >> >> >> >> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> >> >> To: >> >> Sent: Saturday, July 28, 2007 12:12 PM >> >> Subject: Re: AeroElectric-List: Vacuume pressure warning light >> >> >> >> >> >>> >> >>> Does this mean that you guys are running more than 6" vacuum in order > to >> >>> put the warning light out?? I had thought that 5" was about normal?? >> >>> >> >>> I'm using a solid state sensor to feed my EIS but have only set the >> >>> regulator for about 5". However sometime after a hundred hours or so > my >> >>> imported horizon became somewhat erratic and unreliable. >> >>> >> >>> Ken >> >>> >> >>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole >> >>> contacts open at 6" Hg., close at 3" Hg. Factory setting > non-adjustable. >> >>> Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port > 1/8" >> >>> NPT. 30" Hg. max. Shpg. 1/4 lb. >> >>> >> >>> rd2(at)evenlink.com wrote: >> >>> >> >>>> >> >>>> Michael- >> >>>> >> >>>> This switch, along with a blinking LED, should work fine: >> >>>> >> >>>> > http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >> >>>> ame >> >>>> >> >>>> The chamber is SS. >> >>>> >> >>>> The problem is, it would need a field approval for certified > aircraft - >> >>>> and >> >>>> local FSDO's may not be very sympathetic to messing with the vac >> >>>> system. >> >>>> I'd like to get my hnads on such a field approval for my own >> >>>> installation. >> >>>> Anyone? >> >>>> >> >>>> Best Rumen >> >>>> >> >>>> >> >>>> _____________________Original message __________________________ >> >>>> (received from Michael Hinchcliff; Date: 06:32 PM >> >>>> ________________________________________________________________ >> >>>> >> >>>> I would like to add a vacuum pressure warning light to my ship's > panel. >> >>>> What do you guys recommend? Is there a particular vacuum pressure >> >>>> switch >> >>>> that I can connect to my vac line that will illuminate a panel lamp > in >> >>>> the >> >>>> event the vacuum pressure slides to an unsafe level - or is there >> >>>> another >> >>>> (better) way to do this? >> >>>> Michael H. >> >>>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >>> >> >> >> >> >> >> >> >> >> >> >> > >> > >> > >> > >> > >> > >> > >> >> >> >> > > > ________________________________________________________________________________
Subject: Re: Vacuume pressure warning light
Date: Jul 28, 2007
Ok, now that we're all totally confused, I'm going to go ahead and order the $8 switch and see if/how it can be implemented. This should make for a good educational test bed. Stay tuned. ----- Original Message ----- From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca> Sent: Saturday, July 28, 2007 6:55 PM Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > Please forget this post. My mind was completely somewhere else and this > description is obvious nonsense. Sorry. > > Bob McC > > > ----- Original Message ----- > From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca> > To: > Sent: Saturday, July 28, 2007 7:01 PM > Subject: Re: AeroElectric-List: Vacuume pressure warning light > > > >> >> Michael; >> The system starts out at give or take 29.92 inches of positive pressure, >> then gets "sucked" down to "zero" positive pressure by the vacuum pump, > then >> gets sucked down further until 1" of vacuum (or negative pressure) is >> created, then 2" of vacuum etc until finally you have, give or take, 5" >> of >> vacuum. It will, in theory, never reach 6" of vacuum unless your vacuum >> regulator fails and allows the pump to create "extra" vacuum if it's >> capable. Your switch will therefore switch on as it passes 3" of vacuum, > but >> it will be "ON" at the normal vacuum of 5", it will never reach 6" to >> turn >> "OFF", just the opposite of what you describe. (ON between 3 and 6, not > OFF) >> >> Bob McC >> >> ----- Original Message ----- >> From: "Michael Hinchcliff" <cfi(at)conwaycorp.net> >> To: >> Sent: Saturday, July 28, 2007 5:31 PM >> Subject: Re: AeroElectric-List: Vacuume pressure warning light >> >> >> >> > >> > Hello, Ken. Since the vacuum system will always initialize at > atmospheric >> > pressure (29.92 Hg give or take) at each startup and then work it's >> > way >> > down to 5" Hg after startup, the switch should work fine according to >> > my >> > interpretation of the description, "Contact open at 6" Hg., close at 3" >> Hg". >> > I interpret that the contactor will be disengaged (i.e. light off) >> > while >> > between 3-6" Hg, which is what I'm looking for. Please let me know if > you >> > think I am overlooking something here. >> > >> > >> > >> > ----- Original Message ----- >> > From: "Ken" <klehman(at)albedo.net> >> > To: >> > Sent: Saturday, July 28, 2007 3:00 PM >> > Subject: Re: AeroElectric-List: Vacuume pressure warning light >> > >> > >> > > >> > > Hmmm I don't think that will work Michael. If I read this correctly, > it >> > > seems to me that switch will do nothing at all unless it has more >> > > than >> 6" >> > > of vacuum applied at every startup. After that then the contacts >> > > would >> > > close at shutdown or whenever vacuum fell to less than 3". >> > > Ken >> > > >> > > Michael Hinchcliff wrote: >> > > >> > >> >> > >> >> > >> Yes, 5 in Hg is normal. I'm going to wire this so the light >> illuminates >> > >> when the pressure falls above the 6 inch Hg range (i.e. vac >> > >> failure). >> If >> > >> it does not work out, I'll be out just 8 bucks. >> > >> >> > >> ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> >> > >> To: >> > >> Sent: Saturday, July 28, 2007 12:12 PM >> > >> Subject: Re: AeroElectric-List: Vacuume pressure warning light >> > >> >> > >> >> > >>> >> > >>> Does this mean that you guys are running more than 6" vacuum in > order >> to >> > >>> put the warning light out?? I had thought that 5" was about >> > >>> normal?? >> > >>> >> > >>> I'm using a solid state sensor to feed my EIS but have only set the >> > >>> regulator for about 5". However sometime after a hundred hours or >> > >>> so >> my >> > >>> imported horizon became somewhat erratic and unreliable. >> > >>> >> > >>> Ken >> > >>> >> > >>> " New WASCO model 414-0005. Compact size vacuum switch. Single pole >> > >>> contacts open at 6" Hg., close at 3" Hg. Factory setting >> non-adjustable. >> > >>> Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port >> 1/8" >> > >>> NPT. 30" Hg. max. Shpg. 1/4 lb. >> > >>> >> > >>> rd2(at)evenlink.com wrote: >> > >>> >> > >>>> >> > >>>> Michael- >> > >>>> >> > >>>> This switch, along with a blinking LED, should work fine: >> > >>>> >> > >>>> >> > http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >> > >>>> ame >> > >>>> >> > >>>> The chamber is SS. >> > >>>> >> > >>>> The problem is, it would need a field approval for certified >> aircraft - >> > >>>> and >> > >>>> local FSDO's may not be very sympathetic to messing with the vac >> > >>>> system. >> > >>>> I'd like to get my hnads on such a field approval for my own >> > >>>> installation. >> > >>>> Anyone? >> > >>>> >> > >>>> Best Rumen >> > >>>> >> > >>>> >> > >>>> _____________________Original message __________________________ >> > >>>> (received from Michael Hinchcliff; Date: 06:32 PM >> > >>>> ________________________________________________________________ >> > >>>> >> > >>>> I would like to add a vacuum pressure warning light to my ship's >> panel. >> > >>>> What do you guys recommend? Is there a particular vacuum pressure >> > >>>> switch >> > >>>> that I can connect to my vac line that will illuminate a panel >> > >>>> lamp >> in >> > >>>> the >> > >>>> event the vacuum pressure slides to an unsafe level - or is there >> > >>>> another >> > >>>> (better) way to do this? >> > >>>> Michael H. >> > >>>> >> > >>> >> > >>> >> > >>> >> > >>> >> > >>> >> > >>> >> > >>> >> > >> >> > >> >> > >> >> > >> >> > >> >> > > >> > > >> > > >> > > >> > > >> > > >> > > >> > >> > >> > >> > >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Vacuume pressure warning light
Date: Jul 28, 2007
At start up, the vacuum pump will pull at least 6"Hg, settling down to around 5 as the gyros spool up. This will result in the switch passing to "OFF", and remaining thus until the vacuum falls below 3" upon pump failure or switch-off. Kenneth Melvin RV9A ________________________________________________________________________________
Date: Jul 28, 2007
Subject: Re: DIY - In the ear headphones
Hey Ernest. Looks like you're well along with your project! I'm not sure what happened, but I see a post I made sometime back to the EAA1114 list never made it out to the door. Here is a copy of it below.. --Ed At a recent builder meeting, I had mentioned this project in the Cozy community to Ernest. But, this can be used by everyone, not just builders... Here are a couple of people that give instructions on how to make your own Clarity Aloft headset clone for around $100. Maybe even approaching under $50 now if you pay attention and find deals. And when I say a clone, I mean right down to the same Comply ear tips that are used with the Clarity Aloft. Check it out... Nick Ugolini (the original project) http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm Drew Chaplin (latest version by Drew) http://www.cozy1200.com/geeklog/article.php?story 070427102533266 --Ed -- Edward G. Savage egs(at)egsavage.com Ernest Christley wrote: > I've been looking into building a in-the-ear type headset using low-end > earphones, following the example given at > http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm > > > I bought the Phillips ANR headphones from Target. I've got Jim Weir's > impedance matching circuit article describing how to use the audio > transformer, so the headphone portion is in the bag. > > The hangup is with the microphone. I found some discussions where Jim > said that an amplifier is needed to use an electret element. Well, I > picked up Item# 270-090 from Radio Shack today. > http://www.radioshack.com/product/index.jsp?summary=summary&techSpecs=techSpecs¤tTab=techSpecs&cp=&custRatings=custRatings&features=features&accessories=accessories&productId 62215&support=support&tab=summary > > > It has a wiring diagram on the back of the package that seems to > indicate that the single transistor amplifier is already built into the > package. I was going to ask if that was in fact what it indicates, and > inquire whether it would work with the RST-443 intercom. Then I got > antsy and just went and tried it. With only two leads, you know I had > to hook it up backwards and feel disappointed for a minute until I > figured out to turn the leads around. Then it was "WOOHOO!!" all the way. > > I'm now well on my way to having the equivalent of a $500, in-the-ear > headset, and it's only costing me about $50. (Testing is incomplete, > but others have reported resounding success.) > This list provided courtesy of Safe Data, Inc. > To leave send an email to eaa1114-request(at)safedataisp.net with the > Keyword LEAVE in the body. > ________________________________________________________________________________
Date: Jul 28, 2007
From: Tammy and Mike Salzman <arrow54t(at)yahoo.com>
I have installed this pressure/vacuum switch in my Lancair. I connected an LED indicator light. Works great in the SUMMER. In the WINTER, the vacuum pump doesn't pull enough vacuum on startup(cold), to open the contacts which causes the LED to stay lighted. Sometimes, the light will go out during flight. On warm starts in the winter, the light usually goes out. I connected the switch to the gauge port on one of the vacuum instruments. Maybe another location would yield better results. Mike Salzman Fairfield, CA LNCE ----- Original Message ---- From: Ken <klehman(at)albedo.net> Sent: Saturday, July 28, 2007 10:12:45 AM Subject: Re: AeroElectric-List: Vacuume pressure warning light Does this mean that you guys are running more than 6" vacuum in order to put the warning light out?? I had thought that 5" was about normal?? I'm using a solid state sensor to feed my EIS but have only set the regulator for about 5". However sometime after a hundred hours or so my imported horizon became somewhat erratic and unreliable. Ken " New WASCO model 414-0005. Compact size vacuum switch. Single pole contacts open at 6" Hg., close at 3" Hg. Factory setting non-adjustable. Contacts rated to 5 Amps at 230 volt AC. Spade terminals 1/4". Port 1/8" NPT. 30" Hg. max. Shpg. 1/4 lb. rd2(at)evenlink.com wrote: > >Michael- > >This switch, along with a blinking LED, should work fine: > >http://www.surpluscenter.com/item.asp?UID 05081210041966&item=11-2344&catn >ame > >The chamber is SS. > >The problem is, it would need a field approval for certified aircraft - and >local FSDO's may not be very sympathetic to messing with the vac system. >I'd like to get my hnads on such a field approval for my own installation. >Anyone? > >Best >Rumen > > >_____________________Original message __________________________ > (received from Michael Hinchcliff; Date: 06:32 PM >________________________________________________________________ > >I would like to add a vacuum pressure warning light to my ship's panel. >What do you guys recommend? Is there a particular vacuum pressure switch >that I can connect to my vac line that will illuminate a panel lamp in the >event the vacuum pressure slides to an unsafe level - or is there another >(better) way to do this? > >Michael H. > > Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more. http://mobile.yahoo.com/go?refer=1GNXIC ________________________________________________________________________________
Date: Jul 29, 2007
I had a similar problem with RFI in my VariEze when I installed the LSE CD ignition system. I tried the foil covering of the plug leads since it seemed to be high voltage ignition noise in time with plug firing, but it had no effect on lessening the noise in the radio. I had a new set of plug leads made up and the problem was solved. Must have had a minute gap in the lead connections causing a spark gap and RFI. Your local auto parts dealer can make up leads of any length. John Greaves VariEze N81JG Redding, CA -----Original Message----- From: Dave Dugas <davedq2(at)yahoo.com> Sent: Sat, 28 Jul 2007 4:26 pm Subject: AeroElectric-List: Very bad RFI Hello, ? I joined this list?with the hope that I could try to solve my problem in my Q2 with a Revmaster engine.? At 450 hours on the engine I converted to auto plugs.? I changed the heads and replaced the aviation plug connection with auto plug connections supplied with the conversion.? The RFI is so bad that my transponder reply light looks like a timing light.? My Tru Trak auto pilot won't stay booted up, and the noise is heard on my com.? Things I've tried are...Lonestar mag filters and eliminator power filter.? Checking all grounds and relocating several to a common grounding lug.? Wrapping the plug connections with tin foil to try to shield the interference.? Checking all of the antenna connections.? Disconnecting various radios and?avionics,trying to isolate a particular source.? Nothing worked. ? I used my handheld radio in the cockpit and didn't pick up any noise.? I also called Revmaster and they is the ones who suggested trying the tin foil shielding. ? The engine is carburated and uses a Bendix 3000 series dual mag.? Plugs are NGK resistor plugs, gapped at .016".? Hopefully someone has a suggestion, or should I consider going back to the aviation setup.? Is there a different harness that would work?? The unfortunate thing is that any work that is done on the magnito requires that the engine is removed enough to access the mag which is recessed into the firewall.? Thank you.? Dave D. ________________________________________________________________________ ________________________________________________________________________________
Date: Jul 29, 2007
People only do this once....Mine was a car when I was 23. Who needs those resistor/plugs and wires anyway? Or so I thought. Change back to resistor wires and/or plugs and the problem will vanish. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=126163#126163 ________________________________________________________________________________
Subject: Receiving spam trough Matronics
Date: Jul 29, 2007
A while ago I signed up to Matronics, as the Yahoo groups were starting to get lots of spam. I used a unique e-mail address to sign up. Now I am starting to receive spam through that address. Is there any way to trace back who 'leaked' matronics email addresses? Rob ________________________________________________________________________________
Date: Jul 29, 2007
X-mailer: Pegasus Mail for Windows (4.41) > > People only do this once....Mine was a car when I was 23. Who needs those resistor/plugs and wires anyway? > > Or so I thought. > > Change back to resistor wires and/or plugs and the problem will vanish. > > -------- > Eric M. Jones > www.PerihelionDesign.com > 113 Brentwood Drive > Southbridge, MA 01550 > (508) 764-2072 > emjones(at)charter.net Of course, Eric has this one right, too......... ____________________________________________ RFI or "Radio Frequency Interference": Many people believe that spark plugs fire instantly. This is partly true because they fire in milliseconds, although if one looks at an oscilloscope pattern you will see much more than a single instantaneous firing event. Many things also occur that you cannot see even with the oscilloscope. Part of what you cannot see, but can in many cases hear, is the noise that is picked up in the speakers of your car stereo. This is called RFI, or Radio Frequency Interference. Spark Plug Firing Voltages:{PRIVATE "TYPE=PICT;ALT=Spark plug secondary wavefom example"} When the breaker points or solid state ignition unit (switching device) interrupts current flow in the primary ignition circuit and induces current flow into the secondary windings of the coil, there is an instantaneous voltage spike. (as seen in the illustration at right in position A to B). This represents the voltage required to overcome the spark plug and distributor rotor gaps. Once the spark gaps have been bridged, the secondary voltage required to sustain the spark across the gap is much less and drops (as seen in position B to C above). The spark continues to arc across the gap at more or less constant voltage until the arc is extinguished (at position D above). This is due to coil energy drop in that it can not sustain the spark any longer. During this arc duration (Spark Duration), the plug actually fires several times. This is caused by high frequency oscillations in the primary and secondary windings of the coil, which continues to induce voltage spikes. They continue and slowly diminish (positions D to E above) even after they are no longer strong enough to sustain spark. All of this takes place in roughly one thousandth of a second. With our race designed ignition units, they concentrate their efforts on sustaining spark duration as well as limiting the voltage drop after the gaps have been bridged. Most aftermarket ignitions concentrate on giving us 20 of spark duration (crank degrees) as well as much higher spark energy output. A high performance coil helps this out, but the Capacitive discharge and digital ignition units assist in storing and delivering this power through the coil more efficiently, faster and give the ability to achieve higher RPMs more safely and efficiently in fuel mixture burning. The coil is only the pawn of the ignition trigger or control unit. The coil is the real workhorse and takes most of the abuse ... make sure you use a good coil. (Read below about aftermarket ignition amplifiers and controls) The Cause of RFI:{PRIVATE "TYPE=PICT;ALT=RFI example"} If we were to slow down the oscilloscope to perhaps 0.00000025 seconds and greatly expand the pattern (as pictured at right), we would see that what appears to be consistent from position C to D in the the first illustration above is actually a series of extremely high bursts of energy. These energy bursts are discharged at the same frequency band as radio and TV frequencies. It is these bursts that make your car radio snap - crackle - and pop ... as well as just about anything electronic including telephones, aircraft control towers and heart pace makers by causing static and interference. Sources of RFI: Automotive ignition systems are not the only things that spew RFI into the atmosphere. Lawn mowers, snowmobiles, ATV's, tractors, power lines, traffic control devices, etc. all do it. One publication refers it to "electronic air pollution". As many of us know, we live in a sea of constant electromagnetic waves. Any time you have a flow of electric current you will have a magnetic field. Coils, relays, switches, solenoids, generators, servomotors all affect communication equipment, electronic circuits and computers. The higher the voltages, the more critical this becomes. Anytime you have the spark jump a gap or a contact, you have a miniature radio transmitter. RFI Standards: Back in the 1930's, engineers recognized that RFI could be a nuisance. As the years, testing and technology advancements went by, it turned into an even greater problem. Especially with the advent of high-tech communications systems, computers and electronic engine control devices. The Society of Automotive Engineers (SAE) decided to set up standards for measuring as well as the control of RFI. These are called "EMI Standards" or the more technical name for radio static of Electromagnetic Interference (EMI). The current standard for EMI was adopted in 1961 and is known as J551. It limits RFI at frequencies between 20-1,000 MHz. All spark plug manufacturers must adhere to it. The most common method used to suppress RFI is to install a resistor in series with the spark plug's center electrode. Other ways that control RFI include: * The metal fenders, grille and hood of your car. These provide a shielding affect which absorbs much of the RFI emitted from your ignition components. Plastic and composite body panels are basically transparent to RFI and provide little to no shielding. * The use of capacitors, silicone grease at connections, proper grounding of all circuits and routing wires to reduce electromagnetic interference are all helpful in reducing RFI. * The use of carbon impregnated secondary wiring (plug wires) and resistor spark plugs have the most impact when reducing and controlling RFI. In our race cars with our high output ignitions, it is best to use a specifically designed plug wire for our applications. These are usually the what is called "Spiral Wound" style plug wires. The construction of these wires starts with a Ferro0-Magnetic impregnated inner core, helical wrapped copper alloy conductor, a high dielectric insulator then a heavy fiberglass braid. Wrapping this is a 8mm to 10mm silicone jacket. Also, secure connections of the plug wire's terminal ends are mandatory along with secure fitting boots. Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
Date: Jul 29, 2007
Subject: Re: Receiving spam trough Matronics
At 09:56 AM 7/29/2007 Sunday, you wrote: > >A while ago I signed up to Matronics, as the Yahoo groups were starting to get lots of spam. I used a unique e-mail address to sign up. Now I am starting to receive spam through that address. Is there any way to trace back who 'leaked' matronics email addresses? > >Rob I believe this issue is really someone(s) that is subscribed to the given List have been infected with a spam reflector "virus". The virus will glean email addresses from the victim's inbox and when it receives a spam message from the mothership, it proceeds to resend it to everyone it the local mailboxes. Unfortunately, spam is a fact of life on the Internet. To give you a data point, Matronics has a Barracuda spam appliance that all incoming email is filtered through before entering the network. The matronics.com domain receives on the average over 70,000 spam emails each day! And there are perhaps 400-600 legitimate emails. That would be a ratio of about 99.3% spam email coming in. There is really no way to hide from spam anymore. If you send emails from an email account, you're going to get spam. At least you'll note that you've never gotten a spam message from any of the Matronics Email Lists directly. Fortunately, I still have the ability to regulate that pretty well. Matt Dralle Matronics Email List Admin Matt G Dralle | Matronics | PO Box 347 | Livermore | CA | 94551 925-606-1001 V | 925-606-6281 F | dralle(at)matronics.com Email http://www.matronics.com/ WWW | Featuring Products For Aircraft ________________________________________________________________________________
Date: Jul 29, 2007
I got the message. What do you think sent me off in a tizzy. "COOL!! I gotta make me wonna those!", as soon as I saw it. Edward G. Savage wrote: > > > Hey Ernest. Looks like you're well along with your project! > > I'm not sure what happened, but I see a post I made sometime back to the > EAA1114 list never made it out to the door. Here is a copy of it below.. > > --Ed > > At a recent builder meeting, I had mentioned this project in the Cozy > community to Ernest. But, this can be used by everyone, not just > builders... > > Here are a couple of people that give instructions on how to make your > own > Clarity Aloft headset clone for around $100. Maybe even approaching > under $50 > now if you pay attention and find deals. And when I say a clone, I > mean right > down to the same Comply ear tips that are used with the Clarity Aloft. > > Check it out... > > Nick Ugolini (the original project) > http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm > > > Drew Chaplin (latest version by Drew) > http://www.cozy1200.com/geeklog/article.php?story 070427102533266 > > --Ed > -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Jul 29, 2007
Subject: Help with adding an Icom A200 to my existing RT-328
List, I just bought an ICOM A200 while here in Oshkosh so now I'm looking at the instructions and have a couple of questions on how to wire it up. I want to add it to the existing RT-328 so that I still have my VOR but I don't have an audio panel so I want to us a toggle switch. I talked to a couple of vendors on how to hook it up but didn't seem to find anyone that seemed to be completely certain on how to do this so I wanted to run it past you folks to make sure I got it right. Here goes: Wire the headset output of both radios together then manage which one you want to listen to using the volume on each radio. Wire the PTT and MIC to a double throw double poll switch so that the mic jack is only connected to one radio at a time. Use a common ground. Wire both radios so that they have their own antennas. Wire the interlock on both radios so that they disable each other when one of the two transmits. I see on the ICOM wiring diagram that pins 9 and N are for PTT and Interlock and on the RT-328 diagram pins L and V are the ANT interlock and mike key. So if I'm understanding this correctly I would connect ping 9 on the Icom to pin L on the RT328 and pin N on the Icom to pin V on the RT328. Does this look right to you guys? If not I would love to know how to do this or even get pointed in the right direction if this is information I can find in a good book. Thanks, schu ________________________________________________________________________________
Date: Jul 29, 2007
John, I still have a magnito system, so harness replacement with resistor wires would be a possible cure? My problem is that every time that I want to access the mags, I have to pull the engine. Do you use auto plugs? Thanks for your reply....Dave D n81jg(at)aol.com wrote: I had a similar problem with RFI in my VariEze when I installed the LSE CD ignition system. I tried the foil covering of the plug leads since it seemed to be high voltage ignition noise in time with plug firing, but it had no effect on lessening the noise in the radio. I had a new set of plug leads made up and the problem was solved. Must have had a minute gap in the lead connections causing a spark gap and RFI. Your local auto parts dealer can make up leads of any length. John Greaves VariEze N81JG Redding, CA -----Original Message----- From: Dave Dugas <davedq2(at)yahoo.com> Sent: Sat, 28 Jul 2007 4:26 pm Subject: AeroElectric-List: Very bad RFI Hello, I joined this list with the hope that I could try to solve my problem in my Q2 with a Revmaster engine. At 450 hours on the engine I converted to auto plugs. I changed the heads and replaced the aviation plug connection with auto plug connections supplied with the conversion. The RFI is so bad that my transponder reply light looks like a timing light. My Tru Trak auto pilot won't stay booted up, and the noise is heard on my com. Things I've tried are...Lonestar mag filters and eliminator power filter. Checking all grounds and relocating several to a common grounding lug. Wrapping the plug connections with tin foil to try to shield the interference. Checking all of the antenna connections. Disconnecting various radios and avionics,trying to isolate a particular source. Nothing worked. I used my handheld radio in the cockpit and didn't pick up any noise. I also called Revmaster and they is the ones who suggested trying the tin foil shielding. The engine is carburated and uses a Bendix 3000 series dual mag. Plugs are NGK resistor plugs, gapped at .016". Hopefully someone has a suggestion, or should I consider going back to the aviation setup. Is there a different harness that would work? The unfortunate thing is that any work that is done on the magnito requires that the engine is removed enough to access the mag which is recessed into the firewall. Thank you. Dave D. --------------------------------- --------------------------------- Luggage? GPS? Comic books? Check out fitting gifts for grads at Yahoo! Search. ________________________________________________________________________________
Date: Jul 29, 2007
You put me on a search and I ran across magnecor wires. magnecor.com is the website. Their 7 mm wire looks great! I think I will try that - I think I saw somewhere where it has 1500 ohms per foot. bobf On 7/28/07, Ken wrote: > > > I run dual DIS (distributorless) ignition with high voltage coil joiners > on my subaru with a total of 12 high voltage ignition wires. I have no > igniton noise or interference but I do run highly recommended premium > 8.5mm Taylor spiral wound racing wires. I run 40 thou spark plug gap > and I think my ignition voltage is quite a bit higher than most > magnetos. The Taylor website used to explain a fair bit about ignition > wires but as I recall mine are considerably more than 150 ohms per foot. > Ken > > Robert Feldtman wrote: > > > I'll be interested to hear the replies on this. I am thinking about > > going to auto plugs for the same RFI reason on my LOM engine > > (Czechoslovakian) -- I'm planning on getting racing wire with 150 ohms > > per foot and shielding it with braid (you can get it from Aircraft > > spruce) and grounding only the mag end, and using heat shrink to hold > > the other end on the plug without a ground at each end (which defeats > > the shield).. Keep us advised as to what you do. > > > > bobf > > > > On 7/28/07, Dave Dugas > > wrote: > > > > Hello, > > > > I joined this list with the hope that I could try to solve my > > problem in my Q2 with a Revmaster engine. At 450 hours on the > > engine I converted to auto plugs. I changed the heads and > > replaced the aviation plug connection with auto plug connections > > supplied with the conversion. The RFI is so bad that my > > transponder reply light looks like a timing light. My Tru Trak > > auto pilot won't stay booted up, and the noise is heard on my > > com. Things I've tried are...Lonestar mag filters and eliminator > > power filter. Checking all grounds and relocating several to a > > common grounding lug. Wrapping the plug connections with tin foil > > to try to shield the interference. Checking all of the antenna > > connections. Disconnecting various radios and avionics,trying to > > isolate a particular source. Nothing worked. > > > > I used my handheld radio in the cockpit and didn't pick up any > > noise. I also called Revmaster and they is the ones who suggested > > trying the tin foil shielding. > > > > The engine is carburated and uses a Bendix 3000 series dual mag. > > Plugs are NGK resistor plugs, gapped at .016". Hopefully someone > > has a suggestion, or should I consider going back to the aviation > > setup. Is there a different harness that would work? The > > unfortunate thing is that any work that is done on the magnito > > requires that the engine is removed enough to access the mag which > > is recessed into the firewall. Thank you. Dave D. > > > > > > ________________________________________________________________________________
Subject: Re: Very bad RFI
Date: Jul 29, 2007
Hi Dave, Yes, I use auto plugs on the top run by the LSE CD ignition. I forgot to mention that the high tension leads from my coils to plugs are the spiral wound?auto leads and work fine after I had new ones with secure connections made up. I am unfamiliar with the grounding you have with the auto plug leads. My problem was RFI in my headset and in a handheld radio that was isolate from the aircraft system. The latter test showed that I was receiving the RFI through the air. Your problem seems to be getting to your radios through your electrical system wiring, possibly your ignition switchs near your antenna wires, radio wiring or intercom wiring. John -----Original Message----- From: Dave Dugas <davedq2(at)yahoo.com> Sent: Sun, 29 Jul 2007 5:07 pm Subject: Re: AeroElectric-List: Very bad RFI John, I still have a magnito system, so harness replacement with resistor wires would be a possible cure?? My problem is that every time that I want to access the mags, I have to pull the engine.? Do you use auto plugs?? Thanks for your reply....Dave D n81jg(at)aol.com wrote: I had a similar problem with RFI in my VariEze when I installed the LSE CD ignition system. I tried the foil covering of the plug leads since it seemed to be high voltage ignition noise in time with plug firing, but it had no effect on lessening the noise in the radio. I had a new set of plug leads made up and the problem was solved. Must have had a minute gap in the lead connections causing a spark gap and RFI. Your local auto parts dealer can make up leads of any length. John Greaves VariEze N81JG Redding, CA -----Original Message----- From: Dave Dugas <davedq2(at)yahoo.com> Sent: Sat, 28 Jul 2007 4:26 pm Subject: AeroElectric-List: Very bad RFI Hello, ? I joined this list?with the hope that I could try to solve my problem in my Q2 with a Revmaster engine.? At 450 hours on the engine I converted to auto plugs.? I changed the heads and replaced the aviation plug connection with auto plug connections supplied with the conversion.? The RFI is so bad that my transponder reply light looks like a timing light.? My Tru Trak auto pilot won't stay booted up, and the noise is heard on my com.? Things I've tried are...Lonestar mag filters and eliminator power filter.? Checking all grounds and relocating several to a common grounding lug.? Wrapping the plug connections with tin foil to try to shield the interference.? Checking all of the antenna connections.? Disconnecting various radios and?avionics,trying to isolate a particular source.? Nothing worked. ? I used my handheld radio in the cockpit and didn't pick up any noise.? I also called Revmaster and they is the ones who suggested trying the tin foil shielding. ? The engine is carburated and uses a Bendix 3000 series dual mag.? Plugs are NGK resistor plugs, gapped at .016".? Hopefully someone has a suggestion, or should I consider going back to the aviation setup.? Is there a different harness that would work?? The unfortunate thing is that any work that is done on the magnito requires that the engine is removed enough to access the mag which is recessed into the firewall.? Thank you.? Dave D. Luggage? GPS? Comic books? ________________________________________________________________________ ________________________________________________________________________________
Subject: Re: Help with adding an Icom A200 to my existing RT-328
Date: Jul 29, 2007
Why not just use a 3PDT (three pole) switch and put the headphones on there as well. If the ICOM is your primary radio, you'll note that it also has Aux In inputs. By wiring the other radio to one of these (optionally with a switch), you can monitor both radios at once. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=126272#126272 ________________________________________________________________________________
Subject: Question about B&C Regulators
Date: Jul 29, 2007
So, I have 2 LR-3C-28's at the moment to be used with a stock continental 100A 28V alternator and an SD-20 backup alternator..... BUT, a friend came by and told me that B&C recommends that you use the LS-1A instead of the LR-3C with the SD-20. Anyone know why, or if it really matters? I plan to call B&C in the next couple of days to get their side of the story. I did notice that the LS-1A doesn't have a huge heat sink like the 28v version of the LR-3C. But I have no idea what else is different under the hood? Alan ________________________________________________________________________________
Date: Jul 29, 2007
Subject: Re: Question about B&C Regulators
Alan, I believe that the issue is How the SD20 is being used, I'm building to a Z14 and as I understand it, if you are planning on having both alternators continuously online at the same time you use the regulators you have. If you plan on only using the SD20 as a back-up then the other regulator is the choice. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Alan K. Adamson wrote: > > So, I have 2 LR-3C-28's at the moment to be used with a stock continental > 100A 28V alternator and an SD-20 backup alternator..... BUT, a friend came > by and told me that B&C recommends that you use the LS-1A instead of the > LR-3C with the SD-20. > > Anyone know why, or if it really matters? I plan to call B&C in the next > couple of days to get their side of the story. I did notice that the LS-1A > doesn't have a huge heat sink like the 28v version of the LR-3C. But I have > no idea what else is different under the hood? > > Alan > > > ________________________________________________________________________________
Date: Jul 30, 2007
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Thermocouple wire connections
I've finally installed all my VM-1000 engine monitor harness and have only to connect the it from the CPU to the pigtails on the EGT/CHT thermocouple probes. Vision supplied the probes with about 2 feet of wire and faston connections terminating them. I have to install fastons on the CPU harness that connects to the probes and was going to use the fastons that Vision supplied but they do not have the second crimp sleeve that provides insulation strain relief. I have a bunch of the strain relief type fastons but not sure if I should use them because it may mess up the readings due to possible metallic connection mismatches between the thermocouple wire. The fastons Vision supplied look to be coated with solder but I don't really know if the underlying material is copper or something else (scratching the surface doesn't yield a copper color underneath). The letters "T&B" are stamped on these terminals. From looking at Bob's book it doesn't appear that this is the way that these thermocouple wires should be spliced but I assume that most Vision Micro buyers use what Vision supplies to assemble their systems. I don't have a problem with this method but would prefer the strain relief terminals if they will work. Otherwise I'll go ahead and splice them with the supplied terminals. Anyone else with VM-1000 have any thoughts? Can I use the strain relief terminals or do I need to use the Vision terminals? The strain relief terminals were purchased at a boat supply store so I suspect they are solder coated copper, may not work for this application (the letters "I2" and "MX" are stamped on these terminals). Also, the Vision fastons on the probe pigtails are not encased in plastic but are installed with some heat shrink around the crimp end. Can't tell if they are soldered but the install manual doesn't say anything about soldering at the harness ends, just crimping the terminals. Would I have to solder these for any reason? Any words of wisdom Bob? Have you returned from OSH yet? Thanks. Dean Psiropoulos RV-6A N197DM Will it ever end? ________________________________________________________________________________
Date: Jul 30, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
> > >So, I have 2 LR-3C-28's at the moment to be used with a stock continental >100A 28V alternator and an SD-20 backup alternator..... BUT, a friend came >by and told me that B&C recommends that you use the LS-1A instead of the >LR-3C with the SD-20. > >Anyone know why, or if it really matters? I plan to call B&C in the next >couple of days to get their side of the story. I did notice that the LS-1A >doesn't have a huge heat sink like the 28v version of the LR-3C. But I have >no idea what else is different under the hood? I designed both of those regulators. You can use the LR-3 series devices on the SD-20 in 14 volt applications . . . in fact, I believe that's what's currently recommended. However, there is no difference between the SD-20 used in 14 volt systems and 28 volts systems . . . only the regulator. To keep from burning the SD-20's 14V field winding by putting 28 volts on it, we crafted a special regulator that is in fact, a 0-15v switchmode power supply. The output of the power supply is steered by the 28V regulator electronics to achieve the desired bus voltage but with a hard upper limit of 15V applied to the field such that it's never in danger of smoking. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 30, 2007
> >Alan, I believe that the issue is How the SD20 is being used, I'm building >to a Z14 and as I understand it, if you are planning on having both >alternators continuously online at the same time you use the regulators >you have. If you plan on only using the SD20 as a back-up then the other >regulator is the choice. Close . . . but the regulator for using the SD-20 as a same-bus standby is a little different yet. The low voltage warning section of the SB series regulators is replaced with an overload detection and annunciation system. When the SD-20 shares a common bus with another alternator, it's set-point is about 1.0 volts BELOW that of the main alternator. When the main alternator fails or is turned off, the bus voltage sags and the SD-20 comes alive in an attempt to pick up all present loads. IF those loads exceed 20A, the ALTERNATOR LOADED light flashes. The pilot then reduces loads to stop the flashing which indicates that the SD-20 is no operating with designed limits. I believe that installation instructions and operating details for the LR, LS and SB series regulators are available from B&C's website. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2007
Deems, thanks for the note. I would agree with your comments if they said to use the SB1B-28, but we are talking about the LS-1A. The justification that B&C used with my friend was that this regulator helps the SD-20 make 28 volts??? Ok, so is there some magic that allows it to make those volts at lower RPM settings? That would be a good thing I suppose... I'll be calling B&C today to find out more. Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Deems Davis Sent: Monday, July 30, 2007 12:13 AM Subject: Re: AeroElectric-List: Question about B&C Regulators --> Alan, I believe that the issue is How the SD20 is being used, I'm building to a Z14 and as I understand it, if you are planning on having both alternators continuously online at the same time you use the regulators you have. If you plan on only using the SD20 as a back-up then the other regulator is the choice. Deems Davis # 406 'Its all done....Its just not put together' http://deemsrv10.com/ Alan K. Adamson wrote: > --> > > So, I have 2 LR-3C-28's at the moment to be used with a stock > continental 100A 28V alternator and an SD-20 backup alternator..... > BUT, a friend came by and told me that B&C recommends that you use the > LS-1A instead of the LR-3C with the SD-20. > > Anyone know why, or if it really matters? I plan to call B&C in the > next couple of days to get their side of the story. I did notice that > the LS-1A doesn't have a huge heat sink like the 28v version of the > LR-3C. But I have no idea what else is different under the hood? > > Alan > > > ________________________________________________________________________________
Date: Jul 30, 2007
Bob, Thanks for the note. So am I to assume from your comments, that in a dual alt, dual 24v battery system, that I should use the LS-1A with the SD-20 *instead* of another LR-3C-28? Are you also saying that the LR-3C-28 *could* damage the SD-20 if used with it? Thanks again, Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, July 30, 2007 10:07 AM Subject: Re: AeroElectric-List: Question about B&C Regulators --> > > >So, I have 2 LR-3C-28's at the moment to be used with a stock >continental 100A 28V alternator and an SD-20 backup alternator..... >BUT, a friend came by and told me that B&C recommends that you use the >LS-1A instead of the LR-3C with the SD-20. > >Anyone know why, or if it really matters? I plan to call B&C in the >next couple of days to get their side of the story. I did notice that >the LS-1A doesn't have a huge heat sink like the 28v version of the >LR-3C. But I have no idea what else is different under the hood? I designed both of those regulators. You can use the LR-3 series devices on the SD-20 in 14 volt applications . . . in fact, I believe that's what's currently recommended. However, there is no difference between the SD-20 used in 14 volt systems and 28 volts systems . . . only the regulator. To keep from burning the SD-20's 14V field winding by putting 28 volts on it, we crafted a special regulator that is in fact, a 0-15v switchmode power supply. The output of the power supply is steered by the 28V regulator electronics to achieve the desired bus voltage but with a hard upper limit of 15V applied to the field such that it's never in danger of smoking. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 30, 2007
Subject: Re: The hottest T-shirt at Oshkosh
George, I for one like your attitude. Your the canary in the coal mine for me. Mike ----- Original Message ----- From: gmcjetpilot(at)yahoo.com To: aeroelectric-list(at)matronics.com Sent: Saturday, July 28, 2007 12:54 PM Subject: AeroElectric-List: Re: The hottest T-shirt at Oshkosh Did not make Oshkosh but there is spirit. Super! Of coruse its the hottest Tee-shirt. I LOVE IT, but I want a cut of sales. Figure @ $50 a pop they'll sell out. I think its hilarious. Some one has a sense of humor, which is refreshing. Life is too short and this is suppose to be fun. Peace. My next shirt will be a big read circle with a diagonal & the word CROWBAR, ha ha. The Real GMCJETPILOT PS I want Tee-shit with the NOT crossed out. LOL >From: "Bruce Gray" >Subject: RE: AeroElectric-List: The hottest T-shirt at Oshkosh > >A green t-shirt with block letters that said, "I am NOT gmcjetpilot". > >Bruce ------------------------------------------------------------------------------ Choose the right car based on your needs. ________________________________________________________________________________
Date: Jul 30, 2007
Subject: Re: Thermocouple wire connections
"DEAN PSIROPOULOS" wrote: > > I've finally installed all my VM-1000 engine monitor harness and have only > to connect the it from the CPU to the pigtails on the EGT/CHT thermocouple > probes. Vision supplied the probes with about 2 feet of wire and faston > connections terminating them. I have to install fastons on the CPU harness > that connects to the probes and was going to use the fastons that Vision > supplied but they do not have the second crimp sleeve that provides > insulation strain relief. I have a bunch of the strain relief type fastons > but not sure if I should use them because it may mess up the readings due to > possible metallic connection mismatches between the thermocouple wire. > > The fastons Vision supplied look to be coated with solder but I don't really > know if the underlying material is copper or something else (scratching the > surface doesn't yield a copper color underneath). The letters "T&B" are > stamped on these terminals. From looking at Bob's book it doesn't appear > that this is the way that these thermocouple wires should be spliced but I > assume that most Vision Micro buyers use what Vision supplies to assemble > their systems. I don't have a problem with this method but would prefer the > strain relief terminals if they will work. Otherwise I'll go ahead and > splice them with the supplied terminals. > > > Anyone else with VM-1000 have any thoughts? Can I use the strain relief > terminals or do I need to use the Vision terminals? The strain relief > terminals were purchased at a boat supply store so I suspect they are solder > coated copper, may not work for this application (the letters "I2" and "MX" > are stamped on these terminals). Also, the Vision fastons on the probe > pigtails are not encased in plastic but are installed with some heat shrink > around the crimp end. Can't tell if they are soldered but the install > manual doesn't say anything about soldering at the harness ends, just > crimping the terminals. Would I have to solder these for any reason? Any > words of wisdom Bob? Have you returned from OSH yet? Thanks. > > Dean Psiropoulos > RV-6A N197DM > Will it ever end? > > Hi Dean, I don't have the VM-1000, but I do make quite a few TC extensions. There are specialized connectors for connecting TC wires together. They are large, expensive, and not necessary for the type measurements made by an EGT probe. Soldering EGT wires is a tricky business. You will need a very aggressive flux if you can do it at all. Crimp connections are preferred and are just fine. I would use the PIDG connectors from AMP because I know the quality. I have used the shrouded connectors which don't have a metal ring to support the wire. I used them because the particular EGT probe had them installed. I used shrink tubing to build up the OD of the insulation for a snug fit in the back of the connector and another shrink tubing over the outside of the connector and the shrink tubing on the wire. To minimize errors caused by the dissimilar materials, keep the connectors on both wires at the same moderate temperature. Bob W. PS: I have a Tru Trak ADI for sale on ebay. Item 160142910426 for anyone who might be interested. -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Date: Jul 30, 2007
> >My next shirt will be a big read circle with a diagonal & >the word CROWBAR, ha ha. > >The Real GMCJETPILOT Then you'll need to add Plane Power to your list of wizards who went to the 'dark side'. Seems their OV protection system is a simple, dead-short across the field breaker when the bus voltage exceeds the designed set point. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2007
> >Bob, > >Thanks for the note. > >So am I to assume from your comments, that in a dual alt, dual 24v battery >system, that I should use the LS-1A with the SD-20 *instead* of another >LR-3C-28? Correct. >Are you also saying that the LR-3C-28 *could* damage the SD-20 if used with >it? ABSOLUTELY guaranteed that it would damage the SD-20. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2007
> Can't tell if they are soldered but the install >manual doesn't say anything about soldering at the harness ends, just >crimping the terminals. Would I have to solder these for any reason? Any >words of wisdom Bob? Have you returned from OSH yet? Thanks. > >Dean Psiropoulos >RV-6A N197DM >Will it ever end? One is seldom wrong for following the manufacturer's instructions. They've been building and selling these products for a very long time. Be wary of dire predictions and helpful suggestions to the contrary unless supported by more than reverence for someone's traditions. At the end of the day, repeatable experiments supported by simple-ideas rule the day. If you were interested in harnessing the thermocouple leads and assuming 20AWG wire or smaller, you could consider making the engine to instrument harness transition in a D-sub connector with machined pins. This too is a repeatable experiment. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2007
Can't tell if they are soldered but the install manual doesn't say anything about soldering at the harness ends, just crimping the terminals. Would I have to solder these for any reason? Any words of wisdom Bob? Have you returned from OSH yet? Thanks. Dean Psiropoulos RV-6A N197DM Will it ever end? One is seldom wrong for following the manufacturer's instructions. They've been building and selling these products for a very long time. Be wary of dire predictions and helpful suggestions to the contrary unless supported by more than reverence for someone's traditions. At the end of the day, repeatable experiments supported by simple-ideas rule the day. Oh yeah, I forgot to add that just about anything you do that contributes to measurement errors will be canceled out as long as you do exactly the same thing to the other side assuming that both "contamination" exist at the same temperature. Sticking a splice in one lead has the potential for creating one or more new thermocouples but equally contaminating couples in opposing polarities will tend to cancel each other. If you were interested in harnessing the thermocouple leads and assuming 20AWG wire or smaller, you could consider making the engine to instrument harness transition in a D-sub connector with machined pins. This too is a repeatable experiment. Bob . . . ________________________________________________________________________________
Subject: Slick Start
Date: Jul 30, 2007
Bob, I'm installing a SlickStart (SS) on a left retard breaker mag, no impulse couplings. We're using two locking mag switches. Customer wants to leave the right mag off for starting without the interlock to the left switch you describe. Powering the SS via the push to start is contrary to the instructions, which have it powered from the starter feed. Problem is, I worry that the starter might generate power while spinning down, thus keeping power to the SS after the start switch is released. If I power the SlickStart from the push to start switch, is there any chance I will damage it from high voltage due to the collapsing contactor coil? The coil has a surge diode installed. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Jul 30, 2007
RT-328 Bill McMullen wrote: > > Why not just use a 3PDT (three pole) switch and put the headphones on there as well. If the ICOM is your primary radio, you'll note that it also has Aux In inputs. By wiring the other radio to one of these (optionally with a switch), you can monitor both radios at once. Thanks for the reply Bill, yes I could use a 3 pole switch, but there may be causes where I want to monitor two channels at once. Do you (or anyone) know if tying the two headset outputs together will cause the radios to backfeed each other? Also, does anyone know if I got my interlock correct? I see that the RT-328 radio has "Ant Interlock" and "Mike Key" so I'm assuming those are like the "Interlock" and "PTT" the icom radio uses. Other than that the wiring seems pretty straight forward, just want to make sure I get it right. I wonder if there are any good books on the subject. Thanks, schu ________________________________________________________________________________
Subject: Com Antenna
Date: Jul 30, 2007
What are folks using for Com Antennas? I am building a RV-6A and wonder what the merits are between Aircraft Spruces' AV-534, and the bent whips like AV-17 and CI-122 which cost over twice a much. Marty in Brentwood TN ________________________________________________________________________________
Date: Jul 30, 2007
RT-328 I wired my coms together with, I think, 150 ohm resisters on each output to prevent backfeed. If I'm transmitting on one and the other is tuned anywhere near, I have to turn it down, but other than that, it works great. I've got the nav audio wired in the same way. I switch the PTT and MIC to the com on which I wish to transmit and use volume control for each audio source. Pax, Ed Holyoke Matthew Schumacher wrote: > >Bill McMullen wrote: > > >> >>Why not just use a 3PDT (three pole) switch and put the headphones on there as well. If the ICOM is your primary radio, you'll note that it also has Aux In inputs. By wiring the other radio to one of these (optionally with a switch), you can monitor both radios at once. >> >> > >Thanks for the reply Bill, yes I could use a 3 pole switch, but there >may be causes where I want to monitor two channels at once. Do you (or >anyone) know if tying the two headset outputs together will cause the >radios to backfeed each other? > >Also, does anyone know if I got my interlock correct? I see that the >RT-328 radio has "Ant Interlock" and "Mike Key" so I'm assuming those >are like the "Interlock" and "PTT" the icom radio uses. > >Other than that the wiring seems pretty straight forward, just want to >make sure I get it right. > >I wonder if there are any good books on the subject. > >Thanks, >schu > > > > ________________________________________________________________________________
Date: Jul 31, 2007
7/31/2007 Hello Dave, 1) You wrote: "Problem is, I worry that the starter might generate power while spinning down, thus keeping power to the SS after the start switch is released." I don't understand why you consider this a problem. Assuming that the engine has already started running and the starter switch has been released, if the starter run down is generating enough electricity to continue to fully activate the SlickStart then you will just have retarded ignition from the left mag for that brief period of time. What is the harm in that? 2) Realize that Slick SB1-06A calls for disconnection of the SS unit from the right magneto and removal of pin #2 on SS1001 SlickStart ignition boosters. This is the pin and wiring that would automatically ground out the right magneto during SS unit activation to avoid the possibility of an advanced spark coming from the right magneto. 3) SB1-06A was created because Unison felt that this connection "potentially compromises the redundancy of the ignition system." I understand that Unison is working on an updated version of the SlickStart. 4) Once SB1-06A is complied with your customer should realize that grounding out the right magneto by having that magneto switched OFF during cranking is the only sure way to ensure that he will not get advanced sparking from the right magneto. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: I hope that Bob Nuckolls or other expert can comment on the rationale behind this statement: "17.Use either a varistor, or a diode plus Zener diode as a protective circuit against reverse surge in the G9EB relay coil. Using a diode alone will reduce the switching characteristics." It came from the Precautions sheet from this web site: http://www.omron.com/ecb/products/pdf/en_g9ea_ec.pdf Thanks ------------------------------------------------------ From: "Dave Saylor" <Dave(at)AirCraftersLLC.com> Subject: AeroElectric-List: Slick Start Bob, I'm installing a SlickStart (SS) on a left retard breaker mag, no impulse couplings. We're using two locking mag switches. Customer wants to leave the right mag off for starting without the interlock to the left switch you describe. Powering the SS via the push to start is contrary to the instructions, which have it powered from the starter feed. Problem is, I worry that the starter might generate power while spinning down, thus keeping power to the SS after the start switch is released. If I power the SlickStart from the push to start switch, is there any chance I will damage it from high voltage due to the collapsing contactor coil? The coil has a surge diode installed. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Jul 31, 2007
Subject: Re: Com Antenna
I have a bent whip underneath and a copper foil on my windshield. The bent whip is removable and I have a second attaching plate over the doubler plate that allows me to cover the hole. I think Bob has posted photos of my Comant installation somewhere?! If not - zap me direct.... -----Original Message----- >From: Emrath <emrath(at)comcast.net> >Sent: Jul 30, 2007 10:17 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: Com Antenna > > >What are folks using for Com Antennas? I am building a RV-6A and wonder >what the merits are between Aircraft Spruces' AV-534, and the bent whips >like AV-17 and CI-122 which cost over twice a much. > >Marty in Brentwood TN > > ________________________________________________________________________________
Subject: Re: Slick Start
Date: Aug 01, 2007
> 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." > PS: I hope that Bob Nuckolls or other expert can comment on the rationale behind this statement: > "17.Use either a varistor, or a diode plus Zener diode as a protective > circuit against reverse surge in the G9EB relay coil. Using a diode > alone will reduce the switching characteristics." > It came from the Precautions sheet from this web site: > http://www.omron.com/ecb/products/pdf/en_g9ea_ec.pdf > Thanks See: http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3264.pdf http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3311.pdf http://relays.tycoelectronics.com/appnotes/app_pdfs/13c3236.pdf http://relays.tycoelectronics.com/kilovac/appnotes/fig48.asp http://www.periheliondesign.com/suppressors/SnapJack.pdf http://forums.matronics.com/viewtopic.php?p=56397#56397 The summary: The use of diodes for coil suppression has been supplanted by far better methods. For those who think that being "used for 70 years" is a good reason to contiunue using diodes...have it your own way. "Beaten paths are for beaten men." -E. A. Johnston -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=126911#126911 ________________________________________________________________________________
Subject: Annunciator Dim
Date: Aug 01, 2007
I purchased the Vx Aviation lamp controller with the intent of using it to control, dim, and provide push-to-test of my incandescent annunciators. Dispite my best efforts, I haven't been able to make things work as advertised. Anyone having experience with annunciator dimming that might be able to offer suggestions, either with the Vx product or others, would be appreciated. Scott Fifield ________________________________________________________________________________
Subject: Comm won't transmit
Date: Aug 01, 2007
I just started flying off the test hours on my Zodiac 601 HDS. Everything seemed to be operating normally until I realized today that I'm getting a very weak transmission on my ICOM A200 Comm. The reception is fine but today when I was trying to communicate with another aircradft at my non-towered field it became obvious that the other pilot couldn't hear me. When I got back on the ground I asked another pilot to see if I was transmittting. He said the signal was very weak on the first transmission and then non-existent on subsequent transmissions. The radio is wired through a Flightcom intercom. I have the transmission problem regardless of whether I have the intercom switched to "All" or "Iso". Reception is fine either way. I did notice that when I push the PTT button, the LED on my Ray Allan trim indicator goes out, which seems rather odd but may be a clue as to what is going on . When I release the PTT button the LED comes back on. I'm guessing I have a short in the PTT circuit but before I start ripping things apart I'd like some opinions on what to check first. Thanks. Mike Brenner Zodiac 601 HDS ________________________________________________________________________________
Date: Aug 01, 2007
Subject: Re: Comm won't transmit
Mike, Though you didn't say the trim and com buttons are in near proximity on the stick, I'd check that proximity and work toward isolating the com from any wires or common connections. It could be a wire crossing another, but the most logical is a connection near the switches. Look carefully at your comm wires first working back thru to the radio if it's involved and fuses. I'm using a A200 with a Sigtronics intercom that had problems with the main Molex plugs and Molex Connector in the back of the radio. Making good connections back there is crucial. None of the Molex plugs and wires in the rear of the A200 should be loose or wobbly. My reception and transmit were soft until that Molex Connector and the Molex plugs (purchased from Mouser components ) was replaced by a professional. Larry McFarland 601HDS at www.macsmachine.com Mike Brenner wrote: > I just started flying off the test hours on my Zodiac 601 HDS. > Everything seemed to be operating normally > until I realized today that I'm getting a very weak transmission on > my ICOM A200 Comm. The reception is fine > but today when I was trying to communicate with another aircradft at > my non-towered field it became obvious that > the other pilot couldn't hear me. When I got back on the ground I > asked another pilot to see if I was transmittting. > He said the signal was very weak on the first transmission and then > non-existent on subsequent transmissions. The > radio is wired through a Flightcom intercom. I have the transmission > problem regardless of whether I have the intercom > switched to "All" or "Iso". Reception is fine either way. > > I did notice that when I push the PTT button, the LED on my Ray Allan > trim indicator goes out, which seems rather odd > but may be a clue as to what is going on . When I release the PTT > button the LED comes back on. I'm guessing I have > a short in the PTT circuit but before I start ripping things apart I'd > like some opinions on what to check first. Thanks. > > Mike Brenner > Zodiac 601 HDS > * > > * ________________________________________________________________________________
Date: Aug 01, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
My first guess is you have a bad ground. The ICOM will consume the most power when it is transmitting. The fact that it does something weired with a totally unrelated piece of equipment when demanding a lot of current normally always means bad grounding. Frank Rv7a...Ex Zenair Zodiac 601HDS. ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Brenner Sent: Wednesday, August 01, 2007 10:58 AM Subject: AeroElectric-List: Comm won't transmit I just started flying off the test hours on my Zodiac 601 HDS. Everything seemed to be operating normally until I realized today that I'm getting a very weak transmission on my ICOM A200 Comm. The reception is fine but today when I was trying to communicate with another aircradft at my non-towered field it became obvious that the other pilot couldn't hear me. When I got back on the ground I asked another pilot to see if I was transmittting. He said the signal was very weak on the first transmission and then non-existent on subsequent transmissions. The radio is wired through a Flightcom intercom. I have the transmission problem regardless of whether I have the intercom switched to "All" or "Iso". Reception is fine either way. I did notice that when I push the PTT button, the LED on my Ray Allan trim indicator goes out, which seems rather odd but may be a clue as to what is going on . When I release the PTT button the LED comes back on. I'm guessing I have a short in the PTT circuit but before I start ripping things apart I'd like some opinions on what to check first. Thanks. Mike Brenner Zodiac 601 HDS ________________________________________________________________________________
Date: Aug 01, 2007
Mike, it sounds like you are getting RFI into other things when transmitting... I'd suspect the antenna connector(ions). While it might RX just fine, a bad connection will make TX flaky and will spew RFI around that will make trim indicators do odd things and other things work funky too. Check the Sheild on the connector and also the center pin and remember, just because it shows good at DC, doesn't mean it works at RF. Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of LarryMcFarland Sent: Wednesday, August 01, 2007 3:04 PM Subject: Re: AeroElectric-List: Comm won't transmit --> Mike, Though you didn't say the trim and com buttons are in near proximity on the stick, I'd check that proximity and work toward isolating the com from any wires or common connections. It could be a wire crossing another, but the most logical is a connection near the switches. Look carefully at your comm wires first working back thru to the radio if it's involved and fuses. I'm using a A200 with a Sigtronics intercom that had problems with the main Molex plugs and Molex Connector in the back of the radio. Making good connections back there is crucial. None of the Molex plugs and wires in the rear of the A200 should be loose or wobbly. My reception and transmit were soft until that Molex Connector and the Molex plugs (purchased from Mouser components ) was replaced by a professional. Larry McFarland 601HDS at www.macsmachine.com Mike Brenner wrote: > I just started flying off the test hours on my Zodiac 601 HDS. > Everything seemed to be operating normally until I realized today > that I'm getting a very weak transmission on my ICOM A200 Comm. The > reception is fine but today when I was trying to communicate with > another aircradft at my non-towered field it became obvious that the > other pilot couldn't hear me. When I got back on the ground I asked > another pilot to see if I was transmittting. > He said the signal was very weak on the first transmission and then > non-existent on subsequent transmissions. The radio is wired through > a Flightcom intercom. I have the transmission problem regardless of > whether I have the intercom switched to "All" or "Iso". Reception is > fine either way. > > I did notice that when I push the PTT button, the LED on my Ray Allan > trim indicator goes out, which seems rather odd but may be a clue as > to what is going on . When I release the PTT button the LED comes back > on. I'm guessing I have a short in the PTT circuit but before I start > ripping things apart I'd like some opinions on what to check first. > Thanks. > > Mike Brenner > Zodiac 601 HDS > * > > * ________________________________________________________________________________
Date: Aug 01, 2007
Larry, The trim switch and LED are both on the panel and PTT is on the stick so I'm pretty sure it isn't a switch crossover problem. I will check the ground and the connector tomorrow. I also have a headset with a PTT button on one of the ear muffs. I've never used it before but I'll try transmitting with that and see what happens. Mike Brenner ________________________________________________________________________________
Date: Aug 01, 2007
Hello Mike, I sort of doubt that the problem is actually with the PTT button.. Looking at the manual for the radio: http://www.icomamerica.com/downloads/manuals/avionics/ic-a200.pdf I notice that the display has a "TX" indicator which should be visible whenever the transmit circuit is being selected by the PTT button. I'd guess that a problem with the PTT would cause the "TX" indicator to flicker, and the output to be noisy, but have normal strength.. I agree with the other posters that have suggested checking the RF side of things. It appears that energy broadcast from the antenna is low, and likely is being lost within the airframe - as evidenced by other circuitry being affected - trim circuit. A few questions: - Is this overall installation typical of other 601's? - Is the antenna mounted to an aluminum skin? - What kind of antenna are you using? - What's the cable routing like? - What kind of coax and connectors are you using? - Do you have a copy of the Aeroelectric Connection? Good luck.. Let us know what you find. Thanks, Matt- > I just started flying off the test hours on my Zodiac 601 HDS. Everything > seemed to be operating normally > until I realized today that I'm getting a very weak transmission on my > ICOM A200 Comm. The reception is fine > but today when I was trying to communicate with another aircradft at my > non-towered field it became obvious that > the other pilot couldn't hear me. When I got back on the ground I asked > another pilot to see if I was transmittting. > He said the signal was very weak on the first transmission and then > non-existent on subsequent transmissions. The > radio is wired through a Flightcom intercom. I have the transmission > problem regardless of whether I have the intercom > switched to "All" or "Iso". Reception is fine either way. > > I did notice that when I push the PTT button, the LED on my Ray Allan trim > indicator goes out, which seems rather odd > but may be a clue as to what is going on . When I release the PTT button > the LED comes back on. I'm guessing I have > a short in the PTT circuit but before I start ripping things apart I'd > like some opinions on what to check first. Thanks. > > Mike Brenner > Zodiac 601 HDS ________________________________________________________________________________
Date: Aug 01, 2007
Mike, The grounds on that Molex plug need to be solid and not wobbly. Frank is right about the grounding. Molex contact terminals in that plug are easy to bend and foul. The wires should feel secure and not "loose in a hole". Placing the wiring for these plugs is something I screwed up badly. The Molex plug that is part of the A200 mounting rack is one that the buyer/builder gets to wire and that was the part that gave me all the trouble. See image of Molex plug on mount rack. I have a removable forward top skin, so the fix was only difficult to get to from above between tank and radio rack. I found the transmission signal would go quiet to very loud when I fingered the loose ground wires coming out of this Molex plug which ultimately was replaced as were the contact terminals. I'd suggest you turn it on and "finger those wires" coming out of the plug to see if your signal strength changes on transmit. http://www.macsmachine.com/images/electrical/full/encoder.gif Good luck, Larry
July 13, 2007 - August 01, 2007
AeroElectric-Archive.digest.vol-hb
