AeroElectric-Archive.digest.vol-hc
August 01, 2007 - August 15, 2007
      Mike Brenner wrote:
      > Larry,
      > The trim switch and LED are both on the panel and PTT is on the stick
      > so I'm pretty sure it isn't a switch crossover problem.  I will check
      > the ground and the connector tomorrow.  I also have a headset with a
      > PTT button on one of the ear muffs.  I've never used it before but
      > I'll try transmitting with that and see what happens.
      > Mike Brenner
From: "Patrick Elliott" <pelliott(at)innercite.com>
Subject: GMCjetpilot T-shirts..
Date: Aug 01, 2007
After seeing multiple comments about these T shirts, and photos of the same in other =91virtual=92 locations, my interest was piqued. So off to Google I go. I found and read Bob=92s article on why =93GMCjetpilot=94 was asked to leave and some other readings, which only caused me to dig deeper. ( as in scroll down the page.) So in order to help clarify the mystery surrounding the identity of =91GMCJetpilot=92 and possibly hurt T-shirt sales, I offer this: =93 http://www.myspace.com/gmcjetpilot =93 _____ Patrick Elliott Not on GMCJetPilots friend list. 541 297 0004 7/31/2007 5:26 PM ________________________________________________________________________________
Date: Aug 01, 2007
Subject: Re: GMCjetpilot T-shirts..
LOL! I think you have too much time on your hands! :-)=0AWell, now we know that he is, at least, an engineer. I could tell by the grammar and spelli ng.=0ARich=0ANot on the friends list either....=0A=0A----- Original Message ----=0AFrom: Patrick Elliott <pelliott(at)innercite.com>=0ATo: aeroelectric-l ist(at)matronics.com=0ASent: Wednesday, August 1, 2007 8:09:14 PM=0ASubject: A eroElectric-List: GMCjetpilot T-shirts..=0A=0A=0AAfter seeing multiple comm ents about these T shirts, and photos of the same in other =91virtual=92 lo cations, my interest was piqued. =0ASo off to Google I go. =0AI found and r ead Bob=92s article on why =93GMCjetpilot=94 was asked to leave and some ot her readings, which only caused me to dig deeper. ( as in scroll down the p age.)=0A =0ASo in order to help clarify the mystery surrounding the identit y of =91GMCJetpilot=92 and possibly hurt T-shirt sales, I offer this: =93 http://www.myspace.com/gmcjetpilot =93=0A =0A =0A =0A=0A=0A=0APatrick Elli ott=0A=0A=0ANot on GMCJetPilots friend list.=0A =0A541 297 0004=0A =0A=0A7/ ============ ________________________________________________________________________________
From: "S. Ramirez" <simon(at)synchronousdesign.com>
Date: Aug 01, 2007
I feel so sorry for Pammy and Haley. Simon Ramirez, Aerocanard Builder Oviedo, FL 32765 USA Copyright C 2007 _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Patrick Elliott Sent: Wednesday, August 01, 2007 8:09 PM Subject: AeroElectric-List: GMCjetpilot T-shirts.. After seeing multiple comments about these T shirts, and photos of the same in other 'virtual' locations, my interest was piqued. So off to Google I go. I found and read Bob's article on why "GMCjetpilot" was asked to leave and some other readings, which only caused me to dig deeper. ( as in scroll down the page.) So in order to help clarify the mystery surrounding the identity of 'GMCJetpilot' and possibly hurt T-shirt sales, I offer this: " http://www.myspace.com/gmcjetpilot " _____ Patrick Elliott Not on GMCJetPilots friend list. 541 297 0004 ________________________________________________________________________________
Subject: Annunciator Dim
Date: Aug 02, 2007
Scott, what are the symptoms of your problems? I designed the unit, so I can help! Vern Little -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott Sent: August 1, 2007 10:43 AM Subject: AeroElectric-List: Annunciator Dim I purchased the Vx Aviation lamp controller with the intent of using it to control, dim, and provide push-to-test of my incandescent annunciators. Dispite my best efforts, I haven't been able to make things work as advertised. Anyone having experience with annunciator dimming that might be able to offer suggestions, either with the Vx product or others, would be appreciated. Scott Fifield ________________________________________________________________________________
From: "Doug Windhorn" <N1DeltaWhiskey(at)comcast.net>
Subject: Noise filter
Date: Aug 02, 2007
Bob, et al, A cohort is having problems with a Century autopilot induced audio noise into his headphones. From any testing we have done, this appears to be motor noise (based on spool-up/spool-down noise) transmitted into the power lines. The Century information indicates that it can produce noise in some avionics at the 5 kHz level. If it is not power line noise, then it might be EMF radiation being picked up by the radio or phone circuits. I have found some information regardng design of a "twin-T band-stop" filter that could probably be used to filter the offending frequency out of the offenders power line. Assume others have probably had this type of problem an wondering how it was solved. On the dumb question front, the above circuit references a source and load. I would normally think of the power supply as the source and the autopilot the load. But, given the noise is from the autopilot, would it not be the source and the rest of the circuit the load? Any insight appreciated. Doug Windhorn ________________________________________________________________________________
Date: Aug 02, 2007
Scott, I assume that you have the datasheet http://vx-aviation.com/documents/IL-4A.pdf. It covers all of the wiring and configuration of the device. Vern -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott Sent: August 1, 2007 10:43 AM Subject: AeroElectric-List: Annunciator Dim I purchased the Vx Aviation lamp controller with the intent of using it to control, dim, and provide push-to-test of my incandescent annunciators. Dispite my best efforts, I haven't been able to make things work as advertised. Anyone having experience with annunciator dimming that might be able to offer suggestions, either with the Vx product or others, would be appreciated. Scott Fifield ________________________________________________________________________________
Date: Aug 03, 2007
Subject: Re: Noise filter
At 22:00 8/2/2007, you wrote: >A cohort is having problems with a Century autopilot induced audio >noise into his headphones. What model CFS system is it? Ron Q. ________________________________________________________________________________
Date: Aug 03, 2007
You might try wrappig about eight wraps of the power, and control cables through a ferrite bead (palomar engineers)- I assume you are using twisted pair or coax shielded wire? bobf W5RF On 8/3/07, Doug Windhorn wrote: > > N1DeltaWhiskey(at)comcast.net> > > Bob, et al, > > A cohort is having problems with a Century autopilot induced audio noise > into his headphones. From any testing we have done, this appears to be > motor noise (based on spool-up/spool-down noise) transmitted into the > power > lines. The Century information indicates that it can produce noise in > some > avionics at the 5 kHz level. If it is not power line noise, then it might > be EMF radiation being picked up by the radio or phone circuits. > > I have found some information regardng design of a "twin-T band-stop" > filter > that could probably be used to filter the offending frequency out of the > offenders power line. > > Assume others have probably had this type of problem an wondering how it > was > solved. > > On the dumb question front, the above circuit references a source and > load. > I would normally think of the power supply as the source and the autopilot > the load. But, given the noise is from the autopilot, would it not be the > source and the rest of the circuit the load? > > Any insight appreciated. > > Doug Windhorn > > ________________________________________________________________________________
Date: Aug 03, 2007
Subject: Multi functions for a hat switch
Does anyone know of a schematic that I can use to control the functions of a hat switch using a 3 position switch to create 3 separate functions for the hat? The 3 position switch will create the logic for the 3 functions, but I need some sort of relay board or transistor array to change the routing of the hat outputs and I have been penciling around and am getting a bit stumped as to the best way to do it- any help would be appreciated- there are 4 normally open switches on the hat and the 3 position switch uses 3 wires....... ________________________________________________________________________________
Subject: Re: Thermocouple wire connections
Date: Aug 03, 2007
Dean, The material of the connectors do not really matter as long as its the same material on both sides. Since there is no temperature difference on either side (as long as you dont have one connector laying against the engine), any effect is canceled out. Now if you were making a connection at the firewall you would have a temperature difference on one side of the connector that would enduce a little bit of an error, all though this too probably isnt much. The bigger issue is the mating of the two connectors. I would go with the Vision connectors (Thomas & Betts) first, when these fastons mate together they are very difficult to pull apart (a good thing) With the thermocouple wire the insulation crimp is negligible. best regards dave Read this topic online here: http://forums.matronics.com/viewtopic.php?p=127430#127430 ________________________________________________________________________________
Date: Aug 03, 2007
Alex, Since no one has replied I will try to answer your question. You need a quad pole, triple throw switch. One of the various electronic warehouses may have it such as McMaster-Carr , Electrosonic, etc may have it. Possibly radio Shack too. What are you trying to accomplish? Bevan RV7A wiring -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex Balic Sent: Friday, August 03, 2007 10:01 AM Subject: AeroElectric-List: Multi functions for a hat switch --> Does anyone know of a schematic that I can use to control the functions of a hat switch using a 3 position switch to create 3 separate functions for the hat? The 3 position switch will create the logic for the 3 functions, but I need some sort of relay board or transistor array to change the routing of the hat outputs and I have been penciling around and am getting a bit stumped as to the best way to do it- any help would be appreciated- there are 4 normally open switches on the hat and the 3 position switch uses 3 wires....... ________________________________________________________________________________
Date: Aug 04, 2007
Century 1. Apparently an early model. Doug ----- Original Message ----- From: "Ron Quillin" <rjquillin(at)gmail.com> Sent: Friday, 03 August, 2007 1:08 Subject: Re: AeroElectric-List: Noise filter > > At 22:00 8/2/2007, you wrote: >>A cohort is having problems with a Century autopilot induced audio noise >>into his headphones. > > What model CFS system is it? > > Ron Q. > > > ________________________________________________________________________________
Date: Aug 04, 2007
Negative. Sounds like you are suggesting twisted B+ and B- wires might correct the problem. Correct? Doug ----- Original Message ----- From: Robert Feldtman To: aeroelectric-list(at)matronics.com Sent: Friday, 03 August, 2007 3:37 Subject: Re: AeroElectric-List: Noise filter You might try wrappig about eight wraps of the power, and control cables through a ferrite bead (palomar engineers)- I assume you are using twisted pair or coax shielded wire? bobf W5RF On 8/3/07, Doug Windhorn wrote: Bob, et al, A cohort is having problems with a Century autopilot induced audio noise into his headphones. From any testing we have done, this appears to be motor noise (based on spool-up/spool-down noise) transmitted into the power lines. The Century information indicates that it can produce noise in some avionics at the 5 kHz level. If it is not power line noise, then it might be EMF radiation being picked up by the radio or phone circuits. I have found some information regardng design of a "twin-T band-stop" filter that could probably be used to filter the offending frequency out of the offenders power line. Assume others have probably had this type of problem an wondering how it was solved. On the dumb question front, the above circuit references a source and load. I would normally think of the power supply as the source and the autopilot the load. But, given the noise is from the autopilot, would it not be the source and the rest of the circuit the load? Any insight appreciated. ________________________________________________________________________________
From: "Terry Miles" <terrence_miles(at)hotmail.com>
Date: Aug 04, 2007
You can buy a relay board from Spruce that is designed for hat switch purpose. Also the same can be had thru Infinity Aerospace that sells a stick grip and has this board on his product list. Over $100 I think. Or if you look on his website or write to him, he may have the wiring schematic available. Terry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alex Balic Sent: Friday, August 03, 2007 1:01 PM Subject: AeroElectric-List: Multi functions for a hat switch Does anyone know of a schematic that I can use to control the functions of a hat switch using a 3 position switch to create 3 separate functions for the hat? The 3 position switch will create the logic for the 3 functions, but I need some sort of relay board or transistor array to change the routing of the hat outputs and I have been penciling around and am getting a bit stumped as to the best way to do it- any help would be appreciated- there are 4 normally open switches on the hat and the 3 position switch uses 3 wires....... ________________________________________________________________________________
Date: Aug 04, 2007
From: "Greg Campbell" <gregcampbellusa(at)GMAIL.COM>
Subject: Intermittent vs. Continuous Duty Contactors (was batteries)...
*Bob wrote:* This is why we SWITCH starter loads with STARTER CONTACTORS. These have exceedingly thin and light contacts compared to *continuous duty contactors* . . . these contacts are *driven together with much greater force* so as to minimize the bouncing and contact resistance. See: http://www.aeroelectric.com/Pictures/Contactors/S702-1b.jpg ---- To which I'd like to add this little anecdote --- I recently read where a friend of mine smelled electrical problems while testing things on the ground and it came from using an *intermittent duty* "starter" contactor where a *continuous duty* "master switch" type contactor was called for. http://groups.yahoo.com/group/Lancair_ES/message/8615 To his credit - the box he bought said it contained a continuous duty contactor. Unfortunately, the little metal can inside the box was an intermittent duty contactor. When he smelled things getting hot on the ground and saw smoke, he shut everything off and discovered a cooked contactor in the back and later figured out why. (The box had contained the wrong part!) LESSON: Check the contents of those boxes - someone may have switched them around! Greg Lesson #1) - check the contents of the box to make sure it's the correct item inside. Lesson #2) - the "starter contactors", as Bob said, are driven together with more force. Typically this means their coils draw about 3 or 4 times as much current as their "continuous duty" brothers. This means more heat in the same area. This means that the "starter" contactors will get hot and that's why they need to cool off between prolonged uses. It's all about heat dissipation - and that boils down to power over surface area. Most of us can relate to a 60 Watt lightbulb. A "regular" light bulb would be the A-style bulb. You can grab one and unscrew it after it's been on for awhile. You probably can't hold it - but you can grab it and spin it out Just as an example: Intermittent Duty "Starter" Contactors - may draw 5 or 6 amps. This lets their coils authoritatively slam the contacts together and allows for more "spring tension" to break the connection reliably & quickly. On a 12v system - this translates to about 60 to 70 Watts. Continuous Duty "Master" Contactors - may draw 1 or 2 amps. This is enough to switch an infrequent and lower current than a starter. On a 12v system - this translates to about 12 to 24 Watts. This comes down to a matter of dissipating the heat. That's a matter of surface area and wattage. The contactors are typically in the same size metal "can", so the surface area is the same. 60 Watts spread out over a large volume won't get too hot. 60 Watts spread out over a Here's a simple way for most folks to visualize the heat dissipation. It's mostly related to Power divided by Surface Area. Put a 60 Watt heater inside a toaster oven and it's not much of a toaster. Put a 60 Watt bulb inside a smaller metal box and you have an Easy Bake oven. Put a 60 Watt bulb inside: - a toaster oven - and it's not much of an oven - a small metal box and it's an Easy Bake oven - inside a candelabra size bulb So for anyone who's not an engineer - here's a simple way to relate this to how hot things can get: Imagine grabbing a common 60 Watt or 75 Watt incandescent light bulb that's been on for an hour with your bare hand. Ouch... Since the starter contactor is smaller than a regular "Type A" light bulb, imagine grabbing a 60 Watt candelabra sized light bulb that's been on for an hour. Ouch + fried skin! Now imagine grabbing our "continous duty" starter by grabbing a 15 Watt candelabra bulb. Warm, but not burning hot. Mount it in a metal can with a little metal standoff bracket - and no problem letting it run all day long. Anyway - that's the way I visualize the power and heat dissipation issues between an intermittent and continuous starter contactor. It's also the way I judge how hot something should "normally" be. For example - if you have an EFIS drawing 5 Amps @ 12V, then you can imagine a 60 Watt light bulb inside a metal box of similar size to the EFIS - and have enough experience to estimate how warm it might be after an hour or two of continuous use. But in the meantime - make sure you double check the part numbers on your "master switch" contactors and make sure it's not an intermittent duty! Fly safe, Greg ________________________________________________________________________________
Date: Aug 04, 2007
>Patrick Elliott >Subject: AeroElectric-List: GMCjetpilot T-shirts.. > >After seeing multiple comments about these T shirts, >and photos of the same in other 'virtual' locations, my >interest was piqued. Dear Pat: You seem obsessed with me? Should I alert the authorities? If any thing happens to me it's Patrick.... BTW, I saw the Tee-shirt and love it. Laughed my tail off. The guy wore the t-shirt because people last year asked if he was me. He must be hansom. lol. I get a cut of sales! Dude, what would possess you to write this and waste every one's time? What have I done to you? Relevance to aircraft wiring is what? Are you just making trouble and instigating? I not impressed. Shame on you. You are "piqued", really? You are the curious one. Bob and I had a riff in the past, but all has been well for months since I learned my lesson; I may not be smart but its obvious the solution is to not comment, reply or debate any of Bob's post. I got it! I realize now the debates where only about tearing people down and discrediting them. I should have known better than to get suckered into these endless urination matches. It never was about clarifying or communication, it's baiting and argument, ostensibly to ridicule or dis-credit. Just look at the manifesto on Bob's web site. I suppose I could get my lawyer since I did not give him permission, but why would any one spend so much time twisting words around? Its just simple DC wiring. I see the motive; its not about an honest debate. Now I don't hold grudges. I could get mad at some of the comments made towards me and others. One of my earlier post on aeroelectric Bob let me know he has contempt for engineers (or persons with engineering degrees)? "I would never hire an engineer". It sounded like a personal problem. That should have been a clue to bail. Who knew going to college was a waste of time and made you retarded. This is why the USA is losing the technical edge. Other countries have more engineering grads and they are beating us technically, but let live, forgive and forget, right. People are dying in Iraq, bridge collapse.... This is suppose to be fun. This is old news Patrick, you should move on. I like to learn, share information and deal in facts and scientific data, not all this baloney. You posted this, to just say to me, I don't like you, is really immature baloney. Lets talk about airplanes for gosh sakes. >I found and read Bob's article on why "GMCjetpilot" was >asked to leave and some other readings, which only caused >me to dig deeper. Caused me to Dig deeper? Stalker? Weird. You're referring to "the manifesto"? That's also old news also. Are you referring to the last blow up, when I said IR alternators be turned on BEFORE engine start and the fur ball round of posts that ensued, which was unpleasant? Yea I said internally regulated alternators should be turned on before start. What was I thinking? After 5 calls to regulator manufactures and designers, plus friends who damaged their alternator by turning them on/off while spinning under load, I came to my conclusion. I should have left my comments with out debate or defense. Go ahead, flip the ALT on after start, off before shut-down under load, its your alternator. (This applies to stock IR ND's, not plane-power units, which are wired differently than stock.) Again, in the future I'll not reply, respond or debate Bob. Its not a contest. If I make a comment or suggestion, they will stand alone. People who understand or appreciate my post/input will accept them it. Others that want to fight, argue, dismiss and ridicule my comments. Feel free. You will tango alone. One post per topic and given with out defense. If you want the full meal deal explanation of my research, data and supporting facts, write me. No mystery, ask, I don't bite. I don't know why Bob and I can't talk? One of my first post, Bob let me know he hates engineers. "I would never hire an engineer." Who knew going to college was a waste of time and makes you retarded. This is why the USA is losing the technical edge. It sounded like a personal problem. When Bob wrote the diatribe and posted it on his site, it starts with a quote of mine (out of context). "No offense to Bob, but OV relays are a step backwards." That comment is true in my opinion. We have better options, Plane-Power, either their internal or externally regulated alternators. If you have a stock internally regulated alternator and if you feel you must have extra OV protection....SELL IT and buy a plane-power unit. It's common sense. If you really care about the BEST, than buy the best, but don't BAND AID it. However a good quality stock unit is very reliable and unlikely to ever fail in a severe over voltage condition, but if you need it because your panel is expensive/sensitive or your operations are critical (IFR) than don't mess around with OV relays. BTW I just found out Plane-Power will have an external voltage regulator soon. I currently suggest the Transpo V1200, OV protected voltage regulator for external regulation. I do not work for P-P, but I looked into getting into the business of making alternators for homebuilts years ago. I gave up when I say what plane-power was doing. The did it right with proper rotation fans, high altitude brushes, corrosion protection and in-house manufacture of critical parts. (B&C is a fine company that Bob has had or has a relationship with. I just think Plane-Power offers better value, sorry only an opinion.) Don't put a band-aid on a cut that needs stitches. I take full responsibility for my words and have got mad at Bob and gave him a few digs, but it takes two tango. I stopped dancing long ago. I realize now the debates where only about tearing people down and discrediting them. I should have known better than to get suckered into these endless urination matches. Nuff said. Folks lighten up, this is fun stuff, learning and sharing. I support & appreciate every ones effort 100%, except all the waste of time arguing for argument sake. >Patrick Elliott Not on GMCJetPilots friend list. I'll have to go on without you on my friends list? Life will go on but will miss you Patrick "piqued" Ellliottt. I'll get a t-shirt so you can find me at the airshow and tell me off in person. 27 years ago I started building my first kit plane, folks where real nice than, helpful and supportive. It would be nice to get back to those days. Flame suit and asbestos underwear on. Cheers --------------------------------- Park yourself in front of a world of choices in alternative vehicles. Visit the Yahoo! Auto Green Center. ________________________________________________________________________________
Date: Aug 04, 2007
Subject: Re: Multi functions for a hat switch
Hi Alex- >...create 3 separate functions for the >hat? ... I know this isn't the response you were looking for, but please be careful about what you wish for. Having multi functions for each switch on your trim system sounds like it would be a human factors issue. For example, one day you will accidentally fire a rocket when all you wanted was to run a little pitch trim... It's statistically bound to happen. Perhaps not a big deal if there are no critical, or at least time critical, functions on the switch. However, incorporating that kind of operational complexity into your cockpit is generally contrary to the KISS principle. FWIW- Glen Matejcek ________________________________________________________________________________
Date: Aug 05, 2007
So This Pat guy writes a couple lines and we get this? Talk about self obsessed. Dude, put the mirror down. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gmcjetpilot(at)yahoo.com Sent: Saturday, August 04, 2007 1:50 PM Subject: Re: AeroElectric-List: GMCjetpilot T-shirts.. >Patrick Elliott >Subject: AeroElectric-List: GMCjetpilot T-shirts.. > >After seeing multiple comments about these T shirts, >and photos of the same in other 'virtual' locations, my >interest was piqued. Dear Pat: You seem obsessed with me? Should I alert the authorities? If any thing happens to me it's Patrick.... BTW, I saw the Tee-shirt and love it. Laughed my tail off. The guy wore the t-shirt because people last year asked if he was me. He must be hansom. lol. I get a cut of sales! Dude, what would possess you to write this and waste every one's time? What have I done to you? Relevance to aircraft wiring is what? Are you just making trouble and instigating? I not impressed. Shame on you. You are "piqued", really? You are the curious one. Bob and I had a riff in the past, but all has been well for months since I learned my lesson; I may not be smart but its obvious the solution is to not comment, reply or debate any of Bob's post. I got it! I realize now the debates where only about tearing people down and discrediting them. I should have known better than to get suckered into these endless urination matches. It never was about clarifying or communication, it's baiting and argument, ostensibly to ridicule or dis-credit. Just look at the manifesto on Bob's web site. I suppose I could get my lawyer since I did not give him permission, but why would any one spend so much time twisting words around? Its just simple DC wiring. I see the motive; its not about an honest debate. Now I don't hold grudges. I could get mad at some of the comments made towards me and others. One of my earlier post on aeroelectric Bob let me know he has contempt for engineers (or persons with engineering degrees)? "I would never hire an engineer". It sounded like a personal problem. That should have been a clue to bail. Who knew going to college was a waste of time and made you retarded. This is why the USA is losing the technical edge. Other countries have more engineering grads and they are beating us technically, but let live, forgive and forget, right. People are dying in Iraq, bridge collapse.... This is suppose to be fun. This is old news Patrick, you should move on. I like to learn, share information and deal in facts and scientific data, not all this baloney. You posted this, to just say to me, I don't like you, is really immature baloney. Lets talk about airplanes for gosh sakes. >I found and read Bob's article on why "GMCjetpilot" was >asked to leave and some other readings, which only caused >me to dig deeper. "Caused me to Dig deeper"? Stalker? Weird. You're referring to "the manifesto"? That's also old news also. Are you referring to the last blow up, when I said IR alternators be turned on BEFORE engine start and the fur ball round of posts that ensued, which was unpleasant? Yea I said internally regulated alternators should be turned on before start. What was I thinking? After 5 calls to regulator manufactures and designers, plus friends who damaged their alternator by turning them on/off while spinning under load, I came to my conclusion. I should have left my comments with out debate or defense. Go ahead, flip the ALT on after start, off before shut-down under load, its your alternator. (This applies to stock IR ND's, not plane-power units, which are wired differently than stock.) Again, in the future I'll not reply, respond or debate Bob. Its not a contest. If I make a comment or suggestion, they will stand alone. People who understand or appreciate my post/input will accept them it. Others that want to fight, argue, dismiss and ridicule my comments. Feel free. You will tango alone. One post per topic and given with out defense. If you want the full meal deal explanation of my research, data and supporting facts, write me. No mystery, ask, I don't bite. I don't know why Bob and I can't talk? One of my first post, Bob let me know he hates engineers. "I would never hire an engineer." Who knew going to college was a waste of time and makes you retarded. This is why the USA is losing the technical edge. It sounded like a personal problem. When Bob wrote the diatribe and posted it on his site, it starts with a quote of mine (out of context). "No offense to Bob, but OV relays are a step backwards." That comment is true in my opinion. We have better options, Plane-Power, either their internal or externally regulated alternators. If you have a stock internally regulated alternator and if you feel you must have extra OV protection....SELL IT and buy a plane-power unit. It's common sense. If you really care about the BEST, than buy the best, but don't BAND AID it. However a good quality stock unit is very reliable and unlikely to ever fail in a severe over voltage condition, but if you need it because your panel is expensive/sensitive or your operations are critical (IFR) than don't mess around with OV relays. BTW I just found out Plane-Power will have an external voltage regulator soon. I currently suggest the Transpo V1200, OV protected voltage regulator for external regulation. I do not work for P-P, but I looked into getting into the business of making alternators for homebuilts years ago. I gave up when I say what plane-power was doing. The did it right with proper rotation fans, high altitude brushes, corrosion protection and in-house manufacture of critical parts. (B&C is a fine company that Bob has had or has a relationship with. I just think Plane-Power offers better value, sorry only an opinion.) Don't put a band-aid on a cut that needs stitches. I take full responsibility for my words and have got mad at Bob and gave him a few digs, but it takes two tango. I stopped dancing long ago. I realize now the debates where only about tearing people down and discrediting them. I should have known better than to get suckered into these endless urination matches. Nuff said. Folks lighten up, this is fun stuff, learning and sharing. I support & appreciate every ones effort 100%, except all the waste of time arguing for argument sake. >Patrick Elliott Not on GMCJetPilots friend list. I'll have to go on without you on my friends list? Life will go on but will miss you Patrick "piqued" Ellliottt. I'll get a t-shirt so you can find me at the airshow and tell me off in person. 27 years ago I started building my first kit plane, folks where real nice than, helpful and supportive. It would be nice to get back to those days. Flame suit and asbestos underwear on. Cheers ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Homemade Aviation Headset
Date: Aug 05, 2007
I am considering trying to make a headset as is described in the link below: http://www.cozy1200.com/geeklog/article.php?story 070427102533266 I am confused by the fact that the transformer he suggests to use from Radio Shack is 1000 ohm input/8 ohm output. The plane system is going to be looking for a 600 ohm input??? What will this 1000 ohm transformer do to the plane system? Will it harm it? Will the system output be louder or softer with the 1000 ohm than it would have been with a 600 ohm transformer? If I knew what I was doing here I would probably afraid to proceed. As it is I am fearless....:>) Thanks for your assistance. Bill B ________________________________________________________________________________
Date: Aug 05, 2007
Subject: Re: Homemade Aviation Headset
Bill Bradburry wrote: > > I am considering trying to make a headset as is described in the link below: > > http://www.cozy1200.com/geeklog/article.php?story 070427102533266 > > I am confused by the fact that the transformer he suggests to use from Radio > Shack is 1000 ohm input/8 ohm output. The plane system is going to be > looking for a 600 ohm input??? > > What will this 1000 ohm transformer do to the plane system? Will it harm > it? Will the system output be louder or softer with the 1000 ohm than it > would have been with a 600 ohm transformer? > > If I knew what I was doing here I would probably afraid to proceed. As it > is I am fearless....:>) > > Thanks for your assistance. > > Bill, I just made a set and tested it in both my embryonic project and it a fellow chapter member's Cherokee. I used Phillips ANR earplugs. I used the 1/4" adapter supplied with the earbuds and got excellent audio quality. I used a $2.59 electret microphone from Radio Shack. In the Cherokee, the voice quality was BETTER through the Radio Shack mic, wired directly to a homemade 3/16" mic plug with no additional electronics, than through my Telex Echelon headsets. I do not know what sort of intercom he was using. I built one of RST-Engineering's intercoms for my project. The Radio Shack mic was obviously loading down the input circuit to the intercom (it draws amplifying power from the input circuit). The voice input was fine with my homemade headset or the Echelons if used individually, but dropped to a very low level if both were plugged in simultaneously. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 05, 2007
"Bill Bradburry" wrote: > > I am considering trying to make a headset as is described in the link below: > > http://www.cozy1200.com/geeklog/article.php?story 070427102533266 > > I am confused by the fact that the transformer he suggests to use from Radio > Shack is 1000 ohm input/8 ohm output. The plane system is going to be > looking for a 600 ohm input??? > > What will this 1000 ohm transformer do to the plane system? Will it harm > it? Will the system output be louder or softer with the 1000 ohm than it > would have been with a 600 ohm transformer? > > If I knew what I was doing here I would probably afraid to proceed. As it > is I am fearless....:>) > > Thanks for your assistance. > > Bill B Hi Bill, The 1000 ohm transformer will not load a 600 ohm circuit quite as much. In audio circuits, you need to match impedance to maximize power transfer. If you don't need maximum power transfer, and you probably don't, it should work just fine. Bob W. -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://www.roblinphoto.com/shop/ ________________________________________________________________________________
Date: Aug 05, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>So This Pat guy writes a couple lines and we get this? >Talk about self obsessed. Dude, put the mirror down. > > >---------- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >gmcjetpilot(at)yahoo.com >Sent: Saturday, August 04, 2007 1:50 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: GMCjetpilot T-shirts.. > > >Patrick Elliott > >Subject: AeroElectric-List: GMCjetpilot T-shirts.. > > > >After seeing multiple comments about these T shirts, > >and photos of the same in other 'virtual' locations, my > >interest was piqued. > >Dear Pat: > >You seem obsessed with me? Should I alert the authorities? >If any thing happens to me it's Patrick.... Gentlemen, this List should be for the posting, sifting and assemblage of simple-ideas into repeatable experiments. The IDEAS should be subject to intense scrutiny for the purpose of gaining understanding and ultimately deciding whether or not the idea is useful or even correct. By carrying this thread beyond the simple notice that someone was publicly advertising his/her personal projections about another person does not speak well of us. I'll suggest that we each endeavor to evaluate things said of us under the microscope of personal critical review. Nobody knows you better than you. When evaluating something said of you, it's either (1) true and worthy of further consideration or (2) false and not worthy of further consideration beyond a simple defense. Hence, none of us needs to fall victim to feelings of injury or insult. When we make the conversations about people, there is no value to be added anywhere, no repeatable experiment to be identified except to demonstrate what has already been shown: Some folks are unwilling or incapable of entering into critical thought without projecting their own vision (usually negative) of others thus driving the conversation out of the practical and into the personal. Folks who speak the truth about you are teachers. Those who do not have a dishonorable agenda or a socio-pathological condition. We should strive for accurate and factual in defense against an conscious agenda for this is honorable behavior. But to make fun of those who may not be able to help themselves does not speak well of us. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2007
George, Please don't get caught up in this drivel. Some of us appreciate your long and thoughtful responses. After a year of reading these posts, I notice you put a bit of time and effort into them. Beats the "check the archives" that many write. It is up to the builder to read, further research, learn, and decide on the matters brought forward. There will always be differing opinions - just today read Greg Richter's booklet and saw his lecture at Osh. There were some obvious differences in aircraft electrical system design compared to the philosophies of Mr. Nuckolls (what a wonderful teacher after spending a year perusing his writings). It is up to ME as a newbie to decide which is best, more accurate and will best fit my needs. Whether I end up agreeing with your opinion on a topic matters not. But I do appreciate anyone who spends the time and effort as you do. Thanks for your contributions and please keep them up. Carl PS - My apologies to the group for furthering this thread, but things were getting a little nasty. I know most of you share the fellowship that usually pervades these posts and what I saw amongst RV'ers at Osh. ________________________________________________________________________________
Date: Aug 05, 2007
Easy solution is to connect hat switch common to -+14v and each other hat contact to each of the three relay board coil -+ connections respectively. Then use the three way switch to select the desired relay common coil ground connection to ground. Deene Ogden EAA Tech Counselor/Flight Advisor ________________________________________________________________________________
Subject: Aero-Electric Chat Room
Date: Aug 06, 2007
I have recently found the AeroElectric-List Digest Archive. Unfortunately, it appears to have become a chat room instead of a constructive exchange of useful information. I would hope that it would return to what I believe was its original intent. John K. Wayne ________________________________________________________________________________
Date: Aug 06, 2007
Subject: AEC9011 and other worries . . .
>Hope your trip to Osh went well. I am still interested in the AEC9011 >module for the Z-19RB diagram. Can you give me an estimate as to when >this module will be available? I will be using the Eggenfellner engine >with an internally regulated alternator. Can you also give me design >modifications to your schematic to suit this application? I wish I could >use an externally regulated alternator, but at this time that isn t an >option. I'm not sure that's true. I'm told that Plane Power is going to be offering an externally regulated alternator. Check with them to see how long that will be. Keep in mind that you don't need an alternator installed on your airplane until time for first flight. How far away are you from flying? I wouldn't spend a LOT of time praying over present options especially if a lack of understanding and knowledge may be driving your anxiety levels upward. >There surely is something I can include in my design to make this >alternator application as safe as possible. Eggenfellner isn t offering >any changes in alternator options. Your help would be greatly >appreciated. I am working with Tim Hedding from B&C Electronics and >purchasing all hardware from their supply if available. You might be more >aware of what they stock and recommend something. Beyond incorporation of ov protection there are no SAFETY issues that should drive your alternator selection. Many folks seem to feel that they're flying around with a fused bomb that only waiting for some opportune time to light up and ruin their day. Alternators are indeed capable of extreme and expensive misbehavior but they are never a safety concern in a properly architectured, adequately maintained system, only a cost-of- ownership concern. >Do I need a separate avionics master switch for the Z-19 design? Everyone >seems to think about protecting the avionics, or is the 7A fuse to the >E-bus built-in protection? Go to the website front page and do a search on "avionics master". If one were useful, it would have appeared on the Z-figures. > Can the (1-7) switch for the volt meter be exchanged for a (2-1) > switch? This might give the option of continuous monitoring voltage on > either battery. Yes, you can adjust functionality of any Z-figure to address your wants and desires. The Z-figures are illustrations of architecture with some parts selection and system fabrication details. But the primary value of the Z-figures are to lay the ground-work for a minimum-parts count, simplest-operation system to achieve the desired operability. If it's absolutely necessary that a decision be made today, get a Plane Power alternator. Install the AEC9011 when it becomes available later this summer and you'll be done. If you can provide me with a set of Eggenflener's drawings, perhaps I can tailor Z-19 to be a tad more specific to this engine. Bob . . . ________________________________________________________________________________
Subject: BATTERY MASTER SWITCH
Date: Aug 06, 2007
Cheers, I'm still searching for that elusive device - in an attempt to avoid the cost of an ampere or two of contactor current - which will control a primary battery source and another for secondary battery source. I have found several which meet one criterion or another, but not all: [a] should carry as much current as a contactor for that job; [b] needs to be an up-down rather than rotary type switch; [c] should be on a remote(able) stalk so I can undo the connection to remove the instrument panel ; [d] cost less than the usual contactor - or at least be competitive. I have devised a system to isolate the controls from wandering fingers so am not fussy about security. I'm not sure what a "Kill switch" is really. Any help would be most appreciated. Ferg Classic 914 CS prop mono PS: My server is down for the last 2 days, so my thanks will be delayed......... ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Re: Aero-Electric Chat Room
>I have recently found the AeroElectric-List Digest >Archive. Unfortunately, it appears to have become a chat room instead of >a constructive exchange of useful information. > >I would hope that it would return to what I believe was its original intent. This is a fundamental condition for every "wide open" forum. This is why one needs to be adept at using the search functions. You'll find that adjustment of search terms and honing your scanning skills will offer a strong filtering function for separating chaff from the good stuff. The archives were never intended to be a short-cut, in fact it may be a longer path to the answer sought than to simply repeat the topic on today's postings. However, the archives offer a greater depth of coverage than you might get from a lick-and-a-promise exchange on the current list. I'm sorry my friend but education is never a simple, time-frugal endeavor. If it were, everybody would be smart. I've attempted to condense the salient features of some topics into articles on the website. I'll suggest you being with a search at http://aeroelectric.com and expand the search if you don't get the needed help there. Bob . . . ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Re: Intermittent vs. Continuous Duty Contactors (was
batteries)... Greg or Bob , I know that there is an electrical way of telling the two apart in the Connection, but do you know if there is a way to tell them apart visually? All mine as they came with the firewall from Lancair seem to look alike, even to the stenciled numbers on them? > ** > -- John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Optimal bus voltage set point . . .
>Comments/Questions: I plan on using a gell cell battery in my Glasair and >have been told that I must set the charging voltage at a different level >if I do not want to damage the battery. No one is able to tell me what >voltage level I should use.So much for these self styled experts ,eh? >Can you help? >Stan No special considerations. Set for 14.2 volts nominal. There ARE "optimal" modes of operation for best life in the lab . . . which are generally impractical in the field and overshadowed by other, much more significant stresses. Install it, run it, check for capacity after first year and replace when capacity drops below your personally defined endurance minimums. The act of "tweaking" nominal bus voltage for the purpose of maximizing service life will be exceedingly difficult to validate and probably not improve on service life by more than a few percent. Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 06, 2007
batteries)... >Greg or Bob , I know that there is an electrical way of telling the two >apart in the Connection, but do you know if there is a way to tell them >apart visually? All mine as they came with the firewall from Lancair seem >to look alike, even to the stenciled numbers on them? No. Put an ohmmeter on them. A continuous duty contactor will NEVER measure under 6 ohms while an intermittent duty device is always under 6 ohms. Or wire to battery and measure coil current. A tennis ball sized contactor that dissipates more than 20 watts is in deep doo-doo in a matter of minutes. 1.5 A draw from a 12v battery is 18 watts . . . . An intermittent duty device will draw 3-5 amps, 36 to 60 watts. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Strobe whoop whoop wine
> > >> We have completed 130 flight hours with our Z-14 wired subaru now >> without any nuisance OV trips. The only electrical issue is that I >> recently purchased a comfortable David Clarke headset and with our >> fairly quiet engine, I now hear weak but annoying strobe whine that I >> couldn't hear in cruise with other headsets. I have already followed >> most of your wiring recommendations so it may take me awhile to solve >> this one especially since the strobes operate off a different >> alternator and battery as the radio and intercom. > > > Start with a test battery made up of a couple 6v > lantern batteries to run the strobe supply with a > short cable and batteries located right at the power > supply. You need to deduce the propagation mode. I suspect > it's conducted and a relatively simple filter at the > power supply will fix it. > > Bob . . . > It is a pain to pull my wingtips to get at the aeroflash power supplies and I have not done that yet. However I have powered the strobes from a separate battery with their normal fuse pulled and I still hear the noise faintly in the headset even with the engine, master switch, intercom, and radio turned OFF. It is a bit louder with the intercom powered up but I was not expecting to hear it with the intercom and radio turned off. It is a metal airframe and the strobe power supplies, the comm radio, and the intercom are all grounded to the airframe because they are all internally grounded to their respective cases. The headset jacks are insulated from the airframe (in a plastic box) and wired with shielded wire. Thinking it could be a ground loop situation I tried grounding the temporary battery to a screw on the wing spar but it did not seem to make a difference. Adding some inductance to the +power lead and some electrolytic capacitors made no diference. Before I pull the wingtips I'd like to have a plan and any needed parts on hand. I will look for some automotive radio power supply filters and pick up some nylon bolts to insulate the power supply from the airframe. Any other suggestions? Is there any point adding some capacitance to the headphone audio circuit to try and bypass some of the higer frequencies. This noise was not bothering me until I replaced one headset with a DC H10-13.4. thanks Ken ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Re: ...T-shirts..
Henador Titzoff a crit : > They're talking about a nice song in French and Spanish... Wait a minute...I'm French ;-) Sorry, no moustache, no beret, no baguette... Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Aug 06, 2007
Subject: Antenna for second com radio
To get ready for the 2008 AirVenture Cup Race, I am conducting a drag reduction program on my all metal Evo. I would like to eliminate one of the two external surface com antennae from the belly. Two options seem available, an antenna mounted in the cockpit behind the passenger seat on the aft cockpit bulkhead, or a thin wire antenna taped to the windscreen (not unlike the thin wire antennae found in windshields on automobiles.) Any suggestions from the list members on how to proceed? If I use the taped wire antenna on the windscreen, should I use the same system as used on copper foil entennae on composite aircraft but substituting a thin wire for the copper foil? Thanks in advance for any help or suggestions! Paul Siegel N4XU ________________________________________________________________________________
Subject: Powering a Camcorder to Record Flight Tests
Date: Aug 06, 2007
I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount in the cockpit to record my upcoming flight tests. Batteries are expensive and don't last long -- I'd like to use ship's power. It has a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special adapter plate that clicks into the place where the battery would go. The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord between the brick and the adapter plate, insert a set of connectors and make a pigtail with a matching connector on one end and a cigarette lighter plug on the other. Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll need about a 4 ohm resistor to drop the 6.5VDC. It looks like the power consumption will be about 10.4 Watts. The closest thing I could find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% wire-wound power resistor (Catalog No. 271-131). There was no indication how large they are physically. In theory, I could chain four of the 1 ohm units together. Is my thinking correct? All I want is to power the camcorder from ship's power. Any recommendations on connectors and any critique on the idea of simply putting a resistor (and a fuse) in the pigtail/circuit to reduce the voltage? Is there any other power conditioning I should do? Best regards, Bob ________________________________________________________________________________
Date: Aug 07, 2007
Hi Bob, Depending on how complicated you want to get. A LM2579 plus a few external components (a schotty diode, a couple of caps / resistors and an inductor) can provide a switched DC-DC step down supply <3A. http://www.onsemi.com/pub/Collateral/LM2576-D.PDF Total parts from digikey / mouser should be < $20 I would hope. Regards, Carl (working on a Canon DV camera power feed ;-) -- ZK-VII - RV 7A QB - still finishing? - New Zealand http://www.rvproject.gen.nz/ -----Original Message----- From: r falstad [mailto:bobair8(at)msn.com] Sent: Tuesday, 7 August 2007 1:13 p.m. To: AEROELECTRIC LIST Subject: AeroElectric-List: Powering a Camcorder to Record Flight Tests I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount in the cockpit to record my upcoming flight tests. Batteries are expensive and don't last long -- I'd like to use ship's power. It has a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special adapter plate that clicks into the place where the battery would go. The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord between the brick and the adapter plate, insert a set of connectors and make a pigtail with a matching connector on one end and a cigarette lighter plug on the other. Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll need about a 4 ohm resistor to drop the 6.5VDC. It looks like the power consumption will be about 10.4 Watts. The closest thing I could find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% wire-wound power resistor (Catalog No. 271-131). There was no indication how large they are physically. In theory, I could chain four of the 1 ohm units together. Is my thinking correct? All I want is to power the camcorder from ship's power. Any recommendations on connectors and any critique on the idea of simply putting a resistor (and a fuse) in the pigtail/circuit to reduce the voltage? Is there any other power conditioning I should do? Best regards, Bob ________________________________________________________________________________
Subject: Re: Powering a Camcorder to Record Flight Tests
Date: Aug 06, 2007
Your calculations on how to do this show why it isn't usually done with resistors. Resistors also presume constant load, which in general is not often true. If you had to do this in a hurry you could simply wire a 6V lamp in series. But the right way to do it is a linear regulator chip like the LM350. See: http://www.national.com/mpf/LM/LM350.html. The LM317 can be used, but is 1.5A. The LM350 is the same part at 3A. "Don't worry about people stealing an idea. If it's original, you will have to ram it down their throats." -- Howard Aiken -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=127880#127880 ________________________________________________________________________________
Date: Aug 07, 2007
r falstad wrote: > I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount in the cockpit to record my upcoming flight tests. Batteries are expensive and don't last long -- I'd like to use ship's power. It has a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special adapter plate that clicks into the place where the battery would go. The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord between the brick and the adapter plate, insert a set of connectors and make a pigtail with a matching connector on one end and a cigarette lighter plug on the other. > > Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll need about a 4 ohm resistor to drop the 6.5VDC. It looks like the power consumption will be about 10.4 Watts. The closest thing I could find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% wire-wound power resistor (Catalog No. 271-131). There was no indication how large they are physically. In theory, I could chain four of the 1 ohm units together. > > Is my thinking correct? All I want is to power the camcorder from ship's power. Any recommendations on connectors and any critique on the idea of simply putting a resistor (and a fuse) in the pigtail/circuit to reduce the voltage? Is there any other power conditioning I should do? > > Best regards, > > Bob > > Seems to be a lot of work for a temporary use that could be holding up your flight tests. You can get a 70watt inverter for about $20 that will plug into the cigarette lighter jack. Then you can use your adapter plate as-is, don't have to worry that you got all the electronics modified correctly, and won't regret cutting the cord at some point in the future. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
From: "Bob McCallum" <robert.mccallum2(at)sympatico.ca>
Date: Aug 06, 2007
Bob; One of the shortcomings of doing it with a simple resistor is that the Camcorder's current draw will vary as you record, or go to standby, zoom, or turn it on/off etc. (It's not constant at that 1.6 Amp figure, that's just a max) Therefore the voltage you're applying to it will vary (perhaps drastically, all the way up to the supply voltage) and the camcorder may not like that. (As the current requirement falls so does the voltage drop across your resistor and therefore a greater voltage is applied to your camcorder than you planned for) Bob McC ----- Original Message ----- From: r falstad To: AEROELECTRIC LIST Sent: Monday, August 06, 2007 9:13 PM Subject: AeroElectric-List: Powering a Camcorder to Record Flight Tests I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount in the cockpit to record my upcoming flight tests. Batteries are expensive and don't last long -- I'd like to use ship's power. It has a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special adapter plate that clicks into the place where the battery would go. The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord between the brick and the adapter plate, insert a set of connectors and make a pigtail with a matching connector on one end and a cigarette lighter plug on the other. Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll need about a 4 ohm resistor to drop the 6.5VDC. It looks like the power consumption will be about 10.4 Watts. The closest thing I could find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% wire-wound power resistor (Catalog No. 271-131). There was no indication how large they are physically. In theory, I could chain four of the 1 ohm units together. Is my thinking correct? All I want is to power the camcorder from ship's power. Any recommendations on connectors and any critique on the idea of simply putting a resistor (and a fuse) in the pigtail/circuit to reduce the voltage? Is there any other power conditioning I should do? Best regards, Bob ________________________________________________________________________________
Date: Aug 06, 2007
At 19:13 8/6/2007, you wrote: >Seems to be a lot of work for a temporary use that could be holding >up your flight tests. You can get a 70watt inverter for about $20 >that will plug into the cigarette lighter jack. Then you can use >your adapter plate as-is, don't have to worry that you got all the >electronics modified correctly, and won't regret cutting the cord at >some point in the future. Or just purchase a car-cord for the unit... http://www.ebuybatteries.com/product/models/2_Sony-NP-77-AC-charger_Sony+CCD-FX310.htm http://www.dc-battery.com.au/sony-np77-battery-charger-p-1330.html ________________________________________________________________________________
From: "S. Ramirez" <simon(at)synchronousdesign.com>
Date: Aug 07, 2007
Bob, Th other guys are correct about using a resistor to drop the voltage. It will have varying voltage at the load, as it draws varying current. Not a good way to go. You need a voltage regulator. Someone earlier suggested that you need a linear voltage regulator. The problem with this solution is that it will dissipate (not consume) 6.5V*1.6A = 10.4W. That's a lot of power, and you will have to heat sink it very heftily. It does have the advantage of providing the cleanest output, though, if you can handle the heat sinking. Another solution is to go with a packaged switching voltage regulator. Digi-Key has the TI PT78HT208H (Digi-Key pn 296-20250-ND) in stock for USD $16.20. It outputs 8.0V at 2.0A all day long. Can you handle 8.0V =B1 2%? Can you handle output voltage ripple of =B11% (0.08V)? If you can, this may be the way to go. This part comes in an EFA package, which is about 1 inch X .90 inch X .31 inch. Unfortunately, it needs a 1 uF ceramic capacitor C1 at the input and a 100 uF electrolytic capacitor C2 at the output. Here are some examples: Digi-Key pn493-1283-ND 100 uF, 16V, electrolytic, radial, 20%, general purpose, min buy 1, price USD $0.14 each Digi-Key pn 478-4504-ND 1 uF, 50V, ceramic, 10%, radial, general purpose, min buy 1, price USD $9.02 each All parts above are RoHS, so soldering will be about the same temp. Since Digi-Key has a USD $5 handling charge for orders less than USD $25, you can throw these caps into the same order to get it above $25. I would strongly advise you looking at the datasheets to know what you are getting into, but I believe that this combo of parts would suit your requirements, if you can handle 8 VDC =B1 the tolerances above. Simon Ramirez, Aerocanard Builder Flying LEZ Copyright =A9 2007 _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of r falstad Sent: Monday, August 06, 2007 9:13 PM Subject: AeroElectric-List: Powering a Camcorder to Record Flight Tests I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount in the cockpit to record my upcoming flight tests. Batteries are expensive and don't last long -- I'd like to use ship's power. It has a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special adapter plate that clicks into the place where the battery would go. The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord between the brick and the adapter plate, insert a set of connectors and make a pigtail with a matching connector on one end and a cigarette lighter plug on the other. Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll need about a 4 ohm resistor to drop the 6.5VDC. It looks like the power consumption will be about 10.4 Watts. The closest thing I could find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% wire-wound power resistor (Catalog No. 271-131). There was no indication how large they are physically. In theory, I could chain four of the 1 ohm units together. Is my thinking correct? All I want is to power the camcorder from ship's power. Any recommendations on connectors and any critique on the idea of simply putting a resistor (and a fuse) in the pigtail/circuit to reduce the voltage? Is there any other power conditioning I should do? Best regards, Bob 7.5.476 / ________________________________________________________________________________
Date: Aug 06, 2007
Getting ready to do the same, and have all the parts and an old headset to gut for the mic, cords, and plugs. A couple simple Q's: 1) And the most basic of questions - if I build a stereo headset, is there any problem with a stereo plug in a mono intercom system jack? I assume I will just hear monaural sound. 2) One builder put in pots and another just added resistors to adjust the ear speakers to match other headsets (in case someone flying with you uses a different headset) - has anyone built one without these? I guess I will need to experiment, and it will depend on the sensitivity of the in-ear speakers. I did get the Comply headset with their proprietary tips that are wonderful. The set looks to be the same from TrickAudio. Haven't tested in the air, but cuts out the wife and kids nicely...I mean excessive noises. After two hours in the ear, the comfort is wonderful - really don't notice the tips. The set is nice enough that I will have it jack separately into the project box so I can use them elsewhere besides the plane. http://www.canardzone.com/members/nickugolini/CuplessHeadet/cupless_headset.htm http://www.cozy1200.com/geeklog/index.php http://www.trickearphones.com/index.htm Carl ________________________________________________________________________________
Date: Aug 07, 2007
and if you run two such headsets at the same time, the 1000 ohms falls to 500 ohms, a much better match? Bill ----- Original Message ----- From: "Bob White" <bob@bob-white.com> Sent: Monday, August 06, 2007 2:02 AM Subject: Re: AeroElectric-List: Homemade Aviation Headset > > "Bill Bradburry" wrote: > >> >> >> I am considering trying to make a headset as is described in the link >> below: >> >> http://www.cozy1200.com/geeklog/article.php?story 070427102533266 >> >> I am confused by the fact that the transformer he suggests to use from >> Radio >> Shack is 1000 ohm input/8 ohm output. The plane system is going to be >> looking for a 600 ohm input??? >> >> What will this 1000 ohm transformer do to the plane system? Will it harm >> it? Will the system output be louder or softer with the 1000 ohm than it >> would have been with a 600 ohm transformer? >> >> If I knew what I was doing here I would probably afraid to proceed. As >> it >> is I am fearless....:>) >> >> Thanks for your assistance. >> >> Bill B > > Hi Bill, > > The 1000 ohm transformer will not load a 600 ohm circuit quite as > much. In audio circuits, you need to match impedance to maximize power > transfer. If you don't need maximum power transfer, and you probably > don't, it should work just fine. > > Bob W. > > -- > N93BD - Rotary Powered BD-4 - http://www.bob-white.com > 3.8 Hours Total Time and holding > Cables for your rotary installation - http://www.roblinphoto.com/shop/ > > > ________________________________________________________________________________
Date: Aug 07, 2007
Carl Peters wrote: > > > Getting ready to do the same, and have all the parts and an old > headset to gut for the mic, cords, and plugs. > A couple simple Q's: > 1) And the most basic of questions - if I build a stereo headset, is > there any problem with a stereo plug in a mono intercom system jack? I > assume I will just hear monaural sound. No the stereo plug was designed around the mono plug to be interchangable. You'll simply get sound in one ear when you plug a stereo headphone into a mono jack. My intercom is mono, and I don't want to modify the headphones (so that I can use them elsewhere, as you state). The stereo jack has three contacts: ground, left and right. The stereo plug has 3 regions. The sleeve closest to the plastic is ground. The middle area is left and the tip is right (I think. I may have left and right reversed). By jumpering the left and right together in the jack, I get sound in both ears without modifying the phones. This also drops the 1000ohm to 500 as Bill stated. ________________________________________________________________________________
Date: Aug 07, 2007
Carl Peters wrote: > 2) One builder put in pots and another just added resistors to adjust > the ear speakers to match other headsets (in case someone flying with > you uses a different headset) - has anyone built one without these? I > guess I will need to experiment, and it will depend on the sensitivity > of the in-ear speakers. The intercom has a volume control. Most aviation headsets have a volume control. I'll set the volume to my comfort with the intercom, and let everyone else adjust to that. If it gets to be a problem, a pot can be added easily enough later. Another option is that there are lots of earbuds with inline volume control already. ________________________________________________________________________________
Date: Aug 07, 2007
Have you considered simply buying a new camera? The new snapshot cameras also do video as good as the digital camcorders. Kinda an all-in-one. I just got a Fuji V10 from Tiger Direct for $170 that not only takes 5 MB photos, but has an almost unlimited video feature (and it does it in AVI...uncompressed...format..best quality...results look - and are- BETTER than my JVC analog video camera). Has a card slot, which Fuji uses their own more expensive XD cards in, but with the 1 GB XD card that came with it, I'm all set for 15 minute videos. You don't have to get a Fuji, though. Todays newer cameras have all the featueres of ones just a month or two old. Look for a camera that uses the cheaper SD cards, and get a couple of $20 2GB cards, and you'll be set for hour long videos. Video length is limited only by the size or number of the SD cards. It also has several neat games built in to keep the GIB or KIB (Kid In Back) busy on long trips. www.dpreview.com/news/0601/06010403fuji_v10.asp As someone else mentioned, get a universal car power cord from Radio Shack and with the camera's standard tripod mount, you could mount it just about anywhere in the plane with a tripod screw. Haven't tested the battery yet for longevity, but it lasts for days. I take many pictures daily...took a 15 minute video and a bunch of flash pictures at a family gathering last Friday, transferred them to the computer and the battery indicator still read full. Has full normal video...30 frames per second at 640 x 480 pixels, so it's as good as any analog unit. Also has NTSC output for TV viewing, sound, built in slide show option, etc. Look around and you'll probably find a better one cheaper now...they seem to upgrade monthly! Harley Dixon ------------------------------------------------------------------------ r falstad wrote: > I have an old analog Sony Handycam (CCD-FX310) that I'd like to mount > in the cockpit to record my upcoming flight tests. Batteries are > expensive and don't last long -- I'd like to use ship's power. It has > a 110VAC to 7.5VDC power brick (Sony Model AC-V35) with a special > adapter plate that clicks into the place where the battery would go. > The brick says the output is 7.5VDC & 1.6A. I'd like to cut the cord > between the brick and the adapter plate, insert a set of connectors > and make a pigtail with a matching connector on one end and a > cigarette lighter plug on the other. > > Because of the voltage difference (14VDC - 7.5VDC), it looks like I'll > need about a 4 ohm resistor to drop the 6.5VDC. It looks like the > power consumption will be about 10.4 Watts. The closest thing I could > find on Radio Shack's website is either a 1 ohm or 10 ohm, 10 Amp, 10% > wire-wound power resistor (Catalog No. 271-131). There was no > indication how large they are physically. In theory, I could chain > four of the 1 ohm units together. > > Is my thinking correct? All I want is to power the camcorder from > ship's power. Any recommendations on connectors and any critique on > the idea of simply putting a resistor (and a fuse) in the > pigtail/circuit to reduce the voltage? Is there any other power > conditioning I should do? > > Best regards, > > Bob > > ________________________________________________________________________________
Date: Aug 07, 2007
Subject: Re: BATTERY MASTER SWITCH
> >Cheers, > I'm still searching for that elusive device - in an attempt to avoid >the cost of an ampere or two of contactor current - which will control a >primary battery source and another for secondary battery source. > I have found several which meet one criterion or another, but not >all: >[a] should carry as much current as a contactor for that job; >[b] needs to be an up-down rather than rotary type switch; >[c] should be on a remote(able) stalk so I can undo the connection to >remove the instrument panel ; >[d] cost less than the usual contactor - or at least be competitive. > I have devised a system to isolate the controls from wandering >fingers so am not fussy about security. I'm not sure what a "Kill switch" is >really. > Any help would be most appreciated. Ferg, Why not build one? You need to support two 5/16" brass studs on an insulating material, say 1/8" thick fiberglass/epoxy sheet. Taper switch ends of studs to provide a spherical tip with about 1/8th inch radius. Mount studs just far enough apart to allow connection with fat-wires . . . about 1" would probably do. Build box on terminal board to capture a brass "slider" (3/8" square stock) that is pressed against stud tips with spring loading from back side. You could rig a Bowden control cable to operate the slide (you need about 1/2 to 3/4" stroke) for making and breaking the switch. This seems like a project that could be crafted with common hand tools. The end product would be on the order of 3" long, 1.5" wide and perhaps 2" deep. Perfect the design and we'll do an article on it for the website. Bob . . . ________________________________________________________________________________
Date: Aug 07, 2007
Subject: Re: Antenna for second com radio
> >To get ready for the 2008 AirVenture Cup Race, I am conducting a drag >reduction program on my all metal Evo. I would like to eliminate one of >the two external surface com antennae from the belly. > >Two options seem available, an antenna mounted in the cockpit behind the >passenger seat on the aft cockpit bulkhead, or a thin wire antenna taped >to the windscreen (not unlike the thin wire antennae found in windshields >on automobiles.) > >Any suggestions from the list members on how to proceed? > >If I use the taped wire antenna on the windscreen, should I use the same >system as used on copper foil entennae on composite aircraft but >substituting a thin wire for the copper foil? > >Thanks in advance for any help or suggestions! > >Paul Siegel N4XU If this is a temporary configuration change to accommodate a short time event, why not simply do away with the sticky-out antennas all together? Use a hand-held with rubber duck during the event. I had a builder some years ago mount all his sticky-out antennas on removable inspection plates. While being judged for show, all antennas were replaced with blank plates. Seems like cheating to me but perhaps the judges were not interested in overall system utility, only appearances. In any case, the optimum solution to your problem is one that generates the least amount of pre-event labor and modifications to an otherwise perfectly good working airplane. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 07, 2007
Good Morning Bob, Paul, Back in my glider flying days, we used one of those little fiberglass antennas that were sometimes used instead of rubber duckies with a handheld. We used a section of Coax between the handheld and the antenna. A hole was drilled in the belly of the glider and the antenna stuck through the hole when it was needed. A piece of tape was applied over the hole when it was not in use so as to eliminate any drag produced by the hole. We did seem to get better results from the handheld with the antenna out the belly than when it was just used directly. I doubt if it was a very efficient set up, but seemed to work fairly well except for when somebody forgot to remove the antenna before landing. To handle that eventuality, most of us carried a spare antenna. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 8/7/2007 9:37:10 A.M. Central Daylight Time, nuckollsr(at)cox.net writes: If this is a temporary configuration change to accommodate a short time event, why not simply do away with the sticky-out antennas all together? Use a hand-held with rubber duck during the event. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Circuit Breaker Bus Bar
Date: Aug 07, 2007
Greetings, I have lurked in the AeroElectric list for a while and I am coming to point in my project where I am going to be planning and building my electrical system. I am looking at 12 circuit breakers (spare the groans) in a 3 x 4 configuration. Would anyone be willing to send a photo or many photos of how would one go about making a copper bus bar for a configuration like that where the breakers are not inline? Also, what are you doing to insulate the bus bar against accidental contact with a ground? Thank you, Scott R. Shook RV-7A (Building) N696JS (Reserved) ________________________________________________________________________________
Date: Aug 07, 2007
Subject: Re: Circuit Breaker Bus Bar
Scott, The answers you look for are the same reasons folks don't use that system. But: Use 3 cappoer bars and tie them together on the ends with another copper strip. You can put "liquid Electrical Tape" on the ends to try and keep it all safe. Most bus bars have no protection, at least the ones I have seen. I am sure your idea will work and you will fly successfully for years. Build on, Mike ----- Original Message ----- From: "Scott R. Shook" <sshook(at)cox.net> Date: Tuesday, August 7, 2007 1:31 pm Subject: AeroElectric-List: Circuit Breaker Bus Bar > Greetings, > > I have lurked in the AeroElectric list for a while and I am coming > to point > in my project where I am going to be planning and building my > electricalsystem. I am looking at 12 circuit breakers (spare the > groans) in a 3 x 4 > configuration. > > Would anyone be willing to send a photo or many photos of how > would one go > about making a copper bus bar for a configuration like that where the > breakers are not inline? > > Also, what are you doing to insulate the bus bar against > accidental contact > with a ground? > > Thank you, > > > > Scott R. Shook > RV-7A (Building) > N696JS (Reserved) > > ________________________________________________________________________________
Subject: Missed email mesages
Date: Aug 07, 2007
I must apologize, but my server 'ra.ca' had lost control of its machinery this last weekend and in the process of countering spam lost all emails to me from Saturday 04AUG to yesterday, Monday 07Aug. 7, 07 inclusive. If you had sent me critical advice or legal information during that period, I will not have got it and cannot therefore respond.......... Sorry Ferg ________________________________________________________________________________
Date: Aug 07, 2007
I don't know if this will work for anyone but... Lancair Avionics will sell "pre-drilled" copper buss bars that are setup on a specific spacing for Klixon breakers. I actually have some and won't be using them. They come in two lengths with two different centers. I just pulled mine and the long bars (about 8-9 inches) are on approx .75" centers... The short bars are about 7" long and on drilled on 1.1" centers (these are approx centers and I just grabbed my dial calipers and eyeballed them. The wider centers are used to connect the horizontal rows, vertically and to the main wires coming to the busses. The narrower centers are used to connect the breakers together in any specific row. Here are some pictures that I shot quick http://www.highrf.com/albums/Legacy-Panel/DSCN1977.sized.jpg - the buss bars <http://www.highrf.com/albums/Legacy-Panel/DSCN1978.sized.jpg> http://www.highrf.com/albums/Legacy-Panel/DSCN1978.sized.jpg - another of the bars <http://www.highrf.com/albums/Legacy-Panel/DSCN1979.sized.jpg> http://www.highrf.com/albums/Legacy-Panel/DSCN1979.sized.jpg - the spacing that they fit Hope this helps. I don't remember those strips being that expensive, but it's been awhile since I got these. Alan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Ice Sent: Tuesday, August 07, 2007 7:11 PM Subject: Re: AeroElectric-List: Circuit Breaker Bus Bar Scott, The answers you look for are the same reasons folks don't use that system. But: Use 3 cappoer bars and tie them together on the ends with another copper strip. You can put "liquid Electrical Tape" on the ends to try and keep it all safe. Most bus bars have no protection, at least the ones I have seen. I am sure your idea will work and you will fly successfully for years. Build on, Mike ----- Original Message ----- From: "Scott R. Shook" <sshook(at)cox.net> Date: Tuesday, August 7, 2007 1:31 pm Subject: AeroElectric-List: Circuit Breaker Bus Bar > Greetings, > > I have lurked in the AeroElectric list for a while and I am coming > to point > in my project where I am going to be planning and building my > electricalsystem. I am looking at 12 circuit breakers (spare the > groans) in a 3 x 4 > configuration. > > Would anyone be willing to send a photo or many photos of how > would one go > about making a copper bus bar for a configuration like that where the > breakers are not inline? > > Also, what are you doing to insulate the bus bar against > accidental contact > with a ground? > > Thank you, > > > > Scott R. Shook > RV-7A (Building) > N696JS (Reserved) > > ________________________________________________________________________________
Date: Aug 07, 2007
>Greetings, > >I have lurked in the AeroElectric list for a while and I am coming to >point in my project where I am going to be planning and building my >electrical system. I am looking at 12 circuit breakers (spare the groans) >in a 3 x 4 configuration. > >Would anyone be willing to send a photo or many photos of how would one go >about making a copper bus bar for a configuration like that where the >breakers are not inline? See: http://www.aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_0.jpg http://www.aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_1.jpg http://www.aeroelectric.com/Pictures/Breakers/Breaker_Panel_Busing_2.jpg >Also, what are you doing to insulate the bus bar against accidental >contact with a ground? Not necessary. There should be nothing in vicinity capable of producing the ground. All bus bars on light aircraft are essentially waving in the breeze behind the breaker panel. Bob . . . ________________________________________________________________________________
Date: Aug 07, 2007
> >Cheers, > I'm still searching for that elusive device - in an attempt to avoid >the cost of an ampere or two of contactor current - which will control a >primary battery source and another for secondary battery source. > I have found several which meet one criterion or another, but not >all: >[a] should carry as much current as a contactor for that job; >[b] needs to be an up-down rather than rotary type switch; >[c] should be on a remote(able) stalk so I can undo the connection to >remove the instrument panel ; >[d] cost less than the usual contactor - or at least be competitive. > I have devised a system to isolate the controls from wandering >fingers so am not fussy about security. I'm not sure what a "Kill switch" is >really. > Any help would be most appreciated. Ferg, Why not build one? You need to support two 5/16" brass studs on an insulating material, say 1/8" thick fiberglass/epoxy sheet. Taper switch ends of studs to provide a spherical tip with about 1/8th inch radius. Mount studs just far enough apart to allow connection with fat-wires . . . about 1" would probably do. Build box on terminal board to capture a brass "slider" (3/8" square stock) that is pressed against stud tips with spring loading from back side. You could rig a Bowden control cable to operate the slide (you need about 1/2 to 3/4" stroke) for making and breaking the switch. This seems like a project that could be crafted with common hand tools. The end product would be on the order of 2.5" long, 1.2" wide and perhaps 2" tall overall. Perfect the design and we'll do an article on it for the website. Here's a rough layout of a possible design http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf The brass stock, parts and spring-stud are McMaster catalog items. Side brackets can be aluminum sheet or extrusion. Insulating material could be Delrin or perhaps even a hard "machinable" wood like walnut or oak. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2007
Clever design. I guess the operating cable is non conductive, or did I miss something? Paul ====================== At 11:05 PM 8/7/2007, you wrote: > > Ferg, Why not build one? You need to support two 5/16" brass > studs on an insulating material, say 1/8" thick fiberglass/epoxy > sheet. Taper switch ends of studs to provide a spherical tip > with about 1/8th inch radius. Mount studs just far enough apart > to allow connection with fat-wires . . . about 1" would probably > do. Build box on terminal board to capture a brass "slider" > (3/8" square stock) that is pressed against stud tips with > spring loading from back side. You could rig a Bowden control > cable to operate the slide (you need about 1/2 to 3/4" stroke) > for making and breaking the switch. This seems like a project > that could be crafted with common hand tools. The > end product would be on the order of 2.5" long, 1.2" wide and > perhaps 2" tall overall. Perfect the design and we'll do an article > on it for the website. > > Here's a rough layout of a possible design > >http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf > > The brass stock, parts and spring-stud are McMaster catalog > items. Side brackets can be aluminum sheet or extrusion. > Insulating material could be Delrin or perhaps even a > hard "machinable" wood like walnut or oak. > > Bob . . . > > ________________________________________________________________________________
Date: Aug 08, 2007
Robert L. Nuckolls, III wrote: > > Here's a rough layout of a possible design > > http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf > > The brass stock, parts and spring-stud are McMaster catalog > items. Side brackets can be aluminum sheet or extrusion. > Insulating material could be Delrin or perhaps even a > hard "machinable" wood like walnut or oak. > > Bob . . . > What a cool idea. This looks like it would be a fun project, Bob. The only thing I would change would be to make the slider a square piece and arrange it so that it contacts both taper switch ends at the same time. I know this real smart guy that taught me that contactors have multiple break points in order to break the arc faster. With a couple more of those spring-studs, it should be possible to make the slider pop off the switch ends at a much higher rate. Just arrange a few on both sides of the switch ends so that the slider is cantilevered away when it is slid out, but hits the springs and pushed against the contacts when slid in. Dang!! I'm gonna have to make one now. Right after I finish building several more earbud headsets. I'll never get airplane finished at this rate (but, I will have the coolest contactor in the universe!!). Ernest (Is anyone else having this much fun?) ________________________________________________________________________________
Subject: WOW.....
Date: Aug 08, 2007
Bob sent: From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Subject: Re: AeroElectric-List: BATTERY MASTER SWITCH > I'm still searching for that elusive device - in an attempt to avoid >the cost of an ampere or two of contactor current - which will control a >primary battery source and another for secondary battery source. > I have found several which meet one criterion or another, but not >all: >[a] should carry as much current as a contactor for that job; >[b] needs to be an up-down rather than rotary type switch; >[c] should be on a remote(able) stalk so I can undo the connection to >remove the instrument panel ; >[d] cost less than the usual contactor - or at least be competitive. > I have devised a system to isolate the controls from wandering >fingers so am not fussy about security. I'm not sure what a "Kill switch" is >really. > Any help would be most appreciated. Ferg, Why not build one? You need to support two 5/16" brass studs on an insulating material, say 1/8" thick fiberglass/epoxy sheet. Taper switch ends of studs to provide a spherical tip with about 1/8th inch radius. Mount studs just far enough apart to allow connection with fat-wires . . . about 1" would probably do. Build box on terminal board to capture a brass "slider" (3/8" square stock) that is pressed against stud tips with spring loading from back side. You could rig a Bowden control cable to operate the slide (you need about 1/2 to 3/4" stroke) for making and breaking the switch. This seems like a project that could be crafted with common hand tools. The end product would be on the order of 2.5" long, 1.2" wide and perhaps 2" tall overall. Perfect the design and we'll do an article on it for the website. Here's a rough layout of a possible design http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf The brass stock, parts and spring-stud are McMaster catalog items. Side brackets can be aluminum sheet or extrusion. Insulating material could be Delrin or perhaps even a hard "machinable" wood like walnut or oak. Bob . . . 'lectric Bob, What a scheme! I appreciate the work and creativity, but not too sure I am up to it. I would have to check with my inspector about the reliability design factors - I see him Friday night so will broach the subject. How do you find these tidbits? Having a couple of productive buddies may prove the answer as am 'way behind and have had to move the project up to the hangar this week as family events will demand the 'factory' back to a bedroom. Perhaps between us we can come up with a couple of samples. Thanks again for your diligence. It's always an eye-opener.......... Hugs to Dr. Dee Ferg ________________________________________________________________________________
Date: Aug 08, 2007
> I'm still searching for that elusive device - in an attempt to avoid > the cost of an ampere or two of contactor current - which will control a > primary battery source and another for secondary battery source. > I have found several which meet one criterion or another, but not > all: > [a] should carry as much current as a contactor for that job; > [b] needs to be an up-down rather than rotary type switch; > [c] should be on a remote(able) stalk so I can undo the connection to > remove the instrument panel ; > [d] cost less than the usual contactor - or at least be competitive. > I have devised a system to isolate the controls from wandering > fingers so am not fussy about security. I'm not sure what a "Kill switch" is > really. Any help would be most appreciated. Ferg, As Bob says you can build one. but I suggest Flaming River's push-pull battery switch. Not cheap but you won't have to build it. If you want to build one, get a scrap type-70 or similar contactor, toss the coil and use the parts. You can buy high current contacts too, although you can buy silver and make contacts that will do the job for this application. Don't neglect the patents online at USPTO. Search high current switch, etc. and see how people did it. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=128076#128076 ________________________________________________________________________________
Date: Aug 08, 2007
From: "Walter Fellows" <walter.fellows(at)gmail.com>
There are some diagrams on spacing you may find useful in the Tony Bingelis book Sportplane Construction Techniques available from EAA. On 8/7/07, Scott R. Shook wrote: > > Greetings, > > I have lurked in the AeroElectric list for a while and I am coming to > point in my project where I am going to be planning and building my > electrical system. I am looking at 12 circuit breakers (spare the groans) > in a 3 x 4 configuration. > > Would anyone be willing to send a photo or many photos of how would one go > about making a copper bus bar for a configuration like that where the > breakers are not inline? > > Also, what are you doing to insulate the bus bar against accidental > contact with a ground? > > Thank you, > > *** * > > *Scott R. Shook* > > *RV-7A (Building)* > > *N696JS (Reserved)* > > * > > > * > > ________________________________________________________________________________
Date: Aug 08, 2007
> >Clever design. I guess the operating cable is non conductive, or did I >miss something? >Paul The conventional Bowden push-pull control is obviously metallic. I'd probably drill the slider and fit a full length plastic insulator tubing down the hole and craft insulator washers for each end that would isolate the wire from the slider. There's a variety of ways to consider for attaching the wire . . . but your observations concerning the need for insulation are correct. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2007
Eric Jones had a neat design for such a device. Contact him at _emjones(at)charter.net_ (mailto:emjones(at)charter.net) . Stan Sutterfield >Cheers, > I'm still searching for that elusive device - in an attempt to avoid >the cost of an ampere or two of contactor current - which will control a >primary battery source and another for secondary battery source. > I have found several which meet one criterion or another, but not >all: >[a] should carry as much current as a contactor for that job; >[b] needs to be an up-down rather than rotary type switch; >[c] should be on a remote(able) stalk so I can undo the connection to >remove the instrument panel ; >[d] cost less than the usual contactor - or at least be competitive. > I have devised a system to isolate the controls from wandering >fingers so am not fussy about security. I'm not sure what a "Kill switch" is >really. > Any help would be most appreciated. Ferg, Why not build one? You need to support two 5/16" brass studs on an insulating material, say 1/8" thick fiberglass/epoxy sheet. Taper switch ends of studs to provide a spherical tip with about 1/8th inch radius. Mount studs just far enough apart to allow connection with fat-wires . . . about 1" would probably do. Build box on terminal board to capture a brass "slider" (3/8" square stock) that is pressed against stud tips with spring loading from back side. You could rig a Bowden control cable to operate the slide (you need about 1/2 to 3/4" stroke) for making and breaking the switch. This seems like a project that could be crafted with common hand tools. The end product would be on the order of 3" long, 1.5" wide and perhaps 2" deep. Perfect the design and we'll do an article on it for the website. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Avionics Stack width
Date: Aug 08, 2007
I've measured a few items now and have found some discrepancy in dimensions. What is the supposed standard panel opening for avionics ?? In the case of a slide in unit utilizing a tray, this would be the outside width of the tray. Second, what is the supposed standard slide-in width ?? In the same case, this would be the inside opening width of the tray; of the outside width of the avionics unit. Thanks !!! Larry E. James Bellevue, WA Super Decathlon Rocket (fuselage / systems) ________________________________________________________________________________
Date: Aug 08, 2007
Scott, If you haven't already considered it, a 20 slot fuse block is easier and cheaper to setup than breakers. Use a breaker for the alternator and main buss, but as Bob would say, you can only reset those expensive critters once - after that you already have a problem. Install the fuse block where it's accessible to easily change the fuses but not ugly and you'll have more panel space for other goodies. You'll also have hundreds of dollars left over from not buying breakers. If you are dead set on cb's I think the list has already donated some nice examples. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: Tuesday, August 07, 2007 5:28 PM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Circuit Breaker Bus Bar Greetings, I have lurked in the AeroElectric list for a while and I am coming to point in my project where I am going to be planning and building my electrical system. I am looking at 12 circuit breakers (spare the groans) in a 3 x 4 configuration. Would anyone be willing to send a photo or many photos of how would one go about making a copper bus bar for a configuration like that where the breakers are not inline? Also, what are you doing to insulate the bus bar against accidental contact with a ground? Thank you, Scott R. Shook RV-7A (Building) N696JS (Reserved) ________________________________________________________________________________
Date: Aug 08, 2007
Subject: Re: Avionics Stack width
Good Afternoon Larry, Ever since the "Glover Box" radios appeared in the late forties, the standard width was considered to be six and one quarter inches for us light plane types. Unfortunately, it seems that some have fattened up a bit so that it now seems better to plan on six and five sixteenths of an inch. If your box is skinny, you can always add washer or two, but if they are on the fat side, it is hard to fix. In any case, it is best to measure the actual units. Some of them will give a dimension to within one one thousandth of an inch, but when you measure them, as you have noted, there can be a fifty thousandth error. Once again , measure the actual box if at all possible! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 8/8/2007 2:55:06 P.M. Central Daylight Time, larry(at)ncproto.com writes: I=99ve measured a few items now and have found some discrepancy in di mensions. What is the supposed standard panel opening for avionics ?? In the case o f a slide in unit utilizing a tray, this would be the outside width of the tray. Second, what is the supposed standard slide-in width ?? In the same case, this would be the inside opening width of the tray; of the outside wi dth of the avionics unit. Thanks !!! Larry E. James Bellevue, WA Super Decathlon Rocket (fuselage / systems) t http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 08, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Old Bob is right...I measured my stack ( A PS engineering Audio panel and the rest Garmin) and cut a 6.25" hole in the panel. Frank RV 7a ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com Sent: Wednesday, August 08, 2007 1:30 PM Subject: Re: AeroElectric-List: Avionics Stack width Good Afternoon Larry, Ever since the "Glover Box" radios appeared in the late forties, the standard width was considered to be six and one quarter inches for us light plane types. Unfortunately, it seems that some have fattened up a bit so that it now seems better to plan on six and five sixteenths of an inch. If your box is skinny, you can always add washer or two, but if they are on the fat side, it is hard to fix. In any case, it is best to measure the actual units. Some of them will give a dimension to within one one thousandth of an inch, but when you measure them, as you have noted, there can be a fifty thousandth error. Once again, measure the actual box if at all possible! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 8/8/2007 2:55:06 P.M. Central Daylight Time, larry(at)ncproto.com writes: I've measured a few items now and have found some discrepancy in dimensions. What is the supposed standard panel opening for avionics ?? In the case of a slide in unit utilizing a tray, this would be the outside width of the tray. Second, what is the supposed standard slide-in width ?? In the same case, this would be the inside opening width of the tray; of the outside width of the avionics unit. Thanks !!! Larry E. James Bellevue, WA Super Decathlon Rocket (fuselage / systems) ________________________________ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . ________________________________________________________________________________
Date: Aug 08, 2007
> > >Robert L. Nuckolls, III wrote: >> >> Here's a rough layout of a possible design >> >>http://aeroelectric.com/Catalog/AEC/9042/9042-100.pdf >> >> The brass stock, parts and spring-stud are McMaster catalog >> items. Side brackets can be aluminum sheet or extrusion. >> Insulating material could be Delrin or perhaps even a >> hard "machinable" wood like walnut or oak. >> >> Bob . . . >What a cool idea. This looks like it would be a fun project, Bob. The >only thing I would change would be to make the slider a square piece and >arrange it so that it contacts both taper switch ends at the same time. >I know this real smart guy that taught me that contactors have multiple >break points in order to break the arc faster. This isn't a contactor. It's a low velocity, sliding contact switch that depends on PRESSURE at the contact locations to achieve low resistance connection. This is a low voltage (12v) low current (10A or less) SWITCHING task that must handle 200+ amps only after the switch is static in the close position. >With a couple more of those spring-studs, it should be possible to make >the slider pop off the switch ends at a much higher rate. Just arrange a >few on both sides of the switch ends so that the slider is cantilevered >away when it is slid out, but hits the springs and pushed against the >contacts when slid in. This borrows from some very old technology - the knife switch. See: http://www.aeroelectric.com/Pictures/Switches/knife_switch_1.jpg http://www.aeroelectric.com/Pictures/Switches/knife_switch_2.jpg Two pressure dependent contacts to one moving part. Operating velocity is not critical but good connection in the pressure joints is. Hence two spring-studs to maintain force against the slider . . . flat surface against a spherical surface. VERY LOW contact area, HIGH pressure. >Dang!! I'm gonna have to make one now. Right after I finish building >several more earbud headsets. I'll never get airplane finished at this >rate (but, I will have the coolest contactor in the universe!!). >Ernest (Is anyone else having this much fun?) This is properly called a SPST switch. The drawing is intended to be a door-opener for individuals who would like to expend some effort and acquire some real-time, hands-on experience. At the same time, it offers at least one compact solution to the remotely controlled, zero draw battery switch. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 08, 2007
> > > > I'm still searching for that elusive device - in an attempt to avoid > > the cost of an ampere or two of contactor current - which will control a > > primary battery source and another for secondary battery source. > > I have found several which meet one criterion or another, but not > > all: > > [a] should carry as much current as a contactor for that job; > > [b] needs to be an up-down rather than rotary type switch; > > [c] should be on a remote(able) stalk so I can undo the connection to > > remove the instrument panel ; > > [d] cost less than the usual contactor - or at least be competitive. > > I have devised a system to isolate the controls from wandering > > fingers so am not fussy about security. I'm not sure what a "Kill > switch" is > > really. Any help would be most appreciated. > > >Ferg, > >As Bob says you can build one. but I suggest Flaming River's push-pull >battery switch. Not cheap but you won't have to build it. > >If you want to build one, get a scrap type-70 or similar contactor, toss >the coil and use the parts. The type-70 is a low pressure, large area design where it's not clear to me how one would utilize the components . . . http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1c.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1d.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1e.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1f.jpg and craft a manually operated mechanism to achieve remote control. > You can buy high current contacts too, although you can buy silver and > make contacts that will do the job for this application. If one were seeking to craft a high cycle SWITCHING device, higher quality contacts would be useful as would some design philosophy that achieves minimum bounce on closure and rapid contact spreading velocity. In the case of a battery contactor, going beyond the requirement to occasionally SWITCH 10A and occasionally CARRY 200A in a once-per flight-cycle operation seems to have a poor return on infestment for the effort. >Don't neglect the patents online at USPTO. Search high current switch, >etc. and see how people did it. Good idea . . . but keep in mind that most designs are at least attempting to improve on an existing design that exhibits less than ideal service life or performance as a kilo-operations switch working at or near max ratings. For our purposes, a wrench used to connect the battery terminal before flight and disconnect at the end of flight would have more than adequate electrical performance. The design goals here are to achieve convenient manual remote control, light weight, small size and use materials and techniques readily available to the greatest number of interested builders. I.e., the elegant solution. Bob . . . ________________________________________________________________________________
From: "Peter Harris" <peterjfharris(at)bigpond.com>
Date: Aug 09, 2007
Bob If you remove the circlip and fit a bolt threaded to engage at the bottom, it could be used to pull the circular contactor down to engage with the copper terminals. Insulate where required. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, 9 August 2007 9:10 AM Subject: Re: AeroElectric-List: Re: BATTERY MASTER SWITCH > > > > I'm still searching for that elusive device - in an attempt to avoid > > the cost of an ampere or two of contactor current - which will control a > > primary battery source and another for secondary battery source. > > I have found several which meet one criterion or another, but not > > all: > > [a] should carry as much current as a contactor for that job; > > [b] needs to be an up-down rather than rotary type switch; > > [c] should be on a remote(able) stalk so I can undo the connection to > > remove the instrument panel ; > > [d] cost less than the usual contactor - or at least be competitive. > > I have devised a system to isolate the controls from wandering > > fingers so am not fussy about security. I'm not sure what a "Kill > switch" is > > really. Any help would be most appreciated. > > >Ferg, > >As Bob says you can build one. but I suggest Flaming River's push-pull >battery switch. Not cheap but you won't have to build it. > >If you want to build one, get a scrap type-70 or similar contactor, toss >the coil and use the parts. The type-70 is a low pressure, large area design where it's not clear to me how one would utilize the components . . . http://www.aeroelectric.com/Pictures/Contactors/S701-1a.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1b.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1c.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1d.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1e.jpg http://www.aeroelectric.com/Pictures/Contactors/S701-1f.jpg and craft a manually operated mechanism to achieve remote control. > You can buy high current contacts too, although you can buy silver and > make contacts that will do the job for this application. If one were seeking to craft a high cycle SWITCHING device, higher quality contacts would be useful as would some design philosophy that achieves minimum bounce on closure and rapid contact spreading velocity. In the case of a battery contactor, going beyond the requirement to occasionally SWITCH 10A and occasionally CARRY 200A in a once-per flight-cycle operation seems to have a poor return on infestment for the effort. >Don't neglect the patents online at USPTO. Search high current switch, >etc. and see how people did it. Good idea . . . but keep in mind that most designs are at least attempting to improve on an existing design that exhibits less than ideal service life or performance as a kilo-operations switch working at or near max ratings. For our purposes, a wrench used to connect the battery terminal before flight and disconnect at the end of flight would have more than adequate electrical performance. The design goals here are to achieve convenient manual remote control, light weight, small size and use materials and techniques readily available to the greatest number of interested builders. I.e., the elegant solution. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2007
Subject: Re: Manual Battery Switch Project
>'lectric Bob, > What a scheme! I appreciate the work and creativity, but not too sure I am >up to it. I would have to check with my inspector about the reliability >design factors - I see him Friday night so will broach the subject. Reliability should not be an issue. The classic master-switch/ battery-contactor has no published reliability statistics. I.e., and MTBF "calculation" would be so fraught with assumptions as to make the exercise meaningless. Even if you purchased a manufactured manual battery switch, there's no data to allow a quantified comparison between the legacy switch/contactor combination versus a manually operated substitute. At the same time, (repeat after me) "WE craft failure tolerant systems." I.e., we KNOW that the legacy contactors have failed at inopportune times for thousands of airplane owners and we've crafted a plan-B to comfortably accommodate a battery switch failure whether it's the traditional switch/contactor approach or a manual switch. >How do you find these tidbits? Having a couple of productive buddies may >prove the >answer as am 'way behind and have had to move the project up to the hangar >this week as family events will demand the 'factory' back to a bedroom. >Perhaps between us we can come up with a couple of samples. I have all the materials in the shop to craft this switch and access to the machine tools necessary to do a really "professional looking" job. However, it would be nice if I could demonstrate a fabrication process that used nothing more exotic than a table or band saw, a 1" vertical belt sander and a drill press. It would be a fun comic book to do. Unfortunately, I've got a ton of things on my plate right now . . . but who knows. > Thanks again for your diligence. It's always an eye-opener.......... >Hugs to Dr. Dee Thank you sir. I'll pass along your compliments. Bob . . . ________________________________________________________________________________
Subject: Mr. Nuckolls
Date: Aug 08, 2007
Bob, We didn't get (or I missed) a report on your Dad. I hope the news was better. Terry ________________________________________________________________________________
Subject: Vertical Power transcends on Z-19
Date: Aug 08, 2007
Bob, Just wanted to get your opinion of the integration of Z-19 and Vertical Powers' V-200 unit. I believe they are charging about 10k for that package. Do you feel there is enough valued added integrity there to substantiate that investment? It seems to me that Z-19 already has enough robustness built into the design. VP does perform some fancy automation stuff, but that becomes personal rather an integral to the system. I will be using an external EIS 4000 which is married to the Subaru and provides all necessary engine parameters. The V-200 supports just a few of the Subaru engine functions at this time - more planned for 2008. http://www.verticalpower.com/docs/VP_Z-19.pdf ________________________________________________________________________________
Date: Aug 08, 2007
> > >Bob >If you remove the circlip and fit a bolt threaded to engage at the bottom, >it could be used to pull the circular contactor down to engage with the >copper terminals. Insulate where required. >Peter Not sure what you mean. The motion in this device is longitudinal to the "slider", I.e., a Bowden wire coming in from the left would be used to move the slider such that it disengages from the left-hand stud only. The motion is not intended to emulated the actions of a contactor. There's no circlip in the assembly as illustrated. Only two fixed terminal studs with spherical ends and a brass-slide bar held against the studs with spring loaded balls from underneath. The spring-studs are threaded so that the pressure and spring-travel can be adjusted. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2007
Subject: Re: Vertical Power transcends on Z-19
> >Bob, > Just wanted to get your opinion of the integration of Z-19 and >Vertical Powers' V-200 unit. I believe they are charging about 10k for >that package. Do you feel there is enough valued added integrity there >to substantiate that investment? It seems to me that Z-19 already has >enough robustness built into the design. VP does perform some fancy >automation stuff, but that becomes personal rather an integral to the >system. I will be using an external EIS 4000 which is married to the >Subaru and provides all necessary engine parameters. The V-200 supports >just a few of the Subaru engine functions at this time - more planned >for 2008. Return on investment is a decision you'll have to make. What are your proposed design goals for incorporating the system? Are you wanting to save time? How would the time "saved" be put to better use in the conduct of your flight? What's the cost of ownership? Is there risk that you'll spend more money over your ownership of the airplane such that you're going to come out money ahead for compared to not having incorporated the system? I have no doubts that the product performs as advertised (or will if any bugs are detected). The questions to be asked and answered have to be based on perception of performance or hazard shortfall for not having used this system to replace the traditional hardware and techniques. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 08, 2007
Subject: RE: Manual Battery Master Switch
Based on the number of on and off-List comments I'm getting on the proposed design, it's apparent that some folks are not understanding the operation of the device. I've updated the drawing at: http://www.aeroelectric.com/Catalog/AEC/9042/9042-100.pdf to show the Bowden control and insulation necessary to complete the manual battery switch system. Bob . . . ________________________________________________________________________________
Date: Aug 09, 2007
Bob I was referring to the first of the pics you sent showing a type 70 contactor open for inspection. It could be used by manually actuating the movement with the use of a bolt. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Thursday, 9 August 2007 2:05 PM Subject: RE: AeroElectric-List: Re: BATTERY MASTER SWITCH > > >Bob >If you remove the circlip and fit a bolt threaded to engage at the bottom, >it could be used to pull the circular contactor down to engage with the >copper terminals. Insulate where required. >Peter Not sure what you mean. The motion in this device is longitudinal to the "slider", I.e., a Bowden wire coming in from the left would be used to move the slider such that it disengages from the left-hand stud only. The motion is not intended to emulated the actions of a contactor. There's no circlip in the assembly as illustrated. Only two fixed terminal studs with spherical ends and a brass-slide bar held against the studs with spring loaded balls from underneath. The spring-studs are threaded so that the pressure and spring-travel can be adjusted. Bob . . . ________________________________________________________________________________
Subject: Manual Battery Switch Project
Date: Aug 09, 2007
8/9/2007 Bob Nuckolls wrote: "Reliability should not be an issue. The classic master-switch/ battery-contactor has no published reliability statistics. I.e., and MTBF "calculation" would be so fraught with assumptions as to make the exercise meaningless......skip....." and "At the same time, (repeat after me) "WE craft failure tolerant systems." I.e., we KNOW that the legacy contactors have failed at inopportune times for thousands of airplane owners and we've crafted a plan-B to comfortably accommodate a battery switch failure whether it's the traditional switch/contactor approach or a manual switch." Precisely on target. I personally am aware of three contactor failures within the last year. One nearly new, presently available, commonly used type, and two decades older ones built by SBC. Two were battery contactors and one was a starter contactor. I have rewired my plane a bit accordingly. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ________________________________________________________________________________
Date: Aug 09, 2007
> > >Bob I was referring to the first of the pics you sent showing a type 70 >contactor open for inspection. >It could be used by manually actuating the movement with the use of a bolt. >Peter Aha! Understand. Interestingly enough, there have been products offered in the distant past that allowed for manual operation of this style of contactor. I helped some folks find a suitable replacement for a contactor much like the Model 70 on a Lockheed Lodestar. The contactor they took off was much like the Model 70 except it had a non-metalic push-button protruding from a hole in the top cap that allowed one to push the plunger assembly down manually. I suppose one could use modified guts of a Model 70 to craft a manual switch but it would not be my process of choice. The contactor is a large area, relatively low pressure connection device that would be more prone to failure due to contamination and/or corrosion. Once opened for the purpose of converting to manual operations, then we've exposed the innards to the environment which opens opportunities for unintended consequences for service life. As folks follow this thread, please keep in mind that in no way are we suggesting that one launch into any sort of modification to their stock battery contactor of any make. Nor are we suggesting that it's even desirable to replace the electro-mechanical contactor with a purely mechanical switch. This is an exercise in crafting a light, compact, ZERO POWER switch capable of reasonably convenient control by push-pull Bowden cable. It's a design study for specific cases (airplanes fitted with small alternators). We KNOW that battery contactors of any pedigree can, do and will fail at some point in time. In my never humble opinion, it's far better to craft a plan-b to comfortably mitigate such failures than to modify manufactured parts or spend a lot of $time$ crafting our own, one-of-a-kind, manual switch. Until someone has crafted what they believe is a part that meets the zero-power, remote-controlled design goal then all of the foregoing is simply an academic exercise to consider the options. No generalized recommendations to depart from what's published in the Z-figures or elsewhere should be inferred. Bob . . . ________________________________________________________________________________
Date: Aug 09, 2007
> >8/9/2007 > >Precisely on target. I personally am aware of three contactor failures >within the last year. One nearly new, presently available, commonly used >type, and two decades older ones built by SBC. Two were battery contactors >and one was a starter contactor. If one goes into the repair records of aircraft in existence, there are no doubt dozens of failures every week . . . and all of those aircraft went to the shop for replacement from which we may infer that the failure did not produce a "smoking-hole" event. While your assertions concerning numbers of observed failures are no doubt correct, we should be careful that we do not read meaning into those assertions that cannot be directly quantified into fleet-wide risk. Anecdotal data are often useful but should with caution. For example, I could say that I'm aware of dozens of sidewall failures in tires and then offer a follow-on assertion as to how I reacted to that information. Now, if I was observing the flow of flat tires into a tire-store, and the dozens of sidewall failures were but 1/2 percent of all failures, then perhaps the sense of urgency to craft an alternative philosophy for the use of tires. >I have rewired my plane a bit accordingly. As I recall you're working with a TC aircraft. How did you rewire your airplane? Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 09, 2007
In a message dated 8/9/2007 9:53:26 A.M. Central Daylight Time, nuckollsr(at)cox.net writes: Aha! Understand. Interestingly enough, there have been products offered in the distant past that allowed for manual operation of this style of contactor. I helped some folks find a suitable replacement for a contactor much like the Model 70 on a Lockheed Lodestar. The contactor they took off was much like the Model 70 except it had a non-metalic push-button protruding from a hole in the top cap that allowed one to push the plunger assembly down manually. For What It Is Worth, When I was a lad, Ford automobiles had a plunger on their starter contactor that allowed us to actuate the starter manually. There was no way to open the contactor if it was stuck closed, but if the electrical activation option was not operative, we could spin over the engine by pushing on the plunger. Obviously, the battery had to be sound. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 09, 2007
For the sake of complete disclosure, there are multiple versions of the Vertical Power product. The 10K version is slated primarily for a dual buss, dual alternator environment. There are also other versions for $6495 and 3495 as well. These are slated for less complex environments and also have differing feature sets. Here's a very complete version of the 2 major product lines, the VP-200 comes in a single Control Unit and Dual Control unit version (the latter is the 10K priced version). http://www.verticalpower.com/features.html Hope this helps further, I should have mine flying in the next couple of months and I just can't wait. I know it's hard to think about it as something different than just a wiring solution, but there is so much more capability to the product, it really is better positioned as a Smart Aircraft Management system.... But I'll let you all make your own decision... Btw, I'm doing a VP-200 Duo in a 24v dual alt, dual batt system. Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com Sent: Wednesday, August 08, 2007 10:18 PM Subject: AeroElectric-List: Vertical Power transcends on Z-19 Bob, Just wanted to get your opinion of the integration of Z-19 and Vertical Powers' V-200 unit. I believe they are charging about 10k for that package. Do you feel there is enough valued added integrity there to substantiate that investment? It seems to me that Z-19 already has enough robustness built into the design. VP does perform some fancy automation stuff, but that becomes personal rather an integral to the system. I will be using an external EIS 4000 which is married to the Subaru and provides all necessary engine parameters. The V-200 supports just a few of the Subaru engine functions at this time - more planned for 2008. http://www.verticalpower.com/docs/VP_Z-19.pdf ________________________________________________________________________________
Date: Aug 09, 2007
My mistake, I had no idea that the phrase that I thot I had made up was actually another product. Vertical Power in no way, to the best of my knowledge, is associated with Smart Aircraft Management Systems or their product line. The owner of SAMS requested that I post a clarification, which I'll quickly do. www.smartaircraftsystems.com Guess, you learn something every day... My apologies, Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Alan Adamson Sent: Thursday, August 09, 2007 3:10 PM Subject: RE: AeroElectric-List: Vertical Power transcends on Z-19 --> For the sake of complete disclosure, there are multiple versions of the Vertical Power product. The 10K version is slated primarily for a dual buss, dual alternator environment. There are also other versions for $6495 and 3495 as well. These are slated for less complex environments and also have differing feature sets. Here's a very complete version of the 2 major product lines, the VP-200 comes in a single Control Unit and Dual Control unit version (the latter is the 10K priced version). http://www.verticalpower.com/features.html Hope this helps further, I should have mine flying in the next couple of months and I just can't wait. I know it's hard to think about it as something different than just a wiring solution, but there is so much more capability to the product, it really is better positioned as a Smart Aircraft Management system.... But I'll let you all make your own decision... Btw, I'm doing a VP-200 Duo in a 24v dual alt, dual batt system. Alan -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com Sent: Wednesday, August 08, 2007 10:18 PM Subject: AeroElectric-List: Vertical Power transcends on Z-19 Bob, Just wanted to get your opinion of the integration of Z-19 and Vertical Powers' V-200 unit. I believe they are charging about 10k for that package. Do you feel there is enough valued added integrity there to substantiate that investment? It seems to me that Z-19 already has enough robustness built into the design. VP does perform some fancy automation stuff, but that becomes personal rather an integral to the system. I will be using an external EIS 4000 which is married to the Subaru and provides all necessary engine parameters. The V-200 supports just a few of the Subaru engine functions at this time - more planned for 2008. http://www.verticalpower.com/docs/VP_Z-19.pdf ________________________________________________________________________________
Date: Aug 09, 2007
Subject: Re: Mr. Nuckolls
> > >Bob, > >We didn't get (or I missed) a report on your Dad. I hope the news was >better. > >Terry After 83 years of gracefully playing the cards dealt to him, Dad cashed out in peace and comfort about 10 days ago. It was time and he was ready. Dr. Dee and I were with him at the end. He left us with many admirable goals and recipes for success. He will be missed but will live on in all those who learned from him. Thanks for asking. See: http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf Bob . . . ________________________________________________________________________________
Date: Aug 09, 2007
In a message dated 8/9/2007 8:07:45 P.M. Eastern Standard Time, nuckollsr(at)cox.net writes: http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf I am sorry for your loss. I also had a dad from the greatest generation, who survived and thrived under circumstances that intimidate me. I lack your eloquence, but share your pride and sorrow. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 09, 2007
In a message dated 8/9/2007 9:07:47 P.M. Eastern Daylight Time, nuckollsr(at)cox.net writes: http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf Dear Bob, I read about your Dad's passing. I also read the biography that you wrote. He seemed like quite a guy. One I wouldn't of minded knowing. Please accept our sympathy's Tom & Sandy Saccio http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 09, 2007
Bob, Thank you for sharing this with us. Your love for this very special man is quite moving. Maurice Fitzgerald ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 09, 2007 7:06 PM Subject: Re: AeroElectric-List: Mr. Nuckolls > > > >> >> >> >>Bob, >> >>We didn't get (or I missed) a report on your Dad. I hope the news was >>better. >> >>Terry > > After 83 years of gracefully playing the cards dealt > to him, Dad cashed out in peace and comfort about 10 > days ago. It was time and he was ready. Dr. Dee and > I were with him at the end. He left us with many > admirable goals and recipes for success. He will > be missed but will live on in all those who learned > from him. Thanks for asking. > > See: > > http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 09, 2007
Subject: P-mag to VM-1000C tach signal
I've been trying to get my Vision Microsystems VM-1000C to read the RPM pul ses coming from my P-mag ignition. After much testing, here is where I am: =0A =0ATesting the ignition separately with an oscilloscope determined that it is putting out a 5V pulse with a 4ms duration. The bottom of the pulse (baseline) is at ground. Some of the pulses are slightly distorted on the b ack end, but I don't think that should matter.=0A =0ATesting the VM-1000C s eparately with the scope and a frequency generator determined that it corre ctly counts pulses as long as the bottom of the pulse (baseline) is within 300mv of ground. If the bottom of the pulse gets higher than this, the VM-1 000C doesn't see it.=0A =0AHowever... When I connect the ignition to the VM -1000C and watch both of them together with the scope, I see that the VM-10 00C raises the baseline of the ignition output from 0V to 2.7V. This is obv iously way too high for it to count, and the RPM indicator thus reads zero. =0A =0AThe ignition people suggested putting a 0.47 microfarad capacitor in series between the ignition and the VM-1000C in an attempt to move the bot tom of the pulse closer to ground. However, the capacitor actually raised t he bottom of the pulse from 2.7V to 4.8V. That obviously doesn't help.=0A =0ACan anyone offer me any guidance here? Something in the VM-1000C appears to be raising the baseline of the tach signal and preventing the pulses fr om being counted because they never get close enough to ground.=0A =0APleas e reference these images from the scope:=0A=0Ahttp://home.comcast.net/~n70g e/end_images/Ign.jpg shows the ignition output by itself.=0A=0Ahttp://home. comcast.net/~n70ge/end_images/ignvms.jpg shows the ignition output when con nected to the VM-1000C.=0A=0Ahttp://home.comcast.net/~n70ge/end_images/ignv mscap.jpg shows the ignition output connected to the VM-1000C through the c apacitor.=0A =0AThere must be a simple fix for this...=0A=0AThanks,=0A=0A-G eoff=0A=0ARV-8 ready to fly for the first time once I get this bug fixed=0A =0A=0A =0A___________________________________________________________ _________________________=0ABe a better Heartthrob. Get better relationship nswers.yahoo.com/dir/?link=list&sid=396545433 ________________________________________________________________________________
Date: Aug 10, 2007
Bob,=0A=0AThat is one heck of a tribute. I am terribly sorry for your loss , but I am eternally grateful that this man was with us to inspire family a nd friends.=0A=0ASincerely,=0ARich=0A=0A----- Original Message ----=0AFrom: "Robert L. Nuckolls, III" =0ATo: aeroelectric-list@matr onics.com=0ASent: Thursday, August 9, 2007 10:06:06 PM=0ASubject: Re: AeroE "Robert L. Nuckolls, III" =0A=0AAt 05:37 PM 8/8/2007 -0 n" =0A>=0A>=0A>Bob,=0A>=0A>We didn't get (or I missed) a report on your Dad. I hope the news was=0A>better.=0A>=0A>Terry=0A=0A A fter 83 years of gracefully playing the cards dealt=0A to him, Dad cashed out in peace and comfort about 10=0A days ago. It was time and he was re ady. Dr. Dee and=0A I were with him at the end. He left us with many=0A admirable goals and recipes for success. He will=0A be missed but will l ive on in all those who learned=0A from him. Thanks for asking.=0A=0A S ee:=0A=0Ahttp://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr ============ ________________________________________________________________________________
From: Michael W Stewart <mike.stewart(at)us.ibm.com>
Date: Aug 10, 2007
Bob, So sorry for your loss. Thanks for the great reading tribute to your da d. You should know that even from afar, with people you have never met, yo u have extended his reach to many with your years of teaching to us. I read this list every day, always in amazement at what I learn, and yo ur patience and focus to teach us. While I still smoke a wire and blow a a fuse now and again from poor technique, Im always striving to find out why and fix it. Voices of Bob in my head from all the readings. Keep it sim ple, put in what you need for good reasons whose risk reward can be articula ted, and enjoy the fruits of my labor. I enjoy the fruits of my labor nearly every day on my plane, whose electrons whizzing about are supporting my lifes great pleasure. And wh en im in the soup, and its dark and lonely, im confident my whiz bang stuf f will keep alive to get me home each time cause Ive paid good attention to this list and your techniques over the years. Your dads teachings live on and spread far and wide for us here, and my kids at home. Thanks for all you do. Here's to your dad. Cheers. Mike Stewart "Robert L. Nuckolls, III" aeroelectric-list(at)matronics.com Sent by: cc owner-aeroelectri c-list-server@mat Subj ect ronics.com Re: AeroElectric-List: Mr. Nucko lls 08/09/2007 10:06 PM Please respond to aeroelectric-list @matronics.com > > >Bob, > >We didn't get (or I missed) a report on your Dad. I hope the news was >better. > >Terry After 83 years of gracefully playing the cards dealt to him, Dad cashed out in peace and comfort about 10 days ago. It was time and he was ready. Dr. Dee and I were with him at the end. He left us with many admirable goals and recipes for success. He will be missed but will live on in all those who learned from him. Thanks for asking. See: http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf Bob . . . ======================== ============ ======================== ============ ======================== ============ ________________________________________________________________________________
From: "Terry Miles" <terrence_miles(at)hotmail.com>
Date: Aug 10, 2007
Bob I join my sentiments to you and to yours with so many others, Bob. I sorry to hear of this. I lost my own father many, many years ago. I was an electrician by trade.and I still miss him. Terry Miles _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of TSaccio(at)aol.com Sent: Thursday, August 09, 2007 11:01 PM Subject: Re: AeroElectric-List: Mr. Nuckolls In a message dated 8/9/2007 9:07:47 P.M. Eastern Daylight Time, nuckollsr(at)cox.net writes: http://aeroelectric.com/articles/In_Memory_of_Robert_L_Nuckolls_Jr.pdf Dear Bob, I read about your Dad's passing. I also read the biography that you wrote. He seemed like quite a guy. One I wouldn't of minded knowing. Please accept our sympathy's Tom & Sandy Saccio _____ AOL.com. ________________________________________________________________________________
Date: Aug 10, 2007
8/10/2007 Hello Bob Nuckolls, You wrote: "As I recall you're working with a TC aircraft. How did you rewire your airplane?" Thank you for your follow up interest -- amazing memory considering the many subjects that you deal with just on this list alone. The TC aircraft was my friend's 24 volt system Beech Sierra that suffered first an SBC9401 (-?) black plastic case, base mounted, starter contactor failure then within a year an SBC 9401 (-?) black plastic case, base mounted, main battery contactor failure. (Both of these contactors had just the number 9401 stamped on them even though the starter contactor was supposed to be a 9401-1). After much flailing around, false starts, wrong part ordering, and research, the starter contactor was replaced with a metal case, side mounted, Eaton Aerospace Controls Division, P/N 6041H190 intermittent duty contactor. The main battery contactor was replaced with a metal case, side mounted, Eaton Aerospace Controls Division, P/N 6041H189 continuous duty contactor. The Beechcraft Aeroclub community and Beechcraft itself is largely ignorant and bereft of documentation on both the fact that two different types (intermittent versus continuous duty) of contactors are preferred / required for these two installations and how the mounting method conversion and wiring is to be accomplished. To date I have not located any Beechcraft documentation on how one is supposed to change either the physical mounting or the wiring from the base mounted to the side mounted contactors so the local A&P is forced to just wing it. I haven't given up entirely on trying to wring some further information on this subject from Beech. Also the original SBC contactors had a confusing, unmarked array of TVS devices attached and it is unclear just how the local FBO handled the installation of any replacement TVS devices. (I am only allowed to "help" to a certain extent on this TC aircraft that is FBO maintained.) My comment about rewiring my plane a bit referred to my amateur built experimental airplane. After my hangar mate suffered a fairly new main battery contactor failure I moved my transponder electrical power source from the main avionics bus to the essential avionics bus so that I could have transponder power for "get home" operation within the Washington DC ADIZ. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: The few pages of Sierra wiring diagrams that you emailed to me a while back were absolutely essential in helping to understand the aircraft's contactor situation -- many thanks again. ----------------------------------- RESPONDING TO ----------------- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Subject: Re: AeroElectric-List: Manual Battery Switch Project > >8/9/2007 > >Precisely on target. I personally am aware of three contactor failures >within the last year. One nearly new, presently available, commonly used >type, and two decades older ones built by SBC. Two were battery contactors >and one was a starter contactor. If one goes into the repair records of aircraft in existence, there are no doubt dozens of failures every week . . . and all of those aircraft went to the shop for replacement from which we may infer that the failure did not produce a "smoking-hole" event. While your assertions concerning numbers of observed failures are no doubt correct, we should be careful that we do not read meaning into those assertions that cannot be directly quantified into fleet-wide risk. Anecdotal data are often useful but should with caution. For example, I could say that I'm aware of dozens of sidewall failures in tires and then offer a follow-on assertion as to how I reacted to that information. Now, if I was observing the flow of flat tires into a tire-store, and the dozens of sidewall failures were but 1/2 percent of all failures, then perhaps the sense of urgency to craft an alternative philosophy for the use of tires. >I have rewired my plane a bit accordingly. As I recall you're working with a TC aircraft. How did you rewire your airplane? Bob . . . ________________________________________________________________________________
Date: Aug 10, 2007
Subject: Re: P-mag to VM-1000C tach signal
Makes me think you need a better ground between the mag and the VM unit - sounds like a floating ground issue. Capacitor won't work, dodn't know why they suggested that. You could build a separate transistor based trigger circuit, but you shouldn't have to. Check your ground carefully and don't rely on the air frame. I'd use a separate large copper wire between the two bobf On 8/10/07, Geoff Evans wrote: > > I've been trying to get my Vision Microsystems VM-1000C to read the RPM > pulses coming from my P-mag ignition. After much testing, here is where I > am: > Testing the ignition *separately* with an oscilloscope determined that > it is putting out a 5V pulse with a 4ms duration. The bottom of the pulse > (baseline) is at ground. Some of the pulses are slightly distorted on the > back end, but I don't think that should matter. > > Testing the VM-1000C *separately* with the scope and a frequency generator > determined that it correctly counts pulses as long as the bottom of the > pulse (baseline) is within 300mv of ground. If the bottom of the pulse gets > higher than this, the VM-1000C doesn't see it. > > However... When I connect the ignition to the VM-1000C and watch *both of > them together* with the scope, I see that the VM-1000C raises the baseline > of the ignition output from 0V to 2.7V. This is obviously way too high for > it to count, and the RPM indicator thus reads zero. > > The ignition people suggested putting a 0.47 microfarad capacitor in > series between the ignition and the VM-1000C in an attempt to move the > bottom of the pulse closer to ground. However, the capacitor actually raised > the bottom of the pulse from 2.7V to 4.8V. That obviously doesn't help. > > Can anyone offer me any guidance here? Something in the VM-1000C appears > to be raising the baseline of the tach signal and preventing the pulses from > being counted because they never get close enough to ground. > > Please reference these images from the scope: > > http://home.comcast.net/~n70ge/end_images/Ign.jpg shows the ignition > output by itself. > > http://home.comcast.net/~n70ge/end_images/ignvms.jpg shows the ignition > output when connected to the VM-1000C. > > http://home.comcast.net/~n70ge/end_images/ignvmscap.jpg shows the ignition > output connected to the VM-1000C through the capacitor. > > There must be a simple fix for this... > > Thanks, > > -Geoff > > RV-8 ready to fly for the first time once I get this bug fixed > > ------------------------------ > Ready for /body> > > ________________________________________________________________________________
Date: Aug 10, 2007
I don't think the 0.47 uF cap is right either. There may be a simple way to fix this thing. The P-mag people should know. But failing all that, I have just finished a little circuit to convert 0-14.2V to 0.20 to 1.35 V to feed the R.A.C. bar graph indicator. The circuit uses one LM324 quad op amp. One of the op amps is configured as a non-inverting summing amplifier where Vout is the sum of V1+V2-V3-V4. This makes it simple to manipulate the output with small voltage dividers using the other op amps as buffers. PCBs are available. Email me offline. Additionally, for those with a tacho frequency problem, I have designed a tiny device that converts 3 ppr to 1.5 ppr and maintains pulse width. PCBs are available. Email me offline. See attached. "Everything you've learned in school as "obvious" becomes less and less obvious as you begin to study the universe. For example, there are no solids in the universe. There's not even a suggestion of a solid. There are no absolute con- tinuums. There are no surfaces. There are no straight lines." - R. Buckminster Fuller -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=128457#128457 ________________________________________________________________________________
Date: Aug 10, 2007
Subject: North to Alaska . . .
Dr. Dee and I are getting into the big iron bird this afternoon to travel to Anchorage Alaska for a weekend seminar. We've tacked a few days on the end for some goof-off time too. We'll be back on the List next Thursday. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 10, 2007
>I've been trying to get my Vision Microsystems VM-1000C to read the RPM >pulses coming from my P-mag ignition. After much testing, here is where I am: > >Testing the ignition separately with an oscilloscope determined that it is >putting out a 5V pulse with a 4ms duration. The bottom of the pulse >(baseline) is at ground. Some of the pulses are slightly distorted on the >back end, but I don't think that should matter. > >Testing the VM-1000C separately with the scope and a frequency generator >determined that it correctly counts pulses as long as the bottom of the >pulse (baseline) is within 300mv of ground. If the bottom of the pulse >gets higher than this, the VM-1000C doesn't see it. > >However... When I connect the ignition to the VM-1000C and watch both of >them together with the scope, I see that the VM-1000C raises the baseline >of the ignition output from 0V to 2.7V. This is obviously way too high for >it to count, and the RPM indicator thus reads zero. > >The ignition people suggested putting a 0.47 microfarad capacitor in >series between the ignition and the VM-1000C in an attempt to move the >bottom of the pulse closer to ground. However, the capacitor actually >raised the bottom of the pulse from 2.7V to 4.8V. That obviously doesn't help. > >Can anyone offer me any guidance here? Something in the VM-1000C appears >to be raising the baseline of the tach signal and preventing the pulses >from being counted because they never get close enough to ground. > >Please reference these images from the scope: > ><http://home.comcast.net/~n70ge/end_images/Ign.jpg>http://home.comcast.net/~n70ge/end_images/Ign.jpg >shows the ignition output by itself. > ><http://home.comcast.net/~n70ge/end_images/ignvms.jpg>http://home.comcast.net/~n70ge/end_images/ignvms.jpg >shows the ignition output when connected to the VM-1000C. > ><http://home.comcast.net/~n70ge/end_images/ignvmscap.jpg>http://home.comcast.net/~n70ge/end_images/ignvmscap.jpg >shows the ignition output connected to the VM-1000C through the capacitor. > >There must be a simple fix for this... Without knowing more about the input-output characteristics of the two systems, I'll have to wag it a bit. Sounds like a classic dc-restoration problem reminiscent of the TV sync separator designs many moons ago. Take a peek at: http://www.aeroelectric.com/Pictures/Schematics/p-Mag_VM-1000_Interface.JPG I'm fairly certain that the first circuit will work but is more complex in that it requires power. The second circuit may work and I'd try that first. If this doesn't get you running, I'll contact P-mag and VM to see if we can take a more predictable approach knowing the details of their input and output circuits. Bob . . . ________________________________________________________________________________
Date: Aug 10, 2007
Bob wrote: Without knowing more about the input-output characteristics of the two systems, I'll have to wag it a bit. Sounds like a classic dc-restoration problem reminiscent of the TV sync separator designs many moons ago. Take a peek at: http://www.aeroelectric.com/Pictures/Schematics/p-Mag_VM-1000_Interface.JPG I'm fairly certain that the first circuit will work but is more complex in that it requires power. The second circuit may work and I'd try that first. If this doesn't get you running, I'll contact P-mag and VM to see if we can take a more predictable approach knowing the details of their input and output circuits. Bob . . . ========= After explaining all of this to Tom from E-mag, he (correctly) figured out that the tach pulse input line on the VM-1000C is biased hi (+5V). According to Tom, I have an older (1.5 years) version of the P-mag circuit board that uses a resistor to drive the baseline of the pulse to ground, and it doesn't work when connected to an instrument that is biased hi. Newer versions of the P-mag circuit boards use an opto-isolator instead of a resistor to drive baseline of the pulse to ground. This newer board also has a configurable option called "open collector mode" that, in conjunction with the opto-isolator, should make this whole setup work properly. At least that's what Tom thinks, anyway. Later today I got an email from an engineer at Vision (JPI). He confirmed that the tach input line was biased hi, and he suggested this circuit to fix it if the ignition couldn't be made compatible: http://home.comcast.net/~n70ge/end_images/Electronic_Ignition_Interface.pdf. This circuit is slightly different than the ones you drew, Bob, but I assume it has the same function. Is that correct? Alternatively, Tom from E-mag suggested using a TTL 7404 driver chip if the upgrade to the P-mag board doesn't work. Thank for your help.. I can troubleshoot somewhat and throw around big electronic words, but I'm certainly no circuit designer... Interestingly enough, the drawing I linked to above from JPI is titled "Electronic Ignition Interface to EDM900/930/950/VM1000/VM1000C". If all of those instruments are biased hi on the input line, I wonder why this problem hasn't come up before with other instrument and/or ignition combinations. -Geoff http://smallbusiness.yahoo.com/webhosting ________________________________________________________________________________
Subject: solenoids relays contactors & Aunt Min
Date: Aug 11, 2007
Ancient Robert: "When I was a lad, Ford automobiles had a plunger on their starter contactor that allowed us to actuate the starter manually. There was no way to open the contactor if it was stuck closed, but if the electrical activation option was not operative, we could spin over the engine by pushing on the plunger. Obviously, the battery had to be sound. Happy Skies, Old Bob" When I was lad, we didn't have a car, we had streetcar tickets though. On the other hand, Aunt Minnie (yup) had a Ford A and I think she stamped on the floor to flog the little engine into life. Do you suppose that itty bump was the top of a mechanical contactor? Ferg ________________________________________________________________________________
Date: Aug 12, 2007
Subject: GPS/XM antenna interference
At an OSH forum it was recommended to not locate active antennas(ae?) next to each other as their active electronics could degrade or corrupt data from them. I've been unable to find any such restrictions in the installation information provided with the equipment which includes GNS430W, GRT Dual Horizons with XM satellite and internal GPS, Trutrak ADI with it's own GPS, for a total of 3 GPS antennas(ae?) and one XM receiver. I'd like to mount these on a common shelf at the top of the firewall under the cowl. Each antenna appears to have a simple coaxial connection which tells me little of it's "active" capability or if these are simple (non-active) devices, although I know the antenna for the 430W is a dedicated unit (not same as non-W unit). The antenna for the ADI is a Laipac Tech model GLP1. Before I contact the various suppliers tomorrow, does anyone have any actual experience with this or know of any installation requirements/recommended practices for these devices, or is this more Urban Legend? Mark Phillips (with apologies for posting to multiple lists!) http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 12, 2007
I believe that the issue is a little more complicated. There are really 2 types of antennas. One that just has a pre-amp in it - these are mostly for GPS receivers, and then the XM type antennas - these not only have a pre-amp installed, but also have a full communications receiver in them. Even receivers are basically little transmitters with LO frequencies that may "mix" with other active antennas. Either in the pre-amp or the RX that may be included in the antenna. This MIX may cause interference with the RX'rs ability to decode the signal that they are intended for and so the signal may be degraded. At 2.4Ghz, these wave lengths are pretty small so locating item at least 1 wave length apart shouldn't be too difficult. What I wouldn't do it stack or locate them so they were touching in any way. The farther apart the better just to be safe. Alan _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com Sent: Sunday, August 12, 2007 2:06 PM Subject: AeroElectric-List: GPS/XM antenna interference At an OSH forum it was recommended to not locate active antennas(ae?) next to each other as their active electronics could degrade or corrupt data from them. I've been unable to find any such restrictions in the installation information provided with the equipment which includes GNS430W, GRT Dual Horizons with XM satellite and internal GPS, Trutrak ADI with it's own GPS, for a total of 3 GPS antennas(ae?) and one XM receiver. I'd like to mount these on a common shelf at the top of the firewall under the cowl. Each antenna appears to have a simple coaxial connection which tells me little of it's "active" capability or if these are simple (non-active) devices, although I know the antenna for the 430W is a dedicated unit (not same as non-W unit). The antenna for the ADI is a Laipac Tech model GLP1. Before I contact the various suppliers tomorrow, does anyone have any actual experience with this or know of any installation requirements/recommended practices for these devices, or is this more Urban Legend? Mark Phillips (with apologies for posting to multiple lists!) _____ AOL.com. ________________________________________________________________________________
Date: Aug 12, 2007
Subject: Seminar in Anchorage
Hello, I just had the pleasure of being involved in one of Bob Nuckolls' seminars. It was a great event and worth every penny. If you ever have the opportunity to attend one of these seminars, do it. Blue Skies, Mike Ice Anchorage, Alaska ________________________________________________________________________________
Date: Aug 12, 2007
Subject: Re: Seminar in Anchorage
In a message dated 8/12/2007 9:35:52 P.M. Central Daylight Time, aurbo(at)ak.net writes: Hello, I just had the pleasure of being involved in one of Bob Nuckolls' seminars. It was a great event and worth every penny. If you ever have the opportunity to attend one of these seminars, do it. Blue Skies, Mike Ice Anchorage, Alaska Been There, Done That!! I agree!!!! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Subject: Nav/com 'acoustic feedback'
Date: Aug 13, 2007
From: "Miskelly, Francis G" <f.miskelly(at)imperial.ac.uk>
The KX155 nav/com in my Glastar has 2 problems which may be related. 1. Inserting the headphone jack i have near perfect reception. However, when i insert the microphone jack there is a loud whine suggestive of 'acoustic feedback'. Moving the boom away from my mouth reduces the whine. With a different headset it appears as lots of static noise which again changes with position of the boom. I've changed the aerial, power supply and checked all the earths. It occurs with either mag and when the generator is disconnected. It only happens when the engine is running. The radio's been bench tested and passed as good. 2. Radio reception is good with just the headphone jack inserted. However, insert the microphone jack and reception becomes very poor or disappears completely. I suspect the 'acoustic feedback' is raising the automatic squelch which is cutting off the radio station Can anyone suggest an explanation and a solution! Many thanks Frank ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Headset plug polarity
Date: Aug 13, 2007
I am amazed at the difficulty in finding the polarity on the internet. Can someone help me here? What should be the polarity of the sleeve, ring, and tip on a stereo plug? Which, ring or tip, is probably right and which is probably left on the stereo plug? Also what should be the polarity of the sleeve and tip on the mono plug. How should I wire a stereo receptacle so that it could be used for both stereo or mono? Thanks, Bill B ________________________________________________________________________________
Subject: Re: Headset plug polarity
Date: Aug 13, 2007
My first thought was to quickly reply, but my information is off the top of my head and may not be correct. My recommendation is to check your headset manufacturer's web site or give them a call. I'm sure in a couple minutes you would have an answer. My guess would have be tip-right, ring-left, sleeve-ground. On a mono plug, the tip has the signal and the sleeve is the ground. > > From: "Bill Bradburry" <bbradburry(at)bellsouth.net> > Date: 2007/08/13 Mon AM 07:57:05 EST > To: > Subject: AeroElectric-List: Headset plug polarity > > > I am amazed at the difficulty in finding the polarity on the internet. Can > someone help me here? > > What should be the polarity of the sleeve, ring, and tip on a stereo plug? > Which, ring or tip, is probably right and which is probably left on the > stereo plug? > > Also what should be the polarity of the sleeve and tip on the mono plug. > > How should I wire a stereo receptacle so that it could be used for both > stereo or mono? > > Thanks, > Bill B > > > > > ________________________________________________________________________________
Date: Aug 13, 2007
Subject: Re: Nav/com 'acoustic feedback'
Miskelly, Francis G wrote: > The KX155 nav/com in my Glastar has 2 problems which may be related. > > 1. Inserting the headphone jack i have near perfect reception. > However, when i insert the microphone jack there is a loud whine > suggestive of 'acoustic feedback'. Moving the boom away from my mouth > reduces the whine. With a different headset it appears as lots of > static noise which again changes with position of the boom. I've > changed the aerial, power supply and checked all the earths. It occurs > with either mag and when the generator is disconnected. It only > happens when the engine is running. The radio's been bench tested and > passed as good. > > 2. Radio reception is good with just the headphone jack inserted. > However, insert the microphone jack and reception becomes very poor or > disappears completely. I suspect the 'acoustic feedback' is raising > the automatic squelch which is cutting off the radio station > > Can anyone suggest an explanation and a solution! > Many thanks > Frank Since there is a problem with multiple headset, I would check the jack first. The symptoms seem to imply some feedback from the mic to the audio. Look for a short or a broken ground. Beyond that, it would seem circuitry withing the intercom is fritzed, and it gets much more complicated. ________________________________________________________________________________
Date: Aug 13, 2007
At 05:57 8/13/2007, you wrote: > > >I am amazed at the difficulty in finding the polarity on the internet. Can >someone help me here? > >What should be the polarity of the sleeve, ring, and tip on a stereo plug? >Which, ring or tip, is probably right and which is probably left on the >stereo plug? "Standards" have evolved and changed over the years, and not every manufacturer follows them anyway, and draftsmen frequently don't know or care how a jack is drawn and get it wrong. From the audio world: Tip Right Ring Left Sleeve Common PS-Engineering, and others, agree. >Also what should be the polarity of the sleeve and tip on the mono plug. Tip hot Sleeve Common >How should I wire a stereo receptacle so that it could be used for both >stereo or mono? There isn't any really good, safe and easy way and the method selected would properly be dependent on what the signal source is, and how well it may or may not be fault protected. With two broken wrists in casts, I'm typing challenged. Perhaps others can elaborate. Ron Q. >Thanks, >Bill B ________________________________________________________________________________
Date: Aug 13, 2007
Thanks for your comments Ernest. I've double-checked all the grounds i could find. Even took the whole harness out (which was new) and had it double-checked. Nothing found. If its the intercom in the radio why does it not cause the same problem when the engine is off? It only causes the problem when the engine is running Kind regards Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest Christley Sent: Mon 13/08/2007 15:04 Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' Miskelly, Francis G wrote: > The KX155 nav/com in my Glastar has 2 problems which may be related. > > 1. Inserting the headphone jack i have near perfect reception. > However, when i insert the microphone jack there is a loud whine > suggestive of 'acoustic feedback'. Moving the boom away from my mouth > reduces the whine. With a different headset it appears as lots of > static noise which again changes with position of the boom. I've > changed the aerial, power supply and checked all the earths. It occurs > with either mag and when the generator is disconnected. It only > happens when the engine is running. The radio's been bench tested and > passed as good. > > 2. Radio reception is good with just the headphone jack inserted. > However, insert the microphone jack and reception becomes very poor or > disappears completely. I suspect the 'acoustic feedback' is raising > the automatic squelch which is cutting off the radio station > > Can anyone suggest an explanation and a solution! > Many thanks > Frank Since there is a problem with multiple headset, I would check the jack first. The symptoms seem to imply some feedback from the mic to the audio. Look for a short or a broken ground. Beyond that, it would seem circuitry withing the intercom is fritzed, and it gets much more complicated. ________________________________________________________________________________
Date: Aug 13, 2007
Miskelly, Francis G wrote: > Thanks for your comments Ernest. > I've double-checked all the grounds i could find. Even took the whole harness out (which was new) and had it double-checked. Nothing found. > If its the intercom in the radio why does it not cause the same problem when the engine is off? > It only causes the problem when the engine is running > Kind regards > Frank > > Where is your squelch set at? ________________________________________________________________________________
Date: Aug 13, 2007
Ernest, Your response kind of points to what I was thinking.. I don't think the KX155 has any intercom, but the description of the symptoms seem like an intercom problem. If so, I wonder if turning off the intercom aleviates the behavior. If there isn't any intercom, then I might suspect the radio has a problem. Plugging in the mic shouldn't have any effect until the PTT circuitry is activated, but then you wouldn't get _any_ reception (because the transmitter would be active).. If the problem is related to the intercom, consider trying to find a way to adjust the mic gain on the intercom. Regards, Matt- > > > Miskelly, Francis G wrote: >> The KX155 nav/com in my Glastar has 2 problems which may be related. >> >> 1. Inserting the headphone jack i have near perfect reception. >> However, when i insert the microphone jack there is a loud whine >> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >> reduces the whine. With a different headset it appears as lots of >> static noise which again changes with position of the boom. I've >> changed the aerial, power supply and checked all the earths. It occurs >> with either mag and when the generator is disconnected. It only >> happens when the engine is running. The radio's been bench tested and >> passed as good. >> >> 2. Radio reception is good with just the headphone jack inserted. >> However, insert the microphone jack and reception becomes very poor or >> disappears completely. I suspect the 'acoustic feedback' is raising >> the automatic squelch which is cutting off the radio station >> >> Can anyone suggest an explanation and a solution! >> Many thanks >> Frank > Since there is a problem with multiple headset, I would check the jack > first. The symptoms seem to imply some feedback from the mic to the > audio. Look for a short or a broken ground. Beyond that, it would seem > circuitry withing the intercom is fritzed, and it gets much more > complicated. > > ________________________________________________________________________________
Date: Aug 13, 2007
Subject: Re: LCD
Rumen, I would like to have it. Let me know the shipping to ZIP 33190. Thanks, Ed. Sadler http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 13, 2007
Does it help if you cover the mic with your hand (both sides - pull the muff off)? I suspect that the input stage of your intercom is being overdriven by the acoustic noise of the engine. Regards, Matt- > Thanks for your comments Ernest. > I've double-checked all the grounds i could find. Even took the whole > harness out (which was new) and had it double-checked. Nothing found. > If its the intercom in the radio why does it not cause the same problem > when the engine is off? > It only causes the problem when the engine is running > Kind regards > Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest > Christley > Sent: Mon 13/08/2007 15:04 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Miskelly, Francis G wrote: >> The KX155 nav/com in my Glastar has 2 problems which may be related. >> >> 1. Inserting the headphone jack i have near perfect reception. >> However, when i insert the microphone jack there is a loud whine >> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >> reduces the whine. With a different headset it appears as lots of >> static noise which again changes with position of the boom. I've >> changed the aerial, power supply and checked all the earths. It occurs >> with either mag and when the generator is disconnected. It only >> happens when the engine is running. The radio's been bench tested and >> passed as good. >> >> 2. Radio reception is good with just the headphone jack inserted. >> However, insert the microphone jack and reception becomes very poor or >> disappears completely. I suspect the 'acoustic feedback' is raising >> the automatic squelch which is cutting off the radio station >> >> Can anyone suggest an explanation and a solution! >> Many thanks >> Frank > Since there is a problem with multiple headset, I would check the jack > first. The symptoms seem to imply some feedback from the mic to the > audio. Look for a short or a broken ground. Beyond that, it would seem > circuitry withing the intercom is fritzed, and it gets much more > complicated. > > ________________________________________________________________________________
Date: Aug 13, 2007
Subject: Z-20 System
Hi All, I'm getting ready for the electrical system in my zenith 601XL with a Jabiru 3300. I'm trying to keep things simple and am thinking about going with the Z-20 Small Jabiru System. That diagram switches the main bus thru the Master switch instead of a battery contactor. Whats the practical cutoff in terms of current for using a contactor vs routing directly thru the switch. Any downside to adding a contactor to this plan ? Any upsides ? Any issues with the Z-20 plan ? Thanks, John Davis Burnsville, NC ________________________________________________________________________________
Date: Aug 13, 2007
Matt 1. When i cover the mic with my hand (muff off) the character of the feedback alters significantly but is not overall reduced. If i move the boom away from my mouth and around to the back of my head then the feedback reduces but doesn't disappear. Its worse (louder) the closer the boom to my mouth. These symptoms occur on both left and right hand headsets 2. My KX155 has an internal intercom. I haven't tried to disconnect it. 3. Plugging in the mic jack should activate the intercom and the transmit on the radio (when PTT pressed) 4. Remember the problem only occurs when the engine is running. 5. Does anyone know how to adjust the mic gain (intercom volume control) on the KX155? Couldn't find this info in the installation manual. Kind regards Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather Sent: Mon 13/08/2007 20:12 Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' Does it help if you cover the mic with your hand (both sides - pull the muff off)? I suspect that the input stage of your intercom is being overdriven by the acoustic noise of the engine. Regards, Matt- > Thanks for your comments Ernest. > I've double-checked all the grounds i could find. Even took the whole > harness out (which was new) and had it double-checked. Nothing found. > If its the intercom in the radio why does it not cause the same problem > when the engine is off? > It only causes the problem when the engine is running > Kind regards > Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest > Christley > Sent: Mon 13/08/2007 15:04 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Miskelly, Francis G wrote: >> The KX155 nav/com in my Glastar has 2 problems which may be related. >> >> 1. Inserting the headphone jack i have near perfect reception. >> However, when i insert the microphone jack there is a loud whine >> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >> reduces the whine. With a different headset it appears as lots of >> static noise which again changes with position of the boom. I've >> changed the aerial, power supply and checked all the earths. It occurs >> with either mag and when the generator is disconnected. It only >> happens when the engine is running. The radio's been bench tested and >> passed as good. >> >> 2. Radio reception is good with just the headphone jack inserted. >> However, insert the microphone jack and reception becomes very poor or >> disappears completely. I suspect the 'acoustic feedback' is raising >> the automatic squelch which is cutting off the radio station >> >> Can anyone suggest an explanation and a solution! >> Many thanks >> Frank > Since there is a problem with multiple headset, I would check the jack > first. The symptoms seem to imply some feedback from the mic to the > audio. Look for a short or a broken ground. Beyond that, it would seem > circuitry withing the intercom is fritzed, and it gets much more > complicated. > > ________________________________________________________________________________
Date: Aug 13, 2007
Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see the manual says it has 500ohm aux inputs, but don't see any reference to intercom. We're talking about a Bendix/King KX-155, right? Do you have a link to a file which describes the feature? Does the sound vary depending on where your head/headset is sitting, or by bending the wires around on the headset, or the wires to the jack? Is the frequency of the whine/feedback dependent on the engine RPM? Or is it just a steady tone? I agree with item 3 (assuming an intercom). Regards, Matt- > Matt > 1. When i cover the mic with my hand (muff off) the character of the > feedback alters significantly but is not overall reduced. If i move the > boom away from my mouth and around to the back of my head then the > feedback reduces but doesn't disappear. Its worse (louder) the closer the > boom to my mouth. These symptoms occur on both left and right hand > headsets > 2. My KX155 has an internal intercom. I haven't tried to disconnect it. > 3. Plugging in the mic jack should activate the intercom and the transmit > on the radio (when PTT pressed) > 4. Remember the problem only occurs when the engine is running. > 5. Does anyone know how to adjust the mic gain (intercom volume control) > on the KX155? Couldn't find this info in the installation manual. > Kind regards > Frank > > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt > Prather > Sent: Mon 13/08/2007 20:12 > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Does it help if you cover the mic with your hand (both sides - pull the > muff off)? > > I suspect that the input stage of your intercom is being overdriven by the > acoustic noise of the engine. > > > Regards, > > Matt- > >> Thanks for your comments Ernest. >> I've double-checked all the grounds i could find. Even took the whole >> harness out (which was new) and had it double-checked. Nothing found. >> If its the intercom in the radio why does it not cause the same problem >> when the engine is off? >> It only causes the problem when the engine is running >> Kind regards >> Frank >> >> ________________________________ >> >> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest >> Christley >> Sent: Mon 13/08/2007 15:04 >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' >> >> >> >> >> >> Miskelly, Francis G wrote: >>> The KX155 nav/com in my Glastar has 2 problems which may be related. >>> >>> 1. Inserting the headphone jack i have near perfect reception. >>> However, when i insert the microphone jack there is a loud whine >>> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >>> reduces the whine. With a different headset it appears as lots of >>> static noise which again changes with position of the boom. I've >>> changed the aerial, power supply and checked all the earths. It occurs >>> with either mag and when the generator is disconnected. It only >>> happens when the engine is running. The radio's been bench tested and >>> passed as good. >>> >>> 2. Radio reception is good with just the headphone jack inserted. >>> However, insert the microphone jack and reception becomes very poor or >>> disappears completely. I suspect the 'acoustic feedback' is raising >>> the automatic squelch which is cutting off the radio station >>> >>> Can anyone suggest an explanation and a solution! >>> Many thanks >>> Frank >> Since there is a problem with multiple headset, I would check the jack >> first. The symptoms seem to imply some feedback from the mic to the >> audio. Look for a short or a broken ground. Beyond that, it would seem >> circuitry withing the intercom is fritzed, and it gets much more >> complicated. >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 13, 2007
At 14:29 8/13/2007, you wrote: >Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see >the manual says it has 500ohm aux inputs, but don't see any reference to >intercom. We're talking about a Bendix/King KX-155, right? Do you have a >link to a file which describes the feature? I do find a reference in the IM for a 155A/165A to an intercom level adjustment. Is this an A model? Ron Q ________________________________________________________________________________
Subject: emagair recommendation against Nuckoll's wiring schematic?
Date: Aug 13, 2007
Bob et al: Recent postings on the Vans Airforce site (see posts #44-47 at www.tiny.cc/bb2oY) indicate that the folks at emagair do not want us to use the wiring method suggested for their product in your schematics (I fo rget the Z#). The logic for your schematic made sense to me, so I used it a nd dont want to re-do now unless there is a good reason. Could I impose o n you to talk the fine folks at Emagair and get to the bottom of this? Im not sure I understand the issue and Im sure you will have more insights an d better questions for them than I can come up with. Thank you - Lookin g forward to your response. Erich Weaver ________________________________________________________________________________
Date: Aug 14, 2007
1. The radio is a Bendix/King KX155 2. It is approximately 1 year old. Don't know the model # but could find out 3. It definately has an internal intercom but i've no links to describe it 4. I didn't check whether the sound varied depending on where your head/headset is sitting, or by bending the wires around on the headset, or the wires to the jack but it occurred with 3 separate headsets and on both pilot and co-pilot outputs. Pretty sure its not a headset problem as same headsets work fine in other planes 5. The noise gets worse with higher engine RPM but is very obvious even at 1000 RPM. The character doesn't change - just its loudness Many thanks Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather Sent: Mon 13/08/2007 22:29 Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see the manual says it has 500ohm aux inputs, but don't see any reference to intercom. We're talking about a Bendix/King KX-155, right? Do you have a link to a file which describes the feature? Does the sound vary depending on where your head/headset is sitting, or by bending the wires around on the headset, or the wires to the jack? Is the frequency of the whine/feedback dependent on the engine RPM? Or is it just a steady tone? I agree with item 3 (assuming an intercom). Regards, Matt- > Matt > 1. When i cover the mic with my hand (muff off) the character of the > feedback alters significantly but is not overall reduced. If i move the > boom away from my mouth and around to the back of my head then the > feedback reduces but doesn't disappear. Its worse (louder) the closer the > boom to my mouth. These symptoms occur on both left and right hand > headsets > 2. My KX155 has an internal intercom. I haven't tried to disconnect it. > 3. Plugging in the mic jack should activate the intercom and the transmit > on the radio (when PTT pressed) > 4. Remember the problem only occurs when the engine is running. > 5. Does anyone know how to adjust the mic gain (intercom volume control) > on the KX155? Couldn't find this info in the installation manual. > Kind regards > Frank > > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt > Prather > Sent: Mon 13/08/2007 20:12 > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Does it help if you cover the mic with your hand (both sides - pull the > muff off)? > > I suspect that the input stage of your intercom is being overdriven by the > acoustic noise of the engine. > > > Regards, > > Matt- > >> Thanks for your comments Ernest. >> I've double-checked all the grounds i could find. Even took the whole >> harness out (which was new) and had it double-checked. Nothing found. >> If its the intercom in the radio why does it not cause the same problem >> when the engine is off? >> It only causes the problem when the engine is running >> Kind regards >> Frank >> >> ________________________________ >> >> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest >> Christley >> Sent: Mon 13/08/2007 15:04 >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' >> >> >> >> >> >> Miskelly, Francis G wrote: >>> The KX155 nav/com in my Glastar has 2 problems which may be related. >>> >>> 1. Inserting the headphone jack i have near perfect reception. >>> However, when i insert the microphone jack there is a loud whine >>> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >>> reduces the whine. With a different headset it appears as lots of >>> static noise which again changes with position of the boom. I've >>> changed the aerial, power supply and checked all the earths. It occurs >>> with either mag and when the generator is disconnected. It only >>> happens when the engine is running. The radio's been bench tested and >>> passed as good. >>> >>> 2. Radio reception is good with just the headphone jack inserted. >>> However, insert the microphone jack and reception becomes very poor or >>> disappears completely. I suspect the 'acoustic feedback' is raising >>> the automatic squelch which is cutting off the radio station >>> >>> Can anyone suggest an explanation and a solution! >>> Many thanks >>> Frank >> Since there is a problem with multiple headset, I would check the jack >> first. The symptoms seem to imply some feedback from the mic to the >> audio. Look for a short or a broken ground. Beyond that, it would seem >> circuitry withing the intercom is fritzed, and it gets much more >> complicated. >> >> >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Aug 13, 2007
Subject: Re: emagair recommendation against Nuckoll's wiring
schematic? Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ----- Original Message ----- From: Erich_Weaver(at)URSCorp.com To: aeroelectric-list(at)matronics.com Sent: Monday, August 13, 2007 2:36 PM Subject: AeroElectric-List: emagair recommendation against Nuckoll's wiring schematic? Bob et al: Recent postings on the Vans Airforce site (see posts #44-47 at www.tiny.cc/bb2oY) indicate that the folks at emagair do not want us to use the wiring method suggested for their product in your schematics (I forget the Z#). The logic for your schematic made sense to me, so I used it and dont want to re-do now unless there is a good reason. Could I impose on you to talk the fine folks at Emagair and get to the bottom of this? Im not sure I understand the issue and Im sure you will have more insights and better questions for them than I can come up with. Thank you - Looking forward to your response. Erich Weaver ________________________________________________________________________________
Date: Aug 14, 2007
The squelch is set to off. Pulling out the volume control knob takes off the squelch. When i leave the squelch on there is virtually no radio reception at all. - Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest Christley Sent: Mon 13/08/2007 17:57 Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' Miskelly, Francis G wrote: > Thanks for your comments Ernest. > I've double-checked all the grounds i could find. Even took the whole harness out (which was new) and had it double-checked. Nothing found. > If its the intercom in the radio why does it not cause the same problem when the engine is off? > It only causes the problem when the engine is running > Kind regards > Frank > > Where is your squelch set at? ________________________________________________________________________________
schematic?
Date: Aug 14, 2007
WIRE PER THE MANUFACTURERS RECOMMENDATIONS!!! I respect Bob but why differ from what the manufactureres want. Bob's wiring should be in consultation with Brad and Tom. I wired per Emagair's instructions and have not had any wiring issues. The breakers provide the ability to isolate if necessary. When I had a mechanical failure of the Pmag (magnet came loose) I used the key switch to isolate and go to the good mag. I then cut the breaker also to the bad mag. During run up I use the keyed switch for the mag check. I don't do an idle check with the Pmags every flight. I did an initial install check to deteremine the cutoff RPM for each mag. My idle is set higher than the cutoff so I see no need to do idle check each run up. I'm not an electronics person but in talking to Brad I can see where a power interuption could potentially cause issues. I'm missing a point I was going to say but the bottomline, wire per the instructions and you'll be fine. Darwin N. Barrie Chandler AZ RV7 N717EE 2 Pmags 260+ hours ________________________________________________________________________________
Date: Aug 14, 2007
Subject: Emag Wiring
Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield _www.rv-8a.net_ (http://www.rv-8a.net) Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 14, 2007
Darwin Bob shares the Z-figures because he believes there is an advantage to t hem over "standard" methods. Im sure the Emagair wiring method works fine, but if all we ever did was to do what was done before, there would be no progress. If there is a real issue with Bob's schematics for emags/pma gs I am confident that he will want to know about it and either improve them or toss them, and at that point I will re-wire mine. I cant see any harm in having Bob get together with the fine folks at Emagair and then see wha t both have to say about the issue. I really kind of doubt this is that big of a deal. If others are in a hurry and concerned, by all means, go wi th the Emagair method. best regards erich ________________________________________________________________________________
Date: Aug 14, 2007
Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice _____ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . ________________________________________________________________________________
Date: Aug 14, 2007
Just to pass along my learnings- after contacting the techies at Garmin, Trutrak and GRT, none expressed any concerns or related any experiences where locating these antennas(ae?) next to each other would create any problems. None of the replies from the various lists indicated much of a problem either- at least no one identified any specific technical issues. Proceeding as planned- >From the Antenna Farm... Mark (again, apologies for multi-list posting!) http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 14, 2007
schematic? Darwin, I think I agree with your view point completely. What I am realizing though is that folks are wiring these mags all sorts of ways. I wonder if the lack of a common way to wire them has or is causing some of the troubles we read about? When it comes time to wire my e & p mags I will likely use the Emagair system. Mike ice ----- Original Message ----- From: Darwin N. Barrie To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 7:01 AM Subject: Re: AeroElectric-List: emagair recommendation against Nuckoll's wiring schematic? WIRE PER THE MANUFACTURERS RECOMMENDATIONS!!! I respect Bob but why differ from what the manufactureres want. Bob's wiring should be in consultation with Brad and Tom. I wired per Emagair's instructions and have not had any wiring issues. The breakers provide the ability to isolate if necessary. When I had a mechanical failure of the Pmag (magnet came loose) I used the key switch to isolate and go to the good mag. I then cut the breaker also to the bad mag. During run up I use the keyed switch for the mag check. I don't do an idle check with the Pmags every flight. I did an initial install check to deteremine the cutoff RPM for each mag. My idle is set higher than the cutoff so I see no need to do idle check each run up. I'm not an electronics person but in talking to Brad I can see where a power interuption could potentially cause issues. I'm missing a point I was going to say but the bottomline, wire per the instructions and you'll be fine. Darwin N. Barrie Chandler AZ RV7 N717EE 2 Pmags 260+ hours ________________________________________________________________________________
Date: Aug 14, 2007
Subject: Re: Emag Wiring
Stan, I agree with you that the guys at Emag want to keep their mags wired the way they designed them. It makes sense to me to follow their recommendations. I was just wondering out loud about the differences in the way Bob Nuckolls suggests and the Emag system. One thing I like about the AeroElectric ideas is the concept of reducing "parts count". More parts equals more possible trouble. But in this instance either system uses at least 2 switches for each P-mag, so it is a wash. I understand the need for the switch to shut off the power to the P-mag so you can check the internal alternator but why hide them? If you hide them will you need a warning light to tell you they are in one position or another? I have been thinking I might use a toggle switch with an LED light in the end of it. I sent you a personal email about float planes in Alaska, yes I do live in Anchorage, when your son gets up here tell him we have a good EAA Chapter www.eaa42.org . Mike Ice ----- Original Message ----- From: Speedy11(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 8:05 AM Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ------------------------------------------------------------------------------ ________________________________________________________________________________
Date: Aug 14, 2007
Erich, The AeroElectric z-33 figure shows the 2-10 switch being hooked up to P-mags using wire colors. I think that it would be better if the connector plug was numbered on those drawings. I agree, we should hope that Bob and Emag can get together and come up with a one size fits all, with a reduced parts count, and doesn't cause damage to the P-mags with and accidental push or flick of a switch. Mike ----- Original Message ----- From: Erich_Weaver(at)URSCorp.com To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 8:15 AM Subject: AeroElectric-List: Re: emagair recommendation against Nuckoll's wiring Darwin Bob shares the Z-figures because he believes there is an advantage to them over "standard" methods. Im sure the Emagair wiring method works fine, but if all we ever did was to do what was done before, there would be no progress. If there is a real issue with Bob's schematics for emags/pmags I am confident that he will want to know about it and either improve them or toss them, and at that point I will re-wire mine. I cant see any harm in having Bob get together with the fine folks at Emagair and then see what both have to say about the issue. I really kind of doubt this is that big of a deal. If others are in a hurry and concerned, by all means, go with the Emagair method. best regards erich ________________________________________________________________________________
Date: Aug 14, 2007
Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ------------------------------------------------------------------------- ----- href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Aeroelectric Connection Book
Date: Aug 15, 2007
Hi all Can anyone confirm if Bob is still active? I ordered his book over a month ago and received a confirmation email but have still not received the book in the mail. I've sent Bob a chaser via his web page but got no reply... 73 Phil Maley VK6AD Tripacer VH-OLD RV-7A under construction phil(at)vk6ad.net Perth Australia ________________________________________________________________________________
Date: Aug 15, 2007
His was at Oshkosh, then headed to Alaska for a seminar and vacation. His father also passed away recently. He's kept the list updated when he's away, so you can find more details in the archives. I would suspect that when he gets back in the office, he'll get caught up on everything. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Phil Maley Sent: Wednesday, August 15, 2007 1:34 AM Subject: AeroElectric-List: Aeroelectric Connection Book Hi all Can anyone confirm if Bob is still active? I ordered his book over a month ago and received a confirmation email but have still not received the book in the mail. I've sent Bob a chaser via his web page but got no reply... 73 Phil Maley VK6AD Tripacer VH-OLD RV-7A under construction phil(at)vk6ad.net Perth Australia __________ NOD32 2463 (20070815) Information __________ ________________________________________________________________________________
From: "David & Elaine Lamphere" <lamphere(at)vabb.com>
Date: Aug 15, 2007
Mike, Unless I have misunderstood the literature that came with my PMag and Emag, the "P-Lead" is used as a control signal to the ignition controller circuitry to shut off spark when it is grounded. It is NOT the main ground to the unit. The power and main ground are separate leads. Dave ----- Original Message ----- From: Michael T. Ice To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 11:45 PM Subject: Re: AeroElectric-List: Emag Wiring Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ------------------------------------------------------------------------- --- href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 15, 2007
Hi all Thanks to those who have replied. I haven't dealt with Bob before so was not familiar with his operation and not sure what to expect. Glad all is OK and very sorry to hear about his father. Best wishes to you all Phil Maley -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bob Leffler Sent: Wednesday, 15 August 2007 18:44 Subject: RE: AeroElectric-List: Aeroelectric Connection Book --> His was at Oshkosh, then headed to Alaska for a seminar and vacation. His father also passed away recently. He's kept the list updated when he's away, so you can find more details in the archives. I would suspect that when he gets back in the office, he'll get caught up on everything. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Phil Maley Sent: Wednesday, August 15, 2007 1:34 AM Subject: AeroElectric-List: Aeroelectric Connection Book Hi all Can anyone confirm if Bob is still active? I ordered his book over a month ago and received a confirmation email but have still not received the book in the mail. I've sent Bob a chaser via his web page but got no reply... 73 Phil Maley VK6AD Tripacer VH-OLD RV-7A under construction phil(at)vk6ad.net Perth Australia __________ NOD32 2463 (20070815) Information __________ ________________________________________________________________________________
Date: Aug 15, 2007
Indeed, it does help. Thanks for your experienced advice. Stan I hope this helps, regards, Peter http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 15, 2007
Subject: B&C SD 8 Alternator
Morning, Everyone... Now that I'm dumping all my remaining vacuum instruments (the one I have left!) and the associated pump and gauge, and settling for an all electric panel (except for the static gauges), I am starting to look at alternator options. I've kept up on the past discussions here, and Bob's Connection info, and have a pretty good idea of what's involved. But, I just noticed the B&C model SD-8 alternator that fits on the vacuum pump pad! What a great replacement for a gasket and a cover! I also see that Bob does mention it's use in one of his articles, but as a backup alternator. Seeing that the original Long Ez plans call out an alternator only as an option if you plan on IFR or night flying, or if you use a starter, and strongly recommend just the VariEZE solar panel to keep the battery charged, has anyone here installed the SD-8 and used it as the main unit. It only has a maximum 10 amp output, and a nominal 8 amp, but I would think that would be enough to keep the battery charged and operate the newer low current instruments quite well. I have yet to calculate my panel's consumption (don't have all the instruments yet), let alone the plane's, so it's still in the planning stage. Open to all suggestions. Redundancy is always best, but if one can save some weight and still do the job (I also have two P-mags with their own generators so the engine should keep running on the electronic ignition even if the battery and alternator go down) then I'm all for it. Harley Dixon Long EZ N28EZ Airport Hangar 29 Canandaigua, NY ________________________________________________________________________________
Subject: Re: Aeroelectric Connection Book
Date: Aug 15, 2007
Phil Bob is still active. He did a weekend seminar in Alaska and is taking some vacation time while there. Dean Van Winkle RV-9A Fuselage/FWF/Finish ----- Original Message ----- From: "Phil Maley" <phil(at)vk6ad.net> Sent: Wednesday, August 15, 2007 12:33 AM Subject: AeroElectric-List: Aeroelectric Connection Book > > Hi all > > Can anyone confirm if Bob is still active? I ordered his book over a month > ago and received a confirmation email but have still not received the book > in the mail. I've sent Bob a chaser via his web page but got no reply... > > 73 > Phil Maley VK6AD > Tripacer VH-OLD > RV-7A under construction > phil(at)vk6ad.net > Perth Australia > > > -- ________________________________________________________________________________
Date: Aug 15, 2007
Subject: Re: B&C SD 8 Alternator
Good Morning Harley, The B&C 20 ampere unit fits on the same pad. It is a bit heavier but it is also a more robust looking device. I am very electronically challenged, but I did install one of the twenty amp units on my airplane about ten years ago. Very happy with the result. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator Stearman N3977A Brookeridge Air Park LL22 Downers Grove, IL 60516 630 985-8503 In a message dated 8/15/2007 7:41:01 A.M. Central Daylight Time, harley(at)AgelessWings.com writes: But, I just noticed the B&C model SD-8 alternator that fits on the vacuum pump pad! What a great replacement for a gasket and a cover! http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 15, 2007
Dave, Thanks for the post. On the diagram I have there is no lead labeled Main ground, there is one labeled to ground on engine case. Is this one your calling the main ground? If so then I agree with you that the power and main ground are separate leads. In the instructions that I have for the e/p mags there is a diagram that shows the wiring sequence. On that diagram it shows a wire from the connector plug #4 that is labeled P-lead (Kill Switch). The other end of this wire shows that it is a ground with the same symbol used with the wire that goes to connector plug #1. Perhaps yours is different? Once again I am not putting down e/p mags. I just think (maybe wrongly) that there is some come confusion as to how to wire these mags. And perhaps I am the only one that is confused, wouldn't be the first time. Mike ----- Original Message ----- From: David & Elaine Lamphere To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 3:05 AM Subject: Re: AeroElectric-List: Emag Wiring Mike, Unless I have misunderstood the literature that came with my PMag and Emag, the "P-Lead" is used as a control signal to the ignition controller circuitry to shut off spark when it is grounded. It is NOT the main ground to the unit. The power and main ground are separate leads. Dave ----- Original Message ----- From: Michael T. Ice To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 11:45 PM Subject: Re: AeroElectric-List: Emag Wiring Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ------------------------------------------------------------------------- - href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 15, 2007
Mornin', Bob... I guess I didn't look far enough! Didn't see the 20 amp version! Now that looks like a winner...guess it pays to ask, doesn't it! Have to see if I have room for it on the Long between the firewall and the case, but at 6", it should fit. Otherwise, I like it. I see they have a couple of others as well...should have browsed B&Cs site before I started asking questions, I guess! Thanks for the heads up... Now, back to sealing my driveway today...... Harley Dixon Long EZ N28EZ Airport Hangar 29 Canandaigua, NY ------------------------------------------------------------------------ BobsV35B(at)aol.com wrote: > Good Morning Harley, > > The B&C 20 ampere unit fits on the same pad. It is a bit heavier but > it is also a more robust looking device. I am very electronically > challenged, but I did install one of the twenty amp units on my > airplane about ten years ago. Very happy with the result. > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > Stearman N3977A > Brookeridge Air Park LL22 > Downers Grove, IL 60516 > 630 985-8503 ________________________________________________________________________________
Date: Aug 15, 2007
Ok, here we go... page 20 in my documentation has pin 1 connected to engine case. Since the case is connected to the ground bus via a nice 4-8 gage flexible braided wire, it sure seems to me it's a main ground. Yes, pin 4 is the P-lead (kill switch) - this is to be connected to the ignition switch pin (L or R) where you would normally connect a mag. Notice that pin 5 is connected to +13.8vdc. This is what I would call main DC power. It really is very simple... Dave ----- Original Message ----- From: Michael T. Ice To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 10:02 AM Subject: Re: AeroElectric-List: Emag Wiring Dave, Thanks for the post. On the diagram I have there is no lead labeled Main ground, there is one labeled to ground on engine case. Is this one your calling the main ground? If so then I agree with you that the power and main ground are separate leads. In the instructions that I have for the e/p mags there is a diagram that shows the wiring sequence. On that diagram it shows a wire from the connector plug #4 that is labeled P-lead (Kill Switch). The other end of this wire shows that it is a ground with the same symbol used with the wire that goes to connector plug #1. Perhaps yours is different? Once again I am not putting down e/p mags. I just think (maybe wrongly) that there is some come confusion as to how to wire these mags. And perhaps I am the only one that is confused, wouldn't be the first time. Mike ----- Original Message ----- From: David & Elaine Lamphere To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 3:05 AM Subject: Re: AeroElectric-List: Emag Wiring Mike, Unless I have misunderstood the literature that came with my PMag and Emag, the "P-Lead" is used as a control signal to the ignition controller circuitry to shut off spark when it is grounded. It is NOT the main ground to the unit. The power and main ground are separate leads. Dave ----- Original Message ----- From: Michael T. Ice To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 11:45 PM Subject: Re: AeroElectric-List: Emag Wiring Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ------------------------------------------------------------------------ href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Subject: Emag Wiring
Date: Aug 15, 2007
Mike, I could probably have written a little more clearly. The object is to get one P-mag running on its internal generator (by removing busbar power), then cycle the other mag/P-mag to find out if the engine still runs (I wrote it the other way around). If the engine runs, the generator is good, if it does not generator is bad. So, probably the best sequence is 1. Carry out normal mag drop check to deduce "normal" mag drop. Bear in mind there will always be an rpm drop when only a P/E-mag is running, but that drop won't be as large as when only a magneto is running. 2. Shut off busbar power to one P-mag 3. Switch off/ground other mag/P-mag (so it is not producing sparks) 4. Observe engine behaviour. Rpm drop as in 1 above = everything working fine, other results require investigation. 5. Restore switches to normal positions if generator is working fine 6. Repeat procedure from 2 above for other P-mag, if fitted. I don't check the P-mag generator every flight. Hope this is a little more clear. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael T. Ice Sent: 15 August 2007 04:45 Subject: Re: AeroElectric-List: Emag Wiring Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly <mailto:peter(at)sportingaero.com> Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice _____ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 15, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Yes the confusion is....The P lead is NOT the ground but when you do ground the Plead it kills the engine. You UN-Ground the P lead to allow the engine to run. The E/Pmag still needs a power supply and any power supply consists of a +12V feed and a ground. Thats why there are two grounds shown...terminal 1 is the power ground that has to be permanently connected to provide power to the unit. Frank RV 7a Pmag/Emag ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David & Elaine Lamphere Sent: Wednesday, August 15, 2007 9:43 AM Subject: Re: AeroElectric-List: Emag Wiring Ok, here we go... page 20 in my documentation has pin 1 connected to engine case. Since the case is connected to the ground bus via a nice 4-8 gage flexible braided wire, it sure seems to me it's a main ground. Yes, pin 4 is the P-lead (kill switch) - this is to be connected to the ignition switch pin (L or R) where you would normally connect a mag. Notice that pin 5 is connected to +13.8vdc. This is what I would call main DC power. It really is very simple... Dave ----- Original Message ----- From: Michael T. Ice <mailto:aurbo(at)ak.net> To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 10:02 AM Subject: Re: AeroElectric-List: Emag Wiring Dave, Thanks for the post. On the diagram I have there is no lead labeled Main ground, there is one labeled to ground on engine case. Is this one your calling the main ground? If so then I agree with you that the power and main ground are separate leads. In the instructions that I have for the e/p mags there is a diagram that shows the wiring sequence. On that diagram it shows a wire from the connector plug #4 that is labeled P-lead (Kill Switch). The other end of this wire shows that it is a ground with the same symbol used with the wire that goes to connector plug #1. Perhaps yours is different? Once again I am not putting down e/p mags. I just think (maybe wrongly) that there is some come confusion as to how to wire these mags. And perhaps I am the only one that is confused, wouldn't be the first time. Mike ----- Original Message ----- From: David & Elaine Lamphere <mailto:lamphere(at)vabb.com> To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 3:05 AM Subject: Re: AeroElectric-List: Emag Wiring Mike, Unless I have misunderstood the literature that came with my PMag and Emag, the "P-Lead" is used as a control signal to the ignition controller circuitry to shut off spark when it is grounded. It is NOT the main ground to the unit. The power and main ground are separate leads. Dave ----- Original Message ----- From: Michael T. Ice <mailto:aurbo(at)ak.net> To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 11:45 PM Subject: Re: AeroElectric-List: Emag Wiring Peter, Forgive me but I am trying to understand your sequence of events for checking the p-mag. Perhaps it is semantics but let me get this straight at least to me. 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag says to use the P leads as kill switches) 2. Then turn off the switched breaker ( so now there is no ground and no power? I imagine the engine might run rough unless the other P-mag is doing the duty of both, I suspect it could) Emag says if the engine starts to quit, don't reapply power to the mag. They say to let the engine stop and let the ignition fully power down. Again, I am not doubting you I am just trying to clear up some confusing (perhaps only to me) issues. Thanks for your help in this issue. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Tuesday, August 14, 2007 10:35 AM Subject: RE: AeroElectric-List: Emag Wiring Stan, I have been running an E-mag for 3 years and have also swapped in a P-mag at times. My view is the best way to wire a P-mag is to route the power via a switched breaker, that minimizes the number of connections. If ship's power is shut off to a P-mag whose generator is not working, then the P-mag will act like an E-mag and will not work. If you turn off the p-lead switch to the other mag, the engine will quit. There is no magic here, 2 P-mags are completely independent of each other. Checking both generators is relatively easy, during the run up use the p-lead switch to stop one P-mag from generating sparks, note the rpm drop (there will be one); now turn off the switched breaker (thereby shutting off ship's power to the P-mag), if the engine continues to run at the same rpm then all is well. If the engine falters or runs roughly all is not well and the generator is suspect. Turn the switched breaker back on and repeat on the other P-mag. I've never had a problem with the generator and would recommend anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the failure of one generator is no big deal as the battery will keep the ignition running if the ship's alternator were to fail. The P-mag generator does not produce current all of the time (so E-magair tell me), only when the bus voltage falls below a pre-set level. The P-mag will use the highest voltage source available. I don't consider that a warning light showing P-mag generator failure will be worthwhile when a ground check will provide the same information and it is not a critical failure that requires immediate attention. To answer your specific questions, I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. No, there is no indication. Each P-mag doesn't know (and doesn't care) the other is there. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Best not to remove ship's power from both P-mags at once, switch off power in turn when the p-lead switch is turned off. If the P-mag internal alternator is failed and ship's power is removed the engine will quit if the other mag's p-lead is switched off. Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. There will be, and yes, your right, but you have to do each in turn. I hope this helps, regards, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 14 August 2007 17:05 To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Emag Wiring Mike, Since you invited comment, I will. I haven't asked them, but I suspect the Emag guys want to limit the variables as much as possible at this juncture in their progress. They are working out the bugs in their new system and adding other wiring methods to the mix doesn't help them resolve problems. If I were in their position, I would recommend builders use only the company recommended wiring procedure and if the builder deviates from that recommendation then the builder should not expect Emag assistance to resolve problems. I believe that would not be unreasonable. I believe that would be true of any company selling a product - if the buyer deviates from recommended installation, then the company cannot assist. I have two Pmags (haven't run the engine yet) and I am wiring them with two hidden 3A switched circuit breakers to provide power from the bus and two panel-mounted p-lead switches. I wired it this way because the Emag installation manual says "You can check the internal alternator operation on the P model during run-up (900+ rpm) by switching to the P model ignition and cutting 12 volt power (not the p-lead switch) at the breaker." I hesitate to deviate from the factory recommended wiring procedure - despite Bob's depth of knowledge and recommended technique. Even Bob often says contact the manufacturer and follow their recommendations. I am wondering (and I need to contact Emagair) if there will be any indication of one internal Pmag alternator failure when running two Pmags on their internal alternators. For example, when I'm doing the mag check with 14V power removed and both Pmags are running on internal alternators, if I turn off the p-lead switch to one Pmag (that Pmag is now totally inoperative), will there be an RPM drop or other indication that the chosen Pmag is not working? Even if there is no indication, I still intend to do the check because if one internal alternator has failed, then the only way to know may be to switch each Pmag completely off and check for continued operation on one internal alternator. Experimental aviation is challenging. Fortunately, the original OBAM builders (the Wright brothers) succeeded with each challenge. Surely we can, too. Off subject - I assume from your comment re:seminar that you live in Alaska. My son in moving to AK in spring of next year to fly the F-22 and we are looking for a Piper Pacer to put on floats. Any leads? Stan Sutterfield www.rv-8a.net Erich, I had the pleasure of attending Bob's seminar this past weekend and I asked him about this very same issue. First the caveat. I am not an engineer and don't claim to know a whole lot about electrical theory or application. What I am is curious and I do have an E and a P/mag. After reading everything I can get my hands on and studying the Z figures Z-13 and Z-33 for the Maintenance hand prop option I can detect only subtle differences. Emag powers the mags directly from the main bus, so when you turn on the master there is power at the mags. The switches on the panel for the emags are for P-lead kill switches. To do maintenance (timing) all you have to do is turn on the master and leave the panel switch off. But to check the alternator part of the P-Mag you have to put a separate switch in line with the power supply to the mag. When you do a run up check, you turn this switch off and if all is well the motor keeps on humming. Bob's design has the power go to a switch first. The positions on the switch are down is off, middle is for internal power, up is for ships power. In the Z-33 schematic you then have to add a switch (and possibly a light) to be able to cut the P-lead so you can do maintenance (Timing). So to do the internal alternator check all you have to do is flick the switch to the middle position and if all is well you can't tell the difference. So what's the big difference. Both systems use 3 switches. Both systems do the same thing just in slightly different ways. Personally I can see an advantage in the Emag system where each mag has it's own P-lead ground kill switch. Starting sequence should be pretty easy. Master on, both switches in the up position, mash the start button. But I am a confirmed Nuckoll's advocate and I want to see what he has to say about this. He is still here in Alaska and touring around visiting the sights. He has assured me that when he gets back he will dig into this and provide help. I have sent an email to Emagair asking the same questions. Open dialog on this question can only help us and Emagair greatly. I have not personally heard from the guys at Emagair nor have I read anything directly from them concerning this issue. Until I do I will keep an open mind. Perhaps this issue is a non-event and some of the problems stem from us folks in the field still trying to make these new mags act like the old style. For instance how can you perform a mag drop check if there isn't one. Perhaps the answer is who cares. I don't know but I am sure interested in how this turns out. Please comment at will. Any dialog is appreciated. Mike Ice ________________________________ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. m atronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com ________________________________________________________________________________
Date: Aug 15, 2007
Subject: Re: Emag Wiring
Frank, Yes, I think that is part of the problem for me. I keep trying to relate these mags to the old style and it just doesn't work. But trying to erase many years of old and replacing it with new. Maybe it is age related. Thanks for your comments. Mike ----- Original Message ----- From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com> Date: Wednesday, August 15, 2007 9:42 am Subject: RE: AeroElectric-List: Emag Wiring > Yes the confusion is....The P lead is NOT the ground but when you do > ground the Plead it kills the engine. You UN-Ground the P lead to > allowthe engine to run. > > The E/Pmag still needs a power supply and any power supply > consists of a > +12V feed and a ground. > > Thats why there are two grounds shown...terminal 1 is the power ground > that has to be permanently connected to provide power to the unit. > > Frank > > RV 7a Pmag/Emag > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > David& Elaine Lamphere > Sent: Wednesday, August 15, 2007 9:43 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Emag Wiring > > > Ok, here we go... page 20 in my documentation has pin 1 connected to > engine case. Since the case is connected to the ground bus via a nice > 4-8 gage flexible braided wire, it sure seems to me it's a main > ground. > Yes, pin 4 is the P-lead (kill switch) - this is to be connected > to the > ignition switch pin (L or R) where you would normally connect a > mag. > > Notice that pin 5 is connected to +13.8vdc. This is what I would call > main DC power. > > It really is very simple... > > Dave > ----- Original Message ----- > From: Michael T. Ice <mailto:aurbo(at)ak.net> > To: aeroelectric-list(at)matronics.com > Sent: Wednesday, August 15, 2007 10:02 AM > Subject: Re: AeroElectric-List: Emag Wiring > > Dave, > > Thanks for the post. On the diagram I have there is no lead > labeled Main ground, there is one labeled to ground on engine > case. Is > this one your calling the main ground? If so then I agree with you > thatthe power and main ground are separate leads. > > In the instructions that I have for the e/p mags there is a > diagram that shows the wiring sequence. On that diagram it shows a > wirefrom the connector plug #4 that is labeled P-lead (Kill > Switch). The > other end of this wire shows that it is a ground with the same symbol > used with the wire that goes to connector plug #1. > > Perhaps yours is different? > > Once again I am not putting down e/p mags. I just think (maybe > wrongly) that there is some come confusion as to how to wire these > mags.And perhaps I am the only one that is confused, wouldn't be > the first > time. > > Mike > > ----- Original Message ----- > From: David & Elaine Lamphere <mailto:lamphere(at)vabb.com> > > To: aeroelectric-list(at)matronics.com > Sent: Wednesday, August 15, 2007 3:05 AM > Subject: Re: AeroElectric-List: Emag Wiring > > Mike, > > Unless I have misunderstood the literature that came > with my PMag and Emag, the "P-Lead" is used as a control signal to the > ignition controller circuitry to shut off spark when it is > grounded. It > is NOT the main ground to the unit. The power and main ground are > separate leads. > > Dave > ----- Original Message ----- > From: Michael T. Ice <mailto:aurbo(at)ak.net> > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 11:45 PM > Subject: Re: AeroElectric-List: Emag Wiring > > Peter, > > Forgive me but I am trying to understand your > sequence of events for checking the p-mag. Perhaps it is semantics but > let me get this straight at least to me. > > 1. turn off the p-lead (so the mag is grounded > or ungrounded? Emag says to use the P leads as kill switches) > > 2. Then turn off the switched breaker ( so now > there is no ground and no power? I imagine the engine might run rough > unless the other P-mag is doing the duty of both, I suspect it could) > > Emag says if the engine starts to quit, don't > reapply power to the mag. They say to let the engine stop and let the > ignition fully power down. > > Again, I am not doubting you I am just trying to > clear up some confusing (perhaps only to me) issues. > > Thanks for your help in this issue. > > Mike > ----- Original Message ----- > From: Peter Pengilly > > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 10:35 AM > Subject: RE: AeroElectric-List: Emag > Wiring > > Stan, > > I have been running an E-mag for 3 years > and have also swapped in a P-mag at times. My view is the best way to > wire a P-mag is to route the power via a switched breaker, that > minimizes the number of connections. If ship's power is shut off > to a > P-mag whose generator is not working, then the P-mag will act like an > E-mag and will not work. If you turn off the p-lead switch to the > othermag, the engine will quit. There is no magic here, 2 P-mags are > completely independent of each other. Checking both generators is > relatively easy, during the run up use the p-lead switch to stop one > P-mag from generating sparks, note the rpm drop (there will be > one); now > turn off the switched breaker (thereby shutting off ship's power > to the > P-mag), if the engine continues to run at the same rpm then all is > well.If the engine falters or runs roughly all is not well and the > generatoris suspect. Turn the switched breaker back on and repeat > on the other > P-mag. I've never had a problem with the generator and would recommend > anyone considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the > failure of one generator is no big deal as the battery will keep the > ignition running if the ship's alternator were to fail. > > The P-mag generator does not produce > current all of the time (so E-magair tell me), only when the bus > voltagefalls below a pre-set level. The P-mag will use the highest > voltagesource available. I don't consider that a warning light > showing P-mag > generator failure will be worthwhile when a ground check will provide > the same information and it is not a critical failure that requires > immediate attention. > > To answer your specific questions, > > I am wondering (and I need to contact > Emagair) if there will be any indication of one internal Pmag > alternatorfailure when running two Pmags on their internal > alternators. > > No, there is no indication. Each P-mag > doesn't know (and doesn't care) the other is there. > > For example, when I'm doing the mag > check with 14V power removed and both Pmags are running on internal > alternators, if I turn off the p-lead switch to one Pmag (that > Pmag is > now totally inoperative), will there be an RPM drop or other > indicationthat the chosen Pmag is not working? > > Best not to remove ship's power from > both P-mags at once, switch off power in turn when the p-lead > switch is > turned off. If the P-mag internal alternator is failed and ship's > poweris removed the engine will quit if the other mag's p-lead is > switchedoff. > > Even if there is no indication, I still > intend to do the check because if one internal alternator has failed, > then the only way to know may be to switch each Pmag completely > off and > check for continued operation on one internal alternator. > > There will be, and yes, your right, but > you have to do each in turn. > > I hope this helps, regards, Peter > > -----Original Message----- > From: > owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com > Sent: 14 August 2007 17:05 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Emag Wiring > > Mike, > Since you invited comment, I will. > > I haven't asked them, but I suspect the > Emag guys want to limit the variables as much as possible at this > juncture in their progress. They are working out the bugs in > their new > system and adding other wiring methods to the mix doesn't help them > resolve problems. If I were in their position, I would recommend > builders use only the company recommended wiring procedure and if the > builder deviates from that recommendation then the builder should not > expect Emag assistance to resolve problems. I believe that would > not be > unreasonable. I believe that would be true of any company selling a > product - if the buyer deviates from recommended installation, > then the > company cannot assist. > > I have two Pmags (haven't run the engine > yet) and I am wiring them with two hidden 3A switched circuit breakers > to provide power from the bus and two panel-mounted p-lead > switches. I > wired it this way because the Emag installation manual says "You can > check the internal alternator operation on the P model during run-up > (900+ rpm) by switching to the P model ignition and cutting 12 volt > power (not the p-lead switch) at the breaker." > > I hesitate to deviate from the factory > recommended wiring procedure - despite Bob's depth of knowledge and > recommended technique. Even Bob often says contact the > manufacturer and > follow their recommendations. > > I am wondering (and I need to contact > Emagair) if there will be any indication of one internal Pmag > alternatorfailure when running two Pmags on their internal > alternators. For > example, when I'm doing the mag check with 14V power removed and both > Pmags are running on internal alternators, if I turn off the p-lead > switch to one Pmag (that Pmag is now totally inoperative), will > there be > an RPM drop or other indication that the chosen Pmag is not working? > Even if there is no indication, I still > intend to do the check because if one internal alternator has failed, > then the only way to know may be to switch each Pmag completely > off and > check for continued operation on one internal alternator. > > Experimental aviation is challenging. > Fortunately, the original OBAM builders (the Wright brothers) > succeededwith each challenge. Surely we can, too. > > Off subject - I assume from your comment > re:seminar that you live in Alaska. My son in moving to AK in > spring of > next year to fly the F-22 and we are looking for a Piper Pacer to > put on > floats. Any leads? > > Stan Sutterfield > www.rv-8a.net > > Erich, > > I had the pleasure of attending Bob's > seminar this past weekend and I asked him > about this very same issue. > > First the caveat. I am not an engineer > and don't claim to know a whole lot about > electrical theory or application. What I > am is curious and I do have an E and > a P/mag. > > After reading everything I can get my > hands on and studying the Z figures Z-13 > and Z-33 for the Maintenance hand prop > option I can detect only subtle differences. > > Emag powers the mags directly from the > main bus, so when you turn on the master > there is power at the mags. The switches > on the panel for the emags are for P-lead > kill switches. To do maintenance > (timing) all you have to do is turn on > the master and leave the panel switch > off. But to check the alternator part of > the P-Mag you have to put a separate > switch in line with the power supply to > the mag. When you do a run up check, you > turn this switch off and if all is well > the motor keeps on humming. > > Bob's design has the power go to a > switch first. The positions on the switch are > down is off, middle is for internal > power, up is for ships power. In the Z-33 > schematic you then have to add a switch > (and possibly a light) to be able to > cut the P-lead so you can do maintenance > (Timing). So to do the internal alternator > check all you have to do is flick the > switch to the middle position and > if all is well you can't tell the > difference. > > So what's the big difference. Both > systems use 3 switches. Both systems do the > same thing just in slightly different > ways. > > Personally I can see an advantage in the > Emag system where each mag has it's own > P-lead ground kill switch. Starting > sequence should be pretty easy. Master on, > both switches in the up position, mash > the start button. > > But I am a confirmed Nuckoll's advocate > and I want to see what he has to say about > this. He is still here in Alaska and > touring around visiting the sights. He > has assured me that when he gets back he > will dig into this and provide help. > > I have sent an email to Emagair asking > the same questions. Open dialog on this > question can only help us and Emagair > greatly. > > I have not personally heard from the > guys at Emagair nor have I read anything directly > from them concerning this issue. Until I > do I will keep an open mind. > > > Perhaps this issue is a non-event and > some of the problems stem from us folks in > the field still trying to make these new > mags act like the old style. For instance > how can you perform a mag drop check if > there isn't one. Perhaps the answer > is who cares. I don't know but I am sure > interested in how this turns out. > > Please comment at will. Any dialog is > appreciated. > > Mike Ice > > > > > > ________________________________ > > <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> > . > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > > href="http://forums.matronics.com">http://forums.matronics.com > > > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > > href="http://forums.matronics.com">http://forums.matronics.com > > > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > > href="http://forums.matronics.com">http://forums.matronics.com > > > > > > > ________________________________________________________________________________
Date: Aug 15, 2007
Dave, Thanks for the clarification. Words often times confuse the issue. Now we are on the same page. I agree with your statements. Thank you. My troubles stem from trying to mix two wiring systems together and they don't mix well. So I believe it is best (for me) to follow the Emag wizards and their reccomendations to the letter. One again thanks for helping to clear the fog. Mike ----- Original Message ----- From: David & Elaine Lamphere <lamphere(at)vabb.com> Date: Wednesday, August 15, 2007 8:46 am Subject: Re: AeroElectric-List: Emag Wiring > Ok, here we go... page 20 in my documentation has pin 1 connected > to engine case. Since the case is connected to the ground bus via > a nice 4-8 gage flexible braided wire, it sure seems to me it's a > main ground. > > Yes, pin 4 is the P-lead (kill switch) - this is to be connected > to the ignition switch pin (L or R) where you would normally > connect a mag. > > Notice that pin 5 is connected to +13.8vdc. This is what I would > call main DC power. > > It really is very simple... > > Dave > ----- Original Message ----- > From: Michael T. Ice > To: aeroelectric-list(at)matronics.com > Sent: Wednesday, August 15, 2007 10:02 AM > Subject: Re: AeroElectric-List: Emag Wiring > > > Dave, > > Thanks for the post. On the diagram I have there is no lead > labeled Main ground, there is one labeled to ground on engine > case. Is this one your calling the main ground? If so then I agree > with you that the power and main ground are separate leads. > > In the instructions that I have for the e/p mags there is a > diagram that shows the wiring sequence. On that diagram it shows a > wire from the connector plug #4 that is labeled P-lead (Kill > Switch). The other end of this wire shows that it is a ground with > the same symbol used with the wire that goes to connector plug #1. > > Perhaps yours is different? > > Once again I am not putting down e/p mags. I just think (maybe > wrongly) that there is some come confusion as to how to wire these > mags. And perhaps I am the only one that is confused, wouldn't be > the first time. > > Mike > > ----- Original Message ----- > From: David & Elaine Lamphere > To: aeroelectric-list(at)matronics.com > Sent: Wednesday, August 15, 2007 3:05 AM > Subject: Re: AeroElectric-List: Emag Wiring > > > Mike, > > Unless I have misunderstood the literature that came with my > PMag and Emag, the "P-Lead" is used as a control signal to the > ignition controller circuitry to shut off spark when it is > grounded. It is NOT the main ground to the unit. The power and > main ground are separate leads. > > Dave > ----- Original Message ----- > From: Michael T. Ice > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 11:45 PM > Subject: Re: AeroElectric-List: Emag Wiring > > > Peter, > > Forgive me but I am trying to understand your sequence of > events for checking the p-mag. Perhaps it is semantics but let me > get this straight at least to me. > > 1. turn off the p-lead (so the mag is grounded or > ungrounded? Emag says to use the P leads as kill switches) > > 2. Then turn off the switched breaker ( so now there is no > ground and no power? I imagine the engine might run rough unless > the other P-mag is doing the duty of both, I suspect it could) > > Emag says if the engine starts to quit, don't reapply power > to the mag. They say to let the engine stop and let the ignition > fully power down. > > Again, I am not doubting you I am just trying to clear up > some confusing (perhaps only to me) issues. > > Thanks for your help in this issue. > > Mike > ----- Original Message ----- > From: Peter Pengilly > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 10:35 AM > Subject: RE: AeroElectric-List: Emag Wiring > > > Stan, > > > > I have been running an E-mag for 3 years and have also > swapped in a P-mag at times. My view is the best way to wire a P- > mag is to route the power via a switched breaker, that minimizes > the number of connections. If ship's power is shut off to a P-mag > whose generator is not working, then the P-mag will act like an E- > mag and will not work. If you turn off the p-lead switch to the > other mag, the engine will quit. There is no magic here, 2 P-mags > are completely independent of each other. Checking both generators > is relatively easy, during the run up use the p-lead switch to > stop one P-mag from generating sparks, note the rpm drop (there > will be one); now turn off the switched breaker (thereby shutting > off ship's power to the P-mag), if the engine continues to run at > the same rpm then all is well. If the engine falters or runs > roughly all is not well and the generator is suspect. Turn the > switched breaker back on and repeat on the other P-mag. I've never > had a problem with the generator and would recommend anyone > considering an E/P-mag to buy a P-mag. With 2 P-mags fitted the > failure of one generator is no big deal as the battery will keep > the ignition running if the ship's alternator were to fail. > > > > The P-mag generator does not produce current all of the > time (so E-magair tell me), only when the bus voltage falls below > a pre-set level. The P-mag will use the highest voltage source > available. I don't consider that a warning light showing P-mag > generator failure will be worthwhile when a ground check will > provide the same information and it is not a critical failure that > requires immediate attention. > > > > To answer your specific questions, > > > > I am wondering (and I need to contact Emagair) if there > will be any indication of one internal Pmag alternator failure > when running two Pmags on their internal alternators. > > > > No, there is no indication. Each P-mag doesn't know (and > doesn't care) the other is there. > > > > For example, when I'm doing the mag check with 14V power > removed and both Pmags are running on internal alternators, if I > turn off the p-lead switch to one Pmag (that Pmag is now totally > inoperative), will there be an RPM drop or other indication that > the chosen Pmag is not working? > > > > Best not to remove ship's power from both P-mags at once, > switch off power in turn when the p-lead switch is turned off. If > the P-mag internal alternator is failed and ship's power is > removed the engine will quit if the other mag's p-lead is switched > off. > > > Even if there is no indication, I still intend to do the > check because if one internal alternator has failed, then the only > way to know may be to switch each Pmag completely off and check > for continued operation on one internal alternator. > > > > There will be, and yes, your right, but you have to do > each in turn. > > > > I hope this helps, regards, Peter > > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com Sent: 14 August 2007 17:05 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Emag Wiring > > > > Mike, > > Since you invited comment, I will. > > > > I haven't asked them, but I suspect the Emag guys want to > limit the variables as much as possible at this juncture in their > progress. They are working out the bugs in their new system and > adding other wiring methods to the mix doesn't help them resolve > problems. If I were in their position, I would recommend builders > use only the company recommended wiring procedure and if the > builder deviates from that recommendation then the builder should > not expect Emag assistance to resolve problems. I believe that > would not be unreasonable. I believe that would be true of any > company selling a product - if the buyer deviates from recommended > installation, then the company cannot assist. > > > > I have two Pmags (haven't run the engine yet) and I am > wiring them with two hidden 3A switched circuit breakers to > provide power from the bus and two panel-mounted p-lead switches. > I wired it this way because the Emag installation manual says "You > can check the internal alternator operation on the P model during > run-up (900+ rpm) by switching to the P model ignition and cutting > 12 volt power (not the p-lead switch) at the breaker." > > > > I hesitate to deviate from the factory recommended wiring > procedure - despite Bob's depth of knowledge and recommended > technique. Even Bob often says contact the manufacturer and > follow their recommendations. > > > > I am wondering (and I need to contact Emagair) if there > will be any indication of one internal Pmag alternator failure > when running two Pmags on their internal alternators. For > example, when I'm doing the mag check with 14V power removed and > both Pmags are running on internal alternators, if I turn off the > p-lead switch to one Pmag (that Pmag is now totally inoperative), > will there be an RPM drop or other indication that the chosen Pmag > is not working? > > Even if there is no indication, I still intend to do the > check because if one internal alternator has failed, then the only > way to know may be to switch each Pmag completely off and check > for continued operation on one internal alternator. > > > > Experimental aviation is challenging. Fortunately, the > original OBAM builders (the Wright brothers) succeeded with each > challenge. Surely we can, too. > > > > Off subject - I assume from your comment re:seminar that > you live in Alaska. My son in moving to AK in spring of next year > to fly the F-22 and we are looking for a Piper Pacer to put on > floats. Any leads? > > > > Stan Sutterfield > > www.rv-8a.net > > > > Erich, > > I had the pleasure of attending Bob's seminar this past > weekend and I asked him > about this very same issue. > > First the caveat. I am not an engineer and don't claim > to know a whole lot about > electrical theory or application. What I am is curious > and I do have an E and > a P/mag. > > After reading everything I can get my hands on and > studying the Z figures Z-13 > and Z-33 for the Maintenance hand prop option I can > detect only subtle differences. > > Emag powers the mags directly from the main bus, so when > you turn on the master > there is power at the mags. The switches on the panel > for the emags are for P-lead > kill switches. To do maintenance (timing) all you have > to do is turn on > the master and leave the panel switch off. But to check > the alternator part of > the P-Mag you have to put a separate switch in line with > the power supply to > the mag. When you do a run up check, you turn this > switch off and if all is well > the motor keeps on humming. > > Bob's design has the power go to a switch first. The > positions on the switch are > down is off, middle is for internal power, up is for > ships power. In the Z-33 > schematic you then have to add a switch (and possibly a > light) to be able to > cut the P-lead so you can do maintenance (Timing). So to > do the internal alternator > check all you have to do is flick the switch to the > middle position and > if all is well you can't tell the difference. > > So what's the big difference. Both systems use 3 > switches. Both systems do the > same thing just in slightly different ways. > > Personally I can see an advantage in the Emag system > where each mag has it's own > P-lead ground kill switch. Starting sequence should be > pretty easy. Master on, > both switches in the up position, mash the start button. > > But I am a confirmed Nuckoll's advocate and I want to > see what he has to say about > this. He is still here in Alaska and touring around > visiting the sights. He > has assured me that when he gets back he will dig into > this and provide help. > > I have sent an email to Emagair asking the same > questions. Open dialog on this > question can only help us and Emagair greatly. > > I have not personally heard from the guys at Emagair nor > have I read anything directly > from them concerning this issue. Until I do I will keep > an open mind. > > > Perhaps this issue is a non-event and some of the > problems stem from us folks in > the field still trying to make these new mags act like > the old style. For instance > how can you perform a mag drop check if there isn't one. > Perhaps the answer > is who cares. I don't know but I am sure interested in > how this turns out. > > Please comment at will. Any dialog is appreciated. > > Mike Ice > > > > > > > > > ------------------------------------------------------------------- > ----- > > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Date: Aug 15, 2007
Peter, Thanks for the list. Clear as a bell now. I think I would do as you suggest and not check the P-mag internal alternator every flight either. How many hours do you have on your P-mags? Any troubles? Mike ----- Original Message ----- From: Peter Pengilly <peter(at)sportingaero.com> Date: Wednesday, August 15, 2007 9:25 am Subject: RE: AeroElectric-List: Emag Wiring > Mike, > > I could probably have written a little more clearly. The object is to > get one P-mag running on its internal generator (by removing busbar > power), then cycle the other mag/P-mag to find out if the engine still > runs (I wrote it the other way around). If the engine runs, the > generator is good, if it does not generator is bad. > > So, probably the best sequence is > > 1. Carry out normal mag drop check to deduce "normal" mag drop. > Bear in mind there will always be an rpm drop when only a P/E-mag is > running, but that drop won't be as large as when only a magneto is > running. > 2. Shut off busbar power to one P-mag > 3. Switch off/ground other mag/P-mag (so it is not producing > sparks) > 4. Observe engine behaviour. Rpm drop as in 1 above = everything > working fine, other results require investigation. > 5. Restore switches to normal positions if generator is working > fine > 6. Repeat procedure from 2 above for other P-mag, if fitted. > > I don't check the P-mag generator every flight. > > Hope this is a little more clear. > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Michael T. Ice > Sent: 15 August 2007 04:45 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Emag Wiring > > Peter, > > Forgive me but I am trying to understand your sequence of events for > checking the p-mag. Perhaps it is semantics but let me get this > straightat least to me. > > 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag > saysto use the P leads as kill switches) > > 2. Then turn off the switched breaker ( so now there is no ground > and no > power? I imagine the engine might run rough unless the other P-mag is > doing the duty of both, I suspect it could) > > Emag says if the engine starts to quit, don't reapply power to the > mag.They say to let the engine stop and let the ignition fully > power down. > > Again, I am not doubting you I am just trying to clear up some > confusing(perhaps only to me) issues. > > Thanks for your help in this issue. > > Mike > ----- Original Message ----- > From: Peter Pengilly <mailto:peter(at)sportingaero.com> > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 10:35 AM > Subject: RE: AeroElectric-List: Emag Wiring > > Stan, > > I have been running an E-mag for 3 years and have also swapped in a > P-mag at times. My view is the best way to wire a P-mag is to > route the > power via a switched breaker, that minimizes the number of > connections.If ship's power is shut off to a P-mag whose generator > is not working, > then the P-mag will act like an E-mag and will not work. If you > turn off > the p-lead switch to the other mag, the engine will quit. There is no > magic here, 2 P-mags are completely independent of each other. > Checkingboth generators is relatively easy, during the run up use > the p-lead > switch to stop one P-mag from generating sparks, note the rpm drop > (there will be one); now turn off the switched breaker (thereby > shuttingoff ship's power to the P-mag), if the engine continues to > run at the > same rpm then all is well. If the engine falters or runs roughly > all is > not well and the generator is suspect. Turn the switched breaker > back on > and repeat on the other P-mag. I've never had a problem with the > generator and would recommend anyone considering an E/P-mag to buy a > P-mag. With 2 P-mags fitted the failure of one generator is no big > dealas the battery will keep the ignition running if the ship's > alternatorwere to fail. > > The P-mag generator does not produce current all of the time (so > E-magair tell me), only when the bus voltage falls below a pre-set > level. The P-mag will use the highest voltage source available. I > don'tconsider that a warning light showing P-mag generator failure > will be > worthwhile when a ground check will provide the same information > and it > is not a critical failure that requires immediate attention. > > To answer your specific questions, > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. > > No, there is no indication. Each P-mag doesn't know (and doesn't care) > the other is there. > > For example, when I'm doing the mag check with 14V power removed and > both Pmags are running on internal alternators, if I turn off the > p-lead > switch to one Pmag (that Pmag is now totally inoperative), will > there be > an RPM drop or other indication that the chosen Pmag is not working? > > Best not to remove ship's power from both P-mags at once, switch off > power in turn when the p-lead switch is turned off. If the P-mag > internal alternator is failed and ship's power is removed the engine > will quit if the other mag's p-lead is switched off. > > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > There will be, and yes, your right, but you have to do each in turn. > > I hope this helps, regards, Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com > Sent: 14 August 2007 17:05 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Emag Wiring > > Mike, > Since you invited comment, I will. > > I haven't asked them, but I suspect the Emag guys want to limit the > variables as much as possible at this juncture in their progress. > Theyare working out the bugs in their new system and adding other > wiringmethods to the mix doesn't help them resolve problems. If I > were in > their position, I would recommend builders use only the company > recommended wiring procedure and if the builder deviates from that > recommendation then the builder should not expect Emag assistance to > resolve problems. I believe that would not be unreasonable. I > believethat would be true of any company selling a product - if > the buyer > deviates from recommended installation, then the company cannot > assist. > I have two Pmags (haven't run the engine yet) and I am wiring them > withtwo hidden 3A switched circuit breakers to provide power from > the bus > and two panel-mounted p-lead switches. I wired it this way > because the > Emag installation manual says "You can check the internal alternator > operation on the P model during run-up (900+ rpm) by switching to > the P > model ignition and cutting 12 volt power (not the p-lead switch) > at the > breaker." > > I hesitate to deviate from the factory recommended wiring > procedure - > despite Bob's depth of knowledge and recommended technique. Even Bob > often says contact the manufacturer and follow their recommendations. > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. For example, when I'm doing the > mag check with 14V power removed and both Pmags are running on > internalalternators, if I turn off the p-lead switch to one Pmag > (that Pmag is > now totally inoperative), will there be an RPM drop or other > indicationthat the chosen Pmag is not working? > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > Experimental aviation is challenging. Fortunately, the original OBAM > builders (the Wright brothers) succeeded with each challenge. > Surely we > can, too. > > Off subject - I assume from your comment re:seminar that you live in > Alaska. My son in moving to AK in spring of next year to fly the > F-22 > and we are looking for a Piper Pacer to put on floats. Any leads? > > Stan Sutterfield > www.rv-8a.net > > Erich, > > I had the pleasure of attending Bob's seminar this past weekend > and I > asked him > about this very same issue. > > First the caveat. I am not an engineer and don't claim to know a whole > lot about > electrical theory or application. What I am is curious and I do > have an > E and > a P/mag. > > After reading everything I can get my hands on and studying the Z > figures Z-13 > and Z-33 for the Maintenance hand prop option I can detect only subtle > differences. > > Emag powers the mags directly from the main bus, so when you turn > on the > master > there is power at the mags. The switches on the panel for the > emags are > for P-lead > kill switches. To do maintenance (timing) all you have to do is > turn on > the master and leave the panel switch off. But to check the alternator > part of > the P-Mag you have to put a separate switch in line with the power > supply to > the mag. When you do a run up check, you turn this switch off and > if all > is well > the motor keeps on humming. > > Bob's design has the power go to a switch first. The positions on the > switch are > down is off, middle is for internal power, up is for ships power. > In the > Z-33 > schematic you then have to add a switch (and possibly a light) to be > able to > cut the P-lead so you can do maintenance (Timing). So to do the > internalalternator > check all you have to do is flick the switch to the middle > position and > if all is well you can't tell the difference. > > So what's the big difference. Both systems use 3 switches. Both > systemsdo the > same thing just in slightly different ways. > > Personally I can see an advantage in the Emag system where each > mag has > it's own > P-lead ground kill switch. Starting sequence should be pretty easy. > Master on, > both switches in the up position, mash the start button. > > But I am a confirmed Nuckoll's advocate and I want to see what he > has to > say about > this. He is still here in Alaska and touring around visiting the > sights.He > has assured me that when he gets back he will dig into this and > providehelp. > > I have sent an email to Emagair asking the same questions. Open dialog > on this > question can only help us and Emagair greatly. > > I have not personally heard from the guys at Emagair nor have I read > anything directly > from them concerning this issue. Until I do I will keep an open mind. > > > Perhaps this issue is a non-event and some of the problems stem > from us > folks in > the field still trying to make these new mags act like the old style. > For instance > how can you perform a mag drop check if there isn't one. Perhaps the > answer > is who cares. I don't know but I am sure interested in how this turns > out. > > Please comment at will. Any dialog is appreciated. > > Mike Ice > > > > > > _____ > > <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> > . > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Date: Aug 15, 2007
Subject: Nav/com 'acoustic feedback'
I'm still not sure whether it's electrical noise or acoustic noise - since covering the mic has some effect on the behavior. If it were just acoustic, covering the mic should stop the noise. More questions: - Is the acoustic squelch on the intercom adjustable? Can you set the threshold higher? Maybe pulling out the volume knob and turning it adjusts that? Or is it dynamic/smart adjusting? - What kind of engine is it? - Does it have separate ignition systems? Can you turn one off at a time (to help isolate electrical noise)? - Can you turn the alternator off with the engine running? - You probably answered this before, but with the engine off, does the intercom appear to work properly? Speaking in the mic on one headset yields sound coming from the other headset - using the radio sidetone? - Are you able to transmit/receiver properly when the engine is off? - Are the mic leads made with shielded wire? - Do other aspects of the electrical system all appear to function normally - bus voltage, nav signals, etc? Bob often recommends powering from a separate battery the piece(s) of equipment that are involved in the problem. A couple of lantern batteries could be used to power the radio while the engine is running.. If that has any effect on the noise, it indicates that the problem is conducted to the radio via the power bus. What would be slick for this kind of online debug process would be to have an online spreadsheet or form which could be used to document the problem, behaviors, and the things that have been tried in order to fix it.. Have to ponder that a bit. Regards, Matt- > 1. The radio is a Bendix/King KX155 > 2. It is approximately 1 year old. Don't know the model # but could find > out > 3. It definately has an internal intercom but i've no links to describe it > 4. I didn't check whether the sound varied depending on where your > head/headset is sitting, or by > bending the wires around on the headset, or the wires to the jack but it > occurred with 3 separate headsets and on both pilot and co-pilot outputs. > Pretty sure its not a headset problem as same headsets work fine in other > planes > 5. The noise gets worse with higher engine RPM but is very obvious even at > 1000 RPM. The character doesn't change - just its loudness > Many thanks > Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt > Prather > Sent: Mon 13/08/2007 22:29 > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see > the manual says it has 500ohm aux inputs, but don't see any reference to > intercom. We're talking about a Bendix/King KX-155, right? Do you have a > link to a file which describes the feature? > > Does the sound vary depending on where your head/headset is sitting, or by > bending the wires around on the headset, or the wires to the jack? > > Is the frequency of the whine/feedback dependent on the engine RPM? Or is > it just a steady tone? > > I agree with item 3 (assuming an intercom). > > > Regards, > > Matt- > > >> Matt >> 1. When i cover the mic with my hand (muff off) the character of the >> feedback alters significantly but is not overall reduced. If i move the >> boom away from my mouth and around to the back of my head then the >> feedback reduces but doesn't disappear. Its worse (louder) the closer >> the >> boom to my mouth. These symptoms occur on both left and right hand >> headsets >> 2. My KX155 has an internal intercom. I haven't tried to disconnect it. >> 3. Plugging in the mic jack should activate the intercom and the >> transmit >> on the radio (when PTT pressed) >> 4. Remember the problem only occurs when the engine is running. >> 5. Does anyone know how to adjust the mic gain (intercom volume control) >> on the KX155? Couldn't find this info in the installation manual. >> Kind regards >> Frank >> >> >> >> >> ________________________________ >> >> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt >> Prather >> Sent: Mon 13/08/2007 20:12 >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' >> >> >> >> >> >> Does it help if you cover the mic with your hand (both sides - pull the >> muff off)? >> >> I suspect that the input stage of your intercom is being overdriven by >> the >> acoustic noise of the engine. >> >> >> >> Regards, >> >> Matt- >> >>> Thanks for your comments Ernest. >>> I've double-checked all the grounds i could find. Even took the whole >>> harness out (which was new) and had it double-checked. Nothing found. >>> If its the intercom in the radio why does it not cause the same problem >>> when the engine is off? >>> It only causes the problem when the engine is running >>> Kind regards >>> Frank >>> >>> ________________________________ >>> >>> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest
August 01, 2007 - August 15, 2007
AeroElectric-Archive.digest.vol-hc
