AeroElectric-Archive.digest.vol-hd
August 15, 2007 - September 02, 2007
      >>> Christley
      >>> Sent: Mon 13/08/2007 15:04
      >>> To: aeroelectric-list(at)matronics.com
      >>> Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback'
      >>> Miskelly, Francis G wrote:
      >>>> The KX155 nav/com in my Glastar has 2 problems which may be related.
      >>>> 1. Inserting the headphone jack i have near perfect reception.
      >>>> However, when i insert the microphone jack there is a loud whine
      >>>> suggestive of 'acoustic feedback'. Moving the boom away from my mouth
      >>>> reduces the whine. With a different headset it appears as lots of
      >>>> static noise which again changes with position of the boom. I've
      >>>> changed the aerial, power supply and checked all the earths. It occurs
      >>>> with either mag and when the generator is disconnected. It only
      >>>> happens when the engine is running. The radio's been bench tested and
      >>>> passed as good.
      >>>> 2. Radio reception is good with just the headphone jack inserted.
      >>>> However, insert the microphone jack and reception becomes very poor or
      >>>> disappears completely. I suspect the 'acoustic feedback' is raising
      >>>> the automatic squelch which is cutting off the radio station
      >>>> Can anyone suggest an explanation and a solution!
      >>>> Many thanks
      >>>> Frank
      >>> Since there is a problem with multiple headset, I would check the jack
      >>> first.  The symptoms seem to imply some feedback from the mic to the
      >>> audio.  Look for a short or a broken ground.  Beyond that, it would
      >>> seem
      >>> circuitry withing the intercom is fritzed, and it gets much more
      >>> complicated.
Subject: Emag Wiring
Date: Aug 15, 2007
I now have around 140 hours total on 3 individual units. I bought the 10th E-mag built as the "factory" (a large shed in Tom's backyard) was 20 minutes from where I worked. I didn't have any issues with the 110 series unit. About 16 months ago that unit was replaced foc with a 113 series E-mag, at about the same time I bought a P-mag with the intention of replacing the other mag. The 113 series has always had an intermittent problem on start up where it doesn't always start up, ie is dead when mag checked and required the power to be cycled to bring it on line (this was before the current issues with powering down while the engine was turning). That was believed to be a firmware problem. When a firmware version update was available I swapped out the E-mag for the P-mag (which has not had any problems) and sent the E-mag back for updating. I have recently re-installed the E-mag (no real reason for the delay in re-installing, just never got around to it), with a similar, but slightly different problem, now evident. I now live a long way from the factory so we're trying to figure out how best to fix the problem, I'm flying again with the P-mag. Once again the P-mag is trouble free. Support from the E-magair folks has been outstanding. Since fitting the E-mag I have gained about 40rpm static, starting is improved (very rarely more than 3 blades) and performance at altitude is definitely better as is the ability to lean more aggressively. I was well aware that I was fitting an experimental ignition system when I installed the first E-mag - that is why I retained one mag, but its never been an issue in flight. I now think the P-mag is an inherently better solution to the ignition problem and would recommend one (or two) to anyone. I'm aware that some others have experienced problems, but E-magair seem committed to fully supporting their products. I am a happy customer. Peter O-320 with fixed pitch prop on an RV-6A -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Ice Sent: 15 August 2007 20:35 Subject: Re: RE: AeroElectric-List: Emag Wiring Peter, Thanks for the list. Clear as a bell now. I think I would do as you suggest and not check the P-mag internal alternator every flight either. How many hours do you have on your P-mags? Any troubles? Mike ----- Original Message ----- From: Peter Pengilly <peter(at)sportingaero.com> Date: Wednesday, August 15, 2007 9:25 am Subject: RE: AeroElectric-List: Emag Wiring > Mike, > > I could probably have written a little more clearly. The object is to > get one P-mag running on its internal generator (by removing busbar > power), then cycle the other mag/P-mag to find out if the engine still > runs (I wrote it the other way around). If the engine runs, the > generator is good, if it does not generator is bad. > > So, probably the best sequence is > > 1. Carry out normal mag drop check to deduce "normal" mag drop. > Bear in mind there will always be an rpm drop when only a P/E-mag is > running, but that drop won't be as large as when only a magneto is > running. > 2. Shut off busbar power to one P-mag > 3. Switch off/ground other mag/P-mag (so it is not producing > sparks) > 4. Observe engine behaviour. Rpm drop as in 1 above = everything > working fine, other results require investigation. > 5. Restore switches to normal positions if generator is working > fine > 6. Repeat procedure from 2 above for other P-mag, if fitted. > > I don't check the P-mag generator every flight. > > Hope this is a little more clear. > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Michael T. Ice > Sent: 15 August 2007 04:45 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Emag Wiring > > Peter, > > Forgive me but I am trying to understand your sequence of events for > checking the p-mag. Perhaps it is semantics but let me get this > straightat least to me. > > 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag > saysto use the P leads as kill switches) > > 2. Then turn off the switched breaker ( so now there is no ground > and no > power? I imagine the engine might run rough unless the other P-mag is > doing the duty of both, I suspect it could) > > Emag says if the engine starts to quit, don't reapply power to the > mag.They say to let the engine stop and let the ignition fully > power down. > > Again, I am not doubting you I am just trying to clear up some > confusing(perhaps only to me) issues. > > Thanks for your help in this issue. > > Mike > ----- Original Message ----- > From: Peter Pengilly <mailto:peter(at)sportingaero.com> > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 10:35 AM > Subject: RE: AeroElectric-List: Emag Wiring > > Stan, > > I have been running an E-mag for 3 years and have also swapped in a > P-mag at times. My view is the best way to wire a P-mag is to > route the > power via a switched breaker, that minimizes the number of > connections.If ship's power is shut off to a P-mag whose generator > is not working, > then the P-mag will act like an E-mag and will not work. If you > turn off > the p-lead switch to the other mag, the engine will quit. There is no > magic here, 2 P-mags are completely independent of each other. > Checkingboth generators is relatively easy, during the run up use > the p-lead > switch to stop one P-mag from generating sparks, note the rpm drop > (there will be one); now turn off the switched breaker (thereby > shuttingoff ship's power to the P-mag), if the engine continues to > run at the > same rpm then all is well. If the engine falters or runs roughly > all is > not well and the generator is suspect. Turn the switched breaker > back on > and repeat on the other P-mag. I've never had a problem with the > generator and would recommend anyone considering an E/P-mag to buy a > P-mag. With 2 P-mags fitted the failure of one generator is no big > dealas the battery will keep the ignition running if the ship's > alternatorwere to fail. > > The P-mag generator does not produce current all of the time (so > E-magair tell me), only when the bus voltage falls below a pre-set > level. The P-mag will use the highest voltage source available. I > don'tconsider that a warning light showing P-mag generator failure > will be > worthwhile when a ground check will provide the same information > and it > is not a critical failure that requires immediate attention. > > To answer your specific questions, > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. > > No, there is no indication. Each P-mag doesn't know (and doesn't care) > the other is there. > > For example, when I'm doing the mag check with 14V power removed and > both Pmags are running on internal alternators, if I turn off the > p-lead > switch to one Pmag (that Pmag is now totally inoperative), will > there be > an RPM drop or other indication that the chosen Pmag is not working? > > Best not to remove ship's power from both P-mags at once, switch off > power in turn when the p-lead switch is turned off. If the P-mag > internal alternator is failed and ship's power is removed the engine > will quit if the other mag's p-lead is switched off. > > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > There will be, and yes, your right, but you have to do each in turn. > > I hope this helps, regards, Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com > Sent: 14 August 2007 17:05 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Emag Wiring > > Mike, > Since you invited comment, I will. > > I haven't asked them, but I suspect the Emag guys want to limit the > variables as much as possible at this juncture in their progress. > Theyare working out the bugs in their new system and adding other > wiringmethods to the mix doesn't help them resolve problems. If I > were in > their position, I would recommend builders use only the company > recommended wiring procedure and if the builder deviates from that > recommendation then the builder should not expect Emag assistance to > resolve problems. I believe that would not be unreasonable. I > believethat would be true of any company selling a product - if > the buyer > deviates from recommended installation, then the company cannot > assist. > I have two Pmags (haven't run the engine yet) and I am wiring them > withtwo hidden 3A switched circuit breakers to provide power from > the bus > and two panel-mounted p-lead switches. I wired it this way > because the > Emag installation manual says "You can check the internal alternator > operation on the P model during run-up (900+ rpm) by switching to > the P > model ignition and cutting 12 volt power (not the p-lead switch) > at the > breaker." > > I hesitate to deviate from the factory recommended wiring > procedure - > despite Bob's depth of knowledge and recommended technique. Even Bob > often says contact the manufacturer and follow their recommendations. > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. For example, when I'm doing the > mag check with 14V power removed and both Pmags are running on > internalalternators, if I turn off the p-lead switch to one Pmag > (that Pmag is > now totally inoperative), will there be an RPM drop or other > indicationthat the chosen Pmag is not working? > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > Experimental aviation is challenging. Fortunately, the original OBAM > builders (the Wright brothers) succeeded with each challenge. > Surely we > can, too. > > Off subject - I assume from your comment re:seminar that you live in > Alaska. My son in moving to AK in spring of next year to fly the > F-22 > and we are looking for a Piper Pacer to put on floats. Any leads? > > Stan Sutterfield > www.rv-8a.net > > Erich, > > I had the pleasure of attending Bob's seminar this past weekend > and I > asked him > about this very same issue. > > First the caveat. I am not an engineer and don't claim to know a whole > lot about > electrical theory or application. What I am is curious and I do > have an > E and > a P/mag. > > After reading everything I can get my hands on and studying the Z > figures Z-13 > and Z-33 for the Maintenance hand prop option I can detect only subtle > differences. > > Emag powers the mags directly from the main bus, so when you turn > on the > master > there is power at the mags. The switches on the panel for the > emags are > for P-lead > kill switches. To do maintenance (timing) all you have to do is > turn on > the master and leave the panel switch off. But to check the alternator > part of > the P-Mag you have to put a separate switch in line with the power > supply to > the mag. When you do a run up check, you turn this switch off and > if all > is well > the motor keeps on humming. > > Bob's design has the power go to a switch first. The positions on the > switch are > down is off, middle is for internal power, up is for ships power. > In the > Z-33 > schematic you then have to add a switch (and possibly a light) to be > able to > cut the P-lead so you can do maintenance (Timing). So to do the > internalalternator > check all you have to do is flick the switch to the middle > position and > if all is well you can't tell the difference. > > So what's the big difference. Both systems use 3 switches. Both > systemsdo the > same thing just in slightly different ways. > > Personally I can see an advantage in the Emag system where each > mag has > it's own > P-lead ground kill switch. Starting sequence should be pretty easy. > Master on, > both switches in the up position, mash the start button. > > But I am a confirmed Nuckoll's advocate and I want to see what he > has to > say about > this. He is still here in Alaska and touring around visiting the > sights.He > has assured me that when he gets back he will dig into this and > providehelp. > > I have sent an email to Emagair asking the same questions. Open dialog > on this > question can only help us and Emagair greatly. > > I have not personally heard from the guys at Emagair nor have I read > anything directly > from them concerning this issue. Until I do I will keep an open mind. > > > Perhaps this issue is a non-event and some of the problems stem > from us > folks in > the field still trying to make these new mags act like the old style. > For instance > how can you perform a mag drop check if there isn't one. Perhaps the > answer > is who cares. I don't know but I am sure interested in how this turns > out. > > Please comment at will. Any dialog is appreciated. > > Mike Ice > > > > > > _____ > > <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> > . > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Date: Aug 15, 2007
Subject: Re: Emag Wiring
Peter, Many thanks for your write up on the e/p mags. I have bought one of each and will begin wiring them very soon. Mike ----- Original Message ----- From: Peter Pengilly To: aeroelectric-list(at)matronics.com Sent: Wednesday, August 15, 2007 2:27 PM Subject: RE: AeroElectric-List: Emag Wiring I now have around 140 hours total on 3 individual units. I bought the 10th E-mag built as the "factory" (a large shed in Tom's backyard) was 20 minutes from where I worked. I didn't have any issues with the 110 series unit. About 16 months ago that unit was replaced foc with a 113 series E-mag, at about the same time I bought a P-mag with the intention of replacing the other mag. The 113 series has always had an intermittent problem on start up where it doesn't always start up, ie is dead when mag checked and required the power to be cycled to bring it on line (this was before the current issues with powering down while the engine was turning). That was believed to be a firmware problem. When a firmware version update was available I swapped out the E-mag for the P-mag (which has not had any problems) and sent the E-mag back for updating. I have recently re-installed the E-mag (no real reason for the delay in re-installing, just never got around to it), with a similar, but slightly different problem, now evident. I now live a long way from the factory so we're trying to figure out how best to fix the problem, I'm flying again with the P-mag. Once again the P-mag is trouble free. Support from the E-magair folks has been outstanding. Since fitting the E-mag I have gained about 40rpm static, starting is improved (very rarely more than 3 blades) and performance at altitude is definitely better as is the ability to lean more aggressively. I was well aware that I was fitting an experimental ignition system when I installed the first E-mag - that is why I retained one mag, but its never been an issue in flight. I now think the P-mag is an inherently better solution to the ignition problem and would recommend one (or two) to anyone. I'm aware that some others have experienced problems, but E-magair seem committed to fully supporting their products. I am a happy customer. Peter O-320 with fixed pitch prop on an RV-6A -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael Ice Sent: 15 August 2007 20:35 To: aeroelectric-list(at)matronics.com Subject: Re: RE: AeroElectric-List: Emag Wiring Peter, Thanks for the list. Clear as a bell now. I think I would do as you suggest and not check the P-mag internal alternator every flight either. How many hours do you have on your P-mags? Any troubles? Mike ----- Original Message ----- From: Peter Pengilly <peter(at)sportingaero.com> Date: Wednesday, August 15, 2007 9:25 am Subject: RE: AeroElectric-List: Emag Wiring To: aeroelectric-list(at)matronics.com > Mike, > > I could probably have written a little more clearly. The object is to > get one P-mag running on its internal generator (by removing busbar > power), then cycle the other mag/P-mag to find out if the engine still > runs (I wrote it the other way around). If the engine runs, the > generator is good, if it does not generator is bad. > > So, probably the best sequence is > > 1. Carry out normal mag drop check to deduce "normal" mag drop. > Bear in mind there will always be an rpm drop when only a P/E-mag is > running, but that drop won't be as large as when only a magneto is > running. > 2. Shut off busbar power to one P-mag > 3. Switch off/ground other mag/P-mag (so it is not producing > sparks) > 4. Observe engine behaviour. Rpm drop as in 1 above = everything > working fine, other results require investigation. > 5. Restore switches to normal positions if generator is working > fine > 6. Repeat procedure from 2 above for other P-mag, if fitted. > > I don't check the P-mag generator every flight. > > Hope this is a little more clear. > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Michael T. Ice > Sent: 15 August 2007 04:45 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Emag Wiring > > Peter, > > Forgive me but I am trying to understand your sequence of events for > checking the p-mag. Perhaps it is semantics but let me get this > straightat least to me. > > 1. turn off the p-lead (so the mag is grounded or ungrounded? Emag > saysto use the P leads as kill switches) > > 2. Then turn off the switched breaker ( so now there is no ground > and no > power? I imagine the engine might run rough unless the other P-mag is > doing the duty of both, I suspect it could) > > Emag says if the engine starts to quit, don't reapply power to the > mag.They say to let the engine stop and let the ignition fully > power down. > > Again, I am not doubting you I am just trying to clear up some > confusing(perhaps only to me) issues. > > Thanks for your help in this issue. > > Mike > ----- Original Message ----- > From: Peter Pengilly <mailto:peter(at)sportingaero.com> > To: aeroelectric-list(at)matronics.com > Sent: Tuesday, August 14, 2007 10:35 AM > Subject: RE: AeroElectric-List: Emag Wiring > > Stan, > > I have been running an E-mag for 3 years and have also swapped in a > P-mag at times. My view is the best way to wire a P-mag is to > route the > power via a switched breaker, that minimizes the number of > connections.If ship's power is shut off to a P-mag whose generator > is not working, > then the P-mag will act like an E-mag and will not work. If you > turn off > the p-lead switch to the other mag, the engine will quit. There is no > magic here, 2 P-mags are completely independent of each other. > Checkingboth generators is relatively easy, during the run up use > the p-lead > switch to stop one P-mag from generating sparks, note the rpm drop > (there will be one); now turn off the switched breaker (thereby > shuttingoff ship's power to the P-mag), if the engine continues to > run at the > same rpm then all is well. If the engine falters or runs roughly > all is > not well and the generator is suspect. Turn the switched breaker > back on > and repeat on the other P-mag. I've never had a problem with the > generator and would recommend anyone considering an E/P-mag to buy a > P-mag. With 2 P-mags fitted the failure of one generator is no big > dealas the battery will keep the ignition running if the ship's > alternatorwere to fail. > > The P-mag generator does not produce current all of the time (so > E-magair tell me), only when the bus voltage falls below a pre-set > level. The P-mag will use the highest voltage source available. I > don'tconsider that a warning light showing P-mag generator failure > will be > worthwhile when a ground check will provide the same information > and it > is not a critical failure that requires immediate attention. > > To answer your specific questions, > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. > > No, there is no indication. Each P-mag doesn't know (and doesn't care) > the other is there. > > For example, when I'm doing the mag check with 14V power removed and > both Pmags are running on internal alternators, if I turn off the > p-lead > switch to one Pmag (that Pmag is now totally inoperative), will > there be > an RPM drop or other indication that the chosen Pmag is not working? > > Best not to remove ship's power from both P-mags at once, switch off > power in turn when the p-lead switch is turned off. If the P-mag > internal alternator is failed and ship's power is removed the engine > will quit if the other mag's p-lead is switched off. > > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > There will be, and yes, your right, but you have to do each in turn. > > I hope this helps, regards, Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > Speedy11(at)aol.com > Sent: 14 August 2007 17:05 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Emag Wiring > > Mike, > Since you invited comment, I will. > > I haven't asked them, but I suspect the Emag guys want to limit the > variables as much as possible at this juncture in their progress. > Theyare working out the bugs in their new system and adding other > wiringmethods to the mix doesn't help them resolve problems. If I > were in > their position, I would recommend builders use only the company > recommended wiring procedure and if the builder deviates from that > recommendation then the builder should not expect Emag assistance to > resolve problems. I believe that would not be unreasonable. I > believethat would be true of any company selling a product - if > the buyer > deviates from recommended installation, then the company cannot > assist. > I have two Pmags (haven't run the engine yet) and I am wiring them > withtwo hidden 3A switched circuit breakers to provide power from > the bus > and two panel-mounted p-lead switches. I wired it this way > because the > Emag installation manual says "You can check the internal alternator > operation on the P model during run-up (900+ rpm) by switching to > the P > model ignition and cutting 12 volt power (not the p-lead switch) > at the > breaker." > > I hesitate to deviate from the factory recommended wiring > procedure - > despite Bob's depth of knowledge and recommended technique. Even Bob > often says contact the manufacturer and follow their recommendations. > > I am wondering (and I need to contact Emagair) if there will be any > indication of one internal Pmag alternator failure when running two > Pmags on their internal alternators. For example, when I'm doing the > mag check with 14V power removed and both Pmags are running on > internalalternators, if I turn off the p-lead switch to one Pmag > (that Pmag is > now totally inoperative), will there be an RPM drop or other > indicationthat the chosen Pmag is not working? > Even if there is no indication, I still intend to do the check because > if one internal alternator has failed, then the only way to know > may be > to switch each Pmag completely off and check for continued > operation on > one internal alternator. > > Experimental aviation is challenging. Fortunately, the original OBAM > builders (the Wright brothers) succeeded with each challenge. > Surely we > can, too. > > Off subject - I assume from your comment re:seminar that you live in > Alaska. My son in moving to AK in spring of next year to fly the > F-22 > and we are looking for a Piper Pacer to put on floats. Any leads? > > Stan Sutterfield > www.rv-8a.net > > Erich, > > I had the pleasure of attending Bob's seminar this past weekend > and I > asked him > about this very same issue. > > First the caveat. I am not an engineer and don't claim to know a whole > lot about > electrical theory or application. What I am is curious and I do > have an > E and > a P/mag. > > After reading everything I can get my hands on and studying the Z > figures Z-13 > and Z-33 for the Maintenance hand prop option I can detect only subtle > differences. > > Emag powers the mags directly from the main bus, so when you turn > on the > master > there is power at the mags. The switches on the panel for the > emags are > for P-lead > kill switches. To do maintenance (timing) all you have to do is > turn on > the master and leave the panel switch off. But to check the alternator > part of > the P-Mag you have to put a separate switch in line with the power > supply to > the mag. When you do a run up check, you turn this switch off and > if all > is well > the motor keeps on humming. > > Bob's design has the power go to a switch first. The positions on the > switch are > down is off, middle is for internal power, up is for ships power. > In the > Z-33 > schematic you then have to add a switch (and possibly a light) to be > able to > cut the P-lead so you can do maintenance (Timing). So to do the > internalalternator > check all you have to do is flick the switch to the middle > position and > if all is well you can't tell the difference. > > So what's the big difference. Both systems use 3 switches. Both > systemsdo the > same thing just in slightly different ways. > > Personally I can see an advantage in the Emag system where each > mag has > it's own > P-lead ground kill switch. Starting sequence should be pretty easy. > Master on, > both switches in the up position, mash the start button. > > But I am a confirmed Nuckoll's advocate and I want to see what he > has to > say about > this. He is still here in Alaska and touring around visiting the > sights.He > has assured me that when he gets back he will dig into this and > providehelp. > > I have sent an email to Emagair asking the same questions. Open dialog > on this > question can only help us and Emagair greatly. > > I have not personally heard from the guys at Emagair nor have I read > anything directly > from them concerning this issue. Until I do I will keep an open mind. > > > Perhaps this issue is a non-event and some of the problems stem > from us > folks in > the field still trying to make these new mags act like the old style. > For instance > how can you perform a mag drop check if there isn't one. Perhaps the > answer > is who cares. I don't know but I am sure interested in how this turns > out. > > Please comment at will. Any dialog is appreciated. > > Mike Ice > > > > > > _____ > > <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> > . > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > > > href="http://www.matronics.com/Navigator?AeroElectric- > List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > ________________________________________________________________________________
Subject: B&C SD 8 Alternator
Date: Aug 16, 2007
Harley, et al, I have a friend with a Pitts who has a SD 8 as his only power source other than the battery. He has no electronics other than a radio and the starter. His SD 8 is more than adequate to run the radio with enough current left over to charge the battery. The only concern I would have with the SD 8 or the SD 20 as a sole power source is that both require fairly high RPM to produce adequate current for much of anything. Our usual high amp alternators produce enough juice at idle to charge the battery. Charlie Brame RV-6A N11CB San Antonio -------------------------------------------------- > From: Harley <harley(at)AgelessWings.com> > Subject: AeroElectric-List: B&C SD 8 Alternator > > > Morning, Everyone... > > Now that I'm dumping all my remaining vacuum instruments (the one I > have > left!) and the associated pump and gauge, and settling for an all > electric panel (except for the static gauges), I am starting to > look at > alternator options. > > I've kept up on the past discussions here, and Bob's Connection info, > and have a pretty good > idea of what's involved. > > But, I just noticed the B&C model SD-8 alternator that fits on the > vacuum pump pad! What a great replacement for a gasket and a cover! > > I also see that Bob does mention it's use in one of his articles, > but as > a backup alternator. > > Seeing that the original Long Ez plans call out an alternator only > as an > option if you plan on IFR or night flying, or if you use a starter, > and > strongly recommend just the VariEZE solar panel to keep the battery > charged, has anyone here installed the SD-8 and used it as the main > unit. It only has a maximum 10 amp output, and a nominal 8 amp, but I > would think that would be enough to keep the battery charged and > operate > the newer low current instruments quite well. > > I have yet to calculate my panel's consumption (don't have all the > instruments yet), let alone the plane's, so it's still in the planning > stage. Open to all suggestions. Redundancy is always best, but if > one > can save some weight and still do the job (I also have two P-mags with > their own generators so the engine should keep running on the > electronic > ignition even if the battery and alternator go down) then I'm all > for it. > > Harley Dixon > ________________________________________________________________________________
Subject: Nav/com 'acoustic feedback'
Date: Aug 16, 2007
From: "Miskelly, Francis G" <f.miskelly(at)imperial.ac.uk>
Thanks Matt Answers (in italics) to your questions below - Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather Sent: Wed 15/08/2007 23:27 Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' I'm still not sure whether it's electrical noise or acoustic noise - since covering the mic has some effect on the behavior. If it were just acoustic, covering the mic should stop the noise. More questions: I suspect its not acoustic as it doesn't affect my handheld ICOM and the a/c is not that noisy - Is the acoustic squelch on the intercom adjustable? Can you set the threshold higher? Maybe pulling out the volume knob and turning it adjusts that? Or is it dynamic/smart adjusting? I don't know how to adjust the intercom volume. I presume it is adjustible. Pulling out the volume knob takes off the automatic squelch. There is no obvious knob to adjust the intercom vol. - What kind of engine is it? Its a Lycoming 0-320 with 150hp - Does it have separate ignition systems? Can you turn one off at a time (to help isolate electrical noise)? It has 2 mags and i've tried both separately - no effect - Can you turn the alternator off with the engine running? Turning off alternator - no effect - You probably answered this before, but with the engine off, does the intercom appear to work properly? Speaking in the mic on one headset yields sound coming from the other headset - using the radio sidetone? With the engine off the radio is perfect. No intercom problems. Perfect reception and transmit - Are you able to transmit/receiver properly when the engine is off? - Are the mic leads made with shielded wire? Mic leads are not shielded. They are 2 twisted wires - Do other aspects of the electrical system all appear to function normally - bus voltage, nav signals, etc? All other parts of electrics are fine Bob often recommends powering from a separate battery the piece(s) of equipment that are involved in the problem. A couple of lantern batteries could be used to power the radio while the engine is running.. If that has any effect on the noise, it indicates that the problem is conducted to the radio via the power bus. Tried that from a separate 12V battery - no effect What would be slick for this kind of online debug process would be to have an online spreadsheet or form which could be used to document the problem, behaviors, and the things that have been tried in order to fix it.. Have to ponder that a bit. I've changed the antenna, power supply, headsets, earthed everything possible and checked all the earths. The problem of feedback only occurs when i plug in the mic jack when the engine is running. I have a handheld ICOM which uses the same power supply and aerial yet it works perfectly. It has no intercom. I plan to disconnect the intercom this weekend to see whether the problem disappears. Regards, Matt- > 1. The radio is a Bendix/King KX155 > 2. It is approximately 1 year old. Don't know the model # but could find > out > 3. It definately has an internal intercom but i've no links to describe it > 4. I didn't check whether the sound varied depending on where your > head/headset is sitting, or by > bending the wires around on the headset, or the wires to the jack but it > occurred with 3 separate headsets and on both pilot and co-pilot outputs. > Pretty sure its not a headset problem as same headsets work fine in other > planes > 5. The noise gets worse with higher engine RPM but is very obvious even at > 1000 RPM. The character doesn't change - just its loudness > Many thanks > Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt > Prather > Sent: Mon 13/08/2007 22:29 > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' > > > > > Interesting.. I wasn't aware that any KX155 has intercom. Okay. I see > the manual says it has 500ohm aux inputs, but don't see any reference to > intercom. We're talking about a Bendix/King KX-155, right? Do you have a > link to a file which describes the feature? > > Does the sound vary depending on where your head/headset is sitting, or by > bending the wires around on the headset, or the wires to the jack? > > Is the frequency of the whine/feedback dependent on the engine RPM? Or is > it just a steady tone? > > I agree with item 3 (assuming an intercom). > > > Regards, > > Matt- > > >> Matt >> 1. When i cover the mic with my hand (muff off) the character of the >> feedback alters significantly but is not overall reduced. If i move the >> boom away from my mouth and around to the back of my head then the >> feedback reduces but doesn't disappear. Its worse (louder) the closer >> the >> boom to my mouth. These symptoms occur on both left and right hand >> headsets >> 2. My KX155 has an internal intercom. I haven't tried to disconnect it. >> 3. Plugging in the mic jack should activate the intercom and the >> transmit >> on the radio (when PTT pressed) >> 4. Remember the problem only occurs when the engine is running. >> 5. Does anyone know how to adjust the mic gain (intercom volume control) >> on the KX155? Couldn't find this info in the installation manual. >> Kind regards >> Frank >> >> >> >> >> ________________________________ >> >> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt >> Prather >> Sent: Mon 13/08/2007 20:12 >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: Nav/com 'acoustic feedback' >> >> >> >> >> >> Does it help if you cover the mic with your hand (both sides - pull the >> muff off)? >> >> I suspect that the input stage of your intercom is being overdriven by >> the >> acoustic noise of the engine. >> >> >> >> Regards, >> >> Matt- >> >>> Thanks for your comments Ernest. >>> I've double-checked all the grounds i could find. Even took the whole >>> harness out (which was new) and had it double-checked. Nothing found. >>> If its the intercom in the radio why does it not cause the same problem >>> when the engine is off? >>> It only causes the problem when the engine is running >>> Kind regards >>> Frank >>> >>> ________________________________ >>> >>> From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ernest >>> Christley >>> Sent: Mon 13/08/2007 15:04 >>> To: aeroelectric-list(at)matronics.com >>> Subject: Re: AeroElectric-List: Nav/com 'acoustic feedback' >>> >>> >>> >>> >>> >>> Miskelly, Francis G wrote: >>>> The KX155 nav/com in my Glastar has 2 problems which may be related. >>>> >>>> 1. Inserting the headphone jack i have near perfect reception. >>>> However, when i insert the microphone jack there is a loud whine >>>> suggestive of 'acoustic feedback'. Moving the boom away from my mouth >>>> reduces the whine. With a different headset it appears as lots of >>>> static noise which again changes with position of the boom. I've >>>> changed the aerial, power supply and checked all the earths. It occurs >>>> with either mag and when the generator is disconnected. It only >>>> happens when the engine is running. The radio's been bench tested and >>>> passed as good. >>>> >>>> 2. Radio reception is good with just the headphone jack inserted. >>>> However, insert the microphone jack and reception becomes very poor or >>>> disappears completely. I suspect the 'acoustic feedback' is raising >>>> the automatic squelch which is cutting off the radio station >>>> >>>> Can anyone suggest an explanation and a solution! >>>> Many thanks >>>> Frank >>> Since there is a problem with multiple headset, I would check the jack >>> first. The symptoms seem to imply some feedback from the mic to the >>> audio. Look for a short or a broken ground. Beyond that, it would >>> seem >>> circuitry withing the intercom is fritzed, and it gets much more >>> complicated. >>> >>> >>> >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >> > > <http://www.matronics.com/Navigator?AeroElectric-List> ________________________________________________________________________________
Date: Aug 16, 2007
Subject: strobe whine noise
FWIW powering my strobes from separate batteries made no difference to the audio whine that I was hearing from them. Adding some homemade filter devices likewise had no effect so I guess I did not hit on the best component values. I never did find a ground issue that I could blame the problem on. And yet when I finally obtained and tried a cheap automotive filter on the 12 volt feed to the strobes, the situation improved markedly and I can no longer hear the strobes in flight. The directions said to try reversing the filter leads for best effect. Sure enough the filter only worked well in one direction. Grounding the ground connection to the filter also had no effect. Ken >snip >Bob often recommends powering from a separate battery the piece(s) of >equipment that are involved in the problem. A couple of lantern batteries >could be used to power the radio while the engine is running.. If that >has any effect on the noise, it indicates that the problem is conducted to >the radio via the power bus. Tried that from a separate 12V battery - no effect > > snip ________________________________________________________________________________
Date: Aug 16, 2007
Hi Ken How and where did you insert the filter into the 12V feed to the strobes? Sounds like you inserted it 'in line' to the strobes. Its interesting you inserted the filter before the strobes and yet it reduced the interference in your radio. How do you explain that? - Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ken Sent: Thu 16/08/2007 14:45 Subject: AeroElectric-List: strobe whine noise FWIW powering my strobes from separate batteries made no difference to the audio whine that I was hearing from them. Adding some homemade filter devices likewise had no effect so I guess I did not hit on the best component values. I never did find a ground issue that I could blame the problem on. And yet when I finally obtained and tried a cheap automotive filter on the 12 volt feed to the strobes, the situation improved markedly and I can no longer hear the strobes in flight. The directions said to try reversing the filter leads for best effect. Sure enough the filter only worked well in one direction. Grounding the ground connection to the filter also had no effect. Ken >snip >Bob often recommends powering from a separate battery the piece(s) of >equipment that are involved in the problem. A couple of lantern batteries >could be used to power the radio while the engine is running.. If that >has any effect on the noise, it indicates that the problem is conducted to >the radio via the power bus. Tried that from a separate 12V battery - no effect > > snip ________________________________________________________________________________
Date: Aug 16, 2007
When tackling a noise problem, it sometimes makes sense to clean up the victim, but sometimes it also works to clean up the noise source. In this case, it sounds like the transient current load presented by the strobes was causing noise to be added to the audio signal of the comm system (ground/supply noise). Adding a filter to the strobe circuit likely reduced the transient load on the bus, decreasing the noise signal seen by the audio system. Wiring a power supply filter depends on the components in the filter. If it is just a choke (coil - inductance), in-line works. If it's a 2nd (or higher) order filter - has a cap, the filter will need to be both inline and have a connection to ground. Regards, Matt- > Hi Ken > > How and where did you insert the filter into the 12V feed to the strobes? > Sounds like you inserted it 'in line' to the strobes. > > Its interesting you inserted the filter before the strobes and yet it > reduced the interference in your radio. How do you explain that? > > - Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ken > Sent: Thu 16/08/2007 14:45 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: strobe whine noise > > > FWIW powering my strobes from separate batteries made no difference to > the audio whine that I was hearing from them. Adding some homemade > filter devices likewise had no effect so I guess I did not hit on the > best component values. I never did find a ground issue that I could > blame the problem on. And yet when I finally obtained and tried a cheap > automotive filter on the 12 volt feed to the strobes, the situation > improved markedly and I can no longer hear the strobes in flight. The > directions said to try reversing the filter leads for best effect. Sure > enough the filter only worked well in one direction. Grounding the > ground connection to the filter also had no effect. > Ken > >>snip >>Bob often recommends powering from a separate battery the piece(s) of >>equipment that are involved in the problem. A couple of lantern >> batteries >>could be used to power the radio while the engine is running.. If that >>has any effect on the noise, it indicates that the problem is conducted >> to >>the radio via the power bus. Tried that from a separate 12V battery - no >> effect >> >> > snip > > ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Off Subject Question
Date: Aug 16, 2007
Sorry about the diversion, but I am certain some of you can solve my problem. I have Direct TV and one of my sets uses a UHF remote control. The remote is used about 30 feet and through 2 block walls from the receiver. It barely works and is very frustrating. What can I do to improve the reception of this remote? Is there some homemade way to increase The antenna gain? Thanks for your help! Bill B ________________________________________________________________________________
Subject: Loss of essential bus
Date: Aug 16, 2007
I have an intermittent loss of the essential bus in my RV-8. I have wired it similar to Bob's Z-11 Generic Light Aircraft Electrical System except that I have added an aux battery as depicted in his Z-30 diagram, as I have dual electronic ignition. I suspect that the problem is in the diode that prevents reverse current when the essential bus alternate feed switch is turned on. My question: Is it possible that this diode is defective and could cause intermittent loss of the essential bus? When it occurs, the current is almost immediately restored without any action on my part, but it does cause all the avionics to reboot. It occurs without warning and I cannot trust it in IFR conditions. Any suggestions? Thanks. Ron Schreck RV-8, "Miss Izzy" Gold Hill Airpark, NC ________________________________________________________________________________
Subject: P-Lead Routing
Date: Aug 16, 2007
Is it an acceptable practice to route P-Leads trough the firewall alongside other power supply cables? I read somewhere (Tony Bingelis Books, I think) that shielded cables should not run alongside other cables. Thanks, Mike Creek ________________________________________________________________________________
Date: Aug 16, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Aeroelectric Connection Book
> >Hi all > >Can anyone confirm if Bob is still active? I ordered his book over a month >ago and received a confirmation email but have still not received the book >in the mail. I've sent Bob a chaser via his web page but got no reply... Sorry for the delay. We were preoccupied with shepherding my father through his last days and had a long trip to do the Alaska seminar right on the heals of Dad's funeral. I promise to chain my self to the order 'puter tomorrow and get 100% caught up. Bob . . . ________________________________________________________________________________
Date: Aug 16, 2007
I think I can speak for most all others when I say: Thanks Bob, now stop and take deeeep breath. We all want what we want and most often we want it right now! Rest easy fella . What we want from you can wait a day or maybe even two.....but don't push it eh g-) Jim in Kelowna ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Sent: Thursday, August 16, 2007 6:55 PM Subject: Re: AeroElectric-List: Aeroelectric Connection Book > > > >> >>Hi all >> >>Can anyone confirm if Bob is still active? I ordered his book over a month >>ago and received a confirmation email but have still not received the book >>in the mail. I've sent Bob a chaser via his web page but got no reply... > > Sorry for the delay. We were preoccupied with shepherding my > father through his last days and had a long trip to do the > Alaska seminar right on the heals of Dad's funeral. I promise > to chain my self to the order 'puter tomorrow and get 100% > caught up. > > Bob . . . > > > ________________________________________________________________________________
Date: Aug 17, 2007
Many thanks for the explanation Matt - Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Matt Prather Sent: Thu 16/08/2007 17:23 Subject: RE: AeroElectric-List: strobe whine noise When tackling a noise problem, it sometimes makes sense to clean up the victim, but sometimes it also works to clean up the noise source. In this case, it sounds like the transient current load presented by the strobes was causing noise to be added to the audio signal of the comm system (ground/supply noise). Adding a filter to the strobe circuit likely reduced the transient load on the bus, decreasing the noise signal seen by the audio system. Wiring a power supply filter depends on the components in the filter. If it is just a choke (coil - inductance), in-line works. If it's a 2nd (or higher) order filter - has a cap, the filter will need to be both inline and have a connection to ground. Regards, Matt- > Hi Ken > > How and where did you insert the filter into the 12V feed to the strobes? > Sounds like you inserted it 'in line' to the strobes. > > Its interesting you inserted the filter before the strobes and yet it > reduced the interference in your radio. How do you explain that? > > - Frank > > ________________________________ > > From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ken > Sent: Thu 16/08/2007 14:45 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: strobe whine noise > > > FWIW powering my strobes from separate batteries made no difference to > the audio whine that I was hearing from them. Adding some homemade > filter devices likewise had no effect so I guess I did not hit on the > best component values. I never did find a ground issue that I could > blame the problem on. And yet when I finally obtained and tried a cheap > automotive filter on the 12 volt feed to the strobes, the situation > improved markedly and I can no longer hear the strobes in flight. The > directions said to try reversing the filter leads for best effect. Sure > enough the filter only worked well in one direction. Grounding the > ground connection to the filter also had no effect. > Ken > >>snip >>Bob often recommends powering from a separate battery the piece(s) of >>equipment that are involved in the problem. A couple of lantern >> batteries >>could be used to power the radio while the engine is running.. If that >>has any effect on the noise, it indicates that the problem is conducted >> to >>the radio via the power bus. Tried that from a separate 12V battery - no >> effect >> >> > snip > > ________________________________________________________________________________
Date: Aug 17, 2007
Subject: Re: Headset plug polarity
Bill Bradburry wrote: > > I am amazed at the difficulty in finding the polarity on the internet. Can > someone help me here? > > What should be the polarity of the sleeve, ring, and tip on a stereo plug? > Which, ring or tip, is probably right and which is probably left on the > stereo plug? > > Also what should be the polarity of the sleeve and tip on the mono plug. > > How should I wire a stereo receptacle so that it could be used for both > stereo or mono? > > Thanks, > Bill B Hi Bill, I think that my email messages have been wandering around in Ted Stevens' "pipes" for days before being delivered to me. There's a simple way to check right/left wiring in a connector. Grab a 1 1/2V battery, a couple of clip leads & your stereo headset. Put the headset on your head, but offset the earcups so they aren't over your ears. Connect one terminal from the battery to the sleeve (closest to the insulated end & wire). Touch the other terminal of the battery to the tip of the connector. The side that clicks as you make & break the connection is wired to the tip. Assuming that you are wearing the headset correctly, you now know how the connector should be wired. To get the right terminal on the jack, just remember that the tip is farthest from the nut and follow the metal to the solder tab. Same principle for ring & sleeve in the jack. There isn't really any practical way to wire a stereo connector for both stereo & mono. You can set it up with a switch, but then you're dependent on remembering to set the switch correctly. Charlie ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Re: strobe whine noise
Hi Frank Yes the filter is in line with the strobe power after the power switch. My best theory is similar to Matt's and that the noise is coming in via the common grounds. It is a metal airframe and the strobe power supplies are internally grounded to their metal cases, same as the radio and the intercom. The headphone jacks are isolated from ground. Everything except the strobes has a ground wire to the forrest of tabs on the firewall. Since the ground connection on the filter has no effect, it seems to me that it can't be a capacitor in the filter that is helping. And yet reversing the filter leads does make a difference which seems an unlikely result to me. I don't think there can be anything else other than a choke (inductor) in the filter?? If I was still building I think I would try electrically insulating the strobe power supplies from the airframe with plastic washers and bolts. I seem to recall opening the aeroflash units when I installed them but I must have decided that their grounds could not be easilly separated from the case, or it did not seem worth the effort at the time. The strobe heads are mounted in fibreglass wingtips so they should already be isolated from the airframe. Ken Matt Prather wrote: > >When tackling a noise problem, it sometimes makes sense to clean up the >victim, but sometimes it also works to clean up the noise source. In this >case, it sounds like the transient current load presented by the strobes >was causing noise to be added to the audio signal of the comm system >(ground/supply noise). Adding a filter to the strobe circuit likely >reduced the transient load on the bus, decreasing the noise signal seen by >the audio system. > >Wiring a power supply filter depends on the components in the filter. If >it is just a choke (coil - inductance), in-line works. If it's a 2nd (or >higher) order filter - has a cap, the filter will need to be both inline >and have a connection to ground. > > >Regards, > >Matt- > > > >>Hi Ken >> >>How and where did you insert the filter into the 12V feed to the strobes? >>Sounds like you inserted it 'in line' to the strobes. >> >>Its interesting you inserted the filter before the strobes and yet it >>reduced the interference in your radio. How do you explain that? >> >> - Frank >> >>________________________________ >> >>From: owner-aeroelectric-list-server(at)matronics.com on behalf of Ken >>Sent: Thu 16/08/2007 14:45 >>To: aeroelectric-list(at)matronics.com >>Subject: AeroElectric-List: strobe whine noise >> >> >> >> >>FWIW powering my strobes from separate batteries made no difference to >>the audio whine that I was hearing from them. Adding some homemade >>filter devices likewise had no effect so I guess I did not hit on the >>best component values. I never did find a ground issue that I could >>blame the problem on. And yet when I finally obtained and tried a cheap >>automotive filter on the 12 volt feed to the strobes, the situation >>improved markedly and I can no longer hear the strobes in flight. The >>directions said to try reversing the filter leads for best effect. Sure >>enough the filter only worked well in one direction. Grounding the >>ground connection to the filter also had no effect. >>Ken >> >> >> >>>snip >>>Bob often recommends powering from a separate battery the piece(s) of >>>equipment that are involved in the problem. A couple of lantern >>>batteries >>>could be used to power the radio while the engine is running.. If that >>>has any effect on the noise, it indicates that the problem is conducted >>>to >>>the radio via the power bus. Tried that from a separate 12V battery - no >>>effect >>> >>> >>> >>> >>snip >> >> ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Re: P-Lead Routing
>Is it an acceptable practice to route P-Leads trough the firewall >alongside other power supply cables? I read somewhere (Tony Bingelis >Books, I think) that shielded cables should not run alongside other cables. > > The reason they are shielded is so that you CAN route them with other cables. However, be sure to ground shield at one end only (engine end) and use the shieled to PROVIDE GROUND at the switch end as illustrated in numerous z-figures. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Re: Loss of essential bus
>I have an intermittent loss of the essential bus in my RV-8. I have wired >it similar to Bob's Z-11 Generic Light Aircraft Electrical System except >that I have added an aux battery as depicted in his Z-30 diagram, as I >have dual electronic ignition. I suspect that the problem is in the diode >that prevents reverse current when the essential bus alternate feed switch >is turned on. My question: Is it possible that this diode is defective >and could cause intermittent loss of the essential bus? I've never seen a diode go intermittently open . . . but that doesn't mean it absolutely cannot happen however it's hard to imagine how. > When it occurs, the current is almost immediately restored without any > action on my part, but it does cause all the avionics to reboot. It > occurs without warning and I cannot trust it in IFR conditions. Any > suggestions? Thanks. I'd suspect a loose connection first. There's not many. Check them all. As long as your crawling around under there . . . you could consider replacing both wires (fresh crimps) and a new diode. In any case, the problem cannot be terribly difficult, it doesn't involved much hardware. Bob . . . ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Rotax Voltage Regulator
All, It looks like my Rotax 582 three phase voltage regulator's dying. (It will occasionally go over voltage. I can re-set it and get it to work, but it's happening more often now.) Does anyone have a recommended replacement? I've mounted it in the engine compartment to minimize electrical noise in the cockpit and I suspect things are a little hot for the stock Rotax unit. Has anyone tried any of the Harley replacements? Any after-market units? Or should I just increase the cooling to the Rotax unit? Thanks, Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Subject: Coax Diameter
Date: Aug 18, 2007
Can someone advise me what is the diameter of RG400 and RG58 Coax? I'm planning antenna runs for my RV6A and looking to see how big my wire bundle may be getting. Thanks. Marty in Brentwood TN ________________________________________________________________________________
Subject: Re: Rotax Voltage Regulator
Date: Aug 18, 2007
Guy, Are you sure its not the battery geeting aged. regulators dont usually deteriorate in the way you describe, but a poor internal resistance battery may bring on the symptom. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=129762#129762 ________________________________________________________________________________
Date: Aug 18, 2007
Subject: Re: Coax Diameter
My RG-400 measures 0.195" diameter. Emrath wrote: > >Can someone advise me what is the diameter of RG400 and RG58 Coax? I'm >planning antenna runs for my RV6A and looking to see how big my wire bundle >may be getting. Thanks. > > >Marty in Brentwood TN > > ________________________________________________________________________________
Date: Aug 18, 2007
At 04:53 PM 8/18/2007, you wrote: >Are you sure its not the battery geeting aged. regulators dont >usually deteriorate in the way you describe, but a poor internal >resistance battery may bring on the symptom. I'm intrigued, since this battery has been nearly dead twice and resurrected with a BatteryMinder. I read Bob's section on regulator failures and it seems like the over-voltage condition should be permanent, and not intermittent. (It seems like it doesn't work when cold, then with my switching it in and out it finally starts to regulate the voltage. Once it's working it never quits. And if I re-start it seems to work fine.) I'll dig into Bob's book to try to find an easy way to check internal resistance. Thanks, Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Aug 18, 2007
In a message dated 08/17/2007 10:06:34 PM Central Daylight Time, ceengland(at)bellsouth.net writes: There isn't really any practical way to wire a stereo connector for both stereo & mono. You can set it up with a switch, but then you're dependent on remembering to set the switch correctly. >>> My understanding as well. I installed mono & stereo jacks on my plane using a switching mono plug that ties L&R channels together when the plug is inserted, and used a spring-loaded cover on the stereo jack with a lable stating "Stereo Only" on it. One way to git a kitty rug! Diagram available on AutoCAD if interested... >From The PossumWorks in TN Mark Phillips http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 19, 2007
> >At 04:53 PM 8/18/2007, you wrote: >>Are you sure its not the battery geeting aged. regulators dont usually >>deteriorate in the way you describe, but a poor internal resistance >>battery may bring on the symptom. > >I'm intrigued, since this battery has been nearly dead twice and >resurrected with a BatteryMinder. I read Bob's section on regulator >failures and it seems like the over-voltage condition should be permanent, >and not intermittent. (It seems like it doesn't work when cold, then with >my switching it in and out it finally starts to regulate the voltage. Once >it's working it never quits. And if I re-start it seems to work fine.) >I'll dig into Bob's book to try to find an easy way to check internal >resistance. > >Thanks, > > >Guy Buchanan Intermittent voltage excursions both upward and downward are manifestations of ageing components and/or internal connections that have become less than the best we know how to do. I believe John Deere (and others) offer a 3-phase rectifier/regulator for their 25-40 amp PM alternators. I searched the web hoping to find some maintenance data or at least some part numbers. No joy. Anyone out there have some experience with the larger 3-phase PM alternator products. I've got to visit a customer Monday on the west side of town near a John Deere dealership. I'll see if there's a helpful individual there who can give me more data on the larger PM alternator systems. Now, this is an excellent DIY project. We've explored the inner workings of the various PM alternator rectifier/ regulators. I've taken an exemplar single phase R/R schematic and added the SCR and diode to accommodate a 3 phase alternator. It's posted at: http://www.aeroelectric.com/Pictures/Schematics/3-Phase_PM_Rectifier_Regulator.gif This is a case where the electronics are pretty much a no-brainer but the task to be mounted and solved is getting the heat out. Average voltage drop in one of these regulators is 2.2 volts. So if you're dragging 30A from a really husky alternator, the R/R needs to get rid of 66W of heat. This is where attention is paid to the diodes and SCRs to use beefy devices with low thermal resistances and then mount them in an enclosure suited for conducting that much heat out of the box. Problems with longevity of the PM R/R have roots more in cooling than in the absolute ratings of the components. For this design, I might even consider putting the hot parts on a finned heat sink and blowing air through the assembly. There's a wealth of 12V DC brushless fans out there to consider. I think I'd also add some form of temperature sensing to at least light a warning light and allow the pilot to consider a temporary load reduction. Just some food for thought. As soon as the support tools and materials for our hardwood floor project are out of the garage, I'll get started on the alternator drive stand . . . should be able to run some experimental regulator/alternator combinations on the bench this fall. Bob . . . ________________________________________________________________________________
Date: Aug 19, 2007
> >Hi Frank > >Yes the filter is in line with the strobe power after the power switch. > >My best theory is similar to Matt's and that the noise is coming in via >the common grounds. It is a metal airframe and the strobe power supplies >are internally grounded to their metal cases, same as the radio and the >intercom. The headphone jacks are isolated from ground. Everything except >the strobes has a ground wire to the forrest of tabs on the firewall. >Since the ground connection on the filter has no effect, it seems to me >that it can't be a capacitor in the filter that is helping. And yet >reversing the filter leads does make a difference which seems an unlikely >result to me. I don't think there can be anything else other than a choke >(inductor) in the filter?? > >If I was still building I think I would try electrically insulating the >strobe power supplies from the airframe with plastic washers and bolts. I >seem to recall opening the aeroflash units when I installed them but I >must have decided that their grounds could not be easilly separated from >the case, or it did not seem worth the effort at the time. The strobe >heads are mounted in fibreglass wingtips so they should already be >isolated from the airframe. Hmmmm . . . grounds contribute to noise issues ONLY when sensitive potential victims share TWO or more ground paths. If you have immediate access to the power supplies, try the dry-battery experiment again with the battery located right at the power supply and grounded locally to the power supply. There's something we're not seeing here. I presume that your power supply does ground locally and doesn't have a second wire running all the way to the firewall ground bus???? Bob . . . ________________________________________________________________________________
Date: Aug 19, 2007
Subject: Re: B&C SD 8 Alternator
> >Harley, et al, > >I have a friend with a Pitts who has a SD 8 as his only power source >other than the battery. He has no electronics other than a radio and >the starter. His SD 8 is more than adequate to run the radio with >enough current left over to charge the battery. > >The only concern I would have with the SD 8 or the SD 20 as a sole >power source is that both require fairly high RPM to produce adequate >current for much of anything. Our usual high amp alternators produce >enough juice at idle to charge the battery. Which is no worse than generators used to offer. There are hundreds of OBAM light aircraft flying with vacuum pump driven alternator products from B&C as their sole source of engine driven power. These are, of course, mostly day VFR aircraft. A few night VFR too . . . but if one had LED based position and strobes, then perhaps night VFR on 8A would be quite comfortably managed. It can be done now and is going to get easier in the near future. Bob . . . ________________________________________________________________________________
Date: Aug 19, 2007
Subject: My vacuum instruments for sale on eBay
Good Morning... After the successful ending of my iPaq/Anywhere Map listing on eBay, and the decision to finally join the high technology age and have an all electric panel, I am now offering the entire vacuum system that I no longer need on eBay starting today. After these end in 10 days, this should be the end of my Long EZ related eBay listings for some time! I hope! I've already replaced the directional gyro with an electric one, and only have the artificial horizon left to replace, but I am working on that. So, anything that has to do with the vacuum system is going, including the AH. Here are direct links to the eBay pages where I am offering them...note that there is no reserve, and I am starting them all ridiculously low, so they WILL sell, and someone will get real bargains. All the details about each one and their conditions and photos are in their respective eBay listings. You can also link to each item at the bottom of each listing. Artificial Horizon http://tinyurl.com/2d269m Directional gyro http://tinyurl.com/yq5mgg Vacuum Pump http://tinyurl.com/yp9gkf (The description includes a link to a great tutorial on vacuum pumps) Vacuum Gage http://tinyurl.com/22tl5r Harley Dixon Long EZ N28EZ Airport, Hangar 29 Canandaigua, NY ________________________________________________________________________________
Date: Aug 19, 2007
Thanks Ken Marty From: Ken <klehman(at)albedo.net> Subject: Re: AeroElectric-List: Coax Diameter My RG-400 measures 0.195" diameter. Emrath wrote: > >Can someone advise me what is the diameter of RG400 and RG58 Coax? I'm >planning antenna runs for my RV6A and looking to see how big my wire >bundle may be getting. Thanks. > > >Marty in Brentwood TN ________________________________________________________________________________
Date: Aug 19, 2007
They are essentially the same. For sure interchangeable. Paul ========= At 04:29 PM 8/18/2007, you wrote: > >Can someone advise me what is the diameter of RG400 and RG58 Coax? I'm >planning antenna runs for my RV6A and looking to see how big my wire bundle >may be getting. Thanks. > > >Marty in Brentwood TN > > ________________________________________________________________________________
Date: Aug 19, 2007
Hi Mark I am totally deaf in one ear and always have trouble with stereo headsets. I feel like I am only hearing half the world! Do you know of a commercially available adapter that would ALWAYS combine the signals on a standard aviation headset? While we are on the subject.....it is even a bigger problem with my MP3 player. It has a little 1/8 (?) inch stereo jack. Do you know of any full time, stereo to mono, adaptors for that? Thanks Brooke ----- Original Message ----- From: Fiveonepw(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Saturday, August 18, 2007 11:41 PM Subject: Re: AeroElectric-List: Headset plug polarity In a message dated 08/17/2007 10:06:34 PM Central Daylight Time, ceengland(at)bellsouth.net writes: There isn't really any practical way to wire a stereo connector for both stereo & mono. You can set it up with a switch, but then you're dependent on remembering to set the switch correctly. >>> My understanding as well. I installed mono & stereo jacks on my plane using a switching mono plug that ties L&R channels together when the plug is inserted, and used a spring-loaded cover on the stereo jack with a lable stating "Stereo Only" on it. One way to git a kitty rug! Diagram available on AutoCAD if interested... From The PossumWorks in TN Mark Phillips ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Date: Aug 19, 2007
At 08:47 8/19/2007, you wrote: >I am totally deaf in one ear and always have trouble with stereo >headsets. I feel like I am only hearing half the world! Do you >know of a commercially available adapter that would ALWAYS combine >the signals on a standard aviation headset? While we are on the >subject.....it is even a bigger problem with my MP3 player. It has >a little 1/8 (?) inch stereo jack. Do you know of any full time, >stereo to mono, adaptors for that? > >Thanks > >Brooke One "always works" solution I've seen on at least one commercial headset was the inclusion of a switch somewhere on/in the headphone or cable that took the wire normally connected to the ring of the connector and electrically moved it to parallel the wire connected to the tip. Both earphone transducers were then parallel on the tip, with the common return on the sleeve. Downside; the impedance seen by the intercom/radio driving the headphones in now only half what it was and this may be a problem, but generally far less than shorting out the left and right outputs of some amplifier to one another. A SPDT (3-terminal) switch mounted in an ear cup could easily suffice. Ron Q. ________________________________________________________________________________
Date: Aug 19, 2007
The Mil Spec RG-58 and RG-400 we sell is about .195" or just a bit over 3/16". http://www.terminaltown.com/Pages/Coaxial%20Cable.html Regards, Gaylen Terminaltown.com ----- Original Message ----- From: "Emrath" <emrath(at)comcast.net> Sent: Saturday, August 18, 2007 5:29 PM Subject: AeroElectric-List: Coax Diameter > > Can someone advise me what is the diameter of RG400 and RG58 Coax? I'm > planning antenna runs for my RV6A and looking to see how big my wire > bundle > may be getting. Thanks. > > > Marty in Brentwood TN > > > ________________________________________________________________________________
Date: Aug 19, 2007
Brooke Wolf wrote: > Hi Mark > > I am totally deaf in one ear and always have trouble with stereo > headsets. I feel like I am only hearing half the world! Do you know of > a commercially available adapter that would ALWAYS combine the signals > on a standard aviation headset? While we are on the subject.....it is > even a bigger problem with my MP3 player. It has a little 1/8 (?) inch > stereo jack. Do you know of any full time, stereo to mono, adaptors > for that? > > Thanks > > Brooke > Google is your friend. http://www.google.com/search?num &hl=en&q=mono+to+stereo+headphone+adaptor&btnG=Search Charlie ________________________________________________________________________________
Date: Aug 19, 2007
Thanks Ken and Bob. I'll try Bob's suggestion of connecting both +ve and -ve of the battery to the radio later this week Bob - my radio has a +ve from the power bus and a -ve which grounds at the firewall ground bus. I suspect it also grounds locally - Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com on behalf of Robert L. Nuckolls, III Sent: Sun 19/08/2007 07:33 Subject: Re: AeroElectric-List: strobe whine noise > >Hi Frank > >Yes the filter is in line with the strobe power after the power switch. > >My best theory is similar to Matt's and that the noise is coming in via >the common grounds. It is a metal airframe and the strobe power supplies >are internally grounded to their metal cases, same as the radio and the >intercom. The headphone jacks are isolated from ground. Everything except >the strobes has a ground wire to the forrest of tabs on the firewall. >Since the ground connection on the filter has no effect, it seems to me >that it can't be a capacitor in the filter that is helping. And yet >reversing the filter leads does make a difference which seems an unlikely >result to me. I don't think there can be anything else other than a choke >(inductor) in the filter?? > >If I was still building I think I would try electrically insulating the >strobe power supplies from the airframe with plastic washers and bolts. I >seem to recall opening the aeroflash units when I installed them but I >must have decided that their grounds could not be easilly separated from >the case, or it did not seem worth the effort at the time. The strobe >heads are mounted in fibreglass wingtips so they should already be >isolated from the airframe. Hmmmm . . . grounds contribute to noise issues ONLY when sensitive potential victims share TWO or more ground paths. If you have immediate access to the power supplies, try the dry-battery experiment again with the battery located right at the power supply and grounded locally to the power supply. There's something we're not seeing here. I presume that your power supply does ground locally and doesn't have a second wire running all the way to the firewall ground bus???? Bob . . . ________________________________________________________________________________
From: "Hoffmann D- Remscheid" <Hoffmann.RS@T-Online.de>
Date: Aug 19, 2007
Rotax rectifier / regulators (and the other motorcycle types too) are not unproblematic. As Gilles found out by direct experiment at nominal power the maximum temperature for the 912 / 914 series R/R is minus 59=B0 Celsius: http://contrails.free.fr/elec_ducati.php This is somewhere in the vicinity of the liquid CO2, please forgive me that I cannot transfer it to Fahrenheit units by heart (;-). I used a standard 3" vent from a computer power unit mounted upon the cooling fins to make the system reliable, as Bob mentioned too. Nevertheless the power output of the 2 phase Rotax alternator is marginal. A friend experienced a trip of the main circuit breaker when operating the flaps at idle. Imagine what would have happened with an electrical dependent 914 engine. His Dynon and his GPS went black too (which is not an issue at the home airport). I am aware that he might beef up his 7Ah battery a little bit, too (;-) Increased use of glass panel instruments with reasonable brightness, strobes etc. would ask for a state-of-the-art generator system for the future. It is not very elegant to use a reduction gear and then mount a generator driven by a belt from the prop axis to increase rpms again. It is more elegant to mount a second generator the crankshaft itself rotating at some 5000rpm at the back of the 912/914, which has been done: http://contrails.free.fr/elec_second_alternateur.php If You can live with one sole generator providing sufficient power, the standard Rotax system should be modified. With the existing standard 2phase coil system I can imagine that a more modern regulator could work not at the frequency determined by engine rotation, but at a higher frequency as a real switching regulator with a corresponding higher efficiency; maybe some inductivity would have to be added. I would however prefer another way of solving the problem. As the rpm is high enough, why not integrate a common 3phase generator into the original site of the Rotax coils? One wound have to redesign the (presumably 9) stator coils for the given dimensions and add a rotor with coil. Add a standard regulator and You are done: greater power mainly because of better efficiency, no high frequency switching problems, standard technology and reliability, no belt to break, no hump in streamlined cowlings. Would be just a standard generator put into the Rotax. By the way: You could even get rid of any sliprings without any electric change at all. Honda has done that on their CB500f motorcycles even some years ago: http://www.autoschrauber.de/content/000058/image/limakomplett.jpg The only disadvantage is the introduction of an air gap. When reliability is an issue, that could be a good trade-off for aircraft use anyway: almost no moving parts J. As Bob already stated, it would be an excellent DIY - project - not without future potential. Richard ________________________________________________________________________________
Date: Aug 19, 2007
Subject: Switch ratings
Comments/Questions: Bob, I bought a bunch of rocker switches from Aircraft Spruce (P/N 14-100) for use in my RV-6A. The switches have a 120VAC rating of 20 Amps. AC43-13 says that AC ratings are different from DC ratings, so I am concerned as to whether these switches will be adequate for my uses. The highest current devices I am switching are the nav lights at 7.5 Amps. See: http://www.aeroelectric.com/articles/swtchrat.pdf and page 2 of http://www.aeroelectric.com/Reference_Docs/Eaton/toggle.pdf and page 2 of http://www.aeroelectric.com/Mfgr_Data/Switches/tl_series.pdf Virtually ALL switches have SOME rating at ANY voltage whether AC or DC. The fact that any given switch is marked on the side with 125VAC ratings is a testament to the fact that MORE switches are SOLD into the 125VAC domestic power market than for any other application. There's not enough room on the side of a switch to print ALL of it's capabilities so the fall-back position is to accommodate the greatest number of purchasers. Further, to exceed the published ratings by as much as 50% has little significance to us as OBAM aviation users where the average switch sees perhaps 100 operating cycles per year. The published ratings are for tens of thousands of cycles total. Most switches in personally owned, light aircraft die of effects having more to do with environment and chronological age than from operating stresses. The short answer is, "don't loose any sleep over switch ratings." Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 19, 2007
>Thanks Ken and Bob. I'll try Bob's suggestion of connecting both +ve and >-ve of the battery to the radio later this week >Bob - my radio has a +ve from the power bus and a -ve which grounds at the >firewall ground bus. I suspect it also grounds locally my suggested experiment was to power the strobe locally and leave it grounded . . . but your assertion raises another possibility. If the radio has an internal ground to chassis, then try simply removing the 'extra' ground to the firewall. You may be experiencing a rare but real situation that was addressed with the last upgrade to Z-15 in particular where the idea of an avionics ground ON THE PANEL was suggested for gathering all grounds for panel mounted devices together at a single point before extending the ground to the firewall. In fact, in the all metal airplane, the panel ground could be tied to the panel as an airframe ground . . . the extra wires to the firewall would not be beneficial. However, Getting all the panel grounds tied together on or near where the radios bring their internal grounds is a good thing to consider. MOST of the time, it's not an issue . . . which goes for the vast majority of installations in light aircraft since day-one. From time to time, situations like yours do arise where the standard cures for filtering and shielding have no effect and sometimes make it worse. When you finally discover the root cause of your noise it will be stone simple and probably have nothing to do with shielding or filtering. Bob . . . ________________________________________________________________________________
Date: Aug 19, 2007
Bob wrote: "if one had LED based position and strobes, then perhaps night VFR on 8A would be quite comfortably managed." This is a good point, and opens up the topic of LED position lights. I have a Jabiru J400, and the alternator is good for 20 amps max, closer to 15 amps continuous. I had planned to put an SD20 alternator on the crank splined shaft to get more total power, but the complication of two alternators and two batteries seemed far too great for what will be mainly a day and night VFR plane with pretensions. The Whelan strobe and position light system has two lamps per wingtip and the strobe supply. Each lamp is two amps, and the strobe supply is 6 amps. Yikes! That is 14 amps for running lights. The gold plated pins that go into DB connectors and also the circular plastic locking connectors are very easy to use, but should not be used for much over 4 amps. I could parallel these critters, but that gets to be more work. By going to the LED system from either Kunzleman or GS, the current draw is between 150 and 300 ma per wingtip. The strobe systems run 2 to 4 amps. Are these wingtip nav lights equivalent to the Whelan incandescent? I have bought both GS and Kunztleman systems for testing. I just made a simple turntable marked off in degrees to rotate the wingtip unit to measure lux output vs. angle. I'm using the nice primer on lighting requirements that Eric Jones posted on his website, Perihelion Designs. http://www.periheliondesign.com/ To measure the light output, I got a lux meter, calibrated in lux. Photographic light meters can be converted from exposure value to lux, but these meters are intrinsically logarithmic in response, and I don't trust it. The horizontal plane measurement will be relatively easy, but the vertical plane may be harder. Eric himself does not believe that present commercial units meet the FARs, but for experimental, they do not need to. Of course, the low power strobes don't, but any strobe is far better than none, and the logarithmic response of the eye comes to our rescue here. James Foerster, J400, wiring. ________________________________________________________________________________
Date: Aug 19, 2007
Subject: Bright star on the horizon - OV protection and anytime
control >Comments/Questions: Bob - What is the latest wisdom on the crowbar and b-lead >disconnect for the IR alternators? I have read all the Matronics threads, >and it seems that you have withdrawn the Z-24 diagram. >BTW I am a PhD electrical engineer, and I have not seen anyone with the >clarity and good explanations and sheer common sense that you give. >Keep up the good work. Thank you sir for the kind words and validation of my efforts. Here's some background: http://www.aeroelectric.com/DIY/DIY_Crowbar_OVP_F.pdf Here's the Z-24 replacement in the works . . . http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf in the interim, Z-24 is entirely suited to the task as long as the pilot is aware that the alternator should not be turned off while under load except when it's mis-behaving or there is possibility of electrically generated smoke in the cockpit. When AEC9004 becomes available, it will drop neatly into the spot where the crowbar module is used and will allow any time, any conditions, damage free control of the stock, automotive IR alternator. Holler if I can help! Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 19, 2007
Subject: Re: Bright star on the horizon - OV protection and
anytime control Bob, Any ETA on availability of the AEC9004? Thanks, Tim Lewis -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 900 hrs RV-10 #40059 under construction Robert L. Nuckolls, III wrote: > > When AEC9004 becomes available, it will drop neatly into > the spot where the crowbar module is used and will allow > any time, any conditions, damage free control of the > stock, automotive IR alternator. > > Holler if I can help! > > Bob . . . > > ---------------------------------------- > ( IF one wishes to be "world class" at ) > ( anything, what ever you do must be ) > ( exercised EVERY day . . . ) > ( R. L. Nuckolls III ) > ---------------------------------------- > > ________________________________________________________________________________
Date: Aug 19, 2007
Subject: PMag Preflight Check
Peter and Mike, You both said you do not recommend checking the PMag internal alternator before each flight. Will you please expand on your reasoning? Thanks, Stan Sutterfield I think I would do as you suggest and not check the P-mag internal alternator every flight either. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 19, 2007
anytime control > >Bob, > >Any ETA on availability of the AEC9004? > >Thanks, > >Tim Lewis Not definite - this spring's plans for getting the alternator drive stand were interrupted. It's too hot to work in the garage for about the next month. The circuit has been brass-boarded and the first-pass software tested. The BIG questions are to demonstrate an ability to seamlessly control the un-modified IR alternator when running at full load and 11,000 rpm. I'm 98% sure we've got the recipe for success but won't know until it's been run on real hardware. Certainly before the end of the year. Bob. . . ________________________________________________________________________________
Subject: B&C SD 8 Alternator
Date: Aug 20, 2007
8/20/2007 Hello James, You wrote: "Eric himself does not believe that present commercial units meet the FARs, but for experimental, they do not need to." I am questioning your statement that stobe and position lights installed on amateur built experimental aircraft do not need to meet FAR requirements. What is your basis for that statement? A) Each amateur built experimental aircraft will have a set of Operating Limitations that are part of that aircraft's special airworthiness certificate. The Operating Limitations will include the words: "After completion of Phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated under VFR, day only." B) FAR Sec. 91.205 paragraphs (c) (1) and (2) read: "(c) Visual flight rules (night). For VFR flight at night, the following instruments and equipment are required: (2) Approved position lights. (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft......skip....." C) Here is a quote from the introduction to my table on the subject of amateur built aircraft equipment requirements: "The builder should note that some items required by the FAR's are described in the FAR's as needing to be approved, but since there are no certification standards established for amateur built experimental aircraft, no formal individual item approval, such as meeting a TSO (Technical Standard Order) or FAR Part 23, is required. However certain items must interface properly with ATC (Air Traffic Control), other aircraft, or other entities external to the aircraft. Transponders, communication radios, exterior lighting and ELT's (Emergency Locator Transmitters) are examples of such equipment. Therefore, the builder can expect that the initial airworthiness inspection of his aircraft will require evidence that this type of equipment in the aircraft is acceptable to the FAA." D) It would appear that the inspector performing the original airworthiness inspection of an amateur built experimental aircraft would have the prerogative of insisting that the strobe and position lights of that aircraft (if installed) meet the requirements of FAR Part 23 regarding strobe and position light performance. The presumption being made that the installation of such lights indicates an intention to fly at night on some occasions. Your comments? 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." --------------------------------- ----------------------------- From: "James Foerster" <jmfpublic(at)comcast.net> Subject: Re: AeroElectric-List: B&C SD 8 Alternator Bob wrote: "if one had LED based position and strobes, then perhaps night VFR on 8A would be quite comfortably managed." This is a good point, and opens up the topic of LED position lights. I have a Jabiru J400, and the alternator is good for 20 amps max, closer to 15 amps continuous. I had planned to put an SD20 alternator on the crank splined shaft to get more total power, but the complication of two alternators and two batteries seemed far too great for what will be mainly a day and night VFR plane with pretensions. The Whelan strobe and position light system has two lamps per wingtip and the strobe supply. Each lamp is two amps, and the strobe supply is 6 amps. Yikes! That is 14 amps for running lights. The gold plated pins that go into DB connectors and also the circular plastic locking connectors are very easy to use, but should not be used for much over 4 amps. I could parallel these critters, but that gets to be more work. By going to the LED system from either Kunzleman or GS, the current draw is between 150 and 300 ma per wingtip. The strobe systems run 2 to 4 amps. Are these wingtip nav lights equivalent to the Whelan incandescent? I have bought both GS and Kunztleman systems for testing. I just made a simple turntable marked off in degrees to rotate the wingtip unit to measure lux output vs. angle. I'm using the nice primer on lighting requirements that Eric Jones posted on his website, Perihelion Designs. http://www.periheliondesign.com/ To measure the light output, I got a lux meter, calibrated in lux. Photographic light meters can be converted from exposure value to lux, but these meters are intrinsically logarithmic in response, and I don't trust it. The horizontal plane measurement will be relatively easy, but the vertical plane may be harder. Eric himself does not believe that present commercial units meet the FARs, but for experimental, they do not need to. Of course, the low power strobes don't, but any strobe is far better than none, and the logarithmic response of the eye comes to our rescue here. James Foerster, J400, wiring. ________________________________________________________________________________
Date: Aug 20, 2007
Subject: Re: PMag Preflight Check
Stan, I looked back at what I wrote and I can't seem to find where I would recommend that anyone not check the onboard alternator function of the P-mag at the beginning of each and every flight. But (I think I) would not do so as (I) gained confidence in those units. Just a personal thing Stan, I would likely still do the mag drop check, old habits die hard. Mike ----- Original Message ----- From: Speedy11(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Sunday, August 19, 2007 5:35 PM Subject: AeroElectric-List: PMag Preflight Check Peter and Mike, You both said you do not recommend checking the PMag internal alternator before each flight. Will you please expand on your reasoning? Thanks, Stan Sutterfield I think I would do as you suggest and not check the P-mag internal alternator every flight either. ------------------------------------------------------------------------------ ________________________________________________________________________________
Date: Aug 20, 2007
Hi Stan, I don't think I recommended not to check the internal generator, just that I don't do it. The generator is a back-up to a back-up, as the ignition typically uses power from the alternator, then it could use battery power, or it could use generator power, and the engine will continue to run on the magneto alone in a pinch. There is certainly nothing wrong with checking it every flight, I just don't do it. My choice is not to do a complete run up check on (usually) other than the first flight of the day, I check for dead cut, check for normal temperatures & pressures, carry out the normal before take-off checks and go - probably my glider towing background showing through. I have nearly 300 hours on the aeroplane and am familiar with the normal feel and have seen/felt/heard several abnormal 'feels'. I don't get too bunched over systems check when the systems have show themselves to be reliable in my aeroplane, operated the way I operate it. Yours, Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com Sent: 20 August 2007 02:35 Subject: AeroElectric-List: PMag Preflight Check Peter and Mike, You both said you do not recommend checking the PMag internal alternator before each flight. Will you please expand on your reasoning? Thanks, Stan Sutterfield I think I would do as you suggest and not check the P-mag internal alternator every flight either. _____ <http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982> . ________________________________________________________________________________
From: "David & Elaine Lamphere" <lamphere(at)vabb.com>
Subject: KX125 connector
Date: Aug 20, 2007
I would like to know what type of connector is used for a KX125 NAV/COM as I would like to wire up a used (wires were just cut off) unit and will probably need to get some pins at least (or is this a "replace the whole unit" situation?? I found the .pdf listing at the reference materials at Aeroelectric (thanks!), but not what kind of connector it was (or at least I didn't see it). The RF connections look like they are soldered 90 deg, I "think" I can undo them and attach new cable... but then again, I haven't started working on them yet.. Thanks in advance, Dave ________________________________________________________________________________
Date: Aug 20, 2007
Ebay is a great source for these pins and connectors Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David & Elaine Lamphere Sent: 20 August 2007 21:17 Subject: AeroElectric-List: KX125 connector I would like to know what type of connector is used for a KX125 NAV/COM as I would like to wire up a used (wires were just cut off) unit and will probably need to get some pins at least (or is this a "replace the whole unit" situation?? I found the .pdf listing at the reference materials at Aeroelectric (thanks!), but not what kind of connector it was (or at least I didn't see it). The RF connections look like they are soldered 90 deg, I "think" I can undo them and attach new cable... but then again, I haven't started working on them yet.. Thanks in advance, Dave ________________________________________________________________________________
Subject: Re: Official AeroElectric-List FAQ (Frequently Asked
Questions)
Date: Aug 20, 2007
Hi Matt I have tried a couple times to unsubcribe (sales(at)6440autoparts.com) from the Aeroelectric list. I have gone though the motions and all it says is "No changes were required to execute your subscription/unsubscription request." Either something is wrong or this is just way too technical for me. Randy ________________________________________________________________________________
From: "6440 Auto Parts" <sales(at)6440autoparts.com>
Questions)
Date: Aug 20, 2007
OOOPs sorry this was intended to go straight to Matt not this list sorry ----- Original Message ----- From: "Randy" <brinker(at)suddenlinkmail.com> Sent: Monday, August 20, 2007 4:49 PM Subject: Re: AeroElectric-List: Official AeroElectric-List FAQ (Frequently Asked Questions) > > > Hi Matt I have tried a couple times to unsubcribe > (sales(at)6440autoparts.com) from the Aeroelectric list. I have gone though > the motions and all it says is "No changes were required to execute your > subscription/unsubscription request." Either something is wrong or this > is just way too technical for me. > > Randy > > > -- > 269.12.0/961 - Release Date: 8/19/2007 7:27 AM > > ________________________________________________________________________________
Date: Aug 20, 2007
I have two pmags, total time now 265 hours. This includes one replacement and both sent in for updates during the annual. After each reinstall I check to insure the mags were working at my idle setting. Both were. I didn't take the time to adjust the idle abnormally low to find the cut off of each Pmag. (I did the first time) As long as they work at my idle setting I was happy. I have my panel set up so everything to start works from Left to Right and reverse for shut down. My process is as follows, Pmag switched breakers, ON, Master On, full rich yada yada yada. On run up, RPM 1700, key switch on both. Check left, back to Both, Check Right, back to Both. Done deal. If there is a problem you'll know there. Why do anything different? During the one failure I had in flight (an internal magnet failure of my left Pmag) I switched to the Right mag and proceeded on safely. If you have a sudden rise in temps, rough running, loss of power, switch mags to isolate and find out if it is a mag issue. I firmly believe people are getting them in the set up mode and messing up the timing. Set them up and leave them alone!!! Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Subject: Re: KX125 connector
Date: Aug 20, 2007
OK, but what do I look for?? I doubt they are listed as KX125 connectors.. :-) ----- Original Message ----- From: "Peter Pengilly" <peter(at)sportingaero.com> Sent: Monday, August 20, 2007 5:28 PM Subject: RE: AeroElectric-List: KX125 connector > > > Ebay is a great source for these pins and connectors > > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David > & Elaine Lamphere > Sent: 20 August 2007 21:17 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: KX125 connector > > > > I would like to know what type of connector is used for a KX125 NAV/COM > as I > would like to wire up a used (wires were just cut off) unit and will > probably need to get some pins at least (or is this a "replace the whole > > unit" situation?? I found the .pdf listing at the reference materials > at > Aeroelectric (thanks!), but not what kind of connector it was (or at > least I > didn't see it). > > The RF connections look like they are soldered 90 deg, I "think" I can > undo > them and attach new cable... but then again, I haven't started working > on > them yet.. > > > Thanks in advance, > > Dave > > > ________________________________________________________________________________
Date: Aug 20, 2007
Here is some additional information. I think the 125 uses the same connectors as most of the King series radios. http://www.berkut13.com/extractor.htm James Redmon - Race 13 Berkut #013 N97TX http://www.berkut13.com ----- Original Message ----- From: "David & Elaine Lamphere" <lamphere(at)vabb.com> Sent: Monday, August 20, 2007 7:33 PM Subject: Re: AeroElectric-List: KX125 connector > > > OK, but what do I look for?? I doubt they are listed as KX125 connectors.. > :-) > > ----- Original Message ----- > From: "Peter Pengilly" <peter(at)sportingaero.com> > To: > Sent: Monday, August 20, 2007 5:28 PM > Subject: RE: AeroElectric-List: KX125 connector > > >> >> >> Ebay is a great source for these pins and connectors >> >> Peter ________________________________________________________________________________
Date: Aug 21, 2007
Ah yes! That's what I was looking for. Thank you! David Lamphere Wittman W10 Tailwind N828DL (under construction) ----- Original Message ----- From: <berkut13(at)berkut13.com> Sent: Monday, August 20, 2007 10:28 PM Subject: Re: AeroElectric-List: KX125 connector > > > Here is some additional information. I think the 125 uses the same > connectors as most of the King series radios. > > http://www.berkut13.com/extractor.htm > > > James Redmon - Race 13 > Berkut #013 N97TX > http://www.berkut13.com > > > ----- Original Message ----- > From: "David & Elaine Lamphere" <lamphere(at)vabb.com> > To: > Sent: Monday, August 20, 2007 7:33 PM > Subject: Re: AeroElectric-List: KX125 connector > > >> >> >> OK, but what do I look for?? I doubt they are listed as KX125 >> connectors.. :-) >> >> ----- Original Message ----- >> From: "Peter Pengilly" <peter(at)sportingaero.com> >> To: >> Sent: Monday, August 20, 2007 5:28 PM >> Subject: RE: AeroElectric-List: KX125 connector >> >> >>> >>> >>> Ebay is a great source for these pins and connectors >>> >>> Peter > > > ________________________________________________________________________________
Subject: B and C SD8 Alternator
Date: Aug 21, 2007
Having read the discussion this topic regarding Running Lights (Nav Lts?) and the pro-/anti-Whelen sides, it occurred to me that perhaps another tack be taken. The coloured lights are there so that (like ships) an early estimate of direction of travel be made in order to plan evasive manoeuvres if needed. In that case, the lights are not just for our protection but for the Others out there. That's what I think the U.S. regs require - service to other flyers. If they don't satisfy the particular standards drawn up, they don't protect other aircraft - and that could be 300 people..... That's why I've chosen an approved source for lights. Ferg Europa 914 mono ________________________________________________________________________________
From: "Frank Stringham" <fstringham(at)hotmail.com>
Subject: RE: AeroElectric-Z13/8 ????
Date: Aug 21, 2007
I am wiring my RV7A using Z 13/8 as my basic scheme. I did change the scheme to use Z-25 as the SD-8 Aux Alternator controller and the B&C LR-3 as the controller of the main alternator (as shown on Z-12). I also have the Dynon EMS-120 which has an ammeter shunt to monitor electrical flow in one of three locations. I have choosen to place the shunt in the A position to monitor current flow into or out of the battery. Now the ??????? 1. With all this said I would like to eliminate the two shunts that monitor the SD-8 and Main alternator in in their place use the inticator lights. Does this make sense? My argument is I just want to know when the failure of an alternator occures and then monitor battery current specifically. 2. Does the indicator light attach to the S704-1 at the NC location ......assuming that 1 above is ok to do. Thanks in Advance for your help. Frank @ SGU RV7A Wiring in progress _________________________________________________________________ Messenger Caf open for fun 24/7. Hot games, cool activities served daily. Visit now. http://cafemessenger.com?ocid=TXT_TAGHM_AugHMtagline ________________________________________________________________________________
Subject: Z-19 Clarifications
Date: Aug 21, 2007
Hi , I am planning to install a Z-19 system and had a couple of clarifying questions. Feedback is very much appreciated. 1. Do all of the contactors in the system have to be Amperage rated at or above the maximum output of the alternator? I guess this is not a z-19 specific question but I'm still unsure. 2. How does the E-bus alternate feed relay work, I am not sure of its intended purpose? I can see the E-bus is normally fed from the Main power bus through a diode but I'm not sure what function the relay provides. Do you normally start with the E-bus relay switch OFF. Then if your alternator dies you manually switch the E-bus ON? My E-bus load comes up to 9.5 amps. Do I even need the relay? 3. Should both batteries be connected to the same ground point on the airframe, rather than two separate locations? In my case it means running about 5' of wire to that designed ground stud. 4. Parts - Diodes for the ECU and Fuel pumps - is the B&C Essential Bus Diode and the Perihelion Power-Deuce-Schottky Auto-Power Selector Diode Assembly essentially the same component. In the Z-19 the it says 'Note 24', but I cannot find that in my Aeroelectric Connection manual or the website. Thanks very much, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130200#130200 ________________________________________________________________________________
Date: Aug 22, 2007
Mark, I would be interested in the cad file. BTW, just recently installed your static ports. My local RV buddies all have static port envy. send it to : plaurence@the-beach.net Peter ----- Original Message ----- From: Fiveonepw(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Saturday, August 18, 2007 11:41 PM Subject: Re: AeroElectric-List: Headset plug polarity In a message dated 08/17/2007 10:06:34 PM Central Daylight Time, ceengland(at)bellsouth.net writes: There isn't really any practical way to wire a stereo connector for both stereo & mono. You can set it up with a switch, but then you're dependent on remembering to set the switch correctly. >>> My understanding as well. I installed mono & stereo jacks on my plane using a switching mono plug that ties L&R channels together when the plug is inserted, and used a spring-loaded cover on the stereo jack with a lable stating "Stereo Only" on it. One way to git a kitty rug! Diagram available on AutoCAD if interested... From The PossumWorks in TN Mark Phillips ------------------------------------------------------------------------- ----- ________________________________________________________________________________
Subject: Essential buss failure
Date: Aug 22, 2007
I wrote last week concerning this failure of my essential buss and Bob suggested I check the connections and replace the diode. I have a diode on order, but I did find that the faston connections were loose, so I crimped them down a bit. Well, the bus failed again this morning. I have found that pressing the push-to-talk switch on the SL-30 seems to trigger the failure and most of the time it is the first actuation of the switch after startup. It trips off the essential buss power for a fraction of a second, then everything returns to normal. Any ideas? Ron Schreck RV-8, "Miss Izzy" Gold Hill Airpark, NC ________________________________________________________________________________
Subject: LED Position and Anti-collision lighting.
Date: Aug 22, 2007
Let's put this discussion where one can find it... > > Hello James, You wrote: "Eric himself does not believe that present > commercial units meet the FARs, but for experimental, they do not need to." > I am questioning your statement that stobe and position lights installed on > amateur built experimental aircraft do not need to meet FAR requirements. What is your basis for that statement? > A) Each amateur built experimental aircraft will have a set of Operating > Limitations that are part of that aircraft's special airworthiness > certificate. The Operating Limitations will include the words: > "After completion of Phase I flight testing, unless appropriately equipped > for night and/or instrument flight in accordance with 91.205, this aircraft > is to be operated under VFR, day only." > B) FAR Sec. 91.205 paragraphs (c) (1) and (2) read: > "(c) Visual flight rules (night). For VFR flight at night, the following > instruments and equipment are required: > (2) Approved position lights. > (3) An approved aviation red or aviation white anticollision light system on all U.S.-registered civil aircraft......skip....." > C) Here is a quote from the introduction to my table on the subject of > amateur built aircraft equipment requirements: > "The builder should note that some items required by the FAR's are > described in the FAR's as needing to be approved, but since there are no > certification standards established for amateur built experimental aircraft, > no formal individual item approval, such as meeting a TSO (Technical > Standard Order) or FAR Part 23, is required. However certain items must > interface properly with ATC (Air Traffic Control), other aircraft, or other > entities external to the aircraft. Transponders, communication radios, > exterior lighting and ELT's (Emergency Locator Transmitters) are examples of such equipment. Therefore, the builder can expect that the initial airworthiness inspection of his aircraft will require evidence that this > type of equipment in the aircraft is acceptable to the FAA." > D) It would appear that the inspector performing the original airworthiness inspection of an amateur built experimental aircraft would have the prerogative of insisting that the strobe and position lights of that > aircraft (if installed) meet the requirements of FAR Part 23 regarding > strobe and position light performance. The presumption being made that the installation of such lights indicates an intention to fly at night on some > occasions. > > Bob wrote: "if one had LED based position and strobes, then perhaps > night VFR on 8A would be quite comfortably managed." > > This is a good point, and opens up the topic of LED position lights. I > have a Jabiru J400, and the alternator is good for 20 amps max, closer > to 15 amps continuous. I had planned to put an SD20 alternator on the > crank splined shaft to get more total power, but the complication of two > alternators and two batteries seemed far too great for what will be > mainly a day and night VFR plane with pretensions. > > The Whelan strobe and position light system has two lamps per wingtip > and the strobe supply. Each lamp is two amps, and the strobe supply is > 6 amps. Yikes! That is 14 amps for running lights. The gold plated > pins that go into DB connectors and also the circular plastic locking > connectors are very easy to use, but should not be used for much over 4 > amps. I could parallel these critters, but that gets to be more work. > By going to the LED system from either Kunzleman or GS, the current draw is between 150 and 300 ma per wingtip. The strobe systems run 2 to 4 amps. > > Are these wingtip nav lights equivalent to the Whelan incandescent? I > have bought both GS and Kunztleman systems for testing. I just made a > simple turntable marked off in degrees to rotate the wingtip unit to > measure lux output vs. angle. I'm using the nice primer on lighting > requirements that Eric Jones posted on his website, Perihelion Designs. > http://www.periheliondesign.com/ > > To measure the light output, I got a lux meter, calibrated in lux. > Photographic light meters can be converted from exposure value to lux, > but these meters are intrinsically logarithmic in response, and I don't > trust it. > > The horizontal plane measurement will be relatively easy, but the > vertical plane may be harder. Eric himself does not believe that > present commercial units meet the FARs, but for experimental, they do > not need to. Of course, the low power strobes don't, but any strobe is > far better than none, and the logarithmic response of the eye comes to > our rescue here. > James Foerster, J400, wiring. > > From: "Fergus Kyle" > > Having read the discussion this topic regarding Running Lights (Nav Lts?) > and the pro-/anti-Whelen sides, it occurred to me that perhaps another tack be taken. > The coloured lights are there so that (like ships) an early estimate > of direction of travel be made in order to plan evasive manoeuvres if > needed. In that case, the lights are not just for our protection but for the > Others out there. That's what I think the U.S. regs require - service to > other flyers. If they don't satisfy the particular standards drawn up, they > don't protect other aircraft - and that could be 300 people..... > That's why I've chosen an approved source for lights. > Ferg > Europa 914 mono I have some concern that the FAA will tighten up exterior lighting requirements, probably after some very public night accident, but for now you get your airplane signed off as VFR-day flightworthy and the rest seems up to your good judgement and the insurance company. I agree with Ferg that the position and anticollision lights are for the protection of others, so we should insist that other builders design for safety all around. Don't be shy. Not just your own life is at risk. I have made offers to test LED position lights made by other but got no takers. I state categorically that many LED lighting systems are not per the FAA specs. See my website for information. I have sold some position lights that ARE per the FAA specs. One of my customers landed using only the LED position lights to see the runway. An amazing accomplishment. But the LEDs were really really bright. I am planning to reintroduce these later, but others will enter the field with good systems too. For now I am working on too many other things. Exceeding the FAA specs would be in the best interest of builders who may want LEDs but don't want to certificate them or buy certificated parts. It is also true that the differences in LEDs (soon 4-10X the luminous efficacy, essentially infinite lifetime, organic LED sheets, etc.) gives rise to vastly different schemes for placement and operation of exterior lighting. I am interested in making a flush beacon. Ideas appreciated. As for James Foerster's testing: It will be great to see your results. We anxiously await data. "THE VERY BIG STUPID" is a thing which breeds by eating The Future. Have you seen it? It sometimes disguises itself as a good-looking quarterly bottom line, derived by closing the R&D Department. --Frank Zappa -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130238#130238 ________________________________________________________________________________
Date: Aug 22, 2007
8/22/2007 Hello Fergus, Thanks for your input. You wrote: "In that case, the lights are not just for our protection but for the Others out there. That's what I think the U.S. regs require - service to other flyers." You are right on target. Whenever we fly we are sharing the airspace and, if so equipped, the electromagnetic environment with other aircraft and the air traffic control system. Our own amateur built experimental aircraft, to varying degrees, must be compatible with the other entities to avoid creating confusion or unsafe conditions. Here is an extract from the introduction to my table MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT EXPERIMENTAL AIRCRAFT "The builder should note that some items required by the FAR's are described in the FAR's as needing to be approved, but since there are no certification standards established for amateur built experimental aircraft no formal individual item approval, such as meeting a TSO (Technical Standard Order) or FAR Part 23, is required. However certain items must interface properly with ATC (Air Traffic Control), other aircraft, or other entities external to the aircraft. Transponders, communication radios, exterior lighting and ELT's (Emergency Locator Transmitters) are examples of such equipment. Therefore, the builder could expect that the initial airworthiness inspector of his aircraft may require evidence that this type of equipment in the aircraft is acceptable to the FAA. But regardless of the actions of the inspector, the burden for complying with the provisions of the aircraft's special airworthiness certificate (which includes the Operating Limitations), and the relevant FAR's, rests with the builder / pilot." A complete copy of this table can be obtained as an attachment to an email by request direct to me. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ------------------ RESPONDING TO ------------------------------ From: "Fergus Kyle" <VE3LVO(at)rac.ca> Subject: AeroElectric-List: B and C SD8 Alternator Having read the discussion this topic regarding Running Lights (Nav Lts?) and the pro-/anti-Whelen sides, it occurred to me that perhaps another tack be taken. The coloured lights are there so that (like ships) an early estimate of direction of travel be made in order to plan evasive manoeuvres if needed. In that case, the lights are not just for our protection but for the Others out there. That's what I think the U.S. regs require - service to other flyers. If they don't satisfy the particular standards drawn up, they don't protect other aircraft - and that could be 300 people..... That's why I've chosen an approved source for lights. Ferg Europa 914 mono ________________________________________________________________________________
Date: Aug 22, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Z-19 Clarifications
> >Hi , > >I am planning to install a Z-19 system and had a couple of clarifying >questions. Feedback is very much appreciated. > >1. Do all of the contactors in the system have to be Amperage rated at or >above the maximum output of the alternator? I guess this is not a z-19 >specific question but I'm still unsure. Contactor "ratings" are much like switch ratings. Many times a device performs quite well even if it appears to be under-rated. For example, the S701-1 contactors offered by B&C as battery contactors are rated to switch 70A but will carry the starter current of several hundred amps when they're already closed and stable. Suggest you utilize the contactors recommended in the drawings and don't get wrapped around the axle on ratings. >2. How does the E-bus alternate feed relay work, I am not sure of its >intended purpose? I can see the E-bus is normally fed from the Main power >bus through a diode but I'm not sure what function the relay provides. Read chapter 17 in the book. A "lite" e-bus (7A or less) gets alternate power from the battery bus via direct wire and switch. Crash safety conventions dictate a "mini" battery contactor located at the battery bus for larger loads. >Do you normally start with the E-bus relay switch OFF. Then if your >alternator dies you manually switch the E-bus ON? Yes and sorta yes. The main bus should also be shut down during alternator out operations to maximize endurance in the enroute phase of flight. >My E-bus load comes up to 9.5 amps. Do I even need the relay? See chapter 17. >3. Should both batteries be connected to the same ground point on the >airframe, rather than two separate locations? In my case it means >running about 5' of wire to that designed ground stud. What kind of airplane. See: http://aeroelectric.com/articles/Battery_Grounds/Battery_Grounds.html >4. Parts - Diodes for the ECU and Fuel pumps - is the B&C Essential Bus >Diode and the Perihelion Power-Deuce-Schottky Auto-Power Selector Diode >Assembly essentially the same component. There are virtually thousands of diodes that will function as needed in this circuit. The parts offered by B&C and Perihelion are but two such devices cited for your convenience. > In the Z-19 the it says 'Note 24', but I cannot find that in my > Aeroelectric Connection manual or the website. Note 24 is on page Z-11 of http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf Bob . . . ________________________________________________________________________________
Date: Aug 22, 2007
Subject: Re: Essential buss failure
>I wrote last week concerning this failure of my essential buss and Bob >suggested I check the connections and replace the diode. I have a diode >on order, but I did find that the faston connections were loose, so I >crimped them down a bit. Well, the bus failed again this morning. I have >found that pressing the push-to-talk switch on the SL-30 seems to trigger >the failure and most of the time it is the first actuation of the switch >after startup. It trips off the essential buss power for a fraction of a >second, then everything returns to normal. Any ideas? It's a simple circuit. One diode, a couple of hunks of wire, a few terminals. Something's loose. Bob . . . ________________________________________________________________________________
Subject: Re: Headset plug polarity
Date: Aug 22, 2007
bbradburry(at)bellsouth.n wrote: > I am amazed at the difficulty in finding the polarity on the internet. Can > someone help me here? Try this link: http://www.rst-engr.com/rst/support/APNOTE02.pdf This is a web page about using an aviation headset with a PC, but it has some pinout info that may help you: http://www.flightsim.com/cgi/kds?$=main/howto/adapter.htm Another link that may help: http://www.flickr.com/photos/zorlack/43579792/in/set-800495/ Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130249#130249 ________________________________________________________________________________
Date: Aug 22, 2007
Subject: Re: RE: AeroElectric-Z13/8 ????
> > >I am wiring my RV7A using Z 13/8 as my basic scheme. I did change the >scheme to use Z-25 as the SD-8 Aux Alternator controller and the B&C LR-3 >as the controller of the main alternator (as shown on Z-12). I also have >the Dynon EMS-120 which has an ammeter shunt to monitor electrical flow in >one of three locations. I have choosen to place the shunt in the A >position to monitor current flow into or out of the battery. Now the ??????? > >1. With all this said I would like to eliminate the two shunts that >monitor the SD-8 and Main alternator in in their place use the inticator >lights. Does this make sense? My argument is I just want to know when the >failure of an alternator occures and then monitor battery current specifically. > >2. Does the indicator light attach to the S704-1 at the NC location >......assuming that 1 above is ok to do. The diagrams are recommendations, not requirements. You can choose to install or any combination of monitoring and display tools for your electrical system. Bob . . . ________________________________________________________________________________
Date: Aug 22, 2007
OC wrote 8/20/2007 > > Hello James, You wrote: "Eric himself does not believe that present > commercial units meet the FARs, but for experimental, they do not need > to." > > I am questioning your statement that stobe and position lights installed > on > amateur built experimental aircraft do not need to meet FAR requirements. > What is your basis for that statement? My basis was misremembering your original explaination-sorry. Thanks for setting the record straight once again. That said, I am trying to measure the available commercial units to see how close they come. Since that post, my sources tell me that the inspectors for exerimental and amateur built aircraft are taking a closer, and more jaundiced, look at the LED position lights. I did see some units molded into the wing at the last Oshkosh that clearly did not meet the field of view requirements, although brightness is impossible to judge in the daylight. Jim ________________________________________________________________________________
Subject: Shower of Sparks
Date: Aug 22, 2007
Bob: In discussing Shower of Sparks ignition, you have mentioned Unison Slick Start. On the Aircraft Spruce webpage, then imply that Slick Start is only for use with Slick magnetos, not Bendix units. Do you think there's a technical reason, or that's just certification/lawyer talk? Thanks, Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
From: "Terry Miles" <terrence_miles(at)hotmail.com>
Subject: Ess Bus or Engine Failure and proper electrical installation
Date: Aug 22, 2007
I have done 100 + faston connectors in the last 45 days. Blue ones, red ones, yellow ones.you name it. One wire to three wires.you name it. .and some bigger crimps using the B&C #10 to #2 wire masher that they have. It works great and has been an enormous help. I have learned, and I am passing it to you, that you do a grab and yank test on EACH wire in each joint. If you grab all the wires it once, it only proves that one is in there for keeps. Think about that. Also I have learned that the blue fastons are a little more loose on the faston ground or fuse tabs than are the red ones. Be careful if you make your own "forest of ground tabs" that the rows are not so close together or so out of the way that you can't see if each and every connector is fully seated. In my humble opinion (IMHO) any faston going into an electronic ignition component, or any fuel pumps, be given the utmost of care and attention. Give equal attention to power, to ground, to any splices..every dam connector in the chain. Equal attention to data transfer issues.like the map signal on your Elect Ign. Treat it like torquing the nuts and bolts on your throttle cable, because it has the same affect. Terry Velocity XLRG-5 Final wiring _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ron Schreck Sent: Wednesday, August 22, 2007 8:14 AM Subject: AeroElectric-List: Essential buss failure I wrote last week concerning this failure of my essential buss and Bob suggested I check the connections and replace the diode. I have a diode on order, but I did find that the faston connections were loose, so I crimped them down a bit. Well, the bus failed again this morning. I have found that pressing the push-to-talk switch on the SL-30 seems to trigger the failure and most of the time it is the first actuation of the switch after startup. It trips off the essential buss power for a fraction of a second, then everything returns to normal. Any ideas? Ron Schreck RV-8, "Miss Izzy" Gold Hill Airpark, NC ________________________________________________________________________________
Date: Aug 22, 2007
Says who????? Peter Laurence wrote: > Mark, > > I would be interested in the cad file. > > BTW, just recently installed your static ports. My local RV buddies > all have static port envy. > > send it to : plaurence@the-beach.net > > > Peter > > > > > ----- Original Message ----- > *From:* Fiveonepw(at)aol.com > *To:* aeroelectric-list(at)matronics.com > > *Sent:* Saturday, August 18, 2007 11:41 PM > *Subject:* Re: AeroElectric-List: Headset plug polarity > > In a message dated 08/17/2007 10:06:34 PM Central Daylight Time, > ceengland(at)bellsouth.net writes: > > There isn't really any practical way to wire a stereo > connector for both > stereo & mono. You can set it up with a switch, but then you're > dependent on remembering to set the switch correctly. > > >>> > My understanding as well. I installed mono & stereo jacks on my > plane using a switching mono plug that ties L&R channels together > when the plug is inserted, and used a spring-loaded cover on the > stereo jack with a lable stating "Stereo Only" on it. One way to > git a kitty rug! > > Diagram available on AutoCAD if interested... > > From The PossumWorks in TN > Mark Phillips > > > ------------------------------------------------------------------------ > title=http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982 > href="http://discover.aol.com/memed/aolcom30tour/?ncid=AOLAOF00020000000982" > target=_blank>AOL.com. > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > > * > > * > > > * > ------------------------------------------------------------------------ > > ________________________________________________________________________________
Date: Aug 22, 2007
Bob, Thanks for your input. I found most of the answer per your referenced documents. >> Contactor "ratings" are much like switch ratings. Many times a device performs quite well even if it appears to be under-rated. For example, the S701-1 contactors offered by B&C as battery contactors are rated to switch 70A but will carry the starter current of several hundred amps when they're already closed and stable. Suggest you utilize the contactors recommended in the drawings and don't get wrapped around the axle on ratings. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130294#130294 ________________________________________________________________________________
Subject: RE: KX155 Nav/com 'acoustic feedback'
Date: Aug 22, 2007
From: "Miskelly, Francis G" <f.miskelly(at)imperial.ac.uk>
Discovered today the radio interference is coming from the intercom! I disconnected the KX155 internal intercom and the problem disappeared! The radio worked fine. My questions now are: 1. Can anyone explain why the interference arises from the intercom? Is the intercom esp prone to interference? 2. I'm told the KX155 internal intercom is poor and people often have to install an external intercom eg. SPA400. Is that correct? 3. If i install an external intercom will that solve the problem? 4. To disconnect the intercom i removed the 'intercom mic' pin. From my pin-out diagram of the KX155 the 'intercom mic' pin is #8. My radio is wired with the 'intercom mic' into pin B (B for Bravo). Can someone confirm the correct pin for the 'intercom mic'? Is it pin 8 or pin B? Many thanks Frank >The KX155 nav/com in my Glastar has 2 problems which may be related. >1. Inserting the headphone jack i have near perfect reception. >However, when i insert the microphone jack there is a loud whine >suggestive of 'acoustic feedback'. Moving the boom away from my mouth >reduces the whine. With a different headset it appears as lots of >static noise which again changes with position of the boom. I've >changed the aerial, power supply and checked all the earths. It occurs >with either mag and when the generator is disconnected. It only >happens when the engine is running. The radio's been bench tested and >passed as good. >2. Radio reception is good with just the headphone jack inserted. >However, insert the microphone jack and reception becomes very poor or >disappears completely. I suspect the 'acoustic feedback' is raising >the automatic squelch which is cutting off the radio station ________________________________________________________________________________
Date: Aug 22, 2007
Ron, If you are having difficulty isolating the poor connection visually. Measure the voltages at the source and any accessible points along the way to the E-Buss. If you used the Bridge Rectifier with Fastons this may be 4 points. Take these measurements while the buss is loaded (your SL30 PTT experience suggests series resistance) you will see a drop of about 1.2 volts (unless you used a Schottky diode* *then it will be less)* *across the diode, more than that between any two points will isolate the poor connection. You may also try pulling hard on each of the fastons. If you can pull them off with moderate force they are not crimped properly. Diodes are typically not intermittent, they generally open or short and usually only when abused (over temp or mechanical stress) Bad crimps are common, good crimp tools, properly sized (wire and terminal) and high quality connectors (AMP PIDG or Molex Avikrimp) with metal insulation support sleeves and careful installation will resolve this. Other things to look for are partially cut wires (rare if properly installed), corrosion on terminals, fuse blocks, fuses. It may be helpful to load the E-Buss with a high current device (landing lights, pitot heat, both?) in my installation this only requires moving a connection a few inches on a split fuse block. That will obviate the need to key the transmitter to get the current up and thus the IR drop. (The voltage drop is equal to the Current I * R Resistance plus any diode junction drops that are in series) Good luck. -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
From: "Keith Hallsten" <KeithHallsten(at)quiknet.com>
Subject: Shakeup at EAA Sport Aviation
Date: Aug 22, 2007
This was just posted to another list I watch, & may be seen at: Mr. Ernest Christley posted the following to http://www.flyrotary.com/. It may be of interest to EAA'rs disappointed with the current state of the organization. ============================ Following the lead of a fellow member of the Dyke Delta Yahoo group, Bernie, I sent the editors at EAA an email explaining why I was not renewing my membership. It looks like Bernie and I either spoke to soon, or our actions are finally having the intended effect. I'll not argue the point either way, but I got some news through the grapevine this weekend that is very encouraging concerning the EAA. The editor of Sport Aviation has been fired. Now, I hate to see anyone lose their job, but here is how I understand the situation. The guy took a job editing what should be an intensely hardcore aviation publication, and he didn't have so much as a PP-SEL. It appears that he had no interest in flying airplanes, and even less in building one. He was in the wrong place. That's sad; both for him and the EAA membership. Over the past year, EAA membership dropped 20%. Sport Aviation content was cited most often as the reason. That is sad; both for him and the membership. He is being replaced. I wish him luck in finding a position better suited for him, but the bigger issue for EAA members (past and present) is why he was replaced. The board of directors saw the 20% drop in membership and started asking why. Have you seen the makeup of the board? Sport Aviation printed the nominees for the next year a couple months back. There weren't but a couple that had ever worked on an airplane, and I believe only one nominee that had ever built anything. The rest were bean counters and management types, with a couple academics thrown in. While bean counters and management types are both necessary and useful, I think it wouldn't be that hard to find a few that had built at least one airplane and would know what is wrong with the EAA's focus. Instead, they, being bean counters and management types, do what bean counters and management types do. They look at spreadsheets and charts and try to draw a picture of reality from the summarization. Spreadsheets and charts leave out a lot of data and twist reality all to easily. Until the membership started dropping, they assumed everything was hunky-dory, and all the talk about losing focus was just background noise. Now the moaning has risen to a roar. Members are leaving. So, we've punched them in the nose to get their attention. It is time for a come to Jesus meeting where we calmly and clearly explain what the problem is. If you've left the EAA without an explanation, please send a quick email to editorial(at)eaa.org and state why you left. Just a few polite lines so that they will know. If you're considering not renewing your membership, let them know that. If you've tried to make your voice heard before, but feel you were rebuked, please try again. I believe the microphone is turned your way now. If you know someone who is trying to fix the EAA from the inside, please mention their efforts so that the board will have insiders to turn to for advise. It's not often that an organization as large as the EAA will see one in five members drop out in a single year. This is an historic opportunity to set thing straight. The people in charge will be paying attention like never before. It may be that the editor will just be a scapegoat, and it will be back to business as usual in a few months. I think it more likely that the board is genuinely concerned, but they just don't understand. If we speak up and the situation is the former, then we can say, "We told you so" next year when the membership drops another 20%. If the situation is the latter then speaking up now will help draw back the 20% that left and insure that they stay. It is my opinion that the problem with the EAA is that the leadership has forgotten why we are building airplanes. It is NOT, by any means, simply to have an airplane. The analysis has been done all over the place, and everyone agrees it would be more economical and less labor intensive to get a second job, buy an airplane now, and be in the air immediately. *WE* as builders know that. We're not stupid...DANG-IT! The reason we build airplanes is....get this....PRIDE! Plane (har-har) and simple. We want to say, "I built that." We want to compare our workmanship to the guy on the next row, and marvel at the simplicity/uniqueness/complexity/workmanship of the guy on the next. The more bolt-on, manufactured goods are added, the less pride is involved. The more the leadership has forgotten that PRIDE is the driving force and been lured astray by advertising dollars from manufactured goods, the more they've eaten away at the heart of the organization. Now, I've got nothing against manufactured goods, or their advertising. There are some parts of my project that I just had no interest in making, wheel hubs, for example, so I chose to buy those off the shelf. The problem is that I often get the feeling from the EAA organization that my project is lessened by it not being a kit, or by me making my own strobes or marker lights. If I'm building out of pride, and you look down your nose at me for building...well, that's just a punch in the gut, and I don't really care to be around you. You can't go around punching your members and expect them to keep coming back. Ernest Christley ________________________________________________________________________________
Date: Aug 23, 2007
Subject: Re: Shakeup at EAA Sport Aviation
Keith Hallsten wrote: > This was just posted to another list I watch, & may be seen at: > > Mr. Ernest Christley posted the following to http://www.flyrotary.com/. It > may be of interest to > EAA'rs disappointed with the current state of the organization. > ============================ > I open my big mouth to much. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 22, 2007
(sigh) As you and the others likely know, the "grapevine" seldom can be relied upon for accurate dissemination of news. I looked at the published, audited financial statement for EAA. It compares the most recent audited years ending February 28, 2006 and 2007. While the report does not give the number of members, it does show the revenue from membership dues (same rate for both years @ $40). There was a $143,667 increase in revenue in 2007 over 2006. Based on that, it seems membership increased. For membership to have dropped by 20% in the last year, the membership dues revenue would have to show a decrease of more than $1.2 million. As for Mr. David Hipschman, he is still listed as the Editor of Sport Aviation magazine in the August issue. Even if he is leaving, there is no way to know if he was fired. I also looked up David Hipschman in the FAA database - he is a PP-ASEL for three years now and lives in WI. It may still be a good idea to suggest that members write EAA with their own ideas for change or improvement of the organization, but I'm not sure that we can take the so-called "change" as a given - or the validity of this email for that matter. James Redmon Berkut #013 N97TX http://www.berkut13.com ----- Original Message ----- From: "Keith Hallsten" <KeithHallsten(at)quiknet.com> Sent: Wednesday, August 22, 2007 9:52 PM Subject: AeroElectric-List: Shakeup at EAA Sport Aviation > This was just posted to another list I watch, & may be seen at: > > Mr. Ernest Christley posted the following to http://www.flyrotary.com/. > It > may be of interest to > EAA'rs disappointed with the current state of the organization. > ============================ > > Following the lead of a fellow member of the Dyke Delta Yahoo group, > Bernie, I sent the editors at EAA an email explaining why I was not > renewing my membership. It looks like Bernie and I either spoke to > soon, or our actions are finally having the intended effect. I'll not > argue the point either way, but I got some news through the grapevine > this weekend that is very encouraging concerning the EAA. > > The editor of Sport Aviation has been fired. (snip) ________________________________________________________________________________
Date: Aug 22, 2007
Golly gosh, everything printed on the internet isn't always true? I'm shocked, truly shocked. Maybe Elvis really is dead. Rick On 8/22/07, berkut13(at)berkut13.com wrote: > > > (sigh) > > As you and the others likely know, the "grapevine" seldom can be relied > upon > for accurate dissemination of news. > > I looked at the published, audited financial statement for EAA. It > compares > the most recent audited years ending February 28, 2006 and 2007. While > the > report does not give the number of members, it does show the revenue from > membership dues (same rate for both years @ $40). There was a $143,667 > increase in revenue in 2007 over 2006. Based on that, it seems membership > increased. For membership to have dropped by 20% in the last year, the > membership dues revenue would have to show a decrease of more than $1.2 > million. > > As for Mr. David Hipschman, he is still listed as the Editor of Sport > Aviation magazine in the August issue. Even if he is leaving, there is no > way to know if he was fired. I also looked up David Hipschman in the FAA > database - he is a PP-ASEL for three years now and lives in WI. > > It may still be a good idea to suggest that members write EAA with their > own > ideas for change or improvement of the organization, but I'm not sure that > we can take the so-called "change" as a given - or the validity of this > email for that matter. > > James Redmon > Berkut #013 N97TX > http://www.berkut13.com > > > ----- Original Message ----- > From: "Keith Hallsten" <KeithHallsten(at)quiknet.com> > To: > Sent: Wednesday, August 22, 2007 9:52 PM > Subject: AeroElectric-List: Shakeup at EAA Sport Aviation > > > > This was just posted to another list I watch, & may be seen at: > > > > Mr. Ernest Christley posted the following to http://www.flyrotary.com/. > > It > > may be of interest to > > EAA'rs disappointed with the current state of the organization. > > ============================ > > > > Following the lead of a fellow member of the Dyke Delta Yahoo group, > > Bernie, I sent the editors at EAA an email explaining why I was not > > renewing my membership. It looks like Bernie and I either spoke to > > soon, or our actions are finally having the intended effect. I'll not > > argue the point either way, but I got some news through the grapevine > > this weekend that is very encouraging concerning the EAA. > > > > The editor of Sport Aviation has been fired. > (snip) > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 23, 2007
Subject: Re: Shower of Sparks
>Bob: > > >In discussing Shower of Sparks ignition, you have mentioned Unison Slick >Start. On the Aircraft Spruce webpage, then imply that Slick Start is >only for use with Slick magnetos, not Bendix units. Do you think there s >a technical reason, or that s just certification/lawyer talk? > > >Thanks, Shower of Sparks or "SOS" enhancement to magneto performance still stands out in my mind as one of those extra-ordinary examples of clever design from the CSP era (copper, steel phenolic). Contemporary designers can select from millions of commercial off the shelf parts and in particular, little chunks of multi-legged plastic offering functionality from "simple" amplifiers (20 transistors!) to gigaflop-fast super-processors (tens of thousands of transistors). In the time when Shower of Sparks was crafted, the catalog of materials available to our creative ancestors was limited to a relatively few, rudimentary components. Yet, by understanding the simple-ideas for the materials at hand and the task to be accomplished, devices like . . . http://www.aeroelectric.com/Pictures/Regulators/ALTREG2.jpg were produced with out-the-door performance on a par with the later . . . http://www.aeroelectric.com/Pictures/Regulators/Ford_SS_Reg_open.jpg or most modern incarnations like . . . http://www.aeroelectric.com/Pictures/Regulators/Alternator_Regulators.jpg Shower of sparks was conceived as a melding of magneto and Kettering ignition systems for battery enhancement of spark energy during low speed operations (cranking). The enhancement had two important features . . . a battery excited, electromechanical "buzzer" that would supply the magneto primary with a rapidly repeating pulse of energy from the battery and a second set of delayed-timing, cranking-points temporarily switched in parallel with the advanced-timing, running-points. See: http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf I've not been made privy to the simple-ideas that support functionality of the Slick Start. My present understanding of the product suggests that it does not require a second set of points. From this I infer the device is fitted with some intelligence that delays delivery of battery enhanced pulses by some amount which emulates the delayed-timing points common to the earlier system. Assuming my understanding is correct, then I can deduce no reason why the product (or one exceedingly similar to it) wouldn't function with any brand of magneto. But without the support of the designers or a cognizant technician, we'll not have enough information to craft a definitive answer to your question. Perhaps someone on the List has a lead on the details of this systems design and operation. Bob . . . ________________________________________________________________________________
Date: Aug 23, 2007
8/23/2007 Hello Tim, Will you permit a non Bob to answer? Unison originaly built the SlickSTART P/N SS1001 for only Slick magnetos. In 1998 they added SlickSTART P/N SS1002 for use with TCM/Bendix magnetos. So which version of the SlickSTART Magneto Start Booster (solid state ignition starting vibrator) you use will depend upon which brand of magnetos you use. The Unison Service Letter L-1492 (Revision D is current) contains a caution that says using P/N SS1001 with Bendix/TCM magnetos may result in magneto damage and engine stoppage. There are some fairly recent postings in the aeroelectric archives that may be of value or interest to someone considering SlickSTART. I suggest that you search for SoS Vibrator Recommendations, or Slick Start. You can also pick out the pertinent items if you search for bakerocb. Please let me know if you have any further questions. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: It would be more precise if we used the generic term "starting vibrator" when writing in general about this subject and reserve "Shower of Sparks" for referring specifically to the TCM/Bendix mechanical vibrator and "SlickSTART" for referring specifically to the Unison solid state starting vibrator. ---------------- RESPONDING TO ---------------------------------------- Subject: AeroElectric-List: Shower of Sparks From: <tdawson-townsend(at)aurora.aero> Bob: In discussing Shower of Sparks ignition, you have mentioned Unison Slick Start. On the Aircraft Spruce webpage, then imply that Slick Start is only for use with Slick magnetos, not Bendix units. Do you think there's a technical reason, or that's just certification/lawyer talk? Thanks, Tim Dawson-Townsend tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Aug 23, 2007
I went through, I'm unhappy with Sport Aviation magazine, a few years ago. This is not new or just in the last year. Actually I thought I saw some improvement last year and earlier this year. When I wrote a while back, the EAA replied, incl Tom P. I was upset about the "fluffy" articles that where like ads and short on facts; I was also unhappy they dropped the Cafe Foundation Org group and their articles. I was told they where too technical. They also asked me to write articles. Clearly month to month they are desperate to get content. They do need contributors, you and me, to write articles. To be fair, putting out a magazine to a bunch of eccentric hard- core crazies like us, who actually build planes we fly, can't satisfy everyone. (Note: this tongue in-cheek sarcasm.) Seriously EAA has a lot of folks with wide interest. The guy who claimed/implied he was behind the shake-up, if that is what happen, I assume is an alternative engine rotary guy? Clearly Sport Aviation and their one alt engine article every 12-18 month would not make that crowd happy. The wide interest of members aside, your membership in EAA should be more than just the magazine. As far as membership, the magazine is the main benefit people see. I can see some dropping because they don't read the magazine. However ALL print media is having problems, INTERNET and FREE VAST CONTENT. -Internet has long out paced the detailed content of any monthly general EAA magazine could ever hope to match by a huge factor. -Gas prices are high and people getting out flying The EAA does a lot of stuff behind the scenes on behalf of the experimental aircraft community. You really don't think AOPA will push for kit planes, when they lobby and represent certified manufactures, corporate and non- scheduled commercial operators. Sure there's common ground, but AOPA is not really orientated to our niche of GA. EAA is all we have. They do a lot and they don't blow their horn like AOPA. Not an AOPA put down, AOPA has its place and we need more power on Capital hill for sure. Bad magazine or not I'll stay a EAA member. I have 20 years of EAA articles ripped from issues over the years, lots of good stuff. They should print monthly electrical, structure and general build/maintenance articles, not one or five every year, total. Again they need continent, but the Tony B. days are long gone. I suspect they don't want to pay for content. From their Tax return the Mag cost them a lot. As far as the editor firing, an expert pilot or plane builder might know planes but not make a great editor either. Sure the editor should have a clue. It's like many businesses where a good technical guy gets promoted to management, a line Captain becomes Chief pilot, once competent technical guys, now are mediocre managers and bureaucrats. Much a do about nothing. George RV-7 --------------------------------- Be a better Heartthrob. Get better relationship answers from someone who knows. ________________________________________________________________________________
Date: Aug 23, 2007
Subject: E-Mag P-Mag
Hello Bob, I hope you enjoyed your trip to Alaska as much as we enjoyed having you here. Have you had any time to review the recent postings concerning the E-Mag P-Mag wiring issues? The folks at Emagair have indicated their willingness to talk with you. Blue Skies, Mike Ice ________________________________________________________________________________
Date: Aug 23, 2007
gmcjetpilot(at)yahoo.com wrote: > The guy who claimed/implied he was behind the shake-up, if > that is what happen, I assume is an alternative engine rotary > guy? Clearly Sport Aviation and their one alt engine article > every 12-18 month would not make that crowd happy. The > wide interest of members aside, your membership in EAA > should be more than just the magazine. > I neither claimed or implied that I was behind the shake-up. I did claim and imply that dropping membership was behind the shake-up. My facts may be very much in error. Time will tell. I am a rotary guy. The one article they publish concerning alternative engines once every 12-18 months is generally full of error, bias and broad-based silliness. They search out one commercial entity that has done the most advertising without searching out any of the other players that may actually have a larger impact. That's what makes that crowd unhappy. Just like wire pushers are unhappy about articles on electronics that ignore basic, simple ideas, and spouts ridiculous noise about having to get replacement components from the original batch used to manufacture a device. We are unhappy that the magazine that is supposed to be representing an educational organization is full of nonsense. You state, "the magazine is the main benefit people see." Everyone I've ever talked to agrees on this. Wouldn't it follow that the directors of the organization would realize this, and make sure that the main benefit was actually a benefit? If they need articles, why do they not request them, right there in the magazine? How about a few lines of text to refer would-be authors to set of directions on the Internet for how to submit an article? If they're doing something behind the scenes, then use the magazine to tell the members what's happening, instead of printing another press release about an unaffordable jet engine that is to big for any of the planes we're building. (Do any of us really care that Diamond Jet is meeting certification criteria?) I can't believe the EAA leadership is to dense to see something so obvious, which leaves me with only one explanation. They don't care. In the same way that TV broadcasters don't really care if I enjoy the show, as long as I sit for the commercials, the EAA leadership doesn't care. Well, that's fine. They don't have to care about my sensibilities. If they have some nefarious "behind the scenes" activity going on, then they need to tell me about it. Until they do, I refuse to be the beaten wife that repeatedly returns to an abusive home. The EAA is not a monopoly and never will be "all we have". It's just what we've settled for. ________________________________________________________________________________
Date: Aug 23, 2007
Ernest, These things happen and I am sympathetic. I, too, have little use for "Martha Stewart Flying". I always complain each time I re-up that although the form as many reasons for "Why are you joining/renewing?", not one of them is "I am building an airplane". On the other hand, My EAA membership has paid for itself many times over whether I am renting a car from Hertz or the $1000 of discounts I've gotten from the various schools I've attended over the last year. Every once and a while, they do print an informative article. They are few and far between, but it does happen. As far as their coverage of alternative engines, I'll paraphrase William Randolph Hearst, "Freedom of the press belongs to the man who owns one" as "the accuracy of any article in any publication belongs to the man who wrote it." Write that article and I, for one, will be happy to read it. Rick On 8/23/07, Ernest Christley wrote: > > echristley(at)nc.rr.com> > > gmcjetpilot(at)yahoo.com wrote: > > The guy who claimed/implied he was behind the shake-up, if > > that is what happen, I assume is an alternative engine rotary > > guy? Clearly Sport Aviation and their one alt engine article > > every 12-18 month would not make that crowd happy. The > > wide interest of members aside, your membership in EAA > > should be more than just the magazine. > > > I neither claimed or implied that I was behind the shake-up. I did > claim and imply that dropping membership was behind the shake-up. My > facts may be very much in error. Time will tell. > > I am a rotary guy. The one article they publish concerning alternative > engines once every 12-18 months is generally full of error, bias and > broad-based silliness. They search out one commercial entity that has > done the most advertising without searching out any of the other players > that may actually have a larger impact. That's what makes that crowd > unhappy. Just like wire pushers are unhappy about articles on > electronics that ignore basic, simple ideas, and spouts ridiculous noise > about having to get replacement components from the original batch used > to manufacture a device. We are unhappy that the magazine that is > supposed to be representing an educational organization is full of > nonsense. > > You state, "the magazine is the main benefit people see." Everyone I've > ever talked to agrees on this. Wouldn't it follow that the directors of > the organization would realize this, and make sure that the main benefit > was actually a benefit? If they need articles, why do they not request > them, right there in the magazine? How about a few lines of text to > refer would-be authors to set of directions on the Internet for how to > submit an article? If they're doing something behind the scenes, then > use the magazine to tell the members what's happening, instead of > printing another press release about an unaffordable jet engine that is > to big for any of the planes we're building. (Do any of us really care > that Diamond Jet is meeting certification criteria?) I can't believe > the EAA leadership is to dense to see something so obvious, which leaves > me with only one explanation. They don't care. In the same way that > TV broadcasters don't really care if I enjoy the show, as long as I sit > for the commercials, the EAA leadership doesn't care. > > Well, that's fine. They don't have to care about my sensibilities. If > they have some nefarious "behind the scenes" activity going on, then > they need to tell me about it. Until they do, I refuse to be the beaten > wife that repeatedly returns to an abusive home. The EAA is not a > monopoly and never will be "all we have". It's just what we've settled > for. > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Subject: Homemade 1/4 wave Comm Antennas
Date: Aug 23, 2007
Bob, In Ch13 of the Connection you describe how to make a =BC wave Comm antenna with 4-10 1=94 copper strips as the ground plane. You also briefly describe a center =93commoning disk=94. Question: How big can/should the center communing disk be? What happens if the center disk is ~11=94 radius (~1/2 the size of the strips)? Does this tend to mess-up the resonant length/properties of the strips? If said antenna is being placed on the belly of a composite aircraft with various metal items in direct proximity overhead (flap motor, aux fuel pump, flap mechanism, avionics bay, etc), is there anything that should be done to help =93shield=94 the antenna (and/or ground plane strips) from the effects of the metal items overhead? Rick ________________________________________________________________________________
Date: Aug 23, 2007
Subject: Re: Homemade 1/4 wave Comm Antennas
>Bob, > > >In Ch13 of the Connection you describe how to make a wave Comm antenna >with 4-10 1 copper strips as the ground plane. You also briefly describe >a center commoning disk . > > >Question: > >How big can/should the center communing disk be? What ever is convenient. A commoning disk with a radius equal to height of antenna, then you have a contiguous, "ideal" ground plane. If you make it too small, it serves no purpose as a doubler. Someplace between ideal and too small, it provides a convenient point to tie off the radials -AND- possibly a reinforcing effect of skin around the antenna. >What happens if the center disk is ~11 radius (~1/2 the size of the strips)? No problem. >Does this tend to mess-up the resonant length/properties of the strips? The tips of ground plane radial strips are measured from base of antenna to tip of radial. The larger the commoning disk, the shorter the radial. Think of it as starting with an ideal disk and then cutting away as much material as practical to provide an effective ground plane, effective doubler and minimum weight. Something on the order of 6" in diameter and 4-10 radials is a reasonable compromise. >If said antenna is being placed on the belly of a composite aircraft with >various metal items in direct proximity overhead (flap motor, aux fuel >pump, flap mechanism, avionics bay, etc), is there anything that should be >done to help shield the antenna (and/or ground plane strips) from the >effects of the metal items overhead? No. The proximate effect of a ground plane is to attenuate (shield) the antenna from conductor/ noise effects on the opposite side. Bob . . . ________________________________________________________________________________
Subject: Strobes - Light Plane Maintenance Article
Date: Aug 23, 2007
The Sept 2007 edition of LPM has an article on strobe lights. I'm curious as to how accurate the following excerpt is: "A strobe power supply that has been left "off" for long periods - weeks or months - is subject to eventual failure because the electrolytic capacitors used in the device will loose polarity formation. As a rule, a strobe that has been inactive for one year can be considered eligible for sudden failure" I have two Areoflash power supplies that were purchased new six months ago and have since been waiting for final installation. Do I need to "exercise" this strobe system to keep it from going bad? Thanks, Mike Creek ________________________________________________________________________________
Subject: Re: Strobes - Light Plane Maintenance Article
Date: Aug 24, 2007
In the radio tube era (when Lycoming engines were designed ;-) this was true for equipment that was shelved for many years, but with modern parts this is not true anymore. Elco's are indeed getting worse when left without power for extended periodes of time, but not in the 'weeks or months' timeframe. All electronic equipment has electrolytic capacitors in them, and if this was the general timespan for elco's then you'd also have to replace your ELT transmitter every so many weeks or months. They have elco's too, and I hope for your sake you do not have to run them every six months... I think the article has been inspired by an over-active marketing department who would like to see you replace perfectly good parts. Can you imagine their revenue increase if their 'rule' would be mandatory? Every owner who doesn't fly their plane for 6 months (winter or so) replacing all electronics with elco's in them? I'm gonna buy me some stock... Rob ----- Original Message ----- From: "Michel Creek" <mwcreek(at)frontiernet.net> Sent: Friday, August 24, 2007 2:52 AM Subject: AeroElectric-List: Strobes - Light Plane Maintenance Article > > > > The Sept 2007 edition of LPM has an article on strobe lights. I'm curious > as to how accurate the following excerpt is: > > "A strobe power supply that has been left "off" for long periods - weeks > or > months - is subject to eventual failure because the electrolytic > capacitors > used in the device will loose polarity formation. As a rule, a strobe > that > has been inactive for one year can be considered eligible for sudden > failure" > > I have two Areoflash power supplies that were purchased new six months ago > and have since been waiting for final installation. Do I need to > "exercise" > this strobe system to keep it from going bad? > > Thanks, > Mike Creek > > > ________________________________________________________________________________
Date: Aug 24, 2007
I doubt it. The message is greatly exaggerated. Electrolytic capacitors will eventually lose their capacitor ability if left on a shelf for a long time, but that is many years in my experience. They rely upon being connected in circuit with a voltage across them, so an oxide layer can form on the aluminium foil from which they are constructed. It provides the necesary dielectric layer. However, a capacitor which has lost that layer can be re-formed by connecting them up andprogressively increasing the voltage to the rated working voltage. If the LPM article were correct, every set of strobes would need to carry an "instal by" date. I imagine that most would have a period between manufacture and sale of greater than 12 months. Bill ----- Original Message ----- From: "Michel Creek" <mwcreek(at)frontiernet.net> Sent: Friday, August 24, 2007 10:52 AM Subject: AeroElectric-List: Strobes - Light Plane Maintenance Article > > > > The Sept 2007 edition of LPM has an article on strobe lights. I'm curious > as to how accurate the following excerpt is: > > "A strobe power supply that has been left "off" for long periods - weeks > or > months - is subject to eventual failure because the electrolytic > capacitors > used in the device will loose polarity formation. As a rule, a strobe > that > has been inactive for one year can be considered eligible for sudden > failure" > > I have two Areoflash power supplies that were purchased new six months ago > and have since been waiting for final installation. Do I need to > "exercise" > this strobe system to keep it from going bad? > > Thanks, > Mike Creek > > > ________________________________________________________________________________
Date: Aug 24, 2007
8/24/2007 Hello Bob, 1) You wrote: "Perhaps someone on the List has a lead on the details of this systems design and operation." Looking at the patent for the Unison SlickSTART Magneto Start Booster may provide some helpful information. See this link: http://patft.uspto.gov/netacgi/nph-Parser?u=%2Fnetahtml%2Fsrchnum.htm&Sect1=PTO1&Sect2=HITOFF&p=1&r=1&l=50&f=G&d=PALL&s1=5630384.PN.&OS=PN/5630384&RS=PN/5630384 If that doesn't work just Google "US Patent 5630384" (thanks to Eric). 2) You wrote: "My present understanding of the product suggests that it does not require a second set of points. From this I infer the device is fitted with some intelligence that delays delivery of battery enhanced pulses by some amount which emulates the delayed-timing points common to the earlier system." You are correct that the solid state SlickSTART unit does not require a second set of points, but it does not incorporate any internal delayed timing. To explain: To take best advantage of the SlickSTART's longer duration and higher peak voltage sparking over that provided by just an impulse coupled magneto a magneto with a set of retard breaker points is required. However, if the SlickSTART unit is used with an impulse coupled magneto with a single set of points there will still be an increase in both peak output voltage and sparks per sequence over that which would be provided by the impulse coupling acting alone. A copy of Unison's SlickSTART brochure and its claims can be found at this link: http://www.unisonindustries.com/docs/Slickstartflyer_1493.pdf 3) You wrote: "Assuming my understanding is correct, then I can deduce no reason why the product (or one exceedingly similar to it) wouldn't function with any brand of magneto." I can't offer any technical reason, but can only repeat what I posted earlier on this specific point: "The Unison Service Letter L-1492 (Revision D is current) contains a caution that says using P/N SS1001 with Bendix/TCM magnetos may result in magneto damage and engine stoppage." Unison does provide SlickSTART P/N SS1002 for use with the TCM/Bendix magnetos. Some general comments: A) I have been operating my amateur built experimental aircraft equipped with a TCM IO-240 B9B engine and a SlickSTART P/N SS1001 magneto start booster for over 185 hours. B) The left magneto is a Slick P/N 4310 with a set of retard breaker points. The SlickSTART booster is connected to this magneto. The right magneto is a Slick P/N 4309 direct drive with no impulse coupling or retard breaker points. C) The engine is cranked with the right magneto grounded out during cranking. D) I had difficulty in obtaining enough information on the functioning of the SlickSTART unit from Unison to make my initial wiring installation. This was because all of their installation information was based on the assumption that one was removing a TCM/Bendix "Shower of Sparks" unit and replacing it with the SlickSTART unit. It was difficult to reverse engineer their instructions into a "start from scratch" situation. After a false start response from the Unison marketing department, and follow up detailed correspondence with their tech support people, I was able to make the installation. E) I am very satisfied with the performance of my SlickSTART unit and would highly recommend it to anyone using conventional magnetos instead of electronic ignition in their Lycoming or TCM engine. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ------------------ RESPONDING TO ---------------------------------------------- From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net> Subject: Re: AeroElectric-List: Shower of Sparks >Bob: > > >In discussing Shower of Sparks ignition, you have mentioned Unison Slick >Start. On the Aircraft Spruce webpage, then imply that Slick Start is >only for use with Slick magnetos, not Bendix units. Do you think there s >a technical reason, or that s just certification/lawyer talk? > > >Thanks, Shower of Sparks or "SOS" enhancement to magneto performance still stands out in my mind as one of those extra-ordinary examples of clever design from the CSP era (copper, steel phenolic). Contemporary designers can select from millions of commercial off the shelf parts and in particular, little chunks of multi-legged plastic offering functionality from "simple" amplifiers (20 transistors!) to gigaflop-fast super-processors (tens of thousands of transistors). In the time when Shower of Sparks was crafted, the catalog of materials available to our creative ancestors was limited to a relatively few, rudimentary components. Yet, by understanding the simple-ideas for the materials at hand and the task to be accomplished, devices like . . . http://www.aeroelectric.com/Pictures/Regulators/ALTREG2.jpg were produced with out-the-door performance on a par with the later . . . http://www.aeroelectric.com/Pictures/Regulators/Ford_SS_Reg_open.jpg or most modern incarnations like . . . http://www.aeroelectric.com/Pictures/Regulators/Alternator_Regulators.jpg Shower of sparks was conceived as a melding of magneto and Kettering ignition systems for battery enhancement of spark energy during low speed operations (cranking). The enhancement had two important features . . . a battery excited, electromechanical "buzzer" that would supply the magneto primary with a rapidly repeating pulse of energy from the battery and a second set of delayed-timing, cranking-points temporarily switched in parallel with the advanced-timing, running-points. See: http://www.aeroelectric.com/articles/Shower-of-Sparks/ShowerOfSparks.pdf I've not been made privy to the simple-ideas that support functionality of the Slick Start. My present understanding of the product suggests that it does not require a second set of points. From this I infer the device is fitted with some intelligence that delays delivery of battery enhanced pulses by some amount which emulates the delayed-timing points common to the earlier system. Assuming my understanding is correct, then I can deduce no reason why the product (or one exceedingly similar to it) wouldn't function with any brand of magneto. But without the support of the designers or a cognizant technician, we'll not have enough information to craft a definitive answer to your question. Perhaps someone on the List has a lead on the details of this systems design and operation. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2007
Subject: Re: Strobes - Light Plane Maintenance Article-capacitor
life Yes absolutely but... Several people seemed to have problems shortly after first flight so I personally did power up my strobes every 6 months prior to flying. IIRC aeroflash did recommend that. However I'm sensitive to the issue because I have replaced failed electrolytics in consumer electronics in as little as 3 years from manufacture. Last week it was a little used photocopier. Previous to that was a DVD player. One of my favorite troubleshooting tools has become a little in circuit ESR (equivalent series resistance) tester for capacitors. I think it was a kit from Bob Parker for well under a $100. Ken Bill Maxwell wrote: > > > I doubt it. The message is greatly exaggerated. Electrolytic > capacitors will eventually lose their capacitor ability if left on a > shelf for a long time, but that is many years in my experience. They > rely upon being connected in circuit with a voltage across them, so an > oxide layer can form on the aluminium foil from which they are > constructed. It provides the necesary dielectric layer. However, a > capacitor which has lost that layer can be re-formed by connecting > them up andprogressively increasing the voltage to the rated working > voltage. > > If the LPM article were correct, every set of strobes would need to > carry an "instal by" date. I imagine that most would have a period > between manufacture and sale of greater than 12 months. > > Bill > ----- Original Message ----- From: "Michel Creek" > > To: > Sent: Friday, August 24, 2007 10:52 AM > Subject: AeroElectric-List: Strobes - Light Plane Maintenance Article > > >> >> >> >> The Sept 2007 edition of LPM has an article on strobe lights. I'm >> curious >> as to how accurate the following excerpt is: >> >> "A strobe power supply that has been left "off" for long periods - >> weeks or >> months - is subject to eventual failure because the electrolytic >> capacitors >> used in the device will loose polarity formation. As a rule, a >> strobe that >> has been inactive for one year can be considered eligible for sudden >> failure" >> >> I have two Areoflash power supplies that were purchased new six >> months ago >> and have since been waiting for final installation. Do I need to >> "exercise" >> this strobe system to keep it from going bad? >> >> Thanks, >> Mike Creek >> >> ________________________________________________________________________________
Date: Aug 24, 2007
> > > >The Sept 2007 edition of LPM has an article on strobe lights. I'm curious >as to how accurate the following excerpt is: > >"A strobe power supply that has been left "off" for long periods - weeks or >months - is subject to eventual failure because the electrolytic capacitors >used in the device will loose polarity formation. As a rule, a strobe that >has been inactive for one year can be considered eligible for sudden >failure" > >I have two Areoflash power supplies that were purchased new six months ago >and have since been waiting for final installation. Do I need to "exercise" >this strobe system to keep it from going bad? There have been some excellent responses to this so I'll offer only the following: Articles like this are a disservice to the community because they are non-quantified. I.e., no data followed with logical deductions which lead to repeatable experiments (recipes for success). This topic has been raised many times over the years on the various aviation forums. On one occasion in years past, I scrounged around in my junk box for a high voltage electrolytic capacitor that I KNEW had not been powered up for decades. I connected it to a supply equal to it's rated voltage (450 volts if I recall correctly). On initial power up, the capacitor did what every capacitor does . . . draw whatever current the source will deliver until equilibrium is achieved. After several seconds, the capacitor's "draw" was measured in a hand-full of milliamps and after a minute, charging was essentially complete and "leakage" was under 1 mA. After ten minutes, leakage dropped to about 100 microamps. I then did a measurement of apparent capacity. The device was within 10% of rated value. I left the capacitor connected to the power supply for several days and measured apparent capacity again. It's increase was so tiny as to make measurement problematic. Bottom line: In days of yore when capacitor technology and fabrication techniques were in a relative state of infancy, the devices were indeed subject to deleterious effects of long term, dormant storage. But "modern" capacitors (meaning those built in the last 20 or so years) have exhibited great strides in operating performance and service life. Here's an exemplar article on the topic: http://www.aeroelectric.com/articles/Long_Term_Stability_Aluminum_Electrolytics.pdf This article addresses an expected elevation of leakage currents in the first few minutes of a long term storage but that, "no damage to the capacitor is to be expected". This article is consistent with my own experience and in particular, with an experiment conducted on the bench. If anyone has data from an experiment arguing with the foregoing deductions, it would be interesting and useful for us to examine it for new understanding. Bob . . . ________________________________________________________________________________
life
Date: Aug 24, 2007
This could be a different issue altogether. A couple years ago an Asian manufacturer was caught when they stole a new formula for elco's. They happened to steal a flawed version, which caused millions of bad elco's to be produced. They ended up in a lot of PC motherboards and other consumer goods and they all failed after six months to a year or so . See: http://www.geek.com/capacitor-failures-plague-motherboard-vendors/ I thought by now those should have all been weeded out, apparently not. These failures however are not the same as ageing failures. Rob ----- Original Message ----- From: "Ken" <klehman(at)albedo.net> Sent: Friday, August 24, 2007 3:16 PM Subject: Re: AeroElectric-List: Strobes - Light Plane Maintenance Article-capacitor life > > Yes absolutely but... > Several people seemed to have problems shortly after first flight so I > personally did power up my strobes every 6 months prior to flying. IIRC > aeroflash did recommend that. However I'm sensitive to the issue because > I have replaced failed electrolytics in consumer electronics in as little > as 3 years from manufacture. Last week it was a little used photocopier. > Previous to that was a DVD player. One of my favorite troubleshooting > tools has become a little in circuit ESR (equivalent series resistance) > tester for capacitors. I think it was a kit from Bob Parker for well under > a $100. > Ken > > Bill Maxwell wrote: > >> >> >> I doubt it. The message is greatly exaggerated. Electrolytic capacitors >> will eventually lose their capacitor ability if left on a shelf for a >> long time, but that is many years in my experience. They rely upon being >> connected in circuit with a voltage across them, so an oxide layer can >> form on the aluminium foil from which they are constructed. It provides >> the necesary dielectric layer. However, a capacitor which has lost that >> layer can be re-formed by connecting them up andprogressively increasing >> the voltage to the rated working voltage. >> >> If the LPM article were correct, every set of strobes would need to carry >> an "instal by" date. I imagine that most would have a period between >> manufacture and sale of greater than 12 months. >> >> Bill >> ----- Original Message ----- From: "Michel Creek" >> >> To: >> Sent: Friday, August 24, 2007 10:52 AM >> Subject: AeroElectric-List: Strobes - Light Plane Maintenance Article >> >> >>> >>> >>> >>> The Sept 2007 edition of LPM has an article on strobe lights. I'm >>> curious >>> as to how accurate the following excerpt is: >>> >>> "A strobe power supply that has been left "off" for long periods - weeks >>> or >>> months - is subject to eventual failure because the electrolytic >>> capacitors >>> used in the device will loose polarity formation. As a rule, a strobe >>> that >>> has been inactive for one year can be considered eligible for sudden >>> failure" >>> >>> I have two Areoflash power supplies that were purchased new six months >>> ago >>> and have since been waiting for final installation. Do I need to >>> "exercise" >>> this strobe system to keep it from going bad? >>> >>> Thanks, >>> Mike Creek >>> >>> > > > ________________________________________________________________________________
Date: Aug 24, 2007
life > >Yes absolutely but... >Several people seemed to have problems shortly after first flight so I >personally did power up my strobes every 6 months prior to flying. IIRC >aeroflash did recommend that. However I'm sensitive to the issue because >I have replaced failed electrolytics in consumer electronics in as little >as 3 years from manufacture. Last week it was a little used photocopier. >Previous to that was a DVD player. One of my favorite >troubleshooting tools has become a little in circuit ESR (equivalent >series resistance) tester for capacitors. I think it was a kit from Bob >Parker for well under a $100. >Ken . . . but was dormant, long term storage the proximate cause of failure? I've replaced a ton of capacitors in my career but I can recall no situation where I might have attributed the part's demise to long term inactivity followed by an indiscriminate power up. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2007
Robert L. Nuckolls, III wrote: > > This article is consistent with my own experience > and in particular, with an experiment conducted on > the bench. If anyone has data from an experiment arguing > with the foregoing deductions, it would be interesting > and useful for us to examine it for new understanding. > > The electrolytics I have had to replace have been cheap ones in consumer products that experience continuous elevated temperatures. Computer motherboards and stereo equipment stored in closed cabinets, for the most part. This is consistent with the article Bob presented. Cheap caps could be expected to possibly include more defect producing contaminants, and the article makes note that high heat tends to be detrimental. -A strobe power supply may or may not be stored in a way to control temperature. Ambient temps have exceeded the 25C that the article suggest for weeks now here in NC. If it were buried in a wing stored in the rafters of a hanger, the temps could be much higher still. Could that be the nexus of the problem? -If the strobe is using cheap caps...well, I'd just be upset about that one. ________________________________________________________________________________
Subject: Radio problem!
Date: Aug 24, 2007
I have an XCom radio in my RV-7A and I am having some problems transmitting. I seem to receive just fine. When I push the PTT button on the pilot control stick I get a static in my headset. If I push the PTT button on the passenger control stick I get the same static (in the pilot headset) with the same intensity. When I switch headsets to my backup headset I don't hear the static when I push the PTT. HOWEVER, the problem is much worse in flight (possibly due to a louder environment); on the ground with the engine shut down the static is minimal. I have not tried the backup headset in flight. I will fly tonight with the other headset to see if this eliminates the problem, but I don't think it will. Since it only happens when transmitting I am starting to think there is a problem with the PTT wiring?? Any ideas to start me out? I will report back with the results of using a different headset. Could this be a gain adjustment needed (I can adjust the gain)? Travis Read this topic online here: http://forums.matronics.com/viewtopic.php?p=130771#130771 ________________________________________________________________________________
Date: Aug 24, 2007
If I want to find out all about general aviation, I read AOPA's magazine, which has good content usually. To learn about the latest bizjet or how to fly IFR back east in the dead of winter in a Cessna, I flip thru "Flying" at the newstand. Experimental Aviation? Just can't wait for the next issue of "Kitplanes", lots of really good content, often from names familiar to us, like Stein. EAA's "Sport Aviation"? Says it all right on the cover..."The Magazine of Recreational Aviation". Looks like an appeal to a broader audience than just a few scraggly experimenters... Just like Oshkosh has morphed into. OK, got that off my shoulders... Jerry Cochran In a message dated 8/23/2007 11:58:58 P.M. Pacific Daylight Time, aeroelectric-list(at)matronics.com writes: From: <gmcjetpilot(at)yahoo.com> Subject: AeroElectric-List: Re: Shakeup at EAA Sport Aviation I went through, I'm unhappy with Sport Aviation magazine, a few years ago. This is not new or just in the last year. Actually I thought I saw some improvement last year and earlier this year. When I wrote a while back, the EAA replied, incl Tom P. I was upset about the "fluffy" articles that where like ads and short on facts; I was also unhappy they dropped the Cafe Foundation Org group and their articles. I was told they where too technical. They also asked me to write articles. Clearly month to month they are desperate to get content. http://discover.aol.com/memed/aolcom30tour ________________________________________________________________________________
Date: Aug 24, 2007
Subject: Re: Radio problem!
If you speak into the mic while transmitting, do you hear your voice (from the sidetone) through the headphones? Are other stations able to hear your transmission? With good quality? In addition to adjusting the gain, you might be able to adjust the sidetone volume if everything else appears to be working properly. Regards, Matt- > > > I have an XCom radio in my RV-7A and I am having some problems > transmitting. I seem to receive just fine. When I push the PTT button on > the pilot control stick I get a static in my headset. If I push the PTT > button on the passenger control stick I get the same static (in the pilot > headset) with the same intensity. When I switch headsets to my backup > headset I don't hear the static when I push the PTT. HOWEVER, the problem > is much worse in flight (possibly due to a louder environment); on the > ground with the engine shut down the static is minimal. I have not tried > the backup headset in flight. I will fly tonight with the other headset > to see if this eliminates the problem, but I don't think it will. Since > it only happens when transmitting I am starting to think there is a > problem with the PTT wiring?? Any ideas to start me out? I will report > back with the results of using a different headset. Could this be a gain > adjustment needed (I can adjust the gain)? > > Travis > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=130771#130771 > > ________________________________________________________________________________
Date: Aug 24, 2007
From: "Walter Fellows" <walter.fellows(at)gmail.com>
Let's be fair now and not forget the great t-shirts and bomber jackets they sell for your ride in the B-17. And all of the US taxpayer supplied jet fuel for the endless F-15 flybys while we are trying to hear the forum speakers attending the forums at OSH. I heard a rumor the CEO has flies an EAA sponsored P-51 for promotion, I hope that is just a rumor (can anyone shed light on this?) On a more serious note, we seriously need EAA's help for representing the OBAM aircraft interests before congress and the administration. There seems to be a lot of sentiment among the established aerospace companies to severely limit the scope of the amateur builder's rights. Also, I still find the EAA forums and weekend workshops to be excellent value and put on by really dedicated and capable people. My suggestion is that we continue to support them but work to remove a lot of the mindless corporate professional management thinking that has crept in there. On 8/24/07, Jerry2DT(at)aol.com wrote: > > If I want to find out all about general aviation, I read AOPA's magazine, > which has good content usually. To learn about the latest bizjet or how to > fly IFR back east in the dead of winter in a Cessna, I flip thru "Flying" at > the newstand. > > Experimental Aviation? Just can't wait for the next issue of "Kitplanes", > lots of really good content, often from names familiar to us, like Stein. > > EAA's "Sport Aviation"? Says it all right on the cover..."The Magazine of > Recreational Aviation". Looks like an appeal to a broader audience than just > a few scraggly experimenters... Just like Oshkosh has morphed into. > > OK, got that off my shoulders... > > Jerry Cochran > > In a message dated 8/23/2007 11:58:58 P.M. Pacific Daylight Time, > aeroelectric-list(at)matronics.com writes: > > From: <gmcjetpilot(at)yahoo.com> > Subject: AeroElectric-List: Re: Shakeup at EAA Sport Aviation > > I went through, I'm unhappy with Sport Aviation magazine, a > few years ago. This is not new or just in the last year. Actually I > thought I saw some improvement last year and earlier this > year. When I wrote a while back, the EAA replied, incl Tom P. > I was upset about the "fluffy" articles that where like ads and > short on facts; I was also unhappy they dropped the Cafe > Foundation Org group and their articles. I was told they > where too technical. They also asked me to write articles. > Clearly month to month they are desperate to get content. > > > > > ------------------------------ > . > > * > > > * > > ________________________________________________________________________________
Date: Aug 24, 2007
>On a more serious note, we seriously need EAA's help for representing the >OBAM aircraft interests before congress and the administration. There >seems to be a lot of sentiment among the established aerospace companies >to severely limit the scope of the amateur builder's rights. Also, I still >find the EAA forums and weekend workshops to be excellent value and put on >by really dedicated and capable people. My suggestion is that we continue >to support them but work to remove a lot of the mindless corporate >professional management thinking that has crept in there. Astute observation. I've dropped my EAA membership and no longer write for SA for reasons cited in the past. However, in spite of what ever EAA is or is not, how does one replace OSH? I attend that event not to promote (or badmouth) EAA but to meet folks who gather there annually. I've attended many a regional fly-in that produced zero or a tiny fraction of return on investment for the $time$ expended compared to a few days at OSH. EAA's inarguable value is the opportunity to network with folks of like interests. We could endlessly debate whether or not the organization has lost the vision of the founding fathers. However, I'll suggest the organization has little or nothing to do with the vision of those who make the annual pilgrimage to aviation's Mecca. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2007
> >-A strobe power supply may or may not be stored in a way to control >temperature. Ambient temps have exceeded the 25C that the article suggest >for weeks now here in NC. If it were buried in a wing stored in the >rafters of a hanger, the temps could be much higher still. Could that be >the nexus of the problem? > >-If the strobe is using cheap caps...well, I'd just be upset about that one. Which speaks to the value of conducting tests per DO-160. One cannot attract many customers in the type certificated aircraft world without jumping these hoops. Further, given the exceedingly small fraction of the world represented by aviation circles, it's impossible to keep the astute mechanics from knowing about poorly crafted products or less than helpful customer support. Stack these notions with the idea that really good capacitors are not that much more expensive than mediocre devices. Given the blood, sweat and tears sacrificed to the altars of regulation, it's unlikely that a company like Grimes or Whelen is going to compound their grief-to-market by cutting corners in the selection of components. Bob . . . ________________________________________________________________________________
Date: Aug 24, 2007
As to you Bob, astute observation as well! If it wasn't for OSH I don't think I would be doing much with the EAA. I will always support the EAA for their interests into homebuilt aviation but the future for us homebuilder's looks to be about Money. I agree OSH is a great value for everyone in aviation. It is a much better value then Sun & Fun for example. I'm 44 and have 3 experimental airplanes (credit to the EAA of days gone bye). But today's EAA is just a wanabe competitor to AOPA (with a lot of improvement needed). The last big thing I can remember the EAA doing that was important to real EAAers was the auto fuel STC. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, August 24, 2007 11:09 AM Subject: Re: AeroElectric-List: Re: Shakeup at EAA Sport Aviation >On a more serious note, we seriously need EAA's help for representing the >OBAM aircraft interests before congress and the administration. There >seems to be a lot of sentiment among the established aerospace companies >to severely limit the scope of the amateur builder's rights. Also, I still >find the EAA forums and weekend workshops to be excellent value and put on >by really dedicated and capable people. My suggestion is that we continue >to support them but work to remove a lot of the mindless corporate >professional management thinking that has crept in there. Astute observation. I've dropped my EAA membership and no longer write for SA for reasons cited in the past. However, in spite of what ever EAA is or is not, how does one replace OSH? I attend that event not to promote (or badmouth) EAA but to meet folks who gather there annually. I've attended many a regional fly-in that produced zero or a tiny fraction of return on investment for the $time$ expended compared to a few days at OSH. EAA's inarguable value is the opportunity to network with folks of like interests. We could endlessly debate whether or not the organization has lost the vision of the founding fathers. However, I'll suggest the organization has little or nothing to do with the vision of those who make the annual pilgrimage to aviation's Mecca. Bob . . . 7/29/2007 11:14 PM 7/29/2007 11:14 PM ________________________________________________________________________________
From: "David & Elaine Lamphere" <lamphere(at)vabb.com>
Subject: KX125 Wiring / Nav Com Question
Date: Aug 24, 2007
I'm in the process of rewiring the connectors on a used King KX125 nav/com and am puzzled by a couple of pins that were previously wired. Connector P501 pins H and J are labeled (according to pinout I got from the aeroelectric website): (H) VOR/LOC COMPOSITE IN and (J) VOR/LOC COMPOSITE OUT These were previously jumpered together with a wire leading off from the pair.. Would someone who is familiar with NAV/COMS please explain what these pins are used for and a guess as to where they could have been connected to (in it's previous life)?? Thanks, Dave ________________________________________________________________________________
Date: Aug 24, 2007
life Robert L. Nuckolls, III wrote: > > > >> >> Yes absolutely but... >> Several people seemed to have problems shortly after first flight so I >> personally did power up my strobes every 6 months prior to flying. >> IIRC aeroflash did recommend that. However I'm sensitive to the issue >> because I have replaced failed electrolytics in consumer electronics >> in as little as 3 years from manufacture. Last week it was a little >> used photocopier. Previous to that was a DVD player. One of my favorite >> troubleshooting tools has become a little in circuit ESR (equivalent >> series resistance) tester for capacitors. I think it was a kit from >> Bob Parker for well under a $100. >> Ken > > . . . but was dormant, long term storage the proximate cause > of failure? I've replaced a ton of capacitors in my career > but I can recall no situation where I might have attributed > the part's demise to long term inactivity followed by an > indiscriminate power up. > > Bob . . . I rather doubt that this is relevant with today's technology, but back in the '70's the Crown DC-300 was a very popular pro-grade audio power amplifier with very large (for the time) electrolytic capacitors used for brute-force DC supply filtering. If an amp wasn't powered up for many months (unfortunately, no specific count), it was not unusual for it to take out its protective fuses upon power-up. It would continue to do so until the big filter caps were either replaced or 'conditioned' by plugging the amp's power cord into a variac and bringing up the voltage slowly over many hours. Supposedly, this had the effect of reforming the capacitors so that the bridge rectifier was no longer looking at a dead short. I might consider this an old hangar tale if I hadn't experienced it myself. Your tidbit of the day... Charlie ________________________________________________________________________________
Date: Aug 24, 2007
Subject: Re: KX125 Wiring / Nav Com Question
At 14:54 8/24/2007, you wrote: >Would someone who is familiar with NAV/COMS please explain what >these pins are used for and a guess as to where they could have >been connected to (in it's previous life)?? External RMI perhaps? ________________________________________________________________________________
Date: Aug 24, 2007
The wiring diagram for the KX125 shows these connections drive an external indicator such as KI208, KI209. Kenneth Melvin N669TJ ________________________________________________________________________________
Date: Aug 24, 2007
Those pins are used to drive certin CDIs, RMIs or HSIs that accept a single composite line. Older unites require the older style of direct analog signaling. With the composite signal you can send the information over one wire instead of the 6-10 from the analog style. Both sides have to be able to interpret a composite signal. Hope this helps! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David & Elaine Lamphere Sent: Friday, August 24, 2007 2:55 PM Subject: AeroElectric-List: KX125 Wiring / Nav Com Question I'm in the process of rewiring the connectors on a used King KX125 nav/com and am puzzled by a couple of pins that were previously wired. Connector P501 pins H and J are labeled (according to pinout I got from the aeroelectric website): (H) VOR/LOC COMPOSITE IN and (J) VOR/LOC COMPOSITE OUT These were previously jumpered together with a wire leading off from the pair.. Would someone who is familiar with NAV/COMS please explain what these pins are used for and a guess as to where they could have been connected to (in it's previous life)?? Thanks, Dave 7/29/2007 11:14 PM 7/29/2007 11:14 PM ________________________________________________________________________________
Date: Aug 25, 2007
Thanks to all that responded. Due to another persons kindness, I obtained an installation manual for the KX125. You guys are correct in that the vor/loc composite signal pins are used for driving an indicator. What isn't clear or mentioned in the manual, is whether these two pins need to be jumpered (even if you are not using an external indicator).. if there is an output AND input involved, then does the unit need this jumper for it to function properly? I would guess that it won't hurt to put this jumper in anyway.. :-) Dave ----- Original Message ----- From: "Mike" <mlas(at)cox.net> Sent: Friday, August 24, 2007 10:51 PM Subject: RE: AeroElectric-List: KX125 Wiring / Nav Com Question > > Those pins are used to drive certin CDIs, RMIs or HSIs that accept a > single composite line. Older unites require the older style of direct > analog signaling. With the composite signal you can send the > information over one wire instead of the 6-10 from the analog style. > Both sides have to be able to interpret a composite signal. Hope this > helps! > > Mike > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David > & Elaine Lamphere > Sent: Friday, August 24, 2007 2:55 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: KX125 Wiring / Nav Com Question > > > > I'm in the process of rewiring the connectors on a used King KX125 > nav/com > and am puzzled by a couple of pins that were previously wired. > > Connector P501 pins H and J are labeled (according to pinout I got from > the > aeroelectric website): > > (H) VOR/LOC COMPOSITE IN and (J) VOR/LOC COMPOSITE OUT > > These were previously jumpered together with a wire leading off from the > > pair.. > > Would someone who is familiar with NAV/COMS please explain what these > pins > are used for and a guess as to where they could have been connected to > (in > it's previous life)?? > > Thanks, > > Dave ________________________________________________________________________________
Date: Aug 25, 2007
Subject: Re: Shakeup at EAA Sport Aviation
>From: "Mike" <mlas(at)cox.net> >Subject: Re: Shakeup at EAA Sport Aviation > >But today's EAA is just a wanabe competitor to AOPA. > >Mike Not sure where you are going, but I did a little study of AOPA and EAA and what they actually do for experimental amateur built and flown planes. Just for clarity AOPA is a lobby group and represents manufactures and small non- scheduled commercial operators, as well as individual private operators (allegedly). EAA is non profit and therefore can't lobby but they do a lot of legal work clarifying the FAR's. If you ever had a DAR tell you that your RV-7 needs an A&P sign off because the engine is from a certified aircraft, you will appreciate what they do. Since the AOPA is aligned heavily with manufactures of certified aircraft and the aviation business, the needs of experimental aircraft is not a priority for them. The EAA is all we have and they are best suited to protect our niche of the aviation world. There are common goals and interest between AOPA and EAA, who do work together some times, but not always. In California, LA area an airport banned experimental aircraft (tried to) and the Las Vegas FSDO tried to restrict experimental's from a huge block of air space. Behind the scene the EAA solved the issue. Unlike the AOPA the EAA did not blow their own horn. They like to take a quite approach and not embarrass the FAA. They where successful in both cases. EAA is not immune of criticism. This topic went around the RV-list. The main complaint I had in the past was the magazine was dummied down and they dropped the Caf Foundation org reports. I was told they where too technical for most. They have done better in the last year or so, but if you want technical info, go to the internet, which has replaced most topical print media. "Contact" magazine is more technical for the real experimenter and tinkerer. EAA's SA magazine does need contributors. If you have an idea for an article write it, they need content. Many past articles where "fluff" and seemed more like advertisement propaganda than fact. EAA does many things to protect experimental plane rights, building and use of airspace, fighting made up interpretations of the FAR's by DAR's and FAA inspectors. If you have a question about AD compliance, required equip or TSO'ed requirements for experimental aircraft, they have brief on it for members. The EAA tax records are public record. Not surprising on about $30 mil revenue, expenses where almost exactly $30 mil, thus non-profit. Not a surprise. Tom Poberezny makes $418,000, about 1/2 million in total compensation a year as CEO of the EAA. That seems in-line with CEO salaries I suppose, for a $30 organization.. Airventure does bring in lots of money but also cost a lot of money to put on. The magazine is a huge expense on the budget. I guess all the color pictures? Dues are the big revenue stream. The P-51 thing is very old news. It was about his dad, Paul, EAA founder and former CEO. There was some blow-up I recall about his P-51 time being paid for by the EAA. That was resolved and I recall Paul retired soon thereafter. Paul's still on the payroll and makes about $80k or $160k a year? EAA's tax return looks normal to me; the board of directors are all volunteers. They spend a lot on office space and professional services. My EAA membership is based on more than the magazine and Airventure. They do have good programs like young eagles, and the local chapters are also a nice thing. If you are active in building and flying experimental aircraft the EAA is valuable. I have talked to EAA legal a few times and they know their stuff, surprisingly better than the FAA. There are some old bones in the FAA closet that they try to pass as facts. Of all organizations, EAA does the most to protect our incredible freedom to build and fly planes we make with our own hands. Forces constantly are trying to re-write and restrict those freedoms. EAA is doing the most of us specifically, IMHO. To be fair AOPA is the only real lobby group on capital hill that is representing our "special interest". Of course we can always write our DC politicians directly. May be we should start a quasi political group of all experimental aircraft builders/ owners. That would be a good sized voter block. The economy of the kit plane business and all the support and part companies is substantial. Cheers George EAA member since 1985 --------------------------------- ________________________________________________________________________________
Date: Aug 25, 2007
The jumper is required (and I know as I just spend several weeks debugging a KX125 installation in which the internal VOR indicator would not work). I had to talk to the factory tech guy to get this info as the installation schematic shows the jumper as part of a connection to an external indicator but DOES NOT have a note indicating that the jumper is required for the operation of the internal VOR indicator. Deene Ogden EAA Tech Counselor/Flight Advisor ________________________________________________________________________________
Date: Aug 25, 2007
Thanks very much for the clarification. On 8/25/07, gmcjetpilot(at)yahoo.com wrote: > > >From: "Mike" <mlas(at)cox.net> > >Subject: Re: Shakeup at EAA Sport Aviation > > > >But today's EAA is just a wanabe competitor to AOPA. > > > >Mike > > Not sure where you are going, but I did a > little study of AOPA and EAA and what they > actually do for experimental amateur built > and flown planes. > > Just for clarity AOPA is a lobby group and > represents manufactures and small non- > scheduled commercial operators, as well as > individual private operators (allegedly). > > EAA is non profit and therefore can't lobby > but they do a lot of legal work clarifying > the FAR's. If you ever had a DAR tell you > that your RV-7 needs an A&P sign off because > the engine is from a certified aircraft, you > will appreciate what they do. > > Since the AOPA is aligned heavily with > manufactures of certified aircraft and the > aviation business, the needs of experimental > aircraft is not a priority for them. The EAA > is all we have and they are best suited to > protect our niche of the aviation world. > > There are common goals and interest between > AOPA and EAA, who do work together some > times, but not always. > In California, LA area an airport banned > experimental aircraft (tried to) and the Las > Vegas FSDO tried to restrict experimental's > from a huge block of air space. Behind the > scene the EAA solved the issue. Unlike the > AOPA the EAA did not blow their own horn. > They like to take a quite approach and not > embarrass the FAA. They where successful > in both cases. > > EAA is not immune of criticism. This topic > went around the RV-list. The main complaint > I had in the past was the magazine was > dummied down and they dropped the Caf=E9 > Foundation org reports. I was told they > where too technical for most. They have done > better in the last year or so, but if you > want technical info, go to the internet, > which has replaced most topical print media. > "Contact" magazine is more technical for the > real experimenter and tinkerer. > > EAA's SA magazine does need contributors. If > you have an idea for an article write it, they need > content. Many past articles where "fluff" and seemed > more like advertisement propaganda than fact. > > > EAA does many things to protect experimental > plane rights, building and use of airspace, fighting > made up interpretations of the FAR's by DAR's and > FAA inspectors. > > If you have a question about AD compliance, > required equip or TSO'ed requirements for > experimental aircraft, they have brief on it > for members. > The EAA tax records are public record. Not > surprising on about $30 mil revenue, > expenses where almost exactly $30 mil, thus > non-profit. Not a surprise. > > Tom Poberezny makes $418,000, about > 1/2 million in total compensation a year as > CEO of the EAA. That seems in-line with CEO > salaries I suppose, for a $30 organization.. > > Airventure does bring in lots of money but > also cost a lot of money to put on. > The magazine is a huge expense on the budget. > I guess all the color pictures? > Dues are the big revenue stream. > The P-51 thing is very old news. It was about his > dad, Paul, EAA founder and former CEO. There > was some blow-up I recall about his P-51 > time being paid for by the EAA. That was > resolved and I recall Paul retired soon > thereafter. Paul's still on the payroll and > makes about $80k or $160k a year? > > EAA's tax return looks normal to me; the board > of directors are all volunteers. They spend a > lot on office space and professional services. > > My EAA membership is based on more than the > magazine and Airventure. They do have good > programs like young eagles, and the local > chapters are also a nice thing. If you are active > in building and flying experimental aircraft the > EAA is valuable. I have talked to EAA legal > a few times and they know their stuff, surprisingly > better than the FAA. There are some old bones > in the FAA closet that they try to pass as facts. > > > Of all organizations, EAA does the most to protect > our incredible freedom to build and fly planes we > make with our own hands. Forces constantly are > trying to re-write and restrict those freedoms. EAA > is doing the most of us specifically, IMHO. > > > To be fair AOPA is the only real lobby group on > capital hill that is representing our "special interest". > Of course we can always write our DC politicians > directly. May be we should start a quasi political > group of all experimental aircraft builders/ owners. > That would be a good sized voter block. The > economy of the kit plane business and all the support > and part companies is substantial. > > > Cheers George EAA member since 1985 > > * > =========== =========== =========== > > * > > ________________________________________________________________________________
Date: Aug 25, 2007
Whoops! Make that thank you Deene ... eyes must be going! Dave ________________________________________________________________________________
Date: Aug 25, 2007
AHAH!!! Thanks Duane! without an external indicator, there aren't too many connections required. Dave ----- Original Message ----- From: Deene Ogden To: aeroelectric-list(at)matronics.com Sent: Saturday, August 25, 2007 10:07 AM Subject: Re: AeroElectric-List: KX125 Wiring / Nav Com Question The jumper is required (and I know as I just spend several weeks debugging a KX125 installation in which the internal VOR indicator would not work). I had to talk to the factory tech guy to get this info as the installation schematic shows the jumper as part of a connection to an external indicator but DOES NOT have a note indicating that the jumper is required for the operation of the internal VOR indicator. Deene Ogden EAA Tech Counselor/Flight Advisor ________________________________________________________________________________
Subject: Blind Encoder Power Connection to Garmin GTX-327 Transponder
Date: Aug 25, 2007
Anyone have a blind altitude encoder (like an AK-350) that is getting it's power from pin 14 (switched power output) on a Garmin GTX327 transponder? I notice that the schematic for the Garmin says that pin is good for 1.5A max. The encoder document says it draws .60 amp for 1 min during warm-up. This seems to me to be OK, but what puzzles me is that the page in the encoder that lists connections for the 320/327 has pin 15 (main power for the 327) listed for power. What have you guys used for powering up the blind encoder?? Thanks, Dave ________________________________________________________________________________
Transponder
Date: Aug 25, 2007
Dave, You can do it either way! Pin 14 is switched out limited to 1.5 amps which is well below the use of the encoder. If you use an avionics master you can go to pin 15 which is power into the transponder or you could go directly to a circuit breaker. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David & Elaine Lamphere Sent: Saturday, August 25, 2007 1:12 PM Subject: AeroElectric-List: Blind Encoder Power Connection to Garmin GTX-327 Transponder Anyone have a blind altitude encoder (like an AK-350) that is getting it's power from pin 14 (switched power output) on a Garmin GTX327 transponder? I notice that the schematic for the Garmin says that pin is good for 1.5A max. The encoder document says it draws .60 amp for 1 min during warm-up. This seems to me to be OK, but what puzzles me is that the page in the encoder that lists connections for the 320/327 has pin 15 (main power for the 327) listed for power. What have you guys used for powering up the blind encoder?? Thanks, Dave 7/29/2007 11:14 PM 7/29/2007 11:14 PM ________________________________________________________________________________
Date: Aug 25, 2007
PROBLEM SOLVED!!! The BNC connector at the antenna was gounding out. I made a whole new cable for good measure, and all the problems are long gone!!! Thanks for all the advice.... Travis mprather(at)spro.net wrote: > If you speak into the mic while transmitting, do you hear your voice (from > the sidetone) through the headphones? Are other stations able to hear > your transmission? With good quality? In addition to adjusting the gain, > you might be able to adjust the sidetone volume if everything else appears > to be working properly. > > > Regards, > > Matt- > > > > > > > > > > I have an XCom radio in my RV-7A and I am having some problems > > transmitting. I seem to receive just fine. When I push the PTT button on > > the pilot control stick I get a static in my headset. If I push the PTT > > button on the passenger control stick I get the same static (in the pilot > > headset) with the same intensity. When I switch headsets to my backup > > headset I don't hear the static when I push the PTT. HOWEVER, the problem > > is much worse in flight (possibly due to a louder environment); on the > > ground with the engine shut down the static is minimal. I have not tried > > the backup headset in flight. I will fly tonight with the other headset > > to see if this eliminates the problem, but I don't think it will. Since > > it only happens when transmitting I am starting to think there is a > > problem with the PTT wiring?? Any ideas to start me out? I will report > > back with the results of using a different headset. Could this be a gain > > adjustment needed (I can adjust the gain)? > > > > Travis > > > > > > > > > > Read this topic online here: > > > > http://forums.matronics.com/viewtopic.php?p=130771#130771 > > > > > > > > > > > > > > > > > > > > > > > > > > > Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131000#131000 ________________________________________________________________________________
Subject: Re: Blind Encoder Power Connection
Date: Aug 25, 2007
Thanks Mike. I'll go with pin 14 as it will be easier just to put that wire (from encoder-xpndr cable) on a pin and insert it into the transponder socket. Otherwize, it would be harder to do (either putting more than one wire in a transponder pin or running a wire back from the connector bundle). Just wanted to be sure I was interpreting the information correctly.. Dave ----- Original Message ----- From: "Mike" <mlas(at)cox.net> Sent: Saturday, August 25, 2007 4:41 PM Subject: RE: AeroElectric-List: Blind Encoder Power Connection to Garmin GTX-327 Transponder > > Dave, > > You can do it either way! Pin 14 is switched out limited to 1.5 amps > which is well below the use of the encoder. If you use an avionics > master you can go to pin 15 which is power into the transponder or you > could go directly to a circuit breaker. > > Mike > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David > & Elaine Lamphere > Sent: Saturday, August 25, 2007 1:12 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Blind Encoder Power Connection to Garmin > GTX-327 Transponder > > > > Anyone have a blind altitude encoder (like an AK-350) that is getting > it's > power from pin 14 (switched power output) on a Garmin GTX327 > transponder? > > I notice that the schematic for the Garmin says that pin is good for > 1.5A > max. The encoder document says it draws .60 amp for 1 min during > warm-up. > > This seems to me to be OK, but what puzzles me is that the page in the > encoder that lists connections for the 320/327 has pin 15 (main power > for > the 327) listed for power. > > What have you guys used for powering up the blind encoder?? > > Thanks, > > Dave > > > 7/29/2007 11:14 PM > > > 7/29/2007 11:14 PM > > > ________________________________________________________________________________
Date: Aug 25, 2007
Subject: Re: Blind Encoder Power Connection to Garmin GTX-327
Transponder
At 13:12 8/25/2007, you wrote: >Anyone have a blind altitude encoder (like an AK-350) that is >getting it's power from pin 14 (switched power output) on a Garmin >GTX327 transponder? Yes >I notice that the schematic for the Garmin says that pin is good for >1.5A max. The encoder document says it draws .60 amp for 1 min during warm-up. OK, no problem there. 0.6A is far less than 1.5A >This seems to me to be OK, but what puzzles me is that the page in >the encoder that lists connections for the 320/327 has pin 15 (main >power for the 327) listed for power. Yes, that is the supply to the 327, and anything else powered from pin 14 as well. Your encoder document shows connections to/from the 327? Either pin could be used, but should you need/want encoder output (perhaps for a GPS/LORAN) while the transponder was off, pin 14 would not be a good choice for encoder power. >What have you guys used for powering up the blind encoder?? > >Thanks, > >Dave ________________________________________________________________________________
Date: Aug 26, 2007
Travis, You said: " PROBLEM SOLVED!!! The BNC connector at the antenna was gounding out. I made a whole new cable for good measure, and all the problems are long gone!!! Thanks for all the advice.... Travis" After about 40 years on an Amateur Radio committee to solve transmission problems, I've concluded that about 90% of the faults lie inside the coaxial connector somewhere in the antenna system. They are the The reason is - coax connector fitting is a science AND an art. Many folk think they have only to jamb things together and the electrons find the way. Not so. Cheers, Ferg ________________________________________________________________________________
Subject: Shakeup at EAA Sport Aviation
Date: Aug 26, 2007
8/26/2007 Hello George, You wrote: "EAA is non profit and therefore can't lobby.....skip......" I agree with the content and thrust of your defense of the EAA (copied below), but I assure you that being a not for profit organization does not prohibit that organization from lobbying. Washington DC is infested with such organizations -- I used to work for one. There may be some gray areas regarding what one considers "real lobbying". Real lobbyists are required to register and file reports, but "concerned cititzens" are not -- semantic games may be played. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." --------------- RESPONDING TO --------------- From: <gmcjetpilot(at)yahoo.com> Subject: AeroElectric-List: Re: Shakeup at EAA Sport Aviation >From: "Mike" <mlas(at)cox.net> >Subject: Re: Shakeup at EAA Sport Aviation > >But today's EAA is just a wanabe competitor to AOPA. > >Mike Not sure where you are going, but I did a little study of AOPA and EAA and what they actually do for experimental amateur built and flown planes. Just for clarity AOPA is a lobby group and represents manufactures and small non- scheduled commercial operators, as well as individual private operators (allegedly). EAA is non profit and therefore can't lobby but they do a lot of legal work clarifying the FAR's. If you ever had a DAR tell you that your RV-7 needs an A&P sign off because the engine is from a certified aircraft, you will appreciate what they do. Since the AOPA is aligned heavily with manufactures of certified aircraft and the aviation business, the needs of experimental aircraft is not a priority for them. The EAA is all we have and they are best suited to protect our niche of the aviation world. There are common goals and interest between AOPA and EAA, who do work together some times, but not always. In California, LA area an airport banned experimental aircraft (tried to) and the Las Vegas FSDO tried to restrict experimental's from a huge block of air space. Behind the scene the EAA solved the issue. Unlike the AOPA the EAA did not blow their own horn. They like to take a quite approach and not embarrass the FAA. They where successful in both cases. EAA is not immune of criticism. This topic went around the RV-list. The main complaint I had in the past was the magazine was dummied down and they dropped the Caf Foundation org reports. I was told they where too technical for most. They have done better in the last year or so, but if you want technical info, go to the internet, which has replaced most topical print media. "Contact" magazine is more technical for the real experimenter and tinkerer. EAA's SA magazine does need contributors. If you have an idea for an article write it, they need content. Many past articles where "fluff" and seemed more like advertisement propaganda than fact. EAA does many things to protect experimental plane rights, building and use of airspace, fighting made up interpretations of the FAR's by DAR's and FAA inspectors. If you have a question about AD compliance, required equip or TSO'ed requirements for experimental aircraft, they have brief on it for members. The EAA tax records are public record. Not surprising on about $30 mil revenue, expenses where almost exactly $30 mil, thus non-profit. Not a surprise. Tom Poberezny makes $418,000, about 1/2 million in total compensation a year as CEO of the EAA. That seems in-line with CEO salaries I suppose, for a $30 organization.. Airventure does bring in lots of money but also cost a lot of money to put on. The magazine is a huge expense on the budget. I guess all the color pictures? Dues are the big revenue stream. The P-51 thing is very old news. It was about his dad, Paul, EAA founder and former CEO. There was some blow-up I recall about his P-51 time being paid for by the EAA. That was resolved and I recall Paul retired soon thereafter. Paul's still on the payroll and makes about $80k or $160k a year? EAA's tax return looks normal to me; the board of directors are all volunteers. They spend a lot on office space and professional services. My EAA membership is based on more than the magazine and Airventure. They do have good programs like young eagles, and the local chapters are also a nice thing. If you are active in building and flying experimental aircraft the EAA is valuable. I have talked to EAA legal a few times and they know their stuff, surprisingly better than the FAA. There are some old bones in the FAA closet that they try to pass as facts. Of all organizations, EAA does the most to protect our incredible freedom to build and fly planes we make with our own hands. Forces constantly are trying to re-write and restrict those freedoms. EAA is doing the most of us specifically, IMHO. To be fair AOPA is the only real lobby group on capital hill that is representing our "special interest". Of course we can always write our DC politicians directly. May be we should start a quasi political group of all experimental aircraft builders/ owners. That would be a good sized voter block. The economy of the kit plane business and all the support and part companies is substantial. Cheers George EAA member since 1985 ________________________________________________________________________________
Date: Aug 26, 2007
Yes, yes. It's not lobbying...the EAA would just be informing and educating the Legislator's about the issues. Actually, it would be educating the Legislator's staff. Congressmen don't know anything...they are lead around by their nose by their staff. The only other uses of their nose is to sniff out photo opportunities and to sniffing the prevailing wind of opinion. Fortunately, they are always positioned upwind of themselves so the odor is tolerable. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bakerocb(at)cox.net Sent: Sunday, August 26, 2007 10:49 AM Subject: AeroElectric-List: Shakeup at EAA Sport Aviation 8/26/2007 Hello George, You wrote: "EAA is non profit and therefore can't lobby.....skip......" I agree with the content and thrust of your defense of the EAA (copied below), but I assure you that being a not for profit organization does not prohibit that organization from lobbying. Washington DC is infested with such organizations -- I used to work for one. There may be some gray areas regarding what one considers "real lobbying". Real lobbyists are required to register and file reports, but "concerned cititzens" are not -- semantic games may be played. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." --------------- RESPONDING TO --------------- From: <gmcjetpilot(at)yahoo.com> Subject: AeroElectric-List: Re: Shakeup at EAA Sport Aviation >From: "Mike" <mlas(at)cox.net> >Subject: Re: Shakeup at EAA Sport Aviation > >But today's EAA is just a wanabe competitor to AOPA. > >Mike Not sure where you are going, but I did a little study of AOPA and EAA and what they actually do for experimental amateur built and flown planes. Just for clarity AOPA is a lobby group and represents manufactures and small non- scheduled commercial operators, as well as individual private operators (allegedly). EAA is non profit and therefore can't lobby but they do a lot of legal work clarifying the FAR's. If you ever had a DAR tell you that your RV-7 needs an A&P sign off because the engine is from a certified aircraft, you will appreciate what they do. Since the AOPA is aligned heavily with manufactures of certified aircraft and the aviation business, the needs of experimental aircraft is not a priority for them. The EAA is all we have and they are best suited to protect our niche of the aviation world. There are common goals and interest between AOPA and EAA, who do work together some times, but not always. In California, LA area an airport banned experimental aircraft (tried to) and the Las Vegas FSDO tried to restrict experimental's from a huge block of air space. Behind the scene the EAA solved the issue. Unlike the AOPA the EAA did not blow their own horn. They like to take a quite approach and not embarrass the FAA. They where successful in both cases. EAA is not immune of criticism. This topic went around the RV-list. The main complaint I had in the past was the magazine was dummied down and they dropped the Caf Foundation org reports. I was told they where too technical for most. They have done better in the last year or so, but if you want technical info, go to the internet, which has replaced most topical print media. "Contact" magazine is more technical for the real experimenter and tinkerer. EAA's SA magazine does need contributors. If you have an idea for an article write it, they need content. Many past articles where "fluff" and seemed more like advertisement propaganda than fact. EAA does many things to protect experimental plane rights, building and use of airspace, fighting made up interpretations of the FAR's by DAR's and FAA inspectors. If you have a question about AD compliance, required equip or TSO'ed requirements for experimental aircraft, they have brief on it for members. The EAA tax records are public record. Not surprising on about $30 mil revenue, expenses where almost exactly $30 mil, thus non-profit. Not a surprise. Tom Poberezny makes $418,000, about 1/2 million in total compensation a year as CEO of the EAA. That seems in-line with CEO salaries I suppose, for a $30 organization.. Airventure does bring in lots of money but also cost a lot of money to put on. The magazine is a huge expense on the budget. I guess all the color pictures? Dues are the big revenue stream. The P-51 thing is very old news. It was about his dad, Paul, EAA founder and former CEO. There was some blow-up I recall about his P-51 time being paid for by the EAA. That was resolved and I recall Paul retired soon thereafter. Paul's still on the payroll and makes about $80k or $160k a year? EAA's tax return looks normal to me; the board of directors are all volunteers. They spend a lot on office space and professional services. My EAA membership is based on more than the magazine and Airventure. They do have good programs like young eagles, and the local chapters are also a nice thing. If you are active in building and flying experimental aircraft the EAA is valuable. I have talked to EAA legal a few times and they know their stuff, surprisingly better than the FAA. There are some old bones in the FAA closet that they try to pass as facts. Of all organizations, EAA does the most to protect our incredible freedom to build and fly planes we make with our own hands. Forces constantly are trying to re-write and restrict those freedoms. EAA is doing the most of us specifically, IMHO. To be fair AOPA is the only real lobby group on capital hill that is representing our "special interest". Of course we can always write our DC politicians directly. May be we should start a quasi political group of all experimental aircraft builders/ owners. That would be a good sized voter block. The economy of the kit plane business and all the support and part companies is substantial. Cheers George EAA member since 1985 ________________________________________________________________________________
Date: Aug 26, 2007
Chuck, You forget the politician's use of his/her nose to pack the rectal cavity of campaign contributors and lobbyists. :-) Rick On 8/26/07, Chuck Jensen wrote: > > cjensen(at)dts9000.com> > > Yes, yes. It's not lobbying...the EAA would just be informing and > educating the Legislator's about the issues. Actually, it would be > educating the Legislator's staff. Congressmen don't know > anything...they are lead around by their nose by their staff. The only > other uses of their nose is to sniff out photo opportunities and to > sniffing the prevailing wind of opinion. Fortunately, they are always > positioned upwind of themselves so the odor is tolerable. > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > bakerocb(at)cox.net > Sent: Sunday, August 26, 2007 10:49 AM > To: aeroelectric-list(at)matronics.com; gmcjetpilot(at)yahoo.com > Subject: AeroElectric-List: Shakeup at EAA Sport Aviation > > > 8/26/2007 > > Hello George, You wrote: "EAA is non profit and therefore can't > lobby.....skip......" > > I agree with the content and thrust of your defense of the EAA (copied > below), but I assure you that being a not for profit organization does > not > prohibit that organization from lobbying. Washington DC is infested with > > such organizations -- I used to work for one. > > There may be some gray areas regarding what one considers "real > lobbying". > Real lobbyists are required to register and file reports, but "concerned > > cititzens" are not -- semantic games may be played. > > 'OC' Says: "The best investment we can make is the effort to gather and > understand knowledge." > > --------------- RESPONDING TO --------------- > > From: <gmcjetpilot(at)yahoo.com> > Subject: AeroElectric-List: Re: Shakeup at EAA Sport Aviation > > >From: "Mike" <mlas(at)cox.net> > >Subject: Re: Shakeup at EAA Sport Aviation > > > >But today's EAA is just a wanabe competitor to AOPA. > > > >Mike > > Not sure where you are going, but I did a > little study of AOPA and EAA and what they > actually do for experimental amateur built > and flown planes. > > Just for clarity AOPA is a lobby group and > represents manufactures and small non- > scheduled commercial operators, as well as > individual private operators (allegedly). > > EAA is non profit and therefore can't lobby > but they do a lot of legal work clarifying > the FAR's. If you ever had a DAR tell you > that your RV-7 needs an A&P sign off because > the engine is from a certified aircraft, you > will appreciate what they do. > > Since the AOPA is aligned heavily with > manufactures of certified aircraft and the > aviation business, the needs of experimental > aircraft is not a priority for them. The EAA > is all we have and they are best suited to > protect our niche of the aviation world. > > There are common goals and interest between > AOPA and EAA, who do work together some > times, but not always. > > In California, LA area an airport banned > experimental aircraft (tried to) and the Las > Vegas FSDO tried to restrict experimental's > from a huge block of air space. Behind the > scene the EAA solved the issue. Unlike the > AOPA the EAA did not blow their own horn. > They like to take a quite approach and not > embarrass the FAA. They where successful > in both cases. > > EAA is not immune of criticism. This topic > went around the RV-list. The main complaint > I had in the past was the magazine was > dummied down and they dropped the Caf > Foundation org reports. I was told they > where too technical for most. They have done > better in the last year or so, but if you > want technical info, go to the internet, > which has replaced most topical print media. > "Contact" magazine is more technical for the > real experimenter and tinkerer. > > EAA's SA magazine does need contributors. If > you have an idea for an article write it, they need > content. Many past articles where "fluff" and seemed > more like advertisement propaganda than fact. > > > EAA does many things to protect experimental > plane rights, building and use of airspace, fighting > made up interpretations of the FAR's by DAR's and > FAA inspectors. > > If you have a question about AD compliance, > required equip or TSO'ed requirements for > experimental aircraft, they have brief on it > for members. > > The EAA tax records are public record. Not > surprising on about $30 mil revenue, > expenses where almost exactly $30 mil, thus > non-profit. Not a surprise. > > Tom Poberezny makes $418,000, about > 1/2 million in total compensation a year as > CEO of the EAA. That seems in-line with CEO > salaries I suppose, for a $30 organization.. > > Airventure does bring in lots of money but > also cost a lot of money to put on. > The magazine is a huge expense on the budget. > I guess all the color pictures? > Dues are the big revenue stream. > > The P-51 thing is very old news. It was about his > dad, Paul, EAA founder and former CEO. There > was some blow-up I recall about his P-51 > time being paid for by the EAA. That was > resolved and I recall Paul retired soon > thereafter. Paul's still on the payroll and > makes about $80k or $160k a year? > > EAA's tax return looks normal to me; the board > of directors are all volunteers. They spend a > lot on office space and professional services. > > My EAA membership is based on more than the > magazine and Airventure. They do have good > programs like young eagles, and the local > chapters are also a nice thing. If you are active > in building and flying experimental aircraft the > EAA is valuable. I have talked to EAA legal > a few times and they know their stuff, surprisingly > better than the FAA. There are some old bones > in the FAA closet that they try to pass as facts. > > > Of all organizations, EAA does the most to protect > our incredible freedom to build and fly planes we > make with our own hands. Forces constantly are > trying to re-write and restrict those freedoms. EAA > is doing the most of us specifically, IMHO. > > > To be fair AOPA is the only real lobby group on > capital hill that is representing our "special interest". > Of course we can always write our DC politicians > directly. May be we should start a quasi political > group of all experimental aircraft builders/ owners. > That would be a good sized voter block. The > economy of the kit plane business and all the support > and part companies is substantial. > > > Cheers George EAA member since 1985 > > -- Rick Girard "Ya'll drop on in" takes on a whole new meaning when you live at the airport. ________________________________________________________________________________
Date: Aug 26, 2007
Subject: How to check and alternator??
I have a 35 amp alternator and a 12 volt concorde battery and a Linear Voltage Regulator. Lycoming 160hp I have noticed the voltage reads just under 14 volts with the engine running. I also noticed the ammeter stays at zero unless I turn on something such as the nav lights or strobe lights. Then it goes to the negative about 1/16 of an inch on a +40/-40 amp guage. This remains the same even at high throttle settings. No change at low or high power settings. I have a shunt. I checked all the wiring an it is correct from Bingelis' book so I am wondering if my alternator is bad. What is the best way to check an alternator on an airplane? Can't really take it to my neighborhood Advance AutoParts. They might wonder what the big fan is for. Thanks!! --------------------------------- Boardwalk for $500? In 2007? Ha! ________________________________________________________________________________
Date: Aug 26, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: AeroElectric-List Digest: 10 Msgs - 08/23/07
>Hey, I can't find any info about shortening the leads on the EGT and CHT. >Is it ok and do I have to keep them all the same length? Thanks in >advance. Jack Modern thermocouple measurement systems have high-impedance instrument inputs and are immune to variability in thermocouple length. The self powered instruments of WWII era used (1) either fixed length thermocouples of a specific type of wire or included a compensating resistor in the system for calibrating an instrument to a thermocouple. You may adjust the length of the leads as you see fit as long as you observe the "splicing rules" outlined in http://www.aeroelectric.com/articles/excerpt.pdf When you "reply" to a digest posting it would be a good idea to cut away all the text that is not pertinent to your topic. Bob . . . ________________________________________________________________________________
Date: Aug 26, 2007
Subject: Re: How to check and alternator??
>I have a 35 amp alternator and a 12 volt concorde battery and a Linear >Voltage Regulator. Lycoming 160hp > >I have noticed the voltage reads just under 14 volts with the engine running. > >I also noticed the ammeter stays at zero unless I turn on something such >as the nav lights or strobe lights. Then it goes to the negative about >1/16 of an inch on a +40/-40 amp guage. This remains the same even at >high throttle settings. No change at low or high power settings. > >I have a shunt. I checked all the wiring an it is correct from Bingelis' >book so I am wondering if my alternator is bad. > >What is the best way to check an alternator on an airplane? Can't really >take it to my neighborhood Advance AutoParts. They might wonder what the >big fan is for. Sounds like your alterantor is working. You can't have a bus votlage greater than about 12.8 if the alternator is not picking up ship's loads. Where is your ammeter in the system? If you have a -0+ reading ammeter, then it suggests a battery ammeter which is almost useless as a diagnostic tool. Suggest that you convert the ammeter to a +only alternator load meter. Then you'll see the alternator functioning as expected . . . picking up loads as they are added to the system. Bob . . . ________________________________________________________________________________
Date: Aug 26, 2007
Subject: Re: AeroElectric-List Digest: 11 Msgs - 08/25/07
Why did you say that Oshkosh was a much better value than Sun n Fun? Not argueing, just wondering... Lee... ________________________________________________________________________________
Date: Aug 26, 2007
>Why did you say that Oshkosh was a much better value than Sun n Fun? Not >argueing, just wondering... > >Lee... I can drive to OSH in one day. I have principals who subsidize my attendance. The volume of networking contacts and depth of access to new technologies is better. I sell 30-40 books at OSH. It takes two days to drive to Florida for 1/10th the exposure and access. I think I sold 5 books the first and only time I was there. The return on investment for $time$ spent at OSH is, for me at least, the hands-down winner. Bob . . . ________________________________________________________________________________
Date: Aug 27, 2007
Subject: Re: Strobes - Light Plane Maintenance Article
Just an additional comment.. In the Whelan strobe installation manual it cautions you not to apply full voltage to a power supply that has not been charged for a long time, such as on initial installation. If I remember correctly it says to start by applying half power initially. I am on the road so cannot look it up until the end of the month, maybe someone else can confirm my recollection. On 8/24/07, Robert L. Nuckolls, III wrote: > > nuckollsr(at)cox.net> > > > > > > > > >-A strobe power supply may or may not be stored in a way to control > >temperature. Ambient temps have exceeded the 25C that the article > suggest > >for weeks now here in NC. If it were buried in a wing stored in the > >rafters of a hanger, the temps could be much higher still. Could that be > >the nexus of the problem? > > > >-If the strobe is using cheap caps...well, I'd just be upset about that > one. > > Which speaks to the value of conducting tests per DO-160. > One cannot attract many customers in the type certificated > aircraft world without jumping these hoops. Further, given > the exceedingly small fraction of the world represented by > aviation circles, it's impossible to keep the astute mechanics > from knowing about poorly crafted products or less than > helpful customer support. Stack these notions with the > idea that really good capacitors are not that much more > expensive than mediocre devices. Given the blood, sweat and > tears sacrificed to the altars of regulation, it's > unlikely that a company like Grimes or Whelen is going > to compound their grief-to-market by cutting corners in > the selection of components. > > Bob . . . > > -- John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Aug 27, 2007
Just looked at the manual, and it does indeed hold a warning for older units only. Below is a quote from the manual. Rob == WARNING: Strobe light power supplies are meant to be used, not to remain in an inactive state. Use them at all times, this will improve their proper functioning. Any strobe light power supply that has been out of service for a long period of time is subject to failure because the electrolytic condenser loses the polarity formation. A strobe light power supply not having been used for one year or longer is vulnerable to failure, applies to 1993 & older units. If this is the case, it is recommended to start operating the system on a voltage that is reduced by 25 percent for 10 to 15 minutes before putting the power supply into normal service. This will prevent overheating of the condenser while they reform. If the power supply, after a long period of non use, is operated at full voltage immediately, there is an excellent possibility that the condenser will become overheated. == ----- Original Message ----- From: John McMahon Sent: Monday, August 27, 2007 3:06 PM Subject: Re: AeroElectric-List: Strobes - Light Plane Maintenance Article Just an additional comment.. In the Whelan strobe installation manual it cautions you not to apply full voltage to a power supply that has not been charged for a long time, such as on initial installation. If I remember correctly it says to start by applying half power initially. I am on the road so cannot look it up until the end of the month, maybe someone else can confirm my recollection. ________________________________________________________________________________
Date: Aug 27, 2007
I called Wheelen when I had a "new in the box" twenty year old power supply. I was told three volts for an hour, then six, nine, twelve. Each for one hour. That was three years ago, still works fine. Kevin Boddicker Tri Q 200 N7868B 63.5 hours Luana, IA. On Aug 27, 2007, at 8:06 AM, John McMahon wrote: > Just an additional comment.. In the Whelan strobe installation > manual it cautions you not to apply full voltage to a power supply > that has not been charged for a long time, such as on initial > installation. If I remember correctly it says to start by > applying half power initially. I am on the road so cannot look it > up until the end of the month, maybe someone else can confirm my > recollection. > > On 8/24/07, Robert L. Nuckolls, III wrote: > > > > > > > > > >-A strobe power supply may or may not be stored in a way to control > >temperature. Ambient temps have exceeded the 25C that the article > suggest > >for weeks now here in NC. If it were buried in a wing stored in the > >rafters of a hanger, the temps could be much higher still. Could > that be > >the nexus of the problem? > > > >-If the strobe is using cheap caps...well, I'd just be upset about > that one. > > Which speaks to the value of conducting tests per DO-160. > One cannot attract many customers in the type certificated > aircraft world without jumping these hoops. Further, given > the exceedingly small fraction of the world represented by > aviation circles, it's impossible to keep the astute mechanics > from knowing about poorly crafted products or less than > helpful customer support. Stack these notions with the > idea that really good capacitors are not that much more > expensive than mediocre devices. Given the blood, sweat and > tears sacrificed to the altars of regulation, it's > unlikely that a company like Grimes or Whelen is going > to compound their grief-to-market by cutting corners in > Lancair Super ES, S/N 170, N9637M (Reserved) > > ________________________________________________________________________________
Date: Aug 27, 2007
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
It depends on where your ammeter is connected as to what info it is giving you. The best way to know if your alternator is working adequately (i.e is making more current than is consumed by the electrical devices in your airplane) is to watch the voltmeter. I.e if you turn everything on and it maintains above say 13.5V it working just fine. If it drops below 12.5V then it is either malfunctioning or is undersized for the application. Sounds to me like your unit is working just fine. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Reeves Sent: Sunday, August 26, 2007 4:51 PM Subject: AeroElectric-List: How to check and alternator?? I have a 35 amp alternator and a 12 volt concorde battery and a Linear Voltage Regulator. Lycoming 160hp I have noticed the voltage reads just under 14 volts with the engine running. I also noticed the ammeter stays at zero unless I turn on something such as the nav lights or strobe lights. Then it goes to the negative about 1/16 of an inch on a +40/-40 amp guage. This remains the same even at high throttle settings. No change at low or high power settings. I have a shunt. I checked all the wiring an it is correct from Bingelis' book so I am wondering if my alternator is bad. What is the best way to check an alternator on an airplane? Can't really take it to my neighborhood Advance AutoParts. They might wonder what the big fan is for. Thanks!! ________________________________________________________________________________
Date: Aug 27, 2007
Subject: Sorry
Bob et. all, I was looking through the digest from yesterday and wondered what idiot didn't delete the messages before posting. Almost missed the reply Bob gave to my message and then realized from Bob's remark that I was the idiot. Sorry, and thanks for the info Bob, Jack --------------------------------- Fussy? Opinionated? Impossible to please? Perfect. Join Yahoo!'s user panel and lay it on us. ________________________________________________________________________________
Date: Aug 27, 2007
Subject: Mixing and matching strobe supplies and flash tube
heads > >Comments/Questions: Bill Vondane of CreatiVair has a new low profile >streamlined Strobe/LED position light, the answer to my prayers. Bill says >my already installed Grimes Powerpack ex '79 Grumman Cougar is too >powerful for his strobe tubes and he wants to sell me a police style >powerpak as "a matched umit". Also he will not give warranty on his >strobes if used with Grimes. > >Is he right, or just trying to sell me stuff I do not need? Specs. of his >powerpack ans strobe unit are on the Creativair Website. > >I have studied your book on the subject, but am still unsure. Flash tubes are rather inefficient and will get pretty hot when operated within ratings. It's entirely possible that one of super, eye-ball frying strobe systems would deliver too much energy per flash. Without doing bench testing or analyzing his choice of parts for flash-tubes, I'd be hard pressed to offer any better information. Bob . . . ---------------------------------------- ( IF one wishes to be "world class" at ) ( anything, what ever you do must be ) ( exercised EVERY day . . . ) ( R. L. Nuckolls III ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 27, 2007
>I called Wheelen when I had a "new in the box" twenty year old power supply. >I was told three volts for an hour, then six, nine, twelve. Each for one >hour. That was three years ago, still works fine. >Kevin Boddicker >Tri Q 200 N7868B 63.5 hours >Luana, IA. > > >On Aug 27, 2007, at 8:06 AM, John McMahon wrote: > >>Just an additional comment.. In the Whelan strobe installation manual it >>cautions you not to apply full voltage to a power supply that has not >>been charged for a long time, such as on initial installation. If I >>remember correctly it says to start by applying half power initially. I >>am on the road so cannot look it up until the end of the month, maybe >>someone else can confirm my recollection. It never hurts to do a 'reforming' exercise on a strobe supply that has been in storage for a long period of time. What is not known . . . and will never be known without some judicious data gathering and analysis is whether or not the device really benefits from this exercise. It's doubtful that any of the big dogs in the strobe business will come forward with real data . . . it's pretty hard to find capacitors that have been in storage for 20+ years. The 'reforming' routine has been a standard fixture in the installation manuals for 40 years. Some folks still recommend avionics master switches for radios. But when asked to supports the validity of the exercise with simple-ideas and repeatable-experiments, the standard response is "that's the way we've always done it." If anyone is worried about it, by all means do the extended spool-up exercise. Bob . . . ---------------------------------------- ( "Physics is like sex: sure, it may ) ( give some practical results, but ) ( that's not why we do it." ) ( ) ( Richard P. Feynman ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 27, 2007
Thanks for messages. Here's the answer to your questions. I have a Chief Aircraft +/- 40 ammeter with a 40amp shunt. I think my alternator is 35 amps but can't remember - I'll have to look that up. I am running Nav lights, strobe lights, wig wag lights, and a full Garmin stack so I'm thinking I may need to upgrade my alternator. Will have to add that up before first flight to see the load. The ammeter has a positive and negative terminal on the back. The positive is connected to to the small screw on the shunt which also has a large screw on the same side which is wired directly to the main power bus which also splits to a wire between the master and starter relay. The negative side on the back of the ammeter is connected to the opposite small screw on the shunt which also has a large screw which is wired through a 60amp circuit breaker to the main power bus. Kinda hard to explain without a picture. I followed the Bingeles book when I wired it up a few years back so maybe I messed something up. I do know that the volt meter reads barely under 14 volts with the engine running. Thanks for the help!!!! Matt P.S. My brother Danny has an RV-7A completely built in the basement of his house in Harrisburg, PA. His MIL lives in the garage. We got an estimate of $7000 to have someone dig a hole, cut the blocks out and put it all back together. We are hoping for some suggestions as to how to get it out. (The airplane - not the Mother-In-Law) "Robert L. Nuckolls, III" wrote: >I have a 35 amp alternator and a 12 volt concorde battery and a Linear >Voltage Regulator. Lycoming 160hp > >I have noticed the voltage reads just under 14 volts with the engine running. > >I also noticed the ammeter stays at zero unless I turn on something such >as the nav lights or strobe lights. Then it goes to the negative about >1/16 of an inch on a +40/-40 amp guage. This remains the same even at >high throttle settings. No change at low or high power settings. > >I have a shunt. I checked all the wiring an it is correct from Bingelis' >book so I am wondering if my alternator is bad. > >What is the best way to check an alternator on an airplane? Can't really >take it to my neighborhood Advance AutoParts. They might wonder what the >big fan is for. Sounds like your alterantor is working. You can't have a bus votlage greater than about 12.8 if the alternator is not picking up ship's loads. Where is your ammeter in the system? If you have a -0+ reading ammeter, then it suggests a battery ammeter which is almost useless as a diagnostic tool. Suggest that you convert the ammeter to a +only alternator load meter. Then you'll see the alternator functioning as expected . . . picking up loads as they are added to the system. Bob . . . --------------------------------- Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool. ________________________________________________________________________________
From: "Peter Harris" <peterjfharris(at)bigpond.com>
Subject: A simple ECU
Date: Aug 28, 2007
I am in the process of installing a simple TBI system to the Jabiru 3300. Just two injectors in a spigot type throttle body which takes the place of the Bing, it works from a MAP sensor and air temp sensor, the ECU is triggered from the flywheel magnets. We are using a regular automotive ECU which is a giant overkill and very expensive. We can trim the mixture using a pot if required. My question is has anyone seen a simple programmable unit that could be programmed with a pot, a switch and a digital dial. The programming would be done by select injector time and enter as required. We would keep the manual over ride. What would be the elements of such a simple ECU ? Any idea where I could get some help would be appreciated. Thanks Peter H ________________________________________________________________________________
Date: Aug 28, 2007
Subject: Re: A simple ECU
Peter Google "megasquirt efi" for an under $200. system and lots of related info. Not recommended for aviation of course but I run one as a manually selectable backup to my main subaru efi. I have mine configured with the inputs that you describe and it is fine for my purposes. For everyday use it would benefit from connecting a TPS (throttle position sensor) acceleration enrichment, or one could run the code that enriches based on delta MAP. A water temp (cylinder or oil temp for you) sensor would also be handy for starting and warmup but I don't use mine for startup. There are some schemes for doing this with analog electronics but the megasquirt is definately the way to do it nowadays and about as simple as I could find. I have a manual mixture tweaking knob but it is not needed (especially if one has an engine emp sensor) and if it isn't there - it can't fail. I use an old 486 laptop for programming. If you are only going to have a primary controller I'd suggest googling SDS EFI. That would most likely require re-arranging your flywheel pickups but it would have "established" reliability. I think there are thousands of megaquirt units in use but each is somewhat different and subject to unique failures. Megasquirt has very little capability of keeping the engine running after a sensor or wire failure compared to oem or even the SDS system. Ken Peter Harris wrote: > > > I am in the process of installing a simple TBI system to the Jabiru > 3300. Just two injectors in a spigot type throttle body which takes > the place of the Bing, it works from a MAP sensor and air temp sensor, > the ECU is triggered from the flywheel magnets. We are using a regular > automotive ECU which is a giant overkill and very expensive. > > We can trim the mixture using a pot if required. > > My question is has anyone seen a simple programmable unit that could > be programmed with a pot, a switch and a digital dial. The programming > would be done by select injector time and enter as required. We would > keep the manual over ride. > > What would be the elements of such a simple ECU ? Any idea where I > could get some help would be appreciated. > > Thanks > > Peter H > > ________________________________________________________________________________
Subject: Homemade 1/4 wave TSPD antenna
Date: Aug 28, 2007
Bob, Thanks for the reply to my last msg (1/4 Wave Comm Ant). A follow-up... I am contemplating putting a 1/4 wave TSPD antenna on the belly of a composite aircraft, directly under the pilot seat. In chapter 13 of the Connection you talk about making the ground plane 5.5" dia to keep it resonant. >From a health standpoint, does 5.5" effectively shield the pilot (and co-pilot) - i.e. keep all the radiated energy below horizontal, or should I do something else. Options: a. Make the ground plane bigger (but I can only get to about 13" diameter). b. Make a second, larger shield slightly above the ground plane and not connected to it. Rick ________________________________________________________________________________
Date: Aug 28, 2007
Check--http://industrial.rell.com/pdfs/IPG_AN_appguide.pdf Excerpt from above: "Aluminum electrolytic capacitors stored for more than 5 to 10 years may have increased levels of DC leakage current. Check if DCL meets application requirements before placing in service. Recondition high DCL units by applying rated voltage through 1,000 ohm resistor for 30 minutes. Shelf life is a measure of how the capacitors will withstand storage for long times especially at high temperature. To test shelf life place the capacitors in an oven set to the shelf-life test temperature 0 +3 C for the shelf-life test period. Upon completion of the test stabilize the capacitors at 25 C for 24 h or more. Apply the rated voltage for 30 minutes, then verify the post test limits. Unless otherwise specified the capacitance, DCL and ESR will meet initial requirements." -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131345#131345 ________________________________________________________________________________
Subject: Rotax electrical switches
Date: Aug 28, 2007
I am building my Zenith 701/Rotax 912 electrical system following Aeroelectric's Z16 diagram because I trust that Bob Nuckolls knows a hell of a lot more about aircraft electrical systems than I do. I don't even know enough to fully understand the use of the two switches in the diagram. I would appreciate if Bob or someone who understands this diagram can tell me how to use switch S1 (the double poll double throw switch) and the switch attached to the endurance buss. I also need to understand what type of switch this second one is. It looks like a single poll on-off type but I'm not certain because it has a "^" symbol in it. Thanks for the help, Les ________________________________________________________________________________
Date: Aug 28, 2007
Subject: Re: Rotax electrical switches
Les, If you don't have Bob's book buy it. If you do then read the chapter on switches about 5 times. That is the number I am up to and I think I am about to "get it". Good luck, Mike ----- Original Message ----- From: Les Goldner <lgold@quantum-associates.com> Date: Tuesday, August 28, 2007 9:42 am Subject: AeroElectric-List: Rotax electrical switches > I am building my Zenith 701/Rotax 912 electrical system following > Aeroelectric's Z16 diagram because I trust that Bob Nuckolls knows > a hell of > a lot more about aircraft electrical systems than I do. I don't > even know > enough to fully understand the use of the two switches in the > diagram. I > would appreciate if Bob or someone who understands this diagram > can tell me > how to use switch S1 (the double poll double throw switch) and the > switchattached to the endurance buss. I also need to understand > what type of > switch this second one is. It looks like a single poll on-off type > but I'm > not certain because it has a "^" symbol in it. > > Thanks for the help, > Les > > > ________________________________________________________________________________
Date: Aug 29, 2007
Thanks Ken I had not checked the price of Megasquirt it is cheaper than I expected. I guess I am interested in making something like the EC2 series from Real World Solutions, but will take a closer look at the Megasquirt. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Sent: Tuesday, 28 August 2007 10:35 PM Subject: Re: AeroElectric-List: A simple ECU Peter Google "megasquirt efi" for an under $200. system and lots of related info. Not recommended for aviation of course but I run one as a manually selectable backup to my main subaru efi. I have mine configured with the inputs that you describe and it is fine for my purposes. For everyday use it would benefit from connecting a TPS (throttle position sensor) acceleration enrichment, or one could run the code that enriches based on delta MAP. A water temp (cylinder or oil temp for you) sensor would also be handy for starting and warmup but I don't use mine for startup. There are some schemes for doing this with analog electronics but the megasquirt is definately the way to do it nowadays and about as simple as I could find. I have a manual mixture tweaking knob but it is not needed (especially if one has an engine emp sensor) and if it isn't there - it can't fail. I use an old 486 laptop for programming. If you are only going to have a primary controller I'd suggest googling SDS EFI. That would most likely require re-arranging your flywheel pickups but it would have "established" reliability. I think there are thousands of megaquirt units in use but each is somewhat different and subject to unique failures. Megasquirt has very little capability of keeping the engine running after a sensor or wire failure compared to oem or even the SDS system. Ken Peter Harris wrote: > > > I am in the process of installing a simple TBI system to the Jabiru > 3300. Just two injectors in a spigot type throttle body which takes > the place of the Bing, it works from a MAP sensor and air temp sensor, > the ECU is triggered from the flywheel magnets. We are using a regular > automotive ECU which is a giant overkill and very expensive. > > We can trim the mixture using a pot if required. > > My question is has anyone seen a simple programmable unit that could > be programmed with a pot, a switch and a digital dial. The programming > would be done by select injector time and enter as required. We would > keep the manual over ride. > > What would be the elements of such a simple ECU ? Any idea where I > could get some help would be appreciated. > > Thanks > > Peter H > > ________________________________________________________________________________
Date: Aug 28, 2007
Peter, >>I guess I am interested in making something like the EC2 series from Real World Solutions, but will take a closer look at the Megasquirt. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131469#131469 ________________________________________________________________________________
Date: Aug 29, 2007
Mike at this stage I am gathering information. There is a lot I like about the EC2 but I would like to do it myself and cheaper. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of mikef Sent: Wednesday, 29 August 2007 8:17 AM Subject: AeroElectric-List: Re: A simple ECU Peter, >>I guess I am interested in making something like the EC2 series from Real World Solutions, but will take a closer look at the Megasquirt. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131469#131469 ________________________________________________________________________________
Date: Aug 29, 2007
Peter Harris wrote: > > Thanks Ken I had not checked the price of Megasquirt it is cheaper than I > expected. I guess I am interested in making something like the EC2 series > from Real World Solutions, but will take a closer look at the Megasquirt. > > Peter > Peter, I'm working on a MegaSquirt system. The kits while cheap, seem to be extremely solid with quality components, and the documentation is excellent. The system I've worked out uses two of the Ford EDIS-4 ignition modules, and a standby manual fuel feed to provide an amazing amount of system redundancy. I've got a little more airframe and electronics installation work left, then I will be full-bore concentrating on the engine installation. I'd be happy to discuss what I'm working on with you. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 29, 2007
Subject: Re: NOT airplane related-digital phone sevice
B Tomm wrote: > > I've had cell trouble inside the top floor of an office building. The > building's roof across the parking lot (about 400 feet away) had the cell > tower on it at the same height as where I was. After some testing with the > techs at the cell company it was determined that the cell tower was > over-driving my cellular data communicator. I had a friend build an > attenuator and installed it between the antenna and the cell pack and since > then all is well. Oddly enough, the way we discovered this was when I moved > the cell pack outside the building (to find better reception) it worked best > inside the elevator. This was the first clue that the signal was too > strong. I wonder about the health of those who work in that building > everyday. > There's a fundamental lesson here that applies to all RF communication devices. You have to design the reciever for a particular amount of power. The reciever works by sensing the RF energy as it goes up and down, and then converting and amplifying the energy to give you a sound in a speaker. All very complicated, but the gist is that the input signal has to be moving up and down within a certain range. Don't apply enough power, and the reciever doesn't have enough amplification power to make the voice heard (or the signal can just get sort of lost in the input circuits through attenuation). Apply to much power, and the reciever is driven to the high rail and stays there. The reciever is basically "always on". When designing a cell tower, you want to reach people a mile away. You need to pour quite a lot of energy out of an antennae to cover an area with a 1 mile radius (I don't know the actual coverage of a tower. 1 mile just sounds good). So, you turn the power up so that recievers 1 mile away can get the signal up off the bottom rail, but that driver the reciever that is only 10ft away to the top rail...and keeps it there. Same thing will happen in aircraft radios. Put the transmitter to close to the reciever, and you will overdrive it. Sometimes, more is less. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 30, 2007
Thanks Ernest. At this stage it looks like the EC2 has cheapest ECU as well as other features that suit aircraft. Two Megasquirts would come close. I have just completed istallation and tuning with a Haltech ECU but it is ean exoensive overkill with no ECU redundancy. We are looking at making a more affordable redundant unit. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Thursday, 30 August 2007 1:36 AM Subject: Re: AeroElectric-List: A simple ECU Peter Harris wrote: > > Thanks Ken I had not checked the price of Megasquirt it is cheaper than I > expected. I guess I am interested in making something like the EC2 series > from Real World Solutions, but will take a closer look at the Megasquirt. > > Peter > Peter, I'm working on a MegaSquirt system. The kits while cheap, seem to be extremely solid with quality components, and the documentation is excellent. The system I've worked out uses two of the Ford EDIS-4 ignition modules, and a standby manual fuel feed to provide an amazing amount of system redundancy. I've got a little more airframe and electronics installation work left, then I will be full-bore concentrating on the engine installation. I'd be happy to discuss what I'm working on with you. -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 29, 2007
Hi Peter, For what it is worth, I started out with an HALTECH F3 unit way back in the 90s. The engine ran fine with it although to tune the higher RPM, you had to take a laptop airborne with you - not the best means of tuning in a sprightly RV aircraft. But, the unit eventually failed me (fortunately during a ground run up) causing all 4 injectors to stick in the open position and dump a lot of gasoline through the exhaust pipe before I finally realized what was happening and shut the unit off. I then switched to the RWS EC2 and found it much more to my liking - no lap top, much easier to refine the fuel map, etc. but, most importantly it the EC2 had a redundant system with the flick of a switch and the price was very reasonable. There are no doubt a number of good systems out there but for the $$ I think the EC2 wins the competition. Ed ----- Original Message ----- From: "Peter Harris" <peterjfharris(at)bigpond.com> Sent: Wednesday, August 29, 2007 5:35 PM Subject: RE: AeroElectric-List: A simple ECU > > > Thanks Ernest. At this stage it looks like the EC2 has cheapest ECU as > well > as other features that suit aircraft. Two Megasquirts would come close. > I have just completed istallation and tuning with a Haltech ECU but it is > ean exoensive overkill with no ECU redundancy. > We are looking at making a more affordable redundant unit. > Peter > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest > Christley > Sent: Thursday, 30 August 2007 1:36 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: A simple ECU > > > > Peter Harris wrote: > >> >> Thanks Ken I had not checked the price of Megasquirt it is cheaper than I >> expected. I guess I am interested in making something like the EC2 series >> from Real World Solutions, but will take a closer look at the Megasquirt. >> >> Peter >> > > Peter, I'm working on a MegaSquirt system. The kits while cheap, seem > to be extremely solid with quality components, and the documentation is > excellent. > > The system I've worked out uses two of the Ford EDIS-4 ignition modules, > and a standby manual fuel feed to provide an amazing amount of system > redundancy. I've got a little more airframe and electronics > installation work left, then I will be full-bore concentrating on the > engine installation. I'd be happy to discuss what I'm working on with > you. > > -- > "Life is not a journey to the grave with the intention of arriving safely > in > > a pretty and well preserved body, but rather to skid in broadside, > thoroughly used up, totally worn out, with chocolate in one hand and wine > in > > the other, loudly proclaiming 'WOO HOO What a Ride!'" > --Unknown > > > ________________________________________________________________________________
Date: Aug 30, 2007
Thanks Ed it is shaping up that way. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Anderson Sent: Thursday, 30 August 2007 10:52 AM Subject: Re: AeroElectric-List: A simple ECU Hi Peter, For what it is worth, I started out with an HALTECH F3 unit way back in the 90s. The engine ran fine with it although to tune the higher RPM, you had to take a laptop airborne with you - not the best means of tuning in a sprightly RV aircraft. But, the unit eventually failed me (fortunately during a ground run up) causing all 4 injectors to stick in the open position and dump a lot of gasoline through the exhaust pipe before I finally realized what was happening and shut the unit off. I then switched to the RWS EC2 and found it much more to my liking - no lap top, much easier to refine the fuel map, etc. but, most importantly it the EC2 had a redundant system with the flick of a switch and the price was very reasonable. There are no doubt a number of good systems out there but for the $$ I think the EC2 wins the competition. Ed ----- Original Message ----- From: "Peter Harris" <peterjfharris(at)bigpond.com> Sent: Wednesday, August 29, 2007 5:35 PM Subject: RE: AeroElectric-List: A simple ECU > > > Thanks Ernest. At this stage it looks like the EC2 has cheapest ECU as > well > as other features that suit aircraft. Two Megasquirts would come close. > I have just completed istallation and tuning with a Haltech ECU but it is > ean exoensive overkill with no ECU redundancy. > We are looking at making a more affordable redundant unit. > Peter > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest > Christley > Sent: Thursday, 30 August 2007 1:36 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: A simple ECU > > > > Peter Harris wrote: > >> >> Thanks Ken I had not checked the price of Megasquirt it is cheaper than I >> expected. I guess I am interested in making something like the EC2 series >> from Real World Solutions, but will take a closer look at the Megasquirt. >> >> Peter >> > > Peter, I'm working on a MegaSquirt system. The kits while cheap, seem > to be extremely solid with quality components, and the documentation is > excellent. > > The system I've worked out uses two of the Ford EDIS-4 ignition modules, > and a standby manual fuel feed to provide an amazing amount of system > redundancy. I've got a little more airframe and electronics > installation work left, then I will be full-bore concentrating on the > engine installation. I'd be happy to discuss what I'm working on with > you. > > -- > "Life is not a journey to the grave with the intention of arriving safely > in > > a pretty and well preserved body, but rather to skid in broadside, > thoroughly used up, totally worn out, with chocolate in one hand and wine > in > > the other, loudly proclaiming 'WOO HOO What a Ride!'" > --Unknown > > > ________________________________________________________________________________
Date: Aug 30, 2007
Ed I had a similar experience whith the new F10ex Haltech when I first cranked the engine with the throttle body outboard. It kept on squirting after I stopped cranking until the fuel rail was empty. Must have got a bad trigger signal. Looks as if the EC2 is the way to go. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed Anderson Sent: Thursday, 30 August 2007 10:52 AM Subject: Re: AeroElectric-List: A simple ECU Hi Peter, For what it is worth, I started out with an HALTECH F3 unit way back in the 90s. The engine ran fine with it although to tune the higher RPM, you had to take a laptop airborne with you - not the best means of tuning in a sprightly RV aircraft. But, the unit eventually failed me (fortunately during a ground run up) causing all 4 injectors to stick in the open position and dump a lot of gasoline through the exhaust pipe before I finally realized what was happening and shut the unit off. I then switched to the RWS EC2 and found it much more to my liking - no lap top, much easier to refine the fuel map, etc. but, most importantly it the EC2 had a redundant system with the flick of a switch and the price was very reasonable. There are no doubt a number of good systems out there but for the $$ I think the EC2 wins the competition. Ed ----- Original Message ----- From: "Peter Harris" <peterjfharris(at)bigpond.com> Sent: Wednesday, August 29, 2007 5:35 PM Subject: RE: AeroElectric-List: A simple ECU > > > Thanks Ernest. At this stage it looks like the EC2 has cheapest ECU as > well > as other features that suit aircraft. Two Megasquirts would come close. > I have just completed istallation and tuning with a Haltech ECU but it is > ean exoensive overkill with no ECU redundancy. > We are looking at making a more affordable redundant unit. > Peter > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest > Christley > Sent: Thursday, 30 August 2007 1:36 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: A simple ECU > > > > Peter Harris wrote: > >> >> Thanks Ken I had not checked the price of Megasquirt it is cheaper than I >> expected. I guess I am interested in making something like the EC2 series >> from Real World Solutions, but will take a closer look at the Megasquirt. >> >> Peter >> > > Peter, I'm working on a MegaSquirt system. The kits while cheap, seem > to be extremely solid with quality components, and the documentation is > excellent. > > The system I've worked out uses two of the Ford EDIS-4 ignition modules, > and a standby manual fuel feed to provide an amazing amount of system > redundancy. I've got a little more airframe and electronics > installation work left, then I will be full-bore concentrating on the > engine installation. I'd be happy to discuss what I'm working on with > you. > > -- > "Life is not a journey to the grave with the intention of arriving safely > in > > a pretty and well preserved body, but rather to skid in broadside, > thoroughly used up, totally worn out, with chocolate in one hand and wine > in > > the other, loudly proclaiming 'WOO HOO What a Ride!'" > --Unknown > > > ________________________________________________________________________________
Date: Aug 29, 2007
Subject: NOT airplane related-digital phone sevice
> >I would add that the cable based phone service needs local AC power to work. >They usually use a UPS for standby power should the power go out. But this >standby time will be limited by the capacity and condition of the back up. >The old style phone service is not dependant on AC power at the premises. > >Bevan >RV7A >wiring I was curious about that and asked when they installed our system. For our provider at least, ALL power is provided by the system. If one puts a voltmeter on the center conductor of the coax coming into the back of the house, it has about 90 volts DC on it. I was told that this power is provided NORMALLY by the electric power company . . . but here's the interesting part. All the little green 'dog-houses' around our neighborhood for the cable company also have gas lines going into them. Seems there is a small NG powered standby source. The dog-house at the corner of my housing development says it's made by Alpha and the model number is "CE-SC3". The electric meter on one end shows a peak draw of 1.25 KVA. Before this box went in, if there was a sustained power outage in the neighborhood, the cable guy would show up and plug the box into a little portable Honda putt-putt. Now when theres a power outage, he's noticeably absent and the phones are still working . . . along with any other cable driven appliances that are powered independently of the ac mains. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2007
Yes, Thanks Bob. I forgot about that. A friend of mine works for the cable phone company and had told me some time ago that it's common in larger centers (eastern I think) that the power comes "down the line" from the cable provider. We don't have this technology in our area yet because of the current infrastructure has to be upgraded, so I think of cable phone as requiring local power as that's the standard here. Nothing stays the same anymore? Did it ever? Bevan RV7A -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, August 29, 2007 8:53 PM Subject: RE: AeroElectric-List: NOT airplane related-digital phone sevice --> >--> > >I would add that the cable based phone service needs local AC power to work. >They usually use a UPS for standby power should the power go out. But >this standby time will be limited by the capacity and condition of the back up. >The old style phone service is not dependant on AC power at the premises. > >Bevan >RV7A >wiring I was curious about that and asked when they installed our system. For our provider at least, ALL power is provided by the system. If one puts a voltmeter on the center conductor of the coax coming into the back of the house, it has about 90 volts DC on it. I was told that this power is provided NORMALLY by the electric power company . . . but here's the interesting part. All the little green 'dog-houses' around our neighborhood for the cable company also have gas lines going into them. Seems there is a small NG powered standby source. The dog-house at the corner of my housing development says it's made by Alpha and the model number is "CE-SC3". The electric meter on one end shows a peak draw of 1.25 KVA. Before this box went in, if there was a sustained power outage in the neighborhood, the cable guy would show up and plug the box into a little portable Honda putt-putt. Now when theres a power outage, he's noticeably absent and the phones are still working . . . along with any other cable driven appliances that are powered independently of the ac mains. Bob . . . ________________________________________________________________________________
Date: Aug 29, 2007
Bob, would you mind finding a little more about those dog boxes, if they indeed have propane? gas power? Some remote telecommunication sites use such thermo electric generators and I've read that some thermocouples are available to generate from external exhaust heat of road trucks - you know where this is leading - I wouldnt mind attaching one to my aircraft as a backup power source. Its a little frustrating here in New Zealand there is a manufacturer of stirling engine power generators for boats and homes - called "whispergen" - however they ony seem to supply to certain markets and that doesnt include locally. Regards, Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131740#131740 ________________________________________________________________________________
Date: Aug 30, 2007
Ralph, Sending this off list as it is waaaay off topic. But here's another Kiwi's answer to standby power for important things. Check this out----> http://www.asciimation.co.nz/beer/ Tony www.alejandra.net/velocity 62% done, 78% to go. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jetboy Sent: Wednesday, August 29, 2007 10:56 PM Subject: AeroElectric-List: Re: NOT airplane related-digital phone sevice Bob, would you mind finding a little more about those dog boxes, if they indeed have propane? gas power? Some remote telecommunication sites use such thermo electric generators and I've read that some thermocouples are available to generate from external exhaust heat of road trucks - you know where this is leading - I wouldnt mind attaching one to my aircraft as a backup power source. Its a little frustrating here in New Zealand there is a manufacturer of stirling engine power generators for boats and homes - called "whispergen" - however they ony seem to supply to certain markets and that doesnt include locally. Regards, Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131740#131740 ________________________________________________________________________________
Date: Aug 30, 2007
Oops, sorry. I meant to send this off list. > -----Original Message----- > From: Tony Babb [mailto:tonybabb(at)alejandra.net] > Sent: Thursday, August 30, 2007 2:21 AM > To: 'aeroelectric-list(at)matronics.com' > Subject: RE: AeroElectric-List: Re: NOT airplane > related-digital phone sevice > > > Ralph, > > Sending this off list as it is waaaay off topic. But here's > another Kiwi's answer to standby power for important things. > Check this out----> > > http://www.asciimation.co.nz/beer/ > > Tony > www.alejandra.net/velocity > 62% done, 78% to go. > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of jetboy > Sent: Wednesday, August 29, 2007 10:56 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: NOT airplane related-digital > phone sevice > > > > > Bob, > would you mind finding a little more about those dog > boxes, if they indeed have propane? gas power? Some remote > telecommunication sites use such thermo electric generators > and I've read that some thermocouples are available to > generate from external exhaust heat of road trucks - you know > where this is leading - I wouldnt mind attaching one to my > aircraft as a backup power source. > > Its a little frustrating here in New Zealand there is a > manufacturer of stirling engine power generators for boats > and homes - called "whispergen" - however they ony seem to > supply to certain markets and that doesnt include locally. > > > Regards, Ralph > > -------- > Ralph - CH701 / 2200a > > > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=131740#131740 > > > > > > > > > > ________________________________________________________________________________
Date: Aug 30, 2007
Yes, Peter, I never attempted a diagnoses of the F3 HALTECH unit, but certainly glad I was on the ground when it decided to malfunction. My units problem was more than a stray signal as it never recovered. Ed ----- Original Message ----- From: "Peter Harris" <peterjfharris(at)bigpond.com> Sent: Wednesday, August 29, 2007 9:37 PM Subject: RE: AeroElectric-List: A simple ECU > > > Ed I had a similar experience whith the new F10ex Haltech when I first > cranked the engine with the throttle body outboard. It kept on squirting > after I stopped cranking until the fuel rail was empty. > Must have got a bad trigger signal. > Looks as if the EC2 is the way to go. > Peter > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ed > Anderson > Sent: Thursday, 30 August 2007 10:52 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: A simple ECU > > > > Hi Peter, > > For what it is worth, I started out with an HALTECH F3 unit way back in > the > 90s. The engine ran fine with it although to tune the higher RPM, you had > to take a laptop airborne with you - not the best means of tuning in a > sprightly RV aircraft. > > But, the unit eventually failed me (fortunately during a ground run up) > causing all 4 injectors to stick in the open position and dump a lot of > gasoline through the exhaust pipe before I finally realized what was > happening and shut the unit off. > > I then switched to the RWS EC2 and found it much more to my liking - no > lap > top, much easier to refine the fuel map, etc. but, most importantly it the > EC2 had a redundant system with the flick of a switch and the price was > very reasonable. > > There are no doubt a number of good systems out there but for the $$ I > think > > the EC2 wins the competition. > > > Ed > > > ----- Original Message ----- > From: "Peter Harris" <peterjfharris(at)bigpond.com> > To: > Sent: Wednesday, August 29, 2007 5:35 PM > Subject: RE: AeroElectric-List: A simple ECU > > >> >> >> Thanks Ernest. At this stage it looks like the EC2 has cheapest ECU as >> well >> as other features that suit aircraft. Two Megasquirts would come close. >> I have just completed istallation and tuning with a Haltech ECU but it is >> ean exoensive overkill with no ECU redundancy. >> We are looking at making a more affordable redundant unit. >> Peter >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest >> Christley >> Sent: Thursday, 30 August 2007 1:36 AM >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: A simple ECU >> >> >> >> Peter Harris wrote: >> >>> >>> Thanks Ken I had not checked the price of Megasquirt it is cheaper than >>> I >>> expected. I guess I am interested in making something like the EC2 >>> series >>> from Real World Solutions, but will take a closer look at the >>> Megasquirt. >>> >>> Peter >>> >> >> Peter, I'm working on a MegaSquirt system. The kits while cheap, seem >> to be extremely solid with quality components, and the documentation is >> excellent. >> >> The system I've worked out uses two of the Ford EDIS-4 ignition modules, >> and a standby manual fuel feed to provide an amazing amount of system >> redundancy. I've got a little more airframe and electronics >> installation work left, then I will be full-bore concentrating on the >> engine installation. I'd be happy to discuss what I'm working on with >> you. >> >> -- >> "Life is not a journey to the grave with the intention of arriving safely >> in >> >> a pretty and well preserved body, but rather to skid in broadside, >> thoroughly used up, totally worn out, with chocolate in one hand and wine >> in >> >> the other, loudly proclaiming 'WOO HOO What a Ride!'" >> --Unknown >> >> >> >> >> >> >> >> >> >> > > > ________________________________________________________________________________
Subject: Bob's Audio mixer board.
Date: Aug 30, 2007
Bob K, I recall you had an Audio mixer board at one time and I would like to somehow get hold of one. IIRC it was attached to a 25Pin PCB mount D-Sub connector, with 3-4 inputs and a single output. This would be perfect for me since I plan to mix together the audio from an alternate radio plus the audio from an anunciating EFIS system and feed these to my intercom. For PTT and MIC I plan to fit a 2 pole 2 position switch to select between Radio1 and Radio2. Even if I could acquire the CCT and bare PCB that would be a great help. Thanks, Doug Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131790#131790 ________________________________________________________________________________
Date: Aug 30, 2007
> >Bob, > would you mind finding a little more about those dog boxes, if they > indeed have propane? gas power? Some remote telecommunication sites use > such thermo electric generators and I've read that some thermocouples are > available to generate from external exhaust heat of road trucks - you > know where this is leading - I wouldnt mind attaching one to my aircraft > as a backup power source. I'm not aware of any thermoelectric products that go beyond a hand-full of watts capability. That technology goes back a very long way. Here's a small step back in time to when thermoelectric power generation became commercially practical technology: http://tinyurl.com/2gshpm and a modern incarnation: http://tinyurl.com/ytv3th >Its a little frustrating here in New Zealand there is a manufacturer of >stirling engine power generators for boats and homes - called "whispergen" >- however they ony seem to supply to certain markets and that doesnt >include locally. If your interested in the Stirling engine development programs, suggest you visit http://www.stirlingengine.com/ That company started here in Wichita by a good friend of mine. I have a couple of the earliest "Coffee Cup Engines". In particular, check out Brent's book offerings at: http://www.stirlingengine.com/ecommerce/category-browse.tcl?category_id=2 and the links cited at: http://www.stirlingengine.com/general-links/ The cable system dog-house is branded "Alpha" which suggests it's the product of The Alpha Group. I wasn't able to find the model of device sitting on my street but here's on example of many products described on their website http://www.alpha.com/us/default.aspx?id=catalog&catId=/477/3482/3357/ The next time our cable guy is in the neighborhood, I'll ask him what he knows about our particular version. Bob . . . ________________________________________________________________________________
Date: Aug 30, 2007
Subject: Icom A-200 dimming
I've read through the archives, but can't find a "Yes/No" answer to this question, though I think I've come close. I'm choosing to light my panel and cabin with LEDs that all pass through a pulse-width modulator for dimming. I'd like to hook the Icom's display into the same circuit, but a posting to this list on 2/13/06 indicates that only the positive side of the lighting circuit is exposed to through the connector. My first question is, "Is this correct? There's no easy access to the lighting circuit's ground lead?" (I could put the PWM at the head end of the circuit, but I have some lighted switches that aren't amenable to this.) The second question, "Is a dimmer necessary?" My Icom will be situated on a side panel, situated about 75 degrees from front-center (a delta configuration has it's benefits). Is the light level low enough to not be a bother? -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown ________________________________________________________________________________
Date: Aug 30, 2007
Subject: Re: Icom A-200 dimming
My A-200 has incandescent bulbs with no easy access to the ground as I recall. Think the draw was on order of 60 or 90 ma. I have a two position switch to dim them through a resistor but suspect a dimmer is not really required. Ken Ernest Christley wrote: > > > I've read through the archives, but can't find a "Yes/No" answer to > this question, though I think I've come close. > > I'm choosing to light my panel and cabin with LEDs that all pass > through a pulse-width modulator for dimming. I'd like to hook the > Icom's display into the same circuit, but a posting to this list on > 2/13/06 indicates that only the positive side of the lighting circuit > is exposed to through the connector. > > My first question is, "Is this correct? There's no easy access to the > lighting circuit's ground lead?" > (I could put the PWM at the head end of the circuit, but I have some > lighted switches that aren't amenable to this.) > > The second question, "Is a dimmer necessary?" My Icom will be > situated on a side panel, situated about 75 degrees from front-center > (a delta configuration has it's benefits). Is the light level low > enough to not be a bother? > > ________________________________________________________________________________
Date: Aug 30, 2007
From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
Subject: Re: Bob's Audio mixer board.
> >Bob K, > >I recall you had an Audio mixer board at one time and I would like to >somehow get hold of one. > >IIRC it was attached to a 25Pin PCB mount D-Sub connector, with 3-4 inputs >and a single output. > >This would be perfect for me since I plan to mix together the audio from >an alternate radio plus the audio from an anunciating EFIS system and feed >these to my intercom. > >For PTT and MIC I plan to fit a 2 pole 2 position switch to select between >Radio1 and Radio2. > >Even if I could acquire the CCT and bare PCB that would be a great help. The board is still available at: https://matronics.com/aeroelectric/Catalog/AECcatalog.html The assembly manual and BOM is at: http://www.aeroelectric.com/Catalog/AEC/9009/9009-700J.pdf I'm told that a number of the parts cited from the Digikey catalog have been replaced . . . you'll have to do a bit of substituting. I have a list of the changes somewhere, I'll try to find it an publish it on the List. I don't know when I'll get to updating the BOM . . . Bob . . . ________________________________________________________________________________
Date: Aug 30, 2007
Toni, Thanks for sharing the link, must confess I already had seen that one and do similar things with turbines in my spare time... http://aardvark.co.nz/pjet/turbinenuts.shtml http://youtube.com/watch?v=7bfHozA4kpM Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=131969#131969 ________________________________________________________________________________
Date: Aug 31, 2007
Ernest from the installation manual: Pin "B" is +14v for light Pin "1" is GROUND for pin "B" This may what you want. Do some bench test. It sounds like a discrete ground for the light! Dimming is nice but you don't know until you fly at night with it. I fly a bubble canopy (RV) and it can reflect light. Sounds like you PWM will work off the ligt ground on PIN 1. Good Luck George >From: Ernest Christley <echristley(at)nc.rr.com> >Subject: AeroElectric-List: Icom A-200 dimming > >posting to this list on 2/13/06 indicates that only the positive >side of the lighting circuit is exposed to through the connector. > >My first question is, "Is this correct? > >There's no easy access to the lighting circuit's ground lead?" > >The second question, "Is a dimmer necessary?" --------------------------------- Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more. ________________________________________________________________________________
Date: Aug 31, 2007
Subject: Re: How to check and alternator??
>Thanks for messages. > >Here's the answer to your questions. > >I have a Chief Aircraft +/- 40 ammeter with a 40amp shunt. > >I think my alternator is 35 amps but can't remember - I'll have to look >that up. I am running Nav lights, strobe lights, wig wag lights, and a >full Garmin stack so I'm thinking I may need to upgrade my >alternator. Will have to add that up before first flight to see the load. > >The ammeter has a positive and negative terminal on the back. The >positive is connected to to the small screw on the shunt which also has a >large screw on the same side which is wired directly to the main power bus >which also splits to a wire between the master and starter relay. The >negative side on the back of the ammeter is connected to the opposite >small screw on the shunt which also has a large screw which is wired >through a 60amp circuit breaker to the main power bus. > >Kinda hard to explain without a picture. I followed the Bingeles book >when I wired it up a few years back so maybe I messed something up. > >I do know that the volt meter reads barely under 14 volts with the engine >running. > >Thanks for the help!!!! The -zero+ reading ammeter is a BATTERY ammeter. When things are running normally (alternator carrying ship's loads and battery fully charged) then it SHOULD read at or near zero. Turn some things on with the engine not running. Let them run of the battery for 10 minutes or so. The ammeter should be showing a (-) value - energy is coming out of the battery. Take a voltmeter reading. Now, start the engine and turn the alternator on. Note the bus voltage. We would LIKE to see 14.2 to 14.6 volts but 13.8 or 13.9 would still charge the battery. After the alternator comes on, if you see a rise in bus voltage, then the alternator IS working to some degree. Its set point may be too low . . . but it is working. Now the ammeter should show a decided (+) reading - energy is being stuffed back into the battery. Turn all the accessories off and observe the ammeter which should begin to move back toward zero indicating that the battery is topped off. For the moment, nothing you've written suggests that the system is seriously malfunctioning. It may need adjustment of voltage. Bob . . . ________________________________________________________________________________
Subject: No charge
Date: Aug 31, 2007
I'm having charging problems again. Using the Z16 diagram with Rotax 912 ULS. I had a charging problem before and found my "C" wire connector from the Voltage Regulator was not properly seated. When I made good connection I got a charge. Today there's no charge again, according to the Dynon & GRT voltmeters. I believe I have a good connection to the regulator but not sure how to test. Suggestions? Other possible problems to consider? Thanks Frank McDonald ________________________________________________________________________________
Date: Aug 31, 2007
Subject: Re: No charge
frank.phyllis(at)mindspring.com a crit : > Using the Z16 diagram with Rotax 912 ULS. > I had a charging problem before and found my "C" wire connector from the > Voltage Regulator was not properly seated. When I made good connection > I got a charge. > Today there's no charge again, according to the Dynon & GRT voltmeters. > I believe I have a good connection to the regulator but not sure how to > test. > Franck, Have you checked the regulator ground wire ? It should be the same size as the positive wire, since it will carry the 18-20 A current. Best regards, -- Gilles, Z16 with dual battery http://contrails.free.fr ________________________________________________________________________________
Date: Aug 31, 2007
Subject: Thermoelectric Generators
I don't know how many your "hand-full of watts" are but here is a source of thermoelectric generators in the 2.5 to 19 watt range. Certainly wouldn't run an all electric airplane, but might keep your radios running. They also offer a DC-DC converter to provide a regulated 12V output. Dick Tasker Robert L. Nuckolls, III wrote: > > > I'm not aware of any thermoelectric products that go beyond > a hand-full of watts capability. That technology goes back a > very long way. Here's a small step back in time to when thermoelectric > power generation became commercially practical technology: ________________________________________________________________________________
Date: Aug 31, 2007
Subject: spade lug failure.
I have been wiring my plane using some high quality (well, at least they're expensive - $0.65 each) T&B insulated fast-on type connectors and an Ideal crimping tool (not expensive as crimpers go - about $50). A couple days ago I found a #22 ground wire that simply didn't conduct. I removed it from the plane and sliced away insulation near each end to expose the wire just before the connectors and determined which one wasn't conducting. It looked fine. The wires were just visible sticking out of the spade lug end and I could touch them directly with my continuity tester, but they weren't connected to the rest of the wire. Using a dremel tool, I removed the plastic covering and part of the crimp. A little bit of the insulation extended into the part of the barrel that crimps the copper wire. Apparently what happened was that the act of crimping it cut thru the wire, but NOT thru the insulation. The connector was held on by the insulation. That tefzel is pretty tough stuff. I made a new wire and got things working, but I have to wonder if more of my wires aren't in the same or nearly the same condition. Am I doing something wrong here or was this probably just a 1 in a 1000 fluke? Do I need to check the connections that seem to be working? If so, how? -- Tom Sargent, RV-6A Electrical system ________________________________________________________________________________
Date: Aug 31, 2007
Subject: Lightspeed spark plug wires
I am not mounting my ignition coils on top of my engine, so the spark plug wires I got with the Lightspeed unit aren't the right lengths. Are these ordinary automotive sparkplug wires or something special? How does one get wires of non-standard lengths? I emailed Klaus but have not received an answer. Thanks, ---- Tom Sargent, RV-6A ________________________________________________________________________________
Subject: Re: Lightspeed spark plug wires
Date: Sep 01, 2007
Tom, I had an identical situation. I returned the supplied wires along with my specs for the replacements. Klaus fabricated the new wires at no charge. Dick Jordan RV 8A N888BZ -------------- Original message -------------- From: sarg314 <sarg314(at)comcast.net> > > I am not mounting my ignition coils on top of my engine, so the spark > plug wires I got with the Lightspeed unit aren't the right lengths. Are > these ordinary automotive sparkplug wires or something special? How > does one get wires of non-standard lengths? I emailed Klaus but have > not received an answer. > > Thanks, > ---- > Tom Sargent, RV-6A > > > > >
Tom,
Dick Jordan
RV 8A
N888BZ
arch &
Date: Sep 01, 2007
Subject: Lead-free soldering?
Since going green is all the rage these days, what is the latest on going lead-free when soldering aircraft wiring? Any actual data on advantages/disadvantages of going to Sn97 Ag2.5 Cu.5 solder instead of our traditional Pb63 Sn37 solder? What's the bottom line? Paul Siegel ________________________________________________________________________________
Date: Sep 01, 2007
The bottom line is you'll do more for the enviroment by not driving down to radioshack in your SUV to pick up the silver solder then switching to leadless solder (particularly so if you through the spool of lead solder in the garbage. However, if it makes you feel good, and others confirm that its technically equivalent, then by all means. :-) Chuck -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of psiegel(at)fuse.net Sent: Saturday, September 01, 2007 5:21 AM Subject: AeroElectric-List: Lead-free soldering? Since going green is all the rage these days, what is the latest on going lead-free when soldering aircraft wiring? Any actual data on advantages/disadvantages of going to Sn97 Ag2.5 Cu.5 solder instead of our traditional Pb63 Sn37 solder? What's the bottom line? Paul Siegel ________________________________________________________________________________
Date: Sep 01, 2007
Subject: Re: Lead-free soldering?
Hams have used solder for years. The only disease that spikes some in hams is lymphoma; but is that from the lead? or the resin? or the RF we sit in in our radio shacks? Who knows. I wouldn't chew on a piece of solder as you are working for sure. Probably not a good idea to enjoy inhaling the smell of solder, but there are probably a bigger dose of carcinogens in the "new car smell" you get in your new car as plastics off gas formaldehyde and all sorts of other nasty aldehydes and orgai=nic materials. Every time I fly my Glastar I smell the plastic smell a lot sitting in the fiberglass fuselage. I still fly! and don't worry about it. I wouldn't let your grandbabies play with the solder, but we buy toys made in China all the time! painted with lead we are finding out. bobf W5RF On 9/1/07, psiegel(at)fuse.net wrote: > > > Since going green is all the rage these days, what is the latest on going > lead-free when soldering aircraft wiring? > > Any actual data on advantages/disadvantages of going to Sn97 Ag2.5 Cu.5solder instead of our traditional Pb63 Sn37 solder? > > What's the bottom line? > > Paul Siegel > > ________________________________________________________________________________
From: "S. Ramirez" <simon(at)synchronousdesign.com>
Date: Sep 01, 2007
Paul, The rage to use less lead came from the European Union in a directive called "the restriction of the use of certain hazardous substances in electrical and electronic equipment, commonly called RoHS (Restriction of Hazardous Substances). Article 4 Prevention, Paragraph 1 says "...new electrical and electronic equipment put on the market does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE)." Since the European Union is a large market and also has many electrical and electronic vendors, RoHS affects the USA and other countries. RoHS has caused a lot of problems here, mostly because they do not mix well with leaded parts on electronic circuit boards. The temperatures and oven profiles to make populated boards are different, and mixing of the two types of components causes some solder joints to be deficient and out of spec, thus decreasing reliability and causing anomalies that require further troubleshooting and possible redesign. The end result of all this is to go either all leaded parts or all RoHS parts on boards, which was hard to do earlier but getting easier. Manufacturers in the USA and other non-European countries have been forced to adopt the RoHS directive even when they're manufacturing and selling only in the USA, because non-RoHS parts are getting harder to come by. There are exceptions to RoHS, like military equipment, but even the military is hard-pressed to go with leaded parts. Many simply don't exist anymore. As such, defense contractors have qualified lead-free finishes and soldering and are making military equipment with no lead. There has been a learning curve, and even when everyone thinks they have everything under control, something always comes back to bite them. Nonetheless, defense contractors make equipment with lead free components and solder, and there is no reason to suspect that lead-free solder is unreliable or less reliable if the operation is done properly. There are many resources that can be found on the internet to help you do this. One that comes to mind is by Dynamix Technology at the following link: http://www.dynamixtechnology.com/pbwillis.htm There you can find their offering of an interactive CD-ROM about Soldertec hand soldering and de-soldering lead-free. If anyone needs the actual EU Directive on RoHS, I will be more than glad to send them a PDF. Simon Ramirez, Aerocanard Builder LEZ N-44LZ Oviedo, FL 32765 USA Copyright C 2007 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of psiegel(at)fuse.net Sent: Saturday, September 01, 2007 5:21 AM Subject: AeroElectric-List: Lead-free soldering? Since going green is all the rage these days, what is the latest on going lead-free when soldering aircraft wiring? Any actual data on advantages/disadvantages of going to Sn97 Ag2.5 Cu.5 solder instead of our traditional Pb63 Sn37 solder? What's the bottom line? Paul Siegel ________________________________________________________________________________
Date: Sep 01, 2007
Simon - thanks for the great post. John Cox RV-10 builder -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of S. Ramirez Sent: Saturday, September 01, 2007 7:59 AM Subject: RE: AeroElectric-List: Lead-free soldering? Paul, The rage to use less lead came from the European Union in a directive called "the restriction of the use of certain hazardous substances in electrical and electronic equipment, commonly called RoHS (Restriction of Hazardous Substances). Article 4 Prevention, Paragraph 1 says "...new electrical and electronic equipment put on the market does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE)." Since the European Union is a large market and also has many electrical and electronic vendors, RoHS affects the USA and other countries. RoHS has caused a lot of problems here, mostly because they do not mix well with leaded parts on electronic circuit boards. The temperatures and oven profiles to make populated boards are different, and mixing of the two types of components causes some solder joints to be deficient and out of spec, thus decreasing reliability and causing anomalies that require further troubleshooting and possible redesign. The end result of all this is to go either all leaded parts or all RoHS parts on boards, which was hard to do earlier but getting easier. Manufacturers in the USA and other non-European countries have been forced to adopt the RoHS directive even when they're manufacturing and selling only in the USA, because non-RoHS parts are getting harder to come by. There are exceptions to RoHS, like military equipment, but even the military is hard-pressed to go with leaded parts. Many simply don't exist anymore. As such, defense contractors have qualified lead-free finishes and soldering and are making military equipment with no lead. There has been a learning curve, and even when everyone thinks they have everything under control, something always comes back to bite them. Nonetheless, defense contractors make equipment with lead free components and solder, and there is no reason to suspect that lead-free solder is unreliable or less reliable if the operation is done properly. There are many resources that can be found on the internet to help you do this. One that comes to mind is by Dynamix Technology at the following link: http://www.dynamixtechnology.com/pbwillis.htm There you can find their offering of an interactive CD-ROM about Soldertec hand soldering and de-soldering lead-free. If anyone needs the actual EU Directive on RoHS, I will be more than glad to send them a PDF. Simon Ramirez, Aerocanard Builder LEZ N-44LZ Oviedo, FL 32765 USA Copyright C 2007 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of psiegel(at)fuse.net Sent: Saturday, September 01, 2007 5:21 AM Subject: AeroElectric-List: Lead-free soldering? Since going green is all the rage these days, what is the latest on going lead-free when soldering aircraft wiring? Any actual data on advantages/disadvantages of going to Sn97 Ag2.5 Cu.5 solder instead of our traditional Pb63 Sn37 solder? What's the bottom line? Paul Siegel ________________________________________________________________________________
Date: Sep 01, 2007
Tom, Call Klaus directly, he has always been happy to answer questions for me directly. I think they are high end auto wires, but ask Klaus. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of sarg314 Sent: Friday, August 31, 2007 6:02 PM Subject: AeroElectric-List: Lightspeed spark plug wires I am not mounting my ignition coils on top of my engine, so the spark plug wires I got with the Lightspeed unit aren't the right lengths. Are these ordinary automotive sparkplug wires or something special? How does one get wires of non-standard lengths? I emailed Klaus but have not received an answer. Thanks, ---- Tom Sargent, RV-6A 7/29/2007 11:14 PM 7/29/2007 11:14 PM ________________________________________________________________________________
Date: Sep 01, 2007
Subject: OT - KN-75 remote GS receiver
After a panel upgrade, I have available a King KN-75 Glideslope Receiver (used to drive a KI-209 VOR/LOC/Glideslope Indicator via King KX-170B NAV/COMM). If anyone is interested, please contact me directly Rumen rd2(at)evenlink.com ________________________________________________________________________________
Date: Sep 01, 2007
Go here http://www.magnecor.com/ , for the best ignition wires that can be had . John D. ________________________________________________________________________________
Subject: Re: Thermoelectric Generators
Date: Sep 02, 2007
Dick,, i dont see the link? -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=132318#132318 ________________________________________________________________________________
Subject: Re: GNS430W Installation Manual Rev status?
Date: Sep 02, 2007
Revision B is the latest I have. Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy ________________________________________________________________________________
Date: Sep 02, 2007
Hi Bob !! Thanks for the help and suggestions !! I really appreciate you and all I learn from you. So, I did exactly as you said, and you are 100% correct. I left on a bunch of stuff for about 10 minutes, then started the plane and immediately noticed the ammeter was slightly on the negative side, maybe reading about 4 negative amps. The voltage read just under 15 volts - say 14.7 the whole time and stays there but within about 3 minutes, the ammeter came back up to zero and stayed there. I wired the ammeter and external shunt as per Van's Aircraft instructions and my brother Danny (which you've all heard from many times) says there are 2 other ways (according to Dynon) to wire the ammeter which I might do. I'm not sure of the best or correct way to wire the ammeter but at least now I know my alternator is working perfectly and THAT makes me happy. Maybe I should leave it alone since I now know exactly what it's reading. Thanks for your input and suggestions. Matt "Robert L. Nuckolls, III" wrote: >Thanks for messages. > >Here's the answer to your questions. > >I have a Chief Aircraft +/- 40 ammeter with a 40amp shunt. > >I think my alternator is 35 amps but can't remember - I'll have to look >that up. I am running Nav lights, strobe lights, wig wag lights, and a >full Garmin stack so I'm thinking I may need to upgrade my >alternator. Will have to add that up before first flight to see the load. > >The ammeter has a positive and negative terminal on the back. The >positive is connected to to the small screw on the shunt which also has a >large screw on the same side which is wired directly to the main power bus >which also splits to a wire between the master and starter relay. The >negative side on the back of the ammeter is connected to the opposite >small screw on the shunt which also has a large screw which is wired >through a 60amp circuit breaker to the main power bus. > >Kinda hard to explain without a picture. I followed the Bingeles book >when I wired it up a few years back so maybe I messed something up. > >I do know that the volt meter reads barely under 14 volts with the engine >running. > >Thanks for the help!!!! The -zero+ reading ammeter is a BATTERY ammeter. When things are running normally (alternator carrying ship's loads and battery fully charged) then it SHOULD read at or near zero. Turn some things on with the engine not running. Let them run of the battery for 10 minutes or so. The ammeter should be showing a (-) value - energy is coming out of the battery. Take a voltmeter reading.
August 15, 2007 - September 02, 2007
AeroElectric-Archive.digest.vol-hd
