AeroElectric-Archive.digest.vol-ho
January 12, 2008 - January 29, 2008
      police don't have to go into SAR mode for a wife that
      did not come home after work. I guess that is a sales
      pitch for ON-Star. FLY SAFE.
        Other wise flight following AND file detailed flight planes & fly them.
        George RV-7 finishing
      Never miss a thing.   Make Yahoo your homepage.
Date: Jan 12, 2008
Subject: Re: Automatic fuel pump backup switch
Robert L. Nuckolls, III wrote: > The Eggenfellner Subaru conversion recommends > the arrangement I believe you're looking for. > Their recommended installation calls for a > pair of pumps, either of which can run the engine > through appropriate plumbing parts . . . > > On the electrical side, he suggests a #1, #2, Auto > switch for pump selection. #1 and #2 are self > explanatory. One or the other but not both. The Auto > position powers the #1 pump through relaxed contacts > of a relay that is energized by the closing of a low > pressure switch. Once the relay is energized, contacts > transition to remove power from #1 and apply power to > #2 pump. At the same time, the relay is electrically > latched so that it will not de-energize without some > externally applied conditions (pilot actions, loss of > electrical power) that cause the relay to relax. > > I'll be incorporating this feature into an Eggenfellner > version of Z-19 but before that drawing comes out, I'll > refer you to their webite publications at: > > http://eggenfellneraircraft.com/ESeriesInstallationGuide.pdf > > Bob . . . Hi Bob, I'm confused. I'm pretty sure I remember from the Eggenfellner mailing list that they currently recommend both pumps on for takeoff and landing, and to turn off one for cruise. On page 51 of the PDF you reference, I don't see any of the relays or low pressure switches that you refer to. In the "green" area of the schematic, there are just two switches, one for each fuel pump, each inline with a 10A circuit breaker, that are both attached to pin #8 of the "Bus Master Switch". In the past Eggenfellner had pressure switches in their installations, but no longer recommends them due to reliability issues with the pressure switch and the added complexity of the setup. -Dj -- Dj Merrill Sportsman 2+2 Builder #7118 http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 12, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Apppendix Z, Rev M
I've just posted an update to Appendix Z at: http://aeroelectric.com/articles/Rev11/AppZ_R11M.pdf It adds two pages to figure Z-15, grounding architectures that go into some OK/NOT-OKAY examples for grounding various equipment items in the airplane. The additional coverage goes to the goals of (1) avoiding the grounding of potential victim systems (avionics, instruments) in more than one place on an airframe that is carrying (2) significant alternator and other systems noises injected by local grounds for those antagonists. It also goes to the notion of a linear system of multiple ground points. I.e, engine (G1), forward side of firewall (G2), aft side of firewall (G3) and panel (G5) as a suite of 'single-point' grounds while accommodating a few local grounds (G4) for potential antagonists where they do not share ground returns (loops) with potential victims. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 12, 2008
Subject: Re: Fw: Europa XS with ULPower 260i engine
> >I have received the following reply from the ULPower representatvie to my >question, "Why do I not need to include crowbar OV protection with this >engine?" > > >Our electronics guy sent me a diagram showing the principle of how our >type of regulator works. He says (in Dutch below) that: > >---------- >our type is a "shunt" regulator which shorts the PMG to ground when the >battery voltage increases above the nominal level so that the battery can >never be over charged and damaged. >The principle of a PMG is different to a Regulated Field Generator >(typical in cars) where the magnetic field is regulated to vary the >voltage of the generator. >A PMG acts as a constant current source and therefore may be shorted out. > >---------- >The regulator / rectifier we use is typically used on large capacity >motorbikes and our supplier says they are very robust. > >He also sent the attached schematic: > >So as I see it, the attached schematic for my airplane should be sufficient. > >Vaughn Teegarden What you've proposed will be fine. The regulator topology you cited is a carry through of the earliest PM alternator regulators. It throttles or controls alternator output to the system by putting a dead short on the alternator's stator windings during short periods where unrestrained output would boost the system voltage too much. This is a very simple approach that has been effective since day-one . . . but does have the down-side of causing the alternator to run at max output current 100% of the time whether that energy is used by the electrical system or not. Of course, if wire size and cooling considerations for the alternator are carefully addressed, this can produce a robust, reliable system. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: ELT/PLB
Date: Jan 12, 2008
All, One function of a PLB that seems to have been forgotten is the tracking mode (see http://www.findmespot.com/). Assuming you go down and the PLB is destroyed, your next of kin have a very good idea of your whereabouts - much better idea than an ELT provides. Frankly, if I crash and die, I could care less if someone finds me (I know my family does not feel that way). What I desire out of my PLB is the ability to tell someone exactly where I am if I have a problem and survive. Ya - all kinds of scenario's can be debated but if you MUST have a completely fail safe solution - don't expect to get it from a $150 device. Jon Finley N314JF - Q2 - Subaru EJ-22 Legacy http://www.finleyweb.net Mid-Valley Airpark (E98), Los Lunas, NM ________________________________________________________________________________
Subject: RE: RV-List: Cheaper 406mhz plb alternative?
Date: Jan 12, 2008
I attended a presentation on this device a few days ago. - It absolutely does not replace any kind of ELT on aircraft. You must still have an ELT, either 121.5 or 406 MHz. - It is a private satellite service. You don't pay the annual fee, it doesn't work for you. It seems to be an initially cheaper alternative to portable PLBs, but they then charge annual fees to make up the cheaper purchase price. Seems really designed for outdoors hikers, backpackers, sportsmen, etc. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Wednesday, January 09, 2008 7:18 PM Subject: RV-List: Cheaper 406mhz plb alternative? --> RV-List message posted by: Charlie England Anyone know any details about this product? http://www.findmespot.com/explorespot/spotmessenger.aspx IF it's using the public SARSAT satellites, maybe it would still work after the 1st mandatory subscription lapses. (Still be a lot cheaper than typical PLBs with built in GPS.) Charlie ________________________________________________________________________________
Date: Jan 13, 2008
Hi All, There are some poor man's versions of tracking for mobile phones that might do some of the functions outlined here. Have a look at http://www.codeproject.com/KB/mobile/FindMe.aspx It's a program that gets your GPS equipped Mobile phone to report its location in response to a SMS call. I would still have the PLB but if the family want to find you then this may be a cheap alternative using stuff you may already have. Cheers John -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Ralph Finch Sent: Sunday, 13 January 2008 8:09 AM Subject: RE: RV-List: Cheaper 406mhz plb alternative? --> RV-List message posted by: "Ralph Finch" I attended a presentation on this device a few days ago. - It absolutely does not replace any kind of ELT on aircraft. You must still have an ELT, either 121.5 or 406 MHz. - It is a private satellite service. You don't pay the annual fee, it doesn't work for you. It seems to be an initially cheaper alternative to portable PLBs, but they then charge annual fees to make up the cheaper purchase price. Seems really designed for outdoors hikers, backpackers, sportsmen, etc. -----Original Message----- From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England Sent: Wednesday, January 09, 2008 7:18 PM Subject: RV-List: Cheaper 406mhz plb alternative? --> RV-List message posted by: Charlie England Anyone know any details about this product? http://www.findmespot.com/explorespot/spotmessenger.aspx IF it's using the public SARSAT satellites, maybe it would still work after the 1st mandatory subscription lapses. (Still be a lot cheaper than typical PLBs with built in GPS.) Charlie ________________________________________________________________________________
Date: Jan 12, 2008
Thanks Bob, I am going down to LSA show in Sebring, Florida to see the guys who make the engine. I hope it works out well for me. Vaughn Teegarden ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> Sent: Saturday, January 12, 2008 2:33 PM Subject: Re: AeroElectric-List: Fw: Europa XS with ULPower 260i engine > > > >> >>I have received the following reply from the ULPower representatvie to my >>question, "Why do I not need to include crowbar OV protection with this >>engine?" >> >> >>Our electronics guy sent me a diagram showing the principle of how our >>type of regulator works. He says (in Dutch below) that: >> >>---------- >>our type is a "shunt" regulator which shorts the PMG to ground when the >>battery voltage increases above the nominal level so that the battery can >>never be over charged and damaged. >>The principle of a PMG is different to a Regulated Field Generator >>(typical in cars) where the magnetic field is regulated to vary the >>voltage of the generator. >>A PMG acts as a constant current source and therefore may be shorted out. >> >>---------- >>The regulator / rectifier we use is typically used on large capacity >>motorbikes and our supplier says they are very robust. >> >>He also sent the attached schematic: >> >>So as I see it, the attached schematic for my airplane should be >>sufficient. >> >>Vaughn Teegarden > > What you've proposed will be fine. The regulator > topology you cited is a carry through of the > earliest PM alternator regulators. It throttles > or controls alternator output to the system by > putting a dead short on the alternator's stator > windings during short periods where unrestrained > output would boost the system voltage too much. > > This is a very simple approach that has been > effective since day-one . . . but does have the > down-side of causing the alternator to run at > max output current 100% of the time whether that > energy is used by the electrical system or not. > Of course, if wire size and cooling considerations > for the alternator are carefully addressed, this > can produce a robust, reliable system. > > Bob . . . > > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > ________________________________________________________________________________
Date: Jan 12, 2008
The way I handled this was on my 601 HD with A Stratus Suburu was to put both electric pumps is series. This will cause an addition of pressures so after the pumps I put a fuel pressure regulator adjusted to 5 psi. in this way I can run both pumps for takeoff and landing, or any other time I like and not exceed the limits of the carb. By the way one of the Fauset pumps required a by pass check valve so that either pump could operate independently. I looked into various automatic systems such as sensing the pressure and modulating one of the pumps but this was far simpler and so far with my 65 hours has been trouble free. Tim Shankland mtmeans wrote: > >I have an auto conversion project with dual high pressure fuel pumps. The fuel pumps are plumbed in parallel with one way valves and are not happy when running together (stronger pump blocks flow of weaker), ie harmful to switch secondary on during critical flight. Reflexes being what they are during these times I am considering a fuel pressure (or other switch) that could turn on the second pump if first fails. Any suggestions. I tried to search for this exact issue and had problems. Thanks. > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=157617#157617 > > > > ________________________________________________________________________________
Date: Jan 12, 2008
Subject: Re: Europa XS with ULPower 260i engine (OOPS!!!)
I just realized that I didn't answer "the question" about justification for OV protection. ALL engine driven power sources fitted with regulators have the ability to produce output voltages well in excess of the system design voltages. RISKS from failure of the regulator are mitigated by (1) the alternator's limited ability to deliver energy (current limit), (2) te alternators open-circuit, runaway limits for voltage and (3) the battery's ability to soak-up what the alternator dishes out for an interval of time sufficient for OV protection to take notice and shut the system down. In the case of an SD-8 driving a 18 a.h. battery, a simple OV warning light might suffice presuming that the owner operator is willing to place him/herself in the OV protection loop. Most designers op for some form of automatic device as do all folks who design systems for certified aircraft. Indeed, all of my z-figures for power generation feature some form of automatic OV protection combined with immediate notification of LOW VOLTAGE that follows. I was concentrating on the operating characteristics of your particular alternator/regulator combination and overlooked the fact that your original question asked about the value of adding OV protection. There are NO votlage regualtors for which probability of runaway failure is ZERO. Some are very good, some are not. Without doing the MTBF/FMEA analysis on every design to be considered, the prudent thing to do is simply include OV protection on every system. This is a 3-phase machine which I presume is more robust than the 18A alternator on a Rotax. It's probably capable of boosting bus votlage to over 16 volts immediately followed by a steady rise to over 18 volts in a matter of minutes. It would not be my personal choice to hope that I would notice and react to a regulator failure for the purpose of mitigating damage to the rest of the system . . . I would recommend inclusion of OV protection. To do this on the AC side of a 3-phase system would require a two-pole relay so perhaps the best approach is leaving the relay on the DC side so it can be a single-pole device. See figure Z-20. Bob . . . > > >Thanks Bob, > >I am going down to LSA show in Sebring, Florida to see the guys who make >the engine. I hope it works out well for me. > >Vaughn Teegarden > >----- Original Message ----- From: "Robert L. Nuckolls, III" > >To: >Sent: Saturday, January 12, 2008 2:33 PM >Subject: Re: AeroElectric-List: Fw: Europa XS with ULPower 260i engine > > >> >> >> >>> >>>I have received the following reply from the ULPower representatvie to >>>my question, "Why do I not need to include crowbar OV protection with >>>this engine?" >>> >>> >>>Our electronics guy sent me a diagram showing the principle of how our >>>type of regulator works. He says (in Dutch below) that: >>> >>>---------- >>>our type is a "shunt" regulator which shorts the PMG to ground when the >>>battery voltage increases above the nominal level so that the battery >>>can never be over charged and damaged. >>>The principle of a PMG is different to a Regulated Field Generator >>>(typical in cars) where the magnetic field is regulated to vary the >>>voltage of the generator. >>>A PMG acts as a constant current source and therefore may be shorted out. >>> >>>---------- >>>The regulator / rectifier we use is typically used on large capacity >>>motorbikes and our supplier says they are very robust. >>> >>>He also sent the attached schematic: >>> >>>So as I see it, the attached schematic for my airplane should be sufficient. >>> >>>Vaughn Teegarden >> >> What you've proposed will be fine. The regulator >> topology you cited is a carry through of the >> earliest PM alternator regulators. It throttles >> or controls alternator output to the system by >> putting a dead short on the alternator's stator >> windings during short periods where unrestrained >> output would boost the system voltage too much. >> >> This is a very simple approach that has been >> effective since day-one . . . but does have the >> down-side of causing the alternator to run at >> max output current 100% of the time whether that >> energy is used by the electrical system or not. >> Of course, if wire size and cooling considerations >> for the alternator are carefully addressed, this >> can produce a robust, reliable system. >> >> Bob . . . >> >> >> ----------------------------------------) >> ( . . . a long habit of not thinking ) >> ( a thing wrong, gives it a superficial ) >> ( appearance of being right . . . ) >> ( ) >> ( -Thomas Paine 1776- ) >> ---------------------------------------- >> >> >> >> >> > > >-- >269.19.1/1220 - Release Date: 1/11/2008 6:09 PM > > >incoming mail is certified Virus Free. >Checked by AVG. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 13, 2008
Subject: Toggle switch tool
i use masking tape to protect the panel. 1 horizontal strip of tape above, 1 horizontal strip below and as many vertical strips as necessary between the switches / circuit breakers. --------------------------------- ________________________________________________________________________________
Date: Jan 13, 2008
As another has pointed out, Eggenfellner Aircraft no longer recommends an auto-switching scheme for the dual pump configuration. Regards, Mark Sletten ________________________________________________________________________________
Date: Jan 13, 2008
So if I included OV protection as shown in attached, I can feel good about protecting my electronics. I noticed that in Z-20, you did not have a 5amp alt field breaker. I have it in mine. Is it required? Vaughn ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> Sent: Saturday, January 12, 2008 8:48 PM Subject: AeroElectric-List: Re: Europa XS with ULPower 260i engine (OOPS!!!) > > > I just realized that I didn't answer "the question" about justification > for OV protection. ALL engine driven power sources fitted with regulators > have the ability to produce output voltages well in excess of the > system design voltages. RISKS from failure of the regulator are mitigated > by (1) the alternator's limited ability to deliver energy (current limit), > (2) te alternators open-circuit, runaway limits for voltage and (3) the > battery's ability to soak-up what the alternator dishes out for an > interval > of time sufficient for OV protection to take notice and shut the system > down. > > In the case of an SD-8 driving a 18 a.h. battery, a simple OV warning > light > might suffice presuming that the owner operator is willing to place > him/herself > in the OV protection loop. > > Most designers op for some form of automatic device as do all folks who > design > systems for certified aircraft. Indeed, all of my z-figures for power > generation > feature some form of automatic OV protection combined with immediate > notification > of LOW VOLTAGE that follows. > > I was concentrating on the operating characteristics of your particular > alternator/regulator combination and overlooked the fact that your > original > question asked about the value of adding OV protection. There are NO > votlage regualtors for which probability of runaway failure is ZERO. Some > are > very good, some are not. Without doing the MTBF/FMEA analysis on every > design to be considered, the prudent thing to do is simply include OV > protection > on every system. > > This is a 3-phase machine which I presume is more robust than the 18A > alternator on a Rotax. It's probably capable of boosting bus votlage > to over 16 volts immediately followed by a steady rise to over 18 volts > in a matter of minutes. It would not be my personal choice to hope that > I would notice and react to a regulator failure for the purpose of > mitigating damage to the rest of the system . . . I would recommend > inclusion of OV protection. > > To do this on the AC side of a 3-phase system would require a two-pole > relay so perhaps the best approach is leaving the relay on the DC side > so it can be a single-pole device. See figure Z-20. > > Bob . . . > > > >> >> >>Thanks Bob, >> >>I am going down to LSA show in Sebring, Florida to see the guys who make >>the engine. I hope it works out well for me. >> >>Vaughn Teegarden >> >>----- Original Message ----- From: "Robert L. Nuckolls, III" >> >>To: >>Sent: Saturday, January 12, 2008 2:33 PM >>Subject: Re: AeroElectric-List: Fw: Europa XS with ULPower 260i engine >> >> >>> >>> >>> >>>> >>>>I have received the following reply from the ULPower representatvie to >>>>my question, "Why do I not need to include crowbar OV protection with >>>>this engine?" >>>> >>>> >>>>Our electronics guy sent me a diagram showing the principle of how our >>>>type of regulator works. He says (in Dutch below) that: >>>> >>>>---------- >>>>our type is a "shunt" regulator which shorts the PMG to ground when the >>>>battery voltage increases above the nominal level so that the battery >>>>can never be over charged and damaged. >>>>The principle of a PMG is different to a Regulated Field Generator >>>>(typical in cars) where the magnetic field is regulated to vary the >>>>voltage of the generator. >>>>A PMG acts as a constant current source and therefore may be shorted >>>>out. >>>> >>>>---------- >>>>The regulator / rectifier we use is typically used on large capacity >>>>motorbikes and our supplier says they are very robust. >>>> >>>>He also sent the attached schematic: >>>> >>>>So as I see it, the attached schematic for my airplane should be >>>>sufficient. >>>> >>>>Vaughn Teegarden >>> >>> What you've proposed will be fine. The regulator >>> topology you cited is a carry through of the >>> earliest PM alternator regulators. It throttles >>> or controls alternator output to the system by >>> putting a dead short on the alternator's stator >>> windings during short periods where unrestrained >>> output would boost the system voltage too much. >>> >>> This is a very simple approach that has been >>> effective since day-one . . . but does have the >>> down-side of causing the alternator to run at >>> max output current 100% of the time whether that >>> energy is used by the electrical system or not. >>> Of course, if wire size and cooling considerations >>> for the alternator are carefully addressed, this >>> can produce a robust, reliable system. >>> >>> Bob . . . >>> >>> >>> ----------------------------------------) >>> ( . . . a long habit of not thinking ) >>> ( a thing wrong, gives it a superficial ) >>> ( appearance of being right . . . ) >>> ( ) >>> ( -Thomas Paine 1776- ) >>> ---------------------------------------- >>> >>> >>> >>> >>> >> >> >> >> >> >> >> >> >>-- >>269.19.1/1220 - Release Date: 1/11/2008 6:09 PM >> >> >> >> >>incoming mail is certified Virus Free. >>Checked by AVG. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > ________________________________________________________________________________
Date: Jan 13, 2008
>So if I included OV protection as shown in attached, I can feel good about >protecting my electronics. I noticed that in Z-20, you did not have a 5amp >alt field breaker. I have it in mine. Is it required? > >Vaughn Yes, that's works. Look closer at Z-20. EVERY used of the crowbar OV protection module has a 2 to 5A breaker upstream of the crowbar module. In this case, it's between terminals 1 and 5 on the "master switch". Bob . . . ________________________________________________________________________________
Date: Jan 13, 2008
Subject: Re: Strobe discharge pop-pop-pop
> >Ralph, > > > >I had this same problem with the strobes in my Cessna 172. > >I solved it by inserting a 1N4002 diode in the power feed to my > >intercom and putting a 2200uF/35V capacitor between power and ground > >on the intercom side. > >Unfortunately this was after rewiring all the intercom wires which had > >been shoddily installed and incorrectly grounded at both ends. Parts > >were what I had at hand. It is an easy thing to for you to try. > > > >I also found the problem was much more noticable when testing on the > >ground when the alternator was not running to boost the voltage than > >when flying. > > Interesting! This demonstrates that the noise is conducted > and the only way that the flash-tube circuit can couple to > ship's wiring is magnetic or electrostatic. Twisting of > the strobe head wires under a shield takes care of both of > these coupling modes except where a ground loop (something > connected to airframe at fixture end of wires). > > As an experiment, try operating your victim system(s) from > their own quiet power source . . . say a couple of 6v lantern > batteries in series. Get some el-cheesos from Wal-Mart. > If the noise goes away while powered only by the batteries, > then it's coming in through the +14v power wires. In this case, > adding the diode and capacitor as cited above is worth exploring. > > Alternatively, it's worth exploring how the admittedly intense > flash tube noises are getting out of their normally tight > confines. > > Bob . . . In my case, I think the noise wasn't from the discharge itself, but from the initial surge current as the strobe power pack started to re-charge its internal capacitors for the next flash. I expect the inconsistent connection of power and ground to the strobes and intercom led to a voltage drop across the power feed wire to the intercom - apparently all the folks who worked on the airplane in its 37 year history hadn't read your book :-) The internal circuitry of the intercom was unable to compensate for the power fluctuation, which isn't a surprise to me considering the extremely poor design of the internal circuitry of the intercom - sometimes products are popular because of features and price, not quality :-( In my case, it was just as easy to try sticking the diode and capacitor in the line as a test as it would have been to try using separate batteries as a power source. It worked so well that I left them there, rathering than trying to optimize the values. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Jan 13, 2008
Just to clarify, 406MHz Personal Location Beacon (PLB's), is basically a hand held ELT. You register the owner. It's free and is the official Search and Rescue (SAR) freq with satellites operated by Governments. The "Personal Tracking Device" (PTD) is a for FEE commercial service. Cost of the SPOT service is $110 year, initially. 406Mhz is free. The PTD have their own satellite or piggy back off one. I don't know how good their coverage is. It's fairly new. The PTD are geared for hikers, snowmobile and other out door stuff. Yes I agree a constant tracking device is a good idea. May be it is a good substitute for a PLB? Who knows? True PTD can be used to get an update on location. Your family can go on the web I guess and look up your position real time. PLB's is only activated for emergency. Other wise it's off. It is also passive in that it must be activated by the user. It gives no position unless turned on. The PTD is on all the time, which might be a battery issue, since they run off of two little AA's. Some of the PTD out there from different companies have the ability to send a message to the PTD. At one time they where talking about future voice capability (like a satellite phone), but the PTD's have backed down from that, for technical (cost?) reasons. If you HAVE a PTD than you MUST have some one monitor you or at least know to look for you and know you have a PTD. A PLB is monitored 24/7 and has world wide coverage. >From: "Jon Finley" <jon(at)finleyweb.net> >Subject: RE: AeroElectric-List: Re: ELT/PLB >One function of a PLB that seems to have been >forgotten is the tracking mode (see >http://www.findmespot.com/). Assuming you go down >and the PLB is destroyed, your next of kin have a >very good idea of your whereabouts much better i>dea than an ELT provides. >Frankly, if I crash and die, I could care less if >someone finds me (I know my family does not feel >that way). What I desire out of my PLB is the ability >to tell someone exactly where I am if I have a >problem and survive. Ya - all kinds of scenario's can >be debated but if you MUST have a completely fail >safe solution - don't expect to get it from a $150 >device. >Jon Finley >N314JF - Q2 - Subaru EJ-22 Legacy >http://www.finleyweb.net >Mid-Valley Airpark (E98), Los Lunas, NM --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Blue Mountain EFIS
Date: Jan 13, 2008
I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 ________________________________________________________________________________
Subject: Re: Blue Mountain EFIS
Date: Jan 14, 2008
I have 4 BMA Efis's and 2 autopilots in 2 different planes. Have had them for over 4 years and 500 hrs now. My experience with service and support has been good. Depending on the Generation of EFIS it may or may not be the right one for you. It also depends on what you want it to do. If you are going to use a Garmin 430 or 530 or an autopilot other than BMA I would not get a BMA EFIS especially if it is a pre gen 4 EFIS and even then I would be hesitant. They work great with an SL 30. Also the pre gen 4 units will never be upgradable to the features of the generation 4 units so what you get is what you will have. I enjoy flying my Gen 1 EFIS 1 but it just cant compare to my Gen 4 Sport in features and function. Support right now for the pre gen 4 units is slow but improving. BMA had a real nightmare of a launch with the Gen 4 products and appears to have gotten most (not all) items resolved and hopefully they are now going back and finishing the un resolved issues with Gen 3. For me the BMA units did all the things I wanted at the right price and weight. The delivery delays were not an issue for me but for some they caused considerable problems and rightfully made a lot of people really angry. Hopefully this is all in the past. In any event fully evaluate your needs in an EFIS and what you expect to integrate it with and then look at all the options available. If the BMA unit fits the bill and is at a good price I wouldn't hesitate at buying it. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157952#157952 ________________________________________________________________________________
Subject: Intercom Troubleshooting Help Needed
Date: Jan 14, 2008
I put power to my PS Engineering PM501 intercom last night for the first time and have a problem that has me at a dead-end. When I powered it up, the fuse blow immediately. I metered the power lead to ground and got infinite resistance which tells me that there are no dead shorts in the wiring. I moved the power circuit to a breaker, just to eliminate the fuse from contention, and it also popped. Again, no short to ground with the meter. When the unit is switched off, power can be applied and the breaker will stay latched. This also appears to tells me that there are no dead shorts in the wiring. It is only when turned on that it blows. Is this a problem inside the box that I may not be able to troubleshoot, let alone fix? Any thoughts on what my options are here, maybe something I have overlooked? Thanks, -------- David Gallagher 601 XL, tail and wings completed, fueslage almost done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157954#157954 ________________________________________________________________________________
Date: Jan 14, 2008
PS- On BMA They won't let customers back onto their board if you leave bad feedback, that's why you don't see as much negative reporting. I'm not sure if they do this actively or not but I have sent them three requests to get on their web board and they don't reply. I gave up so I don't know what they would say if I pressured them. Besides, I can only deal with their attitudes for about five minutes a month and I didn't want to use up all my gum balls. Here are some of my more recent stories regarding BMA: I ran into a guy that had two Blue Mountain EFIS One's in his Harmon Rocket. I was looking at it and I asked why he also had two Dynon's right next to the EFIS One. His response to me was the EFIS One would fail all the time and he would simply pull the unites and send them back every oil change because the most he would every get out of the unit was about 40 hours. He has over a year and a half on the units and was going to remove them this winter. This story was from August 2007. This is a story from my unit: A BMA EFIS Lite G3. For those of you who read the BMA web boards there is a story about the altimeter freezing up in flight. The response is that it can't happen from the BMA folks. I have had that problem twice and was told over the phone that that can't happen. So I looked into the mirror and said it must be me and the altimeter is really working and the ground is just not staying in the correct spot. (on a serious note, I think the problem is a thermal issue, I think the unit needs forced air to keep it cool so far that seems to be working. "I fear the day I have to use it in the clouds fortunately it only backs up a real EFIS and I added a stem gauge!") This last story is in progress: I have a coworker who is building an RV8 fastback with a partner. Both are detailed people are doing a high end build with all the bells and whistles. Attention to detail is a 10 (I'll send photos). One of them is an EE and knows his way around electronics at the micro level. They purchased a BMA EFIS one and have not flown yet. Most of the probes had to have trimmers installed so they would read accurately throughout the range of operations (I told you they were detailed). Most of the probes went out of cal out of nominal rest. I will post when we get to first flight. Mike Larkin -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: Sunday, January 13, 2008 9:20 PM Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 14, 2008
Subject: Removing D-Sub sockets
Fellow tronners.... Is there a trick to removing D-Sub sockets from the connector? I have the tool from radio shack (I have actually destroyed three of them) for the standard sockets. My trouble is that I can't get the tool to go past the base of the pin to where it would release the 'holding' fingers in the connector assembly. It has to be either the tool or my gorilla fisted technique..... every once in a while, I can wiggle while holding my tongue right, and it'll go in to allow me to extract the socket. I have two sockets remaining - I need to get a new tool - is there a better one? Thanks, Ralph ________________________________________________________________________________
Date: Jan 14, 2008
If you purchased the unit from PS Engineering call them and they should give you an RMA for a free repair. PSE has always gone over and above for me both personally and through the shop. If you purchased it second hand, call them and see what they can do, I'd bet the repair wont be very much. Based on your report of the failure, I think the unit has an internal failure. It doesn't sound like it should be that complicated to repair. It sounds like a power control problem. Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of DaveG601XL Sent: Monday, January 14, 2008 6:40 AM Subject: AeroElectric-List: Intercom Troubleshooting Help Needed I put power to my PS Engineering PM501 intercom last night for the first time and have a problem that has me at a dead-end. When I powered it up, the fuse blow immediately. I metered the power lead to ground and got infinite resistance which tells me that there are no dead shorts in the wiring. I moved the power circuit to a breaker, just to eliminate the fuse from contention, and it also popped. Again, no short to ground with the meter. When the unit is switched off, power can be applied and the breaker will stay latched. This also appears to tells me that there are no dead shorts in the wiring. It is only when turned on that it blows. Is this a problem inside the box that I may not be able to troubleshoot, let alone fix? Any thoughts on what my options are here, maybe something I have overlooked? Thanks, -------- David Gallagher 601 XL, tail and wings completed, fueslage almost done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157954#157954 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 14, 2008
Subject: Re: Removing D-Sub sockets
Hi Ralph, The tool Bob N. shows on his site, http://aeroelectric.com/articles/D-Sub_Pin/D-Sub_H.jpg has two ends on it. The red end only goes about 1/2 way around. The other end goes about 80% of the way around the pin. If your tool looks like the white end of Bob's picture, it should work without a lot of force. In fact a delicate touch and patience is necessary. For some reason, it takes a long time to get the first one or two out, but once you develop the "feel", they are pretty easy. Force won't work! The white end is fairly thin and easily bent. You might want to review Bob's entire procedure at http://aeroelectric.com/articles/D-Sub_Pin/Pin-Extraction.html I cursed a lot of pins out using the wrong tool that looked like the red end before I learned the difference. Bob W. "Ralph E. Capen" wrote: > > Fellow tronners.... > > Is there a trick to removing D-Sub sockets from the connector? > > I have the tool from radio shack (I have actually destroyed three of them) for the standard sockets. My trouble is that I can't get the tool to go past the base of the pin to where it would release the 'holding' fingers in the connector assembly. > > It has to be either the tool or my gorilla fisted technique..... every once in a while, I can wiggle while holding my tongue right, and it'll go in to allow me to extract the socket. > > I have two sockets remaining - I need to get a new tool - is there a better one? > > Thanks, > Ralph > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/cables/ ________________________________________________________________________________
Subject: RE: Terminal Tool TT5000
Date: Jan 14, 2008
Just received mine, and it works great on 6AWG and some 8AWG. Nicely made and more compact than I expected. Works well in a vice. Not sure about holding the frame with a wrench or whatever say in the plane. Haven't used it yet for the larger battery cables, but looks like it will work up to 1AWG or so. The tool's not really designed for 8AWG, but if the ferrule is thick enough (or I suppose if you add a few wire strands to a 8AWG wire in a 6AWG terminal ala Bobs soldering technique), it works pretty well. Very nice circumferential squeeze on the ferrule. I used 6AWG splices to join MAXI fuse holders (6AWG wire) to 8AWG Tefzel, and it worked fine. No extra wire strands required. Snip From: "Michael D. Cencula" <matronics(at)cencula.com> Subject: AeroElectric-List: Terminal Tool TT5000 Terry Frazier 7A Fuselage Anyone used one of these: http://www.averytools.com/pc-937-80-the-terminal-tool.aspx It looks like it might be good for those heavy gauge wires. Thanks, Mike Cencula RV-7A Fuse Snip ________________________________________________________________________________
Date: Jan 14, 2008
N395V wrote: > BMA had a real nightmare of a launch with the Gen 4 products and appears to have gotten most (not all) items resolved and hopefully they are now going back and finishing the un resolved issues with Gen 3. > This statement right here would eliminate the entire company from any prospect of doing business with me. Read what is written there. Their Gen 3 products do not work for the purpose intended. Instead of fixing that product and making things right for their customers, they're busy working on the next revision...which they subsequently sell to customers in a broken state. A flight computer for a GA aircraft lives in a very constrained environment. Temperature ranges and inertial forces have well defined limits. There is no excuse for a unit not to be tested to the extent of those limits. The fact that they would repeatedly push untested products into a potentially life threatening situation says to me that the company is less than ethical. ________________________________________________________________________________
Date: Jan 14, 2008
Subject: Re: Audio panel #inputs vs #sources
Will 1/4 watt be sufficient? -----Original Message----- >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> >Sent: Jan 11, 2008 10:47 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Audio panel #inputs vs #sources > > > >> >> >>Bob, >> >>I have heard 100ohm, 470ohm, and 510ohm. I'm guessing that either will >>function properly and that the 470 and 510's will decrease the volume more >>in addition to preventing the backfeed. >> >>Ralph > > Astute supposition sir. > > Bob . . . ----------------------------------------) > > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
Subject: Re: Intercom Troubleshooting Help Needed
Date: Jan 14, 2008
Mike, I have the same question into PSE via e-mail to their customer service address. Yeah, I was thinking the same thing. I made ultra sure that I had no shorts to ground as well as circuit protection in the loop before firing it up. Thanks, -------- David Gallagher 601 XL, tail and wings completed, fueslage almost done. Working engine and electrical systems. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158021#158021 ________________________________________________________________________________
Date: Jan 14, 2008
Thanks, Bob.... I have two broken white ends - and I didn't push hard at all. I'm guessing there's a bunch of finesse to get this right. Good part is I only need to remove two more pins - I was able to get the other eight out..... I'll order a new tool - and go over the stuff from the aeroelectric website......coupled with a lot less force....... Ralph -----Original Message----- >From: Bob White <bob@bob-white.com> >Sent: Jan 14, 2008 11:17 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Removing D-Sub sockets > > >Hi Ralph, > >The tool Bob N. shows on his site, >http://aeroelectric.com/articles/D-Sub_Pin/D-Sub_H.jpg >has two ends on it. The red end only goes about 1/2 way around. The >other end goes about 80% of the way around the pin. If your tool >looks like the white end of Bob's picture, it should work without a lot >of force. In fact a delicate touch and patience is necessary. For >some reason, it takes a long time to get the first one or two out, but >once you develop the "feel", they are pretty easy. Force won't work! >The white end is fairly thin and easily bent. > >You might want to review Bob's entire procedure at >http://aeroelectric.com/articles/D-Sub_Pin/Pin-Extraction.html > >I cursed a lot of pins out using the wrong tool that looked like the >red end before I learned the difference. > >Bob W. > > >"Ralph E. Capen" wrote: > >> >> Fellow tronners.... >> >> Is there a trick to removing D-Sub sockets from the connector? >> >> I have the tool from radio shack (I have actually destroyed three of them) for the standard sockets. My trouble is that I can't get the tool to go past the base of the pin to where it would release the 'holding' fingers in the connector assembly. >> >> It has to be either the tool or my gorilla fisted technique..... every once in a while, I can wiggle while holding my tongue right, and it'll go in to allow me to extract the socket. >> >> I have two sockets remaining - I need to get a new tool - is there a better one? >> >> Thanks, >> Ralph >> >> >> >> >> >> > > >-- >N93BD - Rotary Powered BD-4 - http://www.bob-white.com >3.8 Hours Total Time and holding >Cables for your rotary installation - http://roblinstores.com/cables/ > > ________________________________________________________________________________
Subject: KX-155 / KT-76A pin wiring & antennas
Date: Jan 14, 2008
I am attempting to install a KX-155 (no GS) and KT-76A in my Zenith CH701 project. I have the pin wiring diagrams from Bendix/King showing what pin does what, but I'm confused about the pin labeling. I referenced Bob's site at http://www.aeroelectric.com/Installation_Data/KX155.pdf and http://www.aeroelectric.com/Installation_Data/KT76A-76C-78A.pdf but my unit has a different number of pins. My A1 board is only 15 pins and the A2 board is 11 pins. How are the pins labeled (1-15, a-z, etc.). Also, what letters are skipped (I, O)? Second question: I realize the transponder antenna should not be bundled with other wires, but is it okay to bundle the COM and NAV antenna cables with other wires? Thanks, Dan Ginty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158036#158036 ________________________________________________________________________________
Date: Jan 14, 2008
I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 ________________________________________________________________________________
Date: Jan 14, 2008
> > >Will 1/4 watt be sufficient? Yes or even 1/2 watt. I often use 'oversized' components just to get mechanically more robust devices. This is one case where electrical ratings take a back seat being big, mean and ugly. Bob . . . >-----Original Message----- > >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> > >Sent: Jan 11, 2008 10:47 AM > >To: aeroelectric-list(at)matronics.com > >Subject: Re: AeroElectric-List: Audio panel #inputs vs #sources > > > > > > > > >> > >> > >>Bob, > >> > >>I have heard 100ohm, 470ohm, and 510ohm. I'm guessing that either will > >>function properly and that the 470 and 510's will decrease the volume more > >>in addition to preventing the backfeed. > >> > >>Ralph > > > > Astute supposition sir. ________________________________________________________________________________
Date: Jan 14, 2008
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 Looking for last minute shopping deals? ________________________________________________________________________________
Date: Jan 14, 2008
From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net>
I've been in the aircraft business as long as most people on this list,and I've never head as many complaints about any other vender as Blue Mountain. Why don't you just blow off the advice of this list,and go ahead and buy there product, then tell us were wrong! :-) Sam ---- Henador Titzoff wrote: ============ Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 Looking for last minute shopping deals? ________________________________________________________________________________
Date: Jan 14, 2008
Sam, the advice on this list sometimes gets pretty ridiculous, like telling me to buy an EFIS that I don't need. What are you, some kind of control freak? Henador ----- Original Message ---- From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net> Sent: Monday, January 14, 2008 8:31:29 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS I've been in the aircraft business as long as most people on this list,and I've never head as many complaints about any other vender as Blue Mountain. Why don't you just blow off the advice of this list,and go ahead and buy there product, then tell us were wrong! :-) Sam ---- Henador Titzoff wrote: ============ Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Jan 14, 2008
Subject: Alternator / Charging issue
A while back my alternator decided to start cycling on and off every now and again, mostly when under load. It will never do it during a day flight, and only during the day when running strobes. I can induce it at night fairly easily sometimes with the navs, fuel pump, landing light, and panel lights (no strobes needed..they seem able to induce the problem by themselves). I was returning from Miss. a few nights ago and it decided to do this. I shut down the strobes and everything was fine (as usual). I turned the strobes back on and the last 30 min or so of the flight was uneventful. I installed a new B&C battery yesterday and the problem occurred again yesterday evening 1 time near the beginning of the flight, and more so on the ground after I landed and had the engine at idle power. I stayed in the pattern since I had a "known" electrical issue. Here are few things I may have forgotten to mention, and I can't be sure if this could be a cause of my problem. 2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro ;) ) are reporting about 13.5V when in flight. I would assume this should be around 14.5 or so. I think before this problem it did. Funny the little things you start to notice when you actually have a problem. 3) The main problem is that if under load, the system will "shut down" the charging system intermittently and then come back online. Sometimes in a rapid (5 secs or so) succession or sometimes in more erratic unpredictable intervals. Like the flight back the other night, it acted up then stayed online for the remainder of the flight. I'll see the voltage annunciator come on and the voltage drop to 11.8 or 12...then it will go back up to 13.5. It may stay for a while...the remainder of the flight...or maybe 10 secs. It's crazy. I thought I had the alternator tested at one time and was told it was fine. I also just replaced my main solenoid (it was going bad..wouldn't connect when I turned the master on). That's fine now, but that didn't help the problem either. This problem is driving me crazy. Any and all input would be appreciated. I'm almost convinced I'm never going to find the root if this thing. Thanks again. Steve Reeves Glasair 38SR ________________________________________________________________________________
Date: Jan 14, 2008
Henador, I don't mean to be rude, but I don't think you have any idea what you are talking about as it pertains to Blue Mountain Avionics. I have written four posts today on this subject on two different sites. I have been nice and danced around the issue figuring that all could read between the lines. But for you let me be direct, if a boat anchor is what you need then BMA is for you. If you want to fly in the clouds then BMA is not for you.... Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Henador Titzoff Sent: Monday, January 14, 2008 6:17 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 Looking for last minute shopping deals? 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 14, 2008
Just to play devil's advocate, I HAVE a BMA, and have been satisfied. I think that for the price, they offer the most capable and current functionality, but I think you need to be choiceful with your upgrades because being first can mean things aren't as solid as many expect. I'd rather have the option of perfectly stable or leading tech with some possibility of issue - at my discretion. They are certainly not for everyone. Brett www.velocityxl.com Quoting Mike : > > Henador, > > I don't mean to be rude, but I don't think you have any idea what you > are talking about as it pertains to Blue Mountain Avionics. I have > written four posts today on this subject on two different sites. I have > been nice and danced around the issue figuring that all could read > between the lines. But for you let me be direct, if a boat anchor is > what you need then BMA is for you. If you want to fly in the clouds > then BMA is not for you.... > > Mike > ________________________________________________________________________________
Date: Jan 14, 2008
Subject: Re: Alternator / Charging issue
Steve, I saw nearly identical symptoms on my RV4. It turned out to be a poor quality crimp on the b lead connector on the alternator. Dick Sipp RV10 N110DV ________________________________________________________________________________
Date: Jan 14, 2008
Wow! So much information from people who have never owned the product! You know I heard from someone that Elvis is alive...I don't have to listen to anyone else cause it nust be true! On Jan 14, 2008 7:59 PM, Brett Ferrell wrote: > bferrell(at)123mail.net> > > Just to play devil's advocate, I HAVE a BMA, and have been satisfied. I > think > that for the price, they offer the most capable and current functionality, > but > I think you need to be choiceful with your upgrades because being first > can > mean things aren't as solid as many expect. I'd rather have the option of > perfectly stable or leading tech with some possibility of issue - at my > discretion. They are certainly not for everyone. > > Brett > www.velocityxl.com > > Quoting Mike : > > > > > Henador, > > > > I don't mean to be rude, but I don't think you have any idea what you > > are talking about as it pertains to Blue Mountain Avionics. I have > > written four posts today on this subject on two different sites. I have > > been nice and danced around the issue figuring that all could read > > between the lines. But for you let me be direct, if a boat anchor is > > what you need then BMA is for you. If you want to fly in the clouds > > then BMA is not for you.... > > > > Mike > > > > ________________________________________________________________________________
Date: Jan 15, 2008
1/15/2008 Hello Steve, Suggest that you check the wiring, particularly the ground wire, on your voltage regulator. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ---------------------------------------------- From: Steve Reeves <sreeves(at)gw.med.sc.edu> Subject: AeroElectric-List: Alternator / Charging issue A while back my alternator decided to start cycling on and off every now and again, mostly when under load. It will never do it during a day flight, and only during the day when running strobes. I can induce it at night fairly easily sometimes with the navs, fuel pump, landing light, and panel lights (no strobes needed..they seem able to induce the problem by themselves). I was returning from Miss. a few nights ago and it decided to do this. I shut down the strobes and everything was fine (as usual). I turned the strobes back on and the last 30 min or so of the flight was uneventful. I installed a new B&C battery yesterday and the problem occurred again yesterday evening 1 time near the beginning of the flight, and more so on the ground after I landed and had the engine at idle power. I stayed in the pattern since I had a "known" electrical issue. Here are few things I may have forgotten to mention, and I can't be sure if this could be a cause of my problem. 2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro ;) ) are reporting about 13.5V when in flight. I would assume this should be around 14.5 or so. I think before this problem it did. Funny the little things you start to notice when you actually have a problem. 3) The main problem is that if under load, the system will "shut down" the charging system intermittently and then come back online. Sometimes in a rapid (5 secs or so) succession or sometimes in more erratic unpredictable intervals. Like the flight back the other night, it acted up then stayed online for the remainder of the flight. I'll see the voltage annunciator come on and the voltage drop to 11.8 or 12...then it will go back up to 13.5. It may stay for a while...the remainder of the flight...or maybe 10 secs. It's crazy. I thought I had the alternator tested at one time and was told it was fine. I also just replaced my main solenoid (it was going bad..wouldn't connect when I turned the master on). That's fine now, but that didn't help the problem either. This problem is driving me crazy. Any and all input would be appreciated. I'm almost convinced I'm never going to find the root if this thing. Thanks again. Steve Reeves Glasair 38SR ________________________________________________________________________________
Date: Jan 15, 2008
I'm missing something here, Bruce. As I said, I HAVE owned (and still do) the product, you can see pictures of it on my website (listed below), so I'm not sure how this message is relevant. Or, were you not trying to make a relevant point?? http://www.velocityxl.com/EFIS_one.JPG B Quoting Bruce Peters : > Wow! So much information from people who have never owned the product! You > know I heard from someone that Elvis is alive...I don't have to listen to > anyone else cause it nust be true! > > On Jan 14, 2008 7:59 PM, Brett Ferrell wrote: > > > bferrell(at)123mail.net> > > > > Just to play devil's advocate, I HAVE a BMA, and have been satisfied. I > > think > > that for the price, they offer the most capable and current functionality, > > but > > I think you need to be choiceful with your upgrades because being first > > can > > mean things aren't as solid as many expect. I'd rather have the option of > > perfectly stable or leading tech with some possibility of issue - at my > > discretion. They are certainly not for everyone. > > > > Brett > > www.velocityxl.com > > > > Quoting Mike : > > > > > > > > Henador, > > > > > > I don't mean to be rude, but I don't think you have any idea what you > > > are talking about as it pertains to Blue Mountain Avionics. I have > > > written four posts today on this subject on two different sites. I have > > > been nice and danced around the issue figuring that all could read > > > between the lines. But for you let me be direct, if a boat anchor is > > > what you need then BMA is for you. If you want to fly in the clouds > > > then BMA is not for you.... > > > > > > Mike > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 15, 2008
Bruce, I have a BMA EFIS, I=92ll sell it to you for half price! What I think is funny, is that people who don=92t have one want to support it, or people who spent all the money they had are stuck with it and are forced to love it. I just want to keep people informed and keep them from make the same mistake others including myself have made. The BMA product looks good on paper. When I started looking at it I saw the problems with the original product and the second generation product. I used some of the same deduction and reasoning that has been exhibited here on this site. I said self, they should have their shit together by the third iteration and the price should be right. The whole time the product litterateur got prettier and prettier. Well it doesn=92t work! The screens freeze up, the unit crashes, most of the info coming from the probes on the engine system is not correct, the database they use is not certified(this may have changed recently), and their product support in a word sucks (It=92s the worst in the industry). Caveat emptor! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bruce Peters Sent: Tuesday, January 15, 2008 12:33 AM Subject: Re: AeroElectric-List: Blue Mountain EFIS Wow! So much information from people who have never owned the product! You know I heard from someone that Elvis is alive...I don't have to listen to anyone else cause it nust be true! On Jan 14, 2008 7:59 PM, Brett Ferrell wrote: "mailto:bferrell(at)123mail.net"bferrell(at)123mail.net > Just to play devil's advocate, I HAVE a BMA, and have been satisfied. I think that for the price, they offer the most capable and current functionality, but I think you need to be choiceful with your upgrades because being first can mean things aren't as solid as many expect. I'd rather have the option of perfectly stable or leading tech with some possibility of issue - at my discretion. They are certainly not for everyone. Brett HYPERLINK "http://www.velocityxl.com/" \nwww.velocityxl.com 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 15, 2008
> > >I've been in the aircraft business as long as most people on this list,and >I've never head as many complaints about any other vender as Blue >Mountain. Why don't you just blow off the advice of this list,and go ahead >and buy there product, then tell us were wrong! :-) >Sam What we're witnessing here is a "snowstorm" of anecdotal data and the attempts by many to deduce a "degree of goodness" for a product based on analysis of that data. In the TC aircraft world, we rely on repeatable experiments that put a product through a representative set of tests that benchmark performance. These tests are completely independent of the producer's talents for design, manufacturing and customer service. Complaints are valuable information but must be sorted for relevance to (1) science or (2) business model. The world's most elegant product is worthless when it cannot be supported by quality workmanship and honorable marketing. On the other hand, many a marginal and/or even dangerous product has gained a marketplace toe-hold when manufactured and promoted by persuasive individuals. Just watch late night TV for a host of examples for the later class of merchandise. We've all heard less than complimentary reports about Blue Mountain. I've received numerous stories from knowledgeable system integrators, pilots and marketing folks who had nothing but good wishes for success of this product. They wanted to sell it as a supporting system in their own airframes. All of these stories are dated. I would hope that Blue Mountain's longevity in the marketplace has more to do with IMPROVEMENTS to both their science and marketing than for an ability to squeeze, bottle and sell snake-oil. When evaluating the usefulness of anecdotal data from the field, one would do well to view that data through the filters of reasonableness. Does the data item make sense? The data items need to be sorted into two piles: (1) science and (2) production, marketing and customer service. Finally, one is well advised to deduce the story teller's intent . . . informative, humorous, persuasive or simply hurtful. If this sounds like more effort and skill than most of us are able to bring to the argument, the risk to value for participating in such discussions becomes obvious. It's an fundamental element of human nature that individuals with unhappy experiences will tend toward persuasive words intended to hurt. But without knowing the simple-ideas which support an individual's experience, the intent and value of their words is not calculable. I hope individuals who wish to contribute to the List's collective knowledge and understanding will do a bit of pre-filtering for their own words before committing them to the archives. Try to be informative as to fact and the outcomes of repeatable experiments. Avoid passing on information that was not observed/experienced first hand. Whether you support or disfavor a product or service, be specific as to the PERSONAL command of facts upon which you've based your opinion. Bob . . . ________________________________________________________________________________
Date: Jan 15, 2008
Subject: Re: KX-155 / KT-76A pin wiring & antennas
> >I am attempting to install a KX-155 (no GS) and KT-76A in my Zenith CH701 >project. I have the pin wiring diagrams from Bendix/King showing what pin >does what, but I'm confused about the pin labeling. > >I referenced Bob's site at >http://www.aeroelectric.com/Installation_Data/KX155.pdf and >http://www.aeroelectric.com/Installation_Data/KT76A-76C-78A.pdf > >but my unit has a different number of pins. My A1 board is only 15 pins >and the A2 board is 11 pins. How are the pins labeled (1-15, a-z, >etc.). Also, what letters are skipped (I, O)? The data posted on my website was purloined from an out of print publication called "Where the wires go", the effort of an avionics technician that bothered to compile and share his personal library of knowledge. I have no way to confirm or deny the accuracy of these drawings. Obviously, if the drawing differs physically from what your particular equipment items show, then the data are suspect and probably cannot be relied upon. Suggest you visit an avionics shop on a small airport and make friends with the owner. Years ago, I was privileged to enjoy the friendship of one of the real grey-beards in avionics. He had a library of data that went all the way back to these wonderful products: http://www.aeroelectric.com/Pictures/Radios/P1012765.JPG http://www.aeroelectric.com/Pictures/Radios/P1012780.JPG http://www.aeroelectric.com/Pictures/Radios/P1012763.JPG I used to buy, refurbish and sell these radios back in the days when I was the proud holder of a 1st Class Radio Telephone License. The radios you're wrestling with are not nearly so dated . . . but finding useful data out in the wild is becoming increasingly difficult. If you do find some information that's more useful than what I've published, I'd be pleased to receive some copies which I will scan and make available to others. >Second question: I realize the transponder antenna should not be bundled >with other wires, but is it okay to bundle the COM and NAV antenna cables >with other wires? There are no fundamentals in physics that recommend separation of wires between potentially antagonistic systems. There are two purposes for DO-160 testing against a TSO document for TC aircraft appliances. (1) make sure the device performs as advertised and (2) relieve the installer from making concessions to one system versus another system for happy coexistence in an airplane. Folks who experienced success at eliminating interference by repositioning wires have only succeeded in masking the root cause of a problem. The practice of sorting wire bundles as a prophylactic against interference problems is not an industry practice. Bob . . . ________________________________________________________________________________
Date: Jan 15, 2008
> >A while back my alternator decided to start cycling on and off every now >and again, mostly when under load. It will never do it during a day >flight, and only during the day when running strobes. I can induce it at >night fairly easily sometimes with the navs, fuel pump, landing light, and >panel lights (no strobes needed..they seem able to induce the problem by >themselves). I was returning from Miss. a few nights ago and it decided >to do this. I shut down the strobes and everything was fine (as >usual). I turned the strobes back on and the last 30 min or so of the >flight was uneventful. > >I installed a new B&C battery yesterday and the problem occurred again >yesterday evening 1 time near the beginning of the flight, and more so on >the ground after I landed and had the engine at idle power. I stayed in >the pattern since I had a "known" electrical issue. > >Here are few things I may have forgotten to mention, and I can't be sure >if this could be a cause of my problem. > > >2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro >;) ) are reporting about 13.5V when in flight. I would assume this >should be around 14.5 or so. I think before this problem it did. Funny >the little things you start to notice when you actually have a problem. > >3) The main problem is that if under load, the system will "shut down" >the charging system intermittently and then come back online. Sometimes >in a rapid (5 secs or so) succession or sometimes in more erratic >unpredictable intervals. Like the flight back the other night, it acted up >then stayed online for the remainder of the flight. I'll see the voltage >annunciator come on and the voltage drop to 11.8 or 12...then it will go >back up to 13.5. It may stay for a while...the remainder of the >flight...or maybe 10 secs. It's crazy. > > I thought I had the alternator tested at one time and was told it > was fine. > >I also just replaced my main solenoid (it was going bad..wouldn't connect >when I turned the master on). That's fine now, but that didn't help the >problem either. > >This problem is driving me crazy. Any and all input would be appreciated. > >I'm almost convinced I'm never going to find the root if this >thing. Thanks again. I've never encountered a system problem that was not fixable. You don't say what kind of alternator. External or internally regulated? Bob . . . ________________________________________________________________________________
Date: Jan 15, 2008
Bob, I respect your opinion but I must make a distinction between designing systems vs. purchasing high dollar systems that you have really no practical way of modifying or changing. A system where failure is common vs. occasional. Most of the issues discussed on this site are based on simple boiler plate system design that can be tested thoroughly prior to full use. My fear is people will add these off the shelf products using the marketing as fact on units that seem to work and sometimes do for a short period of time, this leading toward a false sense of security. The bottom line is most of what is reported here is not opinion but fact of failure regard failure with out systematic data collection. For example I have experienced more then 20 hard failures of my BMA system while running side by side with a Chelton non-certified EFIS and an Advanced Flight System AF engine system with no failures at all on these unites over a period of 18 months and three hundred hours of in-flight time. Just to clarify! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, January 15, 2008 9:16 AM Subject: Re: AeroElectric-List: Blue Mountain EFIS > > >I've been in the aircraft business as long as most people on this list,and >I've never head as many complaints about any other vender as Blue >Mountain. Why don't you just blow off the advice of this list,and go ahead >and buy there product, then tell us were wrong! :-) >Sam What we're witnessing here is a "snowstorm" of anecdotal data and the attempts by many to deduce a "degree of goodness" for a product based on analysis of that data. In the TC aircraft world, we rely on repeatable experiments that put a product through a representative set of tests that benchmark performance. These tests are completely independent of the producer's talents for design, manufacturing and customer service. Complaints are valuable information but must be sorted for relevance to (1) science or (2) business model. The world's most elegant product is worthless when it cannot be supported by quality workmanship and honorable marketing. On the other hand, many a marginal and/or even dangerous product has gained a marketplace toe-hold when manufactured and promoted by persuasive individuals. Just watch late night TV for a host of examples for the later class of merchandise. We've all heard less than complimentary reports about Blue Mountain. I've received numerous stories from knowledgeable system integrators, pilots and marketing folks who had nothing but good wishes for success of this product. They wanted to sell it as a supporting system in their own airframes. All of these stories are dated. I would hope that Blue Mountain's longevity in the marketplace has more to do with IMPROVEMENTS to both their science and marketing than for an ability to squeeze, bottle and sell snake-oil. When evaluating the usefulness of anecdotal data from the field, one would do well to view that data through the filters of reasonableness. Does the data item make sense? The data items need to be sorted into two piles: (1) science and (2) production, marketing and customer service. Finally, one is well advised to deduce the story teller's intent . . . informative, humorous, persuasive or simply hurtful. If this sounds like more effort and skill than most of us are able to bring to the argument, the risk to value for participating in such discussions becomes obvious. It's an fundamental element of human nature that individuals with unhappy experiences will tend toward persuasive words intended to hurt. But without knowing the simple-ideas which support an individual's experience, the intent and value of their words is not calculable. I hope individuals who wish to contribute to the List's collective knowledge and understanding will do a bit of pre-filtering for their own words before committing them to the archives. Try to be informative as to fact and the outcomes of repeatable experiments. Avoid passing on information that was not observed/experienced first hand. Whether you support or disfavor a product or service, be specific as to the PERSONAL command of facts upon which you've based your opinion. Bob . . . 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Off Subject - Barry Controls Engine Mounts
Date: Jan 15, 2008
I have 4 new in box Barry Controls mounts. They are Barry Controls part number 94150-41. They are for the Lancair O-235, O-320, or O-360 per the Aircraft Spruce catalog. They sell them for $104.95 each. AeroCraftParts (Lancair) sells them for $95 each plus shipping in each case. You can have mine for $50 each and I will pay shipping. They have a CD of 0346. (Construction Date of 46th week of 2003) Tech support at BM says that they have a shelf life of 10 years. If you need to replace your mounts now or in the near future, you will not find a better deal. Thanks, Bill B ________________________________________________________________________________
Date: Jan 15, 2008
Brent, I think you might be missing something. Many are reading these posts and wondering the viability of a specific product. Greg does a sizzling hot job on a web page to promote his products (Marketing wise)but I have heard static for three years on service, tech support and product reliability. It is always great to hear of people who are happy. Knowing if they have 10 hours or 600 on the system helps establish a benchmark. I have a close friend that bought the highest end BMA four years ago for a tandem seat project rebuild. Two years ago, Greg said the equipment (New and in the box) was value-less and the sub-manufacturers had gone south. The owner had to pay twice and the aircraft is still yet to fly. These discussions tap on an important discussion point as firms such as AFS court larger suitors and companies like OP Technologies sell out to bigger fish. My question remains "Who will be here in three years and which products are well supported for the Experimental Build market. EFIS is grand but a shakeout is inevitable. John Cox -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brett Ferrell Sent: Tuesday, January 15, 2008 6:44 AM Subject: Re: AeroElectric-List: Blue Mountain EFIS I'm missing something here, Bruce. As I said, I HAVE owned (and still do) the product, you can see pictures of it on my website (listed below), so I'm not sure how this message is relevant. Or, were you not trying to make a relevant point?? http://www.velocityxl.com/EFIS_one.JPG B Quoting Bruce Peters : > Wow! So much information from people who have never owned the product! You > know I heard from someone that Elvis is alive...I don't have to listen to > anyone else cause it nust be true! > > On Jan 14, 2008 7:59 PM, Brett Ferrell wrote: > > > bferrell(at)123mail.net> > > > > Just to play devil's advocate, I HAVE a BMA, and have been satisfied. I > > think > > that for the price, they offer the most capable and current functionality, > > but > > I think you need to be choiceful with your upgrades because being first > > can > > mean things aren't as solid as many expect. I'd rather have the option of > > perfectly stable or leading tech with some possibility of issue - at my > > discretion. They are certainly not for everyone. > > > > Brett > > www.velocityxl.com > > > > Quoting Mike : > > > > > > > > Henador, > > > > > > I don't mean to be rude, but I don't think you have any idea what you > > > are talking about as it pertains to Blue Mountain Avionics. I have > > > written four posts today on this subject on two different sites. I have > > > been nice and danced around the issue figuring that all could read > > > between the lines. But for you let me be direct, if a boat anchor is > > > what you need then BMA is for you. If you want to fly in the clouds > > > then BMA is not for you.... > > > > > > Mike > > > > > > > > > > > > > > ________________________________________________________________________________
Date: Jan 15, 2008
> > >Bob, > >I respect your opinion but I must make a distinction between designing >systems vs. purchasing high dollar systems that you have really no >practical way of modifying or changing. A system where failure is >common vs. occasional. Most of the issues discussed on this site are >based on simple boiler plate system design that can be tested thoroughly >prior to full use. My fear is people will add these off the shelf >products using the marketing as fact on units that seem to work and >sometimes do for a short period of time, this leading toward a false >sense of security. The bottom line is most of what is reported here is >not opinion but fact of failure regard failure with out systematic data >collection. For example I have experienced more then 20 hard failures >of my BMA system while running side by side with a Chelton non-certified >EFIS and an Advanced Flight System AF engine system with no failures at >all on these unites over a period of 18 months and three hundred hours >of in-flight time. Just to clarify! > >Mike I don't see where I've argued with you. Your data are first-hand, unarguable facts which should given due attention by folks who are making up their own minds as to how the best investment of $time$ is made for their project. I didn't intend to come down for or against Blue Mountain. The preponderance of evidence in the marketplace is decidedly not in their favor. My hope is that folks learn sift the clouds of floobydust that invariably arise when searching out useful data. This is especially important when the equipment is part of a closed loop stabilization and navigation system. Doing a reliable display based on rate sensors as opposed to gyros is an exceedingly non-trivial software task. Not only is there a need for robust sensing, interpretation, calculation for valid display, there's an equally critical task for sensing and notification of crew when the display is not valid. I've been intimately involved in programs that replaced iron gyros with laser rate sensors for the autopilots in 0.5M to 4.0M targets which maneuvered at up to 10Gs! I've watched those processes. We expended manpower and taxpayer dollars that would make most of the low-cost EFIS OBAM aircraft systems look like crystal sets. So in no way do I want to trivialize anyone's offering of hard data. I do want to encourage folks to make decisions based on hard data and to sift that data from information that is more emotional noise than data. Bob . . . ________________________________________________________________________________
Subject: Blue Mountain EFIS
Date: Jan 15, 2008
Henador, It has nothing to do with military experience, it has to do with the experience of the designer with systems that have flown and acquired time in an airborne environment. That environment is very different from a lab or a car. There are some useful and useless questions to ask, Useless: How many colors on the display Useful: What is the update rate of the display when using the full color palate? Useless: How fast is the processor? Useful: What is the latency from the air data or attitude sensor sensing a parameter to it being displayed when the system is displaying its most complex page? If more than 100ms you will notice the lag, it will be more difficult to fly the airplane than with a faster system). Useless: How fast does the internal data bus run at, what is the update rate of the screen? Useful: How many times a second does the flight data get updated on the screen when displaying the most complex page? If less than 20Hz (preferably 40 or 60Hz) you will notice jumpiness in the display. Useless: What language did you use for coding? Useful: What precautions did you take with the software and hardware designs to ensure accurate and reliable data is always presented to the pilot, and that any data that is unreliable or stale is not displayed? The point is airplane guys usually understand what is required from a system to allow a pilot to properly fly the airplane, what kind of dynamic response is desireable, and where to optimise the system at the design stage. Electronics guys might be tempted to use a better resolution screen, but not consider updates rates or latency in the basic systems architecture. Errors at the design stage are difficult to overcome during testing and development. Any company who claims you should buy their product because it has a big display that shows lots of data doesn't understand the task that display will have to perform! If they claim that the basic flight data is updated much more quickly than the graphics intensive map or terrain data, then that would make much more sense. It is really difficult for the average homebuilder to get a good assessment of the real world performance that might be offered by any particular EFIS or similar. There are very few comparative evaluations. One of the only factors is the skill and background of the folks who designed and built the equipment. Peter PS If anyone can answer the above questions for Blue Mountain (or any other EFIS) I, for one, would be interested. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Henador Titzoff Sent: 15 January 2008 01:17 Subject: Re: AeroElectric-List: Blue Mountain EFIS Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Read this topic online here: http://forums.matronics.com/viewtopic.php?p=157917#157917 Looking for last minute shopping deals? ________________________________________________________________________________
Date: Jan 15, 2008
> > >Henador, > >It has nothing to do with military experience, it has to do with the >experience of the designer with systems that have flown and acquired >time in an airborne environment. That environment is very different from >a lab or a car. > >There are some useful and useless questions to ask, > >Useless: How many colors on the display >Useful: What is the update rate of the display when using the full color >palate? >Useless: How fast is the processor? >Useful: What is the latency from the air data or attitude sensor sensing >a parameter to it being displayed when the system is displaying its most >complex page? If more than 100ms you will notice the lag, it will be >more difficult to fly the airplane than with a faster system). >Useless: How fast does the internal data bus run at, what is the update >rate of the screen? >Useful: How many times a second does the flight data get updated on the >screen when displaying the most complex page? If less than 20Hz >(preferably 40 or 60Hz) you will notice jumpiness in the display. >Useless: What language did you use for coding? >Useful: What precautions did you take with the software and hardware >designs to ensure accurate and reliable data is always presented to the >pilot, and that any data that is unreliable or stale is not displayed? > >The point is airplane guys usually understand what is required from a >system to allow a pilot to properly fly the airplane, what kind of >dynamic response is desireable, and where to optimise the system at the >design stage. Electronics guys might be tempted to use a better >resolution screen, but not consider updates rates or latency in the >basic systems architecture. Errors at the design stage are difficult to >overcome during testing and development. > >Any company who claims you should buy their product because it has a big >display that shows lots of data doesn't understand the task that display >will have to perform! If they claim that the basic flight data is >updated much more quickly than the graphics intensive map or terrain >data, then that would make much more sense. > >It is really difficult for the average homebuilder to get a good >assessment of the real world performance that might be offered by any >particular EFIS or similar. There are very few comparative evaluations. >One of the only factors is the skill and background of the folks who >designed and built the equipment. > >Peter Exactly! To your list of questions I would add: Has your product been designed to comply with design goals set forth in DO-160? If so, which levels and which chapters? Have any tests been conducted to confirm compliance? Does your product feature any form of data integrity monitoring? Does the software monitor internally or externally developed data for reasonableness? If any item becomes suspect, how is it handled in displays to the pilot? Are there provisions for useful if degraded performance if some feature of normal operations is no longer reliable? Are there any maneuvers that exceed the sensor/software ability to deduce true conditions? If the system falls out of bed, how fast and under what conditions might the user expect the system to get stood up again? There are probably more questions but these came to mind first. Peter is right, the average homebuilder should not be expected to know enough to ask such questions or understand the answers. But these ARE questions that should be addressed in detail in the product's published specifications, installation and service data. No details as to circuit design, software or even sources of components need be revealed. All these questions go to the designer's ability to do the job right and the manufacturer's ability and willingness to support it. The capable and honorable supplier will have no problems with answering them. These are exactly the kind of questions I'm expected to answer for clients . . . clients who couldn't care less about the gee-whiz and do care a lot about delivering to customer's expectations at a price he/she is pleased to pay. Bob . . . ________________________________________________________________________________
Date: Jan 15, 2008
Subject: Re: Blue Mountain EFIS
No, my apologies, just tired of of vendors that stretch the truth, to sell there junk. You can find the answer to your questions if you read between the lines here on this fourm. These are the people that have been at your crossroads in life and taken both roads, at one time or another. Sam ---- Henador Titzoff wrote: ============ Sam, the advice on this list sometimes gets pretty ridiculous, like telling me to buy an EFIS that I don't need. What are you, some kind of control freak? Henador ----- Original Message ---- From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net> Sent: Monday, January 14, 2008 8:31:29 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS I've been in the aircraft business as long as most people on this list,and I've never head as many complaints about any other vender as Blue Mountain. Why don't you just blow off the advice of this list,and go ahead and buy there product, then tell us were wrong! :-) Sam ---- Henador Titzoff wrote: ============ Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Jan 15, 2008
Sam, you are a noble man. I must apologize to you, also. Well, you aren't the only one who's tired of vendors who don't deliver and when they do, they deliver crapp product. I believe we all are. The reason I've been abrupt with you and Peter is because I believe that both of you misread what I initially said. Nowhere in my response did I say that I wanted an EFIS. And nowhere did I defend or condone BMA products. What I simply said is that Peter is biased being a military guy and saying that only airplane guys know how to design autopilot and EFISs. Being a military guy has nothing to do with it unless you want to pay 85% slouches and 15% good guys to get the job done. Later on he makes the same mistake you made and tells me to blow off the advice of the people on this list and go buy BMA products. Again, I never said I wanted to buy BMA products nor do I condone them, because I have no direct experience with them. I plainly say that I do not have direct experience with them, but that I have seen BMA guys at airshows, and they seem to know what they're talking about. Anybody can talk good shiite, because they are salespeople and have static displays to show. This is true of any company. The only way to evaluate a good product is to try it out under normal and extended operating conditions. Nothing beats experience. What you hear on this email list is, as Bob said, lots of anecdotal data, no -prefiltering of data, and some good stuff. Often times, when people post to this and other lists, their intentions are to either sale, sale, sale what they bought regardless of how good or bad it is, or condemn, condemn, condemn for several reasons, some being questionable. P.S. I'm perfectly happy with the equipment I have. If I ever decide to move up in the EFIS world, I will ride shotgun in people's planes who have such equipment, then make up my own mind. I know enough EFIS owners already, and they all talk great about what they have (sale, sale, sale). Henador ----- Original Message ---- From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net> Cc: Henador Titzoff Sent: Tuesday, January 15, 2008 5:02:22 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS No, my apologies, just tired of of vendors that stretch the truth, to sell there junk. You can find the answer to your questions if you read between the lines here on this fourm. These are the people that have been at your crossroads in life and taken both roads, at one time or another. Sam ---- Henador Titzoff wrote: ============ Sam, the advice on this list sometimes gets pretty ridiculous, like telling me to buy an EFIS that I don't need. What are you, some kind of control freak? Henador ----- Original Message ---- From: "sam(at)fr8dog.net" <sam.marlow(at)adelphia.net> Sent: Monday, January 14, 2008 8:31:29 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS I've been in the aircraft business as long as most people on this list,and I've never head as many complaints about any other vender as Blue Mountain. Why don't you just blow off the advice of this list,and go ahead and buy there product, then tell us were wrong! :-) Sam ---- Henador Titzoff wrote: ============ Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Date: Jan 15, 2008
From: Henador Titzoff <henador_titzoff(at)yahoo.com>
Mike, I know you're not trying to be rude, but please go back and read what I said again. Nowhere does it say that I am in the market for an EFIS, BMA or whatever. Nowhere does it say that I am condoning BMA products. I did say that I've talked to their salespeople at airshows, and they seem to know what they're talking about. This does NOT amount to my condoning their products. Anybody can talk a good talk. My post was to contradict Peter about military guys and why companies get in trouble and nothing else. Have a wonderful evening, Mike and Peter and Sam. Henador ----- Original Message ---- From: Mike <mlas(at)cox.net> Sent: Monday, January 14, 2008 10:41:50 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS Henador, I don't mean to be rude, but I don't think you have any idea what you are talking about as it pertains to Blue Mountain Avionics. I have written four posts today on this subject on two different sites. I have been nice and danced around the issue figuring that all could read between the lines. But for you let me be direct, if a boat anchor is what you need then BMA is for you. If you want to fly in the clouds then BMA is not for you.... Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Henador Titzoff Sent: Monday, January 14, 2008 6:17 PM Subject: Re: AeroElectric-List: Blue Mountain EFIS Peter, Your view seems biased to me. You work in military avionics yet ou think that airplane guys who move into electronics produce much better EFISs and autopilots than "electronic guys" who move into airplanes. I'm not sure what you mean by "electronic guys," but I suspect it is workers who produce commercial products. That's like Lenin claiming that communism is better than capitalism. I also do not have direct experience with BMA products, but I've seen their reps at airshows. They seem to know what they're talking about just like the other guys. If they're having problems, I am willing to bet that they are business related decisions, i.e., shipping too early to meet deadlines, not ordering enough parts on time, technical problems due to hurried schedules, etc. These problems plague any organization that isn't run properly. It has nothing to do with whether someone has military experience or not. Henador ----- Original Message ---- From: Peter Pengilly <peter(at)sportingaero.com> Sent: Monday, January 14, 2008 3:25:57 PM Subject: RE: AeroElectric-List: Blue Mountain EFIS I work in military avionics (I started out as an aerodynamicist); my view is that airplane guys who move into electronics produce much better EFIS and autopilot products than electronics guys who move into airplanes. Ask about the background of the company who built the product and make a decision accordingly. I have no direct experience of BMA products, but their representatives at the various airshows did not talk enough 'airplane' for me. Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sully Sent: 14 January 2008 04:20 Subject: AeroElectric-List: Blue Mountain EFIS I wanted to find out if anyone has recent experience with performance and support from Blue Mountain. I have an opportunity to buy a EFIS/One from someone who hasn't been satisfied, but most of the negative posts I've seen, seem to be several months old. Any current info will appreciated. Sully -------- Sully RV-7 In-work Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ ________________________________________________________________________________
Subject: IFR GPS requirements
Date: Jan 15, 2008
Hello All, I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During discussions with an FAA inspector, I was told that I was not allowed to use this unit for IFR use until I completed a 337 form with a field approval, and completed the required test flight. I was not aware that the experimental ships had to jump through the same hoops as the Type Certificated aircraft. Can this possibly be true? I welcome all input on this subject. Bill RV-7 Lee's Summit, MO ________________________________________________________________________________
Date: Jan 15, 2008
Hello Steve, The 13.5 volt output appears to be too low, possibly due to a bad diode. The intermittent nature also could be due to excessive leakage from one or more of the other diodes when the alternator gets hot. It might be wise to take it to an alternator overhaul shop to be checked vs. the local auto parts establishment. What type of alternator do you have? Any cooling via blast tube? Please let us know what you find. Thanks. Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve Reeves Sent: Monday, January 14, 2008 8:35 PM Subject: AeroElectric-List: Alternator / Charging issue A while back my alternator decided to start cycling on and off every now and again, mostly when under load. It will never do it during a day flight, and only during the day when running strobes. I can induce it at night fairly easily sometimes with the navs, fuel pump, landing light, and panel lights (no strobes needed..they seem able to induce the problem by themselves). I was returning from Miss. a few nights ago and it decided to do this. I shut down the strobes and everything was fine (as usual). I turned the strobes back on and the last 30 min or so of the flight was uneventful. I installed a new B&C battery yesterday and the problem occurred again yesterday evening 1 time near the beginning of the flight, and more so on the ground after I landed and had the engine at idle power. I stayed in the pattern since I had a "known" electrical issue. Here are few things I may have forgotten to mention, and I can't be sure if this could be a cause of my problem. 2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro ;) ) are reporting about 13.5V when in flight. I would assume this should be around 14.5 or so. I think before this problem it did. Funny the little things you start to notice when you actually have a problem. 3) The main problem is that if under load, the system will "shut down" the charging system intermittently and then come back online. Sometimes in a rapid (5 secs or so) succession or sometimes in more erratic unpredictable intervals. Like the flight back the other night, it acted up then stayed online for the remainder of the flight. I'll see the voltage annunciator come on and the voltage drop to 11.8 or 12...then it will go back up to 13.5. It may stay for a while...the remainder of the flight...or maybe 10 secs. It's crazy. I thought I had the alternator tested at one time and was told it was fine. I also just replaced my main solenoid (it was going bad..wouldn't connect when I turned the master on). That's fine now, but that didn't help the problem either. This problem is driving me crazy. Any and all input would be appreciated. I'm almost convinced I'm never going to find the root if this thing. Thanks again. Steve Reeves Glasair 38SR ________________________________________________________________________________
Date: Jan 15, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: IFR GPS requirements
>Hello All, > > >I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During >discussions with an FAA inspector, I was told that I was not allowed to >use this unit for IFR use until I completed a 337 form with a field >approval, and completed the required test flight. I was not aware that the >experimental ships had to jump through the same hoops as the Type >Certificated aircraft. Can this possibly be true? I welcome all input on >this subject. It would be interesting to see who he recommends for an IA to sign this off! Assuming you can get it submitted, it would be interesting to watch what happens to the document once it hit the appropriate offices for approval and filing. 337's are the equivalent of a one-time STC against a particular certificated airframe. The guys here tell me to install it, go fly it, satisfy yourself that it is functioning as advertised and be done with it. Be cautious about getting into any serious discussions with a bureaucrat. Bob . . . ________________________________________________________________________________
Subject: OT-- Solar panel overvoltage
Date: Jan 15, 2008
Sorry to drift off topic, but chalk it up to Remote Hangar Power-Supply Project. I've got a couple solar (PV) panels, each rated 48 watt, 3 amp @ 16 volts, 18-19 volts open circuit. Problem is that I bought an inverter that has a 15.5 high-voltage cutoff, so no worky for 110a/c. My question(s): If I got a "Solar Charge Controller", designed to limit charge into batteries, could I use it to supply the inverter ?? And how about a 12-v. resistive load, or pump/fan motors, (no inverter) that would pull down the voltage at max draw ?? ... assuming the charge controller could handle the current. Any other ideas for regulating 16 v down to a usable 13-14 (for 6 A.) Thanks in advance for any advice. --Richard V., 601xl in a cold shop in KC Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158464#158464 ________________________________________________________________________________
Date: Jan 15, 2008
Subject: Re: AeroElectric-List Digest: 22 Msgs - 01/14/08
David, I have a different model PSE intercom in my Cessna. It has a failover mode that connects the radio directly to the headset when the intercom power is off. When you turn it on, some relays click and the intercom inserts itself into the radio to headset circuitry. So with the power off, you cannot measure a short. Try measuring for a short between the headset, mic and ptt leads to ground and see if you mis-wired something. PSE has great tech support. I spent quite a while talking with a tech named Brad when I had a weird incompatibility issue with the intercom and my headset. They will take your unit back for test and trade, but check all your wiring first. Just disconnect the connector at the back of the unit and search for grounds that are not supposed to be. Jeff Page Dream Aircraft Tundra #10 > Subject: AeroElectric-List: Intercom Troubleshooting Help Needed > From: "DaveG601XL" <david.m.gallagher(at)ge.com> > > I put power to my PS Engineering PM501 intercom last night for the > first time and > have a problem that has me at a dead-end. When I powered it up, the > fuse blow > immediately. I metered the power lead to ground and got infinite resistance > which tells me that there are no dead shorts in the wiring. I moved > the power > circuit to a breaker, just to eliminate the fuse from contention, and it also > popped. Again, no short to ground with the meter. When the unit is switched > off, power can be applied and the breaker will stay latched. This > also appears > to tells me that there are no dead shorts in the wiring. It is only when > turned on that it blows. Is this a problem inside the box that I may not be > able to troubleshoot, let alone fix? Any thoughts on what my > options are here, > maybe something I have overlooked? > > David Gallagher > 601 XL, tail and wings completed, > fueslage almost done. Working engine and electrical systems. ________________________________________________________________________________
Date: Jan 15, 2008
Subject: Re: OT-- Solar panel overvoltage
At 20:16 1/15/2008, you wrote: > >Sorry to drift off topic, but chalk it up to Remote Hangar >Power-Supply Project. > >I've got a couple solar (PV) panels, each rated 48 watt, 3 amp @ 16 >volts, 18-19 volts open circuit. Problem is that I bought an >inverter that has a 15.5 high-voltage cutoff, so no worky for 110a/c. >My question(s): >If I got a "Solar Charge Controller", designed to limit charge into >batteries, could I use it to supply the inverter ?? > > And how about a 12-v. resistive load, or pump/fan motors, (no > inverter) that would pull down the voltage at max draw ?? ... > assuming the charge controller could handle the current. > >Any other ideas for regulating 16 v down to a usable 13-14 (for 6 A.) > >Thanks in advance for any advice. >--Richard V., 601xl in a cold shop in KC Why not just dump them into a battery and the inverter in parallel? Ron Q. ________________________________________________________________________________
Date: Jan 16, 2008
Good Morning Bill, I agree with 'Lectric Bob's comment, but may I add a bit more? What it basically amounts to is that you are the certifying agent. As long as the equipment operates in the manner required to meet the IFR requirement s, you are good to go. However, that does seem to mean that you should do the checks that would be required for the flight testing to assure yourself that the set is working properly. Just follow the directions given in the installation manual for the test flight and so certify in the ship's papers . I don't have the regulations memorized, but EAA has issued a paper on the subject of IFR certification of experimental aircraft. It may have been auth ored by Earl Lawrence, but I am not sure. Hopefully, someone more knowledgeable than I will pipe up with a better reference. In any case, don't get in an argument with a local FSDO inspector. Remember, even though most of them are great guys who want to do a good job , they are still at the very bottom of the food chain. Just listen and then do what you want! You are the responsible party. No arguments needed. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/15/2008 9:44:48 P.M. Central Standard Time, wgill10(at)comcast.net writes: Hello All, I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During discussions with an FAA inspector, I was told that I was not allowed to use this unit for IFR use until I completed a 337 form with a field approval, and completed the required test flight. I was not aware that the experimental s hips had to jump through the same hoops as the Type Certificated aircraft. Can t his possibly be true? I welcome all input on this subject. Bill RV-7 Lee=99s Summit, MO **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 16, 2008
I don't personally own a BMA unit but I have certainly evaluated every competitor out there. There are a few observations I would make about their top of the line product: * Until recently very few of the avionics shops would sell it. Several privately told me to consider why that was but did not actually give me a specific reason. * As far as I am aware only one is openly selling BMA stuff today. That same person told me at Oshkosh several years ago that he wouldn't sell it and recommended another product. Times change and commercial realities change that is for sure, but has the reason for the original decision changed? I don't know. * Second hand BMA stuff seems to come on the market frequently. I have not seen this occur with too much other gear that is to all intents and purposes the latest model. * Stories abound if you ask about of people that are not happy with the product, many continue to swear by it though. Some must have had good service, some may not wish to conclude they spent a lot of money on something that is not perfect. Some are happy pushing the envelope or investing in the technology. However other vendors exist that no one has a bad thing to say about. Surely this would make many people's decision easy if they are looking for a polished product. However, I would say this is experimental aviation and each has their own reason for purchasing. What really convinced me is the method these guys use to develop and ship code. This is something I am very well qualified to comment on as I work in the software industry and have been doing so for many years. From discussions with them and observation of the activities on their message board I would not fly their latest code under the IFR. This was my priority and it was a deal breaker for me. I could ask why people buy these units when they do not want to fly NVFR or IFR, but that would be a whole other can of worms. However, If you own BMA hardware, or you want to buy it, please do not take offense. I support the nature of experimental aviation and your continuing investment in the technology will no doubt lead to competition and improvements in the marketplace for everyone. BMA is not for me, for the reasons I outlined above. If you want to buy it, then that is cool too. Good luck with your project and happy flying! Richard ________________________________________________________________________________
Date: Jan 16, 2008
Bob, This inspector said he has done over 50 field inspections via 337 in experimental aircraft in the Kansas City area. He did not say who the submitting agency was, but I believe it was a repair station that he has oversight responsibility. Strange. I will take everyone's advice and quietly stay back away from the FAA and proceed. I have done a flight test in visual conditions performing GPS approaches (as well as LOC/ILS approaches) and all went great. Thanks for your input. Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, January 15, 2008 10:12 PM Subject: Re: AeroElectric-List: IFR GPS requirements >Hello All, > > >I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During >discussions with an FAA inspector, I was told that I was not allowed to >use this unit for IFR use until I completed a 337 form with a field >approval, and completed the required test flight. I was not aware that the >experimental ships had to jump through the same hoops as the Type >Certificated aircraft. Can this possibly be true? I welcome all input on >this subject. It would be interesting to see who he recommends for an IA to sign this off! Assuming you can get it submitted, it would be interesting to watch what happens to the document once it hit the appropriate offices for approval and filing. 337's are the equivalent of a one-time STC against a particular certificated airframe. The guys here tell me to install it, go fly it, satisfy yourself that it is functioning as advertised and be done with it. Be cautious about getting into any serious discussions with a bureaucrat. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2008
Bill I did a bit of research on this subject last year. The FAA inspector is WRONG! Peter Laurence ----- Original Message ----- From: William Gill To: aeroelectric-list(at)matronics.com ; rv-list(at)matronics.com Sent: Tuesday, January 15, 2008 10:39 PM Subject: AeroElectric-List: IFR GPS requirements Hello All, I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During discussions with an FAA inspector, I was told that I was not allowed to use this unit for IFR use until I completed a 337 form with a field approval, and completed the required test flight. I was not aware that the experimental ships had to jump through the same hoops as the Type Certificated aircraft. Can this possibly be true? I welcome all input on this subject. Bill RV-7 Lee's Summit, MO ________________________________________________________________________________
Date: Jan 16, 2008
Ron Quillin wrote: > > > At 20:16 1/15/2008, you wrote: >> >> Sorry to drift off topic, but chalk it up to Remote Hangar >> Power-Supply Project. >> >> I've got a couple solar (PV) panels, each rated 48 watt, 3 amp @ 16 >> volts, 18-19 volts open circuit. Problem is that I bought an >> inverter that has a 15.5 high-voltage cutoff, so no worky for 110a/c. >> My question(s): >> If I got a "Solar Charge Controller", designed to limit charge into >> batteries, could I use it to supply the inverter ?? >> >> And how about a 12-v. resistive load, or pump/fan motors, (no >> inverter) that would pull down the voltage at max draw ?? ... >> assuming the charge controller could handle the current. >> >> Any other ideas for regulating 16 v down to a usable 13-14 (for 6 A.) >> >> Thanks in advance for any advice. >> --Richard V., 601xl in a cold shop in KC > > Why not just dump them into a battery and the inverter in parallel? > > Ron Q. My thought exactly. This will have the added advantage of allowing you to draw more than 6amps on the rare occasion that you need it. ________________________________________________________________________________
Date: Jan 16, 2008
>Why not just dump them into a battery and the inverter in parallel? I really wanted to see what was possible without a battery... --RJV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158503#158503 ________________________________________________________________________________
Date: Jan 16, 2008
> Just Curious, how many successfull flight hours do you have behind your BMA? > > About 700hrs. > > What I think is funny, is that people who don?t have one want to support it, or people who spent all the money they had are stuck with it and are forced to love it. > > Yeah, My first two units sucked so bad I felt compelled to buy 3 more guess I'm just lucky that my 5 units are the only ones in the world that work . -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158505#158505 ________________________________________________________________________________
Date: Jan 16, 2008
1/16/2008 Hello Bill, Avoid that poor soul -- he has not been around long enough or cared enough to learn that type certificated aircraft and amateur built experimental aircraft are treated very differently in the FAA's paperwork system. What he has described in the way of paperwork approval just simply does not apply to your airplane. Here is a quote from the signature section of the FAA Form 337: "I certify that the repair and/or alteration made to the unit(s) identified in item 5 above and described on the reverse or attachments hereto have been made in accordance with the requirements of Part 43 of the U.S. Federal Aviation Regulations and that the information furnished herein is true and correct to the best of my knowledge." And here is a quote from FAR Part 43.1: "(b) This part does not apply to any aircraft for which the FAA has issued an experimental certificate, unless the FAA has previously issued a different kind of airworthiness certificate for that aircraft." Since part 43 does not apply to amateur built aircraft issued a Special Airworthiness Certificate in the Experimental Category for the purpose of operating amateur-built aircraft (FAR 21.191 (g)) how can one properly comply with the signature certification requirement on the FAA Form 337? Several years ago a poster described his mistaken attempt to comply with all FAA type certificated regulatory and advisory circular requirements for the IFR GPS installation in his amateur built experimental airplane. He even flew a test flight with a terrified FAA inspector who spent the entire flight frantically looking out the window in fear of a mid air collision. The entire effort was wasted because no FAA agency or procedure for the approval existed -- just initial erroneous assumptions by uninformed FAA employees. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ----------------------------------------- From: "William Gill" <wgill10(at)comcast.net>Subject: IFR GPS requirements Date: Jan 15, 2008 Hello All, I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During discussions with an FAA inspector, I was told that I was not allowed to use this unit for IFR use until I completed a 337 form with a field approval, and completed the required test flight. I was not aware that the experimental ships had to jump through the same hoops as the Type Certificated aircraft. Can this possibly be true? I welcome all input on this subject. Bill RV-7 Lee's Summit, MO ________________________________________________________________________________
Date: Jan 16, 2008
Peter, et al, It depends on what the inspector wrote into you ops limits. If he referenced 91.205 as a requirement for IFR flight, then you must get the system tested by an FAA certified shop. If not you can proceed as you wish. In the Ops Limits I received yesterday, Item 11: "After completion of phase 1 testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated VFR day only." Rick Girard On Jan 16, 2008 7:27 AM, Peter Laurence wrote: > Bill > > I did a bit of research on this subject last year. The FAA inspector is > WRONG! > > Peter Laurence > > > ----- Original Message ----- > *From:* William Gill > *To:* aeroelectric-list(at)matronics.com ; rv-list(at)matronics.com > *Sent:* Tuesday, January 15, 2008 10:39 PM > *Subject:* AeroElectric-List: IFR GPS requirements > > Hello All, > > > I have a Bendix-King KLN 94 GPS (IFR certified unit) in an RV-7. During > discussions with an FAA inspector, I was told that I was not allowed to use > this unit for IFR use until I completed a 337 form with a field approval, > and completed the required test flight. I was not aware that the > experimental ships had to jump through the same hoops as the Type > Certificated aircraft. Can this possibly be true? I welcome all input on > this subject. > > > Bill > > RV-7 > > Lee's Summit, MO > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Jan 16, 2008
vozzen wrote: > > >> Why not just dump them into a battery and the inverter in parallel? >> > > I really wanted to see what was possible without a battery... > --RJV > > You can operate without a battery. Anything is possible, if you throw enough money at it. But the utility you will get from a couple of batteries will be by far the biggest bang for the buck. Not only will they let you have an occasional large power draw that the panels wouldn't support, but they will let you have limited power at night or when it's cloudy. If you're rotating cheap batteries as Bob suggests, then you should be able to rotate the 2yr old battery into a "solar panel support" position. A spare lawn tractor battery would suffice until it's time to rotate one in from the airplane. The batteries should last a LONG time, being constantly charged and only occasionally drained, so you can keep adding capacity by hooking more up in series as they rotate out of the plane. Again, it's possible to solve the problem with some creative electronics. You could chop the panel's DC to create AC, then run that through a regulator, then rectify it back to DC. Or you could put a large capacitor and enough Zener diodes to handle 6amps across the panel's output. What you'll end up with is some electronics to maintain, without the added benefits of the stored capacity. You'll spend a lot more than the $30 battery will cost, even if you kit and build it yourself. ________________________________________________________________________________
Date: Jan 16, 2008
Milt, You must live next door to the shop or married into the family. :) Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of N395V Sent: Wednesday, January 16, 2008 6:59 AM Subject: AeroElectric-List: Re: Blue Mountain EFIS > Just Curious, how many successfull flight hours do you have behind your BMA? > > About 700hrs. > > What I think is funny, is that people who don?t have one want to support it, or people who spent all the money they had are stuck with it and are forced to love it. > > Yeah, My first two units sucked so bad I felt compelled to buy 3 more guess I'm just lucky that my 5 units are the only ones in the world that work . -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158505#158505 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 16, 2008
Good Morning Rick, That is exactly the way it should read! The next step is to equip it in accordance with the specifications of 14 CFR Part 91, section 91.205 for the type of flight you wish to conduct and make an entry into the ship's papers stating that you have done so. No need to change anything on your ops spec and no need to contact any Fed. Just install the equipment and test it in accordance with the manufacturers directions. As long as you have the proper equipment, just hop in the machine and go fly IFR and/or night Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/16/2008 8:53:03 A.M. Central Standard Time, jindoguy(at)gmail.com writes: In the Ops Limits I received yesterday, Item 11: "After completion of phase 1 testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated VFR day only." Rick Girard **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 16, 2008
mlas(at)cox.net wrote: > Milt, > > You must live next door to the shop or married into the family. :) > > Mike > > -- Nah! they are way too ugly to marry but it is a short flight to the shop. In all seriousness though I am lucky in that my units have functioned well and I have had a pleasant experience when interacting with them. I do know many BMA owners who rightfully are really pissed off at them and have had nothing but trouble with their units and have had anything but a pleasant experience in attempting to obtain service. Also know a lot of BMA owners who got the unit, slapped it in their plane and tried to use it without ever looking at the install manual, installed them incorrectly nand then raised hell with BMA. I think currently BMAs major problem is support for the older units. They do not have enough staff to fully bring the Gen 4s online and support the gen1s and 3s at the same time. Their G4 launch was a real nightmare for those who needed their units in a timely fashion. (timely meaning on the date promised) I do not think BMA or its owners are unethical or do not care about their customers I think they are exceedingly brilliant techno geeks who hadn't a clue on how to run a company and had no knowledge of consumer relations. Hopefully they have learned a lesson and hopefully will survive the past and continue to grow. While I am a happy customer and an unashamed supporter I do recognize the problems they have had and the problems they still have. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158533#158533 ________________________________________________________________________________
Date: Jan 16, 2008
> >Bob, > >This inspector said he has done over 50 field inspections via 337 in >experimental aircraft in the Kansas City area. He did not say who the >submitting agency was, but I believe it was a repair station that he has >oversight responsibility. Strange. I will take everyone's advice and >quietly stay back away from the FAA and proceed. I have done a flight >test in visual conditions performing GPS approaches (as well as LOC/ILS >approaches) and all went great. Thanks for your input. > >Bill What he "has done" compared to what he is supposed "to do" may have some serious disconnect here. But then KC is the home of the Small Aircraft Directorate. As Thomas Paine noted many moons ago: When subject to dictatorships, monarchy, or oligarchy, at least we KNOW the source from which our irritations emanate. With democracies, we can only just begin to perceive the major players in a mass of individuals who's power needs to be metered through constitutional boundaries. It would not surprise me that what was recited to you by this individual was a portent of things to come. After all, the FAA is only here to help! With the numbers of TC light aircraft dwindling, he's only looking for more things to do. The prohibition against night and/or IFR flight speaks only to having the necessary equipment under part 91 rules to safely conduct such operations. It does not speak to whether it's silver plated, platinum plated, or holy-watered by individuals knighted by the oligarchy. A wise mentor of many years ago once advised me never to ask a question of anyone with power unless I already knew what that answer would be. Seems like a silly notion but as I grew older, it made a lot of sense. Folks with much power over my life leave a trail of activities that can be researched for predictors of their answers. If you don't like what the answer is going to be, then don't ask it. It many cases, the expenditure of $time$ to receive permission far exceeds the $time$ expended to beg forgiveness. So sifting through the pile of wreckage after bagging your remains they discover that your GPS was not holy-watered . . . what are they going to do, fine you? Bob . . . ________________________________________________________________________________
Date: Jan 16, 2008
Guys, I don't own an EFIS of any kind. I have no personal interest in any of this except in the ad hominem attacks that are escalating daily. Bob created this site for information exchange, how about keeping it that way and leave the personal insults and disingenuous apologies to political hacks. Enough, please. Rick Girard On Jan 16, 2008 9:01 AM, Mike wrote: > > Milt, > > You must live next door to the shop or married into the family. :) > > Mike > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of N395V > Sent: Wednesday, January 16, 2008 6:59 AM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Re: Blue Mountain EFIS > > > > > > Just Curious, how many successfull flight hours do you have behind > your BMA? > > > > > > > About 700hrs. > > > > > > What I think is funny, is that people who don?t have one want to > support it, or people who spent all the money they had are stuck with it > and are forced to love it. > > > > > > > Yeah, > > My first two units sucked so bad I felt compelled to buy 3 more guess > I'm just lucky that my 5 units are the only ones in the world that work > . > > -------- > Milt > 2003 F1 Rocket > 2006 Radial Rocket > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=158505#158505 > > > 10/2/2007 11:10 AM > > > 10/2/2007 11:10 AM > > ________________________________________________________________________________
Date: Jan 16, 2008
Rick, Go look up reading between the lines=85. The intended reader got it! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Richard Girard Sent: Wednesday, January 16, 2008 8:59 AM Subject: Re: AeroElectric-List: Re: Blue Mountain EFIS Guys, I don't own an EFIS of any kind. I have no personal interest in any of this except in the ad hominem attacks that are escalating daily. Bob created this site for information exchange, how about keeping it that way and leave the personal insults and disingenuous apologies to political hacks. Enough, please. Rick Girard On Jan 16, 2008 9:01 AM, Mike wrote: "mailto:mlas(at)cox.net" \nmlas(at)cox.net> Milt, You must live next door to the shop or married into the family. :) Mike -----Original Message----- From: HYPERLINK "mailto:owner-aeroelectric-list-server(at)matronics.com" \nowner-aeroelectric-list-server(at)matronics.com [mailto:HYPERLINK "mailto:owner-aeroelectric-list-server(at)matronics.com" \n owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of N395V Sent: Wednesday, January 16, 2008 6:59 AM \naeroelectric-list(at)matronics.com Subject: AeroElectric-List: Re: Blue Mountain EFIS > Just Curious, how many successfull flight hours do you have behind your BMA? > > About 700hrs. > > What I think is funny, is that people who don?t have one want to support it, or people who spent all the money they had are stuck with it and are forced to love it. > > Yeah, My first two units sucked so bad I felt compelled to buy 3 more guess I'm just lucky that my 5 units are the only ones in the world that work . -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" \nhttp://forums.matronics.com/viewtopic.php?p=158505#158505 HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" \n HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" \n HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" =========== HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" HYPERLINK "http://forums.matronics.com/viewtopic.php?p=158505#158505" "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Jan 16, 2008
Rick, The postings aren't necessarily insults and attacks; they are just raw data. We're all grown ups. It would be nice, but not necessary, that posting be routed through a "pleasantness filter", but I suspect everyone is able to do their own receipt inspection of the information and recalibrate it as necessary. Sugar coating is best left to cakes and donuts. I've seen postings, pro and con, on the BMA matter and take it all at face value as I'm sure others do. Bob prefers posting be tilted more toward facts and conclusions based on repeatable data. Unfortunately, in this matter, its virtually impossible to conduct objective testing that's useful for the potential buyer/user. In this case, we are stuck with reliance on anecdotal observations and subjective opinions. I personally don't put great weight in any one anecdotal observation, but as the observations, objective or subjective, continue to pile up on one side of the ledger, then at some point I decide that yes, that may be useful information. Even if some of the postings were quite blunt, even harsh, I don't perceive it as a coordinated attack against any individual, company or product. If there happens to be a large number of unhappy users, then that is the problem of the Seller and his product, not of the individuals who posted their personal experience, even if in colorful and direct language. So, the open exchanges of information is commission no great sin, but useful information has been exchanged that can be used as seen appropriate. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Richard Girard Sent: Wednesday, January 16, 2008 10:59 AM Subject: Re: AeroElectric-List: Re: Blue Mountain EFIS Guys, I don't own an EFIS of any kind. I have no personal interest in any of this except in the ad hominem attacks that are escalating daily. Bob created this site for information exchange, how about keeping it that way and leave the personal insults and disingenuous apologies to political hacks. Enough, please. Rick Girard On Jan 16, 2008 9:01 AM, Mike < mlas(at)cox.net> wrote: Milt, You must live next door to the shop or married into the family. :) Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto: owner-aeroelectric-list-server(at)matronics.com ] On Behalf Of N395V Sent: Wednesday, January 16, 2008 6:59 AM Subject: AeroElectric-List: Re: Blue Mountain EFIS < Bearcat(at)bearcataviation.com> > Just Curious, how many successfull flight hours do you have behind your BMA? > > About 700hrs. > > What I think is funny, is that people who don?t have one want to support it, or people who spent all the money they had are stuck with it and are forced to love it. > > Yeah, My first two units sucked so bad I felt compelled to buy 3 more guess I'm just lucky that my 5 units are the only ones in the world that work . -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158505#158505 <http://forums.matronics.com/viewtopic.php?p=158505#158505> ________________________________________________________________________________
Date: Jan 16, 2008
Couldn't agree more. I'm totally tired of the BMA bashing. Let's get back to the basics. On Jan 16, 2008, at 7:58 AM, Richard Girard wrote: > Guys, I don't own an EFIS of any kind. I have no personal interest > in any of this except in the ad hominem attacks that are escalating > daily. Bob created this site for information exchange, how about > keeping it that way and leave the personal insults and disingenuous > apologies to political hacks. Enough, please. > > Rick Girard ________________________________________________________________________________
Subject: Question about Annunciating Lights
Date: Jan 16, 2008
Found a nice example while browsing. Why build anything? Just install the lights in the panel and label to suit. http://www.advanced-flight-systems.com/Installations/RobbinsPanel.JPG -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Brett Ferrell Sent: Thursday, January 10, 2008 9:18 AM Subject: RE: AeroElectric-List: Question about Annunciating Lights --> I made my panel out of Honeywell microswitches. It's not really a cheap way, but the results are nice, and it's fairly straight-forward, with "dead face" (labels so you KNOW the lamp is out, because it cannot be read unless illuminated from behind). I also built a push-to-test circuit. http://www.velocityxl.com/Electrical.htm (just the pictures) http://www.velocityxl.com/annunciator.JPG http://www.velocityxl.com/press_to_test.JPG http://www.velocityxl.com/IMAGES2/GRT3.JPG I bought mine from these folks http://www.fmw411.com/ Brett Quoting Carl Morgan : > I took Mark's work as a basis, and this is what I ended up with.... > > Close up: http://www.rvproject.gen.nz/photos/2007-06/Web_Img_9760.jpg > > http://www.rvproject.gen.nz/dailylog/dailylog_2007-07-28.html the > final look, > > > http://www.rvproject.gen.nz/dailylog/dailylog_2007-06-18.html and > http://www.rvproject.gen.nz/dailylog/dailylog_2007-06-19.html for some > of the fabrication process. > > Just another possible source of ideas. > > Carl > > -- > Carl Morgan - ZK-VII - RV 7A - Inspection next Tue! > http://www.rvproject.gen.nz/ > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Fiveonepw(at)aol.com > Sent: 10 January 2008 18:14 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Question about Annunciating Lights > > > Here's another take on rollin' yer own: > > > http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5126 > > Click on fotos for bigger view and Next Entry>> for more info > (several > pages) including wiring diagram, part #s etc... > > From The PossumWorks in TN > Mark Phillips > > > ---------------------------------------------------------------------- > ------ > -- > Start the year off right. Easy ways to stay in shape in the new year. > > > 10:16 > ________________________________________________________________________________
Date: Jan 16, 2008
Subject: Re: Blue Mountain EFISBlue Mountain EFISBlue Mountain
EFIS As often happens during forum debates, we tend to veer from the original qu estion and digress into personalities. FWIW, I'm now wiring the panel in my -8A, and spent more time by far on the EFIS decision than any other compon ent over the past 3 years (hey, I may be old, but I'm awfully slow). My goi ng in PANEL requirements were an IFR capability (please do not start a deba te on whether RVs are really IFR airplanes - I have significant IFR experie nce and wanted my plane to have the capability if I wanted to ever exercise it). That implied an HSI and ILS capability, and the ability to tie to a G PS and SL30. Display could be a 106 or internal to the EFIS. Reliability ma tters. So does customer relations. Just like the basic safety rule of aviat ion: Listen to the experiences of others - you can't possibly live long eno ugh to experience them all yourself. Word of mouth reputation matters, but should be taken as a subjective assessment unless hard data is presented. C ost was a concern, but not the driver. Autopilot compatibility was also att ractive. I initially ranked BMA ahead of GRT, with Dynon third (because of lack of H IS stuff at the time). As I researched more, GRT became first choice. Then AFS came out with the 3500. After talking to them and learning more about t he company and the reputation of their other products, I settled on an AFS 3500 and a TruTrak ADI Pilot. No regrets - customer service from both compa nies has been outstanding, and the capabilities of the 3500 satisfy all my personal requirements at reasonable cost. Even though I am over a year from first flight, I have continued to acquire additional EFIS knowledge - and haven't found anything yet to imply I made an incorrect - or even marginal - decision. Rightly or wrongly, in the fast-moving, public world of experimental avioni cs, you're only as good as your last sortie - or customer experience. There was enough unanswered negative stuff about BMA to make me think "Why bothe r", when other companies offered similar or better capabilities at comparab le or affordably higher cost. As always, it gets back to personal requireme nts and personal hot buttons that need to be addressed in satisfying those requirements. There is no cook book. However, a "Do you guys have time to s hoot the breeze about EFIS systems?" call to customer service (with your ho mework already done) of each company will give you some pretty good indicat ors. And another FWIW - I also carefully researched engine choices, and in the e nd paid Bart & Sue at Aerosport over $28K for a new IO-360 - mainly because their approach to customer service resonated so well with me. Other compan ies would have also satisfied my requirements - perhaps even more cheaply - but Bart and Sue had an attitude and approach that worked for me. In this business you will almost never have the 100% solution - and many ti mes not even the 75% solution. Sometimes your ahead if you're only 51% sure . Just like Dirty Harry sez: "Do ya' feel lucky, punk? Well do ya?" ________________________________________________________________________________
Subject: EFIS screen brightness
Date: Jan 16, 2008
Does anybody know which is the brightness / resolution (in nits) of the AFS-3400 EFIS' displays ? Carlos ________________________________________________________________________________
Date: Jan 16, 2008
Subject: Re: AeroElectric-List Digest: 26 Msgs - 01/15/08
"Being a military guy has nothing to do with it unless you want to pay 85% slouches and 15% good guys to get the job done." Say what? I must have never been introduced to the 85% of Marines I served with who were "slouches"... Glad to discuss this with you personally some time, however... Lee... ________________________________________________________________________________
Date: Jan 16, 2008
Sorry to drift off topic, but chalk it up to Remote Hangar Power-Supply Project. I've got a couple solar (PV) panels, each rated 48 watt, 3 amp @ 16 volts, 18-19 volts open circuit. Problem is that I bought an inverter that has a 15.5 high-voltage cutoff, so no worky for 110a/c. My question(s): If I got a "Solar Charge Controller", designed to limit charge into batteries, could I use it to supply the inverter ?? Kinda, sorta . . . Solar panels have a significant source impedance. Hence the drop from 19 volts no load to 16 volts at a 3A load. DeltaV of 3 volts divided by DeltaI of 3A yields a source impedance on the order of 1 ohm. Two panels in parallel would drop this to 1/2 ohm for the array. 16 volts would smoke most 12/14v accessories and some accessories would draw less than 6A which boosts the voltage still more. The most "stable" application of solar power is to combine the array with a battery maintainer designed to integrate the array with a rechargeable battery. This allows you to store energy even if you're not using it for the moment (until battery is charged). It also allows you to tax the system with loads much larger than 6A albeit intermittently. And how about a 12-v. resistive load, or pump/fan motors, (no inverter) that would pull down the voltage at max draw ?? ... assuming the charge controller could handle the current. Any other ideas for regulating 16 v down to a usable 13-14 (for 6 A.) A Google search for "solar battery charger" yielded a bucket full of hits . . . a few are cited below. http://tinyurl.com/ybh9wz http://tinyurl.com/246w34 http://tinyurl.com/2c3orf Suggest you team the solar panels with a regulating charger, the largest battery you're willing to acquire and maintain. NOW you have an energy source that will run a pretty hefty inverter and permit you to run a variety of loads rain or shine. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Note #24 in appendix Z part number ?
Date: Jan 16, 2008
Hello List I am getting ready to order some parts for my OBAM aircraft electrical system and would like to verify I have found the correct Diode Bridge per note #24 in appendix Z. I found this at digi key Is it the correct part? http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=GBPC3502A-N D My next question is how big of a heat sink do I need for it if the device getting power from it draws about 6 amps? Thanks in advance Jeff. ________________________________________________________________________________
Date: Jan 16, 2008
Subject: Re: Note #24 in appendix Z part number ?
> >Hello List > >I am getting ready to order some parts for my OBAM aircraft electrical >system and would like to verify I have found the correct Diode Bridge per >note #24 in appendix Z. > >I found this at digi key >Is it the correct part? >http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=GBPC3502A-N >D > >My next question is how big of a heat sink do I need for it if the device >getting power from it draws about 6 amps? Mount it to any metal surface and it will be fine. Bob . . . ________________________________________________________________________________
Date: Jan 16, 2008
Rob at AFS should be able to answer that question. Just go to their website and ask. Scott R. Shook RV-7A (Building) N696JS (Reserved) -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Wednesday, 16 January, 2008 16:06 Subject: AeroElectric-List: EFIS screen brightness Does anybody know which is the brightness / resolution (in nits) of the AFS-3400 EFIS' displays ? Carlos ________________________________________________________________________________
Subject: RE: IFR GPS requirements
Date: Jan 17, 2008
Hi Bill et al- Re: >Hello Bill, Avoid that poor soul -- he has not been around long enough or >cared enough to learn that type certificated aircraft and amateur built >experimental aircraft are treated very differently in the FAA's paperwork >system. While I greatly appreciate and highly regard and respect the source of that comment, I couldn't disagree more. If this inspector has run 50 unnecessary 337's through the system, he has cost a lot of people a lot of money, spread misinformation across the system, and will no doubt cause other improperly educated or motivated inspectors to take the 'conservative' (ignorant) route at our collective expense. In other words, there has been a gross misuse of governmental power. These kinds of topics have gone to DC and back via OSH, and we have the tools to correct the problem you are facing. My personal experience with an amateur built rule hose-up was to be very (politely) clear with the person involved about the nature and basis for our disconnect, and then call OSH with the details. Within 24 hours they had achieved understanding with the head of the directorate involved, and within another 24 the fed involved had been re-educated. That ended the problem for me, and, presumably, everyone who came along after. Also, the feds now have a program to handle customer service issues in house. As I understand it, it's the equivalent of 'let me speak to your supervisor', although I don't recall the precise terminology. Mike, can you fill us in? While I don't advocate getting into hostile conflicts with The Man, I strongly urge you (and anyone else having bogus reg interpretation issues) to fight the good fight with the resources we have developed and paid for through our EAA dues and those gate fees at OSH we are all unhappy about. Heck, Brian got a law in Jacksonville repealed with a little help from his friends. What's one confused inspector? glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jan 17, 2008
Bob, Thanks for the quick reply about the heat sink, so that does mean that I found the correct part for this function at digikey ? Info shows: Technical/Catalog Information GBPC3502A-ND <http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=698&M=GBPC3502A> Standard Package <http://dkc1.digikey.com/US/EN/help/help14.html> 100 Category Discrete Semiconductor Products Family Bridge Rectifiers Vendor Vishay IR <http://www.digikey.com/scripts/Redirect/Redirect.dll?R=9&V=698> Diode/Rectifier Type Single Phase Voltage - Rated 200V Current Rating 35A Package / Case GBPC-A Packaging Bulk Speed Standard Recovery > 200mA Reverse Recovery Time (trr) - Lead Free Status Lead free RoHS Status RoHS compliant Other Names *GBPC3502A GBPC3502A GBPC3502A-ND -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, January 16, 2008 11:39 PM Subject: Re: AeroElectric-List: Note #24 in appendix Z part number ? > >Hello List > >I am getting ready to order some parts for my OBAM aircraft electrical >system and would like to verify I have found the correct Diode Bridge per >note #24 in appendix Z. > >I found this at digi key >Is it the correct part? >http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=GBPC3502A- N >D > >My next question is how big of a heat sink do I need for it if the device >getting power from it draws about 6 amps? Mount it to any metal surface and it will be fine. Bob . . . ________________________________________________________________________________
Date: Jan 17, 2008
Subject: Controlling defrost fans
I have a pair of 1.5"x1.5" fans (Radio Shack 273-240) mounted forward of the instrument panel on my 6A slider - think about the intersection of the support bulkhead parallel and forward of the instrument panel and the ribs that point aft that support the top of the instrument panel in three places. I am wondering if a straight on-off switch is sufficient or should I put in a rheostat to control the fan speed? KISS would dictate that a simple on-off switch would work - but has anyone out there wished for a half-speed? Here on the DelMarVa peninsula - I'm certain that I'll need it on a regular basis Thanks, Ralph ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jan 17, 2008
I doubt it...Just give it full blast to de-mist then shut them off...Once your flying I doubt you'll ever turn 'em back on. I wish I had installed a fan now too on my tip up in Western oregon Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, January 17, 2008 6:36 AM Subject: AeroElectric-List: Controlling defrost fans --> I have a pair of 1.5"x1.5" fans (Radio Shack 273-240) mounted forward of the instrument panel on my 6A slider - think about the intersection of the support bulkhead parallel and forward of the instrument panel and the ribs that point aft that support the top of the instrument panel in three places. I am wondering if a straight on-off switch is sufficient or should I put in a rheostat to control the fan speed? KISS would dictate that a simple on-off switch would work - but has anyone out there wished for a half-speed? Here on the DelMarVa peninsula - I'm certain that I'll need it on a regular basis Thanks, Ralph ________________________________________________________________________________
Subject: Re: Controlling defrost fans
Date: Jan 17, 2008
I just put a 5 ohm resistor across a SPDT switch to give a? high-off-low option. Works great in the garage, but not flying yet. Jim Timoney -----Original Message----- From: Hinde, Frank George (Corvallis) <frank.hinde(at)hp.com> Sent: Thu, 17 Jan 2008 10:15 am Subject: RE: AeroElectric-List: Controlling defrost fans I doubt it...Just give it full blast to de-mist then shut them off...Once your flying I doubt you'll ever turn 'em back on. I wish I had installed a fan now too on my tip up in Western oregon Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ralph E. Capen Sent: Thursday, January 17, 2008 6:36 AM Subject: AeroElectric-List: Controlling defrost fans --> I have a pair of 1.5"x1.5" fans (Radio Shack 273-240) mounted forward of the instrument panel on my 6A slider - think about the intersection of the support bulkhead parallel and forward of the instrument panel and the ribs that point aft that support the top of the instrument panel in three places. I am wondering if a straight on-off switch is sufficient or should I put in a rheostat to control the fan speed? KISS would dictate that a simple on-off switch would work - but has anyone out there wished for a half-speed? Here on the DelMarVa peninsula - I'm certain that I'll need it on a regular basis Thanks, Ralph ________________________________________________________________________ ________________________________________________________________________________
Date: Jan 17, 2008
> Suggest you team the solar panels with a regulating charger, the largest battery Yep, those are the charge controllers I'd looked at, and I understand the role of the battery. I had tested a direct-driven 12v. boat bilge pump (1.5A) in a water-garden-fish-pond, but found the 16-18v roasted the pump (it did work for a whole summer). Other thought was for an attic exhaust fan-- but without controller, will have same problem. Will head down to local H.F. Chinese outlet store, get a controller, and go from there. Thanks, Bob, and others, for suggestions. --RJV Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158804#158804 ________________________________________________________________________________
Date: Jan 17, 2008
1/17/2008 Hello Rick, Thanks for your input and interest in this subject. You wrote: 1) "It depends on what the inspector wrote into you ops limits." The FAA Inspector or DAR is directed by FAA Order 8130.2_ (edition F, with change 3 incorporated is the current version) what to write into the Operating Limitations when issuing the Special Airworthiness Certificate for an amateur built experimental aircraft. His prerogative to ad lib in this specific area (IFR GPS requirements) is extremely limited to non existent. 2) "If he referenced 91.205 as a requirement for IFR flight, then you must get the system tested by an FAA certified shop." and "If not you can proceed as you wish." These two statements are misleading / incorrect. 2A) First off, There is no "if" about it. He most certainly will reference 91.205 as a requirement for IFR flight. He will do this by incorporating this statement into the Operating Limitations: "After completion of phase 1 testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated VFR day only." See paragraph 1 above. 2B) Second, Other than the normal regulatory requirements for periodic inspections of the altitude encoder, the altimeter, and the transponder (these inspection requirements also apply to type certificated aircraft) there is no requirement to "get the system tested by an FAA certified shop." 2C) Third, It is not clear what you mean when you write the word "system". I have prepared a table that serves as a quick reference on this subject: MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT EXPERIMENTAL AIRCRAFT. I will email a copy of this table to any reader requesting it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ------------------------------------------------------- From: "Richard Girard" <jindoguy(at)gmail.com> Subject: Re: AeroElectric-List: IFR GPS requirements Peter, et al, It depends on what the inspector wrote into you ops limits. If he referenced 91.205 as a requirement for IFR flight, then you must get the system tested by an FAA certified shop. If not you can proceed as you wish. In the Ops Limits I received yesterday, Item 11: "After completion of phase 1 testing, unless appropriately equipped for night and/or instrument flight in accordance with 91.205, this aircraft is to be operated VFR day only." Rick Girard ________________________________________________________________________________
Subject: Z-11 Main Battery Bus
Date: Jan 17, 2008
Bob: On diagrams Z-11 and Z-13 I notice that you have the Hobbs meter powered off the main battery bus which is on all the time. Shouldn't the Hobbs come off the main power bus instead? -------- Al Rice Skybolt 260 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158861#158861 ________________________________________________________________________________
Date: Jan 17, 2008
Hi Bob, Could you send me a copy of the list? I am setting up for lite IFR but having the right stuff is important also. Jim Nelson N15JN RV9-A ________________________________________________________________________________
Date: Jan 17, 2008
Bob, I could sure use a copy of your table. Thank You, Bryan > > I have prepared a table that serves as a quick reference on this subject: > > MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT > EXPERIMENTAL AIRCRAFT. > > I will email a copy of this table to any reader requesting it. > > 'OC' Says: "The best investment we can make is the effort to gather and > understand knowledge." > ________________________________________________________________________________
Date: Jan 17, 2008
Good Afternoon OC, I would appreciate a copy of your listing! _BobsV35B(at)aol.com_ (mailto:BobsV35B(at)aol.com) Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/17/2008 1:07:41 P.M. Central Standard Time, bakerocb(at)cox.net writes: MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT EXPERIMENTAL AIRCRAFT. I will email a copy of this table to any reader requesting it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
From: "Henry Trzeciakowski" <hammer408(at)comcast.net>
Date: Jan 17, 2008
Good evening OC: I also would appreciate a copy. Thanks hammer408(at)comcast.net Henry ----- Original Message ----- From: BobsV35B(at)aol.com To: aeroelectric-list(at)matronics.com Sent: Thursday, January 17, 2008 3:11 PM Subject: Re: AeroElectric-List: IFR GPS requirements Good Afternoon OC, I would appreciate a copy of your listing! BobsV35B(at)aol.com Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/17/2008 1:07:41 P.M. Central Standard Time, bakerocb(at)cox.net writes: MINIMUM INSTRUMENT AND EQUIPMENT REQUIREMENTS FOR POWERED AMATEUR BUILT EXPERIMENTAL AIRCRAFT. I will email a copy of this table to any reader requesting it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." ------------------------------------------------------------------------- ----- Start the year off right. Easy ways to stay in shape in the new year. ________________________________________________________________________________
Date: Jan 17, 2008
Subject: Re: Z-11 Main Battery Bus
> >Bob: >On diagrams Z-11 and Z-13 I notice that you have the Hobbs meter powered >off the main battery bus which is on all the time. Shouldn't the Hobbs >come off the main power bus instead? A Hobbs may be POWERED by the battery bus (as it is in virtually ALL Cessna single engine aircraft) it is CONTROLLED by an oil pressure switch so that it records engine run time, not bus hot time. See: http://www.aeroelectric.com/PPS/Engine/Oil_Pressure/Oil_P_Warn.pdf Bob . . . >-------- >Al Rice >Skybolt 260 > > >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=158861#158861 > > >-- >9:01 AM > > >incoming mail is certified Virus Free. >Checked by AVG. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 17, 2008
Good Evening Al Rice, For What It Is Worth! It is done that way to make it more difficult for the thieves who would turn the Master Switch off in an effort to cheat the FBO! Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/17/2008 9:14:15 P.M. Central Standard Time, nuckolls.bob(at)cox.net writes: A Hobbs may be POWERED by the battery bus (as it is in virtually ALL Cessna single engine aircraft) it is CONTROLLED by an oil pressure switch so that it records engine run time, not bus hot time. See: http://www.aeroelectric.com/PPS/Engine/Oil_Pressure/Oil_P_Warn.pdf Bob . . . **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 17, 2008
Keeps the FBO's renting out airplanes in business... :) Matt- > > > >> >>Bob: >>On diagrams Z-11 and Z-13 I notice that you have the Hobbs meter powered >>off the main battery bus which is on all the time. Shouldn't the Hobbs >>come off the main power bus instead? > > A Hobbs may be POWERED by the battery bus (as it is > in virtually ALL Cessna single engine aircraft) it is > CONTROLLED by an oil pressure switch so that it records > engine run time, not bus hot time. > > See: > > http://www.aeroelectric.com/PPS/Engine/Oil_Pressure/Oil_P_Warn.pdf > > > Bob . . . > > >>-------- >>Al Rice >>Skybolt 260 >> >> >> >> >>Read this topic online here: >> >>http://forums.matronics.com/viewtopic.php?p=158861#158861 >> >> >> >> >> >> >> >> >> >> >> >> >>-- >>9:01 AM >> >> >>incoming mail is certified Virus Free. >>Checked by AVG. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > ________________________________________________________________________________
Date: Jan 17, 2008
I didn't know that. Thanks for the clarification. -------- Al Rice Skybolt 260 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=158963#158963 ________________________________________________________________________________
Date: Jan 18, 2008
1/18/2008 Hello Glen, You are absolutely correct and I apologize for that moment of weakness when I wrote to just avoid the ignorant bureaucrat. If we don't (politely) confront these people who are misusing their position, either out of ignorance or ego, we will suffer further abuses down the line. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." -------------------------------------------------- From: "glen matejcek" <aerobubba(at)earthlink.net> Subject: AeroElectric-List: RE: IFR GPS requirements Hi Bill et al- Re: >Hello Bill, Avoid that poor soul -- he has not been around long enough or >cared enough to learn that type certificated aircraft and amateur built >experimental aircraft are treated very differently in the FAA's paperwork >system. While I greatly appreciate and highly regard and respect the source of that comment, I couldn't disagree more. If this inspector has run 50 unnecessary 337's through the system, he has cost a lot of people a lot of money, spread misinformation across the system, and will no doubt cause other improperly educated or motivated inspectors to take the 'conservative' (ignorant) route at our collective expense. In other words, there has been a gross misuse of governmental power. These kinds of topics have gone to DC and back via OSH, and we have the tools to correct the problem you are facing. My personal experience with an amateur built rule hose-up was to be very (politely) clear with the person involved about the nature and basis for our disconnect, and then call OSH with the details. Within 24 hours they had achieved understanding with the head of the directorate involved, and within another 24 the fed involved had been re-educated. That ended the problem for me, and, presumably, everyone who came along after. Also, the feds now have a program to handle customer service issues in house. As I understand it, it's the equivalent of 'let me speak to your supervisor', although I don't recall the precise terminology. Mike, can you fill us in? While I don't advocate getting into hostile conflicts with The Man, I strongly urge you (and anyone else having bogus reg interpretation issues) to fight the good fight with the resources we have developed and paid for through our EAA dues and those gate fees at OSH we are all unhappy about. Heck, Brian got a law in Jacksonville repealed with a little help from his friends. What's one confused inspector? glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Subject: Changing Prop & FSDO
Date: Jan 18, 2008
1/18/2008 Hello Ron, You wrote: 1) "Another thing that the FSDO told me, even when an experimental aircraft is sold and there is a new owner, along with the FAA registration records update, the new owner needs to get a new Airworthiness Certificate with the himself as the owner (the original builder info stays the same). He mentioned that very few owners of experimental aircraft that they bought from pervious owners know this,......" I would venture that very few subsequent owners of amateur built experimental aircraft do not know of this requirement because it is not true. 2) ",,,,,,,,,, plus the FAA has this requirement too deeply hidden in the regulations." No matter how deeply hidden in the regulations this requirement may be it has to be written down. I would dearly love for you to contact this gent and find out just exactly where it is written so that we can read it for ourselves. The FAA is not in the business of having secret regulations. Many thanks. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." -------------------------------------------------- ----- Original Message ----- From: "Ronko" <ronko1(at)peoplepc.com> Sent: Thursday, January 17, 2008 11:52 AM Subject: Re: Changing Prop & FSDO Thanks for your response. I called the local FSDO in West Chicago, Illinois, and they gave me the same instructions that you outlined. Interesting set of responses from the group. Another thing that the FSDO told me, even when an experimental aircraft is sold and there is a new owner, along with the FAA registration records update, the new owner needs to get a new Airworthiness Certificate with the himself as the owner (the original builder info stays the same). He mentioned that very few owners of experimental aircraft that they bought from pervious owners know this, plus the FAA has this requirement too deeply hidden in the regulations. The guy that I talked to at the FSDO told me my situation was not a problem. With the new prop process, I will get both requirements met. Thanks again for your feedback. Best regards, Ron ________________________________________________________________________________
Date: Jan 18, 2008
Hi O.C.- Thanks for the feedback / response, O.C. It's always a nuisance to have to go through this with bureaucrats, but we are the front line when it comes to protecting our rights and interests. Also, sorry about the spamblocker. It is very effective and protective. I've told it to allow anything you should choose to send in the future, but it has a bit of a mind of it's own. Should you send me something and get one of those 'allowed sender requests' again, just ignore it. I'll still get your note, albeit with a bit of a delay. Best regards- glen matejcek aerobubba(at)earthlink.net > [Original Message] > From: <bakerocb(at)cox.net> > To: ; ; > Date: 1/18/2008 9:24:31 AM > Subject: IFR GPS requirements > > 1/18/2008 > > Hello Glen, You are absolutely correct and I apologize for that moment of > weakness when I wrote to just avoid the ignorant bureaucrat. > > If we don't (politely) confront these people who are misusing their > position, either out of ignorance or ego, we will suffer further abuses down > the line. > > 'OC' Says: "The best investment we can make is the effort to gather and > understand knowledge." > > -------------------------------------------------- > > From: "glen matejcek" <aerobubba(at)earthlink.net> > Subject: AeroElectric-List: RE: IFR GPS requirements > > > Hi Bill et al- > > Re: >Hello Bill, Avoid that poor soul -- he has not been around long > enough or > >cared enough to learn that type certificated aircraft and amateur built > >experimental aircraft are treated very differently in the FAA's paperwork > >system. > > While I greatly appreciate and highly regard and respect the source of that > comment, I couldn't disagree more. If this inspector has run 50 > unnecessary 337's through the system, he has cost a lot of people a lot of > money, spread misinformation across the system, and will no doubt cause > other improperly educated or motivated inspectors to take the > 'conservative' (ignorant) route at our collective expense. In other words, > there has been a gross misuse of governmental power. These kinds of topics > have gone to DC and back via OSH, and we have the tools to correct the > problem you are facing. > > My personal experience with an amateur built rule hose-up was to be very > (politely) clear with the person involved about the nature and basis for > our disconnect, and then call OSH with the details. Within 24 hours they > had achieved understanding with the head of the directorate involved, and > within another 24 the fed involved had been re-educated. That ended the > problem for me, and, presumably, everyone who came along after. > > Also, the feds now have a program to handle customer service issues in > house. As I understand it, it's the equivalent of 'let me speak to your > supervisor', although I don't recall the precise terminology. Mike, can > you fill us in? > > While I don't advocate getting into hostile conflicts with The Man, I > strongly urge you (and anyone else having bogus reg interpretation issues) > to fight the good fight with the resources we have developed and paid for > through our EAA dues and those gate fees at OSH we are all unhappy about. > Heck, Brian got a law in Jacksonville repealed with a little help from his > friends. What's one confused inspector? > > glen matejcek > aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Jan 18, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: Alternator / Charging issue
> > > Steve, I'm going on vacation tomorrow morning early. Didn't see a response as to what kind of alternator we're trying to troubleshoot. Bob . . . >>A while back my alternator decided to start cycling on and off every now >>and again, mostly when under load. It will never do it during a day >>flight, and only during the day when running strobes. I can induce it at >>night fairly easily sometimes with the navs, fuel pump, landing light, >>and panel lights (no strobes needed..they seem able to induce the problem >>by themselves). I was returning from Miss. a few nights ago and it >>decided to do this. I shut down the strobes and everything was fine (as >>usual). I turned the strobes back on and the last 30 min or so of the >>flight was uneventful. >> >>I installed a new B&C battery yesterday and the problem occurred again >>yesterday evening 1 time near the beginning of the flight, and more so on >>the ground after I landed and had the engine at idle power. I stayed in >>the pattern since I had a "known" electrical issue. >> >>Here are few things I may have forgotten to mention, and I can't be sure >>if this could be a cause of my problem. >> >> >>2) I notice both my EI voltmeter as well as the Dynon (backup to my gyro >>;) ) are reporting about 13.5V when in flight. I would assume this >>should be around 14.5 or so. I think before this problem it did. Funny >>the little things you start to notice when you actually have a problem. >> >>3) The main problem is that if under load, the system will "shut down" >>the charging system intermittently and then come back online. Sometimes >>in a rapid (5 secs or so) succession or sometimes in more erratic >>unpredictable intervals. Like the flight back the other night, it acted >>up then stayed online for the remainder of the flight. I'll see the >>voltage annunciator come on and the voltage drop to 11.8 or 12...then it >>will go back up to 13.5. It may stay for a while...the remainder of the >>flight...or maybe 10 secs. It's crazy. >> >> I thought I had the alternator tested at one time and was told >> it was fine. >> >>I also just replaced my main solenoid (it was going bad..wouldn't connect >>when I turned the master on). That's fine now, but that didn't help the >>problem either. >> >>This problem is driving me crazy. Any and all input would be appreciated. >> >>I'm almost convinced I'm never going to find the root if this >>thing. Thanks again. > > > I've never encountered a system problem that was not > fixable. > > You don't say what kind of alternator. External or internally > regulated? > > Bob . . . > > >-- >269.19.2/1224 - Release Date: 1/14/2008 5:39 PM > > >incoming mail is certified Virus Free. >Checked by AVG. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 18, 2008
Subject: Re: AeroElectric-List Digest: 29 Msgs - 01/16/08
Hernador: If no insult was intended, then none taken. Semper Fi ________________________________________________________________________________
Date: Jan 18, 2008
Subject: Of Line for a week
Dr. Dee and I are headed southeast tomorrow. A friend of many years and a co-worker at Beech's Missiles Division bought a condo in P.R. about 25 years ago when he was having to spend many weeks working out of Roosevelt Roads naval base to support target launches. Nowadays, he and his wife spend three months in P.R. every winter. They have proven generous and graceful hosts to a number of the Missiles families. This will be our second trip to take in the sights and snorkel in some pretty amazing waters. We'll be back on Sunday, Jan 27. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Back to the scrap bins
Date: Jan 20, 2008
Does anyone have some single conductor shielded wire (S906-1-22 or equiv) in their scrap bins? I need a one foot piece and a three foot piece. Thanks in advance, Ralph ________________________________________________________________________________
Date: Jan 20, 2008
Subject: Infinity Stick connector?
I chose to install my Infinity sticks on my Cozy so that they were not hard-wired into the plane, but "plugged into" the plane via 24-pin Molex connectors through the instrument panel bulkhead. That way, if the sticks ever needed servicing, they can be completely removed from the plane by detaching the plug. I should have kept it simple - I have discovered intermittent connections, which I've narrowed down to the Molex connectors. By joggling them about I can make or break circuits. It's time to dump these sloppy plastic connectors and go with something more robust. I've searched Digikey's catalogue but they offer such a dizzying array of "through bulkhead" circular connectors of 17+ wire cables, I'm confused about what to select. Without eyeballing each one I'm sure to order something that won't work. I need a twist-on or bayonet M-to-F connector, through-bulkhead, 17+ pins, solder or crimp, large enough to accept the ~1/2" diameter blue cable that come with Infinity sticks. Could anyone please propose a model number/type of connector that will satisfy this need? Would D-sub connectors be able to handle the high operating currents that the pitch trim and speed brake motors draw? Many thanks Neil ________________________________________________________________________________
Date: Jan 20, 2008
Subject: Re: Back to the scrap bins
If that's just single conductor shielded, send me your address. Ron Q. At 18:26 1/20/2008, you wrote: > > >Does anyone have some single conductor shielded wire (S906-1-22 or >equiv) in their scrap bins? > >I need a one foot piece and a three foot piece. > >Thanks in advance, >Ralph ________________________________________________________________________________
Date: Jan 20, 2008
Subject: Re: Infinity Stick connector?
At 18:56 1/20/2008, you wrote: >I need a twist-on or bayonet M-to-F connector, through-bulkhead, 17+ >pins, solder or crimp, large enough to accept the ~1/2" diameter >blue cable that come with Infinity sticks. Could anyone please >propose a model number/type of connector that will satisfy this need? Try the AMP 19 position CPC series Ron Q. ________________________________________________________________________________
Date: Jan 21, 2008
Ron, Exactly what I need. Here's the snail directions..... Ralph Capen 27215 Patriot Dr Salisbury, MD 21801 Thanks, Ralph ----- Original Message ----- From: "Ron Quillin" <rjquillin(at)gmail.com> Sent: Sunday, January 20, 2008 11:04 PM Subject: Re: AeroElectric-List: Back to the scrap bins > > If that's just single conductor shielded, send me your address. > > Ron Q. > > At 18:26 1/20/2008, you wrote: >> >> >>Does anyone have some single conductor shielded wire (S906-1-22 or equiv) >>in their scrap bins? >> >>I need a one foot piece and a three foot piece. >> >>Thanks in advance, >>Ralph > > > ________________________________________________________________________________
Date: Jan 22, 2008
Take a look at the wire gauge in the Infifity. How high do you think the current can be? Almost any airworthy connector can take it. I completely agree with you about the Molex connectors. They don't seem to wipe well and the crimps from Radio Shack don't hold the wire reliably despite using my ProCrimp tool on them. At the very least solder them after crimping. Personally, I removed all of the Molex (0.6 and 0.9 sizes) before 200hr on my airframe. Cheers, -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159761#159761 ________________________________________________________________________________
Date: Jan 22, 2008
Hi All, This thread about BMA has made for interesting reading over the past few days. I've enjoyed it and feel modestly motivated to weigh in. I am a BMA customer, in fact, one of the first E/1 black plastic boxes came to me. Why did I choose it? Features for price, an analysis that, in my eyes is as true today as it was 6 years ago. I upgraded to the gold box when it was available, and just recently replaced it with a Gen4 E/2. Yes, I paid the freight and kept going with BMA. The original up to the Gen3 models got a bad rep for what I consider a poor reason. The original schema was completely flexible in its input configuration. That meant for people like me with a rotax, could use the probes that came with the engine, any probes would work. They just needed to be calibrated, a concept it turns out in practice was foreign to many builders, "system integrators (I think panel builders is a far more accurate description BTW)", and especially non-building owners of experimental aircraft. It turns out, most of the general aviation never calibrates anything except the mandated encoder. This is really sloppy practice for non-mated sensor / indicators, especially when they are non mil or medical grade. My little experience informs me that you cant expect better than 10%, maybe 20% accuracy in an automotive sensor unless you calibrate it to the indicator. How many people calibrate their oil temp and pressure probes on their RV? Not many. Does the 10% really matter, not really in most applications. But the BMA required calibration. The BMA also had its ADCs outside the engine compartment and the repeated warnings about low resistance gounds to the battery and engine block were apparently inadequate for many people. Digital avionics and low level voltage signals just require more care in grounding and layout than older analog systems, especially in composite airframes (like mine). I will certainly grant you that the manuals are a bit sparse, but then I always found that the telephone worked for me. For what Greg has told me, most problematic installations eventually work once external wiring errors are caught and corrected. The BMA guys sought to simplify installation wiring by mandating a fixed set of sensors, none of which are unipolar and return back through the engine block. Wiring is now much simpler as I can attest in my own install last month. Calibration is no longer needed. I think that BMA will be out with a skin for the Rotax engines soon so I can integrate the VDO sensors built in to the engine. The stuff works and I believe it provides the most advanced EFIS functions for the price. It is also among the simplest to use in flight. So there have been some problems with the company. I see these kinds of issues in IT all the time. Greg chose the brand-new at the time SISC CPU chip for Gen 1-2. Many thought SISC would win out the future of computing over CISC chips like the Pentium. It was faster and cheaper right up until SISC guys went out of business. No more parts. No evolution of SISC. Technology moves fast, airplane building slow. I bought early, so do most. Some get more burned than others. Anyone want a Mode S transponder? ANyone want a 430, I heard the WAAS upgrade will be simple and very cheap! Most of Gen3 features worked out the door, but some did not. Some worked for some owners and not for others. More strenuous beta testing might help. Again not very different for many vendors from airframe kits to headsets. Ever hear of ADs? I don't work for Greg, et al, I'm just a customer who has appreciated life on the bleeding edge with my experimental aircraft. You might even find me at the BMA booth at SnF talking about my experience in using the EFIS for nearly 4 years. I am always delighted to talk to fellow listers ;-) Cheers -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159780#159780 ________________________________________________________________________________
Date: Jan 22, 2008
If one wants quality connectors, take a look a Deutsch. They're distributed by Ladd Industries. LADD Industries- Deutsch IPD Electrical Connectors Used them on a Velocity. Four years and five hindred hours later not a peep from the connectors. These are high end products and are not cheap.. However, neither is building an airplane. Peter ----- Original Message ----- From: "rampil" <ira.rampil(at)gmail.com> Sent: Tuesday, January 22, 2008 11:28 AM Subject: AeroElectric-List: Re: Infinity Stick connector? > > Take a look at the wire gauge in the Infifity. How high do you think the > current can be? > Almost any airworthy connector can take it. > > I completely agree with you about the Molex connectors. > They don't seem to wipe well and the crimps from Radio Shack don't > hold the wire reliably despite using my ProCrimp tool on them. > > At the very least solder them after crimping. > > Personally, I removed all of the Molex (0.6 and 0.9 sizes) before 200hr > on my airframe. > > Cheers, > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=159761#159761 > > > ________________________________________________________________________________
Date: Jan 22, 2008
Peter Laurence wrote: > > > If one wants quality connectors, take a look a Deutsch. They're > distributed by Ladd Industries. LADD Industries- Deutsch IPD > Electrical Connectors > Used them on a Velocity. Four years and five hindred hours later not a > peep from the connectors. These are high end products and are not cheap.. > However, neither is building an airplane. > ; however, neither is building an *expensive* airplane. There, I fixed that for you. Truth be told, I'll end up spending much less over 6 years of building than most guys spend on golfing, or what my brother spends on smoking. Building airplanes gets expensive in the same way they get heavy. Adding one more support. Beefing up a connector just a bit. Using a material that is just a bit stronger. High end connectors might be needed, if you're planning a trip into space or you expect the connector to hold the wing on. Probably not even then. Makes more economic sense to use decent hardware, then support and protect it properly. The need for high-end parts evaporates. I talk to a lot of fellows that are immediately resistant to the idea of building an airplane, because they assume that it is prohibitively expensive. We do our community a disservice if we perpetuate the myth. Building an airplane is only expensive if we choose for it to be so. ________________________________________________________________________________
Subject: MagnaFlite MZ-6222 starter
Date: Jan 22, 2008
A (yellow tagged) MZ-6222 lightweight MagnaFlite starter came with my rebuilt O-540 engine. Does anyone know of a source to estimate real world current draw at starter engagement so as to properly size the wire? I'm pretty sure #2 would be safe, but can it be quantified a bit better than "hundreds of amps"? The unit looks like it's in pretty good shape (teeth are not worn at least). Is there any way to test the state of internal electrical stuff besides disassembly? Thanks in advance for replies. Regards, Jay RV-10 Builder Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159889#159889 ________________________________________________________________________________
Date: Jan 23, 2008
Ira, Nice response. And, in my opinion, accurate. Stan Sutterfield Hi All, This thread about BMA has made for interesting reading over the past few days. I've enjoyed it and feel modestly motivated to weigh in. I am a BMA customer, in fact, one of the first E/1 black plastic boxes came to me. Why did I choose it? Features for price, an analysis that, in my eyes is as true today as it was 6 years ago. I upgraded to the gold box when it was available, and just recently replaced it with a Gen4 E/2. Yes, I paid the freight and kept going with BMA. The original up to the Gen3 models got a bad rep for what I consider a poor reason. The original schema was completely flexible in its input configuration. That meant for people like me with a rotax, could use the probes that came with the engine, any probes would work. They just needed to be calibrated, a concept it turns out in practice was foreign to many builders, "system integrators (I think panel builders is a far more accurate description BTW)", and especially non-building owners of experimental aircraft. It turns out, most of the general aviation never calibrates anything except the mandated encoder. This is really sloppy practice for non-mated sensor / indicators, especially when they are non mil or medical grade. My little experience informs me that you cant expect better than 10%, maybe 20% accuracy in an automotive sensor unless you calibrate it to the indicator. How many people calibrate their oil temp and pressure probes on their RV? Not many. Does the 10% really matter, not really in most applications. But the BMA required calibration. The BMA also had its ADCs outside the engine compartment and the repeated warnings about low resistance gounds to the battery and engine block were apparently inadequate for many people. Digital avionics and low level voltage signals just require more care in grounding and layout than older analog systems, especially in composite airframes (like mine). I will certainly grant you that the manuals are a bit sparse, but then I always found that the telephone worked for me. For what Greg has told me, most problematic installations eventually work once external wiring errors are caught and corrected. The BMA guys sought to simplify installation wiring by mandating a fixed set of sensors, none of which are unipolar and return back through the engine block. Wiring is now much simpler as I can attest in my own install last month. Calibration is no longer needed. I think that BMA will be out with a skin for the Rotax engines soon so I can integrate the VDO sensors built in to the engine. The stuff works and I believe it provides the most advanced EFIS functions for the price. It is also among the simplest to use in flight. So there have been some problems with the company. I see these kinds of issues in IT all the time. Greg chose the brand-new at the time SISC CPU chip for Gen 1-2. Many thought SISC would win out the future of computing over CISC chips like the Pentium. It was faster and cheaper right up until SISC guys went out of business. No more parts. No evolution of SISC. Technology moves fast, airplane building slow. I bought early, so do most. Some get more burned than others. Anyone want a Mode S transponder? ANyone want a 430, I heard the WAAS upgrade will be simple and very cheap! Most of Gen3 features worked out the door, but some did not. Some worked for some owners and not for others. More strenuous beta testing might help. Again not very different for many vendors from airframe kits to headsets. Ever hear of ADs? I don't work for Greg, et al, I'm just a customer who has appreciated life on the bleeding edge with my experimental aircraft. You might even find me at the BMA booth at SnF talking about my experience in using the EFIS for nearly 4 years. I am always delighted to talk to fellow listers ;-) Cheers -------- Ira N224XS **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 23, 2008
Subject: Re: LED Lighting
Dan, As Bevan mentioned, aeroleds.com is manufacturing two LED based landing/taxi/recognition lights. I don't know if they perform well as I haven't seen them in person yet. I was on the verge of ordering a pair when I discovered they have a 10% restocking fee. That, in my opinion, is too high, so I didn't order them. I would like to try them out - and if suitable I would keep them. I'm experimenting with 1W LEDs with optics and it appears you can produce enough illumination with multiple LEDs to at least make an acceptable taxi/recognition light. I'm not yet convinced they will suffice for a landing light. I'm also experimenting with MR-16 lights, but they get very hot and would require cooling to be mounted in an enclosed wingtip. I intend to use HIDs for the landing lights and perhaps the Aerosun Lite for the taxi/recognition light. Stan Sutterfield _www.rv-8a.net_ (http://www.rv-8a.net) Has anyone thought much of making LED landing/taxi lights? Just something that might be fun to mess around with. **************Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Date: Jan 23, 2008
Sorry for the confusion, After medical school, RISC became SISC for me ;-) -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159969#159969 ________________________________________________________________________________
From: "CharlieTango" <ed.cesnalis(at)mammothlakesinsulation.com>
Date: Jan 23, 2008
i have 300 hours of flying with a BMA EFIS. first i flew with a gen 4 EFIS Lite Plus, it was the largest unit offered that fit my panel. i fly mostly in the high sierra nevada with terrain up to 14,000'+ all around while limited to 10,000' ( sport pilot limitation ) the bma unit with the synthetic vision was the best choice for me. the vertical and horizontal terrain views are very useful when flying below the surronding terrain. on a flight last year i went imc due to shifting smoke from southern california fires, turning back didn't help. i was without visibility for 40 minutes and was perfectly comfortable with the situational awareness provided by the bma. since then i upgraded to a larger unit, the 9" EFIS / two. i can't imagine ever flying without. the company is matured and they have gone the extra mile in providing service. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159991#159991 ________________________________________________________________________________
Subject: Mode S & 430 - Was Blue Mountain EFIS
Date: Jan 23, 2008
Hey Ira, Interesting thoughts. If you need to sell a Mode S txpdr or non WAAS 430 you could always send them to Europe. No WAAS and we will all have to have Mode S very soon. Pete -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rampil Sent: 22 January 2008 17:27 Subject: AeroElectric-List: Re: Blue Mountain EFIS Hi All, This thread about BMA has made for interesting reading over the past few days. I've enjoyed it and feel modestly motivated to weigh in. I am a BMA customer, in fact, one of the first E/1 black plastic boxes came to me. Why did I choose it? Features for price, an analysis that, in my eyes is as true today as it was 6 years ago. I upgraded to the gold box when it was available, and just recently replaced it with a Gen4 E/2. Yes, I paid the freight and kept going with BMA. The original up to the Gen3 models got a bad rep for what I consider a poor reason. The original schema was completely flexible in its input configuration. That meant for people like me with a rotax, could use the probes that came with the engine, any probes would work. They just needed to be calibrated, a concept it turns out in practice was foreign to many builders, "system integrators (I think panel builders is a far more accurate description BTW)", and especially non-building owners of experimental aircraft. It turns out, most of the general aviation never calibrates anything except the mandated encoder. This is really sloppy practice for non-mated sensor / indicators, especially when they are non mil or medical grade. My little experience informs me that you cant expect better than 10%, maybe 20% accuracy in an automotive sensor unless you calibrate it to the indicator. How many people calibrate their oil temp and pressure probes on their RV? Not many. Does the 10% really matter, not really in most applications. But the BMA required calibration. The BMA also had its ADCs outside the engine compartment and the repeated warnings about low resistance gounds to the battery and engine block were apparently inadequate for many people. Digital avionics and low level voltage signals just require more care in grounding and layout than older analog systems, especially in composite airframes (like mine). I will certainly grant you that the manuals are a bit sparse, but then I always found that the telephone worked for me. For what Greg has told me, most problematic installations eventually work once external wiring errors are caught and corrected. The BMA guys sought to simplify installation wiring by mandating a fixed set of sensors, none of which are unipolar and return back through the engine block. Wiring is now much simpler as I can attest in my own install last month. Calibration is no longer needed. I think that BMA will be out with a skin for the Rotax engines soon so I can integrate the VDO sensors built in to the engine. The stuff works and I believe it provides the most advanced EFIS functions for the price. It is also among the simplest to use in flight. So there have been some problems with the company. I see these kinds of issues in IT all the time. Greg chose the brand-new at the time SISC CPU chip for Gen 1-2. Many thought SISC would win out the future of computing over CISC chips like the Pentium. It was faster and cheaper right up until SISC guys went out of business. No more parts. No evolution of SISC. Technology moves fast, airplane building slow. I bought early, so do most. Some get more burned than others. Anyone want a Mode S transponder? ANyone want a 430, I heard the WAAS upgrade will be simple and very cheap! Most of Gen3 features worked out the door, but some did not. Some worked for some owners and not for others. More strenuous beta testing might help. Again not very different for many vendors from airframe kits to headsets. Ever hear of ADs? I don't work for Greg, et al, I'm just a customer who has appreciated life on the bleeding edge with my experimental aircraft. You might even find me at the BMA booth at SnF talking about my experience in using the EFIS for nearly 4 years. I am always delighted to talk to fellow listers ;-) Cheers -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=159780#159780 ________________________________________________________________________________
Subject: Re: Mode S & 430 - Was Blue Mountain EFIS
Date: Jan 23, 2008
Hi Pete, Sadly, I project there will not be a market in Europe much longer for general aviation products. The EU seems absolutely bound and determined to terminate private flight. A buddy of mine just returned from London, where he tells me a C172 rents for over 200 BPS per hour, thats over $400/hr! Who can afford a used Garmin after that? -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160085#160085 ________________________________________________________________________________
Date: Jan 24, 2008
That's why we build our own planes here as you do in the US! Werner (from Switzerland) rampil wrote: > > Hi Pete, > > Sadly, I project there will not be a market in Europe much longer for > general aviation products. The EU seems absolutely bound and determined > to terminate private flight. A buddy of mine just returned from London, > where he tells me a C172 rents for over 200 BPS per hour, thats over > $400/hr! > > Who can afford a used Garmin after that? > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160085#160085 > > > ________________________________________________________________________________
Subject: Mono Isolation Amp - Where to get circuit board?
From: "Craig Winkelmann, CFI" <capav8r(at)gmail.com>
Date: Jan 24, 2008
I am adding a second radio to a plane that has no room for a full audio panel without making a whole new panel. I am going to route two coms and one marker beacon to the intercom. I have speced out the switched and dome a wiring diagram. I looked at the Isolation Amp at the AeroElectric web site. However, under parts, I don't see where I can order the circuit board to make the amp (part no 9009-301-2A). Where do I get one? Craig Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160175#160175 ________________________________________________________________________________
Date: Jan 24, 2008
I have written about this extensively on this list and IMHO-- 1) Aeroleds is to be saluted for making their led landing and taxi light. There will be many good led products. I have said to interested parties that any led product you can now buy becomes obsolete in the time it takes to develop a product. The design engineer's current nightmare! The best LED product efficiency is nearly 100 lumens/watt and soon will be 150 lumens/watt (7X better than halogens). For experimenters, I recommend you check-- http://www.dealextreme.com/products.dx/category.917 Dig around the site until your head spins. Also Kaidoman.com . Cheap prices, fast shipping. Amazing stuff. As for LED landing lights, you could just tape together a few of their big flashlights and do the job cheaply. Check their 20W and 50W leds!!!! Awesome. I still have a couple LED technical notes on my website: www.periheliondesign.com/downloads/aircraft_beacons_using_leds.pdf (out of date now but still interesting). www.periheliondesign.com/downloads/redandgreenledpositionlights.pdf and I still sell the LED tail light, which I have upgraded to a 2X brighter led. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160190#160190 ________________________________________________________________________________
Subject: Re: MagnaFlite MZ-6222 starter
Date: Jan 24, 2008
#2 wire it is... Response received from Kelly Aerospace: The only information we have is for testing the starters in a "no load" condition on our test bench which does not correlate to the current draw under load with the starter turning the engine. I recall from past experiences that the current draw during cranking would be 250 - 350 amps under normal conditions, obviously higher at the initial onset of the start, then tapering off as the engine rotates. I think the best idea would be to review a service manual for a production aircraft and use its electrical system schematic as a guide. Any Piper PA-235 Commanche or PA-23-250 Aztec series might be good examples to consider. Each of them run a Lycoming 540 engine. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160204#160204 ________________________________________________________________________________
Date: Jan 24, 2008
Subject: Low Volt Warning breaker
Just curious why there is a breaker for the Low Volt OV sense - on the LR3C regulator - Z13 - and not just combined with the ALT field breaker? Tks. ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Voltage drop under load
Date: Jan 24, 2008
I noticed today that my voltage would drop from about 14.5 volts down to 13.3 volts when I turned all my lights on. That is two 100W landing, two 100W taxi, position, and strobe lights. I made sure that I had plenty of rpm to be certain that the alternator was putting out its max. The alternator is rated at 55A. Is it possible that I am pulling more amps than the alternator can handle? Is the drop of voltage an indicator of this? What should be the size of the B lead wire for a 55A alternator? Thanks, Bill B ________________________________________________________________________________
Date: Jan 24, 2008
I purchased the AeroSun 800 for my weight shift trike nose landing light. Flying sport pilot I don't fly at night, but do land in civil twilight. The product is well made, very sturdy, bright as hell, easy to wire up. My single light is controlled with one switch, as either light or wig-wag/flasher. I talked to the folks at Aerosun before purchase. They even sent me to Aircraft Spruce for a lesser price than direct from them. http://www.aircraftspruce.com/catalog/elpages/1105710.php Yes, I could build my own LED light but for the $$ their unit is very nice, works well. Whatever floats your boat. Fly safe, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160321#160321 ________________________________________________________________________________
Date: Jan 24, 2008
Subject: Re: Voltage drop under load
Yes voltage starts to sag as the alternator output starts to lag demand. Quick math suggests that your alternator is working properly. (100 watts divided by 13.3 volts is about 7.5 amps per 100 watt load) My alternator can handle all loads but the voltage will drop a bit if I pull the throttle to idle on approach. No big deal if the battery helps out for a few dozen seconds on final approach. In cruise my taxi lights wig wag which halves the current draw. Ken Bill Bradburry wrote: > > I noticed today that my voltage would drop from about 14.5 volts down to > 13.3 volts when I turned all my lights on. That is two 100W landing, two > 100W taxi, position, and strobe lights. > I made sure that I had plenty of rpm to be certain that the alternator was > putting out its max. The alternator is rated at 55A. > > Is it possible that I am pulling more amps than the alternator can handle? > Is the drop of voltage an indicator of this? > > What should be the size of the B lead wire for a 55A alternator? > > Thanks, > Bill B > ________________________________________________________________________________
Date: Jan 24, 2008
Subject: Re: Low Volt Warning breaker
If the ALT breaker pops (and it will in milliseconds in an OV situation) wouldn't that also kill the low voltage warning and defeat the purpose of it? Ken John Tvedte wrote: > > Just curious why there is a breaker for the Low Volt OV sense - on the LR3C regulator - Z13 - and not just combined with the ALT field breaker? > > Tks. > > ________________________________________________________________________________
Subject: Re: Blue Mountain EFIS
Date: Jan 24, 2008
I too am a BMA customer with a G4 lite plus. I have gone through the same problems that others have mentioned. looking back I can remember several occasions that I wanted to rip out the unit and drive over it with my truck. Nothing worked as advertised, Software was incomplete, Features were missing etc... It has been over a year now and with the updates that have been released it has become quite useful. Right now as it stands I have a very stable and informative EFIS. The autopilot is now functional and has good integration with external device as the Sl30 and GNS430. I now trust it for my primary IFR but i also have backup gauges. I can not find a single EFIS system out there that I would trust solely for IFR without some backup anyway. Trust me.. I looked at every EFIS company out there. I looked at the features and performance and still I stayed with the Blue Mountain. It has been a love hate relationship with them. Greg is not the best business manager I have ever dealt with. He really screwed the pooch with the roll out of the G4 line. Releasing it before it was fully tested or the software was fully implemented would not have been my first choice. But I do not know the full story or what his game plan was. I know he was forced to put out the G4 line as the design for the G3 had too many limitations. In the last six months I have seen a huge change in the product and his efforts to release quality updates. Every update is carefully tested and refined and shows major improvements. The first six months the releases were just to add the functionality he promised it was to have and the last six months the updates have refined small issues. Over all I now have a unit that is 95.5% of what was first promised. I have not found any EFIS that has everything that I would like to have. Dynon has a good unit but the decision not to support 3rd party autopilots is a Big turn off for me. BMA has their own autopilot that now works very very good but they still chose to allow integration with other autopilots. Bravo!! Advance's EFIS has a really complicated GUI. BMA is a small company. Releasing the G4 line before it was fully ready might have been a financial one but I am happy that they stuck with it and now they can focus on marketing a product that can hold it's own against any other. I find it really ironic that I am defending them after all this time. But I really like the design and simplicity of the design now. I would defiantly put another one in my next plane. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160329#160329 ________________________________________________________________________________
Subject: Dimmer hookup to Avionics
Date: Jan 24, 2008
I know some (ALL?) of you folks know a lot more about this than I do, and rather than take a chance of frying something, I'm going to ask here. I am hooking up several of the AeroElectric dimmer boards units Bob used to sell on the AEC site to my panel, (Now B&C sells them as DIM15-14's) and one of them is to be used for dimming the internal lighting on my MAC 1700 (Really a KX-170A) radio, and a King KT-76 transponder. I want to make sure I get the hookups right. I hate letting the smoke out of expensive "stuff". On the pre-wired harness I bought (years ago) with the NavCom, it had one wire labeled "Lighting" and another yellow wire labeled "Dimmer". I don't want to just start trying things, so can any of you tell me which of those wires I need to hook to the output of the dimmer unit? Does one of these wires from the radio go to +14VDC, and the other to the dimmer board output? I have tested the dimmers and they work fine with light bulbs, etc., but I don't want to fry anything internally in the radio(s). Thanks in advance. -------- Ron Cox Glasair Super II F/T Under Construction at C77 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160331#160331 ________________________________________________________________________________
Subject: Re: IFR GPS requirements/TSO-88C
Date: Jan 25, 2008
Hi: For those of you with non-certified EFIS systems that you also use to encode your transponder, what do you have to do to comply with FAR 91.217(c) in meeting the requirements of TSO-88C. Thanks Mark ________________________________________________________________________________
Date: Jan 24, 2008
In a message dated 1/24/2008 3:00:52 A.M. Eastern Standard Time, aeroelectric-list(at)matronics.com writes: Stan, thanks for the reply. How are you coming on the lights? I have just started messing around with them and was wondering if anyone else had come up with anything. I agree about the charge for restocking for something you don't know will be as advertised. Dan, I did some experiments about a year ago and then again recently. I'm using Luxeon K2s which are one watt and produce about 80 lumen. Later model LEDs produce more lumen per watt. I have some optics for them that focus the light nicely but it would require 6 or 8 to adequately illuminate in front of the plane. Also, mounting them and heat sinking are problems to be solved. The number of LEDs in series on a single power supply has to be carefully studied to make sure you don't over or under voltage them too much. With the Luxeon K2s, I can have only 4 on a single 12v power supply. It appears the aeroleds.com guys have solved the problems and the best solution may be to wait for them (or someone else) to work out the bugs. ACS sells the AeroSun 800 for $155 each. My estimate is that you will have to invest about $100-120 to develop a similar light yourself, so their price is not too bad. If the AeroSun 800 produces sufficient light, then I believe that is the best current option for LED-based landing/taxi lighting. Stan **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Subject: IFR GPS requirements/TSO-88C
Date: Jan 24, 2008
In essence, passing the bi-annual check, satisfies the regulation. Bruce www.Glasair.org -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of FLAGSTONE Sent: Friday, January 25, 2008 9:31 AM Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C Hi: For those of you with non-certified EFIS systems that you also use to encode your transponder, what do you have to do to comply with FAR 91.217(c) in meeting the requirements of TSO-88C. Thanks Mark ________________________________________________________________________________
Date: Jan 25, 2008
My FAA office required a certified encoder, I think it was about a $200.00 box. Yours may not be so stupid, because the EFIS encoder is a superior unit. Sam FLAGSTONE wrote: > > Hi: > > For those of you with non-certified EFIS systems that you also use to encode > your transponder, what do you have to do to comply with FAR 91.217(c) in > meeting the requirements of TSO-88C. > > Thanks > > Mark > > > > > > ________________________________________________________________________________
Date: Jan 25, 2008
Good Morning Sam, Maybe I have missed something, but how did the FSDO get involved? As near as I can tell, there is no need to ask them anything. If you elect to fly your experimental airplane IFR, all that is required is that it meet the specified functional requirements. There is no requirement that any piece of equipment be TSO'd. The only requirement is that it perform properly. What am I missing here? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/25/2008 7:58:18 A.M. Central Standard Time, sam(at)fr8dog.net writes: My FAA office required a certified encoder, I think it was about a $200.00 box. Yours may not be so stupid, because the EFIS encoder is a superior unit. Sam **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Jan 25, 2008
The avionics shop that does the static check, wouldn't certify the test without an approved encoder. The avionics inspector from the FSDO was there when I made my inquiry as to what is required. He said I had to have a three things before a shop in his district would approve an installation. TSO altimeter, TSO encoder, and a TSO transponder. BobsV35B(at)aol.com wrote: > Good Morning Sam, > > Maybe I have missed something, but how did the FSDO get involved? > > As near as I can tell, there is no need to ask them anything. > > If you elect to fly your experimental airplane IFR, all that is > required is that it meet the specified functional requirements. There > is no requirement that any piece of equipment be TSO'd. The only > requirement is that it perform properly. > > What am I missing here? > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > 628 West 86th Street > Downers Grove, IL 60516 > 630 985-8502 > Stearman N3977A > Brookeridge Air Park LL22 > > In a message dated 1/25/2008 7:58:18 A.M. Central Standard Time, > sam(at)fr8dog.net writes: > > My FAA office required a certified encoder, I think it was about a > $200.00 box. Yours may not be so stupid, because the EFIS encoder > is a superior unit. > Sam > > > ------------------------------------------------------------------------ > Who's never won? Biggest Grammy Award surprises of all time on AOL > Music. > <http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548> > * > > > * ________________________________________________________________________________
Date: Jan 25, 2008
Sam Marlow wrote: > The avionics shop that does the static check, wouldn't certify the > test without an approved encoder. The avionics inspector from the FSDO > was there when I made my inquiry as to what is required. He said I had > to have a three things before a shop in his district would approve an > installation. TSO altimeter, TSO encoder, and a TSO transponder. > You should chat with the EAA and ask if they would be willing to talk to this person. In an experimental aircraft, the avionics shops are not required to approve any installation - you do this as the builder of the aircraft. All they have to do is run the tests to see if the equipment passes or not. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 25, 2008
While I don't think redundancy is necessarily a bad thing, a TSO blind encoder is not strictly necessary. Maybe the presence of the FSDO guy in the shop spooked the boys. When I had my gold box BMA EFIS/1 it was approved for its biennial without a peep as the encoder for my SL-70 transponder. Well, not quite. The shop guys had never before seen a transponder squawk within 1 foot of all 10 target altitudes from zero to 16000! This was after it had warmed up for an hour or so. Having said that, when I upgraded to the BMA Gen4, the panel lost so much weight, that when I saw a good price on a TransCal encoder, I bought it. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160441#160441 ________________________________________________________________________________
Date: Jan 25, 2008
I understand I really only have to meet the specifications of the TSO, but the avionics shop won't do it unless it satisfies the local Feds. Which means if they did certify the static and transponder, and I wasn't TSO equipment, then they could lose there certificate. I can't certify the static and txp checks as a builder, so I'm bound by my local FSDO bureaucracy! Sam Dj Merrill wrote: > > Sam Marlow wrote: >> The avionics shop that does the static check, wouldn't certify the >> test without an approved encoder. The avionics inspector from the >> FSDO was there when I made my inquiry as to what is required. He said >> I had to have a three things before a shop in his district would >> approve an installation. TSO altimeter, TSO encoder, and a TSO >> transponder. >> > > You should chat with the EAA and ask if they would be willing to > talk to this person. In an experimental aircraft, the avionics shops > are not required to approve any installation - you do this as the > builder of the aircraft. All they have to do is run the tests to see > if the equipment passes or not. > > -Dj > ________________________________________________________________________________
Date: Jan 25, 2008
Sam Marlow wrote: > I understand I really only have to meet the specifications of the TSO, > but the avionics shop won't do it unless it satisfies the local Feds. > Which means if they did certify the static and transponder, and I > wasn't TSO equipment, then they could lose there certificate. > I can't certify the static and txp checks as a builder, so I'm bound > by my local FSDO bureaucracy! > Sam As the builder, it is my understanding that you 'certify' EVERYTHING on the project. You're not asking that the avionics shop certify the setup. You're just asking them to test it and provide you with the raw data. It is *YOU* that gets to decide if it meets the requirements. Or have I completely misunderstood it all? ________________________________________________________________________________
Date: Jan 25, 2008
Sam Marlow wrote: > I understand I really only have to meet the specifications of the TSO, > but the avionics shop won't do it unless it satisfies the local Feds. > Which means if they did certify the static and transponder, and I > wasn't TSO equipment, then they could lose there certificate. > I can't certify the static and txp checks as a builder, so I'm bound > by my local FSDO bureaucracy! > Sam > Hi Sam, All they can do is run the tests and tell you if the equipment passes the test, or not. As I understand it, their responsibility ends there. There have been many discussions about this that can be found in this list's archives if you want to read more about it. Bottom line is that your avionics shop and your local FSDO are not properly following the guidelines set forth and documented by the FAA. Within the last few months a similar situation was discussed on this list that was happening (in Florida I think), and the builder contacted the EAA, who in turn contacted the FAA, who in turn contacted the FSDO and set them straight. In the end the builder used his EFIS encoder to drive the transponder and it passed the tests, so he was all set to go. In my sometimes-not-so-humble opinion, you would be doing builders in your area a great service if you were to place a phone call to the EAA to report this, and hopefully they will also be able to correct your local FSDO's incorrect interpretation of the FAA rules. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Jan 25, 2008
I would call up your local inspector at FSDO...Explain to him what the requ irements are and ask him to send an email to the local shop. FSDO is bound by federal aviation law, they can't go round making up their own rules...My guess is they are not clear on what the rules are so I would get on the EAA website and download the document about experimenatls and f lying IFR...The EAA did an exposee on this very subject and got an "interpr etation" of the law from the FAA itself. So you need to get this document into the hands of the local FSDO inspector . I have found they are usually pretty normal people with a genuine interest in aviation....I'm sure its just a misunderstanding somewhere. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Sam Marlow Sent: Friday, January 25, 2008 10:30 AM Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C I understand I really only have to meet the specifications of the TSO, but the avionics shop won't do it unless it satisfies the local Feds. Which mea ns if they did certify the static and transponder, and I wasn't TSO equipme nt, then they could lose there certificate. I can't certify the static and txp checks as a builder, so I'm bound by my local FSDO bureaucracy! Sam ________________________________________________________________________________
Date: Jan 25, 2008
You can have Radio Shack and WallyWorld stuff behind the panel. For IFR certification, the Avionics shop doesn't pass judgment on what they think of the equipment, but simply if it meets the accuracy requirements. If it meets the accuracy requirements at all the appropriate altitudes, then they give you approval and they can keep their opinions of what they think of the setup to themselves. Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dj Merrill Sent: Friday, January 25, 2008 2:02 PM Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C Sam Marlow wrote: > I understand I really only have to meet the specifications of the TSO, > but the avionics shop won't do it unless it satisfies the local Feds. > Which means if they did certify the static and transponder, and I > wasn't TSO equipment, then they could lose there certificate. > I can't certify the static and txp checks as a builder, so I'm bound > by my local FSDO bureaucracy! > Sam > Hi Sam, All they can do is run the tests and tell you if the equipment passes the test, or not. As I understand it, their responsibility ends there. There have been many discussions about this that can be found in this list's archives if you want to read more about it. Bottom line is that your avionics shop and your local FSDO are not properly following the guidelines set forth and documented by the FAA. Within the last few months a similar situation was discussed on this list that was happening (in Florida I think), and the builder contacted the EAA, who in turn contacted the FAA, who in turn contacted the FSDO and set them straight. In the end the builder used his EFIS encoder to drive the transponder and it passed the tests, so he was all set to go. In my sometimes-not-so-humble opinion, you would be doing builders in your area a great service if you were to place a phone call to the EAA to report this, and hopefully they will also be able to correct your local FSDO's incorrect interpretation of the FAA rules. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 25, 2008
I can't do a static check or transponder ck, without thousands of dollars worth of equipment. So I have to depend on an avionics shop for this. It doesn't matter if I built it or Beech built it, it still has to be checked by an approved shop with approved equipment, every 24 months. Ernest Christley wrote: > > > Sam Marlow wrote: >> I understand I really only have to meet the specifications of the >> TSO, but the avionics shop won't do it unless it satisfies the local >> Feds. Which means if they did certify the static and transponder, and >> I wasn't TSO equipment, then they could lose there certificate. >> I can't certify the static and txp checks as a builder, so I'm bound >> by my local FSDO bureaucracy! >> Sam > As the builder, it is my understanding that you 'certify' EVERYTHING > on the project. You're not asking that the avionics shop certify the > setup. You're just asking them to test it and provide you with the > raw data. It is *YOU* that gets to decide if it meets the requirements. > > Or have I completely misunderstood it all? > > ________________________________________________________________________________
Date: Jan 25, 2008
Yes, but they won't do it period. I've tried to deal with the FAA on several similar matters, I'm an IA, but it's just a loosing battle. They have their little kingdom, cushy chairs, and GS pay schedules, and they do make up their own rules, as they go. I've given up............let someone else fight that battle, that's what we pay dues to EAA for, right. Chuck Jensen wrote: > > You can have Radio Shack and WallyWorld stuff behind the panel. For IFR certification, the Avionics shop doesn't pass judgment on what they think of the equipment, but simply if it meets the accuracy requirements. If it meets the accuracy requirements at all the appropriate altitudes, then they give you approval and they can keep their opinions of what they think of the setup to themselves. > > Chuck Jensen > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Dj > Merrill > Sent: Friday, January 25, 2008 2:02 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C > > > Sam Marlow wrote: > >> I understand I really only have to meet the specifications of the TSO, >> but the avionics shop won't do it unless it satisfies the local Feds. >> Which means if they did certify the static and transponder, and I >> wasn't TSO equipment, then they could lose there certificate. >> I can't certify the static and txp checks as a builder, so I'm bound >> by my local FSDO bureaucracy! >> Sam >> >> > > Hi Sam, > All they can do is run the tests and tell you if the equipment > passes the test, or not. As I understand it, their responsibility ends > there. > > There have been many discussions about this that can be found in > this list's archives if you want to read more about it. Bottom line is > that your avionics shop and your local FSDO are not properly following > the guidelines set forth and documented by the FAA. > > Within the last few months a similar situation was discussed on this > list that was happening (in Florida I think), and the builder contacted > the EAA, who in turn contacted the FAA, who in turn contacted the FSDO > and set them straight. In the end the builder used his EFIS encoder to > drive the transponder and it passed the tests, so he was all set to go. > > In my sometimes-not-so-humble opinion, you would be doing builders > in your area a great service if you were to place a phone call to the > EAA to report this, and hopefully they will also be able to correct your > local FSDO's incorrect interpretation of the FAA rules. > > -Dj > > ________________________________________________________________________________
Date: Jan 25, 2008
Good Afternoon Sam, You are absolutely correct that it needs to be checked in accordance with the regulatory requirements and that you are unlikely to have the equipment and expertise to do the checks required. The local avionics shop is probably the best place to get the checks performed. However, they don't have to approve it. All they need to do is provide you with the data they found. You are the certifying entity and it is up to you to decide if it meets the regulatory requirements or not. Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 1/25/2008 2:29:03 P.M. Central Standard Time, sam(at)fr8dog.net writes: I can't do a static check or transponder ck, without thousands of dollars worth of equipment. So I have to depend on an avionics shop for this. It doesn't matter if I built it or Beech built it, it still has to be checked by an approved shop with approved equipment, every 24 months. Ernest Christley wrote: **************Biggest Grammy Award surprises of all time on AOL Music. (http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp003000000025 48) ________________________________________________________________________________
Date: Jan 25, 2008
Sam Marlow wrote: > > Yes, but they won't do it period. I've tried to deal with the FAA on > several similar matters, I'm an IA, but it's just a loosing battle. > They have their little kingdom, cushy chairs, and GS pay schedules, > and they do make up their own rules, as they go. > I've given up............let someone else fight that battle, that's > what we pay dues to EAA for, right. Unless the EAA knows there is a problem, they can't do much about it. Any chance you'd be willing to give them a call to let them know there is an issue with your local FSDO? Hopefully they can then take it from there. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 25, 2008
Your correct Bob, but the shop is afraid of loosing it's certificate if they certify it meets requirement on non TSD'd equipment. They do, have to certify it meets min requirements, just look at the log book entry. BobsV35B(at)aol.com wrote: > Good Afternoon Sam, > > You are absolutely correct that it needs to be checked in accordance > with the regulatory requirements and that you are unlikely to have the > equipment and expertise to do the checks required. The local avionics > shop is probably the best place to get the checks performed. > > However, they don't have to approve it. > > All they need to do is provide you with the data they found. You are > the certifying entity and it is up to you to decide if it meets the > regulatory requirements or not. > > Happy Skies, > > Old Bob > AKA > Bob Siegfried > Ancient Aviator > 628 West 86th Street > Downers Grove, IL 60516 > 630 985-8502 > Stearman N3977A > Brookeridge Air Park LL22 > > In a message dated 1/25/2008 2:29:03 P.M. Central Standard Time, > sam(at)fr8dog.net writes: > > I can't do a static check or transponder ck, without thousands of > dollars worth of equipment. So I have to depend on an avionics > shop for this. It doesn't matter if I built it or Beech built it, > it still has to be checked by an approved shop with approved > equipment, every 24 months. > > Ernest Christley wrote: > > > ------------------------------------------------------------------------ > Who's never won? Biggest Grammy Award surprises of all time on AOL > Music. > <http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548> > * > > > * ________________________________________________________________________________
Date: Jan 25, 2008
Are you kidding, walk into a FSDO and challenge them. I'd never get another 337 approved. Not me, I'm done dealing on that level. If one of you guy's want to, that's well and good, I'll even drive you. I just want to enjoy flying, and not argue and bicker with every new FAA guy that thinks he's God's gift to aviation. Dj Merrill wrote: > > Sam Marlow wrote: >> >> Yes, but they won't do it period. I've tried to deal with the FAA on >> several similar matters, I'm an IA, but it's just a loosing battle. >> They have their little kingdom, cushy chairs, and GS pay schedules, >> and they do make up their own rules, as they go. >> I've given up............let someone else fight that battle, that's >> what we pay dues to EAA for, right. > > Unless the EAA knows there is a problem, they can't do much about > it. Any chance you'd be willing to give them a call to let them know > there is an issue with your local FSDO? Hopefully they can then take > it from there. > > -Dj > ________________________________________________________________________________
Date: Jan 25, 2008
Sam Marlow wrote: > Are you kidding, walk into a FSDO and challenge them. That is not at all what I said... :-) I simply suggested making a phone call to the EAA and let them handle it, which leaves you out of the direct confrontation. If we as individuals do not stand up for ourselves, or at the very least notify the organizations that represent us, then we give the power to "every new FAA guy that thinks he's God's gift to aviation" to act in whatever way they wish. -Dj -- Dj Merrill - N1JOV Glastar Sportsman 2+2 Builder #7118 N421DJ http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Date: Jan 25, 2008
Sam, The simple problem is that you picked the wrong avionics shop. Thats all. Or, as I said before, the guys were spooked by Mr FSDO standing there as you said. My airframe log note from my local shop simply says, that as per the relevant regs, my system meets the accuracy required for flight in the NAS. The point of calling the EAA is simply so they can cite for you all the needed CFRs and other publications to make it clear to the shop that homebuilts follow a different protocol. I assure you that my local shop is a major national shop which does 135 and warbird work as well as part 91 and homebuilts. They know the score and what they are doing is fully complying with all the regs. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160490#160490 ________________________________________________________________________________
Date: Jan 25, 2008
This wouldn't be the Richmond FSDO, of dual brakes fiasco fame? Most feds will not get too huffy if you ask them to politely educate you as to which FAR or other publication states whatever their position is. Something along the lines of "I'm from Missouri, I'd sleep better if you could please show me where that requirement is for experimental aircraft". KM also an IA Sam Marlow wrote: > > Yes, but they won't do it period. I've tried to deal with the FAA on > several similar matters, I'm an IA, but it's just a loosing battle. > They have their little kingdom, cushy chairs, and GS pay schedules, > and they do make up their own rules, as they go. > I've given up............let someone else fight that battle, that's > what we pay dues to EAA for, right. ________________________________________________________________________________
Date: Jan 25, 2008
I suppose so, but I didn't have much choice, considering my location. rampil wrote: > > Sam, > > The simple problem is that you picked the wrong avionics shop. > Thats all. Or, as I said before, the guys were spooked by Mr FSDO > standing there as you said. > > My airframe log note from my local shop simply says, that as per the > relevant regs, my system meets the accuracy required for flight in > the NAS. > > The point of calling the EAA is simply so they can cite for you all the > needed CFRs and other publications to make it clear to the shop that > homebuilts follow a different protocol. I assure you that my local > shop is a major national shop which does 135 and warbird work as well > as part 91 and homebuilts. They know the score and what they are doing > is fully complying with all the regs. > > -------- > Ira N224XS > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160490#160490 > > > ________________________________________________________________________________
Date: Jan 25, 2008
Yea, well you know the battle I've been fighting for years, it just takes to much out of me to fight all the time. I just want enjoy aviation, and have fun. Kelly McMullen wrote: > > > This wouldn't be the Richmond FSDO, of dual brakes fiasco fame? Most > feds will not get too huffy if you ask them to politely educate you as > to which FAR or other publication states whatever their position is. > Something along the lines of "I'm from Missouri, I'd sleep better if > you could please show me where that requirement is for experimental > aircraft". > KM > also an IA > Sam Marlow wrote: >> >> Yes, but they won't do it period. I've tried to deal with the FAA on >> several similar matters, I'm an IA, but it's just a loosing battle. >> They have their little kingdom, cushy chairs, and GS pay schedules, >> and they do make up their own rules, as they go. >> I've given up............let someone else fight that battle, that's >> what we pay dues to EAA for, right. > > ________________________________________________________________________________
Date: Jan 25, 2008
And that's exactly whats happened. Sadly enough. Dj Merrill wrote: > > Sam Marlow wrote: >> Are you kidding, walk into a FSDO and challenge them. > > > That is not at all what I said... :-) I simply suggested making a > phone call to the EAA and let them handle it, which leaves you out of > the direct confrontation. > > If we as individuals do not stand up for ourselves, or at the very > least notify the organizations that represent us, then we give the > power to "every new FAA guy that thinks he's God's gift to aviation" > to act in whatever way they wish. > -Dj > ________________________________________________________________________________
Date: Jan 25, 2008
This may sound like a dumb thought...but why don't you just take it to another shop? Bret Smith RV-9A N16BL Blue Ridge, Ga www.FlightInnovations.com <http://www.flightinnovations.com/> _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Marlow Sent: Friday, January 25, 2008 4:07 PM Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C Are you kidding, walk into a FSDO and challenge them. I'd never get another 337 approved. Not me, I'm done dealing on that level. If one of you guy's want to, that's well and good, I'll even drive you. I just want to enjoy flying, and not argue and bicker with every new FAA guy that thinks he's God's gift to aviation. Dj Merrill wrote: Sam Marlow wrote: Yes, but they won't do it period. I've tried to deal with the FAA on several similar matters, I'm an IA, but it's just a loosing battle. They have their little kingdom, cushy chairs, and GS pay schedules, and they do make up their own rules, as they go. I've given up............let someone else fight that battle, that's what we pay dues to EAA for, right. Unless the EAA knows there is a problem, they can't do much about it. Any chance you'd be willing to give them a call to let them know there is an issue with your local FSDO? Hopefully they can then take it from there. -Dj ________________________________________________________________________________
Date: Jan 26, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> >A (yellow tagged) MZ-6222 lightweight MagnaFlite starter came with my >rebuilt O-540 engine. Does anyone know of a source to estimate real world >current draw at starter engagement so as to properly size the wire? I'm >pretty sure #2 would be safe, but can it be quantified a bit better than >"hundreds of amps"? > >The unit looks like it's in pretty good shape (teeth are not worn at >least). Is there any way to test the state of internal electrical stuff >besides disassembly? > >Thanks in advance for replies. If your battery and engine are on the same end of the airplane, #4 would probably be fine for all of your "fat" wires . . . #2 would certainly be okay. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 26, 2008
Subject: Re: TurboCAD software at a discount
> >I recently purchased a copy of TurboCAD Deluxe 14 from >academicsuperstore.com for $70 (including shipping). This price seemed >like a really good deal as it retails for $149. > >Here's the catch... You have to have a student in your household to qualify. If one is primarily interested in opening, editing, saving and printing AeroElectric Connection .dwg files, then any version 7 or later will work. The last V7 I purchased of Ebay was $10 plus postage. Obviously, if one needs the more advanced features of a later version, the $higher$ editions are indicated. Bob . . . ________________________________________________________________________________
Date: Jan 26, 2008
> >Just curious why there is a breaker for the Low Volt OV sense - on the >LR3C regulator - Z13 - and not just combined with the ALT field breaker? Because the B&C devices are not just "regulators" . . . they contain OV protection, alternator regulation AND LV Warning. Further, these regulators conform to design goals that have become pretty much standard over the last 20+ years: DON'T MAKE FIELD SUPPLY AND VOLTAGE SENSE LINES TO THE BUS SHARE A COMMON CONDUCTOR. This is called, "remote sensing for voltage regulation". This prevents the very common ammeter oscillation phenomenon common in many light aircraft of yesteryear. It also insures that the LV warning system stays operational even if the alternator has been taken off line manually or by reason of an OV condition. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 26, 2008
Bob, I agree with you, but there are requirements for TSO even on a homebuilt/experimental/amateur built: ELT IFR GPS Transponder I agree encoder is not a TSO item, and if it passes the 24 month pitot / static test than its good. >From: BobsV35B(at)aol.com >Subject: Re: AeroElectric-List: IFR GPS requirements/TSO-88C >There is no requirement that any piece of equipment be TSO'd. >The only requirement is that it perform properly. > >What am I missing here? Happy Skies, > >Old Bob >Ancient Aviator --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Jan 26, 2008
Davinci Technologies has a product called Airplane PDQ $99 that is built on Intellicad, it is ACAD compatible, you may want to take a look. This quote is from their website "AirplanePDQ is a conceptual/preliminary design tool for light homebuilt and general aviation aircraft." I use it to translate newer ACAD files to the R14 version that I use. http://www.davincitechnologies.com/ -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Jan 26, 2008
Great post. 100% right on. With the web you have advice of many, and everyone is in such agreement, plus lots of excellent advice, you should be encouraged. 1 Go to different shop 2 Call EAA, get all the regs references to back you up. 3 Call the FAA and politely ask, "educate me?" 4 Than challenge FAA to advice shop its OK. (EAA not sure they make calls for you, but their legal will advise you.) Once you educate them if you have, they will know they're wrong and it would make them look bad; they will agree and tell the shop it's OK to do a Pitot Static test. That is ALL it is a TEST for accuracy, not certification of the equip. Sometimes its ego and they don't want to back down, but they will if you have the information. It's not even a gray area. They are wrong. Some times you have to take a stand. Be an advocate for all EAA'ers. You can do it and it will not take that much time. You can do it all on the phone most likely. Here are some Reg Ref links for FUN? Sec. 91.215 ATC transponder and altitude reporting equipment and use. http://www.ferrer-aviation.com/far91215.htm Sec. 91.217 - Data correspondence between automatically reported pressure altitude data and the pilot's altitude reference. http://www.ferrer-aviation.com/far91217.htm TSO-10b (altimeter) http://tinyurl.com/2f8rla TSO-C88 (alt reporting / digitizing) http://tinyurl.com/2ez4a3 Don't panic, when you see TSO. It's a definition and many sections of part 91 Ref. part 21, 23, 34, 43, 47 & TSO's to name a few. None (almost) apply to experimentals. --------------------------------- Never miss a thing. Make Yahoo your homepage. ________________________________________________________________________________
Date: Jan 26, 2008
I did some more research and here is the break down of TSO'ed equip, including encoder in an experimental plane. Great thread on BMA. Check out page 2 and even more page 3, which are most relevant. http://tinyurl.com/2au2pe Paper on legality of experimental EFIS (encoder, altimeter, GPS, aka none TSO) in experimentals. http://tinyurl.com/2fbloa Bottom line is the pitot/static test is not an approval of the equip. As the builder you state it meets the TSO. I posted on Dynon's forum the same question. Some manufactures like GRT say their encoder meets the TSO. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Subject: Circuit breaker polarity
Date: Jan 27, 2008
I am rewiring my Navion panel using busses with Potter-Brumfield W31 switch breakers and Klixon 7277 c/b's. I put the P-B buss bar on the bottom following their Load-Line labeling but put the Klixon bar on top to ease access to the load terminals. My IA neighbor (not my supervising IA) tried to tell me it was backward but I had already checked and there is no labeling on the Klixon c/b's. I see no intuitive reason it should care about polarity but then I don't have a real understanding of their inner workings. Did I miss something? Does polarity matter for the Klixons? If so, I can change my buss. If not, why does P-B label their units (it's also on their W23 c/b's?) Is it real or just a case of eliminating choice? Thanks for the education. Regards, Greg Young ________________________________________________________________________________
Subject: Re: Circuit breaker polarity
Date: Jan 27, 2008
Breakers have no polarity. Element heating occurs in either direction! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160648#160648 ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Re: Mono Isolation Amp - Where to get circuit board?
> > >I am adding a second radio to a plane that has no room for a full audio >panel without making a whole new panel. I am going to route two coms and >one marker beacon to the intercom. I have speced out the switched and >dome a wiring diagram. I looked at the Isolation Amp at the AeroElectric >web site. However, under parts, I don't see where I can order the circuit >board to make the amp (part no 9009-301-2A). > >Where do I get one? I've had a lot of requests for this item and I'm in the process of placing it back on the website order form. I'll try to get this done in the next few days. I've been out of town for a week and have some taller fires to beat down first. Bob . . . ________________________________________________________________________________
Date: Jan 27, 2008
> >Yes voltage starts to sag as the alternator output starts to lag demand. >Quick math suggests that your alternator is working properly. (100 watts >divided by 13.3 volts is about 7.5 amps per 100 watt load) My alternator >can handle all loads but the voltage will drop a bit if I pull the >throttle to idle on approach. No big deal if the battery helps out for a >few dozen seconds on final approach. In cruise my taxi lights wig wag >which halves the current draw. >Ken > >Bill Bradburry wrote: >> >> I noticed today that my voltage would drop from about 14.5 volts down to >>13.3 volts when I turned all my lights on. That is two 100W landing, two >>100W taxi, position, and strobe lights. >>I made sure that I had plenty of rpm to be certain that the alternator was >>putting out its max. The alternator is rated at 55A. >>Is it possible that I am pulling more amps than the alternator can handle? >>Is the drop of voltage an indicator of this? >>What should be the size of the B lead wire for a 55A alternator? >>Thanks, >>Bill B 13.3 is TOO low. You need to put a temporary lead wire on the alternator's b-lead terminal and bring it into the cockpit for attaching a voltmeter. You MAY find that the alternator voltage at the b-lead is holding up just fine and that your wiring is too small . . . i.e. accounts for the drops under load that you've observed. I recommend 4AWG minimum for all the "fat" wires in the airplane. There's so little of it that weight deltas are insignificant . . . but 4AWG or larger makes for very solid voltage regulation at all loads. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 27, 2008
>I am rewiring my Navion panel using busses with Potter-Brumfield W31 >switch breakers and Klixon 7277 c/b's. I put the P-B buss bar on the >bottom following their Load-Line labeling but put the Klixon bar on top to >ease access to the load terminals. My IA neighbor (not my supervising IA) >tried to tell me it was backward but I had already checked and there is no >labeling on the Klixon c/b's. I see no intuitive reason it should care >about polarity but then I don't have a real understanding of their inner >workings. Did I miss something? Does polarity matter for the Klixons? If >so, I can change my buss. If not, why does P-B label their units (it's >also on their W23 c/b's?) Is it real or just a case of eliminating choice? >Thanks for the education. Intuitively, the physics of a series-connected heat-tripped, switch do not suggest a reason why the breaker would care which way electrons flow through it . . . and in particular, AC system breakers where electrons are known to turn around and run the other direction 120 times a second! You've already had some good responses but I'll take this opportunity to elaborate. Not all breakers are rudimentary . . . i.e. a simple spring-loaded, heater-tripped latch holding a set of single or double-break contacts closed. Breakers can be had with auxiliary switches, indicator lights, voltage sense coils, and all manner of enhancements where proper function of the enhancement depends on a connection to power being available even when the breaker is open. Obviously, some third terminal is necessary for an enhancement to function, this is sometimes an obvious connection, or perhaps it gets hooked up through the mounting. In any case, it's not uncommon for a manufacturer to use common tooling to mold a breaker housing for all versions, hence you often see the word "load", "line" or both formed right next to the breaker's terminals . . . I've asked several tech reps for breakers and except for enhanced breakers, orientation in the system doesn't matter. Interestingly enough, if an electrician encounters "line" and/or "load" labels on a breaker, he'll wire it up that way whether it matters or not. And I suspect many aviation techs do too . . . not because the physics matters but because some inspector who doesn't know any better can be counted on to insist that the protocols be followed. The only time I've encountered this as a "problem" is when a builder finds it convenient to fabricate a two-row bus-bar and take load feeders off opposite ends of the breaker. When they come stamped with a breaker rating, they look pretty funky with one row upside-down in their holes! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Dumb questions
I have been sitting in the back row on this list, hoping to learn something. I was born without any electronic genes. I am building an all metal light sport plane.(Zenith) Right or wrong, I developed the habit (over five decades of personal, military and commercial flying) of listening to broadcast radio on the ADF. I'm thinking that I need to install an of the shelf automobile radio in my project. No second hand Ebay ADF's. My two questions are: Will I fry the radio if I use only a headset and no speakers? About the antenna. I know that I should mount it vertically, but it must withstand airspeed excursions to Vne (156kts/180mph) without going L shaped. I've come up with somehow jamming it inside the canopy, or insulating it and mounting against the landing gear, or inside some kind of tubular mast on the belly. I did come across a NOS Volkswagen telescoping antenna in my shop. It would be great if that Lyc carburetor turns up again the same way. Somebody stop me if I'm on the wrong track. This isn't the most pressing problem out there, but all suggestions are appreciated. Bob Dingley ************** Start the year off right. Easy ways to stay in shape. http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 ________________________________________________________________________________
Subject: Power Board on EBay
Date: Jan 27, 2008
Check out Item # 120215336354 or search for "Power Board" for an auction for a Blue Mountain Avionics Power Board. Jim Butcher Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160699#160699 ________________________________________________________________________________
Subject: LEDs at 24volts?
Date: Jan 27, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
I have my reasons, so let's not get into that, but we're building a 24/28 volt airplane. Question: Can I take an LED with built-in resistor for 12 volt operation (as bought at Radio Shack) and run it at 24 volts? On the bench it seems to operate fine. Even if it reduces LED life somewhat, with the insane life that LEDs have anyway, and an application as warning light that is intermittant at best, maybe it will do fine. Thoughts? TDT RV-10 40025 ________________________________________________________________________________
Date: Jan 27, 2008
=0AHi Bob,=0A=0A =0A=0AMight I suggest you take a look at satellite radio - like XM (http://www.xmradio.com) or Sirius? I've been flying with an XM s etup (Roady XL) and love it. I can move it from car to airplane to house o r listen on my computer/Internet, in-flight station reception doesn't fade out every 15 minutes (as I fly away from a station), and the antenna is a l ittle tiny thing that is mounted inside my airplane (zero drag). It does r equire a subscription so is not free. In my plane, I just connect the radi o output to my intercom music input.=0A=0A =0A=0AJon=0A=0A=0A-----Original Message-----=0AFrom: MaxNr(at)aol.com=0ASent: Sunday, January 27, 2008 3:49pm =0ATo: aeroelectric-list(at)matronics.com=0ASubject: AeroElectric-List: Dumb q uestions=0A=0AI have been sitting in the back row on this list, hoping to l earn something. I was born without any electronic genes. I am building an a ll metal light sport plane.(Zenith) Right or wrong, I developed the habit ( over five decades of personal, military and commercial flying) of listening to broadcast radio on the ADF. I'm thinking that I need to install an of t he shelf automobile radio in my project. No second hand Ebay ADF's. My two questions are: Will I fry the radio if I use only a headset and no speakers ? About the antenna. I know that I should mount it vertically, but it must withstand airspeed excursions to Vne (156kts/180mph) without going L shaped . I've come up with somehow jamming it inside the canopy, or insulating it and mounting against the landing gear, or inside some kind of tubular mast on the belly. I did come across a NOS Volkswagen telescoping antenna in my shop. It would be great if that Lyc carburetor turns up again the same way. Somebody stop me if I'm on the wrong track. This isn't the most pressing p roblem out there, but all suggestions are appreciated.=0ABob Dingley =0A ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Re: Dumb questions
Bob, I'm no expert, but I did learn this from one. Some automotive audio systems use completely separate grounds for each channel. For that you'd have to rewire your headphones and run three jacks instead of two. This info may be old, it was a few years ago and things move on, but it never hurts to ask the sales guy or look at the wiring layout of any system you're thinking of buying. Rick On Jan 27, 2008 2:49 PM, wrote: > I have been sitting in the back row on this list, hoping to learn > something. I was born without any electronic genes. I am building an all > metal light sport plane.(Zenith) Right or wrong, I developed the habit (over > five decades of personal, military and commercial flying) of listening to > broadcast radio on the ADF. I'm thinking that I need to install an of the > shelf automobile radio in my project. No second hand Ebay ADF's. My two > questions are: Will I fry the radio if I use only a headset and no speakers? > About the antenna. I know that I should mount it vertically, but it must > withstand airspeed excursions to Vne (156kts/180mph) without going L shaped. > I've come up with somehow jamming it inside the canopy, or insulating it and > mounting against the landing gear, or inside some kind of tubular mast on > the belly. I did come across a NOS Volkswagen telescoping antenna in my > shop. It would be great if that Lyc carburetor turns up again the same way. > Somebody stop me if I'm on the wrong track. This isn't the most pressing > problem out there, but all suggestions are appreciated. > Bob Dingley > > > ************** > Start the year off right. Easy ways to stay in shape. > http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 > > * > > * > > ________________________________________________________________________________
Subject: Re: LEDs at 24volts?
Date: Jan 27, 2008
LED Resistor exist to limit the current flow through the LED. You did not mention want kind of 24v supply you used to test your 12v LED with, I wonder if it had high internal resistance. Your safest bet is to add a serial resistor, otherwise the lifetime of the LED may be VERY short Ira -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160713#160713 ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Z13-8 N error ?
Reading through the docs on E-Mag and P-Mag products, I think the wiring as shown on Z13-8 version N is incorrect. First, the labels are switched. The P-Mag is the one with the internal power generator. Second, the wiring for the real P-Mag I believe is incorrect. As shown, in the center test position, the P-lead, pin 4 is grounded and the battery bus is applied to pin 5. The engine should stop if the P-lead is grounded and it is not possible to test the internal power generator if there is power externally applied. Keep the wiring all the same, but specify the switch as S700-2-1 and I think it should be correct. Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Jan 27, 2008
If you know or measure the current of the LED at 12 V you can divide 12 by the current and obtain the correct series resistor to maintain the same current at 24. Assuming about 20ma for a run of the mill led you would get 600 ohms. 12V across 600 ohms will dissipate .24W so a 1/2 watt resistor would be in order. You will probably find that if the LED doesn't fail at 24V it's series resistor may!! You will find either 560 or 620 ohm resistors are common values and either would work. -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Jan 27, 2008
Subject: Re: Z13-8 N error ?
> >Reading through the docs on E-Mag and P-Mag products, I think the >wiring as shown on Z13-8 version N is incorrect. > >First, the labels are switched. The P-Mag is the one with the >internal power generator. > >Second, the wiring for the real P-Mag I believe is incorrect. >As shown, in the center test position, the P-lead, pin 4 is grounded >and the battery bus is applied to pin 5. The engine should stop if >the P-lead is grounded and it is not possible to test the internal >power generator if there is power externally applied. >Keep the wiring all the same, but specify the switch as S700-2-1 and I >think it should be correct. I checked the drawings again and they are correct as published. The P-Mag is wired to the main bus. This lets you do the occasional "test" of the internal alternator by shutting down the main bus while the engine is running. This is easy to do by configuring the system to the ENDURANCE MODE where flight is sustained with only the E-bus and battery-bus hot. Emagair suggests this test be conducted infrequently . . . about as often as you would test the ENDURANCE MODE of operation for your electrical system. Emagair's drawings do not exploit this feature unique to Z-13/8 . . . and it should not. The vast majority of their customers will not be using Z-13/8. I hope that the majority of my customers ARE using Z-13/8. The E-mag is wired to run from the always-hot battery bus. A means by which power can be removed from the ignition system at shutdown is necessary. Hence the double-pole, three- position, progressive transfer switch offers independent control of E-Mag power and ONLY AFTER the E-mag has been shut down by means of grounding pin 4 (control) has been suggested. This particular architecture was crafted to support AeroElectric Connection philosophy for having all electrically dependent engine functions run from a battery bus. This goes toward a design goal that allows shutting down the entire electrical system with minimal (if not zero) influence on engine operations. Since the E-Mag needs power, it has been wired to the battery bus. The P-Mag is internally powered and needs only occasional tests of its internal power operations . . . which is easy to do when wired as shown by combing the ignition tests with any ENDURANCE MODE tests one might choose to conduct on the rest of the system. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jan 27, 2008
> > In any case, it's not uncommon for a manufacturer > to use common tooling to mold a breaker housing > for all versions, hence you often see the word > "load", "line" or both formed right next to the > breaker's terminals . . . That's likely. There are a bunch of P-B series that use the same case. > > I've asked several tech reps for breakers and > except for enhanced breakers, orientation in > the system doesn't matter. Interestingly enough, > if an electrician encounters "line" and/or "load" > labels on a breaker, he'll wire it up that way > whether it matters or not. And I suspect many > aviation techs do too . . . not because the > physics matters but because some inspector who > doesn't know any better can be counted on to > insist that the protocols be followed. It just happened that the labeling on the P-B's matched my preferred bus bar mounting. The Klixon row below it has the bar on the opposite terminals which then looked wrong to the "do it the standard way and don't ask why" crowd. > The only time I've encountered this as a > "problem" is when a builder finds it convenient > to fabricate a two-row bus-bar and take load > feeders off opposite ends of the breaker. When > they come stamped with a breaker rating, > they look pretty funky with one row upside-down > in their holes! > > Bob . . . > Thanks for reaffirming my choices. Insightful as always. Regards, Greg Young ________________________________________________________________________________
Subject: TNC connections
Date: Jan 27, 2008
Okay, I am having a hard time finding the comic book or other type simple guide to making TNC connections. Is there such a creature at aeroelectic? I found the one for bnc http://www.aeroelectric.com/articles/bnccrimp.pdf is the tnc similar? I ask since my Garmin 430 was converted to the new Garmin 430W and that GPS antenna has a tnc connector. Thanks in advance. Jeff. ________________________________________________________________________________
Date: Jan 28, 2008
Subject: Z13-8 N P-Mags
You might think wiring up an electronic mag might be simple :-( Replacing the S700-2-10 with a S700-2-1 as I indicated in my previous post isn't the correct solution. It does allow removing external power to test the internal alternator, but in normal use, it removes external power before grounding the P-Lead, which is clearly stated by E-Mag as not the way to shut down the engine :-( At one point I had the design such that I used only three switches to control power/ground to the mags, allowing testing and with a position to engage the starter. However, it used three expensive switches and I have encountered poorer reliability with spring return types. The main problem really, is that the power to both mags was routed through one single switch. Since it is not being moved in flight, it is unlikely to fail, but .. My current plan is to use four of the simplest single-pole on-off switches, two for power and two for p-lead grounding, plus a push button for start. So that is a total of five switches, but much simpler and cheaper components and the plane will still fly if any one of them fails. I like the simple flow of operating the switches. However, I am not completely comfortable without a keyswitch, which would be difficult to include in this design. I do not like keyswitches, but there is a clear delineation between someone being (or not) permitted to start the aircraft if they are in possession of the key. To prevent starting, the key would need to disconnect mag power to avoid hand propping. The secret switch under the dash, used for auto anti-theft is a safety of flight issue. Anyone have any good ideas how to handle this ? Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Jan 28, 2008
Subject: Re: Dumb questions (AM radio)
>From: "Richard Girard" <jindoguy(at)gmail.com> >Re: AeroElectric-List: Dumb questions >personal (habit) of listening to broadcast > radio on the ADF. >Bob Dingley Bob, I assume you are an AM radio junkie? My suggestion/opinion DO NOT buy a big heavy car radio/CD player and mount it in the panel. Why? Its heavy and not needed to listen to radio. My suggestion is MOST all intercoms have an audio input with a little phone jack. You can connect a little portable AM/FM battery powered radio or iPod / MP3 player or any audio source you desire to it. The antenna can just be the internal antenna or small whip, no need to install antennas and run coax and add drag/weight. The antenna in cockpit can pick up plenty of signal through plexi. I use a little high quality portable AM/FM radio. It has digital tuning and scanning. The wire from the radio to the head phone acts as the antenna. I just used a little phone to phone jumper cable, plugging it into the intercom, and had radio. It worked very well. I like listening to some radio shows or sports on a cross country. No need to take up the panel with a big automotive unit. Keep it light and keep it simple. Plan on a good intercom and good head sets. The nice thing is when the COM radio kicks in the intercom cuts the entertainment audio out. When the COM is quite, the entertainment fades back in. Go to Radio Shack and search "AM/FM Pocket Radio". There are 23 models to pick from $10-$30. Check out the Grundig Mini 300 AM/FM/SW Pocket Radio, its pretty cool and has a rubber duckie antenna and SW radio, for $30. The DOWN side with radio, as you know, you out fly the station. Of course super powerful AM radio stations at night, with "skip" can be listened to for a long time time, if you are flying towards them. "The Captains Guide", has list of high powered AM radio stations around the county. I can't stand AM radio for the most part. Now [Pod cast are almost anything and often entertainment programs, like radio shows. You download them from the web, often for free. For example I download a NPR program or two on my iPod.] ADF is dead, heavy, bulky and on deaths door with GPS. George ATP/CFI (RV7 still pounding) PS: per other suggestions XM radio is the bomb but cost monthly subscription. However if you have a protable XM radio unit, it can plug into the same intercom audio/aux input the protable AM/FM radio does. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Jan 28, 2008
>Bob, I'm no expert, but I did learn this from one. Some automotive audio >systems use completely separate grounds for each channel. For that you'd >have to rewire your headphones and run three jacks instead of two. This >info may be old, it was a few years ago and things move on, but it never >hurts to ask the sales guy or look at the wiring layout of any system >you're thinking of buying. > >Rick > >On Jan 27, 2008 2:49 PM, <MaxNr(at)aol.com> wrote: >>I have been sitting in the back row on this list, hoping to learn >>something. I was born without any electronic genes. I am building an all >>metal light sport plane.(Zenith) Right or wrong, I developed the habit >>(over five decades of personal, military and commercial flying) of >>listening to broadcast radio on the ADF. I'm thinking that I need to >>install an of the shelf automobile radio in my project. No second hand >>Ebay ADF's. My two questions are: Will I fry the radio if I use only a >>headset and no speakers? About the antenna. I know that I should mount it >>vertically, but it must withstand airspeed excursions to Vne >>(156kts/180mph) without going L shaped. I've come up with somehow jamming >>it inside the canopy, or insulating it and mounting against the landing >>gear, or inside some kind of tubular mast on the belly. I did come across >>a NOS Volkswagen telescoping antenna in my shop. It would be great if >>that Lyc carburetor turns up again the same way. Somebody stop me if I'm >>on the wrong track. This isn't the most pressing problem out there, but >>all suggestions are appreciated. What Rick is referring to is the differential balanced PAIR of wires that goes to each speaker. This is a technique that allows TWO amplifiers to drive both wires of a speaker out of phase with each other. This effectively doubles the potential peak-to-peak voltage to drive each speaker . . . 4x the watts without having to resort to power supply boosters or very low impedance speakers. It also eliminated the need for an output coupling capacitor . . . a fat passive rascal that was a necessary inconvenience. See: http://www.aeroelectric.com/Pictures/Schematics/LM4752.pdf Here's a "single ended" stereo amplifier. Note the 1000 uF capacitors in series with the speakers. Note also that the speakers are grounded on one side. See: http://www.aeroelectric.com/Pictures/Schematics/LM4950.pdf Here we see two amplifiers wired to each side of the speaker. No 1000 uF capacitor needed. Most car radios use a similar scheme with one pair of dif-amps for the front speakers and another pair for the rear speakers, a total of eight, ungrounded wires. There are perhaps a half-dozen ways to adapt the speaker outputs of a radio to the headphone inputs of the intercom. However, many automotive radios have line output features for taking stereo audio to external amplifiers. These are already in the ballpark for connection directly to the stereo inputs of an intercom system. They're already single-ended and shielded against case ground for the radio. I'll suggest you seek a radio with the AUX OUTPUT feature and start from there. If this proves unsatisfactory, I can show you how to craft an interface network to go between your radio's speaker outputs and the stereo inputs of your intercom. The antenna is another deal entirely. Vertically polarized, medium wave signals run along the ground and work really fine with short antennas on ground based vehicles. Once you leave the ground, performance for a short whip antenna degrades. The antenna input to an automotive AM receiver is a unique beast. It's a very high impedance port that is performance degraded by CAPACITY. If you cut the feedline open on a car radio antenna, you may find that the center conductor is a very small single strand of wire supported down the center of the coaxial cable by a hollow plastic tube. This high-impedance coax was supplied to us in large spools at Cessna way back when . . . it was necessary for the purpose of extending the sense antenna feeder from radio on the panel to a feed-through insulator on the cabin roof. I suspect that this input philosophy is still used. Off-the-shelf car antennas come with a run of this specialized "coax" that is already terminated to mate with jacks on radio and base of antenna. The 'ideal' AM receiver antenna for airborne applications would be the "ferrite loopstick" described in the 'Connection's section on antennas. This is an H-field antenna that is not unlike that which your ADF uses to find bearing of an incoming signal. Unfortunately, the loopstick IS directional. Unless you can rotate the antenna, you would need 2 or three of the things along with an ability to switch between them as well as tune them to the station's frequency for best reception. This calls for some experimentation. Ideally, your radio's antenna input would be characterized for performance with a longer piece of coax (higher capacity) and a relatively long wire antenna not unlike that used for sense antennas of the earliest ADFs. In this respect, the ADF receivers and AM radio receivers have a great deal in common with respect to crafting a high performance antenna with an exceedingly small size compared to the wavelength of energy being tapped. Crafting a "high speed" whip antenna has it's challenges. My first thought is that actual orientation of the antenna would have little effect on performance. I think I'd experiment with a "trailing wire" . . . a 5' of wire that attaches to a suitable fitting just before you taxi out. Or, consider crafting a j-bend antenna, not unlike that used for marker beacons. Use the standard AM radio antenna that's a solid rod. Heat it with a torch so that you can put a 90-degree bend in it about 6" from the base. Then allow it to fair rearward and support the tip on an insulated mast of some variety. Check with the automotive radio/audio shops for an antenna with longer than usual coax cable. This might be for a truck, van or RV. The antenna can't be a telescoping variety . . . solid stainless rod is called for. But then, depending on your particular installation, perhaps a standard automotive antenna for a sedan will have enough coax. See what it takes to install it on the belly modified and supported as described above. Let us know how it works out! Bob . . . ________________________________________________________________________________
Date: Jan 28, 2008
Subject: Re: Z13-8 N P-Mags
> >You might think wiring up an electronic mag might be simple :-( > >Replacing the S700-2-10 with a S700-2-1 as I indicated in my previous >post isn't the correct solution. . . . >My current plan is to use four of the simplest single-pole on-off >switches, two for power and two for p-lead grounding, plus a push >button for start. So that is a total of five switches, but much >simpler and cheaper components and the plane will still fly if any one >of them fails. Hmmmm . . . I take it that you have not read my response to your original posting on this topic. Stand the circuit as-published against the design goals stated and see if your concerns are not already addressed by the proposed two-switch configuration. >I like the simple flow of operating the switches. However, I am not >completely comfortable without a keyswitch, which would be difficult >to include in this design. I do not like keyswitches, but there is a >clear delineation between someone being (or not) permitted to start >the aircraft if they are in possession of the key. To prevent >starting, the key would need to disconnect mag power to avoid hand >propping. The secret switch under the dash, used for auto anti-theft >is a safety of flight issue. Anyone have any good ideas how to handle >this ? What are the risks? How many folks of dishonorable behavior know how to fly YOUR airplane? Hundreds of airplanes are subjected to evil intent every year. Radios and instruments are stolen, airframes vandalized but exceedingly few airplanes are removed from their parking places. The most effective theft deterrents are the simplest. Folks who want whole airplanes are generally professional drug runners and the hauling ability of an SE lightplane is simply not in conformance with their business model. One of my favorite deterrents is used by several folks at ICT. See: http://www.aeroelectric.com/Pictures/Misc/AC_Theft_Protection.jpg THIS airplane would haul a LOT of pot . . . The whole idea of a "secret switch" doesn't consider the mind-set of folks who prey upon others. If he/she goes to work on your airplane only to find that the "puzzle" is beyond their ability solve, they're more likely to take out their frustration with a hammer to your panel or a knife to your upholstery or canopy. Thieves are a lazy lot, else they would make their living by exploiting their own productiveness as opposed to exploiting the products of others. Hence a hardened steel chain and lock is very likely to send your antagonist off to "greener" pastures. If you make the solution to the puzzle quite clear from the get-go, they're more likely to go in search of easier prey. I had a hangar renter at 1K1 ask me NOT to lock his airplane. He had to do thousands of dollars of work to repair damage to doors over the years and thieves got his radios anyhow. He correctly deduced that it was a whole lot less expensive to leave the doors unlocked and just have to replace radios. Interestingly enough, after his airplane was moved to our Podunk International Airport (See http://www.aeroelectric.com/Pictures/Misc/1K1_Spring_1989.jpg he was not victim of any more attacks against his airplane. Bob . . . ________________________________________________________________________________
Date: Jan 28, 2008
Subject: Re: TNC connections
> >Okay, > >I am having a hard time finding the comic book or other type simple guide to >making TNC connections. > >Is there such a creature at aeroelectic? > >I found the one for bnc >http://www.aeroelectric.com/articles/bnccrimp.pdf > >is the tnc similar? > >I ask since my Garmin 430 was converted to the new Garmin 430W and that GPS >antenna has a tnc connector. The TNC connectors I have are installed EXACTLY the same way with the same tools. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Alternator Problems
Date: Jan 28, 2008
I have a B&C 60 Amp alternator and a B&C Voltage regulator. Lately on 3 occasions, while out flying, after about 20 minutes, my alternator stops putting out( Amps go to zero, and volts start dropping). Upon landing and charging battery(to Make it home). All works well. Also notice that the volts, while cruising, while the alternator is on line, vary from 13.5to 14.9 . I have checked all the wiring and it SEEMS fine. Do I have a voltage regulator problem??? Thanks Al Grajek RV8 859-361-9460 algrajek(at)msn.com -------- just rv8in Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160846#160846 ________________________________________________________________________________
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
Subject: Soliciting knowledgable comments about Eagle EMS
Date: Jan 28, 2008
Have any listers looked at this system? I saw it at EAA NW/Arlington 2007. I bent the ears of both the Precision Airmotive guys and Bart LaLonde at Aerosport about it. Among its appeals are excellent mixture distribution, easy starting, no return lines, self-purging for easier hot starts and seemingly a lot of redundancy designed into the system. Coming from an automotive engineering background, adjusting my R&D expectations to the reality of miniscule (by comparison) aviation sales volume has proven difficult at times for me. There just isn't enough sales volume to amortize a great deal of testing. Furthermore, I am probably a little more of a flyer than a builder, but there is nothing like an RV-7 and modern avionics available unless one builds it oneself. Although I generally am uncomfortable with the idea of being a Beta tester, the Eagle EMS has definite appeal. The system appears to be the first common rail/timed fuel injection developed for aircraft engine use. Common rail/pulse width fuel injection has been the auto industry preferred choice for at least 15 years. Precision Airmotive has had units flying in two different test beds for about 5 years, supposedly without issues. If one wishes to equip a Lycoming (clone) engine with an Eagle EMS the engine must be purchased from one of only three experimental engine suppliers, Aerosport, G&N or Penn Yann. All of these suppliers have stellar reputations. Their selection will provide some assurance of "proper installation." Perhaps this will avoid the "great debate" over whether any problems exposed are installation related, as we have seen with BMA. At any rate, if you are familiar with this system and have comments I would appreciate it if you would share them, especially if they are "failure mode analysis' type comments. Thanks, Larry Tompkins ________________________________________________________________________________
Subject: Firewall penetration
Date: Jan 28, 2008
Hi- Working on making firewall penetrations and making them fireproof. I'm using steel eyeballs for engine control cables and a stainless heater valve. I'm expecting to have a single penetration for electrical wiring and for engine sensors etc near the battery box. I like Bob's modified grab handle method for a fireproof penetration but it's larger and bulkier than I need. And it's probably not a good use of my $time$ to try to come up with a less expensive alternative to the SafeAir 1 stainless fire wall pass through system; it's only $50. But it's $50! I came across a plumbing fitting in the "swamp cooler" section of my local plumbing supply today and it just might be a $3.50 alternative. I have posted some photos at http://picasaweb.google.com/rvtach/FirewallPassthrough that show the hardware. It comes threaded internally for 1/2" NPT. I removed the threads by running a 7/8" drill through it. The whole thing fits snugly through a 1" hole and is secured by a threaded nut which would need to be secured with some thread locker. I would use firesleeve and hose clamps like Bob's grab handle or the SafeAir 1 product. There's just over 1/2" to clamp the sleeve to which is a little short but should be adequate. So, can any of you guys think of any problems with this method? Maybe I shouldn't use brass hardware against the s/s firewall? Brass melts to easily? Anything? Appreciate any help at all here. -------- Jim McChesney Tucson, AZ RV-7A Finishing Kit Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160931#160931 ________________________________________________________________________________
Subject: Re: Firewall penetration
Date: Jan 28, 2008
Hello, Tony Bingelis wrote an article on making pass-thru fittings. They are similar to those used on Cessnas except that they are one piece where as the Cessna fittings are two piece. They are oval in shape, SS with fire retardant material surrounding your pass-thru item. You make them out of stainless steel using sockets or pipe as the forming die. They are attached to the firewall with 2 screws. You drill a hole to fit your pass-thru item. You can make them as large or small as you like. You just have to find the right die. I will see if I can find the article and maybe I can post some pictures or a poorly drawn facsimile. BTW, in case of an engine fire, you want these fittings to provide some protection so you really need something good. JF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=160942#160942 ________________________________________________________________________________
Date: Jan 28, 2008
Be aware of possible impact on engine sensor data if sensor leads are too close to high current (fat) wires. Dale Ensing ----- Original Message ----- From: "rvtach" <rvtach(at)msn.com> Sent: Monday, January 28, 2008 6:42 PM Subject: AeroElectric-List: Firewall penetration > > Hi- > > Working on making firewall penetrations and making them fireproof. I'm > using steel eyeballs for engine control cables and a stainless heater > valve. I'm expecting to have a single penetration for electrical wiring > and for engine sensors etc near the battery box. > > I like Bob's modified grab handle method for a fireproof penetration but > it's larger and bulkier than I need. And it's probably not a good use of > my $time$ to try to come up with a less expensive alternative to the > SafeAir 1 stainless fire wall pass through system; it's only $50. But it's > $50! I came across a plumbing fitting in the "swamp cooler" section of my > local plumbing supply today and it just might be a $3.50 alternative. I > have posted some photos at > http://picasaweb.google.com/rvtach/FirewallPassthrough that show the > hardware. > > It comes threaded internally for 1/2" NPT. I removed the threads by > running a 7/8" drill through it. The whole thing fits snugly through a 1" > hole and is secured by a threaded nut which would need to be secured with > some thread locker. I would use firesleeve and hose clamps like Bob's > grab handle or the SafeAir 1 product. There's just over 1/2" to clamp the > sleeve to which is a little short but should be adequate. > > So, can any of you guys think of any problems with this method? Maybe I > shouldn't use brass hardware against the s/s firewall? Brass melts to > easily? Anything? Appreciate any help at all here. > > -------- > Jim McChesney > Tucson, AZ > RV-7A Finishing Kit > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=160931#160931 > > > ________________________________________________________________________________
Subject: Thumb screws for plastic hoods
Date: Jan 28, 2008
Having worked on PCs for the last 25 years I have learned to hate the little screws that are used to fasten db connectors to the back of computers. Fortunately, most cable manufacturers have gone to using thumb screws so a screw driver is not required. Until GRT, Trutrak, and others!! After two false starts I have finally found a supplier and the thumb screw that will fit most all the plastic db hoods provided by GRT, Trutrak, and others. You may not care BUT IF YOU DO here is the link to the part. 50 of them will cost you 12.50 plus frt. ($6.10) and tax ($1.07). Allied Electronics, Inc. Stock No. is 810-0009. Link to page follows: https://www.alliedelec.com/Search/ProductDetail.asp?SKU=810-0009&SEARCH=&MPN =B71E014276&DESC=B71E014276&R=810%2D0009&sid=479D1B001E0BE17F Allen Fulmer RV7 Wiring/Plumbing Eggenfellner Subaru E6T on firewall N808AF reserved Alexander City, AL 256-329-2001 ________________________________________________________________________________
Date: Jan 28, 2008
rvtach wrote: > > Hi- > > Working on making firewall penetrations and making them fireproof. I'm using steel eyeballs for engine control cables and a stainless heater valve. I'm expecting to have a single penetration for electrical wiring and for engine sensors etc near the battery box. > > I like Bob's modified grab handle method for a fireproof penetration but it's larger and bulkier than I need. And it's probably not a good use of my $time$ to try to come up with a less expensive alternative to the SafeAir 1 stainless fire wall pass through system; it's only $50. But it's $50! I came across a plumbing fitting in the "swamp cooler" section of my local plumbing supply today and it just might be a $3.50 alternative. I have posted some photos at http://picasaweb.google.com/rvtach/FirewallPassthrough that show the hardware. > > It comes threaded internally for 1/2" NPT. I removed the threads by running a 7/8" drill through it. The whole thing fits snugly through a 1" hole and is secured by a threaded nut which would need to be secured with some thread locker. I would use firesleeve and hose clamps like Bob's grab handle or the SafeAir 1 product. There's just over 1/2" to clamp the sleeve to which is a little short but should be adequate. > > So, can any of you guys think of any problems with this method? Maybe I shouldn't use brass hardware against the s/s firewall? Brass melts to easily? Anything? Appreciate any help at all here. > > -------- > Jim McChesney > Tucson, AZ > RV-7A Finishing Kit Is it a brass fitting? If so, it will melt at a lower temp than stainless, but so will the aluminum rivets & angles (and the copper wire going through it will, too). You might be able to find the same fitting in stainless from a food supply grade plumbing supplier. You just have to weigh risk/benefit/expense. My personal opinion is that there's much more risk from the heater penetration, even with stainless parts, than with any penetration carrying solid wires or steel cables. If you look at the air gap around the flapper valve on the heater penetration, the total area of the gap is effectively a gaping hole, compared to a wire penetration filled with wire & fire suppressing caulk. Charlie ________________________________________________________________________________
Date: Jan 28, 2008
rvtach wrote: > So, can any of you guys think of any problems with this method? Maybe I shouldn't use brass hardware against the s/s firewall? Brass melts to easily? Anything? Appreciate any help at all here. > A big contributor to the elbow fitting's effectiveness is the elbow. The fire would have to turn a corner. You loose that with a straight through fitting. It should be fairly easy to find a stainless elbow that would do the same thing. You might have to got up to $10 to get one though 8*) ________________________________________________________________________________
Date: Jan 29, 2008
Subject: Re: Note 8 in App_ ZR11 M
> >Bob, >Instead of running the test lead from the alternator, can one run the lead >from terminal #4 of the LR3C-14? Sure . . . you're looking for a voltage measurement on that lead. The only advantage of moving out on the lead is to include an ability to sense broken circuits further downstream. Bob . . . ________________________________________________________________________________
Date: Jan 29, 2008
Subject: Re: Alternator Problems
> >I have a B&C 60 Amp alternator and a B&C Voltage regulator. Lately on 3 >occasions, while out flying, after about 20 minutes, my alternator stops >putting out( Amps go to zero, and volts start dropping). Upon landing and >charging battery(to Make it home). All works well. Also notice that the >volts, while cruising, while the alternator is on line, vary from 13.5to >14.9 . I have checked all the wiring and it SEEMS fine. Do I have a >voltage regulator problem??? Note 8 in Appendix Z describes a troubleshooting technique that will help you isolate the problem to wiring, alternator or regulator. You want to know exactly where the problem is before you remove anything from the airplane. Bob . . . ________________________________________________________________________________
Date: Jan 29, 2008
It is not difficult to make a stainless guillotine valve right on the firewall. A pull cable pulls a plate over the firewall hole to block it and control the heat. In case things distort in a fire, I have it set to pull closed. It is on the cabin side of the FW. Perhaps not as good a solution for those who have to dump excess manifold heat but excellant for water heat and for fire blocking. Ken snip > My personal opinion is that there's much more risk from the heater > penetration, even with stainless parts, than with any penetration > carrying solid wires or steel cables. If you look at the air gap around > the flapper valve on the heater penetration, the total area of the gap > is effectively a gaping hole, compared to a wire penetration filled with > wire & fire suppressing caulk. > > Charlie > ________________________________________________________________________________
Date: Jan 29, 2008
I found the article that I mentioned on the EAA builders site. http://members.eaa.org/home/homebuilders/building/firewall/How%20to%20Make%20Firewall%20Grommet%20Shields.html#TopOfPage Check this out and see if it will work for you. JF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=161057#161057 ________________________________________________________________________________
Date: Jan 29, 2008
From: "David E. Nelson" <david.nelson(at)pobox.com>
Hi Jim, Clever idea. I presume it's brass so it's corrosion resistant even though you drilled out the threads. I saw a clever use of EMT tubing set screw connectors (ie steel electrical conduit tubing). You can see a picture here (search for 'set-screw'): http://www.alliedtube.com/electrical-raceways/conduit/emt-connectors-couplings.asp The builder had notched out the set screw. Personally, I think I'd leave the set screw hole (and toss the set screw) and make sure the inside of coupling was free of any burrs, etc. The set screw hole is slightly raised thus providing a little bit of a "barb" to keep any clamps and fire sleeve from backing out. The connectors are available in a variety of nominal sizes from 1/2", 3/4", 1", 1-1/4", 1-1/2", all the way up to 4". Any hardware store (at least in the US) would have the smaller sizes. I would also think about using some .032 sheet behind the locking nut rather than have the nut gouge the firewall. Regards, /\/elson Austin, TX RV-7A - Canopy frame ~~ Lately my memory seems to be like a steel trap .... without any spring. ~~ On Mon, 28 Jan 2008, rvtach wrote: > > Hi- > > Working on making firewall penetrations and making them fireproof. I'm using steel eyeballs for engine control cables and a stainless heater valve. I'm expecting to have a single penetration for electrical wiring and for engine sensors etc near the battery box. > > I like Bob's modified grab handle method for a fireproof penetration but it's larger and bulkier than I need. And it's probably not a good use of my $time$ to try to come up with a less expensive alternative to the SafeAir 1 stainless fire wall pass through system; it's only $50. But it's $50! I came across a plumbing fitting in the "swamp cooler" section of my local plumbing supply today and it just might be a $3.50 alternative. I have posted some photos at http://picasaweb.google.com/rvtach/FirewallPassthrough that show the hardware. > > It comes threaded internally for 1/2" NPT. I removed the threads by running a 7/8" drill through it. The whole thing fits snugly through a 1" hole and is secured by a threaded nut which would need to be secured with some thread locker. I would use firesleeve and hose clamps like Bob's grab handle or the SafeAir 1 product. There's just over 1/2" to clamp the sleeve to which is a little short but should be adequate. > > So, can any of you guys think of any problems with this method? Maybe I shouldn't use brass hardware against the s/s firewall? Brass melts to easily? Anything? Appreciate any help at all here. > > -------- > Jim McChesney > Tucson, AZ > RV-7A Finishing Kit > > > Read this topic online here: >
January 12, 2008 - January 29, 2008
AeroElectric-Archive.digest.vol-ho
