AeroElectric-Archive.digest.vol-hr
March 04, 2008 - March 23, 2008
      On all other drawings it appears the E-BUS normal feed is directly off the
      Main PWR Dist Block binding post (not a breaker) thru a diode.
      Is there a reason for the different setup on the Z-19 series?
      Mark Sletten
Date: Mar 04, 2008
Subject: New EMAG and PMAG Wiring question
This idea may have been hashed/rehashed enough, but I can't resist putting in my two cents.. Bob has said (and others have agreed) that it makes sense to design system architecture to comfortably deal with single failures gracefully. The odds of having multiple component failures on a single flight is comfortably unlikely, given good component selection and best practices installation/implementation methods. This is how to have low cost fault tolerance. In my opinion, the P-mags are best powered from the main bus. Their operation on internal power can be checked regularly (once per flying day?). If an in-flight situation develops that warrants shutting down the main bus (electrical fire, main alternator failure, etc.), I think you can be confident that both p-mags will continue to function on internal power. No sweat. This is one of the beauties of the P-mags - they allow for more easy fault tolerance. I believe this is part of the rationale of the recommended wiring configuration. You say, "you like the idea of running them (the P-mags) from the always hot battery bus." Can you explain why you like the idea of this? Regards, Matt- > > > >> >>Thanks Bob. I forgot to mention that I have 2 PMAGS and like the idea of >>running them from the always hot battery bus. > > It's your airplane. I'm only echoing a design philosophy > that's recommended by the manufacturer supported by > a elegant assemblage of simple-ideas. You'll need to > do something different with respect to the switching. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 04, 2008
Matt and Bob. Thanks for the replies. I guess this was just a left over idea from Bob's original design. Both of my PMAGs will be powered from the main bus. Don ---- Matt Prather wrote: > > This idea may have been hashed/rehashed enough, but I can't resist putting > in my two cents.. > > Bob has said (and others have agreed) that it makes sense to design system > architecture to comfortably deal with single failures gracefully. The > odds of having multiple component failures on a single flight is > comfortably unlikely, given good component selection and best practices > installation/implementation methods. This is how to have low cost fault > tolerance. > > In my opinion, the P-mags are best powered from the main bus. Their > operation on internal power can be checked regularly (once per flying > day?). If an in-flight situation develops that warrants shutting down the > main bus (electrical fire, main alternator failure, etc.), I think you > can be confident that both p-mags will continue to function on internal > power. No sweat. This is one of the beauties of the P-mags - they allow > for more easy fault tolerance. I believe this is part of the rationale of > the recommended wiring configuration. > > You say, "you like the idea of running them (the P-mags) from the always > hot battery bus." Can you explain why you like the idea of this? > > > Regards, > > Matt- > > > > > > > > > >> > >>Thanks Bob. I forgot to mention that I have 2 PMAGS and like the idea of > >>running them from the always hot battery bus. > > > > It's your airplane. I'm only echoing a design philosophy > > that's recommended by the manufacturer supported by > > a elegant assemblage of simple-ideas. You'll need to > > do something different with respect to the switching. > > > > Bob . . . > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Starter Choice
Date: Mar 04, 2008
I am changing the engine on my One Design. I am removing an O-320-E3D and fitting an IO-360-B1B (180 hp regular compression). I will be fitting an Odyssey 17ah battery. The 320 has a B&C starter that has been used for around 100 hours, it also has 122 teeth on the starter ring. The 360 has a Sky-tec PM starter (and is brand new and is painted bright red) and a 149 tooth starter ring. The airplane is fitted with a B&C SD-8 generator so cannot guarantee a fully charged battery every time. I have heard stories that permanent magnet starters and Odyssey batteries do not get on, and that starting is often slow, especially the first couple of blades. All things being equal I would swap the starter and the starter ring, but that's not possible as the part numbers of the starter rings between the two engines are different - I don't know the precise differences, and I would have to paint the old starter ring. To be able to use the B&C starter on the new engine B&C recommend I change out the ring gear, or return the starter for overhaul ($310 plus shipping from Europe). And will have to change something on the old engine. So my questions is, am I right to be concerned about the long term abilities of a Skytec PM starter and the Odyssey battery to provide reliable starting? Does anyone have any experience with this combination? Regards, Peter ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Mar 04, 2008
there are many Io360's and Skytec PM starters used mainly on Vans aircraft. ..In fact the Odyssy is that standard supplied battery...Never heard of any one having an issue...Mine works just fine. Now, Skytecs will break if they suffer kickback, My emags avoid this by all owing three blades to pass through before firing...This can be over ridden if you ever had to hand prop. But generally the odyssy/Skytech combo has a long relaible track record. Frank RV7a Io360 ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Peter Pengilly Sent: Tuesday, March 04, 2008 2:20 PM Subject: AeroElectric-List: Starter Choice I am changing the engine on my One Design. I am removing an O-320-E3D and f itting an IO-360-B1B (180 hp regular compression). I will be fitting an Ody ssey 17ah battery. The 320 has a B&C starter that has been used for around 100 hours, it also has 122 teeth on the starter ring. The 360 has a Sky-tec PM starter (and is brand new and is painted bright red) and a 149 tooth st arter ring. The airplane is fitted with a B&C SD-8 generator so cannot guar antee a fully charged battery every time. I have heard stories that permanent magnet starters and Odyssey batteries d o not get on, and that starting is often slow, especially the first couple of blades. All things being equal I would swap the starter and the starter ring, but that's not possible as the part numbers of the starter rings betw een the two engines are different - I don't know the precise differences, a nd I would have to paint the old starter ring. To be able to use the B&C st arter on the new engine B&C recommend I change out the ring gear, or return the starter for overhaul ($310 plus shipping from Europe). And will have t o change something on the old engine. So my questions is, am I right to be concerned about the long term abilitie s of a Skytec PM starter and the Odyssey battery to provide reliable starti ng? Does anyone have any experience with this combination? Regards, Peter ________________________________________________________________________________
Date: Mar 04, 2008
Subject: Re: Starter Choice
Peter, I have over 500 flight hours on my O-360 with a skytec permanent magnet starter and not one moment of problem with just an Odyssey 17 AH battery and a B&C SD-8 permanent magnet alternator. Jim ---------------------------------------------------------------------------------- Peter Pengilly wrote: I am changing the engine on my One Design. I am removing an O-320-E3D and fitting an IO-360-B1B (180 hp regular compression). I will be fitting an Odyssey 17ah battery. The 320 has a B&C starter that has been used for around 100 hours, it also has 122 teeth on the starter ring. The 360 has a Sky-tec PM starter (and is brand new and is painted bright red) and a 149 tooth starter ring. The airplane is fitted with a B&C SD-8 generator so cannot guarantee a fully charged battery every time. I have heard stories that permanent magnet starters and Odyssey batteries do not get on, and that starting is often slow, especially the first couple of blades. All things being equal I would swap the starter and the starter ring, but thats not possible as the part numbers of the starter rings between the two engines are different I dont know the precise differences, and I would have to paint the old starter ring. To be able to use the B&C starter on the new engine B&C recommend I change out the ring gear, or return the starter for overhaul ($310 plus shipping from Europe ). And will have to change something on the old engine. So my questions is, am I right to be concerned about the long term abilities of a Skytec PM starter and the Odyssey battery to provide reliable starting? Does anyone have any experience with this combination? Regards, Peter ---------------------------------------------------------------------------------- ________________________________________________________________________________
Date: Mar 05, 2008
Subject: Re: New EMAG and PMAG Wiring question
Don _ I have wired my 2 p-mags as follows. Both are connected via a fuse to the main bus. I have then used two 2-50 switches, one for each mag. - in the bottom position with the master on, the P-mag was powered, but the P-lead off. - in the middle position (and this is the normal flying position) the power and P-lead is on. - in the top, momentary position, the power is cut. (To test the self generation.) The P-lead remains on. Operating this way the P-mag would see power once the master is on. It would only loose power from the battery when the engine is running and you switch to the self generation test. P-mag condone that. So to test say the RH mag before takeoff, you turn the LH mag's plugs off, by pushing the switch down from the middle position. It remains powered but the p-lead is off. You then lift the RH switch. It should keep running if it is self generating. It is very close to the e-mag wiring but permits just two switches. It makes sense to me. Steve. ________________________________________________________________________________
Subject: VOR Diplexer
Date: Mar 05, 2008
I'm building an RV7A with one SL-30 radio and inside the wingtip antennae. I'll probably use the Sport Aircraft design for the antennae. Question is, can I use a diplexer "backwards" to feed the one VOR with two antenna feeds to both boost signal and reduce shadowing effects? Would a standard diplexer work, or would I need something special? Thanks in advance, Terry 7A Panel Wiring ________________________________________________________________________________
From: "Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: RG-400 vs. RG-142?
Date: Mar 05, 2008
I know that has been discussed before, but I want to be sure. Are there any significant downsides to using RG-142 for aircraft antenna applications where the cable will not be regularly flexed (except for normal vibration)? I am somewhat leery of using a solid core coax. Andy Elliott, Mesa, AZ N601GE (reserved) 601XL/TD, Corvair, building... ________________________________________________________________________________
Date: Mar 05, 2008
From: "Dawson, Bill" <Bill.Dawson(at)pepperdine.edu>
You are talking about diversity reception. Google that term and lot's of things pop up. I use it a great deal with wireless mics. Go to this website for starters... http://www.lectrosonics.com/WPapers-Magazines/ReceptionTechniques/Recepti onTechniques.htm The problem is, the antennas can not be tied together as the signal one picks up will not be in phase with the other antenna. The result is a reduced signal and in some cases complete cancel of the signal. So how do the dual antenna receivers do it? They constantly sample the antennas and *switch* to the antenna with the most signal. Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com on behalf of Terry Frazier Sent: Wed 3/5/2008 7:51 AM Subject: AeroElectric-List: VOR Diplexer I'm building an RV7A with one SL-30 radio and inside the wingtip antennae. I'll probably use the Sport Aircraft design for the antennae. Question is, can I use a diplexer "backwards" to feed the one VOR with two antenna feeds to both boost signal and reduce shadowing effects? Would a standard diplexer work, or would I need something special? Thanks in advance, Terry 7A Panel Wiring ________________________________________________________________________________
Date: Mar 05, 2008
Subject: static system leak check procedure
I started to do a preliminary static system leak check and noticed that it only takes about 500 feet of static vacuum to make the ASI read about 100 knots. 10 or 20 thousand feet would peg the ASI pretty firmly. Is the pitot side subjected to the same vacuum as the static side of the system to prevent altimeter damage or is that not a concern? It seems prudent to check for obvious leaks before taking the plane to the radio shop. thank you Ken ________________________________________________________________________________
Date: Mar 05, 2008
Subject: Re: static system leak check procedure
I did a similar test with the ASI removed and its fittings plugged to verify the integrity of the rest of the system up to 20000ft. Then I put it all back together and verified the leakdown integrity. -----Original Message----- >From: Ken <klehman(at)albedo.net> >Sent: Mar 5, 2008 2:02 PM >To: aeroelectric-list(at)matronics.com >Subject: AeroElectric-List: static system leak check procedure > > >I started to do a preliminary static system leak check and noticed that >it only takes about 500 feet of static vacuum to make the ASI read about >100 knots. 10 or 20 thousand feet would peg the ASI pretty firmly. Is >the pitot side subjected to the same vacuum as the static side of the >system to prevent altimeter damage or is that not a concern? It seems >prudent to check for obvious leaks before taking the plane to the radio >shop. >thank you >Ken > > ________________________________________________________________________________
Date: Mar 05, 2008
Frank & Jim, Thanks for your advice - do nothing is an option! Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of J. Mcculley Sent: 04 March 2008 23:47 Subject: Re: AeroElectric-List: Starter Choice Peter, I have over 500 flight hours on my O-360 with a skytec permanent magnet starter and not one moment of problem with just an Odyssey 17 AH battery and a B&C SD-8 permanent magnet alternator. Jim ------------------------------------------------------------------------ ---------- Peter Pengilly wrote: I am changing the engine on my One Design. I am removing an O-320-E3D and fitting an IO-360-B1B (180 hp regular compression). I will be fitting an Odyssey 17ah battery. The 320 has a B&C starter that has been used for around 100 hours, it also has 122 teeth on the starter ring. The 360 has a Sky-tec PM starter (and is brand new and is painted bright red) and a 149 tooth starter ring. The airplane is fitted with a B&C SD-8 generator so cannot guarantee a fully charged battery every time. I have heard stories that permanent magnet starters and Odyssey batteries do not get on, and that starting is often slow, especially the first couple of blades. All things being equal I would swap the starter and the starter ring, but that's not possible as the part numbers of the starter rings between the two engines are different - I don't know the precise differences, and I would have to paint the old starter ring. To be able to use the B&C starter on the new engine B&C recommend I change out the ring gear, or return the starter for overhaul ($310 plus shipping from Europe ). And will have to change something on the old engine. So my questions is, am I right to be concerned about the long term abilities of a Skytec PM starter and the Odyssey battery to provide reliable starting? Does anyone have any experience with this combination? Regards, Peter ------------------------------------------------------------------------ ---------- ________________________________________________________________________________
Date: Mar 05, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: RG-400 vs. RG-142?
>I know that has been discussed before, but I want to be sure. Are there >any significant downsides to using RG-142 for aircraft antenna >applications where the cable will not be regularly flexed (except for >normal vibration)? I am somewhat leery of using a solid core coax. Then use the stranded version, RG-400. RG-58 in the lengths we common use for small airplanes does not present a significant performance impact. However, the materials from which RG-58 is made and the technology behind the design of the coax is now over 60 years old. See: http://www.aeroelectric.com/Pictures/Curves/coaxloss1.pdf Consider a 10' run of coax from GPS receiver to antenna. RG58 offers an attenuation of about 35db/100'; RG-400/142 is about 24db/100'. 10' runs reduce to 3.5 and 2.4 db for a difference of 1.3 db . . . delta that is impossible to observe and difficult to measure at that frequency. With respect to materials, RG-400/142 are double- layer, silver-plated shield and fabricated from modern cousins to Teflon. It's the best we know how to do . . . today. Bob . . . ________________________________________________________________________________
Date: Mar 05, 2008
>I am changing the engine on my One Design. I am removing an O-320-E3D and >fitting an IO-360-B1B (180 hp regular compression). I will be fitting an >Odyssey 17ah battery. The 320 has a B&C starter that has been used for >around 100 hours, it also has 122 teeth on the starter ring. The 360 has a >Sky-tec PM starter (and is brand new and is painted bright red) and a 149 >tooth starter ring. The airplane is fitted with a B&C SD-8 generator so >cannot guarantee a fully charged battery every time. Size of the alternator certainly influences how well your battery is charged at shutdown. But judicious stewardship of stored energy from the battery after to back off the throttle for approach to landing can go a long way toward mitigating the effects. From an energy perspective, cranking an engine takes perhaps 5% of the total energy stored on your battery. If you use say 20% off the top during descent and taxi to parking, cranking performance from 100% charge versus 80% charge would not be terribly noticable. > > >I have heard stories that permanent magnet starters and Odyssey batteries >do not get on, and that starting is often slow, especially the first >couple of blades. All things being equal I would swap the starter and the >starter ring, but that s not possible as the part numbers of the starter >rings between the two engines are different I don t know the precise >differences, and I would have to paint the old starter ring. To be able to >use the B&C starter on the new engine B&C recommend I change out the ring >gear, or return the starter for overhaul ($310 plus shipping from Europe). >And will have to change something on the old engine. >So my questions is, am I right to be concerned about the long term >abilities of a Skytec PM starter and the Odyssey battery to provide >reliable starting? Does anyone have any experience with this combination? This question stands on a whole lot of variables both in the observed performance of your as-installed starter/proposed battery -AND- the as-installed/ demonstrated battery of those who would hope to advise you. Let's consider another approach that takes advantage of a demonstrated experiment using your equipment. What are the risks of leaving the present starter in place and going ahead with the installation? EVERY starter system benefits from wound-field starter motors in terms of cranking under worst case conditions. However, there are thousands of PM starters in service where users report satisfactory performance to their needs. I'll suggest that if time and costs to get your new engine installed are to be minimized, there's little risk in leaving the system configured as you've described. In fact, I'll suggest there is an advantage for leaving the configuration alone. You have a significant task for changing out the engine and getting everything tight and tuned up. Why not get these tasks done while being sensitive to starter performance for the purpose of answering your own question . . . and then having some experimental data to share with the rest of us? Bob . . . ________________________________________________________________________________
Subject: z16 rev L
Date: Mar 05, 2008
Question for Bob. I am doing my final wiring checkout on my soon to be complete Pulsar lll Rotax 912 project. I came across a revision L to Z16. Question, Was their a specific problem for the change to the alternator disconnect ckt? and would you recommend changing from version k to rev. L and why. Thanks Bill ________________________________________________________________________________
Date: Mar 06, 2008
By the way, can somebody explain how is a static leak check performed? Carlos > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Ken > Sent: quarta-feira, 5 de Maro de 2008 19:02 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: static system leak check procedure > > > I started to do a preliminary static system leak check and noticed that > it only takes about 500 feet of static vacuum to make the ASI read about > 100 knots. 10 or 20 thousand feet would peg the ASI pretty firmly. Is > the pitot side subjected to the same vacuum as the static side of the > system to prevent altimeter damage or is that not a concern? It seems > prudent to check for obvious leaks before taking the plane to the radio > shop. > thank you > Ken ________________________________________________________________________________
Date: Mar 05, 2008
Subject: Status of the small strobe wiring experiment.
Neal's strobe parts have arrived. I've decided to shift the emphasis to a lab experiment. My good ol' Luna Pro-F flash light meter died years ago and I've had no good reason to replace it until now. Just picked up a much younger replacement off of Ebay. We'll wire one tube with 15' of 20AWG Beldfoil and the other with 22AWG twisted trio and see what the difference is between light output of the two tubes. I'll also get some waveforms for both the flash-tubes and the 14V DC input power. We can convert these measurement to total energy numbers. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 05, 2008
Subject: Re: z16 rev L
> Question for Bob. I am doing my final wiring checkout on my soon to be > complete Pulsar lll Rotax 912 project. I came across a revision L to > Z16. Question, Was their a specific problem for the change to the > alternator disconnect ckt? and would you recommend changing from version > k to rev. L and why. Thanks Bill It's a cleaner way to do it. The previous configuration will function as advertised but it's better to interrupt the energy flow as close to the source as possible. Bob . . . ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Date: Mar 05, 2008
Carlos, check out the following website... http://www.kilohotel.com/rv8/rvlinks/ssec.html Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Wednesday, March 05, 2008 7:16 PM Subject: RE: AeroElectric-List: static system leak check procedure --> By the way, can somebody explain how is a static leak check performed? Carlos > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Ken > Sent: quarta-feira, 5 de Maro de 2008 19:02 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: static system leak check procedure > > > I started to do a preliminary static system leak check and noticed > that it only takes about 500 feet of static vacuum to make the ASI > read about 100 knots. 10 or 20 thousand feet would peg the ASI pretty > firmly. Is the pitot side subjected to the same vacuum as the static > side of the system to prevent altimeter damage or is that not a > concern? It seems prudent to check for obvious leaks before taking the > plane to the radio shop. > thank you > Ken ________________________________________________________________________________
Subject: RE: "Poor Man's" coax termination with RG-400
Date: Mar 06, 2008
Since RG-400 has a doulble braid shield, how do I do the "Poor Man's" coax termination with it? Braid the two shields as one and crimp on the lug OR .... Rodney in Tennessee _________________________________________________________________ Need to know the score, the latest news, or you need your Hotmail=AE-get yo ur "fix". http://www.msnmobilefix.com/Default.aspx ________________________________________________________________________________
Date: Mar 06, 2008
Here's how I did it: I got a vacuum brake bleeding kit (JC Whitney IIRC) - it has a guage that will allow you to see an evacuation level and watch it change. I disconnected my ASI, VSI, and capped off the rest of the static system. The VSI has a built in leak and the ASI limits your altitude as the airspeed is artificially induced by the differential pressure. I plugged one static port and attached the brake bleeder to the other port. Pump the handle and watch the dial as you pull a vacuum. (I did mine all the way to 20,000'). Start a stop watch and look for the dial to rotate downward indicating leakdown. Swap static ports and start over. I added the ASI and did another test with lower altitude levels to ensure the integrity of the ASI. Swap static ports and start over. You're allowed 100'/min IIRC from the regs - I ended up with 150'/hr so I think I'm OK...... Someone may convince me of the error of my ways and I'll re-do it differently - but noone's tried yet. -----Original Message----- >From: Carlos Trigo <trigo(at)mail.telepac.pt> >Sent: Mar 5, 2008 7:16 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: static system leak check procedure > > >By the way, can somebody explain how is a static leak check performed? > >Carlos > > >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list- >> server(at)matronics.com] On Behalf Of Ken >> Sent: quarta-feira, 5 de Maro de 2008 19:02 >> To: aeroelectric-list(at)matronics.com >> Subject: AeroElectric-List: static system leak check procedure >> >> >> I started to do a preliminary static system leak check and noticed that >> it only takes about 500 feet of static vacuum to make the ASI read about >> 100 knots. 10 or 20 thousand feet would peg the ASI pretty firmly. Is >> the pitot side subjected to the same vacuum as the static side of the >> system to prevent altimeter damage or is that not a concern? It seems >> prudent to check for obvious leaks before taking the plane to the radio >> shop. >> thank you >> Ken > > ________________________________________________________________________________
Date: Mar 06, 2008
You can do an acceptable test much more simply than this. The standard (as described in FAR 23.1325(b)(2)(i)) only calls for enough vacuum to raise th e indicated altitude 1000 ft above the altitude of the test site. On my RV-8 , I put a piece of tape over one static port, and held a piece of rubber hose against the other static port. I put the other end of the hose in my mouth , and sucked until I had increased the altitude more than 1000 ft. I put my tongue over the end of hose to trap the pressure, and made sure to keep pushing the other end hard against the static port so no air leaked out there. The altimeter dropped much less than 100 ft in a minute (the pass/fail criteria from FAR 23.1325), so my system was OK. There is no need to disconnect ASI or VSI (assuming you don't introduce excessive vacuum, which could damage an ASI). In fact, doing it with instruments removed invalidates the test, as you might introduce a leak whe n you put those instruments back into the static system. You really need to do an end-to-end leak check with the whole static system in the state it would be when you fly the airplane. Kevin Horton On Thu, Mar 6, 2008 at 8:27 AM, Ralph E. Capen wrote: > recapen(at)earthlink.net> > > Here's how I did it: > > I got a vacuum brake bleeding kit (JC Whitney IIRC) - it has a guage that > will allow you to see an evacuation level and watch it change. > > I disconnected my ASI, VSI, and capped off the rest of the static system. > The VSI has a built in leak and the ASI limits your altitude as the > airspeed is artificially induced by the differential pressure. > > I plugged one static port and attached the brake bleeder to the other > port. > > Pump the handle and watch the dial as you pull a vacuum. (I did mine all > the way to 20,000'). > > Start a stop watch and look for the dial to rotate downward indicating > leakdown. Swap static ports and start over. > > I added the ASI and did another test with lower altitude levels to ensure > the integrity of the ASI. Swap static ports and start over. > > You're allowed 100'/min IIRC from the regs - I ended up with 150'/hr so I > think I'm OK...... > > Someone may convince me of the error of my ways and I'll re-do it > differently - but noone's tried yet. > > -----Original Message----- > >From: Carlos Trigo <trigo(at)mail.telepac.pt> > >Sent: Mar 5, 2008 7:16 PM > >To: aeroelectric-list(at)matronics.com > >Subject: RE: AeroElectric-List: static system leak check procedure > > > trigo(at)mail.telepac.pt> > > > >By the way, can somebody explain how is a static leak check performed? > > > >Carlos > > > > > >> -----Original Message----- > >> From: owner-aeroelectric-list-server(at)matronics.com > >[mailto:owner-aeroelectric-list- > >> server(at)matronics.com] On Behalf Of Ken > >> Sent: quarta-feira, 5 de Mar=E7o de 2008 19:02 > >> To: aeroelectric-list(at)matronics.com > >> Subject: AeroElectric-List: static system leak check procedure > >> > >> > >> I started to do a preliminary static system leak check and noticed tha t > >> it only takes about 500 feet of static vacuum to make the ASI read > about > >> 100 knots. 10 or 20 thousand feet would peg the ASI pretty firmly. Is > >> the pitot side subjected to the same vacuum as the static side of the > >> system to prevent altimeter damage or is that not a concern? It seems > >> prudent to check for obvious leaks before taking the plane to the radi o > >> shop. > >> thank you > >> Ken > > > > > > > > > > > > ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Subject: Re: RE: "Poor Man's" coax termination with RG-400
Date: Mar 06, 2008
Rodney, Bob shows an excellent way to attach BNC connectors on the RG-400. Just archive aeroelectric. Mike H 9A/8A ----- Original Message ----- From: Rodney Dunham To: aeroelectric-list(at)matronics.com Sent: Thursday, March 06, 2008 7:34 AM Subject: AeroElectric-List: RE: "Poor Man's" coax termination with RG-400 Since RG-400 has a doulble braid shield, how do I do the "Poor Man's" coax termination with it? Braid the two shields as one and crimp on the lug OR .... Rodney in Tennessee ------------------------------------------------------------------------- ----- Need to know the score, the latest news, or you need your Hotmail=AE-get your "fix". Check it out. ________________________________________________________________________________
Date: Mar 06, 2008
>Since RG-400 has a doulble braid shield, how do I do the "Poor Man's" coax >termination with it? > >Braid the two shields as one and crimp on the lug OR .... What are you wanting to attach it to? I presume that since you're talking about "crimp" that you don't want to install the usual connector. Here's a technique I've used on all manner of shielded wires for 50 years. See how this works for you. http://aeroelectric.com/articles/shldwire/shldwire.html Bob . . . ________________________________________________________________________________
Date: Mar 06, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> Consider a 10' run of coax from GPS receiver to antenna. RG58 offers an attenuation of about 35db/100'; RG-400/142 is about 24db/100'. 10' runs reduce to 3.5 and 2.4 db for a difference of 1.3 db . . . delta that is impossible to observe and difficult to measure at that frequency. With respect to materials, RG-400/142 are double- layer, silver-plated shield and fabricated from modern cousins to Teflon. It's the best we know how to do . . . today. What do you think about Andrew FSJ1RN-50B Heliax Cable ? At 150MHz the attenuation is only 2.2 dB/100' The minimum bend radius is only 1" and it doesn't try to unbend itself due to the corrugated shield. It is more expensive of course, plus you need their expensive BNC connectors. http://www.andrew.com/catalog/product_details.aspx?id=1343 Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Mar 06, 2008
Bob, Sorry I didn't explain it very well. My buddy wants to use RG-400 for his VHF COMM. He has one of those antennas that has only a Delrin insulator and the end of the antenna is threaded. H e currently has some old RG-58 which is installed according to the 'Connect ion, Chapter 13, The "Poor Man's" coax termination in lieu of a BNC connect or, which is not an option with this antenna. He was wondering if he should just twist the two layers of (RG-400) braid i nto one "wire" and crimp on a lug like the previous (RG-58) install. I was wondering if the outer (RG-400) braid should be trimmed short and only the inner braid teased out for crimping onto the ground lug. Or does it even ma tter? Sorry for the misdirect. Rodney in Tennessee _________________________________________________________________ Climb to the top of the charts!-Play the word scramble challenge with sta r power. http://club.live.com/star_shuffle.aspx?icid=starshuffle_wlmailtextlink_ja n ________________________________________________________________________________
Date: Mar 06, 2008
Subject: Re: Low voltage indicator for LR3
My "spam can" doesn't have much in the way of a low voltage warning but the Garmin x96 does! I found a data field that displays volts and an alarm that allows you to set the voltage threshold. johninreno Jeff Page wrote: > >> Failure of the main alternator is not an emergency. It's >> an emergency only if you have no alternatives i.e, you >> have no back up engine driven power source and you haven't >> the foggiest notion of how long your battery will run goodies >> in the endurance mode. > ________________________________________________________________________________
Date: Mar 06, 2008
>Bob, > >Sorry I didn't explain it very well. > >My buddy wants to use RG-400 for his VHF COMM. He has one of those >antennas that has only a Delrin insulator and the end of the antenna is >threaded. He currently has some old RG-58 which is installed according to >the 'Connection, Chapter 13, The "Poor Man's" coax termination in lieu of >a BNC connector, which is not an option with this antenna. > >He was wondering if he should just twist the two layers of (RG-400) braid >into one "wire" and crimp on a lug like the previous (RG-58) install. I >was wondering if the outer (RG-400) braid should be trimmed short and only >the inner braid teased out for crimping onto the ground lug. Or does it >even matter? > >Sorry for the misdirect. That's what I thought . . . and the technique described in the link I provided at: http://aeroelectric.com/articles/shldwire/shldwire.html is what I would suggest. If you pull the center conductor through the side of BOTH shields, then there's no "twisting" necessary. The braid conductors are already grouped together in a manner that's conducive to installation of a terminal. The rule of thumb is to keep the coax pigtails as short as practical and know that the short length of exposed center conductor will cause an electrical "lengthening" of the antenna. This will shift the antenna's center-frequency down a Mhz or so . . . not generally a big deal. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 06, 2008
> >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> > Consider a 10' run of coax from GPS receiver > to antenna. RG58 offers an attenuation of about > 35db/100'; RG-400/142 is about 24db/100'. > 10' runs reduce to 3.5 and 2.4 db for a difference > of 1.3 db . . . delta that is impossible to > observe and difficult to measure at that frequency. > > With respect to materials, RG-400/142 are double- > layer, silver-plated shield and fabricated from > modern cousins to Teflon. It's the best we know how > to do . . . today. > >What do you think about Andrew FSJ1RN-50B Heliax Cable ? > >At 150MHz the attenuation is only 2.2 dB/100' >The minimum bend radius is only 1" and it doesn't try to unbend itself >due to the corrugated shield. >It is more expensive of course, plus you need their expensive BNC connectors. > >http://www.andrew.com/catalog/product_details.aspx?id=1343 There are MANY alternative coax products that would reduce losses in the antenna's feedline. But what's the return on investment? The as-installed performance differences for having utilized some form of super-coax would be difficult to measure, much less observe. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 06, 2008
>From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> >Subject: Re: AeroElectric-List: RG-400 vs. RG-142? >>any significant downsides to using RG-142 for aircraft antenna >>applications where the cable will not be regularly flexed (except >> for normal vibration)? I am somewhat leery of using a solid core >>coax. >Then use the stranded version, RG-400. Bob is right but you can get stranded versions of many coxial cables if you know where to look. The best thing recommending RG-58 (which can be had stranded) is its easier to find. Cost? RG-400 is spendy but when you look at cost of plane and avionics it's nickles and dimes. I still would not criticize you for using RG-58 but at least look for stranded. RG-400 prices have come down to $1.85/ft. cost difference small. SCORE! http://www.steinair.com/wire.htm has RG-400 for $1.85/ft. B&C also has a the same price. I know you don't need 500ft of RG-58 stranded but this is $0.23/ft http://www.pacificcable.com/Picture_Page.asp?DataName=RG58AU It does show RG-58 comes in stranded. There are many RG-58 equiv on the market but RG-400 is king, but be careful RG-400 comes in solid and stranded as well. Get stranded; why not? Not sure RG-142 comes in stranded? G --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 06, 2008
I'm up to my elbows on a daily basis in FSJ1-50 and the larger family of heliax up to 3" dia. They are unsuitable for aircraft use due to weight and flexibility. Especially the end connections which do not tolerate much post - install stress. The cables Bob has replied are the best for the purpose, besides, transponders and radios are designed to operate with some cable loss and in fact you will have a harder time getting a satisfactory match over the VHF band if your cable is too good. Then you have to start re-engineering and / or ferrite loading the antenna system. Be sure to use good connectors, not the computer - grade variety. Connectors improperly installed cause more problems than the cable. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168096#168096 ________________________________________________________________________________
Date: Mar 06, 2008
I installed my transponder antenna about 6 months ago in the rear of my plane. Now I am getting ready to install the transponder itself. While reading the instructions, I discovered that the max distance for RG400 is 8.8 feet. My installation is probably 10 feet. Do I need to move the antenna? If I don't move it, what will be the down side? It is a Garmin GTX327 if that matters.. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of jetboy Sent: Thursday, March 06, 2008 4:11 PM Subject: AeroElectric-List: Re: RG-400 vs. RG-142 I'm up to my elbows on a daily basis in FSJ1-50 and the larger family of heliax up to 3" dia. They are unsuitable for aircraft use due to weight and flexibility. Especially the end connections which do not tolerate much post - install stress. The cables Bob has replied are the best for the purpose, besides, transponders and radios are designed to operate with some cable loss and in fact you will have a harder time getting a satisfactory match over the VHF band if your cable is too good. Then you have to start re-engineering and / or ferrite loading the antenna system. Be sure to use good connectors, not the computer - grade variety. Connectors improperly installed cause more problems than the cable. Ralph -------- Ralph - CH701 / 2200a Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168096#168096 ________________________________________________________________________________
Date: Mar 06, 2008
While we're on the topic of coax and RG-400....what would you guys recommend as to a wire stripper tool? I got the Ideal Stripmaster for stripping regular wire but need something for coax. And while we're on wire...what would you recommend for a crimper? Thanks, Ralph Finch Davis CA ________________________________________________________________________________
Date: Mar 06, 2008
Subject: RE: "Poor Man's" coax termination with RG-400(coax
stripper) Ralph, A single edge razor blade or small knife used with care works fine. Score the jacket and pull it off with a small diagonal cutter. Do the same for the center conductor. Any nicks to the conductors start over!! You can master this in several practice attempts and when done properly there is no difference in results. Any time you may save with the expensive tool you will probably loose looking for the too :) The diagonal cutter can be used to trim the braid. I have used the expensive tools, a razor blade and a swiss army knife over the course of years and many hundreds of connectors, The knife is always in my pocket and the final result is the same. Whatever tool you use slide the ferrule on first and then prep the cable. Here is another option but your wallet will be $50 lighter. http://www.specialized.net/ecommerce/shop/layout.asp?product%5Fid=108X956 -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Mar 06, 2008
Go here and then to the product drawing for cable strip details. http://catalog.tycoelectronics.com/TE/bin/TE.Connect?C=1&M=BYPN&TCPN=5225395-6&RQPN=5225395-6 -- Ralph C. Hoover RV7A hooverra at verizon dot net ________________________________________________________________________________
Date: Mar 06, 2008
I'm still wondering how the radio shop does a transponder check? I'm guessing they connect their vacuum source to the static port AND the pitot port?? If so, I'm going to need to check the pitot side of things for leakage as well I think. thank you Ken Kevin Horton wrote: > You can do an acceptable test much more simply than this. The standard > (as described in FAR 23.1325(b)(2)(i)) only calls for enough vacuum to > raise the indicated altitude 1000 ft above the altitude of the test > site. On my RV-8, I put a piece of tape over one static port, and held > a piece of rubber hose against the other static port. I put the other > end of the hose in my mouth, and sucked until I had increased the > altitude more than 1000 ft. I put my tongue over the end of hose to > trap the pressure, and made sure to keep pushing the other end hard > against the static port so no air leaked out there. The altimeter > dropped much less than 100 ft in a minute (the pass/fail criteria from > FAR 23.1325), so my system was OK. > > There is no need to disconnect ASI or VSI (assuming you don't introduce > excessive vacuum, which could damage an ASI). In fact, doing it with > instruments removed invalidates the test, as you might introduce a leak > when you put those instruments back into the static system. You really > need to do an end-to-end leak check with the whole static system in the > state it would be when you fly the airplane. > > Kevin Horton > ________________________________________________________________________________
Date: Mar 06, 2008
I think I asked the same question awhile ago Bill but 11 feet seems to work fine on a GTX320 despite the 8.8 foot caution. Ken Bill Bradburry wrote: > > I installed my transponder antenna about 6 months ago in the rear of my > plane. Now I am getting ready to install the transponder itself. While > reading the instructions, I discovered that the max distance for RG400 is > 8.8 feet. My installation is probably 10 feet. Do I need to move the > antenna? If I don't move it, what will be the down side? It is a Garmin > GTX327 if that matters.. > > Bill B > ________________________________________________________________________________
Subject: Coax termination and electrical theory explained.
Date: Mar 07, 2008
I have been dabbling with the physics of current moving along a wire. One of the remarkable things about physics that I have to keep re-learning is that seemingly simple phenomena have wildly complicated reasons for working as they do. But understanding these reasons keep us on track . You would think that the theory of electricity has been well worked out by now. But heres your test: 1)What carries the energy in a simple electrical circuit? a-Electrons, b-Holes, c-God knows! 2)What returns on the ground or return wire? a-Electrons, b-Holes, c-God knows! 3)In a coaxial cable, exactly where is the energy carried? a-In the center conductor, b-In the shield, c-God knows! If you answered c for the three questions, you are close to correct but we can shed considerable light on the subject and only a few miracles will be invoked. Lets start with some simple truths: 1) You can't expect electrons to carry energy to the load because a coulomb (a miniscule amount of electrons), a meter from another coulomb electrostatically repel each other with about a million tons of force. (So there's probably some kind of taxpayer-funded DARPA electronic weapon based on this fact in our future....). 2) Electrons dont carry signals or information either because they are far too slow. It takes days for an electron to go a mile. Electromagnetic fields do the job. 3) The notion of ground current as used-up tired electrons slowly returning home to battery rehabilitation is wrong. BOTH the high potential and ground return conductors do identical things, but with opposite polaritieseven in DC circuits. 4) Electrons dont carry energy to the load because they usually dont get there anyway. Most circuits just dont connect power and load in any contiguous way. 5) Coaxial cables are waveguides because the energy transmitted is almost entirely within the inner insulation. An amazing proof of this is that the wave velocity is almost exactly the speed of the electromagnetic wave in the particular material out of which the insulation is made. The importance of this is directly proportional to frequency. For audio purposes it matters little. Skin Effect is a 1957 tribute to Bridgette Bardot, and also what happens to electrons that increasingly drift towards the surface of a conductor at high frequencies. Why do we care about this when electrons dont do much anyway? This is interesting only because the center of conductors at high frequencies have no function. This is easily seen in HF induction coils made of hollow tubing instead of solid. The "pigtails" where the coax shield is twisted into a lead and both the inner conductor and twisted up shield lead are treated as separate wires is deadly to high frequency signals >Megahertz. The shield should be terminated by any method that does not decrease the impedance of the shield or the inner conductor. There are many ways to do this, but they all use some collar arrangement to terminate the messy coax shield. Any coax catalog has lots of solutions. Remember that above a megaHertz, the inner INSULATION carries the bulk of the energy! (As an aside--50 Ohms and 75 Ohms are the impedance of vacuum and air respectively. Early coaxial cables were one or the other.) Bob, in my humble opinion, needs a little nudge on this. Here's how NOT to terminate coaxial cable-- http://aeroelectric.com/articles/shldwire/shldwire.html But yikes....! So it turns out that the simplest DC circuit operation is wildly difficult to explain, but basically the electromagnetic fields carry the energy, not the electrons. They are just there to move and cause the magnetic field. The electrons have only an electric field, and it is only the electrons movement through space that generates a magnetic field. If you followed alongside an electron, you wouldnt see ANY magnetic field. This is the difference between static electricity and the regular stuff. Static electricity has no magnetic field because the electrons arent moving with respect to the observer. http://science.uniserve.edu.au/school/curric/stage6/phys/stw2002/sefton.pdf and if this (excellent!) paper doesn't blow your mind, try-- http://sites.huji.ac.il/science/stc/staff_h/Igal/Research%20Articles/Pointing-AJP.pdf http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/audio/part6/page3.html Textbook, Electromagnetics Explained: Part of the EDN Series for Design Engineers by Ron Schmidt -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168228#168228 ________________________________________________________________________________
Date: Mar 07, 2008
Subject: Grounding shielded wires
I know - the subject's been covered before. And yes, I know - it's in the archives. But, I can't find it in the archives and I'd appreciate some help. I'm getting conflicting advice from the radio harness maker and from the intercom maker regarding the grounding of shielded wires. One tells me to ground the shield on only one end while the other says to ground both ends. Who to believe? My situation: SL30 with professionally wired harness. Shields are all grounded on the radio chassis. I'm building the harness for the intercom. The intercom instructions show shielding grounded at both ends only on the audio wires. However, email from intercom maker says to ground both ends of all shielded wire. 1. Should shielded wires from SL30 to intercom be grounded at both ends? 2. Should those grounds be ganged together to connect to the single ground pin on the intercom? 3. Should mic phone plug wire shields be grounded at both ends? 4. Should headphone plug wire shields be grounded at both ends? 5. Should all shields be ganged together to connect to the single ground pin on the intercom? Stumped, Stan Sutterfield **************It's Tax Time! Get tips, forms, and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) ________________________________________________________________________________
Date: Mar 07, 2008
> >While we're on the topic of coax and RG-400....what would you guys recommend >as to a wire stripper tool? I got the Ideal Stripmaster for stripping >regular wire but need something for coax. > >And while we're on wire...what would you recommend for a crimper? My personal favorite stripper is offered by Gilchrist Electric at: http://www.gilchrist-electric.com/3-blade-coax-cable-strip.php They used to have an Ebay store but seem to have split the sheets with Ebay. The link above goes directly to their website. This is a 3-blade tool that comes with the appropriate sized allen wrench to effect adjustment of cutting depth for each blade. See the 3-Blade Stripper pictures at: http://www.aeroelectric.com/Pictures/Tools/Wire_Strippers/ I presume you're asking about coax crimpers . . . for BNC connectors, you need a high-leverage, hard-die tool with 0.068" and 0.213" pockets. This tool offered by Radio Shack is one option: http://tinyurl.com/ys7oed as is the RCT-2 offered by http://bandc.biz For the pre-insulated ring terminals, consider this tool: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93977 Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 07, 2008
> >I think I asked the same question awhile ago Bill but 11 feet seems to >work fine on a GTX320 despite the 8.8 foot caution. >Ken > >Bill Bradburry wrote: >> >>I installed my transponder antenna about 6 months ago in the rear of my >>plane. Now I am getting ready to install the transponder itself. While >>reading the instructions, I discovered that the max distance for RG400 is >>8.8 feet. My installation is probably 10 feet. Do I need to move the >>antenna? If I don't move it, what will be the down side? It is a Garmin >>GTX327 if that matters.. >>Bill B When a manufacturer publishes performance specifications for a product, they need to state the boundaries on installation variables that influence the numbers. In the case of 8.8' max length, they're only saying that performance will be degraded from the published specifications if that length is exceeded. What is not so apparent is whether or not a user/observer would be aware of the degradation . . . and in this case, the answer is no. There's enough head-room in the receiver's capability to deliver useful performance in spite of an additional 0.1 Db or so of feedline losses. Now, if you were installing this radio in a 787 and needed to put the antenna out on a wing tip, a higher performance coax cable would be a really good idea. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 07, 2008
Subject: Re: Coax termination and electrical theory explained.
Eric M. Jones wrote: > Bob, in my humble opinion, needs a little nudge on this. Here's how NOT to terminate coaxial cable-- > > http://aeroelectric.com/articles/shldwire/shldwire.html > The difference between theory and practice is that in theory they are the same. You have two copper strips to form an antennae. One must be connected to the center conductor, the other to the shield. Whether you terminate the coax with some fancy, expensive solution from an electronics catalogue or Bob's method, at some point the center conductor has to split out from the shield. The difference in actual performance in the flying airplane will be lost in the noise (pun intended). In theory, there is an advantage in the expensive, complicated solution. In practice, the advantage ain't worth the headache. ________________________________________________________________________________
Date: Mar 07, 2008
Subject: Re: Grounding shielded wires
>I know - the subject's been covered before. And yes, I know - it's in the >archives. >But, I can't find it in the archives and I'd appreciate some help. >I'm getting conflicting advice from the radio harness maker and from the >intercom maker regarding the grounding of shielded wires. One tells me to >ground the shield on only one end while the other says to ground both >ends. Who to believe? >My situation: SL30 with professionally wired harness. Shields are all >grounded on the radio chassis. >I'm building the harness for the intercom. The intercom instructions show >shielding grounded at both ends only on the audio wires. However, email >from intercom maker says to ground both ends of all shielded wire. > >1. Should shielded wires from SL30 to intercom be grounded at both ends? >2. Should those grounds be ganged together to connect to the single ground >pin on the intercom? >3. Should mic phone plug wire shields be grounded at both ends? >4. Should headphone plug wire shields be grounded at both ends? >5. Should all shields be ganged together to connect to the single ground >pin on the intercom? Follow the instructions. If the wiring diagram provided by the manufacturer SHOWS a ground connection at both ends, then there's a reason for it an the designer's intentions should be observed. However, the general rule of thumb is that shields are to be GROUNDED at one end only . . . that doesn't mean that the shield is not CONNECTED at both ends . . . the shield may have an important role to play with respect to signal or power return paths. A very common double-grounding error in aircraft audio systems occurs when headset and microphone jacks are allowed to find local ground at the point of attachment to the airframe. This is why insulating washers . . . http://www.aeroelectric.com/Pictures/Connectors/Audio/Jack_Insulation_Washers.jpg are recommended where the jacks are to me mounted to a conductive location on structure. The schematic for wiring the product should be quite explicit as to where the shields are connected. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 07, 2008
> >I have been dabbling with the physics of current moving along a wire. One >of the remarkable things about physics that I have to keep re-learning is >that seemingly simple phenomena have wildly complicated reasons for >working as they do. But understanding these reasons keep us on track . >You would think that the theory of electricity has been well worked >out by now. But heres your test: > > 1)What carries the energy in a simple electrical circuit? > a-Electrons, > b-Holes, > c-God knows! >Bob, in my humble opinion, needs a little nudge on this. Here's how NOT to >terminate coaxial cable-- > >http://aeroelectric.com/articles/shldwire/shldwire.html > >But yikes....! So it turns out that the simplest DC circuit operation is >wildly difficult to explain, but basically the electromagnetic fields >carry the energy, not the electrons. They are just there to move and cause >the magnetic field. The electrons have only an electric field, and it is >only the electrons movement through space that generates a magnetic field. >If you followed alongside an electron, you wouldnt see ANY magnetic >field. This is the difference between static electricity and the regular >stuff. Static electricity has no magnetic field because the electrons >arent moving with respect to the observer. Eric my friend . . . you're making this far more complex than it needs to be. Yes, the physics of conducting electrical energy from one place to another have been studied, quantified and explained for a century or so. However, there ARE practical departures from "ideal" that do not materially affect performance. Super-simple VHF COMM antennas were installed by the tens of thousands in light aircraft using the technique illustrated. Yes, the effects on SWR, radiation patterns, and radiation efficiency were degraded from ideal . . . but the the ideal was never perfect either. For the frequencies of interest (118 - 135 Mhz), effects of the 1" or so of non-coaxial conductor that results from the use of terminals on pigtails was barely noticeable in the lab and never noticed by a pilot in an airplane. Now, the effects of this technique at transponder frequencies is much larger . . . easily measured in the lab. But with some judicious refinement of fabrication technique to get the shortest possible leads (below 1/2") the effects on real time performance were not observable. When we go to the lab to make calibrated measurements of performance, the obvious goal is to minimize the effects of test-setup error. In this environment we strive for the-best-we-know-how-to-do with the goal of suppressing sum of all test errors to less than 1/4 that of the phenomenon being measured. But in the real world of talking to Flight Watch from an RV, well considered departures from the best-we-know-how-to-do don't reflect badly upon our craftsmanship. Bob . . . ________________________________________________________________________________
Date: Mar 07, 2008
> The difference in actual performance in the > flying airplane will be lost in the noise (pun intended). In theory, > there is an advantage in the expensive, complicated solution. In > practice, the advantage ain't worth the headache. Maybe, maybe not. It depends on the details. But you have not tested it, (nor has Bob). I submit that when the HANDY SHORT-CUT solution is proposed as the GENERAL solution, the best interests are not well served. The coax terminations in electronics catalogs are neither difficult nor complicated. Furthermore you can make you own in a pinch. So there are two choices: 1) The right way. 2) The other way. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168247#168247 ________________________________________________________________________________
Date: Mar 07, 2008
Subject: Ignition/Starter switch wiring
Bob and all, I have a couple questions. I am wiring a Rotax 914 in my Europa per Z-16(sort of). I want to use a switch for each "mag" that will be down-off, middle-on, momentary-up of both to start. Is there a drawing somewhere on the site that shows how to wire this? I also want to wire a switch to control two alternators, the rotax built dynamo and a Denso IR alternator mounted on the vac pad. I would like to use one switch; down-dynamo middle-off and up-main alternator(denso).Is there a drawing showing how to wire that? Thanks, Kevin ________________________________________________________________________________
Date: Mar 07, 2008
> > > > The difference in actual performance in the > > flying airplane will be lost in the noise (pun intended). In theory, > > there is an advantage in the expensive, complicated solution. In > > practice, the advantage ain't worth the headache. > > >Maybe, maybe not. It depends on the details. But you have not tested it, >(nor has Bob). ???? I've made a good living for over 40 years delivering products to a customer's needs and in many cases, verifying performance both in the lab and in the customer's application. For you to make ANY assertions about what I have or have not learned by experiment, or success of myself and colleagues in the field is specious and without foundation. > I submit that when the HANDY SHORT-CUT solution is proposed as the > GENERAL solution, the best interests are not well served. You extrapolate much floobydust from the original question. The goal was to make an electrically adequate connection between a coax feedline and the classic stone-simple, rod-on-a-feedthru comm antenna. This style antenna is still offered by many suppliers not the least of which is . . . http://www.chiefaircraft.com/Aircraft/Antennas/Images/AS_AV534.jpg and yields 76 hits on a Google search. So, returning to the original question, what are your recommendations for attaching a coax to this product? Further, if your recommendations involve extensive $time$ to satisfy some goals for transmission line matching or keeping the holes separated from the electrons, what's the expected return on investment for making that effort? You should know that the last time I designed one of these antennas into an installation, I discarded the large ring-terminal intended for shield braid connection to airframe (large area, low pressure) in favor of the PIDG ring terminal (small area, high pressure) connection of the shield to the airframe. What we were discussing was NOT a SHORT-CUT as a GENERAL solution but a well considered, time tested, current marketplace practice to a very SPECIFIC application. >The coax terminations in electronics catalogs are neither difficult nor >complicated. Furthermore you can make you own in a pinch. So there are two >choices: > >1) The right way. >2) The other way. There are MANY ways to work toward design goals. Some perform better, some most more, some are not possible to implement in the present situation. The hallmark of craftsmanship is achieving the best solution to the task of the moment with resources at hand. Bob . . . ________________________________________________________________________________
Date: Mar 08, 2008
Subject: Coax termination, theory, and..do I balun?
I'm using a King KNS-80 and Narco 12D, and replacing the rg-58 in my spam can with rg400 for my vor/glideslope catwhisker antenna, Should I replicate the 40 year old balun where it mates with antenna? or does the termination issue outweigh the benefits of the balun? Thanks Skip **************It's Tax Time! Get tips, forms, and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) ________________________________________________________________________________
Subject: Re: Z-19 Series Architecture
Date: Mar 08, 2008
Bob, I was wondering if you had a chance to take a look at the Z-19 drawings in response to my inquiry. Specifically, the latest revs of the Z-19 drawings on your website show the E-bus normal feed on a fused connection from the primary bus. Is there a reason for supplying the E-bus on the Z-19 drawings this way? Regards, Mark -------- Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168391#168391 ________________________________________________________________________________
Date: Mar 08, 2008
Yes, if they do the transponder check on the aircraft, they would have to also connect to the pitot to put vacuum there, or they could damage the ASI. But, you really should do a pitot leak check anyway, as a leak in the pitot side could affect ASI accuracy. Be aware that some pitot ports have a water drain on the tube, which introduces a very small at the tube. This doesn't affect ASI accuracy as it is so close to the pitot tube, that any air that leaks out is quickly replaced without affecting the pressure in the pitot line. But it does affect leak checks - you need to block the water drain during the leak check, or you'll end up looking for a phantom leak. Kevin On 6 Mar 2008, at 22:06, Ken wrote: > > I'm still wondering how the radio shop does a transponder check? > I'm guessing they connect their vacuum source to the static port > AND the pitot port?? If so, I'm going to need to check the pitot > side of things for leakage as well I think. > thank you > Ken > > Kevin Horton wrote: >> You can do an acceptable test much more simply than this. The >> standard (as described in FAR 23.1325(b)(2)(i)) only calls for >> enough vacuum to raise the indicated altitude 1000 ft above the >> altitude of the test site. On my RV-8, I put a piece of tape over >> one static port, and held a piece of rubber hose against the other >> static port. I put the other end of the hose in my mouth, and >> sucked until I had increased the altitude more than 1000 ft. I >> put my tongue over the end of hose to trap the pressure, and made >> sure to keep pushing the other end hard against the static port so >> no air leaked out there. The altimeter dropped much less than 100 >> ft in a minute (the pass/fail criteria from FAR 23.1325), so my >> system was OK. >> There is no need to disconnect ASI or VSI (assuming you don't >> introduce excessive vacuum, which could damage an ASI). In fact, >> doing it with instruments removed invalidates the test, as you >> might introduce a leak when you put those instruments back into >> the static system. You really need to do an end-to-end leak check >> with the whole static system in the state it would be when you fly >> the airplane. >> Kevin Horton > > ________________________________________________________________________________
Date: Mar 08, 2008
Subject: Re: Cheap "Coat Hanger" antenna (was Coax termination
elect theory) No offense to Ernest or Bob, the old coat hanger antennas that you terminated the coax with crimp on lugs has not been used in production airplanes since the 50's or early 60's. Coat hanger antenna http://www.aircraftspruce.com/catalog/avpages/av534.php What Eric says about "EM field energy", which I recall bits from physics and armature radio, the coax, BNC connector is way more efficient. That inch of exposed shield/core & important lost insulation does count. The "coat hanger antenna connections are subject to corrosion and fatigue way more than a BNC connector. Just my opinion. No one is seriously using the coat hanger wire antenna on new OEM aircraft any more. "Testimonials" that they work in the plane or bench are great, but unless you do a test on the airframe in an antenna test chamber (EMF / RF anechoic chamber), we are guessing. Besides performance there is the reliability of the installation. Just from an installation standpoint, spend the $124 for the real antenna and leave the $50 coat hanger antenna for the closet. Antenna energy, non-ionizing radiation is EMF energy at high frequencies. It needs "ducting" to be most effective. Does the "strip-it crimp-it" antenna connection work? Yes it "works", but gosh ughaaa, ugly. We're talking about 5-8 watts of energy and communications of 5 to 50 mile, line of sight, listening for even more powerful transmitters, usually without obstacles. We can get away with a weak antenna. The coat hanger works, but its not ideal. We have better ways. If I was restoring a classic Beech or something, yea I'd keep the coat hanger antenna. Other wise coat hangers are for the closet (pun intended). $110-$150 for newer antenna design http://www.aircraftspruce.com/catalog/avpages/av17.php PS: Some have experienced RFI with unshielded antenna connections thru gauges and avionics. >From: Ernest Christley <echristley(at)nc.rr.com> >Subject: Re: Coax termination and electrical theory >explained. >Eric M. Jones wrote: >> Bob, in my humble opinion, needs a little nudge >> on this. Here's how NOT to terminate coaxial >> cable-- http://aeroelectric.com/articles/shldwire/shldwire.html >The difference between theory and practice is that in >theory they are the same. > You have two copper strips to form an >antennae. One must be connected to the center >conductor, the other to the shield. Whether you >terminate the coax with some fancy, expensive >solution from an electronics catalogue or Bob's >method, at some point the center conductor has to >split out from the shield. The difference in actual >performance in the flying airplane will be lost in >the noise (pun intended). In theory, there is an >advantage in the expensive, complicated solution. >In practice, the advantage ain't worth the >headache. --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 08, 2008
Subject: The difference between theory and practice
All this discussion about antenna connections brings to mind an old story about a mathematician, a theoretical physicist, and an engineer. They began pondering a thought experiment about a man and a beautiful naked red head standing six feet apart. The question was this; if the man halves the distance between himself and the red head each second, how long will it take before he reaches her? The mathematician and the physicist both immediately answered that of course the man would never reach her. The engineer calculated that in four seconds he'd be close enough for all practical purposes. This is what comes from listening to the annual "Prairie Home Companion" joke show this evening. Ya'll take it easy and have a nice Sunday. Rick ________________________________________________________________________________
Date: Mar 08, 2008
Subject: High density D-sub crimper
Howdy, I've got to crimp about 30 machined high density d-sub pins on an ACU install and I don't think my standard density crimper (B&C) is gonna work. I'd hate to spend $800 on a Daniels and postitioners for one little deed. Any ideas? I thought about getting a $30 crimper and some of the fold over pins. Are those pins as reliable as the machined ones? Will the crimper (fold over style, also B&C) do those little pins in one of it's slots? Pax, Ed Holyoke ________________________________________________________________________________
Subject: B&C S895-1 as start button for 20A/14VDC ciruit?
Date: Mar 09, 2008
Hi Bob, Hope all is well with you :) I have a B&C S895-1 push button originally intended as a start buton; however, the Eggenfellner recommendation for the starter circuit is for a switch or push button capable of 20A/14VDC (switch will be connected to the internal contactor on the Subaru H6 starter solenoid). I have been reviewing both your Switch_Rating.pdf and the chapter in the Connection, and I'm coming to the conclusion that this switch is probably too light for this application. Would it work? Sure. For how long? Who knows... But what would be the risk that I could fuse this switch closed or just plain heat it up too much? Also, the connection leads on this switch seem a bit small/light for 12AWG wire... Please advise when you have a moment. Thanks in advance! Michael O'Brien Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168543#168543 ________________________________________________________________________________
Subject: Re: High density D-sub crimper
Date: Mar 09, 2008
My UMA instruments came with the overfold sub D pins. Crimps looked good and they have worked fine for a long time. -------- Milt 2003 F1 Rocket 2006 Radial Rocket Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168553#168553 ________________________________________________________________________________
Date: Mar 09, 2008
If you crimp connectors without the specific dies, you would be well served by soldering the wire strands to the crimps as well or the wires might just fall out! I have an AMP ProCrimp II with all the dies for the CPC Series I connectors, and they still sometimes fail the tug test when I don't oversolder them! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=168557#168557 ________________________________________________________________________________
Date: Mar 09, 2008
If you have the standard density crimper (the red one that puts the 4 little indents into the pin), you can use it on the high density machined pins if you're careful. What I did was cut a short piece of wire (like 1/8" or so) and put it into the hole first as a spacer to position the pin in the right spot. Then you can crimp like normal. You may have to play around a bit to adjust the length of the spacer to get the pin in the right spot. If you're only doing a few pins you shouldn't have any issues. Mine passed a 15lb pull test and that's good enough for me. PJ Seipel RV-10 #40032 Ed Holyoke wrote: > > > Howdy, > > I've got to crimp about 30 machined high density d-sub pins on an ACU > install and I don't think my standard density crimper (B&C) is gonna > work. I'd hate to spend $800 on a Daniels and postitioners for one > little deed. Any ideas? > > I thought about getting a $30 crimper and some of the fold over pins. > Are those pins as reliable as the machined ones? Will the crimper > (fold over style, also B&C) do those little pins in one of it's slots? > > Pax, > > Ed Holyoke > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Diodes versus switches 101 ?
Date: Mar 09, 2008
There was some discussion about Z19 using diodes in a critical ECU circuit and the question arose as to what kind of failure modes apply to diodes and their reliability as compared to switches. I think the trust of that thread (sub list) and post below is that diodes might be "automatic" but switches are safer and less likely to fail? ( I have no opinion but would like to understand the rationale ) This was posted and I was just wondering what the thought might be on the AE list since most of Bobs diagrams "suggest" a diode in the E-Bus circuit as opposed to a switch. That might not be AS critical as the ECU/EFI circuit on an all electric engine but the same concerns still apply? Posted to the Sub list: "After 30 years in the industrial electrical construction and maintenance field I can say without equivocation that a robust switch is much less likely to fail than a robust diode. The science of the switch is much simpler - use a lot of good conducting material that is not likely to corrode and support it with stout mechanical parts that hold tightly. Now, by contrast, the science of the diode starts with getting good silicon material and contaminating it in just the right proportion with just the right material at just the right temperature for just the right time. THEN you can start on building the junctions onto some sort of heat dissipating holder. I have replaced dozens of solid state devices that failed (always failed open) and I never found the root cause of failure. I put in an exact replacement and the circuit worked just fine for years. The trade off you get for the "automatic" switching of a diode vs. the manual switch is in the area of RELIABILITY. I'll be using manual switches for all critical loads." Not wanting to stir anything up, just want to understand the thinking and factual matter in the post above? Thanks Bill S 7a Z13/8 Z32(HD E-Bus) Z35(7ah) ________________________________________________________________________________
Date: Mar 09, 2008
From: "Richard E. Tasker" <retasker(at)optonline.net>
Subject: Re: Diodes versus switches 101 ?
Here is an excerpt of something I posted on the Sub list which relates to this email: Regarding the reliability of switches and diodes... According to Mil handbook 217F - the "bible" of reliability prediction - a Schottky power diode (which is the only type anyone should be using in any power circuit in an airplane) has a predicted failure rate of 0.0028 failures per million hours. A mil rated toggle switch has a predicted failure rate of 0.1 failures per million hours. Now, realistically, this prediction for a switch is partially related to the toggle mechanics and partially related to the individual contacts. The mil handbook relates to a single set of contacts while the specified switch has four sets of contacts so the switch in question is probably less reliable that the handbook predicts for a simple toggle switch. But even if we ignore that detail, for what it is worth, a diode of the type that should be used is 35 times more reliable than the type switch specified. So much for the superiority reliability of a switch that some have been bandying ab out... A properly designed diode circuit provides automatic, uninterrupted power transfer in the event of the loss of the main supply. A switched circuit requires the pilot to notice the problem and take some action (toggle the switch to the other position). A diode circuit has not been specified (in the Subaru application), so one is on their own if that were to be the choice of a user. While this is not an insurmountable problem, the diode circuit is more susceptible to a poor design. One must choose a diode with sufficient current and voltage ratings for the desired circuit conditions. Additionally, since there can be considerable heat generated in a power diode, proper heat sinking must be provided (not particularly hard to do as long as you know how to calculate what is needed). So... If you are electrically challenged use the factory recommended circuit design - good or bad as it may be, it has full factory support. If you really know what you are doing, a diode circuit has certain advantages. However, if you choose to depart from the factory design, do not expect any assistance or support from the factory for your design and if you have a problem it is your problem. I have already wired my RV9A (long before this discussion and long before "diode" became a dirty word) and I am using two very beefy Schottky diodes to connect both battery buses to the engine bus. If either bus goes down for whatever reason, the engine keeps on running and an annunciator tells me which bus is down. Additionally, a voltmeter on each bus keeps me informed of its health continuously. It should also be noted that in the instance in question that the ECU was provided power from a, probably, inadequately heat sinked bridge that was, possibly, underrated for the application. For what Bob recommends the bridge - the Ebus - it is an excellent solution for the typical experimental plane builder. Dick Tasker Bill Schlatterer wrote: > > There was some discussion about Z19 using diodes in a critical ECU > circuit and the question arose as to what kind of failure modes apply > to diodes and their reliability as compared to switches. I think the > trust of that thread (sub list) and post below is that diodes might be > "automatic" but switches are safer and less likely to fail? ( I have > no opinion but would like to understand the rationale ) This was > posted and I was just wondering what the thought might be on the AE > list since most of Bobs diagrams "suggest" a diode in the E-Bus > circuit as opposed to a switch. That might not be AS critical as the > ECU/EFI circuit on an all electric engine but the same concerns still > apply? > > Posted to the Sub list: > > "After 30 years in the industrial electrical construction and > maintenance field I can say without equivocation that a robust switch > is much less likely to fail than a robust diode. The science of the > switch is much simpler - use a lot of good conducting material that is > not likely to corrode and support it with stout mechanical parts that > hold tightly. > > Now, by contrast, the science of the diode starts with getting good > silicon material and contaminating it in just the right proportion > with just the right material at just the right temperature for just > the right time. THEN you can start on building the junctions onto some > sort of heat dissipating holder. I have replaced dozens of solid state > devices that failed (always failed open) and I never found the root > cause of failure. I put in an exact replacement and the circuit worked > just fine for years. The trade off you get for the "automatic" > switching of a diode vs. the manual switch is in the area of > RELIABILITY. I'll be using manual switches for all critical loads." > > Not wanting to stir anything up, just want to understand the thinking > and factual matter in the post above? > Thanks Bill S > 7a Z13/8 Z32(HD E-Bus) Z35(7ah) > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Mar 09, 2008
I think it's important to take into account what the purpose of the switch and/or diode is, and more important, what the failure modes of the circuits around it is. A diode may be much more reliable when used within it's designed specs, but if you overload it, it will fail much quicker than a switch. Compare a diode and a switch, both rated at 25A. A short-circuit current of 100A through the diode for a few seconds will make it fail, most likely open circuit. The same current through a switch may heat it up and damage the contacts, even cause some sparks, but it may still limp along. Rob ----- Original Message ----- From: "Richard E. Tasker" <retasker(at)optonline.net> Sent: Sunday, March 09, 2008 8:42 PM Subject: Re: AeroElectric-List: Diodes versus switches 101 ? > > > Here is an excerpt of something I posted on the Sub list which relates to > this email: > > Regarding the reliability of switches and diodes... According to Mil > handbook 217F - the "bible" of reliability prediction - a Schottky power > diode (which is the only type anyone should be using in any power circuit > in an airplane) has a predicted failure rate of 0.0028 failures per > million hours. A mil rated toggle switch has a predicted failure rate of > 0.1 failures per million hours. Now, realistically, this prediction for a > switch is partially related to the toggle mechanics and partially related > to the individual contacts. The mil handbook relates to a single set of > contacts while the specified switch has four sets of contacts so the > switch in question is probably less reliable that the handbook predicts > for a simple toggle switch. But even if we ignore that detail, for what > it is worth, a diode of the type that should be used is 35 times more > reliable than the type switch specified. So much for the superiority > reliability of a switch that some have been bandying ab > out... ________________________________________________________________________________
Date: Mar 09, 2008
Subject: ANL/ANN current limiter
Hello I have a relatively long run (10+ ft) of 1/0 CCA main battery power wire in my -8 I am building from the rear baggage all the way to the front firewall. I would like to install an current limiter on the output of the battery as an added layer of protection for my long wire run. I know Mr. Nuckolls has not advocated that on small aircraft, but I want to do it anyway as peace of mind since the wire passes thru quite few bulkheads and want to have something which will trip alot faster than I can act. So, which is the better choice, ANN or ANL and what current rating would be best, I have a 200 hp angle valve to start? Thank you, Wade Lively N100WL, reserved ________________________________________________________________________________
Date: Mar 09, 2008
Subject: switch wiring
Bob and all, I have a couple questions. I am wiring a Rotax 914 in my Europa per Z-16(sort of). I want to use a switch for each "mag" that will be down-off, middle-on, momentary-up of both to start. Is there a drawing somewhere on the site that shows how to wire this? I also want to wire a switch to control two alternators, the rotax built indynamo and a Denso IR alternator mounted on the vac pad. I would like to use one switch; down-dynamo middle-off and up-main alternator(denso).Is there a drawing showing how to wire that? Thanks, Kevin ________________________________________________________________________________
Date: Mar 09, 2008
Hmmmm, I was worried about the diameter difference and hadn't addressed the depth. You're saying that the red handle crimper worked on the skinny pins. I haven't counted the pins that came with the install kit, but I'd be surprised if there are extras to burn so I've been a little leery of trying tests. Pax, Ed Holyoke PJ Seipel wrote: > > If you have the standard density crimper (the red one that puts the 4 > little indents into the pin), you can use it on the high density > machined pins if you're careful. What I did was cut a short piece of > wire (like 1/8" or so) and put it into the hole first as a spacer to > position the pin in the right spot. Then you can crimp like normal. > You may have to play around a bit to adjust the length of the spacer > to get the pin in the right spot. If you're only doing a few pins you > shouldn't have any issues. Mine passed a 15lb pull test and that's > good enough for me. > > PJ Seipel > RV-10 #40032 > > Ed Holyoke wrote: >> >> >> Howdy, >> >> I've got to crimp about 30 machined high density d-sub pins on an ACU >> install and I don't think my standard density crimper (B&C) is gonna >> work. I'd hate to spend $800 on a Daniels and postitioners for one >> little deed. Any ideas? >> >> I thought about getting a $30 crimper and some of the fold over pins. >> Are those pins as reliable as the machined ones? Will the crimper >> (fold over style, also B&C) do those little pins in one of it's slots? >> >> Pax, >> >> Ed Holyoke >> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 09, 2008
I bought some from Mouser, so I had some to practice on. If they have the little hole in them then you could also put some solder in there and that would probably work as well. If you don't have any extras, I'd be leery of trying the crimper as well, because it took me a few tries to find the right depth. PJ Seipel RV-10 #40032 Ed Holyoke wrote: > > > Hmmmm, I was worried about the diameter difference and hadn't > addressed the depth. You're saying that the red handle crimper worked > on the skinny pins. I haven't counted the pins that came with the > install kit, but I'd be surprised if there are extras to burn so I've > been a little leery of trying tests. > > Pax, > > Ed Holyoke > > PJ Seipel wrote: >> >> If you have the standard density crimper (the red one that puts the 4 >> little indents into the pin), you can use it on the high density >> machined pins if you're careful. What I did was cut a short piece of >> wire (like 1/8" or so) and put it into the hole first as a spacer to >> position the pin in the right spot. Then you can crimp like normal. >> You may have to play around a bit to adjust the length of the spacer >> to get the pin in the right spot. If you're only doing a few pins >> you shouldn't have any issues. Mine passed a 15lb pull test and >> that's good enough for me. >> >> PJ Seipel >> RV-10 #40032 >> >> Ed Holyoke wrote: >>> >>> >>> Howdy, >>> >>> I've got to crimp about 30 machined high density d-sub pins on an >>> ACU install and I don't think my standard density crimper (B&C) is >>> gonna work. I'd hate to spend $800 on a Daniels and postitioners for >>> one little deed. Any ideas? >>> >>> I thought about getting a $30 crimper and some of the fold over >>> pins. Are those pins as reliable as the machined ones? Will the >>> crimper (fold over style, also B&C) do those little pins in one of >>> it's slots? >>> >>> Pax, >>> >>> Ed Holyoke >>> >>> >>> >>> >>> >>> >> >> >> >> >> > > ________________________________________________________________________________
Date: Mar 09, 2008
True, but it is easy to get a diode that is rated for far over the normal operating current. In fact, doing so costs very little extra and has other advantages. Additionally, while your example as started is true, hopefully no one on this forum would end up with a design where it is possible to draw 100A on a 25A circuit without some sort of protective device interrupting the current before "a few seconds" are up... Rob Turk wrote: > > > I think it's important to take into account what the purpose of the > switch and/or diode is, and more important, what the failure modes of > the circuits around it is. A diode may be much more reliable when used > within it's designed specs, but if you overload it, it will fail much > quicker than a switch. Compare a diode and a switch, both rated at > 25A. A short-circuit current of 100A through the diode for a few > seconds will make it fail, most likely open circuit. The same current > through a switch may heat it up and damage the contacts, even cause > some sparks, but it may still limp along. > > Rob > > ----- Original Message ----- From: "Richard E. Tasker" > > To: > Sent: Sunday, March 09, 2008 8:42 PM > Subject: Re: AeroElectric-List: Diodes versus switches 101 ? > > >> >> >> Here is an excerpt of something I posted on the Sub list which >> relates to this email: >> >> Regarding the reliability of switches and diodes... According to Mil >> handbook 217F - the "bible" of reliability prediction - a Schottky >> power diode (which is the only type anyone should be using in any >> power circuit in an airplane) has a predicted failure rate of 0.0028 >> failures per million hours. A mil rated toggle switch has a >> predicted failure rate of 0.1 failures per million hours. Now, >> realistically, this prediction for a switch is partially related to >> the toggle mechanics and partially related to the individual >> contacts. The mil handbook relates to a single set of contacts while >> the specified switch has four sets of contacts so the switch in >> question is probably less reliable that the handbook predicts for a >> simple toggle switch. But even if we ignore that detail, for what it >> is worth, a diode of the type that should be used is 35 times more >> reliable than the type switch specified. So much for the superiority >> reliability of a switch that some have been bandying ab >> out... > > -- Please Note: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been temporarily inconvenienced. -- ________________________________________________________________________________
Date: Mar 09, 2008
Subject: Diode from the Main Bus to the Endurance Bus
Hi Folks I have already one airplane flying using Bob's Z-11 architecture with absolutely no issues. It has been great & really appreciated all the info provided by Bob & the forum. I do have one question. I am not questioning the wisdom of the design but merely wondering why a diode is placed between the main bus & the endurance bus. I realize that it is there to prevent backfeeding from the E bus to the main bus when the master is turned off in the case of an alternator failure etc. However, you can easily install a 2-10 switch that could be used to set to 1/ Both buses off 2/ E bus only on, master off & all other buses turned off 3/ Main bus & E bus on with the E bus being fed through the main bus & master Is the considered opinion of the group that a diode is more reliable than a switch & therefore used, or, to simplify the whole design or what? Just curious as there is a slight power loss across the diode of course which is the only negative and think of at this point. Thanks very much Brian Cross RV-8 #81844 ________________________________________________________________________________
Date: Mar 09, 2008
> >Holy cow, I just want to talk on the radio. I've got a plastic airplane so >I just snip off the ends and throw them away. "snip of the ends"??? Are you talking about coax connectors? On your plastic airplane, have you fabricated some form of ground plane under the antennas? Bob . . . ________________________________________________________________________________
Date: Mar 09, 2008
Subject: Re: Coax termination, theory, and..do I balun?
>I'm using a King KNS-80 and Narco 12D, and replacing the rg-58 in my spam >can with rg400 for my vor/glideslope catwhisker antenna, > >Should I replicate the 40 year old balun where it mates with antenna? or >does the termination issue outweigh the benefits of the balun? Thanks Skip Not easy to measure, and almost impossible to tell a difference by observation from the pilot's seat. We built thousands of Cessnas with split conductors of a coax simply attached to the cat-whiskers. Then somebody got religion and for a time we built a bunch of baluns. Some time later, we were having too much trouble with process . . . seems the PVC and Polyethelyene insulations got somewhat gooey at solder temperatures and unless the fabricator was particularly careful, poor craftsmanship caused field failures later. So we became heathens again and dumped the balun. Today, one may return to the old faiths with greater probability of success . . . seems the insulations used on RG400/142 withstand soldering temperatures very handily. So if you feel the urge, you can craft a balun as shown in: http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html May your radios navigate on stations nobody else even hears and may your antenna patterns be exemplary. Bob . . . ________________________________________________________________________________
Date: Mar 10, 2008
Subject: Re: Diode from the Main Bus to the Endurance Bus
> >Hi Folks > >I have already one airplane flying using Bob's Z-11 architecture with >absolutely no issues. It has been great & really appreciated all the info >provided by Bob & the forum. > >I do have one question. I am not questioning the wisdom of the design but >merely wondering why a diode is placed between the main bus & the >endurance bus. I realize that it is there to prevent backfeeding from the >E bus to the main bus when the master is turned off in the case of an >alternator failure etc. > >However, you can easily install a 2-10 switch that could be used to set to >1/ Both buses off >2/ E bus only on, master off & all other buses turned off >3/ Main bus & E bus on with the E bus being fed through the main bus & master > >Is the considered opinion of the group that a diode is more reliable than >a switch & therefore used, or, to simplify the whole design or what? > >Just curious as there is a slight power loss across the diode of course >which is the only negative and think of at this point. The design goal is to have TWO INDEPENDENT paths of power to the e-bus, ONE of which is battery direct so that one can operate e-bus loads with the battery master switch off. If you use a single switch in the mode you've described, there is a single point of failure in the switch. Voltage drop in the diode is not significant. Consider the fact that when power is expected to come through the diode, the alternator is operating. This raises the main bus to 14.2 to 14.6 volts. A typical 0.7 volt drop in the diode offers an e-bus supply of 13.5 to 13.9 volts . . . entirely satisfactory supply levels. Contrast normal operating conditions with battery-only operations where the e-bus will start out at 12.5 and drop to 11.0 by the time the battery is used up. Bob . . . ________________________________________________________________________________
Date: Mar 10, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> > >I think it's important to take into account what the purpose of the switch >and/or diode is, and more important, what the failure modes of the >circuits around it is. A diode may be much more reliable when used within >it's designed specs, but if you overload it, it will fail much quicker >than a switch. Compare a diode and a switch, both rated at 25A. A >short-circuit current of 100A through the diode for a few seconds will >make it fail, most likely open circuit. The same current through a switch >may heat it up and damage the contacts, even cause some sparks, but it may >still limp along. I've never replaced a diode that failed open. I don't mean to imply that they NEVER fail open but in what must be dozens of personal observations, I've never seen one open. Oh yeah, take that back. I did have a plastic 1A device that blew up such that the stuff between the wires just disappeared. I guess that could be classified as an "open". Diodes are generally pretty robust. Exemplar devices might include the diminutive 1A, plastic 1N4001 described here . . . http://www.aeroelectric.com/Mfgr_Data/Semiconductors/1N4001.pdf and his big brother 25A bridge rectifier . . . http://www.aeroelectric.com/Mfgr_Data/Semiconductors/gbpc12.pdf Note that the single cycle surge (approx 8 milliseconds) for the 1A device is 30A. The 25A device will stand off 300A for 8 mS. Power diodes for steering energy amongst the busses in the heavy iron birds have been used for 50+ years. Their failure rates have been exceedingly low. Diodes also have an exceedingly long service life. I've never seen one 'wear out'. On the other hand, switches do have a service life . . . one that is profoundly affected by numbers of operations per year and under what electrical load and environmental conditions. I've seen switches open up with very few cycles on them after ten+ years of sitting in an airplane. 99.9% of observed diode failures in light aircraft were in alternators where the designers of the installation did not exercise due diligence with respect to cooling. Concerns for a 25A diode used as the e-bus normal feedpath management are not well founded. Bob . . . ________________________________________________________________________________
Date: Mar 10, 2008
Subject: Re: ANL/ANN current limiter
> >Hello > > I have a relatively long run (10+ ft) of 1/0 CCA main battery power > wire in my -8 I am building from the rear baggage all the way to the > front firewall. I would like to install an current limiter on the output > of the battery as an added layer of protection for my long wire run. I > know Mr. Nuckolls has not advocated that on small aircraft, but I want to > do it anyway as peace of mind since the wire passes thru quite few > bulkheads and want to have something which will trip alot faster than I > can act. So, which is the better choice, ANN or ANL and what current > rating would be best, I have a 200 hp angle valve to start? An ANL200 will carry 300A continuously. See: http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf This device can practically be expected to carry worst case cranking currents without nuisance tripping. At the same time, if you did fault that cable to the edge of a lightening hole, the same ANL will probably not trip while the wire burns its way clear at the edge of the hole. This is why these circuits have not been "protected" in TC aircraft. Protection robust enough to stay connected for worst case cranking will also carry more than enough current in a 'soft fault' condition to burn away the offending aluminum with little or no damage to the copper. Bob . . . ________________________________________________________________________________
Date: Mar 10, 2008
Subject: Re: "Coat Hanger" antenna
>No offense to Ernest or Bob, the old coat hanger >antennas that you terminated the coax with crimp on >lugs has not been used in production airplanes since >the 50's or early 60's. > >Coat hanger antenna ><http://www.aircraftspruce.com/catalog/avpages/av534.php>http://www.aircraftspruce.com/catalog/avpages/av534.php > >What Eric says about "EM field energy", which I recall >bits from physics and armature radio, the coax, >BNC connector is way more efficient. That inch of >exposed shield/core & important lost insulation does >count. The "coat hanger antenna connections are >subject to corrosion and fatigue way more than a BNC >connector. Just my opinion. But without quantification. The advantages of the modern antennas are mainly mechanical. They don't twist in the insulator. In high-dollar models there are p-static immunities due to the DC grounded fabrication . . . and they look sexier and have lower maintenance costs. > >No one is seriously using the coat hanger wire antenna >on new OEM aircraft any more. . . . for the reasons stated plus some others but none related to observable performance. >"Testimonials" that they work in the plane or bench are >great, but unless you do a test on the airframe in an >antenna test chamber (EMF / RF anechoic chamber), >we are guessing. Besides performance there is the >reliability of the installation. > >Just from an installation standpoint, spend the $124 >for the real antenna and leave the $50 coat hanger >antenna for the closet. Antenna energy, non-ionizing >radiation is EMF energy at high frequencies. It needs >"ducting" to be most effective. ???? don't know what this "ducting" stuff is. > >Does the "strip-it crimp-it" antenna connection work? >Yes it "works", but gosh ughaaa, ugly. > >We're talking about 5-8 watts of energy and communications >of 5 to 50 mile, line of sight, listening for even more powerful >transmitters, usually without obstacles. We can get away >with a weak antenna. "Weak" is un-quantified. However, just like concerns about "iron poor blood" it may help sell alternative antennas. > >The coat hanger works, but its not ideal. We have better >ways. If I was restoring a classic Beech or something, yea >I'd keep the coat hanger antenna. Other wise coat hangers >are for the closet (pun intended). > >$110-$150 for newer antenna design > ><http://www.aircraftspruce.com/catalog/avpages/av17.php>http://www.aircraftspruce.com/catalog/avpages/av17.php > >PS: Some have experienced RFI with unshielded antenna >connections thru gauges and avionics. Now this IS a potential effect because the little chunk of antenna inside the aircraft is indeed a radiator. However, in the age of plastic airplanes (both experimental and T/C) and reasonable adherence to DO-160 radiated and conducted susceptibility issues, potential victims are not going to go T/U due to the small increase in energy at the panel due to errant radiation. Field strengths for your VHF comm while transmitting are really strong in the cockpit (tens of volts per meter) even with idealized antenna installations. Bottom line is that we're fabricating OBAM aircraft. Yes, there are sexier, more convenient and probably more 'efficient' antennas to be considered over the stone-simple, rod and feed-thru insulator antennas that were quite popular 40 years ago. It all comes down to the builder's preferences for trading his/her personal expenditure of $time$ versus purchasing the product of someone else's $time$ for a more sophisticated design. Performance risks for going the low-dollar, DIY route are low and easily managed. Bob . . . ________________________________________________________________________________
Subject: Plane Power's Friendly Warning Light
Date: Mar 10, 2008
B&C's flashing warning light is pretty annoying, so I was glad to see Plane Power's light is a steady, happy glow. Trouble is, it turns out, that the annoying flash is pretty handy when you really need to see it...no equipment failures to report, just didn't use the checklist...twice >:-( So, does anyone have a suggestion as to how to wire a flasher into the PP light? Can I just use a simple automotive flasher, or do I need something designed for less current? I want a fairly high (annoying) flash rate. Hope I don't need a horn. Thanks, Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
Date: Mar 11, 2008
Subject: Re: Plane Power's Friendly Warning Light
>B&C's flashing warning light is pretty annoying, so I was glad to see >Plane Power's light is a steady, happy glow. If I recall correctly, the Plane Power warning light drives from the alternator fail output of the built-in regulator. While certainly better than no light, it's not an independent monitor of alternator/regulator performance. You might consider a separate LV Warning system that flashes the light. > >Trouble is, it turns out, that the annoying flash is pretty handy when you >really need to see it...no equipment failures to report, just didn't use >the checklist...twice >:-( Yup, when we crafted that system the flash rate was set at approx 3 flashes per second. Supposedly this is the rate most 'irritating', i.e. attention getting for cockpit warning lamps. Bill also supplied a 6v lamp for the 14V regulators to increase intensity of the lamp for sunlight viewability. > >So, does anyone have a suggestion as to how to wire a flasher into the PP >light? Can I just use a simple automotive flasher, or do I need something >designed for less current? I want a fairly high (annoying) flash rate. The simplest method for adding flashing to an existing lamp circuit is by means of a "two-wire lamp flasher". There are a number of variations on the theme. One such circuit is illustrated here: http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_1.pdf This circuit should be assembled with a C-Mos version of the ubiquitous 555 timer. In this case, the Intersil ICM7555 is called out. This flasher will deliver a symmetrical ON-OFF flash pattern at approx 3Hz. An alternative is shown at: http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_2.pdf This is built from more generic discrete parts and can probably be made to do what you want to accomplish although its not likely to be a symmetrical pattern. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Critique please Bob and other learned members
Date: Mar 12, 2008
Bob, First, thank you for your outstanding contribution to the OBAM community, especially for the AeroElectric Connection, this email list, and the sample wire book which we have used to craft our design. We are building an all electric panel, IFR RV-10, and in the development of our thoughts and knowledge about and around our electrical design, your input, and that of the other learned people on this email list, have been invaluable. You have all helped us move from a position of zero knowledge to a position where we now have some idea of what questions to ask. We struggled around Z-14, Z-13/8 and finally Z-12 to settle on our current design, and we would welcome comments from you and others on any aspect of our design, but especially on the specific question areas noted below. Our mission is cross country flight with IFR capability, mostly with two POB and the ability to take large amounts of luggage as we tour Australia. We concluded that the alternator was the unit with the highest probability of failure in service and decided early on that we would go with 2 alternators. We have calculated that we have added about 55 lb to the basic VANs design empty weight, primarily in the panel, console, overhead console, second alternator and second battery. We have elected to maintain design gross weight which limits baggage in the baggage compartment to 45lb 95% of the time my wife and I will fly in the front seats. We are both light by VANs standards, and that combination plus the added weight indicated a need to move some weight forward. We have decided to go with 2 PC680 batteries instead of the standard battery, and the W & B works out theoretically perfect with the second battery relocated forward in the centre console. The console battery, power buss and power switches are all co-located in the centre console with a spark isolation barrier between the electrical switches and the fuel system. This is a long introduction, but necessary I think for you to understand why we have gone the way we have. We began by trying to fit Z14 to our perceived needs, then Z13/8. The electrical load analysis shows that in IFR conditions with the pitot heater on, we will draw about 17 amps continuous on the power circuit and also on the combined endurance and avionics circuits. The max/intermittent draw on each circuit is about 37 amps. We weren=92t happy with either of these being loaded onto the 20 amp system as part of normal operations, especially if that system was to be our endurance circuit. Z14 and Z13/8 also both required that we run an extra fat wire back to one of the batteries. Our decision finally was that we should concentrate on designing the system for robust normal operations with the minimum parts count for reliability, weight and cost reasons, and make the back up systems as simple as possible. We decided to go with a modified Z12 design because it keeps the noisy wires firewall forward and away from the panel, it uses one less contactor to use both batteries to crank the engine, the day to day loads are left with the larger alternator, and there is one less fat wire needed when the batteries are down the back. Normal operations will be to run with both battery contactors energised, the main alt on, the endurance and avionics busses fed from the main buss, and the aux alt resting on standby. Failure modes would be treated as follows:- Main alt failure - turn off main alt, turn on aux alt and adjust loads to suit Much less likely failures:- Main battery contactor fails closed in flight ' no action needed till landed Main battery contactor fails open in flight ' The alternator load is balanced by the aux battery which needs to be always on in flight. The main battery relay can be opened to bring the main battery back on line Aux battery contactor fails closed in flight ' no action needed till landed Aux battery contactor fails open in flight ' No action necessary, but aux relay can be opened if desired Both alts fail ' Open main or aux battery relay to run min endurance load approx 3.5A. Close main and aux batt contactors to conserve power for landing phase Fuse link between power buss and endurance buss blows ' Open main or aux batt relay to feed endurance and avionics busses Alternators:- We plan to go with the Plane Power 60A alternator for the main alt, primarily because of its inherent simplicity from an installation and operations perspective. We plan to leave the aux alt turned off unless the main alt fails, which means it should rarely get used. The SD 8 seems perfectly designed for this task and there is about a 3 lb penalty with the SD 20, but the SD 20 will give better peace of mind should the main alt fail in IMC. So, we plan to go with the SD-20 subject to your critique, and this leads us to our first question:- Is it OK to leave the SD 20 installed but not running? Will this cause any problems with the SD 20? Are the generic ford regulator and OVM adequate and appropriate to this task with the SD 20? Power supply to the alternator fields:- Do you have any concerns with the alt fields supplied as depicted ' ie main alt field via 22AWG fuseable link through 18AWG wire to the 5A CB, then 20AWG to switch and the main alt field. Does it matter which side of the switch the CB goes in this case? Would a 5A SCB be better? Ground system:- We plan to use your forest of tabs either side of the firewall for everything on the panel and firewall forward, with the engine crankcase grounded to the through firewall stud. We have nominated local grounds for items such as landing lights, pitot heater, etc. We think we should ground both batteries locally. Is this correct, or should we handle battery grounds some other way with this design? Fuse tray:- Are there any risks in placing the endurance buss, avionics buss, regulator and OVM in close proximity to each other on a hinged fuse tray under the panel? Is there a preferred way to connect the two busses together when in such close proximity? We currently plan not to fit the diode between the main buss and the endurance buss because the SD 20 gives us the time needed to systematically reduce loads as needed should the main alt fail. Do we create any problems for ourselves not having an isolation relay or diode between the main buss and the endurance buss? Bob, in appendix Z you comment that the ACS-OFF-L-R-BOTH-START keyswitch is not suitable for electronic ignition. I have also read somewhere that if you use this switch with an electronic ignition you disconnect the ground at the back of the switch. We are confused on this matter, so would you please explain whether you can use this switch or not with a future electronic ignition, and what you have to do to make it work properly? If it can=92t be used, would you please explain what problem it causes? Do the same issues apply with the potential future installation of a Pmag? Bob and others, we thank you for the time you take to look at our design, which is a works in progress. We will value any comments you care to make. John and Jenny Cleary and Peter Bowman, Australia Canopy and doors 90% done and 90% to go Trying to finalise the wiring plan so we can drill the holes and fit the cable attachments prior to painting inside Checked by AVG. 10/03/2008 11:07 AM ________________________________________________________________________________
Date: Mar 11, 2008
Subject: Re: Plane Power's Friendly Warning Light (Corrected
Link) B&C's flashing warning light is pretty annoying, so I was glad to see Plane Power's light is a steady, happy glow. If I recall correctly, the Plane Power warning light drives from the alternator fail output of the built-in regulator. While certainly better than no light, it's not an independent monitor of alternator/regulator performance. You might consider a separate LV Warning system that flashes the light. Trouble is, it turns out, that the annoying flash is pretty handy when you really need to see it...no equipment failures to report, just didn't use the checklist...twice >:-( Yup, when we crafted that system the flash rate was set at approx 3 flashes per second. Supposedly this is the rate most 'irritating', i.e. attention getting for cockpit warning lamps. Bill also supplied a 6v lamp for the 14V regulators to increase intensity of the lamp for sunlight viewability. So, does anyone have a suggestion as to how to wire a flasher into the PP light? Can I just use a simple automotive flasher, or do I need something designed for less current? I want a fairly high (annoying) flash rate. The simplest method for adding flashing to an existing lamp circuit is by means of a "two-wire lamp flasher". There are a number of variations on the theme. One such circuit is illustrated here: http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_1.pdf This circuit should be assembled with a C-Mos version of the ubiquitous 555 timer. In this case, the Intersil ICM7555 is called out. This flasher will deliver a symmetrical ON-OFF flash pattern at approx 3Hz. An alternative is shown at: http://www.aeroelectric.com/Pictures/Schematics/Lamp_Flasher_2.jpg (was .pdf) This is built from more generic discrete parts and can probably be made to do what you want to accomplish although its not likely to be a symmetrical pattern. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 11, 2008
>From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> >Subject: Re: "Coat Hanger" antenna >>No offense to Ernest or Bob, the old coat hanger >>antennas that you terminated the coax with crimp on >>lugs has not been used in production airplanes since >>the 50's or early 60's. >> >>Coat hanger antenna >><http://www.aircraftspruce.com/catalog/avpages/av534.php">http://www.aircraftspruce.com/catalog/avpages/av534.php>http://www.aircraftspruce.com/catalog/avpages/av534.php >> >>What Eric says about "EM field energy", which I recall >>bits from physics and armature radio, the coax, >>BNC connector is way more efficient. That inch of >>exposed shield/core & important lost insulation does >>count. The "coat hanger antenna connections are >>subject to corrosion and fatigue way more than a BNC >>connector. Just my opinion. >But without quantification. The advantages of the >modern antennas are mainly mechanical. They don't >twist in the insulator. In high-dollar models there >are p-static immunities due to the DC grounded >fabrication . . . and they look sexier and have lower >maintenance costs. Bob its more than sexy it is indeed that last inch of exposed dielectric, often close to some conductive material, even in a composite plane (don't they need a ground plane for a 1/4 wave dipole?) that is the issue, at least to me. >>No one is seriously using the coat hanger wire antenna >>on new OEM aircraft any more. >for the reasons stated plus some others but >none related to observable performance. Bob I have to take your word for it. However in my experience I have seen these antennas SRW go up and up and up with time because of dissimilar metal corrosion and bad crimps. Like I said most pilots only demand short range line-O-sight communication, not DX comm. The term observable performance should include maintenance and durability in my humble opinion. >>"Testimonials" that they work in the plane or bench are >>great, but unless you do a test on the airframe in an >>antenna test chamber (EMF / RF anechoic chamber), >>we are guessing. Besides performance there is the >>reliability of the installation. >> >>Just from an installation standpoint, spend the $124 >>for the real antenna and leave the $50 coat hanger >>antenna for the closet. Antenna energy, non-ionizing >>radiation is EMF energy at high frequencies. It needs >>"ducting" to be most effective. >> >>???? don't know what this "ducting" stuff is. Well Wikipedia to the rescue: http://en.wikipedia.org/wiki/Coaxial_cable I use the word "ducting" in an informal way to describe how a coaxial cable propagates elect mag wave energy. "Coaxial lines solve this problem by confining the electromagnetic wave to the area inside the cable, between the center conductor and the shield. The transmission of energy in the line occurs totally through the dielectric inside the cable between the conductors." "ducting" - was a casual my way of describing how coaxial propagates EMW. Where open wire transmission lines, like you have that inch before the "coat hanger" antenna, two parallel wires, have the property where the electromagnetic wave propagating down the line, extends into the space surrounding it, an undesirable characteristic. You say the loss is small? OK I guess, sure but every little bit helps or hurts. The fact is radios are so good with filters and excellent sensitivity and stability, a less than optimal antenna can be some what tollerated. >>Does the "strip-it crimp-it" antenna connection work? >>Yes it "works", but gosh ughaaa, ugly. >> >>We're talking about 5-8 watts of energy and communications >>of 5 to 50 mile, line of sight, listening for even more powerful >>transmitters, usually without obstacles. We can get away >>with a weak antenna. >"Weak" is un-quantified. However, just like concerns about >"iron poor blood" it may help sell alternative antennas. True it is unqualified, but we could get into dB or signal strength, but all I am saying is in Aviation we are talking about strong signals at short distances, most of the time, period. However if you want real long range communications at distance than it does matter. Yes "matter" is an unqualified term as well. >>The coat hanger works, but its not ideal. We have better >>ways. If I was restoring a classic Beech or something, yea >>I'd keep the coat hanger antenna. Other wise coat hangers >>are for the closet (pun intended). >> >>$110-$150 for newer antenna design >><http://www.aircraftspruce.com/catalog/avpages/av17.php">http://www.aircraftspruce.com/catalog/avpages/av17.php>http://www.aircraftspruce.com/catalog/avpages/av17.php >> >>PS: Some have experienced RFI with unshielded antenna >>connections thru gauges and avionics. >Now this IS a potential effect because the little >chunk of antenna inside the aircraft is indeed a >radiator. So true Bob. >However, in the age of plastic airplanes (both experimental >and T/C) and reasonable adherence to DO-160 radiated >and conducted susceptibility issues, potential victims >are not going to go T/U due to the small increase in >energy at the panel due to errant radiation. Field >strengths for your VHF comm. while transmitting are really >strong in the cockpit (tens of volts per meter) even >with idealized antenna installations. > >Bottom line is that we're fabricating OBAM aircraft. >Yes, there are sexier, more convenient and probably >more 'efficient' antennas to be considered over the >stone-simple, rod and feed-thru insulator antennas >that were quite popular 40 years ago. It all comes >down to the builder's preferences for trading his/her >personal expenditure of $time$ versus purchasing >the product of someone else's $time$ for a more >sophisticated design. Well sexier I guess, but cost is only times 2 and when you have a $1000 or $3000 radio, $60 more is a drop in da bucket. >Performance risks for going the low-dollar, DIY >route are low and easily managed. > >Bob Well I guess we disagree with the last part, but I agree making antennas and testing them is FUN! VHF on a plane is pretty easy, and I have no problem with a DIY, however as I said in my opinion, if you are going to buy an antenna, like most builders, get a $120 antenna with a BNC connector. My focus is all towards metal planes, composites have more flexibility to experiment with internal antennas. A BNC will be more secure & robust. You can have BNC problems and other issues, but keeping the coaxial cable intact to the last inch, is not totally trivial. With a composite plane the connection will be on the "back side of the ground plane? Right? There will be signal loss and reflected RF into the airplane, IMHO. Good discussion. The proof is in the eating of the pudding. Fly a plane with both antennas and test them against a ground station for both TX and RX. I think you will see a difference in one antenna getting a weak incoming signal and getting out a stronger signal. Of course bent whips are a compromise. The radiating element should be as perpendicular to the ground plane as possible but most pilots like the looks and lower drag of the bent whip for a little more SRW. Also the "Blade" high speed antennas have "wider" band width. There are good enough antennas and better, best antennas. It is definitely esoteric but for just secure connection the BNC has it over the crimp and screw exposed twin lead approach, at least in the VHF band of freq's, in my opinion. Old ways are still good but there is a reason new methods & connections where developed. It may take more sensitive lab equip to notice but I can't believe it makes NO difference, but than you say you tested it, and I have not. All I can go by is when trouble shooting poor radio performance on old planes, the first place I look is at those old corroded connections on the "coat hanger". Cheers George --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 11, 2008
From: "nauga(at)brick.net" <dhyde01(at)earthlink.net>
Subject: Request for Bob N.
Bob, I have not been able to reach you through direct e-mail or the message area of your website (multiple attempts both ways) - can you check on the status of an order for me? Dave 'Nauga' Hyde ________________________________________________________________________________
Subject: Test
Date: Mar 12, 2008
Date: Mar 12, 2008
> >From: "Robert L. Nuckolls, III" > <nuckolls.bob(at)cox.net> > >Subject: Re: "Coat Hanger" antenna > > > >>No offense to Ernest or Bob, the old coat hanger > >>antennas that you terminated the coax with crimp on > >>lugs has not been used in production airplanes since > >>the 50's or early 60's. > >> > >>Coat hanger antenna > > > >><<http://www.aircraftspruce.com/catalog/avpages/av534.php>http://www.aircraftspruce.com/catalog/avpages/av534.php>http://www.aircraftspruce.com/catalog/avpages/av534.php>http://www.aircraftspruce.com/catalog/avpages/av534.php > >> > >>What Eric says about "EM field energy", which I recall > >>bits from physics and armature radio, the coax, > >>BNC connector is way more efficient. That inch of > >>exposed shield/core & important lost insulation does > >>count. The "coat hanger antenna connections are > >>subject to corrosion and fatigue way more than a BNC > >>connector. Just my opinion. > > >But without quantification. The advantages of the > >modern antennas are mainly mechanical. They don't > >twist in the insulator. In high-dollar models there > >are p-static immunities due to the DC grounded > >fabrication . . . and they look sexier and have lower > >maintenance costs. > >Bob its more than sexy it is indeed that last inch of exposed >dielectric, often close to some conductive material, even >in a composite plane (don't they need a ground plane for a 1/4 >wave dipole?) that is the issue, at least to me. Sure. But let's consider the "loaded" antenna. An antenna that's physically too short for efficient operation at the desired frequency. The ideal, full sized quarter-wave mobile antennas operating at say 14 Mhz would LIKE to have about 17.5 feet of antenna on the bumper. See: http://tinyurl.com/2dyfss This is not practical on a moving vehicle so some means of electrically lengthening a "too short" antenna is called for. This is done in a variety of ways but all involve adding some reactive component (inductive or capacitive) to the antenna. My last HF mobile installation featured a 4' stub mast, an adjustable center loading coil and an 8' whip antenna above all this. Here's a modern example of this style of artificial antenna lengthening: http://www.hiqantennas.com/images/MVC-462.jpg Let's examine a practical example where there's value in making an antenna shorter while minimizing effects on performance. A few years ago I got a call from the production line on some new ELT transmitters that were shutting down with a high SWR fault. Here's the antennas in question: http://tinyurl.com/2u5c8u The original system integrator installed dual antennas (125.5 and 406 Mhz) under the fiberglas 'instep cap' of the vertical fin. There were some composite air ducts with metallic components also located in the fin cap. These not only made it necessary to fold the longer antenna over, proximity of the metal further de-tuned it. See: http://tinyurl.com/38symp Older versions of the ELT transmitter would tolerate this degradation of antenna performance, the new ones would not. I wrote a white paper suggesting a variety of options. The elegant solution was a top-loaded antenna physically short enough to mount under the fin cap and avoid close proximity to the duct-metal. http://tinyurl.com/2vv5e4 I crafted an exemplar antenna that was only 9" tall and took it to the lab for comparison with a full sized 24" antenna. It's radiation angle was higher and maximum radiation levels were down by less than 2 dB from the full sized quarter wave. Entirely satisfactory for this installation. We could have considered some other scenarios. See: http://tinyurl.com/3aaocs There are an infinite number of combinations of top, center and base loading that would minimize SWR at the frequency of interest. However, all versions other than top-loading increased fabrication labor and produced a lower performance. Let's take the ideas illustrated above and consider when one chooses to use the stone-simple, rod and feed-thru antenna. Open conductors have inductance. As a rule of thumb, we ball-park an open wire (and in this case, an extension of the antenna base below the ground plane) at 20 nH/inch. Assuming 1.5" of bare conductors total, we can expect something on the order of 30nH of series inductance at the base of the antenna. This works out to about 25 ohms of reactance at 130 Mhz. A full length, 24" antenna's center frequency would shift downward due to this loading inductance. A purest would get out the antenna analyzer and trim the antenna's physical length (shift toward capacitive reactance) to balance reactive effects of the base loading inductance. The next time I have occasion to get the test ground plane out, I'll take a look at the effects of exposed conductors at the base of the stone-simple antenna and report the amount of shortening required to shift the antenna's center frequency back to the design optimum. These exposed conductors ARE at the base of the antenna where the highest currents are encountered which go hand-in-hand with the highest radiation. So indeed, we are squirting some RF into the aircraft's interior spaces that would not be present with other antennas . . . but in practice this is seldom a problem either for EMC issues or overall performance. > > >>No one is seriously using the coat hanger wire antenna > >>on new OEM aircraft any more. > > >for the reasons stated plus some others but > >none related to observable performance. > >Bob I have to take your word for it. However in my experience >I have seen these antennas SRW go up and up and up with time >because of dissimilar metal corrosion and bad crimps. Absolutely! But connectors corrode too . . . and suffer from bad craftsmanship at assembly. I tossed out the large-area, low-pressure ground terminal supplied with the stone-simple antenna and substituted a PIDG terminal properly bonded to the skin with a 10-32 screw torqued up tight. Similarly, I made sure that the PIDG terminal at the base of the antenna had the super-mash on it between two nuts. If you don't have gas-tight joints, they will degrade with time. > Like I >said most pilots only demand short range line-O-sight >communication, not DX comm. The term observable >performance should include maintenance and durability in >my humble opinion. To be sure. The DIY antennas do have cost of ownership issues that are strongly affected by craftsmanship of the original installation. But if one understands the potential 'gotchas' with ANY antenna and exercises due diligence for craftsmanship, there's good value to be realized from either of these antennas. 't know what this "ducting" stuff is. > >Well Wikipedia to the rescue: ><http://en.wikipedia.org/wiki/Coaxial_cable>http://en.wikipedia.org/wiki/Coaxial_cable > >I use the word "ducting" in an informal way to describe how >a coaxial cable propagates elect mag wave energy. > > "Coaxial lines solve this problem by confining the > electromagnetic wave to the area inside the cable, > between the center conductor and the shield. The > transmission of energy in the line occurs totally through > the dielectric inside the cable between the conductors." > >"ducting" - was a casual my way of describing how coaxial >propagates EMW. Where open wire transmission lines, like >you have that inch before the "coat hanger" antenna, two >parallel wires, have the property where the electromagnetic >wave propagating down the line, extends into the space >surrounding it, an undesirable characteristic. You say the >loss is small? OK I guess, sure but every little bit helps >or hurts. The fact is radios are so good with filters and >excellent sensitivity and stability, a less than optimal >antenna can be some what tollerated. Understand. > > > >"Weak" is un-quantified. However, just like concerns about > >"iron poor blood" it may help sell alternative antennas. > >True it is unqualified, but we could get into dB or signal strength, >but all I am saying is in Aviation we are talking about strong >signals at short distances, most of the time, period. However if >you want real long range communications at distance than it >does matter. Yes "matter" is an unqualified term as well. Wouldn't argue that the stone-simple antenna does not represent the best-we-know-how-to-do. But neither is a Toyota starter bolted to a Lycoming on an adapter plate carved out on a bandsaw. I would recommend that any builder take advantage of the convenience of pre-fabricated, optimized antennas. But I think we would be remiss as teachers if we did not define the simple-ideas that control performance and service life of the DIY approaches. I would not discourage anyone from doing the best they can with what they have to work with . . . whether by choice or circumstance. > > >Bottom line is that we're fabricating OBAM aircraft. > >Yes, there are sexier, more convenient and probably > >more 'efficient' antennas to be considered over the > >stone-simple, rod and feed-thru insulator antennas > >that were quite popular 40 years ago. It all comes > >down to the builder's preferences for trading his/her > >personal expenditure of $time$ versus purchasing > >the product of someone else's $time$ for a more > >sophisticated design. > >Well sexier I guess, but cost is only times 2 and when you >have a $1000 or $3000 radio, $60 more is a drop in da bucket. Agreed. But one can do the stone-simple antenna with self procured components for much less than the $60 sale price . . . and there are very few builders who have $3000 tied up in a radio. > > >Performance risks for going the low-dollar, DIY > >route are low and easily managed. > > > >Bob > >Well I guess we disagree with the last part, but I agree >making antennas and testing them is FUN! VHF on a plane >is pretty easy, and I have no problem with a DIY, however >as I said in my opinion, if you are going to buy an antenna, >like most builders, get a $120 antenna with a BNC connector. >My focus is all towards metal planes, composites have more >flexibility to experiment with internal antennas. > >A BNC will be more secure & robust. You can have BNC >problems and other issues, but keeping the coaxial cable >intact to the last inch, is not totally trivial. True. We could build a bracket to mount the connector but it needs to be attached to the airframe with rivets, not by assembly forces of the ceramic feed-thru insulator. The problems of establishing gas-tight joints at both the ground plane and at the antenna feed-point are the same for both metal and plastic airplanes. See: http://tinyurl.com/yu38rz I would hope that the efforts I made toward that goal over 35 years ago paid off in trouble-free performance over the lifetime of the installation. The last time I had occasion to install a rod-n-cone antenna was on a wrecked straight-tail, C182 during the rebuild. It was a belly mounted antenna for a #2 nav/com. The antenna survived the accident but the belly skin was wrinkled and got replaced. > >With a composite plane the connection will be on the "back >side of the ground plane? Right? There will be signal loss and >reflected RF into the airplane, IMHO. True. The effects are non-zero but for most users are not operationally significant. > >Good discussion. The proof is in the eating of the pudding. >Fly a plane with both antennas and test them against a >ground station for both TX and RX. I think you will see a >difference in one antenna getting a weak incoming signal >and getting out a stronger signal. Of course bent whips >are a compromise. The radiating element should be as >perpendicular to the ground plane as possible but most >pilots like the looks and lower drag of the bent whip for a >little more SRW. Also the "Blade" high speed antennas >have "wider" band width. There are good enough antennas >and better, best antennas. It is definitely esoteric but for >just secure connection the BNC has it over the crimp >and screw exposed twin lead approach, at least in the >VHF band of freq's, in my opinion. Old ways are still >good but there is a reason new methods & connections >where developed. It may take more sensitive lab equip >to notice but I can't believe it makes NO difference, . . . no perceivable difference from the pilot's seat. We often get wrapped around a performance axle trying to tweak things based on test measurements that return no operational benefits. I had one instructor tell me there was benefit after a balked landing to turn off the alternator so that we could get more horsepower to the prop! Intuitively we know there's a measurable difference but the practical benefits are someplace between zero and not much. > . . . but than you say you tested it, and I have not. All of the testing has been in the lab were we do indeed see quantifiable differences. But in practice, tens of thousands of these antennas have flown and offered the user good return on investment too. > All I can go >by is when trouble shooting poor radio performance on >old planes, the first place I look is at those old corroded >connections on the "coat hanger". All very much on point . . . and I would suggest that any readers of this List make note of the fact that some installations are more deserving of preventative maintenance than others. Use of good assembly practice when making up the joints will forestall if not eliminate future maintenance events. Bob . . . ________________________________________________________________________________
Subject: Re: Z-19 Series Architecture
Date: Mar 12, 2008
Listers, I've posted this question a couple of times via the Matronics Forum interface, but I've not gotten a response. My posts are coming back to me via the daily list digest, but I'm not sure Bob is getting them. Should I email directly to the Matronics list instead of posting via the Forum? Regards, Mark Mark Sletten wrote: > Bob, > > On the Z-19 rev M and Z-19/RB rev A drawings the E-BUS normal feed is from > the Main PWR Dist block thru a 7A breaker and diode. > > On all other drawings it appears the E-BUS normal feed is directly off the > Main PWR Dist Block binding post (not a breaker) thru a diode. > > Is there a reason for the different setup on the Z-19 series? > > > Regards, > > Mark Sletten -------- Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169244#169244 ________________________________________________________________________________
Date: Mar 12, 2008
Mark, Your posts are getting through, I've not seen any replies to your question either. There was a related Z19 question a few weeks before xmas about updating the Z19 to reflect separate power feeds for coils (and possibly injectors). No further replies seen on that either. Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169263#169263 ________________________________________________________________________________
Date: Mar 12, 2008
Mark, I questioned that too. Not sure I ever got a strait answer. As far as I am concerned that constitutes the weakest link for what is supposed to be an essential bus system. I did see something Bob mentioned about the feed coming from both ends. One side is fed from the 7A fuse, and the other from the switch which is powered via the backup battery via its contactor switch. I believe Bob's logic is that one will backup the other. If you turn the switch off, the e-bus still has 7A and if you lose the 7A job, the switch will power the e-bus through via the backup battery contactor. The diode keeps the juice from going back other way (through the fuse) when powered by the switch. Earlier I questioned the 7A limit, but if you start breaking down the load, that can support a lot of today's panel. A Dynon and an sl30 are still within values. That's all I need to get down. The fuel pumps, ignition and engine stuff would all feed off of the secondary power switch not the e-bus. To hell with idealism - for my Sub, the e-bus will work both ways based on the intended design or an improvement in it. 7A is not going to make anything glow. In an emergency we'll be glad for the 7A. What I think is missing or confusing is the process (a standard issue for technos). Be sure you have a sound practice for throwing switches and knowing what is working etc. I may even include a warning light which closes if that ole 7A takes a pill. How'z that project going? Glenn http://n661gl.blogspot.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Sletten Sent: Wednesday, March 12, 2008 11:06 AM Subject: AeroElectric-List: Re: Z-19 Series Architecture --> Listers, I've posted this question a couple of times via the Matronics Forum interface, but I've not gotten a response. My posts are coming back to me via the daily list digest, but I'm not sure Bob is getting them. Should I email directly to the Matronics list instead of posting via the Forum? Regards, Mark Mark Sletten wrote: > Bob, > > On the Z-19 rev M and Z-19/RB rev A drawings the E-BUS normal feed is > from the Main PWR Dist block thru a 7A breaker and diode. > > On all other drawings it appears the E-BUS normal feed is directly off > the Main PWR Dist Block binding post (not a breaker) thru a diode. > > Is there a reason for the different setup on the Z-19 series? > > > Regards, > > Mark Sletten -------- Mark Sletten Legacy FG N828LM http://www.legacyfgbuilder.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169244#169244 ________________________________________________________________________________
Date: Mar 12, 2008
>Mark Sletten wrote: > > Bob, > > > > On the Z-19 rev M and Z-19/RB rev A drawings the E-BUS normal feed is from > > the Main PWR Dist block thru a 7A breaker and diode. > > > > On all other drawings it appears the E-BUS normal feed is directly off the > > Main PWR Dist Block binding post (not a breaker) thru a diode. > > > > Is there a reason for the different setup on the Z-19 series? No reason other than observance practice for protecting any small wire feeder of 6" or more in length. If the e-bus is located right next to the main bus fuse block, then you can make direct connections through the diode without fuses or breakers to protect the wires. Bob . . . ________________________________________________________________________________
Date: Mar 12, 2008
> >Mark, > >Your posts are getting through, I've not seen any replies to your question >either. > >There was a related Z19 question a few weeks before xmas about updating >the Z19 to reflect separate power feeds for coils (and possibly >injectors). No further replies seen on that either. I'm not in a position at present to modify the Z-figures for the purpose of customizing. Remember, these are intended to illustrate architectures that offer attractive failure modes effects analysis, I.e, failure tolerance. Exactly what loads are tied to what busses by what sizes of wire/fuse is up to the builder to work out as appropriate to their particular engine and suite of appliances. Bob . . . ________________________________________________________________________________
Date: Mar 12, 2008
Subject: Re: Diodes versus switches 101 ?
> > Bill Schlatterer wrote: >> >> There was some discussion about Z19 using diodes in a critical ECU >> circuit and the question arose as to what kind of failure modes apply >> to diodes and their reliability as compared to switches. I think the >> trust of that thread (sub list) and post below is that diodes might >> be "automatic" but switches are safer and less likely to fail? ( I >> have no opinion but would like to understand the rationale ) This >> was posted and I was just wondering what the thought might be on the >> AE list since most of Bobs diagrams "suggest" a diode in the E-Bus >> circuit as opposed to a switch. That might not be AS critical as the >> ECU/EFI circuit on an all electric engine but the same concerns still >> apply? >> >> Posted to the Sub list: >> >> "After 30 years in the industrial electrical construction and >> maintenance field I can say without equivocation that a robust switch >> is much less likely to fail than a robust diode. The science of the >> switch is much simpler - use a lot of good conducting material that >> is not likely to corrode and support it with stout mechanical parts >> that hold tightly. >> >> Now, by contrast, the science of the diode starts with getting good >> silicon material and contaminating it in just the right proportion >> with just the right material at just the right temperature for just >> the right time. THEN you can start on building the junctions onto >> some sort of heat dissipating holder. I have replaced dozens of solid >> state devices that failed (always failed open) and I never found the >> root cause of failure. I put in an exact replacement and the circuit >> worked just fine for years. The trade off you get for the "automatic" >> switching of a diode vs. the manual switch is in the area of >> RELIABILITY. I'll be using manual switches for all critical loads." >> >> Not wanting to stir anything up, just want to understand the thinking >> and factual matter in the post above? >> Thanks Bill S >> 7a Z13/8 Z32(HD E-Bus) Z35(7ah) >> > Not a direct answer to the question of whether a diode is more likely to fail than a switch, but a response to the method used to reach his answer. Old pre-1970's era point-type ignitions are based around switches (the points). Just about every production car since then has used variations on diodes (doped semiconductor junctions) in all the various components of modern solid state ignitions (transistors, FETs, photocells, etc). Using his analysis technique, it's obvious that point-type ignitions are the way to go, since they are in fact cheaper & *much* simpler. Yet we don't see them in new cars. The real question is, which is more reliable in real world applications? Charlie ________________________________________________________________________________
Date: Mar 12, 2008
Subject: Re: switch wiring
Kevin You may need a starter contactor or relay but an ON-OFF-momentary ON switch can probably be wired to do the mags like that. I don't know if you will find such a ready made diagram though (or anyone to recommend it), as I think such a scheme would greatly increase the risk of injury from a live mag. I can understand an OFF-Batt-Alt switch but generally I try to avoid those 3 position switches as I find them awkward, especially at night. Also it may be more common to use a separate switch for each alternator. That way one failed switch can't disable both alternators. Ken Kevin Klinefelter wrote: > > > Bob and all, > > I have a couple questions. > > I am wiring a Rotax 914 in my Europa per Z-16(sort of). I want to use a > switch for each "mag" that will be down-off, middle-on, momentary-up of > both to start. Is there a drawing somewhere on the site that shows how > to wire this? > > I also want to wire a switch to control two alternators, the rotax built > indynamo and a Denso IR alternator mounted on the vac pad. I would like > to use one switch; down-dynamo middle-off and up-main > alternator(denso).Is there a drawing showing how to wire that? > > Thanks, Kevin > ________________________________________________________________________________
Date: Mar 12, 2008
Kevin Klinefelter wrote: Bob and all, I have a couple questions. I am wiring a Rotax 914 in my Europa per Z-16(sort of). I want to use a switch for each "mag" that will be down-off, middle-on, momentary-up of both to start. Is there a drawing somewhere on the site that shows how to wire this? I also want to wire a switch to control two alternators, the rotax built indynamo and a Denso IR alternator mounted on the vac pad. I would like to use one switch; down-dynamo middle-off and up-main alternator(denso).Is there a drawing showing how to wire that? Thanks, Kevin For the ignition switches you need two, two-pole, three position, center off, one side momentary devices. Another way to describe this switch is 2P3T on-off-(on). This would be a B&C S700-2-5 switch. See: http://www.bandc.biz Wire one side of each switch to their respective ignition modules such that the switch is closed in the down position and shorts the ignition module to an OFF condition. Wire the other sides of the two switches in series such that both have to be lifted to the START position to engage the starter contactor. Recommend you keep the two alternator switches separate. You don't want failure of one switch to cause both alternators to become unavailable to you. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 12, 2008
There was some discussion about Z19 using diodes in a critical ECU circuit and the question arose as to what kind of failure modes apply to diodes and their reliability as compared to switches. I think the trust of that thread (sub list) and post below is that diodes might be "automatic" but switches are safer and less likely to fail? ( I have no opinion but would like to understand the rationale ) This was posted and I was just wondering what the thought might be on the AE list since most of Bobs diagrams "suggest" a diode in the E-Bus circuit as opposed to a switch. That might not be AS critical as the ECU/EFI circuit on an all electric engine but the same concerns still apply? Posted to the Sub list: "After 30 years in the industrial electrical construction and maintenance field I can say without equivocation that a robust switch is much less likely to fail than a robust diode. The science of the switch is much simpler - use a lot of good conducting material that is not likely to corrode and support it with stout mechanical parts that hold tightly. Now, by contrast, the science of the diode starts with getting good silicon material and contaminating it in just the right proportion with just the right material at just the right temperature for just the right time. THEN you can start on building the junctions onto some sort of heat dissipating holder. I have replaced dozens of solid state devices that failed (always failed open) Interesting! Most solid state failures I've observed were shorted devices (overheated and or voltage spiked). The devices that did go OPEN were transistors that shorted first and then opened their emitter bond-wires due to over current. . . . and I never found the root cause of failure. I put in an exact replacement and the circuit worked just fine for years. The trade off you get for the "automatic" switching of a diode vs. the manual switch is in the area of RELIABILITY. I'll be using manual switches for all critical loads." Not wanting to stir anything up, just want to understand the thinking and factual matter in the post above? About 1980 I was designing a new solid state speed controller and runaway monitor system for the Lear 55 and ultimately the entire fleet of 30 series aircraft. It was the first time I was tasked with doing a formal failure mode effects analysis and mean-time-between-failures (MTBF) study on a new product. I dug out Mil-HDK-217 and began slogging through the part-by-part service life prediction algorithms. By the time some 200+ items of solder joints, transistors, resistors, capacitors, etc were all accounted for, I was pleased to turn the crank and a really nice MTBF number on the order of 10,000 hours fell out. But wait, there was this really expensive, mil-spec, hermetically sealed 25A power relay used as a last-ditch backup disconnect. After factoring this device into the grand scheme of things, my shinning MTBF number fell to something on the order of 900 hours! Several times over the last 25 years I've asked the guys at Electromech's field service shop how the Lear trim controllers are holding up. The failure items they have to report were surprising. MOST of the field failures were in mass-terminated ribbon cable connectors followed by loss of ground through the mounting hardware that held the two boards together. Seems this was before I learned about having solid, on-purpose wiring grounds and NOT to depend on mountings that loosen and/or corrode. Electronically, most failures were the usual gang of jelly bean components, solder joints, etc. Most failures were in the monitor boards that had 3x the parts count of a controller board. There were NO failures of the controller that caused a runaway and a tiny fraction of the failures incapacitated the system. There had been no failures for that piece-o-#@@$, high-dollar relay that crashed my MTBF study. Bottom line: Was this relay badly misjudged? No, I had a pretty good understanding of contact physics and designed the electronics such that relay contacts were closed before electronics actually caused the motor to run. Similarly, electronics shut the motor down and waited some tens of milliseconds before opening the relay. Hence, the relay was never required to actually switch any power. No current was flowing when the relay contacts opened or closed and current was not allowed to flow until contacts stopped bouncing on closure. This is why Lear bought my design with the somewhat distorted MTBF numbers because in thousands of hours of flight, the relay never really saw any switching service. Nowadays, there are more accurate considerations of how a part is used that will provide a more realistic prediction of failure rates. Does this mean that the very robust, mil-spec relay is the golden child of the design and the electronics were left holding the bag for all the failures? No, most failures were due to bonding/connection issues. This controller resides in the vertical fin, just under the leading edge of the stabilizer. This has to be the worst environment in the airplane for environmental extremes. For the most part, the electronics seem to be living up to predictions for a long and quite satisfactory service life in thousands of hours. My personal experience since supports an assertion that the silicon rectifier diode has an expected service life that will far outpace any electro-mechanical device (relay or switch) that is tasked with controlling current flow. Some of my most vexing field failures problems to solve involve relays or switches. I've never had to chase down root cause for failures of energy steering diodes in an airplane. Now, let us consider the gentleman's contrary assertion. No doubt he has replaced blown diodes and perceives them to be less robust than a switch. I cannot help but wonder if his problem children were not subject to overheating and or over-voltage due to industrial line transients or local lightning. Whatever the root cause of his observed failures, there is nothing in my experience or that of my colleagues in the aircraft industry that parallels his experience. I'm not suggesting that he is being untruthful; only that we're probably observing an apples/oranges situation. The environments in which our diodes live and the manner in which they are applied in airplanes are sufficiently different from his industrial environment to prevent a useful comparison. So please folks, don't rip out your diodes and put in switches. There are two reasons to support this suggestion: First, we design for failure tolerance. What are the risks if a diode DOES fail? How will the pilot know it? Is it pre-flight detectable? Will the failure cripple the system such that it becomes a hazard? If the answers to any of these questions give you cause for concern about comfortable termination of flight, then redesign the system to eliminate the potential for stress. Consider his statement: "I'll be using manual switches for all critical loads." Our common usage of steering diodes for power is one of TWO power paths to an e-bus. So even if it does fail open, it has backup. If it fails shorted, we can detect this during pre-flight. Second, there is nothing in the service history of diodes (or any other solid state device) to suggest they are recognized problem children waiting for a chance to ruin your day or drive up your cost of ownership. Bob . . . ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Diodes versus switches 101 ?
Date: Mar 12, 2008
Thanks Bob, that tells me what I need to know. Wasn't planning on taking the diode out anyway but it's good to understand the why and why not? My only regret about my building process is that once I'm done, I won't have much use for the things I have come to understand from this list. Education is a good thing but practical use makes it excellent. In my case, I have learned just enough from this list to recognize what I don't know yet? That may be the reason I become a repeat builder ;-) Thanks Bill S -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, March 12, 2008 9:41 PM Subject: Re: AeroElectric-List: Diodes versus switches 101 ? --> There was some discussion about Z19 using diodes in a critical ECU circuit and the question arose as to what kind of failure modes apply to diodes and their reliability as compared to switches. I think the trust of that thread (sub list) and post below is that diodes might be "automatic" but switches are safer and less likely to fail? ( I have no opinion but would like to understand the rationale ) This was posted and I was just wondering what the thought might be on the AE list since most of Bobs diagrams "suggest" a diode in the E-Bus circuit as opposed to a switch. That might not be AS critical as the ECU/EFI circuit on an all electric engine but the same concerns still apply? Posted to the Sub list: "After 30 years in the industrial electrical construction and maintenance field I can say without equivocation that a robust switch is much less likely to fail than a robust diode. The science of the switch is much simpler - use a lot of good conducting material that is not likely to corrode and support it with stout mechanical parts that hold tightly. Now, by contrast, the science of the diode starts with getting good silicon material and contaminating it in just the right proportion with just the right material at just the right temperature for just the right time. THEN you can start on building the junctions onto some sort of heat dissipating holder. I have replaced dozens of solid state devices that failed (always failed open) Interesting! Most solid state failures I've observed were shorted devices (overheated and or voltage spiked). The devices that did go OPEN were transistors that shorted first and then opened their emitter bond-wires due to over current. . . . and I never found the root cause of failure. I put in an exact replacement and the circuit worked just fine for years. The trade off you get for the "automatic" switching of a diode vs. the manual switch is in the area of RELIABILITY. I'll be using manual switches for all critical loads." Not wanting to stir anything up, just want to understand the thinking and factual matter in the post above? About 1980 I was designing a new solid state speed controller and runaway monitor system for the Lear 55 and ultimately the entire fleet of 30 series aircraft. It was the first time I was tasked with doing a formal failure mode effects analysis and mean-time-between-failures (MTBF) study on a new product. I dug out Mil-HDK-217 and began slogging through the part-by-part service life prediction algorithms. By the time some 200+ items of solder joints, transistors, resistors, capacitors, etc were all accounted for, I was pleased to turn the crank and a really nice MTBF number on the order of 10,000 hours fell out. But wait, there was this really expensive, mil-spec, hermetically sealed 25A power relay used as a last-ditch backup disconnect. After factoring this device into the grand scheme of things, my shinning MTBF number fell to something on the order of 900 hours! Several times over the last 25 years I've asked the guys at Electromech's field service shop how the Lear trim controllers are holding up. The failure items they have to report were surprising. MOST of the field failures were in mass-terminated ribbon cable connectors followed by loss of ground through the mounting hardware that held the two boards together. Seems this was before I learned about having solid, on-purpose wiring grounds and NOT to depend on mountings that loosen and/or corrode. Electronically, most failures were the usual gang of jelly bean components, solder joints, etc. Most failures were in the monitor boards that had 3x the parts count of a controller board. There were NO failures of the controller that caused a runaway and a tiny fraction of the failures incapacitated the system. There had been no failures for that piece-o-#@@$, high-dollar relay that crashed my MTBF study. Bottom line: Was this relay badly misjudged? No, I had a pretty good understanding of contact physics and designed the electronics such that relay contacts were closed before electronics actually caused the motor to run. Similarly, electronics shut the motor down and waited some tens of milliseconds before opening the relay. Hence, the relay was never required to actually switch any power. No current was flowing when the relay contacts opened or closed and current was not allowed to flow until contacts stopped bouncing on closure. This is why Lear bought my design with the somewhat distorted MTBF numbers because in thousands of hours of flight, the relay never really saw any switching service. Nowadays, there are more accurate considerations of how a part is used that will provide a more realistic prediction of failure rates. Does this mean that the very robust, mil-spec relay is the golden child of the design and the electronics were left holding the bag for all the failures? No, most failures were due to bonding/connection issues. This controller resides in the vertical fin, just under the leading edge of the stabilizer. This has to be the worst environment in the airplane for environmental extremes. For the most part, the electronics seem to be living up to predictions for a long and quite satisfactory service life in thousands of hours. My personal experience since supports an assertion that the silicon rectifier diode has an expected service life that will far outpace any electro-mechanical device (relay or switch) that is tasked with controlling current flow. Some of my most vexing field failures problems to solve involve relays or switches. I've never had to chase down root cause for failures of energy steering diodes in an airplane. Now, let us consider the gentleman's contrary assertion. No doubt he has replaced blown diodes and perceives them to be less robust than a switch. I cannot help but wonder if his problem children were not subject to overheating and or over-voltage due to industrial line transients or local lightning. Whatever the root cause of his observed failures, there is nothing in my experience or that of my colleagues in the aircraft industry that parallels his experience. I'm not suggesting that he is being untruthful; only that we're probably observing an apples/oranges situation. The environments in which our diodes live and the manner in which they are applied in airplanes are sufficiently different from his industrial environment to prevent a useful comparison. So please folks, don't rip out your diodes and put in switches. There are two reasons to support this suggestion: First, we design for failure tolerance. What are the risks if a diode DOES fail? How will the pilot know it? Is it pre-flight detectable? Will the failure cripple the system such that it becomes a hazard? If the answers to any of these questions give you cause for concern about comfortable termination of flight, then redesign the system to eliminate the potential for stress. Consider his statement: "I'll be using manual switches for all critical loads." Our common usage of steering diodes for power is one of TWO power paths to an e-bus. So even if it does fail open, it has backup. If it fails shorted, we can detect this during pre-flight. Second, there is nothing in the service history of diodes (or any other solid state device) to suggest they are recognized problem children waiting for a chance to ruin your day or drive up your cost of ownership. Bob . . . ________________________________________________________________________________
Date: Mar 12, 2008
I have followed the switch vs diode controversy on a number of forums with interest since I am building a Sportsman with a Subaru H6 Engine. I am aware of crash involving a failed diode. I believe the diode was not rated for the actual amp load which was the most likely reason for the diode failure and the ensuing controversy. There is another design recommending the elimination of the diodes and using one switch to supply the fuel pumps, ECU and EFI. This provides a single point of failure which I think violates the design goals of the Z19 drawing of providing redundant paths, components and circuits. Being a committed party ( I have the engine) and wanting the simplest most reliable electrical system possible, I have designed a variation of the Z19 drawing using the same parts count with diodes (rated for the load) than includes a bypass circuit in case of diode failure (unlikely). Please see attached drawing. I welcome all comments and suggestions. Rocky Morrison Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169493#169493 Attachments: http://forums.matronics.com//files/proposed_fuel_pump_eci_efi_circuit_for_eggenfellner_subaru_h6_233.pdf ________________________________________________________________________________
Date: Mar 13, 2008
> > >Thanks Bob, that tells me what I need to know. Wasn't planning on taking >the diode out anyway but it's good to understand the why and why not? My >only regret about my building process is that once I'm done, I won't have >much use for the things I have come to understand from this list. Education >is a good thing but practical use makes it excellent. In my case, I have >learned just enough from this list to recognize what I don't know yet? That >may be the reason I become a repeat builder ;-) Correct . . . presuming that you do not take what you've learned and share it with others. Knowledge and understanding are commodities that grow in value the more they are given away. We all benefit every day from associations with individuals who are willing to share what they've learned. After your airplane is finished, you can satisfy your debt to all the teachers who participated in your success by "paying it forward". See: http://en.wikipedia.org/wiki/Pay_it_forward http://tinyurl.com/32cfym Bob . . . ________________________________________________________________________________
Date: Mar 13, 2008
> >I have followed the switch vs diode controversy on a number of forums with >interest since I am building a Sportsman with a Subaru H6 Engine. I am >aware of crash involving a failed diode. I believe the diode was not >rated for the actual amp load which was the most likely reason for the >diode failure and the ensuing controversy. Due diligence in design cannot be discounted. It could just as easily have been a failure due to an improperly tightened nut. Had it been a fastener failure, is there value in responding to that knowledge by replacing all the fasteners in our machines with grade 8 hardware and metal locknuts? The real issue is to understand what suite of components are available to arrive at at an elegant solution and then properly apply those components to the task. >There is another design recommending the elimination of the diodes and >using one switch to supply the fuel pumps, ECU and EFI. This provides a >single point of failure which I think violates the design goals of the Z19 >drawing of providing redundant paths, components and circuits. Consideration of design goals and failure mode effects are important components of the process . . . >Being a committed party ( I have the engine) and wanting the simplest most >reliable electrical system possible, I have designed a variation of the >Z19 drawing using the same parts count with diodes (rated for the load) >than includes a bypass circuit in case of diode failure (unlikely). It's unfortunate that your lack of confidence leads you to conclude that there is value in "backing up" a diode. On the other hand, it's far better that you fly this airplane free of worry about it. Worries do not enhance your piloting skills and should be assuaged irrespective of the physics and/or probabilities. Bob . . . ________________________________________________________________________________
Subject: Electrical Question
Date: Mar 13, 2008
3/12/2008 Hello Tom, You wrote: 1) "For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch?" We used to say that having helicopter time in your logbook was like having an STD entry (Sexually Transmitted Disease -- it was called venereal disease back then) in your health record. So I will reluctantly admit that I did fly a helicopter (CH-46) for a year in Viet Nam. The cyclic grip had a button on it that when pressed would disconnect the electronic flight stability / attitude positioning system so that one could manually reposition the stick and the helicopter's attitude then releasing the button would reengage the electronic attitude positioning system. Maybe you have a control stick grip that does something similar. 2) "Again, is there any way I can wire it to work with my remote ident operation?" I am not the right guy to answer that question, but I am sure that by using two of the small "ice cube" type relays that ident operation could be accomplished. It might be a pretty awkward way of doing it though from an electrical viewpoint. I'll forward your question to the Matronic's aeroelectric-list and maybe one of the electrical experts there (even the great guru Bob Nuckolls) would take a shot at it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: You can subscribe to this list here -- the daily digest is a great deal. One email inbound each day puts you in contact with the living beating heart of the homebuilder's electrical world. http://www.matronics.com/Navigator/?AeroElectric-List -------------------------------------------------------- ----- Original Message ----- From: "Tom Gibbons" <TomisFlyingby(at)comcast.net> Sent: Wednesday, March 12, 2008 12:25 AM Subject: Electrical question On my military surplus control stick I have 4 push buttons, 2 wired normally opened (NO) and 2 wired normally closed (NC). I really do not have access to these switches so I have to make due but can I use the NC switches somehow? I have plans for comm flip/flop, nav flip/flop, and Ident for my transponder. I actually have a "hattie" switch in the middle for trim which is not hooked up. The stick is installed with the ptt and intercom trigger switches working good. All kinds of switches on this guy. Was not going to use it but hey, it felt so comfortable, why not. For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch? Again, is there any way I can wire it to work with my remote ident operation? Tom Paint this summer??? ________________________________________________________________________________
Date: Mar 13, 2008
Subject: Re: B&C S895-1 as start button for 20A/14VDC ciruit?
> >Hi Bob, > >Hope all is well with you :) > >I have a B&C S895-1 push button originally intended as a start buton; >however, the Eggenfellner recommendation for the starter circuit is for a >switch or push button capable of 20A/14VDC (switch will be connected to >the internal contactor on the Subaru H6 starter solenoid). > >I have been reviewing both your Switch_Rating.pdf and the chapter in the >Connection, and I'm coming to the conclusion that this switch is probably >too light for this application. Would it work? Sure. For how long? Who >knows... But what would be the risk that I could fuse this switch closed >or just plain heat it up too much? Also, the connection leads on this >switch seem a bit small/light for 12AWG wire... > >Please advise when you have a moment. The S895-1 switch would probably give a good service life in this application. See: http://www.aeroelectric.com/articles/Switch_Ratings.pdf the REAL stress on this device will be the arcing that takes place during release -AND- the openings that occur during contact bounce at closure. Make sure there's a diode from contactor (+) to ground. I think B&C is supplying that switch with an MOV already mounted. I recommended that about 10 years ago during my brief love affair with MOVs . . . turns out the diode is a MUCH more effective solution to inductive energy management. I'm wondering if the starter solenoid supplied is the two-stage configuration described in http://www.aeroelectric.com/articles/strtctr.pdf If so, the 20A rating request by Eggenfellner is probably an acknowledgement of the short term energizing inrush unique to this design. The wires supplied on that switch were tailored to the starter contactor supplied in tht B&C starter installation kit. Your application would be better served with 16AWG wire and a 15A fuse. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 13, 2008
Subject: Re: High density D-sub crimper
> >If you crimp connectors without the specific dies, you would >be well served by soldering the wire strands to the crimps as >well or the wires might just fall out! >I have an AMP ProCrimp II with all the dies for the CPC >Series I connectors, and they still sometimes fail the tug test when I >don't oversolder them! Your talking about the open-barrel, sheet metal pins. I just went to the shop and pulled three 24AWG wires from pins installed with my generic open-barrel crimp tool. I got pullout forces that ran from 8 to 11 pounds. If your pulling these off with your fingers you may have the wrong tool or are not closing it hard enough. I put some high density machined pins on with the $low$ d-sub crimp tool and produced crimps that I could not pull off with the fingers. I don't have any of these pins on hand right now but as soon as I can, I'll do a calibrated pull-test and look at the cross sectioned wire grips under the microscope. But I'm betting that we'll find the crimps to be satisfactory on the HD pins too. Bob . . . ________________________________________________________________________________
Date: Mar 13, 2008
> >Howdy, > >I've got to crimp about 30 machined high density d-sub pins on an ACU >install and I don't think my standard density crimper (B&C) is gonna work. >I'd hate to spend $800 on a Daniels and postitioners for one little deed. >Any ideas? > >I thought about getting a $30 crimper and some of the fold over pins. Are >those pins as reliable as the machined ones? Will the crimper (fold over >style, also B&C) do those little pins in one of it's slots? Your risks for process error are lower with the machined pins. I thick Steinair can sell you some. I also believe the 20AWG crimper from B&C will properly install the 22AWG pins. I'll see if I can get a considered confirmation in the next few days. I have come connectors on order with my favorite local connector guy but he's a 15 mile drive from here. When my order comes in, I'll pick up some 22AWG HD pins for the experiment. Bob . . . ________________________________________________________________________________
Date: Mar 13, 2008
Bob, I appreciate your comments, thoughts and efforts in helping all the builders develop more reliable and better electrical systems. A worrier I am not, but a simple change to the design that provides backup to a potential component failure makes logical sense to me. I plan on flying in remote places and reliability is high on my list of design goals. That is why I am here to learn and listen, ask questions and share if I think something is worthy of the groups time. Keep up the great work. Your work has been invaluable to me in the building process. Bob, Thanks!! Rocky Morrison Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169589#169589 ________________________________________________________________________________
Date: Mar 13, 2008
Bob, Thanks for the background and scope of the diode. That said and given the intended reliability of the diode, I would hope my e-bus capacity remains below 20A in my Z19 setup. Assuming the use of the B & C cooled diode setup, should I fear any continuous load up to the 25A suggested rating? Thanks too for the tips on switching. I can see a few 2-10's in my future for saving valuable panel space. Some great examples through 8-9x in your book. Glenn -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Schlatterer Sent: Wednesday, March 12, 2008 11:57 PM Subject: RE: AeroElectric-List: Diodes versus switches 101 ? --> Thanks Bob, that tells me what I need to know. Wasn't planning on taking the diode out anyway but it's good to understand the why and why not? My only regret about my building process is that once I'm done, I won't have much use for the things I have come to understand from this list. Education is a good thing but practical use makes it excellent. In my case, I have learned just enough from this list to recognize what I don't know yet? That may be the reason I become a repeat builder ;-) Thanks Bill S -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, March 12, 2008 9:41 PM Subject: Re: AeroElectric-List: Diodes versus switches 101 ? --> There was some discussion about Z19 using diodes in a critical ECU circuit and the question arose as to what kind of failure modes apply to diodes and their reliability as compared to switches. I think the trust of that thread (sub list) and post below is that diodes might be "automatic" but switches are safer and less likely to fail? ( I have no opinion but would like to understand the rationale ) This was posted and I was just wondering what the thought might be on the AE list since most of Bobs diagrams "suggest" a diode in the E-Bus circuit as opposed to a switch. That might not be AS critical as the ECU/EFI circuit on an all electric engine but the same concerns still apply? Posted to the Sub list: "After 30 years in the industrial electrical construction and maintenance field I can say without equivocation that a robust switch is much less likely to fail than a robust diode. The science of the switch is much simpler - use a lot of good conducting material that is not likely to corrode and support it with stout mechanical parts that hold tightly. Now, by contrast, the science of the diode starts with getting good silicon material and contaminating it in just the right proportion with just the right material at just the right temperature for just the right time. THEN you can start on building the junctions onto some sort of heat dissipating holder. I have replaced dozens of solid state devices that failed (always failed open) Interesting! Most solid state failures I've observed were shorted devices (overheated and or voltage spiked). The devices that did go OPEN were transistors that shorted first and then opened their emitter bond-wires due to over current. . . . and I never found the root cause of failure. I put in an exact replacement and the circuit worked just fine for years. The trade off you get for the "automatic" switching of a diode vs. the manual switch is in the area of RELIABILITY. I'll be using manual switches for all critical loads." Not wanting to stir anything up, just want to understand the thinking and factual matter in the post above? About 1980 I was designing a new solid state speed controller and runaway monitor system for the Lear 55 and ultimately the entire fleet of 30 series aircraft. It was the first time I was tasked with doing a formal failure mode effects analysis and mean-time-between-failures (MTBF) study on a new product. I dug out Mil-HDK-217 and began slogging through the part-by-part service life prediction algorithms. By the time some 200+ items of solder joints, transistors, resistors, capacitors, etc were all accounted for, I was pleased to turn the crank and a really nice MTBF number on the order of 10,000 hours fell out. But wait, there was this really expensive, mil-spec, hermetically sealed 25A power relay used as a last-ditch backup disconnect. After factoring this device into the grand scheme of things, my shinning MTBF number fell to something on the order of 900 hours! Several times over the last 25 years I've asked the guys at Electromech's field service shop how the Lear trim controllers are holding up. The failure items they have to report were surprising. MOST of the field failures were in mass-terminated ribbon cable connectors followed by loss of ground through the mounting hardware that held the two boards together. Seems this was before I learned about having solid, on-purpose wiring grounds and NOT to depend on mountings that loosen and/or corrode. Electronically, most failures were the usual gang of jelly bean components, solder joints, etc. Most failures were in the monitor boards that had 3x the parts count of a controller board. There were NO failures of the controller that caused a runaway and a tiny fraction of the failures incapacitated the system. There had been no failures for that piece-o-#@@$, high-dollar relay that crashed my MTBF study. Bottom line: Was this relay badly misjudged? No, I had a pretty good understanding of contact physics and designed the electronics such that relay contacts were closed before electronics actually caused the motor to run. Similarly, electronics shut the motor down and waited some tens of milliseconds before opening the relay. Hence, the relay was never required to actually switch any power. No current was flowing when the relay contacts opened or closed and current was not allowed to flow until contacts stopped bouncing on closure. This is why Lear bought my design with the somewhat distorted MTBF numbers because in thousands of hours of flight, the relay never really saw any switching service. Nowadays, there are more accurate considerations of how a part is used that will provide a more realistic prediction of failure rates. Does this mean that the very robust, mil-spec relay is the golden child of the design and the electronics were left holding the bag for all the failures? No, most failures were due to bonding/connection issues. This controller resides in the vertical fin, just under the leading edge of the stabilizer. This has to be the worst environment in the airplane for environmental extremes. For the most part, the electronics seem to be living up to predictions for a long and quite satisfactory service life in thousands of hours. My personal experience since supports an assertion that the silicon rectifier diode has an expected service life that will far outpace any electro-mechanical device (relay or switch) that is tasked with controlling current flow. Some of my most vexing field failures problems to solve involve relays or switches. I've never had to chase down root cause for failures of energy steering diodes in an airplane. Now, let us consider the gentleman's contrary assertion. No doubt he has replaced blown diodes and perceives them to be less robust than a switch. I cannot help but wonder if his problem children were not subject to overheating and or over-voltage due to industrial line transients or local lightning. Whatever the root cause of his observed failures, there is nothing in my experience or that of my colleagues in the aircraft industry that parallels his experience. I'm not suggesting that he is being untruthful; only that we're probably observing an apples/oranges situation. The environments in which our diodes live and the manner in which they are applied in airplanes are sufficiently different from his industrial environment to prevent a useful comparison. So please folks, don't rip out your diodes and put in switches. There are two reasons to support this suggestion: First, we design for failure tolerance. What are the risks if a diode DOES fail? How will the pilot know it? Is it pre-flight detectable? Will the failure cripple the system such that it becomes a hazard? If the answers to any of these questions give you cause for concern about comfortable termination of flight, then redesign the system to eliminate the potential for stress. Consider his statement: "I'll be using manual switches for all critical loads." Our common usage of steering diodes for power is one of TWO power paths to an e-bus. So even if it does fail open, it has backup. If it fails shorted, we can detect this during pre-flight. Second, there is nothing in the service history of diodes (or any other solid state device) to suggest they are recognized problem children waiting for a chance to ruin your day or drive up your cost of ownership. Bob . . . ________________________________________________________________________________
Date: Mar 13, 2008
Hi Bob, I was responding to Ed's comment that he might get some stamped pins. I still think soldering crimped open barrels is the way to go. The reason is that to meet specs on the pull test you must have a connector pin specific to both the wire size and insulation along with accompanying crimp dies. Since available wire may have unpredictable insulation thickness in a homebuilder's shop, soldering is just extra assurance. -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=169619#169619 ________________________________________________________________________________
Date: Mar 13, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> >Bob, >Thanks for the background and scope of the diode. That said and given >the intended reliability of the diode, I would hope my e-bus capacity >remains below 20A in my Z19 setup. Assuming the use of the B & C cooled >diode setup, should I fear any continuous load up to the 25A suggested >rating? > >Thanks too for the tips on switching. I can see a few 2-10's in my >future for saving valuable panel space. Some great examples through 8-9x >in your book. You're welcome. I would hope your endurance bus is below 20A too. I get about 2 or 3 drawings a month from builders who are asking for a review of their particular implementation of a Z-figure. The majority of these drawings have too much stuff on the e-bus. A review of the endurance bus philosophy might be useful here. If one is flying one alternator and one battery, the e-bus is intended to offer a minimum power load on a battery of known capacity for the purpose of NOT turning an alternator failure into an emergency. How much 'stuff' is necessary to stay on-course for say 1 to 2 hours with the airplane configured for en route phase of flight? This list boils down to one nav receiver, transponder, minimal panel lighting, etc. The nicely crafted e-bus for a one-alternator airplane should be reduced to 4A or less total load. Now, other things can drive from the e-bus but should be capable of being switched off during alternator out operations. If you have an auxiliary 8A alternator then the e-bus loads can be elevated to 8A total. Likewise, a 20A aux alternator would support a 20A e-bus . . . and perhaps there's little if any value in even having an e-bus. The 25A diode bridge recommended since day-one for the e-bus normal feedpath diode was selected for its MECHANICAL convenience of mounting and making connections via fast-on terminals. In no way was it intended to imply that e-bus loads could total up to that value. Anything over 10A should prompt a review of the diode installation for the purpose of deducing thermal adequacy of the mounting in carrying away heat. Most of my fused feeders to the e-bus in the Z-figures are protected at 7A. If you have an SD-8 second alternator, perhaps that fuse should go up to 10A. But if your suite of proposed equipment combined with an evaluation of how you plan to fly causes you to pile everything but the kitchen sink on the e-bus, then we need to talk. If your e-bus loads are more than 10x the battery contactor load then the advantages of shedding the contactor as a battery only load are diminished considerably. If most of the stuff you really need to run exceeds 8A then you need an SD20 aux alternator and Figure Z-12 is probably your minimum parts count approach to managing alternator out conditions. Z-12 cannot fully exploit the design goals for an e-bus so it would not be unreasonable to eliminate it entirely and run the whole airplane from the main bus with the SD-20 backing up the main alternator. That takes care of the worries about diodes and e-bus switches and makes the airplane simpler to operate. Bob . . . ________________________________________________________________________________
Date: Mar 13, 2008
snip > A review of the endurance bus philosophy might be useful here. > If one is flying one alternator and one battery, the e-bus is > intended to offer a minimum power load on a battery of known > capacity for the purpose of NOT turning an alternator failure > into an emergency. How much 'stuff' is necessary to stay on-course > for say 1 to 2 hours with the airplane configured for en route > phase of flight? > > This list boils down to one nav receiver, transponder, minimal > panel lighting, etc. The nicely crafted e-bus for a one-alternator Plus any devices required to remain upright (in an all-electric airplane) - aviate, then navigate? An EFIS (or an electric attitude indicator). > > Bob . . . > Regards, Matt- ________________________________________________________________________________
Date: Mar 13, 2008
Subject: Re: AeroElectric-List Digest: 13 Msgs - 03/12/08
Does anyone know where I can download the installation manuals for the Garmin GNC300, SL-30, and a PS Engineering PMA6000MC? Thanks for the help! Lee... ________________________________________________________________________________
Date: Mar 13, 2008
Thanks Bob, I'm interested in how the experiment comes out. Ed Holyoke Robert L. Nuckolls, III wrote: > > > >> >> >> Howdy, >> >> I've got to crimp about 30 machined high density d-sub pins on an ACU >> install and I don't think my standard density crimper (B&C) is gonna >> work. I'd hate to spend $800 on a Daniels and postitioners for one >> little deed. Any ideas? >> >> I thought about getting a $30 crimper and some of the fold over pins. >> Are those pins as reliable as the machined ones? Will the crimper >> (fold over style, also B&C) do those little pins in one of it's slots? > > Your risks for process error are lower with the machined > pins. I thick Steinair can sell you some. I also believe > the 20AWG crimper from B&C will properly install the > 22AWG pins. I'll see if I can get a considered confirmation > in the next few days. I have come connectors on order with > my favorite local connector guy but he's a 15 mile drive from > here. When my order comes in, I'll pick up some 22AWG HD > pins for the experiment. > > Bob . . . > > ________________________________________________________________________________
From: "Andrew Butler" <andrewbutler(at)ireland.com>
Date: Mar 14, 2008
Subject: Keyed Master Switch?
All, I plan on a PUSH Button Start and Dual Electonic Ignition. Can anyone help with a method of enabling "key start" access to ignition/power? I have dual paths to each ignition, so need four switches (to enable pre-flight checks of each path), so the documented adapted mag key start switch option won't work. I can't get fully comfortable with a fully live system being just a flip of a switch away....... See attached to get the idea. Best regards, Andrew Butler RV 71700 - West of Ireland. Fueslage (right way up!) ________________________________________________________________________________
Date: Mar 14, 2008
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
Consider putting a keyed switch in the Push Button Start circuit. If the key isn't on, the start button doesn't work! One switch does the trick and it doesn't put another switch (point of failure) in any of your other critical circuits. Your ignition systems may be live if their switches are flipped, but nothing happens without the starter. Dennis Glaeser RV7A - Subaru H6 - DAR inspection next week! ----------------------------------------- I plan on a PUSH Button Start and Dual Electonic Ignition. Can anyone help with a method of enabling "key start" access to ignition/power? I have dual paths to each ignition, so need four switches (to enable pre-flight checks of each path), so the documented adapted mag key start switch option won't work. I can't get fully comfortable with a fully live system being just a flip of a switch away....... See attached to get the idea. Best regards, Andrew Butler RV 71700 - West of Ireland. Fueslage (right way up!) ________________________________________________________________________________
Subject: ANL 50 Failure
Date: Mar 14, 2008
Here is a picture of a current limiter from a recent job. It had been replaced for unknown reasons over a year ago. The installer didn't use a washer between the limiter terminal tab and the nut. The nut grabbed and torqued the tab, deformed the ears that are supported by the rivets, and partially tore the base of the filiment (right word?) After many months the filiment finally broke. I don't think it was experienceing any particularly high current load, but from the looks of the mounting terminal, it did see some pretty rough handling. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
From: "CHARLES T BECKER" <ctbecker(at)atlanticbb.net>
Subject: Re: Keyed Master Switch?
Date: Mar 14, 2008
Dennis has the right idea, especially in light of all the emphasis on '2 locks'. My 8A will have a key switch between the battery and the starter switch. The actual starter switch will be on the stick, controlling a relay in the starter circuit. Charlie Becker N464CB(r) 8A(e) Finishing "Glaeser, Dennis A" wrote: >Dennis A" > > Consider putting a keyed switch in the Push Button Start >circuit. If > the key isn't on, the start button doesn't work! One >switch does the > trick and it doesn't put another switch (point of >failure) in any of > your other critical circuits. > Your ignition systems may be live if their switches are >flipped, but > nothing happens without the starter. > > Dennis Glaeser > RV7A - Subaru H6 - DAR inspection next week! > > ----------------------------------------- > I plan on a PUSH Button Start and Dual Electonic >Ignition. Can anyone > help with a method of enabling "key start" access to >ignition/power? > > I have dual paths to each ignition, so need four >switches (to enable > pre-flight checks of each path), so the documented >adapted mag key start > switch option won't work. > > I can't get fully comfortable with a fully live system >being just a flip > of a switch away....... See attached to get the idea. > > Best regards, > > Andrew Butler > RV 71700 - West of Ireland. >Fueslage (right way up!) > > > >Un/Subscription, >http://www.matronics.com/Navigator?AeroElectric-List >Forums! >Admin. > > > ________________________________________________________________________________
Date: Mar 14, 2008
My plan has been to put a simple toggle switch in the baggage compartment that disconnects the starter switch. Hopefully this plus a canopy lock will meet the 2 lock requirement. The baggage compartment will also have a lock. I wonder how many times I will get all strapped in before I realize I haven't enabled the starter switch. Terry RV-8A wiring -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CHARLES T BECKER Sent: Friday, March 14, 2008 12:09 PM Subject: Re: AeroElectric-List: Keyed Master Switch? Dennis has the right idea, especially in light of all the emphasis on '2 locks'. My 8A will have a key switch between the battery and the starter switch. The actual starter switch will be on the stick, controlling a relay in the starter circuit. Charlie Becker N464CB(r) 8A(e) Finishing "Glaeser, Dennis A" wrote: >Dennis A" > > Consider putting a keyed switch in the Push Button Start >circuit. If > the key isn't on, the start button doesn't work! One >switch does the > trick and it doesn't put another switch (point of >failure) in any of > your other critical circuits. > Your ignition systems may be live if their switches are >flipped, but > nothing happens without the starter. > > Dennis Glaeser > RV7A - Subaru H6 - DAR inspection next week! > > ----------------------------------------- > I plan on a PUSH Button Start and Dual Electonic >Ignition. Can anyone > help with a method of enabling "key start" access to >ignition/power? > > I have dual paths to each ignition, so need four >switches (to enable > pre-flight checks of each path), so the documented >adapted mag key start > switch option won't work. > > I can't get fully comfortable with a fully live system >being just a flip > of a switch away....... See attached to get the idea. > > Best regards, > > Andrew Butler > RV 71700 - West of Ireland. >Fueslage (right way up!) > > > >Un/Subscription, >http://www.matronics.com/Navigator?AeroElectric-List >Forums! >Admin. > > > ________________________________________________________________________________
Date: Mar 14, 2008
Do you plan to put a guard on the switch (or cover) to keep loose items in the baggage compartment from bumping it? I suppose that in flight you probably won't have to engage the starter ever should that happen. If you fly the plane long enough without a guard on that switch, you'll eventually be in a situation where you can't figure out why you can't engage the starter - after giving somebody a ride maybe, or trying to restart after a fuel stop.. Will the switch be in a place where it interferes with loading things into the baggage compartment? Will you have to unload anything form the compartment in order to gain access to the switch? Matt- > > > My plan has been to put a simple toggle switch in the baggage compartment > that disconnects the starter switch. Hopefully this plus a canopy lock > will > meet the 2 lock requirement. The baggage compartment will also have a > lock. > I wonder how many times I will get all strapped in before I realize I > haven't enabled the starter switch. > > Terry > RV-8A wiring > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CHARLES > T > BECKER > Sent: Friday, March 14, 2008 12:09 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Keyed Master Switch? > > > > Dennis has the right idea, especially in light of all the > emphasis on '2 locks'. My 8A will have a key switch > between the battery and the starter switch. The actual > starter switch will be on the stick, controlling a relay > in the starter circuit. > > Charlie Becker > N464CB(r) 8A(e) > Finishing > > > "Glaeser, Dennis A" wrote: >>Dennis A" >> >> Consider putting a keyed switch in the Push Button Start >>circuit. If >> the key isn't on, the start button doesn't work! One >>switch does the >> trick and it doesn't put another switch (point of >>failure) in any of >> your other critical circuits. >> Your ignition systems may be live if their switches are >>flipped, but >> nothing happens without the starter. >> >> Dennis Glaeser >> RV7A - Subaru H6 - DAR inspection next week! >> >> ----------------------------------------- >> I plan on a PUSH Button Start and Dual Electonic >>Ignition. Can anyone >> help with a method of enabling "key start" access to >>ignition/power? >> >> I have dual paths to each ignition, so need four >>switches (to enable >> pre-flight checks of each path), so the documented >>adapted mag key start >> switch option won't work. >> >> I can't get fully comfortable with a fully live system >>being just a flip >> of a switch away....... See attached to get the idea. >> >> Best regards, >> >> Andrew Butler >> RV 71700 - West of Ireland. >>Fueslage (right way up!) >> >> >> >>Un/Subscription, >>http://www.matronics.com/Navigator?AeroElectric-List >>Forums! >>Admin. >> >> >> > > ________________________________________________________________________________
Date: Mar 14, 2008
Those are all good considerations, but having it on the starter circuit rather than ignition makes them a little less critical. The switch guard is probably pretty important. I would not expect to always use the switch to disconnect the starter when leaving the airplane, but more for away from home, overnight -- just one more safeguard, and of course one more point of possible failure. I am willing to be convinced that it is not a good idea. Terry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Matt Prather Sent: Friday, March 14, 2008 2:40 PM Subject: RE: AeroElectric-List: Keyed Master Switch? Do you plan to put a guard on the switch (or cover) to keep loose items in the baggage compartment from bumping it? I suppose that in flight you probably won't have to engage the starter ever should that happen. If you fly the plane long enough without a guard on that switch, you'll eventually be in a situation where you can't figure out why you can't engage the starter - after giving somebody a ride maybe, or trying to restart after a fuel stop.. Will the switch be in a place where it interferes with loading things into the baggage compartment? Will you have to unload anything form the compartment in order to gain access to the switch? Matt- > > > My plan has been to put a simple toggle switch in the baggage compartment > that disconnects the starter switch. Hopefully this plus a canopy lock > will > meet the 2 lock requirement. The baggage compartment will also have a > lock. > I wonder how many times I will get all strapped in before I realize I > haven't enabled the starter switch. > > Terry > RV-8A wiring > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of CHARLES > T > BECKER > Sent: Friday, March 14, 2008 12:09 PM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Keyed Master Switch? > > > > Dennis has the right idea, especially in light of all the > emphasis on '2 locks'. My 8A will have a key switch > between the battery and the starter switch. The actual > starter switch will be on the stick, controlling a relay > in the starter circuit. > > Charlie Becker > N464CB(r) 8A(e) > Finishing > > > "Glaeser, Dennis A" wrote: >>Dennis A" >> >> Consider putting a keyed switch in the Push Button Start >>circuit. If >> the key isn't on, the start button doesn't work! One >>switch does the >> trick and it doesn't put another switch (point of >>failure) in any of >> your other critical circuits. >> Your ignition systems may be live if their switches are >>flipped, but >> nothing happens without the starter. >> >> Dennis Glaeser >> RV7A - Subaru H6 - DAR inspection next week! >> >> ----------------------------------------- >> I plan on a PUSH Button Start and Dual Electonic >>Ignition. Can anyone >> help with a method of enabling "key start" access to >>ignition/power? >> >> I have dual paths to each ignition, so need four >>switches (to enable >> pre-flight checks of each path), so the documented >>adapted mag key start >> switch option won't work. >> >> I can't get fully comfortable with a fully live system >>being just a flip >> of a switch away....... See attached to get the idea. >> >> Best regards, >> >> Andrew Butler >> RV 71700 - West of Ireland. >>Fueslage (right way up!) >> >> >> >>Un/Subscription, >>http://www.matronics.com/Navigator?AeroElectric-List >>Forums! >>Admin. >> >> >> > > ________________________________________________________________________________
Subject: Re: ANL 50 Failure
Date: Mar 14, 2008
Thank you Dave for sharing that critical information. I will be very careful when installing the 3 ANLs in my RV-7, project. Bill Schoen N727BN res South Fork, Co. ----- Original Message ----- From: Dave Saylor<mailto:Dave(at)AirCraftersLLC.com> To: aeroelectric-list(at)matronics.com Sent: Friday, March 14, 2008 12:49 PM Subject: AeroElectric-List: ANL 50 Failure Here is a picture of a current limiter from a recent job. It had been replaced for unknown reasons over a year ago. The installer didn't use a washer between the limiter terminal tab and the nut. The nut grabbed and torqued the tab, deformed the ears that are supported by the rivets, and partially tore the base of the filiment (right word?) After many months the filiment finally broke. I don't think it was experienceing any particularly high current load, but from the looks of the mounting terminal, it did see some pretty rough handling. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com ________________________________________________________________________________
From: "Dennis & Anne Glaeser" <glaesers(at)wideopenwest.com>
Subject: RE: Keyed Master Switch?
Date: Mar 14, 2008
Why not a key switch in a more convenient (in the cockpit somewhere) location? It doesn't have to be on the panel, maybe tucked away somewhere, but reasonably easy to access. Then no post strap-in remorse, and if you use the baggage compartment much at all, I predict you'll be removing or relocating that switch before long. If you are in a locked hangar, you probably won't use it unless you're away from home. Believe me, you're convenience and ease of use is most important. Dennis --------------------------------------------------------------------------- My plan has been to put a simple toggle switch in the baggage compartment that disconnects the starter switch. Hopefully this plus a canopy lock will meet the 2 lock requirement. The baggage compartment will also have a lock. I wonder how many times I will get all strapped in before I realize I haven't enabled the starter switch. Terry RV-8A wiring ________________________________________________________________________________
Date: Mar 15, 2008
Hi Charlie, What type of switch are you using and where did you source it? Cheers, Andrew. ----- Original Message ----- From: "CHARLES T BECKER" To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: Keyed Master Switch? Date: Fri, 14 Mar 2008 15:09:25 -0400 Dennis has the right idea, especially in light of all the emphasis on '2 locks'. My 8A will have a key switch between the battery and the starter switch. The actual starter switch will be on the stick, controlling a relay in the starter circuit. Charlie Becker N464CB(r) 8A(e) Finishing "Glaeser, Dennis A" wrote: > > Consider putting a keyed switch in the Push Button Start circuit. If > the key isn't on, the start button doesn't work! One switch does the > trick and it doesn't put another switch (point of failure) in any of > your other critical circuits. > Your ignition systems may be live if their switches are flipped, but > nothing happens without the starter. > > Dennis Glaeser > RV7A - Subaru H6 - DAR inspection next week! > > ----------------------------------------- > I plan on a PUSH Button Start and Dual Electonic Ignition. Can anyone > help with a method of enabling "key start" access to ignition/power? > > I have dual paths to each ignition, so need four switches (to enable > pre-flight checks of each path), so the documented adapted mag key start > switch option won't work. > > I can't get fully comfortable with a fully live system being just a flip > of a switch away....... See attached to get the idea. > > Best regards, > > Andrew Butler > RV 71700 - West of Ireland. > Fueslage (right way up!) > > > > Un/Subscription, > http://www.matronics.com/Navigator?AeroElectric-List > Forums! > Admin. > > > =========== =========== =========== =========== ________________________________________________________________________________
Date: Mar 15, 2008
Why not just use a standard keyed starter switch? Get rid of all the other push button/toggle switches in the circuit. Power your electrical system thru a standard toggle if you like and just use the starter side of the keyed switch in the starter circuit. Regards, Mark ________________________________________________________________________________
Date: Mar 15, 2008
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Subject: Keyed Master Switch?Keyed Master Switch?
Terry, I would put, on the instrument panel, a simple key switch, (on-off) no other contacts, between the 12V supply and the start button. This has several advantages, convenience, ease of use, and due to the convenience and ease of use it will get used regularly to help protect your aircraft from theft. These switches are available from electronic supply houses, cheap. Roger ________________________________________________________________________________
Date: Mar 15, 2008
Automotive and farm suppliers sell good key switches for around $12 and marine suppliers (at about twice the price) as well. Typically rated for a 25 amp starter solenoid load. I use one for the battery master and the spring loaded position cranks the engine. I like the fact that with the key in my pocket nobody can crank the engine accidentally, and that from cars we subconsciously associate keys with cranking. Also I think there is very little chance of the circuit staying energized after cranking since my fingers can force it back from the crank position even if the spring fails or the contacts try to weld. Of course my starter solenoid can still physically stick, but not the switch I hope. Ken Mark Sletten wrote: > > Why not just use a standard keyed starter switch? Get rid of all the other > push button/toggle switches in the circuit. Power your electrical system > thru a standard toggle if you like and just use the starter side of the > keyed switch in the starter circuit. > > Regards, > > Mark ________________________________________________________________________________
Date: Mar 15, 2008
Think of it this way: I prefer combination locks to keyed locks because the latter requires that I have the proper physical key with me while a combination lock requires only that I know how to open it. What I am proposing amounts to a combination lock on the ignition: you just have to know where the switches are. Locking the baggage compartment where the disconnect switch is located is that additional security feature that we are now required to have. When I was in college I bought a sad looking '50 Chevy sedan for $60. It turned out to be a great car until I ran it low on oil and threw a rod, but one of the great features was the ignition switch. Key use was optional. You could turn it to the left with the key in it and remove the key and it was locked, or you could just remove the key without turning it to the left and it was still an ignition switch but didn't require a key. Yes, canopy and baggage compartments will still require a key. My current Mazda MX-5 only requires that I have the key in my pocket and it "recognizes" me and allows me to open the doors or trunk and start the engine. But that's way more complex than I want to go with my airplane. Terry -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mark Sletten Sent: Saturday, March 15, 2008 6:47 AM Subject: AeroElectric-List: Re: Keyed Master Switch? Why not just use a standard keyed starter switch? Get rid of all the other push button/toggle switches in the circuit. Power your electrical system thru a standard toggle if you like and just use the starter side of the keyed switch in the starter circuit. Regards, Mark ________________________________________________________________________________
Date: Mar 15, 2008
I like the idea of a shorting plug that will short the mag p leads to ground. Insert the plug to disable the airplane. Remove the plug to fly. You really are not adding anything to fail in flight. I will only be using it when away from my home field. Simple, cheap and relatively free from unintended consequences (I think). Steve Eberhart RV-7A, Wiring up everything so I can finally fly this thing. Andrew Butler wrote: > All, > > I plan on a PUSH Button Start and Dual Electonic Ignition. Can anyone > help with a method of enabling "key start" access to ignition/power? > > I have dual paths to each ignition, so need four switches (to enable > pre-flight checks of each path), so the documented adapted mag key > start switch option won't work. > > I can't get fully comfortable with a fully live system being just a > flip of a switch away....... See attached to get the idea. ________________________________________________________________________________
Subject: Ground Start enunciator light
Date: Mar 16, 2008
Listers I installed a Piper-type male socket to my airplane, to have the possibility of a ground start in case of a low battery cranking difficulty. As recommended by this List experts, I connected the socket to the battery through a continuous duty contactor (aka Master Relay or Battery solenoid), the S701-1 from B&C, controlled by a SPST switch, which grounds the contactor when thrown to ON. Now what I want to do is to put a green enunciator light in my panel, which illuminates when that switch is ON and the contactor is closed to allow the ground start procedure, to remind me to switch it Off after finishing that procedure. I have tried some wiring of the warning light to the switch, but I cannot make it work properly. Can somebody please enlighten me how to wire it? TIA Carlos ________________________________________________________________________________
Date: Mar 15, 2008
Subject: Re: Ground Start enunciator light
I assume you want this to be on whenever the ground switch (relay) is ON, whether external power is connected or not. If so, use a DPDT switch for the relay instead of an SPST, and use the extra pair of contacts to switch the light to run from your main battery bus. Ron On 3/15/08, Carlos Trigo wrote: > > trigo(at)mail.telepac.pt> > > Listers > > I installed a Piper-type male socket to my airplane, to have the > possibility > of a ground start in case of a low battery cranking difficulty. > As recommended by this List experts, I connected the socket to the battery > through a continuous duty contactor (aka Master Relay or Battery > solenoid), > the S701-1 from B&C, controlled by a SPST switch, which grounds the > contactor when thrown to ON. > > Now what I want to do is to put a green enunciator light in my panel, > which > illuminates when that switch is ON and the contactor is closed to allow > the > ground start procedure, to remind me to switch it Off after finishing that > procedure. > > I have tried some wiring of the warning light to the switch, but I cannot > make it work properly. Can somebody please enlighten me how to wire it? > > TIA > Carlos > > ________________________________________________________________________________
Date: Mar 15, 2008
>Here is a picture of a current limiter from a recent job. It had been >replaced for unknown reasons over a year ago. The installer didn't use a >washer between the limiter terminal tab and the nut. The nut grabbed and >torqued the tab, deformed the ears that are supported by the rivets, and >partially tore the base of the filiment (right word?). Looks like it was probably stress cracked, there's no evidence of a melt-open event. > After many months the filiment finally broke. I don't think it was > experienceing any particularly high current load, but from the looks of > the mounting terminal, it did see some pretty rough handling. Thanks for sharing this with us. This is an excellent reminder of the need to think about where reaction torques are going when we cinch things down tight. Another at-risk-joint is on the fat-wire main terminals of these contactors: http://www.aeroelectric.com/Pictures/Contactors/s701-2.jpg It's a good idea to put a wrench on the nut adjacent to the case and put some counter-acting torque while tightening the nut that holds wires. Take a look at: http://www.aeroelectric.com/Pictures/Fuses/Fuse_Holders/ANN-ANL_Base.jpg If you look real closely under the washers, you'll see the bottom nut in the stack for each terminal. The things that should on top of the first nut are terminals on ends of wires and/or straps. Next is the second, thin,-jam nut, preferably brass torqued to 80% of ultimate for brass. The ANL limiter goes next followed by the washer and finally, the third locking nut shown. This order of assembly allows replacing of the ANL without opening the joints for conductors. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 15, 2008
> > >Listers > >I installed a Piper-type male socket to my airplane, to have the possibility >of a ground start in case of a low battery cranking difficulty. >As recommended by this List experts, I connected the socket to the battery >through a continuous duty contactor (aka Master Relay or Battery solenoid), >the S701-1 from B&C, controlled by a SPST switch, which grounds the >contactor when thrown to ON. > >Now what I want to do is to put a green enunciator light in my panel, which >illuminates when that switch is ON and the contactor is closed to allow the >ground start procedure, to remind me to switch it Off after finishing that >procedure. > >I have tried some wiring of the warning light to the switch, but I cannot >make it work properly. Can somebody please enlighten me how to wire it? The schematic is shown at: http://www.aeroelectric.com/articles/grndpwr.pdf Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
From: "Richard T. Schaefer" <Schaefer@rts-services.com>
Date: Mar 15, 2008
You might also want to power the relay from the external power with a diode to verify that the external power is of the right polarity. r.t.s. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Saturday, March 15, 2008 8:54 PM Subject: AeroElectric-List: Ground Start enunciator light Listers I installed a Piper-type male socket to my airplane, to have the possibility of a ground start in case of a low battery cranking difficulty. As recommended by this List experts, I connected the socket to the battery through a continuous duty contactor (aka Master Relay or Battery solenoid), the S701-1 from B&C, controlled by a SPST switch, which grounds the contactor when thrown to ON. Now what I want to do is to put a green enunciator light in my panel, which illuminates when that switch is ON and the contactor is closed to allow the ground start procedure, to remind me to switch it Off after finishing that procedure. I have tried some wiring of the warning light to the switch, but I cannot make it work properly. Can somebody please enlighten me how to wire it? TIA Carlos ________________________________________________________________________________
Date: Mar 16, 2008
Bob Thanks for pointing me to this schematic. I have 2 questions about this schematic: - shouldn't the "Ground Power" contactor p/n be S701-1 instead of S702-1? - regarding the lamp, if I want to put a simple 2 terminal lamp, instead of a ptt lamp, is the wiring the same? Carlos > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III > Sent: domingo, 16 de Mar=E7o de 2008 3:08 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Ground Start enunciator light > > > > > > > > > >Listers > > > >I installed a Piper-type male socket to my airplane, to have the possibility > >of a ground start in case of a low battery cranking difficulty. > >As recommended by this List experts, I connected the socket to the battery > >through a continuous duty contactor (aka Master Relay or Battery solenoid), > >the S701-1 from B&C, controlled by a SPST switch, which grounds the > >contactor when thrown to ON. > > > >Now what I want to do is to put a green enunciator light in my panel, which > >illuminates when that switch is ON and the contactor is closed to allow the > >ground start procedure, to remind me to switch it Off after finishing that > >procedure. > > > >I have tried some wiring of the warning light to the switch, but I cannot > >make it work properly. Can somebody please enlighten me how to wire it? > > The schematic is shown at: > > http://www.aeroelectric.com/articles/grndpwr.pdf > > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > > > > ________________________________________________________________________________
Date: Mar 16, 2008
3/12/2008 Hello Tom, You wrote: 1) "For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch?" We used to say that having helicopter time in your pilot's logbook was like having an STD entry (it was called venereal disease back then) in your health record. So I will reluctantly admit that I did fly a helicopter (CH-46) for a year in Viet Nam. The cyclic grip had a button on it that when pressed would disconnect the electronic flight stability / attitude positioning system so that one could manually reposition the stick and the helicopter's attitude then releasing the button would reengage the electronic attitude positioning system. Maybe you have a control stick grip that does something similar. 2) "Again, is there any way I can wire it to work with my remote ident operation?" I am not the right guy to answer that question, but I am sure that by using two of the small "ice cube" type relays that ident operation could be accomplished. It might be a pretty awkward way of doing it though from an electrical viewpoint. I'll forward your question to the Matronic's aeroelectric-list and maybe one of the electrical experts there (even the great guru Bob Nuckolls) would take a shot at it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." -------------------------------------------------------- ----- Original Message ----- From: "Tom Gibbons" <TomisFlyingby(at)comcast.net> Sent: Wednesday, March 12, 2008 12:25 AM Subject: Electrical question On my military surplus control stick I have 4 push buttons, 2 wired normally opened (NO) and 2 wired normally closed (NC). I really do not have access to these switches so I have to make due but can I use the NC switches somehow? I have plans for comm flip/flop, nav flip/flop, and Ident for my transponder. I actually have a "hattie" switch in the middle for trim which is not hooked up. The stick is installed with the ptt and intercom trigger switches working good. All kinds of switches on this guy. Was not going to use it but hey, it felt so comfortable, why not. For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch? Again, is there any way I can wire it to work with my remote ident operation? Tom ________________________________________________________________________________
Subject: Van's Ammeter Question
Date: Mar 16, 2008
Anyone know why Van's Ammeter gauge requires a +12V source (independent of lighting)? My hangar neighbor is building a -7 and noticed that when he keys his ICOM his ammeter goes to 20-30 Amps on some frequencies but only 2-3 Amps on others. Externally, the ammeter looks like a standard analog mechanical gauge using an external shunt and with no technical docs provided by Vans. My buddy also has RFI on his trim servo indicator (apparently quite common) and on his Van's Manifold Pressure gauge. Shielded cable apparently does the trick for the servo, but I'd like to understand the Ammeter a bit better before throwing bypass caps and ferrites at it. Thanks! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=170155#170155 ________________________________________________________________________________
Date: Mar 16, 2008
Subject: Ground Start enunciator light (Addendum)
> > >Listers > >I installed a Piper-type male socket to my airplane, to have the possibility >of a ground start in case of a low battery cranking difficulty. >As recommended by this List experts, I connected the socket to the battery >through a continuous duty contactor (aka Master Relay or Battery solenoid), >the S701-1 from B&C, controlled by a SPST switch, which grounds the >contactor when thrown to ON. > >Now what I want to do is to put a green enunciator light in my panel, which >illuminates when that switch is ON and the contactor is closed to allow the >ground start procedure, to remind me to switch it Off after finishing that >procedure. > >I have tried some wiring of the warning light to the switch, but I cannot >make it work properly. Can somebody please enlighten me how to wire it? Carlos, A couple of hours after I replied to this it occurred to me that you probably were not incorporating a press-to-test light fixture nor did you mention crowbar ov protection. I've updated the schematics in the article to include "Ground Power Lite" without OV protection and using a plain vanilla lamp fixture. See the last page of: http://www.aeroelectric.com/articles/grndpwr.pdf Is this more like what you needed? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: DPDT high-current contactor needed
Date: Mar 16, 2008
Hi, Listers, I need a manually operated double pole double throw contactor that will carry (not make or break) up to 400 amps. I'm building a 14v system, but my engine requires 24v to spin the starter. My plan is to install 2 batteries. Normal configuration will be parallel for charging and normal running, but switching one battery into a series configuration for starting. Actual starting will be with a starter contactor, so the dpdt contactor won't make or break the starting current. Any thoughts on where I could find such a contactor? Blue skies and tailwinds Jim CH-801 DeltaHawk diesel Augusta GA 90% done, 90% left ________________________________________________________________________________
Date: Mar 16, 2008
From: "nauga(at)brick.net" <dhyde01(at)earthlink.net>
Subject: Audio iso amp ordered, never received
First, to all, Bob Nuckolls included, I apologize for bringing this up here, but I don't see any alternative. Bob, I ordered an audio isolation amp board from you in December and paid using Paypal. You said you were planning on updating the board but would pull one and send it to me. I've sent messages through the message area, e-mails using the address in your responses to my questions before ordering, and a request for info on the Aeroelectric list. I've gotten no response or recognition that you've received any of my attempts at communication. So: Can you let me know what's going on with my order? I wouldn't mind the wait if I knew something was happening at your end but that just hasn't been the case. Please respond here or contact me by e-mail. You have my address. Dave Hyde ________________________________________________________________________________
From: "William Slaughter" <willslau(at)comcast.net>
Date: Mar 16, 2008
On a related note: The instructions for modifying the receptacle call for a propane torch or "large soldering iron". How large an iron? I ask because I incinerated the phenolic insulator when I tried to solder it with my propane torch, and have just ordered a replacement receptacle to try again. If I preheat the bolt in the oven, would a Weller 100/140 soldering gun have enough oomph? If not, ????. William Slaughter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, March 16, 2008 9:01 PM Subject: AeroElectric-List: Ground Start enunciator light (Addendum) > > >Listers > >I installed a Piper-type male socket to my airplane, to have the possibility >of a ground start in case of a low battery cranking difficulty. >As recommended by this List experts, I connected the socket to the battery >through a continuous duty contactor (aka Master Relay or Battery solenoid), >the S701-1 from B&C, controlled by a SPST switch, which grounds the >contactor when thrown to ON. > >Now what I want to do is to put a green enunciator light in my panel, which >illuminates when that switch is ON and the contactor is closed to allow the >ground start procedure, to remind me to switch it Off after finishing that >procedure. > >I have tried some wiring of the warning light to the switch, but I cannot >make it work properly. Can somebody please enlighten me how to wire it? Carlos, A couple of hours after I replied to this it occurred to me that you probably were not incorporating a press-to-test light fixture nor did you mention crowbar ov protection. I've updated the schematics in the article to include "Ground Power Lite" without OV protection and using a plain vanilla lamp fixture. See the last page of: http://www.aeroelectric.com/articles/grndpwr.pdf Is this more like what you needed? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 16, 2008
Subject: Re: Audio iso amp ordered, never received
> > >First, to all, Bob Nuckolls included, I apologize for bringing this up >here, but I don't see any alternative. >Bob, I ordered an audio isolation amp board from you in December and paid >using Paypal. You said you were >planning on updating the board but would pull one and send it to me. I've >sent messages through the message >area, e-mails using the address in your responses to my questions before >ordering, and a request for info on the >Aeroelectric list. I've gotten no response or recognition that you've >received any of my attempts at communication. > >So: Can you let me know what's going on with my order? I wouldn't mind >the wait if I knew something was happening >at your end but that just hasn't been the case. My apologies. I HAVE 20 some boards around here somewhere. After your request came in I modified the artwork to include some later enhancements and ordered boards. They came in with some other boards and I've misplaced them. I've had so many irons in the fire the past few months that my shop is presently in a stage II train wreck. They're not lost, I just don't know where I "filed" them. I've just ordered another batch. They should be here Wednesday morning. I'll get your board out Wednesday afternoon via priority mail. I wasn't planning on resurrecting this product but when I find the first batch, I'll have "plenty" on hand. I guess I'll have to put it back up on the website! In the mean time, things re starting to spool down a bit on the 20hr/wk (yeah right!) consulting job. Weather is getting warmer and I'd really like to get the alternator drive stand in the garage running as well as cleanup/organize the shop! Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
> -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III > Sent: segunda-feira, 17 de Mar=E7o de 2008 2:01 > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Ground Start enunciator light (Addendum) > > > A couple of hours after I replied to this it occurred to me that > you probably were not incorporating a press-to-test light fixture > nor did you mention crowbar ov protection. I've updated the > schematics in the article to include "Ground Power Lite" without > OV protection and using a plain vanilla lamp fixture. See the > last page of: > > http://www.aeroelectric.com/articles/grndpwr.pdf > > Is this more like what you needed? > > Bob . . . You=92re right on target, Bob. Thanks again (Having a good teacher and being a good pupil ' forgive my immodesty ' I had already wired it yesterday like you now designed, and it worked!!) Carlos ________________________________________________________________________________
Date: Mar 17, 2008
Subject: Re: Van's Ammeter Question
> >Anyone know why Van's Ammeter gauge requires a +12V source >(independent of lighting)? Don't know for sure. I've ordered one to find out. >My hangar neighbor is building a -7 and noticed that when he keys >his ICOM his ammeter goes to 20-30 Amps on some frequencies but >only 2-3 Amps on others. > >Externally, the ammeter looks like a standard analog mechanical >gauge using an external shunt and with no technical docs provided >by Vans. > >My buddy also has RFI on his trim servo indicator (apparently quite >common) and on his Van's Manifold Pressure gauge. > >Shielded cable apparently does the trick for the servo, but I'd like >to understand the Ammeter a bit better before throwing bypass >caps and ferrites at it. Van's ammeter appears to be enhanced with internal electronics. The rudimentary meter movement is not sensitive to radio frequency interference. It's unfortunate that suppliers to the OBAM aircraft industry are so slow on the uptake for rudimentary design skills. It should NEVER be the responsibility of the installer to RFI-proof the system. On the TC side of the house, all accessories are tested in the lab and the designer is only rarely allowed to take credit for external shielding and/or filters on the interconnect cables. We see this a lot in consumer electronics where video, data and some audio cables come with some form of RFI mitigation enhancement on them. In each of these cases, the cables are pre-assembled and the end user is never expected to fabricate one that is longer or has different connectors on it. In aircraft, the installers are always expected to fabricate cables and install connectors. Installations of a product over time and many different airframes can experience a wide variety of assaults from EMC/RFI issues. As I write these words, I'm assisting an OEM with a random nuisance tripping of the fault detection system in a product that is over 20 years old and installed by the thousands in aircraft where this phenomenon has never manifested itself. However, in this new installation, a device that has been traditionally installed in the nose has been moved to the top of the vertical fin on a large a/c. This is the first time (anyone knows of) that the harness became so long and traversed so many EMC gauntlets on its way through the a/c. A review of schematics for the product revealed some ill-conceived filtering on i/o pins . . . that PASSED DO-160 conducted and radiated susceptibility tests 20+ years ago. When root cause of this problem is deduced, I'm betting that a few changes to components inside the product will fix it. But changing anything inside will raise re-certification flags with those-who-know-more-about-airplanes-than-we-do. We may well have to fabricate a filtered connector to go on the end of our interface harness. Seems the installer controls harnesses and are not part of the cert basis for the appliance. We can fix the problem with an external band-aid without having to re-qualify the appliance. The bureaucratic Catch 22 causes us to do really dumb things to work around the do-gooders. On the OBAM aircraft side of the house, suppliers of devices like trim indicators and ammeters can make indicated improvements to their products in a heartbeat without seeking anyone's permission. Problem is getting them to recognize shortcomings of their design and fix them. The TC guys will go to great lengths to avoid significant changes to the certification effort. I've seen changes to a 10-cent resistor generate thousands of dollars in re-qualification testing! (sigh) As soon as the Van's ammeter gets here, I'll see what makes it tick and report back to the group. Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
Subject: test
Wondering if the server is asleep . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 17, 2008
Date: Mar 17, 2008
Date: Mar 17, 2008
Subject: Z-19 with Z-30 and Z-31B
I connected my Piper style socket to a brass bus bar which will connect my two 12 v. batteries on the aircraft side of the contactors. I was doing this to keep the batteries isolated from each other unless both battery contactors were closed. This would allow charging either or both batteries or only powering aircraft systems from the ground power plug. If I understand correctly, that would not be a good idea because powering aircraft systems without a battery on line is a bad idea. Any pros or cons to this? On Sun, Mar 16, 2008 at 7:00 PM, Robert L. Nuckolls, III < nuckolls.bob(at)cox.net> wrote: > nuckolls.bob(at)cox.net> > > > > > > > >Listers > > > >I installed a Piper-type male socket to my airplane, to have the > possibility > >of a ground start in case of a low battery cranking difficulty. > >As recommended by this List experts, I connected the socket to the > battery > >through a continuous duty contactor (aka Master Relay or Battery > solenoid), > >the S701-1 from B&C, controlled by a SPST switch, which grounds the > >contactor when thrown to ON. > > > >Now what I want to do is to put a green enunciator light in my panel, > which > >illuminates when that switch is ON and the contactor is closed to allow > the > >ground start procedure, to remind me to switch it Off after finishing > that > >procedure. > > > >I have tried some wiring of the warning light to the switch, but I cannot > >make it work properly. Can somebody please enlighten me how to wire it? > > > Carlos, > > A couple of hours after I replied to this it occurred to me that > you probably were not incorporating a press-to-test light fixture > nor did you mention crowbar ov protection. I've updated the > schematics in the article to include "Ground Power Lite" without > OV protection and using a plain vanilla lamp fixture. See the > last page of: > > http://www.aeroelectric.com/articles/grndpwr.pdf > > Is this more like what you needed? > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > -- John McMahon Lancair Super ES, S/N 170, N9637M (Reserved) ________________________________________________________________________________
Date: Mar 17, 2008
Subject: Re: KX196
>Hi Bob, > >I have sort of an electrical problem/issue and I was wondering if you >could give me some guidance. I have a pristine Bendix King KLX 100 GPS >Portable Nav Com that I want to use primarily to listen to air traffic >while in my hangar. It runs fine on the eight AA batteries required but I >want to use AC in the hangar and/or DC in my car to power it. It doesn't >have the factory cords. So I called Bendix King and they want 350 for the >AC cord and 150 for the DC cord the total of which is more than the unit >itself is worth. I was wondering if there was some way for me to figure >out which type of AC and DC cords I could use say from Radio Shack or some >other supplier to get the job done. > >As I'm sure you know some AC cords are 9v some 12v with different outputs >from 500millamps on up. The DC cords also come in varieties. My owner's >manual doesn't say much on what is required for AC or DC power. Is there >any way for me to figure this out based on the batteries used to power the >unit, (8 AA's) or is there some other resource that could assist me? What does the external power connector look like on the radio? Does it look like the external power jacks found on most consumer electronics? See: http://www.aeroelectric.com/Pictures/Connectors/Power/Coaxial_DC_Power.jpg If so, it's only necessary to find the appropriate "wall wart" power supply and mating connector. If not this form factor, take a picture of the external power port on your radio and send it to me. Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
Subject: Re: Z-19 with Z-30 and Z-31B
> > I connected my Piper style socket to a brass bus bar which will connect > my two 12 v. batteries on the aircraft side of the contactors. I was > doing this to keep the batteries isolated from each other unless both > battery contactors were closed. This would allow charging either or both > batteries or only powering aircraft systems from the ground power plug. > If I understand correctly, that would not be a good idea because powering > aircraft systems without a battery on line is a bad idea. Any pros or > cons to this? There's been much discussion on this over the years. Generally speaking in the TC world, ground power is not considered a battery charging tool. In fact, it's not recommended that the pilot use ground power to get an engine started with a dead battery . . . ground power is to ASSIST the battery for difficult starts, i.e. cold weather or long cranking cycles for turbine engines, and ground maintenance. You can use what ever philosophy you're comfortable with. My reason for the architecture shown is that first, a pilot has absolute control over incoming power. Second, ground power can be applied, turned on and verified for polarity and proper voltage before the battery master is closed thus connecting the ground power/battery combination to the aircraft's systems. For your situation, being able to charge only one of the two batteries should not be a problem very often during your ownership of the airplane. On the other hand, when that kid standing out in the cold wind, back to you is flipping switches on that WWII surplus gasoline driven generator, it would be nice if YOU were the final arbiter of when ground power is actually applied to your airplane's electrical system. Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
Thanks Bob, It's hard to imagine why they would need an "enhancement" to the rudimentary meter movement since they are so widely used in this shunt current (voltage) range without. Also, the price of the meter from Van's suggests they are just custom labeling a automotive movement. Well, we will see thanks to Bob's generosity! -------- Ira N224XS Read this topic online here: http://forums.matronics.com/viewtopic.php?p=170457#170457 ________________________________________________________________________________
Date: Mar 17, 2008
> > >On a related note: >The instructions for modifying the receptacle call for a propane torch or >"large soldering iron". How large an iron? I ask because I incinerated the >phenolic insulator when I tried to solder it with my propane torch, and have >just ordered a replacement receptacle to try again. If I preheat the bolt in >the oven, would a Weller 100/140 soldering gun have enough oomph? If not, >????. No. Go to Home Depot or Lowes and see if you can find a Bernzomatic ST100T micro torch. This is my all time favorite although I don't find it described on the Bernszomatic website. It may be discontinued. In any case, you need a micro-torch not unlike those shown at: http://www.aeroelectric.com/Pictures/Tools/Soldering/Gas_Tools/ Harbor Freight has some butane micro-torches as do many hardware stores. I think Walmart stocks one too. Ace Hardware stores have: http://tinyurl.com/2tgatp Also, use 63/37 alloy solder. This stuff melts at 361F and flows nicely below 400. There's a rubber-bumper on the end of the receptacle center-pin. Pull this off for soldering operations and replace it after the pin cools. Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
The instruments themselves are manufactured by ISS for Van's, and now Cheif and Aircraft Spruce both sell the same item with different faceplates. I did open the case to take a peek and it had a small circuit board with SM parts all over it. You'll have fun with it Bob. I gleaned all this when I ordered one from spruce for a customer of mine, it didn't come with instructions but had 4 pins on the back, so I called spruce. The saleperson there gave me the number to an engineer at ISS who was very unhappy I interupted his day. I did get the instructions from van's site and a few weeks later a friend ordered one for his homebuilt from spruce. This time it came with the Van's instructions. so the engineer must have got it resolved in that direction. So far as I know, niether installation has had problems so I'd be curious as well. Ed Larsen (43G) Larsen Airpark **************It's Tax Time! Get tips, forms, and advice on AOL Money & Finance. (http://money.aol.com/tax?NCID=aolprf00030000000001) ________________________________________________________________________________
Date: Mar 17, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> The instruments themselves are manufactured by ISS for Van's, and now > Cheif and Aircraft Spruce both sell the same item with different faceplates. > I did open the case to take a peek and it had a small circuit board with > SM parts all over it. You'll have fun with it Bob. > I gleaned all this when I ordered one from spruce for a customer of > mine, it didn't come with instructions but had 4 pins on the back, so I > called spruce. The saleperson there gave me the number to an engineer at > ISS who was very unhappy I interupted his day. I did get the instructions > from van's site and a few weeks later a friend ordered one for his > homebuilt from spruce. This time it came with the Van's instructions. so > the engineer must have got it resolved in that direction. > So far as I know, niether installation has had problems so I'd be > curious as well. > Ed Larsen > (43G) Larsen Airpark Thank you for sharing this. It's what I would have guessed that it has some form of electronics. When you have an instrument with this mechanical span (approx 270 degrees) you either use a stepper motor or a moving magnet suspended in quadrature coils. You can buy a motor driven instrument for $40 so it must be a moving magnet device. There are a number of integrated circuits designed to drive a 2-coil instrument motor . . . many transistors capable of responding to VHF radios. Do you have a name and phone number for the engineer at ISS? Bob . . . ________________________________________________________________________________
Date: Mar 17, 2008
Subject: Re: DPDT high-current contactor needed
> >Hi, Listers, > >I need a manually operated double pole double throw contactor that will >carry (not make or break) up to 400 amps. I'm building a 14v system, but my >engine requires 24v to spin the starter. My plan is to install 2 batteries. >Normal configuration will be parallel for charging and normal running, but >switching one battery into a series configuration for starting. Actual >starting will be with a starter contactor, so the dpdt contactor won't make >or break the starting current. Any thoughts on where I could find such a >contactor? The last time I saw a series-parallel battery controller it was a about half the size of a breadbox, weighed about 10 pounds and cost a couple of grand. Of course, this was an electrically engaged/disengaged device. It was a WWII era design. I think a Hartman product. Not part of their current bag of tricks that I could see . . . http://relays.tycoelectronics.com/hartman.asp I'm unaware of any manually operated device for this purpose. On the TC side of the house, we go to a LOT of effort to avoid a need for such agility in battery management. Here's a drawing I did for a client some years ago to address a similar requirement. He didn't need 400A so the Stancore/White-Rogers contactors would suffice. If this approach works for you, you'll need to consider some heavier devices. Perhaps Type 124? http://www.stancor.com/wrdstc/pdfs/Catalog_2006/Pg_054_55.pdf Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: AeroElectric Manual
Date: Mar 18, 2008
Bob: any chance of getting an manual? I have tried to order online. Thanks Keith Rhea N52VP ________________________________________________________________________________
Date: Mar 18, 2008
Subject: Re: AeroElectric Manual
I placed an order a couple weeks back also, and am still anxiously waiting for delivery. David Dalton On Tue, Mar 18, 2008 at 5:11 AM, Keith Rhea wrote: > > Bob: any chance of getting an manual? I have tried to order online. > > Thanks > > Keith Rhea > N52VP > > ________________________________________________________________________________
Date: Mar 18, 2008
My wife ordered one for my B-day about 8 days ago, & it came in 4 days later. Charlie David Dalton wrote: > I placed an order a couple weeks back also, and am still anxiously > waiting for delivery. > > David Dalton > > On Tue, Mar 18, 2008 at 5:11 AM, Keith Rhea > wrote: > > > > > Bob: any chance of getting an manual? I have tried to order online. > > Thanks > > Keith Rhea > N52VP > ________________________________________________________________________________
Date: Mar 18, 2008
Subject: Smoke
Date: Mar 18, 2008
Last evening I experienced smoke in the cockpit of my Kitfox--912S. First, I want to thank Bob N for convincing me of the importance of using Z16, incorporating an E-Bus circuit. Worked great and reduced the load on my "little" motorcycle battery so that I maintained > 11.5 v for the 15 min duration of my flt. It was twilight & I had Whelan strobe & nav lights on, near max elec capacity for the 912 generator. I threw on the landing lt to see what the added load would do to the system. (Probably not a smart move) Immediately the system voltage, normally runs 13v, began dropping, so I turned the landing lt off after a few seconds. I then began doing a series of steep climbs at slow airspeed. After about five min I noticed a burning odder, thinking to myself "someone must be burning trash and I'm in the trail of smoke." After about 30 seconds I noticed smoke coming from under the instrument panel and a much stronger burning odder. I dropped the nose of the airplane--no more smoke. At that moment my GRT EIS warning lt flashed and I noticed the system voltage below 11 v. I turned on the E Bus switch and off on the main. Voltage came up--12 v I think. No odder or smoke or falling voltage. After a few minutes I decided to try the main switch again, pulling in the battery relay and alternator. Voltage began to climb above 12 v to about 12.5 v. I added strobe & nav lt again causing an immediate reversal in voltage trend and warning lt came on again as it plunged below 11 v. Again I went to E Bus an off main. I landed uneventfully. My guess is the relay over heated with the momentary excessive electrical draw (does that happen?) causing the smoke. Any Ideas? I assume I need to replace the regulator??? What would you recommend as a replacement regulator/source. Anything else?????? Thanks Frank N5929 ________________________________________________________________________________
Date: Mar 18, 2008
Subject: Re: Smoke
*Positive ground depends upon proper circuit functioning, the transmission of negative ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work; we know this to be true because every time one lets the smoke out of the electrical system, it stops working. This can be verified repeatedly through empirical testing. When, for example, the smoke escapes from an electrical component (i.e., say, a Lucas voltage regulator), it will be observed that the component stops working. The function of the wire harness is to carry the smoke from one device to another; when the wire harness "springs a leak", and lets all the smoke out of the system, nothing works afterwards. Starter motors were frowned upon in British Automobiles for some time, largely because they consume large quantities of smoke, requiring very large wires. It has been noted that Lucas components are possibly more prone to electrical leakage than Bosch or generic Japanese electrics. Experts point out that this is because Lucas is British and all things British leak. British engines leak oil, shock absorbers, hydraulic forks and disk brakes leak fluid, British tires leak air and the British defense establishment leaks secrets...so, naturally, British electronics leak smoke. The Theory Explained through Discussion. When wires smoke, how come the smoke is not the same color as the wire? This is not completely true. When the smoke is in the wire, it is under pressure (called voltage). The pressure difference causes the color to change from the normal color we are used to. Not unlike the blood in our veins and arteries changing color due to the oxygen content. When the smoke escapes the wire and is exposed to air, the pressure is released, and the color reverts back to what we commonly recognize as smoke. The wire then changes to the color of the smoke that escaped. I hope this helps you understand. I would only question the last sentence of that description. It has been my experience that the wire turns a color directly opposite of the smoke. Not always true, I think it must depend on the composition of the smoke in question. I should have made it a little clearer; the color the wire becomes, is directly proportional to the escape velocity of the smoke. Higher velocities generate higher heat. This heat tends to burn the wire and affect the coloring. The statement was meant to be a generalization, indicating the fact that the color of the wire does in fact change. Sorry for the miscommu nication. I was speaking of electrical smoke which is generally white. The spent smoke casing generally assumes a color somewhat near black after the smoke leaves. I can't stand it anymore! If, as you say, light bulbs suck up darkness and convert it to smoke which is transmitted (via wire) to a power source for recycling...why do car batteries go dead when lights are left on? Do car batteries (and flashlight batteries for that matter) have a limited amount of storage capability? Is it like a hard drive that gets so full that you have to double-space and then lose all data? Now you're getting it....... I thought you guys were smarter than this. Of course the battery stores the smoke. In fact it can store so much smoke that if you open the top and light a match, the resulting explosion can do serious damage. I'm sure you are aware that usually where there's smoke there's fire. If you connect the battery to a charger, the smoke is then returned to the wire (Remember, a light bulb wont work unless it is connected to a wire system) for the utility companies to use. Your hard drive analogy is a very good example. Our hardware guys might be onto something in their quest for superior wiring. I have noticed the unique method of series/parallel wiring the power strips on our systems seems to prevent the smoke from getting out of the wires. A "Smoke Loop" of sorts. In the case of the "smoked" workstation recently, you should notice that this was a conventional single power strip installation. Since color is perceived by the cone shaped receptors in our eyes, and cones require more light that their rod shaped counterparts. Is the sky blue at night? At night the process including contraction of the pupil is visual purple by which the eye adapts to conditions of increased illumination when facing 300 candle power redeflecting devices. Since there is a spectrum of light that we as humans cannot see, I support the theory that everything is going up in smoke, we just can't see it. This may explain why the neighbors dog barks for no apparent reason. I think your basic understanding of smoke systems is remarkable. However I find a flaw with your theory. The battery is a reusable storage device for smoke. therefore, one would assume that some sort of one way valve (we can call it a diode) should be needed to prevent pressure flooding back into the system while at rest. Unlike the A/C system, the smoke system is collecting darkness at the headlights and converting it to smoke. This causes the system to fill up. The battery can contain much higher pressures and volumes than the wires. If this pressure exceeds the capacity of the wire, it will cause a rupture as you described. The rupture can be controlled by a sacrificial device known as a fuse. Bu t this still doesn't eliminate the problem. Perhaps a two way valve (zener diode) is used to allow a small amount of pressure to return to the system, and partially equalize. I find this theory unlikely though, due to the increase in the force required to start the pump (which is now under pressure) working again... The smoke continues circulating through the system, due to the pressure differential in the battery (smoke pressure/vacuum reservoir). When the reservoir becomes depleted, the pressure simply equalizes everywhere in the system (similar to an A/C system when it's turned off) and stuff just wont work. Notice the relations: Work (W) = Force (F) x Distance (D); Force (F) = total difference in pressure (Dp) x Area (A). Therefore, the work done in a pressure system is: Dp x A x D. If the pressure differential (Dp) is reduced to zero then W = 0 x A x D = 0. The smoke only escapes the wires when a path is created b etween the pressure differential areas (@ either the reservoir or the pump) that has too little restriction. When this happens, the smoke travels through the wires so fast that the friction between the smoke and the outer walls of the wiring heats the wires until they rupture. The smoke continues to escape until its pressure is equalized with the atmosphere, or until the conduit that provides the path between pressure areas is severed. When this happens, the sudden drop in pressure allows the wires to "collapse" slightly and, being soo hot, as the edges of the ruptures and severed ends touch, the material becomes fused, sealing the system and retaining the remaining smoke. Don't forget, when the system is at rest, all the valves, (switches and relays) are closed, keeping the pressure areas separated. When restarting the pump, as long as everything is OK, the smoke pressure is equal on both sides of the pump and there is no net force on the pump when it begins operating again. Also, within the pump there are pressure/volume actuated one-way valves with restrictors built in, arranged in such a way that they keep excess smoke volume recirculating through an integral smoke loop, which maintains the pressure within manageable limits. The excess smoke, created by the light/smoke converters (headlights and other darkness absorbing devices), is changed back to darkness and dissipated in small unit concentrations so its dark effect is not locally observed. The smoke pump impeller (stator), converts smoke into magnetic flux which does work on the engine. Some of the excess work energy is dissipated through the cooling system and exhaust in the form of heat, while the remaining work energy is converted back to smoke and distributed evenly in small concentrations as you drive. This maintains the total quantity of smoke in the system at an average that does not change over time.* On Tue, Mar 18, 2008 at 7:43 PM, wrote: > > Last evening I experienced smoke in the cockpit of my Kitfox--912S. > > First, I want to thank Bob N for convincing me of the importance of > using Z16, incorporating an E-Bus circuit. Worked great and reduced the > load on my "little" motorcycle battery so that I maintained > 11.5 v for > the 15 min duration of my flt. > > It was twilight & I had Whelan strobe & nav lights on, near max elec > capacity for the 912 generator. I threw on the landing lt to see what > the added load would do to the system. (Probably not a smart move) > Immediately the system voltage, normally runs 13v, began dropping, so I > turned the landing lt off after a few seconds. > > I then began doing a series of steep climbs at slow airspeed. After > about five min I noticed a burning odder, thinking to myself "someone > must be burning trash and I'm in the trail of smoke." After about 30 > seconds I noticed smoke coming from under the instrument panel and a > much stronger burning odder. I dropped the nose of the airplane--no > more smoke. > > At that moment my GRT EIS warning lt flashed and I noticed the system > voltage below 11 v. I turned on the E Bus switch and off on the main. > Voltage came up--12 v I think. No odder or smoke or falling voltage. > > After a few minutes I decided to try the main switch again, pulling in > the battery relay and alternator. Voltage began to climb above 12 v to > about 12.5 v. I added strobe & nav lt again causing an immediate > reversal in voltage trend and warning lt came on again as it plunged > below 11 v. Again I went to E Bus an off main. I landed uneventfully. > > My guess is the relay over heated with the momentary excessive > electrical draw (does that happen?) causing the smoke. Any Ideas? I > assume I need to replace the regulator??? What would you recommend as a > replacement regulator/source. Anything else?????? > > Thanks > > Frank > N5929 > > ________________________________________________________________________________
From: "Dale Alexander" <dalexan48(at)dslextreme.com>
Subject: Re:Smoke
Date: Mar 19, 2008
For those of you out there that own, have owned, may own or have worked on anything British: What are the three positions of a Lucas headlight switch? 1) Dim 2) Flicker 3) and Smoke Now let's not mention Lucas in a aviation newsgroup again...or Microsoft. The blue screen of death takes on a WHOLE new meaning when you MS powered glass screen goes belly-up in the scud. Dale Alexander Trying to build something, probably never finish it... ________________________________ Message 8 _____________________________________ > > > From: "Sam Hoskins" <shoskins(at)MCHSI.COM> > Subject: Re: AeroElectric-List: Smoke > > *Positive ground depends upon proper circuit functioning, the > transmission of negative ions by retention of the visible spectral > manifestation known as "smoke". Smoke is the thing that makes electrical > circuits work; we know this to be true because every time one lets the > smoke out of the electrical system, it stops working. This can be > verified repeatedly through empirical testing. ________________________________________________________________________________
Date: Mar 19, 2008
Subject: Re:Smoke
=0AYeah, no doubt. While we're at it:=0A=0A =0A=0A1. NEVER fly behind a Ly coming (or pick your most hated brand). They are the most dangerous engine ever built. I had one die on me in 1961 and have never flown one since.=0A =0A2. NEVER purchase a Ford (or pick your most hated brand). I owned a 195 2 that got horrible mileage and always needed work. They are terrible produ cts.=0A=0A3. DO NOT operate a computer. I tried to use one once but didn't know what I was doing. It got is so screwed up that it wouldn't work - OBV IOUSLY someone else's fault (pick your most hated vendor).=0A=0A4. ABSOLUTE LY NEVER EVER use a calculator. I had one once that pinched my index finde r between the keys - horribly dangerous machines!!=0A=0A5. STAY AWAY from t elephones. Someone called me once trying to sell me something. They are wo rks of Satan and huge time wasters.=0A=0A =0A=0AJon=0A=0APLEASE do not arch ive=0A=0A =0A=0A=0A=0A=0A-----Original Message-----=0AFrom: Dale Alexander =0ASent: Wednesday, March 19, 2008 10:04am=0ATo: aeroelectric-list(at)matronics.com=0ASubject: AeroElectric-List: Re:Smoke=0A e of you out there that own, have owned, may own or have worked on =0Aanyth ing British:=0A=0AWhat are the three positions of a Lucas headlight switch? =0A1) Dim=0A2) Flicker=0A3) and Smoke=0A=0ANow let's not mention Lucas in a aviation newsgroup again...or Microsoft. =0AThe blue screen of death takes on a WHOLE new meaning when you MS powered =0Aglass screen goes belly-up i n the scud.=0A=0ADale Alexander=0ATrying to build something, probably never finish it...=0A ________________________________________________________________________________
Date: Mar 19, 2008
Subject: Re: Smoke
> >Last evening I experienced smoke in the cockpit of my Kitfox--912S. > >First, I want to thank Bob N for convincing me of the importance of >using Z16, incorporating an E-Bus circuit. Worked great and reduced the >load on my "little" motorcycle battery so that I maintained > 11.5 v for >the 15 min duration of my flt. > >It was twilight & I had Whelan strobe & nav lights on, near max elec >capacity for the 912 generator. I threw on the landing lt to see what >the added load would do to the system. (Probably not a smart move) >Immediately the system voltage, normally runs 13v, began dropping, so I >turned the landing lt off after a few seconds. > >I then began doing a series of steep climbs at slow airspeed. After >about five min I noticed a burning odder, thinking to myself "someone >must be burning trash and I'm in the trail of smoke." After about 30 >seconds I noticed smoke coming from under the instrument panel and a >much stronger burning odder. I dropped the nose of the airplane--no >more smoke. > >At that moment my GRT EIS warning lt flashed and I noticed the system >voltage below 11 v. I turned on the E Bus switch and off on the main. >Voltage came up--12 v I think. No odder or smoke or falling voltage. > >After a few minutes I decided to try the main switch again, pulling in >the battery relay and alternator. Voltage began to climb above 12 v to >about 12.5 v. I added strobe & nav lt again causing an immediate >reversal in voltage trend and warning lt came on again as it plunged >below 11 v. Again I went to E Bus an off main. I landed uneventfully. > >My guess is the relay over heated with the momentary excessive >electrical draw (does that happen?) causing the smoke. Any Ideas? I >assume I need to replace the regulator??? What would you recommend as a >replacement regulator/source. Anything else?????? Do we know exactly where the smoke was coming from? Is the relay visibly damaged or the regulator? The fact that your voltage started to come up when you re-energized the alternator suggests that the rectifier-regulator was not killed. Try making a hard connection to bypass the control relay and do a ground run to see if the bus voltage comes up . . . do this with a fully charged battery so that you don't have to wait for the alternator to top off the battery. If I'm understanding your words, the relay is what failed. I'd like to get my hands on it for examination. I'd be pleased to send you a replacement but I suspect you can find one much faster locally. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 19, 2008
Subject: KLN-35(A) pinout....
X-mailer: Pegasus Mail for Windows (4.41) X-SpamReason %%SpamReason%%: Had a gentleman ask me about a pinout for the above after seeing a reference in this list and a posting I'd made. It's not in the AeroElectric archives. Should be a 15 pin card edge connector. Thanks! Jim Baker 580.788.2779 Elmore City, OK ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: ELT antenna requirements
Date: Mar 19, 2008
I will be installing the Artex ME406 w/110-773 whip antenna. It broadcasts on 121.5 and 406 Mhz. I am installing it in an E-glass plane. What is the mimimum ground plane that will work. The instructions are suggesting that the ground plane radius should be 24" in all directions! The plane is not 4' wide at any point in the fuselage!!? I really don't have much room for this install since I am trying to keep all the antennas inside the plane. Does anyone have a suggestion as to how I can install this antenna or make a half wave that doesn't require a ground plane? Bill B ________________________________________________________________________________
Subject: Re:Smoke
Date: Mar 19, 2008
Lucas was the first to invent intermittent wipers....I'm told Tim Andres For those of you out there that own, have owned, may own or have worked on anything British: What are the three positions of a Lucas headlight switch? 1) Dim 2) Flicker 3) and Smoke Now let's not mention Lucas in a aviation newsgroup again...or Microsoft. The blue screen of death takes on a WHOLE new meaning when you MS powered glass screen goes belly-up in the scud. Dale Alexander Trying to build something, probably never finish it... ________________________________ Message 8 _____________________________________ > > > From: "Sam Hoskins" <shoskins(at)MCHSI.COM> > Subject: Re: AeroElectric-List: Smoke > > *Positive ground depends upon proper circuit functioning, the > transmission of negative ions by retention of the visible spectral > manifestation known as "smoke". Smoke is the thing that makes electrical > circuits work; we know this to be true because every time one lets the > smoke out of the electrical system, it stops working. This can be > verified repeatedly through empirical testing. ________________________________________________________________________________
Date: Mar 19, 2008
Subject: Re: ELT antenna requirements
The ground plane can curve - to some extent following the contour of the fuse. I imagine that if the radiator is in the middle of the fuse and the ground plane wraps very far up the sides, performance will suffer to some extent, though performance may still be acceptable to you. What type of antenna have other builders used? External? Is it possible to install the antenna in the fin? Is it e-glass also? You may be able to install an antenna that looks electrically like a 1/4 wave dipole, but is more physically compact in length (height). How tall is the fin? Regards, Matt- > > > I will be installing the Artex ME406 w/110-773 whip antenna. It > broadcasts > on 121.5 and 406 Mhz. > I am installing it in an E-glass plane. What is the mimimum ground plane > that will work. The instructions are suggesting that the ground plane > radius should be 24" in all directions! The plane is not 4' wide at any > point in the fuselage!!? > I really don't have much room for this install since I am trying to keep > all > the antennas inside the plane. > Does anyone have a suggestion as to how I can install this antenna or make > a > half wave that doesn't require a ground plane? > > Bill B > > ________________________________________________________________________________
Subject: "Shuntless" Ammeter in Diagram Z-16
Date: Mar 19, 2008
Hello, I am building a Zenith CH701 with a Rotax 912ULS engine. I am using the Z-16 diagram as reference for my electrical system. I purchased a VDO ammeter (no shunt required) from Aircraft Spruce: http://www.aircraftspruce.com/catalog/inpages/vdoammeter.php I am wondering how I can incorporate this into the electrical system to monitor battery output/discharge. Can the ammeter simply be put in between the battery and battery contactor? Thanks, Dan Ginty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=171146#171146 ________________________________________________________________________________
Date: Mar 19, 2008
> > > I will be installing the Artex ME406 w/110-773 whip antenna. It broadcasts >on 121.5 and 406 Mhz. >I am installing it in an E-glass plane. What is the mimimum ground plane >that will work. The instructions are suggesting that the ground plane >radius should be 24" in all directions! The plane is not 4' wide at any >point in the fuselage!!? >I really don't have much room for this install since I am trying to keep all >the antennas inside the plane. >Does anyone have a suggestion as to how I can install this antenna or make a >half wave that doesn't require a ground plane? The ground plane radials need to be 24" long but not necessarily flat. The easiest way to make this happen is to mount a "patch" of brass sheet (shim stock, sheet stock from hobby shop) about 3" diameter on the inside surface of the skin centered on your antenna location. Copper foil is nice stuff to make radials out of but copper wire will work too. Further, it's easier to find (a 6 foot piece of 12x2 Romex with ground will yield 18' total of 12AWG solid wire). Solder as many 23" pieces of 12AWG wire as you are willing to mess with to the edge of your brass grounding pad at the base of the antenna. Route radials away from antenna following inside contours of skin. Stick each radial to the skin with patches of BID glass and 5 minute epoxy. 4 radials is about the minimum, return on investment of time beyond 8 radials is poor. Recommend you stay with the supplied antenna . . . it may have features that enhance its two-frequency performance. Bob . . . ________________________________________________________________________________
Date: Mar 19, 2008
Subject: Re: KLN-35(A) pinout....
> >X-SpamReason %%SpamReason%%: > >Had a gentleman ask me about a pinout for the above after seeing a >reference in >this list and a posting I'd made. It's not in the AeroElectric archives. >Should >be a 15 pin card edge connector. I found it in 'the book' and I've posted it at: http://www.aeroelectric.com/Installation_Data/KLN-35A.pdf Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: "Shuntless" Ammeter in Diagram Z-16
Date: Mar 19, 2008
Never mind. I just reviewed Section 7 and found what I was looking for. I'll try and rearrange the system to the 'classic battery ammeter wiring' shown in Figure 7-11. Thanks anyway. Dan Ginty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=171156#171156 ________________________________________________________________________________
Date: Mar 19, 2008
Subject: Re:Smoke
Tim, How can you have a discussion of electricity without paying homage to Joseph Lucas, the discoverer of the short circuit? :-) Rick On Wed, Mar 19, 2008 at 7:38 PM, Tim Andres wrote: > tim2542(at)sbcglobal.net> > > Lucas was the first to invent intermittent wipers....I'm told > Tim Andres > > For those of you out there that own, have owned, may own or have worked on > anything British: > > What are the three positions of a Lucas headlight switch? > 1) Dim > 2) Flicker > 3) and Smoke > > Now let's not mention Lucas in a aviation newsgroup again...or Microsoft. > The blue screen of death takes on a WHOLE new meaning when you MS powered > glass screen goes belly-up in the scud. > > Dale Alexander > Trying to build something, probably never finish it... > > ________________________________ Message 8 > _____________________________________ > > > > > > From: "Sam Hoskins" <shoskins(at)MCHSI.COM> > > Subject: Re: AeroElectric-List: Smoke > > > > *Positive ground depends upon proper circuit functioning, the > > transmission of negative ions by retention of the visible spectral > > manifestation known as "smoke". Smoke is the thing that makes electrical > > circuits work; we know this to be true because every time one lets the > > smoke out of the electrical system, it stops working. This can be > > verified repeatedly through empirical testing. > > ________________________________________________________________________________
Date: Mar 20, 2008
> >Never mind. I just reviewed Section 7 and found what I was looking >for. I'll try and rearrange the system to the 'classic battery ammeter >wiring' shown in Figure 7-11. Thanks anyway. > >Dan Ginty Dan, do you have a scanner? I'm not familiar with this ammeter and I'd like to have a copy of the installation instructions for it for my library. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2008
> >Never mind. I just reviewed Section 7 and found what I was looking >for. I'll try and rearrange the system to the 'classic battery ammeter >wiring' shown in Figure 7-11. Thanks anyway. > >Dan Ginty Dan, do you have a scanner? I'm not familiar with this ammeter and I'd like to have a copy of the installation instructions for it for my library. Scratch that request, I found it on the Internet! Bob . . . ________________________________________________________________________________
Date: Mar 20, 2008
I have an Ameriking AK450 ELT (121.5/243.0MHz) also in a plastic plane. The ELT antenna was broken when I got the plane so I calculated the optimal length and made a whip antenna out of welding rod. I simply soldered the rod to the center BNC conductor and insulated the section coming out of the BNC shell area. To fit the approx. 23" antenna in the space I had to bend it 90 degrees over a 2" radius, about 5" from the BNC. My biggest concern was lack of ground plane, but I was hoping the ELT itself acted as a ground plane. Even I know this is not optimal, but is it "workable"? --Jose ________________________________________________________________________________
Date: Mar 20, 2008
> >I have an Ameriking AK450 ELT (121.5/243.0MHz) also in a plastic plane. The >ELT antenna was broken when I got the plane so I calculated the optimal >length and made a whip antenna out of welding rod. I simply soldered the rod >to the center BNC conductor and insulated the section coming out of the BNC >shell area. To fit the approx. 23" antenna in the space I had to bend it 90 >degrees over a 2" radius, about 5" from the BNC. My biggest concern was lack >of ground plane, but I was hoping the ELT itself acted as a ground plane. >Even I know this is not optimal, but is it "workable"? Depends on what how we define "workable". The task of getting some manifestation of energy stored on the ELT's batteries to an overhead satellite is burdened with many losses and pitfalls in the conversion and conduction of energy. The batteries will deliver at 10-14 volts, the satellite will hear your ELT if the signal arrives at the 1 to 10 MICROvolt level. The weakest link in the energy conduction process is the antenna. It has no way of knowing where the satellite is so it spreads your signal all over the sky . . . and ground too. Everything you do that departs from the best-we-know-how-to-do adds another degree of uncertainty to the probability that the satellite gets a useful signal. On the other side of the coin, the probability that this piece of equipment will be a major contributor to your surviving the unplanned arrival with the earth is low. An article published in one of the journals a couple of years ago cited something much less than 10% of recovery situations where the ELT figured strongly in the success of the operation. The departures you've described from "ideal" will no doubt degrade the benchmark performance of the system. Will it make the difference between your pile of bent aluminum being found or not found? Probably not. Your failure to make good on a flight plan followed by a decision by someone to go looking for you is more likely to initiate any sort of rescue action. Then, if search aircraft also happen to carry receivers and direction finding equipment for ELT frequencies, then even your degraded performance MIGHT be of some assistance in finding you sooner . . . if ever. If you're putting much faith in the utility of this device to make the difference between surviving or not, then one of the more sophisticated devices is called for. One that transmits your last known GPS position. You can also consider an internal antenna like this: http://www.aircraftspruce.com/catalog/avpages/antennasystems.php At the very least, put a ground plane under the antenna you described above. I posted a recommended process on adding ground planes to plastic antennas to the List yesterday. Alternatively, making your ELT a hand-held device with a full length, telescoping antenna gets around a lot of installation hassles. Bob . . . ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Re: AeroElectric-List Digest: 8 Msgs - 03/18/08
Sam, I think I am beginning to understand how airplanes work. If I extrapolate [dangerous, I know, but humor me], then gasoline must be a natural storage device of wind energy, and the engines on our planes simply liberate the wind stored in the gasoline. Is this correct? If so, does it then follow that the reason some of us need bigger engines is because we naturally have more stored wind which the larger engine is more able to convert? Your views are appreciated in advance, John Markey Glasair II-FT _____________________________________ From: "Sam Hoskins" <shoskins(at)MCHSI.COM> Subject: Re: AeroElectric-List: Smoke *Positive ground depends upon proper circuit functioning, the transmission of negative ions by retention of the visible spectral manifestation known as "smoke". Smoke is the thing that makes electrical circuits work; we know this to be true because every time one lets the smoke out of the electrical system, it stops working. This can be verified repeatedly through empirical testing. "I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man." -- Thomas Jefferson --------------------------------- Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. ________________________________________________________________________________
Date: Mar 20, 2008
Subject: alternator field current
I'm building a dual alternator, single battery Z-12 and am trying to figure out the running current loads of the alternator field circuits. Of course, I see that a 5A fuse is recommended, however, I'd like to know what is the normal current on this circuit. Ron ________________________________________________________________________________
Date: Mar 20, 2008
I'm building a dual alternator, single battery Z-12 and am trying to figure out the running current loads of the alternator field circuits. Of course, I see that a 5A fuse is recommended, however, what is the normal current on this circuit? Ron ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Smoke
Ah yes, Lucas, the folks who invented darkness Jim ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Re: alternator field current
> >I'm building a dual alternator, single battery Z-12 and am trying to >figure out the running current loads of the alternator field circuits. >Of course, I see that a 5A fuse is recommended, however, what is the >normal current on this circuit? These are not normally considered to be part of the ship's running loads. It's assumed that an alternator will be required to carry its own excitation requirements. Therefore, an alternator rated for say 60A is really expected to supply 60 amps IN ADDITION to energy needed to excite the field. So use 3A as a max, 1A as average and then don't add it into your load analysis. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Plane Power Alternator Failure (brand new)
Date: Mar 20, 2008
A friend had a Plane Power alternator fail after his first flight. Apparently, he left the Master "on" (in ALT position) for 30-40 minutes while he was working on the plane, and after that he noticed that his ALT Field enable fuse was blown. It happened to a replacement fuse as well. I checked the wiring right to the alternator-- no fault with it unplugged. I can't measure any shorts to ground on the Alternator pins. My theory is the the internal voltage regulator overheated and failed short. My theory is that it would overheat because there was no airflow and was providing maximum field current for a long time. Has anyone else experienced this or have an alternate diagnosis? Thanks, Vern Little ________________________________________________________________________________
Date: Mar 20, 2008
> > > >So: Can you let me know what's going on with my order? I wouldn't mind >the wait if I knew something was happening >at your end but that just hasn't been the case. Dave, the boards just arrived. I'm putting your board first class mail. I've also refunded your money for the board. You've suffered enough over this project! There are some changes to the board that don't affect the parts you'll need to install. There are some extra holes for speaker-out load resistors (not often needed) that you won't use. I'll try to get the data package updated to the new board and put the DIY project back up on the website! Bob . . . ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Re: Plane Power Alternator Failure (brand new)
I'm not sure if the theory is good or bad, but I can say that I've left my master on for a very very long time before....many hours, as opposed to those 30-40 minutes, and I've never seen anything like that. I suppose the regulator or something could have gone bad, but I'd also check real well for any wiring errors. First off though, I'd call them and see what they say...they'll know better than most people, and I bet they take care of it right away. Tim Olson - RV-10 N104CD - Flying Vernon Little wrote: > > A friend had a Plane Power alternator fail after his first flight. > > Apparently, he left the Master "on" (in ALT position) for 30-40 minutes > while he was working on the plane, and after that he noticed that his ALT > Field enable fuse was blown. It happened to a replacement fuse as well. > > I checked the wiring right to the alternator-- no fault with it unplugged. > I can't measure any shorts to ground on the Alternator pins. > > My theory is the the internal voltage regulator overheated and failed short. > My theory is that it would overheat because there was no airflow and was > providing maximum field current for a long time. > > Has anyone else experienced this or have an alternate diagnosis? > > Thanks, Vern Little > > ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Tool to crimp a 90 degree Faston terminal?
I have a need to use a few 90 degree 1/4" Faston Terminal ( I believe they are also called "Flags") but can't figure out what tool is used to crimp the wires. It doesn't appear there is any way to use the standard dies for other insulated crimp terminals. Anybody know what works? Thanks much, Harold Lanfear ________________________________________________________________________________
Date: Mar 20, 2008
> > >A friend had a Plane Power alternator fail after his first flight. > >Apparently, he left the Master "on" (in ALT position) for 30-40 minutes >while he was working on the plane, and after that he noticed that his ALT >Field enable fuse was blown. It happened to a replacement fuse as well. > >I checked the wiring right to the alternator-- no fault with it unplugged. >I can't measure any shorts to ground on the Alternator pins. > >My theory is the the internal voltage regulator overheated and failed short. >My theory is that it would overheat because there was no airflow and was >providing maximum field current for a long time. > >Has anyone else experienced this or have an alternate diagnosis? It's a plausible theory. The only schematics for regulators I've been able to study take a sample of the AC from the alternator's stator windings and won't turn the field on unless there is a detected motion of the rotor. But I don't know that all regulators do that . . . in particular, those used in Plane Power's products. A phone call to them should reinforce or wash out your hypothesis. They've been courteous and quite forthcoming with useful information when I've had occasion to communicate with them. If the regulator doesn't shut down during engine-off ops, then it full-fields the alternator. I wouldn't expect this to overheat the regulator . . . but it might have cooked insulation in the field windings and cause a short there. This is one of several reasons why the Z-figures are configured to allow pilot/mechanic control of field excitation both in flight and on the ground. Separate but interlocked Battery and Alternator switches configured to emulate the infamous split-rocker switch. Give PlanePower a call and let us know what they have to say. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 20, 2008
Subject: Re: Tool to crimp a 90 degree Faston terminal?
>I have a need to use a few 90 degree 1/4" Faston Terminal ( I believe >they are also called "Flags") but can't figure out what tool is used to >crimp the wires. It doesn't appear there is any way to use the standard >dies for other insulated crimp terminals. Anybody know what works? Push comes to shove, use the hardware store crimp tool for insulated terminals. Put the super mash on the wire grip, be more gentle on the insulation grip. See: http://www.aeroelectric.com/Pictures/Tools/Crimp_Tools/Two_Shot_Crimp_Tool.jpg Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 20, 2008
Harold Lanfear wrote: > I have a need to use a few 90 degree 1/4" Faston Terminal ( I believe they are also called "Flags") but can't figure out what tool is used to crimp the wires. It doesn't appear there is any way to use the standard dies for other insulated crimp terminals. Anybody know what works? > > Thanks much, > Harold Lanfear > I used a standard B crimper. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Mar 20, 2008
Would not surprise me Vern. My wee ND IR alternator draws a couple of amps and heats up quite noticeably with the engine off and the IGN terminal (and B+ lead) connected to the battery. Fortunately the OV relay lets me disconnect it by opening the alternator control switch. Ken Vernon Little wrote: > > A friend had a Plane Power alternator fail after his first flight. > > Apparently, he left the Master "on" (in ALT position) for 30-40 minutes > while he was working on the plane, and after that he noticed that his ALT > Field enable fuse was blown. It happened to a replacement fuse as well. > > I checked the wiring right to the alternator-- no fault with it unplugged. > I can't measure any shorts to ground on the Alternator pins. > > My theory is the the internal voltage regulator overheated and failed short. > My theory is that it would overheat because there was no airflow and was > providing maximum field current for a long time. > > Has anyone else experienced this or have an alternate diagnosis? > > Thanks, Vern Little > ________________________________________________________________________________
Subject: ELTs
Date: Mar 21, 2008
From: "Dawson-Townsend,Timothy" <tdawson-townsend(at)aurora.aero>
Jose wrote: "I have an Ameriking AK450 ELT (121.5/243.0MHz)" After next January, the satellites are going to stop listening for 121.5 MHz (too many false alerts), and instead only listen for 406 MHz. So you best bet is to buy a new ELT next year. Bob wrote: "On the other side of the coin, the probability that this piece of equipment will be a major contributor to your surviving the unplanned arrival with the earth is low. An article published in one of the journals a couple of years ago cited something much less than 10% of recovery situations where the ELT figured strongly in the success of the operation." The poor performance of 121.5 MHz probably contributes to that. The 406 MHz signal will offer better accuracy at determining your position, and do it faster, too. Remember the accident that spurred closing a loophole that allowed business jets to fly without ELTs: A Learjet with no ELT went down within 30 miles or so of taking off of Lebanon, NH, but due to snow cover and then dense forest, they didn't find it for over a year . . . TDT Tim Dawson-Townsend RV-10 N52KS tdt(at)aurora.aero 617-500-4812 (office) 617-905-4800 (mobile) ________________________________________________________________________________
Date: Mar 21, 2008
Hi Vern, When my battery is low the Plane Power Alt pulls over 4 amps with the master on. I have had it pop my 5amp field breaker. I increased my C/B to 7 amps and haven't had any more problems. Once the engine is running, the currents drops down to less than 1/2 amp on the field line. Regards, Tom Velvick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=171476#171476 ________________________________________________________________________________
Date: Mar 21, 2008
We checked this, and blew 10A fuse immediately. Alternator is kaput. V -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of tomvelvick Sent: March 21, 2008 7:34 AM Subject: AeroElectric-List: Re: Plane Power Alternator Failure (brand new) --> Hi Vern, When my battery is low the Plane Power Alt pulls over 4 amps with the master on. I have had it pop my 5amp field breaker. I increased my C/B to 7 amps and haven't had any more problems. Once the engine is running, the currents drops down to less than 1/2 amp on the field line. Regards, Tom Velvick Read this topic online here: http://forums.matronics.com/viewtopic.php?p=171476#171476 ________________________________________________________________________________
Date: Mar 21, 2008
Subject: Re: ELTs
Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a crash. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is why I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy. --Jose ________________________________________________________________________________
Date: Mar 21, 2008
Subject: Re: ELTs
Good Afternoon Jose, Please understand that I am not an expert on the FARs and I have very little electronic knowledge, but I do have a question concerning your antenna installation. Is it not true that the ELT is a required piece of requirement? Because of that, is it not true that the emission from the ELT must meet some certain standard? The last one that I installed did have specifications concerning the available signal emission. It said the antenna that came with the set OR an antennae that met specified standards must be used before the ELT met the regulatory standards. I realize that many regulations do not apply to OBAM aircraft, but I would not be surprised if the regulations concerning the ELT must be followed. Any thoughts thereon? Happy Skies, Old Bob AKA Bob Siegfried Ancient Aviator 628 West 86th Street Downers Grove, IL 60516 630 985-8502 Stearman N3977A Brookeridge Air Park LL22 In a message dated 3/21/2008 2:59:52 P.M. Central Daylight Time, paula.alvary(at)verizon.net writes: Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a crash. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is why I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy. --Jose **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001) ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Mar 21, 2008
Subject: ELTs
Answer Steve Fossett! Just the chance of the g switch not working, the antenna being ripped off i s enough to push me to the PLB...Ya sure its another chore to set it off... buts its #2 on my emergency list. I also make sure I am talking to ATC when going across the rocks..I just fi le an IFR flight plan because I can, but VFR flight following is as good as long as they will do it for you. I migth also look into an APHRS datalogger at some point. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Palvary Sent: Friday, March 21, 2008 1:54 PM Subject: Re: AeroElectric-List: ELTs Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a cras h. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is w hy I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy. --Jose ________________________________________________________________________________
Date: Mar 21, 2008
Subject: Re: ELTs
>Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a >crash. Not only is it old technology, but in the best scenario it will >probably go undetected for the various reasons that Bob stated. (Case in >point, who knows what direction the antenna will wind up in after a >crash?) That is why I did not go to the extent of doing the antenna in the >best fashion that we know how to do. However, even after emergency >services stop listening, it still meets the FAA requirement for an ELT as >detailed in the recent EAA Sport Aviation article. My question was simply >trying to determine if what I did was next to useless or had a reasonable >chance of radiating some RF energy. Sounds like you have a realistic understanding of the capabilities/limitations for the system. The simple answer is, "yes, the thing will radiate . . . and probably no worse than some less-than-ideal installations found on some certified aircraft." Best yet, it keeps those-who-know-more-about-airplanes- than-we-do at arms length . . . for awhile. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 21, 2008
Subject: ELTs
Oh yes, the 125.5 ELT has to have an RF power output of just 100mW...PLB's (or 406MHz ELTS) have an output of 5W...I.e a 50 times stronger signal...Ap parently the signal even punches through tree cover. Its the emergency equivilent of a big battery drill compared to a screwdriv er...:) frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Hinde, Frank George (Corvallis) Sent: Friday, March 21, 2008 1:16 PM Subject: RE: AeroElectric-List: ELTs Answer Steve Fossett! Just the chance of the g switch not working, the antenna being ripped off i s enough to push me to the PLB...Ya sure its another chore to set it off... buts its #2 on my emergency list. I also make sure I am talking to ATC when going across the rocks..I just fi le an IFR flight plan because I can, but VFR flight following is as good as long as they will do it for you. I migth also look into an APHRS datalogger at some point. Frank ________________________________ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectr ic-list-server(at)matronics.com] On Behalf Of Palvary Sent: Friday, March 21, 2008 1:54 PM Subject: Re: AeroElectric-List: ELTs Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a cras h. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is w hy I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy. --Jose ist">http://www.matronics.com/Navigator?AeroElectric-List ics.com .matronics.com/contribution ________________________________________________________________________________
Subject: ELTs
Date: Mar 21, 2008
I'm not 100% sure, but if you are talking about an Artex ELT, I believe that the TSO covers the unit AND the antenna. If you don't install the correct antenna properly, you won't meet the TSO. And that could lead to an inspection problem. You might want to check the manufacturer's website. Thanks! Bill Denton bdenton(at)bdenton.com From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Palvary Sent: Friday, March 21, 2008 3:54 PM Subject: Re: AeroElectric-List: ELTs Admittedly, my 121.5/243.0MHz ELT offers little insurance in case of a crash. Not only is it old technology, but in the best scenario it will probably go undetected for the various reasons that Bob stated. (Case in point, who knows what direction the antenna will wind up in after a crash?) That is why I did not go to the extent of doing the antenna in the best fashion that we know how to do. However, even after emergency services stop listening, it still meets the FAA requirement for an ELT as detailed in the recent EAA Sport Aviation article. My question was simply trying to determine if what I did was next to useless or had a reasonable chance of radiating some RF energy. --Jose ________________________________________________________________________________
Date: Mar 21, 2008
Subject: ELTs
What was the question?? > Answer Steve Fossett! > > Just the chance of the g switch not working, the antenna being ripped off > is enough to push me to the PLB...Ya sure its another chore to set it > off...buts its #2 on my emergency list. > > I also make sure I am talking to ATC when going across the rocks..I just > file an IFR flight plan because I can, but VFR flight following is as good > as long as they will do it for you. There's a good amount of the western US over which I have flown where the minimum radar altitude is above 11000MSL. The MEA on the route between BOI and TWF is 10000MSL and there aren't any passes to cross; the route can be comfortably flown at 5500 - and not be even slightly close to terrain. Having to climb to 10000 on such a short trip isn't particularly efficient... I agree with the philosophy you are proposing however. > > I migth also look into an APHRS datalogger at some point. > > Frank > Matt- ________________________________________________________________________________
Date: Mar 21, 2008
Subject: Re: ELTs
Hi Bob S., Because of that, is it not true that the emission from the ELT must meet some certain standard? ------A good point worth considering. I do not have an anwer nor meter to check the output. Best I can do for now is just do a tower check on the hour. I do know that my ELT came with a simple (non-loaded) telescoping antenna (which had broken and dissappeared) and I think the solid wire antenna I made is hopefully as good as that one. Eventually, 406MHz and/or APRS is the way to go. --Jose PS-This is the best list ever. Thanks everyone. ________________________________________________________________________________
Subject: Install Manuals
Date: Mar 21, 2008
I am looking for an install manual for the GNS430W. Didn't I see where someone had these manuals on a website somewhere? Thanks, Bill B ________________________________________________________________________________
Date: Mar 22, 2008
Subject: Re: Install Manuals
Bill Bradburry a crit : > > I am looking for an install manual for the GNS430W. Didnt I see where > someone had these manuals on a website somewhere? > Bill, At one time, those manuals were concealed on the Garmin website, but they seem to be unavailable now. The revision M is downloadable from my website : http://contrails.free.fr/download.php Scroll down to "Avionique" then "GPS Garmin series 400" Hope this helps, Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
From: "William Slaughter" <willslau(at)comcast.net>
Date: Mar 21, 2008
Try http://www.mstewart.net/Downloads/howtogetagarminmanual.htm William From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Friday, March 21, 2008 5:50 PM Subject: AeroElectric-List: Install Manuals I am looking for an install manual for the GNS430W. Didn't I see where someone had these manuals on a website somewhere? Thanks, Bill B ________________________________________________________________________________
Date: Mar 22, 2008
William Slaughter a crit : > > Try > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > William and all, Unfortunately Garmin changed their website in order to make their installation manuals no longer readily available to the layman. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Mar 21, 2008
That's not very neighborly. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Gilles Thesee Sent: Friday, March 21, 2008 6:29 PM Subject: Re: AeroElectric-List: Install Manuals <Gilles.Thesee@ac-grenoble.fr> William Slaughter a crit : > > Try > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > William and all, Unfortunately Garmin changed their website in order to make their installation manuals no longer readily available to the layman. Best regards, -- Gilles http://contrails.free.fr ________________________________________________________________________________
Date: Mar 21, 2008
Subject: Re: ELTs
You are correct. All ELTs must meet TSO, and TSO includes antenna spec. Even a different brand antenna for ELT does not meet letter of the law. And yes, it doesn't matter whether experimental or type certified, both are required by reg to have TSOd ELT. Bill Denton wrote: > > Im not 100% sure, but if you are talking about an Artex ELT, I > believe that the TSO covers the unit AND the antenna. If you dont > install the correct antenna properly, you wont meet the TSO. And that > could lead to an inspection problem. > > You might want to check the manufacturers website > > Thanks! > > Bill Denton > > bdenton(at)bdenton.com > > * > > * ________________________________________________________________________________
Date: Mar 21, 2008
Gentlemen all, you are gussing. Call PP & send it back. Get the real reason. PP does modify the regulator & therefore he's the source of creditable facts. I can say a stock ND should not get hot with BAT/ALT on, but I stand to be corrected. I never tried it. However............ For a regular internally regulated ND alternator, if it uses more than 50 millivolts, with the engine shut down you have voltage regulator or diode issue. Internally regulated alternators do not have a FIELD WIRE of course. >From: Ken <klehman(at)albedo.net> >Subject: Re: Plane Power Alternator Failure (brand new) >Would not surprise me Vern. My wee ND IR alternator draws a couple of >amps and heats up quite noticeably with the engine off and the IGN >terminal (and B+ lead) connected to the battery. Fortunately the OV >relay lets me disconnect it by opening the alternator control switch. >Ken Ken is it possible you are reading more than the alternator? Master contactor? --------------------------------- ________________________________________________________________________________
Date: Mar 22, 2008
gmcjetpilot(at)yahoo.com wrote: > Gentlemen all, you are gussing. > > Call PP & send it back. Get the real reason. PP does modify the > regulator & therefore he's the source of creditable facts. I can say > a stock ND should not get hot with BAT/ALT on, but I stand to > be corrected. I never tried it. However............ > > For a regular internally regulated ND alternator, if it uses more than > 50 millivolts, with the engine shut down you have voltage regulator or > diode issue. Internally regulated alternators do not have a FIELD > WIRE of course. > > > >From: Ken <klehman(at)albedo.net <mailto:klehman(at)albedo.net>> > >Subject: Re: Plane Power Alternator Failure (brand > new) > >Would not surprise me Vern. My wee ND IR alternator draws a couple of > >amps and heats up quite noticeably with the engine off and the IGN > >terminal (and B+ lead) connected to the battery. Fortunately the OV > >relay lets me disconnect it by opening the alternator control switch. > >Ken > > Ken is it possible you are reading more than the alternator? Master > contactor? > No It was purchased new about 5 years ago and it always did this. Of course in a car the Ign terminal would not be powered with the key in the off or accessory position. Newer models might sense rotation before they power the field. But apparently this 40 amp unit that often is found on small industrial equipment is not that sophisticated. Ken ps. I assume you meant to type 50 milliamps above. I've never seen anything near that high (yet) but standby parasitic current "leakage" is getting ridiculous on cars these days. ________________________________________________________________________________
Subject: Re: ELTsELTs
Date: Mar 22, 2008
I know that at this time personal locator beacons aren't legal to be used as ELTs. If someone designed an automatic activation system for a PLB, I wonder if a case could be made to "the-guys-who-know-airplanes-better-than-we-do" to use such in lieu of a TSOd ELT in OBAM aircraft? Just thinking (oops, not supposed to do that). Blue skies and tailwinds Jim CH-801 DeltaHawk diesel Augusta GA 90% done, 90% left ________________________________________________________________________________
Date: Mar 22, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
INnn >Gentlemen all, you are gussing. > >Call PP & send it back. Get the real reason. PP does modify the >regulator & therefore he's the source of creditable facts. I can say >a stock ND should not get hot with BAT/ALT on, but I stand to >be corrected. I never tried it. However............ > I can't imagine that ND would not take advantage of the practice for monitoring rotor motion and shutting down field current if the engine is stopped. >For a regular internally regulated ND alternator, if it uses more than >50 millivolts, with the engine shut down you have voltage regulator or >diode issue. Internally regulated alternators do not have a FIELD >WIRE of course. Plane-Power's offerings that include the externally mounted crowbar ov protection have been modified to bring the internal regulator's b-lead feed out side so that one may effectively shut down the alternator from outside. Normally, this does not require modification of the regulator itself (difficult to do . . . it's a hybrid device and usually sealed up). It does require that you open the b-lead feeder to the regulator and bring it outside (relatively easy). We were offered this information by Mr. Steve Klodd at Plain-Power just over a year ago. See: http://www.aeroelectric.com/Mfgr_Data/Alternators/Plane_Power/70129A_Plane-Power_SKlodd.pdf > > > >From: Ken <<mailto:klehman(at)albedo.net>klehman(at)albedo.net> > >Subject: Re: Plane Power Alternator Failure (brand > new) > >Would not surprise me Vern. My wee ND IR alternator draws a couple of > >amps and heats up quite noticeably with the engine off and the IGN > >terminal (and B+ lead) connected to the battery. Fortunately the OV > >relay lets me disconnect it by opening the alternator control switch. > >Ken > >Ken is it possible you are reading more than the alternator? Master contactor? I presume that the internal regulator would still be expected to shut the field down if no rotation were sensed. I'll drop a note to Steve requesting clarification. Bob . . . ----------------------------------------- ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Smoke
Date: Mar 22, 2008
Bob, Today I ran the engine. I was not sure how to make a "hard connection to bypass the control relay" as you suggested. So I just operated the system normally. Minimal load the voltage was initially 11.8 and then went to 11.9 with the master on "alternator". No further change after about three minutes. Looks like I may not be getting alternator input?? As I said, normally I get 13 v. I did not charge the battery before hand. I pulled the covers off (cowling, etc). The relay appears to be undamaged. I don't see any signs that would indicate it was "fried". During the even I was unable to tell exactly where the smoke was actually coming from--just from under the panel. I've ordered another relay. I'll plug it in and see what happens. Any other suggestions? If it's the relay, I'd be happy to send you the old one. Thanks for your help. Frank N5929 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Wednesday, March 19, 2008 11:42 AM Subject: Re: AeroElectric-List: Smoke > >Last evening I experienced smoke in the cockpit of my Kitfox--912S. > >First, I want to thank Bob N for convincing me of the importance of >using Z16, incorporating an E-Bus circuit. Worked great and reduced the >load on my "little" motorcycle battery so that I maintained > 11.5 v for >the 15 min duration of my flt. > >It was twilight & I had Whelan strobe & nav lights on, near max elec >capacity for the 912 generator. I threw on the landing lt to see what >the added load would do to the system. (Probably not a smart move) >Immediately the system voltage, normally runs 13v, began dropping, so I >turned the landing lt off after a few seconds. > >I then began doing a series of steep climbs at slow airspeed. After >about five min I noticed a burning odder, thinking to myself "someone >must be burning trash and I'm in the trail of smoke." After about 30 >seconds I noticed smoke coming from under the instrument panel and a >much stronger burning odder. I dropped the nose of the airplane--no >more smoke. > >At that moment my GRT EIS warning lt flashed and I noticed the system >voltage below 11 v. I turned on the E Bus switch and off on the main. >Voltage came up--12 v I think. No odder or smoke or falling voltage. > >After a few minutes I decided to try the main switch again, pulling in >the battery relay and alternator. Voltage began to climb above 12 v to >about 12.5 v. I added strobe & nav lt again causing an immediate >reversal in voltage trend and warning lt came on again as it plunged >below 11 v. Again I went to E Bus an off main. I landed uneventfully. > >My guess is the relay over heated with the momentary excessive >electrical draw (does that happen?) causing the smoke. Any Ideas? I >assume I need to replace the regulator??? What would you recommend as a >replacement regulator/source. Anything else?????? Do we know exactly where the smoke was coming from? Is the relay visibly damaged or the regulator? The fact that your voltage started to come up when you re-energized the alternator suggests that the rectifier-regulator was not killed. Try making a hard connection to bypass the control relay and do a ground run to see if the bus voltage comes up . . . do this with a fully charged battery so that you don't have to wait for the alternator to top off the battery. If I'm understanding your words, the relay is what failed. I'd like to get my hands on it for examination. I'd be pleased to send you a replacement but I suspect you can find one much faster locally. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 23, 2008
Yes I meant 50 milliamps and you are right with all the memory keep alive, the parasitic drain is high. I travel and have to sometimes disconnect the battery. I have one of those battery disconnect terminals. It's an old car 1990 but it still has a computer, so I lose the codes and fuel injection mapping. But its better than jumping the the thing. I have some small industrial ND's, new genuine
March 04, 2008 - March 23, 2008
AeroElectric-Archive.digest.vol-hr
