AeroElectric-Archive.digest.vol-hs
March 23, 2008 - April 11, 2008
      NipponDenso. I'll test it on mine. Interesting.
      You are right, in a car the IGN is not ON unless the
      driver puts the IGN switch to the IGN position.
      Even the industrial alternators have a "soft start"
      function. The internal VR sense voltage from several
      places internally from the rotor, stator, rectifier and
      externally, b-lead, ign and even a remote voltage sense
      in some models. It does not see RPM, but it sees that
      EMF from the rotation. With internal timers it ramps the
      voltage regulator on. So it probably tickles the field a little
      to get things going, but the ON drain should through the
      IGN lead is always small . I guess 50 milliamps, but it
      may be switching the B-lead drain on. The field voltage
      comes from the b-lead not the IGN lead. The IGN as
      you know is just an WAKE / SLEEP signal.
        I wounder if its a leaky rectifier diode?
      I'll test this. I never checked this. I want to understand
      how the internal VR works. I wonder what an external
      VR does being on for a long time before spinning it?
        >From: Ken <klehman(at)albedo.net>
      >Subject: Re: AeroElectric-List: Re: Plane Power Alternator Failure (brand  new)
      >No It was purchased new about 5 years ago and it always did this.
        >ps. I assume you meant to type 50 milliamps above. I've never seen
      >anything near that high (yet) but standby parasitic current "leakage"
       >is getting ridiculous on cars these days.
      Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it now.
Date: Mar 23, 2008
Subject: Moving a battery
Hello all, We've just completed the second flight of our velocity (http://www.youtube.com/watch?v=DpyMP7GkA-Y), and find that we really are a bit more nose heavy than is really right, so if I want to carry passengers I need to move my battery from the nose to back near the firewall. So, I'm looking at my options, and want some input. My current wiring diagram is here http://www.velocityxl.com/Power/Power_Distribution.htm . Since it's a pusher I already have a full-sized 2 gauge wire running the full length of the airplane for the starter and the ground. My concern is around the battery bus and the ground power, they currently connect directly to the batter contactor's always-hot side with short runs. I don't really want to move these bits, nor do I really want them on the switched-side of the master. However, I'm not tickled with the idea of have a 20' run of always hot 2ga wire either. I thought about putting a 200A ANL current limiter on both ends, since you only *need* to protect the wire, but who am I kidding, only 200A? That's not going to help sleep at night knowing she's in the hangar like that. So, it seems to me that my only *realistic* options are: 1) put the ground power in the back, and fuse the battery bus always-hot at 30A (since it back-feeds the e-bus) with a new 8 gauge or so wire 2) put the ground power on the switched side, and require the master be on to charge the battery (and fuse the battery bus always-hot at 30A, same as #1) 3) ?? Any thoughts and/or suggestions greatly appreciated. Brett ________________________________________________________________________________
Date: Mar 23, 2008
Subject: Re: Install Manuals
Since Gilles offered the 400 manual, I'll just note a few places you can still get other Garmin manuals (not all are available, so the ones I found are listed here) http://www.golfsierra.org/reference/GTX327_install.pdf http://www8.garmin.com/manuals/GTX327Transponder_PilotsGuide.pdf http://www8.garmin.com/manuals/GTX330Transponder_PilotsGuide.pdf http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_PilotsGuide.pdf http://www.velocityxl.com/Downloads/143_InstallationManual.pdf http://www8.garmin.com/manuals/GNS530_PilotsGuide.pdf http://www8.garmin.com/manuals/GNS530_QuickReferenceGuide.pdf http://www8.garmin.com/manuals/GPS400_QuickReferenceGuide.pdf http://www8.garmin.com/manuals/GNS430_QuickReferenceGuide.pdf http://www8.garmin.com/manuals/GNS430_PilotsGuide.pdf http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_QuickReferenceGuide.pdf http://www8.garmin.com/manuals/GPS150XL_PilotsGuide.pdf http://www8.garmin.com/manuals/GPS155XLTSO_PilotsGuide.pdf http://www8.garmin.com/manuals/MX20_QuickReferenceGuide.pdf http://www8.garmin.com/manuals/SL70Transponder_UserGuide.pdf http://www8.garmin.com/manuals/SL15MAudioPanel_SL15OperationManual.pdf http://www8.garmin.com/manuals/SL15MAudioPanel_SL15-CDandCD15OperationManual.pdf http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf http://www8.garmin.com/manuals/GPSMAP196_QuickStartGuide.pdf Brett William Slaughter wrote: > Try > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > > > > William > > > > > > > > *From:* owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > *Bill Bradburry > *Sent:* Friday, March 21, 2008 5:50 PM > *To:* aeroelectric-list(at)matronics.com > *Subject:* AeroElectric-List: Install Manuals > > > > > > I am looking for an install manual for the GNS430W. Didnt I see where > someone had these manuals on a website somewhere? > > > > Thanks, > > Bill B > > * * > > * * > > * * > > ** > > ** > > ** > > ** > > ** > > ** > > *http://www.matronics.com/Navigator?AeroElectric-List* > > ** > > ** > > ** > > *http://forums.matronics.com* > > ** > > ** > > ** > > ** > > *http://www.matronics.com/contribution* > > ** > > * * > > * > > > * > > > > __________ NOD32 2967 (20080321) Information __________ > ________________________________________________________________________________
Date: Mar 23, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Smoke
> >Bob, > >Today I ran the engine. I was not sure how to make a "hard connection >to bypass the control relay" as you suggested. Take the relay out of the circuit. I.e. don't use the relay to control it, just let the alternator be ON all the time. > So I just operated the >system normally. Minimal load the voltage was initially 11.8 and then >went to 11.9 with the master on "alternator". No further change after >about three minutes. Looks like I may not be getting alternator input?? >As I said, normally I get 13 v. It should certainly be higher than 12v . . . the battery delivers energy at 12.5 and below, it gets charged at 13.5 and above. Your normal operating voltage should be around 14.2 to 14.6 volts. What you've described suggests that alternator is either (1) not working due to failed rectifier/regulator or (2) not connected to the system due to a failed relay. >I did not charge the battery before hand. > >I pulled the covers off (cowling, etc). The relay appears to be >undamaged. I don't see any signs that would indicate it was "fried". Hmmmm . . . I've never seen the aftermath of one of these relays going to toast. It has to have happened somewhere, sometime. Even the big guys go up in flames sometimes. See: http://www.aeroelectric.com/Pictures/Contactors/6041_Contactor.jpg http://www.aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg >During the even I was unable to tell exactly where the smoke was >actually coming from--just from under the panel. Where are your regulator and relay mounted? If they're under the cowl I'm wondering how you got smoke from either of these devices . . . the engine and people spaces are supposed to be pretty well isolated from each other. >I've ordered another relay. I'll plug it in and see what happens. Any >other suggestions? Yes, take the relay completely out of the circuit disconnect the two fat wires from the relay and hook them to each other. You can cut a little piece of metal (brass is best but a piece of tin can will work) as shown in: http://www.aeroelectric.com/Pictures/Tools/Test_Equipment/Relay_Bypass_Test.jpg The technique here is "divide and conquer" . . . by taking the relay completely out of the equation, you can quickly find if it can be eliminated from the possible root causes of failure. However, at this stage of the investigation, if you could not see visible damage to the relay, I suspect that it is not root cause. Bob . . . ________________________________________________________________________________
Subject: Install Manuals
Date: Mar 23, 2008
Is there any place to get King manuals? > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Brett Ferrell > Sent: Sunday, March 23, 2008 10:30 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Install Manuals > > > Since Gilles offered the 400 manual, I'll just note a few places you can > still get other Garmin manuals (not all are available, so the ones I > found are listed here) > > http://www.golfsierra.org/reference/GTX327_install.pdf > http://www8.garmin.com/manuals/GTX327Transponder_PilotsGuide.pdf > http://www8.garmin.com/manuals/GTX330Transponder_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_PilotsGuide.pd > f > http://www.velocityxl.com/Downloads/143_InstallationManual.pdf > > http://www8.garmin.com/manuals/GNS530_PilotsGuide.pdf > http://www8.garmin.com/manuals/GNS530_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/GPS400_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_QuickReferen > ceGuide.pdf > > http://www8.garmin.com/manuals/GPS150XL_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPS155XLTSO_PilotsGuide.pdf > > http://www8.garmin.com/manuals/MX20_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/SL70Transponder_UserGuide.pdf > > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15OperationManual.pdf > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15- > CDandCD15OperationManual.pdf > > http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPSMAP196_QuickStartGuide.pdf > > > Brett > > William Slaughter wrote: > > Try > > > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > > > > > > > > William > > > > > > > > > > > > > > > > *From:* owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > > *Bill Bradburry > > *Sent:* Friday, March 21, 2008 5:50 PM > > *To:* aeroelectric-list(at)matronics.com > > *Subject:* AeroElectric-List: Install Manuals > > > > > > > > > > > > I am looking for an install manual for the GNS430W. Didn't I see where > > someone had these manuals on a website somewhere? > > > > > > > > Thanks, > > > > Bill B > > > > * * > > > > * * > > > > * * > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/Navigator?AeroElectric-List* > > > > ** > > > > ** > > > > ** > > > > *http://forums.matronics.com* > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/contribution* > > > > ** > > > > * * > > > > * > > > > > > * > > > > > > > > __________ NOD32 2967 (20080321) Information __________ > > > > > ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Date: Mar 23, 2008
I have a KLN90B POH if you need it. Bill S 7a Ark -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Curry Sent: Sunday, March 23, 2008 11:50 AM Subject: RE: AeroElectric-List: Install Manuals --> Is there any place to get King manuals? > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Brett Ferrell > Sent: Sunday, March 23, 2008 10:30 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Install Manuals > > > Since Gilles offered the 400 manual, I'll just note a few places you > can still get other Garmin manuals (not all are available, so the ones > I found are listed here) > > http://www.golfsierra.org/reference/GTX327_install.pdf > http://www8.garmin.com/manuals/GTX327Transponder_PilotsGuide.pdf > http://www8.garmin.com/manuals/GTX330Transponder_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_PilotsGuide.pd > f > http://www.velocityxl.com/Downloads/143_InstallationManual.pdf > > http://www8.garmin.com/manuals/GNS530_PilotsGuide.pdf > http://www8.garmin.com/manuals/GNS530_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/GPS400_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_QuickRefe > ren > ceGuide.pdf > > http://www8.garmin.com/manuals/GPS150XL_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPS155XLTSO_PilotsGuide.pdf > > http://www8.garmin.com/manuals/MX20_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/SL70Transponder_UserGuide.pdf > > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15OperationManual.pdf > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15- > CDandCD15OperationManual.pdf > > http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPSMAP196_QuickStartGuide.pdf > > > Brett > > William Slaughter wrote: > > Try > > > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > > > > > > > > William > > > > > > > > > > > > > > > > *From:* owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > > *Bill Bradburry > > *Sent:* Friday, March 21, 2008 5:50 PM > > *To:* aeroelectric-list(at)matronics.com > > *Subject:* AeroElectric-List: Install Manuals > > > > > > > > > > > > I am looking for an install manual for the GNS430W. Didn't I see where > > someone had these manuals on a website somewhere? > > > > > > > > Thanks, > > > > Bill B > > > > * * > > > > * * > > > > * * > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/Navigator?AeroElectric-List* > > > > ** > > > > ** > > > > ** > > > > *http://forums.matronics.com* > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/contribution* > > > > ** > > > > * * > > > > * > > > > > > * > > > > > > > > __________ NOD32 2967 (20080321) Information __________ > > > > > ________________________________________________________________________________
Date: Mar 23, 2008
Subject: Re: Moving a battery
> >Hello all, > >We've just completed the second flight of our velocity >(http://www.youtube.com/watch?v=DpyMP7GkA-Y), and find that we really >are a bit more nose heavy than is really right, so if I want to carry >passengers I need to move my battery from the nose to back near the >firewall. So, I'm looking at my options, and want some input. > >My current wiring diagram is here >http://www.velocityxl.com/Power/Power_Distribution.htm . Since it's a >pusher I already have a full-sized 2 gauge wire running the full length >of the airplane for the starter and the ground. My concern is around >the battery bus and the ground power, they currently connect directly to >the batter contactor's always-hot side with short runs. I don't really >want to move these bits, nor do I really want them on the switched-side >of the master. However, I'm not tickled with the idea of have a 20' run >of always hot 2ga wire either. I thought about putting a 200A ANL >current limiter on both ends, since you only *need* to protect the wire, >but who am I kidding, only 200A? That's not going to help sleep at >night knowing she's in the hangar like that. > >So, it seems to me that my only *realistic* options are: >1) put the ground power in the back, and fuse the battery bus always-hot >at 30A (since it back-feeds the e-bus) with a new 8 gauge or so wire That seems to be the best solution. Given that you have dual alternators a-la Z-12, then perhaps an e-bus is overly redundant. Just tie it right to the main bus. If ground power moves aft, then your panel feeders for the main bus and ground can probably drop to 4AWG and move the c.g. still further aft. In fact, with the battery back next to the engine, ALL the fat feeders can drop to 4AWG and recover some empty weight too. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 23, 2008
Which ones do you need? Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Curry Sent: Sunday, March 23, 2008 11:50 AM Subject: RE: AeroElectric-List: Install Manuals Is there any place to get King manuals? > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Brett Ferrell > Sent: Sunday, March 23, 2008 10:30 AM > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: Install Manuals > > > Since Gilles offered the 400 manual, I'll just note a few places you can > still get other Garmin manuals (not all are available, so the ones I > found are listed here) > > http://www.golfsierra.org/reference/GTX327_install.pdf > http://www8.garmin.com/manuals/GTX327Transponder_PilotsGuide.pdf > http://www8.garmin.com/manuals/GTX330Transponder_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_PilotsGuide .pd > f > http://www.velocityxl.com/Downloads/143_InstallationManual.pdf > > http://www8.garmin.com/manuals/GNS530_PilotsGuide.pdf > http://www8.garmin.com/manuals/GNS530_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/GPS400_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_QuickReferenceGuide.pdf > http://www8.garmin.com/manuals/GNS430_PilotsGuide.pdf > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_QuickRefere n > ceGuide.pdf > > http://www8.garmin.com/manuals/GPS150XL_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPS155XLTSO_PilotsGuide.pdf > > http://www8.garmin.com/manuals/MX20_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/SL70Transponder_UserGuide.pdf > > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15OperationManual.pdf > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15- > CDandCD15OperationManual.pdf > > http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf > http://www8.garmin.com/manuals/GPSMAP196_QuickStartGuide.pdf > > > Brett > > William Slaughter wrote: > > Try > > > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > > > > > > > > William > > > > > > > > > > > > > > > > *From:* owner-aeroelectric-list-server(at)matronics.com > > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > > *Bill Bradburry > > *Sent:* Friday, March 21, 2008 5:50 PM > > *To:* aeroelectric-list(at)matronics.com > > *Subject:* AeroElectric-List: Install Manuals > > > > > > > > > > > > I am looking for an install manual for the GNS430W. Didn't I see where > > someone had these manuals on a website somewhere? > > > > > > > > Thanks, > > > > Bill B > > > > * * > > > > * * > > > > * * > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/Navigator?AeroElectric-List* > > > > ** > > > > ** > > > > ** > > > > *http://forums.matronics.com* > > > > ** > > > > ** > > > > ** > > > > ** > > > > *http://www.matronics.com/contribution* > > > > ** > > > > * * > > > > * > > > > > > * > > > > > > > > __________ NOD32 2967 (20080321) Information __________ > > > > > ________________________________________________________________________________
Date: Mar 23, 2008
Subject: UltraLast AA Battery Tests
A few days ago I received some non-mainstream alkaline AA cells to test for capacity. These are sold under the UltraLast brand. Unfortunately, they do not live up to their name. Their performance is plotted against several other brands at: http://www.aeroelectric.com/Pictures/Curves/AA_Battery_Tests_80322.jpg Seems even the Harbor Freight cells will edge out these puppies. Bad value? Depends. They delivered about 80% of the snort that I got from some Duracell branded cells. Sam's club offers bricks of AA Duracells for about 38 cents apiece . . . so if you can buy "UltraLast" or "Battery.com" cells for 80 or less of 38 cents . . . or about 30 cents each, then they could be said to be a good value. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Smoke
Date: Mar 23, 2008
I bypassed the control relay as you suggested, Bob. Started off with voltage matching battery 12.25v and quickly (~15 seconds) climbed to 13v. I then plugged the control relay back in. Immediately got the same 13v. I let the engine warm up (5 min). Then set RPM to 3000. Loaded system with nav lts & strobes and it stayed at 13v. Seems the problem has gone away. . .for the moment???? Not sure what else to check. Wind was a bit high to fly. I'll take it up this week to see what happens. (I checked the battery before hand and it was 12.25 v. After all the testing it was 12.85v) I'll come up on the net again if I have additional problems--even if I can figure it out I'll let you know. Thanks Frank N5929 -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, March 23, 2008 12:00 PM Subject: RE: AeroElectric-List: Smoke > >Bob, > >Today I ran the engine. I was not sure how to make a "hard connection >to bypass the control relay" as you suggested. Take the relay out of the circuit. I.e. don't use the relay to control it, just let the alternator be ON all the time. > So I just operated the >system normally. Minimal load the voltage was initially 11.8 and then >went to 11.9 with the master on "alternator". No further change after >about three minutes. Looks like I may not be getting alternator input?? >As I said, normally I get 13 v. It should certainly be higher than 12v . . . the battery delivers energy at 12.5 and below, it gets charged at 13.5 and above. Your normal operating voltage should be around 14.2 to 14.6 volts. What you've described suggests that alternator is either (1) not working due to failed rectifier/regulator or (2) not connected to the system due to a failed relay. >I did not charge the battery before hand. > >I pulled the covers off (cowling, etc). The relay appears to be >undamaged. I don't see any signs that would indicate it was "fried". Hmmmm . . . I've never seen the aftermath of one of these relays going to toast. It has to have happened somewhere, sometime. Even the big guys go up in flames sometimes. See: http://www.aeroelectric.com/Pictures/Contactors/6041_Contactor.jpg http://www.aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg >During the even I was unable to tell exactly where the smoke was >actually coming from--just from under the panel. Where are your regulator and relay mounted? If they're under the cowl I'm wondering how you got smoke from either of these devices . . . the engine and people spaces are supposed to be pretty well isolated from each other. >I've ordered another relay. I'll plug it in and see what happens. Any >other suggestions? Yes, take the relay completely out of the circuit disconnect the two fat wires from the relay and hook them to each other. You can cut a little piece of metal (brass is best but a piece of tin can will work) as shown in: http://www.aeroelectric.com/Pictures/Tools/Test_Equipment/Relay_Bypass_T est.jpg The technique here is "divide and conquer" . . . by taking the relay completely out of the equation, you can quickly find if it can be eliminated from the possible root causes of failure. However, at this stage of the investigation, if you could not see visible damage to the relay, I suspect that it is not root cause. Bob . . . ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: TNC Vs BNC
Date: Mar 23, 2008
Other than the obvious $20 each, what is the difference between TNC connectors and BNC connectors? Why do I want to spend that much more for the connectors? Other than they are required by Garmin on the GNS430W reason?? Bill B ________________________________________________________________________________
Subject: What to do with old batteries?
Date: Mar 23, 2008
Listers, I've replaced w/new the Odyssey PC 535 in my Z-11 supported kitfox. I'm extremely happy with my airplane, but I abused the battery pretty bad - lost confidence in it when she wouldn't start or even excite the alternator field after 4 weeks of sitting. Since then it held a trickle charge and worked fine until my new battery came in. I would think the battery is fine for a motorcycle or another application but can't even give it away on Craig's list. Any suggestions? What do you do with your old batteries? Thanks, Grant Krueger Read this topic online here: http://forums.matronics.com/viewtopic.php?p=172130#172130 ________________________________________________________________________________
Date: Mar 24, 2008
Just off the top of my head: KX-155, KX-165, KN-63, KLX-135A, KR-87, KT-76A, KA-39, kma-24. There are probably others. Don > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of William Gill > Sent: Sunday, March 23, 2008 8:28 PM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Install Manuals > > > Which ones do you need? > > Bill > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don > Curry > Sent: Sunday, March 23, 2008 11:50 AM > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: Install Manuals > > > > Is there any place to get King manuals? > > > -----Original Message----- > > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list- > > server(at)matronics.com] On Behalf Of Brett Ferrell > > Sent: Sunday, March 23, 2008 10:30 AM > > To: aeroelectric-list(at)matronics.com > > Subject: Re: AeroElectric-List: Install Manuals > > > > > > > Since Gilles offered the 400 manual, I'll just note a few places you > can > > still get other Garmin manuals (not all are available, so the ones I > > found are listed here) > > > > http://www.golfsierra.org/reference/GTX327_install.pdf > > http://www8.garmin.com/manuals/GTX327Transponder_PilotsGuide.pdf > > http://www8.garmin.com/manuals/GTX330Transponder_PilotsGuide.pdf > > > > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_PilotsGuide > .pd > > f > > http://www.velocityxl.com/Downloads/143_InstallationManual.pdf > > > > http://www8.garmin.com/manuals/GNS530_PilotsGuide.pdf > > http://www8.garmin.com/manuals/GNS530_QuickReferenceGuide.pdf > > > > http://www8.garmin.com/manuals/GPS400_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/GNS430_QuickReferenceGuide.pdf > > http://www8.garmin.com/manuals/GNS430_PilotsGuide.pdf > > > > > http://www8.garmin.com/manuals/CNX80IntegratedAvionicsSystem_QuickRefere > n > > ceGuide.pdf > > > > http://www8.garmin.com/manuals/GPS150XL_PilotsGuide.pdf > > http://www8.garmin.com/manuals/GPS155XLTSO_PilotsGuide.pdf > > > > http://www8.garmin.com/manuals/MX20_QuickReferenceGuide.pdf > > > > http://www8.garmin.com/manuals/SL70Transponder_UserGuide.pdf > > > > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15OperationManual.pdf > > http://www8.garmin.com/manuals/SL15MAudioPanel_SL15- > > CDandCD15OperationManual.pdf > > > > http://www8.garmin.com/manuals/GPSMAP196_PilotsGuide.pdf > > http://www8.garmin.com/manuals/GPSMAP196_QuickStartGuide.pdf > > > > > > Brett > > > > William Slaughter wrote: > > > Try > > > > > > http://www.mstewart.net/Downloads/howtogetagarminmanual.htm > > > > > > > > > > > > William > > > > > > > > > > > > > > > > > > > > > > > > *From:* owner-aeroelectric-list-server(at)matronics.com > > > [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of > > > *Bill Bradburry > > > *Sent:* Friday, March 21, 2008 5:50 PM > > > *To:* aeroelectric-list(at)matronics.com > > > *Subject:* AeroElectric-List: Install Manuals > > > > > > > > > > > > > > > > > > I am looking for an install manual for the GNS430W. Didn't I see > where > > > someone had these manuals on a website somewhere? > > > > > > > > > > > > Thanks, > > > > > > Bill B > > > > > > * * > > > > > > * * > > > > > > * * > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > *http://www.matronics.com/Navigator?AeroElectric-List* > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > *http://forums.matronics.com* > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > ** > > > > > > *http://www.matronics.com/contribution* > > > > > > ** > > > > > > * * > > > > > > * > > > > > > > > > * > > > > > > > > > > > > __________ NOD32 2967 (20080321) Information __________ > > > > > > > > > > > > > > > > > > ________________________________________________________________________________
Subject: Re: What to do with old batteries?
Date: Mar 24, 2008
Where are you located? I need a new battery for my motorcycle. Dale ----- Original Message ----- From: "tinnemaha" <tinnemaha(at)hotmail.com> Sent: Monday, March 24, 2008 1:00 AM Subject: AeroElectric-List: What to do with old batteries? > > > Listers, > > I've replaced w/new the Odyssey PC 535 in my Z-11 supported kitfox. I'm > extremely happy with my airplane, but I abused the battery pretty bad - > lost confidence in it when she wouldn't start or even excite the > alternator field after 4 weeks of sitting. Since then it held a trickle > charge and worked fine until my new battery came in. > > I would think the battery is fine for a motorcycle or another application > but can't even give it away on Craig's list. Any suggestions? What do > you do with your old batteries? > > Thanks, > > Grant Krueger > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=172130#172130 > > > ________________________________________________________________________________
Date: Mar 24, 2008
I put my old Odyssey batteries in riding lawnmowers and my standby generator starting circuit and also in amateur radio field service ("picnic table portable") until they completely give up (which is long after they've spent 2-3 years in the plane, then off to the recyclers. They have several lives that way. -Bill B On Mon, Mar 24, 2008 at 1:00 AM, tinnemaha wrote: > tinnemaha(at)hotmail.com> > > Listers, > > I've replaced w/new the Odyssey PC 535 in my Z-11 supported kitfox. I'm > extremely happy with my airplane, but I abused the battery pretty bad - lost > confidence in it when she wouldn't start or even excite the alternator field > after 4 weeks of sitting. Since then it held a trickle charge and worked > fine until my new battery came in. > > I would think the battery is fine for a motorcycle or another application > but can't even give it away on Craig's list. Any suggestions? What do you > do with your old batteries? > > Thanks, > > Grant Krueger > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=172130#172130 > > ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Re: TNC Vs BNC
> > > Other than the obvious $20 each, what is the difference between TNC >connectors and BNC connectors? > >Why do I want to spend that much more for the connectors? Other than they >are required by Garmin on the GNS430W reason?? One is threaded, one is bayonet lock. Both perform as advertised. Connectors are like laundry soap. There are what appears to be dozens of brands . . . most mfg by a handful of companies. Is one soap markedly better than another . . . maybe but it's hard to tell sometimes. Take a look at: http://www.baproducts.com/rf-conn.htm This is but a small sample of the range from which one might select coax connectors. Aboard aircraft, there are few reasons to depart from RG400 coax and BNC connectors . . . but there's no accounting for taste. As to the $20 TNC connector, shop around a bit. There's no reason to pay that much for a TNC connector. See: http://tinyurl.com/2g5t6l Also, if you have a case where your installing a new device having a TNC and it replaced similar device with a BNC, you can use an adapter like: http://www.mpja.com/prodinfo.asp?number=0578+RC Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 24, 2008
Whenever I hear, "Moving a Battery," my ears perk up. Stein sells the Perihelion Design Super-2-CCA that not only will remove some weight (It's lower weight per foot than copper 4 AWG but has a much lower resistance than silver 2 AWG). SteinAir sells it. Contact them. I still sell the Super-4-CCA, but I will transfer it to Stein when my spool is empty. -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=172173#172173 ________________________________________________________________________________
Date: Mar 24, 2008
> >Listers, > >I've replaced w/new the Odyssey PC 535 in my Z-11 supported kitfox. I'm >extremely happy with my airplane, but I abused the battery pretty bad - >lost confidence in it when she wouldn't start or even excite the >alternator field after 4 weeks of sitting. Since then it held a trickle >charge and worked fine until my new battery came in. > >I would think the battery is fine for a motorcycle or another application >but can't even give it away on Craig's list. Any suggestions? What do >you do with your old batteries? If the battery has any usable CAPACITY left, here are a couple of things you can do that are outside the normal second-life options for batteries pulled from service in aircraft: http://www.aeroelectric.com/Pictures/Battery/Battery_Second_Life.jpg The battery the light bulb on it was an instrumentation battery that fell to less than 75% of it's new capacity. I had a garage sale derelict headlamp bulb. Forget the number but it only draws 2.5 amps. I glued it to the top of the battery, added a fuse and switch and I've got a big honk'n flashlight that will deliver useful light output for more than 8 hours on a charge. The other battery was new (32 a.h.) about 5 years ago. It's got a 300 watt inverter Velcroed to the top and a tape-handle. I use it when I need to run my instrumentation package in an airplane where access to ship's power is hard to get at. It's been deep cycled perhaps a dozen times. I cap checked it last week at 8A drain (100W) and it's still within a few percent of its new capacity. I won't be making a flashlight out of this one soon. If I were a betting man, I'd wager that the battery you describe is pretty well shot. If it won't crank your engine unless it comes off a fresh top-off charge, it's internal resistance is too high to be useful for anything practical. I use the local Batteries-R-Us store to put my used up batteries into the recycle stream. If you don't have one handy, any store that sells car batteries has a scrap-lead pile to which you can contribute your dead lead. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Smoke
> >I bypassed the control relay as you suggested, Bob. Started off with >voltage matching battery 12.25v and quickly (~15 seconds) climbed to >13v. > >I then plugged the control relay back in. Immediately got the same 13v. > >I let the engine warm up (5 min). Then set RPM to 3000. Loaded system >with nav lts & strobes and it stayed at 13v. > >Seems the problem has gone away. . .for the moment???? Not sure what >else to check. > >Wind was a bit high to fly. I'll take it up this week to see what >happens. > > (I checked the battery before hand and it was 12.25 v. After all the >testing it was 12.85v) > >I'll come up on the net again if I have additional problems--even if I >can figure it out I'll let you know. Hmmmm . . . watch your votlage in flight. If it doesn't get to something over 13.8 volts after you've been flying for awhile you need to investigate. Try running minimum loads. Everything OFF for awhile. Do you have a smart charger? Like: http://tinyurl.com/2z2zta or http://tinyurl.com/29f2qp You need to make sure that you have a topped-off battery before you start a test flight. One of these critters will do the job. Then within say 30 minutes after takeoff, your bus voltage should be just over 14 volts. If not, your regulator is set too low and you're not going to fully charge your battery. Bob . . . ________________________________________________________________________________
Date: Mar 24, 2008
From: "nauga(at)brick.net" <dhyde01(at)earthlink.net>
Subject: Audio iso amp board received!
A week or so ago I posted here to get Bob N's attention re: his audio isolation amp 'project' board. Bob, I received the board on Saturday and all is well. I'm happy with the outcome and your response more than makes up for the issue I originally posted about. Thanks for the extra service! Dave 'Nauga' Hyde ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Re: Audio iso amp board received!
> > >A week or so ago I posted here to get Bob N's attention re: his audio >isolation amp >'project' board. Bob, I received the board on Saturday and all is >well. I'm happy >with the outcome and your response more than makes up for the issue I >originally >posted about. Thanks for the extra service! My pleasure sir. I think I need to go get a job. This retirement thing is taking up too much time. I found the misplaced boards so there's now a bucket full in stock. I need to update the DIY package and put them back up on the website. Hmmmm . . . maybe we should turn this into a plug-n-play product. I looked through the order records and we've sold 50 bare boards over the past 4 years. Now if we could just order up 36 hour days . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 24, 2008
I want to thank everyone for the excellent response to my request for a copy of the GNS430W install manual. I now have a copy of revisions A, B, and C. If anyone wants to upgrade their copy, please let me know. Thanks, Bill B ________________________________________________________________________________
Date: Mar 24, 2008
> > My pleasure sir. I think I need to go get a job. This retirement > thing is taking up too much time. I found the misplaced boards so > there's now a bucket full in stock. I need to update the > DIY package and put them back up on the website. > > Hmmmm . . . maybe we should turn this into a plug-n-play > product. I looked through the order records and we've sold > 50 bare boards over the past 4 years. Now if we could just > order up 36 hour days . . . > > Bob . . . If you put out a critter which mixes several audio warnings (I need some 6 or 7) with stereo music into one double out line to connect to the Intercom, consider me your next client Carlos ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Rotax 582 Starter Problem?
All, Can a starter short a battery? This happened on my Ford van and now I think it's happened to my Rotax 582. (Battery appears OK, no start, battery stone dead. How did I know the starter failed on the Ford Van? Easy, first I replaced the batteries, it wouldn't start, then I replaced the starter. The starter fixed it.) Today upon start the Rotax starter engaged for maybe 1/2 second then died. Upon an attempted re-start all I got was a weak solenoid click and the battery was down to 9.7 volts. As of Saturday afternoon the battery was 13 volts and I had left nothing on since then. (I do not know the voltage when I tried to start, but it was definitely not 9.7 volts as the 1/2 engagement was much more energetic than the subsequent clicks.) I have been fighting a cold engine weak start for the past few months, assuming it was ground issues. I had reworked the ground system and replaced the battery to no avail. First, what fails in the starter to dead short the battery? Is there any way to diagnose the starter before I remove it? (Resistance checks, etc.) Can I rebuild the starter? Finally, anybody know if a 912 starter will work on the 582? (I'm interested in the Sky-Tec starter.) Thanks, Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Mar 24, 2008
IMHO, the KX-145 is worthless for anything more than a paperweight. Weakest transmit power I've ever heard in a production radio, worse than the original Escort 110. raymondj wrote: > > > Please add KX-145 to the list. > > Thanks, > Raymond Julian > Kettle River, MN ________________________________________________________________________________
Date: Mar 24, 2008
From: Dennis Golden <dgolden@golden-consulting.com>
Subject: Re: UltraLast AA Battery Tests
Robert L. Nuckolls, III wrote: > > > A few days ago I received some non-mainstream alkaline AA > cells to test for capacity. > > These are sold under the UltraLast brand. Unfortunately, > they do not live up to their name. Their performance is > plotted against several other brands at: > > http://www.aeroelectric.com/Pictures/Curves/AA_Battery_Tests_80322.jpg > > Seems even the Harbor Freight cells will edge out these > puppies. Bad value? Depends. > > They delivered about 80% of the snort that I got from > some Duracell branded cells. Sam's club offers bricks > of AA Duracells for about 38 cents apiece . . . so if > you can buy "UltraLast" or "Battery.com" cells for 80 > or less of 38 cents . . . or about 30 cents each, then > they could be said to be a good value. Thanks Bob, Fry's normal price is 100 pack at $19.99. I bought them on sale for $14.99. Dennis > Bob . . . > -- Dennis Golden Golden Consulting Services, Inc. ________________________________________________________________________________
Date: Mar 24, 2008
><dgolden@golden-consulting.com> > > > > > They delivered about 80% of the snort that I got from > > some Duracell branded cells. Sam's club offers bricks > > of AA Duracells for about 38 cents apiece . . . so if > > you can buy "UltraLast" or "Battery.com" cells for 80% > > or less of 38 cents . . . or about 30 cents each, then > > they could be said to be a good value. > >Thanks Bob, > >Fry's normal price is 100 pack at $19.99. I bought them on sale for $14.99. > >Dennis Okay. I think you got your money's worth and then some! The very worst cells I ever tested were some obscure brand offered for a short time at O'Rileys's autoparts. I think I bought a small brick of 36 cells for $6.00 and they contained about 70% that of a hot-shot, name-brand product. But at 17 cents each, they were still a good value for energy contained as long as you can live with more frequent replacement. That reminds me, I should test some of those "heavy duty" carbon zinc cells that still seem to grace the shelves of some stores for pretty cheap. I'll pick some up next time I see them. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: B&C SD-20 and magnetic interference
Date: Mar 25, 2008
Hi, We have been running for about 20 hours now chasing different problems. One outstanding one is magnetic interference from the SD-20 / LR3 combination. We have a TSO'd vertical card compass (and yes it is a southern hemisphere model) mounted in the middle of the panel area (center/center). We are dual alt / dual bus configuration. When the field wire is connected to the SD-20 (lower connection) we get up to 40 degree swing on the compass - it does vary in amount (from 20-40 degrees) based on direction - south seems the worst. Pulling the field breaker causes it swings back about 30 degrees, but the regulator / alt are still have an affect. B&C are saying some swing is 'normal' - but 40 degrees - I'm struggling! I can't calibrate that much out (best effort so far is +- 15 degrees). I've tried changing the location / orientation of the regulator - no difference. I've tried moving another wet compass around the panel / cockpit - it looks like same problem (although a bit hard to tell). I've tried running some grounded braid around the firewall forward side of the field wire - no change. Same symptoms on ground, air, zero RPM and full power. There may be a small movement (< 3 degrees) based on current draw from SD-20. With SD-20 field disconnected and X-Feed in - no movement. Questions: a) Have others got this / solved this? b) Any suggested methods of screening the SD-20? Thanks, Carl -- Carl Morgan - ZK-VII - RV 7A http://www.rvproject.gen.nz/ Checked by AVG. 15:03 ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Re: Rotax 582 Starter Problem?
> >All, > Can a starter short a battery? This happened on my Ford van and > now I think it's happened to my Rotax 582. (Battery appears OK, no start, > battery stone dead. How did I know the starter failed on the Ford Van? > Easy, first I replaced the batteries, it wouldn't start, then I replaced > the starter. The starter fixed it.) > Today upon start the Rotax starter engaged for maybe 1/2 second > then died. Upon an attempted re-start all I got was a weak solenoid click > and the battery was down to 9.7 volts. As of Saturday afternoon the > battery was 13 volts and I had left nothing on since then. (I do not know > the voltage when I tried to start, but it was definitely not 9.7 volts as > the 1/2 engagement was much more energetic than the subsequent clicks.) I > have been fighting a cold engine weak start for the past few months, > assuming it was ground issues. I had reworked the ground system and > replaced the battery to no avail. > First, what fails in the starter to dead short the battery? Is > there any way to diagnose the starter before I remove it? (Resistance > checks, etc.) Can I rebuild the starter? Finally, anybody know if a 912 > starter will work on the 582? (I'm interested in the Sky-Tec starter.) There's not really enough data to tell the whole story. Starters can fail to work for a host of reasons that include failed battery, loose connections, failed starter contactor, worn brushes in starter and even shorted windings in starter. Killer starters are pretty rare. Modern insulations and assembly techniques make for pretty robust motors even if they're at the bottom of the price structure for similar products. Try these tests: Pull your battery lead terminals off, brighten up with wire brush, grease with Vaseline and reassemble with max recommended torque on fittings. Make sure your battery is topped off. If you don't own a Battery Tender or similar device . . . http://www.aeroelectric.com/Pictures/Battery/Chargers/Schumacher_1562.jpg http://www.aeroelectric.com/Pictures/Battery/Chargers/Battery_Tender_Jr.jpeg http://www.aeroelectric.com/Pictures/Tools/Battery_Chargers/Battery_Minder.jpg http://www.aeroelectric.com/Pictures/Tools/Battery_Chargers/Battery_Tender_Plus.jpg . . . now would be a good time to acquire one. Walmart used to handle the Schumacher 1562 for about $20. An excellent buy. If you have access to a battery load tester . . . http://www.aeroelectric.com/Pictures/Tools/Battery_Testers/HF_Carbon_Pile_Load.jpg http://www.remybattery.com/images/products/Autometer_Tester_SB-3_LG.jpg Load your topped off battery until its terminal voltage falls to 9 volts and hold that voltage for 15 seconds. At the end of 15 seconds, the ammeter should be showing over 300 amps. Perhaps a service station would test your battery. A Batteries- R-Us store certainly would. If you've eliminated the battery as a possible root cause, then it's time to dig through the rest of the system. Check the terminal voltage at the starter while cranking. 8V is about the minimum and if your battery is in good shape and close to the engine, 9+ volts would not be unexpected. If lower, check voltage drop across starter and battery contactors while cranking. If you haven't made up 20' clip leads for your voltmeter, now would be a good time to do it. I have a couple of long lead-sets for my multimeters that allow me to clip onto remote devices and take readings while sitting in the pilots seat. If all the battery, wiring, connections and contactors are good, then it's time to scrutinize the starter more closely. An inductive ammeter like http://www.aeroelectric.com/Pictures/Tools/Test_Equipment/Snap-On_Inductive_Ammeters.jpg is really handy for getting a quick look-see at current flowing in a wire without disconnecting it. The ammeters shown are sold by Snap-On in a set of two for about $60. On goes to 600A for starters, the other to 100A for alternators. If your starter is 'killing' batteries, it's cranking draw will be really high for your size engine. Normally, I wouldn't expect to see more than 150 amps. In all likelihood, your battery is simply gone south with loose connections or bad switching running in second place. The foregoing suggests that with some measurements, it's pretty easy to tell what needs to be done before you get out the wrenches or go into the swaptronics mode of troubleshooting. Bob . . . ________________________________________________________________________________
Date: Mar 24, 2008
> > > > > > > My pleasure sir. I think I need to go get a job. This retirement > > thing is taking up too much time. I found the misplaced boards so > > there's now a bucket full in stock. I need to update the > > DIY package and put them back up on the website. > > > > Hmmmm . . . maybe we should turn this into a plug-n-play > > product. I looked through the order records and we've sold > > 50 bare boards over the past 4 years. Now if we could just > > order up 36 hour days . . . > > > > Bob . . . > > >If you put out a critter which mixes several audio warnings (I need some 6 >or 7) with stereo music into one double out line to connect to the Intercom, >consider me your next client I've got some design notes and did a quick guess at a footprint for a device such as you've described. It would have multi-turn potentiometers right on the board for each input too. It would be about a 2 x 3" fooprint and a 25-pin d-sub connector for input/output connections. I'll keep praying over it but I've got 4-5 new products much closer to completion that need to get up on the website first. Bob . . . ________________________________________________________________________________
Subject: KX-145 performance
Date: Mar 24, 2008
Kelly, I'm sorry to hear that. What were the circumstances where you had the poor performance. I'll be sure to have a good bench test and tune done and try it out before I think about installing it. Thanks for sharing your experience. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Monday, March 24, 2008 2:15 PM Subject: Re: AeroElectric-List: Install Manuals > > > IMHO, the KX-145 is worthless for anything more than a paperweight. > Weakest transmit power I've ever heard in a production radio, worse than > the original Escort 110. > > raymondj wrote: >> >> >> Please add KX-145 to the list. >> >> Thanks, >> Raymond Julian >> Kettle River, MN > > > -- > Date: 3/23/2008 6:50 PM > > ________________________________________________________________________________
Date: Mar 24, 2008
Subject: Re: KX-145 performance
I was a controller in a tower where several planes were equipped with them. Had to turn up volume and listen closely when they were flying. However, could have been just a very poor installation, like in a fabric plane without proper ground plane, as I know that with good install and antenna, 1 watt is plenty. For all I know, they all could have been installed by same shop making same mistakes. I hope you have much better results. Of course that is also a really old radio, probably at least 20 years. raymondj wrote: > > > Kelly, > > I'm sorry to hear that. What were the circumstances where you had > the poor performance. I'll be sure to have a good bench test and tune > done and try it out before I think about installing it. Thanks for > sharing your experience. > > Raymond Julian > Kettle River, MN > > "Hope for the best, > but prepare for the worst." > > ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> > To: > Sent: Monday, March 24, 2008 2:15 PM > Subject: Re: AeroElectric-List: Install Manuals > > >> >> >> IMHO, the KX-145 is worthless for anything more than a paperweight. >> Weakest transmit power I've ever heard in a production radio, worse >> than the original Escort 110. >> >> raymondj wrote: >>> >>> >>> Please add KX-145 to the list. >>> >>> Thanks, >>> Raymond Julian >>> Kettle River, MN >> >> >> >> >> >> >> >> >> >> -- >> Date: 3/23/2008 6:50 PM >> >> > > ________________________________________________________________________________
Date: Mar 24, 2008
Hello Bill, Please forward the latest 430W revision...thanks. Bill RV-7 N151WP Lee's Summit, MO -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Monday, March 24, 2008 12:09 PM Subject: RE: AeroElectric-List: Install Manuals I want to thank everyone for the excellent response to my request for a copy of the GNS430W install manual. I now have a copy of revisions A, B, and C. If anyone wants to upgrade their copy, please let me know. Thanks, Bill B ________________________________________________________________________________
Date: Mar 24, 2008
Well...., the price was right. I'll be day VFR with a portable backup, if I use it at all. Thanks for the info. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Monday, March 24, 2008 6:58 PM Subject: Re: AeroElectric-List: KX-145 performance > > > I was a controller in a tower where several planes were equipped with > them. Had to turn up volume and listen closely when they were flying. > However, could have been just a very poor installation, like in a fabric > plane without proper ground plane, as I know that with good install and > antenna, 1 watt is plenty. For all I know, they all could have been > installed by same shop making same mistakes. > I hope you have much better results. Of course that is also a really old > radio, probably at least 20 years. > > raymondj wrote: >> >> >> Kelly, >> >> I'm sorry to hear that. What were the circumstances where you had the >> poor performance. I'll be sure to have a good bench test and tune done >> and try it out before I think about installing it. Thanks for sharing >> your experience. >> >> Raymond Julian >> Kettle River, MN >> >> "Hope for the best, >> but prepare for the worst." >> >> ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> >> To: >> Sent: Monday, March 24, 2008 2:15 PM >> Subject: Re: AeroElectric-List: Install Manuals >> >> >>> >>> >>> IMHO, the KX-145 is worthless for anything more than a paperweight. >>> Weakest transmit power I've ever heard in a production radio, worse than >>> the original Escort 110. >>> >>> raymondj wrote: >>>> >>>> >>>> Please add KX-145 to the list. >>>> >>>> Thanks, >>>> Raymond Julian >>>> Kettle River, MN >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> -- >>> Date: 3/23/2008 6:50 PM >>> >>> >> >> >> >> > > > -- > Date: 3/23/2008 6:50 PM > > ________________________________________________________________________________
Date: Mar 25, 2008
Date: Mar 24, 2008
The KX 145 is at least 30 years old and the install manual is available only through ATP (Aircraft Technical Publications, phone 415-330-9500). Bill -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of raymondj Sent: Monday, March 24, 2008 8:24 PM Subject: Re: AeroElectric-List: KX-145 performance Well...., the price was right. I'll be day VFR with a portable backup, if I use it at all. Thanks for the info. Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." ----- Original Message ----- From: "Kelly McMullen" <kellym(at)aviating.com> Sent: Monday, March 24, 2008 6:58 PM Subject: Re: AeroElectric-List: KX-145 performance > > > I was a controller in a tower where several planes were equipped with > them. Had to turn up volume and listen closely when they were flying. > However, could have been just a very poor installation, like in a fabric > plane without proper ground plane, as I know that with good install and > antenna, 1 watt is plenty. For all I know, they all could have been > installed by same shop making same mistakes. > I hope you have much better results. Of course that is also a really old > radio, probably at least 20 years. > > raymondj wrote: >> >> >> Kelly, >> >> I'm sorry to hear that. What were the circumstances where you had the >> poor performance. I'll be sure to have a good bench test and tune done >> and try it out before I think about installing it. Thanks for sharing >> your experience. >> >> Raymond Julian >> Kettle River, MN >> >> "Hope for the best, >> but prepare for the worst." >> >> ----- Original Message ----- From: "Kelly McMullen" >> To: >> Sent: Monday, March 24, 2008 2:15 PM >> Subject: Re: AeroElectric-List: Install Manuals >> >> >>> >>> >>> IMHO, the KX-145 is worthless for anything more than a paperweight. >>> Weakest transmit power I've ever heard in a production radio, worse than >>> the original Escort 110. >>> >>> raymondj wrote: >>>> >>>> >>>> Please add KX-145 to the list. >>>> >>>> Thanks, >>>> Raymond Julian >>>> Kettle River, MN >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> -- >>> Date: 3/23/2008 6:50 PM >>> >>> >> >> >> >> > > > -- > Date: 3/23/2008 6:50 PM > > ________________________________________________________________________________
Subject: Smoke
Date: Mar 24, 2008
Bob Is there a way to adjust the DUCATI voltage regulator? Frank -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, March 24, 2008 9:30 AM Subject: RE: AeroElectric-List: Smoke > >I bypassed the control relay as you suggested, Bob. Started off with >voltage matching battery 12.25v and quickly (~15 seconds) climbed to >13v. > >I then plugged the control relay back in. Immediately got the same 13v. > >I let the engine warm up (5 min). Then set RPM to 3000. Loaded system >with nav lts & strobes and it stayed at 13v. > >Seems the problem has gone away. . .for the moment???? Not sure what >else to check. > >Wind was a bit high to fly. I'll take it up this week to see what >happens. > > (I checked the battery before hand and it was 12.25 v. After all the >testing it was 12.85v) > >I'll come up on the net again if I have additional problems--even if I >can figure it out I'll let you know. Hmmmm . . . watch your votlage in flight. If it doesn't get to something over 13.8 volts after you've been flying for awhile you need to investigate. Try running minimum loads. Everything OFF for awhile. Do you have a smart charger? Like: http://tinyurl.com/2z2zta or http://tinyurl.com/29f2qp You need to make sure that you have a topped-off battery before you start a test flight. One of these critters will do the job. Then within say 30 minutes after takeoff, your bus voltage should be just over 14 volts. If not, your regulator is set too low and you're not going to fully charge your battery. Bob . . . ________________________________________________________________________________
Subject: DME/Transponder Suppression
Date: Mar 24, 2008
When a KT-76A transponder and a KN-63 DME are installed in an aircraft, and the two units are connected via suppression circuitry built into both units, is it necessary to comply with the requirement for there to be 6-foot spacing between the two antennae? I can't find an exception to this rule in the install manual for either unit, yet I understand the suppression circuit is designed to keep each unit from receiving the other unit's transmission. So, why should it matter how close the antennae are to eachother? Thanks, Don ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Subject: S700-2-1 wiring
Date: Mar 25, 2008
Bob or any other electrical wizard... Used a S700-2-1 DPDT on-off-on switch to wire my avionics master switch to include panel lights for 'main bus' and 'bat bus'. wired it like this: #3 bat bus & light post #4 light post #2 avionics bus #5 grnd #1 main bus & light post #6 light post When I toggle 'bat bus' instruments come on - no light When I toggle 'off' - everything off When I toggle 'main bus' - everything off When I turn master switch on(battery Cessna Split Switch) 'bat bus' instruments come on - no light 'off' - everything off 'main bus' instruments on - no light What am I doing wrong to get no lights? New switch from B&C. Lights from B&C 12V - Lights work-checked separately direct to battery. Thanks in advance. Mike H 9A/8A ________________________________________________________________________________
Date: Mar 24, 2008
At 03:00 PM 3/24/2008, you wrote: >In all likelihood, your battery is simply gone south > with loose connections or bad switching running in > second place. The foregoing suggests that with some > measurements, it's pretty easy to tell what needs to > be done before you get out the wrenches or go into > the swaptronics mode of troubleshooting. Bob, You were right, the battery had suddenly and inexplicably gone south. When jumped with an enormous RV battery the 582 still had a difficult time starting, but it started. The dead battery wouldn't accept a charge, (measured by the load meter,) so I guess it was well and truly dead. I tried jumping from various locations, eliminating various wires, and the engine started slowly every time. I was unable to eliminate one wire, though because of access, so that will have to wait until I can pull the engine. I'll then be able to check the starter too. I'll check cranking voltage against your recommended numbers first, though. As an aside, how do the "low amp" testers work? (E.g. DHC BT002 Battery Tester, Auto Meter BVA-350 Battery Tester) Thanks, Guy Buchanan San Diego, CA K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. ________________________________________________________________________________
Date: Mar 25, 2008
Subject: oddball 0.25" fast-on terminal source?
Hello all, I'm fabricating a new harness for my voltage regulator (Zeftronics regulator for a Cessna) and am searching for a supplier of uninsulated 0.25" female fast-on terminals that have a small tab sticking out of the 'back' that will lock them inside the plastic backshell. I've checked the Mouser, Newark, B&C, Waytek, and Allied catalogs without luck. However, perhaps I'm not using the correct keyword to find these oddball terminals in their search engines. Perhaps an autoparts store would carry them (the original Cessna regulator was a Ford part, I believe)? Thanks for any suggestions you folks can provide. D ________________________________________________________________________________
Date: Mar 25, 2008
Subject: Re: B&C SD-20 and magnetic interference
> > >Hi, > >We have been running for about 20 hours now chasing different problems. One >outstanding one is magnetic interference from the SD-20 / LR3 combination. >We have a TSO'd vertical card compass (and yes it is a southern hemisphere >model) mounted in the middle of the panel area (center/center). We are dual >alt / dual bus configuration. > >When the field wire is connected to the SD-20 (lower connection) we get up >to 40 degree swing on the compass - it does vary in amount (from 20-40 >degrees) based on direction - south seems the worst. Pulling the field >breaker causes it swings back about 30 degrees, but the regulator / alt are >still have an affect. > >B&C are saying some swing is 'normal' - but 40 degrees - I'm struggling! I >can't calibrate that much out (best effort so far is +- 15 degrees). > >I've tried changing the location / orientation of the regulator - no >difference. I've tried moving another wet compass around the panel / >cockpit - it looks like same problem (although a bit hard to tell). > >I've tried running some grounded braid around the firewall forward side of >the field wire - no change. Same symptoms on ground, air, zero RPM and full >power. There may be a small movement (< 3 degrees) based on current draw >from SD-20. With SD-20 field disconnected and X-Feed in - no movement. > >Questions: > a) Have others got this / solved this? > b) Any suggested methods of screening the SD-20? > >Thanks, > >Carl The problem is magnetic, not electrical. Had this problem on the Bonanza too. The SD-20 (as do most alternators) has a considerable leakage of magnetic flux from the rotor winding. This isn't a problem for most installations where the alternator mounts on the front of the engine. Alternators hung on the rear of the engine are much closer to the instrument panel and more likely to be an issue with a panel mounted compass. In the Bonanza, we moved the compass off the glareshield to a location on higher on the windshield. Adding a magnetic shield around the SD-20 is a pretty busy task. The shield material would have to be magnetic and cover the rear and perhaps the circumference of the alternator. This has some issues with cooling, wiring egress and labor to implement it. The easiest fix is to increase distance between the compass and the alternator. Magnetic 'radiation' is a weak propagator . . . a little distance really helps. Alternatively, an electronic compass with a remote sensor out in a wing is the best way to achieve the highest performance in a magnetic direction indicator. The case can be made that since you have 3 sources of DC power, reliability of the electronic compass is assured. I would also hope that you carry a hand-held GPS in the flight bag too. I'm not sure I'd bother to install a whisky compass any more. Likelihood of ever needing one these days is about nil. Same thing happened to buggy whips. We were fortunate not to be plagued by the FHA (Federal Horsecart Administration) when the transition occurred. Hmmmm . . . maybe they didn't really go away . . . they just morphed into radio antennas. Let's be really clear about this condition. This is NOT a downside checkmark on the blackboard for the B&C SD-20. ALL alternators have a steel shaft that runs through the device parallel to the magnetic lines of force generated in the field windings. See: http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Internal_Fan2.gif This mechanical feature insures that EVERY alternator will present a strong external magnetic field. It's a system integration problem that seldom presents but has multiple solutions for maintaining flight-system reliability. The REAL problem is getting those-who-know-more- about-airplanes-than-we-do to join us in the 21st century. Bob . . . ________________________________________________________________________________
Date: Mar 25, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: DME/Transponder Suppression
> >When a KT-76A transponder and a KN-63 DME are installed in an aircraft, and >the two units are connected via suppression circuitry built into both units, >is it necessary to comply with the requirement for there to be 6-foot >spacing between the two antennae? I can't find an exception to this rule in >the install manual for either unit, yet I understand the suppression circuit >is designed to keep each unit from receiving the other unit's transmission. >So, why should it matter how close the antennae are to eachother? Transponders and DME use frequencies very close to each other and there's risk of receiver overloading in one device due to the very strong signal from the other device. This is mostly mitigated electronically via the suppression system but the 6' rule gave the engineers and marketing types a warmer set of fuzzies. Give it a try doing the best you can. It will probably be fine. Have you considered a GPS receiver in lieu of DME? DME works with a hand full of ground stations while GPS will give you distance to any point on the surface of the earth. DME is one of those electronic buggy whips that needs to be moved to the museum. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 25, 2008
>At 03:00 PM 3/24/2008, you wrote: >>In all likelihood, your battery is simply gone south >> with loose connections or bad switching running in >> second place. The foregoing suggests that with some >> measurements, it's pretty easy to tell what needs to >> be done before you get out the wrenches or go into >> the swaptronics mode of troubleshooting. > >Bob, > You were right, the battery had suddenly and inexplicably gone > south. When jumped with an enormous RV battery the 582 still had a > difficult time starting, but it started. The dead battery wouldn't accept > a charge, (measured by the load meter,) so I guess it was well and truly > dead. I tried jumping from various locations, eliminating various wires, > and the engine started slowly every time. I was unable to eliminate one > wire, though because of access, so that will have to wait until I can > pull the engine. I'll then be able to check the starter too. I'll check > cranking voltage against your recommended numbers first, though. > As an aside, how do the "low amp" testers work? (E.g. > >DHC BT002 Battery Tester, Auto Meter BVA-350 Battery Tester) > I've seen these kinds of things in the repair shops. These are obviously NOT load testers in the usual sense. There's no way these little fellers can accept that much energy and dump the heat through those little leads and small hand-held cases. My guess is that they're internal impedance testers of some variety. Hit the battery with 100A for a few milliseconds, get a quick reading, compute internal resistance by dividing delta-E by delta-I. Obviously, they have many other features too. It would be interesting to get my hands on one and watch it do the full bag of tricks. I did a design for a client some years ago for a cranking system tester. It was nothing more than a processor driven data acquisition system that took 6 readings of voltage around the system referenced to battery(-) terminal. It filtered the short term perturbations and offered a digital display of minimums and averages for the 6 measurement points. With one setup and one short cranking interval, it would map the system's voltage drops. I don't know if that ever went to production. Haven't heard from them in years. It was the first time I was able to take advantage of the agility offered by microelectronics to make measurements that even the most skilled observer with a multimeter would not be able to duplicate. That design had a lot of components that are now contained in a single micro-controller. It would be VERY easy to do the same product today with a bill of materials of less than $30! It could even offer 8 to 12 channels of monitoring capability. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 25, 2008
Subject: Re: oddball 0.25" fast-on terminal source?
> >Hello all, > >I'm fabricating a new harness for my voltage regulator (Zeftronics >regulator for a Cessna) and am searching for a supplier of uninsulated >0.25" female fast-on terminals that have a small tab sticking out of >the 'back' that will lock them inside the plastic backshell. I've >checked the Mouser, Newark, B&C, Waytek, and Allied catalogs without >luck. However, perhaps I'm not using the correct keyword to find >these oddball terminals in their search engines. Perhaps an autoparts >store would carry them (the original Cessna regulator was a Ford part, >I believe)? > >Thanks for any suggestions you folks can provide. I've never found these as loose fabrication or repair parts . . . but that doesn't mean somebody doesn't have them. Most builders use individual fast-on terminals and ditch the housing. You can buy the housing with terminals installed and short pig-tails at some care parts stores. I think I've seen them in the red "Help" line of blister-packed, peg-board products. I can get you a part number for a reel of 5,000! B&C used to have some that were used with the housing that fits the connector on the back of an alternator. These were bare-brass (un-plated) parts. They might work with your regulator tabs connector housing. I'd go with the loose PIDG fast-on terminals and ditch the housing. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 25, 2008
"uninsulated 0.25" female fast-on terminals that have a small tab sticking out of the 'back' that will lock them inside the plastic backshell" I have bought just such a part for the voltage regulator connector on my pl ane from NAPA aircraft and auto parts store. Rodney in Tennessee _________________________________________________________________ In a rush? Get real-time answers with Windows Live Messenger. http://www.windowslive.com/messenger/overview.html?ocid=TXT_TAGLM_WL_Refr esh_realtime_042008 ________________________________________________________________________________
Date: Mar 25, 2008
If you really want them I believe I have purchased these, tin plated, in small quantity, cut from a reel, from digi-key however they are open barrel crimps (cheap automotive) onto the wire. There were at least two sizes listed depending on wire gauge. You want the small for tefzel or just clip the fingers. Like Bob, I prefer to shove individual PIDG connectors into the housing or ditch the housing. I will use the open barrel crimps on small awg 22 and smaller if I must, but I don't consider them suitable for 18 awg or larger unless soldered and that has other issues associated. Ken Robert L. Nuckolls, III wrote: > > > >> >> Hello all, >> >> I'm fabricating a new harness for my voltage regulator (Zeftronics >> regulator for a Cessna) and am searching for a supplier of uninsulated >> 0.25" female fast-on terminals that have a small tab sticking out of >> the 'back' that will lock them inside the plastic backshell. I've >> checked the Mouser, Newark, B&C, Waytek, and Allied catalogs without >> luck. However, perhaps I'm not using the correct keyword to find >> these oddball terminals in their search engines. Perhaps an autoparts >> store would carry them (the original Cessna regulator was a Ford part, >> I believe)? >> >> Thanks for any suggestions you folks can provide. > > I've never found these as loose fabrication or repair > parts . . . but that doesn't mean somebody doesn't have > them. Most builders use individual fast-on terminals > and ditch the housing. You can buy the housing with > terminals installed and short pig-tails at some care > parts stores. I think I've seen them in the red "Help" > line of blister-packed, peg-board products. > > I can get you a part number for a reel of 5,000! B&C > used to have some that were used with the housing that > fits the connector on the back of an alternator. These > were bare-brass (un-plated) parts. They might work with > your regulator tabs connector housing. I'd go with the > loose PIDG fast-on terminals and ditch the housing. > > Bob . . . ________________________________________________________________________________
Subject: WX-500 Install Manual
Date: Mar 25, 2008
Would anyone happen to know where I could obtain a WX-500 Install Manual? Don ________________________________________________________________________________
Subject: Question about Resistors
Date: Mar 25, 2008
Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) ________________________________________________________________________________
Date: Mar 26, 2008
Hi Bob, Removing the 'whiskey compass' could / will result in my aircraft being grounded. I have been round the loop with the NZ CAA and the 'need' for a traditional compass, I already have a GRT EFIS with magnetometer, IFR GPS and still not enough. At the moment it is going to be an up cliff paperwork struggle. Removing the SD-20 is a 'better' option from their perspective, but with a full FADEC I'm not comfortable with just dual battery, single alternator - and having got to this point where the engine is running great (or too well) removing the SD-20 isn't an option either. Distance changing is going to be in the order of 1" difference, unless I mounted it in the baggage compartment. What options can be used to reduce the magnetic impact - is it a luck of the draw with the SD-20 - ie. they all vary abit? We are only taking 3-4 amps under normal operations. I understand some interference coming out, but what is 'too much'? WRT: > This is NOT a downside checkmark on the blackboard > for the B&C SD-20. ALL alternators have a steel > shaft that runs through the device parallel > to the magnetic lines of force generated in > the field windings. My biggest complaint is there is NO indication or warnings about this anywhere in the instruction / website information - I would have reconsidered the panel layout with this information, as it is I'm fixed without major rework and it is affecting my Autopilot backup and one of the few instruments the regulator is specifically interested in.... How can I reduce this interference at the source - hopefully a small reduction will be enough to get calibration within spec. Thanks, Carl -- Carl Morgan - ZK-VII - RV 7A http://www.rvproject.gen.nz/ > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Robert L. Nuckolls, III > Sent: 26 March 2008 00:12 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference > > > III" > > > > > > > >Hi, > > > >We have been running for about 20 hours now chasing different > problems. One > >outstanding one is magnetic interference from the SD-20 / LR3 > combination. > >We have a TSO'd vertical card compass (and yes it is a southern > hemisphere > >model) mounted in the middle of the panel area (center/center). > We are dual > >alt / dual bus configuration. > > > >When the field wire is connected to the SD-20 (lower connection) > we get up > >to 40 degree swing on the compass - it does vary in amount (from 20-40 > >degrees) based on direction - south seems the worst. Pulling the field > >breaker causes it swings back about 30 degrees, but the > regulator / alt are > >still have an affect. > > > >B&C are saying some swing is 'normal' - but 40 degrees - I'm > struggling! I > >can't calibrate that much out (best effort so far is +- 15 degrees). > > > >I've tried changing the location / orientation of the regulator - no > >difference. I've tried moving another wet compass around the panel / > >cockpit - it looks like same problem (although a bit hard to tell). > > > >I've tried running some grounded braid around the firewall > forward side of > >the field wire - no change. Same symptoms on ground, air, zero > RPM and full > >power. There may be a small movement (< 3 degrees) based on current draw > >from SD-20. With SD-20 field disconnected and X-Feed in - no movement. > > > >Questions: > > a) Have others got this / solved this? > > b) Any suggested methods of screening the SD-20? > > > >Thanks, > > > >Carl > > > The problem is magnetic, not electrical. > Had this problem on the Bonanza too. The SD-20 > (as do most alternators) has a considerable > leakage of magnetic flux from the rotor winding. > This isn't a problem for most installations > where the alternator mounts on the front of > the engine. > > Alternators hung on the rear of the engine > are much closer to the instrument panel and > more likely to be an issue with a panel > mounted compass. > > In the Bonanza, we moved the compass off the > glareshield to a location on higher on the > windshield. Adding a magnetic shield around > the SD-20 is a pretty busy task. The shield > material would have to be magnetic and cover > the rear and perhaps the circumference of the > alternator. This has some issues with cooling, > wiring egress and labor to implement it. > > The easiest fix is to increase distance between > the compass and the alternator. Magnetic > 'radiation' is a weak propagator . . . a little > distance really helps. > > Alternatively, an electronic compass with > a remote sensor out in a wing is the best > way to achieve the highest performance > in a magnetic direction indicator. The > case can be made that since you have > 3 sources of DC power, reliability of > the electronic compass is assured. I would > also hope that you carry a hand-held GPS > in the flight bag too. > > I'm not sure I'd bother to install a > whisky compass any more. Likelihood of > ever needing one these days is about nil. > Same thing happened to buggy whips. We > were fortunate not to be plagued by the > FHA (Federal Horsecart Administration) > when the transition occurred. Hmmmm . . . > maybe they didn't really go away . . . > they just morphed into radio antennas. > > Let's be really clear about this condition. > This is NOT a downside checkmark on the blackboard > for the B&C SD-20. ALL alternators have a steel > shaft that runs through the device parallel > to the magnetic lines of force generated in > the field windings. See: > > http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Inte > rnal_Fan2.gif > > This mechanical feature insures that EVERY > alternator will present a strong external > magnetic field. It's a system integration problem > that seldom presents but has multiple solutions > for maintaining flight-system reliability. The > REAL problem is getting those-who-know-more- > about-airplanes-than-we-do to join us in > the 21st century. > > Bob . . . > > > Checked by AVG. > 25/03/2008 10:26 > Checked by AVG. 10:26 ________________________________________________________________________________
Subject: Alternator
Date: Mar 25, 2008
I have a 12V 60A Chrysler alternator that came with the engine I am rebuilding. Unfortunately I do not have the brackets for this alternator. Does anyone know where to get brackets for a reasonable price (I don't even know what part number), or would I be better off just going with a Plane Power kit? Thanks Bryan ________________________________________________________________________________
Date: Mar 25, 2008
Hi Scott: Here's the formula: R = (Vbatt-Vf)/If ohms, where Vf is 1.7 V and If is 20 ma (from datasheet) For the part you chose, R = (14.2-1.7)/0.020 = 625 ohms (use 680 ohm standard value) -- if you power each segment seperately. If you connect all 5 of the LEDs in series, then R = (14.2 - 5*1.7)/0.020 285 ohms (use 330 ohm standard value). Now, here's one issue to deal with: If you are dimming the LEDs, you may want to power each segment separately so that they dim the same as other displays in the cockpit. Only experimentation will give you the answer for this. Finally, you may want to try one light bar first before you commit to using them in a panel. They may have a tendency to wash out in bright sunlight. I used to sell a product line that used similar light bars, and this was an issue unless you carefully shield the display from ambient light (such as locating right underneath the glareshield). I found some 1/8" LEDs that will dazzle your eyes, but they were very difficult to dim due to their intensity. Of course, they were tiny and not easy to label!. Good luck. Vern Little. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: March 25, 2008 12:59 PM Subject: AeroElectric-List: Question about Resistors Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) ________________________________________________________________________________
Date: Mar 25, 2008
Are _you_ concerned about the function of the whiskey compass? If not (given the other equipment on board), do your best to come up with a calibration card for it and call it good. Side question.. I got the impression that your compass reads accurately when the field is turned off on the SD-20. Can the SD-20 be used only when your main alternator is off line? If so, the only time your compass will have a problem is if the main alternator fails. I could live with that.. Also, what's the wire routing of the output and field of the SD-20 (with respect to the compass? Is it possible that the wire routing is contributing to the B-field generated by the SD-20? Is the ground following a different route than the field and output wires? I'm pretty sure Bob's assessment of the cause of your headache was correct, but I wonder if there might be additional factors... In a different direction, you can get a remote compass from Century Instruments: http://www.trade-a-plane.com/dispads/0000769074.pdf Kinda spendy at $500 for the kit.. And, I don't know if it actually satisfies the requirement. Regards, Matt- > > > Hi Bob, > > Removing the 'whiskey compass' could / will result in my aircraft being > grounded. I have been round the loop with the NZ CAA and the 'need' for a > traditional compass, I already have a GRT EFIS with magnetometer, IFR GPS > and still not enough. At the moment it is going to be an up cliff > paperwork > struggle. > > Removing the SD-20 is a 'better' option from their perspective, but with a > full FADEC I'm not comfortable with just dual battery, single alternator - > and having got to this point where the engine is running great (or too > well) > removing the SD-20 isn't an option either. Distance changing is going to > be > in the order of 1" difference, unless I mounted it in the baggage > compartment. What options can be used to reduce the magnetic impact - is > it > a luck of the draw with the SD-20 - ie. they all vary abit? We are only > taking 3-4 amps under normal operations. I understand some interference > coming out, but what is 'too much'? > > WRT: >> This is NOT a downside checkmark on the blackboard >> for the B&C SD-20. ALL alternators have a steel >> shaft that runs through the device parallel >> to the magnetic lines of force generated in >> the field windings. > > My biggest complaint is there is NO indication or warnings about this > anywhere in the instruction / website information - I would have > reconsidered the panel layout with this information, as it is I'm fixed > without major rework and it is affecting my Autopilot backup and one of > the > few instruments the regulator is specifically interested in.... > > How can I reduce this interference at the source - hopefully a small > reduction will be enough to get calibration within spec. > > Thanks, > > Carl > -- > Carl Morgan - ZK-VII - RV 7A > http://www.rvproject.gen.nz/ > >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >> Robert L. Nuckolls, III >> Sent: 26 March 2008 00:12 >> To: aeroelectric-list(at)matronics.com >> Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference >> >> >> III" >> >> >> > >> > >> >Hi, >> > >> >We have been running for about 20 hours now chasing different >> problems. One >> >outstanding one is magnetic interference from the SD-20 / LR3 >> combination. >> >We have a TSO'd vertical card compass (and yes it is a southern >> hemisphere >> >model) mounted in the middle of the panel area (center/center). >> We are dual >> >alt / dual bus configuration. >> > >> >When the field wire is connected to the SD-20 (lower connection) >> we get up >> >to 40 degree swing on the compass - it does vary in amount (from 20-40 >> >degrees) based on direction - south seems the worst. Pulling the field >> >breaker causes it swings back about 30 degrees, but the >> regulator / alt are >> >still have an affect. >> > >> >B&C are saying some swing is 'normal' - but 40 degrees - I'm >> struggling! I >> >can't calibrate that much out (best effort so far is +- 15 degrees). >> > >> >I've tried changing the location / orientation of the regulator - no >> >difference. I've tried moving another wet compass around the panel / >> >cockpit - it looks like same problem (although a bit hard to tell). >> > >> >I've tried running some grounded braid around the firewall >> forward side of >> >the field wire - no change. Same symptoms on ground, air, zero >> RPM and full >> >power. There may be a small movement (< 3 degrees) based on current >> draw >> >from SD-20. With SD-20 field disconnected and X-Feed in - no movement. >> > >> >Questions: >> > a) Have others got this / solved this? >> > b) Any suggested methods of screening the SD-20? >> > >> >Thanks, >> > >> >Carl >> >> >> The problem is magnetic, not electrical. >> Had this problem on the Bonanza too. The SD-20 >> (as do most alternators) has a considerable >> leakage of magnetic flux from the rotor winding. >> This isn't a problem for most installations >> where the alternator mounts on the front of >> the engine. >> >> Alternators hung on the rear of the engine >> are much closer to the instrument panel and >> more likely to be an issue with a panel >> mounted compass. >> >> In the Bonanza, we moved the compass off the >> glareshield to a location on higher on the >> windshield. Adding a magnetic shield around >> the SD-20 is a pretty busy task. The shield >> material would have to be magnetic and cover >> the rear and perhaps the circumference of the >> alternator. This has some issues with cooling, >> wiring egress and labor to implement it. >> >> The easiest fix is to increase distance between >> the compass and the alternator. Magnetic >> 'radiation' is a weak propagator . . . a little >> distance really helps. >> >> Alternatively, an electronic compass with >> a remote sensor out in a wing is the best >> way to achieve the highest performance >> in a magnetic direction indicator. The >> case can be made that since you have >> 3 sources of DC power, reliability of >> the electronic compass is assured. I would >> also hope that you carry a hand-held GPS >> in the flight bag too. >> >> I'm not sure I'd bother to install a >> whisky compass any more. Likelihood of >> ever needing one these days is about nil. >> Same thing happened to buggy whips. We >> were fortunate not to be plagued by the >> FHA (Federal Horsecart Administration) >> when the transition occurred. Hmmmm . . . >> maybe they didn't really go away . . . >> they just morphed into radio antennas. >> >> Let's be really clear about this condition. >> This is NOT a downside checkmark on the blackboard >> for the B&C SD-20. ALL alternators have a steel >> shaft that runs through the device parallel >> to the magnetic lines of force generated in >> the field windings. See: >> >> http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Inte >> rnal_Fan2.gif >> >> This mechanical feature insures that EVERY >> alternator will present a strong external >> magnetic field. It's a system integration problem >> that seldom presents but has multiple solutions >> for maintaining flight-system reliability. The >> REAL problem is getting those-who-know-more- >> about-airplanes-than-we-do to join us in >> the 21st century. >> >> Bob . . . >> >> >> >> >> >> Checked by AVG. >> 25/03/2008 10:26 >> > Checked by AVG. > 10:26 > > ________________________________________________________________________________
Subject: KX-155 Audio Out
Date: Mar 25, 2008
I have a KX-155 and a Sigtronics Sport 200 intercom. I'm trying to figure out the proper wiring between units. The KX-155 has an 'audio hi' and 'audio lo' for both the comm and nav. I'm confused what is meant with the 'hi' and 'lo'. Are the 'audio hi' connections supposed to go to the common blue intercom wire, common with the headset jacks, while the 'audio lo' connections go to ground? If that's the case, why must the 'audio lo' connections be shielded if it's going to ground anyway? Thanks for your help! Dan Ginty Read this topic online here: http://forums.matronics.com/viewtopic.php?p=172651#172651 ________________________________________________________________________________
Date: Mar 25, 2008
Scott, You need to drop 12.3V (14-1.7) while limiting the current to ~20ma R=E/I (12.3/.02 = 615 Ohms). The power dissipated will be P=I*E (.02*12.3=.246 watts). A 620 ohm 1/2W resistor would be fine for 1 LED. If you connect several LED's in series subtract the total voltage drop and do the same calculation. 14-3.4 for 2 and so on. LED's will work over a fairly broad range of current depending on the type and brightness desired so don't worry too much about exact resistor values. You can work backwards to find the current I=E/R so if you use 560 ohms (12.3/560=.022) or 22ma. Check your Digikey catalog for standard resistor values. Good luck _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: Tuesday, March 25, 2008 2:59 PM Subject: AeroElectric-List: Question about Resistors Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) ________________________________________________________________________________
Date: Mar 25, 2008
D, I had the same issue and bought a roll of AMP tin plated for 18-22 AWG wire. DigiKey P/N A27933CT-ND AMP P/N 60295-2 If these will help send me your address off list and I will mail you a few. I bought 100 and needed 3 :( I just couldn't think of butt splices on the Alternator wires. Hooverra at verizon dot net Ralph -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of D Wysong Sent: Tuesday, March 25, 2008 4:50 AM Subject: AeroElectric-List: oddball 0.25" fast-on terminal source? Hello all, I'm fabricating a new harness for my voltage regulator (Zeftronics regulator for a Cessna) and am searching for a supplier of uninsulated 0.25" female fast-on terminals that have a small tab sticking out of the 'back' that will lock them inside the plastic backshell. I've checked the Mouser, Newark, B&C, Waytek, and Allied catalogs without luck. However, perhaps I'm not using the correct keyword to find these oddball terminals in their search engines. Perhaps an autoparts store would carry them (the original Cessna regulator was a Ford part, I believe)? Thanks for any suggestions you folks can provide. D ________________________________________________________________________________
Date: Mar 26, 2008
Hi Matt, Thanks for the ideas, I'm really not that concerned about the whiskey compass functionality - if I've lost all my other mag direction indicators - the engine has stopped, so I don't really care about direction ;-) However the CAA so far is and the calibration card per regs has to be within 10 degrees :-(. SD-20 off / disconnected - yes I think the compass reads right - but we are dual bus (two independent active buses), not endurance / essential bus - so both alts need to be running / working. Wire routing - the B lead and field goes aft from the SD-20 to the firewall, left across the top of the firewall, aft again through the firewall and back to a mid location for the regulator which is on a tray between the forward panel ribs (RV 7A Tipup). Remote compass - it could yet be the option - but I don't like to even think about the routing of the cables through the tunnel / spar / wing..... Regards, Carl -- Carl Morgan - ZK-VII - RV 7A http://www.rvproject.gen.nz/ > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Matt > Prather > Sent: 26 March 2008 11:59 > To: aeroelectric-list(at)matronics.com > Subject: RE: AeroElectric-List: B&C SD-20 and magnetic interference > > > > > Are _you_ concerned about the function of the whiskey compass? If not > (given the other equipment on board), do your best to come up with a > calibration card for it and call it good. > > Side question.. I got the impression that your compass reads accurately > when the field is turned off on the SD-20. Can the SD-20 be used only > when your main alternator is off line? If so, the only time your compass > will have a problem is if the main alternator fails. I could live with > that.. > > Also, what's the wire routing of the output and field of the SD-20 (with > respect to the compass? Is it possible that the wire routing is > contributing to the B-field generated by the SD-20? Is the ground > following a different route than the field and output wires? I'm pretty > sure Bob's assessment of the cause of your headache was correct, but I > wonder if there might be additional factors... > > In a different direction, you can get a remote compass from Century > Instruments: > > http://www.trade-a-plane.com/dispads/0000769074.pdf > > Kinda spendy at $500 for the kit.. And, I don't know if it actually > satisfies the requirement. > > > Regards, > > Matt- > > > > > > > Hi Bob, > > > > Removing the 'whiskey compass' could / will result in my aircraft being > > grounded. I have been round the loop with the NZ CAA and the > 'need' for a > > traditional compass, I already have a GRT EFIS with > magnetometer, IFR GPS > > and still not enough. At the moment it is going to be an up cliff > > paperwork > > struggle. > > > > Removing the SD-20 is a 'better' option from their perspective, > but with a > > full FADEC I'm not comfortable with just dual battery, single > alternator - > > and having got to this point where the engine is running great (or too > > well) > > removing the SD-20 isn't an option either. Distance changing > is going to > > be > > in the order of 1" difference, unless I mounted it in the baggage > > compartment. What options can be used to reduce the magnetic > impact - is > > it > > a luck of the draw with the SD-20 - ie. they all vary abit? We are only > > taking 3-4 amps under normal operations. I understand some interference > > coming out, but what is 'too much'? > > > > WRT: > >> This is NOT a downside checkmark on the blackboard > >> for the B&C SD-20. ALL alternators have a steel > >> shaft that runs through the device parallel > >> to the magnetic lines of force generated in > >> the field windings. > > > > My biggest complaint is there is NO indication or warnings about this > > anywhere in the instruction / website information - I would have > > reconsidered the panel layout with this information, as it is I'm fixed > > without major rework and it is affecting my Autopilot backup and one of > > the > > few instruments the regulator is specifically interested in.... > > > > How can I reduce this interference at the source - hopefully a small > > reduction will be enough to get calibration within spec. > > > > Thanks, > > > > Carl > > -- > > Carl Morgan - ZK-VII - RV 7A > > http://www.rvproject.gen.nz/ > > > >> -----Original Message----- > >> From: owner-aeroelectric-list-server(at)matronics.com > >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > >> Robert L. Nuckolls, III > >> Sent: 26 March 2008 00:12 > >> To: aeroelectric-list(at)matronics.com > >> Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference > >> > >> > >> III" > >> > >> > >> > > >> > > >> >Hi, > >> > > >> >We have been running for about 20 hours now chasing different > >> problems. One > >> >outstanding one is magnetic interference from the SD-20 / LR3 > >> combination. > >> >We have a TSO'd vertical card compass (and yes it is a southern > >> hemisphere > >> >model) mounted in the middle of the panel area (center/center). > >> We are dual > >> >alt / dual bus configuration. > >> > > >> >When the field wire is connected to the SD-20 (lower connection) > >> we get up > >> >to 40 degree swing on the compass - it does vary in amount (from 20-40 > >> >degrees) based on direction - south seems the worst. Pulling > the field > >> >breaker causes it swings back about 30 degrees, but the > >> regulator / alt are > >> >still have an affect. > >> > > >> >B&C are saying some swing is 'normal' - but 40 degrees - I'm > >> struggling! I > >> >can't calibrate that much out (best effort so far is +- 15 degrees). > >> > > >> >I've tried changing the location / orientation of the regulator - no > >> >difference. I've tried moving another wet compass around the panel / > >> >cockpit - it looks like same problem (although a bit hard to tell). > >> > > >> >I've tried running some grounded braid around the firewall > >> forward side of > >> >the field wire - no change. Same symptoms on ground, air, zero > >> RPM and full > >> >power. There may be a small movement (< 3 degrees) based on current > >> draw > >> >from SD-20. With SD-20 field disconnected and X-Feed in - no > movement. > >> > > >> >Questions: > >> > a) Have others got this / solved this? > >> > b) Any suggested methods of screening the SD-20? > >> > > >> >Thanks, > >> > > >> >Carl > >> > >> > >> The problem is magnetic, not electrical. > >> Had this problem on the Bonanza too. The SD-20 > >> (as do most alternators) has a considerable > >> leakage of magnetic flux from the rotor winding. > >> This isn't a problem for most installations > >> where the alternator mounts on the front of > >> the engine. > >> > >> Alternators hung on the rear of the engine > >> are much closer to the instrument panel and > >> more likely to be an issue with a panel > >> mounted compass. > >> > >> In the Bonanza, we moved the compass off the > >> glareshield to a location on higher on the > >> windshield. Adding a magnetic shield around > >> the SD-20 is a pretty busy task. The shield > >> material would have to be magnetic and cover > >> the rear and perhaps the circumference of the > >> alternator. This has some issues with cooling, > >> wiring egress and labor to implement it. > >> > >> The easiest fix is to increase distance between > >> the compass and the alternator. Magnetic > >> 'radiation' is a weak propagator . . . a little > >> distance really helps. > >> > >> Alternatively, an electronic compass with > >> a remote sensor out in a wing is the best > >> way to achieve the highest performance > >> in a magnetic direction indicator. The > >> case can be made that since you have > >> 3 sources of DC power, reliability of > >> the electronic compass is assured. I would > >> also hope that you carry a hand-held GPS > >> in the flight bag too. > >> > >> I'm not sure I'd bother to install a > >> whisky compass any more. Likelihood of > >> ever needing one these days is about nil. > >> Same thing happened to buggy whips. We > >> were fortunate not to be plagued by the > >> FHA (Federal Horsecart Administration) > >> when the transition occurred. Hmmmm . . . > >> maybe they didn't really go away . . . > >> they just morphed into radio antennas. > >> > >> Let's be really clear about this condition. > >> This is NOT a downside checkmark on the blackboard > >> for the B&C SD-20. ALL alternators have a steel > >> shaft that runs through the device parallel > >> to the magnetic lines of force generated in > >> the field windings. See: > >> > >> http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Inte > >> rnal_Fan2.gif > >> > >> This mechanical feature insures that EVERY > >> alternator will present a strong external > >> magnetic field. It's a system integration problem > >> that seldom presents but has multiple solutions > >> for maintaining flight-system reliability. The > >> REAL problem is getting those-who-know-more- > >> about-airplanes-than-we-do to join us in > >> the 21st century. > >> > >> Bob . . . > >> > >> > >> > >> > >> > >> Checked by AVG. > >> 25/03/2008 10:26 > >> > > Checked by AVG. > > 10:26 > > > > > > > > > > > > > > > Checked by AVG. > 25/03/2008 10:26 > Checked by AVG. 10:26 ________________________________________________________________________________
Date: Mar 25, 2008
That is the formula I was looking for. Thank you. The light bars themselves, have 5 LED's so those will go in a series. My last trick will be mounting them and the wiring of said LED's. I am hoping a blank project circuit board will do what I want. The trick with the circuit board will be the spacing requirements (space between light bars). Once that is figured, I can order the face (reverse engraved acrylic). I am also working on a "push-to test" option. As far as the intensity, since these will be behind a reverse engraved acrylic (black behind clear) only the letters themselves will light up. Once I get the mock up completed, the day/night intensity testing will be performed. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vernon Little Sent: Tuesday, 25 March, 2008 15:46 Subject: RE: AeroElectric-List: Question about Resistors Hi Scott: Here's the formula: R = (Vbatt-Vf)/If ohms, where Vf is 1.7 V and If is 20 ma (from datasheet) For the part you chose, R = (14.2-1.7)/0.020 = 625 ohms (use 680 ohm standard value) -- if you power each segment seperately. If you connect all 5 of the LEDs in series, then R = (14.2 - 5*1.7)/0.020 285 ohms (use 330 ohm standard value). Now, here's one issue to deal with: If you are dimming the LEDs, you may want to power each segment separately so that they dim the same as other displays in the cockpit. Only experimentation will give you the answer for this. Finally, you may want to try one light bar first before you commit to using them in a panel. They may have a tendency to wash out in bright sunlight. I used to sell a product line that used similar light bars, and this was an issue unless you carefully shield the display from ambient light (such as locating right underneath the glareshield). I found some 1/8" LEDs that will dazzle your eyes, but they were very difficult to dim due to their intensity. Of course, they were tiny and not easy to label!. Good luck. Vern Little. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: March 25, 2008 12:59 PM Subject: AeroElectric-List: Question about Resistors Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Mar 25, 2008
There are type certificated aircraft where the whiskey compass is only accurate in a very particular electrical system configuration. For example, on the Cessna C550 (Citation II business jet), the whiskey compass is only useable if both generators are OFF. This is quite acceptable to the FAA, Transport Canada, and I presume the NZ CAA. Given that you have an EFIS with a remote flux valve that acts as your primary source of magnetic heading, you don't need the whiskey compass to read accurately most of the time. I wonder if it might be acceptable to put a placard by the whiskey compass that said "SD-20 Alternator must be OFF to use compass". Then make a compass correction card that is only valid if the SD-20 is OFF. Kevin Horton On 25 Mar 2008, at 19:51, Carl Morgan wrote: > vii(at)rvproject.gen.nz> > > Hi Matt, > > Thanks for the ideas, I'm really not that concerned about the whiskey > compass functionality - if I've lost all my other mag direction > indicators - > the engine has stopped, so I don't really care about direction ;-) > However > the CAA so far is and the calibration card per regs has to be > within 10 > degrees :-(. > > SD-20 off / disconnected - yes I think the compass reads right - > but we are > dual bus (two independent active buses), not endurance / essential > bus - so > both alts need to be running / working. > > Wire routing - the B lead and field goes aft from the SD-20 to the > firewall, > left across the top of the firewall, aft again through the firewall > and back > to a mid location for the regulator which is on a tray between the > forward > panel ribs (RV 7A Tipup). > > Remote compass - it could yet be the option - but I don't like to > even think > about the routing of the cables through the tunnel / spar / wing..... > > Regards, > > Carl > -- > Carl Morgan - ZK-VII - RV 7A > http://www.rvproject.gen.nz/ > >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >> Matt >> Prather >> Sent: 26 March 2008 11:59 >> To: aeroelectric-list(at)matronics.com >> Subject: RE: AeroElectric-List: B&C SD-20 and magnetic interference >> >> >> >> >> Are _you_ concerned about the function of the whiskey compass? If >> not >> (given the other equipment on board), do your best to come up with a >> calibration card for it and call it good. >> >> Side question.. I got the impression that your compass reads >> accurately >> when the field is turned off on the SD-20. Can the SD-20 be used >> only >> when your main alternator is off line? If so, the only time your >> compass >> will have a problem is if the main alternator fails. I could live >> with >> that.. >> >> Also, what's the wire routing of the output and field of the SD-20 >> (with >> respect to the compass? Is it possible that the wire routing is >> contributing to the B-field generated by the SD-20? Is the ground >> following a different route than the field and output wires? I'm >> pretty >> sure Bob's assessment of the cause of your headache was correct, >> but I >> wonder if there might be additional factors... >> >> In a different direction, you can get a remote compass from Century >> Instruments: >> >> http://www.trade-a-plane.com/dispads/0000769074.pdf >> >> Kinda spendy at $500 for the kit.. And, I don't know if it actually >> satisfies the requirement. >> >> >> Regards, >> >> Matt- >> >>> >>> >>> Hi Bob, >>> >>> Removing the 'whiskey compass' could / will result in my aircraft >>> being >>> grounded. I have been round the loop with the NZ CAA and the >> 'need' for a >>> traditional compass, I already have a GRT EFIS with >> magnetometer, IFR GPS >>> and still not enough. At the moment it is going to be an up cliff >>> paperwork >>> struggle. >>> >>> Removing the SD-20 is a 'better' option from their perspective, >> but with a >>> full FADEC I'm not comfortable with just dual battery, single >> alternator - >>> and having got to this point where the engine is running great >>> (or too >>> well) >>> removing the SD-20 isn't an option either. Distance changing >> is going to >>> be >>> in the order of 1" difference, unless I mounted it in the baggage >>> compartment. What options can be used to reduce the magnetic >> impact - is >>> it >>> a luck of the draw with the SD-20 - ie. they all vary abit? We >>> are only >>> taking 3-4 amps under normal operations. I understand some >>> interference >>> coming out, but what is 'too much'? >>> >>> WRT: >>>> This is NOT a downside checkmark on the blackboard >>>> for the B&C SD-20. ALL alternators have a steel >>>> shaft that runs through the device parallel >>>> to the magnetic lines of force generated in >>>> the field windings. >>> >>> My biggest complaint is there is NO indication or warnings about >>> this >>> anywhere in the instruction / website information - I would have >>> reconsidered the panel layout with this information, as it is I'm >>> fixed >>> without major rework and it is affecting my Autopilot backup and >>> one of >>> the >>> few instruments the regulator is specifically interested in.... >>> >>> How can I reduce this interference at the source - hopefully a small >>> reduction will be enough to get calibration within spec. >>> >>> Thanks, >>> >>> Carl >>> -- >>> Carl Morgan - ZK-VII - RV 7A >>> http://www.rvproject.gen.nz/ >>> >>>> -----Original Message----- >>>> From: owner-aeroelectric-list-server(at)matronics.com >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of >>>> Robert L. Nuckolls, III >>>> Sent: 26 March 2008 00:12 >>>> To: aeroelectric-list(at)matronics.com >>>> Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference >>>> >>>> >>>> III" >>>> >>>> >>>>> >>>>> >>>>> Hi, >>>>> >>>>> We have been running for about 20 hours now chasing different >>>> problems. One >>>>> outstanding one is magnetic interference from the SD-20 / LR3 >>>> combination. >>>>> We have a TSO'd vertical card compass (and yes it is a southern >>>> hemisphere >>>>> model) mounted in the middle of the panel area (center/center). >>>> We are dual >>>>> alt / dual bus configuration. >>>>> >>>>> When the field wire is connected to the SD-20 (lower connection) >>>> we get up >>>>> to 40 degree swing on the compass - it does vary in amount >>>>> (from 20-40 >>>>> degrees) based on direction - south seems the worst. Pulling >> the field >>>>> breaker causes it swings back about 30 degrees, but the >>>> regulator / alt are >>>>> still have an affect. >>>>> >>>>> B&C are saying some swing is 'normal' - but 40 degrees - I'm >>>> struggling! I >>>>> can't calibrate that much out (best effort so far is +- 15 >>>>> degrees). >>>>> >>>>> I've tried changing the location / orientation of the regulator >>>>> - no >>>>> difference. I've tried moving another wet compass around the >>>>> panel / >>>>> cockpit - it looks like same problem (although a bit hard to >>>>> tell). >>>>> >>>>> I've tried running some grounded braid around the firewall >>>> forward side of >>>>> the field wire - no change. Same symptoms on ground, air, zero >>>> RPM and full >>>>> power. There may be a small movement (< 3 degrees) based on >>>>> current >>>> draw >>>>> from SD-20. With SD-20 field disconnected and X-Feed in - no >> movement. >>>>> >>>>> Questions: >>>>> a) Have others got this / solved this? >>>>> b) Any suggested methods of screening the SD-20? >>>>> >>>>> Thanks, >>>>> >>>>> Carl >>>> >>>> >>>> The problem is magnetic, not electrical. >>>> Had this problem on the Bonanza too. The SD-20 >>>> (as do most alternators) has a considerable >>>> leakage of magnetic flux from the rotor winding. >>>> This isn't a problem for most installations >>>> where the alternator mounts on the front of >>>> the engine. >>>> >>>> Alternators hung on the rear of the engine >>>> are much closer to the instrument panel and >>>> more likely to be an issue with a panel >>>> mounted compass. >>>> >>>> In the Bonanza, we moved the compass off the >>>> glareshield to a location on higher on the >>>> windshield. Adding a magnetic shield around >>>> the SD-20 is a pretty busy task. The shield >>>> material would have to be magnetic and cover >>>> the rear and perhaps the circumference of the >>>> alternator. This has some issues with cooling, >>>> wiring egress and labor to implement it. >>>> >>>> The easiest fix is to increase distance between >>>> the compass and the alternator. Magnetic >>>> 'radiation' is a weak propagator . . . a little >>>> distance really helps. >>>> >>>> Alternatively, an electronic compass with >>>> a remote sensor out in a wing is the best >>>> way to achieve the highest performance >>>> in a magnetic direction indicator. The >>>> case can be made that since you have >>>> 3 sources of DC power, reliability of >>>> the electronic compass is assured. I would >>>> also hope that you carry a hand-held GPS >>>> in the flight bag too. >>>> >>>> I'm not sure I'd bother to install a >>>> whisky compass any more. Likelihood of >>>> ever needing one these days is about nil. >>>> Same thing happened to buggy whips. We >>>> were fortunate not to be plagued by the >>>> FHA (Federal Horsecart Administration) >>>> when the transition occurred. Hmmmm . . . >>>> maybe they didn't really go away . . . >>>> they just morphed into radio antennas. >>>> >>>> Let's be really clear about this condition. >>>> This is NOT a downside checkmark on the blackboard >>>> for the B&C SD-20. ALL alternators have a steel >>>> shaft that runs through the device parallel >>>> to the magnetic lines of force generated in >>>> the field windings. See: >>>> >>>> http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Inte >>>> rnal_Fan2.gif >>>> >>>> This mechanical feature insures that EVERY >>>> alternator will present a strong external >>>> magnetic field. It's a system integration problem >>>> that seldom presents but has multiple solutions >>>> for maintaining flight-system reliability. The >>>> REAL problem is getting those-who-know-more- >>>> about-airplanes-than-we-do to join us in >>>> the 21st century. >>>> >>>> Bob . . . >>>> >>>> ________________________________________________________________________________
Subject: B&C SD-20 and magnetic interference
Date: Mar 26, 2008
Very interesting - Thanks Kevin.... This could be a short term solution for the paperwork battle.... Carl PS: I wonder how close a C550 is to a glider with both generators OFF ;-) > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > Kevin Horton > Sent: 26 March 2008 14:17 > To: aeroelectric-list(at)matronics.com > Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference > > > > > There are type certificated aircraft where the whiskey compass is > only accurate in a very particular electrical system configuration. > For example, on the Cessna C550 (Citation II business jet), the > whiskey compass is only useable if both generators are OFF. This is > quite acceptable to the FAA, Transport Canada, and I presume the NZ CAA. > > Given that you have an EFIS with a remote flux valve that acts as > your primary source of magnetic heading, you don't need the whiskey > compass to read accurately most of the time. I wonder if it might be > acceptable to put a placard by the whiskey compass that said "SD-20 > Alternator must be OFF to use compass". Then make a compass > correction card that is only valid if the SD-20 is OFF. > > Kevin Horton > > > On 25 Mar 2008, at 19:51, Carl Morgan wrote: > > vii(at)rvproject.gen.nz> > > > > Hi Matt, > > > > Thanks for the ideas, I'm really not that concerned about the whiskey > > compass functionality - if I've lost all my other mag direction > > indicators - > > the engine has stopped, so I don't really care about direction ;-) > > However > > the CAA so far is and the calibration card per regs has to be > > within 10 > > degrees :-(. > > > > SD-20 off / disconnected - yes I think the compass reads right - > > but we are > > dual bus (two independent active buses), not endurance / essential > > bus - so > > both alts need to be running / working. > > > > Wire routing - the B lead and field goes aft from the SD-20 to the > > firewall, > > left across the top of the firewall, aft again through the firewall > > and back > > to a mid location for the regulator which is on a tray between the > > forward > > panel ribs (RV 7A Tipup). > > > > Remote compass - it could yet be the option - but I don't like to > > even think > > about the routing of the cables through the tunnel / spar / wing..... > > > > Regards, > > > > Carl > > -- > > Carl Morgan - ZK-VII - RV 7A > > http://www.rvproject.gen.nz/ > > > >> -----Original Message----- > >> From: owner-aeroelectric-list-server(at)matronics.com > >> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > >> Matt > >> Prather > >> Sent: 26 March 2008 11:59 > >> To: aeroelectric-list(at)matronics.com > >> Subject: RE: AeroElectric-List: B&C SD-20 and magnetic interference > >> > >> > >> > >> > >> Are _you_ concerned about the function of the whiskey compass? If > >> not > >> (given the other equipment on board), do your best to come up with a > >> calibration card for it and call it good. > >> > >> Side question.. I got the impression that your compass reads > >> accurately > >> when the field is turned off on the SD-20. Can the SD-20 be used > >> only > >> when your main alternator is off line? If so, the only time your > >> compass > >> will have a problem is if the main alternator fails. I could live > >> with > >> that.. > >> > >> Also, what's the wire routing of the output and field of the SD-20 > >> (with > >> respect to the compass? Is it possible that the wire routing is > >> contributing to the B-field generated by the SD-20? Is the ground > >> following a different route than the field and output wires? I'm > >> pretty > >> sure Bob's assessment of the cause of your headache was correct, > >> but I > >> wonder if there might be additional factors... > >> > >> In a different direction, you can get a remote compass from Century > >> Instruments: > >> > >> http://www.trade-a-plane.com/dispads/0000769074.pdf > >> > >> Kinda spendy at $500 for the kit.. And, I don't know if it actually > >> satisfies the requirement. > >> > >> > >> Regards, > >> > >> Matt- > >> > >>> > >>> > >>> Hi Bob, > >>> > >>> Removing the 'whiskey compass' could / will result in my aircraft > >>> being > >>> grounded. I have been round the loop with the NZ CAA and the > >> 'need' for a > >>> traditional compass, I already have a GRT EFIS with > >> magnetometer, IFR GPS > >>> and still not enough. At the moment it is going to be an up cliff > >>> paperwork > >>> struggle. > >>> > >>> Removing the SD-20 is a 'better' option from their perspective, > >> but with a > >>> full FADEC I'm not comfortable with just dual battery, single > >> alternator - > >>> and having got to this point where the engine is running great > >>> (or too > >>> well) > >>> removing the SD-20 isn't an option either. Distance changing > >> is going to > >>> be > >>> in the order of 1" difference, unless I mounted it in the baggage > >>> compartment. What options can be used to reduce the magnetic > >> impact - is > >>> it > >>> a luck of the draw with the SD-20 - ie. they all vary abit? We > >>> are only > >>> taking 3-4 amps under normal operations. I understand some > >>> interference > >>> coming out, but what is 'too much'? > >>> > >>> WRT: > >>>> This is NOT a downside checkmark on the blackboard > >>>> for the B&C SD-20. ALL alternators have a steel > >>>> shaft that runs through the device parallel > >>>> to the magnetic lines of force generated in > >>>> the field windings. > >>> > >>> My biggest complaint is there is NO indication or warnings about > >>> this > >>> anywhere in the instruction / website information - I would have > >>> reconsidered the panel layout with this information, as it is I'm > >>> fixed > >>> without major rework and it is affecting my Autopilot backup and > >>> one of > >>> the > >>> few instruments the regulator is specifically interested in.... > >>> > >>> How can I reduce this interference at the source - hopefully a small > >>> reduction will be enough to get calibration within spec. > >>> > >>> Thanks, > >>> > >>> Carl > >>> -- > >>> Carl Morgan - ZK-VII - RV 7A > >>> http://www.rvproject.gen.nz/ > >>> > >>>> -----Original Message----- > >>>> From: owner-aeroelectric-list-server(at)matronics.com > >>>> [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of > >>>> Robert L. Nuckolls, III > >>>> Sent: 26 March 2008 00:12 > >>>> To: aeroelectric-list(at)matronics.com > >>>> Subject: Re: AeroElectric-List: B&C SD-20 and magnetic interference > >>>> > >>>> > >>>> III" > >>>> > >>>> > >>>>> > >>>>> > >>>>> Hi, > >>>>> > >>>>> We have been running for about 20 hours now chasing different > >>>> problems. One > >>>>> outstanding one is magnetic interference from the SD-20 / LR3 > >>>> combination. > >>>>> We have a TSO'd vertical card compass (and yes it is a southern > >>>> hemisphere > >>>>> model) mounted in the middle of the panel area (center/center). > >>>> We are dual > >>>>> alt / dual bus configuration. > >>>>> > >>>>> When the field wire is connected to the SD-20 (lower connection) > >>>> we get up > >>>>> to 40 degree swing on the compass - it does vary in amount > >>>>> (from 20-40 > >>>>> degrees) based on direction - south seems the worst. Pulling > >> the field > >>>>> breaker causes it swings back about 30 degrees, but the > >>>> regulator / alt are > >>>>> still have an affect. > >>>>> > >>>>> B&C are saying some swing is 'normal' - but 40 degrees - I'm > >>>> struggling! I > >>>>> can't calibrate that much out (best effort so far is +- 15 > >>>>> degrees). > >>>>> > >>>>> I've tried changing the location / orientation of the regulator > >>>>> - no > >>>>> difference. I've tried moving another wet compass around the > >>>>> panel / > >>>>> cockpit - it looks like same problem (although a bit hard to > >>>>> tell). > >>>>> > >>>>> I've tried running some grounded braid around the firewall > >>>> forward side of > >>>>> the field wire - no change. Same symptoms on ground, air, zero > >>>> RPM and full > >>>>> power. There may be a small movement (< 3 degrees) based on > >>>>> current > >>>> draw > >>>>> from SD-20. With SD-20 field disconnected and X-Feed in - no > >> movement. > >>>>> > >>>>> Questions: > >>>>> a) Have others got this / solved this? > >>>>> b) Any suggested methods of screening the SD-20? > >>>>> > >>>>> Thanks, > >>>>> > >>>>> Carl > >>>> > >>>> > >>>> The problem is magnetic, not electrical. > >>>> Had this problem on the Bonanza too. The SD-20 > >>>> (as do most alternators) has a considerable > >>>> leakage of magnetic flux from the rotor winding. > >>>> This isn't a problem for most installations > >>>> where the alternator mounts on the front of > >>>> the engine. > >>>> > >>>> Alternators hung on the rear of the engine > >>>> are much closer to the instrument panel and > >>>> more likely to be an issue with a panel > >>>> mounted compass. > >>>> > >>>> In the Bonanza, we moved the compass off the > >>>> glareshield to a location on higher on the > >>>> windshield. Adding a magnetic shield around > >>>> the SD-20 is a pretty busy task. The shield > >>>> material would have to be magnetic and cover > >>>> the rear and perhaps the circumference of the > >>>> alternator. This has some issues with cooling, > >>>> wiring egress and labor to implement it. > >>>> > >>>> The easiest fix is to increase distance between > >>>> the compass and the alternator. Magnetic > >>>> 'radiation' is a weak propagator . . . a little > >>>> distance really helps. > >>>> > >>>> Alternatively, an electronic compass with > >>>> a remote sensor out in a wing is the best > >>>> way to achieve the highest performance > >>>> in a magnetic direction indicator. The > >>>> case can be made that since you have > >>>> 3 sources of DC power, reliability of > >>>> the electronic compass is assured. I would > >>>> also hope that you carry a hand-held GPS > >>>> in the flight bag too. > >>>> > >>>> I'm not sure I'd bother to install a > >>>> whisky compass any more. Likelihood of > >>>> ever needing one these days is about nil. > >>>> Same thing happened to buggy whips. We > >>>> were fortunate not to be plagued by the > >>>> FHA (Federal Horsecart Administration) > >>>> when the transition occurred. Hmmmm . . . > >>>> maybe they didn't really go away . . . > >>>> they just morphed into radio antennas. > >>>> > >>>> Let's be really clear about this condition. > >>>> This is NOT a downside checkmark on the blackboard > >>>> for the B&C SD-20. ALL alternators have a steel > >>>> shaft that runs through the device parallel > >>>> to the magnetic lines of force generated in > >>>> the field windings. See: > >>>> > >>>> http://www.aeroelectric.com/Pictures/Alternators/Alternator_w_Inte > >>>> rnal_Fan2.gif > >>>> > >>>> This mechanical feature insures that EVERY > >>>> alternator will present a strong external > >>>> magnetic field. It's a system integration problem > >>>> that seldom presents but has multiple solutions > >>>> for maintaining flight-system reliability. The > >>>> REAL problem is getting those-who-know-more- > >>>> about-airplanes-than-we-do to join us in > >>>> the 21st century. > >>>> > >>>> Bob . . . > >>>> > >>>> > > > Checked by AVG. > 25/03/2008 10:26 > Checked by AVG. 10:26 ________________________________________________________________________________
Subject: Alternator
Date: Mar 25, 2008
Try Vans web store (www.vansaircraft.com). They have alt brackets for reasonable prices. However, having gone down this road myself, I would recommend going with the PP alternator. I first bought the Vans mounts and later switched to the PP. You'll be really happy with it and their mounting brackets. Mike _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bryan Sent: Tuesday, March 25, 2008 2:26 PM Subject: AeroElectric-List: Alternator I have a 12V 60A Chrysler alternator that came with the engine I am rebuilding. Unfortunately I do not have the brackets for this alternator. Does anyone know where to get brackets for a reasonable price (I don't even know what part number), or would I be better off just going with a Plane Power kit? Thanks Bryan ________________________________________________________________________________
Date: Mar 25, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: oddball 0.25" fast-on terminal source?
> >D, > I had the same issue and bought a roll of AMP tin plated for 18-22 >AWG wire. >DigiKey P/N A27933CT-ND >AMP P/N 60295-2 >If these will help send me your address off list and I will mail you a few. >I bought 100 and needed 3 :( I just couldn't think of butt splices on the >Alternator wires. Why butt splice? You can do a very compact, robust solder splice. See: http://aeroelectric.com/articles/Tech_Tips/Solder_Lap_Splicing/Solder_Lap_Splices.html Bob . . . ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: DME/Transponder Suppression
Good Morning Don and 'Lectric Bob, I imagine you are both aware of this, but just in case some others may not be, the GPS is a legal substitute for any published IFR DME function. The GPS must be in an IFR approved installation configuration, but it does not have to be approach approved, just enroute and terminal approved. The substitution is approved in the entire US National Airspace system and in many other countries as well. Happy Skies, Old Bob AKA Bob Siegfried N3977A Downers Grove, IL In a message dated 3/25/2008 6:25:57 A.M. Central Daylight Time, nuckolls.bob(at)cox.net writes: Have you considered a GPS receiver in lieu of DME? DME works with a hand full of ground stations while GPS will give you distance to any point on the surface of the earth. DME is one of those electronic buggy whips that needs to be moved to the museum. Bob . . . **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 26, 2008
> > >Hi Matt, > >Thanks for the ideas, I'm really not that concerned about the whiskey >compass functionality - if I've lost all my other mag direction indicators - >the engine has stopped, so I don't really care about direction ;-) However >the CAA so far is and the calibration card per regs has to be within 10 >degrees :-(. > >SD-20 off / disconnected - yes I think the compass reads right - but we are >dual bus (two independent active buses), not endurance / essential bus - so >both alts need to be running / working. If you have a cross-feed, then just about every individual who knows- more-about-airplanes-than-we-do will accept a fall back position for dealing with failures that might present other limits as well. Assuming that all other "normal" methods for pointing the nose in the right direction are no longer available, then shutting the SD-20 OFF, closing the cross-feed contactor, reducing total loads to that of the main alternator and flying with a now acceptable performance from the antiquated pointing device is a perfectly valid 'plan-B'. >Wire routing - the B lead and field goes aft from the SD-20 to the firewall, >left across the top of the firewall, aft again through the firewall and back >to a mid location for the regulator which is on a tray between the forward >panel ribs (RV 7A Tipup). The B-lead comes into the cockpit? Where are your batteries? The B-lead can and should be well away from the instrument panel and tie to fat-wires through a small ANL or MAXI fuse. I presume that you're seeing maximum effect with the engine at idle while doing the Mexican hat-dance at the compass rose. These are the conditions where current in the b-lead is least . . . perhaps even zero while current through the field is maxed out. The regulator is hollering down to the engine room for "more power Mr. Scott . . . I need MORE power". Of course, at low engine RPM, the regulator isn't going to get what it wants to see and field current and associated external effects are at their maximums. >Remote compass - it could yet be the option - but I don't like to even think >about the routing of the cables through the tunnel / spar / wing..... Then consider the special ops protocols for getting the whisky compass to live in the real world of a highly capable, failure tolerant electrical system. Perhaps some day, those-who-know- more-about-airplanes-than-we-do will allow us to relegate the once venerable magnetic direction indicator to the function of hood ornaments. Bob . . . ________________________________________________________________________________
Date: Mar 26, 2008
Subject: RE: B&C SD-20 and magnetic interference
. . . a luck of the draw with the SD-20 - ie. they all vary abit? We are only taking 3-4 amps under normal operations. I understand some interference coming out, but what is 'too much'? WRT: "This is NOT a downside checkmark on the blackboard for the B&C SD-20. ALL alternators have a steel shaft that runs through the device parallel to the magnetic lines of force generated in the field windings." My biggest complaint is there is NO indication or warnings about this anywhere in the instruction / website information - I would have reconsidered the panel layout with this information, as it is I'm fixed without major rework and it is affecting my Autopilot backup and one of the few instruments the regulator is specifically interested in.... How can I reduce this interference at the source - hopefully a small reduction will be enough to get calibration within spec. It wouldn't hurt to drop B&C a note suggesting that their install literature be appropriately enhanced. But in their defense, this is not a common occurrence . . . you COULD be having a similar problem by routing some fat wire too close to the compass . . . or some other system integration problem like installing one of the older DC motor driven turn indicators too close and having interference from its internal magnets. It's unfortunate that after all the work you've put into the airplane (and being so VERY close to finished) that this problem should become the longest pole in your tent. Welcome to the real world of aviation products design and qualification! 95% of my services to clients on the TC side of the house right now involve chasing $100 rats from multi-million dollar airplanes . . . with those-who-know-more-about-airplanes-than-we-do holding the type certification hostage until the flight system is pest-free. A well considered and easily demonstrated low-risk plan-B for making the compass readings fall within specs is the no-hardware, no hammers-n-saws approach to getting your machine blessed until it's legal to move the "hood ornament" out onto the cowl. Interestingly enough, I recall sometime in the past seeing a compass installation that was on a bracket just outside the windscreen. I think it was put there to get outside the cage of a day-vfr, rag-n-tube machine that was too badly magnetized to allow calibration of the compass when installed in it's normal position within the cockpit. Bob . . . ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: S700-2-1 wiring
>Bob or any other electrical wizard... > >Used a S700-2-1 DPDT on-off-on switch to wire my avionics master switch to >include panel lights for 'main bus' and 'bat bus'. >wired it like this: > #3 bat bus & light post #4 light post > > #2 avionics bus #5 grnd > > #1 main bus & light post #6 light post > >When I toggle 'bat bus' instruments come on - no light >When I toggle 'off' - everything off >When I toggle 'main bus' - everything off > >When I turn master switch on(battery Cessna Split Switch) > 'bat bus' instruments come on - no light > 'off' - > everything off > 'main bus' instruments on - no light >What am I doing wrong to get no lights? New switch from B&C. Lights from >B&C 12V - Lights work-checked separately direct to battery. >Thanks in advance. >Mike H 9A/8A Mike, can you do a schematic of how your system is wired and post a scan to the List? I'm not sure my mental image based on your words is an accurate depiction of the electron map. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: RE: Whisky compass(was B&C SD-20 and magnetic interference)
Date: Mar 26, 2008
> > Then consider the special ops protocols for getting the whisky > compass to live in the real world of a highly capable, failure > tolerant electrical system. Perhaps some day, those-who-know- > more-about-airplanes-than-we-do will allow us to relegate the > once venerable magnetic direction indicator to the function of > hood ornaments. > > Bob . . . Just for fun, will somebody please explain why do you Americans call "Whisky" to the magnetic compass? Is it because you only follow that needle when you had too much scotch before flying :-) Carlos ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: RE: Whisky compass(was B&C SD-20 and magnetic
interference) Carlos, Many many moons ago the damping fluid for the magnetic compass was alcohol as it was cheep, readily available and would not freeze. Good building and great flying, Bob B On Wednesday, March 26, 2008, at 07:52AM, "Carlos Trigo" wrote: > > >> >> Then consider the special ops protocols for getting the whisky >> compass to live in the real world of a highly capable, failure >> tolerant electrical system. Perhaps some day, those-who-know- >> more-about-airplanes-than-we-do will allow us to relegate the >> once venerable magnetic direction indicator to the function of >> hood ornaments. >> >> Bob . . . > > >Just for fun, will somebody please explain why do you Americans call >"Whisky" to the magnetic compass? > >Is it because you only follow that needle when you had too much scotch >before flying >:-) > >Carlos > > ________________________________________________________________________________
Subject: Am I correct.......
Date: Mar 26, 2008
..........That message number 19 for Wed, 26Mar08 is over 330 lines long? Why? Ferg ________________________________________________________________________________
Subject: Question about Resistors
Date: Mar 26, 2008
I have lights! The resistors worked great and my mock up works great. The pins on the Stanley LED's are standard to a project board so mounting them will be easier than I first thought. I am going to do a burn-in and temperature test this weekend to make sure I am not generating heat. For a low voltage, non-critical application like this, would it be acceptable to use a solder bridge for the pins I need to bridge? On the 5 LED bars, you have to bridge 2-3, 4.5, 6-7, 8-9. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: Tuesday, 25 March, 2008 17:01 Subject: RE: AeroElectric-List: Question about Resistors That is the formula I was looking for. Thank you. The light bars themselves, have 5 LED's so those will go in a series. My last trick will be mounting them and the wiring of said LED's. I am hoping a blank project circuit board will do what I want. The trick with the circuit board will be the spacing requirements (space between light bars). Once that is figured, I can order the face (reverse engraved acrylic). I am also working on a "push-to test" option. As far as the intensity, since these will be behind a reverse engraved acrylic (black behind clear) only the letters themselves will light up. Once I get the mock up completed, the day/night intensity testing will be performed. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vernon Little Sent: Tuesday, 25 March, 2008 15:46 Subject: RE: AeroElectric-List: Question about Resistors Hi Scott: Here's the formula: R = (Vbatt-Vf)/If ohms, where Vf is 1.7 V and If is 20 ma (from datasheet) For the part you chose, R = (14.2-1.7)/0.020 = 625 ohms (use 680 ohm standard value) -- if you power each segment seperately. If you connect all 5 of the LEDs in series, then R = (14.2 - 5*1.7)/0.020 285 ohms (use 330 ohm standard value). Now, here's one issue to deal with: If you are dimming the LEDs, you may want to power each segment separately so that they dim the same as other displays in the cockpit. Only experimentation will give you the answer for this. Finally, you may want to try one light bar first before you commit to using them in a panel. They may have a tendency to wash out in bright sunlight. I used to sell a product line that used similar light bars, and this was an issue unless you carefully shield the display from ambient light (such as locating right underneath the glareshield). I found some 1/8" LEDs that will dazzle your eyes, but they were very difficult to dim due to their intensity. Of course, they were tiny and not easy to label!. Good luck. Vern Little. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: March 25, 2008 12:59 PM Subject: AeroElectric-List: Question about Resistors Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/contribution ________________________________________________________________________________
From: "Andrew Butler" <andrewbutler(at)ireland.com>
Date: Mar 26, 2008
Subject: Aux power and the battery
All, I have two general queries that I would like some help on. 1. I have purchased an AC to 12V 5A DC power supply. I would like to use this as an ad-hoc power for install and testing of components through the build. I was thinking of attaching a standard male cigaratte lighter plug to the leads and then use a female recepticle to receive and power the bus. What issues do I need to consider? What will happen if I do this while the battery (an Odyssey PC680) is left attached to the system? 2. I have purchased a two stage charger. Is it kohser to charge the battery through the same female cigaratte power port? Thanks for your help. Andrew Butler. RV71700 - Finishing kit. Galway, Ireland. ________________________________________________________________________________
Date: Mar 26, 2008
interference) Along with following the needle after too much Scotch, sit back and watch the fun when your over-prepared student finds a good spot to stick his flashlight with the magnetic catch. (This really happened.) Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Carlos Trigo Sent: Wednesday, March 26, 2008 4:31 AM Subject: AeroElectric-List: RE: Whisky compass(was B&C SD-20 and magnetic interference) > > Then consider the special ops protocols for getting the whisky > compass to live in the real world of a highly capable, failure > tolerant electrical system. Perhaps some day, those-who-know- > more-about-airplanes-than-we-do will allow us to relegate the > once venerable magnetic direction indicator to the function of > hood ornaments. > > Bob . . . Just for fun, will somebody please explain why do you Americans call "Whisky" to the magnetic compass? Is it because you only follow that needle when you had too much scotch before flying :-) Carlos ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Splicing was (oddball 0.25" fast-on terminal source?)
Bob, Although I have been splicing wire for 45 years I prefer #1 no splices, #2 properly crimped gas tight connectors, or #3 strain relieved connections soldered to a terminal #4 would be a mid span splice. In most cases I will install a connector mid wire run if it may need to be broken for service, or ease of assembly. That said the fewer connections the less likelihood for failure. In the case of the alternator connector any splice adds mass that is hanging a few inches from the connector that then must be supported to prevent it moving in relation to the alternator and breaking the wiring. Yes it's doable but in keeping with KISS I just used the proper terminal as designed. And yes I did splice a few wires mid span in my project, no I didn't need to but I just got lazy and didn't want to pull a longer wire. They will outlast both me and the plane. No worries, the electrons don't know the difference. :) Thanks for all you do, we have all learned a lot. Ralph -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, March 25, 2008 10:56 PM Subject: RE: AeroElectric-List: oddball 0.25" fast-on terminal source? > >D, > I had the same issue and bought a roll of AMP tin plated for 18-22 >AWG wire. >DigiKey P/N A27933CT-ND >AMP P/N 60295-2 >If these will help send me your address off list and I will mail you a few. >I bought 100 and needed 3 :( I just couldn't think of butt splices on the >Alternator wires. Why butt splice? You can do a very compact, robust solder splice. See: http://aeroelectric.com/articles/Tech_Tips/Solder_Lap_Splicing/Solder_Lap_Sp lices.html Bob . . . ________________________________________________________________________________
From: "Tom Barter" <kesleyelectric(at)chooseblue.coop>
Subject: METCAL tip cartridges
Date: Mar 26, 2008
I am looking for a recommendation of a couple of Metcal STTC tip cartridges for the MX-RM3E wand. The power supply is a PS2E-01. For 63/37 solder, is the 600 degree tip appropriate? For soldering fat wires, it seems that the STTC-045 or -145 tip would be appropriate. Not sure about a tip for smaller, general propose soldering. Any advice from well acquainted users would be welcome. Tom Barter Kesley, IA Avid Magnum ________________________________________________________________________________
From: "Richard T. Schaefer" <schaefer@rts-services.com>
Date: Mar 26, 2008
Make sure you have the right polarity. If the power supply does not handle short circuits (internal current limit and shutdown) you might want to fuse it. _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Andrew Butler Sent: Wednesday, March 26, 2008 11:39 AM Subject: AeroElectric-List: Aux power and the battery All, I have two general queries that I would like some help on. 1. I have purchased an AC to 12V 5A DC power supply. I would like to use this as an ad-hoc power for install and testing of components through the build. I was thinking of attaching a standard male cigaratte lighter plug to the leads and then use a female recepticle to receive and power the bus. What issues do I need to consider? What will happen if I do this while the battery (an Odyssey PC680) is left attached to the system? 2. I have purchased a two stage charger. Is it kohser to charge the battery through the same female cigaratte power port? Thanks for your help. Andrew Butler. RV71700 - Finishing kit. Galway, Ireland. ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: Question about Resistors
In a message dated 03/25/2008 3:15:23 PM Central Daylight Time, sshook(at)cox.net writes: I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. Hi Scott- I used the same LEDs and they've worked quite nicely for 4 years/almost 500 hours. Here's the arrangement I cobbled together: _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7604_ (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=7604) click on foto for larger view. Drawing available in AutoCAD if you'd like a copy... >From The PossumWorks in TN Mark Phillips, RV-6A "Mojo" _http://websites.expercraft.com/n51pw/_ (http://websites.expercraft.com/n51pw/) **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: Aux power and the battery
>All, I have two general queries that I would like some help on. > >1. I have purchased an AC to 12V 5A DC power supply. I would like to use >this as an ad-hoc power for install and testing of components through the >build. I was thinking of attaching a standard male cigaratte lighter plug >to the leads and then use a female recepticle to receive and power the >bus. What issues do I need to consider? What will happen if I do this >while the battery (an Odyssey PC680) is left attached to the system? 12 volts is a bit too low to be run in parallel with a battery. Generally speaking, 12v power supplies are crafted for energizing electronics. Since 12v batteries in vehicles need 13.8 minimum (14.2 better) to co-exist with a power source, the supply you have could be used for limited testing as a stand-alone source of power. >2. I have purchased a two stage charger. Is it kohser to charge the >battery through the same female cigaratte power port? If it's an automotive "smart charger", what is it's rated capacity for charging? The BEST way to power your airplane from the AC mains is to acquire some form of smart charger. Exemplar devices can be viewed in this .pdf catalog from Schumacher. http://www.schumacherproducts.com/assets/pdf/sec_catalog.pdf I have a couple of Schumacher products, one of which is good for 25A in the recharge mode. I'll need to do some tests with it but my thinking is that devices like these could be permanently connected across your ship's battery and plugged into the wall. Their microprocessor smarts should react to keep the battery charged irrespective of how much "stuff" you test. This should work even large loads and relatively small smart chargers. Of course the battery will have to make up the difference between what say a 2A charger will put out and a 10A test load. But as soon as you shut things off, the battery charger can be trusted to do its thing and bring the battery back up to 100%. If you'd like to have a power supply that emulates "real" vehicular power, watch for 13.8 volt devices sold to power mobile electronics in the house. I used to sell the Samlex 1223 and a kit to make it emulate an alternator. You could plug it into wall, hook it to the alternator's b-lead and have it respond to the cockpit alternator control switch. Sitting in the left seat, everything on the panel worked as if you had an engine running with a 23A alternator on it. See: http://tinyurl.com/2zdt3u I've always recommended that builders not buy a new battery until the airplane was ready to fly. During construction phases, a lawn tractor battery and a plug-in-the-wall power supply would let you get everything running in the airplane without abusing a brand new flight-battery. A smart charger connected across the battery is a reasonable substitute for a high-quality power supply. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 26, 2008
Sure if it is on a battery bus. Maybe not a good idea if you have to leave a battery contactor energised. Ken > > 2. I have purchased a two stage charger. Is it kohser to charge the > battery through the same female cigaratte power port? > > Thanks for your help. > > Andrew Butler. > RV71700 - Finishing kit. > Galway, Ireland. > ________________________________________________________________________________
Date: Mar 26, 2008
>Make sure you have the right polarity. > >If the power supply does not handle short circuits (internal current limit >and shutdown) you might want to fuse it. Good points! Bob . . . ________________________________________________________________________________
Date: Mar 26, 2008
Subject: Re: METCAL tip cartridges
>I am looking for a recommendation of a couple of Metcal STTC tip >cartridges for the MX-RM3E wand. The power supply is a PS2E-01. For >63/37 solder, is the 600 degree tip appropriate? For soldering fat wires, >it seems that the STTC-045 or -145 tip would be appropriate. Not sure >about a tip for smaller, general propose soldering. Any advice from well >acquainted users would be welcome. > > We've used only Metcal soldering irons in the shop now for 10 years. I have three in various locations in my facilities and a couple more I loan out to folks who put stuff together for me. To date, I've found no finer tool (that I can afford) for the task. The Metcal catalog for STTC series tips can be downloaded at: http://www.aeroelectric.com/Mfgr_Data/Tools/Metcal/Metcal_Tips.pdf The heaviest tip for fat-wire work is the #65. I've installed terminals on 4AWG wire with this critter. It takes awhile but it will do it. The commonly found tips in the wild are 000 hundred (600F) or 100 series (700F). For 63/37 solder, it doesn't matter much for most work. I'm interested in getting some really fine 500 series tips for working some really tiny stuff. For general soldering tasks, a #25, 04 or 36 will serve you well. I have a few tips like the #45 for soldering down those parts surface mounted parts fitted with copper "cat-hair" for leads. I presume you're watching the offerings on ebay. Most of my tips came in assortments of used where some were pretty rough but I got them cheap and enough good tips in the lot to make it a good value. But there's some really reasonable offerings for new, single tips. Bob . . . ________________________________________________________________________________
Date: Mar 26, 2008
Tom Barter wrote: > > I am looking for a recommendation of a couple of Metcal STTC tip > cartridges for the MX-RM3E wand. The power supply is a PS2E-01. For > 63/37 solder, is the 600 degree tip appropriate? For soldering fat > wires, it seems that the STTC-045 or -145 tip would be appropriate. > Not sure about a tip for smaller, general propose soldering. Any > advice from well acquainted users would be welcome. > > > > Tom Barter > > Kesley, IA > > Avid Magnum > > > I soldered more connections than I want to think about using old Weller soldering stations in another life. I always opted for 700 degree tips. My logic was that with half-way decent technique, the extra temp can actually reduce the chance of damaging components. It drives the joint temperature up quicker, giving less time for the heat to spread out into critical areas you *don't* want heated up. It can also extend the usefulness of an iron that's marginal for the mass of the joint you're trying to solder. The extra temperature increases the effective thermal 'mass' available to heat a big joint. It's a pretty safe bet that others will have different opinions. Charlie ________________________________________________________________________________
Date: Mar 26, 2008
In a message dated 03/26/2008 11:37:31 AM Central Daylight Time, sshook(at)cox.net writes: For a low voltage, non-critical application like this, would it be acceptable to use a solder bridge for the pins I need to bridge? >>> That's exactly what I did, on a standard project board like you mentioned- bend the prongs over and nail 'em with a touch of solder. Only difference is I used the 3-LED blocks instead of the 5... see: _http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5135_ (http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5135) I'll also mention that I chose slightly smaller resistors than would normally be called for to brighten them up a bit. Consider that these annunciators are typically illuminated for relatively short periods of time and even if overdriven, they will likely outlast your airplane. I tested this by intentionally overdriving sample blocks well over their limit for about two weeks continuous with no failures. I would also recommend buying several spares of each specific block you use- they are really cheap, and you never know how long an identical item will be available for replacement, if ever needed. Neat stuff... Mark **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15?ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 26, 2008
Scott: surf to aircraftextras.com here: http://aircraftextras.com/VxAviation.htm <http://www.vx-aviation.com/page_2.html#IL-4A,%20IL-12A_more> The IL-4A controller can be used to drive lamps, and support various polarities of input signals. It also allows you to connect to your dimmer and supports push-to-test. Vern -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: March 25, 2008 5:01 PM Subject: RE: AeroElectric-List: Question about Resistors That is the formula I was looking for. Thank you. The light bars themselves, have 5 LED's so those will go in a series. My last trick will be mounting them and the wiring of said LED's. I am hoping a blank project circuit board will do what I want. The trick with the circuit board will be the spacing requirements (space between light bars). Once that is figured, I can order the face (reverse engraved acrylic). I am also working on a "push-to test" option. As far as the intensity, since these will be behind a reverse engraved acrylic (black behind clear) only the letters themselves will light up. Once I get the mock up completed, the day/night intensity testing will be performed. Scott R. Shook RV-7A (Building) N696JS (Reserved) _____ From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Vernon Little Sent: Tuesday, 25 March, 2008 15:46 Subject: RE: AeroElectric-List: Question about Resistors Hi Scott: Here's the formula: R = (Vbatt-Vf)/If ohms, where Vf is 1.7 V and If is 20 ma (from datasheet) For the part you chose, R = (14.2-1.7)/0.020 = 625 ohms (use 680 ohm standard value) -- if you power each segment seperately. If you connect all 5 of the LEDs in series, then R = (14.2 - 5*1.7)/0.020 285 ohms (use 330 ohm standard value). Now, here's one issue to deal with: If you are dimming the LEDs, you may want to power each segment separately so that they dim the same as other displays in the cockpit. Only experimentation will give you the answer for this. Finally, you may want to try one light bar first before you commit to using them in a panel. They may have a tendency to wash out in bright sunlight. I used to sell a product line that used similar light bars, and this was an issue unless you carefully shield the display from ambient light (such as locating right underneath the glareshield). I found some 1/8" LEDs that will dazzle your eyes, but they were very difficult to dim due to their intensity. Of course, they were tiny and not easy to label!. Good luck. Vern Little. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott R. Shook Sent: March 25, 2008 12:59 PM Subject: AeroElectric-List: Question about Resistors Bob et al, I am putting together an annunciator panel using some Stanley LED Light Bars PN# (404-1148-ND). And if I read correctly on the spec sheet from Digikey, the voltage is 1.7v per LED. This being the case, do you have a 'cheat sheet' showing what resistors I would need to provide the appropriate voltage drop for our 14v OBAM aircraft? Scott R. Shook RV-7A (Building) N696JS (Reserved) href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matro nics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c http://www.matronics.com/Navigator?AeroElectric-List http://forums.matronics.com http://www.matronics.com/contribution ________________________________________________________________________________
From: "mike humphrey" <mike109g6(at)insideconnect.net>
Date: Mar 27, 2008
Bob, I figured out what was wrong. I didn't realize that the indicator lights were LEDS and must be wired differently from bulbs. White dot on side of light housing apparently meant 12v source. When I wired it that way(had it reversed) the lights came on. HooRahh!. Thanks for responding, wiring is completed-at last. Mike H 9A/8A ----- Original Message ----- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> Sent: Wednesday, March 26, 2008 7:49 AM Subject: Re: AeroElectric-List: S700-2-1 wiring > > > >>Bob or any other electrical wizard... >> >>Used a S700-2-1 DPDT on-off-on switch to wire my avionics master switch to >>include panel lights for 'main bus' and 'bat bus'. >>wired it like this: >> #3 bat bus & light post #4 light >> post >> >> #2 avionics bus #5 grnd >> >> #1 main bus & light post #6 light >> post >> >>When I toggle 'bat bus' instruments come on - no light >>When I toggle 'off' - everything >>off >>When I toggle 'main bus' - everything off >> >>When I turn master switch on(battery Cessna Split Switch) >> 'bat bus' instruments come on - no light >> 'off' - >> everything off >> 'main bus' instruments on - no light >>What am I doing wrong to get no lights? New switch from B&C. Lights from >>B&C 12V - Lights work-checked separately direct to battery. >>Thanks in advance. >>Mike H 9A/8A > > Mike, can you do a schematic of how your system is wired > and post a scan to the List? I'm not sure my mental image > based on your words is an accurate depiction of the electron > map. > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > ________________________________________________________________________________
Subject: Using NC Switches
Date: Mar 27, 2008
3/27/2008 Hello Again Tom, I am disappointed that nobody on the aeroelectric list responded to your request that I forwarded to them for help on using NC switches . (See copy below) Let me take a stab at your request and if I provide bum information maybe one of the experts on the list (even Bob Nuckolls) may step in and provide correct, or better, information. There are small electrical relays, commonly called "ice cube relays" because of their size, that can be used for the purpose that you want -- providing an electrical signal when all you have available for control is a NC (normally closed) switch in your aircraft's control grip. Here is one such relay available from B&C -- I am sure that there are many others: http://www.bandc.biz/S704-1_tips.html It has a 12 volt activated coil and two contacts activated by the slug that is moved when electricity is applied to the relay coil. One of the contacts is labeled NC (normally closed) and the other is labeled NO (normally open). Status A) If there is no electricity flowing through the relay coil the relay NC contact is connected to the relay common contact and the relay NO contact is not connected to the relay common contact. Status B) When there is electricty flowing through the relay coil the relay NC contact is disconnected from the relay common contact and the relay NO contact is connected to the relay common contact. You can wire one side of the NC switch in your control grip with a wire leading to one of the relay coil contacts. Then you can wire the other relay coil contact on to aircraft ground. Then you can wire the other side of the NC switch in the control grip to a live electrical source in the aircraft. You will have created a continuous electric flow through the coil and the relay and its contacts will be in status B above. Now you determine whatever electrical signal is to be sent to the transponder in order to have it ident and wire a continuous source of that signal to the transponder through the relay common and the relay NC contacts. Because you are in status B there is no connection between the relay common connection and the relay NC contact and the transponder will not ident. When you depress the button for the NC switch in your control grip the relay will go into status A and an ident signal will be sent to the transponder as long you keep the button for the NC switch on the control grip depressed. Realize that there are some downsides to this arrangement: 1) There will be a continuous drain on your electrical system to keep the relay coil activated at all times except for the brief moments when you depress the NC switch button on the control grip. 2) If you have a wiring disconnect beween the NC switch on the control grip and the relay the transponder will receive a continuous signal to ident. There are probably more elegant electrical solutions to solving this problem and one could eliminate the two downsides listed above by using two relays to accomplish the ident (or other actions desired), but that is left as an exercise for the reader. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." PS: I realize that HOTAS (Hands On Trottle And Stick) is appealing to some homebuilders as a high tech form of snobbery, but it ain't my cup of tea. I fly in a pretty intense radar coverage environment (the Washington DC ADIZ) and I bet that in the past several years that it has been in effect that I haven't been asked to ident more than 4 or 5 times. Not a big deal to just reach over and push the button on my transponder. ----------------------------------------- 3/12/2008 Hello Tom, You wrote: 1) "For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch?" We used to say that having helicopter time in your pilot's logbook was like having an STD entry (it was called venereal disease back then) in your health record. So I will reluctantly admit that I did fly a helicopter (CH-46) for a year in Viet Nam. The cyclic grip had a button on it that when pressed would disconnect the electronic flight stability / attitude positioning system so that one could manually reposition the stick and the helicopter's attitude then releasing the button would reengage the electronic attitude positioning system. Maybe you have a control stick grip that does something similar. 2) "Again, is there any way I can wire it to work with my remote ident operation?" I am not the right guy to answer that question, but I am sure that by using two of the small "ice cube" type relays that ident operation could be accomplished. It might be a pretty awkward way of doing it though from an electrical viewpoint. I'll forward your question to the Matronic's aeroelectric-list and maybe one of the electrical experts there (even the great guru Bob Nuckolls) would take a shot at it. 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." --------------------------------------------------------------------------- ----- Original Message ----- From: "Tom Gibbons" <TomisFlyingby(at)comcast.net> Sent: Wednesday, March 12, 2008 12:25 AM Subject: Electrical question On my military surplus control stick I have 4 push buttons, 2 wired normally opened (NO) and 2 wired normally closed (NC). I really do not have access to these switches so I have to make due but can I use the NC switches somehow? I have plans for comm flip/flop, nav flip/flop, and Ident for my transponder. I actually have a "hattie" switch in the middle for trim which is not hooked up. The stick is installed with the ptt and intercom trigger switches working good. All kinds of switches on this guy. Was not going to use it but hey, it felt so comfortable, why not. For clarification, the NC switch means that I press the button to actually cut the power. Why would this be used on an old military helicopter stick? What is the reason for cutting the power on a switch? Again, is there any way I can wire it to work with my remote ident operation? Tom ________________________________________________________________________________
Date: Mar 27, 2008
Thanks very much Bob. Here is the charger I bought: http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=12204&doy=27m3 #spec How does it look? Andrew. ----- Original Message ----- From: "Robert L. Nuckolls, III" To: aeroelectric-list(at)matronics.com Subject: Re: AeroElectric-List: Aux power and the battery Date: Wed, 26 Mar 2008 20:19:39 -0500 > All, I have two general queries that I would like some help on. > > 1. I have purchased an AC to 12V 5A DC power supply. I would like to use this as an ad-hoc > power for install and testing of components through the build. I was thinking of attaching a > standard male cigaratte lighter plug to the leads and then use a female recepticle to receive > and power the bus. What issues do I need to consider? What will happen if I do this while the > battery (an Odyssey PC680) is left attached to the system? 12 volts is a bit too low to be run in parallel with a battery. Generally speaking, 12v power supplies are crafted for energizing electronics. Since 12v batteries in vehicles need 13.8 minimum (14.2 better) to co-exist with a power source, the supply you have could be used for limited testing as a stand-alone source of power. > 2. I have purchased a two stage charger. Is it kohser to charge the battery through the same > female cigaratte power port? If it's an automotive "smart charger", what is it's rated capacity for charging? The BEST way to power your airplane from the AC mains is to acquire some form of smart charger. Exemplar devices can be viewed in this .pdf catalog from Schumacher. http://www.schumacherproducts.com/assets/pdf/sec_catalog.pdf I have a couple of Schumacher products, one of which is good for 25A in the recharge mode. I'll need to do some tests with it but my thinking is that devices like these could be permanently connected across your ship's battery and plugged into the wall. Their microprocessor smarts should react to keep the battery charged irrespective of how much "stuff" you test. This should work even large loads and relatively small smart chargers. Of course the battery will have to make up the difference between what say a 2A charger will put out and a 10A test load. But as soon as you shut things off, the battery charger can be trusted to do its thing and bring the battery back up to 100%. If you'd like to have a power supply that emulates "real" vehicular power, watch for 13.8 volt devices sold to power mobile electronics in the house. I used to sell the Samlex 1223 and a kit to make it emulate an alternator. You could plug it into wall, hook it to the alternator's b-lead and have it respond to the cockpit alternator control switch. Sitting in the left seat, everything on the panel worked as if you had an engine running with a 23A alternator on it. See: http://tinyurl.com/2zdt3u I've always recommended that builders not buy a new battery until the airplane was ready to fly. During construction phases, a lawn tractor battery and a plug-in-the-wall power supply would let you get everything running in the airplane without abusing a brand new flight-battery. A smart charger connected across the battery is a reasonable substitute for a high-quality power supply. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- =========== =========== =========== =========== ________________________________________________________________________________
Date: Mar 27, 2008
Don't have much to add over what Bob said, except I can echo his comments. We only use Metcal here as well...tried just about every type out there and Metcal seems to have the best reliability vs functionality. I have over a dozen of them, and I would agree with him on tips. I too buy them off Ebay once and awhile because sometimes they are a deal! Cheers, Stein >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Robert >L. Nuckolls, III >Sent: Wednesday, March 26, 2008 8:51 PM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: METCAL tip cartridges > > > > > >>I am looking for a recommendation of a couple of Metcal STTC tip >>cartridges for the MX-RM3E wand. The power supply is a PS2E-01. For >>63/37 solder, is the 600 degree tip appropriate? For soldering >fat wires, >>it seems that the STTC-045 or -145 tip would be appropriate. Not sure >>about a tip for smaller, general propose soldering. Any advice from well >>acquainted users would be welcome. >> >> > > We've used only Metcal soldering irons in the shop now for > 10 years. I have three in various locations in my facilities > and a couple more I loan out to folks who put stuff together for > me. To date, I've found no finer tool (that I can afford) for > the task. > > The Metcal catalog for STTC series tips can be downloaded > at: > >http://www.aeroelectric.com/Mfgr_Data/Tools/Metcal/Metcal_Tips.pdf > > The heaviest tip for fat-wire work is the #65. I've installed > terminals on 4AWG wire with this critter. It takes awhile but > it will do it. The commonly found tips in the wild are 000 hundred > (600F) or 100 series (700F). For 63/37 solder, it doesn't matter > much for most work. I'm interested in getting some really fine > 500 series tips for working some really tiny stuff. > > For general soldering tasks, a #25, 04 or 36 will serve you well. > I have a few tips like the #45 for soldering down those parts > surface mounted parts fitted with copper "cat-hair" for leads. > > > I presume you're watching the offerings on ebay. Most of > my tips came in assortments of used where some were pretty > rough but I got them cheap and enough good tips in the lot > to make it a good value. But there's some really reasonable > offerings for new, single tips. > > Bob . . . > > ________________________________________________________________________________
Date: Mar 27, 2008
FWIW, I use a variable voltage (1-14 VDC) power supply <* http://tinyurl.com/ypdhy6/>* to test run the electrical equipment. It can be run at 13.8VDC for routine operational tests, or the voltage can be progressively lowered to test low voltage monitors, etc. Ron ________________________________________________________________________________
Subject: METCAL soldering irons
Date: Mar 27, 2008
What will happen if I buy an American (110V-60Hz) soldering iron and connect it directly (without a transformer) to an European (220V-50Hz) power socket? Do I get some smoke? Carlos ________________________________________________________________________________
Date: Mar 27, 2008
Subject: Re: METCAL soldering irons
"Carlos Trigo" wrote: > > What will happen if I buy an American (110V-60Hz) soldering iron and connect > it directly (without a transformer) to an European (220V-50Hz) power socket? > Do I get some smoke? > > Carlos > Yes! Later if not sooner. I would bet on sooner. Bob W. -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/cables/ ________________________________________________________________________________
Subject: Any Ray Allen LED Dimming Circuit ideas?
Date: Mar 27, 2008
Hello, Panel is all wired up, just some fine tuning. One item is that the Ray Allen LED trim indicators are too bright when switched to =BD brightness. I have scanned the net for a way to convert them to a linear dimming range but have found nothing. I am at point of installing a switch to turn them off except when needed. I am hoping someone has a more elegant (read cheap) solution. They=92re already mounted in the panel so chucking them is not an option. Thanks! Vince H. Idaho ' RV-8 VSB (Very Slow Built) Finish ________________________________________________________________________________
Subject: Alternator Breaker Pop
Date: Mar 27, 2008
I am performing my first engine runs with a Jabiru 3300 powered Zenith 601XL. This is a PM alternator and my wiring is based on the Z16 architecture using the S704-1 alternator control and crowbar OV protection. So far everything is working just fine with one exception. Of the 10 or so engine starts I have made, twice I found the 5A alternator breaker popped. This is the breaker between the main bus and the master switch. On both occasions, the engine was at idle and I shut it down then re-started it after a few moments. It was after the start that I noticed the popped breaker. I don't know if the breaker popped on shutdown or during the re-start. In either case I was able to reset the breaker and all appeared to be OK. Anybody have any ideas on what is going on here? All the volt and amp numbers I have seen are "in the green." Do shutdown or start-ups cause nuisance pops? Thanks, DaveG -------- David Gallagher 601 XL, all major assemblies complete. Have run the engine and am starting final assembly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=173164#173164 ________________________________________________________________________________
Date: Mar 27, 2008
Subject: Re: Using NC Switches
>--------------------------------------------------------------------------- >----- Original Message ----- From: "Tom Gibbons" <TomisFlyingby(at)comcast.net> >To: "Pulsar List" >Sent: Wednesday, March 12, 2008 12:25 AM >Subject: Electrical question > > >On my military surplus control stick I have 4 push buttons, 2 wired normally >opened (NO) and 2 wired normally closed (NC). I really do not have access >to these switches so I have to make due but can I use the NC switches >somehow? >I have plans for comm flip/flop, nav flip/flop, and Ident for my >transponder. I actually have a "hattie" switch in the middle for trim which >is not hooked up. The stick is installed with the ptt and intercom trigger >switches working good. All kinds of switches on this guy. Was not going to >use it but hey, it felt so comfortable, why not. >For clarification, the NC switch means that I press the button to actually >cut the power. Why would this be used on an old military helicopter stick? >What is the reason for cutting the power on a switch? Again, is there any >way I can wire it to work with my remote ident operation? > >Tom Sorry I didn't get to this. Pretty busy around here lately . . . and I've got a new modus-operandi for dealing with the 'fun' stuff. I completely clear my in-box every couple of days so that I don't get messages stacked up for weeks that have little if any prospect of getting my attention. So posting again is not a bad idea. Exactly what do you wish to do with the NC buttons. You mentioned 4 switches total, two of which are normally closed an you inferred that you might like to use them in circuits that need NO operation. The elegant solution is dependent upon what functionality you wish the switch to perform. Relays can be used but solid state is better. Let's "talk" about it an see what works best. Bob . . . ________________________________________________________________________________
Date: Mar 27, 2008
Subject: Just for grins
Last week when I put the UltraLast cells on the hand-dandy- battery-runner-downer I had a single loose Maxell AA cell laying on the bench. I threw it on the tester at 1/6th the benchmark loads I've used to compare various brands of batteries. My benchmark testing is done at 300 mA, this cell was loaded to 50 mA. The differences in apparent capacity are pretty profound. See: http://www.aeroelectric.com/Pictures/Curves/300_vs_50mA_discharge_of_AA_cell.jpg A reduction of load to 50 mA allowed me to get twice the stored energy from the cells chemistry. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 28, 2008
Subject: Coax Stripper Clearance
I was looking through some boxes for parts on a client project and ran across some 3-blade, coax wire strippers left over from a time when we were merchandising tools and materials. This tool: http://www.aeroelectric.com/Pictures/Tools/Wire_Strippers/3-Blade_Adjustable_1.jpg produces this strip job: http://www.aeroelectric.com/Pictures/Tools/Wire_Strippers/3-Blade_Adjustable_6.jpg on RG-58/400/141 coax making it ready to install a connector: http://www.aeroelectric.com/Pictures/Tools/Wire_Strippers/3-Blade_Adjustable_9.jpg It's adjustable and comes with the right size Allen wrench to set depths for other styles of coax. I have about a dozen of these and will make them available to folks for $10 each plus $1.30 postage for a total of $11.30 You can place an order on our secure order form at: https://matronics.com/aeroelectric/Catalog/AECcatalog.html Put a note in the comments box that you want a coax stripper. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 28, 2008
Subject: Re: Just for grins
Robert L. Nuckolls, III wrote: > > See: > > http://www.aeroelectric.com/Pictures/Curves/300_vs_50mA_discharge_of_AA_cell.jpg > > > A reduction of load to 50 mA allowed me to get twice > the stored energy from the cells chemistry. When designing the battery configuration, I will get more than twice the energy from the system if I wire the batteries in parallel? Could you run a test with 150mA load? That would simulate dual batteries loaded in parallel vs a single battery. ________________________________________________________________________________
Subject: Re: Any Ray Allen LED Dimming Circuit ideas?
Date: Mar 28, 2008
From: "Glaeser, Dennis A" <dennis.glaeser(at)eds.com>
The LED units have a lead which dims them when connected to 12v. It's an on-off type of thing as far as I know, no way to use a dimming circuit. I'm using the Perihelion Dimmer which has a switched output as well as a dimmed output. I connected the Trim indicators dimmer wire to the switched side, so when I turn on my interior lights, the trim indicators dim. Dennis Glaeser RV7A - first flight planned for tomorrow! --------------------------------------------------- Hello, Panel is all wired up, just some fine tuning. One item is that the Ray Allen LED trim indicators are too bright when switched to =BD brightness. I have scanned the net for a way to convert them to a linear dimming range but have found nothing. I am at point of installing a switch to turn them off except when needed. I am hoping someone has a more elegant (read cheap) solution. They=92re already mounted in the panel so chucking them is not an option. Thanks! Vince H. Idaho ' RV-8 VSB (Very Slow Built) Finish ________________________________________________________________________________
Subject: Re: Alternator Breaker Pop
Date: Mar 28, 2008
A wire could be intermittently shorting to ground or there could be an over-voltage condition. Shut off all expensive electronics, then try disconnecting the wire at the master switch that goes to the over-voltage module and see if the problem goes away. If it does, then there could be an over-voltage condition. The battery should help prevent voltage spikes. Does the battery contactor remain energized until the engine stops turning? -------- Joe Gores Read this topic online here: http://forums.matronics.com/viewtopic.php?p=173273#173273 ________________________________________________________________________________
Date: Mar 28, 2008
Along the lines of the current thread, what is the best way to connect the power supply/ charger? Can a 20A charger be connected via the b-lead to sim ulate alternator current to the system, or should the charger always be con nected across the battery. Same for a dedicated power supply? I'm also loo king for a good power supply while I work through the avionics configuratio n and familiarization of the systems. Jim RV-7 Getting Close ________________________________________________________________________________
Date: Mar 28, 2008
>Along the lines of the current thread, what is the best way to connect the >power supply/ charger? Can a 20A charger be connected via the b-lead to >simulate alternator current to the system, or should the charger always be >connected across the battery. Same for a dedicated power supply? I m also >looking for a good power supply while I work through the avionics >configuration and familiarization of the systems. A "power supply" is generally clean and stable enough to be stand alone energy source for running things in your airplane or on the bench. A "battery charger" may not . . . and the best way to use a charger is to connect it permanently across the battery and then use the battery to run ship's systems. Any of the power supply products rated for an output voltage of "13.8" will be a stand-alone product designed to run loads up to and including it's rated output current. Do a Goggle search on 13.8 power supply and you get a wad of hits. I'd recommend something on the order of 20A or better capability like a Samlex 1223 . . . but there are many serviceable products. See: http://www.nextag.com/13.8vdc-power-supply/search-html http://www.radiodan.com/misc/samlex1223.htm Bob . . . ________________________________________________________________________________
Date: Mar 28, 2008
> > >Robert L. Nuckolls, III wrote: >> >>See: >> >>http://www.aeroelectric.com/Pictures/Curves/300_vs_50mA_discharge_of_AA_cell.jpg >> >> >>A reduction of load to 50 mA allowed me to get twice >>the stored energy from the cells chemistry. >When designing the battery configuration, I will get more than twice the >energy from the system if I wire the batteries in parallel? Could you run >a test with 150mA load? That would simulate dual batteries loaded in >parallel vs a single battery. EXCELLENT question. Actually, doubling the batteries up in parallel will get you MORE than twice the energy. The reasoning here is that energy lost in the battery's internal resistance is a Watt=I(squared)*R function. Went to the bench an measured one of those same Maxell cells open circuit at 1610 mV. I put a 25 ohm load across the cell and it dropped to 1580 for a difference of 30 millivolts. The load was 1580mV/25ohms = 63mA . Therefor the internal resistance of this cell is 30mV/63mA or about 475 milliohms. Okay, 475 milliohms loaded to 300 mA will drop 140 millivolts and toss off .140v x .3A or 42 milliwats of heat. Now, let us connect two cells in parallel. Each cell now sees 1/2 the total load or .15A x .475 ohms = 71 millivolts drop and .071 x .15 = 10 milliwatts of heating. Considering the two cells in parallel they now each toss off 10 milliwatts for a TOTAL of 20 milliwatts . . . where the single cell was tossing off twice that amount with the same load. Paralleling cells has the effect of paralleling internal resistance (making it go down) while doubling the chemical mass (electrical capacity). Given that current in each internal resistance falls by 1/2, the power dissipated in each falls to 1/4th the original thus allowing both cells to deliver more of their content while doubling their total potential energy as a team. Lowering effective internal resistance is always a good thing for return on investment in electro-chemical energy. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2008
Subject: Strippers are all spoken for.
Gee guys . . . I didn't expect such a quick response! Thanks. I'll fill your requests in order received and let the late-comers know that they were just too late. These strippers are readily available for only slightly more than what I asked. In fact, I think they're generally 9.95 in the wild . . . but they hit you a bit harder for s/h. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: Strippers are all spoken for.
Date: Mar 28, 2008
On 28 Mar 2008, at 17:38, Robert L. Nuckolls, III wrote: > > > Gee guys . . . I didn't expect such a quick response! Thanks. > I'll fill your requests in order received and let the late-comers > know that they were just too late. These strippers are readily > available for only slightly more than what I asked. In fact, > I think they're generally 9.95 in the wild . . . but they > hit you a bit harder for s/h. The problem is that while there may be some very acceptable strippers available for $10, there is also a lot of junk for sale too. When purchasing online, it is hard to tell the jems from the junk. We trust your judgement, so if you tell us that a particular $10 stripper is a jem, people will buy it to avoid having to deal with junk. -- Kevin Horton RV-8 (FInal Assembly) Ottawa, Canada http://www.kilohotel.com/rv8 ________________________________________________________________________________
Subject: AMR-350 pin-out
Date: Mar 28, 2008
Hey guys, does anybody out there have an electronic copy of the Collins Audio Panel (AMR-350) pin-out diagram? If so, can you share it with me? Thanks! Michael H. ________________________________________________________________________________
Subject: Re: Using NC SwitchesElectrical question
Date: Mar 28, 2008
Gentleman, I have seen this before where someone finds it necessary to be able to activate the IDENT function of the transponder from the control stick. I have to ask: How often does one have to IDENT in one flight, what is the chance of activating it accidentally, and just how far would you really have to reach otherwise? Robert Seccombe 35 years ATP ________________________________________________________________________________
Date: Mar 28, 2008
Subject: Re: AMR-350 pin-out
>Hey guys, does anybody out there have an electronic copy of the Collins >Audio Panel (AMR-350) pin-out diagram? If so, can you share it >with me? Thanks! > >Michael H. > See: http://www.aeroelectric.com/Installation_Data/ Bob . . . ________________________________________________________________________________
Date: Mar 28, 2008
> >On 28 Mar 2008, at 17:38, Robert L. Nuckolls, III wrote: >> >> >>Gee guys . . . I didn't expect such a quick response! Thanks. >>I'll fill your requests in order received and let the late-comers >>know that they were just too late. These strippers are readily >>available for only slightly more than what I asked. In fact, >>I think they're generally 9.95 in the wild . . . but they >>hit you a bit harder for s/h. > >The problem is that while there may be some very acceptable strippers >available for $10, there is also a lot of junk for sale too. When >purchasing online, it is hard to tell the jems from the junk. We >trust your judgement, so if you tell us that a particular $10 >stripper is a jem, people will buy it to avoid having to deal with junk. Understand. Those who missed out on the 'sale' are encouraged to see: http://www.gilchrist-electric.com/3-blade-coax-cable-strip.php These are the folks I bought them from at 25 to 50 at a whack when we were selling them. Bob . . . ________________________________________________________________________________
Date: Mar 28, 2008
> > >I am performing my first engine runs with a Jabiru 3300 powered Zenith >601XL. This is a PM alternator and my wiring is based on the Z16 >architecture using the S704-1 alternator control and crowbar OV >protection. So far everything is working just fine with one >exception. Of the 10 or so engine starts I have made, twice I found the >5A alternator breaker popped. This is the breaker between the main bus >and the master switch. On both occasions, the engine was at idle and I >shut it down then re-started it after a few moments. It was after the >start that I noticed the popped breaker. > >I don't know if the breaker popped on shutdown or during the re-start. In >either case I was able to reset the breaker and all appeared to be OK. > >Anybody have any ideas on what is going on here? All the volt and amp >numbers I have seen are "in the green." Do shutdown or start-ups cause >nuisance pops? The crowbar ov protection module has been known to trip on system noises. I've helped a number of builders track down a noise source that was irritating the OVM-14. How long have you had your OV module? There were some changes about 4-5 years ago that made them more resistant to all but the worst noises. This is a pretty rare condition. It could also be that your particular OVM has a problem. You can send it to me for a checkout and update too if you've had it a very long time. I've not built and sold these for about 6 years but I can help you tame the little beast. Bob . . . ________________________________________________________________________________
Subject: Shadin ADC-200
Date: Mar 29, 2008
I'm installing a Shadin ADC-200 to display air-data/fuel-flow on my Garmin GPS-400. Does anybody know if the ADC-200 will accept OAT information from my already-installed Davtron M307FC or will I have to install a separate OAT probe? Also, does anybody know which fuel flow sensors are compatible with the ADC-200 (my aircraft has a Lycoming O-360 and a 28v electrical system). Thanks, Don ________________________________________________________________________________
Date: Mar 29, 2008
Bob, I have purchased all of my electrical parts since September so barring any of it sitting on B&C's shelves for a long time, everything should be fairly new. I have not had the chance to go over the system wire-by-wire yet. I will report back after I have had the chance. Thanks, -------- David Gallagher 601 XL, all major assemblies complete. Have run the engine and am starting final assembly. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=173387#173387 ________________________________________________________________________________
Date: Mar 29, 2008
Geez, I go out of town for a few days and the List turns to debauchery! Bob, you better hope Dee doesn't hear about this! Bret Smith RV-9A N16BL Blue Ridge, Ga www.FlightInnovations.com ________________________________________________________________________________
Date: Mar 29, 2008
Subject: Two New Lists Added to the Matronics Lineup!
Dear Listers, I've added two new Email Lists to the Matronics List and Forum lineup today. These include the Rans-List and RV12-List. Please surf over to the Matronics List Subscription page and sign up for these new Lists if they are of interest to you: http://www.matronics.com/subscribe Full support on the Forums, List Browse, Archives, etc. is available. Rans-List: http://www.matronics.com/Navigator?Rans-List RV12-List http://www.matronics.com/Navigator?RV12-List Best regards, Matt Dralle Matronics Email List Administrator ________________________________________________________________________________
Date: Mar 30, 2008
Subject: Adding to your bag of tricks . . .
I put new laminated hardwood flooring down in our house about a year ago. I added quite a pile of cut-offs and left over pieces to my pile of skunk-werks materials in the shop. In the interim I've found a number of instances where this material proved handy and quite capable to a variety of tasks. It's quite hard . . . almost machineable. I've used it to assemble small enclosures for electronics. At .320" thick the edges are wide enough to fabricate good glue joints for assembling. E6000 works good here. I've also drilled the edges to glue threaded metal spacers for attaching edge-on with machine screws. The wood grain finish is a bit quaint for enclosures but attractive and certainly resistant to scratches. IT IS FLOORING after all. I put the finishing touches on my junk box environmental chamber last night with this flooring. The chamber came without a top closure panel. http://www.aeroelectric.com/Pictures/Misc/Temperature_Chamber_1.jpg This picture was taken before the countersunk, flat-heads were installed to hold the lid on. It's quite rigid and will support any test equipment I might place on top. You can lock pieces of this stuff together (glue in the joints before final assembly) and make virtually any size flat sheet desired. Make sure it's well mated and laying absolutely flat while the glue dries. It's a bit heavy (1.5# sq/ft) but IT IS FLOORING after all. I use black magic marker to finish cut edges. It's hell-for-stout in longitudinal bending . . . obviously, glue joints are the weakest link for bending across the joints. I've used small scraps for various fixtures and as small parts in assemblies (like corner gussets). Stores like Big Lots carry boxes of this stuff at pretty attractive prices (avoid flooring with foam backing already bonded on). When my scrap pile no longer addresses my needs, I'll have no problem going out to buy another box just to cut up! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 30, 2008
Subject: Re: Splicing was (oddball 0.25" fast-on terminal source?)
In a message dated 3/26/2008 5:33:25 P.M. Central Daylight Time, hooverra(at)verizon.net writes: --> AeroElectric-List message posted by: "RALPH HOOVER" Bob, Although I have been splicing wire for 45 years I prefer #1 no splices, #2 properly crimped gas tight connectors, or #3 strain relieved connections soldered to a terminal #4 would be a mid span splice. In most cases I will install a connector mid wire run if it may need to be broken for service, or ease of assembly. That said the fewer connections the less likelihood for failure. In the case of the alternator connector any splice adds mass that is hanging a few inches from the connector that then must be supported to prevent it moving in relation to the alternator and breaking the wiring. Yes it's doable but in keeping with KISS I just used the proper terminal as designed. And yes I did splice a few wires mid span in my project, no I didn't need to but I just got lazy and didn't want to pull a longer wire. They will outlast both me and the plane. No worries, the electrons don't know the difference. :) Thanks for all you do, we have all learned a lot. Ralph -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Tuesday, March 25, 2008 10:56 PM Subject: RE: AeroElectric-List: oddball 0.25" fast-on terminal source? --> AeroElectric-List message posted by: "Robert L. Nuckolls, III" >--> AeroElectric-List message posted by: "RALPH HOOVER" > >D, > I had the same issue and bought a roll of AMP tin plated for 18-22 >AWG wire. >DigiKey P/N A27933CT-ND >AMP P/N 60295-2 >If these will help send me your address off list and I will mail you a few. >I bought 100 and needed 3 :( I just couldn't think of butt splices on the >Alternator wires. Why butt splice? You can do a very compact, robust solder splice. See: http://aeroelectric.com/articles/Tech_Tips/Solder_Lap_Splicing/Solder_Lap_Sp lices.html Bob . . . **************Create a Home Theater Like the Pros. Watch the video on AOL Home. (http://home.aol.com/diy/home-improvement-eric-stromer?video=15&ncid=aolhom00030000000001) ________________________________________________________________________________
Date: Mar 31, 2008
Subject: Connecting External Power Supply
Guys, For an external power supply such as Samlex 1223, if this is connected at t he alternator, I assume the + lead can be connected directly to the B-lead. Does the - lead just connect to the engine or any common ground to simulat e the alternator power? Jim ________________________________________________________________________________
Date: Mar 31, 2008
> Panel is all wired up, just some fine tuning. One item is that the Ray Allen LED trim indicators are too bright when switched to ? brightness. > > I have scanned the net for a way to convert them to a linear dimming range but have found nothing. I am at point of installing a switch to turn them off except when needed. Vince H. Idaho RV-8 The LM3914 Bar Graph Driver chip used by RAC/MAC is a clever little device. But it has its limitations too. Usually people don't complain about the bright "Day" output, since most airplanes have too much sun in them anyway. But if you want to dim the bright output, you can add a 28K or so (a 50k 10-turn pot might be nice) between the white lead and +, instead of being left open. The "Night" output is connected to + directly, but there is a design limitation to be understood...since the driver for the LEDs are in the chip, there is a limit to the dynamic range that can be programmed. 10 to 1 is all you can get by ordinary means. The "Night" output brightness is about at the bottom now, so you can't get more dim. "A witty saying proves nothing" --Voltaire -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=173937#173937 ________________________________________________________________________________
Date: Mar 31, 2008
Subject: E-Buss diode vs. Switch
I am planning to follow Aeroelectric's Z13 / 8 diagram; but as I've started wiring, I was looking at the diode that separates the e-buss from the main buss. In use, the diode allows power to flow from the main to the e-buss in normal use. However, should the main buss fail, the pilot 'flips' a switch to allow power to flow from the Battery buss to the e-buss and power cannot feed the main buss because of the diode. My question is this; why not eliminate the diode and replace the on-off switch with an on-on switch so power is fed either from the Battery Buss or the Main Buss but never both? Either way the pilot manually changes the switch and the diode is not needed (and you eliminate any voltage reduction due to the diode). Apparently I'm missing something, can somewhat explain what that is? Thanks much, Harold ________________________________________________________________________________
Date: Mar 31, 2008
Subject: Re: E-Buss diode vs. Switch
The purpose of the E-bus is to be able to achieve a rapid load reduction in case of either alternator failure, main battery contactor failure, or a stuck starter. To understand the need for the diode approach, you need to examine your switching alternatives and the effect on running equipment under each scenario if you use a switch instead of a diode. For example, if the alternator has failed, which will normally be deduced from falling voltage, you will need to switch THREE switches (alternate feed ON, contactor OFF, inter-bus OFF) to get to the load reduction -- otherwise the alternate feed will back feed the main bus. If you switch in the wrong sequence (harder to avoid with three) you may also shut down and/or reboot gear you'd, uh, rather keep running. :-) Either way, that's "suboptimal". If the main battery contactor fails, you still have three switches to throw to be sure you're settling things down, and if you don't flip three or are unsure of the problem, you are still feeding current to the downstream side of a battery contactor that is at best in an uncertain condition. If you have a stuck starter (whether contactor or motor) you''re back to having to flip three switches. The voltage drop associated with the diode is a minimal price to pay for the simplicity and reliability of the diode approach. Note that when you have feed through the main bus and diode, you're going to be running with the alternator/regulator in play anyway, and by definition should have more than adequate of voltage even through the diode. Further, that voltage drop can be greatly minimized to the point of being inconsequential by using a Schottky diode, such as those available from Perihelion. Bottom line, the voltage drop issue only exists when you have an alternator anyway, it can be minimized by using a Schottky, and you will have fewer switches to maintain, and flip. Ron On Mon, Mar 31, 2008 at 3:07 PM, Harold Lanfear wrote: > I am planning to follow Aeroelectric's Z13 / 8 diagram; but as I've > started wiring, I was looking at the diode that separates the e-buss from > the main buss. In use, the diode allows power to flow from the main to the > e-buss in normal use. However, should the main buss fail, the pilot 'flips' > a switch to allow power to flow from the Battery buss to the e-buss and > power cannot feed the main buss because of the diode. > > My question is this; why not eliminate the diode and replace the on-off > switch with an on-on switch so power is fed either from the Battery Buss or > the Main Buss but never both? Either way the pilot manually changes the > switch and the diode is not needed (and you eliminate any voltage reduction > due to the diode). Apparently I'm missing something, can somewhat explain > what that is? Thanks much, Harold > > * > > * > > ________________________________________________________________________________
Subject: KLN90B Lighting
Date: Mar 31, 2008
I'm working on the wiring harness for my KLN90B GPS. The instructions for the lighting circuits are not 100% clear to me. There are three pins for a 14V install: two for "Lighting Bus Low" (pins 28 and 32) and one "14 V DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the installation manual are attached). Where should these be sourced? More specifically, what is a "LO" source? Is the "14 V DC Panel Lighting Bus" the dimmer switch? .or am I wrong on both counts? Is there something else that I'm missing? This will be a VFR installation. Thanks, Michael H. ________________________________________________________________________________
Date: Apr 01, 2008
Subject: Large Gauge Wire Crimper
I saw this under homemade tools for a Volvo. Ron Parigoris Large Gauge Wire Crimper. [Tip from Tom Harper] Ever needed to get a solidly crimped electrical terminal on larger cables (8 - 4 gauge), but found the cost of crimp tools in that size to cause "sticker shock"? Here's something I've been doing - it works for UNinsulated terminals. 1. Measure the OD of the uninsulated terminal barrel you need to crimp 2. Find (or buy - a dime or so) a nut with a thread size (thread OD - not ID) equal to or slightly smaller than the size in step 1 3. Drill out the nut to match the terminal OD 4. Cut the nut in half, across opposing corners (NOT across the flats). Your Dremel tool will come in handy for this - a hacksaw will do it also, just takes more time. 5. Find a piece of round stock about 1/8" - 3/16" (3-4 mm) diameter, about 3/8" (1 cm) long (you can cut the head off a screw for this - the threads won't affect anything.) You now have a "saddle" and a "punch" (halved nut & screw/round stock piece). 6. Put the terminal in the "saddle", and the "punch" lying lengthwise on top of the terminal, opposite the "saddle" - you'll probably want to tape the assembly together, otherwise it takes 3 or 4 hands. 7. Put the cable end into the terminal, and crimp the whole works together using a bench vise, Vise-Grips, or equivalent. The "saddle" supports the bottom of the terminal, while the "punch" crimps everything nice & tight. I've gotten really tight & secure crimps on up to 4 gauge cable by hand with this method. After a dozen or so uses, the nut may crack & start to spread; no problem, since you have the other half, and making new "saddles" is easy & cheap anyway. Make sure your terminal barrel ID is close to the wire OD - this method doesn't do too well if there's a lot of empty space between the wire and the terminal. You may be a bit clumsy at first, but once you work out a way to keep everything aligned as you start the crimp, it'll go really well. The new Vice-Grip adjustable wrench is ideal for this - the "V"-shaped jaw is ideal for supporting the "saddle". Volvo content - used this trick yesterday when making some "overkill" (4 gauge) engine-to-body ground and alternator-to-starter terminal cables. ________________________________________________________________________________
Date: Apr 01, 2008
Subject: Re: KLN90B Lighting
Michael, I suspect the LO connections are just panel lighting grounds and HI is supply voltage for your panel lighting. There may be other opinions on this . As an aside, I've just bought a used KLN90B and I'm looking for instal/user manuals. Any chance of copies or links to same? thanks, Ian - in Canberra On Tue, Apr 1, 2008 at 11:01 AM, Michael Hinchcliff wrote: > I'm working on the wiring harness for my KLN90B GPS. The instructions > for the lighting circuits are not 100% clear to me. There are three pin s > for a 14V install: two for "Lighting Bus Low" (pins 28 and 32) and one > "14 V DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the > installation manual are attached). Where should these be sourced? More > specifically, what is a "LO" source? Is the "14 V DC Panel Lighting Bus " > the dimmer switch? =85or am I wrong on both counts? Is there something > else that I'm missing? This will be a VFR installation. > > > Thanks, > Michael H. > ________________________________________________________________________________
Date: Mar 31, 2008
>Im working on the wiring harness for my KLN90B GPS. The instructions for >the lighting circuits are not 100% clear to me. There are three pins for >a 14V install: two for Lighting Bus Low (pins 28 and 32) and one 14 V >DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the >installation manual are attached). Where should these be sourced? More >specifically, what is a LO source? Is the 14 V DC Panel Lighting Bus >the dimmer switch? or am I wrong on both counts? Is there something >else that Im missing? This will be a VFR installation.' There are two strings of 14v lights in series. The 14V wiring grounds the top end of the 28V string and drives the center with the two ends in parallel. For 28V, the 14V center tap is left open and one of the 14V "lo" connections becomes the 28V lighting load. Bob . . . ________________________________________________________________________________
Date: Mar 31, 2008
>I am planning to follow Aeroelectric's Z13 / 8 diagram; but as I've >started wiring, I was looking at the diode that separates the e-buss from >the main buss. In use, the diode allows power to flow from the main to >the e-buss in normal use. However, should the main buss fail, the pilot >'flips' a switch to allow power to flow from the Battery buss to the >e-buss and power cannot feed the main buss because of the diode. > >My question is this; why not eliminate the diode and replace the on-off >switch with an on-on switch so power is fed either from the Battery Buss >or the Main Buss but never both? Either way the pilot manually changes >the switch and the diode is not needed (and you eliminate any voltage >reduction due to the diode). Apparently I'm missing something, can >somewhat explain what that is? Thanks Voltage drop in diode is not significant. Use of single switch offers a single point of failure for BOTH power paths to the e-bus. Recommend you wire as depicted. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 31, 2008
Subject: Re: Connecting External Power Supply
>Guys, > > >For an external power supply such as Samlex 1223, if this is connected at >the alternator, I assume the + lead can be connected directly to the >B-lead. Does the lead just connect to the engine or any common ground to >simulate the alternator power? Yes. ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 31, 2008
>The purpose of the E-bus is to be able to achieve a rapid load reduction >in case of either alternator failure, main battery contactor failure, or a >stuck starter. To understand the need for the diode approach, you need to >examine your switching alternatives and the effect on running equipment >under each scenario if you use a switch instead of a diode. > >For example, if the alternator has failed, which will normally be deduced >from falling voltage, you will need to switch THREE switches (alternate >feed ON, contactor OFF, inter-bus OFF) to get to the load reduction -- >otherwise the alternate feed will back feed the main bus. If you switch in >the wrong sequence (harder to avoid with three) you may also shut down >and/or reboot gear you'd, uh, rather keep running. :-) Either way, that's >"suboptimal". > >If the main battery contactor fails, you still have three switches to >throw to be sure you're settling things down, and if you don't flip three >or are unsure of the problem, you are still feeding current to the >downstream side of a battery contactor that is at best in an uncertain >condition. If you have a stuck starter (whether contactor or motor) >you''re back to having to flip three switches. > >The voltage drop associated with the diode is a minimal price to pay for >the simplicity and reliability of the diode approach. Note that when you >have feed through the main bus and diode, you're going to be running with >the alternator/regulator in play anyway, and by definition should have >more than adequate of voltage even through the diode. Further, that >voltage drop can be greatly minimized to the point of being >inconsequential by using a Schottky diode, such as those available from >Perihelion. > >Bottom line, the voltage drop issue only exists when you have an >alternator anyway, it can be minimized by using a Schottky, and you will >have fewer switches to maintain, and flip. > >Ron Excellent treatise on the subject sir . . . Bob . . . >On Mon, Mar 31, 2008 at 3:07 PM, Harold Lanfear ><hlanfear(at)verizon.net> wrote: >>I am planning to follow Aeroelectric's Z13 / 8 diagram; but as I've >>started wiring, I was looking at the diode that separates the e-buss from >>the main buss. In use, the diode allows power to flow from the main to >>the e-buss in normal use. However, should the main buss fail, the pilot >>'flips' a switch to allow power to flow from the Battery buss to the >>e-buss and power cannot feed the main buss because of the diode. >> >>My question is this; why not eliminate the diode and replace the on-off >>switch with an on-on switch so power is fed either from the Battery Buss >>or the Main Buss but never both? Either way the pilot manually changes >>the switch and the diode is not needed (and you eliminate any voltage >>reduction due to the diode). Apparently I'm missing something, can >>somewhat explain what that is? Thanks much, Harold >> >> ________________________________________________________________________________
Date: Mar 31, 2008
Subject: Off line for a few days.
I'm climbing into the big iron bird tomorrow morning to join my co-conspirators at the facilities of a couple of clients. Then instead of coming straight home I'll be joining Dr. Dee in KC for some goof-off time. There's a really good Mexican restaurant and a couple of good BBQ places we plan to visit! Be back Sunday. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Mar 31, 2008
An avionics guy explained to that Low is another word for ground. My icom and ps engineering audio panel used the same terms and that is how I wired them. Jerry ----- Original Message ----- From: Michael Hinchcliff To: aeroelectric-list(at)matronics.com Sent: Monday, March 31, 2008 8:01 PM Subject: AeroElectric-List: KLN90B Lighting I'm working on the wiring harness for my KLN90B GPS. The instructions for the lighting circuits are not 100% clear to me. There are three pins for a 14V install: two for "Lighting Bus Low" (pins 28 and 32) and one "14 V DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the installation manual are attached). Where should these be sourced? More specifically, what is a "LO" source? Is the "14 V DC Panel Lighting Bus" the dimmer switch? .or am I wrong on both counts? Is there something else that I'm missing? This will be a VFR installation. Thanks, Michael H. ________________________________________________________________________________
Date: Mar 31, 2008
Bob, If you are in KC on Thurs, I can highly recommend Tanners (sports bar) on Broadway for some EXCELLENT fillet mignon and fried shrimp. Decent salad and baked potato, too. For 10 bucks (2004 dollars) you can't beat it! Enjoy, Don > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list- > server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III > Sent: Monday, March 31, 2008 9:49 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: Off line for a few days. > > > > I'm climbing into the big iron bird tomorrow morning to join > my co-conspirators at the facilities of a couple of clients. > Then instead of coming straight home I'll be joining Dr. Dee > in KC for some goof-off time. There's a really good Mexican > restaurant and a couple of good BBQ places we plan to > visit! > > Be back Sunday. > > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > ________________________________________________________________________________
Date: Apr 01, 2008
Ian, Your are correct! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ian Edgar Sent: Monday, March 31, 2008 5:58 PM Subject: Re: AeroElectric-List: KLN90B Lighting Michael, I suspect the LO connections are just panel lighting grounds and HI is supply voltage for your panel lighting. There may be other opinions on this. As an aside, I've just bought a used KLN90B and I'm looking for instal/user manuals. Any chance of copies or links to same? thanks, Ian - in Canberra On Tue, Apr 1, 2008 at 11:01 AM, Michael Hinchcliff wrote: I'm working on the wiring harness for my KLN90B GPS. The instructions for the lighting circuits are not 100% clear to me. There are three pins for a 14V install: two for "Lighting Bus Low" (pins 28 and 32) and one "14 V DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the installation manual are attached). Where should these be sourced? More specifically, what is a "LO" source? Is the "14 V DC Panel Lighting Bus" the dimmer switch? =85or am I wrong on both counts? Is there something else that I'm missing? This will be a VFR installation. Thanks, Michael H. "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Apr 01, 2008
Bob, No offence, but based on the writing of the original post, I think your reply will be considered more confusing then the King notes on the drawing. Just having a little fun! Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Monday, March 31, 2008 6:41 PM Subject: Re: AeroElectric-List: KLN90B Lighting >Im working on the wiring harness for my KLN90B GPS. The instructions for >the lighting circuits are not 100% clear to me. There are three pins for >a 14V install: two for Lighting Bus Low (pins 28 and 32) and one 14 V >DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the >installation manual are attached). Where should these be sourced? More >specifically, what is a LO source? Is the 14 V DC Panel Lighting Bus >the dimmer switch? or am I wrong on both counts? Is there something >else that Im missing? This will be a VFR installation.' There are two strings of 14v lights in series. The 14V wiring grounds the top end of the 28V string and drives the center with the two ends in parallel. For 28V, the 14V center tap is left open and one of the 14V "lo" connections becomes the 28V lighting load. Bob . . . 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Date: Apr 01, 2008
Jerry, Also correct. 14v = Positive (HI) pin 29. Bus ground (LO) pin 28 & 32. 28v = Positive (Hi) pin 28. Bus ground (LO) pin 32 Mike -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Jerry Ricciotti Sent: Monday, March 31, 2008 7:06 PM Subject: Re: AeroElectric-List: KLN90B Lighting An avionics guy explained to that Low is another word for ground. My icom and ps engineering audio panel used the same terms and that is how I wired them. Jerry ----- Original Message ----- From: HYPERLINK "mailto:cfi(at)conwaycorp.net"Michael Hinchcliff "mailto:aeroelectric-list(at)matronics.com"aeroelectric-list(at)matronics.com Sent: Monday, March 31, 2008 8:01 PM Subject: AeroElectric-List: KLN90B Lighting I=92m working on the wiring harness for my KLN90B GPS. The instructions for the lighting circuits are not 100% clear to me. There are three pins for a 14V install: two for =93Lighting Bus Low=94 (pins 28 and 32) and one =9314 V DC Panel Lighting Bus"/HI (pin 29) (figures 2-1 and 2-17 from the installation manual are attached). Where should these be sourced? More specifically, what is a =93LO=94 source? Is the =9314 V DC Panel Lighting Bus=94 the dimmer switch? =85or am I wrong on both counts? Is there something else that I=92m missing? This will be a VFR installation. Thanks, Michael H. "http://www.matronics.com/Navigator?AeroElectric-List"http://www.matroni cs.com/Navigator?AeroElectric-List "http://forums.matronics.com"http://forums.matronics.com "http://www.matronics.com/contribution"http://www.matronics.com/contribu tion 10/2/2007 11:10 AM 10/2/2007 11:10 AM ________________________________________________________________________________
Subject: Panel lights
Date: Apr 01, 2008
Listers: anyone using Vans LED light strip part number "LC LED STRIP RED" or something similar that can tell me how it is that these can be cut to length and not have to put any voltage dropping resistors in series with the strip? Marty in Brentwood TN ________________________________________________________________________________
Subject: Transponder for sale
Date: Apr 03, 2008
Hey listers I just listed a transponder for sale on ebay. You can see it (and place bids) here <http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=626608286&site=0&ver=LCA0808 05&item=230238620596&lk=URL> http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=626608286&site=0&ver=LCA08080 5&item=230238620596&lk=URL It is a NARCO AT-155 transponder I had purchased for my RV-9A , but decided not to install because mode S became obligatory in Europe. Cheers Carlos Trigo ________________________________________________________________________________
From: "Andrew Butler" <andrewbutler(at)ireland.com>
Date: Apr 03, 2008
Subject: Re: Transponder for sale
Hey Carlos, I am having trouble finding a Mode S that won't break the bank, and it is nigh on impossible to source a Garmin GTX328 that you can install yourself. What brand are you looking at and from where? Cheers, Andrew. ----- Original Message ----- From: "Carlos Trigo" To: aeroelectric-list(at)matronics.com, avionics-list(at)matronics.com Subject: AeroElectric-List: Transponder for sale Date: Thu, 3 Apr 2008 00:39:00 +0100 Hey listers I just listed a transponder for sale on ebay. You can see it (and place bids) here http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=626608286&site=0&ver =LCA080805&item=230238620596&lk=URL It is a NARCO AT-155 transponder I had purchased for my RV-9A , but decided not to install because mode S became obligatory in Europe. Cheers Carlos Trigo =========== ======== === ________________________________________________________________________________
Date: Apr 03, 2008
All mode-S transponders are insanely expensive. I got mine (Filser TRT800) for the low, low price of 1850 Euro but that was during a special offer through Lambert Aircraft in Belgium. I'm hearing from other pilots that there are lead times of several months on any brand mode-S transponder. In The Netherlands these are mandatory as of last tuesday, but apparently due to the shortage, local authorities will go easy on us until july 1st. Rob ----- Original Message ----- From: Andrew Butler To: aeroelectric-list(at)matronics.com Sent: Thursday, April 03, 2008 4:42 PM Subject: Re: AeroElectric-List: Transponder for sale Hey Carlos, I am having trouble finding a Mode S that won't break the bank, and it is nigh on impossible to source a Garmin GTX328 that you can install yourself. What brand are you looking at and from where? Cheers, Andrew. ----- Original Message ----- From: "Carlos Trigo" To: aeroelectric-list(at)matronics.com, avionics-list(at)matronics.com Subject: AeroElectric-List: Transponder for sale Date: Thu, 3 Apr 2008 00:39:00 +0100 Hey listers I just listed a transponder for sale on ebay. You can see it (and place bids) here http://cm.ebay.com/cm/ck/1065-29296-2357-0?uid=626608286&site=0&ver= LCA080805&item=230238620596&lk=URL It is a NARCO AT-155 transponder I had purchased for my RV-9A , but decided not to install because mode S became obligatory in Europe. Cheers Carlos Trigo ist">http://www.matronics.com/Navigator?AeroElectric-List ics.com .matronics.com/contribution ________________________________________________________________________________
Subject: Re: Firewall penetration
Date: Apr 04, 2008
Mark, Do you still have any firewall passthroughs you want to sell/ The static port The static ports you sold me were great! Peter Laurence Please respond to both email addresses. plaurence@the-beach.net dr.laurence(at)mbdi.org Thanks again ________________________________________________________________________________
Date: Apr 04, 2008
Subject: Re: Transponder for sale (mode S)
Mode S is mandatory in Europe? Mode S is already obsolete in the USA. They are fighting for the next gen transponder (that will be even more expensive). http://www.aopa.org/advocacy/articles/2008/080304ads-b.html The fact is Mode S does not do anything more for general aviation. Even as a technology its based on OLD technology. So for the USA take a wait see attitude. I find it draconian that the Euro authorities mandated this. Well may be better than being in limbo as the USA fights. However for USA fliers hang on to your Mode C transponder it does all you need, position and altitude, probably for another 20 years or more. I love how the USA gave into METARS and WX reports with french words like "fume" in weather reports. Now they are just issuing unilateral rules, country by country. Some countries have even mandated 406 ELT's. So you don't have one you can't fly there. They will actually ground the plane and make you install one, I've been told. I fly international. Yes the future is sunny with data links and other fancy things, all mean nothing to me in my RV-7. I have 1970's technology, a tube TDR950 Collins. Actually I have two of them. I bought both off eBay, ones a spare. I think with both I have $500 into it, including antenna. That is progress! --------------------------------- You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost. ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Source for a VHF Diplexer Splitter
Date: Apr 05, 2008
I need to split my one nav antenna into both a nav and glide slope receiver. Where can I find an inexpensive splitter? Bill B ________________________________________________________________________________
Date: Apr 05, 2008
Subject: Re: Source for a VHF Diplexer Splitter
Bill, << I need to split my one nav antenna into both a nav and glide slope receiver. Where can I find an inexpensive splitter? >> Jim Weir of RST Engineering suggests a series resonant circuit composed of a 10pf capacitor and a total of 1 inch of lead length. You can build the splitter with a small project box, two short lengths of co-axial cable with BNC plugs on one end and a BNC jack. Run one cable through a grommet on one side of the box to the jack on the other side. Connect the shield by forming two pigtails. This cable goes to the VOR. Run the other cable through a second grommet. Strip off 1/2 inch of outer insulation, shield and inner insulation. Put some heat shrink over the cable. Cut one lead of the capacitor to 1/2 inch and solder it along the cable center conductor. Make sure the shield is well trimmed and can't touch the center conductor. Insulate with the heat shrink tube. This cable will go to the Glide Slope. Put 1/2 inch of insulation on the other lead of the capacitor. Wrap the other capacitor lead around the center post of the BNC jack with no lead showing beyond the insulation and solder. Ty-wrap the cables together and just inside the grommet to prevent pulling on the connections. This is what I'm doing for the KX-155 in my Sportsman. Can't get much simpler or cheaper. Tom Kuffel ________________________________________________________________________________
From: "earl_schroeder(at)juno.com" <earl_schroeder(at)juno.com>
Date: Apr 05, 2008
Bill, if you want to 'roll your own', try www.rst-engr.com I made one and it works. Otherwise, check Chief aircraft for low pricing. Earl -- "Bill Bradburry" wrote: I need to split my one nav antenna into both a nav and glide slope receiver. Where can I find an inexpensive splitter? Bill B ________________________________________________________________________________
Date: Apr 05, 2008
Well, Mode S is not mandatory in all European airspace, although if you fly IFR it is. There=92s still plenty of sky where no transponder at all is required, or radio for that matter ' at least for the time being. What=92s an ELT (not required in the UK)? That=92s the wonderful thing about Europe ' common rules across all of the EU ;) Peter -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of gmcjetpilot(at)yahoo.com Sent: 04 April 2008 22:52 Subject: AeroElectric-List: Re: Transponder for sale (mode S) Mode S is mandatory in Europe? Mode S is already obsolete in the USA. They are fighting for the next gen transponder (that will be even more expensive). http://www.aopa.org/advocacy/articles/2008/080304ads-b.html The fact is Mode S does not do anything more for general aviation. Even as a technology its based on OLD technology. So for the USA take a wait see attitude. I find it draconian that the Euro authorities mandated this. Well may be better than being in limbo as the USA fights. However for USA fliers hang on to your Mode C transponder it does all you need, position and altitude, probably for another 20 years or more. I love how the USA gave into METARS and WX reports with french words like "fum=E9e" in weather reports. Now they are just issuing unilateral rules, country by country. Some countries have even mandated 406 ELT's. So you don't have one you can't fly there. They will actually ground the plane and make you install one, I've been told. I fly international. Yes the future is sunny with data links and other fancy things, all mean nothing to me in my RV-7. I have 1970's technology, a tube TDR950 Collins. Actually I have two of them. I bought both off eBay, ones a spare. I think with both I have $500 into it, including antenna. That is progress! ________________________________________________________________________________
Date: Apr 05, 2008
Peter Pengilly wrote: > Mode S is mandatory in Europe? Mode S is already obsolete in the USA. > They are fighting for the next gen transponder (that will be even more > expensive). > > http://www.aopa.org/advocacy/articles/2008/080304ads-b.html > > The fact is Mode S does not do anything more for general aviation. Even > as a technology its based on OLD technology. So for the USA take a wait > see attitude. > > I find it amazing that a group of volunteers can develop a $200 laptop to distribute to children in third world countries that, as only one small part of the project, includes a mesh network technology that allows them configure themselves to talk to one another on the fly. A GPS signal (another $100) and a shared database (a correspondingly cheap FAA controlled ground-station) gives a complete information sharing system. Yet, we have a local representative advocating a "low-cost" ADS-B system that would cost around $3,000. It is simply freaking ridiculous how "those that know more than we do" continue to settle on technologies that are outdated and controlled by entrenched commercial interest to the detriment of us all. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Apr 06, 2008
Subject: Re: AeroElectric-List Digest: 4 Msgs - 04/05/08
><< I need to split my one nav antenna into both a nav and glide >slope receiver. Where can I find an inexpensive splitter? >> > You could also contact Wentworth Aircraft. They have a huge supply of salvaged bits and pieces for pretty cheap. Glen Matejcek ________________________________________________________________________________
Subject: 24-Pole Relay Needed
Date: Apr 06, 2008
I need a couple of 24-pole relays for an avionics project. Would anyone have a spare MD41-248 or MD41-24P they'd be willing to sell? Thanks, Don ________________________________________________________________________________
Date: Apr 06, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: 24-Pole Relay Needed
> > >I need a couple of 24-pole relays for an avionics project. Would anyone >have a spare MD41-248 or MD41-24P they d be willing to sell? > >Thanks, > >Don Sounds like you MIGHT be crafting a switching box for sharing a single set of displays with multiple receivers. The last time I needed that many poles I built an etched circuit board to hold 12 dpdt minature relays. If your search for single relay doesn't work out, I can probably find the artwork I laid out for the multiple relay assembly. You can order a batch of 3 boards for $59. Bob . . . ________________________________________________________________________________
Date: Apr 06, 2008
Perihelion Design sells an 18 pole relay to use as an 18-Pole CDI Switcher for VOR/GPS Receiver. It is $150 I think... http://www.periheliondesign.com/18polerelays.htm Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, April 06, 2008 4:55 PM Subject: Re: AeroElectric-List: 24-Pole Relay Needed --> > > >I need a couple of 24-pole relays for an avionics project. Would >anyone have a spare MD41-248 or MD41-24P they d be willing to sell? > >Thanks, > >Don Sounds like you MIGHT be crafting a switching box for sharing a single set of displays with multiple receivers. The last time I needed that many poles I built an etched circuit board to hold 12 dpdt minature relays. If your search for single relay doesn't work out, I can probably find the artwork I laid out for the multiple relay assembly. You can order a batch of 3 boards for $59. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2008
4/7/2008 Hello Don, You can find them here: http://www.sandia.aero/?q=system/files/MARC70Relays11-18-04.pdf 'OC' Says: "The best investment we can make is the effort to gather and understand knowledge." -------------------------------------------------- From: "Don Curry" <currydon(at)bellsouth.net> Subject: AeroElectric-List: 24-Pole Relay Needed I need a couple of 24-pole relays for an avionics project. Would anyone have a spare MD41-248 or MD41-24P they'd be willing to sell? Thanks, Don ________________________________________________________________________________
Date: Apr 07, 2008
Subject: Fat Wires & Brass vs. Copper
Bob & Listers, I'm finishing up the contactor mounting/wiring on my RV-7 firewall and about to make and mount the ground busses and ground pass-through. I'm planning on 2AWG welding cable for both battery cables, the starter cable, and the engine to firewall ground bus. Is this OK or should I use a braided strap for the engine to firewall ground? This leaves the Alternator B-Lead. 2AWG is overkill but convenient to buy and use. However, would I be better off downsizing it to a smaller gauge welding cable? I'm planning on a 60amp Plane Power alternator. I can get brass plate and bar easily and cheaply. Is it practically / functionally equivalent to copper for the main contactor to starter contactor bar? Same for the bar to connect the current limiter? Van's specs out .125 x .5 for the first and there is no spec for the second but I plan on .063 x .5 for it. Will those work in brass? I've already sourced two copper bars that are a bit thinner (.050) that are perfect size for each side of the firewall for the ground busses. I'm planning on soldering brass tabs onto them and mounting them with brass bolts through them for the fat wires? Is this OK? I've summarized these 5 questions below, and I appreciate the help. Other questions following in separate threads. George Jenson Tucson, AZ RV-7 Summary - 5 questions: 1. 2AWG welding cable OK for engine to firewall ground in lieu of braid? 2. 2AWG welding cable OK for 60amp PP alternator b-lead or should I downsize? 3. .125 x .5 brass bar OK for contactor to contactor run (Van's specs same size but Copper)? 4. .063 x .5 brass bar OK for contactor to current limiter (no starter current)? 5. .050 x .75 x 5 copper bars/straps on either side of firewall, each soldered with brass tabs, with 3/16 brass bolts as ground setup OK? ________________________________________________________________________________
Date: Apr 07, 2008
Subject: Re: Fat Wires & Brass vs. Copper
> > > >Bob & Listers, > >I'm finishing up the contactor mounting/wiring on my RV-7 firewall and >about to make and mount the ground busses and ground pass-through. > >I'm planning on 2AWG welding cable for both battery cables, the starter >cable, and the engine to firewall ground bus. Is this OK or should I use a >braided strap for the engine to firewall ground? The welding cable is sufficiently fine/flexible to serve well as a crankcase ground jumper. >This leaves the Alternator B-Lead. 2AWG is overkill but convenient to buy >and use. However, would I be better off downsizing it to a smaller gauge >welding cable? I'm planning on a 60amp Plane Power alternator. In an RV . . . 4AWG is fine for all fat wires. 2AWG is indicated on plastic canard pushers and some rear-battery installations in metal airplanes. >I can get brass plate and bar easily and cheaply. Is it practically / >functionally equivalent to copper for the main contactor to starter >contactor bar? Same for the bar to connect the current limiter? Van's >specs out .125 x .5 for the first and there is no spec for the second but >I plan on .063 x .5 for it. Will those work in brass? .063 is plenty good and brass is easier to work with than copper which is exceedingly soft and hard to drill. >I've already sourced two copper bars that are a bit thinner (.050) that >are perfect size for each side of the firewall for the ground busses. I'm >planning on soldering brass tabs onto them and mounting them with brass >bolts through them for the fat wires? Is this OK? Sure . . . but go with brass. Check out local hardware/hobby stores for K&S Engineering displays like: http://www.ksmetals.com/HobbyMerchandisers/metal_center.asp?Title=Hobby_Merchandisers They will stock some .032 brass sheet that is fine for crafting the short jumper straps between contactors, limiter mounts, etc. Make the 5/8" wide or so and thinner. Easier to work with . . . >I've summarized these 5 questions below, and I appreciate the help. Other >questions following in separate threads. > >George Jenson >Tucson, AZ >RV-7 > >Summary - 5 questions: >1. 2AWG welding cable OK for engine to firewall ground in lieu of braid? >2. 2AWG welding cable OK for 60amp PP alternator b-lead or should I downsize? Go 4AWG throughout . . . >3. .125 x .5 brass bar OK for contactor to contactor run (Van's specs same >size but Copper)? >4. .063 x .5 brass bar OK for contactor to current limiter (no starter >current)? >5. .050 x .75 x 5 copper bars/straps on either side of firewall, each >soldered with brass tabs, with 3/16 brass bolts as ground setup OK? Go .032 brass for all and at LEAST 5/16 or better yet 3/8" brass bolts for fat-wire terminals. Torque to 80+ percent of maximum for the materials and thread sizes. Check AC43.13 for values. Bob . . . ________________________________________________________________________________
Date: Apr 07, 2008
Subject: PM3000 Wiring
Bob & Listers, I have a used PM3000 stereo intercom for my RV-7. I am intending to wire two stereo signals, a Garmin 496 and a 1/8" panel jack, through a 4PDT switch into the intercom's entertainment input. This input mutes when there is other activity and allows for pilot isolation. That is the easy part. The more complicated part is how to handle all the mono signals: 1. Comm1 - Panel mounted, probably a Garmin 480 or a 430w 2. Comm2 - Icom A6 handheld in a panel dock (I have a 4PDT switch for these two to switch the intercom's transmit output) 3. Nav1 - Garmin 480 or 430w 4. EIS - GRT EIS has audio, and it is the likely candidate. 5. EFIS (?) - Some EFIS's output audio so this is a possibility 6. Garmin 496 Voice Output (?) - Not sure if I need to use this if the stereo output is attached, though I'd rather have warnings come through an unmutable (immutable?) input and I'd like to still get 496 audio warnings if I happen to be listening to an mp3 player. So that's 4 for sure, 5 likely, and perhaps 6, mono signals for the PM3000, which has one mono input. Further, the mono input of the PM3000 is supposed to come after the Aux headset jack. That jack is supposed to be installed between the Comm radio and the intercom, and from a SHTF perspective, that makes great sense. Note that I don't need nor want any of those inputs switched nor do any need added volume controls. Simple is as simple does, and I'm a simple (minded) guy. My current plan is build an audio isolation amp per Bob's plans and route the output of that into the Aux jack and then into the PM3000. 1. Is this OK or should I put the isolation amp between the Aux jack and the PM3000 so that the primary comm goes to the Aux jack first, then to the isolation amp? If the SHTF, I would think that having the Aux jack immediately after Comm1 might be more betterer, though I would lose all the other audio. If the audio iso amp is so robust as to be a likely survivor of most failure modes, then perhaps having the Aux jack on the output side of it but before the intercom is best. What are your thoughts? 2. If I build the isolation amp per the mono schematics (1.8 an 1.8.1) there appear to be sufficient inputs and others can even be added (with a little breading of Bob's circuit board). However they both show only one input going to pin 3 of U115 and the rest going to pin 2. Does it matter or should the number of inputs be balanced between those two pins? Or, should they all go to pin 2 as none of the inputs are a single channel of a stereo signal? I confess my understanding of how that circuit actually works is minimal. 3. Is there a chance that this can all be done without the iso amp? I sorta figured that after about 2 mono signals you pretty well need the iso amp, but I wanted to confirm that. Finally Bob, assuming I do need an iso amp, I'd like to order one of your remaining circuit boards for it. Please advise how I should do so. I was a teenage ham radio operator and worked in an two-way radio factory during my youth so I'm very comfortable soldering and building projects. Thanks in advance, George Jenson Tucson, AZ RV-7 in progress ________________________________________________________________________________
Date: Apr 07, 2008
George: I think I can help. Today, I signed off for proto release on a new aviation audio product called the AMX-2A Audio Mixer Amplifier. It takes 10 monophonic audio sources, isolates and amplifies them into one output. Sort of like Bob's isolation amplifier, but more inputs, mono only and much smaller package. Four of the audio inputs have volume controls to allow the adjustment of audio levels from instruments that have no controls (e.g. Dynon EFIS). The other six inputs are fixed level, assuming that you have source control of the audio level from them (e.g. Comms, Traffic Monitors). All inputs are 10K ohm impedance. The output can be connected into the aux audio input on an intercom. If your intercom does not support aux inputs (Such as Sigtronics types), the output can be wired directly into the headphone bus. Both mono and stereo headphone buses are supported. All of this is contained in a small package, with a 25-pin D-sub connector (10 inputs, 2 outputs, power and 12 grounds). In fact, it's so small that the entire unit mounts in a D-sub backshell. I don't want to compete with Bob's isolation amplifier (after all it's his site), but I think he offers it more as a public service than a profit center. In that spirit, If Bob objects, I will back off. Documentation is pending, but I can send a pinout pretty quickly. Thanks, Vern -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George Jenson Sent: April 7, 2008 2:37 PM Subject: AeroElectric-List: PM3000 Wiring --> Bob & Listers, I have a used PM3000 stereo intercom for my RV-7. I am intending to wire two stereo signals, a Garmin 496 and a 1/8" panel jack, through a 4PDT switch into the intercom's entertainment input. This input mutes when there is other activity and allows for pilot isolation. That is the easy part. The more complicated part is how to handle all the mono signals: 1. Comm1 - Panel mounted, probably a Garmin 480 or a 430w 2. Comm2 - Icom A6 handheld in a panel dock (I have a 4PDT switch for these two to switch the intercom's transmit output) 3. Nav1 - Garmin 480 or 430w 4. EIS - GRT EIS has audio, and it is the likely candidate. 5. EFIS (?) - Some EFIS's output audio so this is a possibility 6. Garmin 496 Voice Output (?) - Not sure if I need to use this if the stereo output is attached, though I'd rather have warnings come through an unmutable (immutable?) input and I'd like to still get 496 audio warnings if I happen to be listening to an mp3 player. So that's 4 for sure, 5 likely, and perhaps 6, mono signals for the PM3000, which has one mono input. Further, the mono input of the PM3000 is supposed to come after the Aux headset jack. That jack is supposed to be installed between the Comm radio and the intercom, and from a SHTF perspective, that makes great sense. Note that I don't need nor want any of those inputs switched nor do any need added volume controls. Simple is as simple does, and I'm a simple (minded) guy. My current plan is build an audio isolation amp per Bob's plans and route the output of that into the Aux jack and then into the PM3000. 1. Is this OK or should I put the isolation amp between the Aux jack and the PM3000 so that the primary comm goes to the Aux jack first, then to the isolation amp? If the SHTF, I would think that having the Aux jack immediately after Comm1 might be more betterer, though I would lose all the other audio. If the audio iso amp is so robust as to be a likely survivor of most failure modes, then perhaps having the Aux jack on the output side of it but before the intercom is best. What are your thoughts? 2. If I build the isolation amp per the mono schematics (1.8 an 1.8.1) there appear to be sufficient inputs and others can even be added (with a little breading of Bob's circuit board). However they both show only one input going to pin 3 of U115 and the rest going to pin 2. Does it matter or should the number of inputs be balanced between those two pins? Or, should they all go to pin 2 as none of the inputs are a single channel of a stereo signal? I confess my understanding of how that circuit actually works is minimal. 3. Is there a chance that this can all be done without the iso amp? I sorta figured that after about 2 mono signals you pretty well need the iso amp, but I wanted to confirm that. Finally Bob, assuming I do need an iso amp, I'd like to order one of your remaining circuit boards for it. Please advise how I should do so. I was a teenage ham radio operator and worked in an two-way radio factory during my youth so I'm very comfortable soldering and building projects. Thanks in advance, George Jenson Tucson, AZ RV-7 in progress ________________________________________________________________________________
Date: Apr 07, 2008
One thing to consider... Even though they haven't made much noise about it, about a year ago PS Engineering added two mono auxiliary inputs to the PM3000. I don't know how old your unit is, but you might check with PS to see if it has the auxiliary inputs... Bill Denton -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George Jenson Sent: Monday, April 07, 2008 4:37 PM Subject: AeroElectric-List: PM3000 Wiring Bob & Listers, I have a used PM3000 stereo intercom for my RV-7. I am intending to wire two stereo signals, a Garmin 496 and a 1/8" panel jack, through a 4PDT switch into the intercom's entertainment input. This input mutes when there is other activity and allows for pilot isolation. That is the easy part. The more complicated part is how to handle all the mono signals: 1. Comm1 - Panel mounted, probably a Garmin 480 or a 430w 2. Comm2 - Icom A6 handheld in a panel dock (I have a 4PDT switch for these two to switch the intercom's transmit output) 3. Nav1 - Garmin 480 or 430w 4. EIS - GRT EIS has audio, and it is the likely candidate. 5. EFIS (?) - Some EFIS's output audio so this is a possibility 6. Garmin 496 Voice Output (?) - Not sure if I need to use this if the stereo output is attached, though I'd rather have warnings come through an unmutable (immutable?) input and I'd like to still get 496 audio warnings if I happen to be listening to an mp3 player. So that's 4 for sure, 5 likely, and perhaps 6, mono signals for the PM3000, which has one mono input. Further, the mono input of the PM3000 is supposed to come after the Aux headset jack. That jack is supposed to be installed between the Comm radio and the intercom, and from a SHTF perspective, that makes great sense. Note that I don't need nor want any of those inputs switched nor do any need added volume controls. Simple is as simple does, and I'm a simple (minded) guy. My current plan is build an audio isolation amp per Bob's plans and route the output of that into the Aux jack and then into the PM3000. 1. Is this OK or should I put the isolation amp between the Aux jack and the PM3000 so that the primary comm goes to the Aux jack first, then to the isolation amp? If the SHTF, I would think that having the Aux jack immediately after Comm1 might be more betterer, though I would lose all the other audio. If the audio iso amp is so robust as to be a likely survivor of most failure modes, then perhaps having the Aux jack on the output side of it but before the intercom is best. What are your thoughts? 2. If I build the isolation amp per the mono schematics (1.8 an 1.8.1) there appear to be sufficient inputs and others can even be added (with a little breading of Bob's circuit board). However they both show only one input going to pin 3 of U115 and the rest going to pin 2. Does it matter or should the number of inputs be balanced between those two pins? Or, should they all go to pin 2 as none of the inputs are a single channel of a stereo signal? I confess my understanding of how that circuit actually works is minimal. 3. Is there a chance that this can all be done without the iso amp? I sorta figured that after about 2 mono signals you pretty well need the iso amp, but I wanted to confirm that. Finally Bob, assuming I do need an iso amp, I'd like to order one of your remaining circuit boards for it. Please advise how I should do so. I was a teenage ham radio operator and worked in an two-way radio factory during my youth so I'm very comfortable soldering and building projects. Thanks in advance, George Jenson Tucson, AZ RV-7 in progress ________________________________________________________________________________
Date: Apr 07, 2008
Subject: Re: PM3000 Wiring
Put me on your list for more info, etc. Sam Marlow Vernon Little wrote: > > George: > > I think I can help. > > Today, I signed off for proto release on a new aviation audio product called > the AMX-2A Audio Mixer Amplifier. > It takes 10 monophonic audio sources, isolates and amplifies them into one > output. Sort of like Bob's isolation amplifier, but more inputs, mono only > and much smaller package. > > Four of the audio inputs have volume controls to allow the adjustment of > audio levels from instruments that have no controls (e.g. Dynon EFIS). The > other six inputs are fixed level, assuming that you have source control of > the audio level from them (e.g. Comms, Traffic Monitors). All inputs are > 10K ohm impedance. > > The output can be connected into the aux audio input on an intercom. If > your intercom does not support aux inputs (Such as Sigtronics types), the > output can be wired directly into the headphone bus. Both mono and stereo > headphone buses are supported. > > All of this is contained in a small package, with a 25-pin D-sub connector > (10 inputs, 2 outputs, power and 12 grounds). In fact, it's so small that > the entire unit mounts in a D-sub backshell. > > I don't want to compete with Bob's isolation amplifier (after all it's his > site), but I think he offers it more as a public service than a profit > center. In that spirit, If Bob objects, I will back off. > > Documentation is pending, but I can send a pinout pretty quickly. > > Thanks, Vern > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of George > Jenson > Sent: April 7, 2008 2:37 PM > To: aeroelectric-list(at)matronics.com > Subject: AeroElectric-List: PM3000 Wiring > > > --> > > Bob & Listers, > > I have a used PM3000 stereo intercom for my RV-7. I am intending to wire > two stereo signals, a Garmin 496 and a 1/8" panel jack, through a 4PDT > switch into the intercom's entertainment input. This input mutes when there > is other activity and allows for pilot isolation. That is the easy part. > > The more complicated part is how to handle all the mono signals: 1. Comm1 - > Panel mounted, probably a Garmin 480 or a 430w 2. Comm2 - Icom A6 handheld > in a panel dock (I have a 4PDT switch for these two to switch the intercom's > transmit output) 3. Nav1 - Garmin 480 or 430w 4. EIS - GRT EIS has audio, > and it is the likely candidate. 5. EFIS (?) - Some EFIS's output audio so > this is a possibility 6. Garmin 496 Voice Output (?) - Not sure if I need to > use this if the > stereo output is attached, though I'd rather have warnings come through an > unmutable (immutable?) input and I'd like to still get 496 audio warnings > if I happen to be listening to an mp3 player. > > So that's 4 for sure, 5 likely, and perhaps 6, mono signals for the PM3000, > which has one mono input. Further, the mono input of the PM3000 is supposed > to come after the Aux headset jack. That jack is supposed to be installed > between the Comm radio and the intercom, and from a SHTF perspective, that > makes great sense. > > Note that I don't need nor want any of those inputs switched nor do any > need added volume controls. Simple is as simple does, and I'm a simple > (minded) guy. > > My current plan is build an audio isolation amp per Bob's plans and route > the output of that into the Aux jack and then into the PM3000. > > 1. Is this OK or should I put the isolation amp between the Aux jack and > the PM3000 so that the primary comm goes to the Aux jack first, then to the > isolation amp? If the SHTF, I would think that having the Aux jack > immediately after Comm1 might be more betterer, though I would lose all the > other audio. If the audio iso amp is so robust as to be a likely survivor > of most failure modes, then perhaps having the Aux jack on the output side > of it but before the intercom is best. What are your thoughts? > > 2. If I build the isolation amp per the mono schematics (1.8 an 1.8.1) > there appear to be sufficient inputs and others can even be added (with a > little breading of Bob's circuit board). However they both show only one > input going to pin 3 of U115 and the rest going to pin 2. Does it matter or > should the number of inputs be balanced between those two pins? Or, should > they all go to pin 2 as none of the inputs are a single channel of a stereo > signal? I confess my understanding of how that circuit actually works is > minimal. > > 3. Is there a chance that this can all be done without the iso amp? I sorta > figured that after about 2 mono signals you pretty well need the iso amp, > but I wanted to confirm that. > > Finally Bob, assuming I do need an iso amp, I'd like to order one of your > remaining circuit boards for it. Please advise how I should do so. I was a > teenage ham radio operator and worked in an two-way radio factory during my > youth so I'm very comfortable soldering and building projects. > > Thanks in advance, > > George Jenson > Tucson, AZ > RV-7 in progress > > > > > > ________________________________________________________________________________
Subject: wiring of 477 rotax
Date: Apr 07, 2008
I need a little help!!! I have a used rotax 447 with single carb. There are three wire looms coming out of case. #1 has a yellow wire, and a yellow wire with black stripe on it. #2 has a green wire, and a green wire with black stripe on it. #3 has two black wires, and one brown wire. I need to know where these wires should be hooked up. There is only a pull starter, and no lights. I need to know how to wire it to run and how to wire in a tach. Also I think is puts out some voltage when running that may be used somewhere. Please Help???? Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175378#175378 ________________________________________________________________________________
Subject: Re: wiring of 477 rotax
Date: Apr 07, 2008
Sam, I have the info but it is in my hangar. If no one else gets the info to you by tomorrow I'll send it to you. Dale Ensing ----- Original Message ----- From: "Sam Brunson" <samscycles(at)juno.com> Sent: Monday, April 07, 2008 9:09 PM Subject: AeroElectric-List: wiring of 477 rotax > > > I need a little help!!! I have a used rotax 447 with single carb. There > are three wire looms coming out of case. #1 has a yellow wire, and a > yellow wire with black stripe on it. #2 has a green wire, and a green > wire with black stripe on it. #3 has two black wires, and one brown wire. > I need to know where these wires should be hooked up. There is only a > pull starter, and no lights. I need to know how to wire it to run and how > to wire in a tach. Also I think is puts out some voltage when running > that may be used somewhere. Please Help???? > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175378#175378 > > > ________________________________________________________________________________
Date: Apr 07, 2008
> >I need a little help!!! I have a used rotax 447 with single carb. There >are three wire looms coming out of case. #1 has a yellow wire, and a >yellow wire with black stripe on it. #2 has a green wire, and a green >wire with black stripe on it. #3 has two black wires, and one brown >wire. I need to know where these wires should be hooked up. There is >only a pull starter, and no lights. I need to know how to wire it to run >and how to wire in a tach. Also I think is puts out some voltage when >running that may be used somewhere. Please Help???? > You can find a number of Rotax data packages at: http://www.aeroelectric.com/Mfgr_Data/Rotax/ In particular, the information you want is in the 503 series installation manual: http://www.aeroelectric.com/Mfgr_Data/Rotax/Rotax_503_installation_manual.pdf If you're wanting only the electrical system, download: http://www.aeroelectric.com/Mfgr_Data/Rotax/Rotax_503_Electrical.pdf Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Apr 07, 2008
nuckolls.bob(at)cox.net wrote: > > > > > > > > Summary - 5 questions: > > 1. 2AWG welding cable OK for engine to firewall ground in lieu of braid? > > 2. 2AWG welding cable OK for 60amp PP alternator b-lead or should I downsize? > > > > > > Go 4AWG throughout . . . > > > > 3. .125 x .5 brass bar OK for contactor to contactor run (Van's specs same > > size but Copper)? > > 4. .063 x .5 brass bar OK for contactor to current limiter (no starter > > current)? > > 5. .050 x .75 x 5 copper bars/straps on either side of firewall, each > > soldered with brass tabs, with 3/16 brass bolts as ground setup OK? > > > > > > Go .032 brass for all and at LEAST 5/16 or better > yet 3/8" brass bolts for fat-wire terminals. Torque > to 80+ percent of maximum for the materials and thread > sizes. Check AC43.13 for values. Fantastic Bob, thanks for the help and for the work you continue to do. Simply extraordinary. George -------- George Jenson - Tucson, AZ - RV-7 Standard Build Empennage Completed 1/06 Wings Completed 11/06 Fuselage in Progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175442#175442 ________________________________________________________________________________
Date: Apr 08, 2008
Vern, I'd love to hear more, particularly price, and assuming we're not overstepping things on the list. It sounds like exactly what I need. Bill, My PM3000 is older than that based on the manual provided. I haven't examined the intercom closely enough to confirm, but it's a fair bet that I don't have one of the newer ones. All, I'm likely to still be interested in rolling my own once I find out what buying one will cost (I'm frugal in the extreme). So if anyone can shed light on my questions, I'd be obliged. George -------- George Jenson - Tucson, AZ - RV-7 Standard Build Empennage Completed 1/06 Wings Completed 11/06 Fuselage in Progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175443#175443 ________________________________________________________________________________
Date: Apr 08, 2008
I agree completely with the technology costs and the apparent wallet choking by marketers. As this list has often found in the past, there are always alternatives to the big player designs. In the computer world, Linux has proven there is a cheaper, efficient way to include the entire world in the movement. I feel ADSB is just another government scam and just another excuse to act as big brother of the sky. I won't buy into that pork belly junket even if the entry level becomes $0.00. What a bunch of crap, they offer something for free and then steal your identity. Wait until you get the tax bill... If you can manage to keep the terrorists out of the country they won't fly your Cessna's and you won't need to spy on them. No, I'm not an isolationist, but let's exercise some control here. On Peter's note, I'll agree that mode S does not offer added value in itself but it still provides a low cost interface for traffic avoidance if you already have the unit. It's not so much that mode "S" is obsolete, we are just to ignorant or lazy to further develop the technology into something that adds value to the flight plan while not harboring data from our aircraft like we were all fugitives or gangsters. What the hell, we are all bored in the US and have lots of money, so why not build an entirely new system, ADSB or some other pipe dream which is neither economical or leading edge (by the time the government releases it). To be sure I talked business in here somewhere, keep an eye on http://www.mglavionics.com/ If there is anyone left with enough ambition and appreciation for cost vs. value, they will be the ones to release a low cost mode S or other for consumers. Don't expect the big dogs to help the little guy - they are getting too rich stealing from the rest of us. It's sort of like the alternator business. Most shops won't admit it, but an alternator costing $200 - $300 can be rebuilt for $50 or less (probably $10.00). I've never had a shop pass that saving on to me before. Have a great week of flying and try a flight plan-less trip (it keeps the tax man away and it's more fun). -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ernest Christley Sent: Saturday, April 05, 2008 10:19 PM Subject: Re: AeroElectric-List: Re: Transponder for sale (mode S) --> Peter Pengilly wrote: > Mode S is mandatory in Europe? Mode S is already obsolete in the USA. > They are fighting for the next gen transponder (that will be even more > expensive). > > http://www.aopa.org/advocacy/articles/2008/080304ads-b.html > > The fact is Mode S does not do anything more for general aviation. > Even as a technology its based on OLD technology. So for the USA take > a wait see attitude. > > I find it amazing that a group of volunteers can develop a $200 laptop to distribute to children in third world countries that, as only one small part of the project, includes a mesh network technology that allows them configure themselves to talk to one another on the fly. A GPS signal (another $100) and a shared database (a correspondingly cheap FAA controlled ground-station) gives a complete information sharing system. Yet, we have a local representative advocating a "low-cost" ADS-B system that would cost around $3,000. It is simply freaking ridiculous how "those that know more than we do" continue to settle on technologies that are outdated and controlled by entrenched commercial interest to the detriment of us all. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Apr 08, 2008
I don't really understand this. The cost of avionics is because of the low volume and the liability costs. Implementing Linux isn't going to cut the costs more than 20 bucks on a device. This is a huge deduction for something like a wifi router. It's noise if you're talking about a device like a garmin 430. I'm a full fledged linux bigot but linux isn't the answer to everything. For something like a mode-s transponder that does very little but must do it in real time, it probably isn't the right answer. (And if your answer is ever Windows you're asking the wrong questions). I don't see anyone getting rich in the GA aviation market other than probably the lawyers Cessna and Cirrus must have on retainer. Also, if I'm not mistaken both mode-s and adsb encode the n-number of the aircraft they are installed in, so there is no privacy difference. Adsb is self contained, it transmits a bunch of information, listens to broadcasts from other aircraft and ATC has passive receivers. If you're concern is government misbehavior you should be more interested in adsb than mode-s. Adsb you turn the device off and you're gone as far as atc is concerned. I assume most mode-s installations will be made concurrently with primary radar (like mode-c is). I imagine adsb can be made with more commercial of the shelf parts since it's basically a gps coupled with a microprocessor and a transmitter. That has to be easier than implementing something that interacts with a government provided radar infrastructure (which if I know the government well enough, probably isn't documented as well as it should be). But, forcing everyone to go to mode-s then a half heartbeat later adsb is annoying and can't be justified considering the expense it's going to put on aircraft owners. On Tue, Apr 8, 2008 at 10:17 AM, wrote: > > I agree completely with the technology costs and the apparent wallet > choking by marketers. As this list has often found in the past, there > are always alternatives to the big player designs. In the computer > world, Linux has proven there is a cheaper, efficient way to include the > entire world in the movement. > > I feel ADSB is just another government scam and just another excuse to > act as big brother of the sky. I won't buy into that pork belly junket > even if the entry level becomes $0.00. What a bunch of crap, they offer > something for free and then steal your identity. Wait until you get the > tax bill... > > If you can manage to keep the terrorists out of the country they won't > fly your Cessna's and you won't need to spy on them. No, I'm not an > isolationist, but let's exercise some control here. > > On Peter's note, I'll agree that mode S does not offer added value in > itself but it still provides a low cost interface for traffic avoidance > if you already have the unit. It's not so much that mode "S" is > obsolete, we are just to ignorant or lazy to further develop the > technology into something that adds value to the flight plan while not > harboring data from our aircraft like we were all fugitives or > gangsters. What the hell, we are all bored in the US and have lots of > money, so why not build an entirely new system, ADSB or some other pipe > dream which is neither economical or leading edge (by the time the > government releases it). > > To be sure I talked business in here somewhere, keep an eye on > http://www.mglavionics.com/ If there is anyone left with enough ambition > and appreciation for cost vs. value, they will be the ones to release a > low cost mode S or other for consumers. Don't expect the big dogs to > help the little guy - they are getting too rich stealing from the rest > of us. > > It's sort of like the alternator business. Most shops won't admit it, > but an alternator costing $200 - $300 can be rebuilt for $50 or less > (probably $10.00). I've never had a shop pass that saving on to me > before. > > Have a great week of flying and try a flight plan-less trip (it keeps > the tax man away and it's more fun). > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of > > Ernest Christley > Sent: Saturday, April 05, 2008 10:19 PM > To: aeroelectric-list(at)matronics.com > > > Subject: Re: AeroElectric-List: Re: Transponder for sale (mode S) > > > --> > > Peter Pengilly wrote: > > Mode S is mandatory in Europe? Mode S is already obsolete in the USA. > > They are fighting for the next gen transponder (that will be even more > > expensive). > > > > http://www.aopa.org/advocacy/articles/2008/080304ads-b.html > > > > The fact is Mode S does not do anything more for general aviation. > > Even as a technology its based on OLD technology. So for the USA take > > a wait see attitude. > > > > > I find it amazing that a group of volunteers can develop a $200 laptop > to distribute to children in third world countries that, as only one > small part of the project, includes a mesh network technology that > allows them configure themselves to talk to one another on the fly. A > GPS signal (another $100) and a shared database (a correspondingly cheap > > FAA controlled ground-station) gives a complete information sharing > system. > > Yet, we have a local representative advocating a "low-cost" ADS-B system > > that would cost around $3,000. It is simply freaking ridiculous how > "those that know more than we do" continue to settle on technologies > that are outdated and controlled by entrenched commercial interest to > the detriment of us all. > > -- > > http://www.ronpaultimeline.com > > ________________________________________________________________________________
Date: Apr 08, 2008
> > >I don't really understand this. The cost of avionics is because of the >low volume and the liability costs. Implementing Linux isn't going to >cut the costs more than 20 bucks on a device. This is a huge deduction >for something like a wifi router. It's noise if you're talking about a >device like a garmin 430. Having been both a airframe-consumer and an OEM-supplier in the type certificated aircraft industry, I can share that as much as 1/2 the cost of a product has nothing to do with the economics of volume or even the development costs. The piles of paper generated before one achieves permission to sell to TC aviation are a significant portion of the development costs. Piles of paper to retain permission after certification are significant. The piles of paper generated to implement even the most rudimentary of fix or improvement to design are significant. Each pile of paper is subject to submission and review by the cognizant faction of The Administrator's staff with each reviewer having 90 days to respond. All the while, the manufacturer has folks drawing salaries charged against the work order for that product while they wait for reviewers to finish praying over the paper. I won't suggest that EVERYTHING we're required to do is not necessary or useful . . . but folks-who-know- more-about-airplanes-than-we-do have no stake in profitability or even performance of those whom they regulate. Like lawyers who bill by the hour, there's no incentive to bring any matter to closure soon. I've seen the in-boxes on a regulator's desk piled with a 91-day backlog of work . . . and he/she was proud of it. When I walked in with my request for an audience, I was greeted warmly and my little pile of papers for phase 4 of a 10-phase endeavor, my stuff went to the bottom of the 91-day stack. And you better not complain lest you find that your next project keeps dropping to the bottom of the stack every few weeks. It's easy to understand why this happens. EVERYONE wants to get a raise next year. Most everyone likes to move up in the ranks of their discipline every year. How does one advance excellence in presiding over a static set of rules with a static staff? Under static conditions, performance eventually goes asymptotic to perfection and advancement ceases. But if you create more rules and hire more staff to administer those rules, then the bar goes up and one can justify expecting and receiving more pay. Getting things done quickly has a poor return on investment for the career track. While Gates and IBM are capable of adding value to their products . . . regulation only ADDS cost. If Gates and IBM had the same hurdles to cross as manufacturers of products for aviation, we'd still be running 20 MHz 486 machines under CP/M for 3 to 10x the cost of a current off-the-shelf CPU. Bob . . . ________________________________________________________________________________
Date: Apr 08, 2008
for sale (mode S) "Robert L. Nuckolls, III" wrote: > > While Gates and IBM are capable of adding value to > their products . . . regulation only ADDS cost. > If Gates and IBM had the same hurdles to cross as > manufacturers of products for aviation, we'd still be > running 20 MHz 486 machines under CP/M for 3 to 10x > the cost of a current off-the-shelf CPU. > > Bob . . . > > CP/M ran just fine on the 8080 and Z80 chips so it's doubtful the 8086 or any of the other advanced processors would have made it past the paperwork. :) Bob W. (I still have a CP/M machine that was working the last time I turned it on - about 10 years ago.) -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/cables/ ________________________________________________________________________________
Date: Apr 08, 2008
Michael Pereira wrote: > > I don't really understand this. The cost of avionics is because of the > low volume and the liability costs. Implementing Linux isn't going to > cut the costs more than 20 bucks on a device. This is a huge deduction > for something like a wifi router. It's noise if you're talking about a > device like a garmin 430. > The point wasn't that the OLPC uses Linux. The point was that the technology to implement a self configuring mesh network is both cheap and widespread. The point was that the people in charge think of $3,000 as "low cost", while the same task is being done for <$200. I realize that Garmin has to make a few pennies. I'm also an engineer, and I like to eat, too. But I don't expect the government to legislate that everyone by a Cisco C6500 to use the internet. That sort of equipment is just way overkill for the job. To say that the industry should pursue a technology direction that forces everyone to buy expensive equipment, when the same job can be performed...neigh, is being performed...by much cheaper equipment so that someone can make some money is a broken window argument. Part of the problem is the low volume, as you claim. And so they propose a system that will perpetuate the need to use low volume devices? All that would be required to implement the design goals that I've seen is a white-box GPS, the innards of a PalmVx, and a medium strength transceiver. The software is trivial, considering the number of examples with open source available (ie, the hard part is done already). There's nothing in the mix that would push a marginally successful product into the $3,000 range. I think most people involved with aircraft are jaded to the point they truly believe everything should cost thousands. You have not, because you ask not. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Subject: Risky Jump Starts?
Date: Apr 09, 2008
Greetings, Someone posted on the rec.aviation.piloting newsgroup a story about damage caused by jumpstarting the airplane with the alternator switch on. According to the story, the jump start was from an FBO tug capable of "much more juice" than the owner's pickup truck that he had successfully used in the past, and as soon as he turned the key, "every breaker in the plane tripped." Sensors for fuel quantity, oil temp, ammeter, and oil pressure strip "got fried and needed to be rebuilt." I'm having trouble understanding how getting a jump start with the alternator switch turned on could cause this problem. Even if it were a 12 volt system and the FBO tug produced 24 volts, I don't see why it would trip the circuit breakers. Any ideas? Dennis Johnson Legacy, now flying ________________________________________________________________________________
Date: Apr 09, 2008
Subject: Re: Risky Jump Starts?
I'm with you.. I don't see how leaving the alternator turned off would have helped. OWT People love to dramatize events. Hooking 24V to a 12V system can blow breakers on some circuits - like lighting. And can damage some items. Doubling the V, doubles the I - when a circuit isn't regulated to constant P (which is true for many things). Matt- > Greetings, > > Someone posted on the rec.aviation.piloting newsgroup a story about damage > caused by jumpstarting the airplane with the alternator switch on. > According to the story, the jump start was from an FBO tug capable of > "much more juice" than the owner's pickup truck that he had successfully > used in the past, and as soon as he turned the key, "every breaker in the > plane tripped." Sensors for fuel quantity, oil temp, ammeter, and oil > pressure strip "got fried and needed to be rebuilt." > > I'm having trouble understanding how getting a jump start with the > alternator switch turned on could cause this problem. Even if it were a > 12 volt system and the FBO tug produced 24 volts, I don't see why it would > trip the circuit breakers. > > Any ideas? > > Dennis Johnson > Legacy, now flying > > ________________________________________________________________________________
Date: Apr 09, 2008
>Greetings, > >Someone posted on the rec.aviation.piloting newsgroup a story about damage >caused by jumpstarting the airplane with the alternator switch >on. According to the story, the jump start was from an FBO tug capable of >"much more juice" than the owner's pickup truck that he had successfully >used in the past, and as soon as he turned the key, "every breaker in the >plane tripped." Sensors for fuel quantity, oil temp, ammeter, and oil >pressure strip "got fried and needed to be rebuilt." > >I'm having trouble understanding how getting a jump start with the >alternator switch turned on could cause this problem. Even if it were a >12 volt system and the FBO tug produced 24 volts, I don't see why it would >trip the circuit breakers. 24 volts of normal polarity would not trip all the breakers . . . however 24 volts of REVERSED polarity might. Ground power carts are typically capable of 1000 to 2000 amp currents. A set of paralleled-series diodes in an alternator would attempt to hold off voltage rise of a reversed polarity . . . but the forward conduction drop on a highly stressed diode is 1 volt or more. So in milliseconds, the bus voltage goes minus to the tune of 2 volts or more . . . at MANY amps. The battery would also attempt to stand of the event . . . but we don't know if the battery was even on line for this scenario. But if the battery were dead, it wouldn't be much help. The alternator breaker or b-lead fuse would open first and probably before the alternator was damaged. As soon as the breaker opens, then the bus voltage goes WAAAaayyyy negative and really sad things start to happen . . . which may well include the opening of a few more breakers. I've had line-folks put 24v of the RIGHT polarity to my 14v airplane and that was scary enough. I've addressed this possibility in the designs for ground power jacks in your OBAM aircraft project. I've always recommended (1) ov protection, (2) reverse polarity protection and (3) giving the pilot absolute control of when power is applied to the ship's systems. See: http://aeroelectric.com/articles/grndpwr.pdf The outcome of this story would not have been altered by leaving the alternator switch OFF. I used to contribute to the discussions on Usenet groups but had to give up after discovering that many folks who hang out there are not interested in (or perhaps capable of) understanding the simple-ideas behind the physics that controls behavior of their electrical systems. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Apr 09, 2008
>Greetings, > >Someone posted on the rec.aviation.piloting newsgroup a story about damage >caused by jumpstarting the airplane with the alternator switch >on. According to the story, the jump start was from an FBO tug capable of >"much more juice" than the owner's pickup truck that he had successfully >used in the past, and as soon as he turned the key, "every breaker in the >plane tripped." Sensors for fuel quantity, oil temp, ammeter, and oil >pressure strip "got fried and needed to be rebuilt." > >I'm having trouble understanding how getting a jump start with the >alternator switch turned on could cause this problem. Even if it were a >12 volt system and the FBO tug produced 24 volts, I don't see why it would >trip the circuit breakers. 24 volts of normal polarity would not trip all the breakers . . . however 24 volts of REVERSED polarity might. Ground power carts are typically capable of 1000 to 2000 amp currents. A set of paralleled-series diodes in an alternator would attempt to hold off voltage rise of a reversed polarity . . . but the forward conduction drop on a highly stressed diode is 1 volt or more. So in milliseconds, the bus voltage goes minus to the tune of 2 volts or more . . . at MANY amps. The battery would also attempt to stand of the event . . . but we don't know if the battery was even on line for this scenario. But if the battery were dead, it wouldn't be much help. (UPON FURTHER REFLECTION, THE SCENARIO DESCRIBED MAY NOT HAVE INCLUDED REVERSED POLARITY . . . THIS IS AN EXCEEDINGLY RARE EVENT THAT IS USUALLY LIMITED TO RECENTLY SERVICED BATTERY CARTS THAT HAVE BEEN IMPROPERLY ASSEMBLED. THIS PROBABLY WAS A SIMPLE OVER VOLTAGE EVENT SUPPORTED BY A 1000+ AMP CURRENT SOURCE. YOU THINK AN OV EVENT FROM A 60A ALTERNATOR IS BAD, TRY A 1000A GROUND POWER CART!) The alternator breaker or b-lead fuse would open first and probably before the alternator was damaged. As soon as the breaker opens, then the bus voltage goes WAAAaayyyy negative and really sad things start to happen . . . which may well include the opening of a few more breakers. I've had line-folks put 24v of the RIGHT polarity to my 14v airplane and that was scary enough. I've addressed this possibility in the designs for ground power jacks in your OBAM aircraft project. I've always recommended (1) ov protection, (2) reverse polarity protection and (3) giving the pilot absolute control of when power is applied to the ship's systems. See: http://aeroelectric.com/articles/grndpwr.pdf The outcome of this story would not have been altered by leaving the alternator switch OFF. I used to contribute to the discussions on Usenet groups but had to give up after discovering that many folks who hang out there are not interested in (or perhaps capable of) understanding the simple-ideas behind the physics that controls behavior of their electrical systems. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Securing Ends of Wires in Wing for Later Use
Date: Apr 09, 2008
Hello! I have one wing ready to skin and have run a bundle of wires from the root out to the tip through the leading edge. The wire may be used for a heated pitot tube (~3' from the root), landing lights (~1' in from the tip), and a tip nav/pos/strobe combo. I will most likely not install the lights and heated pitot until after hours of flying, if at all. So, what are some good ways to tie off wire that won't be used? The first wire I need to figure out is the one for a heated pitot. My bundle goes through the forward of two lightening hole and the pitot tube is located several inches back near the main spar. If I make a few loops of pitot wire and tie it to the bundle, I wouldn't be able to reach it through the access hole, which is only 2". So I'm thinking it should be real close to the access hole, maybe even on the pitot tube assembly itself? Again, it's not a heated tube but would be available if I switched it over to one in the future. Then there are the rest of the wires that end at or near the tip. For now I've coiled them a few times and cinched down a cable tie or two there for the time being. I'm not in a hurry to get this location figured out, because I'll have access to it after the wing is skinned. But the pitot tube wire needs to be figured out in the next few days. Cheers, Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175812#175812 ________________________________________________________________________________
Subject: Re: Securing Ends of Wires in Wing for Later Use
Date: Apr 09, 2008
Dan, I ran a piece of 3/4-inch OD, 5/8 ID polyethylene tube the length of my wings so I can pull the wires when they are needed. That begs the question of a heated pitot. I figure that if I REALLY need a heated pitot, I can use a soldering iron through an access port to melt a hole in the conduit. Roger Cole Murphy Elite #709 Wings and tail done; starting fuselage On Apr 9, 2008, at 6:32 PM, messydeer wrote: > > > Hello! > > I have one wing ready to skin and have run a bundle of wires from > the root out to the tip through the leading edge. The wire may be > used for a heated pitot tube (~3' from the root), landing lights > (~1' in from the tip), and a tip nav/pos/strobe combo. I will most > likely not install the lights and heated pitot until after hours of > flying, if at all. So, what are some good ways to tie off wire that > won't be used? > > The first wire I need to figure out is the one for a heated pitot. > My bundle goes through the forward of two lightening hole and the > pitot tube is located several inches back near the main spar. If I > make a few loops of pitot wire and tie it to the bundle, I wouldn't > be able to reach it through the access hole, which is only 2". So > I'm thinking it should be real close to the access hole, maybe even > on the pitot tube assembly itself? Again, it's not a heated tube > but would be available if I switched it over to one in the future. > > Then there are the rest of the wires that end at or near the tip. > For now I've coiled them a few times and cinched down a cable tie > or two there for the time being. I'm not in a hurry to get this > location figured out, because I'll have access to it after the wing > is skinned. But the pitot tube wire needs to be figured out in the > next few days. > > Cheers, > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175812#175812 > > ________________________________________________________________________________
Date: Apr 10, 2008
Dan, Consider doing as Roger suggested and instead of running the wires, run a pull line through the conduit to use later to pull the wires through. Also, you can use a file to make a nice, smoothed edge hole in the conduit. You can partially see what I've done at _http://www.rv-8a.net/2006.htm_ (http://www.rv-8a.net/2006.htm) and scroll down to 8 Apr 06 and 14 Apr 06. You can see the conduit in those photos and how I fed lines into them. Regards, Stan Sutterfield Dan, I ran a piece of 3/4-inch OD, 5/8 ID polyethylene tube the length of my wings so I can pull the wires when they are needed. That begs the question of a heated pitot. I figure that if I REALLY need a heated pitot, I can use a soldering iron through an access port to melt a hole in the conduit. Roger Cole Murphy Elite #709 Wings and tail done; starting fuselage On Apr 9, 2008, at 6:32 PM, messydeer wrote: > > > Hello! > > I have one wing ready to skin and have run a bundle of wires from > the root out to the tip through the leading edge. The wire may be > used for a heated pitot tube (~3' from the root), landing lights > (~1' in from the tip), and a tip nav/pos/strobe combo. I will most > likely not install the lights and heated pitot until after hours of > flying, if at all. So, what are some good ways to tie off wire that > won't be used? > > The first wire I need to figure out is the one for a heated pitot. > My bundle goes through the forward of two lightening hole and the > pitot tube is located several inches back near the main spar. If I > make a few loops of pitot wire and tie it to the bundle, I wouldn't > be able to reach it through the access hole, which is only 2". So > I'm thinking it should be real close to the access hole, maybe even > on the pitot tube assembly itself? Again, it's not a heated tube > but would be available if I switched it over to one in the future. > > Then there are the rest of the wires that end at or near the tip. > For now I've coiled them a few times and cinched down a cable tie > or two there for the time being. I'm not in a hurry to get this > location figured out, because I'll have access to it after the wing > is skinned. But the pitot tube wire needs to be figured out in the > next few days. > > Cheers, > Dan (http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000016) ________________________________________________________________________________
Date: Apr 10, 2008
Thanks for the replies, guys. I've already got the wires routed without tubing. What it really comes down to is how to secure the loose spare wires at their ends before they are hooked up. With a tube this wouldn't be a problem. I suppose I could wrap and tape the heater wire around the non-heated pitot tube. -------- Dan Read this topic online here: http://forums.matronics.com/viewtopic.php?p=175906#175906 ________________________________________________________________________________
Subject: Strippers are all spoken for.
Date: Apr 10, 2008
-----Original Message----- Bob and listers. Gilchrist Electric's phone numbers have been disconnected. Out of Business? They clipped me for 14.00$. Payed through Google checkout. Can't seem to get anyone to answer my inquiry at Gilchrist and Google. Caveat Emptor Peter Laurence. ________________________________________________________________________________
Date: Apr 10, 2008
I'd cut it off fold it on itself, stuff it in some heat wrap and heat shrink the wrap on it. That should hold it and eliminate the messiness of electrical tape "goo" bobf On 4/10/08, messydeer wrote: > > > Thanks for the replies, guys. > > I've already got the wires routed without tubing. What it really comes > down to is how to secure the loose spare wires at their ends before they are > hooked up. With a tube this wouldn't be a problem. I suppose I could wrap > and tape the heater wire around the non-heated pitot tube. > > -------- > Dan > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=175906#175906 > > ________________________________________________________________________________
From: "Dave VanLanen" <davevanlanen(at)sbcglobal.net>
Subject: Shunts
Date: Apr 10, 2008
I am reading through the AeroElectric Connection manual as I have time, but I am having trouble comprehending some of the concepts presented. I just read about the use of shunts in an electrical system to allow the measurement of large currents with small meters. One thing I don't understand is, if a shunt is used in the circuit to be measured, what prevents a reduction in energy in the circuit on the downstream side of the shunt? Can someone help me better understand this? Thanks, Dave Van Lanen 601XL - Tail ________________________________________________________________________________
Date: Apr 10, 2008
Subject: Re: Shunts
Quoting Dave VanLanen : > understand is, if a shunt is used in the circuit to be measured, what > prevents a reduction in energy in the circuit on the downstream side of the > shunt? Can someone help me better understand this? Nothing prevents it; there is in fact such a reduction. However, it's such a minuscule reduction that it's not noticeable in ordinary operation. A shunt typically is designed for a 50 mV voltage drop at full capacity. So, a 100A shunt will cause a 50 mV drop at 100A. In a 14V circuit, 100A represents 1400W, and the shunt will consume 5W of that. -- Dan Brown, KE6MKS, dan(at)familybrown.org "Since all the world is but a story, it were well for thee to buy the more enduring story rather than the story that is less enduring." -- The Judgment of St. Colum Cille ________________________________________________________________________________
Date: Apr 10, 2008
Subject: Re: Shunts
Hey Dave, Nothing prevents loss of energy downstream of the shunt. But, a properly selected shunt will have a relatively small voltage drop at full scale current - reducing the power consumption of the device. Typical shunts drop 50mV at full scale. On a 100A peak current circuit that's 5W = 100A * 50mV. If you figure you're dropping the rest of the 13V supply into the 100A load, you're only losing 5W out of 1300W or 0.3%. Not too terrible. At lower currents the percentage of power lost is less: 10A through the same shunt will drop 5mV which is 50mW of the 130W delivered to the load - or 0.03%. Many aircraft engine monitors are setup to use Hall Effect sensors - which do not consume any current from the measured circuit. Regards, Matt- > I am reading through the AeroElectric Connection manual as I have time, > but > I am having trouble comprehending some of the concepts presented. I just > read about the use of shunts in an electrical system to allow the > measurement of large currents with small meters. One thing I don't > understand is, if a shunt is used in the circuit to be measured, what > prevents a reduction in energy in the circuit on the downstream side of > the > shunt? Can someone help me better understand this? > > Thanks, > Dave Van Lanen > 601XL - Tail > ________________________________________________________________________________
Date: Apr 10, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: RE: Gilcrhist Electric
><PLaurence@the-beach.net> > > >-----Original Message----- >Bob and listers. > >Gilchrist Electric's phone numbers have been disconnected. Out of Business? >They clipped me for 14.00$. > >Payed through Google checkout. Can't seem to get anyone to answer my inquiry >at Gilchrist and Google. This has been reported to me by several builders. I've written the Chamber of Commerce in Bozeman and searched the 'net for any indication that the company has folded. No data has been forthcoming as of this writing. Gilchrist has also completely disappeared from Ebay in spite of the fact that their website is still up . . . and silent as to the fortunes of the company. I'm sorry to hear this. They gave me very good prices on lots of coax strippers during the time I was offering them from our website. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Apr 10, 2008
From: John and Nancy Ghertner <nghertner(at)verizon.net>
Subject: Re: RE: Gilcrhist Electric
I received a stripper from them today. Unfortunately, it is the wrong size. Lory Ghertner > > > >> <PLaurence@the-beach.net> >> >> >> >> -----Original Message----- >> Bob and listers. >> >> Gilchrist Electric's phone numbers have been disconnected. Out of Business? >> They clipped me for 14.00$. >> >> Payed through Google checkout. Can't seem to get anyone to answer my inquiry >> at Gilchrist and Google. > > This has been reported to me by several builders. I've written the > Chamber of Commerce in Bozeman and searched the 'net for any > indication that the company has folded. No data has been > forthcoming as of this writing. Gilchrist has also completely > disappeared from Ebay in spite of the fact that their website > is still up . . . and silent as to the fortunes of the company. > > I'm sorry to hear this. They gave me very good prices on > lots of coax strippers during the time I was offering > them from our website. > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > > > ________________________________________________________________________________
Date: Apr 10, 2008
Subject: Copper foil for ground planes
I just ran across this offering on the 'net for .013" thick copper sheet. http://www.craftsetc.com/store/item.aspx?ItemId=37793&dep=50&cat=85&subcat=25&Search=Y This stuff is thick enough to craft mechanically robust ground plane radials for antennas on plastic airplanes. In fact, one could also craft the center commoning disk from two pieces of the same material. Sandwich and sweat solder the radials between the commoning sheets. I've crafted several DIY com antennas with featuring coax connectors. I'm satisfied with the last iteration and will be publishing a comic book on it in the not too distant future. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Splicing Shielded Cable
Date: Apr 10, 2008
Folks, I'm using the Ray Allen electric trim and their stick grips in my GlaStar. I'm using shielded two-conductor cable from the PTT switch to the intercom. I need to splice that cable and originally used Bob's soldered lap splicing technique but kept the exposed wires very short to be able to replace the shield. Long story short -- one of the wires shorted to the shield so I had a "stuck mic". My specific question is: what's the best way to replace the shield after splicing shielded wire? To do it right this time, I'll have to expose about 2" - 3" of each wire. Best regards, Bob GlaStar N248BF ________________________________________________________________________________
Date: Apr 11, 2008
Subject: Re: Splicing Shielded Cable
March 23, 2008 - April 11, 2008
AeroElectric-Archive.digest.vol-hs
