AeroElectric-Archive.digest.vol-ia
July 25, 2008 - August 09, 2008
      http://forums.matronics.com/viewtopic.php?p=194939#194939
Subject: A Tough Decision
Date: Jul 25, 2008
According to the letter of the law, experimental or homebuilt aircraft follow the same rules for liability as do certified aircraft. There are some interesting "what if" scenarios on this link to make you think. As to how many of these have gone to trial and how many pilots have been sent to Siberia with no food to shovel ice, I have no idea. Read: http://www.aviationlawcorp.com/content/liabhomeblt.html ________________________________________________________________________________
Date: Jul 25, 2008
Subject: recommendations for building a 24V battery?
I'm looking into building a 24V battery for an airborne payload with the following spec's: - 12AH minimum, no CCA requirement (not used for starting) - bolted terminals - no FAA/PMA approval required - no need for metal jackets, etc., to protect from the environment - hanging off of a bus fed by a 28V alternator Several offerings from Odyssey (PC535/545/625/680), Panasonic (LC-RD1217P), and Powersonic (PS-12180) fit the bill. Thus far, the Powersonic battery beats the rest on price and weight per AH. Has anyone had good/bad experience with Powersonic batteries? The paperwork from Powersonic posts a charge voltage range of 14.4 to 14.7V and a float range of 13.5V to 13.8V. First, is it valid to simply double these for the 24V battery? Second, the 28V bus will be sitting between 28.5 and 28.9V nominally which is just under the "charge" range (assuming doubling the 12V range is valid) but a volt or so above the "float" range. Probably not worth a worry but I want to make sure. Any other tricks/techniques/gotchas related to the care and feeding of ganged batteries will be appreciated. D ________________________________________________________________________________
Date: Jul 25, 2008
Hey, Cappy What a great way to contribute to following generations. Must say I have mixed emotions about seeing you donate your beautiful aircraft - but likely to stay beautiful that way. Does this mean you have more time to build hangars? Best Regards Ed Anderson Rv-6A N494BW Rotary Powered Matthews, NC eanderson(at)carolina.rr.com http://www.andersonee.com http://members.cox.net/rogersda/rotary/configs.htm#N494BW http://www.dmack.net/mazda/index.html -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Steve Glasgow Sent: Friday, July 25, 2008 8:44 AM Subject: AeroElectric-List: A Tough Decision After three years building and five years flying my RV-8, I have decided to move into Light Sport aviation. I will always cherish the memories of RV's and all they have to offer. After spending months researching Builder Liability Issues, I have decided to donate Cappy's Toy to an Aviation Museum. The museum has offered to create an Experimental Aircraft Section featuring Cappy's Toy. It is heartwarming to know Cappy's Toy will forevermore be representing Experimental Aviation, and that I have found a good home for her. The museum has agreed to accept Cappy's Toy without the engine, engine accessories, NAV/COM GNC 300XL, transponder GTX 327, autopilot Trio Avionics EZ Pilot and 5 point airline type seat belts. The expected delivery date is September 15, 2008. In addition to a tax deduction, the sale of these items will enable me to re-coup some of the losses incurred from not selling the airplane outright. If you are interested in a proven complete functioning power plant package with less than 450 hours for your project, or any of the other items, please give me a call. Engine and Engine Accessories Superior XP 360: 0-360 A1A2, 180 HP Main Alternator: B&C Specialty Products, L-40 with LR3C voltage regulator Standby Alternator: B&C Specialty Products, SD-8 with SB1B-14 voltage regulator, mounted in the Suction Pump engine case pad Starter: B&C Specialty Products, BC315, Light Weight Top Ignition: Light Speed Plasma II, with built in Crank Sender Bottom Ignition: Slick 4000 Magneto with Impulse Coupler, mounted in the Left Magneto engine case pad Carburetor: Precision Airmotive MA4-5 Oil Filter Adapter: B&C BC7000 Oil Cooler: Stewart Warner Exhaust: Viterman Package Cost New $29,500. Price $19,000 Steve Glasgow-Cappy N123SG RV-8 Cappy's Toy 3931 Melchor Avenue Charlotte, NC willfly(at)carolina.rr.com 704-362-0005 Home 704-281-7884 Cell __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. __________ Information from ESET NOD32 Antivirus, version of virus signature database 3267 (20080714) __________ The message was checked by ESET NOD32 Antivirus. ________________________________________________________________________________
Subject: Re: LED Landing Light Benchmark
Date: Jul 25, 2008
The 32 Volts is just a DC-DC converter. Easy to buy. Maybe I misunderstand "Cargo Light" but this thing is the equivalent of maybe 18 headlights each of 55W and brilliant white. This would look like a 747 landing. As I said, too big for you.... -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=194963#194963 ________________________________________________________________________________
From: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net>
Subject: Igntion Switches
Date: Jul 25, 2008
Would just also note that it is NOT a security issue as most twins and up don't use key switches at all. The only lock on our Baron is in the door and baggage access. Bill S -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Dave Saylor Sent: Friday, July 25, 2008 12:11 PM Subject: RE: AeroElectric-List: Igntion Switches --> The reason we usually install a separate push button for starting is that is gives the ability to turn the engine over without running the ignition. The purpose of this is usually to clear a flooded engine. I've found over time that seperating the start and ignition systems allows better troubleshooting, and if you've ever tried to decipher the back of a keyed ignition switch, upside down in the dark, you'll appreciate the straight-forward simplicity of toggles and pushbuttons. Plus they look cool. I usually install locking toggles for the mags. Dave Saylor AirCrafters LLC 140 Aviation Way Watsonville, CA 831-722-9141 831-750-0284 CL www.AirCraftersLLC.com -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Friday, July 25, 2008 9:48 AM Subject: Re: AeroElectric-List: Igntion Switches --> > >7/21/2008 > >Hello Skip, You wrote: "I saw the referenced ACS Keyed Ignition >Switches and a starter switch. What is the benefit in two switches over one?" One might also properly ask, what is the benefit of one switch over two . . . or three? If you consider the ignition/starter controls of the entire fleet of GA aircraft, it's only the single-engine machines likely to be owned by John Q Public pilot with key-switches. The earliest aircraft offered a variety of controls that included rudimentary toggles up to and including specialized single control On-L-R-Both switches. The big-three gravitated to key switches back in the late 40's . . . folks who made those decisions are long gone but we might surmise that there was a lot thought about making an airplane look and feel as much like an automobile as possible. Today, there's an oft stated desire for "security" for having installed a key-operated ignition switch. This is a pretty weak argument given that most airplanes can be flown by simply breaking the wires off the backs of the mags through the oil-filler door or back of the key-switch by simply wiggling the terminals until they break off. Consider that the key-switch is not cheap. It claims a lot of panel space considering its function. It often becomes a pain-in-the-arse when you discover that after being all strapped in, your keys are still in your pocket. Consider further that as soon as one steps up to a twin engine aircraft, key switches for controlling ignition are never installed on the panel. On everything from a twin-bonanza to a King Air or Lear Jet, if you can get into the cabin (secured by one of the easiest locks to pick) you have the airplane! On the other side of the coin a pair of toggle switches and a push button integrate nicely into the panel along with other switches. They're inexpensive, easily wired or re-wires for mags or electronic ignition, etc. Spares for these switches are available from a variety of sources (some even local) while a fussy Off-L-R-Both-Start switch is available from a relatively few numbers of sources (all out of town!). Bob . . . ________________________________________________________________________________
Date: Jul 25, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
Subject: Re: recommendations for building a 24V battery?
> >I'm looking into building a 24V battery for an airborne payload with >the following spec's: > >- 12AH minimum, no CCA requirement (not used for starting) >- bolted terminals >- no FAA/PMA approval required >- no need for metal jackets, etc., to protect from the environment >- hanging off of a bus fed by a 28V alternator > >Several offerings from Odyssey (PC535/545/625/680), Panasonic >(LC-RD1217P), and Powersonic (PS-12180) fit the bill. Thus far, the >Powersonic battery beats the rest on price and weight per AH. Has >anyone had good/bad experience with Powersonic batteries? > >The paperwork from Powersonic posts a charge voltage range of 14.4 to >14.7V and a float range of 13.5V to 13.8V. First, is it valid to >simply double these for the 24V battery? yes > Second, the 28V bus will be >sitting between 28.5 and 28.9V nominally which is just under the >"charge" range (assuming doubling the 12V range is valid) but a volt >or so above the "float" range. the TC fleet setpoint for 28v lead-acid batteries is 28.5 volts . . . 28.9 won't reduce service life in ways that you can observe. What are your battery-only energy storage requirements? Does the system DEPEND on a battery for functionality? In other words, would a failed battery contactor put the outcome of the flight at risk? What preventative maintenance program do you plan for replacing batteries before they're incapable of supporting battery only systems for the designed endurance mode? > Probably not worth a worry but I want >to make sure. > >Any other tricks/techniques/gotchas related to the care and feeding of >ganged batteries will be appreciated. There's nothing magic about a 24v battery vs two 12v batteries. The electrical and chemical characteristics of one 24 is identical to a pair of 12s. There's no objective data to suggest that any particular brand of battery is the better value in terms of $replacement$/service-hours. Periodic cap testing of the batteries in service is the 100% foolproof way to guarantee system performance irrespective of the batteries you choose to try. Bob . . . ________________________________________________________________________________
Subject: Stick wiring cable
Date: Jul 26, 2008
Hello all, While rummaging through my household cables, I found some Ethernet cable I used to install a network at my home. This looks like an 8 wires, color coded, 24 AWG cable (it's also shielded). Would there be any drawbacks using this cable to wire my stickgrip from grip to a connector (probably D-SUB) at the base of the stick? Thanks for your input. Pascal GROELL RV-7A (near Paris, France) www.notreavion.net ________________________________________________________________________________
Date: Jul 26, 2008
Subject: Re: Stick wiring cable
>Hello all, > >While rummaging through my household cables, I found some Ethernet cable I >used to install a network at my home. > >This looks like an 8 wires, color coded, 24 AWG cable (it s also >shielded). Would there be any drawbacks using this cable to wire my >stickgrip from grip to a connector (probably D-SUB) at the base of the stick? > >Thanks for your input. Most Ethernet cable is solid strands of wire. It's not a wire designed for flexibility or robustness under vibration. You could give it a try. It might last quite some time before needing a replacement. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 26, 2008
Robert L. Nuckolls, III wrote: > > > >> Hello all, >> >> While rummaging through my household cables, I found some Ethernet >> cable I used to install a network at my home. >> >> This looks like an 8 wires, color coded, 24 AWG cable (it s also >> shielded). Would there be any drawbacks using this cable to wire my >> stickgrip from grip to a connector (probably D-SUB) at the base of >> the stick? >> >> Thanks for your input. > > Most Ethernet cable is solid strands of wire. > It's not a wire designed for flexibility or > robustness under vibration. You could give it > a try. It might last quite some time before > needing a replacement. > > Bob . . . Consider cutting up one of the off-the-shelf ethernet patch cables. They should be stranded. The most flexible & durable stuff I've ever seen that's easy to find is regular old telephone patch cord, but terminating it with anything other than the standard displacement-type RG connectors can be a problem. Charlie ________________________________________________________________________________
Date: Jul 26, 2008
>>>While rummaging through my household cables, I found some Ethernet cable >>>I used to install a network at my home. >>> >>>This looks like an 8 wires, color coded, 24 AWG cable (it s also >>>shielded). Would there be any drawbacks using this cable to wire my >>>stickgrip from grip to a connector (probably D-SUB) at the base of the stick? >>> >>>Thanks for your input. >> >> Most Ethernet cable is solid strands of wire. >> It's not a wire designed for flexibility or >> robustness under vibration. You could give it >> a try. It might last quite some time before >> needing a replacement. >> >> Bob . . . > >Consider cutting up one of the off-the-shelf ethernet patch cables. They >should be stranded. I did not know that. Thanks! I've got some laying around here somewhere that I'll investigate that condition. Good to know. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 26, 2008
Subject: DIY large radius layout compass
A few years ago when the digital calipers became really inexpensive at H.F., I converted a pair to a very accurate tram-point compass and layout tool. A few days ago I needed to cut out a nice circle from a chunk of laminated flooring and my little 6" calipers cum compass were too small for the task. While visiting H.F. for some sanding disks yesterday, I spotted a 24" aluminum caliper for $10 that solved my problem. With a couple of small drills, some JB Weld and few minutes of time, I converted the HF 96509 calipers to a handy large radius compass: http://aeroelectric.com/Pictures/Tools/Layout_and_Measurement/Large_Radius_Layout_Compass.jpg The stationary leg of these calipers is held onto the rule with set screws. After the JB Weld is set, you can re-calibrate the point-to-point distance by repositioning the stationary leg. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 26, 2008
Robert L. Nuckolls, III wrote: > > > >>>> While rummaging through my household cables, I found some Ethernet >>>> cable I used to install a network at my home. >>>> >>>> This looks like an 8 wires, color coded, 24 AWG cable (it s also >>>> shielded). Would there be any drawbacks using this cable to wire my >>>> stickgrip from grip to a connector (probably D-SUB) at the base of >>>> the stick? >>>> >>>> Thanks for your input. >>> >>> Most Ethernet cable is solid strands of wire. >>> It's not a wire designed for flexibility or >>> robustness under vibration. You could give it >>> a try. It might last quite some time before >>> needing a replacement. >>> >>> Bob . . . >> >> Consider cutting up one of the off-the-shelf ethernet patch cables. >> They should be stranded. > > I did not know that. Thanks! I've got some laying > around here somewhere that I'll investigate that > condition. Good to know. > > Bob . . . Uhh... I hedged a bit with the 'should' in the previous post. Here's a link to the Belden products. Some are solid, some are stranded. The better patch cables are flexible enough that it's hard to believe that they have 8 solid conductors, but it's worth checking. http://www.belden.com/07Markets/07_Industrial/07_Industrial_Products/Industrial_Ethernet_Cable.cfm#ethernet Charlie ________________________________________________________________________________
Date: Jul 26, 2008
Hello, My cable is indeed stranded, I'll count the strands next time I'm in the workshop. Thanks Best regards Pascal > -----Message d'origine----- > De: owner-aeroelectric-list-server(at)matronics.com [mailto:owner- > aeroelectric-list-server(at)matronics.com] De la part de Robert L. > Nuckolls, III > Envoy: samedi 26 juillet 2008 17:53 > : aeroelectric-list(at)matronics.com > Objet: Re: AeroElectric-List: Stick wiring cable > > > > > >>>While rummaging through my household cables, I found some Ethernet > cable > >>>I used to install a network at my home. > >>> > >>>This looks like an 8 wires, color coded, 24 AWG cable (it s also > >>>shielded). Would there be any drawbacks using this cable to wire my > >>>stickgrip from grip to a connector (probably D-SUB) at the base of > the stick? > >>> > >>>Thanks for your input. > >> > >> Most Ethernet cable is solid strands of wire. > >> It's not a wire designed for flexibility or > >> robustness under vibration. You could give it > >> a try. It might last quite some time before > >> needing a replacement. > >> > >> Bob . . . > > > >Consider cutting up one of the off-the-shelf ethernet patch cables. > They > >should be stranded. > > I did not know that. Thanks! I've got some laying > around here somewhere that I'll investigate that > condition. Good to know. > > Bob . . . > > ----------------------------------------) > ( . . . a long habit of not thinking ) > ( a thing wrong, gives it a superficial ) > ( appearance of being right . . . ) > ( ) > ( -Thomas Paine 1776- ) > ---------------------------------------- > > > > ________________________________________________________________________________
Date: Jul 26, 2008
Robert L. Nuckolls, III wrote: > Most Ethernet cable is solid strands of wire. > It's not a wire designed for flexibility or > robustness under vibration. You could give it > a try. It might last quite some time before > needing a replacement. Often ethernet cable intended for building wiring is solid, but that destined for patch cables is stranded. If it is a roll of cable, the side of the box/spindle should say on it which type it is, otherwise just cut a piece of the wire apart and look at it. In my experience you have about a 50/50 chance of it being either. -Dj -- Dj Merrill Sportsman 2+2 Builder #7118 http://deej.net/sportsman/ "Many things that are unexplainable happen during the construction of an airplane." --Dave Prizio, 30 Aug 2005 ________________________________________________________________________________
Subject: Connectors for trim servos?
Date: Jul 26, 2008
Real basic question: I need to connect the wires (2 power, 3 indicator, 24 or 26 gage?) coming from Ray Allen trim servos to a removable connector. What's appropriate? D connector, molex, something else? Thanks, Ralph Finch ________________________________________________________________________________
Date: Jul 26, 2008
Subject: Re: Connectors for trim servos?
> >Real basic question: I need to connect the wires (2 power, 3 indicator, 24 >or 26 gage?) coming from Ray Allen trim servos to a removable connector. >What's appropriate? D connector, molex, something else? > >Thanks, >Ralph Finch Here's one of several dozen alternatives. http://www.aeroelectric.com/articles/macservo/macservo.html Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 26, 2008
Subject: Re: IR to ER alternator
Bob: I didn't do ANYTHING to deserve your demand for me to "go away". It's just not going to happen. I have not engaged you or said one word about you. Please stop harassing me. I didn't say anything wrong technically, personally or controversial in any way. Your comments are not constructive and just mean Sir. I replied to a Gents post asking for opinions on "IR to ER Mod" that I knew about, having done this mod on a friends alternator. It's not about YOU. It is about converting IR to ER alternator mod. Do you have any comment about the IR to ER alternator mods? If not what is the problem? I DID suggest he consider using the IR ND alternator as it was designed, leave it alone, as is with out chopping it all up, spending more time and money on the modification and an ER. Is that a problem? Using IR is a valid consideration. It saves cost, hassle, retains the thermal protection that IR's have, which ER's don't have. Why butcher a 2008 alternator back to the 1970's? I talked to Matt about this situation with you. I agreed not to argue with you. You are out of line here, accusing me of saying I called anyone a liar is a total miss representation of what I wrote........ +++++++++++++++++++++++++++++++++ I did not call you or any one a liar. In the PAST any negative story about IR alternators was accepted and repeated with out any challenge on this forum. I read them. There was no lie, just classic hanger flying. I'm happy to say that the reports of service issues are more factual now. However BOB you say you are all about Science. As I read about these stories of OV with IR I was concerned (because I fly with one). I also questioned the vagueness of the stories. I knew these alternators are very reliable on my plane and others, Lexus, Acura, Honda, tractors and forklifts. The stories did not make sense. What does the electronics on a Lexus cost? Auto manufactures have a vested interest to avoid OV. This is not new. Stories of IR alternators allegedly destroying $30,000 panels where void of any details, facts: type / model of alternator, person, place, type of plane, N-number, what failed and why? That's not scientific is it Bob. As the moderator Bob you let them go with out challenge, and as a self proclaimed man of "Science", that lack of evidence or data did not bother you? If I said something as unsubstantiated as B&C regulators destroyed a friend of a friend's plane, you would yell bloody hell for absolute proof. You can't go on hearsay and rumor. However in the last two years since I started to question it, reports are better. You go with what you know, but let us "experimental" aircraft builders experiment and explore improving IR. What skin is it off your nose? Bob, I do a "REPEATABLE TEST" every time I fly my airplane with an IR alternator, sometimes near FL180. Me and my flying mates individually have as much as 15 years and many 1000's of hours of trouble free IR alternator ops each, in kit planes. The results of my repeatable IR test are always the same, awesome! How may kit planes have you built and how many hours do you fly a month? I am not saying you don't know what you're talking about. I am saying I have had very good experience with IR alternators as a builder & pilot, that's all. My interest is in improving the adaptation, installation and operation of IR alternators (ND in particular) in little planes. You a You take one word I say and make it 100% guarantee? No Bob, that's a silly thing to say. You take something I or others say to ridiculous extremes to discredit. It's not going to work Bob. Of the reports of OV with IR ND's where the pilot was able to note the voltage, 16-17 volts is common, but some times its less, some times it must have been more. Unfortunately not all pilots are able to note the actual voltage. In 2 - 3 yrs of really taking a hard look at IR, talking to pilots, manufactures and reading the web, following up with emails to get more detailed info, I found two cases where damage happened from an OV. Keep in mind the vast number of IR units in service. One was pilot induced & the problem was ignored, as he flew around for awhile. Another case was an actual "lose screw". Stuff does happen. I found some issues, and mitigating factors like improper installation and pilot operation, as well as poor quality rebuilds or aftermarket parts. I am just getting the word out. Bob can you give me a 100% guarantee of failure free operation (in writing) follow all your suggestions? "vary rare" - Sorry for the lack of specific statistics and MTBF (mean time between failures). BTW you don't have MTBF data for airplane alternators with ER. You don't. ******************************************************* I don't see the statistics showing IR Alts are prone to catastrophic OV failure (but it can happen). However if installed and operated properly the "statistics" are good. Depending on the cost of your panel EXTRA OV protection may be a wise idea for peace of mind. Some may choose to install MOV's (varistor) on individual circuits to protect them from transients, with CB's so you can reset. Bob calls that the shotgun approach, I call it redundancy. ******************************************************* What is "Modern"? technology developed in say last two decades, use of IC chips with multi control functions and fault detection and warning. If its based on 1970's or older technology (ER) its not modern. ER technology is not being developed or progressing in the auto industry; all the development is for IR, except in large marine or industrial applications, where paralleling and central control is involved. Jet and turboprop is a different, starter/generators or constant speed drive AC with inverters & battery chargers for DC. GA aircraft are stuck some of the most gosh awful alternators and regulators ever made. The after market like Plane Power and B&C are correcting the poor GA aircraft electrical sys with MODERN alternators. They of course are stuck with ER because that is what was certified. There are 10's of millions of IR ND alternators going 24/7 world wide in cars, trucks, tractors and industrial equipment (and kit planes) with out issue. No OEM makes new ER alternators under 100 amps today. IR alternators are more common and easier to get in a pinch from auto parts stores. Try getting a B&C alternator or voltage regulator 1,000 miles from home on Sunday = good luck.. If you're interested in helping me improve IR for aircraft use, than you are welcomed to help, but please stop insulting me. I am not a threat to you. Do you think ER is the pinnacle and can not be improved upon? Do you think IR will always be a poor second choice? If the answer is yes fine, but its your preference. It is very hard to make a "Scientific" case for one or the other. They share 90% with each other anyway. Cheers George >From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> >Subject: Re: AeroElectric-List: Re: IR to ER alternator mod >>Roger: I have seen that back a few years ago and >>studied it. I even talked by email to the Gent. >> >>If you are doing all this because you are worried that >>your internal regulator will go insane and melt your >>electrical system down, you are worrying too much. That >>story is way over blown and very rare. >Over blown? Is that between humongous and >gargantuan or just under bodacious . . . I forget. >But even your words "very rare" says the risk is >not zero. (WHAT? MY GOSH? YOUR CROW BAR MUST HAVE TRIPPED? YES RARE. LETS SEE YOUR ANALYTICAL STATS? IR ALTS HAVE ACCUMULATED MORE HOURS IN A WEEK (ALL VEHICLES) THAN ALL ER ALTERNATORS IN SMALL GA PLANES (FACTORY OR KIT) IN THE HISTORY OF AVIATION.) >> In the cases where damage was >>done the pilot did a few things to make it happen. >George, go away. You have ZERO evidence of >that and your accusation is uncalled for. >The evidence contrary to that statement is >solid and inarguable which makes your statement >tantamount to calling goodly numbers of folks >liars. (YOU ARE OUT OF LINE) >> Most >>failures of ND type alternator are usually not OV but >>they just stop working. When they do lose stable voltage >>regulation they generally top out in the 16-17 volt range. >Maybe . . . but again, are you ready to offer >100% coverage insurance for the ones that are not >"generally" topping out at 17V? (NO BOB, WHERE IS YOUR 100% GUARANTEE? YOU ARE BEING SILLY. IT IS JUST AN OBSERVATION.) >> Most >>modern avionics can work on 10-30 volts all day long. >But batteries don't. Lights don't. Contactors don't >and how many OBAM aircraft are fitted only with >"modern" avionics . . . and exactly when does "modern" >kick in? 1985? 1996? (BOB BOB, YOU HAVE TO READ THE MANUAL FOR YOUR AVIONICS OR CALL THE MANUFACTURE, VERY SIMPLE. ITS THERE IF YOU WANT TO LEARN.) >>In the event of say an unstable regulator, lower RPM, >Okay, a fully fielded ND puts out full rated current >at about 4500 shaft RPM. When running at cruise >(2500 on engine) the alternator is spinning at about >4x that. So if we want to get the alternator to be >current limited to say 20A, we need to get it down to >about 1500 RPM which puts the engine at less than >idle. What kind of emergency operations procedure >is that? BOB YOU MAKE A GOOD POINT, THERE MY BE LITTLE DIFFERENCE, BUT LOWER RPM WILL LOWER PWR OUTPUT AT ANY RPM. ASSUMING VOLTAGE REGULATOR IS NOT WORKING, RPM AND LOAD ARE THE ONLY WAYS TO CONTROL VOLTAGE. POWER VERSES RPM CURVE IS NOT FLAT, WITH RESPECT. IT DOES START TO FLATTEN OUT AT 7000 TO 8000 RPM BUT LOWER RPM = LESS PWR. YES IN FLIGHT ALT RPM IS ABOUT 6000 TO 8000 (3 TO 1 RATIO NOT 4 TO 1). YES "RATED MIN" POWER IS AT 5000 RPM (NOT 4500 RPM) BUT IT DOES INCREASE ABOVE RATED BY ABOUT 5-7 AMPS FOR HIGHER RPM. SO LOWER RPM DOES HAVE AFFECT ON POWER OUTPUT, ALTERNATOR 101. BUT YOU MAKE A GOOD POINT ITS SMALL AND NOT WORTH THE EFFORT, I AGREE. >>increase load (landing lights) and ideally you have a >>pull-able CB in the panel for you B-lead, pull CB, reduce >>elect load & land. No fear no dark and stormy night. >But assuming that you can pull a b-lead breaker >and bring the power back up, the alternator self- >destructs. YOU ARE DOING THIS BECAUSE ITS AN EMERGENCY AND THE VOLTAGE IS LOW OR HIGH ABOVE THE STANDARD SET VOLTAGE 14.3 - 14.5 VOLTS. WE ASSUME THE ALTERNATOR IS SHOT. YOU ARE NOT WORRIED ABOUT THE ALTERNATOR AT THIS POINT. IF VOLTAGE IS TOO HIGH, WHICH COULD POSSIBLY DAMAGE BATTERY OR AVIONICS, TO HECK WITH THE ALTERNATOR, PULL THE B'LEAD CB. THAT IS WHAT YOUR CROW BAR DOES. IF THE ALTERNATOR IS DEAD PULLING THE CB WILL DO NO DAMAGE, BUT MAY BE SAVE SOME SMALL PARASITIC DRAIN THROUGH THE VOLTAGE REGULATOR. MANUAL CB DISCONNECT AVOIDS ACCIDENTAL TRIPS THAT CAN HAPPEN WITH AUTOMATIC DEVICES LIKE A CROW BAR, WHICH CAN RUIN A GOOD ALTERNATOR. IT HAS HAPPENED MANY TIMES, TURNING GOOD ALTERNATORS INTO TRASH, OUCH. EVEN VAN'S AIRCRAFT BANNED THEM, OUCH X 2. NO OFFENSE BOB. **THE FIRST STEP** SHOULD BE TURNING THE ALT SWITCH OFF, THAN PULL THE CB (B'LEAD). THE ALT SWITCH (POWER TO IGN LEAD) MAY OR MAY NOT TURN ALTERNATOR OFF, DEPENDING IF THE VOLTAGE REGULATOR RESPONDS, WHICH IS AFFECTED BY WHAT FAILED. REGARDLESS IF IT SHUTS DOWN WITH ALT SW, PULL THE CB. YOU CAN'T COUNT ON THE ALT SW (IGN PWR) TO KILL THE ALTERNATOR. ALSO YOU SHOULD NEVER USE THE ALT SWITCH TO ROUTINELY TURN THE ALTERNATOR ON OR OFF WHILE THE ENGINE IS RUNNING, IT WILL DAMAGE THE ALTERNATOR. IN MY RESEARCH PROBLEMS STARTED IN SEVERAL CASES WHEN THE PILOT ELECTED TO PLAY SWITCH MONKEY AND CYCLE THE ALT SW WHILE THE ALTERNATOR WAS UNDER LOAD. IS THIS SCIENCE? WELL ITS MORE ANECDOTAL BUT RELEVANT & SCIENTIFIC OBSERVATION, CAUSE & AFFECT. I HAVE NOT DUPLICATED THIS ON THE BENCH BOB, REPEATABLY, BUT ITS A GOOD OBSERVATION. THIS IS MY CONTRIBUTION TO "SCIENCE". I HAVE DOCUMENTED THIS FAILURE. IF THERE IS CHANCE ITS A PROBLEM DON'T DO IT. FOR SOME REASONS PEOPLE LEARN ON A CESSNA OR PIPER (FAA APPROVED MANUALS) TO NOT CYCLE THE ALT SWITCH UNLESS THERE IS A NON NORMAL CONDITION. HOWEVER HOME-BUILDERS FEEL THE NEED TO THROW STITCHES THEY DON'T NEED TO. MAKE IT SIMPLE, ALT 'ON' WITH BAT BEFORE ENGINE START, ALT 'OFF' WITH BAT AFTER ENGINE SHUTDOWN. THIS IS HOW IT WORKS IN THE CARS IT WAS THESE ALTERNATORS WHERE DESIGNED FOR, ANOTHER "SCIENTIFIC OBSERVATION" OR CORRELATION. >Your advice is horse-hockey by the bucket-full >George. Go away. (YOU ARE BEING RUDE AND AWFUL) >>Also IR gives you a LO/Hi volt and fault warning light. >Which is only a warning light as far as anyone can >deduce from the lack of schematics to substantiate >any claims to the contrary. It does nothing to >actively shut down an alternator being driven by >a failed regulator. BOB THE FUNCTION OF THE IR ALTERNATOR INDICATOR LIGHT (LIKE EVERY CAR HAS) IS WELL ESTABLISHED, AND NO ONE SAID IT WOULD SHUT THE ALTERNATOR DOWN AUTOMATICALLY. BOB THIS INFO IS IN THE AUTO REPAIR MANUALS FOR CARS AND ALTERNATORS. I RESEARCHED THIS. YOU HAVE ASKED OR SAID THIS 20 TIMES BEFORE. THROWING OUT QUESTIONS TO RAISE DOUBT WHEN IT IS CLEAR YOU DON'T REALLY WANT TO LEARN, SO ITS JUST A WASTE OF TIME. YOU WILL NEVER AGREE THERE ARE NICE FEATURES WITH AN IR; YOU JUST ACT LIKE ITS ALL BOGUS SMOKE & MIRRORS. NIPPONDESNO AND THE ENTIRE AUTOMOTIVE ELECTRICAL INDUSTRY ARE IDIOTS, RIGHT. BOB I GAVE YOU A BLOCK SCHEMATIC OF A TYPICAL IC. DID YOU UNDERSTAND IT? IF YOU DON'T GET IT, THAT DOES NOT MEAN IT'S BAD? EVEN IF YOU HAD THE DETAILED ENGINEERING OF THE DIGITAL LOGIC CIRCUITS IN THESE IC CHIPS, WOULD YOU KNOW WHAT IT MEANT? THEY ARE COMPLICATED NO DOUBT, VERY SOPHISTICATED. IT IS MORE THAN TWO TRANSISTOR, DIODE AND A FEW RESISTORS. I SUGGEST BUILDERS INSTALLING IR ALTERNATORS USE THE INDICATOR LIGHT, AND ANY ADDITIONAL HI/LO VOLT IDIOT LIGHT AND VOLT-METER THEY WANT IF DESIRED. THE "INDICATOR LIGHT" ALSO ACTS AS A FAULT LIGHT LIKE TROUBLE CODES ON A CARS COMPUTER. IT DOES NOT GIVE OUT A CODE BUT WHEN IT ILLUMINATES, IT MEANS THERE IS A FAULT CAUSING THE VOLTAGE TO EXCEED SET VOLTAGE (HI/LO). YOU CAN EVEN HAVE NORMAL VOLTAGE AND GET THE INDICATOR LIGHT AS A SOFT FAULT. THE IC CHIP IN IR REGULATORS ARE SMALL MICRO PROCESSORS. YOU JUST DON'T GET THE FACT THESE REGULATORS HAVE FAULT/CONTROL LOGIC. THERE ARE CHEAP AFTERMARKET IR THAT ARE NOT MADE TO FACTORY SPECS OR HAVE AN IC CHIP, BEWARE. YOU WANT TO VERIFY THE BRAND OF REGULATOR. YOU WANT ONE WITH THE ORIGINAL ASIC DESIGN. ONE WAY IS TO BUY OEM ND PARTS OR VICTORY FROM TAIWAN. I'LL BE GLAD TO HELP ANY ONE OFF LIST SO BOB DOES NOT GET MAD. >. . . and oh yes, if the designers included ov warning >in their product, could it be that they also believe >the risk for their product to malfunction is not zero? >. . . or do you think they included that feature just >to placate me? >Go away George. I will not have you trolling this >List for acolytes in the Cult of the Infallible ND. >Go start your own List. >Bob . . . (I AM HAPPY HERE BUT THANKS FOR THE SUGGESTION. IF YOU WANT TO BE AN EXPERT IN IR ALTERNATORS YOU CAN HAVE IT BUT YOU DON'T SUPPORT ITS USE AS OF NOW.) ________________________________________________________________________________
Date: Jul 26, 2008
Subject: Re: IR to ER alternator mod
>From: "Robert L. Nuckolls, III" > >Subject: Re: AeroElectric-List: Re: IR to ER alternator mod >>Bob, Eric, George, JetPilot and the rest of the list: >>From the perspective of someone who has been >>following the list for a >>while and who is not as ignorant as most of >>things electrical nor of lists supporting the free >>exchange of ideas and, perhaps most important, >>someone who is not "tribal" in the least, I >>respectfully ask that Eric, George, JetPilot NOT >>go away. >Sorry. This is MY classroom and in this venue, >it's not a question of opinion and viewpoints. It's a >question of repeatable experiments and good >science. For you to say you use SCIENCE is just funny. It reminds me of the 80's Thomas Dolby song "Blinded By Science" where in the chorus he yells, "SCIENCE"! What do I use, egg salad? You are talking to people, including me, with engineering and science degrees. Any freshman engineering, science or medical student learns scientific methods in their labs. That is great you use science, but Bob what relevant facts do you bring with your "science". What repeatable test have you done regarding IR to ER conversions? Blurting out "repeatable test" and "good science" is a red herring, a non sequitur. It seem like you say it to impress. I have 1000's of flight hours behind IR alternators. That is service history. I run my "test" ever time I fly. Every time I do maintenance and check the brushes, I am doing a test and so are all my friends with IR alternators. I do have more advanced education in engineering, math and science than you Bob, as well as more flight experience and ratings. Advance math is the language of science and the absolute in problem solving and logic. Therefore I must be right since I have more education? Education is irrelevant ...... just like the repeatable test pronouncements are irrelevant. You can't win arguments but just saying "repeatable test". You can try but it doesn't really work. BTW before "repeatable test" you must determine if a test is VALID! You have to know what and why you are testing, what to measure and how to measure it. Than you have to validate the data, correlate with theoretical analysis or other known data. That is why flight test is done, to verify the analysis and component test. I do flight test. I flight test my IR alternators many times a week, as do 100's of other pilots with out problem. My IR alternator has been shown to be reliable, as many friends with IR alternators in their planes have shown. Matt wants a civil tone and contribution from many. I think that is what most members of the list want as well. They just don't want the fighting. We can spar but I rather not. BOB I HAVE INVITED YOU TO JOIN ME IN TESTING AND IMPROVING IR ALTERNATORS. WHY DON'T YOU? >>The 'I'm still right and you're still wrong and >>since you still don't agree with me let me >>explain it to you louder (or longer...)', which, by >>my reading, has been evident in both camps of >>the great debate seems to me to be not just >>disrespectful to the involved parties but also to >>the list-reading public in general. >This List is not frequented by the "public in >general" and the vast majority of the public in >general would receive no benefit from hanging out here. A "can't we all just get along" idea has the >effect of leveling the playing . . . field to average . >. . mediocracy . . .an environment crafted to upset >the least numbers of folks irrespective of their >viewpoints and opinions. I'd like to believe that >the membership of this List represents the top >slice of individuals struggling to build a better >than average airplane. Bob you may think I am the "bottom slice" but you don't know me. I have been involved in building planes both airliners as and engineer out of college and kit planes since 1985. One of my planes, RV-4, won a workmanship award at a major EAA fly-in. There's nothing mediocre or average about what I do, and have much in common with builders as a builder. I did go to college and grad school and paid for every nickel of it my self, by working. No excuses I am proud of that and should be. I also paid every nickel of my initial flight training through 5 instructor ratings and ATP, which helped me get my flying career going, three type ratings and +11,000 hours later and still counting. There's nothing mediocre Bob, I just bring different things ideals to the table as you do. > When you select a doctor, engineer, lawyer or >teacher, do you want one who has been trained >in the "everybody is right to some degree" school >of thought . . . or is the demonstrable best in their >respective fields? > George and Paul have demonstrated nothing . . . >yet they've wasted a lot of $time$ as we >attempted to make nice. Eric has demonstrated a >great deal of initiative and creativity. See: >http://www.periheliondesign.com/ Well that is just rude and untrue. I have helped many people Bob and I know they appreciate it. I know Paul has interesting things to say, which I enjoy, which helped me. The only one upset is YOU! And how do I cost you money? You mean by recommending cool gear that is not B&C, which you get a kick back from? Does that make you mad? Is that what it is about? OK I will not recommend Plane Power any more. It is a free country and free market. I have no interest in Plane Power , Transpo or Perihelion Design. I do want a rich base of knowledge and ideas from more than ONE person. I also want more than one vendor for parts and competition to keep prices down. That is the American way. THE BIG UNKNOWN? You claim there is no detailed info on IR to satisfy you, so you disqualify its use. You just don't want to accept the info. I really don't think more info would make a difference no matter what I show you. I don't think you understand whats going on in an IR. You are set on one idea. Which I am fine with but you seemed like you can tolerate anyone ignoring your advice. If they do they are either dumb or trolls. That is harsh and dogmatic. > . . . and he is trying. And I've offered to assist >his endeavors right here on this List. I'll leave it >up to those who choose to follow the >conversation to judge the value of investing the >$time$. > Please do not mistake confidence and >competence with arrogance and conceit. I'm >simply exercising control over the decorum and >quality of this activity I agree people can make their own minds up. Why are you afraid of other ideas? You claim other input is inferior? Why? More ideas the better. If your concepts are better they will shine. You have to trust people to have the brains to make their own minds up. I just want to help people that DO want to IR alternators. I don't want to sell them on it, only improve upon it for those committed to IR. No criticism of your concepts. >If your concerns are for making nice (no matter >what opinions might be offered) you'll need to >find another group that's more concerned with >making folks feel better than in helping them do >the best we know how to do at a budget they can >afford and technologies their skills and $time$ >can master. > Bob . . . Bob actually I think you are a little insecure. Bob every one agrees and recognizes you are THE expert, the MAIN contributor, but you are proving it all the time. Stop proving it, we all know and respect that. But respect is a two way street. Your last two post have helped me understand how you think and see yourself in this forum, WOW~! I get it. I'll try to say out of your way. ________________________________________________________________________________
Date: Jul 26, 2008
> What are your battery-only energy storage requirements? The system will draw a bit over 14A worst case and I can shed as much as 4A without sacrificing functionality. My design goal is to keep the remaining 10A of "battery only" stuff alive (bus voltage >20V) for at least an hour if the alternator drops offline. > Does the system DEPEND on a battery for functionality? > In other words, would a failed battery contactor put > the outcome of the flight at risk? No, not as long as the alternator remains well behaved with the batt contactor open. BTW, our primary power source is a dedicated 28V 100A alternator (National Airparts N300) wired per the "Z" diagrams with a Zeftronics R25400 for voltage regulation and over-voltage protection. The architecture also includes a "filter" cap sized per Nat'l Airparts recommendations. Have I made a mistake in assuming that this system will remain online without the battery (e.g. - if the 28V battery contactor fails open)? This is something that we can (and will, unless advised otherwise) check out on the ground as part of a systems functional test. > What preventative maintenance program do you plan > for replacing batteries before they're incapable of > supporting battery only systems for the designed > endurance mode? Standard battery care/feeding is the plan (e.g. - battery tender when down, periodic capacity testing as part of the preflight prep after storage). Replacement will occur when capacity tests show that achieving the "1-hour battery only" target is not possible. > There's no objective data to suggest that any particular > brand of battery is the better value in terms of > $replacement$/service-hours. Periodic cap testing of the > batteries in service is the 100% foolproof way to guarantee > system performance irrespective of the batteries you choose > to try. Understood. It will be interesting to compare the results from the "cheap" battery tests against those from the $approved* battery that rides around in my C150. I have a hunch that the 3x cost doesn't necessarily translate to 3x performance/service-hours... ;-) Thanks for your insight, Bob! D ________________________________________________________________________________
Date: Jul 26, 2008
How incredibly arrogant and rude, George. I don't care about your ratings or your degrees. If you were so smart, you wouldn't be flying for hire. On listservs I run, you would be gone, right now, blocked from ever rejoining for your series of insulting posts and arguments you have been told are not welcome. Your lengthy post added zero, was nothing but self flagellation and insults. I ask that Matt block you from this list if Bob won't do it. This isn't a general list for debate, it is Bob's list to discuss his book and its recommendations. You obviously are too lazy to start your own list and rather interfere with list belonging to someone else. That is most offensive. The rest of us subscribe to discuss topics AeroElectric. We don't want to talk about you. I'll filter your posts out from no on, as I have no respect for your antagonistic approach. gmcjetpilot(at)yahoo.com wrote: > > > Bob actually I think you are a little insecure. Bob > every one agrees and recognizes you are THE > expert, the MAIN contributor, but you are proving > it all the time. Stop proving it, we all know and > respect that. But respect is a two way street. > > Your last two post have helped me understand how > you think and see yourself in this forum, WOW~! > I get it. I'll try to say out of your way. > ________________________________________________________________________________
Date: Jul 26, 2008
Hmmm . . . got the message first privately but I see George posted a copy to the list too. Here was my sniped reply: >Bob: > >I didn't do ANYTHING to deserve your demand for me to >"go away". It's just not going to happen. I have not >engaged you or said one word about you. Please stop >harassing me. But you keep dispensing the same bad information . . . sprinkled with enough good information to give yourself credibility. Just review the postings I've made in your honor sir and be reminded of the behaviors that illuminated your dishonor . . . http://www.aeroelectric.com/articles/gmcjetpilot.html http://www.aeroelectric.com/articles/The_Truth_about_Crowbar_OV_Protection.pdf > I didn't say anything wrong technically, >personally or controversial in any way. Your comments are >not constructive and just mean Sir. Soft regulator failures that limit to 16-17 volts are a figment of your imagination. Recommending pilot intervention in an OV condition by reducing rpm, added loads an hoping that a b-lead breaker is bad design and equally bad advice to a neophyte airplane builder that comes here to get solid information. I'm not mean but I am insistent. Your design goals are not consistent with good practice and you've repeatedly demonstrated an unwillingness or inability to carry on a detailed design review in which logic and science prevail. This is not an open forum and you're not being harassed. You're simply being asked to take your advice elsewhere. Probably 95% of the OBAM aircraft licensed each year have no features offered by this forum or my website. That's a pretty fertile ground George. Just imagine how many folks will be impressed with your secret existence, the alphabet soup out the wazoo behind your name and the confidence with which you dispense information about things you have not experienced and cannot demonstrate. Go away George. Bob . . . ________________________________________________________________________________
Date: Jul 27, 2008
Subject: Success!
This last week, with trembling hands and fire extinguisher close at hand, I connected the battery to my Kolb Mk III's new electrical system. I used the Z -17 schematic virtually verbatim. I did put in a SPST key switch between the fuse panel and the starter solenoid, but that's about all I deviated from the plan you laid down. To my delight, and relief, all the smoke remained in the wires and everything works. I realize that my system is bare bones simple compared to all of you glass panel folks out there, but this was my first attempt at wiring up an airplane from scratch. Thanks, Bob. Rick Girard Kolb Mk III, returning to the air this week Yippee! ________________________________________________________________________________
Date: Jul 27, 2008
Subject: Literature source
Stumbled across this site during a websearch: http://home.att.net/%7Ebtuttleman/barrysite.html#ALLISON He offers original and copied manuals on a wide variety of topics and products . . . but in particular interest to us, has a good library of King, Narco and ARC manuals amongst others . . . Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2008
Ralph=2C Those pesky little Ray Allen trim servo wires are a pain in the neck=2C are n't they? A friend of mine recently brought me a Narco AT165 which he had wired to a GRT Enigma EFIS. The EFIS has a low-density 15 pin D-Sub connector which ou tputs the gray (Gillam) scale data to the transponder. He had used a comput er cable which he cut in half and connected the wires to the 18 pin Molex c onnector in the Narco's rack. I liked the idea of the computer cable because it was neat=2C shielded=2C c ontained good quality color-coded stranded wire and made a neat installatio n. That is=2C until you got to the cut end. The 26AWG wires just weren't ro bust enough to serve at the junction between cable and tray connector. Also =2C he had "shielded everything" which is a whole 'nother post:O) At first=2C I discarded the idea of using the cable due to the 26AWG wires. Heck=2C my wire stripper doesn't go smaller than 22AWG! However=2C reality set in as I could not seem to find 9 or more conductor shielded wire in 22 AWG at my local supply house unless I bought 500 feet of it! At over $2 per foot=2C I wasn't going to go there. So=2C how to make 26AWG wire more robust. After all=2C it's plenty good eno ugh to carry microVolts and milliAmps=2C right? Here's what I did. First=2C prepped the cable. Cut the cable back to fresh wire leaving ~1" conductor length. Cut the drain wire flush with the outer insulation and foil shield. Slid medium and large heat shrink over the cable for later. Second=2C prepped the conductors. Stripped the 26AWG wires just enough to accept .062" Molex pins. Slid 1/16" heat shrink (white for signal) over the wire. Crimped on the Molex pins. Pull test to verify good crimp. Slid heat shrink over both insulation and wire grip. Applied heat to heat shrink on individual wires. Now I have a beefed up wire. It's still 26AWG=2C but it is well supported. Repeat for all 9 encoder data wires and 4 grounds for the Enigma. Third=2C populated the intermediate 12 pin Molex connector. Inserted the wires into the holes until click was heard and felt. Gathered the wires together for maximum mutual support. Slid heat shrink up over bundle overlapping cable about an inch. Applied heat to heat shrink over cable and bundle of wires entering Molex. Now I have a beefed up cable to connector junction. Even more support. Fourth=2C prepped wire for 12 pin intermediate Molex to 18 pin Molex Narco tray connector. Cut 18AWG color coded wire from old bundle laying around house. Length minimal to get the wires neatly spread as needed. Had to repeat some colors=2C no biggy. On .062" Molex end used same technic as above to prep wires. On Narco tray end crimped on KK type connectors without heat shrink. The pins would not insert with heat shrink in the way. Fifth=2C populated .062" Molex as in step "Third" above. Sixth=2C populated 18 pin Molex connector on Narco slide-in tray. Seventh=2C created table using MS Word to keep track of all wires=2C wire c olors=2C connectors=2C destinations and functions. Eighth=2C verified table by painstakingly examining each and every wire. Ninth=2C verified continuity between the 15 pin D-sub (origen) and the 18 p in tray connector (destination). What my friend now has is a very neat cable installation that is also quite robust. I can't wait to see if it passes the avionics shop testing process . His wiring job had yielded "ALT INVALID" results and ATC said his altitud e info was wacked. BTW=2C used a second 3 pin .062" Molex conector for the Narco's power and g round wires. It lies right smack on top of the 12 pin connector and looks g reat. These were safetied with plastic tie wraps so they won't work loose. Rodney in TennesseeUnabashed Nuckollhead _________________________________________________________________ Keep your kids safer online with Windows Live Family Safety. http://www.windowslive.com/family_safety/overview.html?ocid=TXT_TAGLM_WL_ family_safety_072008 ________________________________________________________________________________
Date: Jul 27, 2008
Thanks Bob, as usual you have the precise answer... RF -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, July 26, 2008 1:28 PM Subject: Re: AeroElectric-List: Connectors for trim servos? --> >--> > >Real basic question: I need to connect the wires (2 power, 3 indicator, >24 or 26 gage?) coming from Ray Allen trim servos to a removable connector. >What's appropriate? D connector, molex, something else? > >Thanks, >Ralph Finch Here's one of several dozen alternatives. http://www.aeroelectric.com/articles/macservo/macservo.html Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2008
Subject: Re: Success!
>This last week, with trembling hands and fire extinguisher close at hand, >I connected the battery to my Kolb Mk III's new electrical system. I used >the Z -17 schematic virtually verbatim. I did put in a SPST key switch >between the fuse panel and the starter solenoid, but that's about all I >deviated from the plan you laid down. To my delight, and relief, all the >smoke remained in the wires and everything works. I realize that my system >is bare bones simple compared to all of you glass panel folks out there, >but this was my first attempt at wiring up an airplane from scratch. >Thanks, Bob. You're most welcome. I'm pleased that you found your experiences here useful and productive. Bob . . . ________________________________________________________________________________
From: "Richard Dudley" <rhdudley1(at)bellsouth.net>
Subject: RV-6A For Sale (revised)
Date: Jul 27, 2008
Listers, My re-review of the market suggests a revision of asking price. This is one more try here before going to other locations to advertise. A combination of health and financial factors have forced our decision to sell our beloved airplane. If you are seriously looking for a beautiful, well-equipped and flying RV-6A read the description below. RV-6A FOR SALE Completed 2005 Total time <140 hrs O-320-D1A Total time since new <140 hrs Hartzell C/S Prop total time since new <140 hrs Slider Great paint Garmin GNS 430 nav/com SL-30 nav/com Garmin GTX 327transponder Garmin GMA 340 Audio panel Dual CDI with glideslope and coupling to either Nav IFR panel, heated pitot, certified altimeter, encoder, transponder and pitot static system Dual Duckworks landing/taxi lights with Wig-Wag S-Tech System 20 auto pilot/ turn coordinator New main tires Always hangared March 2008 annual Asking: :$95K Serious buyers contact me off line and I'll send you more details. Richard Dudley rhdudley1(at)bellsouth.net Orlando, FL ________________________________________________________________________________
Date: Jul 27, 2008
From: "ROGER & JEAN CURTIS" <mrspudandcompany(at)verizon.net>
Subject: Z-19/RB Question
Bob, In reviewing the Z-19/RB drawing, I have a question regarding the endurance bus feed. There is a diode feed from the main bus, with which I have no problem. However, if the alternator fails and the low voltage module opens the engine battery contactor, there is no way to power the endurance bus from the engine battery. In this case both paths to the endurance bus come from the main battery. Did you intend for this wiring to be this way or should the EBUS ALT FEED connection be made to the engine battery bus instead of to the main battery bus? Roger ________________________________________________________________________________
Date: Jul 27, 2008
Subject: Re: Z-19/RB Question
>Bob, > > >In reviewing the Z-19/RB drawing, I have a question regarding the >endurance bus feed. There is a diode feed from the main bus, with which I >have no problem. However, if the alternator fails and the low voltage >module opens the engine battery contactor, there is no way to power the >endurance bus from the engine battery. In this case both paths to the >endurance bus come from the main battery. Did you intend for this wiring >to be this way or should the EBUS ALT FEED connection be made to the >engine battery bus instead of to the main battery bus? No, the normal feed is from the main bus which (in normal operations) is powered from the main bus supported by the alternator and two batteries. In case of alternator failure (and with the engine battery switch in the AUTO Mode), the engine battery is automatically separated off to support only the engine. The main battery is still supporting the main bus . . . until the pilot elects to drop to an endurance mode (main battery contactor OFF, alternate feedpath closed). Normally, you would never want to power the endurance bus from the engine battery unless you've suffered multiple-failures (main battery craps). Even then you're probably better off reverting to the J-3 mode with stuff from the flight bag as opposed to burdening the engine battery with keeping the fan running -AND- powering up stuff on the panel. So your observations are correct, there was never any intention of powering the e-bus from the engine battery. However, you ALWAYS have the option of closing both battery contactors and running the whole airplane from both batteries in parallel. The set of circumstances that would make this necessary/attractive are exceedingly rare. If it were my airplane, I'd have to be really hard pressed (and probably il-prepared) to burden the engine battery with more than running the engine. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: BnC Continuous Duty Contactor 12 v
Date: Jul 27, 2008
Does anyone know how much current the Continuous Duty Contactor 12 v listed at the B n c Website can handle ? I tried looking for some kind of data sheet but could not find one... Does it handle better than 130 amps ? May 90 ? Help anyone please. The specs they do list are: This contactor is suited for most applications in amateur built airplanes calling for continuous duty operation including (1) battery master contactor (2) ground power contactor (3)alternator b-lead overvoltage protection (4) dual alternator system crossfeed contactor [order S701-2] and (4) extend/retract control in hydraulic landing gear systems. Supplied with spike suppression diode and battery terminal jumper already installed. Coil resistance is 15 ohms. Contactor Weight is 13 ounces This contactor terminals will use a .31 and #10 ring terminals. ________________________________________________________________________________
Date: Jul 27, 2008
Bob, In normal operations of a Z-19, would you have the EBUS ALT FEED switch turned ON (closed)? Seems that would keep the emergency switch manipulation to just one, the Master OFF. The ENGINE BAT switch in the AUTO position would already disconnect the Engine Battery. Do I have this right? Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195274#195274 ________________________________________________________________________________
Subject: Trim noise in Audio speaker
Date: Jul 27, 2008
Bob, Just a follow-up to eliminating the noise on the Ray Allen aileron trim motor. I tested the 272-1070 first which removed some of the noise when activated, but it was on and off. I took that off and did the six finger test using the 272-1436. Worked like a charm. Not a hint of noise. Peace at last. Thanks --------*****************************------------------------ Sure. Start off with a capacitor wired directly across the motor leads (I presume they're still both white). Refer to schematic at: http://www.aeroelectric.com/PPS/Flight/Trim/PitchTrim.pdf It's not common to have noise issues with these actuators. Let's assume the noise is radiated first. Try the .22 uF capacitor first 272-1070. Try the pair of 272-1436 if the first doesn't work. These need to be tied into the harness as close as practical . . . 2-3 inches outside actuator housing. Please let us know the results of your experiments. If the caps don't get it by themselves, we'll ratchet up a notch. ________________________________________________________________________________
Date: Jul 27, 2008
Subject: Re: BnC Continuous Duty Contactor 12 v
Jeffrey, I don't know the max. continuous rating, but I'm sure it's well in excess of 100A, way more than you would ever need in any usual homebuilt airplane. Of course, intermittently, it will handle a lot more than that, including full starter motor loads. Why not just give B&C a call tomorrow and ask them. Ron On Sun, Jul 27, 2008 at 2:46 PM, Jeffrey W. Skiba wrote: > jskiba(at)icosa.net> > > Does anyone know how much current the Continuous Duty Contactor 12 v listed > at the B n c Website can handle ? > ________________________________________________________________________________
Date: Jul 27, 2008
> >Does anyone know how much current the Continuous Duty Contactor 12 v listed >at the B n c Website can handle ? >I tried looking for some kind of data sheet but could not find one... > >Does it handle better than 130 amps ? >May 90 ? See: http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_70-Series.pdf The S701-1 contactor is a Stancor 70-902. It's rated for 80 amps continuous. But like all switches, relays and contactors, the ratings assume that you're going to SWITCH those loads. In the case of a battery conactor, loads seldom exceed tens of amps when the battery master is turned on. By the time the starter is engaged, the battery contactor is closed and stable. An alrady closed switch will carry several times its rated current for short periods of time (like cranking an engine) without serious degradation of service life. How are you using it that its ratings are a concern? Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2008
> >Bob, > >In normal operations of a Z-19, would you have the EBUS ALT FEED switch >turned ON (closed)? Seems that would keep the emergency switch >manipulation to just one, the Master OFF. The ENGINE BAT switch in the >AUTO position would already disconnect the Engine Battery. > > >Do I have this right? Thanks, You can if you wish. However, it's an ALTERNATE feed path and needs to be pre-flight tested. I'd turn it ON first thing and get the ATIS and clearance delivery. Then shut it OFF, start the engine, and leave it off until such time as needed to mitigate the effects of an alternator failure. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 27, 2008
Good data points sir. I'll file them away for future reference Thanks! >Bob, >Just a follow-up to eliminating the noise on the Ray Allen aileron trim >motor. I tested the 272-1070 first which removed some of the noise when >activated, but it was on and off. I took that off and did the six finger >test using the 272-1436. Worked like a charm. Not a hint of noise. Peace >at last. >--------*****************************------------------------ > Sure. Start off with a capacitor wired directly across the > motor leads (I presume they're still both white). Refer > to schematic at: > >http://www.aeroelectric.com/PPS/Flight/Trim/PitchTrim.pdf > > It's not common to have noise issues with these actuators. > Let's assume the noise is radiated first. Try the .22 uF > capacitor first 272-1070. Try the pair of 272-1436 if > the first doesn't work. These need to be tied into the harness > as close as practical . . . 2-3 inches outside actuator > housing. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 28, 2008
See: http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_70- Series.pdf The S701-1 contactor is a Stancor 70-902. It's rated for 80 amps continuous. But like all switches, relays and contactors, the ratings assume that you're going to SWITCH those loads. In the case of a battery conactor, loads seldom exceed tens of amps when the battery master is turned on. By the time the starter is engaged, the battery contactor is closed and stable. An alrady closed switch will carry several times its rated current for short periods of time (like cranking an engine) without serious degradation of service life. How are you using it that its ratings are a concern? I am using it as a battery contactor but with a Very High out alternator, 200amps ..... So I am thinking I need to find a bigger contactor ? or my other thought - guess was maybe to run TWO Stancor 70-902 contactors in parallel ? with the extra wires also... but concern here is that something I haven't thought of will smoke something if both are not closed ? Maybe I am overlooking a simple cheaper solution.... ________________________________________________________________________________
Date: Jul 28, 2008
Those Ray Allen trim boxes (they are not servos), have a number of deficiencies--the wires being one of them. Though many people use the D-subs, I prefer Molex locking C-Grid connectors that are used in computers. I also suggest opening the trim box and mounting the connector header on the wall. This will get rid of the maximum amount of the teeny wires. While you are screwing around in the box's innards--may I suggest a few improvements to their trim box? 1) To prevent dirt entering the box, the threaded rod extension can be covered with a little ballpoint pen cap or similar. Likewise the square actuator rod bottom hollow can be filled and a brush wiper installed. 2) Noise suppressor capacitors are easy to add. One .01 uF ceramic across the motor brushes and one 0.1 uF ceramic from each brush to ground (which you might want to add) is a standard approach. Keep the leads critically short. 3) Sealing the cover lid with a little goo or tape wouldn't hurt. If you want to convert the Ray Allen boxes to true servos, or see a schematic of what is inside the box, see my website. "Democracy is the theory that the common people know what they want and deserve to get it good and hard." -- H. L. Mencken -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195337#195337 ________________________________________________________________________________
Date: Jul 28, 2008
Bob, Understood, that EBus switch is ALTERNATE path to powering the EBus. And as you said, turn it on, check ATIS are all good preflight procedures to test this path. I just wanted to confirm that once you are started and the alternator is running smoothly, it would do no harm to leave the EBus switch turned on (closed) during normal operations. Thanks, Mike Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195343#195343 ________________________________________________________________________________
Date: Jul 28, 2008
I have railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines. Problems-- 1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part. 2) Not sealed. Not dust proof, or fuel proof. 3) Low interrupt capacity. 4) High hold current---16 ohm coil. Almost one amp. 5) Low hold force. The specifications call for specific orientation. 2G rating? 6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts. 7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications) See: www.stancor.com There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred. Can you use them? Sure. Should you use them?....not on my bird, Bubela. Better yet, avoid all contactors and use manual switches if you can. "Facts do not cease to exist because they are ignored." ---Aldous Huxley -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195345#195345 ________________________________________________________________________________
Subject: Grounding of com antenna on Tube and Fabric airframe
Date: Jul 28, 2008
I have a Kitfox 7 that I just had inspected (I have 1 hour on it so far) and am having issues with my transmission and reception quality and effectiveness. Here is a brief description of my problem: When at the airport (taxing, and in the pattern) my radio seems to work fine with the exception of an intermittent static blip every two seconds or so. As I get farther out, the intermittent blip becomes more pronounced to the point that my transmission and reception is horrible (transmission is worse than reception though by a long shot). Basically, my communications become unintelligible around 4-5 miles out. I originally didn't have a ground plane other than the mounting plate for the antenna (which the manual says is fine) so I added one on the advice of a couple people and the problem has not changed a bit. Here is a question: Does the antenna itself have to be electrically bonded to the airframe? I think the answer is yes and according to the maker of my antenna, mine is through the mounting hardware. However, the builder's manual says to remove any fabric and grind down the powder coating under the antenna to get a good bond. Would this be my problem? Would the issues I have described be symptomatic of a poorly grounded antenna? I know just enough about electronics to be dangerous so any help and advice would be greatly appreciated. I guess I should state that I have checked my antenna cable for continuity and it all checks out and the shielding is completely isolated. Also, my radio is clear of all other noise such as engine, alternator, etc. Thanks for the help. -------- Darin Hawkes Series 7 (Phase 1 - Flight Testing) 914 Turbo Kaysville, Utah Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195379#195379 ________________________________________________________________________________
Subject: RV6-A for sale website
Date: Jul 28, 2008
My RV6-A is now actively being advertised for sale, see : http://www3.telus.net/public/a6a36537/ TT 45 Hr. Aero Sport-Power O-360-A1A 50 Hr. Hartzell C/S prop -50 Hr. Oil filter Aeroelectric connection Z-11 based wiring 1 Slick mag 1 electronic ign. 55 Amp. Nippon Denzo alternator Whelen wingtip strobes Wingtip landing lights with wigwags Automotive geared starter with extra new spare starter Navaid wing leveler (accepts handheld GPS waypoints) Altrack Altitude hold Dynon EFIS D10-A plus internal battery, OAT probe and remote compass module Analog, airspeed, altitude,fuel gauges Sirs compass Rocky mountain Instruments uMonitor & uEncoder also with remote compass module SL-40 com - SL-70 Xponder PM-3000 stereo intercom Electric flaps Elevator and aileron trims on left stick Sliding canopy Professionally upholstered Conforfoam seats Removable control panel with removable instrument section. Custom built aluminium floors. Nose wheel fork mod done. Professionally painted yellow (very nicely visible), add decor (stripes etc.) per taste Many painstaking hours spent on rigging, fit and finish. First annual done July 10 2008. Asking $99000.00 The website is; http://www3.telus.net/public/a6a36537/ If you are interested in further information contact. Jim Jewell in Kelowna B.C. jjewell @ telus.net Ph- (250) 861-8706 Checked by PC Tools AntiVirus (4.0.0.26 - 10.100.007). http://www.pctools.com/free-antivirus/ ________________________________________________________________________________
Subject: Re: Trim noise in Audio speaker
Date: Jul 28, 2008
Paul M. reminds me that the capacitors across the brushes also extend the lifetime of the brushes. If the noise appeared recently, it might be a sign that the motor brushes are worn out. Replacing the motor or brushes should be easier than it is. And determining whether or not this is so should also be easier than it is.... But it isn't. "Inventor: A person who makes an ingenious arrangement of wheels, levers and springs, and believes it civilization." --Ambrose Bierce -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195411#195411 ________________________________________________________________________________
Date: Jul 28, 2008
The below is entirely new to me. Could someone with more experience and knowledge than me (that would be almost anyone, but especially Mr. Nuckolls) comment on it? Regards, Michael Wynn RV 8 FWF San Ramon, CA In a message dated 7/28/2008 7:39:15 A.M. Pacific Daylight Time, emjones(at)charter.net writes: railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines. Problems-- 1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part. 2) Not sealed. Not dust proof, or fuel proof. 3) Low interrupt capacity. 4) High hold current---16 ohm coil. Almost one amp. 5) Low hold force. The specifications call for specific orientation. 2G rating? 6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts. 7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications) See: www.stancor.com There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred. Can you use them? Sure. Should you use them?....not on my bird, Bubela. Better yet, avoid all contactors and use manual switches if you can. "Facts do not cease to exist because they are ignored." ---Aldous Huxley **************Get fantasy football with free live scoring. Sign up for FanHouse Fantasy Football today. (http://www.fanhouse.com/fantasyaffair?ncid=aolspr00050000000020) ________________________________________________________________________________
Subject: Success!
Date: Jul 28, 2008
Congratulations Rick! Sounds like you are at the point of having many exciting firsts! Be safe and enjoy the journey. Jon -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Richard Girard Sent: Sunday, July 27, 2008 7:57 AM To: aeroelectric-list(at)matronics.com Subject: AeroElectric-List: Success! This last week, with trembling hands and fire extinguisher close at hand, I connected the battery to my Kolb Mk III's new electrical system. I used the Z -17 schematic virtually verbatim. I did put in a SPST key switch between the fuse panel and the starter solenoid, but that's about all I deviated from the plan you laid down. To my delight, and relief, all the smoke remained in the wires and everything works. I realize that my system is bare bones simple compared to all of you glass panel folks out there, but this was my first attempt at wiring up an airplane from scratch. Thanks, Bob. Rick Girard Kolb Mk III, returning to the air this week Yippee! ________________________________________________________________________________
Date: Jul 28, 2008
I looked at some of those below and found this in the process: http://www.trombetta.com/cm/pdfs/defender-family.pdf Anybody use one of these? Looks like they can be had for fairly cheap and have some type of TVS (Transient Volt Suppression) built in! Looks like it's a little heavier than some of the more expensive ones, so I guess that's the trade off for cost. Thoughts? Jeff. I have railed against these Type-70 contactors for years. But they are almost obsolete. Most electronics distributors have dropped them from their lines. Problems-- 1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in Death Valley in May and take off in October. Maybe. This is primarily due to the Nylon innards. This is a drop-dead reason to avoid the part. 2) Not sealed. Not dust proof, or fuel proof. 3) Low interrupt capacity. 4) High hold current---16 ohm coil. Almost one amp. 5) Low hold force. The specifications call for specific orientation. 2G rating? 6) Wildly wrong for B&C to use coil suppression diodes on these. This causes short lifetimes on the B&C parts. 7) Not designed to open against voltages above 36 volts. (So forget the B-lead applications) See: www.stancor.com There are better ways to go. Omron's line of automotive contactors (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but preferred. Can you use them? Sure. Should you use them?....not on my bird, Bubela. Better yet, avoid all contactors and use manual switches if you can. ________________________________________________________________________________
Date: Jul 29, 2008
The Trombetta mentioned below looks like a type 70 in an expensive package to me. In a nutshell my thoughts on the type 70 criticism are: some of it is true, most of it is irrelevant. Type 70 contactors are widely available, affordable, and no real risk with aeroelectric architecture except perhaps for a B lead overvoltage interupter with an IR alternator. Sure I might have to replace one of mine in my lifetime. I think I have a spare $14. unit in stock from the local hardware store but I'd also expect to find one at most any airport if needed. However if Eric or anyone wanted to suggest a particular "cheap" or value priced Omron part number or series, I would check it out for cost effectiveness and reasonable availability and interchangeability. Lots of discussion in the archives Michael but I would not hesitate to use the type 70's in a new design for the time being. Better stuff is available at a price but I haven't seen anything that has a cost and availability of interest to me yet. Ken Jeffrey W. Skiba wrote: > > I looked at some of those below and found this in the process: > http://www.trombetta.com/cm/pdfs/defender-family.pdf > > > Anybody use one of these? > Looks like they can be had for fairly cheap and have some type of TVS > (Transient Volt Suppression) built in! > Looks like it's a little heavier than some of the more expensive ones, so I > guess that's the trade off for cost. > > Thoughts? > > Jeff. > > > > I have railed against these Type-70 contactors for years. But they are > almost obsolete. Most electronics distributors have dropped them from their > lines. > > Problems-- > > 1) Low Temperature rating. Only 122F max. You could land at Furnace Creek in > Death Valley in May and take off in October. Maybe. This is primarily due to > the Nylon innards. This is a drop-dead reason to avoid the part. > > 2) Not sealed. Not dust proof, or fuel proof. > > 3) Low interrupt capacity. > > 4) High hold current---16 ohm coil. Almost one amp. > > 5) Low hold force. The specifications call for specific orientation. 2G > rating? > > 6) Wildly wrong for B&C to use coil suppression diodes on these. This causes > short lifetimes on the B&C parts. > > 7) Not designed to open against voltages above 36 volts. (So forget the > B-lead applications) > > See: www.stancor.com > > There are better ways to go. Omron's line of automotive contactors (CHEAP) > and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but > preferred. > > Can you use them? Sure. Should you use them?....not on my bird, Bubela. > > Better yet, avoid all contactors and use manual switches if you can. > > ________________________________________________________________________________
Subject: AT150 Interrogation Light
Date: Jul 29, 2008
I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the belly with a 5.5" ground plate. It seems to be working fine according to ATC. Good data and the mode C is accurate. However, the interrogation light is on steady, rather than blinking as the radar sweeps past it. It used to be just fine, but at some point it began to act differently where it would flicker, especially on the ground. Now, if the engine is off and I activate it, the interrogation light comes on for a few seconds, then turns off. I believe that's how it's supposed to act. However, when flying, it seems to come on steady and stay that way with an occasional flicker during flight. As I said, ATC says it's working fine. Has anyone seen this? Any idea what my problem is? Several times I've removed it, cleaned and lubed the contacts, and replaced it with the same results. Since it's working fine, I'm not to worried about it, but I'd like to get this light working like it's supposed to. Thanks for any help offered. Deke ________________________________________________________________________________
Date: Jul 29, 2008
Subject: Re: AT150 Interrogation Light
Maybe you have something in the airplane generating noise which causes the transponder to reply - even though it wasn't interrogated by an actual radar signal. How's the audio in your comm radio? Any new noise? Off the top of my head, maybe you have a bad spark plug wire, or alternator diode or something like that. Does your engine have dual ignition systems? If yes, does the transponder behave the same way on each of them separately? Can you turn the alternator off and still run the txp from battery (as a test)? I doubt you have a DME in a Kitfox, but they operate in the same band as the transponder so might be a source of interference. As a long shot, possibly your cell phone is setting it off. Did you get a new phone? Does it misbehave with the phone turned off? I can't recall if the AT150 has a remote ident button, but maybe the wire that connects that circuit isn't isolated properly. I think those work by grounding the wire. Vibration might cause that wire to rub against ground. In reality, the pin in the shell connector for that function probably doesn't even have a wire in it, so that's probably not the issue. Maybe the reply discrimination circuit is messed up in your txp. Possibly a radio shop has a loaner unit you could swap into the tray. Or maybe they can test the unit for that functionality. Regards, Matt- > I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the > belly with a 5.5" ground plate. It seems to be working fine according to > ATC. Good data and the mode C is accurate. However, the interrogation > light is on steady, rather than blinking as the radar sweeps past it. It > used to be just fine, but at some point it began to act differently where > it would flicker, especially on the ground. Now, if the engine is off and > I activate it, the interrogation light comes on for a few seconds, then > turns off. I believe that's how it's supposed to act. However, when > flying, it seems to come on steady and stay that way with an occasional > flicker during flight. As I said, ATC says it's working fine. > Has anyone seen this? Any idea what my problem is? Several times I've > removed it, cleaned and lubed the contacts, and replaced it with the same > results. Since it's working fine, I'm not to worried about it, but I'd > like to get this light working like it's supposed to. > Thanks for any help offered. > Deke > ________________________________________________________________________________
Date: Jul 29, 2008
Matt, Deke, I was thinking many of the same things, but given ATC was reporting his unit was 'normal', I discounted them, as I would have thought they would have complained of excessive replies or ident's making a mess of their sereens. IIRC, the 150, unlike the 50, does have a remote ident pin. I'll look in my SM tonight as see if there may be a some failure to the light circuit only, doesn't seem likely, but... If the unit is in an area with many ADSB units and/or heavy radar coverage, it could actually be interrogated at some high rate and the reply light is working normally. One would expect it to be a bit quieter on the ground, out of sight of multiple radar sites but perhaps still seeing ADSB inquires. However, Deke reports a change. Has anything else changed within the AC that may give a clue? I agree, a bench check at a radio shop or exchange unit should be near the top of things to try. Ron Q. At 08:22 7/29/2008, you wrote: > >Maybe you have something in the airplane generating noise which causes the >transponder to reply - even though it wasn't interrogated by an actual >radar signal. How's the audio in your comm radio? Any new noise? Off >the top of my head, maybe you have a bad spark plug wire, or alternator >diode or something like that. Does your engine have dual ignition >systems? If yes, does the transponder behave the same way on each of them >separately? Can you turn the alternator off and still run the txp from >battery (as a test)? I doubt you have a DME in a Kitfox, but they operate >in the same band as the transponder so might be a source of interference. > >As a long shot, possibly your cell phone is setting it off. Did you get a >new phone? Does it misbehave with the phone turned off? > >I can't recall if the AT150 has a remote ident button, but maybe the wire >that connects that circuit isn't isolated properly. I think those work by >grounding the wire. Vibration might cause that wire to rub against >ground. In reality, the pin in the shell connector for that function >probably doesn't even have a wire in it, so that's probably not the issue. > >Maybe the reply discrimination circuit is messed up in your txp. Possibly >a radio shop has a loaner unit you could swap into the tray. Or maybe >they can test the unit for that functionality. > > >Regards, > >Matt- > > > > I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the > > belly with a 5.5" ground plate. It seems to be working fine according to > > ATC. Good data and the mode C is accurate. However, the interrogation > > light is on steady, rather than blinking as the radar sweeps past it. It > > used to be just fine, but at some point it began to act differently where > > it would flicker, especially on the ground. Now, if the engine is off and > > I activate it, the interrogation light comes on for a few seconds, then > > turns off. I believe that's how it's supposed to act. However, when > > flying, it seems to come on steady and stay that way with an occasional > > flicker during flight. As I said, ATC says it's working fine. > > Has anyone seen this? Any idea what my problem is? Several times I've > > removed it, cleaned and lubed the contacts, and replaced it with the same > > results. Since it's working fine, I'm not to worried about it, but I'd > > like to get this light working like it's supposed to. > > Thanks for any help offered. > > Deke > > > > ________________________________________________________________________________
Date: Jul 29, 2008
My Garmin xponder does that whenever both Pmags are powered up. If I kill one side, it behaves normally again. If I kill the other side, the problem remains. ATC seems to see me okay most of the time while this is going on. Strange, indeed. Makes it hard to see true interrogation hits. -Bill B On Tue, Jul 29, 2008 at 12:13 PM, Ron Quillin wrote: > > Matt, Deke, > > I was thinking many of the same things, but given ATC was reporting his > unit was 'normal', I discounted them, as I would have thought they would > have complained of excessive replies or ident's making a mess of their > sereens. IIRC, the 150, unlike the 50, does have a remote ident pin. I'll > look in my SM tonight as see if there may be a some failure to the light > circuit only, doesn't seem likely, but... > > If the unit is in an area with many ADSB units and/or heavy radar coverage, > it could actually be interrogated at some high rate and the reply light is > working normally. One would expect it to be a bit quieter on the ground, > out of sight of multiple radar sites but perhaps still seeing ADSB inquires. > However, Deke reports a change. Has anything else changed within the AC > that may give a clue? > > I agree, a bench check at a radio shop or exchange unit should be near the > top of things to try. > > Ron Q. > > At 08:22 7/29/2008, you wrote: > >> mprather(at)spro.net> >> >> Maybe you have something in the airplane generating noise which causes the >> transponder to reply - even though it wasn't interrogated by an actual >> radar signal. How's the audio in your comm radio? Any new noise? Off >> the top of my head, maybe you have a bad spark plug wire, or alternator >> diode or something like that. Does your engine have dual ignition >> systems? If yes, does the transponder behave the same way on each of them >> separately? Can you turn the alternator off and still run the txp from >> battery (as a test)? I doubt you have a DME in a Kitfox, but they operate >> in the same band as the transponder so might be a source of interference. >> >> As a long shot, possibly your cell phone is setting it off. Did you get a >> new phone? Does it misbehave with the phone turned off? >> >> I can't recall if the AT150 has a remote ident button, but maybe the wire >> that connects that circuit isn't isolated properly. I think those work by >> grounding the wire. Vibration might cause that wire to rub against >> ground. In reality, the pin in the shell connector for that function >> probably doesn't even have a wire in it, so that's probably not the issue. >> >> Maybe the reply discrimination circuit is messed up in your txp. Possibly >> a radio shop has a loaner unit you could swap into the tray. Or maybe >> they can test the unit for that functionality. >> >> >> Regards, >> >> Matt- >> >> >> >> > I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the >> > belly with a 5.5" ground plate. It seems to be working fine according >> to >> > ATC. Good data and the mode C is accurate. However, the interrogation >> > light is on steady, rather than blinking as the radar sweeps past it. >> It >> > used to be just fine, but at some point it began to act differently >> where >> > it would flicker, especially on the ground. Now, if the engine is off >> and >> > I activate it, the interrogation light comes on for a few seconds, then >> > turns off. I believe that's how it's supposed to act. However, when >> > flying, it seems to come on steady and stay that way with an occasional >> > flicker during flight. As I said, ATC says it's working fine. >> > Has anyone seen this? Any idea what my problem is? Several times I've >> > removed it, cleaned and lubed the contacts, and replaced it with the >> same >> > results. Since it's working fine, I'm not to worried about it, but I'd >> > like to get this light working like it's supposed to. >> > Thanks for any help offered. >> > Deke >> > >> >> >> >> > > ________________________________________________________________________________
Subject: Capacitors for trim servos?
Date: Jul 29, 2008
Hey...not trying to start an argument but as an electronic nobody, these two advices about caps seem to recommend very different cap sizes (uF). How to resolve? Ralph Finch -----Original Message----- From: Robert L. Nuckolls, III Sent: Monday, July 14, 2008 8:00 AM Subject: Re: AeroElectric-List: Trim noise in Audio speaker Try the .22 uF capacitor first 272-1070. Try the pair of 272-1436 if the first doesn't work. These need to be tied into the harness as close as practical . . . 2-3 inches outside actuator housing. -----Original Message----- From: Eric M. Jones Sent: Monday, July 28, 2008 6:43 AM Subject: AeroElectric-List: Re: Connectors for trim servos? 2) Noise suppressor capacitors are easy to add. One .01 uF ceramic across the motor brushes and one 0.1 uF ceramic from each brush to ground (which you might want to add) is a standard approach. Keep the leads critically short. ________________________________________________________________________________
Subject: Re: Capacitors for trim servos?
Date: Jul 29, 2008
In motors of this size, 0.1uF ceramic caps will do. If caps get below 0.005uF they may not be so effective, above 0.2 they are getting physically big. But the critical thing is to keep the leads short, and use ceramic caps for their stability, lifetime and voltage withstand. Often schematics differ since they indicate how the prototype was built. In wideband noise filtering (as opposed to ripple filtering or timing applications) more is usually better. Sometimes the exact values are critical, sometimes not so much. In this case, not so much. Just use 0.1 uFs 50V ceramic disk caps. Even Radio Shack has them..... -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195654#195654 ________________________________________________________________________________
Date: Jul 29, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> >I am using it as a battery contactor but with a Very High out alternator, >200amps ..... So I am thinking I need to find a bigger contactor ? or my >other thought - guess was maybe to run TWO Stancor 70-902 contactors in >parallel ? with the extra wires also... but concern here is that something I >haven't thought of will smoke something if both are not closed ? No paralleling . . . it's not practical. Yes . . . you need a contactor rated for the task. In the el-cheeso line of contactors, the Stancore 586-902 is rated for this service and should be a good value. See: http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_586-Series.pdf You can get these for about $50 from Allied Electronics at: http://tinyurl.com/5bxtnm If you're interested in "stepping up", these are equally suited to the task: Cutler-Hammer 6041H105 http://aeroelectric.com/Mfgr_Data/Contactors/Eaton_CH/6041SeriesPowerRelays.pdf or Tyco Killvac EV200 http://aeroelectric.com/Mfgr_Data/Contactors/Tyco_Kilovac/ev200.pdf Be advised that some builder's have reported noise from the "power saver" feature on the EV-200 that required filtering. Easy to do should it become necessary. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 29, 2008
> >I have railed against these Type-70 contactors for years. But they are >almost obsolete. Most electronics distributors have dropped them from >their lines. > >Problems-- > >1) Low Temperature rating. Only 122F max. You could land at Furnace Creek >in Death Valley in May and take off in October. Maybe. This is primarily >due to the Nylon innards. This is a drop-dead reason to avoid the part. > >2) Not sealed. Not dust proof, or fuel proof. Neither are most of the switches, contactors, even alternators that have been used with great success for decades. >3) Low interrupt capacity. But they're never asked to interrupt anything but normal pre-parking currents in aircraft . . . maybe 10A? For a time, the TC aircraft industry attempted to use the intermittent duty versions of these contactors for starter control service and found them unsatisfactory. However, they have proven a good value (I didn't say lasts forever) in light aircraft battery contactor service. In other words, the 8x more expensive 6041H series mil spec contactors did not last even 4x as long. Given the exceedingly light duty cycles expected from these devices the way we use them (in failure tolerant systems) they are of good value. >4) High hold current---16 ohm coil. Almost one amp. Which is not an issue as long as the alternator is running . . . you have power to burn. When the alternator is not running, this device is turned off for endurance mode operations. >5) Low hold force. The specifications call for specific orientation. > 2G rating? I've tested these at over 12g. Where do you find any recommendations with respect to g-loading. I can tell you that the vertical orientation is to reduce potential for moisture ingress due to coindensation and/or splash . . . as you've noted, they are not sealed. As a battery contactor, they are closed in all phases of flight and exceedingly difficult to force open with g-loads. >6) Wildly wrong for B&C to use coil suppression diodes on these. This >causes short lifetimes on the B&C parts. I've also demonstrated that this is not true. >7) Not designed to open against voltages above 36 volts. (So forget the >B-lead applications) True . . . and not recommended to routinely SWITCH such loads but will be just fine as suggested on the third page of: http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf where we will routinely switch the alternator ON and OFF at will without exceeding the contactors rated operating conditions. >See: www.stancor.com > >There are better ways to go. Omron's line of automotive contactors (CHEAP) >and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. Expensive but >preferred. Preference is another matter entirely . . . and when it comes to preferences, I'll concede to anyone's desires. I've even cited alternatives that include the Kilovac EV200. But let us not resort to generating climates of fear on the part of the neophyte airplane builders. The track record on this part for return on investment has been exemplary. >Can you use them? Sure. Should you use them?....not on my bird, Bubela. By all means sir . . . >Better yet, avoid all contactors and use manual switches if you can. This IS a stretch Eric. It's true that contactors are the most highly stressed devices on an airplane after generators and followed by alternators. It's also true that they are a significant maintenance item on EVERY airplane from the C-150 through the Hawkers. But so are tires, batteries, generators, etc. The artfully crafted system tolerates these service life limitations without placing the aircraft or occupants at risk. Can we really recommend that anyone resort to manually operated high current switches (bring high current conductors within reach of pilot) just to avoid a service-life issue on a 100-our a year airplane? >"Facts do not cease to exist because they are ignored." > ---Aldous Huxley Absolutely! Please separate deeply held beliefs from demonstrable fact. I have outlined the facts . . . which of these do you find to be in error? Bob . . . ________________________________________________________________________________
Date: Jul 29, 2008
> >Bob, > >Understood, that EBus switch is ALTERNATE path to powering the EBus. And >as you said, turn it on, check ATIS are all good preflight procedures to >test this path. > >I just wanted to confirm that once you are started and the alternator is >running smoothly, it would do no harm to leave the EBus switch turned on >(closed) during normal operations. No harm at all. This part of the design philosophy. No mis-ositioning of switches places any part of the system at-risk for failure. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 29, 2008
> >I looked at some of those below and found this in the process: >http://www.trombetta.com/cm/pdfs/defender-family.pdf > > >Anybody use one of these? >Looks like they can be had for fairly cheap and have some type of TVS >(Transient Volt Suppression) built in! >Looks like it's a little heavier than some of the more expensive ones, so I >guess that's the trade off for cost. These should be entirely suitable for use as battery contactors in the OBAM aircraft. Bob . . . ________________________________________________________________________________
Date: Jul 29, 2008
> >Hey...not trying to start an argument but as an electronic nobody, these two >advices about caps seem to recommend very different cap sizes (uF). How to >resolve? > >Ralph Finch We have a first-hand report that the pair of 272-1436 capacitors back to back "did the job". Would something else work as well? Probably. My selection of "try it" parts was based on availability of parts for a quick look-see. Given that the motor is at the end of long, small gage wires, inrush at the switches due to "too large" capacity is mitigated. But if you'd like to conduct a science experiment an test other sizes, we'd be interested in the results. This is always a bit of a crap-shoot. Noise issues are a unsatisfactory combination of noise intensity, attenuation in the conduction pathway, and noise susceptibility. When working qualification issues in the lab, we have benefit of calibrated equipment with which we can put numbers on all three variables. Once the combination finds it's way to your airplane, the most you can tell us is that the noise exists and you find it unacceptable. The first thing to try is reduce the signal at the source. The next thing to try is increase attenuation in the coupling mode. The last thing you can do is reduce the susceptibility in the victim. For the moment, our brute-force experiment to reduce it to acceptable levels at the source were successful. Is it the optimum solution? Got a few $thousand$ to spend, we can take it to the lab and find out. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 29, 2008
Subject: Re: Grounding of com antenna on Tube and Fabric airframe
> >I have a Kitfox 7 that I just had inspected (I have 1 hour on it so far) >and am having issues with my transmission and reception quality and >effectiveness. Here is a brief description of my problem: > >When at the airport (taxing, and in the pattern) my radio seems to work >fine with the exception of an intermittent static blip every two seconds >or so. As I get farther out, the intermittent blip becomes more >pronounced to the point that my transmission and reception is horrible >(transmission is worse than reception though by a long shot). Basically, >my communications become unintelligible around 4-5 miles out. I >originally didn't have a ground plane other than the mounting plate for >the antenna (which the manual says is fine) so I added one on the advice >of a couple people and the problem has not changed a bit. > >Here is a question: Does the antenna itself have to be electrically >bonded to the airframe? I think the answer is yes and according to the >maker of my antenna, mine is through the mounting hardware. However, the >builder's manual says to remove any fabric and grind down the powder >coating under the antenna to get a good bond. Would this be my >problem? Would the issues I have described be symptomatic of a poorly >grounded antenna? I know just enough about electronics to be dangerous so >any help and advice would be greatly appreciated. > >I guess I should state that I have checked my antenna cable for continuity >and it all checks out and the shielding is completely isolated. Also, my >radio is clear of all other noise such as engine, alternator, etc. The first thing to do is get an antenna analyzer of some type hooked to your feedline at the transceiver end and see what it says. This is not an absolute test of performance but it IS an absolute test of non-performance. High SWR says something is seriously wrong without telling you exactly what it is. Another experiment you can try is substitute a test antenna. Get some brass shim stock from machine shop or sheet from Hobby Lobby/local hardware store. Thinner the better. Wrap a piece around the strut of your airplane 1/2 way out to the wing attach. Secure with rubber banding or wraps of plastic tape around the brass . . . don't get the tape goo on your paint. Take a piece of coax (RG58 will do) and remove outer jacket and shield to expose 20" of inner insulation and conductor. This is the "antenna". Do this . . . http://aeroelectric.com/articles/shldwire/shldwire.html Cut shield pigtail to about 1/2" and tack solder to brass. Tape coax down strut and bring into cabin at trailing edge of door or through window. Install coax connector and attach to transceiver. I've built dozens of these antennas to make temporary installation on ferry aircraft and they've performed well without having to drill holes and/or make more complex installations on the a/c. If THIS antenna works "better", then you'll need to investigate the mounted antenna more closely. If not, then the problem is in the radio. That "every two seconds" thing is a bit buggy . . . antennas don't tell time worth a hoot but electronics is much better at it. Bob . . . ________________________________________________________________________________
Date: Jul 29, 2008
Subject: Re: PMag Preflight Check
Darwin, Mike Ice from Alaska here. Just getting ready to test fly the 9. I have a p and an e mag. Do you have any further recommendations for testing/checking these models before flight, i.e., run up. Mike ----- Original Message ----- From: Darwin N. Barrie To: aeroelectric-list(at)matronics.com Sent: Monday, August 20, 2007 4:12 PM Subject: Re: AeroElectric-List: PMag Preflight Check I have two pmags, total time now 265 hours. This includes one replacement and both sent in for updates during the annual. After each reinstall I check to insure the mags were working at my idle setting. Both were. I didn't take the time to adjust the idle abnormally low to find the cut off of each Pmag. (I did the first time) As long as they work at my idle setting I was happy. I have my panel set up so everything to start works from Left to Right and reverse for shut down. My process is as follows, Pmag switched breakers, ON, Master On, full rich yada yada yada. On run up, RPM 1700, key switch on both. Check left, back to Both, Check Right, back to Both. Done deal. If there is a problem you'll know there. Why do anything different? During the one failure I had in flight (an internal magnet failure of my left Pmag) I switched to the Right mag and proceeded on safely. If you have a sudden rise in temps, rough running, loss of power, switch mags to isolate and find out if it is a mag issue. I firmly believe people are getting them in the set up mode and messing up the timing. Set them up and leave them alone!!! Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Subject: PMag Preflight Check
Date: Jul 29, 2008
Mike, Rob from the Chapter here. Good luck on the test flights, keep us posted. RS Rob Stapleton, Photojournalist Anchorage, Alaska 907-230-9425 KL2AN Skype:rob.stapleton.jr IM Windows Live Messenger: foto(at)alaska.net -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Michael T. Ice Sent: Tuesday, July 29, 2008 8:21 PM Subject: Re: AeroElectric-List: PMag Preflight Check Darwin, Mike Ice from Alaska here. Just getting ready to test fly the 9. I have a p and an e mag. Do you have any further recommendations for testing/checking these models before flight, i.e., run up. Mike ----- Original Message ----- From: Darwin N. Barrie <mailto:ktlkrn(at)cox.net> Sent: Monday, August 20, 2007 4:12 PM Subject: Re: AeroElectric-List: PMag Preflight Check I have two pmags, total time now 265 hours. This includes one replacement and both sent in for updates during the annual. After each reinstall I check to insure the mags were working at my idle setting. Both were. I didn't take the time to adjust the idle abnormally low to find the cut off of each Pmag. (I did the first time) As long as they work at my idle setting I was happy. I have my panel set up so everything to start works from Left to Right and reverse for shut down. My process is as follows, Pmag switched breakers, ON, Master On, full rich yada yada yada. On run up, RPM 1700, key switch on both. Check left, back to Both, Check Right, back to Both. Done deal. If there is a problem you'll know there. Why do anything different? During the one failure I had in flight (an internal magnet failure of my left Pmag) I switched to the Right mag and proceeded on safely. If you have a sudden rise in temps, rough running, loss of power, switch mags to isolate and find out if it is a mag issue. I firmly believe people are getting them in the set up mode and messing up the timing. Set them up and leave them alone!!! Darwin N. Barrie Chandler AZ ________________________________________________________________________________
Date: Jul 30, 2008
Bob, I would use a Type 70 for a puddle jumper of no particular consequence. I agree that they have been used for decades. They are not competitive anymore. I aim for designs where "carrying a spare" is not a requirement for a part, where "better" can be had for not much money. "Better" in my world is defined as "greater capability, wider specs, longer life, higher reliability...etc." Maybe even "similar specs, lighter weight...." Not all builders care about this. >Problems-- >1) Low Temperature rating. Only 122F max. You could land at Furnace >Creek in Death Valley in May and take off in October. Maybe. This is >primarily due to the Nylon innards. This is a drop-dead reason to avoid >the part. >2) Not sealed. Not dust proof, or fuel proof. > Neither are most of the switches, contactors, even > alternators that have been used with great success > for decades. Bob, that's partially true, but Kilovacs and Gigavacs can shut off your battery whilst saturated in fuel. They can also shut off a runaway alternator. They will last forever. They cost more. They have lower hold currents. They use bidirectional Zeners for coil suppression. Nice, huh? >3) Low interrupt capacity. > But they're never asked to interrupt anything but normal > pre-parking currents in aircraft . . . maybe 10A? For a > time, the TC aircraft industry attempted to use the > intermittent duty versions of these contactors for starter > control service and found them unsatisfactory. You are referring to a specific application. I referring to general applications. > However, they have proven a good value (I didn't say lasts > forever) in light aircraft battery contactor service. > In other words, the 8x more expensive 6041H series mil > spec contactors did not last even 4x as long. Given the > exceedingly light duty cycles expected from these devices > the way we use them (in failure tolerant systems) they > are of good value. I don't disagree. They are a good value. But Omron contactors (50A) http://tiny.cc/sXDp3 are a 3X better value and are tiny in comparison. The Type 70 is long in the tooth. As you recall this latest brushfire was sparked by troublemaker Jeff Skiba poking around to get information on higher current performance. He started this.... >4) High hold current---16 ohm coil. Almost one amp. > Which is not an issue as long as the alternator > is running . . . you have power to burn. When the > alternator is not running, this device is turned > off for endurance mode operations. An ampere here, and ampere there...pretty soon you have real power waste. Our philosophies differ. I remember in 1960 when you could buy surplus aircraft and they'd come with full fuel tanks. Not anymore. >5) Low hold force. The specifications call for specific orientation. >2G rating? > I've tested these at over 12g. Where do you find any recommendations with respect to g-loading. I can tell you that the vertical orientation is to reduce potential for moisture ingress due to condensation and/or splash . . . as you've noted, they are not sealed. As a battery contactor, they are closed in all phases of flight and exceedingly difficult to > force open with g-loads. You could be right on this. Type 70 specs are impossible to get on this, (and believe me I've tried). I interpret the orientation spec to be a g-load concern. But Kilovac and Gigavac and others always spec g-load. Usually 10g's. >6) Wildly wrong for B&C to use coil suppression diodes on these. This >causes short lifetimes on the B&C parts. > I've also demonstrated that this is not true. As I said Bob, you are wonderfully on-the-mark about thousands of things, and only wildly wrong about only a few. One Hundred Dollars U.S. to your favorite charity and a jar of jalapenos to you if an agreed upon third party will test the type-70 contactor using 1N5401 Diodes vs. 18V SnapJacks for coil suppression in an agreed upon test. My winning requires you to never again espouse this bonehead notion. >7) Not designed to open against voltages above 36 volts. (So forget the >B-lead applications) > > True . . . and not recommended to routinely SWITCH such > loads but will be just fine as suggested on the third page > of: > > http://aeroelectric.com/articles/Adapting_IR_Alternators_to_Aircraft.pdf > > where we will routinely switch the alternator ON and OFF at will > without exceeding the contactors rated operating conditions. >There are better ways to go. Omron's line of automotive contactors > (CHEAP) and Kilovac's EV200 series, Blue Sea 9012, Gigavac's GX-11. >Expensive but preferred. > Preference is another matter entirely . . . and when > it comes to preferences, I'll concede to anyone's desires. > I've even cited alternatives that include the Kilovac > EV200. But let us not resort to generating climates of fear > on the part of the neophyte airplane builders. The track > record on this part for return on investment has been exemplary. >Better yet, avoid all contactors and use manual switches if you can. > This IS a stretch Eric. It's true that contactors are the > most highly stressed devices on an airplane after generators > and followed by alternators. It's also true that they are > a significant maintenance item on EVERY airplane from the > C-150 through the Hawkers. But so are tires, batteries, > generators, etc. The artfully crafted system tolerates > these service life limitations without placing the aircraft > or occupants at risk. Can we really recommend that anyone > resort to manually operated high current switches (bring > high current conductors within reach of pilot) just to avoid > a service-life issue on a 100-our a year airplane? Bob, Stretching is a good, but not necessary thing. I recommend to my builder-friends using a Flaming River racecar battery switch to satisfy the FAA for the one-hand battery disconnect. That's what's going into my Glastar. No contactor needed. Most other contactors can go bye-bye too. "Everything you've learned in school as 'obvious' becomes less and less obvious as you begin to study the universe. For example, there are no solids in the universe. There's not even a suggestion of a solid. There are no absolute continuums. There are no surfaces. There are no straight lines." -R. Buckminster Fuller -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195736#195736 ________________________________________________________________________________
Subject: FYI: Powergate
Date: Jul 30, 2008
See: http://www.perfectswitch.com/downloads/relaybrochure.pdf This guy sells big SSRs. I'd like to see a schematic. But it might be worth looking into. My concern is that he might have miscalculated the dissipation, but I can't tell from the information. Anybody want to investigate and report back? -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195744#195744 ________________________________________________________________________________
Date: Jul 30, 2008
> >Bob, > >I would use a Type 70 for a puddle jumper of no particular consequence. I >agree that they have been used for decades. They are not competitive >anymore. I aim for designs where "carrying a spare" is not a requirement >for a part, where "better" can be had for not much money. "Better" in my >world is defined as "greater capability, wider specs, longer life, higher >reliability...etc." Maybe even "similar specs, lighter weight...." Not all >builders care about this. Don't now how to quantify "competitive". Hundreds of thousands of airplanes have flown with this contactor and I doubt that few if any owners felt compelled to "carry a spare". Yes, I CAN select from a variety of products with "better" specs . . . but in the final analysis, how does this affect John Q Pilot's utility realized from his airplane? I'm aware of NO contactors suited for battery service that are smaller, noise free, and deliver better life for the dollars spent. You've stirred a lot of un-quantified superlatives into this stew. > > Neither are most of the switches, contactors, even > > alternators that have been used with great success > > for decades. > > >Bob, that's partially true, but Kilovacs and Gigavacs can shut off your >battery whilst saturated in fuel. They can also shut off a runaway >alternator. They will last forever. They cost more. They have lower hold >currents. They use bidirectional Zeners for coil suppression. Nice, huh? Sure . . . but how many battery contactors have ever been asked to open the battery while fuel-soaked? The hold current electronics duty cycle switches the coil circuit and proved to be a noise issue in at least one instance. I was hoping to get one into the lab to look at DO-160 conducted and see how much filter was needed to quiet the puppy down. If I were searching for stretched convictions, I might offer that the electronics in the EV200 were vulnerable to lightning strike. > >3) Low interrupt capacity. > > > > But they're never asked to interrupt anything but normal > > pre-parking currents in aircraft . . . maybe 10A? For a > > time, the TC aircraft industry attempted to use the > > intermittent duty versions of these contactors for starter > > control service and found them unsatisfactory. > > >You are referring to a specific application. I referring to general >applications. The man was asking about a battery contactor. I was addressing that question. I added a note that the manner in which a b-lead contactor would be used in a proposed alternator controller, the type 70 would be suited for that task too. The ONLY places where the venerable type 70 has been recommended for consideration in a Z-figure are situations where it is not required to SWITCH a heavy load, only CARRY them. Starter contactors are another application that demands special consideration. > > However, they have proven a good value (I didn't say lasts > > forever) in light aircraft battery contactor service. > > In other words, the 8x more expensive 6041H series mil > > spec contactors did not last even 4x as long. Given the > > exceedingly light duty cycles expected from these devices > > the way we use them (in failure tolerant systems) they > > are of good value. > > >I don't disagree. They are a good value. But Omron contactors (50A) >http://tiny.cc/sXDp3 are a 3X better value and are tiny in comparison. The >Type 70 is long in the tooth. As you recall this latest brushfire was >sparked by troublemaker Jeff Skiba poking around to get information on >higher current performance. He started this.... That's not a contactor but a fat relay. It IS rated for switching the same loads as a type 70 Stancor but would certainly not be suited for battery contactor service where starter currents are also impressed on the contacts. > >4) High hold current---16 ohm coil. Almost one amp. > > > > Which is not an issue as long as the alternator > > is running . . . you have power to burn. When the > > alternator is not running, this device is turned > > off for endurance mode operations. > > >An ampere here, and ampere there...pretty soon you have real power waste. >Our philosophies differ. I remember in 1960 when you could buy surplus >aircraft and they'd come with full fuel tanks. Not anymore. Philosophies differ? I'm not real sure what philosophy you're embracing. I think I've been quite clear as to my own. > >5) Low hold force. The specifications call for specific orientation. > >2G rating? > > > I've tested these at over 12g. Where do you find any recommendations > with respect to g-loading. I can tell you that the vertical orientation > is to reduce potential for moisture ingress due to condensation and/or > splash . . . as you've noted, they are not sealed. As a battery > contactor, they are closed in all phases of flight and exceedingly difficult to > > force open with g-loads. > >You could be right on this. Type 70 specs are impossible to get on this, >(and believe me I've tried). I interpret the orientation spec to be a >g-load concern. Can't imagine how you get this. Mounting top down adds gravity to the spring tension and probably increases spreading velocity by some factor. It also reduces a pooling opportunity for ingested moisture. But to infer that this orientation has something to do with consideration of g-loading in aircraft is a real stretch. 99.9% of all such contactors manufactured did not go into airplanes. It's a reasonable extrapolation that their recommendations grew out of consideration for the mass market applications as opposed to aircraft. > But Kilovac and Gigavac and others always spec g-load. Usually 10g's. Those are not g-loading specs but shock and vibration qualifications. They do not address resistance to contact motion while energized/de-energized under linear acceleration. Folks have often latched onto those g-numbers and translated them into potential for malfunction during aerobatic maneuvers. They are unrelated. If you're going to use spec sheets as a hammer, you need to interpret them correctly lest the nail you hit is the one on your thumb. > >6) Wildly wrong for B&C to use coil suppression diodes on these. This > >causes short lifetimes on the B&C parts. > > > I've also demonstrated that this is not true. > > >As I said Bob, you are wonderfully on-the-mark about thousands of things, >and only wildly wrong about only a few. Make my day . . . show me where I went wrong. >One Hundred Dollars U.S. to your favorite charity and a jar of jalapenos >to you if an agreed upon third party will test the type-70 contactor using >1N5401 Diodes vs. 18V SnapJacks for coil suppression in an agreed upon >test. My winning requires you to never again espouse this bonehead notion. Do your own tests. I've outlined exactly what I did, how I made and interpreted the measurements. Where do you find fault with the experiment? I explained in detail how the authors of the oft quoted article correctly observed an increase in drop-out delay cased by plain vanilla diodes and then erroneously extrapolated this fact into a commensurate reduction in contact spreading velocity (i.e. extended arcing equals more wear). It's a simple bench setup . . . > >Better yet, avoid all contactors and use manual switches if you can. > > > This IS a stretch Eric. It's true that contactors are the > > most highly stressed devices on an airplane after generators > > and followed by alternators. It's also true that they are > > a significant maintenance item on EVERY airplane from the > > C-150 through the Hawkers. But so are tires, batteries, > > generators, etc. The artfully crafted system tolerates > > these service life limitations without placing the aircraft > > or occupants at risk. Can we really recommend that anyone > > resort to manually operated high current switches (bring > > high current conductors within reach of pilot) just to avoid > > a service-life issue on a 100-our a year airplane? > > >Bob, Stretching is a good, but not necessary thing. I recommend to my >builder-friends using a Flaming River racecar battery switch to satisfy >the FAA for the one-hand battery disconnect. That's what's going into my >Glastar. No contactor needed. Most other contactors can go bye-bye too. Good for you! And yes, the type 70 is a legacy product but so are all the hammers and screwdrivers in my toolboxes. There are a host devices that will function as battery contactors. The Omron relay you cited is not one of them. If we're going to give advice I'll suggest that it is specific to the question and includes a suite of choices . . . and refrain from unsubstantiated fear mongering especially in light of repeatable experiments that demonstrate otherwise. Show me where the interpretation of data in the diode vs. spreading velocity experiment was wrong. Keep in mind too that contact wear in switches and contactors is more tightly linked to behaviors in CLOSING the contacts. Here the contacts bounce . . . close, open and re-close up to a dozen times in an ever decreasing gap where ARCING happens with each opening. The coil suppression technology has nothing to do with contact closing behaviors. The GX11 Gigavac is an interesting product. I've seen their RF vacuum relays for years but this was the first time I was aware of a high current contactor. They don't sell through distribution but I find that an old friend to mine is their local rep. I left a voice mail message for him asking about getting my hands on a GX11BAA. See: http://aeroelectric.com/Mfgr_Data/Contactors/Gigavac/gx11.pdf Note that this data sheet speaks to vibration and shock ratings . . . NOT linear acceleration. Note further that they do not offer a duty-cycle switched, low holding current feature. I'll get one on order and look it over. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2008
Subject: Acceleration ratings for contactors
Just noticed that the spec sheet for the venerable 6041 series contactors at: http://aeroelectric.com/Mfgr_Data/Contactors/Eaton_CH/6041SeriesPowerRelays.pdf speaks to shock, vibration and ACCELERATION. The acceleration number is relevant to applications in aircraft and other vehicles where transient acceleration loads might be impressed on the device. This value would include the de-energized condition where 10G would not cause the contacts to close. However, while closed as a battery or generator bus contactor, resistance to effects of g-loading would be at least 2 times this value. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Jul 30, 2008
Subject: Headset components
I need to put a headset in my Shoei helmet that I use on my trike. I'm reluctant to take apart a $100 headset to get the mic and speakers if it's possible to do this with Rat Shack parts (or Digikey, Mouser, or.....). Anyone out there have any recommendations, part numbers or required specs? Thanks, Rick ________________________________________________________________________________
Date: Jul 30, 2008
Subject: Re: Headset components
Possibly the headset from a motorcycle intercom will work. The are already set up to fit in a motorcycle helmet. They are available from about $20 on the bottom end to more that an aviation headset on the upper end. For what it's worth, Steve > I need to put a headset in my Shoei helmet that I use on my trike. I'm > reluctant to take apart a $100 headset to get the mic and speakers if it's > possible to do this with Rat Shack parts (or Digikey, Mouser, or.....). > Anyone out there have any recommendations, part numbers or required specs? > > Thanks, > Rick > ________________________________________________________________________________
Date: Jul 30, 2008
Steve, A Nady intercom was the first thing I tried on the trike. The headset fit right in the helmet but the unit allowed so much electrical noise in that it was unusable. When one of the cords was accidentally cut I think I discovered why. The cables are not shielded and used varnished wires on top of that. By very careful use of the soldering iron I was finally able to reconnect the wires, but I wasn't able to get the noise out. Trying to interface it with my Icom A22 handheld was also a pain. I've got a Pilot Avionics Pa 200 IK intercom now that plugs directly into the A22, seems electrically isolated from the noise from the engine (HKS 700E four stroke), and allows me to use any aircraft headset. Now I want the safety of my Shoei full face helmet back and I'll be happy. Thanks fo rhte suggeston though. Rick On Wed, Jul 30, 2008 at 5:23 PM, wrote: > > Possibly the headset from a motorcycle intercom will work. The are > already set up to fit in a motorcycle helmet. They are available from > about $20 on the bottom end to more that an aviation headset on the upper > end. > > For what it's worth, > > Steve > > > I need to put a headset in my Shoei helmet that I use on my trike. I'm > > reluctant to take apart a $100 headset to get the mic and speakers if > it's > > possible to do this with Rat Shack parts (or Digikey, Mouser, or.....). > > Anyone out there have any recommendations, part numbers or required > specs? > > > > Thanks, > > Rick > > > > ________________________________________________________________________________
Date: Jul 30, 2008
Thanks, Matt. You've given me several things to try. Yes, I do have a new cell phone and the first thing I'll try is to turn it off and see what happens. I also have dual electronic ignition and I'll do some experimenting there too. One thing I've noticed is that one of the ignitions has begun to make a noise in my headset. Basically I can hear the trigger wheel going past the crank sensors, so I may have some wiring that is leaking through to the headset wiring and possibly to the transponder too. Something to look at. Other than that the ignitions seem to be operating fine, as is the alternator, however I have no way of turning it off. The transponder acts normally when the engine isn't running. I my area its very rural with no interrogation pulses until I get at least 2000agl, and even those are a long way off, so I'm not getting bombarded with pulses. However, I do have some things to try. Thanks. Also, thanks to the others who offered help. Deke mprather(at)spro.net wrote: > Maybe you have something in the airplane generating noise which causes the > transponder to reply - even though it wasn't interrogated by an actual > radar signal. How's the audio in your comm radio? Any new noise? Off > the top of my head, maybe you have a bad spark plug wire, or alternator > diode or something like that. Does your engine have dual ignition > systems? If yes, does the transponder behave the same way on each of them > separately? Can you turn the alternator off and still run the txp from > battery (as a test)? I doubt you have a DME in a Kitfox, but they operate > in the same band as the transponder so might be a source of interference. > > As a long shot, possibly your cell phone is setting it off. Did you get a > new phone? Does it misbehave with the phone turned off? > > I can't recall if the AT150 has a remote ident button, but maybe the wire > that connects that circuit isn't isolated properly. I think those work by > grounding the wire. Vibration might cause that wire to rub against > ground. In reality, the pin in the shell connector for that function > probably doesn't even have a wire in it, so that's probably not the issue. > > Maybe the reply discrimination circuit is messed up in your txp. Possibly > a radio shop has a loaner unit you could s > > > wap into the tray. Or maybe > they can test the unit for that functionality. > > > Regards, > > Matt- > > > > > > I have a Narco AT150 transponder in a Kitfox 5 with the antenna on the > > belly with a 5.5" ground plate. It seems to be working fine according to > > ATC. Good data and the mode C is accurate. However, the interrogation > > light is on steady, rather than blinking as the radar sweeps past it. It > > used to be just fine, but at some point it began to act differently where > > it would flicker, especially on the ground. Now, if the engine is off and > > I activate it, the interrogation light comes on for a few seconds, then > > turns off. I believe that's how it's supposed to act. However, when > > flying, it seems to come on steady and stay that way with an occasional > > flicker during flight. As I said, ATC says it's working fine. > > Has anyone seen this? Any idea what my problem is? Several times I've > > removed it, cleaned and lubed the contacts, and replaced it with the same > > results. Since it's working fine, I'm not to worried about it, but I'd > > like to get this light working like it's supposed to. > > Thanks for any help offered. > > Deke > > > > > > > -------- Deke Morisse Kitfox S5 TD NSI/CAP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195814#195814 ________________________________________________________________________________
Date: Jul 30, 2008
> >Thanks, Matt. You've given me several things to try. Yes, I do have a >new cell phone and the first thing I'll try is to turn it off and see what >happens. I also have dual electronic ignition and I'll do some >experimenting there too. One thing I've noticed is that one of the >ignitions has begun to make a noise in my headset. Basically I can hear >the trigger wheel going past the crank sensors, so I may have some wiring >that is leaking through to the headset wiring and possibly to the >transponder too. Something to look at. Other than that the ignitions >seem to be operating fine, as is the alternator, however I have no way of >turning it off. The transponder acts normally when the engine isn't >running. I my area its very rural with no interrogation pulses until I >get at least 2000agl, and even those are a long way off, so I'm not >getting bombarded with pulses. >However, I do have some things to try. Thanks. >Also, thanks to the others who offered help. Got in on this thread late but as others have noted, the transponder receiver is rather 'twitchy' with respect mistaking incoming noises as a bona fide "paint" from a ground based radar. A technician I used to work with had some rubber bands permanently installed over the hand grip on his line operated electric drill. I asked what they were for and he was happy to demonstrate. Use the rubber bands to hold the trigger made and then lay the drill on the floor right under the transponder antenna. From outside the cockpit you could see the reply light going nutso. He had one of those altitude and squawk code receiver/readouts that could then be used to see if the altimeter encoder was reading the same as the pitot-static test set altitude. The drill motor and the el-cheeso readout accessory took the place of some rather expensive test equipment for doing pitot static tests. Try pulling all the breakers/fuses except transponder. See if effects go away. Reinstall feeder protection one device at a time to see if you can identify the one that's upsetting the transponder. But all who have responded to this thread have identified possibilities for pesky little noises that might be causing the problem. It doesn't take much. Bob . . . ________________________________________________________________________________
Date: Jul 30, 2008
Subject: Re: Z-19/RB Question
Mike, That's exactly how I've operated our RV for years. My reasoning for doing so is that I only have to turn off one switch (the master) in case of alternator failure. I don't have to worry about turning on the alt feed before doing so to avoid rebooting stuff. In fact, when my alternator quit working on my way to British Columbia last spring, that's what I did. Flipped one switch and kept going. Had enough battery for an hour's flight, landing at a towered airport for gas, a start and departure and another 45 minutes of flight and still had enough in the battery for a start after replacing the alternator. I turned off stuff we didn't need, but kept the electronic ignition, transponder and GPS going. Turned on and used the Com when I needed to and didn't worry about maintenance till we stopped at our intended destination for the night. I turn on the alternate feed, check atis while I'm inserting my ear canal headset to make sure I've got them in right then I turn on the master, start and operate normally. My voltmeter is on the E-Buss so, if I do turn the alt feed off, I'm reading a voltage somewhat lower than the actual charging voltage. I don't have to do any math to see what the alternator is up to. Pax, Ed Holyoke mikef wrote: > > Bob, > > Understood, that EBus switch is ALTERNATE path to powering the EBus. And as you said, turn it on, check ATIS are all good preflight procedures to test this path. > > I just wanted to confirm that once you are started and the alternator is running smoothly, it would do no harm to leave the EBus switch turned on (closed) during normal operations. > > Thanks, > > Mike > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=195343#195343 > > > ________________________________________________________________________________
Subject: Cell phone microphone as compared to aviation microphone
Date: Jul 31, 2008
Does anybody have a reference on what a cell phone headset plug expects in terms of impedance and/or excitation signal levels? And how this compares to that produced by an aviation microphone? I've wired a jack into my audio panel for plugging in my cell phone and it "almost" works -- I can hear fine, but I have to yell in my aviation head set's microphone to be heard at all by the recipient of my cell phone call (and then only weakly). Fine for checking voice mail before take off, but not so great for requesting a clearance. I suspect I need a preamp on the microphone line or perhaps an excitation circuit to convert impedance to voltage but have been unsuccessful in finding any data to help design the appropriate circuit. Thanks! Scott ________________________________________________________________________________
From: "Andrew Butler" <andrewbutler(at)ireland.com>
Date: Jul 31, 2008
Subject: FW: Startup Checks
Darwin, Here is a complete thread I had with Brad at E-Mag Ignitions earlier this year on startup checks. Cheers, Andrew. ------------------------------------------------------------------------ From: info(at)emagair.com [mailto:info(at)emagair.com] Sent: 09 May 2008 16:57 Subject: RE: Startup Checks Andrew: When an ignition is first powered up it has to wake up, load the operating code, track engine position, determine when the next spark even needs to happen, and finally trigger that spark event. If you power up while the engine is running all this has to happen very quickly. Since P models make their own power (as long as the engine is running), you cannot shut down the processor. You can turn both the p-lead and the 12 supply OFF and it will still be "awake" doing its business as usual, waiting to resume firing as soon as the p-lead is ungrounded. With E models, however, you can power them OFF when running, and the ignition (truly) will go dark - still no problem. Powering the E model OFF is not the issue. It's when you 1) power an E model ON (while the engine is running) and 2) with the p-lead ungrounded that you are asking it to instantaneously wake up and start firing as described above. The condition can be avoided (if encountered) by making sure the p-lead is grounded (OFF) before powering (12 volt) ON an E model ignition while the engine is running. Even so, if this happens, we aren't predicting disaster. It will probably resume operation just fine, but there is no reason to do it in the first place - that's all. I don't recall any customers (yet) in Ireland - congratulations, you'll be number 1. Kindest Regards, Brad Dement E-MAG Ignitions 2014 Greg Street Box 112 Azle, Texas 76020 (817) 444-5310 ------------------------------------------------------------------------ From: Butler, Andrew [mailto:andrew.butler(at)nuigalway.ie] Sent: Friday, May 09, 2008 10:29 AM Subject: RE: Startup Checks Thanks very much Brad, and you are welcome. =B7 I am assuming that like a magneto, the plugs only spark when the unit (connection 4) is NOT grounded. =B7 What is the logic behind not switching off power to an E-MAG while the engine is running? I am assuming that switching off power is okay, that it is switching power back on while the engine is turning that is the problem. What exactly is the event sequence associated with switching on power while the engine is turning that is problematic? =B7 Why is it problematic to turn power on while the P-MAG is “live” i.e ungrounded? I am not installing a rotary key switch, rather an individual power switch for each ignition. It appears that I will need a two position switch that allows me to control access to power and ground individually. BTW, I think mine will be the first IE registered aircraft will dual EMAGAIR ignitions. Do you know of any other customers in Ireland? Cheers, Andrew. RV71700 Galway, Ireland. From: info(at)emagair.com [mailto:info(at)emagair.com] Sent: 08 May 2008 17:07 Subject: RE: Startup Checks Hi Andrew: Thanks for considering us for your project. The ignition check for E-MAG ignitions is very similar to that of magnetos. You'll do your regular L/R (p-lead) check to make sure both ignitions operate. The only difference is that for each P model ignition you have installed (one or both) you'll add one additional sequence. While switched to the individual P model(s), simply turn OFF the 12 volt power that feeds that ignition for a few seconds to verify the engine continues to run. If the engine runs, the internal alternator is operating. If the engine quits, the alternator is not working. The engine speed should be 1000 rpm or greater when you do this check. There is no need to do this test with an E model as they don't have an alternator. The L/R test is a p-lead (ON/OFF) test applicable to both E and P models. The 12 power (ON/OFF) test is applicable to P models only, and we discourage doing it with E models, so the FAQ you refer to is not in conflict with the pre-flight ignition tests. The Installation and Operating Guide also has some recommendations on starting with our equipment - see Downloads page on our web site. Don't hesitate to call or drop us a note if you have any other questions. Kindest Regards, Brad Dement E-MAG Ignitions 2014 Greg Street Box 112 Azle, Texas 76020 (817) 444-5310 ------------------------------------------------------------------------ From: Butler, Andrew [mailto:andrew.butler(at)nuigalway.ie] Sent: Thursday, May 08, 2008 9:09 AM Subject: Startup Checks Hello, I am awaiting delivery of an XP Superior IO 360. I had opted to replace the mags with dual ignition from lightspeed. Then I was made aware that Superior were about to start offering your product as an option also. Given what I have learned, I am going to switch to dual P-Mags. I need some advice on how to perform prefilght checks of each ignition. Sure, switching off the power to both and see if the engine stops is fine, but how do I determine whether each (or both) continue to fire when power is disconnected? Also, your FAQ says never switch on the E-Mag power with the engine running. How does one then perform preflight checks on each ignition in an E-Mag / P-Mag configuration? Best regards, Andrew Butler. RV71700. ________________________________________________________________________________
Date: Jul 31, 2008
Thanks Ed, That is a helpful confirmation of my understanding. I am building my preflight/postflight checklists for this new z-19 system. I too don't want things to go 'offline' if the alternator dies. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195860#195860 ________________________________________________________________________________
Subject: Re: AT150 Interrogation Light
Date: Jul 31, 2008
Thanks for your reply, Bob. I appreciate all input. Well, I flew this morning for about an hour and the first thing I checked was that my cell phone was turned off. No change. At cruise the light was on steady. Next, I switched off my left ignition which did two things. It stopped the noise in my headset and the interrogation light on the transponder went out and started blinking normally! I'm getting close. So, now I can tear into the wiring and see where my left ignition wiring is in a common bundle with my headset receive and also the transponder. What would you suggest here? Obviously I need to either separate some wiring or do some shielding, but I'm not sure which way I should go. If you were to home in on a specific wire, which would it be? My engine is the NSI EA81 with stock Electromotive ignition modules. I personally don't think anything is wrong with the ignitions. I believe I just have an ignition wire somewhere causing interference. I'll dig my schematics out to see if I can experience an epiphany. Thanks again, Deke NE Michigan nuckolls.bob(at)cox.net wrote: > > > > > > > Thanks, Matt. You've given me several things to try. Yes, I do have a > > new cell phone and the first thing I'll try is to turn it off and see what > > happens. I also have dual electronic ignition and I'll do some > > experimenting there too. One thing I've noticed is that one of the > > ignitions has begun to make a noise in my headset. Basically I can hear > > the trigger wheel going past the crank sensors, so I may have some wiring > > that is leaking through to the headset wiring and possibly to the > > transponder too. Something to look at. Other than that the ignitions > > seem to be operating fine, as is the alternator, however I have no way of > > turning it off. The transponder acts normally when the engine isn't > > running. I my area its very rural with no interrogation pulses until I > > get at least 2000agl, and even those are a long way off, so I'm not > > getting bombarded with pulses. > > However, I do have some things to try. Thanks. > > Also, thanks to the others who offered help. > > > > > > Got in on this thread late but as others have noted, > the transponder receiver is rather 'twitchy' with > respect mistaking incoming noises as a bona fide > "paint" from a ground based radar. > > A technician I used to work with had some rubber > bands permanently installed over the hand grip > on his line operated electric drill. I asked what > they were for and he was happy to demonstrate. Use > the rubber bands to hold the trigger made and then > lay the drill on the floor right under the transponder > antenna. From outside the cockpit you could see the > reply light going nutso. He had one of those altitude > and squawk code receiver/readouts that could then > be used to see if the altimeter encoder was reading > the same as the pitot-static test set altitude. > > The drill motor and the el-cheeso readout accessory > took the place of some rather expensive test equipment > for doing pitot static tests. > > Try pulling all the breakers/fuses except transponder. > See if effects go away. Reinstall feeder protection > one device at a time to see if you can identify the > one that's upsetting the transponder. But all who > have responded to this thread have identified possibilities > for pesky little noises that might be causing the > problem. It doesn't take much. > > Bob . . . Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195880#195880 ________________________________________________________________________________
Date: Jul 31, 2008
Hi Scott. Try this: MICIN---||-----o----/\/\/\/----X----/\/\/\----GND 0.1uF 100 Kohms 10 Kohm Take the cellphone mic input from the "X" This assumes that the MICIN signal from your headset is being biased by your intercom. The capacitor is critical to remove DC from the signal which would overload your cellphone mic input otherwise. >From this, you'll see that the aircraft mic signal is being attenuated by about 20 dB. This can be varied by adjusting the ratio of the two resistors. Good Luck Vern Little Vx Aviation www.vx-aviation.com Audio Mixer/Stereo Headphone Interface/Tone Annunciator/Annunciator Lamp Controller and more. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Scott Sent: July 31, 2008 1:40 AM Subject: AeroElectric-List: Cell phone microphone as compared to aviation microphone Does anybody have a reference on what a cell phone headset plug expects in terms of impedance and/or excitation signal levels? And how this compares to that produced by an aviation microphone? I've wired a jack into my audio panel for plugging in my cell phone and it "almost" works -- I can hear fine, but I have to yell in my aviation head set's microphone to be heard at all by the recipient of my cell phone call (and then only weakly). Fine for checking voice mail before take off, but not so great for requesting a clearance. I suspect I need a preamp on the microphone line or perhaps an excitation circuit to convert impedance to voltage but have been unsuccessful in finding any data to help design the appropriate circuit. Thanks! Scott ________________________________________________________________________________
Date: Jul 31, 2008
From: "Etienne Phillips" <etienne.phillips(at)gmail.com>
Could it be a spark-plug lead connected to the left ignition circuit that has a problem with it's shielding? Etienne 2008/7/31 Fox5flyer > fox5flyer(at)idealwifi.net> > > Thanks for your reply, Bob. I appreciate all input. Well, I flew this > morning for about an hour and the first thing I checked was that my cell > phone was turned off. No change. At cruise the light was on steady. Next, > I switched off my left ignition which did two things. It stopped the noise > in my headset and the interrogation light on the transponder went out and > started blinking normally! I'm getting close. So, now I can tear into the > wiring and see where my left ignition wiring is in a common bundle with my > headset receive and also the transponder. What would you suggest here? > Obviously I need to either separate some wiring or do some shielding, but > I'm not sure which way I should go. If you were to home in on a specific > wire, which would it be? My engine is the NSI EA81 with stock Electromotive > ignition modules. I personally don't think anything is wrong with the > ignitions. I believe I just have an ignition wire somewhere causing > interference. I'll dig my schematics out to see if I can experience an > epiphany. > Thanks again, > Deke > NE Michigan > > ________________________________________________________________________________
Date: Jul 31, 2008
Deke, Sounds like you're making progress.. Does the engine have two plugs per cylinder? If so, the problem could be as simple a faulty high tension lead - or even a bad plug. Along these lines, my guess would be that the source of noise is in the high-energy portion of the system - as that seems most likely to radiate offensive noise. That's why I'd guess the noise is from a high tension lead. If not dual plugs, does your system use a coil switcher? If so, maybe the noise is in that portion of the circuit. Good luck! Matt- > > > Thanks for your reply, Bob. I appreciate all input. Well, I flew this > morning for about an hour and the first thing I checked was that my cell > phone was turned off. No change. At cruise the light was on steady. > Next, I switched off my left ignition which did two things. It stopped > the noise in my headset and the interrogation light on the transponder > went out and started blinking normally! I'm getting close. So, now I can > tear into the wiring and see where my left ignition wiring is in a common > bundle with my headset receive and also the transponder. What would you > suggest here? Obviously I need to either separate some wiring or do some > shielding, but I'm not sure which way I should go. If you were to home in > on a specific wire, which would it be? My engine is the NSI EA81 with > stock Electromotive ignition modules. I personally don't think anything > is wrong with the ignitions. I believe I just have an ignition wire > somewhere causing interference. I'll dig my s! > chematics out to see if I can experience an epiphany. > Thanks again, > Deke > NE Michigan > ________________________________________________________________________________
Date: Jul 31, 2008
Richard Girard wrote: > I need to put a headset in my Shoei helmet that I use on my trike. I'm > reluctant to take apart a $100 headset to get the mic and speakers if it's > possible to do this with Rat Shack parts (or Digikey, Mouser, or.....). > Anyone out there have any recommendations, part numbers or required specs? > > Thanks, > Rick > > Try Radio Shack part number 270-090. I wired one directly to a microphone plug (ACS and Wicks have them for about $5). I used a piece of piano wire to form a mic-boom, and used some higher-end ($40) in-the-ear phones, that also plugged directly into the intercom. It works great in our clubs C150, but is really noisy in our Cherokees. My intercom is one of Jim Weir's 4-place kits. My headset works great with it as long as it is the only one plugged in. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Jul 31, 2008
Just one more thing, Mike. I periodically test the diode feeding the E-Buss by turning on the master only or turning off the E-buss switch first and making sure that the stuff on the E-buss is hot. I don't want the alternate feed switch to be the single point of failure. Pax, Ed Holyoke mikef wrote: > > Thanks Ed, That is a helpful confirmation of my understanding. I am building my preflight/postflight checklists for this new z-19 system. I too don't want things to go 'offline' if the alternator dies. > > > Read this topic online here: > > http://forums.matronics.com/viewtopic.php?p=195860#195860 > > > ________________________________________________________________________________
Date: Aug 01, 2008
Thanks, Matt. First, the engine uses one plug per cylinder. The two ignitions come together in coil joiners (isolation modules). I'd considered the possibility of a bad high tension lead, but sort of discounted that because the engine runs great from either ignition with no drop at all with mag checks. Then again, that's just my logic talking and it doesn't mean that it's not a high tension lead. I've changed plugs with the same result. If I could figure out what "might" be causing it, I could probably do a little wire sorting and find the culprit, but I'm just not knowledgeable enough to get a clear picture in my mind what is happening. Obviously, it's emanating from the left ignition circuit because when I turn off power to it, the noise in my headset stops and the interrogation light on the transponder goes out. I've already checked all of the high tension leads with an ohm meter and none are significantly different which leads me to believe the problem lies in the "placement" of my wiring bundles somewhere. Am I making sense? Thanks again, Deke mprather(at)spro.net wrote: > Deke, > > Sounds like you're making progress.. Does the engine have two plugs per > cylinder? If so, the problem could be as simple a faulty high tension > lead - or even a bad plug. > > Along these lines, my guess would be that the source of noise is in the > high-energy portion of the system - as that seems most likely to radiate > offensive noise. That's why I'd guess the noise is from a high tension > lead. > > If not dual plugs, does your system use a coil switcher? If so, maybe the > noise is in that portion of the circuit. > > Good luck! > > > Matt- > > > > > > > > > > Thanks for your reply, Bob. I appreciate all input. Well, I flew this > > morning for about an hour and the first thing I checked was that my cell > > phone was turned off. No change. At cruise the light was on steady. > > Next, I switched off my left ignition which did two things. It stopped > > the noise in my headset and the interrogation light on the transponder > > went out and started blinking normally! I'm getting close. So, now I can > > tear into the wiring and see where my left ignition wiring is in a common > > bundle with my headset receive and also the transponder. What would you > > suggest here? Obviously I need to either separate some wiring or do some > > shielding, but I'm not sure which way I should go. If you were to home in > > on a specific wire, which would it be? My engine is the NSI EA81 with > > stock Electromotive ignition modules. I personally don't think anything > > is wrong with the ignitions. I believe I just have an ignition wire > > somewhere causing interference. I'll dig my s! > > chematics out to see if I can experience an epiphany. > > Thanks again, > > Deke > > NE Michigan > > > > > > > -------- Deke Morisse Kitfox S5 TD NSI/CAP Read this topic online here: http://forums.matronics.com/viewtopic.php?p=195978#195978 ________________________________________________________________________________
Date: Aug 01, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
> >Thanks, Matt. First, the engine uses one plug per cylinder. The two >ignitions come together in coil joiners (isolation modules). I'd >considered the possibility of a bad high tension lead, but sort of >discounted that because the engine runs great from either ignition with no >drop at all with mag checks. Then again, that's just my logic talking and >it doesn't mean that it's not a high tension lead. I've changed plugs >with the same result. If I could figure out what "might" be causing it, I >could probably do a little wire sorting and find the culprit, but I'm just >not knowledgeable enough to get a clear picture in my mind what is >happening. Obviously, it's emanating from the left ignition circuit >because when I turn off power to it, the noise in my headset stops and the >interrogation light on the transponder goes out. I've already checked all >of the high tension leads with an ohm meter and none are significantly >different which leads me to believe the problem lies in th! > e "placement" of my wiring bundles somewhere. Am I making sense? On the TC side of aviation's house, all appliances considered for use on airplanes is evaluated for its stand-alone characteristics with respect to noise emissions, noise vulnerabilities, temperature limits, etc. The goal is to offer smooth integration of that device into an airplane where the installer does not need to accommodate a shortfall in performance. I presume that you have two identical ignition systems of which only one causes noise. I'm presuming further that few (if any) other builders have experienced the noise issues with these systems. This leads me to suggest that there is something "different" about the two systems installed on your airplane. It might be fixed by a wire installation revision . . . but if so, then perhaps theses systems have not been sufficiently refined sufficiently for smooth integration into aircraft. I mention all this because it offers a mode of investigation that looks for differences between the two systems. One generates an unacceptable level of noise while the other does not. How are wires routed differently between the two? You might try swapping components between the two systems to see if the problem follows the swap. You can use the 12 lantern battery experiment to power each system up independently from ship's power . . . although this is a very long shot for a noise that the transponder sees. The transponder has already been qualified to tolerate a lot of conducted noise into ship's wiring . . . the energy that upsets it now is probably coming through the antenna. So, try disconnecting the transponder antenna for a short test to see if it stops triggering on the noise. This is a game of clue. You've identified the source of noise and victim to that noise. Now you need to ferret out the propagation mode. Once that's identified, the fix will be easy. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2008
> >Just one more thing, Mike. I periodically test the diode feeding the >E-Buss by turning on the master only or turning off the E-buss switch >first and making sure that the stuff on the E-buss is hot. I don't want >the alternate feed switch to be the single point of failure. The e-bus alternate feed switch cannot be a single point of e-bus failure since it's the second of two independent feed paths to the e-bus. If the alternate feed path is pre-flight tested and then "put away unless needed" then probability of it being available as needed is very high. This was the spirit and intent of the alternate feed path philosophy re-enforced by the notion that it was a good thing to shut battery contactors off during battery only operations. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2008
> >Thanks Ed, That is a helpful confirmation of my understanding. I am >building my preflight/postflight checklists for this new z-19 system. I >too don't want things to go 'offline' if the alternator dies. The only thing that happens when the alternator quits is that bus voltage drops from a nominal 14.2 volts down to about 12.6 volts. If you did NOTHING at this point in time, you would be no worse off than if you were flying a C-172 except that your options for load shedding for battery only ops are more limited in the C-172. If you were typical of C-172 drivers, you would have no idea how long the battery would carry the minimum loads you were able to achieve because not one C-172 driver in 1000 has any first hand knowledge of (1) battery capacity and (2) how long his minimized loads will run from that capacity. If you did not have the alternate e-bus feeder installed (replace the diode with an avionics master switch) you MIGHT still have a leg up on a C-172 driver in that you could conduct the experiments to KNOW how much battery only endurance you had with that particular architecture. Now, having added the alternate feed path and the diode that prevents mis-routing of energy, you have an opportunity to craft a confident plan-b for dealing with alternator failure. The plan-b removes all loads not necessary for en route operation of the airplane . . . which can be quite small. This INCLUDES energies need to keep the battery contactor closed. Once you are cleared to land you can turn the battery master back ON and run any number of additional goodies you wish. Whether or not they continue to run to the parking spot is immaterial to the outcome of the flight. There is no compelling reason to fly with the alternate feed path closed. Even if your ships voltmeter feeds from the e-bus, it reads about .7v lower than main bus . . . so what? That value becomes the NORMAL operating point for the e-bus. The fact that it does not represent main bus voltage is of no consequence to you as a pilot in the operation of the airplane. Bob . . . >Read this topic online here: > >http://forums.matronics.com/viewtopic.php?p=195860#195860 > > >Checked by AVG - http://www.avg.com >6:37 PM Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 01, 2008
One cheap "tester" to find the source of the noise, is an old Walkman or equivalent radio(yeah, those things about 2 generations older than the Ipod), tuned away from any station, on the AM band, preferably near the top...1650 or thereabouts. Then just move it about taking all necessary precautions with regard to the prop slice/dicer up front. Wherever the noise peaks, is the location of the offender. I've found bad voltage regulators that way, among other things. Just a resistance reading doesn't prove a high tension lead isn't leaking noise, only proves continuity. Fox5flyer wrote: > > Thanks, Matt. First, the engine uses one plug per cylinder. The two ignitions come together in coil joiners (isolation modules). I'd considered the possibility of a bad high tension lead, but sort of discounted that because the engine runs great from either ignition with no drop at all with mag checks. Then again, that's just my logic talking and it doesn't mean that it's not a high tension lead. I've changed plugs with the same result. If I could figure out what "might" be causing it, I could probably do a little wire sorting and find the culprit, but I'm just not knowledgeable enough to get a clear picture in my mind what is happening. Obviously, it's emanating from the left ignition circuit because when I turn off power to it, the noise in my headset stops and the interrogation light on the transponder goes out. I've already checked all of the high tension leads with an ohm meter and none are significantly different which leads me to believe the problem lies in th! > e "placement" of my wiring bundles somewhere. Am I making sense? > Thanks again, > Deke > ________________________________________________________________________________
Date: Aug 01, 2008
Subject: Re: FYI: Powergate
> >See: http://www.perfectswitch.com/downloads/relaybrochure.pdf > >This guy sells big SSRs. I'd like to see a schematic. But it might be >worth looking into. My concern is that he might have miscalculated the >dissipation, but I can't tell from the information. > >Anybody want to investigate and report back? Looks like these folks have resurrected an idea that was explored and abandoned 33 years ago: http://www.perfectswitch.com/mobipower110vmodule.htm This product appears to capitalize on the ability of the alternator to output voltage that is many times nominal rated output. http://aeroelectric.com/articles/When_is_110V_not_Over_Voltage.pdf I note further that this same company offers accessories fitted to modern alternators that utilize the alternator's higher voltage output abilities to accomplish certain welding operations. http://www.perfectswitch.com/alternators.htm http://www.perfectswitch.com/mobiarc150.htm http://www.perfectswitch.com/remotecontrolmodule.htm No doubt, modern diodes are considerably more robust that those we struggled with in 1975! They are in CA and too early to talk to on phone right now. I've e-mailed them for more information on the high current relays. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2008
> >One cheap "tester" to find the source of the noise, is an old Walkman or >equivalent radio(yeah, those things about 2 generations older than the >Ipod), tuned away from any station, on the AM band, preferably near the >top...1650 or thereabouts. Then just move it about taking all necessary >precautions with regard to the prop slice/dicer up front. Wherever the >noise peaks, is the location of the offender. I've found bad voltage >regulators that way, among other things. Just a resistance reading doesn't >prove a high tension lead isn't leaking noise, only proves continuity. Good point! I've still got some pocket transistor radios around that have been used for that purpose years ago. In my case, I was tracking down arcing insulators on power poles. The directional qualities of their "loopstick" antennas can be exploited to deduce direction of a received signal (as described in the 'Connection's chapter on antennas). I've not had occasion to use one of these radios in many years. I heard of a more modern utilization in a class on RFI/EMC issues about 15 years ago. The speaker told how he boxed a pocket radio up in an RF tight, aluminum enclosure. He brought a coax connector through the box and tied it to a "primary of a transformer" wound around the radio. I think it was 5 turns of 22awg wire. He also brought out the headphone circuit through RFI filters. The radio was turned ON, tuned to the high end of the band, volume up to max and the box closed. A short piece of coax could be fitted at the end with either magnetic or electric field probes http://aeroelectric.com/Pictures/Tools/RF_Antenna_Test_Tools/Sniffer_Probes.jpg I built these probes for use on a very broadband spectrum analyzer. Another name for a fancy receiver. This poor man's electronic "stethoscope" was useful for "sniffing" about the airplane for the purpose of pinpointing the exit location for a radiated noise source. This also assumes that the noise source is also broad band with components in the audible range. In other words, a relatively clean, RF energy or energy at very high frequencies would not produce a signal that one would expect to hear with this tool. In the case before us, the repetition rate for ignition system currents are very much in the audio range and have a base-band component that is at or below the broadcast band detection range of the pocket radio. This system would not be useful for finding conducted noise sources where the offending signal stays pretty much in the wiring. Once it's absolutely confirmed that the transponder's antagonist is radiated (coming in through the antenna) then perhaps Kelly's suggestion offers a useful tool for further investigation. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2008
Bob, What I was saying is that I use the "alternate feed switch" (labeled "E-Buss") as the primary feed to the E-buss, sort of like an avionics master, and that the diode on the master is now a backup and as such, I need to make sure it hasn't failed leaving only one feed path available to my essential equipment. I do test the feed path, but I don't put it away until needed, as you say, because I feel having it on simplifies the process of load shedding (including the contactor and alternator field) in case of alternator failure (or ground ops). I chose this method because I don't want to risk inflight re-booting of my EFIS and autopilot by flipping switches in the wrong order. That I don't have to do (admittedly easy) math with the .7 volt diode drop is gravy, not the deciding factor. It strikes me that, if one didn't mind having an extra switch, the diode could be eliminated as well, leaving the E-Buss as a separate entity from the main buss. The philosophy of having independent feed paths and being able to simply shed unnecessary loads would still be served. Pax, Ed Holyoke Robert L. Nuckolls, III wrote: > > >> >> >> Just one more thing, Mike. I periodically test the diode feeding the >> E-Buss by turning on the master only or turning off the E-buss switch >> first and making sure that the stuff on the E-buss is hot. I don't >> want the alternate feed switch to be the single point of failure. > > The e-bus alternate feed switch cannot be a single point > of e-bus failure since it's the second of two independent > feed paths to the e-bus. If the alternate feed path is > pre-flight tested and then "put away unless needed" then > probability of it being available as needed is very high. > > This was the spirit and intent of the alternate feed path > philosophy re-enforced by the notion that it was a good > thing to shut battery contactors off during battery only > operations. > > Bob . . . > > ________________________________________________________________________________
Date: Aug 01, 2008
Subject: Re: ICOM A200
Rick: Thank you for taking the time to respond to the discussion of the broken tuning knob on the A200. That certainly is good news about the part availability. Too often, misunderstandings, half-truths and false information are repeated on the internet without question, to everyone's detriment. I will be contacting ICOM for a replacement part, and installing it myself, and probably blogging the process. I agree with your time estimate: about 10 minutes start to finish (1 hour minimum charge) seems right, based on my experience. I am glad that ICOM will make this part available to owner-pilot-builders who have the savvy to effect this repair. Thanks for clearing that up. I own 4 different ICOM amateur and aviation radios, and am happy with them all. Keep up the good work! -Bill Boyd On Fri, Aug 1, 2008 at 2:41 PM, Rick Waedekin wrote: > Good morning/ afternoon everyone. I was forwarded a link to your blog > site and felt compelled to respond. It appears there is a lot of > misinformation floating around about ICOM so I thought I would clear up a s > much as I could for you. > > > I would've posted this to your site, but I couldn't figure out how to do > so=85 > > > 1) The part needed to fix the busted knob is our part number > 0308670106 and anyone can call our parts department and buy one for $64.2 7. > Our parts department contact information is listed on our website but her e > it is as well. > > Icom America Parts Department > (800) 346-0495 > Monday - Friday, 8:00 AM-5:00 PM Pacific Time > > 2) We have many Avionics Shops that could also get the part and fix > it for you. Gulf/ Pacific Coast, Eastern Avionics, Aircraft Spruce, > American Avionics, Banyan just to name a few shops. Plus, we have our > Service department here in Bellevue, WA as well as our regional service > center in Anderson, SC that could fix this for you as well. All of this > information is right on our website as well. > > 3) It only takes one hour to repair/ replace the rotary encoder on > the A200. > > > Obviously we'd rather have one of our dealers/ repair facilities fix this > problem as there are a lot of ribbon cables and such that if not treated > correctly can do even more damage to the unit, and wind up costing even m ore > money down the road. > > > On a final note, as a rule ICOM's parts department supports most of the > parts needed to fix our products for up to 10 years after the last date o f > manufacture. > > > I hope this cleared up some of the questions floating around. > > > Thanks for your support of ICOM products. > > > *Rick Waedekin |* National Sales Manager | *Icom America, Inc.* > > 2380 116th Ave NE | Bellevue, WA | 98004 > > ________________________________________________________________________________
Date: Aug 01, 2008
> > >> >> >>See: http://www.perfectswitch.com/downloads/relaybrochure.pdf Just got a data package from Perfect Switch on their "Power-Gate" products. I've combined all the images and files into a single .pdf at: http://tinyurl.com/59faul The information is fairly descriptive. The text of an accompanying e-mail stated that these are, for the moment, un-directional devices. This means that effects of the parasitic diode in their large array of Power FET devices will "backfeed" power to the source should the votlage on the load side become high enough. It also means that they're not ready to perform as a battery contactor with equally low resistance connection for electron flow both directions through the device. Prices for the current offerings are given on page 5 of the file. Here we find that a relay suited for carrying starter currents will set you back over $300. I'm told by my local Gigavac rep that a sample contactor has been ordered for us to play with. Bob . . . ________________________________________________________________________________
Date: Aug 01, 2008
> >Bob, > >What I was saying is that I use the "alternate feed switch" (labeled >"E-Buss") as the primary feed to the E-buss, sort of like an avionics >master, and that the diode on the master is now a backup and as such, I >need to make sure it hasn't failed leaving only one feed path available to >my essential equipment. I do test the feed path, but I don't put it away >until needed, as you say, because I feel having it on simplifies the >process of load shedding (including the contactor and alternator field) in >case of alternator failure (or ground ops). I chose this method because I >don't want to risk inflight re-booting of my EFIS and autopilot by >flipping switches in the wrong order. That I don't have to do (admittedly >easy) math with the .7 volt diode drop is gravy, not the deciding factor. > >It strikes me that, if one didn't mind having an extra switch, the diode >could be eliminated as well, leaving the E-Buss as a separate entity from >the main buss. The philosophy of having independent feed paths and being >able to simply shed unnecessary loads would still be served. The diode was considered necessary and useful to eliminate the potential for having both switches closed at the same time and having the main bus take power through the e-bus alternate feed path . . . a bonus of using the diode IS the automatic switching of one feed path and elimination of the switch. Of course, how you choose to modify the system and its operation is a personal decision. Bob . . . ________________________________________________________________________________
Subject: Transpo V1200 regulator
Date: Aug 01, 2008
Okay, I tried looking at some old posts to help me figure out how to wire a regulator I have but I think it just confused me more.. I have a Transpo V1200 regulator for a high amp output Alternator aka: http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf Question is what all connects to all the terminals listed? The label just shows: "I" "A" "S" "F" "Stator Output" my guess is leave disconnected maybe use for testing ? "B-" my guess is ground here.. Can anybody find a manual on what goes where? Or more to the point how to incorporate it into the Z diagrams ? Thanks Jeff. ________________________________________________________________________________
Date: Aug 02, 2008
Subject: Re: Transpo V1200 regulator
>Okay, I tried looking at some old posts to help me figure out how to wire >a regulator I have but I think it just confused me more&. > > >I have a Transpo V1200 regulator for a high amp output Alternator aka: > ><http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf>http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf > > >Question is what all connects to all the terminals listed? > >The label just shows: > >I > >A > >S > >F > > >Stator Output my guess is leave disconnected maybe use for testing ? Here's the only data I've been able to find on the V1200 to date. It speaks to a lot of its capabilities but gives nothing in the way of a wiring diagram. http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf The "IASF" convention for alternator regulator labels has been around for some time. For the most part, they're consistent in terms of function. "I" terminal is a pull-down connection to illuminate an alternator fail light that is tied to the bus. If you have a low voltage warning system in your airplane, this terminal can be ignored. The "A" terminal supplies alternator field current and is probalby the bus voltage sense wire as well. It goes to a 5A breaker or fuse on your main bus. The "F" terminal connects to the alternator's field terminal. Some alternators have both field terminals brought out. If you have two field terminals, ground one and power the other from the regulator's "F" terminal. The "S" terminal was originally used to sense voltage at the center terminal of a "Wye wound" alternator. Even when no field excitation was applied, the "S" terminal would have a small voltage on it derived from the residual magnetism of the rotor as soon as the alternator was spun up by the engine. This voltage was used to close a field excitation control relay . . . http://aeroelectric.com/Pictures/Regulators/Ford_EM_Reg_Field_Relay.jpg and the left device in . . . http://aeroelectric.com/Pictures/Regulators/Ford_EM_Reg.jpg This feature kept the alternator from drawing field current after the ignition switch was turned on and the engine not yet running. Without seeing schematics and/or having lucid explanations from the manufacturer (Transpo) I would assume that the "S" terminal still functions in the same manner when the regulator is used on alternators with the Wye-wound center tap brought to the outside world. When the stator tap terminal is not present, the regulator still needs to be told that it's time to go to work and we tie the "S" terminal to the "A" terminal so that both are powered up at the same time. This convention is observed in the Z-figures where I've illustrated the generic "ford" regulators. See: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11L.pdf The data sheet speaks to B+ and B- terminals, also S1 and S2. If they are present on your V1200, I have no idea what S1 and S2 are for. >B- my guess is ground here&. Good guess. > > >Can anybody find a manual on what goes where? Or more to the point how to >incorporate it into the Z diagrams ? Z-11 cited above is close if not an exact regulator wiring diagram for the V1200. When our drive stand is up and running, I'll acquire a V1200 and explore its features in more detail. In the mean time, if anyone stumbles across some third party wiring diagrams for Transpo or any other popular product, I'd be pleased to acquire those also for mirroring on my website. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2008
Okay, I spent a little time poking around with the harness that came with the regulator - high output alternator and attached is what I found, does this help at all ? or just ask more questions ? It looks like I and A are tied together from the main output terminal of the alternator ! NOTE: the relay CAME with the harness and I am told the on off for the relay is from the ignition circuit or switch. My main concern is why they took power into I and A from the main output of the alternator with no fuse or wire protection ? and how do I tie this into the Z figures?? Same as below ? This unit is suppose to have OV protection and all that so No crow bar is required. Thanks Jeff. -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Saturday, August 02, 2008 9:52 AM Subject: Re: AeroElectric-List: Transpo V1200 regulator >Okay, I tried looking at some old posts to help me figure out how to wire >a regulator I have but I think it just confused me more&. > > >I have a Transpo V1200 regulator for a high amp output Alternator aka: > ><http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf >http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf > > >Question is what all connects to all the terminals listed? > >The label just shows: > >I > >A > >S > >F > > >Stator Output my guess is leave disconnected maybe use for testing ? Here's the only data I've been able to find on the V1200 to date. It speaks to a lot of its capabilities but gives nothing in the way of a wiring diagram. http://www.aeroelectric.com/Mfgr_Data/Regulators/Transpo/V1200_Transpo.pdf The "IASF" convention for alternator regulator labels has been around for some time. For the most part, they're consistent in terms of function. "I" terminal is a pull-down connection to illuminate an alternator fail light that is tied to the bus. If you have a low voltage warning system in your airplane, this terminal can be ignored. The "A" terminal supplies alternator field current and is probalby the bus voltage sense wire as well. It goes to a 5A breaker or fuse on your main bus. The "F" terminal connects to the alternator's field terminal. Some alternators have both field terminals brought out. If you have two field terminals, ground one and power the other from the regulator's "F" terminal. The "S" terminal was originally used to sense voltage at the center terminal of a "Wye wound" alternator. Even when no field excitation was applied, the "S" terminal would have a small voltage on it derived from the residual magnetism of the rotor as soon as the alternator was spun up by the engine. This voltage was used to close a field excitation control relay . . . http://aeroelectric.com/Pictures/Regulators/Ford_EM_Reg_Field_Relay.jpg and the left device in . . . http://aeroelectric.com/Pictures/Regulators/Ford_EM_Reg.jpg This feature kept the alternator from drawing field current after the ignition switch was turned on and the engine not yet running. Without seeing schematics and/or having lucid explanations from the manufacturer (Transpo) I would assume that the "S" terminal still functions in the same manner when the regulator is used on alternators with the Wye-wound center tap brought to the outside world. When the stator tap terminal is not present, the regulator still needs to be told that it's time to go to work and we tie the "S" terminal to the "A" terminal so that both are powered up at the same time. This convention is observed in the Z-figures where I've illustrated the generic "ford" regulators. See: http://www.aeroelectric.com/PPS/Adobe_Architecture_Pdfs/Z11L.pdf The data sheet speaks to B+ and B- terminals, also S1 and S2. If they are present on your V1200, I have no idea what S1 and S2 are for. >B- my guess is ground here&. Good guess. > > >Can anybody find a manual on what goes where? Or more to the point how to >incorporate it into the Z diagrams ? Z-11 cited above is close if not an exact regulator wiring diagram for the V1200. When our drive stand is up and running, I'll acquire a V1200 and explore its features in more detail. In the mean time, if anyone stumbles across some third party wiring diagrams for Transpo or any other popular product, I'd be pleased to acquire those also for mirroring on my website. Bob . . . ________________________________________________________________________________
Date: Aug 02, 2008
Subject: vm1000 DPU orientation
I have an old Vision Micro VM1000. Does any one recall if there is any orientation restriction on the DPU (digital processor unit) box? The manual doesn't indicate any preference, but the thing does have some socketed parts in it, which will be upside down if I mount it the way I want to. There might be a slightly greater chance of vibration making a part back out of its socket over a long period of time. Thanks, -- Tom S., RV-6A ________________________________________________________________________________
Subject: Re: RE: Why can't the tower hear me?
Date: Aug 02, 2008
A little new information on this. To refresh everyone's memory, I have a handheld with a homemade external antenna (brass brazing rod on the bottom of the nose, with a ground plane). I have no problems whatsoever communicating air to air, even up to 125 miles, and I have flown into multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - 120.825, KDTO - 119.95, KADM - 118.5, and others). Everyone reports my signal as loud and clear, EXCEPT the tower at KOUN (118.0). This morning, I was flying out of KOUN again and got some new information that might be helpful. On the ground, they could hear me very clearly on 121.6. As soon as I switched to 118.0 though, they said my transmission was garbled and unreadable (still on the ground, nothing had changed but the frequency). So, I know I can transmit clearly on 118.3. However, apparently it is not so clear on 118.0. I can hear the tower clearly on 118.0. I've read that an antenna that receives well will also transmit well...this makes me think the antenna is probably good. Is it possible that the digital tuner on my handheld is not tuning correctly? I know, I need to get another handheld in the plane to see if I have the same problem. My radio is a three year old Vertex Standard VXA-150. Anyway, my primary question is, can anyone shed light on why I am not able to transmit clearly on 118.0? Where should I look first to try and solve this problem? I realize that 118.0 is at the very bottom of the aviation band, which made me think maybe my antenna length is off just slightly. I am going to measure that to verify. On that note, what is the exact length of the antenna with respect to the ground plane that I should measure? It is a brass rod sticking through an aluminum plate with nylon spacers as insulators. The brass rod sticks up above the ground plane about 1/2" or so on top. Could that small unshielded portion cause a problem, or is it too small to be a factor, and only the primary antenna length below the ground plane matters? Thanks for any help, Steve Ruse ----- Original Message ----- From: H. M. Haught Jr. To: aeroelectric-list(at)matronics.com Sent: Thursday, February 14, 2008 12:22 PM Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? Cordiality wasn't in evidence at KOUN. I was told in no uncertain terms that it wasn't their fault that my radio was junk, but they would give me light signals to get me out. I tried to explain that I've had the radio worked on a number of times and their facility was the only place I was having any trouble, which was true at the time, and got the reply - "If you want light signals to get out, then tell me, but don't blame our equipment for your radio problems." I was on a telephone talking to them from the service office - wouldn't see me face to face. They see lots of high power stuff and cater to it - my old ratty looking Pacer was consider "junk". I took the light signals and the radio was working fine by the time I got to the end of the taxiway. Called up OK City immediately after leaving the pattern, had radio check and was told "five x five". Next time I go in, (I've got my hand held set up on an external antenna as a backup radio ), as soon as I power down, I'm going to call up tower for radio check on the Icom, and then do the same thing with the handheld on rubber ducky antenna. Next day, if I have problems, I'll try the rubber ducky antenna again, as using the external antenna on the hand held also resulted in unreadable transmissions. Just doesn't make sense that two different radios are having the same problem on the same day. M. Haught Greg Young wrote: <gyoung@cs-sol.com> I've called our tower a couple of times and found them to be very cordial and very much interested to hear from pilots. If the chief/supv is not on then ask for the controller in charge. It's amazing what you can learn and what they are already aware of. I called about a "trainee" who after at least a year on duty totally lost track of only 3 airplanes (I was one of them) while working ground. Turns out that what everyone thought was a trainee is a burn-out 2 weeks away from mandatory retirement. They were well aware of the problem and keeping him on duties where he couldn't hurt anyone. Yup, makes one proud of the system. Regards, Greg Young -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of glen matejcek Sent: Thursday, February 14, 2008 7:39 AM Subject: AeroElectric-List: RE: Why can't the tower hear me? --> Hi All- Sounds like perhaps it's time for phone calls to the tower chief to make sure that he/she knows of the issue. If that gets no results, a letter to the regional office. Make sure to delineate all the steps you guys have taken to verify your own equipment ops. You can also call them to let them on the phone to coordinate a NORDO arrival. Just be sure to review the light gun signals. Also, remember to keep you Piet under 200 KIAS ;-) As an aside, I've a good friend who is a controller who has provided me with various insights. Included in those were that although they can't upgrade equipment, they do get new leather furniture. Makes one proud of the system. glen matejcek aerobubba(at)earthlink.net ________________________________________________________________________________
Date: Aug 02, 2008
Do you have the same problem approaching KOUN from the air on 118.0? Have you tried air to air with a friend on 118.0 (far from KOUN)? Have you tried going to an uncontrolled field far away from KOUN with a friend who's got a known-good radio on 118.0, going to opposite ends of the field & talking to each other ground to ground? Have you tried substituting a different handheld hooked to your antenna at KOUN? I'm still betting on the tower having the problem, but obviously, that's a hard sell if you have arrogant jerks in the tower. If you test your radio against other radios on 118.0 & it works ok, I'd try going further up the food chain. I've read somewhere that the FAA now has a phone number that allows you to bypass the chain of authority & go straight to the top when you have unresolvable issues with local personnel. Sorry I can't offer the number because I haven't had need to use it lately. (I typically avoid controlled fields.) Charlie Steve Ruse wrote: > A little new information on this. To refresh everyone's memory, I have a handheld with a homemade external antenna (brass brazing rod on the bottom of the nose, with a ground plane). I have no problems whatsoever communicating air to air, even up to 125 miles, and I have flown into multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - 120.825, KDTO - 119.95, KADM - 118.5, and others). Everyone reports my signal as loud and clear, EXCEPT the tower at KOUN (118.0). > > This morning, I was flying out of KOUN again and got some new information that might be helpful. On the ground, they could hear me very clearly on 121.6. As soon as I switched to 118.0 though, they said my transmission was garbled and unreadable (still on the ground, nothing had changed but the frequency). > > So, I know I can transmit clearly on 118.3. However, apparently it is not so clear on 118.0. I can hear the tower clearly on 118.0. I've read that an antenna that receives well will also transmit well...this makes me think the antenna is probably good. Is it possible that the digital tuner on my handheld is not tuning correctly? I know, I need to get another handheld in the plane to see if I have the same problem. My radio is a three year old Vertex Standard VXA-150. > > Anyway, my primary question is, can anyone shed light on why I am not able to transmit clearly on 118.0? Where should I look first to try and solve this problem? I realize that 118.0 is at the very bottom of the aviation band, which made me think maybe my antenna length is off just slightly. I am going to measure that to verify. On that note, what is the exact length of the antenna with respect to the ground plane that I should measure? It is a brass rod sticking through an aluminum plate with nylon spacers as insulators. The brass rod sticks up above the ground plane about 1/2" or so on top. Could that small unshielded portion cause a problem, or is it too small to be a factor, and only the primary antenna length below the ground plane matters? > > Thanks for any help, > > Steve Ruse > ----- Original Message ----- > From: H. M. Haught Jr. > To: aeroelectric-list(at)matronics.com > Sent: Thursday, February 14, 2008 12:22 PM > Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? > > > Cordiality wasn't in evidence at KOUN. I was told in no uncertain terms that it wasn't their fault that my radio was junk, but they would give me light signals to get me out. I tried to explain that I've had the radio worked on a number of times and their facility was the only place I was having any trouble, which was true at the time, and got the reply - "If you want light signals to get out, then tell me, but don't blame our equipment for your radio problems." I was on a telephone talking to them from the service office - wouldn't see me face to face. They see lots of high power stuff and cater to it - my old ratty looking Pacer was consider "junk". I took the light signals and the radio was working fine by the time I got to the end of the taxiway. Called up OK City immediately after leaving the pattern, had radio check and was told "five x five". Next time I go in, (I've got my hand held set up on an external antenna as a backup radio ), as soon as I power down, I'm going to call up tower for radio check on the Icom, and then do the same thing with the handheld on rubber ducky antenna. Next day, if I have problems, I'll try the rubber ducky antenna again, as using the external antenna on the hand held also resulted in unreadable transmissions. Just doesn't make sense that two different radios are having the same problem on the same day. > > M. Haught > > > Greg Young wrote: > > I've called our tower a couple of times and found them to be very cordial > and very much interested to hear from pilots. If the chief/supv is not on > then ask for the controller in charge. It's amazing what you can learn and > what they are already aware of. I called about a "trainee" who after at > least a year on duty totally lost track of only 3 airplanes (I was one of > them) while working ground. Turns out that what everyone thought was a > trainee is a burn-out 2 weeks away from mandatory retirement. They were well > aware of the problem and keeping him on duties where he couldn't hurt > anyone. Yup, makes one proud of the system. > > Regards, > Greg Young > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com] On > Behalf Of glen matejcek > Sent: Thursday, February 14, 2008 7:39 AM > To: AeroElectric-List Digest Server > Subject: AeroElectric-List: RE: Why can't the tower hear me? > > --> > > Hi All- > > Sounds like perhaps it's time for phone calls to the tower > chief to make sure that he/she knows of the issue. If that > gets no results, a letter to the regional office. Make sure > to delineate all the steps you guys have taken to verify your > own equipment ops. > > You can also call them to let them on the phone to coordinate > a NORDO arrival. Just be sure to review the light gun > signals. Also, remember to keep you Piet under 200 KIAS ;-) > > As an aside, I've a good friend who is a controller who has > provided me with various insights. Included in those were > that although they can't upgrade equipment, they do get new > leather furniture. Makes one proud of the system. > > glen matejcek > aerobubba(at)earthlink.net > > > > > > > > Checked by AVG - http://www.avg.com > > > ________________________________________________________________________________
Date: Aug 02, 2008
Charlie, Thanks for the suggestions, those will definitely help narrow down the problem. My plane is based on a small grass strip, and I typically avoid towered fields too, but sometimes they are necessary. Unfortunately, the only one I have a problem with is right in my backyard. Thanks for the tips, I'll post again when I find something. Steve Ruse ----- Original Message ----- From: "Charlie England" <ceengland(at)bellsouth.net> Sent: Saturday, August 02, 2008 3:57 PM Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? > > > Do you have the same problem approaching KOUN from the air on 118.0? > > Have you tried air to air with a friend on 118.0 (far from KOUN)? > > Have you tried going to an uncontrolled field far away from KOUN with a > friend who's got a known-good radio on 118.0, going to opposite ends of > the field & talking to each other ground to ground? > > Have you tried substituting a different handheld hooked to your antenna at > KOUN? > > I'm still betting on the tower having the problem, but obviously, that's a > hard sell if you have arrogant jerks in the tower. > > If you test your radio against other radios on 118.0 & it works ok, I'd > try going further up the food chain. I've read somewhere that the FAA now > has a phone number that allows you to bypass the chain of authority & go > straight to the top when you have unresolvable issues with local > personnel. Sorry I can't offer the number because I haven't had need to > use it lately. (I typically avoid controlled fields.) > > Charlie > > Steve Ruse wrote: >> A little new information on this. To refresh everyone's memory, I have a >> handheld with a homemade external antenna (brass brazing rod on the >> bottom of the nose, with a ground plane). I have no problems whatsoever >> communicating air to air, even up to 125 miles, and I have flown into >> multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - >> 120.825, KDTO - 119.95, KADM - 118.5, and others). Everyone reports my >> signal as loud and clear, EXCEPT the tower at KOUN (118.0). >> >> This morning, I was flying out of KOUN again and got some new information >> that might be helpful. On the ground, they could hear me very clearly on >> 121.6. As soon as I switched to 118.0 though, they said my transmission >> was garbled and unreadable (still on the ground, nothing had changed but >> the frequency). >> >> So, I know I can transmit clearly on 118.3. However, apparently it is >> not so clear on 118.0. I can hear the tower clearly on 118.0. I've read >> that an antenna that receives well will also transmit well...this makes >> me think the antenna is probably good. Is it possible that the digital >> tuner on my handheld is not tuning correctly? I know, I need to get >> another handheld in the plane to see if I have the same problem. My >> radio is a three year old Vertex Standard VXA-150. >> >> Anyway, my primary question is, can anyone shed light on why I am not >> able to transmit clearly on 118.0? Where should I look first to try and >> solve this problem? I realize that 118.0 is at the very bottom of the >> aviation band, which made me think maybe my antenna length is off just >> slightly. I am going to measure that to verify. On that note, what is >> the exact length of the antenna with respect to the ground plane that I >> should measure? It is a brass rod sticking through an aluminum plate >> with nylon spacers as insulators. The brass rod sticks up above the >> ground plane about 1/2" or so on top. Could that small unshielded >> portion cause a problem, or is it too small to be a factor, and only the >> primary antenna length below the ground plane matters? >> >> Thanks for any help, >> >> Steve Ruse >> ----- Original Message ----- >> From: H. M. Haught Jr. To: aeroelectric-list(at)matronics.com Sent: >> Thursday, February 14, 2008 12:22 PM >> Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? >> >> >> Cordiality wasn't in evidence at KOUN. I was told in no uncertain >> terms that it wasn't their fault that my radio was junk, but they would >> give me light signals to get me out. I tried to explain that I've had >> the radio worked on a number of times and their facility was the only >> place I was having any trouble, which was true at the time, and got the >> reply - "If you want light signals to get out, then tell me, but don't >> blame our equipment for your radio problems." I was on a telephone >> talking to them from the service office - wouldn't see me face to face. >> They see lots of high power stuff and cater to it - my old ratty looking >> Pacer was consider "junk". I took the light signals and the radio was >> working fine by the time I got to the end of the taxiway. Called up OK >> City immediately after leaving the pattern, had radio check and was told >> "five x five". Next time I go in, (I've got my hand held set up on an >> external antenna as a backup radio ), as soon as I power down! > , I'm going to call up tower for radio check on the Icom, and then do the > same thing with the handheld on rubber ducky antenna. Next day, if I have > problems, I'll try the rubber ducky antenna again, as using the external > antenna on the hand held also resulted in unreadable transmissions. Just > doesn't make sense that two different radios are having the same problem > on the same day. >> >> M. Haught >> >> <gyoung@cs-sol.com> >> >> I've called our tower a couple of times and found them to be very cordial >> and very much interested to hear from pilots. If the chief/supv is not on >> then ask for the controller in charge. It's amazing what you can learn >> and >> what they are already aware of. I called about a "trainee" who after at >> least a year on duty totally lost track of only 3 airplanes (I was one of >> them) while working ground. Turns out that what everyone thought was a >> trainee is a burn-out 2 weeks away from mandatory retirement. They were >> well >> aware of the problem and keeping him on duties where he couldn't hurt >> anyone. Yup, makes one proud of the system. >> >> Regards, >> Greg Young >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of glen >> matejcek >> Sent: Thursday, February 14, 2008 7:39 AM >> To: AeroElectric-List Digest Server >> Subject: AeroElectric-List: RE: Why can't the tower hear me? >> >> >> >> Hi All- >> >> Sounds like perhaps it's time for phone calls to the tower chief to make >> sure that he/she knows of the issue. If that gets no results, a letter >> to the regional office. Make sure to delineate all the steps you guys >> have taken to verify your own equipment ops. >> You can also call them to let them on the phone to coordinate a NORDO >> arrival. Just be sure to review the light gun signals. Also, remember >> to keep you Piet under 200 KIAS ;-) >> >> As an aside, I've a good friend who is a controller who has provided me >> with various insights. Included in those were that although they can't >> upgrade equipment, they do get new leather furniture. Makes one proud of >> the system. >> >> glen matejcek >> aerobubba(at)earthlink.net >> >> >> >> >> >> >> >> >> >> >> >> >> Checked by AVG - http://www.avg.com >> >> > > > ________________________________________________________________________________
Date: Aug 03, 2008
I just plugged in my handheld vertex into the extra antenna on my glastar - over Austin. Received the usual spark plugs ignition noise my Apollo GX65 hears; but when the approach transmitted, the intermodulation on the vertex was terrible. Vertex is Yaesu I believe, and my 2 meter ham radio goes nuts in certain parts of Houston (we call it RF alley) on I-59- so - intermod, usually affects received signals, but who knows maybe in these "cheap" little radios, other equipment on the field might also affect it. Do you have anything else "on" in the plane? I'd say it is not the antenna. best advice, you have already been given - test it with another plane or two on that frequency, and confirm it is okay before you get into it with the FAA. I do believe they have the worst radios on the aviation band however. I always have to turn the squelch "off" to hear them in my glastar - but the garmin in my 500B receives them well. bobf W5RF On Sat, Aug 2, 2008 at 3:02 PM, Steve Ruse wrote: > A little new information on this. To refresh everyone's memory, I have a > handheld with a homemade external antenna (brass brazing rod on the bottom > of the nose, with a ground plane). I have no problems whatsoever > communicating air to air, even up to 125 miles, and I have flown into > multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - 120.825, > KDTO - 119.95, KADM - 118.5, and others). Everyone reports my signal as > loud and clear, EXCEPT the tower at KOUN (118.0). > > This morning, I was flying out of KOUN again and got some new information > that might be helpful. On the ground, they could hear me very clearly on > 121.6. As soon as I switched to 118.0 though, they said my transmission was > garbled and unreadable (still on the ground, nothing had changed but the > frequency). > > So, I know I can transmit clearly on 118.3. However, apparently it is not > so clear on 118.0. I can hear the tower clearly on 118.0. I've read that > an antenna that receives well will also transmit well...this makes me think > the antenna is probably good. Is it possible that the digital tuner on my > handheld is not tuning correctly? I know, I need to get another handheld in > the plane to see if I have the same problem. My radio is a three year old > Vertex Standard VXA-150. > > Anyway, my primary question is, can anyone shed light on why I am not able > to transmit clearly on 118.0? Where should I look first to try and solve > this problem? I realize that 118.0 is at the very bottom of the aviation > band, which made me think maybe my antenna length is off just slightly. I > am going to measure that to verify. On that note, what is the exact length > of the antenna with respect to the ground plane that I should measure? It > is a brass rod sticking through an aluminum plate with nylon spacers as > insulators. The brass rod sticks up above the ground plane about 1/2" or so > on top. Could that small unshielded portion cause a problem, or is it too > small to be a factor, and only the primary antenna length below the ground > plane matters? > > Thanks for any help, > > Steve Ruse > > ----- Original Message ----- > *From:* H. M. Haught Jr. > *To:* aeroelectric-list(at)matronics.com > *Sent:* Thursday, February 14, 2008 12:22 PM > *Subject:* Re: AeroElectric-List: RE: Why can't the tower hear me? > > Cordiality wasn't in evidence at KOUN. I was told in no uncertain terms > that it wasn't their fault that my radio was junk, but they would give me > light signals to get me out. I tried to explain that I've had the radio > worked on a number of times and their facility was the only place I was > having any trouble, which was true at the time, and got the reply - "If you > want light signals to get out, then tell me, but don't blame our equipment > for your radio problems." I was on a telephone talking to them from the > service office - wouldn't see me face to face. They see lots of high power > stuff and cater to it - my old ratty looking Pacer was consider "junk". I > took the light signals and the radio was working fine by the time I got to > the end of the taxiway. Called up OK City immediately after leaving the > pattern, had radio check and was told "five x five". Next time I go in, > (I've got my hand held set up on an external antenna as a backup radio ), as > soon as I power down, I'm going to call up tower for radio check on the > Icom, and then do the same thing with the handheld on rubber ducky antenna. > Next day, if I have problems, I'll try the rubber ducky antenna again, as > using the external antenna on the hand held also resulted in unreadable > transmissions. Just doesn't make sense that two different radios are having > the same problem on the same day. > > M. Haught > > > Greg Young wrote: > > > I've called our tower a couple of times and found them to be very cordial > and very much interested to hear from pilots. If the chief/supv is not on > then ask for the controller in charge. It's amazing what you can learn and > what they are already aware of. I called about a "trainee" who after at > least a year on duty totally lost track of only 3 airplanes (I was one of > them) while working ground. Turns out that what everyone thought was a > trainee is a burn-out 2 weeks away from mandatory retirement. They were well > aware of the problem and keeping him on duties where he couldn't hurt > anyone. Yup, makes one proud of the system. > > Regards, > Greg Young > > > -----Original Message----- > From: owner-aeroelectric-list-server(at)matronics.com > [mailto:owner-aeroelectric-list-server(at)matronics.com ] On > Behalf Of glen matejcek > Sent: Thursday, February 14, 2008 7:39 AM > To: AeroElectric-List Digest Server > Subject: AeroElectric-List: RE: Why can't the tower hear me? > > --> > > Hi All- > > Sounds like perhaps it's time for phone calls to the tower > chief to make sure that he/she knows of the issue. If that > gets no results, a letter to the regional office. Make sure > to delineate all the steps you guys have taken to verify your > own equipment ops. > > You can also call them to let them on the phone to coordinate > a NORDO arrival. Just be sure to review the light gun > signals. Also, remember to keep you Piet under 200 KIAS ;-) > > As an aside, I've a good friend who is a controller who has > provided me with various insights. Included in those were > that although they can't upgrade equipment, they do get new > leather furniture. Makes one proud of the system. > > glen matejcekaerobubba(at)earthlink.net > > > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
From: "Bill Bradburry" <bbradburry(at)bellsouth.net>
Subject: Broken Low Voltage Module
Date: Aug 03, 2008
Hi Bob, I don't know if you missed my last inquiry, but I haven't seen a response. You were going to pot the back of the low voltage module and send it back. That has been several weeks and I have not seen it as yet. Did you send it? If so, it must be lost in the mail. Let me know. I would like to reinstall it and check my plane wiring to see if I can determine the problem. Thanks for your help. Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill Bradburry Sent: Friday, July 25, 2008 1:29 PM Subject: RE: AeroElectric-List: Broken Low Voltage Module --> Bob, I was out of town for three weeks and thought that I would find the board in my mail when I returned, but it was not there. Did you manage to get it out?? Thanks, Bill B -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III Sent: Sunday, July 06, 2008 2:00 PM Subject: RE: AeroElectric-List: Broken Low Voltage Module --> > > >Hi Bob. > >Have you had a chance to take a look at my low voltage module yet? > >Bill B Yes. Aside from more corrosion than I would like to see, both the instrument and ECB are functional as advertised. I've cleaned the board and plan to conformal coat before I return them. Leaving for ML in a few hours but will be back in shop Wednesday. I can probably get it out then. What ever difficulties you're experiencing must be in ship's wiring. Bob . . . >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Bill >Bradburry >Sent: Tuesday, June 17, 2008 1:29 PM >To: aeroelectric-list(at)matronics.com >Subject: RE: AeroElectric-List: Broken Low Voltage Module > >--> > >Great! >Thanks Bob! > >Bill B > >-----Original Message----- >From: owner-aeroelectric-list-server(at)matronics.com >[mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of >Robert L. >Nuckolls, III >Sent: Tuesday, June 17, 2008 11:55 AM >To: aeroelectric-list(at)matronics.com >Subject: Re: AeroElectric-List: Broken Low Voltage Module > >--> > > > > > > >Bob, > >I sent the board in a couple of weeks ago. It should have been > >waiting for you when you returned from your vacation to California. > >I never heard if you found it ok. > > > >Have you had a chance to take a look at it, and if so, what did you > >discover? > > > >Bill B > > It's laying on the desk right in front of me. I was thinking > this morning that I could probably get to it this evening. > I've been on travel quite a bit but there's a breathing spell > coming up. > > Bob . . . > > >Checked by AVG - http://www.avg.com >5:26 AM Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 03, 2008
My plane actually has no engine driven electrical system, just a 12v battery that runs the radio, intercom and GPS. My wires are all shielded (including plug wires), and the plane has almost no electronics so noise sources are minimal. Today, I did another test that sheds a lot of light on the situation. >From 2,500', I called the tower from less than 6 miles out. My friend in his plane a few miles away reported that he could hear me loud and clear, but the tower said I was garbled and unreadable. To me, that indicates that some combination of factors between my radio and theirs is causing problems. At what point should I try to address it with them? I doubt they will care about my problem if no one else is having problems. Thanks for any tips. Steve Ruse ----- Original Message ----- From: Robert Feldtman To: aeroelectric-list(at)matronics.com Sent: Sunday, August 03, 2008 12:29 PM Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? I just plugged in my handheld vertex into the extra antenna on my glastar - over Austin. Received the usual spark plugs ignition noise my Apollo GX65 hears; but when the approach transmitted, the intermodulation on the vertex was terrible. Vertex is Yaesu I believe, and my 2 meter ham radio goes nuts in certain parts of Houston (we call it RF alley) on I-59- so - intermod, usually affects received signals, but who knows maybe in these "cheap" little radios, other equipment on the field might also affect it. Do you have anything else "on" in the plane? I'd say it is not the antenna. best advice, you have already been given - test it with another plane or two on that frequency, and confirm it is okay before you get into it with the FAA. I do believe they have the worst radios on the aviation band however. I always have to turn the squelch "off" to hear them in my glastar - but the garmin in my 500B receives them well. bobf W5RF On Sat, Aug 2, 2008 at 3:02 PM, Steve Ruse wrote: A little new information on this. To refresh everyone's memory, I have a handheld with a homemade external antenna (brass brazing rod on the bottom of the nose, with a ground plane). I have no problems whatsoever communicating air to air, even up to 125 miles, and I have flown into multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - 120.825, KDTO - 119.95, KADM - 118.5, and others). Everyone reports my signal as loud and clear, EXCEPT the tower at KOUN (118.0). This morning, I was flying out of KOUN again and got some new information that might be helpful. On the ground, they could hear me very clearly on 121.6. As soon as I switched to 118.0 though, they said my transmission was garbled and unreadable (still on the ground, nothing had changed but the frequency). So, I know I can transmit clearly on 118.3. However, apparently it is not so clear on 118.0. I can hear the tower clearly on 118.0. I've read that an antenna that receives well will also transmit well...this makes me think the antenna is probably good. Is it possible that the digital tuner on my handheld is not tuning correctly? I know, I need to get another handheld in the plane to see if I have the same problem. My radio is a three year old Vertex Standard VXA-150. Anyway, my primary question is, can anyone shed light on why I am not able to transmit clearly on 118.0? Where should I look first to try and solve this problem? I realize that 118.0 is at the very bottom of the aviation band, which made me think maybe my antenna length is off just slightly. I am going to measure that to verify. On that note, what is the exact length of the antenna with respect to the ground plane that I should measure? It is a brass rod sticking through an aluminum plate with nylon spacers as insulators. The brass rod sticks up above the ground plane about 1/2" or so on top. Could that small unshielded portion cause a problem, or is it too small to be a factor, and only the primary antenna length below the ground plane matters? Thanks for any help, Steve Ruse ----- Original Message ----- From: H. M. Haught Jr. To: aeroelectric-list(at)matronics.com Sent: Thursday, February 14, 2008 12:22 PM Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? Cordiality wasn't in evidence at KOUN. I was told in no uncertain terms that it wasn't their fault that my radio was junk, but they would give me light signals to get me out. I tried to explain that I've had the radio worked on a number of times and their facility was the only place I was having any trouble, which was true at the time, and got the reply - "If you want light signals to get out, then tell me, but don't blame our equipment for your radio problems." I was on a telephone talking to them from the service office - wouldn't see me face to face. They see lots of high power stuff and cater to it - my old ratty looking Pacer was consider "junk". I took the light signals and the radio was working fine by the time I got to the end of the taxiway. Called up OK City immediately after leaving the pattern, had radio check and was told "five x five". Next time I go in, (I've got my hand held set up on an external antenna as a backup radio ), as soon as I power down, I'm going to call up tower for radio check on the Icom, and then do the same thing with the handheld on rubber ducky antenna. Next day, if I have problems, I'll try the rubber ducky antenna again, as using the external antenna on the hand held also resulted in unreadable transmissions. Just doesn't make sense that two different radios are having the same problem on the same day. M. Haught Greg Young wrote: <gyoung@cs-sol.com> I've called our tower a couple of times and found them to be very cordial and very much interested to hear from pilots. If the chief/supv is not on then ask for the controller in charge. It's amazing what you can learn and what they are already aware of. I called about a "trainee" who after at least a year on duty totally lost track of only 3 airplanes (I was one of them) while working ground. Turns out that what everyone thought was a trainee is a burn-out 2 weeks away from mandatory retirement. They were well aware of the problem and keeping him on duties where he couldn't hurt anyone. Yup, makes one proud of the system. Regards, Greg Young -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of glen matejcek Sent: Thursday, February 14, 2008 7:39 AM Subject: AeroElectric-List: RE: Why can't the tower hear me? --> Hi All- Sounds like perhaps it's time for phone calls to the tower chief to make sure that he/she knows of the issue. If that gets no results, a letter to the regional office. Make sure to delineate all the steps you guys have taken to verify your own equipment ops. You can also call them to let them on the phone to coordinate a NORDO arrival. Just be sure to review the light gun signals. Also, remember to keep you Piet under 200 KIAS ;-) As an aside, I've a good friend who is a controller who has provided me with various insights. Included in those were that although they can't upgrade equipment, they do get new leather furniture. Makes one proud of the system. glen matejcek aerobubba(at)earthlink.net href="http://www.matronics.com/Navigator?AeroElectric-List">http://www. matronics.com/Navigator?AeroElectric-List href="http://forums.matronics.com">http://forums.matronics.com href="http://www.matronics.com/contribution">http://www.matronics.com/c ________________________________________________________________________________
Date: Aug 03, 2008
sounds like it is the tower's receiver. bobf On Sun, Aug 3, 2008 at 9:26 PM, Steve Ruse wrote: > My plane actually has no engine driven electrical system, just a 12v > battery that runs the radio, intercom and GPS. My wires are all shielded > (including plug wires), and the plane has almost no electronics so noise > sources are minimal. > > Today, I did another test that sheds a lot of light on the situation. From > 2,500', I called the tower from less than 6 miles out. My friend in his > plane a few miles away reported that he could hear me loud and clear, but > the tower said I was garbled and unreadable. To me, that indicates that > some combination of factors between my radio and theirs is causing > problems. At what point should I try to address it with them? I doubt they > will care about my problem if no one else is having problems. > > Thanks for any tips. > > Steve Ruse > > ----- Original Message ----- > *From:* Robert Feldtman > *To:* aeroelectric-list(at)matronics.com > *Sent:* Sunday, August 03, 2008 12:29 PM > *Subject:* Re: AeroElectric-List: RE: Why can't the tower hear me? > > I just plugged in my handheld vertex into the extra antenna on my glastar - > over Austin. Received the usual spark plugs ignition noise my Apollo GX65 > hears; but when the approach transmitted, the intermodulation on the vertex > was terrible. Vertex is Yaesu I believe, and my 2 meter ham radio goes nuts > in certain parts of Houston (we call it RF alley) on I-59- so - intermod, > usually affects received signals, but who knows maybe in these "cheap" > little radios, other equipment on the field might also affect it. Do you > have anything else "on" in the plane? I'd say it is not the antenna. best > advice, you have already been given - test it with another plane or two on > that frequency, and confirm it is okay before you get into it with the FAA. > I do believe they have the worst radios on the aviation band however. I > always have to turn the squelch "off" to hear them in my glastar - but the > garmin in my 500B receives them well. > bobf > W5RF > > On Sat, Aug 2, 2008 at 3:02 PM, Steve Ruse wrote: > >> A little new information on this. To refresh everyone's memory, I have >> a handheld with a homemade external antenna (brass brazing rod on the bottom >> of the nose, with a ground plane). I have no problems whatsoever >> communicating air to air, even up to 125 miles, and I have flown into >> multiple class D areas with no trouble at all (KFTW - 118.3, KAFW - 120.825, >> KDTO - 119.95, KADM - 118.5, and others). Everyone reports my signal as >> loud and clear, EXCEPT the tower at KOUN (118.0). >> >> This morning, I was flying out of KOUN again and got some new information >> that might be helpful. On the ground, they could hear me very clearly on >> 121.6. As soon as I switched to 118.0 though, they said my transmission was >> garbled and unreadable (still on the ground, nothing had changed but the >> frequency). >> >> So, I know I can transmit clearly on 118.3. However, apparently it is not >> so clear on 118.0. I can hear the tower clearly on 118.0. I've read that >> an antenna that receives well will also transmit well...this makes me think >> the antenna is probably good. Is it possible that the digital tuner on my >> handheld is not tuning correctly? I know, I need to get another handheld in >> the plane to see if I have the same problem. My radio is a three year old >> Vertex Standard VXA-150. >> >> Anyway, my primary question is, can anyone shed light on why I am not able >> to transmit clearly on 118.0? Where should I look first to try and solve >> this problem? I realize that 118.0 is at the very bottom of the aviation >> band, which made me think maybe my antenna length is off just slightly. I >> am going to measure that to verify. On that note, what is the exact length >> of the antenna with respect to the ground plane that I should measure? It >> is a brass rod sticking through an aluminum plate with nylon spacers as >> insulators. The brass rod sticks up above the ground plane about 1/2" or so >> on top. Could that small unshielded portion cause a problem, or is it too >> small to be a factor, and only the primary antenna length below the ground >> plane matters? >> >> Thanks for any help, >> >> Steve Ruse >> >> ----- Original Message ----- >> *From:* H. M. Haught Jr. >> *To:* aeroelectric-list(at)matronics.com >> *Sent:* Thursday, February 14, 2008 12:22 PM >> *Subject:* Re: AeroElectric-List: RE: Why can't the tower hear me? >> >> Cordiality wasn't in evidence at KOUN. I was told in no uncertain terms >> that it wasn't their fault that my radio was junk, but they would give me >> light signals to get me out. I tried to explain that I've had the radio >> worked on a number of times and their facility was the only place I was >> having any trouble, which was true at the time, and got the reply - "If you >> want light signals to get out, then tell me, but don't blame our equipment >> for your radio problems." I was on a telephone talking to them from the >> service office - wouldn't see me face to face. They see lots of high power >> stuff and cater to it - my old ratty looking Pacer was consider "junk". I >> took the light signals and the radio was working fine by the time I got to >> the end of the taxiway. Called up OK City immediately after leaving the >> pattern, had radio check and was told "five x five". Next time I go in, >> (I've got my hand held set up on an external antenna as a backup radio ), as >> soon as I power down, I'm going to call up tower for radio check on the >> Icom, and then do the same thing with the handheld on rubber ducky antenna. >> Next day, if I have problems, I'll try the rubber ducky antenna again, as >> using the external antenna on the hand held also resulted in unreadable >> transmissions. Just doesn't make sense that two different radios are having >> the same problem on the same day. >> >> M. Haught >> >> >> Greg Young wrote: >> >> >> I've called our tower a couple of times and found them to be very cordial >> and very much interested to hear from pilots. If the chief/supv is not on >> then ask for the controller in charge. It's amazing what you can learn and >> what they are already aware of. I called about a "trainee" who after at >> least a year on duty totally lost track of only 3 airplanes (I was one of >> them) while working ground. Turns out that what everyone thought was a >> trainee is a burn-out 2 weeks away from mandatory retirement. They were well >> aware of the problem and keeping him on duties where he couldn't hurt >> anyone. Yup, makes one proud of the system. >> >> Regards, >> Greg Young >> >> >> >> >> -----Original Message----- >> From: owner-aeroelectric-list-server(at)matronics.com >> [mailto:owner-aeroelectric-list-server(at)matronics.com ] On >> Behalf Of glen matejcek >> Sent: Thursday, February 14, 2008 7:39 AM >> To: AeroElectric-List Digest Server >> Subject: AeroElectric-List: RE: Why can't the tower hear me? >> >> --> >> >> Hi All- >> >> Sounds like perhaps it's time for phone calls to the tower >> chief to make sure that he/she knows of the issue. If that >> gets no results, a letter to the regional office. Make sure >> to delineate all the steps you guys have taken to verify your >> own equipment ops. >> >> You can also call them to let them on the phone to coordinate >> a NORDO arrival. Just be sure to review the light gun >> signals. Also, remember to keep you Piet under 200 KIAS ;-) >> >> As an aside, I've a good friend who is a controller who has >> provided me with various insights. Included in those were >> that although they can't upgrade equipment, they do get new >> leather furniture. Makes one proud of the system. >> >> glen matejcekaerobubba(at)earthlink.net >> >> >> * >> >> href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List >> href="http://forums.matronics.com">http://forums.matronics.com >> href="http://www.matronics.com/contribution">http://www.matronics.com/c* >> >> * >> >> * >> >> > * > > href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List > href="http://forums.matronics.com">http://forums.matronics.com > href="http://www.matronics.com/contribution">http://www.matronics.com/c* > > * > > * > > ________________________________________________________________________________
Date: Aug 04, 2008
No engine driven alternator or generator? How do you keep the battery charg ed? Dale Ensing ----- Original Message ----- From: Steve Ruse To: aeroelectric-list(at)matronics.com Sent: Sunday, August 03, 2008 10:26 PM Subject: Re: AeroElectric-List: RE: Why can't the tower hear me? My plane actually has no engine driven electrical system, just a 12v batt ery that runs the radio, intercom and GPS. My wires are all shielded (incl uding plug wires), and the plane has almost no electronics so noise sources are minimal. ________________________________________________________________________________
Date: Aug 04, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
>My plane actually has no engine driven electrical system, just a 12v >battery that runs the radio, intercom and GPS. My wires are all shielded >(including plug wires), and the plane has almost no electronics so noise >sources are minimal. > >Today, I did another test that sheds a lot of light on the >situation. From 2,500', I called the tower from less than 6 miles >out. My friend in his plane a few miles away reported that he could hear >me loud and clear, but the tower said I was garbled and unreadable. To >me, that indicates that some combination of factors between my radio and >theirs is causing problems. At what point should I try to address it with >them? I doubt they will care about my problem if no one else is having >problems. It's been suggested that you try another hand-held on the same antenna. Also, while still on the field you might try using the "rubber-ducky" antenna that comes with the radio. It would also be interesting to have a friend visit the tower (a gray-haired ol' ham operator that used to build his own stuff would be good) and see what your signal sounds like to him while you switch between the rubber duck, the ship's antenna and perhaps even another hand-held on its own rubber duck and the ship's antenna. I recall a trip to the practice area early one morning before I got my ticket. Some guy in a Pacer called the tower and was truly garbled to the point that I could barely understand him in the airplane. However, the tower guys could understand him better than I could from the quieter tower cab . . . they handled him like any other traffic. I was amazed that they did not at least suggest he have his radio looked at (I'll bet his REAL carbon mic was going bad). By the time I got back from the practice area, the guy had refueled and gone or I would have approached him. In fact, I cannot recall any time hearing a traffic controller complain about signals that I thought sucked for air. It's only when the pilot specifically asked about his radio that anyone offered much of an opinion and for the most part, controllers were exceedingly generous in their assessments. Years ago it was not uncommon for a multi-channel radio to have problems on every tenth step in the progression of frequency selections when one frequency control crystal of several dozen had gone bad. Modern radios use one crystal to stabilize a digital frequency synthesizer so if one frequency is off, ALL frequencies are off too. A quick check of your radio against a counter would be good. Any two-way radio shop in your area could do this test in about ten seconds. It's just possible that someone in the tower has a "thing" for you or your homebuilt . . . I've come to understand that the bell-curve is a fact of nature . . . it cannot be ignored. For every Mother Theresa there's GOT to be a Saddam Hussein. The best way to resolve the true nature of your difficulties is to get a third party involved . . . someone experienced in judging the quality of radio signals. If your third party approaches the tower folks with the notion that you need to conduct an experiment to resolve a problem they'd be hard pressed not to cooperate. Do a double-blind study of the four conditions I suggested above with your radio and one other radio and two different antennas. Just speak to condition A, B, C and D without letting anyone at the other end know what the details of any particular condition. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2008
>Okay, I spent a little time poking around with the harness that came with >the regulator - high output alternator and attached is what I found, does >this help at all ? or just ask more questions ? >It looks like I and A are tied together from the main output terminal of the >alternator ! > >NOTE: the relay CAME with the harness and I am told the on off for the relay >is from the ignition circuit or switch. It appears that your regulator came with a companion alternator. It also appears that the previous installer went inside the alternator to ADD a leadwire for the "S" terminal. Most of regulators with the I, A, S, F terminal sets run well when wired as shown for the "ford" regulator in Z-11. For your installation, the wire off the relay would go to directly to your field supply breaker or fuse. The wire to "+12v ignition" would go to the downstream side of the alternator control switch. See: http://www.aeroelectric.com/_temp/Skiba_VR1200_Wiring.jpg >My main concern is why they took power into I and A from the main output of >the alternator with no fuse or wire protection ? and how do I tie this into >the Z figures?? In the good old days, the "I" terminal was an open collector, transistor pull-down that would not tolerate being wired as shown. If the bus was hot and the engine not running, then the "I" terminal current expecting to illuminate a bulb would be too high and the transistor would be damaged. It may be that modern equivalents of this design >Same as below ? >This unit is suppose to have OV protection and all that so No crow bar is >required. It would be interesting to know the details of the advertised OV protection. Many automotive devices where I've been privileged to see real schematics offered only OV warning by lighting the fault light. It did not shut down the regulator. Further, if the failure was due to some fault on the regulator chip itself, most design goals would be wary of letting a chip monitor itself. Unfortunately, the folks who sell these devices tend to be cognizant only of those words that are offered on the advertising literature and installation instructions. So, if the data say "OV protected" what else would you want to know? I'd like to see the schematics before I hung my hat on their OV protection peg. There are dozens of independent, OV protection devices for alternators who's design goals are quite clear and their functionality assured. I don't know enough about the V1200 to offer any advice one way or another. In any case, wired as shown in the drawing cited above should get it up and running. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Article from AOPA on Glass EFIS failures
Article worth forwarding to this list from AOPA - - July 30, 2008 by Bruce Landsberg , AOPA Safety blog The old joke about the fully automated airliner with no flight crew --jus t an automated cabin announcement that misfires --seems prophetic with la st week=92s NTSB announcement about massive display failure on Airbus aircr aft. There were 49 failures on Airbus 319 and 320 aircraft including seven incidents where all six screens failed simultaneously. Didn=92t think that was possible? Neither did the manufacturer, the FAA or the NTSB. As light GA manufacturers rush into glass cockpits, is it unseemly to ask w hat assurance we have that there will not be a catastrophic failure or at l east a significant failure in our less robust systems? Several years ago I had the privilege of getting a demo in one of the early all-glass light air craft which suffered a total flight display meltdown. It wasn=92t an issue since we were in good VFR and there were backup instruments. Still, this is n=92t what=92s supposed to happen. After one flies enough and sees enough equipment break - some of it harmles sly and some of it at the least opportune time --a sense of caution or pe rhaps cynicism sets in. Duplication of hardware on critical things like com m, nav and flight displays means less fancy footwork on the pilot=92s part when something goes south. I suspect the record keeping on Part 91 flights flown in light aircraft whe n a flight display dies is not very accurate, even though NTSB Part 830 req uires, somewhat vaguely, pilots to report the in-flight failure of electric al systems that require =93sustained use of =85.backup power to =85retain f light control or essential instruments.=94 Has anybody had, or know of someone who had, a major glass malfunction and did it get reported and to whom? The purpose is not to rat out the manufact urers but to insure that weak points get fixed before someone is hurt. Bruce Landsberg Executive Director, AOPA Air Safety Foundation - - "One of the great mistakes is to judge policies and programs - by their intentions rather than their results."- -Milton Friedman - -=0A=0A=0A ________________________________________________________________________________
Date: Aug 04, 2008
Date: Aug 04, 2008
Subject: Re: Article from AOPA on Glass EFIS failures
>Article worth forwarding to this list from AOPA > > >July 30, 2008 by Bruce Landsberg , AOPA Safety blog= o ns = "urn:schemas-microsoft-com:office:office" /> >The old joke about the fully automated airliner with no flight crew - just >an automated cabin announcement that misfires - seems prophetic with last >week's NTSB announcement about massive display failure on Airbus aircraft. >There were 49 failures on Airbus 319 and 320 aircraft including seven >incidents where all six screens failed simultaneously. Didn't think that >was possible? Neither did the manufacturer, the FAA or the NTSB. > >"One of the great mistakes is to judge policies and programs > by their intentions rather than their results." -Milton Friedman You betcha! Has anyone found further discussions of these events on the Airbus? I spent about 30 minutes searching the web . . . turned up a number of items dealing with EFIS (or electrical system) failures on various ATP class aircraft . . . but nothing that speaks to what might be called an epidemic of failures aboard the Airbus. I'm having trouble visualizing the lack of attention to system design that produces gross failures of flight deck systems. I cannot imagine folks who designed the A319/320 were so lacking in due diligence. How do these tales affect the OBAM aircraft community? I'll suggest no more than ANY story of gross systems failure aboard ANY vehicle. If it's important that failures do not propagate across multiple systems, then it's generally not difficult to make sure this doesn't happen. I think I've mentioned this before . . . but if I were building an airplane intended to spend a lot of time in the clouds, I'd take advantage of the low cost, GPS aided wing levelers and install TWO . . . each driven by its own GPS engine (they're under $30 now). Further, I'd make sure that each system was powered separately. If you have even one of these devices working (along with alt and a/s) there is nothing ATC asks you to do that cannot be accomplished with no other instrumentation at all while you maneuver to VMC somewhere. As many of you have already decided, there are back-up steam gages to your "non certified" glass displays. We've discussed separation of duties between various energy sources -AND- loads that are exceedingly useful when you can't see the ground. I'm still pained by narratives from incident investigations where a single failure (perhaps combined with mis-positioning of controls by crew) caused a cascade of failures or shutdowns in otherwise perfectly good systems. Z-14 is but one example of a way that one can build a firewall between a catastrophic electrical event and the total suite of necessary equipment items. Z-13/8 is a two-layer electrical system that offers excellent robustness in the face of certain failures. There's a difference between how the TC side of the house thinks and how we are permitted to think when it comes to failure management. They bust their butts striving for MTBF and reliability tree numbers that would make King Midas envious. We're allowed to consider that EVERY part in the system is going to quit at some point in time. If it quits because we ignored simple preventative maintenance duties and wore the thing out, then a pox on OUR house. If we REALLY want it to work, it FAILS for unanticipated issues and we didn't have a Plan-B . . . then it matters not whether the thing had a 1,000 or 1,000,000 hour MTBF number. Anyone who places any degree of faith in the published reliability numbers for the purpose of keeping his underwear dry has been poorly taught or wasn't paying attention. I don't intend to diminish the significance of anyone's difficulties in the cockpit . . . especially those responsible for hundreds of lives. I ride behind a crew of those folks with some frequency. At the same time, let us not assign significance to the miseries handed down to our brothers by a regulatory process that runs smoother on intentions than upon cold logic. By virtue of understanding you've acquired one can craft and meet design goals that put you light-years away from the probability of experiencing an electrical system event that ruins your day. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Charging a low battery
I think this has been discussed before, but I vaguely remember. Why doesn't my truck blow the 30a fuse when I use it to charge my nearly dead trailer batteries (less than 9v)? I have had to do this several times and I just connect the truck to the trailer up start the engine and rev it up. No ill effects to report and the fuse did not fail. The truck has a 110a alternator and 2 size 65 batteries (diesel). During this charging I see 13.8v or so on the cigar lighter plug. Thanks, Paul ________________________________________________________________________________
Date: Aug 04, 2008
The three letters "EMP" should strike fear in our flying (and driving) hearts - I know, very remote, but some in the govt are planning for it. bobf On 8/4/08, Robert L. Nuckolls, III wrote: > > nuckolls.bob(at)cox.net> > > >> Article worth forwarding to this list from AOPA >> >> >> >> July 30, 2008 by Bruce Landsberg , AOPA Safety blog> = o ns = "urn:schemas-microsoft-com:office:office" /> >> The old joke about the fully automated airliner with no flight crew - just >> an automated cabin announcement that misfires - seems prophetic with last >> week's NTSB announcement about massive display failure on Airbus aircraft. >> There were 49 failures on Airbus 319 and 320 aircraft including seven >> incidents where all six screens failed simultaneously. Didn't think that was >> possible? Neither did the manufacturer, the FAA or the NTSB. >> > > > >> >> "One of the great mistakes is to judge policies and programs >> by their intentions rather than their results." -Milton Friedman >> > > You betcha! > > Has anyone found further discussions of these events on the Airbus? > I spent about 30 minutes searching the web . . . turned up a number > of items dealing with EFIS (or electrical system) failures on > various ATP class aircraft . . . but nothing that speaks to what > might be called an epidemic of failures aboard the Airbus. > > I'm having trouble visualizing the lack of attention to system > design that produces gross failures of flight deck systems. > I cannot imagine folks who designed the A319/320 were so lacking > in due diligence. > > How do these tales affect the OBAM aircraft community? > I'll suggest no more than ANY story of gross systems failure > aboard ANY vehicle. If it's important that failures do not > propagate across multiple systems, then it's generally not > difficult to make sure this doesn't happen. > > I think I've mentioned this before . . . but if I were > building an airplane intended to spend a lot of time in > the clouds, I'd take advantage of the low cost, GPS aided > wing levelers and install TWO . . . each driven by its > own GPS engine (they're under $30 now). Further, I'd make > sure that each system was powered separately. If you have > even one of these devices working (along with alt and a/s) > there is nothing ATC asks you to do that cannot be > accomplished with no other instrumentation at all while > you maneuver to VMC somewhere. > > As many of you have already decided, there are back-up > steam gages to your "non certified" glass displays. > We've discussed separation of duties between various energy > sources -AND- loads that are exceedingly useful when you > can't see the ground. > > I'm still pained by narratives from incident investigations > where a single failure (perhaps combined with mis-positioning > of controls by crew) caused a cascade of failures or shutdowns > in otherwise perfectly good systems. > > Z-14 is but one example of a way that one can build a firewall > between a catastrophic electrical event and the total suite > of necessary equipment items. Z-13/8 is a two-layer electrical > system that offers excellent robustness in the face of certain > failures. > > There's a difference between how the TC side of the house > thinks and how we are permitted to think when it comes to > failure management. They bust their butts striving for > MTBF and reliability tree numbers that would make King > Midas envious. We're allowed to consider that EVERY part > in the system is going to quit at some point in time. If > it quits because we ignored simple preventative maintenance > duties and wore the thing out, then a pox on OUR house. If we > REALLY want it to work, it FAILS for unanticipated issues > and we didn't have a Plan-B . . . then it matters not > whether the thing had a 1,000 or 1,000,000 hour MTBF > number. Anyone who places any degree of faith in the > published reliability numbers for the purpose of keeping > his underwear dry has been poorly taught or wasn't paying > attention. > > I don't intend to diminish the significance of anyone's > difficulties in the cockpit . . . especially those > responsible for hundreds of lives. I ride behind > a crew of those folks with some frequency. At the same > time, let us not assign significance to the miseries > handed down to our brothers by a regulatory > process that runs smoother on intentions than > upon cold logic. By virtue of understanding > you've acquired one can craft and meet design > goals that put you light-years away from the > probability of experiencing an electrical system > event that ruins your day. > > Bob . . . > > ________________________________________________________________________________
From: "Hinde, Frank George (Corvallis)" <frank.hinde(at)hp.com>
Date: Aug 04, 2008
Amen Bob!..Plan for failure because it will happen. As for me I fly behind a DYNON EFIS and have a Trutrak wingleveler.. During all of my practice approaches (and some real approaches) I fly my twitchy RV by hand...I don't feel I need 2 winglevelers but I am certainly prepared to hand fly it out of the clouds (or down to minimums) if have to.. To me the multiple failure scenario is unbelievable also. Cheers Frank Electrically dependant RV7a You betcha! . By virtue of understanding you've acquired one can craft and meet design goals that put you light-years away from the probability of experiencing an electrical system event that ruins your day. Bob . . . ________________________________________________________________________________
Date: Aug 04, 2008
Bob, et al, Here's one possibility for failure while still on the ground, an open or leaky canopy on a night of intense ground fog that lets the whole aircraft cold soak and become coated with water. Happened on my truck (an electrically dependant 2006 Toyota Tacoma Pre Runner) which has eight on board computers. I left the windows down all night and came out the next morning to find the interior soaked. The engine started normally, but almost immediately the dash began to light up like the proverbial Christmas tree. The stability control system, ABS system, the electric limited slip differential, and the service engine warning lamps were all lit. Brakes worked, as did the FBW throttle, although applying the brakes caused the left turn signal to light, so I continued on my way. After my first stop the lights were out after start up, then came back on a mile or so down the road. After my second stop the lights were out after start up and stayed out, although applying the brakes still caused the left turn signal to light. It was on this leg of the trip that I learned that actuating the left turn signal caused the cruise control to turn off. Once we were well into the heat of the Kansas day, all the symptoms went away. I've put the truck through some pretty wild weather on many cross country drives to both coasts and never saw any problems like this, but one good soaking of the interior sure made for an interesting morning. Rick On Mon, Aug 4, 2008 at 2:40 PM, Hinde, Frank George (Corvallis) < frank.hinde(at)hp.com> wrote: > > > Amen Bob!..Plan for failure because it will happen. > > As for me I fly behind a DYNON EFIS and have a Trutrak wingleveler.. > > During all of my practice approaches (and some real approaches) I fly my > twitchy RV by hand...I don't feel I need 2 winglevelers but I am certainly > prepared to hand fly it out of the clouds (or down to minimums) if have to.. > > To me the multiple failure scenario is unbelievable also. > > Cheers > > Frank > Electrically dependant RV7a > > You betcha! > > . By virtue of understanding > you've acquired one can craft and meet design > goals that put you light-years away from the > probability of experiencing an electrical system > event that ruins your day. > > Bob . . . > > ________________________________________________________________________________
Date: Aug 04, 2008
Subject: Re: Charging a low battery
I think what's going on here is that it probably takes very little current to raise the voltage on a dead battery from 9V to 14V - as long as no cells are shorted. Once the cell voltage comes up, the current drawn drops even further - small voltage difference between the alternator output and the stacked cell voltage. How much current the battery can take will also depend on the internal resistance of its cells. It's possible that if you had batteries with low(er) internal resistance (an RG type, maybe), you'd start blowing fuses. Bob posted a note a while back about certain aircraft that had charging system problems when running low internal resistance RG batteries. Your hi power alternator can be convinced to provide its full output if you connect a load which will continue to drop the bus voltage. Regards, Matt- > > I think this has been discussed before, but I vaguely remember. Why > doesn't my truck blow the 30a fuse when I use it to charge my nearly > dead trailer batteries (less than 9v)? I have had to do this several > times and I just connect the truck to the trailer up start the engine > and rev it up. No ill effects to report and the fuse did not fail. > The truck has a 110a alternator and 2 size 65 batteries (diesel). > During this charging I see 13.8v or so on the cigar lighter plug. > Thanks, Paul > > ________________________________________________________________________________
Date: Aug 05, 2008
http://online.wsj.com/article/SB121684995725478651.html?mod=googlenews_wsj -------------- Original message -------------- From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net> > > > >Article worth forwarding to this list from AOPA > > > > > > > >July 30, 2008 by Bruce Landsberg , AOPA Safety blog> >= o ns = "urn:schemas-microsoft-com:office:office" /> > >The old joke about the fully automated airliner with no flight crew - just > >an automated cabin announcement that misfires - seems prophetic with last > >week's NTSB announcement about massive display failure on Airbus aircraft. > >There were 49 failures on Airbus 319 and 320 aircraft including seven > >incidents where all six screens failed simultaneously. Didn't think that > >was possible? Neither did the manufacturer, the FAA or the NTSB. > > > > > >"One of the great mistakes is to judge policies and programs > > by their intentions rather than their results." -Milton Friedman > > You betcha! > > Has anyone found further discussions of these events on the Airbus? > I spent about 30 minutes searching the web . . . turned up a number > of items dealing with EFIS (or electrical system) failures on > various ATP class aircraft . . . but nothing that speaks to what > might be called an epidemic of failures aboard the Airbus. > > I'm having trouble visualizing the lack of attention to system > design that produces gross failures of flight deck systems. > I cannot imagine folks who designed the A319/320 were so lacking > in due diligence. > > How do these tales affect the OBAM aircraft community? > I'll suggest no more than ANY story of gross systems failure > aboard ANY vehicle. If it's important that failures do not > propagate across multiple systems, then it's generally not > difficult to make sure this doesn't happen. > > I think I've mentioned this before . . . but if I were > building an airplane intended to spend a lot of time in > the clouds, I'd take advantage of the low cost, GPS aided > wing levelers and install TWO . . . each driven by its > own GPS engine (they're under $30 now). Further, I'd make > sure that each system was powered separately. If you have > even one of these devices working (along with alt and a/s) > there is nothing ATC asks you to do that cannot be > accomplished with no other instrumentation at all while > you maneuver to VMC somewhere. > > As many of you have already decided, there are back-up > steam gages to your "non certified" glass displays. > We've discussed separation of duties between various energy > sources -AND- loads that are exceedingly useful when you > can't see the ground. > > I'm still pained by narratives from incident investigations > where a single failure (perhaps combined with mis-positioning > of controls by crew) caused a cascade of failures or shutdowns > in otherwise perfectly good systems. > > Z-14 is but one example of a way that one can build a firewall > between a catastrophic electrical event and the total suite > of necessary equipment items. Z-13/8 is a two-layer electrical > system that offers excellent robustness in the face of certain > failures. > > There's a difference between how the TC side of the house > thinks and how we are permitted to think when it comes to > failure management. They bust their butts striving for > MTBF and reliability tree numbers that would make King > Midas envious. We're allowed to consider that EVERY part > in the system is going to quit at some point in time. If > it quits because we ignored simple preventative maintenance > duties and wore the thing out, then a pox on OUR house. If we > REALLY want it to work, it FAILS for unanticipated issues > and we didn't have a Plan-B . . . then it matters not > whether the thing had a 1,000 or 1,000,000 hour MTBF > number. Anyone who places any degree of faith in the > published reliability numbers for the purpose of keeping > his underwear dry has been poorly taught or wasn't paying > attention. > > I don't intend to diminish the significance of anyone's > difficulties in the cockpit . . . especially those > responsible for hundreds of lives. I ride behind > a crew of those folks with some frequency. At the same > time, let us not assign significance to the miseries > handed down to our brothers by a regulatory > process that runs smoother on intentions than > upon cold logic. By virtue of understanding > you've acquired one can craft and meet design > goals that put you light-years away from the > probability of experiencing an electrical system > event that ruins your day. > > Bob . . . > > > > >
> --> AeroElectric-List message posted by: "Robert L. Nuckolls, III"
> >incidents where all six scr eens f ailed simultaneously. Didn't think that
> You betcha!
> in due diligence.
> As many of you have already decide d, the re are back-up
> failures.
> failure manageme nt. Th ey bust their butts striving for
> attention.
> a crew of tho se fol =====
Date: Aug 04, 2008
This sort of thing is why my EFIS-equipped RV-10 (with electronic ignition) is built with backup mechanical altimeter and airspeed, a vacuum powered artificial horizon, and an old fashioned mag to back up the electronic ignition. That's the most diverse approach to redundancy I could get for my experimental aircraft. An unanticipated event may be able to take out even a well designed electrical bus that has passed multiple peer reviews (Diamond twin star, for example), but it's pretty unlikely to take out the vacuum pump or the mag at the same time. -- Tim Lewis -- HEF (Manassas, VA) RV-6A N47TD -- 1000 hrs RV-10 #40059 under construction John Markey wrote: > Article worth forwarding to this list from AOPA > > > > July 30, 2008 by Bruce Landsberg , AOPA Safety blog > > The old joke about the fully automated airliner with no flight crew > - just an automated cabin announcement that misfires - seems prophetic > with last weeks NTSB announcement about massive display failure on > Airbus aircraft. There were 49 failures on Airbus 319 and 320 aircraft > including seven incidents where all six screens failed simultaneously. > Didnt think that was possible? Neither did the manufacturer, the FAA > or the NTSB. > As light GA manufacturers rush into glass cockpits, is it unseemly to > ask what assurance we have that there will not be a catastrophic > failure or at least a significant failure in our less robust systems? > Several years ago I had the privilege of getting a demo in one of the > early all-glass light aircraft which suffered a total flight display > meltdown. It wasnt an issue since we were in good VFR and there were > backup instruments. Still, this isnt whats supposed to happen. > After one flies enough and sees enough equipment break - some of it > harmlessly and some of it at the least opportune time - a sense of > caution or perhaps cynicism sets in. Duplication of hardware on > critical things like comm, nav and flight displays means less fancy > footwork on the pilots part when something goes south. > I suspect the record keeping on Part 91 flights flown in light > aircraft when a flight display dies is not very accurate, even though > NTSB Part 830 requires, somewhat vaguely, pilots to report the > in-flight failure of electrical systems that require sustained use of > .backup power to retain flight control or essential instruments. > Has anybody had, or know of someone who had, a major glass malfunction > and did it get reported and to whom? The purpose is not to rat out the > manufacturers but to insure that weak points get fixed before someone > is hurt. > > Bruce Landsberg > Executive Director, AOPA Air Safety Foundation > > > > > * > > > * > Checked by AVG - http://www.avg.com > ________________________________________________________________________________
Date: Aug 04, 2008
>>An unanticipated event may be able to take out even a well designed elect rical bus that has passed multiple peer reviews (Diamond twin star, for exa mple), << Ah... what makes you assume it passed multiple peer reviews ? By whom? When ? ________________________________________________________________________________
Date: Aug 04, 2008
paul wilson wrote: > > I think this has been discussed before, but I vaguely remember. Why > doesn't my truck blow the 30a fuse when I use it to charge my nearly > dead trailer batteries (less than 9v)? I have had to do this several > times and I just connect the truck to the trailer up start the engine > and rev it up. No ill effects to report and the fuse did not fail. > The truck has a 110a alternator and 2 size 65 batteries (diesel). > During this charging I see 13.8v or so on the cigar lighter plug. > Thanks, Paul What is the path resistance between from the alternator, to the trailer battery and back again? The trailer batter is at 9V and the alternator is putting out 13.8V. That gives you 4.8V to drive current with. 0.16 Ohms will limit 4.8V to 30A. In that circuit, you've got at least 30ft of wire (of unknown gauge), two pin connectors (probably half corroded if they look like the ones on the back of my truck), and two battery connections of unknown condition. Half an ohm would be no problem to mix in there somewhere. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Aug 05, 2008
I just want to add my 2 cents here. I have been flying the Airbus 319/320 for over 11 years and have not heard of a failure of all screens at once. But I will add this, I have seen and heard of avionics failures that were not suppose to happen and did. In every case that I have heard of or been a part of they ALL have been due to changes during modification or maintenance and not the original TC wiring. What I have extrapolated from these anomalies is the oversight of system integrity goes down considerably once the airplane leaves the factory. Just my 2 cents, Mike Larkin >Article worth forwarding to this list from AOPA > > >July 30, 2008 by Bruce Landsberg , AOPA Safety blog= o ns = "urn:schemas-microsoft-com:office:office" /> >The old joke about the fully automated airliner with no flight crew - just >an automated cabin announcement that misfires - seems prophetic with last >week's NTSB announcement about massive display failure on Airbus aircraft. >There were 49 failures on Airbus 319 and 320 aircraft including seven >incidents where all six screens failed simultaneously. Didn't think that >was possible? Neither did the manufacturer, the FAA or the NTSB. > >"One of the great mistakes is to judge policies and programs > by their intentions rather than their results." -Milton Friedman You betcha! Has anyone found further discussions of these events on the Airbus? I spent about 30 minutes searching the web . . . turned up a number of items dealing with EFIS (or electrical system) failures on various ATP class aircraft . . . but nothing that speaks to what might be called an epidemic of failures aboard the Airbus. I'm having trouble visualizing the lack of attention to system design that produces gross failures of flight deck systems. I cannot imagine folks who designed the A319/320 were so lacking in due diligence. How do these tales affect the OBAM aircraft community? I'll suggest no more than ANY story of gross systems failure aboard ANY vehicle. If it's important that failures do not propagate across multiple systems, then it's generally not difficult to make sure this doesn't happen. I think I've mentioned this before . . . but if I were building an airplane intended to spend a lot of time in the clouds, I'd take advantage of the low cost, GPS aided wing levelers and install TWO . . . each driven by its own GPS engine (they're under $30 now). Further, I'd make sure that each system was powered separately. If you have even one of these devices working (along with alt and a/s) there is nothing ATC asks you to do that cannot be accomplished with no other instrumentation at all while you maneuver to VMC somewhere. As many of you have already decided, there are back-up steam gages to your "non certified" glass displays. We've discussed separation of duties between various energy sources -AND- loads that are exceedingly useful when you can't see the ground. I'm still pained by narratives from incident investigations where a single failure (perhaps combined with mis-positioning of controls by crew) caused a cascade of failures or shutdowns in otherwise perfectly good systems. Z-14 is but one example of a way that one can build a firewall between a catastrophic electrical event and the total suite of necessary equipment items. Z-13/8 is a two-layer electrical system that offers excellent robustness in the face of certain failures. There's a difference between how the TC side of the house thinks and how we are permitted to think when it comes to failure management. They bust their butts striving for MTBF and reliability tree numbers that would make King Midas envious. We're allowed to consider that EVERY part in the system is going to quit at some point in time. If it quits because we ignored simple preventative maintenance duties and wore the thing out, then a pox on OUR house. If we REALLY want it to work, it FAILS for unanticipated issues and we didn't have a Plan-B . . . then it matters not whether the thing had a 1,000 or 1,000,000 hour MTBF number. Anyone who places any degree of faith in the published reliability numbers for the purpose of keeping his underwear dry has been poorly taught or wasn't paying attention. I don't intend to diminish the significance of anyone's difficulties in the cockpit . . . especially those responsible for hundreds of lives. I ride behind a crew of those folks with some frequency. At the same time, let us not assign significance to the miseries handed down to our brothers by a regulatory process that runs smoother on intentions than upon cold logic. By virtue of understanding you've acquired one can craft and meet design goals that put you light-years away from the probability of experiencing an electrical system event that ruins your day. Bob . . . 7/22/2008 4:05 PM 7/22/2008 4:05 PM ________________________________________________________________________________
Date: Aug 05, 2008
> >>An unanticipated event may be able to take out even a well designed > electrical bus that has passed multiple peer reviews (Diamond twin star, > for example), << > > Ah... what makes you assume it passed multiple peer reviews ? > > By whom? When ? Exactly . . . and then you have "executive decision" to contend with. I'm seriously considering bowing out of a program wherein we walked in with a proposal for a "been there, done that, best-we-know-how-to-do" product. Various "forces" were applied to the design by both supplier sales ("the customer is always right") and buyer's engineering ("that's the way we used to do it and I don't want to do something I don't understand"). The first article delivered was a super pain in the arse. We're starting to stack band-aids on to fix the problems . . . which is slowly creeping the design toward the original proposal. I'd like to rip it all out and start over but it's beginning to look like the system will go to qualification with a pile of band-aids in place as opposed to backing up and doing it right. If left unchanged the parts count will be too high, the customer service technicians will curse "those idiot engineers" and cost of ownership will be unnecessarily high. One would like to believe that these situations don't happen a Boeing, Airbus, et. als. but I wouldn't bet on it! Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 05, 2008
>Bob, et al, Here's one possibility for failure while still on the ground, >an open or leaky canopy on a night of intense ground fog that lets the >whole aircraft cold soak and become coated with water. >Happened on my truck (an electrically dependant 2006 Toyota Tacoma Pre >Runner) which has eight on board computers. I left the windows down all >night and came out the next morning to find the interior soaked. >The engine started normally, but almost immediately the dash began to >light up like the proverbial Christmas tree. The stability control system, >ABS system, the electric limited slip differential, and the service engine >warning lamps were all lit. Brakes worked, as did the FBW throttle, >although applying the brakes caused the left turn signal to light, so I >continued on my way. After my first stop the lights were out after start >up, then came back on a mile or so down the road. After my second stop the >lights were out after start up and stayed out, although applying the >brakes still caused the left turn signal to light. It was on this leg of >the trip that I learned that actuating the left turn signal caused the >cruise control to turn off. Once we were well into the heat of the Kansas >day, all the symptoms went away. >I've put the truck through some pretty wild weather on many cross country >drives to both coasts and never saw any problems like this, but one good >soaking of the interior sure made for an interesting morning. Condensation and hygroscopic behavior of normally insulating materials is a sleeping misery that we 'normally' discover during qualification. DO-160 calls for testing under conditions of severe humidity. But as you've experienced, there are occasions WWAAaaay out on the end of the bell-curve that can lead to new and unpleasant discoveries. An airplane (or any other vehicle) that sits outside gets to test all the points on the bell curve. Most folks never get past 99.9; some folks get there but one time. One of the slippery challenges of engineering is to anticipate and make rational plans to deal with 99.9th percentile events without stacking a lot of "worry expense" on the product. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2008
><http://online.wsj.com/article/SB121684995725478651.html?mod=googlenews_wsj>http://online.wsj.com/article/SB121684995725478651.html?mod=googlenews_wsj Hmmm . . . funny thing about those search engines. Another search today on "airbus" and "failures" didn't turn up items on the EFIS failures but plenty of other stuff. In particular, you may run across some stories about one Joe Mangan. I'll leave it up to the List readers to research and draw their own conclusions. As I suggested earlier, all this kerfuffle has very little if anything to do with our airplanes. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2008
>This sort of thing is why my EFIS-equipped RV-10 (with electronic >ignition) is built with backup mechanical altimeter and airspeed, a vacuum >powered artificial horizon, and an old fashioned mag to back up the >electronic ignition. That's the most diverse approach to redundancy I >could get for my experimental aircraft. > >An unanticipated event may be able to take out even a well designed >electrical bus that has passed multiple peer reviews (Diamond twin star, >for example), but it's pretty unlikely to take out the vacuum pump or the >mag at the same time. The reliability gurus have long suggested that "twin" systems are not as confidence building as "alternative" designs. As you've cited, it's unlikely that products of disparate but functionally interchangeable systems yield the highest probability for at least one system staying awake if one of them goes to sleep. This goes to the idea that identical systems can simultaneously suffer the same failure mode. When I propose a micro to do control, the companion monitor processor is a different device with code produced on a different tool. Folks flying a Dynon to back up a Blue Mountain are not only saving some $ but are taking advantage of the separation of failure modes in disparate designs. Bob . . . ________________________________________________________________________________
Date: Aug 05, 2008
> >I just want to add my 2 cents here. I have been flying the Airbus >319/320 for over 11 years and have not heard of a failure of all screens >at once. But I will add this, I have seen and heard of avionics >failures that were not suppose to happen and did. In every case that I >have heard of or been a part of they ALL have been due to changes during >modification or maintenance and not the original TC wiring. What I have >extrapolated from these anomalies is the oversight of system integrity >goes down considerably once the airplane leaves the factory. > >Just my 2 cents, > >Mike Larkin Thanks for your contribution. It's always useful to hear from someone who has been-there, done-that. I'm not suggesting that the stories be totally discounted but given the scientific acumen of those who write for the popular press, a rational skepticism as to severity of the problem is called for. Bob . . . ________________________________________________________________________________
Subject: Bose X Aviation Headset For Sale
Date: Aug 05, 2008
I have a nice Bose X for sale on e-Bay http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMESE%3AIT&viewitem=&item=300247651009&rd=1 Read this topic online here: http://forums.matronics.com/viewtopic.php?p=196670#196670 ________________________________________________________________________________
Date: Aug 06, 2008
Subject: P-Mag Overvoltage
> The reliability gurus have long suggested that > "twin" systems are not as confidence building as > "alternative" designs. This is the most reliable strategy. However, I am considering installing two P-Mags (or one P and one E). This provides variable spark timing to both plugs, which should result in improved engine performance. With internal power generation, the P-Mags should be very reliable. The only common failure mode I can think of is an overvoltage event that damages the electronics in both P-Mags. Do you know enough about the product design to comment on the robustness of these products to a major overvoltage event ? Is there a switching regulator that can handle almost anything ? Thanks, Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Aug 06, 2008
Subject: Re: P-Mag Overvoltage
> >> The reliability gurus have long suggested that >> "twin" systems are not as confidence building as >> "alternative" designs. > >This is the most reliable strategy. >However, I am considering installing two P-Mags (or one P and one E). >This provides variable spark timing to both plugs, which should result >in improved engine performance. Agreed . . . and better starting and longer life on plugs. >With internal power generation, the P-Mags should be very reliable. Agreed >The only common failure mode I can think of is an overvoltage event >that damages the electronics in both P-Mags. > >Do you know enough about the product design to comment on the >robustness of these products to a major overvoltage event ? Is there >a switching regulator that can handle almost anything ? I'll have to talk to Tom and Brad . . . my short visit with them last year left me with an impression of much smarter-than-average-bears. I'd like to believe their product is equal to or better than DO-160 qualification recommendations for aircraft. Of course, you could call them too! I've copied them on this message and expect an answer to your concern will be forthcoming. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 06, 2008
Hinde, Frank George (Corvallis) wrote: > > Ahh yes...As I tell my engineers who want every cool gadget going on their sysytems..."Every component is an expensive point of failure" > > It's not a disease in the high-tech industry. It's a pandemic. You ask for a simple function to do a specific simple job. You get back several thousand lines of code with a dozen optional parameters and a slew of hidden side effects (for the uninitiated: unrelated things are changing that you don't expect). Software is a funny thing in that it is very easy to change. This leads to a mentality of "throw it at the wall, and let's keep what sticks". I don't know the veracity of the reports about all the displays going out on the airliners, but my experience tells me that it is very likely. I've seen code be approved by "professionals" that wouldn't pass muster in a freshman college class, and the argument is always that "we don't have time to fix it". If it passes QA (that also doesn't have time to fix anything), then it is shipped. Proper software engineering requires the same sort of methodical, tedious system review and modularity that we expect to put in our electrical design. In the end, that is exactly what it is, a lot of tiny electrical switches going off all over the place. The fault scenarios are often difficult to identify. Even people who should know better often forget this. -- http://www.ronpaultimeline.com ________________________________________________________________________________
From: "Andrew Butler" <andrewbutler(at)ireland.com>
Date: Aug 07, 2008
Subject: Fw: Serious Incident to Piper PA-34-200T,Reg: EI-CMT,on
7 November 2007, at Shannon CTA, Co Kerry. Published yesterday by the Air Accident Investigation Unit in Ireland. http://www.aaiu.ie/upload/general/10887-0.pdf Concerns a complete electrical failure aboard a twin Piper on an IFR flight during winter. Safe landing in the end. Thoughts on lessons learned? Andrew. ----- Original Message ----- From: AAIU Subject: Serious Incident to Piper PA-34-200T,Reg: EI-CMT,on 7 November 2007, at Shannon CTA, Co Kerry. Date: Wed, 6 Aug 2008 14:57:59 +0100 Subscriber, The AAIU have published Final Report No. 2008-018 on www.aaiu.ie concerning a Piper PA-34-200T, Reg: EI-CMT, which occurred on 7 November 2007, at Shannon CTA, Co Kerry. It's URL is <http://www.aaiu.ie/upload/general/10887-0.pdf Regards AAIU PLEASE CONSIDER THE ENVIRONMENT BEFORE PRINTING THIS EMAIL ************************************************************ T=E1 eolas sa teachtaireacht leictreonach seo a d'fh=E9adfadh bheith pr=EDo bh=E1ideach n=F3 faoi r=FAn agus b'fh=E9idir go mbeadh =E1bhar r=FAnda n=F3 pribhl=E9id each ann. Is le h-aghaidh an duine/na ndaoine n=F3 le h-aghaidh an aon=E1in at=E1 ain mnithe thuas agus le haghaidh an duine/na ndaoine sin amh=E1in at=E1 an t-eolas. T=E1 cosc ar rochtain don teachtaireacht leictreonach seo do aon duine eile. Murab ionann tusa agus an t=E9 a bhfuil an teachtaireacht ceaptha d=F3 b=ED odh a fhios agat nach gceada=EDtear nochtadh, c=F3ipe=E1il, scaipeadh n=F3 =FAs=E1id an eolais agus/n=F3 n chomhaid seo agus b'fh=E9idir d'fh=E9adfadh bheith m=EDdhleathach. The information in this email is confidential and may be legally privileged . It is intended solely for the addressee. Access to this email by anyone els e is unauthorised. If you are not the intended recipient, any disclosure, copying, distribution or any action taken or omitted to be taken in reliance on it is prohibited and may be unlawful. *********************************************************** ________________________________________________________________________________
Date: Aug 07, 2008
From: "Stucklen, Frederic W UTPWR" <Fred.Stucklen(at)UTCPower.com>
I concur! "Never enough time to do the job right, but always enough time to do it over again"! Fred Stucklen Sr Software Engineer If you had to identify, in one word, the reason why the human race has not achieved, and never will achieve, its full potential, that word would be "meetings." From: Ernest Christley <echristley(at)nc.rr.com> Subject: Re: Article from AOPA on Glass EFIS failures Hinde, Frank George (Corvallis) wrote: > > Ahh yes...As I tell my engineers who want every cool gadget going on their sysytems..."Every component is an expensive point of failure" > > It's not a disease in the high-tech industry. It's a pandemic. You ask for a simple function to do a specific simple job. You get back several thousand lines of code with a dozen optional parameters and a slew of hidden side effects (for the uninitiated: unrelated things are changing that you don't expect). Software is a funny thing in that it is very easy to change. This leads to a mentality of "throw it at the wall, and let's keep what sticks". I don't know the veracity of the reports about all the displays going out on the airliners, but my experience tells me that it is very likely. I've seen code be approved by "professionals" that wouldn't pass muster in a freshman college class, and the argument is always that "we don't have time to fix it". If it passes QA (that also doesn't have time to fix anything), then it is shipped. Proper software engineering requires the same sort of methodical, tedious system review and modularity that we expect to put in our electrical design. In the end, that is exactly what it is, a lot of tiny electrical switches going off all over the place. The fault scenarios are often difficult to identify. Even people who should know better often forget this. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Date: Aug 07, 2008
We let our customers do all of our beta testing. :-) Chuck Jensen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Stucklen, Frederic W UTPWR Sent: Thursday, August 07, 2008 7:22 AM Subject: AeroElectric-List: Re: Article from AOPA on Glass EFIS failures I concur! "Never enough time to do the job right, but always enough time to do it over again"! Fred Stucklen Sr Software Engineer If you had to identify, in one word, the reason why the human race has not achieved, and never will achieve, its full potential, that word would be "meetings." From: Ernest Christley < echristley(at)nc.rr.com> Subject: Re: Article from AOPA on Glass EFIS failures Hinde, Frank George (Corvallis) wrote: > > Ahh yes...As I tell my engineers who want every cool gadget going on their sysytems..."Every component is an expensive point of failure" > > It's not a disease in the high-tech industry. It's a pandemic. You ask for a simple function to do a specific simple job. You get back several thousand lines of code with a dozen optional parameters and a slew of hidden side effects (for the uninitiated: unrelated things are changing that you don't expect). Software is a funny thing in that it is very easy to change. This leads to a mentality of "throw it at the wall, and let's keep what sticks". I don't know the veracity of the reports about all the displays going out on the airliners, but my experience tells me that it is very likely. I've seen code be approved by "professionals" that wouldn't pass muster in a freshman college class, and the argument is always that "we don't have time to fix it". If it passes QA (that also doesn't have time to fix anything), then it is shipped. Proper software engineering requires the same sort of methodical, tedious system review and modularity that we expect to put in our electrical design. In the end, that is exactly what it is, a lot of tiny electrical switches going off all over the place. The fault scenarios are often difficult to identify. Even people who should know better often forget this. -- http://www.ronpaultimeline.com ________________________________________________________________________________
Subject: relay wiring question
Date: Aug 07, 2008
I am looking for the proper way to wire my battery and starter contactor. I have a Spruce bought battery contactor, which is a White-Rodgers Type 70 DC power contactor. I expected to see two large posts and two small posts on the unit but it has only one small post. The manufactures web site refers to this as a "Terminal Type 3B - Coil Common to Load" . I want to confirm how to properly wire this to my DPDT master switch, the manufacturers diagram shows a pig tail to the small post from large post that is connected to battery positive. I assume I wire from that large post to the master switch and the back to small post on the contactor. There is no connection from the master switch to ground in this case? Part 2 I have B&C starter relay, it also has only one small post. I assume that it is grounded through it's own case and I should bring positive line through the starter switch and back to the small post and then pig tail a ground wire from the case mounting bolt to the firewall ground? Thanks in advance for your help. Jerry ________________________________________________________________________________
Subject: Re: Fraudulent Purchase Attampt (Off Topic)
Date: Aug 07, 2008
In the hope that even one vendor will be saved from this, I relate my recent experience with a guy who wanted to buy some large quantity of my stuff and tried to scam me. But, even though I was born in the morning, I wasn't born THIS MORNING. Be careful out there. > Dear Eric, > Thanks for the total quote of my order.The total cost of my order is quite correct and okay by me and I'm ready to pay the bills . I shall inform my freight forwarder who will be coming to pick up the order to hold on and come immediately you inform me that the items are ready for pick up then i can give you a call on that day to get the items packed for pick up and they will call you on their arrival at your address.Also I want you to help me Charge another $230.00 from my card for the freight forwarder who will be coming to pick up my ordered items from you. > > The $230.00 that will be sent to the freight forwarder is for the shipping of my order and other items i ordered from different part of the country which is to be picked up by him and should be deducted from my credit card.Also, I'm compensating you with the sum of $90.00 for the transfer fee and for your efforts. Please note that i should have given the shipping agency my credit card for him to deduct the freight charges but he told me that he doesn't have the facilities to charge or debit credit card , so that's why i bring my vote of confidence in you and i want you to assist me in this measure, so i want you to transfer the funds to him after you have make the charges and the money charged from my credit card is in your account,then you can now make the transfer to the agent via western union.i will have love to do this my self but there are no western union here around me cos i am out of town to monitor my estate construction at a remote village,So the charges you'll make on my credit card will be: > > Order Fee: $450.00 > Agent fee with shipping fare: $230.00 > Transfer Fee plus Your Compensation: $90.00 > Total: $770.00 > > I await your quick response. > Kind Regards > > Terry Gilson C & H Store Inc > > 67 Whitbread Street, Taree, NSW, 2430, Australia > > Phone +61 8 9467 5956, Fax (08) 9439 5544 > > Email:candhstoreinc(at)gmail.com So I'll be taking a bogus credit card and handing a box of stuff to some yokel in a car? Never to be seen again. I especially like the smooth tip-off "$90 for the transfer fee and for your efforts". "...this guy is going to offer to bet you that he can make the jack of spades jump out of this brand-new deck of cards and squirt cider in your ear. But, son, do not accept this bet, because as sure as you stand there, you're going to wind up with an ear full of cider." ---Guys and Dolls -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197105#197105 ________________________________________________________________________________
Date: Aug 07, 2008
Subject: Re: Serious Incident to Piper PA-34-200T
>Published yesterday by the Air Accident Investigation Unit in Ireland. > >http://www.aaiu.ie/upload/general/10887-0.pdf > >Concerns a complete electrical failure aboard a twin Piper on an IFR >flight during winter. Safe landing in the end. > >Thoughts on lessons learned? > >Andrew. This is an interesting case. While the symptom was not repeated by experiment (difficult and hazardous) the deduction drawn by the investigators is quite plausible. There is only one error in the data which is the 0.3 ohm contact resistance cited for the contactor specification . . . this is probably 0.3 MILLIOHMS. Obviously, a contactor with 300 milliohms resistance would be useless. If one tracks the history of system evolution for aircraft, the first time this airplane (or it's ancestors) flew, it was fitted with generators. Generators are noteworthy for their ability to function without benefit of external power for excitation support. The history of the 6041 series contactors in aircraft and throughout industry has been exemplary. However, they DO have a service life and they do WEAR OUT at some point in time. http://aeroelectric.com/Pictures/Failures/6041_Contactor_Failure.jpg The MTBF study offered up in the report spoke to "three failures" . . . of course, these were failures that generated noteworthy incidents such as the case under study. There were thousands of failures for both battery and starter contactors where the difficulty was discovered on the ground or the contactor was teamed with generators and the in-flight failure of a battery contactor did not generate a reportable incident. This is a GREAT example of how architecture, selection of components, and plan-a/plan-b operating procedures can utilize seemingly pedestrian components in a way that failures are simply maintenance events as opposed to reportable events (where there was risk of bending an airplane or occupants). It was consideration of vulnerabilities demonstrated by various components that evolved the Z-figures. First with addition of the e-bus in Z-11. Had the case study airplane been fitted with an e-bus, they would not have needed to resort to cell phone communications or augering around in clouds sans electronic nav aids. The next step was independent, cross-feed electrical systems, Z-14. Obviously a giant step above any of the intertwined architectures that fly in the majority of GA aircraft. I'm aware of NO production aircraft that features such an architecture. The shift to all electric panels vacated the vacuum pump pad. A second engine driven power source could utilize the vacated pad and offer up a three layer system illustrated in Z-11. (1) Battery only + e-bus (2) battery + e-bus supported by 8A engine driven power source holding the battery in reserve for approach to landing and (3) full up battery + e-bus + main bus supported by ships normal alternator. With the advent of the SD-20 offered into GA aircraft and Z-12 architecture, they can come close to a Z-11 configuration . . . but there is still the specter of battery contactor failure that could generate a total loss of system under certain conditions. We were able to address that issue on the Cessna 337 when for a short time there was a small battery pack of flashlight cells and a push button offered up to kick-start a stalled alternator. Later, we took a 3-phase rectifier off the tach generator to provide a source of voltage for the same purpose. Decades later, we're finding alternators that either by accident or on-purpose design have enough residual rotor magnetism to come on line self-excited. Given the speed at which we rotate little automotive alternators in belt-driven applications, it may be that most of those installations will come up without a battery . . . if lightly loaded. Certainly, there are little features we could explore but without a broad spectrum of purposeful design amongst the field of suitable alternators, it's not likely that we'll be able to recommend exploitation of this quality . . . hence the configuration the z-figures as presently published. Is there value in combing through these reports? Certainly. There is (1) the potential for making us aware of previously undiscovered/unconsidered failure modes and (2) re-enforcement of our confidence in the state of our art in crafting failure tolerant systems. The sad part is the regulatory hurdles that prevent our brothers on the TC side of the house from exploiting the simple pleasures of electrical system confidence we enjoy on OBAM aircraft. Present trends plotted out into the future do not suggest they will ever be beneficiaries of such freedoms. Bob . . . ________________________________________________________________________________
Date: Aug 07, 2008
Subject: Re: relay wiring question
Jerry, The 12 volt cable from the battery to the battery contactor also provides the power to the contactor. You run a wire from the single small terminal to your master switch and another wire from the master switch to ground. The master switch then provides ground to complete the circuit and activate the contactor. The starter relay requires that 12 volts be supplied to the small terminal for the relay to activate. Yes, ground is through the case. If your aircraft is composite or tube and fabric construction then you should run a ground wire from the case mount bolt to the firewall ground block. If your aircraft is aluminum ground should be available directly from the airframe. I hope this helps, Bob Borger Europa XS, Rotax 914, Airmaster C/S prop http://www.europaowners.org/N914XL On Thursday, August 07, 2008, at 08:27AM, "Jerry Ricciotti" wrote: >I am looking for the proper way to wire my battery and starter contactor. > >I have a Spruce bought battery contactor, which is a White-Rodgers Type 70 DC power contactor. I expected to see two large posts and two small posts on the unit but it has only one small post. The manufactures web site refers to this as a "Terminal Type 3B - Coil Common to Load" . I want to confirm how to properly wire this to my DPDT master switch, the manufacturers diagram shows a pig tail to the small post from large post that is connected to battery positive. I assume I wire from that large post to the master switch and the back to small post on the contactor. There is no connection from the master switch to ground in this case? > >Part 2 >I have B&C starter relay, it also has only one small post. >I assume that it is grounded through it's own case and I should bring positive line through the starter switch and back to the small post and then pig tail a ground wire from the case mounting bolt to the firewall ground? > >Thanks in advance for your help. > Jerry ________________________________________________________________________________
Date: Aug 07, 2008
---- Chuck Jensen wrote: > We let our customers do all of our beta testing. :-) > > Chuck Jensen > You work for Microsoft!? 8*) That's one of my favorite quotes, that I use when I'm getting to the end of my frustration quota with 'managers' that are just being dumb. "Hell, just ship it. The customers will ALWAYS tell us what's wrong with it." ________________________________________________________________________________
Date: Aug 07, 2008
> >In the hope that even one vendor will be saved from this, I relate my >recent experience with a guy who wanted to buy some large quantity of my >stuff and tried to scam me. But, even though I was born in the morning, I >wasn't born THIS MORNING. Be careful out there. > I get several requests per year to confirm that I can take orders paid for by Visa or MC to be shipped to Nigeria or some such remote place . . . when my website clearly states that we do process charge cards. A number of these inquiries ask me to acquire merchandise that is not even offered on the website . . . but clearly available from dozens if not hundreds of sites elsewhere on the 'net. You are quite justified in your suspicions. On a trip to Brazil some years ago, I watched a DC6 being unloaded of PT-6 engines and $millions$ of other goodies. The location was on a ramp at a well known aircraft manufacturer. It was illegal to deal in dollars for external trade . . . but the local currency was running about 500% per year inflation . . . essentially worthless. The government choose to 'overlook' these flights between Florida and Brazil where the plane came in with much needed parts to keep the workers employed, and flew back with literally $millions$ in suitcases full of dollars! Drop your customer a note telling him that his courier is most welcome to pick up the shipment if he first hands you a fist full of dollars! It's the way honorable criminals conduct themselves! Bob . . . ________________________________________________________________________________
Subject: Aux Power Socket
Date: Aug 07, 2008
Is there a convention for which of the 2 terminals in an Aux/cigar lighter port goes to + or -? I'm currently wiring my Aux power socket and wondered what everyone else does. I can't seem to find anything definite on whether to wire the centre pin or the outside pin to the +. Does it actually matter? Thanks in advance. Ian Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197164#197164 ________________________________________________________________________________
Subject: Re: Aux Power Socket
Date: Aug 07, 2008
Yes it matters. Center pin is positive. You'll note that the pin that is off-center will be shorted to the case of the receptacle, which in turn would be shorted in the panel. You would quickly know you wired it wrong. Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197167#197167 ________________________________________________________________________________
Date: Aug 07, 2008
Thanks Alfio. Good job I checked. It never ceases to amaze me that these things can be produced and not labeled, assuming that everyone knows what they're doing - clearly wrong in my case! Ian Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197169#197169 ________________________________________________________________________________
From: "Ivor Phillips" <ivor.phillips(at)ntlworld.com>
Date: Aug 07, 2008
The standard convention is Positive + to the centre pin and Negative - to the outside body or pin, Yes it definitely matters! Ivor -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of ianwilson2 Sent: 07 August 2008 19:19 Subject: AeroElectric-List: Aux Power Socket Is there a convention for which of the 2 terminals in an Aux/cigar lighter port goes to + or -? I'm currently wiring my Aux power socket and wondered what everyone else does. I can't seem to find anything definite on whether to wire the centre pin or the outside pin to the +. Does it actually matter? Thanks in advance. Ian Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197164#197164 ________________________________________________________________________________
Date: Aug 07, 2008
Subject: Re: AeroElectric-List Digest: 4 Msgs - 08/06/08
> I'll have to talk to Tom and Brad . . . my short > visit with them last year left me with an impression > of much smarter-than-average-bears. I'd like to believe > their product is equal to or better than DO-160 qualification > recommendations for aircraft. > > Of course, you could call them too! I would expect a "sales" answer to a call like this :-( An outsider who has seem the schematics and heard the behind the scenes stories can usually provide the more truthful answer I am looking for. I had a lot of trouble with the intercom on my Cessna last year. It turned out that the headset used the mic bias voltage to power the audio amplifier. After reverse engineering much of the intercom circuitry, I was appalled at the design. Although it was a 4 place intercom, the co-pilot circuitry "borrowed" some of the pilot's circuitry during transmit. So the pilot lost mic bias voltage and the audio disappeared whenever the co-pilot transmitted. No problem when normal headsets were used with the intercom and no problem when these headsets were used with other intercoms. Yuck. The headset manufacturer was very forthcoming with the design details necessary for me to figure this out. The intercom manufacturer (including the president) absolutely insisted there was nothing wrong with the design of the intercom. They were very helpful swapping out my intercom for another to confirm it was functioning correctly, but that did not fix the problem of course. Having finally solved it, I encouraged the intercom manufacturer to at least make all their tech support people aware of this issue, since with the number of those intercoms in the field and the popularity of the headsets being sold, the problem would certainly be an issue for others. They treated this like an unusual case that concerned no one else. Based on this, I am hesitant to purchase a new audio panel for my Tundra from this very popular intercom manufacturer. What if the same guy designed this product too ? Jeff Page Dream Aircraft Tundra #10 ________________________________________________________________________________
Date: Aug 07, 2008
Afternoon, Jeff... >>I would expect a "sales" answer to a call like this :-( << Excuse me for inserting my two cents here, but I think I have something to offer as well. I doubt very much that you would get a salesmen's type of reply to any call you make to Brad. Tom and Brad ARE Emagair ... not salesmen or support staff. Even though, come to think of it, they also ARE salesmen AND the support staff. And the designers, and the technicians...well you get the picture. A more helpful and knowledgeable couple of guys I've never run across with any company. They would not pull any punches or give you any false information about their products. No one, either in their company or users, knows their products better than they do, and in this case, I relying on information from "An outsider who has seem the schematics and heard the behind the scenes stories" would not be as informed or helpful as Brad would be. Excellent company to do business with... As far as user stories, I think there are some here in the archives if you want to search for them...maybe also in the Canard-Aviators Yahoo group, if you belong to that as well. Harley Dixon (biased...2 P-mags ) ------------------------------------------------------------------------ Jeff Page wrote: > >> I'll have to talk to Tom and Brad . . . my short >> visit with them last year left me with an impression >> of much smarter-than-average-bears. I'd like to believe >> their product is equal to or better than DO-160 qualification >> recommendations for aircraft. >> >> Of course, you could call them too! > > I would expect a "sales" answer to a call like this :-( > An outsider who has seem the schematics and heard the behind the > scenes stories can usually provide the more truthful answer I am > looking for. > > I had a lot of trouble with the intercom on my Cessna last year. It > turned out that the headset used the mic bias voltage to power the > audio amplifier. After reverse engineering much of the intercom > circuitry, I was appalled at the design. Although it was a 4 place > intercom, the co-pilot circuitry "borrowed" some of the pilot's > circuitry during transmit. So the pilot lost mic bias voltage and the > audio disappeared whenever the co-pilot transmitted. No problem when > normal headsets were used with the intercom and no problem when these > headsets were used with other intercoms. Yuck. > > The headset manufacturer was very forthcoming with the design details > necessary for me to figure this out. The intercom manufacturer > (including the president) absolutely insisted there was nothing wrong > with the design of the intercom. They were very helpful swapping out > my intercom for another to confirm it was functioning correctly, but > that did not fix the problem of course. > > Having finally solved it, I encouraged the intercom manufacturer to at > least make all their tech support people aware of this issue, since > with the number of those intercoms in the field and the popularity of > the headsets being sold, the problem would certainly be an issue for > others. They treated this like an unusual case that concerned no one > else. > > Based on this, I am hesitant to purchase a new audio panel for my > Tundra from this very popular intercom manufacturer. What if the same > guy designed this product too ? > ________________________________________________________________________________
Date: Aug 07, 2008
Thanks for the reply A comment and an additional question. I noticed the battery contactor only works with the large post opposite the small post connected to positive and does not work with the other large post connected to positive (i.e.. flip flopping the positive) This does not seem to be the case for the starter contactor, it seems to work with either post connected to positive. Is there a reason for this? ----- Original Message ----- From: "Robert Borger" <rlborger(at)mac.com> Sent: Thursday, August 07, 2008 10:01 AM Subject: Re: AeroElectric-List: relay wiring question > > Jerry, > > The 12 volt cable from the battery to the battery contactor also provides > the power to the contactor. You run a wire from the single small terminal > to your master switch and another wire from the master switch to ground. > The master switch then provides ground to complete the circuit and > activate the contactor. > > The starter relay requires that 12 volts be supplied to the small terminal > for the relay to activate. Yes, ground is through the case. If your > aircraft is composite or tube and fabric construction then you should run > a ground wire from the case mount bolt to the firewall ground block. If > your aircraft is aluminum ground should be available directly from the > airframe. > > I hope this helps, > Bob Borger > Europa XS, Rotax 914, Airmaster C/S prop > http://www.europaowners.org/N914XL > > On Thursday, August 07, 2008, at 08:27AM, "Jerry Ricciotti" > wrote: >>I am looking for the proper way to wire my battery and starter contactor. >> >>I have a Spruce bought battery contactor, which is a White-Rodgers Type 70 >>DC power contactor. I expected to see two large posts and two small posts >>on the unit but it has only one small post. The manufactures web site >>refers to this as a "Terminal Type 3B - Coil Common to Load" . I want to >>confirm how to properly wire this to my DPDT master switch, the >>manufacturers diagram shows a pig tail to the small post from large post >>that is connected to battery positive. I assume I wire from that large >>post to the master switch and the back to small post on the contactor. >>There is no connection from the master switch to ground in this case? >> >>Part 2 >>I have B&C starter relay, it also has only one small post. >>I assume that it is grounded through it's own case and I should bring >>positive line through the starter switch and back to the small post and >>then pig tail a ground wire from the case mounting bolt to the firewall >>ground? >> >>Thanks in advance for your help. >> Jerry > > > ________________________________________________________________________________
Subject: SD-20 repairable?
Date: Aug 07, 2008
I had a secondary buss failure in the last couple of day. Tracked it back to the alternator and SD-20. After some simple debugging, I decided to see if I could see anything move inside it when I turned the engine over by hand. While the ratio is pretty small, I could detect no movement. Further I found that the cooling fins that I could see where moveable with a simple small pointy tool inserted in the back of the unit while it was still attached to the engine. Long story short, after removal, I found that the input spline shaft was intact (all of it's teeth there), but it freely spins and it's obvious that it's not attached to the central armature of the SD-20 any longer. Are these things serviceable? I called B&C, but no tech people until Monday due to travel back from OSH. Thot I'd ask here? Thanks in advance, Alan Adamson Atlanta, Ga ________________________________________________________________________________
Date: Aug 07, 2008
Hi Jerry, The reason is on the starter relay, the coil is activated by a positive voltage to the small terminal and the case is grounded. It has nothing to do with the large terminals. On the contactor, one side of the coil is connected to one of the large terminals (BAT). The other side is connected to ground through the master switch. If you connect the large terminals backwards, then one side of the coil is NOT connected to the battery and you can't activate the coil. You have to get 12V across the coil to activate the contacts on both devices. Look at the attached drawing and it should be easy to see why you can't switch the large terminals on the contactor. Bob W. "Jerry Ricciotti" wrote: > > Thanks for the reply > > A comment and an additional question. > I noticed the battery contactor only works with the large post opposite the > small post connected to positive and does not work with the other large post > connected to positive (i.e.. flip flopping the positive) > This does not seem to be the case for the starter contactor, it seems to > work with either post connected to positive. > > Is there a reason for this? > > > ----- Original Message ----- > From: "Robert Borger" <rlborger(at)mac.com> > To: > Sent: Thursday, August 07, 2008 10:01 AM > Subject: Re: AeroElectric-List: relay wiring question > > > > > > Jerry, > > > > The 12 volt cable from the battery to the battery contactor also provides > > the power to the contactor. You run a wire from the single small terminal > > to your master switch and another wire from the master switch to ground. > > The master switch then provides ground to complete the circuit and > > activate the contactor. > > > > The starter relay requires that 12 volts be supplied to the small terminal > > for the relay to activate. Yes, ground is through the case. If your > > aircraft is composite or tube and fabric construction then you should run > > a ground wire from the case mount bolt to the firewall ground block. If > > your aircraft is aluminum ground should be available directly from the > > airframe. > > > > I hope this helps, > > Bob Borger > > Europa XS, Rotax 914, Airmaster C/S prop > > http://www.europaowners.org/N914XL > > > > On Thursday, August 07, 2008, at 08:27AM, "Jerry Ricciotti" > > wrote: > >>I am looking for the proper way to wire my battery and starter contactor. > >> > >>I have a Spruce bought battery contactor, which is a White-Rodgers Type 70 > >>DC power contactor. I expected to see two large posts and two small posts > >>on the unit but it has only one small post. The manufactures web site > >>refers to this as a "Terminal Type 3B - Coil Common to Load" . I want to > >>confirm how to properly wire this to my DPDT master switch, the > >>manufacturers diagram shows a pig tail to the small post from large post > >>that is connected to battery positive. I assume I wire from that large > >>post to the master switch and the back to small post on the contactor. > >>There is no connection from the master switch to ground in this case? > >> > >>Part 2 > >>I have B&C starter relay, it also has only one small post. > >>I assume that it is grounded through it's own case and I should bring > >>positive line through the starter switch and back to the small post and > >>then pig tail a ground wire from the case mounting bolt to the firewall > >>ground? > >> > >>Thanks in advance for your help. > >> Jerry > > > > > > > > > > > > > -- N93BD - Rotary Powered BD-4 - http://www.bob-white.com 3.8 Hours Total Time and holding Cables for your rotary installation - http://roblinstores.com/cables/ ________________________________________________________________________________
Subject: Flightline FL-760 Tranceiver and Sigtronics SPA-400
Intercom
Date: Aug 08, 2008
I have a very, very strange issue that has to do with the FL-760 radio and the Sigtronics SPA-400 intercom. Here is the installation: Pilot's head set and PTT, and Co-pilot's headset and PTT are wired to the intercom with shielded cable. There are three wires from the intercom to the FL-760; audio out (mic to radio), audio in (from radio to intercom) ad transmit. Connection between the radio and intercom is through a Molex connector. Power to the radio and intercom are from a single avionics switch. The avionics switch goes to a terminal strip and there are separate power wires to the intercom and radio. The intercom and radio each have a power switch on them. Here is the problem: If the intercom is plugged into the radio and I turn on the avionics switch, and then the radio switch, the radio turns on (I can transmit and receive) but the LCD display does not come on. It does not matter the state of the intercom power switch. If the intercom is plugged into the radio and I turn on the radio switch, and then the avionics switch, the radio turns on (I can transmit and receive) and the LCD display comes on! It does not matter the state of the intercom power switch. If the intercom is not plugged into the radio, the radio LCD display comes on regardless of the power switch sequence. I can't see any connection at all between the LCD display and the intercom, but there obviously is one! This has me completely stumped, so if anyone has any ideas, I'll give anything a try!! Thanks!! -------- Chris Smith N694CS www.cleanex.cmsdreams.com Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197288#197288 ________________________________________________________________________________
Date: Aug 08, 2008
Subject: Fraudulent Purchase attempt (Off Topic)
Eric, I have a small business and was also a "victim" of this style fraud. They wanted about $500 worth of "bearings" that I sell. They used a third party phone conversation. They provided a "good" charge card and promised the same deal. But then, said they could not come by and pick the order up. Would I send it FED X to the address given. When I called Fed X, they said it was going to Nigeria with out me even giving them the complete address. They turned me over to their fraud division of Fed X and they confirmed it was a scam. They said I should call the FBI here in Tampa and report it. The FBI said that they get about 10 to 20 a day reported to them. I thank Fed X for the heads up. BTW, the credit card will go through as a good transaction but the charge will be declined later as the card will be found to be stolen. Your are then out of the merchandise and freight charges. Been there, done that Glad you were not "had" by the scum of the world. Also, most of these scams originate in Nigeria. Jim Nelson N15JN leaking tank-- ____________________________________________________________ Click here for free info on Graduate Degrees. http://thirdpartyoffers.juno.com/TGL2141/fc/Ioyw6i3nNPPsIHgZAnN0gGTzFdIuVlBbx6TH3q1cDwtK6doEMCrZ7D/ ________________________________________________________________________________
Subject: fwf wiring questions...
Date: Aug 08, 2008
1) Alternator. Is it normal\ok to run the alt-field line along the same route as the heavy gauge power output line from the alternator, along the underside of the engine around the top of the sump? (my case: rv7/io360) 2) What is typically used for small gauge connections under the cowl? For instances, leads to rpm sensor, fuel flow, etc solder, butt-splice, small fastons? Also fwf, my direct crank sensor has a 2-pair shielded line that needs to be joined. Is 9-pin D-Sub ok fwf? or should I just KISS and splice... Don ________________________________________________________________________________
Date: Aug 08, 2008
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)cox.net>
>Afternoon, Jeff... > > >>I would expect a "sales" answer to a call like this :-( << > >Excuse me for inserting my two cents here, but I think I have something to >offer as well. > >I doubt very much that you would get a salesmen's type of reply to any >call you make to Brad. Tom and Brad ARE Emagair ... not salesmen or >support staff. Even though, come to think of it, they also ARE salesmen >AND the support staff. And the designers, and the technicians...well you >get the picture. > >A more helpful and knowledgeable couple of guys I've never run across with >any company. They would not pull any punches or give you any false >information about their products. No one, either in their company or >users, knows their products better than they do, and in this case, I >relying on information from "An outsider who has seem the schematics and >heard the behind the scenes stories" would not be as informed or helpful >as Brad would be. > >Excellent company to do business with... > >As far as user stories, I think there are some here in the archives if you >want to search for them...maybe also in the Canard-Aviators Yahoo group, >if you belong to that as well. Thank you Harley, you beat me to it. I'll confirm that Emagair is a very small company, Brad, Tom (and when I was there) one other fellow who helped out in a variety of tasks. They were forthcoming about their design and business philosophies and willing to share their knowledge. If you have any questions, I'll suggest you e-mail so that they can work you in as time becomes available. I've not heard from them on my questions of several days ago . . . but they just got back from OSH and probably have dozens of items in their mailbox. If anyone has a pressing issued (broken airplane) then by all means call. You won't be disappointed in the treatment you receive. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2008
Subject: Re: SD-20 repairable?
>I had a secondary buss failure in the last couple of day. Tracked it back >to the alternator and SD-20. After some simple debugging, I decided to >see if I could see anything move inside it when I turned the engine over >by hand. While the ratio is pretty small, I could detect no >movement. Further I found that the cooling fins that I could see where >moveable with a simple small pointy tool inserted in the back of the unit >while it was still attached to the engine. > >Long story short, after removal, I found that the input spline shaft was >intact (all of it's teeth there), but it freely spins and it's obvious >that it's not attached to the central armature of the SD-20 any longer. > >Are these things serviceable? I called B&C, but no tech people until >Monday due to travel back from OSH. It sounds like the shear section on your spline shaft has opened up. Yes, that's imminently repairable. Bob . . . ________________________________________________________________________________
Date: Aug 08, 2008
Thanks for the reply A comment and an additional question. I noticed the battery contactor only works with the large post opposite the small post connected to positive and does not work with the other large post connected to positive (i.e.. flip flopping the positive) This does not seem to be the case for the starter contactor, it seems to work with either post connected to positive. Is there a reason for this? Nothing special . . . it's the factory's way of accommodating a variety of design goals for incorporating the device into an electrical system. I'll refer you to the 3rd and 4th pages of the .pdf catalog for the 70 series contactors from Stancor: http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_70-Series.pdf Note that the 4-terminal device features no internal coil connections. This is the style contactor I used to offer (B&C still does) as "universal" to the task of battery contactor, cross-feed contactor, hydraulic pump contactor, alternator b-lead contactor, etc. In all these instances, the little terminals and fat terminals are interchangeable. In cases where you want to purchase a bunch of contactors for use as a battery contactor only, then they'll be pleased to sell you a version wherein one coil connection is tied to a fat terminal. Obviously, one of the fat terminals needs to be designated "BATTERY" and if you look at the contactor shell, this terminal will be labeled "BAT" or "BATTERY". This leaves you but one wire to hook up to the battery master that pulls the free end of the coil to ground to energize the contactor. This feature can be used in a variety of applications where "pull to ground" control is desired. Just connect the BAT terminal to power source and the other terminal to supply the load. If you want to use the contactor in a "pull to bus" situation, you can also purchase a version where one end of the coil is internally connected to contactor case. Now, the fat terminals are still interchangeable but attention must be paid to the small terminal(s) where one will be internally connected to case. This wiring convention is quite common in intermittent duty, starter contactors. ---------------------- On Thursday, August 07, 2008, at 08:27AM, "Jerry Ricciotti" wrote: I am looking for the proper way to wire my battery and starter contactor. I have a Spruce bought battery contactor, which is a White-Rodgers Type 70 DC power contactor. I expected to see two large posts and two small posts on the unit but it has only one small post. The manufactures web site refers to this as a "Terminal Type 3B - Coil Common to Load" . The term "3B" comes from the schematic description of functionality from the 4th page of the above catalog excerpt. In this case, your coil suppression device would go between the small terminal and the one marked "BAT" as opposed to the externally jumpered wiring depicted in: http://www.aeroelectric.com/Pictures/Contactors/s701-1.jpg I want to confirm how to properly wire this to my DPDT master switch, the manufacturers diagram shows a pig tail to the small post from large post that is connected to battery positive. I assume I wire from that large post to the master switch and the back to small post on the contactor. No, you wire the battery to the BAT terminal of the contactor and take a single wire from the small terminal through your battery master switch to ship's ground. This is illustrated in all of the z-figures. There is no connection from the master switch to ground in this case? Yes there IS a master switch ground connection . . . as shown in the z-figures. Part 2 I have B&C starter relay, it also has only one small post. I assume that it is grounded through it's own case and I should bring positive line through the starter switch and back to the small post and then pig tail a ground wire from the case mounting bolt to the firewall ground? Yes, except if you have a metal firewall, there's no need for an extra ground between the mounting flange and the firewall ground. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Subject: Re: Fraudulent Purchase attempt (Off Topic)
Date: Aug 08, 2008
And let's not forget the Western Union payment to the consolidator. WU takes only cash in hand...no CCs or checks. That $230.00 would have come out of my pocket. Eric -------- Eric M. Jones www.PerihelionDesign.com 113 Brentwood Drive Southbridge, MA 01550 (508) 764-2072 emjones(at)charter.net Read this topic online here: http://forums.matronics.com/viewtopic.php?p=197374#197374 ________________________________________________________________________________
Date: Aug 08, 2008
I discovered a diagram I'd published a few years ago at: http://aeroelectric.com/Pictures/Schematics/Contactors_PU_and_PD.pdf In this drawing, you see the control paths for the classic "pull down" to ground control of battery contactor (shown in red) and the "pull up" to bus control typical of starter contactors (shown in green). I've also published a one-pager on the three common contactor wiring conventions at: http://aeroelectric.com/Pictures/Schematics/Contactor_Wiring_Conventions.pdf Bob . . . ________________________________________________________________________________
Subject: Alternator part number?
Date: Aug 08, 2008
On the way back from Oshkosh to Florida my alternator died (lasted 2 years).? Switched off the main bus and ran the E bus all the way home (thanks Bob N.).? It was a 35 amp externally regulated part #14184.? Anyone out there know what the part number is for the same type of alternator?except in?55 amp unit externally regulated? Eddy Fernandez RV9A 300 TT ________________________________________________________________________________
Date: Aug 08, 2008
Subject: Re: fwf wiring questions...
> >1) Alternator. Is it normal\ok to run the alt-field line along the >same route as the heavy gauge power output line from the alternator, >along the underside of the engine around the top of the sump? (my >case: rv7/io360) Sure >2) What is typically used for small gauge connections under the >cowl? For instances, leads to rpm sensor, fuel flow, etc solder, >butt-splice, small fastons? The no-arguments best joining of wires happens with permanent splices of some variety . . . .crimped or soldered. The automotive experience with under-the-hood connectors has been a mixed bag . . . but sealed connectors over the past 15 years or so seem to hang in there quite well. Problem is that these critters are not easy to get in small end-user quantities . . . nor are the installation tools cheap. There's a host of options that range from permanent solder lap joints (how often do you expect to open these joints?) as shown at: http://aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html > Also fwf, my direct crank sensor has a 2-pair shielded line >that needs to be joined. Is 9-pin D-Sub ok fwf? or should I just >KISS and splice... . . . I'd consider lap-solder-and-shrink for this important signal path. I'm aware of no reasonably priced, easily acquired crimp connector/tools combination that would be very attractive. Hirose makes a line of solderable connectors which are very small and environmentally pretty tight. See: http://www.hirose.co.jp/cataloge_hp/e11000216.pdf You can get these from Digikey.com http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=HR1598-ND http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=HR1583-ND A mated pair will set you back about $25. A d-sub with metal backshells would probably work well for you also. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 08, 2008
Subject: Re: Alternator part number?
>On the way back from Oshkosh to Florida my alternator died (lasted 2 >years). Switched off the main bus and ran the E bus all the way home >(thanks Bob N.). It was a 35 amp externally regulated part >#14184. Anyone out there know what the part number is for the same type >of alternator except in 55 amp unit externally regulated? I'm wondering if that was originally an externally regulated unit. There's a lot of not terribly favorable traffic that comes up on a Google search about that part number as a Van's supplied alternator. There's a 'stock', probably internally regulated version offered on Ebay right now: http://tinyurl.com/6crakr It appears to be an older, external fan ND. If yours runs externally regulated, then do you know who might have modified it to bypass the internal regulator? About any of the more modern, internal fan ND alternators would mechanically adapt to your installation and are pretty easy to acquire up to at least 60A output. If you're presently using external regulation, you have a choice of changing over to keep the internal regulator that will certainly come with the alternator, or to embark upon an external regulator mod-program that's not terribly hard to do. That same supplier on Ebay is offering a wide variety of alternators that are sure to include a 50-60 amp machine in the more modern frame. You might drop them an email and inquire. For example, this item http://tinyurl.com/5bu25h is a husky looking ND product and I can't see a fan so it might be an attractive alternative to the device you have installed at the moment. They talk about "custom" reman . . . they might be willing to supply you an alternator with the regulator already by-passed. Bob . . . ________________________________________________________________________________
Date: Aug 09, 2008
Subject: I-Phone Inclinometer
My partner just showed me the 2 axis Inclinometer on his I-Phone. Curious if one can use it as emergency attitude indicator? Degree wheel for roll, pitch you would use the less definitive widening line? Anyone want to give it a try? Ron P. ________________________________________________________________________________
Date: Aug 08, 2008
Subject: Re: I-Phone Inclinometer
Would you suppose it uses force or acceleration sensors for this data. I did a minor amount of googling to try to learn that.. If force, I doubt it would provide reliable pitch and roll data - just like the 'ball' doesn't provide bank angle while in coordinated flight. Even if it's a mems gyro I suspect for that application, very little effort would have been made to cancel out drift rates. I'd be happy to be wrong, however... Matt- > > My partner just showed me the 2 axis Inclinometer on his I-Phone. > > Curious if one can use it as emergency attitude indicator? Degree wheel > for roll, pitch you would use the less definitive widening line? > > Anyone want to give it a try? > > Ron P. > > ________________________________________________________________________________
Date: Aug 08, 2008
Won't work because it doesn't have a gyro. Would get fooled just like a weight on a string. RF -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of rparigor(at)SUFFOLK.LIB.NY.US Sent: Friday, August 08, 2008 8:20 PM Subject: AeroElectric-List: I-Phone Inclinometer My partner just showed me the 2 axis Inclinometer on his I-Phone. Curious if one can use it as emergency attitude indicator? Degree wheel for roll, pitch you would use the less definitive widening line? Anyone want to give it a try? Ron P. ________________________________________________________________________________
Subject: Re: BnC Continuous Duty Contactor 12 v
Date: Aug 09, 2008
Jeff wrote:"I am using it as a battery contactor but with a Very High out alternator, 200amps ..... So I am thinking I need to find a bigger contactor ? or my other thought - guess was maybe to run TWO Stancor 70-902 contactors in parallel ? with the extra wires also... but concern here is that something I haven't thought of will smoke something if both are not closed ? Maybe I am overlooking a simple cheaper solution...." Jeff,The size of the alternator has nothing to do with the current rating of the battery contactor. The ampacity of the battery contactor should be determined by the engine starting current and by the battery charging current. These two currents are the only significant currents normally flowing through the battery contactor. Even if you have a very large load such as an electric cockpit heater, that current would flow directly from the alternator to the heater without going through the battery contactor. Just because the alternator is rated at 200 amps does not mean that it will be supplying that much. The alternator will only be putting out that current which is needed to operate the loads that are turned on, most likely only a fraction of the alternator's ampacity. I would use the same battery contactor regardless of the alternator size.Joe Gores ________________________________________________________________________________
Date: Aug 09, 2008
>Jeff wrote: > >"I am using it as a battery contactor but with a Very High out alternator, >200amps ..... So I am thinking I need to find a bigger contactor ? or my >other thought - guess was maybe to run TWO Stancor 70-902 contactors in >parallel ? with the extra wires also... but concern here is that something >I haven't thought of will smoke something if both are not closed ? Maybe I >am overlooking a simple cheaper solution...." Interesting! Help us understand a bit more about your proposed system. Under what conditions would you expect your 200A alternator to deliver this kind of power. In other words, what design goals for the vehicle drove the selection of this size machine? > > >Jeff, > >The size of the alternator has nothing to do with the current rating of >the battery contactor. The ampacity of the battery contactor should be >determined by the engine starting current and by the battery charging >current. These two currents are the only significant currents normally >flowing through the battery contactor. Even if you have a very large load >such as an electric cockpit heater, that current would flow directly from >the alternator to the heater without going through the battery >contactor. Just because the alternator is rated at 200 amps does not mean >that it will be supplying that much. The alternator will only be putting >out that current which is needed to operate the loads that are turned on, >most likely only a fraction of the alternator's ampacity. I would use the >same battery contactor regardless of the alternator size. > >Joe Gores Joe is quite correct. The battery contactor must CARRY, not SWITCH starting currents that include some bodacious inrush currents. Then it must CARRY, not SWITCH the battery recharge currents and/or expected battery discharge currents during alternator-out operations. The 80-amp, lowly 70 series devices have given good service. But let's be sure that we're not giving you marginal advice. Do you also plan a big battery? If the battery is "up-sized" in concert with a larger alternator, then it follows that your system MIGHT be capable of extra- ordinary stress on the battery contactor . . . like recharging a big battery with you 200A energy source. There are some up-sized contactors not the least of which are the 586 series devices from Stancor. http://aeroelectric.com/Mfgr_Data/Contactors/Stancor-WhiteRogers/Stancor_586-Series.pdf . . . but we don't have enough information about your design goals to make confident recommendations. Bob . . . ----------------------------------------) ( . . . a long habit of not thinking ) ( a thing wrong, gives it a superficial ) ( appearance of being right . . . ) ( ) ( -Thomas Paine 1776- ) ---------------------------------------- ________________________________________________________________________________
Date: Aug 09, 2008
> > >>On the way back from Oshkosh to Florida my alternator died (lasted 2 >>years). Switched off the main bus and ran the E bus all the way home >>(thanks Bob N.). It was a 35 amp externally regulated part >>#14184. Anyone out there know what the part number is for the same type >>of alternator except in 55 amp unit externally regulated? > > I'm wondering if that was originally an externally regulated > unit. There's a lot of not terribly favorable traffic that > comes up on a Google search about that part number as a Van's > supplied alternator. There's a 'stock', probably internally > regulated version offered on Ebay right now: Followup: Another member on the List has turned me on to the following website: http://www.motorcarparts.com/catalog.htm This link takes you to a YMME selection form that may not be of much use in researching alternators. However, stick anything in, like 2000 Honda Accord with 2.3L engine. Then click on "alternator" for that car. This takes you to a cool screen that offers specs and a 3-view for the alternator. Moreover, there's a box on this page for inserting another part number. Pun in your 14184 number and we get an 35A EXTERNALLY regulated ND alternator with three photographic views. Now we know a lot more about the alternator that started this thread. We also know about an information resource that many of you will find valuable in identifying and perhaps integrating certain kinds of alternators into your projects. This website also offers a technical bulletin against that alternator which speaks to the need to retain the b-lead filter capacitor from your old alternator when replacing it with a new one. It also identifies the functionality the rear mounted receptacle. Pretty cool stuff. Bob . . . ________________________________________________________________________________
Date: Aug 09, 2008
Subject: need a tool spec on vacation
I'm at the beach and Tower informs me my transponder has quit working (again!) I am 99% sure from past trouble with this thing that I can fix it by removing, cleaning and reinstalling the Garmin adapter in the Narco tray, but need a foot-long Allen wrench to reach in there, and don't have it with me. One can buy most anything at the beach these days, but I need the size to look for at the hardware store: what is the dimension of the hex screw that holds radios in avionics trays? 3/32"? Thanks for the help. I'm sure they'll let me back out of the class D with an inop transponder, but it's just not right having stuff not functioning. -Stormy / Bill B. ________________________________________________________________________________
Date: Aug 09, 2008
3/32 is correct. Allen -----Original Message----- From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com]On Behalf Of Bill Boyd Sent: Saturday, August 09, 2008 6:13 PM To: rv-list(at)matronics.com; aeroelectric-list(at)matronics.com
July 25, 2008 - August 09, 2008
AeroElectric-Archive.digest.vol-ia
